RV-Archive.digest.vol-un
July 01, 2010 - July 26, 2010
dralle(at)matronics.com writes:
1) I could put a short saw horse under the wing tie down and then put a
hydraulic jack on it and lift the side of the airplane up by this point. If
I just gently lift the plane by hand at this point, it seems like that's an
awful lot of weight to be lifting that far out on the wing. Can the spars
really handle this?
Subject: | Re: Jacking Point |
Hey Matt,
I use two entirely different methods to jack up my RV-8 and both systems wo
rk very well. The first method uses a commonly available bottle jack from H
arbor Freight. Many builders before me have made their own version of a win
g jack based upon the HF bottle jack and my interpretation-is no exceptio
n. Investing-just a few hours work using off the shelf parts, the Harbor
Freight bottle jack be quickly transformed into a-very useful wing jack.
http://tinyurl.com/7eb5ed
The second method I use is the "Handy Jack."- Using leverage, it too-is
a quick and very easy way to lift an RV8-wheel clear of the floor.
http://www.rvtraining.com/html/atp//html/products_pics.html#RVJACK
Rick Galati
RV6A N307R
RV-8 N308R
From: | "Dale Ensing" <densing(at)carolina.rr.com> |
Subject: | Re: Lubing The Tail Wheel Fork Bearing... |
Matt,
I suggest you try/use Molykote G-n paste. It is a molybdenum disulfide paste
(much higher moly content than a moly containing grease) that is especially
good for sliding friction and the minimal back and forth movement of the
tail wheel gear. It will stay in place better and reduces the "stick -
slip" you get when using a grease when there is minimal movement of the
shaft in the bushing.
Apply a good film to the bearing, shaft and locking pin with your fingers or
by brush after cleaning the parts.
BTW I use G-n paste on the friction washers and bushing on the front wheel
of my 6A. It does a much better job of allowing a smooth "brake out" of the
front wheel fork when steering yet maintains the necessary brake out force
important to a free swiveling front wheel.
Link to G-n paste
http://www.dowcorning.com/applications/search/products/details.aspx?prod=01889877&type=PROD
There is also a link on this page to find a distributor in your area. It is
available in an 80 gram tube which should be enough for several applications
over the years.
Dale Ensing
RV-6A
----- Original Message -----
Sent: Wednesday, June 30, 2010 11:06 PM
Subject: RV-List: Lubing The Tail Wheel Fork Bearing...
> How the heck do you lube the bronze bearing on the tailwheel fork short of
> taking the giant nut off. I lubed it up good during initial assembly,
> then at about 40 hours, it started to kind of stick, so I dissembled and
> lubed it again. Now at 70 its doing it again. I foolishly put a Zerk
> fitting in the body of the thing, thinking that next time I could just
> shoot some lube in there. Great idea except that it doesn't work for such
> a tight fit.
> Is there some "super lube" you can get that will last forever? I've used
> both graphite wheel bearing grease and Aeroshell #6 grease.
> Thanks!
> Matt Dralle
> RV-8 #82880 N998RV
> http://www.mattsrv8.com - Matt's RV-8 Construction Blog
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
> Status: Enjoying The Fruits of 2500 Hours of Labor!
Rick,
Did you make any kind of stabilizing frame for the bottle jack or use them
as purchased? Would be interested in pictures or description if you made
stabilizer.
I too have a set of the HF bottle jacks. A "pocket" was created on the top
of the shaft to fit the plastic screw in buttons in the tie down fixtures
( from Van's) Did this with a large counter sink tool. This makes a secure
point at the wing. But, I am always a little concerned about the jack
tipping while jacking or if I bump the airplane while on the jacks - even
with the other wheel chocked.
Dale Ensing
RV-6A
Sent: Thursday, July 01, 2010 7:26 AM
Subject: RV-List: Re: Jacking Point
Hey Matt,
work very well. The first method uses a commonly available bottle jack from
Harbor Freight. Many builders before me have made their own version of a
wing jack based upon the HF bottle jack and my interpretation is no
exception. Investing just a few hours work using off the shelf parts, the
Harbor Freight bottle jack be quickly transformed into a very useful wing
jack.
The second method I use is the "Handy Jack." Using leverage, it too is a
quick and very easy way to lift an RV8 wheel clear of the floor.
Rick Galati
RV6A N307R
RV-8 N308R
Dale Ensing wrote:
> Rick,
> stabilizer.
Dale,
I made up the jack in about 4 hours using a 2'X2'X3/4" precut piece of plywood
as its base, two 3-1/2" band clamps and one 10' stick of 1/2" electrical conduit
all purchased from Home Depot. In practice I find the jack to be very stable.
Perhaps it helps that the ball joint I fashioned from a spare tie-down ring
is allowed a small degree of movement within its socket on the jack itself and
that allows the ball to find its own center under load while lifting the wing.
Rick
http://forums.matronics.com/viewtopic.php?p=303245#303245
I didn't see it mentioned in this thread. Avery makes this:
http://www.averytools.com/p-181-rv-jack-stand.aspx and it's what I used
when changing tires on my RV. After seeing what happens to an airplane
wing when it falls off the jack (no, not me. It was a Bonanza), I
thought this method made a lot of sense and it worked very well.
Bob Skinner
> when changing tires on my RV. After seeing what happens to an airplane wing
> when it falls off the jack (no, not me. It was a Bonanza), I thought this
> Bob Skinner
But then how do you get the wheel off?
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
On 2010-07-01, at 10:41 , Bob wrote:
> I didn't see it mentioned in this thread. Avery makes this: http://www.averytools.com/p-181-rv-jack-stand.aspx and it's what I used when changing tires on my RV. After seeing what happens to an airplane wing when it falls off the jack (no, not me. It was a Bonanza), I thought this method made a lot of sense and it worked very well.
That won't work in Matt's RV-8, as it doesn't have hollow axles.
Kevin Horton
RV-8
Ottawa, Canada
http://www.kilohotel.com/rv8
SNIP >>>>>>>How the heck do you lube the bronze bearing on the tailwheel fork short
of taking the giant nut off. I lubed it up good during initial assembly,
then at about 40 hours, it started to kind of stick, so I dissembled and lubed
it again.
Now at 70 its doing it again. I foolishly put a Zerk fitting in the body of the
thing, thinking that next time I could just shoot some lube in there. Great
idea except that it doesn't work for such a tight fit.
Is there some "super lube" you can get that will last forever? I've used both
Thanks!
Matt<<<<<<<<<<<<<<<<<<<<<http://www.flyboyaccessories.com/store/index.php?main_page=index&cPath=66&zenid=7p0ddvhbkde4177qjrc2gtdru1
Vince Frazier
Flyboy Accessories
3963 Caborn Road
Mount Vernon, IN 47620
812-464-1839
1-888-8FLYBOY
1-888-835-9269
Subject: | Airventure tickets |
We decided not to attend OSH this year, but not before buying our online ti
ckets. =C2- I have two daily member and spouse tickets that are nonrefund
able but completely transferrable. =C2- I have $92 into them but would pa
rt with them for $50.=C2- Reply to cknauf(at)comcast.net .
For my RV8=2C I have the handy jack from avery. Works great and nothing is
in the way when taking the wheel off. http://www.averytools.com/p-913-the
-handy-jack-eldorado-aviation.aspx
Paul Rice
> Subject: Re: RV-List: Re: Jacking Point
> From: khorton01(at)rogers.com
> Date: Thu=2C 1 Jul 2010 12:35:44 -0400
off the jack (no=2C not me. It was a Bonanza)=2C I thought this method mad
> That won't work in Matt's RV-8=2C as it doesn't have hollow axles.
> Kevin Horton
> RV-8
> Ottawa=2C Canada
Subject: | Airventure tickets - SOLD |
Tickets are sold.=C2- Thanks for your interest.
Subject: | tailwheel lube and maintenance |
SNIP>>>>>>A little wear and the zerk fitting will do just fine. Patience,
grasshopper(s).
Linn<<<<<<Date: | Jul 02, 2010 |
From: | Linn Walters <pitts_pilot(at)bellsouth.net> |
Subject: | Re: tailwheel lube and maintenance |
No apologies necessary Vince. I was only addressing the greasing of the
shaft. I've found that the locking mechanism works better with graphite
instead of grease. As you said, keep it clean and lubed (whatever
method you use) and it'll work perfectly.
Linn
> grasshopper(s).
> Linn<<<<<<
> I hate to argue online, but Linn is incorrect on this one. Regardless of how
furiously you pump grease into that zerk it will NEVER properly lube the locking
pin, nor will it effectively remove the dirt and grit that has accumulated
in the mechanism. Since the rotation of the shaft is actually quite minimal
and the locking pin function is what makes this system tick, it behooves the users
to keep the pin area properly maintained, cleaned, and lubed. Do that and
you'll minimize any steering problems.
> My apologies to Linn for disagreeing.
> Vince Frazier
> Flyboy Accessories
> 3963 Caborn Road
> 812-464-1839
> 1-888-8FLYBOY
> 1-888-835-9269
Subject: | Re: Highest Quality...? |
Well, if I'd of been paying attention, I could have rotated them and easily gotten
another 70 from them probably. But, I just got the new Goodyear Flight Custom
III's installed last night and then went out and shot some landings. WHAT
A DIFFERENCE! The GY's are 10 times the quality of the stock one's. The sidewalls
are definately far more rigid and the tread is thicker. The rubber seems
a lot "harder" too.
I noticed that the old ones had a "flat spot" when I was removing them. I just
thought "rough" was the way the RV's were suppose to ride. Now the plane really
rolls smoothly. It also seems to track down the runway much better. Wheel
landings are a thing of beauty, and I've almost got that three-point licked.
I was happy to note that my brakes barely look used! Since the brake incident
and subsequent replacement of the wheels and brakes, I have been ever vigilant
about staying off the brakes. I try to taxi like I don't have brakes. Guess
its paying off!
Yeah, I've been flying a LOT! I just can't seem to not head out to the hanger
after work and fly around. My Chevron av-gas bill was $2700 last month! I just
can't believe how nice the RV-8 is to fly. What a joy.
For those that are still slaving away, *keep at it*! It is worth all of the time
you invest in it...
Best,
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Enjoying The Fruits of 2500 Hours of Labor...
At 02:42 PM 6/28/2010 Monday, you wrote:
>Matt,
>The Van's tires are worn out after only 70 hours? And how in the world did you
put 70 hours on it already? You have been doing some serious flying! I've
got 84 on my originals and I've still got another 20-30 hours left in them. But,
they are not high quality tires.
>I'm ready to order new tires and tubes so I've talked to a number of other RV
owners asking their advice. I've always liked Michelin, but the RV guys near
me all recommend using the Goodyear Flight Custom III. They tell me the sidewalls
are much stiffer and thread is deeper and overall the tire is longer lasting.
Also, many local guys recommended the Michelin Airstop tubes. They tell
me they have no air leaks with the Airstop tubes. With my original tubes, I
have to air up the tires every 6 weeks. The Goodyears have kevlar in the sidewalls
which apparently stiffens the sidewall.
>So, I'm ordering a set of GY tires and Michelin tubes.
>FYI.
>Stan Sutterfield
><http://www.rv-8a.net>www.rv-8a.net
>Its almost time for a new set of tires on the 'ol RV-8. What are the very best
>tires for the RV wheels? I'd like something that will last a little longer than
>70 hours.
Subject: | Re: Update On RV-8 Princeton Fuel Probe Installation... |
At 05:40 PM 6/28/2010 Monday, you wrote:
>On 06/21/2010 12:00 AM, Matt Dralle wrote:
>>All that
>>matters at this point is that they are both working and are exceptionally accurate
in
>>the 15-0 gallon range which is where it counts.
>...and you just *might* owe Princeton an apology for what I *seem* to remember
as some pretty heavy bad-mouthing in your last few posts. But w/o actually going
back into the archives, I may be wrong...
>Regards, J.
>Sonex #325 C-FJNJ, Jabiru 3300a, Prince P-Tip, Aerocarb
>restoring the Johnston Special
>http://cleco.ca
I might have been a little rough on Princeton initially, but considering how annoyed
I was at that prospect of having to replace them, I think I held back pretty
well: :-)
Reference:
http://forums.matronics.com/viewtopic.php?t=69954 and
http://forums.matronics.com/viewtopic.php?t=69999 and
http://forums.matronics.com/viewtopic.php?t=71281
Just having to remove them to adjust the probe tip so that it wasn't touching the
bottom of the tank was a major ordeal. Since in a QB you can see into the
tank when installing them, they should be pre-bent to make sure they don't touch
or have an insulative piece of plastic on the tip.
And why the first three calibrations didn't take is completely baffling. I almost
didn't try to calibrate again for the forth time, but I was just so demoralized
at having to remove them and try to fit floats in, that I just gave the
calibration one more try. Whew, glad I did.
Anyway, I wanted to clear the air and that's why I posted my extended pirep on
the successful calibration finally. I sent the same report to Princeton, GRT,
and the GRT-EFIS forum as well.
I've got about 20 hours on them now since the successful calibration. They remain
about as accurate as I reported. They still give kind of wonky readings when
the tanks are full sometimes. The lower the fuel level, the more accurate
they seem to be. That being said, based on comparisons with the FuelChec DX
flow meter, I wouldn't trust the level probes more than about +- 1.5 gallons or
so (within 3 gallons of actual). But, that's good enough I suppose. I still
rely on the flow meter's fuel "remanding" mostly as it has proved to be reliable
to within .5 gallons or better.
BTW, the FuelChec DX has a really cool feature called the "Switch Tanks" warning.
You set it to the amount of fuel burn you want to keep your tank levels balanced.
For example, I have mine sent to 3 gallons. Every three gallons of fuel
burn, the FuelChec flashes a warning indicating its time to switch tanks.
I've found this really keeps the fuel balanced across the tanks. Its also an
excellent reminder every 20 minutes or so to check the fuel levels.
RV-8 #82880 N998RV
annoyed I
> was at that prospect of having to replace them, I think I held back pretty well:
Hey, Matt...
Glad it all worked out for you!
I've been extremely happy with Princeton senders in two home-builts now, was kind
of
scratching my head at your (and a couple of other's) posts expressing unhappiness
with them.
And believe me, I totally understand your ummm... disappointment at the prospect
of
replacing them! Again, glad all's well.
Regards, J.
http://cleco.ca
| J. Davis, M.Sc. | (computer science) |
| *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca |
I made wine out of raisins so I wouldn't have to wait for
it to age.
--- Steven Wright
N811WT got its airworthiness certificate today. It only took 12 years.
The DAR was actually pretty throrough. He made me start up the engine and
run it for 5 minutes so he could satisfy himself that the engine started
easily and the engine instruments work. Surprised me. Anyway, I'm legal.
Now I have to call the test pilot and get a few hours of dual and I'm good
to go. Woo Hoo!
Tom Sargent, RV-6A
Subject: | Jeppesen Database Updates |
Has anyone found a current Jeppesen Database Update for a Lowrance 2000C?
Subject: | Re: airworthiness |
Congrats, Tom.
Just rolled past 777 hours on the tach here...
Bill Boyd
> to go. Woo Hoo!
> Tom Sargent, RV-6A
From: | "Fisher Paul A." <FisherPaulA(at)johndeere.com> |
Woo Hoo indeed! CONGRATULATIONS TOM! Welcome to the club. You're going to love
it!
Paul A. Fisher
RV-7A N18PF - ~100 hours in 11 months.
-----Original Message-----
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Saturday, July 03, 2010 18:17
Subject: RV-List: airworthiness
The DAR was actually pretty throrough. He made me start up the engine and run
it for 5 minutes so he could satisfy himself that the engine started easily and
Now I have to call the test pilot and get a few hours of dual and I'm good to go.
Woo Hoo!
Tom Sargent, RV-6A
Subject: | Re: Jeppesen Database Updates |
I updated mine (2000C) a few months ago off the lei-extras web site. Was $35 for
the one time update and the instructions are on the web site.
Chris
Tom, congratulations.
It took me a while, too.
> years.
> engine and run it for 5 minutes so he could satisfy himself that the
> engine started easily and the engine instruments work. Surprised
> me. Anyway, I'm legal. Now I have to call the test pilot and get a
> few hours of dual and I'm good to go. Woo Hoo!
> Tom Sargent, RV-6A
Subject: | Prop Governor Cable Bracket |
Can anyone tell me if the Van's bracket VA-153-PC will fit on a PCU5000X governor?
The info on the Van's Web Store site says it will fit an MT or a Hartzell
governor. I have acquired an old bracket of unknown heritage from a neighbor and
the three screw holes are just a bit off from the holes on my PCU governor.
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=303696#303696
Subject: | Wheelpants Part Duex - Air Access Door & Misc... |
I'm happy to report that my second wheel pant installation on the RV-8 is coming
out very nice. With the Grove gear (I guess), I'm finding that I have to add
a large cutout to clear the rear brake caliper. I didn't do this on the first
set and found that it put undue stress on the whole pant assembly. Now I just
have to figure out how to make a "blister" to cover it. Anyone know of a
premade fiberglass blister about 2.25" wide that I could just epoxy to the pant?
Anyway, here's my real question. Has anyone used these little doors on the sides
of their RV wheelpants to access the valve stem for checking the pressure?
Drilling a 1" hole sounds like just the right amount of work to me at this point...
http://www.aircraftspruce.com/catalog/hapages/accessdoors.php
RV-8 #82880 N998RV
I've been using Kitlog so my friends and family could follow my very slow build.
I've recently purchased a new computer and reloaded the software and the backup
file from my old computer to the new one. The problem is, I can't seem to
update the online version. It says that it connects, but after hours, never
finishes. New computer is running Windows 7 Home Premium if that makes any difference.
I've emailed support but it's a holiday and I thought maybe someone
here had some experience. I'm not much of an IT guy so I need a little help.
Paul Rose
N417PR (res)
RV-9A
http://forums.matronics.com/viewtopic.php?p=303739#303739
Subject: | Re: Wheelpants Part Duex - Air Access Door & Misc... |
--- MIME Errors - No Plain-Text Section Found ---
A message with no text/plain MIME section was received.
The entire body of the message was removed. Please
resend the email using Plain Text formatting.
HOTMAIL is notorious for only including an HTML section
in their client's default configuration. If you're using
HOTMAIL, please see your email application's settings
and switch to a default mail option that uses "Plain Text".
--- MIME Errors No Plain-Text Section Found ---
I don't know the answer, but I'm sure Matt Dralle, who owns KitLog and
so generously provides this list, and participates here, either knows
precisely what you need, or knows who on his staff does.
On 7/4/2010 5:05 PM, PaulR wrote:
> --> RV-List message posted by: "PaulR"
backup file from my old computer to the new one. The problem is, I can't seem
to update the online version. It says that it connects, but after hours, never
difference. I've emailed support but it's a holiday and I thought maybe someone
> Thanks
> Paul Rose
> N417PR (res)
> RV-9A
Have you tried running in windows xp compatibility mode?
> Thanks
> Paul Rose
> N417PR (res)
> RV-9A
> Checked by AVG - www.avg.com
Matt,
I bought a set. Threw them in the trash. They are cheep flimsy pieces of
crap that do not fully close nor ever close the same way. Always out of
alignment. Plastic or metel plugs work much better and are very cheep.
:owes of hpme depot XA department has them.
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle
Sent: Sunday, July 04, 2010 4:24 PM
Subject: RV-List: Wheelpants Part Duex - Air Access Door & Misc...
coming out very nice. With the Grove gear (I guess), I'm finding that I
have to add a large cutout to clear the rear brake caliper. I didn't do
this on the first set and found that it put undue stress on the whole pant
assembly. Now I just have to figure out how to make a "blister" to cover
it. Anyone know of a premade fiberglass blister about 2.25" wide that I
sides of their RV wheelpants to access the valve stem for checking the
pressure? Drilling a 1" hole sounds like just the right amount of work to
me at this point...
RV-8 #82880 N998RV
Matt,
Blow up a balloon and tape it to the inside of the wheelpant. Push the
amount you need thru the hole and tape it in place. Buile the blister over
the balloon and when finished pop the balloon and remove. Much faster and
easier than clay.
me at this point...
RV-8 #82880 N998RV
Matt,
Even with the stock Van's gear legs I had to make a "blister" to clear the brake
caliper. I simply formed the blister on top of the wheel pants with modeling
clay, glassed over the clay, the ground out the original pant material and clay
with a die grinder. Voil, caliper clearance.
As far as the valve stem goes, I just used Michelin airstop tubes that seem to
hold air pressure very well. Your mileage may vary.
Skylor
RV-8
Just Completed Phase 1
Sent from my iPhone.
On Jul 4, 2010, at 7:22 PM, rv6n(at)optonline.net wrote:
> It is very easy to make your own blister. Cover the surrounding area with clear
packing tape or electric tape first, pack modeling clay or play-do over the
area you want the blister and shape it with a knife, spoon or spatula, lay it
over with the fiberglass and let it harden. Peel the new blister off, clean
out the clay and now glass the blister in place where it belongs. It will take
less time than waiting for something off the shelf to be found.
> As for access to the valve stem, drill the hole and use a plastic or metal hole
plug available at your local hardware store.
> Bob Bales
> From: Matt Dralle
> Date: Sunday, July 4, 2010 8:36 pm
> To: rv-list(at)matronics.com, rv7-list(at)matronics.com, rv8-list(at)matronics.com
> > the RV-8 is coming out very nice. With the Grove gear (I
> > guess), I'm finding that I have to add a large cutout to clear
> > the rear brake caliper. I didn't do this on the first set and
> > I just have to figure out how to make a "blister" to cover it.
> > doors on the sides of their RV wheelpants to access the valve
> > stem for checking the pressure? Drilling a 1" hole sounds like
> > Matt Dralle
> > RV-8 #82880 N998RV
I installed and use camloc doors and they work as advertised. It is a clean installation,
close tight and look professional. I purchased mine from B&B, a perennial
vendor at the FlyMart for either $5 or $7.50 each. The only problem is
you must find and have the tire valve lined up correctly with the opening in
order to insert the valve extension but other than than, sure saves a lot of time
because you don't have to remove a wheel pant just to add air to the tire.
It is best to make some sort of permanent mark on the tire for that reason.
I much prefer a genuine aircraft part to cheesy and common SS plugs available
at hardware and big box stores best used to do what they were designed to do...plug
open holes in commercial and residential electric boxes. Personal opinion,
YMMV.
Rick Galati
RV6A N307R
RV-8 N308R
From: | "Ralph & Maria Finch" <ralphmariafinch(at)gmail.com> |
Paul, sounds like a firewall problem. Check settings in Windows Firewall:
Start button -> Control Panel -> Windows Firewall
I use Windows 7 Home Premium and use Kitlog with no problems.
Ralph Finch
Davis, California
RV-9A QB-SA
__________ Information from ESET Smart Security, version of virus signature
database 5251 (20100704) __________
The message was checked by ESET Smart Security.
I did the same. Worked great.
http://blog.bowenaero.com/?p=29
__
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
installation, close tight and look professional. I purchased mine from B&B,
a perennial vendor at the FlyMart for either $5 or $7.50 each. The only
problem is you must find and have the tire valve lined up correctly with the
opening in order to insert the valve extension but other than than, sure
saves a lot of time because you don't have to remove a wheel pant just to
add air to the tire. It is best to make some sort of permanent mark on the
tire for that reason. I much prefer a genuine aircraft part to cheesy and
common SS plugs available at hardware and big box stores best used to do
what they were designed to do...plug open holes in commercial and
residential electric boxes. Personal opinion, YMMV.
Rick Galati
RV6A N307R
RV-8 N308R
Matt:
Save your money=2C a little weight=2C and time on making access to air the
tires. Just remove the front half of the wheel pant. This allow you access
to INSPECT the brakes every time you air the tires.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell=2C
2=2C382+ Flying Hours So. CA=2C USA
Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb
ox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O
N:WL:en-US:WM_HMP:042010_1
Matt=2C
I have them on my 8=2C the work=2C but it really is not enough room to see
what you are doing. A more important thing to note is that the valve exten
sion I have got cross threaded part way on and air started to leak out and
I couldn't get it off. The wheel pant contacted the ground as the tire got
lower and cracked out one of the mounting holes. Now I just remove the fr
ont half of the pant to add air.
Good Luck=2C
Paul
> From: dsvs(at)ca.rr.com
> Subject: RE: RV-List: Wheelpants Part Duex - Air Access Door & Misc...
> Date: Sun=2C 4 Jul 2010 23:52:16 -0700
> Matt=2C
> Sent: Sunday=2C July 04=2C 2010 4:24 PM
> To: rv-list(at)matronics.com=3B rv7-list(at)matronics.com=3B rv8-list@matronics
.com
> coming out very nice. With the Grove gear (I guess)=2C I'm finding that I
t
> Anyway=2C here's my real question. Has anyone used these little doors on
the
> me at this point...
> Matt Dralle
> RV-8 #82880 N998RV
From: | "Kyle Boatright" <kboatright1(at)comcast.net> |
Matt,
The easy solution is to use 7/8" or 1" snap plugs from the electrical
section of your local hardware store. They come in plastic or steel, and
cost ~$1.00 ea, so if you lose one, you can replace it for nearly
nothing. If you want, you can even paint the steel ones, although they
are polished when you get 'em. They just snap in and out, so you don't
have to rivet anything to the wheel pant and worry about the rivets
working in the fiberglass over time.
IIRC, the distance from the wheel axle to the air valve is ~2", but you
should check that before you go drilling any holes.
Kyle Boatright
Kyle Boatright wrote:
> Matt,
> and cost ~$1.00 ea, so if you lose one, you can replace it for nearly
> don't have to rivet anything to the wheel pant and worry about the
> rivets working in the fiberglass over time.
But you do have to worry about the goof plugs tearing up that hole in
the fiberglass. My Pitts has plugs in the wings where you access the
flying/landing wires ..... kinda like a inspection plate but about 1"
dia or so with a screw in the middle to clamp the plug down. It'll be
what I use. I put the 90 degree stem tubes in and will use the
extension to air 'em up.
Linn
> you should check that before you go drilling any holes.
> Kyle Boatright
So Ralph,
What should the firewall settings be? Remember, I'm not to much of an IT guy.
I still believe in phones with cords connected to them.
Paul
Paul Rose
N417PR (res)
RV-9A
http://forums.matronics.com/viewtopic.php?p=303863#303863
From: | Charlie England <ceengland(at)bellsouth.net> |
Subject: | Re: For Sale: Hartzell extended hub prop, Precision fuel injection, |
front induction sump
On 7/4/2010 11:15 PM, Charlie England wrote:
> I have for sale a nearly new Hartzell HC-M2YR-1BF extended hub prop.
> Also available, a used governor & high pressure line for this prop.
> This is the prop that fit's James' 'long' cowl without the need for an
> extension. The prop was installed new on a Mustang II, and removed
> when the builder retired the airframe with around 100 hrs on the prop
> (he didn't want to worry about liability when he quit flying the plane).
> I also have available a sump & intake tubes for a parallel valve O-360
> that is set up for a forward facing servo. It's a sump from an A-1x
> series engine that originally had a rear induction, modified by a
> certified engine shop for a forward facing injector. The sump & intake
> tubes will fit an unmodified Rv-x motor mount (unlike the 'C' series
> sumps). The servo mount position appears to be within fractions of an
> inch of the OEM Lyc forward facing servo, based on comparing pics of
> the OEM part to this one.
> Additionally, I have a Precision EX5VA1 fuel injection system,
> complete from the firewall to the heads, including the flex lines with
> firesleeve, high pressure pump, servo, distribution block, injector
> lines, and injectors. This system came off an RV-7 with less than 10
> hours (wrecked). This system is 'as new', if it was still in the
> packing, you couldn't tell it had ever been installed.
> If you're interested in any of these items, email me or give me a call
> at 601-879-9596 & we can discuss price (prices will be very reasonable).
> Thanks,
> Charlie
Correction: the prop's model number is HC-M2YR-1BF.
I agree with Gary IF you have a good inner tube that holds air reasonably w
ell. With Van's supplied tubes it was a one-a-week deal. Too often to remov
e the wheel pant front in my opinion.
Dale
To: RV List
Sent: Monday, July 05, 2010 9:44 AM
Subject: RE: RV-List: Re: Wheelpants Part Duex - Air Access Door & Misc...
Matt:
Save your money, a little weight, and time on making access to air the ti
res. Just remove the front half of the wheel pant. This allow you access to
Gary A. Sobek
2,382+ Flying Hours So. CA, USA
Hotmail has tools for the New Busy. Search, chat and e-mail from your inb
ox. Learn more.
On 7/3/2010 7:46 PM, Chris Hand wrote:
> --> RV-List message posted by: Chris Hand
for the one time update and the instructions are on the web site.
> Chris
> On Jul 3, 2010, at 5:44 PM, Pete& Delee<4680(at)att.net> wrote:
>> --> RV-List message posted by: Pete& Delee<4680(at)att.net>
I just talked to Lowrance Tech. Support and they told me their latest
update is April and they are talking to Jeppesen for current updateds.
He had no idea how long it will take if it will happen at all.
NOT A GOOD SIGN!!!!!
I took the wheelpant install several steps further on my Rocket, to make it
far, far easier to do routine maintenance on the brakes/tires. I used Van's
wheelpants since I have larger 380x150x5 tires, and fabricated 304 stainless
brackets. The inner brackets are oriented vertically so that the attach
points fall under the overlapping seams of the wheelpants--one doesn't have
to crawl into an awkward position to attach the aft screws...also the
bracket attach screws become completely hidden when the front half of the is
in place. I reinforced the wheelpants with a bit of carbon fiber to stiffen
things up on the inboard sides. Since the front half of the wheelpant is
now no longer structural as it doesn't attach to the support brackets
directly, I was able to use the small SK27 Skybolt camlocs, and installed
five of them around the circumference. The front of the wheelpant comes on
in 5 seconds or less, and can have the whole wheelpant off in under 30
seconds. No fooling around with doors, air extensions, and rolling the
airplane around to fill the tires...cleaner installation that turned out
much stronger than the stock setup.
Bob Japundza
RV-6 flying F1 under const.
On Mon, Jul 5, 2010 at 9:44 AM, RV6 Flyer wrote:
> Matt:
> Gary A. Sobek
> inbox. Learn more.<http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1>
Hey Bob,
How about a picture of your wheel pants. This sounds like a really nice
project.
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 7/6/2010 11:08:07 A.M. Pacific Daylight Time,
rocketbob(at)gmail.com writes:
it far, far easier to do routine maintenance on the brakes/tires. I used
Van's wheelpants since I have larger 380x150x5 tires, and fabricated 304
stainless brackets. The inner brackets are oriented vertically so that the
attach points fall under the overlapping seams of the wheelpants--one doesn't
have to crawl into an awkward position to attach the aft screws...also the
is in place. I reinforced the wheelpants with a bit of carbon fiber to
stiffen things up on the inboard sides. Since the front half of the wheelpant
is now no longer structural as it doesn't attach to the support brackets
directly, I was able to use the small SK27 Skybolt camlocs, and installed five
of them around the circumference. The front of the wheelpant comes on in
seconds. No fooling around with doors, air extensions, and rolling the airplane
around to fill the tires...cleaner installation that turned out much
Bob Japundza
On Mon, Jul 5, 2010 at 9:44 AM, RV6 Flyer <_rv6_flyer(at)hotmail.com_
(mailto:rv6_flyer(at)hotmail.com) > wrote:
Matt:
tires. Just remove the front half of the wheel pant. This allow you access to
Gary A. Sobek
inbox. _Learn more._
(http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1)
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com _blank">http://www.matronics.com/contribution
(http://www.matronics.com/Navigator?RV-List)
(http://www.matronics.com/contribution)
The Michelin tubes that I have do not leak. I added a couple of pounds of
air on Sunday July 4=2C 2010. According to my logbook=2C last time I adde
d was July 10=2C 2009.
They tubes that Van supplied me needed air once a month.
Gary A. Sobek
Subject: Re: RV-List: Re: Wheelpants Part Duex - Air Access Door & Misc...
Date: Tue=2C 6 Jul 2010 07:16:55 -0400
air reasonably well. With Van's supplied tubes it was a one-a-week deal. To
o
often to remove the wheel pant front in my opinion.
Dale
RV6
Flyer
To: RV List
Sent: Monday=2C July 05=2C 2010 9:44 AM
Matt:
making access to air the tires. Just remove the front half of the wheel p
ant.
This allow you access to INSPECT the brakes every time you air the tires.
Gary A. Sobek
nbox.
Learn more.
ics.com
The New Busy is not the old busy. Search=2C chat and e-mail from your inbox
N:WL:en-US:WM_HMP:042010_3
I seem to remember that there is lister based in Salida, CO. If you are
still on the list, please reply off-list. I recently passed through the
area and I am looking for info regarding the local area. Thanks.
Ivan Haecker -4 1620 hrs. S. Cen. TX
baremetl(at)gvtc.com
From: | Tracy Crook <tracy(at)rotaryaviation.com> |
Ivan,
I don't live there full time but I do spend several months a year at my
place about 30 mi South of Salida. Love the area. What kind of info you
looking for?
Tracy Crook -4 1800 hrs -8 30 hrs.
> still on the list, please reply off-list. I recently passed through the area
Tracy,
I'm looking for a place to spend summers when I retire (two or three
years, I hope). I have lots of questions about flying activity in the
area, common weather conditions, hangar availability, etc. Probably more
questions than everybody on the list wants to hear about. I'd love to
discuss them, but probably better off list. Thanks for your interest.
Ivan Haecker
Sent: Tuesday, July 06, 2010 8:38 PM
Subject: Re: RV-List: Salida, CO
Ivan,
my place about 30 mi South of Salida. Love the area. What kind of info
you looking for?
are still on the list, please reply off-list. I recently passed through
the area and I am looking for info regarding the local area. Thanks.
I've reduced the asking price on my 6A to $52K. It's a 0360A1A
constant-speed slider with 542 hours on factory-new (when built in 1999)
FWF. Hangared near San Antonio.
Won't take up space here...details and pix on B-stormers and TAP online.
Email or call for more info. Jim 830/537-3508
Here is the official word:
On 7/6/2010 10:17 AM, Pete & Delee wrote:Thank you for your inquiry.
Unfortunately the Jeppesen download site is experiencing technical
difficulties and will be offline approximately 8-10 weeks or until
further notice. We apologize for any inconvenience this has caused.
Please let us know if we may be of further assistance.
Barbara
LEI Extras
Division of Navico Inc.
Hi Michael, when I get a moment I will take some pics...just bugs me to see
that people are putting blisters on stock installations while I was able to
get the wheelpants to cover 380x150x5 tires and double-puck Grove brakes,
and have room to spare...through just a small bit of outside-of-the-box
thinking. It would be easy-peasy to do with the RV8 gear.
Bob Japundza
On Tue, Jul 6, 2010 at 3:03 PM, wrote:
> Hey Bob,
> project.
> Regards,
> Michael Wynn
> RV 8 Finishing
> San Ramon, CA
> Regards,
> Bob Japundza
>> Matt:
>> Gary A. Sobek
> ="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
> ms.matronics.com/">http://forums.matronics.com
> tp://www.matronics.com/contribution">http://www.matronics.com/contribution
http://secretosdelalmacen.com.ar/home.php
Subject: | Dont click on the URL on last msg in Mon night |
Only one msg yhesterday, came in just before midnight, only has a URL
adr. It takes you to a malisious site. Charlie H
Here are the pics guys.
http://picasaweb.google.com/rocketbob/WheelpantPics?authkey=Gv1sRgCLil3-T8krfg2AE&feat=directlink
Bob Japundza
> Regards,
> Bob Japundza
>> Hey Bob,
>> project.
>> Regards,
>> Michael Wynn
>> RV 8 Finishing
>> San Ramon, CA
>> doesn't have to crawl into an awkward position to attach the aft
>> screws...also the bracket attach screws become completely hidden when the
>> front half of the is in place. I reinforced the wheelpants with a bit of
>> carbon fiber to stiffen things up on the inboard sides. Since the front
>> half of the wheelpant is now no longer structural as it doesn't attach to
>> the support brackets directly, I was able to use the small SK27 Skybolt
>> camlocs, and installed five of them around the circumference. The front of
>> the wheelpant comes on in 5 seconds or less, and can have the whole
>> wheelpant off in under 30 seconds. No fooling around with doors, air
>> extensions, and rolling the airplane around to fill the tires...cleaner
>> installation that turned out much stronger than the stock setup.
>> Regards,
>> Bob Japundza
>>> Matt:
>>> Gary A. Sobek
Subject: | For Sale: RV7 Emp, QB Wings, QB Fuse - North Carolina |
See my listing on VAF:
http://www.vansairforce.com/community/showthread.php?t=60219
RV-7 with a tip-up canopy, qb wings and qb fuse. Kit is located in
Denver, N.C. More photos can be found on my website www.therv7.com.
Asking $23,000. Thanks for looking.
http://ecutrip.the-best-web-sites.com/web/about.php
It's about time to start researching the options for liability/hull insurance for
my RV-7. I currently carry Avemco on another plane. Does anyone have recommendations
to share regarding the best value for the RV's?
Thanks!
Wade Roe
EAA 557
RV-7 final touches
Aeronca 7-AC flying
Subject: | Re: RV insurance |
Nationair
877-475-5860
They speak RV.
Sal
N898SC
Lakeland FL
N2504E 7ac ......ready for cover
Sent: Thu, Jul 15, 2010 2:16 pm
Subject: RV-List: RV insurance
nce
for my RV-7. I currently carry Avemco on another plane. Does anyone have
recommendations to share regarding the best value for the RV's?
Thanks!
Wade Roe
EAA 557
RV-7 final touches
Aeronca 7-AC flying
Try Jenny Estes @ Nationair - jestes(at)nationair.com / 877-475-5860
Randy Utsey
randy(at)djdist.com
www.djdist.com
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Wade Roe
Sent: Thursday, July 15, 2010 2:17 PM
Thanks!
Wade Roe
EAA 557
RV-7 final touches
Aeronca 7-AC flying
From: | "Bill Schlatterer" <billschlatterer(at)sbcglobal.net> |
Just got two quotes from Jenny Estes for my 7. Usual coverage including
first flight, 100k hull, etc. $1,800 from Chartis and $2,100 from Global.
They have been doing my builders risk and it has been very reasonable. Great
service and follow-up from Jenny.
Bill S
7a flying next month
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Randy Utsey
Sent: Thursday, July 15, 2010 1:29 PM
Subject: RE: RV-List: RV insurance
Randy Utsey
randy(at)djdist.com
www.djdist.com
insurance for my RV-7. I currently carry Avemco on another plane. Does
anyone have recommendations to share regarding the best value for the RV's?
Thanks!
Wade Roe
EAA 557
RV-7 final touches
Aeronca 7-AC flying
I would say that, if you have AIG, drop them and go Global. JMO.
-GV
In a message dated 7/15/2010 11:20:45 A.M. Pacific Daylight Time,
wroe1(at)dbtech.net writes:
insurance for my RV-7. I currently carry Avemco on another plane. Does anyone
Subject: | For Sale: RV7 Emp w/QB Wings + QB Fuse - North Carolina |
I'm sending this again. I don't think the first time worked (I never got
the email).
Listing on VAF:
Asking $23,000. May be willing to sell the tail seperate from the
wing/fuse if needed. Thanks for looking.
From: | "Richard E. Tasker" <retasker(at)optonline.net> |
Subject: | Re: For Sale: RV7 Emp w/QB Wings + QB Fuse - North Carolina |
I got it the first time. Too bad I am already building a 9A...
Dick Tasker
> got the email).
> Listing on VAF:
> <http://www.therv7.com>. Asking $23,000. May be willing to sell the
> tail seperate from the wing/fuse if needed. Thanks for looking.
> Tim
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Test pilot Joe Shetterly took N811WT off this morning about 7am and stayed
close to Ryan Field for about an hour. I was expecting the usual cooling
problems, but Joe says the cylinder head temps in my Aerosport Power rebuilt
IO-360-B2B stayed below 400 F and the oil temp was at 210, and this is in
Tucson in the summer time. Stall clean was 45 knots - right on Van's
numbers. I made a fiberglass cooling plenum for the thing, maybe that has
had some benefit. At this point I really don't know. It hasn't seemed to
cause a problem at least.
Only squawk was that when he throttled back to 1700 rpm after half an hour
of high cruise operation, the engine loped for a while. He described it as
the typical fuel injected engine loping. Boost pump made no difference.
After a few minutes it settled down and was running smooth when he was in
the pattern. Perhaps that will settle down as the engine breaks-in? I'll
talk to Bart at Aerosport about it.
I haven't flown it yet. I get my transition training on tuesday and
wednesday in an RV-7A at Gillespie Field in San Diego, so I will probably
fly next Friday.
I couldn't have done it without The List!
Tom Sargent, RV-6A with air under the tires after a mere 12 years.
Subject: | Re: N811WT flies! |
Tom:
Like you, I have been on the list for what seems an eternity, and have
noted your posts over the years. Just want to wish you congrats after
a long build time and wish you the best during phase I testing and
beyond.
Well Done!
Best Regards.
Jeff Orear
RV6A N782P
> stayed close to Ryan Field for about an hour. I was expecting the
> usual cooling problems, but Joe says the cylinder head temps in my
> Aerosport Power rebuilt IO-360-B2B stayed below 400 F and the oil
> temp was at 210, and this is in Tucson in the summer time. Stall
> clean was 45 knots - right on Van's numbers. I made a fiberglass
> cooling plenum for the thing, maybe that has had some benefit. At
> this point I really don't know. It hasn't seemed to cause a problem
> at least.
> an hour of high cruise operation, the engine loped for a while. He
> described it as the typical fuel injected engine loping. Boost pump
> made no difference. After a few minutes it settled down and was
> running smooth when he was in the pattern. Perhaps that will settle
> down as the engine breaks-in? I'll talk to Bart at Aerosport about it.
> probably fly next Friday.
Congrats - now the real fun begins.
One of the things I did with my AFP injection system was to reduce the
size of the restrictors from .028 to .024 - I then added one land of
idle mixture adjustment. Mine's an IO360B1F6 with 9.2:1 pistons so
YMMV. You might need a cooling shroud on your fuel pump with fresh air
from the cooling plenum - that should help your running temp on the fuel
pump. I have since balanced the injectors so the all peak within .1gph
- adds to the smoothness.
Break-in and 'regular' oil will drop the temps too.
The list is a treasure trove....
Ralph Capen
RV6A N822AR @ N06 75hrs
To: rv-list
Sent: Saturday, July 17, 2010 3:13 PM
Subject: RV-List: N811WT flies!
stayed close to Ryan Field for about an hour. I was expecting the usual
cooling problems, but Joe says the cylinder head temps in my Aerosport
Power rebuilt IO-360-B2B stayed below 400 F and the oil temp was at 210,
and this is in Tucson in the summer time. Stall clean was 45 knots -
right on Van's numbers. I made a fiberglass cooling plenum for the
thing, maybe that has had some benefit. At this point I really don't
know. It hasn't seemed to cause a problem at least.
described it as the typical fuel injected engine loping. Boost pump made
no difference. After a few minutes it settled down and was running
smooth when he was in the pattern. Perhaps that will settle down as the
Congratulations Tom! Having spend 12.5 years, I too know what "waiting" is
all about. My project, RV-6A N826ME, flew for the first time on May 5th
and just completed Phase 1 testing. It's been so hot and humid here in TN
that I only flew in the mornings and then, usually no longer than 90 min.
each time. The test area starts to seem pretty small towards the end. Good
luck with your project.
Marty in Brentwood TN
fly next Friday.
From: | Charles Rowbotham <crowbotham(at)hotmail.com> |
Hi Tom=2C
CONGRATULLATIONS and WELL DONE !!!!
Chuck & Dave Rowbotham
RV-8A (sold)
RV-9A building
Date: Sat=2C 17 Jul 2010 12:13:59 -0700
close to Ryan Field for about an hour. I was expecting the usual cooling p
roblems=2C but Joe says the cylinder head temps in my Aerosport Power rebui
lt IO-360-B2B stayed below 400 F and the oil temp was at 210=2C and this is
in Tucson in the summer time. Stall clean was 45 knots - right on Van's n
umbers. I made a fiberglass cooling plenum for the thing=2C maybe that has
Tom Sargent=2C RV-6A with air under the tires after a mere 12 years.
Subject: | N826ME - First Flight |
Hi Marty=2C
I apologize for missing your first flight annoucement. First flights are a
significant life accomplishment!
CONGRATULATIONS and WELL DONE !!!!!!!!!
RV-8A (sold)
RV-9A (building)
> From: emrath(at)comcast.net
> My project=2C RV-6A N826ME=2C flew for the first time on May 5th
> that I only flew in the mornings and then=2C usually no longer than 90 mi
n.
d
Congratulations, Tom!!! Well, done!
Post some pictures of your RV-6A. Instrument panel and in the air too!
RV-8 #82880 N998RV
Status: Working on Replacement Wheel Pants & Oil Door
At 12:13 PM 7/17/2010 Saturday, you wrote:
>Test pilot Joe Shetterly took N811WT off this morning about 7am and stayed close
to Ryan Field for about an hour. I was expecting the usual cooling problems,
but Joe says the cylinder head temps in my Aerosport Power rebuilt IO-360-B2B
stayed below 400 F and the oil temp was at 210, and this is in Tucson in the
summer time. Stall clean was 45 knots - right on Van's numbers. I made a fiberglass
cooling plenum for the thing, maybe that has had some benefit. At this
point I really don't know. It hasn't seemed to cause a problem at least.
>Only squawk was that when he throttled back to 1700 rpm after half an hour of
high cruise operation, the engine loped for a while. He described it as the typical
fuel injected engine loping. Boost pump made no difference. After a few
minutes it settled down and was running smooth when he was in the pattern.
Perhaps that will settle down as the engine breaks-in? I'll talk to Bart at Aerosport
about it.
>I haven't flown it yet. I get my transition training on tuesday and wednesday
in an RV-7A at Gillespie Field in San Diego, so I will probably fly next Friday.
Subject: | How to get to several rivets? |
I have just (almost) completed riveting the forward top skin on my RV9A
Slider. However, I am at a loss as to how to rivet these three
locations on each side. The back side of the rivets are buried under
the railing and none of the bucking bars I have will reach any of them.
What has everyone done to set these rivets?
Please Note:
Subject: | Re: RV9-List: How to get to several rivets? |
At 08:04 PM 7/18/2010 Sunday, Richard E. Tasker wrote:
>I have just (almost) completed riveting the forward top skin on my RV9A Slider.
However, I am at a loss as to how to rivet these three locations on each side.
The back side of the rivets are buried under the railing and none of the
bucking bars I have will reach any of them. What has everyone done to set these
rivets?
Hi Richard,
Use some CherryMax CR3214! Done.
Here's a write up I did on using these on my RV-8 Project:
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8%26project=638%26category=2973%26log=94469%26row=192
and
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8%26&project=638%26category=2973%26log=94470%26row=191
RV-8 #82880 N998RV
Status: Redoing Wheelpants & Oil Door...
Subject: | Re: How to get to several rivets? (w/ Links That Work!) |
--> RV9-List message posted by: Matt Dralle
rivets?
Hi Richard,
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2973&log=94469&row=192
and
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2973&log=94470&row=191
RV-8 #82880 N998RV
Subject: | Re: RV9-List: Re: How to get to several rivets? (w/ Links That |
Work!)
Thanks, Matt. I knew there was probably some sort of pulled solution
but didn't know what.
I will order some tonight and then the forward top skin will be done!
Dick Tasker
side. The back side of the rivets are buried under the railing and none of the
rivets?
> Hi Richard,
> and
> Matt Dralle
> RV-8 #82880 N998RV
> Status: Redoing Wheelpants& Oil Door...
Please Note:
Subject: | Re: Instrument Panel Labels |
>Hi Matt,
>I live in Livermore and I'm building an RV10. I contacted Chris at Everon Graphics
in Livermore about a silkscreen for my instrument panel. He said that he
worked on some labels for you and thought that I might like to follow the same
approach. But I didn't really understand how it worked.
>I have heard of an approach in which text is printed on a large sheet of plastic
that is cut to match the outline and cut-outs of the panel. The entire sheet
is adhesively applied to the entire panel. The plastic is available in a choice
of colors; the panel does not get painted.
>Alternatively, some builders will have text printed on a sheet of plastic, cut
the sheet into little pieces that are adhesively applied to the panel, and possibly
spray a clear coat. The plastic might have a color, or might be clear.
>Can you tell me which approach you used? Are you happy with the results? Any
problems working with Chris (he seems a bit slow to return my phone calls)?
>Dave Head
Hi Dave!
Here's my recommendation. Have your completed instrument panel power coated medium-gloss
black. This will give the labels a really good surface to bond too.
I power coated my panel a textured black, and the labels don't like to stick
to that texture nearly as well as a gloss.
Use a good CAD program to layout your instrument panel in 100% exact scale. Be
exact on the placement of instruments and holes. I had my panel CNC cut, so
I already had a CAD diagram to start with that had a very accurate instruemnt
and hole layout.
Take the CAD layout of the instruments and holes, and over lay on a separate layer
all of the silkscreening you want. Use a nice BOLD found. Make sure that
all of your various lettering is all laid out straight using guides in the CAD
program.
Now, print out the whole panel with the labels. If you don't have a wide format
plotter, you can tile the prints and then ScotchTape them together. If you
want, you can email the file and I can plot it out for you and then meet you out
at my hanger sometime.
Using the printout, cut it out, and then tape it to your real panel and sit in
the plane in the normal position. Make sure that you can read all of the labeling
and that it really says what you want it to say. Remember, when you're labeling,
LESS-IS-MORE, so don't get too wordy, but be specific. Also remember
that some instruments may stick out from the panel and might obscure the view
of the label from the normal seating postion.
If you have a stick grip with buttons, you can also add a caricature of the stick
grip with button labels and put this on the panel too. See attached.
Once you're happy with your layout, - and don't be afraid to do a number of iterations
of CAD-Plot-Cut-Fit - output your CAD drawing in a high-resolution PDF.
Use perhaps 2000 dpi or more. You can email this file Chris at Everon Graphics
and he will create the mat-finish label from it directly. Creating the label
is a four layer process and there will be white layer, a black layer, textured
top layer, and a sticky back layer. If you give your power coated panel
to Chris, he will apply the label and cut out all the holes for you. That will
cost extra, however. Chris did a very nice job on my panel and I would recommend
it.
You can also create CAD drawings for all the other little labels around the plane.
I made labels for the cabin lights, alt air, cabin heat, etc. Chris has
a nice die cut machine for cutting out these rectangular sized labels.
Chris can also do full-color labels as well. These cost quite a bit more, but
would be really cool. I just didn't have anything that really screamed out color,
so I went with the black-n-white, in keeping with the rest of my interior.
RV-8 #82880 N998RV
Status: New Wheelpants & Oil Door...
SECTION
HEADER
9
$ACADVER
AC1006
9
$EXTMIN
10
0.179760
20
0.180720
9
$EXTMAX
10
3.815280
20
5.816400
9
$LTSCALE
40
0.024000
9
$PDMODE
70
35
9
$PDSIZE
40
0.019200
ENDSEC
SECTION
TABLES
TABLE
LTYPE
70
9
LTYPE
CONTINUOUS
70
64
Solid line
72
65
73
0.000000
LTYPE
DASHED
70
64
__ __ __ __ __ __ __ __ __ __ __ __ __ __ __
72
65
73
0.000180
49
0.000120
49
-0.000060
LTYPE
HIDDEN
70
64
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
72
65
73
0.000090
49
0.000060
49
-0.000030
LTYPE
CENTER
70
64
____ _ ____ _ ____ _ ____ _ ____ _ ____ _ ____
72
65
73
0.000480
49
0.000300
49
-0.000060
49
0.000060
49
-0.000060
LTYPE
PHANTOM
70
64
_____ _ _ _____ _ _ _____ _ _ _____ _ _ ____
72
65
73
6
40
0.000600
49
0.000300
49
-0.000060
49
0.000060
49
-0.000060
49
0.000060
49
-0.000060
LTYPE
DOT
70
64
65
73
0.000060
49
0.000000
49
-0.000060
LTYPE
DASHDOT
70
64
__ . __ . __ . __ . __ . __ . __ . __ . __ . __
72
65
73
0.000240
49
0.000120
49
-0.000060
49
0.000000
49
-0.000060
LTYPE
BORDER
70
64
__ __ . __ __ . __ __ . __ __ . __ __ . __ __
72
65
73
6
40
0.000420
49
0.000120
49
-0.000060
49
0.000120
49
-0.000060
49
0.000000
49
-0.000060
LTYPE
DIVIDE
70
64
__ . . __ . . __ . . __ . . __ . . __ . . __
72
65
73
6
40
0.000300
49
0.000120
49
-0.000060
49
0.000000
49
-0.000060
49
0.000000
49
-0.000060
LTYPE
DOTDOT
70
64
65
73
5
40
0.000132
49
-0.000060
49
0.000000
49
-0.000060
49
0.000000
49
-0.000060
ENDTAB
TABLE
STYLE
70
8
STYLE
70
SN0
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ITALICC
STYLE
70
68
SV0
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ITALICC
STYLE
70
SN1
40
0.000000
41
0.000240
50
0.000000
71
0.000000
CYRILLIC
STYLE
70
68
SV1
40
0.000000
41
0.000240
50
0.000000
71
0.000000
CYRILLIC
STYLE
70
SN2
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
STYLE
70
68
SV2
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
STYLE
70
SN3
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
STYLE
70
68
SV3
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
ENDTAB
TABLE
LAYER
70
LAYER
FOREGROUND
70
64
62
7
6
CONTINUOUS
LAYER
BACKGROUND
70
65
62
-7
6
CONTINUOUS
LAYER
64
62
7
6
CONTINUOUS
ENDTAB
ENDSEC
SECTION
ENTITIES
POLYLINE
8
FOREGROUND
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
0.000000
20
5.997120
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
4.000080
20
5.997120
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
4.000080
20
-0.002880
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
0.000000
20
-0.002880
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
0.000000
20
5.997120
SEQEND
8
SOLID
8
0.743280
20
5.101200
11
3.355440
21
5.101200
12
0.743280
22
1.976160
13
3.355440
23
1.976160
POLYLINE
8
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
CONTINUOUS
10
0.743280
20
5.101200
VERTEX
8
CONTINUOUS
10
3.355440
20
5.101200
VERTEX
8
CONTINUOUS
10
3.355440
20
1.976160
VERTEX
8
CONTINUOUS
10
0.743280
20
1.976160
VERTEX
8
CONTINUOUS
10
0.743280
20
5.101200
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.640320
VERTEX
8
7
6
CONTINUOUS
10
1.777440
20
3.654960
VERTEX
8
7
6
CONTINUOUS
10
1.800000
20
3.670800
VERTEX
8
7
6
CONTINUOUS
10
1.805040
20
3.680160
VERTEX
8
7
6
CONTINUOUS
10
1.806240
20
3.691920
VERTEX
8
7
6
CONTINUOUS
10
1.805280
20
3.717360
VERTEX
8
7
6
CONTINUOUS
10
1.803120
20
3.733680
VERTEX
8
7
6
CONTINUOUS
10
1.801920
20
3.739920
VERTEX
8
7
6
CONTINUOUS
10
1.795920
20
3.755520
VERTEX
8
7
6
CONTINUOUS
10
1.787040
20
3.770160
VERTEX
8
7
6
CONTINUOUS
10
1.776960
20
3.780960
VERTEX
8
7
6
CONTINUOUS
10
1.779120
20
3.773040
VERTEX
8
7
6
CONTINUOUS
10
1.780080
20
3.768720
VERTEX
8
7
6
CONTINUOUS
10
1.781040
20
3.763920
VERTEX
8
7
6
CONTINUOUS
10
1.782000
20
3.758160
VERTEX
8
7
6
CONTINUOUS
10
1.782720
20
3.751920
VERTEX
8
7
6
CONTINUOUS
10
1.783200
20
3.745200
VERTEX
8
7
6
CONTINUOUS
10
1.783440
20
3.738000
VERTEX
8
7
6
CONTINUOUS
10
1.783440
20
3.723120
VERTEX
8
7
6
CONTINUOUS
10
1.782960
20
3.716160
VERTEX
8
7
6
CONTINUOUS
10
1.782720
20
3.710400
VERTEX
8
7
6
CONTINUOUS
10
1.782240
20
3.705600
VERTEX
8
7
6
CONTINUOUS
10
1.781520
20
3.701760
VERTEX
8
7
6
CONTINUOUS
10
1.779840
20
3.695280
VERTEX
8
7
6
CONTINUOUS
10
1.777200
20
3.688320
VERTEX
8
7
6
CONTINUOUS
10
1.773360
20
3.681360
VERTEX
8
7
6
CONTINUOUS
10
1.771200
20
3.678000
VERTEX
8
7
6
CONTINUOUS
10
1.766400
20
3.671760
VERTEX
8
7
6
CONTINUOUS
10
1.764480
20
3.668880
VERTEX
8
7
6
CONTINUOUS
10
1.762800
20
3.666000
VERTEX
8
7
6
CONTINUOUS
10
1.761360
20
3.663360
VERTEX
8
7
6
CONTINUOUS
10
1.759440
20
3.657840
VERTEX
8
7
6
CONTINUOUS
10
1.758720
20
3.652320
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.647280
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.640320
SEQEND
8
SOLID
8
15
10
1.740720
20
3.018720
11
1.743600
21
3.050640
12
1.681440
22
3.025680
13
1.680720
23
3.073920
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.740720
20
3.018720
VERTEX
8
7
6
CONTINUOUS
10
1.743600
20
3.050640
VERTEX
8
7
6
CONTINUOUS
10
1.680720
20
3.073920
VERTEX
8
7
6
CONTINUOUS
10
1.681440
20
3.025680
VERTEX
8
7
6
CONTINUOUS
10
1.740720
20
3.018720
SEQEND
8
SOLID
8
15
10
1.680720
20
3.073920
11
1.699920
21
3.074640
12
1.743600
22
3.050640
13
1.744080
23
3.055680
POLYLINE
8
15
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
15
6
CONTINUOUS
10
1.680720
20
3.073920
VERTEX
8
15
6
CONTINUOUS
10
1.699920
20
3.074640
VERTEX
8
15
6
CONTINUOUS
10
1.744080
20
3.055680
VERTEX
8
15
6
CONTINUOUS
10
1.743600
20
3.050640
VERTEX
8
15
6
CONTINUOUS
10
1.680720
20
3.073920
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.680720
20
3.073920
VERTEX
8
7
6
CONTINUOUS
10
1.699920
20
3.074640
VERTEX
8
7
6
CONTINUOUS
10
1.744080
20
3.055680
VERTEX
8
7
6
CONTINUOUS
10
1.743600
20
3.050640
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.134320
20
4.146000
VERTEX
8
7
6
CONTINUOUS
10
2.145120
20
4.141920
VERTEX
8
7
6
CONTINUOUS
10
2.155200
20
4.137360
VERTEX
8
7
6
CONTINUOUS
10
2.160000
20
4.134720
VERTEX
8
7
6
CONTINUOUS
10
2.164560
20
4.132080
VERTEX
8
7
6
CONTINUOUS
10
2.168880
20
4.129680
VERTEX
8
7
6
CONTINUOUS
10
2.172480
20
4.127280
VERTEX
8
7
6
CONTINUOUS
10
2.175600
20
4.125120
VERTEX
8
7
6
CONTINUOUS
10
2.178480
20
4.123200
VERTEX
8
7
6
CONTINUOUS
10
2.183760
20
4.119600
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.241840
20
4.060560
VERTEX
8
7
6
CONTINUOUS
10
2.251440
20
4.036560
VERTEX
8
7
6
CONTINUOUS
10
2.253360
20
4.027440
VERTEX
8
7
6
CONTINUOUS
10
2.252880
20
4.019520
VERTEX
8
7
6
CONTINUOUS
10
2.250960
20
4.011120
VERTEX
8
7
6
CONTINUOUS
10
2.246160
20
4.001040
VERTEX
8
7
6
CONTINUOUS
10
2.231040
20
3.981120
VERTEX
8
7
6
CONTINUOUS
10
2.194320
20
3.940800
VERTEX
8
7
6
CONTINUOUS
10
2.173920
20
3.919920
VERTEX
8
7
6
CONTINUOUS
10
2.166000
20
3.909120
VERTEX
8
7
6
CONTINUOUS
10
2.159760
20
3.896640
VERTEX
8
7
6
CONTINUOUS
10
2.156160
20
3.882240
VERTEX
8
7
6
CONTINUOUS
10
2.154480
20
3.866160
VERTEX
8
7
6
CONTINUOUS
10
2.154720
20
3.847680
VERTEX
8
7
6
CONTINUOUS
10
2.158560
20
3.822240
VERTEX
8
7
6
CONTINUOUS
10
2.167440
20
3.786480
VERTEX
8
7
6
CONTINUOUS
10
2.183520
20
3.734640
VERTEX
8
7
6
CONTINUOUS
10
2.206800
20
3.663840
VERTEX
8
7
6
CONTINUOUS
10
2.223840
20
3.601440
VERTEX
8
7
6
CONTINUOUS
10
2.244000
20
3.511920
VERTEX
8
7
6
CONTINUOUS
10
2.256720
20
3.442080
VERTEX
8
7
6
CONTINUOUS
10
2.267280
20
3.370080
VERTEX
8
7
6
CONTINUOUS
10
2.276640
20
3.289920
VERTEX
8
7
6
CONTINUOUS
10
2.282880
20
3.223440
VERTEX
8
7
6
CONTINUOUS
10
2.289360
20
3.128160
VERTEX
8
7
6
CONTINUOUS
10
2.296080
20
2.989920
VERTEX
8
7
6
CONTINUOUS
10
2.296080
20
2.982240
VERTEX
8
7
6
CONTINUOUS
10
2.297520
20
2.980320
VERTEX
8
7
6
CONTINUOUS
10
2.318160
20
2.977920
VERTEX
8
7
6
CONTINUOUS
10
2.356560
20
2.974080
VERTEX
8
7
6
CONTINUOUS
10
2.393760
20
2.968320
VERTEX
8
7
6
CONTINUOUS
10
2.416080
20
2.963520
VERTEX
8
7
6
CONTINUOUS
10
2.435520
20
2.957520
VERTEX
8
7
6
CONTINUOUS
10
2.450400
20
2.950800
VERTEX
8
7
6
CONTINUOUS
10
2.460240
20
2.943840
VERTEX
8
7
6
CONTINUOUS
10
2.465760
20
2.936640
VERTEX
8
7
6
CONTINUOUS
10
2.468880
20
2.929200
VERTEX
8
7
6
CONTINUOUS
10
2.469600
20
2.918880
VERTEX
8
7
6
CONTINUOUS
10
2.468160
20
2.912640
VERTEX
8
7
6
CONTINUOUS
10
2.464320
20
2.906160
VERTEX
8
7
6
CONTINUOUS
10
2.456640
20
2.899680
VERTEX
8
7
6
CONTINUOUS
10
2.442720
20
2.892960
VERTEX
8
7
6
CONTINUOUS
10
2.422800
20
2.886720
VERTEX
8
7
6
CONTINUOUS
10
2.386320
20
2.878560
VERTEX
8
7
6
CONTINUOUS
10
2.341920
20
2.871840
VERTEX
8
7
6
CONTINUOUS
10
2.323440
20
2.869920
VERTEX
8
7
6
CONTINUOUS
10
2.320800
20
2.868240
VERTEX
8
7
6
CONTINUOUS
10
2.319120
20
2.860800
VERTEX
8
7
6
CONTINUOUS
10
2.318640
20
2.829120
VERTEX
8
7
6
CONTINUOUS
10
2.318640
20
2.786400
VERTEX
8
7
6
CONTINUOUS
10
2.316000
20
2.781840
VERTEX
8
7
6
CONTINUOUS
10
2.310000
20
2.777280
VERTEX
8
7
6
CONTINUOUS
10
2.291760
20
2.768640
VERTEX
8
7
6
CONTINUOUS
10
2.262960
20
2.759280
VERTEX
8
7
6
CONTINUOUS
10
2.236800
20
2.753520
VERTEX
8
7
6
CONTINUOUS
10
2.207520
20
2.749680
VERTEX
8
7
6
CONTINUOUS
10
2.173680
20
2.747040
VERTEX
8
7
6
CONTINUOUS
10
2.122320
20
2.745600
VERTEX
8
7
6
CONTINUOUS
10
2.039520
20
2.746320
VERTEX
8
7
6
CONTINUOUS
10
1.969200
20
2.749680
VERTEX
8
7
6
CONTINUOUS
10
1.929600
20
2.753760
VERTEX
8
7
6
CONTINUOUS
10
1.902720
20
2.758080
VERTEX
8
7
6
CONTINUOUS
10
1.878960
20
2.763840
VERTEX
8
7
6
CONTINUOUS
10
1.856400
20
2.771520
VERTEX
8
7
6
CONTINUOUS
10
1.844400
20
2.777760
VERTEX
8
7
6
CONTINUOUS
10
1.839840
20
2.782560
VERTEX
8
7
6
CONTINUOUS
10
1.838640
20
2.798640
VERTEX
8
7
6
CONTINUOUS
10
1.836960
20
2.898240
VERTEX
8
7
6
CONTINUOUS
10
1.835760
20
2.905200
VERTEX
8
7
6
CONTINUOUS
10
1.831200
20
2.912400
VERTEX
8
7
6
CONTINUOUS
10
1.821600
20
2.919840
VERTEX
8
7
6
CONTINUOUS
10
1.790160
20
2.936160
VERTEX
8
7
6
CONTINUOUS
10
1.782720
20
2.940720
VERTEX
8
7
6
CONTINUOUS
10
1.769760
20
2.951760
VERTEX
8
7
6
CONTINUOUS
10
1.758960
20
2.964480
VERTEX
8
7
6
CONTINUOUS
10
1.750800
20
2.976720
VERTEX
8
7
6
CONTINUOUS
10
1.743360
20
2.993280
VERTEX
8
7
6
CONTINUOUS
10
1.741440
20
3.005280
VERTEX
8
7
6
CONTINUOUS
10
1.741440
20
3.023520
VERTEX
8
7
6
CONTINUOUS
10
1.743360
20
3.052080
VERTEX
8
7
6
CONTINUOUS
10
1.745760
20
3.065760
VERTEX
8
7
6
CONTINUOUS
10
1.750080
20
3.078720
VERTEX
8
7
6
CONTINUOUS
10
1.756800
20
3.090240
VERTEX
8
7
6
CONTINUOUS
10
1.765680
20
3.102000
VERTEX
8
7
6
CONTINUOUS
10
1.776000
20
3.112560
VERTEX
8
7
6
CONTINUOUS
10
1.793760
20
3.125520
VERTEX
8
7
6
CONTINUOUS
10
1.814640
20
3.135600
VERTEX
8
7
6
CONTINUOUS
10
1.850880
20
3.148800
VERTEX
8
7
6
CONTINUOUS
10
1.855440
20
3.152400
VERTEX
8
7
6
CONTINUOUS
10
1.857360
20
3.159120
VERTEX
8
7
6
CONTINUOUS
10
1.857360
20
3.202320
VERTEX
8
7
6
CONTINUOUS
10
1.853040
20
3.365520
VERTEX
8
7
6
CONTINUOUS
10
1.851840
20
3.373200
VERTEX
8
7
6
CONTINUOUS
10
1.844160
20
3.383040
VERTEX
8
7
6
CONTINUOUS
10
1.790880
20
3.443280
VERTEX
8
7
6
CONTINUOUS
10
1.763280
20
3.477120
VERTEX
8
7
6
CONTINUOUS
10
1.755360
20
3.489600
VERTEX
8
7
6
CONTINUOUS
10
1.751280
20
3.503280
VERTEX
8
7
6
CONTINUOUS
10
1.749840
20
3.517200
VERTEX
8
7
6
CONTINUOUS
10
1.749840
20
3.524160
VERTEX
8
7
6
CONTINUOUS
10
1.752720
20
3.535200
VERTEX
8
7
6
CONTINUOUS
10
1.757760
20
3.544800
VERTEX
8
7
6
CONTINUOUS
10
1.767600
20
3.557520
VERTEX
8
7
6
CONTINUOUS
10
1.768560
20
3.561120
VERTEX
8
7
6
CONTINUOUS
10
1.767360
20
3.564000
VERTEX
8
7
6
CONTINUOUS
10
1.738320
20
3.600720
VERTEX
8
7
6
CONTINUOUS
10
1.734480
20
3.606960
VERTEX
8
7
6
CONTINUOUS
10
1.733520
20
3.611760
VERTEX
8
7
6
CONTINUOUS
10
1.734480
20
3.616080
VERTEX
8
7
6
CONTINUOUS
10
1.746240
20
3.629520
VERTEX
8
7
6
CONTINUOUS
10
1.766880
20
3.647760
VERTEX
8
7
6
CONTINUOUS
10
1.797360
20
3.669120
VERTEX
8
7
6
CONTINUOUS
10
1.803120
20
3.676800
VERTEX
8
7
6
CONTINUOUS
10
1.804800
20
3.685440
VERTEX
8
7
6
CONTINUOUS
10
1.805520
20
3.699600
VERTEX
8
7
6
CONTINUOUS
10
1.804800
20
3.717600
VERTEX
8
7
6
CONTINUOUS
10
1.802640
20
3.733680
VERTEX
8
7
6
CONTINUOUS
10
1.799520
20
3.745920
VERTEX
8
7
6
CONTINUOUS
10
1.791360
20
3.762480
VERTEX
8
7
6
CONTINUOUS
10
1.782960
20
3.774240
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.798480
VERTEX
8
7
6
CONTINUOUS
10
1.700640
20
3.848400
VERTEX
8
7
6
CONTINUOUS
10
1.686000
20
3.864240
VERTEX
8
7
6
CONTINUOUS
10
1.675440
20
3.879120
VERTEX
8
7
6
CONTINUOUS
10
1.668240
20
3.892560
VERTEX
8
7
6
CONTINUOUS
10
1.663920
20
3.906000
VERTEX
8
7
6
CONTINUOUS
10
1.662000
20
3.922800
VERTEX
8
7
6
CONTINUOUS
10
1.662000
20
3.943200
VERTEX
8
7
6
CONTINUOUS
10
1.663920
20
3.965040
VERTEX
8
7
6
CONTINUOUS
10
1.669440
20
3.999120
VERTEX
8
7
6
CONTINUOUS
10
1.678560
20
4.035120
VERTEX
8
7
6
CONTINUOUS
10
1.682160
20
4.046160
VERTEX
8
7
6
CONTINUOUS
10
1.690800
20
4.064640
VERTEX
8
7
6
CONTINUOUS
10
1.699440
20
4.077360
VERTEX
8
7
6
CONTINUOUS
10
1.711680
20
4.090320
VERTEX
8
7
6
CONTINUOUS
10
1.721520
20
4.099200
VERTEX
8
7
6
CONTINUOUS
10
1.733040
20
4.108080
VERTEX
8
7
6
CONTINUOUS
10
1.745760
20
4.116480
VERTEX
8
7
6
CONTINUOUS
10
1.759680
20
4.124400
VERTEX
8
7
6
CONTINUOUS
10
1.789680
20
4.138560
VERTEX
8
7
6
CONTINUOUS
10
1.821120
20
4.150800
VERTEX
8
7
6
CONTINUOUS
10
1.850640
20
4.160880
VERTEX
8
7
6
CONTINUOUS
10
1.875120
20
4.167600
VERTEX
8
7
6
CONTINUOUS
10
1.901040
20
4.172160
VERTEX
8
7
6
CONTINUOUS
10
1.923840
20
4.174320
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.794960
20
4.105440
VERTEX
8
7
6
CONTINUOUS
10
1.781280
20
4.103520
VERTEX
8
7
6
CONTINUOUS
10
1.773840
20
4.101120
VERTEX
8
7
6
CONTINUOUS
10
1.766640
20
4.097760
VERTEX
8
7
6
CONTINUOUS
10
1.757520
20
4.090560
VERTEX
8
7
6
CONTINUOUS
10
1.753200
20
4.084800
VERTEX
8
7
6
CONTINUOUS
10
1.749840
20
4.074480
VERTEX
8
7
6
CONTINUOUS
10
1.749120
20
4.066080
VERTEX
8
7
6
CONTINUOUS
10
1.750560
20
4.057200
VERTEX
8
7
6
CONTINUOUS
10
1.754160
20
4.048560
VERTEX
8
7
6
CONTINUOUS
10
1.762800
20
4.038480
VERTEX
8
7
6
CONTINUOUS
10
1.773600
20
4.031280
VERTEX
8
7
6
CONTINUOUS
10
1.787280
20
4.025280
VERTEX
8
7
6
CONTINUOUS
10
1.798800
20
4.022880
VERTEX
8
7
6
CONTINUOUS
10
1.811280
20
4.021920
VERTEX
8
7
6
CONTINUOUS
10
1.828800
20
4.022400
VERTEX
8
7
6
CONTINUOUS
10
1.842240
20
4.025040
VERTEX
8
7
6
CONTINUOUS
10
1.846080
20
4.026480
VERTEX
8
7
6
CONTINUOUS
10
1.857600
20
4.034640
VERTEX
8
7
6
CONTINUOUS
10
1.863360
20
4.042800
VERTEX
8
7
6
CONTINUOUS
10
1.865760
20
4.049040
VERTEX
8
7
6
CONTINUOUS
10
1.867440
20
4.059840
VERTEX
8
7
6
CONTINUOUS
10
1.867200
20
4.067040
VERTEX
8
7
6
CONTINUOUS
10
1.866240
20
4.073040
VERTEX
8
7
6
CONTINUOUS
10
1.861920
20
4.082880
VERTEX
8
7
6
CONTINUOUS
10
1.855680
20
4.090800
VERTEX
8
7
6
CONTINUOUS
10
1.848000
20
4.096560
VERTEX
8
7
6
CONTINUOUS
10
1.840080
20
4.099920
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.750320
20
3.525840
VERTEX
8
7
6
CONTINUOUS
10
1.752720
20
3.516240
VERTEX
8
7
6
CONTINUOUS
10
1.757280
20
3.507600
VERTEX
8
7
6
CONTINUOUS
10
1.763520
20
3.502320
VERTEX
8
7
6
CONTINUOUS
10
1.772400
20
3.499440
VERTEX
8
7
6
CONTINUOUS
10
1.779600
20
3.498960
VERTEX
8
7
6
CONTINUOUS
10
1.792320
20
3.500880
VERTEX
8
7
6
CONTINUOUS
10
1.812000
20
3.508560
VERTEX
8
7
6
CONTINUOUS
10
1.835520
20
3.521280
VERTEX
8
7
6
CONTINUOUS
10
1.864080
20
3.542160
VERTEX
8
7
6
CONTINUOUS
10
1.907280
20
3.579120
VERTEX
8
7
6
CONTINUOUS
10
1.986720
20
3.651840
VERTEX
8
7
6
CONTINUOUS
10
2.012640
20
3.677760
VERTEX
8
7
6
CONTINUOUS
10
2.015760
20
3.682560
VERTEX
8
7
6
CONTINUOUS
10
2.017680
20
3.690720
VERTEX
8
7
6
CONTINUOUS
10
2.016720
20
3.695760
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.766880
20
3.555600
VERTEX
8
7
6
CONTINUOUS
10
1.856640
20
3.636000
VERTEX
8
7
6
CONTINUOUS
10
1.904160
20
3.675120
VERTEX
8
7
6
CONTINUOUS
10
1.945440
20
3.704400
VERTEX
8
7
6
CONTINUOUS
10
1.965600
20
3.716160
VERTEX
8
7
6
CONTINUOUS
10
1.976160
20
3.719760
VERTEX
8
7
6
CONTINUOUS
10
1.984560
20
3.720240
VERTEX
8
7
6
CONTINUOUS
10
1.992000
20
3.718800
VERTEX
8
7
6
CONTINUOUS
10
2.000880
20
3.714000
VERTEX
8
7
6
CONTINUOUS
10
2.013360
20
3.701040
VERTEX
8
7
6
CONTINUOUS
10
2.017680
20
3.693120
VERTEX
8
7
6
CONTINUOUS
10
2.019600
20
3.681360
VERTEX
8
7
6
CONTINUOUS
10
2.020080
20
3.644160
VERTEX
8
7
6
CONTINUOUS
10
2.019600
20
3.406320
VERTEX
8
7
6
CONTINUOUS
10
2.020080
20
3.355200
VERTEX
8
7
6
CONTINUOUS
10
2.019600
20
3.345120
VERTEX
8
7
6
CONTINUOUS
10
2.018400
20
3.336480
VERTEX
8
7
6
CONTINUOUS
10
2.014560
20
3.324480
VERTEX
8
7
6
CONTINUOUS
10
2.007120
20
3.312240
VERTEX
8
7
6
CONTINUOUS
10
1.987920
20
3.290880
VERTEX
8
7
6
CONTINUOUS
10
1.974240
20
3.278640
VERTEX
8
7
6
CONTINUOUS
10
1.969200
20
3.276480
VERTEX
8
7
6
CONTINUOUS
10
1.966320
20
3.276720
VERTEX
8
7
6
CONTINUOUS
10
1.956240
20
3.282720
VERTEX
8
7
6
CONTINUOUS
10
1.892160
20
3.338400
VERTEX
8
7
6
CONTINUOUS
10
1.850400
20
3.376080
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.296080
20
2.982000
VERTEX
8
7
6
CONTINUOUS
10
2.296800
20
2.973360
VERTEX
8
7
6
CONTINUOUS
10
2.298240
20
2.968080
VERTEX
8
7
6
CONTINUOUS
10
2.300880
20
2.962800
VERTEX
8
7
6
CONTINUOUS
10
2.305440
20
2.958240
VERTEX
8
7
6
CONTINUOUS
10
2.312880
20
2.955360
VERTEX
8
7
6
CONTINUOUS
10
2.323920
20
2.954160
VERTEX
8
7
6
CONTINUOUS
10
2.358480
20
2.953920
VERTEX
8
7
6
CONTINUOUS
10
2.389680
20
2.952480
VERTEX
8
7
6
CONTINUOUS
10
2.422800
20
2.948400
VERTEX
8
7
6
CONTINUOUS
10
2.437680
20
2.945280
VERTEX
8
7
6
CONTINUOUS
10
2.450880
20
2.941200
VERTEX
8
7
6
CONTINUOUS
10
2.458320
20
2.937120
VERTEX
8
7
6
CONTINUOUS
10
2.463840
20
2.932320
VERTEX
8
7
6
CONTINUOUS
10
2.466720
20
2.927040
VERTEX
8
7
6
CONTINUOUS
10
2.467200
20
2.921520
VERTEX
8
7
6
CONTINUOUS
10
2.465760
20
2.915760
VERTEX
8
7
6
CONTINUOUS
10
2.462160
20
2.910000
VERTEX
8
7
6
CONTINUOUS
10
2.455680
20
2.904720
VERTEX
8
7
6
CONTINUOUS
10
2.445120
20
2.899680
VERTEX
8
7
6
CONTINUOUS
10
2.429760
20
2.895360
VERTEX
8
7
6
CONTINUOUS
10
2.398080
20
2.889840
VERTEX
8
7
6
CONTINUOUS
10
2.349360
20
2.884320
VERTEX
8
7
6
CONTINUOUS
10
2.317920
20
2.881680
VERTEX
8
7
6
CONTINUOUS
10
2.309280
20
2.880240
VERTEX
8
7
6
CONTINUOUS
10
2.301600
20
2.878080
VERTEX
8
7
6
CONTINUOUS
10
2.289120
20
2.871120
VERTEX
8
7
6
CONTINUOUS
10
2.284080
20
2.866080
VERTEX
8
7
6
CONTINUOUS
10
2.275920
20
2.852880
VERTEX
8
7
6
CONTINUOUS
10
2.270160
20
2.838000
VERTEX
8
7
6
CONTINUOUS
10
2.265600
20
2.816880
VERTEX
8
7
6
CONTINUOUS
10
2.263440
20
2.810160
VERTEX
8
7
6
CONTINUOUS
10
2.256000
20
2.796480
VERTEX
8
7
6
CONTINUOUS
10
2.244960
20
2.783760
VERTEX
8
7
6
CONTINUOUS
10
2.232000
20
2.772720
VERTEX
8
7
6
CONTINUOUS
10
2.215920
20
2.763600
VERTEX
8
7
6
CONTINUOUS
10
2.196960
20
2.755920
VERTEX
8
7
6
CONTINUOUS
10
2.186640
20
2.752800
VERTEX
8
7
6
CONTINUOUS
10
2.164320
20
2.748480
VERTEX
8
7
6
CONTINUOUS
10
2.133120
20
2.745840
VERTEX
8
7
6
CONTINUOUS
10
2.123760
20
2.745600
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.020080
20
3.355920
VERTEX
8
7
6
CONTINUOUS
10
2.018400
20
3.205920
VERTEX
8
7
6
CONTINUOUS
10
2.016960
20
3.157920
VERTEX
8
7
6
CONTINUOUS
10
2.014560
20
3.129360
VERTEX
8
7
6
CONTINUOUS
10
2.012400
20
3.117360
VERTEX
8
7
6
CONTINUOUS
10
2.009040
20
3.110640
VERTEX
8
7
6
CONTINUOUS
10
2.001120
20
3.105600
VERTEX
8
7
6
CONTINUOUS
10
1.967760
20
3.094560
VERTEX
8
7
6
CONTINUOUS
10
1.941840
20
3.083280
VERTEX
8
7
6
CONTINUOUS
10
1.923840
20
3.072720
VERTEX
8
7
6
CONTINUOUS
10
1.912320
20
3.062640
VERTEX
8
7
6
CONTINUOUS
10
1.903680
20
3.051120
VERTEX
8
7
6
CONTINUOUS
10
1.895760
20
3.034320
VERTEX
8
7
6
CONTINUOUS
10
1.891200
20
3.016800
VERTEX
8
7
6
CONTINUOUS
10
1.890000
20
2.998800
VERTEX
8
7
6
CONTINUOUS
10
1.890480
20
2.989920
VERTEX
8
7
6
CONTINUOUS
10
1.893840
20
2.972880
VERTEX
8
7
6
CONTINUOUS
10
1.899120
20
2.959440
VERTEX
8
7
6
CONTINUOUS
10
1.906080
20
2.949600
VERTEX
8
7
6
CONTINUOUS
10
1.919280
20
2.938080
VERTEX
8
7
6
CONTINUOUS
10
1.935360
20
2.928240
VERTEX
8
7
6
CONTINUOUS
10
1.954320
20
2.919840
VERTEX
8
7
6
CONTINUOUS
10
1.987920
20
2.905920
VERTEX
8
7
6
CONTINUOUS
10
1.997520
20
2.899680
VERTEX
8
7
6
CONTINUOUS
10
1.998720
20
2.897760
VERTEX
8
7
6
CONTINUOUS
10
1.998000
20
2.896320
VERTEX
8
7
6
CONTINUOUS
10
1.993200
20
2.895360
VERTEX
8
7
6
CONTINUOUS
10
1.979760
20
2.896080
VERTEX
8
7
6
CONTINUOUS
10
1.960560
20
2.899200
VERTEX
8
7
6
CONTINUOUS
10
1.900560
20
2.914800
VERTEX
8
7
6
CONTINUOUS
10
1.880640
20
2.917680
VERTEX
8
7
6
CONTINUOUS
10
1.870560
20
2.918160
VERTEX
8
7
6
CONTINUOUS
10
1.860720
20
2.917680
VERTEX
8
7
6
CONTINUOUS
10
1.830960
20
2.912400
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.994880
20
2.901840
VERTEX
8
7
6
CONTINUOUS
10
2.010000
20
2.890560
VERTEX
8
7
6
CONTINUOUS
10
2.018160
20
2.881920
VERTEX
8
7
6
CONTINUOUS
10
2.023920
20
2.871840
VERTEX
8
7
6
CONTINUOUS
10
2.026800
20
2.860320
VERTEX
8
7
6
CONTINUOUS
10
2.027520
20
2.854080
VERTEX
8
7
6
CONTINUOUS
10
2.026320
20
2.841120
VERTEX
8
7
6
CONTINUOUS
10
2.022480
20
2.826960
VERTEX
8
7
6
CONTINUOUS
10
2.010960
20
2.802240
VERTEX
8
7
6
CONTINUOUS
10
1.996080
20
2.776800
VERTEX
8
7
6
CONTINUOUS
10
1.988160
20
2.766480
VERTEX
8
7
6
CONTINUOUS
10
1.981200
20
2.760720
VERTEX
8
7
6
CONTINUOUS
10
1.974240
20
2.757120
VERTEX
8
7
6
CONTINUOUS
10
1.961760
20
2.754480
VERTEX
8
7
6
CONTINUOUS
10
1.947360
20
2.753520
VERTEX
8
7
6
CONTINUOUS
10
1.930800
20
2.753520
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.857120
20
3.156720
VERTEX
8
7
6
CONTINUOUS
10
1.856880
20
3.151200
VERTEX
8
7
6
CONTINUOUS
10
1.857120
20
3.148320
VERTEX
8
7
6
CONTINUOUS
10
1.857840
20
3.145200
VERTEX
8
7
6
CONTINUOUS
10
1.859280
20
3.142080
VERTEX
8
7
6
CONTINUOUS
10
1.860960
20
3.138960
VERTEX
8
7
6
CONTINUOUS
10
1.863360
20
3.136080
VERTEX
8
7
6
CONTINUOUS
10
1.866000
20
3.133440
VERTEX
8
7
6
CONTINUOUS
10
1.869120
20
3.131040
VERTEX
8
7
6
CONTINUOUS
10
1.872960
20
3.129120
VERTEX
8
7
6
CONTINUOUS
10
1.877520
20
3.127200
VERTEX
8
7
6
CONTINUOUS
10
1.883040
20
3.125520
VERTEX
8
7
6
CONTINUOUS
10
1.889760
20
3.123840
VERTEX
8
7
6
CONTINUOUS
10
1.897440
20
3.122400
VERTEX
8
7
6
CONTINUOUS
10
1.913760
20
3.120000
VERTEX
8
7
6
CONTINUOUS
10
1.929840
20
3.118560
VERTEX
8
7
6
CONTINUOUS
10
1.937760
20
3.118320
VERTEX
8
7
6
CONTINUOUS
10
1.946400
20
3.118080
VERTEX
8
7
6
CONTINUOUS
10
1.964640
20
3.118080
VERTEX
8
7
6
CONTINUOUS
10
1.973520
20
3.118560
VERTEX
8
7
6
CONTINUOUS
10
1.981920
20
3.119040
VERTEX
8
7
6
CONTINUOUS
10
1.989600
20
3.119760
VERTEX
8
7
6
CONTINUOUS
10
1.996080
20
3.120720
VERTEX
8
7
6
CONTINUOUS
10
2.001600
20
3.122160
VERTEX
8
7
6
CONTINUOUS
10
2.005920
20
3.124080
VERTEX
8
7
6
CONTINUOUS
10
2.009040
20
3.126480
VERTEX
8
7
6
CONTINUOUS
10
2.011440
20
3.129360
VERTEX
8
7
6
CONTINUOUS
10
2.013120
20
3.132240
VERTEX
8
7
6
CONTINUOUS
10
2.014080
20
3.135120
VERTEX
8
7
6
CONTINUOUS
10
2.015520
20
3.139440
VERTEX
8
7
6
CONTINUOUS
10
2.016240
20
3.143280
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.748160
20
4.117680
VERTEX
8
7
6
CONTINUOUS
10
1.729200
20
4.100400
VERTEX
8
7
6
CONTINUOUS
10
1.719600
20
4.088400
VERTEX
8
7
6
CONTINUOUS
10
1.714080
20
4.075680
VERTEX
8
7
6
CONTINUOUS
10
1.712640
20
4.068960
VERTEX
8
7
6
CONTINUOUS
10
1.712160
20
4.061760
VERTEX
8
7
6
CONTINUOUS
10
1.712640
20
4.054320
VERTEX
8
7
6
CONTINUOUS
10
1.716240
20
4.040400
VERTEX
8
7
6
CONTINUOUS
10
1.722720
20
4.028400
VERTEX
8
7
6
CONTINUOUS
10
1.731360
20
4.018800
VERTEX
8
7
6
CONTINUOUS
10
1.742160
20
4.010640
VERTEX
8
7
6
CONTINUOUS
10
1.755840
20
4.003920
VERTEX
8
7
6
CONTINUOUS
10
1.764480
20
4.001040
VERTEX
8
7
6
CONTINUOUS
10
1.785120
20
3.997200
VERTEX
8
7
6
CONTINUOUS
10
1.809840
20
3.995520
VERTEX
8
7
6
CONTINUOUS
10
1.837920
20
3.996720
VERTEX
8
7
6
CONTINUOUS
10
1.852560
20
3.998640
VERTEX
8
7
6
CONTINUOUS
10
1.881600
20
4.005600
VERTEX
8
7
6
CONTINUOUS
10
1.907040
20
4.014960
VERTEX
8
7
6
CONTINUOUS
10
1.927200
20
4.025280
VERTEX
8
7
6
CONTINUOUS
10
1.943280
20
4.036080
VERTEX
8
7
6
CONTINUOUS
10
1.971600
20
4.058160
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.702560
20
4.080720
VERTEX
8
7
6
CONTINUOUS
10
1.695600
20
4.066560
VERTEX
8
7
6
CONTINUOUS
10
1.690560
20
4.050960
VERTEX
8
7
6
CONTINUOUS
10
1.688880
20
4.033200
VERTEX
8
7
6
CONTINUOUS
10
1.689360
20
4.024560
VERTEX
8
7
6
CONTINUOUS
10
1.690800
20
4.016160
VERTEX
8
7
6
CONTINUOUS
10
1.693200
20
4.008480
VERTEX
8
7
6
CONTINUOUS
10
1.696320
20
4.001760
VERTEX
8
7
6
CONTINUOUS
10
1.704240
20
3.990960
VERTEX
8
7
6
CONTINUOUS
10
1.713840
20
3.983040
VERTEX
8
7
6
CONTINUOUS
10
1.726800
20
3.976800
VERTEX
8
7
6
CONTINUOUS
10
1.803600
20
3.953520
VERTEX
8
7
6
CONTINUOUS
10
1.839120
20
3.940800
VERTEX
8
7
6
CONTINUOUS
10
1.864080
20
3.929760
VERTEX
8
7
6
CONTINUOUS
10
1.896960
20
3.911760
VERTEX
8
7
6
CONTINUOUS
10
1.912080
20
3.900960
VERTEX
8
7
6
CONTINUOUS
10
1.934160
20
3.880080
VERTEX
8
7
6
CONTINUOUS
10
1.955280
20
3.856800
VERTEX
8
7
6
CONTINUOUS
10
1.964880
20
3.844080
VERTEX
8
7
6
CONTINUOUS
10
1.974480
20
3.826800
VERTEX
8
7
6
CONTINUOUS
10
1.995120
20
3.776880
VERTEX
8
7
6
CONTINUOUS
10
2.007600
20
3.740400
VERTEX
8
7
6
CONTINUOUS
10
2.014560
20
3.712800
VERTEX
8
7
6
CONTINUOUS
10
2.018400
20
3.689760
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.037360
20
4.014000
VERTEX
8
7
6
CONTINUOUS
10
2.033520
20
3.978480
VERTEX
8
7
6
CONTINUOUS
10
2.032800
20
3.949680
VERTEX
8
7
6
CONTINUOUS
10
2.034720
20
3.928560
VERTEX
8
7
6
CONTINUOUS
10
2.039040
20
3.906240
VERTEX
8
7
6
CONTINUOUS
10
2.046960
20
3.884640
VERTEX
8
7
6
CONTINUOUS
10
2.071680
20
3.834480
VERTEX
8
7
6
CONTINUOUS
10
2.085120
20
3.801120
VERTEX
8
7
6
CONTINUOUS
10
2.090880
20
3.783360
VERTEX
8
7
6
CONTINUOUS
10
2.100000
20
3.745440
VERTEX
8
7
6
CONTINUOUS
10
2.106480
20
3.701760
VERTEX
8
7
6
CONTINUOUS
10
2.115120
20
3.621120
VERTEX
8
7
6
CONTINUOUS
10
2.122320
20
3.536880
VERTEX
8
7
6
CONTINUOUS
10
2.128080
20
3.453360
VERTEX
8
7
6
CONTINUOUS
10
2.135040
20
3.309360
VERTEX
8
7
6
CONTINUOUS
10
2.137680
20
3.214800
VERTEX
8
7
6
CONTINUOUS
10
2.137200
20
3.168240
VERTEX
8
7
6
CONTINUOUS
10
2.134800
20
3.141360
VERTEX
8
7
6
CONTINUOUS
10
2.130480
20
3.118080
VERTEX
8
7
6
CONTINUOUS
10
2.127360
20
3.107280
VERTEX
8
7
6
CONTINUOUS
10
2.123520
20
3.097200
VERTEX
8
7
6
CONTINUOUS
10
2.113920
20
3.078960
VERTEX
8
7
6
CONTINUOUS
10
2.101920
20
3.063360
VERTEX
8
7
6
CONTINUOUS
10
2.088000
20
3.050160
VERTEX
8
7
6
CONTINUOUS
10
2.072880
20
3.039360
VERTEX
8
7
6
CONTINUOUS
10
2.056560
20
3.030720
VERTEX
8
7
6
CONTINUOUS
10
2.039760
20
3.024000
VERTEX
8
7
6
CONTINUOUS
10
2.013840
20
3.017040
VERTEX
8
7
6
CONTINUOUS
10
1.980000
20
3.011040
VERTEX
8
7
6
CONTINUOUS
10
1.920000
20
3.006240
VERTEX
8
7
6
CONTINUOUS
10
1.894800
20
3.004320
VERTEX
8
7
6
CONTINUOUS
10
1.904160
20
3.002640
VERTEX
8
7
6
CONTINUOUS
10
1.980000
20
2.995440
VERTEX
8
7
6
CONTINUOUS
10
2.040000
20
2.987760
VERTEX
8
7
6
CONTINUOUS
10
2.065920
20
2.982720
VERTEX
8
7
6
CONTINUOUS
10
2.088240
20
2.975760
VERTEX
8
7
6
CONTINUOUS
10
2.098320
20
2.971200
VERTEX
8
7
6
CONTINUOUS
10
2.107440
20
2.965920
VERTEX
8
7
6
CONTINUOUS
10
2.115840
20
2.959920
VERTEX
8
7
6
CONTINUOUS
10
2.123520
20
2.952960
VERTEX
8
7
6
CONTINUOUS
10
2.130240
20
2.945040
VERTEX
8
7
6
CONTINUOUS
10
2.141520
20
2.927280
VERTEX
8
7
6
CONTINUOUS
10
2.149920
20
2.907840
VERTEX
8
7
6
CONTINUOUS
10
2.155920
20
2.887440
VERTEX
8
7
6
CONTINUOUS
10
2.159760
20
2.867280
VERTEX
8
7
6
CONTINUOUS
10
2.162640
20
2.838480
VERTEX
8
7
6
CONTINUOUS
10
2.165280
20
2.797680
VERTEX
8
7
6
CONTINUOUS
10
2.168880
20
2.774640
VERTEX
8
7
6
CONTINUOUS
10
2.171520
20
2.766720
VERTEX
8
7
6
CONTINUOUS
10
2.176560
20
2.759760
VERTEX
8
7
6
CONTINUOUS
10
2.182320
20
2.756880
VERTEX
8
7
6
CONTINUOUS
10
2.193360
20
2.756160
VERTEX
8
7
6
CONTINUOUS
10
2.199840
20
2.756880
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.786560
20
3.769680
VERTEX
8
7
6
CONTINUOUS
10
1.794000
20
3.773520
VERTEX
8
7
6
CONTINUOUS
10
1.801440
20
3.777840
VERTEX
8
7
6
CONTINUOUS
10
1.808880
20
3.783120
VERTEX
8
7
6
CONTINUOUS
10
1.812480
20
3.786240
VERTEX
8
7
6
CONTINUOUS
10
1.816320
20
3.789840
VERTEX
8
7
6
CONTINUOUS
10
1.820160
20
3.793680
VERTEX
8
7
6
CONTINUOUS
10
1.824000
20
3.798000
VERTEX
8
7
6
CONTINUOUS
10
1.831920
20
3.807360
VERTEX
8
7
6
CONTINUOUS
10
1.839360
20
3.816720
VERTEX
8
7
6
CONTINUOUS
10
1.846800
20
3.825600
VERTEX
8
7
6
CONTINUOUS
10
1.853760
20
3.833280
VERTEX
8
7
6
CONTINUOUS
10
1.860720
20
3.839760
VERTEX
8
7
6
CONTINUOUS
10
1.867200
20
3.845280
VERTEX
8
7
6
CONTINUOUS
10
1.873440
20
3.850320
VERTEX
8
7
6
CONTINUOUS
10
1.879680
20
3.854640
VERTEX
8
7
6
CONTINUOUS
10
1.885680
20
3.858480
VERTEX
8
7
6
CONTINUOUS
10
1.891680
20
3.862080
VERTEX
8
7
6
CONTINUOUS
10
1.897680
20
3.865440
VERTEX
8
7
6
CONTINUOUS
10
1.903680
20
3.868320
VERTEX
8
7
6
CONTINUOUS
10
1.909440
20
3.870720
VERTEX
8
7
6
CONTINUOUS
10
1.914960
20
3.872880
VERTEX
8
7
6
CONTINUOUS
10
1.920000
20
3.874320
July 01, 2010 - July 26, 2010
RV-Archive.digest.vol-un
