RV-Archive.digest.vol-tp
- - - , 20- - August 23, 2008
of date. excessive heat and time will screwup proseal still in the can.
since this is a quick build with only 5 hrs on it. i would be requesting two
new tanks since the other was probably built with the same bad proseal. and
a payment for the cost of painting. remember all of the material for the q
biuld are shipped ocean cargo to the pi. and without climate controlls on
the container. it is quite possible that the material saw in excess of 150
degrees inside the container.
please tell us what happens, if vans does not stand behind thier q builds it
might be a good time to have the local faa give them a chat.
i have repaired more of this type of tank then you can shake a stick at, so
call me if you have to do it yourself. be happy to help with advice.
ps
i am replacing the bonded doublers on a exec helicopter rotor blades right
now , it is my thought that the epoxy used was probably out of date and
failed as a result. having way to much fun removing it.
rick miller
559-270-7113
a+p, i/a
--- On Sun, 8/3/08, Doug Morrison <rv8a.doug@net-lynx.com> wrote:
Subject: | Re: Leaking QB Tanks |
Gentlemen,
This problem is not just related to the relatively new quick-build tanks.
Last week I found the same problem with one of the fuel tanks on an RV-4
(1993) I recently purchased. The previous owner (original builder) repaired
a small leak in the tank a few years ago and is very confident that the
pro-seal he applied was done correctly. We were both very surprised to find
most of the pro-seal on the lower portion of the tank soft and gooey. The
pro-seal on the upper portion of the tank is still hard. Another local
builder had the same problem with one of his -8 QB tanks. It appears that
this is a somewhat common problem on tanks that have been leaking for an
extended period of time. I found the following comments on another RV list:
The proseal on my lhs wing inner rib has gone totally sticky [can smear it
off with a finger] after flying with a leaking tank for 2 months. The wings
are quickbuilt and the inspection cover was leaking. Avgas has leaked onto
the factory applied proseal on the bottom of the inner rib. [just below the
cover]
I queried this with Vans and they said that the blue dye in avgas and oxygen
cause the proseal to soften. I cannot argue with them, but they couldnt
explain why this happened.
The proseal that did not have fuel leaking on it is ok.
I know I should have attended to the leak sooner, but flying was more
important at the time. Had I known I would have taken care of it sooner.
What I still dont understand is why the proseal went totally soft. Can
anyone explain ??
Gus at Vans said that there are no fuel fumes on the outside of the tank, so
as the fuel drips onto the proseal, it evaporates and leaves the blue dye
behind. This will lead to the proseal becoming soft and sticky and resembles
uncured proseal. At least this is how I understand it.
I asked how its possible because it is a fuel sealer, and he said they are
not quite sure.
Basically they say its my fault, [which I wont dispute as the inspection
cover had weeped fuel for 2 months] ,but i still would like a technical
explanation why this happened.[ie why the proseal softened]
Either way I have to sort it out.
It is the bead of proseal from the leading edge to the rear spar on the
outside of the inner rib that has gone soft.
I've seen this on a re-seal job that was done on our Cessna Cardinal. I
scraped it all out of our tanks and reapplied with new/good proseal. That is
NOT normal, don't believe Van's on this one.
Vans has been promising to speak to their supplier to get me the facts. I
have been patiently waiting for a answer ,but none yet. The clearly told me
they mixed it correctly and that it was my fault it went soft.[fuel shouldnt
leak on it]
I dont want to make a issue about it, but feel a bit short changed at the
moment. Vans has always been great about sorting out issues. I wonder why
they are avoiding this one ??
As I said before, if its my fault ,so be it. However everyone I speak to
says its not, and Vans doesnt seem to agree.
My plan is to gently scrape & wipe off the soft stuff, scratch up the
aluminum surface, and re-apply fresh pro-seal I purchased from Van's.
Doug Morrison
RV-4 (N818WW)
RV-8A (N666NJ Reserved) (In the process of converting to a -8)
Larry Pardue wrote:
"mailto:n5lp(at)warpdriveonline.com" \n
On Aug 3, 2008, at 3:09 PM, James H Nelson wrote:
"mailto:rv9jim(at)juno.com" \n
List:
I have a QB RV9-A and I have a leaking left tank. The unusual part is-
the pro seal is softening with the 100LL. On the spar end of the last
rib, the leak begins about half the way down and around the bottom and
almost to the leading edge. The pro seal is soft enough to act like
grease. You can wipe it from the aluminum skin. Not firm and stiff
like it is suppose to...Has any others had the same problem?
Exactly what happened to my quick-build tank. Pictures here HYPERLINK
"http:///" \nhttp:// HYPERLINK
"http://www.vansairforce.com/community/showthread.php?t=26159&highlight=seal
ant"
\nwww.vansairforce.com/community/showthread.php?t=26159&highlight=sealant
D========================
Checked by AVG.
12:00 PM
Checked by AVG.
12:00 PM
Subject: | Leaking QB Tanks |
I'm not disputing what you're saying, but it seems rather out of line for a
fuel sealer to not work with mogas. I'm sure lots of RVs are flying with
all or partial mogas.
I guess I'd better test this, as I plan to use mogas
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Sunday, August 03, 2008 9:12 PM
Subject: Re: RV-List: Leaking QB Tanks
Any chance mogas was used in any of these tanks? I've seen Proseal reduced
to jelly/peanut butter by mogas.
Doug Morrison wrote:
> Gentlemen,
> tanks. Last week I found the same problem with one of the fuel tanks
> on an RV-4 (1993) I recently purchased. The previous owner (original
> builder) repaired a small leak in the tank a few years ago and is very
> confident that the pro-seal he applied was done correctly. We were
> both very surprised to find most of the pro-seal on the lower portion
> of the tank soft and gooey. The pro-seal on the upper portion of the
> tank is still hard. Another local builder had the same problem with
> one of his -8 QB tanks. It appears that this is a somewhat common
> problem on tanks that have been leaking for an extended period of
> smear it off with a finger] after flying with a leaking tank for 2
> months. The wings are quickbuilt and the inspection cover was leaking.
> Avgas has leaked onto the factory applied proseal on the bottom of the
> inner rib. [just below the cover] I queried this with Vans and they
> said that the blue dye in avgas and oxygen cause the proseal to
> soften. I cannot argue with them, but they couldnt explain why this
> happened.
> anyone explain ??
> tank, so as the fuel drips onto the proseal, it evaporates and leaves
> the blue dye behind. This will lead to the proseal becoming soft and
> sticky and resembles uncured proseal. At least this is how I
> understand it.
> are not quite sure.
> inspection cover had weeped fuel for 2 months] ,but i still would like
> a technical explanation why this happened.[ie why the proseal
> softened] Either way I have to sort it out.
> the outside of the inner rib that has gone soft.
> I scraped it all out of our tanks and reapplied with new/good proseal.
> That is NOT normal, don't believe Van's on this one.
> facts. I have been patiently waiting for a answer ,but none yet. The
> clearly told me they mixed it correctly and that it was my fault it
> went soft.[fuel shouldnt leak on it] I dont want to make a issue about
> it, but feel a bit short changed at the moment. Vans has always been
> great about sorting out issues. I wonder why they are avoiding this
> one ??
> to says its not, and Vans doesnt seem to agree.
> Regards,
> Doug Morrison
> RV-4 (N818WW)
>>> List:
>>> is-
>>> last rib, the leak begins about half the way down and around the
>>> bottom and almost to the leading edge. The pro seal is soft enough
>>> to act like grease. You can wipe it from the aluminum skin. Not
>>> firm and stiff like it is suppose to...Has any others had the same
problem?
>> Exactly what happened to my quick-build tank. Pictures here http://
>> nt
Checked by AVG.
12:00 PM
Checked by AVG.
12:00 PM
From: | "Dale Ensing" <densing(at)carolina.rr.com> |
John,
I think you mean polysulfide not polysulfate.
Dale Ensing
----- Original Message -----
To: rv-list(at)matronics.com
Sent: Monday, August 04, 2008 10:33 AM
Subject: RE: RV-List: Leaking QB Tanks
Repeating something posted a long time ago. ProSeal is a trademarked nam
e and is often generically used in conversation to identify tank sealant(mu
ch like Scotch Tape or Kleenex). The product is PolySulfate Thixotrophic.
Most of the stuff Van's sells is sealant but is not ProSeal. ProSeal come
s in scores of product viscosities of A, B and C and various temperature an
d adhesion formulations (which are numbered).
When Kelly mentions proseal turning to putty, it was probably Flamemaster
and was not formulated for MOGAS. I am confident I can find a Desoto "Pro
Seal" T which can withstand MOGAS. I will do some research and do a trial
on the stuff.
There has been poor reporting on what products will hold up to MOGAS.
Fixing a leaking tank is a serious enough issue to get to the root and re
mediate.
John Cox
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@mat
ronics.com] On Behalf Of Doug Morrison
Sent: Sunday, August 03, 2008 7:37 PM
List,
I'll use Richard's message to answer his and John's, Kelly's, & Kevin's.
Remember the comment in red below are from a Vansairforce.net thread. They
are not my comments.
1) Use of a plastic scraper and MEK to remove the soft pro-seal sounds li
ke a good idea.
2) I am fairly confident that oil additives and mogas have never been use
d in my -4 (circa 1993) or my friends -8 QB. The only commonality is that t
he tanks were leaking for an extended period of time.
3) The previous owner of my -4 is fairly confident that the pro-seal he u
sed was fresh and mixed in the proper ratio.
4) The pro-seal on the QB tanks of the -8A I have under construction is f
ull cured. Only time will tell if the pro-seal will soften up when exposed
to fuel in the tank.
5) I am very satisfied with the workmanship of my -8A QB. If the tanks be
gin to leak due to outdated pro-seal used at the time of manufacturer, I wi
ll fix the problem and move on. Of course I will advise Van's of the proble
m so they can revise their manufacture procedure and hopefully prevent the
problem in the future. To be safe, I will probably fill the tanks with fuel
(with the tanks off the wing) and let them sit for a few months before I b
egin painting and final assembly. Any leaks or pro-seal softening should sh
ow up during that time.
As far as I am concerned, the -8A kit is a real bargain, even with the in
evitable anomalies. Each of you will have to decide if you want to press th
e issue with Van's. Personally, I am prepared to accept a few minor problem
s and just move on. Also, getting the FAA involved would be the last thing
I would do.
Thanks for everyone's comments.
Doug Morrison
RICHARD MILLER wrote:
proseal applied and cured per the spec does not disolve with 100ll.
so what happened.
are you using marvel mystry oil. or any other fuel additive.
if not i would have to think that the proseal was stored improperl
y or out of date. excessive heat and time will screwup proseal still in th
e can. since this is a quick build with only 5 hrs on it. i would be reques
ting two new tanks since the other was probably built with the same bad pro
seal. and a payment for the cost of painting. remember all of the material
for the q biuld are shipped ocean cargo to the pi. and without climate cont
rolls on the container. it is quite possible that the material saw in exces
s of 150 degrees inside the container.
builds it might be a good time to have the local faa give them a chat.
k at, so call me if you have to do it yourself. be happy to help with advic
e.
ps
s right now , it is my thought that the epoxy used was probably out of date
and failed as a result. having way to much fun removing it.
rick miller
559-270-7113
a+p, i/a
Date: Sunday, August 3, 2008, 4:41 PM
Gentlemen,
d tanks. Last week I found the same problem with one of the fuel tanks on a
n RV-4 (1993) I recently purchased. The previous owner (original builder) r
epaired a small leak in the tank a few years ago and is very confident that
the pro-seal he applied was done correctly. We were both very surprised to
find most of the pro-seal on the lower portion of the tank soft and gooey.
The pro-seal on the upper portion of the tank is still hard. Another local
this is a somewhat common problem on tanks that have been leaking for an ex
smear it off with a finger] after flying with a leaking tank for 2 months.
The wings are quickbuilt and the inspection cover was leaking. Avgas has l
eaked onto the factory applied proseal on the bottom of the inner rib. [jus
t below the cover]
and oxygen cause the proseal to soften. I cannot argue with them, but they
couldnt explain why this happened.
more important at the time. Had I known I would have taken care of it soone
r.
. Can anyone explain ??
he tank, so as the fuel drips onto the proseal, it evaporates and leaves th
e blue dye behind. This will lead to the proseal becoming soft and sticky a
nd resembles uncured proseal. At least this is how I understand it.
they are not quite sure.
pection cover had weeped fuel for 2 months] ,but i still would like a techn
ical explanation why this happened.[ie why the proseal softened]
on the outside of the inner rib that has gone soft.
nal. I scraped it all out of our tanks and reapplied with new/good proseal.
facts. I have been patiently waiting for a answer ,but none yet. The clearl
y told me they mixed it correctly and that it was my fault it went soft.[fu
d at the moment. Vans has always been great about sorting out issues. I won
der why they are avoiding this one ??
peak to says its not, and Vans doesnt seem to agree.
the aluminum surface, and re-apply fresh pro-seal I purchased from Van's.
Doug Morrison
RV-4 (N818WW)
Larry Pardue wrote:
.com>
List:
rt is-
last
m and
ike
tiff
// www.vansairforce.com/community/showthread.php?t=26159&highlight=seal
ant
href="3D%22http://www.matronics.com/Navigator?RV-List%22">http://www.m
http://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.comhttp
://www.matronics.com/contribution
John,
What I was writing about was an older Mooney that had an older product
number ProSeal used in the 1961-mid-seventies models before they
switched to the current product numbers. I would agree that it wasn't
formulated for mogas, as there was little incentive to use mogas when it
only cost 20-30 cents less than 80/87 or 100/130. That version was pink
in color, with a reddish brown top coat. Most of the current product
I've seen is gray in color(after mixing).
I'm sure that current variety is much more resistant, as they had to
formulate to resist high aromatic concentrations that most gasoline
formulas, av or mo have in them today. I'm as mystified as the rest on
the problem these quick build tanks are showing.
Kelly
> name and is often generically used in conversation to identify tank
> sealant(much like Scotch Tape or Kleenex). The product is PolySulfate
> Thixotrophic. Most of the stuff Van's sells is sealant but is not
> ProSeal. ProSeal comes in scores of product viscosities of A, B and C
> and various temperature and adhesion formulations (which are numbered).
> Flamemaster and was not formulated for MOGAS. I am confident I can
> find a Desoto "ProSeal" ^(TM) which can withstand MOGAS. I will do
> some research and do a trial on the stuff.
> remediate.
> John Cox
My only experience with aircraft tanks is Ercoupes. In that world they can
be sloshed or welded. More and more are getting them welded to avoid any
problems with sealant. Is that feasible with RV tanks?
Ralph Finch
Davis, CA
No sir -
RV tanks are skinned with 2024-T3.
Not a weldable alloy.
neal
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph Finch
Sent: Monday, August 04, 2008 7:46 PM
Ralph Finch
Davis, CA
Subject: | RV Fly-In (M54) Lebanon,Tn |
Just to inform every one that we are having again this year our RV
Fly-In
at M54 Lebanon,Tn which is about 20 miles east of Nashville,Tn..Sept
20th
and Mike Seager will be here again Sept 19,20,and 21st with the RV7....
You can E-Mail me and I will try to put you on the list...There are 6
slots a day
and some are gone already...
John McMahon (RV6 180/CS)
Subject: | Ramona, CA RV-6A N51LW for sale |
Socal RVators-
Does anyone have intimate knowledge of this plane based at Ramona, CA?
Apparently it was finished by Leonard Wilhelm in 1994 in Kansas and it is now
owned by Neal Farinholt My Cessna 140 flying buddy is interested and we would
like to know if this plane is a good quality construct, before we make the
trip down there to see for ourselves.
Please respond to me directly.
_vanremog(at)aol.com_ (mailto:vanremog(at)aol.com)
N1GV (RV-6A, Flying 898hrs, O-360-A1A, C/S, Silicon Valley)
**************Looking for a car that's sporty, fun and fits in your budget?
Read reviews on AOL Autos.
(http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 )
Tim,
I got my response from Van's and it is the same. The accumulated
dye, from evaporation, causes the break down of the sealant when it is
exposed to oxygen from the leaks. Having been in the chemical industry
(sort of) the dye's that are used are often oil based. I was confused
on the first indications of the "blue stuff". It felt like grease and
acted like it. Now, having stood back from the problem, the
accumulation of dye can have a degrading effect on the "Proseal". My
previous aircraft have all used mogas so I was not in the "blue" mode
when the leaks occurred. I now have to remove the cover and put some new
Proseal inside to stop the leaks. Van's also reminded me to use Proseal
on the cover and a bit on the screws to seal it back up. Van's does not
use the cork gaskets on their planes. Just enough to squeeze out upon
tightening the screws. Not squeezed enough to get cover to tank contact.
They say that if you need to remove the cover, the ole putty knife will
'POP' it off.
Jim
Looking for insurance? Click to compare and save big.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3m275YMXfHXPsBxyocOYnO6M0VzgrhIdNYeInezT2i1AOgtF/
I had to remove both fuel senders and reseal so am testing for integrity. The instructions
for testing with a manometer are saying either 2 to 3 inches diff
in water levels or 2 feet 3 inches, can't tell which. Before bothering Van's and
displaying my ignorance anyone here know the answer for sure? I'd rather not
blow my tanks apart, ya know...
Thanks all,
Jerry
Oh, BTW... I would never, repeat NEVER use the supplied rubber gaskets again.
I could not figure out why I'd never get a drip on the hangar floor but mysterious
fuel streaks down the belly. My hangar mate pointed out that at speed the
fuel vents can slightly pressurize the tanks. Fact or fiction? You decide. I took
senders out, slathered proseal and replaced. Hopefully fixed.
Edit/Delete Message
http://forums.matronics.com/viewtopic.php?p=196662#196662
Hi Brian,
I guess there should be an item on our check list to put fuel in
the tanks (100LL) for about a week prior to close up and check for leaks.
That way we find any leaks and can stop the exposure of the Proseal to
the dye on the outside of the tank. The tank only needs to have enough
fuel to cover the root rib. Then leaks can be found before you put the
wings on.
Jim
N15JN
Click here to find a massage therapy school near you.
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3l9deVZIrV8iEpet2FyycrmxVUDl3rErcmB92aT7o5tABXtB/
Subject: | BooHoo - Trim Tab Alignment... |
Listers,
Well, the trim tab came out perfect and I'm really pleased with the
mating to the Elevator. That being said, I'm less than pleased with
the for/aft alignment of the Trim Tab. The Trim Tab hangs past the
Elevator trailing edge by about 1/8" of an inch. It is 1/8" along
the whole distance of the Trim Tab. In looking at the cause, it
appears that the skins are all cut such that you are suppose to use
the roundy part of the hinge and not the square cutout when aligning
the hinge for drilling. This would account for 1/16" on each side
and would add up to the 1/8" overhang I'm seeing. Grrrrrr....
What should I do, fellow builders? I could drill out all the rivets
and use a new hinge, and I'm certainly not opposed to that. But am I
making too big a deal out of the whole thing? Or is everyone gonna
look at it forever and go, "Hey, how come your trim take is too long?" :-(
Bummed Out in Livermore
Matt
RV-8 #82880
Hi Bummed out in Livermore,
> server(at)matronics.com] On Behalf Of Matt Dralle
> Sent: Tuesday, August 05, 2008 2:56 PM
> Subject: RV-List: BooHoo - Trim Tab Alignment...
> Listers,
[Tim]
I wouldn't probably even notice. Do you have the intended hinge pin in
there?
It looks like there is not an alignment of the loops between the two
halves as
If you had a skinny hinge pin in. Would be easy enough to change the hinge
if
you felt the need, but it wouldn't be noticeable to me. If this was the
worse of
your sins when it was all said and done, it would be a champion.
Tim Bryan
RV-6 Flying
N616TB over 100 hours now
From: | "Alden D. Van Winkle" <dvanwinkle(at)royell.org> |
Subject: | Re: Tank Testing |
Jerry
The differential is 2 ft 3 inches which equates to approx one PSI. This is
what I used for my RV-9A tanks and worked very well. Even with one PSI, you
will see a small amount of skin deflection between the tank ribs while
pressurized. Also be aware that the differential is very sensitive to
temperature changes, even if you have no leaks.
Dean Van Winkle
Sent: Tuesday, August 05, 2008 11:52 AM
Subject: RV-List: Tank Testing
The instructions for testing with a manometer are saying either 2 to 3
inches diff in water levels or 2 feet 3 inches, can't tell which. Before
bothering Van's and displaying my ignorance anyone here know the answer for
sure? I'd rather not blow my tanks apart, ya know...
> Thanks all,
> Jerry
again.
mysterious fuel streaks down the belly. My hangar mate pointed out that at
speed the fuel vents can slightly pressurize the tanks. Fact or fiction? You
decide. I took senders out, slathered proseal and replaced. Hopefully fixed.
> Edit/Delete Message
Are you sure you've got the right size pin in there? The loops don't look
like they align right. After that, just set it aside until the end of the
project and then see how you feel about it. It's pretty minor and your F-it
factor changes over time;-)
Greg Young
> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle
> Listers,
> with the mating to the Elevator. That being said, I'm less
> than pleased with the for/aft alignment of the Trim Tab. The
> Trim Tab hangs past the Elevator trailing edge by about 1/8"
> of an inch. It is 1/8" along the whole distance of the Trim
> Tab. In looking at the cause, it appears that the skins are
> all cut such that you are suppose to use the roundy part of
> the hinge and not the square cutout when aligning the hinge
> for drilling. This would account for 1/16" on each side and
> rivets and use a new hinge, and I'm certainly not opposed to
> that. But am I making too big a deal out of the whole thing?
> Or is everyone gonna look at it forever and go, "Hey, how
> Matt
> RV-8 #82880
You better have a quality regulator to ensure you only put one PSI in the
tank. You can damage the tank with three PSI.
From: "Alden D. Van Winkle" <dvanwinkle(at)royell.org>
Sent: Tuesday, August 05, 2008 3:52 PM
Subject: Re: RV-List: Tank Testing
> Jerry
> is
> you
> Dean Van Winkle
> From: "Jerry Cochran" <jerry2dt(at)aol.com>
> To:
> for
>> Thanks all,
>> Jerry
> again.
> You
> fixed.
>> Edit/Delete Message
From: | "Michael D. Cencula" <matronics(at)cencula.com> |
Jerry,
Here's some info on testing the tanks...including the relationship
between temperature and pressure:
http://www.our7a.com/20070911.html
Good luck!
instructions for testing with a manometer are saying either 2 to 3 inches diff
and displaying my ignorance anyone here know the answer for sure? I'd rather
> Thanks all,
> Jerry
> Edit/Delete Message
From: | "John Fasching" <n1cxo320(at)salidaco.com> |
Subject: | Re: BooHoo - Trim Tab Alignment... |
That's so minor that you are the only one that will ever notice it.
Functionally it makes no difference whatever. Keep it as is, continue
building and if it really bugs you change it after you get the plane in the
air....some things are not worth fretting about, and this seems to one of
them.
From: | "Timothy E. Cone" <tcone1(at)comcast.net> |
STOP!!!! Do not hook your tank up to ANY pressure source...I don't care
what kind of regulator you have. Fuel tanks and compressed gasses do not go
together.
Sent: Tuesday, August 05, 2008 3:34 PM
> To:
>> Jerry
>> is
>> you
>> Dean Van Winkle
>> To:
>>> integrity.
>> for
>>> Thanks all,
>>> Jerry
>> again.
>> at
>> You
>> fixed.
>>> Edit/Delete Message
>>> Read this topic online here:
Matt,
You did an excellent job. I've redone several things on my RV-6A QB and am still
not flying after 8 years. As I tell my friends, I strain at knats and swallow
camels.
I would press on with the next step.
Ron Burnett
---- Matt Dralle wrote:
Listers,
Matt
RV-8 #82880
Matt,
Looks good. Don't dwell on the small stuff you will never get done.
Mike Ice
RV-9, DAR inspection this weekend, test flight soon after
Date: Tuesday, August 5, 2008 11:57 am
> Listers,
> the
> with
> the
> use
> aligning
> rivets
> am I
> gonna
> long?" :-(
> Matt
> RV-8 #82880
Subject: | Another Fuel Question |
I have a strong fuel odor in the cabin of my new RV8 which occurs only during
climb attitude. Straight and level, descending and on the ground, there's no gas
odor. I've gone over the entire fuel system (wing tanks, vent system, fuel
selector valve, boost pump connections, gascolator, fuel pressure transducer,
carb connections, mechanical pump connections, etc). I've found a few very small
"weeping" connections which have been corrected, but the fuel smell is still
there. I have also checked for blue streaks throughout the plane and don't see
any.
Any help with this annoying problem will sure be appreciated.
Walt Shipley
Hi Matt how you doing?
BTW the trim is very seldom aligned perfectly when you are parked so
most likely we would
have never known except now you have told us. :-)
Jerry
Matt Dralle wrote:
> Listers,
> Elevator trailing edge by about 1/8" of an inch. It is 1/8" along the
> whole distance of the Trim Tab. In looking at the cause, it appears
> that the skins are all cut such that you are suppose to use the roundy
> part of the hinge and not the square cutout when aligning the hinge
> for drilling. This would account for 1/16" on each side and would add
> long?" :-(
> Matt
> RV-8 #82880
Thanx Dean,
Using 27" overnite as we speak. Lookinf good so far...
Jerry
In a message dated 8/5/2008 1:55:30 P.M. Pacific Daylight Time,
dvanwinkle(at)royell.org writes:
Jerry
Dean Van Winkle
From: | Charlie England <ceengland(at)bellsouth.net> |
> These are not type-certificated aircraft, so FAR 39 (Airworthiness
> Directives) does not apply. If the local FAA wanted to talk to Van's
> about this, which FAR subparagraph should they discuss?
> Kevin Horton
> RV-8 (FInal Assembly)
> Ottawa, Canada
> http://www.kilohotel.com/rv8
Agreed on the legal points, but isn't the stuff Van supplies FAA
approved for type-cert aircraft? I'm torn between being astounded and
not surprised at all that the FAA would have nothing to say about an
approved sealant that is dissolved by one of the components that it's
certified to seal against.
For each RV with a minor fuel leak expanding into a major one, there
would be hundreds if not thousands of type cert a/c with the same issue.
Hey Walt=2C
I had a similar thing=2C found a loose and weeping screw in the fuel sender
access plate. Good luck=2C
Paul Rice
RV8
Flying Siren> Date: Tue=2C 5 Aug 2008 20:50:50 -0400> From: rveighta@earthl
ink.net> To: rv-list(at)matronics.com> Subject: RV-List: Another Fuel Question
climb attitude. Straight and level=2C descending and on the ground=2C there
's no gas odor. I've gone over the entire fuel system (wing tanks=2C vent s
ystem=2C fuel selector valve=2C boost pump connections=2C gascolator=2C fue
l pressure transducer=2C carb connections=2C mechanical pump connections=2C
etc). I've found a few very small "weeping" connections which have been co
rrected=2C but the fuel smell is still there. I have also checked for blue
streaks throughout the plane and don't see any. > > Any help with this anno
Subject: | Engine 'first' start |
Folks,
My list of things to do before engine start is getting small and I think it is
time to consider letting the dragon breathe some fire.....
I have an Aerosport Power IO360B1F6 (AFP injection, LASAR mags) with a MT three
blade prop.
I have the Lycoming manual page for their cold engine start procedures and I have
incorporated that in to my engine cold start checklist:
Alt air - off
Prop - high RPM
Fuel valve - select tank
Purge valve - run
Master - on
Fuel boost pump - on
Throttle - full open
Mixture - rich until fuel flow is noted on guage
Throttle - Idle
Mixture - lean
Fuel boost pump - off
Throttle to 1/4
Clear prop
Ignition switch - START
Mixture - to rich smoothly while cranking
Ignition switch - both when engine fires
Have any of you found that you need to deviate from these instructions in order
to get consistent starts?
Thanks for any input,
Ralph
No, but make sure you remove a top plug from each cylinder and crank the
engine until you get an oil pressure reading before your first start.
Bruce
www.Glasair.org
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen
Sent: Wednesday, August 06, 2008 9:14 AM
Subject: RV-List: Engine 'first' start
Folks,
is time to consider letting the dragon breathe some fire.....
three blade prop.
have incorporated that in to my engine cold start checklist:
Alt air - off
Prop - high RPM
Purge valve - run
Master - on
Throttle - Idle
Mixture - lean
Throttle to 1/4
Clear prop
order to get consistent starts?
Ralph
Thanks Bruce - I have done that - although my intent was to make sure there were
no obvious oil leaks - I got an oil pressure reading for 'free'.......
>From: Bruce Gray <Bruce(at)glasair.org>
>Sent: Aug 6, 2008 9:40 AM
>Subject: RE: RV-List: Engine 'first' start
>Bruce
>www.Glasair.org
>To: rv-list; lycoming engine list
>Folks,
>three blade prop.
>Alt air - off
>Prop - high RPM
>Purge valve - run
>Master - on
>Throttle - Idle
>Mixture - lean
>Throttle to 1/4
>Clear prop
>Ralph
Subject: | Re: Engine 'first' start |
Not sure if you mean for all cold starts, or just your very first start.
If it is for routine cold starts, you could eliminate some steps. Unless
the AFP operates very different from the RSA, throttle position has
nothing to do with priming. Just running rich mixture until fuel flow
probably isn't enough prime. I use 5 seconds or more of boost pump on my
IO-360 powered Mooney.
One other hint. Let the engine sit for 30-60 seconds after you prime it
before you crank. Lets the liquid fuel become vapor.
I don't know, but suspect the purge valve does nothing on a cold engine.
I think you will find that you can eliminate some of your items, as they
will always be in the correct position from shutdown.
Hot starts.........that's another discussion.
If it is your very first start...as suggested, leave 4 plugs out, and
crank engine until you have good oil pressure. Then put plugs back in,
and do normal cold start.
Ralph E. Capen wrote:
> Folks,
blade prop.
> Alt air - off
> Prop - high RPM
> Purge valve - run
> Master - on
> Throttle - Idle
> Mixture - lean
> Throttle to 1/4
> Clear prop
> Ralph
You want to do it no longer than 30 minutes before your first ever engine
start.
Bruce
www.Glasair.org
Sent: Wednesday, August 06, 2008 9:58 AM
were no obvious oil leaks - I got an oil pressure reading for 'free'.......
>the engine until you get an oil pressure reading before your first
>start.
>Bruce
>www.Glasair.org
>Folks,
>think it is time to consider letting the dragon breathe some fire.....
>MT three blade prop.
>and I have incorporated that in to my engine cold start checklist:
>Alt air - off
>Prop - high RPM
>Purge valve - run
>Master - on
>Throttle - Idle
>Mixture - lean
>Throttle to 1/4
>Clear prop
>in order to get consistent starts?
>Ralph
Good point - I'll do it again right before I do the first start.....
>Sent: Aug 6, 2008 10:37 AM
>start.
>Bruce
>www.Glasair.org
>>start.
>>Bruce
>>www.Glasair.org
>>Folks,
>>Alt air - off
>>Prop - high RPM
>>Purge valve - run
>>Master - on
>>Throttle - Idle
>>Mixture - lean
>>Throttle to 1/4
>>Clear prop
>>Ralph
After it starts, what's your intention? I assume it needs to be broken in,
and the various procedures I've seen don't include much ground time running.
Ralph Finch
Sent: Wednesday, August 06, 2008 6:14 AM
Folks,
three blade prop.
Ralph,
You're correct, it only has a few hours on it from the factory running. I'm only
planning to check for leaks and make sure both mags are firing properly - won't
be much ground running time right from the get go.
I still need to season the brakes with a couple of taxi runs and make sure I can
get fuel flow for climbout time at climbout attitude - I'm thinking that the
fuel flow can be done by pointing the nose at climbing attitude and running the
boost pump - shouldn't need the engine running.
More thoughts.....
Ralph
>From: Ralph Finch <rgf(at)dcn.davis.ca.us>
>Sent: Aug 6, 2008 12:11 PM
>Ralph Finch
>Folks,
>three blade prop.
Wally Anderson (Synergy Air) made a presentation about pre first flight inspections
at OSH. He disconnected the fuel line and measured how much fuel he could
get in x amount of minutes. He stated that is how he ensured that there wasn't
fuel starvation on the first flight and to ensure there wasn't any debris
in the fuel line.
> From: "Ralph E. Capen" <recapen(at)earthlink.net>
> Date: 2008/08/06 Wed AM 11:35:53 EST
> Ralph,
only planning to check for leaks and make sure both mags are firing properly -
won't be much ground running time right from the get go.
can get fuel flow for climbout time at climbout attitude - I'm thinking that the
the boost pump - shouldn't need the engine running.
> More thoughts.....
> Ralph
> >Ralph Finch
> >Folks,
> >three blade prop.
During first start plan to have someone stand watch with fire extinguisher
handy looking for oil and gas leaks, smoke or fire. Watch the observer and
have hand signals for emergency shut down.
Dale
> More thoughts.....
> Ralph
I would print on it in small print:
"If you noticed this little booboo, keep it to yourself"
Cecil
writes:
> Listers,
> I
> long?" :-(
> Matt
> RV-8 #82880
Best selection of Bibles. Click Now
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3nhMWQH4MJ1dXNUgbcTX8Qflt9QlstR3WjitJs3HghlcQRPV/
Hey guys, thanks for all the great feedback. I think I'll just set it aside for
now and fry some bigger fish, and then come back to it later and see how I feel
about it. Jerry's comment about the tab never being aligned very often sitting
on the ramp made some good sense. Then again, on picture day.... :-)
Thanks!
Matt
http://forums.matronics.com/viewtopic.php?p=196962#196962
Thanks for the fuel line tip.....
>From: rv(at)thelefflers.com
>Sent: Aug 6, 2008 1:35 PM
>Subject: Re: RE: RV-List: Engine 'first' start
in the fuel line.
>> Ralph,
- won't be much ground running time right from the get go.
the fuel flow can be done by pointing the nose at climbing attitude and running
>> More thoughts.....
>> Ralph
>> >Ralph Finch
>> >Folks,
>> >three blade prop.
I've already made a donation to the local fire department - they want to see anyway...don't
get to the airport much....Thanks!
>From: Dale Ensing <densing(at)carolina.rr.com>
>Sent: Aug 6, 2008 1:52 PM
>Subject: Re: RV-List: Engine 'first' start
>Dale
>> More thoughts.....
>> Ralph
> to see anyway...don't get to the airport much....Thanks!
Just make sure all your fuel and oil lines are tight and there shouldn't
be any way for a fire to start. If your plane is ready for flight, the
risk of fire at first engine start will be the same as when you run out
to the airport six months from now for a flight around the neighborhood.
It's not like the engine is going to explode. :-)
Best wishes for a great phase One. :-)
Sam Buchanan
Thanks Sam!
>From: Sam Buchanan <sbuc(at)hiwaay.net>
>Sent: Aug 6, 2008 3:49 PM
>Sam Buchanan
Actually Sam, there is another way for a fire on the first engine start even
with all the oil and gas lines tight...electrical!
Several years ago when I was still building my 6A at the airport, another
builder came over and asked if I would monitor his first start. There was
smoke almost immediately as the engine attempted to start. Every metal
connection from the engine to the airframe was cooked! When I asked him
where his ground strap was he asked me "what is a ground strap?" All of his
electrical testing before engine start didn't pull enough current to show
the lack of a ground strap but, of course, the starter motor turning the
engine was another story.
Dale
Sent: Wednesday, August 06, 2008 3:49 PM
> risk of fire at first engine start will be the same as when you run out to
> Sam Buchanan
Subject: | 91 octane, time to be heard! |
If you are happy with just 100LL stop here. You won't like where this is going.
This effects us all even in other countries because one tends to follow the other
at some point.
If you are tired of someone saying we can't have 91 octane, read on. It's time
to pick a side and take 5 minutes to email. Our lives as people are good because
someone didn't just say ok. Some took the time to make change and made it better
for all of us. If we choose to sit on the sideline and just go along then
we deserve what we get. I would implore all to take a minute and email these
two people and any other fuel administrator in other companies. I will post on
as many aviation websites as possible and I would you all to pick a side and
stand up to be heard and maybe, just maybe we might effect change. I for one
don't want to roll over. You are about to read a bulletin about the use of Chevron
ground fuel verses aviation fuel. Then I have a response.
Don't sit back and pick my memo apart, use that time to write your own and be heard.
Post this on all your aviation websites. Let them hear a nation wide voice.
Send your emails to:
LIMG(at)chevron.com
kayalbitz(at)chevron.com
or any other fuel company administrator.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Service Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=197012#197012
http://forums.matronics.com//files/2008_04_2008_04_bulletin_2008_04_chevron_position_autogas_for_aviation_use_527.pdf
http://forums.matronics.com//files/ryan_memo_185.doc
Subject: | Re: Another Fuel Question |
It is obviously leaking from the top aft portion of your tank where fuel
normally doesn't get unless you are in a vertical attitude. Check the
connector if you have a capacitance fuel indicator. Mine leaked. Also, check
the fuel vent connection at the root of the tank. I hope this helps.
Sent: Tuesday, August 05, 2008 7:50 PM
> during climb attitude. Straight and level, descending and on the ground,
> there's no gas odor. I've gone over the entire fuel system (wing tanks,
> vent system, fuel selector valve, boost pump connections, gascolator, fuel
> pressure transducer, carb connections, mechanical pump connections, etc).
> corrected, but the fuel smell is still there. I have also checked for blue
> Thanks,
> Walt Shipley
> even with all the oil and gas lines tight...electrical!
> another builder came over and asked if I would monitor his first start.
> There was smoke almost immediately as the engine attempted to start.
> Every metal connection from the engine to the airframe was cooked! When
> I asked him where his ground strap was he asked me "what is a ground
> strap?" All of his electrical testing before engine start didn't pull
> enough current to show the lack of a ground strap but, of course, the
> starter motor turning the engine was another story.
> Dale
Yes.......but if we do the thorough pre-start inspection that is
mandatory...... :-)
Sam Buchanan
Subject: | For sale New Garmin 396 |
For sale new Garmin 396 new in the box (never opened) with all the standard accesorries
and XM weather antenna. Aircraft Spruce price is $1795. Will sell for
$1600 plus shipping from 33029 (Ft. Lauderdale, FL) to you. If you are in the
market for this unit this will save you $200.? Please call me as I will be on
the road Eddy Fernandez (954) 914-5579 cell. Pay pal or cashiers check only.
Eddy Fernandez
RV9A 300hrs tt
RV7A Finishing kit
It is a standard practice in aviation to pressurize bladder and sealed
tanks. Vans even tells you how to do it before installing the tanks. If you
are really concerned, just disconnect the vent line from the wing root and
put a balloon on the vent line fitting and screw the pump fitting into the
low point drain like Vans tells you. Then, pump it slowly to prevent too
much pressure.
Sent: Tuesday, August 05, 2008 7:18 PM
> go together.
> From: "wskimike" <wskimike(at)mchsi.com>
> To:
>> To:
>>> Jerry
>>> is
>>> you
>>> Dean Van Winkle
>>> To:
>>>> integrity.
>>> for
>>>> Thanks all,
>>>> Jerry
>>> again.
>>> at
>>> You
>>> fixed.
>>>> Edit/Delete Message
That may be true, but also consider that airflow can be very strong, and can
vary noticeably in different attitudes and speeds. The path of airflow can
change; a small tornado surrounds our fuselage. Check the shape and
condition of the vent openings, too. You can close one tank including
sealing the vent and do a flight test. Then test the other tank. Double
check to be sure one tank is feeding proper before flight, and as always
when testing and being distracted, be prepared for an emergency. Are there
any signs of fuel stains anywhere in the cockpit, checking the entire route
of all fuel line and vent line with a bright light?
Good luck!
Dale
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of wskimike
Sent: Wednesday, August 06, 2008 9:35 PM
Subject: Re: RV-List: Another Fuel Question
> Thanks,
> Walt Shipley
Subject: | Re: For sale New Garmin 396 |
Eddy,
-How come you are building a 7A? I saw you on the front page of the Sun S
entinel when I came back from Buffalo last month. Congratulations.
--- On Wed, 8/6/08, eddyfernan(at)aol.com wrote:
From: eddyfernan(at)aol.com <eddyfernan(at)aol.com>
Subject: RV-List: For sale New Garmin 396
Date: Wednesday, August 6, 2008, 9:48 PM
accesorries and XM weather antenna. Aircraft Spruce price is $1795. Will s
ell for $1600 plus shipping from 33029 (Ft. Lauderdale, FL) to you. If you
are in the market for this unit this will save you $200.- Please call me
as I will be on the road Eddy Fernandez (954) 914-5579 cell. Pay pal or cas
hiers check only.
Eddy Fernandez
RV9A 300hrs tt
RV7A Finishing kit
It's time to go back to school! Get the latest trends and gadgets that make
the grade on AOL Shopping.
=0A=0A=0A
Walt,
If you find that the leak is at the bulkhead connector for the capacitance fuel
senders (if you have those) be sure to purchase genuine, made in the USA AMPHANOL
brand for the replacement. Vans supplies "made in the orient" units, which
are not as well designed.
Charlie Kuss
--- On Wed, 8/6/08, wskimike wrote:
> From: wskimike <wskimike(at)mchsi.com>
> Date: Wednesday, August 6, 2008, 9:34 PM
> tank where fuel
> attitude. Check the
> leaked. Also, check
> this helps.
> Mike
> From: "rveighta" <rveighta(at)earthlink.net>
> To:
> which occurs only
> and on the ground,
> connections, etc).
> appreciated.
> > Thanks,
> > Walt Shipley
In a message dated 8/6/2008 7:43:52 P.M. Pacific Daylight Time,
chaskuss(at)yahoo.com writes:
fuel senders (if you have those) be sure to purchase genuine, made in the USA
AMPHANOL brand for the replacement.
Actually the name of the company is Amphenol.
N1GV (RV-6A, Flying 895hrs, O-360-A1A, C/S, Silicon Valley)
My error. I should have placed a comma after the abbreviation USA to clarify that
statement.
--- On Thu, 8/7/08, Vanremog(at)aol.com wrote:
> From: Vanremog(at)aol.com <Vanremog(at)aol.com>
> Date: Thursday, August 7, 2008, 12:43 AM
> Time,
> the capacitance
> Valley)
I'm glad I have a ground strap....thanks to Bob Nuckoll's engineering and literary
talents.....
>Sent: Aug 6, 2008 8:08 PM
>Dale
>From: "Sam Buchanan" <sbuc(at)hiwaay.net
>To:
>> Sam Buchanan
Charlie, thank you and the others who have suggested solutions to my fuel leak
problem. I do have the Van's fuel level gauges/sending units on my RV8, and after
removing the wing to fuselage fairings once again, I believe the right sending
unit may be leaking; I don't see any blue stains, but the fiber center of
the unit appears dark in color compared to the one on the left side.
You mentioned Amphenol brand sender as better than the Van's standard unit - where
can I get them? I've tried googling for Amphenol senders several different
ways but don't get anything helpful.
Thanks again....
Walt Shipley
>From: Charles Kuss <chaskuss(at)yahoo.com>
>Sent: Aug 7, 2008 7:39 AM
statement.
>Charlie
>> Time,
>> the capacitance
>> Valley)
Subject: | Re: 91 octane, time to be heard! |
Hi Everyone,
Every website I posted on and I sent the letters to Flight Design have people
speaking up in support. I have received dozens of emails in support and that is
just since last night.
One voice will dye, but thousands may be heard.
Everyone,
Don't sit ideally and complain. 1-2 minutes of your time is all anyone is asking.
It's your future and your time to offer your hand in a worthwhile effort to
help shape it. Do it for yourself if not for anyone else.
Roger Lee
Tucson, Az.
520-574-1080
http://forums.matronics.com/viewtopic.php?p=197125#197125
He's speaking of electronic capacitance senders; sounds like you have
electric, float-type, like mine. Not the same animal.
-Bill
> leak problem. I do have the Van's fuel level gauges/sending units on my RV8,
> and after removing the wing to fuselage fairings once again, I believe the
> right sending unit may be leaking; I don't see any blue stains, but the
> fiber center of the unit appears dark in color compared to the one on the
> left side.
> - where can I get them? I've tried googling for Amphenol senders several
> different ways but don't get anything helpful.
> Thanks again....
> Walt Shipley
> clarify that statement.
> >Charlie
> >> Time,
> >> the capacitance
> >> Valley)
Subject: | -7 tipup rear window fitting problem |
I'm beginning the fit of my rear window (-7 tipup). After the big cut &
trimming the rear window to the plans-specified 1 1/4" outside the top
skin outline, I get a good 'glass/skin fit from top rear to about 10"
back of the roll bar. from that point it looks like the skin is puckered
out, but on closer exam the bottom edge of the window doesn't curve down
& in quick enough & is slightly outside the vertical line of the
fuselage side. The problem is almost identical on both sides. I *might*
be able to pull this in with screws, but my plan is to glue the canopy
and the rear window. I've got misgivings about expecting the sikaflex to
hold against this much stress when it won't be the specified 1/8"
thickness around this curved edge.
Has anyone else seen similar problems, and what did you do? The 1st
thing that comes to mind is heating & re curving the plexi, but the 2nd
thing that comes to mind is needing a new $1K canopy.
From: | "David Carter" <dcarter11(at)sbcglobal.net> |
Subject: | Use of Auto gas in aircraft - Chevron Ops Bulletin 2008-04 Risk |
of Using Automotive Fuels in Aircraft, June 2008
Dear Linda,
I notice from your signature block on the Chevron Ops Bulletin that you
are a quality person in the aviation fuels area.
I'm a retired USAF colonel, fighter pilot, and also a civilian pilot,
flying since I was 13, solo'd at 16, private pilot certificate at 17,
then back into civilian flying starting in 1970s (in my 30's) (Cessna
172), and most recently, building an RV-6 home built "experimental"
aircraft since Jan 1997. Finally bought one a year ago, 1 Jun 07, and
love flying it.
. . . At my last annual inspection in Nov 07 we overhauled the carb,
mainly to make sure it didn't have a plastic float that would dissolve
if I were ever to accidentally get autogas with alcohol in it. Now it
has a brass float and I've begun using mogas, per the STC that is FAA
approved for my engine, a high compression Lycoming IO-320 (160 hp).
The 160 hp model requires 91 octane, not available here at sea level -
only 87, 89, and 93, so I use 93 octane.
I am a very careful pilot, and have spent, and continue to spend, many
hours studying, researching (learning), and expanding my understanding
of "things". One area I've paid attention to is the use of MOGAS (auto
gas) in aircraft.
. . . The only concern of me and the FAA is that auto gas must not
contain ethanol - ethanol may not be compatible with all aircraft
'airframe systems" - tanks and tank sealants (stuff that keeps tanks
from leaking), fuel lines (aluminum, which is corroded by ethanol), etc.
. . . There is ZERO concern about the "engine" - except for the float
and needle valve rubber tip. With those two things of the right
material, which is fully documented in maintenance publications and
engine manufacturers' literature, there is ZERO concern about the
engine's performance at full rated power and about the engine's
durability.
Because you are truly interested in safety, and accuracy of information
you accept, I hope you will look at my favorite info that I have
collected in "My Documents" over the past 11 years - attached. I just
re-read it and it is a stand-alone excellent discussion of aviation
fuel, looking to the future.
Would appreciate your response to this, especially if you issue any
"clarification" or "recision" of your recent Ops Bulletin, which seems
to me to be a good idea. Because,. . .
. . . There is a total absence of any concern by the FAA, the
manufacturer's, and us maintainters and operators of aircraft, over
using automotive fuel that has the FAA required octane and does not have
ethanol. If they are not concerned, why are you, given that the first
reason you gave in the Ops Bulletin is not really an issue of safety,
the 2nd does not stand up to peer review, and the 3rd is "common
knowledge" and agreed to by everyone - don't use any fuel with ethanol
in an airplane that has not been tested and certified compatible (and
none has, to my knowledge)?
Best wishes,
David Carter
619 S. 16th St
Nederland, Texas 77627 (85 mi east of Houston)
home ph 409-722-7259
cell (when away from house) 409-718-2268
Subject: | Consensus On Finishing Back End Of Fiberglass Tips... |
Dear Listers,
Here are some pictures of my recently finished Fin and Rudder
fiberglass tips, specifically highlighting my notion of mounting the
VOR/GS/LOC antenna on the top of the Fin. It came out very nice I
think and gives full access to cabling and antenna mount for maintenance.
But here's my question. Look at that last picture of the back end of
the Fin fiberglass tip and note the gaping hole. I gather from the
plans that it is kind of up to the builder whether to put a cover on
the back of it. My first question would have to be why the f***
isn't there one already molded on it like on the front of the rudder
tip? But, hostility aside, what's everyone's thoughts on finishing
these? I'm just thinking that my patience for fiberglass layups
hovers around zero and I can just see taking a totally sweet tip
installation and mucking it royally. But, I will if I must. I would
really like the back end finished off rather than gaping open like
that, but it might be something I could live with...
Thoughts?
RV-8 #82880
Subject: | Re: Consensus On Finishing Back End Of Fiberglass Tips... |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