RV-Archive.digest.vol-tv
December 11, 2008 - January 13, 2009
                  5 min
                  10 min
                  15 min
                  20 min
                  25 min
                  30 min
            5.. IF CHT => 400=B0F, advise LANDING
            6.. 30 Minutes
              1.. Prompt for
                1.. RPM: ______________
                2.. MAP: ______________
                3.. AIRSPEED: _________
              2.. Remind to LAND
            7.. Record Landing Time: _______________
            8.. IF CRASH:
              1.. Dial 911 & give location
              2.. Save Pilot ' aircraft is secondary
              3.. Gloves, knife, hatchet, Fire Extinguisher
              4.. Canopy latch rotates CLOCKWISE to OPEN
              5.. MASTER OFF (lower left panel)
              6.. Fuel Selector: (center, front of spar)
                1.. OFF (aft left)
              7.. Seat belts: PULL FLAP
              8.. Shoulder Harness: PULL TABS to LOOSEN
              9.. Cowl:
                1.. Oil Door for top cowl hinge wires on firewall
                2.. Phillips screwdriver for hinge wires on cowl halves
              10.. Battery located on pilot side firewall
          2.. Chase
            1.. Monitor 122.85
            2.. Com check: Ground/TestFlight
            3.. Depart first; take station EAST of runway
            4.. Take up =BD mile trail
            5.. Check Fluids/Flapping Parts
            6.. If TestFlight rocks wings:
              1.. Come up on right wing till TestFlight acknowledges
              2.. Fly under to left wing, then over top to right wing
              3.. Signal TestFlight:
                1.. OK: Thumbsup
                2.. Problems: cut Throat to land
            7.. Emergencies:
              1.. Com Failure:
                2.. Point to Ears
              2.. Parts/Fluid/fire:
                2.. Cut Throat to indicate landing
                3.. Remind pilot:
                  1.. Master Off
                  2.. FUEL OFF
                  3.. Canopy Unlatched ' but closed
              3.. Crash:
                1.. Tell Ground location
                2.. Circle till Ground arrives
          3.. TestFlight
            1.. Equipment:
              1.. Fire extinguisher
              2.. Hatchet
              3.. Knife
            2.. Com: 122.85
            3.. Com Check: Ground/Chase
            4.. Ensure EIS configuration set for oil temp
            5.. Retest Brakes on taxi/runup
            6.. Depart after Chase
            7.. TAKEOFF:
              1.. FULL POWER, FULL RICH (lean only to smooth engine)
              2.. 70-75% power
                1.. 3000', 2400/24"
            8.. Verify Airspeed registering
            9.. Boost Pump Off
            10.. Orbit, traffic pattern direction, =BD mile radius of airport
            11.. IF CHT => 400=B0F, LAND
            12.. Tasks
              1.. Straight & Level:
                1.. Both trims in neutral
                2.. Record vsi/roll:
      _____________________________________________________
                3.. Adjust for level
              2.. Tell Ground OilT/P, EGTs, CHTs
              3.. Check w/ Chase that area is clear
              4.. Stall
                1.. Slow to mushy controls/buffet
                2.. Airspeed: _________
                3.. Check: OilT/P, EGTs, CHTs
                4.. Flaps: 20% (two marks)
                5.. Airspeed: _________
                6.. Check: OilT/P, EGTs, CHTs
                7.. Flaps: FULL
                8.. Airspeed: _________
                9.. Check: OilT/P, EGTs, CHTs
              5.. Airspeed Check:
                1.. Setup Airspeed to 120 kts
                2.. Call Chase to right side
                3.. Compare airspeeds with Chase
              6.. Land
                1.. Downwind: 1.5 times clean stall (80-90 kts?)
                2.. Base: 20=B0 flaps
                3.. Stay on mains if possible
            13.. Signals:
              1.. Ears: com failure
              2.. Cut Throat: Land
              3.. Rock Wings: Chase come up to look over TestFlight
Date: Dec 11, 2008
Subject: RV6A N822AR gets airworthiness certificate
Folks, After a five-hour inspection/paperwork session with Bill Meserole (DAR), my aircraft is deemed fit-to-fly the phase one test program (40 hours within a 50nm radius circle, day VFR). Soon I'll have a session with Pierre Smith in GA for some refresher training (I already have my sign-off) - then we'll have a first flight report. Ralph Capen RV6A N822AR 0 hrs ________________________________________________________________________________
Subject: 1st Flight Test Plan?
Date: Dec 11, 2008
I completely agree with another post; this is way more than you need to worry about on your first and even the second flight. Focus on how the plane feels, and try some slow flight before landing. Don=92t venture too far from the airport, keep it short maybe 15 or 20 minutes and then land and go celebrate. The 25 ' 40 hours after this will provide plenty of time to figure out the rest in small chunks. Your complete attention is needed to verify controllability and landing potential on your first flight. Just my .02 cents worth. Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of J Riffel Sent: Wednesday, December 10, 2008 8:38 PM Subject: RV-List: 1st Flight Test Plan? I'd appreciate any constructive input on my plan for my 1st Flight: ____________________ 1. Ground 1. Equipment: 1. Fire extinguisher 2. Hatchet 3. Knife 4. Gloves 5. Phillips screwdriver 2. monitor freq: 122.85 3. Record Launch Time: __________________________________ 4. Prompt/record: Elapsed Oil Press Oil Temp EGT1 EGT2 EGT3 EGT4 CHT1 CHT2 CHT3 CHT4 2 min 5 min 10 min 15 min 20 min 25 min 30 min 5. IF CHT => 400=B0F, advise LANDING 6. 30 Minutes 1. Prompt for 1. RPM: ______________ 2. MAP: ______________ 3. AIRSPEED: _________ 2. Remind to LAND 7. Record Landing Time: _______________ 8. IF CRASH: 1. Dial 911 & give location 2. Save Pilot ' aircraft is secondary 3. Gloves, knife, hatchet, Fire Extinguisher 4. Canopy latch rotates CLOCKWISE to OPEN 5. MASTER OFF (lower left panel) 6. Fuel Selector: (center, front of spar) 1. OFF (aft left) 7. Seat belts: PULL FLAP 8. Shoulder Harness: PULL TABS to LOOSEN 9. Cowl: 1. Oil Door for top cowl hinge wires on firewall 2. Phillips screwdriver for hinge wires on cowl halves 10. Battery located on pilot side firewall 2. Chase 1. Monitor 122.85 2. Com check: Ground/TestFlight 3. Depart first; take station EAST of runway 4. Take up =BD mile trail 5. Check Fluids/Flapping Parts 6. If TestFlight rocks wings: 1. Come up on right wing till TestFlight acknowledges 2. Fly under to left wing, then over top to right wing 3. Signal TestFlight: 1. OK: Thumbsup 2. Problems: cut Throat to land 7. Emergencies: 1. Com Failure: 1. Come up on right wing 2. Point to Ears 2. Parts/Fluid/fire: 1. Come up on right wing 2. Cut Throat to indicate landing 3. Remind pilot: 1. Master Off 2. FUEL OFF 3. Canopy Unlatched ' but closed 3. Crash: 1. Tell Ground location 2. Circle till Ground arrives 3. TestFlight 1. Equipment: 1. Fire extinguisher 2. Hatchet 3. Knife 2. Com: 122.85 3. Com Check: Ground/Chase 4. Ensure EIS configuration set for oil temp 5. Retest Brakes on taxi/runup 6. Depart after Chase 7. TAKEOFF: 1. FULL POWER, FULL RICH (lean only to smooth engine) 2. 70-75% power 1. 3000', 2400/24" 8. Verify Airspeed registering 9. Boost Pump Off 10. Orbit, traffic pattern direction, =BD mile radius of airport 11. IF CHT => 400=B0F, LAND 12. Tasks 1. Straight & Level: 1. Both trims in neutral 2. Record vsi/roll: _____________________________________________________ 3. Adjust for level 2. Tell Ground OilT/P, EGTs, CHTs 3. Check w/ Chase that area is clear 4. Stall 1. Slow to mushy controls/buffet 2. Airspeed: _________ 3. Check: OilT/P, EGTs, CHTs 4. Flaps: 20% (two marks) 5. Airspeed: _________ 6. Check: OilT/P, EGTs, CHTs 7. Flaps: FULL 8. Airspeed: _________ 9. Check: OilT/P, EGTs, CHTs 5. Airspeed Check: 1. Setup Airspeed to 120 kts 2. Call Chase to right side 3. Compare airspeeds with Chase 6. Land 1. Downwind: 1.5 times clean stall (80-90 kts?) 2. Base: 20=B0 flaps 3. Stay on mains if possible 13. Signals: 1. Ears: com failure 2. Cut Throat: Land 3. Rock Wings: Chase come up to look over TestFlight ________________________________________________________________________________
Subject: Re: 1st Flight Test Plan?
Date: Dec 11, 2008
A system I have used as a Flight Advisor that keeps the test pilot attentio n on flying the airplane and not trying to read the flight plan and record data: A person on the ground with handheld radio w/ headset and clip board with t he flight plan/check list.The ground person calls out the items. Test pilot checks the insurments/airplane and responds to the ground member. Ground p erson records the data and flight time. A preflight briefing between test pilot and ground crew helps all this take place. Dale Ensing ----- Original Message ----- From: Ron Lee To: rv-list(at)matronics.com Sent: Wednesday, December 10, 2008 11:33 PM Subject: Re: RV-List: 1st Flight Test Plan? Hopefully someone else will record all that data. Not the test pilot. Ron Lee ----- Original Message ----- From: J Riffel To: rv-list Sent: Wednesday, December 10, 2008 7:37 PM Subject: RV-List: 1st Flight Test Plan? I'd appreciate any constructive input on my plan for my 1st Flight: ____________________ 1.. Ground 1.. Equipment: 1.. Fire extinguisher 2.. Hatchet 3.. Knife 4.. Gloves 5.. Phillips screwdriver 2.. monitor freq: 122.85 3.. Record Launch Time: __________________________________ 4.. Prompt/record: Elapsed Oil Press Oil Temp EGT1 EGT2 EGT3 EGT4 CHT1 CHT2 CHT3 CHT4 2 min 5 min 10 min 15 min 20 min 25 min 30 min 5.. IF CHT => 400=B0F, advise LANDING 6.. 30 Minutes 1.. Prompt for 1.. RPM: ______________ 2.. MAP: ______________ 3.. AIRSPEED: _________ 2.. Remind to LAND 7.. Record Landing Time: _______________ 8.. IF CRASH: 1.. Dial 911 & give location 2.. Save Pilot ' aircraft is secondary 3.. Gloves, knife, hatchet, Fire Extinguisher 4.. Canopy latch rotates CLOCKWISE to OPEN 5.. MASTER OFF (lower left panel) 6.. Fuel Selector: (center, front of spar) 1.. OFF (aft left) 7.. Seat belts: PULL FLAP 8.. Shoulder Harness: PULL TABS to LOOSEN 9.. Cowl: 1.. Oil Door for top cowl hinge wires on firewall 2.. Phillips screwdriver for hinge wires on cowl halves 10.. Battery located on pilot side firewall 2.. Chase 1.. Monitor 122.85 2.. Com check: Ground/TestFlight 3.. Depart first; take station EAST of runway 4.. Take up =BD mile trail 5.. Check Fluids/Flapping Parts 6.. If TestFlight rocks wings: 1.. Come up on right wing till TestFlight acknowledges 2.. Fly under to left wing, then over top to right wing 3.. Signal TestFlight: 1.. OK: Thumbsup 2.. Problems: cut Throat to land 7.. Emergencies: 1.. Com Failure: 1.. Come up on right wing 2.. Point to Ears 2.. Parts/Fluid/fire: 1.. Come up on right wing 2.. Cut Throat to indicate landing 3.. Remind pilot: 1.. Master Off 2.. FUEL OFF 3.. Canopy Unlatched ' but closed 3.. Crash: 1.. Tell Ground location 2.. Circle till Ground arrives 3.. TestFlight 1.. Equipment: 1.. Fire extinguisher 2.. Hatchet 3.. Knife 2.. Com: 122.85 3.. Com Check: Ground/Chase 4.. Ensure EIS configuration set for oil temp 5.. Retest Brakes on taxi/runup 6.. Depart after Chase 7.. TAKEOFF: 1.. FULL POWER, FULL RICH (lean only to smooth engine) 2.. 70-75% power 1.. 3000', 2400/24" 8.. Verify Airspeed registering 9.. Boost Pump Off 10.. Orbit, traffic pattern direction, =BD mile radius of airport 11.. IF CHT => 400=B0F, LAND 12.. Tasks 1.. Straight & Level: 1.. Both trims in neutral 2.. Record vsi/roll: __________________________________________ ___________ 3.. Adjust for level 2.. Tell Ground OilT/P, EGTs, CHTs 3.. Check w/ Chase that area is clear 4.. Stall 1.. Slow to mushy controls/buffet 2.. Airspeed: _________ 3.. Check: OilT/P, EGTs, CHTs 4.. Flaps: 20% (two marks) 5.. Airspeed: _________ 6.. Check: OilT/P, EGTs, CHTs 7.. Flaps: FULL 8.. Airspeed: _________ 9.. Check: OilT/P, EGTs, CHTs 5.. Airspeed Check: 1.. Setup Airspeed to 120 kts 2.. Call Chase to right side 3.. Compare airspeeds with Chase 6.. Land 1.. Downwind: 1.5 times clean stall (80-90 kts?) 2.. Base: 20=B0 flaps 3.. Stay on mains if possible 13.. Signals: 1.. Ears: com failure 2.. Cut Throat: Land 3.. Rock Wings: Chase come up to look over TestFlight href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/ Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 11, 2008
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Very well said Tim... And no big crowd necessary! Darrell --- On Thu, 12/11/08, Tim Bryan wrote: > From: Tim Bryan <n616tb(at)btsapps.com> > Subject: RE: RV-List: 1st Flight Test Plan? > To: rv-list(at)matronics.com > Date: Thursday, December 11, 2008, 7:57 AM > I completely agree with another post; this is way more than > you need to > worry about on your first and even the second flight. > Focus on how the > plane feels, and try some slow flight before landing. > Dont venture too far > from the airport, keep it short maybe 15 or 20 minutes and > then land and go > celebrate. The 25 40 hours after this will provide > plenty of time to > figure out the rest in small chunks. Your complete > attention is needed to > verify controllability and landing potential on your first > flight. > > > > Just my .02 cents worth. > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of J > Riffel > Sent: Wednesday, December 10, 2008 8:38 PM > To: rv-list > Subject: RV-List: 1st Flight Test Plan? > > > > I'd appreciate any constructive input on my plan for my > 1st Flight: > > > > ____________________ > > > > 1. Ground > > 1. Equipment: > > 1. Fire extinguisher > > 2. Hatchet > > 3. Knife > > 4. Gloves > > 5. Phillips screwdriver > > 2. monitor freq: 122.85 > > 3. Record Launch Time: > __________________________________ > > 4. Prompt/record: > > > Elapsed > > Oil Press > > Oil Temp > > EGT1 > > EGT2 > > EGT3 > > EGT4 > > CHT1 > > CHT2 > > CHT3 > > CHT4 > > > 2 min > > > > > 5 min > > > > > 10 min > > > > > 15 min > > > > > 20 min > > > > > 25 min > > > > > 30 min > > > > > 5. IF CHT => 400F, advise LANDING > > 6. 30 Minutes > > 1. Prompt for > > 1. RPM: ______________ > > 2. MAP: ______________ > > 3. AIRSPEED: _________ > > 2. Remind to LAND > > 7. Record Landing Time: _______________ > > 8. IF CRASH: > > 1. Dial 911 & give location > > 2. Save Pilot aircraft is secondary > > 3. Gloves, knife, hatchet, Fire Extinguisher > > 4. Canopy latch rotates CLOCKWISE to OPEN > > 5. MASTER OFF (lower left panel) > > 6. Fuel Selector: (center, front of spar) > > 1. OFF (aft left) > > 7. Seat belts: PULL FLAP > > 8. Shoulder Harness: PULL TABS to LOOSEN > > 9. Cowl: > > 1. Oil Door for top cowl hinge wires on firewall > > 2. Phillips screwdriver for hinge wires on cowl halves > > 10. Battery located on pilot side firewall > > 2. Chase > > 1. Monitor 122.85 > > 2. Com check: Ground/TestFlight > > 3. Depart first; take station EAST of runway > > 4. Take up mile trail > > 5. Check Fluids/Flapping Parts > > 6. If TestFlight rocks wings: > > 1. Come up on right wing till TestFlight acknowledges > > 2. Fly under to left wing, then over top to right wing > > 3. Signal TestFlight: > > 1. OK: Thumbsup > > 2. Problems: cut Throat to land > > 7. Emergencies: > > 1. Com Failure: > > 1. Come up on right wing > > 2. Point to Ears > > 2. Parts/Fluid/fire: > > 1. Come up on right wing > > 2. Cut Throat to indicate landing > > 3. Remind pilot: > > 1. Master Off > > 2. FUEL OFF > > 3. Canopy Unlatched but closed > > 3. Crash: > > 1. Tell Ground location > > 2. Circle till Ground arrives > > 3. TestFlight > > 1. Equipment: > > 1. Fire extinguisher > > 2. Hatchet > > 3. Knife > > 2. Com: 122.85 > > 3. Com Check: Ground/Chase > > 4. Ensure EIS configuration set for oil temp > > 5. Retest Brakes on taxi/runup > > 6. Depart after Chase > > 7. TAKEOFF: > > 1. FULL POWER, FULL RICH (lean only to smooth engine) > > 2. 70-75% power > > 1. 3000', 2400/24" > > 8. Verify Airspeed registering > > 9. Boost Pump Off > > 10. Orbit, traffic pattern direction, mile radius of > airport > > 11. IF CHT => 400F, LAND > > 12. Tasks > > 1. Straight & Level: > > 1. Both trims in neutral > > 2. Record vsi/roll: > _____________________________________________________ > > 3. Adjust for level > > 2. Tell Ground OilT/P, EGTs, CHTs > > 3. Check w/ Chase that area is clear > > 4. Stall > > 1. Slow to mushy controls/buffet > > 2. Airspeed: _________ > > 3. Check: OilT/P, EGTs, CHTs > > 4. Flaps: 20% (two marks) > > 5. Airspeed: _________ > > 6. Check: OilT/P, EGTs, CHTs > > 7. Flaps: FULL > > 8. Airspeed: _________ > > 9. Check: OilT/P, EGTs, CHTs > > 5. Airspeed Check: > > 1. Setup Airspeed to 120 kts > > 2. Call Chase to right side > > 3. Compare airspeeds with Chase > > 6. Land > > 1. Downwind: 1.5 times clean stall (80-90 kts?) > > 2. Base: 20 flaps > > 3. Stay on mains if possible > > 13. Signals: > > 1. Ears: com failure > > 2. Cut Throat: Land > > 3. Rock Wings: Chase come up to look over TestFlight ________________________________________________________________________________
Date: Dec 11, 2008
I did this about two weeks ago and agree with previous comments.- Your to tal focus needs to be on flying the airplane and monitoring engine performa nce to the extent you assure that it continues to make noise.- Plenty of time to record stuff later.- Keep it simple.- Keep it short. Stay focus ed on the airplane.- Have fun. - Craig Gallenbach RV8A N184CG 5 hours --- On Wed, 12/10/08, J Riffel wrote: From: J Riffel <riffeljl(at)gmail.com> Subject: RV-List: 1st Flight Test Plan? Date: Wednesday, December 10, 2008, 8:37 PM I'd appreciate any constructive input on my plan for my 1st Flight: - ____________________ - Ground Equipment: Fire extinguisher Hatchet Knife Gloves Phillips screwdriver monitor freq: 122.85 Record Launch Time: __________________________________ Prompt/record: Elapsed Oil Press Oil Temp EGT1 EGT2 EGT3 EGT4 CHT1 CHT2 CHT3 CHT4 2 min 5 min 10 min 15 min 20 min 25 min 30 min IF CHT => 400=B0F, advise LANDING 30 Minutes Prompt for RPM: ______________ MAP: ______________ AIRSPEED: _________ Remind to LAND Record Landing Time: _______________ IF CRASH: Dial 911 & give location Save Pilot ' aircraft is secondary Gloves, knife, hatchet, Fire Extinguisher Canopy latch rotates CLOCKWISE to OPEN MASTER OFF (lower left panel) Fuel Selector: (center, front of spar) OFF (aft left) Seat belts: PULL FLAP Shoulder Harness: PULL TABS to LOOSEN Cowl: Oil Door for top cowl hinge wires on firewall Phillips screwdriver for hinge wires on cowl halves Battery located on pilot side firewall Chase Monitor 122.85 Com check: Ground/TestFlight Depart first; take station EAST of runway Take up =BD mile trail Check Fluids/Flapping Parts If TestFlight rocks wings: Come up on right wing till TestFlight acknowledges Fly under to left wing, then over top to right wing Signal TestFlight: OK: Thumbsup Problems: cut Throat to land Emergencies: Com Failure: Come up on right wing Point to Ears Parts/Fluid/fire: Come up on right wing Cut Throat to indicate landing Remind pilot: Master Off FUEL OFF Canopy Unlatched ' but closed Crash: Tell Ground location Circle till Ground arrives TestFlight Equipment: Fire extinguisher Hatchet Knife Com: 122.85 Com Check: Ground/Chase Ensure EIS configuration set for oil temp Retest Brakes on taxi/runup Depart after Chase TAKEOFF: FULL POWER, FULL RICH (lean only to smooth engine) 70-75% power 3000', 2400/24" Verify Airspeed registering Boost Pump Off Orbit, traffic pattern direction, =BD mile radius of airport IF CHT => 400=B0F, LAND Tasks Straight & Level: Both trims in neutral Record vsi/roll: _____________________________________________________ Adjust for level Tell Ground OilT/P, EGTs, CHTs Check w/ Chase that area is clear Stall Slow to mushy controls/buffet Airspeed: _________ Check: OilT/P, EGTs, CHTs Flaps: 20% (two marks) Airspeed: _________ Check: OilT/P, EGTs, CHTs Flaps: FULL Airspeed: _________ Check: OilT/P, EGTs, CHTs Airspeed Check: Setup Airspeed to 120 kts Call Chase to right side Compare airspeeds with Chase Land Downwind: 1.5 times clean stall (80-90 kts?) Base: 20=B0 flaps Stay on mains if possible Signals: Ears: com failure Cut Throat: Land Rock Wings: Chase come up to look over TestFlight ________________________________________________________________________________
Date: Dec 11, 2008
You did not say what type of instrumentation you are using to tell you the info you want. I have the EIS from Grand Rapids that has limits (both high and low) set in the unit. If any of these are exceeded, the "big red light" turns on and tells you what is the offending parameter. That way, on my first flight, and the rest of them, I could concentrate on flying the plane. There is enough stress on the pilot for the first flight with out taking your attention off the flying. CHT's are the most important thing to watch. I kept my airspeed on take off in the 110K range. This gave me good cooling as well as good visibility. It also gives you many options if things get sticky. Airspeed is life as the air force jocks will tell you. The biggest problem will be to loose the airspeed on downwind. That means that I need to reduce power as soon as I get to downwind altitude. Tough to do with the slippery RV's. In thirty seconds you will be ready to turn cross wind and then thirty seconds later, to down wind. It all happens fast !!!!!! Jim ____________________________________________________________ Criminal Lawyers - Click here. http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw3dDC4Q87ZKvBGgg4A5PcYwRy849yHbAS7GIRAAEo9AZMtTd/ ________________________________________________________________________________
Date: Dec 11, 2008
On 10-Dec-08, at 21:37 , J Riffel wrote: > I'd appreciate any constructive input on my plan for my 1st Flight: > Three comments: 1. I'd drop the formation airspeed check. Doing a 120 kt airspeed check just adds more low power time, which detracts from the engine break-in, but it doesn't tell you anything that can't wait a few flights. Take your IAS at the full flap stall, and multiply by about 1.5, and do a very quick controllablity evaluation at that speed. If it feels good, use that for the initial approach speed. You can work on dialing that down a bit slower on subsequent flights. 2. I'd restrict the duration to 20 minutes, or less. There are a lot of things that can be happening ahead of the firewall on the first flight, and it is best to keep the duration short, and then do a very detailed inspection before flying again. I know of several RV owners who had the alternator pulley wear through the cowling on the first flight. I thought I had enough clearance between the alternator pulley and the cowling, but apparently the air loads push the lower cowling aft. I did a 20 minute first flight, and my alternator pulley put a very deep gouge in the cowling. I think it may have worn all the way through in 30 minutes. It is a lot easier to fill in a gouge, that it is to repair it if it comes all the way through. I also had an issue with heat stress on the throttle cable, as it was too close to the exhaust. 3. I wouldn't record EGT. It tells you nothing useful. CHTs, oil temperature and oil pressure should be monitored. Recording them is optional. I like the detailed notes on ground items, chase briefing, etc. Good luck, -- Kevin Horton Ottawa, Canada ________________________________________________________________________________
Date: Dec 11, 2008
Subject: virus
HEADS UP!!! Just got an email from one of our clients warning us of a big virus coming. If you get an attachment entitled 'POSTCARD FROM HALLMARK' regardless of who sent it to you, DO NOT OPEN IT. It is a virus which opens a post card image which "burns" the whole hard disc C of your computer. I have checked with our office computer people and this is a threat that is coming so be warned. ________________________________________________________________________________
Date: Dec 11, 2008
Subject: Re: virus
Best tell your clients to verify before sending hoax warnings. This has been going around for a while. http://urbanlegends.about.com/library/bl_postcard_virus.htm RICHARD MILLER wrote: > >HEADS UP!!! Just got an email from one of our clients warning us of a big virus coming. If you get an attachment entitled 'POSTCARD FROM HALLMARK' regardless of who sent it to you, DO NOT OPEN IT. It is a virus which opens a post card image which "burns" the whole hard disc C of your computer. I have checked with our office computer people and this is a threat that is coming so be warned. > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2008
Subject: Re: virus
Darn you Jerry! Not only did you beat me to calling this a hoax, you sited the same source. Symantec's web site tells us that the MYDOOM virus used the E-card from Hallmark subject but that was a year ago. If your virus definitions are up to date then you will be covered. Virus are a real problem and we appreciate your concern. I work for an ISP and respond to these warnings every week. Education is the best defense. If someone sends a warning such as this, check it out and let the sender know if it isn't real. Cheers Mark Jerry Springer wrote: > > Best tell your clients to verify before sending hoax warnings. This > has been going around for a while. > > http://urbanlegends.about.com/library/bl_postcard_virus.htm > > > RICHARD MILLER wrote: > >> >> HEADS UP!!! Just got an email from one of our clients warning us of a >> big virus coming. If you get an attachment entitled 'POSTCARD FROM >> HALLMARK' regardless of who sent it to you, DO NOT OPEN IT. It is a >> virus which opens a post card image which "burns" the whole hard disc >> C of your computer. I have checked with our office computer people >> and this is a threat that is coming so be warned. >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 11, 2008
Subject: santa
-------------------------------------------------------------------------------- The FAA and Homeland security ban Santa Claus from domestic airspace Written by Buck E Filbert In a surprise move today The Federal Aviation Administration and Homeland Security joined forces to unilaterally deny domestic air space clearance to the traditional Christmas Eve sleigh ride by Santa Claus. Santa's ride has been bringing joy and happiness to millions of children for generations. Irate parents worldwide are said to be absolutely distraught. "Who's going to eat the milk and cookies for a start?" asked one parent. Homeland Security has said that any penetration into American air space will be considered an act of aggression as part of their duty in keeping American airspace and borders safe. A spokesman from Homeland Security told us, "We just can't have every jolly, rosy cheeked, white haired fruitcake in the world flying around American air space unsupervised." FAA are scratching their heads about where to begin certifying Santa's sleigh as safe for flight. There are no standards regulating the stability and performance of reindeer, also the FAA simply don't know how to inspect a machine which, in their minds, "totally defies the laws of physics". The FAA will consider granting clearance if all FAA regulations are met. Here are a few: * As a powered aircraft, Santa's sleigh requires a proper licensed propulsion system (Reindeer fed on magic dust are not mentioned in the regs and can't be used). * A single red light at the lead of the pack of reindeer does not constitute a set of running lights * The Sleigh must have a valid maintenance certificate and must meet aerodynamic requirements and be tested in a wind-tunnel. * Detailed flight plans must be plotted and submitted to the FAA at least six months in advance Santa Claus is said to be very upset by the reaction from these US agencies and feels the actions are a direct violation of the Children's basic human rights. Homeland Security laid down the following ultimatum to Santa Claus, "If we see any flying sleighs in the skies over America you can bet you bottom dollar there'll be a F-16 with sidewinders blasting it outta the sky." ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)fmwildblue.com>
Date: Dec 12, 2008
A well thought out plan guys! I hope to have my RV-9A flying next year. When I flew my Kitfox for the first time I had the classic case of tunnel vision even with that slow flying plane. On the RV I think I'll have some sort of recorder plugged into the intercom to take notes and readings... Joe Connell RV-9A N95JJ ________________________________________________________________________________
Date: Dec 13, 2008
Subject: Which is a good vacuum pump?
I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA **************Make your life easier with all your friends, email, and favorite sites in one place. Try it now. ________________________________________________________________________________
Date: Dec 13, 2008
Subject: Re: Which is a good vacuum pump?
If you really want to keep your vacuum gyros and not upgrade to electric, then I think that the best bet today is the Sigma-Tek piston pump. N1GV (RV-6A, Flying 908hrs, O-360-A1A, C/S, Silicon Valley) In a message dated 12/12/2008 9:20:51 P.M. Pacific Standard Time, Knicholas2(at)aol.com writes: I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? **************Make your life easier with all your friends, email, and favorite sites in one place. Try it now. ________________________________________________________________________________
Date: Dec 13, 2008
What most forget is that when a vacuum pump lets go, it will blow dirt and debris upstream of the pump, fowling the hose and regulator. It's important to flush all the hoses and replace all the filter elements after a pump failure. Each vacuum instrument usually has a filter behind its inlet that should be cleaned also. Failure to clean the system will result in the new pumps first breath of air being full of dirt and soot, not good for the long life of the new pump. If you want a vacuum pump that will last to TBO of your engine, take a look at the wet vacuum pump. Bruce www.Glasair.org <http://www.glasair.org/> -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Saturday, December 13, 2008 12:18 AM Subject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA _____ Make your life easier with all your friends, email, and favorite sites in one place. Try it now. ________________________________________________________________________________
Date: Dec 13, 2008
Agree. The Sigma-Tek I have has been going strong for the last 1=2C200 hour s. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C170+ Flying Hours So. CA=2C USA From: Vanremog(at)aol.com Date: Sat=2C 13 Dec 2008 00:36:29 -0500 Subject: Re: RV-List: Which is a good vacuum pump? If you really want to keep your vacuum gyros and not upgrade to electric=2C then I think that the best bet today is the Sigma-Tek piston pump. N1GV (RV-6A=2C Flying 908hrs=2C O-360-A1A=2C C/S=2C Silicon Valley) In a message dated 12/12/2008 9:20:51 P.M. Pacific Standard Time=2C Knicholas2(at)aol.com writes: I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Make your life easier with all your friends=2C n=new-dp&icid=aolcom40va nity&ncid=emlcntaolcom00000010">Try it now. _________________________________________________________________ Send e-mail anywhere. No map=2C no compass. http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anyw here_122008 ________________________________________________________________________________
Date: Dec 13, 2008
Excellent reminder. Also, if that Rapco only had 300 hours on it, I hope you kept the warranty card, as if I recall correctly they are warranted for 1000. Also, if you are getting any oil around the pump it can cause drag that will break the shear coupling. Of the standard design, Tempest and Rapco are the best made. There are fit issues with the oil separator necessary for wet pumps, and fit issues with the Sigmatek piston pump. If you have the space to install them correctly, I'm sure they are fine, but many aircraft don't have the room. Bruce Gray wrote: > What most forget is that when a vacuum pump lets go, it will blow dirt > and debris upstream of the pump, fowling the hose and regulator. It's > important to flush all the hoses and replace all the filter elements > after a pump failure. Each vacuum instrument usually has a filter > behind its inlet that should be cleaned also. Failure to clean the > system will result in the new pumps first breath of air being full of > dirt and soot, not good for the long life of the new pump. > > If you want a vacuum pump that will last to TBO of your engine, take a > look at the wet vacuum pump. > > > > Bruce > > www.Glasair.org <http://www.glasair.org/> > > > > -----Original Message----- > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of > *Knicholas2(at)aol.com > *Sent:* Saturday, December 13, 2008 12:18 AM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Which is a good vacuum pump? > > I am about to replace the second Rapco dry vacuum pump in 300 > hours flight time. Is there another brand that people have had > better luck with? Tempest? AAA? Sigma-Tek? > > Thanks! > > Kim Nicholas > RV9A > Auburn, WA > > * * > > *===================================================== > * ________________________________________________________________________________
Date: Dec 13, 2008
What is a vacuum pump? :-))) ____________________________________________________________ Visa, MasterCard, AMEX & Discover. Compare Offers & Apply Online. Click here! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw2Oq356sqR3OxPB2KH3LpHhY23qjTKIhfOV9hY1DjOJLUHof/ ________________________________________________________________________________
Date: Dec 13, 2008
Dump the pump. Use solid-state gyros and a backup alternator! Ralph Finch Davis, CA _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Friday, December 12, 2008 9:18 PM Subject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA ________________________________________________________________________________
Date: Dec 13, 2008
Subject: Flight Test Plan - Thanks.
My thanks to all those who reviewed my flight test plan. While most of the suggestions were already incorporated in my plan, there were a couple good ideas (like reminding me to keep the climb-out very shallow for cooling). My plan of making my ground crew "manage" the flight worked Very Well for me. He was responsible for prompting me and recording all the engine data, reminding me when to land (when my 30 minutes expired - or if my CHTs got above 425) and pulling/cutting me out of the plane in an emergency. Because he did all the logging, all I had to do was fly. My mission was to concentrate on flying: basic handling and try 2 stalls (clean and 20% flaps). The Chase crews jobs was simply to keep me close/far enough from the airport, to look me over (no fluids or flapping parts), do a speed check with me, and to mark the crash site for Ground/Emergency if I went down. Everyone understood chatter was to be kept to a minimum. The RV-7A flew exactly as advertised and how I expected it to. It's Very Quick and it's light on the controls. It is pretty pitch sensitive. The landing was easy - actually a "greaser". The only unexpected development was the noise. With no upholstery/carpet and only bare metal at this stage, it's LOUD in there blasting around the pattern at 75% power. I guess I should've expected that sitting in a metal can next to a no-muffler exhaust. Even my ANR headsets didn't help enough. I may stick some carpet in there before I fly it again to see how much it helps. ________________________________________________________________________________
Subject: Re: Flight Test Plan - Thanks.
Date: Dec 13, 2008
Did you have time in an RV before you flew this? Ron Lee The RV-7A flew exactly as advertised and how I expected it to. It's Very Quick and it's light on the controls. It is pretty pitch sensitive. ________________________________________________________________________________
Date: Dec 13, 2008
Lets see here...spend multiple thousands of dollars on solid state stuff and more thousands on EFIS to replace a $200 pump and $600 gyro. Then spend another grand for separate alternator, battery and essential bus to have totally separate systems as required for IFR. Always easy to spend other's money. ;-) Ralph Finch wrote: > Dump the pump. Use solid-state gyros and a backup alternator! > > Ralph Finch > Davis, CA > > ------------------------------------------------------------------------ > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of > *Knicholas2(at)aol.com > *Sent:* Friday, December 12, 2008 9:18 PM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Which is a good vacuum pump? > > I am about to replace the second Rapco dry vacuum pump in 300 > hours flight time. Is there another brand that people have had > better luck with? Tempest? AAA? Sigma-Tek? > > Thanks! > > Kim Nicholas > RV9A > Auburn, WA > > > * > > * ________________________________________________________________________________
Date: Dec 13, 2008
Let's see...fly around with unreliable vacuum pumps with a history of repeated failures...or use modern equipment to make flying easier and safer. No brainer to me! Always easy to spend my money on the better choice :-) :-) RF _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, December 13, 2008 4:45 PM Subject: Re: RV-List: Which is a good vacuum pump? Lets see here...spend multiple thousands of dollars on solid state stuff and more thousands on EFIS to replace a $200 pump and $600 gyro. Then spend another grand for separate alternator, battery and essential bus to have totally separate systems as required for IFR. Always easy to spend other's money. ;-) Ralph Finch wrote: Dump the pump. Use solid-state gyros and a backup alternator! Ralph Finch Davis, CA _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Friday, December 12, 2008 9:18 PM Subject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA ________________________________________________________________________________
Date: Dec 13, 2008
A little snippy there Finch. Actually I've been flying for forty years and have had only one vac pump failure and that was in VFR conditions which is what I'm rated for. Nothing unsafe there. Believe it or not, there's actually some of us out here who don't have unlimited funds, as apparently you do, who are grateful to be able to just build and fly a machine with older technology. But if I made a habit of bungling into IFR I'd probably make some changes in my system, but I don't, so I agree with Kelly; why spend a bunch of money on a system I don't need? Frankly, I'd rather spend my limited flying funds on avgas rather than an expensive system that I don't need...or want. Chuck RV9A 250 hours (sold) RV10 two months to completion From: Ralph Finch Sent: Saturday, December 13, 2008 6:53 PM Subject: RE: RV-List: Which is a good vacuum pump? Let's see...fly around with unreliable vacuum pumps with a history of repeated failures...or use modern equipment to make flying easier and safer. No brainer to me! Always easy to spend my money on the better choice :-) :-) RF ------------------------------------------------------------------------- ----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, December 13, 2008 4:45 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Which is a good vacuum pump? Lets see here...spend multiple thousands of dollars on solid state stuff and more thousands on EFIS to replace a $200 pump and $600 gyro. Then spend another grand for separate alternator, battery and essential bus to have totally separate systems as required for IFR. Always easy to spend other's money. ;-) Ralph Finch wrote: Dump the pump. Use solid-state gyros and a backup alternator! Ralph Finch Davis, CA ------------------------------------------------------------------------- - From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Friday, December 12, 2008 9:18 PM To: rv-list(at)matronics.com Subject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA ________________________________________________________________________________
Date: Dec 13, 2008
I flew IFR for 20 years with two vacuum gyros, powered by venturis. They make a vacuum pump look extremely reliable. These days it is easy to have a setup with only one vacuum gyro and two electric for not much more money. Losing only one gyro in IMC shouldn't cause a competent pilot to even break a sweat. Certainly less of an issue than losing a glass panel in IMC. Chuck Weyant wrote: > A little snippy there Finch. Actually I've been flying for forty > years and have had only one vac pump failure and that was in VFR > conditions which is what I'm rated for. Nothing unsafe there. > Believe it or not, there's actually some of us out here who don't have > unlimited funds, as apparently you do, who are grateful to be able to > just build and fly a machine with older technology. But if I made a > habit of bungling into IFR I'd probably make some changes in my > system, but I don't, so I agree with Kelly; why spend a bunch of money > on a system I don't need? Frankly, I'd rather spend my limited flying > funds on avgas rather than an expensive system that I don't need...or > want. > > Chuck > RV9A 250 hours (sold) > RV10 two months to completion > > > F*rom:* Ralph Finch > *Sent:* Saturday, December 13, 2008 6:53 PM > *To:* rv-list(at)matronics.com > *Subject:* RE: RV-List: Which is a good vacuum pump? > > Let's see...fly around with unreliable vacuum pumps with a history of > repeated failures...or use modern equipment to make flying easier and > safer. No brainer to me! Always easy to spend my money on the better > choice :-) :-) > > RF > > ------------------------------------------------------------------------ > *From:* owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Kelly > McMullen > *Sent:* Saturday, December 13, 2008 4:45 PM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: Which is a good vacuum pump? > > Lets see here...spend multiple thousands of dollars on solid state > stuff and more thousands on EFIS to replace a $200 pump and $600 > gyro. Then spend another grand for separate alternator, battery > and essential bus to have totally separate systems as required for > IFR. Always easy to spend other's money. ;-) > > Ralph Finch wrote: >> Dump the pump. Use solid-state gyros and a backup alternator! >> >> Ralph Finch >> Davis, CA >> >> ------------------------------------------------------------------------ >> *From:* owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of >> *Knicholas2(at)aol.com >> *Sent:* Friday, December 12, 2008 9:18 PM >> *To:* rv-list(at)matronics.com >> *Subject:* RV-List: Which is a good vacuum pump? >> >> I am about to replace the second Rapco dry vacuum pump in 300 >> hours flight time. Is there another brand that people have >> had better luck with? Tempest? AAA? Sigma-Tek? >> >> Thanks! >> >> Kim Nicholas >> RV9A >> Auburn, WA >> >> > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > * > * > > * ________________________________________________________________________________
Date: Dec 13, 2008
Subject: Pro seal paint
Hi I want to use Van's tank sealant to paint a rusted steel tank removed from a welder.- Pinholes were discovered after it was sandblasted.- What is the best thinner to thin the sealant to a paintable consistency.- I curre ntly have lacquer thinner and toluene. - Sherman Butler RV-7a Wings N497GS reserved Carlsbad, NM =0A=0A=0A ________________________________________________________________________________
From: Michael Karatsonyi <mkaratsonyi(at)hotmail.com>
Date: Dec 13, 2008
i have just started my empenage and wanted to know what everyone is using f or primer? From: chuck(at)chuckdirect.comTo: rv-list(at)matronics.comSubject: Re: RV-List: W hich is a good vacuum pump?Date: Sat=2C 13 Dec 2008 19:50:01 -0800 A little snippy there Finch. Actually I've been flying for forty years and have had only one vac pump failure and that was in VFR conditions which is what I'm rated for. Nothing unsafe there. Believe it or not=2C there's a ctually some of us out here who don't have unlimited funds=2C as apparently you do=2C who are grateful to be able to just build and fly a machine with older technology. But if I made a habit of bungling into IFR I'd probabl y make some changes in my system=2C but I don't=2C so I agree with Kelly=3B why spend a bunch of money on a system I don't need? Frankly=2C I'd rathe r spend my limited flying funds on avgas rather than an expensive system th at I don't need...or want. Chuck RV9A 250 hours (sold) RV10 two months to completion From: Ralph Finch Sent: Saturday=2C December 13=2C 2008 6:53 PM Subject: RE: RV-List: Which is a good vacuum pump? Let's see...fly around with unreliable vacuum pumps with a history of repea ted failures...or use modern equipment to make flying easier and safer. No brainer to me! Always easy to spend my money on the better choice :-) :-) RF From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Kelly McMullenSent: Saturday=2C December 13=2C 2008 4:45 PMTo: rv-list(at)matronics.comSubject: Re: RV-List: Which is a good vacuu m pump? Lets see here...spend multiple thousands of dollars on solid state stuff an d more thousands on EFIS to replace a $200 pump and $600 gyro. Then spend a nother grand for separate alternator=2C battery and essential bus to have t otally separate systems as required for IFR. Always easy to spend other's money. =3B-) Ralph Finch wrote: Dump the pump. Use solid-state gyros and a backup alternator! Ralph Finch Davis=2C CA From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Knicholas2(at)aol.comSent: Friday=2C December 12=2C 200 8 9:18 PMTo: rv-list(at)matronics.comSubject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tem pest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn=2C WA href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/ Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________________________ Suspicious message? There=92s an alert for that. http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broa d2_122008 ________________________________________________________________________________
Subject: Re: Pro seal paint
Date: Dec 14, 2008
MEK works great to thin proseal. It's nasty stuff though so use proper precautions. Jeff Point RV-6/ RV-8/ RLU-1 Milwaukee ________________________________________________________________________________
Date: Dec 14, 2008
Sherman Butler wrote: > Hi > I want to use Van's tank sealant to paint a rusted steel tank removed > from a welder. Pinholes were discovered after it was sandblasted. > What is the best thinner to thin the sealant to a paintable > consistency. I currently have lacquer thinner and toluene. > I found the data sheet online which said it contained toluene. I figure that would work. Linn > > > > > Sherman Butler > RV-7a Wings > N497GS reserved > Carlsbad, NM > > > * > > * ________________________________________________________________________________
Date: Dec 14, 2008
Subject: Instrument Panel - Powercoat Thickness?
Dear Listers, I laid out the RV-8 panel in a CAD program and had experimentalair.com cut a clear Lexan mockup for fitting. I highly recommend using a Lexan mockup first as its a lot cheaper and it really helps to be able to see through the panel to locate brackets, etc. Also, Nick Burns over at ExperimpntalAir has be *super* to work with on this project. I've been emailing him DXF versions of the panel and he made a number of suggestions that I incorporated into the CAD drawing. I sent him the final CAD version Wednesday and he cut the Lexan panel on a FloJet and I received it Friday. It's a work of art! So here's my question. On the hole cutouts, I used a micrometer to measure each instrument, then used these exact measurements in the CAD drawing. I added .005" to both X and Y to allow for easier sliding in and out of the instrument which has turned out to be exactly the right amount. BUT, there's no powercoating on the panel yet. I'm planning on a simi-flat black coating. What is the thickness of the powercoating? How much should I increase the cutout size to account for the coating and still have the nice, tight, fit that I have now? Here's a link to my Builder's Log for anyone that is interested in checking out more on the project: http://www.mykitlog.com/users/category.php?user=dralle&project=619&category=0 Thanks for the feedback, Matt Dralle RV-8 #82880 N998RV (res) ________________________________________________________________________________
Date: Dec 14, 2008
"to have totally separate systems as required for IFR" You do not need separate systems for IFR. Furthermore, a dynon is about the same cost as an attitude indicator, DG, turn coordinator, vacuum pump, regulator, filter, hoses, etc. Yes, vacuum works, and is reasonably reliable...but it's time to move on. I grew up flying steam, and have no problem with a six pack of instruments. But, for building a new aircraft, it really makes no sense going vacuum considering the prices for an experimental EFIS. Honestly, I think vacuum is MORE complex and in the end MORE expensive for overhauls. (Mine are already in need of overhaul due to very mild aerobatics) Paul Besing ________________________________ From: Kelly McMullen <kellym(at)aviating.com> Sent: Saturday, December 13, 2008 5:44:58 PM Subject: Re: RV-List: Which is a good vacuum pump? Lets see here...spend multiple thousands of dollars on solid state stuff and more thousands on EFIS to replace a $200 pump and $600 gyro. Then spend another grand for separate alternator, battery and essential bus to have totally separate systems as required for IFR. Always easy to spend other's money.;-) Ralph Finch wrote: Dump the pump. Use solid-state gyros and a backup alternator! Ralph Finch Davis, CA ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Friday, December 12, 2008 9:18 PM Subject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA href="http://www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 14, 2008
Sherman, The manufacturer recommends thinning with Toluene. Lacquer thinner is 95% Toluene. I had the lacquer thinner on hand, so I always used that. I've built 3 sets of tanks (RV8A/RV6A/RV9A) and none had leaks. Charlie Kuss --- On Sun, 12/14/08, Sherman Butler wrote: > From: Sherman Butler <lsbrv7a(at)yahoo.com> > Subject: RV-List: Pro seal paint > To: rv-list(at)matronics.com > Date: Sunday, December 14, 2008, 12:01 AM > Hi > I want to use Van's tank sealant to paint a rusted > steel tank removed from a welder. Pinholes were discovered > after it was sandblasted. What is the best thinner to thin > the sealant to a paintable consistency. I currently have > lacquer thinner and toluene. > > > Sherman Butler > RV-7a Wings > N497GS reserved > Carlsbad, NM ________________________________________________________________________________
Subject: Re: RV/Rocket Steering Link
Date: Nov 13, 2008
Gabe, I have just installed my third Steering Lind in over 1500 hours on my RV8. 90% of my take offs and landings are on grass fields, so I think that 500 hours apiece on grass is pretty good service life. I find that it is much more responsive than the chain and spring arrangement that is standard Vans equipment, also, it is much quieter and than the chain arrangement that rattles. Good luck. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: ferrerg(at)comcast.net To: rv-list(at)matronics.com Sent: Monday, November 10, 2008 11:20 AM Subject: RV-List: RV/Rocket Steering Link I am considering replacing the Van's tail wheel steering chains in my RV6 with an "RV/Rocket Steering Link". Please, I would appreciate any advice from the listers. I'm specially concerned about landing performance under strong cross winds and maintenance issues. Thank you -- Gabe A Ferrer RV6 N2GX South Florida's Treasure Coast email: ferrerg(at)comcast.net cell: 561 758 8894 ________________________________________________________________________________
Date: Dec 14, 2008
Yes, you can choose to operate without independent systems in an experimental aircraft. It is your hide and your unsuspecting passengers. It is illegal in certificated aircraft, for very good reasons. See Part 23.1309. Most builders aspire to build aircraft safer than certified spam cans. A Dynon is not truly independent, as it depends on the electrical buss. It's backup battery may or may not be satisfactory. Electrical failures occur at least as often as vacuum failures. If an EFIS fails and you don't have some steam gauges, you have no backup, so you are going to need at least an attitude gyro and airspeed and altimeter anyway. So the cost comparison is really vacuum pump and accessories and attitude gyro, vs a second, totally independent separately powered EFIS. Or you can go the least expensive way and get what you list below, no EFIS and buy one or two of the gyros as electric and remaining vacuum. Less than $1 per flight hour to budget vacuum pump replacement every 500 hours. You pays your money and makes your choices. Just don't represent EFIS from anyone as same cost. It isn't. Paul Besing wrote: > "to have totally separate systems as required for IFR" > > You do not need separate systems for IFR. > > Furthermore, a dynon is about the same cost as an attitude indicator, > DG, turn coordinator, vacuum pump, regulator, filter, hoses, etc. > > Yes, vacuum works, and is reasonably reliable...but it's time to move > on. I grew up flying steam, and have no problem with a six pack of > instruments. But, for building a new aircraft, it really makes no > sense going vacuum considering the prices for an experimental EFIS. > Honestly, I think vacuum is MORE complex and in the end MORE expensive > for overhauls. (Mine are already in need of overhaul due to very mild > aerobatics) > > Paul Besing > > > ------------------------------------------------------------------------ > *From:* Kelly McMullen > *To:* rv-list(at)matronics.com > *Sent:* Saturday, December 13, 2008 5:44:58 PM > *Subject:* Re: RV-List: Which is a good vacuum pump? > > Lets see here...spend multiple thousands of dollars on solid state > stuff and more thousands on EFIS to replace a $200 pump and $600 gyro. > Then spend another grand for separate alternator, battery and > essential bus to have totally separate systems as required for IFR. > Always easy to spend other's money. ;-) > > Ralph Finch wrote: >> Dump the pump. Use solid-state gyros and a backup alternator! >> >> Ralph Finch >> Davis, CA >> >> ------------------------------------------------------------------------ >> *From:* owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of >> *Knicholas2(at)aol.com >> *Sent:* Friday, December 12, 2008 9:18 PM >> *To:* rv-list(at)matronics.com >> *Subject:* RV-List: Which is a good vacuum pump? >> >> I am about to replace the second Rapco dry vacuum pump in 300 >> hours flight time. Is there another brand that people have had >> better luck with? Tempest? AAA? Sigma-Tek? >> >> Thanks! >> >> Kim Nicholas >> RV9A >> Auburn, WA >> >> >> * >> >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List >> href="http://forums.matronics.com">http://forums.matronics.com >> * > * > > * > > * > > * ________________________________________________________________________________
Date: Dec 14, 2008
Subject: hybrid autopilot
Hey Folks: I just installed a pitch axis only Dynon autopilot to compliment my Trutrak roll axis only pictoral pilot. When I was building trutrak was the only game in town and I prewired for a trutrak pitch servo which I did to the point where the connectors with proper pinouts were installed and tucked away for when I wanted to spend 1500-2000 to be lazy and let a machine hold altitude. The pictoral pilo tdisplays a turn and bank completely independent from the EFIS and is part of my redundancy scheme. In 330 hrs I became very used to flying on roll axis autopilot with my hand on the manual trip knob to hold altitude and as such I never saw fit to blow the cash. Flash forward and dynon starts making noise about having an autopilot. After a few conversations with them I find out that I'll have to blow more than 1500 on 2 servos since theirs is different than the TT and I'll also have to rethink my reduncancy scheme... Then I find out that you can just install a pitch servo for only about $800. Adding fuel to the fire AIG offers me a 10% discount for a "technically advanced aircraft" which with my existing other equipment(moving map, IFR cert GPS, fuel totalizer, terrain...) I would qualify for if I had a 2 axis autopilot... so in the typical aviation fashion I saved $200 by spending $800. The install was pretty easy, I was able to bridge both the control wheel disconnects into the one existing switch with no adverse effects. One long button press engages roll and pitch, slighty shorter and you get roll only, short disengages both. Since I was leveraging off my trutrak pre wire the wire I used to the servo(DSAB included) was not twisted pair as they reccomend but it still works fine. I took a short flight this afternoon and it seems to work fine but I'll need to do some cross country to really get a feel for it. I've see some posts on Vans Airforce complaing of an install that oscillates in pitch with growing excursion magnitudes. If this is the case they should be able to fix it with a firmware upgrade. Bill Judge N84WJ 330 Hrs. rv-8.blogspot.com ________________________________________________________________________________
Date: Dec 14, 2008
In 15 years of flying, over 2000 hours, and flying 20,000 hour freight airplanes with things breaking all the time, I've never once had a total electrical failure..and trust me..the garbage I was flying, if any rats nest like was in the airplanes I flew will work, a properly crafted experimental electrical system will not fail. Build it right, and it will last indefinitely. Alternator failure, ok, but the chances in IMC, and having to stay IMC longer than an hour for the battery backup, then you shouldn't be flying anyway. RV's are fine for flying light IMC, but if there is no VFR within an hour or two in an RV, there is some SERIOUS weather in your area. Declare emergency, get the nearest approach, and done. Again, the chances are so slim, I would have no problem in trusting a dynon with a backup battery. Second, have a trio autopilot, coupled to a panel mounted handheld, and you will have all the IFR capability you need in an emergency. I've tested this. Flew an ILS approach, on autopilot, with no attitude indicator, in IMC. Just kicked off the autopilot when I was out of the clouds. My small panel RV-4 has plenty of reduntantcy. Vacuum gyros go, I still have autopilot coupled to Garmin 396, and an electric turn coordinator. Build the electrical system right, and you have no issues if your EFIS fails. But again, how many Dynon or similar EFIS just quits working? Short of an electrical problem that fries the thing, I really doubt one will just quick working on it's own without poor wiring being the culprit. If I were to keep my airplane for a long time (it's for sale now), I would put in a dynon, and fly IFR all day without any concerns. YMMV. Paul Besing ________________________________ From: Kelly McMullen <kellym(at)aviating.com> Sent: Sunday, December 14, 2008 5:31:30 PM Subject: Re: RV-List: Which is a good vacuum pump? Yes, you can choose to operate without independent systems in an experimental aircraft. It is your hide and your unsuspecting passengers. It is illegal in certificated aircraft, for very good reasons. See Part 23.1309. Most builders aspire to build aircraft safer than certified spam cans. A Dynon is not truly independent, as it depends on the electrical buss. It's backup battery may or may not be satisfactory. Electrical failures occur at least as often as vacuum failures. If an EFIS fails and you don't have some steam gauges, you have no backup, so you are going to need at least an attitude gyro and airspeed and altimeter anyway. So the cost comparison is really vacuum pump and accessories and attitude gyro, vs a second, totally independent separately powered EFIS. Or you can go the least expensive way and get what you list below, no EFIS and buy one or two of the gyros as electric and remaining vacuum. Less than $1 per flight hour to budget vacuum pump replacement every 500 hours. You pays your money and makes your choices. Just don't represent EFIS from anyone as same cost. It isn't. Paul Besing wrote: "to have totally separate systems as required for IFR" You do not need separate systems for IFR. Furthermore, a dynon is about the same cost as an attitude indicator, DG, turn coordinator, vacuum pump, regulator, filter, hoses, etc. Yes, vacuum works, and is reasonably reliable...but it's time to move on. I grew up flying steam, and have no problem with a six pack of instruments. But, for building a new aircraft, it really makes no sense going vacuum considering the prices for an experimental EFIS. Honestly, I think vacuum is MORE complex and in the end MORE expensive for overhauls. (Mine are already in need of overhaul due to very mild aerobatics) Paul Besing ________________________________ From: Kelly McMullen <kellym(at)aviating.com> Sent: Saturday, December 13, 2008 5:44:58 PM Subject: Re: RV-List: Which is a good vacuum pump? Lets see here...spend multiple thousands of dollars on solid state stuff and more thousands on EFIS to replace a $200 pump and $600 gyro. Then spend another grand for separate alternator, battery and essential bus to have totally separate systems as required for IFR. Always easy to spend other's money.;-) Ralph Finch wrote: Dump the pump. Use solid-state gyros and a backup alternator! Ralph Finch Davis, CA ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Friday, December 12, 2008 9:18 PM Subject: RV-List: Which is a good vacuum pump? I am about to replace the second Rapco dry vacuum pump in 300 hours flight time. Is there another brand that people have had better luck with? Tempest? AAA? Sigma-Tek? Thanks! Kim Nicholas RV9A Auburn, WA href="http://www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 14, 2008
It doesn't take a total failure. All you need is one little component to let out some electrical smoke in the cockpit while you are on the gauges and you will be faced with no electrics without risk of additional fire. Argue all you want, or just make your choice. Just don't lead others blindly down the same risky path. I've seen too many electrical failures in 30+ years of flying and wrenching on planes to totally rely on electrics. A number of Beechcraft are facing an AD right now to replace most of their circuit breakers that on rare occasion leak smoke. So there goes your "will not fail" argument. KM A&P/IA Paul Besing wrote: > In 15 years of flying, over 2000 hours, and flying 20,000 hour freight > airplanes with things breaking all the time, I've never once had a > total electrical failure..and trust me..the garbage I was flying, if > any rats nest like was in the airplanes I flew will work, a properly > crafted experimental electrical system will not fail. * > * > *====== > * ________________________________________________________________________________
Date: Dec 15, 2008
All of which shows you have no appreciation of what happens when you get electric smoke in the cockpit. You don't just loose one item, unless you have a death wish. You kill the master. Period. An MD-11 failed to do that, the crew couldn't get it on to an airfield quickly enough, and the aircraft was lost with all persons on board into the Atlantic. You can gamble with isolating the problem, at your own peril. You don't have to justify your desired system to anyone but yourself. A little common sense will tell you to have at least two completely independent electric systems if you choose to operate IFR. No one is going to make you do it. Even with dual electrics, you don't solve the electrical fire scenario. Yes they are relatively rare. Is your life worth that gamble? Just food for thought. linn Walters wrote: > > Sorry folks, but I'm starting to enjoy this! >> It doesn't take a total failure. All you need is one little >> component to let out some electrical smoke in the cockpit while you >> are on the gauges and you will be faced with no electrics without >> risk of additional fire. > Actually, once the magic smoke gets loose, the only thing you lose is > that little box. >> Argue all you want, or just make your choice. Just don't lead others >> blindly down the same risky path. I've seen too many electrical >> failures in 30+ years of flying and wrenching on planes to totally >> rely on electrics. > You may be a pretty good wrench, but I'm getting the feeling you don't > know squat about "electrics". ________________________________________________________________________________
Date: Dec 15, 2008
Subject: Sucking Air or Pushing 'Trons
This is one of those subjects where personal preferences determine the outc ome. I spent many hours researching the instrumentation options for my -8A. The real issue was not lack of options, but too many available choices. In order to get a logical handle on the subject, I went through a formal deci sion process that relied both on data and gut feel. In the end, I am comfor table with my choices - they may, in many folks minds, not be optimum, but they were my conscious choices. 1. No vacuum pump. Not so much a fear of reliability as much as a des ire to exploit new technology. 2. Redundant electrical sources. Main alternator, SD-8, and battery b ackup(s). 3. IFR capability - including ILS. 4. Redundant attitude displays. 5. Back up altimeter, VSI and airspeed. 6. GPS and VOR nav capability. 7. Backup comms. Ended up with AFS 3500, SL30, ICOM backup, panel-mounted 496, PMA7000B, Tru Trac ADI II and Vans AS, VSI and Alt. Works for me. Paul Valovich N192NM - Canopy and Cowling Will fly Saturday - just don't know which Saturday that will be. ________________________________________________________________________________
Subject: RE: RV/Rocket Steering link
Date: Dec 15, 2008
You can get the steering link from my web store (in the U.S.) or from Wayne Hadath (in Canada). Shipping is a bit easier if you get it in your country, but not a big deal. Wayne can be reached at whadath(at)rogers.com I know of no problems with the steering link use. The entire tailwheel assembly requires periodic inspection and lubrication, but if you do that, you should have no problems. Thx, Vince Frazier Flyboy Accessories 3965 Caborn Road Mount Vernon, IN 47620 812-464-1839 www.flyboyaccessories.com ________________________________________________________________________________
Date: Dec 15, 2008
Subject: RV-6 / 6a kits for sale
RV-6 / 6a kits for sale. Empennage: Complete except for fiberglass tips. Includes electric elevator trim kit. All parts are alodined and primed with Marhyde primer. Wings & Phlogiston Spar: Both skeletons fully assembled. Top skins riveted. Both tanks are complete and sealed. Flaps and ailerons complete, but not fitted. Includes electric aileron trim kit. All parts are alodined and primed with Deft epoxy primer (Mil-P-23377G). Both kits are the pre-punched versions purchased in 1997 & 1998 by myself. Construction is excellent. Preview plans and Orndorff videos are included for both kits. Detailed photos are available upon request. Must sell. The first $3750 takes it all. Buyer arranges transportation. If all items were purchased separately the price would be more than $6500 for the unassembled kits. Regards, Scott Kuebler Buffalo, NY 716-510-0318- cell scottam65(at)gmail.com ________________________________________________________________________________
Date: Dec 15, 2008
I'm late to the discussion but WET is the best IMHO. Of course you need air-oil sep. It will weigh more over all. Some claim oil migration can get to gyros and cause a problem. I have not seen that but I guess it could happen. There are ways to prevent that. The point is WET will last and not fail unexpectedly like DRY pumps. New Dry pump designs look better than the traditional black can design? Just get a spruce AC catalog. I have not used a Vac pump in years with the EFIS. It's about money. Check the warranty. If reliability is critical to you than plan preventative replacement. Dry pump works fine, but those vane's wear and get unstable when they get short, causing catastrophic failure. Do preventative maintence/inspections. The dry pumps are delicate and need to be handled carefully. Cooling is critical as is the overall installation. Restrictive fittings, hoses and improper or missing filters and regulators are sure fire ways to mess your pump up. Educate your self on all the DO's and DON'T of installation and operation of any Vac pump. A lot of premature failures are due to abuse, installation error or operation issues. ________________________________________________________________________________
Date: Dec 15, 2008
Matt, Powdercoat guy here, recommended thickness is .0015" to .003" per side. We usually get .002" to .003" when we spray. Just ask the powdercoater to run his finger or something that will "brush off" the powder around the inside of the holes before he cures the powder. Doing this will brush off the powder and will take most if not all of the thickness away. Chuck RV6A FWF -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, December 14, 2008 1:07 PM Subject: RV-List: Instrument Panel - Powercoat Thickness? Dear Listers, I laid out the RV-8 panel in a CAD program and had experimentalair.com cut a clear Lexan mockup for fitting. I highly recommend using a Lexan mockup first as its a lot cheaper and it really helps to be able to see through the panel to locate brackets, etc. Also, Nick Burns over at ExperimpntalAir has be *super* to work with on this project. I've been emailing him DXF versions of the panel and he made a number of suggestions that I incorporated into the CAD drawing. I sent him the final CAD version Wednesday and he cut the Lexan panel on a FloJet and I received it Friday. It's a work of art! So here's my question. On the hole cutouts, I used a micrometer to measure each instrument, then used these exact measurements in the CAD drawing. I added .005" to both X and Y to allow for easier sliding in and out of the instrument which has turned out to be exactly the right amount. BUT, there's no powercoating on the panel yet. I'm planning on a simi-flat black coating. What is the thickness of the powercoating? How much should I increase the cutout size to account for the coating and still have the nice, tight, fit that I have now? Here's a link to my Builder's Log for anyone that is interested in checking out more on the project: http://www.mykitlog.com/users/category.php?user=dralle&project=619&category 0 Thanks for the feedback, Matt Dralle RV-8 #82880 N998RV (res) ________________________________________________________________________________
Subject: Strobe and E.I. UGB-16 Issue
Date: Dec 15, 2008
I am posting this for a friend.....He can not send, only receive e-mails. " I'm having a problem with Whelen strobe interference on my E.I. UGB-16 engine analyzer showing up on number?two cylinder. The display and bar graph jump between 190 and -300 deg F. When I turn off the strobes the problem disappears. The 2?power packs are mounted on the wingtips and are on a separate breakers for the E.I. and strobes. The interference causes the E.I. to trip its 5 amp breaker taking along the engine instruments and flap circuit with it. If after checking all the T/C connections from number 2 I still have problems can anyone suggest any ideas ? Thanks, Doug Gardner? RV-8A??? N456DG?? 101 hrs Palm Harbor/Lakeland Fl Douglas P. Gardner Fireye Regional Sales Manager/Southeast Palm Harbor, Florida ?34683 (727) 784-2600 Fax (727) 785-4767 Email : seabearfl(at)netzero.com ________________________________________________________________________________
Date: Dec 15, 2008
Subject: Re: Strobe and E.I. UGB-16 Issue
Off the top of my head..........=0A=0ADo not run any-wires that supply po wer near a wire used for an instrument reading. =0A=0AFor example-on my f irewall I have power wires going through in one area and-wires used for s ensors in another area seperated by about 2 feet.=0A=0AI am guesing that so mewhere along the way the strobe wires are to close to other non-power wire s.......?=0A=0AScott RV-8a=0A=0A=0A=0A=0A=0A_______________________________ _=0AFrom: "cbrxxdrv(at)aol.com" <cbrxxdrv(at)aol.com>=0ATo: rv-list(at)matronics.com =0ASent: Monday, December 15, 2008 2:45:08 PM=0ASubject: RV-List: Strobe an d E.I. UGB-16 Issue=0A=0A=0AI am posting this for a friend.....He can not s end, only receive e-mails.=0A=0A=0A=0A=0A" I'm having a problem with Whelen strobe interference on my E.I. UGB-16 engine analyzer showing up on number -two cylinder. The display and bar graph jump between 190 and -300 deg F. When I turn off the strobes the problem disappears. The 2-power packs ar e mounted on the wingtips and are on a separate breakers for the E.I. and s trobes. The interference causes the E.I. to trip its 5 amp breaker taking a long the engine instruments and flap circuit with it.=0AIf after checking a ll the T/C connections from number 2 I still have problems can anyone sugge st any ideas ?=0AThanks,=0ADoug Gardner- RV-8A--- N456DG-- 101 hrs=0APalm Harbor/Lakeland Fl=0A=0ADouglas P. Gardner=0AFireye Regional Sal es Manager/Southeast=0APalm Harbor, Florida -34683=0A(727) 784-2600 Fax ( 727) 785-4767=0AEmail : seabearfl(at)netzero.com=0A=0A=0A_____________________ ___________=0AListen to 350+ music, sports, & news radio stations ' inclu ding songs for the holidays ' FREE while you browse. Start Listening Now! =0A=0A=0A=0A ________________________________________________________________________________
Date: Dec 15, 2008
I will say this for him.......it was fine for the first 100 hours ?? I am gonna take a look at it this weekend with him but will take all suggest ions=C2- :) Sal -----Original Message----- From: scott bilinski <rv8a2001(at)yahoo.com> Sent: Mon, 15 Dec 2008 6:38 pm Subject: Re: RV-List: Strobe and E.I. UGB-16 Issue Off the top of my head.......... =C2- Do not run any=C2-wires that supply power near a wire used for an instrume nt reading. =C2- For example=C2-on my firewall I have power wires going through in one area and=C2-wires used for sensors in another area seperated by about 2 feet. =C2- I am guesing that somewhere along the way the strobe wires are to close to o ther non-power wires.......? =C2- =C2- Scott RV-8a From: "cbrxxdrv(at)aol.com" <cbrxxdrv(at)aol.com> Sent: Monday, December 15, 2008 2:45:08 PM Subject: RV-List: Strobe and E.I. UGB-16 Issue I am posting this for a friend.....He can not send, only receive e-mails. " I'm having a problem with Whelen strobe interference on my E.I. UGB-16 eng ine analyzer showing up on number=C2-two cylinder. The display and bar gra ph jump between 190 and -300 deg F. When I turn off the strobes the problem disappears. The 2=C2-power packs are mounted on the wingtips and are on a separate breakers for the E.I. and strobes. The interference causes the20E.I . to trip its 5 amp breaker taking along the engine instruments and flap cir cuit with it. If after checking all the T/C connections from number 2 I still have problem s can anyone suggest any ideas ? Thanks, Doug Gardner=C2- RV-8A=C2-=C2-=C2- N456DG=C2-=C2- 101 hrs Palm Harbor/Lakeland Fl Douglas P. Gardner Fireye Regional Sales Manager/Southeast Palm Harbor, Florida =C2-34683 (727) 784-2600 Fax (727) 785-4767 Email : seabearfl(at)netzero.com Listen to 350+ music, sports, & news radio stations =93 including song s for the holidays =93 FREE while you browse. Start Listening Now! ________________________________________________________________________________
Date: Dec 15, 2008
Interesting. I have a similar issue with #2 EGT only on same system. Sometimes it is fine, othertimes it jumps around, occasionally drops off line. Strobe switch is next to UBG-16 power switch. However this only developed after 150 hours. Next time it happens will try turning strobes off. cbrxxdrv(at)aol.com wrote: > I will say this for him.......it was fine for the first 100 hours ?? > > I am gonna take a look at it this weekend with him but will take all > suggestions :) > > Sal > > > -----Original Message----- > From: scott bilinski <rv8a2001(at)yahoo.com> > To: rv-list(at)matronics.com > Sent: Mon, 15 Dec 2008 6:38 pm > Subject: Re: RV-List: Strobe and E.I. UGB-16 Issue > > Off the top of my head.......... > > Do not run any wires that supply power near a wire used for an > instrument reading. > > For example on my firewall I have power wires going through in one > area and wires used for sensors in another area seperated by about 2 feet. > > I am guesing that somewhere along the way the strobe wires are to > close to other non-power wires.......? > > > Scott RV-8a > > > ------------------------------------------------------------------------ > *From:* "cbrxxdrv(at)aol.com " > > *To:* rv-list(at)matronics.com > *Sent:* Monday, December 15, 2008 2:45:08 PM > *Subject:* RV-List: Strobe and E.I. UGB-16 Issue > > I am posting this for a friend.....He can not send, only receive e-mails. > > > " I'm having a problem with Whelen strobe interference on my E.I. > UGB-16 engine analyzer showing up on number two cylinder. The display > and bar graph jump between 190 and -300 deg F. When I turn off the > strobes the problem disappears. The 2 power packs are mounted on the > wingtips and are on a separate breakers for the E.I. and strobes. The > interference causes the E.I. to trip its 5 amp breaker taking along > the engine instruments and flap circuit with it. > If after checking all the T/C connections from number 2 I still have > problems can anyone suggest any ideas ? > Thanks, > Doug Gardner RV-8A N456DG 101 hrs > Palm Harbor/Lakeland Fl > > Douglas P. Gardner > Fireye Reg ional Sales Manager/Southeast > Palm Harbor, Florida 34683 > (727) 784-2600 Fax (727) 785-4767 > Email : seabearfl(at)netzero.com > > ------------------------------------------------------------------------ > Listen to 350+ music, sports, & news radio stations including songs > for the holidays FREE while you browse. Start Listening Now > <http://toolbar.aol.com/aolradio/download.html?ncid=emlweusdown00000013>! > < /font> > > <http://www.matronics.com/Navigator?RV-List> > * > > > ========== > > ,courier" size="2">* <http://www.matronics.com/Navigator?RV-List>*http://www.matronics.com/contribution > > ========== > > 0and much much more: > > or?RV-List">http://www.matronics.com/Navigator?RV-List > > ========== > > p://forums.matronics.com > > ========== > > * > > ------------------------------------------------------------------------ > Listen to 350+ music, sports, & news radio stations including songs > for the holidays FREE while you browse. Start Listening Now > <http://toolbar.aol.com/aolradio/download.html?ncid=emlweusdown00000013>! > * > > * ________________________________________________________________________________
Subject: What we did for panel redundancy
Date: Dec 15, 2008
Listers--I'm not going to get into the argument, just share with you?what we did and the logic we followed. We set up our RV-6A for IFR as follows: Vacuum attitude indicator and DG. Electric turn coordinator/S-Tec 30 2-axis autopilot (ship's power only). Electric back up attitude indicator?on right side of panel (ship's power only). Replace vacuum pump (SigmaTek dry pump) every 500 hours. Replace 60 amp alternator from Vans every 500 hours. Garmin 430 panel mounted. Garmin 496 on swing out mount near left side roll?bar with XM weather (ship's power constantly charges battery with automatic battery back-up if power fails).?? The panel page on this unit is our final back-up, which Aviation Consumer has demonstrated can keep you right side up?if you don't get too far out of whack. Our theory: redundancy/multiple power sources plus periodic replacement of potential failure items. We haven't flown IFR yet so no real world data to share. LeRoy Johnston/David White (Ohio)?RV-6A Esperanza 116.2 hours. ________________________________________________________________________________
Date: Dec 15, 2008
Subject: Re: What we did for panel redundancy
Great combination of redundancy and planning, as well as a good mx plan. N ice work. I've tested the 396 in IMC and it would function well as a last resort, although a vacuum failure and an electrical failure on the same fl ight is, well...=0A=0APaul Besing=0A=0A=0A=0A=0A___________________________ _____=0AFrom: "jhnstniii(at)aol.com" <jhnstniii(at)aol.com>=0ATo: rv-list@matroni cs.com=0ASent: Monday, December 15, 2008 8:44:30 PM=0ASubject: RV-List: Wha t we did for panel redundancy=0A=0AListers--I'm not going to get into the a rgument, just share with you what we did and the logic we followed.=0A=0AWe set up our RV-6A for IFR as follows:=0A=0AVacuum attitude indicator and DG .=0A=0AElectric turn coordinator/S-Tec 30 2-axis autopilot (ship's power on ly).=0A=0AElectric back up attitude indicator on right side of panel (ship' s power only).=0A=0AReplace vacuum pump (SigmaTek dry pump) every 500 hours .=0A=0AReplace 60 amp alternator from Vans every 500 hours.=0A=0AGarmin 430 panel mounted.=0A=0AGarmin 496 on swing out mount near left side roll bar with XM weather (ship's power constantly charges battery with automatic bat tery back-up if power fails). The panel page on this unit is our final ba ck-up, which Aviation Consumer has demonstrated can keep you right side up if you don't get too far out of whack. =0A=0AOur theory: redundancy/multipl e power sources plus periodic replacement of potential failure items.=0A=0A We haven't flown IFR yet so no real world data to share. =0A=0ALeRoy Johnst on/David White (Ohio) RV-6A Esperanza 116.2 hours.=0A=0A=0A________________ ________________=0AListen to 350+ music, sports, & news radio stations ' including songs for the holidays ' FREE while you browse. Start Listening ====0A=0A=0A=0A ________________________________________________________________________________
Subject: Static System Assembly
Date: Dec 17, 2008
Dear List ... I'm rebuilding my static system and am looking for "how did you do it" suggestions. Specifically: How did you attach the tubing to the Van's static port rivet tails? Glue, RTV or ... ? Did any of you find a clamp that would work with such a small diameter and short rivet tail? What method does not work or will not hold together between condition inspections? Thanks, Jerry ________________________________________________________________________________
Date: Dec 17, 2008
Hey Jerry=2C I bought some rivets with the same head but a longer grip and used a little sealant and a zip tie. I didn't like that the vans rivets had such a shor t shank to clamp to. Paul Rice RV8 Flying Siren 130 hours> From: jerry(at)mc.net> To: rv-list(at)matronics.com> Subject: RV-List: Static System Assembly> Date: Wed=2C 17 Dec 2008 12:37:31 -0600> > --> RV- List message posted by: "Jerry Grimmonpre" > > Dear List ...> I'm rebuilding my static system and am looking for "how did you do it" > s uggestions.> > Specifically:> How did you attach the tubing to the Van's st atic port rivet tails?> Glue=2C RTV or ... ?> > Did any of you find a clamp that would work with such a small diameter and > short rivet tail?> > What method does not work or will not hold together between condition > inspect ======================> > > ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Subject: Re: Static System Assembly
Date: Dec 17, 2008
RV's Builders, I used a silicone and the rivets in the kit from Van's. Is there any problem with using silicone on the aluminum skin or ribs? Silicone works well for holding parts in place, however, will it effect the skin over time? Thanks for any input. Jim RV9a ----- Original Message ----- From: Paul Rice To: rv-list(at)matronics.com Sent: Wednesday, December 17, 2008 2:07 PM Subject: RE: RV-List: Static System Assembly Hey Jerry, I bought some rivets with the same head but a longer grip and used a little sealant and a zip tie. I didn't like that the vans rivets had such a short shank to clamp to. Paul Rice RV8 Flying Siren 130 hours > From: jerry(at)mc.net > To: rv-list(at)matronics.com > Subject: RV-List: Static System Assembly > Date: Wed, 17 Dec 2008 12:37:31 -0600 > > > Dear List ... > I'm rebuilding my static system and am looking for "how did you do it" > suggestions. > > Specifically: > How did you attach the tubing to the Van's static port rivet tails? > Glue, RTV or ... ? > > Did any of you find a clamp that would work with such a small diameter and > short rivet tail? > > What method does not work or will not hold together between condition > inspections? > Thanks======= > > > ------------------------------------------------------------------------- ----- Checked by AVG. 12/17/2008 8:31 AM ________________________________________________________________________________
Date: Dec 17, 2008
Hi Jim, Just do not get it on the outside where the paint will go. Jim RV9-A ____________________________________________________________ Free information - Learn about Hardwood Floors. Click now! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw2eFAXYnrR0Jzl1WeS2XDfc32K9qOBF9g4HRYoFMoEfgY5S7/ ________________________________________________________________________________
Date: Dec 17, 2008
It won't necessarily affect the skins, but if you use it externally it'll likely make it near to impossible to ever get a paint job to stick to it...even with it visibly cleaned. Silicone (or an product with silicone in it) is a big no-no for external use on airplanes as it doesn't play nicely with paint. Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Wednesday, December 17, 2008 3:09 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Static System Assembly RV's Builders, I used a silicone and the rivets in the kit from Van's. Is there any problem with using silicone on the aluminum skin or ribs? Silicone works well for holding parts in place, however, will it effect the skin over time? Thanks for any input. Jim RV9a ________________________________________________________________________________
Date: Dec 17, 2008
Not sure if they still sell them, but Cleveland tool makes some machined static ports which are very nice. Just be sure and mount them to the OUTSIDE of the skin...otherwise the static port will be caught in the boundary layer, and will not be accurate..ask me how I know.... Paul Besing ________________________________ From: "SteinAir, Inc." <stein(at)steinair.com> Sent: Wednesday, December 17, 2008 2:47:27 PM Subject: RE: RV-List: Static System Assembly It won't necessarily affect the skins, but if you use it externally it'll likely make it near to impossible to ever get a paint job to stick to it...even with it visibly cleaned. Silicone (or an product with silicone in it) is a big no-no for external use on airplanes as it doesn't play nicely with paint. Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Wednesday, December 17, 2008 3:09 PM Subject: Re: RV-List: Static System Assembly RV's Builders, I used a silicone and the rivets in the kit from Van's. Is there any problem with using silicone on the aluminum skin or ribs? Silicone works well for holding parts in place, however, will it effect the skin over time? Thanks for any input. Jim RV9a ________________________________________________________________________________
Date: Dec 17, 2008
There are numerous paintable sealant/adhesives that can do the same kind of job as the silicone-based ones. Proseal-like tank sealants, Lexel and Sikaflex come to mind. Regards, Greg Young _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of SteinAir, Inc. Sent: Wednesday, December 17, 2008 3:47 PM Subject: RE: RV-List: Static System Assembly It won't necessarily affect the skins, but if you use it externally it'll likely make it near to impossible to ever get a paint job to stick to it...even with it visibly cleaned. Silicone (or an product with silicone in it) is a big no-no for external use on airplanes as it doesn't play nicely with paint. Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Wednesday, December 17, 2008 3:09 PM Subject: Re: RV-List: Static System Assembly RV's Builders, I used a silicone and the rivets in the kit from Van's. Is there any problem with using silicone on the aluminum skin or ribs? Silicone works well for holding parts in place, however, will it effect the skin over time? Thanks for any input. Jim RV9a ________________________________________________________________________________
Date: Dec 17, 2008
Stein, Thanks for the info. I appreciate your knowledge, I'm sorry I didn't get to your shop last Saturday. I hope you had a good turn out and that your business is busy. Good luck in 2009. Jim RV9a ----- Original Message ----- From: SteinAir, Inc. To: rv-list(at)matronics.com Sent: Wednesday, December 17, 2008 3:47 PM Subject: RE: RV-List: Static System Assembly It won't necessarily affect the skins, but if you use it externally it'll likely make it near to impossible to ever get a paint job to stick to it...even with it visibly cleaned. Silicone (or an product with silicone in it) is a big no-no for external use on airplanes as it doesn't play nicely with paint. Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Fogarty at Lakes & Leisure Realty Sent: Wednesday, December 17, 2008 3:09 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Static System Assembly RV's Builders, I used a silicone and the rivets in the kit from Van's. Is there any problem with using silicone on the aluminum skin or ribs? Silicone works well for holding parts in place, however, will it effect the skin over time? Thanks for any input. Jim RV9a ------------------------------------------------------------------------- ----- Checked by AVG. 12/17/2008 8:31 AM ________________________________________________________________________________
Date: Dec 17, 2008
I came up with a way to make a back-side fitting for Van's static port. This permits use of a removable fitting for plastic tubing to connect the static vent plumbing. It's described in the EAA chapter 105 newsletter for April 2005, page 2: http://www.eaa105.org/Newsletter/nl-200504.pdf Mike Linse Corvallis, OR RV-6A (canopy, in the winter...) ________________________________________________________________________________
Date: Dec 17, 2008
Hi Mike, You have won the prize for an elegant solution to the static system plumbing challenge. That's a clever approach. If it's OK I am going to use it for my static hook-up. It also seems possible to drill a close fitting hole in a light weight pipe cap, and expand the rivet into that cap then drive out the center stem. Back it up with a little tank sealant. Thanks, Jerry ----- Original Message ----- From: <mikerv6a(at)ao.com> Sent: Wednesday, December 17, 2008 5:59 PM Subject: Re: RV-List: Static System Assembly > > I came up with a way to make a back-side fitting for > Van's static port. This permits use of a removable > fitting for plastic tubing to connect the static vent > plumbing. It's described in the EAA chapter 105 > newsletter for April 2005, page 2: > http://www.eaa105.org/Newsletter/nl-200504.pdf > > Mike Linse > Corvallis, OR > RV-6A (canopy, in the winter...) ________________________________________________________________________________
Date: Dec 17, 2008
I had the same trouble with the rivet tail being to short. I went to the h ardware store and bought some aluminum tubing that would just fit over the rivet tail before it was installed. I cut about a 1 inch length and had so meone hold the tubing over the rivet on the inside of the fuselage while I pulled the rivet from the out side. As the pop rivet expanded it did the s ame to the tubing and the tubing made a nice little nipple to connect van's plastic tubing to on the inside. I sealed it with a couple of turns of sa fety wire. Bob Savage RV7A Firewall Forward > From: jerry(at)mc.net > To: rv-list(at)matronics.com > Subject: RV-List: Static System Assembly > Date: Wed=2C 17 Dec 2008 12:37:31 -0600 > > > Dear List ... > I'm rebuilding my static system and am looking for "how did you do it" > suggestions. > > Specifically: > How did you attach the tubing to the Van's static port rivet tails? > Glue=2C RTV or ... ? > > Did any of you find a clamp that would work with such a small diameter an d > short rivet tail? > > What method does not work or will not hold together between condition > inspections? > Thanks=2C Jerry > > > =========== =========== =========== =========== > > > _________________________________________________________________ Suspicious message? There=92s an alert for that. http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broa d2_122008 ________________________________________________________________________________
Date: Dec 17, 2008
Hi Jerry That's a good idea: It eliminates the tapping operation. Also, one complication of my use of round bar is that there are not features for use of a wrench. Vise grip pliers solved that, but I made later versions from 1/2" hex aluminum bar. Pipe caps generally have features that make them compatible with some kind of wrench or pliers. McMaster sells an aluminum cap that's threaded for 1/8 pipe, their part number 44705K372, $2.18. Mike Linse Corvallis, OR RV-6A > > Hi Mike, > [snip] It also seems possible to drill a close fitting hole > in a light weight pipe cap, and expand the rivet into that > cap then drive out the center stem. Back it up with a little > tank sealant. > Thanks, Jerry > >> >> I came up with a way to make a back-side fitting for >> Van's static port... It's described in the EAA chapter 105 >> newsletter for April 2005, page 2: >> http://www.eaa105.org/Newsletter/nl-200504.pdf >> ________________________________________________________________________________
Date: Dec 18, 2008
Mike, Thanks for the McMaster part number on the cap. I just ordered two of them along with enough "push to connect" parts to assemble the static plumbing. You are right, Mike, these parts will make rebuilding the system far easier and the sealing of small parts is now going to be a non-issue. One other thing to add: If a push to connect T is installed in the static line leading to the instruments, the transponder check will be simple to do. This T could be permanently installed in the line passing through the rear cockpit which makes it accessible while standing on the ground and reaching over the canopy rail. Thanks, Jerry ________________________________________________________________________________
Subject: Oil Cooler Selection
Date: Dec 18, 2008
I am building an RV-7, and am installing the 180HP XP-360 engine with an Airflow Performance FI system. I got the stock/standard oil cooler in my firewall-forward package (Van's part "EA OIL COOLER II"). Reading comments from others my impression is that the -7s have a tendency to run hot. I'm curious as to the impression other on the list have about the best oil cooler to run with the setup I intend to install. Right NOW is the time for me to make a decision, as I'm just starting to do some baffle work. Clearly, if I stick with the existing cooler I can baffle-mount it, but if I switch to the larger Stewart/Warner style ol cooler (Van's part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler and the baffle behind the #4 cylinder will need a fitting for four inch SCAT hose. So ... whats the collected wisdom on this issue, folks? Chime in if you have experiences one way or the other. And ... thanks! -- Dwight Frye ________________________________________________________________________________
Subject: Re: Oil Cooler Selection
Date: Dec 18, 2008
Dwight: I just finished flying off my hours with an XP IO 360. I used the factory mount and radiator mounted on the baffling behind # 4 cylinder. I started flying off my hours in October when daytime temps here in SOCal were in the high nineties and low 100s. Oil temps did not go above 220 and as the engine broke in were normally between 180 and 195. I did do some extra bracing as has been reported by others to reduce vibration and avoid cracking of the cooler mount and baffling. I really like the engine -- it did take some practice to get used to hot starts with the Airflow FI induction system, but it is easy once you get used to it. best wishes dave RV 7A On Dec 18, 2008, at 2:10 PM, Dwight Frye wrote: > > I am building an RV-7, and am installing the 180HP XP-360 engine with > an Airflow Performance FI system. I got the stock/standard oil cooler > in my firewall-forward package (Van's part "EA OIL COOLER II"). > > Reading comments from others my impression is that the -7s have a > tendency to run hot. I'm curious as to the impression other on the > list > have about the best oil cooler to run with the setup I intend to > install. > Right NOW is the time for me to make a decision, as I'm just starting > to do some baffle work. > > Clearly, if I stick with the existing cooler I can baffle-mount it, > but if I switch to the larger Stewart/Warner style ol cooler (Van's > part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler > and the baffle behind the #4 cylinder will need a fitting for four > inch SCAT hose. > > So ... whats the collected wisdom on this issue, folks? Chime in if > you have experiences one way or the other. And ... thanks! > > -- Dwight Frye > > ________________________________________________________________________________
Date: Dec 18, 2008
Check this out Dwight ... it was sent to me by this builder last year, he installed a SW ... just an idea for you. Jerry ----- Original Message ----- From: crunk12 Sent: Saturday, March 31, 2007 1:05 PM Subject: Firewall mounted oil coolers Jerry, Sorry for butting-in but I sent some other -8 builders this pic of my installation. I've had the airplane in Phoenix in 116 degree weather and had no problems. (I live in Atlanta) I hope this will be of some help. This shows the positech which didn't work from the start, i.e., the first flight. I replaced it with the S/W and have had no problems since. I hope this will be of some help. Jim Crunkleton N802JD I am building an RV-7, and am installing the 180HP XP-360 engine with an Airflow Performance FI system. I got the stock/standard oil cooler in my firewall-forward package (Van's part "EA OIL COOLER II"). Reading comments from others my impression is that the -7s have a tendency to run hot. I'm curious as to the impression other on the list have about the best oil cooler to run with the setup I intend to install. Right NOW is the time for me to make a decision, as I'm just starting to do some baffle work. Clearly, if I stick with the existing cooler I can baffle-mount it, but if I switch to the larger Stewart/Warner style ol cooler (Van's part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler and the baffle behind the #4 cylinder will need a fitting for four inch SCAT hose. So ... whats the collected wisdom on this issue, folks? Chime in if you have experiences one way or the other. And ... thanks! -- Dwight Frye ________________________________________________________________________________
Date: Dec 19, 2008
Dwight, I live in central Florida and have the same system you have. I use the Posi---- what ever oil cooler from Van's and baffle mounted it. I added a brace from the inside (centerline side) of the cooler to the mounting tab flange on the engine for the purge valve. This made the oil cooler solid to the engine rather than just attached to the baffle. I have had no cooling problems . I started flying July 1st and only got the oil temps high by leaning (220*F). Now that it is winter (?) here in Florida, I watch to be sure it gets warm enough (over 180*F). I do like the AFP fuel injection system and especially the purge valve. Jim ____________________________________________________________ Free information - Learn about Hardwood Floors. Click now! http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw2eFAHLrX5yxmZQ6W93pZCmRSCYeKksvW6lnoUnBYJ2bqfrV/ ________________________________________________________________________________
Date: Dec 19, 2008
I've been running a setrab 10 row oil cooler mounted to the baffles for ~150 hrs and never had an oil temp issue. the highest I see on a 100 F day is 200 F oil temp. Cruise will generally settle out around 170 F. It is about 1/4 of the stock cooler size. I had a friend who was running one in a 180 hp RV-6 and I figured it was worth a try. I made the swap because the stock cooler kept cracking my baffles and my temps were always low even with the stock cooler completely covered. I beefed up the baffles when I did the change out so it's hard to tell if the lack of cracks is from the extra material, decreased weight or combination. Either way I was cracking baffles about every 60 hrs before. no problems since. Bill Judge N84WJ 330 hrs. rv-8.blogspot.com > > > From: Dwight Frye <dwight(at)openweave.org> > Subject: RV-List: Oil Cooler Selection > > > I am building an RV-7, and am installing the 180HP XP-360 engine with > an Airflow Performance FI system. I got the stock/standard oil cooler > in my firewall-forward package (Van's part "EA OIL COOLER II"). > > Reading comments from others my impression is that the -7s have a > tendency to run hot. I'm curious as to the impression other on the list > have about the best oil cooler to run with the setup I intend to install. > Right NOW is the time for me to make a decision, as I'm just starting > to do some baffle work. > > Clearly, if I stick with the existing cooler I can baffle-mount it, > but if I switch to the larger Stewart/Warner style ol cooler (Van's > part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler > and the baffle behind the #4 cylinder will need a fitting for four > inch SCAT hose. > > So ... whats the collected wisdom on this issue, folks? Chime in if > you have experiences one way or the other. And ... thanks! > > -- Dwight Frye > > > ________________________________ Message 3 > _____________________________________ > > > From: David Cudney <yenduc(at)sbcglobal.net> > Subject: Re: RV-List: Oil Cooler Selection > > > Dwight: > > I just finished flying off my hours with an XP IO 360. I used the > factory mount and radiator mounted on the baffling behind # 4 > cylinder. I started flying off my hours in October when daytime temps > here in SOCal were in the high nineties and low 100s. Oil temps did > not go above 220 and as the engine broke in were normally between 180 > and 195. I did do some extra bracing as has been reported by others > to reduce vibration and avoid cracking of the cooler mount and > baffling. I really like the engine -- it did take some practice to > get used to hot starts with the Airflow FI induction system, but it > is easy once you get used to it. > > best wishes > dave RV 7A > > > On Dec 18, 2008, at 2:10 PM, Dwight Frye wrote: > > > > > I am building an RV-7, and am installing the 180HP XP-360 engine with > > an Airflow Performance FI system. I got the stock/standard oil cooler > > in my firewall-forward package (Van's part "EA OIL COOLER II"). > > > > Reading comments from others my impression is that the -7s have a > > tendency to run hot. I'm curious as to the impression other on the > > list > > have about the best oil cooler to run with the setup I intend to > > install. > > Right NOW is the time for me to make a decision, as I'm just starting > > to do some baffle work. > > > > Clearly, if I stick with the existing cooler I can baffle-mount it, > > but if I switch to the larger Stewart/Warner style ol cooler (Van's > > part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler > > and the baffle behind the #4 cylinder will need a fitting for four > > inch SCAT hose. > > > > So ... whats the collected wisdom on this issue, folks? Chime in if > > you have experiences one way or the other. And ... thanks! > > > > -- Dwight Frye > > > > > > > ________________________________ Message 4 > _____________________________________ > > > From: "Jerry Grimmonpre" <jerry(at)mc.net> > Subject: RV-List: Oil Cooler Selection > > Check this out Dwight ... it was sent to me by this builder last year, > he installed a SW ... just an idea for you. Jerry > ----- Original Message ----- > From: crunk12 > Sent: Saturday, March 31, 2007 1:05 PM > Subject: Firewall mounted oil coolers > > > Jerry, > Sorry for butting-in but I sent some other -8 builders this pic of my > installation. I've had the airplane in Phoenix in 116 degree weather and > had no problems. (I live in Atlanta) > I hope this will be of some help. This shows the positech which didn't > work from the start, i.e., the first flight. > I replaced it with the S/W and have had no problems since. > I hope this will be of some help. > Jim Crunkleton N802JD > > > I am building an RV-7, and am installing the 180HP XP-360 engine with > an Airflow Performance FI system. I got the stock/standard oil cooler > in my firewall-forward package (Van's part "EA OIL COOLER II"). > > Reading comments from others my impression is that the -7s have a > tendency to run hot. I'm curious as to the impression other on the list > have about the best oil cooler to run with the setup I intend to > install. > Right NOW is the time for me to make a decision, as I'm just starting > to do some baffle work. > > Clearly, if I stick with the existing cooler I can baffle-mount it, > but if I switch to the larger Stewart/Warner style ol cooler (Van's > part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler > and the baffle behind the #4 cylinder will need a fitting for four > inch SCAT hose. > > So ... whats the collected wisdom on this issue, folks? Chime in if > you have experiences one way or the other. And ... thanks! > > -- Dwight Frye > > ________________________________________________________________________________
Subject: RV-6A rudder trim tab
Date: Dec 20, 2008
I am priming things. I gather that most planes have a small rectangle of sheet aluminum glued/taped to the trailing edge of the rudder and this is used to make a tiny trim adjustment to the rudder. I can't find a reference to this in my manual. Can some one advise me of the size of this this and what thickness is usually used for it? Thanks, ---Tom Sargent, RV-6A, almost ready for the color coat. ________________________________________________________________________________
From: "Richard Dudley" <rhdudley1(at)bellsouth.net>
Subject: Re: RV-6A rudder trim tab
Date: Dec 20, 2008
Hi Tom, What worked for me was a balsa trailing edge for model airplanes purchased from a hobby shop. I used one about 1" wide attached with double stick foam tape. I started with one about 8" long and finally trimmed it to about 5-6" after several trials. I have seen wedges of various materials, attached in various ways on RVs. I am sure the length needed varies with the individual plane. So, it is an engineering experiment to adjust the length as needed until the plane flies with the ball in the center at cruise speed. It is a separate problem from a heavy wing correction. I used a balsa wedge from the same stick as my final rudder trim and painted it the color of the rudder. The foam tape was still intact after three years and 140 hours. Regards, Richard Dudley ----- Original Message ----- From: "thomas sargent" <sarg314(at)gmail.com> Sent: Saturday, December 20, 2008 12:01 PM Subject: RV-List: RV-6A rudder trim tab > > I am priming things. I gather that most planes have a small rectangle of > sheet aluminum glued/taped to the trailing edge of the rudder and this is > used to make a tiny trim adjustment to the rudder. I can't find a > reference to this in my manual. Can some one advise me of the size of > this this and what thickness is usually used for it? > > Thanks, > ---Tom Sargent, RV-6A, almost ready for the color coat. > > > ________________________________________________________________________________
Date: Dec 20, 2008
Tom, most use balsa wood and size is determined by trial and error. Most I used are about 4 to 7" long by 1.5" wide. After trying in flight and size is determined attach it with JB Weld. and away you go. Dick RV6A > > I am priming things. I gather that most planes have a small >rectangle of sheet aluminum glued/taped to the trailing edge of the >rudder and this is used to make a tiny trim adjustment to the >rudder. I can't find a reference to this in my manual. Can some one >advise me of the size of this this and what thickness is usually used >for it? > >Thanks, >---Tom Sargent, RV-6A, almost ready for the color coat. > > ________________________________________________________________________________
Date: Dec 20, 2008
Oops. Make that a tapered pc of balsa starting at 1/8" and going to about 1/4" >Date: Sat, 20 Dec 2008 12:42:01 -0500 >To: rv-list(at)matronics.com >From: Richard Seiders <seiders(at)bellsouth.net> >Subject: Re: RV-List: RV-6A rudder trim tab > >Tom, most use balsa wood and size is determined by trial and error. >Most I used are about 4 to 7" long by 1.5" wide. After trying in >flight and size is determined attach it with JB Weld. and away you go. >Dick RV6A >> >> I am priming things. I gather that most planes have a small >>rectangle of sheet aluminum glued/taped to the trailing edge of the >>rudder and this is used to make a tiny trim adjustment to the >>rudder. I can't find a reference to this in my manual. Can some one >>advise me of the size of this this and what thickness is usually used >>for it? >> >>Thanks, >>---Tom Sargent, RV-6A, almost ready for the color coat. >> >> ________________________________________________________________________________
Date: Dec 20, 2008
Tom, A few years ago, I installed this simple wedge now sold by Avery. Trim its length in 1/8" increments and test fly until you are happy with the performance. Can be epoxied into place. My wedge is attached to the rudder with double sided carpet tape, works fine. http://www.averytools.com/pc-118-112-rudder-trim-tab.aspx Read this topic online here: http://forums.matronics.com/viewtopic.php?p=220318#220318 ________________________________________________________________________________
Date: Dec 20, 2008
Why would you not want to use a small spring attached to the proper rudder pedal? Jimmy 8A ----- Original Message ----- From: "Rick Galati" <rick6a(at)yahoo.com> Sent: Saturday, December 20, 2008 12:49 PM Subject: RV-List: Re: RV-6A rudder trim tab > > Tom, > A few years ago, I installed this simple wedge now sold by Avery. Trim > its length in 1/8" increments and test fly until you are happy with the > performance. Can be epoxied into place. My wedge is attached to the > rudder with double sided carpet tape, works fine. > > http://www.averytools.com/pc-118-112-rudder-trim-tab.aspx > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=220318#220318 > > > ________________________________________________________________________________
Date: Dec 20, 2008
I tried that. Spring amount that was good at cruise was way too much at low speeds. I changed it out for the wedge. On 12/20/08, jimmy wrote: > > Why would you not want to use a small spring attached to the proper rudder > pedal? > > Jimmy > > 8A > ----- Original Message ----- > From: "Rick Galati" <rick6a(at)yahoo.com> > To: > Sent: Saturday, December 20, 2008 12:49 PM > Subject: RV-List: Re: RV-6A rudder trim tab > > >> >> Tom, >> A few years ago, I installed this simple wedge now sold by Avery. Trim >> its length in 1/8" increments and test fly until you are happy with the >> performance. Can be epoxied into place. My wedge is attached to the >> rudder with double sided carpet tape, works fine. >> >> http://www.averytools.com/pc-118-112-rudder-trim-tab.aspx >> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=220318#220318 >> >> >> >> >> >> >> >> >> >> > > -- -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Subject: Microair Transponder
Date: Dec 20, 2008
I hav a Microair T2000SFL Transponder for sale. $1500 with harness! jetjocal(at)gmail.com ________________________________________________________________________________
Date: Dec 23, 2008
Subject: Starter Ring Gear source?
My starter ring gear has gotten chewed up and is beginning to have problems engaging. Anyone have recommendations for a good parts source. I believe it is 149 teeth -- it is an O-360-A1A, bought new from Van's in 2000. A location in the Washington, DC area would be great, but I suppose it can be mailed from anywhere. Thanks! Randy Garrett RV-6A 850 hours ________________________________________________________________________________
Date: Dec 23, 2008
Randy - I'd suggest Barrett Precision or Mattituck. Rhonda and Mahlon provide an invaluable service to The Lists. Let's support them. Neal George CherokeeJet N9586J RV-7 N8ZG -----Original Message----- My starter ring gear has gotten chewed up and is beginning to have problems engaging. Anyone have recommendations for a good parts source. I believe it is 149 teeth -- it is an O-360-A1A, bought new from Van's in 2000. A location in the Washington, DC area would be great, but I suppose it can be mailed from anywhere. Thanks! Randy Garrett RV-6A 850 hours ________________________________________________________________________________
Date: Dec 23, 2008
I have used Preferred Air Parts in Ohio for years. They have some new but mostly used parts and are reliable and honest. I'm on the road at the moment, but they have a web site. Jim Carey 8-A building -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Neal George Sent: Tuesday, December 23, 2008 9:51 AM Subject: RE: RV-List: Starter Ring Gear source? Randy - I'd suggest Barrett Precision or Mattituck. Rhonda and Mahlon provide an invaluable service to The Lists. Let's support them. Neal George CherokeeJet N9586J RV-7 N8ZG -----Original Message----- My starter ring gear has gotten chewed up and is beginning to have problems engaging. Anyone have recommendations for a good parts source. I believe it is 149 teeth -- it is an O-360-A1A, bought new from Van's in 2000. A location in the Washington, DC area would be great, but I suppose it can be mailed from anywhere. Thanks! Randy Garrett RV-6A 850 hours __________ NOD32 3709 (20081220) Information __________ ________________________________________________________________________________
Date: Dec 23, 2008
Subject: Re: Starter Ring Gear source?
I have the same problem, caused by the factory installed lightweight starter not aligning properly with the ring gear. I replaced the starter at about 400 hours and it now seems to engage properly but the damage to the ring gear was already done. I bought my replacement ring gear from Sacramento Sky Ranch (www.sacskyranch.com). It is 149 teeth. Harry Crosby RV-6 N16CX, 533 hours ----- Original Message ----- From: "Randy Garrett" <rgarrett7(at)gmail.com> Sent: Tuesday, December 23, 2008 8:08:54 AM GMT -08:00 US/Canada Pacific Subject: RV-List: Starter Ring Gear source? My starter ring gear has gotten chewed up and is beginning to have problems engaging. Anyone have recommendations for a good parts source. I believe it is 149 teeth -- it is an O-360-A1A, bought new from Van's in 2000. A location in the Washington, DC area would be great, but I suppose it can be mailed from anywhere. Thanks! Randy Garrett RV-6A 850 hours ________________________________________________________________________________
Date: Dec 23, 2008
I have never had to deal with-a ring gear....... but, couldnt you remove it, flip it over and-reinstall it with the worn teeth facing forward inst ead of on the starter side?=0A-=0AScott=0ARV-8a=0A=0A=0A=0A=0A=0A________ ________________________=0AFrom: "HCRV6(at)comcast.net" <HCRV6(at)comcast.net>=0A ubject: Re: RV-List: Starter Ring Gear source?=0A=0A=0AI have the same prob lem, caused by the factory installed lightweight starter not aligning prope rly with the ring gear.- I replaced the starter at about 400 hours and it now seems to engage properly but the damage to the ring gear was already d one.- I bought my replacement ring gear from Sacramento Sky Ranch (www.sa cskyranch.com).- It is 149 teeth.=0A=0AHarry Crosby=0ARV-6 N16CX, 533 hou rs=0A=0A----- Original Message -----=0AFrom: "Randy Garrett" <rgarrett7@gma il.com>=0ATo: rv-list(at)matronics.com=0ASent: Tuesday, December 23, 2008 8:08 :54 AM GMT -08:00 US/Canada Pacific=0ASubject: RV-List: Starter Ring Gear s .com>=0A=0AMy starter ring gear has gotten chewed up and is beginning to ha ve=0Aproblems engaging. -Anyone have recommendations for a good parts=0As ource. -I believe it is 149 teeth -- it is an O-360-A1A, bought new=0Afro m Van's in 2000. -A location in the Washington, DC area would be=0Agreat, but I suppose it can be mailed from anywhere.=0A=0AThanks!=0A=0ARandy Garr ett=0ARV-nbsp; - - - - - - - --Matt Dralle, ===== ===================0A=0A=0A=0A ________________________________________________________________________________
Date: Dec 23, 2008
Try Don George in Orlando. He has non certified ring gears which are a big seller with the air boat guys down here in Florida. See http://orlando-fl.digicity.org/GeneralCompanies/Don_George_Aircraft_Engines_and_Parts-1987442849id.html Charlie Kuss --- On Tue, 12/23/08, Randy Garrett wrote: > From: Randy Garrett <rgarrett7(at)gmail.com> > Subject: RV-List: Starter Ring Gear source? > To: rv-list(at)matronics.com > Date: Tuesday, December 23, 2008, 11:08 AM > > > My starter ring gear has gotten chewed up and is beginning > to have > problems engaging. Anyone have recommendations for a good > parts > source. I believe it is 149 teeth -- it is an O-360-A1A, > bought new > from Van's in 2000. A location in the Washington, DC > area would be > great, but I suppose it can be mailed from anywhere. > > Thanks! > > Randy Garrett > RV-6A > 850 hours > ________________________________________________________________________________
Date: Dec 23, 2008
You might check Ebay. Check for the proper part number. Not all ring gears are created equal. I recently bought one for an O-320 for $50. Someone earlier mentioned flipping the ring gear. There is a bevel on one side so that will not work. Randy Hooper On Tue, Dec 23, 2008 at 2:40 PM, Charles Kuss wrote: > > Try Don George in Orlando. He has non certified ring gears which are a big > seller with the air boat guys down here in Florida. See > > > http://orlando-fl.digicity.org/GeneralCompanies/Don_George_Aircraft_Engines_and_Parts-1987442849id.html > > Charlie Kuss > > > --- On Tue, 12/23/08, Randy Garrett wrote: > > > From: Randy Garrett <rgarrett7(at)gmail.com> > > Subject: RV-List: Starter Ring Gear source? > > To: rv-list(at)matronics.com > > Date: Tuesday, December 23, 2008, 11:08 AM > > > > > > My starter ring gear has gotten chewed up and is beginning > > to have > > problems engaging. Anyone have recommendations for a good > > parts > > source. I believe it is 149 teeth -- it is an O-360-A1A, > > bought new > > from Van's in 2000. A location in the Washington, DC > > area would be > > great, but I suppose it can be mailed from anywhere. > > > > Thanks! > > > > Randy Garrett > > RV-6A > > 850 hours > > > > -- Randy Hooper ________________________________________________________________________________
Date: Dec 22, 2008
The starter side of the gear tooth is beveled to help the starter gear to engage. No bevel on the other side. Also, how do you get the gear off without destroying it? Linn scott bilinski wrote: > I have never had to deal with a ring gear....... but, couldnt you > remove it, flip it over and reinstall it with the worn teeth facing > forward instead of on the starter side? > > > Scott > > RV-8a > ________________________________________________________________________________
Date: Dec 23, 2008
The starter side of the gear tooth is beveled to help the starter gear to engage. No bevel on the other side. Also, how do you get the gear off without destroying it? Linn Moderately heat the steel and put a bag of ice on the inner aluminum. Bump the ring right off. Works pretty easy. Randy Hooper On Mon, Dec 22, 2008 at 6:00 PM, linn Walters wrote: > > The starter side of the gear tooth is beveled to help the starter gear to > engage. No bevel on the other side. Also, how do you get the gear off > without destroying it? > Linn > scott bilinski wrote: > >> I have never had to deal with a ring gear....... but, couldnt you remove >> it, flip it over and reinstall it with the worn teeth facing forward instead >> of on the starter side? >> >> Scott >> >> RV-8a >> >> > > -- Randy Hooper ________________________________________________________________________________
Subject: GX60/MX20 monthly - require Logbook entry?
Date: Dec 25, 2008
Folks, I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. Am I required to log the software revision and install date in the aircraft logbook? If so, What would the entr look like? Thanks, Ralph RV6A N822AR 0hrs getting ready for refresher training and waiting for the weather...... ________________________________________________________________________________
Date: Dec 25, 2008
I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C174+ Flying Hours So. CA=2C USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu=2C 25 Dec 2008 10:21:38 -0500 > > > Tim=2C > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis=2C the first thin g > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday=2C December 25=2C 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph=2C I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high=2C is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday=2C December 25=2C 2008 8:38 AM > >> To: rv-list(at)matronics.com=3B avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > > >> > >> Folks=2C > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so=2C What would the entr look like? > >> > >> Thanks=2C > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... _________________________________________________________________ Send e-mail anywhere. No map=2C no compass. http://windowslive.com/oneline/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anyw here_122008 ________________________________________________________________________________
Date: Dec 25, 2008
From: Tom & Cathy Ervin <tcervin(at)embarqmail.com>
Subject: Re: GX60/MX20 monthly - require Logbook entry?
=C2-Is something in the aftermarket available for the Garmin 430? Those c ards are also very pricey! =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- Thanks, Tom in Ohio=C2- ----- Original Message ----- From: "RV6 Flyer" <rv6_flyer(at)hotmail.com> Sent: Thursday, December 25, 2008 11:20:14 AM (GMT-0500) America/New_York Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,174+ Flying Hours So. CA, USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu, 25 Dec 2008 10:21:38 -0500 > > > Tim, > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis, the first thing > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday, December 25, 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph, I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high, is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday, December 25, 2008 8:38 AM > >> To: rv-list(at)matronics.com; avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > > >> > >> Folks, > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so, What would the entr look like? > >> > >> Thanks, > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... Send e-mail anywhere. No map, no compass. Get your Hotmail=C2=AE account no ======================= ________________________________________________________________________________
Date: Dec 25, 2008
Gary, Did you have to format the card or was it useable the way you received it? Pete Hudes On Dec 25, 2008, at 8:20 AM, RV6 Flyer wrote: > I purchased my 4 Meg replacement card for my GX60 here: > > http://www.memorydealers.com/4mbcis36serf.html > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 2,174+ Flying Hours So. CA, USA ________________________________________________________________________________
Date: Dec 25, 2008
Hi Gary, I had heard some had problems with the 4MB card size. Has this worked OK for you rather than upgrading to an 8MB card. Thanks Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV6 Flyer Sent: Thursday, December 25, 2008 10:20 AM Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,174+ Flying Hours So. CA, USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu, 25 Dec 2008 10:21:38 -0500 > > > Tim, > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis, the first thing > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday, December 25, 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph, I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high, is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday, December 25, 2008 8:38 AM > >> To: rv-list(at)matronics.com; avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > >> > >> Folks, > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so, What would the entr look like? > >> > >> Thanks, > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... _____ Send e-mail anywhere. No map, no compass. Get your Hotmail <http://windowslive.com/oneline/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anywhe re_122008> R account now. ________________________________________________________________________________
Date: Dec 25, 2008
The card isn=99t so bad, but the update service is costly. Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tom & Cathy Ervin Sent: Thursday, December 25, 2008 10:33 AM Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? Is something in the aftermarket available for the Garmin 430? Those cards are also very pricey! Thanks, Tom in Ohio ----- Original Message ----- From: "RV6 Flyer" <rv6_flyer(at)hotmail.com> Sent: Thursday, December 25, 2008 11:20:14 AM (GMT-0500) America/New_York Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,174+ Flying Hours So. CA, USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu, 25 Dec 2008 10:21:38 -0500 > > > Tim, > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis, the first thing > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday, December 25, 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph, I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high, is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday, December 25, 2008 8:38 AM > >> To: rv-list(at)matronics.com; avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > >> > >> Folks, > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so, What would the entr look like? > >> > >> Thanks, > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... _____ Send e-mail anywhere. No map, no compass. Get your Hotmail=C2=AE account now. <http://windowslive.com/oneline/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_a nywhere_122008> www.matronics.com/contribution" target=_blank>http://www.matronics.com/contribution t" target=_blank>http://www.matronics.com/Navigator?RV-List ; http://forums.matronics.com ============ ________________________________________________________________________________
Date: Dec 25, 2008
Plug it into the Jeppsen Skybound programmer and program it off the interne t. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C174+ Flying Hours So. CA=2C USA > From: phudes(at)ix.netcom.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu=2C 25 Dec 2008 08:42:00 -0800 > To: rv-list(at)matronics.com > > > Gary=2C > > Did you have to format the card or was it useable the way you > received it? > > Pete Hudes > > On Dec 25=2C 2008=2C at 8:20 AM=2C RV6 Flyer wrote: > > > I purchased my 4 Meg replacement card for my GX60 here: > > > > http://www.memorydealers.com/4mbcis36serf.html > > > > Gary A. Sobek > > "My Sanity" RV-6 N157GS O-320 Hartzell=2C > > 2=2C174+ Flying Hours So. CA=2C USA > > =========== =========== =========== =========== > > > _________________________________________________________________ Life on your PC is safer=2C easier=2C and more enjoyable with Windows Vista =AE. ________________________________________________________________________________
Date: Dec 25, 2008
Have not heard of anyone having problems with the 4 Meg cards. I know of ab out 6 that have gone with cards from the link I posted with NO reported pro blems. I got the link and then card from this list years ago when the issu e of 2 Meg cards being too small first came up. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C174+ Flying Hours So. CA=2C USA From: n616tb(at)btsapps.com Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? Date: Thu=2C 25 Dec 2008 10:49:02 -0600 Hi Gary=2C I had heard some had problems with the 4MB card size. Has this worked OK for you rather than upgrading to an 8MB card. Thanks Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.c om] On Behalf Of RV6 Flyer Sent: Thursday=2C December 25=2C 2008 10:20 AM Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C174+ Flying Hours So. CA=2C USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu=2C 25 Dec 2008 10:21:38 -0500 > > > Tim=2C > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis=2C the first thin g > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday=2C December 25=2C 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph=2C I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high=2C is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday=2C December 25=2C 2008 8:38 AM > >> To: rv-list(at)matronics.com=3B avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > >> > >> Folks=2C > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so=2C What would the entr look like? > >> > >> Thanks=2C > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... Send e-mail anywhere. No map=2C no compass. Get your Hotmail=AE account now. http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?R V-Listhttp://forums.matronics.com _________________________________________________________________ Send e-mail anywhere. No map=2C no compass. http://windowslive.com/oneline/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anyw here_122008 ________________________________________________________________________________
Date: Dec 25, 2008
Hmmm. the Jeppesen site shows 2MB, 4MB, or 8MB PCMCIA memory card for the GX60, but the MX20 is only listed as Compact Flash (approved style only) I only find a 32MB and up in the PCMCIA ATA style. The link Gary provided shows a 4MB Compact Flash that would work in the MX20 and they also have an 8MB Cisco approved style for 44.00 Gary do you have an MX20? Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Thursday, December 25, 2008 10:49 AM Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? Hi Gary, I had heard some had problems with the 4MB card size. Has this worked OK for you rather than upgrading to an 8MB card. Thanks Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV6 Flyer Sent: Thursday, December 25, 2008 10:20 AM Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,174+ Flying Hours So. CA, USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu, 25 Dec 2008 10:21:38 -0500 > > > Tim, > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis, the first thing > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday, December 25, 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph, I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high, is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday, December 25, 2008 8:38 AM > >> To: rv-list(at)matronics.com; avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > >> > >> Folks, > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so, What would the entr look like? > >> > >> Thanks, > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... _____ Send e-mail anywhere. No map, no compass. Get your Hotmail <http://windowslive.com/oneline/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anywhe re_122008> R account now. http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV-List http://forums.matronics.com ________________________________________________________________________________
Date: Dec 25, 2008
That display on the unit does not meet the requirements of Part 43. You need a record that meets 43.9 if you want the unit legal for IFR. Randy Hooper wrote: > No log requirement. The current data base will be indicated on your unit. > > Randy Hooper > > *===================================== > * ________________________________________________________________________________
Date: Dec 25, 2008
Kelly McMullen wrote: > > That display on the unit does not meet the requirements of Part 43. You > need a record that meets 43.9 if you want the unit legal for IFR. Is 43.9 applicable to aircraft with an experimental airworthiness certificate? Sam Buchanan > > Randy Hooper wrote: >> No log requirement. The current data base will be indicated on your unit. >> >> Randy Hooper >> ________________________________________________________________________________
Date: Dec 25, 2008
For items that have to meet a TSO, like ELTs and IFR GPSs yes. Sam Buchanan wrote: > > Kelly McMullen wrote: >> >> That display on the unit does not meet the requirements of Part 43. >> You need a record that meets 43.9 if you want the unit legal for IFR. > > > Is 43.9 applicable to aircraft with an experimental airworthiness > certificate? > > Sam Buchanan > > >> >> Randy Hooper wrote: >>> No log requirement. The current data base will be indicated on your >>> unit. >>> >>> Randy Hooper >>> > > ________________________________________________________________________________
Date: Dec 25, 2008
Negative on the MX20. Only the GX60. The SL30 does not use a data card. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C174+ Flying Hours So. CA=2C USA From: n616tb(at)btsapps.com Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? Date: Thu=2C 25 Dec 2008 11:13:25 -0600 Hmmm=85 the Jeppesen site shows 2MB=2C 4MB=2C or 8MB PCMCIA memory card for the GX60=2C but the MX20 is only listed as Compact Flash (approved styl e only) I only find a 32MB and up in the PCMCIA ATA style. The link Gary provided shows a 4MB Compact Flash that would work in the MX20 and they als o have an 8MB Cisco approved style for 44.00 Gary do you have an MX20? Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.c om] On Behalf Of Tim Bryan Sent: Thursday=2C December 25=2C 2008 10:49 AM Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? Hi Gary=2C I had heard some had problems with the 4MB card size. Has this worked OK for you rather than upgrading to an 8MB card. Thanks Tim Bryan RV-6 Flying N616TB over 120 hours now From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV6 Flyer Sent: Thursday=2C December 25=2C 2008 10:20 AM Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? I purchased my 4 Meg replacement card for my GX60 here: http://www.memorydealers.com/4mbcis36serf.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C174+ Flying Hours So. CA=2C USA > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: Re: RV-List: GX60/MX20 monthly - require Logbook entry? > Date: Thu=2C 25 Dec 2008 10:21:38 -0500 > > > Tim=2C > > The cost is still astronomical! The only reason I'm doing it is I'm > planning to get my IFR training and ticket in my 6A. > If you decide to start updating them on a regular basis=2C the first thin g > you'll need is a new 4MB flash card for the GX60 - don't get it from > Garmin - they want a mint.....I'll dig out where I got mine and post it > here. > > Ralph > > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Thursday=2C December 25=2C 2008 10:12 AM > Subject: RE: RV-List: GX60/MX20 monthly - require Logbook entry? > > > > > > Ralph=2C I also have a GX60 & MX20 but have not updated them for over 2 > > years. > > When I last checked the cost was pretty high=2C is this better now? > > > > Tim Bryan > > RV-6 Flying > > N616TB over 120 hours now > > > >> -----Original Message----- > >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > >> server(at)matronics.com] On Behalf Of Ralph E. Capen > >> Sent: Thursday=2C December 25=2C 2008 8:38 AM > >> To: rv-list(at)matronics.com=3B avionics-list(at)matronics.com > >> Subject: RV-List: GX60/MX20 monthly - require Logbook entry? > >> > >> > >> Folks=2C > >> > >> I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. > >> Am I > >> required to log the software revision and install date in the aircraft > >> logbook? If so=2C What would the entr look like? > >> > >> Thanks=2C > >> Ralph > >> RV6A N822AR 0hrs getting ready for refresher training and waiting for > >> the > >> weather...... Send e-mail anywhere. No map=2C no compass. Get your Hotmail=AE account now. http://www.matronics.com/contribution http://www.matronics.com/Navigator ?RV-List http://forums.matronics.com http://www.matronics.com/contributio nhttp://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.com _________________________________________________________________ Send e-mail faster without improving your typing skills. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed _122008 ________________________________________________________________________________
Date: Dec 25, 2008
Dwight, When I built my RV8 .IO360AlB6 ten years ago and converted to IO390AlB6 5 years ago, I experienced the same problems you are encountering. Van supplied the Positeck oil cooler and suggested firewall mounting. This was a disaster. No matter what I did, it overheated immediately. I live in Wisconsin where it is cold. I then tried another popular cooler and mounted it on the back of cyl 4. It worked better, but still hot. After talking to friends in the race group, I found that they had all been there and done that to no avail. The solution is a Niagara/Harrison (now called Niagara) 10 row cooler mounted on the back of Cyl 4 as high as possible and tilted down towards the cowling outlet as much as possible. Approx 30 to 45 degrees. The reason for the tilt is that when the outflow is directed down towards the cowl outlet at the bottom of the cowl, it reduces the back pressure and turbulance that is induced by directing the flow back to the firewall and then down and out. Depending on your engine installation, you will be able to obtain between 30 and 45 degrees down tilt before the engine mount interfers with the oil cooler. Good luck. If you want to discuss this, do not email me, as I do not always monitor the internet. Call me @ 920 619 6968 cell anytime, central time until 1-1 2009, eastern time after, I will be in Spruce Creek Airpark in Florida January thru April 2009. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "Dwight Frye" <dwight(at)openweave.org> Sent: Thursday, December 18, 2008 4:10 PM Subject: RV-List: Oil Cooler Selection > > I am building an RV-7, and am installing the 180HP XP-360 engine with > an Airflow Performance FI system. I got the stock/standard oil cooler > in my firewall-forward package (Van's part "EA OIL COOLER II"). > > Reading comments from others my impression is that the -7s have a > tendency to run hot. I'm curious as to the impression other on the list > have about the best oil cooler to run with the setup I intend to install. > Right NOW is the time for me to make a decision, as I'm just starting > to do some baffle work. > > Clearly, if I stick with the existing cooler I can baffle-mount it, > but if I switch to the larger Stewart/Warner style ol cooler (Van's > part "EA OIL COOLER 20006A") I'll need to firewall mount the cooler > and the baffle behind the #4 cylinder will need a fitting for four > inch SCAT hose. > > So ... whats the collected wisdom on this issue, folks? Chime in if > you have experiences one way or the other. And ... thanks! > > -- Dwight Frye > > > ________________________________________________________________________________
Subject: Electroair ignition
Date: Dec 28, 2008
Greetings: I have an HIO-360-B1A installed on an RV6 with dual Electroair igns. This is a recent "upgrade" from a '90s Electroair version that worked beautifully... well, until it didn't. Anyway, the new version's magnetic timing sensors are apparently more sensitive to some ill-defined variation that Electroair tells me is causing the controller to "reset" -- meaning the ignition shuts off for some fraction of a second. Not noticeable above 900 RPM or so... other than I know it's there. Below 900 RPM there is a noticeable drop and much below that with just the single ignition selected the engine will quit completely. This is only on one side -- the other works as advertised. My local A&P has looked over the mag drive gears and finds absolutely nothing wrong. So Electroair is telling me nothing's wrong with the ignition and my A&P is telling me nothing's wrong with engine... but I still have a problem. Anybody out there with a similiar experience? Or experience with the "modern" version of Electroair? Thanks, Dennis Virginia Beach, VA ________________________________________________________________________________
Date: Dec 28, 2008
Subject: Re: Electroair ignition
Dennis, First off I take you have one of the purple units now. Did the pickups change? Do you have the crank trigger or the magneto hole housing? What gap are you running on the pickups? What size of pickups, 3/8" or 1/2"? What was wrong with your original unit? Regards, Bob Japundza RV-6 flying F1 under const. On Sun, Dec 28, 2008 at 6:14 PM, Dennis Holbrook wrote: > Greetings: > > I have an HIO-360-B1A installed on an RV6 with dual Electroair igns. This > is a recent "upgrade" from a '90s Electroair version that worked > beautifully... well, until it didn't. Anyway, the new version's magnetic > timing sensors are apparently more sensitive to some ill-defined variation > that Electroair tells me is causing the controller to "reset" -- meaning the > ignition shuts off for some fraction of a second. Not noticeable above 900 > RPM or so... other than I know it's there. Below 900 RPM there is a > noticeable drop and much below that with just the single ignition selected > the engine will quit completely. This is only on one side -- the other > works as advertised. My local A&P has looked over the mag drive gears and > finds absolutely nothing wrong. So Electroair is telling me nothing's wrong > with the ignition and my A&P is telling me nothing's wrong with engine... > but I still have a problem. > > Anybody out there with a similiar experience? Or experience with the > "modern" version of Electroair? > > Thanks, Dennis > Virginia Beach, VA > > * > > ________________________________________________________________________________
Date: Dec 28, 2008
electroair works flawless, thanks to jeff 1st class opinion cuz?i,?know iv used one. m n m -----Original Message----- From: Bob J. <rocketbob(at)gmail.com> Sent: Sun, 28 Dec 2008 5:30 pm Subject: Re: RV-List: Electroair ignition Dennis, First off I take you have one of the purple units now.? Did the pickups change?? Do you have the crank trigger or the magneto hole housing?? What gap are you running on the pickups?? What size of pickups, 3/8" or 1/2"? What was wrong with your original unit? Regards, Bob Japundza RV-6 flying F1 under const. On Sun, Dec 28, 2008 at 6:14 PM, Dennis Holbrook wrote: Greetings: ? I have an HIO-360-B1A installed on an RV6 with dual Electroair igns.? This is a recent "upgrade" from a '90s Electroair version that worked beautifully... well, until it didn't.? Anyway, the new version's magnetic timing sensors are apparently more sensitive to some ill-defined variation that?Electroair tells me is causing the controller to "reset" -- meaning the ignition shuts off for some fraction of a second.? Not noticeable above 900 RPM or so... other than I?know it's there.? Below 900 RPM there is a noticeable drop and much below that with just the single ignition selected the engine will quit completely.? This is only on one side -- the other works as advertised.? My local A&P has looked over the mag drive gears and finds absolutely nothing wrong.? So Electroair is telling me nothing's wrong with the ignition and my A&P is telling me nothing's wrong with engine... but I still have a problem.? ? Anybody out there with a similiar experience?? Or experience with the "modern" version of Electroair? ? Thanks,? Dennis Virginia Beach, VA ________________________________________________________________________________
Date: Dec 29, 2008
Subject: Can I log PIC time
Folks, I'm getting ready for my first flight in my RV6A. The plane's legal, the pilot's legal, now I want to work on the safe part...I'll be going to Georgia in a couple of weeks to get some refresher time with Pierre. Meanwhile, I'm trying to figure out if I can log PIC time in other pilots' 6/7/8/9...I don't have a tailwheel endorsement?! I know that the most critical times are take-off and landings - I want to practice some stalls, turns, and slowing down for landing etc. Experience is experience and I already have my type sign-off. Thanks, Ralph N822AR @ N06 0 hrs and chomping at the bit...... ________________________________________________________________________________
Subject: Re: Can I log PIC time
Date: Dec 29, 2008
I would say you neeed the tailwheel endorsement to act as and log as PIC. I know you ar anxious to get started but do it right. In the long run there is no significant benefit to packing a few questionable hours in your logbook. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221589#221589 ________________________________________________________________________________
Date: Dec 29, 2008
Short answer is yes, you can log PIC time w/o an endorsement as long as someone else is "acting" as the PIC. 61.31 prohibits you to "act" as PIC in a tailwheel plane without an endorsement. 61.51 allows you to "log" PIC time for that portion of the flight in which you are the sole manipulator of the controls in a plane in which you are rated (i.e. Airplane SEL in this case). I copied the far sections below for reference. CFR Title 14, Part 61.31 excerpt (i) *Additional training required for operating tailwheel airplanes. *(1) > Except as provided in paragraph (i)(2) of this section, no person may act as > pilot in command of a tailwheel airplane unless that person has received and > logged flight training from an authorized instructor in a tailwheel airpl ane > and received an endorsement in the person's logbook from an authorized > instructor who found the person proficient in the operation of a tailwhee l > airplane. The flight training must include at least the following maneuve rs > and procedures: > > (i) Normal and crosswind takeoffs and landings; > > (ii) Wheel landings (unless the manufacturer has recommended against such > landings); and > > (iii) Go-around procedures. > CFR Title 14, Part 61.51 excerpt: > (e) *Logging pilot-in-command flight time. *(1) A sport, recreational, > private, or commercial pilot may log pilot-in-command time only for that > flight time during which that person=97 > > (i) Is the sole manipulator of the controls of an aircraft for which the > pilot is rated or has privileges; > > (ii) Is the sole occupant of the aircraft; or > > (iii) Except for a recreational pilot, is acting as pilot in command of a n > aircraft on which more than one pilot is required under the type > certification of the aircraft or the regulations under which the flight i s > conducted. > On Mon, Dec 29, 2008 at 7:15 AM, Ralph E. Capen wrot e: > > Folks, > > I'm getting ready for my first flight in my RV6A. The plane's legal, the > pilot's legal, now I want to work on the safe part...I'll be going to > Georgia in a couple of weeks to get some refresher time with Pierre. > Meanwhile, I'm trying to figure out if I can log PIC time in other pilot s' > 6/7/8/9...I don't have a tailwheel endorsement?! > > I know that the most critical times are take-off and landings - I want to > practice some stalls, turns, and slowing down for landing etc. > > Experience is experience and I already have my type sign-off. > > Thanks, > Ralph > N822AR @ N06 0 hrs and chomping at the bit...... > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Dec 29, 2008
Milt said what I was thinking.....I wasn't planning to do this instead....I'm flying with Pierre regardless. I already have my sign-off for the 6A - just not a tailwheel - which I probably should get regardless/eventually too! -----Original Message----- >From: N395V <Bearcat(at)bearcataviation.com> >Sent: Dec 29, 2008 8:35 AM >To: rv-list(at)matronics.com >Subject: RV-List: Re: Can I log PIC time > > >I would say you neeed the tailwheel endorsement to act as and log as PIC. > >I know you ar anxious to get started but do it right. In the long run there is no significant benefit to packing a few questionable hours in your logbook. > >-------- >Milt >2003 F1 Rocket >2006 Radial Rocket > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=221589#221589 > > ________________________________________________________________________________
Date: Dec 29, 2008
Not trying to be argumentative, but you are part right and part wrong. There is a difference between "acting" as PIC and "logging" PIC time as specified by the CFRs. You are correct in that you can not act as PIC, but you are wrong in that you can log PIC time as long as someone else is "acting" PIC. See my other post where I quoted the CFRs. Along the same lines, did you know you can log PIC time without a current medical? Eric On Mon, Dec 29, 2008 at 7:35 AM, N395V wrote: > > I would say you neeed the tailwheel endorsement to act as and log as PIC. > > I know you ar anxious to get started but do it right. In the long run there > is no significant benefit to packing a few questionable hours in your > logbook. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=221589#221589 > > ________________________________________________________________________________
Date: Dec 29, 2008
I asked several pilots a similar question because I have no tail wheel experience much less an endorsement and my recently completed RV-8 awaits! Recently, an ex-instructor friend of mine has been teaching me to fly his Citabria with him "instructing" from the back seat and I have accumulated several hours to date. As far as he is concerned, I can now fly it solo BUT he cannot provide the endorsement because he let his instructor status lapse. Surely, I thought I can log the time legally but quickly found out that one pilot said this, one pilot said that. A current and seasoned instructor could not give me a straight answer either. I finally decided to contact the AOPA which is what I should have done in the first place. No opinions, no hearsay, no urban legends, just the facts. The fact is this....YES you can legally log PIC time without a tail wheel endorsement as long as you are properly rated which means category and class. The AOPA has a full explanation detailing this often asked question at their website. Don't take my word for it or anybody else's. Check into it yourself. Contact the AOPA. When you are done doing the research, feel free to log all the time as PIC as long as you are the sole manipulator of the controls. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221600#221600 ________________________________________________________________________________
Date: Dec 29, 2008
> Along the same lines, did you know you can log PIC time without a > current medical? > > That is true, same as I can instruct without a current medical as long as the pilot is qualified to act as PIC. There are even some instructors that think you need a 2nd class medical to instruct, which you don't. You can instruct without a medical or only a 3rd class depending on the students qualifications. FAA in their wisdom has determined that we as flight instructors are not being paid as pilots but as teachers. Little OT but interesting. ________________________________________________________________________________
Date: Dec 29, 2008
Subject: RV-6 / 6a kits for sale
RV-6 / 6a kits for sale. Empennage: Complete except for fiberglass tips. Includes electric elevator trim kit. All parts are alodined and primed with Marhyde primer. Wings & Phlogiston Spar: Both skeletons fully assembled. Top skins riveted. Both tanks are complete and sealed. Flaps and ailerons complete, but not fitted. Includes electric aileron trim kit. All parts are alodined and primed with Deft epoxy primer (Mil-P-23377G). Both kits are the pre-punched versions purchased in 1997 & 1998 by myself. Construction is excellent. Preview plans and Orndorff videos are included for both kits. Detailed photos are available upon request. Must sell. The first $3750 takes it all. Buyer arranges transportation. If all items were purchased separately the price would be more than $6500 for the unassembled kits. Regards, Scott Kuebler Buffalo, NY 716-510-0318- cell scottam65(at)gmail.com ________________________________________________________________________________
Date: Dec 29, 2008
Subject: Fast 200HP RV-4 IFR For Sale $43,500
1989 Van=A2s RV-4=0ALycoming IO-360 200HP=0A10:1 Pistons=0AChromed Cylinder s=0A200 HP Cam=0A1000 TTAF=0A1000 SMOH=0AAnnual due 06/09=0AIFR due 05/10 =0A=0AGood compressions, regularly flown=0A=0AProp:=0AClaus Savier made woo d/fiberglass speed prop, Fixed Pitch=0AOverhauled by Claus 2006=0A=0APaint: =0AImron sunburst style, Red, Orange, Yellow Condition is 7-8, but there=0A have been added parts and replacements that require repainting. New=0Arudde r, gear leg fairings, canopy fairing repair, cowl modification,=0Aetc.=0A =0AAvionics:=0AGarmin SL30 NAV/COMM w/GS=0AGarmin GPS396 with Air Gizmos Pa nel Dock=0AXM Radio=0AXM Weather=0AKing KY197 Comm=0AGarmin GTX 327 Transpo nder=0APS Engineering PM8000 Intercom with Marker Beacon=0AGarmin MD200-306 VOR/LOC/GS=0ATrio Avionics EZPilot=0AEDO Vacuum Gyros=0ARocky Mountain Mic roEncoder which provides:=0AAirspeed=0AAltimeter=0AOAT=0AVertical Speed Ind icator=0APressure Altitude/Density Altitude=0A=0AElectronics International UBG-16 engine monitor which provides:=0ACHT all cylinders=0AEGT all cylinde rs=0AVolts=0AAmps=0AOil Temp=0AOil Pressure=0AData Recording=0AElectronics International FP-5L Fuel Flow/Totalizer=0AG-Meter=0AElectric Flaps=0ABell T ailwheel=0AFiberglass gear fairings=0AWing light (left side)=0AWingtip Posi tion/Strobe=0ATail Strobe=0APanel Lighting (Electroluminescent instrument l ights)=0AHeater=0ARear seat control stick (removable)=0ADJM Manufacturing T hrottle Quadrant=0AManual Trim=0A=0A=0ANow, the squaks..I=A2ve been doing a lot of modifications over the last 24 months. =0AA new rudder was built du e to trailing edge cracks on old Van=A2s design.=0ANew rudder is new design with thicker skin. Needs paint.=0A=0ASkybolt fasteners put on aft edge of top cowl to replace hinge.=0AAdjustment and minor fiberglass work needed. C owl needs paint in this=0Aarea.=0A=0ARebuilt front canopy fairing due to ai r leaking in cockpit Needs paint and minor finishing.=0A=0AInstalled rear seat airvent in fuselage. Needs paint in this area=0A=0AInstalled fibergla ss gear leg fairings. Needs paint and minor finish work.=0A=0AGyros need overhaul from aerobatics. IFR not possible for obvious=0Areasons until over hauled. Pitot static is fine and recently certified.=0A=0AMy plan was to fi nish all these modifications and strip and repaint the=0Aairplane. The exis ting paint is fine, but due to all of the=0Amodifications, if a new paint s cheme is desired, it would be a good=0Atime to do it, instead of painting a ll the areas that need assistance.=0A=0A=0AThe airplane flies wonderful. Is very fast (170 kt cruise all day long)=0ASomeone with desire to customize the cosmetics will have a fantastic=0Aairplane. Selling due to military dep loyment and do not want to store,=0Ainsure, maintain, etc while deployed. =0A=0AI paid $55k for this airplane before the IFR panel, and other mods=0A totaling approximately $20K. Will sell a $75k RV-4 for $43,500 since=0Ather e are some minor cosmetic work and paint needed.=0A=0AAdditional pics at ww w.mykitlog.com/pbesing Will post more pics very soon.=0A=0APaul Besing=0A48 0.236.2786=0Apbesing at gmail dot com=0A__________________=0APaul Besing=0A RV-4 N73DD=0Awww.mykitlog.com/pbesing =0A=0A=0A ________________________________________________________________________________
Date: Dec 30, 2008
No, you are misreading the FARs you quoted. No where does it say you have to have an endorsement to "log" PIC, only to "act as PIC". It states you can log the time if you are the sole manipulator of the controls. Quoting the same 61.51 you included: e) /Logging pilot-in-command flight time. /(1) A sport, recreational, private, or commercial pilot may log pilot-in-command time only for that flight time during which that person (i) Is the sole manipulator of the controls of an aircraft for which the pilot is rated or has privileges; Being rated is single engine land airplane, not tailwheel endorsed. Some of us are old enough to not have any of that endorsement junk, being "grandfathered". Eric Ekberg wrote: > Not trying to be argumentative, but you are part right and part wrong. > There is a difference between "acting" as PIC and "logging" PIC time > as specified by the CFRs. You are correct in that you can not act as > PIC, but you are wrong in that you can log PIC time as long as someone > else is "acting" PIC. See my other post where I quoted the CFRs. Along > the same lines, did you know you can log PIC time without a current > medical? > > Eric > > On Mon, Dec 29, 2008 at 7:35 AM, N395V > wrote: > > > > > I would say you neeed the tailwheel endorsement to act as and log > as PIC. > > I know you ar anxious to get started but do it right. In the long > run there is no significant benefit to packing a few questionable > hours in your logbook. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=221589#221589 > > > * > > * ________________________________________________________________________________
Date: Dec 30, 2008
Ummm...that's exactly what I said?? On Tue, Dec 30, 2008 at 7:50 AM, Kelly McMullen wrote : > > No, you are misreading the FARs you quoted. No where does it say you have > to have an endorsement to "log" PIC, only to "act as PIC". It states you can > log the time if you are the sole manipulator of the controls. Quoting the > same 61.51 you included: > > e) /Logging pilot-in-command flight time. /(1) A sport, recreational, > private, or commercial pilot may log pilot-in-command time only for that > flight time during which that person=97 > > (i) Is the sole manipulator of the controls of an aircraft for which the > pilot is rated or has privileges; > > Being rated is single engine land airplane, not tailwheel endorsed. Some of > us are old enough to not have any of that endorsement junk, being > "grandfathered". > > > Eric Ekberg wrote: > >> Not trying to be argumentative, but you are part right and part wrong. >> There is a difference between "acting" as PIC and "logging" PIC time as >> specified by the CFRs. You are correct in that you can not act as PIC, b ut >> you are wrong in that you can log PIC time as long as someone else is >> "acting" PIC. See my other post where I quoted the CFRs. Along the same >> lines, did you know you can log PIC time without a current medical? >> >> Eric >> >> On Mon, Dec 29, 2008 at 7:35 AM, N395V > Bearcat(at)bearcataviation.com>> wrote: >> >> > >> >> I would say you neeed the tailwheel endorsement to act as and log >> as PIC. >> >> I know you ar anxious to get started but do it right. In the long >> run there is no significant benefit to packing a few questionable >> hours in your logbook. >> >> -------- >> Milt >> 2003 F1 Rocket >> 2006 Radial Rocket >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=221589#221589 >> >> >> >> >> >> >> >> >> >> >> >> * >> >> * >> > > =========== =========== =========== =========== > > ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Date: Dec 30, 2008
How about this, "you are rated for a single engine land airplane, however, your endorsement to log time needs to be for a tailwheel on take off and landing." You can log the time in the air as PIC, but not the time for landings and/or takeoffs, because you don't have the endorsement for tailwheel, consequently, you need to have a rated and endorsed pilot with you. Plus, your insurance will not cover you for landings or takeoffs and you need to do that to get up and down with your single engine aircraft! I'm confused, how about you. In the original post, the instructor wasn't certified, so he couldn't give the pilot an endorsement. I think the pilot knows how to fly a tailwheel aircraft and he should go put in a few more hours with someone who is certified and can give him the endorsement. Just my two cents. Jim ----- Original Message ----- From: Eric Ekberg To: rv-list(at)matronics.com Sent: Tuesday, December 30, 2008 9:35 AM Subject: Re: RV-List: Re: Can I log PIC time Ummm...that's exactly what I said?? On Tue, Dec 30, 2008 at 7:50 AM, Kelly McMullen wrote: No, you are misreading the FARs you quoted. No where does it say you have to have an endorsement to "log" PIC, only to "act as PIC". It states you can log the time if you are the sole manipulator of the controls. Quoting the same 61.51 you included: e) /Logging pilot-in-command flight time. /(1) A sport, recreational, private, or commercial pilot may log pilot-in-command time only for that flight time during which that person=97 (i) Is the sole manipulator of the controls of an aircraft for which the pilot is rated or has privileges; Being rated is single engine land airplane, not tailwheel endorsed. Some of us are old enough to not have any of that endorsement junk, being "grandfathered". Eric Ekberg wrote: Not trying to be argumentative, but you are part right and part wrong. There is a difference between "acting" as PIC and "logging" PIC time as specified by the CFRs. You are correct in that you can not act as PIC, but you are wrong in that you can log PIC time as long as someone else is "acting" PIC. See my other post where I quoted the CFRs. Along the same lines, did you know you can log PIC time without a current medical? Eric On Mon, Dec 29, 2008 at 7:35 AM, N395V > wrote: > I would say you neeed the tailwheel endorsement to act as and log as PIC. I know you ar anxious to get started but do it right. In the long run there is no significant benefit to packing a few questionable hours in your logbook. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221589#221589 * * ========== t="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== target="_blank">http://www.matronics.com/Navigator?RV-List ========== MS - k">http://forums.matronics.com ========== ------------------------------------------------------------------------- ----- Checked by AVG. 12/29/2008 10:48 AM ________________________________________________________________________________
Date: Dec 30, 2008
I read your post to say the exact opposite. So perhaps I misunderstood what you thought you were saying? ;-) Eric Ekberg wrote: > Ummm...that's exactly what I said?? > > On Tue, Dec 30, 2008 at 7:50 AM, Kelly McMullen > wrote: > > > > > No, you are misreading the FARs you quoted. No where does it say > you have to have an endorsement to "log" PIC, only to "act as > PIC". It states you can log the time if you are the sole > manipulator of the controls. Quoting the same 61.51 you included: > > e) /Logging pilot-in-command flight time. /(1) A sport, > recreational, private, or commercial pilot may log > pilot-in-command time only for that flight time during which that > person > > (i) Is the sole manipulator of the controls of an aircraft for > which the pilot is rated or has privileges; > > Being rated is single engine land airplane, not tailwheel > endorsed. Some of us are old enough to not have any of that > endorsement junk, being "grandfathered". > > > Eric Ekberg wrote: > > Not trying to be argumentative, but you are part right and > part wrong. There is a difference between "acting" as PIC and > "logging" PIC time as specified by the CFRs. You are correct > in that you can not act as PIC, but you are wrong in that you > can log PIC time as long as someone else is "acting" PIC. See > my other post where I quoted the CFRs. Along the same lines, > did you know you can log PIC time without a current medical? > > Eric > > On Mon, Dec 29, 2008 at 7:35 AM, N395V > > >> wrote: > > > >> > > I would say you neeed the tailwheel endorsement to act as > and log > as PIC. > > I know you ar anxious to get started but do it right. In > the long > run there is no significant benefit to packing a few > questionable > hours in your logbook. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=221589#221589 > > > * > > * > > > ========== > > t="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > target="_blank">http://www.matronics.com/Navigator?RV-List > ========== > MS - > k">http://forums.matronics.com > ========== > > > * > > * ________________________________________________________________________________
Date: Dec 30, 2008
I think relative to this issue the best advice so far is Rick's in the form of "check into it yourself" then decide. After looking over the FARs, definitions and AOPA interpretations I am convinced that the nebulosity of the FARs allow one to distinguish between "acting as PIC" and "logging PIC time" although this is illogical, to me, I am also convinced you cannot be successfully violated by the FAA for logging time as PIC based solely on being the sole manipulator of the controls. I think, though, one must consider the purposes for which they are logging the flight time and the benefits and risks thereof. I currently log flight time only for insurance and currency purposes and because I believe it is required. I am not going to obtain any more ratings and am never going to become an airline pilot so total hours are somewhat irrelevant to me. If you want to become an airline pilot and currently have only a few hundred hours then you may consider every hour possible as precious especially hours of PIC, IMC, ME etc. I have a friend that wanted to be an airline pilot and needed Multi Time. I would let him fly with me in my Twin Commander. He flew from the right seat and for all or some of many flights he was the sole manipulator of the controls. He was a Commercial MEL pilot with an instrument rating and therefore qualified to act as pilot in command of the plane except he never had a high altitude endorsement. >From an insurance standpoint I clearly had to be acting PIC as on every flight but as a "sole manipulator of the controls" he elected to "log PIC time" for those hours he flew the plane. He got an offer to fly a King Air and went through training and received his high altitude endorsement to qualify for insurance. Eventually the day came and he was invited to an American Eagle interview. The high point of his life. It was a group interview by 3 captains. The 1st part of the interview went well for him. They took a break and the Captains examined the candidates log books. After the break they questioned him as to how he could log PIC hours in a pressurised aircraft before he received a high altitude endorsement. They also noted a training certificate for the King Air stapled in his logbook and lack of one for the Twin Commander. One of the capatains suggested he was packing his logbook with "questionable hours". his explanation of the FARs and the various interpretations did not help. His interview ended at that point, he was not invited back. H logged a totlal of 25 hrs in the Commander, and insignificant amount in the overall scheme of things. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221800#221800 ________________________________________________________________________________
Date: Dec 30, 2008
On Tue, 30 Dec 2008, Jim Fogarty at Lakes & Leisure Realty wrote: > In the original post, the instructor wasn't certified, so he couldn't > give the pilot an endorsement. I think the pilot knows how to fly a > tailwheel aircraft and he should go put in a few more hours with > someone who is certified and can give him the endorsement. Just my two > cents. This is what I did when learning to fly the Starduster, flew with other partners in the airplane till I knew what I was doing, then flew with an instructor to get the endorsement. Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 Mounting brake resevior 1/4 Starduster II N23UT flying ________________________________________________________________________________
Subject: Terra 760 com radio rack
Date: Dec 31, 2008
I need a radio rack for a Terra 760 com radio. Anybody know where I can get one? ________________________________________________________________________________
Subject: Re: Terra 760 com radio rack
Date: Dec 31, 2008
Send an e-mail to Bob Setzer ( rsetzer1 @tampabay.rr.com ). I think you may be able talk him out of one. He may have an extra from his EZ. I also forwarded your this e-mail to him. This is the famous "Bondo Bob" No better glass man on the face of the earth :) Sal Lakeland, FL -----Original Message----- From: Ann Wilson <capride(at)aol.com> Sent: Wed, 31 Dec 2008 12:15 pm Subject: RV-List: Terra 760 com radio rack ? I need a radio rack for a Terra 760 com radio. Anybody know where I can get one?? ? ? ? ________________________________________________________________________________
Date: Dec 31, 2008
Hmmm . . . I like the interpretation than despite not having a tailwheel endorsement, signifying in my logbook that I have received sufficient instruction in tailwheel aircraft operation to handle a tailwheel airplane on my own as Pilot-In-Command, that I can fly a tailwheel aircraft and log the time as long as I don't try to take off or land it. So following this wishful interpretation of the FARs, as a single engine pilot I could log time in a Boeing 747 as PIlot-In-Command as long as I fly on only one engine and leave the other three shut down. I could get in over an hour's flight time logged at a 500 foot per minute underpowered loss of altitude descent from 35,000 feet before we hit the ground. Pete Cowper RV8 #81139 Lawyer-Pilots Bar Association member ________________________________________________________________________________
Date: Dec 31, 2008
You are a lawyer and write that? A 747 Is not a single engine aircraft even though you shut the other engines down, You are not rated to fly it. Sent from my iPhone On Dec 31, 2008, at 11:02 AM, pcowper(at)webtv.net (Pete Cowper) wrote: > > Hmmm . . . I like the interpretation than despite not having a > tailwheel > endorsement, signifying in my logbook that I have received sufficient > instruction in tailwheel aircraft operation to handle a tailwheel > airplane on my own as Pilot-In-Command, that I can fly a tailwheel > aircraft and log the time as long as I don't try to take off or land > it. > > So following this wishful interpretation of the FARs, as a single > engine > pilot I could log time in a Boeing 747 as PIlot-In-Command as long > as I > fly on only one engine and leave the other three shut down. I could > get > in over an hour's flight time logged at a 500 foot per minute > underpowered loss of altitude descent from 35,000 feet before we hit > the > ground. > > Pete Cowper > RV8 #81139 > Lawyer-Pilots Bar Association member > > ________________________________________________________________________________
Date: Dec 31, 2008
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Lousy idle
Anyone have a few words of wisdom for me: I'm pulling my hair out over a crappy engine idle that I can't seem to tame. The basic problem is that I'll start the engine and it fires right up and runs at about 700-750 RPM just like the book says it should. But from there, all it seems to want to do is gradually idle slower and slower as the engine warms up until it barely runs (between 450-500 RPM) by the time I've done all my checks and am ready to take the runway for takeoff. The engine is a new Mattituck built TMX-IO360 Lycoming clone with Lightspeed electronic ignition on one side and a magneto on the other. It also has Airflow Performance fuel injection with purge valve, a Sterba wood prop and Mark Landoll's 11 pound steel inertia ring bolted to the flywheel. The configuration is updraft with the AFP fuel controller bolted to the bottom of the sump (like carbureted engines) and uses Van's airbox. I've read the AFP manual and talked to the tech there and adjusted the idle mixture and stop numerous times but I can't seem to stabilize it. When I have the cowling off, I make the adjustments and taxi around a bit to warm up the engine and it seems to be ok. Then I'll put the cowling back on and the symptoms seem to reappear. There isn't anything banging against the cowling that I can see that would be causing trouble so I'm totally stumped! Anyone else having this problem? I'm flying out of a long but narrow strip with trees on three side and no good places to land near the airport. Needless to say it makes me nervous, even though the engine runs strong just off idle and at full power. Thanks. Dean Psiropoulos RV-6A N197DM 4.1 hours ________________________________________________________________________________
Subject: Lousy idle
Date: Dec 31, 2008
Try it without the air filter. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DEAN PSIROPOULOS Sent: Wednesday, December 31, 2008 3:39 PM Subject: RV-List: Lousy idle --> Anyone have a few words of wisdom for me: I'm pulling my hair out over a crappy engine idle that I can't seem to tame. The basic problem is that I'll start the engine and it fires right up and runs at about 700-750 RPM just like the book says it should. But from there, all it seems to want to do is gradually idle slower and slower as the engine warms up until it barely runs (between 450-500 RPM) by the time I've done all my checks and am ready to take the runway for takeoff. The engine is a new Mattituck built TMX-IO360 Lycoming clone with Lightspeed electronic ignition on one side and a magneto on the other. It also has Airflow Performance fuel injection with purge valve, a Sterba wood prop and Mark Landoll's 11 pound steel inertia ring bolted to the flywheel. The configuration is updraft with the AFP fuel controller bolted to the bottom of the sump (like carbureted engines) and uses Van's airbox. I've read the AFP manual and talked to the tech there and adjusted the idle mixture and stop numerous times but I can't seem to stabilize it. When I have the cowling off, I make the adjustments and taxi around a bit to warm up the engine and it seems to be ok. Then I'll put the cowling back on and the symptoms seem to reappear. There isn't anything banging against the cowling that I can see that would be causing trouble so I'm totally stumped! Anyone else having this problem? I'm flying out of a long but narrow strip with trees on three side and no good places to land near the airport. Needless to say it makes me nervous, even though the engine runs strong just off idle and at full power. Thanks. Dean Psiropoulos RV-6A N197DM 4.1 hours ________________________________________________________________________________
Subject: Lousy idle
Date: Dec 31, 2008
Dean=2C It sounds like you have an intake leak. A reason it gets worse with the co wling on is that there is warmer air inside the cowling. Without the cowli ng the surrounding air stays the same temp. May I suggest you get a spray water bottle. With the engine running=2C carefully spray all the intake co nnections and see what happens. If there is an intake leak the engine shou ld stutter. If that does not work give me a call. I think you still have my cell phone number. Also=2C we are flying down to your neck of the woods on january 10th for a week in Orlando at out timeshare. maybe we can get together. Mike Robertson > Date: Wed=2C 31 Dec 2008 15:39:06 -0500> From: dean.psirop oulos(at)verizon.net> Subject: RV-List: Lousy idle> To: rv-list(at)matronics.com> zon.net>> > Anyone have a few words of wisdom for me:> > I'm pulling my hai r out over a crappy engine idle that I can't seem to tame.> The basic probl em is that I'll start the engine and it fires right up and> runs at about 7 00-750 RPM just like the book says it should. But from> there=2C all it see ms to want to do is gradually idle slower and slower as the> engine warms u p until it barely runs (between 450-500 RPM) by the time I've> done all my checks and am ready to take the runway for takeoff. > > > The engine is a n ew Mattituck built TMX-IO360 Lycoming clone with Lightspeed> electronic ign ition on one side and a magneto on the other. It also has> Airflow Performa nce fuel injection with purge valve=2C a Sterba wood prop and> Mark Landoll 's 11 pound steel inertia ring bolted to the flywheel. The> configuration i s updraft with the AFP fuel controller bolted to the bottom> of the sump (l ike carbureted engines) and uses Van's airbox. I've read the> AFP manual an d talked to the tech there and adjusted the idle mixture and> stop numerous times but I can't seem to stabilize it. When I have the> cowling off=2C I make the adjustments and taxi around a bit to warm up the> engine and it se ems to be ok. Then I'll put the cowling back on and the> symptoms seem to r eappear. There isn't anything banging against the cowling> that I can see t hat would be causing trouble so I'm totally stumped!> > Anyone else having this problem? I'm flying out of a long but narrow strip> with trees on thre e side and no good places to land near the airport.> Needless to say it mak es me nervous=2C even though the engine runs strong just> off idle and at f ull power. Thanks.> > Dean Psiropoulos> RV-6A N197DM> 4.1 hours> > > > > > =============> > > _________________________________________________________________ Send e-mail faster without improving your typing skills. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed _122008 ________________________________________________________________________________
Subject: Re: Lousy idle
Date: Dec 31, 2008
Might be safer to leave the engine off, blow shop vacuum cleaner air into the intake, spray soapy water on the intake plumbing and look for bubbles. I have never done this, but it sounds like it might work, pinpoint the leak more precisely, and there is no prop blast and extreme danger of loss of limb or life involved. We have a one-armed mechanic around here who stumbled into a running engine in the service hangar while setting the mag timing. Be careful. -Stormy On Dec 31, 2008, at 5:51 PM, Mike Robertson wrote: > Dean, > > It sounds like you have an intake leak. A reason it gets worse with > the cowling on is that there is warmer air inside the cowling. > Without the cowling the surrounding air stays the same temp. May I > suggest you get a spray water bottle. With the engine running, > carefully spray all the intake connections and see what happens. If > there is an intake leak the engine should stutter. If that does not > work give me a call. I think you still have my cell phone number. > > Also, we are flying down to your neck of the woods on january 10th > for a week in Orlando at out timeshare. maybe we can get together. > > Mike Robertson > > > Date: Wed, 31 Dec 2008 15:39:06 -0500 > > From: dean.psiropoulos(at)verizon.net > > Subject: RV-List: Lousy idle > > To: rv-list(at)matronics.com > > > > > > > Anyone have a few words of wisdom for me: > > > > I'm pulling my hair out over a crappy engine idle that I can't > seem to tame. > > The basic problem is that I'll start the engine and it fires right > up and > > runs at about 700-750 RPM just like the book says it should. But > from > > there, all it seems to want to do is gradually idle slower and > slower as the > > engine warms up until it barely runs (between 450-500 RPM) by the > time I've > > done all my checks and am ready to take the runway for takeoff. > > > > > > The engine is a new Mattituck built TMX-IO360 Lycoming clone with > Lightspeed > > electronic ignition on one side and a magneto on the other. It > also has > > Airflow Performance fuel injection with purge valve, a Sterba wood > prop and > > Mark Landoll's 11 pound steel inertia ring bolted to the flywheel. > The > > configuration is updraft with the AFP fuel controller bolted to > the bottom > > of the sump (like carbureted engines) and uses Van's airbox. I've > read the > > AFP manual and talked to the tech there and adjusted the idle > mixture and > > stop numerous times but I can't seem to stabilize it. When I have > the > > cowling off, I make the adjustments and taxi around a bit to warm > up the > > engine and it seems to be ok. Then I'll put the cowling back on > and the > > symptoms seem to reappear. There isn't anything banging against > the cowling > > that I can see that would be causing trouble so I'm totally stumped! > > > > Anyone else having this problem? I'm flying out of a long but > narrow strip > > with trees on three side and no good places to land near the > airport. > > Needless to say it makes me nervous, even though the engine runs > strong just > > off idle and at full power. Thanks. > > > > Dean Psiropoulos > > RV-6A N197DM > > 4.1 hours > > > &======= > > > > > > > > > Send e-mail faster without improving your typing skills. Get your > Hotmail=AE account. ________________________________________________________________________________
Date: Dec 31, 2008
it is time to get the guages out check the unregulated fuel pressure and the regulated fuel pressure, also check the you don't have an internel leak in the servo. but i would still bet it is an intake leak. spray all of the connections with wd-40 and see if you get an increase in rpm. rick --- On Wed, 12/31/08, DEAN PSIROPOULOS wrote: > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> > Subject: RV-List: Lousy idle > To: rv-list(at)matronics.com > Date: Wednesday, December 31, 2008, 12:39 PM > PSIROPOULOS" > > Anyone have a few words of wisdom for me: > > I'm pulling my hair out over a crappy engine idle that > I can't seem to tame. > The basic problem is that I'll start the engine and it > fires right up and > runs at about 700-750 RPM just like the book says it > should. But from > there, all it seems to want to do is gradually idle slower > and slower as the > engine warms up until it barely runs (between 450-500 RPM) > by the time I've > done all my checks and am ready to take the runway for > takeoff. > > > The engine is a new Mattituck built TMX-IO360 Lycoming > clone with Lightspeed > electronic ignition on one side and a magneto on the other. > It also has > Airflow Performance fuel injection with purge valve, a > Sterba wood prop and > Mark Landoll's 11 pound steel inertia ring bolted to > the flywheel. The > configuration is updraft with the AFP fuel controller > bolted to the bottom > of the sump (like carbureted engines) and uses Van's > airbox. I've read the > AFP manual and talked to the tech there and adjusted the > idle mixture and > stop numerous times but I can't seem to stabilize it. > When I have the > cowling off, I make the adjustments and taxi around a bit > to warm up the > engine and it seems to be ok. Then I'll put the > cowling back on and the > symptoms seem to reappear. There isn't anything > banging against the cowling > that I can see that would be causing trouble so I'm > totally stumped! > > Anyone else having this problem? I'm flying out of a > long but narrow strip > with trees on three side and no good places to land near > the airport. > Needless to say it makes me nervous, even though the engine > runs strong just > off idle and at full power. Thanks. > > Dean Psiropoulos > RV-6A N197DM > 4.1 hours > > > > > ________________________________________________________________________________
Date: Jan 01, 2009
Subject: RV-8 Full Glass Panel...
Dear Listers, The panel on the RV-8 got the first power up today. I interconnected all of the major instrument panel devices to the Vertical Power VP-200 electrical system and powered everything up. In the center screen, you can see Mt Diablo in California. I was playing back a flight from a portable GPS I use in the rental plane. Notice the top of the mountain is RED which means that its above our current altitude (from the playback). The Kenwood is playing a James Bond movie... The Vertical Power VP-200 system is very cool, btw. It is basically an electrical system in a box plus a whole lot more. I highly recommend the system. Makes wiring a snap! Components include: 3ea GRT Horizon I HX EFIS 3D Displays XM Weather Radar module for GRT HXs Vertical Power VP-200 power system Garmin SL-30 Nav/Com Garmin GTX-327 Transponder TruTrak DII VSGV Autopilot Matronics FuelChex DX Kenwood DNX-8120 Entertainment w/ XM and Nav Yahoo! Matt Dralle RV-8 #82880 N998RV ________________________________________________________________________________
Date: Jan 01, 2009
Way too cool! You could have a great time just sitting in the cockpit in t he hangar! =0ACan't wait to hear it's time to fly! Keep us posted! =0ARandy "U" =0ARV-7 / N55CU=0A=0A-------------------------------- --------=0A=0AFrom: Matt Dralle <dralle(at)matronics.com>=0ASent: Thu rsday, January 01, 2009 2:38 PM=0ATo: rv-list(at)matronics.com=0ASubject : RV-List: RV-8 Full Glass Panel... =0A=0ADear Listers,=0A=0ATh e panel on the RV-8 got the first power up today. I interconnected all of t he major instrument panel devices to the Vertical Power VP-200 electrical s ystem and powered everything up. In the center screen, you can see Mt Diabl o in California. I was playing back a flight from a portable GPS I use in t he rental plane. Notice the top of the mountain is RED which means that its above our current altitude (from the playback). The Kenwood is playing a J ames Bond movie... =0A=0AThe Vertical Power VP-200 system is very coo l, btw. It is basically an electrical system in a box plus a whole lot more . I highly recommend the system. Makes wiring a snap!=0A=0AComponents include:=0A=0A3ea GRT Horizon I HX EFIS 3D Displays=0AXM Weather Radar module for GRT HXs=0AVertical Power VP-200 power system=0AGarmi n SL-30 Nav/Com=0AGarmin GTX-327 Transponder=0ATruTrak DII VSGV Autop ilot=0AMatronics FuelChex DX=0AKenwood DNX-8120 Entertainment w/ XM a nd Nav=0A=0AYahoo!=0A=0AMatt Dralle=0ARV-8 #82880 N998RV =0A=0A ________________________________________________________________________________
Subject: Re: RV-8 Full Glass Panel...
Date: Jan 01, 2009
I hate to break this to you but I don't think that you will pass your DAR inspection with that much glass. Yu should remove the one to the upper right and send to me. I will send you an altimeter, airspeed and something else to install in that area Ron Lee ________________________________________________________________________________
Date: Jan 01, 2009
Not being familiar with all the glass panel stuff I have two questions. I was looking in the list of equipment for something that said "GPS... something" and I don't see it. Also in the photos I see a glass with buttons that is facing forward into where nobody could see it. What is that one? Tim Bryan RV-6 Flying N616TBover 120 hours now > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Thursday, January 01, 2009 11:57 AM > To: rv-list(at)matronics.com > Subject: RV-List: RV-8 Full Glass Panel... > > > Dear Listers, > > The panel on the RV-8 got the first power up today. I interconnected > all of the major instrument panel devices to the Vertical Power VP-200 > electrical system and powered everything up. In the center screen, you > can see Mt Diablo in California. I was playing back a flight from a > portable GPS I use in the rental plane. Notice the top of the mountain > is RED which means that its above our current altitude (from the > playback). The Kenwood is playing a James Bond movie... > > The Vertical Power VP-200 system is very cool, btw. It is basically an > electrical system in a box plus a whole lot more. I highly recommend > the system. Makes wiring a snap! > > Components include: > > 3ea GRT Horizon I HX EFIS 3D Displays > XM Weather Radar module for GRT HXs > Vertical Power VP-200 power system > Garmin SL-30 Nav/Com > Garmin GTX-327 Transponder > TruTrak DII VSGV Autopilot > Matronics FuelChex DX > Kenwood DNX-8120 Entertainment w/ XM and Nav > > Yahoo! > > Matt Dralle > RV-8 #82880 N998RV ________________________________________________________________________________
Date: Jan 01, 2009
The GPS is an externally mounted unit from GRT and doesn't get mounted in the panel. I haven't received it yet from GRT. Probably should have a secondary, but I'm low on panel space... The forward facing instrument is the GRT EIS4000 engine monitor. All of the display is done through the RS232 link to the HX EFIS displays. I mounted it with the face into the baggage area just in case I had to access the buttons someday, but for normal ops, no access to its front panel is necessary. Matt At 06:50 PM 1/1/2009 Thursday, you wrote: > >Not being familiar with all the glass panel stuff I have two questions. I >was looking in the list of equipment for something that said "GPS... >something" and I don't see it. Also in the photos I see a glass with >buttons that is facing forward into where nobody could see it. What is that >one? > >Tim Bryan >RV-6 Flying >N616TB over 120 hours now > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of Matt Dralle >> Sent: Thursday, January 01, 2009 11:57 AM >> To: rv-list(at)matronics.com >> Subject: RV-List: RV-8 Full Glass Panel... >> >> >> Dear Listers, >> >> The panel on the RV-8 got the first power up today. I interconnected >> all of the major instrument panel devices to the Vertical Power VP-200 >> electrical system and powered everything up. In the center screen, you >> can see Mt Diablo in California. I was playing back a flight from a >> portable GPS I use in the rental plane. Notice the top of the mountain >> is RED which means that its above our current altitude (from the >> playback). The Kenwood is playing a James Bond movie... >> >> The Vertical Power VP-200 system is very cool, btw. It is basically an >> electrical system in a box plus a whole lot more. I highly recommend >> the system. Makes wiring a snap! >> >> Components include: >> >> 3ea GRT Horizon I HX EFIS 3D Displays >> XM Weather Radar module for GRT HXs >> Vertical Power VP-200 power system >> Garmin SL-30 Nav/Com >> Garmin GTX-327 Transponder >> TruTrak DII VSGV Autopilot >> Matronics FuelChex DX >> Kenwood DNX-8120 Entertainment w/ XM and Nav >> >> Yahoo! >> >> Matt Dralle >> RV-8 #82880 N998RV > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jan 01, 2009
That is an amazing use of glass. I don't know your intent ala IFR flying but it would seem that you have ignored GPS approaches. The SL30 will provide VOR and ILS which is a lot but with GPS approaches now outnumbering ILS, did you just decide to forego GPS approaches or is there a certified GPS approach unit that I missed. Ron Lee ________________________________________________________________________________
Date: Jan 02, 2009
Check to make sure all your primer port pipe plugs are tight. Last year I had a Saratoga I worked on with an intake leak, found that a pipe plug was missing on one of the cylinder primer ports. Regards, Bob Japundza RV-6 flying F1 under const. On Wed, Dec 31, 2008 at 10:09 PM, RICHARD MILLER wrote: > > it is time to get the guages out check the unregulated fuel pressure and > the regulated fuel pressure, also check the you don't have an internel leak > in the servo. but i would still bet it is an intake leak. spray all of the > connections with wd-40 and see if you get an increase in rpm. > > rick > > > --- On Wed, 12/31/08, DEAN PSIROPOULOS > wrote: > > > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> > > Subject: RV-List: Lousy idle > > To: rv-list(at)matronics.com > > Date: Wednesday, December 31, 2008, 12:39 PM > > PSIROPOULOS" > > > > Anyone have a few words of wisdom for me: > > > > I'm pulling my hair out over a crappy engine idle that > > I can't seem to tame. > > The basic problem is that I'll start the engine and it > > fires right up and > > runs at about 700-750 RPM just like the book says it > > should. But from > > there, all it seems to want to do is gradually idle slower > > and slower as the > > engine warms up until it barely runs (between 450-500 RPM) > > by the time I've > > done all my checks and am ready to take the runway for > > takeoff. > > > > > > The engine is a new Mattituck built TMX-IO360 Lycoming > > clone with Lightspeed > > electronic ignition on one side and a magneto on the other. > > It also has > > Airflow Performance fuel injection with purge valve, a > > Sterba wood prop and > > Mark Landoll's 11 pound steel inertia ring bolted to > > the flywheel. The > > configuration is updraft with the AFP fuel controller > > bolted to the bottom > > of the sump (like carbureted engines) and uses Van's > > airbox. I've read the > > AFP manual and talked to the tech there and adjusted the > > idle mixture and > > stop numerous times but I can't seem to stabilize it. > > When I have the > > cowling off, I make the adjustments and taxi around a bit > > to warm up the > > engine and it seems to be ok. Then I'll put the > > cowling back on and the > > symptoms seem to reappear. There isn't anything > > banging against the cowling > > that I can see that would be causing trouble so I'm > > totally stumped! > > > > Anyone else having this problem? I'm flying out of a > > long but narrow strip > > with trees on three side and no good places to land near > > the airport. > > Needless to say it makes me nervous, even though the engine > > runs strong just > > off idle and at full power. Thanks. > > > > Dean Psiropoulos > > RV-6A N197DM > > 4.1 hours > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 02, 2009
Good thought Bob, What should be used as a thread sealant? Getting ready to do some engine idling myself this weekend - knowing the engine can idle where it needs to is a very good thing.....especially, short-final.....next weekend it's refresher training. Ralph RV6A N822AR @ N06 0 flight hrs -----Original Message----- >From: "Bob J." <rocketbob(at)gmail.com> >Sent: Jan 2, 2009 10:31 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Lousy idle > >Check to make sure all your primer port pipe plugs are tight. Last year I >had a Saratoga I worked on with an intake leak, found that a pipe plug was >missing on one of the cylinder primer ports. > >Regards, >Bob Japundza >RV-6 flying F1 under const. > >On Wed, Dec 31, 2008 at 10:09 PM, RICHARD MILLER wrote: > >> >> it is time to get the guages out check the unregulated fuel pressure and >> the regulated fuel pressure, also check the you don't have an internel leak >> in the servo. but i would still bet it is an intake leak. spray all of the >> connections with wd-40 and see if you get an increase in rpm. >> >> rick >> >> >> --- On Wed, 12/31/08, DEAN PSIROPOULOS >> wrote: >> >> > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> >> > Subject: RV-List: Lousy idle >> > To: rv-list(at)matronics.com >> > Date: Wednesday, December 31, 2008, 12:39 PM >> > PSIROPOULOS" >> > >> > Anyone have a few words of wisdom for me: >> > >> > I'm pulling my hair out over a crappy engine idle that >> > I can't seem to tame. >> > The basic problem is that I'll start the engine and it >> > fires right up and >> > runs at about 700-750 RPM just like the book says it >> > should. But from >> > there, all it seems to want to do is gradually idle slower >> > and slower as the >> > engine warms up until it barely runs (between 450-500 RPM) >> > by the time I've >> > done all my checks and am ready to take the runway for >> > takeoff. >> > >> > >> > The engine is a new Mattituck built TMX-IO360 Lycoming >> > clone with Lightspeed >> > electronic ignition on one side and a magneto on the other. >> > It also has >> > Airflow Performance fuel injection with purge valve, a >> > Sterba wood prop and >> > Mark Landoll's 11 pound steel inertia ring bolted to >> > the flywheel. The >> > configuration is updraft with the AFP fuel controller >> > bolted to the bottom >> > of the sump (like carbureted engines) and uses Van's >> > airbox. I've read the >> > AFP manual and talked to the tech there and adjusted the >> > idle mixture and >> > stop numerous times but I can't seem to stabilize it. >> > When I have the >> > cowling off, I make the adjustments and taxi around a bit >> > to warm up the >> > engine and it seems to be ok. Then I'll put the >> > cowling back on and the >> > symptoms seem to reappear. There isn't anything >> > banging against the cowling >> > that I can see that would be causing trouble so I'm >> > totally stumped! >> > >> > Anyone else having this problem? I'm flying out of a >> > long but narrow strip >> > with trees on three side and no good places to land near >> > the airport. >> > Needless to say it makes me nervous, even though the engine >> > runs strong just >> > off idle and at full power. Thanks. >> > >> > Dean Psiropoulos >> > RV-6A N197DM >> > 4.1 hours >> > >> > >> > >> > >> > >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Jan 02, 2009
I use Titeseal medium on pipe threads, and I've never had one leak. I even rub gaskets with it. Never, ever, ever put a gasket on dry. You'll appreciate it when a gasket's been on something for a few years and you don't have to scrape it off to remove it. Ralph keep your idling to a minimum. The longer you idle the engine before first flight the longer it will take to get your rings seated. Regards, Bob Japundza A&P RV-6 flying F1 under const. On Fri, Jan 2, 2009 at 11:18 AM, Ralph E. Capen wrote: > > Good thought Bob, > > What should be used as a thread sealant? > > Getting ready to do some engine idling myself this weekend - knowing the > engine can idle where it needs to is a very good thing.....especially, > short-final.....next weekend it's refresher training. > > Ralph > RV6A N822AR @ N06 0 flight hrs > > -----Original Message----- > >From: "Bob J." <rocketbob(at)gmail.com> > >Sent: Jan 2, 2009 10:31 AM > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: Lousy idle > > > >Check to make sure all your primer port pipe plugs are tight. Last year I > >had a Saratoga I worked on with an intake leak, found that a pipe plug was > >missing on one of the cylinder primer ports. > > > >Regards, > >Bob Japundza > >RV-6 flying F1 under const. > > > >On Wed, Dec 31, 2008 at 10:09 PM, RICHARD MILLER >wrote: > > > >> > >> it is time to get the guages out check the unregulated fuel pressure and > >> the regulated fuel pressure, also check the you don't have an internel > leak > >> in the servo. but i would still bet it is an intake leak. spray all of > the > >> connections with wd-40 and see if you get an increase in rpm. > >> > >> rick > >> > >> > >> --- On Wed, 12/31/08, DEAN PSIROPOULOS > >> wrote: > >> > >> > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> > >> > Subject: RV-List: Lousy idle > >> > To: rv-list(at)matronics.com > >> > Date: Wednesday, December 31, 2008, 12:39 PM > >> > PSIROPOULOS" > >> > > >> > Anyone have a few words of wisdom for me: > >> > > >> > I'm pulling my hair out over a crappy engine idle that > >> > I can't seem to tame. > >> > The basic problem is that I'll start the engine and it > >> > fires right up and > >> > runs at about 700-750 RPM just like the book says it > >> > should. But from > >> > there, all it seems to want to do is gradually idle slower > >> > and slower as the > >> > engine warms up until it barely runs (between 450-500 RPM) > >> > by the time I've > >> > done all my checks and am ready to take the runway for > >> > takeoff. > >> > > >> > > >> > The engine is a new Mattituck built TMX-IO360 Lycoming > >> > clone with Lightspeed > >> > electronic ignition on one side and a magneto on the other. > >> > It also has > >> > Airflow Performance fuel injection with purge valve, a > >> > Sterba wood prop and > >> > Mark Landoll's 11 pound steel inertia ring bolted to > >> > the flywheel. The > >> > configuration is updraft with the AFP fuel controller > >> > bolted to the bottom > >> > of the sump (like carbureted engines) and uses Van's > >> > airbox. I've read the > >> > AFP manual and talked to the tech there and adjusted the > >> > idle mixture and > >> > stop numerous times but I can't seem to stabilize it. > >> > When I have the > >> > cowling off, I make the adjustments and taxi around a bit > >> > to warm up the > >> > engine and it seems to be ok. Then I'll put the > >> > cowling back on and the > >> > symptoms seem to reappear. There isn't anything > >> > banging against the cowling > >> > that I can see that would be causing trouble so I'm > >> > totally stumped! > >> > > >> > Anyone else having this problem? I'm flying out of a > >> > long but narrow strip > >> > with trees on three side and no good places to land near > >> > the airport. > >> > Needless to say it makes me nervous, even though the engine > >> > runs strong just > >> > off idle and at full power. Thanks. > >> > > >> > Dean Psiropoulos > >> > RV-6A N197DM > >> > 4.1 hours > >> > > >> > > >> > > >> > > >> > > >> > >> > >> > >> > >> > >> > >> > >> > > ________________________________________________________________________________
Date: Jan 02, 2009
Thanks - good idea - I just want to know that it will idle at an appropriate RPM - 700 or so. -----Original Message----- >From: "Bob J." <rocketbob(at)gmail.com> >Sent: Jan 2, 2009 11:58 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Lousy idle > >I use Titeseal medium on pipe threads, and I've never had one leak. I even >rub gaskets with it. Never, ever, ever put a gasket on dry. You'll >appreciate it when a gasket's been on something for a few years and you >don't have to scrape it off to remove it. > >Ralph keep your idling to a minimum. The longer you idle the engine before >first flight the longer it will take to get your rings seated. > >Regards, >Bob Japundza A&P >RV-6 flying F1 under const. > >On Fri, Jan 2, 2009 at 11:18 AM, Ralph E. Capen wrote: > >> >> Good thought Bob, >> >> What should be used as a thread sealant? >> >> Getting ready to do some engine idling myself this weekend - knowing the >> engine can idle where it needs to is a very good thing.....especially, >> short-final.....next weekend it's refresher training. >> >> Ralph >> RV6A N822AR @ N06 0 flight hrs >> >> -----Original Message----- >> >From: "Bob J." <rocketbob(at)gmail.com> >> >Sent: Jan 2, 2009 10:31 AM >> >To: rv-list(at)matronics.com >> >Subject: Re: RV-List: Lousy idle >> > >> >Check to make sure all your primer port pipe plugs are tight. Last year I >> >had a Saratoga I worked on with an intake leak, found that a pipe plug was >> >missing on one of the cylinder primer ports. >> > >> >Regards, >> >Bob Japundza >> >RV-6 flying F1 under const. >> > >> >On Wed, Dec 31, 2008 at 10:09 PM, RICHARD MILLER > >wrote: >> > >> >> >> >> it is time to get the guages out check the unregulated fuel pressure and >> >> the regulated fuel pressure, also check the you don't have an internel >> leak >> >> in the servo. but i would still bet it is an intake leak. spray all of >> the >> >> connections with wd-40 and see if you get an increase in rpm. >> >> >> >> rick >> >> >> >> >> >> --- On Wed, 12/31/08, DEAN PSIROPOULOS >> >> wrote: >> >> >> >> > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> >> >> > Subject: RV-List: Lousy idle >> >> > To: rv-list(at)matronics.com >> >> > Date: Wednesday, December 31, 2008, 12:39 PM >> >> > PSIROPOULOS" >> >> > >> >> > Anyone have a few words of wisdom for me: >> >> > >> >> > I'm pulling my hair out over a crappy engine idle that >> >> > I can't seem to tame. >> >> > The basic problem is that I'll start the engine and it >> >> > fires right up and >> >> > runs at about 700-750 RPM just like the book says it >> >> > should. But from >> >> > there, all it seems to want to do is gradually idle slower >> >> > and slower as the >> >> > engine warms up until it barely runs (between 450-500 RPM) >> >> > by the time I've >> >> > done all my checks and am ready to take the runway for >> >> > takeoff. >> >> > >> >> > >> >> > The engine is a new Mattituck built TMX-IO360 Lycoming >> >> > clone with Lightspeed >> >> > electronic ignition on one side and a magneto on the other. >> >> > It also has >> >> > Airflow Performance fuel injection with purge valve, a >> >> > Sterba wood prop and >> >> > Mark Landoll's 11 pound steel inertia ring bolted to >> >> > the flywheel. The >> >> > configuration is updraft with the AFP fuel controller >> >> > bolted to the bottom >> >> > of the sump (like carbureted engines) and uses Van's >> >> > airbox. I've read the >> >> > AFP manual and talked to the tech there and adjusted the >> >> > idle mixture and >> >> > stop numerous times but I can't seem to stabilize it. >> >> > When I have the >> >> > cowling off, I make the adjustments and taxi around a bit >> >> > to warm up the >> >> > engine and it seems to be ok. Then I'll put the >> >> > cowling back on and the >> >> > symptoms seem to reappear. There isn't anything >> >> > banging against the cowling >> >> > that I can see that would be causing trouble so I'm >> >> > totally stumped! >> >> > >> >> > Anyone else having this problem? I'm flying out of a >> >> > long but narrow strip >> >> > with trees on three side and no good places to land near >> >> > the airport. >> >> > Needless to say it makes me nervous, even though the engine >> >> > runs strong just >> >> > off idle and at full power. Thanks. >> >> > >> >> > Dean Psiropoulos >> >> > RV-6A N197DM >> >> > 4.1 hours >> >> > >> >> > >> >> > >> >> > >> >> > >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Subject: Garmin 496/XM Weather Data MIA
Date: Jan 02, 2009
I use my Garmin 496 with XM weather several timss per week. I was able to get the XM weather data on 12/31/08. Today (01/02/09), I was not able to retrieve the weather data. I called XM and they made several attempts to 'turn on' my XM receiver to no avail. I then thought that I had a hardware problem with the 496. A call to Garmin tech support was made. The tech that I spoke with indicated that I was about the 20th call that she alone had taken just today. The Garmin tech sayes that this is a XM problem and not a Garmin hardware problem. The tech sayes that it may take a day or two for XM to sort out their problem. (I say that they should go back to the software load that they had on the 31st!!) Dale -------- Dale Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222395#222395 ________________________________________________________________________________
Date: Jan 02, 2009
Subject: GPS Serial Data to Garmin GTX-327 Transponder
Listers, I've tried sending two different sources of NMEA 0183 data at 4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), and configured for "GPS" input. But I don't get anything on the GTX-327 serial input test display. I have been successful at getting AirData Z-format from the GRT EFIS at 9600 baud into either of the GTX-327 serial ports, so the ports are good. The NMEA 0183 data registers correctly on other devices reading it so the GPS serial output seem fine. The GTX-327 just won't seem to see the GPS data for some reason. Am I doing something wrong? Has anyone else tried this successfully? Thanks! Matt Dralle RV-8 #82880 N998RV ________________________________________________________________________________
Date: Jan 02, 2009
This sounds suspiciously like the leap year problem Microsoft had with their Zune. Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rv8builder Sent: Friday, January 02, 2009 10:21 AM Subject: RV-List: Garmin 496/XM Weather Data MIA I use my Garmin 496 with XM weather several timss per week. I was able to get the XM weather data on 12/31/08. Today (01/02/09), I was not able to retrieve the weather data. I called XM and they made several attempts to 'turn on' my XM receiver to no avail. I then thought that I had a hardware problem with the 496. A call to Garmin tech support was made. The tech that I spoke with indicated that I was about the 20th call that she alone had taken just today. The Garmin tech sayes that this is a XM problem and not a Garmin hardware problem. The tech sayes that it may take a day or two for XM to sort out their problem. (I say that they should go back to the software load that they had on the 31st!!) Dale -------- Dale Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222395#222395 ________________________________________________________________________________
Subject: Re: Garmin 496/XM Weather Data MIA
Date: Jan 02, 2009
There was a leap second added. Can't say that has any impact. Ron Lee ----- Original Message ----- From: "Terry Watson" <terry(at)tcwatson.com> Sent: Friday, January 02, 2009 11:47 AM Subject: RE: RV-List: Garmin 496/XM Weather Data MIA > > This sounds suspiciously like the leap year problem Microsoft had with > their > Zune. > > Terry > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rv8builder > Sent: Friday, January 02, 2009 10:21 AM > To: rv-list(at)matronics.com > Subject: RV-List: Garmin 496/XM Weather Data MIA > > > I use my Garmin 496 with XM weather several timss per week. > > I was able to get the XM weather data on 12/31/08. > > Today (01/02/09), I was not able to retrieve the weather data. I called > XM > and they made several attempts to 'turn on' my XM receiver to no avail. > > I then thought that I had a hardware problem with the 496. A call to > Garmin > tech support was made. The tech that I spoke with indicated that I was > about the 20th call that she alone had taken just today. The Garmin tech > sayes that this is a XM problem and not a Garmin hardware problem. > > The tech sayes that it may take a day or two for XM to sort out their > problem. (I say that they should go back to the software load that they > had > on the 31st!!) > > > Dale > > -------- > Dale > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=222395#222395 > > > ________________________________________________________________________________
Date: Jan 02, 2009
Subject: Re: GPS Serial Data to Garmin GTX-327 Transponder
Why would you send GPS data to a Mode A/C transponder? It only transmits a reply with altitude data from encoder. Just wondering if there is some feature to the GTX327 that is unique besides acting as a backup up altimeter and timer? Guess I am clueless about what you are trying to do. Matt Dralle wrote: > > > Listers, > > I've tried sending two different sources of NMEA 0183 data at 4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), and configured for "GPS" input. But I don't get anything on the GTX-327 serial input test display. I have been successful at getting AirData Z-format from the GRT EFIS at 9600 baud into either of the GTX-327 serial ports, so the ports are good. The NMEA 0183 data registers correctly on other devices reading it so the GPS serial output seem fine. The GTX-327 just won't seem to see the GPS data for some reason. > > Am I doing something wrong? Has anyone else tried this successfully? > > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > > > ________________________________________________________________________________
Date: Jan 02, 2009
Because you can have the Txpdr automatically go from STBY into ALT and back to STBY when it has a GPS signal to it...which is what I missed in Matt's first post (Sorry Matt - I thought you were only looking for the AltEnc data, not the GPS data). I don't know as you'll see anything in test mode though, even if it is hooked up right. So, in your setup you should have a line running from the GRT to the Txpdr RS-232 channel for AltEnc data and another line RS-232 line for GPS data....sorry about the missed replay earlier! Cheers, Stein >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kelly McMullen >Sent: Friday, January 02, 2009 3:11 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: GPS Serial Data to Garmin GTX-327 Transponder > > >Why would you send GPS data to a Mode A/C transponder? It only transmits >a reply with altitude data from encoder. Just wondering if there is some >feature to the GTX327 that is unique besides acting as a backup up >altimeter and timer? Guess I am clueless about what you are trying to do. > >Matt Dralle wrote: >> >> >> Listers, >> >> I've tried sending two different sources of NMEA 0183 data at >4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on >both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), >and configured for "GPS" input. But I don't get anything on the >GTX-327 serial input test display. I have been successful at >getting AirData Z-format from the GRT EFIS at 9600 baud into >either of the GTX-327 serial ports, so the ports are good. The >NMEA 0183 data registers correctly on other devices reading it so >the GPS serial output seem fine. The GTX-327 just won't seem to >see the GPS data for some reason. >> >> Am I doing something wrong? Has anyone else tried this successfully? >> >> >> >> Thanks! >> >> Matt Dralle >> RV-8 #82880 N998RV >> >> >> >> >> > > ________________________________________________________________________________
Subject: Tool exchange?
Date: Jan 03, 2009
Hello all, I was wondering if anyone was interested in loaning me their B-crimp open barrel and/or faston/ring terminal crimp tools. I would also be interested in borrowing a swaging tool to crimp the cables supporting my AWI 4-into-1 exhaust. In/around the Twin Cities is preferred but I can also send my FedEx account number for shipping. I would have the swaging tool back within the day and hopefully the pressure of possessing some else's crimpers would be exactly the motivation I need to push through this wiring phase. Thanks, Chris Knauf N707HK
Hello all,
Chris Knauf
N707HK
Date: Jan 02, 2009
Subject: Re: Tool exchange?
cknauf(at)comcast.net wrote: > Hello all, > > I was wondering if anyone was interested in loaning me their B-crimp > open barrel and/or faston/ring terminal crimp tools. I would also be > interested in borrowing a swaging tool to crimp the cables supporting > my AWI 4-into-1 exhaust. In/around the Twin Cities is preferred but > I can also send my FedEx account number for shipping. > > I would have the swaging tool back within the day and hopefully the > pressure of possessing some else's crimpers would be exactly the > motivation I need to push through this wiring phase. > > Thanks, Chris Knauf N707HK These are tools you need in your shop and aren't very expensive. An inexpensive swager is here: http://www.wicksaircraft.com/catalog/product_cat.php/subid=9893/index.html B& C Specialty has a selection of reasonably priced crimpers: http://www.bandc.biz/index.html You will need these tools more than one time. :-) Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Date: Jan 02, 2009
If it only does it with the cowling on could be getting fuel vaporizing in the lines.? -----Original Message----- From: Bob J. <rocketbob(at)gmail.com> Sent: Fri, 2 Jan 2009 9:31 am Subject: Re: RV-List: Lousy idle Check to make sure all your primer port pipe plugs are tight.? Last year I had a Saratoga I worked on with an intake leak, found that a pipe plug was missing on one of the cylinder primer ports.? ? Regards, Bob Japundza RV-6 flying F1 under const. On Wed, Dec 31, 2008 at 10:09 PM, RICHARD MILLER wrote: it is time to get the guages out check the unregulated fuel pressure and the regulated fuel pressure, also check the you don't have an internel leak in the servo. but i would still bet it is an intake leak. spray all of the connections with wd-40 and see if you get an increase in rpm. rick --- On Wed, 12/31/08, DEAN PSIROPOULOS wrote: > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> > Subject: RV-List: Lousy idle > To: rv-list(at)matronics.com > Date: Wednesday, December 31, 2008, 12:39 PM > PSIROPOULOS" > > Anyone have a few words of wisdom for me: > > I'm pulling my hair out over a crappy engine idle that > I can't seem to tame. > The basic problem is that I'll start the engine and it > fires right up and > runs at about 700-750 RPM just like the book says it > should. ?But from > there, all it seems to want to do is gradually idle slower > and slower as the > engine warms up until it barely runs (between 450-500 RPM) > by the time I've > done all my checks and am ready to take the runway for > takeoff. > > > The engine is a new Mattituck built TMX-IO360 Lycoming > clone with Lightspeed > electronic ignition on one side and a magneto on the other. > ?It also has > Airflow Performance fuel injection with purge valve, a > Sterba wood prop and > Mark Landoll's 11 pound steel inertia ring bolted to > the flywheel. ?The > configuration is updraft with the AFP fuel controller > bolted to the bottom > of the sump (like carbureted engines) and uses Van's > airbox. ?I've read the > AFP manual and talked to the tech there and adjusted the > idle mixture and > stop numerous times but I can't seem to stabilize it. > When I have the > cowling off, I make the adjustments and taxi around a bit > to warm up the > engine and it seems to be ok. ?Then I'll put the > cowling back on and the > symptoms seem to reappear. ?There isn't anything > banging against the cowling > that I can see that would be causing trouble so I'm > totally stumped! > > Anyone else having this problem? I'm flying out of a > long but narrow strip > with trees on three side and no good places to land near > the airport. > Needless to say it makes me nervous, even though the engine > runs strong just > off idle and at full power. ?Thanks. > > Dean Psiropoulos > RV-6A N197DM > 4.1 hours > > > > > ________________________________________________________________________________
Date: Jan 02, 2009
If it only idles bad with the cowling on it could be fuel vaporizing in the lines -----Original Message----- From: William Boyd <sportav8r(at)gmail.com> Sent: Wed, 31 Dec 2008 5:48 pm Subject: Re: RV-List: Lousy idle Might be safer to leave the engine off, blow shop vacuum cleaner air into th e intake, spray soapy water on the intake plumbing and look for bubbles. =C2-I have never done this, but it sounds like it might work, pinpoint the leak more precisely, and there is no prop blast and extreme danger of loss of limb or life involved. =C2-We have a one-armed mechanic around here who stumbled into a running engine in the service hangar while setting the mag timing. =C2-Be careful. -Stormy On Dec 31, 2008, at 5:51 PM, Mike Robertson wrote: Dean, =C2- It sounds like you have an intake leak.=C2- A reason it gets worse with th e cowling on is that there is warmer air inside the cowling.=C2- Without t he cowling the surrounding air stays the same temp.=C2- May I suggest you get a spray water bottle.=C2- With the engine running, carefully spray all the intake connections and see what happens.=C2- If there is an intake le ak=C2-the engine=C2-should stutter.=C2- If that does not work give me a call.=C2- I think you still have my cell phone number. =C2- Also, we are flying down to your neck of the woods on=C2-january 10th for a week in Orlando at out timeshare.=C2- maybe we can get together. =C2- Mike Robert son=C2- > Date: Wed, 31 Dec 2008 15:39:06 -0500 > From:=C2-dean.psiropoulos(at)verizon.net > Subject: RV-List: Lousy idle > To:=C2-rv-list(at)matronics.com >=C2- n.net> >=C2- > Anyone have a few words of wisdom for me: >=C2- > I'm pulling my hair out over a crappy engine idle that I can't seem to tam e. > The basic problem is that I'll start the engine and it fires right up and > runs at about 700-750 RPM just like the book says it should. But from > there, all it seems to want to do is gradually idle slower and slower as t he > engine warms up until it barely runs (between 450-500 RPM) by the time I'v e > done all my checks and am ready to take the runway for takeoff.=C2- >=C2- >=C2- > The engine is a new Mattituck built TMX-IO360 Lycoming clone with Lightspe ed > electronic ignition on one side and a magneto on the other. It also has > Airflow Performance fuel injection with purge valve, a Sterba wood prop an d > Mark Landoll's 11 pound steel inertia ring bolted to the flywheel. The > configuration is updraft with the AFP fuel controller bolted to the bottom > of the sump (like carbureted engines) and uses Van's airbox. I've read the > AFP manual and talked to the tech there and adjusted the idle mixture and > stop numerous times but I can't seem to stabilize it. When I have the > cowling off, I make the adjustments and taxi around a bit to warm up the > engine and it seems to be ok. Then I'l l put the cowling back on and the > symptoms seem to reappear. There isn't anything banging against the cowlin g > that I can see that would be causing trouble so I'm totally stumped! >=C2- > Anyone else having this problem? I'm flying out of a long but narrow strip > with trees on three side and no good places to land near the airport. > Needless to say it makes me nervous, even though the engine runs strong ju st > off idle and at full power. Thanks. >=C2- > Dean Psiropoulos > RV-6A N197DM > 4.1 hours >=C2- &======= >=C2- >=C2- >=C2- Send e-mail faster without improving your typing skills.=C2-Get your Hotma il=C2=AE account. http://www.matronics.com/contribution href="http://www.matronics.com/Navi gator?RV-List"http://www.matronics.com/Navigator?RV-List href="http://for ums.matronics.com"http://forums.matronics.com ============= ________________________________________________________________________________
Date: Jan 02, 2009
I have both but am in CA. Let me know if you strike out with "closer by" sources and I can get them off to you if you like. -N1GV (RV-6A, Flying 908hrs, O-360-A1A, C/S, Silicon Valley) In a message dated 1/2/2009 4:04:59 P.M. Pacific Standard Time, cknauf(at)comcast.net writes: I was wondering if anyone was interested in loaning me their B-crimp open barrel and/or faston/ring terminal crimp tools. I would also be interested in borrowing a swaging tool to crimp the cables supporting my AWI 4-into-1 exhaust. In/around the Twin Cities is preferred but I can also send my FedEx account number for shipping. **************New year...new news. Be the first to know what is making ________________________________________________________________________________
Date: Jan 01, 2001
I would suspect an intake leak that gets worse as the engine warms up. Linn DEAN PSIROPOULOS wrote: > > Anyone have a few words of wisdom for me: > > I'm pulling my hair out over a crappy engine idle that I can't seem to tame. > The basic problem is that I'll start the engine and it fires right up and > runs at about 700-750 RPM just like the book says it should. But from > there, all it seems to want to do is gradually idle slower and slower as the > engine warms up until it barely runs (between 450-500 RPM) by the time I've > done all my checks and am ready to take the runway for takeoff. > > > The engine is a new Mattituck built TMX-IO360 Lycoming clone with Lightspeed > electronic ignition on one side and a magneto on the other. It also has > Airflow Performance fuel injection with purge valve, a Sterba wood prop and > Mark Landoll's 11 pound steel inertia ring bolted to the flywheel. The > configuration is updraft with the AFP fuel controller bolted to the bottom > of the sump (like carbureted engines) and uses Van's airbox. I've read the > AFP manual and talked to the tech there and adjusted the idle mixture and > stop numerous times but I can't seem to stabilize it. When I have the > cowling off, I make the adjustments and taxi around a bit to warm up the > engine and it seems to be ok. Then I'll put the cowling back on and the > symptoms seem to reappear. There isn't anything banging against the cowling > that I can see that would be causing trouble so I'm totally stumped! > > Anyone else having this problem? I'm flying out of a long but narrow strip > with trees on three side and no good places to land near the airport. > Needless to say it makes me nervous, even though the engine runs strong just > off idle and at full power. Thanks. > > Dean Psiropoulos > RV-6A N197DM > 4.1 hours > > > ________________________________________________________________________________
Subject: Looking for Ken Beene
Date: Jan 03, 2009
Anyone know how to contact him - or forward this to him to cantact me. I am looking for a PDF copy of the GX60 installation manual - he is listed in the archives as having it at one time.... Ralph Capen ________________________________________________________________________________
Subject: Lousy idle
Date: Jan 03, 2009
I Like it! Much better idea!! Mike R. ngine off=2C blow shop vacuum cleaner air into the intake=2C spray soapy wa ter on the intake plumbing and look for bubbles. I have never done this=2C but it sounds like it might work=2C pinpoint the leak more precisely=2C an d there is no prop blast and extreme danger of loss of limb or life involve d. We have a one-armed mechanic around here who stumbled into a running en gine in the service hangar while setting the mag timing. Be careful. -Stormy On Dec 31=2C 2008=2C at 5:51 PM=2C Mike Robertson wrote: Dean=2C It sounds like you have an intake leak. A reason it gets worse wit h the cowling on is that there is warmer air inside the cowling. Without t he cowling the surrounding air stays the same temp. May I suggest you get a spray water bottle. With the engine running=2C carefully spray all the i ntake connections and see what happens. If there is an intake leak the eng ine should stutter. If that does not work give me a call. I think you sti ll have my cell phone number. Also=2C we are flying down to your neck of th e woods on january 10th for a week in Orlando at out timeshare. maybe we c an get together. Mike Robertson > Date: Wed=2C 31 Dec 2008 15:39:06 -0500> From: dean.psiropoulos(at)verizon.net> Subject: RV-List: Lousy idle> To: rv-li .psiropoulos(at)verizon.net>> > Anyone have a few words of wisdom for me:> > I 'm pulling my hair out over a crappy engine idle that I can't seem to tame. > The basic problem is that I'll start the engine and it fires right up and > runs at about 700-750 RPM just like the book says it should. But from> th ere=2C all it seems to want to do is gradually idle slower and slower as th e> engine warms up until it barely runs (between 450-500 RPM) by the time I 've> done all my checks and am ready to take the runway for takeoff. > > > The engine is a new Mattituck built TMX-IO360 Lycoming clone with Lightspee d> electronic ignition on one side and a magneto on the other. It also has> Airflow Performance fuel injection with purge valve=2C a Sterba wood prop and> Mark Landoll's 11 pound steel inertia ring bolted to the flywheel. The > configuration is updraft with the AFP fuel controller bolted to the botto m> of the sump (like carbureted engines) and uses Van's airbox. I've read t he> AFP manual and talked to the tech there and adjusted the idle mixture a nd> stop numerous times but I can't seem to stabilize it. When I have the> cowling off=2C I make the adjustments and taxi around a bit to warm up the> engine and it seems to be ok. Then I'll put the cowling back on and the> s ymptoms seem to reappear. There isn't anything banging against the cowling> that I can see that would be causing trouble so I'm totally stumped!> > An yone else having this problem? I'm flying out of a long but narrow strip> w ith trees on three side and no good places to land near the airport.> Needl ess to say it makes me nervous=2C even though the engine runs strong just> off idle and at full power. Thanks.> > Dean Psiropoulos> RV-6A N197DM> 4.1 hours> &========> > > Send e-mail faster without improving your typing skills. Get your Hotmail =AE account.http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.co m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________________________ Send e-mail anywhere. No map=2C no compass. http://windowslive.com/oneline/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_anyw here_122008 ________________________________________________________________________________
Date: Jan 03, 2009
Subject: RV-List_Lousy Idle
Thanks all for your inputs: I'll be exploring every avenue that has been mentioned just to be sure (cheap things first then on to more expense). The intake leak seems to be a big "seller" and I'm getting a bit of feedback on wood propellers causing idle problems on the big four cyl Lycomings, especially with fuel injection installed. Wish I'd known this sooner and I would have opted for the Sensenich fixed pitch but it's nice to have all you folks out there with your collective knowledge to get me going in the right direction. If anyone else has some more thoughts please forward them to me so I can check all possibilities. If everything checks out ok and there are no engine related culprits, I've decided I'll take the plunge and order a Sensenich prop. Problem is that it takes several weeks to get one and I don't really want to wait. So...does anyone already have a Sensenich prop and spacer laying around that they won't be using for a few months(for 180 HP Lyc 0-360)? If so maybe I could purchase it from you and have the one I order shipped to you when it's ready. Just thinking ahead. Also, if I go ahead with the metal prop, I'll be selling my 70x82 Sterba wood prop (carved in 2006), spacer, crush plate, Landoll inertia ring and fitted spinner (painted silver) so if anyone wants a wood prop for 0-360 Lyc let me know and we'll work out a price for all or part of the assembly. Thanks. Dean Psiropoulos ________________________________________________________________________________
Subject: Re: RV-List_Lousy Idle
Date: Jan 03, 2009
Why are you changing props for what is most likely a problem in the engine? I have a wood prop on an O-360 and no problems like you are having. I would find a competent mechanic to help first. Ron Lee ----- Original Message ----- From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Sent: Saturday, January 03, 2009 7:49 PM Subject: RV-List: RV-List_Lousy Idle > > > > Thanks all for your inputs: > > I'll be exploring every avenue that has been mentioned just to be sure > (cheap things first then on to more expense). The intake leak seems to be > a > big "seller" and I'm getting a bit of feedback on wood propellers causing > idle problems on the big four cyl Lycomings, especially with fuel > injection > installed. Wish I'd known this sooner and I would have opted for the > Sensenich fixed pitch but it's nice to have all you folks out there with > your collective knowledge to get me going in the right direction. If > anyone > else has some more thoughts please forward them to me so I can check all > possibilities. > > If everything checks out ok and there are no engine related culprits, I've > decided I'll take the plunge and order a Sensenich prop. Problem is that > it > takes several weeks to get one and I don't really want to wait. So...does > anyone already have a Sensenich prop and spacer laying around that they > won't be using for a few months(for 180 HP Lyc 0-360)? If so maybe I > could > purchase it from you and have the one I order shipped to you when it's > ready. Just thinking ahead. Also, if I go ahead with the metal prop, I'll > be selling my 70x82 Sterba wood prop (carved in 2006), spacer, crush > plate, > Landoll inertia ring and fitted spinner (painted silver) so if anyone > wants > a wood prop for 0-360 Lyc let me know and we'll work out a price for all > or > part of the assembly. Thanks. > > Dean Psiropoulos > > > ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Jan 03, 2009
Dean, I don't see how a wood prop could cause idle problems unless you have the speed set too low. What is the idle speed of your engine? If it is below 700 RPM, it might be a factor. KB ----- Original Message ----- From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Sent: Saturday, January 03, 2009 9:49 PM Subject: RV-List: RV-List_Lousy Idle > > > > Thanks all for your inputs: > > I'll be exploring every avenue that has been mentioned just to be sure > (cheap things first then on to more expense). The intake leak seems to be > a > big "seller" and I'm getting a bit of feedback on wood propellers causing > idle problems on the big four cyl Lycomings, especially with fuel > injection > installed. Wish I'd known this sooner and I would have opted for the > Sensenich fixed pitch but it's nice to have all you folks out there with > your collective knowledge to get me going in the right direction. If > anyone > else has some more thoughts please forward them to me so I can check all > possibilities. > > If everything checks out ok and there are no engine related culprits, I've > decided I'll take the plunge and order a Sensenich prop. Problem is that > it > takes several weeks to get one and I don't really want to wait. So...does > anyone already have a Sensenich prop and spacer laying around that they > won't be using for a few months(for 180 HP Lyc 0-360)? If so maybe I > could > purchase it from you and have the one I order shipped to you when it's > ready. Just thinking ahead. Also, if I go ahead with the metal prop, I'll > be selling my 70x82 Sterba wood prop (carved in 2006), spacer, crush > plate, > Landoll inertia ring and fitted spinner (painted silver) so if anyone > wants > a wood prop for 0-360 Lyc let me know and we'll work out a price for all > or > part of the assembly. Thanks. > > Dean Psiropoulos > > > ________________________________________________________________________________
Subject: Double-sided Tape
Date: Jan 04, 2009
The mails regarding using double-sided tape to hold the tab in place when bending refer. However it seems futile to chase Van's hit and miss method when there is a far simpler and quicker method. This worked for me: Take a 3/4" thick plank, trace out the "V" that the tab end makes on the face of the plank, leaving a 2" border on the sides and bottom of the "V" ( the top end of the "V" is flush with the forward end of the tab), cut out this "V", insert the trim tab into the "V" cutout and pinch it in place with the other end of the cutout triangle. Put a clamp across the ends of the plank to hold the tab nice and snugly and bend at will without any slipping. I found a bit of masking tape applied to the surface of the tab prevented any scratches and aided in the clamping. Running a rivet gun along the bend gives it a nice straight even finish. Drill the holes for the rivets with the tab still in the clamped position for accuracy. Hope this helps Trevor Davis RV-7 ________________________________________________________________________________
Date: Jan 04, 2009
Subject: Zaon XRX - mounted
I finally got the XRX mounted and out of my sight-line!! Works great and you don't have that ugly on the top of the panel. Use a RAM mount to mount if off the baggage compartment wall. Has a good view of the sky in all directions and feeds into my new GRT screens. I've finally gotten the web-site updated (had to learn new software)..you can see the photos under the What's New tab on the web-site www.n142ds.com. Oh .. if the web-site doesn't display properly .. I'm still learning! :-) Thanks for all the suggestions from the group. David W. Schaefer RV-6A N142DS "Nerdgasm" TMX-IO360 Dual-LightSpeed Plasma IIIs, Hartzell Blended Airfoil, GRT EFIS www.n142ds.com ________________________________________________________________________________
Date: Jan 05, 2009
I have a 13 pound composite prop (wood overlayed with glass) on my O-360 and it idles just fine. I seriously doubt that your idle problem is prop related. Why add 30 or 40 pounds or more to your airplane if not necessary? Harry Crosby RV-6 N16CX, 535 hours ----- Original Message ----- From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Sent: Saturday, January 3, 2009 6:49:17 PM GMT -08:00 US/Canada Pacific Subject: RV-List: RV-List_Lousy Idle Thanks all for your inputs: I'll be exploring every avenue that has been mentioned just to be sure (cheap things first then on to more expense). The intake leak seems to be a big "seller" and I'm getting a bit of feedback on wood propellers causing idle problems on the big four cyl Lycomings, especially with fuel injection installed. Wish I'd known this sooner and I would have opted for the Sensenich fixed pitch but it's nice to have all you folks out there with your collective knowledge to get me going in the right direction. If anyone else has some more thoughts please forward them to me so I can check all possibilities. If everything checks out ok and there are no engine related culprits, I've decided I'll take the plunge and order a Sensenich prop. Problem is that it takes several weeks to get one and I don't really want to wait. So...does anyone already have a Sensenich prop and spacer laying around that they won't be using for a few months(for 180 HP Lyc 0-360)? If so maybe I could purchase it from you and have the one I order shipped to you when it's ready. Just thinking ahead. Also, if I go ahead with the metal prop, I'll be selling my 70x82 Sterba wood prop (carved in 2006), spacer, crush plate, Landoll inertia ring and fitted spinner (painted silver) so if anyone wants a wood prop for 0-360 Lyc let me know and we'll work out a price for all or part of the assembly. Thanks. Dean Psiropoulos ________________________________________________________________________________
Date: Jan 04, 2009
Dean=2C I don't think it is the prop. I am going to be in Orlando next week. I don't have your number anymore. G ive me a call at (509) 998-1793. Mike Robertson > Date: Sat=2C 3 Jan 2009 21:49:17 -0500> From: dean.psiropoulos(at)verizon.ne t> Subject: RV-List: RV-List_Lousy Idle> To: rv-list(at)matronics.com> > --> R V-List message posted by: "DEAN PSIROPOULOS" > > > Thanks all for your inputs:> > I'll be exploring every avenue that ha s been mentioned just to be sure> (cheap things first then on to more expen se). The intake leak seems to be a> big "seller" and I'm getting a bit of f eedback on wood propellers causing> idle problems on the big four cyl Lycom ings=2C especially with fuel injection> installed. Wish I'd known this soon er and I would have opted for the> Sensenich fixed pitch but it's nice to h ave all you folks out there with> your collective knowledge to get me going in the right direction. If anyone> else has some more thoughts please forw ard them to me so I can check all> possibilities.> > If everything checks o ut ok and there are no engine related culprits=2C I've> decided I'll take t he plunge and order a Sensenich prop. Problem is that it> takes several wee ks to get one and I don't really want to wait. So...does> anyone already ha ve a Sensenich prop and spacer laying around that they> won't be using for a few months(for 180 HP Lyc 0-360)? If so maybe I could> purchase it from y ou and have the one I order shipped to you when it's> ready. Just thinking ahead. Also=2C if I go ahead with the metal prop=2C I'll> be selling my 70x 82 Sterba wood prop (carved in 2006)=2C spacer=2C crush plate=2C> Landoll i nertia ring and fitted spinner (painted silver) so if anyone wants> a _________________________________________________________________ Life on your PC is safer=2C easier=2C and more enjoyable with Windows Vista =AE. ________________________________________________________________________________
Date: Jan 06, 2009
Subject: Engine warning parameters
Folks, I am configuring my engine monitor system (AFS3400EM) in preparation for first flight. The engine configuration is as follows: IO360B1F6 with 9.2:1 pistons, AFP injection, LASAR ignition, Vetterman dual crossover exhaust system with heaterboxes/mufflers, and MT 3 blade CS prop (MTV12B 183-59) within a SamJames cowl and engine cooling plenum. The oil cooler is behind the #4 (left rear) cylinder and the cabin heat take-off is behind the #3 (right rear) cylinder - the cabin heat take-off will need to constantly flow air to cool the mufflers/heaterboxes per Vetterman. Manifold pressure port is on #2 (left front) cylinder. CHT sensors are mounted on the underside of the cylinder heads in the provided threaded ports. EGT sensors are all mounted approximately 2" below the interface flange for the exhaust pipes through a hole in the exhaust pipes - the variance between cylinders in mounting distance should be less than 1/4". I do understand that the mounting distance can influence the temperature reading - some of my pipes barely allowed this distance before bending. I have performed brief idle testing to determine low idle capabilities and have idled as low as 550RPM. The low idle stop is currently set for 700 RPM. Other than the factory run time, I have just under an hour on the hobbs meter. The Engine monitor has multiple warning points and I would like to set them up for optimal warning capabilities. Oil pressure Max, Min (0?), High yellow warn, High red warn, Low yellow warn, Low red warn Oil temperature Max, Min (0?), High yellow warn, High red warn, Low yellow warn, Low red warn Fuel pressure Max, Min (0?), High yellow warn, High red warn, Low yellow warn, Low red warn Fuel flow Max, Min (0?), High yellow warn, High red warn, Low yellow warn, Low red warn RPM Max, Min (0?), High yellow warn, High red warn, with mid-bands to accomodate propellor operating restrictions (according to MT, I don't have any) Manifold pressure Max, Min (0?), High yellow warn, High red warn CHT Max, Min (87? - lowest seen even with 0 ambient), High yellow warn, High red warn EGT Max, Min (87? - lowest seen even with 0 ambient), High yellow warn, High red warn Can you provide suggested numbers to put in to my engine monitor for these warning/operating parameters? Thanks, Ralph Capen ________________________________________________________________________________
Date: Jan 09, 2009
Subject: Spinner Template
I have seen numerous references to a constant speed spinner cut-out templat e - supposedly located somewhere on the web. I have searched in all the usual places in an attempt to locate it - with z ero success. Can anyone provide the link? I have a new Hartzell prop. The -8A plans provide clear direction for drawing one by hand, but I want a cross-check on my efforts. Seems to me that random mass distribution error s introduced during the prop/spinner mounting process should nearly cancel out or have minimal effect if one is very careful. However, this is one are a where I want to do everything possible to eliminate vibration. Paul Valovich RV-8A N192NM Reserved (again) ________________________________________________________________________________
Subject: Re: Spinner Template
Date: Jan 09, 2009
Paul, I have a drawing/tracing of the actual finished cut-outs in my Van's 6A spi nner for a Hartzell prop. Can fax to you if you would like. Dale Ensing ----- Original Message ----- From: Valovich, Paul To: rv-list(at)matronics.com Sent: Friday, January 09, 2009 11:59 AM Subject: RV-List: Spinner Template I have seen numerous references to a constant speed spinner cut-out templ ate - supposedly located somewhere on the web. I have searched in all the usual places in an attempt to locate it - with zero success. Can anyone provide the link? I have a new Hartzell prop. The -8A plans provide clear direction for drawing one by hand, but I want a cross-check on my efforts. Seems to me that random mass distribution err ors introduced during the prop/spinner mounting process should nearly cance l out or have minimal effect if one is very careful. However, this is one a rea where I want to do everything possible to eliminate vibration. Paul Valovich RV-8A N192NM Reserved (again) ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jan 09, 2009
Not sure if this is the one you want but it is for the blended AF Hartzell on my O-360 A1A. Others available on the Hartzell site. Hope this helps! Bill S 7a finishing _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul Sent: Friday, January 09, 2009 11:00 AM Subject: RV-List: Spinner Template I have seen numerous references to a constant speed spinner cut-out template - supposedly located somewhere on the web. I have searched in all the usual places in an attempt to locate it - with zero success. Can anyone provide the link? I have a new Hartzell prop. The -8A plans provide clear direction for drawing one by hand, but I want a cross-check on my efforts. Seems to me that random mass distribution errors introduced during the prop/spinner mounting process should nearly cancel out or have minimal effect if one is very careful. However, this is one area where I want to do everything possible to eliminate vibration. Paul Valovich RV-8A N192NM Reserved (again) ________________________________________________________________________________
Subject: New to Fiberglass
Date: Jan 10, 2009
Any suggestions of videos, articles, DVDs on how-to fiberglass? The RV10 requires considerable fiberglass work and it is intimidating! Thanks. Wayne Checked by AVG. 7:59 PM ________________________________________________________________________________
Subject: Re: New to Fiberglass
Date: Jan 10, 2009
Here are a few sites and docs: http://www.ultraligero.net/Cursos/diseno/Fiberglass.pdf http://www.cafes.net/leo/RV-6/R-Fairing/R-Fairing.html http://www.smittysrv.com/blog.asp?ID=13 Smitty http://SmittysRV.com ----- Original Message ----- From: "Wayne Williams" <rwayne(at)gamewood.net> Sent: Saturday, January 10, 2009 8:16 AM Subject: RV-List: New to Fiberglass > > Any suggestions of videos, articles, DVDs on how-to fiberglass? The RV10 > requires considerable fiberglass work and it is intimidating! > Thanks. > > Wayne > > > Checked by AVG. > 7:59 PM > > > > > > > ________________________________________________________________________________
Date: Jan 10, 2009
Wayne, Good fiberglass work is mostly in the prep work. I've built two Lancairs and do composites everyday in my shop. I'm glad to provide advice and enjoy talking with builders. Feel free to call anytime. BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES 101 Caroline Circle Hurricane, WV 25526 www.carbonfibercomposites.net 304-562-6800 home 304-395-4932 cell How are you going to win by a nose if you don't stick out your neck? --- On Sat, 1/10/09, Wayne Williams wrote: > From: Wayne Williams <rwayne(at)gamewood.net> > Subject: RV-List: New to Fiberglass > To: rv-list(at)matronics.com > Date: Saturday, January 10, 2009, 9:16 AM > > > Any suggestions of videos, articles, DVDs on how-to > fiberglass? The RV10 > requires considerable fiberglass work and it is > intimidating! > Thanks. > > Wayne > > > Checked by AVG. > 7:59 PM > > > ________________________________________________________________________________
From: "Terry Mortimore" <terry.mortimore(at)shaw.ca>
Subject: Converting Conical to Dynafocal engine mount.
Date: Jan 12, 2009
Hi Gang: Years ago a local fellow had a Lycoming crankcase Conical mount converted to a Dynafocal mount. He has since moved and I have a email out to him. In case he does not remember the name of the company that done the work, does anybody here know who is capable of performing this conversion? Thanks, Terry. Terry Mortimore 426 McNabb Street Apt#4 Sault Ste Marie, Ontario P6B 1Z3 ________________________________________________________________________________
Date: Jan 13, 2009
Subject: Re: RV-List Digest: 1 Msgs - 01/12/09
Just in case, I have a friend who did the same thing. Company in Kansas I believe. Will try to contact him for the name of the company. Wally Hunt Rockford, IL RV-4 Finishing Kit In a message dated 1/13/2009 2:16:49 A.M. Central Standard Time, rv-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2 009-01-12&Archive=RV Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 09-01-12&Archive=RV =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV-List Digest Archive --- Total Messages Posted Mon 01/12/09: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 08:14 AM - Converting Conical to Dynafocal engine mount. (Terry Mortimore) ________________________________ Message 1 _____________________________________ From: "Terry Mortimore" <terry.mortimore(at)shaw.ca> Subject: RV-List: Converting Conical to Dynafocal engine mount. Hi Gang: Years ago a local fellow had a Lycoming crankcase Conical mount converted to a Dynafocal mount. He has since moved and I have a email out to him. In case he does not remember the name of the company that done the work, does anybody here know who is capable of performing this conversion? Thanks, Terry. Terry Mortimore 426 McNabb Street Apt#4 Sault Ste Marie, Ontario P6B 1Z3 **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Subject: Re: Converting Conical to Dynafocal engine mount.
Date: Jan 13, 2009
ECI does those, did a great job on mine, try eci2fly.com Dan Sent from cell On Jan 12, 2009, at 10:11 AM, "Terry Mortimore" wrote: > > > > Hi Gang: > > Years ago a local fellow had a Lycoming crankcase Conical mount > converted to a Dynafocal mount. He has since moved and I have a > email out to him. > > In case he does not remember the name of the company that done the > work, does anybody here know who is capable of performing this > conversion? > > > Thanks, Terry. > > > Terry Mortimore > 426 McNabb Street Apt#4 > Sault Ste Marie, Ontario > P6B 1Z3 > > ________________________________________________________________________________
Date: Jan 13, 2009
From: Carlos Hernandez <carlosh(at)structuralaz.com>
FYI - For those who have not visited their site in a while, ECI's web address has changed to www.eci.aero Sportypilot wrote: > > ECI does those, did a great job on mine, try eci2fly.com > > Dan > > Sent from cell > > On Jan 12, 2009, at 10:11 AM, "Terry Mortimore" > wrote: > >> >> >> Hi Gang: >> >> Years ago a local fellow had a Lycoming crankcase Conical mount >> converted to a Dynafocal mount. He has since moved and I have a email >> out to him. >>
December 11, 2008 - January 13, 2009
RV-Archive.digest.vol-tv
