RV-Archive.digest.vol-tr
September 05, 2008 - September 25, 2008
      Federal Aviation RegulationSec. 91.409
      Part 91 GENERAL OPERATING AND FLIGHT RULES
      Subpart E--Maintenance=2C Preventive Maintenance=2C and Alterations
      Sec. 91.409Inspections.(a) Except as provided in paragraph (c) of this sect
      ion=2C no person may operate an aircraft unless=2C within the preceding 12
      calendar months=2C it has had--(1) An annual inspection in accordance with
      part 43 of this chapter and has been approved for return to service by a pe
      rson authorized by Sec. 43.7 of this chapter=3B
      Sec. 43.16Airworthiness Limitations.Each person performing an inspection or
       other maintenance specified in an Airworthiness Limitations section of a m
      anufacturer's maintenance manual or Instructions for Continued Airworthines
      s shall perform the inspection or other maintenance in accordance with that
       section=2C or in accordance with operations specifications approved by the
       Administrator under part 121 or 135=2C or an inspection program approved u
      nder Sec. 91.409(e).(e) Large airplanes (to which part 125 is not applicabl
      e)=2C turbojet multiengine airplanes=2C turbopropeller-powered multiengine
      airplanes=2C and turbine-powered rotorcraft.
      It's only a deal if it's where you want to go. Find your travel deal here.
      See how Windows Mobile brings your life together=97at home=2C work=2C or on
       the go.
Subject: Re: A&P Standard
Date: Sep 05, 2008
Dead on, Mike. I have an A&E with IA in the hangar next to me. He doesn't "practice" anymore, but offered good suggestions while I was building my RV6A. I think I know more about the specific plane I spent 4-years building than a causal observer or someone who spends perhaps an hour looking at it. I don't mind suggestions, or even constructive critisims, but I know that all examinations (like A&E, Law, Physiciams, etc) are all designed to measure if the candidate has the MINIMUM knowledge to proceed. So mere possession of any "credential" is always proof positive that the person is all knowledgeable. I do my own annual condtion inspections in strict accord with the operating limitations, and feel very comfortable doing so...and have done so for the past 13 or more years. FWIW John at Salida, CO ________________________________________________________________________________
Date: Sep 05, 2008
Subject: A&P Standard
Long and boring answer, delete if you are tired of this discussion. >Excellent post and understandable. So here is a hypothetical question: >Mr. John Jones builds an RX-4 and gets his AWC as an experimental >Homebuilt Aircraft. But he decides since it is an experimental and >he can do whatever he wants to he decides to use several non >aircraft type parts and automotive wiring, plus RC model servo >equipment for electric trims. Each year if he also obtained the A&P >license for this aircraft can perform the conditional inspection. Anybody can perform the conditional inspection. However, only the repairman or an A&P can sign the logbook with the appropriate statement in my operating conditions assigned to me by the FAA, I must sate: "I certify that this aircraft has been inspected in accordance with the scope and detail of Part 43, appendix D and found to be in a condition for safe flight." As far a non certified parts, when the aircraft receives the DAR inspection, or in my case the FAA inspection, then non standard parts, engineering, etc should be discussed and then evaluated by the builder and inspector for its appropriateness for safe flight. My FAA inspector did not allow me to do some things that I wanted, made me change a few things. So just because it is an experimental, that did not give me a license to do anything I wanted. A wild example: I don't expect I would be allowed to hold my wings on with rubber bands the way I do with some R/C aircraft! But, I can use a non certified experimental oil filter for my formerly certified Lycoming engine! It is my opinion that many non certified parts/equipment are as good or maybe better than the certified parts (yes I agree some are not, buyer beware). But, we will never know, because most of the time the reason a part is not certified is because of the extra cost and burden associated with the testing and evaluation, i.e destructive testing and the endless paper trail (this is good and bad). >But then in year 4 he is real busy with work so he hires a licensed >A&P mechanic to do his condition inspection. Does that A&P have the >leisure to inspect this aircraft and have no concerns for the parts >that were used in this aircraft? Is he in jeopardy if he inspects >this aircraft and one of those parts causes an accident? This is my >real question as an A&P has some obligation to follow the accepted >practices in the aviation field but an experimental doesn't really >have to meet the same criteria. It is an experiment. Like anything in life there is a risk. I will give my opinion, but the issue can only be resolved in a court of law, or with more specific FAA regulations (which I don't think we need or want). I have an obnoxious A&P/IA friend who has refused to do a conditional inspection on a retaliative's homebuilt aircraft because parts installed did not meet the detail of Part 43, appendix D. He has done conditional inspections on numerous homebuilts. He uses his professional judgment on the issue in question on whether the aircraft is airworthy/safe or not. It is his right to refuse to do the inspection, or to not sign the logbook if in his judgement he determines the aircraft is not safe or unairworthy using Part 43, appendix D as a guide. Yes if there is a part that fails (experimental or certified) I am sure the FAA will question him if there is a crash. As for experimental parts. If the manufacturer installs this part, i.e. the builder, even if the builder is Cessna , then by installing the part, the manufacturer is making a statement that the part is necessary and safe for flight and during testing will determine if it is safe and or appropriate. The way I see it, once the FAA or DAR inspector inspects the aircraft, it is as if by decree, all parts (certified or non certified) are airworthy. Certified parts fail (Slick Mags), non certified parts fail, the question would be, did the part failure cause the crash, and was the part inspected or checked using reasonable sound inspection techniques? Some non certified parts/equipment give inspection criteria within the owners manual, i.e. the Rocky Mountain Instruments Micro Encoder. On the other hand , I have a non certified fuel injection system, how does it get checked/inspected? The same way a certified fuel system would be checked. I have a non certified Lycoming engine, it gets inspected the same way a certified engine does. Now 4 years later, I decide to change out a part because I designed a new, better, faster, part (example: I build a tapered wing for my RV6, spar and leading edge all the same, but aft ribs and trailing edge is tapered). My operating procedures spell out what I must do to maintain the airworthiness of my aircraft if I make a major alteration such as this, (or if I just go from a fixed pitched prop to a constant speed). I put my aircraft back into phase 1 testing for 5 hours. After the 5 hours and I have worked all the bugs out, I sign the log book with the work done and the test results. After that time the A&P would be inspecting the airplane based upon the changes made. Sort of like the STC/337 process. On the other hand, I am not a professional builder, I have had many A&P/IAs look at my aircraft to give me advice on how to, is it right, is it safe. I welcome an A&P/IA comments/advice. Things that I did not know how to do, I hired an A&P/IA to do the work and inspect it, i.e. time the Mags and Mag inspection. As far as parts go, I had to design and fabricate my own throttle mixture bracket for a Fuel Injected servo. Vans did not have one, nor did anyone else at the time. Non standard part, not even on the aircraft plans. Of all the A&P/IAs that have checked my aircraft (especially the engine installation) not one has ever mention this! I often wonder why? As I said before, this is really not a big issue, it is spelled out in the FAA regulations on how to do it. It should also be in the aircraft operating conditions that are required to be a part of the aircraft documents. If this issue really bothers you, then don't deal with homebuilts, simple solution. Note: We are allowed to put auto engines in our homebuilts. What better place to get parts and stuff for the installation than "Autozone," .....well personally, I might use "Summit Racing," but Autozone would do. Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Date: Sep 05, 2008
Subject: Navaid question
Hello: Well finally I am ready to connect the Wing Leveler "Nav Aid" but I cannot do center the "arm, I tried but is difficult to do, since it has to be in place, mine is under the seat....hard to work with... So I wanted to ship the unit to Nav Aid, and pay them to center lthe arm etc... I called but the numnber I have is not in service. Does any one, knows the new number....? Thanks, Bert rv6a P>S. any one has a real clear picture of the servo, and how you center the thing???Any one near DELand Aiport...(DED) ________________________________________________________________________________
Date: Sep 05, 2008
Subject: Re: Navaid question
bert murillo wrote: > > Hello: > > Well finally I am ready to connect the Wing Leveler "Nav Aid" > but I cannot do center the "arm, I tried but is difficult > to do, since it has to be in place, mine is under the seat....hard > to work with... > > So I wanted to ship the unit to Nav Aid, and pay them to center > lthe arm etc... I called but the numnber I have is not in service. > > Does any one, knows the new number....? > > Thanks, > > Bert > rv6a > > P>S. any one has a real clear picture of the servo, and how > you center the thing???Any one near DELand Aiport...(DED) Bert, Navaid is out of business. I am not aware of anyone who offers service or parts for the system. Sam Buchanan ________________________________________________________________________________
Date: Sep 05, 2008
This is an adjustment you can do yourself. You will find you will also need to reposition the gear that drives the feedback potentiometer as well. The instructions cover this, but not well. Recommend you find an RV builder in the area who has already done this. My Navaid has been flying for five years and works as advertised. It did take some tweaking however to get it zeroed out such that the wings are level with the "Trim" and "Turn" panel controls in the mid (pointing straight up) position. This tweaking can only be done with the servo installed and the servo cover removed, so sending it back to the factory is not an option. The next autopilot will be a new servo connected to the Dynon EFIS that is already in the panel. Carl Froehlich RV-8A (450 hrs) RV-10 (fuselage) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan Sent: Friday, September 05, 2008 4:57 PM Subject: Re: RV-List: Navaid question bert murillo wrote: > > Hello: > > Well finally I am ready to connect the Wing Leveler "Nav Aid" > but I cannot do center the "arm, I tried but is difficult > to do, since it has to be in place, mine is under the seat....hard > to work with... > > So I wanted to ship the unit to Nav Aid, and pay them to center > lthe arm etc... I called but the numnber I have is not in service. > > Does any one, knows the new number....? > > Thanks, > > Bert > rv6a > > P>S. any one has a real clear picture of the servo, and how > you center the thing???Any one near DELand Aiport...(DED) Bert, Navaid is out of business. I am not aware of anyone who offers service or parts for the system. Sam Buchanan ________________________________________________________________________________
Subject: Re: Builder Available!
Date: Sep 05, 2008
This is a long read but offers some background as to why A&Ps IA are concerned about liability. http://www.avweb.com/news/savvyaviator/savvy_aviator_51_mechanics_liability_196570-1.html -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2837#202837 ________________________________________________________________________________
Date: Sep 05, 2008
Your other option (though much more expensive) is to just leave the servo in place and install the trio control head. It has software that will compensate for a non-centered servo. Dave Leonard On Fri, Sep 5, 2008 at 2:35 PM, Carl Froehlich wrote: > > This is an adjustment you can do yourself. You will find you will also > need > to reposition the gear that drives the feedback potentiometer as well. The > instructions cover this, but not well. > > Recommend you find an RV builder in the area who has already done this. > > My Navaid has been flying for five years and works as advertised. It did > take some tweaking however to get it zeroed out such that the wings are > level with the "Trim" and "Turn" panel controls in the mid (pointing > straight up) position. This tweaking can only be done with the servo > installed and the servo cover removed, so sending it back to the factory is > not an option. > > The next autopilot will be a new servo connected to the Dynon EFIS that is > already in the panel. > > Carl Froehlich > RV-8A (450 hrs) > RV-10 (fuselage) > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan > Sent: Friday, September 05, 2008 4:57 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Navaid question > > > bert murillo wrote: > > > > Hello: > > > > Well finally I am ready to connect the Wing Leveler "Nav Aid" > > but I cannot do center the "arm, I tried but is difficult > > to do, since it has to be in place, mine is under the seat....hard > > to work with... > > > > So I wanted to ship the unit to Nav Aid, and pay them to center > > lthe arm etc... I called but the numnber I have is not in service. > > > > Does any one, knows the new number....? > > > > Thanks, > > > > Bert > > rv6a > > > > P>S. any one has a real clear picture of the servo, and how > > you center the thing???Any one near DELand Aiport...(DED) > > > Bert, > > Navaid is out of business. I am not aware of anyone who offers service > or parts for the system. > > Sam Buchanan > > -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net ________________________________________________________________________________
Subject: A request for action
Date: Sep 05, 2008
This is going to take a bit=2C so if you don't want to get involved this is a good time to hit delete. Gentleman=2C and any ladies that may still be with us=2C I have a request for all of you that =2C if heard=2C will benefit everyone. Everyone has known me for quite a while. I built my first RV in 1998=2C and have been building and flying RV's ever since. Over that time I have been greatly involved with my job in certificating an d overseeing amateur-built aircraft. I have also seen a very disturbing tr end that I feel now needs to be addressed. And that is the lack of service you have receiving from the Flight Standards Offices. I am requesting tha t all of you call=2C or email=2C you US Representative and/or US Senator=2C and let them know that you are NOT receiving service from the FAA that you r tax dollars are paying for. As a matter of fact you have been paying a p rivate user fee for quite some time now=2C and you have the right to tell t hem it needs to stop. And this involves your having to pay for certificati on of your amateur-built aircraft. And with the attempt by the FAA to chan ge the Amateur-built rules and a recent change to the authority of the DARs you are going to have to pay more very soon. I would also request that you keep my name out of it off of this list. Now...Let me explain. Please bare with me as I need to explain the system just a little so you can be somewhat educated. Within the FAA there are two branches that are tasked with conducting inspe ctions and issuing airworthiness certificates to all aircraft=2C be they St andard category or Experimental. Those two branches are the Manufacturing Inspection District Offices (MIDO) and the Flight Standards District Office s (FSDO). Most of the work is done by the FSDOs due to the fact that MIDOs are located with the regional offices=2C thus very far from most of us. T here are only 9 MIDOs in the country. Due to politics and high profiles the management within the flight standard s has made the decision that focusing on inspections of scheduled Air Carri ers (i.e=2C United Airlines=2C etc.) gives them the biggest bang for the bu ck=2C if you will. If the Flight Standards management had their way ALL gen eral aviation would have to use designees and pay for service. And that is exactly what they are trying to do through the back door. Most of you already know that if you contact your FSDO to get an inspection done=2C they will refer you to a DAR telling you that they no longer do in spections. That is a LIE. It is part of the job description of every airw orthiness inspector in the FAA. Granted=2C many of them do not know anythi ng about the types of aircraft we build but there are many many more who do know=2C want to do them=2C and have the time do do them=2C but management within the Flight Standards has declared=2C in writing=2C that we are not t o bother with Amateur-builders=2C and are to send everyone to a DAR=2C irre gardless of what it may cost you=2C the builder. Your tax dollar pays for the operation of the FAA and you have the right to receive service for that dollar. You are not. Please do not get me wrong . As you know from the recent Southwest Airlines fiasco=2C inspecting big air carriers is important. But general aviation inspectors do NOT routinel y inspect big air carriers.. We inspect general aviation operators=2C such as charter operations=2C flight schools=2C crop dusters=2C and repair stati ons. And at no additional cost to the FAA of travel dollars airworthiness inspectors could include certification of Amateur-built aircraft in their surveillence/inspections trips. Each of us goes on the road often enough t o include everyone=2C if we were allowed. I am sorry for being up on a soap box for so long but I am tired of telling people 'no'=2C I can't help you even though I have the expertise and the t ime. And I have talked with numerous airworthiness inspectors who feel the same way. But from the inside we have no way to buck the system. It has to come from outside=2C and that is why I am asking for all of you to take action. Contact your Representatives=2C Senators=2C the EAA=2C and AOPA an d let them know that you are not happy about what is happening. Mike R. RV Builder Tech Counselor A&P Das *** _________________________________________________________________ See how Windows Mobile brings your life together=97at home=2C work=2C or on the go. ________________________________________________________________________________
Subject: Re: A request for action
Date: Sep 06, 2008
Thank you for going out on the line! Bruce Bell Lubbock, Texas RV-4 #2888 N23BB ----- Original Message ----- From: Mike Robertson To: rv list Sent: Saturday, September 06, 2008 1:46 AM Subject: RV-List: A request for action This is going to take a bit, so if you don't want to get involved this is a good time to hit delete. Gentleman, and any ladies that may still be with us, I have a request for all of you that , if heard, will benefit everyone. Everyone has known me for quite a while. I built my first RV in 1998, and have been building and flying RV's ever since. Over that time I have been greatly involved with my job in certificating and overseeing amateur-built aircraft. I have also seen a very disturbing trend that I feel now needs to be addressed. And that is the lack of service you have receiving from the Flight Standards Offices. I am requesting that all of you call, or email, you US Representative and/or US Senator, and let them know that you are NOT receiving service from the FAA that your tax dollars are paying for. As a matter of fact you have been paying a private user fee for quite some time now, and you have the right to tell them it needs to stop. And this involves your having to pay for certification of your amateur-built aircraft. And with the attempt by the FAA to change the Amateur-built rules and a recent change to the authority of the DARs you are going to have to pay more very soon. I would also request that you keep my name out of it off of this list. Now...Let me explain. Please bare with me as I need to explain the system just a little so you can be somewhat educated. Within the FAA there are two branches that are tasked with conducting inspections and issuing airworthiness certificates to all aircraft, be they Standard category or Experimental. Those two branches are the Manufacturing Inspection District Offices (MIDO) and the Flight Standards District Offices (FSDO). Most of the work is done by the FSDOs due to the fact that MIDOs are located with the regional offices, thus very far from most of us. There are only 9 MIDOs in the country. Due to politics and high profiles the management within the flight standards has made the decision that focusing on inspections of scheduled Air Carriers (i.e, United Airlines, etc.) gives them the biggest bang for the buck, if you will. If the Flight Standards management had their way ALL general aviation would have to use designees and pay for service. And that is exactly what they are trying to do through the back door. Most of you already know that if you contact your FSDO to get an inspection done, they will refer you to a DAR telling you that they no longer do inspections. That is a LIE. It is part of the job description of every airworthiness inspector in the FAA. Granted, many of them do not know anything about the types of aircraft we build but there are many many more who do know, want to do them, and have the time do do them, but management within the Flight Standards has declared, in writing, that we are not to bother with Amateur-builders, and are to send everyone to a DAR, irregardless of what it may cost you, the builder. Your tax dollar pays for the operation of the FAA and you have the right to receive service for that dollar. You are not. Please do not get me wrong. As you know from the recent Southwest Airlines fiasco, inspecting big air carriers is important. But general aviation inspectors do NOT routinely inspect big air carriers.. We inspect general aviation operators, such as charter operations, flight schools, crop dusters, and repair stations. And at no additional cost to the FAA of travel dollars airworthiness inspectors could include certification of Amateur-built aircraft in their surveillence/inspections trips. Each of us goes on the road often enough to include everyone, if we were allowed. I am sorry for being up on a soap box for so long but I am tired of telling people 'no', I can't help you even though I have the expertise and the time. And I have talked with numerous airworthiness inspectors who feel the same way. But from the inside we have no way to buck the system. It has to come from outside, and that is why I am asking for all of you to take action. Contact your Representatives, Senators, the EAA, and AOPA and let them know that you are not happy about what is happening. Mike R. RV Builder Tech Counselor A&P Das *** ------------------------------------------------------------------------- ----- See how Windows Mobile brings your life together=97nkwxp1020093182mrt/direct/01/' target='_new'>See Now ________________________________________________________________________________
Subject: Efis Question
Date: Sep 06, 2008
FWIW=2C Talking with the DYNON president at AirVenture=2C he stated they ar e trying to add synthetic vision to their system next year. Marty Heller RV-7=2C fitting canopy > From: carl.froehlich(at)cox.net> To: rv-list(at)matronics.com> Subject: RE: RV- List: Efis Question> Date: Fri=2C 5 Sep 2008 22:47:55 -0400> > --> RV-List message posted by: "Carl Froehlich" > > Bert=2C> > I replaced an electric RC Allen AI with the D10A. I feed it with the serial > output from my GX-60 GPS nav/comm=2C and will also feed it from a SL-30> nav/comm when I save up a few more pennies.> > In short=2C the D10A has don e everything Dynon advertises it would do=2C and> considering the continuou s (and free) software upgrades from Dynon I expect> it will do more in the future. The D10A is about the best bang for the buck> as you can get.> > So me thoughts:> 1. Get the EDC D10A remote compass. While I flew with just th e internal> compass for a few months and found it to work well=2C the exter nal compass is> far easier to calibrate and it is required if you want to i nput outside air> temperature into the D10A. With outside air temperature t he D10A provides> continuous True Air Speed indication as well as wind dire ction and wind> speed. I find I use this wind information far more than I e xpected and now> would not want to be without it. > 2. As I have dual batte ries I did not get the battery backup. Your install> may be different.> 3. As I only removed the AI to install the D10A=2C I still have all the> stand ard steam gauges (air speed=2C altitude=2C vertical speed). Considering> th e minor cost=2C I would recommend having these standard instruments in the> panel along with the D10A.> 4. The HSI function works just as good as a st andard HSI.> 5. If you are going to use the D10A for glide slope and locali zer> indication=2C you should consider getting two D10As. That way you can keep> the normal display up on one and HSI on the other. Considering the co st of> a CDI head these day=2C a second D10A make a whole lot more sense th an putting> a standalone CDI in the panel.> 6. If you can solder wires to a D connector=2C you can install the D10A.> 7. Dynon has a list of known GPS and Nav radios that customer report> working with the D10A. You should cal l them to see if what you are planning> to feed it is on the list or not. > 8. While the D10A does not need GPS input to work=2C the GPS input provide s> the data to compute wind speed and direction. Either a GPS or a Nav inpu t> is needed of course for HSI functions.> 9. I have a Navaid wing level fo r my autopilot. When it dies I'll get the> Dynon servo and feed it off the D10A. Again the best bang for the buck for> an autopilot. > > Carl Froehlic h> RV-8A (450 hrs)> RV-10 (fuselage)> > -----Original Message-----> From: o wner-rv-list-server(at)matronics.com> [mailto:owner-rv-list-server(at)matronics.c om] On Behalf Of bert murillo> Sent: Friday=2C September 05=2C 2008 3:19 PM > To: rv-list(at)matronics.com> Subject: RV-List: Efis Question> > --> RV-List message posted by: bert murillo > > Hello:> > > I a m considering buying the Efis-D10A=2C For those with this unit=2C> question 1- Do you find it=2C to work proplerly=2C and are you happy with> it.> > 2 - How difficult is to connect. I am tired of working under that> crowded sp ace=2C=2C=2C=2CAll I need would be basic fuctions...> > NO G or anyof the o ptions...> > Does any one has the schematic=2C drawings for connection..> > it shows a 25 pin connector....do I have to have 25 wires????> > Finally =2C when installing this unit=2C what instruments one remove> from the pann el....I believe the Attitud Ind. is out??> > What happens if the unit fails ? one would be without a very essential> tool..... for safety etc...> > You r comments and suggestions appreciated...> > > Bert> > rv6a> > Do not Archi ==========> > > _________________________________________________________________ Get more out of the Web. Learn 10 hidden secrets of Windows Live. http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!5 50F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008 ________________________________________________________________________________
Date: Sep 06, 2008
Mike, your contribution to the RV-10 community, the RV community and the Experimental Built Amateur Owned community has been valued over the years. Your loss to the Oregon community has become Spokane's gain. I think of you at every EAA 105 breakfast just like this morning. I support whole heartedly the value in owners seeking their Airworthiness Inspectors insight, training and wisdom in the certification process of OBAM aircraft. I am only aware of one Inspector nationwide who like some DARs are repetitively signing off aircraft mass produced by Pro Builders. Most are an invaluable resource to make our projects safer. I found with my 23 years while serving as a DPE for NM-09 that the staff and inspectors, both Ops and Airworthiness to be a wonderful resource for aviation. You civil servants have too often been maligned and few understand the long hours and dedication you provide. For those of you reading this, take Mike's heed and write your legislators. In Oregon we have Rep. DeFazio and may soon have VP Sarah Palin who has come out in support of GA on behalf of her husband (the family pilot). We need all the friends we can get to preserve our wonderful activity. Make your voices heard and your tax dollars count. John Cox RV Builder Tech Counselor A&P I/A Airline Mechanic Pilot Voter From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Sent: Friday, September 05, 2008 11:46 PM Subject: RV-List: A request for action This is going to take a bit, so if you don't want to get involved this is a good time to hit delete. Gentleman, and any ladies that may still be with us, I have a request for all of you that , if heard, will benefit everyone. Everyone has known me for quite a while. I built my first RV in 1998, and have been building and flying RV's ever since. Over that time I have been greatly involved with my job in certificating and overseeing amateur-built aircraft. I have also seen a very disturbing trend that I feel now needs to be addressed. And that is the lack of service you have receiving from the Flight Standards Offices. I am requesting that all of you call, or email, you US Representative and/or US Senator, and let them know that you are NOT receiving service from the FAA that your tax dollars are paying for. As a matter of fact you have been paying a private user fee for quite some time now, and you have the right to tell them it needs to stop. And this involves your having to pay for certification of your amateur-built aircraft. And with the attempt by the FAA to change the Amateur-built rules and a recent change to the authority of the DARs you are going to have to pay more very soon. I would also request that you keep my name out of it off of this list. Now...Let me explain. Please bare with me as I need to explain the system just a little so you can be somewhat educated. Within the FAA there are two branches that are tasked with conducting inspections and issuing airworthiness certificates to all aircraft, be they Standard category or Experimental. Those two branches are the Manufacturing Inspection District Offices (MIDO) and the Flight Standards District Offices (FSDO). Most of the work is done by the FSDOs due to the fact that MIDOs are located with the regional offices, thus very far from most of us. There are only 9 MIDOs in the country. Due to politics and high profiles the management within the flight standards has made the decision that focusing on inspections of scheduled Air Carriers (i.e, United Airlines, etc.) gives them the biggest bang for the buck, if you will. If the Flight Standards management had their way ALL general aviation would have to use designees and pay for service. And that is exactly what they are trying to do through the back door. Most of you already know that if you contact your FSDO to get an inspection done, they will refer you to a DAR telling you that they no longer do inspections. That is a LIE. It is part of the job description of every airworthiness inspector in the FAA. Granted, many of them do not know anything about the types of aircraft we build but there are many many more who do know, want to do them, and have the time do do them, but management within the Flight Standards has declared, in writing, that we are not to bother with Amateur-builders, and are to send everyone to a DAR, irregardless of what it may cost you, the builder. Your tax dollar pays for the operation of the FAA and you have the right to receive service for that dollar. You are not. Please do not get me wrong. As you know from the recent Southwest Airlines fiasco, inspecting big air carriers is important. But general aviation inspectors do NOT routinely inspect big air carriers.. We inspect general aviation operators, such as charter operations, flight schools, crop dusters, and repair stations. And at no additional cost to the FAA of travel dollars airworthiness inspectors could include certification of Amateur-built aircraft in their surveillence/inspections trips. Each of us goes on the road often enough to include everyone, if we were allowed. I am sorry for being up on a soap box for so long but I am tired of telling people 'no', I can't help you even though I have the expertise and the time. And I have talked with numerous airworthiness inspectors who feel the same way. But from the inside we have no way to buck the system. It has to come from outside, and that is why I am asking for all of you to take action. Contact your Representatives, Senators, the EAA, and AOPA and let them know that you are not happy about what is happening. Mike R. RV Builder Tech Counselor A&P Das *** ________________________________ See how Windows Mobile brings your life together-nkwxp1020093182mrt/direct/01/' target='_new'>See Now ________________________________________________________________________________
Date: Sep 06, 2008
Hello Mike, When I was ready for my inspection last year, I called the Kansas City FSDO and was told EXACTLY what you are informing us about. I got the "lack of budget" because of failure to pass the "User Fee" legislation and was told to contact a DAR. I explained that I was entitled to the FREE services of the FAA as a result of my tax dollars. They finally agreed to do the inspection, but informed me that they would only grant a minimal test area for the RV-7 during a required 40-hour phase one. The FAA obviously wanted no part of the experimental airworthiness inspections. Since I wanted (and needed) a larger test area, I reluctantly contacted a DAR and paid for the service. You're right, the current treatment/actions of the FAA is unwarranted and unfair. Now, I'm actually seeing the experimentals getting MORE attention from the FAA in the KC FSDO area - from equipment installations (trying to tell us what's legal - WRONG), ramp checks, and airworthiness inspections. It appears that the high fuel costs are significantly reducing GA operations, especially for the Spam Cans. Overall, the fuel efficient experimentals are flying more regularly than the certified ships. As a result, I believe the FAA uses the increasing numbers of experimentals to justify their jobs or reqs for additional positions. Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Sent: Saturday, September 06, 2008 1:46 AM Subject: RV-List: A request for action This is going to take a bit, so if you don't want to get involved this is a good time to hit delete. Gentleman, and any ladies that may still be with us, I have a request for all of you that , if heard, will benefit everyone. Everyone has known me for quite a while. I built my first RV in 1998, and have been building and flying RV's ever since. Over that time I have been greatly involved with my job in certificating and overseeing amateur-built aircraft. I have also seen a very disturbing trend that I feel now needs to be addressed. And that is the lack of service you have receiving from the Flight Standards Offices. I am requesting that all of you call, or email, you US Representative and/or US Senator, and let them know that you are NOT receiving service from the FAA that your tax dollars are paying for. As a matter of fact you have been paying a private user fee for quite some time now, and you have the right to tell them it needs to stop. And this involves your having to pay for certification of your amateur-built aircraft. And with the attempt by the FAA to change the Amateur-built rules and a recent change to the authority of the DARs you are going to have to pay more very soon. I would also request that you keep my name out of it off of this list. Now...Let me explain. Please bare with me as I need to explain the system just a little so you can be somewhat educated. Within the FAA there are two branches that are tasked with conducting inspections and issuing airworthiness certificates to all aircraft, be they Standard category or Experimental. Those two branches are the Manufacturing Inspection District Offices (MIDO) and the Flight Standards District Offices (FSDO). Most of the work is done by the FSDOs due to the fact that MIDOs are located with the regional offices, thus very far from most of us. There are only 9 MIDOs in the country. Due to politics and high profiles the management within the flight standards has made the decision that focusing on inspections of scheduled Air Carriers (i.e, United Airlines, etc.) gives them the biggest bang for the buck, if you will. If the Flight Standards management had their way ALL general aviation would have to use designees and pay for service. And that is exactly what they are trying to do through the back door. Most of you already know that if you contact your FSDO to get an inspection done, they will refer you to a DAR telling you that they no longer do inspections. That is a LIE. It is part of the job description of every airworthiness inspector in the FAA. Granted, many of them do not know anything about the types of aircraft we build but there are many many more who do know, want to do them, and have the time do do them, but management within the Flight Standards has declared, in writing, that we are not to bother with Amateur-builders, and are to send everyone to a DAR, irregardless of what it may cost you, the builder. Your tax dollar pays for the operation of the FAA and you have the right to receive service for that dollar. You are not. Please do not get me wrong. As you know from the recent Southwest Airlines fiasco, inspecting big air carriers is important. But general aviation inspectors do NOT routinely inspect big air carriers.. We inspect general aviation operators, such as charter operations, flight schools, crop dusters, and repair stations. And at no additional cost to the FAA of travel dollars airworthiness inspectors could include certification of Amateur-built aircraft in their surveillence/inspections trips. Each of us goes on the road often enough to include everyone, if we were allowed. I am sorry for being up on a soap box for so long but I am tired of telling people 'no', I can't help you even though I have the expertise and the time. And I have talked with numerous airworthiness inspectors who feel the same way. But from the inside we have no way to buck the system. It has to come from outside, and that is why I am asking for all of you to take action. Contact your Representatives, Senators, the EAA, and AOPA and let them know that you are not happy about what is happening. Mike R. RV Builder Tech Counselor A&P Das *** _____ See how Windows Mobile brings your life together-nkwxp1020093182mrt/direct/01/' target='_new'>See Now ________________________________________________________________________________
Date: Sep 06, 2008
Despite the opinions I was wasting my time, I contacted the FSDO @ GSO for my RV-8 inspection back in 2004. It worked out great. The inspector was professional, interested, and a joy to work with. He even had to come out a second time after I had fixed a CS prop that would not cycle. Moral of the story: it usually doesn't hurts to ask! -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com RV-7 QB fuse ... On Sat, Sep 6, 2008 at 10:11 AM, John Cox wrote: > Mike, your contribution to the RV-10 community, the RV community and the > Experimental Built Amateur Owned community has been valued over the years. > Your loss to the Oregon community has become Spokane's gain. I think of you > at every EAA 105 breakfast just like this morning. > > > I support whole heartedly the value in owners seeking their Airworthiness > Inspectors insight, training and wisdom in the certification process of OBAM > aircraft. I am only aware of one Inspector nationwide who like some DARs > are repetitively signing off aircraft mass produced by Pro Builders. Mos t > are an invaluable resource to make our projects safer. I found with my 23 > years while serving as a DPE for NM-09 that the staff and inspectors, bot h > Ops and Airworthiness to be a wonderful resource for aviation. You civil > servants have too often been maligned and few understand the long hours and > dedication you provide. > > > For those of you reading this, take Mike's heed and write your legislators. > In Oregon we have Rep. DeFazio and may soon have VP Sarah Palin who has come > out in support of GA on behalf of her husband (the family pilot). We nee d > all the friends we can get to preserve our wonderful activity. Make your > voices heard and your tax dollars count. > > > John Cox > > RV Builder > > Tech Counselor > > A&P I/A > > Airline Mechanic > > Pilot > > Voter > > > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson > Sent: Friday, September 05, 2008 11:46 PM > To: rv list > Subject: RV-List: A request for action > > > This is going to take a bit, so if you don't want to get involved this is a > good time to hit delete. > > Gentleman, and any ladies that may still be with us, > > I have a request for all of you that , if heard, will benefit everyone. > Everyone has known me for quite a while. I built my first RV in 1998, an d > have been building and flying RV's ever since. > > Over that time I have been greatly involved with my job in certificating and > overseeing amateur-built aircraft. I have also seen a very disturbing trend > that I feel now needs to be addressed. And that is the lack of service you > have receiving from the Flight Standards Offices. I am requesting that all > of you call, or email, you US Representative and/or US Senator, and let them > know that you are NOT receiving service from the FAA that your tax dollar s > are paying for. As a matter of fact you have been paying a private user fee > for quite some time now, and you have the right to tell them it needs to > stop. And this involves your having to pay for certification of your > amateur-built aircraft. And with the attempt by the FAA to change the > Amateur-built rules and a recent change to the authority of the DARs you are > going to have to pay more very soon. I would also request that you keep m y > name out of it off of this list. > > Now...Let me explain. Please bare with me as I need to explain > the system just a little so you can be somewhat educated. > > Within the FAA there are two branches that are tasked with conducting > inspections and issuing airworthiness certificates to all aircraft, be they > Standard category or Experimental. Those two branches are the Manufacturing > Inspection District Offices (MIDO) and the Flight Standards District Offices > (FSDO). Most of the work is done by the FSDOs due to the fact that MIDOs > are located with the regional offices, thus very far from most of us. There > are only 9 MIDOs in the country. > > Due to politics and high profiles the management within the flight standards > has made the decision that focusing on inspections of scheduled Air Carriers > (i.e, United Airlines, etc.) gives them the biggest bang for the buck, if > you will. If the Flight Standards management had their way ALL general > aviation would have to use designees and pay for service. And that is > exactly what they are trying to do through the back door. > > Most of you already know that if you contact your FSDO to get an inspection > done, they will refer you to a DAR telling you that they no longer do > inspections. That is a LIE. It is part of the job description of every > airworthiness inspector in the FAA. Granted, many of them do not know > anything about the types of aircraft we build but there are many many mor e > who do know, want to do them, and have the time do do them, but managemen t > within the Flight Standards has declared, in writing, that we are not to > bother with Amateur-builders, and are to send everyone to a DAR, > irregardless of what it may cost you, the builder. > > Your tax dollar pays for the operation of the FAA and you have the right to > receive service for that dollar. You are not. Please do not get me wrong. > As you know from the recent Southwest Airlines fiasco, inspecting big air > carriers is important. But general aviation inspectors do NOT routinely > inspect big air carriers.. We inspect general aviation operators, such as > charter operations, flight schools, crop dusters, and repair stations. And > at no additional cost to the FAA of travel dollars airworthiness inspectors > could include certification of Amateur-built aircraft in their > surveillence/inspections trips. Each of us goes on the road often enough to > include everyone, if we were allowed. > > I am sorry for being up on a soap box for so long but I am tired of telling > people 'no', I can't help you even though I have the expertise and the > time. And I have talked with numerous airworthiness inspectors who feel the > same way. But from the inside we have no way to buck the system. It has to > come from outside, and that is why I am asking for all of you to take > action. Contact your Representatives, Senators, the EAA, and AOPA and le t > them know that you are not happy about what is happening. > > Mike R. > RV Builder > Tech Counselor > A&P > Das *** > > > ________________________________ > > See how Windows Mobile brings your life > together=97nkwxp1020093182mrt/direct/01/' target='_new'>See Now > > > http://www.matronics.com/Navigator?RV-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Sep 06, 2008
Subject: Re: A request for action (you asked)
So, John, are you saying that you like aviation user fees or are you praying for a death from old age the day after inauguration? :-) You might want to explain (to those of us who are seeing our retirement savings and investments disappear before we can even retire) how massive deficit spending is different from taxation. The current policies have already crippled my ability to fly; having a VP who's husband owns a plane isn't likely to help us any. McCain owns more houses than he can count; did he help, or help cause the current mortgage debacle? Check McCain's voting record on veterans' affairs. I think you'll be shocked. The current crop of Republicans (who are NOT conservative), with their borrow-and-spend tactics, make tax-and-spend Democrats look conservative. I'd strongly suggest that you look beyond Ms. Palin's acceptance speech & look at her long list of past activities, like attempted book banning, attempting to fire the town librarian when she wouldn't go along with the book banning, favoring Alaska secession, massive deficit spending on 'frills' (still running at a deficit today) while letting infrastructure decay in her home town, firing the head law enforcement official in Alaska because he wouldn't fire her ex-brother in law, sale of that jet, not on Ebay, but to a big Alaskan GOP contributor, *at a loss*, actively supporting Ted Stevens' "bridge to nowhere" until it became obvious that there was near universal opposition, even among Alaskans, actively seeking earmarks, shall I continue? Please do not read this as an endorsement of the Democratic ticket. If we want to see improvements in this country, we will have to look outside the two major parties. Charlie John Cox wrote: > > Mike, your contribution to the RV-10 community, the RV community and > the Experimental Built Amateur Owned community has been valued over > the years. Your loss to the Oregon community has become Spokane's > gain. I think of you at every EAA 105 breakfast just like this morning. > > I support whole heartedly the value in owners seeking their > Airworthiness Inspectors insight, training and wisdom in the > certification process of OBAM aircraft. I am only aware of one > Inspector nationwide who like some DARs are repetitively signing off > aircraft mass produced by Pro Builders. Most are an invaluable > resource to make our projects safer. I found with my 23 years while > serving as a DPE for NM-09 that the staff and inspectors, both Ops and > Airworthiness to be a wonderful resource for aviation. You civil > servants have too often been maligned and few understand the long > hours and dedication you provide. > > For those of you reading this, take Mike's heed and write your > legislators. In Oregon we have Rep. DeFazio and may soon have VP Sarah > Palin who has come out in support of GA on behalf of her husband (the > family pilot). We need all the friends we can get to preserve our > wonderful activity. Make your voices heard and your tax dollars count. > > John Cox > > RV Builder > > Tech Counselor > > A&P I/A > > Airline Mechanic > > Pilot > > Voter > > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Mike Robertson > *Sent:* Friday, September 05, 2008 11:46 PM > *To:* rv list > *Subject:* RV-List: A request for action > > This is going to take a bit, so if you don't want to get involved this > is a good time to hit delete. > > Gentleman, and any ladies that may still be with us, > > I have a request for all of you that , if heard, will benefit > everyone. Everyone has known me for quite a while. I built my first RV > in 1998, and have been building and flying RV's ever since. > > Over that time I have been greatly involved with my job in > certificating and overseeing amateur-built aircraft. I have also seen > a very disturbing trend that I feel now needs to be addressed. And > that is the lack of service you have receiving from the Flight > Standards Offices. I am requesting that all of you call, or email, you > US Representative and/or US Senator, and let them know that you are > NOT receiving service from the FAA that your tax dollars are paying > for. As a matter of fact you have been paying a private user fee for > quite some time now, and you have the right to tell them it needs to > stop. And this involves your having to pay for certification of your > amateur-built aircraft. And with the attempt by the FAA to change the > Amateur-built rules and a recent change to the authority of the DARs > you are going to have to pay more very soon. I would also request that > you keep my name out of it off of this list. > > Now...Let me explain. Please bare with me as I need to explain the > system just a little so you can be somewhat educated. > > Within the FAA there are two branches that are tasked with conducting > inspections and issuing airworthiness certificates to all aircraft, be > they Standard category or Experimental. Those two branches are the > Manufacturing Inspection District Offices (MIDO) and the Flight > Standards District Offices (FSDO). Most of the work is done by the > FSDOs due to the fact that MIDOs are located with the regional > offices, thus very far from most of us. There are only 9 MIDOs in the > country. > > Due to politics and high profiles the management within the flight > standards has made the decision that focusing on inspections of > scheduled Air Carriers (i.e, United Airlines, etc.) gives them the > biggest bang for the buck, if you will. If the Flight Standards > management had their way ALL general aviation would have to use > designees and pay for service. And that is exactly what they are > trying to do through the back door. > > Most of you already know that if you contact your FSDO to get an > inspection done, they will refer you to a DAR telling you that they no > longer do inspections. That is a LIE. It is part of the job > description of every airworthiness inspector in the FAA. Granted, many > of them do not know anything about the types of aircraft we build but > there are many many more who do know, want to do them, and have the > time do do them, but management within the Flight Standards has > declared, in writing, that we are not to bother with Amateur-builders, > and are to send everyone to a DAR, irregardless of what it may cost > you, the builder. > > Your tax dollar pays for the operation of the FAA and you have the > right to receive service for that dollar. You are not. Please do not > get me wrong. As you know from the recent Southwest Airlines fiasco, > inspecting big air carriers is important. But general aviation > inspectors do NOT routinely inspect big air carriers.. We inspect > general aviation operators, such as charter operations, flight > schools, crop dusters, and repair stations. And at no additional cost > to the FAA of travel dollars airworthiness inspectors could include > certification of Amateur-built aircraft in their > surveillence/inspections trips. Each of us goes on the road often > enough to include everyone, if we were allowed. > > I am sorry for being up on a soap box for so long but I am tired of > telling people 'no', I can't help you even though I have the expertise > and the time. And I have talked with numerous airworthiness inspectors > who feel the same way. But from the inside we have no way to buck the > system. It has to come from outside, and that is why I am asking for > all of you to take action. Contact your Representatives, Senators, the > EAA, and AOPA and let them know that you are not happy about what is > happening. > > Mike R. > RV Builder > Tech Counselor > A&P > Das *** > > > ------------------------------------------------------------------------ > > See how Windows Mobile brings your life > togethernkwxp1020093182mrt/direct/01/' target='_new'>See Now > > * * > * * > ** > ** > *http://www.matronics.com/Navigator?RV-List* > ** > ** > *http://forums.matronics.com* > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * > ------------------------------------------------------------------------ > > > Checked by AVG - http://www.avg.com > > ________________________________________________________________________________
Subject: A request for action (you asked)
Date: Sep 06, 2008
Charlie=2C If you read Mike's letter=2C you will note that he and his counterparts hav e the TIME and experience to perform our inspections. "Time"=2C means that no other personnel would have to be hired by the FAA to do this job and no more money spent=2C therefore no reason for them to bring up user fees=2C let alone you bringing up your view of politics. Stop blaming the governme nt for all your problems=2C get on with flying=2C and only post things pert aining to aircraft building. Paul RV8 Flying Siren > Date: Sat=2C 6 Sep 2008 13:05:10 -0500> From: ceengland(at)bellsouth.net> To : rv-list(at)matronics.com> Subject: Re: RV-List: A request for action (you as .net>> > So=2C John=2C are you saying that you like aviation user fees or a re you > praying for a death from old age the day after inauguration? :-)> > You might want to explain (to those of us who are seeing our retirement > savings and investments disappear before we can even retire) how massive > deficit spending is different from taxation. The current policies have > a lready crippled my ability to fly=3B having a VP who's husband owns a > pla ne isn't likely to help us any. McCain owns more houses than he can > count =3B did he help=2C or help cause the current mortgage debacle? Check > McCa in's voting record on veterans' affairs. I think you'll be shocked.> > The current crop of Republicans (who are NOT conservative)=2C with their > borr ow-and-spend tactics=2C make tax-and-spend Democrats look conservative.> > I'd strongly suggest that you look beyond Ms. Palin's acceptance speech > & look at her long list of past activities=2C like attempted book banning=2C > attempting to fire the town librarian when she wouldn't go along with > the book banning=2C favoring Alaska secession=2C massive deficit spending o n > 'frills' (still running at a deficit today) while letting infrastructur e > decay in her home town=2C firing the head law enforcement official in > Alaska because he wouldn't fire her ex-brother in law=2C sale of that jet =2C > not on Ebay=2C but to a big Alaskan GOP contributor=2C *at a loss*=2C actively > supporting Ted Stevens' "bridge to nowhere" until it became obv ious that > there was near universal opposition=2C even among Alaskans=2C a ctively > seeking earmarks=2C shall I continue?> > Please do not read this as an endorsement of the Democratic ticket. If > we want to see improvement s in this country=2C we will have to look > outside the two major parties.> > Charlie> > > John Cox wrote:> >> > Mike=2C your contribution to the RV-1 0 community=2C the RV community and > > the Experimental Built Amateur Owne d community has been valued over > > the years. Your loss to the Oregon com munity has become Spokane's > > gain. I think of you at every EAA 105 break fast just like this morning.> >> > I support whole heartedly the value in o wners seeking their > > Airworthiness Inspectors insight=2C training and wi sdom in the > > certification process of OBAM aircraft. I am only aware of one > > Inspector nationwide who like some DARs are repetitively signing of f > > aircraft mass produced by Pro Builders. Most are an invaluable > > re source to make our projects safer. I found with my 23 years while > > servi ng as a DPE for NM-09 that the staff and inspectors=2C both Ops and > > Air worthiness to be a wonderful resource for aviation. You civil > > servants have too often been maligned and few understand the long > > hours and dedi cation you provide.> >> > For those of you reading this=2C take Mike's heed and write your > > legislators. In Oregon we have Rep. DeFazio and may soo n have VP Sarah > > Palin who has come out in support of GA on behalf of he r husband (the > > family pilot). We need all the friends we can get to pre serve our > > wonderful activity. Make your voices heard and your tax dolla rs count.> >> > John Cox> >> > RV Builder> >> > Tech Counselor> >> > A&P I/ A> >> > Airline Mechanic> >> > Pilot> >> > Voter> >> > *From:* owner-rv-lis t-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Mike Robertson> > *Sent:* Friday=2C September 05=2C 2008 11:46 P M> > *To:* rv list> > *Subject:* RV-List: A request for action> >> > This i s going to take a bit=2C so if you don't want to get involved this > > is a good time to hit delete.> >> > Gentleman=2C and any ladies that may still be with us=2C> >> > I have a request for all of you that =2C if heard=2C wi ll benefit > > everyone. Everyone has known me for quite a while. I built m y first RV > > in 1998=2C and have been building and flying RV's ever since .> >> > Over that time I have been greatly involved with my job in > > cert ificating and overseeing amateur-built aircraft. I have also seen > > a ver y disturbing trend that I feel now needs to be addressed. And > > that is t he lack of service you have receiving from the Flight > > Standards Offices . I am requesting that all of you call=2C or email=2C you > > US Representa tive and/or US Senator=2C and let them know that you are > > NOT receiving service from the FAA that your tax dollars are paying > > for. As a matter of fact you have been paying a private user fee for > > quite some time now =2C and you have the right to tell them it needs to > > stop. And this invo lves your having to pay for certification of your > > amateur-built aircraf t. And with the attempt by the FAA to change the > > Amateur-built rules an d a recent change to the authority of the DARs > > you are going to have to pay more very soon. I would also request that > > you keep my name out of it off of this list.> >> > Now...Let me explain. Please bare with me as I n eed to explain the > > system just a little so you can be somewhat educated .> >> > Within the FAA there are two branches that are tasked with conducti ng > > inspections and issuing airworthiness certificates to all aircraft =2C be > > they Standard category or Experimental. Those two branches are t he > > Manufacturing Inspection District Offices (MIDO) and the Flight > > Standards District Offices (FSDO). Most of the work is done by the > > FSDO s due to the fact that MIDOs are located with the regional > > offices=2C t hus very far from most of us. There are only 9 MIDOs in the > > country.> > > > Due to politics and high profiles the management within the flight > > standards has made the decision that focusing on inspections of > > schedul ed Air Carriers (i.e=2C United Airlines=2C etc.) gives them the > > biggest bang for the buck=2C if you will. If the Flight Standards > > management h ad their way ALL general aviation would have to use > > designees and pay f or service. And that is exactly what they are > > trying to do through the back door.> >> > Most of you already know that if you contact your FSDO to get an > > inspection done=2C they will refer you to a DAR telling you that they no > > longer do inspections. That is a LIE. It is part of the job > > description of every airworthiness inspector in the FAA. Granted=2C many > > of them do not know anything about the types of aircraft we build but > > there are many many more who do know=2C want to do them=2C and have the > > time do do them=2C but management within the Flight Standards has > > d eclared=2C in writing=2C that we are not to bother with Amateur-builders=2C > > and are to send everyone to a DAR=2C irregardless of what it may cost > > you=2C the builder.> >> > Your tax dollar pays for the operation of the FAA and you have the > > right to receive service for that dollar. You are not. Please do not > > get me wrong. As you know from the recent Southwest Airlines fiasco=2C > > inspecting big air carriers is important. But gener al aviation > > inspectors do NOT routinely inspect big air carriers.. We i nspect > > general aviation operators=2C such as charter operations=2C flig ht > > schools=2C crop dusters=2C and repair stations. And at no additional cost > > to the FAA of travel dollars airworthiness inspectors could inclu de > > certification of Amateur-built aircraft in their > > surveillence/in spections trips. Each of us goes on the road often > > enough to include ev eryone=2C if we were allowed.> >> > I am sorry for being up on a soap box f or so long but I am tired of > > telling people 'no'=2C I can't help you ev en though I have the expertise > > and the time. And I have talked with num erous airworthiness inspectors > > who feel the same way. But from the insi de we have no way to buck the > > system. It has to come from outside=2C an d that is why I am asking for > > all of you to take action. Contact your R epresentatives=2C Senators=2C the > > EAA=2C and AOPA and let them know tha t you are not happy about what is > > happening.> >> > Mike R.> > RV Builde r> > Tech Counselor> > A&P> > Das ***> >> >> >> > ------------------------- -----------------------------------------------> >> > See how Windows Mobil e brings your life > > together=97nkwxp1020093182mrt/direct/01/' target=' _new'>See Now> >> > * *> > * *> > **> > **> > *http://www.matronics.com/Nav igator?RV-List*> > **> > **> > *http://forums.matronics.com*> > **> > **> > **> > *http://www.matronics.com/contribution*> > **> > * *> > *> >> >> > * > > ----------------------------------------------------------------------- ========================> _ ======================> > > ________________________________________________________________________________
Date: Sep 06, 2008
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: Dimpling of Elevator Trim Tab Piano Hinge ????
Greetings: Ref: Elevator Trim Tab PIANO HINGE Anybody have any idea why Vans recommends Dimpling the Elevator Skin, machine countersinking the Trim Tab Spar and then attaching the Elevator Trim Tab Piano Hinge ?? Why not dimple the Elevator Skin (per Vans directions), DIMPLE the Trim Tab Spar and DIMPLE the Piano Hinge ?? This does away with the machine countersinking the Elev Trim Tab SPAR ???? Just wondering. Thanks, Garey ________________________________________________________________________________
Date: Sep 06, 2008
Evidently the temptation to introduce B. Hussein's talking points onto the list was too much to pass over, Paul. Charlie, we've had our disagreements in the past, when I mistook you for a fellow conservative and sent you some pro-2nd amendment stuff - I won't go there again with you since it ruffles your feathers so, and to no net positive effect that I can see. But I think you might possibly find the thread referenced here -> http://www.ar15.com/forums/topic.html?b=1&f=5&t=749631 worth your ti me, since not everything you have heard and repeated about Gov. Palin is, in fact, true. Respectfully, Bill B. On Sat, Sep 6, 2008 at 4:38 PM, Paul Rice wrote: > Charlie, > > If you read Mike's letter, you will note that he and his counterparts hav e > the *TIME* and experience to perform our inspections. *"Time*", means > that no other personnel would have to be hired by the FAA to do this job and > no more money spent, therefore no reason for them to bring up user fees, let > alone you bringing up your view of politics. Stop blaming the government > for all your problems, get on with flying, and only post things pertainin g > to aircraft building. > > Paul > RV8 > Flying Siren > > > > Date: Sat, 6 Sep 2008 13:05:10 -0500 > > From: ceengland(at)bellsouth.net > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: A request for action (you asked) > > > > > > > > So, John, are you saying that you like aviation user fees or are you > > praying for a death from old age the day after inauguration? :-) > > > > You might want to explain (to those of us who are seeing our retirement > > savings and investments disappear before we can even retire) how massiv e > > deficit spending is different from taxation. The current policies have > > already crippled my ability to fly; having a VP who's husband owns a > > plane isn't likely to help us any. McCain owns more houses than he can > > count; did he help, or help cause the current mortgage debacle? Check > > McCain's voting record on veterans' affairs. I think you'll be shocked. > > > > The current crop of Republicans (who are NOT conservative), with their > > borrow-and-spend tactics, make tax-and-spend Democrats look conservativ e. > > > > I'd strongly suggest that you look beyond Ms. Palin's acceptance speech > > & look at her long list of past activities, like attempted book banning , > > attempting to fire the town librarian when she wouldn't go along with > > the book banning, favoring Alaska secession, massive deficit spending o n > > 'frills' (still running at a deficit today) while letting infrastructur e > > decay in her home town, firing the head law enforcement official in > > Alaska because he wouldn't fire her ex-brother in law, sale of that jet , > > not on Ebay, but to a big Alaskan GOP contributor, *at a loss*, activel y > > supporting Ted Stevens' "bridge to nowhere" until it became obvious tha t > > there was near universal opposition, even among Alaskans, actively > > seeking earmarks, shall I continue? > > > > Please do not read this as an endorsement of the Democratic ticket. If > > we want to see improvements in this country, we will have to look > > outside the two major parties. > > > > Charlie > > > > > > John Cox wrote: > > > > > > Mike, your contribution to the RV-10 community, the RV community and > > > the Experimental Built Amateur Owned community has been valued over > > > the years. Your loss to the Oregon community has become Spokane's > > > gain. I think of you at every EAA 105 breakfast just like this mornin g. > > > > > > I support whole heartedly the value in owners seeking their > > > Airworthiness Inspectors insight, training and wisdom in the > > > certification process of OBAM aircraft. I am only aware of one > > > Inspector nationwide who like some DARs are repetitively signing off > > > aircraft mass produced by Pro Builders. Most are an invaluable > > > resource to make our projects safer. I found with my 23 years while > > > serving as a DPE for NM-09 that the staff and inspectors, both Ops an d > > > Airworthiness to be a wonderful resource for aviation. You civil > > > servants have too often been maligned and few understand the long > > > hours and dedication you provide. > > > > > > For those of you reading this, take Mike's heed and write your > > > legislators. In Oregon we have Rep. DeFazio and may soon have VP Sara h > > > Palin who has come out in support of GA on behalf of her husband (the > > > family pilot). We need all the friends we can get to preserve our > > > wonderful activity. Make your voices heard and your tax dollars count . > > > > > > John Cox > > > > > > RV Builder > > > > > > Tech Counselor > > > > > > A&P I/A > > > > > > Airline Mechanic > > > > > > Pilot > > > > > > Voter > > > > > > *From:* owner-rv-list-server(at)matronics.com > > > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Mike > Robertson > > > *Sent:* Friday, September 05, 2008 11:46 PM > > > *To:* rv list > > > *Subject:* RV-List: A request for action > > > > > > This is going to take a bit, so if you don't want to get involved thi s > > > is a good time to hit delete. > > > > > > Gentleman, and any ladies that may still be with us, > > > > > > I have a request for all of you that , if heard, will benefit > > > everyone. Everyone has known me for quite a while. I built my first R V > > > in 1998, and have been building and flying RV's ever since. > > > > > > Over that time I have been greatly involved with my job in > > > certificating and overseeing amateur-built aircraft. I have also seen > > > a very disturbing trend that I feel now needs to be addressed. And > > > that is the lack of service you have receiving from the Flight > > > Standards Offices. I am requesting that all of you call, or email, yo u > > > US Representative and/or US Senator, and let them know that you are > > > NOT receiving service from the FAA that your tax dollars are paying > > > for. As a matter of fact you have been paying a private user fee for > > > quite some time now, and you have the right to tell them it needs to > > > stop. And this involves your having to pay for certification of your > > > amateur-built aircraft. And with the attempt by the FAA to change the > > > Amateur-built rules and a recent change to the authority of the DARs > > > you are going to have to pay more very soon. I would also request tha t > > > you keep my name out of it off of this list. > > > > > > Now...Let me explain. Please bare with me as I need to explain the > > > system just a little so you can be somewhat educated. > > > > > > Within the FAA there are two branches that are tasked with conducting > > > inspections and issuing airworthiness certificates to all aircraft, b e > > > they Standard category or Experimental. Those two branches are the > > > Manufacturing Inspection District Offices (MIDO) and the Flight > > > Standards District Offices (FSDO). Most of the work is done by the > > > FSDOs due to the fact that MIDOs are located with the regional > > > offices, thus very far from most of us. There are only 9 MIDOs in the > > > country. > > > > > > Due to politics and high profiles the management within the flight > > > standards has made the decision that focusing on inspections of > > > scheduled Air Carriers (i.e, United Airlines, etc.) gives them the > > > biggest bang for the buck, if you will. If the Flight Standards > > > management had their way ALL general aviation would have to use > > > designees and pay for service. And that is exactly what they are > > > trying to do through the back door. > > > > > > Most of you already know that if you contact your FSDO to get an > > > inspection done, they will refer you to a DAR telling you that they n o > > > longer do inspections. That is a LIE. It is part of the job > > > description of every airworthiness inspector in the FAA. Granted, man y > > > of them do not know anything about the types of aircraft we build but > > > there are many many more who do know, want to do them, and have the > > > time do do them, but management within the Flight Standards has > > > declared, in writing, that we are not to bother with Amateur-builders , > > > and are to send everyone to a DAR, irregardless of what it may cost > > > you, the builder. > > > > > > Your tax dollar pays for the operation of the FAA and you have the > > > right to receive service for that dollar. You are not. Please do not > > > get me wrong. As you know from the recent Southwest Airlines fiasco, > > > inspecting big air carriers is important. But general aviation > > > inspectors do NOT routinely inspect big air carriers.. We inspect > > > general aviation operators, such as charter operations, flight > > > schools, crop dusters, and repair stations. And at no additional cost > > > to the FAA of travel dollars airworthiness inspectors could include > > > certification of Amateur-built aircraft in their > > > surveillence/inspections trips. Each of us goes on the road often > > > enough to include everyone, if we were allowed. > > > > > > I am sorry for being up on a soap box for so long but I am tired of > > > telling people 'no', I can't help you even though I have the expertis e > > > and the time. And I have talked with numerous airworthiness inspector s > > > who feel the same way. But from the inside we have no way to buck the > > > system. It has to come from outside, and that is why I am asking for > > > all of you to take action. Contact your Representatives, Senators, th e > > > EAA, and AOPA and let them know that you are not happy about what is > > > happening. > > > > > > Mike R. > > > RV Builder > > > Tech Counselor > > > A&P > > > Das *** > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > See how Windows Mobile brings your life > > > together=97nkwxp1020093182mrt/direct/01/' target='_new'>See Now > > > > > > * * > > > * * > > > ** > > > ** > > > *http://www.matronics.com/Navigator?RV-List* > > > ** > > > ** > > > *http://forums.matronics.com* > > > ** > > > ** > > > ** > > > *http://www.matronics.com/contribution* > > > ** > > > * * > > > * > > > > > > > > > * > > > > ------------------------------------------------------------------------ > > > > > > > > > Checked by AVG - http://www.avg.com < Archive Search & Download, 7-Da y > Browse, Chat, FAQ, > >==================== > > _==== > > > > > > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: Strobe switch problem
Date: Sep 06, 2008
Fellow RVers, My strobe system blew its fuse. Replaced, the fuse blew again when the Master Power was turned on with the strobe switch OFF. Investigation found the switch shorted internally and the fast on connectors charred from heat. The switch was a B&C 700 series 1-3 toggle operating a 12v Whelen single pack strobe system. I put the above info on the AeroElectric list. It turns out switch failures on Whelen Strobe systems is fairly common. There were several cases where the switch had not failed, but the fast on contacts were blackened from heat. Bob Nuckolls is investigating just why a strobe system would cause switch failures and switch heating with reasonable 12 v amperages. I would like to recommend that every RV owner with a strobe system, check the strobe ON-OFF switch for signs of over heating. Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Date: Sep 06, 2008
Subject: Re: Dimpling of Elevator Trim Tab Piano Hinge ????
The piano hinge is a little thick to be dimpling but even if you did, it would deform the hinge enough that the wire might not line up. Try it with a scrap piece of hinge and I think you'll find it gets deformed enough after dimpling that the hing won't go together with the wire properly. Mike > Anybody have any idea why Vans recommends Dimpling the Elevator Skin, machine countersinking the Trim Tab Spar and then attaching the Elevator Trim Tab Piano Hinge ?? > > Why not dimple the Elevator Skin (per Vans directions), DIMPLE the Trim Tab Spar and DIMPLE the Piano Hinge ?? This does away with the machine countersinking the Elev Trim Tab SPAR ???? > > Just wondering. Thanks, Garey > > > > > > ________________________________________________________________________________
Date: Sep 06, 2008
Subject: Re: Strobe switch problem
In a message dated 9/6/2008 2:54:06 P.M. Pacific Daylight Time, chasb(at)satx.rr.com writes: My strobe system blew its fuse. Replaced, the fuse blew again when the Master Power was turned on with the strobe switch OFF. Investigation found the switch shorted internally and the fast on connectors charred from heat. The switch was a B&C 700 series 1-3 toggle operating a 12v Whelen single pack strobe system. I put the above info on the AeroElectric list. It turns out switch failures on Whelen Strobe systems is fairly common. There were several cases where the switch had not failed, but the fast on contacts were blackened from heat. Bob Nuckolls is investigating just why a strobe system would cause switch failures and switch heating with reasonable 12 v amperages. I would like to recommend that every RV owner with a strobe system, check the strobe ON-OFF switch for signs of over heating. ================================== Odd. I am using a Carlingswitch DPST rocker switch to run three Whelen single strobe Power Supplies triggered together for wing tip and tail coverage. I have seen no such situation with this combination and I run them every time I fly, day and night. N1GV (RV-6A, Flying 900hrs, O-360-A1A, C/S, Silicon Valley) **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Date: Sep 06, 2008
In a message dated 9/6/2008 11:15:00 A.M. Pacific Daylight Time, ceengland(at)bellsouth.net writes: You might want to explain (to those of us who are seeing our retirement savings and investments disappear before we can even retire) how massive deficit spending is different from taxation. The current policies have already crippled my ability to fly; having a VP who's husband owns a plane isn't likely to help us any. McCain owns more houses than he can count; did he help, or help cause the current mortgage debacle? Check McCain's voting record on veterans' affairs. I think you'll be shocked. ============================================ Good shot Charlie. Many of us are not ready to drink the Kool-aid, so you are not alone. N1GV (RV-6A, Flying 900hrs, O-360-A1A, C/S, Silicon Valley) **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Subject: 121.5 MHz ELT termination
Date: Sep 07, 2008
Hi Listers, I have noticed a few hints of this on the list over the last year but never really knew (or obviously paid attention) to the reasons. A few days ago I received a post card from the NOAA informing me the Satellite Coverage for 121.5 MHz ELT's will end on February 1, 2009. It further indicates in order to receive Satellite coverage I would need to be operating on 406 MHz. Does this mean there will be a mandatory change of ELT device in order to maintain my AW? I realize it would be near useless to continue with the one I got if I don't change it. The question is more about what the requirements are going to be. I also noticed just a week or two ago where someone was purchasing a new unit at something like $895. This is about twice what I remember paying for my current ELT that works perfectly. What are others doing here? I really hate this! That is my fuel budget for several months. Tim Bryan RV-6 Flying N616TB over 100 hours now ________________________________________________________________________________
Subject: Re: 121.5 MHz ELT termination
Date: Sep 07, 2008
"Satellite" coverage ends. Not all monitoring of 121.5 MHz 406 MHz ELT not now required in USA. Check AOPA or VAF for recent discussions. Spend that money on fuel for now. Ron Lee ________________________________________________________________________________
Date: Sep 07, 2008
Tim: I am with you as to the expense, but yes, AOPA has told us for the past year, the change and explain all the details... What we do we the old unit...I wish some one could use them, The reality is we have to get the new unit, otherwise we will not have any communication incase of accident etc... I better star saving for the $800 or so... Bert rv6a --- On Sun, 9/7/08, Tim Bryan wrote: > From: Tim Bryan <n616tb(at)btsapps.com> > Subject: RV-List: 121.5 MHz ELT termination > To: rv-list(at)matronics.com > Date: Sunday, September 7, 2008, 10:16 AM > > > Hi Listers, > > I have noticed a few hints of this on the list over the > last year but never > really knew (or obviously paid attention) to the reasons. > A few days ago I > received a post card from the NOAA informing me the > Satellite Coverage for > 121.5 MHz ELT's will end on February 1, 2009. It > further indicates in order > to receive Satellite coverage I would need to be operating > on 406 MHz. > > Does this mean there will be a mandatory change of ELT > device in order to > maintain my AW? I realize it would be near useless to > continue with the one > I got if I don't change it. The question is more about > what the > requirements are going to be. I also noticed just a week > or two ago where > someone was purchasing a new unit at something like $895. > This is about > twice what I remember paying for my current ELT that works > perfectly. What > are others doing here? > > I really hate this! That is my fuel budget for several > months. > > Tim Bryan > RV-6 Flying > N616TB over 100 hours now > > > > ________________________________________________________________________________
Date: Sep 07, 2008
In a message dated 9/7/2008 7:19:31 A.M. Pacific Daylight Time, n616tb(at)btsapps.com writes: I have noticed a few hints of this on the list over the last year but never really knew (or obviously paid attention) to the reasons. A few days ago I received a post card from the NOAA informing me the Satellite Coverage for 121.5 MHz ELT's will end on February 1, 2009. It further indicates in order to receive Satellite coverage I would need to be operating on 406 MHz. Does this mean there will be a mandatory change of ELT device in order to maintain my AW? I realize it would be near useless to continue with the one I got if I don't change it. The question is more about what the requirements are going to be. I also noticed just a week or two ago where someone was purchasing a new unit at something like $895. This is about twice what I remember paying for my current ELT that works perfectly. What are others doing here? I really hate this! That is my fuel budget for several months. ================================== I have the older ACK E-01 ELT and their new compliant ELT E-04 that uses the same panel mounted control and will fit in the same tray is going to be out in a few weeks. The retrofit kit is going for MSRP of $560. Maybe ACS will discount it slightly so perhaps it's worth calling them to see once it is released. I will probably budget mine for Q1CY09. My suspicion is that once their new design and qualification investment is recaptured they will deal on these, but it could be a few years. N1GV (RV-6A, Flying 900hrs, O-360-A1A, C/S, Silicon Valley) **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Date: Sep 07, 2008
bert murillo wrote: > > Tim: I am with you as to the expense, but yes, AOPA has told us > for the past year, the change and explain all the details... > > What we do we the old unit...I wish some one could use them, > The reality is we have to get the new unit, otherwise we will not > have any communication incase of accident etc... I better star > saving for the $800 or so... > > Bert > rv6a > There are no regulatory requirements to purchase a new ELT at this time. Our ELTs are still perfectly legal, we just need to be aware that satellites will no longer be listening on 121.5. If our ELT is triggered, responses will be based on either aircraft monitoring 121.5 (nearly all commercial aircraft do so) or monitoring by ground stations. The satellite-based ELTs are obviously superior to the 121.5 only units, and each pilot must decide how important it is to have the latest ELT technology. But the FAA has left that decision to us. Canadian pilots MUST make the change to the 406 ELT. Sam Buchanan ________________________________________________________________________________
Date: Sep 07, 2008
Thanks everyone, I will monitor the prices and keep what I got until I am more comfortable with the price. One additional question if anyone knows. I almost always fly with flight following. If for some reason, I dropped off the scope, would they pin point that spot and call emergency or would they just say: "oh, must have lost him" and cancel the squak code? I would hope I at least had time to notify them I was in trouble but you never know. Tim Bryan RV-6 Flying N616TB over 100 hours now > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Sam Buchanan > Sent: Sunday, September 07, 2008 11:11 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: 121.5 MHz ELT termination > > > bert murillo wrote: > > > > Tim: I am with you as to the expense, but yes, AOPA has told us > > for the past year, the change and explain all the details... > > > > What we do we the old unit...I wish some one could use them, > > The reality is we have to get the new unit, otherwise we will not > > have any communication incase of accident etc... I better star > > saving for the $800 or so... > > > > Bert > > rv6a > > > > There are no regulatory requirements to purchase a new ELT at this > time. > > Our ELTs are still perfectly legal, we just need to be aware that > satellites will no longer be listening on 121.5. If our ELT is > triggered, responses will be based on either aircraft monitoring 121.5 > (nearly all commercial aircraft do so) or monitoring by ground > stations. > > The satellite-based ELTs are obviously superior to the 121.5 only > units, > and each pilot must decide how important it is to have the latest ELT > technology. But the FAA has left that decision to us. > > Canadian pilots MUST make the change to the 406 ELT. > > Sam Buchanan > > ________________________________________________________________________________
Date: Sep 07, 2008
Tim Bryan wrote: > > Thanks everyone, I will monitor the prices and keep what I got until I am > more comfortable with the price. One additional question if anyone knows. > I almost always fly with flight following. If for some reason, I dropped > off the scope, would they pin point that spot and call emergency or would > they just say: "oh, must have lost him" and cancel the squak code? I would > hope I at least had time to notify them I was in trouble but you never know. > > Tim Bryan > RV-6 Flying > N616TB over 100 hours now Tim, if you want to learn more about an exciting enhancement to aircraft tracking, check out the APRS forum on the VansAirforce forum: http://www.vansairforce.com/community/forumdisplay.php?f=104 You can read about the installation of an APRS tracker in my plane: http://home.hiwaay.net/~sbuc/journal/tracker.htm And the August issue of KitPlanes magazine has an article I wrote about aviation APRS. Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Date: Sep 07, 2008
> The reality is we have to get the new unit, otherwise we will not > have any communication incase of accident etc... I better star > saving for the $800 or so... WRONG!!!!!!!!! I have no intent to get a 406 MHz ELT at this time. I have an unreliable 121.5 MHz ELT. I have a 406 MHz PLB (GPS enabled) I intend to get an APRS system. The later two offer better "services" that the 121.5 MHz ELT in my opinion. Ron Lee ________________________________________________________________________________
Date: Sep 07, 2008
You only need 406 if you want to fly in Canada or parts of Mexico. Not required for US at this time. Tim Bryan wrote: > > > I really hate this! That is my fuel budget for several months. > > Tim Bryan > RV-6 Flying > N616TB over 100 hours now > > ________________________________________________________________________________
Date: Sep 07, 2008
Subject: My Interpretation Of Tip Installation...
Dear Listers, Today marks the completion of my RV-8 Tail including all of the fiberglassing and tip installation. I had asked the List a while back about filling the backs of the tips on the Vert/Horz Stabs and got some great feedback. I used some hard foam and built a "dam" and glassed the inside then rapped the outside with tape and filled with resin/flockedcotton and then sanded it down to the right size. Worked great and the next time I could do the whole thing in a couple of days. Rather than glassing over the whole end of the surface onto the fiberglass tips, I opted to just mount using screws and platenuts and only glassed AL-to-tip on the Elevator counterbalances where necessary. They came out very nice I think with minimal fuss and muss. Since the Rudder bottom and Fin Top had to be removable for access to wiring, I decided that I wanted everything to look the same and so I used the screws and platenuts throughout. Really didn't add that much weight and allows for tip removal down the road without paint damage. The mount for the VOR/GS/LOC antenna on the Vert Stab came out very nice I think and is very solid. I definitely learned a lot about fiberglassing in the last couple of weeks as well as gel-coating. Lots of pictures attached. Best regards, Matt Dralle RV-8 #82880 - N844RV (res) ________________________________________________________________________________
Date: Sep 08, 2008
Subject: RV-6 / 6a kit for sale
RV-6 / 6a kit for sale. Empennage: Complete except for fiberglass tips. Includes electric elevator trim kit. All parts are alodined and primed with Marhyde primer. Wings & Phlogiston Spar: Both skeletons fully assembled. Top skins riveted. Both tanks are complete and sealed. Flaps and ailerons complete, but not fitted. Includes electric aileron trim kit. All parts are alodined and primed with Deft epoxy primer (Mil-P-23377G). Both kits are the pre-punched versions purchased in 1997 & 1998 by myself. Construction is excellent. Preview plans and Orndorff videos are included for both kits. Detailed photos are available upon request. Must sell. The first $3750 takes it all. Buyer arranges transportation. If all items were purchased separately the price would be more than $6500 for the unassembled kits. Regards, Scott Kuebler Buffalo, NY 716-510-0318- cell scottam65(at)gmail.com ________________________________________________________________________________
Subject: NE Builders Forum with RV's +++ this weekend
Date: Sep 08, 2008
Reminder it is this Friday-Saturday and ending with Sunday Pancake Breakfast. Sept 12-13-14.? NE Builders forum, used to be RV only dedicated but it has expanded. Last year there was hands on wood rib building, hands on MIG welding and saftey wiring. 2 Tech Advisors manning those and numerous other houlry presentors in main classroom. KFZY Oswego County NY EAA 486. http://www.eaachapter486.com/ See photos & past details on the website. Mike Seager and Van's Factory RV7 to attend give lessons. EAA lodge ammenities & simple camping on field allowed. Hope to see you there... Regards David McManmon RV6 Builder-pilot. ________________________________________________________________________________
Subject: Canopy Cover
Date: Sep 09, 2008
Light weight RV-8 canopy cover For Sale. Excellent condition. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy 704-362-0005 Home 704-281-7884 Cell ________________________________________________________________________________
Date: Sep 09, 2008
Subject: Hangar available: Manassas, VA
My hangar mate is moving out. I'm looking for an RV builder to share the space and rent. Beautiful new hangar with insulation, heat, electricity at HEF. $300 per month. Randy RV-6A 800+ hours ________________________________________________________________________________
Date: Sep 10, 2008
Subject: Re: Engine monitor question..
bert murillo wrote: > Question to those who have the Grand rapids, Engine Monitor... > > I notice that when I set the Rpm,,,numbers, they never remain steady.... > > example if I pull down to 1700 RPM it goes up and down, is that normal, any > suggestions,, does any one has this problem? > > Small fluctuations are likely quite normal, especially if you have a fixed pitch prop. Even with a constant speed prop there will be occasional 10 to 20 rpm fluctuations as the prop governor reacts to gusts, etc. Do you have a fixed pitch or constant speed prop? How large fluctuations are you seeing? -- Kevin Horton RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: Re: Canopy Cover
Date: Sep 10, 2008
They are also a perfect fit for F1s and Harmons -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3554#203554 ________________________________________________________________________________
Date: Sep 10, 2008
I have a fixed Porp Kevin:: - the fluctuation is 10 or 20 rpms... I know is not much, but I see my frien that has the old steam gauges,,, and it seems that stays steady as a rock... may be I am wrong.. - Thanks - bert --- On Wed, 9/10/08, Kevin Horton wrote: From: Kevin Horton <khorton01(at)rogers.com> Subject: Re: RV-List: Engine monitor question.. Date: Wednesday, September 10, 2008, 1:54 AM bert murillo wrote: > Question to those who have the Grand rapids, Engine Monitor... > > I notice that when I set the Rpm,,,numbers, they never remain steady... . > > example if I pull down to 1700 RPM it goes up and down, is that normal, any > suggestions,, does any one has this problem? > > Small fluctuations are likely quite normal, especially if you have a fixed pitch prop. Even with a constant speed prop there will be occasional 10 to 20 rpm fluctuations as the prop governor reacts to gusts, etc. Do you have a fixed pitch or constant speed prop? How large fluctuations are you seeing? -- Kevin Horton RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 =0A=0A=0A ________________________________________________________________________________
Date: Sep 10, 2008
Subject: FOR SALE - PRICE REDUCED: Isham RV Tool Kit with upgrades
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 Price on this set is reduced to $2200 OBO plus shipping, now including the Sioux 1/4" air drill with keyless chuck. Please reply off list if interested. Dan Brown wrote: > > For a variety of reasons, mostly relating to my being called to active > duty with the Army, I won't be able to complete my planned RV-7A. > Consequently, I'll need to sell my tools. This is the complete Isham > kit pictured at: > > http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=9 > > This kit includes a pneumatic rivet squeezer and the popular DRDT-2 > dimpling tool. > > In addition, the following extras are included: > > Screw-adjustable Rivet Squeezer Ram (a $70 value) > Avery Longeron Yoke (a $150 value) > Avery Thin-nose (no-hole) Yoke (a $140 value) > Avery back-rivet plate (a $50 value) > Avery flush swivel rivet set (a $40 value) > A couple of additional countersink cutters > Additional side-grip clecos (about 10 extra of each, IIRC) > > That's $450 in upgrades, in addition to the Isham set. All tools are in > excellent condition. The air drill is NOT, repeat NOT included; > everything else is. > > This would cost nearly $3000 for these tools ordered new. I'll take > $2500 OBO, plus shipping. If you're local to Fayetteville, NC, you can > pick up. Contact me by e-mail at dan(at)familybrown.org if interested. > Thanks for your interest! > > The following tools are included: > > DRDT-2 Dimpler* (email for delivery date on DRDT-2) > Pneumatic Rivet Squeezer (U.S.A.)* > 3 C-Yoke Installed on Squeezer (U.S.A.)* > Adjustable Set Holder for Pneumatic Squeezer (U.S.A.)* > 3X Rivet Gun with excellent teasing trigger* > EZ change spring for straight rivet sets* > EZ Change Spring for flush sets (Snap-On Ind U.S.A.)* > Swivel and Air Flow Restrictor with fine precision adjustment* > 1 Diameter Flush Rivet Set (Snap-On U.S.A.)* > 3/32 Cupped Rivet Set 3.5 (Snap-On U.S.A.)* > 1/8 Cupped Rivet Set 3.5 (Snap-On U.S.A.)* > 3/16 Cupped Rivet Set 3.5 (Snap-On U.S.A.)* > 1/8 Double Offset Rivet Set (Snap-On U.S.A.)* > Back Rivet Set* (Special Small 1/2" Diameter for RV's) > Mini-Bucking Bar, 1 lb. (Snap-On U.S.A.)* > Bulkhead Bucking Bar (Snap-On U.S.A.)* > Footed Bucking Bar (Snap-On U.S.A.)* > Microstop Countersink Unit, needle-bearing, non-chattering (U.S.A.)* > #40 Countersink Bit, 3/32 (Snap-On U.S.A.)* > #30 Countersink Bit, for 1/8 & #6 Screw (Snap-On U.S.A.)* > #8 Countersink Bit, #8 Screw (Snap-On U.S.A.)* > #10 Countersink Bit, #10 Screw (Snap-On U.S.A.)* > Left Cut Snips, easy to use offset type (Klein Tools U.S.A.)* > Right Cut Snips, easy to use offset type (Klein Tools U.S.A.)* > Straight Cut Snips, easy to use offset type (Klein Tools U.S.A.)* > #40 Aviation Cobalt Drill Bits for 3/32 rivets, 8 each > #30 Aviation Cobalt Drill Bits for 1/8 rivets, 6 each > #27 Aviation Cobalt Drill Bit > #21 Aviation Cobalt Drill Bit > #19 Aviation Cobalt Drill Bit > #12 Aviation Cobalt Drill Bit > 1/4" Aviation Cobalt Drill Bit > 12 Aviation Extra Long #40 Drill Bit > 12 Aviation Extra Long #30 Drill Bit > Deburr Tool, Speed Handle Type for small & large holes (U.S.A.)* > Cleco Pliers* > 4 Cleco Clamps, 1/2" (Calif Assoc Prod or Zephyr U.S.A.)* > 4 Cleco Clamps, 1 (Calif Assoc Prod or Zephyr U.S.A.)* > Pop Rivet Tool, Professional Heavy-Duty unit with Swivel Head* > 3/32" Universal Cupped Squeezer Set (Snap-On U.S.A.)* > 1/8 Universal Cupped Squeezer Set (Snap-On U.S.A.)* > 5/32" Universal Cupped Squeezer Set (Snap-On U.S.A.)* > 3/16 Universal Cupped Squeezer Set (Snap-On U.S.A.)* > Flat Squeezer Set 1/8 (Snap-On U.S.A.)* > Flat Squeezer Set 1/4" (Snap-On U.S.A.)* > Flat Squeezer Set 3/8 (Snap-On U.S.A.)* > Flat Squeezer Set 1/2" (Snap-On U.S.A.)* > 3/32 Rivet Dimple Die (Springback U.S.A.)* > 1/8 Rivet Dimple Die (Springback U.S.A.)* > 5/32" Dimple Die* > 3/16" - #10 Screw Dimple Die* > #8 Screw Dimple Die* > #6 Screw Dimple Die* > Squeezer Set Organizer* > Squeezer Set Adjustment Washers * > Stainless Steel Rule, 12* > Unibit 1/4" - 3/4" by 1/16ths, (Klein U.S.A.)* > 3 Permanent Markers, Sharpie > 1/2 x 1 Reducers for 3M Wheel* > 325 Cleco Fasteners, 3/32 (Calif Assoc Prod or Zephyr U.S.A.)* > 175 Cleco Fasteners, 1/8 (Calif Assoc Prod or Zephyr U.S.A.)* > 10 Cleco Fasteners, 5/32" (Calif Assoc Prod or Zephyr U.S.A.)* > 10 Cleco Fasteners, 3/16 (Calif Assoc Prod or Zephyr U.S.A.)* > Edge Deburring Tool, Hex Swivel type* > Fluting Pliers, Smooth Flute Nylon Jaws* > Fluting Pliers, Deep V Nylon Jaws* > Rivet Cutter* > Air Tool Oil > Drill Stop Set of 4 with Allen Wrench* > Rivet Set DOTS, Easier than Rivet Tape > 3/32 Pop Rivet Dimple Die, Springback (U.S.A.)* > 1/8 Pop Rivet Dimple Die, Springback (U.S.A.)* > Hand Seamer (Klein Tools U.S.A.)* > 3/32 Drive Pin Punch (Klein Tools U.S.A.)* > 1/8 Drive Pin Punch (Klein Tools U.S.A.)* > Scotch Brite Hand Pads, 4 each > Rivet Length Gauge* > Rivet Shop Head Gauge, 4-piece* > - -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.1 (MingW32) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFIyFctyQGUivXxtkERAp4TAKCIURWWxSCdzkPhXv8bVtTYvNrbSQCdEkNc 3RPVti0x0O3Cne/DzKFYcNU =Xmss -----END PGP SIGNATURE----- ________________________________________________________________________________
Subject: Aeroshell 5 or 6
Date: Sep 10, 2008
Which one of these two greases is better suited for use in wheel bearings. From the site, it looks like #5 but in my plans, Vans says to use #6... Or is there something better altogether? -------- Andrew Rayhill RV-10 40078 Phoenix Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3749#203749 ________________________________________________________________________________
Date: Sep 10, 2008
Subject: Re: Aeroshell 5 or 6
I'm no where that far along in the build process..........but, for grins, I own a Mooney M20E which is 1644 lbs empty, 2575 gross, and it specifies Aeroshell #5 for wheel bearings. #6 is lighter. I've had it in Phoenix for 10 years, with no issues on the wheel bearings using #5. Given our dry heat, I'd be inclined to use #5 unless I got a very good explanation why #6 was recommended. Kelly RV10 40866 CHD AndrewTR30 wrote: > > Which one of these two greases is better suited for use in wheel bearings. From the site, it looks like #5 but in my plans, Vans says to use #6... > Or is there something better altogether? > > -------- > Andrew Rayhill > RV-10 40078 > Phoenix > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3749#203749 > > > ________________________________________________________________________________
Date: Sep 11, 2008
With a fixed pitch prop, if the throttle and mixture settings are fixed, the engine rpm will depend on the airspeed and altitude. But, there are always small variations in airspeed and altitude, and that leads to small variations in rpm. Those variations occur no matter what type of engine instruments you have, but they are much harder to see on old steam gauges. What you are seeing sounds very normal. Kevin bert murillo wrote: > I have a fixed Porp Kevin:: > > the fluctuation is 10 or 20 rpms... I know is not much, but I see my frien that > has the old steam gauges,,, and it seems that stays steady as a rock... maybe > I am wrong.. > > Thanks > > bert > > --- On Wed, 9/10/08, Kevin Horton wrote: > > From: Kevin Horton <khorton01(at)rogers.com> > Subject: Re: RV-List: Engine monitor question.. > To: rv-list(at)matronics.com > Date: Wednesday, September 10, 2008, 1:54 AM > > > bert murillo wrote: > >> Question to those who have the Grand rapids, Engine Monitor... >> >> I notice that when I set the Rpm,,,numbers, they never remain steady.... >> >> example if I pull down to 1700 RPM it goes up and down, is that normal, >> > any > >> suggestions,, does any one has this problem? >> >> >> > Small fluctuations are likely quite normal, especially if you have a > fixed pitch prop. Even with a constant speed prop there will be > occasional 10 to 20 rpm fluctuations as the prop governor reacts to > gusts, etc. > > Do you have a fixed pitch or constant speed prop? How large > fluctuations are you seeing? > > ________________________________________________________________________________
Date: Sep 11, 2008
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
My Cleveland wheels had a sticker on them when they were new that said they put Aeroshell 22 in the bearing at the factory, so that is what I use. ---- Surfing the web from Hopkinsville, KY Visit my website at: http://www.geocities.com/hester-hoptown/RVSite/ AndrewTR30 wrote: > > Which one of these two greases is better suited for use in wheel bearings. From the site, it looks like #5 but in my plans, Vans says to use #6... > Or is there something better altogether? > > -------- > Andrew Rayhill > RV-10 40078 > Phoenix > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3749#203749 > > > ________________________________________________________________________________
Date: Sep 11, 2008
- Thanks Kevin for the info. - I feel- better, knowing that is nothing wrong with the Instrument... now if I can get my Nav Aid to work.... - Bert - rv6a --- On Thu, 9/11/08, Kevin Horton wrote: From: Kevin Horton <khorton01(at)rogers.com> Subject: Re: RV-List: Engine monitor question.. Date: Thursday, September 11, 2008, 2:28 AM With a fixed pitch prop, if the throttle and mixture settings are fixed, the engine rpm will depend on the airspeed and altitude. But, there are always small variations in airspeed and altitude, and that leads to small variations in rpm. Those variations occur no matter what type of engine instruments you have, but they are much harder to see on old steam gauges. What you are seeing sounds very normal. Kevin bert murillo wrote: > I have a fixed Porp Kevin:: > > the fluctuation is 10 or 20 rpms... I know is not much, but I see my frie n that > has the old steam gauges,,, and it seems that stays steady as a rock... maybe > I am wrong.. > > Thanks > > bert > > --- On Wed, 9/10/08, Kevin Horton wrote: > > From: Kevin Horton <khorton01(at)rogers.com> > Subject: Re: RV-List: Engine monitor question.. > To: rv-list(at)matronics.com > Date: Wednesday, September 10, 2008, 1:54 AM > > > bert murillo wrote: > >> Question to those who have the Grand rapids, Engine Monitor... >> >> I notice that when I set the Rpm,,,numbers, they never remain steady.... >> >> example if I pull down to 1700 RPM it goes up and down, is that normal, >> > any > >> suggestions,, does any one has this problem? >> >> >> > Small fluctuations are likely quite normal, especially if you have a > fixed pitch prop. Even with a constant speed prop there will be > occasional 10 to 20 rpm fluctuations as the prop governor reacts to > gusts, etc. > > Do you have a fixed pitch or constant speed prop? How large > fluctuations are you seeing? > > =0A=0A=0A ________________________________________________________________________________
Date: Sep 11, 2008
Subject: Re: Efis Question
bert murillo wrote: > Bobby : Again thanks for the reply.. have a question, do you have any schematic > drawing shoing the wiring, the way you did it? > > It would be a great help to see how it is done... > > thanks > Bert Dynon installation manual with all wiring schematics and pinouts can be downloaded here: http://www.dynonavionics.com/downloads/Install_Guides/EFIS-D10A%20Installation%20Guide.pdf In particular see section 2, "Wiring Overview". Sam Buchanan ________________________________________________________________________________
Date: Sep 11, 2008
Sam: Thanks for the info.-- One question, when I make the harness,- a t least I hope I can,,, hate to pay $200 plus for one....is better to use all the pin s, that is connect all 25 wires, even if I do not need them... or should I sav e myself a lot of work, and use only the minimun required.. to connect the unit.... - your suggestions will be appreciated as always. - Bert rv6a --------- --- On Thu, 9/11/08, Sam Buchanan wrote: From: Sam Buchanan <sbuc(at)hiwaay.net> Subject: Re: RV-List: Efis Question Date: Thursday, September 11, 2008, 2:51 PM bert murillo wrote: > Bobby : Again thanks for the reply.. have a question, do you have any schematic > drawing shoing the wiring, the way you did it? > > It would be a great help to see how it is done... > > thanks > Bert Dynon installation manual with all wiring schematics and pinouts can be downloaded here: http://www.dynonavionics.com/downloads/Install_Guides/EFIS-D10A%20Installat ion%20Guide.pdf In particular see section 2, "Wiring Overview". Sam Buchanan =0A=0A=0A ________________________________________________________________________________
Date: Sep 11, 2008
Subject: Re: FOR SALE - PRICE REDUCED: Isham RV Tool Kit with upgrades
I don't need the tool kit but good luck to you in the Army and thank you for your service. Best regards, Rick Lundin --- On Wed, 9/10/08, Dan Brown wrote: > From: Dan Brown <dan(at)familybrown.org> > Subject: RV-List: FOR SALE - PRICE REDUCED: Isham RV Tool Kit with upgrades > To: rv-list(at)matronics.com > Date: Wednesday, September 10, 2008, 7:24 PM > > > -----BEGIN PGP SIGNED MESSAGE----- > Hash: SHA1 > > Price on this set is reduced to $2200 OBO plus shipping, > now including > the Sioux 1/4" air drill with keyless chuck. Please > reply off list if > interested. > > Dan Brown wrote: > > > > > For a variety of reasons, mostly relating to my being > called to active > > duty with the Army, I won't be able to complete my > planned RV-7A. > > Consequently, I'll need to sell my tools. This is > the complete Isham > > kit pictured at: > > > > > http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=9 > > > > This kit includes a pneumatic rivet squeezer and the > popular DRDT-2 > > dimpling tool. > > > > In addition, the following extras are included: > > > > Screw-adjustable Rivet Squeezer Ram (a $70 value) > > Avery Longeron Yoke (a $150 value) > > Avery Thin-nose (no-hole) Yoke (a $140 value) > > Avery back-rivet plate (a $50 value) > > Avery flush swivel rivet set (a $40 value) > > A couple of additional countersink cutters > > Additional side-grip clecos (about 10 extra of each, > IIRC) > > > > That's $450 in upgrades, in addition to the Isham > set. All tools are in > > excellent condition. The air drill is NOT, repeat NOT > included; > > everything else is. > > > > This would cost nearly $3000 for these tools ordered > new. I'll take > > $2500 OBO, plus shipping. If you're local to > Fayetteville, NC, you can > > pick up. Contact me by e-mail at dan(at)familybrown.org > if interested. > > Thanks for your interest! > > > > The following tools are included: > > > > DRDT-2 Dimpler* (email for delivery date on DRDT-2) > > Pneumatic Rivet Squeezer (U.S.A.)* > > 3 C-Yoke Installed on Squeezer (U.S.A.)* > > Adjustable Set Holder for Pneumatic Squeezer (U.S.A.)* > > 3X Rivet Gun with excellent teasing trigger* > > EZ change spring for straight rivet sets* > > EZ Change Spring for flush sets (Snap-On Ind U.S.A.)* > > Swivel and Air Flow Restrictor with fine precision > adjustment* > > 1 Diameter Flush Rivet Set (Snap-On U.S.A.)* > > 3/32 Cupped Rivet Set 3.5 (Snap-On U.S.A.)* > > 1/8 Cupped Rivet Set 3.5 (Snap-On U.S.A.)* > > 3/16 Cupped Rivet Set 3.5 (Snap-On U.S.A.)* > > 1/8 Double Offset Rivet Set (Snap-On U.S.A.)* > > Back Rivet Set* (Special Small 1/2" Diameter for > RV's) > > Mini-Bucking Bar, 1 lb. (Snap-On U.S.A.)* > > Bulkhead Bucking Bar (Snap-On U.S.A.)* > > Footed Bucking Bar (Snap-On U.S.A.)* > > Microstop Countersink Unit, needle-bearing, > non-chattering (U.S.A.)* > > #40 Countersink Bit, 3/32 (Snap-On U.S.A.)* > > #30 Countersink Bit, for 1/8 & #6 Screw > (Snap-On U.S.A.)* > > #8 Countersink Bit, #8 Screw (Snap-On U.S.A.)* > > #10 Countersink Bit, #10 Screw (Snap-On U.S.A.)* > > Left Cut Snips, easy to use offset type (Klein Tools > U.S.A.)* > > Right Cut Snips, easy to use offset type (Klein Tools > U.S.A.)* > > Straight Cut Snips, easy to use offset type (Klein > Tools U.S.A.)* > > #40 Aviation Cobalt Drill Bits for 3/32 rivets, 8 > each > > #30 Aviation Cobalt Drill Bits for 1/8 rivets, 6 > each > > #27 Aviation Cobalt Drill Bit > > #21 Aviation Cobalt Drill Bit > > #19 Aviation Cobalt Drill Bit > > #12 Aviation Cobalt Drill Bit > > 1/4" Aviation Cobalt Drill Bit > > 12 Aviation Extra Long #40 Drill Bit > > 12 Aviation Extra Long #30 Drill Bit > > Deburr Tool, Speed Handle Type for small & large > holes (U.S.A.)* > > Cleco Pliers* > > 4 Cleco Clamps, 1/2" (Calif Assoc Prod or Zephyr > U.S.A.)* > > 4 Cleco Clamps, 1 (Calif Assoc Prod or Zephyr > U.S.A.)* > > Pop Rivet Tool, Professional Heavy-Duty unit with > Swivel Head* > > 3/32" Universal Cupped Squeezer Set (Snap-On > U.S.A.)* > > 1/8 Universal Cupped Squeezer Set (Snap-On U.S.A.)* > > 5/32" Universal Cupped Squeezer Set (Snap-On > U.S.A.)* > > 3/16 Universal Cupped Squeezer Set (Snap-On > U.S.A.)* > > Flat Squeezer Set 1/8 (Snap-On U.S.A.)* > > Flat Squeezer Set 1/4" (Snap-On U.S.A.)* > > Flat Squeezer Set 3/8 (Snap-On U.S.A.)* > > Flat Squeezer Set 1/2" (Snap-On U.S.A.)* > > 3/32 Rivet Dimple Die (Springback U.S.A.)* > > 1/8 Rivet Dimple Die (Springback U.S.A.)* > > 5/32" Dimple Die* > > 3/16" - #10 Screw Dimple Die* > > #8 Screw Dimple Die* > > #6 Screw Dimple Die* > > Squeezer Set Organizer* > > Squeezer Set Adjustment Washers * > > Stainless Steel Rule, 12* > > Unibit 1/4" - 3/4" by 1/16ths, (Klein > U.S.A.)* > > 3 Permanent Markers, Sharpie > > 1/2 x 1 Reducers for 3M Wheel* > > 325 Cleco Fasteners, 3/32 (Calif Assoc Prod or > Zephyr U.S.A.)* > > 175 Cleco Fasteners, 1/8 (Calif Assoc Prod or > Zephyr U.S.A.)* > > 10 Cleco Fasteners, 5/32" (Calif Assoc Prod or > Zephyr U.S.A.)* > > 10 Cleco Fasteners, 3/16 (Calif Assoc Prod or > Zephyr U.S.A.)* > > Edge Deburring Tool, Hex Swivel type* > > Fluting Pliers, Smooth Flute Nylon Jaws* > > Fluting Pliers, Deep V Nylon Jaws* > > Rivet Cutter* > > Air Tool Oil > > Drill Stop Set of 4 with Allen Wrench* > > Rivet Set DOTS, Easier than Rivet Tape > > 3/32 Pop Rivet Dimple Die, Springback (U.S.A.)* > > 1/8 Pop Rivet Dimple Die, Springback (U.S.A.)* > > Hand Seamer (Klein Tools U.S.A.)* > > 3/32 Drive Pin Punch (Klein Tools U.S.A.)* > > 1/8 Drive Pin Punch (Klein Tools U.S.A.)* > > Scotch Brite Hand Pads, 4 each > > Rivet Length Gauge* > > Rivet Shop Head Gauge, 4-piece* > > > > - -- > Dan Brown, KE6MKS, dan(at)familybrown.org > "Since all the world is but a story, it were well for > thee to buy the > more enduring story rather than the story that is less > enduring." > -- The Judgment of St. Colum Cille > -----BEGIN PGP SIGNATURE----- > Version: GnuPG v1.2.1 (MingW32) > Comment: Using GnuPG with Mozilla - > http://enigmail.mozdev.org > > iD8DBQFIyFctyQGUivXxtkERAp4TAKCIURWWxSCdzkPhXv8bVtTYvNrbSQCdEkNc > 3RPVti0x0O3Cne/DzKFYcNU > =Xmss > -----END PGP SIGNATURE----- > ________________________________________________________________________________
Date: Sep 11, 2008
bert murillo wrote: > Sam: Thanks for the info. One question, when I make the harness, > at least I hope I can,,, hate to pay $200 plus for one....is better > to use all the pins, that is connect all 25 wires, even if I do not > need them... or should I save myself a lot of work, and use only the > minimun required.. to connect the unit.... > > your suggestions will be appreciated as always. > > Bert rv6a Bert, I would use only the pins necessary to make the connections you need. Sam Buchanan ________________________________________________________________________________
Date: Sep 12, 2008
Anyone know if these numbers mean viscosity? would they be like wire , biger number thiner, or vice/versa? Charlie ________________________________________________________________________________
Date: Sep 12, 2008
Charlie, The higher the number the thicker the grease. Normally, a #2 is the most common viscosity you will find. It goes down- #1, 0, 00, 000, then it goes to heavy oils. "Drop point" temperature is more critical for our wheel bearings. Our bearings get hot (altho for a short time) so the higher the drop point temp the better it is for us. This means that if you put a "blob" of grease on a steel plate and put it vertical and heat it, what temp will the grease begin to slide down the plate and off the steel plate. The synthetic based greases are prefered as they have the highest drop point temps while maintaining their viscosity. I sell regular #2 grease that has a drop point around 300* and a synthetic that is also a viscosity #2 that has a drop point temp of 560*. Needless to say I use the synthetic based greases. The side bar on the synthetic greases is they are "water proof" vs: regular grease that will absorb the water and thus put the water in direct contact with the bearing. Rust occurs even tho you use regular grease. The synthetic based greases will not absorb water. I live in the Florida area with lots of trailers that haul boats in and out of the ocean. You can see real quick what works and what does not. Jim Nelson RV9-A N15JN ____________________________________________________________ Dreaming of getting away? Click here for an island experience in Hawaii. http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3nKLOkLZEILgh2wQmZ0yTepHPH9cmbiNAUpUZj9uwiZzJA4D/ ________________________________________________________________________________
Date: Sep 12, 2008
Jim, your note on grease peaked my interest. Do you have any brand names of the synthetic wheel bearing grease suitable for the RV wheel bearings you'd care to share?? Thanks Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: Friday, September 12, 2008 9:36 AM Subject: RV-List: Aeroshell 5 or 6 Charlie, The higher the number the thicker the grease. Normally, a #2 is the most common viscosity you will find. It goes down- #1, 0, 00, 000, then it goes to heavy oils. "Drop point" temperature is more critical for our wheel bearings. Our bearings get hot (altho for a short time) so the higher the drop point temp the better it is for us. This means that if you put a "blob" of grease on a steel plate and put it vertical and heat it, what temp will the grease begin to slide down the plate and off the steel plate. The synthetic based greases are prefered as they have the highest drop point temps while maintaining their viscosity. I sell regular #2 grease that has a drop point around 300* and a synthetic that is also a viscosity #2 that has a drop point temp of 560*. Needless to say I use the synthetic based greases. The side bar on the synthetic greases is they are "water proof" vs: regular grease that will absorb the water and thus put the water in direct contact with the bearing. Rust occurs even tho you use regular grease. The synthetic based greases will not absorb water. I live in the Florida area with lots of trailers that haul boats in and out of the ocean. You can see real quick what works and what does not. Jim Nelson RV9-A N15JN ____________________________________________________________ Dreaming of getting away? Click here for an island experience in Hawaii. http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3nKLOkLZEILgh2wQmZ0yTepHPH 9cmbiNAUpUZj9uwiZzJA4D/ __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Sep 12, 2008
Thanks - bert --- On Thu, 9/11/08, Sam Buchanan wrote: From: Sam Buchanan <sbuc(at)hiwaay.net> Subject: Re: RV-List: Efis Question Date: Thursday, September 11, 2008, 11:16 PM bert murillo wrote: > Sam: Thanks for the info. One question, when I make the harness, > at least I hope I can,,, hate to pay $200 plus for one....is better > to use all the pins, that is connect all 25 wires, even if I do not > need them... or should I save myself a lot of work, and use only the > minimun required.. to connect the unit.... > > your suggestions will be appreciated as always. > > Bert rv6a Bert, I would use only the pins necessary to make the connections you need. Sam Buchanan =0A=0A=0A ________________________________________________________________________________
Date: Sep 12, 2008
Subject: Synthetic grease
Hi Ed and all, I sell the Castrol brand. However, any of the major brands that say it is "synthetic based" will do fine. The spec sheet tells the drop point. My brand says it is 560*. If it doesn't say its synthetic based, then it probably is not. I run across "marine" grease but that does not tell you anything. Its a regular soap based lubricant. And you say "soap based"??? Yup, most regular grease is soap based. I use the test to see if its synthetic by putting a blob in my hand. Then I put water on it and swirl and press it and try to mix the two products. Its called "homogenation" and if I can make the water disappear in the grease, its regular grease. A synthetic based grease will not let you mix the water into the grease. It just pops back on the top of the grease blob. A neat test. Jim ____________________________________________________________ See Mexico for less! Click now for great vacation deals! http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3mqbsf5YgonuCEuxVazu6Wx8nhhwgdWBRFr9dzWEX6Cs4y7J/ ________________________________________________________________________________
Subject: Hangar Sale
Date: Sep 12, 2008
Hangar Sale More information and photos on request: Light Speed Thirty 3 G Headset, like new, one year old. $250 + Shipping Light Weight In Ear Auri Comm Aviation Headset by Quiet Technologies. The ladies love it because it does not mess up their hair. $125 + Shipping Avery Hand Dimpling C Type Tool 1001 $ 90 + Shipping Avery Hand Rivet Squeezer with 1 , 2 , and 4 yokes, 1 yoke modified for tight spots like the end of trim tabs, with a set of dimple and rivet dies. $220 + Shipping 3x Rivet Gun with all riveting accessories and 2 bucking bars $100 + Shipping Nesco 420 3/8 Pistol Grip Air Drill, with countersink bit. $ 75 + Shipping Bogart Tow Bar for RV Tailwheel Airplanes $ 40 + Shipping 0-360 Engine Drive Fuel Pump, like new $ 50 + Shipping Direct Reading Fuel Pressure Gauge, great for testing and other $ 30 + Shipping inch torque wrench $ 30 + Shipping Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy willfly(at)carolina.rr.com 704-362-0005 Home 704-281-7884 Cell ________________________________________________________________________________
Date: Sep 12, 2008
Subject: Re: Looking for dipstick & tube
We have several Lycoming metal dipstick tubes these are blems from the factory, ie. top where dipstick screws in with non concentric flange. These were given to us by a fellow who used to work at lycoming, they are 11" from top flange to flange at crankcase, 12.125 overall, send name and address you pay freight till they are gone. Jess In a message dated 9/12/2008 1:50:50 P.M. Pacific Daylight Time, n212pj(at)gmail.com writes: --> RV-List message posted by: "John Jessen" I'm looking for a tube myself. Got two? John Jessen Do not archive -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Darrell Reiley Sent: Monday, September 01, 2008 4:28 PM Subject: Re: RV-List: Looking for dipstick & tube --> Mark, I've got a a Lycoming oil dip stick extention in the truck I believe. Darrell --- On Mon, 9/1/08, Fiveonepw(at)aol.com wrote: > From: Fiveonepw(at)aol.com <Fiveonepw(at)aol.com> > Subject: RV-List: Looking for dipstick & tube > To: rv-list(at)matronics.com > Date: Monday, September 1, 2008, 5:49 PM Howdy, y'all- > > My E3D came with a modified (shortened) oil dipstick and tube, and I'd > like to replace them with the correct parts, specifically > LW-14735 (stick), 75736 > (tube) -part#s from Lycoming parts manual- and have wasted about 2 > hours > googling- tried e-bay, Wentworth, broad search queries etc. > with no joy. Not > much help digging through current Trade-a-plane either. > > Suggestions? > > Thanks! > Mark > > > > **************It's only a deal if it's where you want to go. Find your > travel > deal here. > (http://information.travel.aol.com/deals?ncid=aoltrv00050000000047) **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Date: Sep 12, 2008
Hi Steve: I just talked to you on the phone. I will take the Lightspeed he adset for $250.00. My address is 15315 Kelly Street=2C Spring Lake=2C MI 49 456. My name is Steve Kiekover. Cell # 616-402-0038. Thanks Steve> Fr om: willfly(at)carolina.rr.com> To: rv-list(at)matronics.com> Subject: RV-List: H angar Sale> Date: Fri=2C 12 Sep 2008 16:10:16 -0400> > --> RV-List message posted by: "Steve Glasgow" > > Hangar Sale> > > > More information and photos on request:> > > > Light Speed Thirty 3 G Heads et=2C like new=2C one year old. > $250 + Shipping> > > > Light Weight In Ea r Auri Comm Aviation Headset by Quiet Technologies.> > The ladies love it b ecause it does not mess up their hair. > $125 + Shipping> > > > Avery Hand Dimpling =93C Type=94 Tool 1001 > $ 90 + Shipping> > > > Avery Hand Rivet S queezer with 1 =BD=2C 2 =BD=2C and 4=94 yokes=2C> > 1 =BD yoke modified for tight spots like the end of trim tabs=2C> > with a set of dimple and rivet dies. > $220 + Shipping> > > > 3x Rivet Gun with all riveting accessories and 2 bucking bars > $100 + Shipping> > > > Nesco 420 3/8 Pistol Grip Air D rill=2C with countersink bit. > $ 75 + Shipping> > > > Bogart Tow Bar for R V Tailwheel Airplanes > $ 40 + Shipping> > > > 0-360 Engine Drive Fuel Pump =2C like new > $ 50 + Shipping> > > > Direct Reading Fuel Pressure Gauge=2C great for testing and other > $ 30 + Shipping> > > > =BC inch torque wrenc h > $ 30 + Shipping> > > > Steve Glasgow-Cappy> N123SG RV-8> Cappy's Toy> > willfly(at)carolina.rr.com> 704-362-0005 Home> 704-281-7884 Cell> > > > > > > =============> > > _________________________________________________________________ Want to do more with Windows Live? Learn =9310 hidden secrets=94 from Jamie . http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!5 50F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008 ________________________________________________________________________________
Date: Sep 12, 2008
I am interested in your 1/4" torque wrench. What type is it (Beam, click, dial)? What range? Brand? Model? Thanks, Mike McKenna -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Steve Kiekover Sent: Friday, September 12, 2008 5:17 PM To: rv-list(at)matronics.com Subject: RE: RV-List: Hangar Sale Hi Steve: I just talked to you on the phone. I will take the Lightspeed headset for $250.00. My address is 15315 Kelly Street, Spring Lake, MI 49456. My name is Steve Kiekover. Cell # 616-402-0038. Thanks Steve > From: willfly(at)carolina.rr.com > To: rv-list(at)matronics.com > Subject: RV-List: Hangar Sale > Date: Fri, 12 Sep 2008 16:10:16 -0400 > > > Hangar Sale > > > > More information and photos on request: > > > > Light Speed Thirty 3 G Headset, like new, one year old. > $250 + Shipping > > > > Light Weight In Ear Auri Comm Aviation Headset by Quiet Technologies. > > The ladies love it because it does not mess up their hair. > $125 + Shipping > > > > Avery Hand Dimpling C Type Tool 1001 > $ 90 + Shipping > > > > Avery Hand Rivet Squeezer with 1 , 2 , and 4 yokes, > > 1 yoke modified for tight spots like the end of trim tabs, > > with a set of dimple and rivet dies. > $220 + Shipping > > > > 3x Rivet Gun with all riveting accessories and 2 bucking bars > $100 + Shipping > > > > Nesco 420 3/8 Pistol Grip Air Drill, with countersink bit. > $ 75 + Shipping > > > > Bogart Tow Bar for RV Tailwheel Airplanes > $ 40 + Shipping > > > > 0-360 Engine Drive Fuel Pump, like new > $ 50 + Shipping > > > > Direct Reading Fuel Pressure Gauge, great for testing and other > $ 30 + Shipping > > > > inch torque wrench > $ 30 + Shipping > > > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > willfly(at)carolina.rr.com > 704-362-0005 Home > 704-281-7884 Cell > > > > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------------------------- -- Want to do more with Windows Live? Learn 10 hidden secrets from Jamie. Learn Now ________________________________________________________________________________
Date: Sep 12, 2008
Thanks Jim, appreciate you sharing your knowledge. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: Friday, September 12, 2008 12:00 PM Subject: RV-List: Synthetic grease Hi Ed and all, I sell the Castrol brand. However, any of the major brands that say it is "synthetic based" will do fine. The spec sheet tells the drop point. My brand says it is 560*. If it doesn't say its synthetic based, then it probably is not. I run across "marine" grease but that does not tell you anything. Its a regular soap based lubricant. And you say "soap based"??? Yup, most regular grease is soap based. I use the test to see if its synthetic by putting a blob in my hand. Then I put water on it and swirl and press it and try to mix the two products. Its called "homogenation" and if I can make the water disappear in the grease, its regular grease. A synthetic based grease will not let you mix the water into the grease. It just pops back on the top of the grease blob. A neat test. Jim ____________________________________________________________ See Mexico for less! Click now for great vacation deals! http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3mqbsf5YgonuCEuxVazu6Wx8nh hwgdWBRFr9dzWEX6Cs4y7J/ __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Subject: Re: Hangar Sale
Date: Sep 13, 2008
Sorry I missed out on your Light Speed headset. This whole thing saddens me. Have you decided what your next choice will be? Dale ----- Original Message ----- From: "Steve Glasgow" <willfly(at)carolina.rr.com> Sent: Friday, September 12, 2008 4:10 PM Subject: RV-List: Hangar Sale > > Hangar Sale > > > More information and photos on request: > > > Light Speed Thirty 3 G Headset, like new, one year old. $250 + Shipping > > > Light Weight In Ear Auri Comm Aviation Headset by Quiet Technologies. > > The ladies love it because it does not mess up their hair. $125 + Shipping > > > Avery Hand Dimpling C Type Tool 1001 $ 90 + Shipping > > > Avery Hand Rivet Squeezer with 1 , 2 , and 4 yokes, > > 1 yoke modified for tight spots like the end of trim tabs, > > with a set of dimple and rivet dies. $220 + Shipping > > > 3x Rivet Gun with all riveting accessories and 2 bucking bars $100 + > Shipping > > > Nesco 420 3/8 Pistol Grip Air Drill, with countersink bit. $ 75 + > Shipping > > > Bogart Tow Bar for RV Tailwheel Airplanes $ 40 + Shipping > > > 0-360 Engine Drive Fuel Pump, like new $ 50 + Shipping > > > Direct Reading Fuel Pressure Gauge, great for testing and other $ 30 + > Shipping > > > inch torque wrench $ 30 + Shipping > > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > willfly(at)carolina.rr.com > 704-362-0005 Home > 704-281-7884 Cell > > > ________________________________________________________________________________
Date: Sep 13, 2008
Subject: Fly above 8000 ft ?
If you do and are interested in flying at higher altitudes safely I have be en offered a great discount from our supplier on Checkmate Pulse Oximeters. - If enough folks (5-10) are interested we can get these for $119.95.- Sportys sells these for $169 so its a great price.- - I had my 6A up to 19,000 ft a few weeks ago and these Pulse Oximeters are a great safety tool.- - -Email me at:- bisonmountain(at)gmail.com- to get on the list.- Link t o our pulse oximeter webpage:- http://www.bisonmountainbags.com/checkmate ..html--- We have lots of other cool RV stuff if you have time to visi t.- Thanks. - Kurt www.bisonmountainbags.com bisonmountain(at)gmail.com -=0A=0A=0A ________________________________________________________________________________
From: "Stephan Servatius" <romeo.victor@t-online.de>
Subject: ACI Props
Date: Sep 13, 2008
Dear fellow builders, For my new project I try to get the Aero Composite people on the phone. I tried it a couple of times and send emails, no respond. Does anybody know what's going on there or if the business is already sold to someone else? Stephan RV8 D-EBRV 185 hrs. ________________________________________________________________________________
Date: Sep 13, 2008
Subject: Re: Fly above 8000 ft ?
<http://sedationresource.com/pilot.pdf <http://sedationresource.com/pilot.pdf>> Has pulse oximeters much cheaper. K Klewin wrote: > If you do and are interested in flying at higher altitudes safely I > have been offered a great discount from our supplier on Checkmate > Pulse Oximeters. If enough folks (5-10) are interested we can get > these for $119.95. Sportys sells these for $169 so its a great price. > > I had my 6A up to 19,000 ft a few weeks ago and these Pulse Oximeters > are a great safety tool. > > Email me at: bisonmountain(at)gmail.com > to get on the list. Link to our > pulse oximeter webpage: > http://www.bisonmountainbags.com/checkmate.html We have lots of > other cool RV stuff if you have time to visit. Thanks. > > Kurt > www.bisonmountainbags.com <http://www.bisonmountainbags.com> > bisonmountain(at)gmail.com > > > > * > > > * ________________________________________________________________________________
Date: Sep 13, 2008
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Nosewheel Breakout Force
I am installing my nosewheel (RV9A) and attempting to set the breakout force as specified in the construction manual. It seems that to get to the 14 ft-lbs (22 lbs side force) I have to crank the nut down so the two belleville washers are totally compressed! Is this correct? Second, the instructions say to temporarily safety the nut and move the fork back and forth to the stops. How are you supposed to safety the nut?? Is the fork leg supposed to be already drilled for a cotter pin? I have a reworked leg and it isn't. Thanks for your advice! Dick Tasker -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Sep 13, 2008
IIRC, mine squished down quite a bit, but not completely flattened. Once you get the breakout force set, you drill the leg for a cotter pin Brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard E. Tasker Sent: Saturday, September 13, 2008 6:12 PM Subject: RV-List: Nosewheel Breakout Force --> I am installing my nosewheel (RV9A) and attempting to set the breakout force as specified in the construction manual. It seems that to get to the 14 ft-lbs (22 lbs side force) I have to crank the nut down so the two belleville washers are totally compressed! Is this correct? Second, the instructions say to temporarily safety the nut and move the fork back and forth to the stops. How are you supposed to safety the nut?? Is the fork leg supposed to be already drilled for a cotter pin? I have a reworked leg and it isn't. Thanks for your advice! Dick Tasker -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- Checked by AVG. 2:18 PM Checked by AVG. 2:18 PM ________________________________________________________________________________
Date: Sep 13, 2008
Subject: RV-8 Nylon Flap Bolt Interference...
Dear Listers, Have a look at the attached photo. The rear predrilled holes for mounting the flap weldment nylon blocks seems to interfere with the seatbelt attachment. Am I missing something here? The blocks are drilled according to the plans and the rear holes are already drilled and have the platenut installed. Do I just added some washers above and below and call it good? Seems hokey. Notching the belt attach also seems like a poor idea. Thanks, Matt Dralle RV-8 #82880 N844RV ________________________________________________________________________________
Date: Sep 13, 2008
On another aviation list they have been discussing cheap pulse oximeters. Here's a link to two of them. One is $58 and one is $69. I haven't tried either of them so I can't say they're better than the deal you can get from Kurt. But you can't beat the price. http://www.portablenebs.com/ascent.htm http://sedationresource.com/pilot.pdf Henry H. RV-7 N79994 (borrowed from time to time) K Klewin wrote: > If you do and are interested in flying at higher altitudes safely I > have been offered a great discount from our supplier on Checkmate > Pulse Oximeters. If enough folks (5-10) are interested we can get > these for $119.95. Sportys sells these for $169 so its a great price. > > I had my 6A up to 19,000 ft a few weeks ago and these Pulse Oximeters > are a great safety tool. > > Email me at: bisonmountain(at)gmail.com > to get on the list. Link to our > pulse oximeter webpage: > http://www.bisonmountainbags.com/checkmate.html We have lots of > other cool RV stuff if you have time to visit. Thanks. > > Kurt > www.bisonmountainbags.com <http://www.bisonmountainbags.com> > bisonmountain(at)gmail.com > > > > * > > * ________________________________________________________________________________
Date: Sep 14, 2008
Subject: Re: RV-8 Nylon Flap Bolt Interference...
Matt, My nylon blocks were so poorly made, that I decided to make a proper set of replacement pieces myself. I noted the same problem you did. I counter-bored the tops of my parts to allow the use of SHCS (socket head cap screws aka Allen head bolts) to retain the flap weldment. This eliminated the interference issue you have noted. Using the SHCSs also eases future maintenance of this assembly. Charlie Kuss PS Sorry, but I never took any photos of this mod. If needed, I suppose I could take a few. --- On Sat, 9/13/08, Matt Dralle wrote: > From: Matt Dralle <dralle(at)matronics.com> > Subject: RV-List: RV-8 Nylon Flap Bolt Interference... > To: rv-list(at)matronics.com > Date: Saturday, September 13, 2008, 7:39 PM > Dear Listers, > > Have a look at the attached photo. The rear predrilled > holes for > mounting the flap weldment nylon blocks seems to interfere > with the > seatbelt attachment. Am I missing something here? The > blocks are > drilled according to the plans and the rear holes are > already drilled > and have the platenut installed. Do I just added some > washers above > and below and call it good? Seems hokey. Notching the > belt attach > also seems like a poor idea. > > Thanks, > > Matt Dralle > RV-8 #82880 N844RV ________________________________________________________________________________
Date: Sep 14, 2008
Keep in mind you will need to tighten the nut again after the first few landings and takeoffs. Make sure you get grease throughout the nose fork. Carl Froehlich RV-8A (450 hrs) RV-10 (wings) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Meyette Sent: Saturday, September 13, 2008 7:12 PM Subject: RE: RV-List: Nosewheel Breakout Force IIRC, mine squished down quite a bit, but not completely flattened. Once you get the breakout force set, you drill the leg for a cotter pin Brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard E. Tasker Sent: Saturday, September 13, 2008 6:12 PM Subject: RV-List: Nosewheel Breakout Force --> I am installing my nosewheel (RV9A) and attempting to set the breakout force as specified in the construction manual. It seems that to get to the 14 ft-lbs (22 lbs side force) I have to crank the nut down so the two belleville washers are totally compressed! Is this correct? Second, the instructions say to temporarily safety the nut and move the fork back and forth to the stops. How are you supposed to safety the nut?? Is the fork leg supposed to be already drilled for a cotter pin? I have a reworked leg and it isn't. Thanks for your advice! Dick Tasker -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- Checked by AVG. 2:18 PM Checked by AVG. 2:18 PM ________________________________________________________________________________
Subject: FAA Proposed Rule Changes
Date: Sep 14, 2008
Just my thoughts, hope it helps others who might be in the process of writing. _____ 4002 Oakridge Drive Crestwood, KY 40014 September 14, 2008 Miguel L. Vasconcelos Production and Airworthiness Division AIR-200, Room 815 800 Independence Ave., SW Washington, D.C. 20591 Reference: Proposed Policy changes regarding Certification of Amateur Built Aircraft. Dear Mr. Vasconcelos; I am a recreational aviation pilot who has built a Van's Aircraft RV-10 metal airplane, which was an educational experience for my whole family. Building this aircraft took 13 months and 9 days with the help of my wife and teenage daughters building with me full time. It was certificated in 2006 and we have flown it together all over the U.S. I will be purchasing another kit and building an airplane in the near future and am very concerned about the changes to the future 51% construction rules. I do not see a need to change the rules as they stand. This proposal is the typical response that takes place when a small percentage of individuals blatantly disregard the rules. Those types of individuals will always exist and the new rules will not prohibit their disregard. In any society, there will always be those who cross the line and the new rules will not be an exception. Those individuals who tempt fate will ultimately sponsor new and more stringent rules. The result of which, typifies treatment of the symptom and not the disease. Enforcement is the real solution, as without it, those who suffer are the ones adhering to the rules. My primary concern is that the complexities of this new policy will place significant new burdens on amateur aircraft builders and make them reluctant to participate in a market that has become an industry phenomenon. Those of us who have followed the regulations as they stand today are concerned that the daunting task of producing an airworthy craft will become secondary to a bureaucratic nightmare. This would not be in the best interest of the overall experimental market. In my lifetime, I have never witnessed a government agency's intervention actually promote the advancement of the free enterprise system. In fact, there is a basic premise that I have observed in terms of absolutes and that is; regulation is not the friend of free enterprise. Has the FAA considered the negative economic impact that these regulations could induce? It wouldn't be the first time that regulation killed or crippled an entire industry. It should be self evident that the overregulated commercial side of this industry has experienced this crippling effect. This is the primary reason the experimental market has had so much success. I fear that your proposed rule changes could have a far reaching and devastating effect on this market segment, i.e. the vendors, suppliers, and their employees and families. Please give this point of view the consideration it deserves and don't fix it if it's not broken. The rules worked well when the industry was in its infancy, they should work just as well now that it has matured. You will no doubt receive hundreds if not thousands of letters voicing concerns about this issue. Many will attempt to espouse the virtues of their changes to your proposed rules as they have already conceded that these changes are coming whether we speak out or not. I am of the belief that you are of an open mind, otherwise you would not have solicited our input. I sincerely appreciate the opportunity to submit my comments on this proposed policy change. Very Truly Yours, Jack H Sparling, Jr. ________________________________________________________________________________
Date: Sep 14, 2008
I would guess there are some cheaper models out there.- I would also surm ise that larger distributerships probably get a better price than I current ly receive.- If you can find them cheaper (with case) I say buy it...I'm an RV'r.....I know how we all shop around for the best deal.....avgas is ex pensive...I sure don't blame anyone at all.-- - Thanks to those who have visited our site.- We have had a great year with our RV Flight Bags and will have a few more new bags online in the next fe w months.- Thanks for passing the word. - Happy Building/Flying... - Cheers, - Kurt www.bisonmountainbags.com bisonmountain(at)gmail.com --- On Sat, 9/13/08, Henry wrote: From: Henry <aeroncadoc(at)comcast.net> Subject: Re: RV-List: Fly above 8000 ft ? Date: Saturday, September 13, 2008, 11:42 PM On another aviation list they have been discussing cheap pulse oximeters. Here's a link to two of them. One is $58 and one is $69. I haven't tried either of them so I can't say they're better than the deal you can get from Kurt. But you can't beat the price. http://www.portablenebs.com/ascent.htm http://sedationresource.com/pilot.pdf Henry H. RV-7 N79994 (borrowed from time to time) K Klewin wrote: > If you do and are interested in flying at higher altitudes safely I > have been offered a great discount from our supplier on Checkmate > Pulse Oximeters. If enough folks (5-10) are interested we can get > these for $119.95. Sportys sells these for $169 so its a great price. > > I had my 6A up to 19,000 ft a few weeks ago and these Pulse Oximeters > are a great safety tool. > > Email me at: bisonmountain(at)gmail.com > to get on the list. Link to our > pulse oximeter webpage: > http://www.bisonmountainbags.com/checkmate.html We have lots of > other cool RV stuff if you have time to visit. Thanks. > > Kurt > www.bisonmountainbags.com <http://www.bisonmountainbags.com> > bisonmountain(at)gmail.com > > > > * > > * =0A=0A=0A ________________________________________________________________________________
Date: Sep 14, 2008
>From VAF. I read the postings by Van and the EAA about the NPRM. Vans shows why he's the man and most of us just gawkers: "As always, name-calling and vague gripes serve no purpose other than to help convince the FAA that we are a bunch of idiots." * The proposed rule has nothing to do with accommodating pro-built planes, even though some of us, maybe including me, think that should be allowed. Probably the FAA would need a directive from Congress to address that. So no point in mentioning such potential accommodation in a response. * Van again: "Unless the FAA sees a serious safety reason, they will not re-evaluate existing kits that have previously been found to meet the major portion rule." So most of us are good now. Of course we can still comment for the sake of future kit designs, but I see no problem for future builders of today's kits. * Aside from some relatively minor changes for clarity, the only change I'd like to see is a further definition of "fabrication" and percentage: by time? by task? Unlike the EAA and others, I think the further refinement of what constitutes an amateur built aircraft is welcome, or at the very least, simply not a big deal. I find it very unlikely that a legitimate amateur builder now will not be legit with these new rules. It might be a little more onerous documenting one's work, but I think better logging of work is to the good. * My guess is that in addition to wanting to halt the blatant pro-building, the FAA wants to head off a potential future problem: well-meaning amateur builders getting more and more pre-fabbed parts until only assembly, not fabrication, is done. I think such concern is fair and even forward-thinking, contrary to some stereotyped responses here. <http://www.vansairforce.com/community/newreply.php?do=newreply&p=255316> Reply With Quote ________________________________________________________________________________
Subject: Re: FAA Proposed Rule Changes
Date: Sep 15, 2008
Well put Jack. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p 4356#204356 ________________________________________________________________________________
Date: Sep 15, 2008
Be careful about one thing- the batteries they take. I have a SPO medical pule ox that I use in the office and in the RV. I got a good deal on it, but found the lithium battery does not last the claimed 1000 readings, and in 1/2AA size, is twenty dollars a pop to replace. Get one that uses AAA's or similar inexpensive battery. Bill B On Sun, Sep 14, 2008 at 6:05 PM, K Klewin wrote: > I would guess there are some cheaper models out there. I would also > surmise that larger distributerships probably get a better price than I > currently receive. If you can find them cheaper (with case) I say buy > it...I'm an RV'r.....I know how we all shop around for the best > deal.....avgas is expensive...I sure don't blame anyone at all. > > Thanks to those who have visited our site. We have had a great year with > our RV Flight Bags and will have a few more new bags online in the next few > months. Thanks for passing the word. > > Happy Building/Flying... > > Cheers, > > Kurt > www.bisonmountainbags.com > bisonmountain(at)gmail.com > > > --- On *Sat, 9/13/08, Henry * wrote: > > From: Henry <aeroncadoc(at)comcast.net> > Subject: Re: RV-List: Fly above 8000 ft ? > To: rv-list(at)matronics.com > Date: Saturday, September 13, 2008, 11:42 PM > > > On another aviation list they have been discussing cheap pulse > oximeters. Here's a link to two of them. One is $58 and one is $69. I > haven't tried either of them so I can't say they're better than the > deal > you can get from Kurt. But you can't beat the price. > http://www.portablenebs.com/ascent.htm > > http://sedationresource.com/pilot.pdf > > > Henry H. > RV-7 N79994 (borrowed from time to time) > > K Klewin wrote: > > If you do and are interested in flying at higher altitudes safely I > > have been offered a great discount from our supplier on Checkmate > > Pulse Oximeters. If enough folks (5-10) are interested we can get > > these for $119.95. Sportys sells these for $169 so its a great price. > > > > I had my 6A up to 19,000 ft a few weeks ago and these Pulse Oximeters > > are a great safety tool. > > > > Email me at: bisonmountain(at)gmail.com > > to get on the list. Link to our > > pulse oximeter webpage: > > http://www.bisonmountainbags.com/checkmate.html We have lots of > > other cool RV stuff if you have time to visit. Thanks. > > > > Kurt > > www.bisonmountainbags.com <http://www.bisonmountainbags.com> > > bisonmountain(at)gmail.com > > > > > > > > * > > > > * > > > * > > 3D > > * > > ________________________________________________________________________________
Date: Sep 15, 2008
Subject: Re: RV-List:Pulse Oximeters was Fly above 8000 ft ?
Bill, Can you tell us which ones use commonly available batteries? Charlie Kuss --- On Mon, 9/15/08, Bill Boyd wrote: > From: Bill Boyd <sportav8r(at)gmail.com> > Subject: Re: RV-List: Fly above 8000 ft ? > To: rv-list(at)matronics.com > Date: Monday, September 15, 2008, 10:40 AM > Be careful about one thing- the batteries they take. I have a SPO > medical pule ox that I use in the office and in the RV. I got a good > deal on it, but found the lithium battery does not last the claimed 1000 > readings, and in 1/2AA size, is twenty dollars a pop to replace. Get > one that uses AAA's or similar inexpensive battery. > > Bill B snipped ________________________________________________________________________________
Date: Sep 15, 2008
Nope. Haven't researched it. I only know mine doesn't, and I wish it did :-) On Mon, Sep 15, 2008 at 12:23 PM, Charles Kuss wrote: > > Bill, > Can you tell us which ones use commonly available batteries? > Charlie Kuss > > > --- On Mon, 9/15/08, Bill Boyd wrote: > > > From: Bill Boyd <sportav8r(at)gmail.com> > > Subject: Re: RV-List: Fly above 8000 ft ? > > To: rv-list(at)matronics.com > > Date: Monday, September 15, 2008, 10:40 AM > > Be careful about one thing- the batteries they take. I have a SPO > > medical pule ox that I use in the office and in the RV. I got a good > > deal on it, but found the lithium battery does not last the claimed 1000 > > readings, and in 1/2AA size, is twenty dollars a pop to replace. Get > > one that uses AAA's or similar inexpensive battery. > > > > Bill B > snipped > > ________________________________________________________________________________
Subject: Engine-landing gear mount loose
Date: Sep 16, 2008
Warning, I was working on a project to move stuff away from my cooling outlet and observed that the four lower bolts holding my engine/landing gear mount on were in excess of 1/2 a turn loose, as in easily turnable by finger. These are cotter pinned. TTIS is 1240 on an RV-6, bolts last checked three years ago and I delayed this because I got tired of ruining good cotter pins when nothing was ever loose. So it's back to ruining cotter pins,,, I pulled a few of the bolts out and explored, but I didn't find any reason for why things got loose in the last 200 hours but didn't in the first 1000??? Also, there was a rant some time ago about AD's and how they do or don't apply to experimentals. The recent ECI Titan cylinder AD 2008-19-05 pretty much applies to any installation where that range of serial number cylinders with a specific part number are in service. While they do use the verbiage "Lycoming engines with these cylinders installed" the focus is clearly the cylinders irrespective of what you choose to call your Lycoming parallel valve engine. They also list cases of engines and aircraft where these might be found but they do not limit the AD to these groups. The focus is on those parts as installed in an airplane. If you have Titan cylinders but not those in that range or part numbers you might want to note this in the engine logs. ________________________________________________________________________________
Date: Sep 16, 2008
Subject: Loose bolts
I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft. Scott ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Sep 16, 2008
Where did you get your engine? -----Original Message----- From: scott bilinski <rv8a2001(at)yahoo.com> Sent: Tuesday, September 16, 2008 8:15 AM Subject: RV-List: Loose bolts I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft. Scott ________________________________________________________________________________
Date: Sep 16, 2008
Subject: paint shaker recommendation
Can anyone recommend a paint shaker for quart and gallon cans? Thanks, John Bright o:757-864-2305 h:757-874-0861 c:757-812-1909 http://www.facebook.com/people/John_Bright/1450601073 ________________________________________________________________________________
Date: Sep 16, 2008
Subject: Re: Loose bolts
One of the engineers I know from Lycoming has told me in the past that Lycoming case half bolts should be checked periodically for torque (100in/lbs) and that its not uncommon to find loose bolts. In other words check them at every condition inspection. Regards, Bob Japundza RV-6 flying F1 under const. On Tue, Sep 16, 2008 at 8:15 AM, scott bilinski wrote: > > I have found all sorts of loose bolts on the engine. First it was the > exhaust bolts, I had to tighten them 3 times before they would "hold". Then > the valve covers started leaking, nothing new, this is "normal". Well the > screws were so loose I could remove some with my fingers, now they have been > tightened and the leaks have stopped and have not come loose again since. > The last couple bolts I found loose were to the case halves! From what I > have read about others and their loose hardware experiences, the next > upcoming annual just months away, ALL fasteners will be checked over the > entire aircraft. > > Scott > > ________________________________________________________________________________
Date: Sep 16, 2008
They were tight when the engine was new/refurbed. This was after several hundred hours flying. Scott ----- Original Message ---- From: Michael Kraus <n223rv(at)wolflakeairport.net> Sent: Tuesday, September 16, 2008 7:00:07 AM Subject: RE: RV-List: Loose bolts Where did you get your engine? -----Original Message----- From: scott bilinski <rv8a2001(at)yahoo.com> Sent: Tuesday, September 16, 2008 8:15 AM Subject: RV-List: Loose bolts I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft. Scott ________________________________________________________________________________
Date: Sep 16, 2008
From: "Schans, Jeffery" <JSchans(at)lycoming.textron.com>
Here is the actual tightening procedure. Jeff Schans ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob J. Sent: Tuesday, September 16, 2008 10:34 AM Subject: Re: RV-List: Loose bolts One of the engineers I know from Lycoming has told me in the past that Lycoming case half bolts should be checked periodically for torque (100in/lbs) and that its not uncommon to find loose bolts. In other words check them at every condition inspection. Regards, Bob Japundza RV-6 flying F1 under const. On Tue, Sep 16, 2008 at 8:15 AM, scott bilinski wrote: I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft. Scott ________________________________________________________________________________
Date: Sep 16, 2008
Also tells you if merely deeper breathing is working to increase your oxygenation. It often helps enough, more than you'd think. Bill B On Tue, Sep 16, 2008 at 2:27 PM, scott bilinski wrote: > Different people react differently to altitude. I know one woman pilot who > needs oxygen above 8,000. Then there are other people who are in really good > shape and they dont need Ox until 11~12k. > > > Scott > > ________________________________________________________________________________
Date: Sep 16, 2008
I think the original poster stated that nuts WITH cotter pins had loosened. How does this happen? Isn't that what cotter pins are supposed to prevent? If not, they're just extra weight I can eliminate on my -4 :) Scott scott bilinski wrote: > >I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft. > > Scott > > > > > > > -- Scott http://corbenflyer.tripod.com/ Flying Corben Junior Ace - Building RV-4 Gotta Fly or Gonna Die ________________________________________________________________________________
Date: Sep 16, 2008
If your cotter pinned bolts are loose, two things to check were they really torqued correctly the first time or did the Bolts STRECH. If they did, replace them. In a message dated 9/16/2008 2:30:29 P.M. Pacific Daylight Time, acepilot(at)bloomer.net writes: --> RV-List message posted by: Scott I think the original poster stated that nuts WITH cotter pins had loosened. How does this happen? Isn't that what cotter pins are supposed to prevent? If not, they're just extra weight I can eliminate on my -4 :) Scott scott bilinski wrote: >--> RV-List message posted by: scott bilinski > >I have found all sorts of loose bolts on the engine. First it was the exhaust bolts, I had to tighten them 3 times before they would "hold". Then the valve covers started leaking, nothing new, this is "normal". Well the screws were so loose I could remove some with my fingers, now they have been tightened and the leaks have stopped and have not come loose again since. The last couple bolts I found loose were to the case halves! From what I have read about others and their loose hardware experiences, the next upcoming annual just months away, ALL fasteners will be checked over the entire aircraft. > > Scott > > > > > > > -- Scott http://corbenflyer.tripod.com/ Flying Corben Junior Ace - Building RV-4 Gotta Fly or Gonna Die **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Subject: Blood Oxygen Levels
Date: Sep 16, 2008
I have lived at about 7,500-ft for over 20-years now so I am probably a bit more adapted to low levels of Ox then 'flat-landers' but I thought to add one more data point to your discussion regarding oxygen use. Tomorrow I will leave home airport, and climb steadily until 13,500 to cross the continental divide in Colorado....after crossing at Monarch Pass I will descend to 12,500 to cruise altitude for another 45-minutes to my destination. Enroute at various altitudes I will use my rather expensive blood oxygen meter to see what levels of ox I have in my system. At home I usually see 86-89 % saturation. I do have oxygen but will not be using it tomorrow...I've made this trips many times so there's nothing new going on here. I'll post results just to add to the discussion. John ________________________________________________________________________________
Date: Sep 17, 2008
John: Someone like me that lives near sea level=2C I would be falling asleep at t hat low of O2 level. I have O2 and one of the old expensive blood oxygen m eters. I need O2 when flying for more than 2 hours above 9=2C500. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C159 + Flying Hours So. CA=2C USA From: n1cxo320(at)salidaco.com Subject: RV-List: Blood Oxygen Levels Date: Tue=2C 16 Sep 2008 18:07:49 -0600 I have lived at about 7=2C500-ft for over 20-years now so I am probably a bit more adapted to low levels of Ox then 'flat-land ers' but I thought to add one more data point to your discussion regarding oxyge n use. Tomorrow I will leave home airport=2C and climb steadily until 13=2C500 to cross the continental divide in Colorado....afte r crossing at Monarch Pass I will descend to 12=2C500 to cruise altitude for another 45-minutes to my destination. Enroute at various altitudes I will use my rather expensive blood oxygen meter to see what levels of ox I have in my system. At home I usually see 86-89 % saturation. I do have oxygen but will not be using it tomorrow...I've made this trips many times so there's nothing new going on here. I'll post results just to add to the discussion. John _________________________________________________________________ See how Windows Mobile brings your life together=97at home=2C work=2C or on the go. ________________________________________________________________________________
Date: Sep 16, 2008
This is a phenomenon I have experienced on my RV-6A and also by other RV builders I know. It was actually brought to my attention by another builder. (Thanks, Charlie Bravo!) After some hours in operation, engine vibration & flight loads will tend to compress the stack of materials at the engine mount bolt locations on the firewall, resulting in a natural loosening of the nuts. Each annual condition inspection, this is an item I religiously check and address as necessary. Mark Phillips - RV-6A "Mojo" 500 hours and warming up for the next C.I.... **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Date: Sep 17, 2008
I routinly fly above 12500 for long periods, much higher even, till have to come down for gas, Im one of those reare ones that need less oxy I suppose. Charlie h ________________________________________________________________________________
Date: Sep 17, 2008
Subject: Re: Blood Oxygen Levels
Agreed=0A=0A=0A=0A----- Original Message ----=0AFrom: N395V <Bearcat@bearca taviation.com>=0ATo: rv-list(at)matronics.com=0ASent: Wednesday, September 17, 2008 7:23:16 AM=0ASubject: RV-List: Re: Blood Oxygen Levels=0A=0A--> RV-Li st message posted by: "N395V" =0A=0A=0ABarry C hapman wrote:=0A> John,=0A> =0A> Us flat landers in the medical community w ould be ordering you home oxygen and likely portable oxygen if your pulse o ximetry showed that low.- Normal for most adults is 92% or better.- If you are indeed that low on oxygen (adapted or not) think of what your brain is deprived of?- Oxygen!!- Low oxygen equates to decreased level of co nsciousness, slowed brain function, and even possible damage to the brain c ells.- BTW, this low of pulse ox is usually seen in those with emphysema or COPD.- Also, don't let your AME know this, he'll ground you in a heart beat.- Just my half of a nickels worth of input.=0A> =0A> Barry Chapman, Family Nurse Practitioner=0A> RV-9A wings in progress=0A> =0A> Do not archi ve=0A> =0A> =0A> ---=0A=0A=0ABarry,=0A=0ABy now he has significantly elevat ed levels of 3DPG=0A=0Ahttp://en.wikipedia.org/wiki/2,3-Bisphosphoglycerate =0A=0AThis allows his blood at lower Sats to oxygenate his tissue at the sa me rate you and I do in th 90+% range.=0A=0AI would guess he would do fine at 15-16000' without O2.=0A=0A--------=0AMilt=0A2003 F1 Rocket=0A2006 Radia l Rocket=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matr ===================== ________________________________________________________________________________
Subject: Closure Rates
Date: Sep 17, 2008
Before I begin let me ask two questions. How many times have you been given traffic at three miles and you never saw the traffic? How much traffic do we miss seeing because we are VFR and/or ATC has not pointed out the traffic? To keep the numbers simple lets use an RV traveling at 180 mph and a Jet traveling at 540 mph. With two RVs closing head on, we have 180 + 180 = 360 mph or 6 miles/minute. This means if there was another RV three miles ahead, both aircraft would have 30 seconds to see and avoid the each other. With an RV and a Jet closing head on, we have 180 + 540 = 720 mph or 12 miles/minute. This means if there was traffic three miles ahead, both aircraft would have only 15 seconds to see and avoid the each other. With a Jet directly behind an RV, we have 540 -180 = 360 mph or 6 miles/minute. This means the Jet would only have 30 seconds to see and avoid running the RV. Assuming he/she is looking, now only one pilot has just 30 seconds to see and avoid! Except for takeoff and landings where they are restricted to 250 knots, Jets and other faster planes generally fly above 10,000. Additionally, many Jets and other faster planes regularly fly between 10,000 and 17,500 without positive control or VFR. Therefore, unless there are rocks to avoid, my personal preference is to stay below 10,000. Im not telling anyone how to fly their airplane or suggesting flying above 10,000 is unsafe. Im just pointing out some facts that might be food for thought. Steve Glasgow - Cappy willfly(at)carolina.rr.com ________________________________________________________________________________
Date: Sep 17, 2008
Subject: Re: RV-List Digest: 25 Msgs - 09/16/08
>From: John Bright <john_s_bright(at)yahoo.com> >Subject: RV-List: paint shaker recommendation > >Can anyone recommend a paint shaker for quart and gallon cans? > > Thanks, While conducting some other business, I asked the paint distributor around the corner what it would take to have them shake up some non-house paint. They said they'd be happy to do it for free, anytime. Might be someone in your neck of the woods who'd do the same. Glen Matejcek ________________________________________________________________________________
Date: Sep 17, 2008
As a flatlander when making extended trips in the mountains I will usually spend one or 2 nites at a 4000 ft elevation then one or 2 at 7000 feet and this helps immensely. In the past I have tried taking acetazolamide for 2 weeks before the trip as it is supposed to enhance endogenous production of 3 dpg but I never really noticed any benefit. After about 2 weeks you at altitude you have probably started increasing your supply of red blood cells which also helps. I have never been a big fan of O2 sat monitors. I think it better for us low altitude types to either just use O2 above 10,000 or go through some process of acclimatization if we have the time to do so. Even then I wouldn't spend a lot of time above 12,000 without O2. Maybe we have a Pulmonologist on the list who can chime in and shed a little more light on this. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p 4771#204771 ________________________________________________________________________________
Date: Sep 17, 2008
Subject: Re: Closure Rates
I like to fly 10k to 12.5k to keep away from all the other traffic that flies below 10k. I understand your point, but at 12.5k I would guess you have at least 50% less traffic than you do at 8k. So which is better.......faster traffic up high but less of them, or slower traffic down low and more of them? Scott ----- Original Message ---- From: Steve Glasgow <willfly(at)carolina.rr.com> Sent: Wednesday, September 17, 2008 7:20:47 AM Subject: RV-List: Closure Rates Before I begin let me ask two questions. How many times have you been given traffic at three miles and you never saw the traffic? How much traffic do we miss seeing because we are VFR and/or ATC has not pointed out the traffic? To keep the numbers simple lets use an RV traveling at 180 mph and a Jet traveling at 540 mph. With two RVs closing head on, we have 180 + 180 = 360 mph or 6 miles/minute. This means if there was another RV three miles ahead, both aircraft would have 30 seconds to see and avoid the each other. With an RV and a Jet closing head on, we have 180 + 540 = 720 mph or 12 miles/minute. This means if there was traffic three miles ahead, both aircraft would have only 15 seconds to see and avoid the each other. With a Jet directly behind an RV, we have 540 -180 = 360 mph or 6 miles/minute. This means the Jet would only have 30 seconds to see and avoid running the RV. Assuming he/she is looking, now only one pilot has just 30 seconds to see and avoid! Except for takeoff and landings where they are restricted to 250 knots, Jets and other faster planes generally fly above 10,000. Additionally, many Jets and other faster planes regularly fly between 10,000 and 17,500 without positive control or VFR. Therefore, unless there are rocks to avoid, my personal preference is to stay below 10,000. Im not telling anyone how to fly their airplane or suggesting flying above 10,000 is unsafe. Im just pointing out some facts that might be food for thought. Steve Glasgow - Cappy willfly(at)carolina.rr.com ________________________________________________________________________________
Date: Sep 17, 2008
"Except for takeoff and landings where they are restricted to 250 knots, Jets and other faster planes generally fly above 10,000'. Additionally, many Jets and other faster planes regularly fly between 10,000' and 17,500' without positive control or VFR." So pick up flight following above 10K. Even if other aircraft aren't talking to Center, at that altitude they will have their Mode-C on and Center can give you avoidance alerts. ________________________________________________________________________________
Date: Sep 17, 2008
Steve, let me repond as an RV6A pilot and an En Route controller with over 20 years experience. The numbers you quote are close on closing times. Most controllers try to call traffic soon enough to give either pilot time to r espond, additionally you should know that we spend a great deal of time com paring ground tracks, climb or descent rates, etc to determine if close pro ximity is imminent. It is not our discretion to decide if we wish to call t raffic to you, but it may be based upon controller workload. If the control ler feels two aircraft may be too close and either not see each other, they will recommend a course of action to alleviate the problem, it will not be surprise to you. I am completely comfortable flying VFR in class B, C or D airspace while receiving flight following that ATC will keep me appraised of potential traffic problems. - M. Phipps --- On Wed, 9/17/08, Steve Glasgow wrote: From: Steve Glasgow <willfly(at)carolina.rr.com> Subject: RV-List: Closure Rates Date: Wednesday, September 17, 2008, 8:20 AM Before I begin let me ask two questions. How many times have you been give n traffic at three miles and you never saw the traffic? How much traffic do we miss seeing because we are VFR and/or ATC has not pointed out the traffic? To keep the numbers simple lets use an RV traveling at 180 mph and a Jet traveling at 540 mph. With two RV=A2s closing head on, we have 180 + 180 = 360 mph or 6 miles/minute. This means if there was another RV three miles ahead, both aircraft would have 30 seconds to see and avoid the each other. With an RV and a Jet closing head on, we have 180 + 540 = 720 mph or 12 miles/minute. This means if there was traffic three miles ahead, both aircraft would have only 15 seconds to see and avoid the each other. With a Jet directly behind an RV, we have 540 -180 = 360 mph or 6 miles/minute. This means the Jet would only have 30 seconds to see and avoid running the RV. Assuming he/she is looking, now only one pilot has just 30 seconds to see and avoid! Except for takeoff and landings where they are restricted to 250 knots, Jet s and other faster planes generally fly above 10,000=A2. Additionally, many Jets and other faster planes regularly fly between 10,000=A2 and 17,500=A2 without positive control or VFR. Therefore, unless there are rocks to avoid, my personal preference is to stay below 10,000=A2. I=A2m not telling anyone how to fly their airplane or suggesting flying abo ve 10,000=A2 is unsafe. I=A2m just pointing out some facts that might be food for thought. Steve Glasgow - Cappy willfly(at)carolina.rr.com =0A=0A=0A ________________________________________________________________________________
Date: Sep 17, 2008
> Except for takeoff and landings where they are restricted to 250 knots, > Jets and other faster planes generally fly above 10,000. Additionally, > many Jets and other faster planes regularly fly between 10,000 and 17,500 > without positive control or VFR. > > Im not telling anyone how to fly their airplane or suggesting flying > above 10,000 is unsafe. Im just pointing out some facts that might be > food for thought. > > Steve Glasgow - Cappy My home airport is at 6840 feet so I rarely fly below 10,000' Over the mountains 12,500' minimum and often 14,500' to 17,500'. Even when I flew in Florida I was above 10,000'. I use fly following and other than a FedEx plane leaving Memphis and another airline flying into Orlando I have never seen a jet. The only other called out jet was a F-117 (?) near White Sands. I did not see it. OK, I just remember that flying over Denver Class B I see airliners. My point relates to areas away from airports. I stay above 10,000' to avoid other GA aircraft. I don't expect many other aircraft of any sort in the areas I fly (between 10,000' and 17,500') and my experience where I fly supports that. My limited time back east also supports that view but with less experience. Ron Lee ________________________________________________________________________________
Date: Sep 17, 2008
I love flight following. Even if it's a no-joy, at least I know they spotted something and will stay on top of it. Once going from Boston to White Plains they cut me loose during a heavy traffic situation, and man, I tell you, that got my attention. Right smack dab in the middle of the busiest airspace in the country, being let go from radar services, going into a busy airport on a hazy summer day, VFR, after seeing all sorts of traffic at all sorts of altitudes, hearing all kinds of chatter over the frequencies, it gets the old ticker pumping. And, it makes you realize just how valuable flight following is for the VFR only pilot. Out here in the west, I fly anywhere from 1,500 to 12,500 going over the mountains, and anytime I'm above 3,000 and going any distance, I usually get hooked up with them. Highly recommend it. John J -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Subject: Re: RV-List: Closure Rates ...I use fly following and other than a FedEx plane leaving Memphis and another airline flying into Orlando I have never seen a jet... ________________________________________________________________________________
Date: Sep 17, 2008
Yeah, It is likely compression of both the metal stack and the tube that projects out which is the weld point for the rest of the mount. What is frustrating is the four stayed tight for 1000 hours and then got loose in the last 200. On the case half discussion, all cases flex a microscopic amount as the cylinder is projected away from the piston. Ya, you should check those fasteners every chance you get. On the Titan ECI AD, piss, I got 'em, fortunately am very low in the A group and now need to do a comp check every 50 instead of 100 hours. And they did a "hartzel" bait and switch by making them throwaway units after the fact. Not that I disagree with this, running cylinders beyond the original TBO comes at some increased risk. Given the low cost differential between overhauled and new it is hard to justify reusing them over peace of mind. But still it rankles one's sensibilities. ________________________________________________________________________________
Date: Sep 17, 2008
How would you know? Hypoxemic impairment is transparent to the sufferer. You will be the last to know that your O2 levels are too low, absent a pulse oximeter. Bill B On Wed, Sep 17, 2008 at 8:30 AM, Charles Heathco wrote: > I routinly fly above 12500 for long periods, much higher even, till have > to come down for gas, Im one of those reare ones that need less oxy I > suppose. Charlie h > > * > > * > > ________________________________________________________________________________
Date: Sep 17, 2008
I made the flight I mentioned. Here's what I saw re ox levels. On ground before starting...airport 7523 msl OX level 90% saturadtion Climbing through 11,000 -ft msl OX level 84% saturation. At 13,.500 crossing the continental divide near Monarch Pass 79% saturation Level off at 12,500 to cruise westbound, OX level 80% After cruising 30 minutes at 12,500 OX level at 82% No adverse effect, no tiredness, mental confusion, or any other abnormalties I might mention I am 78-years old. It was just a very nice flight. FWIW John ________________________________________________________________________________
Date: Sep 17, 2008
steve if you keep asking these question and we will all be required to have tcas. occasiobally i have to fly to the SF bay area, and have never liked it. but the big boys are not the ones that i worry about. we have a large collection of migs and l-39s here. those are the guys that are tough to see. While it does seem to happen the odds that you put your aircraft in the same fifty foot box as somebody else enroute, is very slim. the odds of this happening though, see pic is much higher rick ________________________________________________________________________________
Date: Sep 17, 2008
Subject: RV-6 / 6a kit for sale
RV-6 / 6a kit for sale. Empennage: Complete except for fiberglass tips. Includes electric elevator trim kit. All parts are alodined and primed with Marhyde primer. Wings & Phlogiston Spar: Both skeletons fully assembled. Top skins riveted. Both tanks are complete and sealed. Flaps and ailerons complete, but not fitted. Includes electric aileron trim kit. All parts are alodined and primed with Deft epoxy primer (Mil-P-23377G). Both kits are the pre-punched versions purchased in 1997 & 1998 by myself. Construction is excellent. Preview plans and Orndorff videos are included for both kits. Detailed photos are available upon request. Must sell. The first $3750 takes it all. Buyer arranges transportation. If all items were purchased separately the price would be more than $6500 for the unassembled kits. Regards, Scott Kuebler Buffalo, NY 716-510-0318- cell scottam65(at)gmail.com ________________________________________________________________________________
Date: Sep 17, 2008
Speculating here, John, but even with a high hemoglobin level (which affects tissue delivery, but not partial pressure) and a right-shifted dissociation curve, you're not likely above 55 Torr PaO2 at that 79% pulse ox reading (if it's accurate), and that's hypoxemic impairment territory, IMO. Why not don the oxygen cannula at 13,500 and increase your chances of being a Flying Octagenarian, one day? Hope I can do at 78 what you are. Will know in another 26 years. Bill B On Wed, Sep 17, 2008 at 2:19 PM, John Fasching wrote: > I made the flight I mentioned. Here's what I saw re ox levels. > > On ground before starting...airport 7523 msl OX level 90% saturadtion > > Climbing through 11,000 -ft msl OX level 84% saturation. > > At 13,.500 crossing the continental divide near Monarch Pass 79% saturation > > Level off at 12,500 to cruise westbound, OX level 80% > > After cruising 30 minutes at 12,500 OX level at 82% > > No adverse effect, no tiredness, mental confusion, or any other > abnormalties > > I might mention I am 78-years old. > > It was just a very nice flight. > > FWIW > > John > > * > > * > > ________________________________________________________________________________
Date: Sep 17, 2008
One simple test is to fly right seat. Have the pilot call out a point on the sectional map and see how long it takes you to find it at 10,000 feet. Go on oxygen, wait 3 minutes and try to find another point on the map. My location time dropped by 67% on oxygen. As Bill mentions, you don't realize how impaired you are until you perform a repeatable test. Charlie Kuss --- On Wed, 9/17/08, Bill Boyd wrote: > From: Bill Boyd <sportav8r(at)gmail.com> > Subject: Re: RV-List: Fly above 8000 ft ? > To: rv-list(at)matronics.com > Date: Wednesday, September 17, 2008, 2:02 PM > How would you know? Hypoxemic impairment is transparent to > the sufferer. > You will be the last to know that your O2 levels are too > low, absent a pulse > oximeter. > > Bill B > > On Wed, Sep 17, 2008 at 8:30 AM, Charles Heathco > wrote: > > > I routinly fly above 12500 for long periods, much > higher even, till have > > to come down for gas, Im one of those reare ones that > need less oxy I > > suppose. Charlie h > > > > * > > > > * > > > > ________________________________________________________________________________
Date: Sep 17, 2008
I hate to be the one to suggest something as basic as training, but... You can, and I feel should, avail yourself of the altitude chamber training that the FAA provides. http://www.faa.gov/pilots/training/airman_education/aerospace_physiology/ I know that people "feel fine"...wouldn't it be better to expand your knowledge base? Tim ----- Original Message ----- From: "Charles Kuss" <chaskuss(at)yahoo.com> Sent: Wednesday, September 17, 2008 5:32 PM Subject: Re: RV-List: Fly above 8000 ft ? > > One simple test is to fly right seat. Have the pilot call out a point on > the sectional map and see how long it takes you to find it at 10,000 feet. > Go on oxygen, wait 3 minutes and try to find another point on the map. My > location time dropped by 67% on oxygen. As Bill mentions, you don't > realize how impaired you are until you perform a repeatable test. > Charlie Kuss > > > --- On Wed, 9/17/08, Bill Boyd wrote: > >> From: Bill Boyd <sportav8r(at)gmail.com> >> Subject: Re: RV-List: Fly above 8000 ft ? >> To: rv-list(at)matronics.com >> Date: Wednesday, September 17, 2008, 2:02 PM >> How would you know? Hypoxemic impairment is transparent to >> the sufferer. >> You will be the last to know that your O2 levels are too >> low, absent a pulse >> oximeter. >> >> Bill B >> >> On Wed, Sep 17, 2008 at 8:30 AM, Charles Heathco >> wrote: >> >> > I routinly fly above 12500 for long periods, much >> higher even, till have >> > to come down for gas, Im one of those reare ones that >> need less oxy I >> > suppose. Charlie h >> > >> > * >> > >> > * >> > >> > > > > ________________________________________________________________________________
Subject: Re: Closure RatesClosure Rates
Date: Sep 18, 2008
Scott, your question "which is best" implies a known quantity of which you have determined by a guess. One thing that is not a guess is every one of the planes that go above 10,000' will come back down at some time. As pointed out by the controller, positive control of both aircraft on a collision course is very helpful. Flight Following may or may not help. Those that use Flight Following are well aware that you are on the bottom of the totem pole, and many times are told Flight Following is canceled swank 1200. Also there are many areas where it is not available. Over my many years or airline flying, I can't tell you how may times I have been vectored away from slower aircraft above 10,000' who were not in positive control. The guy we were vectored around never even knew he had created a problem because he was VFR, not looking or did not see us. Just because we can't see them doesn't mean they are not there. The skies are very crowded and there are more and more light jets in the air every day. But as my original posts stated, "Additionally, many Jets and other faster planes regularly fly between 10,000 and 17,500 without positive control or VFR". Note: I said, "without positive control or VFR". These are the ones I am primarily concerned about. Again as stated in my previous post, "I'm not telling anyone how to fly their airplane or suggesting flying above 10,000 is unsafe. I'm just pointing out some facts that might be food for thought." Steve Glasgow-Cappy willfly(at)carolina.rr.com 704-362-0005 Home ________________________________________________________________________________
Date: Sep 11, 2008
I don't fly that high ...... yet ......... so my question is ...... is the problem due to 'vfr' traffic not holding to the odd/even +500 enroute or is the system mucked up by climbing/descending aircraft ..... of all types???? Other than filing a VFR flight plan, what else can we do??? Linn Steve Glasgow wrote: > > Scott, your question "which is best" implies a known quantity of which > you have determined by a guess. One thing that is not a guess is > every one of the planes that go above 10,000' will come back down at > some time. > > As pointed out by the controller, positive control of both aircraft on > a collision course is very helpful. Flight Following may or may not > help. Those that use Flight Following are well aware that you are on > the bottom of the totem pole, and many times are told Flight Following > is canceled swank 1200. Also there are many areas where it is not > available. > > Over my many years or airline flying, I can't tell you how may times I > have been vectored away from slower aircraft above 10,000' who were > not in positive control. The guy we were vectored around never even > knew he had created a problem because he was VFR, not looking or did > not see us. > > Just because we can't see them doesn't mean they are not there. The > skies are very crowded and there are more and more light jets in the > air every day. > > But as my original posts stated, "Additionally, many Jets and other > faster planes regularly fly between 10,000 and 17,500 without positive > control or VFR". Note: I said, "without positive control or VFR". > These are the ones I am primarily concerned about. > > Again as stated in my previous post, "I'm not telling anyone how to > fly their airplane or suggesting flying above > 10,000 is unsafe. I'm just pointing out some facts that might be food > for thought." > > Steve Glasgow-Cappy > willfly(at)carolina.rr.com > 704-362-0005 Home > > ________________________________________________________________________________
Date: Sep 18, 2008
I do not remember were I heard it or read it. The 12,500 ft rule was established in the late 30' using young, physical fit, healthy flyers. Most of us have passed the young and physically fit criteria. I am a flat lander, elevation 14 ft, and use O2 above 8000 ft and above 5000 ft at night. Richard Reynolds Norfolk, VA ________________________________________________________________________________
Date: Sep 18, 2008
From: George Inman 204 287 8334 <ghinman(at)mts.net>
** <http://www.aircraftspruce.com/catalog/hapages/ms27151palnuts.php> I noticed one guy had -MS27151 PAL NUTS - ON TOP of the regular nuts on his crank case bolts. I do not know if this works,but may be worth a try for those who have had loose engine bolts. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Sep 18, 2008
Well, an IFR aircraft on autopilot could easily be 150 ft high or low from the nominal altitude, once you consider normally seen static system position errors, altimeter errors, autopilot altitude hold tolerances, and differences in altimeter settings from region to region. If the aircraft is not on autopilot, you can add another 100 ft to that, for plus or minus 250 ft. If we have an amateur-built aircraft, the vast majority have completely unknown static system position errors, as most builders don't take the time to learn how to determine them. I've seen reports from several RV builders who report static system position errors of more than 100 ft. For VFR traffic not using flight following, they may very well be using a different altimeter setting than the IFR traffic. Even if the IFR and VFR traffic are making reasonable efforts to fly the correct altitudes, they could easily be less than 200 ft apart in altitude, maybe even closer. Thing you can do: 1. Use flight following. This ensures you are using the same altimeter setting as the IFR traffic. It also helps cue to where to look for some traffic. 2. Determine the static system position error of your aircraft. If it is large, either make some mods to reduce it, or at least deliberately fly an indicated altitude so as to be at the correct real altitude. For example, if you determine that your altimeter will be reading 100 ft too low due to static system position error, you could deliberately fly 8400 ft indicated, instead of 8500 ft, to account for this static system position error. Of course there is no way to correct the altitudes reported by the transponder for static system position error, so the best approach is to make mods to the static system to reduce the error. How to determine static system position error: http://www.kilohotel.com/rv8/rvlinks/ssec.html Kevin Horton linn Walters wrote: > > I don't fly that high ...... yet ......... so my question is ...... is > the problem due to 'vfr' traffic not holding to the odd/even +500 > enroute or is the system mucked up by climbing/descending aircraft > ..... of all types???? > > Other than filing a VFR flight plan, what else can we do??? > Linn > > > Steve Glasgow wrote: >> >> Scott, your question "which is best" implies a known quantity of >> which you have determined by a guess. One thing that is not a guess >> is every one of the planes that go above 10,000' will come back down >> at some time. >> >> As pointed out by the controller, positive control of both aircraft >> on a collision course is very helpful. Flight Following may or may >> not help. Those that use Flight Following are well aware that you are >> on the bottom of the totem pole, and many times are told Flight >> Following is canceled swank 1200. Also there are many areas where it >> is not available. >> >> Over my many years or airline flying, I can't tell you how may times >> I have been vectored away from slower aircraft above 10,000' who were >> not in positive control. The guy we were vectored around never even >> knew he had created a problem because he was VFR, not looking or did >> not see us. >> >> Just because we can't see them doesn't mean they are not there. The >> skies are very crowded and there are more and more light jets in the >> air every day. >> >> But as my original posts stated, "Additionally, many Jets and other >> faster planes regularly fly between 10,000 and 17,500 without >> positive control or VFR". Note: I said, "without positive control or >> VFR". These are the ones I am primarily concerned about. >> >> Again as stated in my previous post, "I'm not telling anyone how to >> fly their airplane or suggesting flying above >> 10,000 is unsafe. I'm just pointing out some facts that might be >> food for thought." >> >> Steve Glasgow-Cappy >> willfly(at)carolina.rr.com >> 704-362-0005 Home >> >> >> >> >> >> >> >> >> >> >> >> > -- Kevin Horton RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: Flight Oxygen
Date: Sep 18, 2008
Thanks to all for the suggestions regarding high altitude flight and oxygen. For what its worth I do have oxygen in the plane and normally use it for any sustained flights and have used it for testing the airplane as high as 17.600 feet. thanks again John ________________________________________________________________________________
Date: Sep 19, 2008
Subject: Picture Source...
Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to paint my RV-8 the same color. Thanks for any leads... Matt ________________________________________________________________________________
Date: Sep 19, 2008
From: Carlos Hernandez <carlosh(at)structuralaz.com>
Subject: Re: Picture Source...
I believe it to be Doug Reeves form VAF. http://www.dougreeves.com/ Matt Dralle wrote: > > > Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to paint my RV-8 the same color. > > Thanks for any leads... > > Matt > > > ------------------------------------------------------------------------ > > ------------------------------------------------------------------------ > > Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Sep 19, 2008
That is Paul Shattauers (spelling is wrong I'm sure) airplane. Jh -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, September 19, 2008 9:46 AM Subject: RV-List: Picture Source... Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to paint my RV-8 the same color. Thanks for any leads... Matt ________________________________________________________________________________
Date: Sep 19, 2008
Oops... try this one, www.deltaromeo.com - Yeah this one's the ticket! Sorry about that. Carlos Carlos Hernandez wrote: > > > I believe it to be Doug Reeves form VAF. http://www.dougreeves.com/ > > Matt Dralle wrote: >> >> >> Does anyone know where this picture came from off the Van's web >> site? I'd love to get some other shots of this particular aircraft >> as I want to paint my RV-8 the same color. >> >> Thanks for any leads... >> >> Matt >> >> ------------------------------------------------------------------------ >> >> ------------------------------------------------------------------------ >> >> Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Sep 19, 2008
Matt, Is this the same RV-8? It's one of my favorites but I can't recall who posted it to VAF. Jack Hilditch -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, September 19, 2008 11:46 AM Subject: RV-List: Picture Source... Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to paint my RV-8 the same color. Thanks for any leads... Matt ________________________________________________________________________________
Date: Sep 19, 2008
I'm almost certain that's a -9 in the photo Matt referenced... look at the aspect ratio on that wing; very non-traditional RV profile. Just my guess. Bill B On Fri, Sep 19, 2008 at 1:16 PM, Jack Hilditch wrote: > Matt, > > Is this the same RV-8? It's one of my favorites but I can't recall who > posted it > to VAF. > > > Jack Hilditch > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Friday, September 19, 2008 11:46 AM > To: rv-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV-List: Picture Source... > > > Does anyone know where this picture came from off the Van's web site? I'd > love > to get some other shots of this particular aircraft as I want to paint my > RV-8 > the same color. > > Thanks for any leads... > > Matt > > ________________________________________________________________________________
Date: Sep 19, 2008
You may be right on that Bill. I'm so used to a close-up view of the rivets on my -9A project fuse that I seldom step back to look at the wings as a whole. I just assumed that since Matt was building an -8 the photo would be of one as well. Goes to show that the acronym for 'assume' is correct. Jack _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Boyd Sent: Friday, September 19, 2008 1:44 PM Subject: Re: RV-List: Picture Source... I'm almost certain that's a -9 in the photo Matt referenced... look at the aspect ratio on that wing; very non-traditional RV profile. Just my guess. Bill B On Fri, Sep 19, 2008 at 1:16 PM, Jack Hilditch wrote: Matt, Is this the same RV-8? It's one of my favorites but I can't recall who posted it to VAF. Jack Hilditch -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, September 19, 2008 11:46 AM Subject: RV-List: Picture Source... Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to paint my RV-8 the same color. Thanks for any leads... Matt ________________________________________________________________________________
Date: Sep 19, 2008
No, it's an -8. http://www.airport-data.com/aircraft/N808PS.html Carlos Jack Hilditch wrote: > > You may be right on that Bill. Im so used to a close-up view of the > rivets on my -9A project fuse that I seldom step back to look at the > wings as a whole. I just assumed that since Matt was building an -8 > the photo would be of one as well. Goes to show that the acronym for > assume is correct. > > *Jack *** > > ------------------------------------------------------------------------ > > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Bill Boyd > *Sent:* Friday, September 19, 2008 1:44 PM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: Picture Source... > > I'm almost certain that's a -9 in the photo Matt referenced... look at > the aspect ratio on that wing; very non-traditional RV profile. Just > my guess. > > Bill B > > On Fri, Sep 19, 2008 at 1:16 PM, Jack Hilditch > wrote: > > Matt, > > Is this the same RV-8? It's one of my favorites but I can't recall who > posted it > to VAF. > > > Jack Hilditch > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com > ] On Behalf Of Matt Dralle > Sent: Friday, September 19, 2008 11:46 AM > To: rv-list(at)matronics.com ; > rv8-list(at)matronics.com > Subject: RV-List: Picture Source... > > > Does anyone know where this picture came from off the Van's web site? > I'd love > to get some other shots of this particular aircraft as I want to paint > my RV-8 > the same color. > > Thanks for any leads... > > Matt > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution* > * * > * > > > * > ------------------------------------------------------------------------ > > Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Sep 19, 2008
Whatever. Must be the sexy wing tips and the tandem fuselage :-) Certainly doesn't look like the short & stubby -6, -7 RV wing planform from this angle. If you've found the registration number, you've found the owner and, with a phone call, the paint spec. Good job. -Bill On Fri, Sep 19, 2008 at 2:52 PM, Carlos Hernandez wrote: > > No, it's an -8. http://www.airport-data.com/aircraft/N808PS.html > > Carlos > > Jack Hilditch wrote: > >> >> You may be right on that Bill. I'm so used to a close-up view of the >> rivets on my -9A project fuse that I seldom step back to look at the wings >> as a whole. I just assumed that since Matt was building an -8 the photo >> would be of one as well. Goes to show that the acronym for 'assume' is >> correct. >> >> *Jack *** >> >> ------------------------------------------------------------------------ >> >> *From:* owner-rv-list-server(at)matronics.com [mailto: >> owner-rv-list-server(at)matronics.com] *On Behalf Of *Bill Boyd >> *Sent:* Friday, September 19, 2008 1:44 PM >> *To:* rv-list(at)matronics.com >> *Subject:* Re: RV-List: Picture Source... >> >> I'm almost certain that's a -9 in the photo Matt referenced... look at the >> aspect ratio on that wing; very non-traditional RV profile. Just my guess. >> >> Bill B >> >> On Fri, Sep 19, 2008 at 1:16 PM, Jack Hilditch > wmjack1(at)t3cs.net>> wrote: >> >> Matt, >> >> Is this the same RV-8? It's one of my favorites but I can't recall who >> posted it >> to VAF. >> >> >> >> Jack Hilditch >> >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com <mailto: >> owner-rv-list-server(at)matronics.com> >> [mailto:owner-rv-list-server(at)matronics.com > owner-rv-list-server(at)matronics.com>] On Behalf Of Matt Dralle >> Sent: Friday, September 19, 2008 11:46 AM >> To: rv-list(at)matronics.com ; >> rv8-list(at)matronics.com >> Subject: RV-List: Picture Source... >> >> >> >> Does anyone know where this picture came from off the Van's web site? I'd >> love >> to get some other shots of this particular aircraft as I want to paint my >> RV-8 >> the same color. >> >> Thanks for any leads... >> >> Matt >> >> * * >> * * >> ** >> ** >> ** >> ** >> ** >> ** >> ** >> *http://www.matronics.com/contribution* >> * * >> * >> >> >> * >> ------------------------------------------------------------------------ >> >> Checked by AVG. >> > > -- > Carlos Hernandez <carlosh@sec-engr.com> > Structural Engineers Company > 2963 W. Elliot Rd. - Suite 3 > Chandler, AZ 85224 > Phone: 480.968.8600 > Fax: 480.968.8608 > www.sec-engr.com > > > CONFIDENTIALITY NOTICE > > The information in this email may be confidential and/or privileged. > This email is intended to be reviewed by only the individual or > organization named above. If you are not the intended recipient or > an authorized representative of the intended recipient, you are hereby > notified that any review, dissemination or copyingof this email and > its attachments, if any, or the information contained herein is > prohibited. If you havereceived this email in error, please > immediately notify the sender by return email and delete this email > from your system. > > ________________________________________________________________________________
Date: Sep 19, 2008
I have seen this airplane in the Reno area. I think it is named, "Red Ryder". Carlos Hernandez wrote: > > > No, it's an -8. http://www.airport-data.com/aircraft/N808PS.html > > Carlos > > Jack Hilditch wrote: >> >> You may be right on that Bill. Im so used to a close-up view of the >> rivets on my -9A project fuse that I seldom step back to look at the >> wings as a whole. I just assumed that since Matt was building an -8 >> the photo would be of one as well. Goes to show that the acronym for >> assume is correct. >> >> *Jack *** >> >> ------------------------------------------------------------------------ >> >> *From:* owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Bill Boyd >> *Sent:* Friday, September 19, 2008 1:44 PM >> *To:* rv-list(at)matronics.com >> *Subject:* Re: RV-List: Picture Source... >> >> I'm almost certain that's a -9 in the photo Matt referenced... look >> at the aspect ratio on that wing; very non-traditional RV profile. >> Just my guess. >> >> Bill B >> >> On Fri, Sep 19, 2008 at 1:16 PM, Jack Hilditch > > wrote: >> >> Matt, >> >> Is this the same RV-8? It's one of my favorites but I can't recall >> who posted it >> to VAF. >> >> >> >> Jack Hilditch >> >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> >> [mailto:owner-rv-list-server(at)matronics.com >> ] On Behalf Of Matt Dralle >> Sent: Friday, September 19, 2008 11:46 AM >> To: rv-list(at)matronics.com ; >> rv8-list(at)matronics.com >> Subject: RV-List: Picture Source... >> >> >> >> Does anyone know where this picture came from off the Van's web site? >> I'd love >> to get some other shots of this particular aircraft as I want to >> paint my RV-8 >> the same color. >> >> Thanks for any leads... >> >> Matt >> >> * * >> * * >> ** >> ** >> ** >> ** >> ** >> ** >> ** >> *http://www.matronics.com/contribution* >> * * >> * >> >> >> * >> ------------------------------------------------------------------------ >> >> Checked by AVG. > ________________________________________________________________________________
Date: Sep 19, 2008
Here's a better picture of the plane. http://www.jetphotos.net/viewphoto.php?id=5961145 Carlos ________________________________________________________________________________
Date: Sep 20, 2008
In a message dated 9/19/2008 11:59:35 A.M. Central Daylight Time, rv8tor(at)lazy8.net writes: That is Paul Shattauers (spelling is wrong I'm sure) airplane. It is indeed Paul's RV-8 and was perhaps the last plane finished by Mike Taylor at Tuscaloosa AL (TCL) just before he robbed me and several others of our deposits as we were waiting for paint. The biggest crime is that I have seen several planes he painted, and Mike did absolutely beautiful work. An RV-4 that Taylor had started was finished by Bobby Potts in the same facility, which Bobby owns. I was so impressed with Bobbys integrity and quality of work, that he painted my plane. see: _http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5270_ (http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5270) and click Next Entry>> at top for my whole paint story. Mark Phillips **************Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators. (http://www.walletpop.com/?NCID=emlcntuswall00000001) ________________________________________________________________________________
Subject: Oil leak
Date: Sep 20, 2008
Hi all, Searched the archives but have a "new" oil leak location. Anyone had one on the mechanical fuel pump? I have a total of 58 hours on the pump and it appears that the oil is wicking out of the top of the stainless screws that sandwich the whole pump together. First off, are they supposed to be safety wired, because mine are not (came from the "factory" that way). The aft face of the engine that the pump mounts to is dry. It is not a big leak, but one just the same. I will try the solvent and Dr. Scholl's to confirm. But anyone with something like this? Very lubed, John N802RJ "Rockin' Robin" ________________________________________________________________________________
Date: Sep 20, 2008
Subject: Re: Oil leak
Yes, I have been fighting it on my Mooney. Tightening the screws I could get to reduced the problem a lot. Next time I can get in there, I will replace the pump. I have an IO-360-A1A with an AC high pressure mechanical pump. John Porter wrote: > Hi all, > Searched the archives but have a "new" oil leak location. Anyone had > one on the mechanical fuel pump? I have a total of 58 hours on the > pump and it appears that the oil is wicking out of the top of the > stainless screws that sandwich the whole pump together. First off, > are they supposed to be safety wired, because mine are not (came from > the "factory" that way). The aft face of the engine that the pump > mounts to is dry. > It is not a big leak, but one just the same. I will try the solvent > and Dr. Scholl's to confirm. But anyone with something like this? > > Very lubed, > > John > N802RJ > "Rockin' Robin" > * > > > * ________________________________________________________________________________
Date: Sep 20, 2008
Subject: dissolving Lexel
Does any one know if there is any solvent that will dissolve Lexel but not hurt plexiglass? When I put my tip-up canopy plexiglass in, I sealed it with lexel across the front to prevent leaks. My canopy installation is different than most. I have a strip of aluminum across the front of my plexiglass - I did not lay-up fiberglass bonded to the skin as the plans suggest. I formed a piece of aluminum to contour the whole thing and riveted it in. I thought that would make it possible to remove the canopy which I now want to do for painting. The canopy is not broken. Plexi was installed 3 or 4 years ago and the Lexel seems to be holding well - better than I expected. I guess I can live with painting it with the plexi in place, but I'd rather remove it if at all possible. -- Tom Sargent RV-6A - getting ready to paint. ________________________________________________________________________________
Date: Sep 21, 2008
John: tha is wondefull, but- try this,- next time you are at or above 8 ,000 try using some- Oxigen.... you would not believe how really good you feel... - is like this,- you have your Head sets" you have used for years you like them etc.. now try a pair of the expense ones, not the $900,- but some where in betw een, the active cancellation type.... you can not believe, how you lived with ou t them.. the difference is unbelieavable... I know I just bit the bullet, and got a pair...really something.... the same with Oxigen.. - bert --- On Wed, 9/17/08, John Fasching wrote: From: John Fasching <n1cxo320(at)salidaco.com> Subject: RV-List: Blood Oxygen Levels Date: Wednesday, September 17, 2008, 2:19 PM I made the flight I mentioned. Here's what I saw re ox levels. - On ground before starting...airport 7523 msl OX level 90% saturadtion - Climbing through 11,000 -ft msl OX level 84% saturation. - At 13,.500 crossing the continental divide near Monarch Pass 79% saturation - Level off at 12,500 to cruise westbound, OX level 80% - After cruising 30 minutes at 12,500 OX level at 82% - No adverse effect, no tiredness, mental confusion, or any other abnormaltie s - I might mention I am 78-years old. - It was just a very nice flight. - FWIW- - John =0A=0A=0A ________________________________________________________________________________
Date: Sep 21, 2008
FWIW: I'm not flying my 6A yet, but I frequently WORK at 10500. I live at 2500ft and occasionally (maybe 10 times a year) go up to a telescope on a 10,500ft mountain top and stay there for a few days. I've been doing this for 7 years. The observatory keeps oxygen up there for whoever needs it. What I find is that I am fine (pulse ox around 90 - 91, which is low) as long as I don't move or exert myself. As soon as I get out of the car, climb stairs, move around, lug stuff out of a pickup truck into the building, I very quickly become fatigued, can't type straight on the computer, have trouble remembering things and soon get a whopping migraine headache. The best fix I've found for it is to breathe O2 for 15 min. as soon as I get there. Sit still for half an hour or so and breath O2 again for 15 min. Then I start working (I'm a computer nerd) and hit the O2 once an hour for the next few hours. After that, I'm just tired - no headache. The next day I feel OK. I'm planning on getting a portable O2 system for my plane. -- Tom Sargent, RV-6A - painting. ________________________________________________________________________________
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Sep 22, 2008
Matt, The plane is Pauls. Hangers at KPDK. The color is Ford Red Fire Pearl. The color code is G2 and its from 2002-2005 Ford Mustangs. Thats the color I also used cause I used to have to stare at Paul flyin g off my wing all the time. Loved it. Its very translucent, takes quite a few coats. The paint mixer said it was the most expensive production color her has ever mixed. MIke . Matt Dralle To Sent by: rv-list(at)matronics.com, owner-rv-list-ser rv8-list(at)matronics.com ver(at)matronics.com cc Subj ect 09/19/2008 11:46 RV-List: Picture Source... AM Please respond to rv-list@matronics .com Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to p aint my RV-8 the same color. Thanks for any leads... Matt (See attached file: profile_image.jpg) ________________________________________________________________________________
Date: Sep 22, 2008
Subject: Re: Efis questionEfis question
I am finishing the panel on my -8A. Spent a lot of time analyzing "what ifs ?" regarding failure modes. Finally settled on an AFS-3500, with a TruTrac ADI II for attitude back up - along with a Garmin 496 for a rough last ditc h "get it right side up" capability. SL40 NavCom with an ICOM backup. Regul ar airspeed, altimeter, vsi as backup. In my opinion, regularly going IMC with only a single EFIS and no backup wi ll eventually get you killed. FWIW. Paul Valovich N192NM Reserved - Again! ________________________________________________________________________________
Date: Sep 22, 2008
Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Date: Sep 22, 2008
Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee ------------------------------------------------------------------------- ----- Checked by AVG. 9/22/2008 6:39 AM ________________________________________________________________________________
Date: Sep 22, 2008
Sweet! I've seen that color on the Mustangs and always thought that was the color I wanted to paint my RV. That color code is going in my book of things to remember! I wonder if its a two or three stage application? Thanks! Matt At 05:43 AM 9/22/2008 Monday, you wrote: >Matt, The plane is Pauls. Hangers at KPDK. >The color is Ford Red Fire Pearl. >The color code is G2 and its from 2002-2005 Ford Mustangs. >Thats the color I also used cause I used to have to stare at Paul flying off my wing all the time. Loved it. >Its very translucent, takes quite a few coats. >The paint mixer said it was the most expensive production color her has ever mixed. >MIke > > >Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to paint my RV-8 the same color. > >Thanks for any leads... > >Matt Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Sep 22, 2008
Its 2 satge both at the ford factory, and in my basement where I painte d mine. I recommend before you get too settled on it to check a local supplier of automotive paint and the cost. You may just have to find a second job. I paid $1249/gallon 4 years ago, I used 3 gallons of red alone. Does no t include activator, hardener, reducer etc. Its expensive. I used Sikkens . It shoots beautifully. I get many positive comments from on-lookers. The w omen swoon over it:) Mike Matt Dralle To Sent by: rv-list(at)matronics.com owner-rv-list-ser cc ver(at)matronics.com Subj ect Re: RV-List: Picture Source... 09/22/2008 12:23 PM Please respond to rv-list@matronics .com Sweet! I've seen that color on the Mustangs and always thought that wa s the color I wanted to paint my RV. That color code is going in my book of things to remember! I wonder if its a two or three stage application? Thanks! Matt At 05:43 AM 9/22/2008 Monday, you wrote: >Matt, The plane is Pauls. Hangers at KPDK. >The color is Ford Red Fire Pearl. >The color code is G2 and its from 2002-2005 Ford Mustangs. >Thats the color I also used cause I used to have to stare at Paul flyi ng off my wing all the time. Loved it. >Its very translucent, takes quite a few coats. >The paint mixer said it was the most expensive production color her ha s ever mixed. >MIke > > >Does anyone know where this picture came from off the Van's web site? I'd love to get some other shots of this particular aircraft as I want to p aint my RV-8 the same color. > >Thanks for any leads... > >Matt Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Sep 22, 2008
Subject: Radio Problem
Guys, I have an Apollo SL-30 in my RV-8 which has a rather unique (to me anyway) problem; on the ground, even with the engine running at high rpm, the radio works flawlessly, in the air it's a different story. As soon as I take off, a loud background noise begins which makes receiving transmissions nearly impossible. Usually, sometime during the flight, this noise goes away and the reception is crystal clear! I have a belly mounted Comant bent whip antenna. Coax connections are tight. Any ideas of what the problem is? Walt Shipley ________________________________________________________________________________
Date: Sep 22, 2008
Subject: Re: Radio Problem
Walt, try disconnecting your ELT antennae. I had a situation once where the ELT would receive an AM band broadcast and then generate a signal that would make reception of com transmission unintelligible. This would happen on the low end of the VHF band. Changing the ELT antennae cured my problem. Hope this helps. Randy Hooper On Mon, Sep 22, 2008 at 5:51 PM, rveighta wrote: > > Guys, I have an Apollo SL-30 in my RV-8 which has a rather unique (to me > anyway) problem; on the ground, even with the engine running at high rpm, > the radio works flawlessly, in the air it's a different story. As soon as I > take off, a loud background noise begins which makes receiving transmissions > nearly impossible. Usually, sometime during the flight, this noise goes away > and the reception is crystal clear! > > I have a belly mounted Comant bent whip antenna. Coax connections are > tight. Any ideas of what the problem is? > > Walt Shipley > > -- Randy Hooper ________________________________________________________________________________
Date: Sep 23, 2008
It might be static buildup as you are flying along. In the Air Force, our planes had "static wicks" on the trailing edge of the wings and tail surfaces to dissipate the charge buildup.... Scott rveighta wrote: > >Guys, I have an Apollo SL-30 in my RV-8 which has a rather unique (to me anyway) problem; on the ground, even with the engine running at high rpm, the radio works flawlessly, in the air it's a different story. As soon as I take off, a loud background noise begins which makes receiving transmissions nearly impossible. Usually, sometime during the flight, this noise goes away and the reception is crystal clear! > >I have a belly mounted Comant bent whip antenna. Coax connections are tight. Any ideas of what the problem is? > >Walt Shipley > > > > -- Scott http://corbenflyer.tripod.com/ Flying Corben Junior Ace - Building RV-4 Gotta Fly or Gonna Die ________________________________________________________________________________
Date: Sep 23, 2008
Walt, I have a similar problem with my SL40, same antenna too. Unfortunately the background noise does not clear up after a while for me like your's does. Garmin said it was probably due to static build-up during flight but I have not figured out how to eliminate it. If you figure this out please let me know too. My problem is mostly related with the intercom, not the com. I have a rubber duck antenna on my ELT from my hand-held nav-com. There must be a way to fix this without adding static wicks. Bob ----- Original Message ----- From: rveighta Date: Monday, September 22, 2008 7:08 pm Subject: RV-List: Radio Problem > > Guys, I have an Apollo SL-30 in my RV-8 which has a rather > unique (to me anyway) problem; on the ground, even with the > engine running at high rpm, the radio works flawlessly, in the > air it's a different story. As soon as I take off, a loud > background noise begins which makes receiving transmissions > nearly impossible. Usually, sometime during the flight, this > noise goes away and the reception is crystal clear! > > I have a belly mounted Comant bent whip antenna. Coax > connections are tight. Any ideas of what the problem is? > > Walt Shipley > > > > > ________________________________________________________________________________
Date: Sep 22, 2008
Subject: Tail wheel bolt torque
What torque do you use for the 1/2 inch nut that holds the tailwhel fork on the spring? The torque for 1/2 in. bolts is 480 inch lbs ,but when it is this tight the fork is hard to turn in the mount. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Sep 22, 2008
That is true whether it is an EFIS or a "steam gauge" attitude indicator that is your sole spatial orientation reference. David Maib On Sep 22, 2008, at 10:38 AM, Jim Fogarty at Lakes & Leisure Realty wrote: Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: Ron Lee Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee href="http://www.matronics.com/Navigator?RV-List">http:// www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 9/22/2008 6:39 AM ________________________________________________________________________________
Date: Sep 22, 2008
Walt ... you could run this by the Aeroelectric List at aeroelectric-list(at)matronics.com and Bob Nuckolls could suggest some things to try. Bob is very good at finding the mysteries of black art. Let us know what happens. Good luck, Jerry > Guys, I have an Apollo SL-30 in my RV-8 which has a rather > unique (to me anyway) problem; on the ground, even with the > engine running at high rpm, the radio works flawlessly, in the > air it's a different story. As soon as I take off, a loud > background noise begins which makes receiving transmissions > nearly impossible. Usually, sometime during the flight, this > noise goes away and the reception is crystal clear! > > I have a belly mounted Comant bent whip antenna. Coax > connections are tight. Any ideas of what the problem is? > > Walt Shipley ________________________________________________________________________________
Date: Sep 22, 2008
Since when is a loss of ADI or artificial horizon an automatic trip to the morgue? Don't they teach "partial panel" anymore? ----- Original Message ----- From: David Maib To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 7:34 PM Subject: Re: RV-List: Efis question That is true whether it is an EFIS or a "steam gauge" attitude indicator that is your sole spatial orientation reference. David Maib On Sep 22, 2008, at 10:38 AM, Jim Fogarty at Lakes & Leisure Realty wrote: Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ------------------------------------------------------------------------- --- 9/22/2008 6:39 AM http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Date: Sep 22, 2008
Do you think that most people are competent at partial panel in IMC? The oroginal poster suggested that panel space was an issue which I find hard to believe. Perhaps a good wing-leveler/autopilot might save you in you lost your only attitude source. Ron Lee ----- Original Message ----- From: Timothy E. Cone To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:48 PM Subject: Re: RV-List: Efis question Since when is a loss of ADI or artificial horizon an automatic trip to the morgue? Don't they teach "partial panel" anymore? ________________________________________________________________________________
Date: Sep 22, 2008
I'm really not trying to be snide, but if they aren't competent at partial panel, what in the heck are they doing penetrating IMC???? Betting their life that everything works? I'll take the odds in Vegas over that bet, any day. Training is a much better investment than ANY gizmo. Tim Cone ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:27 PM Subject: Re: RV-List: Efis question Do you think that most people are competent at partial panel in IMC? The oroginal poster suggested that panel space was an issue which I find hard to believe. Perhaps a good wing-leveler/autopilot might save you in you lost your only attitude source. Ron Lee ----- Original Message ----- From: Timothy E. Cone To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:48 PM Subject: Re: RV-List: Efis question Since when is a loss of ADI or artificial horizon an automatic trip to the morgue? Don't they teach "partial panel" anymore? ________________________________________________________________________________
Date: Sep 23, 2008
Tim, look at accident reports and you will find that 75% or so of the fatalities are due to pilot error. You have running out of fuel. You see flying into IMC when the pilot is not instrument rated but had been trained on partial panel. The Seaside OR crash appears to be a guy of unknown (to me) qualifications taking off into IMC. There was a plane that took off out of Steamboat Springs CO or close who impacted terrain. The weather was not suitable for this VFR pilot to fly and possibly not for any plane not certified for flight into icing conditions. I have not seen the report but would guess that it was gross pilot error. A family killed because of pilot stupidity. You see all kinds of Darwinistic behavior. Reality. A gizmo "may" make up for other system or human failures. Better judgement and training are perhaps better. The original poster needs to objectively assess his training, abilities and judgement and plan accordingly. Leaving out a alternate attitude reference that works for him may get him killed. Adding a "gizmo" might save him. Ron Lee ----- Original Message ----- From: Timothy E. Cone To: rv-list(at)matronics.com Sent: Tuesday, September 23, 2008 12:29 AM Subject: Re: RV-List: Efis question I'm really not trying to be snide, but if they aren't competent at partial panel, what in the heck are they doing penetrating IMC???? Betting their life that everything works? I'll take the odds in Vegas over that bet, any day. Training is a much better investment than ANY gizmo. Tim Cone ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:27 PM Subject: Re: RV-List: Efis question Do you think that most people are competent at partial panel in IMC? The oroginal poster suggested that panel space was an issue which I find hard to believe. Perhaps a good wing-leveler/autopilot might save you in you lost your only attitude source. Ron Lee ----- Original Message ----- From: Timothy E. Cone To: rv-list(at)matronics.com Sent: Monday, September 22, 2008 9:48 PM Subject: Re: RV-List: Efis question Since when is a loss of ADI or artificial horizon an automatic trip to the morgue? Don't they teach "partial panel" anymore? href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Regaurding radio noise
Date: Sep 23, 2008
This may not apply here but I had loud static that developed a while back that I couldnt find problem, then by accident I turned the vol contr down on Nav side (KX124) and noise gone. havent fixed as I never use Nav side. Also couple weeks ago I got a loude noise in earph as soon as I started take off, traced to Icom, problem turned out to be girlfriend had hung her head set on my 296 on panel and when I took it off and hung it on back hook noise gone. Charlie heaqthco ________________________________________________________________________________
Subject: Air Box Mounting Plate
Date: Sep 23, 2008
The last two times that I did my conditional inspection I found that my air box mounting aluminum plate was cracked. The first time I made a new mounting plate and tried to eliminate as many stress risers as I could. But it cracked again. This time I'm having a machine shop cut the rear hole behind the carburetor air intake (needed to clear the rear part of the carburetor) with a water cutting tool. I'm hoping that a smoother cut will prevent stress risers. Does anyone have any suggestions that may prevent the cracking? -- Gabe A Ferrer RV6 N2GX South Florida's Treasure Coast email: ferrerg(at)comcast.net cell: 561 758 8894
Gabe A Ferrer
RV6 N2GX
cell: 561 758 8894
Subject: Re: Air Box Mounting Plate
Date: Sep 23, 2008
Do you have adequate flexibility/movement at the airbox snout/cowl inlet se al to minimize stress on the airbox plate when there is movement of the eng ine? Dale Ensing ----- Original Message ----- From: ferrerg(at)comcast.net To: RV List Sent: Tuesday, September 23, 2008 9:37 AM Subject: RV-List: Air Box Mounting Plate The last two times that I did my conditional inspection I found that my a ir box mounting aluminum plate was cracked. The first time I made a new mounting plate and tried to eliminate as many stress risers as I could. But it cracked again. This time I'm having a machine shop cut the rear hole behind the carburet or air intake (needed to clear the rear part of the carburetor) with a wate r cutting tool. I'm hoping that a smoother cut will prevent stress risers. Does anyone have any suggestions that may prevent the cracking? -- Gabe A Ferrer RV6 N2GX South Florida's Treasure Coast email: ferrerg(at)comcast.net cell: 561 758 8894 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Sep 23, 2008
V2UgbWFkZSBvdXIgc2Vjb25kIG9uZSBvdXQgb2YgMC4wOTAgbWF0ZXJpYWwuLi4uDQoNCi0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBmZXJyZXJnQGNvbWNhc3QubmV0DQpTZW50OiBU dWVzZGF5LCBTZXB0ZW1iZXIgMjMsIDIwMDggOTozNyBBTQ0KVG86IFJWIExpc3QgPHJ2LWxpc3RA bWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJWLUxpc3Q6IEFpciBCb3ggTW91bnRpbmcgUGxhdGUN Cg0KVGhlIGxhc3QgdHdvIHRpbWVzIHRoYXSgSSBkaWQgbXkgY29uZGl0aW9uYWwgaW5zcGVjdGlv biBJIGZvdW5kIHRoYXSgbXkgYWlyIGJveCBtb3VudGluZyBhbHVtaW51bSBwbGF0ZaB3YXMgY3Jh Y2tlZC4NCqANClRoZSBmaXJzdCB0aW1lIEkgbWFkZSBhIG5ldyBtb3VudGluZyBwbGF0ZSBhbmQg dHJpZWQgdG8gZWxpbWluYXRlIGFzIG1hbnkgc3RyZXNzIHJpc2VycyBhcyBJIGNvdWxkLiBCdXQg aXQgY3JhY2tlZCBhZ2Fpbi4NCqANClRoaXOgdGltZSBJJ20gaGF2aW5nIGEgbWFjaGluZSBzaG9w IGN1dCB0aGUgcmVhciBob2xlIGJlaGluZCB0aGWgY2FyYnVyZXRvciBhaXIgaW50YWtloChuZWVk ZWQgdG8gY2xlYXIgdGhlIHJlYXIgcGFydCBvZiB0aGWgY2FyYnVyZXRvcimgd2l0aCBhIHdhdGVy IGN1dHRpbmcgdG9vbC4NCqANCkknbSBob3BpbmcgdGhhdCBhIHNtb290aGVyIGN1dCB3aWxsIHBy ZXZlbnQgc3RyZXNzIHJpc2Vycy4NCqANCkRvZXMgYW55b25lIGhhdmUgYW55IHN1Z2dlc3Rpb25z IHRoYXQgbWF5IHByZXZlbnQgdGhlIGNyYWNraW5nPw0KLS0NCkdhYmUgQSBGZXJyZXINClJWNiBO MkdYDQpTb3V0aCBGbG9yaWRhJ3MgVHJlYXN1cmUgQ29hc3QNCmVtYWlsOiBmZXJyZXJnQGNvbWNh c3QubmV0DQpjZWxsOiA1NjEgNzU4IDg4OTQNCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIFJW LUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBO YXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExp c3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkg QnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWLUxpc3QKXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0 IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0gICAtLT4gaHR0 cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3Vw cG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0 IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQoK ________________________________________________________________________________
Subject: tailwheel nut torque
Date: Sep 23, 2008
SNIP ******** Subject: RV-List: Tail wheel bolt torque What torque do you use for the 1/2 inch nut that holds the tailwheel fork on the spring? The torque for 1/2 in. bolts is 480 inch lbs ,but when it is this tight the fork is hard to turn in the mount. George H. Inman SNIP************** Ideally you should be able to tighten that nut normally, i.e. all the way down. I don't believe that putting 40 foot pounds (480 inch pounds) is really necessary... hand tightening normally is OK if your self-locking nut is in good shape. However, if you tighten the nut and it puts the mechanism in a bind, that isn't good. What is happening is that your socket is too tall for your fork. When you tighten the big nut, it binds everything. You can remedy this by removing a few thousandths of an inch of the socket height with a file, belt sander, etc. Obviously, you want to keep it relatively square while you're doing this. You can remove material from either end as it shouldn't be very much at all. An alternate fix for the "too tall, too tight" might be to drill the threaded portion of the fork to accept a cotter pin. Then you could leave the (castle) nut a little bit loose and not worry about it departing. If this doesn't make sense, feel free to call me in my office at from that number, so if I don't answer please try again later or send an e-mail. Vince Frazier - the tailwheel guy, 150+ sold, in stock and ready to ship always Screaming Eagle Graphics and Accessories 3965 Caborn Road Mount Vernon, IN 47620 812-464-1839 http://www.vincesrocket.com/products.htm ________________________________________________________________________________
Date: Sep 23, 2008
Subject: Wheel pants too low?
I installed the wheel pants on my RV-8 per Van's directions,but I think they may be too low. I cannot get a 2X4 underneath the back for a wheel chock when the plane is down on the tail. I will be using a grass strip so have concerns.Do others have their wheel pants this low? -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Sep 23, 2008
Subject: Re: Wheel pants too low?
Sounds about right to me, I can not get a 2X4 under the wheel pant either. I use 1/2" aluminum angle as a wheel chock. Even that is a tight fit! Bob RV6 "Wicked Witch of the West" At 10:29 AM 9/23/08, you wrote: > > > I installed the wheel pants on my RV-8 >per Van's directions,but I think they may be too low. > I cannot get a 2X4 underneath the back for a wheel chock >when the plane is down on the tail. > I will be using a grass strip so have concerns.Do others have >their wheel pants this low? > >-- > >George H. Inman >ghinman(at)mts.net > > ________________________________________________________________________________
From: "Richard Dudley" <rhdudley1(at)bellsouth.net>
Subject: Instrument Refresher Simulator and Joy Stick for sale
Date: Sep 23, 2008
I no longer have need for these. Software and Pilot's Operating Handbook. Instrument Refresher Simulator by ASA Interactive Products. Like new. Requires joystick. I'll sell for $40. It cost me $74. See attachment. High end joystick. By CH Products Flight Simulator and Gaming Gear. Called "Flightstick". USB interface to computer. Recommended for IPC Instrument Refresher Simulator. In original box with software. Like new. I'll sell the joystick for $50.It cost me $85. For details, see: http://www.mypilotstore.com/MyPilotStore/sep/4128 RHDudley RV-6A flying and for sale ________________________________________________________________________________
Date: Sep 23, 2008
I installed my RV-6's wheel pants also per Van's instructions and cannot get any standard chocks under them. I made some "U" shaped chocks from 3/4 PVC pipe and elbows that work great and weigh next to nothing. -- Harry Crosby RV-6 N16CX, flying - 516 hours -------------- Original message ---------------------- From: George Inman 204 287 8334 <ghinman(at)mts.net> > > > > I installed the wheel pants on my RV-8 > per Van's directions,but I think they may be too low. > I cannot get a 2X4 underneath the back for a wheel chock > when the plane is down on the tail. > I will be using a grass strip so have concerns.Do others have > their wheel pants this low? > > -- > > George H. Inman > ghinman(at)mts.net > > > > > > ________________________________________________________________________________
Date: Sep 23, 2008
Walt: I have kind of same problem, untill I discovered it was the way I con trol the Intercom...I had it too much to the noise side....play with the Interco m, next time you are flying, ( ofcurse, in non congested area OK?) It worked for me now no more noise on radio..... - robert --- On Mon, 9/22/08, Jerry Grimmonpre wrote: From: Jerry Grimmonpre <jerry(at)mc.net> Subject: Re: RV-List: Radio Problem Date: Monday, September 22, 2008, 10:44 PM Walt ... you could run this by the Aeroelectric List at--- aeroelectr ic-list(at)matronics.com---- and Bob Nuckolls could suggest some thing s to try. Bob is very good at finding the mysteries of black art.- Let us know what happens.- Good luck, Jerry- > Guys, I have an Apollo SL-30 in my RV-8 which has a rather > unique (to me anyway) problem; on the ground, even with the > engine running at high rpm, the radio works flawlessly, in the > air it's a different story. As soon as I take off, a loud > background noise begins which makes receiving transmissions > nearly impossible. Usually, sometime during the flight, this > noise goes away and the reception is crystal clear! > > I have a belly mounted Comant-bent whip antenna. Coax > connections are tight. Any ideas of what the problem is? > > Walt Shipley =0A=0A=0A ________________________________________________________________________________
Date: Sep 23, 2008
-Quesstion again,:- what are people that have installed the EFIS,- do ... Robert --- On Mon, 9/22/08, Jim Fogarty at Lakes & Leisure Realty wrote: From: Jim Fogarty at Lakes & Leisure Realty <jfogarty(at)tds.net> Subject: Re: RV-List: Efis question Date: Monday, September 22, 2008, 11:38 AM Ron,- That is- a great point. - Jim RV9a building - MN ----- Original Message ----- From: Ron Lee Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. - People...think about what you are doing. - Ron Lee - - href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.co m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 9/22/2008 6:39 AM =0A=0A=0A ________________________________________________________________________________
Subject: Efis question
Date: Sep 23, 2008
Just look at the panel of any small certified EFIS equipped airplane. They all have a steam gage attitude gyro, altimeter, and ASI. Of course you could install one of those cute single instrument electronic standby gyros they install on the big iron, about 20k I think. Bruce <http://www.glasair.org/> www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bert murillo Sent: Tuesday, September 23, 2008 3:34 PM Subject: Re: RV-List: Efis question Quesstion again,: what are people that have installed the EFIS, do... Robert --- On Mon, 9/22/08, Jim Fogarty at Lakes & Leisure Realty wrote: From: Jim Fogarty at Lakes & Leisure Realty <jfogarty(at)tds.net> Subject: Re: RV-List: Efis question Date: Monday, September 22, 2008, 11:38 AM Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: Ron Lee <mailto:ronlee(at)pcisys.net> Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ 9/22/2008 6:39 AM 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Sep 23, 2008
George, My -8 wheel pants are the same way. No way will a 2x4 fit behind the tire. Mine seem to be lower in the back compared to most others I've looked at. I have flown on grass strips many, many times with no problem. The only issue I have is getting into hangars that have steel angle installed on the floor as a door track. The back of my pant can't clear these tracks without putting down some type of ramp. I've scarred the bottom rear of my pants numerous times. Rick McBride ----- Original Message ----- From: George Inman 204 287 8334<mailto:ghinman(at)mts.net> To: RV-list matronics Sent: Tuesday, September 23, 2008 11:29 AM Subject: RV-List: Wheel pants too low? > I installed the wheel pants on my RV-8 per Van's directions,but I think they may be too low. I cannot get a 2X4 underneath the back for a wheel chock when the plane is down on the tail. I will be using a grass strip so have concerns.Do others have their wheel pants this low? -- George H. Inman ghinman(at)mts.net http://www.matronics.com/Navigator?RV-List ator?RV-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: Oil leak
Date: Sep 23, 2008
Hey John=2C I have a TMX IO360 and have the same problem. I already replaced the pump o nce=2C and the new one is doing the same thing. I've retorqued the screws a nd bolts=2C but that has not solved the problem. I have to do some researc h to find a differend pump as well as call Mattituck and talk to them about it. Mine is also not leaking enough that I worry about it in flight=2C bu t I do have to clean the belly a lot. Let us know how you make out. From: december29(at)bellsouth.netTo: rv-list(at)matronics.comSubject: RV-List: Oi l leakDate: Sat=2C 20 Sep 2008 14:43:40 -0400 Hi all=2C Searched the archives but have a "new" oil leak location. Anyone had one on the mechanical fuel pump? I have a total of 58 hours on the pump and it appears that the oil is wicking out of the top of the stainless screws tha t sandwich the whole pump together. First off=2C are they supposed to be s afety wired=2C because mine are not (came from the "factory" that way). The aft face of the engine that the pump mounts to is dry. It is not a big leak=2C but one just the same. I will try the solvent an d Dr. Scholl's to confirm. But anyone with something like this? Very lubed=2C John N802RJ "Rockin' Robin" ________________________________________________________________________________
Date: Sep 23, 2008
Robert - I installed AFS-3500 & -3400 (both with internal backup batteries), TruTrak ADI with internal GPS and backup battery, TruTrak Digiflight VSGV, round ASI, round Altimeter. But I'm not flying yet. Neal RV-7 N8ZG From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bert murillo Sent: Tuesday, September 23, 2008 2:34 PM Subject: Re: RV-List: Efis question Quesstion again,: what are people that have installed the EFIS, do... Robert --- On Mon, 9/22/08, Jim Fogarty at Lakes & Leisure Realty wrote: From: Jim Fogarty at Lakes & Leisure Realty <jfogarty(at)tds.net> Subject: Re: RV-List: Efis question Date: Monday, September 22, 2008, 11:38 AM Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: Ron Lee <mailto:ronlee(at)pcisys.net> Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ 9/22/2008 6:39 AM D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Date: Sep 23, 2008
I had two plates crack on my 8A. I modified the cowl intake (more forward) and have a scat hose connection to the airbox. I assumed the added weight of the hose was causing the problem. I made a plate out of .032" stainless steel - problem solved. Carl Froehlich RV-8A (450 hrs) RV-10 (fuselage) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Tuesday, September 23, 2008 10:18 AM Subject: RE: RV-List: Air Box Mounting Plate We made our second one out of 0.090 material.... _____ From: ferrerg(at)comcast.net Sent: Tuesday, September 23, 2008 9:37 AM Subject: RV-List: Air Box Mounting Plate The last two times that I did my conditional inspection I found that my air box mounting aluminum plate was cracked. The first time I made a new mounting plate and tried to eliminate as many stress risers as I could. But it cracked again. This time I'm having a machine shop cut the rear hole behind the carburetor air intake (needed to clear the rear part of the carburetor) with a water cutting tool. I'm hoping that a smoother cut will prevent stress risers. Does anyone have any suggestions that may prevent the cracking? -- Gabe A Ferrer RV6 N2GX South Florida's Treasure Coast email: ferrerg(at)comcast.net cell: 561 758 8894 ========== //www.matronics.com/Navigator?RV-List ========== ics.com ========== matronics.com/contribution ========== ________________________________________________________________________________
Date: Sep 23, 2008
My wheel pants also had the same problem, couldn=92t clear the angle on the bottom of my door. I ended up always backing my plane in by lifting the tail to clear. When I finally wore the original tire out, I replaced them with retreads and the tires just happen to be taller by =BD=94 to =BE=94. This allowed the rear of the wheel pants to clear the angle. John L. Danielson _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard McBride Sent: Tuesday, September 23, 2008 2:07 PM Subject: Re: RV-List: Wheel pants too low? George, My -8 wheel pants are the same way. No way will a 2x4 fit behind the tire. Mine seem to be lower in the back compared to most others I've looked at. I have flown on grass strips many, many times with no problem. The only issue I have is getting into hangars that have steel angle installed on the floor as a door track. The back of my pant can't clear these tracks without putting down some type of ramp. I've scarred the bottom rear of my pants numerous times. Rick McBride ----- Original Message ----- From: George <mailto:ghinman(at)mts.net> Inman 204 287 8334 Sent: Tuesday, September 23, 2008 11:29 AM Subject: RV-List: Wheel pants too low? I installed the wheel pants on my RV-8 per Van's directions,but I think they may be too low. I cannot get a 2X4 underneath the back for a wheel chock when the plane is down on the tail. I will be using a grass strip so have concerns.Do others have their wheel pants this low? -- George H. Inman
http://www.matronics.nbsp; via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com nbsp; generous bsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c ==== =========== ________________________________________________________________________________
Date: Sep 23, 2008
This seems to be a universal problem with the Van's tail draggers. My 8 is the same; I taxi across about 100' of grass to get to my airpark's runway and I get a collection of grass inside the rear half of the pants everytime. Walt Shipley -----Original Message----- >From: HCRV6(at)comcast.net >Sent: Sep 23, 2008 1:38 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Wheel pants too low? > > >I installed my RV-6's wheel pants also per Van's instructions and cannot get any standard chocks under them. I made some "U" shaped chocks from 3/4 PVC pipe and elbows that work great and weigh next to nothing. > >-- >Harry Crosby >RV-6 N16CX, flying - 516 hours > > -------------- Original message ---------------------- >From: George Inman 204 287 8334 <ghinman(at)mts.net> >> >> >> >> I installed the wheel pants on my RV-8 >> per Van's directions,but I think they may be too low. >> I cannot get a 2X4 underneath the back for a wheel chock >> when the plane is down on the tail. >> I will be using a grass strip so have concerns.Do others have >> their wheel pants this low? >> >> -- >> >> George H. Inman >> ghinman(at)mts.net >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 23, 2008
Robert I am flying my RV and I do agree with Neal's statement below. I do have a 2 1/4 TruTrak ADI with a backup battery plus its own GPS and it works great . It is also nice to have a cross check to my OP Technologies EFIS GPS Tracking number. and that Tracking number on the TruTrak ADI . I do have to admit that when I am flying the GPS Tracking Degree number on the TruTrak ADI , TruTrak Autopilot and the OP Technologies EFIS is seldom the match. Don't know why but they are always a degree or two off. Dane N838RV RV8a In a message dated 9/23/2008 4:09:37 P.M. Central Daylight Time, n8zg(at)mchsi.com writes: Robert =93 I installed AFS-3500 & -3400 (both with internal backup batteries), TruTrak ADI with internal GPS and backup battery, TruTrak Digiflight VSGV, round ASI , round Altimeter. But I=99m not flying yet Neal RV-7 N8ZG From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bert murillo Sent: Tuesday, September 23, 2008 2:34 PM Subject: Re: RV-List: Efis question Quesstion again,: what are people that have installed the EFIS, do... Robert --- On Mon, 9/22/08, Jim Fogarty at Lakes & Leisure Realty wrote: From: Jim Fogarty at Lakes & Leisure Realty <jfogarty(at)tds.net> Subject: Re: RV-List: Efis question Date: Monday, September 22, 2008, 11:38 AM Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: _Ron Lee_ (mailto:ronlee(at)pcisys.net) Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com /Nav igator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ____________________________________ 9/22/2008 6:39 AM http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?RV-List) (http://www.matronics.com/contribution) **************Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips a nd calculators. (http://www.walletpop.com/?NCID=emlcntuswall00000001) ________________________________________________________________________________
Date: Sep 23, 2008
My 2 1/4" ADI, 2 1/4" Altimeter and 2 1/4" Airspeed is my partial panel. (plus an old battery operator Garmin 95 GPS ) Dane N838RV RV8a In a message dated 9/22/2008 10:50:52 P.M. Central Daylight Time, tcone1(at)comcast.net writes: Since when is a loss of ADI or artificial horizon an automatic trip to the morgue? Don't they teach "partial panel" anymore? ----- Original Message ----- From: _David Maib_ (mailto:dmaib(at)mac.com) Sent: Monday, September 22, 2008 7:34 PM Subject: Re: RV-List: Efis question That is true whether it is an EFIS or a "steam gauge" attitude indicator that is your sole spatial orientation reference. David Maib On Sep 22, 2008, at 10:38 AM, Jim Fogarty at Lakes & Leisure Realty wrote: Ron, That is a great point. Jim RV9a building - MN ----- Original Message ----- From: _Ron Lee_ (mailto:ronlee(at)pcisys.net) Sent: Monday, September 22, 2008 9:25 AM Subject: Re: RV-List: Efis question Bert, if you are IMC and all you have is an EFIS for spatial orientation and you lose it then most likely within a minute or two you will enter uncontrolled flight and will soon be dead. People...think about what you are doing. Ron Lee href="_http://www.matronics.com/Navigator?RV-List_ (http://www.matronics.com/Navigator?RV-List) ">_http://www.matronics.com/Navigator?RV-List_ (http://www.matronics.com/Navigator?RV-List) href="_http://forums.matronics.com_ (http://forums.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) href="_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/c_ (http://www.matronics.com/c) ____________________________________ 9/22/2008 6:39 AM http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution (http://www.matronics.com/Navigator?RV-List) (http://www.matronics.com/contribution) **************Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators. (http://www.walletpop.com/?NCID=emlcntuswall00000001) ________________________________________________________________________________
Subject: RE: Oil Leak
Date: Sep 24, 2008
Paul, Yep, that's exactly what I'm getting. I have a Lycoming AEIO-360 and it's just enough to get my attention. I'm going to pull my pump as well and use some permetex on it and we torque everything. I can't stand seeing oil on the outside of something. (Now when the new "radial" RV comes out, that will be another story, ha,ha) Oh, Van swore me to secrecy on that.................darn. Thanks for the input, glad (I guess) that I'm not the only one with this issue. John N802RJ "Rockin' Robin" ________________________________________________________________________________
Date: Sep 24, 2008
Subject: IMC - What If??? Analysis
FWIW - I spent a lot of time analyzing panel options for my -8A, and so far have found no major issues with the conclusions I reached. Here's a summar y: Requirement 1: IMC capability (if I choose to go there) - including ILS. ( Pilot instrument experience not an issue - I'm a retired Naval aviator). Requirement 2: Electric panel - no vacuum pumps. Requirement 3: Multiple redundancy - fidelity can vary. Final instrument configuration: AFS-3500 with AOA; TruTrac ADI II; Sl 40; Garmin 496; ICOM Radio; GTX-327; PMA-7000B; Separate altimeter, airspeed, V SI; Heated pitot tube. Electrical System: B&C 40 amp alternator; SD-8 alternator; self-contained b ackup batteries in 3500 and 496; regular ship's battery. In IMC - What ifs? (Normal ops - everything works and power is from main bu s) 1. AFS-3500 failure - use ADI II for attitude info; if unsure of atti tude, select a heading and altitude hold mode. Use AS / Altimeter / VSI ste am gages. 2. AFS-3500 and ADI II failure - use rough attitude functions of 496 to get back to approximate level flight (a real emergency) 3. AFS-3500, ADI II and 496 failure - partial panel with the AS / Alt and VSI; but realistically, sometimes it just ain't your day. 4. Alternator failure - endurance bus powered by SD-8 (3500, SL-40, A DI II are on it) 5. Alternator and SD-8 failure - endurance bus powered by main batter y 6. Alternator, SD-8 and main battery failure - 3500 and 496 powered b y internal backup batteries 7. Alternator, SD-8, main battery and backup battery failures - see ( 3) above 8. Pitot static failure - 496 and AOA attitude reference (if AOA is below stall you are at least somewhat in control and may have additional ti me to sort things out) 9. Icing - Get the hell out of there asap Panel configuration is a very personal decision. However, some version of t he "What ifs???" should be used in every analysis. The above is just one gu y's opinion. Be interested in hearing from folks who think I'm off on a tan gent or missed something. Booger N192NM Reserved - Again ________________________________________________________________________________
Date: Sep 24, 2008
Paul, Those aren't "rubber gaskets". They are the rubber diaphragms which do the pumping of the fuel. If the screws which retain the sections are reasonably tight, it means that one of the diaphragms has failed. In that case you will need a new or rebuilt fuel pump. Charlie Kuss --- On Wed, 9/24/08, Paul Rice wrote: > From: Paul Rice <rice737(at)msn.com> > Subject: RE: RV-List: RE: Oil Leak > To: rv-list(at)matronics.com > Date: Wednesday, September 24, 2008, 10:43 AM > The oil leaks out between the parts of the oil pump itself, > not the flange between the pump and the engine. The pump is > made up of three sections, the upper is has screw head bolts > attaching it to the middle section, and the lower has hex > heads with rubber gaskets between. They go thru a > compression ring around the bottom, I can remember the top > right now, so you can only tighten them up so much. I seems > over tightening will just crush the rubber gasket out of the > sides causing more of a leak. I don't know about taking > it apart and using the permetex, I really don't want to > take my pump apart if I can help it. > > Paul Rice > RV8 100 hours > Flying Siren> Date: Wed, 24 Sep 2008 10:20:10 -0400> > From: pitts_pilot(at)bellsouth.net> To: > rv-list(at)matronics.com> Subject: Re: RV-List: RE: Oil > > > OK guys ...... > where exactly is the oil coming out??? Lead me to it > > just like a progressive taxi ;-)> Linn> do not > archive> > John Porter wrote:> > Paul,> > > Yep, that's exactly what I'm getting. I have a > Lycoming AEIO-360 > > and it's just enough to get > my attention. I'm going to pull my pump > > as > well and use some permetex on it and we torque everything. I > can't > > stand seeing oil on the outside of > something. (Now when the new > > "radial" RV > comes out, that will be another story, ha,ha) Oh, Van > > > swore me to secrecy on that.................darn.> > > Thanks for the input, glad (I guess) that I'm not > the only one with > > this issue.> > > > > ====================> > > ________________________________________________________________________________
Date: Sep 24, 2008
Subject: RV-8 "Curved Control Stick" Option...?
Greetings, I sat in a friend's RV-8 this weekend and was testing out the various ergonomic aspects. One thing that struck me was the pilot's control stick placement. It seemed a bit far away and definitely way too low. The top of the stick cleared the bottom of the instrument panel by maybe an inch or less, so it was definitely about as long as it could be. The seat cushion didn't seem abnormally thick. When I ordered my seats from Classic Aero Designs, one of the questions they asked me was if I had the "Curved Stick Option". I didn't think about it much at the time but now I'm intrigued. Is this something that could give me more stick height without impacting the instrument panel? Does Van's sell it? Part number? Pros and cons? Pictures? Thanks, Matt Dralle RV-8 #82880 N844RV (res.) ________________________________________________________________________________
Date: Sep 24, 2008
And another thing! Mike Robbins has an interesting and apparently very functional stick grip offset that I think was built by Rocket builder Larry James. Either of them could probably tell you about it or maybe send a photo. Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Wednesday, September 24, 2008 8:53 AM Subject: RV-List: RV-8 "Curved Control Stick" Option...? Greetings, I sat in a friend's RV-8 this weekend and was testing out the various ergonomic aspects. One thing that struck me was the pilot's control stick placement. It seemed a bit far away and definitely way too low. The top of the stick cleared the bottom of the instrument panel by maybe an inch or less, so it was definitely about as long as it could be. The seat cushion didn't seem abnormally thick. When I ordered my seats from Classic Aero Designs, one of the questions they asked me was if I had the "Curved Stick Option". I didn't think about it much at the time but now I'm intrigued. Is this something that could give me more stick height without impacting the instrument panel? Does Van's sell it? Part number? Pros and cons? Pictures? Thanks, Matt Dralle RV-8 #82880 N844RV (res.) ________________________________________________________________________________
Date: Sep 24, 2008
Walt, Did you install a bulkhead in the rear half of the wheel pants to prevent crud from collecting back there? -- Harry Crosby RV-6 N16CX, flying - 517 hours -------------- Original message ---------------------- From: rveighta <rveighta(at)earthlink.net> > > This seems to be a universal problem with the Van's tail draggers. My 8 is the > same; I taxi across about 100' of grass to get to my airpark's runway and I get > a collection of grass inside the rear half of the pants everytime. > > Walt Shipley ________________________________________________________________________________
Subject: Re: RV-8 "Curved Control Stick" Option...?
Date: Sep 24, 2008
Matt, RV Woody 4606 107th Street Mukilter, WA 98275 ATTN Todd Rudberg This is the guy that was making them for builders, usually in batches. Dont know if this is still the case. I have attached the low res drawing. Yo u can see the dimentions. Best, Mike, (See attached file: bentstick.jpg) Matt Dralle To Sent by: rv-list(at)matronics.com owner-rv-list-ser cc ver(at)matronics.com Subj ect RV-List: RV-8 "Curved Control 09/24/2008 11:52 Stick" Option...? AM Please respond to rv-list@matronics .com Greetings, I sat in a friend's RV-8 this weekend and was testing out the various ergonomic aspects. One thing that struck me was the pilot's control st ick placement. It seemed a bit far away and definitely way too low. The t op of the stick cleared the bottom of the instrument panel by maybe an inc h or less, so it was definitely about as long as it could be. The seat cush ion didn't seem abnormally thick. When I ordered my seats from Classic Aero Designs, one of the questions they asked me was if I had the "Curved Stick Option". I didn't think a bout it much at the time but now I'm intrigued. Is this something that coul d give me more stick height without impacting the instrument panel? Does Van's sell it? Part number? Pros and cons? Pictures? Thanks, Matt Dralle RV-8 #82880 N844RV (res.) ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Sep 24, 2008
Interesting, what tail wheel system are you using? I understand there are some available that raise the tail slightly and maybe that would be enough to correct it also. Tim Bryan RV-6 Flying N616TB over 100 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Danielson Sent: Tuesday, September 23, 2008 6:59 PM Subject: RE: RV-List: Wheel pants too low? My wheel pants also had the same problem, couldn=92t clear the angle on the bottom of my door. I ended up always backing my plane in by lifting the tail to clear. When I finally wore the original tire out, I replaced them with retreads and the tires just happen to be taller by =BD=94 to =BE=94. This allowed the rear of the wheel pants to clear the angle. John L. Danielson _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard McBride Sent: Tuesday, September 23, 2008 2:07 PM Subject: Re: RV-List: Wheel pants too low? George, My -8 wheel pants are the same way. No way will a 2x4 fit behind the tire. Mine seem to be lower in the back compared to most others I've looked at. I have flown on grass strips many, many times with no problem. The only issue I have is getting into hangars that have steel angle installed on the floor as a door track. The back of my pant can't clear these tracks without putting down some type of ramp. I've scarred the bottom rear of my pants numerous times. Rick McBride ----- Original Message ----- From: George <mailto:ghinman(at)mts.net> Inman 204 287 8334 Sent: Tuesday, September 23, 2008 11:29 AM Subject: RV-List: Wheel pants too low? I installed the wheel pants on my RV-8 per Van's directions,but I think they may be too low. I cannot get a 2X4 underneath the back for a wheel chock when the plane is down on the tail. I will be using a grass strip so have concerns.Do others have their wheel pants this low? -- George H. Inman http://www.matronics.nbsp; via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com nbsp; generous bsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c ==== =========== http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 24, 2008
Harry::: - What is this??? please tell me I should have done that?- I did not see th at on the plans.... I have the rv6a,-- please explain... I am now worried I am missing that?? how is it done etc... - bert --- On Wed, 9/24/08, HCRV6(at)comcast.net wrote: From: HCRV6(at)comcast.net <HCRV6(at)comcast.net> Subject: Re: RV-List: Wheel pants too low? Date: Wednesday, September 24, 2008, 12:31 PM Walt, Did you install a bulkhead in the rear half of the wheel pants to prevent c rud from collecting back there? -- Harry Crosby RV-6 N16CX, flying - 517 hours -------------- Original message ---------------------- From: rveighta <rveighta(at)earthlink.net> > > This seems to be a universal problem with the Van's tail draggers. My 8 is the > same; I taxi across about 100' of grass to get to my airpark's runway and I get > a collection of grass inside the rear half of the pants everytime. > > Walt Shipley =0A=0A=0A ________________________________________________________________________________
Date: Sep 24, 2008
From: Carlos Hernandez <carlosh(at)structuralaz.com>
Yeah he's not doing it any more. Here's what he says from his web site www.rvwoody.com /"LAST BATCH EVER: March 1, 2007. Due to customer complaints about the six week lead time, this service is terminated. If you want a stick done, better get it to me by March 1. Sticks received after March 1 will be returned to sender." /Bummer cause I was wanting one when I get there in my build./ / Carlos in AZ Michael W Stewart wrote: > > Matt, > RV Woody > 4606 107th Street > Mukilter, WA 98275 > ATTN Todd Rudberg > > This is the guy that was making them for builders, usually in batches. > Dont know if this is still the case. I have attached the low res > drawing. You can see the dimentions. > Best, > Mike > > /(See attached file: bentstick.jpg)/ > > > Inactive hide details for Matt Dralle ---09/24/2008 12:31:33 PM-----> > > > *Matt Dralle * > Sent by: owner-rv-list-server(at)matronics.com > > 09/24/2008 11:52 AM > Please respond to > rv-list(at)matronics.com > > > > To > > rv-list(at)matronics.com > > cc > > > Subject > > RV-List: RV-8 "Curved Control Stick" Option...? > > > > > Greetings, > > I sat in a friend's RV-8 this weekend and was testing out the various > ergonomic aspects. One thing that struck me was the pilot's control > stick placement. It seemed a bit far away and definitely way too low. > The top of the stick cleared the bottom of the instrument panel by > maybe an inch or less, so it was definitely about as long as it could > be. The seat cushion didn't seem abnormally thick. > > When I ordered my seats from Classic Aero Designs, one of the > questions they asked me was if I had the "Curved Stick Option". I > didn't think about it much at the time but now I'm intrigued. Is this > something that could give me more stick height without impacting the > instrument panel? Does Van's sell it? Part number? Pros and cons? > Pictures? > > Thanks, > > Matt Dralle > RV-8 #82880 N844RV (res.) > > > ==================================== > tor?RV-List">http://www.matronics.com/Navigator?RV-List > ==================================== > FORUMS - > tp://forums.matronics.com > ==================================== > Site - > bsp; -Matt Dralle, List Admin. > bution">http://www.matronics.com/contribution > ==================================== > > > ------------------------------------------------------------------------ > > ------------------------------------------------------------------------ > > Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Sep 24, 2008
Subject: Mud Shield - was Wheel pants too low?
I did it for all three of mine too - mine are from SamJames they had explicit instructions to do so - not as good on how though..... Here's what I did: Lay up three layers of BID on alternating angles. Cut out rough shape so it fits one inch behind the tire. Trim corners so it fits tightly all the way around. Using two layers of BID to glue the edges in place. Drill a small hole on the bottom of the pant behind the shield to allow pressure to bleed off and condensation to drain. Have a cold one..... -----Original Message----- >From: bert murillo <robertrv607(at)yahoo.com> >Sent: Sep 24, 2008 1:59 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Wheel pants too low? > >Harry::: > >What is this??? please tell me I should have done that? I did not see that >on the plans.... I have the rv6a, please explain... I am now worried I am >missing that?? how is it done etc... > >bert > >--- On Wed, 9/24/08, HCRV6(at)comcast.net wrote: > >From: HCRV6(at)comcast.net <HCRV6(at)comcast.net> >Subject: Re: RV-List: Wheel pants too low? >To: rv-list(at)matronics.com >Date: Wednesday, September 24, 2008, 12:31 PM > > >Walt, > >Did you install a bulkhead in the rear half of the wheel pants to prevent crud >from collecting back there? > >-- >Harry Crosby >RV-6 N16CX, flying - 517 hours > > -------------- Original message ---------------------- >From: rveighta <rveighta(at)earthlink.net> >> >> This seems to be a universal problem with the Van's tail draggers. My >8 is the >> same; I taxi across about 100' of grass to get to my airpark's >runway and I get >> a collection of grass inside the rear half of the pants everytime. >> >> Walt Shipley > > ________________________________________________________________________________
Date: Sep 24, 2008
To play the devils advocate, You'll be lucky if, when your EFIS fails, the screen goes dark. More than likely, part of it will just freeze, or worse yet - start giving you false information. What do you do when all your electro-wizzies fail? It's happened - several times in big iron aircraft, failure of multiple electrical systems and their backups leaving a totally dark cockpit. One of the reasons that all EFIS certified panels have a vacuum ADI or equivalent. But let's look at a more likely failure mode, the AHRS starts to put out false information. Your Tru-Trak ADI (It's not really) only displays quasi pitch info. It shows a GPS derived VSI as pitch up/down commands. Now, the big question is - are you willing to bet your life that you addled and confused brain is going to be able to sort out the conflicting and non standard pitch information before you go "THUD"? And as your screaming brain is yelling - which system is right? Needle, ball, and airspeed tie breaker? I know I've spent hundreds of hours scanning the basic 6 pack in IMC and am well aware of its failure modes. But when screens go dark or scrambled it's the easiest and fasted for me to revert to and feel comfortable. Bruce <http://www.glasair.org/> www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul Sent: Wednesday, September 24, 2008 11:37 AM Subject: RV-List: IMC - What If??? Analysis FWIW - I spent a lot of time analyzing panel options for my -8A, and so far have found no major issues with the conclusions I reached. Here's a summary: Requirement 1: IMC capability (if I choose to go there) - including ILS. (Pilot instrument experience not an issue - I'm a retired Naval aviator). Requirement 2: Electric panel - no vacuum pumps. Requirement 3: Multiple redundancy - fidelity can vary. Final instrument configuration: AFS-3500 with AOA; TruTrac ADI II; Sl 40; Garmin 496; ICOM Radio; GTX-327; PMA-7000B; Separate altimeter, airspeed, VSI; Heated pitot tube. Electrical System: B&C 40 amp alternator; SD-8 alternator; self-contained backup batteries in 3500 and 496; regular ship's battery. In IMC - What ifs? (Normal ops - everything works and power is from main bus) 1. AFS-3500 failure - use ADI II for attitude info; if unsure of attitude, select a heading and altitude hold mode. Use AS / Altimeter / VSI steam gages. 2. AFS-3500 and ADI II failure - use rough attitude functions of 496 to get back to approximate level flight (a real emergency) 3. AFS-3500, ADI II and 496 failure - partial panel with the AS / Alt and VSI; but realistically, sometimes it just ain't your day. 4. Alternator failure - endurance bus powered by SD-8 (3500, SL-40, ADI II are on it) 5. Alternator and SD-8 failure - endurance bus powered by main battery 6. Alternator, SD-8 and main battery failure - 3500 and 496 powered by internal backup batteries 7. Alternator, SD-8, main battery and backup battery failures - see (3) above 8. Pitot static failure - 496 and AOA attitude reference (if AOA is below stall you are at least somewhat in control and may have additional time to sort things out) 9. Icing - Get the hell out of there asap Panel configuration is a very personal decision. However, some version of the "What ifs???" should be used in every analysis. The above is just one guy's opinion. Be interested in hearing from folks who think I'm off on a tangent or missed something. Booger N192NM Reserved - Again ________________________________________________________________________________
Date: Sep 24, 2008
MessageHi Bruce, You know I agree with you historically on some of your points, but I have to jump in here just a little bit - nothing personal, just want to re-direct a few facts. Your understanding of the TruTrak ADI is not just a little bit off....it's just flat wrong. Who told you it uses GPS information for vertical information? They use GPS to show a track in the little LCD window...it has nothing to do with the flight display. You do of course realize that it has solid state gyros inside of it and shows instantaneous pitch and bank information as well? Naturally you also know that it has a Pitot and Static connection on the back of it to sense pitot/satic info? Of course some of the EFIS mfgrs out there use GPS as an aiding function to offset the accelerometer drift, etc.., but I'm not aware of any other than the little "instrument page" of the Garmin handhelds that do anything of the sort. Anyway, I don't want to get into a debate on what should be used when and where nor if the ADI is for you or not...just want to make sure people don't think it uses GPS to display any flight information. I do agree that there is a BIG question on lower cost EFISes knowing whether they are ill or not. The certified stuff has a ton of software in it for that very purpose, and will paint a big red "X" over any portion of the instrument it thinks doesn't has perfect information. Most of the really low cost EFISes will not alert you to anything being wrong, because the EFIS itself doesn't know it's sick. It's what I try to tell people over and over. There is a MUCH larger difference between EFISes than just plain cost. There is a lot of other unseen functionality that comes with the higher priced units other than their name on the faceplate. Of course every EFIS mfgr will tell you their stuff is the same as the certified Garmin or what is in the Boeings while standing in the booth at OSH (I actually heard a rep from a low cost EFIS mfgr repeatedly tell people their stuff was as good or better than the Garmin certified stuff)....hopefully people realize that's just not the case and couldn't be farther from the truth. Does that mean the low cost EFISes are bad? Heck no! They are a marvel of technology as long as you use them for what they are. FYI...most of the heavy iron is going to solid state peanut backups as well....but they aren't anything like our low cost EFISes (nor the price)! Again, nothing personal and I'm not necessarily disagreeing with premise in general, just some of the details. The whole "tie breaker" discussion gets really interesting really fast in some of these configurations. There are a number of historical crashes of airliners because of the fight between pilot/copilot and the "tie breaker" of instruments indications. Overall I could ramble on and on about this stuff, as well as the whole AHRS theory, but in the end we're all entitled to our own opinions. Like I said, no necessarily agreeing or disagreeing, just putting out a few facts. Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bruce Gray Sent: Wednesday, September 24, 2008 4:50 PM To: rv-list(at)matronics.com Subject: RE: RV-List: IMC - What If??? Analysis To play the devils advocate, You'll be lucky if, when your EFIS fails, the screen goes dark. More than likely, part of it will just freeze, or worse yet - start giving you false information. What do you do when all your electro-wizzies fail? It's happened - several times in big iron aircraft, failure of multiple electrical systems and their backups leaving a totally dark cockpit. One of the reasons that all EFIS certified panels have a vacuum ADI or equivalent. But let's look at a more likely failure mode, the AHRS starts to put out false information. Your Tru-Trak ADI (It's not really) only displays quasi pitch info. It shows a GPS derived VSI as pitch up/down commands. Now, the big question is - are you willing to bet your life that you addled and confused brain is going to be able to sort out the conflicting and non standard pitch information before you go "THUD"? And as your screaming brain is yelling - which system is right? Needle, ball, and airspeed tie breaker? I know I've spent hundreds of hours scanning the basic 6 pack in IMC and am well aware of its failure modes. But when screens go dark or scrambled it's the easiest and fasted for me to revert to and feel comfortable. Bruce www.Glasair.org ________________________________________________________________________________
Date: Sep 24, 2008
Hmmm, I could be wrong but.... The TruTrak website says the roll is instantaneous gyro and the pitch is enhanced VSI. Perhaps we're both right. Bruce <http://www.glasair.org/> www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of SteinAir, Inc. Sent: Wednesday, September 24, 2008 6:22 PM Subject: RE: RV-List: IMC - What If??? Analysis Hi Bruce, You know I agree with you historically on some of your points, but I have to jump in here just a little bit - nothing personal, just want to re-direct a few facts. Your understanding of the TruTrak ADI is not just a little bit off....it's just flat wrong. Who told you it uses GPS information for vertical information? They use GPS to show a track in the little LCD window...it has nothing to do with the flight display. You do of course realize that it has solid state gyros inside of it and shows instantaneous pitch and bank information as well? Naturally you also know that it has a Pitot and Static connection on the back of it to sense pitot/satic info? Of course some of the EFIS mfgrs out there use GPS as an aiding function to offset the accelerometer drift, etc.., but I'm not aware of any other than the little "instrument page" of the Garmin handhelds that do anything of the sort. Anyway, I don't want to get into a debate on what should be used when and where nor if the ADI is for you or not...just want to make sure people don't think it uses GPS to display any flight information. I do agree that there is a BIG question on lower cost EFISes knowing whether they are ill or not. The certified stuff has a ton of software in it for that very purpose, and will paint a big red "X" over any portion of the instrument it thinks doesn't has perfect information. Most of the really low cost EFISes will not alert you to anything being wrong, because the EFIS itself doesn't know it's sick. It's what I try to tell people over and over. There is a MUCH larger difference between EFISes than just plain cost. There is a lot of other unseen functionality that comes with the higher priced units other than their name on the faceplate. Of course every EFIS mfgr will tell you their stuff is the same as the certified Garmin or what is in the Boeings while standing in the booth at OSH (I actually heard a rep from a low cost EFIS mfgr repeatedly tell people their stuff was as good or better than the Garmin certified stuff)....hopefully people realize that's just not the case and couldn't be farther from the truth. Does that mean the low cost EFISes are bad? Heck no! They are a marvel of technology as long as you use them for what they are. FYI...most of the heavy iron is going to solid state peanut backups as well....but they aren't anything like our low cost EFISes (nor the price)! Again, nothing personal and I'm not necessarily disagreeing with premise in general, just some of the details. The whole "tie breaker" discussion gets really interesting really fast in some of these configurations. There are a number of historical crashes of airliners because of the fight between pilot/copilot and the "tie breaker" of instruments indications. Overall I could ramble on and on about this stuff, as well as the whole AHRS theory, but in the end we're all entitled to our own opinions. Like I said, no necessarily agreeing or disagreeing, just putting out a few facts. Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bruce Gray Sent: Wednesday, September 24, 2008 4:50 PM Subject: RE: RV-List: IMC - What If??? Analysis To play the devils advocate, You'll be lucky if, when your EFIS fails, the screen goes dark. More than likely, part of it will just freeze, or worse yet - start giving you false information. What do you do when all your electro-wizzies fail? It's happened - several times in big iron aircraft, failure of multiple electrical systems and their backups leaving a totally dark cockpit. One of the reasons that all EFIS certified panels have a vacuum ADI or equivalent. But let's look at a more likely failure mode, the AHRS starts to put out false information. Your Tru-Trak ADI (It's not really) only displays quasi pitch info. It shows a GPS derived VSI as pitch up/down commands. Now, the big question is - are you willing to bet your life that you addled and confused brain is going to be able to sort out the conflicting and non standard pitch information before you go "THUD"? And as your screaming brain is yelling - which system is right? Needle, ball, and airspeed tie breaker? I know I've spent hundreds of hours scanning the basic 6 pack in IMC and am well aware of its failure modes. But when screens go dark or scrambled it's the easiest and fasted for me to revert to and feel comfortable. Bruce <http://www.glasair.org/> www.Glasair.org ________________________________________________________________________________
Date: Sep 25, 2008
Date: Sep 24, 2008
I wanted one of the bent stick too,-I e-mailed him about a year ago, with no response?? I still want one, Dan --- On Wed, 9/24/08, Carlos Hernandez wrote: From: Carlos Hernandez <carlosh(at)structuralaz.com> Subject: Re: RV-List: RV-8 "Curved Control Stick" Option...? Date: Wednesday, September 24, 2008, 11:32 AM Yeah he's not doing it any more. Here's what he says from his web site www.rvwoody.com /"LAST BATCH EVER: March 1, 2007. Due to customer complaints about the six week lead time, this service is terminated. If you want a stick done, better get it to me by March 1. Sticks received after March 1 will be returned to sender." /Bummer cause I was wanting one when I get there in my build./ / Carlos in AZ Michael W Stewart wrote: > > Matt, > RV Woody > 4606 107th Street > Mukilter, WA 98275 > ATTN Todd Rudberg > > This is the guy that was making them for builders, usually in batches. > Dont know if this is still the case. I have attached the low res > drawing. You can see the dimentions. > Best, > Mike > > /(See attached file: bentstick.jpg)/ > > > Inactive hide details for Matt Dralle ---09/24/2008 12:31:33 PM-----> > > > *Matt Dralle * > Sent by: owner-rv-list-server(at)matronics.com > > 09/24/2008 11:52 AM > Please respond to > rv-list(at)matronics.com > > > > To > > rv-list(at)matronics.com > > cc > > > Subject > > RV-List: RV-8 "Curved Control Stick" Option...? > > > > > Greetings, > > I sat in a friend's RV-8 this weekend and was testing out the various > ergonomic aspects. One thing that struck me was the pilot's control > stick placement. It seemed a bit far away and definitely way too low. > The top of the stick cleared the bottom of the instrument panel by > maybe an inch or less, so it was definitely about as long as it could > be. The seat cushion didn't seem abnormally thick. > > When I ordered my seats from Classic Aero Designs, one of the > questions they asked me was if I had the "Curved Stick Option". I > didn't think about it much at the time but now I'm intrigued. Is this > something that could give me more stick height without impacting the > instrument panel? Does Van's sell it? Part number? Pros and cons? > Pictures? > > Thanks, > > Matt Dralle > RV-8 #82880 N844RV (res.) > > > ======================== ============ > tor?RV-List">http://www.matronics.com/Navigator?RV-List > ======================== ============ > FORUMS - > tp://forums.matronics.com > ======================== ============ > Site - > bsp; -Matt Dralle, List Admin. > bution">http://www.matronics.com/contribution > ======================== ============ > > > ------------------------------------------------------------------------ > > ------------------------------------------------------------------------ > > Checked by AVG. > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Sep 25, 2008
Subject: Re: IMC - What If??? Analysis
As I understand it, this means that the pitch info comes from changes in barometric altitude (i.e. VSI), enhanced with solid state pitch rate "gyro" info. No GPS info is used for pitch or roll display. Kevin Horton Bruce Gray wrote: > Hmmm, I could be wrong but.... The TruTrak website says the roll is > instantaneous gyro and the pitch is enhanced VSI. Perhaps we're both right. > > > > Bruce > > <http://www.glasair.org/> www.Glasair.org > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of SteinAir, Inc. > Sent: Wednesday, September 24, 2008 6:22 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: IMC - What If??? Analysis > > > Hi Bruce, > > You know I agree with you historically on some of your points, but I have to > jump in here just a little bit - nothing personal, just want to re-direct a > few facts. Your understanding of the TruTrak ADI is not just a little bit > off....it's just flat wrong. Who told you it uses GPS information for > vertical information? They use GPS to show a track in the little LCD > window...it has nothing to do with the flight display. You do of course > realize that it has solid state gyros inside of it and shows instantaneous > pitch and bank information as well? Naturally you also know that it has a > Pitot and Static connection on the back of it to sense pitot/satic info? Of > course some of the EFIS mfgrs out there use GPS as an aiding function to > offset the accelerometer drift, etc.., but I'm not aware of any other than > the little "instrument page" of the Garmin handhelds that do anything of the > sort. > > Anyway, I don't want to get into a debate on what should be used when and > where nor if the ADI is for you or not...just want to make sure people don't > think it uses GPS to display any flight information. I do agree that there > is a BIG question on lower cost EFISes knowing whether they are ill or not. > The certified stuff has a ton of software in it for that very purpose, and > will paint a big red "X" over any portion of the instrument it thinks > doesn't has perfect information. Most of the really low cost EFISes will > not alert you to anything being wrong, because the EFIS itself doesn't know > it's sick. It's what I try to tell people over and over. There is a MUCH > larger difference between EFISes than just plain cost. There is a lot of > other unseen functionality that comes with the higher priced units other > than their name on the faceplate. Of course every EFIS mfgr will tell you > their stuff is the same as the certified Garmin or what is in the Boeings > while standing in the booth at OSH (I actually heard a rep from a low cost > EFIS mfgr repeatedly tell people their stuff was as good or better than the > Garmin certified stuff)....hopefully people realize that's just not the case > and couldn't be farther from the truth. Does that mean the low cost EFISes > are bad? Heck no! They are a marvel of technology as long as you use them > for what they are. > > FYI...most of the heavy iron is going to solid state peanut backups as > well....but they aren't anything like our low cost EFISes (nor the price)! > > Again, nothing personal and I'm not necessarily disagreeing with premise in > general, just some of the details. The whole "tie breaker" discussion gets > really interesting really fast in some of these configurations. There are a > number of historical crashes of airliners because of the fight between > pilot/copilot and the "tie breaker" of instruments indications. Overall I > could ramble on and on about this stuff, as well as the whole AHRS theory, > but in the end we're all entitled to our own opinions. Like I said, no > necessarily agreeing or disagreeing, just putting out a few facts. > > Cheers, > Stein > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bruce Gray > Sent: Wednesday, September 24, 2008 4:50 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: IMC - What If??? Analysis > > > To play the devils advocate, > > You'll be lucky if, when your EFIS fails, the screen goes dark. More than > likely, part of it will just freeze, or worse yet - start giving you false > information. > > What do you do when all your electro-wizzies fail? It's happened - several > times in big iron aircraft, failure of multiple electrical systems and their > backups leaving a totally dark cockpit. One of the reasons that all EFIS > certified panels have a vacuum ADI or equivalent. > > But let's look at a more likely failure mode, the AHRS starts to put out > false information. Your Tru-Trak ADI (It's not really) only displays quasi > pitch info. It shows a GPS derived VSI as pitch up/down commands. Now, the > big question is - are you willing to bet your life that you addled and > confused brain is going to be able to sort out the conflicting and non > standard pitch information before you go "THUD"? > And as your screaming brain is yelling - which system is right? Needle, > ball, and airspeed tie breaker? > > I know I've spent hundreds of hours scanning the basic 6 pack in IMC and am > well aware of its failure modes. But when screens go dark or scrambled it's > the easiest and fasted for me to revert to and feel comfortable. > > > > > Bruce > > <http://www.glasair.org/> www.Glasair.org > > > -- Kevin Horton RV-8 (Flight Test Phase) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: Re: RV-8
Date: Sep 25, 2008
I made my curved RV8 front stick. Just layout on paper your desired curved
September 05, 2008 - September 25, 2008
RV-Archive.digest.vol-tr
