RV-Archive.digest.vol-te
December 10, 2007 - December 26, 2007
      ----- Original Message -----
From: "Michael Kraus" <n223rv(at)wolflakeairport.net>
Sent: Monday, December 10, 2007 7:01 AM
Subject: Off Topic: Hanger Lighting
> > > I am building a new hanger on my house and was looking for information on > what type of hanger lighting to install. The ceilings will be 16' tall > and it is 44' x 60'. I would like good work lighting throughout. Also, > if anyone knows of the light spacing it would help. > > Thanks > -Mike Kraus > RV-4 Flying > RV-10 wiring > > > -- > 12/9/2007 11:06 AM > > ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Re: Off Topic: Hanger Lighting
I just read through all the replies to this post and being an electrician, here is my .02. I would not mount the fixtures at 16 feet. The light amount does disperse geometrically. Use fixture chain and lower the fixtures to 12 inches above the rudder or highest point of the aircraft. Consider that you will have to change the lamps sooner or later. If unheated, use cold weather ballasts. Reflectors make a big difference unless you like lighting the ceiling. If you will be doing a lot of maintenance, consider mounting a row of lights on each side of the hangar walls horizontally at about 4 feet from the floor. All the light in the world shining down will not light up the area under the wings or cockpit (as in a Cessna172). A floor paint will help with reflectivity but it is more for easy clean up as in an oil spill, which I have never done. :D I reiterated a lot of comments here, just reaffirming what has been said. Dave --- Michael Kraus wrote: > > > > > I am building a new hanger on my house and was > looking for information on what type of hanger > lighting to install. The ceilings will be 16' tall > and it is 44' x 60'. I would like good work > lighting throughout. Also, if anyone knows of the > light spacing it would help. > > Thanks > -Mike Kraus > RV-4 Flying > RV-10 wiring > > > > > Click on > about > Admin. > > browse > Un/Subscription, > FAQ, > > Forums! > > > > > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Dec 10, 2007
> > ? - Why wouldn't the 65 watt fluorescent units that you talk about below > suffer > from the same effects (or is it affects)? > > Regards, > /\/elson > [Tim] They still get brighter as they warm up but they don't flicker like the 8 foot fluorescents do. 4 foot fluorescents don't really flicker to bad, but these lights use a lens that helps get the light down. They say they are equivalent to a 500 watt but it is only 65 watts of power. I like them except for they are hard to mount on a flat ceiling. ________________________________________________________________________________
Date: Dec 10, 2007
Mike, I agree with what Mike Humphrey said. I have a 26' x 32' detached garage that I use solely to build my -8 with. It has a 10' ceiling and the interior is all painted white. I have (9) 8' dual bulb T-12 fixtures and it is ample lighting. I have no problems at all with the lights coming on all the way down into the 20's F. However, I have had to replace one ballast at a cost of $43 after only 2 1/2 years though. I would still do the same thing again... I know a guy who works for a large tire manufacturer. He said his company paid a lighting consultant come in and come up with ideas to lower their lighting expenses. He said the guy came in and walked all through the plant looking at the facility. In the end, he asked what the highest level was that their tallest forklift would reach. They gave him their answer, (I don't recall what it was) and his solution was to lower all the fixtures to within 2' of the tallest forklift reach, then turn off half their lights... Bill Settle -8 Wings (Still) Winston-Salem, NC ----------- Original message from "mike humphrey" : -------------- > > Mike, > In my hanger I have the T-12 cold weather 8' units. Great lighting, work in > cold fine, easy to replace, just started replacing bulbs after 3 1/2 years > continual use, pricey but great lighting. Lowe's carries the 8' fixture and > bulbs(green ends and they just push in, no twisting). In my work areas I > have added specific lighting to the situation. Bandsaw, lathe, drill press > (dangerous areas) have separate lighting on switches. I would not hang any > lighting on the 16' ceiling though. Lighting disperses geometrically. So > whatever lighting that you choose, suspend it from some cheap chain and > lower it to about 2-3 feet above your highest point on the floor, ie tail of > plane. Reflectors are cheaper than lighting units and you will save > electricity which equals $. More $ to spend on RV's. Remember, whatever > lighting that you put in, you will not want to replace anytime soon, if > ever, by lowering your units, maintenance will be easier also, unless you > just happen to have a 16' step ladder. > Mike H > 9A/8A > ----- Original Message ----- > From: "Michael Kraus" > To: > Sent: Monday, December 10, 2007 8:01 AM > Subject: RV-List: Off Topic: Hanger Lighting > > > > > > > > > > I am building a new hanger on my house and was looking for information on > > what type of hanger lighting to install. The ceilings will be 16' tall > > and it is 44' x 60'. I would like good work lighting throughout. Also, > > if anyone knows of the light spacing it would help. > > > > Thanks > > -Mike Kraus > > RV-4 Flying > > RV-10 wiring > > > > > > > > > > > > > > > > > > >
Mike,
Bill Settle
-8 Wings (Still)
Winston-Salem, NC
----------- Original message from "mike humphrey" <mike109g6(at)insideconnect.net>: --------------
> --> RV-List message posted by: "mike humphrey"
> Mike,
> pla ne. Re flectors are cheaper than lighting units and you will save
> Mike H
> 9A/8A
> ----- Original Message ----- <BR>> From: "Michael Kraus" <N223RV(at)WOLFLAKEAIRPORT.NET><BR>> To:
> > --> RV-List message posted by: Michael Kraus
> > and it is 44' x 60'. I would like good w =====
Subject: Re: Van's foil comm antenna
Date: Dec 10, 2007
I just tested mine today - works as advertised....gonna have it tuned by a bunch of ham guys in the spring..... ----- Original Message ----- From: Lincoln Keill To: RV-list(at)matronics.com Sent: Monday, December 10, 2007 2:33 PM Subject: RV-List: Van's foil comm antenna Has anyone successfully used Van's copper foil comm antenna that mounts on the windscreen...or anyone who would recommend NOT using it? ________________________________________________________________________________
Subject: Van's foil comm antenna
Date: Dec 10, 2007
I've been using one for 11 years. It's cheap, simple, no-drag, and it works. I get plenty of range, and good radio quality. It's got some nicks and scratches on it from people grabbing the center bar, yet no problems. Heck, maybe I'll replace it someday. Ed Bundy -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Lincoln Keill Sent: Monday, December 10, 2007 12:34 PM To: RV-list(at)matronics.com Subject: RV-List: Van's foil comm antenna Has anyone successfully used Van's copper foil comm antenna that mounts on the windscreen...or anyone who would recommend NOT using it? ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Re: Trio EZ-Pilot or Altitude Hold
I don't have answers to all the questions raised in this post but I'll take a stab at some of them. John Jessen wrote: > This thread is interesting to me. I'd not considered the Trio. TT seemed > to be the leader and well liked. I suspect TruTrak is the market leader in volume of units in the field because they have been in the experimental autopilot market longer than anyone except Navaid. They make good products and their market share is deserved. I know the individuals at Trio and their high level of business ethics prevented them from releasing their EZ-Pilot until it was ready for prime time. It was tough for the Trio guys to sit on their baby during development as TT gained market share, but they were determined to release no units before their time. Now I see that many seem satisfied with > the Trio. Why is it if their units are so good (and the pricing seems okay) > and their support very good, that they are not being supported by GRT? I don't have personal background in this particular instance since I don't use GRT equipment. I can tell you that "supporting" a particular autopilot is not necessarily a simple endeavor. It is particularly difficult for the Trio guys because they designed their unit to be compatible with only data that strictly follows standard NMEA protocol. The software designer at Trio has a ballistic missile guidance background and he is *very picky* :-) about having his unit only track pristine data. There have been vendors (not GRT) that have not been able to support the EZ-Pilot because their hardware didn't send standard NMEA AnywhereMap's PDA-based system being a prime example). I suspect the reason GRT has supported TT is due more to marketing and personal reasons than hardware issues. Maybe they wanted to piggyback the company with the largest market share. Why > is it they are not commanding the popular numbers of TT? Less time in the market, fewer ad $$$$$$'s spent, a much smaller product line, which no doubt has resulted in less market inertia. Do they lack > product depth? Guess that depends on your point of view and what you want your autopilot system to do. Is their need for a separate knob and bezel for the altitude > hold unit a drawback? I don't think so. Trio's interface allows the system to offer a huge feature set with only a "separate knob and bezel". :-) > Is it lack of GPSS steering? That is a perceived difference but there is much more to the GPSS steering issue than meets the uneducated eye. I won't delve into that, just to say that for most of us "GPSS" is vastly overrated, and is not unique in an operational sense to TT. Maybe they are just as > popular as TT? Yes, with their customers they are avidly endorsed. What's the deal? Don't know what else I can add beyond what has already been presented in this thread. It is great to have two wonderful vendors of fantastic equipment. Do your homework and chose what is best for your mission profile. Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Subject: Trio EZ-Pilot or Altitude Hold
Date: Dec 10, 2007
I'm not flying yet, so you can take my comments for what they are worth. The feature set and price were consideration, but servo design was the primary selling factor for the Trio. I design aerospace hardware for a living and know that things can and do go wrong. In my opinion, the Trio Servo is the most failsafe servo out there. When the system is powered down (by a real mechanical switch in the control head), the servo is physically disengaged from the control arm. This means that when the system is powered down you're not moving the servo every time you move the stick (maintain control feel). Since the gears between the servo and control arm are held together by an electric solenoid, if you cut power to the system, it disengages. Period. On top of that, there's an adjustable slip clutch instead of a shear pin between the linkage and the servo. This means that if you have to overpower the system, you don't damage the servo. To summarize, despite the popularity and obvious quality of TT I decided Trio had more features for less money. The redundant safety systems in the servo cause me to write the check. Kind Regards, Guy This thread is interesting to me. I'd not considered the Trio. TT seemed to be the leader and well liked. Now I see that many seem satisfied with the Trio. Why is it if their units are so good (and the pricing seems okay) and their support very good, that they are not being supported by GRT? Why is it they are not commanding the popular numbers of TT? Do they lack product depth? Is their need for a separate knob and bezel for the altitude hold unit a drawback? Is it lack of GPSS steering? Maybe they are just as popular as TT? What's the deal? John Jessen ________________________________________________________________________________
Date: Dec 11, 2007
Brian I'd avoid this route as this is exactly what I've done. the color from the cheap mercvapor lighting is an awful yellow that distorts all color perception. although the light was bright enough, i actually got headaches from the poor light color after long periods of exposure. i haven't changed them out yet, but i have lined the perimeter of the hangar with 4ft fluorescent fixtures and it has made a huge difference. perhaps the best lighting solution is a marriage of different technologies. of coarse your mileage may vary... steve dinieri Iflyrv10.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Meyette Sent: Monday, December 10, 2007 10:13 AM Subject: RE: RV-List: Off Topic: Hanger Lighting What was suggested to me as the cheapest and simplest way to get good lighting is to use those mercury vapor yard lights. You can just tape over the light sensor, or I rewired mine around the sensor. Lots of light, they only cost about $25 each, and they are not sensitive to cold as fluorescents are. brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Monday, December 10, 2007 8:02 AM Subject: RV-List: Off Topic: Hanger Lighting --> I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring 11:06 AM 11:06 AM ________________________________________________________________________________
Date: Dec 11, 2007
Just to be correct, mercury vapor lights have a bluish light. If the light is a deep yellow, it is a low pressure sodium light. If the light is almost white with a yellowish tint, it is a high pressure sodium light. Dave --- Steven DiNieri wrote: > > > Brian > I'd avoid this route as this is exactly what I've > done. the color from the > cheap mercvapor lighting is an awful yellow that > distorts all color > perception. although the light was bright enough, i > actually got headaches > from the poor light color after long periods of > exposure. i haven't changed > them out yet, but i have lined the perimeter of the > hangar with 4ft > fluorescent fixtures and it has made a huge > difference. perhaps the best > lighting solution is a marriage of different > technologies. > of coarse your mileage may vary... > steve dinieri > Iflyrv10.com > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of Brian Meyette > Sent: Monday, December 10, 2007 10:13 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Off Topic: Hanger Lighting > > > > What was suggested to me as the cheapest and > simplest way to get good > lighting is to use those mercury vapor yard lights. > You can just tape over > the light sensor, or I rewired mine around the > sensor. Lots of light, they > only cost about $25 each, and they are not sensitive > to cold as fluorescents > are. > brian > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of Michael Kraus > Sent: Monday, December 10, 2007 8:02 AM > To: rv-list(at)matronics.com > Subject: RV-List: Off Topic: Hanger Lighting > > --> > > > > I am building a new hanger on my house and was > looking for information on > what type of hanger lighting to install. The > ceilings will be 16' tall and > it is 44' x 60'. I would like good work lighting > throughout. Also, if > anyone knows of the light spacing it would help. > > Thanks > -Mike Kraus > RV-4 Flying > RV-10 wiring > > > > > > > 11:06 AM > > > 11:06 AM > > > > > > > > > > Click on > about > Admin. > > browse > Un/Subscription, > FAQ, > > Forums! > > > > > Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 11, 2007
> autopilot is not necessarily a simple endeavor. It is particularly > difficult for the Trio guys because they designed their unit to be > compatible with only data that strictly follows standard NMEA > protocol. > The software designer at Trio has a ballistic missile guidance > background and he is *very picky* :-) about having his unit only > track > p Sam and others, >From what I have seen the NMEA sentences are not properly defined in the first instance and are interpreted differently by just about every manufacturer. Because of these differences most software that reads NMEA sentences (or any other nav data for that matter) must be validated with each sending device one by one. The differences are not just the sentence structure (when does a null value mean zero, is an integer 0 the same as a float zero 0.0) where well tested bullet proof software is necessary to be able to parse all manner of data variants. Some of these differences can be very subtle. Though not NMEA related I have personally seen a navy frigate nav system fail because it received a heading of 360.0 degrees rather than 0.0 degrees. There are well documented incidents of nav failures when aircraft have crossed the International Date line. Did you know some GPSs will send data for more than 12 satellites - ambiguous in NMEA and in the manufacturers spec but only discovered when the constellation grew. You don't want your system to crash when satellite #13 shows up in the messages. There are also significant dynamic differences between GPSs. Each GPS chip-set manufacturer implements it's own proprietary (and secret) algorithms. This will include the type and nature of the filtering and these factors will significantly alter the interaction between a GPS and say an autopilot. For example it is reasonably clear how the cross track error responds along a straight course segment, but what about near to or transiting through a way point. How does the smoothing algorithm alter this behaviour. Also another factor - what about a reduced satellite signal strength (sunspots/antenna preamp problems/out of band interference) impact on position error and resulting tracking performance. Garmin is pretty lean with specifications on their products performance and are no better than any other chip-set maker at specifying how the dynamics work. This makes it pretty difficult for an auto pilot or alt hold manufacturer to make GPS coupling work well with any NMEA source. Even then each will require considerable testing. IF GRT and TRIO are as reputable as people are reporting I am not surprised that we do not see immediate support. Perhaps it will come when they have the interfaces properly specified between themselves. 'nuf said, rant over. Doug Gray ________________________________________________________________________________
Date: Dec 11, 2007
Ok, I would like to chime in on yet another subject I know NOTHING about! I own a 50' x 50' hangar (2500 square feet) and it came with lighting that was detailed in Jim's email: http://www.businesslights.com/high-bay-metal-halide-fixtures-c-277_477.h tml My unit has only 4 of these lights hung very high in the rafters (probably 25' high ceilings) and it is plenty of light for that space. Frankly I was surprised to see how inexpensive they were listed as I always assumed they were more expensive that that. While I have read and understand that lowing the lights is the proper decision for some styles of lights if one goes into a Costco you see these lights suspended all the way up the very top of the store, well clear of any equipment or storage needs. I assume they know what they are doing in placing these lamps that high. The drawback to these lights is that they do not turn on instantly. When I flip the switch I get annoyed that I don't have instant light but before I think about it a second time the lights are fully on. I have no idea how energy efficient these lights are but I am a satisfied owner for both amount or light and light quality. 4:30 am, Can't sleep, Robin RV-4 Sold RV-6A 400 Hours RV-10 BPE Engine arrived ________________________________________________________________________________
Date: Dec 11, 2007
Subject: Re: Wheel Pants fairings
At 05:18 PM 12/10/07, you wrote: > >Hi: > >I asked this before, but I did not get complete info. > >After seeing the prices on Van's, Over $200 and a fellow builder more >than $300.... It is for us to steep.... If you think this is expensive, try buying a set for a DR-107 One Design! To really save money, make your own. Of course, you don't need them at all to fly. Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Date: Dec 11, 2007
I tried it, very poor reception, both in the air and ground. Went with a standard antenna on the bottom of the fuselage. Bob RV6 "Wicked Witch of the West" At 01:33 PM 12/10/07, you wrote: >Has anyone successfully used Van's copper foil comm antenna that >mounts on the windscreen...or anyone who would recommend NOT using it? ________________________________________________________________________________
Date: Dec 11, 2007
Living in a residential airpark I've got to see a variety of lighting. All of the hangars on my street are the same dimensions, 45'x40', 15' ceilings. Stock lighting was 6 -2 bulb 4' flourescent fixtures. This is inadequate. One of my neighbors went with 6 -4 bulb 4' fixtures and this improved things greatly but still wasn't ideal. By far the best lighting I've seen is large Halogen fixtures. My next door neighbor has them and his lighting is unequalled. Another followed his lead but added a couple of extra fixtures. He has light. Another huge factor is the floor. My floor is epoxy and gray in color with a slight gloss finish. My next door neigbor (with the halogens) floor is tan, leaning toward a more yellowish tint with very little gloss. Although the lights are white the hangar has a yellowish tint when the lights are on. The other neighbor who added halogens has a light blue floor with light gloss. He has the best lighting on the block. If doing again, I'd go with the halogens despite the added cost. The lighting is incredible. The fixtures hang down from the ceiling making bulb changes although my neighbor hasn't had any bulb failures in 6 years. Good lighting makes things so much nicer. I'm going to go with the halogens before next summer. Darwin N. Barrie Chandler AZ RV7 N717EE ________________________________________________________________________________
Date: Dec 11, 2007
I built my shop several years ago and wrestled with the lighting issue. I tried several and have finally settled on using "brood Lights" with the clamp removed, that I got at Lowes, They are single lamp screw base fixtures that have a 10" aluminum reflector. I installed eight 4x4 outlet boxes on the ceiling of the 35'x40 shop for a total of 32 lights. I use the 20' cords that the lamps come with to suspend them over each of my work areas. I can drop them down to just above the table top of a work table or pull them up over the main parking bay to clear my truck... I have each outfitted with a 9-27 watt standard CFL bulb and they are switched in banks of 8. I use the cheap plastic work clamps and/or a zip tie to clip the wire to a conduit over where I need the lamp and have screwed 16" long sections of 4" PVC pipe to the ceiling to roll up the excess cordage and stuff it into to get it out of the way. While I was wiring I also installed 8 ea. quad outlet boxes on #10 AWG 3 cond. SO cord that drop to the floor from the ceiling for outlets in the shop. I'll post some photos of the setup on my kitlog site http://www.mykitlog.com/n7hqk . I love it! Low cost the CLF's start in the cold and can be purchased cheaply and in various color temps and cost little to run. -------- Ray D. Congdon - N7HQK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=151658#151658 ________________________________________________________________________________
Date: Dec 11, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Bob, Do you have a picture of this contraption? Darrell --- Bob wrote: > > > I tried it, very poor reception, both in the air and > ground. Went > with a standard antenna on the bottom of the > fuselage. > > Bob > RV6 "Wicked Witch of the West" > > At 01:33 PM 12/10/07, you wrote: > >Has anyone successfully used Van's copper foil comm > antenna that > >mounts on the windscreen...or anyone who would > recommend NOT using it? > > > > > > Click on > about > Admin. > > browse > Un/Subscription, > FAQ, > > Forums! > > > > > Looking for last minute shopping deals? ________________________________________________________________________________
Subject: FAA wants input re changes needed
Date: Dec 11, 2007
Have you come across something that's arcane, anachronistic or just plain useless in your travels through the regs? Well, the FAA says it wants to know about it. The agency has issued a Review of Existing Regulations that invites anyone with a beef about how the law of the air is now set to drop them a line. "Getting public comments is a necessary element of our effort to make our regulations more effective and less burdensome," the agency claims in the document. It's asking that you list the top three aggravations in descending order for it to consider. More... ________________________________________________________________________________
Date: Dec 11, 2007
If you think this is expensive, try buying a set for a DR-107 One > Design! To really save money, make your own. Of course, you don't > need them at all to fly. > Wheel pants and gear leg fairings may be the cheapest speed improvement you will do. And the improvement is substantial. Ron Lee ________________________________________________________________________________
Date: Dec 11, 2007
"By far the best lighting I've seen is large Halogen fixtures. My next door neighbor has them and his lighting is unequalled. Another followed his lead but added a couple of extra fixtures. He has light. " I'm just about to tackle the lighting issue myself. Can you give us any more information about the type of halogen fixture you like? I like metal halide a lot, but it's pretty expensive to run and the bulbs are expensive and have a fairly short life. Thanks, Dave ________________________________________________________________________________
Date: Dec 11, 2007
Subject: Nosewheel pant brackets
Folks, I'm trying to verify if the original "two brackets per side" have been replaced by a single bracket per side (U-713C-L and U-713C-R). It should be held on by a single 3/8"x24x3/4" allen screw with washer/lockwasher on each side and hooks around the axel bolt. My understanding is that the new brackets allow easier maintenance without disassembling the nosewheel to fork assembly. Are there other parts in this assembly? My earlier kit does not have the newer parts and I would like to do things easier. I think drawing C2 has probably been updated too...... Thanks in advance, Ralph Capen ________________________________________________________________________________
Subject: Re Trutrac and Trio Cust svc
Date: Dec 11, 2007
I can tell you that Trio Cust Svc is outstanding and that Trutrack customer service is not worth a damn. Charlie Heathco ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Dec 11, 2007
That depends on what type of fluorescent you are using. I have a 40x64 shop/hanger up here in Wisconsin and I use 8 of the 8ft High Output strip lights you can find from your local LowesDepot for about $50. If it drops below 30F it takes them a couple minutes to warm up for full light output but they work fine down into the negative temperatures with no flicker. Again, they MUST be the 110 watt HO type light which are also referred to as "cold start". Another nice thing is they are cheaper to run than most other lighting out there, I believe each fixture is around 1.5 amp. The 8 lights in that space are adequate but two more would probably be perfect. I would also try and get units with a reflector. If you look around on the net you can get HO ballasts and just pick up the el cheapo 8' lights w/reflector and swap the ballast. Michael Sausen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Monday, December 10, 2007 9:29 AM Subject: RE: RV-List: Off Topic: Hanger Lighting If this is not a heated area I would not recommend using the 8' fluorescents. They do not respond as well to colder weather as they flicker. You can use 4' fixtures with light shields (ceiling height) but there are better options. Lowes and Home Depot sell a 65 watt fluorescent area light that is round and has a parabolic type reflective lens. We have many hangars here at our airpark that uses these including mine. A new hangar was just built and 9 of these were spaced out in there which provides excellent lighting in this hangar. The cost for these is around $44each. We have some metal hangars that have very high ceilings and the same light were used but were mounted on a metal extension to get the light down to about 10-12 feet off the floor. I am not an engineer and I didn't stay in a Holiday Inn Express last night but I did spend over 20 years installing lighting systems in both residential and commercial applications. I used these lights in my hangar and they work well. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of David Nelson > Sent: Monday, December 10, 2007 8:41 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Off Topic: Hanger Lighting > > > Hi Michael, > > I can't speak about hangar lighting specifically, but I'll share my > experiences > w/ lighting the garage. > > I initially went with some dual florescenct bulb fixtures (40 watt, I > believe) > that hung from an 8' ceiling about one foot. Sadly, they just didn't > quite put > out the kind of light I was wanting. Especially if I was going to be > working > under them. And, admittedly, I was a little tight in the wallet when I > purchased them. > > I eventually replaced the above units w/ some dual flourescent 8 foot, 96 > watt > bulbs (F96T12 bulbs). The fixtures attached to the ceiling. At the time > (~4 > yrs ago), the fixture and bulbs were about $50 per setup at Lowes. Also, > the > nice thing about the F96T12 bulbs is that you don't have insert-and-twist > to > install them. They use the spring loaded setup that works axially; so > it's > more of a stab-and-release operation. > > About a year ago I helped a friend replace some 2'x2' units in his office. > The > new units used some little skinny flourescent bulbs (~3/4 of the diameter > of > the traditional flourescent bulbs) that relied on electronics rather than > ballasts to operate. When we 1st turned them on, we couldn't help but > notice > how bright they were. Don't know if they exist in the longer versions or > not, > but you might consider them. > > Also, since you're installing in a hangar (and with a high ceiling that is > probably dark and does not reflect any light), I'd consider adding some > kind of > reflector that covers the top of the fixture to relect light back down > where > it's needed/wanted. No sense wasting light upwards. > > Good luck, > > /\/elson > RV-7A - Fuse (getting close to the canopy work) > Austin, TX > > > On Mon, 10 Dec 2007, Michael Kraus wrote: > > > > > > > > > > I am building a new hanger on my house and was looking for information > on > > what type of hanger lighting to install. The ceilings will be 16' tall > and > > it is 44' x 60'. I would like good work lighting throughout. Also, if > > anyone knows of the light spacing it would help. > > > > Thanks -Mike Kraus RV-4 Flying RV-10 wiring > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2007
You are spot on. I really shouldn't call my lights mercury vapors as I don't know exactly what I bought.....duh.. from your description I probably bought low pres sodium lamps. the point I was making (or trying to ) was to avoid the temptation to buy cheap lowe-depot lights. Because as with everything else, you get what you pay for. OH, To top the cake, a week ago Sunday when I opened the hangar door the acrylic diffuser dropped off one of the suspended light fixtures and smashed on the floor a few feet from the wing of my 6A. It looked as if the heat from the bulb was slowly cooking the plastic over time making it brittle, and although the lamp was cold when it fell off, a gust of wind may have caught it. Steve dinieri Iflyrv10.com Just to be correct, mercury vapor lights have a bluish light. If the light is a deep yellow, it is a low pressure sodium light. If the light is almost white with a yellowish tint, it is a high pressure sodium light. Dave --- Steven DiNieri wrote: > > > Brian > I'd avoid this route as this is exactly what I've > done. the color from the > cheap mercvapor lighting is an awful yellow that > distorts all color > perception. although the light was bright enough, i > actually got headaches > from the poor light color after long periods of > exposure. i haven't changed > them out yet, but i have lined the perimeter of the > hangar with 4ft > fluorescent fixtures and it has made a huge > difference. perhaps the best > lighting solution is a marriage of different > technologies. > of coarse your mileage may vary... > steve dinieri > Iflyrv10.com > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of Brian Meyette > Sent: Monday, December 10, 2007 10:13 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Off Topic: Hanger Lighting > > > > What was suggested to me as the cheapest and > simplest way to get good > lighting is to use those mercury vapor yard lights. > You can just tape over > the light sensor, or I rewired mine around the > sensor. Lots of light, they > only cost about $25 each, and they are not sensitive > to cold as fluorescents > are. > brian > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of Michael Kraus > Sent: Monday, December 10, 2007 8:02 AM > To: rv-list(at)matronics.com > Subject: RV-List: Off Topic: Hanger Lighting > > --> > > > > I am building a new hanger on my house and was > looking for information on > what type of hanger lighting to install. The > ceilings will be 16' tall and > it is 44' x 60'. I would like good work lighting > throughout. Also, if > anyone knows of the light spacing it would help. > > Thanks > -Mike Kraus > RV-4 Flying > RV-10 wiring > > > > > > > 11:06 AM > > > 11:06 AM > > > > > > > > > > Click on > about > Admin. > > browse > Un/Subscription, > FAQ, > > Forums! > > > > > Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 11, 2007
I know the individuals at Trio and their high level of business ethics > prevented them from releasing their EZ-Pilot until it was ready for prime > time. It was tough for the Trio guys to sit on their baby during > development as TT gained market share, but they were determined to release > no units before their time. Note the issues with one electronic ignition system. At least one forced landing resulted from what may have been software/hardware issues. > >> Is it lack of GPSS steering? > > That is a perceived difference but there is much more to the GPSS steering > issue than meets the uneducated eye. I won't delve into that, just to say > that for most of us "GPSS" is vastly overrated, and is not unique in an > operational sense to TT. Since I don't understand GPSS I just read this link: http://www.avionicswest.com/articles/GPSS.htm I still have no idea why I want or need it. My Trio EZ-Pilot tracks courses, intercepts courses, maintains a heading if GPS is lost and will follow GPS approaches (probably VOR and ILS as well...I just don't remember). You have options and I am not going to bash TruTrak. I suspect that it is a fine system. Ron Lee ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Subject: Re: Re Trutrac and Trio Cust svc
Date: Dec 11, 2007
Have not had any dealings with Trio, but TruTrak has been super with me. Bought my ADI Pilot II from A/C Spruce. Arrived without servos, mounting hdwre, and was an ADI Pilot I, but paid the Pilot II price. A/C Spruce rep didn't know that there was a difference. Called TT and explained the situation, also told them that the unit that I received had 'stuff' rattling around inside. TT immediately told me to give them my invoice #, name, date of purchase and that they would contact A/C Spruce. Called me back in 20 minutes and told me to either send it back to A/C Spruce or to them directly. Sent it to them. Within 2 weeks turn around TT sent me the new, complete ADI Pilot II with everything that I paid for through A/C Spruce. Even paid shipping both ways. To top it off, A/C Spruce had a promotion on at the time that was selling the ADI Pilot II BELOW TT cost, according to TT. TT still honored the price without a squabble. How can you beat that service? FYI - whenever A/C Spruce has a 'request quote' price. USE IT! I have purchased MANY items from them that have a VERY reduced price. Also did y'all know that A/C Spruce has a price matching policy? Find the cheapest price that you can on the web and they will beat it-even Van's. All they ask for is the website name. Back on TT-get Stein to build you your harness-he will at no extra charge include a jack in the wiring harness to plug your GPS into-including handhelds if TT supports it, as with my AvMap IV that I panel mounted in my 9A using the AirGizmos docking station. My 2cents worth, Mike H 9A/8A ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Tuesday, December 11, 2007 11:24 AM Subject: RV-List: Re Trutrac and Trio Cust svc I can tell you that Trio Cust Svc is outstanding and that Trutrack customer service is not worth a damn. Charlie Heathco ________________________________________________________________________________
Date: Dec 11, 2007
The ones you see at Costco are 400 watt fixtures and they are high up so the light "umbrella" they cast overlaps with the next fixture. Next time you are in their store, find an open area of floor and count how many shadows your body casts, if you can see them. Dave 30+ years an electrician --- Robin Marks wrote: > Ok, I would like to chime in on yet another subject > I know NOTHING > about! > > I own a 50' x 50' hangar (2500 square feet) and it > came with lighting > that was detailed in Jim's email: > > http://www.businesslights.com/high-bay-metal-halide-fixtures-c-277_477.h > tml > > My unit has only 4 of these lights hung very high in > the rafters > (probably 25' high ceilings) and it is plenty of > light for that space. > Frankly I was surprised to see how inexpensive they > were listed as I > always assumed they were more expensive that that. > > While I have read and understand that lowing the > lights is the proper > decision for some styles of lights if one goes into > a Costco you see > these lights suspended all the way up the very top > of the store, well > clear of any equipment or storage needs. I assume > they know what they > are doing in placing these lamps that high. > > The drawback to these lights is that they do not > turn on instantly. When > I flip the switch I get annoyed that I don't have > instant light but > before I think about it a second time the lights are > fully on. I have no > idea how energy efficient these lights are but I am > a satisfied owner > for both amount or light and light quality. > > > > 4:30 am, Can't sleep, > > Robin > > RV-4 Sold > > RV-6A 400 Hours > > RV-10 BPE Engine arrived > > Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Dec 11, 2007
Ron Lee wrote: >>> Is it lack of GPSS steering? >> >> That is a perceived difference but there is much more to the GPSS >> steering issue than meets the uneducated eye. I won't delve into that, >> just to say that for most of us "GPSS" is vastly overrated, and is not >> unique in an operational sense to TT. > > Since I don't understand GPSS I just read this link: > > http://www.avionicswest.com/articles/GPSS.htm > > I still have no idea why I want or need it. My Trio EZ-Pilot tracks > courses, > intercepts courses, maintains a heading if GPS is lost and will follow GPS > approaches (probably VOR and ILS as well...I just don't remember). Ron, I think what builders considering an autopilot need to keep in mind in regards to "GPSS" is that the current digital systems work so well that GPSS is for all practical purposes a moot point. It seems to me that the effort TruTrak has taken to promote GPSS is primarily to differentiate their system from the legacy systems (Century, S-Tec, etc). As you mentioned, our Trio EZ-Pilots track so accurately that we have no need for "GPSS". GPSS sounds pretty cool if all you have flown are the old analog autopilots, but for us fortunate enough to enjoy the digital toys in our experimental aircraft, our systems far outperform the old stuff. I still marvel at how a sub-$2000 autopilot can hold my plane within a wingspan of the course line with an inexpensive handheld GPS providing the data! How many King Airs and Citations can match that? :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 11, 2007
I haven't actually installed mine yet, so thanks for the tip. I'd just bought one at my electrician's suggestion, to see how the concept would work. I'll check it for color before installing it. Thanks brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Tuesday, December 11, 2007 1:34 AM Subject: RE: RV-List: Off Topic: Hanger Lighting Brian I'd avoid this route as this is exactly what I've done. the color from the cheap mercvapor lighting is an awful yellow that distorts all color perception. although the light was bright enough, i actually got headaches from the poor light color after long periods of exposure. i haven't changed them out yet, but i have lined the perimeter of the hangar with 4ft fluorescent fixtures and it has made a huge difference. perhaps the best lighting solution is a marriage of different technologies. of coarse your mileage may vary... steve dinieri Iflyrv10.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Meyette Sent: Monday, December 10, 2007 10:13 AM Subject: RE: RV-List: Off Topic: Hanger Lighting What was suggested to me as the cheapest and simplest way to get good lighting is to use those mercury vapor yard lights. You can just tape over the light sensor, or I rewired mine around the sensor. Lots of light, they only cost about $25 each, and they are not sensitive to cold as fluorescents are. brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Monday, December 10, 2007 8:02 AM Subject: RV-List: Off Topic: Hanger Lighting --> I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring 11:06 AM 11:06 AM 11:06 AM 2:51 PM ________________________________________________________________________________
Date: Dec 11, 2007
> I still marvel at how a sub-$2000 autopilot can hold my plane within a > wingspan of the course line with an inexpensive handheld GPS providing the > data! How many King Airs and Citations can match that? :-) That is probably why Sam. I often save flight tracks on my Airmap 500 and it is easy to tell when I am flying and when the Trio EZ-Pilot is flying. Now to get the altitude hold so ATC does not see the 100-200' (is that all?) altitude excursions when I make a sandwich or read a map. Ron Lee ________________________________________________________________________________
Date: Dec 11, 2007
Ralph, The single piece brackets for the nosewheel are as you describe. I just drilled out the 2 piece brackets and replaced them. Not to bad a job. I made a mandrel that located the new bracket via the axle holes in the pant and a 3/8 dowel through the front holes a couple brass flair fitting nuts that had a 3/8 id and a tapered OD centered the front holes in the existing cap screw access holes. Note if you haven't drilled your pants yet all of this is moot. I didn't order the washers called out on the drawing so I just drilled a 1/4" ID AN 970-4 fender washer to 3/8 and along with a thick and thin 3/8 AN960-616 the rear attachment is just right. Was it worth it, don't know depends on how many time the pant would need to be removed while leaving the wheel in place. It's not a big deal to remove the front of the pant and swing the strut end up onto a block of wood. I suspect I'll have it all off and on more while fitting and finishing than in all of the next few years. The updated drawing came with my new fork. I thing I need to go one size longer on the boll as well. If you are making the change you will need: Drawing C1 R3 1 ea U-713-L 1 ea U-713-R 2 ea AN960-616L Washers 2 ea AN960-616 Washers 2 ea 062 25783054 Washers ( I drilled 2 AN 970-4's but it's much easier to just add the right washers to your bracket order) The bolt is still called out as a AN6-60A as before but I only have about a single thread showing. YMMV The drawing calls for plate nuts and #8 screws to hold the bracket on, I used -3 flush rivets 3 per tab and assembled it with epoxy and a layer of fiberglass. I hope to never see the fasteners!! Good luck -- Ralph C. Hoover RV7A Almost ready for the trip to the airport for final assembly. hooverra at verizon dot net ________________________________________________________________________________
Subject: Sun-N-Fun
Date: Dec 11, 2007
The Thunderbirds will be @ Sun-N-Fun this year. Should be a good show, it has been several years since they have attended and performed. I just got a memo from the airport. I am sure it will be on the Sun-N-Fun site soon if not already. Sal Lakeland, FL ________________________________________________________________________ ________________________________________________________________________________
Date: Dec 11, 2007
Subject: Re: Nosewheel pant brackets
Thanks Ralph! -----Original Message----- >From: Ralph Hoover <hooverra(at)verizon.net> >Sent: Dec 11, 2007 4:48 PM >To: rv-list(at)matronics.com >Subject: RV-List: Nosewheel pant brackets > > >Ralph, > The single piece brackets for the nosewheel are as you describe. I >just drilled out the 2 piece brackets and replaced them. Not to bad a >job. I made a mandrel that located the new bracket via the axle holes in >the pant and a 3/8 dowel through the front holes a couple brass flair >fitting nuts that had a 3/8 id and a tapered OD centered the front holes >in the existing cap screw access holes. Note if you haven't drilled your >pants yet all of this is moot. > I didn't order the washers called out on the drawing so I just >drilled a 1/4" ID AN 970-4 fender washer to 3/8 and along with a thick >and thin 3/8 AN960-616 the rear attachment is just right. Was it worth >it, don't know depends on how many time the pant would need to be >removed while leaving the wheel in place. It's not a big deal to remove >the front of the pant and swing the strut end up onto a block of wood. I >suspect I'll have it all off and on more while fitting and finishing >than in all of the next few years. > The updated drawing came with my new fork. I thing I need to go one >size longer on the boll as well. > If you are making the change you will need: >Drawing C1 R3 >1 ea U-713-L >1 ea U-713-R >2 ea AN960-616L Washers >2 ea AN960-616 Washers >2 ea 062 25783054 Washers ( I drilled 2 AN 970-4's but it's much easier >to just add the right washers to your bracket order) >The bolt is still called out as a AN6-60A as before but I only have >about a single thread showing. YMMV > >The drawing calls for plate nuts and #8 screws to hold the bracket on, I >used -3 flush rivets 3 per tab and assembled it with epoxy and a layer >of fiberglass. I hope to never see the fasteners!! > Good luck > >-- >Ralph C. Hoover >RV7A Almost ready for the trip to the airport for final assembly. >hooverra at verizon dot net > > ________________________________________________________________________________
Subject: Safety-Trim Group Buy
Date: Dec 11, 2007
Dear Fellow RV Builders, TCW Technologies and SteinAir are pleased to announce a group buy is now available on our new servo trim controller. Safety-Trim is an electronic trim servo controller that resolves the issues with run-away trim conditions plus it provides 2 speed trim operation as well as greatly simplified switch wiring. For all the detail please follow this direct link: http://www.vansairforce.com/community/showthread.php?t=24478 Thank you, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Date: Dec 11, 2007
Charlie, Sorry to hear you had an issue with TruTrak's customer service. I had a problem with a cracked case on my ADI-II ( used a tinybit of halomar sealant, DON"T it caused the case material to deteriorate and crack). TruTrak replaced the case in short order and didn't charge me a dime. I would recommend them to anyone. -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
From: "Donald Harker" <dpharker(at)worldnet.att.net>
Subject: Marker Beacon in lower cowl
Date: Dec 11, 2007
Planning on glassing in a 40 " bare 22 gauge wire in bottom of 7A cowl for use as marker beacon antenna. One concern is that the antenna is not perfectly flat. Anyone done this before? Thanks Don Harker N767DH Finishing ________________________________________________________________________________
Date: Dec 11, 2007
It need not be flat, or straight. It need not be bare wire for that matter. Use a BNC bulkhead fitting at the firewall and a short piece of coax in the cowl side BNC connector, then transition from the center conductor of the coax to your wire. The coax shield need not extend past the connector and is not connected to anything. The coax just makes it easy to use a BNC connector to disconnect the antenna for cowl removal. If you have a ham friend have him/her check the antenna for resonance at 75 MHZ. In free air a =BC wavelength antenna (as your=92s will be) at this frequency is 37.5 inches. If you don=92t have a ham friend to check, then just use 38=94 or so. This is really not critical for marker beacon use. Carl Froehlich RV-8A (375 hrs) RV-10 (wings) _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Donald Harker Sent: Tuesday, December 11, 2007 9:44 PM Subject: RV-List: Marker Beacon in lower cowl Planning on glassing in a 40 =93 bare 22 gauge wire in bottom of 7A cowl for use as marker beacon antenna. One concern is that the antenna is not perfectly flat. Anyone done this before? Thanks Don Harker N767DH Finishing ________________________________________________________________________________
Date: Dec 11, 2007
Subject: Re: Marker Beacon in lower cowl
Don, I did something very similar to what Carl describes and it works adequate though is not as sensitive as most certified installations I have flown... Could be the RST receiver, but I blame my makeshift antenna and the interference from all the metal parts around the engine. I did the same with my nav antenna and it worked OK, though not great. I recently changed it out for a wing-tip archer antenna an it seems to get a much more stable nav signal. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Dec 11, 2007 7:03 PM, Carl Froehlich wrote: > It need not be flat, or straight. It need not be bare wire for that > matter. Use a BNC bulkhead fitting at the firewall and a short piece of > coax in the cowl side BNC connector, then transition from the center > conductor of the coax to your wire. The coax shield need not extend past > the connector and is not connected to anything. The coax just makes it e asy > to use a BNC connector to disconnect the antenna for cowl removal. > > > If you have a ham friend have him/her check the antenna for resonance at > 75 MHZ. In free air a =BC wavelength antenna (as your's will be) at this > frequency is 37.5 inches. If you don't have a ham friend to check, then > just use 38" or so. This is really not critical for marker beacon use. > > > Carl Froehlich > > RV-8A (375 hrs) > > RV-10 (wings) > > > ------------------------------ > > *From:* owner-rv-list-server(at)matronics.com [mailto: > owner-rv-list-server(at)matronics.com] *On Behalf Of *Donald Harker > *Sent:* Tuesday, December 11, 2007 9:44 PM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Marker Beacon in lower cowl > > > Planning on glassing in a 40 " bare 22 gauge wire in bottom of 7A cowl fo r > use as marker beacon antenna. One concern is that the antenna is not > perfectly flat. > > > Anyone done this before? > > > Thanks > > > Don Harker > > N767DH > > Finishing > > * * > > * * > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV-List* > > ** > > *http://forums.matronics.com* > > * * > > * > =========== com/contribution =========== nics.com/Navigator?RV-List =========== =========== > * > > ________________________________________________________________________________
Date: Dec 12, 2007
Darwin: Can you describe, or better yet provide a brand/photo of these halogen fixtures? I need to add lights in my hanger.? I have a standard T-hanger with?three (3)?- two (2) 8' fluorescent tubes fixtures, mounted on the ceiling (appx 16' high).? Inadequate to say the least. Thanks. Jeff -----Original Message----- From: Darwin N. Barrie <ktlkrn(at)cox.net> Sent: Tue, 11 Dec 2007 8:55 am Subject: Re: RV-List: Off Topic: Hanger Lighting Living in a residential airpark I've got to see a variety of lighting. All of the hangars on my street are the same dimensions, 45'x40', 15' ceilings.? Stock lighting was 6 -2 bulb 4' flourescent fixtures. This is inadequate. One of my neighbors went with 6 -4 bulb 4' fixtures and this improved things greatly but still wasn't ideal. ? By far the best lighting I've seen is large Halogen fixtures. My next door neighbor has them and his lighting is unequalled. Another followed his lead but added a couple of extra fixtures. He has light. ? Another huge factor is the floor. My floor is epoxy and gray in color with a slight gloss finish. My next door neigbor (with the halogens) floor is tan, leaning toward a more yellowish tint with very little gloss.?Although the lights are white the hangar has a yellowish tint when the lights are on. ? The other neighbor who added halogens has a light blue floor with light gloss. He has the best lighting on the block. ? If doing again, I'd go with the halogens despite the added cost. The lighting is incredible. The fixtures hang down from the ceiling making bulb changes although my neighbor hasn't had any bulb failures in 6 years. Good lighting makes things so much nicer. I'm going to go with the halogens before next summer. ? Darwin N. Barrie Chandler AZ RV7 N717EE ________________________________________________________________________ ________________________________________________________________________________
Date: Dec 12, 2007
Subject: Re: Required RV Tools
this needs to be archived. Michael Wynn RV 8 Used almost all of these tools, just in the manner described. Add: Pneumatic rivet squeezer: Tool designed to accurately remove 1/4 moon sized pieces of your left index finger. **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 12, 2007
Check out: http://www.lightmart.com/index.asp?PageAction=VIEWPROD&ProdID=18842 Mauri RV-8 Finishing ----- Original Message ----- From: darnpilot(at)aol.com To: rv-list(at)matronics.com Sent: Wednesday, December 12, 2007 8:58 AM Subject: Re: RV-List: Off Topic: Hanger Lighting Darwin: Can you describe, or better yet provide a brand/photo of these halogen fixtures? I need to add lights in my hanger. I have a standard T-hanger with three (3) - two (2) 8' fluorescent tubes fixtures, mounted on the ceiling (appx 16' high). Inadequate to say the least. Thanks. Jeff -----Original Message----- From: Darwin N. Barrie <ktlkrn(at)cox.net> To: rv-list(at)matronics.com Sent: Tue, 11 Dec 2007 8:55 am Subject: Re: RV-List: Off Topic: Hanger Lighting Living in a residential airpark I've got to see a variety of lighting. All of the hangars on my street are the same dimensions, 45'x40', 15' ceilings. Stock lighting was 6 -2 bulb 4' flourescent fixtures. This is inadequate. One of my neighbors went with 6 -4 bulb 4' fixtures and this improved things greatly but still wasn't ideal. By far the best lighting I've seen is large Halogen fixtures. My next door neighbor has them and his lighting is unequalled. Another followed his lead but added a couple of extra fixtures. He has light. Another huge factor is the floor. My floor is epoxy and gray in color with a slight gloss finish. My next door neigbor (with the halogens) floor is tan, leaning toward a more yellowish tint with very little gloss. Although the lights are white the hangar has a yellowish tint when the lights are on. The other neighbor who added halogens has a light blue floor with light gloss. He has the best lighting on the block. If doing again, I'd go with the halogens despite the added cost. The lighting is incredible. The fixtures hang down from the ceiling making bulb changes although my neighbor hasn't had any bulb failures in 6 years. Good lighting makes things so much nicer. I'm going to go with the halogens before next summer. Darwin N. Barrie Chandler AZ RV7 N717EE ------------------------------------------------------------------------- ----- ------------------------------------------------------------------------- ----- 12/12/2007 11:29 AM ________________________________________________________________________________
Date: Dec 12, 2007
Negative, Sam James. Tracy has pants from Lightspeed Engineering. Klaus developed them to go fast on EZs. He sells them on his website. Don't know the price without looking. Tracy made the original fiberglass gear leg fairings and I think his daughter still offers them along with his side mounted throttle quadrant. Check the yeller pages for contact info. Pax, Ed Holyoke > > I know that Tracy Saylor and most of the other "fast" RV's used Sam > James wheelpants, which were essentially the same price as Van's > offering, but didn't include the mounting hardware that Van's supplies > with theirs. > > ________________________________________________________________________________
Subject: Off Topic: Hanger Lighting
Date: Dec 12, 2007
Hangar lighting is simple and cheap...good hangar lighting is a bit more complex and costs a little more. Chuck Jensen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of darnpilot(at)aol.com Sent: Wednesday, December 12, 2007 10:58 AM Subject: Re: RV-List: Off Topic: Hanger Lighting Darwin: Can you describe, or better yet provide a brand/photo of these halogen fixtures? I need to add lights in my hanger. I have a standard T-hanger with three (3) - two (2) 8' fluorescent tubes fixtures, mounted on the ceiling (appx 16' high). Inadequate to say the least. Thanks. Jeff -----Original Message----- From: Darwin N. Barrie <ktlkrn(at)cox.net> Sent: Tue, 11 Dec 2007 8:55 am Subject: Re: RV-List: Off Topic: Hanger Lighting Living in a residential airpark I've got to see a variety of lighting. All of the hangars on my street are the same dimensions, 45'x40', 15' ceilings. Stock lighting was 6 -2 bulb 4' flourescent fixtures. This is inadequate. One of my neighbors went with 6 -4 bulb 4' fixtures and this improved things greatly but still wasn't ideal. By far the best lighting I've seen is large Halogen fixtures. My next door neighbor has them and his lighting is unequalled. Another followed his lead but added a couple of extra fixtures. He has light. Another huge factor is the floor. My floor is epoxy and gray in color with a slight gloss finish. My next door neigbor (with the halogens) floor is tan, leaning toward a more yellowish tint with very little gloss. Although the lights are white the hangar has a yellowish tint when the lights are on. The other neighbor who added halogens has a light blue floor with light gloss. He has the best lighting on the block. If doing again, I'd go with the halogens despite the added cost. The lighting is incredible. The fixtures hang down from the ceiling making bulb changes although my neighbor hasn't had any bulb failures in 6 years. Good lighting makes things so much nicer. I'm going to go with the halogens before next summer. Darwin N. Barrie Chandler AZ RV7 N717EE _____ <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid =aolcmp00050000000003> ! ________________________________________________________________________________
Date: Dec 12, 2007
The very same tool will both punch and dimple a skin next to that freshly match drilled hole and of course violate edge distances in the process. :) Of course I only know that from this list. NOT! Add: Pneumatic rivet squeezer: Tool designed to accurately remove 1/4 moon sized pieces of your left index finger. -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Dec 13, 2007
Sam, You know that the accuracy of the GPS coupled to the autopilot is probably what caused the Brazilian GOL 737, and the Embraer Legacy 600 Collision in October 06 both were at 37,000 feet and on opposing courses between Brasilia and Manause, both probably used the airport coordinates in a common data base. There are probably not more than 75 airplanes in the air in northern Brasil at one time. Sometimes being accurate down to the micron is not good, and being able to fly an offset course is good. The Trio will do that easily all day long. Just a thought. Trying to justify being a sloppy pilot }:>) Bob Perkinson I still marvel at how a sub-$2000 autopilot can hold my plane within a wingspan of the course line with an inexpensive handheld GPS providing the data! How many King Airs and Citations can match that? :-) Sam Buchanan
Sam,
You know that the accuracy of the GPS coupled to the autopilot is probably what caused the Brazilian GOL 737, and the Embraer Legacy 600 Collision in October 06 both were at 37,000 feet and on opposing courses between Brasilia and Manause, both probably used the airport coordinates in a common data base.  There are probably not more than 75 airplanes in the air in northern Brasil at one time.  Sometimes being accurate down to the micron is not good, and being able to fly an offset course is good.  The Trio will do that easily all day long.  Just a thought.  Trying to justify being a sloppy pilot }:> )
Bob Perkinson
Sam Buchanan
Date: Dec 13, 2007
Doesn't TRIOs have a offset feature that allows the pilot to chose by 1/10t h of a mile how far right of center line (up to 2 miles) the autopilot will track? Last year, I heard at an FAA safety conference about a program call SLOP; stategic lateral offset procedure.... basically you either fly on center li ne, 1 mile right or 2 miles right.... Helps avoid this type of airborne Russian roulette.... Marty Heller RV-7 (fitting interior systems) From: bobperk90658(at)bellsouth.netTo: rv-list(at)matronics.comSubject: Re: RV-Li st: Trio EZ-Pilot or Altitude HoldDate: Thu, 13 Dec 2007 05:46:08 +0000 Sam, You know that the accuracy of the GPS coupled to the autopilot is probably what caused the Brazilian GOL 737, and the Embraer Legacy 600 Collision in October 06 both were at 37,000 feet and on opposing courses between Brasili a and Manause, both probably used the airport coordinates in a common data base. There are probably not more than 75 airplanes in the air in northern Brasil at one time. Sometimes being accurate down to the micron is not go od, and being able to fly an offset course is good. The Trio will do that easily all day long. Just a thought. Trying to justify being a sloppy pil ot }:> ) Bob Perkinson I still marvel at how a sub-$2000 autopilot can hold my plane within a win gspan of the course line with an inexpensive handheld GPS providing the dat a! How many King Airs and Citations can match that? :-) Sam Buchanan _________________________________________________________________ i=92m is proud to present Cause Effect, a series about real people making a difference. ________________________________________________________________________________
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Dec 13, 2007
WWVzLiBJbiBmYWN0IHRoZSB3cml0dGVyIHNhaWQgZXhhY3RseSB0aGF0IGJlbG93Lg0KIlNvbWV0 aW1lcyBiZWluZyBhY2N1cmF0ZSBkb3duIHRvIHRoZSBtaWNyb24gaXMgbm90IGdvb2QsIGFuZCBi ZWluZyBhYmxlIHRvDQpmbHkgYW4gb2Zmc2V0IGNvdXJzZSBpcyBnb29kLiAgVGhlIFRyaW8gd2ls bCBkbyB0aGF0IGVhc2lseSBhbGwgZGF5IGxvbmcuIg0KDQpXZSBldmVuIHVzZSB0aGUgVHJpb3Mg b2Zmc2V0IHRvIGZseSBpbiByb3V0ZSBmb3JtYXRpb24gZnJvbSBBIHRvIEIuIFdvcmtzDQpsaWtl IGEgY2hhbXAuIEJvdXQgaGFsZiBvZiB1cyBhcmUgcnVubmluZyB0aGUgVHJpby4gVGhlIG90aGVy IGhhbGYgd2lzaA0KdGhleSB3ZXJlIHdoZW4gdGhlIFRyaW8gaXMgYnV6emluZyB1cyBhbG9uZyBp biBmb3JtYXRpb24gaGFuZHMgZnJlZS4NCk1pa2UNCmRvIG5vdCBhcmNoaXZlDQoNCg0KDQoNCiAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgIE1hcnR5IEhlbGxsZXIgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgDQogICAgICAgICAgICAgPG1hcnR5 X2F3YXlAaG90bWEgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAN CiAgICAgICAgICAgICBpbC5jb20+ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIFRvIA0KICAgICAgICAgICAgIFNlbnQgYnk6ICAgICAgICAgICAgICAg ICAgPHJ2LWxpc3RAbWF0cm9uaWNzLmNvbT4gICAgICAgICAgICAgDQogICAgICAgICAgICAgb3du ZXItcnYtbGlzdC1zZXIgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICBj YyANCiAgICAgICAgICAgICB2ZXJAbWF0cm9uaWNzLmNvbSAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIFN1YmplY3QgDQogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICBSRTogUlYtTGlzdDogVHJpbyBFWi1QaWxvdCBvciAg ICAgICANCiAgICAgICAgICAgICAxMi8xMy8yMDA3IDA4OjEyICAgICAgICAgIEFsdGl0dWRlIEhv bGQgICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgIEFNICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgDQogICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICANCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgIFBsZWFzZSByZXNwb25k IHRvICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgDQogICAgICAg ICAgICAgcnYtbGlzdEBtYXRyb25pY3MgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICANCiAgICAgICAgICAgICAgICAgICAuY29tICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIA0KICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgDQogICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICANCg0KDQoNCg0KRG9lc24ndCBUUklPcyBoYXZlIGEgb2Zmc2V0IGZlYXR1 cmUgdGhhdCBhbGxvd3MgdGhlIHBpbG90IHRvIGNob3NlIGJ5DQoxLzEwdGggb2YgYSBtaWxlIGhv dyBmYXIgcmlnaHQgb2YgY2VudGVyIGxpbmUgKHVwIHRvIDIgbWlsZXMpIHRoZSBhdXRvcGlsb3QN CndpbGwgdHJhY2s/DQoNCkxhc3QgeWVhciwgSSBoZWFyZCBhdCBhbiBGQUEgc2FmZXR5IGNvbmZl cmVuY2UgYWJvdXQgYSAgcHJvZ3JhbSBjYWxsIFNMT1A7DQpzdGF0ZWdpYyBsYXRlcmFsIG9mZnNl dCBwcm9jZWR1cmUuLi4uIGJhc2ljYWxseSB5b3UgZWl0aGVyIGZseSBvbiBjZW50ZXINCmxpbmUs IDEgbWlsZSByaWdodCBvciAyIG1pbGVzIHJpZ2h0Li4uLg0KSGVscHMgYXZvaWQgdGhpcyB0eXBl IG9mIGFpcmJvcm5lIFJ1c3NpYW4gcm91bGV0dGUuLi4uDQoNCk1hcnR5IEhlbGxlcg0KUlYtNyAo Zml0dGluZyBpbnRlcmlvciBzeXN0ZW1zKQ0KDQoNCiAgICAgIEZyb206IGJvYnBlcms5MDY1OEBi ZWxsc291dGgubmV0DQogICAgICBUbzogcnYtbGlzdEBtYXRyb25pY3MuY29tDQogICAgICBTdWJq ZWN0OiBSZTogUlYtTGlzdDogVHJpbyBFWi1QaWxvdCBvciBBbHRpdHVkZSBIb2xkDQogICAgICBE YXRlOiBUaHUsIDEzIERlYyAyMDA3IDA1OjQ2OjA4ICswMDAwDQoNCg0KICAgICAgIFNhbSwNCiAg ICAgICBZb3Uga25vdyB0aGF0IHRoZSBhY2N1cmFjeSBvZiB0aGUgR1BTIGNvdXBsZWQgdG8gdGhl IGF1dG9waWxvdCBpcw0KICAgICAgIHByb2JhYmx5IHdoYXQgY2F1c2VkIHRoZSBCcmF6aWxpYW4g R09MIDczNywgYW5kIHRoZSBFbWJyYWVyIExlZ2FjeQ0KICAgICAgIDYwMCBDb2xsaXNpb24gaW4g T2N0b2JlciAwNiBib3RoIHdlcmUgYXQgMzcsMDAwIGZlZXQgYW5kIG9uIG9wcG9zaW5nDQogICAg ICAgY291cnNlcyBiZXR3ZWVuIEJyYXNpbGlhIGFuZCBNYW5hdXNlLCBib3RoIHByb2JhYmx5IHVz ZWQgdGhlIGFpcnBvcnQNCiAgICAgICBjb29yZGluYXRlcyBpbiBhIGNvbW1vbiBkYXRhIGJhc2Uu ICBUaGVyZSBhcmUgcHJvYmFibHkgbm90IG1vcmUgdGhhbg0KICAgICAgIDc1IGFpcnBsYW5lcyBp biB0aGUgYWlyIGluIG5vcnRoZXJuIEJyYXNpbCBhdCBvbmUgdGltZS4gIFNvbWV0aW1lcw0KICAg ICAgIGJlaW5nIGFjY3VyYXRlIGRvd24gdG8gdGhlIG1pY3JvbiBpcyBub3QgZ29vZCwgYW5kIGJl aW5nIGFibGUgdG8gZmx5DQogICAgICAgYW4gb2Zmc2V0IGNvdXJzZSBpcyBnb29kLiAgVGhlIFRy aW8gd2lsbCBkbyB0aGF0IGVhc2lseSBhbGwgZGF5DQogICAgICAgbG9uZy4gIEp1c3QgYSB0aG91 Z2h0LiAgVHJ5aW5nIHRvIGp1c3RpZnkgYmVpbmcgYSBzbG9wcHkgcGlsb3QgfTo+ICkNCg0KDQoN CiAgICAgICBCb2IgUGVya2luc29uDQoNCg0KICAgICAgICBJIHN0aWxsIG1hcnZlbCBhdCBob3cg YSBzdWItJDIwMDAgYXV0b3BpbG90IGNhbiBob2xkIG15IHBsYW5lDQogICAgICAgd2l0aGluIGEN CiAgICAgICB3aW5nc3BhbiBvZiB0aGUgY291cnNlIGxpbmUgd2l0aCBhbiBpbmV4cGVuc2l2ZSBo YW5kaGVsZCBHUFMNCiAgICAgICBwcm92aWRpbmcNCiAgICAgICB0aGUgZGF0YSEgSG93IG1hbnkg S2luZyBBaXJzIGFuZCBDaXRhdGlvbnMgY2FuIG1hdGNoIHRoYXQ/IDotKQ0KDQogICAgICAgU2Ft IEJ1Y2hhbmFuDQoNCg0KDQoNCiAgICAgIGJsYW5rPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24NCiAgICAgIHQ9X2JsYW5rPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/UlYtTGlzdA0KICAgICAgcDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoNCg0KDQpp4oCZ bSBpcyBwcm91ZCB0byBwcmVzZW50IENhdXNlIEVmZmVjdCwgYSBzZXJpZXMgYWJvdXQgcmVhbCBw ZW9wbGUgbWFraW5nIGENCmRpZmZlcmVuY2UuIExlYXJuIG1vcmUNCg0KDQpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09DQpf LT0gICAgICAgLS0gUGxlYXNlIFN1cHBvcnQgWW91ciBMaXN0cyBUaGlzIE1vbnRoIC0tDQpfLT0g ICAgICAgICAgIChBbmQgR2V0IFNvbWUgQVdFU09NRSBGUkVFIEdpZnRzISkNCl8tPQ0KXy09ICAg Tm92ZW1iZXIgaXMgdGhlIEFubnVhbCBMaXN0IEZ1bmQgUmFpc2VyLiAgQ2xpY2sgb24NCl8tPSAg IHRoZSBDb250cmlidXRpb24gbGluayBiZWxvdyB0byBmaW5kIG91dCBtb3JlIGFib3V0DQpfLT0g ICB0aGlzIHllYXIncyBUZXJyaWZpYyBGcmVlIEluY2VudGl2ZSBHaWZ0cyENCl8tPQ0KXy09ICAg TGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT0NCl8tPSAgIFRoYW5rIHlvdSBmb3IgeW91ciBn ZW5lcm91cyBzdXBwb3J0IQ0KXy09DQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAt TWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUg UlYtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJl cyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBh cyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3 LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1v cmU6DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVi1MaXN0 DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0g U2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8t PSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg= ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Re: Trio EZ-Pilot or Altitude Hold
bobperk90658(at)bellsouth.net wrote: > > Sam, You know that the accuracy of the GPS coupled to the autopilot > is probably what caused the Brazilian GOL 737, and the Embraer Legacy > 600 Collision in October 06 both were at 37,000 feet and on opposing > courses between Brasilia and Manause, both probably used the airport > coordinates in a common data base. There are probably not more than > 75 airplanes in the air in northern Brasil at one time. Sometimes > being accurate down to the micron is not good, and being able to fly > an offset course is good. The Trio will do that easily all day long. > Just a thought. Trying to justify being a sloppy pilot }:>) You're right Bob, the guys at Trio recognize that "accurate" sometimes may not be the most comfortable way to navigate. The offset feature does work very nicely even though I hardly ever use it since I'm usually flying "direct" VFR. I have used the offset feature a few times when I saw my direct route was going to take me over a power plant. Another neat feature is the one-button automatic 180 turn. Fortunately I have *never* found the need to use it. :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
At the altitudes I fly there is very little traffic. I use flight following and I have been alerted to jets far more than GA aircraft. Ron Lee ________________________________________________________________________________
Subject: TRIO AUTOPILOT
Date: Dec 13, 2007
Hello Sam Did you required a special cable to hook up your handheld GPS to your TRIO? I have a Garmin 295 that I could use for this purpose or the GPS built in my BMA Efis Lite G3. Cheers Bruno ---------------------------------------------------------------------- From: bobperk90658(at)bellsouth.net Subject: Re: RV-List: Trio EZ-Pilot or Altitude Hold Sam, You know that the accuracy of the GPS coupled to the autopilot is probably what caused the Brazilian GOL 737, and the Embraer Legacy 600 Collision in October 06 both were at 37,000 feet and on opposing courses between Brasilia and Manause, both probably used the airport coordinates in a common data base. There are probably not more than 75 airplanes in the air in northern Brasil at one time. Sometimes being accurate down to the micron is not good, and being able to fly an offset course is good. The Trio will do that easily all day long. Just a thought. Trying to justify being a sloppy pilot }:>) Bob Perkinson I still marvel at how a sub-$2000 autopilot can hold my plane within a wingspan of the course line with an inexpensive handheld GPS providing the data! How many King Airs and Citations can match that? :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Cost of Paint Job
I'm shopping around for a paint job and am getting sticker shock. The only "local" shop around Chicago told me his last RV paint job was $7200. I thought they typically cost around 5000. I've spent a lot of time on my glass stuff and its pretty much ready to paint. Anyone have a cost of a good relatively simple 2 color paint job that didnt require a lot of work by the painters? Shemp 300+ 6a Chicago mike humphrey wrote: > > > Mike, > In my hanger I have the T-12 cold weather 8' units. Great lighting, > work in cold fine, easy to replace, just started replacing bulbs after > 3 1/2 years continual use, pricey but great lighting. Lowe's carries > the 8' fixture and bulbs(green ends and they just push in, no > twisting). In my work areas I have added specific lighting to the > situation. Bandsaw, lathe, drill press (dangerous areas) have > separate lighting on switches. I would not hang any lighting on the > 16' ceiling though. Lighting disperses geometrically. So whatever > lighting that you choose, suspend it from some cheap chain and lower > it to about 2-3 feet above your highest point on the floor, ie tail of > plane. Reflectors are cheaper than lighting units and you will save > electricity which equals $. More $ to spend on RV's. Remember, > whatever lighting that you put in, you will not want to replace > anytime soon, if ever, by lowering your units, maintenance will be > easier also, unless you just happen to have a 16' step ladder. > Mike H > 9A/8A > ----- Original Message ----- From: "Michael Kraus" > > To: > Sent: Monday, December 10, 2007 8:01 AM > Subject: RV-List: Off Topic: Hanger Lighting > > >> >> >> >> >> I am building a new hanger on my house and was looking for >> information on what type of hanger lighting to install. The ceilings >> will be 16' tall and it is 44' x 60'. I would like good work >> lighting throughout. Also, if anyone knows of the light spacing it >> would help. >> >> Thanks >> -Mike Kraus >> RV-4 Flying >> RV-10 wiring >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Re: Off Topic: Hanger Lighting
Has anyone mentioned the Sodium vapor lights? I have them in my hangar and love em. They take a while to warm up but offer great light in a large space. Shemp Tim Bryan wrote: > > > >> ? - Why wouldn't the 65 watt fluorescent units that you talk about below >> suffer >> from the same effects (or is it affects)? >> >> Regards, >> /\/elson >> >> > > [Tim] They still get brighter as they warm up but they don't flicker like > the 8 foot fluorescents do. 4 foot fluorescents don't really flicker to > bad, but these lights use a lens that helps get the light down. They say > they are equivalent to a 500 watt but it is only 65 watts of power. > > I like them except for they are hard to mount on a flat ceiling. > > > ________________________________________________________________________________
Subject: Re: Cost of Paint Job
Date: Dec 13, 2007
I painted my plane with three colors of Imron. The total cost of materials was about $400. I did all the prep work myself, built a booth in my garage, and asked a local pro to come over and squirt the top coat. He did a great job and had about 2 hours into the whole thing. I bought him a case of scotch and went flying with him a couple times. Everyone walked away very happy. With mine, the prep work was just that - "work". Its nothing difficult or anything that requries any unusual skills. But it takes a lot of time and that's why your local shop wants $7200. The only part of the job that takes skill and experience to get right is the final squirt. If you want to see how to prep and paint your RV, get Sam James's Painting 101 video. (Its at Builder's Bookstore www.buildersbooks.com ) Andy ----- Original Message ----- From: "Shemp" <shempdowling(at)gmail.com> Sent: Thursday, December 13, 2007 9:59 AM Subject: RV-List: Cost of Paint Job > > I'm shopping around for a paint job and am getting sticker shock. The > only "local" shop around Chicago told me his last RV paint job was $7200. > I thought they typically cost around 5000. I've spent a lot of time on my > glass stuff and its pretty much ready to paint. Anyone have a cost of a > good relatively simple 2 color paint job that didnt require a lot of work > by the painters? > > Shemp > 300+ > 6a > Chicago > > mike humphrey wrote: >> >> >> Mike, >> In my hanger I have the T-12 cold weather 8' units. Great lighting, work >> in cold fine, easy to replace, just started replacing bulbs after 3 1/2 >> years continual use, pricey but great lighting. Lowe's carries the 8' >> fixture and bulbs(green ends and they just push in, no twisting). In my >> work areas I have added specific lighting to the situation. Bandsaw, >> lathe, drill press (dangerous areas) have separate lighting on switches. >> I would not hang any lighting on the 16' ceiling though. Lighting >> disperses geometrically. So whatever lighting that you choose, suspend >> it from some cheap chain and lower it to about 2-3 feet above your >> highest point on the floor, ie tail of plane. Reflectors are cheaper >> than lighting units and you will save electricity which equals $. More $ >> to spend on RV's. Remember, whatever lighting that you put in, you will >> not want to replace anytime soon, if ever, by lowering your units, >> maintenance will be easier also, unless you just happen to have a 16' >> step ladder. >> Mike H >> 9A/8A >> ----- Original Message ----- From: "Michael Kraus" >> >> To: >> Sent: Monday, December 10, 2007 8:01 AM >> Subject: RV-List: Off Topic: Hanger Lighting >> >> >>> >>> >>> >>> >>> I am building a new hanger on my house and was looking for information >>> on what type of hanger lighting to install. The ceilings will be 16' >>> tall and it is 44' x 60'. I would like good work lighting throughout. >>> Also, if anyone knows of the light spacing it would help. >>> >>> Thanks >>> -Mike Kraus >>> RV-4 Flying >>> RV-10 wiring >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 13, 2007
Shemp, Rarely is the prep work done by a builder even close to the degree of finish that a quality painter requires. The builder/owner thinks just a few hours of touch up is all that is required, but more often, its like several days or a week or more. If the local shop does a high quality prep job and paint to match, $7,200 isn't unreasonable. If he's doing an "Earl Schribe" type paint job, then $5,000 is way too much. Chuck -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Shemp Sent: Thursday, December 13, 2007 12:00 PM Subject: RV-List: Cost of Paint Job I'm shopping around for a paint job and am getting sticker shock. The only "local" shop around Chicago told me his last RV paint job was $7200. I thought they typically cost around 5000. I've spent a lot of time on my glass stuff and its pretty much ready to paint. Anyone have a cost of a good relatively simple 2 color paint job that didnt require a lot of work by the painters? Shemp 300+ 6a Chicago mike humphrey wrote: > > > Mike, > In my hanger I have the T-12 cold weather 8' units. Great lighting, > work in cold fine, easy to replace, just started replacing bulbs after > 3 1/2 years continual use, pricey but great lighting. Lowe's carries > the 8' fixture and bulbs(green ends and they just push in, no > twisting). In my work areas I have added specific lighting to the > situation. Bandsaw, lathe, drill press (dangerous areas) have > separate lighting on switches. I would not hang any lighting on the > 16' ceiling though. Lighting disperses geometrically. So whatever > lighting that you choose, suspend it from some cheap chain and lower > it to about 2-3 feet above your highest point on the floor, ie tail of > plane. Reflectors are cheaper than lighting units and you will save > electricity which equals $. More $ to spend on RV's. Remember, > whatever lighting that you put in, you will not want to replace > anytime soon, if ever, by lowering your units, maintenance will be > easier also, unless you just happen to have a 16' step ladder. > Mike H > 9A/8A > ----- Original Message ----- From: "Michael Kraus" > > To: > Sent: Monday, December 10, 2007 8:01 AM > Subject: RV-List: Off Topic: Hanger Lighting > > >> >> >> >> >> I am building a new hanger on my house and was looking for >> information on what type of hanger lighting to install. The ceilings >> will be 16' tall and it is 44' x 60'. I would like good work >> lighting throughout. Also, if anyone knows of the light spacing it >> would help. >> >> Thanks >> -Mike Kraus >> RV-4 Flying >> RV-10 wiring >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: TRIO AUTOPILOT
Date: Dec 13, 2007
Both can be used to drive the Trio. I know cause I have done so with both myself. Mike Bruno To Sent by: RV LIST owner-rv-list-ser cc ver(at)matronics.com Subj ect RV-List: TRIO AUTOPILOT 12/13/2007 11:41 AM Please respond to rv-list@matronics .com Hello Sam Did you required a special cable to hook up your handheld GPS to your TRIO? I have a Garmin 295 that I could use for this purpose or the GPS built in my BMA Efis Lite G3. Cheers Bruno ---------------------------------------------------------------------- From: bobperk90658(at)bellsouth.net Subject: Re: RV-List: Trio EZ-Pilot or Altitude Hold Sam, You know that the accuracy of the GPS coupled to the autopilot is proba bly what caused the Brazilian GOL 737, and the Embraer Legacy 600 Collision in October 06 both were at 37,000 feet and on opposing courses between Brasilia an d Manause, both probably used the airport coordinates in a common data base. Ther e are probably not more than 75 airplanes in the air in northern Brasil a t one time. Sometimes being accurate down to the micron is not good, and being able to fly an offset course is good. The Trio will do that easily all day long. Just a thought. Trying to justify being a sloppy pilot }:>) Bob Perkinson I still marvel at how a sub-$2000 autopilot can hold my plane within a wingspan of the course line with an inexpensive handheld GPS providing the data! How many King Airs and Citations can match that? :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
Take a look at Randy's Lervold's write-up of his RV-3B paint process. I've seen the final outcome and it looks great. He is a meticulous and thoughtful builder, so you can trust his commentary. I have never painted more than the interior walls of my house, so cannot say anything about this topic, but the statement below, "the prep work...takes a lot of time and that's why your local shop wants..." $$ is the truth. You just need to know what to do and how to do it. Then you need to decide if your labor is worth the savings. Applying the paint is the skill part. The rest is time and effort. http://www.romeolima.com/RV3hq/Paint/paint.htm John J 40328 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Andy Gold Sent: Thursday, December 13, 2007 9:59 AM Subject: Re: RV-List: Cost of Paint Job I painted my plane with three colors of Imron. The total cost of materials was about $400. I did all the prep work myself, built a booth in my garage, and asked a local pro to come over and squirt the top coat. He did a great job and had about 2 hours into the whole thing. I bought him a case of scotch and went flying with him a couple times. Everyone walked away very happy. With mine, the prep work was just that - "work". Its nothing difficult or anything that requries any unusual skills. But it takes a lot of time and that's why your local shop wants $7200. The only part of the job that takes skill and experience to get right is the final squirt. If you want to see how to prep and paint your RV, get Sam James's Painting 101 video. (Its at Builder's Bookstore www.buildersbooks.com ) Andy ----- Original Message ----- From: "Shemp" <shempdowling(at)gmail.com> Sent: Thursday, December 13, 2007 9:59 AM Subject: RV-List: Cost of Paint Job > > I'm shopping around for a paint job and am getting sticker shock. The > only "local" shop around Chicago told me his last RV paint job was $7200. > I thought they typically cost around 5000. I've spent a lot of time on my > glass stuff and its pretty much ready to paint. Anyone have a cost of a > good relatively simple 2 color paint job that didnt require a lot of work > by the painters? > > Shemp > 300+ > 6a > Chicago > > mike humphrey wrote: >> >> >> Mike, >> In my hanger I have the T-12 cold weather 8' units. Great lighting, work >> in cold fine, easy to replace, just started replacing bulbs after 3 1/2 >> years continual use, pricey but great lighting. Lowe's carries the 8' >> fixture and bulbs(green ends and they just push in, no twisting). In my >> work areas I have added specific lighting to the situation. Bandsaw, >> lathe, drill press (dangerous areas) have separate lighting on switches. >> I would not hang any lighting on the 16' ceiling though. Lighting >> disperses geometrically. So whatever lighting that you choose, suspend >> it from some cheap chain and lower it to about 2-3 feet above your >> highest point on the floor, ie tail of plane. Reflectors are cheaper >> than lighting units and you will save electricity which equals $. More $ >> to spend on RV's. Remember, whatever lighting that you put in, you will >> not want to replace anytime soon, if ever, by lowering your units, >> maintenance will be easier also, unless you just happen to have a 16' >> step ladder. >> Mike H >> 9A/8A >> ----- Original Message ----- From: "Michael Kraus" >> >> To: >> Sent: Monday, December 10, 2007 8:01 AM >> Subject: RV-List: Off Topic: Hanger Lighting >> >> >>> >>> >>> >>> >>> I am building a new hanger on my house and was looking for information >>> on what type of hanger lighting to install. The ceilings will be 16' >>> tall and it is 44' x 60'. I would like good work lighting throughout. >>> Also, if anyone knows of the light spacing it would help. >>> >>> Thanks >>> -Mike Kraus >>> RV-4 Flying >>> RV-10 wiring >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 13, 2007
Andy Gold wrote: > > I painted my plane with three colors of Imron. The total cost of > materials was about $400. I did all the prep work myself, built a booth > in my garage, and asked a local pro to come over and squirt the top > coat. He did a great job and had about 2 hours into the whole thing. I > bought him a case of scotch and went flying with him a couple times. > Everyone walked away very happy. > > With mine, the prep work was just that - "work". Its nothing difficult > or anything that requries any unusual skills. But it takes a lot of > time and that's why your local shop wants $7200. The only part of the > job that takes skill and experience to get right is the final squirt. > > If you want to see how to prep and paint your RV, get Sam James's > Painting 101 video. (Its at Builder's Bookstore www.buildersbooks.com ) > When I painted my RV-6 eight years ago, my cost of materials (PPG Concept single stage) was close to $1000. Wish I could've sprayed my plane in two hours...bet I had 15 hours just in masking.............. )-: I used to think aircraft paint jobs were outrageously priced. After painting a couple of planes, I am amazed a paint shop can stay in business by only charging $7000. Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
Bruno wrote: > Hello Sam > > Did you required a special cable to hook up your handheld GPS to your > TRIO? > > I have a Garmin 295 that I could use for this purpose or the GPS > built in my BMA Efis Lite G3. > > Cheers > > Bruno Bruno, the cable is special only in the sense that it has to have the proper connector to plug into the GPS. Most GPS vendors have a data/power cable for the popular models, and all you have to do is connect the data transmit wire in the cable to the EZ-Pilot. Just make sure you Garmin can send NMEA data (most if not all Garmins can). The BMA unit may be a little problematic. From reading the BMA forum, I know there have been issues with getting good NMEA out of some of the BMA devices, a call to Greg or the guys at Trio might be in order. Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
I had my -8 painted two summers ago. I probably got a dozen quotes from companies with RV experience from all over the country. Mine was a multi-colored paint scheme and my quotes ranged from about $4900 to $7000 for a single stage job and $6500 to $12,000 for a base coat/clear coat job. I decided on a base coat/clear coat for $8500 from Prestige Paint in upsate Vermont (see the Yellerpages). I would suggest you shop around. Additionally, virtually every shop I spoke to said they include a few hours labor for prep in their quote because they rarely experienced an airplane that was indeed ready for final color coating. You'll be hard pressed to get them to quote less unless they see your work. Rick McBride RV-8 N523RJ >From: Shemp <shempdowling(at)gmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Cost of Paint Job >Date: Thu, 13 Dec 2007 10:59:57 -0600 > > >I'm shopping around for a paint job and am getting sticker shock. The only >"local" shop around Chicago told me his last RV paint job was $7200. I >thought they typically cost around 5000. I've spent a lot of time on my >glass stuff and its pretty much ready to paint. Anyone have a cost of a >good relatively simple 2 color paint job that didnt require a lot of work >by the painters? > >Shemp >300+ >6a >Chicago > >mike humphrey wrote: >> >> >>Mike, >>In my hanger I have the T-12 cold weather 8' units. Great lighting, work >>in cold fine, easy to replace, just started replacing bulbs after 3 1/2 >>years continual use, pricey but great lighting. Lowe's carries the 8' >>fixture and bulbs(green ends and they just push in, no twisting). In my >>work areas I have added specific lighting to the situation. Bandsaw, >>lathe, drill press (dangerous areas) have separate lighting on switches. >>I would not hang any lighting on the 16' ceiling though. Lighting >>disperses geometrically. So whatever lighting that you choose, suspend it >>from some cheap chain and lower it to about 2-3 feet above your highest >>point on the floor, ie tail of plane. Reflectors are cheaper than >>lighting units and you will save electricity which equals $. More $ to >>spend on RV's. Remember, whatever lighting that you put in, you will not >>want to replace anytime soon, if ever, by lowering your units, maintenance >>will be easier also, unless you just happen to have a 16' step ladder. >>Mike H >>9A/8A >>----- Original Message ----- From: "Michael Kraus" >> >>To: >>Sent: Monday, December 10, 2007 8:01 AM >>Subject: RV-List: Off Topic: Hanger Lighting >> >> >>> >>> >>> >>>I am building a new hanger on my house and was looking for information on >>>what type of hanger lighting to install. The ceilings will be 16' tall >>>and it is 44' x 60'. I would like good work lighting throughout. Also, >>>if anyone knows of the light spacing it would help. >>> >>>Thanks >>>-Mike Kraus >>>RV-4 Flying >>>RV-10 wiring >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 13, 2007
In a message dated 12/13/2007 12:36:18 PM Central Standard Time, sbuc(at)hiwaay.net writes: I used to think aircraft paint jobs were outrageously priced. After painting a couple of planes, I am amazed a paint shop can stay in business by only charging $7000. >>> Same here. Doug Reeves used to have paint shop reviews on his Vans Air Force website, but it looks like they are gone. Here is a description of my most excellent paint shop experience, courtesy of Bobby Potts at TCL, Tuscaloosa, AL (you didn't REALLY want to paint in the snow, didja?!). Damage was $7K almost 3yrs ago, and very happy to pay it: _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) (The Expercraft website seems to down right now, but try later- select Painting link from bottom of left column of homepage above) Mark Phillips Columbia, TN **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Re: Public vs Private use airpark - I know a little off topic
Going public will make your airport property tax exempt...no property taxes on the runway and hangars. The airpark we live on is a public airport and as such has to be inspected by the state aviation department once a year. Insurance is reasonable, under $3K/year. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Dec 13, 2007
>When I painted my RV-6 eight years ago, my cost of materials (PPG >Concept single stage) was close to $1000. > >Wish I could've sprayed my plane in two hours...bet I had 15 hours >just in masking.............. )-: > >Sam Buchanan I agree. And I only painted a single color with no primer! Even with a single color, you still have to mask!?! Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Re: : TRIO AUTOPILOT & Anywhere Map/iPaq?
Can the Trio read the signal from a hand held iPaq and Anywhere Map? Kim Nicholas Seattle RV9A **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 13, 2007
Heres a pic of my 6a getting painted at my shop. I parked it in front during the day to showoff but had to move it because it caused a few accidents with the traffic out front. Any quality auto paint shop can do a great job. Just pull the wings and flatbed the fuse. I did mine in basecoat clearcoat because the painters were most familiar with that system. I think I have 500-600 in materials and 20hrs of shop time. Steve dinieri Iflyrv10 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan Sent: Thursday, December 13, 2007 1:31 PM Subject: Re: RV-List: Cost of Paint Job Andy Gold wrote: > > I painted my plane with three colors of Imron. The total cost of > materials was about $400. I did all the prep work myself, built a booth > in my garage, and asked a local pro to come over and squirt the top > coat. He did a great job and had about 2 hours into the whole thing. I > bought him a case of scotch and went flying with him a couple times. > Everyone walked away very happy. > > With mine, the prep work was just that - "work". Its nothing difficult > or anything that requries any unusual skills. But it takes a lot of > time and that's why your local shop wants $7200. The only part of the > job that takes skill and experience to get right is the final squirt. > > If you want to see how to prep and paint your RV, get Sam James's > Painting 101 video. (Its at Builder's Bookstore www.buildersbooks.com ) > When I painted my RV-6 eight years ago, my cost of materials (PPG Concept single stage) was close to $1000. Wish I could've sprayed my plane in two hours...bet I had 15 hours just in masking.............. )-: I used to think aircraft paint jobs were outrageously priced. After painting a couple of planes, I am amazed a paint shop can stay in business by only charging $7000. Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
Man, am I glad I'm going the polished route!! I think I can do the few fiberglass parts with spray bombs from Wal Mart... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Andy Gold wrote: > > I painted my plane with three colors of Imron. The total cost of > materials was about $400. I did all the prep work myself, built a > booth in my garage, and asked a local pro to come over and squirt the > top coat. He did a great job and had about 2 hours into the whole > thing. I bought him a case of scotch and went flying with him a couple > times. Everyone walked away very happy. > > With mine, the prep work was just that - "work". Its nothing difficult > or anything that requries any unusual skills. But it takes a lot of > time and that's why your local shop wants $7200. The only part of the > job that takes skill and experience to get right is the final squirt. > > If you want to see how to prep and paint your RV, get Sam James's > Painting 101 video. (Its at Builder's Bookstore www.buildersbooks.com ) > > Andy > > > ----- Original Message ----- From: "Shemp" <shempdowling(at)gmail.com> > To: > Sent: Thursday, December 13, 2007 9:59 AM > Subject: RV-List: Cost of Paint Job > > >> >> I'm shopping around for a paint job and am getting sticker shock. >> The only "local" shop around Chicago told me his last RV paint job >> was $7200. I thought they typically cost around 5000. I've spent a >> lot of time on my glass stuff and its pretty much ready to paint. >> Anyone have a cost of a good relatively simple 2 color paint job that >> didnt require a lot of work by the painters? >> >> Shemp >> 300+ >> 6a >> Chicago >> >> mike humphrey wrote: >> >>> >>> >>> Mike, >>> In my hanger I have the T-12 cold weather 8' units. Great lighting, >>> work in cold fine, easy to replace, just started replacing bulbs >>> after 3 1/2 years continual use, pricey but great lighting. Lowe's >>> carries the 8' fixture and bulbs(green ends and they just push in, >>> no twisting). In my work areas I have added specific lighting to >>> the situation. Bandsaw, lathe, drill press (dangerous areas) have >>> separate lighting on switches. I would not hang any lighting on the >>> 16' ceiling though. Lighting disperses geometrically. So whatever >>> lighting that you choose, suspend it from some cheap chain and lower >>> it to about 2-3 feet above your highest point on the floor, ie tail >>> of plane. Reflectors are cheaper than lighting units and you will >>> save electricity which equals $. More $ to spend on RV's. >>> Remember, whatever lighting that you put in, you will not want to >>> replace anytime soon, if ever, by lowering your units, maintenance >>> will be easier also, unless you just happen to have a 16' step ladder. >>> Mike H >>> 9A/8A >>> ----- Original Message ----- From: "Michael Kraus" >>> >>> To: >>> Sent: Monday, December 10, 2007 8:01 AM >>> Subject: RV-List: Off Topic: Hanger Lighting >>> >>> >>>> >>>> >>>> >>>> >>>> I am building a new hanger on my house and was looking for >>>> information on what type of hanger lighting to install. The >>>> ceilings will be 16' tall and it is 44' x 60'. I would like good >>>> work lighting throughout. Also, if anyone knows of the light >>>> spacing it would help. >>>> >>>> Thanks >>>> -Mike Kraus >>>> RV-4 Flying >>>> RV-10 wiring >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 13, 2007
I just got done having my plane painted. I also shopped around and had quotes of $7000 (plus any required body work) to $10,000. I decided it was too much and would do it on my own. Boy was I naive! I couldn't do anything in my own hangar at a public airport, so I made arrangements to work at a friend's hangar at an airpark. I proceeded to take the whole airplane apart and set up a paint booth in a Costco car tent in my back yard. I bought a big compressor and a DeVilbiss FinishLine 3 HVLP gun. Based on Randy Lervold's recommendations, I went with PPG Concept. I washed, acid etched, scuffed and alodyned all the aluminum. I spent a lot of time on the fiberglass and used almost a whole gallon of K38 high build primer, most of which ended up on everything in my shop when I sanded it off. I also used quite a bit of SuperFil. I started painting the color coats with white Concept. It wasn't great, but it wasn't horrible either. Had the usual problems with dust, runs, and orange peel. There is a real art to putting on the final coat. You really can't sand very much because you will cut through a rivet or just a high spot on the aluminum. When I painted the empennage fairing with a dark blue, I kind of lost it. The one piece had orange peel, runs, and dust everywhere, even with fans and filters. I decided I couldn't do a job I would be happy with. I went back to the shop who quoted $10,000 and asked them how much just to put on the color. They said between $3000 and $4000. Based on really good review from a person I trust (Terry Burch), I decided to go ahead an do that. I brought the pieces to them in sanded primer/sealer. They had to spray a coat of primer and then basecoat clearcoat. I ended up eating some Concept, but that's the way it goes. I spent upwards of 200 hours over the summer doing the prep and priming. I know it's a lot of hours, but there is a lot to do, especially with the fiberglass work. There are a lot of pin holes and they will show up if you don't totally take care of them. I had one of the very first S type cowls, and it was rough in places. I ended up spending about $3000 for materials plus $3800 to the paint shop. This doesn't count the compressor, paint gun, tent, lights, fans, etc. Plenty of people paint there own airplanes, and I admire them for it. It is a lot of work. I took my plane down in late April and didn't fly again until September. In hindsight, I really wished I had just bit the bullet and had the whole thing done. That is one person's opinion. Your mileage may vary. If your curious on how it came out, check out: home.comcast.net/~doug.medema. Doug Medema RV-6A N276DM Date: 12/13/2007 9:15 AM ________________________________________________________________________________
From: "Russell Lassetter" <rblassett(at)alltel.net>
Date: Dec 13, 2007
Doug, Man you hit the nail on the head. I've painted a few airplanes and the amount of work required for a nice finish is much more than you would think. Russ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Doug Medema Sent: Thursday, December 13, 2007 6:13 PM To: RV-List(at)matronics.com Subject: RV-List: Re: Cost of Paint Job I just got done having my plane painted. I also shopped around and had quotes of $7000 (plus any required body work) to $10,000. I decided it was too much and would do it on my own. Boy was I naive! ________________________________________________________________________________
Date: Dec 13, 2007
Hi Doug, Good advice. There is the pride of having done most of it yourself and I'm sure it was a good learning experience. Regardless of how you got there the plane looks fabulous! I can't wait to see it in person. Dave, RV6 _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Doug Medema Sent: Thursday, December 13, 2007 3:13 PM Subject: RV-List: Re: Cost of Paint Job I just got done having my plane painted ________________________________________________________________________________
Date: Dec 13, 2007
Knicholas2(at)aol.com wrote: > Can the Trio read the signal from a hand held iPaq and Anywhere Map? > > Kim Nicholas > Seattle > RV9A Kim, the last I heard on this matter was....no. It seems AWM doesn't send the data in a format that EZ-Pilot needs in order to clear the tight filters that are part of the Trio software. I know Trio was working with a customer that had AWM so I suggest a call to Trio to make sure some recent developments haven't proved me wrong. Sam Buchanan ________________________________________________________________________________
Date: Dec 13, 2007
I have a 396 and it works fine. There is a special connector you can get from Garmin and others that has single wires coming out to splice into your autopilot harness. I think I got mine right from Garmin if I remember. Paul Besing ----- Original Message ---- From: Michael W Stewart <mike.stewart(at)us.ibm.com> Sent: Thursday, December 13, 2007 11:21:43 AM Subject: Re: RV-List: TRIO AUTOPILOT Both can be used to drive the Trio. I know cause I have done so with both myself. Mike Bruno Bruno Sent by: owner-rv-list-server(at)matronics.com 12/13/2007 11:41 AM Please respond to rv-list(at)matronics.com To RV LIST cc Subject RV-List: TRIO AUTOPILOT Hello Sam Did you required a special cable to hook up your handheld GPS to your TRIO? I have a Garmin 295 that I could use for this purpose or the GPS built in my BMA Efis Lite G3. Cheers Bruno ---------------------------------------------------------------------- From: bobperk90658(at)bellsouth.net Subject: Re: RV-List: Trio EZ-Pilot or Altitude Hold Sam, You know that the accuracy of the GPS coupled to the autopilot is probably what caused the Brazilian GOL 737, and the Embraer Legacy 600 Collision in October 06 both were at 37,000 feet and on opposing courses between Brasilia and Manause, both probably used the airport coordinates in a common data base. There are probably not more than 75 airplanes in the air in northern Brasil at one time. Sometimes being accurate down to the micron is not good, and being able to fly an offset course is good. The Trio will do that easily all day long. Just a thought. Trying to justify being a sloppy pilot }:>) Bob Perkinson I still marvel at how a sub-$2000 autopilot can hold my plane within a wingspan of the course line with an inexpensive handheld GPS providing the data! How many King Airs and Citations can match that? :-) Sam Buchanan Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Dec 13, 2007
Sam Buchanan wrote: > > Knicholas2(at)aol.com wrote: >> Can the Trio read the signal from a hand held iPaq and Anywhere Map? >> >> Kim Nicholas >> Seattle >> RV9A Update: I have just been informed from a *very* good source (its amazing how many vendors monitor these forums!) that at least some of the versions of AnywhereMap software do indeed output a data stream that works nicely with the EZ-Pilot. However.....the problem lies with the new PDA platforms that don't provide a serial port. Many of the newest PDAs only provide Bluetooth connectivity and there is considerable concern as to whether or not Bluetooth is reliable enough to be driving an autopilot, and Trio doesn't support Bluetooth connectivity. So, if you have an older PDA that has a RS232 data port, AWM may indeed drive an autopilot. When I was actively using AWM in their earlier days, it would sorta drive my old Navaid, but left me high and dry when I upgraded to the EZ-Pilot. Apparently some of the newer versions of the software play nice with the EZ-Pilot. As usual, the best course to take is to call the vendors and get the scoop directly from them. Sam Buchanan ________________________________________________________________________________
Date: Dec 14, 2007
Subject: Server Issue?: RV-List Digest: 9 Msgs - 12/09/07
Is anyone besides me getting bombarded with multiple copies of the digest below? E-mails to Matronics have gone unanswered. - Alan On Mon, December 10, 2007 2:57 am, RV-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-12-09&Archive=RV > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-12-09&Archive=RV > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV-List Digest Archive > --- > Total Messages Posted Sun 12/09/07: 9 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:52 AM - Re: KLX-135A Internal Battery (David Burton) > 2. 06:52 AM - Re: Condition Inspection Log Entry (Tim Bryan) > 3. 07:29 AM - Re: KLX-135A Internal Battery (Denis Walsh) > 4. 08:35 AM - Apollo GX?? was:KLX-135A Internal Battery (RV6 Flyer) > 5. 08:36 AM - F697 thickness? (hat section in front deck structure) > (ceengland(at)bellsouth.net) > 6. 09:14 AM - Re: F697 thickness? (hat section in front deck > structure) (Bob Collins) > 7. 10:35 AM - Re: KLX-135A Internal Battery (Vanremog(at)aol.com) > 8. 04:38 PM - Re: F697 thickness? (hat section in front deck > structure) (Charlie England) > 9. 05:41 PM - GRETZ AERO ELECTRIC TRIM MOD FOR RV-4 (RV4WGH(at)aol.com) > <...> ________________________________________________________________________________
Date: Dec 15, 2007
Subject: O-320
Hello all, I'm at the point on my RV-4 project that I have to cough up a wad of cash & buy an O-320. I'm contemplating purchasing an experimental engine from one of the following: Van's, Mattituck, or Aerosport. I live about 20 minutes from Matittuck, so I'm leaning in that direction, any thoughts? Hal Benjamin RV-4 Long Island, New York ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: O-320
I've heard nothing but great things about Aerosport, but no experience with them or any other. I'm a long way from needing things that go vroom ;) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) halbenjamin(at)optonline.net wrote: > Hello all, > > I'm at the point on my RV-4 project that I have to cough up a wad of > cash & buy an O-320. I'm contemplating purchasing an experimental > engine from one of the following: Van's, Mattituck, or Aerosport. I > live about 20 minutes from Matittuck, so I'm leaning in that > direction, any thoughts? > > Hal Benjamin RV-4 > Long Island, New York ________________________________________________________________________________
Subject: Re: O-320
Date: Dec 14, 2007
YEP. Go for Mattituck if they are your Neighbors anyway. And if you are unhappy for whatever unforeseen reason that may crop up, then you can go to actually see them face to face to resolve the problem... ----- Original Message ----- From: halbenjamin(at)optonline.net To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 8:15 PM Subject: RV-List: O-320 Hello all, I'm at the point on my RV-4 project that I have to cough up a wad of cash & buy an O-320. I'm contemplating purchasing an experimental engine from one of the following: Van's, Mattituck, or Aerosport. I live about 20 minutes from Matittuck, so I'm leaning in that direction, any thoughts? Hal Benjamin RV-4 Long Island, New York ________________________________________________________________________________
Date: Dec 14, 2007
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Subject: Re: O-320
I'd say that's a givin, buy from Matittuck! I'd go there and build it if you could, I think they have a program that allows you to do that. ---- Surfing the web from Hopkinsville, KY Visit my RV7A web site: http://www.geocities.com/hester-hoptown/RVSite/ halbenjamin(at)optonline.net wrote: > Hello all, > > I'm at the point on my RV-4 project that I have to cough up a wad of > cash & buy an O-320. I'm contemplating purchasing an experimental > engine from one of the following: Van's, Mattituck, or Aerosport. I > live about 20 minutes from Matittuck, so I'm leaning in that > direction, any thoughts? > > Hal Benjamin RV-4 > Long Island, New York ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: O-320
Hey Hal, I live in Mattituck and originally wanted to buy locally at the time but it was less expensive for me to buy from Aerosport and pay the shipping than to drive five minutes and pick it up from Mattituck. I have no idea how competitive they are now. Aerosport has a good reputation and I have no regrets having bought from them. There was only one or two times I had to contact Aerosport after the purchase during the installation and they were very helpful. I would suggest delaying buying from anyone for as long as possible because in my case it was still about two years from purchase to first run. Where are you building? Bob (RV6n) at FOK ----- Original Message ----- From: halbenjamin(at)optonline.net Date: Friday, December 14, 2007 10:31 pm Subject: RV-List: O-320 > Hello all, > > I'm at the point on my RV-4 project that I have to cough up a > wad of cash & buy an O-320. I'm contemplating purchasing an > experimental engine from one of the following: Van's, Mattituck, > or Aerosport. I live about 20 minutes from Matittuck, so I'm > leaning in that direction, any thoughts? > > Hal Benjamin RV-4 > Long Island, New York > ________________________________________________________________________________
Subject: Re: O-320
Date: Dec 15, 2007
I agree with Konrad but FWIW ........I have been very pleased with the O-360 purchased from Aerosport Power. Now has 179 hours. Needed to contact them two times and their response was excellent. Dale Ensing RV-6A ----- Original Message ----- From: Konrad L. Werner To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 10:32 PM Subject: Re: RV-List: O-320 YEP. Go for Mattituck if they are your Neighbors anyway. And if you are unhappy for whatever unforeseen reason that may crop up, then you can go to actually see them face to face to resolve the problem... ----- Original Message ----- From: halbenjamin(at)optonline.net To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 8:15 PM Subject: RV-List: O-320 Hello all, I'm at the point on my RV-4 project that I have to cough up a wad of cash & buy an O-320. I'm contemplating purchasing an experimental engine from one of the following: Van's, Mattituck, or Aerosport. I live about 20 minutes from Matittuck, so I'm leaning in that direction, any thoughts? Hal Benjamin RV-4 Long Island, New York ________________________________________________________________________________
Subject: Re: O-320
Date: Dec 15, 2007
Perhaps the other reason would be *final cost*... I'd get a bid from each of the many engine builders and shop around for what you really want. I don't know what the sales tax situation is like in L.I.,NY, but it may even cost more in sales tax alone then what it would cost for getting a Bartized Lycosaurus shipped from Canada. Aerosport Power has certainly earned themselves a stellar reputation (not to put down Mattituck, PenYan, LyCon and the various many other custom shops). Your call, but I would simply visit Mattituck to see what they would have in store for you, and then compare apples to apples... Good Luck! ----- Original Message ----- From: Dale Ensing To: rv-list(at)matronics.com Sent: Saturday, December 15, 2007 6:03 AM Subject: Re: RV-List: O-320 I agree with Konrad but FWIW ........I have been very pleased with the O-360 purchased from Aerosport Power. Now has 179 hours. Needed to contact them two times and their response was excellent. Dale Ensing RV-6A ----- Original Message ----- From: Konrad L. Werner To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 10:32 PM Subject: Re: RV-List: O-320 YEP. Go for Mattituck if they are your Neighbors anyway. And if you are unhappy for whatever unforeseen reason that may crop up, then you can go to actually see them face to face to resolve the problem... ----- Original Message ----- From: halbenjamin(at)optonline.net To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 8:15 PM Subject: RV-List: O-320 Hello all, I'm at the point on my RV-4 project that I have to cough up a wad of cash & buy an O-320. I'm contemplating purchasing an experimental engine from one of the following: Van's, Mattituck, or Aerosport. I live about 20 minutes from Matittuck, so I'm leaning in that direction, any thoughts? Hal Benjamin RV-4 Long Island, New York href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: O-320
Date: Dec 15, 2007
Just to throw a wrench in the deal, I have from some builders that the import of goods from Canada triggers their local tax authority and they have gotten hefty bills. In our case, the state of OK passed HB1577 last year exempting all aircraft parts/repairs from sales tax to the end user. I have a customer in another state whose friend is over tax collection, and there has been discussion that the state he resides in may not be able to collect tax on his engine because of our state doesn't tax anyone, including its own residents for aircraft parts. If you have an accountant, you could always ask them to write the tax commission for a ruling on the taxability of the item by giving a hypothetical situation. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Konrad L. Werner Sent: Saturday, December 15, 2007 9:22 AM Subject: Re: RV-List: O-320 Perhaps the other reason would be *final cost*... I'd get a bid from each of the many engine builders and shop around for what you really want. I don't know what the sales tax situation is like in L.I.,NY, but it may even cost more in sales tax alone then what it would cost for getting a Bartized Lycosaurus shipped from Canada. Aerosport Power has certainly earned themselves a stellar reputation (not to put down Mattituck, PenYan, LyCon and the various many other custom shops). Your call, but I would simply visit Mattituck to see what they would have in store for you, and then compare apples to apples... Good Luck! ----- Original Message ----- From: Dale Ensing <mailto:densing(at)carolina.rr.com> To: rv-list(at)matronics.com Sent: Saturday, December 15, 2007 6:03 AM Subject: Re: RV-List: O-320 I agree with Konrad but FWIW ........I have been very pleased with the O-360 purchased from Aerosport Power. Now has 179 hours. Needed to contact them two times and their response was excellent. Dale Ensing RV-6A ----- Original Message ----- From: Konrad L. Werner <mailto:klwerner(at)comcast.net> To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 10:32 PM Subject: Re: RV-List: O-320 YEP. Go for Mattituck if they are your Neighbors anyway. And if you are unhappy for whatever unforeseen reason that may crop up, then you can go to actually see them face to face to resolve the problem... ----- Original Message ----- From: halbenjamin(at)optonline.net To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 8:15 PM Subject: RV-List: O-320 Hello all, I'm at the point on my RV-4 project that I have to cough up a wad of cash & buy an O-320. I'm contemplating purchasing an experimental engine from one of the following: Van's, Mattituck, or Aerosport. I live about 20 minutes from Matittuck, so I'm leaning in that direction, any thoughts? Hal Benjamin RV-4 Long Island, New York href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.c o m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.c o m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: 60s
In a message dated 12/15/2007 1:36:27 A.M. Pacific Standard Time, wnorth(at)sdccd.edu writes: In the time memorialized words of Aldus Huxley "Ooh that was a bad trip, please do not archive." ================================================ Anyone who has read The Doors of Perception gets the nod in my book, even if he misspells Aldous. N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: O-320
Another important thing to consider is the warranty. I went with Aerosport Power for a variety of reasons but the deciding factor for me was the warranty. It's associated with the first start rather than with the purchase date. "Konrad L. Werner" wrote: Perhaps the other reason would be *final cost*... I'd get a bid from each of the many engine builders and shop around for what you really want. I don't know what the sales tax situation is like in L.I.,NY, but it may even cost more in sales tax alone then what it would cost for getting a Bartized Lycosaurus shipped from Canada. Aerosport Power has certainly earned themselves a stellar reputation (not to put down Mattituck, PenYan, LyCon and the various many other custom shops). Your call, but I would simply visit Mattituck to see what they would have in store for you, and then compare apples to apples... Good Luck! ----- Original Message ----- From: Dale Ensing To: rv-list(at)matronics.com Sent: Saturday, December 15, 2007 6:03 AM Subject: Re: RV-List: O-320 I agree with Konrad but FWIW ........I have been very pleased with the O-360 purchased from Aerosport Power. Now has 179 hours. Needed to contact them two times and their response was excellent. Dale Ensing RV-6A ----- Original Message ----- From: Konrad L. Werner To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 10:32 PM Subject: Re: RV-List: O-320 YEP. Go for Mattituck if they are your Neighbors anyway. And if you are unhappy for whatever unforeseen reason that may crop up, then you can go to actually see them face to face to resolve the problem... ----- Original Message ----- From: halbenjamin(at)optonline.net To: rv-list(at)matronics.com Sent: Friday, December 14, 2007 8:15 PM Subject: RV-List: O-320 Hello all, I'm at the point on my RV-4 project that I have to cough up a wad of cash & buy an O-320. I'm contemplating purchasing an experimental engine from one of the following: Van's, Mattituck, or Aerosport. I live about 20 minutes from Matittuck, so I'm leaning in that direction, any thoughts? Hal Benjamin RV-4 Long Island, New York href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: Wheel pants fairings etc.
bert murillo wrote: > Hi: I have posted a couple messages, no respond.. I will try again. > Does any one knows, any one that sells the fairings for the > rv6a...the wheels and legs fairings... other than Van's or Bob's I > do not want to pay that kind of money...I will be willing to pay $150 > for the set.. Bert, I think you will have to raise your threshold in order to purchase ready-made fairings. I have been flying the TeamRocket fairings for several years: http://www.teamrocketaircraft.com/TeamRocketAircraftcgi/hazel.exe Their fairings are $150 for the set but you must use their gear leg fairings. Here are details of my installation: http://thervjournal.com/fairings.htm Sam Buchanan ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: 60s
Adios Huxley. Wasnt he one of our esteemed congress persons who opened The Doors to our current immigration policies? Perceived or otherwise. Unsigned to prevent visits in the night. Vanremog(at)aol.com wrote: In a message dated 12/15/2007 1:36:27 A.M. Pacific Standard Time, wnorth(at)sdccd.edu writes: In the time memorialized words of Aldus Huxley "Ooh that was a bad trip, please do not archive." ======================= Anyone who has read The Doors of Perception gets the nod in my book, even if he misspells Aldous. N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) --------------------------------- See AOL's top rated recipes and easy ways to stay in shape for winter. "No pressure, no diamonds". ~Thomas Carlyle ________________________________________________________________________________
Date: Dec 15, 2007
In a message dated 12/15/2007 4:55:59 PM Central Standard Time, robertrv 607(at)yahoo.com writes: I will be willing to pay $150 for the set.. Can you be more specific? Are you talking about the pants, leg fairings AND upper & lower intersection fairings? Plus, I noticed you are one of the smart guys like me with a nosewheel (uh-oh!!) which means three of everything, basically- I think you could spend almost that much just for tools & material to make them all- Other wise, can some one tell me how difficult would be to make my own..... If you are a masochist, that helps. There are those who actually "enjoy" delving into the black art of fiberglass, but IMHO they retire to padded rooms in the evening. 8-) Seriously, unless you already know how to work this stuff, you could spend a great deal of $time$ learning the mysteries of fiberglass. But if you have the patience and time, you could sure get all the information you need off the Internet. Browse these publications offered by The Builders Bookstore: _http://www.actechbooks.com/airframeCOMPOSITES.htm_ (http://www.actechbooks.com/airframeCOMPOSITES.htm) Even buying the parts offered by Van's, Fairings etc. and Team Rocket (among others) will result in much time spent whipping them into useable condition. If your personal standards for fit/finish are particularly high, you will spend much, much more time. I have used components from all of the above and they are all OK if all you want is OK- if you want exceptional, buy from the same places and plan on a lot of shoptime fine-tuning each part. My personal experience is that the offerings from the latter two are pretty darn good- especially that upper nosewheel fairing from Fairings etc. that was an almost perfect fit right out of the box- (Thanks, Bob!) Here's some of my log entries from building my plane, if interested: _http://websites.expercraft.com/n51pw/index.php?q=log_list&c=68_ (http://websites.expercraft.com/n51pw/index.php?q=log_list&c=68) Have fun! Mark Phillips Columbia, TN _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 15, 2007
I will be willing to pay $150 for the set.. My suggestion is either forget about using them and the significanty speed penalty that you will pay OR Pay the price and be done with it. Don't make a few flights if you have to to "pay" for the cost. OR Place a WTB ad somewhere and hope that someone wants to sell theirs Ron Lee ________________________________________________________________________________
Date: Dec 16, 2007
Subject: Re: O-320
Thanks to all for the comments. I'll be talking to Aerosport next week & figure it out from there. Hal Benjamin RV-4 HWV - Long Island, New York ----- Original Message ----- From: Dan Reeves Date: Saturday, December 15, 2007 3:12 pm Subject: Re: RV-List: O-320 > Another important thing to consider is the warranty. I went > with Aerosport Power for a variety of reasons but the deciding > factor for me was the warranty. It's associated with the first > start rather than with the purchase date. > > "Konrad L. Werner" wrote: > Perhaps the other reason would be *final cost*... I'd get a bid > from each of the many engine builders and shop around for what > you really want. I don't know what the sales tax situation is > like in L.I.,NY, but it may even cost more in sales tax alone > then what it would cost for getting a Bartized Lycosaurus > shipped from Canada. Aerosport Power has certainly earned > themselves a stellar reputation (not to put down Mattituck, > PenYan, LyCon and the various many other custom shops). Your > call, but I would simply visit Mattituck to see what they would > have in store for you, and then compare apples to apples... > Good Luck! > ----- Original Message ----- > From: Dale Ensing > To: rv-list(at)matronics.com > Sent: Saturday, December 15, 2007 6:03 AM > Subject: Re: RV-List: O-320 > > > I agree with Konrad but FWIW ........I have been very pleased > with the O-360 purchased from Aerosport Power. Now has 179 > hours. Needed to contact them two times and their response was > excellent. Dale Ensing > RV-6A > ----- Original Message ----- > From: Konrad L. Werner > To: rv-list(at)matronics.com > Sent: Friday, December 14, 2007 10:32 PM > Subject: Re: RV-List: O-320 > > > YEP. Go for Mattituck if they are your Neighbors anyway. And > if you are unhappy for whatever unforeseen reason that may crop > up, then you can go to actually see them face to face to resolve > the problem... > ----- Original Message ----- > From: halbenjamin(at)optonline.net > To: rv-list(at)matronics.com > Sent: Friday, December 14, 2007 8:15 PM > Subject: RV-List: O-320 > > > Hello all, > > I'm at the point on my RV-4 project that I have to cough up a > wad of cash & buy an O-320. I'm contemplating purchasing an > experimental engine from one of the following: Van's, Mattituck, > or Aerosport. I live about 20 minutes from Matittuck, so I'm > leaning in that direction, any thoughts? > > Hal Benjamin RV-4 > Long Island, New York > > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com > > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com > > > > > --------------------------------- > Never miss a thing. Make Yahoo your homepage. > ________________________________________________________________________________
Date: Dec 15, 2007
Subject: test
My last two messages did not go thru :-( -- ---- Surfing the web from Hopkinsville, KY Visit my RV7A web site: http://www.geocities.com/hester-hoptown/RVSite/ ________________________________________________________________________________
Date: Dec 15, 2007
Subject: test
My last few messages have not made it to the list :-( -- ---- Surfing the web from Hopkinsville, KY ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Re: O-320
Aerosport, hands down. My next, middle, last, er..all engines will be from Aerosport. 'nuff said. Paul Besing ----- Original Message ---- From: Scott <acepilot(at)bloomer.net> Sent: Friday, December 14, 2007 8:27:10 PM Subject: Re: RV-List: O-320 I've heard nothing but great things about Aerosport, but no experience with them or any other. I'm a long way from needing things that go vroom ;) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) halbenjamin(at)optonline.net wrote: > Hello all, > > I'm at the point on my RV-4 project that I have to cough up a wad of > cash & buy an O-320. I'm contemplating purchasing an experimental > engine from one of the following: Van's, Mattituck, or Aerosport. I > live about 20 minutes from Matittuck, so I'm leaning in that > direction, any thoughts? > > Hal Benjamin RV-4 > Long Island, New York Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Dec 16, 2007
Subject: Re: test
That's OK. This one didn't make it either.....8*) Merry Christmas & HO HO HO. KABONG >From: Bobby Hester <bobbyhester(at)newwavecomm.net> >Date: 2007/12/15 Sat PM 10:46:02 CST >To: rv-list(at)matronics.com >Subject: RV-List: test > >My last few messages have not made it to the list :-( > >-- >---- >Surfing the web from Hopkinsville, KY > > ________________________________________________________________________________
Date: Dec 15, 2007
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: Gel Coated Fairings
Greetings: Have an "older" Emphennage Kit (circa 1999) that came with Gel Coated F.G. Fairings. 1) Do the "newer" Kits from Vans still come with the Gel Coated Fairings ? 2) My understanding from reading the Archieves is that the Gel Coat is used over Polyester Resin F.G. parts and not over Epoxy Resin F.G. Parts. Is this true ? 3) Is it worth buying from Vans the "newer" NON Gel Coated Fairings (assuming they come that way now) than trying to work with the existing Gel Coated fairings that I have ? 4) What is the purpose of the Gel Coat - mold release ? 5) What Grit / Method used - would you recommend to take off the Gel Coat (and not digging into the F.G. weave) ? 6) Is it recommended to remove ALL the Gel Coat down to the F.G. weave so that any "flexing" of the F.G. fairing will not crack any final Top Coat of paint in the future ? [My Fairing on the TOP of the VS will be removable for access to the VOR Antenna - should that be necessary and could flex during removal and crack the Top Coat of paint.] 7) Any helpful HINTS on getting a nice Fairing / Skin edge line where the Fairing meets the Skin and still keeping the Fairing removable ? [Will be using #6 Screws into Nutplates riveted to the F.G. Fairing] Appreciate your helpful inputs, Garey Wittich Santa Monica, CA Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Gel Coated Fairings
Date: Dec 16, 2007
Gareys In general, gelcoat is your friend. It supplies a smooth pinhole free surface that is more or less ready to paint. Unless your gelcoat is damaged (spiderweb cracks), or the part needs to be seriously reworked by cutting away part or adding to the part, there is no need to remove it. In fact, you'll be creating a lot of work for yourself because you'll have to completely refinish the part once you sand it down to the glass. I believe the wingtips and empennage tips are made with polyester resin and are still supplied with gelcoat. Cowlings and landing gear fairings are from epoxy resin and don't have gelcoat. On getting a nice skin/fairing line, I don't know any specific techniques other than fit, cut, fill, sand, and repeat until you're happy with the finished product. Sorry! Kyle Boatright 2001 RV-6 N46KB ----- Original Message ----- From: "Garey Wittich" <gareywittich2000(at)yahoo.com> Sent: Sunday, December 16, 2007 2:49 AM Subject: RV-List: Gel Coated Fairings > > Greetings: > > Have an "older" Emphennage Kit (circa 1999) that came > with Gel Coated F.G. Fairings. > > 1) Do the "newer" Kits from Vans still come with the > Gel Coated Fairings ? > > 2) My understanding from reading the Archieves is > that the Gel Coat is used over Polyester Resin F.G. > parts and not over Epoxy Resin F.G. Parts. Is this > true ? > > 3) Is it worth buying from Vans the "newer" NON Gel > Coated Fairings (assuming they come that way now) than > trying to work with the existing Gel Coated fairings > that I have ? > > 4) What is the purpose of the Gel Coat - mold release > ? > > 5) What Grit / Method used - would you recommend to > take off the Gel Coat (and not digging into the F.G. > weave) ? > > 6) Is it recommended to remove ALL the Gel Coat down > to the F.G. weave so that any "flexing" of the F.G. > fairing will not crack any final Top Coat of paint in > the future ? [My Fairing on the TOP of the VS will be > removable for access to the VOR Antenna - should that > be necessary and could flex during removal and crack > the Top Coat of paint.] > > 7) Any helpful HINTS on getting a nice Fairing / Skin > edge line where the Fairing meets the Skin and still > keeping the Fairing removable ? [Will be using #6 > Screws into Nutplates riveted to the F.G. Fairing] > > Appreciate your helpful inputs, > > Garey Wittich Santa Monica, CA > > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ > > > ________________________________________________________________________________
Date: Dec 16, 2007
I can't answer all your questions definitively and the ones I can are as much opinion as fact, so you'll likely get more than one answer from the list. But here goes: Gel coat is most commonly used over poly; it's often just a colored finishing resin painted into the mold before the first ply is laid down with plying resin. Its purpose is to provide a finished surface. In practical use, this is almost never the final surface because seams will be visible or, in the case of our RVs, the molded color will not be the desired finish color. I've flown competition model sailplanes for year with molded components and the competitors usually leave them alone; lightness is more important than cosmetic detail. Gelcoat can be sanded, use a fine grit so you don't gouge the gel or dig into the weave. You just want enough "tooth" for your primer; sand until the shine is gone. Wipe with a solvent or alcohol (I like MEK) to remove dust and any mold release (gelcoat itself isn't a mold release, so the mold is usually first coated with release). Flexing should not be a problem for your finish; you shouldn't have to squeeze the fairing much to get it on. The biggest problem area will be filling the gap between the parts. Filler tends to crack and while epoxy can be used over poly, filling with resin usually leaves a brittle edge. What you should do is fit the fairing with a little gap built in, say 1/16" to 1/8". Then go back and carefully sand the sharp molded corners working along the surface of the piece, not down into it. This will enlarge the gap but not cut down into the weave. Both the inside and outside corners of the joggle should be rounded; the main purpose is to ensure that the entire area has been sanded to receive the fill. The flat area of the joggle should also be lightly sanded. Mix up some epoxy filler, using flox until it is fairly stiff. Wax or mold release the empennage along the joint both inside, outside, and along the edge (if it were me, I'd do this with clecos rather than after the screws and nutplates are fitted, to avoid epoxy in bad places). Paint the gap with extra epoxy and apply the filler. Let harden and then sand the joint smooth before carefully separating the parts. That should leave you with an exact fit that won't easily crack. By the way, consider the wingtip VOR antenna; saves you from having to make the empennage fairing removable and from having the antenna sticking out of the tail. The instructions for making the joint still apply except that you can fill after the fairings have been riveted on and you can obviously skip the mold release. Pat Kelley - RV-6A - Making antenna cable runs to the panel. -----Original Message----- Greetings: Have an "older" Emphennage Kit (circa 1999) that came with Gel Coated F.G. Fairings. 1) Do the "newer" Kits from Vans still come with the Gel Coated Fairings ? 2) My understanding from reading the Archieves is that the Gel Coat is used over Polyester Resin F.G. parts and not over Epoxy Resin F.G. Parts. Is this true ? 3) Is it worth buying from Vans the "newer" NON Gel Coated Fairings (assuming they come that way now) than trying to work with the existing Gel Coated fairings that I have ? 4) What is the purpose of the Gel Coat - mold release ? 5) What Grit / Method used - would you recommend to take off the Gel Coat (and not digging into the F.G. weave) ? 6) Is it recommended to remove ALL the Gel Coat down to the F.G. weave so that any "flexing" of the F.G. fairing will not crack any final Top Coat of paint in the future ? [My Fairing on the TOP of the VS will be removable for access to the VOR Antenna - should that be necessary and could flex during removal and crack the Top Coat of paint.] 7) Any helpful HINTS on getting a nice Fairing / Skin edge line where the Fairing meets the Skin and still keeping the Fairing removable ? [Will be using #6 Screws into Nutplates riveted to the F.G. Fairing] Appreciate your helpful inputs, Garey Wittich Santa Monica, CA ________________________________________________________________________________
Date: Dec 16, 2007
Subject: Re: 60s
In a message dated 12/16/2007 4:07:30 A.M. Pacific Standard Time, cjensen(at)dts9000.com writes: Unfortunately, there are no assigned value to my nods, since they are not traded on any exchanges, even though they are invaluable. If they were convertible to a currency, the exchange rate with the value of the dollar would still be incalculable since one can not divide by "0". ======================================= I have been to ancient Greece...just look at this grape... N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 16, 2007
Subject: Re: 60s
Catherwood? Put down that pickle! Pax, Ed Holyoke > I have been to ancient Greece...just look at this grape... > > > > *N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley)* > > > ------------------------------------------------------------------------ > See AOL's top rated recipes > <http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004> and > easy ways to stay in shape > <http://body.aol.com/fitness/winter-exercise?NCID=aoltop00030000000003> > for winter. > >* > > >* > ________________________________________________________________________________
Date: Dec 16, 2007
Subject: 2006 RV-6A Xmas Special $59,500
Merry Christmas to the listers... 2006 RV-6A for $59,500. See pictures at http://web.mac.com/fpthomas. Currently on the ramp in front of the tower at KHWD. Lycoming O-320 E3D 130 SMOH. This engine is NOT compatible with a CS prop. Aymar-Demuth fixed wood prop (it looks metal in the pictures, but it is wood). Sliding canopy, electric flaps, day/night VFR. First flight was on February 15th, 2006. The interior is from Classic Aero with carpet under the feet and baggage area, upholstered vinyl and cloth seats and side coverings in all areas. The panel has a Vision Microsystems VM1000C (color display) monitoring all 4 CHT=B9s and EGT=B9s, fuel pressure, fuel flow, gallon s burned and remaining, oil temp and pressure, voltage and amps, RPM and manifold pressure, OAT and CAT and left and right fuel levels all on one 6 inch screen. It also has a panel-mounted Garmin 296, a NARCO transponder and an Icom A-200 Radio with emergency inputs that bypass the intercom. Th e big 6 gauges are all overhauled or new. The intercom is Flightcom from Van=B9s. Engine was overhauled in January 2005 =AD see web site for A&P signof f with a list of replaced parts. Other little things: upgraded fuel valve, right stick PTT is on the panel s o the stick can be removed, both pilot and copilot brakes. One strobe light on the top of the vertical stabilizer with nav lights on both wings and tail. One landing light on left wing. Red map lights on both sides of the cockpit. Entire airframe primed with zinc chromate. I purchased the kit almost flying from an A&P builder, removed the panel an d replaced every wire, switch and gauge. This is the second RV I=B9ve finishe d - the first was an RV-8 I built from a QB fuse and slow-build wing set. Call me at 510-393-9876. Parker ____________________________________ F. Parker Thomas me(at)parkerthomas.com www.parkerthomas.com Phone 510-393-9876 Fax 510-225-2358 ________________________________________________________________________________
Date: Dec 17, 2007
Subject: Micro Air Radio or Xcom 760?
Hi: Would like to hear from those with either or these two radios.. Some one responded, on the Micro air, with comments that there was some problem with ground on the Pilot PTT?, but it was fixed. The price is better on this, thatn on the Xcom 760... Thanks for comments and information. Bert rv6a do not arlchive. ________________________________________________________________________________
Date: Dec 17, 2007
I Had a micro air when I first started flying my 6 and soon changed it out for a full size radio. I found that it was really difficult to change channels in rough air and hard to see the readout in bright sun. This was back in 2000 so things may have changed sense then. Happy Holidays All Ken -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bert Murillo Sent: Monday, December 17, 2007 2:09 PM Subject: RV-List: Micro Air Radio or Xcom 760? Hi: Would like to hear from those with either or these two radios.. Some one responded, on the Micro air, with comments that there was some problem with ground on the Pilot PTT?, but it was fixed. The price is better on this, thatn on the Xcom 760... Thanks for comments and information. Bert rv6a do not arlchive. ________________________________________________________________________________
Date: Dec 18, 2007
Subject: MT-Prop Governor
I recently test flighted a new RV with an Aerosport IO-360, Hartzell BA prop and MT governor, and the prop would surge approximately 150-200 rpms about once per second under takeoff & climb power. Pretty darn interesting on a first flight. After calling Hartzell (they new about it and suggested calling Vans), Vans (the tech guy I talked to seemed a bit evasive, but gave me MTs phone#), then MT, I finally learned that any of their governors with a model # with anything earlier than an -F suffix has to be returned for modification to an -F series level. This particular governor was a -B series purchased from Vans about 16-18 months ago. Off to MT in DeLand Florida it went and was back in about 10 days- It now performs perfectly. But- I recently visited a builder near me who had bought the same governor, but had not yet installed it. I asked to see it and it is a -C series unit. He had no idea that when he installed it on his plane and had the surging problem he would have to pull it for modification as well- quite a hassle on a flying airplane, much easier to do before initial installation of course. I sent Vans a polite e-mail asking if they were aware of this situation, and if so, were they planning to notify those who had bought these governors. No response in over a week, so I thought I'd give y'all a little heads-up so you can avoid the same hassle I had. If you have one of these units, contact Juergen at: _http://www.mt-propellerusa.com/home.htm_ (http://www.mt-propellerusa.com/home.htm) Mark Phillips, RV-6A "Mojo" Columbia, TN _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 18, 2007
At 11:03 AM 12/16/07, you wrote: >Other wise, can some one tell me how difficult would be to make my >own.....Those with the talent to do this, can send me photos, and >'details of how to do it etc... Bert You are going to have to buy some technical books on "how to" not only for fiberglass but for building in general. This list is good, but the books will provide pictures and step by step instructions. I was reading one of Tony Bingilis's books last night about this very topic. Of course there are other books by other authors. Check with Andy Gold for some good ones (he is on the list, RV Bookstore). As far as how hard it is, once again that is a personal question. I find working with fiberglass very easy and I am fairly good at it, and that comes from years of practice. I would have no problem making wheel pants, but for me I would estimate 300 hours of work and a cost of about $150.00 for materials and equipment. Buying from Van's seems to be the way to go, my time is worth more than 50 cents an hour (assuming Van's wheel pants cost approx $300.00!) If you are trying to save money and you have plenty of time on your hands, then making your own is the way to go. Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Subject: Re: MT-Prop Governor
Date: Dec 18, 2007
Mark, The governor may well need to be updated, but the surging you mention can also be caused by the fine pitch stop on the prop being too fine. The way to test it is to do a static full power run-up. The prop should not turn more than around 2625 rpm, 2640 tops. If it does, adjust the fine pitch stop to a slightly courser setting. Randy Lervold Camas, WA ----- Original Message ----- From: Fiveonepw(at)aol.com To: rv-list(at)matronics.com Sent: Monday, December 17, 2007 10:23 PM Subject: RV-List: MT-Prop Governor I recently test flighted a new RV with an Aerosport IO-360, Hartzell BA prop and MT governor, and the prop would surge approximately 150-200 rpms about once per second under takeoff & climb power. Pretty darn interesting on a first flight. After calling Hartzell (they new about it and suggested calling Vans), Vans (the tech guy I talked to seemed a bit evasive, but gave me MTs phone#), then MT, I finally learned that any of their governors with a model # with anything earlier than an -F suffix has to be returned for modification to an -F series level. This particular governor was a -B series purchased from Vans about 16-18 months ago. Off to MT in DeLand Florida it went and was back in about 10 days- It now performs perfectly. But- I recently visited a builder near me who had bought the same governor, but had not yet installed it. I asked to see it and it is a -C series unit. He had no idea that when he installed it on his plane and had the surging problem he would have to pull it for modification as well- quite a hassle on a flying airplane, much easier to do before initial installation of course. I sent Vans a polite e-mail asking if they were aware of this situation, and if so, were they planning to notify those who had bought these governors. No response in over a week, so I thought I'd give y'all a little heads-up so you can avoid the same hassle I had. If you have one of these units, contact Juergen at: http://www.mt-propellerusa.com/home.htm Mark Phillips, RV-6A "Mojo" Columbia, TN http://websites.expercraft.com/n51pw/ ------------------------------------------------------------------------- ----- See AOL's top rated recipes and easy ways to stay in shape for winter. ________________________________________________________________________________
Subject: Just a Few Van's Belt Buckles..
Date: Dec 18, 2007
I only have a total of 8 two-tone and nickel buckles left. When they sell, I have decided not to re-order them. I will continue to sell the brass models. If you have been thinking about one of these, now may be the last chance. Thanks for looking. __________________ -------- Glenn Brasch RV-9A Finishing #90623, O-360 Tucson, Arizona Van's Aircraft Belt Buckles http://home.earthlink.net/~gbrasch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152972#152972 ________________________________________________________________________________
Date: Dec 18, 2007
Subject: Tail Dragger Towbar Question
I'm getting to the point with my RV-8 where I am going to need a towbar to maneuver the plane in and out of my hangar, and I need some advice on what type of towbar works well at a reasonable price (ACS has 'em starting at $159 for the "Taildragger Dragger" and upwards). Sure would appreciate your input............ Thanks, Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' ________________________________________________________________________________
Date: Dec 18, 2007
Mark, I copied your message and posted it on VAF forums. Here is the link to the thread: http://www.vansairforce.com/community/showthread.php?t=24754 ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm Fiveonepw(at)aol.com wrote: > I recently test flighted a new RV with an Aerosport IO-360, Hartzell > BA prop and MT governor, and the prop would surge approximately > 150-200 rpms about once per second under takeoff & climb power. > Pretty darn interesting on a first flight. After calling Hartzell > (they new about it and suggested calling Vans), Vans (the tech guy > I talked to seemed a bit evasive, but gave me MTs phone#), then MT, I > finally learned that any of their governors with a model # with > anything earlier than an -F suffix has to be returned for modification > to an -F series level. This particular governor was a -B series > purchased from Vans about 16-18 months ago. Off to MT in DeLand > Florida it went and was back in about 10 days- It now performs perfectly. > > But- I recently visited a builder near me who had bought the same > governor, but had not yet installed it. I asked to see it and it is a > -C series unit. He had no idea that when he installed it on his plane > and had the surging problem he would have to pull it for modification > as well- quite a hassle on a flying airplane, much easier to do before > initial installation of course. > > I sent Vans a polite e-mail asking if they were aware of this > situation, and if so, were they planning to notify those who had > bought these governors. No response in over a week, so I thought I'd > give y'all a little heads-up so you can avoid the same hassle I had. > If you have one of these units, contact Juergen at: > http://www.mt-propellerusa.com/home.htm > > Mark Phillips, RV-6A "Mojo" > Columbia, TN > http://websites.expercraft.com/n51pw/ > > > ------------------------------------------------------------------------ > See AOL's top rated recipes > <http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004> and > easy ways to stay in shape > <http://body.aol.com/fitness/winter-exercise?NCID=aoltop00030000000003> > for winter. > * > > > * ________________________________________________________________________________
Subject: Re: Tail Dragger Towbar Question
Date: Dec 18, 2007
Buy the "Cessna style towbar" from Aircraft Spruce. This is the one that collapses when you remove a cotterless hitch pin. The towbar is less than $50 and works very well. All you need to do is pay a little more attention in bending and trimming the cotter pin that holds the nut to the axle bolt on the tailwheel. ----- Original Message ----- From: "rveighta" <rveighta(at)earthlink.net> Sent: Tuesday, December 18, 2007 8:48 PM Subject: RV-List: Tail Dragger Towbar Question > > I'm getting to the point with my RV-8 where I am going to need a towbar to > maneuver the plane in and out of my hangar, and I need some advice on what > type of towbar works well at a reasonable price (ACS has 'em starting at > $159 for the "Taildragger Dragger" and upwards). > > Sure would appreciate your input............ > > Thanks, > > Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' > > > ________________________________________________________________________________
Date: Dec 19, 2007
Walt, I use the tail dragger dragger and it works fine on concrete and asphalt but I don't think the wheels are large enough for use on grass. Bob Bales RV6 ----- Original Message ----- From: rveighta Date: Tuesday, December 18, 2007 9:25 pm Subject: RV-List: Tail Dragger Towbar Question > > I'm getting to the point with my RV-8 where I am going to need a > towbar to maneuver the plane in and out of my hangar, and I need > some advice on what type of towbar works well at a reasonable > price (ACS has 'em starting at $159 for the "Taildragger > Dragger" and upwards). > > Sure would appreciate your input............ > > Thanks, > > Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' > > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Hey Mark, I had the same problem on my RV8. Give MT a call in Florida, I think it was Dean I spoke with, they will send you an updated governor modi fied for the Hartzell blended airfoil. I replace mine and have had no prob lems since. I believe it is a -F model that you need. Anyway, I got good service from them. If you can't get a hold of them in Florida, try Eric Gre indl (Eric.Greindl@MT-Propeller.com) over in Germany, he was also helpfull. Good luck, Paul Rice N64PR RV8 60 hours From: Fiveonepw(at)aol.comDate: Tue, 18 Dec 2007 01:23:49 -0500Subject: RV-Lis t: MT-Prop Governor To: rv-list(at)matronics.com I recently test flighted a new RV with an Aerosport IO-360, Hartzell BA pro p and MT governor, and the prop would surge approximately 150-200 rpms abou t once per second under takeoff & climb power. Pretty darn interesting on a first flight. After calling Hartzell (they new about it and suggested ca lling Vans), Vans (the tech guy I talked to seemed a bit evasive, but gave me MTs phone#), then MT, I finally learned that any of their governors with a model # with anything earlier than an -F suffix has to be returned for m odification to an -F series level. This particular governor was a -B serie s purchased from Vans about 16-18 months ago. Off to MT in DeLand Florida it went and was back in about 10 days- It now performs perfectly. But- I recently visited a builder near me who had bought the same governor, but had not yet installed it. I asked to see it and it is a -C series uni t. He had no idea that when he installed it on his plane and had the surgi ng problem he would have to pull it for modification as well- quite a hassl e on a flying airplane, much easier to do before initial installation of co urse. I sent Vans a polite e-mail asking if they were aware of this situation, an d if so, were they planning to notify those who had bought these governors. No response in over a week, so I thought I'd give y'all a little heads-up so you can avoid the same hassle I had. If you have one of these units, c ontact Juergen at: http://www.mt-propellerusa.com/home.htm Mark Phillips, RV-6A "Mojo" Columbia, TN http://websites.expercraft.com/n51pw/ See AOL's top rated recipes and easy ways to stay in shape for winter. ________________________________________________________________________________
Date: Dec 19, 2007
In a message dated 12/18/2007 1:41:31 PM Central Standard Time, randy(at)romeolima.com writes: The way to test it is to do a static full power run-up. The prop should not turn more than around 2625 rpm, 2640 tops. >>> Hi Randy- it would hit just over 2600 whilst dragging the plane across the run-up area, brakes locked. Max climbout rpm would be in the area you mentioned. Mark p.s.- be careful doing this without a sissy wheel! 8-) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 19, 2007
Subject: Re: Just a Few Van's Belt Buckles..
In a message dated 12/18/2007 3:00:31 P.M. Pacific Standard Time, gbrasch(at)earthlink.net writes: I only have a total of 8 two-tone and nickel buckles left. When they sell, I have decided not to re-order them. I will continue to sell the brass models. If you have been thinking about one of these, now may be the last chance. =================================== I'll take one of the two tone ones if you have one left. I'll fire you off a check if you confirm. Cell 408-375-4450 Gary VanRemortel N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 19, 2007
2nd what Kyle said about the Deluxe Cessna Towbar. Wag Aero also sells a similar which I have (since Wag is in my back yard.) As Kyle said, a little tweaking of the cotter pin is in order. Also, I reamed out the lugs on the towbar ever so slightly and that helps. I also used a slightly longer bolt for the tailwheel and put a few washers under each side. This gives the towbar some more "meat" to grab onto, but it probably cost me .001 knot. I forget the exact bolt size but it was about 1/2 inch longer than standard. Jeff Point RV-6 flying RV-8 tail done Milwaukee > > ________________________________________________________________________________
Date: Dec 19, 2007
After 10-years of flying my RV, I use the built in towbar (horizontal stab) to move the airplane were ever it needs to go. It is already part of the airplane, does not increase empty weight of the airplane, and did not cost any extra money. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,0638 + Flying Hours So. CA, USA > Date: Tue, 18 Dec 2007 20:48:43 -0500 > From: rveighta(at)earthlink.net > To: rv-list(at)matronics.com > Subject: RV-List: Tail Dragger Towbar Question > > > I'm getting to the point with my RV-8 where I am going to need a towbar t o maneuver the plane in and out of my hangar, and I need some advice on wha t type of towbar works well at a reasonable price (ACS has 'em starting at $159 for the "Taildragger Dragger" and upwards). > > Sure would appreciate your input............ > > Thanks, > > Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' > =========== =========== =========== =========== > > > _________________________________________________________________ i=92m is proud to present Cause Effect, a series about real people making a difference. ________________________________________________________________________________
Date: Dec 19, 2007
Walt, I made my own tow bar. It cost me nothing because I had the materials at hand. It is light; less than 3 ounces. It folds to an overall length of 4 inches, so I take it with me with no problems. It is a rope with a 1-inch diameter dowel used for a handle. Slip it around the vertical shaft of the tailwheel and the plane will follow you wherever you pull it. I'm not trying to by cute. IMHO money spent on a towbar for a tail dragger is wasted. Ron Schreck RV-8 "Miss Izzy" Gold Hill Airpark, NC *************************************************************** I'm getting to the point with my RV-8 where I am going to need a towbar to maneuver the plane in and out of my hangar, and I need some advice on what type of towbar works well at a reasonable price (ACS has 'em starting at $159 for the "Taildragger Dragger" and upwards). Sure would appreciate your input............ Thanks, Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' ________________________________________________________________________________
Date: Dec 19, 2007
Ron Schreck wrote: > Walt, I made my own tow bar. It cost me nothing because I had the > materials at hand. It is light; less than 3 ounces. It folds to an > overall length of 4 inches, so I take it with me with no problems. > It is a rope with a 1-inch diameter dowel used for a handle. Slip it > around the vertical shaft of the tailwheel and the plane will follow > you wherever you pull it. > > I'm not trying to by cute. IMHO money spent on a towbar for a tail > dragger is wasted. The rope works great....unless you want to *push* the plane with the "towbar". :-) With my hangar situation it is easiest to manage the plane with the towbar both coming and going while maneuvering around my hangarmate's RV-6A. The Cessna bar has worked great for eight years: http://thervjournal.com/airport.html#towbar Sam Buchanan ________________________________________________________________________________
Date: Dec 19, 2007
Why do you need a towbar? If you have a full swivel tailwheel (all of them do nowadays, but I just recently had to upgrade mine to the Bell tailwheel fork) just push on the horizontal and vertical stab and she'll move anywhere you want to go. Paul Besing RV-4 N73DD Arizona ----- Original Message ---- From: rveighta <rveighta(at)earthlink.net> Sent: Tuesday, December 18, 2007 6:48:43 PM Subject: RV-List: Tail Dragger Towbar Question I'm getting to the point with my RV-8 where I am going to need a towbar to maneuver the plane in and out of my hangar, and I need some advice on what type of towbar works well at a reasonable price (ACS has 'em starting at $159 for the "Taildragger Dragger" and upwards). Sure would appreciate your input............ Thanks, Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 19, 2007
Subject: King A&P Mechanics Exam Courses
Anyone have the King A&P Mechanics Exam Courses DVDs they are willing to part with? ...or anything similar? Please contact me off list... -Bill VonDane bill(at)vondane.com 719-266-2388 ________________________________________________________________________________
Date: Dec 19, 2007
I made up the same thing Ron. It works as well as any towbar I have ever used. Plus I always have it with me in the plane. John L. Danielson -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Schreck Sent: Wednesday, December 19, 2007 6:51 AM Subject: RV-List: Re: Tail Dragger Towbar Question Walt, I made my own tow bar. It cost me nothing because I had the materials at hand. It is light; less than 3 ounces. It folds to an overall length of 4 inches, so I take it with me with no problems. It is a rope with a 1-inch diameter dowel used for a handle. Slip it around the vertical shaft of the tailwheel and the plane will follow you wherever you pull it. I'm not trying to by cute. IMHO money spent on a towbar for a tail dragger is wasted. Ron Schreck RV-8 "Miss Izzy" Gold Hill Airpark, NC *************************************************************** I'm getting to the point with my RV-8 where I am going to need a towbar to maneuver the plane in and out of my hangar, and I need some advice on what type of towbar works well at a reasonable price (ACS has 'em starting at $159 for the "Taildragger Dragger" and upwards). Sure would appreciate your input............ Thanks, Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' ________________________________________________________________________________
Date: Dec 19, 2007
Agreed the Tail Dragger Dragger might work ok on asphalt but it does not work well on grass. Here is my experience with it. I have to push the dragger up under the belly by going quite a bit up forward else the wheel doesn't fit under the back of my -6. Then pull it back to get it to the tail wheel and it wont really just slide to get the tailwheel between the pins so usually I end up picking up the plane slightly to set it on the dragger. Hard to do with only two hands. Then when I try to pull it backwards on the grass the wheel tends to want to turn in the saddle. This is especially true if you need to turn the dragger to position the plane differently. Once the wheel turns in the saddle, it will pop off the dragger and be a bad thing. To fix this I use a bungy cord to wrap around the wheel and the dragger and hook it to the pins. Well you can't just go under the dragger with the bungy so again you have to lift up on the handle while stretching the bungy under the bar so you can bring it over the top of the wheel again to hook it. Overall I have deemed it next to useless for my needs and would be willing to sell it to someone with asphalt only needs. Personally I wouldn't buy one again even if I was on asphalt. An engineer friend here on the airpark designed a simple and easy to use with positive connection for his Sonex. After seeing how easy it was it looked to me like it would work for my RV. He has redesigned a version for me and this works about as perfect as it could. Now I just walk this back up to the rear of the tail wheel and tip the handle up and push it in. Once under the wheel bolt, let the handle down and you have a positive lock on the wheel and it will NOT turn out, pop off or even require me to get down and screw around with it. I love it and am absolutely willing to share the design. Problem is you have to build it. If anyone is interested, just email me and I will scan the detail drawings in so you can see for yourself. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rv6n(at)optonline.net Sent: Tuesday, December 18, 2007 8:38 PM Subject: Re: RV-List: Tail Dragger Towbar Question Walt, I use the tail dragger dragger and it works fine on concrete and asphalt but I don't think the wheels are large enough for use on grass. Bob Bales RV6 ----- Original Message ----- From: rveighta Date: Tuesday, December 18, 2007 9:25 pm Subject: RV-List: Tail Dragger Towbar Question > > I'm getting to the point with my RV-8 where I am going to need a > towbar to maneuver the plane in and out of my hangar, and I need > some advice on what type of towbar works well at a reasonable > price (ACS has 'em starting at $159 for the "Taildragger > Dragger" and upwards). > > Sure would appreciate your input............ > > Thanks, > > Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' > > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Here is page one for viewing. If you are interested in building this just ask me off line and I will send the other two detail drawings. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Wednesday, December 19, 2007 9:21 AM Subject: RE: RV-List: Tail Dragger Towbar Question Agreed the Tail Dragger Dragger might work ok on asphalt but it does not work well on grass. Here is my experience with it. I have to push the dragger up under the belly by going quite a bit up forward else the wheel doesn't fit under the back of my -6. Then pull it back to get it to the tail wheel and it wont really just slide to get the tailwheel between the pins so usually I end up picking up the plane slightly to set it on the dragger. Hard to do with only two hands. Then when I try to pull it backwards on the grass the wheel tends to want to turn in the saddle. This is especially true if you need to turn the dragger to position the plane differently. Once the wheel turns in the saddle, it will pop off the dragger and be a bad thing. To fix this I use a bungy cord to wrap around the wheel and the dragger and hook it to the pins. Well you can't just go under the dragger with the bungy so again you have to lift up on the handle while stretching the bungy under the bar so you can bring it over the top of the wheel again to hook it. Overall I have deemed it next to useless for my needs and would be willing to sell it to someone with asphalt only needs. Personally I wouldn't buy one again even if I was on asphalt. An engineer friend here on the airpark designed a simple and easy to use with positive connection for his Sonex. After seeing how easy it was it looked to me like it would work for my RV. He has redesigned a version for me and this works about as perfect as it could. Now I just walk this back up to the rear of the tail wheel and tip the handle up and push it in. Once under the wheel bolt, let the handle down and you have a positive lock on the wheel and it will NOT turn out, pop off or even require me to get down and screw around with it. I love it and am absolutely willing to share the design. Problem is you have to build it. If anyone is interested, just email me and I will scan the detail drawings in so you can see for yourself. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rv6n(at)optonline.net Sent: Tuesday, December 18, 2007 8:38 PM Subject: Re: RV-List: Tail Dragger Towbar Question Walt, I use the tail dragger dragger and it works fine on concrete and asphalt but I don't think the wheels are large enough for use on grass. Bob Bales RV6 ----- Original Message ----- From: rveighta Date: Tuesday, December 18, 2007 9:25 pm Subject: RV-List: Tail Dragger Towbar Question > > I'm getting to the point with my RV-8 where I am going to need a > towbar to maneuver the plane in and out of my hangar, and I need > some advice on what type of towbar works well at a reasonable > price (ACS has 'em starting at $159 for the "Taildragger > Dragger" and upwards). > > Sure would appreciate your input............ > > Thanks, > > Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' > > ========== > ========== > ========== > ========== > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Be careful doing a full power static runup with a taildragger? Can you say nose over? Please provide accepted methods of securing the plane so that a nose over does not happen. Ron Lee ----- Original Message ----- From: Fiveonepw(at)aol.com To: rv-list(at)matronics.com Sent: Tuesday, December 18, 2007 10:33 PM Subject: Re: RV-List: MT-Prop Governor In a message dated 12/18/2007 1:41:31 PM Central Standard Time, randy(at)romeolima.com writes: The way to test it is to do a static full power run-up. The prop should not turn more than around 2625 rpm, 2640 tops. >>> Hi Randy- it would hit just over 2600 whilst dragging the plane across the run-up area, brakes locked. Max climbout rpm would be in the area you mentioned. Mark p.s.- be careful doing this without a sissy wheel! 8-) ------------------------------------------------------------------------- ----- See AOL's top rated recipes and easy ways to stay in shape for winter. ________________________________________________________________________________
Subject: Fw: Tail Wind Project For sale
Date: Dec 19, 2007
On the way back from a trip to Louisiana, I landed at Walker County Airport (KJFX) Alabama to refuel. While refueling a gentleman came over and introduced himself as Ed Banks. Mentioned that he had an RV-6 and invited me to see it. Very nice RV with clean paint lines. While in his hangar I noticed he had a Tailwind with the wings off which he was restoring. Ed stated that he had built new wings, had a newly overhauled O-295, new Plexiglas all around and had complete the process of recovering. The cloth needs one more coat of aluminum UV blocker before applying paint. I believe he also had a new instrument panel blank. He had new lightweight fiberglass cowling components as well. Citing insufficient time to complete it, Ed would like to find a buyer for it as a project. I asked him what he wanted for the project and he quoted me an attractive price. I must admit I was tempted as I have the plans for a TailWind that I had once planned on building, but I also lack the time. So if anyone is interested or knows of a Tailwind list where someone might be interested, please contact Ed direct. His e mail is IFLYRV6N264EB(at)AOL.Com his cell phone is 205-522-0539 Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html ________________________________________________________________________________
Date: Dec 19, 2007
Of course you'd have your tail tied down, wouldn't think of doing the test without. In fact the tail should be tied low so that the prop has a much ground clearance as possible. My bad for not mentioning that. I use a fire hydrant near my hangar and tie a short rope right at ground level. This keeps the tailwheel on the ground. Randy Lervold ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Wednesday, December 19, 2007 8:30 AM Subject: Re: RV-List: MT-Prop Governor Be careful doing a full power static runup with a taildragger? Can you say nose over? Please provide accepted methods of securing the plane so that a nose over does not happen. Ron Lee ----- Original Message ----- From: Fiveonepw(at)aol.com To: rv-list(at)matronics.com Sent: Tuesday, December 18, 2007 10:33 PM Subject: Re: RV-List: MT-Prop Governor In a message dated 12/18/2007 1:41:31 PM Central Standard Time, randy(at)romeolima.com writes: The way to test it is to do a static full power run-up. The prop should not turn more than around 2625 rpm, 2640 tops. >>> Hi Randy- it would hit just over 2600 whilst dragging the plane across the run-up area, brakes locked. Max climbout rpm would be in the area you mentioned. Mark p.s.- be careful doing this without a sissy wheel! 8-) ------------------------------------------------------------------------- --- See AOL's top rated recipes and easy ways to stay in shape for winter. href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: prop governor
Date: Dec 19, 2007
Can anyone recommend a good source for an overhauled prop governor? It is for an IO-470. Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Dec 19, 2007
The "Taildragger", works fine as long as you don't have to pull the plane up any significant incline. I have used the least expensive version on my -6 for over 5 years. ----- Original Message ----- From: "rveighta" <rveighta(at)earthlink.net> Sent: Tuesday, December 18, 2007 8:48 PM Subject: RV-List: Tail Dragger Towbar Question > > I'm getting to the point with my RV-8 where I am going to need a towbar to maneuver the plane in and out of my hangar, and I need some advice on what type of towbar works well at a reasonable price (ACS has 'em starting at $159 for the "Taildragger Dragger" and upwards). > > Sure would appreciate your input............ > > Thanks, > > Walt Shipley RV8A 300 hrs, RV8 gettin' close to flyin' > > > -- 12/18/2007 9:40 PM > > ________________________________________________________________________________
Date: Dec 19, 2007
Subject: Re: O-320
> From: "Konrad L. Werner" <klwerner(at)comcast.net> > Subject: Re: RV-List: O-320 > > Perhaps the other reason would be *final cost*... > I'd get a bid from > each of the many engine builders and shop around for > what you really > want. I don't know what the sales tax situation is > like in L.I.,NY, but > it may even cost more in sales tax alone then what > it would cost for > getting a Bartized Lycosaurus shipped from Canada. > Aerosport Power has > certainly earned themselves a stellar reputation > (not to put down > Mattituck, PenYan, LyCon and the various many other > custom shops). Your > call, but I would simply visit Mattituck to see what > they would have in > store for you, and then compare apples to apples... > Good Luck! I vote for Mattituck. I also live on Long Island and have a flying RV-6A out of Bayport. There is a Mattituck TMX-IO-540 sitting in my garage for a project that I am helping to build. The support from Mattituck has been first rate. They offer the free engine builders class and are right in your backyard. This is a huge benefit if you need assistance or parts. You are also able to witness the test running of YOUR engine if you want. There will be no sales tax. New York State exempts airplane parts from sales tax. There was no sales tax on that 540 mentioned above. I'm sure Aerosport produces a fine engine, but they can't offer you the local support that Mattituck can provide. If you still need more inforation, then call Mahlon from Mattituck and arrange to talk to them personally. They have been known to give builders a tour of their facility upon request. Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Dec 19, 2007
Subject: Re: Fw: Tail Wind Project For sale
Ed Anderson wrote: > > > On the way back from a trip to Louisiana, I landed at Walker County > Airport (KJFX) Alabama to refuel. While refueling a gentleman came > over and introduced himself as Ed Banks. Mentioned that he had an > RV-6 and invited me to see it. Very nice RV with clean paint lines. > While in his hangar I noticed he had a Tailwind with the wings off > which he was restoring. > > Ed stated that he had built new wings, had a newly overhauled O-295, > new Plexiglas all around and had complete the process of recovering. > The cloth needs one more coat of aluminum UV blocker before applying > paint. I believe he also had a new instrument panel blank. He had > new lightweight fiberglass cowling components as well. > > Citing insufficient time to complete it, Ed would like to find a > buyer for it as a project. I asked him what he wanted for the > project and he quoted me an attractive price. I must admit I was > tempted as I have the plans for a TailWind that I had once planned on > building, but I also lack the time. > > > So if anyone is interested or knows of a Tailwind list where someone > might be interested, please contact Ed direct. > > His e mail is IFLYRV6N264EB(at)AOL.Com his cell phone is 205-522-0539 I can personally vouch for Ed Banks. He is part of our Tennessee Valley RV group, an honest fellow, and whatever he tells you about the Tailwind is the way it is. Sam Buchanan ________________________________________________________________________________
Subject: good warning label.
Date: Dec 19, 2007
Your ironic humor for today: I'm adding the matco parking brake and needed to order some shorter brake lines. Found some 20" steel braided straight an4 lines from an online auto/performance website. They came with the label: "Warning: Competition/Off Road Use Only. Not approved for highway use." Hmmm. Well. I do hope to go "off road", so I'm thinking I should be good. ****************************************** Don Hall N517DG (registered) rv7 finishing ****************************************** ________________________________________________________________________________
Date: Dec 19, 2007
Konrad L. Werner wrote: > Ed, Is this newly overhauled O-295 a mixed breed between a O-235 and > a O-290? More out of curiosity then anything else, but would you > mind sharing with us this attractive price you were quoted? Thanks... Wouldn't it be much better to contact Ed Banks. the Tailwind owner, directly for this information? Sam Buchanan ________________________________________________________________________________
Date: Dec 19, 2007
Konrad L. Werner wrote: > Sam, Wouldn't the absence of all information limit this gentlemen's > projects exposure, thereby greatly affecting its marketability, as > well as hindering a potential sale ?? I'd rather put all the > information out there and then get call's only from interested > parties ( even they do take a great deal of weeding out qualified > buyers) Konrad, I guess if the plane for sale was mine, I would want interested parties to get detailed, first-hand, totally accurate info straight from me instead of from someone whom I happened to meet on an airport ramp.... Ed Anderson provided Mr. Banks' contact info, I suspect in order to encourage interested folks to contact the seller directly. But if Ed Anderson wishes to answer your inquiry, I'm sure he will. I'm done. :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 19, 2007
> Konrad, I guess if the plane for sale was mine, I would want interested > parties to get detailed, first-hand, totally accurate info straight from > me instead of from someone whom I happened to meet on an airport ramp.... > > Ed Anderson provided Mr. Banks' contact info, I suspect in order to > encourage interested folks to contact the seller directly. But if Ed > Anderson wishes to answer your inquiry, I'm sure he will. > > I'm done. :-) > > Sam Buchanan Actually, Ed Banks did not ask me to spread the word. When I found out he was interested in selling his project, I volunteered to distribute the news. Not only to the RV list (which might know of someone interested), but also to the TailWind list. I thought I would be simply helping someone get rid of a project they did not have time for and to help someone looking for a reasonable way to get airborne. I get no $$ out of it. Don't know about Ed Banks, but some folks just don't feel comfortable trying to use a computer. I'm not the broker {:>), just the messenger - please don't shoot {:>) Ed ________________________________________________________________________________
Date: Dec 19, 2007
I sent Mark a private email and I think he thought it was on the list. I am sure he wanted everyone to hear his reply :-) In a message dated 12/18/2007 8:09:13 PM Central Standard Time, bobbyhester(at)newwavecomm.net writes: Mark, I copied your message and posted it on VAF forums. Here is the link to the thread: http://www.vansairforce.com/community/showthread.php?t=24754 Hi Bobby- appreciate you letting the VAF folks in on it. In their thread it was mentioned that cold oil or low ambient temps might cause this. I wrestled with this situation for almost 20 hours hoping it was just break-in on new equipment- ambient temps were anywhere from 80-45 def.F. No amount of cycling helped and neither did taking off again immediately after landing, even TAGs. MT replaced several main components in the unit to fix the problem, admitting the earlier units hadn't quite been as good as they were expecting. But let me re-iterate here that they willingly updated the unit with excellent turn-around time, and the returned unit works very well after about 4 hours additional flight time. My main beef was not knowing about this "known" condition prior to initial installation and flight testing... Mark ------------------------------------------------------------------------ See AOL's top rated recipes <http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004> and easy ways to stay in shape <http://body.aol.com/fitness/winter-exercise?NCID=aoltop00030000000003> for winter. -- ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm ________________________________________________________________________________
Date: Dec 19, 2007
Dumb question. This thread listed the prop as a BA. Is this a pure Govenor problem that should show up regardless of the prop used? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bobby Hester Sent: Wednesday, December 19, 2007 5:27 PM To: rv-list(at)matronics.com Subject: Re: RV-List: MT-Prop Governor I sent Mark a private email and I think he thought it was on the list. I am sure he wanted everyone to hear his reply :-) In a message dated 12/18/2007 8:09:13 PM Central Standard Time, bobbyhester(at)newwavecomm.net writes: Mark, I copied your message and posted it on VAF forums. Here is the link to the thread: http://www.vansairforce.com/community/showthread.php?t=24754 Hi Bobby- appreciate you letting the VAF folks in on it. In their thread it was mentioned that cold oil or low ambient temps might cause this. I wrestled with this situation for almost 20 hours hoping it was just break-in on new equipment- ambient temps were anywhere from 80-45 def.F. No amount of cycling helped and neither did taking off again immediately after landing, even TAGs. MT replaced several main components in the unit to fix the problem, admitting the earlier units hadn't quite been as good as they were expecting. But let me re-iterate here that they willingly updated the unit with excellent turn-around time, and the returned unit works very well after about 4 hours additional flight time. My main beef was not knowing about this "known" condition prior to initial installation and flight testing... Mark ---------------------------------------------------------------------------- -- See AOL's top rated recipes and easy ways to stay in shape for winter. -- ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm ________________________________________________________________________________
Date: Dec 19, 2007
Make that regardless of the CS prop used. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Don Vs Sent: Wednesday, December 19, 2007 8:16 PM To: rv-list(at)matronics.com Subject: RE: RV-List: MT-Prop Governor Dumb question. This thread listed the prop as a BA. Is this a pure Govenor problem that should show up regardless of the prop used? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bobby Hester Sent: Wednesday, December 19, 2007 5:27 PM To: rv-list(at)matronics.com Subject: Re: RV-List: MT-Prop Governor I sent Mark a private email and I think he thought it was on the list. I am sure he wanted everyone to hear his reply :-) In a message dated 12/18/2007 8:09:13 PM Central Standard Time, bobbyhester(at)newwavecomm.net writes: Mark, I copied your message and posted it on VAF forums. Here is the link to the thread: http://www.vansairforce.com/community/showthread.php?t=24754 Hi Bobby- appreciate you letting the VAF folks in on it. In their thread it was mentioned that cold oil or low ambient temps might cause this. I wrestled with this situation for almost 20 hours hoping it was just break-in on new equipment- ambient temps were anywhere from 80-45 def.F. No amount of cycling helped and neither did taking off again immediately after landing, even TAGs. MT replaced several main components in the unit to fix the problem, admitting the earlier units hadn't quite been as good as they were expecting. But let me re-iterate here that they willingly updated the unit with excellent turn-around time, and the returned unit works very well after about 4 hours additional flight time. My main beef was not knowing about this "known" condition prior to initial installation and flight testing... Mark ---------------------------------------------------------------------------- See AOL's top rated recipes and easy ways to stay in shape for winter. -- ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Naviga tor?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 20, 2007
In a message dated 12/19/2007 10:21:08 PM Central Standard Time, dsvs(at)ca.rr.com writes: Dumb question. This thread listed the prop as a BA. Is this a pure Govenor problem that should show up regardless of the prop used? >>> I don't know if it is a result of this governor in combination with any specific prop- MT may be best equipped to answer that... _http://www.mt-propellerusa.com/contact.htm_ (http://www.mt-propellerusa.com/contact.htm) Mark **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: cutting off the sticks
Date: Dec 20, 2007
Dont do it! Anyone who is on here actually building. if you are considering shortnig your stick, think twice. I recently took an hr of taildrager time in a 6 with stick cut where top is even with top of your hand when laying on your thigh, about 5 or maybe 6 in shortened. on landing I was having a very hard time holding the nose off, so next time I flew my 6a I tried holding the stick down low, same posit as the taildrager stick, and found same thing, very hard to hold nose off.(fist in crotch) I usuallly fly around with hand on thigh, holding stick low, but always take off and land, as well as tight manuvers with hand up high. Charlie Heathco ________________________________________________________________________________
Subject: Re: cutting off the sticks
Date: Dec 20, 2007
Interesting. While waiting to cut the stick may make sense, I fly, take-off and land with my hand on my thigh and my fingers low on the stick. I have to use another hand to activate the PTT switch on top of the stick. If I remember, I will provide actual numbers for reference. Note that I have not done aerobatics in my plane so that may make a difference. Ron Lee ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Thursday, December 20, 2007 7:15 AM Subject: RV-List: cutting off the sticks Dont do it! Anyone who is on here actually building. if you are considering shortnig your stick, think twice. I recently took an hr of taildrager time in a 6 with stick cut where top is even with top of your hand when laying on your thigh, about 5 or maybe 6 in shortened. on landing I was having a very hard time holding the nose off, so next time I flew my 6a I tried holding the stick down low, same posit as the taildrager stick, and found same thing, very hard to hold nose off.(fist in crotch) I usuallly fly around with hand on thigh, holding stick low, but always take off and land, as well as tight manuvers with hand up high. Charlie Heathco ________________________________________________________________________________
Subject: Re: King A&P Mechanics Exam Courses
Date: Dec 20, 2007
Bill, I rented them from justplanevideos.com. They have lots of aviation re lated videos for rent. Chris _________________________________________________________________ Don't get caught with egg on your face. Play Chicktionary! http://club.live.com/chicktionary.aspx?icid=chick_wlhmtextlink1_dec ________________________________________________________________________________
Date: Dec 20, 2007
All the two tone models are gone, but I have three very nice Nickel models left. -------- Glenn Brasch RV-9A Finishing #90623, O-360 Tucson, Arizona Van's Aircraft Belt Buckles http://home.earthlink.net/~gbrasch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153271#153271 ________________________________________________________________________________
Date: Dec 20, 2007
When I built Scooter, I installed a 2 inch sub panel. With the sticks at full length, the stick would get into the panel. I shortened mine two inches and have seen no problems with that. I also fly my RV with my hands well below the top of the stick; but, I move my hand to the top of the stick for take off and landing work. Cutting the sticks off as much as six inches may be overkill. A longer stick gives leverage and allows for smaller inputs at crucial times. I'd do mine with two inches cut off, again. I'd probably not go beyond that. Jim Sears in KY ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Thursday, December 20, 2007 9:15 AM Subject: RV-List: cutting off the sticks Dont do it! Anyone who is on here actually building. if you are considering shortnig your stick, think twice. I recently took an hr of taildrager time in a 6 with stick cut where top is even with top of your hand when laying on your thigh, about 5 or maybe 6 in shortened. on landing I was having a very hard time holding the nose off, so next time I flew my 6a I tried holding the stick down low, same posit as the taildrager stick, and found same thing, very hard to hold nose off.(fist in crotch) I usuallly fly around with hand on thigh, holding stick low, but always take off and land, as well as tight manuvers with hand up high. Charlie Heathco ________________________________________________________________________________
Date: Dec 20, 2007
A few years back, Van himself responded to the "Shorten" the stick question. He was not for it. As best I recall, he stated that shortening the stick could cause stick loads doing aerobatics to become uncomfortably high. While I will cruise with my arm on my knee and fingers gripping the stick about 4 -6 inches below the top, I found that in landing with my hand in that position that stick loads did become higher and responsiveness a bit twitchy. Perhaps continued practice would have improved my performance. IF you are considering shorting the stick, I would suggest try flying an RV through a number of typical maneuvers with your hand at the "shorten" position and then decide. My 0.02 Ed ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Thursday, December 20, 2007 9:15 AM Subject: RV-List: cutting off the sticks Dont do it! Anyone who is on here actually building. if you are considering shortnig your stick, think twice. I recently took an hr of taildrager time in a 6 with stick cut where top is even with top of your hand when laying on your thigh, about 5 or maybe 6 in shortened. on landing I was having a very hard time holding the nose off, so next time I flew my 6a I tried holding the stick down low, same posit as the taildrager stick, and found same thing, very hard to hold nose off.(fist in crotch) I usuallly fly around with hand on thigh, holding stick low, but always take off and land, as well as tight manuvers with hand up high. Charlie Heathco ________________________________________________________________________________
Subject: Re: cutting off sticks
Date: Dec 20, 2007
Guys: I cut 3" off my -9A stick with no problems noted. Note: The -9s are not acrobatic. Dan ________________________________________________________________________________
Date: Dec 20, 2007
From: Tom & Cathy Ervin <tcervin(at)embarqmail.com>
Glenn, Make that 2 left! Sure wish I hadn't missed out on the two tone! If run across one in the future I'll take it also. Tom in Ohio RV6-A ----- Original Message ----- From: "gbrasch" <gbrasch(at)earthlink.net> Sent: Thursday, December 20, 2007 10:53:49 AM (GMT-0500) America/New_York Subject: RV-List: Re: Just a Few Van's Belt Buckles.. All the two tone models are gone, but I have three very nice Nickel models left. -------- Glenn Brasch RV-9A Finishing #90623, O-360 Tucson, Arizona Van's Aircraft Belt Buckles http://home.earthlink.net/~gbrasch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153271#153271 ________________________________________________________________________________
Date: Dec 20, 2007
I cut off 2 or 3 inches an am glad I did. It could even stand to loose another inch or so. I made the cut by sitting in the aircraft (with simulated cushons etc) and played with it to see what I liked. Full length stick definately got too close to the panel. Stick forces are not even close to being a problem even when landing or doing aerobatics. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Dec 20, 2007 8:15 AM, Jim Sears wrote: > When I built Scooter, I installed a 2 inch sub panel. With the sticks at > full length, the stick would get into the panel. I shortened mine two > inches and have seen no problems with that. I also fly my RV with my hands > well below the top of the stick; but, I move my hand to the top of the stick > for take off and landing work. > > Cutting the sticks off as much as six inches may be overkill. A longer > stick gives leverage and allows for smaller inputs at crucial times. I'd do > mine with two inches cut off, again. I'd probably not go beyond that. > > Jim Sears in KY > > ----- Original Message ----- > *From:* Charles Heathco > *To:* rv-list > *Sent:* Thursday, December 20, 2007 9:15 AM > *Subject:* RV-List: cutting off the sticks > > Dont do it! Anyone who is on here actually building. if you are > considering shortnig your stick, think twice. I recently took an hr of > taildrager time in a 6 with stick cut where top is even with top of your > hand when laying on your thigh, about 5 or maybe 6 in shortened. on landing > I was having a very hard time holding the nose off, so next time I flew my > 6a I tried holding the stick down low, same posit as the taildrager stick, > and found same thing, very hard to hold nose off.(fist in crotch) I usuallly > fly around with hand on thigh, holding stick low, but always take off and > land, as well as tight manuvers with hand up high. Charlie Heathco > > ________________________________________________________________________________
Date: Dec 20, 2007
In a message dated 12/20/2007 6:06:44 PM Central Standard Time, wdleonard(at)gmail.com writes: Full length stick definately got too close to the panel. >>> Another consideration is interference with panel controls- my DAR would not pink me until I cut my sticks another 1/2" since the pilot stick would touch the throttle when at idle and stick hard right, full fwd., and the right stick could just graze the mixture control at ICO with stick fully left/fwd. (My throttle and mixture are in a small subpanel under the standard main panel) Even if sticks were an inch shorter, they'd probably still be fine in my plane. No hard aero yet, but rolls are easy with very comfortable stick loading... See photo at: _http://websites.expercraft.com/n51pw/?q=project_ (http://websites.expercraft.com/n51pw/?q=project) and _http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=7435_ (http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=7435) which was taken before shortening. >From The PossumWorks in TN Mark **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 21, 2007
Subject: Re: good warning label
In a message dated 12/20/2007 8:55:53 P.M. Pacific Standard Time, mike109g6(at)insideconnect.net writes: As mentioned - you must use 45 degree flaring tools -not automotive 37 degree. If it is 'AN' fitting, it is 45 degree. =========================================================== Actually he's got it exactly backwards, so please don't believe this information. Standard brass fittings at the hardware store and most other similar commercial fittings are 45 degree and aircraft (AN) is 37 degrees. Do not mix up the applications or the tooling. Many of the new racing applications have adopted the aircraft standard. -GV **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 21, 2007
Hummm, I must have been supplied with a shorter stick to begin with. I have a stick grip handle which adds approx 2" to the stick length and have never had a problem with my hand hitting the panel even with the stick full forward. Its close but not touching. This in an RV-6A - I wonder if there is a difference in spacing between stick location and panel in different models?? Ed ----- Original Message ----- From: Fiveonepw(at)aol.com To: rv-list(at)matronics.com Sent: Thursday, December 20, 2007 10:57 PM Subject: Re: RV-List: cutting off the sticks In a message dated 12/20/2007 6:06:44 PM Central Standard Time, wdleonard(at)gmail.com writes: Full length stick definately got too close to the panel. >>> Another consideration is interference with panel controls- my DAR would not pink me until I cut my sticks another 1/2" since the pilot stick would touch the throttle when at idle and stick hard right, full fwd., and the right stick could just graze the mixture control at ICO with stick fully left/fwd. (My throttle and mixture are in a small subpanel under the standard main panel) Even if sticks were an inch shorter, they'd probably still be fine in my plane. No hard aero yet, but rolls are easy with very comfortable stick loading... See photo at: http://websites.expercraft.com/n51pw/?q=project and http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=743 5 which was taken before shortening. From The PossumWorks in TN Mark ------------------------------------------------------------------------- ----- See AOL's top rated recipes and easy ways to stay in shape for winter. ________________________________________________________________________________
Subject: RE: Hydraulic lines, was good warning label
Date: Dec 21, 2007
Hi All- RE: > Go to the speedshop and tell them it's for an airplane and look > stupid and ask for advice...they'll push you out the door and lock it > and tell you to never come back... I live close to gasoline alley, and have been to several speed shops there. Earl's has some familiarity with homebuilts, and doesn't flinch in the slightest. As they put it, nothing would give them more grief than if their products failed during the Indy 500. Also, unlike Aeroquip, Earl's hoses don't require any special tools to assemble. All the components are reusable, as well. With the larger fittings (I have up to 3/4) padded or aluminum tools would be nice, but I just used a couple layers of T shirt material to pad my steel tools. The catalog has embedded tutorials on how to make up assemblies from their parts. The shop also has a lot of stuff not in the catalog, including a pretty complete line of AN hardware, SCAT, some electrical goodies, a full line of the various grit scotch brite pads, a big bowl of Jolly Ranchers, lots of useful knowledge and insights, and a sense of humor. All in all, a very good place to do business. http://www.earlsindy.com 317-241-0318 The next shop down the street, North American Race Parts, suggested I could trailer my plane to their shop and stand there and watch as they custom made all my oil lines to fit, and for only the cost of the parts. That would have saved me from buying and using all the different mandrels for my different hose sizes, but that would have meant using Aeroquip. For a couple of reasons, I've decided not to use them. While a lot of places absolutely will freak at the mention of aircraft usage for their goods, Earl's isn't one of them. I can't say enough good about the guys at Earl's Indy. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Dec 21, 2007
Sorry to disagree BUT "AN" fittings are 37 degree NOT 45. Go to the www.jegs.com sited below and read what it says about the 37 degree flairing tool Jegs# 80084. 45 degree flare is used in plumbing, heating & A/C lines. Hot rod & racing use 37 degree because of aviation fitting availabilty. KABONG (C-20, C-36 Calif Contractor for A/C & Plumbing and HRII builder and EAA Tech Advisor and one time Corvette racer) >From: mike humphrey <mike109g6(at)insideconnect.net> >Date: 2007/12/20 Thu PM 10:51:45 CST >To: rv-list(at)matronics.com >Subject: Re: RV-List: good warning label >Jim,To make your own brake hoses is really no big deal. ANY fitting that says 'AN' is an acceptable fitting. 'AN' is a standardized mil-spec terminology= ArmyNavy. Any auto shop can make you brake lines. As mentioned - you must use 45 degree flaring tools -not automotive 37 degree. If it is 'AN' fitting, it is 45 degree. Go to www.summitracing.com or www.jegs.com ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Dec 21, 2007
Mea Coupa - I got it backwards. You are correct. Thanks for the correction. Mike H ----- Original Message ----- From: <jhstarn(at)verizon.net> Sent: Friday, December 21, 2007 10:51 AM Subject: RV-List: good warning label > > Sorry to disagree BUT "AN" fittings are 37 degree NOT 45. Go to the > www.jegs.com sited below and read what it says about the 37 degree > flairing tool Jegs# 80084. 45 degree flare is used in plumbing, heating & > A/C lines. Hot rod & racing use 37 degree because of aviation fitting > availabilty. > KABONG > (C-20, C-36 Calif Contractor for A/C & Plumbing and HRII builder and EAA > Tech Advisor and one time Corvette racer) > > >>From: mike humphrey <mike109g6(at)insideconnect.net> >>Date: 2007/12/20 Thu PM 10:51:45 CST >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: good warning label > >>Jim,To make your own brake hoses is really no big deal. ANY fitting >>that says 'AN' is an acceptable fitting. 'AN' is a standardized >>mil-spec terminology= ArmyNavy. Any auto shop can make you brake >>lines. As mentioned - you must use 45 degree flaring tools -not >>automotive 37 degree. If it is 'AN' fitting, it is 45 >>degree. Go to www.summitracing.com or www.jegs.com > > > ________________________________________________________________________________
Date: Dec 21, 2007
Subject: Re: RE: Hydraulic lines, was good warning label
glen matejcek wrote: > Hi All- > > RE: > Go to the speedshop and tell them it's for an airplane and > look > >> stupid and ask for advice...they'll push you out the door and lock it >> and tell you to never come back... >> [snip] > While a lot of places absolutely will freak at the mention of aircraft > usage for their goods, Earl's isn't one of them. I can't say enough good > about the guys at Earl's Indy. > When asked the question I always tell them it is for a three wheeled off road vehicle. No lies, only the truth. Steve Eberhart RV-7A, 180 HP three wheeled off road vehicle ________________________________________________________________________________
Date: Dec 21, 2007
We needed to replace the electrical connection point on the alternator (stripped threads) for HRII N561FS. Took it to a local repair shop and when ask "What's it from ?" we answered very truthfully, "It's from a homebuilt RV, We would have brought it but it's not drivable on the road yet". 8*) KABONG >From: Steven Eberhart <steve(at)newtech.com> >Date: 2007/12/21 Fri AM 10:10:32 CST >To: rv-list(at)matronics.com >Subject: Re: RV-List: RE: Hydraulic lines, was good warning label > >glen matejcek wrote: >> Hi All- >> >> RE: > Go to the speedshop and tell them it's for an airplane and >> look >> >>> stupid and ask for advice...they'll push you out the door and lock it >>> and tell you to never come back... >>> >[snip] >> While a lot of places absolutely will freak at the mention of aircraft >> usage for their goods, Earl's isn't one of them. I can't say enough good >> about the guys at Earl's Indy. >> >When asked the question I always tell them it is for a three wheeled off >road vehicle. No lies, only the truth. > >Steve Eberhart >RV-7A, 180 HP three wheeled off road vehicle ________________________________________________________________________________
Date: Dec 21, 2007
A local auto electric shop rebuilt the starter for the Cherokee that I flew and they charged the same as if it had come off of a tractor. The FBO takes things in there regularly. jhstarn(at)verizon.net wrote: > > We needed to replace the electrical connection point on the alternator (stripped threads) for HRII N561FS. Took it to a local repair shop and when ask "What's it from ?" we answered very truthfully, "It's from a homebuilt RV, We would have brought it but it's not drivable on the road yet". 8*) KABONG > > > >>From: Steven Eberhart <steve(at)newtech.com> >>Date: 2007/12/21 Fri AM 10:10:32 CST >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: RE: Hydraulic lines, was good warning label > > >> >>glen matejcek wrote: >> >>>Hi All- >>> >>>RE: > Go to the speedshop and tell them it's for an airplane and >>>look >>> >>> >>>>stupid and ask for advice...they'll push you out the door and lock it >>>>and tell you to never come back... >>>> >> >>[snip] >> >>>While a lot of places absolutely will freak at the mention of aircraft >>>usage for their goods, Earl's isn't one of them. I can't say enough good >>>about the guys at Earl's Indy. >>> >> >>When asked the question I always tell them it is for a three wheeled off >>road vehicle. No lies, only the truth. >> >>Steve Eberhart >>RV-7A, 180 HP three wheeled off road vehicle > > > > > > > ________________________________________________________________________________
Date: Dec 21, 2007
Also, AN is now Air Force-Navy standards, some bureaucrat changed it a while back. I'm from the government and I'm here to help. EEEE gads. CJ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of mike humphrey Sent: Friday, December 21, 2007 11:21 AM Subject: Re: RV-List: good warning label Mea Coupa - I got it backwards. You are correct. Thanks for the correction. Mike H ----- Original Message ----- From: <jhstarn(at)verizon.net> Sent: Friday, December 21, 2007 10:51 AM Subject: RV-List: good warning label > > Sorry to disagree BUT "AN" fittings are 37 degree NOT 45. Go to the > www.jegs.com sited below and read what it says about the 37 degree > flairing tool Jegs# 80084. 45 degree flare is used in plumbing, heating & > A/C lines. Hot rod & racing use 37 degree because of aviation fitting > availabilty. > KABONG > (C-20, C-36 Calif Contractor for A/C & Plumbing and HRII builder and EAA > Tech Advisor and one time Corvette racer) > > >>From: mike humphrey <mike109g6(at)insideconnect.net> >>Date: 2007/12/20 Thu PM 10:51:45 CST >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: good warning label > >>Jim,To make your own brake hoses is really no big deal. ANY fitting >>that says 'AN' is an acceptable fitting. 'AN' is a standardized >>mil-spec terminology= ArmyNavy. Any auto shop can make you brake >>lines. As mentioned - you must use 45 degree flaring tools -not >>automotive 37 degree. If it is 'AN' fitting, it is 45 >>degree. Go to www.summitracing.com or www.jegs.com > > > ________________________________________________________________________________
Subject: Re: Aircraft Painting
Date: Dec 21, 2007
Had my RV-6A painted by Legends in May. I would not/do not recommend them. If anyone would like more details on my experience please contact me direct. Basically, they do not understand how homebuilt airplanes are viewed/examined up close by other builders. Also, depends on who is handling the spray gun this week. Dale Ensing ----- Original Message ----- From: "Carl Bell" <carlbell(at)gforcecable.com> Sent: Friday, December 21, 2007 6:25 PM Subject: RE: RV-List: Aircraft Painting; Central Florida > > Legend Air in Aiken SC does an all white RV for $4000 and a two color for > about $5000, 3 colors for about $5500. Your have to have it ready to go > and > pulled apart. Otherwise he charges for AP time or body work time. If he > balances control surfaces it may be a few hundred more. He does Jets and > turbos, and uses the new SW Jet Flow paints. He etches, Alodine and sands > between coats and stands behind their work. Just an FYI. CJ ________________________________________________________________________________
Date: Dec 21, 2007
Subject: Re: Brake lines and Hydrauli fire
In a message dated 12/21/2007 6:22:21 P.M. Pacific Standard Time, pitts_pilot(at)bellsouth.net writes: replace the older brake fluid with the newer MIL-PRF-83282 D brake fluid which has a much higher flash point (around 440F). I then replace the brake rotors with discs twice the thickness to hold down the temps. Thanks for those two tips. I wasn't aware of either. =================================================== Search on the MIL-PRF in the archives. I tried to hip everyone to this a couple of years back when I did the research and changed mine. I believe that several manufacturers have recommended this change for their fleets but suspect that the old MIL-H-5606 is just too deeply ingrained in the FBOs for anyone to stock to the better fluid. BTW, can the thicker Cleveland disc really fit under the old (original non pressure recovery) wheel pants? N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 22, 2007
In a message dated 12/21/2007 7:42:55 AM Central Standard Time, eanderson(at)carolina.rr.com writes: This in an RV-6A - I wonder if there is a difference in spacing between stick location and panel in different models?? >>> I'd reckon there is much more difference in which grip you stick on the stick- each commercially available grip will require some modification to the actual "stick" tube supplied with the kit. Infinity grips (for example) are totally different than the CH grips I used. Bottom line is that the final configuration is acceptable to pilot and DAR... Mark **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: RE:cutting off the sticks
Date: Dec 22, 2007
Hi Ed- >This in an RV-6A - I wonder if there is a difference in spacing between >stick location and panel in different models?? In my -8, a RAC/MAC stick grip (the old style) would have hit the fwd panel had I not modified it. IIRC, I cut about 2" off of it, which I may live to regret. I kind of like the idea of putting an 'S' curve into the stick, a la decathlon. glen matejcek aerobubba(at)earthlink.ne ________________________________________________________________________________
Subject: RE: Brake lines and Hydrauli fire
Date: Dec 22, 2007
Hi Again, Ed! >Just had time to >get the engine shut down and used the starter to get the prop horizontal >before going into a ditch off the side of the runway. Wow- quick thinking. Sometimes the force is with you. I was going to go the Teflon route for the brake line loop to the caliper, but it's been suggested that there is a threat of brake temps melting the Teflon in the braided line. Does anyone have any hard evidence, numbers, or anecdotal info to this effect? >Did I mention, its smart to carry a fire extinguisher in your cockpit? Thanks for reminding me to get that on the do list. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Dec 22, 2007
Yes, I had to buy the new stuff by the gallon - enough to last me for a decade {:>). Have not found any at local FBOs who carry it. Apparently the need for the new higher flash point was driven my Military need for less flammable brake fluid - so I read. Yes, the thicker rotors will fit under the old (pre-pressure recovery) wheelpants. However, I had to redo my wheelpant brackets and add 1/8" to the three aluminum tube bracket spacers. Ed ----- Original Message ----- From: Vanremog(at)aol.com To: rv-list(at)matronics.com Sent: Friday, December 21, 2007 10:07 PM Subject: Re: RV-List: Brake lines and Hydrauli fire In a message dated 12/21/2007 6:22:21 P.M. Pacific Standard Time, pitts_pilot(at)bellsouth.net writes: replace the older brake fluid with the newer MIL-PRF-83282 D brake fluid which has a much higher flash point (around 440F). I then replace the brake rotors with discs twice the thickness to hold down the temps. Thanks for those two tips. I wasn't aware of either. = Search on the MIL-PRF in the archives. I tried to hip everyone to this a couple of years back when I did the research and changed mine. I believe that several manufacturers have recommended this change for their fleets but suspect that the old MIL-H-5606 is just too deeply ingrained in the FBOs for anyone to stock to the better fluid. BTW, can the thicker Cleveland disc really fit under the old (original non pressure recovery) wheel pants? N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) ------------------------------------------------------------------------- ----- See AOL's top rated recipes and easy ways to stay in shape for winter. ________________________________________________________________________________
Subject: Re: RE: Brake lines and Hydrauli fire
Date: Dec 22, 2007
Hi Glen, Well, I didn't think to try ground looping with the one good brake - it may not have worked out too well with a nose wheel aircraft - I can just picture it pitching over in a sharp turn. Perhaps the fact, I had just installed a new $1500 propeller might have had some influence on the decision process {:>). . The brake lines with Teflon lining are standard use brake lines. I have found that having stainless steel braid around any hose liner material seems to do a good job of holding the temps down. Not to say it couldn't happen. My view is the stainless steel Teflon lines are less likely to give you an immediate and catastrophic failure - I believe that leaks would develop and you would get some indication (mushy peddle?) of a problem before the leak got large enough to preclude braking. But, that is just speculation on my part. Yes, get that fire extinguisher - that way you will never need it. Ed . ----- Original Message ----- From: "glen matejcek" <aerobubba(at)earthlink.net> Sent: Saturday, December 22, 2007 7:27 AM Subject: RV-List: RE: Brake lines and Hydrauli fire > > Hi Again, Ed! > >>Just had time to >>get the engine shut down and used the starter to get the prop horizontal >>before going into a ditch off the side of the runway. > > Wow- quick thinking. Sometimes the force is with you. I was going to go > the Teflon route for the brake line loop to the caliper, but it's been > suggested that there is a threat of brake temps melting the Teflon in the > braided line. Does anyone have any hard evidence, numbers, or anecdotal > info to this effect? > >>Did I mention, its smart to carry a fire extinguisher in your cockpit? > > Thanks for reminding me to get that on the do list. > > glen matejcek > aerobubba(at)earthlink.net > > > ________________________________________________________________________________
Subject: Fw: [SERV] Fwd: RV8A Brake Fire
Date: Dec 22, 2007
On the topic of brake line failure and fires, I am forwarding account of an incident that happened on a RV-8A back in 2004. Just to show it happens on the newer models as well as my old RV-6A. Ed ----- Original Message ----- From: Lenleg(at)aol.com Sent: Sunday, February 01, 2004 7:55 AM Subject: [SERV] Fwd: RV8A Brake Fire In a message dated 1/31/2004 9:48:32 PM Eastern Standard Time, rgray67968(at)aol.com writes: Gang, Had a brake fire on an RV-8A last weekend. Tidy combination of operator error and design issues, much of which is specific to the 8A and/or castering nosewheel, steer-with-the-brakes airplanes in general. However, research did turn up a few items perhaps everyone should know. The fire started after an overheated caliper leaked fluid on a hot disk. The fluid flashed and lit the resin in the fiberglass wheel pant, as well as the tire sidewall. The brake worked fine, with only slightly higher pedal pressure required even when on fire. I've posted a photo to the vault (yep, a bystander had a digital camera). In the photo, I'm holding pedal pressure while shutting down for the fire crew. Note the fire on the ground under the pant, believed to be fluid and dripping resin. I don't recall any additional pedal travel. When something like this happens I get curious. Why did the seal leak at some temperature well below a failure temperature for the rest of the brake? And why did the fluid catch fire? Fast forward: It turns out the Cleveland piston seal for the little 30-9 caliper is an ordinary MS28775-218 nitrile o-ring. Nitrile's temperature rating is - 65F to +275 F. We found the seal to be brittle and flaking when we dismantled the caliper. A caliper seal with a 275 F temp limit is below automotive standards, but that's another story. As for fluid, Cleveland's tech manual specifies either Mil-H- 5606 or Mil-H-83282 as acceptable. Both are listed in AC-43 and the A&P texts. Turns out that Mil-H-83282 was created because the military was tired of setting it's airplanes on fire. Mil-H-5606 is the standard red hydraulic fluid sold by Spruce, Wicks, Chief, etc. It is a petroleum base, and turns out to have a very low flash point. The Mil-H-83282 is also red, and compatible with 5606 fluid as well as seals created for 5606. However, it is a synthetic, with much higher flash and burn points, and is self-extinguishing when removed from the ignition source. You can download complete specs for Aeroshell Fluid 41 (Mil-H- 5606) and Aeroshell Fluid 31 (Mil-H-83282) at: http://193.113.209.166/aeroshell/aeroshellhydraulicfluids.pdf Note the flash points of the two fluids. Aeroshell 41 is 104 C, which is only 219 F. Aeroshell 31 is 237 C, or 458 F. A flash point of 219 F means that when a Cleveland caliper seal fails at something above 275, the fluid is already hot enough to light when it hits a hot disk and vaporizes inside the pant. Makes for an interesting combination. Live and learn. I always assumed standard "mil-spec red brake fluid" was something special, and I doubt I was alone in this assumption. It's not. It's just another one of those "always done it that way" things prevalent with light airplanes. Note that the Shell literature declines to even refer to it as brake fluid. Spruce, etc, doesn't sell Mil-H-83282 fluid, but they should. I've already ordered a gallon of Fluid 31 from the local Shell distributor. Since the old and new fluids are compatible, switching is as easy as draining the old, flush with new, refill, and bleed. ------------------------------------------------------------------------- ------- ________________________________________________________________________________
Subject: Re: Just a Few Van's Belt Buckles..
Date: Dec 22, 2007
Thanks! Buckles Sold! Group Buy? Thanks to those who bought up my two tone gold and nickel, and nickel buckles. I was surprised at the response, must be some psychological factor about a closeout! I have gotten more requests for them, so if people are still interested, e mail me your contact info and I will save the requests and re-contact you if I get enough interest for a group buy of 6 or so. My brass models are still for sale on my website. Happy Holidays! Glenn -------- Glenn Brasch RV-9A Finishing #90623, O-360 Tucson, Arizona Van's Aircraft Belt Buckles http://home.earthlink.net/~gbrasch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153677#153677 ________________________________________________________________________________
Date: Dec 22, 2007
Subject: prop bolt length
I have a Catto 3 blade prop with the recommended Saber prop extension (same one van's sells). It is delivered with 6" bolts. I need a 1/4" spacer to get the distance between the 2 spinner bulkheads to match the spinner and of course there's the 3/8" crush plate, the washers and the 4 5/16" thick prop hub. When I add up the thickness of *everything* in the stack-up and add to that the 0.435" by which the threaded portion of the prop extension is recessed into the prop extension, I compute that only the last 1/2" of threads on the 6" prop bolts are going to engage the threads in the prop extension. Seems kind of skinny to me. On the other hand, I think this is a typical installation. Is this normal? Is it adequate? -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Dec 22, 2007
Subject: Brake lines and Hydraulic fire
Ed, Do you want to sell some of the new mil-spec brake fluid? I haven't put any into my system yet but its about due. Let me know. I guess about a quart would do. That should leave me with a small bit of spare fluid ! ? Jim Nelson ________________________________________________________________________________
Subject: Timing 0-360A1A
Date: Dec 22, 2007
It appears the timing on my 0-360A1A is off some. Since the points are not opening at the same time I need to make some adjustment. My flywheel has a line on it for TDC as well as 25 degrees. Where should the mark for 25 be aligned on this engine for timing? I had thought it was the split in the case but apparently that may not be the true. My right mag points are opening well before the left mag but the left mag seems pretty well opening with the impulse coupler. I don't have an engine service manual for this engine, thus I needed to ask. Thanks Tim ________________________________________________________________________________
Date: Dec 22, 2007
OK, following up on this question. The left mag points are opening up about 25 degrees later and coincide with the snap of the impulse coupler. This leads me to believe I need to do something to lock the impulse out in order to time these together. Any help appreciated. Thanks Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Tim Bryan > Sent: Saturday, December 22, 2007 2:36 PM > To: rv-list(at)matronics.com > Subject: RV-List: Timing 0-360A1A > > > It appears the timing on my 0-360A1A is off some. Since the points are > not > opening at the same time I need to make some adjustment. My flywheel has > a > line on it for TDC as well as 25 degrees. Where should the mark for 25 be > aligned on this engine for timing? I had thought it was the split in the > case but apparently that may not be the true. > > My right mag points are opening well before the left mag but the left mag > seems pretty well opening with the impulse coupler. > > I don't have an engine service manual for this engine, thus I needed to > ask. > Thanks > Tim > > > > ________________________________________________________________________________
Date: Dec 22, 2007
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Subject: Re: Timing 0-360A1A
If I remember right there are marks both on the front and on the back, the marks on the back line up with the slit in the case at the top and the ones on the front line up at a point on the starter. I think! Someone else let Tim know if this is right. ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm Tim Bryan wrote: > > It appears the timing on my 0-360A1A is off some. Since the points are not > opening at the same time I need to make some adjustment. My flywheel has a > line on it for TDC as well as 25 degrees. Where should the mark for 25 be > aligned on this engine for timing? I had thought it was the split in the > case but apparently that may not be the true. > > My right mag points are opening well before the left mag but the left mag > seems pretty well opening with the impulse coupler. > > I don't have an engine service manual for this engine, thus I needed to ask. > Thanks > Tim > > > ________________________________________________________________________________
Date: Dec 22, 2007
Turn the prop until the impulse coupler snaps then turn it back past the timing mark then forward to time. On my engine the timing mark lines up with a hole in the starter housing at the proper timing point. Larry Pardue On Dec 22, 2007, at 2:24 PM, Tim Bryan wrote: > > OK, following up on this question. The left mag points are opening > up about > 25 degrees later and coincide with the snap of the impulse > coupler. This > leads me to believe I need to do something to lock the impulse out > in order > to time these together. > > Any help appreciated. > Thanks > Tim > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of Tim Bryan >> Sent: Saturday, December 22, 2007 2:36 PM >> To: rv-list(at)matronics.com >> Subject: RV-List: Timing 0-360A1A >> >> >> It appears the timing on my 0-360A1A is off some. Since the >> points are >> not >> opening at the same time I need to make some adjustment. My >> flywheel has >> a >> line on it for TDC as well as 25 degrees. Where should the mark >> for 25 be >> aligned on this engine for timing? I had thought it was the split >> in the >> case but apparently that may not be the true. >> >> My right mag points are opening well before the left mag but the >> left mag >> seems pretty well opening with the impulse coupler. >> >> I don't have an engine service manual for this engine, thus I >> needed to >> ask. >> Thanks >> Tim >> >> >> >> > > ________________________________________________________________________________
Date: Dec 22, 2007
Got mine in the mail today. Looks good!! Dave Nellis --- gbrasch wrote: > > > Thanks! Buckles Sold! Group Buy? > Thanks to those who bought up my two tone gold and > nickel, and nickel buckles. I was surprised at the > response, must be some psychological factor about a > closeout! I have gotten more requests for them, so > if people are still interested, e mail me your > contact info and I will save the requests and > re-contact you if I get enough interest for a group > buy of 6 or so. My brass models are still for sale > on my website. Happy Holidays! Glenn > > -------- > Glenn Brasch > RV-9A Finishing #90623, O-360 > Tucson, Arizona > > Van's Aircraft Belt Buckles > http://home.earthlink.net/~gbrasch/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=153677#153677 > > > > > > > > > Click on > about > Admin. > > browse > Un/Subscription, > FAQ, > > Forums! > > > > > Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 22, 2007
Mine too .... I usually put a small drill bit in the hole on the starter to align with the mark on the flywheel.? Len Leggette -----Original Message----- From: Larry Pardue <n5lp(at)warpdriveonline.com> Sent: Sat, 22 Dec 2007 5:02 pm Subject: Re: RV-List: Timing 0-360A1A ? Turn the prop until the impulse coupler snaps then turn it back past the timing mark then forward to time. On my engine the timing mark lines up with a hole in the starter housing at the proper timing point.? ? Larry Pardue? ? On Dec 22, 2007, at 2:24 PM, Tim Bryan wrote:? ? >? > OK, following up on this question. The left mag points are opening > up about? > 25 degrees later and coincide with the snap of the impulse > coupler. This? > leads me to believe I need to do something to lock the impulse out > in order? > to time these together.? >? > Any help appreciated.? > Thanks? > Tim? >? >> -----Original Message-----? >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-? >> server(at)matronics.com] On Behalf Of Tim Bryan? >> Sent: Saturday, December 22, 2007 2:36 PM? >> To: rv-list(at)matronics.com? >> Subject: RV-List: Timing 0-360A1A? >>? >>? >> It appears the timing on my 0-360A1A is off some. Since the >> points are? >> not? >> opening at the same time I need to make some adjustment. My >> flywheel has? >> a? >> line on it for TDC as well as 25 degrees. Where should the mark >> for 25 be? >> aligned on this engine for timing? I had thought it was the split >> in the? >> case but apparently that may not be the true.? >>? >> My right mag points are opening well before the left mag but the >> left mag? >> seems pretty well opening with the impulse coupler.? >>? >> I don't have an engine service manual for this engine, thus I >> needed to? >> ask.? >> Thanks? >> Tim? >>? >>? >>? >>? >? >? >? >? >? >? >? ? ? ? ________________________________________________________________________ ________________________________________________________________________________
Date: Dec 22, 2007
Glad you like it, Dave! Glenn truflite(at)yahoo.com wrote: > Got mine in the mail today. > > Looks good!! > > Dave Nellis > > --- gbrasch wrote: > > > > > > > > > > Thanks! Buckles Sold! Group Buy? > > Thanks to those who bought up my two tone gold and > > nickel, and nickel buckles. I was surprised at the > > response, must be some psychological factor about a > > closeout! I have gotten more requests for them, so > > if people are still interested, e mail me your > > contact info and I will save the requests and > > re-contact you if I get enough interest for a group > > buy of 6 or so. My brass models are still for sale > > on my website. Happy Holidays! Glenn > > > > -------- > > > > > > Glenn Brasch > > RV-9A Finishing #90623, O-360 > > Tucson, Arizona > > > > Van's Aircraft Belt Buckles > > http://home.earthlink.net/~gbrasch/ > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=153677#153677 > > > > > > > > > > > > > > > > > > > > > > Click on > > about > > Admin. > > > > browse > > Un/Subscription, > > FAQ, > > > > Forums! > > > > > > > > > > > > > > > > > > Looking for last minute shopping deals? -------- Glenn Brasch RV-9A Finishing #90623, O-360 Tucson, Arizona Van's Aircraft Belt Buckles http://home.earthlink.net/~gbrasch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153728#153728 ________________________________________________________________________________
Date: Dec 22, 2007
In a message dated 12/22/2007 10:13:43 A.M. Pacific Standard Time, gbrasch(at)earthlink.net writes: Thanks to those who bought up my two tone gold and nickel, and nickel buckles. I was surprised at the response, must be some psychological factor about a closeout! I have gotten more requests for them, so if people are still interested, e mail me your contact info and I will save the requests and re-contact you if I get enough interest for a group buy of 6 or so. My brass models are still for sale on my website. Happy Holidays! ============================================================== I didn't know about them so it is nice to hear a sales pitch once in awhile. Got my two toner today and it is quite nice. Thanks a million, Glenn. I'll be wearing it with my new A-2 jacket and be the best looking airport rat on the flight line. N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: Canopy "Big Cut" Question
Date: Dec 22, 2007
I just did my 6A tip-up with Sika and I'm not a big fan of the "make the big cut and let the canopy settle" line of thinking. I had made 1/4" spacers and set them on the bow and glare shield and found that I ended up with about a 1" gap between the canopy and spacers. Because of the angle of the front of the canopy, trimming the front 1" up would also move the front edge back about the same amount. However, when I moved the canopy forward an inch, I found that the gap had lessened and so I kept cutting the front until I reduced the gap. Then I trimmed the sides until they fit into the channels, and finally I marked and trimmed the aft curves after drilling the canopy to the aft skin and channels and made sure the gaps for gluing were still appropriate. Before you cut any more from the aft area, you should still have enough room to improve your fit. I varied the gluing process because I want that "Big Cut line to be neat and also the overall canopy line to flow. So I masked the rollover structure and glued the canopy to the canopy frame with the frame in place on the fuselage. I crawled in from behind the baggage area (that top skin is not in place yet, while I do some antenna wiring), and did the fillets around the glare shield and bow and then crawled back out and clecoed the aft skin on to position the rear of the canopy and I also did the outside fillet on the glare shield. After it had set a week, I removed the aft skin and the whole canopy lifted with the frame just fine. It's been too cold here to continue, so I've been working on electrical stuff. I've masked the rollover again, this time to expose where I want the Sika to adhere. I've also masked the inside of the canopy in the same area. My next step will be to glue the canopy to the rollover (I can reach in from the aft to make the fillet on the back side of the bow). I'll cleco the aft skin on again to set the position of the canopy. After it sets, I'll make the big cut (I used red electrical tape to mask the inside of the canopy, so it will be easy to see where to cut). Any Sika that has oozed forward can be trimmed down to the rollover structure with a razor blade, and the masking will keep the ooze from sticking to either the canopy or the rollover. To the question of the gap you have, I don't see how making the cut and letting the pieces drop down to the canopy will fail to alter the entire geometry of the canopy. Try a little more patience and get a better fit to begin with. Pat Kelley - RV-6A - routing antenna cables in a freezing hangar... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dwight Frye Sent: Saturday, December 22, 2007 7:48 PM Subject: RV-List: Canopy "Big Cut" Question Ok gang ... my canopy trimming is going quite well. And I am getting close (already there?) to being ready for the "big cut". I'm building an RV-7 with a tip-up canopy, and I intend to glue with SikaFlex. At this point I have the rough-trimming done all the way around. The front of the canopy comes to the spot that the instructions suggest is the "right place" (though I know this can easily vary a bit from installation to installation). I have the "do not cut" line drawn along the back of the canopy matching the curve of the rear fuselage skin. I've trimmed to within 2 inches of that "do not cut" line. I have also trimmed away the bits of plexiglas with the molding lines from the sides, but am clearly not done trimming to an exact fit (nor should I be, according to the instructions), at least on the sides and along the back. The only place I'm trying to get the trim _exact_ is along the front. I tell all this to paint a picture of exactly where I am in the canopy trimming/fitting process. With the situation as described above, and with the sides of the canopy being pressed firmly against the side of the fuselage, I am showing roughly a 1-inch gap between the roll bar and the inside of the canopy. Gus at Van's suggested that getting it down to a half-inch was ideal, but I've heard others say they did the "big cut" with a as much as a whopping 2-inch gap there. So ... my question is, should I continue to trim to reduce the gap or should I just DO it? If I want to reduce the gap the only option is to trim from the front, I believe. I figure taking off a 1/4 inch at a time would be the way to go. True? That would be tedious ... but ... at this point I take "tedious" as a given. Suggestions? Insights? Comments? Any and all are welcome. -- Dwight RV-7, Tip-up, XP-360, API fuel injection, Hartzell BA prop (The slowest builder in the east .... ) ________________________________________________________________________________
Subject: Re: Hydraulic lines - thread sealant
Date: Dec 23, 2007
I would appreciate suggestions to cure the following. I have a very slight weep on the joint where the standard Vans nylon brake line enters into the aluminum master cylinder fitting. Dave Emond ________________________________________________________________________________
Date: Dec 23, 2007
Dave, You may need to give the nylon fitting another turn into the aluminum master cylinder. If you are like me...I was reluctant to give the nylon another turn when it didn't clock right into the proper position..so the threaded connection was not really tight. I then fought leaky connections for a year until I finally decided I had to give it another turn and risk stripping the nylon threads. I just did another one last week on one of the pedal cylinder. I turned it about 300 dergrees. The threads didn't strip and the leak appears to be gone. Dale Ensing ----- Original Message ----- From: "Emond" <d_emond(at)mweb.co.za> Sent: Sunday, December 23, 2007 3:33 AM Subject: RV-List: Re: Hydraulic lines - thread sealant > > I would appreciate suggestions to cure the following. > > I have a very slight weep on the joint where the standard Vans nylon brake > line enters into the aluminum master cylinder fitting. > > > Dave Emond > > > ________________________________________________________________________________
Date: Dec 23, 2007
Learning on your own is admirable but this may be a case where hiring an A&P to show you how to do it may be in your best interest. Ron Lee ________________________________________________________________________________
Date: Dec 23, 2007
Subject: Any builders in the Covington, GA area?
Hi folks, I'm currently visiting a friend in Covington, GA - will stay here until the 5th. Are the any builders in the area - preferably RV8A builders - that would like to show me their project? I just delivery of an RV 8A kit. Thanks Thilo -- GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS. Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail ________________________________________________________________________________
Date: Dec 23, 2007
Tim, I think you will find good reading here: http://www.sacskyranch.com/timingbendixslick.htm http://www.sacskyranch.com/faqslickmagneto.htm Dana Overall Richmond, KY i39 RV-7 slider, Imron black, "Black Magic" O 360 A1A, C/S C2YK-1BF/F7666A4 http://rvflying.tripod.com/blackwing1.jpg http://rvflying.tripod.com _________________________________________________________________ The best games are on Xbox 360. Click here for a special offer on an Xbox 360 Console. http://www.xbox.com/en-US/hardware/wheretobuy/ ________________________________________________________________________________
Date: Dec 23, 2007
Dwight, I did the skia flex on my canopy. Make sure you have the spacers in place that will keep the canopy up away from the metal structures that you will glue to. This will require the canopy to be "longer" on the sides to make up for the raising of the canopy. I did the slider and "forgot" about the difference. Needless to say, I had to make the side skins again to make up for the taller canopy. I had cut to fit and then went oops! I also had to make my rear canopy fairing from glass as the aluminum would not work as the canopy was taller back there. It worked out ok and I'm happy with the fit. The same goes for the windscreen in the front. I used about a 3/8" spacer to let the adhesive work properly. I did bolt the sides thru the canopy to the frame. Those are the only holes in my canopy. Jim Nelson RV9-A ________________________________________________________________________________
Date: Dec 23, 2007
With the help, I think I got it all figured out. Results: Data plate indicates timing is 25 BTDC. The left mag with impulse points open exactly at 25 BTDC The impulse fires exactly at TDC The right mag points open at the valley before the timing mark indicating they open about 1.5 degrees early. According to all indication I have found if it is within 2 degrees it is acceptable. I guess I am concluding the timing is OK. And the bonus is I understand it again as I had done this before but several years ago. I just had forgotten how to go through this process. Thanks to all, happy building Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Ron Lee > Sent: Sunday, December 23, 2007 9:21 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Timing 0-360A1A > > > Learning on your own is admirable but this may be a case where > hiring an A&P to show you how to do it may be in your best interest. > > Ron Lee > > > ________________________________________________________________________________
Subject: Re: Canopy "Big Cut" Question
Date: Dec 23, 2007
Hmm.. thus you have more headroom in the airplane. How much did you think you added? One of our local RV-9A folks used this technique and it never occurred to me that you would be increasing headroom. I have just started an RV-7 and may consider the sikaflex method when the time comes. Doug Weiler RV-4, 450 hours ----- Original Message ----- From: "James H Nelson" <rv9jim(at)juno.com> Sent: Sunday, December 23, 2007 10:45 AM Subject: RV-List: Canopy "Big Cut" Question > > Dwight, > I did the skia flex on my canopy. Make sure you have the spacers > in place that will keep the canopy up away from the metal structures that > you will glue to. This will require the canopy to be "longer" on the > sides to make up for the raising of the canopy. I did the slider and > "forgot" about the difference. Needless to say, I had to make the side > skins again to make up for the taller canopy. I had cut to fit and then > went oops! I also had to make my rear canopy fairing from glass as the > aluminum would not work as the canopy was taller back there. It worked > out ok and I'm happy with the fit. The same goes for the windscreen in > the front. I used about a 3/8" spacer to let the adhesive work properly. > I did bolt the sides thru the canopy to the frame. Those are the only > holes in my canopy. > > > Jim Nelson ________________________________________________________________________________
Date: Dec 23, 2007
He added 3/8". That's the recommended spacing. It may make the difference between wearing a cap or not, but it's not huge. Pat Kelley - RV-6A - Hoping Santa brings me an engine... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Doug Weiler Sent: Sunday, December 23, 2007 2:03 PM Subject: Re: RV-List: Canopy "Big Cut" Question Hmm.. thus you have more headroom in the airplane. How much did you think you added? One of our local RV-9A folks used this technique and it never occurred to me that you would be increasing headroom. I have just started an RV-7 and may consider the sikaflex method when the time comes. Doug Weiler RV-4, 450 hours ----- Original Message ----- From: "James H Nelson" <rv9jim(at)juno.com> Sent: Sunday, December 23, 2007 10:45 AM Subject: RV-List: Canopy "Big Cut" Question > > Dwight, > I did the skia flex on my canopy. Make sure you have the spacers > in place that will keep the canopy up away from the metal structures that > you will glue to. This will require the canopy to be "longer" on the > sides to make up for the raising of the canopy. I did the slider and > "forgot" about the difference. Needless to say, I had to make the side > skins again to make up for the taller canopy. I had cut to fit and then > went oops! I also had to make my rear canopy fairing from glass as the > aluminum would not work as the canopy was taller back there. It worked > out ok and I'm happy with the fit. The same goes for the windscreen in > the front. I used about a 3/8" spacer to let the adhesive work properly. > I did bolt the sides thru the canopy to the frame. Those are the only > holes in my canopy. > > > Jim Nelson ________________________________________________________________________________
Date: Dec 23, 2007
Subject: [ Edward Anderson ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Edward Anderson Lists: RV-List Subject: Brake Line Failure http://www.matronics.com/photoshare/eanderson@carolina.rr.com.12.23.2007/index.html ---------------------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ---------------------------------------------------------- ________________________________________________________________________________
Subject: Brakeline Failure Photos [ Edward Anderson ] : New Email List
Date: Dec 23, 2007
For those interested, there are two photos of my brake line fracture and fire at the below Matronics link. One shows the charred tire and wheel pant and the other shows the broken brake line - with a chunk of the side of the tube clearly blown out. Ed Ed Anderson ----- Original Message ----- From: "Email List Photo Shares" <pictures(at)matronics.com> Sent: Sunday, December 23, 2007 5:55 PM Subject: RV-List: [ Edward Anderson ] : New Email List Photo Share Available! > > > > A new Email List Photo Share is available: > > Poster: Edward Anderson > > Lists: RV-List > > Subject: Brake Line Failure > > http://www.matronics.com/photoshare/eanderson@carolina.rr.com.12.23.2007/index.html > > > ---------------------------------------------------------- > > o Main Photo Share Index > > http://www.matronics.com/photoshare > > o Submitting a Photo Share > > If you wish to submit a Photo Share of your own, please include the > following information along with your email message and files: > > 1) Email List or Lists that they are related to: > 2) Your Full Name: > 3) Your Email Address: > 4) One line Subject description: > 5) Multi-line, multi-paragraph description of topic: > 6) One-line Description of each photo or file: > > Email the information above and your files and photos to: > > pictures(at)matronics.com > > ---------------------------------------------------------- > > > ________________________________________________________________________________
Subject: Re: Brakeline Failure Photos [ Edward Anderson ] : New Email
Date: Dec 24, 2007
Ed, Perhaps I missed an earlier post on this subject but I would like to know what caused your brakes to get so hot in the first place. Had you been practicing short field landings with max braking? Maybe you had a brake dragging and you were not awear of it. Just wondering. It's hard for me to imagine brakes getting that hot in "normal" braking conditions. Steve Struyk St. Charles, MO RV-8 ----- Original Message ----- From: "Ed Anderson" <eanderson(at)carolina.rr.com> Sent: Sunday, December 23, 2007 6:23 PM Subject: RV-List: Brakeline Failure Photos [ Edward Anderson ] : New Email List Photo Share Available! > > For those interested, there are two photos of my brake line fracture and > fire at the below Matronics link. One shows the charred tire and wheel > pant and the other shows the broken brake line - with a chunk of the side > of the tube clearly blown out. > > Ed > > Ed Anderson > ----- Original Message ----- > From: "Email List Photo Shares" <pictures(at)matronics.com> > To: "Email List Photo Shares" > Sent: Sunday, December 23, 2007 5:55 PM > Subject: RV-List: [ Edward Anderson ] : New Email List Photo Share > Available! > > >> >> >> >> A new Email List Photo Share is available: >> >> Poster: Edward Anderson >> >> Lists: RV-List >> >> Subject: Brake Line Failure >> >> http://www.matronics.com/photoshare/eanderson@carolina.rr.com.12.23.2007/index.html >> >> >> >> ---------------------------------------------------------- >> >> o Main Photo Share Index >> >> http://www.matronics.com/photoshare >> >> o Submitting a Photo Share >> >> If you wish to submit a Photo Share of your own, please include the >> following information along with your email message and files: >> >> 1) Email List or Lists that they are related to: >> 2) Your Full Name: >> 3) Your Email Address: >> 4) One line Subject description: >> 5) Multi-line, multi-paragraph description of topic: >> 6) One-line Description of each photo or file: >> >> Email the information above and your files and photos to: >> >> pictures(at)matronics.com >> >> ---------------------------------------------------------- >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: RE: canopy options, was Canopy "Big Cut" Question
Date: Dec 24, 2007
Hi Doug- >Hmm.. thus you have more headroom in the airplane. How much did you think >you added? As of 2 years ago, Todd's canopies in FL could make you a canopy with more headroom, thicker material, all manner of tints, and less cost than the OEM unit. Plus, they're guaranteed. If you break it, the replacement is (relatively) cheap. FWIW- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Dec 24, 2007
Hi Steve, Reasonable questions. At the time, I had over 50 hours on those brake pads and no indication of dragging. No, I had started my take off roll and had almost reached lift off when the engine started to miss. Since I was on a 4000 foot runway, I decided to abort the take off to check things out before setting off on my 800 mile return trip to NC. So I aborted and coasted down to the far end which was on a downhill grade and everything seemed normal as I braked for the turn around. As I pushed on the right brake peddle to turn I noticed the brake seemed mushy. On the way back, I gunned the engine to check out the engine miss and was probably riding the brakes a bit to keep the speed down, when the right brake peddle goes to the floor board. Things really got exciting after that point. Loss of steering, airplane on fire and off runway excursion!! I did not think at the time I had ridden the brakes that hard and I may or may not have. But when I did a bit of research, I found the flash point of the brake fluid was between 215F and 240F - believe me. any braking at all can get your disc up to that temperature easily. I also posted to the list the same thing happening on an RV-8A. The low flash point of the brake fluid is the reason I then switched to the newer brake fluid with a flash point of nearly 440F. So did my braking contribute to the temps of the disc - no question it did, was it unusually braking - I didn't think so at the time or now - but its clear that any disc temp over 240F could have cooked off the fluid. But, it would have been a moot point, had the brake line not broke and sprayed fluid on the hot disc. I did a quick calculation of the kinetic energy dissipation required to bring my 1700 lb aircraft to a stop from 60 mph. If I did the calculations correctly it indicated I could get a disc temp max temperature increase of 330F. The temp depends of course, on how hard I braked or how long the slow down took. So that is probably the maximum increase, but even if it were 1/2 that rise in temp, if starting out with a ambient temp of 80 + 330/2 = 240F which is above the fluid's flash point. So it does not take a lot of braking to get those disc temps up. That is also one reason I discarded the old discs and went with ones that were twice as thick as the standard van discs. Having more disc material to absorb the same amount of heat will keep the disc temp lower. YMMV Ed ----- Original Message ----- From: "Steve Struyk" <rv8striker(at)hotmail.com> Sent: Monday, December 24, 2007 10:16 AM Subject: Re: RV-List: Brakeline Failure Photos [ Edward Anderson ] : New Email List Photo Share Available! > > Ed, > > Perhaps I missed an earlier post on this subject but I would like to know > what caused your brakes to get so hot in the first place. Had you been > practicing short field landings with max braking? Maybe you had a brake > dragging and you were not awear of it. Just wondering. It's hard for me to > imagine brakes getting that hot in "normal" braking conditions. > > Steve Struyk > St. Charles, MO > RV-8 > > ----- Original Message ----- > From: "Ed Anderson" <eanderson(at)carolina.rr.com> > To: "RV-List" > Sent: Sunday, December 23, 2007 6:23 PM > Subject: RV-List: Brakeline Failure Photos [ Edward Anderson ] : New Email > List Photo Share Available! > > >> >> For those interested, there are two photos of my brake line fracture and >> fire at the below Matronics link. One shows the charred tire and wheel >> pant and the other shows the broken brake line - with a chunk of the side >> of the tube clearly blown out. >> >> Ed >> >> Ed Anderson >> ----- Original Message ----- >> From: "Email List Photo Shares" <pictures(at)matronics.com> >> To: "Email List Photo Shares" >> Sent: Sunday, December 23, 2007 5:55 PM >> Subject: RV-List: [ Edward Anderson ] : New Email List Photo Share >> Available! >> >> >>> >>> >>> >>> A new Email List Photo Share is available: >>> >>> Poster: Edward Anderson >>> >>> Lists: RV-List >>> >>> Subject: Brake Line Failure >>> >>> http://www.matronics.com/photoshare/eanderson@carolina.rr.com.12.23.2007/index.html >>> >>> >>> >>> ---------------------------------------------------------- >>> >>> o Main Photo Share Index >>> >>> http://www.matronics.com/photoshare >>> >>> o Submitting a Photo Share >>> >>> If you wish to submit a Photo Share of your own, please include the >>> following information along with your email message and files: >>> >>> 1) Email List or Lists that they are related to: >>> 2) Your Full Name: >>> 3) Your Email Address: >>> 4) One line Subject description: >>> 5) Multi-line, multi-paragraph description of topic: >>> 6) One-line Description of each photo or file: >>> >>> Email the information above and your files and photos to: >>> >>> pictures(at)matronics.com >>> >>> ---------------------------------------------------------- >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 24, 2007
Subject: spinner screw spacing
My old (1999) Van's manual doesn't specify the spacing for the screws in the aft spinner bulkhead. Does any one know the nominal value? I'm guessing it's 2.5 - 3.0 inches. -- Tom S., RV-6A ________________________________________________________________________________
Subject: Re: spinner screw spacing
Date: Dec 24, 2007
RV-6A, O-360, FP prop 1) 2 blade Aymar Demuth prop: Average about 2.5 inches but varied from 2.35 to 2.6 inches 2) 3 blade Catto prop: average 2.4 inches but again some variance Ron Lee ________________________________________________________________________________
Subject: timing
Date: Dec 24, 2007
Hi Linn, I would partly disagree with you about the timing. The most critical thing is that both mags are equal, but if they are slightly off of 25 it just means the engine will be most efficient at a slightly different RPM. Since we don't know what that was when set at 25 it really doesn't matter. I've found that setting them at 23 brought chts down by 20 deg and egts up by about 50-75 But they should be within .5 deg of each other. There's an SB on 0-360-A1A's installed in Mooney's, I think, which allows for them to be set all the way back to 20. W ________________________________________________________________________________
Date: Dec 24, 2007
Subject: Re: timing
It is a service instruction, not a bulletin, and it is for 200 hp IO360s regardless of airframe. It requires internal modification to the mags, so that starting timing remains at TDC while cruise timing is 20 degrees. You will cause problems if you just dial it back to 20 degrees. The change was to reduce peak cylinder pressures for extreme cold temp operations to prevent cylinder heads from flying off the engine, dates back to the late seventies. Not applicable to the lower compression O-360 engines. Wheeler North wrote: > > Hi Linn, > > I would partly disagree with you about the timing. The most critical thing > is that both mags are equal, but if they are slightly off of 25 it just > means the engine will be most efficient at a slightly different RPM. Since > we don't know what that was when set at 25 it really doesn't matter. > > I've found that setting them at 23 brought chts down by 20 deg and egts up > by about 50-75 > > But they should be within .5 deg of each other. > > There's an SB on 0-360-A1A's installed in Mooney's, I think, which allows > for them to be set all the way back to 20. > > W > > > ________________________________________________________________________________
Date: Dec 25, 2007
Subject: synthetic brake fluid -- available locally
As an option to spending your hard earned cash on special order brake fluid, you can purchase the same stuff from your local auto parts store, but it will be labeled synthetic automatic transmission fluid.... Merry Christmas! -- Cheers! Mark Frederick Team Rocket LP www.teamrocketaircraft.com Tech Support 512.352.6979 ________________________________________________________________________________
Subject: Re: synthetic brake fluid -- available locally
Date: Dec 25, 2007
Can you provide a source that substantiates this? Since I have not added anything to my brake system since I bought it but may make some mods to improve its durability, I may add such fluid. I believe that you never use automotive brake fluid in aircraft brake systems. Is that correct? I have heard of using auto transmission fluid but would like confirmation from those more knowing about it. Ron Lee ----- Original Message ----- From: Mark Frederick To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 6:24 AM Subject: RV-List: synthetic brake fluid -- available locally As an option to spending your hard earned cash on special order brake fluid, you can purchase the same stuff from your local auto parts store, but it will be labeled synthetic automatic transmission fluid.... Merry Christmas! -- Cheers! Mark Frederick Team Rocket LP www.teamrocketaircraft.com Tech Support 512.352.6979 ________________________________________________________________________________
Date: Dec 25, 2007
A couple of years back I studied the spec sheets for Aeroshell Fluid 30 and Mobil 1 Synthetic ATF and found they are virtually the same (composition, flash point, viscosities, etc.). I would have to guess that there are at least 20 RV's/Rockets I know of (mine included) that have been flying for years without any leaks, drips, flames, etc. using ATF in the brake lines. If I were a betting man I'd bet the newer replacements for 5606 are rebranded automatic transmission fluid. About $6.00/qt at your local Walmart. Its been known that urine, bottled water, soft drinks will work as a fluid in hydraulic systems in a pinch, FWIW... IMO opinion these fluids are superior to 5606, as unfortunately original poster found out the hard way. O-rings in the system wouldn't last long with these fluids though. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Dec 25, 2007
I don't know - so can't comment on ATF - as suitable brake fluid. But, as Bob said, I found out the hard way about the flammability of the 5606 - fortunately without destroying my aircraft. You may never have a brake line failure (hopefully), and if you do it may not ignite, however, trust me once is more than enough. If you can't get rolling is one thing - not being able to get stopped is a horse of different color. Ed ----- Original Message ----- From: Bob J. To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 10:27 AM Subject: Re: RV-List: synthetic brake fluid -- available locally A couple of years back I studied the spec sheets for Aeroshell Fluid 30 and Mobil 1 Synthetic ATF and found they are virtually the same (composition, flash point, viscosities, etc.). I would have to guess that there are at least 20 RV's/Rockets I know of (mine included) that have been flying for years without any leaks, drips, flames, etc. using ATF in the brake lines. If I were a betting man I'd bet the newer replacements for 5606 are rebranded automatic transmission fluid. About $6.00/qt at your local Walmart. Its been known that urine, bottled water, soft drinks will work as a fluid in hydraulic systems in a pinch, FWIW... IMO opinion these fluids are superior to 5606, as unfortunately original poster found out the hard way. O-rings in the system wouldn't last long with these fluids though. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Dec 25, 2007
Which leads to the next question: What's a good way to purge the system of 5606 and refill with ATF? Would it suffice to cycle a pint (?) of ATF through the system by using the brake pedals to push it through to force out the 5606? KB ----- Original Message ----- From: Bob J. To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 10:27 AM Subject: Re: RV-List: synthetic brake fluid -- available locally A couple of years back I studied the spec sheets for Aeroshell Fluid 30 and Mobil 1 Synthetic ATF and found they are virtually the same (composition, flash point, viscosities, etc.). I would have to guess that there are at least 20 RV's/Rockets I know of (mine included) that have been flying for years without any leaks, drips, flames, etc. using ATF in the brake lines. If I were a betting man I'd bet the newer replacements for 5606 are rebranded automatic transmission fluid. About $6.00/qt at your local Walmart. Its been known that urine, bottled water, soft drinks will work as a fluid in hydraulic systems in a pinch, FWIW... IMO opinion these fluids are superior to 5606, as unfortunately original poster found out the hard way. O-rings in the system wouldn't last long with these fluids though. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Dec 25, 2007
KB, I don't know about the ATF - but the new 83282 if fully compatible with the older 5606, you can even mix the two although the flash point will not be as high as pure 83282. So there is no requirement to get the last drop of the 5606 out of the system. Presumably if the ATF is the same liquid as the 83282 then you could do the same. IF they are the same. Ed ----- Original Message ----- From: Kyle Boatright To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 11:18 AM Subject: Re: RV-List: synthetic brake fluid -- available locally Which leads to the next question: What's a good way to purge the system of 5606 and refill with ATF? Would it suffice to cycle a pint (?) of ATF through the system by using the brake pedals to push it through to force out the 5606? KB ----- Original Message ----- From: Bob J. To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 10:27 AM Subject: Re: RV-List: synthetic brake fluid -- available locally A couple of years back I studied the spec sheets for Aeroshell Fluid 30 and Mobil 1 Synthetic ATF and found they are virtually the same (composition, flash point, viscosities, etc.). I would have to guess that there are at least 20 RV's/Rockets I know of (mine included) that have been flying for years without any leaks, drips, flames, etc. using ATF in the brake lines. If I were a betting man I'd bet the newer replacements for 5606 are rebranded automatic transmission fluid. About $6.00/qt at your local Walmart. Its been known that urine, bottled water, soft drinks will work as a fluid in hydraulic systems in a pinch, FWIW... IMO opinion these fluids are superior to 5606, as unfortunately original poster found out the hard way. O-rings in the system wouldn't last long with these fluids though. Regards, Bob Japundza RV-6 flying F1 under const. href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: timing
Date: Dec 25, 2007
While all of that is true the inherent point was the engine will run just fine at altered timing, particularly just off a degree or two. And in fact may run a bit better with respect to chts and or egts depending on how well your airplane is cooling. I back mine down to 23 during summer and kick it up to 25 during winter. However the mags should fire at as close a time as possible. It is one reason I'm not in favor of running one mag and one variable ECM base ignition system. It is probably not too bad when they fire very differently as the later spark is wasted, but when they are firing close, heaven only knows what that does to the flame front, balanced piston loads, and potential detonation issues. ________________________________________________________________________________
Date: Dec 25, 2007
I may have missed the post that mentions where to purchase Mil-H-83282 brake fluid. Could someone tell me where I can purchase it? Thanks in advance. Richard Dudley RV-6A flying Kyle Boatright wrote: > Which leads to the next question: > > What's a good way to purge the system of 5606 and refill with ATF? > Would it suffice to cycle a pint (?) of ATF through the system by > using the brake pedals to push it through to force out the 5606? > > KB > > ----- Original Message ----- > From: Bob J. <mailto:rocketbob(at)gmail.com> > To: rv-list(at)matronics.com > Sent: Tuesday, December 25, 2007 10:27 AM > Subject: Re: RV-List: synthetic brake fluid -- available locally > > A couple of years back I studied the spec sheets for Aeroshell > Fluid 30 and Mobil 1 Synthetic ATF and found they are virtually > the same (composition, flash point, viscosities, etc.). I would > have to guess that there are at least 20 RV's/Rockets I know of > (mine included) that have been flying for years without any leaks, > drips, flames, etc. using ATF in the brake lines. > > If I were a betting man I'd bet the newer replacements for 5606 > are rebranded automatic transmission fluid. > > About $6.00/qt at your local Walmart. > > Its been known that urine, bottled water, soft drinks will work as > a fluid in hydraulic systems in a pinch, FWIW... IMO opinion > these fluids are superior to 5606, as unfortunately original > poster found out the hard way. O-rings in the system wouldn't > last long with these fluids though. > > Regards, > Bob Japundza > RV-6 flying F1 under const. > > >href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List >href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Subject: timing
Date: Dec 25, 2007
Wow this thread has become very interesting. My timing was actually about 26 degrees on one mag and closer to 24 on the second mag. I have had high CHT's all along and have done everything I can think of to get my temps down without full success. I installed louvers in the cowl, sealed around my baffles with goup, put a door behind my oil cooler and closed off one of my heater intakes. I still after settling into cruise get about 399-405 degrees for CHT's with oil temps around 185. Now I have changed my timing to be right together at 25 degrees. I have not flown yet, but when summer comes around I may very well try adjusting it to about 23 to see what happens. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Wheeler North > Sent: Tuesday, December 25, 2007 11:29 AM > To: rv-list(at)matronics.com > Subject: RV-List: timing > > > While all of that is true the inherent point was the engine will run just > fine at altered timing, particularly just off a degree or two. And in fact > may run a bit better with respect to chts and or egts depending on how > well > your airplane is cooling. I back mine down to 23 during summer and kick it > up to 25 during winter. > > However the mags should fire at as close a time as possible. It is one > reason I'm not in favor of running one mag and one variable ECM base > ignition system. It is probably not too bad when they fire very > differently > as the later spark is wasted, but when they are firing close, heaven only > knows what that does to the flame front, balanced piston loads, and > potential detonation issues. > > > > ________________________________________________________________________________
Subject: Re: timing
Date: Dec 25, 2007
Tim, what is your compression ratio? If around 9.5:1 what I have read states that timing should be 20 degrees BTDC. Ron Lee ________________________________________________________________________________
Subject: timing
Date: Dec 25, 2007
I don't know right now. It is standard 0-360 however. I will look later when I get back home. My data tag from Aero Sport says 25 BTDC. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Ron Lee > Sent: Tuesday, December 25, 2007 1:43 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: timing > > > Tim, what is your compression ratio? If around 9.5:1 what I have read > states that timing should be 20 degrees BTDC. > > Ron Lee > > > ________________________________________________________________________________
Date: Dec 25, 2007
There are a number of places, Richard, but here is where I got mine. Only down side is the minimum order is 1 gallon at $25.00. It's the 4th product on the list MIL-PRF-83282. http://commerce.acilubes.com/SearchResult.aspx?CategoryID=7 Ed ----- Original Message ----- From: Richard Dudley To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 12:53 PM Subject: Re: RV-List: synthetic brake fluid -- available locally I may have missed the post that mentions where to purchase Mil-H-83282 brake fluid. Could someone tell me where I can purchase it? Thanks in advance. Richard Dudley RV-6A flying Kyle Boatright wrote: Which leads to the next question: What's a good way to purge the system of 5606 and refill with ATF? Would it suffice to cycle a pint (?) of ATF through the system by using the brake pedals to push it through to force out the 5606? KB ----- Original Message ----- From: Bob J. To: rv-list(at)matronics.com Sent: Tuesday, December 25, 2007 10:27 AM Subject: Re: RV-List: synthetic brake fluid -- available locally A couple of years back I studied the spec sheets for Aeroshell Fluid 30 and Mobil 1 Synthetic ATF and found they are virtually the same (composition, flash point, viscosities, etc.). I would have to guess that there are at least 20 RV's/Rockets I know of (mine included) that have been flying for years without any leaks, drips, flames, etc. using ATF in the brake lines. If I were a betting man I'd bet the newer replacements for 5606 are rebranded automatic transmission fluid. About $6.00/qt at your local Walmart. Its been known that urine, bottled water, soft drinks will work as a fluid in hydraulic systems in a pinch, FWIW... IMO opinion these fluids are superior to 5606, as unfortunately original poster found out the hard way. O-rings in the system wouldn't last long with these fluids though. Regards, Bob Japundza RV-6 flying F1 under const. href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 25, 2007
Subject: Re: timing
Tim, your the first one I've heard of that has the exact same thing as I do. In cruise on 80-90 degree days I have about 400 CHTs and on climb out I have to level off about 1500 ft and pull back the throttle when the CHTs get to about 430 degrees. I've done the same things that you have, checked timing, checked baffles, put the louvers in the bottom of the cowl. I have a Superior XPO360 with one mag and one lightspeed. ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm Tim Bryan wrote: > > Wow this thread has become very interesting. My timing was actually about > 26 degrees on one mag and closer to 24 on the second mag. I have had high > CHT's all along and have done everything I can think of to get my temps down > without full success. I installed louvers in the cowl, sealed around my > baffles with goup, put a door behind my oil cooler and closed off one of my > heater intakes. I still after settling into cruise get about 399-405 > degrees for CHT's with oil temps around 185. > > Now I have changed my timing to be right together at 25 degrees. I have not > flown yet, but when summer comes around I may very well try adjusting it to > about 23 to see what happens. > > Tim > > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of Wheeler North >> Sent: Tuesday, December 25, 2007 11:29 AM >> To: rv-list(at)matronics.com >> Subject: RV-List: timing >> >> >> While all of that is true the inherent point was the engine will run just >> fine at altered timing, particularly just off a degree or two. And in fact >> may run a bit better with respect to chts and or egts depending on how >> well >> your airplane is cooling. I back mine down to 23 during summer and kick it >> up to 25 during winter. >> >> However the mags should fire at as close a time as possible. It is one >> reason I'm not in favor of running one mag and one variable ECM base >> ignition system. It is probably not too bad when they fire very >> differently >> as the later spark is wasted, but when they are firing close, heaven only >> knows what that does to the flame front, balanced piston loads, and >> potential detonation issues. >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Tailwheel & bearings
Date: Dec 25, 2007
It's time to replace my tailwheel, since it's down to 5" dia. Does anyone have a better source than Vans, or better bearing ideas? John DeCuir N204CP RV4, SNS ________________________________________________________________________________
Date: Dec 25, 2007
Subject: Fuel tank questions
I've just started flying an RV-7A with Grand Rapids displays and Van's float type sensors. I have a couple of questions for people who have a similar setup: 1. What did you find the maximum indicated fuel to be ? 2. Did you find the GRT recommended calibration to work for you ? There are two of us on the field and neither of us have gotten satisfactory results. Any alternative methods appreciated. -- Regards, m ____________________________ mike.corder(at)sbcglobal.net Cell 831-239-0915 ________________________________________________________________________________
Date: Dec 25, 2007
Subject: Re: Tailwheel & bearings
A Google search for: RV Tail wheel http://www.vansairforce.net/buildermodifications/tailwheel/Tailwheel_DougBell.htm http://www.rvproject.com/20060309.html http://www.decisionlabs.com/QuickPlace/wayne/Main.nsf/h_Toc/C659F28ABCA0A5C4852572830074B73A/?OpenDocument http://www.decisionlabs.com/QuickPlace/wayne/Main.nsf/h_Toc/3F6DF4BE0484540D85257291005B7BAE/?OpenDocument ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm John DeCuir wrote: > > It's time to replace my tailwheel, since it's down to 5" dia. Does > anyone have a better source than Vans, or better bearing ideas? > > John DeCuir > N204CP > RV4, SNS > > ________________________________________________________________________________
Date: Dec 25, 2007
I have an 8A with float sensors and the Grand Rapids EIS. I find the fuel level indication to be quite accurate following the calibration as recommended by Grand Rapids. I set up the float senders to be accurate at the bottom end of the tank level as the sensor does not have the range to do the full tank level. I did the "one gallon at a time" calibration of the EIS, logging down the EIS reading at each gallon. From this data you create a line equation just like you did back in High School algebra: Y=mX+B, where Y is gallons, m is the slope of the line, x is the reading you got while calibrating, and B is the offset so that 0 gallons reads out as 0. You set m and B as constants in the EIS so that your panel reading is in gallons. Have the plane level when you do this calibration data run. On my standard tank, readings go from 0 to 13 gallons. Any level above 13 gallons just reads 13 gallons. On the flop tube tank, readings go from 0 to 16 gallons. The senders are mounted in different locations in each tank, thus the difference in ranges. Carl Froehlich RV-8A (375 hrs) RV-10 (wings) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of MR Corder Sent: Tuesday, December 25, 2007 6:52 PM Subject: RV-List: Fuel tank questions I've just started flying an RV-7A with Grand Rapids displays and Van's float type sensors. I have a couple of questions for people who have a similar setup: 1. What did you find the maximum indicated fuel to be ? 2. Did you find the GRT recommended calibration to work for you ? There are two of us on the field and neither of us have gotten satisfactory results. Any alternative methods appreciated. -- Regards, m ____________________________ mike.corder(at)sbcglobal.net Cell 831-239-0915 ________________________________________________________________________________
Date: Dec 26, 2007
Subject: Re: timing
If I recall, my small Continentals (65 & 85) have different timings that are 2 degrees apart...something like 28 on the left and 30 on the right maybe? Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Tim Bryan wrote: > >Wow this thread has become very interesting. My timing was actually about >26 degrees on one mag and closer to 24 on the second mag. I have had high >CHT's all along and have done everything I can think of to get my temps down >without full success. I installed louvers in the cowl, sealed around my >baffles with goup, put a door behind my oil cooler and closed off one of my >heater intakes. I still after settling into cruise get about 399-405 >degrees for CHT's with oil temps around 185. > >Now I have changed my timing to be right together at 25 degrees. I have not >flown yet, but when summer comes around I may very well try adjusting it to >about 23 to see what happens. > >Tim > > > >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >>server(at)matronics.com] On Behalf Of Wheeler North >>Sent: Tuesday, December 25, 2007 11:29 AM >>To: rv-list(at)matronics.com >>Subject: RV-List: timing >> >> >>While all of that is true the inherent point was the engine will run just >>fine at altered timing, particularly just off a degree or two. And in fact >>may run a bit better with respect to chts and or egts depending on how >>well >>your airplane is cooling. I back mine down to 23 during summer and kick it >>up to 25 during winter. >> >>However the mags should fire at as close a time as possible. It is one >>reason I'm not in favor of running one mag and one variable ECM base >>ignition system. It is probably not too bad when they fire very >>differently >>as the later spark is wasted, but when they are firing close, heaven only >>knows what that does to the flame front, balanced piston loads, and >>potential detonation issues. >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Dec 25, 2007
Subject: Re: timing
The standard O-360 parallel valve engine is 8.5 to 1 in its certified configuration. YMMV if anyone did modifications. Tim Bryan wrote: > > I don't know right now. It is standard 0-360 however. I will look later > when I get back home. My data tag from Aero Sport says 25 BTDC. > Tim > > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of Ron Lee >> Sent: Tuesday, December 25, 2007 1:43 PM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: timing >> >> >> Tim, what is your compression ratio? If around 9.5:1 what I have read >> states that timing should be 20 degrees BTDC. >> >> Ron Lee >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 25, 2007
Subject: RV-4 Cabin Heat Routing
Anyone come up with a good place to run the duct for the cabin heat? Just about anywhere up front will burn my legs, and haven't quite figured a way to get the heat throughout the cabin. Was thinking of using the warm/cold mixer box that Van's sells, and could then run heat through the vents. Thoughts? Paul Besing RV-4 N73DD "Sunny" Arizona Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Dec 26, 2007
Subject: Re: timing
Try running on the lightspeed only. I have the same setup but with a O320. The temps on my engine come right down when I run on lightspeed only. Have no idea why. Bob **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: timing
Date: Dec 26, 2007
Hi Bobby, Have any of those things you did made a difference? The baffles made the biggest difference for me but not enough in my opinion. In summer I am at over 460 degrees after climb out at 110 mph initially then lowering the nose to about 130. I don't have to climb to more than 4 or 5,000 to be this hot. The louvers made the biggest difference in cruise as I was cruising at nearly 425 degrees and after the louvers it is pretty close to 400. I haven't given up on finding the reason my engine runs hotter than everyone else with the exact same thing, but I have run out of ideas. What do you have your timing set to? Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bobby Hester Sent: Tuesday, December 25, 2007 4:45 PM Subject: Re: RV-List: timing Tim, your the first one I've heard of that has the exact same thing as I do. In cruise on 80-90 degree days I have about 400 CHTs and on climb out I have to level off about 1500 ft and pull back the throttle when the CHTs get to about 430 degrees. I've done the same things that you have, checked timing, checked baffles, put the louvers in the bottom of the cowl. I have a Superior XPO360 with one mag and one lightspeed. ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm Tim Bryan wrote: Wow this thread has become very interesting. My timing was actually about 26 degrees on one mag and closer to 24 on the second mag. I have had high CHT's all along and have done everything I can think of to get my temps down without full success. I installed louvers in the cowl, sealed around my baffles with goup, put a door behind my oil cooler and closed off one of my heater intakes. I still after settling into cruise get about 399-405 degrees for CHT's with oil temps around 185. Now I have changed my timing to be right together at 25 degrees. I have not flown yet, but when summer comes around I may very well try adjusting it to about 23 to see what happens. Tim -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- server(at)matronics.com] On Behalf Of Wheeler North Sent: Tuesday, December 25, 2007 11:29 AM Subject: RV-List: timing While all of that is true the inherent point was the engine will run just fine at altered timing, particularly just off a degree or two. And in fact may run a bit better with respect to chts and or egts depending on how well your airplane is cooling. I back mine down to 23 during summer and kick it up to 25 during winter. However the mags should fire at as close a time as possible. It is one reason I'm not in favor of running one mag and one variable ECM base ignition system. It is probably not too bad when they fire very differently as the later spark is wasted, but when they are firing close, heaven only knows what that does to the flame front, balanced piston loads, and potential detonation issues. ________________________________________________________________________________
Subject: timing
Date: Dec 26, 2007
Hi Ron, I can't find anything that indicates my compression ratio. I purchased it from Aerosport Power and did not specify anything but standard so I can only presume it is the 8.5 : 1 somebody referred to. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Ron Lee > Sent: Tuesday, December 25, 2007 1:43 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: timing > > > Tim, what is your compression ratio? If around 9.5:1 what I have read > states that timing should be 20 degrees BTDC. > > Ron Lee > > > ________________________________________________________________________________
Date: Dec 26, 2007
Subject: timing
The piston part numbers may be able to help - there should be a list of components in your documentation. I got 9.2:1 with mine..... -----Original Message----- >From: Tim Bryan <n616tb(at)btsapps.com> >Sent: Dec 26, 2007 10:33 AM >To: rv-list(at)matronics.com >Subject: RE: RV-List: timing > > >Hi Ron, > >I can't find anything that indicates my compression ratio. I purchased it >from Aerosport Power and did not specify anything but standard so I can only >presume it is the 8.5 : 1 somebody referred to. > >Tim > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of Ron Lee >> Sent: Tuesday, December 25, 2007 1:43 PM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: timing >> >> >> Tim, what is your compression ratio? If around 9.5:1 what I have read >> states that timing should be 20 degrees BTDC. >> >> Ron Lee >> >> >> > > ________________________________________________________________________________
Subject: TEST
Date: Dec 26, 2007
?? ________________________________________________________________________________
Subject: Timing
Date: Dec 26, 2007
FWIW - I have an O-320-160 HP w/ fixed prop and was runniing two
December 10, 2007 - December 26, 2007
RV-Archive.digest.vol-te
