RV-Archive.digest.vol-um
June 01, 2010 - July 01, 2010
      Chris
      On Tue, Jun 1, 2010 at 4:58 AM,  wrote:
      > If you are drilling holes for 3/32" rivets, shouldn't you be using a #40
      > drill and not a 3/32"?
      > ---- Chris Colohan  wrote:
      > > I've reached the horizontal stabilizer in building my RV-10.  While
      > drilling
      > > the 3/32" holes in the spar doublers for the forward spar, I mucked one
      > of
      > > the holes up.
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 01, 2010
Subject: Re: Fixing a bad hole...
You could countersink the mis-drilled hole and put a flush rivet in it, under the skin. Then using the pre-drilled skin as a template, drill the correct hole in the spar, and continue on. I'd think that one repair on the spar wouldn't have much if any effect on the overall strength. If you're concerned about the strength of the spar cap you could put a doubler under the existing row of rivets that picked up 6-8 holes. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Jun 1, 2010 at 8:20 AM, Chris Colohan wrote: > This is a slightly unusual assembly in the RV-10. > > The spar comes pre-drilled with undersized holes in the flange. The > doubler comes with no holes. > > You clamp the doubler on the spar, and drill through the existing spar > flange holes and through the doubler with a 3/32" drill. When you later > assemble the whole thing with the skin in place, you match drill everything > (including the skin) with a #40 drill. > > So for this hole I've messed up the spar flange and doubler, and now have a > misplaced hole to go under my pre-drilled skin (which I have not touched > yet). I was hoping to find a solution which does not involve: (a) drilling > another hole right next to the first mistake, since that would weaken the > spar flange, or (b) making my skin look ugly. I fear this solution doesn't > exist... > > Chris > > On Tue, Jun 1, 2010 at 4:58 AM, wrote: > >> If you are drilling holes for 3/32" rivets, shouldn't you be using a #40 >> drill and not a 3/32"? >> >> >> ---- Chris Colohan wrote: >> > I've reached the horizontal stabilizer in building my RV-10. While >> drilling >> > the 3/32" holes in the spar doublers for the forward spar, I mucked one >> of >> > the holes up. >> >> > * > > > * > > ________________________________________________________________________________
Date: Jun 01, 2010
Subject: RV-9A on its back in Hanover County, VA
http://www.nbc12.com/global/story.asp?s=12575399 ________________________________________________________________________________
Date: Jun 01, 2010
Chris, However you fix this oops, save yourself a lot of headaches in the future by ordering a dozen or so #40 and #30 (for AN4 rivets) drill bits from Avery or Cleveland Tool. Do not use fractional drill bits for aircraft rivets. A sharp #40 drill should take no more than about 5 seconds to go thru that flange. Harry Crosby RV-6 N16CX, 692 hours ----- Original Message ----- From: "Chris Colohan" <rv10(at)colohan.com> Sent: Monday, May 31, 2010 9:51:12 PM GMT -08:00 US/Canada Pacific Subject: RV-List: Fixing a bad hole... I've reached the horizontal stabilizer in building my RV-10. While drilling the 3/32" holes in the spar doublers for the forward spar, I mucked one of the holes up. In particular, the drill appears to have slid about 3/32" sideways while drilling, mis-placing the hole by 3/32". Perhaps better explained through pictures: http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink So I know how to fix a hole when you make it slightly too large -- you drill it out larger and put an "oops" rivet in it. But what can you do to fix a hole which is misplaced? Is there a good fix for this? Drilling a hole large enough to cover this error would take a rivet larger than 1/8"... (At worst, I can just replace the spar -- I have a spare, due to an earlier error that Van's made, and so I'd just need to order some new spar doublers. But I'd like to first learn if I can fix this one.) Also, while I have your ear -- I made this error while using a brand new Rigid Cobalt drill bit (like this one: http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm ). The bit appears to be able to cut sideways just as well (or even better) than it can drill straight ahead in aluminum. It also takes about 20-30 seconds per hole drilling at 4000rpm (assuming my air drill is making its rated speed) while applying moderate pressure. Is this a known problem with this type of bit, or is my drilling technique off? I've ordered some "aviation" 3/32" bits from Avery, but wanted to know if I should expect it to be easier to drill straight with those bits. Thanks! ________________________________________________________________________________
Date: Jun 01, 2010
Also, you need a drill with a good teasing trigger that you can start very slow, and only after the drill bit has started, run the speed up high. Chicago Pneumatics makes a good one that Avery sells for around $125, and there are the Sioux drills for about double that. On 6/1/2010 7:43 AM, John Bright wrote: > It's only one hole of tens... not a structural issue... you could do > your best with an oops rivet and move on. Is it a cosmetic issue with > the skin? You don't show the skin... is the skin bungled-up also? You > could fill around it on the exterior skin cosmetically with pro-seal > when you mix it for the tanks. > > I like the 135 degree split points. IMO cobalt or TiN or whatever does > not matter to us with this aluminum. Split points have less tendency > to walk than 118 degree non split points but they will still walk. All > drills make triangular holes in thin sheet metal. > > I use an electric drill that spins maybe 2,400 rpm and I go thru skin > and doubler in 1 or 2 seconds. I don't know what's going on with 20-30 > seconds but something is wrong. > Thanks, > > John Bright > o:757-864-2305 > c:757-812-1909 > > > ------------------------------------------------------------------------ > *From:* Chris Colohan > *To:* rv-list(at)matronics.com > *Sent:* Tue, June 1, 2010 12:51:12 AM > *Subject:* RV-List: Fixing a bad hole... > > I've reached the horizontal stabilizer in building my RV-10. While > drilling the 3/32" holes in the spar doublers for the forward spar, I > mucked one of the holes up. > > In particular, the drill appears to have slid about 3/32" sideways > while drilling, mis-placing the hole by 3/32". Perhaps better > explained through pictures: > > http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > > So I know how to fix a hole when you make it slightly too large -- you > drill it out larger and put an "oops" rivet in it. But what can you > do to fix a hole which is misplaced? Is there a good fix for this? > Drilling a hole large enough to cover this error would take a rivet > larger than 1/8"... > > (At worst, I can just replace the spar -- I have a spare, due to an > earlier error that Van's made, and so I'd just need to order some new > spar doublers. But I'd like to first learn if I can fix this one.) > > Also, while I have your ear -- I made this error while using a brand > new Rigid Cobalt drill bit (like this one: > http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The > bit appears to be able to cut sideways just as well (or even better) > than it can drill straight ahead in aluminum. It also takes about > 20-30 seconds per hole drilling at 4000rpm (assuming my air drill is > making its rated speed) while applying moderate pressure. Is this a > known problem with this type of bit, or is my drilling technique off? > I've ordered some "aviation" 3/32" bits from Avery, but wanted to > know if I should expect it to be easier to drill straight with those bits. > > Thanks! > > Chris > > * > > > * ________________________________________________________________________________
Date: Jun 01, 2010
Chris, - I see at least two ways of addressing that particular problem: - [IMG]http://i48.tinypic.com/11lsxz9.jpg[/IMG] - First fix option: You could "pull" the hole over and clean-it up although I suspect it may need to go up to .1875 to do that perfectly.- Then afte r dimpling, the hole would require an AD6 rivet or more likely....a structu ral screw. The problem is you likely do not possess the proper tooling to c lean up the hole and even if you did, any 3/16" fastener would stand out li ke a sore thumb among all those AD3 rivets. Still, here is a link to "build ers tip" I once wrote that-describes-the technique of "pulling" or movi ng a hole over: - http://www.vansairforce.com/community/showthread.php?t=11769&highlight= move+hole+bushing - Second fix option: This fix is what I would be inclined to do, because in t he end you can-install a regular AD3 rivet in the bad-hole as if it nev er existed.--Using a pattern file or similar, clean up the bad hole in the spar so no sharp edges exist.- Then fabricate an .032 doubler of a gi ven length.--You could install that doubler-by simply picking up a nu mber-of existing holes-in the spar OR you could fabricate it as shown i n the second picture by riveting it in place using a total of- four NAS10 97 rivets through the spar and doubler. Then later, when the skin is clecoe d into place, use the subject hole location on the match hole skin to-dri ll through the doubler.- The over-sized spar hole would be-effectively ignored.- Care must be taken to insure whatever dimpling you do-to the spar is effective.- Done properly, nobody but you will ever know. - Rick Galati - RV-6A RV-8 ________________________________________________________________________________
Date: Jun 01, 2010
I have a bunch of these numbered bits from Avery -- but the in this one place the instructions call for drilling to 3/32" when you assemble the spar and doublers, and then match drilling up to #40 when you have the skins in place. I've now ordered some fractional aviation bits from Avery, and so when I redo this I'll have the right tools. Chris On Tue, Jun 1, 2010 at 1:15 PM, wrote: > Chris, > > However you fix this oops, save yourself a lot of headaches in the future > by ordering a dozen or so #40 and #30 (for AN4 rivets) drill bits from Avery > or Cleveland Tool. Do not use fractional drill bits for aircraft rivets. A > sharp #40 drill should take no more than about 5 seconds to go thru that > flange. > > Harry Crosby > RV-6 N16CX, 692 hours > > > ----- Original Message ----- > From: "Chris Colohan" <rv10(at)colohan.com> > To: rv-list(at)matronics.com > Sent: Monday, May 31, 2010 9:51:12 PM GMT -08:00 US/Canada Pacific > Subject: RV-List: Fixing a bad hole... > > I've reached the horizontal stabilizer in building my RV-10. While > drilling the 3/32" holes in the spar doublers for the forward spar, I mucked > one of the holes up. > > In particular, the drill appears to have slid about 3/32" sideways while > drilling, mis-placing the hole by 3/32". Perhaps better explained through > pictures: > > > http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > > http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink > > http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > > http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > > So I know how to fix a hole when you make it slightly too large -- you > drill it out larger and put an "oops" rivet in it. But what can you do to > fix a hole which is misplaced? Is there a good fix for this? Drilling a > hole large enough to cover this error would take a rivet larger than 1/8"... > > (At worst, I can just replace the spar -- I have a spare, due to an earlier > error that Van's made, and so I'd just need to order some new spar doublers. > But I'd like to first learn if I can fix this one.) > > Also, while I have your ear -- I made this error while using a brand new > Rigid Cobalt drill bit (like this one: > http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The bit > appears to be able to cut sideways just as well (or even better) than it can > drill straight ahead in aluminum. It also takes about 20-30 seconds per > hole drilling at 4000rpm (assuming my air drill is making its rated speed) > while applying moderate pressure. Is this a known problem with this type of > bit, or is my drilling technique off? I've ordered some "aviation" 3/32" > bits from Avery, but wanted to know if I should expect it to be easier to > drill straight with those bits. > > Thanks! > > Chris > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Jun 01, 2010
I have the Avery drill -- the issue here is not that I started the hole in the wrong place, but that once the hole started through one piece of aluminum the bit managed to expand the hole sideways into a giant oval instead of drilling through the next piece. It acted more like a router than a drill. :-( After the messages on this list and off -- I've ordered new HS-1013 doublers from Van's, and will use this with my spare spar to redo the whole thing the right way. Chris On Tue, Jun 1, 2010 at 1:16 PM, Kelly McMullen wrote: > > Also, you need a drill with a good teasing trigger that you can start very > slow, and only after the drill bit has started, run the speed up high. > Chicago Pneumatics makes a good one that Avery sells for around $125, and > there are the Sioux drills for about double that. > > > On 6/1/2010 7:43 AM, John Bright wrote: > >> It's only one hole of tens... not a structural issue... you could do your >> best with an oops rivet and move on. Is it a cosmetic issue with the skin? >> You don't show the skin... is the skin bungled-up also? You could fill >> around it on the exterior skin cosmetically with pro-seal when you mix it >> for the tanks. >> >> I like the 135 degree split points. IMO cobalt or TiN or whatever does not >> matter to us with this aluminum. Split points have less tendency to walk >> than 118 degree non split points but they will still walk. All drills make >> triangular holes in thin sheet metal. >> >> I use an electric drill that spins maybe 2,400 rpm and I go thru skin and >> doubler in 1 or 2 seconds. I don't know what's going on with 20-30 seconds >> but something is wrong. >> Thanks, >> >> John Bright >> o:757-864-2305 >> c:757-812-1909 >> >> >> ------------------------------------------------------------------------ >> *From:* Chris Colohan >> *To:* rv-list(at)matronics.com >> >> *Sent:* Tue, June 1, 2010 12:51:12 AM >> *Subject:* RV-List: Fixing a bad hole... >> >> I've reached the horizontal stabilizer in building my RV-10. While >> drilling the 3/32" holes in the spar doublers for the forward spar, I mucked >> one of the holes up. >> >> In particular, the drill appears to have slid about 3/32" sideways while >> drilling, mis-placing the hole by 3/32". Perhaps better explained through >> pictures: >> >> >> http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> So I know how to fix a hole when you make it slightly too large -- you >> drill it out larger and put an "oops" rivet in it. But what can you do to >> fix a hole which is misplaced? Is there a good fix for this? Drilling a >> hole large enough to cover this error would take a rivet larger than 1/8"... >> >> (At worst, I can just replace the spar -- I have a spare, due to an >> earlier error that Van's made, and so I'd just need to order some new spar >> doublers. But I'd like to first learn if I can fix this one.) >> >> Also, while I have your ear -- I made this error while using a brand new >> Rigid Cobalt drill bit (like this one: >> http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The bit >> appears to be able to cut sideways just as well (or even better) than it can >> drill straight ahead in aluminum. It also takes about 20-30 seconds per >> hole drilling at 4000rpm (assuming my air drill is making its rated speed) >> while applying moderate pressure. Is this a known problem with this type of >> bit, or is my drilling technique off? I've ordered some "aviation" 3/32" >> bits from Avery, but wanted to know if I should expect it to be easier to >> drill straight with those bits. >> >> Thanks! >> >> Chris >> >> * >> >> >> * >> > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Fixing a bad hole...
Date: Jun 01, 2010
The way I approach these kind of problems: 1. If you can drill it out to 1/8", then do so and use a 1/8" rivet. No one will ever see the one or two 1/8" rivets in the sea of 3/32" rivets. 2. If after drilling out the screw up the hole it too large, then just get a replacement part from Van's. The parts are cheap - especially when you think about flying this plane for 20-30 years and every time you look at the tail you wonder if you should have replace the part or not. Carl Froehlich RV-8A (550 hrs) RV-10 (systems install) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chris Colohan Sent: Tuesday, June 01, 2010 5:29 PM Subject: Re: RV-List: Fixing a bad hole... I have a bunch of these numbered bits from Avery -- but the in this one place the instructions call for drilling to 3/32" when you assemble the spar and doublers, and then match drilling up to #40 when you have the skins in place. I've now ordered some fractional aviation bits from Avery, and so when I redo this I'll have the right tools. Chris On Tue, Jun 1, 2010 at 1:15 PM, wrote: Chris, However you fix this oops, save yourself a lot of headaches in the future by ordering a dozen or so #40 and #30 (for AN4 rivets) drill bits from Avery or Cleveland Tool. Do not use fractional drill bits for aircraft rivets. A sharp #40 drill should take no more than about 5 seconds to go thru that flange. Harry Crosby RV-6 N16CX, 692 hours ----- Original Message ----- From: "Chris Colohan" <rv10(at)colohan.com> Sent: Monday, May 31, 2010 9:51:12 PM GMT -08:00 US/Canada Pacific Subject: RV-List: Fixing a bad hole... I've reached the horizontal stabilizer in building my RV-10. While drilling the 3/32" holes in the spar doublers for the forward spar, I mucked one of the holes up. In particular, the drill appears to have slid about 3/32" sideways while drilling, mis-placing the hole by 3/32". Perhaps better explained through pictures: <http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HH lTjwc?feat=directlink> http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHl Tjwc?feat=directlink <http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HH lTjwc?feat=directlink> http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHl Tjwc?feat=directlink <http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HH lTjwc?feat=directlink> http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHl Tjwc?feat=directlink <http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HH lTjwc?feat=directlink> http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHl Tjwc?feat=directlink So I know how to fix a hole when you make it slightly too large -- you drill it out larger and put an "oops" rivet in it. But what can you do to fix a hole which is misplaced? Is there a good fix for this? Drilling a hole large enough to cover this error would take a rivet larger than 1/8"... (At worst, I can just replace the spar -- I have a spare, due to an earlier error that Van's made, and so I'd just need to order some new spar doublers. But I'd like to first learn if I can fix this one.) Also, while I have your ear -- I made this error while using a brand new Rigid Cobalt drill bit (like this one: <http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm> http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The bit appears to be able to cut sideways just as well (or even better) than it can drill straight ahead in aluminum. It also takes about 20-30 seconds per hole drilling at 4000rpm (assuming my air drill is making its rated speed) while applying moderate pressure. Is this a known problem with this type of bit, or is my drilling technique off? I've ordered some "aviation" 3/32" bits from Avery, but wanted to know if I should expect it to be easier to drill straight with those bits. Thanks! Chris t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 01, 2010
Subject: Re: Trouble with Altimeter
Went out to the airport today to blow out the static line and adjust the altimeter. It was back to normal. Took a flight and it worked OK. Had some flutter to it though. Don't know about it's longevity. David R. Cook N815DC RV-6 Flying ________________________________ From: david cook <davercook1501(at)yahoo.com> Sent: Mon, May 31, 2010 10:34:17 PM Subject: Re: RV-List: Trouble with Altimeter Thanks for the replies. I will let you know the end result. David R. Cook N815DC RV-6 Flying ________________________________ From: david cook <davercook1501(at)yahoo.com> Sent: Sat, May 29, 2010 8:37:40 PM Subject: RV-List: Trouble with Altimeter Hi All My altimeter just went crazy. Jumped in the ole 6 and spotted the altitude had gone up 300 feet. Reset to field elevation and the pressure reading was 28.7. I looked around an there was no hurricane in sight. Any one have an explanation. The unit is only 3 years old from Vans. Do I just reset it or is there a problem? Dave David R. Cook N815DC RV-6 Flying ________________________________________________________________________________
Date: Jun 01, 2010
I agree with this approach. Done properly, there should be no strength compromise. You can also slightly countersink the underside of the bad hole, to give the shop head a better grip. In fact, I know there are a number of RV 10 wings that have this sort of repair where the plans call for one single lug nut plate in the middle of a bunch of two lug nut plates. Before long you will learn how to efficiently repair your mistakes, the plan mistakes, the QB facility mistakes, etc. In fact, fixing mistakes is one of the better skills you acquire as you move along. There are some who say you should just pick a finger to drill through, with a small bit, so it isn't a surprise when it happens. Since I had already done that long ago working on the motorhome type of RV, I figured I didn't need to repeat the experience. ;-p On 6/1/2010 10:35 AM, Dave Saylor wrote: > You could countersink the mis-drilled hole and put a flush rivet in > it, under the skin. Then using the pre-drilled skin as a template, > drill the correct hole in the spar, and continue on. I'd think that > one repair on the spar wouldn't have much if any effect on the overall > strength. If you're concerned about the strength of the spar cap you > could put a doubler under the existing row of rivets that picked up > 6-8 holes. > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Tue, Jun 1, 2010 at 8:20 AM, Chris Colohan > wrote: > > This is a slightly unusual assembly in the RV-10. > > The spar comes pre-drilled with undersized holes in the flange. > The doubler comes with no holes. > > You clamp the doubler on the spar, and drill through the existing > spar flange holes and through the doubler with a 3/32" drill. > When you later assemble the whole thing with the skin in place, > you match drill everything (including the skin) with a #40 drill. > > So for this hole I've messed up the spar flange and doubler, and > now have a misplaced hole to go under my pre-drilled skin (which I > have not touched yet). I was hoping to find a solution which does > not involve: (a) drilling another hole right next to the first > mistake, since that would weaken the spar flange, or (b) making my > skin look ugly. I fear this solution doesn't exist... > > Chris > > On Tue, Jun 1, 2010 at 4:58 AM, > wrote: > > If you are drilling holes for 3/32" rivets, shouldn't you be > using a #40 drill and not a 3/32"? > > > ---- Chris Colohan > wrote: > > I've reached the horizontal stabilizer in building my RV-10. > While drilling > > the 3/32" holes in the spar doublers for the forward spar, I > mucked one of > > the holes up. > > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution * > > > * > > > * ________________________________________________________________________________
Date: Jun 01, 2010
Personally, I have found that #41 drills make for a snugger fit dimpled hole. I use either the drill bit for new holes, or #41 chucking reamer to enlarge the pre-punched holes. The reamer both makes it unlikely you will get a hole where it isn't supposed to be, and leaves a smoother edge that needs less de-burring. Most of my skins were probably pre-punched to #42, and won't accept dimple die, but with #41 the dimple die fits perfectly. On 6/1/2010 1:15 PM, HCRV6(at)comcast.net wrote: > Chris, > > However you fix this oops, save yourself a lot of headaches in the > future by ordering a dozen or so #40 and #30 (for AN4 rivets) drill > bits from Avery or Cleveland Tool. Do not use fractional drill bits > for aircraft rivets. A sharp #40 drill should take no more than about > 5 seconds to go thru that flange. > > Harry Crosby > RV-6 N16CX, 692 hours > > ----- Original Message ----- > From: "Chris Colohan" <rv10(at)colohan.com> > To: rv-list(at)matronics.com > Sent: Monday, May 31, 2010 9:51:12 PM GMT -08:00 US/Canada Pacific > Subject: RV-List: Fixing a bad hole... > > I've reached the horizontal stabilizer in building my RV-10. While > drilling the 3/32" holes in the spar doublers for the forward spar, I > mucked one of the holes up. > > In particular, the drill appears to have slid about 3/32" sideways > while drilling, mis-placing the hole by 3/32". Perhaps better > explained through pictures: > > http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > > So I know how to fix a hole when you make it slightly too large -- you > drill it out larger and put an "oops" rivet in it. But what can you > do to fix a hole which is misplaced? Is there a good fix for this? > Drilling a hole large enough to cover this error would take a rivet > larger than 1/8"... > > (At worst, I can just replace the spar -- I have a spare, due to an > earlier error that Van's made, and so I'd just need to order some new > spar doublers. But I'd like to first learn if I can fix this one.) > > Also, while I have your ear -- I made this error while using a brand > new Rigid Cobalt drill bit (like this one: > http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The > bit appears to be able to cut sideways just as well (or even better) > than it can drill straight ahead in aluminum. It also takes about > 20-30 seconds per hole drilling at 4000rpm (assuming my air drill is > making its rated speed) while applying moderate pressure. Is this a > known problem with this type of bit, or is my drilling technique off? > I've ordered some "aviation" 3/32" bits from Avery, but wanted to > know if I should expect it to be easier to drill straight with those bits. > > Thanks! > > Chris > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > * > > > * ________________________________________________________________________________
Date: Jun 01, 2010
Sounds like your drill bit was either bent, or not installed straight in the drill. You shouldn't get that kind of wobble from a drill bit. You can keep a few pieces of scrap to test a drill bit on before doing critical parts, and to fine tune your rivet gun pressures before driving any that will look bad if not driven right. Don't feel bad. I know one or two people that misread the instructions and misdrilled those doublers, needing to obtain new ones. When you get into wings and fuselage you will forget all those minor speed bumps on the tail. On 6/1/2010 2:27 PM, Chris Colohan wrote: > I have the Avery drill -- the issue here is not that I started the > hole in the wrong place, but that once the hole started through one > piece of aluminum the bit managed to expand the hole sideways into a > giant oval instead of drilling through the next piece. It acted more > like a router than a drill. :-( > > After the messages on this list and off -- I've ordered new HS-1013 > doublers from Van's, and will use this with my spare spar to redo the > whole thing the right way. > > Chris > > On Tue, Jun 1, 2010 at 1:16 PM, Kelly McMullen > wrote: > > > > > Also, you need a drill with a good teasing trigger that you can > start very slow, and only after the drill bit has started, run the > speed up high. Chicago Pneumatics makes a good one that Avery > sells for around $125, and there are the Sioux drills for about > double that. > > > On 6/1/2010 7:43 AM, John Bright wrote: > > It's only one hole of tens... not a structural issue... you > could do your best with an oops rivet and move on. Is it a > cosmetic issue with the skin? You don't show the skin... is > the skin bungled-up also? You could fill around it on the > exterior skin cosmetically with pro-seal when you mix it for > the tanks. > > I like the 135 degree split points. IMO cobalt or TiN or > whatever does not matter to us with this aluminum. Split > points have less tendency to walk than 118 degree non split > points but they will still walk. All drills make triangular > holes in thin sheet metal. > > I use an electric drill that spins maybe 2,400 rpm and I go > thru skin and doubler in 1 or 2 seconds. I don't know what's > going on with 20-30 seconds but something is wrong. > Thanks, > > John Bright > o:757-864-2305 > c:757-812-1909 > > > ------------------------------------------------------------------------ > *From:* Chris Colohan > > *To:* rv-list(at)matronics.com > > *Sent:* Tue, June 1, 2010 12:51:12 AM > *Subject:* RV-List: Fixing a bad hole... > > I've reached the horizontal stabilizer in building my RV-10. > While drilling the 3/32" holes in the spar doublers for the > forward spar, I mucked one of the holes up. > > In particular, the drill appears to have slid about 3/32" > sideways while drilling, mis-placing the hole by 3/32". > Perhaps better explained through pictures: > > http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > > So I know how to fix a hole when you make it slightly too > large -- you drill it out larger and put an "oops" rivet in > it. But what can you do to fix a hole which is misplaced? Is > there a good fix for this? Drilling a hole large enough to > cover this error would take a rivet larger than 1/8"... > > (At worst, I can just replace the spar -- I have a spare, due > to an earlier error that Van's made, and so I'd just need to > order some new spar doublers. But I'd like to first learn if > I can fix this one.) > > Also, while I have your ear -- I made this error while using a > brand new Rigid Cobalt drill bit (like this one: > http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The > bit appears to be able to cut sideways just as well (or even > better) than it can drill straight ahead in aluminum. It also > takes about 20-30 seconds per hole drilling at 4000rpm > (assuming my air drill is making its rated speed) while > applying moderate pressure. Is this a known problem with this > type of bit, or is my drilling technique off? I've ordered > some "aviation" 3/32" bits from Avery, but wanted to know if I > should expect it to be easier to drill straight with those bits. > > Thanks! > > Chris > > * > > > * > > > ========== > get="_blank">http://www.matronics.com/Navigator?RV-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * ________________________________________________________________________________
Date: Jun 02, 2010
Maybe there's still some trapped water in the system??? Linn david cook wrote: > Went out to the airport today to blow out the static line and adjust > the altimeter. It was back to normal. > Took a flight and it worked OK. Had some flutter to it though. Don't > know about it's longevity. > > David R. Cook > N815DC RV-6 > Flying > > > ------------------------------------------------------------------------ > *From:* david cook > *To:* rv-list(at)matronics.com > *Sent:* Mon, May 31, 2010 10:34:17 PM > *Subject:* Re: RV-List: Trouble with Altimeter > > Thanks for the replies. I will let you know the end result. > > David R. Cook > N815DC RV-6 > Flying > > > ------------------------------------------------------------------------ > *From:* david cook > *To:* RV-List > *Sent:* Sat, May 29, 2010 8:37:40 PM > *Subject:* RV-List: Trouble with Altimeter > > Hi All > My altimeter just went crazy. Jumped in the ole 6 and spotted the > altitude had gone up 300 feet. Reset to field elevation and the > pressure reading was 28.7. I looked around an there was no hurricane > in sight. > Any one have an explanation. The unit is only 3 years old from Vans. > Do I just reset it or is there a problem? > > Dave > > David R. Cook > N815DC RV-6 > Flying > > > * > > > * > > * > > > * > > * > > > * ________________________________________________________________________________
Date: Jun 02, 2010
Of all the rhetoric this thread has generated, I find the suggestion of making the hole 'clean' to accept a rivet .... put one in, and then use the skin as a guide to redrill the hole .... with a good bit. As Kelly said in a previous post .... fixing (not replacing) an oops will become a common skill. Linn Kelly McMullen wrote: > > Sounds like your drill bit was either bent, or not installed straight > in the drill. You shouldn't get that kind of wobble from a drill bit. > You can keep a few pieces of scrap to test a drill bit on before > doing critical parts, and to fine tune your rivet gun pressures before > driving any that will look bad if not driven right. > Don't feel bad. I know one or two people that misread the instructions > and misdrilled those doublers, needing to obtain new ones. When you > get into wings and fuselage you will forget all those minor speed > bumps on the tail. ________________________________________________________________________________
Subject: Radio Noise
Date: Jun 02, 2010
Here is a tough one that maybe some of you guys can point me in the right direction to look. Set up is: RV-7A with an SL-30, Bob Archer antenna in left wingtip, with PTT on stick also FWIW I have a P-Mag and E-mag. Radio is excellent on ground in both transmit and receive, reception in air is OK however when I press the PTT the noise is horrible with static and breaking up. This has been a consistent condition. Attempts to correct the problem have been: checking antenna installation in wingtip, everything seems fine, Checking connectors where stick PTT plugs into the system, the PTT pin may not have been fully seated, it is now, trying different headsets. Nothing has solved the problem to date. I have been working with the tower on this flying the same circuit and when I contact them it is always somewhere between almost NORDO to just generally poor communications. When I'm back on the ground everything is just fine again. Ideas, directions or suggestions? Jim Thorne RV-7A CHD About 12 Hours now. ________________________________________________________________________________
Date: Jun 02, 2010
Subject: New safety tool - canopy breaker
We just received a shipment of a brand new safety item. The Sabre Aviation canopy breaker is something that many of us would want to consider placing right next to our fire extinguisher. Check it out. http://www.flyboyaccessories.com/sto...roducts_id=377 cessories.com/store/index.php?main_page=product_info&cPath=76&products_ id=377> http://www.flyboyaccessories.com/store/index.php?main_page=product_info&c Path=76&products_id=377 Thanks, __________________ Vince Frazier www.flyboyaccessories.com<http://www.flyboyaccessories.com> RV and Rocket Accessories, Tailwheels, Tools, & More 1-888-8FLYBOY (1-888-835-9269) ________________________________________________________________________________
Date: Jun 02, 2010
Jim, My guess is you have a classic example of installing a fairly complex antenna, following instructions, but then not doing the antenna testing and tuning to make it work. From your description you have RF getting back into the audio, either via the radio or audio panel. The first thing I would look at is antenna tuning. If not properly tuned, the antenna will reflect some of the transmit energy back to the radio via the feed line. While a very poor antenna will always receive and transmit something, both will be degraded. On the ground the proximity to the earth may mask this problem. I built two wingtip antennas similar in design to the Archer antenna. I also have 30 years of playing with all kinds of antennas and some basic test equipment to verify they are properly tuned. The one op check I did with someone flying next to me using an out of the box Archer antenna resulted in the controller hearing me but not hearing the other guy. I can also verify the wingtip communication antenna does not work as well as a belly mounted whip (my primary antenna), but it works good enough. The Archer is a good product, but without tuning it or not having it properly mounted the performance could be hit or miss. Recommend you find yourself a knowledgeable Amateur Radio Operator to come over and take a look. Carl Froehlich KV4U RV-8A (540 hrs) RV-10 (system install) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Thorne Sent: Wednesday, June 02, 2010 1:42 PM Subject: RV-List: Radio Noise Here is a tough one that maybe some of you guys can point me in the right direction to look. Set up is: RV-7A with an SL-30, Bob Archer antenna in left wingtip, with PTT on stick also FWIW I have a P-Mag and E-mag. Radio is excellent on ground in both transmit and receive, reception in air is OK however when I press the PTT the noise is horrible with static and breaking up. This has been a consistent condition. Attempts to correct the problem have been: checking antenna installation in wingtip, everything seems fine, Checking connectors where stick PTT plugs into the system, the PTT pin may not have been fully seated, it is now, trying different headsets. Nothing has solved the problem to date. I have been working with the tower on this flying the same circuit and when I contact them it is always somewhere between almost NORDO to just generally poor communications. When I'm back on the ground everything is just fine again. Ideas, directions or suggestions? Jim Thorne RV-7A CHD About 12 Hours now. ________________________________________________________________________________
Date: Jun 03, 2010
And to repeat myself, dump the fractional drill bits and get some decent #40 (or #41 doesn't really matter) and #30 aircraft split point bits from Avery or Cleveland. Harry Crosby RV-6 N16CX, 692 hours ----- Original Message ----- From: "Chris Colohan" <rv10(at)colohan.com> Sent: Tuesday, June 1, 2010 2:27:06 PM GMT -08:00 US/Canada Pacific Subject: Re: RV-List: Fixing a bad hole... I have the Avery drill -- the issue here is not that I started the hole in the wrong place, but that once the hole started through one piece of aluminum the bit managed to expand the hole sideways into a giant oval instead of drilling through the next piece. It acted more like a router than a drill. :-( After the messages on this list and off -- I've ordered new HS-1013 doublers from Van's, and will use this with my spare spar to redo the whole thing the right way. Chris On Tue, Jun 1, 2010 at 1:16 PM, Kelly McMullen wrote: > > Also, you need a drill with a good teasing trigger that you can start very > slow, and only after the drill bit has started, run the speed up high. > Chicago Pneumatics makes a good one that Avery sells for around $125, and > there are the Sioux drills for about double that. > > > > On 6/1/2010 7:43 AM, John Bright wrote: > >> It's only one hole of tens... not a structural issue... you could do your >> best with an oops rivet and move on. Is it a cosmetic issue with the skin? >> You don't show the skin... is the skin bungled-up also? You could fill >> around it on the exterior skin cosmetically with pro-seal when you mix it >> for the tanks. >> >> I like the 135 degree split points. IMO cobalt or TiN or whatever does not >> matter to us with this aluminum. Split points have less tendency to walk >> than 118 degree non split points but they will still walk. All drills make >> triangular holes in thin sheet metal. >> >> I use an electric drill that spins maybe 2,400 rpm and I go thru skin and >> doubler in 1 or 2 seconds. I don't know what's going on with 20-30 seconds >> but something is wrong. >> Thanks, >> >> John Bright >> o:757-864-2305 >> c:757-812-1909 >> >> >> ------------------------------------------------------------------------ >> *From:* Chris Colohan >> *To:* rv-list(at)matronics.com >> >> *Sent:* Tue, June 1, 2010 12:51:12 AM >> *Subject:* RV-List: Fixing a bad hole... >> >> I've reached the horizontal stabilizer in building my RV-10. While >> drilling the 3/32" holes in the spar doublers for the forward spar, I mucked >> one of the holes up. >> >> In particular, the drill appears to have slid about 3/32" sideways while >> drilling, mis-placing the hole by 3/32". Perhaps better explained through >> pictures: >> >> >> http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink >> >> So I know how to fix a hole when you make it slightly too large -- you >> drill it out larger and put an "oops" rivet in it. But what can you do to >> fix a hole which is misplaced? Is there a good fix for this? Drilling a >> hole large enough to cover this error would take a rivet larger than 1/8"... >> >> (At worst, I can just replace the spar -- I have a spare, due to an >> earlier error that Van's made, and so I'd just need to order some new spar >> doublers. But I'd like to first learn if I can fix this one.) >> >> Also, while I have your ear -- I made this error while using a brand new >> Rigid Cobalt drill bit (like this one: >> http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The bit >> appears to be able to cut sideways just as well (or even better) than it can >> drill straight ahead in aluminum. It also takes about 20-30 seconds per >> hole drilling at 4000rpm (assuming my air drill is making its rated speed) >> while applying moderate pressure. Is this a known problem with this type of >> bit, or is my drilling technique off? I've ordered some "aviation" 3/32" >> bits from Avery, but wanted to know if I should expect it to be easier to >> drill straight with those bits. >> >> Thanks! >> >> Chris >> >> * >> >> >> * >> > > > > > ________________________________________________________________________________
Date: Jun 02, 2010
I took your advice and ordered new bits from Avery Sunday night when I ordered the replacement parts. Hopefully they arrive before next weekend... Thanks! Chris On Wed, Jun 2, 2010 at 9:29 PM, wrote: > And to repeat myself, dump the fractional drill bits and get some decent > #40 (or #41 doesn't really matter) and #30 aircraft split point bits from > Avery or Cleveland. > > > Harry Crosby > RV-6 N16CX, 692 hours > > ----- Original Message ----- > From: "Chris Colohan" <rv10(at)colohan.com> > To: rv-list(at)matronics.com > Sent: Tuesday, June 1, 2010 2:27:06 PM GMT -08:00 US/Canada Pacific > Subject: Re: RV-List: Fixing a bad hole... > > I have the Avery drill -- the issue here is not that I started the hole in > the wrong place, but that once the hole started through one piece of > aluminum the bit managed to expand the hole sideways into a giant oval > instead of drilling through the next piece. It acted more like a router > than a drill. :-( > > After the messages on this list and off -- I've ordered new HS-1013 > doublers > from Van's, and will use this with my spare spar to redo the whole thing > the > right way. > > Chris > > On Tue, Jun 1, 2010 at 1:16 PM, Kelly McMullen > wrote: > > > > > Also, you need a drill with a good teasing trigger that you can start > very > > slow, and only after the drill bit has started, run the speed up high. > > Chicago Pneumatics makes a good one that Avery sells for around $125, and > > there are the Sioux drills for about double that. > > > > > > > > On 6/1/2010 7:43 AM, John Bright wrote: > > > >> It's only one hole of tens... not a structural issue... you could do > your > >> best with an oops rivet and move on. Is it a cosmetic issue with the > skin? > >> You don't show the skin... is the skin bungled-up also? You could fill > >> around it on the exterior skin cosmetically with pro-seal when you mix > it > >> for the tanks. > >> > >> I like the 135 degree split points. IMO cobalt or TiN or whatever does > not > >> matter to us with this aluminum. Split points have less tendency to walk > >> than 118 degree non split points but they will still walk. All drills > make > >> triangular holes in thin sheet metal. > >> > >> I use an electric drill that spins maybe 2,400 rpm and I go thru skin > and > >> doubler in 1 or 2 seconds. I don't know what's going on with 20-30 > seconds > >> but something is wrong. > >> Thanks, > >> > >> John Bright > >> o:757-864-2305 > >> c:757-812-1909 > >> > >> > >> ------------------------------------------------------------------------ > >> *From:* Chris Colohan > >> *To:* rv-list(at)matronics.com > >> > >> *Sent:* Tue, June 1, 2010 12:51:12 AM > >> *Subject:* RV-List: Fixing a bad hole... > >> > >> I've reached the horizontal stabilizer in building my RV-10. While > >> drilling the 3/32" holes in the spar doublers for the forward spar, I > mucked > >> one of the holes up. > >> > >> In particular, the drill appears to have slid about 3/32" sideways while > >> drilling, mis-placing the hole by 3/32". Perhaps better explained > through > >> pictures: > >> > >> > >> > http://picasaweb.google.com/lh/photo/YZEMcGR7IQ7RKKSRLDgTIKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > >> > >> > http://picasaweb.google.com/lh/photo/eN0TsDBeAFqGoRwnEt8-s6Iqw9YRHPUJIjz5HHlTjwc?feat=directlink > >> > >> > http://picasaweb.google.com/lh/photo/e83Ltq54S8AOdpT-fXhSuKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > >> > >> > http://picasaweb.google.com/lh/photo/JklKOOxA-qYDu9BtPMZJeKIqw9YRHPUJIjz5HHlTjwc?feat=directlink > >> > >> So I know how to fix a hole when you make it slightly too large -- you > >> drill it out larger and put an "oops" rivet in it. But what can you do > to > >> fix a hole which is misplaced? Is there a good fix for this? Drilling > a > >> hole large enough to cover this error would take a rivet larger than > 1/8"... > >> > >> (At worst, I can just replace the spar -- I have a spare, due to an > >> earlier error that Van's made, and so I'd just need to order some new > spar > >> doublers. But I'd like to first learn if I can fix this one.) > >> > >> Also, while I have your ear -- I made this error while using a brand new > >> Rigid Cobalt drill bit (like this one: > >> http://www.ridgid.com/Tools/332-Cobalt-Drill-Bit/EN/index.htm). The > bit > >> appears to be able to cut sideways just as well (or even better) than it > can > >> drill straight ahead in aluminum. It also takes about 20-30 seconds per > >> hole drilling at 4000rpm (assuming my air drill is making its rated > speed) > >> while applying moderate pressure. Is this a known problem with this > type of > >> bit, or is my drilling technique off? I've ordered some "aviation" > 3/32" > >> bits from Avery, but wanted to know if I should expect it to be easier > to > >> drill straight with those bits. > >> > >> Thanks! > >> > >> Chris > >> > >> * > >> > >> > >> * > >> > > > > > > > > > > > > * > > > * > > ________________________________________________________________________________
Date: Jun 02, 2010
Subject: some approx V speeds
Anticpating the first flight of my RV-6A, can some one tell me typical Vx and Vy, best angle of glide speed, and Va for these planes. I can refine them after it is flying, but I'd like to have some idea of what to expect to start with. -- Tom Sargent ________________________________________________________________________________
Date: Jun 03, 2010
Subject: Re: some approx V speeds
Try out my POH for that and more. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) Ya'know this reminds me very little of the time I wired my tinfoil hat in series with the output of an early 1990's vintage Sovtek MIG-100 amplifier, detuned the B string of my bass a few sonts short of 60Hz Dinah Moe HUMM, slathered the strings with braunschweiger and turned the cats loose upon it. Taken altogether, synergistically and copacetically, the net effect was nothing short of...thrilling. In a message dated 6/2/2010 10:41:24 P.M. Pacific Daylight Time, sarg314(at)gmail.com writes: Anticpating the first flight of my RV-6A, can some one tell me typical Vx and Vy, best angle of glide speed, and Va for these planes. I can refine them after it is flying, but I'd like to have some idea of what to expect to start with. -- Tom Sargent (http://www.matronics.com/Navigator?RV-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Jun 03, 2010
Subject: Formation Invitation - San Jose RHV June 26, 2010
The Reid-Hillview Airport Association would like to invite the RV Formation community to San Jose Reid-Hillview Airport (RHV) for our June 26 Airport Day. There is no airshow or formal waivered airspace. But there will be room to fly and an appreciative audience. The tower understands the needs of formation and is very accommodating. If you can bring a group of RVs, Rockets, or mixed formation, great. We'd love to see you and fly with you. I'll be in the little blue Lancair. -bob mackey ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Jun 03, 2010
Thomas, which engine and prop do you have? Whether you have fixed pitch or constant speed prop makes a difference. ----- Original Message ----- From: thomas sargent To: rv-list Sent: Thursday, June 03, 2010 1:37 AM Subject: RV-List: some approx V speeds Anticpating the first flight of my RV-6A, can some one tell me typical Vx and Vy, best angle of glide speed, and Va for these planes. I can refine them after it is flying, but I'd like to have some idea of what to expect to start with. -- Tom Sargent ________________________________________________________________________________
Date: Jun 03, 2010
Jim, I have the Icom A200 radio, but the symptoms sound similar enough. I woul d suggest you turn down the Mic Gain in the radio. For my first flights, it was painful to key the mic as the noise in my ears was like a sledgehammer. The cockpit of the RV's is a really noisy place and that noise gets into the mic and gets amplified. On the Icom, there is a foil sticky on the top surface of the radio. Peel that back and there is a var iable resistor inside. Note where it is, then turn it down some. I think in my case it was origi nally about half way and I turned it down to about 1/4 and took a flight to check. After about three flights, you'll zero in on where you want it. I hope this is the cause of your problem be cause it is an easy fix. Rick Grenwis RV-6A 220 hours Denver, CO ________________________________ Message 3 _____________________________ ________ From: "Jim Thorne" <rv7a(at)cox.net> Subject: RV-List: Radio Noise Here is a tough one that maybe some of you guys can point me in the right direction to look. Set up is: RV-7A with an SL-30, Bob Archer antenna in left wingtip, with PTT on stick also FWIW I have a P-Mag and E-mag. Radio is excellent on ground in both transmit and receive, reception in air is OK however when I press the PTT the noise is horrible with static and breaking up. This has been a consistent condition. Attempts to correct the problem have been: checking antenna installation in wingtip, everything seems fine, Checking connectors where stick PTT plugs into the system, the PTT pin may not have been fully seated, it is now, trying different headsets. Nothing has solved the problem to date. I have been working with the tower on this flying the same circuit and when I contact them it is always somewhere between almost NORDO to just generally poor communications. When I'm back on the ground everything is just fine again. Ideas, directions or suggestions? Jim Thorne RV-7A CHD About 12 Hours now. ______ ________________________________________________________________________________
Date: Jun 03, 2010
Kyle: I have a fixed pitch Catto prop and an IO-360-B2B. On Thu, Jun 3, 2010 at 3:57 AM, Kyle Boatright wrote: > Thomas, which engine and prop do you have? Whether you have fixed pitch > or constant speed prop makes a difference. > -- Tom Sargent ________________________________________________________________________________
Date: Jun 03, 2010
Subject: Re: Stormy's Fly-In 2010
A little update... the river float is the yearly highlight of our fly-in, and we have just gotten ourselves some new tubes to replace the old truck inner tubes we've always used before. These are nice PVC inflatables with comfortable seating, headrest, mesh bottom, quick-inflate valves, drink holders, and rave reviews from other users. We tried 'em out Memorial Day and can confirm they are far nicer and more comfortable than black rubber tubes with slow leaks (as most of our old tubes quickly develop). While not essential (we still have quite a few of the old tubes on hand and can patch them), we are recommending that guests wanting to have the best tubing experience this year order tubes like we did from Amazon or another vendor. We paid 13.88 for the tubes with free shipping and I see they have already gone up a bit as river season arrived. Might want to order NOW ;-) http://www.amazon.com/Intex-58825-River-Run-I/dp/B000PEOMC8 -Bill B On Tue, Jun 1, 2010 at 10:41 AM, Bill Boyd wrote: > Hi, folks! It's June already - time for the 2010 river-float/BBQ fly-in at > the Boyds' place. > > Location: Hop-Along Airfield, identifier 12VA - 2100 x 50 ft turf strip > between Roanoke and Hot Springs, VA. > > Date: Saturday, June 26, 2010 > > Time: Arrivals welcome from 9 AM to Noon (or later, if need be). > > Schedule: BBQ lunch at 12:00 > River float at 14:00 (Takes 1.5 - 2 hours) > > Activities available: Billiards, horse shoes, frisbee, hot tub, camp fire, > chip & putt... > > (R.O.N. camping is available the night before and /or after the Fly-In. > Contact us ahead of time if you want to take advantage of this, please.) > > Updates and more details to follow... We're looking forward to having > y'all back this year! > > -Bill & Miriam Boyd > > ________________________________________________________________________________
Date: Jun 03, 2010
Tom, This was my kneepad checklist when flying my 6A. Hope it helps. Note all speeds in MPH. Robin *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *thomas sargent *Sent:* Thursday, June 03, 2010 6:44 AM *To:* rv-list(at)matronics.com *Subject:* Re: RV-List: some approx V speeds Kyle: I have a fixed pitch Catto prop and an IO-360-B2B. On Thu, Jun 3, 2010 at 3:57 AM, Kyle Boatright wrote: Thomas, which engine and prop do you have? Whether you have fixed pitch or constant speed prop makes a difference. -- Tom Sargent * * * * * * ________________________________________________________________________________
Subject: Airspeeds
Date: Jun 04, 2010
While I think we can prove that an airplane will perform best at some specific speed like 91.23098 kts I would defy anyone to be able to keep it at that airspeed, particularly on a gusty day with thermals and in an emergency, while you are actually supposed to be looking out versus pegging your eyes to interior gauges. Reduce your mental workload by keeping it simple. 90kts for everything in the ATA or an emergency, 70kts for anything with flaps out. On this latter one if you are not comfortable with the airplane kick that up to 75 or 80 kts, but know that this will cause you to float a bit as you rotate to touch down. Practice slow flight ASAP and often, we should all do this... the advice is straight from the mouth of Dick VanGrunsven. Then use 70 kts for all flaps down operations. The 90kts value also gives you more time to process things, see other aircraft, make sounder decisions etc. as opposed to screaming into downwind at warp factor 12 only to piss off some poor C150 as you climb up their static port... ________________________________________________________________________________
Subject: Re: Airspeeds
Date: Jun 04, 2010
Wheeler, this one will likely stir up a blizzard of responses. Piloting techniques do vary quite a bit. I look forward to reading a lot of information and misinformation. As for me, I want to go on record as agreeing with you 100%. D. Walsh On Jun 4, 2010, at 8:49 , Wheeler North wrote: > > While I think we can prove that an airplane will perform best at some > specific speed like 91.23098 kts I would defy anyone to be able to > keep it > at that airspeed, particularly on a gusty day with thermals and in an > emergency, while you are actually supposed to be looking out versus > pegging > your eyes to interior gauges. > Reduce your mental workload by keeping it simple. 90kts for > everything in > the ATA or an emergency, 70kts for anything with flaps out. On this > latter > one if you are not comfortable with the airplane kick that up to 75 > or 80 > kts, but know that this will cause you to float a bit as you rotate > to touch > down. > Practice slow flight ASAP and often, we should all do this... the > advice is > straight from the mouth of Dick VanGrunsven. Then use 70 kts for all > flaps > down operations. > The 90kts value also gives you more time to process things, see other > aircraft, make sounder decisions etc. as opposed to screaming into > downwind > at warp factor 12 only to piss off some poor C150 as you climb up > their > static port... > > ________________________________________________________________________________
Date: Jun 04, 2010
Please explain: Whether you have fixed pitch or constant speed prop makes a difference. Harry Crosby RV-6 N16CX, 693 hours ________________________________________________________________________________
Date: Jun 04, 2010
Yes. I have a fixed pitch prop and a 180hp IO-360-B2B On Fri, Jun 4, 2010 at 1:08 PM, wrote: > Please explain: > > > Whether you have fixed pitch or constant speed prop makes a difference. > > Harry Crosby > RV-6 N16CX, 693 hours > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 04, 2010
Harry, When I first did my airspeed checks with my fixed pitch prop RV-6A, I couldn't get anywhere near the performance/airspeed figures that Van quoted. It turns out his figures are for engines with a constant speed prop. My best climb speed Vy turns out to be 120 MPH IAS, considerably higher than the Van's figure. I'm sure there is someone out there that can give you a more understandable explanation - but it goes something like this. Here is how I see it - with a constant speed prop, you can get more HP at slow airspeeds by making the pitch finer producing less load on the engine, which results in more RPM which results in more HP. When you are discussing climb it's the EXTRA HP above that required to maintain level flight than causes you to climb. If you can increase your HP above that necessary for level flight, you can increase your climb rate at any airspeed (well, just about).. With a fixed pitch prop, you have the maximum load on the prop and therefore the engine at slower airspeeds during climb-out, that keeps the rpm lower and therefore HP down compared to a constant speed prop. Therefore, in order to get more climb you need to produce more HP, with a fixed pitch prop you do that by flying a higher airspeed unloading the prop and engine a bit thereby permitting more rpm and HP and higher climb rate. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Friday, June 04, 2010 4:09 PM Subject: Re: RV-List: some approx V speeds Please explain: Whether you have fixed pitch or constant speed prop makes a difference. Harry Crosby RV-6 N16CX, 693 hours ________________________________________________________________________________
Date: Jun 04, 2010
I was messing around a few months ago, making some charts to illustrate a magazine article on climb performance that I intend to finish someday. I used the combination of CAFE Foundation drag vs speed data for the RV-6A, Lycoming O-360 power charts and some Hartzell prop efficiency maps. I used that data to predict climb performance at various altitudes and speeds. I didn't have any fixed pitch prop efficiency data, so I used the Hartzell data, but forced it to use the same pitch for all conditions. The pitch was selected to give 2700 rpm at full throttle at 8000 ft. The attached chart shows how Vx and Vy are predicted to vary with altitude for both fixed pitch and constant speed props. You will note that Vx and Vy are quite a bit faster with fixed pitch props, as the rpm and power increase as the airspeed is increased. You will also note that there is a significant variation of Vx and Vy with altitude. I caution that this is a very crude prediction. It may not match the actual performance at all, so use at your own risk. It is interesting to note that the predicted fixed pitch Vy at sea level (105 kt, or 121 mph) is close to what Ed found. That may be blind luck. Kevin Horton Ottawa, Canada On 04/06/10 07:41 PM, Ed Anderson wrote: > > Harry, > > When I first did my airspeed checks with my fixed pitch prop RV-6A, I > couldn't get anywhere near the performance/airspeed figures that Van > quoted. It turns out his figures are for engines with a constant > speed prop. > > My best climb speed Vy turns out to be 120 MPH IAS, considerably > higher than the Van's figure. > > I'm sure there is someone out there that can give you a more > understandable explanation -- but it goes something like this. > > Here is how I see it -- with a constant speed prop, you can get more > HP at slow airspeeds by making the pitch finer producing less load on > the engine, which results in more RPM which results in more HP. When > you are discussing climb it's the EXTRA HP above that required to > maintain level flight than causes you to climb. If you can increase > your HP above that necessary for level flight, you can increase your > climb rate at any airspeed (well, just about).. > > With a fixed pitch prop, you have the maximum load on the prop and > therefore the engine at slower airspeeds during climb-out, that keeps > the rpm lower and therefore HP down compared to a constant speed > prop. Therefore, in order to get more climb you need to produce more > HP, with a fixed pitch prop you do that by flying a higher airspeed > unloading the prop and engine a bit thereby permitting more rpm and HP > and higher climb rate. > > Ed > > Ed Anderson > > Rv-6A N494BW Rotary Powered > > Matthews, NC > > eanderson(at)carolina.rr.com > > http://www.andersonee.com > > http://www.dmack.net/mazda/index.html > > http://www.flyrotary.com/ > > http://members.cox.net/rogersda/rotary/configs.htm#N494BW > <http://members.cox.net/rogersda/rotary/configs.htm> > > http://www.rotaryaviation.com/Rotorhead%20Truth.htm > > ------------------------------------------------------------------------ > > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of > *HCRV6(at)comcast.net > *Sent:* Friday, June 04, 2010 4:09 PM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: some approx V speeds > > Please explain: > > Whether you have fixed pitch or constant speed prop makes a difference. > > Harry Crosby > RV-6 N16CX, 693 hours > > ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Fwd: List Introduction & Main spar falls off workbench
From: James S Clark IV <james.s.clark(at)comcast.net>
Hello RV'ers, I've been lurking, reading, and building an RV7A slow build since 2007. I thought I'd introduce myself to the list prior to my first request for help! Well it took till getting the fuselage kit for the first major problem to strike: a comedy of errors, on which I would truly appreciate some advice: Assembling the main spar center section, I had just constructed and temp bolted the wood spacer blocks between the fore and aft main spars to check for fit. Things looked good and I left the center spar on the workbench for the night. Unfortunately, I left it on a piece of foam which gradually compressed and the spar fell off the table 3 feet to the concrete and linoleum floor! The first floor strike appeared to bend a corner of the spar web down 90 degrees on a 45 degree bias. This is on the forward left lower side of the front spar web (where the 7A gear leg will go through later) I just knew it was stressed and would crack bending it back and it did when bent about half way back. I stop drilled the crack #30 and bent it the rest of the way back flat. I then sanded and scotchbrited a smooth slot. My question is (and I will ask Vans): This is a small crack, but it is in a BAD place (1 inch to main spar bolts). Is my fix OK? Is there a better solution? This piece is matched to my left and right main wing spars and wings are 90% done. Is it impossible to get a new center section front spar? Looking at the drawings, I note: Both the forward bottom skin and the aft bottom skin overlap this lower spar web flange at the front spar (lots of skin thickness here). Are there no stresses on the corner of this web at this location? The landing gear leg on the 7A will require scalloping a bit of this flange away anyway, but that scallop area (approximated by red pen in picture) is closer to the second rivet hole than the first. I got excited when I saw this as I thought I might cut my error away anyway, but it looks like the scallop will miss the damaged area. Well so much for you all thinking highly of me on my first intro. I've been pretty careful so far and not many mistakes or drilled fingers, but boy is this a bummer. Could it have happened on a worse piece? Thoughts, comments, fixes, and good natured laughter are appreciated. Best regards, Jim Clark (Gainesville, VA) BTW, for some additional comedy: the bucking bar followed the spar off the table (in the same event) an put a nice dent in the center of the web to add insult to injury. This is not a show stopper though. ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Re: Fwd: List Introduction & Main spar falls off workbench
Just my quick observation is that this appears to be in an area that is under virtually no stress. My 6A has the old laminated 11g spar, so I can't be certain about your situation with the new wing spar. I would take the whole broken area off and smooth the edge transition so that no crack could propagate from the edge. What attaches to the small holes on the flange? -GV In a message dated 6/5/2010 2:03:06 P.M. Pacific Daylight Time, james.s.clark(at)comcast.net writes: Hello RV'ers, I've been lurking, reading, and building an RV7A slow build since 2007. I thought I'd introduce myself to the list prior to my first request for help! Well it took till getting the fuselage kit for the first major problem to strike: a comedy of errors, on which I would truly appreciate some advice: Assembling the main spar center section, I had just constructed and temp bolted the wood spacer blocks between the fore and aft main spars to check for fit. Things looked good and I left the center spar on the workbench for the night. Unfortunately, I left it on a piece of foam which gradually compressed and the spar fell off the table 3 feet to the concrete and linoleum floor! The first floor strike appeared to bend a corner of the spar web down 90 degrees on a 45 degree bias. This is on the forward left lower side of the front spar web (where the 7A gear leg will go through later) I just knew it was stressed and would crack bending it back and it did when bent about half way back. I stop drilled the crack #30 and bent it the rest of the way back flat. I then sanded and scotchbrited a smooth slot. My question is (and I will ask Vans): This is a small crack, but it is in a BAD place (1 inch to main spar bolts). Is my fix OK? Is there a better solution? This piece is matched to my left and right main wing spars and wings are 90% done. Is it impossible to get a new center section front spar? Looking at the drawings, I note: Both the forward bottom skin and the aft bottom skin overlap this lower spar web flange at the front spar (lots of skin thickness here). Are there no stresses on the corner of this web at this location? The landing gear leg on the 7A will require scalloping a bit of this flange away anyway, but that scallop area (approximated by red pen in picture) is closer to the second rivet hole than the first. I got excited when I saw this as I thought I might cut my error away anyway, but it looks like the scallop will miss the damaged area. Well so much for you all thinking highly of me on my first intro. I've been pretty careful so far and not many mistakes or drilled fingers, but boy is this a bummer. Could it have happened on a worse piece? Thoughts, comments, fixes, and good natured laughter are appreciated. Best regards, Jim Clark (Gainesville, VA) BTW, for some additional comedy: the bucking bar followed the spar off the table (in the same event) an put a nice dent in the center of the web to add insult to injury. This is not a show stopper though. ________________________________________________________________________________
Date: Jun 05, 2010
These holes on the flange are on the bottom and rivet to the forward lower skin and the rear lower skin. The two skins overlap both the front spar (problem area) and the rear spar. I agree after studying the plans a bunch that this last rivet hole is not likely to be under much if any stress. Do others familiar with the 7A spar agree? If I remove the 1st rivet hole, or the first and 2nd rivet holes on the flange, should I replace this with a similar thickness backer strip of aluminum when riveting the skin overlap in this area? Other opinions? Thanks, Jim On Sat, Jun 5, 2010 at 7:33 PM, wrote: > Just my quick observation is that this appears to be in an area that is > under virtually no stress. My 6A has the old laminated 11g spar, so I can't > be certain about your situationwith the new wing spar. I would take the > whole broken area off and smooth the edge transitionso that no crack could > propagate from the edge. What attaches to the small holes on the flange? > > -GV > > In a message dated 6/5/2010 2:03:06 P.M. Pacific Daylight Time, > james.s.clark(at)comcast.net writes: > > Hello RV'ers, > > I've been lurking, reading, and building an RV7A slow build since > 2007. I thought I'd introduce myself to the list prior to my first > request for help! > > Well it took till getting the fuselage kit for the first major problem > to strike: a comedy of errors, on which I would truly appreciate some > advice: > > Assembling the main spar center section, I had just constructed and > temp bolted the wood spacer blocks between the fore and aft main spars > to check for fit. > Things looked good and I left the center spar on the workbench for the > night. Unfortunately, I left it on a piece of foam which gradually > compressed and the spar fell off the table 3 feet to the concrete and > linoleum floor! > > The first floor strike appeared to bend a corner of the spar web down > 90 degrees on a 45 degree bias. This is on the forward left lower side > of the front spar web (where the 7A gear leg will go through later) > I just knew it was stressed and would crack bending it back and it did > when bent about half way back. I stop drilled the crack #30 and bent > it the rest of the way back flat. I then sanded and scotchbrited a > smooth slot. > > My question is (and I will ask Vans): > This is a small crack, but it is in a BAD place (1 inch to main spar bolts). > Is my fix OK? Is there a better solution? This piece is matched to my > left and right main wing spars and wings are 90% done. Is it > impossible to get a new center section front spar? > > Looking at the drawings, I note: > Both the forward bottom skin and the aft bottom skin overlap this > lower spar web flange at the front spar (lots of skin thickness here). > Are there no stresses on the corner of this web at this location? > The landing gear leg on the 7A will require scalloping a bit of this > flange away anyway, but that scallop area (approximated by red pen in > picture) is closer to the second rivet hole than the first. I got > excited when I saw this as I thought I might cut my error away anyway, > but it looks like the scallop will miss the damaged area. > > Well so much for you all thinking highly of me on my first intro. I've > been pretty careful so far and not many mistakes or drilled fingers, > but boy is this a bummer. Could it have happened on a worse piece? > > Thoughts, comments, fixes, and good natured laughter are appreciated. > > Best regards, > Jim Clark (Gainesville, VA) > > BTW, for some additional comedy: the bucking bar followed the spar off > the table (in the same event) an put a nice dent in the center of the > web to add insult to injury. This is not a show stopper though. > > ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Sweet Pics From Cross Country To Lake Tahoe Today...
Dear Listers, The second major cross country post-Phase 1 this weekend took us to South Lake Tahoe in our continuing "Quest For A $100 Hamburger"... The weather was unbelievable today. Simply amazing! We ran into Marc Ausman of Vertical Power fame http://www.verticalpower.com as we were fueling up for our trip home. Marc has another sweet Lycoming IO-390 powered RV. After lunch, we took a flight over Reno at about 11000ft. Who knew this RV-8 was going to be such a fun vehicle of journey! :-) Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor... ________________________________________________________________________________
Date: Jun 06, 2010
Subject: Re: Sweet Pics From Cross Country To Lake Tahoe Today...
Glad you're not letting any moss grow on it. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) "I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?" In a message dated 6/5/2010 9:31:53 P.M. Pacific Daylight Time, dralle(at)matronics.com writes: The second major cross country post-Phase 1 this weekend took us to South Lake Tahoe in our continuing "Quest For A $100 Hamburger". ________________________________________________________________________________
Subject: Piece of Grass 2010 refunds
Date: Jun 06, 2010
You've probably heard by now that the spot on which we have had the RV get-together at Oshkosh ("Piece of Grass") for (most of) the last 6 years is not likely to be available to us because EAA is moving the 24-hour generator area out to the middle of the field at Camp Scholler (I don't really want to camp in a truck stop), which is where people have always been able to find us (because we told them exactly where we'll be). But EAA has still not made maps available for the new Camp Scholler design and because it's unclear what the net effect of displacing tenters (like me) from that area, I'm in no position to say where my camp area will end up at. A couple of alternative locations have fallen apart (it would appear the Van's dinner is the most likely spot for those who wish to socialize). A lot of people donated a lot of money to secure 6 camping sites for the event, and we won't be needing them, so a week or so ago -- because of the uncertainty -- I returned it via PayPayl (for those of you who submitted it via PayPal). For those of you who sent checks, I've simply shredded the checks and you should "void" them in your register. If you HAVEN'T received a refund, please contact me ASAP. Thanks. ________________________________________________________________________________
Subject: Re: Piece of Grass 2010 refunds
Date: Jun 06, 2010
MessageAh, thats what's meant by the term "EAA in Action"! Ivan Haecker ----- Original Message ----- From: Bob Collins To: rv-list(at)matronics.com Sent: Sunday, June 06, 2010 9:24 AM Subject: RV-List: Piece of Grass 2010 refunds You've probably heard by now that the spot on which we have had the RV get-together at Oshkosh ("Piece of Grass") for (most of) the last 6 years is not likely to be available to us because EAA is moving the 24-hour generator area out to the middle of the field at Camp Scholler (I don't really want to camp in a truck stop), which is where people have always been able to find us (because we told them exactly where we'll be). But EAA has still not made maps available for the new Camp Scholler design and because it's unclear what the net effect of displacing tenters (like me) from that area, I'm in no position to say where my camp area will end up at. A couple of alternative locations have fallen apart (it would appear the Van's dinner is the most likely spot for those who wish to socialize). A lot of people donated a lot of money to secure 6 camping sites for the event, and we won't be needing them, so a week or so ago -- because of the uncertainty -- I returned it via PayPayl (for those of you who submitted it via PayPal). For those of you who sent checks, I've simply shredded the checks and you should "void" them in your register. If you HAVEN'T received a refund, please contact me ASAP. Thanks. ________________________________________________________________________________
Date: Jun 06, 2010
Subject: Chainsaw Propeller Carving
There is a propeller carving demo given at Oshkosh every year that shows how to carve a wooden propeller using all power tools (chainsaws and power sanders). Here are some pictures of the process, on my blog, if anyone is interested. http://nickhelsper.blogspot.com/p/propeller-carving-all-power-tool-method.html ~Nick Helsper ________________________________________________________________________________
Date: Jun 06, 2010
Ed, Thanks for that. Without giving it much thought (make that any thought) my reaction was, what does it matter what kind of prop? Obviously it does as s oon as one recognizes the effect of airspeed/RPM on HP with the fixed pitch props. My experience is consistent with your observation, at 120 MPH my Catto prop allows me to climb with any of my buddies with CS props. They always get a bit of a jump on me at takeoff but as soon as I accelerate to 120 to 130 I can catch up. Harry Crosby RV-6 N16CX, 695 hours ----- Original Message ----- From: "Ed Anderson" <eanderson(at)carolina.rr.com> Sent: Friday, June 4, 2010 4:41:21 PM GMT -08:00 US/Canada Pacific Subject: RE: RV-List: some approx V speeds Harry, When I first did my airspeed checks with my fixed pitch prop RV-6A, I could n=99t get anywhere near the performance/airspeed figures that Van quo ted. It turns out his figures are for engines with a constant speed prop. My best climb speed Vy turns out to be 120 MPH IAS, considerably higher tha n the Van=99s figure. I=99m sure there is someone out there that can give you a more unders tandable explanation =93 but it goes something like this. Here is how I see it =93 with a constant speed prop, you can get more HP at slow airspeeds by making the pitch finer producing less load on the engine, which results in more RPM which results in more HP. When you are di scussing climb it=99s the EXTRA HP above that required to maintain le vel flight than causes you to climb. If you can increase your HP above that necessary for level flight, you can increase your climb rate at any airspe ed (well, just about).. With a fixed pitch prop, you have the maximum load on the prop and therefor e the engine at slower airspeeds during climb-out, that keeps the rpm lower and therefore HP down compared to a constant speed prop. Therefore, in ord er to get more climb you need to produce more HP, with a fixed pitch prop y ou do that by flying a higher airspeed unloading the prop and engine a bit thereby permitting more rpm and HP and higher climb rate. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of HCRV6(at)comcast.net Sent: Friday, June 04, 2010 4:09 PM Subject: Re: RV-List: some approx V speeds Please explain: Whether you have fixed pitch or constant speed prop makes a difference. Harry Crosby RV-6 N16CX, 693 hours http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http ===================== == ________________________________________________________________________________
Date: Jun 06, 2010
Obviously, Van should have the final word. But I'll bet they tell you to clean up the edges of the crack & build on. It's hard to imagine that one rivet doing a lot to keep the plane in the air. Take a look at edge distances & see if you can add a rivet outboard (toward the corner), & one between the original outboard pair. Adding a doubler there looks like it would be difficult, with the gear weldment in that space. Charlie ________________________________ From: James S Clark IV <james.s.clark(at)comcast.net> Sent: Sat, June 5, 2010 3:56:56 PM Subject: RV-List: Fwd: List Introduction & Main spar falls off workbench Hello RV'ers, I've been lurking, reading, and building an RV7A slow build since 2007. I thought I'd introduce myself to the list prior to my first request for help! Well it took till getting the fuselage kit for the first major problem to strike: a comedy of errors, on which I would truly appreciate some advice: Assembling the main spar center section, I had just constructed and temp bolted the wood spacer blocks between the fore and aft main spars to check for fit. Things looked good and I left the center spar on the workbench for the night. Unfortunately, I left it on a piece of foam which gradually compressed and the spar fell off the table 3 feet to the concrete and linoleum floor! The first floor strike appeared to bend a corner of the spar web down 90 degrees on a 45 degree bias. This is on the forward left lower side of the front spar web (where the 7A gear leg will go through later) I just knew it was stressed and would crack bending it back and it did when bent about half way back. I stop drilled the crack #30 and bent it the rest of the way back flat. I then sanded and scotchbrited a smooth slot. My question is (and I will ask Vans): This is a small crack, but it is in a BAD place (1 inch to main spar bolts). Is my fix OK? Is there a better solution? This piece is matched to my left and right main wing spars and wings are 90% done. Is it impossible to get a new center section front spar? Looking at the drawings, I note: Both the forward bottom skin and the aft bottom skin overlap this lower spar web flange at the front spar (lots of skin thickness here). Are there no stresses on the corner of this web at this location? The landing gear leg on the 7A will require scalloping a bit of this flange away anyway, but that scallop area (approximated by red pen in picture) is closer to the second rivet hole than the first. I got excited when I saw this as I thought I might cut my error away anyway, but it looks like the scallop will miss the damaged area. Well so much for you all thinking highly of me on my first intro. I've been pretty careful so far and not many mistakes or drilled fingers, but boy is this a bummer. Could it have happened on a worse piece? Thoughts, comments, fixes, and good natured laughter are appreciated. Best regards, Jim Clark (Gainesville, VA) BTW, for some additional comedy: the bucking bar followed the spar off the table (in the same event) an put a nice dent in the center of the web to add insult to injury. This is not a show stopper though. ________________________________________________________________________________
Date: Jun 06, 2010
Welcome, Harry. Yeah, I really thought I had a dog at first, because I couldn't match Van's performance numbers - just the wrong comparison in my case {:>). There are certainly benefits to having a C/S on take off - however, for cost and simplicity reasons, I have not regretted staying fixed pitch. I swing a 74x 88 Performance Wood Prop which takes all the right rudder I have in my 6A to keep it on our 35' wide runway, in fact until I hit around 40 mph, there is not sufficient rudder authority. Take off performance is great, but I still need to hit 120 MPH to get best rate of climb. Now if I had to fly up a mountain side after take off - I might sing a different tune {:>) ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Sunday, June 06, 2010 4:24 PM Subject: Re: RV-List: some approx V speeds Ed, Thanks for that. Without giving it much thought (make that any thought) my reaction was, what does it matter what kind of prop? Obviously it does as soon as one recognizes the effect of airspeed/RPM on HP with the fixed pitch props. My experience is consistent with your observation, at 120 MPH my Catto prop allows me to climb with any of my buddies with CS props. They always get a bit of a jump on me at takeoff but as soon as I accelerate to 120 to 130 I can catch up. Harry Crosby RV-6 N16CX, 695 hours ----- Original Message ----- From: "Ed Anderson" <eanderson(at)carolina.rr.com> Sent: Friday, June 4, 2010 4:41:21 PM GMT -08:00 US/Canada Pacific Subject: RE: RV-List: some approx V speeds Harry, When I first did my airspeed checks with my fixed pitch prop RV-6A, I couldn't get anywhere near the performance/airspeed figures that Van quoted. It turns out his figures are for engines with a constant speed prop. My best climb speed Vy turns out to be 120 MPH IAS, considerably higher than the Van's figure. I'm sure there is someone out there that can give you a more understandable explanation - but it goes something like this. Here is how I see it - with a constant speed prop, you can get more HP at slow airspeeds by making the pitch finer producing less load on the engine, which results in more RPM which results in more HP. When you are discussing climb it's the EXTRA HP above that required to maintain level flight than causes you to climb. If you can increase your HP above that necessary for level flight, you can increase your climb rate at any airspeed (well, just about).. With a fixed pitch prop, you have the maximum load on the prop and therefore the engine at slower airspeeds during climb-out, that keeps the rpm lower and therefore HP down compared to a constant speed prop. Therefore, in order to get more climb you need to produce more HP, with a fixed pitch prop you do that by flying a higher airspeed unloading the prop and engine a bit thereby permitting more rpm and HP and higher climb rate. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com <http://www.andersonee.com> http://www.andersonee.com <http://www.dmack.net/mazda/index.html> http://www.dmack.net/mazda/index.html http://www.flyrotary.com/ <http://members.cox.net/rogersda/rotary/configs.htm> http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.rotaryaviation.com/Rotorhead%20Truth.htm <http://www.dmack.net/mazda/index.html> _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Friday, June 04, 2010 4:09 PM Subject: Re: RV-List: some approx V speeds Please explain: Whether you have fixed pitch or constant speed prop makes a difference. Harry Crosby RV-6 N16CX, 693 hours http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: KCDC
Date: Jun 06, 2010
Hey RVers, anyone in the vicinity of Cedar City UT? Have an RV-6 stranded there with electrical/battery issues. pls call 503-703 1724 thanks! ________________________________________________________________________________
Date: Jun 06, 2010
Subject: engine serial number?
I am filling out the forms to request an airworthiness inspection. Form 8130-12 asks for the engine model and serial number. Mine is an Aerosport Power rebuild. The Aerosport power data plate on the engine shows the serial number as 0240, which in retrospect (after I got back home) seems way too small to be a Lycoming serial number. Is that what they are asking for? Who is deemed to be the engine maker, Lycoming or Aerosport? I'm not aware of a Lycoming serial number anywhere on the engine, though I easily could have missed it. I didn't think to check the engine log book which is at the hangar. -- Tom Sargent, RV-6A, doing the paper work. ________________________________________________________________________________
Date: Jun 07, 2010
The engine Data plate can only be installed by the engine manufacturer. If the data plate says Aerosport=2C it is not a Lycoming. It is an Aerospor t Experimental Engine. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C377+ Flying Hours So. CA=2C USA Date: Sun=2C 6 Jun 2010 21:28:14 -0700 Subject: RV-List: engine serial number? From: sarg314(at)gmail.com I am filling out the forms to request an airworthiness inspection. Form 81 30-12 asks for the engine model and serial number. Mine is an Aerosport Po wer rebuild. The Aerosport power data plate on the engine shows the serial number as 0240=2C which in retrospect (after I got back home) seems way to o small to be a Lycoming serial number. Is that what they are asking for? Who is deemed to be the engine maker=2C Lycoming or Aerosport? I'm not aware of a Lycoming serial number anywhere on the engine=2C though I easily could have missed it. I didn't think to c heck the engine log book which is at the hangar. -- Tom Sargent=2C RV-6A=2C doing the paper work. _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H otmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid= PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Subject: Re: engine serial number?
Date: Jun 07, 2010
My O-360 was rebuilt by Aerosport Power in 1998 and has the original Lycoming data plate with serial number. When I had my airworthiness inspection done by the FAA in 2004, the guy refuse to recognize it as a Lycoming because he said "Aerosport Power builds engines for Experimental aircraft". He required 40 hours Phase I instead of 25 hours I anticipated. (I also had a matched Hartzell CS prop purchased new from Van's) Dale Ensing ----- Original Message ----- From: RV6 Flyer To: RV List Sent: Monday, June 07, 2010 7:22 AM Subject: RE: RV-List: engine serial number? The engine Data plate can only be installed by the engine manufacturer. If the data plate says Aerosport, it is not a Lycoming. It is an Aerosport Experimental Engine. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,377+ Flying Hours So. CA, USA ------------------------------------------------------------------------- ----- Date: Sun, 6 Jun 2010 21:28:14 -0700 Subject: RV-List: engine serial number? From: sarg314(at)gmail.com To: rv-list(at)matronics.com I am filling out the forms to request an airworthiness inspection. Form 8130-12 asks for the engine model and serial number.. Mine is an Aerosport Power rebuild. The Aerosport power data plate on the engine shows the serial number as 0240, which in retrospect (after I got back home) seems way too small to be a Lycoming serial number. Is that what they are asking for? Who is deemed to be the engine maker, Lycoming or Aerosport? I'm not aware of a Lycoming serial number anywhere on the engine, though I easily could have missed it. I didn't think to check the engine log book which is at the hangar. -- Tom Sargent, RV-6A, doing the paper work. http://www.matronics.com/Navigator?R========= ------------------------------------------------------------------------- ----- The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. ________________________________________________________________________________
Date: Jun 07, 2010
If it was built from a kit, the OEM does not assign it a serial number. Aerosport probably assigned it their own serial number. Give Sue a call. She'll tell you what you need to know. ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent Sent: Sunday, June 06, 2010 11:28 PM Subject: RV-List: engine serial number? I am filling out the forms to request an airworthiness inspection. Form 8130-12 asks for the engine model and serial number. Mine is an Aerosport Power rebuild. The Aerosport power data plate on the engine shows the serial number as 0240, which in retrospect (after I got back home) seems way too small to be a Lycoming serial number. Is that what they are asking for? Who is deemed to be the engine maker, Lycoming or Aerosport? I'm not aware of a Lycoming serial number anywhere on the engine, though I easily could have missed it. I didn't think to check the engine log book which is at the hangar. -- Tom Sargent, RV-6A, doing the paper work. ________________________________________________________________________________
Subject: RV-9 Empennage for sale
Date: Jun 07, 2010
EAA Chapter 35 has been donated a completed RV-9 empennage by a member who lost his medical. The chapter would like to sell the assembly but has been unable to find interested buyers through local advertising, thus this notice. The empennage is complete and includes horizontal and vertical tail, rudder, elevators, and electric trim. The workmanship is excellent according to Paul McReynolds, an RV guru and former Oshkosh Grand Champion winner. Van's price for an unassembled RV-9 empennage kit is $1660 plus shipping. Chapter 35 would like $700 for the completed assembly. The assembly is located at San Geronimo airport (8T8) near San Antonio, Texas. Point of contact is: Dave Baker, Chapter 35 president, at (210) 410-9235. Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Date: Jun 07, 2010
I'll take it. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Brame Sent: Monday, June 07, 2010 9:01 AM Subject: RV-List: RV-9 Empennage for sale EAA Chapter 35 has been donated a completed RV-9 empennage by a member who lost his medical. The chapter would like to sell the assembly but has been unable to find interested buyers through local advertising, thus this notice. The empennage is complete and includes horizontal and vertical tail, rudder, elevators, and electric trim. The workmanship is excellent according to Paul McReynolds, an RV guru and former Oshkosh Grand Champion winner. Van's price for an unassembled RV-9 empennage kit is $1660 plus shipping. Chapter 35 would like $700 for the completed assembly. The assembly is located at San Geronimo airport (8T8) near San Antonio, Texas. Point of contact is: Dave Baker, Chapter 35 president, at (210) 410-9235. Charlie Brame RV-6A N11CB San Antonio Checked by AVG - www.avg.com 23:35:00 ________________________________________________________________________________
Date: Jun 07, 2010
Subject: Pecan Plantation near Granbury Texas
Does anybody know anything about a fly-in at the Pecan Plantation near Gran bury Texas? I had heard there was a fly-in next weekend, but cannot seem t o confirm this anywhere. Also, I was up there this last weekend and wanted to look around but could not get past the security gate. I wondered if we had anybody on the list who lives there. Thanks Tim RV-6 N616TB Flying ________________________________________________________________________________
Date: Jun 07, 2010
From: Carlos Hernandez <carlosh(at)structuralaz.com>
Subject: Re: Pecan Plantation near Granbury Texas
here ya go. http://www.vansairforce.net/delete_eventually/pecan2010.jpg Carlos N616TB wrote: > *Does anybody know anything about a fly-in at the Pecan Plantation > near Granbury Texas? I had heard there was a fly-in next weekend, but > cannot seem to confirm this anywhere. Also, I was up there this last > weekend and wanted to look around but could not get past the security > gate. I wondered if we had anybody on the list who lives there.* > *Thanks* > *Tim* > *RV-6* > *N616TB* > *Flying* > * > > > * -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Jun 07, 2010
See http://www.vansairforce.com/community/calendar.php?do=getinfo&day 10-6-12&e=585&c=1 On Mon, Jun 7, 2010 at 3:48 PM, N616TB wrote: > *Does anybody know anything about a fly-in at the Pecan Plantation near > Granbury Texas? I had heard there was a fly-in next weekend, but cannot > seem to confirm this anywhere. Also, I was up there this last weekend and > wanted to look around but could not get past the security gate. I wondered > if we had anybody on the list who lives there.* > *Thanks* > *Tim* > *RV-6* > *N616TB* > *Flying* > > * > > * > > -- Marty Santic ----- W9EAA My RV-12 (Light Sport Aircraft) Build Log - http://www.martysrv12.blogspot.com/ ________________________________________________________________________________
Date: Jun 07, 2010
Great pics Matt! Only time we ever went to Tahoe we were fighting 60mph headwinds on the way back west and rough as heck at 12.5 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Saturday, June 05, 2010 9:11 PM Subject: RV-List: Sweet Pics From Cross Country To Lake Tahoe Today... Dear Listers, The second major cross country post-Phase 1 this weekend took us to South Lake Tahoe in our continuing "Quest For A $100 Hamburger"... The weather was unbelievable today. Simply amazing! We ran into Marc Ausman of Vertical Power fame http://www.verticalpower.com as we were fueling up for our trip home. Marc has another sweet Lycoming IO-390 powered RV. After lunch, we took a flight over Reno at about 11000ft. Who knew this RV-8 was going to be such a fun vehicle of journey! :-) Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor... ________________________________________________________________________________
Date: Jun 07, 2010
I don't live in Pecan Plantation but I'm a member of that local EAA chapter. It will be a wonderful fly-in and I understand that Van's Air Force will attend. Should be well worth the trip by land or air. --Pete Capani From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N616TB Sent: Monday, June 07, 2010 3:49 PM Subject: RV-List: Pecan Plantation near Granbury Texas Does anybody know anything about a fly-in at the Pecan Plantation near Granbury Texas? I had heard there was a fly-in next weekend, but cannot seem to confirm this anywhere. Also, I was up there this last weekend and wanted to look around but could not get past the security gate. I wondered if we had anybody on the list who lives there. Thanks Tim RV-6 N616TB Flying ________________________________________________________________________________
Date: Jun 07, 2010
Thanks! At one point we were seeing 40mph headwinds. The trip up and around the lake in the morning was smooth. In the afternoon, however, it was pretty darn rough over the lake and over Reno. Still, the view was worth it! I wonder what its like in the middle of the Summer...? Matt At 04:35 PM 6/7/2010 Monday, you wrote: > >Great pics Matt! >Only time we ever went to Tahoe we were fighting 60mph headwinds on the way >back west and rough as heck at 12.5 > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >Sent: Saturday, June 05, 2010 9:11 PM >To: rv-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com >Subject: RV-List: Sweet Pics From Cross Country To Lake Tahoe Today... > >Dear Listers, > >The second major cross country post-Phase 1 this weekend took us to South >Lake Tahoe in our continuing "Quest For A $100 Hamburger"... The weather >was unbelievable today. Simply amazing! We ran into Marc Ausman of >Vertical Power fame http://www.verticalpower.com as we were fueling up for >our trip home. Marc has another sweet Lycoming IO-390 powered RV. > >After lunch, we took a flight over Reno at about 11000ft. > >Who knew this RV-8 was going to be such a fun vehicle of journey! :-) > > >Matt Dralle >RV-8 #82880 N998RV >http://www.mattsrv8.com - Matt's RV-8 Construction Log >http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >Status: Enjoying The Fruits of 2500 Hours of Labor... > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jun 07, 2010
We were in Lake Tahoe last year with the EAA B- 17 'Aluminum Overcast' and it was very rough flying over and around the lake. Even in the big bird. Probably the roughest flights I have ever had. Would love to return with my wife in my 6A sometime. Is it any better around the time of the Reno Races? Dale Ensing ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Monday, June 07, 2010 8:17 PM Subject: RE: RV-List: Sweet Pics From Cross Country To Lake Tahoe Today... > > Thanks! At one point we were seeing 40mph headwinds. The trip up and > around the lake in the morning was smooth. In the afternoon, however, it > was pretty darn rough over the lake and over Reno. Still, the view was > worth it! I wonder what its like in the middle of the Summer...? > > Matt > > > At 04:35 PM 6/7/2010 Monday, you wrote: >>Great pics Matt! >>Only time we ever went to Tahoe we were fighting 60mph headwinds on the >>way >>back west and rough as heck at 12.5 >> >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >>Sent: Saturday, June 05, 2010 9:11 PM >>To: rv-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com >>Subject: RV-List: Sweet Pics From Cross Country To Lake Tahoe Today... >> >>Dear Listers, >> >>The second major cross country post-Phase 1 this weekend took us to South >>Lake Tahoe in our continuing "Quest For A $100 Hamburger"... The weather >>was unbelievable today. Simply amazing! We ran into Marc Ausman of >>Vertical Power fame http://www.verticalpower.com as we were fueling up >>for >>our trip home. Marc has another sweet Lycoming IO-390 powered RV. >> >>After lunch, we took a flight over Reno at about 11000ft. >> >>Who knew this RV-8 was going to be such a fun vehicle of journey! :-) >> >> >>Matt Dralle >>RV-8 #82880 N998RV >>http://www.mattsrv8.com - Matt's RV-8 Construction Log >>http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >>Status: Enjoying The Fruits of 2500 Hours of Labor... >> >> > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > > ________________________________________________________________________________
Date: Jun 08, 2010
=0A=0A=0A=0A=0A________________________________=0AFrom: "HCRV6(at)comcast.net" =0ATo: rv-list(at)matronics.com=0ASent: Sun, June 6, 2010 3:23:32 PM=0ASubject: Re: RV-List: some approx V speeds=0A=0A=0AEd,=0A=0ATh anks for that.=C2- Without giving it much thought (make that any thought) my reaction was, what does it matter what kind of prop?=C2- Obviously it does as soon as one recognizes the effect of airspeed/RPM on HP with the f ixed pitch props.=0A=0AMy experience is consistent with your observation, a t 120 MPH my Catto prop allows me to climb with any of my buddies with CS p rops.=C2- They always get a bit of a jump on me at takeoff but as soon as I accelerate to 120 to 130 I can catch up.=0A=0AHarry Crosby=0ARV-6 N16CX, 695 hours=0A=0A----- Original Message -----=0AFrom: "Ed Anderson" <eanders on(at)carolina.rr.com>=0ATo: rv-list(at)matronics.com=0ASent: Friday, June 4, 201 0 4:41:21 PM GMT -08:00 US/Canada Pacific=0ASubject: RE: RV-List: some appr ox V speeds=0A=0A=0AHarry,=0A=C2-=0AWhen I first did my airspeed checks w ith my fixed pitch prop RV-6A, I couldn=99t get anywhere near the per formance/airspeed figures that Van quoted.=C2- It turns out his figures a re for engines with a constant speed prop.=0A=C2-=0AMy best climb speed V y turns out to be 120 MPH IAS, considerably higher than the Van=99s f igure.=0A=C2-=0AI=99m sure there is someone out there that can give you a more understandable explanation =93 but it goes something like this.=0A=C2-=0AHere is how I see it =93 with a constant speed prop , you can get more HP at slow airspeeds by making the pitch finer producing less load on the engine, which results in more RPM which results in more H P.=C2- When you are discussing climb it=99s the EXTRA HP above that required to maintain level flight than causes you to climb.=C2- If you c an increase your HP above that necessary for level flight, =C2-you can in crease your climb rate at any airspeed (well, just about)..=0A=C2-=0AWith a fixed pitch prop, you have the maximum load on the prop and therefore th e engine at slower airspeeds during climb-out, that keeps the rpm lower =C2 -and therefore HP down compared to a constant speed prop.=C2- Therefore , in order to get more climb you need to produce more HP, with a fixed pitc h prop you do that by flying a higher airspeed unloading the prop and engin e a bit thereby permitting more rpm and HP and higher climb rate.=0A=C2- =0AEd=0A=C2-=0AEd Anderson=0ARv-6A N494BW Rotary Powered=0AMatthews, NC =0Aeanderson@carolina.rr.com=0Ahttp://www.andersonee.com=0Ahttp://www.dmack .net/mazda/index.html=0Ahttp://www.flyrotary.com/=0Ahttp://members.cox.net/ rogersda/rotary/configs.htm#N494BW=0Ahttp://www.rotaryaviation.com/Rotorhea d%20Truth.htm=0A=0A________________________________=0A=0AFrom:owner-rv-list -server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net=0ASent: Friday, June 04, 2010 4:09 PM=0ATo: rv-list@m atronics.com=0ASubject: Re: RV-List: some approx V speeds=0A=C2-=0APlease explain:=0A=0AWhether you have=C2-fixed pitch or constant speed prop mak es a difference.=0A=0AHarry Crosby=0ARV-6 N16CX, 693 hours=0A=0A=0A=C2- =0A=C2-=0Ahttp://www.matronics.com/Navigator?RV-List=0Ahttp://forums.matr onics.com=0Ahttp://www.matronics.com/contribution=0A=C2-=0A=0A=0At="_bl ank">http://www.matronics.com/Navigator?RV-List=0Atp://forums.matronics.com =========0A=0A=0A ________________________________________________________________________________
Date: Jun 08, 2010
Subject: Replacing Fuel Level Senders...
Dear Listers, Well, okay, so I've resigned myself to replacing my Princeton capacitance fuel level probes with the standard S&W float probea from Van's. Has anyone replaced these without removing the wing or the fuel tank from the airplane? Basically just doing it from underneath the airplane through the gap afforded by the fuselage-to-wing fairing? Is this even possible? I know that it won't be possible to remove the Princeton units without destroying them, but can the S&W probes be installed? If I can do it without pulling the fuel tanks or wings off, then I might just tackle this sooner than later. But if the tanks have to come off, then I might procrastinate more and enjoy the great flying weather. That being said, I'm going in for paint in either August or October and it has to be complete before then either way. Arg, why couldn't those Princeton probes just work? Geeze, how much do you have to spend to get a product that works. How frustrating. So, how accurate are the bending dimensions on the Van's plans for the S&W float arms? I've got no way to test or trial fit these units so its a one-shot deal. I've already pulled the probes out once, I definitely don't want to do this again! Thanks for the insight... Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor! ________________________________________________________________________________
Date: Jun 09, 2010
Subject: Re: Replacing Fuel Level Senders...
Matt- I'm going to go on record as recommending you drain and remove the tanks to do this job. If you can do it thru the wing fairing gap you are a better man than I. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) "I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?" In a message dated 6/8/2010 9:01:32 P.M. Pacific Daylight Time, dralle(at)matronics.com writes: Well, okay, so I've resigned myself to replacing my Princeton capacitance fuel level probes with the standard S&W float probea from Van's. Has anyone replaced these without removing the wing or the fuel tank from the airplane? Basically just doing it from underneath the airplane through the gap afforded by the fuselage-to-wing fairing? Is this even possible? I know that it won't be possible to remove the Princeton units without destroying them, but can the S&W probes be installed? If I can do it without pulling the fuel tanks or wings off, then I might just tackle this sooner than later. But if the tanks have to come off, then I might procrastinate more and enjoy the great flying weather. That being said, I'm going in for paint in either August or October and it has to be complete before then either way. ________________________________________________________________________________
Date: Jun 09, 2010
I've pulled a sender out of the gap without removing the tank. I had a float that seemed to be stuck - ended up being a glob of fuel-lube. Put it back together - works fine..... Ralph RV6A N822AR @ N06 68 hrs.... ----- Original Message ----- From: Vanremog(at)aol.com To: rv-list(at)matronics.com Sent: Wednesday, June 09, 2010 2:40 AM Subject: Re: RV-List: Replacing Fuel Level Senders... Matt- I'm going to go on record as recommending you drain and remove the tanks to do this job. If you can do it thru the wing fairing gap you are a better man than I. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) "I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?" In a message dated 6/8/2010 9:01:32 P.M. Pacific Daylight Time, dralle(at)matronics.com writes: Well, okay, so I've resigned myself to replacing my Princeton capacitance fuel level probes with the standard S&W float probea from Van's. Has anyone replaced these without removing the wing or the fuel tank from the airplane? Basically just doing it from underneath the airplane through the gap afforded by the fuselage-to-wing fairing? Is this even possible? I know that it won't be possible to remove the Princeton units without destroying them, but can the S&W probes be installed? If I can do it without pulling the fuel tanks or wings off, then I might just tackle this sooner than later. But if the tanks have to come off, then I might procrastinate more and enjoy the great flying weather. That being said, I'm going in for paint in either August or October and it has to be complete before then either way. ________________________________________________________________________________
Date: Jun 09, 2010
It ain't easy, but can be done. If you put the plate on with phillips head screws, the trick is using an acme bit and some sort of ratcheting right angle driver. Got to get a lot of pressure onto the screw head or you're screwed. ;-( I used allen head socket screws and it makes life easier. That's just to get the plate off. Getting the old sender out and the new sender in through the small gap in the wing root may well be beyond difficult. Since you're not yet painted, why not pull the tanks? You could run one dry at altitude, land on the other one, pull the tank and do the work and then do the same with the other side. I found that, when I ran my tanks dry (one per flight, please), I had very little fuel left in the tank. I ran until the fuel pressure dropped off, turned on the pump and ran 'til the engine quit. Took about five or six seconds to restart after switching tanks. This was with a carbureted engine. Not sure how quick it'd come back with injection, but shouldn't be a problem. Be careful and good luck, Ed Holyoke Matt Dralle wrote: > > Dear Listers, > > Well, okay, so I've resigned myself to replacing my Princeton capacitance fuel level probes with the standard S&W float probea from Van's. Has anyone replaced these without removing the wing or the fuel tank from the airplane? Basically just doing it from underneath the airplane through the gap afforded by the fuselage-to-wing fairing? Is this even possible? > > I know that it won't be possible to remove the Princeton units without destroying them, but can the S&W probes be installed? If I can do it without pulling the fuel tanks or wings off, then I might just tackle this sooner than later. But if the tanks have to come off, then I might procrastinate more and enjoy the great flying weather. That being said, I'm going in for paint in either August or October and it has to be complete before then either way. > > Arg, why couldn't those Princeton probes just work? Geeze, how much do you have to spend to get a product that works. How frustrating. > > So, how accurate are the bending dimensions on the Van's plans for the S&W float arms? I've got no way to test or trial fit these units so its a one-shot deal. I've already pulled the probes out once, I definitely don't want to do this again! > > Thanks for the insight... > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Enjoying The Fruits of 2500 Hours of Labor! > > > ________________________________________________________________________________
Date: Jun 09, 2010
I installed with bolt-head screws which allowed me to use a ratchet and socket. -----Original Message----- >From: Ed Holyoke <bicyclop(at)pacbell.net> >Sent: Jun 9, 2010 3:17 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Replacing Fuel Level Senders... > > >It ain't easy, but can be done. If you put the plate on with phillips >head screws, the trick is using an acme bit and some sort of ratcheting >right angle driver. Got to get a lot of pressure onto the screw head or >you're screwed. ;-( I used allen head socket screws and it makes life >easier. That's just to get the plate off. Getting the old sender out and >the new sender in through the small gap in the wing root may well be >beyond difficult. Since you're not yet painted, why not pull the tanks? >You could run one dry at altitude, land on the other one, pull the tank >and do the work and then do the same with the other side. I found that, >when I ran my tanks dry (one per flight, please), I had very little fuel >left in the tank. I ran until the fuel pressure dropped off, turned on >the pump and ran 'til the engine quit. Took about five or six seconds to >restart after switching tanks. This was with a carbureted engine. Not >sure how quick it'd come back with injection, but shouldn't be a problem. > >Be careful and good luck, > >Ed Holyoke > >Matt Dralle wrote: >> >> Dear Listers, >> >> Well, okay, so I've resigned myself to replacing my Princeton capacitance fuel level probes with the standard S&W float probea from Van's. Has anyone replaced these without removing the wing or the fuel tank from the airplane? Basically just doing it from underneath the airplane through the gap afforded by the fuselage-to-wing fairing? Is this even possible? >> >> I know that it won't be possible to remove the Princeton units without destroying them, but can the S&W probes be installed? If I can do it without pulling the fuel tanks or wings off, then I might just tackle this sooner than later. But if the tanks have to come off, then I might procrastinate more and enjoy the great flying weather. That being said, I'm going in for paint in either August or October and it has to be complete before then either way. >> >> Arg, why couldn't those Princeton probes just work? Geeze, how much do you have to spend to get a product that works. How frustrating. >> >> So, how accurate are the bending dimensions on the Van's plans for the S&W float arms? I've got no way to test or trial fit these units so its a one-shot deal. I've already pulled the probes out once, I definitely don't want to do this again! >> >> Thanks for the insight... >> >> >> Matt Dralle >> RV-8 #82880 N998RV >> http://www.mattsrv8.com - Matt's RV-8 Construction Blog >> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >> Status: Enjoying The Fruits of 2500 Hours of Labor! >> >> >> >> >> >> >> > > ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Date: Jun 09, 2010
Hate to tell you this Matt: But I installed the inexpensive Van's capacitive sensors when I built my tanks and later bought the not-so-inexpensive EI gauge that goes with them. Another of the Van's solutions that works great. Unfortunately you won't be able to install the sensors in your finished tanks without some major surgery (I wouldn't). Taking the tanks off to install the float type sender is easiest way and shouldn't take but a weekend to do. Been there done that (to repair an accessable leak) earlier in Delta Mikes flying career. Definately want to bite the bullet before you paint. I know how you feel though, spent one of my recent weekends fiddling with my EzPilot trying to get everything working so "George" can fly once in a while when I look at charts. It's been a year and a half since the airplane first flew and I really didn't want to spend my weekend wrenching on the plane but...it was worth it in the end. Regards Dean N197DM ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)fmwildblue.com>
Subject: RV-9A Main Gear foot print...
Date: Jun 10, 2010
Guys, I've been building an RV-9A in the basement for a number of years - time to take it to the airport. I've raised the RV with an engine hoist, removed the main gear, and placed the fuselage in a wheeled cradle to get it through the basement door. I forgot to measure the width of the main gear before I did this. I need the info to determine the width of the trailer to transport it to the airport. Can anyone give me the measurement - I'm guessing about 8 ft. (My old age is catching up with me...) Joe Connell Stewartville, MN ________________________________________________________________________________
Subject: Re: RV-9A Main Gear foot print...
Date: Jun 10, 2010
You will need an 8" trailer. I hired a wrecker lowboy. Bret Smith RV-9A N16BL Blue Ridge, GA www.FlightInnovations.com ----- Original Message ----- From: Joe & Jan Connell To: RV-List Sent: Thursday, June 10, 2010 12:56 PM Subject: RV-List: RV-9A Main Gear foot print... Guys, I've been building an RV-9A in the basement for a number of years - time to take it to the airport. I've raised the RV with an engine hoist, removed the main gear, and placed the fuselage in a wheeled cradle to get it through the basement door. I forgot to measure the width of the main gear before I did this. I need the info to determine the width of the trailer to transport it to the airport. Can anyone give me the measurement - I'm guessing about 8 ft. (My old age is catching up with me...) Joe Connell Stewartville, MN ________________________________________________________________________________
Date: Jun 10, 2010
Its actually closer to seven feet wide. Fits very nice onto a car hauler t railer. Mike Robertson Das Fed From: jconnell(at)fmwildblue.com Subject: RV-List: RV-9A Main Gear foot print... Date: Thu=2C 10 Jun 2010 11:56:43 -0500 Guys=2C I've been building an RV-9A in the basement for a number of years - time to take it to the airport. I've raised the RV with an engine hoist=2C removed the main gear=2C and pla ced the fuselage in a wheeled cradle to get it through the basement door. I forgot to measure the width of the main gear before I did this. I need t he info to determine the width of the trailer to transport it to the airpor t. Can anyone give me the measurement - I'm guessing about 8 ft. (My old age is catching up with me...) Joe Connell Stewartville=2C MN _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H otmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid= PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Date: Jun 10, 2010
If you have the Princeton probes that bend around just inside the tank (in -up-over&down) they can be replaced without a tankcision.? I've done this 3 times before giving up on them on a -7A and installing the floats from Van.? You will have to bend them a bit to get them out, but with the righ t combination of wiggling/twisting etc. they will come out.? Adding the fl oats is pretty simple- bend the float arms per instructions, paying close attention to R/L, then set them up on a bench to simulate the tank for ad justment before installing.? Mount the sender perpendicular to the bench on some kind of support at the same height as?it would be in the tank wit h the float resting on the bench, and note the float travel distance by me asuring from top to bottom on the tank where the sender installs (7-8"?), then adjust the arm to get the correct resistance readings for that trave l.? Make sure the float will miss the stiffener on the tank bottom so it won't hang up and will get full travel- you can note the location of the stiffener by the rivet line on the tank- check with a dental mirror to se e which way the stiffener flange faces. ? Just another fun day at the hangar! ? Mark Phillips - RV-6A "Mojo", almost 600 hrs, floats recently replaced... http://websites.expercraft.com/n51pw/ -----Original Message----- From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> Sent: Wed, Jun 9, 2010 8:22 pm Subject: RV-List: Replacing Fuel Level Senders --> RV-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos@ verizon.net> Hate to tell you this Matt: But I installed the inexpensive Van's capacitive sensors when I built my tanks and later bought the not-so-inexpensive EI gauge that goes with them . Another of the Van's solutions that works great. Unfortunately you won't be able to install the sensors in your finished tanks without some major surgery (I wouldn't). Taking the tanks off to install the float type send er is easiest way and shouldn't take but a weekend to do. Been there done th at (to repair an accessable leak) earlier in Delta Mikes flying career. Definately want to bite the bullet before you paint. I know how you feel though, spent one of my recent weekends fiddling with my EzPilot trying to get everything working so "George" can fly once in a while when I look at charts. It's been a year and a half since the airplane first flew and I really didn't want to spend my weekend wrenching on the plane but...it was worth it in the end. Regards Dean N197DM ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Subject: RV-9A Main Gear Footprint
Date: Jun 11, 2010
Joe, This was recent enough in my experience that I can tell you that if you use a panel truck that is 8' wide you will need to wiggle the wheels past the door frame one at a time to get it in. I think I even had to remove the AN4 bolts that I'd had installed to get it to fit. I think, with the weight of the engine pushing the mains out it's going to around 7'10 to the outside of the structure of the wheels. Good luck. Ian Brown C-GOHM 55hrs ________________________________________________________________________________
Subject: A must read for / Single Electronic Mag Users
Date: Jun 11, 2010
G3i will in KOSH again this year in hanger A booth #1148 demonstrating and releasing the new Series-SC (Single Channel) which focuses on curing the issues of the off-set ignition timing events with the EI and magneto systems. The G3i SC module reads the variable/ advance-timing signal from the existing aftermarket electronic mag. The SC tracks it, and timing it in perfect synchronization to fire the magneto at the same timing event as the electronic mag. With a multiple spark technology. Dual EIs and keeping your existing single magneto as an added redundancy. Thomas S. www.g3ignition.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300952#300952 ________________________________________________________________________________
Subject: XM weather updates
Date: Jun 11, 2010
Guys, I've finally started the Phase I of my RV-6A, after a 12.5 year build. Thanks to many for there help over the years. I'm having a bit of an issue with the weather updates to my Garmin 496. Garmin advised me to update the software to version 4.2 which I've done but it didn't help. Researching the posts on this list suggests that others have noticed long delays in updates to their units, but I didn't see where there was a solution given. Did anyone who had long updates, and I mean things like Nexrad being over an hour old, find a fix for this? Marty in Brentwood TN N826ME finally an airplane. ________________________________________________________________________________
Date: Jun 11, 2010
Subject: Re: XM weather updates
Call XM. When that happened to me, they reset things and all was well. ________________________________________________________________________________
Date: Jun 11, 2010
Hi Joe.- I moved my RV from my home to the airport last summer for final assembly and used a car carrier tow truck.- With the weight of the aircra ft bearing down on the main wheels, it will cause the main gear legs to spr ead a bit.- So, in order to pull the plane up onto the sloped deck of the car carrier, you will need to wrap a-cargo strap around the main gear le gs and then place-2x4's along the side rails.- The reason for this is t hat usually the edge of the rails are angled outward and the 2x4's raise th e wheels up enough so the tires clear the edge ever so tightly.- Once up on the truck, strap her-in and off to the airport you go. - Hope this is helpful. - Steve Koziol N424JK- 70 hours of flying fun.- --- On Thu, 6/10/10, Joe & Jan Connell wrote: From: Joe & Jan Connell <jconnell(at)fmwildblue.com> Subject: RV-List: RV-9A Main Gear foot print... Date: Thursday, June 10, 2010, 12:56 PM Guys, - I've been building an RV-9A in the basement for a number of years - time to take it to the airport. - I've raised the RV with an engine hoist, removed the main gear, and placed the fuselage in a wheeled cradle to get it through the basement door. - I forgot to measure the width of the main gear before I did this.- I need the info to determine the width of the trailer to transport it to the airp ort. - Can anyone give me the measurement - I'm guessing about 8 ft.- (My old ag e is catching up with me...) - Joe Connell Stewartville, MN - - =0A=0A=0A ________________________________________________________________________________
Date: Jun 12, 2010
Subject: fuel placards
Does any one know a source for fuel filler placards that say "100LL only" ? I got a couple from aircraft spruce and they are much bigger than they need to be. It's the circular, doughnut-shaped type of placard. The placard is 6" in diameter - you could read it from 20 feet away. I've looked for something smaller, but haven't come up with anything yet. I thought Vans would sell something appropriate, but if they do, I can't find it in the on-line catalog. -- Tom Sargent, RV-6A, trying to schedule the airworthiness inspection. ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 12, 2010
Most people get the fuel cap engraved. Here is one place that does it: http://www.rvengraving.com/ Carl Froehlich RV-8A (540 hrs) RV-10 (systems install) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent Sent: Saturday, June 12, 2010 7:25 PM Subject: RV-List: fuel placards Does any one know a source for fuel filler placards that say "100LL only" ?=C2 I got a couple from aircraft spruce and they are much bigger than they need to be.=C2 It's the circular, doughnut-shaped type of placard.=C2 The placard is 6" in diameter - you could read it from 20 feet away.=C2 I've looked for something smaller, but haven't come up with anything yet.=C2 I thought Vans would sell something appropriate, but if they do, I can't find it in the on-line catalog. -- Tom Sargent, RV-6A, trying to schedule the airworthiness inspection. ________________________________________________________________________________
Date: Jun 12, 2010
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Subject: Re: fuel placards
http://www.aircraftspruce.com/catalog/cspages/fuelplacards.php http://www.rvengraving.com/ Local vinyl lettering shop can make one up cheap and quick ---- Surfing the web from Hopkinsville, KY Visit my web site: http://home.newwavecomm.net/bobbyhester/RVSite.htm thomas sargent wrote: > Does any one know a source for fuel filler placards that say "100LL > only" ? I got a couple from aircraft spruce and they are much bigger > than they need to be. It's the circular, doughnut-shaped type of > placard. The placard is 6" in diameter - you could read it from 20 > feet away. I've looked for something smaller, but haven't come up > with anything yet. I thought Vans would sell something appropriate, > but if they do, I can't find it in the on-line catalog. > > -- > Tom Sargent, RV-6A, trying to schedule the airworthiness inspection. > * > > > * ________________________________________________________________________________
Date: Jun 12, 2010
TOM: IF I REMEMBER CORRECTLY I GOT SOME REAL SMALL LABELS AS PART OF AN EAA EXPERIMENTAL AIRCRAFT CERTIFICATION PAPERWORK PACKET. THERE WERE ALL KINDS OF INSTRUMENT PANEL LABELS AND SOME SMALL RECTANGULAR FUEL TANK "100 LL" LABELS. I EVENTUALLY HADE MY FILLER CAPS ENGRAVED WITH "100 LL - 21 GALS." INCIDENTALLY - THE FILLER CAP TENSION IS ADJUSTABLE. BE CAREFUL HOW MUCH TENSION YOU CRANK INTO THEM - TOO MUCH AND YOU'LL SNAP THE PINS - THEY'RE ROLLED AND NOT SOLID. IF YOU SNAP THEM THEY'RE EASILY REPLACED WITH CUT DOWN SHANKS FROM 1/16" DRILL BITS. DAN BERGERON RV-7A - N307TB 149 HOURS SINCE FIRST FLIGHT ON 08/04/09 On Sat, Jun 12, 2010 at 7:25 PM, thomas sargent wrote: > Does any one know a source for fuel filler placards that say "100LL only" > ? I got a couple from aircraft spruce and they are much bigger than they > need to be. It's the circular, doughnut-shaped type of placard. The > placard is 6" in diameter - you could read it from 20 feet away. I've > looked for something smaller, but haven't come up with anything yet. I > thought Vans would sell something appropriate, but if they do, I can't find > it in the on-line catalog. > > -- > Tom Sargent, RV-6A, trying to schedule the airworthiness inspection. > > * > > ________________________________________________________________________________
Date: Jun 13, 2010
I had mine engraved WITHOUT my N number. IF they fall off in flight and hi t someone=2C it will not be traceable back to me. Others had good answers. Brother Label makers make good labels that meet the FAA requirement=2C they last a long time plus are cheap to replace. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C377+ Flying Hours So. CA=2C USA Date: Sat=2C 12 Jun 2010 16:25:20 -0700 Subject: RV-List: fuel placards From: sarg314(at)gmail.com Does any one know a source for fuel filler placards that say "100LL only" ? I got a couple from aircraft spruce and they are much bigger than they ne ed to be. It's the circular=2C doughnut-shaped type of placard. The placa rd is 6" in diameter - you could read it from 20 feet away. I've looked fo r something smaller=2C but haven't come up with anything yet. I thought Va ns would sell something appropriate=2C but if they do=2C I can't find it in the on-line catalog. -- Tom Sargent=2C RV-6A=2C trying to schedule the airworthiness inspection. _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Date: Jun 13, 2010
Subject: MT prop paint problem?
About a year ago, I had my MT prop overhauled. Amazingly, it had been 6 years. The prop life is time-limited, I believe because grease gradually seeps out and there are no grease fittings to replace it. Grease certainly has come out of my prop and sure enough some of the internal bearings were wearing and had to be replaced. Now for the problem ... the paint keeps coming off. I have had the prop repainted 3 times and it needs a fourth. Each time the prop has to be pulled and shipped to the repair facility, resulting in 2 weeks or more downtime. This is far more practice than I wanted in removing and re-installing the prop! As best I can tell, flying through (very light) rain is what does it. The paint seems fine for a few months until I do a little IFR, then the paint on the tips are eroded. It looks hideous and I wonder if it does anything to the balance, though I can't detect any difference. Has anyone else had similar issues? ________________________________________________________________________________
Date: Jun 13, 2010
Subject: vinyl letters for fuel type and quantity
>>>>SNIP Does any one know a source for fuel filler placards that say "100LL only" ?<<<<Subject: Re: MT prop paint problem?
Date: Jun 13, 2010
I just took my prop over to MT USA in Deland, FL to get it repainted after 235 hours and a year and a half flying. Flying in rain is the culprit and is pretty well known in the MT community. My prop is black with yellow tips, so the grey primer shows up pretty clearly and your observation that it looks hideous is correct. I flew it over to Deland a few months ago and had them look at it to make sure the problem was only cosmetic. Juergen, at MT, confirmed this for me. He suggested that I paint the prop grey so the erosion won't looks so bad!!!!!!! Not my idea of a fix, but I think he was serious! Anyway, I love everything else about the prop but I will avoid rain as much as possible and just live with it. I am a 30 minute drive to Deland, so at least I don't have such a long turnaround time. David Maib RV-10 N380DM On Jun 13, 2010, at 12:33 AM, Randy Garrett wrote: > > About a year ago, I had my MT prop overhauled. Amazingly, it had been > 6 years. The prop life is time-limited, I believe because grease > gradually seeps out and there are no grease fittings to replace it. > Grease certainly has come out of my prop and sure enough some of the > internal bearings were wearing and had to be replaced. > > Now for the problem ... the paint keeps coming off. I have had the > prop repainted 3 times and it needs a fourth. Each time the prop has > to be pulled and shipped to the repair facility, resulting in 2 weeks > or more downtime. This is far more practice than I wanted in removing > and re-installing the prop! > > As best I can tell, flying through (very light) rain is what does it. > The paint seems fine for a few months until I do a little IFR, then > the paint on the tips are eroded. It looks hideous and I wonder if it > does anything to the balance, though I can't detect any difference. > > Has anyone else had similar issues? > > > > ________________________________________________________________________________
Subject: Re: Fly from your home! Tennessee home with airstrip for sale!
Date: Jun 14, 2010
http://longmeadow.vflyer.com/home/flyer/home/3291623 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301136#301136 ________________________________________________________________________________
Subject: VSI Adjustment
Date: Jun 14, 2010
Listers, I notice my VSI doesn't indicate a "0" VSI when I'm in level flight. Is there an adjustment that can be made to "zero the needle"? Marty N826ME ________________________________________________________________________________
Date: Jun 14, 2010
Subject: Re: VSI Adjustment
Most vsi's have a "zero" screw that you can adjust located on the face. On Mon, Jun 14, 2010 at 5:41 PM, emrath wrote: > > Listers, > I notice my VSI doesn't indicate a "0" VSI when I'm in level flight. Is > there an adjustment that can be made to "zero the needle"? > > Marty N826ME > > ________________________________________________________________________________
Date: Jun 14, 2010
Subject: Special Nuts In Cylinders...
What are those special little nuts called that insert into the bottom of the Lycoming cylinder so that you can hold the baffling on? I think four of them came in my Van's FWF kit. I noticed this weekend that one of them had the screw come out and the nut insert fell to earth somewhere, no doubt. A part number would be great! -- Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog 44 Hours since May 02 2010 and enjoying every minute of it! ________________________________________________________________________________
Date: Jun 15, 2010
Subject: Kalispell MT
Hi All, I'm in Kalispell MT for the next couple of days, and have some free time. Is there anybody in this area that needs some electrical or mechanical help? I've built three RV-s, and helped several other builders with electrical and mechanical solutions for their planes. The weather looks like it's about to take a turn for the worst, so I won't be flying in the area, so will be free Tues & Wed. Thursday morning I leave for Canada and then Fairbanks..... Fred Stucklen RV-7A N924RV 385 Hrs (Flying) RV-6A N926RV 875 Hrs (sold) RV-6A N925RV 2008 Hrs (Sold) Email: wstucklen1(at)cox.net 8Cell: 60-490-3933 ________________________________________________________________________________
From: Charles Rowbotham <crowbotham(at)hotmail.com>
Date: Jun 15, 2010
Hi Fred=2C Glad to hear your trip is going well. Have a great and safe trip! Chuck Rowbotham RV-8A (sold) > Date: Tue=2C 15 Jun 2010 00:44:53 -0400 > From: wstucklen1(at)cox.net > To: RV-List(at)matronics.com > Subject: RV-List: Kalispell MT > > > Hi All=2C > > I'm in Kalispell MT for the next couple of days=2C and have some free tim e. Is there anybody in this area that needs some electrical or mechanical h elp? I've built three RV-s=2C and helped several other builders with electr ical and mechanical solutions for their planes. The weather looks like it's about to take a turn for the worst=2C so I won't be flying in the area=2C so will be free Tues & Wed. Thursday morning I leave for Canada and then Fa irbanks..... > > Fred Stucklen > RV-7A N924RV 385 Hrs (Flying) > RV-6A N926RV 875 Hrs (sold) > RV-6A N925RV 2008 Hrs (Sold) > > Email: wstucklen1(at)cox.net > 8Cell: 60-490-3933 _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H otmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid= PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Subject: Paint flaking off in countersunk holes
Date: Jun 15, 2010
I recently removed a tank and was dismayed to see rusting screws and the paint coming off around the holes. I guess I can use stainless screws instead of the regular ones to avoid the rusting, but does anyone have a solution to the paint coming off? I think the bond with the alumin(i)um is broken as I tighten the screws but doesn't become really visible until I unscrew them. I had the aircraft professionally painted but I'm guessing it's difficult to scuff up the countersinks. While I'm on the subject of removing tanks, does anyone have a solution to removing the second-to-most-inboard row of baffle bracket bolts without losing major amounts of skin? I use a short (3") wrench but I can only just get my hand in place. All 21 bolts are difficult to remove but those three are the worst. Ian Brown, RV-9A C-GOHM, Bromont, Quebec ________________________________________________________________________________
Subject: RV8A Building Question
Date: Jun 15, 2010
Dear Listers ... I bought a partially complete kit. The building manual was not all there and I'm, therefore, not sure which step to begin next. There are several places where rivets are not installed (pending steps to take, in sequence I'm sure). I would like to learn from this vast group of builders: What should I do to make sure I begin at the next step to keep the sequence of steps in order? It wouldn't be smart to get to a place then find several rivets need drilled-out to install something else. I don't mind buying a new build manual if that's called for, or replacing missing prints. What would you gents do in this case? Many thank for your answers ... Jerry jerry(at)mc.net ________________________________________________________________________________
Date: Jun 15, 2010
Subject: Re: Paint flaking off in countersunk holes
I think there are two issues here ..... the painter may have just painted over the screws instead of loosening them up to paint underneath the heads. The second thing that should have been done is to place nylon washers (aircraft spruce) under the screw heads when they were tightened down, which would have saved most of the cracking paint when the screws were removed. the washers also make it easier to remove the screws. Linn Ian wrote: > I recently removed a tank and was dismayed to see rusting screws and > the paint coming off around the holes. I guess I can use stainless > screws instead of the regular ones to avoid the rusting, but does > anyone have a solution to the paint coming off? I think the bond > with the alumin(i)um is broken as I tighten the screws but doesn't > become really visible until I unscrew them. I had the aircraft > professionally painted but I'm guessing it's difficult to scuff up the > countersinks. > > While I'm on the subject of removing tanks, does anyone have a > solution to removing the second-to-most-inboard row of baffle bracket > bolts without losing major amounts of skin? I use a short (3") wrench > but I can only just get my hand in place. All 21 bolts are difficult > to remove but those three are the worst. > > Ian Brown, > RV-9A C-GOHM, Bromont, Quebec ________________________________________________________________________________
Subject: Flap Fuse
Date: Jun 15, 2010
Follow-up to let everyone know the final resolution in case someone else sees the issue in the future. Grease had worked its way up into the motor and was 'binding it up'. Even with the motor completely detached from everything else, it was drawing 2.5 amps just to start spinning. In fact, it drew so much current that small wisps of smoke came out of it when I applied power. Next time I won't ignore the problem when 7.5 amp fuses are periodically blowing! I found that Usher Precision (http://www.usherprecision.com/aircraft-parts.html) sells just the bare Pittman motor for $110. After swapping the motor out I took it for some touch-n-goes and the problem looks like it's gone. Gene From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ian Sent: Sunday, May 16, 2010 6:20 PM Subject: RV-List: Flap Fuse How about disconnecting the pushrods and checking for resistance to movement by moving each flap manually? Excessive current draw suggests that the motor is struggling. You could divide the movement in two - the motor to the push rods and the push rods to the flaps. If you feel no resistance to movement on the flap side then maybe there's some interference or tightness on the motor side. Could anything be misaligned, interfering or overtightened in motor to pushrod chain? Ian Brown "I have an RV-7a with 700 hours on her and a month ago the flap fuse ( 7.5amps ) blew on two consecutive landings. The fuse has never blown before in those 700 hours. I know I was well below the white arc, 10 to 15 knots below, on both of the landings. After I changed the fuse on those two, it went almost a month without ever happening again, then the fuse below twice more over the course of a few landings. It always blows on the downward movement, but the point at which it's blown varies anywhere between just barely having moved and being as much as 20 degrees when it happens." ________________________________________________________________________________
Date: Jun 15, 2010
Ian--We put tinnermans under the tank screws and it makes for a very tidy look and no more paint worries. LeRoy Johnston/David White RV-6A Esperanza 314 hrs Ohio -----Original Message----- From: Ian <ixb(at)videotron.ca> Sent: Tue, Jun 15, 2010 12:40 pm Subject: RV-List: Paint flaking off in countersunk holes I recently removed a tank and was dismayed to see rusting screws and the paint coming off around the holes. I guess I can use stainless screws in stead of the regular ones to avoid the rusting, but does anyone have a sol ution to the paint coming off? I think the bond with the alumin(i)um is broken as I tighten the screws but doesn't become really visible until I unscrew them. I had the aircraft professionally painted but I'm guessin g it's difficult to scuff up the countersinks. While I'm on the subject of removing tanks, does anyone have a solution to removing the second-to-most-inboard row of baffle bracket bolts without losing major amounts of skin? I use a short (3") wrench but I can only just get my hand in place. All 21 bolts are difficult to remove but thos e three are the worst. Ian Brown, RV-9A C-GOHM, Bromont, Quebec ________________________________________________________________________________
Subject: FBOs at KHEF Manassas Regional VA
Date: Jun 15, 2010
Listers--Planning a trip this weekend to KHEF Manassas Regional in VA and need overnight hangar. There are three FBOs: Dulles Aviation Chantilly Air APP Jet Center Any preferences? Thanks. LeRoy Johnston RV-6A Esperanza 314 hrs OH ________________________________________________________________________________
Date: Jun 16, 2010
Subject: Re: RV8A Building Question
Jerry, I built an RV-8A and an RV-8, both quickbuilds.=C2- My advice to y ou is to go ahead and buy the manual from Van's. You will need to do lots of reading & study to figure out where the previous builder left off. Even with the manual, it took quite a bit of study to determine where the quickb uild part started. Walt Shipley ----- Original Message ----- From: "Jerry Grimmonpre" <jerry(at)mc.net> Sent: Tuesday, June 15, 2010 3:41:36 PM GMT -05:00 US/Canada Eastern Subject: RV-List: RV8A Building Question Dear Listers ... I bought a partially complete kit. =C2-The building manual was not all th ere and I'm, therefore, not sure which step to begin next. =C2-There are seve ral places where rivets are not installed (pending steps to take, in sequence I'm sure). I would like to learn from this vast group of builders: What should I do to make sure I begin at the next step to keep the sequence of steps in order? =C2-It wouldn't be smart to get to a place then find s everal rivets need drilled-out to install something else. I don't mind buying a new build manual if that's called for, or replacing missing prints. What would you gents do in this case? Many thank for your answers ... Jerry jerry(at)mc.net =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: AeroElectric-List: Active Notification of Low Voltage
Date: Jun 16, 2010
Bob, et. al., I'm one of the guilty ones with an electronic EFIS and no warning light for a low voltage. In a low voltage situation, my EFIS voltmeter does flash, but I have determined that isn't a sufficient warning. Thus I would like to install a low voltage warning light. To complicate matters: however, I have a generic Ford regulator that does not have a low voltage warning circuit. Is there a simple solution for this situation? Charlie Brame RV-6A N11CB San Antonio ---------------------------------------------------------- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Active Notification of Low Voltage At 05:06 PM 6/14/2010, you wrote: > Many current OBAM aircraft have electronic EFIS and/or EIS systems > installed in their panels. Most of these systems have the > capability to monitor various engine and electrical > parameters. Limits can be programmed so that when a parameter is > outside of the set limits, this is enunciated via audio and/or > visual notification (a warning light). > > Is the use of these EFIS/EIS systems adequate for proper stand alone > "Active Notification of Low Voltage"? Or is it recommended that > additional equipment be employed? This additional equipment would > be such as AEC9005, AEC9024 (when available), or other such devices > on the market. Your choice. The operative word is "active". If the nature of the warning provided as a feature of a panel mounted accessory is sufficient to get your attention within a minute of onset of LV, then the design goals have been met. The B&C LR series regulators are shipped with a rather obnoxious yellow warning light assembly that is guaranteed to get your attention. It's something you can experiment with in flight. Shut the alternator off. Judge for yourself if the resulting indication is sufficiently attention getting. Bob . . . ________________________________________________________________________________
Date: Jun 16, 2010
Vans' carries one for $80. Pretty steep but looks elegant. I have one similar which I got from electric Bob years ago for a lot less, but don't think he is in that business any more. On Jun 16, 2010, at 10:05 , Charles Brame wrote: > Bob, et. al., > > I'm one of the guilty ones with an electronic EFIS and no warning > light for a low voltage. In a low voltage situation, my EFIS > voltmeter does flash, but I have determined that isn't a sufficient > warning. Thus I would like to install a low voltage warning light. > To complicate matters: however, I have a generic Ford regulator that > does not have a low voltage warning circuit. Is there a simple > solution for this situation? > > Charlie Brame > RV-6A N11CB > San Antonio > > ---------------------------------------------------------- > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Active Notification of Low Voltage > > At 05:06 PM 6/14/2010, you wrote: >> Many current OBAM aircraft have electronic EFIS and/or EIS systems >> installed in their panels. Most of these systems have the >> capability to monitor various engine and electrical >> parameters. Limits can be programmed so that when a parameter is >> outside of the set limits, this is enunciated via audio and/or >> visual notification (a warning light). >> >> Is the use of these EFIS/EIS systems adequate for proper stand alone >> "Active Notification of Low Voltage"? Or is it recommended that >> additional equipment be employed? This additional equipment would >> be such as AEC9005, AEC9024 (when available), or other such devices >> on the market. > > Your choice. The operative word is "active". > If the nature of the warning provided as a > feature of a panel mounted accessory is sufficient > to get your attention within a minute of > onset of LV, then the design goals have been > met. > > The B&C LR series regulators are shipped with > a rather obnoxious yellow warning light assembly > that is guaranteed to get your attention. > > It's something you can experiment with in > flight. Shut the alternator off. Judge for > yourself if the resulting indication is sufficiently > attention getting. > > > Bob . . . > > ________________________________________________________________________________
Date: Jun 16, 2010
There is a nice one here: http://www.periheliondesign.com/ <http://www.periheliondesign.com/> -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Wed, Jun 16, 2010 at 12:19 PM, Denis Walsh wrote: > Vans' carries one for $80. Pretty steep but looks elegant. > > I have one similar which I got from electric Bob years ago for a lot less, > but don't think he is in that business any more. > On Jun 16, 2010, at 10:05 , Charles Brame wrote: > > Bob, et. al., > > I'm one of the guilty ones with an electronic EFIS and no warning light for > a low voltage. In a low voltage situation, my EFIS voltmeter does flash, but > I have determined that isn't a sufficient warning. Thus I would like to > install a low voltage warning light. To complicate matters: however, I have > a generic Ford regulator that does not have a low voltage warning circuit. > Is there a simple solution for this situation? > > Charlie Brame > RV-6A N11CB > San Antonio > > ---------------------------------------------------------- > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Active Notification of Low Voltage > > At 05:06 PM 6/14/2010, you wrote: > > Many current OBAM aircraft have electronic EFIS and/or EIS systems > > installed in their panels. Most of these systems have the > > capability to monitor various engine and electrical > > parameters. Limits can be programmed so that when a parameter is > > outside of the set limits, this is enunciated via audio and/or > > visual notification (a warning light). > > > Is the use of these EFIS/EIS systems adequate for proper stand alone > > "Active Notification of Low Voltage"? Or is it recommended that > > additional equipment be employed? This additional equipment would > > be such as AEC9005, AEC9024 (when available), or other such devices > > on the market. > > > Your choice. The operative word is "active". > If the nature of the warning provided as a > feature of a panel mounted accessory is sufficient > to get your attention within a minute of > onset of LV, then the design goals have been > met. > > The B&C LR series regulators are shipped with > a rather obnoxious yellow warning light assembly > that is guaranteed to get your attention. > > It's something you can experiment with in > flight. Shut the alternator off. Judge for > yourself if the resulting indication is sufficiently > attention getting. > > > Bob . . . > > * > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > * > > > * > > * > > ________________________________________________________________________________
Date: Jun 17, 2010
Subject: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion
It is time for us to attach the skirt to the canopy frame where the plans call for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work? Thanks, Robin ________________________________________________________________________________
Subject: Landing gear fairing install
Date: Jun 17, 2010
I need some recommendations as to the best way to elevate my completed RV7 fuselage so that I can align the gear leg fairings. The weight should be around 600lb. Is there a better way than jack stands under the center section and weighting the tail? Thanks! Wade Roe RV7 in the final stretch ________________________________________________________________________________
Date: Jun 17, 2010
Hi Robin=2C We used the same adhensive that Christian Eagle uses on our 8A. The complet e details with product info are in the archives. The RV was hangered in CT and flown on a regular basis through out the year over nine years - No cra cks and no change in the seal. Hope this helps - Keep at it - it's really worth the effort! Chuck & Dave Rowbotham RV-8A (Sold) RV-9A (Dave's building) From: robin(at)PaintTheWeb.com Date: Thu=2C 17 Jun 2010 09:03:30 -0700 Subject: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Sugges tion It is time for us to attach the skirt to the canopy frame where the plans c all for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work? Thanks=2C Robin _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Subject: Re: Landing gear fairing install
Date: Jun 17, 2010
I used saw horses. Sent from my iPhone On Jun 17, 2010, at 1:02 PM, "Wade Roe" wrote: > I need some recommendations as to the best way to elevate my > completed RV7 fuselage so that I can align the gear leg fairings. > The weight should be around 600lb. Is there a better way than jack > stands under the center section and weighting the tail? > > > Thanks! > > > Wade Roe > > > RV7 in the final stretch > > ________________________________________________________________________________
Date: Jun 17, 2010
How did you get the fuselage on the saw horses? Did you elevate the tail then physically lift on side at a time and insert the horses? From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Thursday, June 17, 2010 12:51 PM Subject: Re: RV-List: Landing gear fairing install I used saw horses. Sent from my iPhone On Jun 17, 2010, at 1:02 PM, "Wade Roe" wrote: I need some recommendations as to the best way to elevate my completed RV7 fuselage so that I can align the gear leg fairings. The weight should be around 600lb. Is there a better way than jack stands under the center section and weighting the tail? Thanks! Wade Roe RV7 in the final stretch ________________________________________________________________________________
Date: Jun 17, 2010
I rigged a motorcycle jack under the center section. That worked well for me. On Jun 17, 2010, at 1:02 PM, "Wade Roe" wrote: I need some recommendations as to the best way to elevate my completed RV7 fuselage so that I can align the gear leg fairings. The weight should be around 600lb. Is there a better way than jack stands under the center section and weighting the tail? Thanks! Wade Roe RV7 in the final stretch ________________________________________________________________________________
Date: Jun 17, 2010
Check this posting: http://www.vansairforce.com/community/showthread.php?t=11956 Smitty http://SmittysRV.com ----- Original Message ----- From: Craig Gallenbach To: rv-list(at)matronics.com Sent: Thursday, June 17, 2010 2:02 PM Subject: Re: RV-List: Landing gear fairing install I rigged a motorcycle jack under the center section. That worked well for me. On Jun 17, 2010, at 1:02 PM, "Wade Roe" wrote: I need some recommendations as to the best way to elevate my completed RV7 fuselage so that I can align the gear leg fairings. The weight should be around 600lb. Is there a better way than jack stands under the center section and weighting the tail? Thanks! Wade Roe RV7 in the final stretch ________________________________________________________________________________
Date: Jun 17, 2010
Subject: Re: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion
Hey gents, I am at the same spot. Have been considering sikaflex (how I did the canopy) and 3M 5200. Where in the archives would I find this information? Regards, Michael Wynn RV 8 Finishing San Ramon, CA In a message dated 6/17/2010 10:54:35 A.M. Pacific Daylight Time, crowbotham(at)hotmail.com writes: Hi Robin, We used the same adhensive that Christian Eagle uses on our 8A. The complete details with product info are in the archives. The RV was hangered in CT and flown on a regular basis through out the year over nine years - No cracks and no change in the seal. Hope this helps - Keep at it - it's really worth the effort! Chuck & Dave Rowbotham RV-8A (Sold) RV-9A (Dave's building) ____________________________________ From: robin(at)PaintTheWeb.com Date: Thu, 17 Jun 2010 09:03:30 -0700 Subject: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion It is time for us to attach the skirt to the canopy frame where the plans call for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work? Thanks, Robin p://www.matronics.com/Navigator?RV-List ronics.com ww.matronics.com/contribution ____________________________________ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. _Learn more._ (http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1) (http://www.matronics.com/Navigator?RV-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Jun 17, 2010
Subject: RV-6A/7A test plan
I am starting to work on a test plan which the FAA wants you to have by the time you get an airworthiness certificate. Are there any samples of these of these available on the web anywhere? Does any one have one they would be willing to divulge? -- Tom Sargent, RV-6A. ________________________________________________________________________________
Date: Jun 18, 2010
A starting point is the test plan Advisory Circular which is on the EAA web page. Marty Heller RV-7=2C wiring Date: Thu=2C 17 Jun 2010 16:40:16 -0700 Subject: RV-List: RV-6A/7A test plan From: sarg314(at)gmail.com I am starting to work on a test plan which the FAA wants you to have by th e time you get an airworthiness certificate. Are there any samples of thes e of these available on the web anywhere? Does any one have one they would be willing to divulge? -- Tom Sargent=2C RV-6A. _________________________________________________________________ The New Busy is not the old busy. Search=2C chat and e-mail from your inbox . http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_3 ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jun 17, 2010
Transmission jack works really nice for that but you still have to tie the tail down. Bill S 7a almost there _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Wade Roe Sent: Thursday, June 17, 2010 12:03 PM Subject: RV-List: Landing gear fairing install I need some recommendations as to the best way to elevate my completed RV7 fuselage so that I can align the gear leg fairings. The weight should be around 600lb. Is there a better way than jack stands under the center section and weighting the tail? Thanks! Wade Roe RV7 in the final stretch ________________________________________________________________________________
Date: Jun 18, 2010
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=100711999?KEYS=christian_eagle?LISTNAME=RV?HITNUMBER=3?SERIAL=00300129883?SHOWBUTTONS=YES *Mark,* * * *Here is how we drilled and attached our canopy (no cracks)!!* * * *1. We heated the garage to about 90 degress 6 hours prior to starting to * *work.* * * *2. We drilled the initial holes with a #40* * * *3. Opened up the #40 hole to the proper size with a Uni-Bit (single flute no * *grabbing!* * * *When we installed the canopy and shirt we use semi-weld (Pro-seal) in * *caulking type tube that premixes it ( you'll need to use/borrow a * *specialized caulking type gun to use the tubed material. We used minimal alu * *pop rivets (mostly as keeper riviets). The semi-weld method is the same as * *used on the Christian Eagles and Pits (without any rivets). You can also * *paint the semi-weld after.* * * *Works and looks great and has some ability to flex (read deal with stress,* * * *Good Building,* * * *Chuck & Dave Rowbotham* *RV-8A (Nianitc, CT)* *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *MLWynn(at)aol.com *Sent:* Thursday, June 17, 2010 2:40 PM *To:* rv-list(at)matronics.com *Subject:* Re: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion Hey gents, I am at the same spot. Have been considering sikaflex (how I did the canopy) and 3M 5200. Where in the archives would I find this information? Regards, Michael Wynn RV 8 Finishing San Ramon, CA In a message dated 6/17/2010 10:54:35 A.M. Pacific Daylight Time, crowbotham(at)hotmail.com writes: Hi Robin, We used the same adhensive that Christian Eagle uses on our 8A. The complete details with product info are in the archives. The RV was hangered in CT and flown on a regular basis through out the year over nine years - No cracks and no change in the seal. Hope this helps - Keep at it - it's really worth the effort! Chuck & Dave Rowbotham RV-8A (Sold) RV-9A (Dave's building) ------------------------------ From: robin(at)PaintTheWeb.com Date: Thu, 17 Jun 2010 09:03:30 -0700 Subject: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion It is time for us to attach the skirt to the canopy frame where the plans call for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work? Thanks, Robin * * * * *p://www.matronics.com/Navigator?RV-List* *ronics.com* *ww.matronics.com/contribution* * * ------------------------------ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more.<http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1> * * * * *====================================* *="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List* *====================================* *ms.matronics.com/">http://forums.matronics.com* *====================================* *tp://www.matronics.com/contribution">http://www.matronics.com/contribution* *====================================* * * * * * * * * ________________________________________________________________________________
Date: Jun 18, 2010
Tom, Take a look at Kevin Horton=99s web site: www.kilohotel.com. Click on =9CFlight Test Links=9D in the column on the left, then on =9CTest Plans=9D. Plenty of sample plans to use. John Ciolino RV-8 N894Y From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent Sent: Thursday, June 17, 2010 7:40 PM Subject: RV-List: RV-6A/7A test plan I am starting to work on a test plan which the FAA wants you to have by the time you get an airworthiness certificate. Are there any samples of these of these available on the web anywhere? Does any one have one they would be willing to divulge? -- Tom Sargent, RV-6A. ________________________________________________________________________________
Subject: Re: RV-6A/7A test plan
Date: Jun 18, 2010
Give your local EAA Flight Advisor a call. Find Flight Advisor here http://members.eaa.org/home/lookup/FindFlightAdvisor.asp He can help you with the plan and first flight prep. Dale Ensing EAA FA & TC ----- Original Message ----- From: thomas sargent To: rv-list Sent: Thursday, June 17, 2010 7:40 PM Subject: RV-List: RV-6A/7A test plan I am starting to work on a test plan which the FAA wants you to have by the time you get an airworthiness certificate. Are there any samples of these of these available on the web anywhere? Does any one have one they would be willing to divulge? -- Tom Sargent, RV-6A. ________________________________________________________________________________
Date: Jun 18, 2010
From: Richard Martin <martinaerodrome(at)gmail.com>
robin, 10 years ago when I built my RV8, the adhesive process was started. I procrastinated for several weeks trying to decide which process to use ie rivets or adhesive. I used rivets because I did not understand or trust the adhesive process. That was a mistake. No matter how careful you are during the installation, after 100 hours cracks begin to appear from the rivet points. This forced me to stop drill the cracks. I have watched other installations with adhesive, and I don't see cracks. I noticed after flyinng 2000 hours on my RV8 that the canopy contracts and elongates substantially with weather changes, especially in winter and summer. I live in Wisconsin and it gets cold here in winter. I hope this experience helps you with your decission. I vote for the adhesive process. Dick Martin RV8 N233M the fast one On Thu, Jun 17, 2010 at 11:03 AM, Robin Marks wrote: > It is time for us to attach the skirt to the canopy frame where the plans > call for pop rivets. Is there a preferred or alternate choice to pop rivets > (we hope)? Something like epoxy that has been proven to work? > > > Thanks, > > Robin > > * > > > * > > ________________________________________________________________________________
Date: Jun 18, 2010
Thanks Dick, This morning we ordered two ordered two 2 oz. kits of Scotch weld from Spruce. $35 per kit, but I know it's good stuff, we have used it before. I was not going to use rivets. I remember what rivets did to my RV-4 canopy. Nothing will make you cry quicker than seeing your first crack in a perfectly clean canopy. Thanks, Robin *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *Richard Martin *Sent:* Friday, June 18, 2010 6:06 AM *To:* rv-list(at)matronics.com *Subject:* Re: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion robin, 10 years ago when I built my RV8, the adhesive process was started. I procrastinated for several weeks trying to decide which process to use ie rivets or adhesive. I used rivets because I did not understand or trust the adhesive process. That was a mistake. No matter how careful you are during the installation, after 100 hours cracks begin to appear from the rivet points. This forced me to stop drill the cracks. I have watched other installations with adhesive, and I don't see cracks. I noticed after flyinng 2000 hours on my RV8 that the canopy contracts and elongates substantially with weather changes, especially in winter and summer. I live in Wisconsin and it gets cold here in winter. I hope this experience helps you with your decission. I vote for the adhesive process. Dick Martin RV8 N233M the fast one On Thu, Jun 17, 2010 at 11:03 AM, Robin Marks wrote: It is time for us to attach the skirt to the canopy frame where the plans call for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work? Thanks, Robin * * * * *t="_blank">http://www.matronics.com/Navigator?RV-List* * * *ttp://forums.matronics.com* *_blank">http://www.matronics.com/contribution* * * * * * * * * ________________________________________________________________________________
Date: Jun 18, 2010
Subject: Stormy's Fly-In 6/26/10
As we reach one week from the festivities, I'd like a nose count for food planning purposes. Private e-mail to my gmail address would be fine. Thanks, everyone! Bill & MIriam Boyd 12VA ________________________________________________________________________________
Date: Jun 18, 2010
Over here in the plastic airplane world, the rule is to never drill holes in plexiglass. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Friday, June 18, 2010 1:09 PM Subject: RE: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion Thanks Dick, This morning we ordered two ordered two 2 oz. kits of Scotch weld from Spruce. $35 per kit, but I know it's good stuff, we have used it before. I was not going to use rivets. I remember what rivets did to my RV-4 canopy. Nothing will make you cry quicker than seeing your first crack in a perfectly clean canopy. Thanks, Robin From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard Martin Sent: Friday, June 18, 2010 6:06 AM Subject: Re: RV-List: Alternate way to Attach RV-8 Skirt to Canopy Frame Suggestion robin, 10 years ago when I built my RV8, the adhesive process was started. I procrastinated for several weeks trying to decide which process to use ie rivets or adhesive. I used rivets because I did not understand or trust the adhesive process. That was a mistake. No matter how careful you are during the installation, after 100 hours cracks begin to appear from the rivet points. This forced me to stop drill the cracks. I have watched other installations with adhesive, and I don't see cracks. I noticed after flyinng 2000 hours on my RV8 that the canopy contracts and elongates substantially with weather changes, especially in winter and summer. I live in Wisconsin and it gets cold here in winter. I hope this experience helps you with your decission. I vote for the adhesive process. Dick Martin RV8 N233M the fast one On Thu, Jun 17, 2010 at 11:03 AM, Robin Marks wrote: It is time for us to attach the skirt to the canopy frame where the plans call for pop rivets. Is there a preferred or alternate choice to pop rivets (we hope)? Something like epoxy that has been proven to work? Thanks, Robin t="_blank">http://www.matronics.com/Navigator?RV-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution Use the Matronics List Features Navigator to browse http://www.matronics.com/Navigator?RV -Li =====================< - MATRONICS WEB FORUMS -> m">http://forums.matronics.com -Matt Dralle, List A; ________________________________________________________________________________
Subject: RV8 Building Question
Date: Jun 18, 2010
Dear Listers, My thanks to those who contributed their expertise, experience, and just down to earth tips about how to start building a purchased project. In this case the building manual had missing pages. This list has highly qualified people who love to share their stories. I'm now launching this build in the middle of something I'm confident about. Many thanks fellow builders ... Jerry ________________________________________________________________________________
Date: Jun 20, 2010
Subject: RV-6 or RV-7 motor mount wanted
Anyone have a motor mount they'd like to sell? I need one for non-lyc project. Conical mount would be fine; no gear legs needed. Thanks, Charlie ________________________________________________________________________________
Date: Jun 20, 2010
Subject: Re: RV-6 or RV-7 motor mount wanted
Have an RV6A mount for sale. Not what you are looking for maybe, but might be adaptable. Very reasonable. Dick Seiders On Sun, Jun 20, 2010 at 3:18 PM, Charlie England wrote: > > Anyone have a motor mount they'd like to sell? I need one for non-lyc > project. Conical mount would be fine; no gear legs needed. > > Thanks, > > Charlie > > ________________________________________________________________________________
Date: Jun 20, 2010
Unfortunately, I need the taildragger version with the gear leg sockets in place. I'll keep it in mind if another project comes along, though. Thanks, Charlie On 6/20/2010 4:29 PM, richard seiders wrote: > Have an RV6A mount for sale. Not what you are looking for maybe, but > might be adaptable. Very reasonable. > Dick Seiders > > On Sun, Jun 20, 2010 at 3:18 PM, Charlie England > > wrote: > > > > > Anyone have a motor mount they'd like to sell? I need one for > non-lyc project. Conical mount would be fine; no gear legs needed. > > Thanks================== > owse, Chat, FAQ, > ="http://www.matronics.com/Navigator?RV-List" > target="_blank">http://ww== > http://forums.mle, List Admin. > ===== <http://forums.matronics.com/> > ________________________________________________________________________________
Date: Jun 20, 2010
Subject: Update On RV-8 Princeton Fuel Probe Installation...
Fellow RV'rs, I am elated to report that last week I decided to try recalibrating the Princeton fuel level probes in my RV-8 one last time before I began the arduous task of replacing them with resistive float senders. I started with the right tank and drained all of the fuel out, then entered calibration mode by applying power to the unit with the button pressed. I then pressed the button once to indicate the "empty" set point, then added exactly 5.5 Gallons, pressed the button, etc., etc., until I'd added 21 gallons. During the whole process, the various LED flashing patterns correctly matched the documented sequences based on the stage of calibration. With a full tank, I went out and flew a little over two hours at about 10 gallons per hour. During the flight, I carefully compared the Priceton readings with the turbine fuel flow "fuel used" indicator which has proven to be exceptionally accurate. As expected, the Pricetons reported "Full" for the first 6 gallons or so because of the dihedral in the wing tank and the fact that the probe is mounted at the root. Again, as expected, abruptly the fuel level went from 21 to 15 gallons after about 6 gallons of burn (or there abouts - sometimes both tanks seem to drop to around 18 then back up to 21 during this first 6 gallons). From 15 to about 2 gallons, the Priceton's reported a fuel level within 1 gallon of the flow meter's fuel used indicator! Yahoo. I then repeated the whole calibration procedure exactly as before but this time on the left tank and then went out and repeated the comparison tests above on the left tank. I am even happier to report that again the calibration of the left fuel level tracked the fuel flow meter's used amount within 1 gallon after the initial drop from 21 to 15 gallons after 6 gallons of burn. I flew to about 4-5 gallons remaining on the left and right sides tonight as reported by the fuel level meters and noted that the fuel flow meter's fuel remaining coincided with a reported remaining of 10.3 gallons. I topped off both tan! ks and n oted that both tanks then reported 21 gallons as expected. So why didn't the first and second calibration attempts take? Who knows. All that matters at this point is that they are both working and are exceptionally accurate in the 15-0 gallon range which is where it counts. Oh, and that I don't have to replace the probes! Yahoo. Best regards, Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor! ________________________________________________________________________________
Date: Jun 20, 2010
Subject: airworthiness inspection - random questions
I am going thru the "Sample checklist for a condition inspection" which is appendix I of the AC 90-89A. Some of the items have me puzzled. Checking some of these things just seems like an opportunity to disturb something that was done right the last time it was done. One of the items says to check the cylinder compression. This engine has 1.6 hours on it since rebuild (which admittedly was 10 years ago). The rebuilder checked the compression. Seems to run good. Do I really need to check the compression? Engine mount bolt torque. It's been a couple years, but I torqued torqued and safetied these very meticulously. I think these are best left alone. My PC-680 Odyssey battery is strapped down very securely (in cabin) but not in a battery box. I thought that an RG battery doesn't require an enclosing box - no liquid acid there to leak out. Is there any way to test the altimeter and airspeed when its in the plane? Isn't that what the first flight or high speed taxi is supposed to check? (I'm not going to do a high speed taxi, but my test pilot probably will.) -- Tom Sargent, RV-6A on collision course with DAR ________________________________________________________________________________
Date: Jun 20, 2010
Subject: RV-6A G-loads
One more airworthiness issue: I'm typing up the operating limitations document. My Van's construction manual specifies +6g, -3g limits for the 6A at aerobatic weight of 1385 lbs, but it never mentions G-load limits for a plane at nominal gross weight. I could scale these G loads down by dividing by the ratio of gross weight/1375, I guess. Is there a more official value for this? Thanks, -- Tom Sargent ________________________________________________________________________________
Date: Jun 20, 2010
Subject: Re: airworthiness inspection - random questions
I would recommend doing the compression test. It isn't that much work, and won't hurt anything. I agree with no need to mess with the engine mount bolts, as long as they have the appropriate threads showing. Your DAR may have a preference for cotter pins over safety wire...either done right is fine. There is no requirement for a battery box..just a secure mount for a sealed battery. Any place that does transponder and static system checks can verify your altimeter and pitot system. The altimeter system check is done on the airplane. Some shops prefer to calibrate altimeter on the bench, but it isn't required, especially if you are only getting VFR certification, which is all you can do in Phase I anyway. Airspeed calibrations to the airframe are what you and/or your test pilot do during phase I flights, to identify how the pitot and static port configuration on your airframe affect the indicated values. You can use FAR 43 Appendix D as a minimum check list for your initial condition inspection. How you accomplish each item within what is described is up to you. That list is the bare minimum for a certified plane's annual inspection, but is a good starting point for developing a list you want for your future condition inspections. Kelly A&P/IA RV-10 in progress On 6/20/2010 9:33 PM, thomas sargent wrote: > I am going thru the "Sample checklist for a condition inspection" > which is appendix I of the AC 90-89A. Some of the items have me > puzzled. Checking some of these things just seems like an opportunity > to disturb something that was done right the last time it was done. > > One of the items says to check the cylinder compression. This engine > has 1.6 hours on it since rebuild (which admittedly was 10 years ago). > The rebuilder checked the compression. Seems to run good. Do I > really need to check the compression? > > Engine mount bolt torque. It's been a couple years, but I torqued > torqued and safetied these very meticulously. I think these are best > left alone. > > My PC-680 Odyssey battery is strapped down very securely (in cabin) > but not in a battery box. I thought that an RG battery doesn't > require an enclosing box - no liquid acid there to leak out. > > Is there any way to test the altimeter and airspeed when its in the > plane? Isn't that what the first flight or high speed taxi is > supposed to check? (I'm not going to do a high speed taxi, but my test > pilot probably will.) > > -- > Tom Sargent, RV-6A on collision course with DAR > * > > > * ________________________________________________________________________________
Date: Jun 20, 2010
Subject: Re: RV-6A G-loads
Use what is official for certified planes in Part 23 for your normal category gross wt. Off the top of my head, 3.8 positive, somewhere around 1.5 negative. I'm pretty certain Van's designed for the normal Part 23 limits for their recommended gross wt. You may want to see what your empty wt comes in at before deciding whether you want to use the recommended gross or something a bit higher. On 6/20/2010 9:44 PM, thomas sargent wrote: > One more airworthiness issue: I'm typing up the operating limitations > document. My Van's construction manual specifies +6g, -3g limits for > the 6A at aerobatic weight of 1385 lbs, but it never mentions G-load > limits for a plane at nominal gross weight. I could scale these G > loads down by dividing by the ratio of gross weight/1375, I guess. > Is there a more official value for this? > > Thanks, > > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Subject: Handheld GPS during BFR/ IPC
Date: Jun 20, 2010
I am scheduled to take my bi- annual review and an IFR proficiency check. My evaluator is uncomfortable with my AnyWhere Map GPS in the cockpit. Handheld GPS are not allowed as primary navigation, but are allowed for supplemental situation awareness. Is there a FAR that says a GPS cannot be used during a BFR or IPC? Kim Nicholas RV 9 Sent from my iPhone On Jun 20, 2010, at 9:33 PM, thomas sargent wrote: > I am going thru the "Sample checklist for a condition inspection" > which is appendix I of the AC 90-89A. Some of the items have me > puzzled. Checking some of these things just seems like an > opportunity to disturb something that was done right the last time > it was done. > > One of the items says to check the cylinder compression. This > engine has 1.6 hours on it since rebuild (which admittedly was 10 > years ago). The rebuilder checked the compression. Seems to run > good. Do I really need to check the compression? > > Engine mount bolt torque. It's been a couple years, but I torqued > torqued and safetied these very meticulously. I think these are > best left alone. > > My PC-680 Odyssey battery is strapped down very securely (in cabin) > but not in a battery box. I thought that an RG battery doesn't > require an enclosing box - no liquid acid there to leak out. > > Is there any way to test the altimeter and airspeed when its in the > plane? Isn't that what the first flight or high speed taxi is > supposed to check? (I'm not going to do a high speed taxi, but my > test pilot probably will.) > > -- > Tom Sargent, RV-6A on collision course with DAR > > ________________________________________________________________________________
Date: Jun 20, 2010
If you can't find someone to check your static system with a full test setup, you can create a water manometer to test the pitot system and airspeed indicator. If you search the internet, I'm sure you can find a chart for inches of water to airspeed table. You can check the static system and pitot for leaks by connecting tubing from static port and tee'd to the pitot to a hand vacuum pump. (be sure to temporarily tape shut the drain port on pitot and a second static port if you have it, and then remove when test is done). Pump vacuum to 1000 ft indication above your current elevation and hold. Start timing. If you lose less than 100 ft in 1 min your system meets the requirements for being leak free. Don't just pump vacuum on static port as you can damage your airspeed indicator if it isn't at same pressure altitude as altimeter. On 6/20/2010 9:33 PM, thomas sargent wrote: > I am going thru the "Sample checklist for a condition inspection" > which is appendix I of the AC 90-89A. > > Is there any way to test the altimeter and airspeed when its in the > plane? Isn't that what the first flight or high speed taxi is > supposed to check? (I'm not going to do a high speed taxi, but my test > pilot probably will.) > > -- > Tom Sargent, RV-6A on collision course with DAR > * > > > * ________________________________________________________________________________
Date: Jun 21, 2010
Tom --- Now that you have done your ground runs, every bolt needs to be c hecked for torque. No the battery does not need a box. Yes, check the compr ession, you are an idiot if you don't.- If you have an injected engine an d you have not done pressure checks on the engine, see previous line. If yo ur torque wrench has not seen a cal lab in a year it needs to be put back i n the box until it sees one. I have yet to see a builder that send their to rque wrenches out for annual cal. rick- --- On Sun, 6/20/10, thomas sargent wrote: From: thomas sargent <sarg314(at)gmail.com> Subject: RV-List: airworthiness inspection - random questions Date: Sunday, June 20, 2010, 9:33 PM I am going thru the "Sample checklist for a condition inspection" which is appendix I of the AC 90-89A. -Some of the items have me puzzled. -Check ing some of these things just seems like an opportunity to disturb somethin g that was done right the last time it was done. One of the items says to check the cylinder compression. -This engine has 1.6 hours on it since rebuild (which admittedly was 10 years ago). -The rebuilder checked the compression. -Seems to run good. -Do I really nee d to check the compression? Engine mount bolt torque. -It's been a couple years, but I torqued torque d and safetied these very meticulously. -I think these are best left alon e. My PC-680 Odyssey battery is strapped down very securely (in cabin) but not in a battery box. -I thought that an RG battery doesn't require an enclo sing box - no liquid acid there to leak out. Is there any way to test the altimeter and airspeed when its in the plane? -Isn't that what the first flight or high speed taxi is supposed to check ? (I'm not going to do a high speed taxi, but my test pilot probably will.) -- Tom Sargent, RV-6A on collision course with DAR =0A=0A=0A ________________________________________________________________________________
Date: Jun 21, 2010
IMHO ...... thomas sargent wrote: > I am going thru the "Sample checklist for a condition inspection" > which is appendix I of the AC 90-89A. Some of the items have me > puzzled. Checking some of these things just seems like an opportunity > to disturb something that was done right the last time it was done. > > One of the items says to check the cylinder compression. This engine > has 1.6 hours on it since rebuild (which admittedly was 10 years ago). I take it that you bought the engine 10 years ago and are now just finishing your project? (Finally saw DAR comment at end) Why are you doing a conditional inspection now? I'm missing something here so my comments may not be accurate. If just using it as a checklist instead of a true conditional inspection ..... just look at the items. > The rebuilder checked the compression. Seems to run good. Do I > really need to check the compression? Most definitely yes. All kinds of things happen to degrade an engine and compression test .... especially after 10 years sitting and just after a major rebuild. The test isn't difficult and other than oil pressure is the only real indicator of the engines health. Sitting this long .... especially if the engine wasn't pickled ..... I'd be worried about rust on the cam and the cam followers .... this will destroy both if not cleaned up .... which means tearing the engine down. If it's in a really dry climate you might have dodged this bullet. My advice is to pull a cylinder just to make sure. Time invested here may save you big bucks in the near future and the parts are cheap. > Engine mount bolt torque. It's been a couple years, but I torqued > torqued and safetied these very meticulously. I think these are best > left alone. I would check it at the end of phase 1 if that's where we're at. > > My PC-680 Odyssey battery is strapped down very securely (in cabin) > but not in a battery box. I thought that an RG battery doesn't > require an enclosing box - no liquid acid there to leak out. This is true. > > Is there any way to test the altimeter and airspeed when its in the plane? Yes. It's called a manometer. Simple to make and use. Your EAA chapter might just have one ..... and the expertise to use it. > Isn't that what the first flight or high speed taxi is supposed to > check? (I'm not going to do a high speed taxi, but my test pilot > probably will.) It would be nice to know that they work and are close to being accurate before the airplane leaves the ground. There is no benefit from a high speed taxi test (IMHO) and just invites the opportunity for Murphy to stick his nose in it. Linn > > -- > Tom Sargent, RV-6A on collision course with DAR > * > > > * ________________________________________________________________________________
Date: Jun 21, 2010
Tom, you're making this too difficult. You don't care about the limits at Gross .... because you shouldn't be doing aerobatics that weight. Scaling doesn't work either because of the engineering math involved. My advice is to just don't go there. Linn thomas sargent wrote: > One more airworthiness issue: I'm typing up the operating limitations > document. My Van's construction manual specifies +6g, -3g limits for > the 6A at aerobatic weight of 1385 lbs, but it never mentions G-load > limits for a plane at nominal gross weight. I could scale these G > loads down by dividing by the ratio of gross weight/1375, I guess. > Is there a more official value for this? > > Thanks, > > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: Jun 21, 2010
Subject: Re: Handheld GPS during BFR/ IPC
Kim Nicholas wrote: > > I am scheduled to take my bi- annual review and an IFR proficiency > check. My evaluator is uncomfortable with my AnyWhere Map GPS in the > cockpit. Handheld GPS are not allowed as primary navigation, but are > allowed for supplemental situation awareness. Is there a FAR that > says a GPS cannot be used during a BFR or IPC? I don't know that answer. My examiner didn't care about my AWM. But just to make your guy comfortable, take out the AWM and use a chart and a compass. You might get a copy of the handbook that tells the examiner what you're required to demonstrate as part of the BFR. There's probably one for IPC, but I don't know for sure. That book (BFR) says one hour of ground and one hour of flight ..... and my guy won't accept any less time, even though he's my passenger a lot. He goes by the book! Linn > > Kim Nicholas > RV 9 > Sent from my iPhone > > On Jun 20, 2010, at 9:33 PM, thomas sargent > wrote: > >> I am going thru the "Sample checklist for a condition inspection" >> which is appendix I of the AC 90-89A. Some of the items have me >> puzzled. Checking some of these things just seems like an >> opportunity to disturb something that was done right the last time it >> was done. >> >> One of the items says to check the cylinder compression. This engine >> has 1.6 hours on it since rebuild (which admittedly was 10 years >> ago). The rebuilder checked the compression. Seems to run good. Do >> I really need to check the compression? >> >> Engine mount bolt torque. It's been a couple years, but I torqued >> torqued and safetied these very meticulously. I think these are best >> left alone. >> >> My PC-680 Odyssey battery is strapped down very securely (in cabin) >> but not in a battery box. I thought that an RG battery doesn't >> require an enclosing box - no liquid acid there to leak out. >> >> Is there any way to test the altimeter and airspeed when its in the >> plane? Isn't that what the first flight or high speed taxi is >> supposed to check? (I'm not going to do a high speed taxi, but my >> test pilot probably will.) >> >> -- >> Tom Sargent, RV-6A on collision course with DAR >> * >> >> >> * > * > > > * ________________________________________________________________________________
Date: Jun 21, 2010
Re cyl compression test, I think it is a must do. Every one I know wouldnt do an anual without it. I installed a 170 hr engine three yrs ago, replacing my 2280 hr 320, it ran ok, but #3 only tested 60 over 80. They were Superiors, and I had that cyl OH. The other 3 were in mid 70's. Charlie H ________________________________________________________________________________
Date: Jun 21, 2010
Guidance for both flight review and IPC are contained in the practical test standards booklet (PTS). You have to be prepared to demonstrate satisfactorily anything in the PTS for your highest rating. Most CFIs are going to look that you operate within safe parameters and that you never give them doubt about safe completion of the flight. Our EAA chapter has started offering a 3-4 hour ground school for BFR, that most local instructors accept in lieu of their personal time. Lengthy, yes. How many have kept up with all the reg changes since you got your certificate? How many attend any safety seminars? On-line courses with AOPA or FAA? On 6/21/2010 4:36 AM, Linn Walters wrote: > I don't know that answer. My examiner didn't care about my AWM. > But just to make your guy comfortable, take out the AWM and use a > chart and a compass. You might get a copy of the handbook that tells > the examiner what you're required to demonstrate as part of the BFR. > There's probably one for IPC, but I don't know for sure. > > That book (BFR) says one hour of ground and one hour of flight ..... > and my guy won't accept any less time, even though he's my passenger a > lot. He goes by the book! > Linn > * > * ________________________________________________________________________________
Subject: Rudder cable protection with interior fabric
Date: Jun 21, 2010
I am installing the interior fabric wall panels in my 6A. I am installing the side panels that are next to the pilot/passenger seats. How did you protect the rudder cables that will be under the fabric or did you run the material behind the rudder cables leaving them exposed? Don Mack | don(at)dmack.net | www.dmack.net ________________________________________________________________________________
Date: Jun 21, 2010
Subject: Re: Rudder cable protection with interior fabric
Don: I made 1/2" CPVC tubes for the cables to travel through on the outside of the sidewall upholstery - dresses it up neat and protects objects in the side pockets from being sawed by the cables. The tubes butt onto grommets in the U-channels by means of CPVC couplings. I don't have pics; sorry. Bill Boyd RV-6A On Mon, Jun 21, 2010 at 9:27 AM, Don Mack wrote: > > I am installing the interior fabric wall panels in my 6A. I am installing > the side panels that are next to the pilot/passenger seats. How did you > protect the rudder cables that will be under the fabric or did you run the > material behind the rudder cables leaving them exposed? > > > Don Mack | don(at)dmack.net | www.dmack.net > > ________________________________________________________________________________
Date: Jun 21, 2010
No, I'm not actually interested in pulling G's or even doing aerobatics at all. It just seems like the G-load figures at ma gross should be in the operating limitations. On Mon, Jun 21, 2010 at 4:29 AM, Linn Walters wrote: > Tom, you're making this too difficult. You don't care about the limits at > Gross .... because you shouldn't be doing aerobatics that weight. Scaling > doesn't work either because of the engineering math involved. My advice is > to just don't go there. > Linn > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 21, 2010
OK. I guess I might as well buy the compression test gauges. I'll need them at annual time anyway. I'll get my 2 torque wrenches calibrated too. I did once several years ago, but it needs to be done again. Thanks for all the feedback. -- Tom Sargent ________________________________________________________________________________
Date: Jun 21, 2010
thomas sargent wrote: > OK. I guess I might as well buy the compression test gauges. Harbor freight has them. But you might check your EAA chapter first. > I'll need them at annual time anyway. I'll get my 2 torque wrenches > calibrated too. I did once several years ago, but it needs to be done > again. If that's what you want to do. I'll admit to not getting mine calibrated. So flame me if y'all want to. I use the German method .... gootdentite. Linn > > > Thanks for all the feedback. > > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: Jun 21, 2010
Subject: Re: 406MHz ELTs
Listers- With the recent announcement that the FCC will discourage the sale of the older 121.5MHz ELTs this August, I would be interested in conversing with those of you who have done the switch from the ACK E-01 to the E-04 in a flying aircraft with panel mounted GPS. Thanks in advance. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) "Intelligence is displayed in two fundamental ways: understanding problems and solving problems." --G.E. Moore ________________________________________________________________________________
Date: Jun 22, 2010
Unfortunately, the E-04 from ACK is not yet available - ACK is stuck in certification red tape. -- Corey Crawford corey.crawford(at)gmail.com RV-7A - Denver, CO On Mon, Jun 21, 2010 at 8:37 PM, wrote: > Listers- > > With the recent announcement that the FCC will discourage the sale of the > older 121.5MHz ELTs this August, I would be interested in conversing > with those of you who have done the switch from the ACK E-01 to the E-04 in > a flying aircraft with panel mounted GPS. > > Thanks in advance. > > > N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) > "Intelligence is displayed in two fundamental ways: understanding problems > and solving problems." --G.E. Moore > > ** > > ________________________________________________________________________________
Subject: 406MHz ELTs
Date: Jun 22, 2010
This is discussed in http://eaa.org/news/2010/2010-06-21_conflicting.asp . My question is, does this mean that it is unlawful to broadcast in 121.5 by the ELT. If so, are all the new 406 elts also now illegal since they all from what I see broadcast on both 406 and 121.5? I could not find any that only use 406. Bill Greenley From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com Sent: Monday, June 21, 2010 10:38 PM Subject: Re: RV-List: 406MHz ELTs Listers- With the recent announcement that the FCC will discourage the sale of the older 121.5MHz ELTs this August, I would be interested in conversing with those of you who have done the switch from the ACK E-01 to the E-04 in a flying aircraft with panel mounted GPS. Thanks in advance. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) "Intelligence is displayed in two fundamental ways: understanding problems and solving problems." --G.E. Moore ________________________________________________________________________________
Date: Jun 22, 2010
"Discourage the sale," - yeah. From what I read, it's more like "ban the use of." The FAA is apparently OK with 121.5 ELT's remaining in use, but the FCC plans to cite you if you activate one for any reason. Typical big gov. On Mon, Jun 21, 2010 at 10:37 PM, wrote: > Listers- > > With the recent announcement that the FCC will discourage the sale of the > older 121.5MHz ELTs this August, I would be interested in conversing > with those of you who have done the switch from the ACK E-01 to the E-04 in > a flying aircraft with panel mounted GPS. > > Thanks in advance. > > > N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) > "Intelligence is displayed in two fundamental ways: understanding problems > and solving problems." --G.E. Moore > > * > > * > > ________________________________________________________________________________
Date: Jun 22, 2010
Dang. My new ELT for my RV-9A was just delivered last week. Boat anchor, "get a rope". Smitty ----- Original Message ----- From: Corey Crawford To: rv-list(at)matronics.com Sent: Tuesday, June 22, 2010 10:20 AM Subject: Re: RV-List: 406MHz ELTs Unfortunately, the E-04 from ACK is not yet available - ACK is stuck in certification red tape. -- Corey Crawford corey.crawford(at)gmail.com RV-7A - Denver, CO On Mon, Jun 21, 2010 at 8:37 PM, wrote: Listers- With the recent announcement that the FCC will discourage the sale of the older 121.5MHz ELTs this August, I would be interested in conversing with those of you who have done the switch from the ACK E-01 to the E-04 in a flying aircraft with panel mounted GPS. Thanks in advance. N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) "Intelligence is displayed in two fundamental ways: understanding problems and solving problems." --G.E. Moore ________________________________________________________________________________
Date: Jun 22, 2010
This is what the Aircraft Spruce catalog says about the ACK E-04 ELT:=0AUn dergoing certification testing, ACK is not accepting orders for the E-04 u ntil ELT certification process is complete.-ACK 406/121.5 MHz E-04 ELTAC K 406/121.5 MHz E-04 ELTACK 406/121.5 MHz E-04 ELT ________________________________________________________________________________
Date: Jun 22, 2010
Before taking any action=3B wait for more accurate news. The news clip we' re seeing says=2C 'FCC will discourage the sale' not=2C 'must replace.' Y ou might be one of the last buyers of the technology=2C as am I. The issue isn't about saving lifes=3B it's about rescue workers responding to false alarms..... Marty Heller RV-7=2C Wiring From: smitty(at)smittysrv.com Subject: Re: RV-List: 406MHz ELTs Date: Tue=2C 22 Jun 2010 11:46:00 -0500 Dang. My new ELT for my RV-9A was just delivered last week. Boat anchor=2C "get a rope". Smitty ----- Original Message ----- From: Corey Crawford Sent: Tuesday=2C June 22=2C 2010 10:20 AM Subject: Re: RV-List: 406MHz ELTs Unfortunately=2C the E-04 from ACK is not yet available - ACK is stuck in c ertification red tape. -- Corey Crawford corey.crawford(at)gmail.com RV-7A - Denver=2C CO On Mon=2C Jun 21=2C 2010 at 8:37 PM=2C wrote: Listers- With the recent announcement that the FCC will discourage the sale of the o lder 121.5MHz ELTs this August=2C I would be interested in conversing with those of you who have done the switch from the ACK E-01 to the E-04 in a fl ying aircraft with panel mounted GPS. Thanks in advance. N1GV (RV-6A Flying 944TTAE Silicon Valley=2C CA) "Intelligence is displayed in two fundamental ways: understanding problems and solving problems." --G.E. Moore href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.co m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H otmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid= PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Date: Jun 22, 2010
If you're involved in an emergency and a 121.5 MHz ELT goes off, the FCC would be hard pressed to fine you. As a ham operator, I can use ANY radio or other means necessary to protect life, limb or property in an EMERGENCY and that right should also be with every citizen.... FCC Regulations, Part 97 covers us hams: * 97.403 Safety of life and protection of property.- <http://www.arrl.org/part-97-amateur-radio#> No provision of these rules prevents the use by an amateur station of any means of radio communication at its disposal to provide essential communication needs in connection with the immediate safety of human life and immediate protection of property when normal communication systems are not available. Bill Boyd wrote: > "Discourage the sale," - yeah. From what I read, it's more like "ban > the use of." The FAA is apparently OK with 121.5 ELT's remaining in > use, but the FCC plans to cite you if you activate one for any reason. > > Typical big gov. > > On Mon, Jun 21, 2010 at 10:37 PM, > wrote: > > Listers- > > With the recent announcement that the FCC will discourage the sale > of the older 121.5MHz ELTs this August, I would be interested in > conversing with those of you who have done the switch from the ACK > E-01 to the E-04 in a flying aircraft with panel mounted GPS. > > Thanks in advance. > > > > N1GV (RV-6A Flying 944TTAE Silicon Valley, CA) > "Intelligence is displayed in two fundamental ways: understanding > problems and solving problems." --G.E. Moore > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * -- Scott http://corbenflyer.tripod.com/ Flying Corben Junior Ace - Building RV-4 Gotta Fly or Gonna Die ________________________________________________________________________________
Date: Jun 22, 2010
I still don't get it (and admittedly haven't done my homework)...how will going to the 406 MHz ELTs prevent false alarms? Scott http://corbenflyer.tripod.com/ Flying Corben Junior Ace - Building RV-4 Gotta Fly or Gonna Die Marty Helller wrote: > Before taking any action; wait for more accurate news. The news clip > we're seeing says, 'FCC will discourage the sale' not, 'must > replace.' You might be one of the last buyers of the technology, as > am I. > > The issue isn't about saving lifes; it's about rescue workers > responding to false alarms..... > > Marty Heller > RV-7, Wiring > > > > > > > ------------------------------------------------------------------------ ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: 320 vs 360 flywheel
Date: Jun 22, 2010
Hi all: Anyone know the answer to this question..the perimeter bolt holes (the inch holes just under the ring gear, not the prop bolt holes) on the 0-360 flywheel vs those on an 0-320is there any difference? In other words, if I lay an 0-320 flywheel on top of one for an 0-360 will the perimeter bolt holes all line up? Need to know if my Landoll steel ring for 0-360 will bolt onto 0-320 flywheel. Thanks for the help. Dean Psiropoulos RV-6A N197DM ________________________________________________________________________________
Date: Jun 23, 2010
Subject: Stormy's fly-in
Weather looks, well, possibly stormy. The heat wave is forecast to continue through Sunday, but there's a significant rain chance the next 3 days. A nice slow-moving squall line would help re-fill the river... it's a bit low at present but plenty warm. I've had a few affirmative RSVP's to this point; hopefully others are waiting to the last minute to chime in. I need to get the chicken order to the meat market tomorrow, so if you're planning to drop in for BBQ and fellowship (and hopefully tubing) - give me a heads-up so we have ample grub for all. It's on us - no need to bring any dishes. "Stormy" - earning the nickname for about 10 years now... Hop-Along Airstip identifier 12VA ________________________________________________________________________________
Date: Jun 26, 2010
Subject: Final call
Stormy's fly-in BBQ in western Virginia is on today. Lunch served at 12:00. We won't be tubing because the river is butt-draggin' low (no rain in weeks here) but will enjoy food and fellowship through the afternoon. Wx looks good. Come join us - we have extra food :-) No Unicomm this year - just come on in to 12VA--- www.airnav.com--- for navigational details. Land on "32" - the runway is the brown (usually green, but not this month) strip between the hayfields. See ya! Bill & Miriam Boyd ________________________________________________________________________________
Date: Jun 26, 2010
Subject: Two cooling questions
The airworthiness inspection my RV-6A will be next week, so first flight will be soon after that. I'm wondering about cooling the engine. The 2 main things that steal cooling air form the engine are the oil cooler and the take-off for the cabin heat. 1- I certainly don't need cabin heat in Arizona in June. If I block off the opening in the baffles that is plumbed to the heat muff, no air will circulate thru the heat muff. Is that OK? Will that stretch of exhaust pipe get too hot? Is that what most folks do in the summer? 2- I did the oil cooler installation on the baffles behind cylinder #4. I used the Stewart Warner 7 row oil cooler, so I expect it to be pretty effective; that is, I doubt it needs the full opening that it has. Will I do better to block off, say, 1/3 of that to start with, or should I leave it wide open and just see what happens on the first flight? -- Tom Sargent, RV-6A, ready for inspection. ________________________________________________________________________________
Date: Jun 27, 2010
I don't think you mentioned what engine and such you have but here is my situation. RV-6 with 0-360 carb and constant speed prop. I have my oil cooler mounted on the back of the baffle and two cabin heat muffs. My engine ran very hot initially so I tried just about everything to get the CHT temps down. The two things that did NOT add significant help were: blocking off the cabin heat, blocking off part of the oil cooler. I now have a door behind my oil cooler so I can block it as needed. I see vans has a new slider that goes between the oil cooler and the baffle and that looks real nice. I may adapt mine to that. The only reason however is the oil temps are usually very low so I use the door to try to get my oil temps up. It does not add significantly to the CHT problem. I finally got my CHT's to an acceptable level by adding louvers in the bottom of the cowl. I did everything that was suggested and all my baffles are very tight. My CHT's now run in the low 400's during initial take off and climb out. I climb out between 110 and 120 to keep them in the 410 - 420 range. Once in cruise, my CHT's run more about 375 or a bit lower. I wish it was all lower, but can't seem to get that to happen. I would entertain the idea of leaving things the way they are for first flight until you know what your temps look like. Plan a shallow climb as this is where the high temps would come into play if it was going to be a problem. You will soon know what is or isn't an issue. Double check the baffles are all sealing and that will show up after you fly as it leaves marks on the inside of the baffle. Also another area that creates a problem is at the air intake ramps if the air can go around them as in over the top and escape to the low pressure side. Good luck and I look forward to hearing of your first flight. Tim Bryan Frankston, Texas RV-6 (N616TB) 140 hours and counting ________________________________________ From: owner-rv-list-server(at)matronics.com [owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent [sarg314(at)gmail.com] Sent: Saturday, June 26, 2010 5:18 PM Subject: RV-List: Two cooling questions The airworthiness inspection my RV-6A will be next week, so first flight will be soon after that. I'm wondering about cooling the engine. The 2 main things that steal cooling air form the engine are the oil cooler and the take-off for the cabin heat. 1- I certainly don't need cabin heat in Arizona in June. If I block off the opening in the baffles that is plumbed to the heat muff, no air will circulate thru the heat muff. Is that OK? Will that stretch of exhaust pipe get too hot? Is that what most folks do in the summer? 2- I did the oil cooler installation on the baffles behind cylinder #4. I used the Stewart Warner 7 row oil cooler, so I expect it to be pretty effective; that is, I doubt it needs the full opening that it has. Will I do better to block off, say, 1/3 of that to start with, or should I leave it wide open and just see what happens on the first flight? -- Tom Sargent, RV-6A, ready for inspection. ________________________________________________________________________________
Date: Jun 27, 2010
Subject: DAR Inspection
OK my next problem. You folks have always come to my rescue in previous jams. I am sending this to several "lists" in hopes of getting some help. BTW there ares at least two other projects in our local area that will be in the same predicament. After three years of building and anticipating the sign-off of my Kit Built Zenith CH 701 I find that the DAR that I spoke with three years ago who did inspections in our area - Boise ID / Twin Falls ID - has hung up his hat and no longer does the airworthiness inspections. I looked - cursory glance - at the EAA list of inspectors and the closest three I could find were: Salt Lake City Utah area, Eastern Oregon and Montana - all some distance away. I have been told, but not checked, the FAA office in Boise does not do the inspection due to lack of time and also not the proper credentials. What to do, what to do - I should be ready in a matter of weeks. Any ideas of DAR volunteers that would like to make a nice trip to sunny southern Idaho, would offer the possibility of great home cooked meals, lodging, golf, trout fishing just about anything to get this done expeditiously. Your thoughts please, drop an email or give me a call. Phil Smith 1795 River Rd Buhl, ID 83316 208 543 9270 madriver(at)wildblue.com ________________________________________________________________________________
Date: Jun 27, 2010
Subject: Re: DAR Inspection
Check with the FAA in Boise .... they'll know all the DARs nearby. You should contact the FSDO yourself ...... go there in person ..... may have to make an appointment ..... but YOU should get the word from the horses mouth. If they refuse to inspect your airplane, then you have two choices .... use the DAR they recommend ..... or write the office of your local congressman and explain your plight. The last thing the FAA wants is heat from above. The FAA is tasked with the job of inspecting homebuilts .... but they've subbed the responsibility to DARs which doesn't entirely let them off the hook. We've had two people recently get their planes inspected ..... one was put off (we're too busy, contact this DAR) but they finally came over. He made a stink (and wasted a lot of time) to get his Sonex inspected but they finally came over. The inspection was a real nit-pick, and the second trip got his certificate. Last wed, after a 2 week delay, the FSDO inspected an RV-7 in a half hour, and issued a certificate. So, you may have to wait 'till the 'schedule' opens up (or apply pressure) or get a local DAR. But, first I'd do a face-to-face with the FSDO people. In the case of the -7 above, the FSDO asked for some paperwork to be on file prior to the inspection. I'll ask what they were if you need me to. Linn PS I was born in Boise. Left when I was a toddler. philip smith wrote: > OK my next problem. > > You folks have always come to my rescue in previous jams. I am sending > this to several "lists" in hopes of getting some help. BTW there ares > at least two other projects in our local area that will be in the same > predicament. > > After three years of building and anticipating the sign-off of my Kit > Built Zenith CH 701 I find that the DAR that I spoke with three years > ago who did inspections in our area - Boise ID / Twin Falls ID - has > hung up his hat and no longer does the airworthiness inspections. > > I looked - cursory glance - at the EAA list of inspectors and the > closest three I could find were: Salt Lake City Utah area, Eastern > Oregon and Montana - all some distance away. > > I have been told, but not checked, the FAA office in Boise does not do > the inspection due to lack of time and also not the proper credentials. > > What to do, what to do - I should be ready in a matter of weeks. Any > ideas of DAR volunteers that would like to make a nice trip to sunny > southern Idaho, would offer the possibility of great home cooked > meals, lodging, golf, trout fishing just about anything to get this > done expeditiously. > > Your thoughts please, drop an email or give me a call. > > Phil Smith > 1795 River Rd > Buhl, ID 83316 > > 208 543 9270 > > madriver(at)wildblue.com > * > > > * ________________________________________________________________________________
Date: Jun 27, 2010
Phil=2C Go talk to the FSDO there in Boise. Time permitting they will do the inspe ction. I know the guys there (I helped train the assistant manager in Amat eur-Builts=2C and he is building an RV-4) and they love to inspect them=2C but this time of year is very hard on us inspectors with all the inspection s we have to do. For example=2C I have been on the road 3 of the last 4 we eks doing inspections. If they can't get to you in a time-frame you want I have a couple of recommendations. One is Mike Dehate=2C in Prineville=2C O R=2C and the other is Tom Willis=2C in Sandpoint=2C ID. Tom has a Bonanza and just looks for an excuse to fly it somewhere. Hopefully this info will help. Mike Robertson Das Fed Date: Sun=2C 27 Jun 2010 09:15:39 -0600 Subject: RV-List: DAR Inspection From: madriver(at)wildblue.net @matronics.com OK my next problem. You folks have always come to my rescue in previous jams. I am sending this to several "lists" in hopes of getting some help. BTW there ares at least two other projects in our local area that will be in the same predicament. After three years of building and anticipating the sign-off of my Kit Built Zenith CH 701 I find that the DAR that I spoke with three years ago who di d inspections in our area - Boise ID / Twin Falls ID - has hung up his hat and no longer does the airworthiness inspections. I looked - cursory glance - at the EAA list of inspectors and the closest t hree I could find were: Salt Lake City Utah area=2C Eastern Oregon and Mont ana - all some distance away. I have been told=2C but not checked=2C the FAA office in Boise does not do the inspection due to lack of time and also not the proper credentials. What to do=2C what to do - I should be ready in a matter of weeks. Any idea s of DAR volunteers that would like to make a nice trip to sunny southern I daho=2C would offer the possibility of great home cooked meals=2C lodging =2C golf=2C trout fishing just about anything to get this done expeditiousl y. Your thoughts please=2C drop an email or give me a call. Phil Smith 1795 River Rd Buhl=2C ID 83316 208 543 9270 madriver(at)wildblue.com _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jun 27, 2010
Are you talking about Russ Graves? ----- Original Message Mark Rose Jerome----- From: philip smith To: RV-List(at)matronics.com ; RotaxEngines-List(at)matronics.com ; zenith-list(at)matronics.com Sent: Sunday, June 27, 2010 8:15 AM Subject: RV-List: DAR Inspection OK my next problem. You folks have always come to my rescue in previous jams. I am sending this to several "lists" in hopes of getting some help. BTW there ares at least two other projects in our local area that will be in the same predicament. After three years of building and anticipating the sign-off of my Kit Built Zenith CH 701 I find that the DAR that I spoke with three years ago who did inspections in our area - Boise ID / Twin Falls ID - has hung up his hat and no longer does the airworthiness inspections. I looked - cursory glance - at the EAA list of inspectors and the closest three I could find were: Salt Lake City Utah area, Eastern Oregon and Montana - all some distance away. I have been told, but not checked, the FAA office in Boise does not do the inspection due to lack of time and also not the proper credentials. What to do, what to do - I should be ready in a matter of weeks. Any ideas of DAR volunteers that would like to make a nice trip to sunny southern Idaho, would offer the possibility of great home cooked meals, lodging, golf, trout fishing just about anything to get this done expeditiously. Your thoughts please, drop an email or give me a call. Phil Smith 1795 River Rd Buhl, ID 83316 208 543 9270 madriver(at)wildblue.com ________________________________________________________________________________
Date: Jun 27, 2010
Tom had the hangar beside me at 8A7 while he was in NC. Good guy. __ Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Jun 27, 2010 12:46 PM, "Mike Robertson" wrote: Phil, Go talk to the FSDO there in Boise. Time permitting they will do the inspection. I know the guys there (I helped train the assistant manager in Amateur-Builts, and he is building an RV-4) and they love to inspect them, but this time of year is very hard on us inspectors with all the inspections we have to do. For example, I have been on the road 3 of the last 4 weeks doing inspections. If they can't get to you in a time-frame you want I have a couple of recommendations. One is Mike Dehate, in Prineville, OR, and the other is Tom Willis, in Sandpoint, ID. Tom has a Bonanza and just looks for an excuse to fly it somewhere. Hopefully this info will help. Mike Robertson Das Fed ------------------------------ Date: Sun, 27 Jun 2010 09:15:39 -0600 Subject: RV-List: DAR Inspection From: madriver(at)wildblue.net zenith-list(at)matronics.com OK my next problem. You folks have always come to my rescue in previous jams. I am sending this... *http://www.matronics.com/Navigator?R========= * ------------------------------ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. See how.<http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_2> ________________________________________________________________________________
Date: Jun 27, 2010
Subject: Re: Zenith-List: DAR Inspection
talk to you buds at the local EAA chapter, theyll know. Juan -----Original Message----- >From: philip smith <madriver(at)wildblue.net> >Sent: Jun 27, 2010 11:15 AM >To: RV-List(at)matronics.com, RotaxEngines-List(at)matronics.com, zenith-list(at)matronics.com >Subject: Zenith-List: DAR Inspection > >OK my next problem. > >You folks have always come to my rescue in previous jams. I am sending this >to several "lists" in hopes of getting some help. BTW there ares at least >two other projects in our local area that will be in the same predicament. > >After three years of building and anticipating the sign-off of my Kit Built >Zenith CH 701 I find that the DAR that I spoke with three years ago who did >inspections in our area - Boise ID / Twin Falls ID - has hung up his hat and >no longer does the airworthiness inspections. > >I looked - cursory glance - at the EAA list of inspectors and the closest >three I could find were: Salt Lake City Utah area, Eastern Oregon and >Montana - all some distance away. > >I have been told, but not checked, the FAA office in Boise does not do the >inspection due to lack of time and also not the proper credentials. > >What to do, what to do - I should be ready in a matter of weeks. Any ideas >of DAR volunteers that would like to make a nice trip to sunny southern >Idaho, would offer the possibility of great home cooked meals, lodging, >golf, trout fishing just about anything to get this done expeditiously. > >Your thoughts please, drop an email or give me a call. > >Phil Smith >1795 River Rd >Buhl, ID 83316 > >208 543 9270 > >madriver(at)wildblue.com ________________________________________________________________________________
Date: Jun 27, 2010
Subject: Re: Two cooling questions
TOM: RE YOUR "ANTICIPATED" COOLING PROBLEMS - FLY THE AIRPLANE FIRST AND FIND OUT IF YOU EVEN HAVE A PROBLEM. YOU'RE PROBABLY GOING TO FIND NO PROBLEM AT ALL. LIKE MOST RV BUILDERS - I HAVE TWO OPENINGS CUT INTO MY REAR BAFFLES - ONE FEEDS AIR INTO THE OIL COOLER PLENUM, AND THE OTHER INTO A HEAT MUFF ON ONE EXHAUST PIPE, FROM WHERE IT FEEDS INTO A SECOND MUFF, THEN TO THE HEAT CONTROL UNIT ON THE FIREWALL. I HAVE A SLIDING GATE VALVE, MOUNTED BEHIND THE BAFFLE, WHICH CONTROLS AIR FLOW INTO THE OIL COOLER PLENUM VIA A PUSH/PULL CABLE. ON HOT SUMMER DAYS THAT VALVE IS ALWAYS WIDE OPEN - TYPICALLY MY SUMMER OIL TEMP RUNS IN THE HIGH 170S - IN WINTER OF COURSE I CLOSE THE VALVE DOWN AS NECESSARY TO KEEP THE OIL TEMPS WHERE THEY NEED BE. REMEMBER THAT ENGINE OIL PLAYS A BIG ROLE IN KEEPING YOUR ENGINE COOL AND HAPPY. I'D LEAVE THAT OIL COOLER DOOR WIDE OPEN UNTIL YOU SEE WHAT'S WHAT. THE OTHER OPENING, WHICH FEEDS AIR INTO THE HEAT MUFFS IS ALWAYS GOING TO BE OPEN - IN THE SENSE THAT THE HEAT CONTROL BOX ON THE FIREWALL IS EITHER DIRECTING WARM AIR INTO THE CABIN, OR IT'S DUMPING IT OVERBOARD. IN A CLIMB ON A HOT DAY YOU CAN REDUCE THE CLIMB ANGLE TO KEEP YOUR CLIMB SPEEDS ABOVE 100 KTS. HECK - WITH FULL POWER AT 120 KTS YOU'RE STILL CLIMBING AT APPROX 900' A MINUTE. YOU CAN REDUCE THE CLIMB ANGLE EVEN FURTHER AND CLIMB AT PARTIAL POWER YOU CAN ALSO STEP CLIMB IF NECESSARY TO KEEP YOUR CYL HEAD TEMPS BELOW 400. I RECENTLY FINISHED A BOOK, "FLY THE ENGINE" BY KAS THOMAS. HE STATES SOMEWHERE IN THERE, AND I'M PARAPHRASING: "COOL TEMPS ARE THE WHOLE STORY IN EXTENDING ENGINE LIFE," AND "KEEP CYLINDERS HEALTHY BY KEEPING THEM COOL." HE RECOMMEND KEEPING CHTS BELOW 380 AT ALL TIMES. GOOD LUCK AND FLY SAFE. DAN BERGERON RV-7A - N307TB 154 HOURS SINCE FIRST FLIGHT ON 08/04/09 On Sun, Jun 27, 2010 at 9:07 AM, N616TB wrote: > > > I don't think you mentioned what engine and such you have but here is my > situation. > > RV-6 with 0-360 carb and constant speed prop. > > I have my oil cooler mounted on the back of the baffle and two cabin heat > muffs. > My engine ran very hot initially so I tried just about everything to get > the CHT temps down. > > The two things that did NOT add significant help were: blocking off the > cabin heat, blocking off part of the oil cooler. > > I now have a door behind my oil cooler so I can block it as needed. I see > vans has a new slider that goes between the oil cooler and the baffle and > that looks real nice. I may adapt mine to that. The only reason however is > the oil temps are usually very low so I use the door to try to get my oil > temps up. It does not add significantly to the CHT problem. > > I finally got my CHT's to an acceptable level by adding louvers in the > bottom of the cowl. I did everything that was suggested and all my baffles > are very tight. > > My CHT's now run in the low 400's during initial take off and climb out. I > climb out between 110 and 120 to keep them in the 410 - 420 range. Once in > cruise, my CHT's run more about 375 or a bit lower. I wish it was all > lower, but can't seem to get that to happen. > > I would entertain the idea of leaving things the way they are for first > flight until you know what your temps look like. Plan a shallow climb as > this is where the high temps would come into play if it was going to be a > problem. You will soon know what is or isn't an issue. Double check the > baffles are all sealing and that will show up after you fly as it leaves > marks on the inside of the baffle. Also another area that creates a problem > is at the air intake ramps if the air can go around them as in over the top > and escape to the low pressure side. > > Good luck and I look forward to hearing of your first flight. > Tim Bryan > Frankston, Texas > RV-6 (N616TB) > 140 hours and counting > ________________________________________ > From: owner-rv-list-server(at)matronics.com [ > owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent [ > sarg314(at)gmail.com] > Sent: Saturday, June 26, 2010 5:18 PM > To: rv-list > Subject: RV-List: Two cooling questions > > The airworthiness inspection my RV-6A will be next week, so first flight > will be soon after that. I'm wondering about cooling the engine. The 2 > main things that steal cooling air form the engine are the oil cooler and > the take-off for the cabin heat. > > 1- I certainly don't need cabin heat in Arizona in June. If I block off > the opening in the baffles that is plumbed to the heat muff, no air will > circulate thru the heat muff. Is that OK? Will that stretch of exhaust > pipe get too hot? Is that what most folks do in the summer? > > 2- I did the oil cooler installation on the baffles behind cylinder #4. I > used the Stewart Warner 7 row oil cooler, so I expect it to be pretty > effective; that is, I doubt it needs the full opening that it has. Will I > do better to block off, say, 1/3 of that to start with, or should I leave it > wide open and just see what happens on the first flight? > > -- > Tom Sargent, RV-6A, ready for inspection. > > ________________________________________________________________________________
Date: Jun 27, 2010
Subject: New Tires - Highest Quality...?
Its almost time for a new set of tires on the 'ol RV-8. What are the very best tires for the RV wheels? I'd like something that will last a little longer than 70 hours. Thanks in advance for the feedback... Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor... ________________________________________________________________________________
Date: Jun 27, 2010
Subject: Re: New Tires - Highest Quality...?
I like the Michelins. I've replaced them once in 4 years of flying, bouncing & taxiing. Probably 200 hours of flying. Swapped them on the rims about half way thru their life and will probably replace these some time this winter. On Sun, Jun 27, 2010 at 8:58 PM, Matt Dralle wrote: > > > Its almost time for a new set of tires on the 'ol RV-8. What are the very > best tires for the RV wheels? I'd like something that will last a little > longer than 70 hours. > > Thanks in advance for the feedback... > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Enjoying The Fruits of 2500 Hours of Labor... > > ________________________________________________________________________________
Date: Jun 28, 2010
By far the best tires (longest lasting) have been the Wilkerson Retreads. http://www.wilkersonaircrafttires.com/ http://www.wilkersonaircrafttires.com/range.html Last ones were $50 US Each delivered. 2nd place is Goodyear. 3rd is the Michelin. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C381+ Flying Hours So. CA=2C USA > Date: Sun=2C 27 Jun 2010 20:58:35 -0700 > To: rv-list(at)matronics.com=3B rv7-list(at)matronics.com=3B rv8-list@matronics .com > From: dralle(at)matronics.com > Subject: RV-List: New Tires - Highest Quality...? > > > > Its almost time for a new set of tires on the 'ol RV-8. What are the ver y best tires for the RV wheels? I'd like something that will last a little longer than 70 hours. > > Thanks in advance for the feedback... > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Enjoying The Fruits of 2500 Hours of Labor... > > =========== =========== =========== =========== > > > _________________________________________________________________ The New Busy is not the too busy. Combine all your e-mail accounts with Hot mail. http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4 ________________________________________________________________________________
Date: Jun 28, 2010
Subject: Strobe Light
I'm building an RV-12 without recognition/landing lights because=C2- 1) I don't plan on flying at night, and 2) I'm trying to make this bird as light as possible. My question is about strobe lights - is that a requir ement? Walt Shipley ________________________________________________________________________________
Date: Jun 28, 2010
It has been the accepted wisdom that if the heat muff is on the pipe, then air should be flowing through it to keep it from overheating. I never tested that, but I would just take the heat muff off if I wasn=99t running air through it. I think this is why all heat selector valves are two way rather than just on-off. I would just leave the cooler as isyour vernatherm should keep the oil from being too cold, you can go for drag reduction later. John From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent Sent: Saturday, June 26, 2010 4:18 PM Subject: RV-List: Two cooling questions The airworthiness inspection my RV-6A will be next week, so first flight will be soon after that. I'm wondering about cooling the engine. The 2 main things that steal cooling air form the engine are the oil cooler and the take-off for the cabin heat. 1- I certainly don't need cabin heat in Arizona in June. If I block off the opening in the baffles that is plumbed to the heat muff, no air will circulate thru the heat muff. Is that OK? Will that stretch of exhaust pipe get too hot? Is that what most folks do in the summer? 2- I did the oil cooler installation on the baffles behind cylinder #4. I used the Stewart Warner 7 row oil cooler, so I expect it to be pretty effective; that is, I doubt it needs the full opening that it has. Will I do better to block off, say, 1/3 of that to start with, or should I leave it wide open and just see what happens on the first flight? -- Tom Sargent, RV-6A, ready for inspection. ________________________________________________________________________________
Date: Jun 28, 2010
For the west coast I would consider Desser retreads as well. (standard retread, not their Monster Retread). On 6/28/2010 4:15 AM, RV6 Flyer wrote: > By far the best tires (longest lasting) have been the Wilkerson Retreads. > > http://www.wilkersonaircrafttires.com/ > http://www.wilkersonaircrafttires.com/range.html > Last ones were $50 US Each delivered. > > 2nd place is Goodyear. > > 3rd is the Michelin. > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 2,381+ Flying Hours So. CA, USA > > > > Date: Sun, 27 Jun 2010 20:58:35 -0700 > > To: rv-list(at)matronics.com; rv7-list(at)matronics.com; > rv8-list(at)matronics.com > > From: dralle(at)matronics.com > > Subject: RV-List: New Tires - Highest Quality...? > > > > > > > > Its almost time for a new set of tires on the 'ol RV-8. What are the > very best tires for the RV wheels? I'd like something that will last a > little longer than 70 hours. > > > > Thanks in advance for the feedback... > > > > > > Matt Dralle > > RV-8 #82880 N998RV > > http://www.mattsrv8.com - Matt's RV-8 Construction Log > > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > > Status: Enjoying The Fruits of 2500 Hours of Labor... > >========== > > > > > > > > ------------------------------------------------------------------------ > The New Busy is not the too busy. Combine all your e-mail accounts > with Hotmail. Get busy. > <http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4> > > * > > > * ________________________________________________________________________________
Date: Jun 28, 2010
Walt=2C No=2C a strobe is not required unless Van's states it is in their builder's manual (if you are building the ELSAQ kit). In the case of the RV-12 I th ink Van's calls it optional equipment=2C but I'm not totally sure. Mike Robertson Date: Mon=2C 28 Jun 2010 12:44:16 +0000 From: rveighta(at)comcast.net Subject: RV-List: Strobe Light I'm building an RV-12 without recognition/landing lights because 1) I don' t plan on flying at night=2C and 2) I'm trying to make this bird as light as possible. My question is about strobe lights - is that a requir ement? Walt Shipley 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Date: Jun 28, 2010
Walt, While you might not plan on doing any night flying, look a little farther into the future. When you might want to sell your baby. Most pilots fly at night, any airplane not equipped with nav/landing/strobe lights would place it at the bottom of a buyers list. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Sent: Monday, June 28, 2010 11:41 AM Subject: RE: RV-List: Strobe Light Walt, No, a strobe is not required unless Van's states it is in their builder's manual (if you are building the ELSAQ kit). In the case of the RV-12 I think Van's calls it optional equipment, but I'm not totally sure. Mike Robertson _____ Date: Mon, 28 Jun 2010 12:44:16 +0000 From: rveighta(at)comcast.net Subject: RV-List: Strobe Light I'm building an RV-12 without recognition/landing lights because 1) I don't plan on flying at night, and 2) I'm trying to make this bird as light as possible. My question is about strobe lights - is that a requirement? Walt Shipley 3D======================= 3D==================== 3D======================= 3D==================== 3D======================= 3D==================== 3D======================= 3D==================== _____ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. <http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL :ON:WL:en-US:WM_HMP:042010_1> ________________________________________________________________________________
Date: Jun 28, 2010
Subject: Odd running cylinder
Configuration reminder: RV6A SamJames cowl/plenum AeroSportPower built XP IO360B1F6 9.2:1 pistons AFP injection (Flow balanced to .1gph per AFP instructions) LASAR ignition (MAP monitor on #4, CHT monitor on #3) Vetterman Dual crossover exhaust with heater/mufflers MT three blade MTV12B183-59 propellor During the first few minutes of operation (essentially through climb-out and throttle-back), my number one cylinder indicates a higher CHT and EGT. Neither the CHT or EGT raise to a dangerous level and both return to normal upon establishing cruise settings. My number one cylinder also has an injector restrictor that is 5% larger than the other three in order to balance fuel flow for leaning purposes. This has occurred seven out of the last eight flights. The missing one is kinda in the middle. Data capture is through an AFS3400EM at 1 second intervals. I have data and graphs if someone wants to look-see. I am wondering if I might have something in the fuel injection distribution spider that is partially blocking one line below a certain flow rate. Any other thoughts, Ralph RV6A N822AR @ N06 70 hours ________________________________________________________________________________
Date: Jun 28, 2010
Matt, After my original el cheapo tires wore out in about 70 hours, I tried Goodyear Flight Custom III's (from Desser Tire) and got about 465 hours on the first set. I make lots of short flights so probably average two or tree landings per hour, all on pavement ( and very few of them smooth). I'm on the second set now and I really like 'em (except for the price!) Harry Crosby RV-6 N16CX, 704 hours ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Sunday, June 27, 2010 8:58:35 PM Subject: RV-List: New Tires - Highest Quality...? Its almost time for a new set of tires on the 'ol RV-8. What are the very best tires for the RV wheels? I'd like something that will last a little longer than 70 hours. Thanks in advance for the feedback... Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor... ________________________________________________________________________________
Date: Jun 28, 2010
On Mon, 28 Jun 2010, Bruce Gray wrote: > Walt, > > While you might not plan on doing any night flying, look a little > farther into the future. When you might want to sell your baby. Most > pilots fly at night, any airplane not equipped with nav/landing/strobe > lights would place it at the bottom of a buyers list. > As a contrary viewpoint, build the plane you want, not what you think someone else might want. I don't fly at night or in bad weather, so I'm going no lights, no gyros. Save a few pounds and few hundred dollars. I'm not building to sell, I'm building this plane for me. Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 fitting wings 1/4 Starduster II N23UT flying ________________________________________________________________________________
Date: Jun 28, 2010
Which ever tire you buy, do not under any circumstances get the Dresser bra nd no-leak inner tube. Spend the few bucks more to get a name brand. I had two-flat tires on landings that-were the result of- the very-low- quality-of-the tubes.--The first-flat (right side)-was due to " checking" or rotting of the side wall of the tube-and the 2nd (left side) -was due to a seam letting go. The second tube also exhibited checking / rotting.- I sent the second tube back to Dresser and-let them know I wa s not happy with the quality of their tubes. I asked them for 2 new tubes a nd tires and to pay for the repair of the wheel pants. They credited my car d for the cost of the tubes only. =0A=0ABackground;- I bought 2-tires a nd Dresser no-leak-tubes and installed them at the same time during the D ec 07 annual.- The first flat occured- late 09 and the second about a m onth ago. Between the Dec 07 annual and now I dont think there has been mor e than 30 landings on the tires.-7WT is hangared. --=0A=0AReuven- ---=0A-Enjoy life now=0AIt has an expiration date. =0A=0A=0A=0A=0A_ _______________________________=0AFrom: Linn Walters <pitts_pilot@bellsouth .net>=0ATo: rv-list(at)matronics.com=0ASent: Mon, June 28, 2010 8:33:26 AM=0AS ubject: Re: RV-List: New Tires - Highest Quality...?=0A=0A--> RV-List messa ge posted by: Linn Walters =0A=0AI've been using retreads for a lot of years with zero problems.- The retreads seem to la st a lot longer than first-run tires.- Kinda like the lifespan of origina l car tires Vs. replacements Vs. retreads.- The Monster retreads will las t a lot longer, but for the recreational pilot .... well, they'll dry-rot b efore you get to use up all the tread .... and they're heavy.=0A=0ALinn=0Ad lly McMullen =0A> =0A> For the west coast I would cons ider Desser retreads as well. (standard retread, not their Monster Retread) .=0A> =0A> =0A> On 6/28/2010 4:15 AM, RV6 Flyer wrote:=0A>> By far the best tires (longest lasting) have been the Wilkerson Retreads.=0A>> =0A>> http: //www.wilkersonaircrafttires.com/=0A>> http://www.wilkersonaircrafttires.co m/range.html=0A>> Last ones were $50 US Each delivered.=0A>> =0A>> 2nd plac e is Goodyear.=0A>> =0A>> 3rd is the Michelin.=0A>> =0A>> Gary A. Sobek=0A> > "My Sanity" RV-6 N157GS O-320 Hartzell,=0A>> 2,381+ Flying Hours So. CA, USA=0A>> =0A>> =0A>> =0A>> > Date: Sun, 27 Jun 2010 20:58:35 -0700=0A>> > T o: rv-list(at)matronics.com; rv7-list(at)matronics.com; rv8-list(at)matronics.com=0A >> > From: dralle(at)matronics.com=0A>> > Subject: RV-List: New Tires - Highes lle(at)matronics.com>=0A>> >=0A>> >=0A>> > Its almost time for a new set of ti res on the 'ol RV-8. What are the very best tires for the RV wheels? I'd li ke something that will last a little longer than 70 hours.=0A>> >=0A>> > Th anks in advance for the feedback...=0A>> >=0A>> >=0A>> > Matt Dralle=0A>> > RV-8 #82880 N998RV=0A>> > http://www.mattsrv8.com - Matt's RV-8 Constructi on Log=0A>> > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Ch annel=0A>> > Status: Enjoying The Fruits of 2500 Hours of Labor...=0A>> > ============0A>> >=0A>> >=0A>> >=0A>> =0A>> --------- ---------------------------------------------------------------=0A>> The Ne w Busy is not the too busy. Combine all your e-mail accounts with Hotmail. Get busy. <http://www.windowslive.com/campaign/thenewbusy?tile=multiaccou nt&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4> =0A>> *=0A>> =0A ======================== ________________________________________________________________________________
Date: Jun 28, 2010
Subject: Re: Odd running cylinder
souunds like an intake leak rick --- On Mon, 6/28/10, Ralph E. Capen wrote: > From: Ralph E. Capen <recapen(at)earthlink.net> > Subject: RV-List: Odd running cylinder > To: "rv-list" > Date: Monday, June 28, 2010, 9:12 AM > "Ralph E. Capen" > > Configuration reminder: > RV6A > SamJames cowl/plenum > AeroSportPower built XP IO360B1F6 > 9.2:1 pistons > AFP injection (Flow balanced to .1gph per AFP > instructions) > LASAR ignition (MAP monitor on #4, CHT monitor on #3) > Vetterman Dual crossover exhaust with heater/mufflers > MT three blade MTV12B183-59 propellor > > During the first few minutes of operation (essentially > through climb-out and throttle-back), my number one cylinder > indicates a higher CHT and EGT. > Neither the CHT or EGT raise to a dangerous level and both > return to normal upon establishing cruise settings. > My number one cylinder also has an injector restrictor that > is 5% larger than the other three in order to balance fuel > flow for leaning purposes. > > This has occurred seven out of the last eight > flights. The missing one is kinda in the middle. > > Data capture is through an AFS3400EM at 1 second > intervals. I have data and graphs if someone wants to > look-see. > > I am wondering if I might have something in the fuel > injection distribution spider that is partially blocking one > line below a certain flow rate. > > Any other thoughts, > Ralph > RV6A N822AR @ N06 70 hours > > > > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jun 28, 2010
I will check that one out.... Never heard of one closing itself after take-off though.... Thanks -----Original Message----- >From: RICHARD MILLER <rickpegser(at)yahoo.com> >Sent: Jun 28, 2010 3:25 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Odd running cylinder > > >souunds like an intake leak >rick > >--- On Mon, 6/28/10, Ralph E. Capen wrote: > >> From: Ralph E. Capen <recapen(at)earthlink.net> >> Subject: RV-List: Odd running cylinder >> To: "rv-list" >> Date: Monday, June 28, 2010, 9:12 AM >> "Ralph E. Capen" >> >> Configuration reminder: >> RV6A >> SamJames cowl/plenum >> AeroSportPower built XP IO360B1F6 >> 9.2:1 pistons >> AFP injection (Flow balanced to .1gph per AFP >> instructions) >> LASAR ignition (MAP monitor on #4, CHT monitor on #3) >> Vetterman Dual crossover exhaust with heater/mufflers >> MT three blade MTV12B183-59 propellor >> >> During the first few minutes of operation (essentially >> through climb-out and throttle-back), my number one cylinder >> indicates a higher CHT and EGT. >> Neither the CHT or EGT raise to a dangerous level and both >> return to normal upon establishing cruise settings. >> My number one cylinder also has an injector restrictor that >> is 5% larger than the other three in order to balance fuel >> flow for leaning purposes. >> >> This has occurred seven out of the last eight >> flights. The missing one is kinda in the middle. >> >> Data capture is through an AFS3400EM at 1 second >> intervals. I have data and graphs if someone wants to >> look-see. >> >> I am wondering if I might have something in the fuel >> injection distribution spider that is partially blocking one >> line below a certain flow rate. >> >> Any other thoughts, >> Ralph >> RV6A N822AR @ N06 70 hours >> >> >> >> >> Forum - >> FAQ, >> - MATRONICS WEB FORUMS - >> List Contribution Web Site - >> -Matt >> Dralle, List Admin. >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jun 28, 2010
Subject: Using flaps for takeoff
I just had a conversation with a gentlemen from our airpark who said during the last flyin all the RV-s took off with some flaps. I had been told previously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager and he did not have me using any flaps for take off. Since I have not tried it (yet) I was wondering if some of you are using flaps for takeoff and if you can tell any real difference. Would love to hear your thoughts. Tim Bryan RV-6 N616TB Frankston, Texas ________________________________________________________________________________
Date: Jun 28, 2010
Hey Tim=2C I don't see how the flaps on RV's would only be drag flaps=2C if so=2C they would not lower your stall speed when extended. Mine surely do. (RV8) Ju st like a Piper=2C Cessna=2C or Mooney for that matter=2C adding a little f lap (10 degrees or so) should reduce your take off run and get you over the tree line a little faster. Good flying=2C Paul > From: N616TB(at)btsapps.com > To: rv-list(at)matronics.com > Date: Mon=2C 28 Jun 2010 17:06:28 -0500 > Subject: RV-List: Using flaps for takeoff > > > I just had a conversation with a gentlemen from our airpark who said duri ng the last flyin all the RV-s took off with some flaps. I had been told pr eviously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager an d he did not have me using any flaps for take off. Since I have not tried i t (yet) I was wondering if some of you are using flaps for takeoff and if y ou can tell any real difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston=2C Texas > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: Using flaps for takeoff
Date: Jun 28, 2010
I only use flaps on takeoff when I have someone in the back seat. I'm certain the tail comes up more easily with a little flap. As to whether it improves runway performance in terms of shortening the required field length or not...are you kidding? It would have to be a REALLY short field before my -8 started having to worry about it. Tim ----- Original Message ----- From: Paul Rice To: rv-list(at)matronics.com Sent: Monday, June 28, 2010 3:23 PM Subject: RE: RV-List: Using flaps for takeoff Hey Tim, I don't see how the flaps on RV's would only be drag flaps, if so, they would not lower your stall speed when extended. Mine surely do. (RV8) Just like a Piper, Cessna, or Mooney for that matter, adding a little flap (10 degrees or so) should reduce your take off run and get you over the tree line a little faster. Good flying, Paul > From: N616TB(at)btsapps.com > To: rv-list(at)matronics.com > Date: Mon, 28 Jun 2010 17:06:28 -0500 > Subject: RV-List: Using flaps for takeoff > > > I just had a conversation with a gentlemen from our airpark who said during the last flyin all the RV-s took off with some flaps. I had been told previously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager and he did not have me using any flaps for take off. Since I have not tried it (yet) I was wondering if some of you are using flaps for takeoff and if you can tell any real difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston, Texas &g======================== > > > ________________________________________________________________________________
Date: Jun 28, 2010
Way back before the turn of the century when I got my free ride in the factory RV-8a here at Arlington, WA with Bill Benedict, then general manager of Van's, I remember him commenting that although it wasn't necessarily recommended procedure, he "did it like a Cessna" and put in a little bit of flaps on takeoff. I don't recall his reason, if he gave me one. Terry Stalled (on the ground) RV-8A project From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Timothy E. Cone Sent: Monday, June 28, 2010 3:36 PM Subject: Re: RV-List: Using flaps for takeoff I only use flaps on takeoff when I have someone in the back seat. I'm certain the tail comes up more easily with a little flap. As to whether it improves runway performance in terms of shortening the required field length or not...are you kidding? It would have to be a REALLY short field before my -8 started having to worry about it. Tim ----- Original Message ----- From: Paul Rice <mailto:rice737(at)msn.com> Sent: Monday, June 28, 2010 3:23 PM Subject: RE: RV-List: Using flaps for takeoff Hey Tim, I don't see how the flaps on RV's would only be drag flaps, if so, they would not lower your stall speed when extended. Mine surely do. (RV8) Just like a Piper, Cessna, or Mooney for that matter, adding a little flap (10 degrees or so) should reduce your take off run and get you over the tree line a little faster. Good flying, Paul > From: N616TB(at)btsapps.com > To: rv-list(at)matronics.com > Date: Mon, 28 Jun 2010 17:06:28 -0500 > Subject: RV-List: Using flaps for takeoff > > > I just had a conversation with a gentlemen from our airpark who said during the last flyin all the RV-s took off with some flaps. I had been told previously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager and he did not have me using any flaps for take off. Since I have not tried it (yet) I was wondering if some of you are using flaps for takeoff and if you can tell any real difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston, Texas &g======================= > > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 28, 2010
I'm not sure with RVs, but....wouldn't flaps (ie 10 degrees) be used for soft field takeoffs and no flaps for short field takeoffs (ie clearing trees at the end of a short field)? That's how it works with Cessnas and I assume Pipers and Mooneys as well. That's the way I was taught (in our Cessna 140), but maybe that's old school thinking ;) Scott http://corbenflyer.tripod.com/ Flying Corben Junior Ace - Building RV-4 Gotta Fly or Gonna Die Paul Rice wrote: > Hey Tim, > > I don't see how the flaps on RV's would only be drag flaps, if so, > they would not lower your stall speed when extended. Mine surely do. > (RV8) Just like a Piper, Cessna, or Mooney for that matter, adding a > little flap (10 degrees or so) should reduce your take off run and get > you over the tree line a little faster. > > Good flying, > > Paul > > ________________________________________________________________________________
Date: Jun 28, 2010
Well, I can tell you that in a Cessna 170B and up, flaps shorten takeoff roll and clearing an obstacle until DA is more than 4500 ft. The old ones used 20 degrees until the 172 added a notch for 10 degrees and that was what was used. The Mooney uses 15 degrees of flaps for all takeoffs unless crosswind is too strong to handle with flaps, regardless of DA. On 6/28/2010 4:56 PM, Scott wrote: > > I'm not sure with RVs, but....wouldn't flaps (ie 10 degrees) be used > for soft field takeoffs and no flaps for short field takeoffs (ie > clearing trees at the end of a short field)? That's how it works with > Cessnas and I assume Pipers and Mooneys as well. That's the way I was > taught (in our Cessna 140), but maybe that's old school thinking ;) > > Scott > http://corbenflyer.tripod.com/ > Flying Corben Junior Ace - Building RV-4 > Gotta Fly or Gonna Die > > > Paul Rice wrote: >> Hey Tim, >> >> I don't see how the flaps on RV's would only be drag flaps, if so, >> they would not lower your stall speed when extended. Mine surely do. >> (RV8) Just like a Piper, Cessna, or Mooney for that matter, adding a >> little flap (10 degrees or so) should reduce your take off run and >> get you over the tree line a little faster. >> Good flying, >> >> Paul >> >> > > ________________________________________________________________________________
Date: Jun 29, 2010
I can see how 10 degrees might lessen the takeoff roll due to being able to lift off at a slightly lower airspeed. Can anyone explain why the obstacle clearance would be better with flaps down? There is more drag, so wouldn't rate of climb be slightly less? I suppose if you climb at just above stall speed, your ground speed would be lower, thus taking longer to get to that tree line? So, why do instructors teach flaps for soft field and no flaps for short field? What does the POH in the 170B say about soft and short field ops? Scott Kelly McMullen wrote: > > Well, I can tell you that in a Cessna 170B and up, flaps shorten > takeoff roll and clearing an obstacle until DA is more than 4500 ft. > The old ones used 20 degrees until the 172 added a notch for 10 > degrees and that was what was used. The Mooney uses 15 degrees of > flaps for all takeoffs unless crosswind is too strong to handle with > flaps, regardless of DA. > > ________________________________________________________________________________
Date: Jun 28, 2010
Subject: Re: Update On RV-8 Princeton Fuel Probe Installation...
On 06/21/2010 12:00 AM, Matt Dralle wrote: > All that > matters at this point is that they are both working and are exceptionally accurate in > the 15-0 gallon range which is where it counts. ...and you just *might* owe Princeton an apology for what I *seem* to remember as some pretty heavy bad-mouthing in your last few posts. But w/o actually going back into the archives, I may be wrong... Regards, J. Sonex #325 C-FJNJ, Jabiru 3300a, Prince P-Tip, Aerocarb restoring the Johnston Special http://cleco.ca +-------------------------------------------------------------+ | J. Davis, M.Sc. | (computer science) | | *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca | +-------------------------------------------------------------+ Last year I went fishing with Salvador Dali. He was using a dotted line. He caught every other fish. --- Steven Wright ________________________________________________________________________________
Date: Jun 28, 2010
The reason is the same for most airplanes, Vans included. More lift. To Tim=92s question that included the statement =93all the RV-s took off wi th some flaps=94 Well it=92s hard to get all pilots to do anything the same let alone us non-conformist =93don=92t tell me what to do=94 Experimental pilots. I have never heard of a flap that was =93drag only=94 seems near pointless, might as wel l avoid the weight & complexity of flaps that do not produce lift (and drag). The entire RV product line is extremely versatile and can take off with no flaps in most environments. The RV-10 is the only Vans design (I don=92t kn ow about the RV-12) with a 3 degree flap take off setting to improve hard surface take off performance. That being said adding some flap to all RV models should shorten take off roll. How much is needed or ideal depends on the plane, weight configuration, runway surface etc... Most important is that you as a pilot remember the flaps are deployed and do not exceed Vfe. So Tim give 10 degrees a test to see how it makes a difference on your ship . Then try a little more and a little less. For me flying my RV-4 & RV-6A both with 180 Hp I never used flaps on takeof f unless I was practicing or had concerns of clearing obstacles. In those cases I usually kept my hand on the throttle and finger on the flap up toggle as a reminder to retract flaps when able. Good luck, Robin *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *Terry Watson *Sent:* Monday, June 28, 2010 4:55 PM *To:* rv-list(at)matronics.com *Subject:* RE: RV-List: Using flaps for takeoff Way back before the turn of the century when I got my free ride in the factory RV-8a here at Arlington, WA with Bill Benedict, then general manage r of Van=92s, I remember him commenting that although it wasn=92t necessarily recommended procedure, he =93did it like a Cessna=94 and put in a little bi t of flaps on takeoff. I don=92t recall his reason, if he gave me one. Terry Stalled (on the ground) RV-8A project *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *Timothy E. Cone *Sent:* Monday, June 28, 2010 3:36 PM *To:* rv-list(at)matronics.com *Subject:* Re: RV-List: Using flaps for takeoff I only use flaps on takeoff when I have someone in the back seat. I'm certain the tail comes up more easily with a little flap. As to whether it improves runway performance in terms of shortening the required field length or not...are you kidding? It would have to be a REALLY short field before my -8 started having to worry about it. Tim ----- Original Message ----- *From:* Paul Rice *To:* rv-list(at)matronics.com *Sent:* Monday, June 28, 2010 3:23 PM *Subject:* RE: RV-List: Using flaps for takeoff Hey Tim, I don't see how the flaps on RV's would only be drag flaps, if so, they would not lower your stall speed when extended. Mine surely do. (RV8) Jus t like a Piper, Cessna, or Mooney for that matter, adding a little flap (10 degrees or so) should reduce your take off run and get you over the tree line a little faster. Good flying, Paul > From: N616TB(at)btsapps.com > To: rv-list(at)matronics.com > Date: Mon, 28 Jun 2010 17:06:28 -0500 > Subject: RV-List: Using flaps for takeoff > > > I just had a conversation with a gentlemen from our airpark who said during the last flyin all the RV-s took off with some flaps. I had been tol d previously the flaps in the RV were drag flaps only and did no real good fo r lift. I also did my transition training a few years ago with Mike Seager an d he did not have me using any flaps for take off. Since I have not tried it (yet) I was wondering if some of you are using flaps for takeoff and if you can tell any real difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston, Texas &g======================= > > * * * * *href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.c om/Navigator?RV-List* *href="http://forums.matronics.com">http://forums.matronics.com* *href="http://www.matronics.com/contribution">http://www.matronics.com/c* * * * * * * *http://www.matronics.com/Navigator?RV-List* * * *http://forums.matronics.com* * * *http://www.matronics.com/contribution* * * * * * * * * ===========* ===========* ===========* ===========* * * ________________________________________________________________________________
Date: Jun 28, 2010
I can't speak for Cessnas, since I have very little time in them. Every other airplane I have flown is designed to get off as soon as it can, that is at the lowest speed with which you can be assured of flying under good control. I have not flown any airplane which takes off without using flaps, if it has them. The RV-6 I do know about and have quite a few take offs. Here is my take: the first 10 degrees (1/4) flap is mostly a lift gain and very little drag added at low speed. You also get a new MAC line which gives you a higher angle of attack at a given deck angle. If you go further than 10, you start getting mostly drag and little or no add to the lift. As I see it, your choice is to use 10 flaps and get off a little sooner, or use no flaps and roll a little longer. I believe the plane will accelerate better once the wheels get air under them, so the obstacle clearance will be better, too. Lastly, the deck angle is lower with the ten flaps and you can see better for that point in the take off where you are just lifting off. Retracting the flaps is the first thing I do after take off. before boost pump, RPM, or throttle. Consequently, I always use 10 flap for take off, except in a severe cross wind (above 25K). In that case I am going to "pull it off" for take off with a raid rotation. If you use any flap in that condition it may crow hop toward the down wind side of the runway. Very difficult to control.. A lot of RV guys don't use flap for take off and I don't think it is a big deal. I do recommend every one try it, and try some stalls at 10 also. I think you will find the plane has a much more solid feel at low airspeeds with the flap down a little. My personal observation is that those folks who don't use flaps are operating at a lot higher airspeed than I am. That's ok too. If you are going to not lift off until you have 70 knots then why would you use flaps? Same applies for landing. I will offer that my tires last longer than most. Personally I believe this to be because I try to touch down at 45K, and take off at the same speed. I don't think there is a good solution for everyone. For those who don't fly much it makes sense (to me) to use higher speeds and longer take off rolls. That is not for me, however. For most of us, the RV normally accelerates so fast that this one or two knot difference in stall/lift off speed is hard to even notice any way. You will really notice it at high altitude hot day max gross weight. I hope this "one man's opinion" helps. Everyone sees it a little different. Denis RV-6A 4,300 take offs, 4300 landings On Jun 28, 2010, at 4:06 , N616TB wrote: > > I just had a conversation with a gentlemen from our airpark who said > during the last flyin all the RV-s took off with some flaps. I had > been told previously the flaps in the RV were drag flaps only and > did no real good for lift. I also did my transition training a few > years ago with Mike Seager and he did not have me using any flaps > for take off. Since I have not tried it (yet) I was wondering if > some of you are using flaps for takeoff and if you can tell any real > difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston, Texas > > ________________________________________________________________________________
Date: Jun 29, 2010
Tim: I do not use flaps for takeoff. I was not able to to measure any difference in takeoff with no flaps=2C 10 flaps=2C and 20 flaps. This was over 12.5 years ago. I will use 10 flaps on SOFT grass fields. I do not think it reduces ground roll on grass but I feel that it may reduce some of the weight on the mains . If anyone has some data that shows a difference=2C please share it. Also l et us know what model RV=2C HP=2C and prop. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C381+ Flying Hours So. CA=2C USA > From: N616TB(at)btsapps.com > To: rv-list(at)matronics.com > Date: Mon=2C 28 Jun 2010 17:06:28 -0500 > Subject: RV-List: Using flaps for takeoff > > > I just had a conversation with a gentlemen from our airpark who said duri ng the last flyin all the RV-s took off with some flaps. I had been told p reviously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager and he did not have me using any flaps for take off. Since I have not trie d it (yet) I was wondering if some of you are using flaps for takeoff and i f you can tell any real difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston=2C Texas > =========== =========== =========== =========== > > > _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Cedar Rapids IA area airplane accomodations
Date: Jun 28, 2010
Hi all: I'll be traveling to Cedar Rapids Iowa on the 3rd of July and plan to be there until the 12th. I'd like to fly my airplane to the Cedar Rapids Airport (KCID) because it's closest to where I want to be. I understand the main runway is under construction and it's only a moderately friendly airport (TSA security issues). I'll deal with that if I can find a place to keep my airplane there. Anyone have some recommendations as to what FBO to use there? Do they have some hangar space I can rent for 8-10 days while I'm there? Or would it be best to go to one of the smaller, uncontrolled outlying airports? If so which one? Any help would be greatly appreciated. Thanks. Dean Psiropoulos RV-6A N197DM Tarpon Sprgs, FL ________________________________________________________________________________
Date: Jun 28, 2010
On 6/28/2010 5:06 PM, N616TB wrote: > --> RV-List message posted by: N616TB > > I just had a conversation with a gentlemen from our airpark who said during the last flyin all the RV-s took off with some flaps. I had been told previously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager and he did not have me using any flaps for take off. Since I have not tried it (yet) I was wondering if some of you are using flaps for takeoff and if you can tell any real difference. Would love to hear your thoughts. > > Tim Bryan > RV-6 N616TB > Frankston, Texas > As others have said, they definitely add lift. I came to a purchased -4 after ~200 hrs in a Swift, with flap settings of full or none (never used for T/O). Never thought to try T/O flaps through 7 years of flying that 1st -4, and through about 3 or 4 years of flying the 2nd one. Then one day at a neighboring strip's flyin, I forgot to retract them (full flaps) on T/O. I was off much quicker than expected, and seemingly near pattern altitude before the end of the strip. Felt like departing into a 20kt headwind. Since then I've played with them several times, but just for fun. Even with only 160 hp, it would take a really short strip to make flaps seem necessary. On the obstacles issue, I'm no authority but I'd assume that the reason flaps-down gets you over obstacles better is that you have an improved climb *angle*. Anyway, I can't see any reason to avoid using them on T/O, except the surprise you might get if you aren't prepared to be off the ground so quickly. Try it; you might like it. :-) Charlie Slobovia Outernational flying purchased -4; -7 finish kit ________________________________________________________________________________
Date: Jun 28, 2010
Date: Jun 28, 2010
Hi Gary, Living 6 miles form Van and watching him fly frequently, I guess the best evidence for using flaps is to watch him takeoff, almost always uses flaps and consistently shorter takeoff roll then most others. RV6 Flyer wrote: > Tim: > > I do not use flaps for takeoff. I was not able to to measure any > difference in takeoff with no flaps, 10 flaps, and 20 flaps. This was > over 12.5 years ago. > > I will use 10 flaps on SOFT grass fields. I do not think it reduces > ground roll on grass but I feel that it may reduce some of the weight > on the mains. > > If anyone has some data that shows a difference, please share it. > Also let us know what model RV, HP, and prop. > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 2,381+ Flying Hours So. CA, USA > > > > From: N616TB(at)btsapps.com > > To: rv-list(at)matronics.com > > Date: Mon, 28 Jun 2010 17:06:28 -0500 > > Subject: RV-List: Using flaps for takeoff > > > > > > I just had a conversation with a gentlemen from our airpark who said > during the last flyin all the RV-s took off with some flaps. I had > been told previously the flaps in the RV were drag flaps only and did > no real good for lift. I also did my transition training a few years > ago with Mike Seager and he did not have me using any flaps for take > off. Since I have not tried it (yet) I was wondering if some of you > are using flaps for takeoff and if you can tell any real difference. > Would love to hear your thoughts. > > > > Tim Bryan > > RV-6 N616TB > > Frankston, Texas > > ===================== > >====== > > > > > > > > ------------------------------------------------------------------------ > Hotmail has tools for the New Busy. Search, chat and e-mail from your > inbox. Learn more. > <http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1> > > * > > > * > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 28, 2010
POH for a C170B last produced in 1956? Surely you jest. It had a one page 5X8" two sided FAA approved flight manual. You climb at Vx, which for most planes is flaps and gear down. Best angle of climb, which is what you need when obstacle is near. The FAA short field definition rarely meets real world...paved runway, just short distance to obstacle. Most real world short fields are also either soft or rough fields and flaps are needed. Just my experience in 700 hours of flying 170B in Alaska. Instructors teach what the FAA dictates to pass the test. I do happen to have a C177B POH handy, which calls for 10 degrees for normal takeoff and 15 degrees for max performance takeoff: On 6/28/2010 5:24 PM, Scott wrote: > > I can see how 10 degrees might lessen the takeoff roll due to being > able to lift off at a slightly lower airspeed. Can anyone explain why > the obstacle clearance would be better with flaps down? There is more > drag, so wouldn't rate of climb be slightly less? I suppose if you > climb at just above stall speed, your ground speed would be lower, > thus taking longer to get to that tree line? So, why do instructors > teach flaps for soft field and no flaps for short field? > > What does the POH in the 170B say about soft and short field ops? > > Scott > > > Kelly McMullen wrote: >> >> Well, I can tell you that in a Cessna 170B and up, flaps shorten >> takeoff roll and clearing an obstacle until DA is more than 4500 ft. >> The old ones used 20 degrees until the 172 added a notch for 10 >> degrees and that was what was used. The Mooney uses 15 degrees of >> flaps for all takeoffs unless crosswind is too strong to handle with >> flaps, regardless of DA. >> >> > > ________________________________________________________________________________
Subject: Re: Cedar Rapids IA area airplane accomodations
Date: Jun 28, 2010
Hi Dean - my plane is at KCID. Runway 9/27 is closed but the taxiway (now 8/26) is open and plenty log. 13/31 is also open, for now. It will close, I think at the end of July. The runway thing is no problem, just no taxiways. PS Air is the more friendly FBO for small airplanes. I'd call them and ask about hangar space. They are good people. Good luck, dave ----- Original Message ----- From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Sent: Monday, June 28, 2010 8:40 PM Subject: RV-List: Cedar Rapids IA area airplane accomodations > > > Hi all: > > I'll be traveling to Cedar Rapids Iowa on the 3rd of July and plan to be > there until the 12th. I'd like to fly my airplane to the Cedar Rapids > Airport (KCID) because it's closest to where I want to be. I understand > the > main runway is under construction and it's only a moderately friendly > airport (TSA security issues). I'll deal with that if I can find a place > to > keep my airplane there. Anyone have some recommendations as to what FBO > to > use there? Do they have some hangar space I can rent for 8-10 days while > I'm there? Or would it be best to go to one of the smaller, uncontrolled > outlying airports? If so which one? Any help would be greatly > appreciated. > Thanks. > > Dean Psiropoulos > RV-6A N197DM > Tarpon Sprgs, FL > > > ________________________________________________________________________________
Date: Jun 29, 2010
Intake leaks are easy to find. clean out your shop vac real good and set it up to blow instead of suck. Stick the hose in the intake and seal with shop rags. Spray soapy water all over the intake system and look for bubbles. Two most common leaks are the intake coupling hoses and the are where the intake comes out of the oil pan ..... that's a swaged part, and to fix correctly requires a swaging tool. I've seen them fixed with JB Weld to silicone sealer though. Linn RICHARD MILLER wrote: > > souunds like an intake leak > rick > > --- On Mon, 6/28/10, Ralph E. Capen wrote: > > >> From: Ralph E. Capen <recapen(at)earthlink.net> >> Subject: RV-List: Odd running cylinder >> To: "rv-list" >> Date: Monday, June 28, 2010, 9:12 AM >> "Ralph E. Capen" >> >> Configuration reminder: >> RV6A >> SamJames cowl/plenum >> AeroSportPower built XP IO360B1F6 >> 9.2:1 pistons >> AFP injection (Flow balanced to .1gph per AFP >> instructions) >> LASAR ignition (MAP monitor on #4, CHT monitor on #3) >> Vetterman Dual crossover exhaust with heater/mufflers >> MT three blade MTV12B183-59 propellor >> >> During the first few minutes of operation (essentially >> through climb-out and throttle-back), my number one cylinder >> indicates a higher CHT and EGT. >> Neither the CHT or EGT raise to a dangerous level and both >> return to normal upon establishing cruise settings. >> My number one cylinder also has an injector restrictor that >> is 5% larger than the other three in order to balance fuel >> flow for leaning purposes. >> >> This has occurred seven out of the last eight >> flights. The missing one is kinda in the middle. >> >> Data capture is through an AFS3400EM at 1 second >> intervals. I have data and graphs if someone wants to >> look-see. >> >> I am wondering if I might have something in the fuel >> injection distribution spider that is partially blocking one >> line below a certain flow rate. >> >> Any other thoughts, >> Ralph >> RV6A N822AR @ N06 70 hours >> >> >> >> >> Forum - >> FAQ, >> - MATRONICS WEB FORUMS - >> List Contribution Web Site - >> -Matt >> Dralle, List Admin. >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Jun 29, 2010
The only flat tires I've had in 4,500 hours of flying were with Michelin Airstop tubes. So much for "brand name" tubes. Both had flaws in the ru bber where they failed. I've replaced both with Desser low-leakage tubes but haven't had them on long enough to know if they are any better. Mike Hilger RV-6, N207AM, 920 hours ____________________________________________________________ Neulasta® (pegfilgrastim) Visit the Official Website to Learn About Neulasta and Receive Info. http://thirdpartyoffers.juno.com/TGL3141/4c2975fb206ced3fb3st01vuc ________________________________________________________________________________
Date: Jun 29, 2010
From: Richard Martin <martinaerodrome(at)gmail.com>
Ralph, It is not onusual to have a experience such as you mention. On take off and climb, the engine is at its highest power and the airplane is usually flying slower than in cruise. Dick Martin RV8 N233M the fast one On Mon, Jun 28, 2010 at 11:12 AM, Ralph E. Capen wrote: > > Configuration reminder: > RV6A > SamJames cowl/plenum > AeroSportPower built XP IO360B1F6 > 9.2:1 pistons > AFP injection (Flow balanced to .1gph per AFP instructions) > LASAR ignition (MAP monitor on #4, CHT monitor on #3) > Vetterman Dual crossover exhaust with heater/mufflers > MT three blade MTV12B183-59 propellor > > During the first few minutes of operation (essentially through climb-out > and throttle-back), my number one cylinder indicates a higher CHT and EGT. > Neither the CHT or EGT raise to a dangerous level and both return to normal > upon establishing cruise settings. > My number one cylinder also has an injector restrictor that is 5% larger > than the other three in order to balance fuel flow for leaning purposes. > > This has occurred seven out of the last eight flights. The missing one is > kinda in the middle. > > Data capture is through an AFS3400EM at 1 second intervals. I have data > and graphs if someone wants to look-see. > > I am wondering if I might have something in the fuel injection distribution > spider that is partially blocking one line below a certain flow rate. > > Any other thoughts, > Ralph > RV6A N822AR @ N06 70 hours > > ________________________________________________________________________________
Date: Jun 29, 2010
Subject: Re: Strobe Light
Brian, I concur with your thoughts. Besides, the 912 IS a light sport, whic h appeals to guys like me who want to fly in the LSA=C2- category without a 3rd class medical. By rule, we can't fly at night. By the way, are you related to Edward Chalmers Huffaker? He is from my local area (Chuckey, TN) and did quite a bit of research on flight aroun d the late 1800's to early 1900's. He was with the Wright Bros at Kitty Hawk. Walt ----- Original Message ----- From: "Brian Huffaker" <bifft(at)xmission.com> Sent: Monday, June 28, 2010 12:27:53 PM Subject: RE: RV-List: Strobe Light On Mon, 28 Jun 2010, Bruce Gray wrote: > Walt, > > While you might not plan on doing any night flying, look a little > farther into the future. When you might want to sell your baby. Most > pilots fly at night, any airplane not equipped with nav/landing/strobe > lights would place it at the bottom of a buyers list. > =C2-=C2-As a contrary viewpoint, build the plane you want, not what you think someone else might want. =C2-I don't fly at night or in bad weather, so I 'm going no lights, no gyros. =C2-Save a few pounds and few hundred dollars. I'm not building to sell, I'm building this plane for me. =C2-=C2-Brian Huffaker, DSWL (bifft(at)xmission.com) =C2-=C2-RV-8A 80091 fitting wings =C2-=C2-1/4 Starduster II N23UT flying =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: tires and flaps
Date: Jun 29, 2010
Hey Reuven, If you don't take off with the tires flat you will be less likely to land with them that way... ;{) Michelin leak stop tubes are junk. I've had one fail, one not leak in the tire even though it had a split when I took it apart, and I've helped several folks get rid of them by the side of the runway when theirs split a seam at fly-ins. Mostly I use flaps on take off when I'm practicing using flaps on take off... it does bring the tail up quicker, however one blows through flap speeds so quickly it is just one more thing to remember or forget. One place it is really useful is when taking off in formation with a slower plane. My first time at that was with a Lockheed L60 (think C206 mated with a Sherman tank) at KOSH. We had a plan, however I hadn't completely thought through what it meant to me in terms of throttle and speed. It was not an issue, I just wasn't mentally ready for everything to happen so slow while taking off at 1/3 throttle. Since then I've learned that some flaps do reduce the tendency to catch up too fast but one really has to 'work' at going slow enough to let the lead get airborne first. Practicing a low to medium power take off has some value because most of us have been taught to go full power in a go around. This is not needed and can exacerbate things due to the pitching up moment that occurs in our short airplanes when the throttle is slammed full at really slow speeds. Lastly, grass runways get 10 deg of flaps mostly due to the fact that the 5" tires are really small and tend to be draggy on soft or long grass. Anything that can add lift will reduce tire into sod penetration. My guess is Van's grass strip in soggy Portland has conditioned him into always using flaps. Wheeler ________________________________________________________________________________
Subject: Re: tires
Date: Jun 29, 2010
Lov'en my Michelin Air Stop tubes!! Rarely have to add air instead of every flight. Dale ________________________________________________________________________________
Subject: FS: RV-7A ~80% complete
Date: Jun 29, 2010
I've decided to sell my RV-7A project. It's just dragged on and on, and I've lost interest in completing it. I have more interest in just flying my Challenger II. I made 75 flights in it in 2009. Engine is Subaru WRX STi 2.5 L supercharged. All the bugs are worked out of the original Eggenfellner product. Most Eggenfellner-supplied components have been replaced; SDS ECU, custom radiators, new wiring harness, supercharger gearing. Engine runs great, and all it needs is probably some more fine-tuning of the SDS ECU. John Moody in Australia has been flying his awhile. Includes latest Gen3 rev 4 PSRU, installed. Includes MT7 electric prop, installed. Three EFIS systems installed - Blue Mountain "gold box" EFIS/One, GRT Horizon, and Dynon D10. Blue Mountain AP installed. GRT EIS installed Full Garmin stack trays installed & SL-30 included. Sandia TSOd encoder, Tipup canopy completed but not final-installed. Needs rear window installed, 1 panel each wing installed, top fuse panel behind window and fwd of canopy installed (left out for wiring access). No fiberglass work done. Includes Advanced Flight Systems AoA, wig-wag HID lights, bulletproof electrical system based on Bob Nuckolls' designs and Hyperion products, low fuel warning, low coolant warning, fuel pressure warning, electric flaps, electric trim, custom console, heater, Oregon Aero seats, Hooker harness, Show Planes Flaps Positioning System, Infinity Aerospace grips, cabin lighting, custom baggage compartment and other customizations (see my custom page http://www.meyette.us/custom.htm ). Includes finishing kit and all parts (except remaining Garmin components) to finish it. All gear mounted and brakes installed. Van's front gear leg SB installed. Panel complete, except Garmin wiring. Empennage is done & final-installed. Flaps & ailerons all done. Wings not installed. And much more - this is a list off the top of my head of some of the main components. Entire project very extensively documented at http://www.meyette.us/RV-7Ahome.htm No effort or expense spared in doing everything RIGHT. Only asking $45k for it - way less than cost and making the FWF essentially FREE. Will also trade for an RV-12 ________________________________________________________________________________
From: "Bruce B. Bell" <brucebell74(at)sbcglobal.net>
Subject: Use of Fuel Boost Pump
Date: Jun 30, 2010
Hi All, I turn on the fuel boost pump for all take offs and landings. Since I spend most of my time in the traffic pattern the fuel boost pump is on most of the time. I have lunch on Mondays with The RV Bunch and brought up the use of the fuel boost pump. Three (RV-10, RV-9A and RV-7A) said they only use it to start! So what do the rest of you do who have fuel injected engines? I have 92 hours and 332 landings in the log book. Thanks, Bruce Bell ________________________________________________________________________________
Date: Jun 30, 2010
Subject: Re: Use of Fuel Boost Pump
I always turn on the fuel pump for take-off as the fuel press is very low without it. The eng performs the same when I have forgot it but I like that little more insurance. Hardly ever turn on for landing. Ollie 6A carb. On Wed, Jun 30, 2010 at 9:32 AM, Bruce B. Bell wrote: > > Hi All, > I turn on the fuel boost pump for all take offs and landings. Since I spend > most of my time in the traffic pattern the fuel boost pump is on most of the > time. I have lunch on Mondays with The RV Bunch and brought up the use of > the fuel boost pump. Three (RV-10, RV-9A and RV-7A) said they only use it to > start! So what do the rest of you do who have fuel injected engines? I have > 92 hours and 332 landings in the log book. Thanks, Bruce Bell > > -- >From Central Florida, Ollie ________________________________________________________________________________
Date: Jun 30, 2010
Lycoming fuel injection is different from Continental. Most low wing aircraft with Lycoming(Bendix) fuel injection call for boost pump on for takeoff and landing. TCM engines mixture is affected by boost on or off, so they either use low boost or none for takeoff. Bendix fuel injection is much less sensitive to input pressure, so the only downside to using the boost pump is wear and tear on the boost pump. The reason for the boost pump is in case the engine driven pump fails. Whether you are confident that you could realize fuel was the problem when the engine quit and switch the pump on before you impact is the main issue. If you establish a routine to turn the pump off as soon as you reach 1000AGL, you will minimize wear and tear on the boost pump. Personally, I tend to think it is less critical for landing, but an argument can be made either way. On 6/30/2010 6:32 AM, Bruce B. Bell wrote: > > > Hi All, > I turn on the fuel boost pump for all take offs and landings. Since I > spend most of my time in the traffic pattern the fuel boost pump is on > most of the time. I have lunch on Mondays with The RV Bunch and > brought up the use of the fuel boost pump. Three (RV-10, RV-9A and > RV-7A) said they only use it to start! So what do the rest of you do > who have fuel injected engines? I have 92 hours and 332 landings in > the log book. Thanks, Bruce Bell > > ________________________________________________________________________________
Date: Jun 30, 2010
Bruce, I suggest Don Rivera @ Air Flow Performance. I have one of his boost pumps with good history. His pumps are designed for both boost and continous operation. When I built my RV8 ten plus years ago, I questioned him about your concern. His comments are that the boost pumps are designed for intermittant or continous operation. Also a side note, his pumps and fuel injections systems are preferred by most of the Indy racers. Do not hesitate to call him, he always has been very helpful. Dick Martin RV8 N233M the fast one On Wed, Jun 30, 2010 at 8:32 AM, Bruce B. Bell wrote: > > Hi All, > I turn on the fuel boost pump for all take offs and landings. Since I spend > most of my time in the traffic pattern the fuel boost pump is on most of the > time. I have lunch on Mondays with The RV Bunch and brought up the use of > the fuel boost pump. Three (RV-10, RV-9A and RV-7A) said they only use it to > start! So what do the rest of you do who have fuel injected engines? I have > 92 hours and 332 landings in the log book. Thanks, Bruce Bell > > ________________________________________________________________________________
Date: Jun 30, 2010
BRUCE: I ONLY USE THE FUEL BOOST PUMP WHEN STARTING THE ENGINE TO BRING THE FP UP TO 20+ PSI BEFORE ENGAGING THE STARTER; OTHERWISE - I DON'T USE IT. AN OLD TIMER ADVISED THAT THIS WAS THE WAY TO GO. BE INTERESTING TO KNOW WHAT OTHER'S MIGHT BE DOING WITH THE BOOST PUMP. DAN RV-7A - N307TB 154 HOURS SINCE FIRST FLIGHT ON 08/04/09 On Wed, Jun 30, 2010 at 9:32 AM, Bruce B. Bell wrote: > > Hi All, > I turn on the fuel boost pump for all take offs and landings. Since I spend > most of my time in the traffic pattern the fuel boost pump is on most of the > time. I have lunch on Mondays with The RV Bunch and brought up the use of > the fuel boost pump. Three (RV-10, RV-9A and RV-7A) said they only use it to > start! So what do the rest of you do who have fuel injected engines? I have > 92 hours and 332 landings in the log book. Thanks, Bruce Bell > > ________________________________________________________________________________
From: "Richard Dudley" <rhdudley1(at)bellsouth.net>
Date: Jun 30, 2010
Hi Dan, My procedure has been (in 2 235 Cherokees and my RV -6A): ON for startup fuel pressure, OFF for taxi and runup, ON for takeoff, approach or anything below 1000 feet, ON when changing tanks and ON as an emergency procedure at any hint of engine misbehavior. My rationale for OFF for taxi and rumup is confirmation of engine driven fuel pump operation; ON for takeoff, approach or anything low level as backup of the engine driven fuel pump; ON at any engine hiccup in case it resulted from an engine driven fuel pump failure. An experience that reinforced those procedures was a failed engine driven pump on a 235 Cherokee after takeoff and at about 1000 feet when I turned off the boost pump and the engine started to run down until I turned the boost pump back on. Regards, Rich Dudley ----- Original Message ----- From: Dan Bergeron To: rv-list(at)matronics.com Sent: Wednesday, June 30, 2010 3:51 PM Subject: Re: RV-List: Use of Fuel Boost Pump BRUCE: I ONLY USE THE FUEL BOOST PUMP WHEN STARTING THE ENGINE TO BRING THE FP UP TO 20+ PSI BEFORE ENGAGING THE STARTER; OTHERWISE - I DON'T USE IT. AN OLD TIMER ADVISED THAT THIS WAS THE WAY TO GO. BE INTERESTING TO KNOW WHAT OTHER'S MIGHT BE DOING WITH THE BOOST PUMP. DAN RV-7A - N307TB 154 HOURS SINCE FIRST FLIGHT ON 08/04/09 On Wed, Jun 30, 2010 at 9:32 AM, Bruce B. Bell wrote: Hi All, I turn on the fuel boost pump for all take offs and landings. Since I spend most of my time in the traffic pattern the fuel boost pump is on most of the time. I have lunch on Mondays with The RV Bunch and brought up the use of the fuel boost pump. Three (RV-10, RV-9A and RV-7A) said they only use it to start! So what do the rest of you do who have fuel injected engines? I have 92 hours and 332 landings in the log book. Thanks, Bruce Bell ========== get="_blank">http://www.matronics.com/Navigator?RV-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject:
Date: Jun 30, 2010
I had always assumed that the reason most people took off without flaps is that the recommended flap speed of 100 is attained so quickly that they need to be retracted almost imediatly, but don't see why you couln't if you were right on the ball. Mark Rose RV8A 137MR ________________________________________________________________________________
Date: Jun 30, 2010
From: Tom & Cathy Ervin <tcervin(at)embarqmail.com>
I never use my boost pump unless just befor starting and only if it's set for more than 10 days. RV6-A 360-A1A and never had an issue. Tom in Ohio ----- Original Message ----- From: "Dan Bergeron" <dan.pat.b(at)gmail.com> Sent: Wednesday, June 30, 2010 3:51:11 PM GMT -05:00 US/Canada Eastern Subject: Re: RV-List: Use of Fuel Boost Pump BRUCE: I ONLY USE THE FUEL BOOST PUMP WHEN STARTING THE ENGINE TO BRING THE FP UP TO 20+ PSI BEFORE ENGAGING THE STARTER; OTHERWISE - I DON'T USE IT. AN OLD TIMER ADVISED THAT THIS WAS THE WAY TO GO. BE INTERESTING TO KNOW WHAT OTHER'S MIGHT BE DOING WITH THE BOOST PUMP. DAN RV-7A - N307TB 154 HOURS SINCE FIRST FLIGHT ON 08/04/09 On Wed, Jun 30, 2010 at 9:32 AM, Bruce B. Bell wrote: > > Hi All, > I turn on the fuel boost pump for all take offs and landings. Since I spend > most of my time in the traffic pattern the fuel boost pump is on most of the > time. I have lunch on Mondays with The RV Bunch and brought up the use of > the fuel boost pump. Three (RV-10, RV-9A and RV-7A) said they only use it to > start! So what do the rest of you do who have fuel injected engines? I have > 92 hours and 332 landings in the log book. Thanks, Bruce Bell > > ________________________________________________________________________________
Date: Jun 30, 2010
Bruce: I use Boost Pump to start=2C takeoff=2C climb=2C switch fuel tanks=2C anyti me at or below 1=2C000 AGL=2C landing=2C and anytime taxiing in HOT weather with a HOT engine. Lycoming recommends can be found on the web in the Lycoming Flyer Key Repri nts. See: http://www.lycoming.textron.com/support/tips-advice/key-reprints/pdfs/Key%2 0Operations.pdf (page 19 in the PDF document or page 53 as Lycoming number s it) >From the Lycoming Flyer link above: Use of Fuel Boost Pumps with Lycoming Engines As an engine manufacturer=2C we are frequently asked about the proper use o f the fuel boost pump with our power plants. Although we can=92t pretend to be an expert on the fuel boost pump itself=2C we have some positive recomm endations concerning its use with our engines. Where a boost pump is provid ed by the airframe manufacturer=2C and the airframe Pilot=92s Operating Han dbook has a limited treatment of the use of the fuel boost pump=2C perhaps this discussion can provide the necessary fuel boost pump information for t he pilot in order to operate his or her engine as safely as possible. It is necessary to supply the engine with a steady=2C uninterrupted flow of fuel for all operating conditions. Entrapped air=2C temperature changes=2C pressure drops=2C agitation in the fuel lines and other factors affect the release of air and vapor from the fuel system. Under some circumstances wh ere an engine-mounted fuel pump is provided=2C it may not be able to pump a continuous fuel supply free of excessive vapor. An effective continuous fuel supply is provided by use of the fuel boost pu mp. As a general recommendation=2C the fuel boost pump should be used with Lycoming engines in all conditions where there is any possibility of excess ive vapor formation=2C or when a temporary cessation of fuel flow would int roduce undesirable hazards. The conditions under which Lycoming recommends operation of the fuel boost pump are as follows: 1. Every takeoff. 2. Climb after takeoff unless Pilot=92s Operating Handbook says it is not n ecessary. 3. When switching fuel selectors from one separate fuel tank to another=2C the fuel boost pump should be =93on=94 in the new tank until the operator i s assured there will be no interruption of the fuel flow. 4. Every landing approach. 5. Any time the fuel pressure is fluctuating=2C and the engine is affected by the fluctuation. 6. Hot weather=2C hot engine ground operation where fuel vapor problems cau se erratic engine operation. 7. Some General Aviation aircraft require the use of the fuel boost pump du ring high-altitude flight. This will be spelled out in the Pilot=92s Operat ing Handbook. 8. If the engine-mounted fuel pump fails. If the fuel boost pump is used during ground operation=2C don=92t fail to c heck the condition of the engine-mounted fuel pump before takeoff by turnin g the boost pump off briefly=2C and then back =93on=94 for takeoff. If the engine-mounted pump has failed=2C it would be safer to know that on the gro und rather than in the air when the fuel boost pump is turned =93off.=94 When in doubt=2C do the safest thing and use the fuel boost pump with Lycom ing engines. Don=92t be =93stingy=94 with the boost pump. In most cases=2C they last the overhaul life of the engine=2C and are then exchanged or over hauled themselves. AS A REMINDER=2C the airframe Pilot=92s Operating Handbo ok is the authority if boost pump information is spelled out in it. A note on how long Van's boost pump for a carb will last: My first boost p ump used as listed above lasted more than 10-years and around 2=2C100 hobbs hours. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C381+ Flying Hours So. CA=2C USA > From: brucebell74(at)sbcglobal.net > To: rv-list(at)matronics.com > Subject: RV-List: Use of Fuel Boost Pump > Date: Wed=2C 30 Jun 2010 08:32:07 -0500 > > > > Hi All=2C > I turn on the fuel boost pump for all take offs and landings. Since I spe nd > most of my time in the traffic pattern the fuel boost pump is on most of the > time. I have lunch on Mondays with The RV Bunch and brought up the use of > the fuel boost pump. Three (RV-10=2C RV-9A and RV-7A) said they only use it to > start! So what do the rest of you do who have fuel injected engines? I h ave > 92 hours and 332 landings in the log book. Thanks=2C Bruce Bell > > _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Date: Jun 30, 2010
Subject: Jacking Point
Okay, so I'm sure this has been asked a few times already, and I should search the archive, but what the heck, let's start a new thread. I got my new tires today (Goodyear Custom Flight III, btw. Super sweet.) and started looking for ways to get them on. I can really only see two ways to jack the plane up easily with a normal jack. 1) I could put a short saw horse under the wing tie down and then put a hydraulic jack on it and lift the side of the airplane up by this point. If I just gently lift the plane by hand at this point, it seems like that's an awful lot of weight to be lifting that far out on the wing. Can the spars really handle this? 2) I could put a saw horse under the lower engine mount bolt to the firewall and use a hydraulic jack to lift the plane up. This seems less scary, but I question the shear strength of the bolt lifting all of the weight by this single point. What's the convential wisdom on jacking a tail dragger RV-8 to change the tires? There has to be a way with out building some elaborate dolphin contraption. BTW, with regards to my tire wear, since there's a fair amount of camber(?) afforded by the Grove gear, I've got nearly all the wear on the outside 50% of the tread. I could probably rotate them 180 degrees and get another 70 hours of flight time, which wouldn't be bad for 22-year old stock kit tires from Van's (remember, I swiped them from the RV-4 project after the brake incident). But, I probably should have rotated them a bit sooner. While there's not cord showing, the tread is gone. Live and learn; I'll be rotating these GYCFIII's in a more timely manner. If I can double my wear life by rotating because of the camber, I might get 1000 hours out of these babies! ;-) Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor! ________________________________________________________________________________
Date: Jun 30, 2010
Subject: Lubing The Tail Wheel Fork Bearing...
How the heck do you lube the bronze bearing on the tailwheel fork short of taking the giant nut off. I lubed it up good during initial assembly, then at about 40 hours, it started to kind of stick, so I dissembled and lubed it again. Now at 70 its doing it again. I foolishly put a Zerk fitting in the body of the thing, thinking that next time I could just shoot some lube in there. Great idea except that it doesn't work for such a tight fit. Is there some "super lube" you can get that will last forever? I've used both graphite wheel bearing grease and Aeroshell #6 grease. Thanks! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor! ________________________________________________________________________________
Date: Jul 01, 2010
Subject: Re: Lubing The Tail Wheel Fork Bearing...
Matt, If you find some of that "super lube" stuff please let me know, otherwise accept the fact that every oil change you need to disassemble the fork via the "giant nut" and clean and lube the locking pin and spring and the bearing shaft. I learned that the hard way when my locking tail wheel quit locking after about 150 hours. The pin had galled because of lack of lube and was stuck in the unlock (retracted) position. The grease fitting that is installed is useless for the reason you state. Small price to pay for the many advantages of having the little wheel in back where it belongs :-). Harry Crosby RV-6 N16CX, 705 hours ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Wednesday, June 30, 2010 8:06:34 PM Subject: RV-List: Lubing The Tail Wheel Fork Bearing... How the heck do you lube the bronze bearing on the tailwheel fork short of taking the giant nut off. I lubed it up good during initial assembly, then at about 40 hours, it started to kind of stick, so I dissembled and lubed it again. Now at 70 its doing it again. I foolishly put a Zerk fitting in the body of the thing, thinking that next time I could just shoot some lube in there. Great idea except that it doesn't work for such a tight fit. Is there some "super lube" you can get that will last forever? I've used both graphite wheel bearing grease and Aeroshell #6 grease. Thanks! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor! ________________________________________________________________________________
Date: Jul 01, 2010
Subject: Re: Jacking Point
Matt, When you lift the wing up at the tie down point to change a tire you are putting approximately a one "g" load on the spar. Have you forgotten that these wings have been tested to ten "g's"? BTW, congrats on the Flight Custom III's, you're gonna like "em. And regardless, you are going to have to rotate them every hundred hours or so to even out the wear. BBTW, when you jack up the wing it is going to want to shift toward the low side. Best to use a floor jack on wheels and set it up so that it can roll toward the low side maybe six inches or so as the high wing is raised. Harry Crosby RV-6 N16CX, 705 hours ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Wednesday, June 30, 2010 7:59:42 PM Subject: RV-List: Jacking Point Okay, so I'm sure this has been asked a few times already, and I should search the archive, but what the heck, let's start a new thread. I got my new tires today (Goodyear Custom Flight III, btw. Super sweet.) and started looking for ways to get them on. I can really only see two ways to jack the plane up easily with a normal jack. 1) I could put a short saw horse under the wing tie down and then put a hydraulic jack on it and lift the side of the airplane up by this point. If I just gently lift the plane by hand at this point, it seems like that's an awful lot of weight to be lifting that far out on the wing. Can the spars really handle this? 2) I could put a saw horse under the lower engine mount bolt to the firewall and use a hydraulic jack to lift the plane up. This seems less scary, but I question the shear strength of the bolt lifting all of the weight by this single point. What's the convential wisdom on jacking a tail dragger RV-8 to change the tires? There has to be a way with out building some elaborate dolphin contraption. BTW, with regards to my tire wear, since there's a fair amount of camber(?) afforded by the Grove gear, I've got nearly all the wear on the outside 50% of the tread. I could probably rotate them 180 degrees and get another 70 hours of flight time, which wouldn't be bad for 22-year old stock kit tires from Van's (remember, I swiped them from the RV-4 project after the brake incident). But, I probably should have rotated them a bit sooner. While there's not cord showing, the tread is gone. Live and learn; I'll be rotating these GYCFIII's in a more timely manner. If I can double my wear life by rotating because of the camber, I might get 1000 hours out of these babies! ;-) Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying The Fruits of 2500 Hours of Labor! ________________________________________________________________________________
Date: Jun 30, 2010
Hello all, I bought my 4 last fall, and the tail wheel seemed fine. This spring it see med to stick. I greased the zerk, and it didn't seem to help. I then again greased it about a month later, figuring it may take a little time to work the grease in. Now that I've done that, it seems to almost swivel too easy. Perhaps in your situation, you may need a little more grease. Keep in mind, that all greases are NOT compatible. Some harden when introdu ced to another. Just food for thought. - Jason Edwards RV-4 flying Richland Center, WI. --- On Wed, 6/30/10, HCRV6(at)comcast.net wrote: From: HCRV6(at)comcast.net <HCRV6(at)comcast.net> Subject: Re: RV-List: Lubing The Tail Wheel Fork Bearing... Date: Wednesday, June 30, 2010, 10:39 PM #yiv1863669556 p {margin:0;} Matt, If you find some of that "super lube" stuff please let me know, otherwise a ccept the fact that every oil change you need to disassemble the fork via t he "giant nut" and clean and lube the locking pin and spring and the bearin g shaft.- I learned that the hard way when my locking tail wheel quit loc king after about 150 hours.- The pin had galled because of lack of lube a nd was stuck in the unlock (retracted) position.- The grease fitting that is installed is useless for the reason you state. Small price to pay for the many advantages of having the little wheel in ba ck where it belongs :-). Harry Crosby RV-6 N16CX, 705 hours ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Wednesday, June 30, 2010 8:06:34 PM Subject: RV-List: Lubing The Tail Wheel Fork Bearing... How the heck do you lube the bronze bearing on the tailwheel fork short of taking the giant nut off. -I lubed it up good during initial assembly, th en at about 40 hours, it started to kind of stick, so I dissembled and lube d it again. -Now at 70 its doing it again. -I foolishly put a Zerk fitt ing in the body of the thing, thinking that next time I could just shoot so me lube in there. -Great idea except that it doesn't work for such a tigh t fit. - Is there some "super lube" you can get that will last forever? -I've used both graphite wheel bearing grease and Aeroshell #6 grease. Thanks! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Enjoying Tsp; - - - - - - - - - - & =0A=0A=0A ________________________________________________________________________________
Date: Jul 01, 2010
Matt- I would hope that each wing could in fact support nine times this weight, since by definition that is their job. I screw a lifting eye into the tie down bracket and use a floor jack mounted on a plastic crate to lift each side in turn. A pretty easy job. -GV In a message dated 6/30/2010 8:02:45 P.M. Pacific Daylight Time,
June 01, 2010 - July 01, 2010
RV-Archive.digest.vol-um
