RV-Archive.digest.vol-tm
May 07, 2008 - May 26, 2008
      > to apply a heavy vacuum to the outside of the tank at the
      > effected area to
      > draw any remaining fuel out and and suck the sealant in to
      > the void.
      > additional rivets added along seam lines while still wet
      > helps to.
      > sealant application tricks.
      > clean /clean /clean. pro-seal dose not like oil and most
      > primers but loves a
      > good cleaned alodined surface.
      > mechanical grip/ light scuff on a flaying surface helps
      > with adhesion
      > tape applied along side the joints to assist with clean up
      > gloves, this stuff does not like to come off and mek is bad
      > for you
      > proper fit of parts, don't expect pro-seal to fill
      > gaps.
      > don't use to much. or you will get a wavy structure.
      > use type a for seams it helps with waves and type b for
      > fillets and fastener
      > sealing
      > don't exceed the pot life
      > mix it right and use the correct proportions a good scale
      > really helps.
      > use the longest pot life you can, i have found that 1/2
      > stuff to be almost
      > useless for most jobs.
      > the proper place for sealant is on the inside of the tank
      > not globed on the
      > outside beside it looks ugly.
      > tips of opening seams
      > sharpend putty knives are great but be sure to round the
      > corners to help
      > prevent gouges. take your time here. gentle is better.
      > removal of sealant
      > scotch bright disks work great. wear a mask. and realodine
      > after done.
      > tank testing, quick easy and cheap
      > connect air/nitrogen supply to vent
      > connect clear hose to drain about ten feet worth
      > loop hose to floor and fill with water until you have a
      > loop with three feet
      > high on both sides
      > add nitrogen until the water is four feet higher on one
      > side then the other.
      > you now have 2 psi in the tank. care should be taken here,
      > fill slowly.
      > spray the seams with soapy water and look for bubbles. use
      > hand soap or
      > aircraft soap, some soaps are bad for alum.
      > how to find that damn mystery leak i have tried everything
      > else.
      > sometimes really small leaks are the worse to find, but one
      > way to track
      > them down is to apply dye-pen developer to the outside of
      > the tank it will
      > show up any tiny leaks. over a couple of days.
      > and this ends fuel tank 101 hope it helps.
      > rick miller
      >   _____
      > Be a better friend, newshound, and
      > http://www.matronics.com/contribution
      > <http://www.matronics.com/contribution>
      > t="_blank">http://www.matronics.com/Navigator?RV-List
      > <http://www.matronics.com/Navigator?RV-List>
      > a>http://forums.matronics.com
      > <http://forums.matronics.com/>
      >   _____
      know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Date: May 07, 2008
Subject: Proseal remover?
I am resending this with the subject line changed to aid in easier searching of the archieves. Charlie Kuss --- On Wed, 5/7/08, Charles Kuss wrote: > From: Charles Kuss <chaskuss(at)yahoo.com> > Subject: RE: RV-List: Proseal remover? > To: rv-list(at)matronics.com > Date: Wednesday, May 7, 2008, 5:35 PM > Jan, > The difference between "clear" and > "gold" Alodine (or Iridite) is only cosmetic. > They add a dye to the "gold" to aid you in > knowing when the chromic conversion process has completed. > I just did a quick search regarding the application of > Pro-Seal or Chem Seal (as supplied by Vans) > Here is what I found. > > http://www.aviationproductsinc.com/Publications/TDS_PDF/TDS_CS3204.pdf > > http://corporateportal.ppg.com/NR/rdonlyres/22FFA52B-AC2C-4D75-AE20-08E03ACF8EB8/0/asaguide.pdf > > Both simply stress that the surface be clean. > > I only know of several sets of fuel tanks which were built > locally, which were Alodined prior to sealing. No one has > had any sealing problems so far. > > Charlie Kuss > > > > > --- On Wed, 5/7/08, jan > wrote: > > > From: jan <jan(at)claver.demon.co.uk> > > Subject: RE: RV-List: Proseal remover? > > To: rv-list(at)matronics.com > > Date: Wednesday, May 7, 2008, 1:22 PM > > Hi Richard, (nothing wrong with perfection .. :-) > ...) > > & Charles > > > > > > > > Is the reason for using clear and gold Alodine purely > > esthetic or is there a > > technical (chemical) reason why they are use on > different > > parts of the > > aircraft (at Boeing) ? I have used the > "gold" > > Alodine quite a lot - prior to > > painting ... on several parts of the RV I am building. > > Especially the spar. > > > > > > > > >From a adhesion point - paint does stick very well > to a > > Alodined surface - > > Does the maker of ProSeal have any official policy on > using > > Alodine prior to > > application of its product? > > > > > > > > Do you know "how many / how widely" the > practice > > of alodining the inside of > > the tanks are ?? > > > > > > > > Jan > > > > > > > > > > > > > > > > > > > > _____ > > > > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf > Of > > RICHARD MILLER > > Sent: 07 May 2008 00:22 > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Proseal remover? > > > > > > > > hi guys > > > > > > > > jan i was taught to be a litle anal retentive and > by > > the way had to > > follow boeing spec's so everything gets alodined. > clear > > for skins and gold > > for every thing else. besides i like the color. and > water > > from bad fuel is > > bad for alum tanks. > > > > > > > > larry if they don't leak now why play with it. but > when > > they start to leak > > change them out when you pull the tank. it should only > take > > about an hour > > per tank. > > > > > > > > about fuel filters, airflow performance has a filter > prior > > to the twin pump > > setup it will stop any thing big enough to damage the > > pumps, but, big but, > > do you want to risk your bird on one fuel filter. > install > > one filter per > > tank prior to the selector valve. and sleep better at > > night. remember the > > airflow system much more pressure then a carb. i have > never > > like the one > > filter idea in certified aircraft. maybe i should > apply for > > an stc for two. > > airflow fuel filters are an annual replacement item, > > don't cheat > > > > Larry Bowen wrote: > > > > FYI, I used domed nut plates on my RV-8 tanks....and > had to > > cut a couple of > > them off because they interfered with the fuel > pick-up. > > Sometimes > > second-guessing uncle Van doesn't pay off.... > > > > -- > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > > On Tue, May 6, 2008 at 2:14 PM, jan > > > > wrote: > > > > Hi Richard, > > > > > > > > I will be doing my hand build tanks later on this > summer. I > > have read your > > article with great interest. First ... I have bought > the > > domed nut plates... > > they are used on commercial planes from what I > understand > > ... and should > > make a perfect seal with a "O" ring .. Then > cover > > the nut plate after > > fitting with pro-seal as a extra safeguard against > leaks. > > > > > > > > Do you recommend alodining the tank skin and the ribs > ?? > > That is a new one > > to me ... I thought cleaning with Aluprep ...rinse > with > > water ... and scuff > > the seams is fine ?? > > > > > > > > Appreciate you comments on this > > > > > > > > Best regards > > > > > > > > Jan > > > > > > > > > > _____ > > > > > > From: owner-rv-list-server(at)matronics.com > > > > [mailto:owner-rv-list-server(at)matronics.com > > ] On > > Behalf Of RICHARD MILLER > > Sent: 06 May 2008 14:54 > > To: rv-list(at)matronics.com > > > > Subject: Re: RV-List: Proseal remover? > > > > > > > > Since we seem to have so many complaints about fuel > leaks, > > lets cover fuel > > tank 101. > > > > > > > > static loads on a fuel tank are less then .5 psi. duct > tape > > can hold .5 psi. > > dynamic loads are variable due to high g loading and > can > > reach 4 > > > > psi, with tank destruction emanate. the problem with > > checking tanks is the > > static pressure loading is applied to all surfaces and > they > > need to be > > stressed to handle that load. most are not ie, the > caps. > > > > > > > > next problem is the inherent movement of the structure > as > > it flexes. tearing > > the sealant bonds. > > > > > > > > so lets assume that you built it close to right and > now > > want to test it. > > water, fuel, any material with the exception of the > > original sealant will > > contaminate the joint during testing. so how do we > remove > > the contaminates? > > we don't contaminate in the first place. the > sealants > > we are using are > > sensitive to contaminates so air or better nitrogen is > the > > testing medium of > > choice. > > > > > > > > after inspecting aircraft with properly applied > pro-seal > > that had over > > twenty years in service, the stuff sticks. sloshing > does > > not work and will > > result in a crash, the unfortunate part of this is > that the > > pilot is always > > the first person at the crash site.. fire and medic > support > > might take a > > little longer arriving. do not slosh tanks > > > > > > > > types of leaks. > > > > > > > > seam leaks, very rare, normally caused by poor > > construction, or extreme g > > loading. > > > > > > > > fastener leaks, more common also caused by high g > loading > > and flexing of the > > structure, compounded but poor sealing practices. all > tank > > fasteners are to > > be installed wet. and then sealed on the inside. > > > > > > > > access plate/fitting leaks, most common. cause > improperly > > applied sealant, > > wrong nut plates , they should be all domed and > sealed. too > > long of screw > > that goes through the nut plate dome. bad gaskets, > failed > > orings. rotation > > of a fitting after sealant has dried. always use two > > wrenches when removing > > lines. > > > > > > > > the primary problem with tank repair is the lack of > > structural integrity of > > this tank. riveted tanks and the repair tricks where > > designed around the > > larger transport type aircraft. pro-seal sticks well > and > > can be a problem to > > break the seams apart without disturbing/destroying > the > > structure. > > > > > > > > the best way that i have found to stop small leaks at > > fasteners and seams is > > to apply a heavy vacuum to the outside of the tank at > the > > effected area to > > draw any remaining fuel out and and suck the sealant > in to > > the void. > > additional rivets added along seam lines while still > wet > > helps to. > > > > > > > > sealant application tricks. > > > > > > > > clean /clean /clean. pro-seal dose not like oil and > most > > primers but loves a > > good cleaned alodined surface. > > > > > > > > mechanical grip/ light scuff on a flaying surface > helps > > with adhesion > > > > > > > > tape applied along side the joints to assist with > clean up > > > > > > > > gloves, this stuff does not like to come off and mek > is bad > > for you > > > > > > > > proper fit of parts, don't expect pro-seal to fill > > gaps. > > > > > > > > don't use to much. or you will get a wavy > structure. > > > > > > > > use type a for seams it helps with waves and type b > for > > fillets and fastener > > sealing > > > > > > > > don't exceed the pot life > > > > > > > > mix it right and use the correct proportions a good > scale > > really helps. > > > > > > > > use the longest pot life you can, i have found that > 1/2 > > stuff to be almost > > useless for most jobs. > > > > > > > > the proper place for sealant is on the inside of the > tank > > not globed on the > > outside beside it looks ugly. > > > > > > > > tips of opening seams > > > > > > > > sharpend putty knives are great but be sure to round > the > > corners to help > > prevent gouges. take your time here. gentle is better. > > > > > > > > removal of sealant > > > > > > > > scotch bright disks work great. wear a mask. and > realodine > > after done. > > > > > > > > tank testing, quick easy and cheap > > > > > > > > connect air/nitrogen supply to vent > > > > connect clear hose to drain about ten feet worth > > > > loop hose to floor and fill with water until you have > a > > loop with three feet > > high on both sides > > > > add nitrogen until the water is four feet higher on > one > > side then the other. > > you now have 2 psi in the tank. care should be taken > here, > > fill slowly. > > > > spray the seams with soapy water and look for bubbles. > use > > hand soap or > > aircraft soap, some soaps are bad for alum. > > > > > > > > how to find that damn mystery leak i have tried > everything > > else. > > > > sometimes really small leaks are the worse to find, > but one > > way to track > > them down is to apply dye-pen developer to the outside > of > > the tank it will > > show up any tiny leaks. over a couple of days. > > > > > > > > and this ends fuel tank 101 hope it helps. > > > > > > > > > > > > rick miller > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > Be a better friend, newshound, and > > > > > > > > http://www.matronics.com/contribution > > <http://www.matronics.com/contribution> > > > > > > > t="_blank">http://www.matronics.com/Navigator?RV-List > > <http://www.matronics.com/Navigator?RV-List> > > a>http://forums.matronics.com > > <http://forums.matronics.com/> > > > > > > > > > > > > > > > > _____ > > > > > > > > Be a better friend, newshound, and > > > > > > <http://www.matronics.com/Navigator?RV-List> > > <http://www.matronics.com/contribution> > > > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Subject: Re: Airflow Fuel Filters
Date: May 07, 2008
The filter element does not need to be replaced. Just inspect and clean at your condition inspection. If you need new O-rings, give us a call, the Viton O-rings are a few bucks for the set. Don at Airflow Performance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=181794#181794 ________________________________________________________________________________
Date: May 07, 2008
Subject: Re: MX-20 Install manual
Greg I think I have one but I am not going up to the hangar until Sunday . I you haven't gotten a copy by then call me my cell 847-727-0026 Dane N838RV RV8a In a message dated 05/07/08 15:41:10 Central Daylight Time, gyoung@cs-sol.com writes: I need a PDF copy of the installation manual for an MX-20. I bought a demo unit and didn't get the manuals with it. I've found the Pilot's Guide & Quick Reference online but Garmin says the install manual has to be downloaded by a dealer. I tried all the URLs from the archives and tried to guess the name and download it blindly. No luck - it looks like Garmin has truly hidden it this time - unless someone knows more tricks. If anyone has it already or can download it and send it I'd sure appreciate it. Thanks. Regards, Greg Young Cell: 281-844-0987 gyoung@cs-sol.com www.bentwing.com ________________________________________________________________________________
Subject: Re: sniffle valve in RV 7A
Date: May 07, 2008
from Dave Cudney RV 7A struggler > I am getting further along with my project and was just buttoning up > a few odds an ends when I came to the sniffle valve for my IO 369. > On the tail dragger there is not much of a problem routing the drain > line from the sniffle valve --- but on the nose dragger, the nose > gear bracing on the engine mount is in the way. Has any one out > there solved this problem and what did you do? Thanks in advance dave > > ________________________________________________________________________________
Date: May 07, 2008
In a message dated 05/07/2008 8:14:16 PM Central Daylight Time, yenduc(at)sbcglobal.net writes: Has any one out > there solved this problem and what did you do? On a recently installed valve on an Aerosport IO-360 with AFP injection mounted to forward sump (-7A), I had more of a problem getting the drain tube away from the Vetterman crossovers. I cut the tube from the sniffle valve fairly short (1"?) and soldered a brass 90 deg. fitting to it. The other end of this fitting (from the aviation plumbing aisle at Lowes) provided for connection for a copper tube the same size as from the sniffle valve (1/8"?) using a brass compresion ferule. I installed the valve, then bent/routed a copper tube from the 90 aft, securing it mid-length to the exhaust hangar cross-piece and extended it aft out the air outlet so that when it drips (which it WILL) the fuel will simply drop to the ground rather than down the nose gear fairing and onto the pant. Not sure if this will help with your situation, but it may offer some options... >From The PossumWorks in TN Mark _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Subject: MX-20 Install manual
Date: May 07, 2008
Thank you all. I got the manual sent to me off list. Even after all these years I still marvel at the speed of response on the lists. Thanks! Regards, Greg Young _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FASTPILOTRV8 Sent: Wednesday, May 07, 2008 6:34 PM Subject: Re: RV-List: MX-20 Install manual Greg I think I have one but I am not going up to the hangar until Sunday . I you haven't gotten a copy by then call me my cell 847-727-0026 Dane N838RV RV8a In a message dated 05/07/08 15:41:10 Central Daylight Time, gyoung@cs-sol.com writes: I need a PDF copy of the installation manual for an MX-20. I bought a demo unit and didn't get the manuals with it. I've found the Pilot's Guide & Quick Reference online but Garmin says the install manual has to be downloaded by a dealer. I tried all the URLs from the archives and tried to guess the name and download it blindly. No luck - it looks like Garmin has truly hidden it this time - unless someone knows more tricks. If anyone has it already or can download it and send it I'd sure appreciate it. Thanks. Regards, Greg Young Cell: 281-844-0987 gyoung@cs-sol.com> gyoung@cs-sol.com <http://www.bentwing.com/> www.bentwing.com ="http://www.matronics.com/Navigator?RV-List" alt="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Na vigator?RV-List .matronics.com" alt="http://forums.matronics.com/">http://forums.matronics.com ://www.matronics.com/contribution" alt="http://www.matronics.com/contribution">http://www.matronics.com/contrib ution _____ Plan your next roadtrip with MapQuest.com <http://www.mapquest.com/?ncid=mpqmap00030000000004> : America's #1 Mapping Site. ________________________________________________________________________________
Date: May 07, 2008
Thanks --- I've got one of those aviation plumbing stores close by -- I'll try your method. dave On May 7, 2008, at 7:47 PM, Fiveonepw(at)aol.com wrote: > In a message dated 05/07/2008 8:14:16 PM Central Daylight Time, yenduc(at)sbcglobal.net > writes: > Has any one out > > there solved this problem and what did you do? > On a recently installed valve on an Aerosport IO-360 with AFP > injection mounted to forward sump (-7A), I had more of a problem > getting the drain tube away from the Vetterman crossovers. I cut > the tube from the sniffle valve fairly short (1"?) and soldered a > brass 90 deg. fitting to it. The other end of this fitting (from > the aviation plumbing aisle at Lowes) provided for connection for a > copper tube the same size as from the sniffle valve (1/8"?) using a > brass compresion ferule. I installed the valve, then bent/routed a > copper tube from the 90 aft, securing it mid-length to the exhaust > hangar cross-piece and extended it aft out the air outlet so that > when it drips (which it WILL) the fuel will simply drop to the > ground rather than down the nose gear fairing and onto the pant. > > Not sure if this will help with your situation, but it may offer > some options... > > From The PossumWorks in TN > Mark > http://websites.expercraft.com/n51pw/ > > > Wondering what's for Dinner Tonight? Get new twists on family > favorites at AOL Food. > > ________________________________________________________________________________
Date: May 08, 2008
Subject: sniffle valve in RV 7A
I guess I am missing something. With fuel injection, you will not have fuel "dripping" down into the air box. The sniffle valve is necessary with a carburator style fuel system. With that system you can cause raw fuel to exceed the ability of the engine to ingest it. Especially if you have an accelertor pump on the carb. That will possibly let fuel run back into the air filter box. Am I in error? I have AFP system and it has the fuel purge system which will take off all fuel pressure in the shut down phase. During a starting phase the fuel is placed just in front of the intake valve and "should" all be ingested. Jim Nelson IO-360 ________________________________________________________________________________
Subject: alternative fuel
Date: May 08, 2008
Hi All- I tried to send this yesterday, but somehow pooched it. Looks like this could have some serious potential, and be a wonderful thing for us. http://www.insideindianabusiness.com/newsitem.asp?id=29204 glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: May 08, 2008
On an IO 360 with horizontal induction mounted forward of a cold air sump, small amounts of gas can pool in the sump after shutdown. A sniffle valve is used to drain these few drops. On May 8, 2008, at 6:25 AM, James H Nelson wrote: > > I guess I am missing something. With fuel injection, you will not > have > fuel "dripping" down into the air box. The sniffle valve is necessary > with a carburator style fuel system. With that system you can cause > raw > fuel to exceed the ability of the engine to ingest it. Especially > if you > have an accelertor pump on the carb. That will possibly let fuel run > back > into the air filter box. Am I in error? I have AFP system and it has > the fuel purge system which will take off all fuel pressure in the > shut > down phase. During a starting phase the fuel is placed just in > front of > the intake valve and "should" all be ingested. > > Jim Nelson > IO-360 > > ________________________________________________________________________________
Date: May 08, 2008
Actually you can and will sometimes have fuel drain back down the intake tubes with an injected system. Prime it for a few seconds too long and it'll start dribbling, and sometimes on shutdown you can get a wee bit as well. It's standard practice to at least put a "weep hole" in the FAB or somewhere at the low point to make sure fuel doesn't pool where you don't want it. My 2 cents as usual. Cheers, Stein >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James H Nelson >Sent: Thursday, May 08, 2008 8:26 AM >To: rv-list(at)matronics.com >Subject: RV-List: sniffle valve in RV 7A > > >I guess I am missing something. With fuel injection, you will not have >fuel "dripping" down into the air box. The sniffle valve is necessary >with a carburator style fuel system. With that system you can cause raw >fuel to exceed the ability of the engine to ingest it. Especially if you >have an accelertor pump on the carb. That will possibly let fuel run back >into the air filter box. Am I in error? I have AFP system and it has >the fuel purge system which will take off all fuel pressure in the shut >down phase. During a starting phase the fuel is placed just in front of >the intake valve and "should" all be ingested. > >Jim Nelson >IO-360 > > ________________________________________________________________________________
Subject: Pro seal
remover?
Date: May 08, 2008
Thanks Charles ... Jan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Kuss Sent: 07 May 2008 22:37 Subject: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Proseal remover? I am resending this with the subject line changed to aid in easier searching of the archieves. Charlie Kuss --- On Wed, 5/7/08, Charles Kuss wrote: > From: Charles Kuss <chaskuss(at)yahoo.com> > Subject: RE: RV-List: Proseal remover? > To: rv-list(at)matronics.com > Date: Wednesday, May 7, 2008, 5:35 PM > Jan, > The difference between "clear" and > "gold" Alodine (or Iridite) is only cosmetic. > They add a dye to the "gold" to aid you in > knowing when the chromic conversion process has completed. > I just did a quick search regarding the application of > Pro-Seal or Chem Seal (as supplied by Vans) > Here is what I found. > > http://www.aviationproductsinc.com/Publications/TDS_PDF/TDS_CS3204.pdf > > http://corporateportal.ppg.com/NR/rdonlyres/22FFA52B-AC2C-4D75-AE20-08E03ACF 8EB8/0/asaguide.pdf > > Both simply stress that the surface be clean. > > I only know of several sets of fuel tanks which were built > locally, which were Alodined prior to sealing. No one has > had any sealing problems so far. > > Charlie Kuss > > > > > --- On Wed, 5/7/08, jan > wrote: > > > From: jan <jan(at)claver.demon.co.uk> > > Subject: RE: RV-List: Proseal remover? > > To: rv-list(at)matronics.com > > Date: Wednesday, May 7, 2008, 1:22 PM > > Hi Richard, (nothing wrong with perfection .. :-) > ...) > > & Charles > > > > > > > > Is the reason for using clear and gold Alodine purely > > esthetic or is there a > > technical (chemical) reason why they are use on > different > > parts of the > > aircraft (at Boeing) ? I have used the > "gold" > > Alodine quite a lot - prior to > > painting ... on several parts of the RV I am building. > > Especially the spar. > > > > > > > > >From a adhesion point - paint does stick very well > to a > > Alodined surface - > > Does the maker of ProSeal have any official policy on > using > > Alodine prior to > > application of its product? > > > > > > > > Do you know "how many / how widely" the > practice > > of alodining the inside of > > the tanks are ?? > > > > > > > > Jan > > > > > > > > > > > > > > > > > > > > _____ > > > > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf > Of > > RICHARD MILLER > > Sent: 07 May 2008 00:22 > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Proseal remover? > > > > > > > > hi guys > > > > > > > > jan i was taught to be a litle anal retentive and > by > > the way had to > > follow boeing spec's so everything gets alodined. > clear > > for skins and gold > > for every thing else. besides i like the color. and > water > > from bad fuel is > > bad for alum tanks. > > > > > > > > larry if they don't leak now why play with it. but > when > > they start to leak > > change them out when you pull the tank. it should only > take > > about an hour > > per tank. > > > > > > > > about fuel filters, airflow performance has a filter > prior > > to the twin pump > > setup it will stop any thing big enough to damage the > > pumps, but, big but, > > do you want to risk your bird on one fuel filter. > install > > one filter per > > tank prior to the selector valve. and sleep better at > > night. remember the > > airflow system much more pressure then a carb. i have > never > > like the one > > filter idea in certified aircraft. maybe i should > apply for > > an stc for two. > > airflow fuel filters are an annual replacement item, > > don't cheat > > > > Larry Bowen wrote: > > > > FYI, I used domed nut plates on my RV-8 tanks....and > had to > > cut a couple of > > them off because they interfered with the fuel > pick-up. > > Sometimes > > second-guessing uncle Van doesn't pay off.... > > > > -- > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > > On Tue, May 6, 2008 at 2:14 PM, jan > > > > wrote: > > > > Hi Richard, > > > > > > > > I will be doing my hand build tanks later on this > summer. I > > have read your > > article with great interest. First ... I have bought > the > > domed nut plates... > > they are used on commercial planes from what I > understand > > ... and should > > make a perfect seal with a "O" ring .. Then > cover > > the nut plate after > > fitting with pro-seal as a extra safeguard against > leaks. > > > > > > > > Do you recommend alodining the tank skin and the ribs > ?? > > That is a new one > > to me ... I thought cleaning with Aluprep ...rinse > with > > water ... and scuff > > the seams is fine ?? > > > > > > > > Appreciate you comments on this > > > > > > > > Best regards > > > > > > > > Jan > > > > > > > > > > _____ > > > > > > From: owner-rv-list-server(at)matronics.com > > > > [mailto:owner-rv-list-server(at)matronics.com > > ] On > > Behalf Of RICHARD MILLER > > Sent: 06 May 2008 14:54 > > To: rv-list(at)matronics.com > > > > Subject: Re: RV-List: Proseal remover? > > > > > > > > Since we seem to have so many complaints about fuel > leaks, > > lets cover fuel > > tank 101. > > > > > > > > static loads on a fuel tank are less then .5 psi. duct > tape > > can hold .5 psi. > > dynamic loads are variable due to high g loading and > can > > reach 4 > > > > psi, with tank destruction emanate. the problem with > > checking tanks is the > > static pressure loading is applied to all surfaces and > they > > need to be > > stressed to handle that load. most are not ie, the > caps. > > > > > > > > next problem is the inherent movement of the structure > as > > it flexes. tearing > > the sealant bonds. > > > > > > > > so lets assume that you built it close to right and > now > > want to test it. > > water, fuel, any material with the exception of the > > original sealant will > > contaminate the joint during testing. so how do we > remove > > the contaminates? > > we don't contaminate in the first place. the > sealants > > we are using are > > sensitive to contaminates so air or better nitrogen is > the > > testing medium of > > choice. > > > > > > > > after inspecting aircraft with properly applied > pro-seal > > that had over > > twenty years in service, the stuff sticks. sloshing > does > > not work and will > > result in a crash, the unfortunate part of this is > that the > > pilot is always > > the first person at the crash site.. fire and medic > support > > might take a > > little longer arriving. do not slosh tanks > > > > > > > > types of leaks. > > > > > > > > seam leaks, very rare, normally caused by poor > > construction, or extreme g > > loading. > > > > > > > > fastener leaks, more common also caused by high g > loading > > and flexing of the > > structure, compounded but poor sealing practices. all > tank > > fasteners are to > > be installed wet. and then sealed on the inside. > > > > > > > > access plate/fitting leaks, most common. cause > improperly > > applied sealant, > > wrong nut plates , they should be all domed and > sealed. too > > long of screw > > that goes through the nut plate dome. bad gaskets, > failed > > orings. rotation > > of a fitting after sealant has dried. always use two > > wrenches when removing > > lines. > > > > > > > > the primary problem with tank repair is the lack of > > structural integrity of > > this tank. riveted tanks and the repair tricks where > > designed around the > > larger transport type aircraft. pro-seal sticks well > and > > can be a problem to > > break the seams apart without disturbing/destroying > the > > structure. > > > > > > > > the best way that i have found to stop small leaks at > > fasteners and seams is > > to apply a heavy vacuum to the outside of the tank at > the > > effected area to > > draw any remaining fuel out and and suck the sealant > in to > > the void. > > additional rivets added along seam lines while still > wet > > helps to. > > > > > > > > sealant application tricks. > > > > > > > > clean /clean /clean. pro-seal dose not like oil and > most > > primers but loves a > > good cleaned alodined surface. > > > > > > > > mechanical grip/ light scuff on a flaying surface > helps > > with adhesion > > > > > > > > tape applied along side the joints to assist with > clean up > > > > > > > > gloves, this stuff does not like to come off and mek > is bad > > for you > > > > > > > > proper fit of parts, don't expect pro-seal to fill > > gaps. > > > > > > > > don't use to much. or you will get a wavy > structure. > > > > > > > > use type a for seams it helps with waves and type b > for > > fillets and fastener > > sealing > > > > > > > > don't exceed the pot life > > > > > > > > mix it right and use the correct proportions a good > scale > > really helps. > > > > > > > > use the longest pot life you can, i have found that > 1/2 > > stuff to be almost > > useless for most jobs. > > > > > > > > the proper place for sealant is on the inside of the > tank > > not globed on the > > outside beside it looks ugly. > > > > > > > > tips of opening seams > > > > > > > > sharpend putty knives are great but be sure to round > the > > corners to help > > prevent gouges. take your time here. gentle is better. > > > > > > > > removal of sealant > > > > > > > > scotch bright disks work great. wear a mask. and > realodine > > after done. > > > > > > > > tank testing, quick easy and cheap > > > > > > > > connect air/nitrogen supply to vent > > > > connect clear hose to drain about ten feet worth > > > > loop hose to floor and fill with water until you have > a > > loop with three feet > > high on both sides > > > > add nitrogen until the water is four feet higher on > one > > side then the other. > > you now have 2 psi in the tank. care should be taken > here, > > fill slowly. > > > > spray the seams with soapy water and look for bubbles. > use > > hand soap or > > aircraft soap, some soaps are bad for alum. > > > > > > > > how to find that damn mystery leak i have tried > everything > > else. > > > > sometimes really small leaks are the worse to find, > but one > > way to track > > them down is to apply dye-pen developer to the outside > of > > the tank it will > > show up any tiny leaks. over a couple of days. > > > > > > > > and this ends fuel tank 101 hope it helps. > > > > > > > > > > > > rick miller > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > Be a better friend, newshound, and > > > > > > > > http://www.matronics.com/contribution > > <http://www.matronics.com/contribution> > > > > > > > t="_blank">http://www.matronics.com/Navigator?RV-List > > <http://www.matronics.com/Navigator?RV-List> > > a>http://forums.matronics.com > > <http://forums.matronics.com/> > > > > > > > > > > > > > > > > _____ > > > > > > > > Be a better friend, newshound, and > > > > > > <http://www.matronics.com/Navigator?RV-List> > > <http://www.matronics.com/contribution> > > > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Subject: Pro seal
remover?
Date: May 08, 2008
Alodining is the recommended surface prep prior to applying polysulfide to an aluminum surface. If you visit the PPG website (http://corporateportal.ppg.com/NA/Aerospace/Sealants/Sealants_Products/Fue lTank_StdTech.htm) you will find that the highest strength (polysulfide) bonds are those made to alodined surfaces. Within the aerospace industry, alodine (a.k.a. Chemf ilm or Irridite or chromate conversion coating)is the the accepted best sur face treatment for polysulfide sealing. Regards, > From: jan(at)claver.demon.co.uk> To: rv-list(at)matronics.com> Subject: RE: Alo dining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pro seal remover?> D jan(at)claver.demon.co.uk>> > Thanks Charles ...> > Jan> > -----Original Messa ge-----> From: owner-rv-list-server(at)matronics.com> [mailto:owner-rv-list-se rver(at)matronics.com] On Behalf Of Charles Kuss> Sent: 07 May 2008 22:37> To: rv-list(at)matronics.com> Subject: Alodining Prior to Fuel Tank Sealing was F Kuss > > I am resending this with the subject line cha nged to aid in easier searching> of the archieves.> Charlie Kuss> > > > --- On Wed, 5/7/08, Charles Kuss <chaskuss(at)yahoo.com> wrote:> > > From: Charle s Kuss > > Subject: RE: RV-List: Proseal remover?> > To : rv-list(at)matronics.com> > Date: Wednesday, May 7, 2008, 5:35 PM> > Jan,> > The difference between "clear" and> > "gold" Alodine (or Iridite) is only cosmetic.> > They add a dye to the "gold" to aid you in> > knowing when the chromic conversion process has completed.> > I just did a quick search reg arding the application of> > Pro-Seal or Chem Seal (as supplied by Vans)> > Here is what I found.> > > > http://www.aviationproductsinc.com/Publicatio ns/TDS_PDF/TDS_CS3204.pdf> > > >> http://corporateportal.ppg.com/NR/rdonlyr es/22FFA52B-AC2C-4D75-AE20-08E03ACF> 8EB8/0/asaguide.pdf> > > > Both simply stress that the surface be clean.> > > > I only know of several sets of fu el tanks which were built> > locally, which were Alodined prior to sealing. No one has> > had any sealing problems so far.> > > > Charlie Kuss> > > > > > > > > > --- On Wed, 5/7/08, jan > > wrote:> > > > > From: jan <jan(at)claver.demon.co.uk>> > > Subject: RE: RV-List: Proseal remover?> > > To: rv-list(at)matronics.com> > > Date: Wednesday, May 7, 2008, 1:22 PM> > > Hi Richard, (nothing wrong with perfection .. :-)> > ...)> > > & Charles> > > > > > > > > > > > Is the reason for using clear and gold Al odine purely> > > esthetic or is there a> > > technical (chemical) reason w hy they are use on> > different> > > parts of the> > > aircraft (at Boeing) ? I have used the> > "gold"> > > Alodine quite a lot - prior to> > > paint ing ... on several parts of the RV I am building.> > > Especially the spar. > > > > > > > > > > > > >From a adhesion point - paint does stick very well > > to a> > > Alodined surface -> > > Does the maker of ProSeal have any of ficial policy on> > using> > > Alodine prior to> > > application of its pro duct?> > > > > > > > > > > > Do you know "how many / how widely" the> > pra ctice> > > of alodining the inside of> > > the tanks are ??> > > > > > > > > > > > Jan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ___ __ > > > > > > From: owner-rv-list-server(at)matronics.com> > > [mailto:owner- rv-list-server(at)matronics.com] On Behalf> > Of> > > RICHARD MILLER> > > Sent : 07 May 2008 00:22> > > To: rv-list(at)matronics.com> > > Subject: Re: RV-Lis t: Proseal remover?> > > > > > > > > > > > hi guys> > > > > > > > > > > > j an i was taught to be a litle anal retentive and> > by> > > the way had to> > > follow boeing spec's so everything gets alodined.> > clear> > > for sk ins and gold> > > for every thing else. besides i like the color. and> > wa ter> > > from bad fuel is> > > bad for alum tanks.> > > > > > > > > > > > l arry if they don't leak now why play with it. but> > when> > > they start t o leak> > > change them out when you pull the tank. it should only> > take> > > about an hour> > > per tank.> > > > > > > > > > > > about fuel filters , airflow performance has a filter> > prior> > > to the twin pump> > > setu p it will stop any thing big enough to damage the> > > pumps, but, big but, > > > do you want to risk your bird on one fuel filter.> > install> > > one filter per> > > tank prior to the selector valve. and sleep better at> > > night. remember the> > > airflow system much more pressure then a carb. i have> > never> > > like the one> > > filter idea in certified aircraft. may be i should> > apply for> > > an stc for two.> > > airflow fuel filters are an annual replacement item,> > > don't cheat> > > > > > Larry Bowen @bowenaero.com> wrote:> > > > > > FYI, I used domed nut plates on my RV-8 t anks....and> > had to> > > cut a couple of> > > them off because they inter fered with the fuel> > pick-up. > > > Sometimes> > > second-guessing uncle Van doesn't pay off....> > > > > > -- > > > Larry Bowen> > > Larry@BowenAer o.com> > > http://BowenAero.com > > > > > > On Tue, May 6, 2008 at 2:14 PM, jan> > > > > > wrote:> > > > > > Hi Richard,> > > > > > > > > > > > I will be doing my hand build tanks later on this> > summer. I> > > have re ad your> > > article with great interest. First ... I have bought> > the> > > domed nut plates...> > > they are used on commercial planes from what I> > understand> > > ... and should> > > make a perfect seal with a "O" ring .. Then> > cover> > > the nut plate after> > > fitting with pro-seal as a e xtra safeguard against> > leaks.> > > > > > > > > > > > Do you recommend al odining the tank skin and the ribs> > ??> > > That is a new one> > > to me ... I thought cleaning with Aluprep ...rinse> > with> > > water ... and scu ff> > > the seams is fine ??> > > > > > > > > > > > Appreciate you comments on this> > > > > > > > > > > > Best regards> > > > > > > > > > > > Jan> > > > > > > > > > > > > > > _____ > > > > > > > > > From: owner-rv-list-serve r(at)matronics.com> > > > > > [mail to:owner-rv-list-server(at)matronics.com> > > ] On> > > Behalf Of RICHARD MILLER> > > Sent: 06 May 2008 14:54 > > > To: rv-list(at)matronics.com> > > > > > S ubject: Re: RV-List: Proseal remover?> > > > > > > > > > > > Since we seem to have so many complaints about fuel> > leaks,> > > lets cover fuel> > > t ank 101.> > > > > > > > > > > > static loads on a fuel tank are less then . 5 psi. duct> > tape> > > can hold .5 psi.> > > dynamic loads are variable d ue to high g loading and> > can> > > reach 4> > > > > > psi, with tank dest ruction emanate. the problem with> > > checking tanks is the> > > static pr essure loading is applied to all surfaces and> > they> > > need to be> > > stressed to handle that load. most are not ie, the> > caps.> > > > > > > > > > > > next problem is the inherent movement of the structure> > as> > > i t flexes. tearing> > > the sealant bonds.> > > > > > > > > > > > so lets as sume that you built it close to right and> > now> > > want to test it.> > > water, fuel, any material with the exception of the> > > original sealant will> > > contaminate the joint during testing. so how do we> > remove> > > the contaminates?> > > we don't contaminate in the first place. the> > sea lants> > > we are using are> > > sensitive to contaminates so air or better nitrogen is> > the> > > testing medium of> > > choice. > > > > > > > > > > > > after inspecting aircraft with properly applied> > pro-seal> > > that had over> > > twenty years in service, the stuff sticks. sloshing> > does> > > not work and will> > > result in a crash, the unfortunate part of this is> > that the> > > pilot is always> > > the first person at the crash site .. fire and medic> > support> > > might take a> > > little longer arriving. do not slosh tanks> > > > > > > > > > > > types of leaks.> > > > > > > > > > > > seam leaks, very rare, normally caused by poor> > > construction, or extreme g> > > loading.> > > > > > > > > > > > fastener leaks, more common also caused by high g> > loading> > > and flexing of the> > > structure, c ompounded but poor sealing practices. all> > tank> > > fasteners are to> > > be installed wet. and then sealed on the inside.> > > > > > > > > > > > a ccess plate/fitting leaks, most common. cause> > improperly> > > applied se alant,> > > wrong nut plates , they should be all domed and> > sealed. too> > > long of screw> > > that goes through the nut plate dome. bad gaskets,> > failed> > > orings. rotation> > > of a fitting after sealant has dried. always use two> > > wrenches when removing> > > lines.> > > > > > > > > > > > the primary problem with tank repair is the lack of> > > structural inte grity of> > > this tank. riveted tanks and the repair tricks where> > > des igned around the> > > larger transport type aircraft. pro-seal sticks well> > and> > > can be a problem to> > > break the seams apart without disturbi ng/destroying> > the> > > structure.> > > > > > > > > > > > the best way th at i have found to stop small leaks at> > > fasteners and seams is> > > to apply a heavy vacuum to the outside of the tank at> > the> > > effected are a to> > > draw any remaining fuel out and and suck the sealant> > in to> > > the void.> > > additional rivets added along seam lines while still> > we t> > > helps to. > > > > > > > > > > > > sealant application tricks.> > > > > > > > > > > > clean /clean /clean. pro-seal dose not like oil and> > mos t> > > primers but loves a> > > good cleaned alodined surface. > > > > > > > > > > > > mechanical grip/ light scuff on a flaying surface> > helps> > > with adhesion> > > > > > > > > > > > tape applied along side the joints to assist with> > clean up> > > > > > > > > > > > gloves, this stuff does not like to come off and mek> > is bad> > > for you> > > > > > > > > > > > pro per fit of parts, don't expect pro-seal to fill> > > gaps.> > > > > > > > > > > > don't use to much. or you will get a wavy> > structure. > > > > > > > > > > > > use type a for seams it helps with waves and type b> > for> > > fillets and fastener> > > sealing> > > > > > > > > > > > don't exceed the pot life > > > > > > > > > > > > mix it right and use the correct proportio ns a good> > scale> > > really helps.> > > > > > > > > > > > use the longes t pot life you can, i have found that> > 1/2> > > stuff to be almost> > > u seless for most jobs.> > > > > > > > > > > > the proper place for sealant i s on the inside of the> > tank> > > not globed on the> > > outside beside i t looks ugly.> > > > > > > > > > > > tips of opening seams> > > > > > > > > > > > sharpend putty knives are great but be sure to round> > the> > > cor ners to help> > > prevent gouges. take your time here. gentle is better.> > > > > > > > > > > > removal of sealant > > > > > > > > > > > > scotch brig ht disks work great. wear a mask. and> > realodine> > > after done.> > > > > > > > > > > > tank testing, quick easy and cheap> > > > > > > > > > > > c onnect air/nitrogen supply to vent > > > > > > connect clear hose to drain about ten feet worth> > > > > > loop hose to floor and fill with water unti l you have> > a> > > loop with three feet> > > high on both sides > > > > > > add nitrogen until the water is four feet higher on> > one> > > side the n the other.> > > you now have 2 psi in the tank. care should be taken> > h ere,> > > fill slowly.> > > > > > spray the seams with soapy water and look for bubbles.> > use> > > hand soap or> > > aircraft soap, some soaps are b ad for alum.> > > > > > > > > > > > how to find that damn mystery leak i ha ve tried> > everything> > > else.> > > > > > sometimes really small leaks a re the worse to find,> > but one> > > way to track> > > them down is to app ly dye-pen developer to the outside> > of> > > the tank it will> > > show u p any tiny leaks. over a couple of days.> > > > > > > > > > > > and this en ds fuel tank 101 hope it helps.> > > > > > > > > > > > > > > > > > rick mil ler> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > > > > Be a better friend, newshound, and > > > > > > > > > > > > http://www.matronics.com/contribution> > > > > > > > > > > >> > t="_blank">http ://www.matronics.com/Navigator?RV-List> > > <http://www.matronics.com/Navig ator?RV-List> > > > a>http://forums.matronics.com> > > > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > > > > > > > Be a better friend, newshound, and > > > > > > > > > <http:// www.matronics.com/Navigator?RV-List> > > > <http://www.matronics.com/contri bution>> > > > > > > > Be a better friend, newshound, and > > know-it-all w ith Yahoo! Mobile. Try it now. > > http://mobile.yahoo.com/;_ylt=Ahu06i62 sR8HDtDypao8Wcj9tAcJ> > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now.> http://mobile.yahoo.com/;_ylt=Ahu06i62sR ========> > > _________________________________________________________________ Get Free (PRODUCT) RED=99 Emoticons, Winks and Display Pics. http://joinred.spaces.live.com?ocid=TXT_HMTG_prodredemoticons_052008 ________________________________________________________________________________
Subject: Pro seal
remover?
Date: May 08, 2008
Thanks guys.... Very interesting reading .... Jan _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dean Pichon Sent: 08 May 2008 21:44 Subject: RE: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pro seal remover? Alodining is the recommended surface prep prior to applying polysulfide to an aluminum surface. If you visit the PPG website (http://corporateportal.ppg.com/NA/Aerospace/Sealants/Sealants_Products/Fuel Tank_StdTech.htm <http://corporateportal.ppg.com/NA/Aerospace/Sealants/Sealants_Products/Fuel Tank_StdTech.htm> ) you will find that the highest strength (polysulfide) bonds are those made to alodined surfaces. Within the aerospace industry, alodine (a.k.a. Chemfilm or Irridite or chromate conversion coating)is the the accepted best surface treatment for polysulfide sealing. Regards, > From: jan(at)claver.demon.co.uk > To: rv-list(at)matronics.com > Subject: RE: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pro seal remover? > Date: Thu, 8 May 2008 20:27:05 +0100 > > > Thanks Charles ... > > Jan > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Kuss > Sent: 07 May 2008 22:37 > To: rv-list(at)matronics.com > Subject: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Proseal > remover? > > > I am resending this with the subject line changed to aid in easier searching > of the archieves. > Charlie Kuss > > > > --- On Wed, 5/7/08, Charles Kuss wrote: > > > From: Charles Kuss <chaskuss(at)yahoo.com> > > Subject: RE: RV-List: Proseal remover? > > To: rv-list(at)matronics.com > > Date: Wednesday, May 7, 2008, 5:35 PM > > Jan, > > The difference between "clear" and > > "gold" Alodine (or Iridite) is only cosmetic. > > They add a dye to the "gold" to aid you in > > knowing when the chromic conversion process has completed. > > I just did a quick search regarding the application of > > Pro-Seal or Chem Seal (as supplied by Vans) > > Here is what I found. > > > > http://www.aviationproductsinc.com/Publications/TDS_PDF/TDS_CS3204.pdf > > > > > http://corporateportal.ppg.com/NR/rdonlyres/22FFA52B-AC2C-4D75-AE20-08E03ACF > 8EB8/0/asaguide.pdf > > > > Both simply stress that the surface be clean. > > > > I only know of several sets of fuel tanks which were built > > locally, which were Alodined prior to sealing. No one has > > had any sealing problems so far. > > > > Charlie Kuss > > > > > > > > > > --- On Wed, 5/7/08, jan > > wrote: > > > > > From: jan <jan(at)claver.demon.co.uk> > > > Subject: RE: RV-List: Proseal remover? > > > To: rv-list(at)matronics.com > > > Date: Wednesday, May 7, 2008, 1:22 PM > > > Hi Richard, (nothing wrong with perfection .. :-) > > ...) > > > & Charles > > > > > > > > > > > > Is the reason for using clear and gold Alodine purely > > > esthetic or is there a > > > technical (chemical) reason why they are use on > > different > > > parts of the > > > aircraft (at Boeing) ? I have used the > > "gold" > > > Alodine quite a lot - prior to > > > painting ... on several parts of the RV I am building. > > > Especially the spar. > > > > > > > > > > > > >From a adhesion point - paint does stick very well > > to a > > > Alodined surface - > > > Does the maker of ProSeal have any official policy on > > using > > > Alodine prior to > > > application of its product? > > > > > > > > > > > > Do you know "how many / how widely" the > > practice > > > of alodining the inside of > > > the tanks are ?? > > > > > > > > > > > > Jan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > From: owner-rv-list-server(at)matronics.com > > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf > > Of > > > RICHARD MILLER > > > Sent: 07 May 2008 00:22 > > > To: rv-list(at)matronics.com > > > Subject: Re: RV-List: Proseal remover? > > > > > > > > > > > > hi guys > > > > > > > > > > > > jan i was taught to be a litle anal retentive and > > by > > > the way had to > > > follow boeing spec's so everything gets alodined. > > clear > > > for skins and gold > > > for every thing else. besides i like the color. and > > water > > > from bad fuel is > > > bad for alum tanks. > > > > > > > > > > > > larry if they don't leak now why play with it. but > > when > > > they start to leak > > > change them out when you pull the tank. it should only > > take > > > about an hour > > > per tank. > > > > > > > > > > > > about fuel filters, airflow performance has a filter > > prior > > > to the twin pump > > > setup it will stop any thing big enough to damage the > > > pumps, but, big but, > > > do you want to risk your bird on one fuel filter. > > install > > > one filter per > > > tank prior to the selector valve. and sleep better at > > > night. remember the > > > airflow system much more pressure then a carb. i have > > never > > > like the one > > > filter idea in certified aircraft. maybe i should > > apply for > > > an stc for two. > > > airflow fuel filters are an annual replacement item, > > > don't cheat > > > > > > Larry Bowen wrote: > > > > > > FYI, I used domed nut plates on my RV-8 tanks....and > > had to > > > cut a couple of > > > them off because they interfered with the fuel > > pick-up. > > > Sometimes > > > second-guessing uncle Van doesn't pay off.... > > > > > > -- > > > Larry Bowen > > > Larry(at)BowenAero.com > > > http://BowenAero.com > > > > > > On Tue, May 6, 2008 at 2:14 PM, jan > > > > > > wrote: > > > > > > Hi Richard, > > > > > > > > > > > > I will be doing my hand build tanks later on this > > summer. I > > > have read your > > > article with great interest. First ... I have bought > > the > > > domed nut plates... > > > they are used on commercial planes from what I > > understand > > > ... and should > > > make a perfect seal with a "O" ring .. Then > > cover > > > the nut plate after > > > fitting with pro-seal as a extra safeguard against > > leaks. > > > > > > > > > > > > Do you recommend alodining the tank skin and the ribs > > ?? > > > That is a new one > > > to me ... I thought cleaning with Aluprep ...rinse > > with > > > water ... and scuff > > > the seams is fine ?? > > > > > > > > > > > > Appreciate you comments on this > > > > > > > > > > > > Best regards > > > > > > > > > > > > Jan > > > > > > > > > > > > > > > _____ > > > > > > > > > From: owner-rv-list-server(at)matronics.com > > > > > > [mailto:owner-rv-list-server(at)matronics.com > > > ] On > > > Behalf Of RICHARD MILLER > > > Sent: 06 May 2008 14:54 > > > To: rv-list(at)matronics.com > > > > > > Subject: Re: RV-List: Proseal remover? > > > > > > > > > > > > Since we seem to have so many complaints about fuel > > leaks, > > > lets cover fuel > > > tank 101. > > > > > > > > > > > > static loads on a fuel tank are less then .5 psi. duct > > tape > > > can hold .5 psi. > > > dynamic loads are variable due to high g loading and > > can > > > reach 4 > > > > > > psi, with tank destruction emanate. the problem with > > > checking tanks is the > > > static pressure loading is applied to all surfaces and > > they > > > need to be > > > stressed to handle that load. most are not ie, the > > caps. > > > > > > > > > > > > next problem is the inherent movement of the structure > > as > > > it flexes. tearing > > > the sealant bonds. > > > > > > > > > > > > so lets assume that you built it close to right and > > now > > > want to test it. > > > water, fuel, any material with the exception of the > > > original sealant will > > > contaminate the joint during testing. so how do we > > remove > > > the contaminates? > > > we don't contaminate in the first place. the > > sealants > > > we are using are > > > sensitive to contaminates so air or better nitrogen is > > the > > > testing medium of > > > choice. > > > > > > > > > > > > after inspecting aircraft with properly applied > > pro-seal > > > that had over > > > twenty years in service, the stuff sticks. sloshing > > does > > > not work and will > > > result in a crash, the unfortunate part of this is > > that the > > > pilot is always > > > the first person at the crash site.. fire and medic > > support > > > might take a > > > little longer arriving. do not slosh tanks > > > > > > > > > > > > types of leaks. > > > > > > > > > > > > seam leaks, very rare, normally caused by poor > > > construction, or extreme g > > > loading. > > > > > > > > > > > > fastener leaks, more common also caused by high g > > loading > > > and flexing of the > > > structure, compounded but poor sealing practices. all > > tank > > > fasteners are to > > > be installed wet. and then sealed on the inside. > > > > > > > > > > > > access plate/fitting leaks, most common. cause > > improperly > > > applied sealant, > > > wrong nut plates , they should be all domed and > > sealed. too > > > long of screw > > > that goes through the nut plate dome. bad gaskets, > > failed > > > orings. rotation > > > of a fitting after sealant has dried. always use two > > > wrenches when removing > > > lines. > > > > > > > > > > > > the primary problem with tank repair is the lack of > > > structural integrity of > > > this tank. riveted tanks and the repair tricks where > > > designed around the > > > larger transport type aircraft. pro-seal sticks well > > and > > > can be a problem to > > > break the seams apart without disturbing/destroying > > the > > > structure. > > > > > > > > > > > > the best way that i have found to stop small leaks at > > > fasteners and seams is > > > to apply a heavy vacuum to the outside of the tank at > > the > > > effected area to > > > draw any remaining fuel out and and suck the sealant > > in to > > > the void. > > > additional rivets added along seam lines while still > > wet > > > helps to. > > > > > > > > > > > > sealant application tricks. > > > > > > > > > > > > clean /clean /clean. pro-seal dose not like oil and > > most > > > primers but loves a > > > good cleaned alodined surface. > > > > > > > > > > > > mechanical grip/ light scuff on a flaying surface > > helps > > > with adhesion > > > > > > > > > > > > tape applied along side the joints to assist with > > clean up > > > > > > > > > > > > gloves, this stuff does not like to come off and mek > > is bad > > > for you > > > > > > > > > > > > proper fit of parts, don't expect pro-seal to fill > > > gaps. > > > > > > > > > > > > don't use to much. or you will get a wavy > > structure. > > > > > > > > > > > > use type a for seams it helps with waves and type b > > for > > > fillets and fastener > > > sealing > > > > > > > > > > > > don't exceed the pot life > > > > > > > > > > > > mix it right and use the correct proportions a good > > scale > > > really helps. > > > > > > > > > > > > use the longest pot life you can, i have found that > > 1/2 > > > stuff to be almost > > > useless for most jobs. > > > > > > > > > > > > the proper place for sealant is on the inside of the > > tank > > > not globed on the > > > outside beside it looks ugly. > > > > > > > > > > > > tips of opening seams > > > > > > > > > > > > sharpend putty knives are great but be sure to round > > the > > > corners to help > > > prevent gouges. take your time here. gentle is better. > > > > > > > > > > > > removal of sealant > > > > > > > > > > > > scotch bright disks work great. wear a mask. and > > realodine > > > after done. > > > > > > > > > > > > tank testing, quick easy and cheap > > > > > > > > > > > > connect air/nitrogen supply to vent > > > > > > connect clear hose to drain about ten feet worth > > > > > > loop hose to floor and fill with water until you have > > a > > > loop with three feet > > > high on both sides > > > > > > add nitrogen until the water is four feet higher on > > one > > > side then the other. > > > you now have 2 psi in the tank. care should be taken > > here, > > > fill slowly. > > > > > > spray the seams with soapy water and look for bubbles. > > use > > > hand soap or > > > aircraft soap, some soaps are bad for alum. > > > > > > > > > > > > how to find that damn mystery leak i have tried > > everything > > > else. > > > > > > sometimes really small leaks are the worse to find, > > but one > > > way to track > > > them down is to apply dye-pen developer to the outside > > of > > > the tank it will > > > show up any tiny leaks. over a couple of days. > > > > > > > > > > > > and this ends fuel tank 101 hope it helps. > > > > > > > > > > > > > > > > > > rick miller > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > > > > Be a better friend, newshound, and > > > > > > > > > > > > http://www.matronics.com/contribution > > > <http://www.matronics.com/contribution> > > > > > > > > > > > t="_blank">http://www.matronics.com/Navigator?RV-List > > > <http://www.matronics.com/Navigator?RV-List> > > > a>http://forums.matronics.com > > > <http://forums.matronics.com/> > > > > > > > > > > > > > > > > > > > > > > > > _____ > > > > > > > > > > > > Be a better friend, newshound, and > > > > > > > > > <http://www.matronics.com/Navigator?RV-List> > > > <http://www.matronics.com/contribution> > > > > > > > > Be a better friend, newshound, and > > know-it-all with Yahoo! Mobile. Try it now. > > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ > > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ > > > _____ Get Free (PRODUCT) RED(tm) Emoticons, Winks and Display Pics. Check it out! <http://joinred.spaces.live.com?ocid=TXT_HMTG_prodredemoticons_052008> http://www.w3.org/TR/REC-html40">
Thanks guys…. Very interesting reading ….
Jan
(http://corporateportal.ppg.com/NA/Aerospace /Sealants/Sealants_Products/FuelTank_StdTech.htm)
> From: jan(at)claver.demon.co.uk<br> > To: rv-list(at)matronics.com
> --> RV-List message posted by: jan <jan(at)claver.demon.co.uk>
> Thanks Charles ...
> Jan
> From: owner-rv-list-server(at)matronics.com<br> > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Kuss
> remover?
> --> RV-List message posted by: Charles Kuss <chaskuss(at)yahoo.com>
> of the archieves.
> Charlie Kuss
> > From: Charles Kuss <chaskuss(at)yahoo.com><br> > > Subject: RE: RV-List: Proseal remover?
> > Jan,
> > http://www.aviationproductsinc.com/Publications/TDS_PDF/TDS_CS3204.pdf r> > >
http://corporateportal.ppg.com/NR/rdonlyres/22FFA52B-AC2C-4D75-AE20-08E0 3ACF
> 8EB8/0/asaguide.pdf
> > Charlie Kuss
> > --- On Wed, 5/7/08, jan <jan(at)claver.demon.co.uk>
> > wrote:
> > > From: jan <jan(at)claver.demon.co.uk><br> > > > Subject: RE: RV-List: Proseal remover?
> > > & Charles
> > different
> > > parts of the
> > "gold"
> > to a
> > > Alodined surface -
> > using
> > > Alodine prior to
> > practice
> > > the tanks are ??
> > > Jan
> > > _____
> > > From: owner-rv-list-server(at)matronics.com<br> > > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf
> > Of
> > > RICHARD MILLER
> > > hi guys
> > by
> > > the way had to
> > clear
> > > for skins and gold
> > water
> > > from bad fuel is
> > > bad for alum tanks.
> > when
> > > they start to leak
> > take
> > > about an hour
> > > per tank.
> > prior
> > > to the twin pump
> > install
> > > one filter per
> > > night. remember the
> > never
> > > like the one
> > apply for
> > > an stc for two.
> > > don't cheat
> > had to
> > > cut a couple of
> > pick-up.
> > > Sometimes
> > > Larry Bowen
> > > http://BowenAero.com <http://bowenaero.com/>
> > > <mailto:jan(at)claver.demon.co.uk> > wrote:
> > > Hi Richard,
> > summer. I
> > > have read your
> > the
> > > domed nut plates...
> > understand
> > > ... and should
> > cover
> > > the nut plate after
> > leaks.
> > > That is a new one
> > with
> > > water ... and scuff
> > > Best regards
> > > Jan
> > > _____
> > > From: owner-rv-list-server(at)matronics.com<br> > > > <mailto:owner-rv-list-server(at)matronics.com>
> > > <mailto:owner-rv-list-server(at)matronics.com> ] On
> > > <mailto:rv-list(at)matronics.com>
> > leaks,
> > > lets cover fuel
> > > tank 101.
> > tape
> > > can hold .5 psi.
> > can
> > > reach 4
> > they
> > > need to be
> > caps.
> > as
> > > it flexes. tearing
> > > the sealant bonds.
> > now
> > > want to test it.
> > remove
> > > the contaminates?
> > sealants
> > > we are using are
> > the
> > > testing medium of
> > > choice.
> > pro-seal
> > > that had over
> > does
> > > not work and will
> > that the
> > > pilot is always
> > support
> > > might take a
> > > types of leaks.
> > > loading.
> > loading
> > > and flexing of the
> > tank
> > > fasteners are to
> > improperly
> > > applied sealant,
> > sealed. too
> > > long of screw
> > failed
> > > orings. rotation
> > > lines.
> > > designed around the
> > and
> > > can be a problem to
> > the
> > > structure.
> > the
> > > effected area to
> > in to
> > > the void.
> > wet
> > > helps to.
> > most
> > > primers but loves a
> > helps
> > > with adhesion
> > clean up
> > is bad
> > > for you
> > > gaps.
> > structure.
> > for
> > > sealing
> > scale
> > > really helps.
> > 1/2
> > > stuff to be almost
> > tank
> > > not globed on the
> > the
> > > corners to help
> > > removal of sealant
> > realodine
> > > after done.
> > a
> > > high on both sides
> > one
> > here,
> > > fill slowly.
> > use
> > > hand soap or
> > everything
> > > else.
> > but one
> > > way to track
> > of
> > > the tank it will
> > > rick miller
> > > _____
> > > http://www.matronics.com/contribution> > > > <http://www.matronics.com/contribution>
> > t="_blank">http://www.matronics.com/Navigator?RV-List> > > > <http://www.matronics.com/Navigator?RV-List>
> > > a>http://forums.matronics.com> > > > <http://forums.matronics.com/>
> > > _____
> > > <http://www.matronics.com/contribution>> > >
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ> >
Get Free (PRODUCT) RED™ Emoticons, Winks and Display Pics. Check it out!
Date: May 08, 2008
Subject: Re: Pro
seal remover? Used some Pro-Seal on a car projet a while back but then had to remove it.. ....paint remover worked fairly well.=0A=0A-Scott RV-8a=0A=0A=0A=0A=0A--- -- Original Message ----=0AFrom: jan <jan(at)claver.demon.co.uk>=0ATo: rv-list @matronics.com=0ASent: Thursday, May 8, 2008 2:05:50 PM=0ASubject: RE: Alod ining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pro seal remover?=0A =0A=0AThanks guys=85. Very interesting reading =85.=0A-=0AJan=0A-=0A=0A ________________________________=0A=0AFrom:owner-rv-list-server(at)matronics.c om [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dean Pichon=0AS ent: 08 May 2008 21:44=0ATo: rv-list(at)matronics.com=0ASubject: RE: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pro seal remover?=0A-=0A Alodining is the recommended surface prep prior to applying polysulfide to an aluminum surface.- If-you visit the PPG website=0A-=0A(http://corp orateportal.ppg.com/NA/Aerospace/Sealants/Sealants_Products/FuelTank_StdTec h.htm)=0A-=0Ayou will find that the highest strength (polysulfide) bonds are those made to alodined surfaces.- Within the aerospace industry, alod ine (a.k.a. Chemfilm or Irridite or chromate conversion coating)is the the accepted best surface treatment for polysulfide sealing.=0A-=0ARegards, =0A=0A=0A> From: jan(at)claver.demon.co.uk=0A> To: rv-list(at)matronics.com=0A> S ubject: RE: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pro s eal remover?=0A> Date: Thu, 8 May 2008 20:27:05 +0100=0A> =0A> --> RV-List message posted by: jan =0A> =0A> Thanks Charles ... =0A> =0A> Jan=0A> =0A> -----Original Message-----=0A> From: owner-rv-list-s erver(at)matronics.com=0A> [mailto:owner-rv-list-server(at)matronics.com] On Beha lf Of Charles Kuss=0A> Sent: 07 May 2008 22:37=0A> To: rv-list(at)matronics.co m=0A> Subject: Alodining Prior to Fuel Tank Sealing was Fw: RE: RV-List: Pr askuss(at)yahoo.com>=0A> =0A> I am resending this with the subject line change d to aid in easier searching=0A> of the archieves.=0A> Charlie Kuss=0A> =0A > =0A> =0A> --- On Wed, 5/7/08, Charles Kuss wrote:=0A > =0A> > From: Charles Kuss <chaskuss(at)yahoo.com>=0A> > Subject: RE: RV-List : Proseal remover?=0A> > To: rv-list(at)matronics.com=0A> > Date: Wednesday, M ay 7, 2008, 5:35 PM=0A> > Jan,=0A> > The difference between "clear" and=0A> > "gold" Alodine (or Iridite) is only cosmetic.=0A> > They add a dye to th e "gold" to aid you in=0A> > knowing when the chromic conversion process ha s completed.=0A> > I just did a quick search regarding the application of =0A> > Pro-Seal or Chem Seal (as supplied by Vans)=0A> > Here is what I fou nd.=0A> > =0A> > http://www.aviationproductsinc.com/Publications/TDS_PDF/TD S_CS3204.pdf=0A> > =0A> >=0A> http://corporateportal.ppg.com/NR/rdonlyres/2 2FFA52B-AC2C-4D75-AE20-08E03ACF=0A> 8EB8/0/asaguide.pdf=0A> > =0A> > Both s imply stress that the surface be clean.=0A> > =0A> > I only know of several sets of fuel tanks which were built=0A> > locally, which were Alodined pri or to sealing. No one has=0A> > had any sealing problems so far.=0A> > =0A> > Charlie Kuss=0A> > =0A> > =0A> > =0A> > =0A> > --- On Wed, 5/7/08, jan < jan(at)claver.demon.co.uk>=0A> > wrote:=0A> > =0A> > > From: jan <jan(at)claver.d emon.co.uk>=0A> > > Subject: RE: RV-List: Proseal remover?=0A> > > To: rv-l ist(at)matronics.com=0A> > > Date: Wednesday, May 7, 2008, 1:22 PM=0A> > > Hi Richard, (nothing wrong with perfection .. :-)=0A> > ...)=0A> > > & Charles =0A> > > =0A> > > =0A> > > =0A> > > Is the reason for using clear and gold Alodine purely=0A> > > esthetic or is there a=0A> > > technical (chemical) reason why they are use on=0A> > different=0A> > > parts of the=0A> > > air craft (at Boeing) ? I have used the=0A> > "gold"=0A> > > Alodine quite a lo t - prior to=0A> > > painting ... on several parts of the RV I am building. =0A> > > Especially the spar.=0A> > > =0A> > > =0A> > > =0A> > > >From a ad hesion point - paint does stick very well=0A> > to a=0A> > > Alodined surfa ce -=0A> > > Does the maker of ProSeal have any official policy on=0A> > us ing=0A> > > Alodine prior to=0A> > > application of its product?=0A> > > =0A> > > =0A> > > =0A> > > Do you know "how many / how widely" the=0A> > pr actice=0A> > > of alodining the inside of=0A> > > the tanks are ??=0A> > > =0A> > > =0A> > > =0A> > > Jan =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > _____ =0A> > > =0A> > > From: owner-rv-list-server(at)matronics.com=0A> > > [mailto:owner-rv-list-server@ma tronics.com] On Behalf=0A> > Of=0A> > > RICHARD MILLER=0A> > > Sent: 07 May 2008 00:22=0A> > > To: rv-list(at)matronics.com=0A> > > Subject: Re: RV-List: Proseal remover?=0A> > > =0A> > > =0A> > > =0A> > > hi guys=0A> > > =0A> > > =0A> > > =0A> > > jan i was taught to be a litle anal retentive and=0A> > by=0A> > > the way had to=0A> > > follow boeing spec's so everything gets alodined.=0A> > clear=0A> > > for skins and gold=0A> > > for every thing e lse. besides i like the color. and=0A> > water=0A> > > from bad fuel is=0A> > > bad for alum tanks.=0A> > > =0A> > > =0A> > > =0A> > > larry if they d on't leak now why play with it. but=0A> > when=0A> > > they start to leak =0A> > > change them out when you pull the tank. it should only=0A> > take =0A> > > about an hour=0A> > > per tank.=0A> > > =0A> > > =0A> > > =0A> > > about fuel filters, airflow performance has a filter=0A> > prior=0A> > > t o the twin pump=0A> > > setup it will stop any thing big enough to damage t he=0A> > > pumps, but, big but,=0A> > > do you want to risk your bird on on e fuel filter.=0A> > install=0A> > > one filter per=0A> > > tank prior to t he selector valve. and sleep better at=0A> > > night. remember the=0A> > > airflow system much more pressure then a carb. i have=0A> > never=0A> > > l ike the one=0A> > > filter idea in certified aircraft. maybe i should=0A> > apply for=0A> > > an stc for two.=0A> > > airflow fuel filters are an annu al replacement item,=0A> > > don't cheat=0A> > > =0A> > > Larry Bowen wrote:=0A> > > =0A> > > FYI, I used domed nut plates on my RV-8 tanks....and=0A> > had to=0A> > > cut a couple of=0A> > > them off be cause they interfered with the fuel=0A> > pick-up. =0A> > > Sometimes=0A> > > second-guessing uncle Van doesn't pay off....=0A> > > =0A> > > -- =0A> > > Larry Bowen=0A> > > Larry@BowenAero.com=0A> > > http://BowenAero.com =0A> > > =0A> > > On Tue, May 6, 2008 at 2:14 PM, jan =0A> > > > > > wrote:=0A> > > =0A> > > Hi Richard,=0A> > > =0A> > > =0A> > > =0A> > > I wi ll be doing my hand build tanks later on this=0A> > summer. I=0A> > > have read your=0A> > > article with great interest. First ... I have bought=0A> > the=0A> > > domed nut plates...=0A> > > they are used on commercial plane s from what I=0A> > understand=0A> > > ... and should=0A> > > make a perfec t seal with a "O" ring .. Then=0A> > cover=0A> > > the nut plate after=0A> > > fitting with pro-seal as a extra safeguard against=0A> > leaks.=0A> > > =0A> > > =0A> > > =0A> > > Do you recommend alodining the tank skin and th e ribs=0A> > ??=0A> > > That is a new one=0A> > > to me ... I thought clean ing with Aluprep ...rinse=0A> > with=0A> > > water ... and scuff=0A> > > th e seams is fine ??=0A> > > =0A> > > =0A> > > =0A> > > Appreciate you commen ts on this=0A> > > =0A> > > =0A> > > =0A> > > Best regards=0A> > > =0A> > > =0A> > > =0A> > > Jan=0A> > > =0A> > > =0A> > > =0A> > > =0A> > > _____ =0A> > > =0A> > > =0A> > > From: owner-rv-list-server(at)matronics.com=0A> > > =0A> > > [mailto:owner-rv-list- server(at)matronics.com=0A> > > ] On=0A> > > Behalf Of RICHARD MILLER=0A> > > Sent: 06 May 2008 14:54=0A> > > To: rv-list(at)matronics.com=0A> > > =0A> > > Subject: Re: RV-List: Proseal remover?=0A> > > =0A> > > =0A> > > =0A> > > Since we seem to have so many complaints about fuel=0A> > leaks,=0A> > > l ets cover fuel=0A> > > tank 101.=0A> > > =0A> > > =0A> > > =0A> > > static loads on a fuel tank are less then .5 psi. duct=0A> > tape=0A> > > can hold .5 psi.=0A> > > dynamic loads are variable due to high g loading and=0A> > can=0A> > > reach 4=0A> > > =0A> > > psi, with tank destruction emanate. t he problem with=0A> > > checking tanks is the=0A> > > static pressure loadi ng is applied to all surfaces and=0A> > they=0A> > > need to be=0A> > > str essed to handle that load. most are not ie, the=0A> > caps.=0A> > > =0A> > > =0A> > > =0A> > > next problem is the inherent movement of the structure =0A> > as=0A> > > it flexes. tearing=0A> > > the sealant bonds.=0A> > > =0A > > > =0A> > > =0A> > > so lets assume that you built it close to right and =0A> > now=0A> > > want to test it.=0A> > > water, fuel, any material with the exception of the=0A> > > original sealant will=0A> > > contaminate the joint during testing. so how do we=0A> > remove=0A> > > the contaminates? =0A> > > we don't contaminate in the first place. the=0A> > sealants=0A> > > we are using are=0A> > > sensitive to contaminates so air or better nitro gen is=0A> > the=0A> > > testing medium of=0A> > > choice. =0A> > > =0A> > > =0A> > > =0A> > > after inspecting aircraft with properly applied=0A> > p ro-seal=0A> > > that had over=0A> > > twenty years in service, the stuff st icks. sloshing=0A> > does=0A> > > not work and will=0A> > > result in a cra sh, the unfortunate part of this is=0A> > that the=0A> > > pilot is always =0A> > > the first person at the crash site.. fire and medic=0A> > support =0A> > > might take a=0A> > > little longer arriving. do not slosh tanks=0A > > > =0A> > > =0A> > > =0A> > > types of leaks.=0A> > > =0A> > > =0A> > > =0A> > > seam leaks, very rare, normally caused by poor=0A> > > constructio n, or extreme g=0A> > > loading.=0A> > > =0A> > > =0A> > > =0A> > > fastene r leaks, more common also caused by high g=0A> > loading=0A> > > and flexin g of the=0A> > > structure, compounded but poor sealing practices. all=0A> > tank=0A> > > fasteners are to=0A> > > be installed wet. and then sealed o n the inside.=0A> > > =0A> > > =0A> > > =0A> > > access plate/fitting leaks , most common. cause=0A> > improperly=0A> > > applied sealant,=0A> > > wron g nut plates , they should be all domed and=0A> > sealed. too=0A> > > long of screw=0A> > > that goes through the nut plate dome. bad gaskets,=0A> > f ailed=0A> > > orings. rotation=0A> > > of a fitting after sealant has dried . always use two=0A> > > wrenches when removing=0A> > > lines.=0A> > > =0A> > > =0A> > > =0A> > > the primary problem with tank repair is the lack of =0A> > > structural integrity of=0A> > > this tank. riveted tanks and the r epair tricks where=0A> > > designed around the=0A> > > larger transport typ e aircraft. pro-seal sticks well=0A> > and=0A> > > can be a problem to=0A> > > break the seams apart without disturbing/destroying=0A> > the=0A> > > s tructure.=0A> > > =0A> > > =0A> > > =0A> > > the best way that i have found to stop small leaks at=0A> > > fasteners and seams is=0A> > > to apply a h eavy vacuum to the outside of the tank at=0A> > the=0A> > > effected area t o=0A> > > draw any remaining fuel out and and suck the sealant=0A> > in to =0A> > > the void.=0A> > > additional rivets added along seam lines while s till=0A> > wet=0A> > > helps to. =0A> > > =0A> > > =0A> > > =0A> > > sealan t application tricks.=0A> > > =0A> > > =0A> > > =0A> > > clean /clean /clea n. pro-seal dose not like oil and=0A> > most=0A> > > primers but loves a=0A > > > good cleaned alodined surface. =0A> > > =0A> > > =0A> > > =0A> > > me chanical grip/ light scuff on a flaying surface=0A> > helps=0A> > > with ad hesion=0A> > > =0A> > > =0A> > > =0A> > > tape applied along side the joint s to assist with=0A> > clean up=0A> > > =0A> > > =0A> > > =0A> > > gloves, this stuff does not like to come off and mek=0A> > is bad=0A> > > for you =0A> > > =0A> > > =0A> > > =0A> > > proper fit of parts, don't expect pro-s eal to fill=0A> > > gaps.=0A> > > =0A> > > =0A> > > =0A> > > don't use to m uch. or you will get a wavy=0A> > structure. =0A> > > =0A> > > =0A> > > =0A > > > use type a for seams it helps with waves and type b=0A> > for=0A> > > fillets and fastener=0A> > > sealing=0A> > > =0A> > > =0A> > > =0A> > > do n't exceed the pot life =0A> > > =0A> > > =0A> > > =0A> > > mix it right an d use the correct proportions a good=0A> > scale=0A> > > really helps.=0A> > > =0A> > > =0A> > > =0A> > > use the longest pot life you can, i have fou nd that=0A> > 1/2=0A> > > stuff to be almost=0A> > > useless for most jobs. =0A> > > =0A> > > =0A> > > =0A> > > the proper place for sealant is on the inside of the=0A> > tank=0A> > > not globed on the=0A> > > outside beside i t looks ugly.=0A> > > =0A> > > =0A> > > =0A> > > tips of opening seams=0A> > > =0A> > > =0A> > > =0A> > > sharpend putty knives are great but be sure to round=0A> > the=0A> > > corners to help=0A> > > prevent gouges. take you r time here. gentle is better.=0A> > > =0A> > > =0A> > > =0A> > > removal o f sealant =0A> > > =0A> > > =0A> > > =0A> > > scotch bright disks work grea t. wear a mask. and=0A> > realodine=0A> > > after done.=0A> > > =0A> > > =0A> > > =0A> > > tank testing, quick easy and cheap=0A> > > =0A> > > =0A> > > =0A> > > connect air/nitrogen supply to vent =0A> > > =0A> > > connect clear hose to drain about ten feet worth=0A> > > =0A> > > loop hose to floo r and fill with water until you have=0A> > a=0A> > > loop with three feet =0A> > > high on both sides =0A> > > =0A> > > add nitrogen until the water is four feet higher on=0A> > one=0A> > > side then the other.=0A> > > you n ow have 2 psi in the tank. care should be taken=0A> > here,=0A> > > fill sl owly.=0A> > > =0A> > > spray the seams with soapy water and look for bubble s.=0A> > use=0A> > > hand soap or=0A> > > aircraft soap, some soaps are bad for alum.=0A> > > =0A> > > =0A> > > =0A> > > how to find that damn mystery leak i have tried=0A> > everything=0A> > > else.=0A> > > =0A> > > sometime s really small leaks are the worse to find,=0A> > but one=0A> > > way to tr ack=0A> > > them down is to apply dye-pen developer to the outside=0A> > of =0A> > > the tank it will=0A> > > show up any tiny leaks. over a couple of days.=0A> > > =0A> > > =0A> > > =0A> > > and this ends fuel tank 101 hope i t helps.=0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > rick miller =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A > > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > _____ =0A> > > =0A> > > =0A> > > Be a better fri end, newshound, and =0A> > > =0A> > > =0A> > > =0A> > > http://www.matronic s.com/contribution=0A> > > <http://www.matronics.com/contribution> =0A> > > =0A> > > =0A> > >=0A> > t="_blank">http://www.matronics.com/Navigator?RV -List=0A> > > <http://www.matronics.com/Navigator?RV-List> =0A> > > a>http: //forums.matronics.com=0A> > > <http://forums.matronics.com/> =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > =0A> > > _____ =0A> > > =0A> > > =0A> > > =0A> > > Be a better friend, newshound, and =0A> > > =0A> > > =0A> > > <http://www.matronics.com/Navigator?RV-List> =0A> > > =0A> > =0A> > =0A> > =0A> > Be a better fri end, newshound, and =0A> > know-it-all with Yahoo! Mobile. Try it now. =0A> > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ=0A> =0A> =0A> Be a better friend, newshound, and =0A> know-it-all with Yahoo! Mobile . Try it now.=0A> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9t AcJ=0A=0A> =0A> =0A> =0A=0A=0A=0A________________________________=0A=0AGet Free (PRODUCT) RED=99 Emoticons, Winks and Display Pics. Check it out! =0A ====0A=0A=0A ___________________________________________________ _________________________________=0ABe a better friend, newshound, and =0Ak now-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt =Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Subject: Re: sniffle valve in RV 7A
Date: May 08, 2008
The sniffle valve I got from Superior with my engine sucks. Or more properly does not seal well under suction ( I can detect a slight leak when I check it by blowing backwards on it). I believe Dan Checkoway told me he replaced his with a better one but I lost my notes. Anyone have a sniffle valve source? Thanks dave On May 8, 2008, at 9:11 AM, SteinAir, Inc. wrote: > > Actually you can and will sometimes have fuel drain back down the > intake > tubes with an injected system. Prime it for a few seconds too long > and > it'll start dribbling, and sometimes on shutdown you can get a wee > bit as > well. It's standard practice to at least put a "weep hole" in the > FAB or > somewhere at the low point to make sure fuel doesn't pool where you > don't > want it. > > My 2 cents as usual. > > Cheers, > Stein > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James H >> Nelson >> Sent: Thursday, May 08, 2008 8:26 AM >> To: rv-list(at)matronics.com >> Subject: RV-List: sniffle valve in RV 7A >> >> >> >> I guess I am missing something. With fuel injection, you will not >> have >> fuel "dripping" down into the air box. The sniffle valve is >> necessary >> with a carburator style fuel system. With that system you can >> cause raw >> fuel to exceed the ability of the engine to ingest it. Especially >> if you >> have an accelertor pump on the carb. That will possibly let fuel >> run back >> into the air filter box. Am I in error? I have AFP system and it >> has >> the fuel purge system which will take off all fuel pressure in the >> shut >> down phase. During a starting phase the fuel is placed just in >> front of >> the intake valve and "should" all be ingested. >> >> Jim Nelson >> IO-360 >> >> >> >> > > ________________________________________________________________________________
Date: May 08, 2008
In a message dated 05/08/2008 8:33:29 AM Central Daylight Time, rv9jim(at)juno.com writes: I guess I am missing something. With fuel injection, you will not have fuel "dripping" down into the air box. The sniffle valve is necessary with a carburator style fuel system. With that system you can cause raw fuel to exceed the ability of the engine to ingest it. Especially if you have an accelertor pump on the carb. That will possibly let fuel run back into the air filter box. Am I in error? I have AFP system and it has the fuel purge system which will take off all fuel pressure in the shut down phase. During a starting phase the fuel is placed just in front of the intake valve and "should" all be ingested. >>> Yes, but only while the engine is cranking. When opened, the purge valve routes all fuel back to wherever it is plumbed, and prevents any from entering the engine via the spider when it is open, which is very useful to run cool fuel through the entire system with the boost pump on to help avoid vapor lock if the engine is hot. BUT- any time the boost pump is on (even is mixture control is at idle cut-off), "some" fuel is being discharged from the injectors. If not ingested by the cylinders by cranking the engine, it simply runs down the intake tubes into the "sump" (actually, the manifold under the oil sump) and will accumulate there. Hence the need to drain it via the sniffle valve. Careful control of the boost pump and purge valve will mitigate this drainage, but ultimately some fuel will wind up in the manifold. The AFP system will always "leak" fuel at the injectors if the purge valve is closed and there is fuel pressure, hence the need for the valve. This is one reason the purge valve is necessary, since pulling mixture to ICO will possibly not shut down a running engine as some fuel is still getting through the injectors. Opening the purge valve is the only way to completely shut all fuel flow off to the injectors. (Well, you could always shut off the fuel supply from the tanks or run them dry...) On a carbureted engine, pumping the throttle will definately shoot raw gas into the intake and if the engine is not cranking, this fuel would fall back into the air box, potentially creating a fire hazard. I never pump the throttle on my carbureted engine unless it is cranking for this very reason. Are you currently running your AFP equipped engine? If so, what is your start procedure, cold & hot? Mark **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 08, 2008
In a message dated 05/08/2008 9:01:55 PM Central Daylight Time, yenduc(at)sbcglobal.net writes: Or more properly does not seal well under suction ( I can detect a slight leak when I check it by blowing backwards on it). >>> I performed the same test on the valve I received in Vans FWF kit and it did the same as you describe. Concerned about this, I contacted tech support and was informed this was normal and the tiny amount of leakage would have no discernable effect. Consider the total amount of air consumed by the engine against the amount of air leaking past the valve. The engine (Aerosport IO-360) performed quite nicely with this valve installed both while engine running and while draining... Mark **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 09, 2008
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Aviation Emissions
>From AvWeb on the internet Thursday: Congress Scrutinizes Aviation Emissions The House Subcommittee on Aviation met on Tuesday for a hearing about aviation's impact on the environment. Noise and emissions from aviation are expected to double by 2025, the panel said, so aggressive action is needed soon to prevent that scenario. Gerald Dillingham, speaking for the U.S. Government Accountability Office, told the panel that NextGen developments will improve efficiency, but more funding is needed for research into better technology. National Air Transportation Association (NATA) President James Coyne also testified at the hearing. NetJets, a member of NATA, is investing in the development of an ultra-low-emissions jet fuel, Coyne said. Several representatives of the airline industry noted that given the cost of fuel, the industry is doing all it can to improve efficiency. Mary Ann Schaffer, of the Air Line Pilots Association, said pilots conserve fuel by various strategies, including single-engine taxiing, continuous descent arrivals, and flying at optimal altitudes and speeds. ---------------------------------------------------------------------------- This kind of stuff is going on EVERY day folks, if you are not concerned then you're not paying attention. Environmentalists and politicians would like to control every aspect of your life. Remember, private flying is just a frivolous and wasteful pursuit and it will be stopped(whether through moratoriums on fossil fuel burning to stop global warming, ultra-high gas prices or control freak politicians who need the environmentalist money and vote). If we the sane continue turn a blind eye to this we just as well cut up our airplanes for scrap metal. Politicians who had been braying about getting us independence from foreign oil were whining to OPEC last week to get production up to lower prices. US oil production has fallen by half in the last 20 years and the politicians have done nothing but put up more roadblocks to increasing domestic production. If you think they really want to help lower prices then you are naive. Dean N197DM Will fly if I have to distill the hydrocarbons myself ________________________________________________________________________________
Date: May 09, 2008
Subject: sniffle valve in RV 7A
Hi Mark, I am "running" a IO-360 and I chose to not install a sniffle valve. My first start shoud be in a few weeks. So the proceedure used will be adapted for the purge valve style operation. I have about 5 or 6 things to finish up and then get it blessed with paper work. Then I should be ready to go fly :-))) Jim ________________________________________________________________________________
Date: May 09, 2008
Subject: For Sale - RMI uMonitor - NEW - All Probes and Upgrades!
Dear Listers, I am selling a new, never used, fully assembled RMI uMonitor with all the probes for a 4-cylinder engine including Fuel Flow, 4ea EGT, 4ea CGT, Carb Temp, and Manifold pressure. The uMonitor just had all of the latest hardware and software updates factory installed including the new high contrast LCD display supporting Fahrenheit temp readings AND the new LED fiberoptic backlight. Also included is the Aircraft Extras RM-1B plugin harness extender for the uMonitor which greatly simplifies the wiring installation. The uMonitor is in new condition with no scratches and all installation material and manuals. The pictures below are of the actual unit for sale. The table below lists all of the items included. I have nearly $2800 invested in this complete system. I will sell it for $2200 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Matt Dralle List Admin / RV-4 Builder 1ea RMI microMONITOR Assembled . . . . . . . . . . . . . .$1299.00 $1299.00 1ea Factory Upgrade of LCD (Fahrenheit Temp Display), Fiberoptic LED Backlight, Latest Firmware. . . . . .$ 399.00 $ 399.00 1ea Manifold Pressure Sensor 10.0 to 59.0 InHg. . . . . . $ 68.00 $ 68.00 2ea EGT/CHT Multiplex Switch 2 to 6 cylinders . . . . . . $ 60.00 $ 120.00 1ea Fuel Flow sensor, FloScan 201B-6 - .6 to 60.0 GPH. . .$ 230.00 $ 230.00 1ea Carb Temp Sensor . . . . . . . . . . . . . . . . . . .$ 55.00 $ 55.00 4ea EGT Thermocouple - tubing clamp type . . . . . . . . .$ 65.00 $ 260.00 4ea CHT Thermocouple - bayonet type. . . . . . . . . . . .$ 50.00 $ 200.00 1ea RM-1B Harness Expander, Aircraft Extras. . . . . . . .$ 155.00 $ 155.00 -------------------------- $2786.00 ________________________________________________________________________________
Date: May 09, 2008
Subject: For Sale - Skyforce Skymap IIIC - NEW - Latest Database
Dear Listers, I have a new-in-box Skyforce Skymap IIIC full color GPS moving map with Topo. The database and firmware were just upgraded 05/2008. Includes a Panel Mounting bracket, GPS Antenna, cigarette lighter adapter, carrying case, and all manuals. Brand new, never used. No scratches. The pictures below are of the actual unit. The LCD color display on the IIIC is extremely nice and very bright. Gives altitude readout. RS232 output. I have over $2500 invested in this complete system. I will sell it for $2200 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Matt Dralle List Admin / RV-4 Builder 1ea - Skyforce Skymap IIIC w/ GPS and Americas Database. . .$2367.00 . .$2367.00 1ea - Panel Mount. . . . . . . . . . . . . . . . . . . . . .$ 98.00 . .$ 98.00 1ea - Firmware and Database Update 5/8/2008. . . . . . . . .$ 50.00 . .$ 50.00 --------------------------------------------------------------------------------- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . $2515.00 ________________________________________________________________________________
Subject: crooks at Performance Engines
Date: May 09, 2008
I maintain a list on my web site describing my experiences with various vendors. The vast majority have been super to deal with, but here have been some with poor customer service. Fortunately, none has outright ripped me off, as described by Larry James; the few negatives are mostly just poor customer service & bad attitudes. It isn=92t an all-encompassing list; just my own experiences with the vendors I have dealt with in building my plane. Brian HYPERLINK "http://brian76.mystarband.net/vendors.htm"http://brian76.mystarband.net/ ven dors.htm _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Thursday, May 01, 2008 11:38 AM Subject: Re: RV-List: crooks at Performance Engines We need a list on this site of preferred vendors and vendors we should not deal with and that list should be on the search page for all RV's. I'm wondering if this is possible? We work hard everyday in the shop and at our day job, and we certainly should know who the crooks are! Just my two cents. Jim RV9a N492RV (building) ----- Original Message ----- From: HYPERLINK "mailto:khorton01(at)rogers.com"Kevin Horton Sent: Wednesday, April 30, 2008 6:37 PM Subject: Re: RV-List: crooks at Performance Engines On 30 Apr 2008, at 17:34, Larry James wrote: Well, it's time I go public. Ron Munson / Performance Engines has owed me and promised to pay me back my $20,000 deposit for over two years now. I read Matt Throckmorton's account of his dealings with Mike Moore and mine is a very similar story. Bottom line here, no matter how you slice it Ron Munson is a liar and a cheat and should be in jail; let alone receive any orders from any of us or anyone else. His "salesman" Stuart Featherstone falls into the same category. I've tried being nice talking with him, I've had an attorney send nice letters, I've had an attorney send threatening letters, I've had a collections agency work to get my money back. So far, no joy. Apparently Ron Munson has moved his banking to Nevada while maintaining operations in California; making it more difficult and expensive to go after him. Anyone with any ideas on what to do with this crook ?? I have no intention of letting this go :-). _________________ Well, at this stage, maybe the best bet is to attempt to get enough web coverage of your problems that he starts to realize that not resolving this will cost him a bunch of business. One approach would be to create a web page that gave your side of the story. Post a link here. Post a link on the VAF WWW forum. If enough other people link to your web page, that will start to increase the Google ranking of your page. Eventually it could start to appear close enough to the top of a search for Performance Engines that prospective customers start to see it. Try to get the attention of AvWeb, and the Aero News Network. Contact the Better Business Bureau. They probably can't do much, but they will put an entry in their searchable database saying that there are unresolved customer complaints. That will deter some other potential customers. Go to OSH, with a whole stack of flyers telling your story, and post them all over the site. Keep this up long enough and eventually they may see an affect on their business. -- Kevin Horton RV-8 (FInal Assembly) Ottawa, Canada HYPERLINK "http://www.kilohotel.com/rv8"http://www.kilohotel.com/rv8 href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ 4/29/2008 6:27 PM "http://www.matronics.com/Navigator?RV-List"http://www.matronics.com/Navi gat or?RV-List "http://forums.matronics.com"http://forums.matronics.com "http://www.matronics.com/contribution"http://www.matronics.com/contribut ion 7.5.524 / Checked by AVG. 5/8/2008 5:24 PM ________________________________________________________________________________
Date: May 09, 2008
[quote="yenduc(at)sbcglobal.net"]The sniffle valve I got from Superior with my engine sucks. Or more properly does not seal well under suction ( I can detect a slight leak when I check it by blowing backwards on it). I believe Dan Checkoway told me he replaced his with a better one but I lost my notes. Anyone have a sniffle valve source? Thanks dave We make manifold drains (sniffel valves). You can attach a #4 hose to this part to route the fuel away from the exhaust and out the cowling. In a tight installation where the part cannot hang straight down, you can install a 90 degree pipe fitting to the sump and run a hose back to the manifold drain. As long as the little check ball can fall open when the engine is off it will work. The P/N is 1090138 $17.00. Don at Airflow Performance. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=182269#182269 ________________________________________________________________________________
Date: May 09, 2008
Subject: For Sale - RMI uEncoder - NEW - Assembled
Dear Listers, I am selling a new, never used, fully assembled RMI uEncoder. The uEncoder just had all of the latest hardware and software updates factory installed including the new high contrast LCD display supporting Fahrenheit temp readings AND the new LED fiberoptic backlight. The uEncoder displays airspeed, altitude, fpm, OAT, and outputs Mode C data for most transponders. The uEncoder is in new condition with no scratches and all installation material and manuals. The pictures below are of the actual unit for sale. The table below lists all of the items included. I have nearly $1500 invested in this complete system. I will sell it for $1100 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Matt Dralle List Admin / RV-4 Builder 1ea - RMI microENCODER ASSEMBLED . . . . . . . . . . . . . . . .$1179.00 . $1179.00 1ea - RMI Factory Upgrade of LCD (Fahrenheit Temp, US Miles), . . . . . . Fiberoptic LED Backlight, Latest Firmware . . . . . $ 315.00 . $ 315.00 ------------------------------------------------------------------------------------- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .$1494.00 ________________________________________________________________________________
Date: May 09, 2008
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: Settting the correct Spacing (Gap) between VS Top Rib and Rudder
Top Rib Greetings: The construction of my RV8A (RV7 and RV9 are the same) the Rudders Top Rib swings OVER the top Rib of the VS. There is suppose to be a "Gap" between the two Ribs so that there is no interference (rubbing of them together) as the Rudder is moved. My question is - how do you set this Gap up ??? It seems to me that the Rod End Bearings on the Rudder Spar need to be screwed into the Rudder Spar the " Final" distance so that the Gap can be set up properly BEFORE the Rudder Skin is finally riveted to the Rudders Top Rib (R703) which sets this Gap. My understanding the dimensions for screwing the Rod End Bearings as shown on the Drawing 7 is only "approximate" and needs to be fined tuned later = this could change this Gap distance. Or if one marks a center-line on the flange of the Rudders Top Rib and aligns the pre-punched holes in the Rudder Skin directly over the "center of this line", does it Guarantee automatic clearance and a constant Gap distance when the Rod End bearings are set to their "Final" screwed-in distance ?????? The Orndorff Tapes show the Rod End bearings installed in the Rudder Spar (no Rod End Bearing dimensions given) and mounted to the VS and the Gap set by bending Up the Rudders Top Rib (R703) to parallel the VS Top Rib. Maybe I am missing something. So what worked for you - set the Rod End Bearings "approx" or align the pre-punched holes in the Rudder Skin directly over the marked center-line on the Rudders Top Rib flange and THEN rivet the Rudder Skin ???? Once the Rudder Skin is riveted to the Rudders Top Rib, the Rudders Top Rib is fixed and can NOT be readjusted to get the "correct Gap" later. Appreciate your help, Garey Wittich Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Subject: Re: crooks at Performance Engines
Date: May 10, 2008
Brian, Thanks for this information, I have been on your site many times over the last 3 years and appreciate what you have done to help me and other builders in this process. I still use the information you sent three years ago, regarding my question on how much we should torque down nuts and bolts. At one time, on your website, you had a parity regarding the government and ordering food from a fast food restaurant and how the person taking your order was reviewing your health history online, prior to letting you order. :-) I also enjoyed reading your hangar building process and dealing with all the bureaucrats who get their check on Friday and could careless if you ever get your building constructed. Thanks for making me smile. Keep working on your RV7 and I will continue to work on my RV9. If and when I order my motor and bigger items I will be checking your site for recommend vendors. Thanks. Jim ----- Original Message ----- From: Brian Meyette To: rv-list(at)matronics.com Sent: Friday, May 09, 2008 1:02 PM Subject: RE: RV-List: crooks at Performance Engines I maintain a list on my web site describing my experiences with various vendors. The vast majority have been super to deal with, but here have been some with poor customer service. Fortunately, none has outright ripped me off, as described by Larry James; the few negatives are mostly just poor customer service & bad attitudes. It isn=92t an all-encompassing list; just my own experiences with the vendors I have dealt with in building my plane. Brian http://brian76.mystarband.net/vendors.htm ------------------------------------------------------------------------- ----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Thursday, May 01, 2008 11:38 AM To: rv-list(at)matronics.com Subject: Re: RV-List: crooks at Performance Engines We need a list on this site of preferred vendors and vendors we should not deal with and that list should be on the search page for all RV's. I'm wondering if this is possible? We work hard everyday in the shop and at our day job, and we certainly should know who the crooks are! Just my two cents. Jim RV9a N492RV (building) ----- Original Message ----- From: Kevin Horton To: rv-list(at)matronics.com Sent: Wednesday, April 30, 2008 6:37 PM Subject: Re: RV-List: crooks at Performance Engines On 30 Apr 2008, at 17:34, Larry James wrote: Well, it's time I go public. Ron Munson / Performance Engines has owed me and promised to pay me back my $20,000 deposit for over two years now. I read Matt Throckmorton's account of his dealings with Mike Moore and mine is a very similar story. Bottom line here, no matter how you slice it Ron Munson is a liar and a cheat and should be in jail; let alone receive any orders from any of us or anyone else. His "salesman" Stuart Featherstone falls into the same category. I've tried being nice talking with him, I've had an attorney send nice letters, I've had an attorney send threatening letters, I've had a collections agency work to get my money back. So far, no joy. Apparently Ron Munson has moved his banking to Nevada while maintaining operations in California; making it more difficult and expensive to go after him. Anyone with any ideas on what to do with this crook ?? I have no intention of letting this go J. _________________ Well, at this stage, maybe the best bet is to attempt to get enough web coverage of your problems that he starts to realize that not resolving this will cost him a bunch of business. One approach would be to create a web page that gave your side of the story. Post a link here. Post a link on the VAF WWW forum. If enough other people link to your web page, that will start to increase the Google ranking of your page. Eventually it could start to appear close enough to the top of a search for Performance Engines that prospective customers start to see it. Try to get the attention of AvWeb, and the Aero News Network. Contact the Better Business Bureau. They probably can't do much, but they will put an entry in their searchable database saying that there are unresolved customer complaints. That will deter some other potential customers. Go to OSH, with a whole stack of flyers telling your story, and post them all over the site. Keep this up long enough and eventually they may see an affect on their business. -- Kevin Horton RV-8 (FInal Assembly) Ottawa, Canada http://www.kilohotel.com/rv8 href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.m atronics.comhref="http://www.matronics.com/contribution">http://www.mat ronics.com/c ------------------------------------------------------------------------- --- 4/29/2008 6:27 PM http://www.matronics.com/contribution Checked by AVG. Release Date: 4/30/2008 6:10 PM Checked by AVG. 5/8/2008 5:24 PM ------------------------------------------------------------------------- ----- Checked by AVG. 5/9/2008 12:38 PM ________________________________________________________________________________
Date: May 10, 2008
Brian, Thanks for the link to your site. I'd like to put in a good word for Rocky Mountain Instruments. I purchased both their Micro Encoder and Micro Monitor products used, from other RV owners (they upgraded). My Micro Monitor was missing several buttons. I also wanted to add the fuel totalizer feature. I called RMI, he sold me the fuel flow transducer at a price $80 lower than the next lowest competitor. I explained that I had purchased the products used. He asked for the serial numbers and my info. He likes to keep track of where is products are. He also sent me a complete set of buttons for the Micro Monitor for free (even the shipping). My MicroEncoder has a minor scratch on it's display face. I was able to purchase a replacement display for $24.95! Can you imagine what Garmin would charge for a damaged display?? $$$$$$ Mr. Mower answered tons of questions regarding his products, was very polite and shipped my items immediately. I highly recommend RMI. Charlie Kuss --- On Fri, 5/9/08, Brian Meyette wrote: > From: Brian Meyette <bmeyette(at)gmail.com> > Subject: RE: RV-List: crooks at Performance Engines > To: rv-list(at)matronics.com > Date: Friday, May 9, 2008, 2:02 PM > I maintain a list on my web site describing my experiences > with various > vendors. The vast majority have been super to deal with, > but here have been > some with poor customer service. Fortunately, none has > outright ripped me > off, as described by Larry James; the few negatives are > mostly just poor > customer service & bad attitudes. It isnt an > all-encompassing list; just > my own experiences with the vendors I have dealt with in > building my plane. > > Brian > > HYPERLINK > "http://brian76.mystarband.net/vendors.htm"http://brian76.mystarband.net/ven > dors.htm > > > > > > _____ > > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > Jim Fogarty at > Lakes & Leisure Realty > Sent: Thursday, May 01, 2008 11:38 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: crooks at Performance Engines > > > > We need a list on this site of preferred vendors and > vendors we should not > deal with and that list should be on the search page for > all RV's. I'm > wondering if this is possible? We work hard everyday in > the shop and at > our day job, and we certainly should know who the crooks > are! Just my two > cents. > > > > Jim > > RV9a N492RV (building) > > ----- Original Message ----- > > From: HYPERLINK > "mailto:khorton01(at)rogers.com"Kevin Horton > > To: HYPERLINK > "mailto:rv-list(at)matronics.com"rv-list(at)matronics.com > > > Sent: Wednesday, April 30, 2008 6:37 PM > > Subject: Re: RV-List: crooks at Performance Engines > > > > On 30 Apr 2008, at 17:34, Larry James wrote: > > > > > > Well, it's time I go public. Ron Munson / Performance > Engines has owed me > and promised to pay me back my $20,000 deposit for over two > years now. I > read Matt Throckmorton's account of his dealings with > Mike Moore and mine is > a very similar story. Bottom line here, no matter how you > slice it Ron > Munson is a liar and a cheat and should be in jail; let > alone receive any > orders from any of us or anyone else. His > "salesman" Stuart Featherstone > falls into the same category. I've tried being nice > talking with him, I've > had an attorney send nice letters, I've had an attorney > send threatening > letters, I've had a collections agency work to get my > money back. So far, no > joy. Apparently Ron Munson has moved his banking to Nevada > while > maintaining operations in California; making it more > difficult and expensive > to go after him. Anyone with any ideas on what to do with > this crook ?? I > have no intention of letting this go :-). > _________________ > > > > Well, at this stage, maybe the best bet is to attempt to > get enough web > coverage of your problems that he starts to realize that > not resolving this > will cost him a bunch of business. One approach would be > to create a web > page that gave your side of the story. Post a link here. > Post a link on > the VAF WWW forum. If enough other people link to your web > page, that will > start to increase the Google ranking of your page. > Eventually it could > start to appear close enough to the top of a search for > Performance Engines > that prospective customers start to see it. Try to get the > attention of > AvWeb, and the Aero News Network. Contact the Better > Business Bureau. > They probably can't do much, but they will put an entry > in their searchable > database saying that there are unresolved customer > complaints. That will > deter some other potential customers. Go to OSH, with a > whole stack of > flyers telling your story, and post them all over the site. > Keep this up > long enough and eventually they may see an affect on their > business. > > > > > > -- > > Kevin Horton > > RV-8 (FInal Assembly) > > Ottawa, Canada > > HYPERLINK > "http://www.kilohotel.com/rv8"http://www.kilohotel.com/rv8 > > > > > > > > > > > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N > avigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > _____ > > > 4/29/2008 6:27 PM > > > > "http://www.matronics.com/Navigator?RV-List"http://www.matronics.com/Navigat > or?RV-List > "http://forums.matronics.com"http://forums.matronics.com > "http://www.matronics.com/contribution"http://www.matronics.com/contribution > > 7.5.524 / > > Checked by AVG. > 5/8/2008 > 5:24 PM Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Subject: Re: Settting the correct Spacing (Gap) between VS Top Rib and
Rudder Top Rib
Date: May 10, 2008
Garey, I would not do any bending, the bearings goes into platenuts that you have installed on the forward side of the aft rudder spar, only use the original computer punched holes in all rib, skin and spar. The lower bearing in my RV9 has a longer shaft than the upper two bearing on the rudder. Set the distance on each bearing, per the plans, by using a scrap piece of aluminum for a jag between the rudder aft spar and the bolt hole in the bearing. If you have your fuselage done, then install the HS, VS and then attach your rudder. I did not do this until I had my fuselage and then I did my install and the gap came out just fine. I'm not sure I'm answering your question, but I hope this helps. Think platenut.... Jim RV9a ----- Original Message ----- From: "Garey Wittich" <gareywittich2000(at)yahoo.com> ; Sent: Friday, May 09, 2008 11:24 PM Subject: RV-List: Settting the correct Spacing (Gap) between VS Top Rib and Rudder Top Rib > > Greetings: > > The construction of my RV8A (RV7 and RV9 are the > same) the Rudders Top Rib swings OVER the top Rib of > the VS. There is suppose to be a "Gap" between the > two Ribs so that there is no interference (rubbing of > them together) as the Rudder is moved. > > My question is - how do you set this Gap up ??? > > It seems to me that the Rod End Bearings on the Rudder > Spar need to be screwed into the Rudder Spar the " > Final" distance so that the Gap can be set up properly > BEFORE the Rudder Skin is finally riveted to the > Rudders Top Rib (R703) which sets this Gap. My > understanding the dimensions for screwing the Rod End > Bearings as shown on the Drawing 7 is only > "approximate" and needs to be fined tuned later = this > could change this Gap distance. > > Or if one marks a center-line on the flange of the > Rudders Top Rib and aligns the pre-punched holes in > the Rudder Skin directly over the "center of this > line", does it Guarantee automatic clearance and a > constant Gap distance when the Rod End bearings are > set to their "Final" screwed-in distance ?????? > > The Orndorff Tapes show the Rod End bearings installed > in the Rudder Spar (no Rod End Bearing dimensions > given) and mounted to the VS and the Gap set by > bending Up the Rudders Top Rib (R703) to parallel the > VS Top Rib. Maybe I am missing something. So what > worked for you - set the Rod End Bearings "approx" or > align the pre-punched holes in the Rudder Skin > directly over the marked center-line on the Rudders > Top Rib flange and THEN rivet the Rudder Skin ???? > > Once the Rudder Skin is riveted to the Rudders Top > Rib, the Rudders Top Rib is fixed and can NOT be > readjusted to get the "correct Gap" later. > > Appreciate your help, Garey Wittich > > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ > > > -- > Checked by AVG. > 12:38 PM > > ________________________________________________________________________________
Date: May 10, 2008
I purchased a new IO-360 from Aerosport. It had provisions for a sniffle va lve, so I installed it. Pretty much a no-brainer installation, although I h aven't reached the first engine start page yet. Am I missing something? What's the downside of having a sniffle valve? My plane will be based at Inyokern in the middle of the Mojave Desert. Summ er heat will be an issue. Seemed to me, anything that helped prevent vapor lock problems was ok. Paul Valovich RV-8A N192NM LuJaRo Wiring 99% done - canopy is next ________________________________________________________________________________
Date: May 10, 2008
Subject: Re: RV8-List: Settting the correct Spacing (Gap) between VS Top
Rib and Rudder Top Rib On Fri, 9 May 2008, Garey Wittich wrote: > --> RV8-List message posted by: Garey Wittich > > Greetings: > > The construction of my RV8A (RV7 and RV9 are the > same) the Rudders Top Rib swings OVER the top Rib of > the VS. There is suppose to be a "Gap" between the > two Ribs so that there is no interference (rubbing of > them together) as the Rudder is moved. > > My question is - how do you set this Gap up ??? On mine, I had to file the top of the VS down a bit to get the needed gap. Given the pre-punched holes, there isn't a lot you can play with, other than changing how far the rod ends are screwed in, move the top ones a bit further out than the bottom (keeping them in line of course). Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 riviting fuse. 1/4 Starduster II N23UT flying ________________________________________________________________________________
Date: May 10, 2008
Thank you, Jim, for making ME smile ;-) _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Saturday, May 10, 2008 10:54 AM Subject: Re: RV-List: crooks at Performance Engines Brian, Thanks for this information, I have been on your site many times over the last 3 years and appreciate what you have done to help me and other builders in this process. I still use the information you sent three years ago, regarding my question on how much we should torque down nuts and bolts. At one time, on your website, you had a parity regarding the government and ordering food from a fast food restaurant and how the person taking your order was reviewing your health history online, prior to letting you order. :-) I also enjoyed reading your hangar building process and dealing with all the bureaucrats who get their check on Friday and could careless if you ever get your building constructed. Thanks for making me smile. Keep working on your RV7 and I will continue to work on my RV9. If and when I order my motor and bigger items I will be checking your site for recommend vendors. Thanks. Jim ----- Original Message ----- From: HYPERLINK "mailto:bmeyette(at)gmail.com"Brian Meyette Sent: Friday, May 09, 2008 1:02 PM Subject: RE: RV-List: crooks at Performance Engines I maintain a list on my web site describing my experiences with various vendors. The vast majority have been super to deal with, but here have been some with poor customer service. Fortunately, none has outright ripped me off, as described by Larry James; the few negatives are mostly just poor customer service & bad attitudes. It isn=92t an all-encompassing list; just my own experiences with the vendors I have dealt with in building my plane. Brian HYPERLINK "http://brian76.mystarband.net/vendors.htm"http://brian76.mystarband.net/ ven dors.htm _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Thursday, May 01, 2008 11:38 AM Subject: Re: RV-List: crooks at Performance Engines We need a list on this site of preferred vendors and vendors we should not deal with and that list should be on the search page for all RV's. I'm wondering if this is possible? We work hard everyday in the shop and at our day job, and we certainly should know who the crooks are! Just my two cents. Jim RV9a N492RV (building) ----- Original Message ----- From: HYPERLINK "mailto:khorton01(at)rogers.com"Kevin Horton Sent: Wednesday, April 30, 2008 6:37 PM Subject: Re: RV-List: crooks at Performance Engines On 30 Apr 2008, at 17:34, Larry James wrote: Well, it's time I go public. Ron Munson / Performance Engines has owed me and promised to pay me back my $20,000 deposit for over two years now. I read Matt Throckmorton's account of his dealings with Mike Moore and mine is a very similar story. Bottom line here, no matter how you slice it Ron Munson is a liar and a cheat and should be in jail; let alone receive any orders from any of us or anyone else. His "salesman" Stuart Featherstone falls into the same category. I've tried being nice talking with him, I've had an attorney send nice letters, I've had an attorney send threatening letters, I've had a collections agency work to get my money back. So far, no joy. Apparently Ron Munson has moved his banking to Nevada while maintaining operations in California; making it more difficult and expensive to go after him. Anyone with any ideas on what to do with this crook ?? I have no intention of letting this go :-). _________________ Well, at this stage, maybe the best bet is to attempt to get enough web coverage of your problems that he starts to realize that not resolving this will cost him a bunch of business. One approach would be to create a web page that gave your side of the story. Post a link here. Post a link on the VAF WWW forum. If enough other people link to your web page, that will start to increase the Google ranking of your page. Eventually it could start to appear close enough to the top of a search for Performance Engines that prospective customers start to see it. Try to get the attention of AvWeb, and the Aero News Network. Contact the Better Business Bureau. They probably can't do much, but they will put an entry in their searchable database saying that there are unresolved customer complaints. That will deter some other potential customers. Go to OSH, with a whole stack of flyers telling your story, and post them all over the site. Keep this up long enough and eventually they may see an affect on their business. -- Kevin Horton RV-8 (FInal Assembly) Ottawa, Canada HYPERLINK "http://www.kilohotel.com/rv8"http://www.kilohotel.com/rv8 href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ 4/29/2008 6:27 PM http://www.matronics.com/contribution Checked by AVG. Release Date: 4/30/2008 6:10 PM Checked by AVG. 5/8/2008 5:24 PM href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ 5/9/2008 12:38 PM "http://www.matronics.com/Navigator?RV-List"http://www.matronics.com/Navi gat or?RV-List "http://forums.matronics.com"http://forums.matronics.com "http://www.matronics.com/contribution"http://www.matronics.com/contribut ion 7.5.524 / Checked by AVG. 5/9/2008 12:38 PM ________________________________________________________________________________
Date: May 10, 2008
In a message dated 05/10/2008 10:52:54 AM Central Daylight Time, pvalovich(at)dcscorp.com writes: Seemed to me, anything that helped prevent vapor lock problems was ok. I really don't believe the sniffle valve has anything to do with vapor lock- it is only to allow raw fuel that can accumulate in the intake manifold between the fuel servo and the intake tubes to drain. By design in an injected engine, there SHOULD be no fuel in this area- fuel should only enter the intake airstream at the injector and pass immediately to the cylinder. In the AFP system I am familiar with, if the fuel system is pressurized by the boost pump and the engine is not cranking, some fuel will discharge from the injector nozzles and run down the intake tubes into the manifold. This is the reason for the sniffle valve- to allow this fuel to drain from this area where it is not meant to be. Is it "bad" to have some fuel pooling here? I don't know, but I doubt normal engine running airflow would cause much to be ingested into the engine. It would likely remove itself after "some" period of time by simple evaporation into the airstream. Some might look at the sniffle valve as a band-aid for less-than-ideal understanding & operation of the injection system, but in my experience if you leave the boost pump running for more than 5 or 10 seconds when the engine is not running or cranking (purge valve closed) there WILL be fuel running out the sniffle valve and deposited wherever gravity dictates. The AFP system is an excellent fuel delivery system in wide use, but just like that stick poking up between your legs, if not used as it was intended to be used, it can cause you some measure of grief. It appears Don checks this list occasionally, so if I am in error, PLEASE correct & elaborate. Mark **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 11, 2008
Subject: Re: Current crop of pitot tubes
Another EIFS which hasn't gotten much attention is the MGL Enigma/Odyssey. It appears that it can be set up to derive AOA from either drilled wing ports or a 2 hole pitot/AOA probe like Dynon's. http://www.mglavionics.com/html/odyssey.html Pax, Ed Holyoke Kevin Horton wrote: > You need to match the pressure source (i.e. the holes, either on the > pitot tube, or the wing) to the sensor. So, if you want the Dynon > pitot, then you need to use their EFIS to calculate the AOA. If you > want the AOA Sport system, you need to put the holes where they tell > you to. > > This is not a plug and play system, where you can mix and match > pressure source and sensor, as there are no agreed upon standards for > the pressure source. > > Kevin Horton > > On 25 Apr 2008, at 18:23, Corey Crawford wrote: > >> Does anyone know if the Dynon pitot with angle-of-attack would >> connect to/work with an AOA Sport? I'd love to avoid drilling any >> holes in my QB wings .. >> >> -- >> Corey Crawford >> RV-7A - Denver, CO >> >> >> On Fri, Apr 25, 2008 at 10:57 AM, William Gill > > wrote: >> >> > >> >> The chrome Gretz mount with the Dynon heated pitot or Dynon's heated >> pitot with angle-of-attack looks very nice...and works great. >> >> Bill >> RV-7 >> > * > > > * ________________________________________________________________________________
Subject: off-topic question about AC electric motors
Date: May 12, 2008
This has nothing to do with RVs, but I know there are a lot of very knowledgeable people out there and someone might know. The short question is - what will happen if you plug a 230v motor into 115vac? Will it still run, albeit weakly? If you're interested, this is the long version - I bought an air compressor that the seller said had a motor problem. Rather than just replace the motor, I tested it out, because sometimes you can actually buy things that are not as bad as expected, and just need a simple fix. The compressor came with a standard 15a, 115v 3-prong plug on it. So, I disconnected the belt driving the compressor and tested the motor by plugging it in. It ran fine. So, I connected the belt and let it try to drive the compressor. It starts and runs ok, but then runs out of steam and starts to slow down. Then the start circuit kicks in and it picks up speed again, then slows down again. So, I figured the motor was indeed bad & I'd have to replace it. But, after looking at the motor data plate to see what to order, it clearly says it is a 5 HP GE 230 volt only (not 115/230) motor. The whole thing is well used, so someone in its past must have been using it successfully. Perhaps the previous owner (or one before that) either had a 230v circuit with a 115v outlet on it (REALLY bad idea) or perhaps the guy I bought it from got it without a plug on the end, assumed it was 115v and put the 115v plug on it & then saw it didn't work, so he sold it. So, I am planning to put a 230v plug on it and try it in a 230v circuit. I guess I dont have anything to lose if somehow it is really 115 and I put 230 to it & burn it up , as I would otherwise have to replace the motor anyway, because it is too weak at 115v. I just wondered if it was feasible that it really is a 230v motor and all it needs is a 230v supply. What do you guys think - will a 230v motor run, but weakly, on 115v? Thanks, brian Checked by AVG. 1:08 PM ________________________________________________________________________________
Subject: FW: RV6a step kit
Date: May 12, 2008
From: "ROBERTS, DENIS" <denis.roberts(at)wachoviasec.com>
> ______________________________________________ > From: ROBERTS, DENIS > Sent: Monday, May 12, 2008 12:56 PM > To: ROBERTS, DENIS > Subject: FW: RV6a step kit > > > > ______________________________________________ > From: ROBERTS, DENIS > Sent: Monday, May 12, 2008 12:46 PM > To: 'rv-list(at)matronics.com' > Subject: RV6a step kit > > I was lucky to purchase a beautiful RV6a. The builder did a fantasti c > build, but > did not add steps. I thought of buying a step kit, but wanted some > input to > the installation and whether or not the steps would decrease speed t o > any extent. > Any suggestions would be appreciated > Thanks, > Denis > > Denis Roberts > Senior Investment Broker > A.G. Edwards & Sons, Inc. > Omaha, NE > 402-496-9700 / 800-944-2609 denis.roberts(at)wachoviasec.com Wachovia Securities, LLC's outgoing and incoming e-mails are electroni cally archived and subject to review and/or disclosure to someone other than the recipient. A.G. Edwards, a division of Wachovia Securities, LLC ________________________________________________________________________________
Subject: Re: FW: RV6a step kit
Date: May 12, 2008
FW: RV6a step kitIt is a GREAT addition. I had to drill out the pilot side rivets in the baggage area floor then cut the apprpriate hole in the fuselage side. I had a builder help with the riveting. Any speed decrease...if measurable...is worth it. I would strengthen the area between the flat plate and the downward portion of the step before installation Ron Lee ----- Original Message ----- From: ROBERTS, DENIS To: rv-list(at)matronics.com Sent: Monday, May 12, 2008 12:43 PM Subject: RV-List: FW: RV6a step kit ______________________________________________ From: ROBERTS, DENIS Sent: Monday, May 12, 2008 12:56 PM To: ROBERTS, DENIS Subject: FW: RV6a step kit ______________________________________________ From: ROBERTS, DENIS Sent: Monday, May 12, 2008 12:46 PM To: 'rv-list(at)matronics.com' Subject: RV6a step kit I was lucky to purchase a beautiful RV6a. The builder did a fantastic build, but did not add steps. I thought of buying a step kit, but wanted some input to the installation and whether or not the steps would decrease speed to any extent. Any suggestions would be appreciated Thanks, Denis Denis Roberts Senior Investment Broker A.G. Edwards & Sons, Inc. Omaha, NE 402-496-9700 / 800-944-2609 denis.roberts(at)wachoviasec.com Wachovia Securities, LLC's outgoing and incoming e-mails are electronically archived and subject to review and/or disclosure to someone other than the recipient. A.G. Edwards, a division of Wachovia Securities, LLC ________________________________________________________________________________
Date: May 12, 2008
Subject: Re: off-topic question about AC electric motors
I would look more into it before plugging it into 220. My compressor, usually meant to run on 110, will often bog down and not run well if the 110 supply is weak (like in many hangars where the electrical system is cobbled together). Or if I ever tried to run it through a long extension cord, it would bog down. In other words, ask the manufacturer about your specific model. They may have modified the motor, or installed a step down transformer or resistors. Running a 220 motor on 110 could cause issues just like what you describe, but can also cause a high-current situation when it boggs down. Dave Leonard 2008/5/12 Brian Meyette : > > This has nothing to do with RVs, but I know there are a lot of very > knowledgeable people out there and someone might know. > > The short question is - what will happen if you plug a 230v motor into > 115vac? Will it still run, albeit weakly? > > If you're interested, this is the long version - I bought an air > compressor > that the seller said had a motor problem. Rather than just replace the > motor, I tested it out, because sometimes you can actually buy things that > are not as bad as expected, and just need a simple fix. > > The compressor came with a standard 15a, 115v 3-prong plug on it. So, I > disconnected the belt driving the compressor and tested the motor by > plugging it in. It ran fine. So, I connected the belt and let it try to > drive the compressor. It starts and runs ok, but then runs out of steam > and > starts to slow down. Then the start circuit kicks in and it picks up > speed > again, then slows down again. > > So, I figured the motor was indeed bad & I'd have to replace it. But, > after > looking at the motor data plate to see what to order, it clearly says it > is > a 5 HP GE 230 volt only (not 115/230) motor. The whole thing is well > used, > so someone in its past must have been using it successfully. Perhaps the > previous owner (or one before that) either had a 230v circuit with a 115v > outlet on it (REALLY bad idea) or perhaps the guy I bought it from got it > without a plug on the end, assumed it was 115v and put the 115v plug on it > & > then saw it didn't work, so he sold it. > > So, I am planning to put a 230v plug on it and try it in a 230v circuit. > I > guess I don't have anything to lose if somehow it is really 115 and I put > 230 to it & burn it up , as I would otherwise have to replace the motor > anyway, because it is too weak at 115v. I just wondered if it was > feasible > that it really is a 230v motor and all it needs is a 230v supply. > > What do you guys think - will a 230v motor run, but weakly, on 115v? > > Thanks, > brian > > Checked by AVG. > 1:08 PM > > -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net ________________________________________________________________________________
Date: May 12, 2008
Brian, First, if the name plate says 230 volts, yes, wire up a 230 volt plug and see what happens. Second, if the name plate says 115/230 volts, it is a dual voltage motor. There are connections under the cover where the electrical power comes in that need to be changed. The name plate should have the proper connections to change the voltage. Make these changes to the voltage you wish to use. The wires should be numbered with ink or tags. A quick lesson in electric motors. Dual voltage motors have two coils either in series or parallel. Each coil is rated for 115 volts and for simplicity, let's say each coil draws 5 amps of current. If you wire for 115 V, then each coil loads to 115 V, but, since there are two coils, the current drawn is 10 amps. Next is crude diagram. 5A VVVVVVV 10A / \ 10A ------ -------- \ / VVVVVVV 5A VVVVVV= motor coils XXA= amps through each part of the circuit For 230V connections, the coils are in series, each loads to 115V but the current remains 5Amps. 5A 5A 5A 5A ------VVVVVVV----VVVVVV------ The power or wattage consumed is the same between the two. 115V x 10A = 1150 Watts 230V x 5A = 1150 Watts Hope this helps and let me know if I can be of more help. Dave Nellis Electrician for 30 years --- Brian Meyette wrote: > > > This has nothing to do with RVs, but I know there > are a lot of very > knowledgeable people out there and someone might > know. > > The short question is - what will happen if you plug > a 230v motor into > 115vac? Will it still run, albeit weakly? > > If you're interested, this is the long version - I > bought an air compressor > that the seller said had a motor problem. Rather > than just replace the > motor, I tested it out, because sometimes you can > actually buy things that > are not as bad as expected, and just need a simple > fix. > > The compressor came with a standard 15a, 115v > 3-prong plug on it. So, I > disconnected the belt driving the compressor and > tested the motor by > plugging it in. It ran fine. So, I connected the > belt and let it try to > drive the compressor. It starts and runs ok, but > then runs out of steam and > starts to slow down. Then the start circuit kicks > in and it picks up speed > again, then slows down again. > > So, I figured the motor was indeed bad & I'd have to > replace it. But, after > looking at the motor data plate to see what to > order, it clearly says it is > a 5 HP GE 230 volt only (not 115/230) motor. The > whole thing is well used, > so someone in its past must have been using it > successfully. Perhaps the > previous owner (or one before that) either had a > 230v circuit with a 115v > outlet on it (REALLY bad idea) or perhaps the guy I > bought it from got it > without a plug on the end, assumed it was 115v and > put the 115v plug on it & > then saw it didn't work, so he sold it. > > So, I am planning to put a 230v plug on it and try > it in a 230v circuit. I > guess I dont have anything to lose if somehow it is > really 115 and I put > 230 to it & burn it up , as I would otherwise have > to replace the motor > anyway, because it is too weak at 115v. I just > wondered if it was feasible > that it really is a 230v motor and all it needs is a > 230v supply. > > What do you guys think - will a 230v motor run, but > weakly, on 115v? > > Thanks, > brian > > Checked by AVG. > 1:08 PM > > > > > > browse > Un/Subscription, > FAQ, > > Forums! > > Admin. > > > > > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: May 12, 2008
Brian, Remove the access cover to the wiring and check to see if the motor is wired for lo voltage or high voltage. The internal taps may need to be simply placed on the correct terminal. Check the motor data plate for the correct tap arrangement. Russ ----- Original Message ----- From: "Brian Meyette" <bmeyette(at)gmail.com> Sent: Monday, May 12, 2008 12:54 PM Subject: RV-List: off-topic question about AC electric motors > > This has nothing to do with RVs, but I know there are a lot of very > knowledgeable people out there and someone might know. > > The short question is - what will happen if you plug a 230v motor into > 115vac? Will it still run, albeit weakly? > > If you're interested, this is the long version - I bought an air > compressor > that the seller said had a motor problem. Rather than just replace the > motor, I tested it out, because sometimes you can actually buy things that > are not as bad as expected, and just need a simple fix. > > The compressor came with a standard 15a, 115v 3-prong plug on it. So, I > disconnected the belt driving the compressor and tested the motor by > plugging it in. It ran fine. So, I connected the belt and let it try to > drive the compressor. It starts and runs ok, but then runs out of steam > and > starts to slow down. Then the start circuit kicks in and it picks up > speed > again, then slows down again. > > So, I figured the motor was indeed bad & I'd have to replace it. But, > after > looking at the motor data plate to see what to order, it clearly says it > is > a 5 HP GE 230 volt only (not 115/230) motor. The whole thing is well > used, > so someone in its past must have been using it successfully. Perhaps the > previous owner (or one before that) either had a 230v circuit with a 115v > outlet on it (REALLY bad idea) or perhaps the guy I bought it from got it > without a plug on the end, assumed it was 115v and put the 115v plug on it > & > then saw it didn't work, so he sold it. > > So, I am planning to put a 230v plug on it and try it in a 230v circuit. > I > guess I dont have anything to lose if somehow it is really 115 and I put > 230 to it & burn it up , as I would otherwise have to replace the motor > anyway, because it is too weak at 115v. I just wondered if it was > feasible > that it really is a 230v motor and all it needs is a 230v supply. > > What do you guys think - will a 230v motor run, but weakly, on 115v? > > Thanks, > brian > > Checked by AVG. > 1:08 PM > > > ________________________________________________________________________________
From: "sheldon barrett" <sheldonb(at)frontiernet.net>
Date: May 13, 2008
If it's indeed a dual voltage motor, the name plate will indicate it...(115 v @ some amperage/230v @ half that amperage)... If the motors name plate only says 230v. then it's probably a single voltage winding and there won't be any taps to change.. It will eventually burn up running on low voltage.... Sheldon ----- Original Message ----- From: "Russ & Marilyn" <rmkeith(at)gwi.net> Sent: Monday, May 12, 2008 7:50 PM Subject: Re: RV-List: off-topic question about AC electric motors > > Brian, > > > Remove the access cover to the wiring and check to see if the motor is > wired for lo voltage or high voltage. The internal taps may need to be > simply placed on the correct terminal. Check the motor data plate for the > correct tap arrangement. > > Russ > > > ----- Original Message ----- > From: "Brian Meyette" <bmeyette(at)gmail.com> > To: > Sent: Monday, May 12, 2008 12:54 PM > Subject: RV-List: off-topic question about AC electric motors > > >> >> This has nothing to do with RVs, but I know there are a lot of very >> knowledgeable people out there and someone might know. >> >> The short question is - what will happen if you plug a 230v motor into >> 115vac? Will it still run, albeit weakly? >> >> If you're interested, this is the long version - I bought an air >> compressor >> that the seller said had a motor problem. Rather than just replace the >> motor, I tested it out, because sometimes you can actually buy things >> that >> are not as bad as expected, and just need a simple fix. >> >> The compressor came with a standard 15a, 115v 3-prong plug on it. So, I >> disconnected the belt driving the compressor and tested the motor by >> plugging it in. It ran fine. So, I connected the belt and let it try to >> drive the compressor. It starts and runs ok, but then runs out of steam >> and >> starts to slow down. Then the start circuit kicks in and it picks up >> speed >> again, then slows down again. >> >> So, I figured the motor was indeed bad & I'd have to replace it. But, >> after >> looking at the motor data plate to see what to order, it clearly says it >> is >> a 5 HP GE 230 volt only (not 115/230) motor. The whole thing is well >> used, >> so someone in its past must have been using it successfully. Perhaps the >> previous owner (or one before that) either had a 230v circuit with a 115v >> outlet on it (REALLY bad idea) or perhaps the guy I bought it from got it >> without a plug on the end, assumed it was 115v and put the 115v plug on >> it & >> then saw it didn't work, so he sold it. >> >> So, I am planning to put a 230v plug on it and try it in a 230v circuit. >> I >> guess I dont have anything to lose if somehow it is really 115 and I put >> 230 to it & burn it up , as I would otherwise have to replace the motor >> anyway, because it is too weak at 115v. I just wondered if it was >> feasible >> that it really is a 230v motor and all it needs is a 230v supply. >> >> What do you guys think - will a 230v motor run, but weakly, on 115v? >> >> Thanks, >> brian >> >> Checked by AVG. >> 1:08 PM >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: May 13, 2008
Thanks to all for the advice. I tried hooking it to 230v last night and it ran great. It's definitely a 230v-only motor, and there's nothing wrong with it. So the motor alone is worth way more than the price I paid for the whole compressor. Odd that it came with a 115v plug that threw me. the seller must have bought the compressor somewhere (perhaps an auction), probably without a plug, installed that 115v plug, thinking it was 115v, then sold it cuz it didnt work well. I lucked out on that transaction, as I was expecting to have to buy a new motor for it when I bought it. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of sheldon barrett Sent: Tuesday, May 13, 2008 7:11 AM Subject: Re: RV-List: off-topic question about AC electric motors If it's indeed a dual voltage motor, the name plate will indicate it...(115 v @ some amperage/230v @ half that amperage)... If the motors name plate only says 230v. then it's probably a single voltage winding and there won't be any taps to change.. It will eventually burn up running on low voltage.... Sheldon ----- Original Message ----- From: "Russ & Marilyn" <rmkeith(at)gwi.net> Sent: Monday, May 12, 2008 7:50 PM Subject: Re: RV-List: off-topic question about AC electric motors > > Brian, > > > Remove the access cover to the wiring and check to see if the motor is > wired for lo voltage or high voltage. The internal taps may need to be > simply placed on the correct terminal. Check the motor data plate for the > correct tap arrangement. > > Russ > > > ----- Original Message ----- > From: "Brian Meyette" <bmeyette(at)gmail.com> > To: > Sent: Monday, May 12, 2008 12:54 PM > Subject: RV-List: off-topic question about AC electric motors > > >> >> This has nothing to do with RVs, but I know there are a lot of very >> knowledgeable people out there and someone might know. >> >> The short question is - what will happen if you plug a 230v motor into >> 115vac? Will it still run, albeit weakly? >> >> If you're interested, this is the long version - I bought an air >> compressor >> that the seller said had a motor problem. Rather than just replace the >> motor, I tested it out, because sometimes you can actually buy things >> that >> are not as bad as expected, and just need a simple fix. >> >> The compressor came with a standard 15a, 115v 3-prong plug on it. So, I >> disconnected the belt driving the compressor and tested the motor by >> plugging it in. It ran fine. So, I connected the belt and let it try to >> drive the compressor. It starts and runs ok, but then runs out of steam >> and >> starts to slow down. Then the start circuit kicks in and it picks up >> speed >> again, then slows down again. >> >> So, I figured the motor was indeed bad & I'd have to replace it. But, >> after >> looking at the motor data plate to see what to order, it clearly says it >> is >> a 5 HP GE 230 volt only (not 115/230) motor. The whole thing is well >> used, >> so someone in its past must have been using it successfully. Perhaps the >> previous owner (or one before that) either had a 230v circuit with a 115v >> outlet on it (REALLY bad idea) or perhaps the guy I bought it from got it >> without a plug on the end, assumed it was 115v and put the 115v plug on >> it & >> then saw it didn't work, so he sold it. >> >> So, I am planning to put a 230v plug on it and try it in a 230v circuit. >> I >> guess I dont have anything to lose if somehow it is really 115 and I put >> 230 to it & burn it up , as I would otherwise have to replace the motor >> anyway, because it is too weak at 115v. I just wondered if it was >> feasible >> that it really is a 230v motor and all it needs is a 230v supply. >> >> What do you guys think - will a 230v motor run, but weakly, on 115v? >> >> Thanks, >> brian >> >> Checked by AVG. >> 1:08 PM >> >> >> >> >> >> >> >> > > > Checked by AVG. 6:14 PM Checked by AVG. 6:14 PM ________________________________________________________________________________
Subject: RV9-List: FS: RV9/9A Unassembled Emp Kit + Tools + Primer + Preview
plans + RV9 Orndorff Videos in Vancouver, BC
Date: May 14, 2008
After a year and a half and much deliberation I am ready to admit that I started this project at the wrong time of my life and need to focus my attention on other things. I am putting my unassembled RV9 Empennage (VS spar match drilled) with electric trim option and everything needed to complete the kit up for sale. This includes all the hand tools needed (itemized list for available for anyone interested), Sherwin Williams E2G973 primer and reducer, preview plans if wanted, and the construction videos. This is everything needed to start assembling your RV9/9A right away. Not a single rivet pounded on this kit. I know how much I have invested in this kit and getting geared up to assemble it but I also recognize that I would be being helped out by the person willing to purchase it from me; so at this point I would like to leave it open to offers. The Kit is located in Vancouver, British Columbia. Thank you, Brandon Rigio ________________________________________________________________________________
From: "Chuck & Deanna Schieffer" <cdschieffer(at)msn.com>
Subject: Cylinder head temps
Date: May 14, 2008
Hi guys, I have about 33 hours flown off of my 40 hours on my RV-7A at CMA. I have a Superior O-360 with electronic ignitions and a Hartzell CS prop with 8.5:1 pistons. I usually use full power to climb to 1000' then go to 25"/2500 until about 2500' then level off and go to 23:/2350. My cylinder head temps at 2500' are usually #1 & 2 about 380 to 400 degrees with #s 3 and 4 about 415 to 420 deg on a 70 deg day. Oil temp usually stays between 170 and 185. I was hoping during break-in the CHTs would drop by this time. My oil consumption seems to be about 1/4th of a quart per hour so I think the majority of my engine break-in is done. I have sealed all the significant holes in the upper cowl pressure area and are now considering adding the lower cowl louvers to try to get more CHT cooling. Any thoughts from you guys who have been down this road. Thanks, Chuck Schieffer ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Cylinder head temps
Date: May 14, 2008
Honestly, your temperatures are not bad, and are certainly not a danger to your engine. But, since you want to improve things, how 'bout a little more data? What climb speed are you using? I recommend 120 knots or more unless you've got an obstacle to clear. What type CHT probes are you using and where are they mounted (screw-in probe, spark plug ring , etc)? Do you have a cylinder blocker on #1? FYI, my 0-320 powered RV-6 typically has a peak CHT of 400 degrees or so on #3 cylinder during climb out. Lowering the nose to achieve 120+ knots lowers it. On a hot day, #3 may reach 420 or 425. Before I installed a cylinder blocker on #1, the temperatures on #3 were 25 degrees higher than they are today. Kyle Boatright ----- Original Message ----- From: Chuck & Deanna Schieffer To: rv-list(at)matronics.com Sent: Wednesday, May 14, 2008 10:32 PM Subject: RV-List: Cylinder head temps Hi guys, I have about 33 hours flown off of my 40 hours on my RV-7A at CMA. I have a Superior O-360 with electronic ignitions and a Hartzell CS prop with 8.5:1 pistons. I usually use full power to climb to 1000' then go to 25"/2500 until about 2500' then level off and go to 23:/2350. My cylinder head temps at 2500' are usually #1 & 2 about 380 to 400 degrees with #s 3 and 4 about 415 to 420 deg on a 70 deg day. Oil temp usually stays between 170 and 185. I was hoping during break-in the CHTs would drop by this time. My oil consumption seems to be about 1/4th of a quart per hour so I think the majority of my engine break-in is done. I have sealed all the significant holes in the upper cowl pressure area and are now considering adding the lower cowl louvers to try to get more CHT cooling. Any thoughts from you guys who have been down this road. Thanks, Chuck Schieffer ________________________________________________________________________________
Date: May 14, 2008
Chuck, One thing to think about; when you pull the throttle for your initial power reduction, you come off the carb's enrichener circuit and it runs somewhat leaner. This may be contributing to higher CHTs during climb. What are your EGTs doing when you pull? It might be better to leave the throttle forward and come back about 100 RPM on the prop, if you want to lower the noise level, for climbout until you are ready to reduce power for cruise. That said, the temps do seem a little high for a cool day. Are you sure of your ignition timing? As has been said, a little higher climbout speed makes a difference in temps, also. Pax, Ed Holyoke Chuck & Deanna Schieffer wrote: > Hi guys, > I have about 33 hours flown off of my 40 hours on my RV-7A at CMA. I > have a Superior O-360 with electronic ignitions and a Hartzell CS prop > with 8.5:1 pistons. I usually use full power to climb to 1000' then > go to 25"/2500 until about 2500' then level off and go to 23:/2350. > My cylinder head temps at 2500' are usually #1 & 2 about 380 to 400 > degrees with #s 3 and 4 about 415 to 420 deg on a 70 deg day. Oil > temp usually stays between 170 and 185. I was hoping during break-in > the CHTs would drop by this time. My oil consumption seems to be > about 1/4th of a quart per hour so I think the majority of my engine > break-in is done. I have sealed all the significant holes in the > upper cowl pressure area and are now considering adding the lower cowl > louvers to try to get more CHT cooling. Any thoughts from you guys > who have been down this road. > Thanks, > Chuck Schieffer > > * > > > * ________________________________________________________________________________
Date: May 15, 2008
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Here is a dicussion on that subject that is ging on over at VAF: http://www.vansairforce.com/community/showthread.php?t=29981 I see about the same thing and also have a Superior XP-0360 I installed the lower louvers and they did not seem to help much. I don't use hardly any oil. I have found that the engine oil level likes to stay about 6.5 on the dip stick. If there is more it seems to go away until it gets to 6.5 and then it stays there for a long time. When I see the CHT's going over 410 I usually level off and pull the throttle back until it comes back down then continue my climb. ---- Surfing the web from Hopkinsville, KY Visit my flying RV7A web page: http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm Chuck & Deanna Schieffer wrote: > Hi guys, > I have about 33 hours flown off of my 40 hours on my RV-7A at CMA. I > have a Superior O-360 with electronic ignitions and a Hartzell CS prop > with 8.5:1 pistons. I usually use full power to climb to 1000' then > go to 25"/2500 until about 2500' then level off and go to 23:/2350. > My cylinder head temps at 2500' are usually #1 & 2 about 380 to 400 > degrees with #s 3 and 4 about 415 to 420 deg on a 70 deg day. Oil > temp usually stays between 170 and 185. I was hoping during break-in > the CHTs would drop by this time. My oil consumption seems to be > about 1/4th of a quart per hour so I think the majority of my engine > break-in is done. I have sealed all the significant holes in the > upper cowl pressure area and are now considering adding the lower cowl > louvers to try to get more CHT cooling. Any thoughts from you guys > who have been down this road. > Thanks, > Chuck Schieffer > > * > > > * ________________________________________________________________________________
From: "Wesley Robinson" <wesleyt(at)stanfordfurniture.com>
Subject: Fly-In this Saturday at Hickory, NC
Date: May 15, 2008
EAA Chapter 731 is holding their Spring Fly-in at Hickory (KHKY) this Saturday. There will be an award for best RV! See their website for more info: http://www.eaa731.org Wesley T Robinson RV-9A N224WR 'The Red Baron' ________________________________________________________________________________
Date: May 15, 2008
Subject: What Is This, Where Can I Get Them?
What is this piece of AN hardware? It is holding an AN3 fiction bolt head in place on the back of the Van's throttle quadrants. Thanks! Matt Dralle List Admin / RV-4 Builder ________________________________________________________________________________
Date: May 16, 2008
Subject: Re: What Is This, Where Can I Get Them?
Matt, when you get the answer to this question, please pass it along. Thanks, Dale -----Original Message----- >From: Matt Dralle <dralle(at)matronics.com> >Sent: May 16, 2008 12:11 AM >To: rv-list(at)matronics.com >Subject: RV-List: What Is This, Where Can I Get Them? > > >What is this piece of AN hardware? It is holding an AN3 fiction bolt >head in place on the back of the Van's throttle quadrants. > >Thanks! > >Matt Dralle >List Admin / RV-4 Builder ________________________________________________________________________________
Date: May 16, 2008
Matt, I believe that is a 2 lug hex head retainer (think reverse nut plate). Check out this link: http://www.spstech.com/aero/fastenerfinder/browse.jsp?category=PLATENUTS[/code] -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=183453#183453 ________________________________________________________________________________
Date: May 16, 2008
Subject: RV8 project for sale
RV8 #970 tail and wings complete and inspected (Canada) prior to closure. Excellent workmanship mentored by OSH workmanship award winner. Many reasons for selling, all of them sad but ...my loss , your gain . $10K US includes all tools and builders logbook/plans (avery, Cleveland dies, cp straight and angle drills, cp pneumatic squeezer and a lot of extras) Items crated and ready to ship. Located in Edmonton Alberta Robert Baxter robbax(at)shaw.ca robert.baxter(at)shell.com 780-464-1719 Mobile 780-901-9959 ________________________________________________________________________________
From: "Reginald C. Smith, Sr." <smirdrv(at)hotmail.com>
Subject: Interior Wing Primer
Date: May 17, 2008
Listers, I am in the process of finishing my wings, and found out that my Wash Primer has expired. Just wondering what you'd suggest as an alternative Pri mer for the interior of the Wing. A/C Spruce has Prekote Surface Pretreatme nt PN: 09-00826 (Gal.) that sounds like it might work. I'm open for sugges tions. Thanks. _________________________________________________________________ E-mail for the greater good. Join the i=92m Initiative from Microsoft. ood ________________________________________________________________________________
Subject: Battery problem
Date: May 19, 2008
I have to replace batty, rg25xc now near $200. Ive been told that 300 amp cold cranking lawntractor batty would serve just as well. Im not sure, anybody here have experience or knowledge about this? Charlie Heathco ________________________________________________________________________________
Subject: Re: Battery problem
Date: May 19, 2008
have you checked the Odyssey batteries? PC925 is probably a similar capacity Ron Lee ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Monday, May 19, 2008 8:43 AM Subject: RV-List: Battery problem I have to replace batty, rg25xc now near $200. Ive been told that 300 amp cold cranking lawntractor batty would serve just as well. Im not sure, anybody here have experience or knowledge about this? Charlie Heathco ________________________________________________________________________________
Date: May 19, 2008
I used several of those in the past, with mixed results. Past six or so years I have gone with Odyssey with universal good results. Vans calls them out now for RVs. Can be had for 100, if you shop around. just screw some wood spacers in the battery box. Have use both 680 and 625 Works for me. On May 19, 2008, at 8:43 , Charles Heathco wrote: > I have to replace batty, rg25xc now near $200. Ive been told that > 300 amp cold cranking lawntractor batty would serve just as well. Im > not sure, anybody here have experience or knowledge about this? > Charlie Heathco > > ________________________________________________________________________________
Date: May 19, 2008
Who makes this Odessey, plug in webb, no result. Chas ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Monday, May 19, 2008 10:24 AM Subject: Re: RV-List: Battery problem have you checked the Odyssey batteries? PC925 is probably a similar capacity Ron Lee ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Monday, May 19, 2008 8:43 AM Subject: RV-List: Battery problem I have to replace batty, rg25xc now near $200. Ive been told that 300 amp cold cranking lawntractor batty would serve just as well. Im not sure, anybody here have experience or knowledge about this? Charlie Heathco href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: May 19, 2008
In a message dated 5/19/2008 8:56:34 A.M. Pacific Daylight Time, cheathco(at)cox.net writes: Who makes this Odessey, plug in webb, no result. ========================================= I suppose it would help you to find it were Odyssey spelled correctly. N1GV (RV-6A, Flying 887hrs, O-360-A1A, C/S, Silicon Valley) **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 19, 2008
Aircraft Spruce carries them _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com Sent: Monday, May 19, 2008 9:59 AM Subject: Re: RV-List: Battery problem In a message dated 5/19/2008 8:56:34 A.M. Pacific Daylight Time, cheathco(at)cox.net writes: Who makes this Odessey, plug in webb, no result. ========================================= I suppose it would help you to find it were Odyssey spelled correctly. N1GV (RV-6A, Flying 887hrs, O-360-A1A, C/S, Silicon Valley) _____ Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food <http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001> . __________ NOD32 3109 (20080519) Information __________ ________________________________________________________________________________
Date: May 19, 2008
Date: May 19, 2008
Here's the link: http://www.odysseyfactory.com/ -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=183836#183836 ________________________________________________________________________________
Date: May 19, 2008
From: Carlos Hernandez <carlosh(at)structuralaz.com>
http://www.odysseybatteries.com/ Charles Heathco wrote: > Who makes this Odessey, plug in webb, no result. Chas > > ----- Original Message ----- > *From:* Ron Lee > *To:* rv-list(at)matronics.com > *Sent:* Monday, May 19, 2008 10:24 AM > *Subject:* Re: RV-List: Battery problem > > have you checked the Odyssey batteries? > > PC925 is probably a similar capacity > > Ron Lee > > ----- Original Message ----- > *From:* Charles Heathco > *To:* rv-list > *Sent:* Monday, May 19, 2008 8:43 AM > *Subject:* RV-List: Battery problem > > I have to replace batty, rg25xc now near $200. Ive been told > that 300 amp cold cranking lawntractor batty would serve just > as well. Im not sure, anybody here have experience or > knowledge about this? Charlie Heathco > > * > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * > ------------------------------------------------------------------------ > > Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: May 19, 2008
Alot of places carry them. I got mine from a local Batteries Plus store. Same price if not a few bucks cheaper and no delivery cost. Here's the web page: http://www.odysseybatteries.com/ Carlos Jim CArey wrote: > Aircraft Spruce carries them > > ------------------------------------------------------------------------ > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of > *Vanremog(at)aol.com > *Sent:* Monday, May 19, 2008 9:59 AM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: Battery problem > > In a message dated 5/19/2008 8:56:34 A.M. Pacific Daylight Time, > cheathco(at)cox.net writes: > > Who makes this Odessey, plug in webb, no result. > > ========================================= > > I suppose it would help you to find it were Odyssey spelled correctly. > > *N1GV (RV-6A, Flying 887hrs, O-360-A1A, C/S, Silicon Valley)* > > > ------------------------------------------------------------------------ > Wondering what's for Dinner Tonight? Get new twists on family > favorites at AOL Food > <http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001>. > * > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > > __________ NOD32 3109 (20080519) Information __________ > > * > > > * > ------------------------------------------------------------------------ > > Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: May 19, 2008
I just ordered one from here. http://www.batteryplex.com/odyssey-detail.cfm?model=PC680 This well be my second Odyessy, I have had the one that is in my RV-6 now since Jan. of 2003 and it still works great even after no use for several weeks. I am only buying a new one because I need a new battery for my Honda Goldwing so am going to take the one from airplane and put in motorcycle. Charles Heathco wrote: > I have to replace batty, rg25xc now near $200. Ive been told that 300 > amp cold cranking lawntractor batty would serve just as well. Im not > sure, anybody here have experience or knowledge about this? Charlie > Heathco > > ________________________________________________________________________________
Date: May 19, 2008
With my electrically dependant ignition and avionics, I wanted to maximize the battery that will fit into the stock battery box. This is what I came up with, after hearing Someone else had good luck with panasonic sealed lead batteries: http://www.panasonic.com/industrial/battery/oem/images/pdf/Panasonic_VRLA_LC-R1233P.pdf it is 33 Amp.hr, deep cycle, and can be mounted in any position like the oddessey. In fact, the description seems very much like that of the oddessy batteries: http://www.panasonic.com/industrial/battery/oem/chem/seal/index.html Have used mine for a year now with great success. I paid about $110 for it. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Mon, May 19, 2008 at 10:38 AM, Jerry Springer wrote: > > I just ordered one from here. > > http://www.batteryplex.com/odyssey-detail.cfm?model=PC680 > > > This well be my second Odyessy, I have had the one that is in my RV-6 now > since Jan. of 2003 and > it still works great even after no use for several weeks. I am only buying > a new one because I need a > new battery for my Honda Goldwing so am going to take the one from airplane > and put in motorcycle. > > > Charles Heathco wrote: > > I have to replace batty, rg25xc now near $200. Ive been told that 300 amp >> cold cranking lawntractor batty would serve just as well. Im not sure, >> anybody here have experience or knowledge about this? Charlie Heathco >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 19, 2008
Odysseys work...why anguish over it. Chuck Jensen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of David Leonard Sent: Monday, May 19, 2008 3:29 PM Subject: Re: RV-List: Battery problem With my electrically dependant ignition and avionics, I wanted to maximize the battery that will fit into the stock battery box. This is what I came up with, after hearing Someone else had good luck with panasonic sealed lead batteries: http://www.panasonic.com/industrial/battery/oem/images/pdf/Panasonic_VRLA _LC-R1233P.pdf it is 33 Amp.hr, deep cycle, and can be mounted in any position like the oddessey. In fact, the description seems very much like that of the oddessy batteries: http://www.panasonic.com/industrial/battery/oem/chem/seal/index.html Have used mine for a year now with great success. I paid about $110 for it. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Mon, May 19, 2008 at 10:38 AM, Jerry Springer < jsflyrv(at)verizon.net> wrote: I just ordered one from here. http://www.batteryplex.com/odyssey-detail.cfm?model=PC680 This well be my second Odyessy, I have had the one that is in my RV-6 now since Jan. of 2003 and it still works great even after no use for several weeks. I am only buying a new one because I need a new battery for my Honda Goldwing so am going to take the one from airplane and put in motorcycle. Charles Heathco wrote: I have to replace batty, rg25xc now near $200. Ive been told that 300 amp cold cranking lawntractor batty would serve just as well. Im not sure, anybody here have experience or knowledge about this? Charlie Heathco ________________________________________________________________________________
Subject: Need Terra TRT250 or 250D
Date: May 19, 2008
Anyone out there have a Terra transponder, preferably the "newer" TRT250D model? My pushbutton model died last week, and I don't think it can be revived at a reasonable cost. With limited space for anything larger, I'm hoping to find a working or repairable "D" model to fit in the hole. Call me, 831-277-1177 (cell). I promise I'll call you back! John DeCuir N204CP RV-4, s/n 21 Salinas, CA ________________________________________________________________________________
Date: May 19, 2008
In a message dated 05/19/2008 10:39:43 AM Central Daylight Time, denis.walsh(at)comcast.net writes: I have to replace batty, rg25xc now near $200. Or try one of these from Digi-key.com- A Panasonic VSLA 20 ah unit currently offered for $80: _http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P231-ND_ (http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P231-ND) I've quite successfully used these in O-320 and IO-360 installations... >From The PossumWorks in TN Mark, RV-6A "Mojo" _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 19, 2008
Subject: Re: Need Terra TRT250 or 250D
In a message dated 5/19/2008 7:07:59 P.M. Pacific Daylight Time, jadecuir(at)comcast.net writes: Anyone out there have a Terra transponder, preferably the "newer" TRT250D model? My pushbutton model died last week, and I don't think it can be revived at a reasonable cost. With limited space for anything larger, I'm hoping to find a working or repairable "D" model to fit in the hole. ======================== Check the Yeller Pages at _http://www.matronics.com/YellerPages/_ (http://www.matronics.com/YellerPages/) and search for Terra. N1GV (RV-6A, Flying 895hrs, O-360-A1A, C/S, Silicon Valley) **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Subject: Mike Terpstra
Date: May 19, 2008
Hope someone can help. I breifly met Mike Terpstra in Yerrington, NV. when he flew in to meet with his painter, his RV8 is to be painted in a couple w eeks. Anyway, I failed to get his # or anything because I now have some que stions for him and don't know how so reach him. I do have an address but if someone out them knows him and I can get his e-mail or something that woul d be great. I'm working on an 8 myself and want to share some idea's. TIA, Bruce Gray RV8 Fuse Finishing, Wiring, & You name it! _________________________________________________________________ Make every e-mail and IM count. Join the i=92m Initiative from Microsoft. t ________________________________________________________________________________
Date: May 19, 2008
Other batteries work too. The problem with the odysseys is that the biggest one which fits inside the battery box is only 18ah, and that is not big enough for my preference (electric ignition, fuel pumps, and flight instruments). -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Mon, May 19, 2008 at 3:04 PM, Chuck Jensen wrote: > Odysseys work...why anguish over it. > > Chuck Jensen > > -----Original Message----- > *From:* owner-rv-list-server(at)matronics.com [mailto: > owner-rv-list-server(at)matronics.com]*On Behalf Of *David Leonard > *Sent:* Monday, May 19, 2008 3:29 PM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: Battery problem > > With my electrically dependant ignition and avionics, I wanted to maximize > the battery that will fit into the stock battery box. This is what I came > up with, after hearing Someone else had good luck with panasonic sealed lead > batteries: > > > http://www.panasonic.com/industrial/battery/oem/images/pdf/Panasonic_VRLA_LC-R1233P.pdf > > it is 33 Amp.hr, deep cycle, and can be mounted in any position like the > oddessey. In fact, the description seems very much like that of the oddessy > batteries: > > http://www.panasonic.com/industrial/battery/oem/chem/seal/index.html > > Have used mine for a year now with great success. I paid about $110 for > it. > > -- > David Leonard > > Turbo Rotary RV-6 N4VY > http://N4VY.RotaryRoster.net > http://RotaryRoster.net > > ________________________________________________________________________________
Subject: Re: RV-List Digest: 23 Msgs - 05/19/08
Date: May 20, 2008
Hello Electric buffs. I have a question that may appear stupid, but I'll take my chances. Below is a statement made by a lister recently: >Subject: Re: RV-List: Battery problem > >Other batteries work too. > >The problem with the odysseys is that the biggest one which fits inside the >battery box is only 18ah, and that is not big enough for my preference >(electric ignition, fuel pumps, and flight instruments). If I had electric ignition fuel pumps flight instruments etc that when running should use say 30 amps in total. If my alternator that was putting out 55Amp hours, why should I worry that the battery was not rated at 30 amps? The main task of the battery is to start the big fan at the front. Once that is running, the Alternator should be able to handle the entire load and then some. So the real question should be, what is my essential bus load , and how long do I want my battery to last b4 I need to get on the ground?? Wouldn't it make more sense to have two batteries rated at say 18 amp/hours each rather than a single battery rated at 35 amp hours?? Mick ________________________________________________________________________________
Subject: Battery Problem
Date: May 20, 2008
Not a stupid question. Rather an excellent observation, and a good prompt for a discussion of battery needs for our RVs. First, you should check the subject to insure the readers respond . Most would probably contend that the primary role for the aircraft battery is to carry you to a safe landing in the event of an alternator failure. Secondary is the start. Therefore the 18 amp is good for start since it has a good cranking amperage; however could be marginal if you have a heavy essential load and a need to go quite a way if alternator fails. So the debate will rage on regarding the relative merits of a failure warning system, an essential bus, a backup battery/alternator, and or a bigger battery. A further consideration is a dedicated battery for ignition or EFIS. My current preference for my VFR RV is to have the odyssey but with magneto ignition and a light load which includes an internal battery for both GPS and EFIS. But if I had an automotive type powerplant with electric fuel feed. EEC, and ignition, I would feel different. On May 20, 2008, at 2:29 AM, Mick Muller wrote: > > Hello Electric buffs. I have a question that may appear stupid, but > I'll take my chances. > Below is a statement made by a lister recently: > >> Subject: Re: RV-List: Battery problem >> >> Other batteries work too. >> >> The problem with the odysseys is that the biggest one which fits >> inside the >> battery box is only 18ah, and that is not big enough for my >> preference >> (electric ignition, fuel pumps, and flight instruments). > > If I had electric ignition fuel pumps flight instruments etc that > when running should use say 30 amps in total. > > If my alternator that was putting out 55Amp hours, why should I > worry that the battery was not rated at 30 amps? The main task of > the battery is to start the big fan at the front. Once that is > running, the Alternator should be able to handle the entire load and > then some. So the real question should be, what is my essential bus > load , and how long do I want my battery to last b4 I need to get on > the ground?? Wouldn't it make more sense to have two batteries rated > at say 18 amp/hours each rather than a single battery rated at 35 > amp hours?? > Mick > > ________________________________________________________________________________
Date: May 20, 2008
David, Unless you need the extra battery weight of a larger battery for W&B, as some canards do, why not install an E-Buss so you can shed load. The 18ah battery will last as long as a 30ah one if you shed load properly, and it will get you home equally as well, including IFR. But hey, if its a 'personal preference thing', load 'em up, you're entitled to whatever floats your boat, or anchors your airplane. Chuck Jensen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of David Leonard Sent: Tuesday, May 20, 2008 1:35 AM Subject: Re: RV-List: Battery problem Other batteries work too. The problem with the odysseys is that the biggest one which fits inside the battery box is only 18ah, and that is not big enough for my preference (electric ignition, fuel pumps, and flight instruments). -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Mon, May 19, 2008 at 3:04 PM, Chuck Jensen < cjensen(at)dts9000.com> wrote: Odysseys work...why anguish over it. Chuck Jensen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com]On Behalf Of David Leonard Sent: Monday, May 19, 2008 3:29 PM Subject: Re: RV-List: Battery problem With my electrically dependant ignition and avionics, I wanted to maximize the battery that will fit into the stock battery box. This is what I came up with, after hearing Someone else had good luck with panasonic sealed lead batteries: http://www.panasonic.com/industrial/battery/oem/images/pdf/Panasonic_VRLA _LC-R1233P.pdf it is 33 Amp.hr, deep cycle, and can be mounted in any position like the oddessey. In fact, the description seems very much like that of the oddessy batteries: http://www.panasonic.com/industrial/battery/oem/chem/seal/index.html Have used mine for a year now with great success. I paid about $110 for it. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net ________________________________________________________________________________
Subject: Re: Battery Problem
Date: May 20, 2008
>>> The problem with the odysseys is that the biggest one which fits inside >>> the >>> battery box is only 18ah, and that is not big enough for my >>> preference >>> (electric ignition, fuel pumps, and flight instruments). This is INCORRECT. I have an Odyssey 925 in my RV-6A battery box and am ASSUMING that it is the stock battery box. You can get the dimensions of the 925 easily to see if it will fit. Ron Lee ________________________________________________________________________________
Date: May 20, 2008
I used the Odessey 925 as well. I did have to turn it so the terminals were on the side to fit my stock RV-8 battery mount (not a problem for the battery as far as I know). My 'alternator out' battery drain is about 12 amps for all system in my 'all electric' rotary engine installation.. I can reduce that to about 9 amps by switching off non-essential stuff in a pinch. Tracy Crook On Tue, May 20, 2008 at 10:11 AM, Ron Lee wrote: > > The problem with the odysseys is that the biggest one which fits inside >>>> the >>> battery box is only 18ah, and that is not big enough for my >>>> preference >>> (electric ignition, fuel pumps, and flight instruments). >>>> >>> > This is INCORRECT. I have an Odyssey 925 in my RV-6A battery > box and am ASSUMING that it is the stock battery box. > > You can get the dimensions of the 925 easily to see if it will fit. > > Ron Lee > > ________________________________________________________________________________
Date: May 20, 2008
Subject: Re: Mike Terpstra
Try www.411.com and input his address to get a phone number. --------------------------------------------------------------------- BRUCE GRAY wrote: > Hope someone can help. I breifly met Mike Terpstra in Yerrington, NV. > when he flew in to meet with his painter, his RV8 is to be painted in a > couple weeks. Anyway, I failed to get his # or anything because I now > have some questions for him and don't know how so reach him. I do have > an address but if someone out them knows him and I can get his e-mail or > something that would be great. > I'm working on an 8 myself and want to share some idea's. > > TIA, > > Bruce Gray > RV8 Fuse > Finishing, Wiring, & You name it! ---------------------------------------------------------------------------------- ________________________________________________________________________________
Date: May 20, 2008
I found him on line at Phonenumber.com. All the information is on line you just might have to put a few of the pieces together. Scott ----- Original Message ---- From: J. Mcculley <mcculleyja(at)starpower.net> Sent: Tuesday, May 20, 2008 9:50:05 AM Subject: Re: RV-List: Mike Terpstra Try www.411.com and input his address to get a phone number. --------------------------------------------------------------------- BRUCE GRAY wrote: > Hope someone can help. I breifly met Mike Terpstra in Yerrington, NV. > when he flew in to meet with his painter, his RV8 is to be painted in a > couple weeks. Anyway, I failed to get his # or anything because I now > have some questions for him and don't know how so reach him. I do have > an address but if someone out them knows him and I can get his e-mail or > something that would be great. > I'm working on an 8 myself and want to share some idea's. > > TIA, > > Bruce Gray > RV8 Fuse > Finishing, Wiring, & You name it! ---------------------------------------------------------------------------------- ________________________________________________________________________________
Subject: Battery problem solved, created a serious problem with KX125
Date: May 20, 2008
I found a 35ah batty SLA local (ub12350 by universal) and failed to note that pos and neg were reversed from the concord. Yes I put leads on wrong and of course it wounmlnt crank so i flipped on all the swts and blew 5 amp radio fuse and one other 5 amp havent found out what it drives yet. I got batty cables fixed and replaced fuses which blew again when turned on the radio. Anybody havave some experience with KX125 and have an idea what i might have done? Charlie Heathco ________________________________________________________________________________
Date: May 20, 2008
In a message dated 05/20/2008 6:49:40 AM Central Daylight Time, denis.walsh(at)comcast.net writes: Not a stupid question. Rather an excellent observation, and a good prompt for a discussion of battery needs for our RVs. >>> Discussion: One thing I think is often missed is that one should always consider their battery as a "reservoir" of energy, only capable of offering what it has on board. If the alternator goes Tango Uniform shortly after departure, reservoir is depleted somewhat from bringing the mighty Lycoming to life. And if extended cranking prior to departure were the case, (cold temps, hot starts, blown procedure, whatever...) reservoir just might be quite a bit lower than typical. Methinks it wise to consider remaining battery available based on general condition, plus most recent consumption & time recharging in the event of a failure... Mark **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Subject: Re: Current crop of pitot tubes
Date: May 20, 2008
Warren just posted an update to his site. www.gretzaero.com NOTICE: Good News!! The heated Pitot tube part of Gretz Aero, LLC is pending a sale to a new owner! This transfer of this part of the business will take place very soon. It will not be long before the GA-1000 and the GA-500 are again available under a different ownership. I hope you will be content in waiting a short time until everything is back up and running. Thank you to all of you who have contacted me and want to purchase the GA-1000 or GA-500 and are waiting until it is in production again. I enjoy developing new aviation products. Selling the heated Pitot part of my business will allow me the time to bring some of my newest ideas into product. I fully expect to continue with the mounting bracket part of the business and continue to bring out new products for the aviation market. Very soon I will make an announcement on this website disclosing the name of the new owner and provider of the GA-1000 and GA-500. At that time I will give the contact information for the business where you can order these fine products Warren Gretz -------- Bob Leffler N410BL - Wings RV-10 #40684 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=184136#184136 ________________________________________________________________________________
Date: May 21, 2008
Batteries that crank have completely different reliability tables than batteries that don't crank. If you are dependent on electrics this is a significant tid bit. I've been running 2 PC625 batteries, one starts the engine and the other is maintained through a 150 A diode and feeds the critical buss. With electronic ignition the PC 625 is plenty of power for starting my XP-360 and it is in most cases way too much battery for a backup. The advantage is the same as other people have been doing for some time, at some set time interval you dispose of the cranking battery, move the old emergency battery to its place and buy a new emergency battery. Some people do it at a year, I'm going to do it at 2 years since the battery has a 8-12 year design life span. either way you've got a fresh emergency battery that has never cranked the engine all the time. The PC625 is 16 AH, so multiply the number of amps you are dependent upon by the number hours before you can comfortably land with a reasonable safety factor and make sure that doesn't exceed 16. Since the battery didn't crank the engine the capacity should be nearly 100% at all times. I pretty much ignore the capacity of the starting battery for contingency scenarios. With internal battery backup for my GPS and EFIS I can stay upright in the clouds just running the electronic ignition off the battery for a greater time than my fuel endurance. Bill Judge N84WJ RV-8 240 hrs rv-8.blogspot.com ________________________________________________________________________________
Date: May 21, 2008
Yep! On the phone with him last night. Nice guy! My question to him was, Wh ere did you get those aluminum gear leg fairings? Grove! I'll be light enou gh that I don't need them yet. Thanks for the info guy's, Bruce Gray RV8 Fuse > Date: Tue, 20 May 2008 12:51:30 -0700> From: rv8a2001(at)yahoo.com> Subject: Re: RV-List: Mike Terpstra> To: rv-list(at)matronics.com> > --> RV-L ist message posted by: scott bilinski > > I found him o n line at Phonenumber.com. All the information is on line you just might ha ve to put a few of the pieces together.> > Scott > > > ----- Original Mess age ----> From: J. Mcculley <mcculleyja(at)starpower.net>> To: rv-list@matroni cs.com> Sent: Tuesday, May 20, 2008 9:50:05 AM> Subject: Re: RV-List: Mike wer.net>> > Try www.411.com and input his address to get a phone number.> - --------------------------------------------------------------------> > BRU CE GRAY wrote:> > Hope someone can help. I breifly met Mike Terpstra in Yer rington, NV. > > when he flew in to meet with his painter, his RV8 is to be painted in a > > couple weeks. Anyway, I failed to get his # or anything b ecause I now > > have some questions for him and don't know how so reach hi m. I do have > > an address but if someone out them knows him and I can get his e-mail or > > something that would be great.> > I'm working on an 8 my self and want to share some idea's.> > > > TIA,> > > > Bruce Gray> > RV8 Fuse> > Finishing, Wiring, & You name it!> -------------------------------- ==================> > > _________________________________________________________________ Change the world with e-mail. Join the i=92m Initiative from Microsoft. ld ________________________________________________________________________________
Date: May 21, 2008
> Date: Tue, 20 May 2008 12:50:05 -0400> From: mcculleyja(at)starpower.net> To : rv-list(at)matronics.com> Subject: Re: RV-List: Mike Terpstra> > --> RV-List message posted by: "J. Mcculley" > > Try www.411 .com and input his address to get a phone number.> ------------------------ ---------------------------------------------> > BRUCE GRAY wrote:> > Hope someone can help. I breifly met Mike Terpstra in Yerrington, NV. > > when h e flew in to meet with his painter, his RV8 is to be painted in a > > coupl e weeks. Anyway, I failed to get his # or anything because I now > > have s ome questions for him and don't know how so reach him. I do have > > an add ress but if someone out them knows him and I can get his e-mail or > > some thing that would be great.> > I'm working on an 8 myself and want to share some idea's.> > > > TIA,> > > > Bruce Gray> > RV8 Fuse> > Finishing, Wiring , & You name it!> --------------------------------------------------------- =======> > > I tried it and I recieved a hit on his name. It was him. Thanks for your help. Bruce Gray RV8 Fuse _________________________________________________________________ Give to a good cause with every e-mail. Join the i=92m Initiative from Micr osoft. ________________________________________________________________________________
Date: May 21, 2008
Thew battewry shopuld be used to start you ewngine and then your alternator should be powerful ewnough to run everything.=0A=0A=0A----- Original Messa ge ----=0AFrom: David Leonard <wdleonard(at)gmail.com>=0ATo: rv-list@matronics .com=0ASent: Tuesday, May 20, 2008 12:34:49 AM=0ASubject: Re: RV-List: Batt ery problem=0A=0AOther batteries work too. =0A=0AThe problem with the odyss eys is that the biggest one which fits inside the battery box is only 18ah, and that is not big enough for my preference (electric ignition, fuel pump s, and flight instruments).=0A=0A-- =0ADavid Leonard=0A=0ATurbo Rotary RV-6 N4VY=0Ahttp://N4VY.RotaryRoster.net=0Ahttp://RotaryRoster.net=0A=0A=0A=0AO n Mon, May 19, 2008 at 3:04 PM, Chuck Jensen wrote: =0A=0AOdysseys work...why anguish over it.- =0A-=0AChuck Jensen =0A---- -Original Message-----=0AFrom: owner-rv-list-server(at)matronics.com [mailto:o wner-rv-list-server(at)matronics.com]On Behalf Of David Leonard=0ASent: Monday , May 19, 2008 3:29 PM=0ATo: rv-list(at)matronics.com=0ASubject: Re: RV-List: Battery problem=0A=0A=0AWith my electrically dependant ignition and avionic s, I wanted to maximize the battery that will fit into the stock battery bo x.- This is what I came up with, after hearing Someone else had good luck with panasonic sealed lead batteries:=0A=0Ahttp://www.panasonic.com/indust rial/battery/oem/images/pdf/Panasonic_VRLA_LC-R1233P.pdf=0A=0Ait is 33 Amp. hr, deep cycle, and can be mounted in any position like the oddessey.- In fact, the description seems very much like that of the oddessy batteries: =0A=0Ahttp://www.panasonic.com/industrial/battery/oem/chem/seal/index.html =0A=0AHave used mine for a year now with great success.- I paid about $11 0 for it.=0A=0A-- =0ADavid Leonard=0A=0ATurbo Rotary RV-6 N4VY=0Ahttp://N4V =========================0A =0A=0A ________________________________________________________________________________
Subject: Battery Charge
Date: May 21, 2008
This is not really an issue. My hangar to run-up ramp to runway is about 300 feet of taxiway. By the time I get done with the runup my load meter has dropped to 11 amps which is it's normal duty for everything turned on except the lights and flaps. And I have dual IFR and dual EFIS. Minimizing this with the 18AH I easily have an hour to get the ground. Wiring things as a load mater gives one a better picture of what is going on, but even better one can use two shunts and STDP switch on the feed to the amp gauge to have both a load meter and a charge indicator which gives you a complete picture of alternator output and battery charge rate by simply flipping the switch. <<<<<<<<<<>>>>>>>>>>>>> Discussion: One thing I think is often missed is that one should always consider their battery as a "reservoir" of energy, only capable of offering what it has on board. If the alternator goes Tango Uniform shortly after departure, reservoir is depleted somewhat from bringing the mighty Lycoming to life. And if extended cranking prior to departure were the case, (cold temps, hot starts, blown procedure, whatever...) reservoir just might be quite a bit lower than typical. Methinks it wise to consider remaining battery available based on general condition, plus most recent consumption & time recharging in the event of a failure... ________________________________________________________________________________
Date: May 21, 2008
Subject: Re: Battery Discussion
> >Discussion: One thing I think is often missed is that one should >always consider their battery as a "reservoir" of energy, only >capable of offering what it has on board. If the alternator goes >Tango Uniform shortly after departure, reservoir is depleted >somewhat from bringing the mighty Lycoming to life. And if extended >cranking prior to departure were the case, (cold temps, hot starts, >blown procedure, whatever...) reservoir just might be quite a bit >lower than typical. Methinks it wise to consider remaining battery >available based on general condition, plus most recent consumption & >time recharging in the event of a failure... For the redundant types, why not just put on a second alternator, it is a lot lighter and my primary alternator was a lot cheaper than the battery ($70.00). If the alternator fails upon take off, maybe, it might just be possible to land where you took off from? Of if in route maybe you could land at the nearest airport? When I fly cross country I use airports as my waypoints. At least in the east, seldom do I have a waypoint that is more than 30 miles away! On the other hand many of my aerobatic friends fly with no alternator at all and battery only, one guy gets 30 starts before he has to recharge the battery. And yes they do fly cross country to get to aerobatic meets. Two seats for two pilots with two alternators and two batteries! Why not? Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Subject: Re: Pre Flight Problems
Date: May 21, 2008
On 21 May 2008, at 20:40, rveighta wrote: > > Listers, I'm hoping to make the first flight of my RV-8 in the next > few days, but I have a couple of problems I need to sort out first. > > - With the Batt & Avionics Master on, the manifold pressure > needle pegs when the radio xmit button is > pressed. Any ideas about what could be causing this? > Which MP gauge do you have? This appears to be a relatively common complaint with Van's MP gauge. It seems that it picks up radio frequency energy. I haven't seen a solution, other than not looking at the MP gauge when transmitting. > - With the Batt Master On, before engine start, the fuel > pressure gauge is at zero; as soon as I hit the > boost pump it climbs to around 30psi and stays there during > engine run (with the boost pump turned off) > What is normal fuel pressure for an engine with carburetor > with the engine running? (Can't find this > in my engine manual). Where in the fuel system are you measuring fuel pressure? If you have an O-360, with a Facet (Marvel Schebler) MA-4 or HA-6 series carb, the fuel pressure at the inlet to the carb should be between 0.5 and 8 psi. This info is from engine Type Certificate Data Sheet E-286, available on the FAA web site. > -- Kevin Horton RV-8 (FInal Assembly) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: May 21, 2008
In a message dated 05/21/2008 10:13:39 AM Central Daylight Time, panamared5(at)brier.net writes: Two seats for two pilots with two alternators and two batteries! Why not? "Cause I'm a two-seat (typically one-pilot), one alternator, one battery kinda pilot: Limited budget. No IFR. No question more redundancy is better when mission dictates, but design for the mission. And always understand the physics of whatever configuration you aviate with... Good discussion- Mark **************Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food. (http://food.aol.com/tyler-florence?video=4&?NCID=aolfod00030000000002) ________________________________________________________________________________
Subject: Battery, and radio problems update.
Date: May 21, 2008
Update, the new $80 batty realy kicks it over, like it, now have found out that radio, intercom and xponder all blown. I had a spare 76a bought on ebay 4 yrs ago we put it in and it works. KX125 had blown zener, dont know what problem is with xponder or icom yet. Hard to believe I totally ignore the red terminal and proceeded to hook up batty same as previous. Dum de dum dum----Dum. Charlie H ________________________________________________________________________________
Subject: re: pre flight problem
Date: May 22, 2008
Date: May 22, 2008
Subject: PreFlight Problems - Thanks Guys!!
Thanks to those who responded to my problems with high fuel pressure and the Manifold Press gauge which pegs when the radio is keyed. As usual, I did something dumb - there are two fuel gauges available from Van's; I ordered and Installed the one for an injected engine, which goes from 0-50 psi. The gauge needle is at the one o'clock position when the engine is running, which on the injected version of the gauge is 30 psi. From the picture in Van's catalog, one o'clock is about 8 psi on the carbureted version, just about right. With the manifold pressure gauge, I'm thinking Kevin Horton is right about Vans gauges being sensitive to RF energy. I'll fly with it the way it is for a while, then when I get time, I'll try John Fasching's solution. Thanks again fellow listers...... Walt Shipley ________________________________________________________________________________
Date: May 23, 2008
Subject: F I fuel pump for sale
Listers, I have a brand new (in the box) Carter electric fuel pump. This is the same fuel pump sold by Airflow Performance and Vans. This is ONLY the pump itself, without the manifold, pressure relief valve and check valve. I decided to save some money and buy/build the other parts myself. I built mine for about $250. I bought two extra pumps for my friends. However, one guy decided to use a carbureted engine and backed out. Airflow Performance sells the bare pump for $300. I'll sell this one for $180 plus shipping ($10-$16). I also have info on how to build the manifold and where to buy the valves. Contact me off list if interested. Charlie Kuss ________________________________________________________________________________
Subject: RE: RV-List Digest: 2 Msgs - 05/22/08
Date: May 23, 2008
Vans gauges suck for RF intolerance, I've thrown away about four of them. Of course Van's won't acknowledge there is a problem. please archive again and again ________________________________________________________________________________
Date: May 23, 2008
Subject: Garmin SL-30 For Sale
I had a customer change his mind on his panel from an SL-30 to an SL-40 so if anyone is in need of a factory new / still sealed and in the box SL-30 please call... Will include a 3' power/nav audio/comm audio/ptt harness.....$3500 -Bill VonDane ePanel Builder bill(at)epanelbuilder.com 719-266-2388 ________________________________________________________________________________
Date: May 23, 2008
Subject: Re: F I fuel pump for sale
Charlie, If you or anybody else knows a lot about these pumps, maybe I'm your buyer. I've got one in my RV that is about 4 yrs old with 300 hrs. About 50 hrs ago, I ran it inadvertantly for a few minutes with the fuel valve off. It may be my imagination, but it makes more noise now. No leaks, plenty of pressure but this may be a good time to replace it. I guess my question is, will a few minutes of running with a closed off suction damage these pumps? Greg On Fri, May 23, 2008 at 5:36 AM, Charles Kuss wrote: > > Listers, > I have a brand new (in the box) Carter electric fuel pump. This is the > same fuel pump sold by Airflow Performance and Vans. This is ONLY the pump > itself, without the manifold, pressure relief valve and check valve. > I decided to save some money and buy/build the other parts myself. I built > mine for about $250. I bought two extra pumps for my friends. However, one > guy decided to use a carbureted engine and backed out. > Airflow Performance sells the bare pump for $300. I'll sell this one for > $180 plus shipping ($10-$16). I also have info on how to build the manifold > and where to buy the valves. Contact me off list if interested. > Charlie Kuss > > ________________________________________________________________________________
Subject: How to Tell if You have ECI/Superior Cylinders
Date: May 23, 2008
I've had a few inquiries about whether or not customers' engines may be affected by the proposed Superior/ECI service bulletins. Some of you may not know which types of cylinders were used on your engine. If your engine builder provided you with a detailed parts list, you should be able to distinguish which manufacturer made your cylinders by reviewing the nomenclature. ECI Lycoming replacement cylinders have an AEL in front of them, and Superior Lycoming replacement cylinders have an SL. If you have purchased a kit engine from BPE, only Lycoming OEM cylinders were used. If your engine builder did not provide you a detailed parts list, you can easily identify which cylinders you have by looking at the rocker box boss above the exhaust port for the AEL, SL or Millenium insignia. Hope this information is helpful to at least some of you! Everyone have a safe and enjoyable holiday weekend! Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com ________________________________________________________________________________
Date: May 23, 2008
Greg The fuel in the pump actually lubricates the bearings and internal parts of the pump. I'm an auto mechanic by trade. I've seen pumps (in cars) make noise and yet runs for years after. However, a noisy pump is usually the first sign of a future failure. Charlie --- On Fri, 5/23/08, mr.gsun(at)gmail.com wrote: > From: mr.gsun(at)gmail.com <mr.gsun(at)gmail.com> > Subject: Re: RV-List: F I fuel pump for sale > To: rv-list(at)matronics.com > Date: Friday, May 23, 2008, 12:59 PM > Charlie, > If you or anybody else knows a lot about these pumps, maybe > I'm your buyer. > I've got one in my RV that is about 4 yrs old with 300 > hrs. About 50 hrs > ago, I ran it inadvertantly for a few minutes with the fuel > valve off. It > may be my imagination, but it makes more noise now. No > leaks, plenty of > pressure but this may be a good time to replace it. I > guess my question is, > will a few minutes of running with a closed off suction > damage these pumps? > Greg > > On Fri, May 23, 2008 at 5:36 AM, Charles Kuss > wrote: > > > > > > Listers, > > I have a brand new (in the box) Carter electric fuel > pump. This is the > > same fuel pump sold by Airflow Performance and Vans. > This is ONLY the pump > > itself, without the manifold, pressure relief valve > and check valve. > > I decided to save some money and buy/build the other > parts myself. I built > > mine for about $250. I bought two extra pumps for my > friends. However, one > > guy decided to use a carbureted engine and backed out. > > Airflow Performance sells the bare pump for $300. > I'll sell this one for > > $180 plus shipping ($10-$16). I also have info on how > to build the manifold > > and where to buy the valves. Contact me off list if > interested. > > Charlie Kuss > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Determining value of RV-6AQB kit for sale
Date: May 23, 2008
Hello All, I have searched the archives and not found the answer. I have someone interested in my RV-6AQB kit. It includes the tail, wing, and fuse kit but no finishing kit. I paid $17,800 for the kit plus shipping. Approx. 200 hours build time but lets assume no work has been done. If anyone can provide some insight on what would be a fair asking price, I would appreciate it! Thanks, David ________________________________________________________________________________
Date: May 23, 2008
Subject: Re: Determining value of RV-6AQB kit for sale
David, In 1999 I paid $17k for my QB kit second-hand. It included the finish kit and the empenage kit had been build (very nice job). QB kits from Vans were going for something like $25k at the time. Hope that helps as a data point. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Fri, May 23, 2008 at 2:23 PM, David wrote: > Hello All, > > > I have searched the archives and not found the answer. > > I have someone interested in my RV-6AQB kit. It includes > > the tail, wing, and fuse kit but no finishing kit. I paid $17,800 > > for the kit plus shipping. Approx. 200 hours build time but lets > > assume no work has been done. If anyone can provide some > > insight on what would be a fair asking price, I would appreciate it! > > > Thanks, > > David > > * > > * > > ________________________________________________________________________________
Date: May 23, 2008
David, Just another opinion. I sold my 50% completed RV-9a kit with instruments, prop but no engine for what I had purchased it all from Van's. Prices had gone up and I had paid some builder assistance dollars and of course freight costs. The buyer got a good deal because prices had gone up since I started on the kit 3 years back and quality was quite good. And I felt good about not losing out on my matl's costs. I figured my labor, freight & help were just part of my learning experience. I'm now flying a completed RV and very, very happy with my decision to buy and stop building. I have lots of build experience but with a better RV than I would have ended up with for ( I think) less money. Another Data Point. Greg On Fri, May 23, 2008 at 2:42 PM, David Leonard wrote: > David, > > In 1999 I paid $17k for my QB kit second-hand. It included the finish kit > and the empenage kit had been build (very nice job). QB kits from Vans were > going for something like $25k at the time. > > Hope that helps as a data point. > > -- > David Leonard > > Turbo Rotary RV-6 N4VY > http://N4VY.RotaryRoster.net > http://RotaryRoster.net > > > On Fri, May 23, 2008 at 2:23 PM, David wrote: > >> Hello All, >> >> >> >> I have searched the archives and not found the answer. >> >> I have someone interested in my RV-6AQB kit. It includes >> >> the tail, wing, and fuse kit but no finishing kit. I paid $17,800 >> >> for the kit plus shipping. Approx. 200 hours build time but lets >> >> assume no work has been done. If anyone can provide some >> >> insight on what would be a fair asking price, I would appreciate it! >> >> >> >> Thanks, >> >> David >> >> * >> >> * >> >> > > > * > > * > > ________________________________________________________________________________
Date: May 24, 2008
Subject: I will not quit
I had a week moment,,,, with a 2 year old QB-8 in the garage which I look at every day but had not worked much in about a year. I'd been busy with work and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the plane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly ________________________________________________________________________________
Date: May 24, 2008
Date: May 24, 2008
Subject: Re: I will not quit
I told my wife the only way my plane will not fly is if I die first. Build on! Dave Nellis 7A Slider-wings --- Dan wrote: > I had a week moment,,,, with a 2 year old QB-8 in > the garage which I look at every day but had not > worked much in about a year. I'd been busy with work > and life I had lost interest and motivation to get > back into the project. > I decided to sell it. > When my 11 year old daughter found out she was > astounded and asked a simple question "Why are you > going to quit? I thought you wanted to build the > plane" > > Simply put,, > never give up > > So I will build, and not just for me,, > > I went out dusted it off and built a simple > rewarding thing like build the front seat, > I'm back on a roll, in the grove, it will fly, > > Dan > Lake Stevens WA > -8 > Reserved N728RV > > I will never give up, it will fly > > ________________________________________________________________________________
Date: May 24, 2008
When I built my RV-6 there were no such things as quick built anything, I would look at all of the parts and it would be overwhelming. The secret is to just to try to do a little bit everyday, look at each task not as a whole. Pretty soon you well run out of things to do and well have to fly it. :-) Jerry First flight July 14 1989 and still loving it. Dan wrote: > I had a week moment,,,, with a 2 year old QB-8 in the garage which I > look at every day but had not worked much in about a year. I'd been > busy with work and life I had lost interest and motivation to get back > into the project. > I decided to sell it. > When my 11 year old daughter found out she was astounded and asked a > simple question "Why are you going to quit? I thought you wanted to > build the plane" > > Simply put,, > never give up > > So I will build, and not just for me,, > > I went out dusted it off and built a simple rewarding thing like build > the front seat, > I'm back on a roll, in the grove, it will fly, > > Dan > Lake Stevens WA > -8 > Reserved N728RV > > I will never give up, it will fly > > > ________________________________________________________________________________
Date: May 24, 2008
Dan Congrats on the new found desire........Since Sept 4, 2004 I have been work ing off and on on an RV7A.....Like you family, work, $$$$$$$$$$$$$$$$$$$, l ife's responsibilities have turned a 18 month project into a nearly 4 year project. I am now in the final 1000 last details and hope to fly by the end of this summer. Many well meaning folks have said why in the world would y ou keep going considering the cost, time commitment, frustration, and you n ame....(put negative reason to quit hear).....but I tell them I CAN'T...... "I would never feel good teaching my kids and grandkids that it is OK to gi ve up a worthy project"....... Dan I congratulate you on keeping your dream...and teaching moment....alive Frank @ 1L8...... RV7A......Last 992 details of which 9000 are fiberglass r elated............ Date: Sat, 24 May 2008 09:01:04 -0700From: dan(at)rdan.comSubject: RV-List: I will not quitTo: rv-list(at)matronics.com I had a week moment,,,, with a 2 year old QB-8 in the garage which I look a t every day but had not worked much in about a year. I'd been busy with wor k and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the pl ane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly ________________________________________________________________________________
Date: May 24, 2008
I agree with Jerry, Dan, focus on building a small piece as the goal of each "project" otherwise, the entire project just seems overwhelming. I tried to commit at least 2 hours each and every day - identified a specific accomplishment I wanted to achieve - even if it was just to measure the position for the next 10 rivet holes (yes, before the days of punched rivet holes {:>)) After 3 years (yes, I did average a bit more than 2 hours per day), but the thrill when I first flew it will always be remembered. The only thing I regret, is waiting until I was 56 years old before I started my dream. Don't lose you dream - stay with it. Best Regards Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html. ----- Original Message ----- From: "Jerry Springer" <jsflyrv(at)verizon.net> Sent: Saturday, May 24, 2008 12:51 PM Subject: Re: RV-List: I will not quit > > When I built my RV-6 there were no such things as quick built anything, I > would look at > all of the parts and it would be overwhelming. The secret is to just to > try to do a little bit everyday, > look at each task not as a whole. Pretty soon you well run out of things > to do and well have to fly > it. :-) > > Jerry > First flight July 14 1989 and still loving it. > > > Dan wrote: > >> I had a week moment,,,, with a 2 year old QB-8 in the garage which I look >> at every day but had not worked much in about a year. I'd been busy with >> work and life I had lost interest and motivation to get back into the >> project. >> I decided to sell it. >> When my 11 year old daughter found out she was astounded and asked a >> simple question "Why are you going to quit? I thought you wanted to >> build the plane" >> Simply put,, >> never give up >> So I will build, and not just for me,, >> I went out dusted it off and built a simple rewarding thing like build >> the front seat, >> I'm back on a roll, in the grove, it will fly, >> Dan >> Lake Stevens WA >> -8 >> Reserved N728RV >> I will never give up, it will fly >> >> >> >> >> > > > ________________________________________________________________________________
Date: May 24, 2008
Good for you Dan! A lesson for you and an example for your daughter. Plus, you will love the airplane when it is done. Allow me to make a few comments. Building an airplane was in my Bucket List since college. When I had doubts while building, I would think about my "regrets list" and was this going to be one of my life time regrets. Sometimes it was the knowledge that I would be sorry if I didn't complete it more than the desire to finish it that kept me going. Don't be discouraged when others ask "when is it going to fly". As others have pointed out, working consistently helps but work at your own pace so as to not let the airplane become an issue with you or at home. While building my 6A there were two periods when the project was not touched for a year or more because of other priorities. Building the airplane is one of my most cherished personal accomplishment. N728RV will be one of yours. Regards and best wishes with the project. Dale Ensing RV-6A N118DE Aero Plantation Weddington NC ----- Original Message ----- From: Dan To: rv-list(at)matronics.com Sent: Saturday, May 24, 2008 12:01 PM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look at every day but had not worked much in about a year. I'd been busy with work and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the plane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly ________________________________________________________________________________
Date: May 25, 2008
I have been working on my RV6 for almost 20 years... !! Moving around a lot... Having kids .... Work .... Do not give up ... I should have the wings done this year and the fuselage next year ... About 10 years ago someone wanted to buy the parts I had made ... no way would I sell ... it has taken a long time to get this far ... and no way will I give up ... So hang in there ... It will be great when it is done !! Best of luck !! Jan _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: 24 May 2008 20:39 Subject: Re: RV-List: I will not quit Good for you Dan! A lesson for you and an example for your daughter. Plus, you will love the airplane when it is done. Allow me to make a few comments. Building an airplane was in my Bucket List since college. When I had doubts while building, I would think about my "regrets list" and was this going to be one of my life time regrets. Sometimes it was the knowledge that I would be sorry if I didn't complete it more than the desire to finish it that kept me going. Don't be discouraged when others ask "when is it going to fly". As others have pointed out, working consistently helps but work at your own pace so as to not let the airplane become an issue with you or at home. While building my 6A there were two periods when the project was not touched for a year or more because of other priorities. Building the airplane is one of my most cherished personal accomplishment. N728RV will be one of yours. Regards and best wishes with the project. Dale Ensing RV-6A N118DE Aero Plantation Weddington NC ----- Original Message ----- From: Dan <mailto:dan(at)rdan.com> Sent: Saturday, May 24, 2008 12:01 PM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look at every day but had not worked much in about a year. I'd been busy with work and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the plane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.w3.org/TR/REC-html40">
I have been working on my RV6 for almost 20 years… !! Moving around a lot… Having kids …. Work …. Do not give up … I should have the wings done this year and the fuselage next year …
About 10 years ago someone wanted to buy the parts I had made … no way would I sell … it has taken a long time to get this far … and no way will I give up … So hang in there … It will be great when it is done !!
Best of luck !!
Jan
Dale Ensing
RV-6A N118DE
Aero Plantation
Weddington NC
Simply put,,
never give up
Dan
Lake Stevens WA
-8
Reserved N728RV
      t">http://www.matronics.com/Navigator?RV-List><
      /font>
href="http://www.matronics.com/contribution&quo
      t;>http://www.matronics.com/c>
Date: May 24, 2008
And I thought I was bad, working 12 years on my Glasair III. Bruce <
http://www.glasair.org/> www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jan Sent: Saturday, May 24, 2008 7:20 PM Subject: RE: RV-List: I will not quit I have been working on my RV6 for almost 20 years. !! Moving around a lot. Having kids .. Work .. Do not give up . I should have the wings done this year and the fuselage next year . ________________________________________________________________________________
Date: May 24, 2008
Dan, Great and touching story! Your daughter will someday look back with pride knowing that she has played a part of your decision to build on and realize your dream. This can only help to build her confidence to voice her opinion on important issues as she grows older. I built my "6" from '98 to '02 and I am enjoying it as much today as I did the first day we flew. It changes your life in many ways and it's inspiring to read your story. I too have another RV project in my shop that's collecting dust but now I'm charged up to get back to daily progress Ken Cantrell 720 hours _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Sent: Saturday, May 24, 2008 9:01 AM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look at every day but had not worked much in about a year. I'd been busy with work and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the plane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly ________________________________________________________________________________
Date: May 25, 2008
Date: May 25, 2008
Date: May 24, 2008
Jan And I thought my 3 plus years was bad....you are an inspiration Frank @ 1L8 ....RV7A ......final 992 details........... From: jan(at)claver.demon.co.ukTo: rv-list(at)matronics.comSubject: RE: RV-List: I will not quitDate: Sun, 25 May 2008 00:20:00 +0100 I have been working on my RV6 for almost 20 years=85 !! Moving around a lot =85 Having kids =85. Work =85. Do not give up =85 I should have the wings d one this year and the fuselage next year =85 About 10 years ago someone wanted to buy the parts I had made =85 no way wo uld I sell =85 it has taken a long time to get this far =85 and no way will I give up =85 So hang in there =85 It will be great when it is done !! Best of luck !! Jan From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Dale EnsingSent: 24 May 2008 20:39To: rv-list@matron ics.comSubject: Re: RV-List: I will not quit Good for you Dan! A lesson for you and an example for your daughter. Plus, you will love the airplane when it is done. Allow me to make a few comments. Building an airplane was in my Bucket List since college. When I had doubts while building, I would think about my "regrets list" and was this going t o be one of my life time regrets. Sometimes it was the knowledge that I wou ld be sorry if I didn't complete it more than the desire to finish it that kept me going. Don't be discouraged when others ask "when is it going to fly". As others h ave pointed out, working consistently helps but work at your own pace so as to not let the airplane become an issue with you or at home. While buildin g my 6A there were two periods when the project was not touched for a year or more because of other priorities. Building the airplane is one of my most cherished personal accomplishment. N728RV will be one of yours. Regards and best wishes with the project. Dale Ensing RV-6A N118DE Aero Plantation Weddington NC ----- Original Message ----- From: Dan Sent: Saturday, May 24, 2008 12:01 PM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look a t every day but had not worked much in about a year. I'd been busy with wor k and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the pl ane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly href="http://www.matronics.com/Navigator?RV-List">http://www.matronics .com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.ma tronics.comhref="http://www.matronics.com/contribution">http://www.matron ics.com/c ________________________________________________________________________________
From: "Reginald C. Smith, Sr." <smirdrv(at)hotmail.com>
Date: May 24, 2008
I started my 6A in '98, and am just now a ready for the Fuselage kit. I'd just about given up on being able to complete it (I turn 56 in June. So to here someone say they didn't start till that age takes away any excuse I ha d. The benefit is that I just completed Tail Wheel Transition training and now have my endorsement. So I think I'll build a '6' instead. Any thoughts on a 5ft 5in guy flying a taildragger? I checked with Van's and they say t his is the time to make the choice. Anyway, thank you Dan for setting me f ree from my dilemma. If any on knows of a Fuselage kit gathering dust anywh ere, let me know. R.C Building with new enthusiasm. From: fstringham(at)hotmail.comTo: rv-list(at)matronics.comSubject: RE: RV-List: I will not quitDate: Sat, 24 May 2008 20:19:17 -0600 Jan And I thought my 3 plus years was bad....you are an inspiration Frank @ 1L8 ....RV7A ......final 992 details........... From: jan(at)claver.demon.co.ukTo: rv-list(at)matronics.comSubject: RE: RV-List: I will not quitDate: Sun, 25 May 2008 00:20:00 +0100 I have been working on my RV6 for almost 20 years=85 !! Moving around a lot =85 Having kids =85. Work =85. Do not give up =85 I should have the wings d one this year and the fuselage next year =85 About 10 years ago someone wanted to buy the parts I had made =85 no way wo uld I sell =85 it has taken a long time to get this far =85 and no way will I give up =85 So hang in there =85 It will be great when it is done !! Best of luck !! Jan From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Dale EnsingSent: 24 May 2008 20:39To: rv-list@matron ics.comSubject: Re: RV-List: I will not quit Good for you Dan! A lesson for you and an example for your daughter. Plus, you will love the airplane when it is done. Allow me to make a few comments. Building an airplane was in my Bucket List since college. When I had doubts while building, I would think about my "regrets list" and was this going t o be one of my life time regrets. Sometimes it was the knowledge that I wou ld be sorry if I didn't complete it more than the desire to finish it that kept me going. Don't be discouraged when others ask "when is it going to fly". As others h ave pointed out, working consistently helps but work at your own pace so as to not let the airplane become an issue with you or at home. While buildin g my 6A there were two periods when the project was not touched for a year or more because of other priorities. Building the airplane is one of my most cherished personal accomplishment. N728RV will be one of yours. Regards and best wishes with the project. Dale Ensing RV-6A N118DE Aero Plantation Weddington NC ----- Original Message ----- From: Dan Sent: Saturday, May 24, 2008 12:01 PM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look a t every day but had not worked much in about a year. I'd been busy with wor k and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the pl ane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly href="http://www.matronics.com/Navigator?RV-List">http://www.matronics .com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.ma tronics.comhref="http://www.matronics.com/contribution">http://www.matron ics.com/c t=_blank>http://www.matronics.com/Navigator?RV-List p://forums.matronics.com blank>http://www.matronics.com/contribution _________________________________________________________________ Make every e-mail and IM count. Join the i=92m Initiative from Microsoft. t ________________________________________________________________________________
Date: May 24, 2008
Ed Booth at Twins Lakes SC is one of the best flying 65 year old RV 7 pilots I know and he is about 5'6". If I had 2 legs I would be building a 7 vs. a 7A. Its like training wheels, but at lest I'm flying. You only go around once unless you are a Buddhist, just do it. Good luck CJ Carl W Bell (CJ) Building RV 7A - N947CB http://www.mykitlog.com/carlbell carlbell(at)gforcecable.com _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Reginald C. Smith, Sr. Sent: Saturday, May 24, 2008 10:47 PM Subject: RE: RV-List: I will not quit I started my 6A in '98, and am just now a ready for the Fuselage kit. I'd just about given up on being able to complete it (I turn 56 in June. So to here someone say they didn't start till that age takes away any excuse I had. The benefit is that I just completed Tail Wheel Transition training and now have my endorsement. So I think I'll build a '6' instead. Any thoughts on a 5ft 5in guy flying a taildragger? I checked with Van's and they say this is the time to make the choice. Anyway, thank you Dan for setting me free from my dilemma. If any on knows of a Fuselage kit gathering dust anywhere, let me know. R.C Building with new enthusiasm. _____ From: fstringham(at)hotmail.com Subject: RE: RV-List: I will not quit Date: Sat, 24 May 2008 20:19:17 -0600 Jan And I thought my 3 plus years was bad....you are an inspiration Frank @ 1L8 ....RV7A ......final 992 details........... _____ From: jan(at)claver.demon.co.uk Subject: RE: RV-List: I will not quit Date: Sun, 25 May 2008 00:20:00 +0100 I have been working on my RV6 for almost 20 years. !! Moving around a lot. Having kids .. Work .. Do not give up . I should have the wings done this year and the fuselage next year . About 10 years ago someone wanted to buy the parts I had made . no way would I sell . it has taken a long time to get this far . and no way will I give up . So hang in there . It will be great when it is done !! Best of luck !! Jan _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: 24 May 2008 20:39 Subject: Re: RV-List: I will not quit Good for you Dan! A lesson for you and an example for your daughter. Plus, you will love the airplane when it is done. Allow me to make a few comments. Building an airplane was in my Bucket List since college. When I had doubts while building, I would think about my "regrets list" and was this going to be one of my life time regrets. Sometimes it was the knowledge that I would be sorry if I didn't complete it more than the desire to finish it that kept me going. Don't be discouraged when others ask "when is it going to fly". As others have pointed out, working consistently helps but work at your own pace so as to not let the airplane become an issue with you or at home. While building my 6A there were two periods when the project was not touched for a year or more because of other priorities. Building the airplane is one of my most cherished personal accomplishment. N728RV will be one of yours. Regards and best wishes with the project. Dale Ensing RV-6A N118DE Aero Plantation Weddington NC ----- Original Message ----- From: Dan <mailto:dan(at)rdan.com> Sent: Saturday, May 24, 2008 12:01 PM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look at every day but had not worked much in about a year. I'd been busy with work and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the plane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c t=_blank>http://www.matronics.com/Navigator?RV-List p://forums.matronics.com blank>http://www.matronics.com/contribution t=_blank>http://www.matronics.com/Navigator?RV-List p://forums.matronics.com blank>http://www.matronics.com/contribution _____ Make every e-mail and IM count. <_ MakeCount' target='_new'>Join the i?m Initiative from Microsoft. ________________________________________________________________________________
From: "Bob Perkinson" <bobperk90658(at)bellsouth.net>
Subject: Nose Dragger V Tail Dragger was (I will not quit)
Date: May 25, 2008
Date: May 25, 2008
In a message dated 05/24/2008 11:59:16 AM Central Daylight Time, jsflyrv(at)verizon.net writes: > When my 11 year old daughter found out she was astounded and asked a > simple question "Why are you going to quit? I thought you wanted to > build the plane" >>>>>>> I made an interesting observation when my slo-build RV-6A departed the Earth for the first time on January 31, 2004. Five years of hard-fought battles to construct and pay for that nekkid little newborn were behind me and became fond memories in my family album. What I witnessed being born that day was a future of new experiences flying my RV and becoming a "flying" part of the RV family. She finished kindergarten (Phase One). Beginning with my Dad, her & I shared RV grins with many passengers. Call it Elementary. After another year she was ready for paint and she got her High School diploma. Some additional work and her interior was finished. Grad School. She finally "debued" at Oshkosh, Sun&Fun etc. and gathered a few laurels. Yes, an RV is just a machine. Kinda. It's one you created. Don't neglect the other members of your family, but don't be deterred if one of them throws a curve ball at you every now and then. It's all worth it- you'll see... Mark _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) **************Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food. (http://food.aol.com/tyler-florence?video=4&?NCID=aolfod00030000000002) ________________________________________________________________________________
Date: May 25, 2008
Reginald - I am 5ft 5 and I fly my RV6. We set the left seat attach hinge a little further forward than the plans called for, and set the rudders as far aft as possible. I still needed cushions behind me during the first few hours of flying, but soon got used to it. I have a friend who is a few inches shorter than me and he flies the 6 with ease - just sticks a spare cushion behind him. He does need a little help with forward visoin while taxiing though! It took 7 years to complete our RV6 - maybe two years of that time the project was hardly touched for all the usual reasons. I got discouraged at times - especially when critics told me 'It will never fly'. May be it was the cirtics who stung me into wanting to prove them wrong! Shirley Harding RV6 over 70 hours now and loving it! ________________________________________________________________________________
Date: May 25, 2008
I know I am not the longest build time at 16 years but I can honestly say I never even considered giving up. I took long times away from the project to build a house or restore an airplane but I always kept going. Here is what I did. I had a big white board in my shop near the airplane. When I worked if I came upon something that I needed to remember to do I wrote it on the board. I had a full list on there and when I completed things I crossed it off. I did not erase them until I needed space or reworded the list. Whenever I went to the shop to putter I could see this list calling at me to knock something out. Many things on this list were only an hour task or less. If I only had an hour and hadn't worked on the plane for many weeks it took absolutely no time to just jump on something from the list. Without it I had spent the first hour of every session trying to figure out where to start and getting re-familiar with the project. Make yourself a big nagging list so you don't have to agonize over the whole project like others have said. You can focus on one little thing at a time. The number of years it takes will not matter one bit once you fly it. Good luck! Tim Bryan RV-6 Flying N616TB almost 100 hours now _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Sent: Saturday, May 24, 2008 11:01 AM Subject: RV-List: I will not quit I had a week moment,,,, with a 2 year old QB-8 in the garage which I look at every day but had not worked much in about a year. I'd been busy with work and life I had lost interest and motivation to get back into the project. I decided to sell it. When my 11 year old daughter found out she was astounded and asked a simple question "Why are you going to quit? I thought you wanted to build the plane" Simply put,, never give up So I will build, and not just for me,, I went out dusted it off and built a simple rewarding thing like build the front seat, I'm back on a roll, in the grove, it will fly, Dan Lake Stevens WA -8 Reserved N728RV I will never give up, it will fly ________________________________________________________________________________
Date: May 25, 2008
RC, I suggest you get more Tail Wheel time before making that decision. I received my TW endorsement which is a lot like your certification... a license to learn to fly. The TW endorsement for most people is not comprehensive enough to tell MOST people if they will like flying a TW everyday and in all flying conditions. I personally received excellent TW instruction before transitioning to my RV-4. After many hours I decided that the TW was not for me as I really prefer the A models. I sold my 4 and purchased a 6A and LOVE that decision. Now I don't want to start a TW/Nose Wheel war as this is a personal decision but I find the Vans A models absolutely the easiest planes to land "like butter"... almost every time and in almost all conditions. Part of my choice had to do with a regular commute that has me flying into a commercial airport. My first flying out of that place the lineup was 737, 737, RV-4, G550 and no the tower did not warn the G550 of wake turbulence. As there is a small possibility of a ground loop (even without damage) I did not want to be the one to close down the active runway even for a few minutes diverting commercial traffic. I am sure you will enjoy whatever choice you make and it is your plane and your dream I was just providing a personal data point. Robin RV-4 Sold RV-6A 425 hours RV-10 OSH 2008 a possibility www.painttheweb.com/rv-10 ________________________________________________________________________________
Date: May 25, 2008
Subject: Larger tires
I have mounted slightly larger main gear tires on my RV7A as well as a custom nose gear fork which accommodates a 500 - 5 wheel and tire. So far no negative issues have surfaced after several take-offs and landings with this modification. I have not fitted new wheel fairings yet. For those interested in what I did, see the photo story at: _http://mesawood.info/myrv7a/building/newgear.htm_ (http://mesawood.info/myrv7a/building/newgear.htm) Front page: _http://mesawood.info_ (http://mesawood.info) Bob Trumpfheller N67BT 84 hrs. **************Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food. (http://food.aol.com/tyler-florence?video=4&?NCID=aolfod00030000000002) ________________________________________________________________________________
Subject: building
Date: May 25, 2008
As a two point two-five time airplane builder with attention deficit disorder life is just a series of twenty minute projects. The goal isn't to build an airplane, that's just the bonus that comes at the end. The goal is to create, to master, to become better, to solve, to dream, in between twenty minute parts, about white puffy clouds drifting past as you pass over snowy craggy peaks, bright green terrain and yellow fields. Yet with one in the hangar that I can fly anytime I still dream between twenty minute parts. Who the hell cares when it'll be done? I am privileged to live in a special place that only builders know. That is why I do it. ________________________________________________________________________________
Subject: Re: building
Date: May 26, 2008
> Who the hell cares when it'll be done? I am privileged to live in a > special > place that only builders know. That is why I do it. Well said Wheeler! I secretly curse everyone who says "Built in x years!" when x is always way shorter than my build time (now 11 years). I often wonder what sacrifice they made to achieve that build time. Was it a wife, the children or was it life itself? Quite frankly the RV-6 is not my first priority but I have never lost an once of enthusiasm for it or for flying in the 11 years! It will be done! Doug Gray Panel done - now fitting canopy. ________________________________________________________________________________
Date: May 25, 2008
Amen Bro - Only in America (and some other English speaking countries). As a two point two-five time airplane builder with attention deficit disorder life is just a series of twenty minute projects. The goal isn't to build an airplane, that's just the bonus that comes at the end. The goal is to create, to master, to become better, to solve, to dream, in between twenty minute parts, about white puffy clouds drifting past as you pass over snowy craggy peaks, bright green terrain and yellow fields. Yet with one in the hangar that I can fly anytime I still dream between twenty minute parts. Who the hell cares when it'll be done? I am privileged to live in a special place that only builders know. That is why I do it. "No pressure, no diamonds". ~Thomas Carlyle ________________________________________________________________________________
Subject: Density Altitude Peformace
Date: May 25, 2008
Does anyone have any performance data for specific Density Altitudes. I know it would be aircraft specific but it would be useful as a WAG. I have been using a KOCH chart. Anyway I'm 180 HP with a cruise prop. But any data for other props might be useful. Thanks Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: May 25, 2008
Subject: Electric Trim Travel...?
Dear Listers, Working on my RV-4 electric trim, I don't seem to find anywhere where the actual UP and DOWN travel amounts for the trim tab are called out. I built the Mac Trim servo installation more or less per the plans, and I'm getting about 1" UP and 7/8" DOWN travel measured at the outboard end of the tab with respect to the trailing edge of the elevator. I've included a couple of pics for reference. With an O360 and CS Prop, will this be sufficient trim throw? Thanks for the help! Matt Dralle RV-4 N442RV ________________________________________________________________________________
Date: May 25, 2008
Subject: RV-8 N220ES FLIES!!
Just want everyone on the list, especially to the many who have helped out with answers to my questions, that my RV-8 flew for the first time on May 23rd. Very few problems (minor oil leak, rudder trim tab needed) Thanks again guys! Walt Shipley ________________________________________________________________________________
Date: May 25, 2008
Congrats Walt. It is a great feeling I am sure as I still remember. Tim Bryan RV-6 Flying N616TB almost 100 hours now > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of rveighta > Sent: Sunday, May 25, 2008 7:37 PM > To: rv-list(at)matronics.com > Subject: RV-List: RV-8 N220ES FLIES!! > > > Just want everyone on the list, especially to the many who have helped > out with answers to my questions, that my RV-8 flew for the first time on > May 23rd. Very few problems (minor oil leak, rudder trim tab needed) > Thanks again guys! > > Walt Shipley > > ________________________________________________________________________________
Subject: Full castoring nosewheel - Why not
Date: May 26, 2008
Folks, I'm in the process of installing a larger nosewheel fork on my 6A - kinda like Bob's recently unveiled craftsmanship. I am using a new fork made to fit the stock nosegear leg. In putting this together, I realized that the steering stop doesn't make full sense to me - especially when I will be pushing my plane back in to the hangar. I have seen other planes with full swivel nosewheels (Grumman's come to mind). Why not? Someone educate me! Ralph Capen ________________________________________________________________________________
Date: May 26, 2008
Subject: Re: Full castoring nosewheel - Why not
Prop strike. (prop vs nose wheel/fairing) -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction Ralph E. Capen wrote: > > Folks, > > I'm in the process of installing a larger nosewheel fork on my 6A - > kinda like Bob's recently unveiled craftsmanship. > > I am using a new fork made to fit the stock nosegear leg. > > In putting this together, I realized that the steering stop doesn't > make full sense to me - especially when I will be pushing my plane > back in to the hangar. > > I have seen other planes with full swivel nosewheels (Grumman's come > to mind). > > Why not? > > Someone educate me! > > Ralph Capen > > ________________________________________________________________________________
Date: May 26, 2008
Congrats Walt; I'm jealous! From: rveighta <rveighta(at)earthlink.net> Subject: RV-List: RV-8 N220ES FLIES!! Just want everyone on the list, especially to the many who have helped out with answers to my questions, that my RV-8 flew for the first time on May 23rd. Very few problems (minor oil leak, rudder trim tab needed) Thanks again guys! Walt Shipley glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: May 26, 2008
grummans caster 90 deg from center, prop strike target outherwise mike j. N9805u> From: recapen(at)earthlink.net> To: rv-list(at)matronics.com> Subject: RV -List: Full castoring nosewheel - Why not> Date: Mon, 26 May 2008 07:58:12 .net>> > Folks,> > I'm in the process of installing a larger nosewheel fork on my 6A - kinda > like Bob's recently unveiled craftsmanship.> > I am usi ng a new fork made to fit the stock nosegear leg.> > In putting this togeth er, I realized that the steering stop doesn't make > full sense to me - esp ecially when I will be pushing my plane back in to the > hangar.> > I have seen other planes with full swivel nosewheels (Grumman's come to > mind).> ========================> _ ===============> > > _________________________________________________________________ Give to a good cause with every e-mail. Join the i=92m Initiative from Micr osoft. ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Date: May 26, 2008
I started building my RV9a in Sept. of 2005 and I should be done on the 23rd., I just don't know what month or year! In 2005 I had 3 grandchildren and now I have five, I hoping one of them will catch the bug and be around to witness the first lift off from kpwc. Our two year old grandson was diagnosed with a rare form of cancer called Neuroblastoma at 6 months of age and he is Gramp's best helper in the shop. Life is a journey, so live it to the fullest, I take the Cardinal up if I have a little fuel money and love the freedom as I pass by those beautiful white clouds and laugh at the rest of the folks who aren't so lucky. For additional information about Logan's fight, please visit his website at www.caringbridge.org and enter the name "Logan Fogarty". I know many of you are going through many of the same types of challenges in life and it's not always easy to be in the shop, but for me it is all about the memories in aviation and family! Have a great day. Jim Fogarty fuselage ________________________________________________________________________________
Date: May 26, 2008
Not sure. On my plane however there would be interference between the forward wheel pant and gear leg fiberglass fairings. In practice I find pushing the plane backwards to not be a problem. Carl Froehlich RV-8A (400 hrs) RV-10 (flaps) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of MIKE JEFFERSON Sent: Monday, May 26, 2008 9:16 AM Subject: RE: RV-List: Full castoring nosewheel - Why not grummans caster 90 deg from center, prop strike target outherwise mike j. N9805u > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: RV-List: Full castoring nosewheel - Why not > Date: Mon, 26 May 2008 07:58:12 -0400 > > > Folks, > > I'm in the process of installing a larger nosewheel fork on my 6A - kinda > like Bob's recently unveiled craftsmanship. > > I am using a new fork made to fit the stock nosegear leg. > > In putting this together, I realized that the steering stop doesn't make > full sense to me - especially when I will be pushing my plane back in to the > hangar. > > I have seen other planes with full swivel nosewheels (Grumman's come to > mind). > > Why not? > > Someone educate me! > > > > _____ Give to a good cault.aspx?souce=EML_WL_ GoodCause' target='_new'>Join the
May 07, 2008 - May 26, 2008
RV-Archive.digest.vol-tm
