RV-Archive.digest.vol-uf
October 17, 2009 - December 02, 2009
      > Thanks,
      > Robin
      > RV-4      Sold
      > RV-6A   Sold
      > RV-10    Flying
      > RV-8A   Engine hung
Date: Oct 17, 2009
Subject: Re: SJ Cowl with Standard baffles
Robin Marks wrote: > Linn, > > If you plan on using a plenum with your standard Vans cowl I am. then I > have no data for you but if you plan on installing a James Cowl & plenum > then be forewarned that there are significant cooling issues for both > the cylinders & oil that may be extremely time consuming to resolve > while receiving no additional speed benefit. The issues stem from not > having enough pressure on the upper deck driving down the cooling air to > the lower section of the engine and out to bottom of the cowl. There are > a number of us James/Plenum owners working on these cooling issues as > well as trying to fly LOP. Because of the pressure issues flying LOP is > all but impossible and we as a group are considering adding expensive & > complicated Turbo Pressure rails to counteract the pressure issues plus > a few other small fixes. None of us is able to fly LOP right out of the > box like many if not most standard cowl/baffle builders. I want the plenum so that ALL the cooling air goes through the cylinders and oil cooler, not around them. Cowl seals are poor at best when new, and go downhill fast with age. > > As you asked specifically about the Plenum I have to also say that > it seems an airtight plenum is a requirement. No sloppy work can be > allowed around here. With a well sealed plenum you have basically no > access to the top of your engine w/o both removing the top cowl and then > the plenum. It takes me a minute or two to remove my top cowl. Probably > 15 minutes to remove and another 15 minutes to install the plenum. Plus > what seems like a lot of additional wear & tear. I was considering an > all aluminum plenum for my 8A with a hinged center column so I could > have quicker access to the cylinders but after much thought I was > soooooo much happier with my 4 & 6A and standard baffles. AKA the good > old days. As I have already sold my 8A cowl and committed to buy the > James cowl I was thinking of trying a James cowl w/o the plenum and > wanted input from anyone that may have gone down this path before. I'm aware of the access problem ..... but I tend to only want access to the top of the engine during the conditional inspection ..... unless something breaks. > > One last word for you Linn as a -10 builder. I am flying now with > most of the construction behind me and a beautiful airplane to enjoy but > the whole James Cowl & Plenum has been a huge mistake FOR ME and I am > strongly considering replacing it with a Vans cowl. That is a drastic > step for a flying (and painted) plane. I would never consider this if I > could control my temps and fly LOP. I have not made a final decision so > please take this as another data point before you commit one way or the > other. Feel free to contact me off-list if you have further questions. I will be in touch further on. Thanks for the comments. Linn > > > > Robin > > Robin @ painttheweb.com > > > > > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Linn Walters > Sent: Saturday, October 17, 2009 2:39 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: SJ Cowl with Standard baffles > > > > > > > I plan on a plenum for my -10. What was so terrible about your > > experience??? > > Linn > > > > > > Robin Marks wrote: > > > Is there anyone out there flying the Sam James Cowl but using standard > > > baffles in place of a plenum? If so can you please share your comments / > > > results? > > > > > > I have committed to the James cowl on my 8A but dont want to deal with > > > a Plenum (again). > > > > > > > > > > > > Thanks, > > > > > > Robin > > > > > > > > > > > > RV-4 Sold > > > > > > RV-6A Sold > > > > > > RV-10 Flying > > > > > > RV-8A Engine hung > > > > > > > > > > > > * > > > > > > > > > * > > > > > > to browse > > Un/Subscription, > > Browse, Chat, FAQ, > > more: > > http://www.matronics.com/Navigator?RV-List > > Web Forums! > > http://forums.matronics.com > > support! > > http://www.matronics.com/contribution > > > > > > > > * > > > * ________________________________________________________________________________
Date: Oct 18, 2009
Subject: Oversized Oil Cooler Installation For IO-390...
Since the IO-390's a little bigger than the 0-320's and 0-360's traditionally used on the RVs, there have been reports of issues with oil temperatures climbing too high. Marc Ausman has some very interesting findings on his web site http://www.io-390.com regarding his experiences with the IO-390, his RV-7, and some various oil cooler installations he tried. Essentially, it boiled down to using a Steward Warner 10610R oil cooler to keep oil temperatures in a normal range. The problem with the 10610R, however, is that it is a LOT bigger than the stock Van's oil cooler. Mark had trouble fitting it on his RV-7 and I've got even less space on the RV-8. So, once again, I found myself having the re-engineer to accommodate the IO-390 engine installation. The rear left baffle with the Van's supplied .040" doubler is sufficiently rigid for the stock oil cooler, but the SW10610R is quite a bit heavier and also about 1.5 times as wide. Initial fittings looked like it was going to be a close fit if it would fit at all. I spent the good part of two full days working on a new design for installing the SW10610R. I came up with a .063" double that completely shadows the rear baffle and also ties into the angle on the right of the oil cooler. I emulated the flow baffles on the stock double by cutting the rear baffle hole slightly large then bending them back and through the hole in the .063" doubler. I spent a lot of time carefully measuring and cutting and filing the paired holes and I'm extremely pleased with the fit and function. I riveted the rear baffle and the .063" doubler with a matrix of 1/8" rivets at 1" spacing. Probably went overboard here, but I have to say, it really stiffened up the structure, so maybe it was worth it. I orientated the oil cooler such that I was able to catch the mounting screw in the back of rear cylinder. This will take a huge amount of load off the baffling components and I'm really glad I noticed that I could use it with just a little bit of shifting. I also added a 4" long piece of .063" angle cut down on one side to the center rear baffle picking up the 1/4 mounting screw hole. This also really tightened up the structure. I had to file a large half-moon shape out of the right-rear mounting ear on the oil cooler to clear the engine mount. It is not used structurally on the oil cooler so no harm done. I opted to use all six mounting screw holes on the oil cooler instead of the normal four. This also seems to stiffen up the installation. The oil cooler is sufficiently mounted in toward the centerline such that there are no clearance issues with the cowling, although there would have been if I hadn't hogged out such a large half-moon from the oil cooler mount. The best part of the installation is that the hose fittings are nearly in the stock location, so I will be able to use the standard hose that come with the FWF kit. Whew, for once, something works without modification. All in all, I'm extremely pleased with the oil cooler installation. It is very solidly mounted, still uses the stock hoses, and clears the cowling. There are a few more pictures at (Logs 01-11): http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2972&log=90253&row=12 Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's All New RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 18, 2009
Subject: IO-390 Baffle Templates...
Dear Listers, I have created CAD drawings of the custom baffle pieces I made for the Lycoming IO-390 installation on my RV-8 project. Other builder's utilizing the Lycoming IO-390 in their RV-8 or RV-7 should be able to use these templates to greatly speed up the baffling installation. Note that these templates also include the cut-down for the top cowling installation. Builders may want to leave the tops longer than the templates to assure they get a good fit to the cowling. Attached are the low-res, non-scale JPGs of the templates for reference only. The high resolution, full-scale PDFs can be downloaded from my RV-8 web site: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2972&log=90450&row=2 The PDFs are meant to be printed 1:1 on 11x17 paper. Be sure to use the reference dimensions in both the X and Y to verify that your printer is creating scale diagrams. Note these pieces worked on my installation, but they may or may not work on others. No guarantees that they will fit any other installation. There are many more pictures and descriptions of the installation on my RV-8 website: http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=638&category=2972 Drop me an email if you decide to use these templates and let me know how they worked! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's All New RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 18, 2009
Matt, Nice work around and great pictures. I can't tell but it looks like you used aluminum fittings on the oil cooler. If this is true you need to know that they are very easy to gall. Dan C had this problem. Pacific Oil Cooler was able to repair the damage. Just a head's up to try to keep you from future problems. BTW the normal recommendation is to use steel fittings on the oil cooler. Don VS RV7 Flying -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, October 18, 2009 9:37 AM Subject: RV-List: Oversized Oil Cooler Installation For IO-390... Since the IO-390's a little bigger than the 0-320's and 0-360's traditionally used on the RVs, there have been reports of issues with oil temperatures climbing too high. Marc Ausman has some very interesting findings on his web site http://www.io-390.com regarding his experiences with the IO-390, his RV-7, and some various oil cooler installations he tried. Essentially, it boiled down to using a Steward Warner 10610R oil cooler to keep oil temperatures in a normal range. The problem with the 10610R, however, is that it is a LOT bigger than the stock Van's oil cooler. Mark had trouble fitting it on his RV-7 and I've got even less space on the RV-8. So, once again, I found myself having the re-engineer to accommodate the IO-390 engine installation. The rear left baffle with the Van's supplied .040" doubler is sufficiently rigid for the stock oil cooler, but the SW10610R is quite a bit heavier and also about 1.5 times as wide. Initial fittings looked like it was going to be a close fit if it would fit at all. I spent the good part of two full days working on a new design for installing the SW10610R. I came up with a .063" double that completely shadows the rear baffle and also ties into the angle on the right of the oil cooler. I emulated the flow baffles on the stock double by cutting the rear baffle hole slightly large then bending them back and through the hole in the .063" doubler. I spent a lot of time carefully measuring and cutting and filing the paired holes and I'm extremely pleased with the fit and function. I riveted the rear baffle and the .063" doubler with a matrix of 1/8" rivets at 1" spacing. Probably went overboard here, but I have to say, it really stiffened up the structure, so maybe it was worth it. I orientated the oil cooler such that I was able to catch the mounting screw in the back of rear cylinder. This will take a huge amount of load off the baffling components and I'm really glad I noticed that I could use it with just a little bit of shifting. I also added a 4" long piece of .063" angle cut down on one side to the center rear baffle picking up the 1/4 mounting screw hole. This also really tightened up the structure. I had to file a large half-moon shape out of the right-rear mounting ear on the oil cooler to clear the engine mount. It is not used structurally on the oil cooler so no harm done. I opted to use all six mounting screw holes on the oil cooler instead of the normal four. This also seems to stiffen up the installation. The oil cooler is sufficiently mounted in toward the centerline such that there are no clearance issues with the cowling, although there would have been if I hadn't hogged out such a large half-moon from the oil cooler mount. The best part of the installation is that the hose fittings are nearly in the stock location, so I will be able to use the standard hose that come with the FWF kit. Whew, for once, something works without modification. All in all, I'm extremely pleased with the oil cooler installation. It is very solidly mounted, still uses the stock hoses, and clears the cowling. There are a few more pictures at (Logs 01-11): http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate gory=2972&log=90253&row=12 Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's All New RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 18, 2009
Hi Don, Thanks for the feedback. Right now I've just got the AN822-8D aluminum fittings that Van's includes with the kit screwed into the oil cooler finger tight. I just checked Van's site and didn't find any steel versions of the AN822-8D. Is this something that Van's carries or is ACS a better bet? Do you happen to have a part number? Thanks! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog At 05:25 PM 10/18/2009 Sunday, you wrote: > >Matt, >Nice work around and great pictures. I can't tell but it looks like you >used aluminum fittings on the oil cooler. If this is true you need to know >that they are very easy to gall. Dan C had this problem. Pacific Oil Cooler >was able to repair the damage. Just a head's up to try to keep you from >future problems. BTW the normal recommendation is to use steel fittings on >the oil cooler. >Don VS RV7 Flying > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >Sent: Sunday, October 18, 2009 9:37 AM >To: rv-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com >Subject: RV-List: Oversized Oil Cooler Installation For IO-390... > >Since the IO-390's a little bigger than the 0-320's and 0-360's >traditionally used on the RVs, there have been reports of issues with oil >temperatures climbing too high. Marc Ausman has some very interesting >findings on his web site http://www.io-390.com regarding his experiences >with the IO-390, his RV-7, and some various oil cooler installations he >tried. Essentially, it boiled down to using a Steward Warner 10610R oil >cooler to keep oil temperatures in a normal range. The problem with the >10610R, however, is that it is a LOT bigger than the stock Van's oil cooler. >Mark had trouble fitting it on his RV-7 and I've got even less space on the >RV-8. > >So, once again, I found myself having the re-engineer to accommodate the >IO-390 engine installation. The rear left baffle with the Van's supplied >.040" doubler is sufficiently rigid for the stock oil cooler, but the >SW10610R is quite a bit heavier and also about 1.5 times as wide. Initial >fittings looked like it was going to be a close fit if it would fit at all. > >I spent the good part of two full days working on a new design for >installing the SW10610R. I came up with a .063" double that completely >shadows the rear baffle and also ties into the angle on the right of the oil >cooler. I emulated the flow baffles on the stock double by cutting the rear >baffle hole slightly large then bending them back and through the hole in >the .063" doubler. I spent a lot of time carefully measuring and cutting >and filing the paired holes and I'm extremely pleased with the fit and >function. I riveted the rear baffle and the .063" doubler with a matrix of >1/8" rivets at 1" spacing. Probably went overboard here, but I have to say, >it really stiffened up the structure, so maybe it was worth it. > >I orientated the oil cooler such that I was able to catch the mounting screw >in the back of rear cylinder. This will take a huge amount of load off the >baffling components and I'm really glad I noticed that I could use it with >just a little bit of shifting. I also added a 4" long piece of .063" angle >cut down on one side to the center rear baffle picking up the 1/4 mounting >screw hole. This also really tightened up the structure. > >I had to file a large half-moon shape out of the right-rear mounting ear on >the oil cooler to clear the engine mount. It is not used structurally on >the oil cooler so no harm done. I opted to use all six mounting screw holes >on the oil cooler instead of the normal four. This also seems to stiffen up >the installation. > >The oil cooler is sufficiently mounted in toward the centerline such that >there are no clearance issues with the cowling, although there would have >been if I hadn't hogged out such a large half-moon from the oil cooler >mount. > >The best part of the installation is that the hose fittings are nearly in >the stock location, so I will be able to use the standard hose that come >with the FWF kit. Whew, for once, something works without modification. > >All in all, I'm extremely pleased with the oil cooler installation. It is >very solidly mounted, still uses the stock hoses, and clears the cowling. > >There are a few more pictures at (Logs 01-11): > > >http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2972&log=90253&row=12 > > >Matt Dralle >RV-8 #82880 N998RV >http://www.mattsrv8.com - Matt's All New RV-8 Construction Blog > ________________________________________________________________________________
Date: Oct 18, 2009
Subject: Mag & Alternator Cooling Blast Tubes...
Greetings Listers, I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't. I'm guessing the Slick Mags do. The directions are pretty clear on how to mount the tube in the baffle, but don't mention at all where to shoot the air in around the mag. Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? I've also got the PlanePower 60amp alternator that Van's sells. The instruction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do. Okay, great. But does that mean that it still needs a blast tube off the front baffle for cooling? If so, same question on the mags. Where's a good place to stick the cool air on the alternator? Thanks in advance for the feedback, Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 18, 2009
Matt, I got them from Pacific Oil Cooler, http://www.oilcoolers.com/ . Van's does not stock them as far as I know. ACS does but I do nort know the part # Don VS RV& flying -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, October 18, 2009 7:47 PM Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... Hi Don, Thanks for the feedback. Right now I've just got the AN822-8D aluminum fittings that Van's includes with the kit screwed into the oil cooler finger tight. I just checked Van's site and didn't find any steel versions of the AN822-8D. Is this something that Van's carries or is ACS a better bet? Do you happen to have a part number? Thanks! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog At 05:25 PM 10/18/2009 Sunday, you wrote: > >Matt, >Nice work around and great pictures. I can't tell but it looks like you >used aluminum fittings on the oil cooler. If this is true you need to know >that they are very easy to gall. Dan C had this problem. Pacific Oil Cooler >was able to repair the damage. Just a head's up to try to keep you from >future problems. BTW the normal recommendation is to use steel fittings on >the oil cooler. >Don VS RV7 Flying > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >Sent: Sunday, October 18, 2009 9:37 AM >To: rv-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com >Subject: RV-List: Oversized Oil Cooler Installation For IO-390... > >Since the IO-390's a little bigger than the 0-320's and 0-360's >traditionally used on the RVs, there have been reports of issues with oil >temperatures climbing too high. Marc Ausman has some very interesting >findings on his web site http://www.io-390.com regarding his experiences >with the IO-390, his RV-7, and some various oil cooler installations he >tried. Essentially, it boiled down to using a Steward Warner 10610R oil >cooler to keep oil temperatures in a normal range. The problem with the >10610R, however, is that it is a LOT bigger than the stock Van's oil cooler. >Mark had trouble fitting it on his RV-7 and I've got even less space on the >RV-8. > >So, once again, I found myself having the re-engineer to accommodate the >IO-390 engine installation. The rear left baffle with the Van's supplied >.040" doubler is sufficiently rigid for the stock oil cooler, but the >SW10610R is quite a bit heavier and also about 1.5 times as wide. Initial >fittings looked like it was going to be a close fit if it would fit at all. > >I spent the good part of two full days working on a new design for >installing the SW10610R. I came up with a .063" double that completely >shadows the rear baffle and also ties into the angle on the right of the oil >cooler. I emulated the flow baffles on the stock double by cutting the rear >baffle hole slightly large then bending them back and through the hole in >the .063" doubler. I spent a lot of time carefully measuring and cutting >and filing the paired holes and I'm extremely pleased with the fit and >function. I riveted the rear baffle and the .063" doubler with a matrix of >1/8" rivets at 1" spacing. Probably went overboard here, but I have to say, >it really stiffened up the structure, so maybe it was worth it. > >I orientated the oil cooler such that I was able to catch the mounting screw >in the back of rear cylinder. This will take a huge amount of load off the >baffling components and I'm really glad I noticed that I could use it with >just a little bit of shifting. I also added a 4" long piece of .063" angle >cut down on one side to the center rear baffle picking up the 1/4 mounting >screw hole. This also really tightened up the structure. > >I had to file a large half-moon shape out of the right-rear mounting ear on >the oil cooler to clear the engine mount. It is not used structurally on >the oil cooler so no harm done. I opted to use all six mounting screw holes >on the oil cooler instead of the normal four. This also seems to stiffen up >the installation. > >The oil cooler is sufficiently mounted in toward the centerline such that >there are no clearance issues with the cowling, although there would have >been if I hadn't hogged out such a large half-moon from the oil cooler >mount. > >The best part of the installation is that the hose fittings are nearly in >the stock location, so I will be able to use the standard hose that come >with the FWF kit. Whew, for once, something works without modification. > >All in all, I'm extremely pleased with the oil cooler installation. It is >very solidly mounted, still uses the stock hoses, and clears the cowling. > >There are a few more pictures at (Logs 01-11): > > >http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cat egory=2972&log=90253&row=12 > > >Matt Dralle >RV-8 #82880 N998RV >http://www.mattsrv8.com - Matt's All New RV-8 Construction Blog > ________________________________________________________________________________
Date: Oct 18, 2009
It would be AN822-8. The D is for Dural, i.e. aluminum. Normally -8 and above size fittings are considered strong enough in aluminum for engine installations. -6 and below use steel. Regards, Greg Young > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Don > Sent: Sunday, October 18, 2009 10:12 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... > > > Matt, > I got them from Pacific Oil Cooler, > http://www.oilcoolers.com/ . Van's does not stock them as far > as I know. ACS does but I do nort know the part # Don VS RV& flying > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Sunday, October 18, 2009 7:47 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... > > > Hi Don, > > Thanks for the feedback. Right now I've just got the > AN822-8D aluminum fittings that Van's includes with the kit > screwed into the oil cooler finger tight. I just checked > Van's site and didn't find any steel versions of the > AN822-8D. Is this something that Van's carries or is ACS a > better bet? Do you happen to have a part number? > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > > > At 05:25 PM 10/18/2009 Sunday, you wrote: > > > >Matt, > >Nice work around and great pictures. I can't tell but it looks like > >you used aluminum fittings on the oil cooler. If this is > true you need > >to know that they are very easy to gall. Dan C had this problem. > >Pacific Oil > Cooler > >was able to repair the damage. Just a head's up to try to keep you > >from future problems. BTW the normal recommendation is to use steel > >fittings on the oil cooler. > >Don VS RV7 Flying > > > ________________________________________________________________________________
Date: Oct 19, 2009
Matt, The letter D at the end of the AN822-8D part number specifies that the part is made of aluminum [Dural alloy]. Simply omit the D [AN822-8] to obtain the same part in steel. This rule applies to all AN hydraulic fittings. http://www.aircraftspruce.com/catalog/hapages/an822.php Charlie Kuss PS Using straight or 45 degree fittings will improve oil flow to and from the cooler, if space allows. 90 degree fittings should only be used when the less restrictive straight [AN816-8] or 45 degree [AN823-8] fittings will not work. http://www.aircraftspruce.com/catalog/hapages/an823.php http://www.aircraftspruce.com/catalog/hapages/an816.php --- On Sun, 10/18/09, Matt Dralle wrote: > From: Matt Dralle <dralle(at)matronics.com> > Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... > To: rv-list(at)matronics.com > Date: Sunday, October 18, 2009, 10:47 PM > Matt Dralle > > Hi Don, > > Thanks for the feedback. Right now I've just got the > AN822-8D aluminum fittings that Van's includes with the kit > screwed into the oil cooler finger tight. I just > checked Van's site and didn't find any steel versions of the > AN822-8D. Is this something that Van's carries or is > ACS a better bet? Do you happen to have a part > number? > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction > Blog > > > At 05:25 PM 10/18/2009 Sunday, you wrote: > > > >Matt, > >Nice work around and great pictures. I can't tell > but it looks like you > >used aluminum fittings on the oil cooler. If this > is true you need to know > >that they are very easy to gall. Dan C had this > problem. Pacific Oil Cooler > >was able to repair the damage. Just a head's up > to try to keep you from > >future problems. BTW the normal recommendation is > to use steel fittings on > >the oil cooler. > >Don VS RV7 Flying > > > >-----Original Message----- > >From: owner-rv-list-server(at)matronics.com > >[mailto:owner-rv-list-server(at)matronics.com] > On Behalf Of Matt Dralle > >Sent: Sunday, October 18, 2009 9:37 AM > >To: rv-list(at)matronics.com; > rv8-list(at)matronics.com; > rv7-list(at)matronics.com > >Subject: RV-List: Oversized Oil Cooler Installation For > IO-390... > > > >Since the IO-390's a little bigger than the 0-320's and > 0-360's > >traditionally used on the RVs, there have been reports > of issues with oil > >temperatures climbing too high. Marc Ausman has > some very interesting > >findings on his web site http://www.io-390.com regarding his experiences > >with the IO-390, his RV-7, and some various oil cooler > installations he > >tried. Essentially, it boiled down to using a > Steward Warner 10610R oil > >cooler to keep oil temperatures in a normal > range. The problem with the > >10610R, however, is that it is a LOT bigger than the > stock Van's oil cooler. > >Mark had trouble fitting it on his RV-7 and I've got > even less space on the > >RV-8. > > > >So, once again, I found myself having the re-engineer > to accommodate the > >IO-390 engine installation. The rear left baffle > with the Van's supplied > >.040" doubler is sufficiently rigid for the stock oil > cooler, but the > >SW10610R is quite a bit heavier and also about 1.5 > times as wide. Initial > >fittings looked like it was going to be a close fit if > it would fit at all. > > > >I spent the good part of two full days working on a new > design for > >installing the SW10610R. I came up with a .063" > double that completely > >shadows the rear baffle and also ties into the angle on > the right of the oil > >cooler. I emulated the flow baffles on the stock > double by cutting the rear > >baffle hole slightly large then bending them back and > through the hole in > >the .063" doubler. I spent a lot of time > carefully measuring and cutting > >and filing the paired holes and I'm extremely pleased > with the fit and > >function. I riveted the rear baffle and the .063" > doubler with a matrix of > >1/8" rivets at 1" spacing. Probably went > overboard here, but I have to say, > >it really stiffened up the structure, so maybe it was > worth it. > > > >I orientated the oil cooler such that I was able to > catch the mounting screw > >in the back of rear cylinder. This will take a > huge amount of load off the > >baffling components and I'm really glad I noticed that > I could use it with > >just a little bit of shifting. I also added a 4" > long piece of .063" angle > >cut down on one side to the center rear baffle picking > up the 1/4 mounting > >screw hole. This also really tightened up the > structure. > > > >I had to file a large half-moon shape out of the > right-rear mounting ear on > >the oil cooler to clear the engine mount. It is > not used structurally on > >the oil cooler so no harm done. I opted to use > all six mounting screw holes > >on the oil cooler instead of the normal four. > This also seems to stiffen up > >the installation. > > > >The oil cooler is sufficiently mounted in toward the > centerline such that > >there are no clearance issues with the cowling, > although there would have > >been if I hadn't hogged out such a large half-moon from > the oil cooler > >mount. > > > >The best part of the installation is that the hose > fittings are nearly in > >the stock location, so I will be able to use the > standard hose that come > >with the FWF kit. Whew, for once, something works > without modification. > > > >All in all, I'm extremely pleased with the oil cooler > installation. It is > >very solidly mounted, still uses the stock hoses, and > clears the cowling. > > > >There are a few more pictures at (Logs 01-11): > > > > > >http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2972&log=90253&row=12 > > > > > >Matt Dralle > >RV-8 #82880 N998RV > >http://www.mattsrv8.com - Matt's All New RV-8 > Construction Blog > > > > > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Oct 19, 2009
Subject: Re: Oversized Oil Cooler Installation For IO-390...
Reasons for steel Vs. aluminum fittings in the engine compartment abound. The only credible one I've heard is that the steel will be in place long after the aluminum fitting has disappeared due to fire. That makes sense to me. However, I have found no FACTUAL information that one type of fitting ever helped/caused a fire related incident. That doesn't mean that the facts aren't out there .... it just means I haven't found them. I will admit that I have had aluminum fittings in my Pitts for 28 years .... they were lighter, plentiful, less cost ...... so I used them. Linn Don wrote: > > Matt, > I got them from Pacific Oil Cooler, http://www.oilcoolers.com/ . Van's does > not stock them as far as I know. ACS does but I do nort know the part # > Don VS RV& flying > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Sunday, October 18, 2009 7:47 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... > > > Hi Don, > > Thanks for the feedback. Right now I've just got the AN822-8D aluminum > fittings that Van's includes with the kit screwed into the oil cooler finger > tight. I just checked Van's site and didn't find any steel versions of the > AN822-8D. Is this something that Van's carries or is ACS a better bet? Do > you happen to have a part number? > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 19, 2009
I don't think steel is preferred for fire suppression. Steel is preferred for vibration protection. The fatigue life of aluminum is quite short. Common practice is to use steel on any fitting that hangs off the engine. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Monday, October 19, 2009 9:51 AM Subject: Re: RV-List: Oversized Oil Cooler Installation For IO-390... Reasons for steel Vs. aluminum fittings in the engine compartment abound. The only credible one I've heard is that the steel will be in place long after the aluminum fitting has disappeared due to fire. That makes sense to me. However, I have found no FACTUAL information that one type of fitting ever helped/caused a fire related incident. That doesn't mean that the facts aren't out there .... it just means I haven't found them. I will admit that I have had aluminum fittings in my Pitts for 28 years .... they were lighter, plentiful, less cost ...... so I used them. Linn Don wrote: > > Matt, > I got them from Pacific Oil Cooler, http://www.oilcoolers.com/ . Van's does > not stock them as far as I know. ACS does but I do nort know the part # > Don VS RV& flying > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Sunday, October 18, 2009 7:47 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... > > > Hi Don, > > Thanks for the feedback. Right now I've just got the AN822-8D aluminum > fittings that Van's includes with the kit screwed into the oil cooler finger > tight. I just checked Van's site and didn't find any steel versions of the > AN822-8D. Is this something that Van's carries or is ACS a better bet? Do > you happen to have a part number? > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 19, 2009
Aluminum also galls very easily when tightened against steel. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bruce Gray Sent: Monday, October 19, 2009 7:09 AM Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... I don't think steel is preferred for fire suppression. Steel is preferred for vibration protection. The fatigue life of aluminum is quite short. Common practice is to use steel on any fitting that hangs off the engine. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Monday, October 19, 2009 9:51 AM Subject: Re: RV-List: Oversized Oil Cooler Installation For IO-390... Reasons for steel Vs. aluminum fittings in the engine compartment abound. The only credible one I've heard is that the steel will be in place long after the aluminum fitting has disappeared due to fire. That makes sense to me. However, I have found no FACTUAL information that one type of fitting ever helped/caused a fire related incident. That doesn't mean that the facts aren't out there .... it just means I haven't found them. I will admit that I have had aluminum fittings in my Pitts for 28 years .... they were lighter, plentiful, less cost ...... so I used them. Linn Don wrote: > > Matt, > I got them from Pacific Oil Cooler, http://www.oilcoolers.com/ . Van's does > not stock them as far as I know. ACS does but I do nort know the part # > Don VS RV& flying > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Sunday, October 18, 2009 7:47 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Oversized Oil Cooler Installation For IO-390... > > > Hi Don, > > Thanks for the feedback. Right now I've just got the AN822-8D aluminum > fittings that Van's includes with the kit screwed into the oil cooler finger > tight. I just checked Van's site and didn't find any steel versions of the > AN822-8D. Is this something that Van's carries or is ACS a better bet? Do > you happen to have a part number? > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Subject: Tru Trak Auto Pilot Servo
Date: Oct 21, 2009
I have a Tru Trak servo installed on my RV-7 elevator control and am picking up a sudden large resistance to movement. After almost disassembling my entire elevator system to find the "binding" I traced the problem to the servo. There is of course an expected resistance when moving the controls but I suddenly experienced a loud grinding noise which was reminiscent of say a control surface rubbing over corrugated conduit. I also found that the extra resistance was only evident when the electrical connections were made (9 - pin plug inserted) The same effect could be obtained when 4 of the 9 pins were grounded against the side of the plug. Electrical current not applied. This was not evident throughout construction and has only just manifested itself. (now that I am ready for my maiden flight!) My friends RV with identical setup does not have the resistance that I am experiencing. Any thoughts anyone? Trevor RV-7 Cape Town ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Subject: Re: Tru Trak Auto Pilot Servo
Date: Oct 20, 2009
Yes, pull the servo and send it in. You sure don't need the autopilot on your maiden flight... Isn't the first instance of hearing of issues with the servos.... Sent from my iPhone On Oct 20, 2009, at 6:27 PM, "Trevor" wrote: > I have a Tru Trak servo installed on my RV-7 elevator control and am > picking up a sudden large resistance to movement. After almost > disassembling my entire elevator system to find the "binding" I > traced the problem to the servo. There is of course an expected > resistance when moving the controls but I suddenly experienced a > loud grinding noise which was reminiscent of say a control surface > rubbing over corrugated conduit. I also found that the extra > resistance was only evident when the electrical connections were > made (9 - pin plug inserted) The same effect could be obtained when > 4 of the 9 pins were grounded against the side of the plug. > Electrical current not applied. This was not evident throughout > construction and has only just manifested itself. (now that I am > ready for my maiden flight!) My friends RV with identical setup > does not have the resistance that I am experiencing. Any thoughts > anyone? > > Trevor RV-7 Cape Town > > ________________________________________________________________________________
Date: Oct 20, 2009
Disconnect the servo, remove/secure the pushrod and fly the airplane. Regards, Greg -----Original Message----- From: "Trevor" <davist(at)xsinet.co.za> Date: Wed, 21 Oct 2009 00:27:03 Subject: RV-List: Tru Trak Auto Pilot Servo This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Oct 21, 2009
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Hi Trevor, Many builders have found interference with the F705 Bulkhead and the F789 Elevator Push Rod assembly. The problem has been the bottom or lower side of the tube rubbing on the bottom side of the cut out for the tube in the F705 Bulkhead (lower side of the cut out)... I would check this closely. Build on... Darrell --- On Tue, 10/20/09, Trevor wrote: > From: Trevor <davist(at)xsinet.co.za> > Subject: RV-List: Tru Trak Auto Pilot Servo > To: "RV-List" > Date: Tuesday, October 20, 2009, 5:27 PM > > > > > > > > I have a Tru Trak servo > installed on my RV-7 > elevator control and am picking up a sudden large > resistance to movement. > After almost disassembling my entire elevator system to > find the "binding" I > traced the problem to the servo. There is of course > an > expectedresistance when moving the controls but I > suddenly experienced a > loud grinding noise which was reminiscent of say a control > surface rubbing over > corrugated conduit. I also found that the extra > resistance was only > evident when the electrical connections were made (9 - pin > plug inserted) > The same effect could be obtained when 4 of the 9 pins were > grounded against the > side of the plug. Electrical current not > applied. This was not > evident throughout construction and has only just > manifested itself. (now > that I am ready for my maiden flight!) My friends RV > with identical setup > does not have the resistance that I am experiencing. > Any thoughts > anyone? > > Trevor RV-7 Cape > Town > > > > > > ________________________________________________________________________________
Subject: Van's RV-9A Kit for sale. Amazing deal.
Date: Oct 21, 2009
I started construction in 2001, but do not fly any more, and offering it for sale. Meticulously crafted, primed with zinc chromate. I have completed the Tail, Wings, and most of the Empennage. I even purchased the finishing kit, but have not worked on it for some time, and would be an enormous head start if you are looking to fly soon. Builder #90147. Provision for Tail light, Dual Brake, Dual Landing lights, Wingtip with provision for position lights, Static Air, Slider Canopy, Dyna/cowl for O-320, Spinner for Sensenich metal prop. Many of these options you can probably still change at this point. Currently, the Van's quickbuild price $30,200 and kit price is $20,220. I am offering this kit for $19,000, firm. In addition, I will set aside $1,000 of the payment aside for 12 months from date of purchase to pay for up to that amount in parts which are missing (I have carefully kept track of everything so I don't think this will be an issue). Kit is located in Monterey, California. I was able to move it with a 15' moving truck. Pics available at http://img42.imageshack.us/slideshow/webplayer.php?id=pc150115.jpg Please contact me for any questions. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=268844#268844 ________________________________________________________________________________
Date: Oct 21, 2009
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: RV-8A QB Kit - Sell Kit or Partner Wanted to help Complete
Empennage COMPLETED (Interior - Acid Etched, Alodined and Mil Epoxy Primered) = Meticulous workmanship. QB Wings and QB Fuselage have NOT been started. Everything is in excellent condition and nothing is missing (Complete Kit) Asking $19.5K. Currently Vans sells (above) - Empennage + QB Wings + QB Fuselage for $25K (includes Crating Charges) and there is a long "Lead Time". Ideally like to find a Builder (Partner) to work together to complete Project who has space to build it or sell it. Presently hangared in Chino, CA. Need to move ASAP !! Garey Wittich (310) 392-1682 ________________________________________________________________________________
From: "Stucklen, Frederic W" <stucklfw(at)westinghouse.com>
Date: Oct 22, 2009
Subject: Front Gear Leg Bolt Hole Wear
I posted this on the Van's Airforce site last week, but thought that it might be a good idea to add it to this site as well. The type of locktite I think was #609, but am not sure as the container label has worn off.. It's interesting to note that , while the front gear leg mounting holes have worn, there haven't been any reported instances of the main gear leg m ounting hole wearing.... This front gear fix probably should be used on all new assemblies..... Fred Hi All, I just got done repairing the front gear leg mount bolt hole on my RV-7A a while back. There was a slight bit of wear due to the bolt either loosening and/or the front fork being too tight, causing excessive torque on the gea r leg during turns. In any case, there was a slight amount of rotation in t he gear leg with the bolt loose, indicating that the bolt holes were slight ly oblong... Here's what I did to fix the problem. First I tied down the tail, and remov ed the front gear leg. Next, I cleaned both the top mount area and the lowe r mount area of any grease. I did the same to the gear leg, but re-greased the lower mount area where it comes into contact with the mount. Then I app lied permanent Lock-Tight to the inside of the upper mount area, and also c oated the top mount area of the gear leg. The gear leg was then inserted ba ck into the mount and the bolt partially re-inserted. (My bolt inserts from the top. The firewall has an indentation for the nut. There is no hole in the firewall for the bolt...). Next I used a small amount of "Liquid Steel" into the worn areas of the gea r leg mounting bolt holes. (Since there was very little wear, I did this in stead of drilling out the mount/gear to a larger size bolt, or inserting a taper pin.) The bolt was then torqued normally. I let the assembly dry befo re testing it for any movement. Solid.... I've flown over 100 Hours after that fix was performed, and still have no m ovement in the front gear leg upper mount area. I have checked it at every oil change for any signs of movement.... With the history of issues in this area, it would seem prudent to do the fi nal front gear leg assembly with Lock-Tight on the upper mount area. This w ould prevent the re-occurring issue that we've seen in this area on the -A RV models.... And I've seen it happen to every RV-XA that I've owned.... __________________ Fred Stucklen RV-7A N924RV Flying RV-6A N926RV 875 Hrs (Sold) RV-6A N925RV 2008 Hrs (Sold) ________________________________________________________________________________
Date: Oct 22, 2009
I used LOCTITE 680 on top and bottom area(nose gear) and no movement after 90 hours any more.. Karl 7A _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Stucklen, Frederic W Sent: Thursday, 22 October 2009 10:19 PM Subject: RV-List: Front Gear Leg Bolt Hole Wear I posted this on the Van's Airforce site last week, but thought that it might be a good idea to add it to this site as well. The type of locktite I think was #609, but am not sure as the container label has worn off.. It's interesting to note that , while the front gear leg mounting holes have worn, there haven't been any reported instances of the main gear leg mounting hole wearing.. This front gear fix probably should be used on all new assemblies... Fred Hi All, I just got done repairing the front gear leg mount bolt hole on my RV-7A a while back. There was a slight bit of wear due to the bolt either loosening and/or the front fork being too tight, causing excessive torque on the gear leg during turns. In any case, there was a slight amount of rotation in the gear leg with the bolt loose, indicating that the bolt holes were slightly oblong... Here's what I did to fix the problem. First I tied down the tail, and removed the front gear leg. Next, I cleaned both the top mount area and the lower mount area of any grease. I did the same to the gear leg, but re-greased the lower mount area where it comes into contact with the mount. Then I applied permanent Lock-Tight to the inside of the upper mount area, and also coated the top mount area of the gear leg. The gear leg was then inserted back into the mount and the bolt partially re-inserted. (My bolt inserts from the top. The firewall has an indentation for the nut. There is no hole in the firewall for the bolt...). Next I used a small amount of "Liquid Steel" into the worn areas of the gear leg mounting bolt holes. (Since there was very little wear, I did this instead of drilling out the mount/gear to a larger size bolt, or inserting a taper pin.) The bolt was then torqued normally. I let the assembly dry before testing it for any movement. Solid.... I've flown over 100 Hours after that fix was performed, and still have no movement in the front gear leg upper mount area. I have checked it at every oil change for any signs of movement.... With the history of issues in this area, it would seem prudent to do the final front gear leg assembly with Lock-Tight on the upper mount area. This would prevent the re-occurring issue that we've seen in this area on the -A RV models.... And I've seen it happen to every RV-XA that I've owned.... __________________ Fred Stucklen RV-7A N924RV Flying RV-6A N926RV 875 Hrs (Sold) RV-6A N925RV 2008 Hrs (Sold) 16:44:00 ________________________________________________________________________________
Subject: Re: Front Gear Leg Bolt Hole Wear
Date: Oct 22, 2009
Thanks Fred, Could you give us some tech data on the "Liquid Steel" please? Dale Ensing ----- Original Message ----- From: Stucklen, Frederic W To: rv-list(at)matronics.com Sent: Thursday, October 22, 2009 7:19 AM Subject: RV-List: Front Gear Leg Bolt Hole Wear I posted this on the Van's Airforce site last week, but thought that i t might be a good idea to add it to this site as well. The type of locktite I think was #609, but am not sure as the container label has worn off.. It's interesting to note that , while the front gear leg mounting hole s have worn, there haven't been any reported instances of the main gear leg mounting hole wearing.. This front gear fix probably should be used on all new assemblies... Fred Hi All, I just got done repairing the front gear leg mount bolt hole on my RV-7A a while back. There was a slight bit of wear due to the bolt either looseni ng and/or the front fork being too tight, causing excessive torque on the g ear leg during turns. In any case, there was a slight amount of rotation in the gear leg with the bolt loose, indicating that the bolt holes were slig htly oblong... Here's what I did to fix the problem. First I tied down the tail, and rem oved the front gear leg. Next, I cleaned both the top mount area and the lo wer mount area of any grease. I did the same to the gear leg, but re-grease d the lower mount area where it comes into contact with the mount. Then I a pplied permanent Lock-Tight to the inside of the upper mount area, and also coated the top mount area of the gear leg. The gear leg was then inserted back into the mount and the bolt partially re-inserted. (My bolt inserts fr om the top. The firewall has an indentation for the nut. There is no hole i n the firewall for the bolt...). Next I used a small amount of "Liquid Steel" into the worn areas of the g ear leg mounting bolt holes. (Since there was very little wear, I did this instead of drilling out the mount/gear to a larger size bolt, or inserting a taper pin.) The bolt was then torqued normally. I let the assembly dry be fore testing it for any movement. Solid.... I've flown over 100 Hours after that fix was performed, and still have no movement in the front gear leg upper mount area. I have checked it at ever y oil change for any signs of movement.... With the history of issues in this area, it would seem prudent to do the final front gear leg assembly with Lock-Tight on the upper mount area. This would prevent the re-occurring issue that we've seen in this area on the - A RV models.... And I've seen it happen to every RV-XA that I've owned.... __________________ Fred Stucklen RV-7A N924RV Flying RV-6A N926RV 875 Hrs (Sold) RV-6A N925RV 2008 Hrs (Sold) ________________________________________________________________________________
Date: Oct 24, 2009
Subject: fuel line routing
I planned a route for the fire-sleeved fuel line to my AFP divider on top of the engine, which penetrates the cooling baffle through a large grommet. I'm wondering now if the grommet can take the high temperatures in there in the 10 minutes after engine shutdown. I note that when Bart L. delivered the engine to me he had the fuel line penetrating the intercylinder baffle through a grommet (he didn't know I was going to use a crossover exhaust, so I had to re-plumb it to keep it away from the exhaust) so I guess that's where I got the idea. But now I'm wondering.... -- Tom Sargent, RV-6A, final assembly. ________________________________________________________________________________
Date: Oct 24, 2009
Subject: Re: fuel line routing
I've done this with my 6A and SJ cowl/plenum and have two of these grommets. Pictures seperately - and to others that ask for them...... -----Original Message----- >From: thomas sargent <sarg314(at)gmail.com> >Sent: Oct 24, 2009 10:54 AM >To: rv-list >Subject: RV-List: fuel line routing > >I planned a route for the fire-sleeved fuel line to my AFP divider on top of >the engine, which penetrates the cooling baffle through a large grommet. >I'm wondering now if the grommet can take the high temperatures in there in >the 10 minutes after engine shutdown. > >I note that when Bart L. delivered the engine to me he had the fuel line >penetrating the intercylinder baffle through a grommet (he didn't know I was >going to use a crossover exhaust, so I had to re-plumb it to keep it away >from the exhaust) so I guess that's where I got the idea. But now I'm >wondering.... > >-- >Tom Sargent, RV-6A, final assembly. ________________________________________________________________________________
Date: Oct 24, 2009
At 07:54 AM 10/24/2009 Saturday, you wrote: >I planned a route for the fire-sleeved fuel line to my AFP divider on top of the engine, which penetrates the cooling baffle through a large grommet.=C2 I'm wondering now if the grommet can take the high temperatures in there in the 10 minutes after engine shutdown. > >I note that when Bart L. delivered the engine to me he had the fuel line penetrating the intercylinder baffle through a grommet (he didn't know I was going to use a crossover exhaust, so I had to re-plumb it to keep it away from the exhaust) so I guess that's where I got the idea.=C2 But now I'm wondering.... > >-- >Tom Sargent, RV-6A, final assembly. Hi Tom, Attached are a couple of pictures of how I routed mine. I've got the 4-into-4 exhaust from Vetterman. The fuel from the TB to the distributor doesn't even come close to the exhaust. I would assume that the grommet comes with the Lycoming inter-baffle kit and is designed to handle the temps in that region. If you hear otherwise from Bart or some other authoritative source, be sure to post it to the List. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com Final Finishing Touches To FWF... ________________________________________________________________________________
Date: Oct 24, 2009
I wondered the same thing but was told the grommet I received from AFP was a high-temp grommet designed for these high temps. 100+ hrs so far and no problems yet. Bret Smith RV-9A N16BL Blue Ridge, GA www.FlightInnovations.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Saturday, October 24, 2009 11:19 AM Subject: Re: RV-List: fuel line routing I've done this with my 6A and SJ cowl/plenum and have two of these grommets. Pictures seperately - and to others that ask for them...... -----Original Message----- >From: thomas sargent <sarg314(at)gmail.com> >Sent: Oct 24, 2009 10:54 AM >To: rv-list >Subject: RV-List: fuel line routing > >I planned a route for the fire-sleeved fuel line to my AFP divider on top of >the engine, which penetrates the cooling baffle through a large grommet. >I'm wondering now if the grommet can take the high temperatures in there in >the 10 minutes after engine shutdown. > >I note that when Bart L. delivered the engine to me he had the fuel line >penetrating the intercylinder baffle through a grommet (he didn't know I was >going to use a crossover exhaust, so I had to re-plumb it to keep it away >from the exhaust) so I guess that's where I got the idea. But now I'm >wondering.... > >-- >Tom Sargent, RV-6A, final assembly. ________________________________________________________________________________
Date: Oct 24, 2009
Subject: Re: Mag & Alternator Cooling Blast Tubes...
At 07:56 PM 10/18/2009 Sunday, you wrote: > >Greetings Listers, > >I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't. I'm guessing the Slick Mags do. The directions are pretty clear on how to mount the tube in the baffle, but don't mention at all where to shoot the air in around the mag. Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? > >I've also got the PlanePower 60amp alternator that Van's sells. The instruction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do. Okay, great. But does that mean that it still needs a blast tube off the front baffle for cooling? If so, same question on the mags. Where's a good place to stick the cool air on the alternator? > >Thanks in advance for the feedback, > >Matt Dralle I never got any responses to this post, so I forged ahead. The tubes came out very nice. I ran a tube to the top of each mag about 1" above the surface. I opted to run a duct to the back of the primary 60a alternator. I opted *not* to run a duct to the 20a secondary alternator figuring that it would be off most of the time and didn't warrant the reduction in baffle chamber pressure by drilling yet another hole. I did opt to run a duct to the GPS antenna enclosure. This seems like an area that will get very hot on a hot day, and the sensitive electronics will probably prefer to be cooled. There are a couple of small holes in the back of the enclosure to allow the air to escape. Should provide plenty of cooling for the antennas. Attached are a few pictures for those that might be interested. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 24, 2009
Matt Dralle wrote: > At 07:56 PM 10/18/2009 Sunday, you wrote: > >> >> Greetings Listers, >> >> I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't. I'm guessing the Slick Mags do. The directions are pretty clear on how to mount the tube in the baffle, but don't mention at all where to shoot the air in around the mag. Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? >> >> I've also got the PlanePower 60amp alternator that Van's sells. The instruction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do. Okay, great. But does that mean that it still needs a blast tube off the front baffle for cooling? If so, same question on the mags. Where's a good place to stick the cool air on the alternator? >> >> Thanks in advance for the feedback, >> >> Matt Dralle >> > > > I never got any responses to this post, so I forged ahead. The tubes came out very nice. I ran a tube to the top of each mag about 1" above the surface. > > I opted to run a duct to the back of the primary 60a alternator. I opted *not* to run a duct to the 20a secondary alternator figuring that it would be off most of the time and didn't warrant the reduction in baffle chamber pressure by drilling yet another hole. > > I did opt to run a duct to the GPS antenna enclosure. This seems like an area that will get very hot on a hot day, and the sensitive electronics will probably prefer to be cooled. There are a couple of small holes in the back of the enclosure to allow the air to escape. Should provide plenty of cooling for the antennas. > > Attached are a few pictures for those that might be interested. > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > Hi Matt, Sorry that you didn't get a response earlier. I can't offer much insight on the mags, but the critical stuff in an alternator is typically under the sheet metal on the back, or just inside the case on the back. Having said that, I would determine which way the internal fan is trying to move air through the alternator, & supply the cool air to assist the flow, instead of fighting it. The quick&dirty way to check that is to use a drill to spin up the alternator in the correct rotation & feel for the air flow. Charlie ________________________________________________________________________________
Date: Oct 24, 2009
Hi Matt, Beautiful work and pictures as always. Regarding the antennas: that area during flight will not exceed 120 F IMHO. I believe that based on an extra digital temp probe I move around my engine compartment for testing of different areas. The tubes will work against you at shut down. Do you have the opportunity to get an extra temperature probe stuck in there? You seem like the kind of guy that would enjoy the extra data collection. And I know you have lots of electronics aboard! And regarding Alternator temps, my 70 amp never went above 160 F without cooling tube, although I normally have one. And that is the peak after shut down, peak in flight was 135 F without and 125 F with cooling tube. Dale RV6a 1245 hrs, O-360 A1A, dual electronic ignition, dual electric. GRT EFIS S200 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Saturday, October 24, 2009 6:28 PM Subject: Re: RV-List: Mag & Alternator Cooling Blast Tubes... At 07:56 PM 10/18/2009 Sunday, you wrote: > >Greetings Listers, > >I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't. I'm guessing the Slick Mags do. The directions are pretty clear on how to mount the tube in the baffle, but don't mention at all where to shoot the air in around the mag. Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? > >I've also got the PlanePower 60amp alternator that Van's sells. The instruction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do. Okay, great. But does that mean that it still needs a blast tube off the front baffle for cooling? If so, same question on the mags. Where's a good place to stick the cool air on the alternator? > >Thanks in advance for the feedback, > >Matt Dralle I never got any responses to this post, so I forged ahead. The tubes came out very nice. I ran a tube to the top of each mag about 1" above the surface. I opted to run a duct to the back of the primary 60a alternator. I opted *not* to run a duct to the 20a secondary alternator figuring that it would be off most of the time and didn't warrant the reduction in baffle chamber pressure by drilling yet another hole. I did opt to run a duct to the GPS antenna enclosure. This seems like an area that will get very hot on a hot day, and the sensitive electronics will probably prefer to be cooled. There are a couple of small holes in the back of the enclosure to allow the air to escape. Should provide plenty of cooling for the antennas. Attached are a few pictures for those that might be interested. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Oct 24, 2009
Matt, do you think water through the duct will hurt anything? Note sure you will get a lot of water but you will get some pretty wet air if you fly in the rain. Just wondering? Bill S 7a finishing -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Saturday, October 24, 2009 5:28 PM Subject: Re: RV-List: Mag & Alternator Cooling Blast Tubes... At 07:56 PM 10/18/2009 Sunday, you wrote: > >Greetings Listers, > >I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't. I'm guessing the Slick Mags do. The directions are pretty clear on how to mount the tube in the baffle, but don't mention at all where to shoot the air in around the mag. Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? > >I've also got the PlanePower 60amp alternator that Van's sells. The instruction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do. Okay, great. But does that mean that it still needs a blast tube off the front baffle for cooling? If so, same question on the mags. Where's a good place to stick the cool air on the alternator? > >Thanks in advance for the feedback, > >Matt Dralle I never got any responses to this post, so I forged ahead. The tubes came out very nice. I ran a tube to the top of each mag about 1" above the surface. I opted to run a duct to the back of the primary 60a alternator. I opted *not* to run a duct to the 20a secondary alternator figuring that it would be off most of the time and didn't warrant the reduction in baffle chamber pressure by drilling yet another hole. I did opt to run a duct to the GPS antenna enclosure. This seems like an area that will get very hot on a hot day, and the sensitive electronics will probably prefer to be cooled. There are a couple of small holes in the back of the enclosure to allow the air to escape. Should provide plenty of cooling for the antennas. Attached are a few pictures for those that might be interested. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Oct 24, 2009
Subject: Invitation! Lower Slobovia Garden Club's Pumpkin Drop, 2009
You're cordially invited to the "Lower Slobovia Garden Club" 3rd annual Pumpkin Drop, starting at 11:00 AM on Saturday, November 7, 2009. Lunch will be served at noon, and pumpkin drop demos begin around 2:00 PM. Contact info for driving directions is on the attached flyer; nav info is at http://www.airnav.com/airport/MS71 Y'all come! Charlie & Tupper, for the Lower Slobovia Garden Club members ________________________________________________________________________________
Date: Oct 24, 2009
At 07:18 PM 10/24/2009 Saturday, you wrote: > >Matt, do you think water through the duct will hurt anything? Note sure you >will get a lot of water but you will get some pretty wet air if you fly in >the rain. > >Just wondering? > >Bill S >7a finishing Hi Bill, Well, all five of the GPS antennas are meant to be mounted on the exterior of a vehicle. This would put then in the normal rain and weather directly. Seems that a little moist air would probably be alright. I'm a little concerned about the area not drying out and causing corrosion or rust. But it seems like the high temps should dry it out pretty quickly. Matt Dralle RV-8 #82882 N998RV http://www.mattsrv8.com Finishing Up FWF... ________________________________________________________________________________
Date: Oct 24, 2009
Matt, Just commenting on the blast tubes to your antenna tray:- It appears that you intend for the tray to screw to the cowling when it's in place, or tha t you intend to fix a cover to the top of the tray.- In either case, the tray will be a dead space without an area for the incoming air from the bla st tubes to exit.- In this case, the blast tube won't provide any cooling air flow, just positive ram air pressure during flight.- As others have pointed out, the tube may just create a conduit for heat soak to warm the a ntennas after a hot shut down.- I would probably leave those tube off of the antenna tray. Skylor RV-8 Under Construction (for way too long!) --- On Sat, 10/24/09, Matt Dralle wrote: From: Matt Dralle <dralle(at)matronics.com> Subject: Re: RV-List: Mag & Alternator Cooling Blast Tubes... Date: Saturday, October 24, 2009, 3:28 PM At 07:56 PM 10/18/2009- Sunday, you wrote: > >Greetings Listers, > >I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't.- I'm guessing the Slick Ma gs do.- The directions are pretty clear on how to mount the tube in the b affle, but don't mention at all where to shoot the air in around the mag. - Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? > >I've also got the PlanePower 60amp alternator that Van's sells.- The ins truction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do.- Okay, g reat.- But does that mean that it still needs a blast tube off the front baffle for cooling?- If so, same question on the mags.- Where's a good place to stick the cool air on the alternator? > >Thanks in advance for the feedback, > >Matt Dralle I never got any responses to this post, so I forged ahead.- The tubes cam e out very nice.- I ran a tube to the top of each mag about 1" above the surface. - I opted to run a duct to the back of the primary 60a alternator.- I opted *not* to run a duct to the 20a secondary alternator figuring that it would be off most of the time and didn't warrant the reduction in baffle chamber pressure by drilling yet another hole. I did opt to run a duct to the GPS antenna enclosure.- This seems like an area that will get very hot on a hot day, and the sensitive electronics wi ll probably prefer to be cooled.- There are a couple of small holes in th e back of the enclosure to allow the air to escape.- Should provide plent y of cooling for the antennas. Attached are a few pictures for those that might be interested. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog =0A=0A=0A ________________________________________________________________________________
Date: Oct 25, 2009
Matt, Many Lycomings have shrouds as well as blast tubes for the magnetos. I purchased a pair of used magneto shrouds from a local certified engine shop. Heat and vibration are the enemies of anything electrical, like magnetos and alternators. To properly protect an ND alternator, you need to understand how the cooling fans work. Your PlanePower ND alternator has two internal fans [mounted on the rotor shaft, internal to the cases]. These fans draw air in from both the front and the rear of the alternator case. This air is expelled through the slots located around the middle circumference of the alternator. Lycoming engines spin opposite to what most car engines rotate. Honda engines rotate clockwise, as do our Lycomings. This means that an ND alternator off of something other than a Honda, will have the fans running backwards. Planepower's brag relates to the fact that it has the correct fan rotation for optimum cooling [clockwise]. I would recommend that you either aim your blast tube towards the rear of your alternator. An even better option would be to fabricate a shroud for the rear of the alternator and install the blast tube to the shroud. See attached photos of David Brand's very nice alternator shroud. For folks using an ND alternator with internal fans which is NOT from a Honda, aim the blast tube at the slots around the circumference of the middle of the unit. Since the fans will be running in reverse, the air is being drawn in where it should be expelled. I hope this helps. Charlie Kuss PS I'll try to take a photo of my magneto shrouds later today. I'm looking over this cooling blast tube kit from Van's (DUCT CBT-5/8) and deciding what needs cooling and what doesn't. I'm guessing the Slick Mags do. The directions are pretty clear on how to mount the tube in the baffle, but don't mention at all where to shoot the air in around the mag. Is just in the general vacineity good enough, or is there a little hole in the mag that wants fresh air? > >I've also got the PlanePower 60amp alternator that Van's sells. The instruction booklet that comes with it brags about how, because of its design, it runs much cooler that traditional automobile conversions do. Okay, great. But does that mean that it still needs a blast tube off the front baffle for cooling? If so, same question on the mags. Where's a good place to stick the cool air on the alternator? > >Thanks in advance for the feedback, > >Matt Dralle ________________________________________________________________________________
Date: Oct 25, 2009
Charlie, do you know what aircraft the shrouds came from??? I've never seen them! 'Course I'm no expert either! ! My little Grumman (AA-1B O-235) does have a cooling shroud ..... around the oil screen ..... which has the temp probe ..... to get past the FAA testing! Linn Charles Kuss wrote: > Matt, > Many Lycomings have shrouds as well as blast tubes for the magnetos. ________________________________________________________________________________
Date: Oct 25, 2009
Linn, I'm not sure. Might have been off of a Piper Cherokee??? Charlie --- On Sun, 10/25/09, Linn Walters wrote: > From: Linn Walters <pitts_pilot(at)bellsouth.net> > Subject: Re: RV-List: Mag & Alternator Cooling Blast Tubes... > To: rv-list(at)matronics.com > Date: Sunday, October 25, 2009, 12:51 PM > Linn Walters > > Charlie, do you know what aircraft the shrouds came > from??? I've never seen them! 'Course I'm no > expert either! ! > > My little Grumman (AA-1B O-235) does have a cooling shroud > ..... around the oil screen ..... which has the temp > probe ..... to get past the FAA testing! > Linn > > Charles Kuss wrote: > > Matt, > > Many Lycomings have shrouds as well as blast > tubes for the magnetos. > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Oct 26, 2009
Here are some photos I took of the magneto cooling shrouds. Charlie ________________________________________________________________________________
Date: Oct 26, 2009
At 06:05 AM 10/26/2009 Monday, you wrote: >Here are some photos I took of the magneto cooling shrouds. >Charlie Where do they fit on the mag exactly? Matt ________________________________________________________________________________
Date: Oct 26, 2009
Subject: Wheelpants & Fairings
I'm having one hell of a time figuring out how to best attach the wheel pan ts on my -8A nosedragger. I can usually figure out what to do after reading the directions several times and staring at the plans. In this case, I see m to have developed a terminal brain fart. Spent a lot of time searching VA F and builder sites, but have not yet found one that gets into the details of pants attachment, although several sites provide options for pants and fairing alignment. Anyone have any words of wisdom - or good links? I have the hinges riveted and the leg fairings on, am awaiting a Fairings-etc shipment, but am frozen regarding cutting and drilling the pants. One would think that anyone who figured out Vans baffle kit directions woul d find the fairings a breeze - but not so. Thanks in advance. Paul Valovich Booger N192NM ________________________________________________________________________________
Date: Oct 27, 2009
Charlie.... Are the shrouds for a Slick or Bendix? If for Slick, where/how do they attach. Curious Chris in Oregon RV-8 Overhauling IO-360 A1B6 -----Original Message----- >From: Charles Kuss <chaskuss(at)yahoo.com> >Sent: Oct 26, 2009 9:05 AM >To: RV List >Subject: Re: RV-List: Mag & Alternator Cooling Blast Tubes... > >Here are some photos I took of the magneto cooling shrouds. >Charlie > > > ________________________________________________________________________________
Date: Oct 27, 2009
Chris, These are for Bendix [now TCM] magnetos. The top of the magneto is held on with 5 machine screws. The mounting brackets nest between the heads of 4 of those top screws and the top cap of the magneto. Something similar could be fashioned for the Slick units. Making them out of composite may allow a better fit with less work. Charlie --- On Tue, 10/27/09, Chris Stone wrote: > From: Chris Stone <rv8iator(at)earthlink.net> > Subject: Re: RV-List: Mag & Alternator Cooling Blast Tubes... > To: rv-list(at)matronics.com > Date: Tuesday, October 27, 2009, 9:42 AM > Chris Stone > > Charlie.... > > Are the shrouds for a Slick or Bendix? If for Slick, > where/how do they attach. > > Curious Chris in Oregon > RV-8 > Overhauling IO-360 A1B6 > > -----Original Message----- > >From: Charles Kuss <chaskuss(at)yahoo.com> > >Sent: Oct 26, 2009 9:05 AM > >To: RV List > >Subject: Re: RV-List: Mag & Alternator Cooling > Blast Tubes... > > > >Here are some photos I took of the magneto cooling > shrouds. > >Charlie > > > > > > > > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Nov 01, 2009
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's solely through the Contributions of List members that these Matronics Lists are possible. There is NO advertising to support the Lists. You might have noticed the conspicuous lack of flashing banners and annoying pop-ups on the Matronics Email List email messages and web site pages such as the Matronics List Forums ( http://forums.matronics.com ), the List Wiki ( http://wiki.matronics.com), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), the List Browser ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Using the firmer engine mounts.
Date: Nov 01, 2009
I only have 280 or so hrs on my 6a, but engine saging at least 3/8th inch at prop. I can lift it up about 1/4 inch, so mounts need replacing for sure. I have heard of the aerobatic mounts, Im told they can make for more vibration, being stiffer. Think its counter productive to use Vans as replacement, as these have relative low time. I dont realy do much arebatics, but like to do up to 5g pulls. Would like coments from anyone who has replaced mounts with the stiffer ones. Charlie H ________________________________________________________________________________
Date: Nov 01, 2009
Subject: Re: Using the firmer engine mounts.
The stiffer aerobatic mounts keep the engine from moving around during violent maneuvers. Your mount sagging is plainly due to constant pressure, not the transient pressure of aerobatics. My suggestion ..... because I'm cheap .... is to place washers under the lower mounts to raise the engine back up. My experience says that once the mounts are compressed and have some age on them ..... they quit sagging. At some point you may want to swap the top ones with the bottom. Remember that the harder the mounts, the more vibration is transferred to the airframe with fatigue becoming a problem .... especially if you have mechanical gyros. Linn charlie heathco wrote: > I only have 280 or so hrs on my 6a, but engine saging at least 3/8th > inch at prop. I can lift it up about 1/4 inch, so mounts need > replacing for sure. I have heard of the aerobatic mounts, Im told they > can make for more vibration, being stiffer. Think its counter > productive to use Vans as replacement, as these have relative low > time. I dont realy do much arebatics, but like to do up to 5g pulls. > Would like coments from anyone who has replaced mounts with the > stiffer ones. Charlie H > * > > > * ________________________________________________________________________________
Subject: Airing up the tires through the wheel pants.
Date: Nov 01, 2009
My Wheel pants have been installed on my airplane for less than a year and I am already finding the disadvantage of checking/ filling the air in the tires. I am sure there has been discussion of putting holes in the wheel pants for access to the valve stem. Does anyone have any photos on their building sites of where to put these holes, how big, and what if anything is used to plug the holes? I would appreciate any feedback on this simple thing. Thanks Tim Bryan RV-6 Frankston, Texas The pursuit of happiness is the chase of a lifetime! ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Airing up the tires through the wheel pants.
Date: Nov 01, 2009
I purchased little snap in plugs at Home Depot. They carry sizes ranging from 1/4" to over 1". I think mine are 7/8". The plugs come in plastic and polished (stainless?) steel. I got the steel ones. Aircraft Spruce also carries little hinged doors if you want to spend 20 bucks instead of $2. To locate the holes, all I did was measure the distance from the axle of the wheel to the center of the valve stem, then drilled a 7/8" hole that distance from the hole in the wheelpant where the bolt goes into the axle nut. It was probably 2" or 2 1/4", but don't trust that measurement - measure for yourself. On mine, the hole is in the front half of the wheelpant, but I'm not sure that's important. Kyle Boatright 2001 RV-6 ----- Original Message ----- From: N616TB To: rv-list(at)matronics.com Sent: Sunday, November 01, 2009 8:57 AM Subject: RV-List: Airing up the tires through the wheel pants. My Wheel pants have been installed on my airplane for less than a year and I am already finding the disadvantage of checking/ filling the air in the tires. I am sure there has been discussion of putting holes in the wheel pants for access to the valve stem. Does anyone have any photos on their building sites of where to put these holes, how big, and what if anything is used to plug the holes? I would appreciate any feedback on this simple thing. Thanks Tim Bryan RV-6 Frankston, Texas The pursuit of happiness is the chase of a lifetime! ________________________________________________________________________________
Date: Nov 01, 2009
I had the same issue, installed washers and it fixed the issue. Sent from my iPhone On Nov 1, 2009, at 8:34 AM, Linn Walters wrote: > The stiffer aerobatic mounts keep the engine from moving around > during violent maneuvers. Your mount sagging is plainly due to > constant pressure, not the transient pressure of aerobatics. My > suggestion ..... because I'm cheap .... is to place washers under > the lower mounts to raise the engine back up. My experience says > that once the mounts are compressed and have some age on them ..... > they quit sagging. At some point you may want to swap the top ones > with the bottom. Remember that the harder the mounts, the more > vibration is transferred to the airframe with fatigue becoming a > problem .... especially if you have mechanical gyros. > Linn > > > charlie heathco wrote: >> >> I only have 280 or so hrs on my 6a, but engine saging at least >> 3/8th inch at prop. I can lift it up about 1/4 inch, so mounts need >> replacing for sure. I have heard of the aerobatic mounts, Im told >> they can make for more vibration, being stiffer. Think its counter >> productive to use Vans as replacement, as these have relative low >> time. I dont realy do much arebatics, but like to do up to 5g >> pulls. Would like coments from anyone who has replaced mounts with >> the stiffer ones. Charlie H >> >> >> href="http://www.aeroelectric.com">www.aeroelectric.com >> href="http://www.buildersbooks.com">www.buildersbooks.com >> href="http://www.homebuilthelp.com">www.homebuilthelp.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List >> href="http://forums.matronics.com">http://forums.matronics.com >> > > ________________________________________________________________________________
Subject: engine mount washers
Date: Nov 02, 2009
Thanks for the info re washers, now who is the math whiz that knows how thick the washer should be to raise the front 3/8"? I heard mention of cutting a slot to enable sliping behind mount, anyone done this? ________________________________________________________________________________
Subject: Re: engine mount washers
Date: Nov 02, 2009
Kelly, Lynn, others, This may be a dumb question, but wondering if everyone is talking the same location for washers. I have seen washers mounted under isolation mounts as it seems most are talking about but I have also seen 970's added under the engine mount to firewall gussets. I have used both locations for different purposes. One to reposition the isolation mount geometry and one to reposition the whole mount and engine. I know of one occasion where the spacer inside the mount was reduced in length to tighten up the isolation mount. I would think they present different problems and or solutions. The engine tends to change it's weight on the mounts during flight and moves around a lot during cranking, shutdown and anything other than 1 G flight. On the other hand the mount to firewall fit is more rigid and tends to stay where you bolt it. However a loose bolt or lost washer at that location is possibly more troublesome as the bolt size there may not be sufficient, given the abuse that occurs when they are loose. I also have a sagging engine and was planning on going with one or two 970's between the mount and firewall, but also realize that in flight the engine may not be sagging as much. It seems that most commenting on this thread are putting a 970 washer under the isolation mount but I don't see how that will tighten up the isolation mount without treating the internal spacer. I don't do any negative G stuff (on purpose anyway) and generally never exceed 3 to 3.5 G positive but the engine still moves around a lot with gyroscopic actions as well as simple G loads. Is the concensus that short of changing out the mounts, the best approach is to washer up the isolation mounts? I know the best solution would probably be to replace the kit iso mounts with Lord mounts but what is the consensus for next best solution. John Myers with a little sag with a 360 on an 8 ________________________________________________________________________________
Date: Nov 02, 2009
To answer your-question-it is very simple, you need an access-hole (s quare or round) and a plug or cover. You just have to align it with the valve stem. You'll use an air-chuck with an extension. The most common access is round and one of those SNAP-IN BUTTON COVERS-or PLUGS-(or hole plugs), in metal or plastic/nylon. - http://www.surplussales.com/MetalPlugs/MetalHolePlugs.html - http://www.widgetco.com/hole-plugs - http://www.surplussales.com/Rubber-Plastic/Plastic-1.html - You need to figure out what air tool you will use, for the geometry. - http://www.drillspot.com/products/41080/Dynaquip_AC45_Straight_Body_Air_Chu ck (this is best, with a length of brass tube as needed) - http://www.savinglots.com/lotprod.asp?item=JL5010N (takes up a little more room with the side fitting) - Just a stripe of white paint where the air-stem is so you can align it with the hole in the wheel pants will make it easier. Also to check the air-pressure , you can use the same air-check to a quick disconnect. Than you just plug in the AIR-GAGE into the quick disconnect. So you will need the following: - -Hole Plug -Straight Air-Chuck -Female quick disconnect -Air-Gage with male quick disconnect -Small length of brass tube with 1/4" NFPT (threaded ends) (you can bend the brass pipe slightly than cut, than-thread if you want a slight-angle) (if you use an angle or dual air-chuck you will need at least a-1.25" hol e) - My solution was to use good quality tubes, tires and nitrogen,-so I don't have- to deal with checking or filling them as often. However having access is a good idea. However to get half-back half- of my wheel pants off is-only a handful of Philips screws; it takes about a minute to remove or install. So I decided against it. - Others make a square hole with a small hinged cover to make LOTS of room so you can put in any old big dual chuck, with out having the tire rotated -the tire just the right spot. - - >My Wheel pants have been installed on my airplane for less than a year and I >am already finding the disadvantage of checking/ filling the air in the >tires.- I am sure there has been discussion of putting holes in the whee l >pants for access to the valve stem.- Does anyone have any photos on thei r >building sites of where to put these holes, how big, and what if anything is >used to plug the holes?- I would appreciate any feedback on this simple >thing.=0A=0A=0A ________________________________________________________________________________
Date: Nov 02, 2009
John Myers wrote: > > Kelly, Lynn, others, > > This may be a dumb question, It'll be the first one! but wondering if everyone is talking the > same location for washers. I have seen washers mounted under isolation > mounts as it seems most are talking about but I have also seen 970's > added under the engine mount to firewall gussets. I have used both > locations for different purposes. One to reposition the isolation mount > geometry and one to reposition the whole mount and engine. I know of > one occasion where the spacer inside the mount was reduced in length to > tighten up the isolation mount. I would think they present different > problems and or solutions. The engine tends to change it's weight on > the mounts during flight and moves around a lot during cranking, > shutdown and anything other than 1 G flight. On the other hand the mount > to firewall fit is more rigid and tends to stay where you bolt it. > However a loose bolt or lost washer at that location is possibly more > troublesome as the bolt size there may not be sufficient, given the > abuse that occurs when they are loose. The mount bolts are not as accessible (like on the inside) as the isolators, so I typically work on the isolators. Putting washers under one or two of the airframe bolts also stresses the steel mount. Just MHO. > > I also have a sagging engine and was planning on going with one or two > 970's between the mount and firewall, but also realize that in flight > the engine may not be sagging as much. It seems that most commenting on > this thread are putting a 970 washer under the isolation mount but I > don't see how that will tighten up the isolation mount without treating > the internal spacer. The washer goes forward of the isolator and the flat on the engine mounting ears if you have the ring type isolator mounts. On mounts where the isolator is cone shaped and sandwiches the mounting ear, then the washer will be behind the isolator. > > I don't do any negative G stuff (on purpose anyway) and generally never > exceed 3 to 3.5 G positive but the engine still moves around a lot with > gyroscopic actions as well as simple G loads. Is the concensus that > short of changing out the mounts, the best approach is to washer up the > isolation mounts? I know the best solution would probably be to replace > the kit iso mounts with Lord mounts but what is the consensus for next > best solution. > > John Myers with a little sag with a 360 on an 8 I'd use the washer method before spending so much money on new isolators. I've seen no difference in who makes them .... in my limited experience. I think the consensus is ..... whatever you prefer. No matter what route you take, the end result should be the same. Best of luck. Linn > > > > > > ________________________________________________________________________________
Subject: RV6 jig
Date: Nov 02, 2009
Anyone within striking distance of Portland have a -6/6a fuselage jig I co uld beg/borrow/steal or know someone who does? Cheers, Jerry Cochran ________________________________________________________________________________
Date: Nov 02, 2009
From: George Inman 204 287 8334 <ghinman(at)mts.net>
For filling tires through wheel pants I used KM713-16-064 -from aircraft spruce. I also needed a tire valve extension I got mine from Cleavland tool http://www.cleavelandtoolstore.com/prodinfo.asp?number=VSE5 -- George H. Inman ghinman(at)mts.net Home 204 287 8334 Cell 204 799 7062 ________________________________________________________________________________
Date: Nov 03, 2009
Subject: November List Fund Raiser
A couple of years ago I implemented an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, he or she will instantly cease to receive these Fund Raiser messages for the rest of the month! Its just that simple. Don't you wish PBS worked that way! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: MSP towing
Date: Nov 03, 2009
It's time to move the fuselage to the airport and we're wondering if anyone in the Twin Cities has a flatbed towing company they prefer or who has done this before and understands the attention to detail and special handling required. Thanks, Chris Knauf RV-7, N707HK ________________________________________________________________________________
Subject: Re: Engine mount washer thickness calculation
Date: Nov 03, 2009
You'll have to do some measuring to figure out the width of the washers, but my schoolboy trig would have it that the thickness of the washers would be given by: Thickness required = 3/8" * Distance from top mounting bolts to bottom mounting bolts/Distance from top mounting bolts to base of spinner. This is based on the sine law. The triangle having the angle that includes the 3/8" measurement and the triangle that includes the required washer calculation would both have the same angle (sine). Opposite over hypotenuse in both cases becomes the same value. So, measure the distance from the firewall to the spinner and from the top to the bottom mounting bolts and divide the smaller number by the bigger one and use it to multiply by the height required (3/8", .375" or .9525 millimeters). Good luck, Ian Brown, RV-9A Bromont, Quebec > From: "charlie heathco" <cheathco(at)cox.net> > Subject: RV-List: engine mount washers > > Thanks for the info re washers, now who is the math whiz that knows how > thick the washer should be to raise the front 3/8"? I heard mention of > cutting a slot to enable sliping behind mount, anyone done this? ________________________________________________________________________________
Date: Nov 03, 2009
Subject: Re: MSP towing
Chris, I transported mine twice using a fellow pilot's flatbed trailer. Wings, wheels, and engine mount were not attached. I was told that the engine should not be attached as the road bounces would cause damage. Foam underneath, straps and come-alongs to hold it in place - no issues. I've got a few pictures - zap me direct.... Ralph -----Original Message----- >From: Chris Knauf <cknauf(at)comcast.net> >Sent: Nov 3, 2009 10:55 AM >To: rv-list(at)matronics.com >Subject: RV-List: MSP towing > >It's time to move the fuselage to the airport and we're wondering if anyone >in the Twin Cities has a flatbed towing company they prefer or who has done >this before and understands the attention to detail and special handling >required. > > > >Thanks, > >Chris Knauf > >RV-7, N707HK > ________________________________________________________________________________
Date: Nov 03, 2009
On Tue, 3 Nov 2009, Ralph E. Capen wrote: > > Chris, > > I transported mine twice using a fellow pilot's flatbed trailer. > Wings, wheels, and engine mount were not attached. I was told that the engine should not be attached as the road bounces would cause damage. Foam underneath, straps and come-alongs to hold it in place - no issues. > > I've got a few pictures - zap me direct.... > Just moved mine to a two-car garage, pictures at: http://www.xmission.com/~bifft/plane/ went really easy. Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 organizing new garage. 1/4 Starduster II N23UT flying ________________________________________________________________________________
Date: Nov 03, 2009
In my case, the engine was attached to the fuselage (along with the entire empennage, canopy and landing gear) and it made it 30 miles to the airport on a flat bed trailer. No sign of damage to the engine after 1600 hrs. over the last 17 years. Ivan Haecker -4 S. Cen. TX ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Tuesday, November 03, 2009 10:26 AM Subject: Re: RV-List: MSP towing > > Chris, > > I transported mine twice using a fellow pilot's flatbed trailer. > Wings, wheels, and engine mount were not attached. I was told that the > engine should not be attached as the road bounces would cause damage. > Foam underneath, straps and come-alongs to hold it in place - no issues. > > I've got a few pictures - zap me direct.... > > Ralph > > -----Original Message----- >>From: Chris Knauf <cknauf(at)comcast.net> >>Sent: Nov 3, 2009 10:55 AM >>To: rv-list(at)matronics.com >>Subject: RV-List: MSP towing >> >>It's time to move the fuselage to the airport and we're wondering if >>anyone >>in the Twin Cities has a flatbed towing company they prefer or who has >>done >>this before and understands the attention to detail and special handling >>required. >> >> >> >>Thanks, >> >>Chris Knauf >> >>RV-7, N707HK >> > > > ________________________________________________________________________________
Subject: RV-8 photo in FAA Aviation news Nov/Dec 09 edition
Date: Nov 04, 2009
The FAA publishes a bimonthly Aviation News magazine that you've probably p icked up at Sun N Fun or Air Venture. Anyway=2C the Nov edition shows an b eautiful red=2C RV-8 (page 12). You can find it at: http://www.faa.gov/news/aviation_news/2009/media/NovDe c2009.pdf (In full disclosure=2C I'm employed by the FAA and have authored several ar ticles in the past.) Marty Heller RV-7 (Cowling and Baffling) _________________________________________________________________ Bing brings you maps=2C menus=2C and reviews organized in one place. http://www.bing.com/search?q=restaurants&form=MFESRP&publ=WLHMTAG&cre a=TEXT_MFESRP_Local_MapsMenu_Resturants_1x1 ________________________________________________________________________________
Date: Nov 04, 2009
Subject: MSP towing
I just hooked a trailer hitch to the tail of my RV-8 and towed it on its own wheels. The engine was attached,but no empenage or wings. It worked great.The bearings got a bit hot,but no damage. It's time to move the fuselage to the airport and we're wondering if anyone in the Twin Cities has a flatbed towing company they prefer or who has done this before and understands the attention to detail and special handling required. Thanks, Chris Knauf -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Subject: MSP Towing
Date: Nov 04, 2009
FWIW, when I moved my 9A fuselage with engine mounted I used a U-Haul box van. The dimensions are slightly wider than the footprint of the 9A but the doorway is slightly narrower. This meant getting the aircraft up ramps to the almost-in position, and then doing a sideways jog to get the wheel nuts past the door frame. It was a fairly short trip but I had no problem moving it with the engine mounted - either during or after. The engine/prop were sticking out of the open door! If the mount is designed to withstand a hard landing I assume it's also built to withstand similar stresses on a road trip. By the way, if you try to do this, the typical U-Haul van comes with only one ramp. I used a ladder with an assortment of boards on it for the other main wheel, and friends to balance the nosewheel to the right angle. A combination of a come-along and people turning the wheels by hand managed to get it up the ramp nicely. Ian Brown, C-GOHM, Bromont, QC > From: "Chris Knauf" <cknauf(at)comcast.net> > Subject: RV-List: MSP towing > > It's time to move the fuselage to the airport and we're wondering if anyone > in the Twin Cities has a flatbed towing company they prefer or who has done > this before and understands the attention to detail and special handling > required. > > > Thanks, > > Chris Knauf ________________________________________________________________________________
Date: Nov 04, 2009
Subject: R&B Aircraft (Topeka) Feedback?
I'm thinking of having R&B Aircraft in Topeka paint my RV. I'd appreciate feedback from anyone with experience with them. "Jerry" Riffel 108 Hrs RV-7A ________________________________________________________________________________
Subject: Re: RV-List Digest: 7 Msgs - 11/03/09
Date: Nov 05, 2009
"Ralph E. Capen" SAID >Chris, >. I was told that the engine >should not be attached as the road bounces would cause damage. >Ralph Wow, all that bouncing around taxiing on rough strips, t hose multiple landings I often do, the rollouts on gravel strips etc must be doing a lot of damage is this theory is true! Sometimes you can't believe everything you are told. Mick the skeptic ________________________________________________________________________________
Date: Nov 05, 2009
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: compass location
Date: Nov 05, 2009
We are finalizing our panel design and are looking for the least unacceptable location for a whiskey or vertical card compass. I have read that they never work if panel mounted and some find the glare shield location unacceptable. We will , hopefully , have the Dynon Skyview system and a 430. It would be nice if the compass worked. If it is only going to be for looks I guess it wouldn't matter where we put it..Thanks ________________________________________________________________________________
Date: Nov 05, 2009
I had same problem. I solved it by purchasing the "Leak Proof" inner tubes from Desser tire and rubber. I now find that I loose less than one pound of air per month. I also went with the Goodyear custome 3 tire. No problems over the last 500 hours. Dick Martin RV8 N233M ----- Original Message ----- From: N616TB To: rv-list(at)matronics.com Sent: Sunday, November 01, 2009 7:57 AM Subject: RV-List: Airing up the tires through the wheel pants. My Wheel pants have been installed on my airplane for less than a year and I am already finding the disadvantage of checking/ filling the air in the tires. I am sure there has been discussion of putting holes in the wheel pants for access to the valve stem. Does anyone have any photos on their building sites of where to put these holes, how big, and what if anything is used to plug the holes? I would appreciate any feedback on this simple thing. Thanks Tim Bryan RV-6 Frankston, Texas The pursuit of happiness is the chase of a lifetime! ________________________________________________________________________________
Date: Nov 05, 2009
I drilled I believe a 1 inch hole in the side of the wheel pant and used one of those metal covers that are used one the top of a Piper Cherokee wing to cover the strut schrader valve. Then just get a valve core extension screw it in and you are good to go. Worked fine. Bill Mahoney In a message dated 11/5/2009 11:03:52 A.M. Eastern Standard Time, martin(at)gbonline.com writes: I had same problem. I solved it by purchasing the "Leak Proof" inner tubes from Desser tire and rubber. I now find that I loose less than one pound of air per month. I also went with the Goodyear custome 3 tire. No problems over the last 500 hours. Dick Martin RV8 N233M ----- Original Message ----- From: _N616TB_ (mailto:n616tb(at)btsapps.com) Sent: Sunday, November 01, 2009 7:57 AM Subject: RV-List: Airing up the tires through the wheel pants. My Wheel pants have been installed on my airplane for less than a year and I am already finding the disadvantage of checking/ filling the air in the tires. I am sure there has been discussion of putting holes in the wheel pants for access to the valve stem. Does anyone have any photos on their building sites of where to put these holes, how big, and what if anything is used to plug the holes? I would appreciate any feedback on this simple thing. Thanks Tim Bryan RV-6 Frankston, Texas The pursuit of happiness is the chase of a lifetime! href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator? RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?RV-List) ________________________________________________________________________________
Subject: Re: compass location
Date: Nov 05, 2009
I bought a Pegasus from AC Spruce. I moved it around on the completed panel which was powered at the time. I found an area on the right side of the panel where there was no interferance and mounted the compas there. It seems to be working well 1.5 yes later. Good luck Dave Sent from my iPhone with fat fingers On Nov 5, 2009, at 3:08 AM, Glenn Bell wrote: > We are finalizing our panel design and are looking for the least > unacceptable location for a whiskey or vertical card compass. I have > read that they never work if panel mounted and some find the glare > shield location unacceptable. We will , hopefully , have the Dynon > Skyview system and a 430. It would be nice if the compass worked. > If it is only going to be for looks I guess it wouldn=99t matter where > we put it..Thanks > > ________________________________________________________________________________
Date: Nov 05, 2009
Glenn Bell wrote: > We are finalizing our panel design and are looking for the least > unacceptable location for a whiskey or vertical card compass. I have read > that they never work if panel mounted and some find the glare shield > location unacceptable. We will , hopefully , have the Dynon Skyview system > and a 430. It would be nice if the compass worked. If it is only going to > be for looks I guess it wouldn't matter where we put it..Thanks > Just wondering why you are installing a compass. The Dynon satisfies the requirement to have a magnetic heading indicator. Sam Buchanan ________________________________________________________________________________
Date: Nov 06, 2009
I think only half the idea was expressed. The real concern would be to mount the engine on a temp basis, with bolts to the firewall NOT torqued properly. Then it could bounce around and hammer the mount area. Similar lesson to the story of the canopy that was not secured. Same could happen if wings were not properly secured. Dale -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mick Muller Sent: Wednesday, November 04, 2009 9:13 PM Subject: RV-List: Re: RV-List Digest: 7 Msgs - 11/03/09 "Ralph E. Capen" SAID >Chris, >. I was told that the engine >should not be attached as the road bounces would cause damage. >Ralph Wow, all that bouncing around taxiing on rough strips, t hose multiple landings I often do, the rollouts on gravel strips etc must be doing a lot of damage is this theory is true! Sometimes you can't believe everything you are told. Mick the skeptic ________________________________________________________________________________
Date: Nov 06, 2009
Subject: Apollo GX-60 with a Dynon??
Has anyone flown with a Dynon EFIS & Apollo GX60 (for IFR)? If so, is it a reasonable combination? Is the HS34 required or advisable, and can the Dynon serve as the CDI for approaches? I'm not yet instrument rated & *if* I can get around to getting the rating, I'll still be a big enough coward to only use it to get up through and back down through a layer to good conditions. It's hard to justify the money for a 430W when there's a good chance I'll never use its real power, & GX60's can be had for a much more tolerable price. Thanks for any insight, Charlie ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Air in fuel lines
Date: Nov 06, 2009
Hi all: Been having a lot of trouble with a rough idle problem on my Fuel Injected 0-360 parallel valve engine. I've been going through several tests trying to locate the source of the problem but so far no joy. One suggestion that I have received concerns air getting into the fuel lines. It seems a little far fetched that air could get in through a fitting that is not leaking fuel but I'm running out of ideas so I'll go through and tighten all my fittings to see if that helps. But, that leaves one other possibility and that's air getting in through the fuel selector valve. I'm using the Van's fuel selector that came with my RV-6 kit. It sat in its little brown bag on the shelf in my shop for several years before it got used but seems to working fine. It's not hard to move the selector and its not leaking, at least externally. Anyone experience leaking of this valve or any issue with that might let air into the fuel lines through it? Any ideas on how I might test the valve to see if it's leaking air into the system? I'm using the Van's high pressure pump setup that puts the pump ahead of the selector valve so there will be some suction at the valve. I'm running out of ideas and thinking about switching to a carb. Hate to do that but can't find anything wrong after working on it for the last year, maddening. Thanks. Dean Psiropoulos RV-6A N197DM ________________________________________________________________________________
Date: Nov 07, 2009
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle PO Box 347 Livermore, CA 94551-0347 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 07, 2009
Charlie=2C We have been flying with a Dynon D-10 and the Apollo GX55 for about 4 years now without any problems at all. Very stable platform for instrument appr oaches. I hope that helps Mike Robertson Das Fed > Date: Fri=2C 6 Nov 2009 19:55:02 -0600 > From: ceengland(at)bellsouth.net > To: rv-list(at)matronics.com > Subject: RV-List: Apollo GX-60 with a Dynon?? > > > Has anyone flown with a Dynon EFIS & Apollo GX60 (for IFR)? If so=2C is i t > a reasonable combination? Is the HS34 required or advisable=2C and can th e > Dynon serve as the CDI for approaches? > > I'm not yet instrument rated & *if* I can get around to getting the > rating=2C I'll still be a big enough coward to only use it to get up > through and back down through a layer to good conditions. It's hard to > justify the money for a 430W when there's a good chance I'll never use > its real power=2C & GX60's can be had for a much more tolerable price. > > Thanks for any insight=2C > > Charlie > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Find the right PC with Windows 7 and Windows Live. http://www.microsoft.com/Windows/pc-scout/laptop-set-criteria.aspx?cbid=w l&filt 0=2C2400=2C10=2C19=2C1=2C3=2C1=2C7=2C50=2C650=2C2=2C12=2C0=2C100 0&cat=1=2C2=2C3=2C4=2C5=2C6&brands=5=2C6=2C7=2C8=2C9=2C10=2C11=2C12=2C1 3=2C14=2C15=2C16&addf=4=2C5=2C9&ocid=PID24727::T:WLMTAGL:ON:WL:en-US:WW L_WIN_evergreen2:112009 ________________________________________________________________________________
Subject: Re: Apollo GX-60 with a Dynon??
Date: Nov 07, 2009
Charlie, Garmin is in essence no longer going to support for the GX 50/55/50/65 series. They are offering a $2000 trade-in on those units through the end of the year for a 430W, etc. Mark ________________________________________________________________________________
Date: Nov 07, 2009
Mark Swaney wrote: > > Charlie, > Garmin is in essence no longer going to support for the GX 50/55/50/65 > series. They are offering a $2000 trade-in on those units through the > end of the year for a 430W, etc. > Mark Hmmm... Thanks to everyone for their answers. This is starting to look like when the surgeon came out & told the family, "The operation was a success, but the patient died." What does the discontinuation of support really mean? No repairs, no IFR legal database updates, etc, or just no new software updates? Thanks, Charlie ________________________________________________________________________________
Date: Nov 07, 2009
There are no replacement display panels. When the panel dies the unit is nothing but a spare parts unit. Garmin chose to not acquire any spares beyond what they got when they bought the company. Charlie England wrote: > > Mark Swaney wrote: >> >> Charlie, >> Garmin is in essence no longer going to support for the GX 50/55/50/65 >> series. They are offering a $2000 trade-in on those units through the >> end of the year for a 430W, etc. >> Mark > > Hmmm... > > > Thanks to everyone for their answers. This is starting to look like when > the surgeon came out & told the family, "The operation was a success, > but the patient died." > > What does the discontinuation of support really mean? No repairs, no IFR > legal database updates, etc, or just no new software updates? > > Thanks, > > Charlie > > > > ________________________________________________________________________________
Date: Nov 09, 2009
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2009
Subject: Phase I testing done!
Saturday afternoon I finished my hours and test plan - actually went over my required hours in order to get the Vx and Vy numbers. Sunday, I took my first trip 'out-of-the-box' and went to Soup on Sunday at Campbell field. Lots of planes there and plenty of RV's. A USCG C-130 came by and did a low pass (for a C-130 anyway) over the field. Hot dog, soda and a cupcake for a stuffing of the donation box. Next will be to give my wife Alane her ride as the first passenger (she had a prior committment Sunday and couldn't make 9VG) - then we'll be doing some VFR travelling and I get to start work on my IFR ticket. Let the (more) fun begin, Ralph Capen RV6A N822AR @ N06 43.8 hrs ________________________________________________________________________________
Date: Nov 09, 2009
Congrats on another milestone.............Bravo Zulu (well Done) Frank @ 1L8 ...RV7A... N74BZ .... Flying > Date: Mon=2C 9 Nov 2009 08:16:01 -0500 > From: recapen(at)earthlink.net > To: rv-list(at)matronics.com > Subject: RV-List: Phase I testing done! > > > Saturday afternoon I finished my hours and test plan - actually went over my required hours in order to get the Vx and Vy numbers. > > Sunday=2C I took my first trip 'out-of-the-box' and went to Soup on Sunda y at Campbell field. Lots of planes there and plenty of RV's. A USCG C-130 came by and did a low pass (for a C-130 anyway) over the field. Hot dog=2C soda and a cupcake for a stuffing of the donation box. > > Next will be to give my wife Alane her ride as the first passenger (she h ad a prior committment Sunday and couldn't make 9VG) - then we'll be doing some VFR travelling and I get to start work on my IFR ticket. > > Let the (more) fun begin=2C > > Ralph Capen > RV6A N822AR @ N06 43.8 hrs > > > =========== =========== =========== =========== > > > _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Nov 10, 2009
Subject: Re: Please Make A Contribution To Support Your Lists
In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: http://www.matronics.com/contribution I tried but got an error and I do not wish to re enter my credit card information. Sorry! ________________________________________________________________________________
Date: Nov 10, 2009
At 03:52 PM 11/10/2009 Tuesday, you wrote: >In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: >http://www.matronics.com/contribution > >I tried but got an error and I do not wish to re enter my credit card information. > >Sorry! The log indicates that you didn't enter all of the card information on the contribution page. This was likely the expiration date or the name on the card. Please give it another try and be certain that you've filled in all of the necessary fields. http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 10, 2009
Matt accepts checks! Terry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rquinn1(at)aol.com Sent: Tuesday, November 10, 2009 3:53 PM Subject: Re: RV-List: Please Make A Contribution To Support Your Lists In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: http://www.matronics.com/contribution I tried but got an error and I do not wish to re enter my credit card information. Sorry! ________________________________________________________________________________
Subject: an interesting site to exploret;
Date: Nov 10, 2009
A friend with considerable years and experience in the aircraft industry has this new website up and running. http://hunteraeronautical.com How about some feedback? Jim in Kelowna E-mail message checked by Spyware Doctor (6.1.0.448) Database version: 6.13670 http://www.pctools.com/en/spyware-doctor-antivirus/ ________________________________________________________________________________
Date: Nov 11, 2009
Subject: List Fund Raiser
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: an interesting site to exploret;
Date: Nov 11, 2009
They have misspelled Harmon Rocket -------- Milt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=272298#272298 ________________________________________________________________________________
Date: Nov 11, 2009
Jim wrote: > A friend with considerable years and experience in the aircraft > industry has this new website up and running. > http://hunteraeronautical.com > > How about some feedback? > > Jim in Kelowna Feedback on your email? It's Spam. And written to be deceptive & misleading, like most of the emails from ripoff artists are written. Why not just be up front & say that your friend has some new aviation products we might be interested in? Charlie ________________________________________________________________________________
Date: Nov 11, 2009
Thanks Terry, But Matt has not put his mailing address on these requests. No place to send the check.! writes: Matt accepts checks! Terry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rquinn1(at)aol.com Sent: Tuesday, November 10, 2009 3:53 PM Subject: Re: RV-List: Please Make A Contribution To Support Your Lists In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: http://www.matronics.com/contribution I tried but got an error and I do not wish to re enter my credit card information. Sorry! www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV-List http://forums.matronics.com ____________________________________________________________ One Up the Competition Earn your MBA from Post University. Free textbooks for new students! http://thirdpartyoffers.juno.com/TGL2141/c?cp=e4Yh8_9JzXXakd-p58DIQgAAJ1DOX6m7NtFYSFKPhB8gxgzbAAQAAAAFAAAAAPYo7D4AAAMlAAAAAAAAAAAAAAAAABIhWQAAAAA ________________________________________________________________________________
Date: Nov 11, 2009
The RV8 cargo pod picture doesn't show anything. The 'enlarged' picture is the same size as the small one. Constructive criticism, John Morgensen Jim wrote: > A friend with considerable years and experience in the aircraft > industry has this new website up and running. > http://hunteraeronautical.com > > How about some feedback? > > Jim in Kelowna > > > * > > E-mail message checked by Spyware Doctor (6.1.0.448) > Database version: 6.13670 > http://www.pctools.com/spyware-doctor-antivirus/ > <http://www.pctools.com/en/spyware-doctor-antivirus/> > * > * > > > * ________________________________________________________________________________
Date: Nov 11, 2009
Jim wrote: > A friend with considerable years and experience in the aircraft > industry has this new website up and running. > http://hunteraeronautical.com > > How about some feedback? > > Jim in Kelowna Due to the lack of details, photos and pricing.......vaporware???? :-) Sam Buchanan ________________________________________________________________________________
Date: Nov 11, 2009
Harmon Rocket is the correct spelling, not Harman. Tom Harmon Rocket II N-561FS ----- Original Message ----- From: Jim To: rv-list(at)matronics.com Sent: Tuesday, November 10, 2009 9:21 PM Subject: RV-List: an interesting site to exploret; A friend with considerable years and experience in the aircraft industry has this new website up and running. http://hunteraeronautical.com How about some feedback? Jim in Kelowna E-mail message checked by Spyware Doctor (6.1.0.448) Database version: 6.13670 http://www.pctools.com/spyware-doctor-antivirus/ __________ Information from ESET NOD32 Antivirus, version of virus signature database 4594 (20091111) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Nov 11, 2009
The postal mailing address for the fund raiser is listed towards the bottom of the contribution web page: http://www.matronics.com/contribution But, here it is as well: Matronics / Matt Dralle PO Box 347 Livermore, CA 94551-0347 USA Thank you in advance for your contribution! Matt Dralle Matronics Email List Administrator At 06:25 AM 11/11/2009 Wednesday, you wrote: >Thanks Terry, > But Matt has not put his mailing address on these requests. No place to send the check.! > > >Matt accepts checks! > > > >Terry > > > > > >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rquinn1(at)aol.com >Sent: Tuesday, November 10, 2009 3:53 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Please Make A Contribution To Support Your Lists > >In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: > >http://www.matronics.com/contribution > >I tried but got an error and I do not wish to re enter my credit card information. > >Sorry! Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 11, 2009
Larry, I hadn't looked at the site to see this year, but here is the address I have been sending my donations to over the years: Matt G. Dralle P.O. Box 347 Livermore, CA 94551 Terry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Mac Donald Sent: Wednesday, November 11, 2009 6:26 AM Subject: Re: RV-List: Please Make A Contribution To Support Your Lists Thanks Terry, But Matt has not put his mailing address on these requests. No place to send the check.! writes: Matt accepts checks! Terry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rquinn1(at)aol.com Sent: Tuesday, November 10, 2009 3:53 PM Subject: Re: RV-List: Please Make A Contribution To Support Your Lists In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: http://www.matronics.com/contribution I tried but got an error and I do not wish to re enter my credit card information. Sorry! www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV-List http://forums.matronics.com =================================== oelectric.com com">www.buildersbooks.com omebuilthelp.com www.matronics.com/contribution =================================== tp://www.matronics.com/Navigator?RV-List =================================== ronics.com =================================== ____________________________________________________________ One Up the Competition <http://thirdpartyoffers.juno.com/TGL2142/c?cp=e4Yh8_9JzXXakd-p58DIQgAAJ1DOX 6m7NtFYSFKPhB8gxgzbAAQAAAAFAAAAAPYo7D4AAAMlAAAAAAAAAAAAAAAAABIhWQAAAAA=> Earn your MBA from Post University. Free textbooks for new students! ________________________________________________________________________________
Date: Nov 11, 2009
The site looks very slick & professional however the content is quite lacking. I agree with others about additional DETAILED images and text. Having been around the RV community for some time I have seen many accessories developed for these planes all using generally the same development model. Someone has an idea and discusses it with the RV List and/or Vans Airforce for feedback and further development. Now maybe I missed something but items as significant as Wing Modifications (High Lift Wing) and Winglest are such significant changes to an important component like a the major lifting body cause visitors to disbelieve their value if there is no history, documentation, detailed images (including design, construction & installation) and data supporting the benefits of these modifications. The few images of Winglets shows commercial units. While the people behind the site may have some connection to these units there is no comfort in this knowledge when the site is lacking for the items the RV communit. Robin From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Sent: Tuesday, November 10, 2009 9:22 PM Subject: RV-List: an interesting site to exploret; A friend with considerable years and experience in the aircraft industry has this new website up and running. http://hunteraeronautical.com How about some feedback? Jim in Kelowna E-mail message checked by Spyware Doctor (6.1.0.448) Database version: 6.13670 http://www.pctools.com/spyware-doctor-antivirus/ <http://www.pctools.com/en/spyware-doctor-antivirus/> ________________________________________________________________________________
From: "Airplane Parts For Sale" <araw(at)bellsouth.net>
Subject: Parts for sale from failed project
Date: Nov 12, 2009
Hi Everyone, Here is a list of items for sale from a failed project. If you need any of this, email me directly with an offer. Some of these parts may be listed elsewhere and are subject to prior sale. Lycoming O-360-A1A, rebuilt by Mattituck with millennium cylinder upgrade, new slicks McCauley Blackmac new 3-blade propeller, designed for use with above engine Woodward propeller governor for above, rebuilt Sky-tec starter for above, installed and run for 3 months before the airplane was grounded for repairs Inter-av alternator conversion, installed and run for 3 months before the airplane was grounded for repairs Thanks! ________________________________________________________________________________
Date: Nov 12, 2009
Subject: Fwd: SELECTOR VALVE AIR LEAKS.
____________________________________ From: 144tomjones(at)gmail.com CC: rv-list(at)matronics.com Sent: 11/11/2009 4:33:15 P.M. Pacific Standard Time Subj: SELECTOR VALVE AIR LEAKS. Dean, Jess Meyers of Belted Air Power discovered this many years ago: If the pump is sucking fuel through the valve (not pushing) it can pull air past the "O" ring seals around the selector valve shaft. Fuel will not necessarily leak from the valve, in fact it seldom if ever does in this type of situation, but it will surely pull air into the fuel! This is just like having a pin hole in a soda straw and trying to suck soda from a bottle, it will induce air bubbles from the atmosphere into the straw causing loss of vacuum and dilution of the soda with air. This same phenomena occurs in fuel with even worse effects. The fuel draw is reduced to the point of inadequate fuel to the injectors or carburetor, possible vapor lock, and or foaming in the carburetor bowl causing the float to rise to a false level limiting the fuel flow through the needle valve and possibly completely shutting off the needle valve. Any of these occurrences can cause fuel starvation and is only exacerbated by turning on of a second or booster pump as it only sucks in more air! And yet it may show good fuel pressure! Watch the accident reports and see how many times an engine failed and when checked afterwards there was fuel in the system, but it just stopped running. We hear of reports where the pilot experienced a rough running engine and took the proper action to turn on a boost pump only to have the engine run even worse or stop all together. Jess has been putting this notice out for many years but unfortunately few seem to understand it well enough to heed the warning. Tom Jones, Big Reliable V6 Power (http://www.incredimail.com/?id=603341&rui=114156207) ________________________________________________________________________________
Date: Nov 12, 2009
Thanks Terry, I think thats the one. Larry writes: Larry, I hadnt looked at the site to see this year, but here is the address I have been sending my donations to over the years: Matt G. Dralle P.O. Box 347 Livermore, CA 94551 Terry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Mac Donald Sent: Wednesday, November 11, 2009 6:26 AM Subject: Re: RV-List: Please Make A Contribution To Support Your Lists Thanks Terry, But Matt has not put his mailing address on these requests. No place to send the check.! writes: Matt accepts checks! Terry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rquinn1(at)aol.com Sent: Tuesday, November 10, 2009 3:53 PM Subject: Re: RV-List: Please Make A Contribution To Support Your Lists In a message dated 11/7/2009 1:24:57 A.M. Mountain Standard Time, dralle(at)matronics.com writes: http://www.matronics.com/contribution I tried but got an error and I do not wish to re enter my credit card information. Sorry! www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV-List http://forums.matronics.com =================================== oelectric.com com">www.buildersbooks.com omebuilthelp.com www.matronics.com/contribution =================================== tp://www.matronics.com/Navigator?RV-List =================================== ronics.com =================================== ____________________________________________________________ One Up the Competition Earn your MBA from Post University. Free textbooks for new students! www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV-List http://forums.matronics.com ____________________________________________________________ Doctorate Degrees Online Boost your career with an online doctoral degree. Enroll today! http://thirdpartyoffers.juno.com/TGL2141/c?cp=DWkBLOigwUDfAP-55D0W_QAAJ1DOX6m7NtFYSFKPhB8gxgzbAAQAAAAFAAAAAPurNz8AAAMlAAAAAAAAAAAAAAAAAAAyOQAAAAA ________________________________________________________________________________
Date: Nov 12, 2009
Subject: bleeding brakes?
I will soon need to pour some brake fluid into my RV-6A and, I presume, to bleed the brakes. I've never done this on a car, let alone a plane. Can some one direct me to a web page that explains the process? Thanks, -- Tom Sargent, RV-6A final assembly. ________________________________________________________________________________
Date: Nov 12, 2009
Subject: Re: bleeding brakes?
No website, but my best advice would be to get someone from your local EAA chapter (you should already be a member!!!) to help you do it the first time. It's easy to end up with spongy brakes. Lacking that, the simple and best way is to use a squeeze-type oil can and force fluid through the bleed fitting on the brake cylinder. An adapter with a short piece of hose on the master cylinder will allow you to catch overflow in a container. Bleed one side, then the other. Linn thomas sargent wrote: > I will soon need to pour some brake fluid into my RV-6A and, I presume, > to bleed the brakes. I've never done this on a car, let alone a plane. > Can some one direct me to a web page that explains the process? > > Thanks, > > -- > Tom Sargent, RV-6A final assembly. > > * > > > * ________________________________________________________________________________
Date: Nov 12, 2009
From: Carlos Hernandez <carlosh(at)structuralaz.com>
Here you go. http://www.vansairforce.com/community/showthread.php?t=33493&highlight=brake+bleeding Carlos in AZ thomas sargent wrote: > I will soon need to pour some brake fluid into my RV-6A and, I > presume, to bleed the brakes. I've never done this on a car, let > alone a plane. Can some one direct me to a web page that explains the > process? > > Thanks, > > -- > Tom Sargent, RV-6A final assembly. > * > > > * -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Nov 12, 2009
Subject: trimming wheel fairing tire opening
I am concerned that the opening for the tire in my wheel fairings might not be large enough, or perhaps I should say high enough. It seems to me that if your tire goes flat, the wheel fairing should be trimmed high enough so that the bottom of the fairing doesn't touch the ground. Otherwise the weight of the plane will be on the fairing rather than the tire. Is this an excessive amount of trimming? I'm sure some of you had the experience of opening the hangar and finding a flat. How did your fairings come through the experience and how high do you have them trimmed? Thanks, -- Tom Sargent ________________________________________________________________________________
Date: Nov 13, 2009
Subject: Some Very Nice Comments...
Dear Listers, I've been getting some really nice comments from Listers along with their List Support Contributions. I've shared some of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution. http://www.matronics.com/contribution Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ----------- What Listers Are Saying About The Lists ----------- Few things in life bring more usefulness than the List. This is worth every penny! Stephen T. I have enjoyed the list for way too many years, but continue to get closer to flying my project with the help of listers. C.L. Thanks for this List. It's been a great source of encouragement and information. Arden A. Great service! Gerald T. It's always interesting reading the lists and I've gotten some good help from the issues and answers there. Steve T. Been a member of the List for 12 years. Keep up the good work. John H. Great Site! Harry M. Great source of information... Martin H. Thanks for providing this great service! Jeff P. I continue to get and give information through these lists. Ralph C. This is a wonderful resource! Warren H. This is what inernet was meant for, sharing information and experience. Michael W. Thanks for making such a good list! Fred D. Thanks for running a great service! Michael F. I really appreciate it. Dan H. Thanks for the great service. Michael L. Thanks for maintaining this great resource. John C. Your sites have been a great resourses and an introduction to many competent aircraft designers and fabricators. Jon M. Thanks for all that you do to maintain the Matronics forums and for the personal help that you have been to me in answering my questions regarding the use of the forums. William B. [The List] helped me get flying, fly off my test hours and make my systems better. Ralph C. The Universe is a better place because of you. Eric J. ________________________________________________________________________________
Date: Nov 13, 2009
There was a recent thread (yesterday) on Vans Air force about brake bleeding complete with pictures. Take a look and I think it will answer your questions. John Ciolino RV-8 with 18 hours From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent Sent: Thursday, November 12, 2009 5:36 PM Subject: RV-List: bleeding brakes? I will soon need to pour some brake fluid into my RV-6A and, I presume, to bleed the brakes. I've never done this on a car, let alone a plane. Can some one direct me to a web page that explains the process? Thanks, -- Tom Sargent, RV-6A final assembly. ________________________________________________________________________________
Date: Nov 13, 2009
Its all up to you Tom=2C but I would think that setting the pants up so hig h as to protect them from a flat tire would take away some of their effecti veness. The more tire you can cover=2C the more they will help you go fast . Mine are pretty low=2C and I have damaged them twice. Once from a tire stem malfunction during inflation=2C and once taxiing from a hard surface t o grass=2C the height of the taxiway was just a little high compared to the grass. All I can say is think about where you will be using your plane an d set the pant height accordingly. Paul RV8 Date: Thu=2C 12 Nov 2009 17:20:06 -0700 Subject: RV-List: trimming wheel fairing tire opening From: sarg314(at)gmail.com I am concerned that the opening for the tire in my wheel fairings might not be large enough=2C or perhaps I should say high enough. It seems to me th at if your tire goes flat=2C the wheel fairing should be trimmed high enoug h so that the bottom of the fairing doesn't touch the ground. Otherwise the weight of the plane will be on the fairing rather than the tire. Is this an excessive amount of trimming? I'm sure some of you had the expe rience of opening the hangar and finding a flat. How did your fairings com e through the experience and how high do you have them trimmed? Thanks=2C -- Tom Sargent ________________________________________________________________________________
Date: Nov 15, 2009
Subject: Right Fuel Line and Rudder Cables - Rv-8A
Just performing an inspection and found that the rudder cables were rubbing against the right fuel line that runs to the fuel selector.- While there is clearance when the cables are slack when they are taught, the cables ar e acting like a saw in to the fuel line. - Chilling.=0A=0A=0A ________________________________________________________________________________
Date: Nov 15, 2009
Subject: Hydraulic Strut For RV-8 Baggage Door...
Dear Listers, I was surfing around on the http://www.mykitlog.com recently and saw where someone had installed an hydraulic strut for holding the front baggage door open on the RV-8 similar to what you see on a hatch-back. I'll be darned if I can remember who that was now. I'd like to do something similar and it would be helpful to know the specs and installation points on the strut. Anyone? Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Contributions Down By 21%...
Dear Listers, As of today, contributions to the Matronics List Fund Raiser are lagging behind last year at this time by 21%. I have a fund raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash or worse, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time as well. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments, make a modest contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a contribution today. I also offer some incentive gifts for larger contribution levels. At the Contribution Web Wite, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 16, 2009
Here is one for you, Matt. http://www.lazy8.net/hinges.htm john -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, November 15, 2009 5:09 PM Subject: RV-List: Hydraulic Strut For RV-8 Baggage Door... Dear Listers, I was surfing around on the http://www.mykitlog.com recently and saw where someone had installed an hydraulic strut for holding the front baggage door open on the RV-8 similar to what you see on a hatch-back. I'll be darned if I can remember who that was now. I'd like to do something similar and it would be helpful to know the specs and installation points on the strut. Anyone? Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Subject: RV9A for sale
Date: Nov 16, 2009
Airplane is on wheels. All parts have been etched, chromic converted ( Alodined) and primed with two part epoxy strontium chromate . Needed to complete: Engine, (I have a fixed pitch prop) canopy, avionics and paint. Wings and empennage have been fitted. For more details call P Laurence 786 210 4868 ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Oil cooler attachment bolts
I have a SW 8406R oil cooler on my IO360B1F6 in my RV6A. Temps are fine - even on hot summer days. Three of the attachment bolts go through both sets of oil cooler flanges (and in to the back of the #4 baffle plate) with an aluminum tube providing support between the flanges. One of the bolts only goes through the 'forward' oil cooler flange and in to the baffle - per Vans oil cooler installation instructions. I would like to add a Reiff Oil-Cooler-Heater on the side with the single bolt going through only one flange. It gets cold here on the DelMarVa peninsula in the winter. In order to do that, I would need to make the other bolt on that side go only through the 'forward' flange as well. Does anyone know any reason that I shouldn't do this? Maybe you need pictures to figure out my description. I'll try to take some them to show. Thanks, Ralph ________________________________________________________________________________
Subject: Matronic lists and Replies
Date: Nov 16, 2009
The two recent message below illustrate a setup problem with the list. Clicking the Reply button on your email viewer usually replies only to the original message sender. If you want to reply to the list you click Reply All. But the Matronics lists are set up to always reply to the list, even if you click Reply. I wish this behavior would be changed to the more common behavior. --> LycomingEngines-List message posted by: "Godfrey Lucas" Dear Matt, Apologies I have been meaning to do it - busy!!!! Can I please contribute $25.00 please. Credit card is VISA [cut] Norm I am replying directly to you rather than the list [cut] ________________________________________________________________________________
Date: Nov 16, 2009
Subject: Re: Matronic lists and Replies
The Matronics Lists are configured that way intentionally. I have experimented with a standard reply going back to just the sender (traditional email mode), but the problem is that most people don't reply-all back to the List. Too many threads die out prematurely when the List is configured to reply only to the sender. Unfortunately (I guess), you don't need a license to use email... :-) Matt Dralle Matronics Email List Admin At 10:59 AM 11/16/2009 Monday, you wrote: > >The two recent message below illustrate a setup problem with the list. >Clicking the Reply button on your email viewer usually replies only to the >original message sender. If you want to reply to the list you click Reply >All. But the Matronics lists are set up to always reply to the list, even if >you click Reply. I wish this behavior would be changed to the more common >behavior. > >--> LycomingEngines-List message posted by: "Godfrey Lucas" > >Dear Matt, > >Apologies I have been meaning to do it - busy!!!! > >Can I please contribute $25.00 please. > >Credit card is VISA >[cut] >Norm >I am replying directly to you rather than the list >[cut] > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 16, 2009
I think Matt has it right! The default behavior is to the list and it takes a little effort to reply directly to the sender. John Morgensen Grumman AA1B 150hp - For Sale RV4 - Purchased flying RV9A - wiring Matt Dralle wrote: > > The Matronics Lists are configured that way intentionally. I have experimented with a standard reply going back to just the sender (traditional email mode), but the problem is that most people don't reply-all back to the List. Too many threads die out prematurely when the List is configured to reply only to the sender. > > Unfortunately (I guess), you don't need a license to use email... :-) > > Matt Dralle > Matronics Email List Admin > > > At 10:59 AM 11/16/2009 Monday, you wrote: > >> >> The two recent message below illustrate a setup problem with the list. >> Clicking the Reply button on your email viewer usually replies only to the >> original message sender. If you want to reply to the list you click Reply >> All. But the Matronics lists are set up to always reply to the list, even if >> you click Reply. I wish this behavior would be changed to the more common >> behavior. >> >> --> LycomingEngines-List message posted by: "Godfrey Lucas" >> >> Dear Matt, >> >> Apologies I have been meaning to do it - busy!!!! >> >> Can I please contribute $25.00 please. >> >> Credit card is VISA >> [cut] >> Norm >> I am replying directly to you rather than the list >> [cut] >> >> > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > > ________________________________________________________________________________
Date: Nov 16, 2009
Ralph Finch wrote: > > The two recent message below illustrate a setup problem with the list. > Clicking the Reply button on your email viewer usually replies only to the > original message sender. If you want to reply to the list you click Reply > All. But the Matronics lists are set up to always reply to the list, even if > you click Reply. I wish this behavior would be changed to the more common > behavior. > Hi Ralph, Every list I've ever subscribed to has replies going to the list by default. Think about it; the email came from the list, not the individual that originally wrote it. Since the email came from the list, 'reply' goes back to the list. Completely different environment from a regular email. Charlie ________________________________________________________________________________
Subject: LED Interior Lights
Date: Nov 17, 2009
Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources? Thanks, Norman Hunger RV6A Delta BC Nov 17-09 - 10 ________________________________________________________________________________
Subject: Re: LED Interior Lights
Date: Nov 17, 2009
Norman--Check out www.aircraftextras.com for electroluminescent lighting strips. I remember your name from the list years ago. Glad you're back on the project. It's looking good. LeRoy Johnston RV-6A N176LD "Esperanza" 240+ hrs. Ohio -----Original Message----- From: Norman Hunger <norman96(at)telus.net> Sent: Tue, Nov 17, 2009 8:51 pm Subject: RV-List: LED Interior Lights Hi everybody, I'm looking for suggestions on interior LED lighting. I'm af ter some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources? Thanks, Norman Hunger RV6A Delta BC Nov 17-09 - 10 = ________________________________________________________________________________
Date: Nov 17, 2009
Pep Boys! ________________________________ From: Norman Hunger <norman96(at)telus.net> Sent: Tue, November 17, 2009 7:51:58 PM Subject: RV-List: LED Interior Lights Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources? Thanks, Norman Hunger RV6A Delta BC Nov 17-09 - 10 ________________________________________________________________________________
Date: Nov 17, 2009
I got a strip of led lights from ACS. Used double sided tape under the glare shield and wired it to the dimmer for the post lights. Works great. FLEXIBLE LED INSTRUMENT LIGHTS - WITH CIGARETTE LIGHTER AND DIMMER Mike Divan N64GH - RV6 (flying) http://n64gh.blogspot.com/ FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS! Remember it is the Soldier, Sailor, Airman, Marine and Coast Guard that guarantee your freedom NOT the "community organizer"! ________________________________ From: Hadley Heinrichs <rvhad(at)yahoo.com> Sent: Tue, November 17, 2009 6:46:41 PM Subject: Re: RV-List: LED Interior Lights Pep Boys! ________________________________ From: Norman Hunger <norman96(at)telus.net> Sent: Tue, November 17, 2009 7:51:58 PM Subject: RV-List: LED Interior Lights Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources? Thanks, Norman Hunger RV6A Delta BC Nov 17-09 - 10 ________________________________________________________________________________
Date: Nov 18, 2009
Hi Norman, I'm planning on installing 2x (one for the pilot and one for the passenger) of these to the channel between the rollbar and rear bulkhead (tip-up). Each head has a pair of red and white LEDS that'll be controlled by a locally small switch to select either red or white. http://www.periheliondesign.com/ledlights.htm Regards, /\/elson On Tue, 17 Nov 2009, Norman Hunger wrote: > Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after > some small fixtures to light the floor and luggage areas. Also looking for > some kind of LED strip light to do the panel. Any ideas on sources? > > Thanks, > Norman Hunger > RV6A Delta BC > > > Nov 17-09 - 10 > > ________________________________________________________________________________
Date: Nov 18, 2009
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 20 years (yeah, I really said *20* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 18, 2009
Subject: Work Bench Cover
Guys, on some of the RV websites I've noticed work benches covered with som e sort of protective cover, which I'm assuming is there to prevent scratches on metal parts. I would apprecia te any input as to what is used and where to get it. Thanks,=C2-=C2-=C2- Walt Shipley ________________________________________________________________________________
From: "Fisher Paul A." <FisherPaulA(at)JohnDeere.com>
Date: Nov 18, 2009
SSB1c2VkIHRoZSBsaW5lciBtYXRlcmlhbCBmb3IgdG9vbCBib3hlcy4gIFlvdSBjYW4gYnV5IGl0 IGJ5IHRoZSByb2xsIGF0IFNlYXJzIChhcyB3ZWxsIGFzIG90aGVyIHBsYWNlcykuICBEbyBhIEdv b2dsZSBzZWFyY2ggZm9yIOKAnHRvb2wgZHJhd2VyIGxpbmVy4oCdLiBJdOKAmXMgdHlwaWNhbGx5 IHRvIGtlZXAgdG9vbHMgZnJvbSBzbGlkaW5nIGFyb3VuZCBpbnNpZGUgdGhlIHRvb2wgYm94LCBi dXQgaXQgYWxzbyBoZWxwcyBrZWVwIHBhcnRzIGZyb20gc2xpZGluZyBhcm91bmQgb24gdGhlIGJl bmNoISAgUGx1cyBhcyB5b3Ugc2F5LCBpdCBoZWxwcyBrZWVwIHNjcmF0Y2hlcyB0byBhIG1pbmlt dW0uDQoNCkkgYmVsaWV2ZSB0aGVyZSBhcmUgc2V2ZXJhbCBzdHlsZXMgYXZhaWxhYmxlLiAgTWlu ZSBoYWQgc21hbGwgaG9sZXMgdGhyb3VnaG91dCBpdCB0aGF0IGhlbHBlZCBzZXBhcmF0ZSB0aGUg bWV0YWwgY2hpcHMgZnJvbSBwYXJ0Lg0KDQpIb3BlIHRoYXQgaGVscHMuDQoNClBhdWwgQS4gRmlz aGVyDQpSVi03QSBOMThQRiB+NjAgaG91cnMgc2luY2UgQXVndXN0DQoNCkZyb206IG93bmVyLXJ2 LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydi1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgcnZlaWdodGFAY29tY2FzdC5uZXQNClNlbnQ6IFdl ZG5lc2RheSwgTm92ZW1iZXIgMTgsIDIwMDkgMDY6NDMNClRvOiBydi1saXN0QG1hdHJvbmljcy5j b20NClN1YmplY3Q6IFJWLUxpc3Q6IFdvcmsgQmVuY2ggQ292ZXINCg0KDQpHdXlzLCBvbiBzb21l IG9mIHRoZSBSViB3ZWJzaXRlcyBJJ3ZlIG5vdGljZWQgd29yayBiZW5jaGVzIGNvdmVyZWQgd2l0 aCBzb21lIHNvcnQgb2YgcHJvdGVjdGl2ZSBjb3Zlciwgd2hpY2gNCg0KSSdtIGFzc3VtaW5nIGlz IHRoZXJlIHRvIHByZXZlbnQgc2NyYXRjaGVzIG9uIG1ldGFsIHBhcnRzLiBJIHdvdWxkIGFwcHJl Y2lhdGUgYW55IGlucHV0IGFzIHRvIHdoYXQgaXMgdXNlZCBhbmQNCg0Kd2hlcmUgdG8gZ2V0IGl0 Lg0KDQoNCg0KVGhhbmtzLCAgICBXYWx0IFNoaXBsZXkNCg0KDQoNCg0K ________________________________________________________________________________
Date: Nov 18, 2009
Subject: Re: Work Bench Cover
Walt, I don't have a web page. I use carpeting scraps to prevent scratching of aluminum sheet parts. I usually place this on the work bench just prior to removing the plastic coating. This is usually for the dimpling process. I simply go to my local carpet supplier and check out the dumpster behind his shop. Another material you can use is cork sheet. This is used under carpeting & laminate flooring. Home Depot carries it, in case you can't find any in the dumpster! :-) Charlie Kuss --- On Wed, 11/18/09, rveighta(at)comcast.net wrote: > From: rveighta(at)comcast.net <rveighta(at)comcast.net> > Subject: RV-List: Work Bench Cover > To: rv-list(at)matronics.com > Date: Wednesday, November 18, 2009, 7:43 AM > #yiv2001607845 p > {margin:0;}Guys, > on some of the RV websites I've noticed work benches > covered with some sort of protective cover, which > I'm assuming is there to prevent scratches on metal > parts. I would appreciate any input as to what is used > and > where to get it. > > Thanks, Walt Shipley > > > > provided > Admin. > > ________________________________________________________________________________
Date: Nov 18, 2009
www.Superbrightleds.com ----- Original Message ----- From: Hadley Heinrichs To: rv-list(at)matronics.com Sent: Tuesday, November 17, 2009 9:46 PM Subject: Re: RV-List: LED Interior Lights Pep Boys! ------------------------------------------------------------------------- ----- From: Norman Hunger <norman96(at)telus.net> To: RV List Sent: Tue, November 17, 2009 7:51:58 PM Subject: RV-List: LED Interior Lights Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources? Thanks, Norman Hunger RV6A Delta BC Nov 17-09 - 10 ________________________________________________________________________________
Date: Nov 18, 2009
Strip light LEDs in white and colors. Attach to underside of glareshield and windscreen bow. http://www.mpja.com/prodinfo.asp?number=17362+OP Chris Stone RV-8 Newberg, OR -----Original Message----- From: Norman Hunger Sent: Nov 17, 2009 8:51 PM Subject: RV-List: LED Interior Lights Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources? Thanks, Norman Hunger RV6A Delta BC Nov 17-09 - 10 ________________________________________________________________________________
Date: Nov 18, 2009
Subject: Re: Brakes
Panama Red wrote: > > I think I might have missed something. Why are so many RVs having brake > fires, requiring the redesign of the entire brake system? I don't think you've missed anything. And there aren't 'many' RVs having problems. All it takes is a few. Then add those Long EZs, Velocities etc. that basically started the plastic line implementation .... and now you have a few more. From what I know, the problem arises when there's a long taxi with a crosswind .... the brakes get hot, the plastic gets soft, and it ruptures. Have you just dodged the bullet? Who knows. All I know is that it's a weak spot, and I'm going to fix mine. > > I have been flying my RV for 8 years with the brakes built exactly to > the plans. Just wondering, should I ground my RV and redesign the > entire brake system? I really think that decision is up to you. Do you like to gamble??? BTW, I've already replaced the plastic brake line between the pass and pilot side. I don't understand why, on the high pressure side, he uses plastic from the pass side, then flex (that one I understand) to the firewall, then hard alum to the gear leg and then plastic to the brake cylinder. Linn > > Bob > RV 6 "Wicked Witch of the West" ________________________________________________________________________________
Date: Nov 18, 2009
Subject: elevator trim, manual vs electric
I am doing final assembly on a 6A. I've never had the trim cable fully installed before and am running into various problems that have me reconsidering things. The manual trim has the advantage that it is not electric - no wiring, no dependence on the electrical system. I also like the very positive connection from my hand to the trim tab. But, (I'm guessing here) the electric looks like it's a lot easier to install. It's probably also a lot lighter. Though, I've heard lots of stories about the servo's running away. Have any of you converted from manual trim to electric? Is the electric easier to install/live with? -- Tom Sargent ________________________________________________________________________________
Date: Nov 18, 2009
Subject: Re: elevator trim, manual vs electric
Tom, I went with the Gretz relocated electric trim from day one. Control is on a hat switch on the stick grip. During my initial transition training, I practiced controlling the elevator with the trim in the opposite direction (probably ought to practice that again as it was quite a while ago). My only disappointment has been the little displays - I've had to replace them a couple of time as one of the internal LED's quit. No other issues, Ralph -----Original Message----- >From: thomas sargent <sarg314(at)gmail.com> >Sent: Nov 18, 2009 12:19 PM >To: rv-list >Subject: RV-List: elevator trim, manual vs electric > >I am doing final assembly on a 6A. I've never had the trim cable fully >installed before and am running into various problems that have me >reconsidering things. > >The manual trim has the advantage that it is not electric - no wiring, no >dependence on the electrical system. I also like the very positive >connection from my hand to the trim tab. But, (I'm guessing here) the >electric looks like it's a lot easier to install. It's probably also a lot >lighter. Though, I've heard lots of stories about the servo's running away. > >Have any of you converted from manual trim to electric? Is the electric >easier to install/live with? > >-- >Tom Sargent ________________________________________________________________________________
Subject: Brakes
Date: Nov 18, 2009
Hi Dave Yes, I did install the thicker rotors on my RV-6A. I really love the solid feel I now have. Since they are twice the mass, the same amount of heat energy only raises the rotor temperature approx 1/2 of the thinner rotors - helps keeps the seals from cooking as well as helping to prevent temps high enough to set off the brake fluid. Aircraft Spruce at one time (and may still) offered a thicker rotor kit #199-93 assembly. However, at the time it was close to $350 and I decided to see if I could do better (did!). The Cleveland/parker part number for the thicker rotor disc is 164-09900. However, I used the Rappco part RA 164-09900 from Chief Aircraft for $84.00 each http://www.chiefaircraft.com/airsec/Aircraft/Brakes/BrakeDiscs.html That was the expense 2 * 84 = $168 for both rotors, the rest of the fittings I made in my shop. There were the 1/8" pad spacer described below and the longer aluminum bushings to stand off the wheel pant. At the time I made up some new wheel pant brackets out of SS since I had lost one on the burnt up wheel pant. Now some of the more recent RVs (such as the 8s) have a slightly different brake set up due to the plate gear rod - so this may not apply to them. Otherwise, pretty straight forward. You do have to have a 1/8" (0.125") shim plate to place between the two pad holders to compensate for the thicker rotor for each wheel. If you buy them they cost about the same as the rotors, the cheapest I could find were $84.00 EACH - which I though absurd given the rotors only cost $85 each. So I made mine out of 6061-T6 1/8" aluminum plate/sheet. They will have to be curved on the underside (axle edge) to match the curvature of the rotor - but not a big job. The most critical thing (and not that hard) is to make certain the holes in the plate match the pad holes - you don't want the spacer binding. Took me approx 30 minutes to make both. I anodize them for corrosion resistance. Also, I had to lengthen the aluminum tubes used to stand off the wheel pant attachment bracket by approx 1/8" otherwise the thicker rotor wanted to rub on the bracket. Again, no biggie. I also switched to stainless steel braided Teflon brake lines, they give the brakes a much more solid feel and much less likely to rupture. I personally will never go back to the aluminum lines myself - but that is just my personal viewpoint, thousands are flying with them. Hope this helps Ed http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of dave.gribble(at)mchsi.com Sent: Wednesday, November 18, 2009 10:08 AM Subject: Re: Brake Fire wasRV-List: Brakes Hi Ed - thanks for posting.... can you post the part number / source / approximate $$ of the thicker rotors? Thanks again, dave -------------- Original message ---------------------- __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Nov 18, 2009
Tom, I built an RV-8A with manual trim and an RV-8 with electric trim, and for me I'd go with the manual trim if I had it to do over in another plane. Two reasons: first the manual cable seemed easier to install =C2- and secondly and most important, the manual trim allowed me to precisely adjust trim for any speed. With the electric, preci se trim at cruise speeds was dang near impossible. Just my 2 cents..... Walt Shipley ----- Original Message ----- From: "thomas sargent" <sarg314(at)gmail.com> Sent: Wednesday, November 18, 2009 12:19:05 PM GMT -05:00 US/Canada Eastern Subject: RV-List: elevator trim, manual vs electric I am doing final assembly on a 6A. I've never had the trim cable fully inst alled before and am running into various problems that have me reconsiderin g things. The manual trim has the advantage that it is not electric - no wiring, no d ependence on the electrical system.=C2- I also like the very positive con nection from my hand to the trim tab.=C2- But, (I'm guessing here) the el ectric looks like it's a lot easier to install.=C2- It's probably also a lot lighter.=C2- Though, I've heard lots of stories about the servo's run ning away. Have any of you converted from manual trim to electric?=C2- Is the electr ic easier to install/live with? -- Tom Sargent ________________________________________________________________________________
Date: Nov 18, 2009
Tom, I have 260 hrs on my manual trim RV-7 and would do it again as the trim is so precise and sensitive and it can't break (or not very likely)! 1/4" adjustments at the trim knob are all that is required when you are nearing cruise speed and altitude. Randy Utsey RV-7 / N55CU ----- Original Message ----- From: rveighta(at)comcast.net To: rv-list(at)matronics.com Sent: Wednesday, November 18, 2009 1:37 PM Subject: Re: RV-List: elevator trim, manual vs electric Tom, I built an RV-8A with manual trim and an RV-8 with electric trim, and for me I'd go with the manual trim if I had it to do over in another plane. Two reasons: first the manual cable seemed easier to install and secondly and most important, the manual trim allowed me to precisely adjust trim for any speed. With the electric, precise trim at cruise speeds was dang near impossible. Just my 2 cents..... Walt Shipley ----- Original Message ----- From: "thomas sargent" <sarg314(at)gmail.com> To: "rv-list" Sent: Wednesday, November 18, 2009 12:19:05 PM GMT -05:00 US/Canada Eastern Subject: RV-List: elevator trim, manual vs electric I am doing final assembly on a 6A. I've never had the trim cable fully installed before and am running into various problems that have me reconsidering things. The manual trim has the advantage that it is not electric - no wiring, no dependence on the electrical system. I also like the very positive connection from my hand to the trim tab. But, (I'm guessing here) the electric looks like it's a lot easier to install. It's probably also a lot lighter. Though, I've heard lots of stories about the servo's running away. Have any of you converted from manual trim to electric? Is the electric easier to install/live with? -- Tom Sargent _blank>www.aeroelectric.com /" target=_blank>www.buildersbooks.com =_blank>www.homebuilthelp.com blank>http://www.matronics.com/contribution t=_blank>http://www.matronics.com/Navigator?RV-List p://forums.matronics.com ________________________________________________________________________________
Date: Nov 18, 2009
Tom, I've done both and I prefer the manual. The electric is very sensitive at cruise but works well in the pattern. I've seen various devices to ch ange the speed of the servo depending on your airspeed but they are expe nsive and add complexity. I'll take the weight penalty of the manual. Do n't forget the size of the mount on the trim tab is different from manual to electric. Larry Gagnon RV6 N6LG -----Original Message From: thomas sargent <sarg314(at)gmail.com> Sent: Wed, Nov 18, 2009 12:19 pm Subject: RV-List: elevator trim, manual vs electric I am doing final assembly on a 6A. I've never had the trim cable fully ins talled before and am running into various problems that have me reconsider ing things. The manual trim has the advantage that it is not electric - no wiring, no dependence on the electrical system. I also like the very positive conne ction from my hand to the trim tab. But, (I'm guessing here) the electric looks like it's a lot easier to install. It's probably also a lot lighte r. Though, I've heard lots of stories about the servo's running away. Have any of you converted from manual trim to electric? Is the electric easier to install/live with? -- Tom Sargent ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
From: "Jim Fogarty, Lakes & Leisure Realty, Inc." <jfogarty(at)tds.net>
Date: Nov 18, 2009
Walt, I have used the light weight rubber mats you can get at Fleet Farm or Home Depot, however, pine table tops are just fine or whatever material you have available. I'm moving my project to the hangar this week and making a few more tables. Good luck! Jim Fogarty RV9a Building ----- Original Message ----- From: rveighta(at)comcast.net To: rv-list(at)matronics.com Sent: Wednesday, November 18, 2009 6:43 AM Subject: RV-List: Work Bench Cover Guys, on some of the RV websites I've noticed work benches covered with some sort of protective cover, which I'm assuming is there to prevent scratches on metal parts. I would appreciate any input as to what is used and where to get it. Thanks, Walt Shipley 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
From: "Bill and Tami Britton" <william(at)gbta.net>
Date: Nov 18, 2009
Try short mesh carpet (I think they call it berber). That's what I use and it works great. Bill ----- Original Message ----- From: Jim Fogarty, Lakes & Leisure Realty, Inc. To: rv-list(at)matronics.com Sent: Wednesday, November 18, 2009 3:03 PM Subject: Re: RV-List: Work Bench Cover Walt, I have used the light weight rubber mats you can get at Fleet Farm or Home Depot, however, pine table tops are just fine or whatever material you have available. I'm moving my project to the hangar this week and making a few more tables. Good luck! Jim Fogarty RV9a Building ----- Original Message ----- From: rveighta(at)comcast.net To: rv-list(at)matronics.com Sent: Wednesday, November 18, 2009 6:43 AM Subject: RV-List: Work Bench Cover Guys, on some of the RV websites I've noticed work benches covered with some sort of protective cover, which I'm assuming is there to prevent scratches on metal parts. I would appreciate any input as to what is used and where to get it. Thanks, Walt Shipley 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.aeroelectric.com"'>www.aeroelectric.com href='3D"http://www.buildersbooks.com"'>www.buildersbooks.com href='3D"http://www.homebuilthelp.com"'>www.homebuilthelp.com href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?RV-List"'>http://www.matron 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 11/18/09 01:50:00 ________________________________________________________________________________
Date: Nov 18, 2009
This is a tough trade off analysis, and a lot of it is purely subjective; Here's my take. Cost: the manual is far cheaper Installation: I believe the Installation is slightly easier on the electric but shoe horning that servo in to the elevator is not easy. If the Gretz version is still available, it makes the electric way easier. weight: The electric is far lighter. Space: The manual takes up a bit of space in the cockpit so the electric gets the nod. Feel: This is very subjective to say the least. For my money the manual has a far better feel and preciseness. To add to the bargain you can see what you got for take off or go around. Easier to set, and quicker too. Most pilots don't like the lack of feed back from the electric servo and its slowness. You can get various speed changers and gain switchers. Bottom line is most pilots who have flown with electric trim before can get accustomed to the shortcomings. I did. Safety: Probably the most debated issue. Surely "runaway trim" is a possibility with the electric. It is not a possibility with the manual. I know lots of folks will come after me for saying this, but I don't think it is a significant problem in an RV-6A. First of all most of the dark and stormy night horror stories are about big airplanes with stabilizer trim. On the B-52 it was a real threat. The huge hydraulic motors could drive the huge stabilizer very quickly to a position far beyond you ability to overcome the pitch force with the puny elevator. With elevator trim in the RV 6A. you do not lose elevator effectiveness when the trim tab takes off. For example if the trim runs away to full down (tab up) and you counter it with up elevator, then your effective elevator power is actually more than if the tab were elsewhere. I have tested many times and the elevator force required to overcome full up trim on take off is easily manageable. I don't know how fast you can go and still control it with our using both hands but I believe it is do able. I leave it to Kevin Horton to do this test for us. As for me I installed a pullable circuit breaker for the trim power which is easily accessible. It has never been used in flight. I went with the electric and have had several failures, all broken wires. I replaced most of the wires with mil spec 22 ga and solved that problem. These failures would cause me to lose trim altogether. Basically an inconvenience in the RV-6A. Good luck on your choice.. I like both systems, but went with the electric and have no regrets. My little servo has 2400 hours on it and still works. I used the matronics speed controller and ordered a new improved one after the old one was ten years old, got rained on, and became intermittent. When pulling it out to switch I found a loose connection so it is still in the plane (with a rain guard) and I have a spare if you want to make an offer. ; ). LET THE flames begin on my rant about runaway trim. I would surely like to hear from someone who has experienced it with an RV-6. Denis On Nov 18, 2009, at 10:19 , thomas sargent wrote: > I am doing final assembly on a 6A. I've never had the trim cable > fully installed before and am running into various problems that > have me reconsidering things. > > The manual trim has the advantage that it is not electric - no > wiring, no dependence on the electrical system. I also like the > very positive connection from my hand to the trim tab. But, (I'm > guessing here) the electric looks like it's a lot easier to > install. It's probably also a lot lighter. Though, I've heard lots > of stories about the servo's running away. > > Have any of you converted from manual trim to electric? Is the > electric easier to install/live with? > > -- > Tom Sargent > > ________________________________________________________________________________
Date: Nov 18, 2009
Subject: RV-List: Work Bench Cover Guys, on some of the RV websites I've noticed work benches covered with some sort of protective cover, which I'm assuming is there to prevent scratches on metal parts. I would appreciate any input as to what is used and where to get it. Thanks, Walt Shipley Old timers have used and I continue to use a corrugated cardboard bench cover. It's cheap, usually free, and heavier versions make a good surface for working on. The smooth surface does not retain particulates and a brushing followed by a bare handed wipe makes a clean enough area that you can slide aluminum around without scratching it. Gordon Comfort, N363GC. . ________________________________________________________________________________
Date: Nov 18, 2009
Walt, Try kitchen drawer liner from Big Lots, perforated- foam rubber,- brigh t, soft and non slip. Sherman Butler RV-7a Wings N497GS reserved Carlsbad, NM --- On Wed, 11/18/09, rveighta(at)comcast.net wrote: From: rveighta(at)comcast.net <rveighta(at)comcast.net> Subject: RV-List: Work Bench Cover Date: Wednesday, November 18, 2009, 5:43 AM #yiv1329106890 p {margin:0;} Guys, on some of the RV websites I've noticed work benches covered with som e sort of protective cover, which I'm assuming is there to prevent scratches on metal parts. I would apprecia te any input as to what is used and where to get it. - Thanks,--- Walt Shipley 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =0A=0A=0A ________________________________________________________________________________
Date: Nov 18, 2009
I built the EAA chapter 1000 work tables. About the same time, I found these 2X5' mats at Woodcrafters. They are thick rubber, made for standing on. Perfect fit for the benches. Firm but totally protect aluminum. Regards, Michael Wynn RV 8 San Ramon In a message dated 11/18/2009 5:50:36 A.M. Pacific Standard Time, chaskuss(at)yahoo.com writes: --> RV-List message posted by: Charles Kuss Walt, I don't have a web page. I use carpeting scraps to prevent scratching of aluminum sheet parts. I usually place this on the work bench just prior to removing the plastic coating. This is usually for the dimpling process. I simply go to my local carpet supplier and check out the dumpster behind his shop. Another material you can use is cork sheet. This is used under carpeting & laminate flooring. Home Depot carries it, in case you can't find any in the dumpster! :-) Charlie Kuss --- On Wed, 11/18/09, rveighta(at)comcast.net wrote: > From: rveighta(at)comcast.net <rveighta(at)comcast.net> > Subject: RV-List: Work Bench Cover > To: rv-list(at)matronics.com > Date: Wednesday, November 18, 2009, 7:43 AM > #yiv2001607845 p > {margin:0;}Guys, > on some of the RV websites I've noticed work benches > covered with some sort of protective cover, which > I'm assuming is there to prevent scratches on metal > parts. I would appreciate any input as to what is used > and > where to get it. > > Thanks, Walt Shipley > > > > provided > Admin. > > ________________________________________________________________________________
Date: Nov 19, 2009
On my flying RV6 Manual aileron trim = love it Electric Elevator trim = HATE IT! If I ever finish my RV7 both will be manual Mike Divan N64GH - RV6 (flying) http://n64gh.blogspot.com/ FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS! Remember it is the Soldier, Sailor, Airman, Marine and Coast Guard that guarantee your freedom NOT the "community organizer"! ________________________________ ________________________________________________________________________________
Date: Nov 19, 2009
Can you explain further? Please? RF From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Divan Sent: Thursday, November 19, 2009 5:22 AM Subject: Re: RV-List: elevator trim, manual vs electric On my flying RV6 Manual aileron trim = love it Electric Elevator trim = HATE IT! If I ever finish my RV7 both will be manual ________________________________________________________________________________
Date: Nov 19, 2009
I have 2000 plus hours on my RV8 with the electric trim on aeleron and elevater. I installed a 4 position top hat switch on the top of the control stick for easy operation. The only mod was to install a speed reducer on the elevator trim motor. It was an easy install. The speed reducer is necessaary on the elevator inorder to fine tune elevator cruise position. The aeleron trim allows me to use all of the fuel from each tank at one time on long trips . It is nice to know exactly when a tank is out on a long trip. I did not use tabs for the trim. I cut sections from the trailing edge and made new pieces that are hinged as a part of the aeleron /eleator. Nothing sticks out. It takes time to do this, but i found it well worth the effort. Dick Martin RV8 N233M IO-390 the fast one ----- Original Message ----- From: thomas sargent To: rv-list Sent: Wednesday, November 18, 2009 11:19 AM Subject: RV-List: elevator trim, manual vs electric I am doing final assembly on a 6A. I've never had the trim cable fully installed before and am running into various problems that have me reconsidering things. The manual trim has the advantage that it is not electric - no wiring, no dependence on the electrical system. I also like the very positive connection from my hand to the trim tab. But, (I'm guessing here) the electric looks like it's a lot easier to install. It's probably also a lot lighter. Though, I've heard lots of stories about the servo's running away. Have any of you converted from manual trim to electric? Is the electric easier to install/live with? -- Tom Sargent ________________________________________________________________________________
Date: Nov 19, 2009
Well, Vans eliminated the choice for the RV-10. Electric elevator trim only. Mike Divan wrote: > On my flying RV6 > Manual aileron trim = love it > Electric Elevator trim = HATE IT! > If I ever finish my RV7 both will be manual > ________________________________________________________________________________
Date: Nov 19, 2009
Thanks for all the useful responses on the trim issue. I guess the easiest thing for me to do is to stick with the manual trim. I'm most of the way down that road, so I will continue in that direction. -- Tom Sargent ________________________________________________________________________________
Date: Nov 19, 2009
Subject: PC to LASAR ignition test cable.
Hi, My IO-360 has a LASAR ignition that has failed. I am looking for the PC to LASAR box cable to run troubleshooting. I would like to buy or rent this cable...does anyone have one?? Thanks, Tom Wright 203-551-0746 PRIVACY NOTICE: The information contained in this e-mail (and in any included attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. 2510-2521, and is legally privileged. In addition, it is confidential and intended only for the use of the recipient(s) named above. The review, dissemination, distribution, copying or other use of this information by or to anyone other than the intended recipient is strictly prohibited. If you have received this communication in error, please notify us immediately and delete this message from your system. Thank you. ________________________________________________________________________________
Date: Nov 19, 2009
Subject: Re: PC to LASAR ignition test cable.
I'm interested in this - just in case. I have a LASAR system in my 6A and knock on wood it's currently fine. I would be willing to build a cable if someone has the pinouts... Ralph Capen -----Original Message----- >From: Tom Wright <tomw(at)charterops.com> >Sent: Nov 19, 2009 11:52 AM >To: RV List >Subject: RV-List: PC to LASAR ignition test cable. > >Hi, My IO-360 has a LASAR ignition that has failed. I am looking for the >PC to LASAR box cable to run troubleshooting. I would like to buy or rent >this cable...does anyone have one?? > >Thanks, >Tom Wright 203-551-0746 > >PRIVACY NOTICE: The information contained in this e-mail (and in any included >attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. > 2510-2521, and is legally privileged. In addition, it is confidential and intended >only for the use of the recipient(s) named above. The review, dissemination, >distribution, copying or other use of this information by or to anyone other than the >intended recipient is strictly prohibited. If you have received this communication in >error, please notify us immediately and delete this message from your system. >Thank you. ________________________________________________________________________________
Date: Nov 19, 2009
I have manual trim and am not flying yet. But one thing it kinda hoses up is wiring runs. One of the holes on the left side of the tunnel in my RV-7a is dedicated to a big manual trim cable (and also an ELT wiring run. ) I don't have much electrical stuff in the plane but the hole right side of the tunnel is full up with two strobe cables, a strobe power cable, a nav light cable, and an ELT instrument panel light cable. I could sure use some more room back there. and I havne't even run any antenna cables yet. _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph Finch Sent: Thursday, November 19, 2009 9:40 AM Subject: RE: RV-List: elevator trim, manual vs electric Can you explain further? Please? RF From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Divan Sent: Thursday, November 19, 2009 5:22 AM Subject: Re: RV-List: elevator trim, manual vs electric On my flying RV6 Manual aileron trim = love it Electric Elevator trim = HATE IT! If I ever finish my RV7 both will be manual ________________________________________________________________________________
Date: Nov 19, 2009
It has to be fairly simple...8 pins. I could build one also if I just had the pin outs. BTW, I have put 300 hours on my RV-8 and it has worked great but it (LASAR) suddenly quit in cruise flight...everything is connected and the LASAR rep says to get the cable and readout the diagnostic. Cable is ridiculous at $160. I wish I could rent one...then I would make my own. On Thu, Nov 19, 2009 at 12:47 PM, Ralph E. Capen wro te: > > I'm interested in this - just in case. > > I have a LASAR system in my 6A and knock on wood it's currently fine. > > I would be willing to build a cable if someone has the pinouts... > > Ralph Capen > > -----Original Message----- > >From: Tom Wright <tomw(at)charterops.com> > >Sent: Nov 19, 2009 11:52 AM > >To: RV List > >Subject: RV-List: PC to LASAR ignition test cable. > > > >Hi, My IO-360 has a LASAR ignition that has failed. I am looking for t he > >PC to LASAR box cable to run troubleshooting. I would like to buy or re nt > >this cable...does anyone have one?? > > > >Thanks, > >Tom Wright 203-551-0746 > > > >PRIVACY NOTICE: The information contained in this e-mail (and in any > included > >attachments) is covered by the Electronic Communications Privacy Act, 18 > U.S.C. > >=A7=A7 2510-2521, and is legally privileged. In addition, it is confiden tial > and intended > >only for the use of the recipient(s) named above. The review, > dissemination, > >distribution, copying or other use of this information by or to anyone > other than the > >intended recipient is strictly prohibited. If you have received this > communication in > >error, please notify us immediately and delete this message from your > system. > >Thank you. > > =========== =========== =========== =========== > > PRIVACY NOTICE: The information contained in this e-mail (and in any incl uded attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. =A7=A7 2510-2521, and is legally privileged. In addition, it is confident ial and intended only for the use of the recipient(s) named above. The review, disseminati on, distribution, copying or other use of this information by or to anyone ot her than the intended recipient is strictly prohibited. If you have received this comm unication in error, please notify us immediately and delete this message from your sys tem. Thank you. ________________________________________________________________________________
Date: Nov 19, 2009
I hate to suggest the obvious, but have you asked the LASAR folks for the pinout of the cable??? Linn Tom Wright wrote: > It has to be fairly simple...8 pins. I could build one also if I just > had the pin outs. BTW, I have put 300 hours on my RV-8 and it has > worked great but it (LASAR) suddenly quit in cruise flight...everything > is connected and the LASAR rep says to get the cable and readout the > diagnostic. Cable is ridiculous at $160. I wish I could rent > one...then I would make my own. > > On Thu, Nov 19, 2009 at 12:47 PM, Ralph E. Capen > wrote: > > > > > I'm interested in this - just in case. > > I have a LASAR system in my 6A and knock on wood it's currently fine. > > I would be willing to build a cable if someone has the pinouts... > > Ralph Capen > > -----Original Message----- > >From: Tom Wright <tomw(at)charterops.com <mailto:tomw(at)charterops.com>> > >Sent: Nov 19, 2009 11:52 AM > >To: RV List > > >Subject: RV-List: PC to LASAR ignition test cable. > > > >Hi, My IO-360 has a LASAR ignition that has failed. I am looking > for the > >PC to LASAR box cable to run troubleshooting. I would like to buy > or rent > >this cable...does anyone have one?? > > > >Thanks, > >Tom Wright 203-551-0746 > > > >PRIVACY NOTICE: The information contained in this e-mail (and in > any included > >attachments) is covered by the Electronic Communications Privacy > Act, 18 U.S.C. > > 2510-2521, and is legally privileged. In addition, it is > confidential and intended > >only for the use of the recipient(s) named above. The review, > dissemination, > >distribution, copying or other use of this information by or to > anyone other than the > >intended recipient is strictly prohibited. If you have received > this communication in > >error, please notify us immediately and delete this message from > your system. > >Thank you. > > > > > > ========== > ="_blank">www.aeroelectric.com > ooks.com" target="_blank">www.buildersbooks.com > et="_blank">www.homebuilthelp.com > ="_blank">http://www.matronics.com/contribution > le, List Admin. > ========== > get="_blank">http://www.matronics.com/Navigator?RV-List > ========== > http://forums.matronics.com > ========== > > > > > PRIVACY NOTICE: The information contained in this e-mail (and in any included > attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. > 2510-2521, and is legally privileged. In addition, it is confidential and intended > only for the use of the recipient(s) named above. The review, dissemination, > distribution, copying or other use of this information by or to anyone other than the > intended recipient is strictly prohibited. If you have received this communication in > error, please notify us immediately and delete this message from your system. > Thank you. > > > > * > > > * ________________________________________________________________________________
Date: Nov 19, 2009
Actually no...great idea, i just assumed they wouldn't provide it but of course it never hurts to ask. On Thu, Nov 19, 2009 at 2:59 PM, Linn Walters wr ote: > > I hate to suggest the obvious, but have you asked the LASAR folks for the > pinout of the cable??? > Linn > > Tom Wright wrote: > >> It has to be fairly simple...8 pins. I could build one also if I just h ad >> the pin outs. BTW, I have put 300 hours on my RV-8 and it has worked gr eat >> but it (LASAR) suddenly quit in cruise flight...everything is connected and >> the LASAR rep says to get the cable and readout the diagnostic. Cable i s >> ridiculous at $160. I wish I could rent one...then I would make my own. >> >> On Thu, Nov 19, 2009 at 12:47 PM, Ralph E. Capen > recapen(at)earthlink.net>> wrote: >> >> > >> >> >> I'm interested in this - just in case. >> >> I have a LASAR system in my 6A and knock on wood it's currently fine. >> >> I would be willing to build a cable if someone has the pinouts... >> >> Ralph Capen >> >> -----Original Message----- >> >From: Tom Wright <tomw(at)charterops.com <mailto:tomw(at)charterops.com>> >> >Sent: Nov 19, 2009 11:52 AM >> >To: RV List > >> >Subject: RV-List: PC to LASAR ignition test cable. >> > >> >Hi, My IO-360 has a LASAR ignition that has failed. I am looking >> for the >> >PC to LASAR box cable to run troubleshooting. I would like to buy >> or rent >> >this cable...does anyone have one?? >> > >> >Thanks, >> >Tom Wright 203-551-0746 >> > >> >PRIVACY NOTICE: The information contained in this e-mail (and in >> any included >> >attachments) is covered by the Electronic Communications Privacy >> Act, 18 U.S.C. >> >=A7=A7 2510-2521, and is legally privileged. In addition, it is >> >> confidential and intended >> >only for the use of the recipient(s) named above. The review, >> dissemination, >> >distribution, copying or other use of this information by or to >> anyone other than the >> >intended recipient is strictly prohibited. If you have received >> this communication in >> >error, please notify us immediately and delete this message from >> your system. >> >Thank you. >> >> >> >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> get="_blank">http://www.matronics.com/Navigator?RV-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> >> >> >> PRIVACY NOTICE: The information contained in this e-mail (and in any >> included >> attachments) is covered by the Electronic Communications Privacy Act, 18 >> U.S.C. >> =A7=A7 2510-2521, and is legally privileged. In addition, it is confiden tial >> and intended >> >> only for the use of the recipient(s) named above. The review, >> dissemination, >> distribution, copying or other use of this information by or to anyone >> other than the >> intended recipient is strictly prohibited. If you have received this >> communication in >> error, please notify us immediately and delete this message from your >> system. >> Thank you. >> >> >> >> * >> >> >> * >> > > =========== =========== =========== =========== > > PRIVACY NOTICE: The information contained in this e-mail (and in any incl uded attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. =A7=A7 2510-2521, and is legally privileged. In addition, it is confident ial and intended only for the use of the recipient(s) named above. The review, disseminati on, distribution, copying or other use of this information by or to anyone ot her than the intended recipient is strictly prohibited. If you have received this comm unication in error, please notify us immediately and delete this message from your sys tem. Thank you. ________________________________________________________________________________
Date: Nov 19, 2009
Good idea - I was going to look in my reference documentation first. I just started thinking about this from the original post.... Need an afternoon coffee -----Original Message----- >From: Linn Walters <pitts_pilot(at)bellsouth.net> >Sent: Nov 19, 2009 2:59 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: PC to LASAR ignition test cable. > > >I hate to suggest the obvious, but have you asked the LASAR folks for >the pinout of the cable??? >Linn > >Tom Wright wrote: >> It has to be fairly simple...8 pins. I could build one also if I just >> had the pin outs. BTW, I have put 300 hours on my RV-8 and it has >> worked great but it (LASAR) suddenly quit in cruise flight...everything >> is connected and the LASAR rep says to get the cable and readout the >> diagnostic. Cable is ridiculous at $160. I wish I could rent >> one...then I would make my own. >> >> On Thu, Nov 19, 2009 at 12:47 PM, Ralph E. Capen > > wrote: >> >> > >> >> I'm interested in this - just in case. >> >> I have a LASAR system in my 6A and knock on wood it's currently fine. >> >> I would be willing to build a cable if someone has the pinouts... >> >> Ralph Capen >> >> -----Original Message----- >> >From: Tom Wright <tomw(at)charterops.com <mailto:tomw(at)charterops.com>> >> >Sent: Nov 19, 2009 11:52 AM >> >To: RV List > >> >Subject: RV-List: PC to LASAR ignition test cable. >> > >> >Hi, My IO-360 has a LASAR ignition that has failed. I am looking >> for the >> >PC to LASAR box cable to run troubleshooting. I would like to buy >> or rent >> >this cable...does anyone have one?? >> > >> >Thanks, >> >Tom Wright 203-551-0746 >> > >> >PRIVACY NOTICE: The information contained in this e-mail (and in >> any included >> >attachments) is covered by the Electronic Communications Privacy >> Act, 18 U.S.C. >> > 2510-2521, and is legally privileged. In addition, it is >> confidential and intended >> >only for the use of the recipient(s) named above. The review, >> dissemination, >> >distribution, copying or other use of this information by or to >> anyone other than the >> >intended recipient is strictly prohibited. If you have received >> this communication in >> >error, please notify us immediately and delete this message from >> your system. >> >Thank you. >> >> >> >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> get="_blank">http://www.matronics.com/Navigator?RV-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> >> >> PRIVACY NOTICE: The information contained in this e-mail (and in any included >> attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. >> 2510-2521, and is legally privileged. In addition, it is confidential and intended >> only for the use of the recipient(s) named above. The review, dissemination, >> distribution, copying or other use of this information by or to anyone other than the >> intended recipient is strictly prohibited. If you have received this communication in >> error, please notify us immediately and delete this message from your system. >> Thank you. >> >> >> >> * >> >> >> * > > ________________________________________________________________________________
Date: Nov 20, 2009
Just a note to the guys located in SoCAL. I have the PC to LASAR controller box cable=2C the T100 tool kit=2C all the factory manuals=2C a current subscription to the manuals=2C the LASAR timi ng light=2C a spare controller box (O-360 w/o CHT)=2C and three spare LASAR mags (one has 25-hours [w/sensor]=2C the other two ~ 500 hours[1-w/sensor =2C 1-w/o sensor). NO I will not ship the cable. I also have never used it. I purchased the cable from Bart at AeroSport Power in Kamloops=2C BC. He an d Sue will give you some of the best prices on LASAR parts/equipment. Gary A. Sobek A&P DAR "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C334+ Flying Hours So. CA=2C USA (hangared KCCB) http://www.rvdar.com Date: Thu=2C 19 Nov 2009 11:52:54 -0500 Subject: RV-List: PC to LASAR ignition test cable. From: tomw(at)charterops.com Hi=2C My IO-360 has a LASAR ignition that has failed. I am looking for th e PC to LASAR box cable to run troubleshooting. I would like to buy or ren t this cable...does anyone have one?? Thanks=2C Tom Wright 203-551-0746 PRIVACY NOTICE: The information contained in this e-mail (and in any includ ed attachments) is covered by the Electronic Communications Privacy Act=2C 18 U.S.C. =A7=A7 2510-2521=2C and is legally privileged. In addition=2C it is confide ntial and intended only for the use of the recipient(s) named above. The review=2C disseminati on=2C distribution=2C copying or other use of this information by or to anyone ot her than the intended recipient is strictly prohibited. If you have received this commun ication in error=2C please notify us immediately and delete this message from your sys tem. Thank you. _________________________________________________________________ Windows 7: It works the way you want. Learn more. http://www.microsoft.com/Windows/windows-7/default.aspx?ocid=PID24727::T: WLMTAGL:ON:WL:en-US:WWL_WIN_evergreen:112009v2 ________________________________________________________________________________
Date: Nov 19, 2009
Gary, Are you willing to give us the pinout? ----- Original Message ----- From: RV6 Flyer To: RV List Sent: Thursday, November 19, 2009 8:41 PM Subject: RE: RV-List: PC to LASAR ignition test cable. Just a note to the guys located in SoCAL. I have the PC to LASAR controller box cable, the T100 tool kit, all the factory manuals, a current subscription to the manuals, the LASAR timing light, a spare controller box (O-360 w/o CHT), and three spare LASAR mags (one has 25-hours [w/sensor], the other two ~ 500 hours[1-w/sensor, 1-w/o sensor). NO I will not ship the cable. I also have never used it. I purchased the cable from Bart at AeroSport Power in Kamloops, BC. He and Sue will give you some of the best prices on LASAR parts/equipment. Gary A. Sobek A&P DAR "My Sanity" RV-6 N157GS O-320 Hartzell, 2,334+ Flying Hours So. CA, USA (hangared KCCB) http://www.rvdar.com ------------------------------------------------------------------------- ----- Date: Thu, 19 Nov 2009 11:52:54 -0500 Subject: RV-List: PC to LASAR ignition test cable. From: tomw(at)charterops.com To: rv-list(at)matronics.com Hi, My IO-360 has a LASAR ignition that has failed. I am looking for the PC to LASAR box cable to run troubleshooting. I would like to buy or rent this cable...does anyone have one?? Thanks, Tom Wright 203-551-0746 PRIVACY NOTICE: The information contained in this e-mail (and in any includedattachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C.=A7=A7 2510-2521, and is legally privileged. In addition, it is confidential and intendedonly for the use of the recipient(s) named above. The review, dissemination,distribution, copying or other use of this information by or to anyone other than theintended recipient is strictly prohibited. If you have received this communication inerror, please notify us immediately and delete this message from your system.Thank you.www.buildersbooks--> http://forums.matronics.co================ ------------------------------------------------------------------------- ----- Windows 7: It works the way you want. Learn more. ________________________________________________________________________________
Date: Nov 20, 2009
There is no pin out that I can find in the documentation. They want to SELL you the cable. I have not tried to reverse engineer it and my time is wor th more than the cost of the cable to reverse engineer it. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C334+ Flying Hours So. CA=2C USA From: recapen(at)earthlink.net Subject: Re: RV-List: PC to LASAR ignition test cable. Date: Thu=2C 19 Nov 2009 21:13:41 -0500 Gary=2C Are you willing to give us the pinout? ----- Original Message ----- From: RV6 Flyer To: RV List Sent: Thursday=2C November 19=2C 2009 8:41 PM Subject: RE: RV-List: PC to LASAR ignition test cable. Just a note to the guys located in SoCAL. I have the PC to LASAR controller box cable=2C the T100 tool kit=2C all the fact ory manuals=2C a current subscription to the manuals=2C the LASAR timing ligh t=2C a spare controller box (O-360 w/o CHT)=2C and three spare LASAR mags (one h as 25-hours [w/sensor]=2C the other two ~ 500 hours[1-w/sensor=2C 1-w/o sensor). NO I will not ship the cable. I also have never used it. I purchased the cable from Bart at AeroSport Power in Kamloops=2C BC. He and Sue will give you some of the best prices on LASAR parts/equipment. Gary A. Sobek A&P DAR "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C334+ Flying Hours So. CA=2C USA (hangared KCCB) http://www.rvdar.com Date: Thu=2C 19 Nov 2009 11:52:54 -0500 Subject: RV-List: PC to LASAR ignition test cable. From: tomw(at)charterops.com rv-list(at)matronics.com Hi=2C My IO-360 has a LASAR ignition that has failed. I am looking for the PC to LASAR box cable to run troubleshooting. I would like to buy or rent this cable...does anyone have one?? Thanks=2C Tom Wright 203-551-0746 PRIVACY NOTICE: The information contained in this e-mail (and in any includ ed attachments) is covered by the Electronic Communications Privacy Act=2C 18 U.S.C. =A7=A7 2510-2521=2C and is legally privileged. In addition=2C it is confide ntial and intended only for the use of the recipient(s) named above. The review=2C disseminati on=2C distribution=2C copying or other use of this information by or to anyone ot her than the intended recipient is strictly prohibited. If you have received this commun ication in error=2C please notify us immediately and delete this message from your sys tem. Thank you. www.buildersbooks--> http://forums.matronics.co========= ======= Windows 7: It works the way you want. Learn more. href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/ Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________________________ Bing brings you maps=2C menus=2C and reviews organized in one place. http://www.bing.com/search?q=restaurants&form=MFESRP&publ=WLHMTAG&cre a=TEXT_MFESRP_Local_MapsMenu_Resturants_1x1 ________________________________________________________________________________
Date: Nov 20, 2009
Subject: Just A Few Days Left; Still Trailing Last Year...
Dear Listers, There are just a few more days left of this year's List Fund Raiser! Response has been very good, but still well behind last year. If you've been waiting until the last minute to make your contribution and maybe even pick up a great gift, now might be good time to show your support! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: About Replying
Date: Nov 20, 2009
For those of you who wonder why the list is so long, and whether you can do anything to help reduce it, consider deleting most or all of the text of the message you are replying to. It would really help not to have to read someone else's privacy statement six times. Ideally, just keep the line or two of text relevant to what you are replying to. Respectfully, Ian Brown, RV-9A, Bromont, Quebec ________________________________________________________________________________
Date: Nov 20, 2009
Subject: Fw:LASAR cabling to computer
Here's what I got from Joe Logie at Champaero - they now support the product line. -----Forwarded Message----- >From: JoeLogie(at)champaero.com >Sent: Nov 20, 2009 8:45 AM >To: "Ralph E. Capen" >Subject: Re: Fw: RE: LASAR cabling to computer > >Ralph, Sorry, should have read the whole e-mail stream first! Slick >recommends not leaving anything connected to the controller during flight >to preclude any "antenna effect" possibly interfering with the >micro-processor. >>-----Original Message----- >>From: Ralph E. Capen [mailto:recapen(at)earthlink.net] >>Sent: Thursday, November 19, 2009 6:51 PM >>To: TRANS Unison Piston Product Support (Unison, Non-Unison) >>Subject: Fw: LASAR cabling to computer >> >>Tried to send this to Joe - but it bounced. >> >>Can anyone there help me? >> >>I'm looking for pinout diagrams for the RS232 cable connecting the LASAR >>controller to a computer for diagnostics.... >> >>Ralph Capen >> >>----- Original Message ----- >>From: "Ralph E. Capen" <recapen(at)earthlink.net> >>To: "Logie, Joe (Unison, US)" >>Sent: Thursday, November 19, 2009 6:28 PM >>Subject: LASAR cabling to computer >> >> >>> Is there a diagram with the pinouts? >>> >>> If not, can you give them to me? >>> >>> I would like to make a cable with a disconnect at the firewall in case >>I >>> need to do troubleshooting. >>> >>> Thanks, >>> Ralph /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwgHBgoICAgLCgoLDhgQDg0NDh0VFhEYIx8lJCIf IiEmKzcvJik0KSEiMEExNDk7Pj4+JS5ESUM8SDc9Pjv/2wBDAQoLCw4NDhwQEBw7KCIoOzs7Ozs7 Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozv/wAARCAC+ALQDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD2aiiu d8R3kFxp7QwybnttXsIpRgjaxuIHxz1+V1PHrQB0VFcnaanqL6hZXL3rvFe6pd2BtdiCKJIvP2sp C79x8hc5Yj5mwBxiHwjrGsajPZzX6XKw6hYG7IuGtgofMZAgWNt/l4kbPmAkfJkgk5AOyorE8Kf8 gmf/ALCV/wD+lctc9H4i1W00SLVnuvtL3ugT6qIpo1EcEkaxMETYFbZ+9IO4s2FX5upIB3lFcNdX 99b6hfabLqqaklpPpWPNgjLxtLdkMH2gDdtCkEKuBsIGfmM+mavrN5r8bSpcizmv7q0YStbrb7Ij KFMQDecZMxLnORzIQAACADsqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArnNS1Pw9Y6 3DNe6fM2pp+5guV0maVzlWbakixnPylyQp/ve9dHWNrEMsuqaC8cbssOoO8jKpIRfs065PoMsBn1 I9aALNtY6c90dXt7GFLu6jG+4Nv5czLgYDEgN2Xg9MDjimNBpOhRX+qC1t7NSrXF5PFAAzhQWLNt GWPLHueT61y97pt7L40lmdNrtfW8lrMumPLKsCrFvVbreEiQlZQyHkhnwG3gFLuwdtD8Sw/2ZeNq s1tfiSdYmxOrs5gTd0mPllQuN2wAr8hO0gHTf8I1oP277f8A2Jp/2vzfO+0fZI/M35zu3Yzuzznr mn/2fYWTz/Y7VLK51FiJLm0tl3s+Gbex2kZHzEF8jJxyTg8zquhGK4vrGztLlLKVtLc+SXBeT7Y3 nSbwdxk2KhZ87sBSTwDU9vpktrrUEFtYvDY22ul4I44isUUR08glQBhVMrNyONzHuaANXSPC+n6T CyKDc7vLA82GJFQRuzoFSNFQYd2YHbnLZzwMW5IdIstWjvDa28V/ft9nW4WAebKQhfaXAzjbGTyc fKPauZ0+zaHwfLB/Y9wbzybdNR8yNwk84I85ygIM5HLOV4mGEDN0EOg2V+lxZCSxeG3g115IUjs2 t4o4DYMAyxFm8tS7HgnO5jkKxKgA6i88Q6dY3LwTSygxY86RLaWSKHIz+8kVSkeAQx3EYUgnAINa 1cVrqzxXerR2sWopPdfNFaraC4tNQbylUGVjEwjUlfLZS6fKm7jduo1RZob6/s/sd28l7rVjcwtH aySIYkNsGZpFUquPKkyGIOBnoRkA7WiuB0C2RtYhmtrK5juk1i/a5umQ7ZLbzLhQok5G3zSn7rIO 4F9v8Rz/AA/Y3M/heA6FZXlrdt4cljmlOY2muGSL7OwlJw+AJNpDHywdp2fdoA9OrPl1exgg1CeS fbHpuftbbGPl4jEh7c/IynjPXHWuRn0yG6hvYtI0y4s9Lln01VhhtZLM+Yt1umdUwrKRGYyZABwo 5+Thz6Lb2ekeObPTdI+zvPE3kLb2ZRZlNogUIQuH+fzOFzgk8DdyAdY2sacJrGL7ZCz6jn7IEbd5 wCFyVx1XaM56cjnkZ0K4Gx0S/tvFFhLLA7W1hfvBbkIxWGJo7uTKcYWPbNbxcYG6Lb0VcvgtrweO LW4i0z7ODezrdTJZv5hj8qXZ5l0XxIjEIwRVKxkIhKlVBAO7orgNE0i40rS9K+yaXc+fL4elF3GJ Hhea4CweWjynlWGZFTJ+QbguAMVWsLC9Fvq0UWneXp7fYH8q20t7KKeMTubnEDMzMxjXawIDOoUb SCpYA9IorzQ2fn2l+mn2LxafHrqvNbXVk90oh+xIFDWytuZd5jKpwU+XKrsIGtpWiyPqGg/a4Zpo ba2vZEZoGgjjLTwtCvl7m2qFGURjlQinCsmFAO1ooooAKKKKACsW81S//tR9P0qytrmWCFJ5mubl oVCuzqoXbG+TmN85xjjrk42q53XtHn1G+SZtJ0rWIFiCpBqOE+ztklmVvKkJ3gqCOMeWOuTgAuad rB1G9e2+yTW+2yt7vE42yL5pkGxl/hZfL55PJ9uYZdfxcXdrHa7rqK9WytozJgTuYFmyWx8ihWYn qcIcAkhTSt9N17SL5JbUWmqZ022tZZru6khkd4jKS5xHJnd5meTnOetPXQ9QaafUSbZbz+0Ev4Ih IzRbvsiQMjNtBwf3mGA4yrYOChALMutXVpabr7TjFcpc28LJHKXiYTSrGGSQqN2NxypAIK9MFWNy 1v8A7Zeyx28Re3gyklwXwplBwUQY+bHO48AHC8kMEzr/AEjVdZ0p4L+WGF5Lm2fyIJW2QpHMjttl Cq5dgp5woHygAYLNesLGbTJ2t7dkOnFcxREndbNkfInrGRkgHGzGBlSAgBQ0nxlpWqaZa3hmED3M cLbNrsu6RkTaj7QJNruqMV+6SA22tmC8guZrmGFyz20oilGCNrFFfHPX5XU8etcpa+GL1NEhstck h8ix0WXTi1gHeSVZFj3EIVJDKIsDG7eTnC/dre8OWc9lodut3H5d3LuuLmMEEJNKxkkUY/hDuwHJ 4A5PWgCGx1u6vPIvF07OlXW37Pcxyl5SG+47xbflQ+oYkBlLKo3bF0vxPZalcvahvLuEuJ7fZhmU tFI67d+Nu8qm/ZncFOcEc1Hpmnavp8FrpKSW0enWKokdyrFp5Y0ACoyFdqnAAZwxyAcKhYbGW2hX UR03c8WbXVru9cgnlJftG0Dj7375c9uDyeMgE1v4h0RLa5kgkENvbxSXbt9neNJEBLPLGSoEq5OS ybgd4OfmGWw+JvDtrBHBBdJFFEoEcaQOqpCBgSgBeIAP+Wv+r/2qwpfB2t3IvmuL6GWW40q7sfMk uppPMll8vEu1vliDbTmNBheMFhgLs6zoN1qH9vCB4h/aWkpZQ7yRtcefy2Bwv71emTwePUAuN4h0 kapJp32v/SYpVikXy32xMyqUDtjau7cAuSNxyoyQQG/8JFZR24lmaRmeeeJIrWGW4c+VIUY7VTdg EAE42gkDJyCckaVqt5rOrRFIY7GXVrW58yQMsg8mO3fKDGJFZo9nVdpDH5vuiaDRNU0+eC8tFtLm eKW+BhmnaJClxcCYNvCMdwCqCu3HzHnjkAvzeKNFtp1ikv0LPAlwDGrSL5LFgJSyggR/KcuTtXjJ GRldT1TULbVbTT9Psra5luYZZi1xdNCqrG0a4+WN8kmUenSsn/hEbqLRL/TYrmGQT6BBpcTvlcvG sy7mAzhT5i9CT1/HT1Tw9a6xrVlc6hZ2l5a2tvPGYrmMSfO7RFWAII4EbjPXkepoAS08TWEotYrl jb3l1LNCluA0m94ZfKk2kDlQ3OSAduWIADYH1XQNatZ7a6MM9osRmcXluVhljUgmRTIoWRB8p3Ll RlTnkZm/soxa3YXVusUVpZ2U9sIkG3bvaEqFAGAoERHtx+GJH4Sv59MXTLuW2hitdHm0qCaJ2kaV ZFjXzWQhdhAiB2hmzuI3cZIBc0rX9Fhkn06yt0srSzW2GxLdoSklxK6KhhKgoSwU8jkSA9OTp3Gu WFr5/mTOWt5xbvHHC8jmQoJNqooLOdjBvlBwMk9DjGm0XWdSub69u4bG1mkWxMEUV08qs1vO82GY xrtDFguQGxycHoVj0XWjPJqckNit6NT+2x2y3TmJl+yi32mTywQerfcPQDvkAFtPFenHVLu03P5E FpDdLcpG7JMJWYKqELhicLt2klyxABKmtKwv7fUoGmtmchG2OkkbRvG2AcMjAMpwQcEDIIPQisi8 0TUri+vJXSxuFubC2iJZpIszQySP8oXJjB8zKuGLIwBw2Kv6DZ3ljZvHeyks0haOL7Q9x5K4A2+a 4DyZIZssON20cKKANaiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigArjtXEtx4uuYDZ61fRRWFu6x6dqJt1jZpJwSw86PJIVeefu9u/Y1VS0gS+kvFjxPLG kTvk8qhYqMdOC7fn9KAIdLh1GOyt11O5inuFtokmaNMbpgP3jZ4BUnGBtGMH1wOahub238TWMdx/ aIurjUrmG4aRn+zGDZO8CopPl7iiRHMYyNrByCxDdaIlWdpgX3OApG4lcAkjC5wD8xyQMnjPQYqJ omnwagb6OFxLuZ1UzOYkds7nWMnYrHLZYAE7myfmOQDmtF1M2EGk6ne3lyYr3QpdR1BpZXlXeggY sqEnYAJZPlQAcgY4GLPgTWZNYXWHn1OK8m+2rII4p0kW3R4YmEYKEgqrb03DhijHqTW5ZaFp2mzG a1gcPt2IHld1hTIOyNWJEa8L8qAD5V4+UYmGn20bXDxrIjXM6TyskrKWdQig8HpiNQR0IByDk5AM a3sEfxrPLBc33lWcO6VGvppIXnlJO3YX2qURc7cYxOpwMLlmi6aP7T1aW1v9QSBMWUBkvpbgBgu6 SVPNZl3Bm8vBB2mFvVhW/BZwW01zNChV7mUSynJO5gipnnp8qKOPSmR6fbQ2UtnCrxxTNK77JGVt 0jMzkMDlSWZjkEYzxjigDM0FDHqOpR2s9zJp0LJDH9ouHnJmXd5rK7liV5RMZwHjkGAckmmter4w 1eG5vXnj+y20sUe3akIaS4GFHrhFySSSR2GFW1p3h+w0m1FtZ/a0hHl7Ue+nkCBDlQu5ztXsQMAj ggjiriWkCX0l4seJ5Y0id8nlULFRjpwXb8/pQBwP9rarpdjcNu1CG/XQbu5vJLtmaM3kQi5iWQkB VZ2/1YEbBhjdtwuvdR3dhc6ppunzX0kEcFlO6m4lnmVHnkWco7EyZMUfAU5BGVG487Vt4c0u2Mqp a7o5YzCYppHljSM9Y0RyVRDgAqoCkKoxwMLF4f02O2mt/KmlFxt8x57mWWX5TlMSOxddpyy4I2sS RgnNAFPwncyTrqkOLtbe1vRHbJeOzSrGYYn+YuS/JdmAc7gGAIXG0dFVGwsLfTYGhtlcB23u8kjS PI2AMs7EsxwAMknAAHQCr1ABRRRQAUUUUAFFFFABRRRQAUUUUAFct4j1G/sr15I7uaG0tbYTytbL BJ5XL7nuEkIcxYUYEWGO2QZztrqapXWmWN9Pbz3llbXEtq2+CSaJXaJsg5UkfKcgcj0FAHFrqk+k 21xd26RM9rba9coJIwctHdqVGfvBeeQCM8egxf1qa+09tJEMra9d2uqOI4t0UUpY2cxCSMNqA/Nn O1flI4Y8t1CWVtDKskdtEjrv2skYBG9gz8/7TAE+pGTUcGmWFrBBBbWNvDFbMXgjjiVViYgglQB8 pIZuR/ePrQBzF1rF+ltBfQ6tNNYrYpevc2sMOFVi7F5oZCJPJ2gbVjPmELICxYA1ctNXv5Tpe+fP 2jWr21k+Rfmjj+1bF6cY8pORydvPU52ZNI0yaSCSfTbSR7eRpoWa3UmJ2bczKccMW5JHJPNL/Y+l /wBqf2n/AGZZ/b/+fvyF837u37+M/d469OKAOKt/Eerp4UTUTq6Xk954eur7zFijCwTwrGAFAHXM jbw2RuXgIMrWlJrOo2wuraPVEvRKunyRXiRoAgurhomMYGRtCqGTdvOT8xcVqw+FNLh0GfSIovLj ubJbOadFUTSosflqWbHLBemRgelaCaXYRw3MC2VssV2zvcIIlCzMwwxcY+YkdSetAHNNf6x9sj0m HVXBTWPsbXckMbSvEbIznIACBgxwCFAG1chvmDZMF1cWOnQadJd3dwt1qN+7MJhA8hF4IEj3xBWR WlnSRmXJG1gAVbaO6g0ywtYIILaxt4YrZi8EccSqsTEEEqAPlJDNyP7x9ap33hywuIZVtra3tZ5G kcyLApWRnwJBKvHmK4ADA9cA5DKrAA5e0tW0zVJTbWmnWs1lqVtZqumwtbLemRQ0vmQgkMqQzbly WKmJ2yFJWp5ry/1DwdZ3Umpwy3V7Lpd2sTwqfsrS3EZAwpUmLIwoPzfK2XP8OlpXg9NPvlum/s+3 KY+XSdOWz80ZBxI253K5VThWUHBDBgcVuR6ZYRCRI7G2RZZ/tEgWJQHlyG8w8ctlQd3XIHpQBzsm pahDFeab9vvJriHUVtYJYYYTc3ANus5ALBYVYbm5K42JjG4hqq6TrGq+IP7Jjg1V7WK5gvmlljjh klkENxHHGwYbowxB5KgoctgDKlern0ywuoJ4Lmxt5orlg88ckSssrAAAsCPmICryf7o9KkSytoZV kjtokdd+1kjAI3sGfn/aYAn1IyaAOKbxDrUfh7+03vkae+8PXOpKqQKsdrJGkRQRg5JH735t5bJU Y2jK1bm1jUEuX09NYmvGuYrae3lsoIPMlMonZkhLny1QLBuBk3HbuG5mKkdDe6HYX2mS6eYEhikt Hs1MKKrRROoUqnHyjAXjp8o44pz6NpclvcWr6baNBdSma4iMClJnJBLMMYZsgHJ54FAHJW3iTVdW stJS0N9J9pW8dpbD7IZ2WCZYkLGQmIgq2WKdWxtwuRUsmv62LS71I3NsosvD0OoNbRIrxyXDLOTh wTmPKDoecLhgN27qbrR9LvrcWl1ptpcW4lM3lSwK6bySS2CMbiWYk9eT61ZEMazyTiJBK6qjSADc ygkgE9wCzYHufWgDJ0uW7t9avdKur2a+SC2guEmnSNZAZGlUr+7VV2jygRxnJPJ4AybTV9RfwtbX 7aqr3WorYSGPy0D2guZFRimOqgMdm8McodxfoOis9G0uwiSOy020to45TMiwwKgVyu0sABw20kZ6 4OKkTS7COG5gWytliu2d7hBEoWZmGGLjHzEjqT1oA5pr/WPtkekw6q4Kax9ja7khjaV4jZGc5AAQ MGOAQoA2rkN8wZ+m6lq32rT5bm/M8dxqN1pxiMKqNkInxISBkykwDJGEwxAQHmuhg0ywtYIILaxt 4YrZi8EccSqsTEEEqAPlJDNyP7x9akWztlMe22iHlStMmIx8rtu3MPRjvbJ6ncfU0AWqKKKACiii gAooqrc39tanbJIN56IvLH8KALVFcvqnia/t4XkttNComMyTuOMnAOB/jWXbajq+rT+TLrMdu5GR Fb7c4789vzp2A7uiuFudNaM7rjUZZSv3llnYg/UVny2ZNwsaW1rKQSwVQxJwM4OD0osI9Loryrzb WKTE2+Eg/wDLJWUfzzitvTm+1QN9i1eWORBwFuGP5q4osFzuqK45r/xXpmGlijvYcctt5/MVcs/G VnMo+2wyWmTjzCN0efr2/EUrDOloqKGaK4iEsMiyI3RlOQaloAKKKKACiiigAooooAKKKKACiiig AprMFBLEADkk9qdWZeMt4WtgcoPlKg/ff0+g6mgBJLuW7Qm3byoOgmPVz/sj0964++1qPR3trf7B d3kz2yTyOk7Dk9SRg/rXZxuS+zI+0AfNkcRj2H+fesDSAP8AhL0U8/8AEpj/APQqUr9DegoXbmrp K9jlLzxVpN5LvvNGu3YDHz3zDH4VCniDQI3Dx6HcqwOQy3zAivSjc6DeX8mnmexmu4xmSDcjOv1H WqL6J4RvRC3kWLfaSVhaNwPMI6hcHnHtWbjU6M7I1sF9qm/vOKl8W6VN5fmaRdMYhhG+2tkD69ai vvG2k21q1w2i3beT8wAv2H64rqZPBHhO6nmgguTHLAMyxx3IJjH+0DnH41haj8P/AA/e6YZIvFEU VrK/liZnRlLf3QcgE+1Je0vqayll0oPli07ab7/ec/P8YtKuYBDP4du5IwCAGvyf/ZapxfE3w5BK ssXha6V0OVYai3B/KuitfhF4Jtr0WV74hee7yB5H2iONifTb1rdt/h78OdOtpbqW3tnjt2KTS3F2 WWNh2b5sA+1bHjnGx/GPTIrl7iPQr5ZX+8RqTc/hjFPb4o2WoxSD/hE9RuI2+Z9t6xH1OF/WvStP 03wXa2kNzY2ujpBOwSKZFjIduwDdz7Vc1Wa0fw7q8VpJCxgtpUkSIj5G2HggdDQBxenanFDpmk6z pCy6dDfpI0kMsxlXKsAM5/n713thqkV5iJ2jWfbuKK4YH6Vx3w9tLe+8DaJb3KK6tZzcH/roKp69 FLpOsQ3FoVi2KojMYwFIHT3piPTaKo6RqCanpcF2uMuvzgdm7j86vUhhRRRQAUUUUAFFFFABRRRQ AViWaNHZw3sys7SfvEx1QsOh9ua26yLVmhSKBtzJBIUI6lcA4PuMUAW2SJbbccSd9w6sT6GuY04P /wAJQBHxL/Y6bee+eK6WVIpZYmjbbkliyHrgd/zrmLK6t7PxXHJcTxwp/ZUY3SMFB+b3qZdDeim+ ZLs/0OU8ISeGfs+i2lzaSP4mjuLhpjEuJY5Pm3NKepXGOuazvCyahbDwPcXd5btpxubloIli2vFg NuLN3r0+XxR4YtJXlN7a+cwwzRruZvqQOazZ/iD4ciULFDLMEztCwAAfTOMUOcV1HDC15/DB/cef eF9Quo/FkmsXNtcxQ+Io7xBNIB5cnVk2/QLjn1rkIrDV10i3t2k/4l0Qj1FRjjLusX55B/I169N8 S7TaqW+i7gn3PMdQF+gAOKxdU+J2o21hJLb6ZYIEAwjqWBGenap9rC9rm7y7EKLnKNkvNC3nhu98 T+MPFNjaQWCRm8tmlvZ8+db4QH93gdTj1FUpBDAXn1Ab9Kg8Wym8LrlcbQFZx6ZqKy+PV1FIWu/D 9sxb7zQSlCfzBratfjj4bnVo73RruBZPvhVSRT9eRn8q0OA5zU7NNW0i8h0hxDYXvihEsJFBCAlG BZfbOOldN4Cmv5vC3jFtUXbfedMtwMY+cQ4P8q2LL4reBLlEiF6LYJ9xJbZlC/TAIFSar4z0W8sL yDTNQ06eKe0l8xxOqvu2HsepoAh+G1ulx4L0JX7WkxU+h80Vq+KbSHUdKZTxd2o3qigknsRj0PWs 34Zpv8G6ENzKPsk2dpxn96K64GG2uXRFyWQNtUZJPNAHN/D6Z2sryA52JIrL+IIP/oNdjWVpMCR+ bLGioshUbVGBkcn9Scn1rVoAKKKKACiiigAooooAKKKKACqN7DKHS5twDJGfmU/xr6fXnir1FAGY 8lvJ5VxzEScFhx19+nXFchqemaPqevaLp94lw095ZHEiSAKgQZAIx1PzflXbT2pcO0DKruPmVhlH +o/qK5ZtFK6xZXl3bSR3NqkaxOlyfKOwMMY299x680mk9GXCpKm+aDszK1Dwlotj4h03SAkp+3LI xkkutu3bjhRtO4nd7dKg1jw7oWka/YaW1vdzfbAMyLcAMuXCDC7fm5OT6AE1189tJd61a6gW+z3F ojoqibCyo2CQQU55UdKj1HRF1HW7HV5EC3Np8sEkVxgDnJB+XuAQfY1Ps4djo+u4j+dnM+I/C+ia BFCyW91cvKJHK+eE2xou5znacnHQd6XxJ4I0Ky0D7SIrqdJXjQ7rny1QOwG5m2nAGRniun13RZ9d jijnt1Tyi2GiutpKsNrKcoeCOKfqdne6zpUumyW/2eBx5cnlXAyV6FeVPBH40ckexMsZXkmnN2OC 8R/Czwp4f0tb0RX07PMkWxrxYwNxxncVpl/8NPBtl4QPiFY9UkQ26zJAZ1DMWxhfu9ckV3ms2c97 p8Fvc6UksFtLHMEFznJQ5AOVORxzWDr3iSHUYf7MvtLlRIZlZlguwuSp4GQvTPp6VZzGTqHwo8HW Hh99YU6lIgiWREFwo3FsbRnb6kUXfwi8OWHhy51O8hvkntrd5nt0u1ZcqCcBtnfHXFX28TWknh5d CfTJ3thCIQxuRvwOhzt6jArZtby41Tw9Lp93bSi3ngaJ557kGVwwIJ4TGefSgCLw8kel6X4ftLCL dayW8mSLgsI1LBid20buvoK32eSUyJZoI2mGFdh0X+8R+Jxmqem2uoyrboytFBbxGLzp2DSyjIxw AAOlbsMCQrhAcnksTkk+9ACwxCCFIlJIUYyep96loooAKKKKACiiigAooooAKKKKACiiigAppUMC CAQeoNOooApy6fC64QvFg5Gw8A/Q8VG1jLs2sIZv9opsb8xWhRQBmKt1GMPZ78dGjnxn8DimK1yk jn7BdlWORtnTr3/irWooA53V01q7t/I0+0eAt96Sa4GQPYAmsW08CXkjl7+4TJ5+RyST7nFd5RRc DCtPC9nabCipGVGCY0+ZvqxyfyxWrHaQQ4KpkjozHJH51YooAKKKKACiiigAooooAKKKKACiiigA ooooA5/W7bxFPcStpLWSRmzKRefPKh84uuSQg+7sB5+9nGNvJrnfFmiTXPjHSoLfxJr9o2qyP5sF reMkUUUUXLKAPlJbZ1zksa9CrNk0aCXXYNYeSQz28DwRpkbAHKknGM5+UDr0oA5yG71XR9ai8L6d Kb+K1svtVzfarM0ko3THGWH3iFD4GB0Xkc0638V6rcaF4fuha24vNavQqoVbaludz7uv3vLUd8ZP pW4NCtJNT1C/Z5nk1GBIJFYjaiJuGFwMjO8k8n8KztI8EaZpS2wiutQn+yKwgNxclzEGXbhP7mFJ A24696AKXhvxZrGseJLnT7+1sLBIw5FjI8i3iAEgMQV2Op45U456mmeBb/xbql9qN3rc2nNYLNJB GttvDLJGwT5AePLOHOT8xOO3FaeleC7DTdVXUpL/AFPUrqMP9nfULtpvs4bhgmemRxnk471Y8P8A hi28MG6FneX0sNy4YQXNwZUhOSTsyMjJYkkkk4FAHL6n4u1awgvtQsbKNopdTltvtVw8z29skShd 7opYrlw4ygC8ZPPJ6+11YDw2NYvZLYolsZ5ZLWQyRFQCSVYgEjAzyKy38DWj2dvaQ61rdsIXklZr e+MRm3uzkOFGDyx5ABx3rZ0/RtP0zR00i0tlSyjjMYi6gg5zn1ySSfXNAHJ+G/G2uatq1t9t0Ux6 VfQtLFcRwTr9mAXcPNkdAjBh0KEj3Oam07xZqtx4ug0+eDT5tNvoZZ7ee0aUtHGgHzOzqquGyANn TPpybunfD/RtPMqmS9u45Ld7WOK6umkS3hcAMkYP3QQB6n3pNK8AadpF2bi3v9SdvsDWKCe58wRx kg/LkfKRgAAcYHSgDGh8b+I5NE0rVBplo39rXiQWsC7jIys7ks3zYUCNRzk8nJAAqWbx5qmmQ6rF qmnWxvbW9gs7VbSR3jmklXcF+7vJUHJwvPQCuig8L2UEWiQpNPs0MYgUlcSfuzHl+OTgk8Y5NQ3H g7TLyyv4bh7lxqN4LxpBJtkikwoUoygY27Rjr360AYVr451uHSpxqekJHqX2uC0sn8ma3t7t5idu 0SqH+XB3cfTrVzwtf61qfizVhqwWJ9Ot4LV4raZmtmlJZ2dAe+0p1GR0zVlvh/pDaM+nST30skk6 3Jv5LktdecoAWQSEcMAMDAxU1v4LtbPSdQ0+21PVIDqNx9okukuz9oRvl4WQjOPkxzk4J5oAs6zp NzqksTw391biO3njxBctEGaRQoJAB5XkhjnaexPI0rSA2tnDb+Y8pjjVDJIxZmwMZJOSSfU1aooA KKKKACiiigAooooAKKKKAP/Z
Date: Nov 20, 2009
Here's what I got from Joe Logie at Champaero - they now support the product line. > >-----Forwarded Message----- >>From: JoeLogie(at)champaero.com >>Sent: Nov 20, 2009 8:45 AM >>To: "Ralph E. Capen" >>Subject: Re: Fw: RE: LASAR cabling to computer >> >>Ralph, Sorry, should have read the whole e-mail stream first! Slick >>recommends not leaving anything connected to the controller during flight >>to preclude any "antenna effect" possibly interfering with the >>micro-processor. > >>>-----Original Message----- >>>From: Ralph E. Capen [mailto:recapen(at)earthlink.net] >>>Sent: Thursday, November 19, 2009 6:51 PM >>>To: TRANS Unison Piston Product Support (Unison, Non-Unison) >>>Subject: Fw: LASAR cabling to computer >>> >>>Tried to send this to Joe - but it bounced. >>> >>>Can anyone there help me? >>> >>>I'm looking for pinout diagrams for the RS232 cable connecting the LASAR >>>controller to a computer for diagnostics.... >>> >>>Ralph Capen >>> >>>----- Original Message ----- >>>From: "Ralph E. Capen" <recapen(at)earthlink.net> >>>To: "Logie, Joe (Unison, US)" >>>Sent: Thursday, November 19, 2009 6:28 PM >>>Subject: LASAR cabling to computer >>> >>> >>>> Is there a diagram with the pinouts? >>>> >>>> If not, can you give them to me? >>>> >>>> I would like to make a cable with a disconnect at the firewall in case >>>I >>>> need to do troubleshooting. >>>> >>>> Thanks, >>>> Ralph > > ________________________________________________________________________________
Date: Nov 20, 2009
Subject: elevator trim, manual vs electric
Bob... The future is wireless! If you can wait... I started with manual trim in my -8 and switched to electric. Simpler installation and it works great in John's -8. I put a govenor (Matronics) in to slow the servo speed to make fine adjustments in cruise possible. Chris Stone RV-8 Newberg, OR -----Original Message----- From: Bob Collins Sent: Nov 19, 2009 1:26 PM Subject: RE: RV-List: elevator trim, manual vs electric I have manual trim and am not flying yet. But one thing it kinda hoses up is wiring runs. One of the holes on the left side of the tunnel in my RV-7a is dedicated to a big manual trim cable (and also an ELT wiring run. ) I don't have much electrical stuff in the plane but the hole right side of the tunnel is full up with two strobe cables, a strobe power cable, a nav light cable, and an ELT instrument panel light cable. I could sure use some more room back there. and I havne't even run any antenna cables yet. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph Finch Sent: Thursday, November 19, 2009 9:40 AM Subject: RE: RV-List: elevator trim, manual vs electric Can you explain further? Please? RF From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Divan Sent: Thursday, November 19, 2009 5:22 AM Subject: Re: RV-List: elevator trim, manual vs electric On my flying RV6 Manual aileron trim = love it Electric Elevator trim = HATE IT! If I ever finish my RV7 both will be manual href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Fuel tanks in Germany
Date: Nov 20, 2009
Ok so I built a new set of RV4 tanks for a client in Germany. We had a bit of a miscommunication and I sent him a set for a new model (prepunched skins) wing and his is an early model so he cant use them. I ended up building a new set for him but still need to find a home for the first set. It is cost prohibitive to ship them this direction for some reason so I am looking for someone who can use them on that side of the globe. They are brand new, set up with aerobatic mods on the left side and have Stewart Warner senders installed. I would like to get $1000.00 for them....this is less than half of the retail value. I will entertain any offers of cash or trade (I am currently building an RV9A) Or, If anybody out there has any super deals on shipping them back here, (California) I would sure like to hear about it. I have been told that the military boys get to ship really cheap :) Cheers.. Evan evmeg(at)snowcrest.net ________________________________________________________________________________
Subject: Gretz Heated Pitot Tube attaching
Date: Nov 20, 2009
Folks, I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube fitting does not extend far enough to be able to attach the line to the tube once the tube is in the mount. I'd like to hear from anyone that has found the solution to this problem so I don't have to "reinvent the wheel". Marty in Brentwood TN, RV-6A finish assembly. ________________________________________________________________________________
Date: Nov 20, 2009
Subject: Re: Gretz Heated Pitot Tube attaching
Marty, it's been a bizillion years since I installed my Gretz Pitot tube so I can't offer much other than a few pictures. Here is the technique I used and maybe it will help you out. http://bmnellis.com/WingSkinning3.htm Mike Nellis RV6 Fuselage Roll Bar > > Folks, > I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube > fitting does not extend far enough to be able to attach the line to the tube > once the tube is in the mount. I'd like to hear from anyone that has found > the solution to this problem so I don't have to "reinvent the wheel". > Marty in Brentwood TN, RV-6A finish assembly. > > > ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Nov 21, 2009
What I have done in the past is to extend the line from the wing down through the mount so you can attach the line externally, then push the pitot with the attached line into the mount and secure. Then later it is servicable without opening the wing. -Mike Sent from my iPhone On Nov 20, 2009, at 11:26 PM, "emrath" wrote: > > Folks, > I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot > tube > fitting does not extend far enough to be able to attach the line to > the tube > once the tube is in the mount. I'd like to hear from anyone that > has found > the solution to this problem so I don't have to "reinvent the wheel". > Marty in Brentwood TN, RV-6A finish assembly. > > ________________________________________________________________________________
Date: Nov 21, 2009
At 08:26 PM 11/20/2009 Friday, you wrote: > >Folks, >I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube >fitting does not extend far enough to be able to attach the line to the tube >once the tube is in the mount. I'd like to hear from anyone that has found >the solution to this problem so I don't have to "reinvent the wheel". >Marty in Brentwood TN, RV-6A finish assembly. Hi Marty, Here are some detailed pictures of my Gretz Heated Pitot in the RV-8. Might give you some ideas: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2982&log=81655&row=151 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2982&log=81656&row=150 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2982&log=81657&row=149 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2982&log=81658&row=148 Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com Windscreen Installation (ack)... ________________________________________________________________________________
Date: Nov 21, 2009
Subject: 6A elevator trim tab set-up
I have the manual trim cable installed enough to measure up/down deflection on the trim tab. The manual says 35 deg. down (for nose-up trim) and 25 deg. up. How is that measured? I assume that since the hinge is at the top skin, that you measure it from elev. top skin to trim tab top skin. If that is right, I have about 34 deg. down, but only about 21 deg. up, using the full travel of the trim cable (about 2.3"). Is this something I have to fix? The only way to fix it that I can see is to rivet some aluminum onto the arm of the trim tab so I could make a new attachment point for the cable which would be a little closer to the tab. That would get me more deflection for my 2.3" of motion. The throw of the cable could be increased by removing the locking ring. I don't think I want to do that. Another issue is that the nut that secures the end of the cable. The one which is welded to the little piece of steel. It is about 1/4" above the plate that it is supposed to be pop riveted to. Is this typical? There is no way I can attach it to the cover plate without a substantial spacer. I'm also thinking of holding it in with a couple plate nuts rather than the pop rivets. Seems like the cover plate would be next to impossible to remove if the steel plate was riveted to it. Screws would make it easy to remove. Has any one else had these problems? -- Tom Sargent, RV-6A final assembly. ________________________________________________________________________________
Date: Nov 21, 2009
Subject: Re: Work Bench Cover
I used non-skid rug underlayment. It appears to be like a fine mesh, knotted netting that has been dipped in a soft foam rubber material. The end result is a very flexible sheet of what looks like small beads stuck to each other. The softness cushions the wing skins, the non-skid aspect keeps your work from sliding around, and the gaps / holes in the material provide a place for drilling and deburring chips etc to go such that they can't scratch the aluminum. It can be gotten as drawer liner, but it is MUCH cheaper to get it as rug underlayment from Target, Wally world, or some such. Glen Matejcek ________________________________________________________________________________
Date: Nov 21, 2009
Subject: Gas tank vent line tips
These plastic tips are perfect as vent line caps, just ProSeal them on! _https://www.pattersondental.com/app.aspx?cmd=get_item&id=18669_ (https://www.pattersondental.com/app.aspx?cmd=get_item&id=18669) They are unaffected by gasoline and are cheap, but come in bags of 100----------------so, I've got 90+ that I will never use (I don't like them for their intended purpose in the dental office). Contact me off list for an address to send a suitable SASE and I will mail you 4 for free. Stewart Willoughby, RV6 (fuselage) ________________________________________________________________________________
Date: Nov 21, 2009
Subject: Re: 6A elevator trim tab set-up
Tom, I would not worry about the small deflection problem because you will find that the trim tab is so sensitive that very little movement will be required of it. As for your anchor plate that is a different story. Why is it so far removed from the cover plate? It may be that if it were positioned properly you would recover the lost deflection. Are your stab/tab holes in the correct location? Bob Bales RV6 100 hr TT ________________________________________________________________________________
Subject: In Flight HD Videos
Date: Nov 21, 2009
Anyone out there recording in flight HD videos? I recall seeing a tail mounted bullet camera and some semi-wide angle video that was fantastic. I want to record in flight videos in a similar way. I thought about mounting a HD bullet camera in the fiberglass section of the vertical stabilizer but I cannot find any 12V HD DVR's that are an acceptable size and weight. Most of them are low resolution Security DVR's. A second fly in the ointment is I want to pull the audio in from the audio panel vs. just an open air mic. There seem to be some combination choices like these: Really Small but not HD and no audio input. Or this one: 1080P but no external audio feed. This is an all in one unit so no remote mounting as you have to have access to turn on/off The nice part about this is it's movable Same with this unit: 1080P but no external audio feed. This is an all in one unit so no remote mounting as you have to have access to turn on/off The nice part about this is it's movable Now I made a BIG mistake by mounting two DVD players in my RV-10 when portable ones would have been a much better choice due to advances in technology but I figured mounting an HD camera is not that big a deal as the most important part is the capture device (DVR) but as I can't find any (except the Sony for $3,000) maybe the helmet style is best. I believe this is another example of something I want/need now but the market has not quite caught up with my requirements. Any guidance would be appreciated. Robin ________________________________________________________________________________
Date: Nov 21, 2009
Marty, I made a pair of short AN4 tubes that connect inside the mast and extend outside (up in th the wing). There I have a set of AN4 connectors that allow me to disconnect the 'mess from within the access panel. Ralph Capen ----- Original Message ----- From: "emrath" <emrath(at)comcast.net> Sent: Friday, November 20, 2009 11:26 PM Subject: RV-List: Gretz Heated Pitot Tube attaching > > Folks, > I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube > fitting does not extend far enough to be able to attach the line to the > tube > once the tube is in the mount. I'd like to hear from anyone that has > found > the solution to this problem so I don't have to "reinvent the wheel". > Marty in Brentwood TN, RV-6A finish assembly. > > > ________________________________________________________________________________
Date: Nov 21, 2009
Subject: Re: Gas tank vent line tips
StooDDS(at)aol.com wrote: > These plastic tips are perfect as vent line caps, just ProSeal them on! Sort of depends on the diameter of your vent line ;') If that information is on the web page, I can't find it... Thanks! -- Regards, J. Sonex #325 C-FJNJ, Jabiru 3300a, Prince P-Tip, Aerocarb restoring the Johnston Special http://cleco.ca +-------------------------------------------------------------+ | J. Davis, M.Sc. | (computer science) | | *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca | +-------------------------------------------------------------+ and now... Deep Thought #30, by Jack Handy Ambition is like a frog sitting on a Venus Flytrap. The flytrap can bite and bite, but it won't bother the frog because it only has little tiny plant teeth. But some other stuff could happen and it could be like ambition. ________________________________________________________________________________
Date: Nov 22, 2009
Subject: Make Sure You're Listed! List of Contributors Published in December!
Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2009
The id. is .420" tapering to .425" at the open end. They push over the thread on the AN832-4D fitting. Stewart Willoughby ________________________________________________________________________________
Subject: First passenger
Date: Nov 22, 2009
I got to fly my first passenger yesterday - finished my phase I stuff earlier in the month. Alane (my lovely and patient wife) and I left Laurel airport and did a 1000' flyover of our house and the stables where she keeps her horse. After that, a short trip to Cambridge airport for lunch and watching a handful of Pitts Specials play in the aerobatic box there. The weather looks good again this morning - I'll see who's out and about today. Ralph RV6A N822AR @ N06 44.7 hrs ________________________________________________________________________________
Date: Nov 22, 2009
Subject: Re: elevator trim, manual vs electric
Manual trim is far more precise when setting the trim. It gives a good "touch" making it far easier to get the perfect trim. That is, it gives an excellent feel for where the trim is or needs to be. Electric trim really begs for a motor speed reducer to minimize overrunning (chasing) the desired trim. I love my manual trim and would do it again. I moved mine from between the seats (RV-6) over to the left of the cockpit mounted against the fuselage left wall. I operate it with my left hand. The cable slopes down from the control knob on a 45 degree angle and then loops up along the fuselage wall (near my left knee) and reward running under the left longeron to the rear of the airplane. Neat and out of the way. Pete in Clearwater RV-6, Reserve Grand Champion S 'n F and other awards ________________________________________________________________________________
Subject: Headset Hooks
Date: Nov 22, 2009
Hello Listers, I've noticed headsets on side-by-side RV's hanging on hooks in the baggage compartment. It's likely that the bulkhead panel screws serve dual duty for that. Has anyone made or obtained hooks that they are happy with? Info would be great. Any general info on cabin organization, where you put your checklist etc., would be appreciated. By the way, we're headed south for the winter. Where should we go in the areas of Venice (Florida), Rockport (Texas) and Sedona (Arizona) to check out other folks' RV's? Ian Brown, Bromont, QC RV-9A C-GOHM (55 hours - just getting organized) ________________________________________________________________________________
Date: Nov 22, 2009
For the past 12-years=2C my headset hook has been under the panel. When parked in the sun at a fly-in and having the headsets out in the bagga ge compartment or on the seat=2C they get way too hot to wear. Also less l ikely to be stolen when they cannot be seen. My under panel hook is made from scrap 0.025 or 0.032 bent as a J with a sl ight bend about 1/4" in from the sides that gives some rigidity to the shee t metal. It is more like a L with a lip on the end than a J. | | <- 2 pop rivets go here one above the other | | |_____| It is on the F-902 L and R in the -9(A) and F-602 in the -6(A). Hope the TEXT graphic transmits successfully=2C Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C334+ Flying Hours So. CA=2C USA Subject: RV-List: Headset Hooks From: ixb(at)videotron.ca Date: Sun=2C 22 Nov 2009 16:54:46 -0500 Hello Listers=2C I've noticed headsets on side-by-side RV's hanging on hooks in the baggage compartment. It's likely that the bulkhead panel screws serve dual duty fo r that. Has anyone made or obtained hooks that they are happy with? Info would be great. Any general info on cabin organization=2C where you put your checklist etc.=2C would be appreciated. By the way=2C we're headed south for the winter. Where should we go in the areas of Venice (Florida)=2C Rockport (Texas) and Sedona (Arizona) to chec k out other folks' RV's? Ian Brown=2C Bromont=2C QC RV-9A C-GOHM (55 hours - just getting organized ) _________________________________________________________________ Bing brings you maps=2C menus=2C and reviews organized in one place. http://www.bing.com/search?q=restaurants&form=MFESRP&publ=WLHMTAG&cre a=TEXT_MFESRP_Local_MapsMenu_Resturants_1x1 ________________________________________________________________________________
Date: Nov 22, 2009
Nice installation Matt, but my Pitot was purchased long ago without the electronic module and the tube sticking up from the pitot is only about 1.5" long, terminating in a AN4 tube fitting. Marty From: Matt Dralle <dralle(at)matronics.com> Subject: Re: RV-List: Gretz Heated Pitot Tube attaching At 08:26 PM 11/20/2009 Friday, you wrote: > >Folks, >I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube >fitting does not extend far enough to be able to attach the line to the tube >once the tube is in the mount. I'd like to hear from anyone that has found >the solution to this problem so I don't have to "reinvent the wheel". >Marty in Brentwood TN, RV-6A finish assembly. Hi Marty, Here are some detailed pictures of my Gretz Heated Pitot in the RV-8. Might give you some ideas: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate gory=2982&log=81655&row=151 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate gory=2982&log=81656&row=150 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate gory=2982&log=81657&row=149 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate gory=2982&log=81658&row=148 Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com Windscreen Installation (ack)... ________________________________________________________________________________
Date: Nov 22, 2009
Bob: Yes, I think they're in the right place. There's no discretion in placing the hole in the HS rear spar - there is just barely room for it between the 2 reinforcing bars. As for the elvator, I checked my plans. My drawings are from 1996 (!). The hole in the elevator spar is shown, but no dimensions are specified to locate it. It is towards the bottom of the spar. I could have put it a bit lower (maybe 3/16") before running into anything, but I'm not sure that would still line up well enough with the hole in the H.S. There's only a 2 or 3 inches between the HS spar and the elevator spar. I just made it look like the drawing. I noticed that I didn't have the fork screwed onto the threaded on of the cable completely, so I did that which allowed me to pull the cable a about 3/8" further aft. That brought the anchor plate into slightly better position. Still looks like I'm going to need a 3/16" spacer between it and the cover plate though. I'll call Van's in the morning. On Sat, Nov 21, 2009 at 4:21 PM, wrote: > Are your stab/tab holes in the correct location? > > -- Tom Sargent ________________________________________________________________________________
Date: Nov 23, 2009
We had planned on using manual trim on our 8A.. When we ran it , we went by the shelf where we are putting the ahars for the dynon skyview.we put a boy scout compass on the shelf and found that the last 4 feet or so or the trim cable was magnetized.we were limited on the shelf location and the routing of the cable.so.we are installing the electric trim.anyone installing a remote compass sensor may want to check this out before everything is buttoned up. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of PeterHunt1(at)aol.com Sent: Sunday, November 22, 2009 11:49 AM Subject: RV-List: Re: elevator trim, manual vs electric Manual trim is far more precise when setting the trim. It gives a good "touch" making it far easier to get the perfect trim. That is, it gives an excellent feel for where the trim is or needs to be. Electric trim really begs for a motor speed reducer to minimize overrunning (chasing) the desired trim. I love my manual trim and would do it again. I moved mine from between the seats (RV-6) over to the left of the cockpit mounted against the fuselage left wall. I operate it with my left hand. The cable slopes down from the control knob on a 45 degree angle and then loops up along the fuselage wall (near my left knee) and reward running under the left longeron to the rear of the airplane. Neat and out of the way. Pete in Clearwater RV-6, Reserve Grand Champion S 'n F and other awards ________________________________________________________________________________
Date: Nov 23, 2009
i suppose you could demagnetize the trim cable=0A=0A Thanks,=0A=0A=0AJohn B right=0A=0A=0A=0A________________________________=0AFrom: Glenn Bell <glenn bell(at)cablelynx.com>=0ATo: rv-list(at)matronics.com=0ASent: Mon, November 23, 2 009 9:54:35 AM=0ASubject: RE: RV-List: Re: elevator trim, manual vs electri c =0A=0A =0AWe had planned on using manual trim on our 8A.. When we ran it ,=0Awe went by the shelf where we are putting the ahars for the dynon skyvi ewwe=0Aput a boy scout compass on the shelf and found that the las t 4 feet or so or=0Athe trim cable was magnetizedwe were limited o n the shelf location and=0Athe routing of the cablesowe a re installing the electric trimanyone=0Ainstalling a remote compas s sensor may want to check this out before everything=0Ais buttoned up =0A =0AFrom:owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- server(at)matronics.com] On=0ABehalf Of PeterHunt1(at)aol.com=0ASent: Sunday, Nov ember 22, 2009 11:49 AM=0ATo: rv-list(at)matronics.com=0ASubject: RV-List: Re: elevator trim, manual vs electric =0A =0AManual=0Atrim is far more precise when setting the trim. It gives a good=0A"touch" making it far easier to get the perfect trim. That is,=0Ait gives an excellent feel for where the trim is or needs to be. Electric=0Atrim really begs for a motor speed redu cer to minimize overrunning (chasing)=0Athe desired trim. I love my manual trim and would do it again. I=0Amoved mine from between the seats (RV-6) over to the left of the cockpit=0Amounted against the fuselage left wall. I operate it with my left=0Ahand. The cable slopes down from the control k nob on a 45 degree=0Aangle and then loops up along the fuselage wall (near my left knee) and=0Areward running under the left longeron to the rear of t he airplane. Neat=0Aand out of the way.=0A =0APete=0Ain Clearwater=0ARV-6, =0AReserve Grand Champion S 'n F and other awards=0A =0A =0Awww.aeroelect ric.com=0Awww.buildersbooks.com=0Awww.homebuilthelp.com=0Ahttp://www.matron ics.com/contribution=0Ahttp://www.matronics.com/Navigator?RV-List=0Ahttp:// ===================0A=0A=0A ________________________________________________________________________________
Date: Nov 23, 2009
Loosen the screws holding the mast (mount) to the wing and push it up inside the wing. This will leave the end of the tubing exposed where the flare nut is so you can attach the pitot to it. Then pull the mast back down and reattach it. Thats how mine works...hope this is your answer. Evan ----- Original Message ----- From: "emrath" <emrath(at)comcast.net> Sent: Sunday, November 22, 2009 4:29 PM Subject: RV-List: Gretz Heated Pitot Tube attaching > > Nice installation Matt, but my Pitot was purchased long ago without the > electronic module and the tube sticking up from the pitot is only about > 1.5" > long, terminating in a AN4 tube fitting. > Marty > > > From: Matt Dralle <dralle(at)matronics.com> > Subject: Re: RV-List: Gretz Heated Pitot Tube attaching > > > At 08:26 PM 11/20/2009 Friday, you wrote: >> >>Folks, >>I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube >>fitting does not extend far enough to be able to attach the line to the > tube >>once the tube is in the mount. I'd like to hear from anyone that has >>found >>the solution to this problem so I don't have to "reinvent the wheel". >>Marty in Brentwood TN, RV-6A finish assembly. > > > Hi Marty, > > Here are some detailed pictures of my Gretz Heated Pitot in the RV-8. > Might > give > you some ideas: > > > http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate > gory=2982&log=81655&row=151 > > > http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate > gory=2982&log=81656&row=150 > > > http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate > gory=2982&log=81657&row=149 > > > http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&cate > gory=2982&log=81658&row=148 > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com > Windscreen Installation (ack)... > > > ________________________________________________________________________________
Subject: CHT update
Date: Nov 23, 2009
As many of you may know, I have been obsessing a bit about my CHT's...to get them consistent. Here's the setup: IO360B1F6 9.2:1 pistons AFP Fuel Injection LASAR Ignition with CHT sender relocated to allow for testing Vetterman Dual Crossover Heater/Mufflers SamJames cowl and plenum Advanced Flight Systems 3400 Engine Monitor Oil Cooler mounted behind #4 cylinder Air for both Heater/Mufflers behind #3 cylinder For constant power setting, here's the consistency that I have achieved: #1 and #3 cylinders run within three degrees (avg) of each other #2 and #4 cylinders run within three degrees (avg) of each other The #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 cylinders With the members of the sets of cylinders running this close each other, I'm thinking that I have the balance (front to rear) for each side pretty well matched. I'm trying to wrap my head around what could be causing the right side to run hotter than the left. Here's some of what I'm thinking...: With this plenum set-up, I'm thinking that the pressure/volume should equalize from left to right. This would leave me with not much to change to cause more cooling air to go from the left to the right - meaning that I probably have to live with the differences. Alternatively, maybe it's not really hotter...the two sets of CHT wires for the left side (both equal length) are about three feet longer than the ones for the right side (again, both equal length). Could the difference in the lengths of the wires account for the reported temperature difference? I'm pretty close to thinking that this is as good as it gets...but I would really like to know why... Thanks, Ralph ________________________________________________________________________________
Date: Nov 23, 2009
Subject: Re: CHT update
Ralph, Have you installed an AN960 washer between the rear baffle & cylinder head on the #3 cylinder? The #2 & #3 cylinders have very thin fins between the head itself and the [front on #2] rear baffle. By installing a single washer between the above mentioned parts, for the bolt that holds the rear baffle onto #3, you will reduce the temp on #3. You will then have to cut down the air dam in front of #1 to even out that side. This should help to reduce the side to side variation you have. See http://www.vansairforce.com/community/showpost.php?p=31012&postcount=40 Charlie Kuss --- On Mon, 11/23/09, Ralph E. Capen wrote: > From: Ralph E. Capen <recapen(at)earthlink.net> > Subject: RV-List: CHT update > To: rv-list(at)matronics.com, LycomingEngines-list(at)matronics.com, AeroElectric-list(at)matronics.com > Date: Monday, November 23, 2009, 6:22 PM > > > > > > > > As many of you may know, I have been obsessing a bit > about my CHT's...to > get them consistent. > > Here's the setup: > IO360B1F6 > 9.2:1 > pistons > AFP Fuel Injection > LASAR Ignition with CHT sender relocated to > allow for testing > Vetterman Dual Crossover Heater/Mufflers > SamJames cowl > and plenum > Advanced Flight Systems 3400 Engine Monitor > > Oil Cooler > mounted behind #4 cylinder > Air for both Heater/Mufflers behind #3 > cylinder > > For constant power setting, here's the consistency that > I have > achieved: > #1 and #3 cylinders run within three degrees (avg) of each > other > #2 and #4 cylinders run within three degrees (avg) of each > other > The > #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 > > cylinders > > With the members of the sets of cylinders running this > close > each other, I'm thinking that I have the balance (front > to rear) for each side > pretty well matched. > > I'm trying to wrap my head around what could be > causing the right side to run hotter than the left. > Here's some of what > I'm thinking...: With this plenum set-up, I'm > thinking that the pressure/volume > should equalize from left to right. This would leave > me with not much to > change to cause more cooling air to go from the left to the > right - meaning that > I probably have to live with the differences. > Alternatively, maybe it's > not really hotter...the two sets of CHT wires for the left > side (both equal > length) are about three feet longer than the ones for the > right side (again, > both equal length). Could the difference in the > lengths of the wires > account for the reported temperature difference? > > I'm pretty close to > thinking that this is as good as it gets...but I would > really like to know > why... > > Thanks, > Ralph > > > > > > > provided > > ________________________________________________________________________________
Subject: CHT update
Date: Nov 23, 2009
Ralph, As one who has been perplexed by temperatures (RV-10, James Cowl, Plenum etc...) I would sleep quite well at night with your numbers. If you are looking for reasons why one bank is different that the other you can consider the oil cooler asymmetry or prop rotation or maybe some differences on the lower portion of the fire wall forward making exit air asymmetrical or you can put some of this on the sensors ability to resolve these very small differences in relative temperature. As far as the "pressure volume equalizing left to right" maybe yes, maybe no. I suspect proving this may be very difficult w/o extensive R&D for what benefit? Cutting the difference in half so you are within 4 degrees left/right. I tend to think of the air under the Cowl/Plenum as a frantic tumbling & crashing of molecules with a large amount of air reversing course and exiting out the front of the cowl. It is not a smooth aerodynamic "flow through" environment under the hood. I think even with your numbers you can retain bragging rights over 99% of aircraft flying today. An alternative solution is to revert back to a single CHT/EGT probe and consider them all the same. Wa-la perfect balance! EFIS = Eliminate Further Ignorance Systems Well done, Robin From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, November 23, 2009 3:23 PM AeroElectric-list(at)matronics.com Subject: RV-List: CHT update As many of you may know, I have been obsessing a bit about my CHT's...to get them consistent. Here's the setup: IO360B1F6 9.2:1 pistons AFP Fuel Injection LASAR Ignition with CHT sender relocated to allow for testing Vetterman Dual Crossover Heater/Mufflers SamJames cowl and plenum Advanced Flight Systems 3400 Engine Monitor Oil Cooler mounted behind #4 cylinder Air for both Heater/Mufflers behind #3 cylinder For constant power setting, here's the consistency that I have achieved: #1 and #3 cylinders run within three degrees (avg) of each other #2 and #4 cylinders run within three degrees (avg) of each other The #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 cylinders With the members of the sets of cylinders running this close each other, I'm thinking that I have the balance (front to rear) for each side pretty well matched. I'm trying to wrap my head around what could be causing the right side to run hotter than the left. Here's some of what I'm thinking...: With this plenum set-up, I'm thinking that the pressure/volume should equalize from left to right. This would leave me with not much to change to cause more cooling air to go from the left to the right - meaning that I probably have to live with the differences. Alternatively, maybe it's not really hotter...the two sets of CHT wires for the left side (both equal length) are about three feet longer than the ones for the right side (again, both equal length). Could the difference in the lengths of the wires account for the reported temperature difference? I'm pretty close to thinking that this is as good as it gets...but I would really like to know why... Thanks, Ralph ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: CHT update
Date: Nov 23, 2009
I'd guess you are well be within the accuracy of the temperature probes themselves. In other words, you are way close enough. Carl Froehlich RV-8A (500 hrs) RV-10 (installing systems) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, November 23, 2009 6:23 PM AeroElectric-list(at)matronics.com Subject: RV-List: CHT update As many of you may know, I have been obsessing a bit about my CHT's...to get them consistent. Here's the setup: IO360B1F6 9.2:1 pistons AFP Fuel Injection LASAR Ignition with CHT sender relocated to allow for testing Vetterman Dual Crossover Heater/Mufflers SamJames cowl and plenum Advanced Flight Systems 3400 Engine Monitor Oil Cooler mounted behind #4 cylinder Air for both Heater/Mufflers behind #3 cylinder For constant power setting, here's the consistency that I have achieved: #1 and #3 cylinders run within three degrees (avg) of each other #2 and #4 cylinders run within three degrees (avg) of each other The #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 cylinders With the members of the sets of cylinders running this close each other, I'm thinking that I have the balance (front to rear) for each side pretty well matched. I'm trying to wrap my head around what could be causing the right side to run hotter than the left. Here's some of what I'm thinking...: With this plenum set-up, I'm thinking that the pressure/volume should equalize from left to right. This would leave me with not much to change to cause more cooling air to go from the left to the right - meaning that I probably have to live with the differences. Alternatively, maybe it's not really hotter...the two sets of CHT wires for the left side (both equal length) are about three feet longer than the ones for the right side (again, both equal length). Could the difference in the lengths of the wires account for the reported temperature difference? I'm pretty close to thinking that this is as good as it gets...but I would really like to know why... Thanks, Ralph ________________________________________________________________________________
Date: Nov 23, 2009
If your end results are all cylinders staying below 400 in climb and preferably below 380, your balance between cylinders, both front to rear and side to side is more than adequate. As for reasons the right side is hotter, it is last in the oil delivery plumbing, so the lifters and rocker boxes get about 1/2 what the left side gets. Most Lycomings have #2 and #3 run hottest because of too tight cowling in front of #2 and behind #3, where there are no fins on the intake side of head, so only with a little spacing, perhaps 1/8" will you get airflow over that side of the cylinder. The spacer is worth about 30 degrees cooler. Ralph E. Capen wrote: > As many of you may know, I have been obsessing a bit about my CHT's...to > get them consistent. > > Here's the setup: > IO360B1F6 > 9.2:1 pistons > AFP Fuel Injection > LASAR Ignition with CHT sender relocated to allow for testing > Vetterman Dual Crossover Heater/Mufflers > SamJames cowl and plenum > Advanced Flight Systems 3400 Engine Monitor > > Oil Cooler mounted behind #4 cylinder > Air for both Heater/Mufflers behind #3 cylinder > > For constant power setting, here's the consistency that I have achieved: > #1 and #3 cylinders run within three degrees (avg) of each other > #2 and #4 cylinders run within three degrees (avg) of each other > The #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 cylinders > > With the members of the sets of cylinders running this close each other, > I'm thinking that I have the balance (front to rear) for each side > pretty well matched. > > I'm trying to wrap my head around what could be causing the right side > to run hotter than the left. Here's some of what I'm thinking...: With > this plenum set-up, I'm thinking that the pressure/volume should > equalize from left to right. This would leave me with not much to > change to cause more cooling air to go from the left to the right - > meaning that I probably have to live with the differences. > Alternatively, maybe it's not really hotter...the two sets of CHT wires > for the left side (both equal length) are about three feet longer than > the ones for the right side (again, both equal length). Could the > difference in the lengths of the wires account for the reported > temperature difference? > > I'm pretty close to thinking that this is as good as it gets...but I > would really like to know why... > > Thanks, > Ralph > > * > > > * ________________________________________________________________________________
Date: Nov 24, 2009
Subject: Rate of climb and CHT
Just curious, is there any consensus as what typical rate-of-climb helps the most in keeping the CHTs to a minimum. Bob ________________________________________________________________________________
Date: Nov 24, 2009
Subject: Re: Rate of climb and CHT
120 mph -GV In a message dated 11/23/2009 8:02:30 P.M. Pacific Standard Time, rv6n(at)optonline.net writes: Just curious, is there any consensus as what typical rate-of-climb helps the most in keeping the CHTs to a minimum. ________________________________________________________________________________
Date: Nov 24, 2009
I usually climb at 110-120 knots and the CHT's stay below 400F.=C2- Pull the nose up in a big way and they start going up... Weight and temperature dependant, a 110-120 knot climb delivers 800-1500 fp m.. KB ----- Original Message ----- From: rv6n(at)optonline.net Sent: Monday, November 23, 2009 10:24:15 PM GMT -05:00 US/Canada Eastern Subject: RV-List: Rate of climb and CHT Just curious, is there any consensus=C2-as what typical rate-of-climb hel ps the most in keeping the CHTs=C2-to a minimum. Bob ________________________________________________________________________________
Date: Nov 24, 2009
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 24, 2009
Charlie, I've already done both of these parts as you have suggested. I did them in steps so that I could get the #1 and #3 balanced as well as they are. Thanks, Ralph -----Original Message----- >From: Charles Kuss <chaskuss(at)yahoo.com> >Sent: Nov 23, 2009 6:56 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: CHT update > > >Ralph, > Have you installed an AN960 washer between the rear baffle & cylinder head on the #3 cylinder? The #2 & #3 cylinders have very thin fins between the head itself and the [front on #2] rear baffle. By installing a single washer between the above mentioned parts, for the bolt that holds the rear baffle onto #3, you will reduce the temp on #3. You will then have to cut down the air dam in front of #1 to even out that side. This should help to reduce the side to side variation you have. See > >http://www.vansairforce.com/community/showpost.php?p=31012&postcount=40 > >Charlie Kuss > >--- On Mon, 11/23/09, Ralph E. Capen wrote: > >> From: Ralph E. Capen <recapen(at)earthlink.net> >> Subject: RV-List: CHT update >> To: rv-list(at)matronics.com, LycomingEngines-list(at)matronics.com, AeroElectric-list(at)matronics.com >> Date: Monday, November 23, 2009, 6:22 PM >> >> >> >> >> >> >> >> As many of you may know, I have been obsessing a bit >> about my CHT's...to >> get them consistent. >> >> Here's the setup: >> IO360B1F6 >> 9.2:1 >> pistons >> AFP Fuel Injection >> LASAR Ignition with CHT sender relocated to >> allow for testing >> Vetterman Dual Crossover Heater/Mufflers >> SamJames cowl >> and plenum >> Advanced Flight Systems 3400 Engine Monitor >> >> Oil Cooler >> mounted behind #4 cylinder >> Air for both Heater/Mufflers behind #3 >> cylinder >> >> For constant power setting, here's the consistency that >> I have >> achieved: >> #1 and #3 cylinders run within three degrees (avg) of each >> other >> #2 and #4 cylinders run within three degrees (avg) of each >> other >> The >> #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 >> >> cylinders >> >> With the members of the sets of cylinders running this >> close >> each other, I'm thinking that I have the balance (front >> to rear) for each side >> pretty well matched. >> >> I'm trying to wrap my head around what could be >> causing the right side to run hotter than the left. >> Here's some of what >> I'm thinking...: With this plenum set-up, I'm >> thinking that the pressure/volume >> should equalize from left to right. This would leave >> me with not much to >> change to cause more cooling air to go from the left to the >> right - meaning that >> I probably have to live with the differences. >> Alternatively, maybe it's >> not really hotter...the two sets of CHT wires for the left >> side (both equal >> length) are about three feet longer than the ones for the >> right side (again, >> both equal length). Could the difference in the >> lengths of the wires >> account for the reported temperature difference? >> >> I'm pretty close to >> thinking that this is as good as it gets...but I would >> really like to know >> why... >> >> Thanks, >> Ralph >> >> >> >> >> >> >> provided >> >> > > > > > ________________________________________________________________________________
Date: Nov 24, 2009
Subject: CHT update
Thanks Robin, Good to hear this from multiple sources, Ralph -----Original Message----- >From: Robin Marks <robin1(at)mrmoisture.com> >Sent: Nov 23, 2009 7:02 PM >To: rv-list(at)matronics.com >Subject: RE: RV-List: CHT update > >Ralph, > > As one who has been perplexed by temperatures (RV-10, >James Cowl, Plenum etc...) I would sleep quite well at night with your >numbers. If you are looking for reasons why one bank is different that >the other you can consider the oil cooler asymmetry or prop rotation or >maybe some differences on the lower portion of the fire wall forward >making exit air asymmetrical or you can put some of this on the sensors >ability to resolve these very small differences in relative temperature. >As far as the "pressure volume equalizing left to right" maybe yes, >maybe no. I suspect proving this may be very difficult w/o extensive R&D >for what benefit? Cutting the difference in half so you are within 4 >degrees left/right. I tend to think of the air under the Cowl/Plenum as >a frantic tumbling & crashing of molecules with a large amount of air >reversing course and exiting out the front of the cowl. It is not a >smooth aerodynamic "flow through" environment under the hood. I think >even with your numbers you can retain bragging rights over 99% of >aircraft flying today. > >An alternative solution is to revert back to a single CHT/EGT probe and >consider them all the same. Wa-la perfect balance! EFIS = Eliminate >Further Ignorance Systems > > > >Well done, > >Robin > > > >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Monday, November 23, 2009 3:23 PM >To: rv-list(at)matronics.com; LycomingEngines-list(at)matronics.com; >AeroElectric-list(at)matronics.com >Subject: RV-List: CHT update > > > >As many of you may know, I have been obsessing a bit about my CHT's...to >get them consistent. > >Here's the setup: >IO360B1F6 >9.2:1 pistons >AFP Fuel Injection >LASAR Ignition with CHT sender relocated to allow for testing >Vetterman Dual Crossover Heater/Mufflers >SamJames cowl and plenum >Advanced Flight Systems 3400 Engine Monitor > >Oil Cooler mounted behind #4 cylinder >Air for both Heater/Mufflers behind #3 cylinder > >For constant power setting, here's the consistency that I have achieved: >#1 and #3 cylinders run within three degrees (avg) of each other >#2 and #4 cylinders run within three degrees (avg) of each other >The #1/#3 cylinders run 8.5 degrees hotter (avg) than the #2/#4 >cylinders > >With the members of the sets of cylinders running this close each other, >I'm thinking that I have the balance (front to rear) for each side >pretty well matched. > >I'm trying to wrap my head around what could be causing the right side >to run hotter than the left. Here's some of what I'm thinking...: With >this plenum set-up, I'm thinking that the pressure/volume should >equalize from left to right. This would leave me with not much to >change to cause more cooling air to go from the left to the right - >meaning that I probably have to live with the differences. >Alternatively, maybe it's not really hotter...the two sets of CHT wires >for the left side (both equal length) are about three feet longer than >the ones for the right side (again, both equal length). Could the >difference in the lengths of the wires account for the reported >temperature difference? > >I'm pretty close to thinking that this is as good as it gets...but I >would really like to know why... > >Thanks, >Ralph > > > > ________________________________________________________________________________
Date: Nov 26, 2009
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 26, 2009
Subject: RV-8 - Baggage Door Strut...
Dear Listers, The stock front baggage door on the RV-8 doesn't come with any means of holding it open other than your arm. Since I'd already experienced what happens when the latch pins are in the "latched" position and the door suddenly slams shut (dents and scratches), I really wanted to find a nice strut of some kind that would hold the door open, yet be relatively easy to install/replace/use. Some browsing in the McMaster-Carr on-line catalog turned up what turn out to be the absolute *perfect* part for the job. The strut unit is made for tool box lids and has pre-installed mounts on each end that work perfectly on the RV-8 baggage door with no modifications whatsoever. Incredible, really. The best part is that in operation, and using the mounting dimensions shown in the pictures, the strut will securely hold the door open AND closed! Its amazing actually! At about 2" from closed the geometry of the system has nearly zero pressure open/closed and then at the last 1" or so, slightly pulls the door down. Note that the latch pins are still needed to hold the door securely closed. Conversely, after about 3" open, there is enough push in the spring to gently open the door all the way and then hold it open very nicely. If you have an RV-8 and want a baggage door strut, look no further. This is the perfect ticket: McMaster-Carr Part Number: 11615A14 Here is the on-line web page for the part: http://www.mcmaster.com/#11615A14 At $34.75 (circa 2009) its a little pricey, but its stainless steel and did I mention - works PERFECTLY on the RV-8 front baggage door! Buy one now! I used three standard LP4-3 pop rivets on the top attachment hinge to the side of the baggage door, and two #8 platenuts and screws on the lower attachment. For the correct geometry, you'll want to mount the upper hinge exactly 11/16" from the bottom of the door as shown in the pictures. The lower hinge should be mounted exactly 8.0" from the exterior skin of the fuselage as shown in the picture. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog ________________________________________________________________________________
Date: Nov 28, 2009
Subject: No "Black Friday" For List Fund Raiser...
Even though the number of List subscriptions and List posts are up significantly this year compared to last year, support during this year's List Fund Raiser has been woefully lagging from last year. There are only a couple more days left in November and the end of the Fund Raiser is quickly approaching. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid on the List service expenses, I will have to look into some sort of advertising. Please don't let that happen! Your personal contribution of $20 or $30 goes a long ways to keeping the operation a float. The lunch combo at Carl's Jr costs nearly $10 these days. Isn't the List worth at least as much as a couple of burgers? Please make sure your name is on this year's List of Contributors published in December. The Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 29, 2009
Subject: Just Two More Days Left; Fund Raiser Behind By 12%...
Dear Listers, This year's List Fund Raiser is still trailing last year by a 12% margin. If you like the ad-free environment that is the Matronics Email List and Forum experience, please make a quick Contribution to keep it that way! http://www.matronics.com/contribution I've been getting a ton of really nice comments from Contributors regarding the Lists. Please read over some of them below and see if they don't resonate with you as well. Thank you in advance for your generous contribution to support these Lists! Matt Dralle Matronics Email List Administrator --------------------------- Member Feedback ---------------------------- ur web site is a real institution of the whole Experimental Aircraft subculture. John G Thanks Matt for the lists. A lot of good info. Great bunch of list members. Great videos and no SPAM. Paul C It has been a valuable tool. Troy M ..appreciate the site as much as ever. Larry M By using various forums I've learned a ton, received great advice, made friends, and saved money! Craig W Since I've finished [my project], I've not had much to do as far as fabrication of electrical systems. However, selectively reading various topics is still very valuable and Bob's insights and new how to's make me a continuous subscriber. Larry F Matronics user groups are the best tool I have for learning to build my RV-10! Philip W There is always useful knowledge to be found on this list, and I suspect that it has kept quite a few people out of trouble over the years it has been in operation. Good entertainment, too. Graham H Great web site. I wish I'd known about it while building. Bob S I'm happy to provide some support to this list. It is very helpful. Vaughn T Good service to sport aviation!! Roger B Awesome Service you provide for us! Bill R My [project] is almost finished! However, it wouldn't be close without the [this] group. Douwe B Great list. Robert S I'm not a builder yet but learning lots from the list. Peter M Some nonsense, some humor, but mostly good information. Tony C Thanks for creating and keeping the Lists. They are entertaining and always informative! John M Thanks for this valuable resource to our community. Barry H The list is IMHO the greatest resource on the net. John B Thanks again for providing another year of your useful List service. Jerry B Great site indeed, every time I get a message I usually learn something. Peter B You are making a huge contribution to the builder fraternity and in no small way enhancing sport aviation safety. Richard G The List is the SINGLE, MOST IMPORTANT resource I have in building my RV10. I would be lost without out it. And I have made a bunch of new friends as well! Les K The lists are one of the things I really enjoy, so keep up the good work. Freddie H Every year -- the best value for my time and money! Owen B This list is a major contribution to safe building! Donald K Really enjoy the daily boost it gives me. Walter S In the last 18 months I have been privileged to listen & ask. I have learnt at the feet of the masters... Stewart G You set the standard on how Internet forums should be run and managed. Larry W The Universe is a better place because of you. Eric J [The List] helped me get flying, fly off my test hours and make my systems better. I continue to get and give information through these lists. Ralph C ..another GREAT year of advice, answers, and inspiration courtesy of the Lists and your hard work!!!! Rob B ..the best forum on the Internet! Robert B I can't tell you how grateful I am for your list and your subscribers to keep me up to date and holding the dream. Ashley M This page makes it easy to contribute. Jeffrey P Thank you for your expertise in creating & running the much useful lists! Anthony P Thanks for providing our advertising free on line community. George R Thanks for maintaining the equipment and software to provide this valuable source of information to us individuals. Your effort is appreciated by many more people than you realize. Ross H Thanks for a great site. Although the project is complete and flying I still get a wealth of information from all the messages. Marcus C Only learned about you six months ago...my RV-7A is just finished, but the list has been helpful. Wish I had discovered you sooner. Jack B This is an invaluable communications media for us common minded folks to exchange technical and other information. George H ..great service that you provide. David W ..still appreciate your list. Alain L [The] Lists are an invaluable resource. I know that it has helped me enormously in my project. William B ________________________________________________________________________________
Date: Nov 29, 2009
For those of you with an interest in the average performance of my RV8 equipped with a IO-390 Lycoming engine, Aero Composites propeller, Sam James cowl and plenum, Dual lightspeed electronic ignition, the following is provided. Please do not ask for Email replies,, I will be happy to discuss any questions via telephone anytime. 920 619 6968. initial rate of climb,@ 100 mph is 3000 fpm first 2000 feet sustained ROC up to 11000 is 2000 fpm (start @800 msl) (ROC in montana mountains on way to Vans homecoming flyin above 12,000 to 17,000 avg 300 fpm). I love my RV-8. ----- Original Message ----- From: kboatright1(at)comcast.net To: rv-list(at)matronics.com Sent: Monday, November 23, 2009 11:12 PM Subject: Re: RV-List: Rate of climb and CHT I usually climb at 110-120 knots and the CHT's stay below 400F. Pull the nose up in a big way and they start going up... Weight and temperature dependant, a 110-120 knot climb delivers 800-1500 fpm.. KB ----- Original Message ----- From: rv6n(at)optonline.net To: "RV list" Sent: Monday, November 23, 2009 10:24:15 PM GMT -05:00 US/Canada Eastern Subject: RV-List: Rate of climb and CHT Just curious, is there any consensus as what typical rate-of-climb helps the most in keeping the CHTs to a minimum. Bob 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 30, 2009
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means at least two things. For better or worse, its my 46th birthday! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been jones'n over one of the really nice gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution so far this year in support of our Lists. It is your generosity that keeps this operation a float and I don't ever forget it. Hopefully everyone feels the same. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Mystery Washer
Date: Nov 30, 2009
Folks, I'm in finally assembly of my RV-6A and have a couple AN970-516 washers (sort of a "fender" washer). Can any -6A builder's advise me where these are to be utilized? It seems to me the only -5 bolt is the one attaching the rear spar to the fuselage spar carry thru fork; my drawings show using AN960 washers in this application. Thanks for your assistance in advance. Marty in Brentwood TN ________________________________________________________________________________
Date: Nov 30, 2009
Subject: Flop Tubes 4-Sale
I've got 2 new flop-tubes (fuel pickup aerobatic flight) that I bought from Vans, but didn't use on my RV7A. If anyone's interested, I'll sell them for $32ea ($60 for both) and I'll pay UPS shipping in conUS. Pics available on request. "Jerry" ________________________________________________________________________________
Date: Nov 30, 2009
From: "David E. Nelson" <david.nelson(at)pobox.com>
Subject: Re: Mystery Washer
Hi Marty in Brentwood TN, On the -7A's, I think these washers are used on the front axle to provide for a slot of sorts for the nose gear fairing. Perhaps it's the same on -6A's. Regards, /\/elson ~~ Lately my memory seems to be like a steel trap .... without any spring. ~~ On Mon, 30 Nov 2009, emrath wrote: > > Folks, > I'm in finally assembly of my RV-6A and have a couple AN970-516 washers > (sort of a "fender" washer). Can any -6A builder's advise me where these > are to be utilized? It seems to me the only -5 bolt is the one attaching > the rear spar to the fuselage spar carry thru fork; my drawings show using > AN960 washers in this application. Thanks for your assistance in advance. > Marty in Brentwood TN > > ________________________________________________________________________________
Date: Nov 30, 2009
Subject: RV lands on street in phx
I saw a short story on the local TV station web page (www.kvoa.com) saying that an Van's RV-6 had an engine failure on approach to Deer Valley airport in phoenix at 9:20am Saturday. No injuries and, they say, no damage to plane. Any one know about this event? -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Nov 30, 2009
As there are only two they may be the ones used on the wing leading edge to fuselage attaching point. Mike Robertson Das Fed > Date: Mon=2C 30 Nov 2009 08:53:35 -0600 > From: david.nelson(at)pobox.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Mystery Washer > > > > Hi Marty in Brentwood TN=2C > > On the -7A's=2C I think these washers are used on the front axle to provi de for a > slot of sorts for the nose gear fairing. Perhaps it's the same on -6A's. > > Regards=2C > /\/elson > > ~~ Lately my memory seems to be like a steel trap .... without any spring . ~~ > > On Mon=2C 30 Nov 2009=2C emrath wrote: > > > > > Folks=2C > > I'm in finally assembly of my RV-6A and have a couple AN970-516 washers > > (sort of a "fender" washer). Can any -6A builder's advise me where thes e > > are to be utilized? It seems to me the only -5 bolt is the one attachin g > > the rear spar to the fuselage spar carry thru fork=3B my drawings show using > > AN960 washers in this application. Thanks for your assistance in advanc e. > > Marty in Brentwood TN > > > > > > > > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Hotmail: Trusted email with Microsoft's powerful SPAM protection. ________________________________________________________________________________
Date: Nov 30, 2009
Could they be for the wing leading edge/tank mount where the bolt is adjusted to slide out of the bracket in an accident that pushes the wing aft? > Folks, > I'm in finally assembly of my RV-6A and have a couple AN970-516 washers > (sort of a "fender" washer). Can any -6A builder's advise me where these > are to be utilized? It seems to me the only -5 bolt is the one attaching > the rear spar to the fuselage spar carry thru fork; my drawings show using > AN960 washers in this application. Thanks for your assistance in advance. > Marty in Brentwood TN ________________________________________________________________________________
Date: Nov 30, 2009
Subject: Wing cart pointer
I'm looking for a pointer to a set of plans (or photos) for a "cart" that I can use to hold my wings. Nothing fancy, just a plywood and 2 x 4 cart with wheels is all I'm looking for. I find that my garage is increasingly harder to navigate with this growing pile of airplane parts! Many thanks! Rick (RV-6A - lots of metal still to bend) ________________________________________________________________________________
Date: Nov 30, 2009
Subject: Re: Wing cart pointer
Hi Richard, No plans, but a good idea of what I did: http://caura.dyndns.org/gallery/Right-Wing/afo I used a wing rib as a template for the cutouts. I notched the inboard ends to keep the main spar from vibrating/bouncing off while moving things around. I used the plywood from the "wing kit" and some 2x4's. There's a long 2x4 that joins the two ends. On each end, there is a 2x4 at a 45 deg angle that attaches to the side and the "long 2x4" (sorry, no pic - just some ascii art below). These provide support for the sides so they "flop over". |\ /| | \ / | | \ / | ----------------- Things I'd do again: - Find some old casters and install them. Makes moving _very_ easy. - Bottoms of the wings facing outward Things I'd change or do differently: - You'll notice that for each caster, I doubled up on the 2x4's. I should have sandwiched the vertical portions of the cradle w/ the 2x4's rather than stacked the 2x4's. Reason being, the plywood is not the sturdiest material and now there's a twisting moment on the plywood. So far, I've not had a problems but it definately doesn't give me any good feelings, neither. - I would not have made the outboard end of the cradle so deep; but rather about 4" below the main spar. Two reasons: 1) Makes taking the wing in and out a little easier since one doesn't have to lift it so high. 2) I riveted on my bottom skins with the wing in the cradle and I needed to be able to lift the skin out of the way. Things to look out for: - If you're installing the Duckworks leading edge landing lights, be sure that the overall length of the cradle won't position the cradle support where the light will be installed. Regards, /\/elson ~~ Lately my memory seems to be like a steel trap .... without any spring. ~~ On Mon, 30 Nov 2009, Richard Wagoner wrote: > > I'm looking for a pointer to a set of plans (or photos) for a "cart" > that I can use to hold my wings. Nothing fancy, just a plywood > and 2 x 4 cart with wheels is all I'm looking for. > > I find that my garage is increasingly harder to navigate with > this growing pile of airplane parts! > > Many thanks! > > Rick (RV-6A - lots of metal still to bend) > > > > > ________________________________________________________________________________
Date: Nov 30, 2009
If you're in a population center of more that a few thousand you'll probably find a hand-me-down cart available near by. Just ask. Regards, Greg Young _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard Wagoner Sent: Monday, November 30, 2009 12:05 PM Subject: RV-List: Wing cart pointer I'm looking for a pointer to a set of plans (or photos) for a "cart" that I can use to hold my wings. Nothing fancy, just a plywood and 2 x 4 cart with wheels is all I'm looking for. I find that my garage is increasingly harder to navigate with this growing pile of airplane parts! Many thanks! Rick (RV-6A - lots of metal still to bend) ________________________________________________________________________________
Date: Dec 01, 2009
Subject: Vernatherm stuck open?
Folks, I think my Vernatherm is stuck in the open position allowing oil to always flow through the oil cooler. Here's the basis for my thinking: In October during some of my flights, I was seeing OAT's of 35 and 40 with corresponding OilT's of 174 and 179. In November during one flight I had OAT of 62 and OilT of 177 - I stopped and had lunch - during the flight home, I had OAT of 65 and OilT of 146. Yes plenty of time for it to have warmed up...and no, I didn't change anything on the airplane during lunch. All flights after that one have had OAT's in the 50's and 60's with OilT's not breaking 140. Your thoughts please... How do I unstick the Vernatherm? Is it possible that during lunch that day, my rings seated and my engine finished its break-in process? Thanks, Ralph RV6A N822AR @ N06 46.3 hrs - happy with the CHT's, found something else buggin' me ________________________________________________________________________________
Date: Dec 01, 2009
Subject: Re: Vernatherm stuck open?
The Vernatherm doesn't work that way. It has an expanding salt/wax inside and expands with temperature until it closes the bypass opening. There are published dimensions, so you can remove the vernatherm, measure its length and see whether it is at the expanded dimension or cold dimension. You also could just create a cover for your oil cooler with say 50% as big an opening as the cooler itself, and see if it makes a difference, watching to see oil doesn't get too hot. Ralph E. Capen wrote: > > Folks, > > I think my Vernatherm is stuck in the open position allowing oil to always flow through the oil cooler. > > Here's the basis for my thinking: > > In October during some of my flights, I was seeing OAT's of 35 and 40 with corresponding OilT's of 174 and 179. > > In November during one flight I had OAT of 62 and OilT of 177 - I stopped and had lunch - during the flight home, I had OAT of 65 and OilT of 146. Yes plenty of time for it to have warmed up...and no, I didn't change anything on the airplane during lunch. > > All flights after that one have had OAT's in the 50's and 60's with OilT's not breaking 140. > > Your thoughts please... How do I unstick the Vernatherm? Is it possible that during lunch that day, my rings seated and my engine finished its break-in process? > > Thanks, > Ralph > RV6A N822AR @ N06 46.3 hrs - happy with the CHT's, found something else buggin' me > > > > > > > > ________________________________________________________________________________
Date: Dec 01, 2009
Subject: Re: Wing Cart
Thanks Nelson & Greg! Rick ________________________________ ________________________________________________________________________________
Subject: Wing Cart
Date: Dec 01, 2009
In addition to what David Nelson said about a wing cart: - Make sure your castering wheels are well attached to a robust structure. Mine were always falling off/breaking the wood because there is a lot of force acting through them. - I used ex-furniture casters which worked fine in the garage, but not on the more uneven driveway. - Make one end the shape of the wing rib and the other end flat, to support the main spar as it exits the wing. - Decide how you want the wings facing before you cut the shapes. Least space would be lower surfaces facing each other, but facing outwards lets you work through the access panels in the wings. - You don't actually need an outer frame if you use a relatively strong spine, like a 2X4 attached to a 2X6 but make it shorter than the distance from the landing lights to the inner wing. - I found foam strips, stapled in place around the curvature of the wing slot helped protect the wings. Best of luck, Ian Brown, Bromont, Quebec, RV-9A ________________________________________________________________________________
Subject: Re: Oregon Innovations WIg Wag vs Duckworks HID
Date: Dec 01, 2009
I have been using an electronic wig-wag unit made by Sound Off Signal, model number 'ETHFSS-SP' and it works great. Read about it at their website... http://www.soundoffsignal.com/warnamber/flashers/Headlight/ETHFSS-SP.htm You can buy one for about $40 online... http://ledguy.net/store/index.php?main_page=product_info&products_id=106 I have recently installed a $60.00 HID kit (2 bulbs & 2 power packs) I got on eBay (search for seller FLASHPLUS - no business affiliation!) and have been flashing the HIDs with the above wig-wag unit with great success. -------- Tony Kirk RV-6A N57TK www.TomsRV8.com webmaster www.EAA582.org Read this topic online here: http://forums.matronics.com/viewtopic.php?p=275651#275651 Attachments: http://forums.matronics.com//files/n57tk_wigwag_hid_204.wmv ________________________________________________________________________________
Subject: Wing Cart
Date: Dec 02, 2009
Depending on available space=2C you might want to make two individual carts =2C which will give you more options in moving the wings around. Subject: RV-List: Wing Cart From: ixb(at)videotron.ca Date: Tue=2C 1 Dec 2009 17:38:37 -0500 In addition to what David Nelson said about a wing cart: - Make sure your castering wheels are well attached to a robust structure. Mine were always falling off/breaking the wood because there is a lot of f orce acting through them. - I used ex-furniture casters which worked fine in the garage=2C but not on the more uneven driveway. - Make one end the shape of the wing rib and the other end flat=2C to suppo rt the main spar as it exits the wing. - Decide how you want the wings facing before you cut the shapes. Least spa ce would be lower surfaces facing each other=2C but facing outwards lets yo u work through the access panels in the wings. - You don't actually need an outer frame if you use a relatively strong sp ine=2C like a 2X4 attached to a 2X6 but make it shorter than the distance f rom the landing lights to the inner wing. - I found foam strips=2C stapled in place around the curvature of the wing slot helped protect the wings. Best of luck=2C Ian Brown=2C Bromont=2C Quebec=2C RV-9A _________________________________________________________________ Windows 7: Unclutter your desktop. Learn more. http://www.microsoft.com/windows/windows-7/videos-tours.aspx?h=7sec&slide id=1&media=aero-shake-7second&listid=1&stop=1&ocid=PID24727::T:WL MTAGL:ON:WL:en-US:WWL_WIN_7secdemo:122009 ________________________________________________________________________________
Date: Dec 01, 2009
Thanks for the idea Nelson, but my kit was prior to this mod for the nose wheel. I've since order the updated parts and modified mine and I believe the axle is a AN6 bolt not a AN5 but my plans are at the hanger. Always great to hear from Das Fed :>), but I already checked this and the leading edge tank to fuselage bolt is a AN4 so "NO JOY" here. Great ideas of things to check, I'm still trying to sort this out. Perhaps a call to Van's is in order. Marty From: Mike Robertson <mrobert569(at)hotmail.com> Subject: RE: RV-List: Mystery Washer As there are only two they may be the ones used on the wing leading edge to fuselage attaching point. Mike Robertson Das Fed > Date: Mon=2C 30 Nov 2009 08:53:35 -0600 > From: david.nelson(at)pobox.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Mystery Washer > > > > Hi Marty in Brentwood TN=2C > > On the -7A's=2C I think these washers are used on the front axle to > provi de for a > slot of sorts for the nose gear fairing. Perhaps it's the same on > -6A's. > > Regards=2C > /\/elson > > ~~ Lately my memory seems to be like a steel trap .... without any > spring . ~~ > > On Mon=2C 30 Nov 2009=2C emrath wrote: > > > > > Folks=2C > > I'm in finally assembly of my RV-6A and have a couple AN970-516 > > washers (sort of a "fender" washer). Can any -6A builder's advise me > > where thes e > > are to be utilized? It seems to me the only -5 bolt is the one > > attachin g > > the rear spar to the fuselage spar carry thru fork=3B my drawings > > show using > > AN960 washers in this application. Thanks for your assistance in > > advanc e. > > Marty in Brentwood TN > > > > > > > > > > > > > ========== ========== ========== ========== ________________________________________________________________________________
Date: Dec 02, 2009
Can anyone provide the published dimensions - or point to the publication they are published in? I have some pubs - but don't know where to look... Thanks, Ralph -----Original Message----- >From: Kelly McMullen <kellym(at)aviating.com> >Sent: Dec 1, 2009 11:50 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Vernatherm stuck open? > > >The Vernatherm doesn't work that way. It has an expanding salt/wax >inside and expands with temperature until it closes the bypass opening. >There are published dimensions, so you can remove the vernatherm, >measure its length and see whether it is at the expanded dimension or >cold dimension. You also could just create a cover for your oil cooler >with say 50% as big an opening as the cooler itself, and see if it makes >a difference, watching to see oil doesn't get too hot. > >Ralph E. Capen wrote: >> >> Folks, >> >> I think my Vernatherm is stuck in the open position allowing oil to always flow through the oil cooler. >> >> Here's the basis for my thinking: >> >> In October during some of my flights, I was seeing OAT's of 35 and 40 with corresponding OilT's of 174 and 179. >> >> In November during one flight I had OAT of 62 and OilT of 177 - I stopped and had lunch - during the flight home, I had OAT of 65 and OilT of 146. Yes plenty of time for it to have warmed up...and no, I didn't change anything on the airplane during lunch. >> >> All flights after that one have had OAT's in the 50's and 60's with OilT's not breaking 140. >> >> Your thoughts please... How do I unstick the Vernatherm? Is it possible that during lunch that day, my rings seated and my engine finished its break-in process? >> >> Thanks, >> Ralph >> RV6A N822AR @ N06 46.3 hrs - happy with the CHT's, found something else buggin' me >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 02, 2009
I found a couple different measurements, but haven't found the specs yet cold: 3.800" hot:4.031" diff: 0.231 (3/16" = 0.1876") The Vernaterm should extend at least 0.160" Between 150 F and 185 F (the temperature stamped on the Vernatherm 85 C ). These are individual opinions or measurements..I'm still looking for something official. Ralph E. Capen wrote: > > Can anyone provide the published dimensions - or point to the publication they are published in? > > I have some pubs - but don't know where to look... > > Thanks, > Ralph > > -----Original Message----- >> From: Kelly McMullen <kellym(at)aviating.com> >> Sent: Dec 1, 2009 11:50 AM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: Vernatherm stuck open? >> >> >> The Vernatherm doesn't work that way. It has an expanding salt/wax >> inside and expands with temperature until it closes the bypass opening. >> There are published dimensions, so you can remove the vernatherm, >> measure its length and see whether it is at the expanded dimension or >> cold dimension. You also could just create a cover for your oil cooler >> with say 50% as big an opening as the cooler itself, and see if it makes >> a difference, watching to see oil doesn't get too hot. >> >> Ralph E. Capen wrote: >>> >>> Folks, >>> >>> I think my Vernatherm is stuck in the open position allowing oil to always flow through the oil cooler. >>> >>> Here's the basis for my thinking: >>> >>> In October during some of my flights, I was seeing OAT's of 35 and 40 with corresponding OilT's of 174 and 179. >>> >>> In November during one flight I had OAT of 62 and OilT of 177 - I stopped and had lunch - during the flight home, I had OAT of 65 and OilT of 146. Yes plenty of time for it to have warmed up...and no, I didn't change anything on the airplane during lunch. >>> >>> All flights after that one have had OAT's in the 50's and 60's with OilT's not breaking 140. >>> >>> Your thoughts please... How do I unstick the Vernatherm? Is it possible that during lunch that day, my rings seated and my engine finished its break-in process? >>> >>> Thanks, >>> Ralph >>> RV6A N822AR @ N06 46.3 hrs - happy with the CHT's, found something else buggin' me >>> >>> >>> >>>
October 17, 2009 - December 02, 2009
RV-Archive.digest.vol-uf
