RV-Archive.digest.vol-us
June 03, 2011 - July 08, 2011
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: RE: RV8-List: High Oil Temp Issues - RV-8A
Date: Jun 03, 2011
A couple of thoughts: 1. I assume you have a 200+HP engine with perhaps high compression pistons. You are starting out with a oil cooling challenge as (my understanding) oil has higher cooling load on angle head engines as compared with heat removed via air passing around the cylinders. 2. I notice you don't have ceramic coating on your exhaust pipes. This helps move heat out of the cowl. 3. While the size of the air hose feed to the cooler is a factor, the differential pressure across the oil cooler still tends to drive the actual air flow. Assuming you make no changes to increase the plenum pressure or reduce the aft lower cowl pressure, then you may consider moving the cooler to the lowest area possible and angling the air outflow more toward the exit ramp (which is smaller on the 8a than the 8). On my 8A I have the cooler mounted on the firewall a little lower than what you have, airflow path is vertical (has a straight shot to the exit ramp). 4. The cooler itself has a lot to do with the how much differential pressure is needed to get a certain amount of air flow. Larger air passages allow more airflow but less oil cooling surface area, and vice versa. One model may work better than another in a particular plane. If you have opportunity to swap in a different oil cooler as a test, you may get some useful data. Carl Froehlich RV-8A, 650 hrs, standard cowl and the old, small Positech cooler with fair results (temps always below 220). RV-10, fuselage prep for paint, James cowl with big inlet rings, larger cowl exhaust cross section area, changed oil cooler and oil cooler mount, and shielding to stop the heat muff from dumping hot air onto the fuel pump. From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Friday, June 03, 2011 2:38 PM Subject: RV8-List: High Oil Temp Issues - RV-8A After 20+ hours of flying in which time we were resolving a Fuel Injector issue and a few avionics/electrical issues we are in good shape everywhere but Oil Temperatures which are also driving up our Cylinder Head Temps. We are running: . IO-360 200 Hp standard compression . James Cowl . Metal Plenum (home built) . New RV-10 size oil cooler (designed for 260 Hp) . Custom oil cooler plenum Photo below. The issue is we are seeing oil temps up to 225 when OAT's are in the low 80's running about 23/2300, 3,000'. The CHT's are being driven up by the high OAT's to mid 390's. The oil cooler plenum is a BIG 4" inlet with a smooth ramp down to the oversized (260 Hp) oil cooler. While we have not been trying to resolve this for very long on the 8A but we have a great deal of experience with oil temp issues (and the James Cowl) on our RV-10. The long & short of the -10 issue is the inlet rings are too small to properly cool the CHT/Oil. The only reason I went with the James cowl AGAIN on the 8A was the MUCH larger fleet of flying 6/7/8/9's with James cowls & few reports of cowl design issues for these models. We have toyed with the idea of swapping out this oversized oil cooler for a Niagara unit but I don't see how we are going to find 25 degrees with that swap as this is already an oversized cooler to begin with. It would be pretty tight but doable to relocate the oil cooler closer to the rear baffle area but again I don't see getting 25 degrees from that. The temp issues are the only remaining issues to resolve. Any thoughts would be appreciated. Robin Marks RV-4 Sold Standard Vans Cowl - No Temp Issues RV-6A Sold Standard Vans Cowl - No Temp Issues RV-10 225 Hours James Cowl & Plenum - Significant Temp Issues RV-4 25 Hours James Cowl & Metal Plenum - Significant Temp Issues Oil cooler inlet plenum 001.jpg ________________________________________________________________________________
Subject: High Oil Temp Issues - RV-8A
Date: Jun 03, 2011
Robin=2C We had this same issue several years ago with the same engine=2C and a larg er oil cooler did NOT help. Ended up opening up the air out flow area on t he bottom of the cowling. The nose gear cluster adds tremendous amounts of turbulence. Today I would say add outflow louvers to the bottom of the lo wer cowling. There are numerous others out there that have done that with great results. Mike From: robin(at)PaintTheWeb.com Date: Fri=2C 3 Jun 2011 11:37:56 -0700 Subject: RV-List: High Oil Temp Issues - RV-8A After 20+ hours of flying in which time we were resolving a Fuel Injector i ssue and a few avionics/electrical issues we are in good shape everywhere b ut Oil Temperatures which are also driving up our Cylinder Head Temps. We are running: =B7 IO-360 200 Hp standard compression =B7 James Cowl =B7 Metal Plenum (home built) =B7 New RV-10 size oil cooler (designed for 260 Hp) =B7 Custom oil cooler plenum Photo below. The issue is we are seeing oil temps up to 225 when OAT=92s are in the low 80=92s running about 23/2300=2C 3=2C000=92. The CHT=92s are being driven u p by the high OAT=92s to mid 390=92s. The oil cooler plenum is a BIG 4=94 inlet with a smooth ramp down to the ov ersized (260 Hp) oil cooler. While we have not been trying to resolve this for very long on the 8A but w e have a great deal of experience with oil temp issues (and the James Cowl) on our RV-10. The long & short of the -10 issue is the inlet rings are too small to properly cool the CHT/Oil. The only reason I went with the James cowl AGAIN on the 8A was the MUCH larger fleet of flying 6/7/8/9=92s with J ames cowls & few reports of cowl design issues for these models. We have toyed with the idea of swapping out this oversized oil cooler for a Niagara unit but I don=92t see how we are going to find 25 degrees with th at swap as this is already an oversized cooler to begin with. It would be pretty tight but doable to relocate the oil cooler closer to th e rear baffle area but again I don=92t see getting 25 degrees from that. The temp issues are the only remaining issues to resolve. Any thoughts woul d be appreciated. Robin MarksRV-4 Sold Standard Vans Cowl - No Temp Issues RV-6A Sold Standard Vans Cowl - No Temp IssuesR V-10 225 Hours James Cowl & Plenum ' Significant Temp Issues RV-4 25 Hours James Cowl & Metal Plenum ' Signific ant Temp Issues /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0a HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAMABAADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDphc55 zUq3XbNY4lI6mnrKR3PNcfKXfU2luz61Mt3nnPSsQS8daeJsdTS5Ljubq3pHcU8XvucVhLOSeCal WbPQ0cgcxs/bMnrSG5yetZQlOc56U4TEDANHIg5jS8/BzmpVmJ6GstZuQTUqzgYyeKXIVc2IpyOp q2l1jvWCtwB3p4uT2NTyO4cx0AvCO9SrekY5rnRcn1qRbrHejlY7nRrfHIyanS8z1rmluvepRd47 0K62FodMl0DxkVKLhSOtc0l2fWplvTxz+tUpyWwcqZ0XnKe9KJAawVvT61IL0jvVKrLqTyo294xz TTKB3rI+2kjANMN23dqftZByGs1wo4qtJKpBzWebgnqQaPNB5JrNyb3KSSHy7TnmqUq4zirDSL3q tIwOcVNhspSg88GqrjOavOAcjNVpB2qkrCZSIIOaYTjIIqyygdahZM5wKpLsT6EW4HpTSCTT9mOn Wk2gcHNNJARk5HY/hSEjPSnEEfT0poGcUWFcQqD2oEYz1OKdsGSRzj0pd2CeODQ0wuJsA75pwQEY Bx703JPGKkggknlWOJSzE4AAo5Rp6jkhYsAHIBq/9iFtAJ7q6EMZOAztjJ9AOpPsKVStsRHbbJJh 96VhlEPcAfxH9PrUkdoiSi4mczzt1kkbLAeg9B7AAUrIepAJJHUiztriQdpJnMSn3AwSR9QKia21 1gT9qtYR1ACM5/MkD9K142Z3KoDgnp1pkt2iOYoFE0oPJB+VT7nv9B+dRpcdkzLW01cAme4tpoQP m3xlRj8yBSxGyiIX7Nauw/uKSf0Bq29tJOQ91KZSDkIDhR+ArkfEGv8AiPTC/wBm06C3tlztkRC/ HqSTjP4Cizb0Hdo6xrmKWIxPaP5ZGCgj4/LFcrfeG52u5HtJkWE4KpIpBHqM4xiuVj8a645dbm9Z CVJVkVVAI5549OPrVB/FWt3hAl1S4CrgAI20H6gYB/Gk6cno0CnY6h9C1lAdtt5gHdCCD9MGsS6v pbJytzC8bA4KupB/Wm2nifW4kYxajMXVwMMAwIOcDnPoa73T1fxHaJBrkELlQGV0IBJ/Dp+FH1eK XvKxSrN6I4aG/hmYEuuOuM8ip/NYHIAI7V3yeCNCSVXFs6kAjAbg+hPuKoaz4KVw82nOFyMiHGMH HY+tZSwqveLOmFWDVpHG/aexABpDcjngfnUNzBPZ3BgvYmjlxldwwSPWqTzqhIyTj2NZuk07Mckl qti+87MPlIBFRrI55Ykj2qot3GVyWAx60/7VEf4hj60ezstibotGVQeVqN5geQDUYniI5dR75qNy CMqMg9xQo23HZMYziR+QRg1KQqAkgAAZJNV0bD5IIwaLzc0BbJAJwAKdrtIpaIq3N2JSUTOB1PrU Cxhuq9faiGMHJYEmrccYIA5FdNlBWRg7yd2RpBHwCoOPaphBEBxGpH0qZIRwc9KlVB2PSocn3DlR XFtAesQ/Cnx2yRSLLCuyRTlWHUGpiFHVgKcFU4+b9Km7YcqLFtf62rhnv3ZR0GB/hV9db1NePtL5 75AP9KZDq80Uax+TbsFGBlMk/WpTrLEAmztj9FxUtJ7k2sL/AMJDqgIInBI9UFD+KNVRfl8tz6Fc ZpBq8Tfe02A/QkZpTqVkThtNX8HNCigsOi8U6oUBmhtwf90n+tSDxJI5+e1t2/4DVb+0tNZsNYOP cOaFn0g5JtZ17/eBp2tqg0LQ12Bs79Lt2J6nAP8AMUDVdNfh9HgPr8o/wqv5mjHqlyp+oP8ASgHR cYE1wpPqoNF2nuFl1J3u9CcYbSEX/dAFQMvh1xg6aR6nJH9aPK0hul64+sZ/xqNrLTXORqaDPYoR T55r7QuWPUcLPwxIMG1kXPcMaDpHhWQcmdT7H/61PWwsd4zqMJTuQCT+VS/2bpp+7qUftlSKpVJ9 WHLHsVG8OeGnztup19OQf6VE3hLQ3JCak6/UA1fbS7Uk7dQgIHqcUf2RET8t9bH/AIHT9rUXUTjF mW3grTiRs1VfqVH+NRnwJEQSmqQnHTIPNbP9iyNjZPA30cUp0S7xwEYeoYUKvUDkic+3gOckhb63 P1JGf0qrL4KvUOFlgf3Df/WrpX0a+HRCMDjDD/Gom0/UE/gb8DVKvPqg5F0Zy8nhLUkyNiNg9nFV n8NamoybYkexB/rXWm2v1GTHJj2zTCLtOGWYAdxk01Xl1QuRbXOObQtQTObWT8ATUL6ZeoTm2lAH +ya7TzZxkEvzxyDTTPMBks2PcU1iH1QcltEzhmtJ04aJh9VIqN4nAOVOD7V3El1Kqk5B+orGfxA4 cq9qjAHAPr+laQq82yJcbbs53ymHVSM0hUg8DFdD/bluRh7BOfTB/pQdU05x81iBn0Aq+fuibHOk HOQKbggciui+2aQTzasM8cD/AANBbRXyCrrnp1o5/IGvM5skYyRig5PTiui+z6K5wJWAP1H9KYdO 0p87bvafcinzrqKzOf7+1JnHGT68VvnRbJyNl8h/L/GkPh5WJ2XaMe1HOhqLMHB5yeTRyR0xits+ HJugmj/HNRSaBcoCQ0ZH+91oUo9GHKzKyMc80YHPGfStD+xbwAEID9CKY+lXYPMLYHpTuu4alHGM +tLgk9Ae1WfsNwn3onH4GhIGViGUgAZ5FK63BLoMEa5AA59T2rS0y+K/upMbScA+lRQ23mxEkcg4 qOW1ZDwDjNZT5ZqzNI80XdG/sycgg+hoEOW4POMmqGn3ZAEMx5HAJ9K0xjGR3PeuKScGdsZKSIyF IwwHHp3quxCMWCkjJwAM1bKBxkA5AotkyCSOeB+tOm9bk1NIMr73xnynAPcrTGlwMlWGPVSK3toC gECq94FEROB0rrTVzhsczI4eQspOCcjHFM3tnhj+dDkFiccZNMwOuOMY60W1ubpaDt7gY3Hr0o3s BySfrSAcnikxwepzxRuFhSSeoz9RR5hzyBnscCk4IwSetDBfLABO7PPpihaCaXYtR208lubhVHl5 xn1NR7Zh0BH0J/xrrdCt4n0aKOVAwJJ5Hqa0TpFkV4hXPqCan2m4ly9TgczDgFgPqaTzJgMbnz9a 7s6HaEDEeMjHBNRHw9aHorD8aOddQtE4nz5wPvt+dJ9ruAMB2/KuzPhy0LYBfnryD/SmHwxbcgO/ 6U+dCcYs5AX1yDyx49qX+0LgAEsPyrqW8MxDJWU9c4K1E3hpc8Sjk/3f/r0c0Q5Is5v+0pwcEg/h R/alwPQg/Wt9vDJPSRfxFQN4ZlxwyH65p80XuHIuhkf2vOOozn3pf7XlwAR+taTeGp85BQn64qJ/ DtyM4VSPUGhuIOCfU9ABNPDDHWmAZPApwxya2t2Oe5IHJpwaovTFOXrgUguTq9PD46VACadnAoaC 5YEhPQ04SHrmq4JHWlyT070coJlkS+9OEh45qtuOOtO3Y/Cly2C5aEuD1pwlPXNVAx9acHIo5QuX BKRzmnCY561TzjoMU8NjkGjlHdl1ZueDTxOQetUN5HWlDn1pcoJmktx0yalW4IPWssOcdOKkVyOT RyjuzTW5J6GpRcnuayll4608Skd6lxDmNZbnIpftGRnNZQnOOtKJzzzmlyD5jVE47mkNyPWsvzzj rSmXPGafIHMaJufemNOCOTVHzOTk0hlPrRyhcuGXPQ1E0mQearmUmmlz3NCj3C5Kzim5BHSoyaQM R3qrWFe5LgYpjYx2phc+tNLkj1oSENbBOBSbTzjjFLgmjHXNOwDSAOc/hS4z3P40uD0xTlTccDqe KLdwuOiiMr7RgADJJOAB3JPpV2Ngq7LZsIRhnxy/sPQfqf0qqEEo2A4jBwx6byO30H61bWMiMMrL 6YzzU2GtB6E2xAKAYHQjjFPjAdhgkfjUIZi2CDmmS3GQYkOB0Zh39qlodyzcXIdTBC2Izw8g4Lew PpUDXFtbRZMqxAdCSB/Ouf8AE+sPo+lQmEgT3LMqMRkIq4ycdySQB+Nc/De77dGmcvIygkscnNTa +xVzrJ/F+mWJZJr0YI5CIWIGRyMDrxXH+JfGk2rl7O08yGwIxjA3ynHVj6ew/HJqlcCKQuzIGJ6c VjzxeXKWCnAORkcU1TWjbFcgZD5e2QD2OeaSzEQmEMoUKWyXZsAAA8fjTwof5QQCT34xUDgBiCBk HHPNbIVhY5THOAy45BUg+nQ11uleNb3TsK6LOgGTkHOB7j/CuTmnNzBlhmWMAHCgAKBgcjqaWEmd FZcblOSD3p8qloydtT2XQ/GNlrR2KGikAB2uQQfoa6NXBOQfcV5DoOmhVWcMVkHzAD+ea9G0meR7 dQ5JIAwc5zWco8uxSdyv4t0BdbtFmiGLuDJQjjcO4P8AnrXl1xKtoGE0ZDKSCCOQRxivbgSBkdCe RXAeO9GRCt/EABI22RQO5HBrKcbq7OmlNpOL2OKW/sj97Az6il+2WB7rz6is1o2EpUhcj2oMbY4C /lS5E+pHO1dF8z2TMGLqMduxqVL21ChBIoxwBWR5J5OF/KlWL5hkLnPPFEqSa3KjVaexrkK8qkEH mlugoUBiAM9+lQxH96oHtRqxBtwM9TXMo+9a50ylaN7E0CW4JJKEntkVY8u3PQJ+GK5gIBjBIP1p +COQzfnW7w7bumc/t1bY6IQQqSzEY+tSCCB13KCR7Ma5o7wp+dvzqSMzbtqysoAzwaTw8ujGq0eq OjWKEjlCMcdad9ngzkKfzrnPNuVYgTMAD1zTzcXaYAnPPNL2E+jD2sOxumBQcjI/GmLGxOA7AduA axBe3gGRKfxpI9Ruw2VfJPqM0OjUDngdAIJF6SDB6ZXpTlilwD5inHXK1hDVb0cEg98Yp39rXijJ VcH2pezqIOambRhmOMsh554o8qQYBZMn261j/wBr3eMlB6dKT+2ZyQTEpIPXHSlyVQvTNsQOOCV5 9qcLZj1CVjDW592Sgx6U8eIHA5iH50NVew/cNYW7AkMq/WkNqpGTEpOcYzWYPEGP+WX5GnjxCneI /nS/eroLlhfc0RbKM4i9uDS+SoJBQ8c8d6z18QQ94z+Yp39uwHB2MPXnpQnUtqh8kOjLvkRnqp6U n2eMYI3DNV11u2I5DflTv7ZtScFmH4Uc0raxDkj3J/IiJxuNL9nXBxKw/GqzatZgZ3k+wBpy6lak DMoHpxS55LXlF7NdGWBBIBhbhx9CRQYrnORdOP8AgRqEajbf89l/OnC/tiDiZOfcUe0/uj9n5j9l 7gKt2/PPLmlA1HPFyTn3Bz+dM+1Qk5MqnI/vU5biEjIkU46YNHtPIPZ9mIx1Ef8ALTP4Coyb/GSo b8BUhkRuA/A6YaoZTsIZJn9xuOKaqLqhOm9xD9sIO6Fff5agaFyMvZxEnuY6seY7c+Y4+jGlwzdJ 5Bnr81NVktheybKflIcBrKIjp93H9KhkgtdwzZJzzxmrwEyMQZ3I+oNOCuTgzMfTIHH6VSr92DpM ymtLLGTaEZ9GNR/YrFsgwyAjj71bLRtjJfPcZUUwxHJJKHP+yKft13F7J9jIOnWJHCzAjjqKifS7 UqQkjqx7sOBW2YGIwAhz/sn/ABprW5IwVQ/QkYqlX8w9k+xgHSFxkXKfiCKZ/ZTgjbMpJ75NbxtF IzsH4Gm/Y0IIw3HuOKarLuL2TMT+zLgfdlXj0akNnfAZDMccgh//AK9bRs1HQH86ia0YklSR+IoV dbC9mzL8rUVGS0h/4FmmE6mpxvkx7qD/AErVNtOAQAT+NBt5um0g49aftYh7JmK8+pA8gH3K4piy TybjMADjAxxWw1tORg5P41UmsblzgIx96pVItCVNp3JbMKLYAjkkmnSorLgimpBOihfKYAAdqRo5 QDuRh68VndXvc1SfVFKaIKcg8jv6VoWd35sYiYDeP1FUXBIJIPX0pkKMXBBIbPBpzipR1CN4yNvB XPOPr3qS1wcY9RmoUcMjB8BwPWoUhncgpLsBOMZI/E1hBWZrU1ibZIAwDVLUHAgbJxxUIt7wKCJg f+BUfZrqeJllwwPQlgDWymk7s5eR9Dn2Oc4FJ1GAK2joxPSFiD6OKibSlRirK6sOoODV+0izRRdr GUc55BwTS8ZGCavtp6g4MjAg9Nv/ANemGxA/5agfUUc6HyspAEHgnnk0jdAM8471c+xEjIlXP4/4 Ugs2Lrh1IyMnP+NHMgafQ7TS4gthAgPIUD9K1FUAdeayLbULRI41MyjHXnFSXniGwsYgzyF8nACD P/1qyV27IyaZrEDHamkgCsA+LLY8CGUjjBGP8aQeKbU8mKYfgD/WnZ9i+ST6G8uCSR6UEjGTWGni eyyQRIM/7P8A9enDxHYN1dhjrlDRZ9hOEl0NjqeTSYwORWWviDTyMifr6qeP0pf7csD1uV/I/wCF GvYOVroaPrzTCBnHGKpf2zYnI+0p+dH9q2JOftMfPHDCmvQll7C9cD8qjIBOTiq39o2hHFzHn/eF AvbUnAnjJPTDCi1xG0ARilA7CnbRjpTguB9K7bHONA7g04DBzSgEGnYIosCY0A96cBjtmlC9MU4A 5+tFgG4JxzS4IPWnYPpRjii1guIAcmndRnrS44/SjGQeKLAGfSndOaMY4xmjAHeiwthwOaUEk/Sg DuTS470WHfQMmlyR7igA04DHIosFwBOc9qfk4puOKXpRYLjlYjmnByKj5PU0ootcLkm4il3HPBpn JNGeaVh3H7j0zS7vU1HnPBNGTjg0WC5LuAHJo3c9ajJ9aM+lFguSAkDGaCfU1Hk5zmlyc9aVugXH 7s00tk4NISfekJGcmiwXFP1pc+9NzxS5osFxwNBOT1pmTSj6UJBew8EGlAJkEYyMjLH0HoPc0xn8 pQxGSThR6mpEPygE8nkmnYVydQGBAIAUAAUmWB65+hpjKAMhgT6UBwilm4AGTSGnqSSTmNdqnEjD g9wPWq5IVQo6Dr70w7mcuxGTyPYVFJKIuXJIALEBSeB9AfWpcR3bKHiLTDrWmwQqVEttKZIyf4gQ Ay/jgEe4965iXEUpibCunBB4IPpXZ/aIEge6lJWBFMjHnIUDPT17D3rzifW01jVLm6vQ6FidiqBw AMKM57YA/M0k2tEhp9zSklSJCXYAAVQu5I7i3dYWDMMHA64p5k3xhpEJByMEZOPXFPurrThYxrbw AzgcuAVI475HP1o16h5FC0sLm/lEVrE0kh6KoyahuNMvoZGV7WZWjJDDaeCOuam07WbnSb1bq0bb IM4yARzx0NdQ/je40hY7sQRXEt0JDIHOACdvIA9x0pOUk9FoWlG2pw8TOJjF5vkpLhZCemAc88E0 lowjuygbKkkAjoaS6u/ts7zsioSSSiADH4UpKiSGUJ5YIBBweQDjNax1d3oQ2tj0fQ4jPpiOvJjB BxXR6SXiiKhsjrn0Fcz4Jv4jFNbPjJ+ZSemD1rpLVzFO6gZUEgY54pTSdwizejIZdpJxjOc9ap61 p6X2kz27cEqdvsRyD+dTW06AgshUHABJH5Ut1eqDhcHPUVlZWsXezujw25RkuSCCDyCCOhHWmYx6 11PijTWfV2eCE4kAY7BkEnr06VlHRbwKT9mkxj+6acYyexcrbmVjjpTQAGyRwOa0H064jGWhcD3U iqzwOA3ynj2ocX1RK0Ft5Y3nXa2Segp+qHMSAc888VXsYSLoHb61Z1FDhB781zuHLUR08/NT1MsD kA9+Kcw9+e1P28jilYEHn2rqOT1GOCUx+NPhUGTBz0pHGFA7ZFSRD94cDsKLsSXQYR8x+oFOmXG3 p0NLglzn+9SzjkewNK4akG3Ef4VEgyw571YI/de2KiQfMP50aDH4Bb8DUrjEQBHYVGo5I9jU8o/d qPpQBGoJB5OAarYJ3HnrVtRlCPc1WAGCcjk4oQDpQABkDFMKgjGAPrU0oyB7mmHHU0ebARI1I5GD j86jdAGIHpVhBwD3IqGT/WED0o8w2GhF2g4IJo8sAA45p/RRnB4pcAKOD60OwczIwh5IJwKayZII J9KmAyCaY+MgD1o0C7I9p6Z6UoDYPPAp4AJPtQAdpA6UtOwcz6kYVs8Ht601g45DYx71MBg4zTGH A/nRZdh8zGBnxwc/WgvJ0BpwAwSaVQDnjpRyrsHMxvmOBwTn60hnlHVjx704gE8ZpGBwabjF7ofO wN1MBkO2D2BNKt7ODjzH/M1HjGBRtBIwKXs49gU5Ep1G5UZEj/nTxql0Bkytz14quQDkGgjA6dqT pRfQftJdy2NXugADIePUClGs3I4Lg/hWfgE5z3pSoHUfSl7CFtg9tLuaA1u4GAWT8qU63P3CH6j/ AOvWaVHpzSbAOeOaSoQ7D9rLuan9tygZKoR+NNTV3ViwVfm6jJxWYUBHTgUgQAdKPYQ2H7WRsf20 x6xD6g0o1k8ZhGB7/wD1qxmQY4zShBjPI/Gk8PDsP20kbX9sqeTCR/wKnDW07RNke9YO0DqT9M03 BA+8350vq0A9uzfOsxE8xNnPtR/a8I6I4rniWAB3EGozK4yA3T9af1VAq76nTf2vCTyHH4CmnVIC DgNk8ciuZNw4PUUoncgZA9c4pfV0NVjba9gJJJJz7U2BlmnDKMgnisYyMeOOa1tLUtInTpmlKHJF 6lQm5OzLepzLaxLLgFxwPeqFlqE08hViuTyOOlad9bJchEkzgc8HFYskS22orFBkcZ69zU0uVxt1 HV5k7rY3I5XAJwCak82UnAVQe4yf8KzFlvQMFVGO5xUcmoTQEBgpz6U/ZSexCqLY2DI54KDA689a Y0mMsY8gDsayP7Xc5yg9etJNqrvEUVQpPcHpSVKS3Hzo0tynkAD0FIQMdOtYn22cchyfwFH9oTg5 LZ+oqvZMPaI2sccCgg7eABmscanMBnA9OlWLO5nvZ/LUAYGc80ezktwU11LLoScjIx6Vn6mQWgQc AnOK230+5RSzMmF5OCQcVh3vOoRKOy5rSCtqwupNJEo4GPQUH1z370vTkjGabkd8+wzUnppWQhJA BJFJkeoOaa5AOAfeq083lLkHk9BVJN7Gc5qKuy4CCOvNAQyMFUkE9CapQyyuNxOB+pqVZ3hbzFbB X1FDi1tuZ+1Uo3sXTYspH75jxzxQbJgAVlPPTgVSOqz3LYLED2GKel3MgKh8j3zTXNb3jnfvL3S4 9qdoCuQe+R1qA20oYBXBB68c1GLqYkAtn8akF1IFBOMg8ZI5/StI2W5jyVbnrYHHJpwXvmn4HSlx 3rRI5BgHB4pdpxxUmMc5pQOaLARgAnkUuCO3SpAO9KBxRYBgGTjFLtp+3tTsD86LARheOtKBjrT9 pHbil29qLBewzGBS4PpUm38qXBAyOtOwEYU0u3PannA6UAE9aAADuKXHfFOAHpQBmgBNp9aMcdqf juKTAz9aBjcHtS4xxTgM8frRiiwhuMDilxS4I6UuOxGKAGcmjBHApxGKMHpQMTmkp5U46Ube2aVh XuNAx70uBnpTsY9TmgiiwDOc80ozg8U4jjpSY5wc4pgNwetLjAxSkAdKMd6VgEwBS4wDkgY60Yx2 pkuXIjB5br7ChIAjBlkMhB2jhR7ev41KVIPQ0qgKoAGAKdk+vtTfYBATkd6ilbcwQY2qck+pp7v5 a579AKhGAOvJ5J96VuoD8k9aasJDkgsQexPFZmreILTSIsytvlPKxr1PufQfWuC1vxxqtypjtpBa oeMRj5sfU/0xWbd9ENXO58SzqkRsASANr3DDoMglVPuQCcewrl4oLQyAIm5j04xXHWs0sV150s0j uxBYliST7k9a6uJHASVGzlQwOc8HpTVOT16j5raE9zMlu+xkG4jOAQf5VTmlWRDGFUBuM56VZWNx MsrKrsCCd4yDjsR6UyS2Z5GdVRckkADgZPQe1Uqb6hzIzE0a9nDGBDIFGSU5wKpS2l8IyHRiq9N3 IA9q7KzuJra0niVQrSgAlRgAA5+uf8abcvcm0eCIhkbGVJGTx6dahuSdki1ytbnDKjkHcpBFP8oF QC4BHYmuhGlzAZltZIxjqQQMflUlvpKSyYKKwJ9Qc1W6QRaT11E8LSSjUoYomLOcqAO4r1O20xl+ YyHJwSAK5Gwg0vw7Lb30sbIz5XKgnBwO1dZaeJNJnACX0QJ7Odp/XFJyitwlq7pF4aYGILO57dat pZKgACqcdyM0sM8cqhkdWB6EEEGrKNwKFZ7CuyNbRRKJSpDA5G3Ax+laQugUCnzDjjkKf6CqykGp VAJ6Dmna2zFfuMKwtk+VAxJ5EkIGR9RmoW0vTJwyy6dZEMMEhRn8yOKu+UcZAoMY9KNe4HPz+CdB di66dIh/vQyAj8s1kX3w80u4AJurm3x0MkRAH6H+ddr5QByP0pQJE+67Aexotrd7lKTSt0PM5fhc HG6z1e1mx0DfKf5msi9+HOu2+WS2EyDndGwwfzxXsDwI/MsMbk92UZ/Mc1GIFjYtFLcQn/YkyB+D Z/Si7e6Fc8FvtCv7Nf31rIgBAJKnH51RSF1lbKnoK+jD5roVkW3ulPBEi7WI9O+fzrntU8HabqAa YWT2bkZyoyPzGQfxpWiNNHiew7+hB3UTocjjsa67WfBt7pn7+MefbEkh0HQe4rm54sNyO3pUNNDK LoRASB2qFEO8Zz3rSkQC2PqcVXiiO8ZHapuFiJVO48dB0qaVTtUY4yKlEQ3nA7VPLECFGO4ouh27 lFQfLPB6mqyg4AxyW61qCECMjHGTVdIQQpwOWppg1cgmGCAPxphBI6VekhG4cU0wDBNK4WK6A46c 4FV5B87e1aiwDHA4xVR4SXfjvTTQrMgwNo70uOBx0q15GACRgYpBBx0ougsyrgkd+aawJYAnpVwQ HHA/So2gJcADtQmHL2K4GM459aXBKjPXNTCEkHg07yCFGBRoFu5WUDmmuMDNWREcEj1pjwnqQTTT sKzIMYUkjrQAOe1TeUcHjvR5JwcihuwEIHOCORTWBAJ68VOIiD60142AOR2ouFiADoAO1KAc4A+t PEZ38jtTthyR1wKd1cdiIrnjPekI6jOalKE4JFIyEA4HSjYVupWCnqKdg8c9aeFJYDGKUocg470X C3UiIIPvQRgDIFSFTk5pGUgf4UPUdiLGc4oINOwRkkd6UA+hpgMxz060EcehpzDJ60hGB3oERkck Z/SmHGcZz6U88nFRSMQcAc0ANk4AxUPGGI9akOXx2PtSiIKMdQTnpTv0FZ7kBGeBjNOVCSD1FTBA z/KMYFWbaBSSGGQOlJuxV02VPLOBgck1s6WoEg7YFQm2jAyQcDnrVvT4ySWA46VhWd4s3o/EXJgD IAegFYEv7zW8AZwQOO1X9VnngZTFyDwciqWmRPPetM456k1NGm0uYqtNP3UbHlEqeM1iXqgSkHtX QEEJyTxWDdITcOck84raNzBK7KZQk8EYoCHFThAOo70FCDnAp3ZokivsJ7daQoT279c1YKgc4603 AH5UByogKEdjn1rU8PRE3LtjoAB69aokcYwRx2rovDEKlCxHJY/oKicrRE0jRuyUtJCc88Vx0p36 o5HO1QK7XWMJp+ARlmFcTES17O5z1wKIP3bl0l76LBOabkA4NKTjseKTBI6En6UrHpSZXlYAknoK oAtcTEknaP0rSktnlXBViM84psdg6IQqkAnrWkWkjiqpyl5FCSVkYLHwBTZpXICA5PfFX107BJLD J79cVJFpILEhmYkZGBVKUVuYuMu5lh2iwqde5pzTybgowT0PFa66WgOQrEnuTTxpyA5VFB9Scmk5 xElJK1zIM0i4Crkngmp9zOBlhkcEDtWrHp2SFABJIAAGSTRPaxQRkNKPNPRFAJ/E5wP1pXT2KU7P e562B3pcc+lKBzmnAfpW+5wiYPBpQMjqKdgGjGeMUAIBTsHoadtyOKUAY6UAN2j0pcZPGKfjA560 qigBuMdeKXFOwM0pFMGMwfwpdo7U7GegpcEcilYBgTnJpwAxwKXBPtS4xxjmmA0jHajB6U/acgYp wTjFAEW0kd6UL3qUqO1G3A4FAEYHOQKUAdDT9uOnWgL60WAZgelLgHjipAp6etAXNFgGbBnOKAp7 daeRilx7UWAj255oKgVIRzQV54osBHjI5owMcVJijANFrhuR446UmPapCvpRtNFguR49qXbmpMZ7 UoX14osBAxCqWPAAyTTYkJBdhy3P09qkkAeQRjoOT9OwqZEyOlCQtxilcYI5owMnAp5Qg4IpkhCL kUDKsxZn3D7q8c+tUNUu3stPkmiTfKTtjGOpI6/Qdfy9avzSIIwACMVy+v35gvbaFzlDCJBjsSxz +gA/Cok1ogSOKvDPJO805ZnY5Yt1JrJc4fcQDgg8+xrtLueCaMDCkEdx3rCntoXLBEGSDjHaqjFL YbfQx3CiQkgkE5H0rV0zU1ixBK2Ez8pPb2+lSafaQXNqTImXUkE57VWlsYzJKIwFSMEkk8nH/wCu tOW2xN+50sbgqCrZ9CDxUysSBWJpUGI95mdVUAlc5Bycd/8APFbJimRCySKwAyAe9OzJdrk6SkZy AanWVMYZAc1Vt4r17GW7khGyPOMHOcDJ/pWeNcgTiaKaM+65FJq240+xuxSojZQtGT3RiD+lWUuZ CcicN7TIr/8AoQNYMer2Eh4uUBI/iOP51bjmikAKSq2R2INRZMq7Rr3D/a4RHLb2rqpyCFKkHv0I H6VmvpMWSyxMg9A2R+op0bsDwePrViOd1xg5+tJwTGpPuV4baW2bMM8kZHcZH8q1LfWdTtT8t6zg dmIYfqM0xJyR8ygj1qYCGQglAM+1Q6Kew1U7mnbeLL0Y3pE47nBB/Q1s2/ieJ8B4GX12sD/hXLLY W7/dYD05xThpjjBjlYZ6YNQ6M18LK549Ud3BrVrIM72Q+jA/0zV2O/ifG2VGPpkV52tvqUAykuR6 EA09dR1OA5a3jkUHkYKn8+f5UrVY76j9xno4kDHPH4VIrAnk4+lcDD4mMRxNZTqP+mbA4/UVrWvi rTXwJLmSEntIjD9cEfrQqkl8SBxT2Z1uwFN3aomCnoBWWmuWM8eLa/t5iOSokBP6H+lV5tdjgOJI iR6qwP8APFN1o9RKL6GsUB4GKjZ5YsbXIIPGDWOPFOnHAd5Ij/tIT/LNO/4SDTHGRewj/ebH88Uv aRfUOVmpLqKG2ZLiAOMdhgH/AAPuK8s8X6faJOLq1QorEhk4GO4NdvcapaPGdlzC2R2cH+tcJr84 nVgpBUMM4PAqJTu9Coq25zsqAw4AHUVBGmHHXpVqUDywOe1RRKQ4PbFJlDlQbzgZPFSumSPr0oUf MccdBUjgEjHHNK7DqRbD5RJHXNV0i+VB15NXODGcHJxUaoQFycYOSKXMl1HZt6DJIhuGTSPFleB1 qZgCQaaSC23vjNLmTeg3FpaiKgwSRiqrR5LjsT1rRAwM5xVXbkH3ar0sSkNMQwBijy89AKsFTjpS lcA8Ug0Kwi+UComjzLyOgq6F4BqIg+YSBxihN7hsV1iwnApyxAKMDirAXEfA7U4IABgUXD0KgiGO R3pkkQJHFX44i7BQDknAp91YyQTmJgCRjkHIPuKau9gMxIeDnnmlWDKk45q6ICF5UjmlERC8jiiz 7BoURFlunOKZJCNvTvW7Y6PeX8hW2t3kJBI2qTkU+78O6lbAGaxnQZ6shA/PFVFNgc6IRuJA4ApR BkkYrTNk6sxZCO3IpnkHnj9KT5k9gsZxgGemfwprwAISR9K0fJww4pksYCEAZzSuwsZiwZIOMcUv kAtjFaAhAJGOg60CIFulDbCxmmD6daHtwD0rQMQJHHekeIEknp9KakFrmX5HGCMZNAtwCABV8RAA cc04Qgt0zT5gsZjW/XIOaRrfA6VpGIZ6d6a8QHbjFClqFkY/k/MeO9VpY8PwOh9a11ixkn1qjMmJ cckVSkCWpXEQAGOuKRxjJxxirRQBQevFQMAcKO55oi7u45qyEt4zySPwq7bocEgVFCvDn3q7Ah2/ U0SbM0hjqNpJOABW94bsrS9lWETHJOW46euKx5kxExxz0rb8IxATtKOuMZ/Gueq1ym8LpNnoMXg7 w3cwhJbd2JHLGQ5P9KtQeAPDcSkRRTKD1xID/MVFZyMpBJ4xWolwQM7qzVSaVk9B2T1KT+ANCcEB 7hc+jA/0qhJ8KtCfLC7uQScknaf6V0K3DE8GnfaiBwapVZoVktUcs/wm0gn5dQmH1jB/qKiPwj04 nI1Nx9Yh/jXWG7PXdUf2skE7iABT9tMaued6r8OLS0kENtqDTTEZI8oAKO2TnjPpyawpfAF6pyk0 BA6lmIx+hrQ1vX5jfXyJIwLv1DHgYwP5VzEup3ZJU3MxB4IMhII/OqbqdBxa2Zn31ibW4MPmJIAc F0JIz9a2dMdrCIIq7jgkHBAOay3ZXOSM9z9a3rO3nuYFeNo9oAAyT/QUSbasxppatDLqWe7QI6AA EEADH9azU0xElbC4BOSSe9WtWe500gM6MxUtgDoKo2Uk98xLzLEu0Ek9s+9Uk0tNgU9bosiyQE8K B0BxmmiBEYHIAX2602KCR5I4mZySxVmU5XGcA8dqin0i5mYBPMQKxGTn5gD2rSNNvdmcq8tybzYV 34YfNwRnjFRyyxBQFGFA5xmrlvpU8al/KMZZsbyoJUAAZwSOp96muoTDbzi5B8wAgcjaQemAD17+ tDgosIzcnYwxdxRuWVd3HYU1tSYElUIzwcnHFEVo88gWNGZmOAAMk/hV+fQJbW3Wa6lihUkghiSR j2A5PsMn1xQop6s3dOMfiepmtezORtAANTmOaNBJdzeQpAIXGXYew9Pc4FNa9htAVs0+fGDNIAWz /sjoPryfcVmTSPK7M7MzHkknJNOyRDhf0J7rW3jUw2ymOM9Wzlj9T2HsMCqomEqlxu6d/XvVWaPJ ycYFLaRs7gc4zwPetEopGDTjKyPoDH60oHYU4DBpcHvVnPsJ3pwHFGOcU9VxQgG46cYp4HFKBTgB jFMBoHNKVIPFPx0waMZ5xQIbjHGOaMHIp+M0oGaEMYB+dOwM9KcFHYU4AelAEe3vilA7ipMUmMDF FhCAYpQD0xTsUYwcmgYm09aMeucUueo9KUZIAAphaw0DHegDPUU/b260oQdKQEZGARRk9OaeV570 Ad8UAMwSafjuBTtoxS7cDimIZj1FJjP1qTA6GjFAyPFGO1SY74pNvGTQBHtPY8fSnYGKdtNKFI60 AMAFDAAEkdBmpMD0qC5J2hFPLnH4d/0oC42Bd4LkYLHP4dqm2kEYNOiQBQOnFP2jGcg0xWIsE9aZ 5ZlY4AwoqaQhEJPYUzIS15GC3JqWO1jNkG5iB0B5rjfGEDKlndAcANAx9CCWH5hj+VdoFGcDuc1l azZJqFtLZMQDKAYmJwFkH3SfY5IPsfas5K2pSdmeZs5JAzxnpVqMESg54IxVCQPDK6OpVlJDAjkE HBBq5bSF5QMHjrzTV7qw+g62JgvJohwG+YCmuQlvdEjLEAA9hkj/AANLekJexuCRkbTVaZ2IK54Z hwO/WtlsZtM1LRSLXAxkkDHc9a1GbMSxr1I61QsgFiGQeDn9K0IwQCcZJ61ojNrU07u7i07wgJHm IMjsu09zkc/WuGuL+VsMqgKRkEjJqXXJ5LmcRMx8qI8L2ye9Z0squqKmSQME9K56k3fQ3hBWuw+1 YYebCjqeTwAatw21rOvmRKUPfaSCKpCIsckgYq5Zo8RJABB64pKfcp021oWo4Z4smG9nTuMtkfrV hbvVosBbiKQAfxpjP5UxdwOSjAe3P8qJJVjBJyCDgAjBJrS8NzPkkuhcTXtQiGJbJJB1zG+P0NW4 vFMKn99aXEY7naCP0qkEUICeWI/AUyWFhIjocADBHrXO60b2RqqDauzobbxPpUmAboIemHUj+YrZ tNUtJwDDdROf9lwf61w0QSV2jliRiOQSByKcdOsZODAqt6oSD+lbwfMrpmUouLsz0dbhs/eBqX7T nghSPcV5slg0Rxb313DjsshI/KpP7S1awlAbUWmXaTh4xnggDJ/P8qcm4q7Eld2R6DvhJO+MHPYc UhgtJM8FQfoa4vSPEt3d3ghuPs8aZIMj5UDgkZOcc4wPery+LIFIEsLAnn5GB4/So51uyuV7HQSa RZynBKN7lf8A61Qt4fKjETkA9kcj+RrMtvFul3IJEroRyQ6kYrRh1qxuBmK8hbPYOB+lP3ZBdory 6FdrkLJKeM4JLfzzVF9LuF+8zY6Hgf8A1q6BdQEfzLOMAcENxWVq3jFI1FrBGt1dMQFRFBIPuRUu nDsNTkZn9nRBwbm9jgTIG+RDgH3IJpdSmjNhHDAwaOM7dwPDHk5A9Kw9RHnuDqc7T3TEHyY2wsIz yCehbtjt+VT3RuYbKGIW0pjQcnkjJA/LjFYTppPQ1i5PcY7HywM9KSI5fOewqsbhnGDEwx69KjF6 0bENE2cdqz16l8rZqDBJ/CkaVTJsJ+YdvWs8akoJzG4z7VDLdLNMHiypAxz60PRaCUXszYBwMetI QOveqkd6GUBh82MH0oa5Y9BWEld7G0di2TwcVWeUCeMEjJOKdHbXtyMxQyOPVVJFV306+Eob7NKS Dz8pq4we4pWZp844HWoAMAcdWq0ttOIwTC4JHPymohbzgAeS5wST8prVIxQvUAH1oI4Ip3kTkgiF xj1FHlSZAZcDv60WB6CDIA/OojnexHpUyFQSGIJHHFRMAGfIwSaLML9hSMRj3FOxxSH7oHanAHtS tqBd0mB5b2N0iLiIiRhzgAEZyR0HSuv0u4meRo3IMYcgBhuGPoen0rkdOlkt540XJEpEbKCQCCRj OOoBGau6edXfUpntYysZc4Z5QFIz6EH+X41pTT3REnbY7s2FjMCHsbZiRyfKUH8wM0N4W0iSxubl rPYY0LDY5AyBxwTVi3VjjBHTmr+pyi08MXJZSSwBwDjIJHGfoDXVEi7MDwxahFkCKRCWQEZ6Eg8/ jkflXTS27RLuiaQn0VsY/wA+1Ynh6dW0+dVIBR43ODnA24wffgfnXRlwV5wa46qtK6N46rUoi1Sd SZoY5Ox8yIH+Yyaqy+HNJuQTJp0IY8ZTK/yIFawBJ4P4UmSD16VlzyXUqyOcm8DaPLkqk8RPQq4I H4Ef1rJuvh1buMQXxUnnEkeP5E/yru93GTyKCARyDzVKq0KyPM5vh3fICYbi3l9gxU/qBWbL4J1m Ik/YncDuhDfyJr1koMkjoKQg9jTVXugseKXGiX1s+JrWVCOodSP5iqMts6g5Uj6iveGMhUqXJz2z xVOa0tpgfOtLeTPXdEpP54zTc4voFux4d5JGOD09KPLIOfWvYZvDWiz/AHtPVSe8bkfoSRWdc+BN Kf5op7iInjDAMB/Ki8ejEeWGMEg+pprocHjtXpEnw2L8w38R/wB9Sv8ALNUbr4c6soIi8mUdfkcc /gcGqjC+wHnyx/L09c1lzL+/Iz0Nd9ceCdZt1ObGY4B5Ckj9K5a50O+huCJYHBB6FSDT5GlccdWZ Mq4HXPFQIoL5IrTuLKZAQUYfhVQwMjZK4wPSiKdtQqLawkKHy88davwp8gHrVdIz5YGOvPAq9GmA vsOlKRCIbwYt8jucVveFUKRsxHUgVg33Eaj1Oa6Tw2uy1BOeTWFTaxtH4WdnbSEgY6AVbV23Ak4F Z1qcCr65yD2rJAuxZD4BweTSM5yBmmAgn6UhOeSaBjmbAye/SmzkJaOxPO0kflTVIklCjoOSai1R 9lrJg8EYqkrtCPH9dcQ61IASMgE1kyy7W3A/WtHxSQutuQeCAf0rHZsggntXZyp2M+Z30LKuHXI6 +laGk6o9hOEkYmFiNw9D61hRylGIPNWCRIvX3rOUbaMu/MjX8U3KyyuysCpjAGORzz/WqdjM1l9n l2hlKAEHoRVC5LfZgp5JIHJq63z2ELZ+5lSB+dOWkUjTDxTk77HSJqMU7eZHchQQAYzgYGOhB9eO RU32uVEG51RABgpGT37ZGBxXHZPXNIXbGAM/ShNo1lhIt3T0Ogur5SN005J5G3cGOM9QBwD9SMe9 Zc9+LuQRvKI4xk/MSSff3P8Anis6SQoCSO1OESOoY85HFVvuCpRj8L1Or0zxbpujWW2w00SXuSDP cEMAPZQOfoTj1B61zmoXt1qN008zszkk88AewHQD2FOgtkyFPBIyB0Jq3FZqch9wYHgYwPzqovoj F8kG3LVmQIGJBJ/DFDxDacdRXQRwxoQu0ZHHAzn86y7qIpMwII5q5U2ldjpYiNRtJGHMxLYAyB3q xYhY5UZumeajaJBclZCQuc5AzVj9yVBQsT7jipltoRFXnqe7gE5yaXGeAKUCnAYHNbHFqNx2xTwO OaAO9PAGOBQFxAMdKdigA9eRSgZotcBMDFLjn2oA7dKcAM0xDQO1OA4pcHpS49aSQABn0pcH0pQK cASKYIQCjA6U7rRjPagdxuOOBRg0/HpRj2osAzHOaXB4p23inAAUWAbjA5pcY7cU8Dg8CkxgZosA 3HpRjHOKfg5NGD+FADcUYyMU7HvRj86dgG4ycmjGelPA9aXHOQaVgGYx1pcU7HGaQjHSnYBMdxRj OKdik2kmiwrjcDrVcAyXJYdFGB9T1qzIQkbMTwBk1HboRGCRyeT9TQgZJt4xRsA//XUoUYzkA009 OKQytMNzKgPU5P0qveuxUKh4HFW408xpJCTgcCqd6zxW8jRIXcAlVzyT6UmBkR3UscxDxNgZyxOa p6veqluZcYKgn8e361ctLi6nlcXNj5CBQQSwJJwMg1zev3AdfLIxvbOPYVD7FKxzbASOxILMxJJI 6k1PBEEAIxnHOKUqBjGAKUkKB71cVYHIp3yu4LAZCEEn0FQpZXcpMywOyIAxKgnjnnjp0qe4ZxHJ tYYYEEEZzVjSdfurBCkMKOxAAJ7Y9jwevehuS2Fp1J7WZHVVGQcZweufStSMblz0BHNZcMUsk5ml 4ZjuOAAMn6VrwDKjArdbambSvocxrkDRXpHIDqHA9e39KpxRCW3YAASqc4A6j/EV1OtRpOUBUExr gHHQ1zot5UuCycEAsM98da5qiad0dFNpxtfUosWIxnGOgqS1aVpAgJ54z6VZlhWePzIFwx5YZ5B9 QPSrNlbGIb3+8eB7CiEXIJSt1FIu4APJnLkEZDqD+tTpqE4mMVzFA4I3ZxjqTT8YOSeKr3MRysoG Rgq3t3H58/lRVguW63FSqS5rPY0d1j5ZkeFSARkwSkEA+xp6Lp0iBlu7mIeskQYA/UHOKyNNthO0 uSwOAT6HnpWpcvFNALVFA28AjjJ9/WuRprVneoX3GTWbC5iWy1C2nZwSRtYEAY6jBqe3sdXu5Wig sBM6KXPlSqTgdTgkH9Ky3gIi2AAuCOR6Zp0lpMqkxXcowMgE+3bGDXRR5raHFWtfUkNh4rd3eLT7 gomNyLCTgEZGcDPSs651G6WUrc2jK4UIQSRyCSTgjrz+lWrXWdYsVcRaiqknLRysM8AAEZ9gBwe1 aEfijXTboreRcxKABkqcgccgn+lOTezRCSTuhnhq2LPqN1KpAS0kKkHkFgFH/oWapRRKJnVSzEcc gEg4+la7eKbtdOuLU6RFBHOAJJI7dR0IPBAFVtFUOs05AJZsDj8f6ihJyaVtBtpao0Y9ORNQMpKt GpKqNuNwHAJB7dOD+NXJNK0y4GZLOIE91G0/mMVEsoVckjHv2qnc6yIlKwBWI6ueQPp61u5xgjFJ ydiS70fSLSItLcXEKjoqSkk+wBBJrEa9hgDRadEYEb70hOZG+p7D2FVJbiW4kMkrs7HuT0qME4GB XLUruWiOunQS1kSxuQwIIyDnJFdloPi57O2aF7VJMnJcsQSffg1xa9MdauWTDcwz0ByK5ZN2NnFW Oxl8X6bOxMumqCeuUVv1IFVzrnh2UYl09R9IgP5GuRYfOe+KYSeuKFJ9w5E9Udcb3wg4G+1dSepX eP61EqeDX3CKSdCevU4/PNcjJ0OKpl3STKkgnj61pHmezJlG3U7oW/hRWyb24I7YXH8wa0bHTNBm U3MAvJo4zzkqAT6cgV5/HJ5gwQQfSu90aCZvC7JAjPIxOFUEkk8cAd6T5rkvRblq31hXZntblYIg cJGVRcAdiCST9Tx6Cn3Gt2jq8rCBgDlhC4LH3HIA/AH6VlJ4c1i0iMtxavAshABkIBzkDJXBOACT nA6U3xB4YttJ0lLlL9rm5MgDbI9qAEHkc564q1FtpEba3Gf8JTqd2CsErKAcDYoBA9zgD+VWbKTx LdYaKW7IHIBkH8if6VV8P2juIolAcyHcFTk5JwAR68dPf3r2HQbUaTBi4MUe4A4P3wf5gexrSMVf VENvc8vuNY1G0zFqNsA2PlkCBWz744I/X3qBNRMoDPGjqfQc165r2h2XiPTnQBRLglXA5B968Wnt 5dGvp7G7BQxnjI6/SnOnHl5ohFtuzL8ljDdRma24YclazblNozjnoa7Dw3pNpqdqJorsxzAkMjAE HvwBz0qW/wDA1zKpktriJ0J6BWOD74HFZRTlsXtucLgYHWrFrF5soXBI6kY61u3fgjV7ZQ4WGRc4 ysoHP44p8OgXllBFK+1ZJSQoBB6g5zjIGM9zQ4tArNlfT5opL2GNYNpjALHjnAGT+YJrc0QKI1Jj IJGSCQTn8Ky4tLurIz3UpRlKkFlIOCeg9uhrf0iIBY8jsK0pJrcmodHZW5cAHhRyTnoKk8XkJ4e8 tQCGZVA9sGtW2sVWxCNwWALEdfXFY/jDEWl20I5BlAAPfArpRlcXRoIovDuwbA8pZjjAJwf16VcW NjAhB52jjPfHSoLTS1ksrO4MhBWEqEwMEtk5z171YhkDRDPGCR/n865cQtmawZVjN0JirwsEJ4YE ED681awcZ71IWHY9aTr6Vys1Q0EA5Ip+4YxmmkDPJpcDGM0IQhYDODzTWORnIpcAnOBSEDGAOKLD I2JxxUTkjHXmpmBByDj61C5OaLAKhJPSnSKDGcikQkHAxUpIKEEAGnboA5AAgz1qbAIwTxTUAKj6 UpB7dRSs0IUFlGAxwPQ1XkkZvldVcdMOob+dTdiCKqyAA5yetWpNdQsiOTSdLvVIuNNtm9SE2n8x is248CeHrrJNrJET/cfP881tQkgHBNSKcggkCqjWmhNHGXPwx0xwfIvHjPYMmcfiDWdN8MpwMwXV vJ6AsQT+Yr0IhwTjB/GkORkEEVbrPqhI8i1P4c62Nuy2MgGT8hB/kasWOhX2nW6pPbSRkDJDKR/O vTncg4BIB7jiq0ks4yFmcD03GolKMlsWm0rHIwRsoGVIq58y8npWrLcTDIKxOB2aMEn8cZrOnnJb DWyD/dyP61nyLoHMluIpwCT1NI7YH1qs92EbBRgPrmm/a4ywJJAHY1PJJdBcyL8K7I8kcms3XHIt VAOMsKufbYCABIB25rM1eVZVjCMGwSTjmiKd9UVdNHlni+MrqCOerLjjvg1gocqAevSun8ZoWlgY Ak4IP6Vy0YYE8HFd0V7qZlJaiTAqQw/GnwykEAng0TITGQBziqqsRx0xSautQTsbH2KS8CCEqSDk 5OBj6+tXI9PvY0kSW2YIRkNkEZH0NVNMJMROe+BV8sQMgnPY5xXPKTvY9GhS9y9yiLK5MDTCIlRk n51yMe2c/pVnRiqXkUkqpsLYKyLk/l/jUq3MwIAlc/Uk0TXkyKCGXcCCCVB5/EUlJ7M0qU5uNkyv qd6j30tp9mi2nO1guCOM5rPt0Z4iBgY9T2q2ZHdi7MGdhgkii1iPnJEo4cgfma15kkYQoTj7zYto iy5SWUAqMhhyQfwrV0y5tpZZbTU5mSPBMcwzgEAnGOMk9K2T4Z08TCJJZhLtBbDAYH5ZNZb6dp01 wIGmuC4kZPmIIGBkn6VpH31octSMea7ZVfVbSK4KQqzRjgFiMj3NVbuQXbebEhxjBPUZq4NFsHiR 4pZz5hI4jGQAcZPPTP1rHeJoJWCSsMHGQetVJySsx0KN5c0CK4jU4YgZBwfWpLe0E0UjiVF2kZDE An6DvTvPcjDhXHfeoNS21gL7f5VqAQBkq2P5msuZdWbyVSOtj2oDPOOtPx+FAB6YpwHauk8sTGac ARSge1OxzTATB5FKAcY4pcccUoB70hiAClApccUoB7UxbABjgilwOwpQOcin4B6UaAMApSMDFPwB 2ox6UwG7c9qXHoKcAfSlxjtQAzBzmjGO1Pxx0pQMUANAz2OaAMnFPxSYGelFgExntS4OOKXGMUoG aBjcc9KUDHOKdilAwKLAMA4pdppxHegA5oFcTbxSY55p+O9GAaEDGY4xS4pwHOaXHc0AR4PcUoU9 6fj3pCKAsVbnLhIgPvNz9ByasKpA4qMDfcEkcKMD6nrU4UnpzT2QLcj2kZIzTJSEiJA+n1qfGDjF V5wXdEBPJyaVrgxFPl24UnGetZF/LcrIHiRWQZBUn9TyK17gADGOgqjIo2nPpUvzGtDHa5Z4iHXa fbgVw2r3fn6jIVOQnyj8K6vVroQQyuxCquQAT1OOB9a4CRgzM5JBJJOayv7xaVy0j5IJPFMnZnXC sAc561TYFuQSB9ahkDgnDHr1zVqXQTg9y9JlojuOT396j05M3ByOBnFJ5U9ptfduSSMMjEcEHrjI 6g5GfUUollSI7QAQdxIHJ+vtT5nFgo3VjoWKxrnBIUZwOpxUmlXX22Nm8optbGCc5rEXU5xCHKq+ DhsnBFT22vpEADAQAeSpq/aJ6kuDRp3jAzkcGqLqCxOMfSopNVt5mLEsufUUou7dsASrk9MnFNTi yeVroOWJR0GPWl2cZzTldHOVZSPY1KAOPemmFrkIUgDjIzSkAAgLkHgg1MAMdKCgI49Kbs9AWjui CcstuEtVCk/ez3+lU7S2lW4V5NxAYFsnnGfStLaADxnFCgj7oOKzdGLZr7eVtSNYyXLkkE8YzTyA c4HQ80uw5ySQKfsAHfBHpVxioqyMpScndkAjR2AYKee4zTngQyAlFU4GcDAPbJHrTtgByPpzSs4G SxAGOSeKbtbUFe+hD9gtidypsJOcoxU5+oNH2m20yFl3sxJJAJJJP40zzmkDlGKRry0hHIHt9egr NMAldnZGOTxk5OK5514x2NoUZS3GXOr3E74IAjHRc9fqaha+YKQyHHsatfYl6iMmmPZKRgow9K55 VYyepqqMlsVYZWlBYLgA9DS/aFU4ZSCKl+zSwqRErDJzgjNQkTb/AN5bk54yMikuVs095LUnSdDg 5xnsat6epEkj4JB6H1qrbWz3FwqJbTOxOFVEJJ+gAzXc6T4G1meIPLbfY4COXuiIwPwPP6UpwlbR BzrqzkHyGPHc03DHgAn1r0aPwZoNo5fUdUe5YdY7VcDP+8f8KvQyaLpa/wDEt0iBWHSW4/et9eeB +VNU11E6yWx5pY2iy6hFDOuN5G1GJAbJwBnsCe/pmr1xpVte621lYiNY4gPMkjBKk9Dgkk4z0ycn rVTxJqF1e+KLueZyWRAFI4woAxj0HP61J4TvkW6mDEF5EBB9cE5/nWsYNGMqjkdvp+geHdOiRntZ LycAEmaTCA+wGMj6mtf+2TBGIrVIraMcBYUC/wAuTXNXN86QEwxmSU/LGigksx6DArN/4QXxLqcv nX6tASNwEh5A/wB0dB9cVfs5PUjmOm1LUXtofMu1kXPI8yKQA/jtIH4modJn0nxKXsru7FvnACEZ aTv8p6Z47n8K5y6svEPheEZuHls2OCQxKg9uD0PuKy1BvxNOhWCeIGQ7TtDY5yMdDUqMo6hJ9j23 TrLTdEh8nTbZUOOZM7nb6sen0HFWFMl0zRkgAKWIHUgc/U8+tcr4P1v+19KTzXBuImEbnOMnjB/E V0M939hu4JVYHDZIB6juPyobbWoImtryS2kADHGenas/xjoUetWA1SzRftUQAkGOSo/qKuXyoJ98 RzG4DKR6Hn/61T2E0sAMoXdETtcHnr2NKDcX5Mps4bwqBBeXBhyfkA+Ycjmu+tFkfTZGBABcdfpU MljplkTN9lELSggSQ9GHuDxkd+hrnr+O4spBNbaqkuZQwRpTHhcgEbScHjqeT3oTjHRA1zamrr5a LQyN2BJIoHOOgyTTNJtpksA7Sb1kCuo5+XgYHU/pSeKpVOnW0RAw0gGOo6VM07Wmh7kADRxArx3G KuVm0Sr20KHiW5BstrSKXUNkEg4AAHPtk96k0ILMgc4IUZJHQnFcldC+nt76VgpW5AaNzgbm3AHp yAMGuh8GaHd2LRXc1ypVjgwopAPTkknBPXt+NOCbeoSPR4ZRLGGAIHSuX8ZzKHsYiu4liRzjB45/ Q11O8byvoK47xYTLrdhGOoQnH51rHclbm5cXq6bots7LuyqqACAckds1FZhXWRfRjx6dv6Vo3NvC 9mqzRq4QAgMAcEDqM96ybKTE8hxjcScfkf6msK/w3NIPUdcCWJhshkdc8lCDx9PWpo0fYGIIyOhG CPr71YMi+tG8H0rj0NUyIAgcmgkD1p5II6CmEADrQAgPOAKCevFJnmg85JzSu0FgYYAzxnpUDAZz mpHOB1NQEkD8aLjHggYxTnJCnFRA85JpzkMuAcGi+ugFlGIUZ9Kk3g8kVChAUZNKWBGAaPQLD94G TjrUb4J5GM0oA6nmopGw+M9qeonYemASM1IoAznBqmJSGAJ4BqyGyeCOaARISAeKaxzxUZYg9aaX IOKLhYGAJxVWQAE4FTs5zUMoJOc0aMOhUlQHocGqE0RHJH0IrRlYAcgHiqkwJXIPWhAUZ4FKgkck d6z57YY4OB1raZA9rkjkHFZ0qZBBycdaqMm1YlrqZMsDKMg59KgdHAzg89xWo8Z28Z9M1XMZMRB7 GqUibGVPAkqgSxJJjs6g4/Os6bRtOlJLWaA+qZH8q3mizkgYxUDRcEgVak1oLXc5qXw3pzkgGRM9 gQR/Ks6bwWh+aG7HsHXH8jXZ+WCMlQccUxo1xnA/Cr52K7ORt/DtzbRbQyOeehx/OmyaZcoMGJiR zwM11TxrglSQfQ1HtJGM5+hrNxTdzphipxilbQ457eRCAyMD7jFQ3SlVBI7Z6V3HlK/BIPsaZLYW 0o2vCjA8dBRyK9zZY6+jR56J4wBkkdjwatadPB/aMAaVEG8HcxwBjnJzXUT6FZMeIiv0J/rVGbw3 AeY3ZfqAf8KbgmV9cTVjpba9shDg6jbF+vySglj6kk8/SsV7GKSRpYmzIxIYqQeowTwfc1lHwzKe I5om+oI/xqpL4cvYySIEf3VhV024bHNKMZ9TcayktgZI3kSOMMQW44JzgkHv71y8rqZCcjOfWiXT LuHO61cYHJAqlLauAcRsCB1Oaqbc9zooNUloWMgnOQP610Xh4IIJWYgAnGT9K5FIHRAzhiCOecUo aNeQXB+prJwNKk+eNj6Dx2p4GKQDHA6U7B7V12PGQAY7U7GRQBzS4HWgBcelKB7UAdhSgAGnYBMc 4NOAIpcdqXGTikAYpwA9KTB6CnAGnYA6dBQB3p2PpRj1oATml/CjGKdjFDQDQM07GKXHrQORgUAN xxxS+maXBHIFGD1oC4AZoApcGnY4zQA0D0pcUYNGPWgAxnmjGe1OxRigBMcdKXFLj3pCSBkAnHYU wuJgA9aXHtikUseSpUdgetOxg0bAJikIAGc9Oad70yYAxlc8twPxoAZAuE3HqxJ/OpCWGMDP405F woAHA4p23vQ0CsRDJGWwPxqKL5rh3xwBgVYYbULHGACahjAjtQx4LEk0ugeRDOc5zisDWtXg0y3L Stl24CDqT6Cr+qajDp9rJcTMAqjgdyfQe9eZahqUmpXLzSkMpPyrnBUdgKxnLoi4or3uoXGqXAaV wqE4APAUf571XksJ0ywAkUfxIcj/AOt+NPMSsCY3IP8AdYY/WmpJLEfkZlI6gHFQvI0Tt0KzAgHI wfpTCoALFSfY1pi9kAy0cbH1ZATSTXJliMbRRgEdkAI98003cfMmiC+uYrm2s44s7kjw2ecHOCPp xn8arohGQRkEYqaOyxsdSChOGz2PqanliFpOQCHx0I6Eeopy2uRHR2KRQlSo6E81JDaq8THB3DnO OKArSSZHGTkn0qzHvhGEIJJznkVDbsXboyi0DFcBTwSeKge2Prj61po6mQszFQcg455re8N2eh3e s2w1K4JhbIkTBHOCByO2cHNFOz3Lq6WOSs3NvcKMgkEFWx0Pp9K3vKRovPt2bBPzx55U56j2Pb8q 6C/0fw9bDUIoVcXMNxIscjtlCAxAXA9Bjn1FcpBM9hKpDHCnqRnB9x3FW9X7pKs42Y/UU1LTrVr6 ViluyBokaMkyNnBAPGAMZJ+nHPGNbeKLl5Fja2RyTgbSQc/jmusvtTk1C1iiVUJUEFHclGJPJGTg E89fz6VhJp+mW3nfaYJ0uGIK7eijOTgehHFV7RdDL2bvqXYNTieIs8ZUjgjOefanx6hayMVD7SOT kEY+pqq0IljEMEHlxgZJIyx/wpYdJjDbnJI9AeDUe2kmaKlC2ppRyRTLuRww9RUsMQRXyxbcM/Qk 5z/SqUYWNWCjaAegq7amPY4ZlFvMCrZ6ow6MO+PYe9HtrslUr7FaaZEYquGb0Hb61QiM09w7S4Ea gYJ4A96slUhUlzgE9hy30FQRmW9nMKRNsXG1FBJJ9T6monUlJGtOmou7FLCfhARCpyAT94+ppY8Y AA71qWGgXtxcPbuqW7KoeQzuI1jU9CSTwT6dfar1hp2hxTs17fyPBFwXiUASNnoCx4A9SMnPArlc W3eR0SnFKyMhEJAwv6Vp2OgalqOPstlLIDxkIcfn0rQm8c+GNEymm6TFPIOBJMTIc+vOAPwFYOp/ FbW74FIZfIiHAWMbcD8MVUaSfmZSr9EdZF4EkgAfVdQtbJcZKMwZwPoP8aspbeEtNP3Zb6Re8kgj Qn6DnFeRT+IdQuWLyXDEnvmqjX8zk75WOfet405LZWMpVG92e2N4tit0Mdg2n2Knj9ynzY9zgms2 bV47tt82qwyEnq7sf5ivIxcsedxPtmnCdyBhicc9arkk9WRdHqbXEZyEubd+/Eyj+ZFRt9ocYjj3 45xGwb+RNecQ/aZmVI97MSAAoJJPoB612eleENSjiabVLTU4QoDIsMSkkZ5JBYEcexq1GQrJmTr+ m3U96kkMMguGAQx7SC3pgd63/Dfww1SeVLrUnOnRqQ2wjMpHsvb6nFd94c1fRfIa10wSLNH94Tkm X0Jyen0AGO+K15JmfOTgHkgf55/Gq50lYmy6DLGysNGi2WUIEmOZWILk/wC9jj6AfjSyzs+cnAPJ A/r6/jUEkyqMk4rPudRjiUksB+NRzN7gS38UNzaSwTANHIpUg+hrxMXBstSkiJyFLRsD3HIruNc8 YQWisqOGkwcKD3rz2Cy1DVZWmggdw7ElwMKD1PPTPNOL012Gk27I1fDOrzWd3cQwk5nKhcZwMZyT 6AA/pXQW+tXhul853dAcAnPA/GnWmlWWi6RbowE15KC0mVwcnoAD2GPx5Nb8NoktqqtEq7lGRjoa hSU3psU48u5tadqAuLdELAgDI9q1bed4GyhBB4YHkEehrirB3sLswSE8HKn1Haust5UeMMzogIzl mA/maLWdhas2CgurJ7ZW2iTJiY/8s3xwCfQ14vqlrqCanPDfzOk6OQeTgYPYelew24QEGOeGQEDK q4J/Ppn8ayPGGiw3lm2qPayvPbqFl2OF3KOjZIOSOhrRNPR6sNUc7bX7XOl6fbTTCWSCRsnvt4xn 6DI/Ct2S9LoqMQVIxjtgVjeDrvSp1vYriMRmMAwqTlmHORnHJ6eldXpWlQz6SZhHEV3MAZOSACRj P+NYuTTsy0klc5HU7xTqNnYwInPJB6AZJH6k12+kMyLbq4AAYYA56V5vqYkkvzKYEDqdqsgwQAeO etFxLfLboZLi7i4yrJcMCB9AcVtGRnJNs9cj09LG/u7pJZGacgsrHhcZPH5965nW50l8WQxlxvji QBecnJBJzjHf1715jqGqa2G8xdXvZIxjkzNkD35qXRdcvWu3lnmW4kBUA3GWYjI6HIIPHU54q3Jp XsJR1PcdWnlghkYH92I+ijLFs9h9KwNMnllZGlDLI2SwK4I6jp+Aqtd+I7k3RSeASQKoCmIjOcA5 OTjkEYpLDVkvLoBYTGY/mJJBJyR1x6c1jVknEuKaZvSeamCCSPYZpkU7Sg4ByDyPSreQQDmkJBHN cqsbEaue4Ip+/jrSECm5wMUrWAeGGfWlLDHSohnPWkLY4zRbqASHIxUJA9ac74ByaYGBNCXcTYuc Z+lLkkADg5pBtJwDUiqAc07dQuPAO3JNOJIHem5GMZNKSADk0rFKwK5HUimcPI5J9hTCxAJJpsbk AnpnmlqLQY4IapYnJwO+MVFITk460yNyrc03sK+padgD1ppIznNIzg49MU1iD0NJXGK75HSonJKg jvQW45NMLgqRnkU7WFchYZznFQsgK4BqVyc8GmZzn86BEaIRC64zVF0IJBGM1oKQGIJ6ioXIDYI4 qloD2M1kPIOahVNzMvqK1TEjHOOtQmBEkDDrmm2hGQUwSCOagYAggitW5tyHJAGM5/CqUkRBwRTX cTWpRRSdwAqNgBkkGrO0rJnoDwcVHIoDYIqk9RWKbAAE8H2qA4ySBVmRQcjpVcABiCM1QrWI9xzk jOKdvJ6kjFKxUcYxSKFIPb3poTSRGXJOAc0jMCuOtOYqAccmo8nmn6h1EyAeODTgxByDnFMyTSqQ SckAdeaAJQUf7w5NRvbQv95FYA9wDTsgEEc0EEtlT1ot2C9irc6XaXds0QhSOQcq6jHPofauHvrc 2k7RyqQVODkV6FgnOcjNVNR02LU7cqcLMB8rkdfY00ktzanWa0ex6KAO3NOA5oA9B1p2K6DkAClA x0oA4J9adgYxTAMZpcH0peO1LjnFACYOeadj2pcYpQKAExjtTsUuPWlwTQg3EApcZ4AoxS4HShAG DS4oxzRQDE56nOacB2ox2pcDPNOwCY/CjFOxxSgZ4oC4gHpRjAwaXHtRjigBPwpceooxg07HsKLA NxmlwKXFLjPOKAGcd6MZp5FAGDxTAb0FAA707GOMUYzxikAgUVGwBkUHoOamxTAuZCT24oW4D1HG KUgDHOc+lJgkEA4pcEgEnpTBaEF0SISB1YgCorhsQhQMACpLgkyImM45NZet3q2WnTzsQAik5NRJ 2QLVnnvjPUWv737NDIDHAcEA9W7/AJVyiSSRNjqM9DVqdHkkeZX3FmJOeuSc0z90ynzAQc44rBXs aq2wRys5wEyR6HFKZwrAMCp9+c1WcsXIUgAnAOOtK0TGNRnODzk00uoF5ZIiBmVckccD9acXQsoE qHOSMEHH154rPEZ2FsEgdTUalC3Uj8KFuFmdPc6NPBbpKArpKoYNFIGHTPIBOMdwaowRG5jMcjkT KPkUnGR6CqKSOUzFI3HXBIxTzJISruWYjoScmmgSZKgQKyudjDrkcn2pWIypBGPXNaKWgkjR3RSj EEAHk/U1m6hbLExK5CnOPb2qOVMrnaInfZKQFBUnGKnjgMtwkVsH81iAu0c59BzWdb7nl2DJz296 6j+xleCHaGecnLADAI9AfUUezZSqK2pWtfNt2Zrp2aJmYlmJOGJyT9SetZ+pztdzsbaDK44Ctnn3 96tXs8uw6YbmKG2t1ZgJFKktjJz6k4A7dKq2t3p8WlWzpKz3DljKNmCvPABycjHsKuK0sZSk27le xs9VXLxwuFHJBGePXFaK3UkZjWeEjceAACMj2PFS21/pwV2aeRZBgKBGTnIOe/Hb161bSbSMqLjU nXHIzbBsHvyTmlKCezKjVcd9iFpUc5I2k4zlSP5cUhkQZw6nHoCf6Vevb3RIlEdtqy3CkBiXtvLI PORwDn86pLqdiFwLuAZ9QQfz61m6buWqsX0GBGdTsSRgTyQuB+Z4qxFZIFLT3UcOAcIgLuT6ZxgV H/aFkDuNzA5BOAWOePxq5Yzw3s22JIXUYLOjZIH4E804wB1eiLWk2+mm6iE+nPMWIUF5SBnuSAMk ewIqz4j8TSeH3+y6SLKFtwBe2iwNvfLHnPbGaz9c1aPSLQkECZgVRc8gGvOrq/nvHJkkJUngZ6U+ S70I5r6s3dR8T+ZGYreMkty7ucljWBPfTTMN8rEDgDPA/CqpcAkH86aW7AcVagkJtkhYk+9AB644 9aYAzHABzXT+H/B95qpWa4JtrQ4zIw5bPZR3Pv0qyTnlQscDnPGK27HwlrOoANDYyBDyHkwi49ck jP4V1Zm0zwzctaWOmt9tUgedcxktk9wCM/litay0HxD4hw9zfXMEJ5KoBGMfQDOPqannV7Irldrs 5eL4b6k2C95ZIQOQZDkfpWlpfwtv7m6Amu4VgHLOgYnHsCB+fSvRNG8JaXog3KpnnPJd23HP1P8A StxnONoAVR0AGBVOfZE2M7RPDuk+HIgtlbq0+ADcPhnJ9jjgfQfjWhLKz5LHj0qJ5VXgkZqhc36R gkkce9Ztt6sZzHjOBdKlt/ENoNk0EgEu3jep45/l+IroG1aJ7ZJVYbWUMDnsRmuI8c69HLo8lkjB pJmVVAPTBBz+n61nTNqMumxQwTKhRAoDE5IAA6ilJqwJPodJqviiGDKhwT0AByTXMXWpTamCouzE pODtXcR+AP8AKuemeZJfInQrMDlieSfQA/561beyhtrIXHmqWZS20E5AwCfxwVx7sfSmotq6C6W5 ePh/RZ5Y/J1dSzD5/tGVwe+SBwD25OPWtyS0v9Ito4rWBZgy4jkRgyAevBOB3zj8a4aYMjEA5IJH ByCR1x7DpnvWp4WTU7zV47awuJIS5JZwSQFHUkdCPr1JFZV7RjzTeiNYSe0Udeli9sFv9UeMKFBU qwZWx3BBIPPp3qhc+JL6Yn7CiwoDgFxliPXngVr61YC2szNewJdGIjdJGArkdzxgfmDWLB/Ztzn7 NcowB5EjbCo9MsACfoc+1Y0sRTqq9N7DdN83vBZeIZxfRrq6q0ZO1ZlQZUnuQBgj24rSvtRtrmdr a5cxygZjkhc7JB2yDkj8Kw9SsiIyjAgMAynHXuDWKJWlhIZiWjIwf0xWsE5O4pJJaHW2Wqf2bPuS SQFeqFshhXqOmaxDe6dG8kSyxSKCCeDgjpn2rwyKYyRKzEkqfxxXo/gW5Mulyw55ikJX2BAP881q 01ZrczudEfDHh+dme0Bs5mIOcnAPtzgA1oWGjz2OhXNi8om3szRvHk8HBAP45/OoNxx8yg+5HP5i nRzyQtmN2Q+gPFD1+ILs5y60NwQ1xcQ24XrvPPH+fWoZ30FI1SW9acqMExKSPpkA/wA66TVS2r2L W0saPJjKOFwQf8K5DTtEjkujFOWXGcgcc0XSVx6vQSJNAaOZoLGacoMkSOQD+Gf5iqWneItLj1OG 2tfD0cE0jFRMSPk984yfwxXSJaWds5tooiCerkjmuH1m0bS9bSSMYRiSD2yDg04z5lYTjY1NNu2m uHWeB1RpWkJRjtAIwAB26dfatvS3hF8/lxOgCFVLEHJx149xWBblhYxKhYFuuD154rR0m3kXVIQ5 KqrgMSeAD/8ArrGeqZaep3ccjGJSGJyAaeWlAyQwH0pthaztbABdxT5G5HUdeOtSPp9yCCu8EE4O AxH0yDgVmoNq6RV1tcZ5jEcnmjex6mnNBMoO5GGOpIqMqwOME/hQ4vsF/MUO3Y0hJPOaCGXsaaWJ 4xilZ32Aa+T3pnIPJ4p5J9aYSQT3qrCbAvg5BqVJQRgmoDz1FA47ZpW7CT1LRkBHBxSFyBwetVyc jgmm+YRgEZosO5KzEjAPWmb2BwCKUFTyDg+9NdGA4OaLIL9w3sT2pc45NQlyvUU3zcjuaLAyczAY HWk88HjnPvVN2OSVzx2pFnOcMOfWjl6oXMWjLnjOKZ5oB5PUVG0gxkDNNJUjOcUWHce0ozkHiofO Cnr+tO+UrkDpULopB601FBdkhlBIPcUkjB8MDUIhAB5P50beQA3HvTsK7H5BGe9RuwIyDg+1IQ4O ARimMGB5pcr3C+g6Q+ZGCOo4NVmAZcHBp+9lJ4yD1qIuck7SBTUWg5kQywBgeAKgkg3x7gMkdats 4A5OKjWVQcA5Bp621EmrmXJGepqq6EMGAzityREIyAOapyW/HAoT6A9DLdDnOBzUZA5AxV5oSMg9 D+lV3hII6j0NUG5AAATkdR3prIMEipGQhup4HekwDk9+4pollcjAx60BBjIP1qYgYPGR9KjwR0BF OwthMHqKVW56YNIT3FCk56ZxTAmVgRj+dPkVcAp0Ayc8HNVywB9DU0bqeCSKT1A7kCnDjvSgdwKX GTzXUZgBTsZoxTsDFACAEU4Ak9KMd6cMY4o3AAOMYpcetLjuKUAUIAA9utGM0oAAzS44p9QExzS4 4owaXFILiYPY0oFGMD3pwGaYCYFKKKUcUw2ExmlApeAaMetAgI9KCMUoGDS4oGJjtS4pQMGjHekA nJ7UYpeOlGO1MAxk0YFLj0oI55oDcZggk0uPWlxS4xSuGwnQZpEBxkjrzQ3Cn3p6DCgUxMMc0AD0 pxAAyDzTSQBn0GaARTJ3XDt1AGK4n4jXZi0aOEHBmlAI9gMn+ldtHny2cjkkmvMfiXOWvLOEMQFR mP1Jx/QVlPUqNrnDJM6NlWIHpU4uw8eRw44IxVUDjkUyMEEnPelZFlkSgDbuIz2Hanhiw4lAI4we M1VeXAA2gEe3WkVwwHUHvScUBakllJw4BA6HH9aEcgZ2rn6VCgJcYIIHXmtGxgW6uooXljiViAXf oo9Tx0pN2Vxq7HwMIYyyygGQDcoFTGYAqzAMAeeBmn/2RcsJ5bUCeOJirFCMkA9cdcH1qzodhDfz SRTEjau4D8cc1lG0tnqaN2RPZSqkbFiEjJBXJ4GQe9QawIlt8Bhv3DIPXGK1JdBxFJDBIAGIIz0y OlR2+iX63ZmkaGQ7cEMSfb0rWEXszNtdDntEiV7sysyqEYAgnGQSRn6Cu3aS3gtY50mQRgkqxYYJ CkYB9ckVXs/BU0sBuN0akk4BPcEg9B7UDwdrjW1tbPPaGCKVnALMepGeMd8CrtLYl2OKt4W1/X44 pZ1zKSzuWwBgE4z26YFb8fg5NxC3KMD0AP8AhXYa9pf9madJqb2losasFIhXBBPQ9B1NclrOukX0 YswFEKbM45JOcnj2OM0pyUFsEYuTsZR0qJL0qJ0VFYglz1APUHHFX7jSxFJbNFBHdQuu8mM5AAJB BxyOh61X+3w3EbxzwRp5hAEg+UqeSec4575qnc6omnXBSznDRlQDICGIIznGD09647znK6N2owWo sp09I2lVYyTk+WGyR7AH8qrrfWThsWUmcYACA5NZ0l1EFDR3si5OSgQgD3HNOUyTzpIl7JICwJJB BGDjkZP511xTtqY3W50Om6at/EtzHAkak5UOASfQ4HbPrita91ODQLFTN5b3ZUABFC5PrgAfnWed csNPhEduEV9oBcZxwPfqa4a9vJb27eaWVnJJ5Y5OPSlq2NtEt/qM+oXDTTsSxPQdAPQVSZ8HHc9K DkjOTSIhZsAEk+1WtFoTuIASeetaNppU9zG8oAVVGSG4Jz6V0Og+EmvbZL1Zo5QMl4wfmTB7gjp7 jIrutF8MXdzdeY0SGIDgMgKnjGSD1pXuUklucvoOh2mnWMeo6jCSScpGVyXPbA7j8K6WPS9f125M lqotLdT+7klUggeoXIx+OK7e10KztmEkqrNKBgHHC+w9Pw/OtInjaAFUdgMCk2uom+x5/c2mu+Hn W+1BbfV4oRgyBAGjXuOBnHuCa7DStYttZ06O6tHHktwUAxtI6gj1FWpShQo4BUgggjII9K898P3B 0TxlqukIcWxAmjHZehH6MB+AoVnsLV6s9CZwoJJqlPeqgJJArF1LX4LZSWcAj3rj77xHc3jMsJCL /eY4/IVLA6jU/EEFsSzSKCRjrzXKz6vfavIY7VSqnueCR7D0ptppkM8pa8vCp6h9hYH6DI49/wCd dBpWlx243Q3cc0YPQxspI9ATkH86m+tilHS7PMb+K9OstDJE7yxsQFAJzg9TntXQ6uljp0IispZD dcGSTedicZIAHUema6fV9Xt4pH8qBZpFXDFIwSQDnGcZIzmuN1fTbucRzi6tZ0uCWHkPkLjkgjAw fb2qnrZJDjbqc5cXstzOZnfLHjPTOOKjNxIRksWGABz2GB/QflWvqHhy9g0oX5jQW4baWEqkg5xy ucjn2rIsbC4v7tbe2AaRjhUwck/gP51TkoRu9EhNXdkaOiabfa3ei0skJZhhjnAAzkkn0yM/hXrn h3w4vhqKR3ZZLqYAPIowAB0Ud8e/emeDvD66DYtCSJLtsGRwMAZ7D2963bqAzxBWZkyeQrYYEHjk ZH4Zr5PMswdeThB2ijuo0lBXe4w2wuVaNlDKwIIIzkGucuPhvp/D2t1cQSg5ycMAfYcEfnXV2bBD tOCQODVhyS2cknBwAQM8e9eXQxFbDu9N6GrhGWjPJ9Sl1XQHMF6wvrWQlfNYFmOOwZgSp+n4ZqgI tPvmkeyfyZGwBbu24ZPBO8gAc88/nXoPjC0S508KzKPMUrtznkcgj3B7+9ePyQSRS7CpwOcHofev scBWdekp9Thqx5JWNf7PNbSPFIBlSQSCCCfYjIP4V3vw5cs16o6BVP48/wCFefWWu3dskcMhE8Qc N5cxJjXjqFBAzgmu58HeItCs2mdzJbvO4XL8qTkkBVAJAGe5Ndt7LUx06HopA600qKWOWKVd0Uiu M4OCDg+/oaU0Kz2BkDrjpXO3OqQ6drJiuAVRgCHA6A10xBNefeOz5d/CwHVM5z70ON1Yadnc6mNI 57pZLeUShjn5TmsrxhYGfTw6qC8bb1I69BkfpXIaTrctpMrK7YQgkA9R3H5V39xqOnX9p5drceYh AbLrg9OnPX8KxV4y1NG00c5oiG9tERBucDAA71rxRTJLHbLDKJJGG48bccAA556k1h6Yx0/VprUN tAbchB7HkEfSutnuxFGs8022ZBkFicHaCRn6kAVM73tYcUje0m6aG4+zO376I7Tz/rEBxj3IPT24 rpgQQCOh715PcanNPHLIjkuGDb0J4OSeD2GTXT+HvGUV15dtffu5jwJMYVj7+hP5fSqpVOV2ZE49 UdnkZxQQD1FHB5FLXYZFe4V/LzFEjt6OccfXBqOCESRk3FrHGwOMKQc++cCreKKVrsdysbC2P/LI D6Eiom0q1b+Fh9DV78aKXKuwXZmHR4Cfldx+X+FMOig9Jz+K/wD161SM9DSfN3xUuCvsF2Y50V8c Sr+RFMbQ5ccMn5n/AArRltGaYTJLMDnoJOPyIxVlCxXkEH0OP6UKC7DuzAOj3K9FDD2YUw6deKf9 Wx/X+VdLkUtHs4hzM5OSwuiMGF/yNVms5U4ZSPqMV2tRyyxxIWkZVUdSTik6SDmZxfkMDypxTJLY nlVOfpXZRy2tyD5bRSY64wcVIYYSP9WmP90UlBdGF2cIYpE4IJHXpTdrE4wRXctaWrDDQx/kKhbS 7Fx/ql/Bj/jSdNb3Hc4rcUOM8UFhgEEYrrX0K0ccKw+jf/WqnNoEIU7S4/I/4VDglqNNvQ5lmJPB qIu2TW3JpSLwJfzXH9arvpqgYMij3IP+FTzR2DlkjNWTIwTjHeguMYPSrMmnMOVdSPY1Xa0kAwSC PrR7vRi1Ii+CQelCyKBggYPWke2lHYEVGY5AMlTj2osujDVPYWVFwSCCDVRgozgflUuZEyNpqGQM TkKR7UAtSNmOQMnHsaCQRlWJ+tRsD1Ixz6UAsCCKLAhrbjzgGmEDBDcj+VSsScgjBqInB6Uw2Kso AOMH64qEjByCKulQSCKY8av1XB9qd1sMqhQfxqN1BbAqd4QvTIqJlOPXHqKa1Fa4wRjHPekCYPFS AsByM/Sl2568fUUJ20CxDtB4NKEAbhsCnbcHPWgrkHBp6BY74DFOwMdKBkcinKMnNdJkAHFLjHX6 UYFKAPSgBcYpcYoA/GnCnbsAc+tKBQBS/wAqADHFLRilA4oAMc4oxRgUvWgA4680vuBSYPelHpQg FwBzmgD1pcd8UvNACAUoo70Yx3poQdaXHaj0oGTz0pbgLikxzS0uDTC4g9KUD1pAD1ApcUAGM9KQ Ag0tGMUAhCKXFGKXAoAYRkgVIBxzTMZf1wKfigPMTBxjNMmOIifwqXFRScsi8ctQMjlULCAMdORX lHxGQnVrY+sRx+des3GNpHavNfiJbESWk+3IIZSfQgg/1rKfccUedtGcZxg1CAQScnjtV7ywRw2M +tRyWzj5gu4Y6ipTNLFJlJ+tNjBDgE4zU7DjkYNRgEOCR0p3uTuSohBJJOBUiuQ2FJGfep1hRogw Un15pPJV1JUYZRnr1qG0UkyW0u7mynE8ErIyngqSPwrovD9+J72QOiq7KSWAwTk5Oa5uFDIAAMk+ lb+jadPDcJcERhGViA0qqSAccAkHOe3eiMUncblpY6nK5BBOSfSp4wgkALjkE9DXPT6zHFKVVWO0 84IP8qik8UwIyv8AZpCAD1I5zVpkabnoekqp08hnPErDoehY+3vV+KON2MYck4JU4PUdulea2fxJ tbe1ki/s6RyZCwIlA4yDjpUy/E9FAul0mXy1bBHnAE8fStYpvYhtLc7PxcYl8G6gJQ7qBGSinBOH Xocdea8lmvtKmeFrS1mhVFAkR2DlmB5OcDHbjHFb+ufEWHUtCuLRNNdDcKAHaUEKcg8jHPSuFS4i t1Z5GA3EcKAee5rCpSdRNo0jU5XY3/GGs6PeR2g0zTzbIgIkXfuLHsc4HvXImeEvkoQAMcnvmrEa G4lD8lCSQTxwa1007THlWG6nMIYAk7SR35z2+n60qUeVWbHN3Zz5uYFJzCGBHQnGKu2IkvVkW3VY UGSxB+6vcZNa0+l6DBIRbz3Ewx1aEL+mT+dY97MsIeOAMquMdAMj6CtXroiE/IoXkoeTZGSUXgH1 96rr1wM9alSB5GCqCST0A5JrpdP8Ba9fW/nx6bMUxkgkKSPYEg01HQfmzmoonlcIiksTgADrXpXg 7wDdSgT3NttDDI3jGPw7Vq+C4vDulXqWN5ZPBqRIAe5HVvQZHGe2OD616dnC7VAVewAwKltLYEYu l+FdN0rLrEHlPJPYH/PpW0OAFACqOgAwKQkAc4qCWdUByRxUtgSs4UdRVWe6CAnOKyr7WI4FO5wM e9cnqHiOWclLYFs8Z7CpvYDpNR12C2Qs0gAAJOTXlc3iEy+Ir7VVdUjZRCjk9QABwO/T9asa3HPJ p0ss8zFgpIVTgE9vXiuUh0S7uFVyhwwBH0NVFX6jdzVl8RwyyhiHkPcse/sO1dX4eu9Fv9P8240h JJAxG95HJOAPQ4/IVwraDcoQChwa9B8NX+geG/Ce/Vpc3LTtsgQbnIAHOOw68nFNwW4k7GpPeaZ5 DKlgirEu9yXYlVHXGT+lXi7S2CEKYhIu7YBgqvYexPT86yYPEOkaz576bbzKIoj5izKMEnhRwTnk g49q2bAtEtpHcOWklzIcnJCjOB+eP1qE0mooqztdnHG6NxeyRxgLg7R6ADgf4/jVxdCd42ltlLFz uIHTI4J/oa07bRNSfLQrAQGIBMIJOCRyce1dZ4fP2fTzHcafbyTK7hpNpAbDEdBgDtWijrdkN6HB 3doYtOkgvWVUlGwgsAQxzg468dzVvwR4eXTNOkv51X7TNkLk8hATjH1xn6YpPGVgbu8uLpGEUhYb IwMKFC4GOeuQO3rXSIhOjiGI4LQBFPuVwK8XOazhCMF9pnVhY3u2WbCWQWplYYMrEoAOQvQZz69f xqzGCXIAyD3rG0S7lvbUNNG6Mp24Ycccce2RXQQhkIIGfrXylaKjUstjs1epIlscbzlT2IFBOGBy MdDxT5bguwQnBI4PaqN9cGBCsZBkI6noM/zPtU0qUqs1CI3LlV2c54ru4txQKcQKSzk8EkDj8h+t eRjU5Q0ysQwkIDE8kAdAD24wPpXVeL9YRr0WNtLvKtmYjpuzyCe59e3auNvLZknZkB2Mcr9DX3OA oKjRUDzqsuaTZpQPbXKOwcIwAAVj1JOPp6k+wqw9jPbSIxUhgAykDOAQCD7cEH6EVzyhkOSCAOMi tOx1u6sywVg6MAHVxkMAQcH2JAB9hiu6y2MtDa0rxBqWjOhguJFiWQSSAMQZD6HvjB6e9d5oXxC+ 3tHDfWwWV2bJj4VVGME5znuMD2rhIJrO/jVmgkhAAUOQSpb5Rkn67mPsABXSeHb+w0KxWZ9PSWae YBriZuI4wRnCjGTnJPPtUSgt1uUr9T1OONg3+kMqAgsqAEtgDJJ5ABwOnWuF+I1lJEYborm3ZQqu ARknJ6HpXZ2eq6feANFMpSS6VkkAO2QNwwBI5IyQRWR4z1GwFlZabcwm5KuFdNxVhjgEAEE85Pvi rjpuJ67HjUU5E4A46ium0y5Y20TA8gkHv0NTr4Lub0+faadexKW3ZKEqFPQAEZyD3ycitbQ/Dc2m X9s2q25FozsXLEoEAGeSQBzj1xzzSaQJO50Gk6PZuwv7iCG6dlwxaRkER64OOD9ME/Sm6vpwggaW zJTI5UEgEHngnqOPWlTXLC5b7HYxqhjuA0uyQSBQSQCSDjHAGex61YjCfY3MpKxkSTFwegJwD+SH 8zUOPQtO2xg6HcPcy3FszHEoIz6H/wCvUtxpZtFR1YMrAkEH0OCPqKyo7lZ1ku9OhMKQAJJySGOe vOeuOR2rodO1JNTtwtyQBGQCSeAD/In1rCS5Wy0mzofDetuITBdtlUA2uTyASBg+vUV1Iu4G6Sp+ dea6rK1hDPcq+BtLRkfp0/CpLfxjdhAJNj5A++gP64rSlJpGc0rnpSyK33WB+hp2RXAJ4wRsebaQ /Vcg/oatw+K7M9UnT/clyP1FaqZFjtaSuYj8TWZ+7dTLn+8ob+tWo9et36XsJPoykfyzT50FjdzR msxNUVhkSW7/AO7Jg/rU63wYZ8s49VOf5Ucy7hYuUVVN9Ev3gy/UUq31uw/1gH14p8yCzLVJgVEs 8TfdkU/Qipc5HWmmhCFQR1I+lQywyMpAYMO4YA5/SrFFFrgnYoJAYAzJbopbqVAyfypjzvyCrKR6 H/61aP40hCnggVm6d9mWp90YzTEnBL89yP8A9dRGWQHGSR6g1uFUHIUflTS0fQgflWbprZsrn8jC Nw+cZI96zbvVXhlCCKZucbgBg+45z+ldFcW9vKTwAfpVB7ULkK5A9ASKxlGz3LTuZ4uXY4Kn1qNp 1ZSrA5+taUcESFvNUOD0zwR+VQy2UDElAR7ZqNAdzNJVF3B2z6dqikIcEqxJPUYxirktkcYDHFV/ sEinhgfrTStqBSy54PJpHRwvGCPQ1ca0mRCUVC3YsMgfhkVTWK9QkTLnngqMcU7voFkVjuLYOM0j AgYGQasPCxJJUg98g0EkKAVUk09UIpsQp+ZQc+1NzERkKD6jFWwSRgqpB9RTBaAv8p5PAAFHkKxW IhI5AqIxxE4IFTSwBJChdS/oDzVWWKRDypxTXqDVh3lRZPHX3qMxRDJJb8DTQxztIbNOIAHIOKNb 6iIikJBBYgn1FRNBGTw4/KpWC9eaaUDfxgD601dD0WhAbUnkMD+FKIG6Ej61aWBjyHB/GpBbuOeD TuK1yi1sSTjGfrUbWzAkYP51eYMG5IFNyBySDRdoR1Q5pwAz70g9KcOfrXamYjgOKUDI7UAE9KXG KAAA5zSgY6UoHqKUDtQAClHPFAFOAHWmG4gz3pfcCgA9hQBigAx3pQKPenYoATHrSgcUuPWjGTQA Y54NLgUfSjHrTEHvRS4oxk0DClwRzRg0YxQIKMEUuMUUDClx2oxRigBKMYpSAe1GMUgEoAzS49aO ACaAGqCWJOME8VKACOTimIABzTiCTxTEhMZOBUZAa4AOeATUuMDk5qGIB3kY5GDgUvMGMnIPA5rk vHEDNoRmVQTC4YkjOAeD/Susfljk1S1C0jvrKa1kAKyKVP41EldDW9zxPdBLwYyD6qaQIoI2SkcD AYYpdR0+SxvZIMkOrEEEVGZJUULIocd89azt2NfNjXEYH72IHJ6g/wCFC2tpKAAzKx4znikIilIV SVJOMMeATTPKeLAZTj196mzQE4tJbZTkb4v7wHA+tKqAncDkEc0tvcvFkA8dx6/WrUYt5ASAUyMn HTNJt9SloQIUQYEIJx15zVqK3WVQ0pkjjyAXAzgfnUDOiEjOR61aSCe7tXtrZwJJGXhjgYH+RRqL 5FOK1d2JDgAnHP8AOqmqwyWbGMsGGMgjoR7VakSSOR1eZQykqQe5HWqcttPdsFMgIB4LZx+dVFsN CPTNOOoXAhUBSRksegHrXV3ngcQ6A93BqMciqTmMqVLY5JHJzgc9qo6Tob2is8l0FDDDE8DGc4/T 2rTnvdPtQUWaaQZyAr5A9icelCquLtFg4J/EcfFBujEQBbg4461MujNJEpEDEj/Z61strNugCwWs EIJA3NyQOfT/ADxUDau7g5uVQ54EcQOeDzk++B/+rk52x2WxFH4b8yJCszQvgEox6e9LDoyxzb5L 2MsDyHLZAHuRV2CKC9VmlfUpgM4MaDA4JGT9AT+B+o39M8IRaix8vTbhIwceZcTckfNk4A91/I+v B7z0FZJmEYrQEA3aEk4wqk9xVm0+Hd1rdyZ/OeOM4IJi2jH4nPpz716NpXg7S9MYSGFJJh0JGQPp n/PvXQYAAUAKo6ADAqox5ddxSlfSxzOheBNG0JVYRCe4HJkfkg+x7fh+ddMAAoUAKo6ADAoJA9qi eVVByelNttkpHN+NvD8OraPJcIoW7tlMkbgYJA5IJ/Dj3pfCGvjV/DsM0rEzRExSEnkkY5P1GDV7 UtUht7WV5WAQIS2fTHNeTeF9fOmaTdIo5luCy5OABgDOfwob01D0PWLzVooUJLgY964/UvFYdylv lyDgkdB+Ncjf+IBPKftE+9RyY0PH0Pc1kXGv5IS3hCKD1PU/4Cs230Gl3OmnumnkzdTgk9E3YJqW EqoyoAOOorjG1l2O5ooye5KjPfv+NTxa68S4aJWAGByRxx6Edv5nvghWkx2XQ3tYkWTSLjaQx2EA jnFcpB4l1G3wElHygADaCMAADt6AVfn1pbqF4hbQpvGAVyMZJPHOPbvwB757rw54U0jSfDpn1yCO R7kAuXUkoCeFGOQeecc5+laRtFXYrHnz+NNVP/LROOP9Wv8AhT76/ttV0a2mmUf2iJ3VyuADHhSp IHfJPP1re8Y/DqXTGF7pEU09iwywOC0Z/mRjvj61y+jaa1/rNrZAEebKqEjqASAf0rRO6unoTa25 3/hfShb6bY2pXE96/wBplx1EYyEB+vLVi654wni8YTTWL4gjjNsAOhXuR9TXQarq6aNHql0QFmkQ QWiD+FQNq4+gBP415fDORITsViRj5vXPWsIe9JyNkk7Reh6zpPj1ZrURLqn9ny5yyucKT3IJwOfr WnB4tsbCBzLq6XEjszM6MCSSSegz0z615pp3hrU9QVGa2jhiPIaU7SR7DOf0x712em+CNNTmcySD qQDtA9RnqfwNaOVtxSppbO5zGveLLrUtZM0KB4Yh5cXmAnHvj1649M12/hfU7q60mNLu2nMi4XeI jgg9D07dK6XStJ0DT1VotOgUqMBmABJ+p5NaNxrotEP2dLWP0IUsR/8AWNceKw8MVFRktioTdPVG Ra6Zew35mAb7I4B27ckMepHfn0rVd3XgQy4HbaR/OiPxY0qYdogeP4M/XHUVHN4mlLYM230wB+fT ivPnktKfVl/WX1JYy7PtNrMzAZAwBVbVfCWqa3GAl5HZBlIJ8sswB445AGfXr71E/iVmOGndie4O KqTa+wYsHcg8csTW+HyunQkpJakyxHMrFGH4K2sLmSbWScdSIsY/M1qxfB7RHRTJfXUoHUgqAf0N UD4hcEFUOR33HNPXxLKVCMGIznBY4/n/AEr1k2uhhzXJ7n4O6HLOpivZo0BBMZAOcdfTrVGb4I6c WZk1h1yScGEHA9PvUTa9cBgUVAc9QOfz9akTxJdFQpc57nOf503KdtAuLdaHP4MtLZ7S/Se3jYKy BNuOMZIyQc81ymuXE2r3rNbBN8iklCQAcDJ6kAHArX1rUJ7/AE+SIsTkEgE8ZFcDFfFJ0IYgg4/p WTh9plc11ZHceF9bg0e22PCQ7EhkMgYZ7HBH9aiDrfeKxNp9hNO7urM7/MqnjJOD0H1Fc4JCWyAO eTV601F7ZsxkofUGp53sNprU9Gk8bXFqTC6RK0ZKsMYGQcHvWD4n8UPq2m+ThFKksNvGeMYPrXA6 lq0xvZSznLHd17mqFxfyOgIY4AweaI0+ouZnQaPdRDVFktXMFww2so6MD1GDwQfQ10+pi5v9IuFa 9WCGGNRs3ABgDgDj6k9h1rhNMl3whs4IJ6c1otKZAFIGB7Dmjn5ZajSurnQNqlnBoscelsTCQUmZ iAXbAJOPTnqeuKy9P137G00ZiDLJjHPA6/41RlIS3YIAB1wBistiykEtkk4Jo5VJAm0ztrm9luPC s6El9isBk/dBGR+oNRWzGSCN8n5lB/Sl02JpfDV6COGKqQevIapNJjL6ZASOQgGfwpJWVhN3ZIFJ GBn8qQkqSAM1dSHBAxwaSS3GAcYqrA2UvMcdCR9DTluXXgk1MIMnBGRTGtwTgZpBowF/Kp4cj8as w6vcoeJWwPeqn2fYwPX2oMRJJAAHpRoFkbCeIbuMACZ/zqePxRcjlirfVQawzESpAXOBwaiWJgTk YxRYR1kfisEgPBGT7Aj+VW4vFNqMZiZSf7khH881xWxhxg0BCRnJosGp6Cnii0OAJbhPqQw/pVuL xHatj/TVH+/Hj+RNeaFXHIJpN7DgE/hQm+4M9Xj1u3cZFzbP7bip/UVOupRvgBVbP9yRW/rXkBmk XkE0q3ky9GYfjVczCx7F58JGWWRR6lTj9KaWtnyBOAfQn/GvJYtZvoeUnkXvwxFXI/FGpJybhmHo /wAw/Wk9QVz0t4FcfJKjegDCqsttImTsb6jn+VcTF4vuzw8UDnPUxgH9MVbTxKx5NuB/uMR/Mmoc E9ilNrc6AhsnBA/Gm7ZCeGGPSsceJ4CuJFmBHH3gw/UVLHrti5AMpUn+8pH8iazdNlKaNTy5MZqJ gynJBqKPUrF8YnjOewk2n9RU6T20nC72z/cmU/yqeVj5l0Gh2xwR+IpGLHqo+tPc4ztguf0I/lVW S7ZDgpKv1WjlYXQuxuy5qORGwSUzn1FN/tAg4IB/A/40f2ih4Kkfj/8AWosw0IGUn/lkv5VCFXeA 6FR6jNW2vYScEn8qjaeB8gEihegGdJaRmYNEoyCTycf0qaC2WcssxCEdCeQamJiycMKVDGSPukfW h90HUY2kqTwyEdjiopdJIU4Zc1pI6gYCke4NDSH0JHvRdhZHOto07McMMZ6U86U4t9qxAv3YnP5A H+dbRYEngimebg8EijmY0kc5/Z91GCCpyD6VF9mukJyGH4V1PmgnkA1G0iHkqKpS8hcqOXaOcDJB P4U3BGCVIIrpHFu3UYqB7aFh8pH50+ZC5TRGc9akANNRcipQMV2nOwxkUoHHNKKXHqKe4CAYpwHr QBS0wDBxS44pcZFLjnihANGB2pccdaXHHNFDATAFO6ijr7UYouAAe1L06UehpaAEwD1FLjtSgcUG i4BjFGOM5pcZPNAGO1ACYFLSijHrTAMUYoApcUgQn0o68UtHINABjNGKKUDIpgJg+lI3Q0/Axims M4HvQhN6CqOKXFKBwBSkEdqAsNbAUnHSooh+7J9SaklOIyfaok4QCl0GL5DOCVUnHJp66a8sZJIB xnFSwTqjEHvxxV4SJGAQCT1B7DvzUN2HZHifjRoU8ROiqoKooYjqTyefwIrm5EjcEKean8S3hvPE V/OSSGmYDnoAcD+VZQcjBBPFZq71LSYskRLYHP1qaGVVQpMSU7Hrg09YGeMEkg9eKZJCRGRjpSY0 IYkLfunBB6DvU9nbPPMEVlUA9WOB+Z4qC0if7QCFJA5PsKvSOqKUQYHUnuTSbWxS1RSuUZSzDOM8 HtVZLyYuI4XZZA25SpOQeR29jipLqVnARMkk4A961tF0xYmXfhpZCMkc4HpRdJXZNm3ZDLXRGuLi FZpXkEq+ZJMBhUJGSGJHBHc+3eqV/DLo16YXdXU8ABgwI+o4NdxqU9to2l75Ujk81SI4XGQe24ju PSvLzICZUbJYNlBzhQTn/wCtShNzemw5Ll0Lr3U7korkqBnkk8U+3gDgtcXaRoBkgnJPsAKoQhpX 4BPGAB3rqtF8E6lqpDNEYYSQd7jBI9h1q1DXYL6alO2l0WDg2097JxjJ2qTkfjjHH4+1dJo2ia1q pAhsLaxtzxuMYLY56Z57n07emK7LQ/BOm6SA5j82YdXfn8h2rqEiVFAUAAdABV2sS32MTTPDNtZY e4d7mbAyXOQO/Tp3PStxUAAUAKB0AGBTjgdaY8gA60m2IdwPQVG8oUdcVTuL5IgSWA/Gub1TxNFB lI23Oc4A5NDYHQXWopCDlgPxrldV8VxQB1RtzAEkA9PcnsKx5Li/1P5iSsbEgIDgnjqT2HIqex8O 6dfQPDqM1xHG5BzCoJbGepJ6Z/OlddQSOI1LxHd6zLJC7MkBBG0HBYe59Kht1QIsYUYUcA16LD8P PDAl2rc34B5yVU/1q8ngDw5GSq319uHOTCCP50aMpJJa7nB20iCMwyRK8R4II6fSqN/oha6j+wgz IqNM6KvMYGBkj057elemjwjpsKkpcu2MAZhPJ+mahj0RbK+a9tZXE2Mf6ogYHAA5PXJqeXsOMrPy POtGkSe4WKRlSYHCuQBnHY+9XtR0NQDPCF4PzrgAgnqQPT2rqL7wxBe3zXT2xjdiN3kKVBIGScYw CfbqayfEDwW9t9gtmle6CgybyCQOCAffGKfLZai5k3dGV4asIrnWY1WJBHGd7kqCcDoPxNeoPKrR iNkR1JBAYA4I6GvK9I1FtOlMgGYnwGx1Fdnaa1bzqpEykEevND2BNHUQam0ZKSAMnTB7VzE9hYXH jGz1G0ijiELMZQi4LkggHjjIJpuo6qsFoRCS8rfKgHJJNZugW17p32h5LlpJJ8YyeYxnJAPqT1Iq UmDsyn4s0C61XXmCTItuACXGSATngD1/T3q3onhi205w0EIecciR1DEe4HQfhW7BbBFMsxCqeQTy SfYU2W/aMssDFUIwR6iqinblQN31Y9J1t5CZSHcnq3I9+KbLqL8lDj09qzWLuxJJPrQAQc81agup DlbREklzNKSWkY8560quxGNxPtmowM88k04KQAR61SXYlsUjBBxjtT95I5PTikIB96QLg5I4p2Aa 2egzmkJY4BpzAjtmjBIz360aMBpXuCRS4OMg89Kfg+lAGfrRYkYRx2pAMcipSuDgUhB7UWHqQSk+ U/J6H+Ved7iLjHOA2f1r0lkypBHUYrzp4yl0xI4DH8eaTWhUWdILYiJHBB3DpSJAXcKePU4JxWqk AOlwOAMnOTjmm29szToFbBJwDjOK5eU2vdHH6zEUuhjqRWZvYKVJ6muj8S2zRXCEjPUE/Q1gbCTn HSt4rRXM3uamhhnaRO2Aa3lgIOOKxvDik6iEGOR36V1lxaNHMykYIPIFYzV3oXF6WMueE+Q+Bng/ nWbZrHLBMJASUZWyOuMkH+ldI0ANswzyT0xzjH0rD0mEm5u0AyRExxj0Iq6a0CVjsNNnhls7tIxI UJhB3nJyAw/LpVvRrJjpcRA+6COnoSP6VjaAxi0u8kJ4E8QP4bq9P0RLAaaYXTDrLICw5ydxPHtz TSV9SWzlmtnBAC8j2p3kOVIKgnP5V2x0qwk5WUc+1MOiQfwzJj3NXyroTdnEfZWB5Xj2oNkc5xXa /wBgITxIh+hoHh8A8spFLlHdnDtZNkZXNJ9i4IKnmu7bQjxgLxULaG4PCA/SnyCucUtsQCAppGtC OxrsG0SUHIjPPoKjfR5AOYjg+1JxGpHIC2B4II/CgW+BgDP4V07aSQc7CPqKZ/ZhAPymlyi5jmjA SOQKY1pnoK6Q6YRnIyaZ/ZxH8P6UONthpnNNaEjgVGbRicFT7cV1P9nHGMVA9iynIB/Kp5Quc79l HYcjrxThaZHp+FbosiGzjP4U42BByQMGiw7mFFYAnOcVZFsEOCSfYVqC1KNkDj6U42wKg5AYnkel NIRg3FuoyVJHf6VEIW2gr075rektkwec/hVd4lQDA6etFrgYs0LBgckfSmhZBg5bjvmtKWMkkgcV CYm7ClYehDHcXERG2Vx7gmrUerXqdLqUY4+8armNs9Kb5Tdx+VLQW5eGt3nRpd3+8Af50/8AtyYH 544WHTmMD+QFZjKegBNRshI70WQWNb+24zy1pGfXBI/rUqatYuAHtXX1KyY/mDXP7WBwTSgEHHPN HKg1R0H2zS3PBnT64P8AhUm/TmAKXzKfRoyMfkTXOYxyDzS7DgEGiyC7OlURYzHqEJ9ASR/MUMLn qlxG2ewkB/TNc1hgeppjGQHIY4+tLkQcz2OjJvV5KFvcDNQvdzAjfEc/Sue8+ZTkM3504X1wB/rG x9TxScEPmZuf2gwJylH28E8jGaw/7RnHVyR7jNC37kEkKc89KOQakzb+2IegFIb2MDGTWN9sBHKj 8KDcRnqCPoanksHM+p3QAxgU4D1pMjFOGQeK7DIUDHSjB60oowMUALjilAoApeRyaAsKABSikAzS 4HSmAUAc0Y7UHpkCgNhetGOaAcjpS96AAUUAZFLigAx2oFLRRcBaMZo6UUgDFGM0UuMUwDil7UmA OtLj1oATtmnDGOKKO1ACYpaMHpmjFMAwaTq1OpFGWOaEJjgcfWlJBAA696MUYoGV7okRYAJJ6AHk 0itlASrKccgjkflSzZMiL6c1LFC87hEXJ/lSaA53V/FNppF4lu8UjvwWIIAUHpjPJPtWldXvl2Ms +8lFiLAj0AzT7zwxa6hfo11ZJNNEeGycfjg4PToazvGobS/C99JIAgeLYpBHcgf1qJaRKPE5naWZ 3JJLEsc+pOabGhZgAOfSpWQKqkg7iMn2J7VNp4QXBMxAUAkg9+OlZraxQNK8YAK4I68U2KVnZwwz kGo5p1uIo3UBScggHOOTj6cYqa3AijLEAk8DNSylYlBEUYC9T1NVLiUopwRk1NuByxPU8Vm3Dl5N q8knAFJK7C9loXtLgMsjXD9FOFz69zXQaeP3juwIAGc9sVnwRGC0ijAwQOeOprpdL0K8vbIBF2CQ 8sQQAP60pxcnZDi7as5LW76W8neZzlIwEjXHHHQUug+CtV1k+Y8TQRM2S8gIJHsK9T0jwTp9gVkl Tz5gc73GcH2HauojgVAAqgAcYAreMYwVjOUrs5TQvAum6UFdo/OmH8bjOPoO1dXHAqABVAA7AVNs wM4wKRnVenNFxCYAHpSM4XvUEtwqgktjFYWp+IbezRi0gBHbNIDZmulQElgMVz2qeJYLUFRIC3YD kn8K5y91i+vUMiBobcttLkcnjPA+lZqWWJQZd7zMMoCMk57n04pNsaRZu9Wu785DNHHnkY5I/pRa Wa7hvVjnBAJ5bnuaVYVDZAQtjB5IC/WrcDK+YoWVlIw0gHX2H+NTcZaSNGBVVUr0ZgOvfA9vU961 bC0edgSpCD2punWDXLAgYjHBrpI4ViQKowBVwjdXYm7bEIhVQAAABQUJHSrBQelG05wa1SIKxjPX JpAjAjBOas7cdqTZzkChICqxlGSJGyfc15N4iSfTPF9zLc7mS4IZXPOQQB19sYr2Fk9q4PxsU1e5 h0ayiWa9Db2cDIiHcEjpxyfTjuRQ0mCdmczc6HHPaG9sJlAY4KE8MfUehrGitL43AiMRUnqegA9c 1dk0XU9NnCLN8ucEg4x74NbEKlY1DEsQMZJrOzLb7D9PtEtlALFpD1Y9T9PQVuRPFDD5jEF/4R2B 9TWQgJOR0qwMkc9KOW4uYsTXDysSSeahGScnNOCEjINSKhPb9KtJJaEtt7jQhPUUoQ96kVScZHWl xgnIOKaVxXQwLg5xTtp44qUICAecU9Yz9eKYiDZzx3p2wHtyKnEYJ6ZNOCANyDgGhICt5ftTTHjo DV4IGOAOx4pTGoAyOtJIL6FELkdKAo5J4q15QzweM08wqOmcY64ot2C5TKjOQOKQJnpmrRVewY4/ Wm+UcbiAAelMLlYjAyeSK4OaH95KSORIRjvjJr0Ipzj168Vxt+ipqM6AjAkJH51MtioncadpYk0S 3IQl2UNkA9CB3qzBokqSq5RgAQSRkEflXTeHtVhXw/p6G3jYrAoJI5OABWn/AG3EOBbp+VYpx6l3 Z5D430wwCCYKwVmYAkHngHvzXEGEg4Ir1/4kagLvS7QCJFxKcYHqK8tZCSTgZPtWmjSsLW5d8LWj Ta/bRIuWckAevBP9K9Un8NXNzO8iwnB5AA6flXnHhK4az8TWEygbllHUeoI/rXth1yROi5ycnI/l Wd0paj16HMf8IvcRQsrQEliAPlzz9TXGWOlvaeKbm0dCr4lQgjHYkfoK9ZbW5GHzLjHPHH+NefpI 1x8RC8gJ8yVgT7GM1cZRewa9TOtUMGhXi8AtcgD8B/8AXr0PT0VYPlG3LE49+M1xNyiwabOhAINy x98AJ/jXdafFJLaiREYg4JABPUA1Mk76D6akxLA4BOBSiRwOtDI4YDYwJ7YppJHUGjVCsmSpMwOc nIq0tywUAMRx61SVx0xyfapSwwOKE2FkTm8kH8Z/Omm+m7OR+NVmBJOAaQAk8indiaRa+3zDq5qV dQlHVgfwFUtp9KUIRzRqI0BqDZG5FOfapBdQv96NfyrN2k4BFOXdn7pp3YzRxaOMlAKBbWkoypHP vVIAjk9+1OQkHAyAKLsRZbTIG5VsfrUTaOh6MD+FRtKUBOTipUnkK5yfpTuBC2j4JAAPfNQPpMoB O3OPStBZ3B4PJpTeuikkZNF0wMSSxZTgqevpUT2hIIxyfaug+2KcFgDjnFRieFm3NGBjoAKWgznG sjzkVC9gSTkfSusWS1diDH75qTyLSTJAFCsI4Z7Bhn5c/hUYsm7qa7w6dbMOM8+4ph0iA9CR+FFk PU4J7A88HFMawIHSu9bRoj0b8xUbaIhHDD8qOUWp5+1k2SMHio2smPYmu9fQNx4K1C3h1hyAD+NL lC7OCazI4KkVG1oQeh9M13Uvh6XH3CT7c1Vk8Pygf6tvyo5R3ZxZtmzgA5pEhcZBH6V1jaJIp5Qj 8Kj/ALJcZ+Ug/Sp5Quc3sB4I6VC0WTgDmuik0pwThT+VVzpjhvuH8qOUdznpIiB0yaiMRIPXmuhf SpWPCkD6VE+kSjnaT+FFmwbRgNGSOmajKEcgVvNpUuDhD9MVC2lTAZKED6UWaGmjJCEHpR5ZJyQQ DWt/ZsoAyhNNawlHRT+VFgOyxjpTgDjkUvtTge1a3ZA3BFKAT2p34ZpcincBuDjFKARTuO9KAD2o uKw3BFGDT8A0u0UXCxHSgEnNOKigAdKL6ANxjvS07A7UYHWi4CUvHalx6UYouFhOOgpaAPalxk0X ASlxQBkUuKBjSB05pRnFLgY5GaXA600LcSlpaMY7UAJ060An0GDS4B60gGKYC4pcUYIo6UABpEGa CSATTkHFFw6jsDtSdKcQBjBHvTeooAgYAzn2Aqxb3Itg5IJLDAwcYqBSDI56DOKHcdgABUsEdDFd JJErsNoIySTwPxry/wCMepqfDkMMR4kuQM+oAJP8hXXB8kBy2zPIB7V5h8WrgO1haqThA0hHpkgD 9Aazmtkykc9ptqt1Zh5VkJbBJVQTx3B7U+bRAJTsn2McnbKpXj69K09DSAWSIIXyU52TgFj644wP Y5rXeNgkc0UVyoiA3MsgZQM8H06468UaIepxEWiXEUbNGokjU8shB5prghgpBwBwMV0V1E7MXCsw bndJABg98Ffw5H5VJY6Fe6o4ZIQI8Y3yA4H06E/maTi5Dv0OVkO0Aegya0NB8Jajqt6lwYWS3ByH cYB9MDqa9J0rwVYWbCaVBNNwcvyAfYV1EVusYAVQABwAKqMVETfY5zS/CVpaFZJl86UY5YcA+wro 4oFjACqAB0AFTqntQzqnU5I/KmJtsFXjIFIXVfc1DLcAAkkDFZV7q8NtGWkdRgZPNIRqyXIAJLAV jajrtvZRs0kqqAO5rkdQ8Xy3sjQabGZSPvPztX6mslbaW4ZLu5Y3EgOSrkBBzjG09evf8qWrHY1b zxDfangadC5jLbTMQQgJ6c0qaUixzSGT7bdxNua4cEQRqBk4zySTx+Hen2tp55lV4VkA+ZRny4lx jJJGM8cYHrmtN0luY0dQ1wRhTtfbbRgDgYIBbGMn8KbskNamI8KM3nJKrb8lrjcVAPUhQQCcdKbI Wgge5kmkhhHJlYjc3GMZ64x2zVXUtftbRigkW8mU7QXUCNB7AHnnuaxtELeJdQu5r/8AexxsAkY+ 735I79qz1b0GtNy42qfb7QtaShbYSFWBUbmwBjJ64JNdN4U0p7m1RmGIx1PrWcfDyQ28xSEQxogc BBjJyBz+dd3oEaxaXCqgABR/KtIw7ibNCGBIIwiKABUgHqKUlVBLEADuTioZb21gXfJcwqucAlwM n0rTRE77E2BSYoEitGJAylCMhgeMeuazLzXrS2BEaT3T9kt4i+fx6frRcLGlgUyV0ijLu6oijLMx AAHqSegrmZ9Y8TXp8vTNEFup/wCWl1ICf++Qcj8c1njwdrWrzmTxDqLypnIt4nCKP0x+QB96PUVu xLqfiubUro6V4ajNzcNw9yB8kYPBIP8AU8emafa6da+FtPkeWUT30wDSzOcljnOB3xn8zya3rTTI dIsjFax29tCoyQgJPHck9T7muD1W8a/vXZXZowcAk8nHehyVrIEu5Bc3D3s7SuOCcgelNRCTSqOA ABU8aeo60kh3FRDjJGKmVMClVPfNShe2M1RNxFXpUgXgE05IyTggCpxCeo5H04FFkFyIA46e3FOE ZZTkEA+v4VKsDE4AzxnP5VdS0ICZBzjOMH29Onb60bCKSRZHQj1Pb6VMIiAQT0q5FATJlCWwARgd enGMn9fSpktwxJCg44x15+nbgUWGlcorHzjaGIGcZ/n7ZpQoORkE54A9eelXpLUhTjJBOAcYB6VC IiJgpU8kDGMD0/nj86AsVmh7kE/XrTfKYDOMdODxmtl7QFAVAwRxzVc24HBHPqBQOxlFWDcDr+VP 8+ROAMg9iKuyQADGQMVGRGeHxnufWpuFimZwWJKDPtShi424I57CrSw27YAPzH0pTbrnrz1JJouL lsUygBBJJ9+lcbqkRbVZmAPLfnXdtGoGARn6ZrjrkAajMCMESEdPehq60Kjueo+HNJd9AsXxgNCp H5VrDRW9BWho0Yi0SxTGNtugP/fIq9WPs+5o5HmfxC0todHt5NvAlIJ+oP8AhXmBiwcEV7X8RiB4 ejHczDH5GvHpFAPA4rVRtEV0yz4cti/iCxXHJmUY/Gvbho568V4/4TKnxPpw5P8ApC9PqK96HTis 3BN3Y+a2xjjRgOtcPd6e1r8RLddowzhh+KkV6ga4rVYhL4+sWx02g+/ysf61UYJbCvfc5PU0CZiI HM0p/DKD+ldTYeKUs7CK3MG/aoyeRnNc3raEauIyMcyt+o/woeOa2tROjFQWGCDgnrxn8KJLW4dD rx4ugYAmxU5/2h/hR/wllk5O6yBPfBGf5VyK6lPuGTzjJJHNWVvZnHBJI56DNMR03/CUab1NmwP1 /wDrUHxTpZIH2ZseoJ/wrm1uZSwBcAHuQMD9KcLwoTkg++0f4UgOqj8Q6Q4B8vGexNTDWtJboo/W uQ+2qFwMbvQqD/SmHUWWAOBGGLED5R0+mMUILHanVNMI4A59yKct/prcADp/eNcD/ac5bqCPZR/h V9nlNqJVkRiRkhVHA9+OtF9bBY7A3mnnhWX/AL6pftVkBkYP/Aq4FNTmDkADHqVH+FKdUl6YUH2A FDQHdtd2x4Cgj/eo+0QNgKuPoa4eK/lJAbGfTFSS6i8eAGAPtmgDszJEc/ISD703z4xzsb8GrjF1 O5Zgivkk4GScCp3u7uBSS6sOhwTx+tK3cdjrPNTGSrDPvUbSrxlWH41xTa3cg43Hg9Oal/t2baBu J45yTxRYTOwaeEAZDZ+tV5L6CMjJPuAc1yR1ucsTgGom1iUjJVfoRTsCOwbUbQAYLkkcgcYpv9p2 4/icfjXLwXdzMpkWNMA45qtcanNE5DRLnvxU6DsdkNYtR1lkBHoaVdetc4M8w/GuH/tcgcxLxSjU wRkxJ+RpWC53X9u23UXMmPcig67CQALlvzrhRqIPHkrn2zTpL9UUARAk9uaLNg2jtxrsORm6YfjS trsGMC6euMjLSxCURoAcgcnP86py35iYgwqT06mjUNLHeHW4ScfamoOuRY4u3yK4UXgOCYQM+hP+ NTefGIyfLBPbk0reYaXsdoNcQcm7YCg66hAH2rOfUCuCa8Unb5WfXk0LcI8gRYiSewJoaDQ7k61A clrlcjjG0GoW1i2LD/SFOOfuCuPmMcY+aM5xyAelQCaEgkBgR70cvmB3a6vbHgTIf+ACl/tW2HBl j/GMf4V5/JqEcABVCxP94nj8jUX9tE4JRSB7f/XpKPmGh6MuqW2c74cH1jFI2p2Y4LQn/tmK88Gu EgAICB7VZe/JtRKQvXGCP/r1XK97hp2O3N/aHo0J+iCmG+tCcDyif9wVxbX4SMMsSkkc5JFRQ6q4 kDJEAw6EE5H61KV+oNW6HcinZPFR5FOzxzXRYzJM8cGlzxTAaXPNAXH5xzmlzTc880c9qBj80ZyO tNz3oycYzQA7OaMj1pM9qM5oEOyKM45pM5oz60NBuLk0uabmjNFhjs9qUHjikzRRYVx2aXNNzjpR QkMfkDtSgimZpcinYNh+R3pDzTcmjPeiwrjsDtRj3pAaM+tADscdaMUmaMmmGgOMKTSqMKD6iqGr aimnWqSurvulVAqAEknOOtX0yUGepAotpcOo4g+pFHAHPQdfpRkYxmormVYraR3YKqqSSTgAdOtA EcPKZPOTmlkGOOtLZSQS24bzFYHoVYEDHXJqvf6zommKXu9ShUgZ8tGDsfbAyfzqJNX1GloSZVFa WVwkUalnc9FA6k14l4s1L+29ZuLocIx2xg9Qo4APvj9Sa2/FPjWfWw1jpyNBY5BYE/NIR0LY6D0A /WqOj+H7m9UMYckn77DgCos5NdikrLUg0osUjiCRMxAG1jgn6ntXRWOnXN6Ci2pxkYk3kKvrxzmt zSPB1tanzJgZnJydw4H0FdXBapEoCqAB2AqmlcTZhad4ZhgIeYmRwOAScD6Ct+G2WMAKoAHQAdKn RB0Ap/yqOTk+goEMVPQdKflUHJBPoOlMeUkYzgegqvJIwUkDIFAEsk3uMe1Z13qMNuhZ3AAGck1y mveN7SydreKRXmGRtB6H3rhLnW5dXnIvr9beE8gbGIPscA/nU3vohpM6/WPG8SuYbMGaQnACkYB9 z2rBltr2/kMup3VuoBysPnAg9OpXIIwfXtUVtqmj2EQSE2rtnIb7GzMCOeCwAOfQ1eXWtQuWLWdp eNuAGYbRYww9yM5PvVKLQXJooo4CpRW8sjgIpjXPTOc5I6+n9KerpEjKSpUnJBGevfIP+NRRaN4n 1FiY9NMIPIeaQM31Izj9KtJ8OtavD/pt7GoJyRknn6cChphoULzxNaWW0CRppAAAgJKcdOOnFYN/ 4hv9WCpIwSJSdqIABye+AOa76D4VWJKtdXsshByQgAH8j/Otuz8A6Da4ItWkI7uxP8yR+lS4p7sa aR4pLAxU/KST7V3XwwsI4rG5uLqJldpflDgjIAHIGOetek2+h6ba4MNjCuOhCjP5iryxKoAVFUDp hQKqNlsDdznNRinu/MhtbJ5FeLbvJ2gEkHvz29O9SWFprEECwlLaPaAMsSx/mK6LaSMEkj0pNgHG ABRzME9LWOR1HwVHq9ybnUb6aRyAAisQox2A6Cs2/wDh5bxWrT6c7rdx/MsZY7Hx2OTkE+oNd9kd qaTgd80XYXZxXgbXI9ZtprK6hVbu0IBQ5wVzgHGeoIwfw9a7MIAMKqgewFeYxMNH+MRgiOI7tTuA 4HzKW/mBXpocAZJptdRDyCRgk49M0xgAOBTWmUdwKz9R1RLW3ZwQWxgD3oAxPFuqlIxYQnBbmQg9 uw/xrkEGBwKmu52ubp3cliT1JzSIgGCOnpTSExyJ3IOanQDoaEUDGBmp0GccY96pWJFVeM1MsZJz jH1NOjQEDg5PbvVqKJipwpOOM4J/Dp7j86AsCxgAEke4/wAmp0hD4I59SOg/TrVm1smmwTkALnvy ME4B4BGD61MiBJQpOGBIBJHPXgDPX0OKaWgepAIhDgn5SACSRkAcepGf88U6PLMoADNwwBHXp14P HHWtJLB5SzBNpUE4BxjrzwBz071SljWCUoUJBzwW5J55OTwOKEgHWhVdRiMhIDfKS4wOQB3NXpSI XkRgAVwRkY5zjjPbkc8jg9Ky7lWQiVB34OOpBPQYGAMVoXjozq2MhlDEkc4I6YHfknj170dQvYWJ 1kOwjJyBwOmcADPc9PyPWieKN4gcKWIyOR07dOvaqgdDnJOCcEg4HcHj8T+nSg3YKABjwTgADjv1 PbP48U7Bcm8xo1IJyM8FjwB2GPy6+nWopZ1VCckAngd6qyXYUcDHue1UZrotznOPSloFyzPcjOAc ZqhLKWViCM8dTzUEs5IxkEetQiTJ5APXk0rdRXLtk/7wFieuBj/P+enetJ3YHaATxnKjI/P/AD+t YMcpQ5z6irQucjp1ORyR+X+f5UJDTNJnAUMQwz74xXB3soXULgsekh/U11D3Oc5IxyTgfl3rg9Rn J1CdgeC556Z5oashxep9B6TrMb6RZMQCTBGTz3Kir66rETgj9a8q0jV2TTLZSx+WJR+QArQGttnG 6s7l2uaPxK1JH0q1jTo0jE59gP8AGvKHmyTzXSeMdSa4tbYFsgMxHPsK43zuOtXe8UkK2p0Phe6W DxLp8h5AnX8eQK9zOsIMcivnPT7kpqNs4PKyqc/iK9HGrnaMtkiovZ6js2ejLrERPIz9DXH3t19r 8fQpG5XEsWMdQApJ/wAPxrLXVmH8ZH41Q02/eXx1bAEnc2SevRT/AIU0wtYsa0GPiCRS+SI5HJ9t 2cfpik+1O+ngHBRZQQCOvBqLUZg+pvKBkm3kPPXG40Wd3aPpjvNGwJOFCjgNj+XNEhoEDO+5+OOB jFW03gZAIPTj0qKN4woZjzgcEVKZxIQARx6DrSS01Je+hLsAUEHPrjpTNpJznGO1SRuUUggZI474 qPDGQhRwOckUWQ7jY4XYlh096ibHl+W/ykEkEjqK0FnCW+2RQW7AHrWW1wzucAk59OlO3UV2IAoG RMgPTkgVKLp0gMAnjCkk8sM8/jUSxGV/LiUvIx4UDgeuTTnsra1P70+dJnoDhQfT1P6fjSdhoaJF ACiWJj7MCc1LE4ts3FwrGKP5mwOwqu8swx5ZEYBwAigAfl1qrJ5tyssLu211IJJJx9KV7oDrWW1l 0X+1i8aRuPlgRSSnPcggn3JrmLG8S/llRRlozyc8Y7Yrn/s+rRxvbbi8JAAIPbORWppdmdPgYuSZ XOWIJqdUyna10bLowA2598U/zZhAIip47+1U455ARhjj61I08oGAzAnnqabYgaJzkkNUeHUEYJzS NPKMYlfI68mozPPnBlcZ9zQ3oFh5RgSCpyeuDmmhHBGUJA9c1E93OBjzX4/2jSC7uCciV/8Avo0m wS1L0UroQQCFIwQQcVBMHlkLFWGfUGolvJhyZWyPeo5NQnJKiQ4+tCdgsxr7gPutwfSlMjsoCoQP pUX2qcnJmb86Dezj7srfnRfsBIjzKSSrZHfFPJcoWIwemD1qJb+6z/rSR9ad9suyM+afyp3ES21/ NAxITPGBnOBUcsrs+4gnJzSrf3IGDJ09QKG1CcLncp+qg/0pJodnYt2ltJefKrAMCAqd2J6ACnap Y3GmKDcSLGxP3DjI/XP6ViXGr3ltcw3KMA8R3LtAGPyrM1PWbrV35Vi5JJIySSfUmlK/QqKVtTU8 5ySQcg9xUqTugDq2GHSqtrP5VukUsIJAAJBIJ/WrXkw3CkwuyN/dY8H8aF5iHm9Z0IYnJ69yajMr gkg4rPlE0UhRiwx3pUeTaSXJ+ppgPuZC7AHkgZqLaQuWNOUbmyxJJHU01yc4GMelNK4rjSSMEHgk cVqSk/YYlwfmOcVk5BYD1NasxAFsh5AANOWiCGrRpRQJJLDE5CqxCk+mTjNUNRiWyvZEt33hSQGx gGpxKSwYE8D8qx7iWV5GCkkk9axpdbmtQ9QBFPB6VnrfxZwQ4/CpUvYWHDHA65Brp5l3OezLmQe9 OBH1qp9rhHVwPrxTxdQnpIv5ihNMLFnPrTh9agEqNyGB+hp+8HkHNMSJKXNR7s9DS7vWhAPHqKBT QaXPPWmApyKOpozRmkGwvIpelJSimAZxS5yKB0waWkAZoooz2oAMmlz60lFAC54oyaSlzTBig+tA J6mkzRRYB2aXNMzinZyaLAZ2rWQvWtELlRHMJCAM5wCMH25/StQcADtVdxmaMHoMn/P5VYPAzj2p 9LB1FBINVr8BrUoekjBf1z/Sp1bJIOQR2NV7wFzCmer5x9P/ANdSByvjnTbex8JxSQxBT9pADAc8 g559OnFee2WiX2qOBCjbM/ePAH417Xr9jFf6RaQSoGUXAYg9OFNV7WyigQKiqABjAGKi2t2XfQ5P RPBFvahZLgGaTqcjjP0/xrsbeyjiUKqgAdgOKtIgAGAM+lTBVAySPoKpsl6jEiwQAM9qlwq8sfwF NL54UYHtUixHq4OOpPYUgGFiQSBxUeCQTnGKmluLeGRYi6B3OFBOCfoO9N2E9RikncCA4A561HIW dSqrwRgk1aEIHaniLPQUNXA8/k+GOl3FwZpHmBZixCHGc9jkVpWvw90GAgtaGUgdZHJ/QnH6V2Hl gdcCl2qByR+FC02GZFpoGl2mPI0+3QjoQgB/StBIFQYVFUeygVNlQOMmkMgAwABRr1EN2EjBJxTh F6jH1pvm+pxTDKBzn9aLDJgijkkClOwdSTVVrhQOo/OoWvUXqwH40WAvb1HRfzNNMoHAwPpWTJqk MeSXA+prNu/E9lbAmWdFA7lgKWgHSGUDjNQvOozzj8a4G++I+lW+QLkOfRATn8qzz48F2M2ynB7s cU20twSb2PSmu0UcsBVaTU4UBBcDHvXmdz4jvXRiJQpwSMCuKHiXVb9pYpbxkJBAwMAYBznAJ/Kk pJ7Ds9jq21WLUfiq1+ZAILXPzE4GFUqP1Oa6i88cWsE0am5jwxICgZLemK8h2pb6eJC6NIZCWcLu yMcDBx09qsT21xeXdhIoVRhdi7SATu4wOR1460+boNQbdlueiHx4lzOYbZWLA4JbgA/jTW1G4vYw 04Ck5wAc4FcPZQKNRdAxJDkMCc4I68967CLlQTV8rSuZ36CohLE46VMin2wKRASeOOamUDt2oSC5 KgzgHjNTIgJznpzzUcYHFWo0BwAMk8Y/wp3EiWAAHOcDjkDOPce/FXYQq4DKMjBHHTkcjI9Rz2qp FGXbgZyODjrkenPrVtgACCSWBIODgk88DkevNCQ9kTRStFjYMdiVAG7pkDCnjjNW4HKASMxGCATk jI4yBnGOhqmiBWGGxgkHkHGSeB1z1FWZECRYUkHkgqv3RyeygZ5FUJs2bW4At23bORjC4OOgOevP BNZdwVJZ8MSSDjJAA4yT045P0zVWSdlBUNwQRsZj8oycZyeTyOcelVJJ2Ct1IJzkEDHXngUCJZpw 5bOGB4GAATxjsCR1pTcF4EUEEgAYzzg//qqnvJOTyCOSTnIz0AyeOPT/AApjusYBJ7EAY4A/L9aQ dCz5u0Ak8DkYBJHTrUMlyACAScnmqslySTg8k9KgZyTzwDTDVksk5Y4NRKwMmS2AASR6+1RYLE4I wOck0m8kAcDHoMZpBYGIJIA78U3JHORQxOfSkJ6ZNACk45FHmducdhmo2bj/AApoJPOTQCJWc4zm uIvnxdTgHB8w98967MkgHg1xGpAi8nIJwXOD680paIqKOjsrsiziGeigfpVgXp9TWLay4tox7Dip RNz1rmUtTZLQTXrsyRRDOcE96wDKeRn8qu6vKMRknpmsneT0HHatIu6IejL1rKftUWDj5gf1rtFn OAC3auDtmBuIyDk7h/Oup+0DaOambVyo6mmbogfeqTwzOZPGKMGIKqxB+iEf1rFecc889Kv+FpNu sTzEcJCxB/If1pwYpbaGtdSnzOG5+zsCR6FmH9KisZAdIhYjOZn+vAAqO9ISBZR3h/m7H+tOsfk0 i2YdCznB9cjmqlqxIvq4dwzEkYwB0waesuHPHfiqkBYjg5OanEMxGQMAn1ql2EXhPnleCB3oDscs WyepJqkrspKkAn65xU+x5EBGQepyMYpNCTJZJQEBUkkjnNQEuxCIPnbgCnELEBkgnr16VJasC0ku Qdq4Bz3NLoMlicWEPlxnMrH5pO59h6D+dT/ZLW5AAd97DIcnqfp6VmykuuQwz6UyK5niB2kAYK7i MkZ64PY0rPoNW2Y+FWcEFcgE8+9OEBBzjBPWn25eVSkCMwQbjgZAHqf8alImSLzZomKnnIIPHr1p NdRq4YSKE9CRyQalstNiv4i7SEEnGB2HuaxJ70yykRZC5wAfSkh1K7t9yxt8rdRjrRYGWrmEWlxJ ECXCnhh0II/nUKykkdaYLlnjZWAZmILMf5UAhQCDk0pW6AmPZhnPIFSW0aXE+2RyqgZJquXB65NN SR4ZN6AEEcg1O47alq7tYkIaFiQTggnmqwwikbTk+tSLKzsWI2gn86e7RAjaDnvmn6h6FUnaCW4z 3xzUWUKlgMnOKdKAxzkDNRMoVTg/hTfkLUmtLRrqUJuCrjJY9AKfdWSQx7kk3gdTjFQ2119nJ4yG GCPWiS5EpwAQD1560rsZCqE81bQp5YBbn0qEuAODTDJzk4yKAJZSoIAGSf5046fN5fmF19dvcVUe UlgQeQaufbDORFGpyeDT16C9SGG180ksMgH0qY2qQjIQDucCtCKIW1vhh85Oc+tUrmfGcgnPtRZg VZFABY4xU0WnSvAJS6puGVBPJFUJZy5weB2FTx37opUnnAA9qNQ8wYtKpikGXXofX2qnyCQR0q2j AkyE8k5qC5BEhK8A80JoY0Ak4HX2oIwCSOajZyCB0HrSM5xkn8aaZLBAGnUDGcir12wFygyeABVO 0Ae6UkdwamuXzdMfTinJ3Wg4aO6LcDF2YDsDUDECXyoyDIep9KInKRSP0OMA1lGVhIWBOR3zUxVk OTu9TvwQeMEZqVQEwQc8VTUtjIJpQ7g9ScVkGm5e3gdTnNORxkZAPtiqY3nqeKcGYHBI/CmmBeIU 8leT7VIhAySoz24qkJmA5A6UonJIxmjXoxqxeDg5znr2JFOR0PG5/wDvo/41RaUgEA/pTknUjJJJ zTTdgsjQ3gAYkbHuc/zqRXY8iVjgeg/wqiJQeh4p4nAUqCB3p3kKy7FwFyMiQH6inb3HVl59v/r1 VSbIwDS+aC55460c0l1Cy7FxTL13IR75Bpxdx1C/mf8ACq4kBAIJIxinuSjlQc5APPuM1XPIXKiU yuAP3efoRQJj18tv0/xqIOTyTwKdvA6HmhTYOKJPOB6o4/A0vmqBkhh9VIpokBGRxinibjng1Sqd 0LkAzRjqwH14oE8ROA6k/WkZySDkflTlQEAsAR3yKan5C5RwZTyCPzoyOuRTfKjGMIvX0pHiUDIU AZ7CnzoXKyTI9aAR1zUflLgZHX0JFOWJQcksMcfeJNHOg5WPyKAQOp7ULApbBdhxnnFOMGCSJM59 RTUkHKyDdvutoP3VBJ+pP+FWwQBj8ag+xuCXDckgljz04Ax6U8JKOrKfrkU+ZByseeWyRjFU5yTq FuucAKxx+IFWTvBxwfoaiaB/tEEzDAIZR74wf60XQWaLd0A8EKgHhyf0NV3iVQSeMdanlcAJ9f6G qWouDCIQ21WBaRh1WNRlj9TwPxqQ8jDvL65uZvI09GAbIDg/M2OpHYD3qMeHNWkwxuhG56lmZm/P NdDotskNuJ5FAllAOMfdXso+grW8yMDIIP0o5UtxnLJFqehWE1xPeC6RFJ2MhBB9iST+FUbPXNYu oAwcHJOfkHH046V1GsCCfS50lBKBQSB1IBB/pWLpdsRDIYVcxvK+044wCR/SsKknfQuKVrsx7ifU xfyXBcsQoDEKcAYxjjGOuK1NJ8TkWkUEttJPJEhM0iEHAB6kHrxiql54et3W9vZLxEBOWtyTuIBH Bx26HFc7JdQ2lxGbN+SCrEHqDkEfTFXG6SuJpbHqcd0ksSSxFSjAFSO4NBmODkn865jStRjtdFth K4X5SeTjqSQKgu/F+n2yktOpwMnBzx+FW2kSdWZx60w3CjvXmd18TrBSVtxJK2cDC4H64rL1Tx7q tuyobFoGdQwEpwcH2pXV7Ds2etNeoOrDj3qpNq8EQJaRQB1yRXm+l32o3+l3Gs6veNbafECFEagN K3TAz0GeM+tcusmo6vPPIjSvGOi+Z90EnGR3pyfKtQSvoeuXXi7TrbIe5jB9NwyaxLn4g2YJWEtI fRR/XpXltxaTW5JlUqfc9an0+FZSAQSSw7+9Zuel0Uo23Ov1L4h3EUjRxQZYDu2MVz83jnU7iTYZ ljz2Uc/rWNfRMlw7yHCgkZPGagj03zYxMFZlYnDdsjrzQpXV2HLrZGtcavezxOXuZCSDzuI/lXMt LLJKS7FmHcnJrcSwlMWFBPGMD/GsaOCRbiRJhgqSOPWqpJylYUtFcqzkqRnOD3roPDkUt2AkRAx1 LHFYt5E/nbAMgAY47Gu00Lw5qUWkR38EcLh03A7iGAHUdMHp3zVTaT94UU3sa0OggjM1wMEchRXL 3GjDT9daFot8EhdlkJ7FTgD3Bxn/AOvWxa63LcxkxRuxHUAdKm1E3SbIb20ZGZRIgLDIB6EEHI/Q 0Xihrmvcq22l258OQzIuJ3kJBJbA5IGcHgYAyTkVLqaEaHaTxMTJasVLhSMjPB98EDnvnNUNjqAE QgDpk8/of6UyYyvG+YlBII5YkD8z1ovG1rl8zUuZINCgbzXlYEkkY9z3NdVEMAA1z2igxW4DDJJz XRxjIyOh6VSd0Yt6kyDPToKnVQfqKjQDGe/rUyZAwc4PXFUJakqAZA6nHFTL1IznPHTrTVJwSMAn gDGfyoGVxuB2jvmkFrFuGXac5xjGCO3v+lXUcJhkYADBBzjaOOeo5OP1rPTG4D5SMg5JwD04PTH5 1es51DBCwI6jJ6HAyTg9BzVIV+paW3Mm1kfaRjgN93jqfm4J20SQpAyhiAARtGBkdiTweePxqyl2 IowFOCRwMkk++cnrz1rNurjfIQScnnk8Hr156cn6fnTEMmKg7AcYwQCenTJPT3yPrVIICwGc+hyD nOPc8de34VMTwWwWB6EcEnHrj1I79vya0oBLF3IAIOO+c4A5IA9vrRcOg12McQ5IJ75PPHpx6nmq cr7yASDj8KkuJSxIHQH0AH8hVQsOtIBxbjGAB6elN4IyWOfTFNxkZY4Ht1pGIGMDGP1oBCluAASP X3puT696QkAYFMLAcZ6UtQ3HFgCQajaVQcHJprOcGo943cqCO4NMdiTzFJzkY6Uu4ckEYqPeh5Kn r2NKfKzkE49x/wDXoDyFeQBScjgGuN1FlYsxJJZiSceprq53jWB+v3Tz07Vxt3Irqoxx7fWpkVEv wviBQfQVJv4wBVdWIQD2FLvOK43c21KGrPmSME8AHPNZxkGAAcVPqjZnHqBWcSR1x+FdEdkZySuX 7RybuMdcMDXRmQgE1y+nkm4U56c1tmUkZB4+tZzWpUdiZpj2rV8POd93L0xHj65I/wA/hWCzc9ci tbQ3IsLmQj7zBR9Bz/WqhcJHRanaTppyzbfkaGBQQepYMRx706AGLTLSFhhwGJB7ZP8A9aota1Zx pdtAQAAsBGOuREP8Sa0Jr+1n0uECAieXDqwPCrk8Yq3rYmwxQSAE49eOtWQ7LtBP4VStZMgE9Ksv k4IYAdqYh5ChyefzqQXJAOOMDj0qoWJyOcDqaikcswVfu+pGKbYh80pYZzjPpViBwlkvHLEtnt6f 0NUHHGM4A61fDARxRggbUGCfzqWNETO27PTPXikeUBSCSTnPTipCCykkcDvVV8ZIPbvQgL+ma+uj zLHI6ol2djkqGIHQHH1PGa19cvdP8P2oSPUTKZkLqTGsmCcYBJzgH68elef61HM0aS2oYSxkknPU ccAY6++axftM16RG6BSGGEJYgnoScknPekrLfY0VmrG/aapFdzlFXLqoLEZ+bJ6nJ6/StLexAzj3 4rJ0u1SzRmYCSZ+SB0AHQZ/oK20ttRnjDiAKgHBKnGPqeKi9tx8jexXaTB4AA6dKEkJbBOBjqalk srvAy0PPfK/40wWV2ejRH6Ff8aTnHqWqMn1HglhgAk+xpVIQhiOOw9aFtLwADMa+uCv+NJ9mvOhI I7DI/wAaj2kUWqEu6Hu5cACot4TIIyccc9Kf9nucDMfHrkD+tBhmzkwZPTqP8aPaof1WX8yKxlG7 JPNJvLsMED3NWDbyknMH6/8A16UWkzYUW7HJwMHqfzo9quw/qkv5kVWABPGffFR5xyeParzW04bB t2GDgjBqM20zHIt2P4Gj2q6on6rLoyvk4BIGDTWySSO1Wvssx4FvJx7Gg20wABgl/I/4UKrEPqs+ 5RwzHA6nitTTytjOGkCsepH/ANeq72zoCzQSKPUqQKqSyFeVzVqpFsiWHnHXc7aztl1y7eOzdUmG T5bHBwMZJ46Z7CovEUMGkxotxFGXBAbEgJx34x1xnvXn9v4gvdD1YXcLsrYI3gZIB6iruveK21mx hRYlBAO44GWb1JrRW1uzO1txzmCeVngYiMk4B5IHvTSu04J9xTNL0u6h08TSxlQ5yM+lPYgMQe1J J2uS3qPJyvWnMFKqzHtjAqInAwT+FEgyqAHBxStqF7kcoLdBwaZtAHrgVKyEDk9aYTtU+nqaaES6 cM3G48YpshzO5B6mpdPHLH0BqEkiQnHeiWxUUStlbJie5xWcoy2CBz3rRuTts41zySTVAAk5HShb CZ2qE44IJ9qeCM4PGfeolGCeBUoBxwK520UkSqVPQ4p2PQE1GARzwM0/cQAMg9sU0waHHBGMEUuM DAPShwCgxww6+9MIIGMkgim79AFBByCSf6U8BNwwM/jVcgggA81KoB5BGRTT01AsqVGQB1p6IDwR zVfJx3p6EjkE8c0XAtKMDABOKWRwFAC8Y59ariVwck8U7eSTkdTTvoLclVjkAHOe1W3OdhOMlQMV nljkZA49Km80MFwc44+lFxl0AbgAOCPWnGM8gHpVVZSZMYPHPFWUmByc9BQkAbCDwM0qkAjIzzSC YHqMiiV1AGMdKaAdnIwO1SqSR0PtVaIknPUVaDAECqTYmPUEAEk0pyQRjrSrkoc8YGefSmiQAEEZ NGgkxhyHwQeOaeCThsHjpSlsnGT609WB4/pQMQuQSSAOBSOQACDkk9KnwG6D9KSRkjjBwM9uKpEj DcEKFPtxSebnIIGe2KiyGYscdc1EZAJcA5HrnFMC7FtdsNwSO9F0VMMG04xKQPcYFVftBJGME9MD mi4cvBAFxnzSff7tFkG464faq5cKA2CT06GuX1bU2Se5h3gh444zg/wliSPxwBV7xhdpY6Glw5YK JlBI68giuBl1WG5uQ8M27KgkE8ggkjI/GhPoJrU7U+InxgI4x/s05NdunwIoJXJ9FJpNPlspo1YK CCARk1twm3RcIqqD6DrVNJgnYwLrVL6e2khayuMOjKSIzxkEZ4FcNHdSSxMC7BgTuBPfv+terSXV qtxHC0qiRzkL6/4VyHhyxtrq+u45YkcFeCVBIwx5GahwvsNO25z8MziIrJNPtYYKIeD759K0bPQL idklWJwGGRuBwg9yRyfpXWW3hi3gulk3kxq24RhcZOcjPOMD0AFb/lg9RQo23By7HA+M9MuZ9ItY LFWZYcB0UHLADH41wdzZzLE25ChjUA5ypBOcc/ga93a2VuqiqN5ottdxNFLErI2CQRkHGcfzqXHW 4Jnz1Z6VNPK0+QI0JJJPXAyQPwruLXSh4q1SJxI621ugFzK/AUAdAfU/4muok8BWkDu9qGj3kEqT lehHAPsar6zDfaVpkNhpFgxth81w4IDSN6kDqOO1Ukr36hdpaHO+JnvdYkW1sLORNLtcJEqqQCRx k/0/+vWPY6RfpKQqSIO5Geo+lbT+Mbi0tmtHsWQg5IY4I/DFU08WlAT9lySc/e/+tTlHm3BOxabw rLexPLNI5McZkIKE8AZNaEPhCz02yMlxJOJPtEa5ERAKkjJ+vNZQ8azRxtiDAaNoyN3YjGenpn86 mv8A4j3V7aCAWkahAo5YnJUggnj2/WlZLSw22zY1H4f2l1flFuWeNSWVDE3IyOpGOuazZ/BT6eSl taysJDkkjgY6Yyf84qH/AIWbfSASmxiVlXbkSHnpz09qkb4nXd0+Tp0Kk4/5aE/0FHKnpYLtFe88 O6tAGP2SaHzBnngAHpgZ4FYN34ev4oXmMACqCzHcCTjrx3rsNQ+JeoXsUaiwtkAUKcliTgYrIbxT ezKwa0tiMZIwxGPzq4Lkd0S5XVmc1Z2yXhwQoZByScZGa77T/H1jo2hppp01p9mcsZAAc9QOMge1 eeTmWzvS4QoG+YAKQMHnAzzimS75/mLnHoABiqr0lO0hQqOOhd0zV5dP1KaS12xhy2xXUMFBJwCD wccda0DeXl2xmuneWZzlnc5P/wCr2rmXQxncCSR1ya0bDUgCEkOV6Z9KirS5opx3RUJ2dmbHmt0K rz+dIwDwsNvODUyxxSqGUhgehFNkjCEAE4Jxj2riim5WN5PS4unIQoyOnatqMk4IyMdqzLZMHIAA 4FakI6HBrvitLHI3ctqxbAAwOOO1TAgECoUGO9SZ5yRTGTpzjjI9Mn86fKVB2fNj0J5BqupwMA+1 OcgEAde9CVxN6FlHKcuTg8BgOSCD1rQgAIIJwM5IySCcnGD2AyOKyUkYKUPIPUVPBMY2Ck8e9NaC uachYrgliByRgj8+DUGAQwDEnJwuME9eRwMYwOO/8lEgMZJ2kZOc89jgHg/h9PxEU86HcCQSSdwI 69euAOfp6/k/MERSzFcgMCBkAj649T6etVGlJPB5ollMjMWJJJqLI9D74pAKWJzkk5phAA4OT60m cHr+tMLZNAWHEknk/nTSeSBSbsHrTHcDjuaB2FZsDmoHbtmiR8d846mq7yqTyeAe1AtUOL55zx70 zeM9Rmq8lyOijn61AZgOSaaTtqF+he38ZB4o8zHU1QFyAcE0NcKOM8/WkP0J7yQC0lOeik4/CuSk cNIiDpkDity+uwLSXnOVI6+tc5BJiYNnkc59KmSvoVF9TZXkY9KNuASRVB78A5zmo31Nim0DBPcd azdKKLU2Vb8hrtgvQYFVipI5FOklJlZiDknNNMgJ4OOe9NKysLrqXLBQJGJOAMZ5rQ3xdM1lQqxj JDhc+pxmpQhwR5y/nUSTbGnZGgNjOFUAE8Vu2hEOlFSANzE8DHTgVy8AIfd5gJHAA9e1b8shitlj JIKrz7nFOKsDZd11mMdsMdUQ4+iKK2UiYWtphSSIFxx15NYniE+U9qv/AEyUnH0A/pW7LLmKzUkg rboP0z/Wm90CZNGpHBXHOKsEhVw3BHYCqluGL5HrxmtExExCRsEEkEA88VXUlq+pV3hkEYQEk9ec kenpStEwIJXsOc9B71HIF35HAzTlUtkZOOv1piIbhQqEbhn26VdWJri6jtogA7EIpPGTiqk0RZME EEDjipHEjQrNE5VlIOR2YDkVMk7aDjvqWdUtJdMlWF5VYNgHY2RkVSIABJ6e9QAXE1wJbiUsR0AG AKueUSoweMZJPAA96mN0tS5JX0KvlGbChc9sYpqwiSdLO1RTI5AZhgZ9s9gOc1PJODGYbVeDw0mM lvYeg/nUTWrW13bIxDiUgsiNljk42n0J7j3pOV9EbRpOMeaR2emeDxsX7NKrEgbrggMM99o6YHqf wArYHgdH5nvpHbGOST/UVY0fxHpy2i27yokiEjA4XA7gnt2rB8T+J47W4QW920vmLuGxuAM4HAPt 7Vpa6MHJtmk3gK1JyLv/AMdP+NMPgCEkYu+Poef1rjx4lumG4yyEHkEk/wCNO/4SecjPnSDH+0eP yrOzGmzqn8AxgYW5XPoSw/rVS58BYXJvETA6ljj9awW8UzqPllkJ7kSEf0qJ/FNwQS0shGO0rDn8 v60WHdlm68L2lsCDrNnkdRvyf5VnWuinVr9dOWVGMmTCxO0ADqSMZOe2etQSXb38ElxLHIwBx5hJ O0+me9VDPPbPbTaZAzTxZ3EA5bJzkYOePai1lcE9Td1/w3p+hWSxyCJrkg5ZZmJAHcg8CjwxFpkv mT+egGSqBrny3BHfgYNZ9xe32viG0ltFRpyFdmU5BJ5JPHTqAfyro7TTdA8IWqwzItzfyc7WGVTP qO5o5eZ+6NuyJ18PW1yp8go5J6rd5H44FDeC5iMlQR2xN/8AWqLU/E8NtIqW1zuQqCBHlVB7gD/6 1Zh8V3eTtlfB9WNTKMri5n0NFvB7p/CuR1/ff/Y1Wn8MlFJYqnGOZhj+VVx4puSOZG/77Ipf+Epn ByWcjv8AOaXKx8zM6906ezBeC5VsdfLkyf0xWHLczb8S/MQec9fzre1DV0ujhgSccnOcfieawLkK 7YXnPINDj5DjNrVMqzJDcKSwyM857VZ06wgikWQ8gYODVZEcOGCkr0YY/Wrarhcq2B29qSdnystw 9pHmjudDqGpiWAIDjAxx9KwlVp5QqAlicAAVHlz94kjtS29w9tKJYyN6nI/CtW7LQwSs7Ms3dhc2 QBmQrkcZGDUDuPkGcHA5our651CUNMx5POTk1BK2XwDwMDj2qIOT1kOSWyLLFdow2T7VG7grt7n2 pisMgdfrSyHJGODVrTURatQEt3YHqKgXkkkZOasxkpYknuarxnLAAck4pMa0Rem0+ee3V0QlVUEm snBRip6g4rXvdRnjj+zqcxqMDBxWMd7HJGTSi5Xs9glax2+0Fsk/rRtA55x9aZg9QSeKUbuo6VgM nUgAY5/GnZHBx3qBSSRwafhhwe1FhkzAH2yPWlhJCykDIKkE46VGDkZxikDMitgkZGD9KuMhNEZL Mwx2qQMRxgfWogQDmrCEHgjjrR5ACuRwcYqVXxyewqIAOSMEHNPAXBB644+tALuDSkDgcnilExJ6 nioWO8gZxjrSqdvPFAaomEpIODn0p6OCQOahAJwTxn3pTleQaaYalovtOQeTSpMwbBPGc1WDEjOe acGJ7de9PzE2XGmIbKjj0zQJd5G7PWq4bgDPI71JHgHJ6ii9gRajO44U/hU6OcEE5I6VRMgD8H8a ekv7tgD82f0qk9NBvsXjKzxAg9Mg/QCmpKdoOQSTiqhkYRHk4I/WoklZADk8dKTYtjZ6xBwOAcGk DkgcHnrVaOcGHBI5PIJ6mmtOAxB64phY00clTz0qpPMPMwcnHPtUf2sKuQADjvVZpiSTk4JziquB OQXB2sQCDjJ9qiYErtGMjk0QSZBwRwenrVmKLcpcdemMU9iSojsjFjnPTParmxmtoSCSfNyfptP+ FRHYyOckYPTOQT9KepVbQFgxAkBAHY7Tj8KcXzLQGrHPfEUg+EGAP3Z4/wCteQJMYJd6gZHpXrvj wmTwjcEgjEsZP0z/APXrx+4QBsg5zSW4uhvWmruQrQ3LQuOo6j8RW9D4ongtyJbqNiBjdtxj8Mmv PUUMwGSDnqKnSCR5MbuByc03sOx3Gm61Z3moebPdgFWBw7YZiOnJ4A9q1fC94kOqTZbAeMkHPX5q 8vNsYpSwfcDxkVs3F/c2FvZyQSFHMZBI7jPT86E0kOx7fHco44YH8aso49RXi1n46ubYhblC47Mh wR+B/wARXUaf49sZQoedUY8Yc7SD6c8H8M0732Js0eiAg9DTuD2rn7XX7acArKpz6GtOO9RwMMDQ IuFAeDUb2yPnIBH0oWdSQM8n2qQOD3oAy7rRbG6UrPaQzAjBDrn8j1H4GsA/DzQXlZ3jmUE8IGO0 fjnP6Gu0JBppQEdKWvQd+5xl58PNAhgeUWt1IqjP+jyGQn6AZP5gVz8fgjw7qJMdjqc8FwePKuFG 4H/dIBP4GvUDEQQQSCOhBwar3dpDdjF3bxXGOhkUFh9GHI/Oi76jTR5Nf/DTVbSB2tpIboA5AU7W I+h4/WuUuNMutNujFcwSwv1AkUgkeoz1Fe1P4ahSXfZX11Zk9YyxZCfUY5H4Zq7Fp011aPa6tBBd IpysqAMrD1IxkEeuBSUrPUGro8MORGCAc5qSEkhwOcqe+Kv+ITY22s3Vtawypbq2EJBzkdcA9RnO OaybaZZJCithsEAEYJ+lacy3I5WhLlPPXDknjAJPSs/L28hU/gexFaRKPgLIhwcHnGDTJbYyAgvC R0wZFH8zVwqcvoJxuUyUmXghWPr0q9YaSt3YkhgkyscHPBHHX296z5LKSNspLGR6GQcfjmnwJdAb ouSDjKMD/Kqkoy1i7Maut9S1HcXWlTeXMCBnoehHqDWpBcG7ZZMADHA9KwZp7idNszkhSQN/Y1u6 aoESAYICjkfSonBKza1BSb0Wxr26gjkfStGMEAY5qtbJwCatg5GBUgTJz3px9qYvAzmng5NGwrjh kcilJJOM0mcDGCaQAk4xTQMkQkA5HWgsOo6jimkkDApvbmmhEyysOMg0xpCep9uKbkfj2NN9yeaA sBOT16UmeOlJmmkmgAJ75phIB60M2BUTPxxQP1FZwBxUZcAEk80xiepNVppwoIByaQIWafbkDmqM s5wSTgDrTZJgQSSaybu9wcBhwOB6fSqVhWZclulQnJwe3196qyagoY5bOOhHeobHTr7V59ltGz5P J6Ae5NdfZ+AYYog99Ozv12R8AfjUttvQpRS1ZxFzrKw8hCc8dapPr7nohB+v/wBat7xTpNnbXkEE EWxSCSQSScY9axhplsBkqT+NJ3BNEkup28mkgtMPOdgSgByoAPX8T+lUBd24jJL5JPQZGBRc2EQK hBtJOMnmmnSsKSHLEDIGMCk7jXkKl3anJZS2Pcg0jX9kIyPLcv2IbGPwxzWawaKQgjHsaYUy2B36 UhlprtCcgHilW8hLAMrdQCcCi5sGs41MzIJGGQikEgcYJxwM56ZzxyBVEYyMHmhoLmtLPgFhhVA4 Hciq6XheQJgkk4FPitPtMAZ2ZcZAFQm1VZQAx4PBB6UknuwuakDyIEcLtIbGTz+lb2mBtRWZJHRQ kZYknGSASAPy/lWTbBZHXOSGHbsfWp4IJYrgICytIwXHI4Jxiga3Op15HuNegsokDSGMKM/ia2ru CaMROyEIEVQSOMgDNZHi2Qad4wMtqTuiWPBz3IB/ma3tUu53Mdoz5hjAZUxjBIBJ96HugT0IbYhi MsATV15wEwCcd6z4VIIJXrWlbQxSg+bkcHGD3oEV2dSAcjHbikEoA4GD606eIREDJz1AqIqCMjA+ tDaQWJnlCpsBBzzkgZ/CqSyywOShyDyVIyD+FS447Hn1pGUDoBk9qBJWG/aWIyYUGPQn/GknnaWL azYXgnHAxz2/CmynjIHPrWfdySrEQgzgdfelJKxpTfvI2bC7fUrxNB09I7eWUBmu5G2sx6gA9hjs OT3ravNOt9B0tZpGtJrmNgN63BL5JwTgivOBO+matDcRfLnB8wjJU+o6/UGt+5uZPEOliK3hZ7uJ iTIB8zgnuOpI+lTFO/kaOV3eQzVLuBdQjtluQLUOS0yAMVB59skentxUdrdW0urWyXn2i4sAxQSR jDbcHGAenOMisi70m5trFlmCiRchh3U56H3rT0SVbe8s7OFybhpFKMDjDEcgHP1FTUdokx1eh7Ed M0eO3igElgy7BtE0ShiMcZIwagOgaKekemZ9pGH/ALNXknifVdQi1W7M7nzVlKkdMYOAMD2rFh1E OMyzypxnh2xn9at1UkrDUe57f/YOipkeXpfOf+W7D/2aopND0mVJVjt9LYopyBctk4GfWvHEu7Zy M38wPpvI/mBVS81GSzZZbW8kbJwSXB/kc0lVDliegRyW0+lvp1paFbuW63IQxIAxgKMnmq1zbXei 3HlXCCKUYLISDjIz1FcrpGvzRzqwl2zAhlIOOR0I967fSNLuvFU01zcyztIcHehVh+IJB/Ks1U1c ZbClFWuhkPiK7iKi2ijWU8BzlmB9QTnB+lVru9W1WR5AJLyTncWzszxz6n0HbvzXSJ4Euo8qtzKM 8cQEHH4HH61ZHgGyS2zcTOh3AtNMQoAHUBQSSfqRW2trJkq1zj9A0G+v7m3upLUzwNLt2uSFY4PB II+vXtXpJ8MWfkgPplkpHbzGH65rgPE2uNbSR6bpt4XtrfAQoAvPckDt7nmuI1DxXqSymKPUHkIx kqTjPcZqItxerL5bnsqaZowmNt9isDIDjAvCDn05NXl8L6aVGNOtzn/p5Jr55Ot3byh3uX3jkEk1 dXxVfxKAt84AHABzVKo7ktJHpWvLo2m6vFbyaciiJt0uy4JDDGcZ6Dt71zUrWl3dtLANluTlADn0 4B71y/8AaDavE5vJ5GfGQARkirWmgi2ZRMURQQMeuPSp5+aQNJK6O607w5cXsYnhhkNs2QSihsH8 xk1iazpjaPdSRNLIrKobZKu0nPYYJp2g+OrqzgXTZS5tC4MpBAOOM4J6cCsjxXdx3WpyyWLzSW7E FWkPzY9KfLdWZcXbVMekrOAQcgjoafGFBJJIz0yKqWpcW6bsggAcirA3HqcelJaaGb1epKSoJwcs eM+lM2jBYkZFSJGFGScnGaaVBOc8dxVLYQwYYkjsKUAk9M04YAJxk0KSWAAoTuGpfkIFioIHNV7Y A3CEjuDiprptsEa+gzUdlgyknsCf0pMfQZcyo1wwJI59KdZGEXaGRS0YYFh0yO4qvIQZGY+tR7yp bHBIqulhbux2KuT0JzTt/AyetQBivrilDZ7j6VzWRV2WA/Ug9KcGB5z9ahDADpTlKheSRmjYeqJw ygdacwBUEGoQwx1p6uOQelSrj9QKjsAacrbMUwkHJB49KQEkZGcH9KoXQlUk5YHGSacFLcdTUS5Q gZyPpTi2ckcfSn5iDBDc04gHAyeKaCCMYOaCQDwCcUgJRjjFOIzjvmow4GB0Pen5AGQapMGhM4J4 zjil3AYGeaaSPXOaARkYxTT6CJUYE4PapsjPHI9RVUYBODUkYJOMZ78U9xEvDHBOKljQFc55zxg1 VDhWOexqeCZQSCuQfQ07DuWFbIKngVCACSOopJJRyQcD0pqOCTijcLkm4BcHt0pXlJYEjBxg4qNi BzjimMc4IoQX0JS5KA5JqWLD8bgM8c1ULnywCSR0GKkRwACoyQM8GtEhXLUZAkBUgkcYxjNW1nIB YcYrJErFhhcHOcjvVpZi0RII3DjHrQK9yxLOWbBUAHqcc0juos2VhwGUgDseQP5iqjuSATkcc0hl WK3maQ/IApyTwOQP0zTStsDZneOSG8G3YzzujI+m4CvH2O6RQeMDBr13xe+7wnfkcjahBHb51rx8 sd+Rxk1N9QsPhiAbJI45q5bgnfkfjUMRDuBg9MGrIKxo+OuKGxpWM6WcMCuMYY1panj+yLIg9Bis VyDIM881v3sDz6RYRxqWdmwFAyTkUJX2GzJ2B0BAJJAAAXJJqtc6Rf2WGuoJI1cbkLjBI9a9g8I+ CUsoo7q+QPcEZCHkL+HrXY3djaTW5iuYIpIyCCHUEY/pWiioohu5498NbKzv7i6tbqSRJdoaEB8c DOcds9DXe3GlXOnKXtr4Mg5xLx+teU3xbw943f8As5t6W84KYPBU84J+hINN1zxNqmq3RSS5ZYzx 5aZA/H1pymraCSbPQ08awWk5hupUDg4JVgR+YroLHxLaXagxzKwPoa8AaKXPJ568GpYXuIDvV3Qj oVJBzUcyKsfSMN/HIAQw/OrKzggYI5rwjTfFWpopKMXKjJVh0/HsK6Sx+ISoypcxumf4hyKLphZn q4cdjQSCMnvXJWHi2yuwCk6E9xnmtuHUYpACHB/GmIvlAfSo2iwQwJBHQg4NIs6sOCPzqQOD3zRY CjfWFtfoVvbWC5B6GRAWH0YYP615P448MJpDQXVquxHYrgE8EYIwf89K9lOD6VwvxMdBpdnDkF2l LAewGD/MVLQ03scXoQ0zUNPuEvIANQg+aKYYIYEcBgeCMjr1561mXj2t4w+y25hnBIeNSSCR1xU3 h6JpLu7IICgAZI68np/n0osIGHji2VCQTcKOPc80lHXcbelihaaVc382yNSFBwzkcKP89qta1YLp FrbQ25fDBixP8TDHP69K9XuNGUglIkUnJJRQMn1OOP0rlfEOjl7ULMk7Rg5IhiDsMd+WGB9K1TW5 Gp5hl3kUMCTkcY4J966+wiMahSMEAZHpWDHFAmr+UYJyDIojWT5DyRyRz+Q/OuuMYifAGMdRQ5cz C1kW4yAoAqdDk9apoxNW4xxkCgROORgCnjIGMUxc9upqQCmAuc4Ip2QBgGm9OlGeBgUXEx2QBjv9 ajJwcZ4pSSORTep59M0xXFBpCeetHUdfypDwM9aAAnHFRk4J9aU8dutISMcCgBjepqBiAe1SOwHe qzsACSaBkc8oQHnk9KpMpYbjnB7+tPYl2LE/KOprL1PUVjjZVJCgYOD19AKH5AiDU72KAMEfIBwS O59qx7WNriYTS7gmcYHcU2KBr2UzTMQo4Vc1eVTEP3bjA7GuuhhlNc0jKdTl0R6P4a1XRYrVLeCR YH4BWT5ST656H866Wc5jPOQRXi8bgsAyge9bNhrd9YIBBOWhHHlucrj2Hb8MU54a3wMSqdxPGBA1 aHJ6K2fzFZMcsTgqFyw757VY1+7bU54rgQgbQdy5znp+lVdNu7UXMss0AACgCNScE59T0xXLOLi7 NGyaauiG6QbkIGMnH0poJeIgggjqPWrmoXFtOQYYhHtOcZzn86pl1EYIOCT3rOW5UTKv4fmZ1XOA PwrKLHOfQ1vTTqgYEBg2cj2xisSaMo+SCARkfQ0nYYm89M8Y5pMY4Iyc00ZHHajJJwOTSA1LKcmM xk4I6fSmlgJBx3xzVCKUxyBs4q0pJlyOc0CNvTJWRzsOHGWTnnI7flmtyzK3eq2btgAzISPbIJ/k a5OFnilV1JypyDXTxkhPtMRwr8rg4IJHI9uc0tmVbTQtaxcC/wBflkPO6RV/AYH9K6zUznVJdoyF bHOBwABXE2YSTUoEIJkeVRnPqRXaXoL6nOxGf3jD06Eik9WCWgsTggkHkc1MjsBkkj2z1qv5YXJB 6dBQHLtgHHbpVEkzEyOTg8e/SmscDGB9ablieeCP0pSH25OOeOR1pWuxkTPhsKBgUpIIBAOTUbIy kk4IHcHvTozkggg+oqrCHspChjkAjgetQ3SJ5RAGMgnJ+n+fzqcOXYKRkLkn29qpXEokn2jOF6Ae vb/Gsaj+yjpoRsnN7I19MfTUhEj6cLhopVCq5yGUAAKQBgknJz9K6TX7yw0bQ45dHsYYXnIMs0ak hSc8Annr+HFc+6x6bpiBoj5pUgEnGGOMnHcgYHPsayY9andZIXCyoTkLICQCBgcZ4x+daKXJG7MX eTK08ESMZbmUvLICwUHJz2yM8fzqrqmi39i9jfPbyQBiJIyeMkHOR+ldP4UsfD7lbvU9UTzI2JNu EOeDxk9OeuBVb4g+LodUnRLT5YIl2oOMn3x2qYx57ylsX8LsjiNcv5Ly6d5WLSMSzk8kk1QUZQE9 uKqvIXkIblick5q5GPlxntWU9NEXFXTuMZARx1qNogSRjIq5uUxCLYoIJJcZyc9uuMD29ec04CJU CkZIJJOcZ9qE7ENamcts4O5SRWra3+oWpHk3Eikdw2KjLqQAoA/nRuIGAT70PXcFc3YfFmtRLhb+ 4AI6CQ1Fc+IdRuxma4nfIwQ0nX8qxgSBySafuJwTk+lLmfQLiTySyggsVB67e/1J5NUxCqjnn3NX Nw5BqEkEkgUavcFJplSSIAggAg9MVEYyVxjH4VogKeNvSggAH5Rg9qE7aA+5BZDFtcsDh1Tj2HQ1 s6CjXelNMAW2nDgdR7/SsMO1vOSclWBBHY5re8Ozx29uUVgkgYnr1Hajm5dbCtfQLuyCBbg/Lu44 IqzpcsNtBch0DyY4J7e4qXX50uYY2TAfbyAAACPpWPbTMWGT1BU57mrb0UkK/Q1FIIyAMHmpEIIx g5qpaHKmMnlTiriLnp2pJ66jaXQRwQc55PakO7HANSlCeTSHAOM1foKw0A4J71LEv7xcDPNMUZGQ amhB3gDjmhMTHX7jIHQYxim2JASZz2XH51Hfcy4Bqa3QpYSN1LMB+Q/+vQPcqMN2SPWrcVohtzK5 Oew9ajtohJKFPIJ5NXpiskqQpwo4JHp3ok0lc0pQ55eRpjcBkkkHmlBzjIJz7U8A5wRmnYJ7fpWF yBAc9AeKcQCMAY/GlVD1INPC8454ob7DsM5OMCnDOOCeafjjBApQpA44+tCYWFUEgdOlTRSCOJ02 g7hjJHIqNSQKNuSATQmwsPPK4AHHOaACe2R0pvAJUkcU4EA4OTQAEEDAA9aaUYnOCBTyeT6U0Ngg E5pAAU7qlMDiHzCp2ZwGxxn0zUe7BzUolYxbCx2E5xnjPrTT7gQcnigLg9adgA5xQCN3TFUmybCH PUcU5WZGBBPX86cATwRTsYHA6VSeorA7hiWIGT1HvSRuM4APB6UEEg4FNwR2/Gi6Anch1JHftUCn BPOMGnqDtOaZsIYimmgauWC7MACckjnjvUZDKeCRxzT1BUg9acy5ye4qk9QIWP7sAcmkgYrKMng9 fSn9SSRyBimhQGwDzmncLXLCDDHIB5PFOUYypBGTn6U2MKhyGBzyPY095FAOCdx6+lF2FgYZGCOn f2pHAEEuTxsJxjj1z+lNyzc4yR6UjuXVgM5Kkc/Q0JhYyfEjhvCV9GAcCEY+gZT/AEryRlOcDJ7V 63rCF/Dl4uAd1uR+Iwa8vYxQAhuXI4welJ7gSwoYwZDxkAYqK5YrGTk88GpUlEoUjp6VDdoxiBA6 mizH5IoJG0kqqilmYgAAZyT7V6T4UtN2q6bbzIN8RbKkZwQDVH4f+HDd3P2+dMopxGCO46n8Og98 +lb2hKIvHTIAAiyTAD0wTWqXLoyW7nocjpbxFmIAAyT6V5H42+IUkrzadpblQPleYdeeCB/jWv8A EPxO8UZ020cgsMSOD0HoPevKoYMysWGdwBwfrUNtsEjU0q0murN2CAFW3tI5xknsSep9B14NUDED qKRcElgK7DRgyaDqewkfugDgBsDcOoPQZA+Ycg4965BZ1h1dZGzhWyeKmXkNWuWbm0MTfdGB2xUE 0RWDeSgwwXaTzk55H5frV67v0nkV8EAHOAP1qGQ20zJKSDg8DOOaiNy3boyOAy2kiTxAnHDL2Ydx WxqFlBf24vbEAgrl0Awc4649Rzke2fXFSPyyP9bHxz94dKZDcvp0rTW8qlOrxh+oz1+v0qk3sxNW 1TKCCWJnKlhtAII6ck/4Vo2Ov6nZj5Z2ZQeA5zir7RQanE1zpy43EF4SeGIz+R5P1zx2y230yK7B CtHG4OGjkcKQR7E1Wq2J0NnT/HkqYFxEeOCVOa6ax8ZWM7KhnVXIyFJwfyri/wDhH1jGTNB6/wCu X/GszU9KUJujljWROhDgg+2Qaak+qE7HsSa1bCIyvMiooyWJAAHqa8n8Y+Jl1XVGmXP2aIeXED3H OT+J5+lc49zdiMRSzP5Y7FiR+VSWNqtzMJbjCwx87M5JPv6CgNtTpvDsUVnpjTzYJkJYgnBAxx+g /WpvBFp/avjF7xhlIN0pOOMnIA/XP4Vzeq6v5hFpaNlDgMQOvsK9G8D28GkaSA7qbmYhpSD09Bn2 /mTVJA2d0UBHAqvPao4IKg/hRHdo4yGFSeapGMimSczq2jWvlmdoULxjcpKgkEdMVyEpBlI4Oa7/ AF6RU0udsjOAB+JArzp3JlNC0YFhQVPPI/nVyMjHB61WjOQAe/rVqNRgHH0piJVJPOTTicCgAAcU AA8Y60wHAkrQSADzSnAxxUZOTjvQgFzntS4JxzTQGJwAacFYc5AHuRT8iQ/CmMecVIQCvykE9x3F MYEcGi1gsMORnJqNiMcH8aex5NQSNj6UkBG7YBJNUbhyflB47mrEjE5xVJlO1nJOB0+tA/Mp3lyI 0ManAHOSeg9a4zU7me6kJETrEp4ODgn1NdNdhXBV2K7uCQcYp91YaRZaAJYpjNdvINyCQkhcHJP4 4qb62KSW5yQtpQg23R46gggZA5A9xW54Wsv7Q1MwXMkpj2kjBxzkeorPmtGi/frMjmQAlQpBGecE Yxke1b3hGZzrSq4IypwSMdxVczWzCyZ2L+BbSeIGG5kR/wDbAYfpjFYOp+FNR0oGVV86EDJZOQB7 9x+Ir0m05jFWJgDGQeQRg1pGtNbMhxT6HiolyMMoBHBB61DNbrKC0RCv6+tbfjC1S0vw8SbVbJbA 4HvWJE7KAx5XPWuyE1VVpGMouGsTKfzopCsoPHQ+tI0pKgAg8flWxeJC8G9gAR0Occ+lZwEIdkUg 8ZBByPpmuKtT9nKxvCd1cggTz5QhUHJ7jNW9WsomtAYly8fVumR3AFMtImVXmAOAcDjoTn/A1NI5 cc9PfpWY3ucuQAcHrSnAGR61avLVoXDlSEfJViDgj2PeqmcAik0UHBPcd60NPcSMUIycce9Z2SOT z2qe2do5hIpIINIRsFACQVIJ960LKZ1gaIgheqg9/XFZhnMrbiQSenvU1uzidSSAM9PWm0CudV4U tI73X0Mr7dhEignqQQQK7fVLE2d8xLowkzIACDgEk4OOhrz3wy5Xxbp4VvlaQMcdwAT/AErunjcy u7ZO4k5P1qFuVpYifO0HgDvUPIfIHHXFWcEDnPvj0poQEgAYq1oSIhJII/KrotBJGWYncRwMcfUm qzKEYEEe1XbORlYEkbcd+lSMoSQGMlffpVRwVORwBW9qgjYxvGBtKjJA796ynRXjODk96d7asEru yKjSeVbsxJy36Creg2QnlkuZyTHENzYx1PQDPp/Ssu7cvKkKnuM1016q6NoK2u3FzKBu9QD/AC6f yrCF5y5mdldqEY00YOsX7XMp2kkD5EGeozWJqNyLG1IU5lfgEHn3NWGdXkdmbasYwv1rCkdtR1Dd g+WhwD6AVc2m7dDnj3JYJ2tbRpGOC/TnvWbI7SMWYkk+tXbhvNl8pfuLiq0qFcgD8hUc1tCt9SjC CZWJHOeK0EwGAJxVFPlkPXHWroIIB5J+tRK7aLSsiQEAk560hKkZANRkjJ4IHvRvHIx1ppGZOAAA VAz3NWIbcysgAJZs4A5JI7Ad/wAKz2kI4B9qBdyoUw7jbkDBPGeuPTrTtfYXU07eCGV44yziR2Ix gEe3UgcnjkjHWnSwxxRO3O5XK4AyAR71lLdSo4dGZWUggg4IPsaX7bO8ZjaVihYsVJOC3TOPX3oU e47k5K55xTGK5qLce5pV569TS0DdkyEYPpSgA0RqOnXNShVHtipv1G9rFaeNXGCPyqvAgaURMxUn hSOx7VccEgjOKpzAqQ64GD1FWndE3syfSWlN3PazOxYAsuTnp1FTYMcrL3ByKr3k4gubO+RQACCx GcnnnNaN/EEkSZRwwBH0PIqlqhNaj0cJKkoIw4wfrWvESR7VgowaJlHJU5HtWrZz74gM1Olr9Rrs XsgjnmoXUkkjvThwM5obnt0qr6CtYAMLg1Nbg+YCe1IIjtBPOamhXAZgBgDJppAylcsTMSP5VcI2 6XEO7sSQfTOP6VQlYtKR71qzKEgt1IGAgJ49ef609mOzehXjxBEWIwx6VPZxtLIAAS0hA/DPA/Gq cr73AHT2rc0uHyIzcvgEHaozznHX8BURTnLyOmp+5p8vVl1U9SacAQMAmlEZHfGakCkelY3RjYRQ cetKASTkGnYOelKAMntRcBv4H6UuM9jTgBjrRjrg0XENAI7U4g5yRQRgZNGAeM9KBCDOe3NOwRng UADIHpTsYGDTuO1xpBPamgDgEVJjPrSke1FwsR4HOaeMDtxQBg9Kfjg8UJoLDSoJxj3pCoB6dqlA IHSjBx0zimmFhECg8jmnYUHIODnp60gBzkjH4U5lG0HGeapPuJoYwIOQMA03kgipGBbAPGKaE5wT kdqd0FmNXOMHFIzFWyfY1KUAXj6UxwMjjPFCaEPU7snHB7UEkHBHTvQhIOKVsk5x+lNMBhyM46ik QBjkjp2qTBIJwB2NNQAMdx4I4NPqLUQnJJU4A5waVVJYYI6UpiBXcrE84PtUkcYBAPai+oJE4jCE IWwSAQcdRUIjzcAAHBJAzVxpW2AbVOBgZAJH403KllyuMcmiMWncbatZHPayTD4buGBBzCQeemRi vIpCSxLHJznmvZtTtHufDV6yqSFR8Ae2TXjxiLDdnoe9CknKwnFpIfAGERP5VYtYJb+a3tozl5H2 jPQep+g6/hUDMRbuMjPtXZ/DrSTdXRu3TKRnYhI7kZJH0GB/wKtoRu7voJux6Z4d0pNP0yKJFwFU AZHb39+59ya89v8AURpHiO8u1xuWWYKCepJIA/OvXEAig6DkYrw7xdg6jOwPW6fn/gRpTbvoKKMz VQ89rDM7FpCSzkjPJwTz/Tt+NZcaD7QoIwSuefSti/K/ZEUYJULyAVBG1RnB+nXv7Vl4CXURyOV6 mpi+g7HW6Ypi0C9JXIZAOUIGcnGGHIPt0IBB5xXAXAIvnJwME5OK9IsVL6LOEIDtEQQkvzEZJPyk YIwBnuMAivOL07L2bk4GcHNJv3gsKZ4XVlZW85mUqc8BQDkcfh+VJ0UAVSaUkjHY04zP2OO1WIvC VVHPX2pA++QAAc9apoHfgc81oWUQEwLZ4HHoTSAW3e7tL3fauVJOCOx9iK6KPVbPVNqXX+i3qjAl yAScep4I46HnnGcVlWxA1BQQOT3q5eafDcSFgAHxnHY07XQX1L08V1aAs6efCBnzYweMdcg8gjoe 1Qb4pRlHVgRnA6j8OtZ0N1qekt+4lYrjAD5IH0PUccVYbWbG6YC+sBbvnO+IEAE9SSDk+wPT9KNR EGoWT7BIqkk+g7ViSxTFgiqxweQBzXVqLGUZs9XKkDhJBuz64OMD6EVJdaDdOZH+1Wj7VDEjcOCQ AOmDSa6oepw0SE3KlgpVTkozhSfbJIrTtr7UrImS3lAjXJA89TgemM5/StC68JXLFpHeBQmCSJQM Z6cGrQ0CW2ikiLWSgAFgXYknjH6mhJ7hoiS08eXdoyR3AV8gH5GBx9cH9K6mw8c2k6oZHMZI4D8V xqeHtNUs93qttAB0AUsSe446fiO9VZ5NEgV0hSa4kwoQ5wAe54AyPQEVWu4aM9D13XIp9JASQNvc Dg9uT/SuXRy75rnbR5Xu/lV44DyqMc4roLcHODTTuS1bQ1IckDNWozjGPyqrCAQDVqMYOAKYl2Jx gnBHSngDIBHTmmjPrTueucHNMBMDqGIA9R3puFJ+ZsY9BT85OCM+1MYKThcknoMUK4mG/AwCQB6m gsGxhQAOmKRVGMkEH0PNKRkcUIGOAAHGOnfmmuOOOD+Y/OnonykknIHbtTCCCMgj1x2H0pi6ELEg Y4qu3I6VO+DwOaiIxknpSs9h3Kko+UjuarXAIjwOmM1bcc1UusBPrTEmc3q5Ihx2JAOMc1Xh1WG2 hCeUjHHO7nNJrmRakgEfOBn86o2dtC0e5kDMe5Oah7lrRE+j3cc+rOLlQ8RBIXOADkY/QmuxsDYi +t2to1Rt2D3JGPU1xjWcRk3qpQjoUOMVp6I00Wr2xaUtGXxhhz0I607Cv0PYrMExqcdqsyD5CMVX sMNAoPPAq3IAEPFAzzHx2XjuLVkKhmkC/PgKc+pPGPXPGK5lFmtpXtr6IwyDkA4AIPIII4I9COK7 LxvaC5Eanghsj0ziuDmubmC3exmUPGuPL38mPnPyn0Pp0rSE3B3QuVNakkMAuZ8yM3l5IA9qde6W Y4w8GQV5IzWtbwQ3OkJLD1UAt9en4c02NxLEUccgYANd1OnGrBt7nNObhK3QyLcskJQ4yRz/AI1L AiNcRBjld4yD09qdcRiKTkEZ5pkZByRjqK4JwcJOLOiMlJXRo61pRvbGRwx3xgsCeeAORz7CuDcf MRjBHWuqv7m6+xOonkKAYwWJFcvICWJPWoexSGAYwMmrUQAXHPHJqsvByACfQ1ZtoZriURxIzuR9 1Rkn1/CpAtRnEZATcQCfoOB/WprO7AnU7QQueD3zwans447aO8G5Zn8gLuU5UEsuQD3IGQT69OOa yg4F2Aowo4IFNgdh4VlUeIrSWQ4ESytnHQBGwfwr0GzuJbvT4bqaJkMwLLkdRkgH6HFec+EruG08 S2bzsFgcmNmbou4EZP4kV7L5R8s2sq/KPukDgehBHas3Kz1RaV0c5MWLHaSEJ6YxTCAMYJ56+1X5 7cxzlCMgHg1VmicZZRuA9O1VcVrDWVVAJJbPIz3p6TKQARyO2etVTJn5c4Ip6gqQQT65oTFYtTGV 4gNxMYJIB/hPFUrhlt4GbcO+D0yKt4Kx7pTwxyFz1rP1u2uo40eSJkVwGXIxlexx6VnUk5e7E7KF LkXtJ6DvDdkL3VRLIflTLkkenQf59DTPEuoG4vpCrZwSqgfl/TH4VPaznTNOO04mdSTnjArm5p2Z 5JTltowo7kmiPuxMJNyk2zK1K5YAwoxCL94g9TUkSC1sQcfvJOSPbtVWKLz74RsCUXLOf8/lVudz LMWIwB0HvUSeo7WIlXYOeWPJNNlIA4GQTzT9wJyBxTWAIx61nfW5WnQpso3OQMU6M54HelIIc9cE c0kIOckcCj1KLVtB51wqH7oyWPoB1rV1Z9JuDB/ZltLAFQCTfIGDN3I4GBVK1jKwF2481toJHbPJ q3qVk1jOIhNDMpUNuhbKjIzjPqKtJ7oh6aGa0ETgBQwkHXB4x9KnWytUtmWZZDcMAUKsAFye4IJP HoRVrRNPTUNbitpriK3R1JMkpwoAGeT74xTb3BvZCpGAxAx0AHAqrO10Toa+j2Xhi3tiNUNzcXBA P7khVXjpkgkn8BWNq1rYrdO2mmQQljtWQAkD6jr+VRIS5woJJPbvUs0EkQUSKVzyMip5nshk+jwa SJR/ayTSIVOFhYKQexJIIxSa5FpQnQaRFNGmAGEzBiT3wQBiqKk5JHqRSbCJNxzyAaSGNSNgMkAH 2pxUnqO1PY46jNABI6VKd9BMrsmQc1E0W8EEdRVtkJJwMUmM8EYxVKXYmxQaAz2M1uT88eWX6d60 9Ncah4fTcQZLcmNvXHUH8uPwqowEF0kuPlJw3uDxRpMpstYuLU7fLuEIUHIAI5BGO+M/nVRfcGm1 cWNjHICenQ1ct5DDIVxwDn8KiltyZWUdTyB/n3q3DZytEs5G0AYOeM/SnfsFrllr2BAN8gXPTJxV oKSAR0PSs29si1tuGOQSBkZ/KtTS51l0+JpFJdBtYdORTa0uDunZlhIyAACSacWaKJ12gswxUv2k hcKgGe+MnFQu/mkkjP0qloibXM8xMW5ByTWjqM679qEYUBQfYDFRtGcZJIFQ3NrK8LPGS4UAsR0G aiU+iOyhSs+eWyE0+Jry8SNBkk9ew9z7DrW9eXENuxiUDy1GASeuOp/E1k2qSaXZrMTh51JAA525 5Ptms+/v2uTtXPTnHYVrSioxOatN1JX6HcAEjBNPCc8mpViyeBiniLocVw8yL5WyFUx0NOC47VMI TnnP408QMeBzSuhpMrheORS4HpVv7MxGCKPsrZHH6UcyXUaiynj2pNvNXjaOeQKVbJj2Jo513BQb 6FDaQelOCk8E1e+xOW+7ThZMDyKXtI9xqD7FDBB5xxTipIHHSrxsmPYU4WTHgDJ9qFUXcOR9Sh5Z yCBwadsPTFaCWZOBU62GRkgACk6iW41TbMoID2/SnBDycVspp8ZAOehqX+z4gD1/Go+sLZFKlYwv LJ4xS+UQw/OtprSFRksB+NQSLCmdvJxVRrXdkgdNJXZmeUQckU0oRnjAqyX3AELjPao2DE4IrVSf UzaXQhwDjjmgoSBgYqUIQeAakEZIAI71alYnl7FUKAR+tOCZOccCrPkEnG3P4U5IG4AHempK4OLs VnQ45AAI7VEFIBABx61eeAgkE80JbErwM1XOhKDZUVMRhQDnOTUqITgc1aS3II3DGKeEUMBx0IqV PUfKUyWA4zx0oBO4HkmroiQjJIp32ZcAgjnpT9qr6gqbexQt3zZXNscEM7A+4I6frXhkwKMVHGGI Jr2yM7Lq7QngSA4/AV49fwkXt2ikjbKwAz6EiqikpXREm2rMpKrOQDXuvgrSBpuk20BXDhA0meu5 vmP5AgfhXk3hSw/tLxHZWrKWVnBYY42jk/oK980qIOzMDgM5IPtnj9AK64q0bmLethdVuVtbKR2I CxqST9BXgeqXRvYY7gnBkmLdcckk16t8SdRNp4ZvSrEPLhF9eSB/LNeQIC+nWQVSTvAAxn9O9Yt3 bKSJtRcmFioIUucZbd9Oe9ZUj4lhPP3RWlqcpa2zjIZ2IJXBPJ644/L+lYwfcEOORxmlHYbPRdEL S6SylWYFSCPJDqAAxyccg9cEdMe1ecakmL+VcYycdMV6B4alR7JXJjUxsDksynBIHBGcdep6c1xH iGIQay6jG3Jxg579j3+tJ/EO2hlm1GMgk+1KkSF8HirKKT27VFNGyMHAxnBNaEsmRABgAe1TxCQz opfMaksB7kAH+QqOL5gCOeKmt3KyAjGSCORn+dKwx8ZxqUfH8QHpW4Yy0g/OsPAF9GD3I7V0YldU WH5ShOTlRnPI64zjkce1WtESyMxKw2uAR0ORmq9zpEMoyrFcjoORVsZI5GO1SNGwjQkdRnNNpWFe xyl5pE0EeUKsScDHBqkltexE4EiA8EgkDHviuom/eSkEjCjHPeopw3kOqAEkZAIyD7YqeXTQdzCu ItTjEZkuZBHNjDSSYBwcHnPY1DdQXaWYmluGJMpjKliSCBn1/DpVzUb1ruC0gSIIbbACnncckkn9 Bj2qC9kmitUtXhClcMCBkk+v0I7UgV7lD7FKIjI0g4GcDvXeW2haVZG3eSFrgFgGV2IB+U+mO+K4 NJnfMRHJBA474ruGvUEcQBLMoBIHOOMf1qtLahrfQk1g2w+zLbWyQKpYkJnngdahgwTkVWup5Z5Y 96hQM4Gec8datW4IAz2oTvqhO+xpwgYFW4xngVWhGACTge9W0IwCD+lUIkAPTGcUvAGScU0Entmk 56kUWAXO4ZBIFIOOAeDSjJGSKXYSCQDgdTjpSQr3EGCRzUkahmGSBj1zUYRicAE4GT7CpfLYAkgE AZOO3+fWqESELuIA5yByeT9COn/6utQOccZzjOOMEfjTmBHXke9RvkgcE0AQNySSetRSEAYqduD9 KgkOevegbK7YJ4H4VSuQTkZHAq65IBFUrnjIHGRR0Dqcpr5At1ABGXqCzA+zjntmr+oadPqLJFBt 3KScHPNVmsbqyi2yxMpHHTiovqVrYYzAkKFJJOAB1JrS02wvDJHd7V8uNgxAViQAeeQMfrVfSLQX WoRiVSY2kWMn6gkjPqcY/Gr0+r3ZuLuBbqS3hiJVYUAAYDgg9+cU+thJWPVdMcNbqfUCtBxlDWNo cu+0jbPUA1sMcqaEM5XWLeOe6iSZgsZJBOOnBx+uK5LX9BZDGhB5JAcdxjOa6zxOfKspJc42Atke 3NZ+g+ILa7tmtb+JZYGACSfxKcdj6D0pa79Bpq1mcnpsMmnEwOwZJATyMgHntUkyGGfJBAPtXQ6v obW6mWJg8LAlHByM9vxrIKNd25VY2JiHzknpXfg6qT5TmxEW9bFS4iEsZIAyOQazY48u2RhQcHHr gn+laETlZPKfHHT3FRXMckMoMMTSBjyo656DFb4ulzx5kjOhPllysz7jD2pKjJxmueS3luZgkMbO 5OAqDJP4V0o8qIDznDE5zHGQSPYnoP1I7ism8luEDJCiwwnIIQnLD3J5Prjp6AV5J2JEKWltbANd y+Y/XyYSCeuMFug9eM/hV6G6Bt2hkijitmABWEEMQM9TnnrnnPTjHWsUFzkBckd8VP5V5cx8IwRe pAwB+NK9mMs3N3Bb2xgtizFsFmYAcjPAAJ45698dqowAhwzcknJpREm7apLEHJJ6f5/OpSuCcdKG BcgdfMy+RGeuOuPb3r07wP43RYY9Kv1VgGxBLIckDspPcfWvJA7bSBnI6VPHLMACCQRzkcYNJq+g J2Z9EOFuQxl2hyxI2rgLntj0rLmgNkWEhLbgcY5BFcz4N8Xm9jXT79gLhRiOU8b8dj712MyrPHhw ARwCf5Vldp2Zej1OfK4fdgg9QOtTLOXJLKMAZOB2FWXt0CsHYhweBjjFU5FZIJARgcHOOacpJRbL pR5pqLK8etrFfJFsiaWY+WkkxJWIdCxHcjPHb2NdbeaalnZzXV/fWN/cFNwaYuSwxkBcEDHoBXmd 28sUbSrGGKMQCVBIOc5GevGK1rS+uNZ0abTo7ZpZyyvHIVAYYwCOOoIxwKmknbTqbVpXlaXQk1K/ huJXdGM5eFRgE/K3UrkjJA6e/qayLl7S8hYWrtAijBMxyS2OeeO+cD6VproV3o0DHUQI5nJYLgZU Y749fSsG3gingkWeUoJHJU4yTzxWktFqc630HXMum2VjDb2KStKw3TTSEZY+gAHAHvkmsqW4BfaO meT/AFp15bvA6o4IKg5z35qtIoLZA7VioqxTbuWkIIGDmpMFumKt+HNNi1TUUtZ7mO2iIJaWTOAA Ce3c9BTb2zEOoSQwyrKiEhXXOGAPUZ5xT9m3HmBS1sZkuSxUdc4qaO3dcAjGRVu106S5uY1hZZJX bAQZBX65GMe9b2k+G7jVNRezglgYxoZJJC21VA4OSQPXtmpUZPYd0lYx1dvKRWcNsAVQAAAOv557 0M5dSGfIOMDHOa6rVvClppumm4TWLOeUEAxxsSefQ47Vz1hYvf3gt43jTALM8jBVUDqSf6DJp8rW gebKSx4lWQsQACMetLgYIB79a7O48GW0Ni9wuuWEhVCwVXOWIHbjrXGqjyXgt1VSScBgePr9KGmk K3Q0NCv4tIulme2huCpyomBIBHQ8Ef4VL4g125125E1y4O0YRQMBRnoB2FUdUsn02+NsZYbggD54 H3KSRnAOKsXWjS2mlRXrzQZkYqIRIC647kDoDSjdD8ivpD2lpPuvbcXMZJOwsV57cinalcx3d880 USQoSNsaAgKB2Gc1TaOZI1cquGOANwJ/EdRUlza3NnBFNKqFZQSoVgT+IBJH40tQ2IHZRxnn60Bw F61BKsojEhiyDxwRn8q1NP8AD2p3tkbkJDHFgkGWZUJA9ASCaVrMWr0KinIyM/hSZAJOOtNg3q7I 64IPrmpdgJ696HuCRVnUPGwGc9qp3LOI7e7TmSJgPxB71q+UCMEVC9mFgLMcxyMVIxyD2NPmSBI6 SI6eCblXWaMZKMBjJ69Dzj612Wk+H7PU9Ja8kvrcAEFkYYAJGcADGOvavOFRre2t3iC7RGAcqCMj Izjp+dFhrt1pF9GPOEkcbhwFPykgg8j+lbxtuT1sa/ik2sF8kcDIu0BQV3DJ7cEk1S0y6Zso4ALD PAxkim6tqs2sau+pCAMc7iFGAvYdOlRWIZ7rcRyAc496bt0FI2FckE9xTfN2ZJApWUovPBNVZmZV BwTnPas5Oyua0YqU0madlEL+WOMODLK4jijB5Yn+Q+tbF/4abSrWSS/Vt45ULIoHtx1P4VwK3d3a XMN9CSPJYEEHBBBzmusi1uXxFpzWzQvPqU0vyuMkgEAYA+uadKC3ZrWqNy5eiM7U5UQJMJg3mRAB FbJHHQ+n0qKBrCLS5DDJ5l3JjJJAC8ZIAI5578UXfhi6soFa+VoS5IUPwcDviq9n4eiOhzX8lyig TGNUJG4gAHIHpzj8K35Wcujeh6zHpznGQMVYXTCeSQKvhlHal8wDrXz3tJM9DkSKi6agIJP6VMll EuDtyak87J4U4FHmsegqXKT6jURwt4x/CKDCnoKiMpxnFRtcEc9KVpPqMseVH/dFMKRgdqrm4Y8A gUmSeS9NRezYLyHOEDZByaiLZ6DNOwuclhSGSNR97JrSKt0uP1G4Y8kcUoBHJ59qY9yoOAaia5yO CBWsYyetjNySZZEwXgjn2oa7zwCMVQaUEk55pock8d6r2fcj2j2Roi9IGABUb3bNkZxVUKxPepVg YkHB9KOSKd2HNJjWkYnGSfxppVicZNW1tTwSPep1gRQCQfyo54x2GoN7mcsDOQQDzU62jHqMVdBR DxgY9qk3qRkA/lS9o3sNU0U47Qg8jmneQFkQFeM4578VYDYYccGlkILKc5wR/OpUm3qPkSWgzylA 4ABNNES7SSORzU8rAHHHPrUMksaAkYBxTje5TStqQSRgOSTwRTcqgPOCD6daZNdgnII6c1VecuPl 6nqK3jGT3MXJLYmkuCDkH2qJZtxJJ7YquXJP48imM5DArxxzW0VYxlK5Y8/ZnrUqTswAB6VUYb4X bBIUZP8AjRayKxXBJA459acoq3mEW76FSdyNRuR3YKf05rynWHEOuahGxAzM2Me5z/WvVdQIGosR gBkBryzxXAYvEt1x94q2PqoP9a0jujJ7tHWfDGAC+v7/ABn7Pb4HsWP+A/WvX9OXZagA4IWvL/ho gHh7U5D/ABSomfbj/GvUoOIMD0rrlojJ7nl/xiutunWkAJ/eSknB64FcRYPi1tGwp2sDhlLDA55A 6/Suj+MMpa+sYccAM34nArmLaQRaZE4DHgjAbBGQR1Haue+jNYxbskiDUpNtrEucZBbg5HPoO309 c1n253RliScHI9qXVLlZ5QUJIAABIAOAMZIHeorBwVKkjk85prYcotOzR2vhC7lMc8CO4DRnIQgY xgg5I45AP4Y71m+N4CNTMxLHcA4LlScEd9vB6Y98VV0Oc2d6H3EjcNpABA/Ot7xpApWGaEKYZYwy kKATx3A4zxzionJKzZ0U8LVqbI46M/KCTjinuFdSpIPHPtVNnIYKSAMYGKYTtGQxLZq1JNXRjVoy pS5ZblyAbGKk8npVhCAyg4zn0qluLYJPI6GnrMRIoJIORz6007szaLcxxdRtjkEV0X/LRcnjtXL3 b4KN1wRXSBiWQjOcDpVolloKGkVScZOMnpVu6CxwglgQoycelYt1IzEDfgD7x7jnqP1qsk8jSSxG ZmTcMZ/u4z+pqb6jtpdkqgsSxHU5p20nORzigSBCBnnOMd6UpKyl3xFHnAZuMnBOPrgUOSQJNkH2 eDzPNaNd4Oc98+tSMgnBzErqATkjIwOT+VPjWNkLwRtMOAZHGFGVJPXuCDn1wfrVK9mjBPm3W984 8qPIAOBzg++B09ahybdkNJIcy2Nu3yqryekS5I4yDn09R2qC4vnjDBQkAPT+JiCvPPTGT06gkelR iKd3eN9lmig58wHcSuFK4wcN1POM889KY0+kWakqr3UwJG+Q4XAYFSAD1wMEEkcmhLuO/Ydaziac vudxtAy5ycgAHn0yOPbFb0AO0H8aw7e9N9KJTEka5IVEACjkk4A4HJJregyYx64rSJMrF1CSAMjm ri8ACqcPJHc1dTOOe1WQTAY4JNI5zjt+lJkA5oIyRmgXUkRcggYz2ycVZhVQoUYLcgkDBBOOOv4d qqg4qVJCABnocjjn86EDLnkI4ZgvOAcjoOvX/I6UssAXJODgjDg8H8Ov54+ppkNwVABYgDqRTnuA WBVQAOvGR+RyKbQXK7psIHQkkDjr+H+fpVZgATjOOOnIqw7qcbcDAI4PXrUBKgljjjkUCK8hCjGO R1NVXOeTU7kk5PU1Xfk8daAInHXPf0qjdnAJFXJOhOfaqF2eD64/KgA0LB1dVIyCOmeTz29a7Caw gnX5kBBHcVw+lD/ieoB0CEj65r01EW4gDFQAQCMduBWVtbml9Dkbvw1aK4uUBjeMhw6HGCO/vVK+ 0aG6uxczQjzCBkgcN7kDFdfPC0Dgg5UnBBHao2jil6rg07sDR0iyRdOiKjaQg4xjNXWU4II6Vnaf KbYeWHLIScZPStPIcZBpoRzPiOES2MyEA5UjGPavILS/lspcqCVz8ye/qPevbdXiDwMMZ4ryO6gE F1IpiXhj1A5GafQEdHpHiuAyJbO4eIjJBGcE8Zx6j0rT1LSmt4RqVkUuLSQZYoSAD6EdQR9a85kj IJdABg5BHBB/Cuj8PeJLmyTZIQYpAVdG5Vx0wR2NEZOMrodk1Zhc2jKUdlClhuGDnANJsE0ZRgCc YI9a0zJDOWgBBU/NEcZYkngH6dKzJI3tLgqykAHBB7Gvaw9RVI6nn1IOL0MG6UW8piYAY5XjtWdI 7uCCMjt7102qWgubfco5GSOK5dgqEgttI7Hg152KounLTY6qM1OOu6K4cxucZA9u9Sh5HJAyR04q RQmQTKPqTT/NgAwZQfxrk6mxCluxY5KqCM9eT+VS+SgIGGY9z0H5U06hBEP3alm9ccVD/aN05JRQ PTjNAMtJFEx+VmjkB4JOQfb2/WhxKjlHGCPbrVaOeSVgJVCt2IGAa10Kz2RUgGSMZBxzjuP60gM+ OVopQyEgg5BBwQa9X8HeKV1OOG01BsyRqFBAGXUdPxrzBIF2EuSCeAAMk/0q1YyyWxDIxR1YMpBw QeMGlJXQ0e1zxQ3MjPGpjUnKAnJ9gawtQusRmIsCQSSQOB7Vk2HioXlkYZmKXAGCQMg+h9qr3d2z sIgQCwycelctZvSPU9DCQSvUl0Nfw2kV3qQRoVdWVg27kZPUkeoHA+oPavRr/VNP0PSJLmw063S4 ROTFEB5Y6AkgZzXA6PJFpekzXbgGRxhD09uvXuf0rFbXbm4mmiDgiQAEEA9+MZ6fXrXRSaitdjjq Nyk33Ll5q8uqgy3kjESHkkDOO+B/jWLqVjNHbQ3SI6xFwFfbgZB7H1rrfCej6VcrJf6zfxBYnIEA bLNjvj0qDx34mtdS8m1s4wlrbgiJAAMn19qLupdvRAlayOV8TXyarqkl4ECZVQQO5CgE/iQT+NYZ U5BAHNSyOXOCc5OTTAMEcf8A6qyS6DerJ0DJFkHBJA4qykv735upqvskeNBEuSWBJ9BWvfJZGxth awSJcKp852fIY9sDAwPzoburdAWj0I9P1S50PVDdWjBXkjMZOAeD1xkcH3prX0sTO0bFS/DYOMj0 qs0UkjggcAZJNLJE524XIB5pqbSshtPck8+SQcsT680nmtCjbSVLEA47iun0+50Cw0eQvZPc30gI BlbCx8EZGCM+vOK5WcMzKVAI3ZI9sUa/ExD2nlMTAMwwuRz0qFGZQX3HIB5HFdLGmhJochC3DahI oA3kBE55xjk5H0rnHjYgqgyScfrRo1dhqX9BtoJZria+nWPyojJEGBPmPwAv6559KoSvK85LEkE5 wTTog0ZJYkggYHvSIHIDODnsO9CnpYPMQMWnJJPBx+AqKOK5u7pAgZ9zhVUdyTgCnoGQFmU5IJx3 zSESxqhXOVOcD360mA+aJra6dZAQ0bYKnsR2qSGWe7lALMzOcAE+tRTbjvzkkjg9Sa0LDT7eeNmm vYoNqkgOrEkjoBgHn61MnroO9ivc2slncGKVdjgDK5HGar5IYY6CnSAhySfb601SD378UmL0Hgkn AP1qRzm0ZMZKyBgB+VRjjk0jFjGShwcVKGtNSXRL6K8d9KdW+0mRnjdmAUKBkrg8kk57/hS31tFF cBFUEEdR0JrC1O1mV1vYQUfqQOCD7VrJdtqNpHemIIWyG2rgbhwcYGB68V0qS5UiGnzXHWtxJbWs 0SMRkgMB1IFXtMJV3cAdh681mcCXJGAwwa0tOdEiKs2DkjNCeliWtTVGWYEnOear3ADNtU5PQUv2 iOJWYyDOMDmoMlyoAJZzxz0FTLVWOmjaN5s3dD0C1u3CyMJVJBIQEnHHHI6knFdg+naX4MtfNWAm 5mIITdnbjpn86Zo8Nv4c0UXk23zyAVB7E9PyH61zmq61Nq8UkpyfKYFSMdc962hBKN3sc0puTbZc 1mR9bt5Li9uY0eNQEQck5zwMCsmTRtRn8PiVYpBaJnacHGe5rqtC8Iz6vp6ajf3LBpfmUHkle2T6 Vu6zrGlWfh97NJFIVPLCdCMd8VtTvKSsroTdiH7cnZTn6Uh1EDPFYhnPYmk80k4ya8FUYnd7Rmw2 pNwBj8qYb9ieorKL57mk8zB4NUqUegvas1GuyerfrTDcqcnOazDJ2zikMp6CqVJCdR7ml9qXHAoN 5joay/NJ4Bpd9P2aF7R9DQN2SetMM+eM81T3E8U4Egg1SikJybJjKSeTTtx6Z61HtBOQBTgCDTES jnjPGKniA4z3qFQSOtWoEJxwKT2Gi7CikDC5J9aurGAAAKrwoyAH0qyGOByK5Kl2zojtoIwBGcdK icgDgipGYAHJqF3B4BGMUoptlXSWoAArkj3pSwwMDn3qu86xghuce9VJtQAGBgVryt7EOSXUvSSB Rk9KqS3q4GD0IOKzpb1mOCeD71WMuWIJ61rClrqZyqu1ka81/nGDxVOW6J4BP0rOeUgDJpglBJz6 VtGCT0MnJstmds5JHXpSeacZFVDKQOoP1pBKCcfpVJEt3LySg8Ekn+VShlzh8jI4I7Gs8SKec8jr T9xIzkkDuasVzShl8p8k9eD70skkYO5VCkdgABWdHcBGG4blPBFNlmyME4A4BxQ1cFKw2/YSXEbg HlSD+B/+vXn3i6PPiJ3HRoEOPcDH9K7yYkRxkkEhiCQa4nxao/tW2bnDQkH8Ca0StZEXu2zo/C99 FoPw/kvrjcElvVHAySAVzgfga6NPiZogtiyJdOAOcRgfzNcP4mItvhlocCAYklaRsdzyf61yFs5N uQCRmum6baMmupq+OfEsPiTVYpYIXjjiUqA5GTk56CptIdBpcjvj5YmCgjuSB/Ik1yNycS55zmtd pzFoQIJ5OD+Nc8ldaHdh5qDUmU7wo7OwA6cYqnan5jjoSaWeYtDGCMDBOfXmtOGxSLR4Zm2iSVz5 eerAdee2OPzojorM0rS55XQtpLsuEJyACK9D8RRxT+F/tL8hCNuPVwCP1P6V5xHOFTaYxkHgnrXR Taw974WW1wS0bKH98E4/mB+FYyV73PeoNypq25yl1DtG5SODn6VEjhjjFXJeVI+vFUIXKuRj9KuD 0seVmVPVSJSwABJzn0NBZyQQpIHIPpUDSkNgjvxipEvFBIkBPYYrRHkFmWTz41AA3Bhn863zcSpG jCMbCuCQQT+I7VzVsQXQ7gAzjnHuK6azSS5jCRQuCTySM5AzyOMgYpt2QkrvQiN2ZQVUAkjr6VZt rCWUbmASMEBpHOACTgZJ6Anv0q0YLLS3Mbr9oucEiGMZUNgEFieoIJ6cjHaqeoXUk8he7YIG4S1i 9CchQBk8EnGfzqOZvRFWtuWYinAs495GC0snQdQRgdexBB9aqvcwCdUj3XlyQuM8gEA9ABzgDv2F Vm8+dCZm+z2wOfLBwzAEgg+hBHcVVn1NLZdlsijAGSBgEgY3Z6kkZzjHWhIDQngbY76hdsCqlRHC 2SAVAUk8jbk4IB7Y4rPm1m1gMiWUCQqwKnBJJBxkEkkkZAIz0rn7u9lnkJd+BnAzwPpUEME1wxSN CzEfgKpiNRdQt31COXUWeW3LEukbckYPfI74rf8AEHh6zlW2vtNCQ20sKsYi4DDjIIBJJyCM9eRW JbaJbwRqZx5kxOcchR+HetQRuVCgk4AAHoBwKTi27ofMkhlhbiNVjUcKOT7963oSQoABB6VTtrYo mOhJ5+tXQMEADGK1VjN6l23ABz3q4mRyOKpwEAAn0q0pBHWmhEoOeRyKBknIpM4/AU8ABQfWn6CQ 4cYzRkYJJxjpSZx2oyaEDHhyM44FIWPrQAAOQRSqu4/eCj1P/wBamIjJ5prEkAE8ZzUzIQCx4z0H UGoDkDBHWgFfchfBPSoGOCST0qduhJ7VWckgk9+lGw/MhkOVAIwaz7kjODn6VoSHAAzWfd8dB1pe QlvcyrO6MHiu0TOEkUqR7kHH6gV6xpTl7VATnAI/I/8A1xXh+qTvba7bTKCShVsDvg5xXsuhTh0w OVOGBz0BH/6qllo15IFlXDCsi/22CGWQsIweWAJCj1OOg963Me1MZARggEGkMwoLlHUSxurIwyCp yCPUGtGC9IQKxyB1NMXSraEuYY1QOSSFGAT64FUri0mgyyHI9KdwNG82ywFgeCK4q/0CW/id4lBk Ukr7jriuhgvs5jkJVsY56GtOw2E7cAE8j3oEeKXMbQOyOCCpIYYxUMTqPk/gPI/wrvfHWg+VML6F AI5OJAB0Pr+NefGMpIFPAPIPvTa7BYvR6hJaAMxLBSNpB5FdSfJ1TTluIgqkAAjnJPr0x/8Aqrjw wkQq4BzweK1vDrXdreFIYnmi2ljgZ2jvn2rehVcGtTOpBSRYiYhmhcDI4571n6hpsUhZiVUgZGQO fbNb+o2gdVuYSuTyFB5H1HaqmFubfBGSOD7V61SEa9M4oSdORxM9qkTFWUeoIPUVUMKhgccHrXQ3 1i5lwAQqjHr756e9UZLNljLFGAJwCAOehPFeHODg2megpKSTRmuFUZAH4VLGNwzmnSwFQDg8+1Oh gbdkggelZ6sYzADZOSBjFaFjLsnAP8Q5zU1vpclzGxjXO0ZP+friqsYInTnBAweO4odxqzZtppjS RiVyBACMsGHAJAzjOe9Q3Fsbad4mBBXjJHX3pzXspsGtowSWIJx6Ag/0FW70m60y3u8EOP3T49R0 P4jFTG/UrToN0S3Zp2l4KgZPPQggf1rQLl72RucAhfpVXQ8K0oJIBwQD6k//AFquWiF7uQHGPNIr nmr1Dug+XDNF3UNTV7SOIHAUAYHYYrnrmbZu8obnIAUYJJJ9BU95E3mOecAkfSlsdWt7SKNtubqO Tcj4wQc9SfbjFaNOMbI4003djpLO60WOMXqvHcyqJPLY4KqemR2J64NQBJbg7jnnufSkuL2XV9Zk luXZ3YlmJOc4rSQKFAAHHT0rOUmlZmiV9inHaHOCOPWnGyB7gZ5q4CSOuPQUc4/lWTmxqJb8PjTb G7kfU7J7xCuEQSlApz1OBk8V0LX3hR8htEuFHqt0f6iuUXI4qTkkDk1Sr2VmiuS+pvs/hNyALC/Q A9pwf5inEeET9231FfYSKf6VgFCRkHBqLe0RIYdOQapVU3sJwfQ35R4X8v5IdQ3Y7yL/AIUyGLwv 5YMkeoBs9Ay4/lWF55cAgY70wykcZNPnbIatudF5Hhhjw+oqD/unFILTwtk/vdRx2+Vc/wA65vz8 HAJ96DcAdCaV2Gmx0f2TwwWyLjUB7FFP9aGsvDJHF1qGT/0yX/Gub88nuR6U4SMR9407vcL9DoGs PDrHK316MesKn/2aopbLQRjbe3ZOephXj/x6sZXI6kmh5iOBilzaiN9dM8OkAtqVyTjn/Rx1/wC+ 6jlsdAjjYpqN0xAOALcf/F1zzztkjpURkY9yaFpqNsknCmQhCSvYkYJ/DJpgUDpxTd5HU96Aw6Gh 6u6ES8HjNKBxkVGCMg4z9KeACOtJgyWWJbnTnUj54zuHqR3FP0LY2mahYyyIiREXEZcgEk8ED6jn io4ZDFICMkNwR6g1lXMkkc7xIpAViA3qM9DThvqD2LjqSBgdDxTlyAQc9c1LZQNKmSMnA5PrROjR HJBAJOPet46szexQllzdAg4AGSK2dHuyJopZfmEZBAPQYOQPzrm5nzcSAHkcVp27FIhj0FKafNc0 uuSx2N/rMuqvBaiXLswUDOBknA/nWdrRGiz/AGRX3OAAxVsgt3PFclNcyJOrFiMEEYNalpq9pBc/ aGhSZwuAsuSAfXGeauU3axnFK53Wk/Eaaw0H7DMqs6jEbE8genvXJahqU17cNLI5IY5xmsUym7u2 lwFGcgAYFWMnGM1f1hxhyxVh8quembyOBRvNVvM5zmlD57mvOtqa3J9/fJ60B/QmoQcnGaN3HJpp BdEpfHrQD2qPOR1p4x1709gHgjI7U7gcA0wAkA4xUqgDvmpbSBIcvPanqPXtSAA9CM09R1FTctRH jA4p6DJ6GmhM4wetWYoGYjB5+lJzsUo3dh8UZJAJIq9BFgA4NEVoBgs2PapyyxLyRgetYTq30RtG mluOyVHGfxqKS4VB8xGRWfdaqqEhT2xxWVNfmQ8k04QlLVilOMdEbE2oqAccn61Qk1FjyCRWU8pI JJ+nNQtIScAn8a6Y00jBzbNGS8Y5JYkmq7Tk9TzVQuQeppu8jgEmr5bENll5BnBJPpzSpIC4zVVn JGRxTVkIYEHPNUkS2XHIBJzwTjFRM4A6n8qa0yhiWAPSo2lVzgH26U7IL9CwGOCeoIxmowyjgk5z UG8g4ycGhnUtkDA6etUkSmWFfHII/wAakWQkYJBAqqpGMA/Snocjpz7U1cbsTs4wMcHpUUkz8YGS OAcUpGFznqcH2piuCVQk89OKd7bk2b2Emkd4VPBKsM8dulcz4yTAsZiecsufpg/1rpGQmKQgHCjJ yenNY/i1430q3dlyI5MDA9R/9arvsxdSPUozqnwqtXT5m0+4ZX46Ak/0IrjbPiIgjtXdeCryzvRe aE+5Yr6EgBiCAwHJH16/hXFtbSWF7PaSjDwuUYe4OK1trch9jKugTOQBmtOeMDw4uOu7p+NVGnFt dF/KWQkEYYZH1rSnuWXQTOEUMWyQQCByO1RJaFqTtYxIraSeEl2KiMAAYzkk1e/su+IiVSzxIcgg Hv8A/qqGHWWNjcRlFMjlcOBggA5OK0YvE+owyCO3nZY8Aqm4lVyQcDJPGcflTVtmOU29ipJZXSyE mF8dQQKv6ajIlzFMjAPGcEkgAjp+uPyqV/Geq2TAnyX6El41bp7Ee9LbeMbm7YKbO3Y9MeSOmMZy B9Kn2XNsd1LMJ0klbQzzDIWKhGJ7YBrNZQsrDawOSCCCOK7SXWriIAyaJbsGGQVUgnPPQEH/APWa qT+J7COUJcaNGjEAkBmBwc+5+laPDSgrtaGFfMlX904+QqWIBBPpQbd/3eFJL9Bjk12x1PSXKiTS mO4dElx268g/Wr8GmWtwDqE8ZtrONf3aFgznIJGOBkZBzjpms3ojnWu5i6F4ae4HnTFY4owGeRz8 sYyASeecZHSta4vUQG30xWRFHz3BOWYgEEg44Ug9D+Jpmo6hJf4UgW+nQ5ZY15A4AJHGTnAz/Ksd nN1a7mYwWgyF28M2QQGBxyAQMjP+NSrsq6Ww7e8shhtSoVCBLMQCFySAepyPcDj24qGbVLOwg8iC FZJj96V8M2cDIBI4GRkYGRk1YhB1UGNbiGztkzgOSMk8kAAHqSTjpzUz+B4ZSXTVrRyD/wA9QM84 7gfX6VajoQ3qc8dQSWQmaZSTzgnj/wCvRc3dvIoVZYwCOuelWb/wVOitJ9phKIuSRIpOOe2cnpVO x0mKB9zjew6EjgUcut2CfYSDSxNh2PynnOOv0rWt7eK2UKi4z1Pc04DaucZAFWIUMmCBx2NNKwmw WIsxY8sfXtVyG22gE8nOTUsUAUjI5q0EBGMcVSXUlsiVMckdBTth3E4qYJ2NSeVgDgU9gGx5AFWl IHFQBSDwKlTJ6800K5OCSMA85445pzEZAzwBUW4gggfrTuTz1P60WC4/PHcmnAHOSOlMXBGf/wBV OJwOefwoSDcd9efpUi5AyAQAMnuKhBJIwCSOaczgrjA9M8//AKqfUQSPuwOMDgAVG44yBzQSccGm s3GO/wDKlYEyCUgDFVyDkYNTSHng1ETxyKq4EMnLGs+6yCf8KvOTnPrVG74JANSwOT1baNXXcOAg GfSvTvCV0JLO2bdkmMofcj/9VeZ6mQdUwcH5RkYrsfBNz5UWwkkRyhgCex7foai+ti7dT00HIBBy KCDSR4MYwcgcD8OKdg5oKGEY5xTWQNwQCKkxg4ppAHBH40xGZeaYk3zIArdciq1u8ltIElBAB4Pp W0RzUUkCuu1lGDQAtzbxarYSWsoB3qR9D2NeKatYSWV7NayAh4mIye/pXtUKGErtOdp4+lcf8Q9J VxHq0IAOAkgA6+hpi8zzYSlSGxyOorvPA08B1m2hKDdKGBOeo2k4x+FcBKQkhAzzzXSeBbgt4s00 A8b2B/75NLYPM6PXymja5cWSAeXKAwzyADnisGZDBKJk5jY847Gtj4kceIAQcZhU59CCcVzml6nH cxtbyn5hwQf516+CrRtys469N35kXnQECVADxyMdR6Vn3CQM0eNqkAgrwf5j17//AFqvpm1nCOcx typ9aranZMVMsJxkc47itMVhlNc0dyaNTldnsZbQxFnDMCQBt9+QMfkSamjt4wOACccVms7gnJOR wKkWcr3zXjNcrsztNQ3P2FVKBSWBUjHHIxmq8UajLxhGYckECqFzM8qICQQCfrzXYeDtXstKkM13 EzrtAwoBI4I7ketS9WMi0O0vL3UzDaIWkkhUSAKOAWB49Og5rpG8LXZiuIDCwBXcBjqQRVCa4utJ 1iPW9OR1trsKVHQEA5INelJ4i/trRb6QNbIRbM22NTujJBABPc8UnD3ik1Y8YuoJtMlRJgVcyr19 ADmr9oqrNcHPIZXA9QRg/wAqz9Zlne+RLjIkjBZs9ck8fy/Wp7GdWaGUng/u3z2z0P54rCrFxkpM 7KUuem4LcmvEG+QDofmH0PNcpcWxN6WJIUHpXW3WUyCMleDjuKw7qIo5OOD+PFaJ3Ry2s9SCxITV ASRgqQPx/wD1VvBSCCelcwpf7QrKCGU5B9a6S3mM8QYY6YIPUGuWrF3uawkloyTJJ6ZpQOM45pcA dvypwA7YrBo1TT2E49OtPUkcZoAGOQaQj0P4VO41oO3A8HpTZZU2lSecelN5HP8AOq9wjY3Dp3ql qx37EbSkHAI/KkYkjrxUQyMY65pSTxk/WuhKyOeTd9RxPHXOabnnpSHJPWkOcdaaVyb22H575pd5 zjPaowTjk/SgHHX8aXmIlEh9cUb8k5Pao8Z4zx9aXGRgUadSlqB//VSAYPSlAPAJpQOOPWjoJN3I 3AIGOPWk6HBNKx5wD0poySRjg01a2o3sSKwyACT7VMDyAO9VirA9D+FPLsgBKkk9Bjk0muwK4txO sIBAyw5AqO3gknILgl2OT+NW7Gwa5mLyKWHUg9APf0FdfoWgNfzmUxERRkA54yT0A/KrhG+pMnZW KEVgltYoCTvI3H056D61hahMGcJuyqDA9u9dn40ki0jTSpI85xgc4ryd5Z5SWMzcnnmulQ5UmZ30 EMhN3IeDzmtmNsxgkdgeKwY4ikoJJIPBJ9a3bclrcE9Rwayn8WppFXiUr1SG469jVHYUDEsST0Fa 9zEXTcBkjis0xFpM85HWnq1oTbU0rTAt0IHOMGrWDziq9gR5bRnsamcmI4JPXrWLvctLud8DinZx Rgdjim4OcnJrMoeHPAOaVXJOO1MwcClBIOBQFiZCc4qUcHnFQx8damUjHOazbKSJFGetSgDFRBh6 08OM8GobuWkiUADnipFAJI65qANuPFTJLFDy55+tS7lIuQQFyD2q8Hit1yxAwKwp9ZVBtj4GOtZU +pvICSx/Op9lOe+xTqRjtudLc62kRITBNY9zrEkpIDfrWJJdE5y2c1F5oJJzXRDDxiYyrSehoSXL Ekk5J9Kj88k4JIqoJATkHOadvPUEVso2M7tltpTjJPFJ52RggVW35HB496bnPHWhLUCx5oPSmNKS eSMVHkLjPFMbGcnFAWJ95PU/SgsCeCRUGSBnIp2856VSsK2pOSAeScdaaXPGAKiZyVB/Dim7896X ULFjcDgk9qVSCcEk1XDc+tLk9RVITVtSyrFCM8g1Mkik5yR7VUWQ4wRmlEgDdRmqBGgVBg3g9acZ YQiMIVDqMFhnJ9yM4zVeKXIKk8EZNQtICCASMmlo9GK9noWi6OkqqN2UJzg5GBXOeIgZvDzsByro Tx25Gf1rYtXKzqACd2VIz1zxWdqSF/D15GRkhQfyYH+Qqumgm9TjdHv20zVILteTE4cAd8dvxrq/ HlnGNXh1GBR5N9CJAR0LADP6YNc74dhsZ9dggv8A/VPlRnpuI4z/AJ64r2GbwxYanpVnYzysYrUf u2U/NjGMZ57cVte8US1qeGx6dc6jepBaxl5WyFAIGcDPU8dqtajbT2WiSwXMbJMjYZGHIORXudh4 a03SIibG0USY/wBY4yx/E/0ryXx5HNHc36zsGfcpGBjAIGBUSlZ2Gkjz6MEMCOoPSr8BJlLADPU8 dKqWwXzVycAHPNacaIJAyHIxz7USY4oddYa2bI5xxxVfRZWTVoVYgqx2kEDGSMD9cVcKB4mA78Yr JUtBOGBIZWBB9CD1rbDTSkjKvHmi0d9gAYA7dq5/xDatLLbuilmbMZx6jkfzNbiTK8YZSArKGHrg jNWdNsDqUjXLMEtICGaQgdMgEj15IH4162LqRVGzPHwlKXtrrZDNG0mJLQXuokrDGowoIDSNg4xn qMjBpL/URdhppf3dlGSIokyAeSQB1x1qe+uxftgMI7KDgIDgDnOOvBJJ5rJaRZSL65VVhjJWG3de vAILAjBBBOCO459/A3PebuRXbtOBNdqYoEyEgAIJIyCSM8HOD0wRVNLgXs5echVBJVAMD6/nUbzS Xc7tKDsQAAHnJ7f59qke3zEHUgnocVfJdbk81mWTfwpJsIBAAGRyPpVO7uR9tHlEFSAcDoT0NQ/Z GdgFIHPc8D3q081vNDDGsBSSIcsf4vfNTCm4vcpzTRLAQUZCAc96ekeMKO571FHhTnPUVYQFm2gn J4OD2rW5mh8cQkYADj69a1I4gCMDAwKjt4NoGBj8KvRpkAjtTSE32ECZGMfWpUXPTpTlTJwBxUyo B1NMVyJUyehx1qULkUo9B607GRkdutAehEUz0NOAwcY6U/APHFGMfyosFxAOOmaeAQOeBSDB7U7u BimDYnQdeKXINBOOD+tISR/+qktRD1JGSD0ppOQPU9qTORigcgnJp+oCZJGT60xzxyaccY4xgc1G 3c0eYELnPWoyMA57VI2ckZqOTgYwKNOg7EDDnJGKoXZGMZ71ffhSfyrOujg4HOTSbEjktUbOqPg8 gAD8hXQeErkrfOucbl5Ge4PH9a56+JfXJ1AzkgAY9hV7SpGtdUt2YFfmAOehB4/rWb3NN0e4WL74 AQeoB/MDP65q17Vk6JKXtEz2BH5HP9RWt25pgIRg4zmkxxinHPYU3n1oGMwRwTSbex5p5z+NJngH GaYhFGTz3qpqFouoaddWTgHcpAz2JHB/OrvqRUbRyfaN6Y2kYbPce1AWPA7yMxSOjgBo2KnPUEHB rW+H5LeNLBSRgMx/8cak8Y2v2TxJdqVKiRi4GMZz/wDXpfh8QPHNpngbXI/75NOWwG/8SnJ8RYHX yFGPxNefIXRhKhIcEkEen+FejfEq2DTpeIMlWMT47cAj+v5V54YyigE59Miqu42aJtc6HTtTiv4f JmOHA79QfUVowSmNjBOQVPRuxFcYY2jIljYq454H5Vuafq0dzGIbjCuO57e4r1MNi1JcstzkqUWt UQa1FFDdkRAnP3iOgrMyM5JBFXVuUu52ihTDhiBITwRnqR6+1asnhxFtVaFgzAZJA6muWVGdacpR WhqpxpxSZgKhaMkc85xViG5810gUEuxAAHrRLbS2wKupHbimaayx34mIxsUnp3wa5JwlB+8jeMk9 jYn8SXMmiQ6MwQJbOzKwHzEk8gnrgZ4rsfBVzLB4P16+RgWVVVQwBBI7HPb5hXl0DmWZwGBO48Y5 Hvnpiuk0zWpbTSbnTVXELsZJTnqBtOOnqo/Opvdq49OhW1a9mvtUuLhmQsSASEABIAzgDAHOegpm mT4aSOU/KxwewB7VVTJBLckkk/UnNLGjOxVSB3PPalUSlHUqlOUZpo6QSNKuHP7xQAfcdj+NRPbB o8FTtJ4Pp7VDauQiIWIdeFYjt6H2rWt5lWB9yAkghkJ5B9R7VyQnrY6qtO6547GLBYkXoRYwykkA FsAn0z2qxKbWzkZXM0JPJQASYPfnIz+Vdn4dlu2YWNnE4EgwgQAsWxliMn9TwOKs+I/DupWOl/aL ySUqSAyFQVyfcH+grayluc8exwgLTRGWymWYKCWQjDKB3Iz0+hNNtrwyPsZdknpnINFtaxx3kd1b SGMq2SACVODyDgg4+lSXls0twZ4kQZJP7sbc++CePoDUOmndIfM0y2DkcjFJwTwQapCaWIDeCB7g j+dSLdADDDB+lYuhLc0VVdSwQR1FNYAqQRwaQTxnjOD9adlG6MKz5Gi1NGfIhRumQe9N4IwOtaWx WGDg1ExggBJxx3NaRu9LESs9UU8E9QabggjAOKmkv0QAlCAeMlTj88Uq3aum8Llc9ccfnWqhPsZX RXJwewx7UYByRVkPDMdrAAnpSNaMclSMH1qG2tGirJrRlckZAApc4Gc1P9kYYJIFH2Y45cACnfuB FkH1pMADvzU4hjXq2aC8KDgZNCTeyFdLVlRyRyQST6UsZIGSMZ9qdcuyLu8puRxkEcV13g/wq/ia wmu47iO1jgIVgWO5zjOSTnA/SrUH1BNdDkklLyiNASxOAAO9dBbaA/lrJezQwKckKWDOR7KMnn3x Tdb0SLQNR8oXSTMxAUxMGwScYOAOfau08O+FGeWN7mNw4wSHHI/Dt9TVKMb6kyuhuheGWvtsccRj twQSXAy3ux/kBXcS2dnomlu7BUjiBJ9Scdz3JrRt0tNOgVC8cSgZALYH156n3ry/4j+KPtMv2K2m zCg5weCe5+ldNKm29tEZNrqcB4w1h9Z1Z3ZiUBwo7AdqwIo1d9rMFGOuM0SzCS4diCQeB71GeSee v6U5yuwt0FkUBiAQQOAau2cq52seowaoYOMZ/I809HKENngdaxnG6ujWnKzszZUZyuO35iq95aBA HXgnmrFnKsqZJyQOD61egtorgBnJYlsKvasoysypQaepmRm3CIQWRx1JOQfehrpCSuQwHGQODXWt 4Qujbq7WgQMu5SQTkevSuVu7BIpihwrA44NNxT1YWdju95J4p6knr1qIEDvTwCRmuYpJkh55BNKo IOcZpoOKdv460nfoWl3JB+FO34+tV2kOcCmNKB1PNTZsd0XPM9DzR5yqMs2KznueSAcCq73BOcmq VNvclzSNR7/AwuBVKW7Zjkk1TeU44P61CZCRjNaRppMlzZYeck9aiMpOeTUWSe+c0hYjnFaWtsZt 3JCwxxRv4wKh3+1IHyMZotcZYDjIzn86lBzgZPFVAxAz26VIrkcnk+1GwJljeAPSkDgHg+9VmnA4 J4pnnZOfwqfUd9C4ZuOT+dIZTgHAqsHBPJOKQsScetO1wvpYsNL0INAlPY1XBJOSM04Ec0mguWRJ mPGOhyabuBPsabGTtY+gyKYSScY60WYE+4kEZwKUEnjNQgseM04E9M1SEycFgMAHB4pBkjAB4PNJ GxwFzjHqKVtwPBz/AFppASrIBjBJz+tKzqV4GKhGGIJAGKf5e7ODwOpNPzYtxYpAkisCcgg+1Nug Hsr5ADysgA+oJFKYioGMEEZBHSpTEDcvE3IkUH65GKe6FqtzgdIQP4gsVA6yqfyOf6V9BWICwxgD sK8N0KJTq1icDcsxB46AAivcrQ/uE46AVtH4SZbmkQDHXiHxMiZ9avljUk7Izgdfugn9M17YTlK8 v8RRLL492MMhvLBB7grzUTCO54shbAJzgVctHb5iD1GK19S0ePT9XubcqQqudoPYHkVElvGCcLj3 FZ86aLUXuERBXOMkcmsy5UeezgHA6r3NbMMOxjjkEipBp6Sy7AhZ5GCgDkkmqjOzTQON1Zk/huO6 v1NrCpjjkH7xieSg5I5x2Hrziuo1W7j8pdJ04hYIiS7DOGOMFsdQCADwafc2y+HtMWwgH+lSgGU4 Awf7oGOoORnPIPasKe5a33WlsA08i5d8keWM8n1BHHOSOaqpVlVsm9jOEIw+FEN1OJwYIWItIsl3 BB3MOwOfmGSpI6gVlX0jzxhgdkeQEQDAx7ewqK81JIJI7KIF41bLAk8k4yepwTgA49BV9h9rjV2X ao5APXj+lTZ6Ip7aEQG2CNCMkDJPqac8UtlYpcxzpMm4hoWJyOOvTofY9vpS4BJx3pUU5AHIP61t yqxCb1GW7Ga0EyAgkEEAZ+tJHHkZI5JJ+grQina3Z4YkTEihSSOR9KruACQAcE4z7DijQPIYB3HY 4Ax1960bG3P3iOT1OKgtIGlYEjIArbgiCDAGKEgb0sOSMgYNTonHI4705U4zUoUbTx0pkjQMDPH4 UvHQ8UoHXJ/SjaQeR1osAYyOtOAAHIpM8Ag804ZJwBkntRfoAmAT9aCCOlLkYzg0ZyMmgABA5zSk kjJphzzignHGcUIbsLkHIPNLkY5FMzSE+hxTshdBxIJ4HFKT3HamDOMnrS5z0PA9aAW4Me4GKiJP Wlbp1/rTGJA60B1EJzmoZDmpOe3U1FISTSY0mQPwD0rNuidwBPPatCQ8Gs24GZQOeKHtqCucfdTB NfmbGcMR+mK7PT7CxvdIE6K7XLDgk8KQf/rfrWZbW/h65kl+2SyR3O85IwQTk9sgjj69K2bbTrSC zkSx1WEo5J2yAg9MEdCOfr2NZ2b1RpstTsfDFwXg2nrwSPTI5/XFdKM9jXE+Fy9pcLBLIrkqQWRg Qccg5H0rthzyKq2okwPTJqLeC2ACQO9JdTpa20k7k7Y1LHA5wK4tfHsgkKnSnI3HB83Bx2yNp5/G i3ULncHB5HekAxwKy7PX7G5tUlaYRlhykhwwPTBFTHWNOHBu4/TrmiwrovqMnAFTqMqFHQc1kDxB piKQboH3EbH+QpreJ7JhiCO4mIHSOI8/ninbyC9jN8e6HDq+mG4jCrdQKWBwMsADxx0/xryvwrci y8T2d07AKkgUnPYgg/zr1LUtTu7u2kS30y8bcpALR4HTPXmvPLbwffxSkzqiknOS20569zQ9rAdh 4qiV750mYC2vY1UOTxHIpJVvYc4Psa86uYHtp3imVlkB2kdOc/qK9Dke6l0tLK9WykCrt3vcKScD IOAevv61jz6ZbMgjudStGwMK2WZlAHABA5Hbn09qetkhq3U5y0hV1ZJAWyAAADjj+tQ31qmJDEpD k/KR1Nb62Ok2j7hq5BBJBRSBnA55I70+5bSWhZ5r27mQfxGMAHpjJBPc/wAvWpSdxXRzejXMNnPJ DdIAXOCSP09q6aGSWAeZbOZIzyU6kD+orOnuPCwXC21wzDOCX/LgD6/n7VQTXbe0uAIVdYc4GSSQ Mn1r0sJiVH3JHNWpc3vI6cPZaim11COeDnoay7zw88ZeSAj5h1HIIqyhttRjEsMgRyMgjoaEu72w bDAsmcZAyPyr0ZUqdVa6nKpyg9Dl47C4s55WlQgYGCO9M1C8azt1hiJEshDOR2APA/r+Vdol3Y3o IlUKx4yv9RVO98MWt6fMhdWPqpwenpXBVy/W8TphiekjjP7TuJVXJUP6gYJ/pV7TNUitpybhPM3K V5OMHsatXHhi4tnyg3Y5AIPWsu406cKxaBgwPUdK4KmGmlZo6I1ot3W50Uc6PH5wYBBySTwPrVyC /gvICYZlMicYB5OO+PSuGSO5cCFA7LnO0ZwDXS+EvB2p65qkccK+XErZklYnavGQCR3OOlcU6Fld 6WOylieXTdM2bTUb7TNViuYonkEYBUqT8v0x0rpvE/iSPXbAGJrr7WBiUOwKHjkgAcHkVuS+BLmG 0RoniZ0HLk4GO+ciqUPhS5nVtoimOclIXUg46EgHn8acZuJLabuih4R0fSZdFC6gbtLh3LCSNAyh e3HX16VqT+ClmUHTb+3u89FWQK5H+62P51jyT63pJeKa1uIoQxwJIyU/AEYH4YqSHxMm7E8CsemU OMfgwP6EUuWSdyuS+zK93oGo2LFZbeWMjqHUj9en61lyWrhSWt1YDOSFx+orsrLxXAh2rdXMK9gc kfl8wP4gVdfVbO74YabcOQcF41Vv/HSCfyrSDZnKFtzyW7uTA5BIAPoc4pkMryKGSZVAPJKsc/rj 8hXQa5ZSSXhdLWNxuyQhPAz6NXNXF5JhrZUYBWI4B456Y6VvKF0nYwT1auXpbto1OHjJxwASav8A h6AX2r2kTXixmViJZCAfLX0GRgE+vvUzaJpotFdbkPIVBKCJlIOO5LEflVK3sp7ecPASu3IBGc4r T2E5x92JKqRi/eZ0viLwrpulLcG01RJ2BwylgxOeecDFcZGpJYROUQgqR159PpXQ3T3N7pkNlOqf unZvMCgOc9iRyQOwNUoNNSAks4IJyQT1q44Gq9WE8TT2Rm+RLEFKgSAHgZwR7g+lTfabngCE/i1a TQwDOHAxz1qP/RwcFwR1rdYCb+Kxi8SlsigZrog8IuPXJpFMzfediewRcfzzV4y2oPUE0nn2wPUD 3p/2f5oPrHkRpZyk5+zuw7GR8D+laNppV7PtEXloD08qMk/nj+Zqj9ogI+9096mTUGClUncKeCAx waTy+VtJIPrOuxtTeF1MJE90fOAyQXDN9MAn+dYem63d+HL8wKcQh8lXHDAdMirFtq9xbKVhunQH kgHrVO6C3jF5GUsTnJFR9Qmuty1iYou39+3ifU1mt4BCu8A+UhC7uwGehNelN4si8M2LafcW6C8j UAeW4KAkcEnnJrznQtUbQfNeCKFpZEKrI6hioPXAPAPvis68eW7lMruxJOTnnNTHBzTcpIqWIg0i 9qnie/1G7eZ7l2JPBzgfhXN6jqQDhZZCNx5bqcVZlgcDK9fesC706+nlLFAQDxg8YpShVStayCM4 N3uXlFnKAUu0BHTOR/OlaFQQFljb6MKxG0+7QEGJs+3OKia3ukJBjcfga5nTmt0aqUDeMTjkISPU DIpjo205BB5rB33EfBLgj0JFSLe3SjAkf2yc1Li1uO8ehv2MhRQrHGTxn1rRS9ngVXTJ2nGe4+lc 1pplv9Tt7d2wJHClsdAT1r1+38FQfYVWF2aQAHc3Q1hJWldm3tU48pZtviI99ZCGS4e38qEKu1Ac kADk++K88u3mu9VaRiSCSS3qM11sHhl5Ll0MSl1OCAcc+tU9b0C40SMSlVKuc5HOPaqbTVluJdjX BB6c04OR3qvuwetKrmuZoZY3kjg0BsdahL4GCRimPKACM0krjvYmeUAEZHFVpJic81C8uT14NQs5 ycE/nVxjYhyZI0x9aYZST65qIsT0yBTc471aVibtku49xzTc5xx+FNBHrmgEYznmmAo3E9DilyT3 IpA2ADnPNAc56ij0AUg4JNIAOuKkDZHIBpNxHBXj6Un2BIidzjANOVyRjPSkDqp5XOeKYzhHOF4P IpW0DoDEBhkdKVDkE4wBUZYs3Iye1SICOCBQkrDTHh16HtS7wR1x6VGQAcEU0kgcjin6gThsd6eG UgcnNVwwJGATUyqTzkAUCJYjlsEdRimkDOT9KSMkOASeKVuCSD3o8xjl4POafgYBB5xUAYg5B608 SEcE8fSmkF7EiNg5PUVZJDYwB06VVQliQRin7ihxjIqgJCQByMEVbtJoUJS4i8yNhggHBB7EHtzz VIyBlwcce1IrkMNpHAo33EX5mgUBYQ20d3OTUF9cR2lxA88qIGiBBY4HBqJSWHIyQfWsnxhG72Vi 4bADMP0GP60JWQr3epn6XdxrqMFypBHnknsACcfyr260lD2qMOhANeEW1tFBbI7yhe4A5Oa9p8Pz rc6TBKpBDIDn14raPwkyN5XJT8K831oH/hYkRB5Ji/Ra9EQ/Jj8K4DWUP/CfwkDjMX8jUvcEcz4z 0qcau96kTGIoCxHY8jJ9uP0rl1xkZr2HVI1E22UBo5UKkHnPf/GvIdSRbS8uYwTiNyB9M8VzuNn5 G0Ly0RBNepaAEgs54AH86m0zxDNaaiLoW8UhUEKGzhcgjI98GsJ9zuXckk9vQelTWrIrszkBVBOM 9faqWmx208PH7R151xJ2mu7iQmcDcEcjJJ6Hnryecc1h6jfmxtZZW2Ge6AYAHO0EkhQck45GQehA 9KwpbmR5jKWIOcj2pbmWXU7kPKS8hIAOep7k/U1at1OWvBRfu7EukWUt9eBicFmBZz0GT3PYV1Rt 3WDcQNoJUAHIIHXHtSWFmtlaxwQrumbAOOrMeKt3Lr5/kx4McQCAjuR1P4kk/jTi+ZmEtEU4LOaC 0mvVSGeNDho3YgjIOCACCcdTg+mRiq1lcrcFiFKsDjGc1adGVyASAfSkEgspY5IUUODk5HB+ta2t qZXvoEKkNNMwIMYwoPdjwP6n8KEjLkLjOKtXbOYIQ6qrykzNj34X9AT+NT2VvyGIOTQhu6JrSARo OOavqoPaiOPGAR0qQAjng00rC3HAADg8Yp2B2ORTe4zxx60pPTFG4h+3Jz+PFLkAlSCB2J5xSDJH JyKCQCOnFIew3GDgg0Yz2pWIIwDgjpURcg4NPqGxKAAcmgtgYFQ+ac9aN3rRbXULkhPvSde1MJyB zSg9vyppAO6dcflSEdx0pN4AoyRjnrQIewAA5zx27U3kjPY8ZzSZ44NBPYHrQA1vQ8/hTCePennG OvSmEDPWgBrEAZ7VAx4OanbpgVXc8H2oGQyEjrzxWTNKBcA5GF5OenFakp+U57CsC9cLDO+eiMf0 pAt9DipJGluHYgncxJx9c1oWsLod6u3GOAfWqEaAiRyRgDoTyc+laNiXlkSJAWLAAADJNZtu+hqt Vqdt4NvWS72yMTskVjk5OCcH+VetRliozgfQ15NpeiXVgRdyMD5hPmKP4ckEY/Hj8a9SsJTNZRSZ zuUH8SBn9c07E6Cahatd2UkCyGNmGA47HOR+FcsNI8QpOY91i0ZJO8qOec8gqTn8a7M4ppB7AU7s GjnBo2pFQBdWgJHa1U989cUo8PamQANQgXAx8tsvHOf6108cZyMgZ/lT3ZYlIJ5xQmxHLjQL6EZO rsuDn5ItvTPfPvWNqoayO1tWunYjpuAAA79OmK2fEOvxWEexSGmbhUB5J9fpXmGv6rKCIi5NxIQ0 jA9B2A9Kd2tbhYo6zrGs210ykzpEDhWkBywHfJrHfXdSYEG6cZ9OK7jQN17ZgSatA0h+9bzJuUrn uex4/CoNd8IedqYeCzWC0YA+ZEcgnAzxkjOc4wBU876jSRw/9o3kjBWuZME4yWPStG1e9tJSwuAC DghlD/oQRSXOjRJMREz7QcfNgE0+6SWIx4ic7lGCRgEgDv36ilza7j5XYkurl7uUSTbS6rgbECjH PYADvST3ks4DTzvJjpvYnH51ALa6ZCzFE6cFuevoKaLTAJkbOPyqrti5bbiNPECMEHmkMkDgggHt 0PFKwijj3BCAMDIFQyXYQ4WMjuDjFK4iWC7lsJN0Dkr3U9K6jTPEUN2gjmHPQg9R+NcS91KzZHAP tWpp0AexZyMMzHn6V10MXOl5oynRjPU7F9Otbtd0Em1uuAcHNU3t9SsmzGfMUdjwfzrnG1C70sqQ xdCcAE1uaZ4pa5IRkZiByCMgfjXq08XTmt7M5JUZR03LkevzxYW5iYDuHXI/MVZj1TTrkEPEuc87 T0/ClF/Y3BIliAPfBpr2WmT8qVBPqK2XveZnturErQabNgqQCfUV1ngNBa6tJFDL+6ZCxQHgngAk euK40aVAPuTkfRjXW+AbB4tZklLllEYA/E//AFq5MZCKpNtG+Hbc7HqtxEX02ZFGWZCB9SMVzfg/ RbjTtSmaaFQCpw+BnORxwTWrrmomw0iWZWCsMBSRnBJHbvUHhTUri/t5riaUPlsAgED3xya+eeiR 6VtB3jdwmiSoDgyAqPx4/rXjxskBIJX8TXefEy9llNvaQtggbmP16V5qbS6JyZwPwr2sFQi4c0lc 4a9RqVkzVSKKNQTNCv4AmmtPbIMtcsSOgUVm/wBnsR+8uf1pPsVog3NNuPpk13xowT0RzupNqzZc fULJc5Lt65NV/wCz7W7Rr9LiNArZ8tickgA89uegqBzZRcjB4rE1bUFimUQEhdvQHvmssTCKhcuk 22b8msuq4SDAHAwmazrnxJOgIMUo/wCAkCrVvq9oYlDKpOOfm6VYNxZTDhRz2PNaQ96K5XYzejd0 c+2vXkpwkLkkdzUtteXsr4eFm77QDx+IrSktrZjlcAjuKbAwhlwSBk4B7GuXERxEU3F6G1OVNu1t RqrdPx9hwD6kn+tO2XIYj7HGCBzwSR+bVtK7EDco6dqa8CMQ5Qbs9QK8h16n2pHYox6I5+SW55Qx FT/sxKOPrgmqk0QQ5fzM9ep/pXVlFcZZccccVSuo4grAKCT3IqFiZ3s2aezi1dHNqYiwUNIPTk1M luzZCNIAOvNUNWZoJ0MZ2kHIINb2kwyz2pkLAkgEjaP8RWjr1OjI5I7WM64LWq7nmdQTgZGarf2q q5xOD/wE1Hrt201x9nCgbTjPc1BbaRJLHliVIOQCMgirjiai3ZLpwfQsHxAUPALD8qmTxGpILKwH 51nzaJcggquQfQ1n3VtJbOEcEEc4raONqozdCDdjqE8QQEAMxGfapk1i3J4defeuKUOSAoJ+lW4r K6cgrG3PTIxWix81urk/Vo9DrhqMDjGVOfcVJ9ogbAIGa5j+yrmOIyPkADOBSwxOVBJwB3zVrHJ7 xJeHtszpyLVyQyjnjFR/ZLNz91fxArDQAEhpmBxgYJrX0mGG4GJZmDhiCAe3GP61f1im1rEj2ck1 Zl2ysLaO8ikRQGDAjHrmvbdNQLaxnGSVGRXjmmQQwalGJpCUDAgk4BI9a9JtvEVlAu1p0wo5GRXn 4upCbXIjqowlH4mPnBh18smQGxkVZ8UWYu9AkyBuUAgmuWg1M32uG6EmIdxPXgitrxPr8FpoEgLj LjAGetc0V7xs1Z6HMb8dDml3gDmqplGcCmmQkYzzWCRV+pZeTjHJFRGQFT1yB3qEyEDGc0wueR7d DVKJLdxS56E0Kdx61DuIPJzmhXIbPUd6sCYg9Bmm5A5JpjSjJwMCmCTJJORilYVyTeRwDgUbzgAg UwkEZz36UuQTkgUeox+7jkZoBXPIIPtTcA8g49s05AQck8UbBuPB9CaHYgYOaa2RjBphJyCTmgYE knqaMMTyx/GnDbjPNLkHoKLaCEVSDkEHFLhiemfpRgdzinBT0DA8etLyHqDAjkA9M81GDySRn61K QwXHX6Uzac9DRZ3F5jkAycA4PpUqkZ9KYoIFPA5wB+lCXQY8bSQMAn1FPkiAJDEgj0qJAQ5IH5ip +GUHjIp2Ah2cZUg49aCCCDT8EcgEfhTQhLYzn+lACKxDZHWpkkGCGGVNOEBbFSiBR1BwaaYEbKpX IUgY7VEEYkYUnHtVqQlGAQYXGMHvTVDSMQABgc4NMTsIoMXBQg+mai1W1m1WyhgjAaRZAVBIGRyD yfanO6I+wkhx1zn8qmhlCSYIIwO9Ja6A1oZcXgy6aMfavtAJBYxxxZ2jPdjwPXoa9A8JmODT1tEl 8wwDaSf0rEtdRlEE0SsuMHIc9u+PU1P4SnI1O6Q9GAP6kVrFvYho7hTwRXDauf8AivrYAd4j+ZIr tweQR3rhtXOPiBaZHXysfmaLagbevQhLR5wCTECwA6nA6flmvDb+Zru5mlIYmRyxAGSMnIFfQ95A ssDKc4IIP0rwLXLGXS9ZubYABAxKjHY8g5+lZ8kpSstTow84Qd56GMIpZWwkbMAccAnFRXDptSNU Cuv3jk/Mfoen4Vr6fqF9ot0Lu0cIwPOVBBHoQRgiszUJxd3ZmCKjuMuEHGfXHaiUXF2asegqqlG6 d0UnAIxk/j2pYZGiYMpIYHIIodQykg8A447mkjRmIAGSaqKODESvKyOy0C4lktpb2YH9yAqEDq54 H5DJ/CprZpY2llltPPgUEEqSCueh4P4c5HNOSJbTSrS0QdFMkhAxljxj3wAPzNENzNCrojlRIMMA cAjPQ+1Uo9jlctRsdzbXd0YrZmYAgLvGCe3IycfTJ+tP+zG4vViLKoLBd54A5wST6U7TrKG2klvQ CGUZA9STgAfic/hWlIIwrmOIxllCgZ6DufqarV6Cdtyht+130kq58vdhAeyjhR+QFa0UQUAAEAVH awBFAAxVwLjvimlYLihRgnvilJA4x/8AXprHAIzzTC5xgGnuK9h5Kjvn0pu/BqMsetMJ70JaiJvN NBkPJJqDNLn1PX0p+Q/Ml388dKQtkZOePao92DwaTJ6c9KBDgemKdnHXtUZP6UZJOfSjcB+Se9Lu 5xUYNAJPegfkSggjGcUuQACTzUYPWlBoESEgHP8ASjJJzk4NNzwKXqCTkD60X0ACeCDxTD1yT1pS SKQ8Dmgeoxz6GoW5Iz35qQkZIqFjlifQUmBWuWwrEdSOlc3qrFbSUZOWAGPqa3718LjPJ61zuoky 7UAyWbAx3qZPQaWpz0NlNPKsMKMzucAAda9O8L+FEsIxNOoa4YDJI+6PQVN4W8PJbW6TOuZm5JI6 D0FdnFCsKDIGB0FKKvqxyfRFK4s1OnzADnYdo9SBkfrUnhu4Els0eSSmMZ6YySMfmaS8vEgjLMQA BnnpVTwxOBJJEBgEBhnrgZH9RVy0CJ1PJ6VIkeMEjJPanRpggkc54p7ERKSTyetSMRiI1Jzz3Ncv 4j8QxabbtghpCCFUHkmpPEXiCLTbdiWBc8KoPJNeZtJc6zfmaZiVzkk9AKNFuCQ25v3EU2rXrZY5 Eak9T2AHpXFTX8ss7SSkMWJJNaniO+N9ceXBn7NDlV/2iOCa59gQcE80XA0RdwxqHjZt4OQOhB+t dL4X8Q309+tq0xEW0kBzk5HTHvn+tcR3z6DmnpI8UgdGKsOQQcEUtxp2PVr/AMS6St4trq9urkjJ kVQCp98dfoRUkehWGpx+bo97E4IJMbttJP1GR+GBXk9xcy3Mplmcu5wCT1OKfb3s9rIHgmeNhxlG IP5ip5UCk0d1e6Mun3zLdQCFto3EDGVPfKhgB7kCsu60Se7Aa2uQ8ajlioI/EqCPzxVFPFuokobh o7gqMAyrkn0yRgnH/wCvNXLfxNaM2+ex2uRy8bAnPqAQSPwP40Wa2He+5XjstRtFKvE8kajB2ESL j3xnH6GqT2xlQSIuFOQRg8H0z05966eDXdLlORK6HH3ZlJJ+jZJH5iryHTr2Ngs0cm5gSA4JyDwe cH06EfSldrcOVdDz+RDE21hg9a29LIbT8Z6Eg1p3fhi3njaSFnVwSTjJAHoQRjsedx+lVbawawid GkVwTnABBA96rm7CsytNZPetHGpABbknsK6Cxs7exgEUCgf3m6kn3NZiuqElc4zgUl3qf2WEsTye g9TSvqJJdTWneyhQtMiYHJPT9a5291m2RitqXJ6Ag4A/xrBu76e8kLSuSOwzxUKnnBNaxqShsyXF PodFb63KVBe42kHGCM8e1evfD2/sxpguWmALsQS5AJI4x/n1rwRQcgj9alEroAFYgD3oqVZ1I8sp aBGMYu6Wp9BeNvEtkBaaes4Z3beyoQSR0A79STXR+FwtrokCthZGy7LnkEnPNfLJuZQ4cOwdTkEH kH1zWpaeLtbtNyxajOAylSC5PHtnOPwrFwTtZ7Gl0dl498a+b4mukhAeOI+WCG4OODXHSeKbljhV UfUk1ju7TyM8pJJJJJPU0gjUEYXOa7I4qcEox2MZUoyd2a39u30wBBUA8cD/ABNNa9vnBLTkDvio jbPbQRsylQwJGRjIpVIIwe9S8TUf2h+zguhKEZwC8rsSO5OKDbI3XIz3BojJBwRkEUk8yQnLNz2H ekqzfxaj5V0HrbIAAVB9z1pREUICMyn1DGsp76UMSrEDPAPNaFkZ7pA28DnHStVXittCHTbNCK6u UIBcMO+ev51aW7DjDDBHaqq2U5OAynjrg1o2mju21ncAHk4HP603j3FW3RKw6bubem3Hm2qE5JBx mtBiMYAqraQJBGEQYUVYYEnrwB0rypy5m2dkY2ViF24NZ9y3ykYq9NgAmsy4bsDUJ3Zpaysc1q8s qXC7Iw4PGSM81Ui1u9tQUX5QeCAK2HKNKcgEg1Gunwk7jHkk55PSulWtqYN6lK3lN5kqUM+c4dTz +NWo7zUF+XykXHGSOP51fhskRSVAB7gDrU4gQHBH500S9dSrBNdPjzdmMc4BpJtOju5fNkTcegz0 q75sMQyzKAOtVptcsohtVwSOwGaLtjsTW+lxIAVjUYPoKupaIDknBrnZfFCqSI4yc9ycVSm8RXT5 2MFB9B0osxaHZ3CW5tnRgPmGMk964yUiKZoiQcHgg1Rk1C5mJ3SsQffioC5HOTmmm0DSNYKSQASQ fSp4/NgPmJkE9fescXswHDEAdMVM08ssSbnJyKvnZKijYfU3ICsVJHQk8ioo7q6nnKQkHAJPPpWQ IXY5AJJrW0iI2+oQhxwxIP4jFZt6lptFQ6jdwzHEzqwPGCRiprnWbu8UCeZ3CjABPSodYh8rUJBj GTnFUVzimnZg2z1soobaRg49Kd5S4yRk1MJlwNyKSOhxzTWcEHiuXXoaWITCh7UeRGeCCacXAPHF KJF9BRdgrDfsiAZAAI7Z5ppto8ZANWBcRkYKAkDg81E0qk4zRd3CyGG2ix90g+uaDaxYBA5qVp9y hSFGO4HJpA4yCeaq7ErELWqgEggkdQDzUflIeMYq8XhOW8sbyMZycflVckckGhthZES26HqSKk+z qMYJ96UEg5BHFPVwCMgHvQmwsiIxoxO1gSOo7ikMAxkYyKtb4QCywgSEYLAnH5VCzAAnNDuCRCsQ Ge9PWIHGSeaRXB6mpEYEjB96E3sFlcebdAoYspyeQDyPqKj8pTkY4qyBD94K2/GCc8D8KjY84GaL hZEflAAgE8+9N8oA5zU6kdDSbVJBLYGaau2OwJEACBg464PIpoQKRjNTiK3WUyqzhiPuk/Ln1o2A qSCD702yUr7kaMDwRmngAsMLj0pMADkH8KElCMCADjsaEx27ErxMFJx06jPQVXYhSCARnrVtWgMh kJYEj7vGAfrVa4YEHYTjuKbAQS4PPGewqU3YI2KAO+Tyao5IGTjPpTd5I64PpRcReM2RgkDJ9eaT zdjblwB25qnvJUH04pWcgDJ68ULQGaUt3BcBC9sjSKMBxkE+mcHBx7iq6uzNkDAPaqhc9u1SRuWI J6A9aa7g2ytF4j0qGSVLi4ZGQkECNjgg47Cus8IxG4v3u1DCJkG0kYyDyDXkuooE1e7Q9yTz74Oa 9k8H6tFd6BayKVDxoI3A7EDrWsUmrkO+x1eSgwefQ1w+tMB8QbAjoRFznj7xrrp71Ej3Fh0rz7Wb 1T41s5iRhRHk56AMTT6iSPTpcGM5PavG/HCxTeIWxghUG7r7+ldvrPi+z061YvKDIR8qA8k/579K 8rvL25uLtrq6VkeclwHHBHQEH04x6HFdWEg5VOboc+KnaFjMvywACnOOuT29Ce9ZLSgTI6gjJKsP Y9av6hOYoSMYLnA5zgd6oQRKyCSU4Q5Oe5xj/EVeOUVtuPATklZ7Fl7cx2wxzzx7k9TUthGRKGKB gCOD0PtUzSxXMASIgkY47gVPEgSPKgAAYB75rzYNnbUST0dzoLbU7e6UQsmwAkiNj8o/3WPT6H86 maxPmfuyWHUqRhgOvI/rWExW2tt7qDnoCOpqSy1e5triOJyZUIBAJO5SeRg9R246e1aXfUzsmdJ5 Qjht1ZcDPnN744UfoT+IpsTieclmGR/D6VSv7+aHT/OlK75CQgJ5IBwCR6f4VhW+qSCcM7YcHAcf yIpxaIad7M7lVwBSmQdAOnvVKy1K2ubZQ84W5JI2EAAjAwQc/Xj6c+lk5zyDxVW7i1Akk8AU0nAz QTg4pvXrT2EGfY0hPNLzimkc/SkxoMknrRn3ppOD06Uc54zxQG44HApc0zkcZpc9waEA7PftRnJp oINKSe+KPUGLwaOR3pM54zRn3oAUHqe1Lk+tMJPegEjHP50IPIlU9iafvG3AAA+tRZ55NOyDyDig B3U89O5pjZINOPQAUxiD07daHoCI2wBn0qFiBnk81K2cEEYquzYoApX7AcAjp3rNs7f7Xq0CYyAw NWL+XDHvipvB7pdasXGCIyQfr2qJPsVHuem2kCW1qgIHAFVr2+SCNmdgABzk0y/1GO2hZ3YKqjJJ PAFc5p/2vxDqHnBStkhO3I5Y+v09KpNJXBWb1L1vbTavOGcMIwflU/zPv6DtWhb2L6ZrCuQQjjGT 06ev1ANdDp2nLAiqoAA6mr1xHEyBXVWAOQCM1Cu9WU30Qm9UjDZySM1zuv6/DptszMwLnhVB5Jqf V9XS0hbBy2OAK89vWl1GZnmO4seB2A9BTuCRjXl1c6vfl3JJY8egFSavKNMsFsYDi4mH7wjqq/4m tKCCDSbSW6l+8mSAecjsPzrj57t7y4lupiS0hzj0HYUlrqwfYgaJF+XJwOnNUprUMCVGD05qd3Dt k5A7mkLgHA6H86YjLdNpIIx9KYQPWtJoldTkg1nOAGPoDQAzHcmgYJ96Q4OcdKcCQQR2/GgBeCeD 0pwOOvSmZyeOD1pRxwT75pASZIxxT0kYHhj6/jUOTnPalJ4yRzTAux6jdxcJcSKAc4DHGfpVo6xf yRgTymSMnjceh9eOlZqsCADirDh5QEjGY1HGBj8T70BctJqkSghiQR2xmkh1C2llJuoGeMjCgEA5 9apeRLIMqjMFwOBwM9KX7LKspiMLiQcFdpJH4UmkO5Wl2h2C5xk4z6UxTg+9TzxshBZWAI4yCM1D /EB2Pt0oETqQeOOlSBCcAimQhSwAyR06VqQWwcAk8DpmgEZjxkZJHWq/OcAHNdHc2KiAFRnA61hS RFWIxSTGT2dnLeMViC8DLFmACj1JNaSR2OlfvJ2W4uByqj7oPr7/AMqxY5HjYhWK54yDikwSSScn 3NOz6i0Ls+pzXkxedsgnjPJFIhydw6H8qpbSSQKPLYAkE468HimHmaL3YijKoQ0h4GOcVnlGckkk sTyKWEKjHIySMc54oiYiXdgkZz9aQXL0Gmh0DMAB39/atWxgEOEC4AJ4NS2wiaLMSsrgZ+Yggj6i pbVSWJIyST+FT0GkW0XLDHX1Fa0CkBBntWfGuAD6/nV+33MQQcY9utZTZpHsaCDGBilZxzyOKahJ ORg0OQetZO5qtitOecmsq6ONxNalwcA/zrI1AhLaRvQGnFXaFJ6HODVUjncPHnBPINXF120WIAK5 f3FYiorh2YAknqaWKySQklwuMHB7112Od9zRfxCQSI0OPU006jcygEMRkdqyRGplCgdTjNdDHEiK AFAOB2pNAmZzec4JYMQMkk1juxMh56E10l0Slu5A6A5rmSRk5PemkDYZJIJOaeOCQelRAcmpASMk YoEOXOeeM08njrTV6ZPagk9MdKAQmSMitqxlhWJUmiDp3IODj2NY2CSB6mtS2iJUAnmkxmv/AGcv 2c3Fq+9CchD1H1qvCQbiMMCrqwJyOlMt55rOTchJPsa3IXsdbh8uVVgugDtZRgMfeolJx1KjFM5v VXa5unkBzz29KzwDnB/Gtq906awneOZCOeGzkH6etUPKYNwMjsapSTV0Jpp6npAnycZ/SnmU4yDm qiMc44BqXAIyDzisRpvqDzYJwQaYLgFsE4HrUT53c8CotwGQTzTS0E9yz5q7mG8YA646037QM9Tx 1qucEcfnSHB4J6mnZdAuWxcDB5o+0qM81T5wSKYWJOMYxQkF9C+LntnrTvPAzkjI9DVIHIGeB2NS 7AVABGPWhpIaZaEucHPX3qRZQRjOT9apLkHGM4qdBgZORjmloMn8wAZJFRsxKk5wKhYlmwM4FKT8 vWhtiTEyS2AfxqSMkclhnPSq5BB471LEMnjrQmUWwzADAOPXNOVyTjnHeowSBgfrSgnOSAc9qBFj eCcAiot4L4BGOlNJwDkY+lQOCTzwM5zQnqBc3gkAdqnyAMY/KqK4IBXIPcmpxyBgk+vNU2mCY5zt IGDg05CCSSOMd6jP3zlsijexOcAKOAKBainGeQAeuajLHJAzjtxTC5Y9cYPAqUHgUbjK7hjkjr3q PDZIOeau4UcnjIzUG4A52mlbUCMEjg9KlKDAOAR15PFREkSZwCPTNSBiRjABPPsKaVxWIXOXJAwK sRnGcE4OBipIrbfG0gUkrycDioyihSyk9TznINCdtGFupCvh7T7/AFR7u5ulDhMG3IKgnsdw7eo4 PFX7rULbwxZyS2VrAEAG6OFmIIzyST364rOmkIvVdQACgz9Qf/r03WUNzpEwwSSpJ/KrT5VoS1cq XvxDuJ1KWkGAR1kOcfl1rFa7vLlZprqVjIyggjgqOcAelZOlwGWckj5V5Of5VryMC8gB/g6dPWrb uroS8hRArEMW5I53dSar3bvGojJJjHIGcgepHpViMhmAkJC4xn0qC/KCHYDkg5B9RVQqSg00yZxj JWaMW6ZnYAnJHf2p1jbPeSCJCcHgY7ntTZwXlKRKX4AJ7e/H1PWtnT7UW9nuIweBkdjV1p8zJpRs hbXT1t2dSQxXO5xzwPSrMMReVUHCjk1JbqRCXIJz1+gqxZW7mJ2DBA2SZCMhF7k/0HckVjaxqQyw x3LvLKD9jthhuv7xuyg/qT2HuRVa0d1uzdAgEZI465BHA/Gpbq7WcCC2XZbRjCg9cdyfUk9f/wBV Sw20qWkk4iJUAAccKCcAk9sk4/Gok+hUV1KNzJJdMGZuQMYPT6VSZSDgggjvmraElpC4IKjoRggn pTfI81QdwGDxVRa6EyTvdjYpygCnJA9/5V0Ona0FVYrklk7OeSPr61zrQsi5HzZ9KYHZTkEgjtVp ktJnoEUiSqJI3VlI4IOc0v8AT2ri7PU5bZwY32+oPQ13nh6zm8SW072igSW8fmSK7YyP9n1/GrSv qS1YrkD1ppJxUjAoxUg57g0zk/hSaAbgdDRx0zxSgY6c0Yz/AProBaCd8Dmk5zjFKQB3pODznFCB sB1I/SnfhSEjkjp+dJnHQ0BsOPHPHrQeOabuPTFLkEEAD8qQBgHoBSAEH1PTilwcAjIoOeBg4NMP MM4//VT1IHNR9TjHFOUkc56UwuPyTn2pjEY60E+1NJ657+9L1EMc4BxnOKqStgEk4wKnlfAJrOvJ dkBOck8CkNIx9SkZ0kEZAYgkfWqnhHVxo2os8yny5Btf2PY/gf51n3N451VQMlUIBGevrXc2/hex 1/VIb2wRorF0UyRscneOCM4HBIz+NQ27+RpZJFuyguvFt6JGDx6crZAIIMhB7+1ekaZpkdtCsaKF VQAAB0pNL0yKzt0ijQKFAAAHStTIiUZ/Kq3JFYrEuBwBXPa7rsGmWrSyOAQOB3J9BT9d1uDTLR5p pAAoOBnkn0Fef2wuPEOofb7wEQqf3UR6Y9TRaw0a9s9zrNixnQR3DuXiH95cDCn0PUjsc464rJml +zEiQhSpwVPBFdOsSpHggEYwQRXE+Lru30+JmUl7mXhd7Z2+/PpU2bGmZ+peJbVWe2VTM5yCAPlH 1Jrl5ZhvOBgnkAHgVRictIzMeepPepUBdsk/jT8hEqIWyS35UZCnBNSoDjgcCo2jJJJI/GgBSwK4 UAk96pyREHOMd+lWkCggHjNOKBuBzn1FAGU49BTc9wOat3EBXJA471VIAPoRQAcd/wBKcCB61HkD pSgk96AHg+hz9aQnnJzmk5PPelOTwcZNAChiDwcGr1vdGOIqFHPc9azwTnjNThs4AGOOgpAaFoXm n25LBRkDrkcDgfjn8K27GIqZhEZkgJwFZiCR6nGAfTOBWZoESy35Dc4H9etdZLbgghBgMNp56D1F Jt3sNWMXVNKils3aKPbKgDDkncB17kVyJHJyfrXoscDBi0hJABAyeoPHQcVxes2Js791UfIx3L9D TTvoDRQjchhjPWug0h1adAxGCeM1zmcHvV21uWiYMDyDmiwj0B9M3WpIXII4xXG6lbGCcgqQc1vW niR3gETHOBjk1V1RoruEyZywHGO9K1ndFaW8zl5ADyO1auj2DahG/lDMsYyQDyR6isyUYOMYHSpN OvZbC6WSJ2VhxkHFDu9iVvqaj2SxAhy6BD3BwDn61T8pY5UDysICRuKcnHcgcc+xrbl1xLq2SG5h RyAckjBz6kjGT16006VYagCbG9VHOAI58KScc4PTAPqRS5rLUrlvsYFxOHZVXBVRgHABx7/lUQID 5P6VpXuiXllhpYHCMMq2Mhh6g9CKzwpDAFcEHBp3VroVnezNaymlkjjhiRjIxCggZJrXtU25BPPf PrXXWdpZWWhLNHBGky2+S4UAk7eecZrlIgTzwATxWManNc05bFyIgkY4Aq5bbZWywwM8eoqrbply CMgDP1q7bqFH3cHsal6lIuKAigAYqMlskse9S/w568VESMHPGTms3YtaEEuACawtalK2UgBGSMVt TkDpnrXNa+4EAUHGTitaa1Im9DCgC7BvJUHuBk1cZYEiLRks3fIxx1qnjCrn0+lTSOq2jEDBAwT6 5rpRg0VrGMTXsSM4UMwyxBIA9eK6BxtYgENjv2NYOnLuugfQE1tO2V4OKl3uMpahKRbuOgPH1rni Oc9K2r991ucDvWKSaadwegL65p4J7ZxTFp3UdQKBEqnjrTSeelKvTA4oII46ijcB8I3yovqRXSQ2 0KKD5wJPJAXp7VztspM6kDOOfpW1FCSoO4gHsDUvcfqXJ54YoiEABIwSeSfp6VnASq3mLkHOQRVr 7MhYFskj1NT4G3GBg9qLBe2xdstZiuYhaaim9OQrHqvHXNQXukG0xNEwktmIw49fQ1nSwhjleB7V c0/VZbKQLIBJCRhkfkEfSspRcXeJrGSejOi3E4I4NTxvkgE8d6p7ivOOKlVsYwetFrGZPKAVJHJ7 VUIOcAVYySvPWo2UY96E9B2TIM4OCTx2p+MjODSsqjnGcU0BiOnFUmuorDQRkgk47YoKk5PcGpFU E4Byaeqg8Zwe9LYLEIXI5JHrmngEAEEHH609kAU4PSogxDHAyKLjsTqQTnJx71LuJBANVlYk4Xj2 qeMHPJ60rAkOOFGSMU3zAVwABj2pZgSMAcd6hJwMcdKNxjw2BgYqSEnd046VXAOQcGpoyRyAaWgX 6FvOGxTgR2xmovNYEe9AcE5Ip9AJh7jJ7UxkLHJP4UAr1OfwpwYMflJB70eYDgrkAKoA65qXAVdo AJx1zUCysp2jBx7UPKQM5GT6U76APYqp55PtVcuzOMnvSGUnO4cdqUA7QQMGi4JXHYAbPXHNPBJw BTOd3Hpz9KeowckYFCEyXOVII6DFRYLHg08/dJB7U0EIRkc+9PqBWbcHKkDinB8EkEEfTBpXbg4U ZJJqIFiemBjigZYtr+a0l3wsVI6EdqfPevcsS55PFVgrFckdeBTXVk2sRgHkZp301EyDU7k2duk6 x7yG2kZxwaxdQ8VStaNDFahCQVLls4H0wK19aAk0aYAcrhh+BrmU0y9vIC8NtI6EEBgpwT9elNCY 7SmCWisAMsSSfepuTcuScAqarQW9xaQBJomjOSPnBGCKkVmaRiRzsPHrxV6W0Erpmi0BJB4IxnPr UF5bLLAQBtYdCRUNrdvH8uS0fXHcfSrcs5lAAUgHoCOcDqaVmHmZcMUSkiNSGHDZOST61cB3lYUH OeTjr/8Aqqf9wFBkQZHOVGCRWxoWjLOpu5wQjA+Wvr1GT/SlKagrsaTk7IqbFSFYVALuQoyccetV tTvAQlhbEGNTl3AxuI/oO351oX+nuZyYSWAGBx29Kp2WmOb9Y2QszEADOMHP8sVPtFJaDUXfUueH /D0+p3SqFxEpBYkcE9hn9T7Cp/FMheNNG08KbaJ900oGBLIOBz/dA4Hqcmu9h01rLT49OsQDczgB 3GQVB6n2J5A9ADXJ6naRW9xJFGVZIjtJA4LYPH4YyfYfSs3LUu2hxzWz5a2Zi5jUFm67Segz6VXC MGjJOY+BkdB3OfQ1eNjNcSyOHfDEknJAIz/iKltLKBJ40ubpYVlYrvfG0AAnnPuAPxqlJbolooRT gMVIBUn8qJoUf5ozgntTpraNbp0gkRgGABycN64P5VHJlHCKAGUDII79a0Ur7kuNtiqVKsQRgg96 uWuoz2ilYpnQEYO1iOPwqNiJUAYcj8xULRleQMjHUVrGTWxDXRnSWGtliFuWLA8Bu4+tbiOrqGUg g9CDkV58HZCCDWpp+qS2xwrAjqUJ4P09DTUk9xcvY64gdKaQDzmq9nfwXq5RsMByh4Iqye+KCRpP IA5pAPTk0uD05pMkcZoH6i+5/CmMeOBS/Q59aaTk45+tCXUQZznIp2cAZFIB6Dj6ZpMjP86GMcTn qOTQMkg8k0nI4xS5xwaYWH5AwD1Pp2ozzkDp6U0EE9ePWlwMf0pIAJyODUTHrg0pJBwSQc/lTJHw ODnPShhYrzvg89KxL6dSxJYBVHJJ4q/e3CxRsxYAAEnNZ+gaNP4ovdzhksYzz23HPSok+hUUt2J4 c8OSeI9TF00Rjs0ON2MGQj+le0aVpcVlAkUaBVUAAAU3SdKhsrdIoowqqAAAMYraAWFQSBnHApJW QXuxAFiTJPPYVia3rcGmWck88iqFBJyak1XVY7SB3dgMDNeLeINXvPEuri1G4QKxATtgdSfemrdS ktLl9b258XasbmcEWUTHy4yfvH1NdrZwLDGoAAAAAGKytF05LO1jjVcBQBW0zhF/CjfUkr6jex2d tJK7AKoJJrxnWdTk1O/kncnaSQozwBXT+MteEtwLCPLKOZMHGT2HSuLdEIz8wPoRT6WGxIBkPk9u tW41GAMHHtVRQEPBzk8+1WvNCKMnn2qQLOABkk/SomdScA5+g/rVd5WKlmJx6DuabGrOwLcL9aeg FrDsuVQ4HU9qa1yVGNoAxzV1LmCOExsSAQOFwOR79f1qrIsMi4DD2zz+tAEZu4yAHRip6gEDP0NZ 0oAkLAEA849KsvAYfmA3IeAQeAc014SeSOM4+ho2CxUIx05pAQOcECp5IwCMHgVGVBGMYoATI9aU YI6U3aV60o55x9aAHDBPSrbSJIEKxhSqgHHcjv0FVB9e9TITjOOBxQB0HhhA93KxJyoHP511TEDo Rk/rXN+FUyJ2BHYf5/OuiY+pH5VnfUpLQQkdPyrF8Q2qz2QcAb4zkHIzjHI/lWxnkkEcVQuJoplC BkJB5Dg8/kKpbifY4VgfcUIxBxVvUbYW906ggqeRjOMGqWCMH3piLsDEOCD161oI5xgtxWTE/GfS rSTAEHJoYLcS6ADHB47YqqQMhh9KnnmUngE9qrE8YH1oQGrbwrPIFK4zyecHpVl9OdPmhfoM4J5q ppdwon3SY6YBx3rWNwsiuUPIUnpiktWO/Yp2uv3dluiEpKn5WRzkEZ6YPFEt7Y6jdFp4RbserQDI z64J/kax3O6RjxyTWn4ftkudcsoyoYGQFgRkEDnH6VM0opy7DjJvQ2F1O8hhW1F+txbyDAB+8B6H PI/WrkIOASegyad4ztLSyuLc20CRyFSzbBgHnA4HHY1lwaqEVTMuAOCR/hWcdY3XU0d1ob0ZKqSC QSOKuwklRuI464rMtJ0nQFHBHsa1YiNoPXNQ1qNaFgcjHSoXI5NPLADO4DPbNQO5xg4pWKuVbhzg gcVy2uykyRqecknFdHcE5JzxXLaqS96vGQODxWtNdTKbK2MsATjGBTLtwIlUHljk89qUAmQZHBNQ XLB5sDJAwB71snYzLmlJgO5Bx0FXZXBG3OSfSmW0XlW6qByRzUogycsTxUXHbqzN1ElYAMEAnAFY xwecVtawcbFHHesU8HNVHYGKpJOM8U8ggjIIzTRxjIyDUkrq7jaoAGAB1piHA4HBHFNzk4FHAHJx SKBnHrRsMuWH+tP0rdiGFHFYtgqhtxIHtWr9oVVwATipe4JdSx0yTTHfAxkAnoKhErucgY9KNpOM nJp6jsSl0RQCRyOmaqyTA5IXoOppxjBbGelI0bFWGMjtxSsCTOtcDBwetIrkcHt3FJvzkDHtSbgf TFZ27gWc5UYOabkkY71ErEHvzzSq4JyaVihxGOSB603cfwp2M9qGTJyAfpR0FYahB6cVIpA47GmI cHleR6VJtBGQRn0ovpYEKxz6YqEgZ4PPpUmCPaoSSGyT3o0AdkAg4zVpTleh5FVVJJ7VMpI/rQNI mLAKeOaq7CSWJ5zU6kkZ6iniMP1HBo3DciiXPUYFW1UBc/rTFiIOAMj3qVSAMnA9qNA2Gk54B/Ol Cg8YB9SaAoJ4AGfSniEc5P4A0LYBnlliApIxUZgYOMt+FWsFR8owP51E2AQWP4A80WsDsJgKCSTg elRsQSTkDFDsWODkDPABppAI5HSgBcAruyKepBAAyaiQAHGcDFOAIOR6U7C6EuxgQwqZSSmQOfpV XLkEBiakRmyPmPTkU7hqTFw2B0OajlfaCw5PQChUJbdjBPNQzAmQKTwOcUvQYxSQOQQSc9aFJBBB zj+dMJyxPYDgUgJIAHandidy2pJjBBBw3WmyMjxhTneCecdaASLcgA8kHPYVL9kMsayxSxggYZGY hs+uMcg+3NDdlsCSe5XcKVYOgkQqQVPQjuKmhnsniSMWrARqFRfNO0Adsd/x/Go9oUlWOScj6VUt 3wwIORyPpimtdRWMbVZ5rzXHilYsijcB0A9f5VXlhihmCxOWBjJOexxTtcQDV0YHkryAarRkmcli c7TinG9rhdXIoiVUyK67QM5Jq0lzmNmJGWIGSe1ZcKL5GOQSeMd6khSaa4itkG5mOAB2ye9XfQVt TV062m1XU4rSBWYswBwCSSewrvrvNra/ZokIKgKBjoBxWdpemR6dbKoH7wjLN3JrattXjiMkd3b+ erIAHx8yHJ79+vfpXHUlzvQ3jFxRzlxdvbwkomWA5YjpWv4ctwkMl9cghlXJA6kn7qj3J49ufSr9 mdFjtLiW4O+RgdoYZAPofrxVLT79xamacqkCSNJGo7k4GT68DA/H1pwugs7m5cag2n6eQHU310Dn JwIwRzg9gAMZ9BXLmJr0CGIE55OOCQT19dzH8gB2FF5dtPKzygljjIz0GBhf6n8B61t6KsWmWj6r dYLj5ok9W6A4/Qe31pt9ASuU9S0hNLt4rQFTdSKXl9Il9TXJ39p9su0iRSVjGB7fX37muivruWd3 Z23XE7bnJzwey/QDk+/0FaaaTDpGjC6mUtd3BCwxY+bnuR6k84+gotbVCtfc4KWygtFkeVSdikgZ 6seAPz/rRq0WlpcoNOuXmjK5aRlII4569ea0dVg3qLcEPITkkDjPc+47D8+9VTpS20YMijOM4qk0 9ybNGQyCKIKxB3HIIHBHY03G0kEgg+3NX5Li2l094khCzmUkPzgLjAGPXgfjn1qskQ2s8ZYkAjB6 /XPetIyfUlpFSSMEbl7ckVCMnkZGKssFBG0HI6j1pzosoIxhx+FaJp7E2aGwztGwYMysDwQcEGug sNcVwI7ogE8CQDg/X0rl5EZDz+famrIyNjJ96tSdtSWrnomQ6ghsgjII5BoK56DNcjp2sS2zBQ26 PuhP8vSuotb2G9XMTDcOqHqKejJs0PK+o4pCAOv86mxxyCM8CkKkcYwcA8ihAREHvik4J4zUmOeB n1pu0DmgLCZwORgijPrz9KQkA8igEZ68UwHZxRk8etNIx64oJGODn60tQByASQCBjiqdxKAMg4J4 FTSuFBOeQKyLqZpHEUQLO3Ax71LdtxpFd7SfW9SjsICdhIMjDpjPSvXNC0SHTLKKCJAAoA4HU+tZ fhDw4um2omlXM8nJJ7A9q7REWJNzYB7CpV3qx+QKqwxhiOewrI1jVorK3eaaUKqgkkmnarqsVnA0 srhQATya8b8V+J5NUlMKkiMMCFJxketP1KSOy13U30/QIdZlKtLdqTbRNggKc4Yj9QK5XwzppObq UEySHOT155rP1vVRf6Tpdv5obyItrjOSME4H5YrqfDN0l9pizLHs2sVI+mOahKzuxyelkbkSBEGB yKydd1L7JZuUOXIwoz1NaNzOsERZiAAM8153q2qm9unIb5FOFwaJSsrmlClzys9jHltXuJHlmB3s ck1XeydCSp5960fNB4BP0o3jHJ/rWSqPqdssFFrRmM8DocsOvAqOMNNKqA8k4Fat18wwFHIJBHWq Nom26GeCDxz3xWsZXVzhlScJ8rK8mHnKg5VTjjvinSS5AVeFFRKSGcEdetGCAWI4qkZvcdk9yaTL HkdvWkVwcA5pC3NBJPBOUba43I3BB9KlRAl00BO5HXKn8Miqe8E8cGrkRLTQNnIGcj6ZP9aUtmXH cryo0ZKOMHGeagQE81Zu3Mk+Sc4AAx2AqAEAk/pTWwmtdAwSMECm7QBxzTgcnpxSggZI/KgQ0LgZ 6inKwAIFNZjnIyPalRWkcKFGSeOcUXsNa6I3tBvfs0E7JG7uMMwGcBfU4HHUcmunt7uK7g8xGBHc eledeY0LsgyDnBFaVrrclopEUSYIweDz+vWpcU3cafRnWzXRVtqLknjJHFQwqZLo5wQo5GByawh4 nmHWFD7c/wCNOi8TOhJW2QZPOCeadtNBXLXiW2QWsc6KFKtg4GODXJtx0rfvdfa9tHga3A3d8ng/ lWBknkjOKaVlqDY9Dg4JGKmQgjGarocHBHBqZQTnAIHrQIGAJIB603oCM5px65H/AOukwCcd6ALF gQtwueQT0reuGhitJCMAkYyAcE+mema5yAlZ0I6k1PPeSyr5ZJCgkgZOAT1OPelZXuMrAkseTzXU eCbcy6+j4yIlLE/oP51zQXjJ616V4N0oWWni8JJluFB5HRew/rWNeSUbdyqavK5Q8eRML2CXcCHU AAdsH/69chOWwqjoSK7vxQi3l7GkozsUYx1Bya5j+z0+2xszAxg8gjmiDtFXNHqy1YyJBGqhVOCF PyjJOM9eta41GCGeFSjiF2AO5yARnnBOSPr2rKmsPKlheGZUJbJLEjBPfA9quXmmQPbJLLeAzsxA HOMAdenfNS2mHK7mk72U0zLFOAecJ9oyQPrtwfzppt1IBFw6joCzLj8SSBV6PwzpyKMamrOFGSpB GfbOKim8NRTkql8Gx2wM4/Oo5lcZhaqZ7KLcTuVgdrgDB+hBIP4GuZM7GQCRsseTXS+I9KbSoIyZ 1kU8KozxXMZDyNI4AJHIx0rohaxnK/YfK4iQuOp6Cn6Dpj6rqccKqSoO5z6D1qEQy3UiqiEg8KAO Sa9L8LaH/Y9j5koAuJQC2R0HYVFWpyqy3Yoxu9QXwxaIuCJCQMdR/hUkegWAPzRsQPU1oXGrWVtz LcxjnoDk5+grIu/F1igIijdyM4PAH1rnjGbNGkjhfGKQw6s0MAARQBjrz3rmc4zn8K0NWvDe38s5 /iYnFZ2M8k13RTSSZjJ6ki8jk80oAJBJ5pBkDk0q5yOeRTEPLHAHFOiUswAGT0FNYipbZirA4zjo KT2A0LGAncccg4rRW05yQQPemaaoEQYjknNaaAngjjtmlcpIpeUFOAOPWkKc4JFXHiIGe1QFSSSM YNK/UfqV9gDfWpNgAycU/wArGRg5/SmscDBNFw2Rsq5IBx0HNLkA5BqtFMQdp5zUm4E8d6jQRYLA 446UoIPI71ATnkGjeRjn6UWuNMsgkDg9O1Ads9c1CHJ5B/8ArUokJOAefQ0WfQZKCRginh88HAqD ecHjigMSOmD1pWfUCZ3Kgc1Gx3AHBI9hUbOQQD0NORxkZ5HTFFhepIBjHNSqD1I4pgODwAc09eRk k0egywgBGO3pU6ooHJx6VFGAOc5qYkDjAPHanYBMMW4Bx65pHBByO3X3ppYjJznHQU0Fj8wFFgJV BzyetS78AEkHFUxIS3T8qfuyc+1F9NQJJZ2IwDxVf5s5PPvS5HPagABCSckmhtgKASOc4FKCCSCc CgkHgZHrSAZGO1LcNRME/TsaemSQKcicAEcCnkKOcdKaWoDlUAEZxxQqkYJyKRWDcYxUm4A8CmIC cAkdcYqpMxOCBz0wasvOig+w/AmqskpcFgAM8UNgiNVOCDxmnIgBz7dqFJEeCOvPPajABJBIHbNJ DLKMojZducgYyelORyhjxgDJByKpLIUyCeccc1PbuskmHJGASAByTVIVizfRgbJAcZwOnX3ritRE yX0kUUsqYYsSCR16V27S77UoVOVHBI4GP/rVkPoE+o3wuE3NC4wwjG58gZxgcjOQAenWhaMVjlRE Ek8x3Z2A6k5JNPhVjcAsDyCBkda6fVdAgsNLea5ins5lIEcchDMwPcgAEAetc6QRLHkAckhgeoxV Ji6lWzCSW4QkA5JORgD0q/pTR2F4l5OpaNgVBA6EY598A/rWRbEjORkBjx681aklBkIUkqOFB7et DSa1GnZ3R3wvop4AYJFbIzkGqweWBjKCSAckH0P9K47TLuS2vcoxAB6V0l1eCe1QFSNxIABwQK5Z Q5XobqV9WSGVr+5AJxCvUDvj1qa4uywVVOEU4UdiR3+g/nWclwIoyAMADk+g9PrUUcr3UwRTgdGI 6AelVayuF7uxt6XCtzOJHB8pCep+8e/5/wAqs6lqnmyKVYiGLiMZ4JHVj7DtVCW5WCEW8ZwAMsQe 3p9TVa2jbUbsRqSEH3iOgA7VK7sPJHQ+HLNJ5zf3RIgjOTuPDY5x/U/hTtV1Zr+7e8cnYAViU9VX kEj3PQfifSoL++SO3FjAdsSAB8HGfRfqepqvpcD6pqCoSREhyzg4xjpj8sCmpBY29C0SCSObVdQI W2gXJ5xuI6Aew4H1z2xXP6o/nyySBcGQ8IOwPQfXHJ/Cug13VY2jisLYBbSA429mYDgH1A6n/wCv VbQNH/te/Ekx228Y3yOeMj6+p/QDNN7aC6nOx6R5Vr50qkBhwSOtZGqFkuordVIWMbiE4O44zk+u AB7c16DrE0F3PNcquyxtR5cIA4kcfXsByfwHeuZg0mS6aW7kQhAckn88fWmm1uS1dnOxJvJDKxYA sZMYx9R/WmZCCQMuSyjafTkHI9eAR+Na2phra1cQgKZTtHHJUHJ/UAVnhJ55ATEXYgKVIGD9MAYP vWib3RL00K8gIjUsBhh1/GqslueSgBHXArRvI2QqQp2AbcEdx/8AXquI2eJnUgYIG0960Uk1qS4r oZ+xg2RkEVatrqSJwysVcHgg4IpjAbiGBBB5GKMAHAIyexq07EnU2OurOFiuBhzxvA4P1HatcNkZ BBFcApKnK8Y61taVrRgYJMDJGeCM8r7g+vsf061SdyWjpsehpG4A649xTIrq3u13WzkgDkHgg+9O Jz0o6iQ0jOO2PWkyQRgcfnTsZPSkxnrg0AmNJ596axwpzzTmGBzxiq9w+xSCfxzQPcp3k5AIGSSO AK6Dwb4dM8ov7pcgHKA9z61m6Dosus6gGYEQqQWOOMelesWttFZWygKFVRhQKyb5mWPjjWCMMwHH QVm6rqkVnA80zhUUEkk4ApdT1OK1geaVwqKCSScACvHfEPiSfxFqAtrYsLcNgAZ+Y+p9qrZXYkif Xdfn1y98uMsIAflX19zXIX0TXOoEREHYQuM9SOtdgLFNI0uW6lH77acZ7HsK4eO6FtdZcHJO4nPP NRrcrSxoPpF7DGkk0YSMjglgc/l610/h5mtrUCJgpUnIwcHvk9s4yOOmAe9ZWqa9a3NjDHEH3KBn IAGataPqaWWiyTzQiRWdtuWwQcYAz3GcHGO3Wi76ha60F8W6/m3+zQMQ8g+bB5A7iuGR5Cc7mz16 1ZuJHuZ3lc5LEn2pscZJ5XvRfowTa2Y5HkHIc8VYjlkOASDn1FJ5RwAAB9akjjwQCTk1LiuppGrN bMnlBMYYkDjAxWWhAnBI2kHkelbkUK3JEQbDEgDI4qlr2lf2a1u4YEyKdwByQQe/pkfyog18Ipyk 3zMy7mIpKXU/I/I+vcUFcpjPank74wGyMgFcjhh0qOU7QcjtWi0M209SvwD05pQRzkc9qZgsSBQR jkn8KYhcfNkmr1rJsBJHOMA+lUASAQOakgcjKN1IpNaDWj0HSgg7yeGJ4zUABNatvoeqX8CzW1lI 8RyFYAYOOvWph4U1sgf8S6bjvgf41LqRWjYcretjGBJyD0oOSOM1snwtrQ5OnTf985pjeHNXQZOn XHTtGf8ACjni9mPlfYyCCAMnmpoXCSoRnggnNW20TVAMtp91j18pv8KpSxSwSbXRlI6gggimpJ6J iV07lm/gIuVmVflbHPoap4wT65rUhkWW38pzlSODjofWs6ZDHKykjjoaI9mXNfaQzGeSQB2p4HOR npTcZ96cnFUZDudvXkioccHPJJxU2cjA4NQAnnPrSGIBz1+lX7K/u7LJtriSLdgNscjP1x1qiuc8 j9KmGMdB+FAE1xPLcOXldnc9STkmq7HGMDrTue3SmknOMjii4CqSJFI7HNBbMhPYmmk8j1pRnvnm gCVSzyKo5JIAr3CxhW3023gx/q41Xp6ACvIPD9hLf61aRRxs4Eis5AyFAIJJr2wKoUA9R1rixEry SRvSWjZwuqyF9VmIGdpx+QqmsQfBI5zmnXkhkvbhxyC5PX3pY3HmIoGTjJrfZIXmS/Y0nAV16cgg 96zb6wnSUhWdkGCO+K6GJSFHFPABJG08eoqL9RnOIblEBLMMccgilF5cRsQGII7+tbsiA9upqnLG oYkqKFdsey0Mye43zRyXbEIrAknnAB64rSvtY8PTAOLAXD4+9jaT7kjmue1iUsCoIxkAVRRMKBj8 K0VNPVkOVtDaXXRbSFrGzhgPQMcsR9CSR+QqtPrN/dAiW5dgf4cnH5dKoYIPJGPpTlQA4HNWoRWt ib+YrTO5JLGqt3cFEKhiWPr6VJcSiEZYjJ6Cst3MjEknJPeqt1E2RkknB5pBwSfag4BwB3pcccki gkAMDvUigYBx1pmeMCpFGFzmgBD15qxAmSMDOKhUAsBmtCyg3EZOBmpbsNI2bVSsKr04HWrykYBy MVTVQoABJPapUyDnGfrSKRMzBhwfao8HBAFO5JycD8KMc5J69qWwdSIqxPJHpSeWASW5AqU88E9O ajchwARjvQmMVWweR1qeNyeCaq5P4GnBiDwaQkXNw7GjeTkEDOKhVwc4OD3zTs54oBkgbBHP4Uu5 QOtRf0p2M98A0rsWpMrgcDmnhwSCeMVXUAEYNOyuep4pX7DWosrEnjNCMAck0MQV4HQU1VJPP15o QNltCW6HjHNTISODjB9KhhUgc1KDg8EYp2QXLKOGxtwO3Sp1RlIPUVUikAOQAaka4YrgZo2DUlnw CAQc+1RbyeATj61FuYnkk07k429T3pXfUZIRjHXPekzgDrmkAwME89zTSTnOOBQ1qA89RjkHrSk4 yBxxwKap7kZNOAyR70LuO4qkk5NSgZwRnGaRBkfj6VKoAXrjHSn6kvQUjgY5JqNicEDtUgPGT9c1 A7EjJ7mmCHKSOh6etRTzgfKCRTZJQFIIPJqnI7E8d+CfSk30Cw5pWY4BIHYVIjggZPOelVQSec4x xTl3A55H1pX7j2L2/jHXPrRkdATUO/gHPTsKUsCQc4zTWoPUkKAjBAPfg0Rwl13AkYySR6UgyOTg ipYZ2gkztBTHIPQ0C9SzbSgAoSxUjBB65rLklaK6Qg8EHAB6EH/69XmvI3YGONI0zyAOprM1CVYd rohYB9ox6GmtNQdnsTamzS6exyScZJPNYUykPAcYBIxjp0rQlvzcWzW8MDbmBBJIwB3qtcKUht1Y 5IYVXqJ2MiIEIQqgsWOOenNOBVXDMpwTnB/lUCEpM5zjDE8/WkmuAzktgZPHbNPoCVmXYHiWQyuA XJ3YHf2x6VcSV5nLsw45x0AFZUIBIOTnufapZboKBFGQR3x3NZtJ6spN2sX5Z2lASPlVOM+pPc/l Vu2cW6BVI3nuf51lW5KLuJyx7VYlkMS7SQXbrg9B6VLiWnoWpJTLKIYiWJPXpk9zWzbsLKARQ481 x17D1J9hWNZkW6GRgS56AD9KlmuWRSuAZmPzH0HYD29ai1xrYts5mlWCEliT1J6k9Sa30uU0qxEM LASsMlu49T/hWJp6LaRGVzmRh/kCoLi6Z5SoOWJ5AOefT6CluNbF2FZL26SGIFixxg+h5JP8zXY3 U8em6Yml2bBWkBM0h7Ljkn69APTiuf00rpluZWAMzDnjk+g/xqpdXTzSMgYtJIQXI6k9gPYfz+lC vfULdDUt4n1i+htbVdsEZCoCMgDqWPqe5PrgdMVt669pbxxaNa4WGAb7mYEFj7Z7kn9SOwqvp8qa BpZkUBryUbV4Gc9h+Gck+tYDSSXdwLZGZ3kbLMBksx9P5D8TVppitbQYumza1fboo8RKDgDJCqMD k+nb3INVr+AWyStCuGQYDAd/r+td5dCLw9oa2EGwX1yP3rj+FccnPYAAgfia5Z7KXUpY7a2RihYK AASWJOST7nr7AAdqFdaia6HLuLm9WFpTuMahVwoAwBgdB1HrUV1ZMLdnwihZArEEAbiCRx9B1rs9 S0oaWxtSAZEXLDHQ+n1/xrlY7OS5kcNllL5xnjPT+lWpX8iGrMykhM84EoZVERYHGOAOMfX+tU5N w6qcdm7GuiurcQqYtyguCMMcbQBk4/SsUW7ybdg3IW2k+nIHI9OatSYraXKsZJGDyexHX8aTlGJ5 xnNTTIoupPJACKSAM84zjqaYXV1IIII6HHUVafYlqxNb3slvIHViCOhBx/8ArrotP1lJ8JMQrnoc YB/wrlQinjoT696FYhuDgdMGqv0ZOh3/AGB6j60mQOcdfSuZ0/V5YAEc707AnkfQ1uRX0E6hkYA4 5BOCKolonkcKpJPSqUEMuq6glrACxJwcD9fpST3SAMzttiX7zd/oPc1ueAhAdcMpxgQMyjqTkjFT JaaFRO70bSoNIsEQKOBknux70zUtTjtoXmmcKigkknAAo1HUkgieWVwqqCSScAAV4j408YS6zO1r auRaKSCQfvn/AAqVFJDJvE3iubX71rW1Yi3U4AHVz6/Stfw3oK2NsLm4UGZhkAjoK5fwjZCfV4yw 3BQXOfXGB+pFei3kywRkdFUc017wN20Oc8Ru07xWq8gncwHoOlcBraGLVpUOBtwP0FeiQxNeXDTM MZI2gjtXnniA51+8A5AlIHPTBxSS1uO/Qr7wIwO/atGOaSWyjhOSi5PHqTWaqcAk5JrYtbcGBSCR kVM3ZDjqVREcnINTxxYwCP0q+tqCM+lK1sSCF/Os1K5VrFFgQSRnApUBPUdO9XIdOubmdYoxkscD tXRDwFqfkh0kiORnHOPzxQ5paMEn0MJdotc4GSCOPWs2+ne9hYTu0kiPjc5JJB9z1xXSS+FtagXa LYSL6o4/kSKpr4avxKWmspFB4Jxn+VSpxTua8qcfM5Qo8c6IWJRTheegz2qG4zuIz04rcvrNrW7a KVSCMYyMcYFYdyMTuCeh6VvF31MGrEGCACDyOtBVjggcGmA5OMnFSI5Ix6VRI5AoHAO7p7EVJEim VTgA5HWmEAcjPNCOQyk9QetJ6oD27T44lsYTEAqFAVA6AY6VbVQBg9+mK4Twt4pjijjs7xwEHCP6 D0P+Nd3G6SIHRgQRkEHII9q82dNxZ1RkmtBJDgYAyT05qNSQeMfSpiisATyacAoAyBU2sUxinIzt x+FZ+taTDrOntazDBPKP1KnsRWopB4qCW6tYiRJPGuOu5gKqKkndIltWszx6/wBMudFuGgu4mXJO 2Qcqw9R69vcVRnhLruGCQAcg9q9X1e90Se1aK6ZLhSPuKMkH1B7H3zXn1/aWaTmTT/OEZBDJJg8e xH9a7ac5Ne8jCSS2Zz6jPGcUMcAgHg+9OkUqwPY8DNN6jjrWxA0ORwBn3po7jmnsNq8jk/yprKqg AEk9/SgByjB/Cn54zTFOCDjNSDpyaQAM5JwTTcAn3zTwBjrSAYyT2oAZgGQKDyTiry2ZQBuDgZxV SAA3Azng1rs4EZUAEsMAnt71Em72RUUt2aVnrcmkZTTGRVcAsxjBO7HPXPFOfxLq9zIFe8kAJwdu FH5DFZccQAxgZ71NHGpkUY4zmq5I721EpPZGsjkqCxJJPNSxSsLpFVQQTgk+lVY85I9OadAwa4Vs kYOBzWUmbJHSJ0/Cn5yCfwqGNw0fBwMVOAAoHc1mnoDuQvzVC5bCMc9qvTAkcEis29JWIj1HarQn c5i+JedV65OaUDHXHSo7ggXeScBR3pklyifx5PoK2Wxm3qWFGTjGcdTUU1wkC8EFvT0NUZL5zlV4 HY55qsxZySx5qhXY6WR53JJz/hULnHA604vgECmgZPXrSECqWODj1p5A6dMUo4FMJB+tAAOTjH5V IBjkA0igAZp4BJBHr3oYD4kLMPety1iEajI5xVGxgLEMQcDp9a1FBAwPyqG9SkiUZBzjpT9w6E8G mIjngKSTVyPTLucALC+D3IwKltLqNRZUZ2BwDgUglbjJrXj8N3T43sqfjk/pV6HwtGDmWUsfQCp9 pEaizm/MJGSTSqkkhwqMSfSuvi0S0ixiIEjuTmriWsUQwqKMdMCodVbJD5WzggcnIH507PfGBUfI 470o9cVrcnzJFcA8j8al3g44xUHIwKcrEdeaV+4MnznpxTgSSMk1HuyAevtSq2Dk8A0wsSjJPA/I U8KcdOetCMDjB9qeQME5/WlqG2wIOMEZzTwAOSMUzcFIJ454ppcg5OcYzQG5ZUjAIpS4BySOtVhI QMY60m4k8mjbQErFoS9geanXJUkjFUonRWyQTVsTg8YxnpRbuMfwACc01m2DIJyegpGfJyBnHSm8 Njg570JCHLIehOc96eMkDAzUWASMD8KlUleARz7UMPQkAIHQA09RhgTzTFORweRQGPcnNAE4IA4P U5pScjrioCxAyDwaeWAUEnk80eYEhcDjOMVBI/GAeKa7lVJJ9z7VUklLk46AZoYKwskoIIBpmBjO evWo8kkkjpSgkqSTgVNxjmIzxzT8gYGKiYgYI4pVcAYIJGMdaYEycsAeB7U/G0dQPc1XVz1A/SlL k4Ocj0oSYWRZJzznGKXOVwSeT60xAXUhRyOTTgDgqwPt9aYWFTYFYMGOOQBxVe4VZLZsA5DAge2f /r0/fg5APHepbeUW10sqqrYIYBgCCRzgg9aasDVijFpV6zB4owEJ4LMFz9Mnmsy8eYaiYZVKvEdp U9ieo/lXWnVknlDG0gDqMK2DlfoM4HNcffOx1mZnYks24k9yapPWxNnuZjE+e4xgBjmlkgSUAnIc d88EfSldCbiTA43En86eVyBjigaK0tw8S7FU8jqaWAggMT8x9O1WjGHiKOAw7EjBH0NUvKkiViiE kZJ9h64oumHUu+eIxkE7+gHp71LbnB8xzknoKzLd8ud5ye2RWgkqoNzdug96iS6Fpl97kJhiRuI4 GOg9frUtmvz+dKSSeQD2rNhzLJ5jHjOQKveeEQscbR0Gep/wqWik+pdubzaBzyeg7gev1qxpkIUi eXAOMqD296yrYGeXzZDkA8A961HuVij3Hp0A6ZOKhrWyGn1LVzfFQSD8xGFGeg9frVvSYxF/pU2A eoBHT3rFs0a5lM0udoPAPer9xehUAzkDoOxP+FHkF+5e1DUXlbOcMRhV/ug/1Nbfh6KLTIWv7k5b GVBHIBGMj3PQe3PeuW0yM3E5nmGVByAR1P8AhWje6iXIAI2KcqPU+p+nalrfTYOhdvdQkvbpmYnz JDhs4wq9lHsOp/D3rsdGSHw5pB1K5QG5ZcQxnqCec49TwT6AAVyHh60Esou7gAoDlQ/RiOST7Dqf Wpdf1lrycIjny0BC+uO5+p7VUZaia0uyrezzalcSNks7sXZu7En/AOvge5PtV680I6JYwLMALmcb hHkZA960PC1nDaxHVbzaIowWRSB1HGfoOg9Tk1latqc+r6hJM5w0vCg9FXsOfbkn/Gq31E1pY5i4 tWub4nJbAxx0qOW1W2QyMxTHAIHQ/wCcV3sXh2PTtBbVbs7WlwIUbqcjg+2eT9K43VEaaQQDBJIL Y7EdvzNCk0tdhcupz8tvFJLI0ZKIQQpbgMeMZHOM8+30qGeMYt4eFkC8nHckkA+vGK6A6ekEW6UZ AGSPpWLKqXUgkQEY65OSMHoPoOMe1aJ31RLV9zPYO3DAgLwMDGKRQzrzjI9KvSYitdrncrMMEcEY HGR+JqqkbmQhMtgZODjA71alfchqxEGOcg8ipoDLPIVizu6kg9B602MCSQJsyxOBjrn+tb+n6a9v b75VULI2cjIYEHgHjBH0NPmSdrhZtXGSxn7A0EqLISoALZyCO4I7n37Vo+BnOm387zuFQQsQSegJ H+Gaz70OrADOw8hh0Nc9rF3PAogidlWUYcA9QO30qrXVyVvY1vGXjGXWJ2s7NyLYHBIP3/8A61ck iY+UgkmnpGAoPf1qeGMkgkYwc81DlctKx1ngeBlluZzwI1CgkdyST/IVsajObi4ECkkAguR/Kqej k6b4cMrriW6kLopHUYAH54Jq1ZW5GJH5ZuSfeqWiItd3LlvEI4wAOleUaiRPqt1LnIaZiD9Sa9al ZYoGZjgBSSR2GK8jZTkkg8kkE96V+g7DUCjAzj0+tdDbKywJxnAHasCGJnnVR0yMn0GetdtZ2jPc C1ZQuSQpbg4HqOoOOxrOptoXF20KiKSMjP0p2CBweTXZQ+EYRCjtK+WGcKASB7gkVLF4RsXPz3bD HYoR+uCKw57dC7XMLw1btNqAdh8sYySegrvXjZRgwJ05KPg/yqvZada6cpS2NuwPUs2Sx9OoNT/Z pR87WoAPIKNnI/Kpvd3ZSQ0EIMFZ1x0IbIH4ZP8AKkMrBf8AXAnsJIgP1wKUrsIDC5iB/iHI/IH+ lP8ANUYC3SPjkB4sZ+pwDS3HY4Px9YB4Ib4GMuD5blODjqCRn6j8a801BCJFkA+8Bn6ivcdZsE1i yktZHiG4ggxnBBHI7kfpXleu6BfafBi6gKgsQjggg49wfSt6c1azMpR6o5Qkg9KdGCSM0xwc4Ofx pyEg+1dBmWVKtwSBilMeBgYNVwctjoSe/Sn7inVsEHt0pAPAKEFSQfStPT/EeoWQESTyCMHoGNZf mE4JHQYowpIJJBJ54oaT3Gm1sddD4tvXGBdOvHQkfzqY6zqEvW6kIPPDnH6VxWSrEAkY9qnhup42 BRyMcDmlyroh8z6s6h7m6k4eZyD6sTUO5j/ET9KzYNXOQsyBz6g4NXo9QtXON2wjg5HSi2lgvcc3 zEAH8zSAKSeQfpThPbbixmUgdDSSXtqhBLj8BkmmkxN6mHe27RyMpBwfmU+1UkQgbmOAP1rXvr6C ZVEcfKnOT39aypHLEnt7UJdxETnLZ9e1HU805oXA3MMZ7E84pqjJwDxQBIuADk0E8YPek7fSjBOM 9vagB+RgAChsBSR1NIM8e1I55APT60kAwEhickGphM4AIc4Hv0NQtySQAAelJzjA+nSmBZF3KOBK fzrV0gyTEu7EgcDPSsJULEADknFdVptuILdFxzjJ+tKT0HFaltQAxHTIqOEkSkEAKORxip3lSLAY jJ6VagtQ8YZhjODisJPqbxLlmSYwd3B9KvZGMe3FVFhClQOMU4gjJyfzqIpbie9ySUgAnNYt9MCC ARxV25fZETuPTpmsC5lAjdjycE81og8znb6YvcuQcYOOtVQSSDmiQlpCfU5zSAHqPWtzF6sfnOSf zpOemaesZI4B5608xY4IP0oEQYBPPOakVCASR+FSKgGWbAHoaZI4J4PFFxjCeMUAZwe4oAJ9akAw MAH8KBCAHsOtXbSykuJ1iRSWYgACm2lpJcyhEUsxIAAGTXpGgeHksIVkmAMxHJI6e1YVaiirLcqM Wypp/heJI1EspzgZAGK14NCsIiP3W4+rHNaioM8gZFOKAnoTmuXmb1bNlFFdbKCNcJGo+gAp0amI 4xx9KlChTnmnNgjkCi1xpCja4zgU1iBwD05poBP3eB1p2AcgnmhdhidR0FNK5OQOtSgEAAjimMAc 4PSmI81BOM44p2cdj+dR9eOlOz365rq6mKd1cdgY460oOM4OaYCefWnA0bhYcjEHB6U8HJznvTCc HORSggnk0g2JAzBuDip45QTgnntVXkcnp2pckEGhMC6zFgQB16kUhP7vHQjv61AspAwTnFPDgjJJ 54oWoeQ5SQBk5p5TIz361ESR7YpyuSMZ/Wi9w9RRnOAMVPERnk5x71DuB6DJpwY5BIAoTsHqWwcj 096N4UgcAHrVfzcAA5xUJlJORn8TRfqFjTVVYZB59aXYw6AEH1PNZYlcc7j+FSC6kBxu+madwsXV SQty2ATzxTzwMk8ngVRF24GcjjrSG5c9CBSv2GXweck/nRLcqg4IJHFZvmuSCzEjvS7sqcnoaLrY CRpTISDn8KQEAZJOO/NIigg+pBFIEJGRk0guO+UHAzScgkdvekwQcEUZIJPbpR5hsxcgjkHjpik4 wOOaXAzj1FGRngfWjULCAnGcnFSoAVxkcVFkY4p6uAoxkd6d7D0Ldu+yTAxyCKkZzuYMASDjNVEc lhjn0qzMRnOeWAJ+tHmTbqSpHBLAA00kLryCigg565GRiq5ChwoJIHIJpuQTySABTXG1gSc4PrRZ D8mVobmNG2yOiEEg5OD1rM1F4pNQDxOHGACQcjNVdXj26jIQPvYYAe4zSQRMkQJUgnBBIxVpdRbi lP378dTT9uAB3p5GZGPfijBzz2qWx2VhvABBBPpUEiMGEinaw6Edqs4z1qOUDIGOaI7g3oU2jO4s wUE9DjAJx7VXUyJc4lBPfBrQuUJQLjr3qiWeOQKxLADgelXZsm+pfWVY1DseB0A70sZaaTcx+UdA OlZ0iNKfMDhwOo6FfTIq9FMscQLkKMdPepkuhomaayiJNx4AHHvTEZ7qQMxIUdqoq7XL5z8g6DNX 43VIxngD9ahrsUmaInEURJOABwAf0qCEte3G5hhARnH8hVIvJdSAAkIO/tWhCViTAOFHv+tS1poN PqzWEqpEQTtRRg4/QfjUFsrXt0WbiNTkkenYCs17h7uURR5EYPP9Sa2oHS1g4O1QM5x19/rS20Qe Zq3GoLb2wjXAGAMA447Ae3rVTTYTf3ReU5jUgt7nsB/ngVj+c99cBQcLnqOiitkXC2duEjJXA6jq B3P1NHkJPqzV1jVA0SWsRAiTAIBwCR0H0AqfwvYLd3P2m54gQ/NngMeuM+nc+3Heuatw1/dBAdqD lj12j/GuivdQjtLEWsJ2Ltw2Oy+n1Pei9tENa6sn8UeIDqN0RGx8iIFYUHQnu2Pft+FSaBoEAspd V1EhYowSq92YcZ9wOg9ST6Vh6LZPquoB5SVhTliOoHTA9Sece/Paug8QapFIq2MJC2luBvCngsBg KD6Dnn6nrVX5tHsJq2pzOqsJEd9uDOSFQdQuev4/yz61Rj0pYYQzqVJGenPNdZ4b0QaveNd3RC26 Hc56A9wo7DgZPoAPpVPxFdQT3Mxt1xCvyQqByx6E/T/ED1pq/TYlo4O6Je+kAA8sAKAB3Gf8f0qN E8sSucqxQoM8AnI/Liugi0SVYDcyoQNxAJ6E9/rVO+sGmaOBBhjhsD0PSqUk9hW7kPhvTTc6nGrN sfkgdCSO2e3WvSX02wtLJhOiOdvzMwHA9B6CuO0WKGz1hHRyY41G52PBPfHoOKyPF/i2XU5nsLFi IQcO4P3vYe1VFRlqyZX2QTa3psmpy2cbZhBwrnoT9f61z3iKJUvY0Rs8ZAIx1P6/WoIrIovzAknq aSS2leUO7s4AAGSSQB0FVzLZbBy9WNjgIALDPGa0tKsG1HU4LVFLeY4DfQHn+g/GqZcICCRkDP0F bOmK9tbnaCJ7kcnusf8AiaIrUUnob85F7qZEYAtrf93EB0IHBI+uPyrTRAqgYqhYxrFGAABir0wd LUy8BBwCT1PoKqRMUYviK9MGnzLGeSpB9q5fSjbygBihAByGxxx710c6LcqyygkMCCD3zXIxaY88 lybcgRxMRkntnA/pWMZJt3NGrbGjMIUu0jt1QFiMBcDn1rr7S2ku9Rt7guWLMTISSSTjqSe+f61y Gk6WwlW6kkBIyAoGeenNekeHoAAHYDCqT079qmU1sgS6s2Y5VUYDXCDG0mI8ED15GfpR54J2i6JA 4/eR4H4nGajScxnAluY+pIAyuT1wAT/KpQ5OCbqFhgcSKAf5CsVdmozDzHarW8pPGAwB/n/SlNtL GQWtWRuPuE8j8qlMTyttWC3lOMgxsR+gJzUO0RNg28yHJ+42R/SgLC7mUHD3UfsTkA/TJ/lRglQz XKPns8YBH6Cg3IRvlmnQk8h1yD+HIoafzCC08IOD99AAfwwKGmwIZAjnKLC68cBhnP8An2qhqWlQ 39o8E1sFDDjYQSD2I461dYFzkpC4PQqcf403YADmBwexRv8A9VCVhHiWvaFcaVetHNGQCSVbHDD2 rGwVYHA47V7pqml2WpW7QXIm29RkEkH1B5xXlniDw5NpU5AJkgP3JApAPsc9DXRCpfRmUo9Uc8wO CwwBnHWmgEg5HFOZCpIIOBSd/StiBAxA5p27IANIQeBnPrxTgqkENkHsRTAMknJzSgDGQSMUhQjO CeKTJB5FAEygMwGQKeUwTtIOfaq2/BzgDn1p4lIHAAPrQBLhwMkn3pjE45z9fSo2mPY5FMLsQQel ADySR6fWkVijBsgkHOKaCxAznihQCCSSD9KQEkkpkJZjkkYGKjUnByaQkk9enWgA96YD89s0uCe4 pAORnNSKpOABSYCjIBJqFzk8HpU0hwpxwB61ADjvnPNCAcoB6960bKyjnIDtgGqAcAcj/wCtVi3e R5AkQOTQwsb50q2t1R1cOxOQB6e9XYQAAB34qrDEUjUMST3JNW4SQ2cVm3pqaRQtzbLK0QOM5x+F bGQkaqB0H6Vnwp5t2GxlYxgE+taHDHPpWMnqaLyIY7pjKVK456EVOzZGBwT700ooO7GDjrTC3fnN Gm4bFW8YbSCTisg2U2oF4YACcZJzjArRvicYx17Vzk+pS21wwicrxg471pBakzemhKfDzRkhmGfT NPGlWsC5lmUkcgCs6TU5n5LnNVmuXbgknJrZrsYmhLLAoKxKAB3NUmkUEngn+VQGQsSATSAE8k5F JWHcVnZm9qQKDyfrTtoHI5z6VNFA8pAVSSTwAM0NpLUCJRyMCtLTtKuL+dYoULEnkgcAeprd0bwf cXbJLcgxRk55HJ/Cu+sdMttMhCQRhcDk45P1rmnXS0iXGD3Zk6L4fh0pAzANMRycdPpW8oO3gdqR xk5AxmnAOMHIxXPu7vc0SsrIbkgnPfpUi9AAOR2prkhQcA+tReawGQOnrTsMmKEgnP0pNgKkEkml jlV8A8E0MMHODRcEN247jFIRk8AkikYk8ZIHrT1IA5PNNILjQ4BAPWg4IJ4z7UOgPPSogWQEcn3x R0sHU82Jz9aXOT6YpMgdRg0A5711mI7JJJB5pcH1waaDg8jrTwTgd6VgFGT0GaXPfNCtjsM0mdxx 3osC1FBORmnZJP8ASmjOMZxTsAAHv7UgsPGccCjcQAKbkjv1pc985oXcZLngEnrQDxjHWkUBgQRz 2pOO5yDSuBIGIApTITyMdKYM4wB1oP1oC/cXJPJNA45B70gPGO+aXaTyQcUDuBPbqKUEDgjNJtzy AaUA96LIQox6gUAnp1zSDPbvS5546mgBwBJANPGApzjiowQOCDzTgcAg96LWAliYBwccUocrkDvU IODgnGKXcM5B4pXYehJkscnpSkgqcjOKj3ADHf1zT1IIzmnpsMQkdqACeQCaMENjAo3AHIPPtR6D 0AjPUEUY46dKUOxcDHXvTtyn5SOnQ0IVgRsDIPSpN5YfMQcVDnBwRTlKnv3700A/fgjPekkfIGRg HocdakiKNIBLkqTzjtT7m2eJfnWIqcbWRwcjryAcj8QKNQsQxQ2pvlnmcrKEO0lNwGRgHGRyO1Sa o8Y0h4hPJcOWDF5OMY7AdhzVd4yVRgckEg/Si5w1g4YYAUnJPFO9kKyuY/Q57kCgYBGarTXDRSqA owVBOaVbtCQGGKOUE7blhSCT7GmSYMoHoM09Np5Ugj2pUi3zHAPTFC3EyOUAqDjnFUHTM444rfe0 VIwDgk9zWbcxBZQR2HStUiboy5IsS7lPPpSnEzhHO2Tovofb2NTMMNV/RLJLzWYVdQyqSSOx4NCj cL2RVt2MURLEAAHgnpT45vtLAAkKDzniuy1TwpaJaFoY2BOSQCTXHm2WxmdXY/Lxg8E1m10ZcZLQ vxYAwOAOpNRy3DSt5cZwo6n1rP8AtbzPsA2r064q/axAckgDqSahqxd0y/ZIsa5JwByTRdXj3DCG I/KOB/iaoz3RbEUWcZx9as2sQTBByTySf89KVtL9R31NS0VYIxzk9SfU/wCFRy3LzyiNOST+fvVO 4vQf3UfLHgkd6s2EQjG5jlj1P9BUpW9QWrNm2K2kACkFjySe59T7CqjyvfXAhiOckkn19SapXV4Z WMMXJPBx/KtCyRbSLgZdhyfX2o8g8zoIrpNMshBbsA5GQfQ45Y/h0/8A11l2qPqd+sCH5ASSxGQP Vj7f/WFZ9zdtLMIVO5mODgd/QVt2DpplqSMNI3LHux7D6Dv60Xtog82dDqWpRadpK6dauYwVzI3U hTySfcn+grJ8PacNZ1IPID9nTgAHlRnqPUnOB7knsaxJppdSvBChLszZYjqT/h6V1Iu00TTBaWhB nkGAw45IwW+g5A/Omn0Dcf4iubS7uxawqsdjZLhypxuP90Hv6A/U1gy2nlxG4uRsllXzCO6qR8oA 7Ejn6EVZtkhZTLP81pAd20/8vEnp9AcZ9sDuccR4v8StLM9pE+WJLTOD/Eew9gOKtR5npsLZXZna 54hBZ7SybCniRweo9B7Vj28yoeepHUiootrEkqB+FTE8dBx6CtFaOiI13La3qggsRjtT3vIWGdwB 9M1nck5yAPpTSATgcmiy3DmbWpdjntnulaVh5KnJA/iI6D6Vu2eo2m4yzXCBmOSM8Adh+FcmVIPT p7UYIHWqi0iHG7PQRrOmQgFrpHYjIVScD6n+gqCfX7W4YFrlSBwAAcD6DFcLlsZ9KdGWLAEnA5NE nzaDiuU6651e2SBmjlDMASBg9e3asXTb8wWs0ZBAlIBOOozn+dV0VnVmLhcYIGetWrG+ltpCFAcE EAMMjJ46VCglcbd2i7baxDbhImhdipIJBHPNd1pfiHSo7I+dP5RJAKlSTjuQQMV5utsHux83BIJ7 npWkIiQFAHAwD61HJFlXsej/APCS6XtATWCVHIV4mOPzBqCTxNpYOTeWz55z5TAj8gK4RrYJHliS c1SkUZC9c88dqOSI+Z2PSF8Q6I5BaaI+hDkc/QinDXdLIIGohADwBKMD8jXmixKOg4+lDxADhgee lHJEFJs9Qi1uxfONUtjngiRlP6n/ABqVbuKZzsntJAeAEYH+RrygplRyAaY0QA6jPvS9nHuO560Q Cx3WytjuD1/Mf1o3RjICSpnsDjH615MokQgo7KeuQSKl/tK/iHyXtwBjjEpH9afs09mF7as9U3A5 xcSAAZw6k5/Ej+tVruGK5gaKWW3dWGCsijn9RXmTa3qZG039wfrIf8aRNf1iAfLfz4PYuSD+B4oV HzJ50Xtd8DTRh7mxCyJyTGpyw+meo9uv1riJrWSKUoylWBIIIwQfeuuTxVq6D5njcejQr/MAGquo 6g+qgtPZ25mPSRQwb+ePzFaRUo6Nkuz2OVIIPPUUu/kce1XZLVkbJHIPUcimSwK6l0Yhh1B/pV3J sVt4NAAJxnIpNpPQc0MrJgEEGgQjJk4HrS7CUJIOQcY9aQkjvmkDECgBdmFJPrxmlOAowMHqTnrT dxI6nijqACTmgAJAJ5PvSZB6mkwQO9OCkn2pgHbAGKcASMDtQF/T2qVEJIFK4DVQn1NXLWxuLtzH bQvIwGSFBJA/CtXRfDN5qrqwjaO3yMykdR7etegWmjW2jNDFbJgEDcSclj6k1hOqk7IuMW9WeQXU FzFIVeF028YIwQfeqxJB54r3i4sra5GJ4IpBj+NQcD8a5nWNA8PRBi0RST+5Exz+RziiNbmdmhun bVM8vijeaQIgJJ4rpdN09bZeQDIepx0q1b6fBbEmJCATkZOTj61djjVAWIxn0rRybJS6jGTCAYJN MLmOMkYyeg96mxvOATjNRrGXlDMMhenuah9zVI0LNBHbrnqeTVgMScjt2FU1kYLwcA1LvIUckk1l e5S0JXkODzx0qJmAXIP50xmJOD3qN3IXAppXF0KmoTBImZjjA4xXITEPIWAPJ7mu5k8NX2qwK8bI kZ5AcnJ/Sq3/AAgN9/FNGMdeT/hVqrCOhm4tnF7B1waXZ3IruovAEx5e5QEegNX7fwDbKcyzsxHY DAoeIgthcjPORGc8AnPtVu10y6unCxROxPYDNeo23hTTbYgiAMR3c5rXhs4IMLHEqcdhis5Ynohq n3PPNN8FTzMDc4iBOcHk4+ldfYeHLKwUFIgz93bk1s7ADggZHQ0vH/6qwlOUnqzRRSIcMgwCSB2F KGJ6g/jUoGDk8g8UFQOelSUN4ABJwewppPBIzmpCQewIHrTMryAKpC1IjKQMEcGopWPBAxmpmG7A AH40wqQMAjPfPSncPUbG5GARgmrAckDFU3iIOc5zT4mYHacECnbsBO5BB24z2pikjv0pu4k4IxTs E4IJFPUB+SaGAxyaQHAweaUkFcE4FFwTPMXGSGHAPX2NIOfwoU8YJ4PT2oz+prqMR5PPB7UA5ANN zzSkk8EDilsFxwIB6U7PGQetM5PApQR2HPahhccMnkmnA44ByKaAepPalBHTGDTGmPwO4HPrS4B4 FMyTwT0pwwRkk1Ng3Y5TjGB09adjHfrTMknqOKk4K59KQaBkZyCaOM9MU0YHQ0pPJHBBosAfjUyH IAPSoR069KerYHNHqGhLgZ6mhkAUnHINIByDn3+lByRyc+gpLYaVhnfPelzyc0gByKAMjqMj1ppg +wuTyQc04DsfrTc9+KVQSeM+9AltZik4GR+NLyTigEZGTwacQQMkdaNh2GEEHmlzxgdulDEA8jBp AcnGMg0LuGg/BKA+p5owSDx2pcYjAAJOaUHgkikhrYaARg8ZpM9znNGSOtLkY5FO3YOgFhjGeaQH B6dOlGARkd6OmPSi40hwJ6g0rOxAySfamBiMjoD7UuQaExWGXoc6fM0blXX5gQcHiufaeeUAPNIw BHBYkV1EKpJG8chxGwwxxnAIq1ZadbwwoLea2MYz5kkkYZmyTjAIOMDHGauLIldHH3mNyEjPyDP5 mqpGR6Vr68sY1F/KQJGSSqjoBnIFZm3PQVUX1ESQu0eCCRW9YfNGGwMnrWIqZ7g4NblhkQLjpVWB ssXQG0E8D+dZN0AXHuK0p/3s8SE4G7J561Bq1o0BMoIKE7Rg85wD/WjoTYwjgy9R6c10ng6DzNRe UgHauOnvXObSST07gV2PguErIWxwcZ96uIPY7pgNoBAIA9K4nxbBEIxKiKJAeuB0Hr612jk7SegF cf4gjjubmNZnCQx5eQ56gcY/HNTO1rijucqlm32YXZhKxkkEgcfX2FVp7mUnyo12p3yOTV7UtaSd DbwxARKML6flWVbyyIwWU7o+wPJH09qzjF2uzXmWyL1rEeCBz3Jqae6CDyYep4JHeqcss0sZ8kbY wcEgc1LbQMDkg57k+lQ11Kv0LVrFhsnLOfSrVxeCJfKiOXIwT6VTkuliBjiwXIwTSQJhtzcsTn6V NraspGhZRiMb2GXP5ip7i88pdqtmQ8DHYen1qlNdLApRSC5H5U20jLuHc5OcjPaps1qBrWEWwea/ LkfkP8akubt3kEKEFzwAOwqpPdi3jCqcsenr9asaRGoYzSkb+SMnoPWjZXBbm5psEWmW5nk5lI69 +ew+v8qiluTKztI4EjAlm7IoHAHuf89arXt2AoY8knCJ6+59qx72/S2gZpGyq8nnlm9BRFfeDZd1 nWSkENpbEm4kXbEi8kEnAwB1Iz+JJNcdd6NJBDI04BnB3Mc5IPcVGt3cHUDeSklm+6QMhR2AHpWk 08mpRspIBIJkc9Pc57VpqrWEkmrszobdWjBUZBHYU/7MewGBUtm4MsgDEoDhT7DgVdBiA75zyMcU 23fQEkZptgRk00W+TgDp7Vp+ZEOoGKPMhx93k0XYNamb9mxkkDpUbwhBkjjGa1TJATyv60zEJJJF DYWMoRAgEDrzSiEhgQP6ZrWRbUAAqcdDg1MBYsRtVwMdyKOZhymTDAjnLFwB2ABq2lsgceWpIHVm POatSRQrIPLBwRnn1py4HBHFJybFZLYihhYzjbxg/jV0Wx3AkEDOTmnWxAkAIzmtJggGAoOfSmrs l7lB03nJB4HA7VUkCqwwowBgnpWq7gdQMdKqStCQSR+VFwSZVwpUbTg/nTGUZz3p7ToowKYZo24x yPQ02tAWjGbAeMH6UhiyAQTnOKXzVLDDYwelPEiAElgMdaktIiMRCkg9vSqzrxnn0GKvs4MRK8g9 KqEBmUHGM4PtVQ1JmVPLJJABJ78Zp5i4GRg1M+otFIyRIojU4BA5PvSpfiUhXRTnr8vNXdk8vmVj EDwPoan8nZGAAQT3qYQjzgB0znn0qz5ahWlc4UdeP0pN6glpYzDblskDtzUMlirDO0A+o4rXW4ti MgHB96aUSQ7ojkHqDijmd7NByvc559PYE7eT1A71BNBMBtYEgcDI6fjXReQckgU9YAT8wBx14ouK xyXlvHkFQcjAyOlRGM9Mdq7B7GCQ/MgGe44qNtGgboSPyo5w5Tkth5FGzB65rp30KMnIf9KYNCiB B3ZHsKfMhcrOcC56ZzTljZjwCPwro/7GhQZJP14FKmmJk/LweBmjmCxhxWxLDIJ9cDNdfo1r4dtA kt4008o5wUwoP0B5/H8qpC2AGFUflxTlgwOg/ClJKWlylodrH4l0mCMCGW4AxgKF4A9OTxWffeKY ZZVaCByV6FyAD+Vc8sC9xzUqRBeQOh5zUKEEO7NG412+u127hGp6hBj9etUQCx3uSc+vOacEyMYA +tP2BRjOSOaasth3uREYI460nJBA4qbBY5IAz3qKQsCI0GWPp2HvSbuNIME4RByep9BVgRBYwuen Wmxx+WuCck9TTycgAZqW7lJWY0IQOoNGSOM8inHAGBnJqPIByTz0qWrjFJOMk5Jqzp1m1/dqoB8s HLH29KrRo9xKsUQLMxwAK7HTbJLGBUHU8sfU1nUkoqyBK5djQJGqqAAowAO1OwSQAMUoKnJxjNOG 3HPOawS0KsRFCDyKcAR/+unOcggHH1poAGATTtpcQ7A74FIQB1x7c0uDt+UDPeo93Y8GgB2CTgHI puBnoRinIcE5PFKxBIAP/wBemDGg4XAHX0pSeCKXAPCnGB2oII4J/GhC2ImBPA496YQQMAc1Kw+X AzUZJXqM07hqIMAYPWlXBBBxntULuQcd6cmTycn3p6bgOdAOg6dqgbIOQDVggjoT701uRj86aYPy IlB3cgVLgjAHSkZsACmCXnB//VTBIcwI5P6UgIGTj9aQuW6HFMIYHpn0oA82GQec0pJ4IpoBHNOU HjI4rp21MQAJIp2CSOtJgg5x2o565zRcNOo4nGadk5pgz0INLzyOwoDoP5BwSfrS4I7/AJ03JPXm jr1OaFcEOyfUCnZOR/jTM4pw9SOlIGPGeMU9SA2DnHeo88Y7GjOBjIoWg9iQggkE0Z45pCSQD6UE 9cUaoBRkDkGlB54GaYCTSggnp79aTQaEoPOcnpQW5GCeO9Rkke9LnHUmj0BvoPyepI4ozkHPB60z PQUoOR0oYC5IOBUiHDAk+1R84zSjGQQelA7W1Hcg47VKwLICCOO1REjAIpwk/vcjpxR0AawIOCet OVsADFDoRhs9Rx9KYAdwBGeaQFsA7Rx+lMZgOCM5709nUALnJx+Iqu5JORn0FGowYgnINJkkYBpF Izz3qQlVJyM596YWIySeM4HanA8AZ5FMJBPTikAz1ByPei/cpJEoIJGTV6G3MkRMaCRgclR1xWdg DBOelTRzNGmUcg9iOKEkJosiIxsyMuCQDjPT2qXSwjQSo2SYySACBnBxVJZWMm9mJJ6knNRTNLFL IYpWQsM8HGc1S10IehQ11CLmMk9Qe3vVBCRxjgVPMHliV2JYgkEk5P61XQEE81cdFYl7koOASDkk 1r2six24LEDjuaxRkt16elXAFMQLlweCDnj3/pTbsCTZemmRyhUgkHnHWmamryuAmSWUEDPeoIhF tJDEtkYyO1ahMAhjeUkPkDgdsHP64ocvduFtbGBFbSjCMpDnjH1rvfDMSQo2SOBgfXpXO3Uuki1j cJO0wclmLAZGBgAAHnOec1veHVYachYEEkkA9cZ4/SnTk3uKStodLM48skHI9q808XXDNqSxhiAF yQD6n/61d/IWWInHFeZ69KsmsTE8gYUDOegqpbkxRkqp3DAya3dH0iS/kBIPlg4LY/QUmh6DLfSi WQFYQc9Ov0r0Ww05IIFVFCgDjAxS8gbMdfCtqVBUsj7cAg8fjXP6po13a5iMigEHBGRn/CvRduwY BrD17UbKzti1wqu4+6vBJPtUyhfYqLdzz+C2eJipGCDgk9qla8jiBSIhn6EjsarT34uJWdyFVjkq hxge1JbxKcNEwKEnkjBqLW3NE7liFGd9zcsT35q88620eMZc9BVM3a2/7tPmkPp0H1pkYeR975LG pae5SZdgV5pRJJ8xPQHoK1Q6xR72PHQDPLGs1JRAmCcv2A60w3DFi7nLHoB2+lQ1d3Y09LF27uwg aaZgCAM89B6CuclvI765BkYqinCoemP8aL1L27fARgg6D/Gqv2KaLJkiYD1I4qopb31Jb6Fm6lRM glWGAQoOfpk1XUzzg5YqhxwBxj6U9bNyQTE5P0NTeROAGETgdM4IquZdwSFjIiUBfxPrTzKcZJ6e 9R+VMesbflSeTLzlGx9KV0O4pmyeD700ykcA5PfmnC2kAwEJ/CnC0cDOw49MHmmmhERkYnPQfWnK +cdcmlaCU9EYD6GmLDcKc+S+PoaLrcRKxKgg55Henx78gAE++KmhDMMSQN9SDzVtUTg+W4IAHANK 6HfqNJxtJ4PSnqQcjPT3pLkExgpE2VIONp6VVEw4PQ45qWUtTQiYCRTkYzVtpwSQeaxjOQMg8g55 q0jyOAVjYnGcgE1SdlYlrUuPIJFKkjHPfFUXAKAZ5700XKgYLDIPWonkUnIbqc8U0gHhFLEkmnGJ MZzUXm9ww57GnbwTkEZx3o8xX6jJEABIIP0oiCupDgHmlJyCf6UwEqemM0ntYpMmlk2xhFGM1Rnu Uij3sCOwGO9SurO4O7AHHFVLkMyFWGQDnIqoOzsTJNkCSs+DtPJ4q7EgiYM6HHBHuKi2qIVIBz0B Jzj8KeCcEmQNgYA9Ku3cnbYum5AZ2AAGOMdqS6nLQIu4gE5IFUwWBySGBGMDvVdlMtwV3EA8gZAA oaW6BN2JQUY4B6c1e09CCxLcEZwTWfGFtZhvCkZycc5q7ayqWJUAA5GD6UnfoNM0MAnIOBTwAOAf emqQQMYx9adwDjH0rNtotJC4BPGCTT1AxgD3xTOAOnWjHOc/hmhSuPlQrAZJB5HUCm4c8AYB7+lP UquQCAT2PenI4C4Bz+NF7CaRF5AByQSR60eUCCcfpUoyGJJ4PQCm5Ynv60c3UOUi8oHoP0p3kN0x Uq5HX+dS8gAjknpRcTSK3klcZH40oUDIHP0FWMFh8xIzSEIoOSAPUmhuwJFckjkD24pcEDLHHrTJ JctiJS2B1HT86jMbucysMf3QeKL9WO2o9ZGlO2HnHBcjgfSrCwrEuF5JOST3NRK4RdqjrxxTt5II zik2MVjngc/TvTlKqMHrTDnbnNRO+e+KQD3fJ4xTER5ZAkYLMTgAUsMEtzKI4gSSecdvc11mlaVF ZR7mAaY9WPb6VE5qOiBK+4mk6WtmgeQBpGHJ9PatfC44Htim4GCOOtBIDAEdBwM1hu7sq1hykDk5 Hb3p4ZTkKvPfNQZUZB65pysOuB9BTtYLkxAPBxzS7QBzTVfAyQPWkL5PU0luA8OCuARUbBTyOtBJ IByBTQcjkZp2AaQc5BOKFyxwcg9KeDkZBpWcAYJ/Gk9xX6APlwAMnvQ7tjIGKbuUnAPIpN7k44x6 07DE3kDkZoZwV5AzUZyG56U7g89PrQ9AInCsMcD8KVBjgHHFO2qewoAAJBAHpQLYMjaec+lRMzDO BzmnyA4AB49utR4IPJPSqXmFwYEjnn1pvlZ5B5pST0BB9KQEgYJHPSmFxMlDgDIxSq+4kCgg5JJz nvTGBGABzntRYZ5zuyck8daeGA4I5zUI4HHWlBx1NdNrmF+hPvGKUEDnioB1IGSacM4+tDQD8gjI 4oBA6Ck+gpfc9qLDDI6d6cCcnAFJxjvS4HbH40ri2DJJ6HmnDofc03J9MUe9A/MfyRwOaUDPI703 B6nH4UuQOSTzRcRKvIIzjNNJySc4NICO/PNOY5Oex9KRWjQcZPU0AgHJP4CmknOB2peOv4U/MXoL k5zilycZxSEjHXk0hOQB3oD1HZOTnFOBxwR9KZk9xSg9CDzSsD1H5HQmlUnI+tMGT1/ClORj1zQC JBgggdQc005HTPXuKaGw2cdadk55/Cjcd7j1ZiNpOCOQDSq4LAEd+1RZIwSe9SDDMCBil1HYJCGc kEk5/KgOQMDB+tMYENk9z1pQTnHHPtRfQaQb+oxRnJwaDjOcdKTof1pFC5BOcHinAEtxkU3ODyKc GHTFADgoOMcgetGw7cnOKUEAZPXrUiMCQrYGTTXkLchAII96vxi0+RpnIkI+VCPlOB3P1xTJrWWF csqFDyHDAkj6ZyPxFVLgDy4mB5DEH6Ef/Wqouz1JkuhduLcCzeOWaGZ2IYGNMBRzx0HtWDJZlckD 9K3IUYxAkHBGc47VH5IIOOfpVxZm1bY54IUbkY9a2IYke3UFQRjjNMubUEFlHNLbyEBVKnI61Vk0 JaCvbIi5UYI5zTbgbrKNsEEZA9qtOAUOPSocK9uFdgqhgCSOgprYNShp1i13cF2yY0YFnYnA9h7m vStMtkjtEAUdBXmNjPJ9rSBHLRGUEKOhPQGvUTOtpYAjJYLwO9VBWQpWI9RlEcDkDoOgrhtP0F9S 1KW6nBWEuSoPVuev0rqbZ59S/wBYmxCT7kitqK0SIAAYAAFN7i2G2dhHbQKqqAAMAAdKss6ouAOl MkmESEnJx2FZF/qDE+VbrukPfsPc0mx7kOveIYNMgJJ3SEEKg6k157KL3W70yyluT1wcKPQCuwXQ I7icz3ZM0h5JboPYCtKHTIYWCQxgu3QA9Pepbb2Gmkc5pXhyEOiCAySHq8g4A9QK7UeDrW7tUjdQ jryHAyR7fStTStKWBQSuWPJOOtdJCkVoivKMucBVxnn1PtU+zT3Dmex5J4r8BnQ4Ir+Ji0Uhwygc r7kdga5N5xB8iKWY96951KZJ4nE4DIQcg9MV5tqltay3bC0gAB4Zjzn8TWc7wLi29DiHkcjcc8no O9SWCSTXilm6A4HYDFdN9gUgqyrjGMADFRwadHazmZATkEAY4FZ+0TWxdmPtLJd4aUd+4rSaVIjl QvTAYjJH09D71DuOwYB54+lJ5TPjPI9DUKQ3FX1FWJZAWABPXJ700ooADKCOhBGQakVNoAAOPQU8 BSpBGD70t3cNEtBIoLWX5TAiv2+UYNSGwtwMGJfyqKRCqEp1FTW84KhZSM9iTW8JRejM5J7oQWVs M/uU59qetlbf88U/KpWUgZHIqNZiWKlSDkgVsoRI1HrZWpP+pXP0qUWNqT/qU/Kmq+eM4qYOQOaO SPYLsRbG0PWBB+FSLY2hPEC+mcVWa5uVY4hJUHHHcVat5XckshXPTPSjlXYLvuPGnWhH+oT8qqt4 dsXcsEC5OcAD/CtEEkEH09KkU4AHXFL2cXuF2upkHw5ZDqP0H+FTRaNbQAhV3Z6A9q1NgJDEcgcc 0uOc0eziF33OK1zwyZczWihXByVAwG/wNck9rLExV1IIOCD1FevugY4Izn2rC1bQortC6gLIOjAd fY00rA9Tzvynzgijyn6AfWtG5tZrWUxzIVIPB7EeoqHcOgGPerUU9mTdlQpIBkAmmgzA4w1XMjoS KbuAJOOlDiF2QCWUHn09KR5A4IIGCKuDaRk4zTDGjckdKnlLUnaxXtLOe5jISB3I6EDgVA0EqSMr EZBIIBzzWtBf3Ngu22fapBHABIz0xn3rNAeRiWOXJySe5qUpX1G2rX6jBE4BIGMcgmomJDBiMnOP TFWijgDAOO/NNZCcBwcZzzRqCkmJLECqEAHIyec0RSKHyowDjjtmt+efSE0lViUNPjBHl4Kkjucc /mawhgnlV/LH8qUW2tRuy6mmjFkBVgaQu4HTOPSqUUnlnCgDPapBd8HIxj0qXF7lKa2ZaWc4xnp6 ipBKc9Qao/aUyTnoOeKkWYE8EfyqXFlqS7l3cCMMmR6daiaGM8gun+6SKjWUdM/lTvMB4B/Wkk7h dMkEcmMpck47MAaT/SlPymNh7gio/MwOCKPMPrTDdEu+6zkiPj3NOD3R6tGMexIqPzGx1zmkDMTw RQmLQnAlODJOc+gGKk2ICSxLEdMnNVgx7mnAkgZPFL1GiVpQPlUcVGeTnJPPrTcDqTk0m8A5HajS 1g2JVx1PFLuUDIxUGWkYBQWJ6ACtG20a8uACyiNfVuv5VMpJbsNehRMpPB/AVds9Knu2DMCkZ6k9 SPatq00aC3IZlLyerdj7CtFVKHIGPrWbqN6ILdyG0sIbSMKigep7n61a+ZckcUAHHA/KnKGJ5BxW W7GKC5XqBmkwx4IGPWpCAOMY9qTIAxtyD3FUgIgrEkAdOlSKhOCRgjr71LGygYJwacVA6AUavUCM 7s4xx/KlQEEgNn6U4jI44puCvOaQDmDA5J/Go2cA4I+lPyeOcj3oYrgDHWmAgJAyBTSpI549Kcfx /Co2JDck4oXcVhcADAPJ9aTOOxGfSgv2Apc/LjIz2pjFwWA7n0NIVYjHSmIzIckZzUobIJ5z2pCu M2E9TjFMJ2kg8+9Sk4wSSKilAxkHIoGhnmZORyRTWBIzzQq4OQamBB4I61QEBXaAQOTTCDjORmrJ UEYPHpUJ4B3DgdKasJkZY9PTrS5I5BpMAnqOacwAGBxxQB5oOwpcd8ZOKRTgdc07Ixkd+DXUYgDj kjpTgSOQf0phIPFLnA6UmCJM4OKMZOP60wEYzSg+/egZIMY6/rRx69Kap9aUnJ/lQLcXBOM9O9KA QcA8GgNjigHnIPFA2rC5wMAilzjg+lGR0zRjkgdqQkmHOMj8acpyuCcEU3HFKox15FA1oHAORS84 pcjBGOaMDFK/YBM89DgDvSgHnNABHWlHJ54p3AXGcmgZzg8UYJPFHfpUjtoKCQcd6dnkmm4OOvNL +PNMa0EJOeOlKD9TmkIPXGc0oA6Gi4hOpzUkZKsMd+KZgAjIJ4zUqBV+YnJHbFJvQaTew3JDe1HB 5AwfSlCknp1p2wnIxip3LS7jAfzpcj1xSZAOD1HGaMEdcUBYMUuCOBQCOg6UpHcHpR1AVSeg78U9 QcEnrUXIIH41OMEZ6D3poTEZmIAJJxS8NC6kcdR7UxQzMQAT9KenJKnIyMGrW5L7FawaZp5lJdkD ADkkCtRcA4xjA5FQwiyuIo4nM6IjFiqEDcT6nGe2PanXVzuuiygKrcgAYArTpqZtMfIisvSqLIUk JHY9Kt+YScnI9KidlGT1zQrg0R7wAATnP6Vm3NyQGiVupwf8avuSSADjmqq2ok1GFAu7LDI655qk xNFzw9Z2yTCdyC6gsAegrq0SW+Kgkhe4FZF5bRQSKkQK+ZgkA4AA6Z46da6TTJYwiKCDgAccZ960 jqrEs0rS0SJQAAMCpLk+WuQR0zQ86gZXOMVnXru0LO5KxgfiaTYLUz7ieS5uCsTHIGGOeFH9TzUk FoqKADkg5JPUn3rmHv7+W8NlaqEVmOCRg469av29trMV5HGLgjcASCdwx+PSouupVmdCygYRRukP AA/ma19M04IAzDLHkk03TtOKAM/zOeSTXRQxLAgZhz2FOwh0MKQIHccnoP61VvLoAF2bGOaLu7CK XZgMc1xuraq10xjjYiMHBI70pSUVdlJNsbq2qtdOYoyRGDyR3rKLYGQcD3prEjpyaTIcYbgiuKc3 Jm0UooapJbBGKkCkjAHGPSnCMEYB6CpQMDkdqlIbZWYgAAk5pwfoRjPapXiVxkgA+veoDgHjnHFN aaMT1JMg88A9aMgcj86QE7MACkKArkcHpTEIxyDgnI6UzYCx56ingFV5BJpoPzcjFFgJYrloCFkO 6M8e4q2UVwHQgg9xWc2c8kc1LbytCcg5U9R2raE+jJcU3dFvpT1YHrnikGyVd6HPqO4pACOhrfcz tZ2Jlb3qVWz9Kqg5OCcGpUfnOaAsWlb3walUjPXmqqsTyKlVjnjpQBaVgKeCDyTVcMc8GnhiRzQF iXOe9IyAjFNBxx6U8HjNAGbeWEUwy6AkdCR0rHuNPtkOHgQ54ztFdSwDDBHFVJ7ZZVIIB9qzlHqh pnKto9lKSVQofYmqsugJuJWRgO2Rmt+e3aAnC5FVsseDxk5rHmktLlpRfQxW0GcKCkiMPfIqq+kX sRJEZYexBrqELIeoOeKlLkDlc9+KaqzQOmji5bK6VctA4HrtNUgkkbklSPqK9CXa6524xTZLaOXB YA49QOaft5X1QchwgcqQSOO9OLowzgcV2MmmWrg/uEI7/KOary+HrNgCiFSewY/1qlXXVEumzkGR GBI6nrToVXPzAGuml8NQk4R3U45yQR/Kqh8OTrnY6sQccgiqVaD3BwZlGJOgwKYbdT0PetGTQ75C QqKwx0DD+tQjT72PhraQ/QE/yrRTg9mQ4vsZ5t2JOD19qUQOCCORVxo3QgSKyn0IxQAe9Oy6C1Kp RgcEECjDDrVsjPWm8ego5QuV9x6g80oJ6k81NtU9V60qxKSB09OaORMrma2YxNxIwalMbjncPyp6 QDcMGrDRE8D071DjZ2HzMpEkcE5p0YaRgoOc8U6SJsnin2iN56gjuOlJxSVx872NqHw6GAL3BORn AGKuRaBapyys+OzH/CtRACoxkHAFP44HIricm2borQW0MQIjiVMegxUykggAfSpdhxwOvtRsAIJH FQO4mAecUYbPtnil2HBIyBQCwA2jOO1UrWEyRQoAJHNOyMZzUe8jqKFyTkknnpRYB5wcEjmo2yAS DSsSpIJOPbtTHfPIJJoXkAKGJyBn0qUOwxnvTY2JOCB+VPwCOuDQmAocen50m/J4HFIQSAScYpoO ASefrR5gKSMYyPrRk560hKk5xQuPb2o6CDIPQkmg4IGOlIwGcg9KQgEZB/CmO9xrryCp703kMckg 08EAkE9e1Icg9AfrQhWDJIz1xSeYQcZ4pQRySCD70jAHoQSKaQCmU4zTC+SSe9N46E5x7UoUsxIx zRsFwUgkml3EYFBXAycD6U3B6g/SgB+TnGTUbEE4OeaUFskEj2xTGQk55NNAKsQIzkg0jjAwD+VN LsDkA8dqXcfQ4NC0A805B5zSgk9eh4pMZAJPSlUDpiusx8hRgHpnmlBPoKQHj6Uo5IP6VPkG44cg DGaAQDk0hJ9OBRnpih9g0H8H+tL0wB0NMB7HFKQTwKNhjs5HJpwweKbgkZ4owcZovcLodkgmnBs9 6Zg9SKUZHOD7UwH5OaUZ6D1pnUU7PftU2AfkEZ7nrRkYwelNGQOOaXPPNKw7C5HYfnTsflTOT0pS McZoEkP4HfgUoBzjApgOBShjjOe1LzHYXAxmlA4poJHBFLkEY45pj6C55Hc0E88UgGOoNLgE88Uv MaXUeDjGeakQjIJAI9Kh9s9KkQce4NTe40uxYKqhGBknpjtS4VOSDkikjJOAfqOKlYAjLHgc4otZ Bd9Sk2Mn60gBxweaUkFicdaQkjBH40blCAc5/SlyOh/SmnJPWlU5OOKBbDhkjrTixCAAd6TGE7Zp mTjnr2phYsREcAvsOeoGacx/eAhtxJ5OMZqqpx1NSKT6cVSE9SPesV0VLAHOQM9vWpZJo2YAEE5q O4s5bq4h8lSWbCk9gSQBk9u9MSzUwXDxTBzBgPxgcnHB796tK+rMnLoWRJleCDzgYqNyCcE+/NQR AhuTxT5DgZHNUtxX7jJZduTwcDiq8F2yTyEAGRlAU/3TuByPyx+NR3D570adbm5vlODsXk+/pVIT VzpoDJMFaXBYgA4rTjJiUEHB6A5qvBGFwQBxTrmUKpAOMCqvbUlK7NGHU1jyZZFAHBJOBVme9gli DJKHXGCAcgmuGjibU712eXbbxnBJOAT6Cuos7cEJDCo4AAA6VlKprZI1UNLsbNAl3cRG0iKSg4Zi MEDHr+VdXpumlcM/zOQASeuAOKXStKESgkZY8kkV0UMKwRhiBnsKpLqzO/RDYYkgQMwGewqvd3IQ FmYACnXd0qKWYgAfpXF6xq73DmKJjs6E+v8A9anKSirscU2w1bVWuXMcbERg4J9ayShx8pBB55ph fcBwCfSnZPAAxj3rinNyepuopKw1g2Rg5I7Cm7HGGB59MVYQZ5yc4pxQk5JFSlbUZCCwUAjHrTlZ iMHrU20YwBzTQPXAxTVxNFdnYkqSQc9RT0Uhe5PUmnNGMnBFOSM464AoAYBkHijBAwB781IQAMg0 0kkjFF9RbELFhj19qiRwzEA8+4qwSS2COnQ03YAc4AwapPoBDIMMMg+1ChgOR9KmIBHIpMEgHHAo TswGq8kRDIcHPT1q/DMtyvTbIOqnvWeygHIPfpTGmwQVOGHQitITaJa6mryCQwOaUZGMmq9teLPi OUgOeh7GrBBXg5rdNNXRFnfUejkevtUyvntzVcZHQ5p6tjmmBaV6lVgeh6VVV+OakDACi4vMsA9j TwSRgVArkjHpTww9RRsImB44OaaRxk0gIPQ0tA7WIpIlcHIBrJubIrJuUkD0rbwCKjdARjAxUSim hptPQ56VgvJJyO2KkjkDgEdT61cuLQZ3KOR2xVKQiIZYEAHsK55RaNU00SHK5wAB14oBJ6nAAzUc biXLDJApdpLE7SAahsfqS7w4+VgCKWPJbg9PeoViG7I71MoVCcAnHNF0P0JRk8nr3pSGXDEAA+lR hyWweB60rFjkAnHvQwJMLnOBTgATggAn2qsgcHDHI61OMkjI60g8xxiUggqCOuKiawtpT80CY/3R U4YA5PTpTw6jtx609d0BnvotjJ1gUdjjI/lVWbw7aEEoXX2DZ/nW0TnGDkUoGDnIxQpS6MTjHqjz nUymnanJbfMUXGGPXkA8/nT0dXUMpBBHBqv4mIOu3PPAYA/kKr6ZISWjOSByK9GN+VNnNLc2YjyB nNWM8kDt7VWhHzAj1q2OAR3qJbjjsVZDk+1S2SEzocdxTZUyDgVPp4BukBB+8Afzok/dYK9zsI8B Rxzj0p5HGMc/TpTQCAMcDFOyc5yK861tWdQoJAxnmlODznpSHik5wSM5p+YhxIJBxj3pBxkjHtSZ OBkYoBPUDmh7ADAEgkYP0p2ABjimtkHkUEHg460tBi4GDz9aaVUHgD64pwJA47UhbqcY46U1sAik DJAoLcEkc9KaTkY7H0oPyruIJ9vSloAu7IwTTCDnBORTshsFRg0oXPJB60BcQEdMDpTSTkE9M1Lj JGOKYy4OMg+1PcAzk5HSmbscEGlIIGPX0oJAGM5zQIMAEHilZckZNMJOcA5p271HTvQMXYD1JwB6 00p6HA707cp6mkIGcjn2pi2GMgPIBA70gJAwOvvTySQQOKZyM4H4mjcLjC5Jwf0pcnBANNJJyTgU /Cn39xQMarEA5wKXOTgGgrzg4x0puABwDTAdkZwR+lNDKRwORQCOmTTgADwc5oewjzI9R39qXgZz SDBxxzRnH4V1GNg7ZHSnA4PNN746fSlBPAJpWDYf6HnmjgEHPFICAPpSA88jinqDH5HQUuQDjjnv SZBHSgYHWkMeGGOnTmlznnpTR+HPWlBBzSt2AdkEYIpQQcAikBBzxR174prsA4Y5PpSg5zTQPfNL yMfypMB2eeB9abnnpS4OPWgjjNABkYpcknkcUmSQfQ0AYxk0hp3HAnOR3oHHJzRgd80Akjp+NDHs OznpQBxnvTcknI6etO4BB9aQJXFxj8aXgYJHGaBjGKTp2pPsVFWQ7GBweadGQAc856VGSScjHFKr 4PFIHsWVcEZOcjoamLb4nIPOOxqmpOeuKnVguQCOetF3YNCDIBHpQSB05odcHGfpRtJAIoGmHvRj ng0bSCc9qXkckUWY2wwSeKTBJzjpRuzmlBBPHWmhO4gBPAFSYUcFxkdj1pm8A+4qTzxtwETPqVBP 59aokebuWCLEbYUnDDsR2zU/2tri0MJVVU5OEUAEnucdapcSRsowMjNRRyzIp2qDngGqu7WIdkLE MKAcZHBNRzvggGpMMinPXkn61VmYMxBPQdKtJ2JKsxJOAM5roNEtPKiDMBlufwrEtIDc3SKASCcn 6V2dtBsQADAAx0q0hPYlAwCT0ArH1e68i1dwfmwQM+p6VsTELGBk5NYM1lNrOopaxKQikM7dgOw+ vJpSEn1M/Q9OutTuBEhIRSST2BPU163o+kJawouCSABk9ah0LQodOt0SNAMdTjkmunhiWJAxH0FO 3ULt6D4oliUMQM9hUF1dBFLMQAKS5ugilmYDFcZrGrvcsYoWIQHBPrSlJRV2NJt2Q/VdVe5YpET5 YPJB61hvuPJGBUgcqADzmnlRKMhce9cM5ub8jeMUiJFXABGD61MsQ4Yc5p6xbRnANPABAAPOegFS ihgXrgdqUIQMc4AqdUXA3ZBFBQE4Uj6CnfUViAoTyO9JsBJzU5RhkFSBSNgdCDmncLEOD0wPypNn IAJFSjrTSQDx+lNXBDSijAPJ9KaQM049sUrYwM8mk1YLEW0Fs9KCncnI64p4weKACetMLIhI44HW mMSAABnJqwFHPTNNZAR0AxRpcXqVCmScnk96aEVeAOR3xVooBz1/CkKKDkDrT9RMr7MjOCD7Vat7 w5EU3PYN6fWmYGMYpjrk5AxVRk46iaTRpFMAEHIPQ00HHArA/tl7K9KOC8PAK9x7it2GWK5iEsLB kI7dvY11WukzPZ2JVJBFSBuxqHucdKVTigC0p44NOB7ZFV1fB6VIHHFAWLIP409W4wTiq6se1PBz g5oCxNnPNAHcnrTVYEUuAelAhGQEZNU57QOCcDP0q+cYpjKCc+3Spkk1ZjTtqYhgMYKqSpHTFKpd B8xzWjNAHGSMHtWbOHiPIBGa55QcfQ1jK6Hgcgg4J5AqTaD2JJqIOHIJXBA7VOJE24AwelZ21KSI wFDEZwfSlJPGB14owpOTnNLuUnk9O9PQLBgDjH1p2AcAHGO9ISPTJoUqeCCDQg2Hj7vJyfU0pOQA COKbx0FN5HU/SlbsMcHI4HGKeXwo5wKiHI565pjt8pycYppAcbrumpcanNKt3Gu85w4II/EA1Std Oe1mLmaGRSuMo2T+Rwa19WiDyFh39qybZAs5x1AOa64ybSRhKKuzRgGHA4q7sJGAKp24HmAgZq8x IXjAFOejJiu5XcZGSam01QbuMDswqGUgDAPJqzpQBvYyf73NEvhbBbo60L8oOc5FIFx1Ofen9vlI 9qQDIGRzXCdAu0gZ603OOp5NDORwKZg4znPel6gPByQT+NBwAQBnNNGcZPHpilORgk8GiwEgyAMg 00EEHPWgOSQO3bNGcHJ/SgaFyCRyAfamHIJAGfc07Ocjj60Yz1FAEfTrSebgcgkE4qRkBPXimbDg 5OM9KEgEwCQeQDUqnA4xg1CiMeDjANSjjp2/nRZC1Bgck4+mKTtkg5PvTlOScnj0prgDgnihDEOe hFMI7kY9Kk+ULgHntTWUnvTSFcizk9KN4BIxmn7MDg0hiA5JzRZDGgg9qcSMde1NII4HNAHc5o2D YRyAuQck/pSA54JpxAOfQ0h4AAGaPIRGQAccUoLJxnj6UrE8YNNwQck5pgO3ZHA/Sk3DGDj60gye MnmmsMcGhAK3JyO9Ioyck4pASBgAYpQcEHNNA0eaAnHHT3o5INJkDqeBS9Peun0Mh2cDmjOOxpuc dKC2RjJo1F6jxzjApwwO+aYhz0zTwAOe4o1sFtBwJPagDBI9DQCDkjgmlzzmgYpGPf2o4NO3AqRt 59aTgfSlYGgA4449aBkde9HJOB0pQeQcYo1AcCcDFKcHmm+3qeKXqetJldBckdaXPBANIOAcilwD g4PpQIAcE5P4UoI9zSYAPNKSBjByaBrQXIxj19aMjOBmmE57YpaQDhxwaUEDFNU8kY96UkY6HAof caVxxP40oIJ9M9KYcdRTgcY6DipHrsAA6U5Rk5xmmAjp+VPUk9KQ7WHhDgnI4qXaOtRgkDA/HNPB JAOOKNQYrIXAA4pgR8jAORUoAChieQckU/eoYEEc00tCbjShBBIPPtTZFJIwOnep96vjn9aRiCOM Ed6dh3a3KbAgYximZxzUzKCxAGAaiKAqeelC00HfQZvJOAck0uTnHNM5U9KlQg9QD9apLQl7ixMd +OADwavLHEYhHa3UaMWBaSQEYGOQBz3zz34qk4UEMCMnnAPSqzkiQnkDOR71UWTJXL2ouqz4QAoQ DkDGSOCax5WJkyOhzVvULhNkSqQWJyQD0BFVowZXVVHU4FWtrsi1ma+hWuf3pGM8V08a4UAVnWMQ iiVR2FaK7nIRBljwB6VaWhD3Inia5l8tByePpXTaNpCW0YwoyeScdTUem6aIgGYAseScda6KBBEg JAz2FHKtwJ4o1iUEgewqK4uVRSzHGB37VHcXIRSWOAK5LVtVa5YxRMQnQkHrSk1FXZSTeiDV9XNw xijYhAcEg9TWQWBGQPrTSCFwT75piqzDIJyTXHUm5M3jFRRMuGAB49OKtxoSMggjHSq8a4IJwCBx VoMoGBwR1rOw0x5UhQRjmkiwSSV6dMetNDkHGcipQxA54BosUkNAJy1PRyDkEAj0FRMWPRgKcoIA JbBz0xTtcFclkLEexquc55qSQkgKSM0wjAwCcChIT1EJwMAAZ9RTcjHIp3BIwM5pHUqecc0ANUA5 PWlKg9B14o2lSCBkHtRvK5APXqKNxIaUCkjI6U4ANwKRSewzUkeOhBFDBaibAATxnGajIB5HFWGA CgAHjvUTKM5JH4UK4NELLjp+tNIHTrUrcnB6U1gQKpdgaIcAHPbFBwwJ7ClYEnAqK4YxWsjk4wpO aa3sKzsctduHuXYdyansL2aymDxNweqnoaqMSScjvTk4GcZrtSsrGG7O0s72G+i3Rna4+8h6j/61 Tcg4I5FcVFcvFMJYWKsOQRXTafqsV6BHIAk2Pwb6Ukrq6H5GiCACM05SeoPWmbSOoNJkg9KXoBZV uOuc1KDkYBqpvPHFSK/QE/rQmHmWlYk4NPByKrhgehxUitjvQBPnv1pcg81Fk+tO3c4oCwpAIxUE 0KupBAqbOeKQjHB6UmrqwIy5ITHwBx0qMggjnFaTx5BB7nj2qjJERIDnjPIrCdOyujWM76Mi5I54 xSgHGQc1IFBJUHINIYyoIPTsTWFmjSz3G84z3pu9lIyCc+najnpjFHPQEinqA7eRyeaPMJ57Uw4J xnmm/NngDAouxE3mZPA/WmSuSpBHFHQZ7imSEkZANUlcVjLvArKcjpWOIgkhIHBGK2rlTgnB5rMl GMkfStad7pETWg6AASD1NXGBIIHaqVsf3gHv6VbkJHAPFbS3MoleRAAOScVc0cZvUznGapyA859K v6Ln7anfk/yonpBjiveOqBJHXA7cUpznGBSbgOo470pYEZ71xHQNAyMcYpGGBkelKeBnPvSAjHNK wIaMkYpQSQc9aTdg5FNzzxxQgsO6nkflTiRgHHtTAT7E/WlJO3GaBai5wfWnBwBnB9qiySDjNG4H jvQ7jsODgsSelPOMY5wahAAOSKcSQAaLdWFuo8HBOe3tQSSQe1MByCcE00scZPNFgHs+BnIyaazF hgGmckE4JoOAAR3osFxwOeDzUgOBgiolwDknkc0/IJyT+BoQtx+ODg0nUccUhJxxTMnPXNOwwYkH im7gTnke1OOSST+VRMSCe1Aa2HZ5II4pr8jANN3kDB6Clz3osIbnHA6+9BJA569aXaOpHWggYODT 2CwgOD15FKSp4NM/nQCR1zQkCYEcgd6AQPrQR1IOSaZghu5pgf/Z ________________________________________________________________________________
Subject: Re: RV8-List: High Oil Temp Issues - RV-8A
Date: Jun 04, 2011
Robin, I had the same trouble with my 8, went to extremes to check it out. The temp sensor was ok as far as I could check, changed oil coolers from baffle mounted to firewall with larger cooler to no avail. (etc. etc). You do not say what your instrumentation is. Mine is the Dynon D10 and if you have a Dynon and have had it for a while, it may need the latest software update. The earlier software had an incorrect algorithm for a particulate sensor. I do not have time today to getup the books for details but you can find it all on Dynon's blog. Cheers ..... Alan Searle .... RV8 1 80 hours. On 04/06/2011, at 4:37 AM, Robin Marks wrote: > After 20+ hours of flying in which time we were resolving a Fuel Injector issue and a few avionics/electrical issues we are in good shape everywhere but Oil Temperatures which are also driving up our Cylinder Head Temps. > > We are running: > > =B7 IO-360 200 Hp standard compression > =B7 James Cowl > =B7 Metal Plenum (home built) > =B7 New RV-10 size oil cooler (designed for 260 Hp) > =B7 Custom oil cooler plenum > > Photo below. > > The issue is we are seeing oil temps up to 225 when OAT=92s are in the low 80=92s running about 23/2300, 3,000=92. The CHT=92s are being driven up by the high OAT=92s to mid 390=92s. > The oil cooler plenum is a BIG 4=94 inlet with a smooth ramp down to the oversized (260 Hp) oil cooler. > While we have not been trying to resolve this for very long on the 8A but we have a great deal of experience with oil temp issues (and the James Cowl) on our RV-10. The long & short of the -10 issue is the inlet rings are too small to properly cool the CHT/Oil. The only reason I went with the James cowl AGAIN on the 8A was the MUCH larger fleet of flying 6/7/8/9=92s with James cowls & few reports of cowl design issues for these models. > We have toyed with the idea of swapping out this oversized oil cooler for a Niagara unit but I don=92t see how we are going to find 25 degrees with that swap as this is already an oversized cooler to begin with. > It would be pretty tight but doable to relocate the oil cooler closer to the rear baffle area but again I don=92t see getting 25 degrees from that. > The temp issues are the only remaining issues to resolve. Any thoughts would be appreciated. > > Robin Marks > RV-4 Sold Standard Vans Cowl - No Temp Issues > RV-6A Sold Standard Vans Cowl - No Temp Issues > RV-10 225 Hours James Cowl & Plenum ' Significant Temp Issues > RV-4 25 Hours James Cowl & Metal Plenum ' Significant Temp Issues > > > ________________________________________________________________________________
Date: Jun 03, 2011
Subject: Re: RE: RV8-List: High Oil Temp Issues - RV-8A
Date: Jun 03, 2011
Subject: Re: RV10-List: Small Drill Driver Recommendation
Thanks everyone for the Small Drill Driver recommendations. I ended up purchasing these for $130 delivered. I just arrived home to find them. The quality, weight & balance seem top drawer. Very impressed so far. I basically went this way for a few extra $ mostly to get the second battery (2 batteries required for Hangar use). I consider the impact driver a throw in even though it is also of equal quality. Robin [image: http://ecx.images-amazon.com/images/I/41xXPGP8YHL.jpg] ________________________________________________________________________________
From: Charles Rowbotham <crowbotham(at)hotmail.com>
Subject: High Oil Temp Issues - RV-8A
Date: Jun 04, 2011
Hi Robin=2C We had the same problem with our 8A. While we did not have the James cowl=2C we did try a larger oil cooler and oil cooler plenum with minimal improvement. What worked for us was the following: Mounted the Oil cooler directly to th e rear of the baffling (std Van's mounting location)(made a gasket for the oil cooler to baffling for a good seal and prevent baffling cracking and in stalled a double set of louvers on the bottom of the cowling to increase ai r exit area. This worked for us. It's worth while to note a couple of items: First the the IO-360 installati on is a tight fit and almost everyone we talked with who had this config ba ttled Oil temps=3B Second although we had originally increased the air exit ramp size it still was insufficient without additional venting area and Th ird when ever the OAT was 90+ we lowered the takeoff deck angle and as soon as we got to cruise altitude went Lean of Peak on the mixture (it was alwa ys a joy to watch the oil temps drop). I would suggest the lowers installation first followed by the directly moun ting the oil cooler to the rear of your baffles (or atleast shortenting the oil cooler plenum and making it straight path. Regrads=2C Chuck & Dave Rowbotham RV-8A (sold) From: robin(at)PaintTheWeb.com Date: Fri=2C 3 Jun 2011 11:37:56 -0700 Subject: RV-List: High Oil Temp Issues - RV-8A After 20+ hours of flying in which time we were resolving a Fuel Injector i ssue and a few avionics/electrical issues we are in good shape everywhere b ut Oil Temperatures which are also driving up our Cylinder Head Temps. We are running: =B7 IO-360 200 Hp standard compression =B7 James Cowl =B7 Metal Plenum (home built) =B7 New RV-10 size oil cooler (designed for 260 Hp) =B7 Custom oil cooler plenum Photo below. The issue is we are seeing oil temps up to 225 when OAT=92s are in the low 80=92s running about 23/2300=2C 3=2C000=92. The CHT=92s are being driven up by the high OAT=92s to mid 390=92s. The oil cooler plenum is a BIG 4=94 inlet with a smooth ramp down to the ov ersized (260 Hp) oil cooler. While we have not been trying to resolve this for very long on the 8A but w e have a great deal of experience with oil temp issues (and the James Cowl) on our RV-10. The long & short of the -10 issue is the inlet rings are too small to properly cool the CHT/Oil. The only reason I went with the James cowl AGAIN on the 8A was the MUCH larger fleet of flying 6/7/8/9=92s with J ames cowls & few reports of cowl design issues for these models. We have toyed with the idea of swapping out this oversized oil cooler for a Niagara unit but I don=92t see how we are going to find 25 degrees with th at swap as this is already an oversized cooler to begin with. It would be pretty tight but doable to relocate the oil cooler closer to th e rear baffle area but again I don=92t see getting 25 degrees from that. The temp issues are the only remaining issues to resolve. Any thoughts woul d be appreciated. Robin Marks RV-4 Sold Standard Vans Cowl - No Temp Issue s RV-6A Sold Standard Vans Cowl - No Temp Issues RV-10 225 Hours James Cowl & Plenum ' Significant Temp Issues RV-4 25 Hours James Cowl & Metal Plenum ' Signific ant Temp Issues /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0a HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAMABAADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDphc55 zUq3XbNY4lI6mnrKR3PNcfKXfU2luz61Mt3nnPSsQS8daeJsdTS5Ljubq3pHcU8XvucVhLOSeCal WbPQ0cgcxs/bMnrSG5yetZQlOc56U4TEDANHIg5jS8/BzmpVmJ6GstZuQTUqzgYyeKXIVc2IpyOp q2l1jvWCtwB3p4uT2NTyO4cx0AvCO9SrekY5rnRcn1qRbrHejlY7nRrfHIyanS8z1rmluvepRd47 0K62FodMl0DxkVKLhSOtc0l2fWplvTxz+tUpyWwcqZ0XnKe9KJAawVvT61IL0jvVKrLqTyo294xz TTKB3rI+2kjANMN23dqftZByGs1wo4qtJKpBzWebgnqQaPNB5JrNyb3KSSHy7TnmqUq4zirDSL3q tIwOcVNhspSg88GqrjOavOAcjNVpB2qkrCZSIIOaYTjIIqyygdahZM5wKpLsT6EW4HpTSCTT9mOn Wk2gcHNNJARk5HY/hSEjPSnEEfT0poGcUWFcQqD2oEYz1OKdsGSRzj0pd2CeODQ0wuJsA75pwQEY Bx703JPGKkggknlWOJSzE4AAo5Rp6jkhYsAHIBq/9iFtAJ7q6EMZOAztjJ9AOpPsKVStsRHbbJJh 96VhlEPcAfxH9PrUkdoiSi4mczzt1kkbLAeg9B7AAUrIepAJJHUiztriQdpJnMSn3AwSR9QKia21 1gT9qtYR1ACM5/MkD9K142Z3KoDgnp1pkt2iOYoFE0oPJB+VT7nv9B+dRpcdkzLW01cAme4tpoQP m3xlRj8yBSxGyiIX7Nauw/uKSf0Bq29tJOQ91KZSDkIDhR+ArkfEGv8AiPTC/wBm06C3tlztkRC/ HqSTjP4Cizb0Hdo6xrmKWIxPaP5ZGCgj4/LFcrfeG52u5HtJkWE4KpIpBHqM4xiuVj8a645dbm9Z CVJVkVVAI5549OPrVB/FWt3hAl1S4CrgAI20H6gYB/Gk6cno0CnY6h9C1lAdtt5gHdCCD9MGsS6v pbJytzC8bA4KupB/Wm2nifW4kYxajMXVwMMAwIOcDnPoa73T1fxHaJBrkELlQGV0IBJ/Dp+FH1eK XvKxSrN6I4aG/hmYEuuOuM8ip/NYHIAI7V3yeCNCSVXFs6kAjAbg+hPuKoaz4KVw82nOFyMiHGMH HY+tZSwqveLOmFWDVpHG/aexABpDcjngfnUNzBPZ3BgvYmjlxldwwSPWqTzqhIyTj2NZuk07Mckl qti+87MPlIBFRrI55Ykj2qot3GVyWAx60/7VEf4hj60ezstibotGVQeVqN5geQDUYniI5dR75qNy CMqMg9xQo23HZMYziR+QRg1KQqAkgAAZJNV0bD5IIwaLzc0BbJAJwAKdrtIpaIq3N2JSUTOB1PrU Cxhuq9faiGMHJYEmrccYIA5FdNlBWRg7yd2RpBHwCoOPaphBEBxGpH0qZIRwc9KlVB2PSocn3DlR XFtAesQ/Cnx2yRSLLCuyRTlWHUGpiFHVgKcFU4+b9Km7YcqLFtf62rhnv3ZR0GB/hV9db1NePtL5 75AP9KZDq80Uax+TbsFGBlMk/WpTrLEAmztj9FxUtJ7k2sL/AMJDqgIInBI9UFD+KNVRfl8tz6Fc ZpBq8Tfe02A/QkZpTqVkThtNX8HNCigsOi8U6oUBmhtwf90n+tSDxJI5+e1t2/4DVb+0tNZsNYOP cOaFn0g5JtZ17/eBp2tqg0LQ12Bs79Lt2J6nAP8AMUDVdNfh9HgPr8o/wqv5mjHqlyp+oP8ASgHR cYE1wpPqoNF2nuFl1J3u9CcYbSEX/dAFQMvh1xg6aR6nJH9aPK0hul64+sZ/xqNrLTXORqaDPYoR T55r7QuWPUcLPwxIMG1kXPcMaDpHhWQcmdT7H/61PWwsd4zqMJTuQCT+VS/2bpp+7qUftlSKpVJ9 WHLHsVG8OeGnztup19OQf6VE3hLQ3JCak6/UA1fbS7Uk7dQgIHqcUf2RET8t9bH/AIHT9rUXUTjF mW3grTiRs1VfqVH+NRnwJEQSmqQnHTIPNbP9iyNjZPA30cUp0S7xwEYeoYUKvUDkic+3gOckhb63 P1JGf0qrL4KvUOFlgf3Df/WrpX0a+HRCMDjDD/Gom0/UE/gb8DVKvPqg5F0Zy8nhLUkyNiNg9nFV n8NamoybYkexB/rXWm2v1GTHJj2zTCLtOGWYAdxk01Xl1QuRbXOObQtQTObWT8ATUL6ZeoTm2lAH +ya7TzZxkEvzxyDTTPMBks2PcU1iH1QcltEzhmtJ04aJh9VIqN4nAOVOD7V3El1Kqk5B+orGfxA4 cq9qjAHAPr+laQq82yJcbbs53ymHVSM0hUg8DFdD/bluRh7BOfTB/pQdU05x81iBn0Aq+fuibHOk HOQKbggciui+2aQTzasM8cD/AANBbRXyCrrnp1o5/IGvM5skYyRig5PTiui+z6K5wJWAP1H9KYdO 0p87bvafcinzrqKzOf7+1JnHGT68VvnRbJyNl8h/L/GkPh5WJ2XaMe1HOhqLMHB5yeTRyR0xits+ HJugmj/HNRSaBcoCQ0ZH+91oUo9GHKzKyMc80YHPGfStD+xbwAEID9CKY+lXYPMLYHpTuu4alHGM +tLgk9Ae1WfsNwn3onH4GhIGViGUgAZ5FK63BLoMEa5AA59T2rS0y+K/upMbScA+lRQ23mxEkcg4 qOW1ZDwDjNZT5ZqzNI80XdG/sycgg+hoEOW4POMmqGn3ZAEMx5HAJ9K0xjGR3PeuKScGdsZKSIyF IwwHHp3quxCMWCkjJwAM1bKBxkA5AotkyCSOeB+tOm9bk1NIMr73xnynAPcrTGlwMlWGPVSK3toC gECq94FEROB0rrTVzhsczI4eQspOCcjHFM3tnhj+dDkFiccZNMwOuOMY60W1ubpaDt7gY3Hr0o3s BySfrSAcnikxwepzxRuFhSSeoz9RR5hzyBnscCk4IwSetDBfLABO7PPpihaCaXYtR208lubhVHl5 xn1NR7Zh0BH0J/xrrdCt4n0aKOVAwJJ5Hqa0TpFkV4hXPqCan2m4ly9TgczDgFgPqaTzJgMbnz9a 7s6HaEDEeMjHBNRHw9aHorD8aOddQtE4nz5wPvt+dJ9ruAMB2/KuzPhy0LYBfnryD/SmHwxbcgO/ 6U+dCcYs5AX1yDyx49qX+0LgAEsPyrqW8MxDJWU9c4K1E3hpc8Sjk/3f/r0c0Q5Is5v+0pwcEg/h R/alwPQg/Wt9vDJPSRfxFQN4ZlxwyH65p80XuHIuhkf2vOOozn3pf7XlwAR+taTeGp85BQn64qJ/ DtyM4VSPUGhuIOCfU9ABNPDDHWmAZPApwxya2t2Oe5IHJpwaovTFOXrgUguTq9PD46VACadnAoaC 5YEhPQ04SHrmq4JHWlyT070coJlkS+9OEh45qtuOOtO3Y/Cly2C5aEuD1pwlPXNVAx9acHIo5QuX BKRzmnCY561TzjoMU8NjkGjlHdl1ZueDTxOQetUN5HWlDn1pcoJmktx0yalW4IPWssOcdOKkVyOT RyjuzTW5J6GpRcnuayll4608Skd6lxDmNZbnIpftGRnNZQnOOtKJzzzmlyD5jVE47mkNyPWsvzzj rSmXPGafIHMaJufemNOCOTVHzOTk0hlPrRyhcuGXPQ1E0mQearmUmmlz3NCj3C5Kzim5BHSoyaQM R3qrWFe5LgYpjYx2phc+tNLkj1oSENbBOBSbTzjjFLgmjHXNOwDSAOc/hS4z3P40uD0xTlTccDqe KLdwuOiiMr7RgADJJOAB3JPpV2Ngq7LZsIRhnxy/sPQfqf0qqEEo2A4jBwx6byO30H61bWMiMMrL 6YzzU2GtB6E2xAKAYHQjjFPjAdhgkfjUIZi2CDmmS3GQYkOB0Zh39qlodyzcXIdTBC2Izw8g4Lew PpUDXFtbRZMqxAdCSB/Ouf8AE+sPo+lQmEgT3LMqMRkIq4ycdySQB+Nc/De77dGmcvIygkscnNTa +xVzrJ/F+mWJZJr0YI5CIWIGRyMDrxXH+JfGk2rl7O08yGwIxjA3ynHVj6ew/HJqlcCKQuzIGJ6c VjzxeXKWCnAORkcU1TWjbFcgZD5e2QD2OeaSzEQmEMoUKWyXZsAAA8fjTwof5QQCT34xUDgBiCBk HHPNbIVhY5THOAy45BUg+nQ11uleNb3TsK6LOgGTkHOB7j/CuTmnNzBlhmWMAHCgAKBgcjqaWEmd FZcblOSD3p8qloydtT2XQ/GNlrR2KGikAB2uQQfoa6NXBOQfcV5DoOmhVWcMVkHzAD+ea9G0meR7 dQ5JIAwc5zWco8uxSdyv4t0BdbtFmiGLuDJQjjcO4P8AnrXl1xKtoGE0ZDKSCCOQRxivbgSBkdCe RXAeO9GRCt/EABI22RQO5HBrKcbq7OmlNpOL2OKW/sj97Az6il+2WB7rz6is1o2EpUhcj2oMbY4C /lS5E+pHO1dF8z2TMGLqMduxqVL21ChBIoxwBWR5J5OF/KlWL5hkLnPPFEqSa3KjVaexrkK8qkEH mlugoUBiAM9+lQxH96oHtRqxBtwM9TXMo+9a50ylaN7E0CW4JJKEntkVY8u3PQJ+GK5gIBjBIP1p +COQzfnW7w7bumc/t1bY6IQQqSzEY+tSCCB13KCR7Ma5o7wp+dvzqSMzbtqysoAzwaTw8ujGq0eq OjWKEjlCMcdad9ngzkKfzrnPNuVYgTMAD1zTzcXaYAnPPNL2E+jD2sOxumBQcjI/GmLGxOA7AduA axBe3gGRKfxpI9Ruw2VfJPqM0OjUDngdAIJF6SDB6ZXpTlilwD5inHXK1hDVb0cEg98Yp39rXijJ VcH2pezqIOambRhmOMsh554o8qQYBZMn261j/wBr3eMlB6dKT+2ZyQTEpIPXHSlyVQvTNsQOOCV5 9qcLZj1CVjDW592Sgx6U8eIHA5iH50NVew/cNYW7AkMq/WkNqpGTEpOcYzWYPEGP+WX5GnjxCneI /nS/eroLlhfc0RbKM4i9uDS+SoJBQ8c8d6z18QQ94z+Yp39uwHB2MPXnpQnUtqh8kOjLvkRnqp6U n2eMYI3DNV11u2I5DflTv7ZtScFmH4Uc0raxDkj3J/IiJxuNL9nXBxKw/GqzatZgZ3k+wBpy6lak DMoHpxS55LXlF7NdGWBBIBhbhx9CRQYrnORdOP8AgRqEajbf89l/OnC/tiDiZOfcUe0/uj9n5j9l 7gKt2/PPLmlA1HPFyTn3Bz+dM+1Qk5MqnI/vU5biEjIkU46YNHtPIPZ9mIx1Ef8ALTP4Coyb/GSo b8BUhkRuA/A6YaoZTsIZJn9xuOKaqLqhOm9xD9sIO6Fff5agaFyMvZxEnuY6seY7c+Y4+jGlwzdJ 5Bnr81NVktheybKflIcBrKIjp93H9KhkgtdwzZJzzxmrwEyMQZ3I+oNOCuTgzMfTIHH6VSr92DpM ymtLLGTaEZ9GNR/YrFsgwyAjj71bLRtjJfPcZUUwxHJJKHP+yKft13F7J9jIOnWJHCzAjjqKifS7 UqQkjqx7sOBW2YGIwAhz/sn/ABprW5IwVQ/QkYqlX8w9k+xgHSFxkXKfiCKZ/ZTgjbMpJ75NbxtF IzsH4Gm/Y0IIw3HuOKarLuL2TMT+zLgfdlXj0akNnfAZDMccgh//AK9bRs1HQH86ia0YklSR+IoV dbC9mzL8rUVGS0h/4FmmE6mpxvkx7qD/AErVNtOAQAT+NBt5um0g49aftYh7JmK8+pA8gH3K4piy TybjMADjAxxWw1tORg5P41UmsblzgIx96pVItCVNp3JbMKLYAjkkmnSorLgimpBOihfKYAAdqRo5 QDuRh68VndXvc1SfVFKaIKcg8jv6VoWd35sYiYDeP1FUXBIJIPX0pkKMXBBIbPBpzipR1CN4yNvB XPOPr3qS1wcY9RmoUcMjB8BwPWoUhncgpLsBOMZI/E1hBWZrU1ibZIAwDVLUHAgbJxxUIt7wKCJg f+BUfZrqeJllwwPQlgDWymk7s5eR9Dn2Oc4FJ1GAK2joxPSFiD6OKibSlRirK6sOoODV+0izRRdr GUc55BwTS8ZGCavtp6g4MjAg9Nv/ANemGxA/5agfUUc6HyspAEHgnnk0jdAM8471c+xEjIlXP4/4 Ugs2Lrh1IyMnP+NHMgafQ7TS4gthAgPIUD9K1FUAdeayLbULRI41MyjHXnFSXniGwsYgzyF8nACD P/1qyV27IyaZrEDHamkgCsA+LLY8CGUjjBGP8aQeKbU8mKYfgD/WnZ9i+ST6G8uCSR6UEjGTWGni eyyQRIM/7P8A9enDxHYN1dhjrlDRZ9hOEl0NjqeTSYwORWWviDTyMifr6qeP0pf7csD1uV/I/wCF GvYOVroaPrzTCBnHGKpf2zYnI+0p+dH9q2JOftMfPHDCmvQll7C9cD8qjIBOTiq39o2hHFzHn/eF AvbUnAnjJPTDCi1xG0ARilA7CnbRjpTguB9K7bHONA7g04DBzSgEGnYIosCY0A96cBjtmlC9MU4A 5+tFgG4JxzS4IPWnYPpRjii1guIAcmndRnrS44/SjGQeKLAGfSndOaMY4xmjAHeiwthwOaUEk/Sg DuTS470WHfQMmlyR7igA04DHIosFwBOc9qfk4puOKXpRYLjlYjmnByKj5PU0ootcLkm4il3HPBpn JNGeaVh3H7j0zS7vU1HnPBNGTjg0WC5LuAHJo3c9ajJ9aM+lFguSAkDGaCfU1Hk5zmlyc9aVugXH 7s00tk4NISfekJGcmiwXFP1pc+9NzxS5osFxwNBOT1pmTSj6UJBew8EGlAJkEYyMjLH0HoPc0xn8 pQxGSThR6mpEPygE8nkmnYVydQGBAIAUAAUmWB65+hpjKAMhgT6UBwilm4AGTSGnqSSTmNdqnEjD g9wPWq5IVQo6Dr70w7mcuxGTyPYVFJKIuXJIALEBSeB9AfWpcR3bKHiLTDrWmwQqVEttKZIyf4gQ Ay/jgEe4965iXEUpibCunBB4IPpXZ/aIEge6lJWBFMjHnIUDPT17D3rzifW01jVLm6vQ6FidiqBw AMKM57YA/M0k2tEhp9zSklSJCXYAAVQu5I7i3dYWDMMHA64p5k3xhpEJByMEZOPXFPurrThYxrbw AzgcuAVI475HP1o16h5FC0sLm/lEVrE0kh6KoyahuNMvoZGV7WZWjJDDaeCOuam07WbnSb1bq0bb IM4yARzx0NdQ/je40hY7sQRXEt0JDIHOACdvIA9x0pOUk9FoWlG2pw8TOJjF5vkpLhZCemAc88E0 lowjuygbKkkAjoaS6u/ts7zsioSSSiADH4UpKiSGUJ5YIBBweQDjNax1d3oQ2tj0fQ4jPpiOvJjB BxXR6SXiiKhsjrn0Fcz4Jv4jFNbPjJ+ZSemD1rpLVzFO6gZUEgY54pTSdwizejIZdpJxjOc9ap61 p6X2kz27cEqdvsRyD+dTW06AgshUHABJH5Ut1eqDhcHPUVlZWsXezujw25RkuSCCDyCCOhHWmYx6 11PijTWfV2eCE4kAY7BkEnr06VlHRbwKT9mkxj+6acYyexcrbmVjjpTQAGyRwOa0H064jGWhcD3U iqzwOA3ynj2ocX1RK0Ft5Y3nXa2Segp+qHMSAc888VXsYSLoHb61Z1FDhB781zuHLUR08/NT1MsD kA9+Kcw9+e1P28jilYEHn2rqOT1GOCUx+NPhUGTBz0pHGFA7ZFSRD94cDsKLsSXQYR8x+oFOmXG3 p0NLglzn+9SzjkewNK4akG3Ef4VEgyw571YI/de2KiQfMP50aDH4Bb8DUrjEQBHYVGo5I9jU8o/d qPpQBGoJB5OAarYJ3HnrVtRlCPc1WAGCcjk4oQDpQABkDFMKgjGAPrU0oyB7mmHHU0ebARI1I5GD j86jdAGIHpVhBwD3IqGT/WED0o8w2GhF2g4IJo8sAA45p/RRnB4pcAKOD60OwczIwh5IJwKayZII J9KmAyCaY+MgD1o0C7I9p6Z6UoDYPPAp4AJPtQAdpA6UtOwcz6kYVs8Ht601g45DYx71MBg4zTGH A/nRZdh8zGBnxwc/WgvJ0BpwAwSaVQDnjpRyrsHMxvmOBwTn60hnlHVjx704gE8ZpGBwabjF7ofO wN1MBkO2D2BNKt7ODjzH/M1HjGBRtBIwKXs49gU5Ep1G5UZEj/nTxql0Bkytz14quQDkGgjA6dqT pRfQftJdy2NXugADIePUClGs3I4Lg/hWfgE5z3pSoHUfSl7CFtg9tLuaA1u4GAWT8qU63P3CH6j/ AOvWaVHpzSbAOeOaSoQ7D9rLuan9tygZKoR+NNTV3ViwVfm6jJxWYUBHTgUgQAdKPYQ2H7WRsf20 x6xD6g0o1k8ZhGB7/wD1qxmQY4zShBjPI/Gk8PDsP20kbX9sqeTCR/wKnDW07RNke9YO0DqT9M03 BA+8350vq0A9uzfOsxE8xNnPtR/a8I6I4rniWAB3EGozK4yA3T9af1VAq76nTf2vCTyHH4CmnVIC DgNk8ciuZNw4PUUoncgZA9c4pfV0NVjba9gJJJJz7U2BlmnDKMgnisYyMeOOa1tLUtInTpmlKHJF 6lQm5OzLepzLaxLLgFxwPeqFlqE08hViuTyOOlad9bJchEkzgc8HFYskS22orFBkcZ69zU0uVxt1 HV5k7rY3I5XAJwCak82UnAVQe4yf8KzFlvQMFVGO5xUcmoTQEBgpz6U/ZSexCqLY2DI54KDA689a Y0mMsY8gDsayP7Xc5yg9etJNqrvEUVQpPcHpSVKS3Hzo0tynkAD0FIQMdOtYn22cchyfwFH9oTg5 LZ+oqvZMPaI2sccCgg7eABmscanMBnA9OlWLO5nvZ/LUAYGc80ezktwU11LLoScjIx6Vn6mQWgQc AnOK230+5RSzMmF5OCQcVh3vOoRKOy5rSCtqwupNJEo4GPQUH1z370vTkjGabkd8+wzUnppWQhJA BJFJkeoOaa5AOAfeq083lLkHk9BVJN7Gc5qKuy4CCOvNAQyMFUkE9CapQyyuNxOB+pqVZ3hbzFbB X1FDi1tuZ+1Uo3sXTYspH75jxzxQbJgAVlPPTgVSOqz3LYLED2GKel3MgKh8j3zTXNb3jnfvL3S4 9qdoCuQe+R1qA20oYBXBB68c1GLqYkAtn8akF1IFBOMg8ZI5/StI2W5jyVbnrYHHJpwXvmn4HSlx 3rRI5BgHB4pdpxxUmMc5pQOaLARgAnkUuCO3SpAO9KBxRYBgGTjFLtp+3tTsD86LARheOtKBjrT9 pHbil29qLBewzGBS4PpUm38qXBAyOtOwEYU0u3PannA6UAE9aAADuKXHfFOAHpQBmgBNp9aMcdqf juKTAz9aBjcHtS4xxTgM8frRiiwhuMDilxS4I6UuOxGKAGcmjBHApxGKMHpQMTmkp5U46Ube2aVh XuNAx70uBnpTsY9TmgiiwDOc80ozg8U4jjpSY5wc4pgNwetLjAxSkAdKMd6VgEwBS4wDkgY60Yx2 pkuXIjB5br7ChIAjBlkMhB2jhR7ev41KVIPQ0qgKoAGAKdk+vtTfYBATkd6ilbcwQY2qck+pp7v5 a579AKhGAOvJ5J96VuoD8k9aasJDkgsQexPFZmreILTSIsytvlPKxr1PufQfWuC1vxxqtypjtpBa oeMRj5sfU/0xWbd9ENXO58SzqkRsASANr3DDoMglVPuQCcewrl4oLQyAIm5j04xXHWs0sV150s0j uxBYliST7k9a6uJHASVGzlQwOc8HpTVOT16j5raE9zMlu+xkG4jOAQf5VTmlWRDGFUBuM56VZWNx MsrKrsCCd4yDjsR6UyS2Z5GdVRckkADgZPQe1Uqb6hzIzE0a9nDGBDIFGSU5wKpS2l8IyHRiq9N3 IA9q7KzuJra0niVQrSgAlRgAA5+uf8abcvcm0eCIhkbGVJGTx6dahuSdki1ytbnDKjkHcpBFP8oF QC4BHYmuhGlzAZltZIxjqQQMflUlvpKSyYKKwJ9Qc1W6QRaT11E8LSSjUoYomLOcqAO4r1O20xl+ YyHJwSAK5Gwg0vw7Lb30sbIz5XKgnBwO1dZaeJNJnACX0QJ7Odp/XFJyitwlq7pF4aYGILO57dat pZKgACqcdyM0sM8cqhkdWB6EEEGrKNwKFZ7CuyNbRRKJSpDA5G3Ax+laQugUCnzDjjkKf6CqykGp VAJ6Dmna2zFfuMKwtk+VAxJ5EkIGR9RmoW0vTJwyy6dZEMMEhRn8yOKu+UcZAoMY9KNe4HPz+CdB di66dIh/vQyAj8s1kX3w80u4AJurm3x0MkRAH6H+ddr5QByP0pQJE+67Aexotrd7lKTSt0PM5fhc HG6z1e1mx0DfKf5msi9+HOu2+WS2EyDndGwwfzxXsDwI/MsMbk92UZ/Mc1GIFjYtFLcQn/YkyB+D Z/Si7e6Fc8FvtCv7Nf31rIgBAJKnH51RSF1lbKnoK+jD5roVkW3ulPBEi7WI9O+fzrntU8HabqAa YWT2bkZyoyPzGQfxpWiNNHiew7+hB3UTocjjsa67WfBt7pn7+MefbEkh0HQe4rm54sNyO3pUNNDK LoRASB2qFEO8Zz3rSkQC2PqcVXiiO8ZHapuFiJVO48dB0qaVTtUY4yKlEQ3nA7VPLECFGO4ouh27 lFQfLPB6mqyg4AxyW61qCECMjHGTVdIQQpwOWppg1cgmGCAPxphBI6VekhG4cU0wDBNK4WK6A46c 4FV5B87e1aiwDHA4xVR4SXfjvTTQrMgwNo70uOBx0q15GACRgYpBBx0ougsyrgkd+aawJYAnpVwQ HHA/So2gJcADtQmHL2K4GM459aXBKjPXNTCEkHg07yCFGBRoFu5WUDmmuMDNWREcEj1pjwnqQTTT sKzIMYUkjrQAOe1TeUcHjvR5JwcihuwEIHOCORTWBAJ68VOIiD60142AOR2ouFiADoAO1KAc4A+t PEZ38jtTthyR1wKd1cdiIrnjPekI6jOalKE4JFIyEA4HSjYVupWCnqKdg8c9aeFJYDGKUocg470X C3UiIIPvQRgDIFSFTk5pGUgf4UPUdiLGc4oINOwRkkd6UA+hpgMxz060EcehpzDJ60hGB3oERkck Z/SmHGcZz6U88nFRSMQcAc0ANk4AxUPGGI9akOXx2PtSiIKMdQTnpTv0FZ7kBGeBjNOVCSD1FTBA z/KMYFWbaBSSGGQOlJuxV02VPLOBgck1s6WoEg7YFQm2jAyQcDnrVvT4ySWA46VhWd4s3o/EXJgD IAegFYEv7zW8AZwQOO1X9VnngZTFyDwciqWmRPPetM456k1NGm0uYqtNP3UbHlEqeM1iXqgSkHtX QEEJyTxWDdITcOck84raNzBK7KZQk8EYoCHFThAOo70FCDnAp3ZokivsJ7daQoT279c1YKgc4603 AH5UByogKEdjn1rU8PRE3LtjoAB69aokcYwRx2rovDEKlCxHJY/oKicrRE0jRuyUtJCc88Vx0p36 o5HO1QK7XWMJp+ARlmFcTES17O5z1wKIP3bl0l76LBOabkA4NKTjseKTBI6En6UrHpSZXlYAknoK oAtcTEknaP0rSktnlXBViM84psdg6IQqkAnrWkWkjiqpyl5FCSVkYLHwBTZpXICA5PfFX107BJLD J79cVJFpILEhmYkZGBVKUVuYuMu5lh2iwqde5pzTybgowT0PFa66WgOQrEnuTTxpyA5VFB9Scmk5 xElJK1zIM0i4Crkngmp9zOBlhkcEDtWrHp2SFABJIAAGSTRPaxQRkNKPNPRFAJ/E5wP1pXT2KU7P e562B3pcc+lKBzmnAfpW+5wiYPBpQMjqKdgGjGeMUAIBTsHoadtyOKUAY6UAN2j0pcZPGKfjA560 qigBuMdeKXFOwM0pFMGMwfwpdo7U7GegpcEcilYBgTnJpwAxwKXBPtS4xxjmmA0jHajB6U/acgYp wTjFAEW0kd6UL3qUqO1G3A4FAEYHOQKUAdDT9uOnWgL60WAZgelLgHjipAp6etAXNFgGbBnOKAp7 daeRilx7UWAj255oKgVIRzQV54osBHjI5owMcVJijANFrhuR446UmPapCvpRtNFguR49qXbmpMZ7 UoX14osBAxCqWPAAyTTYkJBdhy3P09qkkAeQRjoOT9OwqZEyOlCQtxilcYI5owMnAp5Qg4IpkhCL kUDKsxZn3D7q8c+tUNUu3stPkmiTfKTtjGOpI6/Qdfy9avzSIIwACMVy+v35gvbaFzlDCJBjsSxz +gA/Cok1ogSOKvDPJO805ZnY5Yt1JrJc4fcQDgg8+xrtLueCaMDCkEdx3rCntoXLBEGSDjHaqjFL YbfQx3CiQkgkE5H0rV0zU1ixBK2Ez8pPb2+lSafaQXNqTImXUkE57VWlsYzJKIwFSMEkk8nH/wCu tOW2xN+50sbgqCrZ9CDxUysSBWJpUGI95mdVUAlc5Bycd/8APFbJimRCySKwAyAe9OzJdrk6SkZy AanWVMYZAc1Vt4r17GW7khGyPOMHOcDJ/pWeNcgTiaKaM+65FJq240+xuxSojZQtGT3RiD+lWUuZ CcicN7TIr/8AoQNYMer2Eh4uUBI/iOP51bjmikAKSq2R2INRZMq7Rr3D/a4RHLb2rqpyCFKkHv0I H6VmvpMWSyxMg9A2R+op0bsDwePrViOd1xg5+tJwTGpPuV4baW2bMM8kZHcZH8q1LfWdTtT8t6zg dmIYfqM0xJyR8ygj1qYCGQglAM+1Q6Kew1U7mnbeLL0Y3pE47nBB/Q1s2/ieJ8B4GX12sD/hXLLY W7/dYD05xThpjjBjlYZ6YNQ6M18LK549Ud3BrVrIM72Q+jA/0zV2O/ifG2VGPpkV52tvqUAykuR6 EA09dR1OA5a3jkUHkYKn8+f5UrVY76j9xno4kDHPH4VIrAnk4+lcDD4mMRxNZTqP+mbA4/UVrWvi rTXwJLmSEntIjD9cEfrQqkl8SBxT2Z1uwFN3aomCnoBWWmuWM8eLa/t5iOSokBP6H+lV5tdjgOJI iR6qwP8APFN1o9RKL6GsUB4GKjZ5YsbXIIPGDWOPFOnHAd5Ij/tIT/LNO/4SDTHGRewj/ebH88Uv aRfUOVmpLqKG2ZLiAOMdhgH/AAPuK8s8X6faJOLq1QorEhk4GO4NdvcapaPGdlzC2R2cH+tcJr84 nVgpBUMM4PAqJTu9Coq25zsqAw4AHUVBGmHHXpVqUDywOe1RRKQ4PbFJlDlQbzgZPFSumSPr0oUf MccdBUjgEjHHNK7DqRbD5RJHXNV0i+VB15NXODGcHJxUaoQFycYOSKXMl1HZt6DJIhuGTSPFleB1 qZgCQaaSC23vjNLmTeg3FpaiKgwSRiqrR5LjsT1rRAwM5xVXbkH3ar0sSkNMQwBijy89AKsFTjpS lcA8Ug0Kwi+UComjzLyOgq6F4BqIg+YSBxihN7hsV1iwnApyxAKMDirAXEfA7U4IABgUXD0KgiGO R3pkkQJHFX44i7BQDknAp91YyQTmJgCRjkHIPuKau9gMxIeDnnmlWDKk45q6ICF5UjmlERC8jiiz 7BoURFlunOKZJCNvTvW7Y6PeX8hW2t3kJBI2qTkU+78O6lbAGaxnQZ6shA/PFVFNgc6IRuJA4ApR BkkYrTNk6sxZCO3IpnkHnj9KT5k9gsZxgGemfwprwAISR9K0fJww4pksYCEAZzSuwsZiwZIOMcUv kAtjFaAhAJGOg60CIFulDbCxmmD6daHtwD0rQMQJHHekeIEknp9KakFrmX5HGCMZNAtwCABV8RAA cc04Qgt0zT5gsZjW/XIOaRrfA6VpGIZ6d6a8QHbjFClqFkY/k/MeO9VpY8PwOh9a11ixkn1qjMmJ cckVSkCWpXEQAGOuKRxjJxxirRQBQevFQMAcKO55oi7u45qyEt4zySPwq7bocEgVFCvDn3q7Ah2/ U0SbM0hjqNpJOABW94bsrS9lWETHJOW46euKx5kxExxz0rb8IxATtKOuMZ/Gueq1ym8LpNnoMXg7 w3cwhJbd2JHLGQ5P9KtQeAPDcSkRRTKD1xID/MVFZyMpBJ4xWolwQM7qzVSaVk9B2T1KT+ANCcEB 7hc+jA/0qhJ8KtCfLC7uQScknaf6V0K3DE8GnfaiBwapVZoVktUcs/wm0gn5dQmH1jB/qKiPwj04 nI1Nx9Yh/jXWG7PXdUf2skE7iABT9tMaued6r8OLS0kENtqDTTEZI8oAKO2TnjPpyawpfAF6pyk0 BA6lmIx+hrQ1vX5jfXyJIwLv1DHgYwP5VzEup3ZJU3MxB4IMhII/OqbqdBxa2Zn31ibW4MPmJIAc F0JIz9a2dMdrCIIq7jgkHBAOay3ZXOSM9z9a3rO3nuYFeNo9oAAyT/QUSbasxppatDLqWe7QI6AA EEADH9azU0xElbC4BOSSe9WtWe500gM6MxUtgDoKo2Uk98xLzLEu0Ek9s+9Uk0tNgU9bosiyQE8K B0BxmmiBEYHIAX2602KCR5I4mZySxVmU5XGcA8dqin0i5mYBPMQKxGTn5gD2rSNNvdmcq8tybzYV 34YfNwRnjFRyyxBQFGFA5xmrlvpU8al/KMZZsbyoJUAAZwSOp96muoTDbzi5B8wAgcjaQemAD17+ tDgosIzcnYwxdxRuWVd3HYU1tSYElUIzwcnHFEVo88gWNGZmOAAMk/hV+fQJbW3Wa6lihUkghiSR j2A5PsMn1xQop6s3dOMfiepmtezORtAANTmOaNBJdzeQpAIXGXYew9Pc4FNa9htAVs0+fGDNIAWz /sjoPryfcVmTSPK7M7MzHkknJNOyRDhf0J7rW3jUw2ymOM9Wzlj9T2HsMCqomEqlxu6d/XvVWaPJ ycYFLaRs7gc4zwPetEopGDTjKyPoDH60oHYU4DBpcHvVnPsJ3pwHFGOcU9VxQgG46cYp4HFKBTgB jFMBoHNKVIPFPx0waMZ5xQIbjHGOaMHIp+M0oGaEMYB+dOwM9KcFHYU4AelAEe3vilA7ipMUmMDF FhCAYpQD0xTsUYwcmgYm09aMeucUueo9KUZIAAphaw0DHegDPUU/b260oQdKQEZGARRk9OaeV570 Ad8UAMwSafjuBTtoxS7cDimIZj1FJjP1qTA6GjFAyPFGO1SY74pNvGTQBHtPY8fSnYGKdtNKFI60 AMAFDAAEkdBmpMD0qC5J2hFPLnH4d/0oC42Bd4LkYLHP4dqm2kEYNOiQBQOnFP2jGcg0xWIsE9aZ 5ZlY4AwoqaQhEJPYUzIS15GC3JqWO1jNkG5iB0B5rjfGEDKlndAcANAx9CCWH5hj+VdoFGcDuc1l azZJqFtLZMQDKAYmJwFkH3SfY5IPsfas5K2pSdmeZs5JAzxnpVqMESg54IxVCQPDK6OpVlJDAjkE HBBq5bSF5QMHjrzTV7qw+g62JgvJohwG+YCmuQlvdEjLEAA9hkj/AANLekJexuCRkbTVaZ2IK54Z hwO/WtlsZtM1LRSLXAxkkDHc9a1GbMSxr1I61QsgFiGQeDn9K0IwQCcZJ61ojNrU07u7i07wgJHm IMjsu09zkc/WuGuL+VsMqgKRkEjJqXXJ5LmcRMx8qI8L2ye9Z0squqKmSQME9K56k3fQ3hBWuw+1 YYebCjqeTwAatw21rOvmRKUPfaSCKpCIsckgYq5Zo8RJABB64pKfcp021oWo4Z4smG9nTuMtkfrV hbvVosBbiKQAfxpjP5UxdwOSjAe3P8qJJVjBJyCDgAjBJrS8NzPkkuhcTXtQiGJbJJB1zG+P0NW4 vFMKn99aXEY7naCP0qkEUICeWI/AUyWFhIjocADBHrXO60b2RqqDauzobbxPpUmAboIemHUj+YrZ tNUtJwDDdROf9lwf61w0QSV2jliRiOQSByKcdOsZODAqt6oSD+lbwfMrpmUouLsz0dbhs/eBqX7T nghSPcV5slg0Rxb313DjsshI/KpP7S1awlAbUWmXaTh4xnggDJ/P8qcm4q7Eld2R6DvhJO+MHPYc UhgtJM8FQfoa4vSPEt3d3ghuPs8aZIMj5UDgkZOcc4wPery+LIFIEsLAnn5GB4/So51uyuV7HQSa RZynBKN7lf8A61Qt4fKjETkA9kcj+RrMtvFul3IJEroRyQ6kYrRh1qxuBmK8hbPYOB+lP3ZBdory 6FdrkLJKeM4JLfzzVF9LuF+8zY6Hgf8A1q6BdQEfzLOMAcENxWVq3jFI1FrBGt1dMQFRFBIPuRUu nDsNTkZn9nRBwbm9jgTIG+RDgH3IJpdSmjNhHDAwaOM7dwPDHk5A9Kw9RHnuDqc7T3TEHyY2wsIz yCehbtjt+VT3RuYbKGIW0pjQcnkjJA/LjFYTppPQ1i5PcY7HywM9KSI5fOewqsbhnGDEwx69KjF6 0bENE2cdqz16l8rZqDBJ/CkaVTJsJ+YdvWs8akoJzG4z7VDLdLNMHiypAxz60PRaCUXszYBwMetI QOveqkd6GUBh82MH0oa5Y9BWEld7G0di2TwcVWeUCeMEjJOKdHbXtyMxQyOPVVJFV306+Eob7NKS Dz8pq4we4pWZp844HWoAMAcdWq0ttOIwTC4JHPymohbzgAeS5wST8prVIxQvUAH1oI4Ip3kTkgiF xj1FHlSZAZcDv60WB6CDIA/OojnexHpUyFQSGIJHHFRMAGfIwSaLML9hSMRj3FOxxSH7oHanAHtS tqBd0mB5b2N0iLiIiRhzgAEZyR0HSuv0u4meRo3IMYcgBhuGPoen0rkdOlkt540XJEpEbKCQCCRj OOoBGau6edXfUpntYysZc4Z5QFIz6EH+X41pTT3REnbY7s2FjMCHsbZiRyfKUH8wM0N4W0iSxubl rPYY0LDY5AyBxwTVi3VjjBHTmr+pyi08MXJZSSwBwDjIJHGfoDXVEi7MDwxahFkCKRCWQEZ6Eg8/ jkflXTS27RLuiaQn0VsY/wA+1Ynh6dW0+dVIBR43ODnA24wffgfnXRlwV5wa46qtK6N46rUoi1Sd SZoY5Ox8yIH+Yyaqy+HNJuQTJp0IY8ZTK/yIFawBJ4P4UmSD16VlzyXUqyOcm8DaPLkqk8RPQq4I H4Ef1rJuvh1buMQXxUnnEkeP5E/yru93GTyKCARyDzVKq0KyPM5vh3fICYbi3l9gxU/qBWbL4J1m Ik/YncDuhDfyJr1koMkjoKQg9jTVXugseKXGiX1s+JrWVCOodSP5iqMts6g5Uj6iveGMhUqXJz2z xVOa0tpgfOtLeTPXdEpP54zTc4voFux4d5JGOD09KPLIOfWvYZvDWiz/AHtPVSe8bkfoSRWdc+BN Kf5op7iInjDAMB/Ki8ejEeWGMEg+pprocHjtXpEnw2L8w38R/wB9Sv8ALNUbr4c6soIi8mUdfkcc /gcGqjC+wHnyx/L09c1lzL+/Iz0Nd9ceCdZt1ObGY4B5Ckj9K5a50O+huCJYHBB6FSDT5GlccdWZ Mq4HXPFQIoL5IrTuLKZAQUYfhVQwMjZK4wPSiKdtQqLawkKHy88davwp8gHrVdIz5YGOvPAq9GmA vsOlKRCIbwYt8jucVveFUKRsxHUgVg33Eaj1Oa6Tw2uy1BOeTWFTaxtH4WdnbSEgY6AVbV23Ak4F Z1qcCr65yD2rJAuxZD4BweTSM5yBmmAgn6UhOeSaBjmbAye/SmzkJaOxPO0kflTVIklCjoOSai1R 9lrJg8EYqkrtCPH9dcQ61IASMgE1kyy7W3A/WtHxSQutuQeCAf0rHZsggntXZyp2M+Z30LKuHXI6 +laGk6o9hOEkYmFiNw9D61hRylGIPNWCRIvX3rOUbaMu/MjX8U3KyyuysCpjAGORzz/WqdjM1l9n l2hlKAEHoRVC5LfZgp5JIHJq63z2ELZ+5lSB+dOWkUjTDxTk77HSJqMU7eZHchQQAYzgYGOhB9eO RU32uVEG51RABgpGT37ZGBxXHZPXNIXbGAM/ShNo1lhIt3T0Ogur5SN005J5G3cGOM9QBwD9SMe9 Zc9+LuQRvKI4xk/MSSff3P8Anis6SQoCSO1OESOoY85HFVvuCpRj8L1Or0zxbpujWW2w00SXuSDP cEMAPZQOfoTj1B61zmoXt1qN008zszkk88AewHQD2FOgtkyFPBIyB0Jq3FZqch9wYHgYwPzqovoj F8kG3LVmQIGJBJ/DFDxDacdRXQRwxoQu0ZHHAzn86y7qIpMwII5q5U2ldjpYiNRtJGHMxLYAyB3q xYhY5UZumeajaJBclZCQuc5AzVj9yVBQsT7jipltoRFXnqe7gE5yaXGeAKUCnAYHNbHFqNx2xTwO OaAO9PAGOBQFxAMdKdigA9eRSgZotcBMDFLjn2oA7dKcAM0xDQO1OA4pcHpS49aSQABn0pcH0pQK cASKYIQCjA6U7rRjPagdxuOOBRg0/HpRj2osAzHOaXB4p23inAAUWAbjA5pcY7cU8Dg8CkxgZosA 3HpRjHOKfg5NGD+FADcUYyMU7HvRj86dgG4ycmjGelPA9aXHOQaVgGYx1pcU7HGaQjHSnYBMdxRj OKdik2kmiwrjcDrVcAyXJYdFGB9T1qzIQkbMTwBk1HboRGCRyeT9TQgZJt4xRsA//XUoUYzkA009 OKQytMNzKgPU5P0qveuxUKh4HFW408xpJCTgcCqd6zxW8jRIXcAlVzyT6UmBkR3UscxDxNgZyxOa p6veqluZcYKgn8e361ctLi6nlcXNj5CBQQSwJJwMg1zev3AdfLIxvbOPYVD7FKxzbASOxILMxJJI 6k1PBEEAIxnHOKUqBjGAKUkKB71cVYHIp3yu4LAZCEEn0FQpZXcpMywOyIAxKgnjnnjp0qe4ZxHJ tYYYEEEZzVjSdfurBCkMKOxAAJ7Y9jwevehuS2Fp1J7WZHVVGQcZweufStSMblz0BHNZcMUsk5ml 4ZjuOAAMn6VrwDKjArdbambSvocxrkDRXpHIDqHA9e39KpxRCW3YAASqc4A6j/EV1OtRpOUBUExr gHHQ1zot5UuCycEAsM98da5qiad0dFNpxtfUosWIxnGOgqS1aVpAgJ54z6VZlhWePzIFwx5YZ5B9 QPSrNlbGIb3+8eB7CiEXIJSt1FIu4APJnLkEZDqD+tTpqE4mMVzFA4I3ZxjqTT8YOSeKr3MRysoG Rgq3t3H58/lRVguW63FSqS5rPY0d1j5ZkeFSARkwSkEA+xp6Lp0iBlu7mIeskQYA/UHOKyNNthO0 uSwOAT6HnpWpcvFNALVFA28AjjJ9/WuRprVneoX3GTWbC5iWy1C2nZwSRtYEAY6jBqe3sdXu5Wig sBM6KXPlSqTgdTgkH9Ky3gIi2AAuCOR6Zp0lpMqkxXcowMgE+3bGDXRR5raHFWtfUkNh4rd3eLT7 gomNyLCTgEZGcDPSs651G6WUrc2jK4UIQSRyCSTgjrz+lWrXWdYsVcRaiqknLRysM8AAEZ9gBwe1 aEfijXTboreRcxKABkqcgccgn+lOTezRCSTuhnhq2LPqN1KpAS0kKkHkFgFH/oWapRRKJnVSzEcc gEg4+la7eKbtdOuLU6RFBHOAJJI7dR0IPBAFVtFUOs05AJZsDj8f6ihJyaVtBtpao0Y9ORNQMpKt GpKqNuNwHAJB7dOD+NXJNK0y4GZLOIE91G0/mMVEsoVckjHv2qnc6yIlKwBWI6ueQPp61u5xgjFJ ydiS70fSLSItLcXEKjoqSkk+wBBJrEa9hgDRadEYEb70hOZG+p7D2FVJbiW4kMkrs7HuT0qME4GB XLUruWiOunQS1kSxuQwIIyDnJFdloPi57O2aF7VJMnJcsQSffg1xa9MdauWTDcwz0ByK5ZN2NnFW Oxl8X6bOxMumqCeuUVv1IFVzrnh2UYl09R9IgP5GuRYfOe+KYSeuKFJ9w5E9Udcb3wg4G+1dSepX eP61EqeDX3CKSdCevU4/PNcjJ0OKpl3STKkgnj61pHmezJlG3U7oW/hRWyb24I7YXH8wa0bHTNBm U3MAvJo4zzkqAT6cgV5/HJ5gwQQfSu90aCZvC7JAjPIxOFUEkk8cAd6T5rkvRblq31hXZntblYIg cJGVRcAdiCST9Tx6Cn3Gt2jq8rCBgDlhC4LH3HIA/AH6VlJ4c1i0iMtxavAshABkIBzkDJXBOACT nA6U3xB4YttJ0lLlL9rm5MgDbI9qAEHkc564q1FtpEba3Gf8JTqd2CsErKAcDYoBA9zgD+VWbKTx LdYaKW7IHIBkH8if6VV8P2juIolAcyHcFTk5JwAR68dPf3r2HQbUaTBi4MUe4A4P3wf5gexrSMVf VENvc8vuNY1G0zFqNsA2PlkCBWz744I/X3qBNRMoDPGjqfQc165r2h2XiPTnQBRLglXA5B968Wnt 5dGvp7G7BQxnjI6/SnOnHl5ohFtuzL8ljDdRma24YclazblNozjnoa7Dw3pNpqdqJorsxzAkMjAE HvwBz0qW/wDA1zKpktriJ0J6BWOD74HFZRTlsXtucLgYHWrFrF5soXBI6kY61u3fgjV7ZQ4WGRc4 ysoHP44p8OgXllBFK+1ZJSQoBB6g5zjIGM9zQ4tArNlfT5opL2GNYNpjALHjnAGT+YJrc0QKI1Jj IJGSCQTn8Ky4tLurIz3UpRlKkFlIOCeg9uhrf0iIBY8jsK0pJrcmodHZW5cAHhRyTnoKk8XkJ4e8 tQCGZVA9sGtW2sVWxCNwWALEdfXFY/jDEWl20I5BlAAPfArpRlcXRoIovDuwbA8pZjjAJwf16VcW NjAhB52jjPfHSoLTS1ksrO4MhBWEqEwMEtk5z171YhkDRDPGCR/n865cQtmawZVjN0JirwsEJ4YE ED681awcZ71IWHY9aTr6Vys1Q0EA5Ip+4YxmmkDPJpcDGM0IQhYDODzTWORnIpcAnOBSEDGAOKLD I2JxxUTkjHXmpmBByDj61C5OaLAKhJPSnSKDGcikQkHAxUpIKEEAGnboA5AAgz1qbAIwTxTUAKj6 UpB7dRSs0IUFlGAxwPQ1XkkZvldVcdMOob+dTdiCKqyAA5yetWpNdQsiOTSdLvVIuNNtm9SE2n8x is248CeHrrJNrJET/cfP881tQkgHBNSKcggkCqjWmhNHGXPwx0xwfIvHjPYMmcfiDWdN8MpwMwXV vJ6AsQT+Yr0IhwTjB/GkORkEEVbrPqhI8i1P4c62Nuy2MgGT8hB/kasWOhX2nW6pPbSRkDJDKR/O vTncg4BIB7jiq0ks4yFmcD03GolKMlsWm0rHIwRsoGVIq58y8npWrLcTDIKxOB2aMEn8cZrOnnJb DWyD/dyP61nyLoHMluIpwCT1NI7YH1qs92EbBRgPrmm/a4ywJJAHY1PJJdBcyL8K7I8kcms3XHIt VAOMsKufbYCABIB25rM1eVZVjCMGwSTjmiKd9UVdNHlni+MrqCOerLjjvg1gocqAevSun8ZoWlgY Ak4IP6Vy0YYE8HFd0V7qZlJaiTAqQw/GnwykEAng0TITGQBziqqsRx0xSautQTsbH2KS8CCEqSDk 5OBj6+tXI9PvY0kSW2YIRkNkEZH0NVNMJMROe+BV8sQMgnPY5xXPKTvY9GhS9y9yiLK5MDTCIlRk n51yMe2c/pVnRiqXkUkqpsLYKyLk/l/jUq3MwIAlc/Uk0TXkyKCGXcCCCVB5/EUlJ7M0qU5uNkyv qd6j30tp9mi2nO1guCOM5rPt0Z4iBgY9T2q2ZHdi7MGdhgkii1iPnJEo4cgfma15kkYQoTj7zYto iy5SWUAqMhhyQfwrV0y5tpZZbTU5mSPBMcwzgEAnGOMk9K2T4Z08TCJJZhLtBbDAYH5ZNZb6dp01 wIGmuC4kZPmIIGBkn6VpH31octSMea7ZVfVbSK4KQqzRjgFiMj3NVbuQXbebEhxjBPUZq4NFsHiR 4pZz5hI4jGQAcZPPTP1rHeJoJWCSsMHGQetVJySsx0KN5c0CK4jU4YgZBwfWpLe0E0UjiVF2kZDE An6DvTvPcjDhXHfeoNS21gL7f5VqAQBkq2P5msuZdWbyVSOtj2oDPOOtPx+FAB6YpwHauk8sTGac ARSge1OxzTATB5FKAcY4pcccUoB70hiAClApccUoB7UxbABjgilwOwpQOcin4B6UaAMApSMDFPwB 2ox6UwG7c9qXHoKcAfSlxjtQAzBzmjGO1Pxx0pQMUANAz2OaAMnFPxSYGelFgExntS4OOKXGMUoG aBjcc9KUDHOKdilAwKLAMA4pdppxHegA5oFcTbxSY55p+O9GAaEDGY4xS4pwHOaXHc0AR4PcUoU9 6fj3pCKAsVbnLhIgPvNz9ByasKpA4qMDfcEkcKMD6nrU4UnpzT2QLcj2kZIzTJSEiJA+n1qfGDjF V5wXdEBPJyaVrgxFPl24UnGetZF/LcrIHiRWQZBUn9TyK17gADGOgqjIo2nPpUvzGtDHa5Z4iHXa fbgVw2r3fn6jIVOQnyj8K6vVroQQyuxCquQAT1OOB9a4CRgzM5JBJJOayv7xaVy0j5IJPFMnZnXC sAc561TYFuQSB9ahkDgnDHr1zVqXQTg9y9JlojuOT396j05M3ByOBnFJ5U9ptfduSSMMjEcEHrjI 6g5GfUUollSI7QAQdxIHJ+vtT5nFgo3VjoWKxrnBIUZwOpxUmlXX22Nm8optbGCc5rEXU5xCHKq+ DhsnBFT22vpEADAQAeSpq/aJ6kuDRp3jAzkcGqLqCxOMfSopNVt5mLEsufUUou7dsASrk9MnFNTi yeVroOWJR0GPWl2cZzTldHOVZSPY1KAOPemmFrkIUgDjIzSkAAgLkHgg1MAMdKCgI49Kbs9AWjui CcstuEtVCk/ez3+lU7S2lW4V5NxAYFsnnGfStLaADxnFCgj7oOKzdGLZr7eVtSNYyXLkkE8YzTyA c4HQ80uw5ySQKfsAHfBHpVxioqyMpScndkAjR2AYKee4zTngQyAlFU4GcDAPbJHrTtgByPpzSs4G SxAGOSeKbtbUFe+hD9gtidypsJOcoxU5+oNH2m20yFl3sxJJAJJJP40zzmkDlGKRry0hHIHt9egr NMAldnZGOTxk5OK5514x2NoUZS3GXOr3E74IAjHRc9fqaha+YKQyHHsatfYl6iMmmPZKRgow9K55 VYyepqqMlsVYZWlBYLgA9DS/aFU4ZSCKl+zSwqRErDJzgjNQkTb/AN5bk54yMikuVs095LUnSdDg 5xnsat6epEkj4JB6H1qrbWz3FwqJbTOxOFVEJJ+gAzXc6T4G1meIPLbfY4COXuiIwPwPP6UpwlbR BzrqzkHyGPHc03DHgAn1r0aPwZoNo5fUdUe5YdY7VcDP+8f8KvQyaLpa/wDEt0iBWHSW4/et9eeB +VNU11E6yWx5pY2iy6hFDOuN5G1GJAbJwBnsCe/pmr1xpVte621lYiNY4gPMkjBKk9Dgkk4z0ycn rVTxJqF1e+KLueZyWRAFI4woAxj0HP61J4TvkW6mDEF5EBB9cE5/nWsYNGMqjkdvp+geHdOiRntZ LycAEmaTCA+wGMj6mtf+2TBGIrVIraMcBYUC/wAuTXNXN86QEwxmSU/LGigksx6DArN/4QXxLqcv nX6tASNwEh5A/wB0dB9cVfs5PUjmOm1LUXtofMu1kXPI8yKQA/jtIH4modJn0nxKXsru7FvnACEZ aTv8p6Z47n8K5y6svEPheEZuHls2OCQxKg9uD0PuKy1BvxNOhWCeIGQ7TtDY5yMdDUqMo6hJ9j23 TrLTdEh8nTbZUOOZM7nb6sen0HFWFMl0zRkgAKWIHUgc/U8+tcr4P1v+19KTzXBuImEbnOMnjB/E V0M939hu4JVYHDZIB6juPyobbWoImtryS2kADHGenas/xjoUetWA1SzRftUQAkGOSo/qKuXyoJ98 RzG4DKR6Hn/61T2E0sAMoXdETtcHnr2NKDcX5Mps4bwqBBeXBhyfkA+Ycjmu+tFkfTZGBABcdfpU MljplkTN9lELSggSQ9GHuDxkd+hrnr+O4spBNbaqkuZQwRpTHhcgEbScHjqeT3oTjHRA1zamrr5a LQyN2BJIoHOOgyTTNJtpksA7Sb1kCuo5+XgYHU/pSeKpVOnW0RAw0gGOo6VM07Wmh7kADRxArx3G KuVm0Sr20KHiW5BstrSKXUNkEg4AAHPtk96k0ILMgc4IUZJHQnFcldC+nt76VgpW5AaNzgbm3AHp yAMGuh8GaHd2LRXc1ypVjgwopAPTkknBPXt+NOCbeoSPR4ZRLGGAIHSuX8ZzKHsYiu4liRzjB45/ Q11O8byvoK47xYTLrdhGOoQnH51rHclbm5cXq6bots7LuyqqACAckds1FZhXWRfRjx6dv6Vo3NvC 9mqzRq4QAgMAcEDqM96ybKTE8hxjcScfkf6msK/w3NIPUdcCWJhshkdc8lCDx9PWpo0fYGIIyOhG CPr71YMi+tG8H0rj0NUyIAgcmgkD1p5II6CmEADrQAgPOAKCevFJnmg85JzSu0FgYYAzxnpUDAZz mpHOB1NQEkD8aLjHggYxTnJCnFRA85JpzkMuAcGi+ugFlGIUZ9Kk3g8kVChAUZNKWBGAaPQLD94G TjrUb4J5GM0oA6nmopGw+M9qeonYemASM1IoAznBqmJSGAJ4BqyGyeCOaARISAeKaxzxUZYg9aaX IOKLhYGAJxVWQAE4FTs5zUMoJOc0aMOhUlQHocGqE0RHJH0IrRlYAcgHiqkwJXIPWhAUZ4FKgkck d6z57YY4OB1raZA9rkjkHFZ0qZBBycdaqMm1YlrqZMsDKMg59KgdHAzg89xWo8Z28Z9M1XMZMRB7 GqUibGVPAkqgSxJJjs6g4/Os6bRtOlJLWaA+qZH8q3mizkgYxUDRcEgVak1oLXc5qXw3pzkgGRM9 gQR/Ks6bwWh+aG7HsHXH8jXZ+WCMlQccUxo1xnA/Cr52K7ORt/DtzbRbQyOeehx/OmyaZcoMGJiR zwM11TxrglSQfQ1HtJGM5+hrNxTdzphipxilbQ457eRCAyMD7jFQ3SlVBI7Z6V3HlK/BIPsaZLYW 0o2vCjA8dBRyK9zZY6+jR56J4wBkkdjwatadPB/aMAaVEG8HcxwBjnJzXUT6FZMeIiv0J/rVGbw3 AeY3ZfqAf8KbgmV9cTVjpba9shDg6jbF+vySglj6kk8/SsV7GKSRpYmzIxIYqQeowTwfc1lHwzKe I5om+oI/xqpL4cvYySIEf3VhV024bHNKMZ9TcayktgZI3kSOMMQW44JzgkHv71y8rqZCcjOfWiXT LuHO61cYHJAqlLauAcRsCB1Oaqbc9zooNUloWMgnOQP610Xh4IIJWYgAnGT9K5FIHRAzhiCOecUo aNeQXB+prJwNKk+eNj6Dx2p4GKQDHA6U7B7V12PGQAY7U7GRQBzS4HWgBcelKB7UAdhSgAGnYBMc 4NOAIpcdqXGTikAYpwA9KTB6CnAGnYA6dBQB3p2PpRj1oATml/CjGKdjFDQDQM07GKXHrQORgUAN xxxS+maXBHIFGD1oC4AZoApcGnY4zQA0D0pcUYNGPWgAxnmjGe1OxRigBMcdKXFLj3pCSBkAnHYU wuJgA9aXHtikUseSpUdgetOxg0bAJikIAGc9Oad70yYAxlc8twPxoAZAuE3HqxJ/OpCWGMDP405F woAHA4p23vQ0CsRDJGWwPxqKL5rh3xwBgVYYbULHGACahjAjtQx4LEk0ugeRDOc5zisDWtXg0y3L Stl24CDqT6Cr+qajDp9rJcTMAqjgdyfQe9eZahqUmpXLzSkMpPyrnBUdgKxnLoi4or3uoXGqXAaV wqE4APAUf571XksJ0ywAkUfxIcj/AOt+NPMSsCY3IP8AdYY/WmpJLEfkZlI6gHFQvI0Tt0KzAgHI wfpTCoALFSfY1pi9kAy0cbH1ZATSTXJliMbRRgEdkAI98003cfMmiC+uYrm2s44s7kjw2ecHOCPp xn8arohGQRkEYqaOyxsdSChOGz2PqanliFpOQCHx0I6Eeopy2uRHR2KRQlSo6E81JDaq8THB3DnO OKArSSZHGTkn0qzHvhGEIJJznkVDbsXboyi0DFcBTwSeKge2Prj61po6mQszFQcg455re8N2eh3e s2w1K4JhbIkTBHOCByO2cHNFOz3Lq6WOSs3NvcKMgkEFWx0Pp9K3vKRovPt2bBPzx55U56j2Pb8q 6C/0fw9bDUIoVcXMNxIscjtlCAxAXA9Bjn1FcpBM9hKpDHCnqRnB9x3FW9X7pKs42Y/UU1LTrVr6 ViluyBokaMkyNnBAPGAMZJ+nHPGNbeKLl5Fja2RyTgbSQc/jmusvtTk1C1iiVUJUEFHclGJPJGTg E89fz6VhJp+mW3nfaYJ0uGIK7eijOTgehHFV7RdDL2bvqXYNTieIs8ZUjgjOefanx6hayMVD7SOT kEY+pqq0IljEMEHlxgZJIyx/wpYdJjDbnJI9AeDUe2kmaKlC2ppRyRTLuRww9RUsMQRXyxbcM/Qk 5z/SqUYWNWCjaAegq7amPY4ZlFvMCrZ6ow6MO+PYe9HtrslUr7FaaZEYquGb0Hb61QiM09w7S4Ea gYJ4A96slUhUlzgE9hy30FQRmW9nMKRNsXG1FBJJ9T6monUlJGtOmou7FLCfhARCpyAT94+ppY8Y AA71qWGgXtxcPbuqW7KoeQzuI1jU9CSTwT6dfar1hp2hxTs17fyPBFwXiUASNnoCx4A9SMnPArlc W3eR0SnFKyMhEJAwv6Vp2OgalqOPstlLIDxkIcfn0rQm8c+GNEymm6TFPIOBJMTIc+vOAPwFYOp/ FbW74FIZfIiHAWMbcD8MVUaSfmZSr9EdZF4EkgAfVdQtbJcZKMwZwPoP8aspbeEtNP3Zb6Re8kgj Qn6DnFeRT+IdQuWLyXDEnvmqjX8zk75WOfet405LZWMpVG92e2N4tit0Mdg2n2Knj9ynzY9zgms2 bV47tt82qwyEnq7sf5ivIxcsedxPtmnCdyBhicc9arkk9WRdHqbXEZyEubd+/Eyj+ZFRt9ocYjj3 45xGwb+RNecQ/aZmVI97MSAAoJJPoB612eleENSjiabVLTU4QoDIsMSkkZ5JBYEcexq1GQrJmTr+ m3U96kkMMguGAQx7SC3pgd63/Dfww1SeVLrUnOnRqQ2wjMpHsvb6nFd94c1fRfIa10wSLNH94Tkm X0Jyen0AGO+K15JmfOTgHkgf55/Gq50lYmy6DLGysNGi2WUIEmOZWILk/wC9jj6AfjSyzs+cnAPJ A/r6/jUEkyqMk4rPudRjiUksB+NRzN7gS38UNzaSwTANHIpUg+hrxMXBstSkiJyFLRsD3HIruNc8 YQWisqOGkwcKD3rz2Cy1DVZWmggdw7ElwMKD1PPTPNOL012Gk27I1fDOrzWd3cQwk5nKhcZwMZyT 6AA/pXQW+tXhul853dAcAnPA/GnWmlWWi6RbowE15KC0mVwcnoAD2GPx5Nb8NoktqqtEq7lGRjoa hSU3psU48u5tadqAuLdELAgDI9q1bed4GyhBB4YHkEehrirB3sLswSE8HKn1Haust5UeMMzogIzl mA/maLWdhas2CgurJ7ZW2iTJiY/8s3xwCfQ14vqlrqCanPDfzOk6OQeTgYPYelew24QEGOeGQEDK q4J/Ppn8ayPGGiw3lm2qPayvPbqFl2OF3KOjZIOSOhrRNPR6sNUc7bX7XOl6fbTTCWSCRsnvt4xn 6DI/Ct2S9LoqMQVIxjtgVjeDrvSp1vYriMRmMAwqTlmHORnHJ6eldXpWlQz6SZhHEV3MAZOSACRj P+NYuTTsy0klc5HU7xTqNnYwInPJB6AZJH6k12+kMyLbq4AAYYA56V5vqYkkvzKYEDqdqsgwQAeO etFxLfLboZLi7i4yrJcMCB9AcVtGRnJNs9cj09LG/u7pJZGacgsrHhcZPH5965nW50l8WQxlxvji QBecnJBJzjHf1715jqGqa2G8xdXvZIxjkzNkD35qXRdcvWu3lnmW4kBUA3GWYjI6HIIPHU54q3Jp XsJR1PcdWnlghkYH92I+ijLFs9h9KwNMnllZGlDLI2SwK4I6jp+Aqtd+I7k3RSeASQKoCmIjOcA5 OTjkEYpLDVkvLoBYTGY/mJJBJyR1x6c1jVknEuKaZvSeamCCSPYZpkU7Sg4ByDyPSreQQDmkJBHN cqsbEaue4Ip+/jrSECm5wMUrWAeGGfWlLDHSohnPWkLY4zRbqASHIxUJA9ac74ByaYGBNCXcTYuc Z+lLkkADg5pBtJwDUiqAc07dQuPAO3JNOJIHem5GMZNKSADk0rFKwK5HUimcPI5J9hTCxAJJpsbk AnpnmlqLQY4IapYnJwO+MVFITk460yNyrc03sK+padgD1ppIznNIzg49MU1iD0NJXGK75HSonJKg jvQW45NMLgqRnkU7WFchYZznFQsgK4BqVyc8GmZzn86BEaIRC64zVF0IJBGM1oKQGIJ6ioXIDYI4 qloD2M1kPIOahVNzMvqK1TEjHOOtQmBEkDDrmm2hGQUwSCOagYAggitW5tyHJAGM5/CqUkRBwRTX cTWpRRSdwAqNgBkkGrO0rJnoDwcVHIoDYIqk9RWKbAAE8H2qA4ySBVmRQcjpVcABiCM1QrWI9xzk jOKdvJ6kjFKxUcYxSKFIPb3poTSRGXJOAc0jMCuOtOYqAccmo8nmn6h1EyAeODTgxByDnFMyTSqQ SckAdeaAJQUf7w5NRvbQv95FYA9wDTsgEEc0EEtlT1ot2C9irc6XaXds0QhSOQcq6jHPofauHvrc 2k7RyqQVODkV6FgnOcjNVNR02LU7cqcLMB8rkdfY00ktzanWa0ex6KAO3NOA5oA9B1p2K6DkAClA x0oA4J9adgYxTAMZpcH0peO1LjnFACYOeadj2pcYpQKAExjtTsUuPWlwTQg3EApcZ4AoxS4HShAG DS4oxzRQDE56nOacB2ox2pcDPNOwCY/CjFOxxSgZ4oC4gHpRjAwaXHtRjigBPwpceooxg07HsKLA NxmlwKXFLjPOKAGcd6MZp5FAGDxTAb0FAA707GOMUYzxikAgUVGwBkUHoOamxTAuZCT24oW4D1HG KUgDHOc+lJgkEA4pcEgEnpTBaEF0SISB1YgCorhsQhQMACpLgkyImM45NZet3q2WnTzsQAik5NRJ 2QLVnnvjPUWv737NDIDHAcEA9W7/AJVyiSSRNjqM9DVqdHkkeZX3FmJOeuSc0z90ynzAQc44rBXs aq2wRys5wEyR6HFKZwrAMCp9+c1WcsXIUgAnAOOtK0TGNRnODzk00uoF5ZIiBmVckccD9acXQsoE qHOSMEHH154rPEZ2FsEgdTUalC3Uj8KFuFmdPc6NPBbpKArpKoYNFIGHTPIBOMdwaowRG5jMcjkT KPkUnGR6CqKSOUzFI3HXBIxTzJISruWYjoScmmgSZKgQKyudjDrkcn2pWIypBGPXNaKWgkjR3RSj EEAHk/U1m6hbLExK5CnOPb2qOVMrnaInfZKQFBUnGKnjgMtwkVsH81iAu0c59BzWdb7nl2DJz296 6j+xleCHaGecnLADAI9AfUUezZSqK2pWtfNt2Zrp2aJmYlmJOGJyT9SetZ+pztdzsbaDK44Ctnn3 96tXs8uw6YbmKG2t1ZgJFKktjJz6k4A7dKq2t3p8WlWzpKz3DljKNmCvPABycjHsKuK0sZSk27le xs9VXLxwuFHJBGePXFaK3UkZjWeEjceAACMj2PFS21/pwV2aeRZBgKBGTnIOe/Hb161bSbSMqLjU nXHIzbBsHvyTmlKCezKjVcd9iFpUc5I2k4zlSP5cUhkQZw6nHoCf6Vevb3RIlEdtqy3CkBiXtvLI PORwDn86pLqdiFwLuAZ9QQfz61m6buWqsX0GBGdTsSRgTyQuB+Z4qxFZIFLT3UcOAcIgLuT6ZxgV H/aFkDuNzA5BOAWOePxq5Yzw3s22JIXUYLOjZIH4E804wB1eiLWk2+mm6iE+nPMWIUF5SBnuSAMk ewIqz4j8TSeH3+y6SLKFtwBe2iwNvfLHnPbGaz9c1aPSLQkECZgVRc8gGvOrq/nvHJkkJUngZ6U+ S70I5r6s3dR8T+ZGYreMkty7ucljWBPfTTMN8rEDgDPA/CqpcAkH86aW7AcVagkJtkhYk+9AB644 9aYAzHABzXT+H/B95qpWa4JtrQ4zIw5bPZR3Pv0qyTnlQscDnPGK27HwlrOoANDYyBDyHkwi49ck jP4V1Zm0zwzctaWOmt9tUgedcxktk9wCM/litay0HxD4hw9zfXMEJ5KoBGMfQDOPqannV7Irldrs 5eL4b6k2C95ZIQOQZDkfpWlpfwtv7m6Amu4VgHLOgYnHsCB+fSvRNG8JaXog3KpnnPJd23HP1P8A StxnONoAVR0AGBVOfZE2M7RPDuk+HIgtlbq0+ADcPhnJ9jjgfQfjWhLKz5LHj0qJ5VXgkZqhc36R gkkce9Ztt6sZzHjOBdKlt/ENoNk0EgEu3jep45/l+IroG1aJ7ZJVYbWUMDnsRmuI8c69HLo8lkjB pJmVVAPTBBz+n61nTNqMumxQwTKhRAoDE5IAA6ilJqwJPodJqviiGDKhwT0AByTXMXWpTamCouzE pODtXcR+AP8AKuemeZJfInQrMDlieSfQA/561beyhtrIXHmqWZS20E5AwCfxwVx7sfSmotq6C6W5 ePh/RZ5Y/J1dSzD5/tGVwe+SBwD25OPWtyS0v9Ito4rWBZgy4jkRgyAevBOB3zj8a4aYMjEA5IJH ByCR1x7DpnvWp4WTU7zV47awuJIS5JZwSQFHUkdCPr1JFZV7RjzTeiNYSe0Udeli9sFv9UeMKFBU qwZWx3BBIPPp3qhc+JL6Yn7CiwoDgFxliPXngVr61YC2szNewJdGIjdJGArkdzxgfmDWLB/Ztzn7 NcowB5EjbCo9MsACfoc+1Y0sRTqq9N7DdN83vBZeIZxfRrq6q0ZO1ZlQZUnuQBgj24rSvtRtrmdr a5cxygZjkhc7JB2yDkj8Kw9SsiIyjAgMAynHXuDWKJWlhIZiWjIwf0xWsE5O4pJJaHW2Wqf2bPuS SQFeqFshhXqOmaxDe6dG8kSyxSKCCeDgjpn2rwyKYyRKzEkqfxxXo/gW5Mulyw55ikJX2BAP881q 01ZrczudEfDHh+dme0Bs5mIOcnAPtzgA1oWGjz2OhXNi8om3szRvHk8HBAP45/OoNxx8yg+5HP5i nRzyQtmN2Q+gPFD1+ILs5y60NwQ1xcQ24XrvPPH+fWoZ30FI1SW9acqMExKSPpkA/wA66TVS2r2L W0saPJjKOFwQf8K5DTtEjkujFOWXGcgcc0XSVx6vQSJNAaOZoLGacoMkSOQD+Gf5iqWneItLj1OG 2tfD0cE0jFRMSPk984yfwxXSJaWds5tooiCerkjmuH1m0bS9bSSMYRiSD2yDg04z5lYTjY1NNu2m uHWeB1RpWkJRjtAIwAB26dfatvS3hF8/lxOgCFVLEHJx149xWBblhYxKhYFuuD154rR0m3kXVIQ5 KqrgMSeAD/8ArrGeqZaep3ccjGJSGJyAaeWlAyQwH0pthaztbABdxT5G5HUdeOtSPp9yCCu8EE4O AxH0yDgVmoNq6RV1tcZ5jEcnmjex6mnNBMoO5GGOpIqMqwOME/hQ4vsF/MUO3Y0hJPOaCGXsaaWJ 4xilZ32Aa+T3pnIPJ4p5J9aYSQT3qrCbAvg5BqVJQRgmoDz1FA47ZpW7CT1LRkBHBxSFyBwetVyc jgmm+YRgEZosO5KzEjAPWmb2BwCKUFTyDg+9NdGA4OaLIL9w3sT2pc45NQlyvUU3zcjuaLAyczAY HWk88HjnPvVN2OSVzx2pFnOcMOfWjl6oXMWjLnjOKZ5oB5PUVG0gxkDNNJUjOcUWHce0ozkHiofO Cnr+tO+UrkDpULopB601FBdkhlBIPcUkjB8MDUIhAB5P50beQA3HvTsK7H5BGe9RuwIyDg+1IQ4O ARimMGB5pcr3C+g6Q+ZGCOo4NVmAZcHBp+9lJ4yD1qIuck7SBTUWg5kQywBgeAKgkg3x7gMkdats 4A5OKjWVQcA5Bp621EmrmXJGepqq6EMGAzityREIyAOapyW/HAoT6A9DLdDnOBzUZA5AxV5oSMg9 D+lV3hII6j0NUG5AAATkdR3prIMEipGQhup4HekwDk9+4pollcjAx60BBjIP1qYgYPGR9KjwR0BF OwthMHqKVW56YNIT3FCk56ZxTAmVgRj+dPkVcAp0Ayc8HNVywB9DU0bqeCSKT1A7kCnDjvSgdwKX GTzXUZgBTsZoxTsDFACAEU4Ak9KMd6cMY4o3AAOMYpcetLjuKUAUIAA9utGM0oAAzS44p9QExzS4 4owaXFILiYPY0oFGMD3pwGaYCYFKKKUcUw2ExmlApeAaMetAgI9KCMUoGDS4oGJjtS4pQMGjHekA nJ7UYpeOlGO1MAxk0YFLj0oI55oDcZggk0uPWlxS4xSuGwnQZpEBxkjrzQ3Cn3p6DCgUxMMc0AD0 pxAAyDzTSQBn0GaARTJ3XDt1AGK4n4jXZi0aOEHBmlAI9gMn+ldtHny2cjkkmvMfiXOWvLOEMQFR mP1Jx/QVlPUqNrnDJM6NlWIHpU4uw8eRw44IxVUDjkUyMEEnPelZFlkSgDbuIz2Hanhiw4lAI4we M1VeXAA2gEe3WkVwwHUHvScUBakllJw4BA6HH9aEcgZ2rn6VCgJcYIIHXmtGxgW6uooXljiViAXf oo9Tx0pN2Vxq7HwMIYyyygGQDcoFTGYAqzAMAeeBmn/2RcsJ5bUCeOJirFCMkA9cdcH1qzodhDfz SRTEjau4D8cc1lG0tnqaN2RPZSqkbFiEjJBXJ4GQe9QawIlt8Bhv3DIPXGK1JdBxFJDBIAGIIz0y OlR2+iX63ZmkaGQ7cEMSfb0rWEXszNtdDntEiV7sysyqEYAgnGQSRn6Cu3aS3gtY50mQRgkqxYYJ CkYB9ckVXs/BU0sBuN0akk4BPcEg9B7UDwdrjW1tbPPaGCKVnALMepGeMd8CrtLYl2OKt4W1/X44 pZ1zKSzuWwBgE4z26YFb8fg5NxC3KMD0AP8AhXYa9pf9madJqb2losasFIhXBBPQ9B1NclrOukX0 YswFEKbM45JOcnj2OM0pyUFsEYuTsZR0qJL0qJ0VFYglz1APUHHFX7jSxFJbNFBHdQuu8mM5AAJB BxyOh61X+3w3EbxzwRp5hAEg+UqeSec4575qnc6omnXBSznDRlQDICGIIznGD09647znK6N2owWo sp09I2lVYyTk+WGyR7AH8qrrfWThsWUmcYACA5NZ0l1EFDR3si5OSgQgD3HNOUyTzpIl7JICwJJB BGDjkZP511xTtqY3W50Om6at/EtzHAkak5UOASfQ4HbPrita91ODQLFTN5b3ZUABFC5PrgAfnWed csNPhEduEV9oBcZxwPfqa4a9vJb27eaWVnJJ5Y5OPSlq2NtEt/qM+oXDTTsSxPQdAPQVSZ8HHc9K DkjOTSIhZsAEk+1WtFoTuIASeetaNppU9zG8oAVVGSG4Jz6V0Og+EmvbZL1Zo5QMl4wfmTB7gjp7 jIrutF8MXdzdeY0SGIDgMgKnjGSD1pXuUklucvoOh2mnWMeo6jCSScpGVyXPbA7j8K6WPS9f125M lqotLdT+7klUggeoXIx+OK7e10KztmEkqrNKBgHHC+w9Pw/OtInjaAFUdgMCk2uom+x5/c2mu+Hn W+1BbfV4oRgyBAGjXuOBnHuCa7DStYttZ06O6tHHktwUAxtI6gj1FWpShQo4BUgggjII9K898P3B 0TxlqukIcWxAmjHZehH6MB+AoVnsLV6s9CZwoJJqlPeqgJJArF1LX4LZSWcAj3rj77xHc3jMsJCL /eY4/IVLA6jU/EEFsSzSKCRjrzXKz6vfavIY7VSqnueCR7D0ptppkM8pa8vCp6h9hYH6DI49/wCd dBpWlx243Q3cc0YPQxspI9ATkH86m+tilHS7PMb+K9OstDJE7yxsQFAJzg9TntXQ6uljp0IispZD dcGSTedicZIAHUema6fV9Xt4pH8qBZpFXDFIwSQDnGcZIzmuN1fTbucRzi6tZ0uCWHkPkLjkgjAw fb2qnrZJDjbqc5cXstzOZnfLHjPTOOKjNxIRksWGABz2GB/QflWvqHhy9g0oX5jQW4baWEqkg5xy ucjn2rIsbC4v7tbe2AaRjhUwck/gP51TkoRu9EhNXdkaOiabfa3ei0skJZhhjnAAzkkn0yM/hXrn h3w4vhqKR3ZZLqYAPIowAB0Ud8e/emeDvD66DYtCSJLtsGRwMAZ7D2963bqAzxBWZkyeQrYYEHjk ZH4Zr5PMswdeThB2ijuo0lBXe4w2wuVaNlDKwIIIzkGucuPhvp/D2t1cQSg5ycMAfYcEfnXV2bBD tOCQODVhyS2cknBwAQM8e9eXQxFbDu9N6GrhGWjPJ9Sl1XQHMF6wvrWQlfNYFmOOwZgSp+n4ZqgI tPvmkeyfyZGwBbu24ZPBO8gAc88/nXoPjC0S508KzKPMUrtznkcgj3B7+9ePyQSRS7CpwOcHofev scBWdekp9Thqx5JWNf7PNbSPFIBlSQSCCCfYjIP4V3vw5cs16o6BVP48/wCFefWWu3dskcMhE8Qc N5cxJjXjqFBAzgmu58HeItCs2mdzJbvO4XL8qTkkBVAJAGe5Ndt7LUx06HopA600qKWOWKVd0Uiu M4OCDg+/oaU0Kz2BkDrjpXO3OqQ6drJiuAVRgCHA6A10xBNefeOz5d/CwHVM5z70ON1Yadnc6mNI 57pZLeUShjn5TmsrxhYGfTw6qC8bb1I69BkfpXIaTrctpMrK7YQgkA9R3H5V39xqOnX9p5drceYh AbLrg9OnPX8KxV4y1NG00c5oiG9tERBucDAA71rxRTJLHbLDKJJGG48bccAA556k1h6Yx0/VprUN tAbchB7HkEfSutnuxFGs8022ZBkFicHaCRn6kAVM73tYcUje0m6aG4+zO376I7Tz/rEBxj3IPT24 rpgQQCOh715PcanNPHLIjkuGDb0J4OSeD2GTXT+HvGUV15dtffu5jwJMYVj7+hP5fSqpVOV2ZE49 UdnkZxQQD1FHB5FLXYZFe4V/LzFEjt6OccfXBqOCESRk3FrHGwOMKQc++cCreKKVrsdysbC2P/LI D6Eiom0q1b+Fh9DV78aKXKuwXZmHR4Cfldx+X+FMOig9Jz+K/wD161SM9DSfN3xUuCvsF2Y50V8c Sr+RFMbQ5ccMn5n/AArRltGaYTJLMDnoJOPyIxVlCxXkEH0OP6UKC7DuzAOj3K9FDD2YUw6deKf9 Wx/X+VdLkUtHs4hzM5OSwuiMGF/yNVms5U4ZSPqMV2tRyyxxIWkZVUdSTik6SDmZxfkMDypxTJLY nlVOfpXZRy2tyD5bRSY64wcVIYYSP9WmP90UlBdGF2cIYpE4IJHXpTdrE4wRXctaWrDDQx/kKhbS 7Fx/ql/Bj/jSdNb3Hc4rcUOM8UFhgEEYrrX0K0ccKw+jf/WqnNoEIU7S4/I/4VDglqNNvQ5lmJPB qIu2TW3JpSLwJfzXH9arvpqgYMij3IP+FTzR2DlkjNWTIwTjHeguMYPSrMmnMOVdSPY1Xa0kAwSC PrR7vRi1Ii+CQelCyKBggYPWke2lHYEVGY5AMlTj2osujDVPYWVFwSCCDVRgozgflUuZEyNpqGQM TkKR7UAtSNmOQMnHsaCQRlWJ+tRsD1Ixz6UAsCCKLAhrbjzgGmEDBDcj+VSsScgjBqInB6Uw2Kso AOMH64qEjByCKulQSCKY8av1XB9qd1sMqhQfxqN1BbAqd4QvTIqJlOPXHqKa1Fa4wRjHPekCYPFS AsByM/Sl2568fUUJ20CxDtB4NKEAbhsCnbcHPWgrkHBp6BY74DFOwMdKBkcinKMnNdJkAHFLjHX6 UYFKAPSgBcYpcYoA/GnCnbsAc+tKBQBS/wAqADHFLRilA4oAMc4oxRgUvWgA4680vuBSYPelHpQg FwBzmgD1pcd8UvNACAUoo70Yx3poQdaXHaj0oGTz0pbgLikxzS0uDTC4g9KUD1pAD1ApcUAGM9KQ Ag0tGMUAhCKXFGKXAoAYRkgVIBxzTMZf1wKfigPMTBxjNMmOIifwqXFRScsi8ctQMjlULCAMdORX lHxGQnVrY+sRx+des3GNpHavNfiJbESWk+3IIZSfQgg/1rKfccUedtGcZxg1CAQScnjtV7ywRw2M +tRyWzj5gu4Y6ipTNLFJlJ+tNjBDgE4zU7DjkYNRgEOCR0p3uTuSohBJJOBUiuQ2FJGfep1hRogw Un15pPJV1JUYZRnr1qG0UkyW0u7mynE8ErIyngqSPwrovD9+J72QOiq7KSWAwTk5Oa5uFDIAAMk+ lb+jadPDcJcERhGViA0qqSAccAkHOe3eiMUncblpY6nK5BBOSfSp4wgkALjkE9DXPT6zHFKVVWO0 84IP8qik8UwIyv8AZpCAD1I5zVpkabnoekqp08hnPErDoehY+3vV+KON2MYck4JU4PUdulea2fxJ tbe1ki/s6RyZCwIlA4yDjpUy/E9FAul0mXy1bBHnAE8fStYpvYhtLc7PxcYl8G6gJQ7qBGSinBOH Xocdea8lmvtKmeFrS1mhVFAkR2DlmB5OcDHbjHFb+ufEWHUtCuLRNNdDcKAHaUEKcg8jHPSuFS4i t1Z5GA3EcKAee5rCpSdRNo0jU5XY3/GGs6PeR2g0zTzbIgIkXfuLHsc4HvXImeEvkoQAMcnvmrEa G4lD8lCSQTxwa1007THlWG6nMIYAk7SR35z2+n60qUeVWbHN3Zz5uYFJzCGBHQnGKu2IkvVkW3VY UGSxB+6vcZNa0+l6DBIRbz3Ewx1aEL+mT+dY97MsIeOAMquMdAMj6CtXroiE/IoXkoeTZGSUXgH1 96rr1wM9alSB5GCqCST0A5JrpdP8Ba9fW/nx6bMUxkgkKSPYEg01HQfmzmoonlcIiksTgADrXpXg 7wDdSgT3NttDDI3jGPw7Vq+C4vDulXqWN5ZPBqRIAe5HVvQZHGe2OD616dnC7VAVewAwKltLYEYu l+FdN0rLrEHlPJPYH/PpW0OAFACqOgAwKQkAc4qCWdUByRxUtgSs4UdRVWe6CAnOKyr7WI4FO5wM e9cnqHiOWclLYFs8Z7CpvYDpNR12C2Qs0gAAJOTXlc3iEy+Ir7VVdUjZRCjk9QABwO/T9asa3HPJ p0ss8zFgpIVTgE9vXiuUh0S7uFVyhwwBH0NVFX6jdzVl8RwyyhiHkPcse/sO1dX4eu9Fv9P8240h JJAxG95HJOAPQ4/IVwraDcoQChwa9B8NX+geG/Ce/Vpc3LTtsgQbnIAHOOw68nFNwW4k7GpPeaZ5 DKlgirEu9yXYlVHXGT+lXi7S2CEKYhIu7YBgqvYexPT86yYPEOkaz576bbzKIoj5izKMEnhRwTnk g49q2bAtEtpHcOWklzIcnJCjOB+eP1qE0mooqztdnHG6NxeyRxgLg7R6ADgf4/jVxdCd42ltlLFz uIHTI4J/oa07bRNSfLQrAQGIBMIJOCRyce1dZ4fP2fTzHcafbyTK7hpNpAbDEdBgDtWijrdkN6HB 3doYtOkgvWVUlGwgsAQxzg468dzVvwR4eXTNOkv51X7TNkLk8hATjH1xn6YpPGVgbu8uLpGEUhYb IwMKFC4GOeuQO3rXSIhOjiGI4LQBFPuVwK8XOazhCMF9pnVhY3u2WbCWQWplYYMrEoAOQvQZz69f xqzGCXIAyD3rG0S7lvbUNNG6Mp24Ycccce2RXQQhkIIGfrXylaKjUstjs1epIlscbzlT2IFBOGBy MdDxT5bguwQnBI4PaqN9cGBCsZBkI6noM/zPtU0qUqs1CI3LlV2c54ru4txQKcQKSzk8EkDj8h+t eRjU5Q0ysQwkIDE8kAdAD24wPpXVeL9YRr0WNtLvKtmYjpuzyCe59e3auNvLZknZkB2Mcr9DX3OA oKjRUDzqsuaTZpQPbXKOwcIwAAVj1JOPp6k+wqw9jPbSIxUhgAykDOAQCD7cEH6EVzyhkOSCAOMi tOx1u6sywVg6MAHVxkMAQcH2JAB9hiu6y2MtDa0rxBqWjOhguJFiWQSSAMQZD6HvjB6e9d5oXxC+ 3tHDfWwWV2bJj4VVGME5znuMD2rhIJrO/jVmgkhAAUOQSpb5Rkn67mPsABXSeHb+w0KxWZ9PSWae YBriZuI4wRnCjGTnJPPtUSgt1uUr9T1OONg3+kMqAgsqAEtgDJJ5ABwOnWuF+I1lJEYborm3ZQqu ARknJ6HpXZ2eq6feANFMpSS6VkkAO2QNwwBI5IyQRWR4z1GwFlZabcwm5KuFdNxVhjgEAEE85Pvi rjpuJ67HjUU5E4A46ium0y5Y20TA8gkHv0NTr4Lub0+faadexKW3ZKEqFPQAEZyD3ycitbQ/Dc2m X9s2q25FozsXLEoEAGeSQBzj1xzzSaQJO50Gk6PZuwv7iCG6dlwxaRkER64OOD9ME/Sm6vpwggaW zJTI5UEgEHngnqOPWlTXLC5b7HYxqhjuA0uyQSBQSQCSDjHAGex61YjCfY3MpKxkSTFwegJwD+SH 8zUOPQtO2xg6HcPcy3FszHEoIz6H/wCvUtxpZtFR1YMrAkEH0OCPqKyo7lZ1ku9OhMKQAJJySGOe vOeuOR2rodO1JNTtwtyQBGQCSeAD/In1rCS5Wy0mzofDetuITBdtlUA2uTyASBg+vUV1Iu4G6Sp+ dea6rK1hDPcq+BtLRkfp0/CpLfxjdhAJNj5A++gP64rSlJpGc0rnpSyK33WB+hp2RXAJ4wRsebaQ /Vcg/oatw+K7M9UnT/clyP1FaqZFjtaSuYj8TWZ+7dTLn+8ob+tWo9et36XsJPoykfyzT50FjdzR msxNUVhkSW7/AO7Jg/rU63wYZ8s49VOf5Ucy7hYuUVVN9Ev3gy/UUq31uw/1gH14p8yCzLVJgVEs 8TfdkU/Qipc5HWmmhCFQR1I+lQywyMpAYMO4YA5/SrFFFrgnYoJAYAzJbopbqVAyfypjzvyCrKR6 H/61aP40hCnggVm6d9mWp90YzTEnBL89yP8A9dRGWQHGSR6g1uFUHIUflTS0fQgflWbprZsrn8jC Nw+cZI96zbvVXhlCCKZucbgBg+45z+ldFcW9vKTwAfpVB7ULkK5A9ASKxlGz3LTuZ4uXY4Kn1qNp 1ZSrA5+taUcESFvNUOD0zwR+VQy2UDElAR7ZqNAdzNJVF3B2z6dqikIcEqxJPUYxirktkcYDHFV/ sEinhgfrTStqBSy54PJpHRwvGCPQ1ca0mRCUVC3YsMgfhkVTWK9QkTLnngqMcU7voFkVjuLYOM0j AgYGQasPCxJJUg98g0EkKAVUk09UIpsQp+ZQc+1NzERkKD6jFWwSRgqpB9RTBaAv8p5PAAFHkKxW IhI5AqIxxE4IFTSwBJChdS/oDzVWWKRDypxTXqDVh3lRZPHX3qMxRDJJb8DTQxztIbNOIAHIOKNb 6iIikJBBYgn1FRNBGTw4/KpWC9eaaUDfxgD601dD0WhAbUnkMD+FKIG6Ej61aWBjyHB/GpBbuOeD TuK1yi1sSTjGfrUbWzAkYP51eYMG5IFNyBySDRdoR1Q5pwAz70g9KcOfrXamYjgOKUDI7UAE9KXG KAAA5zSgY6UoHqKUDtQAClHPFAFOAHWmG4gz3pfcCgA9hQBigAx3pQKPenYoATHrSgcUuPWjGTQA Y54NLgUfSjHrTEHvRS4oxk0DClwRzRg0YxQIKMEUuMUUDClx2oxRigBKMYpSAe1GMUgEoAzS49aO ACaAGqCWJOME8VKACOTimIABzTiCTxTEhMZOBUZAa4AOeATUuMDk5qGIB3kY5GDgUvMGMnIPA5rk vHEDNoRmVQTC4YkjOAeD/Susfljk1S1C0jvrKa1kAKyKVP41EldDW9zxPdBLwYyD6qaQIoI2SkcD AYYpdR0+SxvZIMkOrEEEVGZJUULIocd89azt2NfNjXEYH72IHJ6g/wCFC2tpKAAzKx4znikIilIV SVJOMMeATTPKeLAZTj196mzQE4tJbZTkb4v7wHA+tKqAncDkEc0tvcvFkA8dx6/WrUYt5ASAUyMn HTNJt9SloQIUQYEIJx15zVqK3WVQ0pkjjyAXAzgfnUDOiEjOR61aSCe7tXtrZwJJGXhjgYH+RRqL 5FOK1d2JDgAnHP8AOqmqwyWbGMsGGMgjoR7VakSSOR1eZQykqQe5HWqcttPdsFMgIB4LZx+dVFsN CPTNOOoXAhUBSRksegHrXV3ngcQ6A93BqMciqTmMqVLY5JHJzgc9qo6Tob2is8l0FDDDE8DGc4/T 2rTnvdPtQUWaaQZyAr5A9icelCquLtFg4J/EcfFBujEQBbg4461MujNJEpEDEj/Z61strNugCwWs EIJA3NyQOfT/ADxUDau7g5uVQ54EcQOeDzk++B/+rk52x2WxFH4b8yJCszQvgEox6e9LDoyxzb5L 2MsDyHLZAHuRV2CKC9VmlfUpgM4MaDA4JGT9AT+B+o39M8IRaix8vTbhIwceZcTckfNk4A91/I+v B7z0FZJmEYrQEA3aEk4wqk9xVm0+Hd1rdyZ/OeOM4IJi2jH4nPpz716NpXg7S9MYSGFJJh0JGQPp n/PvXQYAAUAKo6ADAqox5ddxSlfSxzOheBNG0JVYRCe4HJkfkg+x7fh+ddMAAoUAKo6ADAoJA9qi eVVByelNttkpHN+NvD8OraPJcIoW7tlMkbgYJA5IJ/Dj3pfCGvjV/DsM0rEzRExSEnkkY5P1GDV7 UtUht7WV5WAQIS2fTHNeTeF9fOmaTdIo5luCy5OABgDOfwob01D0PWLzVooUJLgY964/UvFYdylv lyDgkdB+Ncjf+IBPKftE+9RyY0PH0Pc1kXGv5IS3hCKD1PU/4Cs230Gl3OmnumnkzdTgk9E3YJqW EqoyoAOOorjG1l2O5ooye5KjPfv+NTxa68S4aJWAGByRxx6Edv5nvghWkx2XQ3tYkWTSLjaQx2EA jnFcpB4l1G3wElHygADaCMAADt6AVfn1pbqF4hbQpvGAVyMZJPHOPbvwB757rw54U0jSfDpn1yCO R7kAuXUkoCeFGOQeecc5+laRtFXYrHnz+NNVP/LROOP9Wv8AhT76/ttV0a2mmUf2iJ3VyuADHhSp IHfJPP1re8Y/DqXTGF7pEU09iwywOC0Z/mRjvj61y+jaa1/rNrZAEebKqEjqASAf0rRO6unoTa25 3/hfShb6bY2pXE96/wBplx1EYyEB+vLVi654wni8YTTWL4gjjNsAOhXuR9TXQarq6aNHql0QFmkQ QWiD+FQNq4+gBP415fDORITsViRj5vXPWsIe9JyNkk7Reh6zpPj1ZrURLqn9ny5yyucKT3IJwOfr WnB4tsbCBzLq6XEjszM6MCSSSegz0z615pp3hrU9QVGa2jhiPIaU7SR7DOf0x712em+CNNTmcySD qQDtA9RnqfwNaOVtxSppbO5zGveLLrUtZM0KB4Yh5cXmAnHvj1649M12/hfU7q60mNLu2nMi4XeI jgg9D07dK6XStJ0DT1VotOgUqMBmABJ+p5NaNxrotEP2dLWP0IUsR/8AWNceKw8MVFRktioTdPVG Ra6Zew35mAb7I4B27ckMepHfn0rVd3XgQy4HbaR/OiPxY0qYdogeP4M/XHUVHN4mlLYM230wB+fT ivPnktKfVl/WX1JYy7PtNrMzAZAwBVbVfCWqa3GAl5HZBlIJ8sswB445AGfXr71E/iVmOGndie4O KqTa+wYsHcg8csTW+HyunQkpJakyxHMrFGH4K2sLmSbWScdSIsY/M1qxfB7RHRTJfXUoHUgqAf0N UD4hcEFUOR33HNPXxLKVCMGIznBY4/n/AEr1k2uhhzXJ7n4O6HLOpivZo0BBMZAOcdfTrVGb4I6c WZk1h1yScGEHA9PvUTa9cBgUVAc9QOfz9akTxJdFQpc57nOf503KdtAuLdaHP4MtLZ7S/Se3jYKy BNuOMZIyQc81ymuXE2r3rNbBN8iklCQAcDJ6kAHArX1rUJ7/AE+SIsTkEgE8ZFcDFfFJ0IYgg4/p WTh9plc11ZHceF9bg0e22PCQ7EhkMgYZ7HBH9aiDrfeKxNp9hNO7urM7/MqnjJOD0H1Fc4JCWyAO eTV601F7ZsxkofUGp53sNprU9Gk8bXFqTC6RK0ZKsMYGQcHvWD4n8UPq2m+ThFKksNvGeMYPrXA6 lq0xvZSznLHd17mqFxfyOgIY4AweaI0+ouZnQaPdRDVFktXMFww2so6MD1GDwQfQ10+pi5v9IuFa 9WCGGNRs3ABgDgDj6k9h1rhNMl3whs4IJ6c1otKZAFIGB7Dmjn5ZajSurnQNqlnBoscelsTCQUmZ iAXbAJOPTnqeuKy9P137G00ZiDLJjHPA6/41RlIS3YIAB1wBistiykEtkk4Jo5VJAm0ztrm9luPC s6El9isBk/dBGR+oNRWzGSCN8n5lB/Sl02JpfDV6COGKqQevIapNJjL6ZASOQgGfwpJWVhN3ZIFJ GBn8qQkqSAM1dSHBAxwaSS3GAcYqrA2UvMcdCR9DTluXXgk1MIMnBGRTGtwTgZpBowF/Kp4cj8as w6vcoeJWwPeqn2fYwPX2oMRJJAAHpRoFkbCeIbuMACZ/zqePxRcjlirfVQawzESpAXOBwaiWJgTk YxRYR1kfisEgPBGT7Aj+VW4vFNqMZiZSf7khH881xWxhxg0BCRnJosGp6Cnii0OAJbhPqQw/pVuL xHatj/TVH+/Hj+RNeaFXHIJpN7DgE/hQm+4M9Xj1u3cZFzbP7bip/UVOupRvgBVbP9yRW/rXkBmk XkE0q3ky9GYfjVczCx7F58JGWWRR6lTj9KaWtnyBOAfQn/GvJYtZvoeUnkXvwxFXI/FGpJybhmHo /wAw/Wk9QVz0t4FcfJKjegDCqsttImTsb6jn+VcTF4vuzw8UDnPUxgH9MVbTxKx5NuB/uMR/Mmoc E9ilNrc6AhsnBA/Gm7ZCeGGPSsceJ4CuJFmBHH3gw/UVLHrti5AMpUn+8pH8iazdNlKaNTy5MZqJ gynJBqKPUrF8YnjOewk2n9RU6T20nC72z/cmU/yqeVj5l0Gh2xwR+IpGLHqo+tPc4ztguf0I/lVW S7ZDgpKv1WjlYXQuxuy5qORGwSUzn1FN/tAg4IB/A/40f2ih4Kkfj/8AWosw0IGUn/lkv5VCFXeA 6FR6jNW2vYScEn8qjaeB8gEihegGdJaRmYNEoyCTycf0qaC2WcssxCEdCeQamJiycMKVDGSPukfW h90HUY2kqTwyEdjiopdJIU4Zc1pI6gYCke4NDSH0JHvRdhZHOto07McMMZ6U86U4t9qxAv3YnP5A H+dbRYEngimebg8EijmY0kc5/Z91GCCpyD6VF9mukJyGH4V1PmgnkA1G0iHkqKpS8hcqOXaOcDJB P4U3BGCVIIrpHFu3UYqB7aFh8pH50+ZC5TRGc9akANNRcipQMV2nOwxkUoHHNKKXHqKe4CAYpwHr QBS0wDBxS44pcZFLjnihANGB2pccdaXHHNFDATAFO6ijr7UYouAAe1L06UehpaAEwD1FLjtSgcUG i4BjFGOM5pcZPNAGO1ACYFLSijHrTAMUYoApcUgQn0o68UtHINABjNGKKUDIpgJg+lI3Q0/Axims M4HvQhN6CqOKXFKBwBSkEdqAsNbAUnHSooh+7J9SaklOIyfaok4QCl0GL5DOCVUnHJp66a8sZJIB xnFSwTqjEHvxxV4SJGAQCT1B7DvzUN2HZHifjRoU8ROiqoKooYjqTyefwIrm5EjcEKean8S3hvPE V/OSSGmYDnoAcD+VZQcjBBPFZq71LSYskRLYHP1qaGVVQpMSU7Hrg09YGeMEkg9eKZJCRGRjpSY0 IYkLfunBB6DvU9nbPPMEVlUA9WOB+Z4qC0if7QCFJA5PsKvSOqKUQYHUnuTSbWxS1RSuUZSzDOM8 HtVZLyYuI4XZZA25SpOQeR29jipLqVnARMkk4A961tF0xYmXfhpZCMkc4HpRdJXZNm3ZDLXRGuLi FZpXkEq+ZJMBhUJGSGJHBHc+3eqV/DLo16YXdXU8ABgwI+o4NdxqU9to2l75Ujk81SI4XGQe24ju PSvLzICZUbJYNlBzhQTn/wCtShNzemw5Ll0Lr3U7korkqBnkk8U+3gDgtcXaRoBkgnJPsAKoQhpX 4BPGAB3rqtF8E6lqpDNEYYSQd7jBI9h1q1DXYL6alO2l0WDg2097JxjJ2qTkfjjHH4+1dJo2ia1q pAhsLaxtzxuMYLY56Z57n07emK7LQ/BOm6SA5j82YdXfn8h2rqEiVFAUAAdABV2sS32MTTPDNtZY e4d7mbAyXOQO/Tp3PStxUAAUAKB0AGBTjgdaY8gA60m2IdwPQVG8oUdcVTuL5IgSWA/Gub1TxNFB lI23Oc4A5NDYHQXWopCDlgPxrldV8VxQB1RtzAEkA9PcnsKx5Li/1P5iSsbEgIDgnjqT2HIqex8O 6dfQPDqM1xHG5BzCoJbGepJ6Z/OlddQSOI1LxHd6zLJC7MkBBG0HBYe59Kht1QIsYUYUcA16LD8P PDAl2rc34B5yVU/1q8ngDw5GSq319uHOTCCP50aMpJJa7nB20iCMwyRK8R4II6fSqN/oha6j+wgz IqNM6KvMYGBkj057elemjwjpsKkpcu2MAZhPJ+mahj0RbK+a9tZXE2Mf6ogYHAA5PXJqeXsOMrPy POtGkSe4WKRlSYHCuQBnHY+9XtR0NQDPCF4PzrgAgnqQPT2rqL7wxBe3zXT2xjdiN3kKVBIGScYw CfbqayfEDwW9t9gtmle6CgybyCQOCAffGKfLZai5k3dGV4asIrnWY1WJBHGd7kqCcDoPxNeoPKrR iNkR1JBAYA4I6GvK9I1FtOlMgGYnwGx1Fdnaa1bzqpEykEevND2BNHUQam0ZKSAMnTB7VzE9hYXH jGz1G0ijiELMZQi4LkggHjjIJpuo6qsFoRCS8rfKgHJJNZugW17p32h5LlpJJ8YyeYxnJAPqT1Iq UmDsyn4s0C61XXmCTItuACXGSATngD1/T3q3onhi205w0EIecciR1DEe4HQfhW7BbBFMsxCqeQTy SfYU2W/aMssDFUIwR6iqinblQN31Y9J1t5CZSHcnq3I9+KbLqL8lDj09qzWLuxJJPrQAQc81agup DlbREklzNKSWkY8560quxGNxPtmowM88k04KQAR61SXYlsUjBBxjtT95I5PTikIB96QLg5I4p2Aa 2egzmkJY4BpzAjtmjBIz360aMBpXuCRS4OMg89Kfg+lAGfrRYkYRx2pAMcipSuDgUhB7UWHqQSk+ U/J6H+Ved7iLjHOA2f1r0lkypBHUYrzp4yl0xI4DH8eaTWhUWdILYiJHBB3DpSJAXcKePU4JxWqk AOlwOAMnOTjmm29szToFbBJwDjOK5eU2vdHH6zEUuhjqRWZvYKVJ6muj8S2zRXCEjPUE/Q1gbCTn HSt4rRXM3uamhhnaRO2Aa3lgIOOKxvDik6iEGOR36V1lxaNHMykYIPIFYzV3oXF6WMueE+Q+Bng/ nWbZrHLBMJASUZWyOuMkH+ldI0ANswzyT0xzjH0rD0mEm5u0AyRExxj0Iq6a0CVjsNNnhls7tIxI UJhB3nJyAw/LpVvRrJjpcRA+6COnoSP6VjaAxi0u8kJ4E8QP4bq9P0RLAaaYXTDrLICw5ydxPHtz TSV9SWzlmtnBAC8j2p3kOVIKgnP5V2x0qwk5WUc+1MOiQfwzJj3NXyroTdnEfZWB5Xj2oNkc5xXa /wBgITxIh+hoHh8A8spFLlHdnDtZNkZXNJ9i4IKnmu7bQjxgLxULaG4PCA/SnyCucUtsQCAppGtC OxrsG0SUHIjPPoKjfR5AOYjg+1JxGpHIC2B4II/CgW+BgDP4V07aSQc7CPqKZ/ZhAPymlyi5jmjA SOQKY1pnoK6Q6YRnIyaZ/ZxH8P6UONthpnNNaEjgVGbRicFT7cV1P9nHGMVA9iynIB/Kp5Quc79l HYcjrxThaZHp+FbosiGzjP4U42BByQMGiw7mFFYAnOcVZFsEOCSfYVqC1KNkDj6U42wKg5AYnkel NIRg3FuoyVJHf6VEIW2gr075rektkwec/hVd4lQDA6etFrgYs0LBgckfSmhZBg5bjvmtKWMkkgcV CYm7ClYehDHcXERG2Vx7gmrUerXqdLqUY4+8armNs9Kb5Tdx+VLQW5eGt3nRpd3+8Af50/8AtyYH 544WHTmMD+QFZjKegBNRshI70WQWNb+24zy1pGfXBI/rUqatYuAHtXX1KyY/mDXP7WBwTSgEHHPN HKg1R0H2zS3PBnT64P8AhUm/TmAKXzKfRoyMfkTXOYxyDzS7DgEGiyC7OlURYzHqEJ9ASR/MUMLn qlxG2ewkB/TNc1hgeppjGQHIY4+tLkQcz2OjJvV5KFvcDNQvdzAjfEc/Sue8+ZTkM3504X1wB/rG x9TxScEPmZuf2gwJylH28E8jGaw/7RnHVyR7jNC37kEkKc89KOQakzb+2IegFIb2MDGTWN9sBHKj 8KDcRnqCPoanksHM+p3QAxgU4D1pMjFOGQeK7DIUDHSjB60oowMUALjilAoApeRyaAsKABSikAzS 4HSmAUAc0Y7UHpkCgNhetGOaAcjpS96AAUUAZFLigAx2oFLRRcBaMZo6UUgDFGM0UuMUwDil7UmA OtLj1oATtmnDGOKKO1ACYpaMHpmjFMAwaTq1OpFGWOaEJjgcfWlJBAA696MUYoGV7okRYAJJ6AHk 0itlASrKccgjkflSzZMiL6c1LFC87hEXJ/lSaA53V/FNppF4lu8UjvwWIIAUHpjPJPtWldXvl2Ms +8lFiLAj0AzT7zwxa6hfo11ZJNNEeGycfjg4PToazvGobS/C99JIAgeLYpBHcgf1qJaRKPE5naWZ 3JJLEsc+pOabGhZgAOfSpWQKqkg7iMn2J7VNp4QXBMxAUAkg9+OlZraxQNK8YAK4I68U2KVnZwwz kGo5p1uIo3UBScggHOOTj6cYqa3AijLEAk8DNSylYlBEUYC9T1NVLiUopwRk1NuByxPU8Vm3Dl5N q8knAFJK7C9loXtLgMsjXD9FOFz69zXQaeP3juwIAGc9sVnwRGC0ijAwQOeOprpdL0K8vbIBF2CQ 8sQQAP60pxcnZDi7as5LW76W8neZzlIwEjXHHHQUug+CtV1k+Y8TQRM2S8gIJHsK9T0jwTp9gVkl Tz5gc73GcH2HauojgVAAqgAcYAreMYwVjOUrs5TQvAum6UFdo/OmH8bjOPoO1dXHAqABVAA7AVNs wM4wKRnVenNFxCYAHpSM4XvUEtwqgktjFYWp+IbezRi0gBHbNIDZmulQElgMVz2qeJYLUFRIC3YD kn8K5y91i+vUMiBobcttLkcnjPA+lZqWWJQZd7zMMoCMk57n04pNsaRZu9Wu785DNHHnkY5I/pRa Wa7hvVjnBAJ5bnuaVYVDZAQtjB5IC/WrcDK+YoWVlIw0gHX2H+NTcZaSNGBVVUr0ZgOvfA9vU961 bC0edgSpCD2punWDXLAgYjHBrpI4ViQKowBVwjdXYm7bEIhVQAAABQUJHSrBQelG05wa1SIKxjPX JpAjAjBOas7cdqTZzkChICqxlGSJGyfc15N4iSfTPF9zLc7mS4IZXPOQQB19sYr2Fk9q4PxsU1e5 h0ayiWa9Db2cDIiHcEjpxyfTjuRQ0mCdmczc6HHPaG9sJlAY4KE8MfUehrGitL43AiMRUnqegA9c 1dk0XU9NnCLN8ucEg4x74NbEKlY1DEsQMZJrOzLb7D9PtEtlALFpD1Y9T9PQVuRPFDD5jEF/4R2B 9TWQgJOR0qwMkc9KOW4uYsTXDysSSeahGScnNOCEjINSKhPb9KtJJaEtt7jQhPUUoQ96kVScZHWl xgnIOKaVxXQwLg5xTtp44qUICAecU9Yz9eKYiDZzx3p2wHtyKnEYJ6ZNOCANyDgGhICt5ftTTHjo DV4IGOAOx4pTGoAyOtJIL6FELkdKAo5J4q15QzweM08wqOmcY64ot2C5TKjOQOKQJnpmrRVewY4/ Wm+UcbiAAelMLlYjAyeSK4OaH95KSORIRjvjJr0Ipzj168Vxt+ipqM6AjAkJH51MtioncadpYk0S 3IQl2UNkA9CB3qzBokqSq5RgAQSRkEflXTeHtVhXw/p6G3jYrAoJI5OABWn/AG3EOBbp+VYpx6l3 Z5D430wwCCYKwVmYAkHngHvzXEGEg4Ir1/4kagLvS7QCJFxKcYHqK8tZCSTgZPtWmjSsLW5d8LWj Ta/bRIuWckAevBP9K9Un8NXNzO8iwnB5AA6flXnHhK4az8TWEygbllHUeoI/rXth1yROi5ycnI/l Wd0paj16HMf8IvcRQsrQEliAPlzz9TXGWOlvaeKbm0dCr4lQgjHYkfoK9ZbW5GHzLjHPHH+NefpI 1x8RC8gJ8yVgT7GM1cZRewa9TOtUMGhXi8AtcgD8B/8AXr0PT0VYPlG3LE49+M1xNyiwabOhAINy x98AJ/jXdafFJLaiREYg4JABPUA1Mk76D6akxLA4BOBSiRwOtDI4YDYwJ7YppJHUGjVCsmSpMwOc nIq0tywUAMRx61SVx0xyfapSwwOKE2FkTm8kH8Z/Omm+m7OR+NVmBJOAaQAk8indiaRa+3zDq5qV dQlHVgfwFUtp9KUIRzRqI0BqDZG5FOfapBdQv96NfyrN2k4BFOXdn7pp3YzRxaOMlAKBbWkoypHP vVIAjk9+1OQkHAyAKLsRZbTIG5VsfrUTaOh6MD+FRtKUBOTipUnkK5yfpTuBC2j4JAAPfNQPpMoB O3OPStBZ3B4PJpTeuikkZNF0wMSSxZTgqevpUT2hIIxyfaug+2KcFgDjnFRieFm3NGBjoAKWgznG sjzkVC9gSTkfSusWS1diDH75qTyLSTJAFCsI4Z7Bhn5c/hUYsm7qa7w6dbMOM8+4ph0iA9CR+FFk PU4J7A88HFMawIHSu9bRoj0b8xUbaIhHDD8qOUWp5+1k2SMHio2smPYmu9fQNx4K1C3h1hyAD+NL lC7OCazI4KkVG1oQeh9M13Uvh6XH3CT7c1Vk8Pygf6tvyo5R3ZxZtmzgA5pEhcZBH6V1jaJIp5Qj 8Kj/ALJcZ+Ug/Sp5Quc3sB4I6VC0WTgDmuik0pwThT+VVzpjhvuH8qOUdznpIiB0yaiMRIPXmuhf SpWPCkD6VE+kSjnaT+FFmwbRgNGSOmajKEcgVvNpUuDhD9MVC2lTAZKED6UWaGmjJCEHpR5ZJyQQ DWt/ZsoAyhNNawlHRT+VFgOyxjpTgDjkUvtTge1a3ZA3BFKAT2p34ZpcincBuDjFKARTuO9KAD2o uKw3BFGDT8A0u0UXCxHSgEnNOKigAdKL6ANxjvS07A7UYHWi4CUvHalx6UYouFhOOgpaAPalxk0X ASlxQBkUuKBjSB05pRnFLgY5GaXA600LcSlpaMY7UAJ060An0GDS4B60gGKYC4pcUYIo6UABpEGa CSATTkHFFw6jsDtSdKcQBjBHvTeooAgYAzn2Aqxb3Itg5IJLDAwcYqBSDI56DOKHcdgABUsEdDFd JJErsNoIySTwPxry/wCMepqfDkMMR4kuQM+oAJP8hXXB8kBy2zPIB7V5h8WrgO1haqThA0hHpkgD 9Aazmtkykc9ptqt1Zh5VkJbBJVQTx3B7U+bRAJTsn2McnbKpXj69K09DSAWSIIXyU52TgFj644wP Y5rXeNgkc0UVyoiA3MsgZQM8H06468UaIepxEWiXEUbNGokjU8shB5prghgpBwBwMV0V1E7MXCsw bndJABg98Ffw5H5VJY6Fe6o4ZIQI8Y3yA4H06E/maTi5Dv0OVkO0Aegya0NB8Jajqt6lwYWS3ByH cYB9MDqa9J0rwVYWbCaVBNNwcvyAfYV1EVusYAVQABwAKqMVETfY5zS/CVpaFZJl86UY5YcA+wro 4oFjACqAB0AFTqntQzqnU5I/KmJtsFXjIFIXVfc1DLcAAkkDFZV7q8NtGWkdRgZPNIRqyXIAJLAV jajrtvZRs0kqqAO5rkdQ8Xy3sjQabGZSPvPztX6mslbaW4ZLu5Y3EgOSrkBBzjG09evf8qWrHY1b zxDfangadC5jLbTMQQgJ6c0qaUixzSGT7bdxNua4cEQRqBk4zySTx+Hen2tp55lV4VkA+ZRny4lx jJJGM8cYHrmtN0luY0dQ1wRhTtfbbRgDgYIBbGMn8KbskNamI8KM3nJKrb8lrjcVAPUhQQCcdKbI Wgge5kmkhhHJlYjc3GMZ64x2zVXUtftbRigkW8mU7QXUCNB7AHnnuaxtELeJdQu5r/8AexxsAkY+ 735I79qz1b0GtNy42qfb7QtaShbYSFWBUbmwBjJ64JNdN4U0p7m1RmGIx1PrWcfDyQ28xSEQxogc BBjJyBz+dd3oEaxaXCqgABR/KtIw7ibNCGBIIwiKABUgHqKUlVBLEADuTioZb21gXfJcwqucAlwM n0rTRE77E2BSYoEitGJAylCMhgeMeuazLzXrS2BEaT3T9kt4i+fx6frRcLGlgUyV0ijLu6oijLMx AAHqSegrmZ9Y8TXp8vTNEFup/wCWl1ICf++Qcj8c1njwdrWrzmTxDqLypnIt4nCKP0x+QB96PUVu xLqfiubUro6V4ajNzcNw9yB8kYPBIP8AU8emafa6da+FtPkeWUT30wDSzOcljnOB3xn8zya3rTTI dIsjFax29tCoyQgJPHck9T7muD1W8a/vXZXZowcAk8nHehyVrIEu5Bc3D3s7SuOCcgelNRCTSqOA ABU8aeo60kh3FRDjJGKmVMClVPfNShe2M1RNxFXpUgXgE05IyTggCpxCeo5H04FFkFyIA46e3FOE ZZTkEA+v4VKsDE4AzxnP5VdS0ICZBzjOMH29Onb60bCKSRZHQj1Pb6VMIiAQT0q5FATJlCWwARgd enGMn9fSpktwxJCg44x15+nbgUWGlcorHzjaGIGcZ/n7ZpQoORkE54A9eelXpLUhTjJBOAcYB6VC IiJgpU8kDGMD0/nj86AsVmh7kE/XrTfKYDOMdODxmtl7QFAVAwRxzVc24HBHPqBQOxlFWDcDr+VP 8+ROAMg9iKuyQADGQMVGRGeHxnufWpuFimZwWJKDPtShi424I57CrSw27YAPzH0pTbrnrz1JJouL lsUygBBJJ9+lcbqkRbVZmAPLfnXdtGoGARn6ZrjrkAajMCMESEdPehq60Kjueo+HNJd9AsXxgNCp H5VrDRW9BWho0Yi0SxTGNtugP/fIq9WPs+5o5HmfxC0todHt5NvAlIJ+oP8AhXmBiwcEV7X8RiB4 ejHczDH5GvHpFAPA4rVRtEV0yz4cti/iCxXHJmUY/Gvbho568V4/4TKnxPpw5P8ApC9PqK96HTis 3BN3Y+a2xjjRgOtcPd6e1r8RLddowzhh+KkV6ga4rVYhL4+sWx02g+/ysf61UYJbCvfc5PU0CZiI HM0p/DKD+ldTYeKUs7CK3MG/aoyeRnNc3raEauIyMcyt+o/woeOa2tROjFQWGCDgnrxn8KJLW4dD rx4ugYAmxU5/2h/hR/wllk5O6yBPfBGf5VyK6lPuGTzjJJHNWVvZnHBJI56DNMR03/CUab1NmwP1 /wDrUHxTpZIH2ZseoJ/wrm1uZSwBcAHuQMD9KcLwoTkg++0f4UgOqj8Q6Q4B8vGexNTDWtJboo/W uQ+2qFwMbvQqD/SmHUWWAOBGGLED5R0+mMUILHanVNMI4A59yKct/prcADp/eNcD/ac5bqCPZR/h V9nlNqJVkRiRkhVHA9+OtF9bBY7A3mnnhWX/AL6pftVkBkYP/Aq4FNTmDkADHqVH+FKdUl6YUH2A FDQHdtd2x4Cgj/eo+0QNgKuPoa4eK/lJAbGfTFSS6i8eAGAPtmgDszJEc/ISD703z4xzsb8GrjF1 O5Zgivkk4GScCp3u7uBSS6sOhwTx+tK3cdjrPNTGSrDPvUbSrxlWH41xTa3cg43Hg9Oal/t2baBu J45yTxRYTOwaeEAZDZ+tV5L6CMjJPuAc1yR1ucsTgGom1iUjJVfoRTsCOwbUbQAYLkkcgcYpv9p2 4/icfjXLwXdzMpkWNMA45qtcanNE5DRLnvxU6DsdkNYtR1lkBHoaVdetc4M8w/GuH/tcgcxLxSjU wRkxJ+RpWC53X9u23UXMmPcig67CQALlvzrhRqIPHkrn2zTpL9UUARAk9uaLNg2jtxrsORm6YfjS trsGMC6euMjLSxCURoAcgcnP86py35iYgwqT06mjUNLHeHW4ScfamoOuRY4u3yK4UXgOCYQM+hP+ NTefGIyfLBPbk0reYaXsdoNcQcm7YCg66hAH2rOfUCuCa8Unb5WfXk0LcI8gRYiSewJoaDQ7k61A clrlcjjG0GoW1i2LD/SFOOfuCuPmMcY+aM5xyAelQCaEgkBgR70cvmB3a6vbHgTIf+ACl/tW2HBl j/GMf4V5/JqEcABVCxP94nj8jUX9tE4JRSB7f/XpKPmGh6MuqW2c74cH1jFI2p2Y4LQn/tmK88Gu EgAICB7VZe/JtRKQvXGCP/r1XK97hp2O3N/aHo0J+iCmG+tCcDyif9wVxbX4SMMsSkkc5JFRQ6q4 kDJEAw6EE5H61KV+oNW6HcinZPFR5FOzxzXRYzJM8cGlzxTAaXPNAXH5xzmlzTc880c9qBj80ZyO tNz3oycYzQA7OaMj1pM9qM5oEOyKM45pM5oz60NBuLk0uabmjNFhjs9qUHjikzRRYVx2aXNNzjpR QkMfkDtSgimZpcinYNh+R3pDzTcmjPeiwrjsDtRj3pAaM+tADscdaMUmaMmmGgOMKTSqMKD6iqGr aimnWqSurvulVAqAEknOOtX0yUGepAotpcOo4g+pFHAHPQdfpRkYxmormVYraR3YKqqSSTgAdOtA EcPKZPOTmlkGOOtLZSQS24bzFYHoVYEDHXJqvf6zommKXu9ShUgZ8tGDsfbAyfzqJNX1GloSZVFa WVwkUalnc9FA6k14l4s1L+29ZuLocIx2xg9Qo4APvj9Sa2/FPjWfWw1jpyNBY5BYE/NIR0LY6D0A /WqOj+H7m9UMYckn77DgCos5NdikrLUg0osUjiCRMxAG1jgn6ntXRWOnXN6Ci2pxkYk3kKvrxzmt zSPB1tanzJgZnJydw4H0FdXBapEoCqAB2AqmlcTZhad4ZhgIeYmRwOAScD6Ct+G2WMAKoAHQAdKn RB0Ap/yqOTk+goEMVPQdKflUHJBPoOlMeUkYzgegqvJIwUkDIFAEsk3uMe1Z13qMNuhZ3AAGck1y mveN7SydreKRXmGRtB6H3rhLnW5dXnIvr9beE8gbGIPscA/nU3vohpM6/WPG8SuYbMGaQnACkYB9 z2rBltr2/kMup3VuoBysPnAg9OpXIIwfXtUVtqmj2EQSE2rtnIb7GzMCOeCwAOfQ1eXWtQuWLWdp eNuAGYbRYww9yM5PvVKLQXJooo4CpRW8sjgIpjXPTOc5I6+n9KerpEjKSpUnJBGevfIP+NRRaN4n 1FiY9NMIPIeaQM31Izj9KtJ8OtavD/pt7GoJyRknn6cChphoULzxNaWW0CRppAAAgJKcdOOnFYN/ 4hv9WCpIwSJSdqIABye+AOa76D4VWJKtdXsshByQgAH8j/Otuz8A6Da4ItWkI7uxP8yR+lS4p7sa aR4pLAxU/KST7V3XwwsI4rG5uLqJldpflDgjIAHIGOetek2+h6ba4MNjCuOhCjP5iryxKoAVFUDp hQKqNlsDdznNRinu/MhtbJ5FeLbvJ2gEkHvz29O9SWFprEECwlLaPaAMsSx/mK6LaSMEkj0pNgHG ABRzME9LWOR1HwVHq9ybnUb6aRyAAisQox2A6Cs2/wDh5bxWrT6c7rdx/MsZY7Hx2OTkE+oNd9kd qaTgd80XYXZxXgbXI9ZtprK6hVbu0IBQ5wVzgHGeoIwfw9a7MIAMKqgewFeYxMNH+MRgiOI7tTuA 4HzKW/mBXpocAZJptdRDyCRgk49M0xgAOBTWmUdwKz9R1RLW3ZwQWxgD3oAxPFuqlIxYQnBbmQg9 uw/xrkEGBwKmu52ubp3cliT1JzSIgGCOnpTSExyJ3IOanQDoaEUDGBmp0GccY96pWJFVeM1MsZJz jH1NOjQEDg5PbvVqKJipwpOOM4J/Dp7j86AsCxgAEke4/wAmp0hD4I59SOg/TrVm1smmwTkALnvy ME4B4BGD61MiBJQpOGBIBJHPXgDPX0OKaWgepAIhDgn5SACSRkAcepGf88U6PLMoADNwwBHXp14P HHWtJLB5SzBNpUE4BxjrzwBz071SljWCUoUJBzwW5J55OTwOKEgHWhVdRiMhIDfKS4wOQB3NXpSI XkRgAVwRkY5zjjPbkc8jg9Ky7lWQiVB34OOpBPQYGAMVoXjozq2MhlDEkc4I6YHfknj170dQvYWJ 1kOwjJyBwOmcADPc9PyPWieKN4gcKWIyOR07dOvaqgdDnJOCcEg4HcHj8T+nSg3YKABjwTgADjv1 PbP48U7Bcm8xo1IJyM8FjwB2GPy6+nWopZ1VCckAngd6qyXYUcDHue1UZrotznOPSloFyzPcjOAc ZqhLKWViCM8dTzUEs5IxkEetQiTJ5APXk0rdRXLtk/7wFieuBj/P+enetJ3YHaATxnKjI/P/AD+t YMcpQ5z6irQucjp1ORyR+X+f5UJDTNJnAUMQwz74xXB3soXULgsekh/U11D3Oc5IxyTgfl3rg9Rn J1CdgeC556Z5oashxep9B6TrMb6RZMQCTBGTz3Kir66rETgj9a8q0jV2TTLZSx+WJR+QArQGttnG 6s7l2uaPxK1JH0q1jTo0jE59gP8AGvKHmyTzXSeMdSa4tbYFsgMxHPsK43zuOtXe8UkK2p0Phe6W DxLp8h5AnX8eQK9zOsIMcivnPT7kpqNs4PKyqc/iK9HGrnaMtkiovZ6js2ejLrERPIz9DXH3t19r 8fQpG5XEsWMdQApJ/wAPxrLXVmH8ZH41Q02/eXx1bAEnc2SevRT/AIU0wtYsa0GPiCRS+SI5HJ9t 2cfpik+1O+ngHBRZQQCOvBqLUZg+pvKBkm3kPPXG40Wd3aPpjvNGwJOFCjgNj+XNEhoEDO+5+OOB jFW03gZAIPTj0qKN4woZjzgcEVKZxIQARx6DrSS01Je+hLsAUEHPrjpTNpJznGO1SRuUUggZI474 qPDGQhRwOckUWQ7jY4XYlh096ibHl+W/ykEkEjqK0FnCW+2RQW7AHrWW1wzucAk59OlO3UV2IAoG RMgPTkgVKLp0gMAnjCkk8sM8/jUSxGV/LiUvIx4UDgeuTTnsra1P70+dJnoDhQfT1P6fjSdhoaJF ACiWJj7MCc1LE4ts3FwrGKP5mwOwqu8swx5ZEYBwAigAfl1qrJ5tyssLu211IJJJx9KV7oDrWW1l 0X+1i8aRuPlgRSSnPcggn3JrmLG8S/llRRlozyc8Y7Yrn/s+rRxvbbi8JAAIPbORWppdmdPgYuSZ XOWIJqdUyna10bLowA2598U/zZhAIip47+1U455ARhjj61I08oGAzAnnqabYgaJzkkNUeHUEYJzS NPKMYlfI68mozPPnBlcZ9zQ3oFh5RgSCpyeuDmmhHBGUJA9c1E93OBjzX4/2jSC7uCciV/8Avo0m wS1L0UroQQCFIwQQcVBMHlkLFWGfUGolvJhyZWyPeo5NQnJKiQ4+tCdgsxr7gPutwfSlMjsoCoQP pUX2qcnJmb86Dezj7srfnRfsBIjzKSSrZHfFPJcoWIwemD1qJb+6z/rSR9ad9suyM+afyp3ES21/ NAxITPGBnOBUcsrs+4gnJzSrf3IGDJ09QKG1CcLncp+qg/0pJodnYt2ltJefKrAMCAqd2J6ACnap Y3GmKDcSLGxP3DjI/XP6ViXGr3ltcw3KMA8R3LtAGPyrM1PWbrV35Vi5JJIySSfUmlK/QqKVtTU8 5ySQcg9xUqTugDq2GHSqtrP5VukUsIJAAJBIJ/WrXkw3CkwuyN/dY8H8aF5iHm9Z0IYnJ69yajMr gkg4rPlE0UhRiwx3pUeTaSXJ+ppgPuZC7AHkgZqLaQuWNOUbmyxJJHU01yc4GMelNK4rjSSMEHgk cVqSk/YYlwfmOcVk5BYD1NasxAFsh5AANOWiCGrRpRQJJLDE5CqxCk+mTjNUNRiWyvZEt33hSQGx gGpxKSwYE8D8qx7iWV5GCkkk9axpdbmtQ9QBFPB6VnrfxZwQ4/CpUvYWHDHA65Brp5l3OezLmQe9 OBH1qp9rhHVwPrxTxdQnpIv5ihNMLFnPrTh9agEqNyGB+hp+8HkHNMSJKXNR7s9DS7vWhAPHqKBT QaXPPWmApyKOpozRmkGwvIpelJSimAZxS5yKB0waWkAZoooz2oAMmlz60lFAC54oyaSlzTBig+tA J6mkzRRYB2aXNMzinZyaLAZ2rWQvWtELlRHMJCAM5wCMH25/StQcADtVdxmaMHoMn/P5VYPAzj2p 9LB1FBINVr8BrUoekjBf1z/Sp1bJIOQR2NV7wFzCmer5x9P/ANdSByvjnTbex8JxSQxBT9pADAc8 g559OnFee2WiX2qOBCjbM/ePAH417Xr9jFf6RaQSoGUXAYg9OFNV7WyigQKiqABjAGKi2t2XfQ5P RPBFvahZLgGaTqcjjP0/xrsbeyjiUKqgAdgOKtIgAGAM+lTBVAySPoKpsl6jEiwQAM9qlwq8sfwF NL54UYHtUixHq4OOpPYUgGFiQSBxUeCQTnGKmluLeGRYi6B3OFBOCfoO9N2E9RikncCA4A561HIW dSqrwRgk1aEIHaniLPQUNXA8/k+GOl3FwZpHmBZixCHGc9jkVpWvw90GAgtaGUgdZHJ/QnH6V2Hl gdcCl2qByR+FC02GZFpoGl2mPI0+3QjoQgB/StBIFQYVFUeygVNlQOMmkMgAwABRr1EN2EjBJxTh F6jH1pvm+pxTDKBzn9aLDJgijkkClOwdSTVVrhQOo/OoWvUXqwH40WAvb1HRfzNNMoHAwPpWTJqk MeSXA+prNu/E9lbAmWdFA7lgKWgHSGUDjNQvOozzj8a4G++I+lW+QLkOfRATn8qzz48F2M2ynB7s cU20twSb2PSmu0UcsBVaTU4UBBcDHvXmdz4jvXRiJQpwSMCuKHiXVb9pYpbxkJBAwMAYBznAJ/Kk pJ7Ds9jq21WLUfiq1+ZAILXPzE4GFUqP1Oa6i88cWsE0am5jwxICgZLemK8h2pb6eJC6NIZCWcLu yMcDBx09qsT21xeXdhIoVRhdi7SATu4wOR1460+boNQbdlueiHx4lzOYbZWLA4JbgA/jTW1G4vYw 04Ck5wAc4FcPZQKNRdAxJDkMCc4I68967CLlQTV8rSuZ36CohLE46VMin2wKRASeOOamUDt2oSC5 KgzgHjNTIgJznpzzUcYHFWo0BwAMk8Y/wp3EiWAAHOcDjkDOPce/FXYQq4DKMjBHHTkcjI9Rz2qp FGXbgZyODjrkenPrVtgACCSWBIODgk88DkevNCQ9kTRStFjYMdiVAG7pkDCnjjNW4HKASMxGCATk jI4yBnGOhqmiBWGGxgkHkHGSeB1z1FWZECRYUkHkgqv3RyeygZ5FUJs2bW4At23bORjC4OOgOevP BNZdwVJZ8MSSDjJAA4yT045P0zVWSdlBUNwQRsZj8oycZyeTyOcelVJJ2Ct1IJzkEDHXngUCJZpw 5bOGB4GAATxjsCR1pTcF4EUEEgAYzzg//qqnvJOTyCOSTnIz0AyeOPT/AApjusYBJ7EAY4A/L9aQ dCz5u0Ak8DkYBJHTrUMlyACAScnmqslySTg8k9KgZyTzwDTDVksk5Y4NRKwMmS2AASR6+1RYLE4I wOck0m8kAcDHoMZpBYGIJIA78U3JHORQxOfSkJ6ZNACk45FHmducdhmo2bj/AApoJPOTQCJWc4zm uIvnxdTgHB8w98967MkgHg1xGpAi8nIJwXOD680paIqKOjsrsiziGeigfpVgXp9TWLay4tox7Dip RNz1rmUtTZLQTXrsyRRDOcE96wDKeRn8qu6vKMRknpmsneT0HHatIu6IejL1rKftUWDj5gf1rtFn OAC3auDtmBuIyDk7h/Oup+0DaOambVyo6mmbogfeqTwzOZPGKMGIKqxB+iEf1rFecc889Kv+FpNu sTzEcJCxB/If1pwYpbaGtdSnzOG5+zsCR6FmH9KisZAdIhYjOZn+vAAqO9ISBZR3h/m7H+tOsfk0 i2YdCznB9cjmqlqxIvq4dwzEkYwB0waesuHPHfiqkBYjg5OanEMxGQMAn1ql2EXhPnleCB3oDscs WyepJqkrspKkAn65xU+x5EBGQepyMYpNCTJZJQEBUkkjnNQEuxCIPnbgCnELEBkgnr16VJasC0ku Qdq4Bz3NLoMlicWEPlxnMrH5pO59h6D+dT/ZLW5AAd97DIcnqfp6VmykuuQwz6UyK5niB2kAYK7i MkZ64PY0rPoNW2Y+FWcEFcgE8+9OEBBzjBPWn25eVSkCMwQbjgZAHqf8alImSLzZomKnnIIPHr1p NdRq4YSKE9CRyQalstNiv4i7SEEnGB2HuaxJ70yykRZC5wAfSkh1K7t9yxt8rdRjrRYGWrmEWlxJ ECXCnhh0II/nUKykkdaYLlnjZWAZmILMf5UAhQCDk0pW6AmPZhnPIFSW0aXE+2RyqgZJquXB65NN SR4ZN6AEEcg1O47alq7tYkIaFiQTggnmqwwikbTk+tSLKzsWI2gn86e7RAjaDnvmn6h6FUnaCW4z 3xzUWUKlgMnOKdKAxzkDNRMoVTg/hTfkLUmtLRrqUJuCrjJY9AKfdWSQx7kk3gdTjFQ2119nJ4yG GCPWiS5EpwAQD1560rsZCqE81bQp5YBbn0qEuAODTDJzk4yKAJZSoIAGSf5046fN5fmF19dvcVUe UlgQeQaufbDORFGpyeDT16C9SGG180ksMgH0qY2qQjIQDucCtCKIW1vhh85Oc+tUrmfGcgnPtRZg VZFABY4xU0WnSvAJS6puGVBPJFUJZy5weB2FTx37opUnnAA9qNQ8wYtKpikGXXofX2qnyCQR0q2j AkyE8k5qC5BEhK8A80JoY0Ak4HX2oIwCSOajZyCB0HrSM5xkn8aaZLBAGnUDGcir12wFygyeABVO 0Ae6UkdwamuXzdMfTinJ3Wg4aO6LcDF2YDsDUDECXyoyDIep9KInKRSP0OMA1lGVhIWBOR3zUxVk OTu9TvwQeMEZqVQEwQc8VTUtjIJpQ7g9ScVkGm5e3gdTnNORxkZAPtiqY3nqeKcGYHBI/CmmBeIU 8leT7VIhAySoz24qkJmA5A6UonJIxmjXoxqxeDg5znr2JFOR0PG5/wDvo/41RaUgEA/pTknUjJJJ zTTdgsjQ3gAYkbHuc/zqRXY8iVjgeg/wqiJQeh4p4nAUqCB3p3kKy7FwFyMiQH6inb3HVl59v/r1 VSbIwDS+aC55460c0l1Cy7FxTL13IR75Bpxdx1C/mf8ACq4kBAIJIxinuSjlQc5APPuM1XPIXKiU yuAP3efoRQJj18tv0/xqIOTyTwKdvA6HmhTYOKJPOB6o4/A0vmqBkhh9VIpokBGRxinibjng1Sqd 0LkAzRjqwH14oE8ROA6k/WkZySDkflTlQEAsAR3yKan5C5RwZTyCPzoyOuRTfKjGMIvX0pHiUDIU AZ7CnzoXKyTI9aAR1zUflLgZHX0JFOWJQcksMcfeJNHOg5WPyKAQOp7ULApbBdhxnnFOMGCSJM59 RTUkHKyDdvutoP3VBJ+pP+FWwQBj8ag+xuCXDckgljz04Ax6U8JKOrKfrkU+ZByseeWyRjFU5yTq FuucAKxx+IFWTvBxwfoaiaB/tEEzDAIZR74wf60XQWaLd0A8EKgHhyf0NV3iVQSeMdanlcAJ9f6G qWouDCIQ21WBaRh1WNRlj9TwPxqQ8jDvL65uZvI09GAbIDg/M2OpHYD3qMeHNWkwxuhG56lmZm/P NdDotskNuJ5FAllAOMfdXso+grW8yMDIIP0o5UtxnLJFqehWE1xPeC6RFJ2MhBB9iST+FUbPXNYu oAwcHJOfkHH046V1GsCCfS50lBKBQSB1IBB/pWLpdsRDIYVcxvK+044wCR/SsKknfQuKVrsx7ifU xfyXBcsQoDEKcAYxjjGOuK1NJ8TkWkUEttJPJEhM0iEHAB6kHrxiql54et3W9vZLxEBOWtyTuIBH Bx26HFc7JdQ2lxGbN+SCrEHqDkEfTFXG6SuJpbHqcd0ksSSxFSjAFSO4NBmODkn865jStRjtdFth K4X5SeTjqSQKgu/F+n2yktOpwMnBzx+FW2kSdWZx60w3CjvXmd18TrBSVtxJK2cDC4H64rL1Tx7q tuyobFoGdQwEpwcH2pXV7Ds2etNeoOrDj3qpNq8EQJaRQB1yRXm+l32o3+l3Gs6veNbafECFEagN K3TAz0GeM+tcusmo6vPPIjSvGOi+Z90EnGR3pyfKtQSvoeuXXi7TrbIe5jB9NwyaxLn4g2YJWEtI fRR/XpXltxaTW5JlUqfc9an0+FZSAQSSw7+9Zuel0Uo23Ov1L4h3EUjRxQZYDu2MVz83jnU7iTYZ ljz2Uc/rWNfRMlw7yHCgkZPGagj03zYxMFZlYnDdsjrzQpXV2HLrZGtcavezxOXuZCSDzuI/lXMt LLJKS7FmHcnJrcSwlMWFBPGMD/GsaOCRbiRJhgqSOPWqpJylYUtFcqzkqRnOD3roPDkUt2AkRAx1 LHFYt5E/nbAMgAY47Gu00Lw5qUWkR38EcLh03A7iGAHUdMHp3zVTaT94UU3sa0OggjM1wMEchRXL 3GjDT9daFot8EhdlkJ7FTgD3Bxn/AOvWxa63LcxkxRuxHUAdKm1E3SbIb20ZGZRIgLDIB6EEHI/Q 0Xihrmvcq22l258OQzIuJ3kJBJbA5IGcHgYAyTkVLqaEaHaTxMTJasVLhSMjPB98EDnvnNUNjqAE QgDpk8/of6UyYyvG+YlBII5YkD8z1ovG1rl8zUuZINCgbzXlYEkkY9z3NdVEMAA1z2igxW4DDJJz XRxjIyOh6VSd0Yt6kyDPToKnVQfqKjQDGe/rUyZAwc4PXFUJakqAZA6nHFTL1IznPHTrTVJwSMAn gDGfyoGVxuB2jvmkFrFuGXac5xjGCO3v+lXUcJhkYADBBzjaOOeo5OP1rPTG4D5SMg5JwD04PTH5 1es51DBCwI6jJ6HAyTg9BzVIV+paW3Mm1kfaRjgN93jqfm4J20SQpAyhiAARtGBkdiTweePxqyl2 IowFOCRwMkk++cnrz1rNurjfIQScnnk8Hr156cn6fnTEMmKg7AcYwQCenTJPT3yPrVIICwGc+hyD nOPc8de34VMTwWwWB6EcEnHrj1I79vya0oBLF3IAIOO+c4A5IA9vrRcOg12McQ5IJ75PPHpx6nmq cr7yASDj8KkuJSxIHQH0AH8hVQsOtIBxbjGAB6elN4IyWOfTFNxkZY4Ht1pGIGMDGP1oBCluAASP X3puT696QkAYFMLAcZ6UtQ3HFgCQajaVQcHJprOcGo943cqCO4NMdiTzFJzkY6Uu4ckEYqPeh5Kn r2NKfKzkE49x/wDXoDyFeQBScjgGuN1FlYsxJJZiSceprq53jWB+v3Tz07Vxt3Irqoxx7fWpkVEv wviBQfQVJv4wBVdWIQD2FLvOK43c21KGrPmSME8AHPNZxkGAAcVPqjZnHqBWcSR1x+FdEdkZySuX 7RybuMdcMDXRmQgE1y+nkm4U56c1tmUkZB4+tZzWpUdiZpj2rV8POd93L0xHj65I/wA/hWCzc9ci tbQ3IsLmQj7zBR9Bz/WqhcJHRanaTppyzbfkaGBQQepYMRx706AGLTLSFhhwGJB7ZP8A9aota1Zx pdtAQAAsBGOuREP8Sa0Jr+1n0uECAieXDqwPCrk8Yq3rYmwxQSAE49eOtWQ7LtBP4VStZMgE9Ksv k4IYAdqYh5ChyefzqQXJAOOMDj0qoWJyOcDqaikcswVfu+pGKbYh80pYZzjPpViBwlkvHLEtnt6f 0NUHHGM4A61fDARxRggbUGCfzqWNETO27PTPXikeUBSCSTnPTipCCykkcDvVV8ZIPbvQgL+ma+uj zLHI6ol2djkqGIHQHH1PGa19cvdP8P2oSPUTKZkLqTGsmCcYBJzgH68elef61HM0aS2oYSxkknPU ccAY6++axftM16RG6BSGGEJYgnoScknPekrLfY0VmrG/aapFdzlFXLqoLEZ+bJ6nJ6/StLexAzj3 4rJ0u1SzRmYCSZ+SB0AHQZ/oK20ttRnjDiAKgHBKnGPqeKi9tx8jexXaTB4AA6dKEkJbBOBjqalk srvAy0PPfK/40wWV2ejRH6Ff8aTnHqWqMn1HglhgAk+xpVIQhiOOw9aFtLwADMa+uCv+NJ9mvOhI I7DI/wAaj2kUWqEu6Hu5cACot4TIIyccc9Kf9nucDMfHrkD+tBhmzkwZPTqP8aPaof1WX8yKxlG7 JPNJvLsMED3NWDbyknMH6/8A16UWkzYUW7HJwMHqfzo9quw/qkv5kVWABPGffFR5xyeParzW04bB t2GDgjBqM20zHIt2P4Gj2q6on6rLoyvk4BIGDTWySSO1Wvssx4FvJx7Gg20wABgl/I/4UKrEPqs+ 5RwzHA6nitTTytjOGkCsepH/ANeq72zoCzQSKPUqQKqSyFeVzVqpFsiWHnHXc7aztl1y7eOzdUmG T5bHBwMZJ46Z7CovEUMGkxotxFGXBAbEgJx34x1xnvXn9v4gvdD1YXcLsrYI3gZIB6iruveK21mx hRYlBAO44GWb1JrRW1uzO1txzmCeVngYiMk4B5IHvTSu04J9xTNL0u6h08TSxlQ5yM+lPYgMQe1J J2uS3qPJyvWnMFKqzHtjAqInAwT+FEgyqAHBxStqF7kcoLdBwaZtAHrgVKyEDk9aYTtU+nqaaES6 cM3G48YpshzO5B6mpdPHLH0BqEkiQnHeiWxUUStlbJie5xWcoy2CBz3rRuTts41zySTVAAk5HShb CZ2qE44IJ9qeCM4PGfeolGCeBUoBxwK520UkSqVPQ4p2PQE1GARzwM0/cQAMg9sU0waHHBGMEUuM DAPShwCgxww6+9MIIGMkgim79AFBByCSf6U8BNwwM/jVcgggA81KoB5BGRTT01AsqVGQB1p6IDwR zVfJx3p6EjkE8c0XAtKMDABOKWRwFAC8Y59ariVwck8U7eSTkdTTvoLclVjkAHOe1W3OdhOMlQMV nljkZA49Km80MFwc44+lFxl0AbgAOCPWnGM8gHpVVZSZMYPHPFWUmByc9BQkAbCDwM0qkAjIzzSC YHqMiiV1AGMdKaAdnIwO1SqSR0PtVaIknPUVaDAECqTYmPUEAEk0pyQRjrSrkoc8YGefSmiQAEEZ NGgkxhyHwQeOaeCThsHjpSlsnGT609WB4/pQMQuQSSAOBSOQACDkk9KnwG6D9KSRkjjBwM9uKpEj DcEKFPtxSebnIIGe2KiyGYscdc1EZAJcA5HrnFMC7FtdsNwSO9F0VMMG04xKQPcYFVftBJGME9MD mi4cvBAFxnzSff7tFkG464faq5cKA2CT06GuX1bU2Se5h3gh444zg/wliSPxwBV7xhdpY6Glw5YK JlBI68giuBl1WG5uQ8M27KgkE8ggkjI/GhPoJrU7U+InxgI4x/s05NdunwIoJXJ9FJpNPlspo1YK CCARk1twm3RcIqqD6DrVNJgnYwLrVL6e2khayuMOjKSIzxkEZ4FcNHdSSxMC7BgTuBPfv+terSXV qtxHC0qiRzkL6/4VyHhyxtrq+u45YkcFeCVBIwx5GahwvsNO25z8MziIrJNPtYYKIeD759K0bPQL idklWJwGGRuBwg9yRyfpXWW3hi3gulk3kxq24RhcZOcjPOMD0AFb/lg9RQo23By7HA+M9MuZ9ItY LFWZYcB0UHLADH41wdzZzLE25ChjUA5ypBOcc/ga93a2VuqiqN5ottdxNFLErI2CQRkHGcfzqXHW 4Jnz1Z6VNPK0+QI0JJJPXAyQPwruLXSh4q1SJxI621ugFzK/AUAdAfU/4muok8BWkDu9qGj3kEqT lehHAPsar6zDfaVpkNhpFgxth81w4IDSN6kDqOO1Ukr36hdpaHO+JnvdYkW1sLORNLtcJEqqQCRx k/0/+vWPY6RfpKQqSIO5Geo+lbT+Mbi0tmtHsWQg5IY4I/DFU08WlAT9lySc/e/+tTlHm3BOxabw rLexPLNI5McZkIKE8AZNaEPhCz02yMlxJOJPtEa5ERAKkjJ+vNZQ8azRxtiDAaNoyN3YjGenpn86 mv8A4j3V7aCAWkahAo5YnJUggnj2/WlZLSw22zY1H4f2l1flFuWeNSWVDE3IyOpGOuazZ/BT6eSl taysJDkkjgY6Yyf84qH/AIWbfSASmxiVlXbkSHnpz09qkb4nXd0+Tp0Kk4/5aE/0FHKnpYLtFe88 O6tAGP2SaHzBnngAHpgZ4FYN34ev4oXmMACqCzHcCTjrx3rsNQ+JeoXsUaiwtkAUKcliTgYrIbxT ezKwa0tiMZIwxGPzq4Lkd0S5XVmc1Z2yXhwQoZByScZGa77T/H1jo2hppp01p9mcsZAAc9QOMge1 eeTmWzvS4QoG+YAKQMHnAzzimS75/mLnHoABiqr0lO0hQqOOhd0zV5dP1KaS12xhy2xXUMFBJwCD wccda0DeXl2xmuneWZzlnc5P/wCr2rmXQxncCSR1ya0bDUgCEkOV6Z9KirS5opx3RUJ2dmbHmt0K rz+dIwDwsNvODUyxxSqGUhgehFNkjCEAE4Jxj2riim5WN5PS4unIQoyOnatqMk4IyMdqzLZMHIAA 4FakI6HBrvitLHI3ctqxbAAwOOO1TAgECoUGO9SZ5yRTGTpzjjI9Mn86fKVB2fNj0J5BqupwMA+1 OcgEAde9CVxN6FlHKcuTg8BgOSCD1rQgAIIJwM5IySCcnGD2AyOKyUkYKUPIPUVPBMY2Ck8e9NaC uachYrgliByRgj8+DUGAQwDEnJwuME9eRwMYwOO/8lEgMZJ2kZOc89jgHg/h9PxEU86HcCQSSdwI 69euAOfp6/k/MERSzFcgMCBkAj649T6etVGlJPB5ollMjMWJJJqLI9D74pAKWJzkk5phAA4OT60m cHr+tMLZNAWHEknk/nTSeSBSbsHrTHcDjuaB2FZsDmoHbtmiR8d846mq7yqTyeAe1AtUOL55zx70 zeM9Rmq8lyOijn61AZgOSaaTtqF+he38ZB4o8zHU1QFyAcE0NcKOM8/WkP0J7yQC0lOeik4/CuSk cNIiDpkDity+uwLSXnOVI6+tc5BJiYNnkc59KmSvoVF9TZXkY9KNuASRVB78A5zmo31Nim0DBPcd azdKKLU2Vb8hrtgvQYFVipI5FOklJlZiDknNNMgJ4OOe9NKysLrqXLBQJGJOAMZ5rQ3xdM1lQqxj JDhc+pxmpQhwR5y/nUSTbGnZGgNjOFUAE8Vu2hEOlFSANzE8DHTgVy8AIfd5gJHAA9e1b8shitlj JIKrz7nFOKsDZd11mMdsMdUQ4+iKK2UiYWtphSSIFxx15NYniE+U9qv/AEyUnH0A/pW7LLmKzUkg rboP0z/Wm90CZNGpHBXHOKsEhVw3BHYCqluGL5HrxmtExExCRsEEkEA88VXUlq+pV3hkEYQEk9ec kenpStEwIJXsOc9B71HIF35HAzTlUtkZOOv1piIbhQqEbhn26VdWJri6jtogA7EIpPGTiqk0RZME EEDjipHEjQrNE5VlIOR2YDkVMk7aDjvqWdUtJdMlWF5VYNgHY2RkVSIABJ6e9QAXE1wJbiUsR0AG AKueUSoweMZJPAA96mN0tS5JX0KvlGbChc9sYpqwiSdLO1RTI5AZhgZ9s9gOc1PJODGYbVeDw0mM lvYeg/nUTWrW13bIxDiUgsiNljk42n0J7j3pOV9EbRpOMeaR2emeDxsX7NKrEgbrggMM99o6YHqf wArYHgdH5nvpHbGOST/UVY0fxHpy2i27yokiEjA4XA7gnt2rB8T+J47W4QW920vmLuGxuAM4HAPt 7Vpa6MHJtmk3gK1JyLv/AMdP+NMPgCEkYu+Poef1rjx4lumG4yyEHkEk/wCNO/4SecjPnSDH+0eP yrOzGmzqn8AxgYW5XPoSw/rVS58BYXJvETA6ljj9awW8UzqPllkJ7kSEf0qJ/FNwQS0shGO0rDn8 v60WHdlm68L2lsCDrNnkdRvyf5VnWuinVr9dOWVGMmTCxO0ADqSMZOe2etQSXb38ElxLHIwBx5hJ O0+me9VDPPbPbTaZAzTxZ3EA5bJzkYOePai1lcE9Td1/w3p+hWSxyCJrkg5ZZmJAHcg8CjwxFpkv mT+egGSqBrny3BHfgYNZ9xe32viG0ltFRpyFdmU5BJ5JPHTqAfyro7TTdA8IWqwzItzfyc7WGVTP qO5o5eZ+6NuyJ18PW1yp8go5J6rd5H44FDeC5iMlQR2xN/8AWqLU/E8NtIqW1zuQqCBHlVB7gD/6 1Zh8V3eTtlfB9WNTKMri5n0NFvB7p/CuR1/ff/Y1Wn8MlFJYqnGOZhj+VVx4puSOZG/77Ipf+Epn ByWcjv8AOaXKx8zM6906ezBeC5VsdfLkyf0xWHLczb8S/MQec9fzre1DV0ujhgSccnOcfieawLkK 7YXnPINDj5DjNrVMqzJDcKSwyM857VZ06wgikWQ8gYODVZEcOGCkr0YY/Wrarhcq2B29qSdnystw 9pHmjudDqGpiWAIDjAxx9KwlVp5QqAlicAAVHlz94kjtS29w9tKJYyN6nI/CtW7LQwSs7Ms3dhc2 QBmQrkcZGDUDuPkGcHA5our651CUNMx5POTk1BK2XwDwMDj2qIOT1kOSWyLLFdow2T7VG7grt7n2 pisMgdfrSyHJGODVrTURatQEt3YHqKgXkkkZOasxkpYknuarxnLAAck4pMa0Rem0+ee3V0QlVUEm snBRip6g4rXvdRnjj+zqcxqMDBxWMd7HJGTSi5Xs9glax2+0Fsk/rRtA55x9aZg9QSeKUbuo6VgM nUgAY5/GnZHBx3qBSSRwafhhwe1FhkzAH2yPWlhJCykDIKkE46VGDkZxikDMitgkZGD9KuMhNEZL Mwx2qQMRxgfWogQDmrCEHgjjrR5ACuRwcYqVXxyewqIAOSMEHNPAXBB644+tALuDSkDgcnilExJ6 nioWO8gZxjrSqdvPFAaomEpIODn0p6OCQOahAJwTxn3pTleQaaYalovtOQeTSpMwbBPGc1WDEjOe acGJ7de9PzE2XGmIbKjj0zQJd5G7PWq4bgDPI71JHgHJ6ii9gRajO44U/hU6OcEE5I6VRMgD8H8a ekv7tgD82f0qk9NBvsXjKzxAg9Mg/QCmpKdoOQSTiqhkYRHk4I/WoklZADk8dKTYtjZ6xBwOAcGk DkgcHnrVaOcGHBI5PIJ6mmtOAxB64phY00clTz0qpPMPMwcnHPtUf2sKuQADjvVZpiSTk4JziquB OQXB2sQCDjJ9qiYErtGMjk0QSZBwRwenrVmKLcpcdemMU9iSojsjFjnPTParmxmtoSCSfNyfptP+ FRHYyOckYPTOQT9KepVbQFgxAkBAHY7Tj8KcXzLQGrHPfEUg+EGAP3Z4/wCteQJMYJd6gZHpXrvj wmTwjcEgjEsZP0z/APXrx+4QBsg5zSW4uhvWmruQrQ3LQuOo6j8RW9D4ongtyJbqNiBjdtxj8Mmv PUUMwGSDnqKnSCR5MbuByc03sOx3Gm61Z3moebPdgFWBw7YZiOnJ4A9q1fC94kOqTZbAeMkHPX5q 8vNsYpSwfcDxkVs3F/c2FvZyQSFHMZBI7jPT86E0kOx7fHco44YH8aso49RXi1n46ubYhblC47Mh wR+B/wARXUaf49sZQoedUY8Yc7SD6c8H8M0732Js0eiAg9DTuD2rn7XX7acArKpz6GtOO9RwMMDQ IuFAeDUb2yPnIBH0oWdSQM8n2qQOD3oAy7rRbG6UrPaQzAjBDrn8j1H4GsA/DzQXlZ3jmUE8IGO0 fjnP6Gu0JBppQEdKWvQd+5xl58PNAhgeUWt1IqjP+jyGQn6AZP5gVz8fgjw7qJMdjqc8FwePKuFG 4H/dIBP4GvUDEQQQSCOhBwar3dpDdjF3bxXGOhkUFh9GHI/Oi76jTR5Nf/DTVbSB2tpIboA5AU7W I+h4/WuUuNMutNujFcwSwv1AkUgkeoz1Fe1P4ahSXfZX11Zk9YyxZCfUY5H4Zq7Fp011aPa6tBBd IpysqAMrD1IxkEeuBSUrPUGro8MORGCAc5qSEkhwOcqe+Kv+ITY22s3Vtawypbq2EJBzkdcA9RnO OaybaZZJCithsEAEYJ+lacy3I5WhLlPPXDknjAJPSs/L28hU/gexFaRKPgLIhwcHnGDTJbYyAgvC R0wZFH8zVwqcvoJxuUyUmXghWPr0q9YaSt3YkhgkyscHPBHHX296z5LKSNspLGR6GQcfjmnwJdAb ouSDjKMD/Kqkoy1i7Maut9S1HcXWlTeXMCBnoehHqDWpBcG7ZZMADHA9KwZp7idNszkhSQN/Y1u6 aoESAYICjkfSonBKza1BSb0Wxr26gjkfStGMEAY5qtbJwCatg5GBUgTJz3px9qYvAzmng5NGwrjh kcilJJOM0mcDGCaQAk4xTQMkQkA5HWgsOo6jimkkDApvbmmhEyysOMg0xpCep9uKbkfj2NN9yeaA sBOT16UmeOlJmmkmgAJ75phIB60M2BUTPxxQP1FZwBxUZcAEk80xiepNVppwoIByaQIWafbkDmqM s5wSTgDrTZJgQSSaybu9wcBhwOB6fSqVhWZclulQnJwe3196qyagoY5bOOhHeobHTr7V59ltGz5P J6Ae5NdfZ+AYYog99Ozv12R8AfjUttvQpRS1ZxFzrKw8hCc8dapPr7nohB+v/wBat7xTpNnbXkEE EWxSCSQSScY9axhplsBkqT+NJ3BNEkup28mkgtMPOdgSgByoAPX8T+lUBd24jJL5JPQZGBRc2EQK hBtJOMnmmnSsKSHLEDIGMCk7jXkKl3anJZS2Pcg0jX9kIyPLcv2IbGPwxzWawaKQgjHsaYUy2B36 UhlprtCcgHilW8hLAMrdQCcCi5sGs41MzIJGGQikEgcYJxwM56ZzxyBVEYyMHmhoLmtLPgFhhVA4 Hciq6XheQJgkk4FPitPtMAZ2ZcZAFQm1VZQAx4PBB6UknuwuakDyIEcLtIbGTz+lb2mBtRWZJHRQ kZYknGSASAPy/lWTbBZHXOSGHbsfWp4IJYrgICytIwXHI4Jxiga3Op15HuNegsokDSGMKM/ia2ru CaMROyEIEVQSOMgDNZHi2Qad4wMtqTuiWPBz3IB/ma3tUu53Mdoz5hjAZUxjBIBJ96HugT0IbYhi MsATV15wEwCcd6z4VIIJXrWlbQxSg+bkcHGD3oEV2dSAcjHbikEoA4GD606eIREDJz1AqIqCMjA+ tDaQWJnlCpsBBzzkgZ/CqSyywOShyDyVIyD+FS447Hn1pGUDoBk9qBJWG/aWIyYUGPQn/GknnaWL azYXgnHAxz2/CmynjIHPrWfdySrEQgzgdfelJKxpTfvI2bC7fUrxNB09I7eWUBmu5G2sx6gA9hjs OT3ravNOt9B0tZpGtJrmNgN63BL5JwTgivOBO+matDcRfLnB8wjJU+o6/UGt+5uZPEOliK3hZ7uJ iTIB8zgnuOpI+lTFO/kaOV3eQzVLuBdQjtluQLUOS0yAMVB59skentxUdrdW0urWyXn2i4sAxQSR jDbcHGAenOMisi70m5trFlmCiRchh3U56H3rT0SVbe8s7OFybhpFKMDjDEcgHP1FTUdokx1eh7Ed M0eO3igElgy7BtE0ShiMcZIwagOgaKekemZ9pGH/ALNXknifVdQi1W7M7nzVlKkdMYOAMD2rFh1E OMyzypxnh2xn9at1UkrDUe57f/YOipkeXpfOf+W7D/2aopND0mVJVjt9LYopyBctk4GfWvHEu7Zy M38wPpvI/mBVS81GSzZZbW8kbJwSXB/kc0lVDliegRyW0+lvp1paFbuW63IQxIAxgKMnmq1zbXei 3HlXCCKUYLISDjIz1FcrpGvzRzqwl2zAhlIOOR0I967fSNLuvFU01zcyztIcHehVh+IJB/Ks1U1c ZbClFWuhkPiK7iKi2ijWU8BzlmB9QTnB+lVru9W1WR5AJLyTncWzszxz6n0HbvzXSJ4Euo8qtzKM 8cQEHH4HH61ZHgGyS2zcTOh3AtNMQoAHUBQSSfqRW2trJkq1zj9A0G+v7m3upLUzwNLt2uSFY4PB II+vXtXpJ8MWfkgPplkpHbzGH65rgPE2uNbSR6bpt4XtrfAQoAvPckDt7nmuI1DxXqSymKPUHkIx kqTjPcZqItxerL5bnsqaZowmNt9isDIDjAvCDn05NXl8L6aVGNOtzn/p5Jr55Ot3byh3uX3jkEk1 dXxVfxKAt84AHABzVKo7ktJHpWvLo2m6vFbyaciiJt0uy4JDDGcZ6Dt71zUrWl3dtLANluTlADn0 4B71y/8AaDavE5vJ5GfGQARkirWmgi2ZRMURQQMeuPSp5+aQNJK6O607w5cXsYnhhkNs2QSihsH8 xk1iazpjaPdSRNLIrKobZKu0nPYYJp2g+OrqzgXTZS5tC4MpBAOOM4J6cCsjxXdx3WpyyWLzSW7E FWkPzY9KfLdWZcXbVMekrOAQcgjoafGFBJJIz0yKqWpcW6bsggAcirA3HqcelJaaGb1epKSoJwcs eM+lM2jBYkZFSJGFGScnGaaVBOc8dxVLYQwYYkjsKUAk9M04YAJxk0KSWAAoTuGpfkIFioIHNV7Y A3CEjuDiprptsEa+gzUdlgyknsCf0pMfQZcyo1wwJI59KdZGEXaGRS0YYFh0yO4qvIQZGY+tR7yp bHBIqulhbux2KuT0JzTt/AyetQBivrilDZ7j6VzWRV2WA/Ug9KcGB5z9ahDADpTlKheSRmjYeqJw ygdacwBUEGoQwx1p6uOQelSrj9QKjsAacrbMUwkHJB49KQEkZGcH9KoXQlUk5YHGSacFLcdTUS5Q gZyPpTi2ckcfSn5iDBDc04gHAyeKaCCMYOaCQDwCcUgJRjjFOIzjvmow4GB0Pen5AGQapMGhM4J4 zjil3AYGeaaSPXOaARkYxTT6CJUYE4PapsjPHI9RVUYBODUkYJOMZ78U9xEvDHBOKljQFc55zxg1 VDhWOexqeCZQSCuQfQ07DuWFbIKngVCACSOopJJRyQcD0pqOCTijcLkm4BcHt0pXlJYEjBxg4qNi BzjimMc4IoQX0JS5KA5JqWLD8bgM8c1ULnywCSR0GKkRwACoyQM8GtEhXLUZAkBUgkcYxjNW1nIB YcYrJErFhhcHOcjvVpZi0RII3DjHrQK9yxLOWbBUAHqcc0juos2VhwGUgDseQP5iqjuSATkcc0hl WK3maQ/IApyTwOQP0zTStsDZneOSG8G3YzzujI+m4CvH2O6RQeMDBr13xe+7wnfkcjahBHb51rx8 sd+Rxk1N9QsPhiAbJI45q5bgnfkfjUMRDuBg9MGrIKxo+OuKGxpWM6WcMCuMYY1panj+yLIg9Bis VyDIM881v3sDz6RYRxqWdmwFAyTkUJX2GzJ2B0BAJJAAAXJJqtc6Rf2WGuoJI1cbkLjBI9a9g8I+ CUsoo7q+QPcEZCHkL+HrXY3djaTW5iuYIpIyCCHUEY/pWiioohu5498NbKzv7i6tbqSRJdoaEB8c DOcds9DXe3GlXOnKXtr4Mg5xLx+teU3xbw943f8As5t6W84KYPBU84J+hINN1zxNqmq3RSS5ZYzx 5aZA/H1pymraCSbPQ08awWk5hupUDg4JVgR+YroLHxLaXagxzKwPoa8AaKXPJ568GpYXuIDvV3Qj oVJBzUcyKsfSMN/HIAQw/OrKzggYI5rwjTfFWpopKMXKjJVh0/HsK6Sx+ISoypcxumf4hyKLphZn q4cdjQSCMnvXJWHi2yuwCk6E9xnmtuHUYpACHB/GmIvlAfSo2iwQwJBHQg4NIs6sOCPzqQOD3zRY CjfWFtfoVvbWC5B6GRAWH0YYP615P448MJpDQXVquxHYrgE8EYIwf89K9lOD6VwvxMdBpdnDkF2l LAewGD/MVLQ03scXoQ0zUNPuEvIANQg+aKYYIYEcBgeCMjr1561mXj2t4w+y25hnBIeNSSCR1xU3 h6JpLu7IICgAZI68np/n0osIGHji2VCQTcKOPc80lHXcbelihaaVc382yNSFBwzkcKP89qta1YLp FrbQ25fDBixP8TDHP69K9XuNGUglIkUnJJRQMn1OOP0rlfEOjl7ULMk7Rg5IhiDsMd+WGB9K1TW5 Gp5hl3kUMCTkcY4J966+wiMahSMEAZHpWDHFAmr+UYJyDIojWT5DyRyRz+Q/OuuMYifAGMdRQ5cz C1kW4yAoAqdDk9apoxNW4xxkCgROORgCnjIGMUxc9upqQCmAuc4Ip2QBgGm9OlGeBgUXEx2QBjv9 ajJwcZ4pSSORTep59M0xXFBpCeetHUdfypDwM9aAAnHFRk4J9aU8dutISMcCgBjepqBiAe1SOwHe qzsACSaBkc8oQHnk9KpMpYbjnB7+tPYl2LE/KOprL1PUVjjZVJCgYOD19AKH5AiDU72KAMEfIBwS O59qx7WNriYTS7gmcYHcU2KBr2UzTMQo4Vc1eVTEP3bjA7GuuhhlNc0jKdTl0R6P4a1XRYrVLeCR YH4BWT5ST656H866Wc5jPOQRXi8bgsAyge9bNhrd9YIBBOWhHHlucrj2Hb8MU54a3wMSqdxPGBA1 aHJ6K2fzFZMcsTgqFyw757VY1+7bU54rgQgbQdy5znp+lVdNu7UXMss0AACgCNScE59T0xXLOLi7 NGyaauiG6QbkIGMnH0poJeIgggjqPWrmoXFtOQYYhHtOcZzn86pl1EYIOCT3rOW5UTKv4fmZ1XOA PwrKLHOfQ1vTTqgYEBg2cj2xisSaMo+SCARkfQ0nYYm89M8Y5pMY4Iyc00ZHHajJJwOTSA1LKcmM xk4I6fSmlgJBx3xzVCKUxyBs4q0pJlyOc0CNvTJWRzsOHGWTnnI7flmtyzK3eq2btgAzISPbIJ/k a5OFnilV1JypyDXTxkhPtMRwr8rg4IJHI9uc0tmVbTQtaxcC/wBflkPO6RV/AYH9K6zUznVJdoyF bHOBwABXE2YSTUoEIJkeVRnPqRXaXoL6nOxGf3jD06Eik9WCWgsTggkHkc1MjsBkkj2z1qv5YXJB 6dBQHLtgHHbpVEkzEyOTg8e/SmscDGB9ablieeCP0pSH25OOeOR1pWuxkTPhsKBgUpIIBAOTUbIy kk4IHcHvTozkggg+oqrCHspChjkAjgetQ3SJ5RAGMgnJ+n+fzqcOXYKRkLkn29qpXEokn2jOF6Ae vb/Gsaj+yjpoRsnN7I19MfTUhEj6cLhopVCq5yGUAAKQBgknJz9K6TX7yw0bQ45dHsYYXnIMs0ak hSc8Annr+HFc+6x6bpiBoj5pUgEnGGOMnHcgYHPsayY9andZIXCyoTkLICQCBgcZ4x+daKXJG7MX eTK08ESMZbmUvLICwUHJz2yM8fzqrqmi39i9jfPbyQBiJIyeMkHOR+ldP4UsfD7lbvU9UTzI2JNu EOeDxk9OeuBVb4g+LodUnRLT5YIl2oOMn3x2qYx57ylsX8LsjiNcv5Ly6d5WLSMSzk8kk1QUZQE9 uKqvIXkIblick5q5GPlxntWU9NEXFXTuMZARx1qNogSRjIq5uUxCLYoIJJcZyc9uuMD29ec04CJU CkZIJJOcZ9qE7ENamcts4O5SRWra3+oWpHk3Eikdw2KjLqQAoA/nRuIGAT70PXcFc3YfFmtRLhb+ 4AI6CQ1Fc+IdRuxma4nfIwQ0nX8qxgSBySafuJwTk+lLmfQLiTySyggsVB67e/1J5NUxCqjnn3NX Nw5BqEkEkgUavcFJplSSIAggAg9MVEYyVxjH4VogKeNvSggAH5Rg9qE7aA+5BZDFtcsDh1Tj2HQ1 s6CjXelNMAW2nDgdR7/SsMO1vOSclWBBHY5re8Ozx29uUVgkgYnr1Hajm5dbCtfQLuyCBbg/Lu44 IqzpcsNtBch0DyY4J7e4qXX50uYY2TAfbyAAACPpWPbTMWGT1BU57mrb0UkK/Q1FIIyAMHmpEIIx g5qpaHKmMnlTiriLnp2pJ66jaXQRwQc55PakO7HANSlCeTSHAOM1foKw0A4J71LEv7xcDPNMUZGQ amhB3gDjmhMTHX7jIHQYxim2JASZz2XH51Hfcy4Bqa3QpYSN1LMB+Q/+vQPcqMN2SPWrcVohtzK5 Oew9ajtohJKFPIJ5NXpiskqQpwo4JHp3ok0lc0pQ55eRpjcBkkkHmlBzjIJz7U8A5wRmnYJ7fpWF yBAc9AeKcQCMAY/GlVD1INPC8454ob7DsM5OMCnDOOCeafjjBApQpA44+tCYWFUEgdOlTRSCOJ02 g7hjJHIqNSQKNuSATQmwsPPK4AHHOaACe2R0pvAJUkcU4EA4OTQAEEDAA9aaUYnOCBTyeT6U0Ngg E5pAAU7qlMDiHzCp2ZwGxxn0zUe7BzUolYxbCx2E5xnjPrTT7gQcnigLg9adgA5xQCN3TFUmybCH PUcU5WZGBBPX86cATwRTsYHA6VSeorA7hiWIGT1HvSRuM4APB6UEEg4FNwR2/Gi6Anch1JHftUCn BPOMGnqDtOaZsIYimmgauWC7MACckjnjvUZDKeCRxzT1BUg9acy5ye4qk9QIWP7sAcmkgYrKMng9 fSn9SSRyBimhQGwDzmncLXLCDDHIB5PFOUYypBGTn6U2MKhyGBzyPY095FAOCdx6+lF2FgYZGCOn f2pHAEEuTxsJxjj1z+lNyzc4yR6UjuXVgM5Kkc/Q0JhYyfEjhvCV9GAcCEY+gZT/AEryRlOcDJ7V 63rCF/Dl4uAd1uR+Iwa8vYxQAhuXI4welJ7gSwoYwZDxkAYqK5YrGTk88GpUlEoUjp6VDdoxiBA6 mizH5IoJG0kqqilmYgAAZyT7V6T4UtN2q6bbzIN8RbKkZwQDVH4f+HDd3P2+dMopxGCO46n8Og98 +lb2hKIvHTIAAiyTAD0wTWqXLoyW7nocjpbxFmIAAyT6V5H42+IUkrzadpblQPleYdeeCB/jWv8A EPxO8UZ020cgsMSOD0HoPevKoYMysWGdwBwfrUNtsEjU0q0murN2CAFW3tI5xknsSep9B14NUDED qKRcElgK7DRgyaDqewkfugDgBsDcOoPQZA+Ycg4965BZ1h1dZGzhWyeKmXkNWuWbm0MTfdGB2xUE 0RWDeSgwwXaTzk55H5frV67v0nkV8EAHOAP1qGQ20zJKSDg8DOOaiNy3boyOAy2kiTxAnHDL2Ydx WxqFlBf24vbEAgrl0Awc4649Rzke2fXFSPyyP9bHxz94dKZDcvp0rTW8qlOrxh+oz1+v0qk3sxNW 1TKCCWJnKlhtAII6ck/4Vo2Ov6nZj5Z2ZQeA5zir7RQanE1zpy43EF4SeGIz+R5P1zx2y230yK7B CtHG4OGjkcKQR7E1Wq2J0NnT/HkqYFxEeOCVOa6ax8ZWM7KhnVXIyFJwfyri/wDhH1jGTNB6/wCu X/GszU9KUJujljWROhDgg+2Qaak+qE7HsSa1bCIyvMiooyWJAAHqa8n8Y+Jl1XVGmXP2aIeXED3H OT+J5+lc49zdiMRSzP5Y7FiR+VSWNqtzMJbjCwx87M5JPv6CgNtTpvDsUVnpjTzYJkJYgnBAxx+g /WpvBFp/avjF7xhlIN0pOOMnIA/XP4Vzeq6v5hFpaNlDgMQOvsK9G8D28GkaSA7qbmYhpSD09Bn2 /mTVJA2d0UBHAqvPao4IKg/hRHdo4yGFSeapGMimSczq2jWvlmdoULxjcpKgkEdMVyEpBlI4Oa7/ AF6RU0udsjOAB+JArzp3JlNC0YFhQVPPI/nVyMjHB61WjOQAe/rVqNRgHH0piJVJPOTTicCgAAcU AA8Y60wHAkrQSADzSnAxxUZOTjvQgFzntS4JxzTQGJwAacFYc5AHuRT8iQ/CmMecVIQCvykE9x3F MYEcGi1gsMORnJqNiMcH8aex5NQSNj6UkBG7YBJNUbhyflB47mrEjE5xVJlO1nJOB0+tA/Mp3lyI 0ManAHOSeg9a4zU7me6kJETrEp4ODgn1NdNdhXBV2K7uCQcYp91YaRZaAJYpjNdvINyCQkhcHJP4 4qb62KSW5yQtpQg23R46gggZA5A9xW54Wsv7Q1MwXMkpj2kjBxzkeorPmtGi/frMjmQAlQpBGecE Yxke1b3hGZzrSq4IypwSMdxVczWzCyZ2L+BbSeIGG5kR/wDbAYfpjFYOp+FNR0oGVV86EDJZOQB7 9x+Ir0m05jFWJgDGQeQRg1pGtNbMhxT6HiolyMMoBHBB61DNbrKC0RCv6+tbfjC1S0vw8SbVbJbA 4HvWJE7KAx5XPWuyE1VVpGMouGsTKfzopCsoPHQ+tI0pKgAg8flWxeJC8G9gAR0Occ+lZwEIdkUg 8ZBByPpmuKtT9nKxvCd1cggTz5QhUHJ7jNW9WsomtAYly8fVumR3AFMtImVXmAOAcDjoTn/A1NI5 cc9PfpWY3ucuQAcHrSnAGR61avLVoXDlSEfJViDgj2PeqmcAik0UHBPcd60NPcSMUIycce9Z2SOT z2qe2do5hIpIINIRsFACQVIJ960LKZ1gaIgheqg9/XFZhnMrbiQSenvU1uzidSSAM9PWm0CudV4U tI73X0Mr7dhEignqQQQK7fVLE2d8xLowkzIACDgEk4OOhrz3wy5Xxbp4VvlaQMcdwAT/AErunjcy u7ZO4k5P1qFuVpYifO0HgDvUPIfIHHXFWcEDnPvj0poQEgAYq1oSIhJII/KrotBJGWYncRwMcfUm qzKEYEEe1XbORlYEkbcd+lSMoSQGMlffpVRwVORwBW9qgjYxvGBtKjJA796ynRXjODk96d7asEru yKjSeVbsxJy36Creg2QnlkuZyTHENzYx1PQDPp/Ssu7cvKkKnuM1016q6NoK2u3FzKBu9QD/AC6f yrCF5y5mdldqEY00YOsX7XMp2kkD5EGeozWJqNyLG1IU5lfgEHn3NWGdXkdmbasYwv1rCkdtR1Dd g+WhwD6AVc2m7dDnj3JYJ2tbRpGOC/TnvWbI7SMWYkk+tXbhvNl8pfuLiq0qFcgD8hUc1tCt9SjC CZWJHOeK0EwGAJxVFPlkPXHWroIIB5J+tRK7aLSsiQEAk560hKkZANRkjJ4IHvRvHIx1ppGZOAAA VAz3NWIbcysgAJZs4A5JI7Ad/wAKz2kI4B9qBdyoUw7jbkDBPGeuPTrTtfYXU07eCGV44yziR2Ix gEe3UgcnjkjHWnSwxxRO3O5XK4AyAR71lLdSo4dGZWUggg4IPsaX7bO8ZjaVihYsVJOC3TOPX3oU e47k5K55xTGK5qLce5pV569TS0DdkyEYPpSgA0RqOnXNShVHtipv1G9rFaeNXGCPyqvAgaURMxUn hSOx7VccEgjOKpzAqQ64GD1FWndE3syfSWlN3PazOxYAsuTnp1FTYMcrL3ByKr3k4gubO+RQACCx GcnnnNaN/EEkSZRwwBH0PIqlqhNaj0cJKkoIw4wfrWvESR7VgowaJlHJU5HtWrZz74gM1Olr9Rrs XsgjnmoXUkkjvThwM5obnt0qr6CtYAMLg1Nbg+YCe1IIjtBPOamhXAZgBgDJppAylcsTMSP5VcI2 6XEO7sSQfTOP6VQlYtKR71qzKEgt1IGAgJ49ef609mOzehXjxBEWIwx6VPZxtLIAAS0hA/DPA/Gq cr73AHT2rc0uHyIzcvgEHaozznHX8BURTnLyOmp+5p8vVl1U9SacAQMAmlEZHfGakCkelY3RjYRQ cetKASTkGnYOelKAMntRcBv4H6UuM9jTgBjrRjrg0XENAI7U4g5yRQRgZNGAeM9KBCDOe3NOwRng UADIHpTsYGDTuO1xpBPamgDgEVJjPrSke1FwsR4HOaeMDtxQBg9Kfjg8UJoLDSoJxj3pCoB6dqlA IHSjBx0zimmFhECg8jmnYUHIODnp60gBzkjH4U5lG0HGeapPuJoYwIOQMA03kgipGBbAPGKaE5wT kdqd0FmNXOMHFIzFWyfY1KUAXj6UxwMjjPFCaEPU7snHB7UEkHBHTvQhIOKVsk5x+lNMBhyM46ik QBjkjp2qTBIJwB2NNQAMdx4I4NPqLUQnJJU4A5waVVJYYI6UpiBXcrE84PtUkcYBAPai+oJE4jCE IWwSAQcdRUIjzcAAHBJAzVxpW2AbVOBgZAJH403KllyuMcmiMWncbatZHPayTD4buGBBzCQeemRi vIpCSxLHJznmvZtTtHufDV6yqSFR8Ae2TXjxiLDdnoe9CknKwnFpIfAGERP5VYtYJb+a3tozl5H2 jPQep+g6/hUDMRbuMjPtXZ/DrSTdXRu3TKRnYhI7kZJH0GB/wKtoRu7voJux6Z4d0pNP0yKJFwFU AZHb39+59ya89v8AURpHiO8u1xuWWYKCepJIA/OvXEAig6DkYrw7xdg6jOwPW6fn/gRpTbvoKKMz VQ89rDM7FpCSzkjPJwTz/Tt+NZcaD7QoIwSuefSti/K/ZEUYJULyAVBG1RnB+nXv7Vl4CXURyOV6 mpi+g7HW6Ypi0C9JXIZAOUIGcnGGHIPt0IBB5xXAXAIvnJwME5OK9IsVL6LOEIDtEQQkvzEZJPyk YIwBnuMAivOL07L2bk4GcHNJv3gsKZ4XVlZW85mUqc8BQDkcfh+VJ0UAVSaUkjHY04zP2OO1WIvC VVHPX2pA++QAAc9apoHfgc81oWUQEwLZ4HHoTSAW3e7tL3fauVJOCOx9iK6KPVbPVNqXX+i3qjAl yAScep4I46HnnGcVlWxA1BQQOT3q5eafDcSFgAHxnHY07XQX1L08V1aAs6efCBnzYweMdcg8gjoe 1Qb4pRlHVgRnA6j8OtZ0N1qekt+4lYrjAD5IH0PUccVYbWbG6YC+sBbvnO+IEAE9SSDk+wPT9KNR EGoWT7BIqkk+g7ViSxTFgiqxweQBzXVqLGUZs9XKkDhJBuz64OMD6EVJdaDdOZH+1Wj7VDEjcOCQ AOmDSa6oepw0SE3KlgpVTkozhSfbJIrTtr7UrImS3lAjXJA89TgemM5/StC68JXLFpHeBQmCSJQM Z6cGrQ0CW2ikiLWSgAFgXYknjH6mhJ7hoiS08eXdoyR3AV8gH5GBx9cH9K6mw8c2k6oZHMZI4D8V xqeHtNUs93qttAB0AUsSe446fiO9VZ5NEgV0hSa4kwoQ5wAe54AyPQEVWu4aM9D13XIp9JASQNvc Dg9uT/SuXRy75rnbR5Xu/lV44DyqMc4roLcHODTTuS1bQ1IckDNWozjGPyqrCAQDVqMYOAKYl2Jx gnBHSngDIBHTmmjPrTueucHNMBMDqGIA9R3puFJ+ZsY9BT85OCM+1MYKThcknoMUK4mG/AwCQB6m gsGxhQAOmKRVGMkEH0PNKRkcUIGOAAHGOnfmmuOOOD+Y/OnonykknIHbtTCCCMgj1x2H0pi6ELEg Y4qu3I6VO+DwOaiIxknpSs9h3Kko+UjuarXAIjwOmM1bcc1UusBPrTEmc3q5Ihx2JAOMc1Xh1WG2 hCeUjHHO7nNJrmRakgEfOBn86o2dtC0e5kDMe5Oah7lrRE+j3cc+rOLlQ8RBIXOADkY/QmuxsDYi +t2to1Rt2D3JGPU1xjWcRk3qpQjoUOMVp6I00Wr2xaUtGXxhhz0I607Cv0PYrMExqcdqsyD5CMVX sMNAoPPAq3IAEPFAzzHx2XjuLVkKhmkC/PgKc+pPGPXPGK5lFmtpXtr6IwyDkA4AIPIII4I9COK7 LxvaC5Eanghsj0ziuDmubmC3exmUPGuPL38mPnPyn0Pp0rSE3B3QuVNakkMAuZ8yM3l5IA9qde6W Y4w8GQV5IzWtbwQ3OkJLD1UAt9en4c02NxLEUccgYANd1OnGrBt7nNObhK3QyLcskJQ4yRz/AI1L AiNcRBjld4yD09qdcRiKTkEZ5pkZByRjqK4JwcJOLOiMlJXRo61pRvbGRwx3xgsCeeAORz7CuDcf MRjBHWuqv7m6+xOonkKAYwWJFcvICWJPWoexSGAYwMmrUQAXHPHJqsvByACfQ1ZtoZriURxIzuR9 1Rkn1/CpAtRnEZATcQCfoOB/WprO7AnU7QQueD3zwans447aO8G5Zn8gLuU5UEsuQD3IGQT69OOa yg4F2Aowo4IFNgdh4VlUeIrSWQ4ESytnHQBGwfwr0GzuJbvT4bqaJkMwLLkdRkgH6HFec+EruG08 S2bzsFgcmNmbou4EZP4kV7L5R8s2sq/KPukDgehBHas3Kz1RaV0c5MWLHaSEJ6YxTCAMYJ56+1X5 7cxzlCMgHg1VmicZZRuA9O1VcVrDWVVAJJbPIz3p6TKQARyO2etVTJn5c4Ip6gqQQT65oTFYtTGV 4gNxMYJIB/hPFUrhlt4GbcO+D0yKt4Kx7pTwxyFz1rP1u2uo40eSJkVwGXIxlexx6VnUk5e7E7KF LkXtJ6DvDdkL3VRLIflTLkkenQf59DTPEuoG4vpCrZwSqgfl/TH4VPaznTNOO04mdSTnjArm5p2Z 5JTltowo7kmiPuxMJNyk2zK1K5YAwoxCL94g9TUkSC1sQcfvJOSPbtVWKLz74RsCUXLOf8/lVudz LMWIwB0HvUSeo7WIlXYOeWPJNNlIA4GQTzT9wJyBxTWAIx61nfW5WnQpso3OQMU6M54HelIIc9cE c0kIOckcCj1KLVtB51wqH7oyWPoB1rV1Z9JuDB/ZltLAFQCTfIGDN3I4GBVK1jKwF2481toJHbPJ q3qVk1jOIhNDMpUNuhbKjIzjPqKtJ7oh6aGa0ETgBQwkHXB4x9KnWytUtmWZZDcMAUKsAFye4IJP HoRVrRNPTUNbitpriK3R1JMkpwoAGeT74xTb3BvZCpGAxAx0AHAqrO10Toa+j2Xhi3tiNUNzcXBA P7khVXjpkgkn8BWNq1rYrdO2mmQQljtWQAkD6jr+VRIS5woJJPbvUs0EkQUSKVzyMip5nshk+jwa SJR/ayTSIVOFhYKQexJIIxSa5FpQnQaRFNGmAGEzBiT3wQBiqKk5JHqRSbCJNxzyAaSGNSNgMkAH 2pxUnqO1PY46jNABI6VKd9BMrsmQc1E0W8EEdRVtkJJwMUmM8EYxVKXYmxQaAz2M1uT88eWX6d60 9Ncah4fTcQZLcmNvXHUH8uPwqowEF0kuPlJw3uDxRpMpstYuLU7fLuEIUHIAI5BGO+M/nVRfcGm1 cWNjHICenQ1ct5DDIVxwDn8KiltyZWUdTyB/n3q3DZytEs5G0AYOeM/SnfsFrllr2BAN8gXPTJxV oKSAR0PSs29si1tuGOQSBkZ/KtTS51l0+JpFJdBtYdORTa0uDunZlhIyAACSacWaKJ12gswxUv2k hcKgGe+MnFQu/mkkjP0qloibXM8xMW5ByTWjqM679qEYUBQfYDFRtGcZJIFQ3NrK8LPGS4UAsR0G aiU+iOyhSs+eWyE0+Jry8SNBkk9ew9z7DrW9eXENuxiUDy1GASeuOp/E1k2qSaXZrMTh51JAA525 5Ptms+/v2uTtXPTnHYVrSioxOatN1JX6HcAEjBNPCc8mpViyeBiniLocVw8yL5WyFUx0NOC47VMI TnnP408QMeBzSuhpMrheORS4HpVv7MxGCKPsrZHH6UcyXUaiynj2pNvNXjaOeQKVbJj2Jo513BQb 6FDaQelOCk8E1e+xOW+7ThZMDyKXtI9xqD7FDBB5xxTipIHHSrxsmPYU4WTHgDJ9qFUXcOR9Sh5Z yCBwadsPTFaCWZOBU62GRkgACk6iW41TbMoID2/SnBDycVspp8ZAOehqX+z4gD1/Go+sLZFKlYwv LJ4xS+UQw/OtprSFRksB+NQSLCmdvJxVRrXdkgdNJXZmeUQckU0oRnjAqyX3AELjPao2DE4IrVSf UzaXQhwDjjmgoSBgYqUIQeAakEZIAI71alYnl7FUKAR+tOCZOccCrPkEnG3P4U5IG4AHempK4OLs VnQ45AAI7VEFIBABx61eeAgkE80JbErwM1XOhKDZUVMRhQDnOTUqITgc1aS3II3DGKeEUMBx0IqV PUfKUyWA4zx0oBO4HkmroiQjJIp32ZcAgjnpT9qr6gqbexQt3zZXNscEM7A+4I6frXhkwKMVHGGI Jr2yM7Lq7QngSA4/AV49fwkXt2ikjbKwAz6EiqikpXREm2rMpKrOQDXuvgrSBpuk20BXDhA0meu5 vmP5AgfhXk3hSw/tLxHZWrKWVnBYY42jk/oK980qIOzMDgM5IPtnj9AK64q0bmLethdVuVtbKR2I CxqST9BXgeqXRvYY7gnBkmLdcckk16t8SdRNp4ZvSrEPLhF9eSB/LNeQIC+nWQVSTvAAxn9O9Yt3 bKSJtRcmFioIUucZbd9Oe9ZUj4lhPP3RWlqcpa2zjIZ2IJXBPJ644/L+lYwfcEOORxmlHYbPRdEL S6SylWYFSCPJDqAAxyccg9cEdMe1ecakmL+VcYycdMV6B4alR7JXJjUxsDksynBIHBGcdep6c1xH iGIQay6jG3Jxg579j3+tJ/EO2hlm1GMgk+1KkSF8HirKKT27VFNGyMHAxnBNaEsmRABgAe1TxCQz opfMaksB7kAH+QqOL5gCOeKmt3KyAjGSCORn+dKwx8ZxqUfH8QHpW4Yy0g/OsPAF9GD3I7V0YldU WH5ShOTlRnPI64zjkce1WtESyMxKw2uAR0ORmq9zpEMoyrFcjoORVsZI5GO1SNGwjQkdRnNNpWFe xyl5pE0EeUKsScDHBqkltexE4EiA8EgkDHviuom/eSkEjCjHPeopw3kOqAEkZAIyD7YqeXTQdzCu ItTjEZkuZBHNjDSSYBwcHnPY1DdQXaWYmluGJMpjKliSCBn1/DpVzUb1ruC0gSIIbbACnncckkn9 Bj2qC9kmitUtXhClcMCBkk+v0I7UgV7lD7FKIjI0g4GcDvXeW2haVZG3eSFrgFgGV2IB+U+mO+K4 NJnfMRHJBA474ruGvUEcQBLMoBIHOOMf1qtLahrfQk1g2w+zLbWyQKpYkJnngdahgwTkVWup5Z5Y 96hQM4Gec8datW4IAz2oTvqhO+xpwgYFW4xngVWhGACTge9W0IwCD+lUIkAPTGcUvAGScU0Entmk 56kUWAXO4ZBIFIOOAeDSjJGSKXYSCQDgdTjpSQr3EGCRzUkahmGSBj1zUYRicAE4GT7CpfLYAkgE AZOO3+fWqESELuIA5yByeT9COn/6utQOccZzjOOMEfjTmBHXke9RvkgcE0AQNySSetRSEAYqduD9 KgkOevegbK7YJ4H4VSuQTkZHAq65IBFUrnjIHGRR0Dqcpr5At1ABGXqCzA+zjntmr+oadPqLJFBt 3KScHPNVmsbqyi2yxMpHHTiovqVrYYzAkKFJJOAB1JrS02wvDJHd7V8uNgxAViQAeeQMfrVfSLQX WoRiVSY2kWMn6gkjPqcY/Gr0+r3ZuLuBbqS3hiJVYUAAYDgg9+cU+thJWPVdMcNbqfUCtBxlDWNo cu+0jbPUA1sMcqaEM5XWLeOe6iSZgsZJBOOnBx+uK5LX9BZDGhB5JAcdxjOa6zxOfKspJc42Atke 3NZ+g+ILa7tmtb+JZYGACSfxKcdj6D0pa79Bpq1mcnpsMmnEwOwZJATyMgHntUkyGGfJBAPtXQ6v obW6mWJg8LAlHByM9vxrIKNd25VY2JiHzknpXfg6qT5TmxEW9bFS4iEsZIAyOQazY48u2RhQcHHr gn+laETlZPKfHHT3FRXMckMoMMTSBjyo656DFb4ulzx5kjOhPllysz7jD2pKjJxmueS3luZgkMbO 5OAqDJP4V0o8qIDznDE5zHGQSPYnoP1I7ism8luEDJCiwwnIIQnLD3J5Prjp6AV5J2JEKWltbANd y+Y/XyYSCeuMFug9eM/hV6G6Bt2hkijitmABWEEMQM9TnnrnnPTjHWsUFzkBckd8VP5V5cx8IwRe pAwB+NK9mMs3N3Bb2xgtizFsFmYAcjPAAJ45698dqowAhwzcknJpREm7apLEHJJ6f5/OpSuCcdKG BcgdfMy+RGeuOuPb3r07wP43RYY9Kv1VgGxBLIckDspPcfWvJA7bSBnI6VPHLMACCQRzkcYNJq+g J2Z9EOFuQxl2hyxI2rgLntj0rLmgNkWEhLbgcY5BFcz4N8Xm9jXT79gLhRiOU8b8dj712MyrPHhw ARwCf5Vldp2Zej1OfK4fdgg9QOtTLOXJLKMAZOB2FWXt0CsHYhweBjjFU5FZIJARgcHOOacpJRbL pR5pqLK8etrFfJFsiaWY+WkkxJWIdCxHcjPHb2NdbeaalnZzXV/fWN/cFNwaYuSwxkBcEDHoBXmd 28sUbSrGGKMQCVBIOc5GevGK1rS+uNZ0abTo7ZpZyyvHIVAYYwCOOoIxwKmknbTqbVpXlaXQk1K/ huJXdGM5eFRgE/K3UrkjJA6e/qayLl7S8hYWrtAijBMxyS2OeeO+cD6VproV3o0DHUQI5nJYLgZU Y749fSsG3gingkWeUoJHJU4yTzxWktFqc630HXMum2VjDb2KStKw3TTSEZY+gAHAHvkmsqW4BfaO meT/AFp15bvA6o4IKg5z35qtIoLZA7VioqxTbuWkIIGDmpMFumKt+HNNi1TUUtZ7mO2iIJaWTOAA Ce3c9BTb2zEOoSQwyrKiEhXXOGAPUZ5xT9m3HmBS1sZkuSxUdc4qaO3dcAjGRVu106S5uY1hZZJX bAQZBX65GMe9b2k+G7jVNRezglgYxoZJJC21VA4OSQPXtmpUZPYd0lYx1dvKRWcNsAVQAAAOv557 0M5dSGfIOMDHOa6rVvClppumm4TWLOeUEAxxsSefQ47Vz1hYvf3gt43jTALM8jBVUDqSf6DJp8rW gebKSx4lWQsQACMetLgYIB79a7O48GW0Ni9wuuWEhVCwVXOWIHbjrXGqjyXgt1VSScBgePr9KGmk K3Q0NCv4tIulme2huCpyomBIBHQ8Ef4VL4g125125E1y4O0YRQMBRnoB2FUdUsn02+NsZYbggD54 H3KSRnAOKsXWjS2mlRXrzQZkYqIRIC647kDoDSjdD8ivpD2lpPuvbcXMZJOwsV57cinalcx3d880 USQoSNsaAgKB2Gc1TaOZI1cquGOANwJ/EdRUlza3NnBFNKqFZQSoVgT+IBJH40tQ2IHZRxnn60Bw F61BKsojEhiyDxwRn8q1NP8AD2p3tkbkJDHFgkGWZUJA9ASCaVrMWr0KinIyM/hSZAJOOtNg3q7I 64IPrmpdgJ696HuCRVnUPGwGc9qp3LOI7e7TmSJgPxB71q+UCMEVC9mFgLMcxyMVIxyD2NPmSBI6 SI6eCblXWaMZKMBjJ69Dzj612Wk+H7PU9Ja8kvrcAEFkYYAJGcADGOvavOFRre2t3iC7RGAcqCMj Izjp+dFhrt1pF9GPOEkcbhwFPykgg8j+lbxtuT1sa/ik2sF8kcDIu0BQV3DJ7cEk1S0y6Zso4ALD PAxkim6tqs2sau+pCAMc7iFGAvYdOlRWIZ7rcRyAc496bt0FI2FckE9xTfN2ZJApWUovPBNVZmZV BwTnPas5Oyua0YqU0madlEL+WOMODLK4jijB5Yn+Q+tbF/4abSrWSS/Vt45ULIoHtx1P4VwK3d3a XMN9CSPJYEEHBBBzmusi1uXxFpzWzQvPqU0vyuMkgEAYA+uadKC3ZrWqNy5eiM7U5UQJMJg3mRAB FbJHHQ+n0qKBrCLS5DDJ5l3JjJJAC8ZIAI5578UXfhi6soFa+VoS5IUPwcDviq9n4eiOhzX8lyig TGNUJG4gAHIHpzj8K35Wcujeh6zHpznGQMVYXTCeSQKvhlHal8wDrXz3tJM9DkSKi6agIJP6VMll EuDtyak87J4U4FHmsegqXKT6jURwt4x/CKDCnoKiMpxnFRtcEc9KVpPqMseVH/dFMKRgdqrm4Y8A gUmSeS9NRezYLyHOEDZByaiLZ6DNOwuclhSGSNR97JrSKt0uP1G4Y8kcUoBHJ59qY9yoOAaia5yO CBWsYyetjNySZZEwXgjn2oa7zwCMVQaUEk55pock8d6r2fcj2j2Roi9IGABUb3bNkZxVUKxPepVg YkHB9KOSKd2HNJjWkYnGSfxppVicZNW1tTwSPep1gRQCQfyo54x2GoN7mcsDOQQDzU62jHqMVdBR DxgY9qk3qRkA/lS9o3sNU0U47Qg8jmneQFkQFeM4578VYDYYccGlkILKc5wR/OpUm3qPkSWgzylA 4ABNNES7SSORzU8rAHHHPrUMksaAkYBxTje5TStqQSRgOSTwRTcqgPOCD6daZNdgnII6c1VecuPl 6nqK3jGT3MXJLYmkuCDkH2qJZtxJJ7YquXJP48imM5DArxxzW0VYxlK5Y8/ZnrUqTswAB6VUYb4X bBIUZP8AjRayKxXBJA459acoq3mEW76FSdyNRuR3YKf05rynWHEOuahGxAzM2Me5z/WvVdQIGosR gBkBryzxXAYvEt1x94q2PqoP9a0jujJ7tHWfDGAC+v7/ABn7Pb4HsWP+A/WvX9OXZagA4IWvL/ho gHh7U5D/ABSomfbj/GvUoOIMD0rrlojJ7nl/xiutunWkAJ/eSknB64FcRYPi1tGwp2sDhlLDA55A 6/Suj+MMpa+sYccAM34nArmLaQRaZE4DHgjAbBGQR1Haue+jNYxbskiDUpNtrEucZBbg5HPoO309 c1n253RliScHI9qXVLlZ5QUJIAABIAOAMZIHeorBwVKkjk85prYcotOzR2vhC7lMc8CO4DRnIQgY xgg5I45AP4Y71m+N4CNTMxLHcA4LlScEd9vB6Y98VV0Oc2d6H3EjcNpABA/Ot7xpApWGaEKYZYwy kKATx3A4zxzionJKzZ0U8LVqbI46M/KCTjinuFdSpIPHPtVNnIYKSAMYGKYTtGQxLZq1JNXRjVoy pS5ZblyAbGKk8npVhCAyg4zn0qluLYJPI6GnrMRIoJIORz6007szaLcxxdRtjkEV0X/LRcnjtXL3 b4KN1wRXSBiWQjOcDpVolloKGkVScZOMnpVu6CxwglgQoycelYt1IzEDfgD7x7jnqP1qsk8jSSxG ZmTcMZ/u4z+pqb6jtpdkqgsSxHU5p20nORzigSBCBnnOMd6UpKyl3xFHnAZuMnBOPrgUOSQJNkH2 eDzPNaNd4Oc98+tSMgnBzErqATkjIwOT+VPjWNkLwRtMOAZHGFGVJPXuCDn1wfrVK9mjBPm3W984 8qPIAOBzg++B09ahybdkNJIcy2Nu3yqryekS5I4yDn09R2qC4vnjDBQkAPT+JiCvPPTGT06gkelR iKd3eN9lmig58wHcSuFK4wcN1POM889KY0+kWakqr3UwJG+Q4XAYFSAD1wMEEkcmhLuO/Ydaziac vudxtAy5ycgAHn0yOPbFb0AO0H8aw7e9N9KJTEka5IVEACjkk4A4HJJregyYx64rSJMrF1CSAMjm ri8ACqcPJHc1dTOOe1WQTAY4JNI5zjt+lJkA5oIyRmgXUkRcggYz2ycVZhVQoUYLcgkDBBOOOv4d qqg4qVJCABnocjjn86EDLnkI4ZgvOAcjoOvX/I6UssAXJODgjDg8H8Ov54+ppkNwVABYgDqRTnuA WBVQAOvGR+RyKbQXK7psIHQkkDjr+H+fpVZgATjOOOnIqw7qcbcDAI4PXrUBKgljjjkUCK8hCjGO R1NVXOeTU7kk5PU1Xfk8daAInHXPf0qjdnAJFXJOhOfaqF2eD64/KgA0LB1dVIyCOmeTz29a7Caw gnX5kBBHcVw+lD/ieoB0CEj65r01EW4gDFQAQCMduBWVtbml9Dkbvw1aK4uUBjeMhw6HGCO/vVK+ 0aG6uxczQjzCBkgcN7kDFdfPC0Dgg5UnBBHao2jil6rg07sDR0iyRdOiKjaQg4xjNXWU4II6Vnaf KbYeWHLIScZPStPIcZBpoRzPiOES2MyEA5UjGPavILS/lspcqCVz8ye/qPevbdXiDwMMZ4ryO6gE F1IpiXhj1A5GafQEdHpHiuAyJbO4eIjJBGcE8Zx6j0rT1LSmt4RqVkUuLSQZYoSAD6EdQR9a85kj IJdABg5BHBB/Cuj8PeJLmyTZIQYpAVdG5Vx0wR2NEZOMrodk1Zhc2jKUdlClhuGDnANJsE0ZRgCc YI9a0zJDOWgBBU/NEcZYkngH6dKzJI3tLgqykAHBB7Gvaw9RVI6nn1IOL0MG6UW8piYAY5XjtWdI 7uCCMjt7102qWgubfco5GSOK5dgqEgttI7Hg152KounLTY6qM1OOu6K4cxucZA9u9Sh5HJAyR04q RQmQTKPqTT/NgAwZQfxrk6mxCluxY5KqCM9eT+VS+SgIGGY9z0H5U06hBEP3alm9ccVD/aN05JRQ PTjNAMtJFEx+VmjkB4JOQfb2/WhxKjlHGCPbrVaOeSVgJVCt2IGAa10Kz2RUgGSMZBxzjuP60gM+ OVopQyEgg5BBwQa9X8HeKV1OOG01BsyRqFBAGXUdPxrzBIF2EuSCeAAMk/0q1YyyWxDIxR1YMpBw QeMGlJXQ0e1zxQ3MjPGpjUnKAnJ9gawtQusRmIsCQSSQOB7Vk2HioXlkYZmKXAGCQMg+h9qr3d2z sIgQCwycelctZvSPU9DCQSvUl0Nfw2kV3qQRoVdWVg27kZPUkeoHA+oPavRr/VNP0PSJLmw063S4 ROTFEB5Y6AkgZzXA6PJFpekzXbgGRxhD09uvXuf0rFbXbm4mmiDgiQAEEA9+MZ6fXrXRSaitdjjq Nyk33Ll5q8uqgy3kjESHkkDOO+B/jWLqVjNHbQ3SI6xFwFfbgZB7H1rrfCej6VcrJf6zfxBYnIEA bLNjvj0qDx34mtdS8m1s4wlrbgiJAAMn19qLupdvRAlayOV8TXyarqkl4ECZVQQO5CgE/iQT+NYZ U5BAHNSyOXOCc5OTTAMEcf8A6qyS6DerJ0DJFkHBJA4qykv735upqvskeNBEuSWBJ9BWvfJZGxth awSJcKp852fIY9sDAwPzoburdAWj0I9P1S50PVDdWjBXkjMZOAeD1xkcH3prX0sTO0bFS/DYOMj0 qs0UkjggcAZJNLJE524XIB5pqbSshtPck8+SQcsT680nmtCjbSVLEA47iun0+50Cw0eQvZPc30gI BlbCx8EZGCM+vOK5WcMzKVAI3ZI9sUa/ExD2nlMTAMwwuRz0qFGZQX3HIB5HFdLGmhJochC3DahI oA3kBE55xjk5H0rnHjYgqgyScfrRo1dhqX9BtoJZria+nWPyojJEGBPmPwAv6559KoSvK85LEkE5 wTTog0ZJYkggYHvSIHIDODnsO9CnpYPMQMWnJJPBx+AqKOK5u7pAgZ9zhVUdyTgCnoGQFmU5IJx3 zSESxqhXOVOcD360mA+aJra6dZAQ0bYKnsR2qSGWe7lALMzOcAE+tRTbjvzkkjg9Sa0LDT7eeNmm vYoNqkgOrEkjoBgHn61MnroO9ivc2slncGKVdjgDK5HGar5IYY6CnSAhySfb601SD378UmL0Hgkn AP1qRzm0ZMZKyBgB+VRjjk0jFjGShwcVKGtNSXRL6K8d9KdW+0mRnjdmAUKBkrg8kk57/hS31tFF cBFUEEdR0JrC1O1mV1vYQUfqQOCD7VrJdtqNpHemIIWyG2rgbhwcYGB68V0qS5UiGnzXHWtxJbWs 0SMRkgMB1IFXtMJV3cAdh681mcCXJGAwwa0tOdEiKs2DkjNCeliWtTVGWYEnOear3ADNtU5PQUv2 iOJWYyDOMDmoMlyoAJZzxz0FTLVWOmjaN5s3dD0C1u3CyMJVJBIQEnHHHI6knFdg+naX4MtfNWAm 5mIITdnbjpn86Zo8Nv4c0UXk23zyAVB7E9PyH61zmq61Nq8UkpyfKYFSMdc962hBKN3sc0puTbZc 1mR9bt5Li9uY0eNQEQck5zwMCsmTRtRn8PiVYpBaJnacHGe5rqtC8Iz6vp6ajf3LBpfmUHkle2T6 Vu6zrGlWfh97NJFIVPLCdCMd8VtTvKSsroTdiH7cnZTn6Uh1EDPFYhnPYmk80k4ya8FUYnd7Rmw2 pNwBj8qYb9ieorKL57mk8zB4NUqUegvas1GuyerfrTDcqcnOazDJ2zikMp6CqVJCdR7ml9qXHAoN 5joay/NJ4Bpd9P2aF7R9DQN2SetMM+eM81T3E8U4Egg1SikJybJjKSeTTtx6Z61HtBOQBTgCDTES jnjPGKniA4z3qFQSOtWoEJxwKT2Gi7CikDC5J9aurGAAAKrwoyAH0qyGOByK5Kl2zojtoIwBGcdK icgDgipGYAHJqF3B4BGMUoptlXSWoAArkj3pSwwMDn3qu86xghuce9VJtQAGBgVryt7EOSXUvSSB Rk9KqS3q4GD0IOKzpb1mOCeD71WMuWIJ61rClrqZyqu1ka81/nGDxVOW6J4BP0rOeUgDJpglBJz6 VtGCT0MnJstmds5JHXpSeacZFVDKQOoP1pBKCcfpVJEt3LySg8Ekn+VShlzh8jI4I7Gs8SKec8jr T9xIzkkDuasVzShl8p8k9eD70skkYO5VCkdgABWdHcBGG4blPBFNlmyME4A4BxQ1cFKw2/YSXEbg HlSD+B/+vXn3i6PPiJ3HRoEOPcDH9K7yYkRxkkEhiCQa4nxao/tW2bnDQkH8Ca0StZEXu2zo/C99 FoPw/kvrjcElvVHAySAVzgfga6NPiZogtiyJdOAOcRgfzNcP4mItvhlocCAYklaRsdzyf61yFs5N uQCRmum6baMmupq+OfEsPiTVYpYIXjjiUqA5GTk56CptIdBpcjvj5YmCgjuSB/Ik1yNycS55zmtd pzFoQIJ5OD+Nc8ldaHdh5qDUmU7wo7OwA6cYqnan5jjoSaWeYtDGCMDBOfXmtOGxSLR4Zm2iSVz5 eerAdee2OPzojorM0rS55XQtpLsuEJyACK9D8RRxT+F/tL8hCNuPVwCP1P6V5xHOFTaYxkHgnrXR Taw974WW1wS0bKH98E4/mB+FYyV73PeoNypq25yl1DtG5SODn6VEjhjjFXJeVI+vFUIXKuRj9KuD 0seVmVPVSJSwABJzn0NBZyQQpIHIPpUDSkNgjvxipEvFBIkBPYYrRHkFmWTz41AA3Bhn863zcSpG jCMbCuCQQT+I7VzVsQXQ7gAzjnHuK6azSS5jCRQuCTySM5AzyOMgYpt2QkrvQiN2ZQVUAkjr6VZt rCWUbmASMEBpHOACTgZJ6Anv0q0YLLS3Mbr9oucEiGMZUNgEFieoIJ6cjHaqeoXUk8he7YIG4S1i 9CchQBk8EnGfzqOZvRFWtuWYinAs495GC0snQdQRgdexBB9aqvcwCdUj3XlyQuM8gEA9ABzgDv2F Vm8+dCZm+z2wOfLBwzAEgg+hBHcVVn1NLZdlsijAGSBgEgY3Z6kkZzjHWhIDQngbY76hdsCqlRHC 2SAVAUk8jbk4IB7Y4rPm1m1gMiWUCQqwKnBJJBxkEkkkZAIz0rn7u9lnkJd+BnAzwPpUEME1wxSN CzEfgKpiNRdQt31COXUWeW3LEukbckYPfI74rf8AEHh6zlW2vtNCQ20sKsYi4DDjIIBJJyCM9eRW JbaJbwRqZx5kxOcchR+HetQRuVCgk4AAHoBwKTi27ofMkhlhbiNVjUcKOT7963oSQoABB6VTtrYo mOhJ5+tXQMEADGK1VjN6l23ABz3q4mRyOKpwEAAn0q0pBHWmhEoOeRyKBknIpM4/AU8ABQfWn6CQ 4cYzRkYJJxjpSZx2oyaEDHhyM44FIWPrQAAOQRSqu4/eCj1P/wBamIjJ5prEkAE8ZzUzIQCx4z0H UGoDkDBHWgFfchfBPSoGOCST0qduhJ7VWckgk9+lGw/MhkOVAIwaz7kjODn6VoSHAAzWfd8dB1pe QlvcyrO6MHiu0TOEkUqR7kHH6gV6xpTl7VATnAI/I/8A1xXh+qTvba7bTKCShVsDvg5xXsuhTh0w OVOGBz0BH/6qllo15IFlXDCsi/22CGWQsIweWAJCj1OOg963Me1MZARggEGkMwoLlHUSxurIwyCp yCPUGtGC9IQKxyB1NMXSraEuYY1QOSSFGAT64FUri0mgyyHI9KdwNG82ywFgeCK4q/0CW/id4lBk Ukr7jriuhgvs5jkJVsY56GtOw2E7cAE8j3oEeKXMbQOyOCCpIYYxUMTqPk/gPI/wrvfHWg+VML6F AI5OJAB0Pr+NefGMpIFPAPIPvTa7BYvR6hJaAMxLBSNpB5FdSfJ1TTluIgqkAAjnJPr0x/8Aqrjw wkQq4BzweK1vDrXdreFIYnmi2ljgZ2jvn2rehVcGtTOpBSRYiYhmhcDI4571n6hpsUhZiVUgZGQO fbNb+o2gdVuYSuTyFB5H1HaqmFubfBGSOD7V61SEa9M4oSdORxM9qkTFWUeoIPUVUMKhgccHrXQ3 1i5lwAQqjHr756e9UZLNljLFGAJwCAOehPFeHODg2megpKSTRmuFUZAH4VLGNwzmnSwFQDg8+1Oh gbdkggelZ6sYzADZOSBjFaFjLsnAP8Q5zU1vpclzGxjXO0ZP+friqsYInTnBAweO4odxqzZtppjS RiVyBACMsGHAJAzjOe9Q3Fsbad4mBBXjJHX3pzXspsGtowSWIJx6Ag/0FW70m60y3u8EOP3T49R0 P4jFTG/UrToN0S3Zp2l4KgZPPQggf1rQLl72RucAhfpVXQ8K0oJIBwQD6k//AFquWiF7uQHGPNIr nmr1Dug+XDNF3UNTV7SOIHAUAYHYYrnrmbZu8obnIAUYJJJ9BU95E3mOecAkfSlsdWt7SKNtubqO Tcj4wQc9SfbjFaNOMbI4003djpLO60WOMXqvHcyqJPLY4KqemR2J64NQBJbg7jnnufSkuL2XV9Zk luXZ3YlmJOc4rSQKFAAHHT0rOUmlZmiV9inHaHOCOPWnGyB7gZ5q4CSOuPQUc4/lWTmxqJb8PjTb G7kfU7J7xCuEQSlApz1OBk8V0LX3hR8htEuFHqt0f6iuUXI4qTkkDk1Sr2VmiuS+pvs/hNyALC/Q A9pwf5inEeET9231FfYSKf6VgFCRkHBqLe0RIYdOQapVU3sJwfQ35R4X8v5IdQ3Y7yL/AIUyGLwv 5YMkeoBs9Ay4/lWF55cAgY70wykcZNPnbIatudF5Hhhjw+oqD/unFILTwtk/vdRx2+Vc/wA65vz8 HAJ96DcAdCaV2Gmx0f2TwwWyLjUB7FFP9aGsvDJHF1qGT/0yX/Gub88nuR6U4SMR9407vcL9DoGs PDrHK316MesKn/2aopbLQRjbe3ZOephXj/x6sZXI6kmh5iOBilzaiN9dM8OkAtqVyTjn/Rx1/wC+ 6jlsdAjjYpqN0xAOALcf/F1zzztkjpURkY9yaFpqNsknCmQhCSvYkYJ/DJpgUDpxTd5HU96Aw6Gh 6u6ES8HjNKBxkVGCMg4z9KeACOtJgyWWJbnTnUj54zuHqR3FP0LY2mahYyyIiREXEZcgEk8ED6jn io4ZDFICMkNwR6g1lXMkkc7xIpAViA3qM9DThvqD2LjqSBgdDxTlyAQc9c1LZQNKmSMnA5PrROjR HJBAJOPet46szexQllzdAg4AGSK2dHuyJopZfmEZBAPQYOQPzrm5nzcSAHkcVp27FIhj0FKafNc0 uuSx2N/rMuqvBaiXLswUDOBknA/nWdrRGiz/AGRX3OAAxVsgt3PFclNcyJOrFiMEEYNalpq9pBc/ aGhSZwuAsuSAfXGeauU3axnFK53Wk/Eaaw0H7DMqs6jEbE8genvXJahqU17cNLI5IY5xmsUym7u2 lwFGcgAYFWMnGM1f1hxhyxVh8quembyOBRvNVvM5zmlD57mvOtqa3J9/fJ60B/QmoQcnGaN3HJpp BdEpfHrQD2qPOR1p4x1709gHgjI7U7gcA0wAkA4xUqgDvmpbSBIcvPanqPXtSAA9CM09R1FTctRH jA4p6DJ6GmhM4wetWYoGYjB5+lJzsUo3dh8UZJAJIq9BFgA4NEVoBgs2PapyyxLyRgetYTq30RtG mluOyVHGfxqKS4VB8xGRWfdaqqEhT2xxWVNfmQ8k04QlLVilOMdEbE2oqAccn61Qk1FjyCRWU8pI JJ+nNQtIScAn8a6Y00jBzbNGS8Y5JYkmq7Tk9TzVQuQeppu8jgEmr5bENll5BnBJPpzSpIC4zVVn JGRxTVkIYEHPNUkS2XHIBJzwTjFRM4A6n8qa0yhiWAPSo2lVzgH26U7IL9CwGOCeoIxmowyjgk5z UG8g4ycGhnUtkDA6etUkSmWFfHII/wAakWQkYJBAqqpGMA/Snocjpz7U1cbsTs4wMcHpUUkz8YGS OAcUpGFznqcH2piuCVQk89OKd7bk2b2Emkd4VPBKsM8dulcz4yTAsZiecsufpg/1rpGQmKQgHCjJ yenNY/i1430q3dlyI5MDA9R/9arvsxdSPUozqnwqtXT5m0+4ZX46Ak/0IrjbPiIgjtXdeCryzvRe aE+5Yr6EgBiCAwHJH16/hXFtbSWF7PaSjDwuUYe4OK1trch9jKugTOQBmtOeMDw4uOu7p+NVGnFt dF/KWQkEYYZH1rSnuWXQTOEUMWyQQCByO1RJaFqTtYxIraSeEl2KiMAAYzkk1e/su+IiVSzxIcgg Hv8A/qqGHWWNjcRlFMjlcOBggA5OK0YvE+owyCO3nZY8Aqm4lVyQcDJPGcflTVtmOU29ipJZXSyE mF8dQQKv6ajIlzFMjAPGcEkgAjp+uPyqV/Geq2TAnyX6El41bp7Ee9LbeMbm7YKbO3Y9MeSOmMZy B9Kn2XNsd1LMJ0klbQzzDIWKhGJ7YBrNZQsrDawOSCCCOK7SXWriIAyaJbsGGQVUgnPPQEH/APWa qT+J7COUJcaNGjEAkBmBwc+5+laPDSgrtaGFfMlX904+QqWIBBPpQbd/3eFJL9Bjk12x1PSXKiTS mO4dElx268g/Wr8GmWtwDqE8ZtrONf3aFgznIJGOBkZBzjpms3ojnWu5i6F4ae4HnTFY4owGeRz8 sYyASeecZHSta4vUQG30xWRFHz3BOWYgEEg44Ug9D+Jpmo6hJf4UgW+nQ5ZY15A4AJHGTnAz/Ksd nN1a7mYwWgyF28M2QQGBxyAQMjP+NSrsq6Ww7e8shhtSoVCBLMQCFySAepyPcDj24qGbVLOwg8iC FZJj96V8M2cDIBI4GRkYGRk1YhB1UGNbiGztkzgOSMk8kAAHqSTjpzUz+B4ZSXTVrRyD/wA9QM84 7gfX6VajoQ3qc8dQSWQmaZSTzgnj/wCvRc3dvIoVZYwCOuelWb/wVOitJ9phKIuSRIpOOe2cnpVO x0mKB9zjew6EjgUcut2CfYSDSxNh2PynnOOv0rWt7eK2UKi4z1Pc04DaucZAFWIUMmCBx2NNKwmw WIsxY8sfXtVyG22gE8nOTUsUAUjI5q0EBGMcVSXUlsiVMckdBTth3E4qYJ2NSeVgDgU9gGx5AFWl IHFQBSDwKlTJ6800K5OCSMA85445pzEZAzwBUW4gggfrTuTz1P60WC4/PHcmnAHOSOlMXBGf/wBV OJwOefwoSDcd9efpUi5AyAQAMnuKhBJIwCSOaczgrjA9M8//AKqfUQSPuwOMDgAVG44yBzQSccGm s3GO/wDKlYEyCUgDFVyDkYNTSHng1ETxyKq4EMnLGs+6yCf8KvOTnPrVG74JANSwOT1baNXXcOAg GfSvTvCV0JLO2bdkmMofcj/9VeZ6mQdUwcH5RkYrsfBNz5UWwkkRyhgCex7foai+ti7dT00HIBBy KCDSR4MYwcgcD8OKdg5oKGEY5xTWQNwQCKkxg4ppAHBH40xGZeaYk3zIArdciq1u8ltIElBAB4Pp W0RzUUkCuu1lGDQAtzbxarYSWsoB3qR9D2NeKatYSWV7NayAh4mIye/pXtUKGErtOdp4+lcf8Q9J VxHq0IAOAkgA6+hpi8zzYSlSGxyOorvPA08B1m2hKDdKGBOeo2k4x+FcBKQkhAzzzXSeBbgt4s00 A8b2B/75NLYPM6PXymja5cWSAeXKAwzyADnisGZDBKJk5jY847Gtj4kceIAQcZhU59CCcVzml6nH cxtbyn5hwQf516+CrRtys469N35kXnQECVADxyMdR6Vn3CQM0eNqkAgrwf5j17//AFqvpm1nCOcx typ9aranZMVMsJxkc47itMVhlNc0dyaNTldnsZbQxFnDMCQBt9+QMfkSamjt4wOACccVms7gnJOR wKkWcr3zXjNcrsztNQ3P2FVKBSWBUjHHIxmq8UajLxhGYckECqFzM8qICQQCfrzXYeDtXstKkM13 EzrtAwoBI4I7ketS9WMi0O0vL3UzDaIWkkhUSAKOAWB49Og5rpG8LXZiuIDCwBXcBjqQRVCa4utJ 1iPW9OR1trsKVHQEA5INelJ4i/trRb6QNbIRbM22NTujJBABPc8UnD3ik1Y8YuoJtMlRJgVcyr19 ADmr9oqrNcHPIZXA9QRg/wAqz9Zlne+RLjIkjBZs9ck8fy/Wp7GdWaGUng/u3z2z0P54rCrFxkpM 7KUuem4LcmvEG+QDofmH0PNcpcWxN6WJIUHpXW3WUyCMleDjuKw7qIo5OOD+PFaJ3Ry2s9SCxITV ASRgqQPx/wD1VvBSCCelcwpf7QrKCGU5B9a6S3mM8QYY6YIPUGuWrF3uawkloyTJJ6ZpQOM45pcA dvypwA7YrBo1TT2E49OtPUkcZoAGOQaQj0P4VO41oO3A8HpTZZU2lSecelN5HP8AOq9wjY3Dp3ql qx37EbSkHAI/KkYkjrxUQyMY65pSTxk/WuhKyOeTd9RxPHXOabnnpSHJPWkOcdaaVyb22H575pd5 zjPaowTjk/SgHHX8aXmIlEh9cUb8k5Pao8Z4zx9aXGRgUadSlqB//VSAYPSlAPAJpQOOPWjoJN3I 3AIGOPWk6HBNKx5wD0poySRjg01a2o3sSKwyACT7VMDyAO9VirA9D+FPLsgBKkk9Bjk0muwK4txO sIBAyw5AqO3gknILgl2OT+NW7Gwa5mLyKWHUg9APf0FdfoWgNfzmUxERRkA54yT0A/KrhG+pMnZW KEVgltYoCTvI3H056D61hahMGcJuyqDA9u9dn40ki0jTSpI85xgc4ryd5Z5SWMzcnnmulQ5UmZ30 EMhN3IeDzmtmNsxgkdgeKwY4ikoJJIPBJ9a3bclrcE9Rwayn8WppFXiUr1SG469jVHYUDEsST0Fa 9zEXTcBkjis0xFpM85HWnq1oTbU0rTAt0IHOMGrWDziq9gR5bRnsamcmI4JPXrWLvctLud8DinZx Rgdjim4OcnJrMoeHPAOaVXJOO1MwcClBIOBQFiZCc4qUcHnFQx8damUjHOazbKSJFGetSgDFRBh6 08OM8GobuWkiUADnipFAJI65qANuPFTJLFDy55+tS7lIuQQFyD2q8Hit1yxAwKwp9ZVBtj4GOtZU +pvICSx/Op9lOe+xTqRjtudLc62kRITBNY9zrEkpIDfrWJJdE5y2c1F5oJJzXRDDxiYyrSehoSXL Ekk5J9Kj88k4JIqoJATkHOadvPUEVso2M7tltpTjJPFJ52RggVW35HB496bnPHWhLUCx5oPSmNKS eSMVHkLjPFMbGcnFAWJ95PU/SgsCeCRUGSBnIp2856VSsK2pOSAeScdaaXPGAKiZyVB/Dim7896X ULFjcDgk9qVSCcEk1XDc+tLk9RVITVtSyrFCM8g1Mkik5yR7VUWQ4wRmlEgDdRmqBGgVBg3g9acZ YQiMIVDqMFhnJ9yM4zVeKXIKk8EZNQtICCASMmlo9GK9noWi6OkqqN2UJzg5GBXOeIgZvDzsByro Tx25Gf1rYtXKzqACd2VIz1zxWdqSF/D15GRkhQfyYH+Qqumgm9TjdHv20zVILteTE4cAd8dvxrq/ HlnGNXh1GBR5N9CJAR0LADP6YNc74dhsZ9dggv8A/VPlRnpuI4z/AJ64r2GbwxYanpVnYzysYrUf u2U/NjGMZ57cVte8US1qeGx6dc6jepBaxl5WyFAIGcDPU8dqtajbT2WiSwXMbJMjYZGHIORXudh4 a03SIibG0USY/wBY4yx/E/0ryXx5HNHc36zsGfcpGBjAIGBUSlZ2Gkjz6MEMCOoPSr8BJlLADPU8 dKqWwXzVycAHPNacaIJAyHIxz7USY4oddYa2bI5xxxVfRZWTVoVYgqx2kEDGSMD9cVcKB4mA78Yr JUtBOGBIZWBB9CD1rbDTSkjKvHmi0d9gAYA7dq5/xDatLLbuilmbMZx6jkfzNbiTK8YZSArKGHrg jNWdNsDqUjXLMEtICGaQgdMgEj15IH4162LqRVGzPHwlKXtrrZDNG0mJLQXuokrDGowoIDSNg4xn qMjBpL/URdhppf3dlGSIokyAeSQB1x1qe+uxftgMI7KDgIDgDnOOvBJJ5rJaRZSL65VVhjJWG3de vAILAjBBBOCO459/A3PebuRXbtOBNdqYoEyEgAIJIyCSM8HOD0wRVNLgXs5echVBJVAMD6/nUbzS Xc7tKDsQAAHnJ7f59qke3zEHUgnocVfJdbk81mWTfwpJsIBAAGRyPpVO7uR9tHlEFSAcDoT0NQ/Z GdgFIHPc8D3q081vNDDGsBSSIcsf4vfNTCm4vcpzTRLAQUZCAc96ekeMKO571FHhTnPUVYQFm2gn J4OD2rW5mh8cQkYADj69a1I4gCMDAwKjt4NoGBj8KvRpkAjtTSE32ECZGMfWpUXPTpTlTJwBxUyo B1NMVyJUyehx1qULkUo9B607GRkdutAehEUz0NOAwcY6U/APHFGMfyosFxAOOmaeAQOeBSDB7U7u BimDYnQdeKXINBOOD+tISR/+qktRD1JGSD0ppOQPU9qTORigcgnJp+oCZJGT60xzxyaccY4xgc1G 3c0eYELnPWoyMA57VI2ckZqOTgYwKNOg7EDDnJGKoXZGMZ71ffhSfyrOujg4HOTSbEjktUbOqPg8 gAD8hXQeErkrfOucbl5Ge4PH9a56+JfXJ1AzkgAY9hV7SpGtdUt2YFfmAOehB4/rWb3NN0e4WL74 AQeoB/MDP65q17Vk6JKXtEz2BH5HP9RWt25pgIRg4zmkxxinHPYU3n1oGMwRwTSbex5p5z+NJngH GaYhFGTz3qpqFouoaddWTgHcpAz2JHB/OrvqRUbRyfaN6Y2kYbPce1AWPA7yMxSOjgBo2KnPUEHB rW+H5LeNLBSRgMx/8cak8Y2v2TxJdqVKiRi4GMZz/wDXpfh8QPHNpngbXI/75NOWwG/8SnJ8RYHX yFGPxNefIXRhKhIcEkEen+FejfEq2DTpeIMlWMT47cAj+v5V54YyigE59Miqu42aJtc6HTtTiv4f JmOHA79QfUVowSmNjBOQVPRuxFcYY2jIljYq454H5Vuafq0dzGIbjCuO57e4r1MNi1JcstzkqUWt UQa1FFDdkRAnP3iOgrMyM5JBFXVuUu52ihTDhiBITwRnqR6+1asnhxFtVaFgzAZJA6muWVGdacpR WhqpxpxSZgKhaMkc85xViG5810gUEuxAAHrRLbS2wKupHbimaayx34mIxsUnp3wa5JwlB+8jeMk9 jYn8SXMmiQ6MwQJbOzKwHzEk8gnrgZ4rsfBVzLB4P16+RgWVVVQwBBI7HPb5hXl0DmWZwGBO48Y5 Hvnpiuk0zWpbTSbnTVXELsZJTnqBtOOnqo/Opvdq49OhW1a9mvtUuLhmQsSASEABIAzgDAHOegpm mT4aSOU/KxwewB7VVTJBLckkk/UnNLGjOxVSB3PPalUSlHUqlOUZpo6QSNKuHP7xQAfcdj+NRPbB o8FTtJ4Pp7VDauQiIWIdeFYjt6H2rWt5lWB9yAkghkJ5B9R7VyQnrY6qtO6547GLBYkXoRYwykkA FsAn0z2qxKbWzkZXM0JPJQASYPfnIz+Vdn4dlu2YWNnE4EgwgQAsWxliMn9TwOKs+I/DupWOl/aL ySUqSAyFQVyfcH+grayluc8exwgLTRGWymWYKCWQjDKB3Iz0+hNNtrwyPsZdknpnINFtaxx3kd1b SGMq2SACVODyDgg4+lSXls0twZ4kQZJP7sbc++CePoDUOmndIfM0y2DkcjFJwTwQapCaWIDeCB7g j+dSLdADDDB+lYuhLc0VVdSwQR1FNYAqQRwaQTxnjOD9adlG6MKz5Gi1NGfIhRumQe9N4IwOtaWx WGDg1ExggBJxx3NaRu9LESs9UU8E9QabggjAOKmkv0QAlCAeMlTj88Uq3aum8Llc9ccfnWqhPsZX RXJwewx7UYByRVkPDMdrAAnpSNaMclSMH1qG2tGirJrRlckZAApc4Gc1P9kYYJIFH2Y45cACnfuB FkH1pMADvzU4hjXq2aC8KDgZNCTeyFdLVlRyRyQST6UsZIGSMZ9qdcuyLu8puRxkEcV13g/wq/ia wmu47iO1jgIVgWO5zjOSTnA/SrUH1BNdDkklLyiNASxOAAO9dBbaA/lrJezQwKckKWDOR7KMnn3x Tdb0SLQNR8oXSTMxAUxMGwScYOAOfau08O+FGeWN7mNw4wSHHI/Dt9TVKMb6kyuhuheGWvtsccRj twQSXAy3ux/kBXcS2dnomlu7BUjiBJ9Scdz3JrRt0tNOgVC8cSgZALYH156n3ry/4j+KPtMv2K2m zCg5weCe5+ldNKm29tEZNrqcB4w1h9Z1Z3ZiUBwo7AdqwIo1d9rMFGOuM0SzCS4diCQeB71GeSee v6U5yuwt0FkUBiAQQOAau2cq52seowaoYOMZ/I809HKENngdaxnG6ujWnKzszZUZyuO35iq95aBA HXgnmrFnKsqZJyQOD61egtorgBnJYlsKvasoysypQaepmRm3CIQWRx1JOQfehrpCSuQwHGQODXWt 4Qujbq7WgQMu5SQTkevSuVu7BIpihwrA44NNxT1YWdju95J4p6knr1qIEDvTwCRmuYpJkh55BNKo IOcZpoOKdv460nfoWl3JB+FO34+tV2kOcCmNKB1PNTZsd0XPM9DzR5yqMs2KznueSAcCq73BOcmq VNvclzSNR7/AwuBVKW7Zjkk1TeU44P61CZCRjNaRppMlzZYeck9aiMpOeTUWSe+c0hYjnFaWtsZt 3JCwxxRv4wKh3+1IHyMZotcZYDjIzn86lBzgZPFVAxAz26VIrkcnk+1GwJljeAPSkDgHg+9VmnA4 J4pnnZOfwqfUd9C4ZuOT+dIZTgHAqsHBPJOKQsScetO1wvpYsNL0INAlPY1XBJOSM04Ec0mguWRJ mPGOhyabuBPsabGTtY+gyKYSScY60WYE+4kEZwKUEnjNQgseM04E9M1SEycFgMAHB4pBkjAB4PNJ GxwFzjHqKVtwPBz/AFppASrIBjBJz+tKzqV4GKhGGIJAGKf5e7ODwOpNPzYtxYpAkisCcgg+1Nug Hsr5ADysgA+oJFKYioGMEEZBHSpTEDcvE3IkUH65GKe6FqtzgdIQP4gsVA6yqfyOf6V9BWICwxgD sK8N0KJTq1icDcsxB46AAivcrQ/uE46AVtH4SZbmkQDHXiHxMiZ9avljUk7Izgdfugn9M17YTlK8 v8RRLL492MMhvLBB7grzUTCO54shbAJzgVctHb5iD1GK19S0ePT9XubcqQqudoPYHkVElvGCcLj3 FZ86aLUXuERBXOMkcmsy5UeezgHA6r3NbMMOxjjkEipBp6Sy7AhZ5GCgDkkmqjOzTQON1Zk/huO6 v1NrCpjjkH7xieSg5I5x2Hrziuo1W7j8pdJ04hYIiS7DOGOMFsdQCADwafc2y+HtMWwgH+lSgGU4 Awf7oGOoORnPIPasKe5a33WlsA08i5d8keWM8n1BHHOSOaqpVlVsm9jOEIw+FEN1OJwYIWItIsl3 BB3MOwOfmGSpI6gVlX0jzxhgdkeQEQDAx7ewqK81JIJI7KIF41bLAk8k4yepwTgA49BV9h9rjV2X ao5APXj+lTZ6Ip7aEQG2CNCMkDJPqac8UtlYpcxzpMm4hoWJyOOvTofY9vpS4BJx3pUU5AHIP61t yqxCb1GW7Ga0EyAgkEEAZ+tJHHkZI5JJ+grQina3Z4YkTEihSSOR9KruACQAcE4z7DijQPIYB3HY 4Ax1960bG3P3iOT1OKgtIGlYEjIArbgiCDAGKEgb0sOSMgYNTonHI4705U4zUoUbTx0pkjQMDPH4 UvHQ8UoHXJ/SjaQeR1osAYyOtOAAHIpM8Ag804ZJwBkntRfoAmAT9aCCOlLkYzg0ZyMmgABA5zSk kjJphzzignHGcUIbsLkHIPNLkY5FMzSE+hxTshdBxIJ4HFKT3HamDOMnrS5z0PA9aAW4Me4GKiJP Wlbp1/rTGJA60B1EJzmoZDmpOe3U1FISTSY0mQPwD0rNuidwBPPatCQ8Gs24GZQOeKHtqCucfdTB NfmbGcMR+mK7PT7CxvdIE6K7XLDgk8KQf/rfrWZbW/h65kl+2SyR3O85IwQTk9sgjj69K2bbTrSC zkSx1WEo5J2yAg9MEdCOfr2NZ2b1RpstTsfDFwXg2nrwSPTI5/XFdKM9jXE+Fy9pcLBLIrkqQWRg Qccg5H0rthzyKq2okwPTJqLeC2ACQO9JdTpa20k7k7Y1LHA5wK4tfHsgkKnSnI3HB83Bx2yNp5/G i3ULncHB5HekAxwKy7PX7G5tUlaYRlhykhwwPTBFTHWNOHBu4/TrmiwrovqMnAFTqMqFHQc1kDxB piKQboH3EbH+QpreJ7JhiCO4mIHSOI8/ninbyC9jN8e6HDq+mG4jCrdQKWBwMsADxx0/xryvwrci y8T2d07AKkgUnPYgg/zr1LUtTu7u2kS30y8bcpALR4HTPXmvPLbwffxSkzqiknOS20569zQ9rAdh 4qiV750mYC2vY1UOTxHIpJVvYc4Psa86uYHtp3imVlkB2kdOc/qK9Dke6l0tLK9WykCrt3vcKScD IOAevv61jz6ZbMgjudStGwMK2WZlAHABA5Hbn09qetkhq3U5y0hV1ZJAWyAAADjj+tQ31qmJDEpD k/KR1Nb62Ok2j7hq5BBJBRSBnA55I70+5bSWhZ5r27mQfxGMAHpjJBPc/wAvWpSdxXRzejXMNnPJ DdIAXOCSP09q6aGSWAeZbOZIzyU6kD+orOnuPCwXC21wzDOCX/LgD6/n7VQTXbe0uAIVdYc4GSSQ Mn1r0sJiVH3JHNWpc3vI6cPZaim11COeDnoay7zw88ZeSAj5h1HIIqyhttRjEsMgRyMgjoaEu72w bDAsmcZAyPyr0ZUqdVa6nKpyg9Dl47C4s55WlQgYGCO9M1C8azt1hiJEshDOR2APA/r+Vdol3Y3o IlUKx4yv9RVO98MWt6fMhdWPqpwenpXBVy/W8TphiekjjP7TuJVXJUP6gYJ/pV7TNUitpybhPM3K V5OMHsatXHhi4tnyg3Y5AIPWsu406cKxaBgwPUdK4KmGmlZo6I1ot3W50Uc6PH5wYBBySTwPrVyC /gvICYZlMicYB5OO+PSuGSO5cCFA7LnO0ZwDXS+EvB2p65qkccK+XErZklYnavGQCR3OOlcU6Fld 6WOylieXTdM2bTUb7TNViuYonkEYBUqT8v0x0rpvE/iSPXbAGJrr7WBiUOwKHjkgAcHkVuS+BLmG 0RoniZ0HLk4GO+ciqUPhS5nVtoimOclIXUg46EgHn8acZuJLabuih4R0fSZdFC6gbtLh3LCSNAyh e3HX16VqT+ClmUHTb+3u89FWQK5H+62P51jyT63pJeKa1uIoQxwJIyU/AEYH4YqSHxMm7E8CsemU OMfgwP6EUuWSdyuS+zK93oGo2LFZbeWMjqHUj9en61lyWrhSWt1YDOSFx+orsrLxXAh2rdXMK9gc kfl8wP4gVdfVbO74YabcOQcF41Vv/HSCfyrSDZnKFtzyW7uTA5BIAPoc4pkMryKGSZVAPJKsc/rj 8hXQa5ZSSXhdLWNxuyQhPAz6NXNXF5JhrZUYBWI4B456Y6VvKF0nYwT1auXpbto1OHjJxwASav8A h6AX2r2kTXixmViJZCAfLX0GRgE+vvUzaJpotFdbkPIVBKCJlIOO5LEflVK3sp7ecPASu3IBGc4r T2E5x92JKqRi/eZ0viLwrpulLcG01RJ2BwylgxOeecDFcZGpJYROUQgqR159PpXQ3T3N7pkNlOqf unZvMCgOc9iRyQOwNUoNNSAks4IJyQT1q44Gq9WE8TT2Rm+RLEFKgSAHgZwR7g+lTfabngCE/i1a TQwDOHAxz1qP/RwcFwR1rdYCb+Kxi8SlsigZrog8IuPXJpFMzfediewRcfzzV4y2oPUE0nn2wPUD 3p/2f5oPrHkRpZyk5+zuw7GR8D+laNppV7PtEXloD08qMk/nj+Zqj9ogI+9096mTUGClUncKeCAx waTy+VtJIPrOuxtTeF1MJE90fOAyQXDN9MAn+dYem63d+HL8wKcQh8lXHDAdMirFtq9xbKVhunQH kgHrVO6C3jF5GUsTnJFR9Qmuty1iYou39+3ifU1mt4BCu8A+UhC7uwGehNelN4si8M2LafcW6C8j UAeW4KAkcEnnJrznQtUbQfNeCKFpZEKrI6hioPXAPAPvis68eW7lMruxJOTnnNTHBzTcpIqWIg0i 9qnie/1G7eZ7l2JPBzgfhXN6jqQDhZZCNx5bqcVZlgcDK9fesC706+nlLFAQDxg8YpShVStayCM4 N3uXlFnKAUu0BHTOR/OlaFQQFljb6MKxG0+7QEGJs+3OKia3ukJBjcfga5nTmt0aqUDeMTjkISPU DIpjo205BB5rB33EfBLgj0JFSLe3SjAkf2yc1Li1uO8ehv2MhRQrHGTxn1rRS9ngVXTJ2nGe4+lc 1pplv9Tt7d2wJHClsdAT1r1+38FQfYVWF2aQAHc3Q1hJWldm3tU48pZtviI99ZCGS4e38qEKu1Ac kADk++K88u3mu9VaRiSCSS3qM11sHhl5Ll0MSl1OCAcc+tU9b0C40SMSlVKuc5HOPaqbTVluJdjX BB6c04OR3qvuwetKrmuZoZY3kjg0BsdahL4GCRimPKACM0krjvYmeUAEZHFVpJic81C8uT14NQs5 ycE/nVxjYhyZI0x9aYZST65qIsT0yBTc471aVibtku49xzTc5xx+FNBHrmgEYznmmAo3E9DilyT3 IpA2ADnPNAc56ij0AUg4JNIAOuKkDZHIBpNxHBXj6Un2BIidzjANOVyRjPSkDqp5XOeKYzhHOF4P IpW0DoDEBhkdKVDkE4wBUZYs3Iye1SICOCBQkrDTHh16HtS7wR1x6VGQAcEU0kgcjin6gThsd6eG UgcnNVwwJGATUyqTzkAUCJYjlsEdRimkDOT9KSMkOASeKVuCSD3o8xjl4POafgYBB5xUAYg5B608 SEcE8fSmkF7EiNg5PUVZJDYwB06VVQliQRin7ihxjIqgJCQByMEVbtJoUJS4i8yNhggHBB7EHtzz VIyBlwcce1IrkMNpHAo33EX5mgUBYQ20d3OTUF9cR2lxA88qIGiBBY4HBqJSWHIyQfWsnxhG72Vi 4bADMP0GP60JWQr3epn6XdxrqMFypBHnknsACcfyr260lD2qMOhANeEW1tFBbI7yhe4A5Oa9p8Pz rc6TBKpBDIDn14raPwkyN5XJT8K831oH/hYkRB5Ji/Ra9EQ/Jj8K4DWUP/CfwkDjMX8jUvcEcz4z 0qcau96kTGIoCxHY8jJ9uP0rl1xkZr2HVI1E22UBo5UKkHnPf/GvIdSRbS8uYwTiNyB9M8VzuNn5 G0Ly0RBNepaAEgs54AH86m0zxDNaaiLoW8UhUEKGzhcgjI98GsJ9zuXckk9vQelTWrIrszkBVBOM 9faqWmx208PH7R151xJ2mu7iQmcDcEcjJJ6Hnryecc1h6jfmxtZZW2Ge6AYAHO0EkhQck45GQehA 9KwpbmR5jKWIOcj2pbmWXU7kPKS8hIAOep7k/U1at1OWvBRfu7EukWUt9eBicFmBZz0GT3PYV1Rt 3WDcQNoJUAHIIHXHtSWFmtlaxwQrumbAOOrMeKt3Lr5/kx4McQCAjuR1P4kk/jTi+ZmEtEU4LOaC 0mvVSGeNDho3YgjIOCACCcdTg+mRiq1lcrcFiFKsDjGc1adGVyASAfSkEgspY5IUUODk5HB+ta2t qZXvoEKkNNMwIMYwoPdjwP6n8KEjLkLjOKtXbOYIQ6qrykzNj34X9AT+NT2VvyGIOTQhu6JrSARo OOavqoPaiOPGAR0qQAjng00rC3HAADg8Yp2B2ORTe4zxx60pPTFG4h+3Jz+PFLkAlSCB2J5xSDJH JyKCQCOnFIew3GDgg0Yz2pWIIwDgjpURcg4NPqGxKAAcmgtgYFQ+ac9aN3rRbXULkhPvSde1MJyB zSg9vyppAO6dcflSEdx0pN4AoyRjnrQIewAA5zx27U3kjPY8ZzSZ44NBPYHrQA1vQ8/hTCePennG OvSmEDPWgBrEAZ7VAx4OanbpgVXc8H2oGQyEjrzxWTNKBcA5GF5OenFakp+U57CsC9cLDO+eiMf0 pAt9DipJGluHYgncxJx9c1oWsLod6u3GOAfWqEaAiRyRgDoTyc+laNiXlkSJAWLAAADJNZtu+hqt Vqdt4NvWS72yMTskVjk5OCcH+VetRliozgfQ15NpeiXVgRdyMD5hPmKP4ckEY/Hj8a9SsJTNZRSZ zuUH8SBn9c07E6Cahatd2UkCyGNmGA47HOR+FcsNI8QpOY91i0ZJO8qOec8gqTn8a7M4ppB7AU7s GjnBo2pFQBdWgJHa1U989cUo8PamQANQgXAx8tsvHOf6108cZyMgZ/lT3ZYlIJ5xQmxHLjQL6EZO rsuDn5ItvTPfPvWNqoayO1tWunYjpuAAA79OmK2fEOvxWEexSGmbhUB5J9fpXmGv6rKCIi5NxIQ0 jA9B2A9Kd2tbhYo6zrGs210ykzpEDhWkBywHfJrHfXdSYEG6cZ9OK7jQN17ZgSatA0h+9bzJuUrn uex4/CoNd8IedqYeCzWC0YA+ZEcgnAzxkjOc4wBU876jSRw/9o3kjBWuZME4yWPStG1e9tJSwuAC DghlD/oQRSXOjRJMREz7QcfNgE0+6SWIx4ic7lGCRgEgDv36ilza7j5XYkurl7uUSTbS6rgbECjH PYADvST3ks4DTzvJjpvYnH51ALa6ZCzFE6cFuevoKaLTAJkbOPyqrti5bbiNPECMEHmkMkDgggHt 0PFKwijj3BCAMDIFQyXYQ4WMjuDjFK4iWC7lsJN0Dkr3U9K6jTPEUN2gjmHPQg9R+NcS91KzZHAP tWpp0AexZyMMzHn6V10MXOl5oynRjPU7F9Otbtd0Em1uuAcHNU3t9SsmzGfMUdjwfzrnG1C70sqQ xdCcAE1uaZ4pa5IRkZiByCMgfjXq08XTmt7M5JUZR03LkevzxYW5iYDuHXI/MVZj1TTrkEPEuc87 T0/ClF/Y3BIliAPfBpr2WmT8qVBPqK2XveZnturErQabNgqQCfUV1ngNBa6tJFDL+6ZCxQHgngAk euK40aVAPuTkfRjXW+AbB4tZklLllEYA/E//AFq5MZCKpNtG+Hbc7HqtxEX02ZFGWZCB9SMVzfg/ RbjTtSmaaFQCpw+BnORxwTWrrmomw0iWZWCsMBSRnBJHbvUHhTUri/t5riaUPlsAgED3xya+eeiR 6VtB3jdwmiSoDgyAqPx4/rXjxskBIJX8TXefEy9llNvaQtggbmP16V5qbS6JyZwPwr2sFQi4c0lc 4a9RqVkzVSKKNQTNCv4AmmtPbIMtcsSOgUVm/wBnsR+8uf1pPsVog3NNuPpk13xowT0RzupNqzZc fULJc5Lt65NV/wCz7W7Rr9LiNArZ8tickgA89uegqBzZRcjB4rE1bUFimUQEhdvQHvmssTCKhcuk 22b8msuq4SDAHAwmazrnxJOgIMUo/wCAkCrVvq9oYlDKpOOfm6VYNxZTDhRz2PNaQ96K5XYzejd0 c+2vXkpwkLkkdzUtteXsr4eFm77QDx+IrSktrZjlcAjuKbAwhlwSBk4B7GuXERxEU3F6G1OVNu1t RqrdPx9hwD6kn+tO2XIYj7HGCBzwSR+bVtK7EDco6dqa8CMQ5Qbs9QK8h16n2pHYox6I5+SW55Qx FT/sxKOPrgmqk0QQ5fzM9ep/pXVlFcZZccccVSuo4grAKCT3IqFiZ3s2aezi1dHNqYiwUNIPTk1M luzZCNIAOvNUNWZoJ0MZ2kHIINb2kwyz2pkLAkgEjaP8RWjr1OjI5I7WM64LWq7nmdQTgZGarf2q q5xOD/wE1Hrt201x9nCgbTjPc1BbaRJLHliVIOQCMgirjiai3ZLpwfQsHxAUPALD8qmTxGpILKwH 51nzaJcggquQfQ1n3VtJbOEcEEc4raONqozdCDdjqE8QQEAMxGfapk1i3J4defeuKUOSAoJ+lW4r K6cgrG3PTIxWix81urk/Vo9DrhqMDjGVOfcVJ9ogbAIGa5j+yrmOIyPkADOBSwxOVBJwB3zVrHJ7 xJeHtszpyLVyQyjnjFR/ZLNz91fxArDQAEhpmBxgYJrX0mGG4GJZmDhiCAe3GP61f1im1rEj2ck1 Zl2ysLaO8ikRQGDAjHrmvbdNQLaxnGSVGRXjmmQQwalGJpCUDAgk4BI9a9JtvEVlAu1p0wo5GRXn 4upCbXIjqowlH4mPnBh18smQGxkVZ8UWYu9AkyBuUAgmuWg1M32uG6EmIdxPXgitrxPr8FpoEgLj LjAGetc0V7xs1Z6HMb8dDml3gDmqplGcCmmQkYzzWCRV+pZeTjHJFRGQFT1yB3qEyEDGc0wueR7d DVKJLdxS56E0Kdx61DuIPJzmhXIbPUd6sCYg9Bmm5A5JpjSjJwMCmCTJJORilYVyTeRwDgUbzgAg UwkEZz36UuQTkgUeox+7jkZoBXPIIPtTcA8g49s05AQck8UbBuPB9CaHYgYOaa2RjBphJyCTmgYE knqaMMTyx/GnDbjPNLkHoKLaCEVSDkEHFLhiemfpRgdzinBT0DA8etLyHqDAjkA9M81GDySRn61K QwXHX6Uzac9DRZ3F5jkAycA4PpUqkZ9KYoIFPA5wB+lCXQY8bSQMAn1FPkiAJDEgj0qJAQ5IH5ip +GUHjIp2Ah2cZUg49aCCCDT8EcgEfhTQhLYzn+lACKxDZHWpkkGCGGVNOEBbFSiBR1BwaaYEbKpX IUgY7VEEYkYUnHtVqQlGAQYXGMHvTVDSMQABgc4NMTsIoMXBQg+mai1W1m1WyhgjAaRZAVBIGRyD yfanO6I+wkhx1zn8qmhlCSYIIwO9Ja6A1oZcXgy6aMfavtAJBYxxxZ2jPdjwPXoa9A8JmODT1tEl 8wwDaSf0rEtdRlEE0SsuMHIc9u+PU1P4SnI1O6Q9GAP6kVrFvYho7hTwRXDauf8AivrYAd4j+ZIr tweQR3rhtXOPiBaZHXysfmaLagbevQhLR5wCTECwA6nA6flmvDb+Zru5mlIYmRyxAGSMnIFfQ95A ssDKc4IIP0rwLXLGXS9ZubYABAxKjHY8g5+lZ8kpSstTow84Qd56GMIpZWwkbMAccAnFRXDptSNU Cuv3jk/Mfoen4Vr6fqF9ot0Lu0cIwPOVBBHoQRgiszUJxd3ZmCKjuMuEHGfXHaiUXF2asegqqlG6 d0UnAIxk/j2pYZGiYMpIYHIIodQykg8A447mkjRmIAGSaqKODESvKyOy0C4lktpb2YH9yAqEDq54 H5DJ/CprZpY2llltPPgUEEqSCueh4P4c5HNOSJbTSrS0QdFMkhAxljxj3wAPzNENzNCrojlRIMMA cAjPQ+1Uo9jlctRsdzbXd0YrZmYAgLvGCe3IycfTJ+tP+zG4vViLKoLBd54A5wST6U7TrKG2klvQ CGUZA9STgAfic/hWlIIwrmOIxllCgZ6DufqarV6Cdtyht+130kq58vdhAeyjhR+QFa0UQUAAEAVH awBFAAxVwLjvimlYLihRgnvilJA4x/8AXprHAIzzTC5xgGnuK9h5Kjvn0pu/BqMsetMJ70JaiJvN NBkPJJqDNLn1PX0p+Q/Ml388dKQtkZOePao92DwaTJ6c9KBDgemKdnHXtUZP6UZJOfSjcB+Se9Lu 5xUYNAJPegfkSggjGcUuQACTzUYPWlBoESEgHP8ASjJJzk4NNzwKXqCTkD60X0ACeCDxTD1yT1pS SKQ8Dmgeoxz6GoW5Iz35qQkZIqFjlifQUmBWuWwrEdSOlc3qrFbSUZOWAGPqa3718LjPJ61zuoky 7UAyWbAx3qZPQaWpz0NlNPKsMKMzucAAda9O8L+FEsIxNOoa4YDJI+6PQVN4W8PJbW6TOuZm5JI6 D0FdnFCsKDIGB0FKKvqxyfRFK4s1OnzADnYdo9SBkfrUnhu4Els0eSSmMZ6YySMfmaS8vEgjLMQA BnnpVTwxOBJJEBgEBhnrgZH9RVy0CJ1PJ6VIkeMEjJPanRpggkc54p7ERKSTyetSMRiI1Jzz3Ncv 4j8QxabbtghpCCFUHkmpPEXiCLTbdiWBc8KoPJNeZtJc6zfmaZiVzkk9AKNFuCQ25v3EU2rXrZY5 Eak9T2AHpXFTX8ss7SSkMWJJNaniO+N9ceXBn7NDlV/2iOCa59gQcE80XA0RdwxqHjZt4OQOhB+t dL4X8Q309+tq0xEW0kBzk5HTHvn+tcR3z6DmnpI8UgdGKsOQQcEUtxp2PVr/AMS6St4trq9urkjJ kVQCp98dfoRUkehWGpx+bo97E4IJMbttJP1GR+GBXk9xcy3Mplmcu5wCT1OKfb3s9rIHgmeNhxlG IP5ip5UCk0d1e6Mun3zLdQCFto3EDGVPfKhgB7kCsu60Se7Aa2uQ8ajlioI/EqCPzxVFPFuokobh o7gqMAyrkn0yRgnH/wCvNXLfxNaM2+ex2uRy8bAnPqAQSPwP40Wa2He+5XjstRtFKvE8kajB2ESL j3xnH6GqT2xlQSIuFOQRg8H0z05966eDXdLlORK6HH3ZlJJ+jZJH5iryHTr2Ngs0cm5gSA4JyDwe cH06EfSldrcOVdDz+RDE21hg9a29LIbT8Z6Eg1p3fhi3njaSFnVwSTjJAHoQRjsedx+lVbawawid GkVwTnABBA96rm7CsytNZPetHGpABbknsK6Cxs7exgEUCgf3m6kn3NZiuqElc4zgUl3qf2WEsTye g9TSvqJJdTWneyhQtMiYHJPT9a5291m2RitqXJ6Ag4A/xrBu76e8kLSuSOwzxUKnnBNaxqShsyXF PodFb63KVBe42kHGCM8e1evfD2/sxpguWmALsQS5AJI4x/n1rwRQcgj9alEroAFYgD3oqVZ1I8sp aBGMYu6Wp9BeNvEtkBaaes4Z3beyoQSR0A79STXR+FwtrokCthZGy7LnkEnPNfLJuZQ4cOwdTkEH kH1zWpaeLtbtNyxajOAylSC5PHtnOPwrFwTtZ7Gl0dl498a+b4mukhAeOI+WCG4OODXHSeKbljhV UfUk1ju7TyM8pJJJJJPU0gjUEYXOa7I4qcEox2MZUoyd2a39u30wBBUA8cD/ABNNa9vnBLTkDvio jbPbQRsylQwJGRjIpVIIwe9S8TUf2h+zguhKEZwC8rsSO5OKDbI3XIz3BojJBwRkEUk8yQnLNz2H ekqzfxaj5V0HrbIAAVB9z1pREUICMyn1DGsp76UMSrEDPAPNaFkZ7pA28DnHStVXittCHTbNCK6u UIBcMO+ev51aW7DjDDBHaqq2U5OAynjrg1o2mju21ncAHk4HP603j3FW3RKw6bubem3Hm2qE5JBx mtBiMYAqraQJBGEQYUVYYEnrwB0rypy5m2dkY2ViF24NZ9y3ykYq9NgAmsy4bsDUJ3Zpaysc1q8s qXC7Iw4PGSM81Ui1u9tQUX5QeCAK2HKNKcgEg1Gunwk7jHkk55PSulWtqYN6lK3lN5kqUM+c4dTz +NWo7zUF+XykXHGSOP51fhskRSVAB7gDrU4gQHBH500S9dSrBNdPjzdmMc4BpJtOju5fNkTcegz0 q75sMQyzKAOtVptcsohtVwSOwGaLtjsTW+lxIAVjUYPoKupaIDknBrnZfFCqSI4yc9ycVSm8RXT5 2MFB9B0osxaHZ3CW5tnRgPmGMk964yUiKZoiQcHgg1Rk1C5mJ3SsQffioC5HOTmmm0DSNYKSQASQ fSp4/NgPmJkE9fescXswHDEAdMVM08ssSbnJyKvnZKijYfU3ICsVJHQk8ioo7q6nnKQkHAJPPpWQ IXY5AJJrW0iI2+oQhxwxIP4jFZt6lptFQ6jdwzHEzqwPGCRiprnWbu8UCeZ3CjABPSodYh8rUJBj GTnFUVzimnZg2z1soobaRg49Kd5S4yRk1MJlwNyKSOhxzTWcEHiuXXoaWITCh7UeRGeCCacXAPHF KJF9BRdgrDfsiAZAAI7Z5ppto8ZANWBcRkYKAkDg81E0qk4zRd3CyGG2ix90g+uaDaxYBA5qVp9y hSFGO4HJpA4yCeaq7ErELWqgEggkdQDzUflIeMYq8XhOW8sbyMZycflVckckGhthZES26HqSKk+z qMYJ96UEg5BHFPVwCMgHvQmwsiIxoxO1gSOo7ikMAxkYyKtb4QCywgSEYLAnH5VCzAAnNDuCRCsQ Ge9PWIHGSeaRXB6mpEYEjB96E3sFlcebdAoYspyeQDyPqKj8pTkY4qyBD94K2/GCc8D8KjY84GaL hZEflAAgE8+9N8oA5zU6kdDSbVJBLYGaau2OwJEACBg464PIpoQKRjNTiK3WUyqzhiPuk/Ln1o2A qSCD702yUr7kaMDwRmngAsMLj0pMADkH8KElCMCADjsaEx27ErxMFJx06jPQVXYhSCARnrVtWgMh kJYEj7vGAfrVa4YEHYTjuKbAQS4PPGewqU3YI2KAO+Tyao5IGTjPpTd5I64PpRcReM2RgkDJ9eaT zdjblwB25qnvJUH04pWcgDJ68ULQGaUt3BcBC9sjSKMBxkE+mcHBx7iq6uzNkDAPaqhc9u1SRuWI J6A9aa7g2ytF4j0qGSVLi4ZGQkECNjgg47Cus8IxG4v3u1DCJkG0kYyDyDXkuooE1e7Q9yTz74Oa 9k8H6tFd6BayKVDxoI3A7EDrWsUmrkO+x1eSgwefQ1w+tMB8QbAjoRFznj7xrrp71Ej3Fh0rz7Wb 1T41s5iRhRHk56AMTT6iSPTpcGM5PavG/HCxTeIWxghUG7r7+ldvrPi+z061YvKDIR8qA8k/579K 8rvL25uLtrq6VkeclwHHBHQEH04x6HFdWEg5VOboc+KnaFjMvywACnOOuT29Ce9ZLSgTI6gjJKsP Y9av6hOYoSMYLnA5zgd6oQRKyCSU4Q5Oe5xj/EVeOUVtuPATklZ7Fl7cx2wxzzx7k9TUthGRKGKB gCOD0PtUzSxXMASIgkY47gVPEgSPKgAAYB75rzYNnbUST0dzoLbU7e6UQsmwAkiNj8o/3WPT6H86 maxPmfuyWHUqRhgOvI/rWExW2tt7qDnoCOpqSy1e5triOJyZUIBAJO5SeRg9R246e1aXfUzsmdJ5 Qjht1ZcDPnN744UfoT+IpsTieclmGR/D6VSv7+aHT/OlK75CQgJ5IBwCR6f4VhW+qSCcM7YcHAcf yIpxaIad7M7lVwBSmQdAOnvVKy1K2ubZQ84W5JI2EAAjAwQc/Xj6c+lk5zyDxVW7i1Akk8AU0nAz QTg4pvXrT2EGfY0hPNLzimkc/SkxoMknrRn3ppOD06Uc54zxQG44HApc0zkcZpc9waEA7PftRnJp oINKSe+KPUGLwaOR3pM54zRn3oAUHqe1Lk+tMJPegEjHP50IPIlU9iafvG3AAA+tRZ55NOyDyDig B3U89O5pjZINOPQAUxiD07daHoCI2wBn0qFiBnk81K2cEEYquzYoApX7AcAjp3rNs7f7Xq0CYyAw NWL+XDHvipvB7pdasXGCIyQfr2qJPsVHuem2kCW1qgIHAFVr2+SCNmdgABzk0y/1GO2hZ3YKqjJJ PAFc5p/2vxDqHnBStkhO3I5Y+v09KpNJXBWb1L1vbTavOGcMIwflU/zPv6DtWhb2L6ZrCuQQjjGT 06ev1ANdDp2nLAiqoAA6mr1xHEyBXVWAOQCM1Cu9WU30Qm9UjDZySM1zuv6/DptszMwLnhVB5Jqf V9XS0hbBy2OAK89vWl1GZnmO4seB2A9BTuCRjXl1c6vfl3JJY8egFSavKNMsFsYDi4mH7wjqq/4m tKCCDSbSW6l+8mSAecjsPzrj57t7y4lupiS0hzj0HYUlrqwfYgaJF+XJwOnNUprUMCVGD05qd3Dt k5A7mkLgHA6H86YjLdNpIIx9KYQPWtJoldTkg1nOAGPoDQAzHcmgYJ96Q4OcdKcCQQR2/GgBeCeD 0pwOOvSmZyeOD1pRxwT75pASZIxxT0kYHhj6/jUOTnPalJ4yRzTAux6jdxcJcSKAc4DHGfpVo6xf yRgTymSMnjceh9eOlZqsCADirDh5QEjGY1HGBj8T70BctJqkSghiQR2xmkh1C2llJuoGeMjCgEA5 9apeRLIMqjMFwOBwM9KX7LKspiMLiQcFdpJH4UmkO5Wl2h2C5xk4z6UxTg+9TzxshBZWAI4yCM1D /EB2Pt0oETqQeOOlSBCcAimQhSwAyR06VqQWwcAk8DpmgEZjxkZJHWq/OcAHNdHc2KiAFRnA61hS RFWIxSTGT2dnLeMViC8DLFmACj1JNaSR2OlfvJ2W4uByqj7oPr7/AMqxY5HjYhWK54yDikwSSScn 3NOz6i0Ls+pzXkxedsgnjPJFIhydw6H8qpbSSQKPLYAkE468HimHmaL3YijKoQ0h4GOcVnlGckkk sTyKWEKjHIySMc54oiYiXdgkZz9aQXL0Gmh0DMAB39/atWxgEOEC4AJ4NS2wiaLMSsrgZ+Yggj6i pbVSWJIyST+FT0GkW0XLDHX1Fa0CkBBntWfGuAD6/nV+33MQQcY9utZTZpHsaCDGBilZxzyOKahJ ORg0OQetZO5qtitOecmsq6ONxNalwcA/zrI1AhLaRvQGnFXaFJ6HODVUjncPHnBPINXF120WIAK5 f3FYiorh2YAknqaWKySQklwuMHB7112Od9zRfxCQSI0OPU006jcygEMRkdqyRGplCgdTjNdDHEiK AFAOB2pNAmZzec4JYMQMkk1juxMh56E10l0Slu5A6A5rmSRk5PemkDYZJIJOaeOCQelRAcmpASMk YoEOXOeeM08njrTV6ZPagk9MdKAQmSMitqxlhWJUmiDp3IODj2NY2CSB6mtS2iJUAnmkxmv/AGcv 2c3Fq+9CchD1H1qvCQbiMMCrqwJyOlMt55rOTchJPsa3IXsdbh8uVVgugDtZRgMfeolJx1KjFM5v VXa5unkBzz29KzwDnB/Gtq906awneOZCOeGzkH6etUPKYNwMjsapSTV0Jpp6npAnycZ/SnmU4yDm qiMc44BqXAIyDzisRpvqDzYJwQaYLgFsE4HrUT53c8CotwGQTzTS0E9yz5q7mG8YA646037QM9Tx 1qucEcfnSHB4J6mnZdAuWxcDB5o+0qM81T5wSKYWJOMYxQkF9C+LntnrTvPAzkjI9DVIHIGeB2NS 7AVABGPWhpIaZaEucHPX3qRZQRjOT9apLkHGM4qdBgZORjmloMn8wAZJFRsxKk5wKhYlmwM4FKT8 vWhtiTEyS2AfxqSMkclhnPSq5BB471LEMnjrQmUWwzADAOPXNOVyTjnHeowSBgfrSgnOSAc9qBFj eCcAiot4L4BGOlNJwDkY+lQOCTzwM5zQnqBc3gkAdqnyAMY/KqK4IBXIPcmpxyBgk+vNU2mCY5zt IGDg05CCSSOMd6jP3zlsijexOcAKOAKBainGeQAeuajLHJAzjtxTC5Y9cYPAqUHgUbjK7hjkjr3q PDZIOeau4UcnjIzUG4A52mlbUCMEjg9KlKDAOAR15PFREkSZwCPTNSBiRjABPPsKaVxWIXOXJAwK sRnGcE4OBipIrbfG0gUkrycDioyihSyk9TznINCdtGFupCvh7T7/AFR7u5ulDhMG3IKgnsdw7eo4 PFX7rULbwxZyS2VrAEAG6OFmIIzyST364rOmkIvVdQACgz9Qf/r03WUNzpEwwSSpJ/KrT5VoS1cq XvxDuJ1KWkGAR1kOcfl1rFa7vLlZprqVjIyggjgqOcAelZOlwGWckj5V5Of5VryMC8gB/g6dPWrb uroS8hRArEMW5I53dSar3bvGojJJjHIGcgepHpViMhmAkJC4xn0qC/KCHYDkg5B9RVQqSg00yZxj JWaMW6ZnYAnJHf2p1jbPeSCJCcHgY7ntTZwXlKRKX4AJ7e/H1PWtnT7UW9nuIweBkdjV1p8zJpRs hbXT1t2dSQxXO5xzwPSrMMReVUHCjk1JbqRCXIJz1+gqxZW7mJ2DBA2SZCMhF7k/0HckVjaxqQyw x3LvLKD9jthhuv7xuyg/qT2HuRVa0d1uzdAgEZI465BHA/Gpbq7WcCC2XZbRjCg9cdyfUk9f/wBV Sw20qWkk4iJUAAccKCcAk9sk4/Gok+hUV1KNzJJdMGZuQMYPT6VSZSDgggjvmraElpC4IKjoRggn pTfI81QdwGDxVRa6EyTvdjYpygCnJA9/5V0Ona0FVYrklk7OeSPr61zrQsi5HzZ9KYHZTkEgjtVp ktJnoEUiSqJI3VlI4IOc0v8AT2ri7PU5bZwY32+oPQ13nh6zm8SW072igSW8fmSK7YyP9n1/GrSv qS1YrkD1ppJxUjAoxUg57g0zk/hSaAbgdDRx0zxSgY6c0Yz/AProBaCd8Dmk5zjFKQB3pODznFCB sB1I/SnfhSEjkjp+dJnHQ0BsOPHPHrQeOabuPTFLkEEAD8qQBgHoBSAEH1PTilwcAjIoOeBg4NMP MM4//VT1IHNR9TjHFOUkc56UwuPyTn2pjEY60E+1NJ657+9L1EMc4BxnOKqStgEk4wKnlfAJrOvJ dkBOck8CkNIx9SkZ0kEZAYgkfWqnhHVxo2os8yny5Btf2PY/gf51n3N451VQMlUIBGevrXc2/hex 1/VIb2wRorF0UyRscneOCM4HBIz+NQ27+RpZJFuyguvFt6JGDx6crZAIIMhB7+1ekaZpkdtCsaKF VQAAB0pNL0yKzt0ijQKFAAAHStTIiUZ/Kq3JFYrEuBwBXPa7rsGmWrSyOAQOB3J9BT9d1uDTLR5p pAAoOBnkn0Fef2wuPEOofb7wEQqf3UR6Y9TRaw0a9s9zrNixnQR3DuXiH95cDCn0PUjsc464rJml +zEiQhSpwVPBFdOsSpHggEYwQRXE+Lru30+JmUl7mXhd7Z2+/PpU2bGmZ+peJbVWe2VTM5yCAPlH 1Jrl5ZhvOBgnkAHgVRictIzMeepPepUBdsk/jT8hEqIWyS35UZCnBNSoDjgcCo2jJJJI/GgBSwK4 UAk96pyREHOMd+lWkCggHjNOKBuBzn1FAGU49BTc9wOat3EBXJA471VIAPoRQAcd/wBKcCB61HkD pSgk96AHg+hz9aQnnJzmk5PPelOTwcZNAChiDwcGr1vdGOIqFHPc9azwTnjNThs4AGOOgpAaFoXm n25LBRkDrkcDgfjn8K27GIqZhEZkgJwFZiCR6nGAfTOBWZoESy35Dc4H9etdZLbgghBgMNp56D1F Jt3sNWMXVNKils3aKPbKgDDkncB17kVyJHJyfrXoscDBi0hJABAyeoPHQcVxes2Js791UfIx3L9D TTvoDRQjchhjPWug0h1adAxGCeM1zmcHvV21uWiYMDyDmiwj0B9M3WpIXII4xXG6lbGCcgqQc1vW niR3gETHOBjk1V1RoruEyZywHGO9K1ndFaW8zl5ADyO1auj2DahG/lDMsYyQDyR6isyUYOMYHSpN OvZbC6WSJ2VhxkHFDu9iVvqaj2SxAhy6BD3BwDn61T8pY5UDysICRuKcnHcgcc+xrbl1xLq2SG5h RyAckjBz6kjGT16006VYagCbG9VHOAI58KScc4PTAPqRS5rLUrlvsYFxOHZVXBVRgHABx7/lUQID 5P6VpXuiXllhpYHCMMq2Mhh6g9CKzwpDAFcEHBp3VroVnezNaymlkjjhiRjIxCggZJrXtU25BPPf PrXXWdpZWWhLNHBGky2+S4UAk7eecZrlIgTzwATxWManNc05bFyIgkY4Aq5bbZWywwM8eoqrbply CMgDP1q7bqFH3cHsal6lIuKAigAYqMlskse9S/w568VESMHPGTms3YtaEEuACawtalK2UgBGSMVt TkDpnrXNa+4EAUHGTitaa1Im9DCgC7BvJUHuBk1cZYEiLRks3fIxx1qnjCrn0+lTSOq2jEDBAwT6 5rpRg0VrGMTXsSM4UMwyxBIA9eK6BxtYgENjv2NYOnLuugfQE1tO2V4OKl3uMpahKRbuOgPH1rni Oc9K2r991ucDvWKSaadwegL65p4J7ZxTFp3UdQKBEqnjrTSeelKvTA4oII46ijcB8I3yovqRXSQ2 0KKD5wJPJAXp7VztspM6kDOOfpW1FCSoO4gHsDUvcfqXJ54YoiEABIwSeSfp6VnASq3mLkHOQRVr 7MhYFskj1NT4G3GBg9qLBe2xdstZiuYhaaim9OQrHqvHXNQXukG0xNEwktmIw49fQ1nSwhjleB7V c0/VZbKQLIBJCRhkfkEfSspRcXeJrGSejOi3E4I4NTxvkgE8d6p7ivOOKlVsYwetFrGZPKAVJHJ7 VUIOcAVYySvPWo2UY96E9B2TIM4OCTx2p+MjODSsqjnGcU0BiOnFUmuorDQRkgk47YoKk5PcGpFU E4Byaeqg8Zwe9LYLEIXI5JHrmngEAEEHH609kAU4PSogxDHAyKLjsTqQTnJx71LuJBANVlYk4Xj2 qeMHPJ60rAkOOFGSMU3zAVwABj2pZgSMAcd6hJwMcdKNxjw2BgYqSEnd046VXAOQcGpoyRyAaWgX 6FvOGxTgR2xmovNYEe9AcE5Ip9AJh7jJ7UxkLHJP4UAr1OfwpwYMflJB70eYDgrkAKoA65qXAVdo AJx1zUCysp2jBx7UPKQM5GT6U76APYqp55PtVcuzOMnvSGUnO4cdqUA7QQMGi4JXHYAbPXHNPBJw BTOd3Hpz9KeowckYFCEyXOVII6DFRYLHg08/dJB7U0EIRkc+9PqBWbcHKkDinB8EkEEfTBpXbg4U ZJJqIFiemBjigZYtr+a0l3wsVI6EdqfPevcsS55PFVgrFckdeBTXVk2sRgHkZp301EyDU7k2duk6 x7yG2kZxwaxdQ8VStaNDFahCQVLls4H0wK19aAk0aYAcrhh+BrmU0y9vIC8NtI6EEBgpwT9elNCY 7SmCWisAMsSSfepuTcuScAqarQW9xaQBJomjOSPnBGCKkVmaRiRzsPHrxV6W0Erpmi0BJB4IxnPr UF5bLLAQBtYdCRUNrdvH8uS0fXHcfSrcs5lAAUgHoCOcDqaVmHmZcMUSkiNSGHDZOST61cB3lYUH OeTjr/8Aqqf9wFBkQZHOVGCRWxoWjLOpu5wQjA+Wvr1GT/SlKagrsaTk7IqbFSFYVALuQoyccetV tTvAQlhbEGNTl3AxuI/oO351oX+nuZyYSWAGBx29Kp2WmOb9Y2QszEADOMHP8sVPtFJaDUXfUueH /D0+p3SqFxEpBYkcE9hn9T7Cp/FMheNNG08KbaJ900oGBLIOBz/dA4Hqcmu9h01rLT49OsQDczgB 3GQVB6n2J5A9ADXJ6naRW9xJFGVZIjtJA4LYPH4YyfYfSs3LUu2hxzWz5a2Zi5jUFm67Segz6VXC MGjJOY+BkdB3OfQ1eNjNcSyOHfDEknJAIz/iKltLKBJ40ubpYVlYrvfG0AAnnPuAPxqlJbolooRT gMVIBUn8qJoUf5ozgntTpraNbp0gkRgGABycN64P5VHJlHCKAGUDII79a0Ur7kuNtiqVKsQRgg96 uWuoz2ilYpnQEYO1iOPwqNiJUAYcj8xULRleQMjHUVrGTWxDXRnSWGtliFuWLA8Bu4+tbiOrqGUg g9CDkV58HZCCDWpp+qS2xwrAjqUJ4P09DTUk9xcvY64gdKaQDzmq9nfwXq5RsMByh4Iqye+KCRpP IA5pAPTk0uD05pMkcZoH6i+5/CmMeOBS/Q59aaTk45+tCXUQZznIp2cAZFIB6Dj6ZpMjP86GMcTn qOTQMkg8k0nI4xS5xwaYWH5AwD1Pp2ozzkDp6U0EE9ePWlwMf0pIAJyODUTHrg0pJBwSQc/lTJHw ODnPShhYrzvg89KxL6dSxJYBVHJJ4q/e3CxRsxYAAEnNZ+gaNP4ovdzhksYzz23HPSok+hUUt2J4 c8OSeI9TF00Rjs0ON2MGQj+le0aVpcVlAkUaBVUAAAU3SdKhsrdIoowqqAAAMYraAWFQSBnHApJW QXuxAFiTJPPYVia3rcGmWck88iqFBJyak1XVY7SB3dgMDNeLeINXvPEuri1G4QKxATtgdSfemrdS ktLl9b258XasbmcEWUTHy4yfvH1NdrZwLDGoAAAAAGKytF05LO1jjVcBQBW0zhF/CjfUkr6jex2d tJK7AKoJJrxnWdTk1O/kncnaSQozwBXT+MteEtwLCPLKOZMHGT2HSuLdEIz8wPoRT6WGxIBkPk9u tW41GAMHHtVRQEPBzk8+1WvNCKMnn2qQLOABkk/SomdScA5+g/rVd5WKlmJx6DuabGrOwLcL9aeg FrDsuVQ4HU9qa1yVGNoAxzV1LmCOExsSAQOFwOR79f1qrIsMi4DD2zz+tAEZu4yAHRip6gEDP0NZ 0oAkLAEA849KsvAYfmA3IeAQeAc014SeSOM4+ho2CxUIx05pAQOcECp5IwCMHgVGVBGMYoATI9aU YI6U3aV60o55x9aAHDBPSrbSJIEKxhSqgHHcjv0FVB9e9TITjOOBxQB0HhhA93KxJyoHP511TEDo Rk/rXN+FUyJ2BHYf5/OuiY+pH5VnfUpLQQkdPyrF8Q2qz2QcAb4zkHIzjHI/lWxnkkEcVQuJoplC BkJB5Dg8/kKpbifY4VgfcUIxBxVvUbYW906ggqeRjOMGqWCMH3piLsDEOCD161oI5xgtxWTE/GfS rSTAEHJoYLcS6ADHB47YqqQMhh9KnnmUngE9qrE8YH1oQGrbwrPIFK4zyecHpVl9OdPmhfoM4J5q ppdwon3SY6YBx3rWNwsiuUPIUnpiktWO/Yp2uv3dluiEpKn5WRzkEZ6YPFEt7Y6jdFp4RbserQDI z64J/kax3O6RjxyTWn4ftkudcsoyoYGQFgRkEDnH6VM0opy7DjJvQ2F1O8hhW1F+txbyDAB+8B6H PI/WrkIOASegyad4ztLSyuLc20CRyFSzbBgHnA4HHY1lwaqEVTMuAOCR/hWcdY3XU0d1ob0ZKqSC QSOKuwklRuI464rMtJ0nQFHBHsa1YiNoPXNQ1qNaFgcjHSoXI5NPLADO4DPbNQO5xg4pWKuVbhzg gcVy2uykyRqecknFdHcE5JzxXLaqS96vGQODxWtNdTKbK2MsATjGBTLtwIlUHljk89qUAmQZHBNQ XLB5sDJAwB71snYzLmlJgO5Bx0FXZXBG3OSfSmW0XlW6qByRzUogycsTxUXHbqzN1ElYAMEAnAFY xwecVtawcbFHHesU8HNVHYGKpJOM8U8ggjIIzTRxjIyDUkrq7jaoAGAB1piHA4HBHFNzk4FHAHJx SKBnHrRsMuWH+tP0rdiGFHFYtgqhtxIHtWr9oVVwATipe4JdSx0yTTHfAxkAnoKhErucgY9KNpOM nJp6jsSl0RQCRyOmaqyTA5IXoOppxjBbGelI0bFWGMjtxSsCTOtcDBwetIrkcHt3FJvzkDHtSbgf TFZ27gWc5UYOabkkY71ErEHvzzSq4JyaVihxGOSB603cfwp2M9qGTJyAfpR0FYahB6cVIpA47GmI cHleR6VJtBGQRn0ovpYEKxz6YqEgZ4PPpUmCPaoSSGyT3o0AdkAg4zVpTleh5FVVJJ7VMpI/rQNI mLAKeOaq7CSWJ5zU6kkZ6iniMP1HBo3DciiXPUYFW1UBc/rTFiIOAMj3qVSAMnA9qNA2Gk54B/Ol Cg8YB9SaAoJ4AGfSniEc5P4A0LYBnlliApIxUZgYOMt+FWsFR8owP51E2AQWP4A80WsDsJgKCSTg elRsQSTkDFDsWODkDPABppAI5HSgBcAruyKepBAAyaiQAHGcDFOAIOR6U7C6EuxgQwqZSSmQOfpV XLkEBiakRmyPmPTkU7hqTFw2B0OajlfaCw5PQChUJbdjBPNQzAmQKTwOcUvQYxSQOQQSc9aFJBBB zj+dMJyxPYDgUgJIAHandidy2pJjBBBw3WmyMjxhTneCecdaASLcgA8kHPYVL9kMsayxSxggYZGY hs+uMcg+3NDdlsCSe5XcKVYOgkQqQVPQjuKmhnsniSMWrARqFRfNO0Adsd/x/Go9oUlWOScj6VUt 3wwIORyPpimtdRWMbVZ5rzXHilYsijcB0A9f5VXlhihmCxOWBjJOexxTtcQDV0YHkryAarRkmcli c7TinG9rhdXIoiVUyK67QM5Jq0lzmNmJGWIGSe1ZcKL5GOQSeMd6khSaa4itkG5mOAB2ye9XfQVt TV062m1XU4rSBWYswBwCSSewrvrvNra/ZokIKgKBjoBxWdpemR6dbKoH7wjLN3JrattXjiMkd3b+ erIAHx8yHJ79+vfpXHUlzvQ3jFxRzlxdvbwkomWA5YjpWv4ctwkMl9cghlXJA6kn7qj3J49ufSr9 mdFjtLiW4O+RgdoYZAPofrxVLT79xamacqkCSNJGo7k4GT68DA/H1pwugs7m5cag2n6eQHU310Dn JwIwRzg9gAMZ9BXLmJr0CGIE55OOCQT19dzH8gB2FF5dtPKzygljjIz0GBhf6n8B61t6KsWmWj6r dYLj5ok9W6A4/Qe31pt9ASuU9S0hNLt4rQFTdSKXl9Il9TXJ39p9su0iRSVjGB7fX37muivruWd3 Z23XE7bnJzwey/QDk+/0FaaaTDpGjC6mUtd3BCwxY+bnuR6k84+gotbVCtfc4KWygtFkeVSdikgZ 6seAPz/rRq0WlpcoNOuXmjK5aRlII4569ea0dVg3qLcEPITkkDjPc+47D8+9VTpS20YMijOM4qk0 9ybNGQyCKIKxB3HIIHBHY03G0kEgg+3NX5Li2l094khCzmUkPzgLjAGPXgfjn1qskQ2s8ZYkAjB6 /XPetIyfUlpFSSMEbl7ckVCMnkZGKssFBG0HI6j1pzosoIxhx+FaJp7E2aGwztGwYMysDwQcEGug sNcVwI7ogE8CQDg/X0rl5EZDz+famrIyNjJ96tSdtSWrnomQ6ghsgjII5BoK56DNcjp2sS2zBQ26 PuhP8vSuotb2G9XMTDcOqHqKejJs0PK+o4pCAOv86mxxyCM8CkKkcYwcA8ihAREHvik4J4zUmOeB n1pu0DmgLCZwORgijPrz9KQkA8igEZ68UwHZxRk8etNIx64oJGODn60tQByASQCBjiqdxKAMg4J4 FTSuFBOeQKyLqZpHEUQLO3Ax71LdtxpFd7SfW9SjsICdhIMjDpjPSvXNC0SHTLKKCJAAoA4HU+tZ fhDw4um2omlXM8nJJ7A9q7REWJNzYB7CpV3qx+QKqwxhiOewrI1jVorK3eaaUKqgkkmnarqsVnA0 srhQATya8b8V+J5NUlMKkiMMCFJxketP1KSOy13U30/QIdZlKtLdqTbRNggKc4Yj9QK5XwzppObq UEySHOT155rP1vVRf6Tpdv5obyItrjOSME4H5YrqfDN0l9pizLHs2sVI+mOahKzuxyelkbkSBEGB yKydd1L7JZuUOXIwoz1NaNzOsERZiAAM8153q2qm9unIb5FOFwaJSsrmlClzys9jHltXuJHlmB3s ck1XeydCSp5960fNB4BP0o3jHJ/rWSqPqdssFFrRmM8DocsOvAqOMNNKqA8k4Fat18wwFHIJBHWq Nom26GeCDxz3xWsZXVzhlScJ8rK8mHnKg5VTjjvinSS5AVeFFRKSGcEdetGCAWI4qkZvcdk9yaTL HkdvWkVwcA5pC3NBJPBOUba43I3BB9KlRAl00BO5HXKn8Miqe8E8cGrkRLTQNnIGcj6ZP9aUtmXH cryo0ZKOMHGeagQE81Zu3Mk+Sc4AAx2AqAEAk/pTWwmtdAwSMECm7QBxzTgcnpxSggZI/KgQ0LgZ 6inKwAIFNZjnIyPalRWkcKFGSeOcUXsNa6I3tBvfs0E7JG7uMMwGcBfU4HHUcmunt7uK7g8xGBHc eledeY0LsgyDnBFaVrrclopEUSYIweDz+vWpcU3cafRnWzXRVtqLknjJHFQwqZLo5wQo5GByawh4 nmHWFD7c/wCNOi8TOhJW2QZPOCeadtNBXLXiW2QWsc6KFKtg4GODXJtx0rfvdfa9tHga3A3d8ng/ lWBknkjOKaVlqDY9Dg4JGKmQgjGarocHBHBqZQTnAIHrQIGAJIB603oCM5px65H/AOukwCcd6ALF gQtwueQT0reuGhitJCMAkYyAcE+mema5yAlZ0I6k1PPeSyr5ZJCgkgZOAT1OPelZXuMrAkseTzXU eCbcy6+j4yIlLE/oP51zQXjJ616V4N0oWWni8JJluFB5HRew/rWNeSUbdyqavK5Q8eRML2CXcCHU AAdsH/69chOWwqjoSK7vxQi3l7GkozsUYx1Bya5j+z0+2xszAxg8gjmiDtFXNHqy1YyJBGqhVOCF PyjJOM9eta41GCGeFSjiF2AO5yARnnBOSPr2rKmsPKlheGZUJbJLEjBPfA9quXmmQPbJLLeAzsxA HOMAdenfNS2mHK7mk72U0zLFOAecJ9oyQPrtwfzppt1IBFw6joCzLj8SSBV6PwzpyKMamrOFGSpB GfbOKim8NRTkql8Gx2wM4/Oo5lcZhaqZ7KLcTuVgdrgDB+hBIP4GuZM7GQCRsseTXS+I9KbSoIyZ 1kU8KozxXMZDyNI4AJHIx0rohaxnK/YfK4iQuOp6Cn6Dpj6rqccKqSoO5z6D1qEQy3UiqiEg8KAO Sa9L8LaH/Y9j5koAuJQC2R0HYVFWpyqy3Yoxu9QXwxaIuCJCQMdR/hUkegWAPzRsQPU1oXGrWVtz LcxjnoDk5+grIu/F1igIijdyM4PAH1rnjGbNGkjhfGKQw6s0MAARQBjrz3rmc4zn8K0NWvDe38s5 /iYnFZ2M8k13RTSSZjJ6ki8jk80oAJBJ5pBkDk0q5yOeRTEPLHAHFOiUswAGT0FNYipbZirA4zjo KT2A0LGAncccg4rRW05yQQPemaaoEQYjknNaaAngjjtmlcpIpeUFOAOPWkKc4JFXHiIGe1QFSSSM YNK/UfqV9gDfWpNgAycU/wArGRg5/SmscDBNFw2Rsq5IBx0HNLkA5BqtFMQdp5zUm4E8d6jQRYLA 446UoIPI71ATnkGjeRjn6UWuNMsgkDg9O1Ads9c1CHJ5B/8ArUokJOAefQ0WfQZKCRginh88HAqD ecHjigMSOmD1pWfUCZ3Kgc1Gx3AHBI9hUbOQQD0NORxkZ5HTFFhepIBjHNSqD1I4pgODwAc09eRk k0egywgBGO3pU6ooHJx6VFGAOc5qYkDjAPHanYBMMW4Bx65pHBByO3X3ppYjJznHQU0Fj8wFFgJV BzyetS78AEkHFUxIS3T8qfuyc+1F9NQJJZ2IwDxVf5s5PPvS5HPagABCSckmhtgKASOc4FKCCSCc CgkHgZHrSAZGO1LcNRME/TsaemSQKcicAEcCnkKOcdKaWoDlUAEZxxQqkYJyKRWDcYxUm4A8CmIC cAkdcYqpMxOCBz0wasvOig+w/AmqskpcFgAM8UNgiNVOCDxmnIgBz7dqFJEeCOvPPajABJBIHbNJ DLKMojZducgYyelORyhjxgDJByKpLIUyCeccc1PbuskmHJGASAByTVIVizfRgbJAcZwOnX3ritRE yX0kUUsqYYsSCR16V27S77UoVOVHBI4GP/rVkPoE+o3wuE3NC4wwjG58gZxgcjOQAenWhaMVjlRE Ek8x3Z2A6k5JNPhVjcAsDyCBkda6fVdAgsNLea5ins5lIEcchDMwPcgAEAetc6QRLHkAckhgeoxV Ji6lWzCSW4QkA5JORgD0q/pTR2F4l5OpaNgVBA6EY598A/rWRbEjORkBjx681aklBkIUkqOFB7et DSa1GnZ3R3wvop4AYJFbIzkGqweWBjKCSAckH0P9K47TLuS2vcoxAB6V0l1eCe1QFSNxIABwQK5Z Q5XobqV9WSGVr+5AJxCvUDvj1qa4uywVVOEU4UdiR3+g/nWclwIoyAMADk+g9PrUUcr3UwRTgdGI 6AelVayuF7uxt6XCtzOJHB8pCep+8e/5/wAqs6lqnmyKVYiGLiMZ4JHVj7DtVCW5WCEW8ZwAMsQe 3p9TVa2jbUbsRqSEH3iOgA7VK7sPJHQ+HLNJ5zf3RIgjOTuPDY5x/U/hTtV1Zr+7e8cnYAViU9VX kEj3PQfifSoL++SO3FjAdsSAB8HGfRfqepqvpcD6pqCoSREhyzg4xjpj8sCmpBY29C0SCSObVdQI W2gXJ5xuI6Aew4H1z2xXP6o/nyySBcGQ8IOwPQfXHJ/Cug13VY2jisLYBbSA429mYDgH1A6n/wCv VbQNH/te/Ekx228Y3yOeMj6+p/QDNN7aC6nOx6R5Vr50qkBhwSOtZGqFkuordVIWMbiE4O44zk+u AB7c16DrE0F3PNcquyxtR5cIA4kcfXsByfwHeuZg0mS6aW7kQhAckn88fWmm1uS1dnOxJvJDKxYA sZMYx9R/WmZCCQMuSyjafTkHI9eAR+Na2phra1cQgKZTtHHJUHJ/UAVnhJ55ATEXYgKVIGD9MAYP vWib3RL00K8gIjUsBhh1/GqslueSgBHXArRvI2QqQp2AbcEdx/8AXquI2eJnUgYIG0960Uk1qS4r oZ+xg2RkEVatrqSJwysVcHgg4IpjAbiGBBB5GKMAHAIyexq07EnU2OurOFiuBhzxvA4P1HatcNkZ BBFcApKnK8Y61taVrRgYJMDJGeCM8r7g+vsf061SdyWjpsehpG4A649xTIrq3u13WzkgDkHgg+9O Jz0o6iQ0jOO2PWkyQRgcfnTsZPSkxnrg0AmNJ596axwpzzTmGBzxiq9w+xSCfxzQPcp3k5AIGSSO AK6Dwb4dM8ov7pcgHKA9z61m6Dosus6gGYEQqQWOOMelesWttFZWygKFVRhQKyb5mWPjjWCMMwHH QVm6rqkVnA80zhUUEkk4ApdT1OK1geaVwqKCSScACvHfEPiSfxFqAtrYsLcNgAZ+Y+p9qrZXYkif Xdfn1y98uMsIAflX19zXIX0TXOoEREHYQuM9SOtdgLFNI0uW6lH77acZ7HsK4eO6FtdZcHJO4nPP NRrcrSxoPpF7DGkk0YSMjglgc/l610/h5mtrUCJgpUnIwcHvk9s4yOOmAe9ZWqa9a3NjDHEH3KBn IAGataPqaWWiyTzQiRWdtuWwQcYAz3GcHGO3Wi76ha60F8W6/m3+zQMQ8g+bB5A7iuGR5Cc7mz16 1ZuJHuZ3lc5LEn2pscZJ5XvRfowTa2Y5HkHIc8VYjlkOASDn1FJ5RwAAB9akjjwQCTk1LiuppGrN bMnlBMYYkDjAxWWhAnBI2kHkelbkUK3JEQbDEgDI4qlr2lf2a1u4YEyKdwByQQe/pkfyog18Ipyk 3zMy7mIpKXU/I/I+vcUFcpjPank74wGyMgFcjhh0qOU7QcjtWi0M209SvwD05pQRzkc9qZgsSBQR jkn8KYhcfNkmr1rJsBJHOMA+lUASAQOakgcjKN1IpNaDWj0HSgg7yeGJ4zUABNatvoeqX8CzW1lI 8RyFYAYOOvWph4U1sgf8S6bjvgf41LqRWjYcretjGBJyD0oOSOM1snwtrQ5OnTf985pjeHNXQZOn XHTtGf8ACjni9mPlfYyCCAMnmpoXCSoRnggnNW20TVAMtp91j18pv8KpSxSwSbXRlI6gggimpJ6J iV07lm/gIuVmVflbHPoap4wT65rUhkWW38pzlSODjofWs6ZDHKykjjoaI9mXNfaQzGeSQB2p4HOR npTcZ96cnFUZDudvXkioccHPJJxU2cjA4NQAnnPrSGIBz1+lX7K/u7LJtriSLdgNscjP1x1qiuc8 j9KmGMdB+FAE1xPLcOXldnc9STkmq7HGMDrTue3SmknOMjii4CqSJFI7HNBbMhPYmmk8j1pRnvnm gCVSzyKo5JIAr3CxhW3023gx/q41Xp6ACvIPD9hLf61aRRxs4Eis5AyFAIJJr2wKoUA9R1rixEry SRvSWjZwuqyF9VmIGdpx+QqmsQfBI5zmnXkhkvbhxyC5PX3pY3HmIoGTjJrfZIXmS/Y0nAV16cgg 96zb6wnSUhWdkGCO+K6GJSFHFPABJG08eoqL9RnOIblEBLMMccgilF5cRsQGII7+tbsiA9upqnLG oYkqKFdsey0Mye43zRyXbEIrAknnAB64rSvtY8PTAOLAXD4+9jaT7kjmue1iUsCoIxkAVRRMKBj8 K0VNPVkOVtDaXXRbSFrGzhgPQMcsR9CSR+QqtPrN/dAiW5dgf4cnH5dKoYIPJGPpTlQA4HNWoRWt ib+YrTO5JLGqt3cFEKhiWPr6VJcSiEZYjJ6Cst3MjEknJPeqt1E2RkknB5pBwSfag4BwB3pcccki gkAMDvUigYBx1pmeMCpFGFzmgBD15qxAmSMDOKhUAsBmtCyg3EZOBmpbsNI2bVSsKr04HWrykYBy MVTVQoABJPapUyDnGfrSKRMzBhwfao8HBAFO5JycD8KMc5J69qWwdSIqxPJHpSeWASW5AqU88E9O ajchwARjvQmMVWweR1qeNyeCaq5P4GnBiDwaQkXNw7GjeTkEDOKhVwc4OD3zTs54oBkgbBHP4Uu5 QOtRf0p2M98A0rsWpMrgcDmnhwSCeMVXUAEYNOyuep4pX7DWosrEnjNCMAck0MQV4HQU1VJPP15o QNltCW6HjHNTISODjB9KhhUgc1KDg8EYp2QXLKOGxtwO3Sp1RlIPUVUikAOQAaka4YrgZo2DUlnw CAQc+1RbyeATj61FuYnkk07k429T3pXfUZIRjHXPekzgDrmkAwME89zTSTnOOBQ1qA89RjkHrSk4 yBxxwKap7kZNOAyR70LuO4qkk5NSgZwRnGaRBkfj6VKoAXrjHSn6kvQUjgY5JqNicEDtUgPGT9c1 A7EjJ7mmCHKSOh6etRTzgfKCRTZJQFIIPJqnI7E8d+CfSk30Cw5pWY4BIHYVIjggZPOelVQSec4x xTl3A55H1pX7j2L2/jHXPrRkdATUO/gHPTsKUsCQc4zTWoPUkKAjBAPfg0Rwl13AkYySR6UgyOTg ipYZ2gkztBTHIPQ0C9SzbSgAoSxUjBB65rLklaK6Qg8EHAB6EH/69XmvI3YGONI0zyAOprM1CVYd rohYB9ox6GmtNQdnsTamzS6exyScZJPNYUykPAcYBIxjp0rQlvzcWzW8MDbmBBJIwB3qtcKUht1Y 5IYVXqJ2MiIEIQqgsWOOenNOBVXDMpwTnB/lUCEpM5zjDE8/WkmuAzktgZPHbNPoCVmXYHiWQyuA XJ3YHf2x6VcSV5nLsw45x0AFZUIBIOTnufapZboKBFGQR3x3NZtJ6spN2sX5Z2lASPlVOM+pPc/l Vu2cW6BVI3nuf51lW5KLuJyx7VYlkMS7SQXbrg9B6VLiWnoWpJTLKIYiWJPXpk9zWzbsLKARQ481 x17D1J9hWNZkW6GRgS56AD9KlmuWRSuAZmPzH0HYD29ai1xrYts5mlWCEliT1J6k9Sa30uU0qxEM LASsMlu49T/hWJp6LaRGVzmRh/kCoLi6Z5SoOWJ5AOefT6CluNbF2FZL26SGIFixxg+h5JP8zXY3 U8em6Yml2bBWkBM0h7Ljkn69APTiuf00rpluZWAMzDnjk+g/xqpdXTzSMgYtJIQXI6k9gPYfz+lC vfULdDUt4n1i+htbVdsEZCoCMgDqWPqe5PrgdMVt669pbxxaNa4WGAb7mYEFj7Z7kn9SOwqvp8qa BpZkUBryUbV4Gc9h+Gck+tYDSSXdwLZGZ3kbLMBksx9P5D8TVppitbQYumza1fboo8RKDgDJCqMD k+nb3INVr+AWyStCuGQYDAd/r+td5dCLw9oa2EGwX1yP3rj+FccnPYAAgfia5Z7KXUpY7a2RihYK AASWJOST7nr7AAdqFdaia6HLuLm9WFpTuMahVwoAwBgdB1HrUV1ZMLdnwihZArEEAbiCRx9B1rs9 S0oaWxtSAZEXLDHQ+n1/xrlY7OS5kcNllL5xnjPT+lWpX8iGrMykhM84EoZVERYHGOAOMfX+tU5N w6qcdm7GuiurcQqYtyguCMMcbQBk4/SsUW7ybdg3IW2k+nIHI9OatSYraXKsZJGDyexHX8aTlGJ5 xnNTTIoupPJACKSAM84zjqaYXV1IIII6HHUVafYlqxNb3slvIHViCOhBx/8ArrotP1lJ8JMQrnoc YB/wrlQinjoT696FYhuDgdMGqv0ZOh3/AGB6j60mQOcdfSuZ0/V5YAEc707AnkfQ1uRX0E6hkYA4 5BOCKolonkcKpJPSqUEMuq6glrACxJwcD9fpST3SAMzttiX7zd/oPc1ueAhAdcMpxgQMyjqTkjFT JaaFRO70bSoNIsEQKOBknux70zUtTjtoXmmcKigkknAAo1HUkgieWVwqqCSScAAV4j408YS6zO1r auRaKSCQfvn/AAqVFJDJvE3iubX71rW1Yi3U4AHVz6/Stfw3oK2NsLm4UGZhkAjoK5fwjZCfV4yw 3BQXOfXGB+pFei3kywRkdFUc017wN20Oc8Ru07xWq8gncwHoOlcBraGLVpUOBtwP0FeiQxNeXDTM MZI2gjtXnniA51+8A5AlIHPTBxSS1uO/Qr7wIwO/atGOaSWyjhOSi5PHqTWaqcAk5JrYtbcGBSCR kVM3ZDjqVREcnINTxxYwCP0q+tqCM+lK1sSCF/Os1K5VrFFgQSRnApUBPUdO9XIdOubmdYoxkscD tXRDwFqfkh0kiORnHOPzxQ5paMEn0MJdotc4GSCOPWs2+ne9hYTu0kiPjc5JJB9z1xXSS+FtagXa LYSL6o4/kSKpr4avxKWmspFB4Jxn+VSpxTua8qcfM5Qo8c6IWJRTheegz2qG4zuIz04rcvrNrW7a KVSCMYyMcYFYdyMTuCeh6VvF31MGrEGCACDyOtBVjggcGmA5OMnFSI5Ix6VRI5AoHAO7p7EVJEim VTgA5HWmEAcjPNCOQyk9QetJ6oD27T44lsYTEAqFAVA6AY6VbVQBg9+mK4Twt4pjijjs7xwEHCP6 D0P+Nd3G6SIHRgQRkEHII9q82dNxZ1RkmtBJDgYAyT05qNSQeMfSpiisATyacAoAyBU2sUxinIzt x+FZ+taTDrOntazDBPKP1KnsRWopB4qCW6tYiRJPGuOu5gKqKkndIltWszx6/wBMudFuGgu4mXJO 2Qcqw9R69vcVRnhLruGCQAcg9q9X1e90Se1aK6ZLhSPuKMkH1B7H3zXn1/aWaTmTT/OEZBDJJg8e xH9a7ac5Ne8jCSS2Zz6jPGcUMcAgHg+9OkUqwPY8DNN6jjrWxA0ORwBn3po7jmnsNq8jk/yprKqg AEk9/SgByjB/Cn54zTFOCDjNSDpyaQAM5JwTTcAn3zTwBjrSAYyT2oAZgGQKDyTiry2ZQBuDgZxV SAA3Azng1rs4EZUAEsMAnt71Em72RUUt2aVnrcmkZTTGRVcAsxjBO7HPXPFOfxLq9zIFe8kAJwdu FH5DFZccQAxgZ71NHGpkUY4zmq5I721EpPZGsjkqCxJJPNSxSsLpFVQQTgk+lVY85I9OadAwa4Vs kYOBzWUmbJHSJ0/Cn5yCfwqGNw0fBwMVOAAoHc1mnoDuQvzVC5bCMc9qvTAkcEis29JWIj1HarQn c5i+JedV65OaUDHXHSo7ggXeScBR3pklyifx5PoK2Wxm3qWFGTjGcdTUU1wkC8EFvT0NUZL5zlV4 HY55qsxZySx5qhXY6WR53JJz/hULnHA604vgECmgZPXrSECqWODj1p5A6dMUo4FMJB+tAAOTjH5V IBjkA0igAZp4BJBHr3oYD4kLMPety1iEajI5xVGxgLEMQcDp9a1FBAwPyqG9SkiUZBzjpT9w6E8G mIjngKSTVyPTLucALC+D3IwKltLqNRZUZ2BwDgUglbjJrXj8N3T43sqfjk/pV6HwtGDmWUsfQCp9 pEaizm/MJGSTSqkkhwqMSfSuvi0S0ixiIEjuTmriWsUQwqKMdMCodVbJD5WzggcnIH507PfGBUfI 470o9cVrcnzJFcA8j8al3g44xUHIwKcrEdeaV+4MnznpxTgSSMk1HuyAevtSq2Dk8A0wsSjJPA/I U8KcdOetCMDjB9qeQME5/WlqG2wIOMEZzTwAOSMUzcFIJ454ppcg5OcYzQG5ZUjAIpS4BySOtVhI QMY60m4k8mjbQErFoS9geanXJUkjFUonRWyQTVsTg8YxnpRbuMfwACc01m2DIJyegpGfJyBnHSm8 Njg570JCHLIehOc96eMkDAzUWASMD8KlUleARz7UMPQkAIHQA09RhgTzTFORweRQGPcnNAE4IA4P U5pScjrioCxAyDwaeWAUEnk80eYEhcDjOMVBI/GAeKa7lVJJ9z7VUklLk46AZoYKwskoIIBpmBjO evWo8kkkjpSgkqSTgVNxjmIzxzT8gYGKiYgYI4pVcAYIJGMdaYEycsAeB7U/G0dQPc1XVz1A/SlL k4Ocj0oSYWRZJzznGKXOVwSeT60xAXUhRyOTTgDgqwPt9aYWFTYFYMGOOQBxVe4VZLZsA5DAge2f /r0/fg5APHepbeUW10sqqrYIYBgCCRzgg9aasDVijFpV6zB4owEJ4LMFz9Mnmsy8eYaiYZVKvEdp U9ieo/lXWnVknlDG0gDqMK2DlfoM4HNcffOx1mZnYks24k9yapPWxNnuZjE+e4xgBjmlkgSUAnIc d88EfSldCbiTA43En86eVyBjigaK0tw8S7FU8jqaWAggMT8x9O1WjGHiKOAw7EjBH0NUvKkiViiE kZJ9h64oumHUu+eIxkE7+gHp71LbnB8xzknoKzLd8ud5ye2RWgkqoNzdug96iS6Fpl97kJhiRuI4 GOg9frUtmvz+dKSSeQD2rNhzLJ5jHjOQKveeEQscbR0Gep/wqWik+pdubzaBzyeg7gev1qxpkIUi eXAOMqD296yrYGeXzZDkA8A961HuVij3Hp0A6ZOKhrWyGn1LVzfFQSD8xGFGeg9frVvSYxF/pU2A eoBHT3rFs0a5lM0udoPAPer9xehUAzkDoOxP+FHkF+5e1DUXlbOcMRhV/ug/1Nbfh6KLTIWv7k5b GVBHIBGMj3PQe3PeuW0yM3E5nmGVByAR1P8AhWje6iXIAI2KcqPU+p+nalrfTYOhdvdQkvbpmYnz JDhs4wq9lHsOp/D3rsdGSHw5pB1K5QG5ZcQxnqCec49TwT6AAVyHh60Esou7gAoDlQ/RiOST7Dqf Wpdf1lrycIjny0BC+uO5+p7VUZaia0uyrezzalcSNks7sXZu7En/AOvge5PtV680I6JYwLMALmcb hHkZA960PC1nDaxHVbzaIowWRSB1HGfoOg9Tk1latqc+r6hJM5w0vCg9FXsOfbkn/Gq31E1pY5i4 tWub4nJbAxx0qOW1W2QyMxTHAIHQ/wCcV3sXh2PTtBbVbs7WlwIUbqcjg+2eT9K43VEaaQQDBJIL Y7EdvzNCk0tdhcupz8tvFJLI0ZKIQQpbgMeMZHOM8+30qGeMYt4eFkC8nHckkA+vGK6A6ekEW6UZ AGSPpWLKqXUgkQEY65OSMHoPoOMe1aJ31RLV9zPYO3DAgLwMDGKRQzrzjI9KvSYitdrncrMMEcEY HGR+JqqkbmQhMtgZODjA71alfchqxEGOcg8ipoDLPIVizu6kg9B602MCSQJsyxOBjrn+tb+n6a9v b75VULI2cjIYEHgHjBH0NPmSdrhZtXGSxn7A0EqLISoALZyCO4I7n37Vo+BnOm387zuFQQsQSegJ H+Gaz70OrADOw8hh0Nc9rF3PAogidlWUYcA9QO30qrXVyVvY1vGXjGXWJ2s7NyLYHBIP3/8A61ck iY+UgkmnpGAoPf1qeGMkgkYwc81DlctKx1ngeBlluZzwI1CgkdyST/IVsajObi4ECkkAguR/Kqej k6b4cMrriW6kLopHUYAH54Jq1ZW5GJH5ZuSfeqWiItd3LlvEI4wAOleUaiRPqt1LnIaZiD9Sa9al ZYoGZjgBSSR2GK8jZTkkg8kkE96V+g7DUCjAzj0+tdDbKywJxnAHasCGJnnVR0yMn0GetdtZ2jPc C1ZQuSQpbg4HqOoOOxrOptoXF20KiKSMjP0p2CBweTXZQ+EYRCjtK+WGcKASB7gkVLF4RsXPz3bD HYoR+uCKw57dC7XMLw1btNqAdh8sYySegrvXjZRgwJ05KPg/yqvZada6cpS2NuwPUs2Sx9OoNT/Z pR87WoAPIKNnI/Kpvd3ZSQ0EIMFZ1x0IbIH4ZP8AKkMrBf8AXAnsJIgP1wKUrsIDC5iB/iHI/IH+ lP8ANUYC3SPjkB4sZ+pwDS3HY4Px9YB4Ib4GMuD5blODjqCRn6j8a801BCJFkA+8Bn6ivcdZsE1i yktZHiG4ggxnBBHI7kfpXleu6BfafBi6gKgsQjggg49wfSt6c1azMpR6o5Qkg9KdGCSM0xwc4Ofx pyEg+1dBmWVKtwSBilMeBgYNVwctjoSe/Sn7inVsEHt0pAPAKEFSQfStPT/EeoWQESTyCMHoGNZf mE4JHQYowpIJJBJ54oaT3Gm1sddD4tvXGBdOvHQkfzqY6zqEvW6kIPPDnH6VxWSrEAkY9qnhup42 BRyMcDmlyroh8z6s6h7m6k4eZyD6sTUO5j/ET9KzYNXOQsyBz6g4NXo9QtXON2wjg5HSi2lgvcc3 zEAH8zSAKSeQfpThPbbixmUgdDSSXtqhBLj8BkmmkxN6mHe27RyMpBwfmU+1UkQgbmOAP1rXvr6C ZVEcfKnOT39aypHLEnt7UJdxETnLZ9e1HU805oXA3MMZ7E84pqjJwDxQBIuADk0E8YPek7fSjBOM 9vagB+RgAChsBSR1NIM8e1I55APT60kAwEhickGphM4AIc4Hv0NQtySQAAelJzjA+nSmBZF3KOBK fzrV0gyTEu7EgcDPSsJULEADknFdVptuILdFxzjJ+tKT0HFaltQAxHTIqOEkSkEAKORxip3lSLAY jJ6VagtQ8YZhjODisJPqbxLlmSYwd3B9KvZGMe3FVFhClQOMU4gjJyfzqIpbie9ySUgAnNYt9MCC ARxV25fZETuPTpmsC5lAjdjycE81og8znb6YvcuQcYOOtVQSSDmiQlpCfU5zSAHqPWtzF6sfnOSf zpOemaesZI4B5608xY4IP0oEQYBPPOakVCASR+FSKgGWbAHoaZI4J4PFFxjCeMUAZwe4oAJ9akAw MAH8KBCAHsOtXbSykuJ1iRSWYgACm2lpJcyhEUsxIAAGTXpGgeHksIVkmAMxHJI6e1YVaiirLcqM Wypp/heJI1EspzgZAGK14NCsIiP3W4+rHNaioM8gZFOKAnoTmuXmb1bNlFFdbKCNcJGo+gAp0amI 4xx9KlChTnmnNgjkCi1xpCja4zgU1iBwD05poBP3eB1p2AcgnmhdhidR0FNK5OQOtSgEAAjimMAc 4PSmI81BOM44p2cdj+dR9eOlOz365rq6mKd1cdgY460oOM4OaYCefWnA0bhYcjEHB6U8HJznvTCc HORSggnk0g2JAzBuDip45QTgnntVXkcnp2pckEGhMC6zFgQB16kUhP7vHQjv61AspAwTnFPDgjJJ 54oWoeQ5SQBk5p5TIz361ESR7YpyuSMZ/Wi9w9RRnOAMVPERnk5x71DuB6DJpwY5BIAoTsHqWwcj 096N4UgcAHrVfzcAA5xUJlJORn8TRfqFjTVVYZB59aXYw6AEH1PNZYlcc7j+FSC6kBxu+madwsXV SQty2ATzxTzwMk8ngVRF24GcjjrSG5c9CBSv2GXweck/nRLcqg4IJHFZvmuSCzEjvS7sqcnoaLrY CRpTISDn8KQEAZJOO/NIigg+pBFIEJGRk0guO+UHAzScgkdvekwQcEUZIJPbpR5hsxcgjkHjpik4 wOOaXAzj1FGRngfWjULCAnGcnFSoAVxkcVFkY4p6uAoxkd6d7D0Ldu+yTAxyCKkZzuYMASDjNVEc lhjn0qzMRnOeWAJ+tHmTbqSpHBLAA00kLryCigg565GRiq5ChwoJIHIJpuQTySABTXG1gSc4PrRZ D8mVobmNG2yOiEEg5OD1rM1F4pNQDxOHGACQcjNVdXj26jIQPvYYAe4zSQRMkQJUgnBBIxVpdRbi lP378dTT9uAB3p5GZGPfijBzz2qWx2VhvABBBPpUEiMGEinaw6Edqs4z1qOUDIGOaI7g3oU2jO4s wUE9DjAJx7VXUyJc4lBPfBrQuUJQLjr3qiWeOQKxLADgelXZsm+pfWVY1DseB0A70sZaaTcx+UdA OlZ0iNKfMDhwOo6FfTIq9FMscQLkKMdPepkuhomaayiJNx4AHHvTEZ7qQMxIUdqoq7XL5z8g6DNX 43VIxngD9ahrsUmaInEURJOABwAf0qCEte3G5hhARnH8hVIvJdSAAkIO/tWhCViTAOFHv+tS1poN PqzWEqpEQTtRRg4/QfjUFsrXt0WbiNTkkenYCs17h7uURR5EYPP9Sa2oHS1g4O1QM5x19/rS20Qe Zq3GoLb2wjXAGAMA447Ae3rVTTYTf3ReU5jUgt7nsB/ngVj+c99cBQcLnqOiitkXC2duEjJXA6jq B3P1NHkJPqzV1jVA0SWsRAiTAIBwCR0H0AqfwvYLd3P2m54gQ/NngMeuM+nc+3Heuatw1/dBAdqD lj12j/GuivdQjtLEWsJ2Ltw2Oy+n1Pei9tENa6sn8UeIDqN0RGx8iIFYUHQnu2Pft+FSaBoEAspd V1EhYowSq92YcZ9wOg9ST6Vh6LZPquoB5SVhTliOoHTA9Sece/Paug8QapFIq2MJC2luBvCngsBg KD6Dnn6nrVX5tHsJq2pzOqsJEd9uDOSFQdQuev4/yz61Rj0pYYQzqVJGenPNdZ4b0QaveNd3RC26 Hc56A9wo7DgZPoAPpVPxFdQT3Mxt1xCvyQqByx6E/T/ED1pq/TYlo4O6Je+kAA8sAKAB3Gf8f0qN E8sSucqxQoM8AnI/Liugi0SVYDcyoQNxAJ6E9/rVO+sGmaOBBhjhsD0PSqUk9hW7kPhvTTc6nGrN sfkgdCSO2e3WvSX02wtLJhOiOdvzMwHA9B6CuO0WKGz1hHRyY41G52PBPfHoOKyPF/i2XU5nsLFi IQcO4P3vYe1VFRlqyZX2QTa3psmpy2cbZhBwrnoT9f61z3iKJUvY0Rs8ZAIx1P6/WoIrIovzAknq aSS2leUO7s4AAGSSQB0FVzLZbBy9WNjgIALDPGa0tKsG1HU4LVFLeY4DfQHn+g/GqZcICCRkDP0F bOmK9tbnaCJ7kcnusf8AiaIrUUnob85F7qZEYAtrf93EB0IHBI+uPyrTRAqgYqhYxrFGAABir0wd LUy8BBwCT1PoKqRMUYviK9MGnzLGeSpB9q5fSjbygBihAByGxxx710c6LcqyygkMCCD3zXIxaY88 lybcgRxMRkntnA/pWMZJt3NGrbGjMIUu0jt1QFiMBcDn1rr7S2ku9Rt7guWLMTISSSTjqSe+f61y Gk6WwlW6kkBIyAoGeenNekeHoAAHYDCqT079qmU1sgS6s2Y5VUYDXCDG0mI8ED15GfpR54J2i6JA 4/eR4H4nGajScxnAluY+pIAyuT1wAT/KpQ5OCbqFhgcSKAf5CsVdmozDzHarW8pPGAwB/n/SlNtL GQWtWRuPuE8j8qlMTyttWC3lOMgxsR+gJzUO0RNg28yHJ+42R/SgLC7mUHD3UfsTkA/TJ/lRglQz XKPns8YBH6Cg3IRvlmnQk8h1yD+HIoafzCC08IOD99AAfwwKGmwIZAjnKLC68cBhnP8An2qhqWlQ 39o8E1sFDDjYQSD2I461dYFzkpC4PQqcf403YADmBwexRv8A9VCVhHiWvaFcaVetHNGQCSVbHDD2 rGwVYHA47V7pqml2WpW7QXIm29RkEkH1B5xXlniDw5NpU5AJkgP3JApAPsc9DXRCpfRmUo9Uc8wO CwwBnHWmgEg5HFOZCpIIOBSd/StiBAxA5p27IANIQeBnPrxTgqkENkHsRTAMknJzSgDGQSMUhQjO CeKTJB5FAEygMwGQKeUwTtIOfaq2/BzgDn1p4lIHAAPrQBLhwMkn3pjE45z9fSo2mPY5FMLsQQel ADySR6fWkVijBsgkHOKaCxAznihQCCSSD9KQEkkpkJZjkkYGKjUnByaQkk9enWgA96YD89s0uCe4 pAORnNSKpOABSYCjIBJqFzk8HpU0hwpxwB61ADjvnPNCAcoB6960bKyjnIDtgGqAcAcj/wCtVi3e R5AkQOTQwsb50q2t1R1cOxOQB6e9XYQAAB34qrDEUjUMST3JNW4SQ2cVm3pqaRQtzbLK0QOM5x+F bGQkaqB0H6Vnwp5t2GxlYxgE+taHDHPpWMnqaLyIY7pjKVK456EVOzZGBwT700ooO7GDjrTC3fnN Gm4bFW8YbSCTisg2U2oF4YACcZJzjArRvicYx17Vzk+pS21wwicrxg471pBakzemhKfDzRkhmGfT NPGlWsC5lmUkcgCs6TU5n5LnNVmuXbgknJrZrsYmhLLAoKxKAB3NUmkUEngn+VQGQsSATSAE8k5F JWHcVnZm9qQKDyfrTtoHI5z6VNFA8pAVSSTwAM0NpLUCJRyMCtLTtKuL+dYoULEnkgcAeprd0bwf cXbJLcgxRk55HJ/Cu+sdMttMhCQRhcDk45P1rmnXS0iXGD3Zk6L4fh0pAzANMRycdPpW8oO3gdqR xk5AxmnAOMHIxXPu7vc0SsrIbkgnPfpUi9AAOR2prkhQcA+tReawGQOnrTsMmKEgnP0pNgKkEkml jlV8A8E0MMHODRcEN247jFIRk8AkikYk8ZIHrT1IA5PNNILjQ4BAPWg4IJ4z7UOgPPSogWQEcn3x R0sHU82Jz9aXOT6YpMgdRg0A5711mI7JJJB5pcH1waaDg8jrTwTgd6VgFGT0GaXPfNCtjsM0mdxx 3osC1FBORmnZJP8ASmjOMZxTsAAHv7UgsPGccCjcQAKbkjv1pc985oXcZLngEnrQDxjHWkUBgQRz 2pOO5yDSuBIGIApTITyMdKYM4wB1oP1oC/cXJPJNA45B70gPGO+aXaTyQcUDuBPbqKUEDgjNJtzy AaUA96LIQox6gUAnp1zSDPbvS5546mgBwBJANPGApzjiowQOCDzTgcAg96LWAliYBwccUocrkDvU IODgnGKXcM5B4pXYehJkscnpSkgqcjOKj3ADHf1zT1IIzmnpsMQkdqACeQCaMENjAo3AHIPPtR6D 0AjPUEUY46dKUOxcDHXvTtyn5SOnQ0IVgRsDIPSpN5YfMQcVDnBwRTlKnv3700A/fgjPekkfIGRg HocdakiKNIBLkqTzjtT7m2eJfnWIqcbWRwcjryAcj8QKNQsQxQ2pvlnmcrKEO0lNwGRgHGRyO1Sa o8Y0h4hPJcOWDF5OMY7AdhzVd4yVRgckEg/Si5w1g4YYAUnJPFO9kKyuY/Q57kCgYBGarTXDRSqA owVBOaVbtCQGGKOUE7blhSCT7GmSYMoHoM09Np5Ugj2pUi3zHAPTFC3EyOUAqDjnFUHTM444rfe0 VIwDgk9zWbcxBZQR2HStUiboy5IsS7lPPpSnEzhHO2Tovofb2NTMMNV/RLJLzWYVdQyqSSOx4NCj cL2RVt2MURLEAAHgnpT45vtLAAkKDzniuy1TwpaJaFoY2BOSQCTXHm2WxmdXY/Lxg8E1m10ZcZLQ vxYAwOAOpNRy3DSt5cZwo6n1rP8AtbzPsA2r064q/axAckgDqSahqxd0y/ZIsa5JwByTRdXj3DCG I/KOB/iaoz3RbEUWcZx9as2sQTBByTySf89KVtL9R31NS0VYIxzk9SfU/wCFRy3LzyiNOST+fvVO 4vQf3UfLHgkd6s2EQjG5jlj1P9BUpW9QWrNm2K2kACkFjySe59T7CqjyvfXAhiOckkn19SapXV4Z WMMXJPBx/KtCyRbSLgZdhyfX2o8g8zoIrpNMshBbsA5GQfQ45Y/h0/8A11l2qPqd+sCH5ASSxGQP Vj7f/WFZ9zdtLMIVO5mODgd/QVt2DpplqSMNI3LHux7D6Dv60Xtog82dDqWpRadpK6dauYwVzI3U hTySfcn+grJ8PacNZ1IPID9nTgAHlRnqPUnOB7knsaxJppdSvBChLszZYjqT/h6V1Iu00TTBaWhB nkGAw45IwW+g5A/Omn0Dcf4iubS7uxawqsdjZLhypxuP90Hv6A/U1gy2nlxG4uRsllXzCO6qR8oA 7Ejn6EVZtkhZTLP81pAd20/8vEnp9AcZ9sDuccR4v8StLM9pE+WJLTOD/Eew9gOKtR5npsLZXZna 54hBZ7SybCniRweo9B7Vj28yoeepHUiootrEkqB+FTE8dBx6CtFaOiI13La3qggsRjtT3vIWGdwB 9M1nck5yAPpTSATgcmiy3DmbWpdjntnulaVh5KnJA/iI6D6Vu2eo2m4yzXCBmOSM8Adh+FcmVIPT p7UYIHWqi0iHG7PQRrOmQgFrpHYjIVScD6n+gqCfX7W4YFrlSBwAAcD6DFcLlsZ9KdGWLAEnA5NE nzaDiuU6651e2SBmjlDMASBg9e3asXTb8wWs0ZBAlIBOOozn+dV0VnVmLhcYIGetWrG+ltpCFAcE EAMMjJ46VCglcbd2i7baxDbhImhdipIJBHPNd1pfiHSo7I+dP5RJAKlSTjuQQMV5utsHux83BIJ7 npWkIiQFAHAwD61HJFlXsej/APCS6XtATWCVHIV4mOPzBqCTxNpYOTeWz55z5TAj8gK4RrYJHliS c1SkUZC9c88dqOSI+Z2PSF8Q6I5BaaI+hDkc/QinDXdLIIGohADwBKMD8jXmixKOg4+lDxADhgee lHJEFJs9Qi1uxfONUtjngiRlP6n/ABqVbuKZzsntJAeAEYH+RrygplRyAaY0QA6jPvS9nHuO560Q Cx3WytjuD1/Mf1o3RjICSpnsDjH615MokQgo7KeuQSKl/tK/iHyXtwBjjEpH9afs09mF7as9U3A5 xcSAAZw6k5/Ej+tVruGK5gaKWW3dWGCsijn9RXmTa3qZG039wfrIf8aRNf1iAfLfz4PYuSD+B4oV HzJ50Xtd8DTRh7mxCyJyTGpyw+meo9uv1riJrWSKUoylWBIIIwQfeuuTxVq6D5njcejQr/MAGquo 6g+qgtPZ25mPSRQwb+ePzFaRUo6Nkuz2OVIIPPUUu/kce1XZLVkbJHIPUcimSwK6l0Yhh1B/pV3J sVt4NAAJxnIpNpPQc0MrJgEEGgQjJk4HrS7CUJIOQcY9aQkjvmkDECgBdmFJPrxmlOAowMHqTnrT dxI6nijqACTmgAJAJ5PvSZB6mkwQO9OCkn2pgHbAGKcASMDtQF/T2qVEJIFK4DVQn1NXLWxuLtzH bQvIwGSFBJA/CtXRfDN5qrqwjaO3yMykdR7etegWmjW2jNDFbJgEDcSclj6k1hOqk7IuMW9WeQXU FzFIVeF028YIwQfeqxJB54r3i4sra5GJ4IpBj+NQcD8a5nWNA8PRBi0RST+5Exz+RziiNbmdmhun bVM8vijeaQIgJJ4rpdN09bZeQDIepx0q1b6fBbEmJCATkZOTj61djjVAWIxn0rRybJS6jGTCAYJN MLmOMkYyeg96mxvOATjNRrGXlDMMhenuah9zVI0LNBHbrnqeTVgMScjt2FU1kYLwcA1LvIUckk1l e5S0JXkODzx0qJmAXIP50xmJOD3qN3IXAppXF0KmoTBImZjjA4xXITEPIWAPJ7mu5k8NX2qwK8bI kZ5AcnJ/Sq3/AAgN9/FNGMdeT/hVqrCOhm4tnF7B1waXZ3IruovAEx5e5QEegNX7fwDbKcyzsxHY DAoeIgthcjPORGc8AnPtVu10y6unCxROxPYDNeo23hTTbYgiAMR3c5rXhs4IMLHEqcdhis5Ynohq n3PPNN8FTzMDc4iBOcHk4+ldfYeHLKwUFIgz93bk1s7ADggZHQ0vH/6qwlOUnqzRRSIcMgwCSB2F KGJ6g/jUoGDk8g8UFQOelSUN4ABJwewppPBIzmpCQewIHrTMryAKpC1IjKQMEcGopWPBAxmpmG7A AH40wqQMAjPfPSncPUbG5GARgmrAckDFU3iIOc5zT4mYHacECnbsBO5BB24z2pikjv0pu4k4IxTs E4IJFPUB+SaGAxyaQHAweaUkFcE4FFwTPMXGSGHAPX2NIOfwoU8YJ4PT2oz+prqMR5PPB7UA5ANN zzSkk8EDilsFxwIB6U7PGQetM5PApQR2HPahhccMnkmnA44ByKaAepPalBHTGDTGmPwO4HPrS4B4 FMyTwT0pwwRkk1Ng3Y5TjGB09adjHfrTMknqOKk4K59KQaBkZyCaOM9MU0YHQ0pPJHBBosAfjUyH IAPSoR069KerYHNHqGhLgZ6mhkAUnHINIByDn3+lByRyc+gpLYaVhnfPelzyc0gByKAMjqMj1ppg +wuTyQc04DsfrTc9+KVQSeM+9AltZik4GR+NLyTigEZGTwacQQMkdaNh2GEEHmlzxgdulDEA8jBp AcnGMg0LuGg/BKA+p5owSDx2pcYjAAJOaUHgkikhrYaARg8ZpM9znNGSOtLkY5FO3YOgFhjGeaQH B6dOlGARkd6OmPSi40hwJ6g0rOxAySfamBiMjoD7UuQaExWGXoc6fM0blXX5gQcHiufaeeUAPNIw BHBYkV1EKpJG8chxGwwxxnAIq1ZadbwwoLea2MYz5kkkYZmyTjAIOMDHGauLIldHH3mNyEjPyDP5 mqpGR6Vr68sY1F/KQJGSSqjoBnIFZm3PQVUX1ESQu0eCCRW9YfNGGwMnrWIqZ7g4NblhkQLjpVWB ssXQG0E8D+dZN0AXHuK0p/3s8SE4G7J561Bq1o0BMoIKE7Rg85wD/WjoTYwjgy9R6c10ng6DzNRe UgHauOnvXObSST07gV2PguErIWxwcZ96uIPY7pgNoBAIA9K4nxbBEIxKiKJAeuB0Hr612jk7SegF cf4gjjubmNZnCQx5eQ56gcY/HNTO1rijucqlm32YXZhKxkkEgcfX2FVp7mUnyo12p3yOTV7UtaSd DbwxARKML6flWVbyyIwWU7o+wPJH09qzjF2uzXmWyL1rEeCBz3Jqae6CDyYep4JHeqcss0sZ8kbY wcEgc1LbQMDkg57k+lQ11Kv0LVrFhsnLOfSrVxeCJfKiOXIwT6VTkuliBjiwXIwTSQJhtzcsTn6V NraspGhZRiMb2GXP5ip7i88pdqtmQ8DHYen1qlNdLApRSC5H5U20jLuHc5OcjPaps1qBrWEWwea/ LkfkP8akubt3kEKEFzwAOwqpPdi3jCqcsenr9asaRGoYzSkb+SMnoPWjZXBbm5psEWmW5nk5lI69 +ew+v8qiluTKztI4EjAlm7IoHAHuf89arXt2AoY8knCJ6+59qx72/S2gZpGyq8nnlm9BRFfeDZd1 nWSkENpbEm4kXbEi8kEnAwB1Iz+JJNcdd6NJBDI04BnB3Mc5IPcVGt3cHUDeSklm+6QMhR2AHpWk 08mpRspIBIJkc9Pc57VpqrWEkmrszobdWjBUZBHYU/7MewGBUtm4MsgDEoDhT7DgVdBiA75zyMcU 23fQEkZptgRk00W+TgDp7Vp+ZEOoGKPMhx93k0XYNamb9mxkkDpUbwhBkjjGa1TJATyv60zEJJJF DYWMoRAgEDrzSiEhgQP6ZrWRbUAAqcdDg1MBYsRtVwMdyKOZhymTDAjnLFwB2ABq2lsgceWpIHVm POatSRQrIPLBwRnn1py4HBHFJybFZLYihhYzjbxg/jV0Wx3AkEDOTmnWxAkAIzmtJggGAoOfSmrs l7lB03nJB4HA7VUkCqwwowBgnpWq7gdQMdKqStCQSR+VFwSZVwpUbTg/nTGUZz3p7ToowKYZo24x yPQ02tAWjGbAeMH6UhiyAQTnOKXzVLDDYwelPEiAElgMdaktIiMRCkg9vSqzrxnn0GKvs4MRK8g9 KqEBmUHGM4PtVQ1JmVPLJJABJ78Zp5i4GRg1M+otFIyRIojU4BA5PvSpfiUhXRTnr8vNXdk8vmVj EDwPoan8nZGAAQT3qYQjzgB0znn0qz5ahWlc4UdeP0pN6glpYzDblskDtzUMlirDO0A+o4rXW4ti MgHB96aUSQ7ojkHqDijmd7NByvc559PYE7eT1A71BNBMBtYEgcDI6fjXReQckgU9YAT8wBx14ouK xyXlvHkFQcjAyOlRGM9Mdq7B7GCQ/MgGe44qNtGgboSPyo5w5Tkth5FGzB65rp30KMnIf9KYNCiB B3ZHsKfMhcrOcC56ZzTljZjwCPwro/7GhQZJP14FKmmJk/LweBmjmCxhxWxLDIJ9cDNdfo1r4dtA kt4008o5wUwoP0B5/H8qpC2AGFUflxTlgwOg/ClJKWlylodrH4l0mCMCGW4AxgKF4A9OTxWffeKY ZZVaCByV6FyAD+Vc8sC9xzUqRBeQOh5zUKEEO7NG412+u127hGp6hBj9etUQCx3uSc+vOacEyMYA +tP2BRjOSOaasth3uREYI460nJBA4qbBY5IAz3qKQsCI0GWPp2HvSbuNIME4RByep9BVgRBYwuen Wmxx+WuCck9TTycgAZqW7lJWY0IQOoNGSOM8inHAGBnJqPIByTz0qWrjFJOMk5Jqzp1m1/dqoB8s HLH29KrRo9xKsUQLMxwAK7HTbJLGBUHU8sfU1nUkoqyBK5djQJGqqAAowAO1OwSQAMUoKnJxjNOG 3HPOawS0KsRFCDyKcAR/+unOcggHH1poAGATTtpcQ7A74FIQB1x7c0uDt+UDPeo93Y8GgB2CTgHI puBnoRinIcE5PFKxBIAP/wBemDGg4XAHX0pSeCKXAPCnGB2oII4J/GhC2ImBPA496YQQMAc1Kw+X AzUZJXqM07hqIMAYPWlXBBBxntULuQcd6cmTycn3p6bgOdAOg6dqgbIOQDVggjoT701uRj86aYPy IlB3cgVLgjAHSkZsACmCXnB//VTBIcwI5P6UgIGTj9aQuW6HFMIYHpn0oA82GQec0pJ4IpoBHNOU HjI4rp21MQAJIp2CSOtJgg5x2o565zRcNOo4nGadk5pgz0INLzyOwoDoP5BwSfrS4I7/AJ03JPXm jr1OaFcEOyfUCnZOR/jTM4pw9SOlIGPGeMU9SA2DnHeo88Y7GjOBjIoWg9iQggkE0Z45pCSQD6UE 9cUaoBRkDkGlB54GaYCTSggnp79aTQaEoPOcnpQW5GCeO9Rkke9LnHUmj0BvoPyepI4ozkHPB60z PQUoOR0oYC5IOBUiHDAk+1R84zSjGQQelA7W1Hcg47VKwLICCOO1REjAIpwk/vcjpxR0AawIOCet OVsADFDoRhs9Rx9KYAdwBGeaQFsA7Rx+lMZgOCM5709nUALnJx+Iqu5JORn0FGowYgnINJkkYBpF Izz3qQlVJyM596YWIySeM4HanA8AZ5FMJBPTikAz1ByPei/cpJEoIJGTV6G3MkRMaCRgclR1xWdg DBOelTRzNGmUcg9iOKEkJosiIxsyMuCQDjPT2qXSwjQSo2SYySACBnBxVJZWMm9mJJ6knNRTNLFL IYpWQsM8HGc1S10IehQ11CLmMk9Qe3vVBCRxjgVPMHliV2JYgkEk5P61XQEE81cdFYl7koOASDkk 1r2six24LEDjuaxRkt16elXAFMQLlweCDnj3/pTbsCTZemmRyhUgkHnHWmamryuAmSWUEDPeoIhF tJDEtkYyO1ahMAhjeUkPkDgdsHP64ocvduFtbGBFbSjCMpDnjH1rvfDMSQo2SOBgfXpXO3Uuki1j cJO0wclmLAZGBgAAHnOec1veHVYachYEEkkA9cZ4/SnTk3uKStodLM48skHI9q808XXDNqSxhiAF yQD6n/61d/IWWInHFeZ69KsmsTE8gYUDOegqpbkxRkqp3DAya3dH0iS/kBIPlg4LY/QUmh6DLfSi WQFYQc9Ov0r0Ww05IIFVFCgDjAxS8gbMdfCtqVBUsj7cAg8fjXP6po13a5iMigEHBGRn/CvRduwY BrD17UbKzti1wqu4+6vBJPtUyhfYqLdzz+C2eJipGCDgk9qla8jiBSIhn6EjsarT34uJWdyFVjkq hxge1JbxKcNEwKEnkjBqLW3NE7liFGd9zcsT35q88620eMZc9BVM3a2/7tPmkPp0H1pkYeR975LG pae5SZdgV5pRJJ8xPQHoK1Q6xR72PHQDPLGs1JRAmCcv2A60w3DFi7nLHoB2+lQ1d3Y09LF27uwg aaZgCAM89B6CuclvI765BkYqinCoemP8aL1L27fARgg6D/Gqv2KaLJkiYD1I4qopb31Jb6Fm6lRM glWGAQoOfpk1XUzzg5YqhxwBxj6U9bNyQTE5P0NTeROAGETgdM4IquZdwSFjIiUBfxPrTzKcZJ6e 9R+VMesbflSeTLzlGx9KV0O4pmyeD700ykcA5PfmnC2kAwEJ/CnC0cDOw49MHmmmhERkYnPQfWnK +cdcmlaCU9EYD6GmLDcKc+S+PoaLrcRKxKgg55Henx78gAE++KmhDMMSQN9SDzVtUTg+W4IAHANK 6HfqNJxtJ4PSnqQcjPT3pLkExgpE2VIONp6VVEw4PQ45qWUtTQiYCRTkYzVtpwSQeaxjOQMg8g55 q0jyOAVjYnGcgE1SdlYlrUuPIJFKkjHPfFUXAKAZ5700XKgYLDIPWonkUnIbqc8U0gHhFLEkmnGJ MZzUXm9ww57GnbwTkEZx3o8xX6jJEABIIP0oiCupDgHmlJyCf6UwEqemM0ntYpMmlk2xhFGM1Rnu Uij3sCOwGO9SurO4O7AHHFVLkMyFWGQDnIqoOzsTJNkCSs+DtPJ4q7EgiYM6HHBHuKi2qIVIBz0B Jzj8KeCcEmQNgYA9Ku3cnbYum5AZ2AAGOMdqS6nLQIu4gE5IFUwWBySGBGMDvVdlMtwV3EA8gZAA oaW6BN2JQUY4B6c1e09CCxLcEZwTWfGFtZhvCkZycc5q7ayqWJUAA5GD6UnfoNM0MAnIOBTwAOAf emqQQMYx9adwDjH0rNtotJC4BPGCTT1AxgD3xTOAOnWjHOc/hmhSuPlQrAZJB5HUCm4c8AYB7+lP UquQCAT2PenI4C4Bz+NF7CaRF5AByQSR60eUCCcfpUoyGJJ4PQCm5Ynv60c3UOUi8oHoP0p3kN0x Uq5HX+dS8gAjknpRcTSK3klcZH40oUDIHP0FWMFh8xIzSEIoOSAPUmhuwJFckjkD24pcEDLHHrTJ JctiJS2B1HT86jMbucysMf3QeKL9WO2o9ZGlO2HnHBcjgfSrCwrEuF5JOST3NRK4RdqjrxxTt5II zik2MVjngc/TvTlKqMHrTDnbnNRO+e+KQD3fJ4xTER5ZAkYLMTgAUsMEtzKI4gSSecdvc11mlaVF ZR7mAaY9WPb6VE5qOiBK+4mk6WtmgeQBpGHJ9PatfC44Htim4GCOOtBIDAEdBwM1hu7sq1hykDk5 Hb3p4ZTkKvPfNQZUZB65pysOuB9BTtYLkxAPBxzS7QBzTVfAyQPWkL5PU0luA8OCuARUbBTyOtBJ IByBTQcjkZp2AaQc5BOKFyxwcg9KeDkZBpWcAYJ/Gk9xX6APlwAMnvQ7tjIGKbuUnAPIpN7k44x6 07DE3kDkZoZwV5AzUZyG56U7g89PrQ9AInCsMcD8KVBjgHHFO2qewoAAJBAHpQLYMjaec+lRMzDO BzmnyA4AB49utR4IPJPSqXmFwYEjnn1pvlZ5B5pST0BB9KQEgYJHPSmFxMlDgDIxSq+4kCgg5JJz nvTGBGABzntRYZ5zuyck8daeGA4I5zUI4HHWlBx1NdNrmF+hPvGKUEDnioB1IGSacM4+tDQD8gjI 4oBA6Ck+gpfc9qLDDI6d6cCcnAFJxjvS4HbH40ri2DJJ6HmnDofc03J9MUe9A/MfyRwOaUDPI703 B6nH4UuQOSTzRcRKvIIzjNNJySc4NICO/PNOY5Oex9KRWjQcZPU0AgHJP4CmknOB2peOv4U/MXoL k5zilycZxSEjHXk0hOQB3oD1HZOTnFOBxwR9KZk9xSg9CDzSsD1H5HQmlUnI+tMGT1/ClORj1zQC JBgggdQc005HTPXuKaGw2cdadk55/Cjcd7j1ZiNpOCOQDSq4LAEd+1RZIwSe9SDDMCBil1HYJCGc kEk5/KgOQMDB+tMYENk9z1pQTnHHPtRfQaQb+oxRnJwaDjOcdKTof1pFC5BOcHinAEtxkU3ODyKc GHTFADgoOMcgetGw7cnOKUEAZPXrUiMCQrYGTTXkLchAII96vxi0+RpnIkI+VCPlOB3P1xTJrWWF csqFDyHDAkj6ZyPxFVLgDy4mB5DEH6Ef/Wqouz1JkuhduLcCzeOWaGZ2IYGNMBRzx0HtWDJZlckD 9K3IUYxAkHBGc47VH5IIOOfpVxZm1bY54IUbkY9a2IYke3UFQRjjNMubUEFlHNLbyEBVKnI61Vk0 JaCvbIi5UYI5zTbgbrKNsEEZA9qtOAUOPSocK9uFdgqhgCSOgprYNShp1i13cF2yY0YFnYnA9h7m vStMtkjtEAUdBXmNjPJ9rSBHLRGUEKOhPQGvUTOtpYAjJYLwO9VBWQpWI9RlEcDkDoOgrhtP0F9S 1KW6nBWEuSoPVuev0rqbZ59S/wBYmxCT7kitqK0SIAAYAAFN7i2G2dhHbQKqqAAMAAdKss6ouAOl MkmESEnJx2FZF/qDE+VbrukPfsPc0mx7kOveIYNMgJJ3SEEKg6k157KL3W70yyluT1wcKPQCuwXQ I7icz3ZM0h5JboPYCtKHTIYWCQxgu3QA9Pepbb2Gmkc5pXhyEOiCAySHq8g4A9QK7UeDrW7tUjdQ jryHAyR7fStTStKWBQSuWPJOOtdJCkVoivKMucBVxnn1PtU+zT3Dmex5J4r8BnQ4Ir+Ji0Uhwygc r7kdga5N5xB8iKWY96951KZJ4nE4DIQcg9MV5tqltay3bC0gAB4Zjzn8TWc7wLi29DiHkcjcc8no O9SWCSTXilm6A4HYDFdN9gUgqyrjGMADFRwadHazmZATkEAY4FZ+0TWxdmPtLJd4aUd+4rSaVIjl QvTAYjJH09D71DuOwYB54+lJ5TPjPI9DUKQ3FX1FWJZAWABPXJ700ooADKCOhBGQakVNoAAOPQU8 BSpBGD70t3cNEtBIoLWX5TAiv2+UYNSGwtwMGJfyqKRCqEp1FTW84KhZSM9iTW8JRejM5J7oQWVs M/uU59qetlbf88U/KpWUgZHIqNZiWKlSDkgVsoRI1HrZWpP+pXP0qUWNqT/qU/Kmq+eM4qYOQOaO SPYLsRbG0PWBB+FSLY2hPEC+mcVWa5uVY4hJUHHHcVat5XckshXPTPSjlXYLvuPGnWhH+oT8qqt4 dsXcsEC5OcAD/CtEEkEH09KkU4AHXFL2cXuF2upkHw5ZDqP0H+FTRaNbQAhV3Z6A9q1NgJDEcgcc 0uOc0eziF33OK1zwyZczWihXByVAwG/wNck9rLExV1IIOCD1FevugY4Izn2rC1bQortC6gLIOjAd fY00rA9Tzvynzgijyn6AfWtG5tZrWUxzIVIPB7EeoqHcOgGPerUU9mTdlQpIBkAmmgzA4w1XMjoS KbuAJOOlDiF2QCWUHn09KR5A4IIGCKuDaRk4zTDGjckdKnlLUnaxXtLOe5jISB3I6EDgVA0EqSMr EZBIIBzzWtBf3Ngu22fapBHABIz0xn3rNAeRiWOXJySe5qUpX1G2rX6jBE4BIGMcgmomJDBiMnOP TFWijgDAOO/NNZCcBwcZzzRqCkmJLECqEAHIyec0RSKHyowDjjtmt+efSE0lViUNPjBHl4Kkjucc /mawhgnlV/LH8qUW2tRuy6mmjFkBVgaQu4HTOPSqUUnlnCgDPapBd8HIxj0qXF7lKa2ZaWc4xnp6 ipBKc9Qao/aUyTnoOeKkWYE8EfyqXFlqS7l3cCMMmR6daiaGM8gun+6SKjWUdM/lTvMB4B/Wkk7h dMkEcmMpck47MAaT/SlPymNh7gio/MwOCKPMPrTDdEu+6zkiPj3NOD3R6tGMexIqPzGx1zmkDMTw RQmLQnAlODJOc+gGKk2ICSxLEdMnNVgx7mnAkgZPFL1GiVpQPlUcVGeTnJPPrTcDqTk0m8A5HajS 1g2JVx1PFLuUDIxUGWkYBQWJ6ACtG20a8uACyiNfVuv5VMpJbsNehRMpPB/AVds9Knu2DMCkZ6k9 SPatq00aC3IZlLyerdj7CtFVKHIGPrWbqN6ILdyG0sIbSMKigep7n61a+ZckcUAHHA/KnKGJ5BxW W7GKC5XqBmkwx4IGPWpCAOMY9qTIAxtyD3FUgIgrEkAdOlSKhOCRgjr71LGygYJwacVA6AUavUCM 7s4xx/KlQEEgNn6U4jI44puCvOaQDmDA5J/Go2cA4I+lPyeOcj3oYrgDHWmAgJAyBTSpI549Kcfx /Co2JDck4oXcVhcADAPJ9aTOOxGfSgv2Apc/LjIz2pjFwWA7n0NIVYjHSmIzIckZzUobIJ5z2pCu M2E9TjFMJ2kg8+9Sk4wSSKilAxkHIoGhnmZORyRTWBIzzQq4OQamBB4I61QEBXaAQOTTCDjORmrJ UEYPHpUJ4B3DgdKasJkZY9PTrS5I5BpMAnqOacwAGBxxQB5oOwpcd8ZOKRTgdc07Ixkd+DXUYgDj kjpTgSOQf0phIPFLnA6UmCJM4OKMZOP60wEYzSg+/egZIMY6/rRx69Kap9aUnJ/lQLcXBOM9O9KA QcA8GgNjigHnIPFA2rC5wMAilzjg+lGR0zRjkgdqQkmHOMj8acpyuCcEU3HFKox15FA1oHAORS84 pcjBGOaMDFK/YBM89DgDvSgHnNABHWlHJ54p3AXGcmgZzg8UYJPFHfpUjtoKCQcd6dnkmm4OOvNL +PNMa0EJOeOlKD9TmkIPXGc0oA6Gi4hOpzUkZKsMd+KZgAjIJ4zUqBV+YnJHbFJvQaTew3JDe1HB 5AwfSlCknp1p2wnIxip3LS7jAfzpcj1xSZAOD1HGaMEdcUBYMUuCOBQCOg6UpHcHpR1AVSeg78U9 QcEnrUXIIH41OMEZ6D3poTEZmIAJJxS8NC6kcdR7UxQzMQAT9KenJKnIyMGrW5L7FawaZp5lJdkD ADkkCtRcA4xjA5FQwiyuIo4nM6IjFiqEDcT6nGe2PanXVzuuiygKrcgAYArTpqZtMfIisvSqLIUk JHY9Kt+YScnI9KidlGT1zQrg0R7wAATnP6Vm3NyQGiVupwf8avuSSADjmqq2ok1GFAu7LDI655qk xNFzw9Z2yTCdyC6gsAegrq0SW+Kgkhe4FZF5bRQSKkQK+ZgkA4AA6Z46da6TTJYwiKCDgAccZ960 jqrEs0rS0SJQAAMCpLk+WuQR0zQ86gZXOMVnXru0LO5KxgfiaTYLUz7ieS5uCsTHIGGOeFH9TzUk FoqKADkg5JPUn3rmHv7+W8NlaqEVmOCRg469av29trMV5HGLgjcASCdwx+PSouupVmdCygYRRukP AA/ma19M04IAzDLHkk03TtOKAM/zOeSTXRQxLAgZhz2FOwh0MKQIHccnoP61VvLoAF2bGOaLu7CK XZgMc1xuraq10xjjYiMHBI70pSUVdlJNsbq2qtdOYoyRGDyR3rKLYGQcD3prEjpyaTIcYbgiuKc3 Jm0UooapJbBGKkCkjAHGPSnCMEYB6CpQMDkdqlIbZWYgAAk5pwfoRjPapXiVxkgA+veoDgHjnHFN aaMT1JMg88A9aMgcj86QE7MACkKArkcHpTEIxyDgnI6UzYCx56ingFV5BJpoPzcjFFgJYrloCFkO 6M8e4q2UVwHQgg9xWc2c8kc1LbytCcg5U9R2raE+jJcU3dFvpT1YHrnikGyVd6HPqO4pACOhrfcz tZ2Jlb3qVWz9Kqg5OCcGpUfnOaAsWlb3walUjPXmqqsTyKlVjnjpQBaVgKeCDyTVcMc8GnhiRzQF iXOe9IyAjFNBxx6U8HjNAGbeWEUwy6AkdCR0rHuNPtkOHgQ54ztFdSwDDBHFVJ7ZZVIIB9qzlHqh pnKto9lKSVQofYmqsugJuJWRgO2Rmt+e3aAnC5FVsseDxk5rHmktLlpRfQxW0GcKCkiMPfIqq+kX sRJEZYexBrqELIeoOeKlLkDlc9+KaqzQOmji5bK6VctA4HrtNUgkkbklSPqK9CXa6524xTZLaOXB YA49QOaft5X1QchwgcqQSOO9OLowzgcV2MmmWrg/uEI7/KOary+HrNgCiFSewY/1qlXXVEumzkGR GBI6nrToVXPzAGuml8NQk4R3U45yQR/Kqh8OTrnY6sQccgiqVaD3BwZlGJOgwKYbdT0PetGTQ75C QqKwx0DD+tQjT72PhraQ/QE/yrRTg9mQ4vsZ5t2JOD19qUQOCCORVxo3QgSKyn0IxQAe9Oy6C1Kp RgcEECjDDrVsjPWm8ego5QuV9x6g80oJ6k81NtU9V60qxKSB09OaORMrma2YxNxIwalMbjncPyp6 QDcMGrDRE8D071DjZ2HzMpEkcE5p0YaRgoOc8U6SJsnin2iN56gjuOlJxSVx872NqHw6GAL3BORn AGKuRaBapyys+OzH/CtRACoxkHAFP44HIricm2borQW0MQIjiVMegxUykggAfSpdhxwOvtRsAIJH FQO4mAecUYbPtnil2HBIyBQCwA2jOO1UrWEyRQoAJHNOyMZzUe8jqKFyTkknnpRYB5wcEjmo2yAS DSsSpIJOPbtTHfPIJJoXkAKGJyBn0qUOwxnvTY2JOCB+VPwCOuDQmAocen50m/J4HFIQSAScYpoO ASefrR5gKSMYyPrRk560hKk5xQuPb2o6CDIPQkmg4IGOlIwGcg9KQgEZB/CmO9xrryCp703kMckg 08EAkE9e1Icg9AfrQhWDJIz1xSeYQcZ4pQRySCD70jAHoQSKaQCmU4zTC+SSe9N46E5x7UoUsxIx zRsFwUgkml3EYFBXAycD6U3B6g/SgB+TnGTUbEE4OeaUFskEj2xTGQk55NNAKsQIzkg0jjAwD+VN LsDkA8dqXcfQ4NC0A805B5zSgk9eh4pMZAJPSlUDpiusx8hRgHpnmlBPoKQHj6Uo5IP6VPkG44cg DGaAQDk0hJ9OBRnpih9g0H8H+tL0wB0NMB7HFKQTwKNhjs5HJpwweKbgkZ4owcZovcLodkgmnBs9 6Zg9SKUZHOD7UwH5OaUZ6D1pnUU7PftU2AfkEZ7nrRkYwelNGQOOaXPPNKw7C5HYfnTsflTOT0pS McZoEkP4HfgUoBzjApgOBShjjOe1LzHYXAxmlA4poJHBFLkEY45pj6C55Hc0E88UgGOoNLgE88Uv MaXUeDjGeakQjIJAI9Kh9s9KkQce4NTe40uxYKqhGBknpjtS4VOSDkikjJOAfqOKlYAjLHgc4otZ Bd9Sk2Mn60gBxweaUkFicdaQkjBH40blCAc5/SlyOh/SmnJPWlU5OOKBbDhkjrTixCAAd6TGE7Zp mTjnr2phYsREcAvsOeoGacx/eAhtxJ5OMZqqpx1NSKT6cVSE9SPesV0VLAHOQM9vWpZJo2YAEE5q O4s5bq4h8lSWbCk9gSQBk9u9MSzUwXDxTBzBgPxgcnHB796tK+rMnLoWRJleCDzgYqNyCcE+/NQR AhuTxT5DgZHNUtxX7jJZduTwcDiq8F2yTyEAGRlAU/3TuByPyx+NR3D570adbm5vlODsXk+/pVIT VzpoDJMFaXBYgA4rTjJiUEHB6A5qvBGFwQBxTrmUKpAOMCqvbUlK7NGHU1jyZZFAHBJOBVme9gli DJKHXGCAcgmuGjibU712eXbbxnBJOAT6Cuos7cEJDCo4AAA6VlKprZI1UNLsbNAl3cRG0iKSg4Zi MEDHr+VdXpumlcM/zOQASeuAOKXStKESgkZY8kkV0UMKwRhiBnsKpLqzO/RDYYkgQMwGewqvd3IQ FmYACnXd0qKWYgAfpXF6xq73DmKJjs6E+v8A9anKSirscU2w1bVWuXMcbERg4J9ayShx8pBB55ph fcBwCfSnZPAAxj3rinNyepuopKw1g2Rg5I7Cm7HGGB59MVYQZ5yc4pxQk5JFSlbUZCCwUAjHrTlZ iMHrU20YwBzTQPXAxTVxNFdnYkqSQc9RT0Uhe5PUmnNGMnBFOSM464AoAYBkHijBAwB781IQAMg0 0kkjFF9RbELFhj19qiRwzEA8+4qwSS2COnQ03YAc4AwapPoBDIMMMg+1ChgOR9KmIBHIpMEgHHAo TswGq8kRDIcHPT1q/DMtyvTbIOqnvWeygHIPfpTGmwQVOGHQitITaJa6mryCQwOaUZGMmq9teLPi OUgOeh7GrBBXg5rdNNXRFnfUejkevtUyvntzVcZHQ5p6tjmmBaV6lVgeh6VVV+OakDACi4vMsA9j TwSRgVArkjHpTww9RRsImB44OaaRxk0gIPQ0tA7WIpIlcHIBrJubIrJuUkD0rbwCKjdARjAxUSim hptPQ56VgvJJyO2KkjkDgEdT61cuLQZ3KOR2xVKQiIZYEAHsK55RaNU00SHK5wAB14oBJ6nAAzUc biXLDJApdpLE7SAahsfqS7w4+VgCKWPJbg9PeoViG7I71MoVCcAnHNF0P0JRk8nr3pSGXDEAA+lR hyWweB60rFjkAnHvQwJMLnOBTgATggAn2qsgcHDHI61OMkjI60g8xxiUggqCOuKiawtpT80CY/3R U4YA5PTpTw6jtx609d0BnvotjJ1gUdjjI/lVWbw7aEEoXX2DZ/nW0TnGDkUoGDnIxQpS6MTjHqjz nUymnanJbfMUXGGPXkA8/nT0dXUMpBBHBqv4mIOu3PPAYA/kKr6ZISWjOSByK9GN+VNnNLc2YjyB nNWM8kDt7VWhHzAj1q2OAR3qJbjjsVZDk+1S2SEzocdxTZUyDgVPp4BukBB+8Afzok/dYK9zsI8B Rxzj0p5HGMc/TpTQCAMcDFOyc5yK861tWdQoJAxnmlODznpSHik5wSM5p+YhxIJBxj3pBxkjHtSZ OBkYoBPUDmh7ADAEgkYP0p2ABjimtkHkUEHg460tBi4GDz9aaVUHgD64pwJA47UhbqcY46U1sAik DJAoLcEkc9KaTkY7H0oPyruIJ9vSloAu7IwTTCDnBORTshsFRg0oXPJB60BcQEdMDpTSTkE9M1Lj JGOKYy4OMg+1PcAzk5HSmbscEGlIIGPX0oJAGM5zQIMAEHilZckZNMJOcA5p271HTvQMXYD1JwB6 00p6HA707cp6mkIGcjn2pi2GMgPIBA70gJAwOvvTySQQOKZyM4H4mjcLjC5Jwf0pcnBANNJJyTgU /Cn39xQMarEA5wKXOTgGgrzg4x0puABwDTAdkZwR+lNDKRwORQCOmTTgADwc5oewjzI9R39qXgZz SDBxxzRnH4V1GNg7ZHSnA4PNN746fSlBPAJpWDYf6HnmjgEHPFICAPpSA88jinqDH5HQUuQDjjnv SZBHSgYHWkMeGGOnTmlznnpTR+HPWlBBzSt2AdkEYIpQQcAikBBzxR174prsA4Y5PpSg5zTQPfNL yMfypMB2eeB9abnnpS4OPWgjjNABkYpcknkcUmSQfQ0AYxk0hp3HAnOR3oHHJzRgd80Akjp+NDHs OznpQBxnvTcknI6etO4BB9aQJXFxj8aXgYJHGaBjGKTp2pPsVFWQ7GBweadGQAc856VGSScjHFKr 4PFIHsWVcEZOcjoamLb4nIPOOxqmpOeuKnVguQCOetF3YNCDIBHpQSB05odcHGfpRtJAIoGmHvRj ng0bSCc9qXkckUWY2wwSeKTBJzjpRuzmlBBPHWmhO4gBPAFSYUcFxkdj1pm8A+4qTzxtwETPqVBP 59aokebuWCLEbYUnDDsR2zU/2tri0MJVVU5OEUAEnucdapcSRsowMjNRRyzIp2qDngGqu7WIdkLE MKAcZHBNRzvggGpMMinPXkn61VmYMxBPQdKtJ2JKsxJOAM5roNEtPKiDMBlufwrEtIDc3SKASCcn 6V2dtBsQADAAx0q0hPYlAwCT0ArH1e68i1dwfmwQM+p6VsTELGBk5NYM1lNrOopaxKQikM7dgOw+ vJpSEn1M/Q9OutTuBEhIRSST2BPU163o+kJawouCSABk9ah0LQodOt0SNAMdTjkmunhiWJAxH0FO 3ULt6D4oliUMQM9hUF1dBFLMQAKS5ugilmYDFcZrGrvcsYoWIQHBPrSlJRV2NJt2Q/VdVe5YpET5 YPJB61hvuPJGBUgcqADzmnlRKMhce9cM5ub8jeMUiJFXABGD61MsQ4Yc5p6xbRnANPABAAPOegFS ihgXrgdqUIQMc4AqdUXA3ZBFBQE4Uj6CnfUViAoTyO9JsBJzU5RhkFSBSNgdCDmncLEOD0wPypNn IAJFSjrTSQDx+lNXBDSijAPJ9KaQM049sUrYwM8mk1YLEW0Fs9KCncnI64p4weKACetMLIhI44HW mMSAABnJqwFHPTNNZAR0AxRpcXqVCmScnk96aEVeAOR3xVooBz1/CkKKDkDrT9RMr7MjOCD7Vat7 w5EU3PYN6fWmYGMYpjrk5AxVRk46iaTRpFMAEHIPQ00HHArA/tl7K9KOC8PAK9x7it2GWK5iEsLB kI7dvY11WukzPZ2JVJBFSBuxqHucdKVTigC0p44NOB7ZFV1fB6VIHHFAWLIP409W4wTiq6se1PBz g5oCxNnPNAHcnrTVYEUuAelAhGQEZNU57QOCcDP0q+cYpjKCc+3Spkk1ZjTtqYhgMYKqSpHTFKpd B8xzWjNAHGSMHtWbOHiPIBGa55QcfQ1jK6Hgcgg4J5AqTaD2JJqIOHIJXBA7VOJE24AwelZ21KSI wFDEZwfSlJPGB14owpOTnNLuUnk9O9PQLBgDjH1p2AcAHGO9ISPTJoUqeCCDQg2Hj7vJyfU0pOQA COKbx0FN5HU/SlbsMcHI4HGKeXwo5wKiHI565pjt8pycYppAcbrumpcanNKt3Gu85w4II/EA1Std Oe1mLmaGRSuMo2T+Rwa19WiDyFh39qybZAs5x1AOa64ybSRhKKuzRgGHA4q7sJGAKp24HmAgZq8x IXjAFOejJiu5XcZGSam01QbuMDswqGUgDAPJqzpQBvYyf73NEvhbBbo60L8oOc5FIFx1Ofen9vlI 9qQDIGRzXCdAu0gZ603OOp5NDORwKZg4znPel6gPByQT+NBwAQBnNNGcZPHpilORgk8GiwEgyAMg 00EEHPWgOSQO3bNGcHJ/SgaFyCRyAfamHIJAGfc07Ocjj60Yz1FAEfTrSebgcgkE4qRkBPXimbDg 5OM9KEgEwCQeQDUqnA4xg1CiMeDjANSjjp2/nRZC1Bgck4+mKTtkg5PvTlOScnj0prgDgnihDEOe hFMI7kY9Kk+ULgHntTWUnvTSFcizk9KN4BIxmn7MDg0hiA5JzRZDGgg9qcSMde1NII4HNAHc5o2D YRyAuQck/pSA54JpxAOfQ0h4AAGaPIRGQAccUoLJxnj6UrE8YNNwQck5pgO3ZHA/Sk3DGDj60gye MnmmsMcGhAK3JyO9Ioyck4pASBgAYpQcEHNNA0eaAnHHT3o5INJkDqeBS9Peun0Mh2cDmjOOxpuc dKC2RjJo1F6jxzjApwwO+aYhz0zTwAOe4o1sFtBwJPagDBI9DQCDkjgmlzzmgYpGPf2o4NO3AqRt 59aTgfSlYGgA4449aBkde9HJOB0pQeQcYo1AcCcDFKcHmm+3qeKXqetJldBckdaXPBANIOAcilwD g4PpQIAcE5P4UoI9zSYAPNKSBjByaBrQXIxj19aMjOBmmE57YpaQDhxwaUEDFNU8kY96UkY6HAof caVxxP40oIJ9M9KYcdRTgcY6DipHrsAA6U5Rk5xmmAjp+VPUk9KQ7WHhDgnI4qXaOtRgkDA/HNPB JAOOKNQYrIXAA4pgR8jAORUoAChieQckU/eoYEEc00tCbjShBBIPPtTZFJIwOnep96vjn9aRiCOM Ed6dh3a3KbAgYximZxzUzKCxAGAaiKAqeelC00HfQZvJOAck0uTnHNM5U9KlQg9QD9apLQl7ixMd +OADwavLHEYhHa3UaMWBaSQEYGOQBz3zz34qk4UEMCMnnAPSqzkiQnkDOR71UWTJXL2ouqz4QAoQ DkDGSOCax5WJkyOhzVvULhNkSqQWJyQD0BFVowZXVVHU4FWtrsi1ma+hWuf3pGM8V08a4UAVnWMQ iiVR2FaK7nIRBljwB6VaWhD3Inia5l8tByePpXTaNpCW0YwoyeScdTUem6aIgGYAseScda6KBBEg JAz2FHKtwJ4o1iUEgewqK4uVRSzHGB37VHcXIRSWOAK5LVtVa5YxRMQnQkHrSk1FXZSTeiDV9XNw xijYhAcEg9TWQWBGQPrTSCFwT75piqzDIJyTXHUm5M3jFRRMuGAB49OKtxoSMggjHSq8a4IJwCBx VoMoGBwR1rOw0x5UhQRjmkiwSSV6dMetNDkHGcipQxA54BosUkNAJy1PRyDkEAj0FRMWPRgKcoIA JbBz0xTtcFclkLEexquc55qSQkgKSM0wjAwCcChIT1EJwMAAZ9RTcjHIp3BIwM5pHUqecc0ANUA5 PWlKg9B14o2lSCBkHtRvK5APXqKNxIaUCkjI6U4ANwKRSewzUkeOhBFDBaibAATxnGajIB5HFWGA CgAHjvUTKM5JH4UK4NELLjp+tNIHTrUrcnB6U1gQKpdgaIcAHPbFBwwJ7ClYEnAqK4YxWsjk4wpO aa3sKzsctduHuXYdyansL2aymDxNweqnoaqMSScjvTk4GcZrtSsrGG7O0s72G+i3Rna4+8h6j/61 Tcg4I5FcVFcvFMJYWKsOQRXTafqsV6BHIAk2Pwb6Ukrq6H5GiCACM05SeoPWmbSOoNJkg9KXoBZV uOuc1KDkYBqpvPHFSK/QE/rQmHmWlYk4NPByKrhgehxUitjvQBPnv1pcg81Fk+tO3c4oCwpAIxUE 0KupBAqbOeKQjHB6UmrqwIy5ITHwBx0qMggjnFaTx5BB7nj2qjJERIDnjPIrCdOyujWM76Mi5I54 xSgHGQc1IFBJUHINIYyoIPTsTWFmjSz3G84z3pu9lIyCc+najnpjFHPQEinqA7eRyeaPMJ57Uw4J xnmm/NngDAouxE3mZPA/WmSuSpBHFHQZ7imSEkZANUlcVjLvArKcjpWOIgkhIHBGK2rlTgnB5rMl GMkfStad7pETWg6AASD1NXGBIIHaqVsf3gHv6VbkJHAPFbS3MoleRAAOScVc0cZvUznGapyA859K v6Ln7anfk/yonpBjiveOqBJHXA7cUpznGBSbgOo470pYEZ71xHQNAyMcYpGGBkelKeBnPvSAjHNK wIaMkYpQSQc9aTdg5FNzzxxQgsO6nkflTiRgHHtTAT7E/WlJO3GaBai5wfWnBwBnB9qiySDjNG4H jvQ7jsODgsSelPOMY5wahAAOSKcSQAaLdWFuo8HBOe3tQSSQe1MByCcE00scZPNFgHs+BnIyaazF hgGmckE4JoOAAR3osFxwOeDzUgOBgiolwDknkc0/IJyT+BoQtx+ODg0nUccUhJxxTMnPXNOwwYkH im7gTnke1OOSST+VRMSCe1Aa2HZ5II4pr8jANN3kDB6Clz3osIbnHA6+9BJA569aXaOpHWggYODT 2CwgOD15FKSp4NM/nQCR1zQkCYEcgd6AQPrQR1IOSaZghu5pgf/Z ________________________________________________________________________________
Date: Jun 04, 2011
Subject: High Oil Temp Issues - RV-8A
Thanks Chuck. We ordered the louvers yesterday. I think we will try that first before modifying the oil cooler assembly. We may also try some of Sta n Sutterfield=92s internal mods to the gear leg assembly. Robin *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *Charles Rowbotham *Sent:* Saturday, June 04, 2011 3:07 AM *To:* RV List *Subject:* RE: RV-List: High Oil Temp Issues - RV-8A Hi Robin, We had the same problem with our 8A. While we did not have the James cowl, we did try a larger oil cooler and oi l cooler plenum with minimal improvement. What worked for us was the following: Mounted the Oil cooler directly to th e rear of the baffling (std Van's mounting location)(made a gasket for the oi l cooler to baffling for a good seal and prevent baffling cracking and installed a double set of louvers on the bottom of the cowling to increase air exit area. This worked for us. It's worth while to note a couple of items: First the the IO-360 installation is a tight fit and almost everyone we talked with who had this config battled Oil temps; Second although we had originally increased the air exit ramp size it still was insufficient without additional venting are a and Third when ever the OAT was 90+ we lowered the takeoff deck angle and a s soon as we got to cruise altitude went Lean of Peak on the mixture (it was always a joy to watch the oil temps drop). I would suggest the lowers installation first followed by the directly mounting the oil cooler to the rear of your baffles (or atleast shortenting the oil cooler plenum and making it straight path. Regrads, Chuck & Dave Rowbotham RV-8A (sold) ------------------------------ From: robin(at)PaintTheWeb.com Date: Fri, 3 Jun 2011 11:37:56 -0700 Subject: RV-List: High Oil Temp Issues - RV-8A After 20+ hours of flying in which time we were resolving a Fuel Injector issue and a few avionics/electrical issues we are in good shape everywhere but Oil Temperatures which are also driving up our Cylinder Head Temps. We are running: =B7 IO-360 200 Hp standard compression =B7 James Cowl =B7 Metal Plenum (home built) =B7 New RV-10 size oil cooler (designed for 260 Hp) =B7 Custom oil cooler plenum Photo below. The issue is we are seeing oil temps up to 225 when OAT=92s are in the low 80=92s running about 23/2300, 3,000=92. The CHT=92s are being driven up by the high OAT=92s to mid 390=92s. The oil cooler plenum is a BIG 4=94 inlet with a smooth ramp down to the oversized (260 Hp) oil cooler. While we have not been trying to resolve this for very long on the 8A but w e have a great deal of experience with oil temp issues (and the James Cowl) o n our RV-10. The long & short of the -10 issue is the inlet rings are too small to properly cool the CHT/Oil. The only reason I went with the James cowl AGAIN on the 8A was the MUCH larger fleet of flying 6/7/8/9=92s with James cowls & few reports of cowl design issues for these models. We have toyed with the idea of swapping out this oversized oil cooler for a Niagara unit but I don=92t see how we are going to find 25 degrees with tha t swap as this is already an oversized cooler to begin with. It would be pretty tight but doable to relocate the oil cooler closer to th e rear baffle area but again I don=92t see getting 25 degrees from that. The temp issues are the only remaining issues to resolve. Any thoughts woul d be appreciated. Robin Marks RV-4 Sold Standard Vans Cowl - No Temp Issue s RV-6A Sold Standard Vans Cowl - No Temp Issues RV-10 225 Hours James Cowl & Plenum ' Significant Temp Issues RV-4 25 Hours James Cowl & Metal Plenum ' Signific ant Temp Issues [image: Oil cooler inlet plenum 001.jpg] ________________________________________________________________________________
Date: Jun 06, 2011
Subject: Re: RV-List Digest: 2 Msgs - 06/04/11
On 6/5/2011 12:00 AM, RV-List Digest Server wrote: > We have toyed with the idea of swapping out this oversized oil cooler for a > Niagara unit Positech used to have a great set of test data on their website... their cooler was fairly efficient, but the Stewart-Warners were even a little bit better. The Niagara did not rate nearly as well. One technique to get more cooling is to go from the single pass 260 HP cooler to the two-pass 260 HP cooler. Dropped our temps about 10 to 15 F. Paul ________________________________________________________________________________
Date: Jun 09, 2011
Subject: FS: RV-8/8A emp kit, tools and DVDs (new/unopened)
Due to an unexpected financial burden, I am looking to sell my new/unopened kit, tools and DVDs. Everything is still in their new and unopened boxes. I can provide photos if requested. Code: Description Store Part No Price ================================== =============== ======== ===== RV-8/8A Preview Plans Set Van's Aircraft $ 47 Empennage Kit Van's Aircraft $1,390 Electric Elevator Trim Option Van's Aircraft $ 276 Toolbox Kit Van's Aircraft $ 22 RV Training Project Van's Aircraft $ 30 Avery Flush Swivel Rivet Set Aircraft Spruce 12-00741 $ 30 Ultimate Bucking Bar Bucking Bars $ 102 Main Squeeze Model 22 Cleaveland SCHKITW $ 322 3" Pneumatic Yoke Quick Change Yoke Pins 1/8" x 1/2" Flat Flush Rivet Set 1/4" x 3/8" Flat Shop Head Side Rivet Set 1/2" x 3/8" Flat Shop Side Rivet Set 1/8" Universal Cupped Set Avery Vise Grip Dimpler 3/32" Aircraft Spruce 12-00611 $ 37 Avery Vise Grip Dimpler 1/8" Aircraft Spruce 12-00612 $ 37 ExperimentalAero Dimpler Bill Benson DRDT-2 $ 285 Vice Grip Fluting Plier Aircraft Spruce 12-00609 $ 37 Avery Hand Seamer 3-1/2" Jaw Aircraft Spruce 12-00608 $ 38 Edge Forming Tool Cleaveland EF60 $ 33 CD - 27 Years of the RVator Van's Aircraft $ 25 DVD - Les Bourne Series Van's Aircraft $ 29 RV Builder Basics: Vol 1 Getting Started DVD - Tools of the Trade Van's Aircraft $ 14 DVD - Pre-punched Emp Construction Van's Aircraft $ 33 I live in Warner Robins, GA. You can pick them up or pay for whichever mode of shipping you like. I'll pay ground shipping to anywhere within the contiguous US if you buy the entire lot. __________________ *Jason Ellingson* ________________________________________________________________________________
Date: Jun 09, 2011
Subject: sudden high temps
I've been flying my 6A here in southern AZ since last august. I haven't had any heating problems until last week. Cyl. head and oil temps on my Bart Lalonde IO-360 were much higher than normal. I carefully inspected everything, took off the cowl and cooling plenum. Everything looked OK except that looking at the cooling fins from underneath the engine there was a LOT of peeling paint on them. (This engine has always had peeling paint.) On closer inspection I found a lot of fins that had a "flap" of paint attached only at the edge of the fin but laying down flat on the fin's surface. This could cover a layer of air between the fin and the paint, thus "insulating" it. The flap of paint that isn't laying flat could impede airflow. I called Bart and he opined that the peeling paint might be the cause. He advised me to remove it and see what happens. I spent a couple hours tonight trying to get the loose paint off using dental picks, tiny brushes, small files. It's difficult because it's hard to reach and the paint is pretty flexible and tough. Has any one else had this problem? Is there anything better to clean the paint out with? Something like a pipe cleaner but with brass bristles would be just right, I think. Any suggestions? -- Tom Sargent ________________________________________________________________________________
Subject: Re: sudden high temps
Date: Jun 09, 2011
I've got a Bart IO390 in gloss black and have 170 hours on it with no signs of pealing. Oil temps always in the 180s, CHTs well under 400, and EGTs <1400. I wonder why the paint is pealing? Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN thomas sargent wrote: I've been flying my 6A here in southern AZ since last august. I haven't had any heating problems until last week. Cyl. head and oil temps on my Bart Lalonde IO-360 were much higher than normal. I carefully inspected everything, took off the cowl and cooling plenum. Everything looked OK except that looking at the cooling fins from underneath the engine there was a LOT of peeling paint on them. (This engine has always had peeling paint.) On closer inspection I found a lot of fins that had a "flap" of paint attached only at the edge of the fin but laying down flat on the fin's surface. This could cover a layer of air between the fin and the paint, thus "insulating" it. The flap of paint that isn't laying flat could impede airflow. I called Bart and he opined that the peeling paint might be the cause. He advised me to remove it and see what happens. I spent a couple hours tonight trying to get the loose paint off using dental picks, tiny brushes, small files. It's difficult because it's hard to reach and the paint is pretty flexible and tough. Has any one else had this problem? Is there anything better to clean the paint out with? Something like a pipe cleaner but with brass bristles would be just right, I think. Any suggestions? -- Tom Sargent ________________________________________________________________________________
Date: Jun 10, 2011
You can buy pipe cleaners that have small wire bristles mixed in with the so ft fibers. Might be worth a try. I also had similar paint peeling on my Aerosport Power O-360 but no high tem ps that I attribute to it. I used a "chip chaser" tool to clean the loose pa int from the fins. Dale Ensing Sent from my iPad On Jun 10, 2011, at 1:39 AM, thomas sargent wrote: > I've been flying my 6A here in southern AZ since last august. I haven't ha d any heating problems until last week. Cyl. head and oil temps on my Bart L alonde IO-360 were much higher than normal. I carefully inspected everythin g, took off the cowl and cooling plenum. Everything looked OK except that l ooking at the cooling fins from underneath the engine there was a LOT of pee ling paint on them. (This engine has always had peeling paint.) On closer i nspection I found a lot of fins that had a "flap" of paint attached only at t he edge of the fin but laying down flat on the fin's surface. This could co ver a layer of air between the fin and the paint, thus "insulating" it. The flap of paint that isn't laying flat could impede airflow. I called Bart a nd he opined that the peeling paint might be the cause. He advised me to rem ove it and see what happens. > > I spent a couple hours tonight trying to get the loose paint off using den tal picks, tiny brushes, small files. It's difficult because it's hard to r each and the paint is pretty flexible and tough. Has any one else had this p roblem? Is there anything better to clean the paint out with? Something li ke a pipe cleaner but with brass bristles would be just right, I think. Any suggestions? > > -- > Tom Sargent > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: RV6A CHT Problem
Date: Jun 10, 2011
I'm seeking advice about a CHT issue with a recently completed RV6A with 30 hours on an O-320 D1A ordered from Van's. 1.5 quarts of break-in oil has been consumed during those hours and I'm getting ready to take plane out of service for an oil change etc. Climbing out at 120 knots produces 415 degrees F. CHT temperatures before getting to pattern altitude and cruise at around 65% power produces about 395 degrees (at ambient temperatures of 70-80 degrees F.). Oil temperatures remain below 210 degrees and both CHT and EGT temperatures are reasonably uniform across the four cylinders. Baffling (both above and below the cylinders) has been checked and the inlet area "ramps" are sealed on both the inboard and outboard ends. There is a 60 - 70 degree F. difference in EGT temperature between "full rich" and "leaned until the first cylinder peaks" during tests at 8500' (conducted without wheel pants or strut fairings). There is no fuel flow instrument but fuel pressure readings appear to be highly affected by engine temperature. On the ground it is 5 PSI (without the boost pump) but the drops to 1 PSI or less when the engine is hot. Since the measured cruise and full power CHT values are slightly below Lycoming's "acceptance levels" for an O-320 they (politely) say: 1) they are "unable to help", 2) the engine cannot be considered broken before 50 hours, and 3) high CHT temperatures are usually cause by airflow problems. Van's referred me to Bart in British Columbia who recommends drilling the carb jet .006" oversize. Web search results suggest opening up the lower cowl outlet area via louvres (or simply cutting back the lower cowl) would be helpful. I'd greatly appreciate advice from those who have "been there done that". jack ________________________________________________________________________________
Date: Jun 10, 2011
Subject: Re: RV6A CHT Problem
If you don't have wheel pants/fairings on, the engine will run hotter, probably 20-30 degrees. Make sure magneto(or equivalent electronic system) timing is spot on. If in doubt, try retarding a couple degrees. Ensure you climb at full throttle. Make sure your throttle cable is taking the carb to the stop. When the throttle is retarded 1/4-1/2 in. the carb power enrichment circuit closes and the engine will run significantly leaner and hotter. Ensure there is at least 1/8" gap between your baffles and cylinder head at front of #2 cyl and rear of #3. If you sealed that area tight, the intake side of the cyl head is not getting cooling because there are very thin to no fins there. Inserting a double thickness strip of baffle seal there to allow airflow will help. They are correct that temps will continue to come down as you get up to 50 hours. Until then be sure to run at least 100 degrees rich of peak EGT. Some of Vans cowlings are marginal in outlet area, but that usually also shows up with high oil temps as well as CHT. I would not have carb main jet drilled. That takes very precision drills. Field drilled jets don't necessarily flow in proportion to expected drilling. If you want to go that route, talk to Tempest(or whatever they are calling the carb company now) and get a new jet of desired size from them. Many carbs have several different jet sizes for different applications. Some 180 hp O-360s have 4 different jet sizes resulting in different 10- numbers where the main jet is the only difference. On 6/10/2011 5:24 AM, Jack Haviland wrote: > --> RV-List message posted by: Jack Haviland > > I'm seeking advice about a CHT issue with a recently completed RV6A with 30 hours on an O-320 D1A ordered from Van's. 1.5 quarts of break-in oil has been consumed during those hours and I'm getting ready to take plane out of service for an oil change etc. > > Climbing out at 120 knots produces 415 degrees F. CHT temperatures before getting to pattern altitude and cruise at around 65% power produces about 395 degrees (at ambient temperatures of 70-80 degrees F.). Oil temperatures remain below 210 degrees and both CHT and EGT temperatures are reasonably uniform across the four cylinders. Baffling (both above and below the cylinders) has been checked and the inlet area "ramps" are sealed on both the inboard and outboard ends. There is a 60 - 70 degree F. difference in EGT temperature between "full rich" and "leaned until the first cylinder peaks" during tests at 8500' (conducted without wheel pants or strut fairings). There is no fuel flow instrument but fuel pressure readings appear to be highly affected by engine temperature. On the ground it is 5 PSI (without the boost pump) but the drops to 1 PSI or less when the engine is hot. > > Since the measured cruise and full power CHT values are slightly below Lycoming's "acceptance levels" for an O-320 they (politely) say: > 1) they are "unable to help", > 2) the engine cannot be considered broken before 50 hours, and > 3) high CHT temperatures are usually cause by airflow problems. > Van's referred me to Bart in British Columbia who recommends drilling the carb jet .006" oversize. Web search results suggest opening up the lower cowl outlet area via louvres (or simply cutting back the lower cowl) would be helpful. > > I'd greatly appreciate advice from those who have "been there done that". > > jack > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 10, 2011
A side note, a recent RV-8 builder with an IO-390 engine noted a measureable drop in temperatures when he shifted from straight weight mineral oil to AeroShell multi-grade after engine break in. If you used only 1.5 quarts over the first 30 hours I'd say your break in is complete. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, June 10, 2011 8:47 AM Subject: Re: RV-List: RV6A CHT Problem If you don't have wheel pants/fairings on, the engine will run hotter, probably 20-30 degrees. Make sure magneto(or equivalent electronic system) timing is spot on. If in doubt, try retarding a couple degrees. Ensure you climb at full throttle. Make sure your throttle cable is taking the carb to the stop. When the throttle is retarded 1/4-1/2 in. the carb power enrichment circuit closes and the engine will run significantly leaner and hotter. Ensure there is at least 1/8" gap between your baffles and cylinder head at front of #2 cyl and rear of #3. If you sealed that area tight, the intake side of the cyl head is not getting cooling because there are very thin to no fins there. Inserting a double thickness strip of baffle seal there to allow airflow will help. They are correct that temps will continue to come down as you get up to 50 hours. Until then be sure to run at least 100 degrees rich of peak EGT. Some of Vans cowlings are marginal in outlet area, but that usually also shows up with high oil temps as well as CHT. I would not have carb main jet drilled. That takes very precision drills. Field drilled jets don't necessarily flow in proportion to expected drilling. If you want to go that route, talk to Tempest(or whatever they are calling the carb company now) and get a new jet of desired size from them. Many carbs have several different jet sizes for different applications. Some 180 hp O-360s have 4 different jet sizes resulting in different 10- numbers where the main jet is the only difference. On 6/10/2011 5:24 AM, Jack Haviland wrote: > --> RV-List message posted by: Jack Haviland > > I'm seeking advice about a CHT issue with a recently completed RV6A with 30 hours on an O-320 D1A ordered from Van's. 1.5 quarts of break-in oil has been consumed during those hours and I'm getting ready to take plane out of service for an oil change etc. > > Climbing out at 120 knots produces 415 degrees F. CHT temperatures before getting to pattern altitude and cruise at around 65% power produces about 395 degrees (at ambient temperatures of 70-80 degrees F.). Oil temperatures remain below 210 degrees and both CHT and EGT temperatures are reasonably uniform across the four cylinders. Baffling (both above and below the cylinders) has been checked and the inlet area "ramps" are sealed on both the inboard and outboard ends. There is a 60 - 70 degree F. difference in EGT temperature between "full rich" and "leaned until the first cylinder peaks" during tests at 8500' (conducted without wheel pants or strut fairings). There is no fuel flow instrument but fuel pressure readings appear to be highly affected by engine temperature. On the ground it is 5 PSI (without the boost pump) but the drops to 1 PSI or less when the engine is hot. > > Since the measured cruise and full power CHT values are slightly below Lycoming's "acceptance levels" for an O-320 they (politely) say: > 1) they are "unable to help", > 2) the engine cannot be considered broken before 50 hours, and > 3) high CHT temperatures are usually cause by airflow problems. > Van's referred me to Bart in British Columbia who recommends drilling the carb jet .006" oversize. Web search results suggest opening up the lower cowl outlet area via louvres (or simply cutting back the lower cowl) would be helpful. > > I'd greatly appreciate advice from those who have "been there done that". > > jack > > ________________________________________________________________________________
Date: Jun 10, 2011
Dale: That sounds interesting. Can you suggest where I might get such a thing? On Fri, Jun 10, 2011 at 2:57 AM, Dale Ensing wrote: > You can buy pipe cleaners that have small wire bristles mixed in with the > soft fibers. Might be worth a try. > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 10, 2011
Tom=2C One other suggestion. Have you tried using compressed air to blow out the area as you are trying to clean out everything? Mike Robertson > From: carl.froehlich(at)verizon.net > To: rv-list(at)matronics.com > Subject: RE: RV-List: RV6A CHT Problem > Date: Fri=2C 10 Jun 2011 09:42:58 -0400 > et> > > A side note=2C a recent RV-8 builder with an IO-390 engine noted a measur eable > drop in temperatures when he shifted from straight weight mineral oil to > AeroShell multi-grade after engine break in. > > If you used only 1.5 quarts over the first 30 hours I'd say your break in is > complete. > > Carl > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Friday=2C June 10=2C 2011 8:47 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV6A CHT Problem > > > If you don't have wheel pants/fairings on=2C the engine will run hotter =2C > probably 20-30 degrees. Make sure magneto(or equivalent electronic > system) timing is spot on. If in doubt=2C try retarding a couple degrees. > Ensure you climb at full throttle. Make sure your throttle cable is > taking the carb to the stop. When the throttle is retarded 1/4-1/2 in. > the carb power enrichment circuit closes and the engine will run > significantly leaner and hotter. Ensure there is at least 1/8" gap > between your baffles and cylinder head at front of #2 cyl and rear of > #3. If you sealed that area tight=2C the intake side of the cyl head is > not getting cooling because there are very thin to no fins there. > Inserting a double thickness strip of baffle seal there to allow airflow > will help. > They are correct that temps will continue to come down as you get up to > 50 hours. Until then be sure to run at least 100 degrees rich of peak > EGT. Some of Vans cowlings are marginal in outlet area=2C but that usuall y > also shows up with high oil temps as well as CHT. > I would not have carb main jet drilled. That takes very precision > drills. Field drilled jets don't necessarily flow in proportion to > expected drilling. If you want to go that route=2C talk to Tempest(or > whatever they are calling the carb company now) and get a new jet of > desired size from them. Many carbs have several different jet sizes for > different applications. Some 180 hp O-360s have 4 different jet sizes > resulting in different 10- numbers where the main jet is the only > difference. > > > On 6/10/2011 5:24 AM=2C Jack Haviland wrote: > > > > I'm seeking advice about a CHT issue with a recently completed RV6A wit h > 30 hours on an O-320 D1A ordered from Van's. 1.5 quarts of break-in oil h as > been consumed during those hours and I'm getting ready to take plane out of > service for an oil change etc. > > > > Climbing out at 120 knots produces 415 degrees F. CHT temperatures befo re > getting to pattern altitude and cruise at around 65% power produces about > 395 degrees (at ambient temperatures of 70-80 degrees F.). Oil temperatur es > remain below 210 degrees and both CHT and EGT temperatures are reasonably > uniform across the four cylinders. Baffling (both above and below the > cylinders) has been checked and the inlet area "ramps" are sealed on both > the inboard and outboard ends. There is a 60 - 70 degree F. difference in > EGT temperature between "full rich" and "leaned until the first cylinder > peaks" during tests at 8500' (conducted without wheel pants or strut > fairings). There is no fuel flow instrument but fuel pressure readings > appear to be highly affected by engine temperature. On the ground it is 5 > PSI (without the boost pump) but the drops to 1 PSI or less when the engi ne > is hot. > > > > Since the measured cruise and full power CHT values are slightly below > Lycoming's "acceptance levels" for an O-320 they (politely) say: > > 1) they are "unable to help"=2C > > 2) the engine cannot be considered broken before 50 hours=2C and > > 3) high CHT temperatures are usually cause by airflow problems. > > Van's referred me to Bart in British Columbia who recommends drilling t he > carb jet .006" oversize. Web search results suggest opening up the lower > cowl outlet area via louvres (or simply cutting back the lower cowl) woul d > be helpful. > > > > I'd greatly appreciate advice from those who have "been there done that ". > > > > jack > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 10, 2011
Tom=2C Have you tried using compressed air while you are cleaning the paint out? That may help. Mike Robertson Date: Thu=2C 9 Jun 2011 22:39:28 -0700 Subject: RV-List: sudden high temps From: sarg314(at)gmail.com I've been flying my 6A here in southern AZ since last august. I haven't had any heating problems until last week. Cyl. head and oil temps on my Bart Lalonde IO-360 were much higher than normal. I carefully inspected everyth ing=2C took off the cowl and cooling plenum. Everything looked OK except t hat looking at the cooling fins from underneath the engine there was a LOT of peeling paint on them. (This engine has always had peeling paint.) On c loser inspection I found a lot of fins that had a "flap" of paint attached only at the edge of the fin but laying down flat on the fin's surface. Thi s could cover a layer of air between the fin and the paint=2C thus "insulat ing" it. The flap of paint that isn't laying flat could impede airflow. I called Bart and he opined that the peeling paint might be the cause. He ad vised me to remove it and see what happens. I spent a couple hours tonight trying to get the loose paint off using dent al picks=2C tiny brushes=2C small files. It's difficult because it's hard to reach and the paint is pretty flexible and tough. Has any one else had this problem? Is there anything better to clean the paint out with? Somet hing like a pipe cleaner but with brass bristles would be just right=2C I t hink. Any suggestions? -- Tom Sargent ________________________________________________________________________________
Date: Jun 10, 2011
If I remember correctly Tom, I purchased them at a tobacco/pipe shop. Dale ----- Original Message ----- From: thomas sargent To: rv-list(at)matronics.com Sent: Friday, June 10, 2011 9:52 AM Subject: Re: RV-List: sudden high temps Dale: That sounds interesting. Can you suggest where I might get such a thing? On Fri, Jun 10, 2011 at 2:57 AM, Dale Ensing wr ote: You can buy pipe cleaners that have small wire bristles mixed in with t he soft fibers. Might be worth a try. -- Tom Sargent ________________________________________________________________________________
Date: Jun 10, 2011
415 to patten altitude? That's real hot, real fast. Do I read you to say that EGT on any given cylinder only spans 60 degrees from rich to lean? I'd expect to see a couple hundred, maybe more. Too bad you don't have a fuel flow. Sounds like you are lean. Check for full travel on both the mixture and throttle arms. If they are both on the stops, your main jet is probably too small. I wouldn't worry about the 1 psi fuel pressure, hot. Just run the boost pump for a few minutes after takeoff and the pressure will eventually come up as it moves more cool fuel into the carb. Pax, Ed Holyoke On 6/10/2011 5:24 AM, Jack Haviland wrote: > --> RV-List message posted by: Jack Haviland > > I'm seeking advice about a CHT issue with a recently completed RV6A with 30 hours on an O-320 D1A ordered from Van's. 1.5 quarts of break-in oil has been consumed during those hours and I'm getting ready to take plane out of service for an oil change etc. > > Climbing out at 120 knots produces 415 degrees F. CHT temperatures before getting to pattern altitude and cruise at around 65% power produces about 395 degrees (at ambient temperatures of 70-80 degrees F.). Oil temperatures remain below 210 degrees and both CHT and EGT temperatures are reasonably uniform across the four cylinders. Baffling (both above and below the cylinders) has been checked and the inlet area "ramps" are sealed on both the inboard and outboard ends. There is a 60 - 70 degree F. difference in EGT temperature between "full rich" and "leaned until the first cylinder peaks" during tests at 8500' (conducted without wheel pants or strut fairings). There is no fuel flow instrument but fuel pressure readings appear to be highly affected by engine temperature. On the ground it is 5 PSI (without the boost pump) but the drops to 1 PSI or less when the engine is hot. > > Since the measured cruise and full power CHT values are slightly below Lycoming's "acceptance levels" for an O-320 they (politely) say: > 1) they are "unable to help", > 2) the engine cannot be considered broken before 50 hours, and > 3) high CHT temperatures are usually cause by airflow problems. > Van's referred me to Bart in British Columbia who recommends drilling the carb jet .006" oversize. Web search results suggest opening up the lower cowl outlet area via louvres (or simply cutting back the lower cowl) would be helpful. > > I'd greatly appreciate advice from those who have "been there done that". > > jack > > ________________________________________________________________________________
Date: Jun 11, 2011
> 3) high CHT temperatures are usually cause by airflow problems. > My experience paralleled yours almost exactly (same engine RV6 sens prop) except my CHT remained below 400 at a 120 knot climb. This was fine except after holding for traffic on the ground for an extended period. In cruise the temps dropped to 333 341 372 367. I thought my baffle seals were fine because they were wide and fit the cowling well. Except: I hand tried to minimise the number of breaks in the fabric obviously to 'improve' the seal. But what I ended up doing was causing some MINOR puckering away from the cowl surface at the reverse bends in 4 places. Above the inlet ramps and above the rear cylinders. I expected air pressure would force these puckers against the cowling. I was thinking that perhaps during climb the increased angle of attack air at the puckers above the inlet ramps was causing the front seals to flip down and allow air to escape past the seal, then in cruise the seal fabric would settle back where it should be.. Only several weeks ago I was determined to solve the issue and drastic action was necessary so I popped the cowling off and slit the material at these puckers to allow them to lay flat flat on the cowling. The test flight following this surgery I was able to climb full power to 6500 at about 90 knots and the temps remained below 400. In cruise the temps dropped to 325 342 360 357, ie about 10 degree drop all round. Also my oil temp dropped (another!) 8 degrees. I am happy with the change. Possibly I need a deflector on cyl 1 to even the temps between 1 and 3. Good luck, Doug Gray ________________________________________________________________________________
Date: Jun 11, 2011
A 20 to 3- degree drop from putting the wheel pants and strut fairing on would make an enormous difference! I never would have predicted a decrease of more than a few degrees but I'm going to put them on and try it. Almost all of the baffling and carb linkage related suggestions have previously been investigated and judged acceptable. I'll also obtain a richer carburetor jet (rather than drilling one out with number drills on a lathe) as soon as I can find one. One last question on that topic. Is a "full-rich to first-cylinder-to lean EGT differential less than 150 degrees F.'" really a "recognized" way of detecting lean carburetor jetting? The Lycoming representative said he had never heard of it but I found references to it during web searches and talking to two engine rebuilders. Thanks for all the help! It is very much appreciated. jack On Jun 10, 2011, at 8:46 AM, Kelly McMullen wrote: > If you don't have wheel pants/fairings on, the engine will run hotter, probably 20-30 degrees. ________________________________________________________________________________
Date: Jun 11, 2011
On takeoff from a sea level airport the EGT should be 150 to 200 degrees less than a normal peak EGT. 1200-1300 on most engines is a safe takeoff EGT. You don't want to see much over 1300. But keep in mind the power enrichment circuit is supplying maybe 1/3 of that extra richness, so you won't see that big a spread from full rich in cruise with less than full throttle to peak in cruise. Probably more like 100 degrees generated by the mixture control. On 6/11/2011 12:34 PM, Jack Haviland wrote: > --> RV-List message posted by: Jack Haviland > > To: Kelly and All Others Who Were Kind Enough to Provide Helpful Comments, > > A 20 to 3- degree drop from putting the wheel pants and strut fairing on would make an enormous difference! I never would have predicted a decrease of more than a few degrees but I'm going to put them on and try it. Almost all of the baffling and carb linkage related suggestions have previously been investigated and judged acceptable. > > I'll also obtain a richer carburetor jet (rather than drilling one out with number drills on a lathe) as soon as I can find one. One last question on that topic. Is a "full-rich to first-cylinder-to lean EGT differential less than 150 degrees F.'" really a "recognized" way of detecting lean carburetor jetting? The Lycoming representative said he had never heard of it but I found references to it during web searches and talking to two engine rebuilders. > > Thanks for all the help! It is very much appreciated. > > jack > On Jun 10, 2011, at 8:46 AM, Kelly McMullen wrote: > >> If you don't have wheel pants/fairings on, the engine will run hotter, probably 20-30 degrees. > > ________________________________________________________________________________
Date: Jun 11, 2011
Best way in my opinion, to verify that you have the correct main jet, is to confirm max fuel flow at WOT as you are climbing out full rich flat pitch max rpm as near MSL as possible. Do you have an engine monitor that logs fuel flow? If so, then you can confirm this with the formula (0.48 * maxhp)/6 = fuel flow at WOT. For example this would be approx 14.4 gph with a 180 hp aircraft engine. Until you get this, you are not flowing enough fuel. Then work from there as needed with your oil cooler, intakes, exit and baffling to maximize the cooling effects for your installation. -GV (RV-6A N1GV flying 972hrs) In a message dated 06/11/11 12:39:12 Pacific Daylight Time, jgh2(at)charter.net writes: A 20 to 3- degree drop from putting the wheel pants and strut fairing on would make an enormous difference! I never would have predicted a decrease of more than a few degrees but I'm going to put them on and try it. Almost all of the baffling and carb linkage related suggestions have previously been investigated and judged acceptable. I'll also obtain a richer carburetor jet (rather than drilling one out with number drills on a lathe) as soon as I can find one. One last question on that topic. Is a "full-rich to first-cylinder-to lean EGT differential less than 150 degrees F.'" really a "recognized" way of detecting lean carburetor jetting? The Lycoming representative said he had never heard of it but I found references to it during web searches and talking to two engine rebuilders. Thanks for all the help! It is very much appreciated. jack On Jun 10, 2011, at 8:46 AM, Kelly McMullen wrote: > If you don't have wheel pants/fairings on, the engine will run hotter, probably 20-30 degrees. ________________________________________________________________________________
Date: Jun 11, 2011
On Jun 11, 2011, at 5:56 PM, vanremog wrote: > Do you have an engine monitor that logs fuel flow? Unfortunately I elected not to install a fuel flow sensor - an error I'm regretting. > 1200-1300 on most engines is a safe takeoff EGT. You don't want to see much over 1300. One more thing to worry about! My EGTs at full power typically run around 1350 to 1375 F. I had attributed that to the sensors being installed only about 2.25" from the exhaust flange. I'm also considering the suggestion to deliberately retard the mag timing slightly. Thanks again for the advice. I'll post my findings after making some progress on the problem jack ________________________________________________________________________________
Date: Jun 11, 2011
On Jun 11, 2011, at 3:56 PM, vanremog wrote: > Best way in my opinion, to verify that you have the correct main jet, is to confirm max fuel flow at WOT as you are climbing out full rich flat pitch max rpm as near MSL as possible. Do you have an engine monitor that logs fuel flow? > > If so, then you can confirm this with the formula (0.48 * maxhp)/6 = fuel flow at WOT. For example this would be approx 14.4 gph with a 180 hp aircraft engine. Until you get this, you are not flowing enough fuel. > > Then work from there as needed with your oil cooler, intakes, exit and baffling to maximize the cooling effects for your installation. > > -GV (RV-6A N1GV flying 972hrs) > > > > > > In a message dated 06/11/11 12:39:12 Pacific Daylight Time, jgh2(at)charter.net writes: > > To: Kelly and All Others Who Were Kind Enough to Provide Helpful Comments, > > A 20 to 3- degree drop from putting the wheel pants and strut fairing on would make an enormous difference! I never would have predicted a decrease of more than a few degrees but I'm going to put them on and try it. Almost all of the baffling and carb linkage related suggestions have previously been investigated and judged acceptable. > > I'll also obtain a richer carburetor jet (rather than drilling one out with number drills on a lathe) as soon as I can find one. One last question on that topic. Is a "full-rich to first-cylinder-to lean EGT differential less than 150 degrees F.'" really a "recognized" way of detecting lean carburetor jetting? The Lycoming representative said he had never heard of it but I found references to it during web searches and talking to two engine rebuilders. > > Thanks for all t > > > > ________________________________________________________________________________
Date: Jun 11, 2011
That is too hot for full power EGT. You need more fuel flow. My probes are 1.5" from exhaust flange and I keep rich enough for 1325 or less on takeoff, normally closer to 1250. On 6/11/2011 4:52 PM, Jack Haviland wrote: > > On Jun 11, 2011, at 5:56 PM, vanremog wrote: > >> Do you have an engine monitor that logs fuel flow? > Unfortunately I elected not to install a fuel flow sensor - an error > I'm regretting. > > > 1200-1300 on most engines is a safe takeoff EGT. You don't want to > see much over 1300. > One more thing to worry about! My EGTs at full power typically run > around 1350 to 1375 F. > I had attributed that to the sensors being installed only about 2.25" > from the exhaust flange. > > I'm also considering the suggestion to deliberately retard the mag > timing slightly. > > Thanks again for the advice. I'll post my findings after making some > progress on the problem > jack > > > * > > > * ________________________________________________________________________________
Date: Jun 12, 2011
http://smhyuksel.com/google.php ________________________________________________________________________________
Subject: RE: RV-List Digest: 7 Msgs - 06/11/11
Date: Jun 12, 2011
I had a similar problem when I first installed my ex-172 O320. Temps were high and Bert Lalonde at Aerosport Power in Kamloops, BC, said the main jet diameter would need to be enlarged. I mailed it to him and he did a good job. No overheating problems since (with or without wheelpants)! Ian Brown, RV-9A, C-GOHM > I'll also obtain a richer carburetor jet (rather than drilling one out with number drills on a lathe) as soon as I can find one. One last question on that topic. Is a "full-rich to first-cylinder-to lean EGT differential less than 150 degrees F.'" really a "recognized" way of detecting lean carburetor jetting? The Lycoming representative said he had never heard of it but I found references to it during web searches and talking to two engine rebuilders. > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jun 12, 2011
I suppose everyone has read this (My Engine Runs HOT) off the Vans factory site but here is the link anyway: http://www.vansaircraft.com/pdf/Hot_engines.pdf This lines up with my Lycoming manual as well. I am running a new Aerosport O-360 in A RV7a and also have had warm CHTs during break in. I am running the larger Positec oil cooler and never have oil temps more than about 190 but CHTs are warm. Running straight mineral oil. This is what I found on the CHTs: 1) Some change - Adding a shim to the rear of the #3 baffle to increase flow there (although not through the cyl fin) helped a little bit. Easy to do but little gain. 2) Some change - Sealing around the baffles helped a little, they were already tight but I have three 3/4 blast tubes plus the cabin heat in the rear baffle. Thinking about reducing the flow there a little. 3) Big Change - Putting a baffle in front of the #1 cyl helped a LOT! I went from a 30 degree spread between #1 and #3 with #3 running up as high as 440 in continuous climb, normally about 390 in cruise, to completely reversing the spread with a 1 1/2 inch baffle. Cutting the baffle back to about 1 inch made #1 and #3 almost even although they still run about 15 degrees hotter than 2 and 4. By changing the baffle size, you can change easily the temps on both #1 and #3. I worked the baffle height until they were about equal. Took 4 flights to check. 4) Big Change - adding the intersection fairing between the front gear leg and the cowl was good for 10-15 degrees over all cyls. I had a pretty large 2 inch wide gap that runs up the front of the lower cowl to make getting the cowl off easier over the front leg. See plans. I think that in climb, high pressure air entered the lower cowl through that large gap facing the airstream and pressurized the lower cowl area which lowered the pressure difference between the upper cowl area and the lower. The pressure differential is one of the major determinants of airflow through the cyl head fins. If the pressures are equal (never are) then no air would move at all. 5) Big Change - Initial break in was with the front gear fairing and wheel fairing only. No intersection fairings at all and the lower cowl leg slot wide open. (someone said draggy helps... Don't think so) Temps were much more controllable once all leg and gear fairings were on as it was much easier (less draggy) to climb at a higher airspeed, take off with no flaps helps or get them up quick. Drag adds heat! Airspeed adds cooling air! Now I have set my "Hot" limit to 420 degrees and see that on #3 in climb occasionally/frequently. Full power climb at 110 will have all cyl running 410+ quickly on a hot day. It's not hard to control but you have to be watching. GRT system makes it easy. Push over to 130 mph and they are all well under 400 in a minute or two. With 50 hours on the engine, I have virtually 0 oil consumption but I still have to quickly reduce TO power back to 23-4/2400 and climb about 130 -140 if the outside temp is high. 23/2400 will show all cyls about 375 +/- 10 in cruise. Not sure full power climbs are "cooler" if you have a CS prop as that equates to 2650 RPM and that makes a lot of heat compared to 2400, (my opinion) In my ride today, getting the RPMs back to 2400 quickly and higher climb airspeed is the easiest way to control the heat! Hope this helps! Bill S 7a Got the Grin ________________________________________________________________________________
Subject: LA area to Tucson routing
Date: Jun 12, 2011
In a week or so I will be flying from Brackett Field (LA) to Tucson. As an East coast guy, I would appreciate any routing suggestions from those who have done it, and recommendations for GA airports around Tucson. I plan to visit Pima museum and Davis-Monthan. Thanks, Eric RV6 ________________________________________________________________________________
Date: Jun 12, 2011
I typically fly out Banning Pass then go GPS direct. If necessary=2C I wil l fly a little south to stay out of Phoenix Class B. I do not have a recom mendation on what airport to use. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C503+ Flying Hours So. CA=2C USA > From: erwhites(at)bellsouth.net > To: rv-list(at)matronics.com > Subject: RV-List: LA area to Tucson routing > Date: Sun=2C 12 Jun 2011 17:45:10 -0400 > > > In a week or so I will be flying from Brackett Field (LA) to Tucson. > As an East coast guy=2C I would appreciate any routing suggestions from t hose > who have done it=2C and recommendations for GA airports around Tucson. > I plan to visit Pima museum and Davis-Monthan. > > Thanks=2C > Eric > RV6 > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 12, 2011
Subject: Re: LA area to Tucson routing
Eric- My brother lives in Vail (SW Tucson), so we've been into Ryan Field quite a bit over the years. It's GA friendly, but usually deserted. Just make sure that you stay well out of the various sensitive areas along your route. We went from LVK Casa Grande via Apple Valley back in April and it a pretty straight route from socal east, just not a lot to see except desert and the Salton Sea. The big problem with Tucson proper is that it is so spread out. I've not landed at Tucson Int'l, except when I'd fly there commercially as a subcontractor to RMS, but the Pima Air Museum area is obviously closest to that airport. I have no other good suggestions. -GV In a message dated 06/12/11 14:48:03 Pacific Daylight Time, erwhites(at)bellsouth.net writes: In a week or so I will be flying from Brackett Field (LA) to Tucson. As an East coast guy, I would appreciate any routing suggestions from those who have done it, and recommendations for GA airports around Tucson. I plan to visit Pima museum and Davis-Monthan. Thanks, Eric RV6 ________________________________________________________________________________
Date: Jun 12, 2011
TWFyYW5hIGNvdW50eSBBVlEgaXMgYSBncmVhdCBhaXJwb3J0IG91dHNpZGUgVHVjc29uLiBHb29k IGZvb2QgYW5kIEZCTyBqdXN0IG9mZiBvZiBJMTAgDQpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJl bGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiB2YW5y ZW1vZyA8dmFucmVtb2dAYW9sLmNvbT4NClNlbmRlcjogb3duZXItcnYtbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbQ0KRGF0ZTogU3VuLCAxMiBKdW4gMjAxMSAxNjoyNzo1MyANClRvOiA8cnYtbGlz dEBtYXRyb25pY3MuY29tPg0KUmVwbHktVG86IHJ2LWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVj dDogUmU6IFJWLUxpc3Q6IExBIGFyZWEgdG8gVHVjc29uIHJvdXRpbmcNCg0KRXJpYy0NCg0KTXkg YnJvdGhlciBsaXZlcyBpbiBWYWlsIChTVyBUdWNzb24pLCBzbyB3ZSd2ZSBiZWVuIGludG8gUnlh biBGaWVsZCBxdWl0ZSBhIGJpdCBvdmVyIHRoZSB5ZWFycy4gIEl0J3MgR0EgZnJpZW5kbHksIGJ1 dCB1c3VhbGx5IGRlc2VydGVkLg0KDQpKdXN0IG1ha2Ugc3VyZSB0aGF0IHlvdSBzdGF5IHdlbGwg b3V0IG9mIHRoZSB2YXJpb3VzIHNlbnNpdGl2ZSBhcmVhcyBhbG9uZyB5b3VyIHJvdXRlLiBXZSB3 ZW50IGZyb20gTFZLIENhc2EgR3JhbmRlIHZpYSBBcHBsZSBWYWxsZXkgYmFjayBpbiBBcHJpbCBh bmQgaXQgYSBwcmV0dHkgc3RyYWlnaHQgcm91dGUgZnJvbSBzb2NhbCBlYXN0LCBqdXN0IG5vdCBh IGxvdCB0byBzZWUgZXhjZXB0IGRlc2VydCBhbmQgdGhlIFNhbHRvbiBTZWEuIA0KDQpUaGUgYmln IHByb2JsZW0gd2l0aCBUdWNzb24gcHJvcGVyIGlzIHRoYXQgaXQgaXMgc28gc3ByZWFkIG91dC4g IEkndmUgbm90IGxhbmRlZCBhdCBUdWNzb24gSW50J2wsIGV4Y2VwdCB3aGVuIEknZCBmbHkgdGhl cmUgY29tbWVyY2lhbGx5IGFzIGEgc3ViY29udHJhY3RvciB0byBSTVMsIGJ1dCB0aGUgUGltYSBB aXIgTXVzZXVtIGFyZWEgaXMgb2J2aW91c2x5IGNsb3Nlc3QgdG8gdGhhdCBhaXJwb3J0LiAgSSBo YXZlIG5vIG90aGVyIGdvb2Qgc3VnZ2VzdGlvbnMuDQoNCi1HVg0KDQoNCg0KSW4gYSBtZXNzYWdl IGRhdGVkIDA2LzEyLzExIDE0OjQ4OjAzIFBhY2lmaWMgRGF5bGlnaHQgVGltZSwgZXJ3aGl0ZXNA YmVsbHNvdXRoLm5ldCB3cml0ZXM6DQotLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkVy aWMgV2hpdGVzaWRlIiA8ZXJ3aGl0ZXNAYmVsbHNvdXRoLm5ldD4gDQoNCkluIGEgd2VlayBvciBz byBJIHdpbGwgYmUgZmx5aW5nIGZyb20gQnJhY2tldHQgRmllbGQgKExBKSB0byBUdWNzb24uIA0K QXMgYW4gRWFzdCBjb2FzdCBndXksIEkgd291bGQgYXBwcmVjaWF0ZSBhbnkgcm91dGluZyBzdWdn ZXN0aW9ucyBmcm9tIHRob3NlIA0Kd2hvIGhhdmUgZG9uZSBpdCwgYW5kIHJlY29tbWVuZGF0aW9u cyBmb3IgR0EgYWlycG9ydHMgYXJvdW5kIFR1Y3Nvbi4gDQpJIHBsYW4gdG8gdmlzaXQgUGltYSBt dXNldW0gYW5kIERhdmlzLU1vbnRoYW4uIA0KDQpUaGFua3MsIA0KRXJpYyANClJWNiANCg0KDQo ________________________________________________________________________________
Date: Jun 13, 2011
http://tantalis.com.tr/google.php ________________________________________________________________________________
Date: Jun 13, 2011
Just to finish this episode, I spent several hours scraping loose paint off the cooling fins using small brushes, dental picks, pipe cleaners with wire bristles and anything else I could think of. Got a huge pile of paint chips. I finally got to fly it this morning. This made a definite improvement. In climb it performed better than it ever has. It seemed like I could keep it in a 105kt climb indefinitely. Oil temp 190 F, CHT usually < 400F. In cruise at 2400rpm with my fixed pitch Catto prop and 40 or 50 F rich of peak I was able to run at a little lower fuel burn than usual. usually it's about 8.5gph. This morning it was about 7.8, which I take as a sign of better cooling. It warmed up when I was motoring around the pattern at 80kt with full flaps, but no where near as bad as last week. So I'm pretty sure that remoiving all that paint from the fins had a benefit. Conditions were not identical - OAT was a couple degrees cooler and last week there was an inversion layer - it was 80F at 6500 ft - but I still think it is distinctly better now. -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Jun 21, 2011
Subject: compression test and mag timing equipment
I am getting ready to do the annual on my 6A and trying to figure out which cyl. compression tester to get. I have an IO-260-B2B. It has a 5.125" bore. I'm seeing conflicting information about the orifice size needed t\for such an engine. Is it 0.040" or 0.060" Also, I have but 1 magneto (Lightspeed Ignition on the right). Which magneto timer should I get? Do I need anything else to time the left mag? Thanks, -- Tom Sargent, N811WT , RV-6A ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: compression test and mag timing equipment
Date: Jun 21, 2011
Tom, I dunno about the compression orifice, but I bet someone on here could tell you how to verify a single mag's timing using only a continuity tester or the multimeter I bet you have in your toolbox. Anyone wanna jump in with how to verify a single mag's timing with a multimeter and the timing marks on the flywheel? KB ----- Original Message ----- From: thomas sargent To: rv-list Sent: Tuesday, June 21, 2011 11:13 PM Subject: RV-List: compression test and mag timing equipment I am getting ready to do the annual on my 6A and trying to figure out which cyl. compression tester to get. I have an IO-260-B2B. It has a 5.125" bore. I'm seeing conflicting information about the orifice size needed t\for such an engine. Is it 0.040" or 0.060" Also, I have but 1 magneto (Lightspeed Ignition on the right). Which magneto timer should I get? Do I need anything else to time the left mag? Thanks, -- Tom Sargent, N811WT , RV-6A ________________________________________________________________________________
Date: Jun 21, 2011
You can follow the old advice and use the smaller orifice(.040) compression tester for engines less than 1000 cu. in. http://www.aircraftspruce.com/catalog/topages/differentialcylindertester.php A few years back they started suggesting the larger orifice(.060) for engines 5" and larger bore. No one I know follows that advice. It will show higher compressions which really isn't what you want. Any buzz box magneto timer will work. This $43 unit is about as cheap as they come: *http://www.aircraftspruce.com/catalog/topages/synchronizer.php* Kelly A&P/IA EAA Tech Counselor On 6/21/2011 8:13 PM, thomas sargent wrote: > I am getting ready to do the annual on my 6A and trying to figure out > which cyl. compression tester to get. I have an IO-260-B2B. It has a > 5.125" bore. I'm seeing conflicting information about the orifice > size needed t\for such an engine. Is it 0.040" or 0.060" > > Also, I have but 1 magneto (Lightspeed Ignition on the right). Which > magneto timer should I get? Do I need anything else to time the left mag? > > Thanks, > > -- > Tom Sargent, N811WT , RV-6A > * > > > * ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jun 22, 2011
You Typically need one of these too! http://www.aircraftspruce.com/catalog/topages/timing_ind.php Sent from my iPhone On Jun 21, 2011, at 11:32 PM, Kelly McMullen wrote: > > You can follow the old advice and use the smaller orifice(.040) compression tester for engines less than 1000 cu. in. > http://www.aircraftspruce.com/catalog/topages/differentialcylindertester.php > A few years back they started suggesting the larger orifice(.060) for engines 5" and larger bore. No one I know follows that advice. It will show higher compressions which really isn't what you want. Any buzz box magneto timer will work. This $43 unit is about as cheap as they come: *http://www.aircraftspruce.com/catalog/topages/synchronizer.php* > Kelly > A&P/IA > EAA Tech Counselor > > > On 6/21/2011 8:13 PM, thomas sargent wrote: >> I am getting ready to do the annual on my 6A and trying to figure out which cyl. compression tester to get. I have an IO-260-B2B. It has a 5.125" bore. I'm seeing conflicting information about the orifice size needed t\for such an engine. Is it 0.040" or 0.060" >> >> Also, I have but 1 magneto (Lightspeed Ignition on the right). Which magneto timer should I get? Do I need anything else to time the left mag? >> >> Thanks, >> >> -- >> Tom Sargent, N811WT , RV-6A >> * >> >> >> * > > > > ________________________________________________________________________________
Date: Jun 22, 2011
Waste of money, IMHO. If you want accurate timing, get/borrow a digital level to determine exact prop position. Once you find the correct mark on your flywheel, it isn't hard to line it up with the case halves, IF you have marks on the engine side of the flywheel. If you only have marks on the front side, you have to use the mark on the starter motor. If you have questions, find an A&P to show you correct positioning...it isn't rocket science. The flower pot isn't so useful because it needs to be positioned on the spinner such that its surface is perpendicular with the ground...hard to do with a tailwheel aircraft. On 6/22/2011 3:15 AM, Michael Kraus wrote: > --> RV-List message posted by: Michael Kraus > > You Typically need one of these too! > > http://www.aircraftspruce.com/catalog/topages/timing_ind.php > > Sent from my iPhone > > On Jun 21, 2011, at 11:32 PM, Kelly McMullen wrote: > >> --> RV-List message posted by: Kelly McMullen >> >> You can follow the old advice and use the smaller orifice(.040) compression tester for engines less than 1000 cu. in. >> http://www.aircraftspruce.com/catalog/topages/differentialcylindertester.php >> A few years back they started suggesting the larger orifice(.060) for engines 5" and larger bore. No one I know follows that advice. It will show higher compressions which really isn't what you want. Any buzz box magneto timer will work. This $43 unit is about as cheap as they come: *http://www.aircraftspruce.com/catalog/topages/synchronizer.php* >> Kelly >> A&P/IA >> EAA Tech Counselor >> >> >> On 6/21/2011 8:13 PM, thomas sargent wrote: >>> I am getting ready to do the annual on my 6A and trying to figure out which cyl. compression tester to get. I have an IO-260-B2B. It has a 5.125" bore. I'm seeing conflicting information about the orifice size needed t\for such an engine. Is it 0.040" or 0.060" >>> >>> Also, I have but 1 magneto (Lightspeed Ignition on the right). Which magneto timer should I get? Do I need anything else to time the left mag? >>> >>> Thanks, >>> >>> -- >>> Tom Sargent, N811WT , RV-6A >>> * >>> >>> >>> * >> >> >> > > ________________________________________________________________________________
Date: Jun 22, 2011
The flower pot is not needed on Lycomings that have a timing mark on the flywheel. Even my GO-480 had a timing mark so perhaps all Lycomings have one somewhere. Not so on Continentals. I had buy one for the IO-550 in my Navion but don't need it for the RV. Greg Young -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Wednesday, June 22, 2011 5:15 AM Subject: Re: RV-List: compression test and mag timing equipment You Typically need one of these too! http://www.aircraftspruce.com/catalog/topages/timing_ind.php Sent from my iPhone On Jun 21, 2011, at 11:32 PM, Kelly McMullen wrote: ________________________________________________________________________________
Date: Jun 22, 2011
Interesting, used it successfully for 9 years with no problems, on my taildragger RV-4...... Inexpensive and worked great for me. And it has worked great on my RV-10 for 1 year. Sent from my iPhone On Jun 22, 2011, at 10:08 AM, Kelly McMullen wrote: > > Waste of money, IMHO. If you want accurate timing, get/borrow a digital level to determine exact prop position. Once you find the correct mark on your flywheel, it isn't hard to line it up with the case halves, IF you have marks on the engine side of the flywheel. If you only have marks on the front side, you have to use the mark on the starter motor. If you have questions, find an A&P to show you correct positioning...it isn't rocket science. The flower pot isn't so useful because it needs to be positioned on the spinner such that its surface is perpendicular with the ground...hard to do with a tailwheel aircraft. > > > On 6/22/2011 3:15 AM, Michael Kraus wrote: >> --> RV-List message posted by: Michael Kraus >> >> You Typically need one of these too! >> >> http://www.aircraftspruce.com/catalog/topages/timing_ind.php >> >> Sent from my iPhone >> >> On Jun 21, 2011, at 11:32 PM, Kelly McMullen wrote: >> >>> --> RV-List message posted by: Kelly McMullen >>> >>> You can follow the old advice and use the smaller orifice(.040) compression tester for engines less than 1000 cu. in. >>> http://www.aircraftspruce.com/catalog/topages/differentialcylindertester.php >>> A few years back they started suggesting the larger orifice(.060) for engines 5" and larger bore. No one I know follows that advice. It will show higher compressions which really isn't what you want. Any buzz box magneto timer will work. This $43 unit is about as cheap as they come: *http://www.aircraftspruce.com/catalog/topages/synchronizer.php* >>> Kelly >>> A&P/IA >>> EAA Tech Counselor >>> >>> >>> On 6/21/2011 8:13 PM, thomas sargent wrote: >>>> I am getting ready to do the annual on my 6A and trying to figure out which cyl. compression tester to get. I have an IO-260-B2B. It has a 5.125" bore. I'm seeing conflicting information about the orifice size needed t\for such an engine. Is it 0.040" or 0.060" >>>> >>>> Also, I have but 1 magneto (Lightspeed Ignition on the right). Which magneto timer should I get? Do I need anything else to time the left mag? >>>> >>>> Thanks, >>>> >>>> -- >>>> Tom Sargent, N811WT , RV-6A >>>> * >>>> >>>> >>>> * >>> >>> >>> >> >> >> >> > > > > ________________________________________________________________________________
Date: Jun 22, 2011
Oops, just notice I said engine was IO-260, It is of course an IO-360-B2B. Thanks for all the info by the way. On Tue, Jun 21, 2011 at 8:13 PM, thomas sargent wrote: > I am getting ready to do the annual on my 6A and trying to figure out which > cyl. compression tester to get. I have an IO-260-B2B. It has a 5.125" > bore. I'm seeing conflicting information about the orifice size needed > t\for such an engine. Is it 0.040" or 0.060" > > Also, I have but 1 magneto (Lightspeed Ignition on the right). Which > magneto timer should I get? Do I need anything else to time the left mag? > > Thanks, > > -- > Tom Sargent, N811WT , RV-6A > > * > > * > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 25, 2011
Subject: Floscan sensor orientation?
Anyone have a floscan 201 sensor that's working ok while mounted in other than a horizontal position? My most convenient location would have the fuel path flowing up at a 45 degree angle. In addition, the mounting can have the wires 'up', but mounting would be a bit more convenient with the wires pointing horizontally. Any thoughts? Thanks, Charlie ________________________________________________________________________________
Date: Jun 25, 2011
Subject: Fixed pitch to constant speed
I have a RV8A with an O-360 and fixed pitch Sensenich prop. -I am conside ring changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. -My plane is on the nose heavy side as i t is, and I would not like to make it any more so. -I am looking at the W hirlwind RV series. -Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? -The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind . -I was hoping to find out the weight of the Sensenich installation with out pulling my prop. Thanks, Craig GallenbachEastover, NCRV8-A, N184CG 195hrs ________________________________________________________________________________
Subject: Re: Fixed pitch to constant speed
Date: Jun 25, 2011
I have a RV8a with a IO-360 200hp which is a little heavier than your engine plus I have constant speed prop and have been flying it since 2002. That being said I do keep 25 lb. of lead shot in the aft baggage compartment and a few tools which keeps the elevator pretty even or level in flight thus creating less drag. When landing it also helps with a lot less trim. I have confess my best landing are when I have a passenger in the rear seat and nothing in the aft baggage area Dane Sheahen RV8a On Jun 25, 2011, at 9:01 AM, Craig Gallenbach wrote: > I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop. > > Thanks, > > Craig Gallenbach > Eastover, NC > RV8-A, N184CG 195hrs > > > ________________________________________________________________________________
Date: Jun 25, 2011
Craig, Do you have your battery in the back? I have an IO-360 200 Hp / Hartzell BA CS prop (great combination) and have no issues flying solo with full fuel or near empty and no weight in the back. One note I have dual G3X and back up EFIS so I suspect my panel is lighter than a 10 year old build with steam gauges. Robin RV-4 Sold RV-6A Sold RV-10 225 Hours RV-8A 30 Hours *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *AOL *Sent:* Saturday, June 25, 2011 7:31 AM *To:* rv-list(at)matronics.com *Subject:* Re: RV-List: Fixed pitch to constant speed I have a RV8a with a IO-360 200hp which is a little heavier than your engine plus I have constant speed prop and have been flying it since 2002. That being said I do keep 25 lb. of lead shot in the aft baggage compartment and a few tools which keeps the elevator pretty even or level in flight thus creating less drag. When landing it also helps with a lot less trim. I have confess my best landing are when I have a passenger in the rear seat and nothing in the aft baggage area Dane Sheahen RV8a On Jun 25, 2011, at 9:01 AM, Craig Gallenbach wrote: I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop. Thanks, Craig Gallenbach Eastover, NC RV8-A, N184CG 195hrs * * * * *href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List* *href="http://forums.matronics.com/">http://forums.matronics.com* *href="http://www.matronics.com/contribution">http://www.matronics.com/contribution* * * * * * * * * ________________________________________________________________________________
Date: Jun 25, 2011
Craig, I did this conversion on my 8A about three years ago. After reviewing all the performance data on the various CS props available, I selected the Hartzell blended airfoil. I have an IO-360, 180 hp engine so the engine weigh is the same as yours. Looking back over my W&B data, I can tell you the Hartzell was 13 pounds heavier than the Sensenich. I have two Odyssey 625 batteries mounted just aft of the firewall. I considered moving one of them to the aft mount location but decided to wait until after flying to see if it I had a nose heavy problem or not. Bottom line, I did not see much difference so I left the batteries where they are. As I did with the Sensenich, I put a 25 pound shot bag in the baggage compartment if I'm solo and no baggage. My W&B does not require this, but I find it helps. I can tell you the performance difference between the Sensenich and the Hartzell was far more dramatic than I anticipated. You will love the change. I have a couple of hotrod Lancairs at the airpark and while they eventually pass me, I give them a surprising run for their money. BTW - I'm using the PCU-5000 governor and am very pleased with it. If you need a governor control cable bracket let me know - I have a new one sitting here I bought from Van's by mistake for the RV-10. Carl RV-8A (650 hrs) RV-10 (prepping the fuselage for paint) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Saturday, June 25, 2011 10:47 AM Subject: RE: RV-List: Fixed pitch to constant speed Craig, Do you have your battery in the back? I have an IO-360 200 Hp / Hartzell BA CS prop (great combination) and have no issues flying solo with full fuel or near empty and no weight in the back. One note I have dual G3X and back up EFIS so I suspect my panel is lighter than a 10 year old build with steam gauges. Robin RV-4 Sold RV-6A Sold RV-10 225 Hours RV-8A 30 Hours From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of AOL Sent: Saturday, June 25, 2011 7:31 AM Subject: Re: RV-List: Fixed pitch to constant speed I have a RV8a with a IO-360 200hp which is a little heavier than your engine plus I have constant speed prop and have been flying it since 2002. That being said I do keep 25 lb. of lead shot in the aft baggage compartment and a few tools which keeps the elevator pretty even or level in flight thus creating less drag. When landing it also helps with a lot less trim. I have confess my best landing are when I have a passenger in the rear seat and nothing in the aft baggage area Dane Sheahen RV8a On Jun 25, 2011, at 9:01 AM, Craig Gallenbach wrote: I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop. Thanks, Craig Gallenbach Eastover, NC RV8-A, N184CG 195hrs href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution RV-List Email Forum - Day Browse, Chat, FAQ, w.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li ==================== m">http://forums.matronics.com http://www.matronics.com/contribution ====================== ________________________________________________________________________________
Date: Jun 25, 2011
Battery is on the firewall. CG with me and no fuel is 79.47. I am hoping to d o this with minimum changes such as having to move the battery. Craig On Jun 25, 2011, at 10:47 AM, Robin Marks wrote: > Craig, > > Do you have your battery in the back? > > I have an IO-360 200 Hp / Hartzell BA CS prop (great combination) and have no issues flying solo with full fuel or near empty and no weight in the bac k. > > One note I have dual G3X and back up EFIS so I suspect my panel is lighter than a 10 year old build with steam gauges. > > > > Robin > > RV-4 Sold > > RV-6A Sold > > RV-10 225 Hours > > RV-8A 30 Hours > > > > > > > > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matr onics.com] On Behalf Of AOL > Sent: Saturday, June 25, 2011 7:31 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Fixed pitch to constant speed > > > > I have a RV8a with a IO-360 200hp which is a little heavier than your engi ne plus I have constant speed prop and have been flying it since 2002. That being said I do keep 25 lb. of lead shot in the aft baggage compartment an d a few tools which keeps the elevator pretty even or level in flight thus c reating less drag. When landing it also helps with a lot less trim. I have c onfess my best landing are when I have a passenger in the rear seat and noth ing in the aft baggage area > > > > Dane Sheahen > > RV8a > > > > > > On Jun 25, 2011, at 9:01 AM, Craig Gallenbach wrote: > > > > > I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am consider ing changing to a constant speed prop, but I am concerned about the added we ight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlw ind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spin ner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my pro p. > > > > Thanks, > > > > Craig Gallenbach > > Eastover, NC > > RV8-A, N184CG 195hrs > > > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.c om/Navigator?RV-List > href="http://forums.matronics.com/">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution > > > > > > RV-List Email Forum - > Day Browse, Chat, FAQ, > w.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-L i > =====================< - MA TRONICS WEB FORUMS - > m">http://forums.matronics.com > http://www.matronics.com/contribution > ====================== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 25, 2011
Craig, I had an RV6A with a Hartzell Constant Speed. I believe it added 40 to 50lbs on the nose. That wasn't a problem for the 6A. Can't speak for the 8. The Hartzell is a great prop (supplied direct from factory by Van's). It performed perfectly for over 500 hrs and is still flying as before. (sold 6A last yr). If you are considering a Whirlwind check it out closely as I have a friend who owned an 8 and could never get his to work as expected. That doesn't mean it's not a good cons.spd. product. It means just what I said. Dick seiders On Sat, Jun 25, 2011 at 10:01 AM, Craig Gallenbach wrote: > I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am > considering changing to a constant speed prop, but I am concerned about the > added weight on the nose of the plane. My plane is on the nose heavy side > as it is, and I would not like to make it any more so. I am looking at the > Whirlwind RV series. Does anyone out there know how the installed weight of > a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop > and spinner weigh in at about 38# according to the folks at Whirlwind. I > was hoping to find out the weight of the Sensenich installation without > pulling my prop. > > Thanks, > > Craig Gallenbach > Eastover, NC > RV8-A, N184CG 195hrs > > * > > * > > ________________________________________________________________________________
Date: Jun 25, 2011
Subject: A Kindred Spirit...
A 20-year Project A 42-foot schooner isn't a big project for a ship-building company. It's a different matter if you're the one doing all the work. In the early 1990s, Dr. John Vardiman decided to build one from scratch. It took over 20 years to complete. What an great story of perseverance... http://www.youtube.com/watch?v=SN4kmlAxvGU&feature=player_embedded I know just how he feels... :-) Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jun 25, 2011
Subject: Re: A Kindred Spirit...
So sorry to hear about your RV8 situation, Matt!- I bet that it is going to go quicker than the original bbuild though.=0A=0A=0ACool Pet Gifts and P roducts at my web site: http://www.pepperspetpantry.com=0A=0AFrom: Matt Dra lle =0ATo: rv-list(at)matronics.com; rv8-list(at)matronics. com; rv7-list(at)matronics.com=0ASent: Saturday, June 25, 2011 10:07 PM=0ASubj Dralle =0A=0A=0A=0AA 20-year Project=0A=0AA 42-foot s chooner isn't a big project for a ship-building company.- It's a differen t matter if you're the one doing all the work.- In the early 1990s, Dr. J ohn Vardiman decided to build one from scratch.- It took over 20 years to complete.- What an great story of perseverance...=0A=0A- - - - h ttp://www.youtube.com/watch?v=SN4kmlAxvGU&feature=player_embedded=0A=0A I know just how he feels... :-)=0A=0AMatt=0A=0A=0A-=0AMatt Dralle=0ARV-8 #8 2880 N998RV "Ruby Vixen"=0Ahttp://www.mattsrv8.com - Matt's Complete RV-8 C onstruction Log=0Ahttp://www.mattsrv8.com/Rebuild - Post Landing Mishap Reb uild Log=0Ahttp://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Chann el=0AStatus: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... =============== ________________________________________________________________________________
Date: Jun 26, 2011
Ouch! Sorry to hear about your mishap, Matt. I had put a new (more aggressive) Prop on my RV-6A and went flying. Neglected to determine at altitude the effect of the prop on airspeed when the throttle was closed. Found out on landing that it was a quite effective airbrake when the throttle was pulled closed - lost airspeed quicker than I thought possible, dropped out of the air from above 12 ft, managed to suck the stick to my backbone and kept the nose up. Very hard landing on the main gear, bounced felt the tail drag during the bounce, hit and bounced a few more times. Noticed on taxi back to hangar that aircraft seemed to have a tilt to the wings. Found one wing tip approx 12" higher than the other. Bent both main gear, stubbed the rudder (had to replace the bearings), but fortunately that was the extent. No rebuild, just gear rod replacements. Hopefully, your rebuild will proceed faster now that you don't have anything knew to learn in building the 8 {:>) Hope you are back in the air soonest. Ed Edward L. Anderson Anderson Electronic Enterprises LLC 305 Reefton Road Weddington, NC 28104 http://www.andersonee.com http://www.eicommander.com -------------------------------------------------- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Saturday, June 25, 2011 2:07 PM Subject: RV-List: A Kindred Spirit... > > > A 20-year Project > > A 42-foot schooner isn't a big project for a ship-building company. It's > a different matter if you're the one doing all the work. In the early > 1990s, Dr. John Vardiman decided to build one from scratch. It took over > 20 years to complete. What an great story of perseverance... > > http://www.youtube.com/watch?v=SN4kmlAxvGU&feature=player_embedded > > I know just how he feels... :-) > > Matt > > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > > ________________________________________________________________________________
Subject: G3i Ignition: Presentation @ AirVenture 2011
Date: Jun 26, 2011
On Tuesday, 7/26/2011 - 8:30 AM - 9:45 AM - Forum Pavilion 11 BRP/Rotax I will be doing an open discussion forum on:Interfacing Aircraft Magnetos with Electronic Ignition Systems, G3i Ignition Systems - Understanding the internal workings/properties of aircraft magnetos (Slick & Bendix). Aircraft spark plugs and automotive style spark plugs in aircraft applications. Secondary ignition timing and cylinder flame propagation. Disassembly and re-assembly of aircraft magnetos. Modifying magnetos to interface with an electronic ignition systems, experimental electronic ignition systems, benefits and end user. AirVenture forum link: http://www.eaaapps.org/presenterinfo.aspx?id=1470 Look forward to seeing you there, Thomas S. -------- Thomas S. Follow G3i on Facebook. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344171#344171 ________________________________________________________________________________
From: "Peck, Gaillard R CTR USAF ACC USAFWS/CBD" <gaillard.peck.ctr(at)nellis.af.mil>
Date: Jun 27, 2011
Here's a tip for anyone building wing tanks for a RV-8. A friend building an RV-10 told me about the fuel pickup tube on the RV-10. It has a strainer attached to the pickup end of the tube. That's a real improvement over the pickup tube in my RV-8 plans. My plans say: bend the tube and crimp the end of the tube and then hacksaw 7 or 8 holes about half way through the tube just above the crimp for the fuel pickup. I ordered the RV-10 tubes from Vans and found them to be a perfect fit and a much niftier way to go. They are nicely bent and come with the compression sleeve and nut already mounted on the flared end of the tube. All that you have to do is screw the nut on the fitting that passes through the inboard tank rib and install the locking bracket. It was a little tricky finding the RV-10 tubes in the Vans catalogue, but they are there. I forget how much they cost. I think both for $31 or so. Well worth it to me for this important component. Regards to all. Gail Peck RV-8 LAS no N number yet -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Saturday, June 25, 2011 9:02 AM Subject: RV8-List: RE: RV-List: Fixed pitch to constant speed Craig, I did this conversion on my 8A about three years ago. After reviewing all the performance data on the various CS props available, I selected the Hartzell blended airfoil. I have an IO-360, 180 hp engine so the engine weigh is the same as yours. Looking back over my W&B data, I can tell you the Hartzell was 13 pounds heavier than the Sensenich. I have two Odyssey 625 batteries mounted just aft of the firewall. I considered moving one of them to the aft mount location but decided to wait until after flying to see if it I had a nose heavy problem or not. Bottom line, I did not see much difference so I left the batteries where they are. As I did with the Sensenich, I put a 25 pound shot bag in the baggage compartment if I'm solo and no baggage. My W&B does not require this, but I find it helps. I can tell you the performance difference between the Sensenich and the Hartzell was far more dramatic than I anticipated. You will love the change. I have a couple of hotrod Lancairs at the airpark and while they eventually pass me, I give them a surprising run for their money. BTW - I'm using the PCU-5000 governor and am very pleased with it. If you need a governor control cable bracket let me know - I have a new one sitting here I bought from Van's by mistake for the RV-10. Carl RV-8A (650 hrs) RV-10 (prepping the fuselage for paint) From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Saturday, June 25, 2011 10:47 AM Subject: RE: RV-List: Fixed pitch to constant speed Craig, Do you have your battery in the back? I have an IO-360 200 Hp / Hartzell BA CS prop (great combination) and have no issues flying solo with full fuel or near empty and no weight in the back. One note I have dual G3X and back up EFIS so I suspect my panel is lighter than a 10 year old build with steam gauges. Robin RV-4 Sold RV-6A Sold RV-10 225 Hours RV-8A 30 Hours From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of AOL Sent: Saturday, June 25, 2011 7:31 AM Subject: Re: RV-List: Fixed pitch to constant speed I have a RV8a with a IO-360 200hp which is a little heavier than your engine plus I have constant speed prop and have been flying it since 2002. That being said I do keep 25 lb. of lead shot in the aft baggage compartment and a few tools which keeps the elevator pretty even or level in flight thus creating less drag. When landing it also helps with a lot less trim. I have confess my best landing are when I have a passenger in the rear seat and nothing in the aft baggage area Dane Sheahen RV8a On Jun 25, 2011, at 9:01 AM, Craig Gallenbach wrote: I have a RV8A with an O-360 and fixed pitch Sensenich prop. I am considering changing to a constant speed prop, but I am concerned about the added weight on the nose of the plane. My plane is on the nose heavy side as it is, and I would not like to make it any more so. I am looking at the Whirlwind RV series. Does anyone out there know how the installed weight of a Whirlwind prop compares to the fixed pitch Sensenich? The Whirlwind prop and spinner weigh in at about 38# according to the folks at Whirlwind. I was hoping to find out the weight of the Sensenich installation without pulling my prop. Thanks, Craig Gallenbach Eastover, NC RV8-A, N184CG 195hrs href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution RV-List Email Forum - Day Browse, Chat, FAQ, w.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li ==================== m">http://forums.matronics.com http://www.matronics.com/contribution ====================== http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 27, 2011
Subject: Re: G3i Ignition: Presentation @ AirVenture 2011
Is this given a second time?- I have a conflict with teacher day and woul d like to see your presentation.- Please advise.- Thanks for your time. - Perhaps I will get to work things into the schedule. - Art Glaser --- On Sun, 6/26/11, G3i Ignition wrote: From: G3i Ignition <mail(at)g3ignition.com> Subject: RV-List: G3i Ignition: Presentation @ AirVenture 2011 Date: Sunday, June 26, 2011, 7:44 PM On Tuesday, 7/26/2011 - 8:30 AM - 9:45 AM - Forum Pavilion 11 BRP/Rotax I w ill be doing an open discussion forum on:Interfacing Aircraft Magnetos with Electronic Ignition Systems, G3i Ignition Systems - Understanding the inte rnal workings/properties of aircraft magnetos (Slick & Bendix). Aircraft sp ark plugs and automotive style spark plugs in aircraft applications. Second ary ignition timing and cylinder flame propagation. Disassembly and re-asse mbly of aircraft magnetos. Modifying magnetos to interface with an electron ic ignition systems, experimental electronic ignition systems, benefits and end user. AirVenture forum link: http://www.eaaapps.org/presenterinfo.aspx ?id=1470 Look forward to seeing you there, Thomas S. -------- Thomas S. Follow G3i on Facebook. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344171#344171 le, List Admin. ________________________________________________________________________________
Date: Jun 27, 2011
Sorry -- I should have sent the message directly to G3i --- On Sun, 6/26/11, G3i Ignition wrote: From: G3i Ignition <mail(at)g3ignition.com> Subject: RV-List: G3i Ignition: Presentation @ AirVenture 2011 Date: Sunday, June 26, 2011, 7:44 PM On Tuesday, 7/26/2011 - 8:30 AM - 9:45 AM - Forum Pavilion 11 BRP/Rotax I w ill be doing an open discussion forum on:Interfacing Aircraft Magnetos with Electronic Ignition Systems, G3i Ignition Systems - Understanding the inte rnal workings/properties of aircraft magnetos (Slick & Bendix). Aircraft sp ark plugs and automotive style spark plugs in aircraft applications. Second ary ignition timing and cylinder flame propagation. Disassembly and re-asse mbly of aircraft magnetos. Modifying magnetos to interface with an electron ic ignition systems, experimental electronic ignition systems, benefits and end user. AirVenture forum link: http://www.eaaapps.org/presenterinfo.aspx ?id=1470 Look forward to seeing you there, Thomas S. -------- Thomas S. Follow G3i on Facebook. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344171#344171 le, List Admin. ________________________________________________________________________________
Subject: MP3 type Audio amplifier?
Date: Jun 27, 2011
My Garmin 696 doesn't output enough power to hear the XM radio it in my headsets very well. Is anyone using any type of audio amplifier to boost their mp3 player or similar? Any recommendations on what to get, or avoid? Thanks -Mike Kraus Sent from my iPhone ________________________________________________________________________________
Date: Jun 27, 2011
Subject: Re: MP3 type Audio amplifier?
I use this one, works great, several versions depending on what you need. http://www.vx-aviation.com/page_2.html#ASX-2A_more Good guy to do business with. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net On Mon, Jun 27, 2011 at 8:14 PM, Michael Kraus wrote: > > My Garmin 696 doesn't output enough power to hear the XM radio it in my > headsets very well. Is anyone using any type of audio amplifier to boost > their mp3 player or similar? Any recommendations on what to get, or avoid? > > Thanks > -Mike Kraus > > Sent from my iPhone > > ________________________________________________________________________________
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Date: Jun 27, 2011
What type of audio panel / intercom are you using? Sent from my Verizon iPhone On Jun 27, 2011, at 9:14 PM, Michael Kraus wrote: > > My Garmin 696 doesn't output enough power to hear the XM radio it in my headsets very well. Is anyone using any type of audio amplifier to boost their mp3 player or similar? Any recommendations on what to get, or avoid? > > Thanks > -Mike Kraus > > Sent from my iPhone > > > > ________________________________________________________________________________
Date: Jun 28, 2011
<> Apollo SL-15. Talked with them, they said some devices need a boost. My 696 is turned up all the way, and still cuts out sometimes. Had the same problem with a couple other devices, but I was able to turn them up and they work fine. I assume they have better output as they are not at max output and still work great. -Mike Sent from my iPhone On Jun 28, 2011, at 12:33 AM, Bobby Hester wrote: > > What type of audio panel / intercom are you using? > > Sent from my Verizon iPhone > > On Jun 27, 2011, at 9:14 PM, Michael Kraus wrote: > >> >> My Garmin 696 doesn't output enough power to hear the XM radio it in my headsets very well. Is anyone using any type of audio amplifier to boost their mp3 player or similar? Any recommendations on what to get, or avoid? >> >> Thanks >> -Mike Kraus >> >> Sent from my iPhone >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jun 29, 2011
Subject: mag timing
I bought the TP105 "mag synchronizer" from Spruce. My plane has only the left magneto. I use a Lightspeed ignition on the right. I was fairly sure this could be used to time a single magneto, but the instructions don't even mention that. Did I buy the wrong buzz box, or is the timing procedure so "well known" that they don't even explain it? -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Jun 29, 2011
Subject: Re: mag timing
I couldn't find the tp105 on spruce, but the 'buzz box' should work fine. I'm guessing that you have an impulse mag on the left. Remove one plug from each cylinder to prevent inadvertent firing. Rotate the engine until you feel compression on #1. Look at the engine data plate to see what the timing BTDC is. Locate this mark on the flywheel. I use the back side which lines up with the case split. The front marks line up with the starter ..... never could find the 'hole' mark! Turn the prop until you hear the 'click' as the impulse breaks. This should be near TDC. Move the prop backwards until the mark lines up with the case split. This should be the same degree mark as is on the data plate. Typically 25 deg BTDC but can vary on different engines. If the mark doesn't line up, rotate the mag until it does. You're only timing the left mag so the right isn't connected because of the lightspeed. Once the left mag is timed, use the Lightspeed instructions to time the right side. Hope this helps. Linn On 6/29/2011 11:03 AM, thomas sargent wrote: > I bought the TP105 "mag synchronizer" from Spruce. My plane has only > the left magneto. I use a Lightspeed ignition on the right. I was > fairly sure this could be used to time a single magneto, but the > instructions don't even mention that. Did I buy the wrong buzz box, > or is the timing procedure so "well known" that they don't even > explain it? > > -- > Tom Sargent, RV-6A > * > > > * ________________________________________________________________________________
Date: Jun 29, 2011
The synchronizer tells you when the points open and close (ie fire). If you have 2 mags, it will show you how close they are together (ie do they fire a t the same time, or one before the other). Use this along with some way to t ell degrees before TDC and you want the single mag to beep at typically 20 d eg before TDC (depending on engine and cylinder compression). Sent from my iPhone On Jun 29, 2011, at 11:03 AM, thomas sargent wrote: > I bought the TP105 "mag synchronizer" from Spruce. My plane has only the l eft magneto. I use a Lightspeed ignition on the right. I was fairly sure th is could be used to time a single magneto, but the instructions don't even m ention that. Did I buy the wrong buzz box, or is the timing procedure so "w ell known" that they don't even explain it? > > -- > Tom Sargent, RV-6A > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 29, 2011
Howdy Tom, Can't find the TP-105 on ACS' site. I use the "Inductor Magneto Synchronizer": http://www.aircraftspruce.com/catalog/topages/synchronizer.php For this unit, remove one set of spark plugs, top or bottom. Find top dead center on #1 by moving the prop until it blows pressure past a finger on the spark plug hole. If the mag has an impulse coupling, go far enough to hear the snap, then back up to about 35 degrees BTDC and sneak up on 25 BTDC by the mark on the flywheel that lines up with the hole in the starter casting. This gets any gear lash out of the picture. Put a drill bit in the hole as a pointer to get a better look at it's relationship to the flywheel mark. Hook the black wire to ground and one or the other of the colored leads to the P-lead on the mag. Turn the mag switch on. Turn the buzz box on. Move the prop back and/or forth until one of the lights goes out and the sound changes. Ignore the other light since it isn't hooked up. Look at the flywheel again to see where the timing really is. Loosen the mag hold downs and adjust as necessary to get it to where the light goes out exactly when the 25 degree mark lines up when you sneak up on it. Snug the hold downs on the mag before you check timing. The timing will often change slightly as you tighten the magneto hold downs, so it may take a few (or many) tries to get it just right. Have fun with it. Pax, Ed Holyoke On 6/29/2011 8:03 AM, thomas sargent wrote: > I bought the TP105 "mag synchronizer" from Spruce. My plane has only > the left magneto. I use a Lightspeed ignition on the right. I was > fairly sure this could be used to time a single magneto, but the > instructions don't even mention that. Did I buy the wrong buzz box, > or is the timing procedure so "well known" that they don't even > explain it? > > -- > Tom Sargent, RV-6A > * > > > * ________________________________________________________________________________
Date: Jun 29, 2011
Ed: Thanks for that description. That helps a lot. The TP-105 is the mfr. number. Spruce lists it on the same page with the E-50. It's the "Mag timing light Industrial Typ" at the bottom of the page. p/n 12-01279 On Wed, Jun 29, 2011 at 9:02 AM, Ed Holyoke wrote: > ** > Howdy Tom, > > Can't find the TP-105 on ACS' site. I use the "Inductor Magneto > Synchronizer": > http://www.aircraftspruce.com/catalog/topages/synchronizer.php > > For this unit, remove one set of spark plugs, top or bottom. Find top dead > center on #1 by moving the prop until it blows pressure past a finger on the > spark plug hole. If the mag has an impulse coupling, go far enough to hear > the snap, then back up to about 35 degrees BTDC and sneak up on 25 BTDC by > the mark on the flywheel that lines up with the hole in the starter casting. > This gets any gear lash out of the picture. Put a drill bit in the hole as a > pointer to get a better look at it's relationship to the flywheel mark. Hook > the black wire to ground and one or the other of the colored leads to the > P-lead on the mag. Turn the mag switch on. Turn the buzz box on. Move the > prop back and/or forth until one of the lights goes out and the sound > changes. Ignore the other light since it isn't hooked up. Look at the > flywheel again to see where the timing really is. Loosen the mag hold downs > and adjust as necessary to get it to where the light goes out exactly when > the 25 degree mark lines up when you sneak up on it. Snug the hold downs > on the mag before you check timing. The timing will often change slightly > as you tighten the magneto hold downs, so it may take a few (or many) tries > to get it just right. Have fun with it. > > Pax, > > Ed Holyoke > > On 6/29/2011 8:03 AM, thomas sargent wrote: > > I bought the TP105 "mag synchronizer" from Spruce. My plane has only the > left magneto. I use a Lightspeed ignition on the right. I was fairly sure > this could be used to time a single magneto, but the instructions don't even > mention that. Did I buy the wrong buzz box, or is the timing procedure so > "well known" that they don't even explain it? > > -- > Tom Sargent, RV-6A > > * > > * > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 30, 2011
Subject: adjusting cooling baffles
I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl #3 is a bit high. I've seen many planes with small "dams" at the inlet, small strips of aluminum blocking the bottom 1/4" or 1/2" of the cooling fins on cyl #1. Is there any science to this or is it just cut and try? How well does the piece of aluminum have to be secured? Since it's backed up against the fins and, I'm assuming has a flange resting on the inlet ramp, I'm guessing that just using good quality tape holding it down to the inlet ramp will do for testing purposes. Or is there a better way to secure it temoporarily? thanks, -- Tom Sargent ________________________________________________________________________________
Date: Jun 30, 2011
Subject: Re: adjusting cooling baffles
You can use aluminum tape across the fins to do your fine tuning, then make a dam to same dimensions when you find what works. On 6/30/2011 2:20 PM, thomas sargent wrote: > I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl > #3 is a bit high. I've seen many planes with small "dams" at the > inlet, small strips of aluminum blocking the bottom 1/4" or 1/2" of > the cooling fins on cyl #1. > > Is there any science to this or is it just cut and try? > > How well does the piece of aluminum have to be secured? Since it's > backed up against the fins and, I'm assuming has a flange resting on > the inlet ramp, I'm guessing that just using good quality tape holding > it down to the inlet ramp will do for testing purposes. Or is there a > better way to secure it temoporarily? > > thanks, > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: Jun 30, 2011
Tape will work to R&D. In fact you can use tape as the dam if you want. We made curved =93ramps=94 of various sizes to adjust the cooling. What we found is there was very little we could do to bring down #3 temps due to the rear baffle being nearly flush to the backside of #3 preventing any cooling air to run past the rear fins. Other builders have placed washers back there to force a gap for a little batter air circulation. Because I am running a 200 Hp & the SJ cowl cooling is at a premium. We decided to open up the rear baffle and build a ramp for real cooling air to wrap around the backside of #3. This made a 15+ degree difference and also allowed us to remove most of our forward cooling ramps. Note: we were able to make this adjustment w/o removing the baffle. Robin *From:* owner-rv-list-server(at)matronics.com [mailto: owner-rv-list-server(at)matronics.com] *On Behalf Of *thomas sargent *Sent:* Thursday, June 30, 2011 2:21 PM *To:* rv-list *Subject:* RV-List: adjusting cooling baffles I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl #3 is a bit high. I've seen many planes with small "dams" at the inlet, small strips of aluminum blocking the bottom 1/4" or 1/2" of the cooling fins on cyl #1. Is there any science to this or is it just cut and try? How well does the piece of aluminum have to be secured? Since it's backed u p against the fins and, I'm assuming has a flange resting on the inlet ramp, I'm guessing that just using good quality tape holding it down to the inlet ramp will do for testing purposes. Or is there a better way to secure it temoporarily? thanks, -- Tom Sargent * * * * ===========* ===========* ===========* ===========* * * ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 30, 2011
Another thing to look at is the backside of #3. Make sure there's a little gap back there as the fins are very shallow on the intake side and, if the baffle is very tight to the back of the head, not much air can pass by that area. A washer under the baffle mounting screw might be enough to make a d ifference. Pax, Ed Holyoke --- On Thu, 6/30/11, Kelly McMullen wrote: From: Kelly McMullen <kellym(at)aviating.com> Subject: Re: RV-List: adjusting cooling baffles Date: Thursday, June 30, 2011, 2:31 PM You can use aluminum tape across the fins to do your fine tuning, then make a dam to same dimensions when you find what works. On 6/30/2011 2:20 PM, thomas sargent wrote: > I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl #3 i s a bit high.- I've seen many planes with small "dams" at the inlet, smal l strips of aluminum blocking the bottom 1/4" or 1/2" of the cooling fins o n cyl #1. > > Is there any science to this or is it just cut and try? > > How well does the piece of aluminum have to be secured? Since it's backed up against the fins and, I'm assuming has a flange resting on the inlet ra mp, I'm guessing that just using good quality tape holding it down to the i nlet ramp will do for testing purposes. Or is there a better way to secure it temoporarily? > > thanks, > -- Tom Sargent > * > > > * le, List Admin. ________________________________________________________________________________
Date: Jun 30, 2011
Robin: Great photos. Thanks. I was thinking about trying a deflector mounted on the back baffle, angling up at about 45 deg. for a couple inches. It might force more air down thru the back fins. Of course, I really don't know how the air is moving in that area. It's probably pretty turbulent and won't move the way I expect it to. I don't think I can move the rear baffle back with a washer at this stage of the game. I'll see if any movement is possible. I doubt it. -- Tom Sargent ________________________________________________________________________________
Date: Jun 30, 2011
Tom, I was able to get one washer between the rear plate and the cylinder for the screw that holds that back baffle plate to the cylinder. I used one of those washer-holder-tools. It really helped to balance that side..... Ralph -----Original Message----- >From: thomas sargent <sarg314(at)gmail.com> >Sent: Jun 30, 2011 4:20 PM >To: rv-list >Subject: RV-List: adjusting cooling baffles > >I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl #3 is a >bit high. I've seen many planes with small "dams" at the inlet, small >strips of aluminum blocking the bottom 1/4" or 1/2" of the cooling fins on >cyl #1. > >Is there any science to this or is it just cut and try? > >How well does the piece of aluminum have to be secured? Since it's backed up >against the fins and, I'm assuming has a flange resting on the inlet ramp, >I'm guessing that just using good quality tape holding it down to the inlet >ramp will do for testing purposes. Or is there a better way to secure it >temoporarily? > >thanks, >-- >Tom Sargent ________________________________________________________________________________
Date: Jun 30, 2011
You can use aluminum tape to find out how much needs to be blocked. 5 yrs la ter and I'm still using tape. Sent from my Verizon iPhone On Jun 30, 2011, at 3:20 PM, thomas sargent wrote: > I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl #3 is a bit high. I've seen many planes with small "dams" at the inlet, small st rips of aluminum blocking the bottom 1/4" or 1/2" of the cooling fins on cyl #1. > > Is there any science to this or is it just cut and try? > > How well does the piece of aluminum have to be secured? Since it's backed u p against the fins and, I'm assuming has a flange resting on the inlet ramp, I'm guessing that just using good quality tape holding it down to the inlet ramp will do for testing purposes. Or is there a better way to secure it te moporarily? > > thanks, > -- > Tom Sargent > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 01, 2011
The temporary aluminum tape can be applied directly to the cyl fins...or, i f you put a couple of plate nuts in the baffle ramp, you can mount a light w eight aluminum angle in front of the cylinder which can be easily removed fo r sizing by reducing the height of the vertical portion. Sent from my iPad On Jun 30, 2011, at 10:23 PM, Bobby Hester wro te: > You can use aluminum tape to find out how much needs to be blocked. 5 yrs l ater and I'm still using tape. > > Sent from my Verizon iPhone > > On Jun 30, 2011, at 3:20 PM, thomas sargent wrote: > >> I notice that CHT on cyl #1 (on my IO-360) is a bit cool and CHT cyl #3 i s a bit high. I've seen many planes with small "dams" at the inlet, small s trips of aluminum blocking the bottom 1/4" or 1/2" of the cooling fins on cy l #1. >> >> Is there any science to this or is it just cut and try? >> >> How well does the piece of aluminum have to be secured? Since it's backed up against the fins and, I'm assuming has a flange resting on the inlet ram p, I'm guessing that just using good quality tape holding it down to the inl et ramp will do for testing purposes. Or is there a better way to secure it t emoporarily? >> >> thanks, >> -- >> Tom Sargent >> >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 01, 2011
Looking at the oil cooler - installed according to plans - I note that the lowest 1 inch of the opening to the oil cooler is directly behind the cooling fins of cyl #4 . Is air heated by the fins going thru the oil cooler? Has any one experimented with a small baffle there to block the aft side of the fins on #4 so that the air can't so easily get to the oil cooler there? I've noticed that once the oil tempo gets high it takes a long time (~10 minutes) to bring it down. Maybe this is why. I managed to get a 1/16" thick washer on the screw between the rear baffle and cyl #3. It took a fair bit of fiddling, but it's there now. I will try some tape on #1. -- Tom Sargent ________________________________________________________________________________
Date: Jul 01, 2011
Tom, If you can come up with a way to temporarily block the lower area in front of #4 for the summer months (and it works to get the temps down), you may w ant the extra heat in the winter. I have difficulty getting/keeping my oil temp up in the winter. Dale ----- Original Message ----- From: thomas sargent To: rv-list(at)matronics.com Sent: Friday, July 01, 2011 11:32 AM Subject: Re: RV-List: adjusting cooling baffles Looking at the oil cooler - installed according to plans - I note that th e lowest 1 inch of the opening to the oil cooler is directly behind the coo ling fins of cyl #4 . Is air heated by the fins going thru the oil cooler? Has any one experimented with a small baffle there to block the aft side of the fins on #4 so that the air can't so easily get to the oil cooler the re? I've noticed that once the oil tempo gets high it takes a long time (~ 10 minutes) to bring it down. Maybe this is why. I managed to get a 1/16" thick washer on the screw between the rear baffl e and cyl #3. It took a fair bit of fiddling, but it's there now. I will t ry some tape on #1. -- Tom Sargent ________________________________________________________________________________
Date: Jul 01, 2011
What you speak of has merit. I lower the oil temps over 5 degrees by just adding two layers of baffle rubber material between the oil cooler and the baffle wall. That effectively moved the oil cooler away from #4 by 1/8 inc h allowing much more cool air to get to the oil cooler. Mike Robertson Date: Fri=2C 1 Jul 2011 08:32:53 -0700 Subject: Re: RV-List: adjusting cooling baffles From: sarg314(at)gmail.com Looking at the oil cooler - installed according to plans - I note that the lowest 1 inch of the opening to the oil cooler is directly behind the cooli ng fins of cyl #4 . Is air heated by the fins going thru the oil cooler? Has any one experimented with a small baffle there to block the aft side of the fins on #4 so that the air can't so easily get to the oil cooler there ? I've noticed that once the oil tempo gets high it takes a long time (~10 minutes) to bring it down. Maybe this is why. I managed to get a 1/16" thick washer on the screw between the rear baffle and cyl #3. It took a fair bit of fiddling=2C but it's there now. I will try some tape on #1. -- Tom Sargent ________________________________________________________________________________
Date: Jul 02, 2011
Subject: Re: RV-List Digest: 6 Msgs - 07/01/11
I will be returning from vacation on June 4, 2007. If you need something prior to then, please contact Bill Barry at 7070 or by email. Rodney ________________________________________________________________________________
Date: Jul 02, 2011
Subject: WxWorx REWX9ID USB Weather Receiver For Sale...
I have a 1-year old WxWorx REWX9ID USB XM Aircraft Weather and XM Audio receiver for sale. It was just removed from my RV-8 and is in perfect working order. Includes Antenna, Mount, Receiver Unit, and USB Interface. It is compatible with the Grand Rapids EFISs and a number of others. Gives text and graphical representations of weather including Rain, Wind, Temp, etc. Requires separate monthly XM subscription which is not included in this offering. Attached are some pictures of the actual unit for sale. Works great and I wouldn't fly without a similar product. I'm replacing the functionality with an ADS-B receiver. Additional information on the unit can be found here: https://www.wxworx.com/portable-receiver-overview https://www.wxworx.com/interface-modules Aircraft Spruce has the unit for $595: http://www.aircraftspruce.com/catalog/avpages/fl190True.php I will take $400 firm for the unit as shown plus $10 for shipping. First come, first served. Email me with questions. I can accept PayPal http://www.paypal.com using "dralle@matronics.com" or I can accept Visa/MC directly. I will take a 2.5% discount for a check, but it will have to clear before I ship. Best regards, Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 02, 2011
Subject: Re: RV7-List: WxWorx REWX9ID USB Weather Receiver For Sale...
Hi folks, I also have something for sale, Pm 1000 intercom with Stein Air harness wired for the SL40 in my RV7, I since upgraded, price would be 400.- including shipping. Cheers Franz On 02/07/11 5:51 PM, "Matt Dralle" wrote: > > I have a 1-year old WxWorx REWX9ID USB XM Aircraft Weather and XM Audio > receiver for sale. It was just removed from my RV-8 and is in perfect working > order. Includes Antenna, Mount, Receiver Unit, and USB Interface. > > It is compatible with the Grand Rapids EFISs and a number of others. Gives > text and graphical representations of weather including Rain, Wind, Temp, etc. > Requires separate monthly XM subscription which is not included in this > offering. Attached are some pictures of the actual unit for sale. > > Works great and I wouldn't fly without a similar product. I'm replacing the > functionality with an ADS-B receiver. > > Additional information on the unit can be found here: > > https://www.wxworx.com/portable-receiver-overview > https://www.wxworx.com/interface-modules > > Aircraft Spruce has the unit for $595: > > http://www.aircraftspruce.com/catalog/avpages/fl190True.php > > I will take $400 firm for the unit as shown plus $10 for shipping. First > come, first served. Email me with questions. > > I can accept PayPal http://www.paypal.com using "dralle@matronics.com" or I > can accept Visa/MC directly. I will take a 2.5% discount for a check, but it > will have to clear before I ship. > > Best regards, > > Matt Dralle > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... Franz Fux Director of Operations Last Frontier Heliskiing Ltd. Bell 2 Lodge P.O. Box 1237 Vernon, BC, V1T 6N6 CANADA Office Contact T: (250) 558-7980 F: (250) 558-7981 Lodge Contact T: (250) 275-4770 F: (250) 275-4912 http://www.bell2lodge.com --- LAST FRONTIER Heliskiing www.lastfrontierheli.com --- And for some of the best Steelhead Fishing in the world at Bell 2 Lodge www.steelhead-fishing.net ________________________________________________________________________________
Subject: Re: WxWorx REWX9ID USB Weather Receiver For Sale...
Date: Jul 02, 2011
> Works great and I wouldn't fly without a similar product. I'm replacing > the functionality with an ADS-B receiver. > Hi Matt, Can you tell us about your ADS-B receiver? I have a lot of interesting in going down that path also... Thanks, David ________________________________________________________________________________
Date: Jul 02, 2011
At 08:22 PM 7/2/2011 Saturday, you wrote: > >>Works great and I wouldn't fly without a similar product. I'm replacing the functionality with an ADS-B receiver. >Hi Matt, > >Can you tell us about your ADS-B receiver? I have a lot of interesting in going down that path also... > >Thanks, >David Well, I haven't received it yet, but I did order it. There's like a 3 week lead time for some reason. I will post a pirep when I get the new unit and get it hooked up. According to GRT, the weather information provided by the ADS-B as far as how and what is displayed on the GRT EFIS is exactly the same as what is display using the WxWorx. The ADS-B adds traffic display as well. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 03, 2011
Matt can you tell us about the ADS-B receiver? Got a link? I need to start thinking about one. Sent from my Verizon iPhone On Jul 2, 2011, at 7:51 PM, Matt Dralle wrote: > > I have a 1-year old WxWorx REWX9ID USB XM Aircraft Weather and XM Audio receiver for sale. It was just removed from my RV-8 and is in perfect working order. Includes Antenna, Mount, Receiver Unit, and USB Interface. > > It is compatible with the Grand Rapids EFISs and a number of others. Gives text and graphical representations of weather including Rain, Wind, Temp, etc. Requires separate monthly XM subscription which is not included in this offering. Attached are some pictures of the actual unit for sale. > > Works great and I wouldn't fly without a similar product. I'm replacing the functionality with an ADS-B receiver. > > Additional information on the unit can be found here: > > https://www.wxworx.com/portable-receiver-overview > https://www.wxworx.com/interface-modules > > Aircraft Spruce has the unit for $595: > > http://www.aircraftspruce.com/catalog/avpages/fl190True.php > > I will take $400 firm for the unit as shown plus $10 for shipping. First come, first served. Email me with questions. > > I can accept PayPal http://www.paypal.com using "dralle@matronics.com" or I can accept Visa/MC directly. I will take a 2.5% discount for a check, but it will have to clear before I ship. > > Best regards, > > Matt Dralle > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > <2011.07.02 - WxWorx XM Aircraft Weather & Audio Receiver with USB Interface & Antenna (1).jpg> > <2011.07.02 - WxWorx XM Aircraft Weather & Audio Receiver with USB Interface & Antenna (2).jpg> > <2011.07.02 - WxWorx XM Aircraft Weather & Audio Receiver with USB Interface & Antenna (3).jpg> > <2011.07.02 - WxWorx XM Aircraft Weather & Audio Receiver with USB Interface & Antenna (4).jpg> ________________________________________________________________________________
Date: Jul 03, 2011
Subject: Re: ADS-B Transceiver...
At 06:23 AM 7/3/2011 Sunday, you wrote: > >Matt can you tell us about the ADS-B receiver? Got a link? I need to start thinking about one. I ordered the ADS600-B unit from NavWorx: http://www.navworx.com/ads600-b.asp Here's their main site: http://www.navworx.com/index.asp They're not exactly cheap. Here's the price list: http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx I also ordered it with the WIFI module and the ARINC-429 for fun. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 03, 2011
People also might want to check skyradar.net which I have running on my Iphone. Works great for weather. On Sun, Jul 3, 2011 at 1:44 PM, Matt Dralle wrote: > > At 06:23 AM 7/3/2011 Sunday, you wrote: >> >>Matt can you tell us about the ADS-B receiver? Got a link? I need to start thinking about one. > > > I ordered the ADS600-B unit from NavWorx: > > http://www.navworx.com/ads600-b.asp > > Here's their main site: > > http://www.navworx.com/index.asp > > They're not exactly cheap. Here's the price list: > > http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx > > I also ordered it with the WIFI module and the ARINC-429 for fun. > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > -- >From Central Florida, Ollie ________________________________________________________________________________
Date: Jul 04, 2011
Subject: Help with Gns 480 Century HSI
I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, MX20, SL15. I had the GNS 480 software upgrade, since then I am not getting any CDI function on the HSI. the VDI etc, still works, but not CDI. I have checked my setup and all seems OK to me - but I may be missing something. Also, Altitude does not display on MX 20 - have an SL70 remote transponder - output from GNS 480 is showing correct altitude. Any GNS 480 experts, help would be appreciated. Avionics shop where I had the upgrade done is not homebuilder friendly. Dave Burnham RV6A - N64FN - flying since 2006 ________________________________________________________________________________
Date: Jul 04, 2011
If the GNS 480 was the only item removed from your panel, I'd start with the connectors and pins used for that unit. Bruce WWW.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Burnham Sent: Monday, July 04, 2011 6:17 PM Subject: RV-List: Help with Gns 480 Century HSI I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, MX20, SL15. I had the GNS 480 software upgrade, since then I am not getting any CDI function on the HSI. the VDI etc, still works, but not CDI. I have checked my setup and all seems OK to me - but I may be missing something. Also, Altitude does not display on MX 20 - have an SL70 remote transponder - output from GNS 480 is showing correct altitude. Any GNS 480 experts, help would be appreciated. Avionics shop where I had the upgrade done is not homebuilder friendly. Dave Burnham RV6A - N64FN - flying since 2006 ________________________________________________________________________________
Date: Jul 04, 2011
Dave, I have a similar setup.NSD1000 MX20 SL70 PSE7000MS( SL15Equiv) - but Garmin 420 instead.. Let me look through my stuff and give you a couple of things to check out... Meanwhile, did it ever work properly? If not - there will be a different set of things to check.. Ralph From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Burnham Sent: Monday, July 04, 2011 6:17 PM Subject: RV-List: Help with Gns 480 Century HSI I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, MX20, SL15. I had the GNS 480 software upgrade, since then I am not getting any CDI function on the HSI. the VDI etc, still works, but not CDI. I have checked my setup and all seems OK to me - but I may be missing something. Also, Altitude does not display on MX 20 - have an SL70 remote transponder - output from GNS 480 is showing correct altitude. Any GNS 480 experts, help would be appreciated. Avionics shop where I had the upgrade done is not homebuilder friendly. Dave Burnham RV6A - N64FN - flying since 2006 ________________________________________________________________________________
Date: Jul 05, 2011
The MX20 has a serial port definition that needs to be configured for altitude input. I had a similar problem when I swapped out my GX60 for my 420W...the altitude signal needs to come directly as serial input either from the encoder or transponder (mine's from the transponder).previously the GX60 would do it but the 420W did not...caused a minor rewiring change. You may have a similar situation... As for the CDI, there are essentially two wires that provide the L/R signal to the NSD1000.hence the 'did it ever work' question. I have all of the wiring diagrams for everything except the CNX-80 - GNS480. If I can get the installation manual for that, I can tell you what pins to shoot for continuity. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, July 04, 2011 9:23 PM Subject: RE: RV-List: Help with Gns 480 Century HSI Dave, I have a similar setup.NSD1000 MX20 SL70 PSE7000MS( SL15Equiv) - but Garmin 420 instead.. Let me look through my stuff and give you a couple of things to check out... Meanwhile, did it ever work properly? If not - there will be a different set of things to check.. Ralph From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Burnham Sent: Monday, July 04, 2011 6:17 PM Subject: RV-List: Help with Gns 480 Century HSI I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, MX20, SL15. I had the GNS 480 software upgrade, since then I am not getting any CDI function on the HSI. the VDI etc, still works, but not CDI. I have checked my setup and all seems OK to me - but I may be missing something. Also, Altitude does not display on MX 20 - have an SL70 remote transponder - output from GNS 480 is showing correct altitude. Any GNS 480 experts, help would be appreciated. Avionics shop where I had the upgrade done is not homebuilder friendly. Dave Burnham RV6A - N64FN - flying since 2006 http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 05, 2011
Hi Guys, I already have all the equipment I need for ADS-B Out for my Glasair III. But it seems that in its rush to get the regulation out to the public, the FAA did not provide any path for Experimental aircraft to install/approve ADBS-B. The FAA has published an advisory circular on the subject (AC 20-165) that states ALL ADBS-B installations must be approved before use. It then goes on to state that approval requires an STC. It also broadly hints that all equipment must be TSO'ed. You all must know that STC's do not apply to us. To add further confusion, I was told by my local FSDO that all STC's for approval were not being accepted and that the only way to get approval was from the original aircraft manufacturer. I asked the FSDO if we (the home builder) were considered the manufacturer and was told the FAA felt that it was the kit manufacturer. I called the EAA, they were clueless. So, it seems that you (or we) can't get there from here. Any one have any ideas? Bruce WWW.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, July 03, 2011 1:45 PM Subject: RV-List: Re: ADS-B Transceiver... At 06:23 AM 7/3/2011 Sunday, you wrote: > >Matt can you tell us about the ADS-B receiver? Got a link? I need to start thinking about one. I ordered the ADS600-B unit from NavWorx: http://www.navworx.com/ads600-b.asp Here's their main site: http://www.navworx.com/index.asp They're not exactly cheap. Here's the price list: http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-P ADS600-Online-Now.aspx I also ordered it with the WIFI module and the ARINC-429 for fun. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 05, 2011
Woops, Here's the link to the AC, http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument Bruce WWW.Glasair.org ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jul 05, 2011
Hi Bruce, I don't think the AC applies to us since it's only for those seeking TC or STC approval--as you said, we don't have TCs or use STCs. Which transceiver are you using? Display? Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Jul 5, 2011 at 6:46 AM, Bruce wrote: > > Woops, > > Here's the link to the AC, > > http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC > ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument > > > Bruce > WWW.Glasair.org > > ________________________________________________________________________________
Date: Jul 05, 2011
On 7/5/2011 9:04 AM, Bruce wrote: > --> RV-List message posted by: "Bruce" > > Hi Guys, > > I already have all the equipment I need for ADS-B Out for my Glasair > III. But it seems that in its rush to get the regulation out to the > public, the FAA did not provide any path for Experimental aircraft to > install/approve ADBS-B. snip > So, it seems that you (or we) can't get there from here. Any one have > any ideas? Yep. Install it like you want it .... and ask forgiveness later. The only thing I'd put into the 'must do' category is to make sure the transmitted information being broadcast is accurate. There are already a lot of ADS-B installations in experimentals. Linn > Bruce > WWW.Glasair.org > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Sunday, July 03, 2011 1:45 PM > To: rv-list(at)matronics.com > Subject: RV-List: Re: ADS-B Transceiver... > > --> RV-List message posted by: Matt Dralle > > At 06:23 AM 7/3/2011 Sunday, you wrote: >> --> RV-List message posted by: Bobby Hester > >> Matt can you tell us about the ADS-B receiver? Got a link? I need to > start thinking about one. > > > I ordered the ADS600-B unit from NavWorx: > > http://www.navworx.com/ads600-b.asp > > Here's their main site: > > http://www.navworx.com/index.asp > > They're not exactly cheap. Here's the price list: > > http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-P > ADS600-Online-Now.aspx > > I also ordered it with the WIFI module and the ARINC-429 for fun. > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > ________________________________________________________________________________
Date: Jul 05, 2011
To me, the section 1-1(b) says enough to move ahead. If you get it installed, and working properly, you're unlikely to have any worries. And the benefits of it are many. Tim On Jul 5, 2011, at 8:46 AM, "Bruce" wrote: > > Woops, > > Here's the link to the AC, > > http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC > ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument > > > Bruce > WWW.Glasair.org > > > > > ________________________________________________________________________________
Date: Jul 05, 2011
Definitely make sure your transmitted info is set up correctly. Other than that, you'll want it to squawk the same code as your transponder....and if you have a gtx330 you're golden. Likely the same with gtx327. Tim On Jul 5, 2011, at 9:30 AM, Linn Walters wrote: > > On 7/5/2011 9:04 AM, Bruce wrote: >> --> RV-List message posted by: "Bruce" >> >> Hi Guys, >> >> I already have all the equipment I need for ADS-B Out for my Glasair >> III. But it seems that in its rush to get the regulation out to the >> public, the FAA did not provide any path for Experimental aircraft to >> install/approve ADBS-B. > snip >> So, it seems that you (or we) can't get there from here. Any one have >> any ideas? > Yep. Install it like you want it .... and ask forgiveness later. The only thing I'd put into the 'must do' category is to make sure the transmitted information being broadcast is accurate. There are already a lot of ADS-B installations in experimentals. > Linn >> Bruce >> WWW.Glasair.org >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >> Sent: Sunday, July 03, 2011 1:45 PM >> To: rv-list(at)matronics.com >> Subject: RV-List: Re: ADS-B Transceiver... >> >> --> RV-List message posted by: Matt Dralle >> >> At 06:23 AM 7/3/2011 Sunday, you wrote: >>> --> RV-List message posted by: Bobby Hester >> >>> Matt can you tell us about the ADS-B receiver? Got a link? I need to >> start thinking about one. >> >> >> I ordered the ADS600-B unit from NavWorx: >> >> http://www.navworx.com/ads600-b.asp >> >> Here's their main site: >> >> http://www.navworx.com/index.asp >> >> They're not exactly cheap. Here's the price list: >> >> http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-P >> ADS600-Online-Now.aspx >> >> I also ordered it with the WIFI module and the ARINC-429 for fun. >> >> Matt >> >> - >> Matt Dralle >> RV-8 #82880 N998RV "Ruby Vixen" >> http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log >> http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log >> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >> Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Jul 05, 2011
Garmin 530W, Garmin 330 transponder updated for ADBS-B Out, and a RMI microencoder/air data unit. All are TSO'ed except the RMI air data system. I still believe it has to be approved because it transmits position data to ATC. We just can't install and turn it on, at least that's what the FSDO tells me. There is no in flight approved testing procedure in place yet, and no one has the ground testing equipment to verify the transmitted data blocks around here. Bruce WWW.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, July 05, 2011 9:59 AM Subject: Re: RV-List: Re: ADS-B Transceiver... Hi Bruce, I don't think the AC applies to us since it's only for those seeking TC or STC approval--as you said, we don't have TCs or use STCs. Which transceiver are you using? Display? Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Jul 5, 2011 at 6:46 AM, Bruce wrote: > > Woops, > > Here's the link to the AC, > > http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC > ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument > > > Bruce > WWW.Glasair.org > > ________________________________________________________________________________
Date: Jul 05, 2011
Another example of the FAA left hand not having a clue what the right hand is doing. Your transponder and GPS are TSO. That means the position information complies with the requirements. Your air data system has to meet a different regulation, and I assume it does if it passes an IFR static system check. Too many FAA inspectors have no experience/training on experimental aircraft side of the house, and rather than linking you up with someone who does, try to bluff their way into making the problem go away. Just read an idiot article today on the "new" air traffic system that once again says ADSB/Next Gen will replace radar. If that were true, we wouldn't be required to have either Mode A/C transponders or Mode S in addition to UAT. The FAA wouldn't have gone to the totally stupid dual frequency system. Also article said lots about airlines not wanting to spend the money, without one mention of GA and who pays for that. Grump, grump. Maybe Das Fed (if he isn't too busy stomping out office brushfires) can shine some light on the subject for us and send something off to the author of the AC to remind them they need to deal with experimental installs as well if they want the air traffic system to retain integrity. Not that I want more fed involvement, but really is necessary on something that affects all aircraft. On 7/5/2011 8:00 AM, Bruce wrote: > --> RV-List message posted by: "Bruce" > > Garmin 530W, Garmin 330 transponder updated for ADBS-B Out, and a RMI > microencoder/air data unit. All are TSO'ed except the RMI air data > system. > > I still believe it has to be approved because it transmits position data > to ATC. We just can't install and turn it on, at least that's what the > FSDO tells me. There is no in flight approved testing procedure in place > yet, and no one has the ground testing equipment to verify the > transmitted data blocks around here. > > Bruce > WWW.Glasair.org > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor > Sent: Tuesday, July 05, 2011 9:59 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: ADS-B Transceiver... > > --> RV-List message posted by: Dave Saylor > > > Hi Bruce, > > I don't think the AC applies to us since it's only for those seeking > TC or STC approval--as you said, we don't have TCs or use STCs. > > Which transceiver are you using? Display? > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Tue, Jul 5, 2011 at 6:46 AM, Bruce wrote: >> --> RV-List message posted by: "Bruce" >> >> Woops, >> >> Here's the link to the AC, >> >> > http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC >> ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument >> >> >> Bruce >> WWW.Glasair.org >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 05, 2011
But all over that document it says "a position source meeting the minimum performance requirements of any revision of TSO-C129, TSO-C145, TSO-C146, or TSO-C196...) So it says all over that it needs to meet the performance reqs but doesn't say it has to BE TSO'd. I won't go on further other than to say if it doesn't make you comfortable than don't do it. I doubt in today's financial climate they'll be equipping ramp checkers with the tools to test and verify the parameters, but I guess you never know. There are many people using such equipment today though, and the AC makes some awesome points. Some of the biggest things are single-entry-point code entry and things like that. So those things would be more worrysome because if you aren't squawking properly, then THAT is something that may be noticed. Tim On Jul 5, 2011, at 10:00 AM, "Bruce" wrote: > > Garmin 530W, Garmin 330 transponder updated for ADBS-B Out, and a RMI > microencoder/air data unit. All are TSO'ed except the RMI air data > system. > > I still believe it has to be approved because it transmits position data > to ATC. We just can't install and turn it on, at least that's what the > FSDO tells me. There is no in flight approved testing procedure in place > yet, and no one has the ground testing equipment to verify the > transmitted data blocks around here. > > Bruce > WWW.Glasair.org > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor > Sent: Tuesday, July 05, 2011 9:59 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: ADS-B Transceiver... > > > > Hi Bruce, > > I don't think the AC applies to us since it's only for those seeking > TC or STC approval--as you said, we don't have TCs or use STCs. > > Which transceiver are you using? Display? > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > > On Tue, Jul 5, 2011 at 6:46 AM, Bruce wrote: >> >> Woops, >> >> Here's the link to the AC, >> >> > http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC >> ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument >> >> >> Bruce >> WWW.Glasair.org >> >> >> >> >> >> >> >> > > > > > > > ________________________________________________________________________________
Date: Jul 05, 2011
I think it's best for Experimental aviations future to install the stuff, do it to certified standards so it's done right and works properly/perfectly, and to NOT spend your time drawing attention by asking them (das fed) the questions in the first place. As we all know, there are too many who don't understand experimentals, and beyond that, different FSDO's interpret things differently. Many many questions can have a variety of answers. So long as that's the case, sometimes we're better off just doing things right and not inviting regulation by asking for clarification that could never be achieved without drafting newer, deeper reaching, regulation. It's tough enough as it is. ADS-B in isn't rocket science and it's not complicated to get a working system that will give you good traffic info and report your precise location exactly. Just read that AC and make sure you work to that level of accuracy and operability. Tim On Jul 5, 2011, at 10:21 AM, Kelly McMullen wrote: > > Another example of the FAA left hand not having a clue what the right hand is doing. Your transponder and GPS are TSO. That means the position information complies with the requirements. Your air data system has to meet a different regulation, and I assume it does if it passes an IFR static system check. > Too many FAA inspectors have no experience/training on experimental aircraft side of the house, and rather than linking you up with someone who does, try to bluff their way into making the problem go away. > Just read an idiot article today on the "new" air traffic system that once again says ADSB/Next Gen will replace radar. If that were true, we wouldn't be required to have either Mode A/C transponders or Mode S in addition to UAT. The FAA wouldn't have gone to the totally stupid dual frequency system. Also article said lots about airlines not wanting to spend the money, without one mention of GA and who pays for that. Grump, grump. > Maybe Das Fed (if he isn't too busy stomping out office brushfires) can shine some light on the subject for us and send something off to the author of the AC to remind them they need to deal with experimental installs as well if they want the air traffic system to retain integrity. Not that I want more fed involvement, but really is necessary on something that affects all aircraft. > > > > On 7/5/2011 8:00 AM, Bruce wrote: >> --> RV-List message posted by: "Bruce" >> >> Garmin 530W, Garmin 330 transponder updated for ADBS-B Out, and a RMI >> microencoder/air data unit. All are TSO'ed except the RMI air data >> system. >> >> I still believe it has to be approved because it transmits position data >> to ATC. We just can't install and turn it on, at least that's what the >> FSDO tells me. There is no in flight approved testing procedure in place >> yet, and no one has the ground testing equipment to verify the >> transmitted data blocks around here. >> >> Bruce >> WWW.Glasair.org >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor >> Sent: Tuesday, July 05, 2011 9:59 AM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: Re: ADS-B Transceiver... >> >> --> RV-List message posted by: Dave Saylor >> >> >> Hi Bruce, >> >> I don't think the AC applies to us since it's only for those seeking >> TC or STC approval--as you said, we don't have TCs or use STCs. >> >> Which transceiver are you using? Display? >> >> Dave Saylor >> AirCrafters >> 140 Aviation Way >> Watsonville, CA 95076 >> 831-722-9141 Shop >> 831-750-0284 Cell >> >> >> >> On Tue, Jul 5, 2011 at 6:46 AM, Bruce wrote: >>> --> RV-List message posted by: "Bruce" >>> >>> Woops, >>> >>> Here's the link to the AC, >>> >>> >> http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC >>> ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument >>> >>> >>> Bruce >>> WWW.Glasair.org >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 05, 2011
Wise words from Tim, IMHO David Maib 40559 Flying On Jul 5, 2011, at 11:45 AM, Tim Olson wrote: > > I think it's best for Experimental aviations future to install the > stuff, do it to certified standards so it's done right and works > properly/perfectly, and to NOT spend your time drawing attention by > asking them (das fed) the questions in the first place. As we all > know, there are too many who don't understand experimentals, and > beyond that, different FSDO's interpret things differently. Many > many questions can have a variety of answers. So long as that's > the case, sometimes we're better off just doing things right and > not inviting regulation by asking for clarification that could > never be achieved without drafting newer, deeper reaching, > regulation. It's tough enough as it is. ADS-B in isn't rocket > science and it's not complicated to get a working system that will > give you good traffic info and report your precise location > exactly. Just read that AC and make sure you work to that level of > accuracy and operability. > Tim > > > On Jul 5, 2011, at 10:21 AM, Kelly McMullen > wrote: > >> >> Another example of the FAA left hand not having a clue what the >> right hand is doing. Your transponder and GPS are TSO. That means >> the position information complies with the requirements. Your air >> data system has to meet a different regulation, and I assume it >> does if it passes an IFR static system check. >> Too many FAA inspectors have no experience/training on >> experimental aircraft side of the house, and rather than linking >> you up with someone who does, try to bluff their way into making >> the problem go away. >> Just read an idiot article today on the "new" air traffic system >> that once again says ADSB/Next Gen will replace radar. If that >> were true, we wouldn't be required to have either Mode A/C >> transponders or Mode S in addition to UAT. The FAA wouldn't have >> gone to the totally stupid dual frequency system. Also article >> said lots about airlines not wanting to spend the money, without >> one mention of GA and who pays for that. Grump, grump. >> Maybe Das Fed (if he isn't too busy stomping out office >> brushfires) can shine some light on the subject for us and send >> something off to the author of the AC to remind them they need to >> deal with experimental installs as well if they want the air >> traffic system to retain integrity. Not that I want more fed >> involvement, but really is necessary on something that affects all >> aircraft. >> >> >> >> On 7/5/2011 8:00 AM, Bruce wrote: >>> --> RV-List message posted by: "Bruce" >>> >>> Garmin 530W, Garmin 330 transponder updated for ADBS-B Out, and a >>> RMI >>> microencoder/air data unit. All are TSO'ed except the RMI air data >>> system. >>> >>> I still believe it has to be approved because it transmits >>> position data >>> to ATC. We just can't install and turn it on, at least that's >>> what the >>> FSDO tells me. There is no in flight approved testing procedure >>> in place >>> yet, and no one has the ground testing equipment to verify the >>> transmitted data blocks around here. >>> >>> Bruce >>> WWW.Glasair.org >>> >>> -----Original Message----- >>> From: owner-rv-list-server(at)matronics.com >>> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor >>> Sent: Tuesday, July 05, 2011 9:59 AM >>> To: rv-list(at)matronics.com >>> Subject: Re: RV-List: Re: ADS-B Transceiver... >>> >>> --> RV-List message posted by: Dave Saylor >>> >>> >>> Hi Bruce, >>> >>> I don't think the AC applies to us since it's only for those seeking >>> TC or STC approval--as you said, we don't have TCs or use STCs. >>> >>> Which transceiver are you using? Display? >>> >>> Dave Saylor >>> AirCrafters >>> 140 Aviation Way >>> Watsonville, CA 95076 >>> 831-722-9141 Shop >>> 831-750-0284 Cell >>> >>> >>> >>> On Tue, Jul 5, 2011 at 6:46 AM, Bruce wrote: >>>> --> RV-List message posted by: "Bruce" >>>> >>>> Woops, >>>> >>>> Here's the link to the AC, >>>> >>>> >>> http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/ >>> RGADVISORYCIRC >>>> ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument >>>> >>>> >>>> Bruce >>>> WWW.Glasair.org >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> > > ________________________________________________________________________________
Date: Jul 05, 2011
Here is a picture of the "cowl insullation material" stuck to my #1 cylinder. Have 3 degree higher on #3 vs #1 - this weekend at 97F OAT - #3 running at 354F - Oil temp doesn't go over 185F winter or summer. Doesn't take much tape to affect #3 temps. Dave Burnham RV6A Madison, AL On Fri, Jul 1, 2011 at 12:06 PM, Mike Robertson wrote: > What you speak of has merit. I lower the oil temps over 5 degrees by just > adding two layers of baffle rubber material between the oil cooler and the > baffle wall. That effectively moved the oil cooler away from #4 by 1/8 inch > allowing much more cool air to get to the oil cooler. > > Mike Robertson > > ------------------------------ > Date: Fri, 1 Jul 2011 08:32:53 -0700 > > Subject: Re: RV-List: adjusting cooling baffles > From: sarg314(at)gmail.com > > To: rv-list(at)matronics.com > > Looking at the oil cooler - installed according to plans - I note that the > lowest 1 inch of the opening to the oil cooler is directly behind the > cooling fins of cyl #4 . Is air heated by the fins going thru the oil > cooler? Has any one experimented with a small baffle there to block the aft > side of the fins on #4 so that the air can't so easily get to the oil cooler > there? I've noticed that once the oil tempo gets high it takes a long time > (~10 minutes) to bring it down. Maybe this is why. > > I managed to get a 1/16" thick washer on the screw between the rear baffle > and cyl #3. It took a fair bit of fiddling, but it's there now. I will try > some tape on #1. > > -- > Tom Sargent > > * > > get="_blank">http://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.com > ="_blank">http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Jul 06, 2011
Subject: Re: certification issues
Hi Bruce- RE: >So, it seems that you (or we) can't get there from here. Any one have >any ideas? I would recommend contacying Earl Lawrence. See: http://eaa.org/news/2010/2010-10-14_lawrence.asp My past experience suggests he would be a fine place to start, if not end, this issue. Glen Matejcek ________________________________________________________________________________
Date: Jul 07, 2011
Subject: Inspiration - Ultimate Air-To-Air Shot...
Fellow RVers, If you feeling like you needed a little inspiration on that RV project, check out the attached photo. What an awesome shot of a P-51 Mustang leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was rebuilt. But then, what doesn't... ;-) Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 08, 2011
Subject: Re: Inspiration - Ultimate Air-To-Air Shot...
Wait a minute!!! I see a -4 in there! :) On 7-8-2011 02:57, Matt Dralle wrote: > Fellow RVers, > > If you feeling like you needed a little inspiration on that RV project, check out the attached photo. What an awesome shot of a P-51 Mustang leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was rebuilt. But then, what doesn't... ;-) > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... -- ________________________________________________________________________________
Date: Jul 08, 2011
There's an Extra in there too. Still a cool shot. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Friday, July 08, 2011 5:47 AM Subject: Re: RV-List: Inspiration - Ultimate Air-To-Air Shot... Wait a minute!!! I see a -4 in there! :) On 7-8-2011 02:57, Matt Dralle wrote: Fellow RVers, If you feeling like you needed a little inspiration on that RV project, check out the attached photo. What an awesome shot of a P-51 Mustang leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was rebuilt. But then, what doesn't... ;-) Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... -- ________________________________________________________________________________
Subject: Re: RV8-List: Inspiration - Ultimate Air-To-Air Shot...
Date: Jul 08, 2011
Nice Log Matt, but sorry for the occasion. That had to be a very violent event ... seeing all the damage. Good work in saving the landing as much as you did. As to your lessons, I certainly agree with your "don't try to make the turn-off." But is there another lesson? In addition to a maximum crosswind component (especially for tail draggers), should we have a simple maximum wind speed limit? ... or maybe a maximum gust component (e.g., Vgust - Vsteady)? Any gust is bound to not be dead nuts down the centerline ... and should produce differential lift that is hard to handle until the airplane is fully planted and slowed ... again, especially in a tail dragger, but also in a nose dragger. Bill *********************************** William & Sandra Paulin 1575 South Forest Drive Prescott, AZ 86303 Bill Cell +1 858 722 2905 Office +1 760 720 2905 Europe +358 40 720 4047 wpaulin(at)usa.net Sandy Cell +1 858 349 1729 Office +1 928 443 7739 On Jul 7, 2011, at 7:57 PM, Matt Dralle wrote: Fellow RVers, If you feeling like you needed a little inspiration on that RV project, check out the attached photo. What an awesome shot of a P-51 Mustang leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was rebuilt. But then, what doesn't... ;-) Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 08, 2011
No doubt that's a cool picture - but I wonder if it is authentic. The lighting on the 51 looks suspect to me. Does anyone know the photographer?? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Thursday, July 07, 2011 19:58 Subject: RV-List: Inspiration - Ultimate Air-To-Air Shot... Fellow RVers, If you feeling like you needed a little inspiration on that RV project, check out the attached photo. What an awesome shot of a P-51 Mustang leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was rebuilt. But then, what doesn't... ;-) Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 08, 2011
At 08:21 AM 7/8/2011 Friday, you wrote: >Ah, never mind. Now I see your rebuild web page. I didn't know you had the mishap. Glad you're okay and that the gear didn't fold. >Good luck with your rebuild. Maybe add a nose wheel like mine? : ) >Stan Sutterfield > >In a message dated 7/8/2011 3:09:56 A.M. Eastern Daylight Time, Matt Dralle writes: >Makes me wish my RV-8 was rebuilt Yeah, its quite the bummer. I figure about 1172 hours to rebuild. Let me tell you, it has been really emotionally difficult to deconstruct a mostly perfect fuselage. Every time I un-build a different part of the old fuselage salvaging parts to put on the new fuselage, I am reminded of all the work involved in building one of these airplanes. But, this week I actually started real construction on the new fuselage and that felt good. Also, a lot of the replacement parts (wiring, connectors, etc) started arriving this week and getting presents in the mail always cheers me up. :-) Be careful out there. The RVs seem really stout, but they're really pretty fragile. I wasn't going that fast and the mishap really wasn't that big of a deal - I see guys in C-150's doing stuff like it all the time - but the damage can be disproportionately great. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 08, 2011
Yup, I know the photographer and all of the guys in the pic except two. It's real. ----- Original Message ----- From: "Jeff Luckey" <JLuckey(at)pacbell.net> Sent: Friday, July 08, 2011 9:09 AM Subject: RE: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > No doubt that's a cool picture - but I wonder if it is authentic. > The lighting on the 51 looks suspect to me. > > Does anyone know the photographer?? > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Thursday, July 07, 2011 19:58 > To: rv-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > Fellow RVers, > > If you feeling like you needed a little inspiration on that RV project, > check out the attached photo. What an awesome shot of a P-51 Mustang > leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was > rebuilt. But then, what doesn't... ;-) > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > > > > > ________________________________________________________________________________
Date: Jul 08, 2011
Most GA airplanes are flying beer cans. Treat them as such. Robin -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, July 08, 2011 9:43 AM Subject: RV-List: Re: Inspiration - Ultimate Air-To-Air Shot... At 08:21 AM 7/8/2011 Friday, you wrote: >Ah, never mind. Now I see your rebuild web page. I didn't know you had the mishap. Glad you're okay and that the gear didn't fold. >Good luck with your rebuild. Maybe add a nose wheel like mine? : ) >Stan Sutterfield > >In a message dated 7/8/2011 3:09:56 A.M. Eastern Daylight Time, Matt Dralle writes: >Makes me wish my RV-8 was rebuilt Yeah, its quite the bummer. I figure about 1172 hours to rebuild. Let me tell you, it has been really emotionally difficult to deconstruct a mostly perfect fuselage. Every time I un-build a different part of the old fuselage salvaging parts to put on the new fuselage, I am reminded of all the work involved in building one of these airplanes. But, this week I actually started real construction on the new fuselage and that felt good. Also, a lot of the replacement parts (wiring, connectors, etc) started arriving this week and getting presents in the mail always cheers me up. :-) Be careful out there. The RVs seem really stout, but they're really pretty fragile. I wasn't going that fast and the mishap really wasn't that big of a deal - I see guys in C-150's doing stuff like it all the time - but the damage can be disproportionately great. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 08, 2011
Is that a 3/4 scale P-51? I do see flaps deployed on the lead so us pesky little RV's can keep up. R -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Timothy E. Cone Sent: Friday, July 08, 2011 9:51 AM Subject: Re: RV-List: Inspiration - Ultimate Air-To-Air Shot... Yup, I know the photographer and all of the guys in the pic except two. It's real. ----- Original Message ----- From: "Jeff Luckey" <JLuckey(at)pacbell.net> Sent: Friday, July 08, 2011 9:09 AM Subject: RE: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > No doubt that's a cool picture - but I wonder if it is authentic. > The lighting on the 51 looks suspect to me. > > Does anyone know the photographer?? > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Thursday, July 07, 2011 19:58 > To: rv-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > Fellow RVers, > > If you feeling like you needed a little inspiration on that RV project, > check out the attached photo. What an awesome shot of a P-51 Mustang > leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was > rebuilt. But then, what doesn't... ;-) > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > ________________________________________________________________________________
Date: Jul 08, 2011
Full-sized. Here's some info on that particular P-51 in the picture: http://www.mustangsmustangs.com/p-51/survivors/pages/44-84900.shtml Matt At 10:07 AM 7/8/2011 Friday, you wrote: > >Is that a 3/4 scale P-51? I do see flaps deployed on the lead so us pesky >little RV's can keep up. > >R > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Timothy E. Cone >Sent: Friday, July 08, 2011 9:51 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > >Yup, > >I know the photographer and all of the guys in the pic except two. > >It's real. > > >----- Original Message ----- >From: "Jeff Luckey" <JLuckey(at)pacbell.net> >To: >Sent: Friday, July 08, 2011 9:09 AM >Subject: RE: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > >> >> No doubt that's a cool picture - but I wonder if it is authentic. >> The lighting on the 51 looks suspect to me. >> >> Does anyone know the photographer?? >> >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >> Sent: Thursday, July 07, 2011 19:58 >> To: rv-list(at)matronics.com; rv8-list(at)matronics.com >> Subject: RV-List: Inspiration - Ultimate Air-To-Air Shot... >> >> Fellow RVers, >> >> If you feeling like you needed a little inspiration on that RV project, >> check out the attached photo. What an awesome shot of a P-51 Mustang >> leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was >> rebuilt. But then, what doesn't... ;-) >> >> Matt >> >> - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 08, 2011
Matt, So sorry to hear about your incident. I can only imagine the horror of seeing the damage when you climbed out of the plane. (I'm building a 7A) This got me to thinking... You mentioned that your plane has aftermarket landing gear. Is it possible that the gear was "too strong" so that instead of sacrificing the gear struts, the energy was transferred to the airframe? Would stock landing gear have bent & saved the fuse? Engineering minds want to know... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, July 08, 2011 10:18 Subject: RE: RV-List: Inspiration - Ultimate Air-To-Air Shot... Full-sized. Here's some info on that particular P-51 in the picture: http://www.mustangsmustangs.com/p-51/survivors/pages/44-84900.shtml Matt At 10:07 AM 7/8/2011 Friday, you wrote: > >Is that a 3/4 scale P-51? I do see flaps deployed on the lead so us pesky >little RV's can keep up. > >R > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Timothy E. Cone >Sent: Friday, July 08, 2011 9:51 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > >Yup, > >I know the photographer and all of the guys in the pic except two. > >It's real. > > >----- Original Message ----- >From: "Jeff Luckey" <JLuckey(at)pacbell.net> >To: >Sent: Friday, July 08, 2011 9:09 AM >Subject: RE: RV-List: Inspiration - Ultimate Air-To-Air Shot... > > >> >> No doubt that's a cool picture - but I wonder if it is authentic. >> The lighting on the 51 looks suspect to me. >> >> Does anyone know the photographer?? >> >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle >> Sent: Thursday, July 07, 2011 19:58 >> To: rv-list(at)matronics.com; rv8-list(at)matronics.com >> Subject: RV-List: Inspiration - Ultimate Air-To-Air Shot... >> >> Fellow RVers, >> >> If you feeling like you needed a little inspiration on that RV project, >> check out the attached photo. What an awesome shot of a P-51 Mustang >> leading a flight of 7 RVs!! Totally cool! Makes me wish my RV-8 was >> rebuilt. But then, what doesn't... ;-) >> >> Matt >> >> -
June 03, 2011 - July 08, 2011
RV-Archive.digest.vol-us
