RV-Archive.digest.vol-uw
August 02, 2011 - November 17, 2011
Subject: | Re: Engine mounted. |
On Tue, 2 Aug 2011, Charles Kuss wrote:
> Brian,
> I assume that you have a prop governor adapter mounted on the engine?
I think so. Don't really know engine stuff, but there is something
squarish that had this line attached.
>If so, you need to keep that oil line connected. The adapter and line
>allows you to keep the plugs in the front of the crankshaft, which would
>allow you to change to a constant speed prop at a later date, without
>having to replace a punctured inner prop plug. That line and adapter will
>allow any excess oil a way out of the nose of the crankshaft.
I don't think I can get the old line back on, it interferes with the
engine mount. However, it would probably be easier to make a new line
than to do the crankshaft plug stuff. And, leave the the possibility of
adding a constant speed prop at some point if I come into a lot of money
or something.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Thinking engine.
1/4 Starduster II N23UT flying
From: | Michael Kraus <n223rv(at)wolflakeairport.net> |
Speaking from experience with my RV-4, the only thing I would have changed on it
was to add a constant speed prop. I gave up a lot of top end speed and performance
with the fixed pitch prop, and a lit of speed control on ascents and decents.
I flew it for 8 years and kicked myself most the time for not going with
constant speed. For me to change was a new engine (or at least crank shaft)
new prop, and a new cowling, and paint for the cowl. That was just too much
of a tear up for me. If I were to do it over again, I'd invest in a constant
speed prop without question.
It is added money up front, but it is a LOT cheaper than doing it later!
YMMV
-Mike Kraus
>> Brian,
> or something.
From: | "carl.froehlich(at)verizon.net" <carl.froehlich(at)verizon.net> |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,=0A Perhaps you could email me a photo of the area where the mount an
d the oil line collide? Would a change of fitting at the governor adapter h
elp ease this issue? Is the problematic line rigid stainless steel? Or is i
t a flex hose? I am enclosing an attachment which details a small modificat
ion you "might" have to make to the block off plate at the rear of the gove
rnor adapter.=0ACharlie Kuss=0A=0A--- On Tue, 8/2/11, Brian Huffaker To: rv-list(at)matronics.com=0A> Dat
Brian Huffaker =0A> =0A> On Tue, 2 Aug 2011, Charles K
@yahoo.com>=0A> >=0A> > Brian,=0A> >- I assume that you have a prop gover
nor adapter=0A> mounted on the engine?=0A> =0A> - I think so.- Don't re
ally know engine stuff,=0A> but there is something=0A> squarish that had th
is line attached.=0A> =0A> >If so, you need to keep that oil line connected
. The=0A> adapter and line=0A> >allows you to keep the plugs in the front o
f the=0A> crankshaft, which would=0A> >allow you to change to a constant sp
eed prop at a later=0A> date, without=0A> >having to replace a punctured in
ner prop plug. That=0A> line and adapter will=0A> >allow any excess oil a w
ay out of the nose of the=0A> crankshaft.=0A> =0A> - I don't think I can
get the old line back on, it=0A> interferes with the=0A> engine mount.- H
owever, it would probably be easier to=0A> make a new line=0A> than to do t
he crankshaft plug stuff.---And,=0A> leave the the possibility of=0A>
adding a constant speed prop at some point if I come into a=0A> lot of mon
ey=0A> or something.=0A> =0A> =0A> - Brian Huffaker, DSWL (bifft@xmission
.com)=0A> - RV-8A 80091 Thinking engine.=0A> - 1/4 Starduster II N23UT
======================0A> =0A>
=0A> =0A>
> Brian,
> Perhaps you could email me a photo of the area where the mount and the
>oil line collide? Would a change of fitting at the governor adapter help
>ease this issue? Is the problematic line rigid stainless steel? Or is it
>modification you "might" have to make to the block off plate at the rear
>of the governor adapter.
The line is rigid stainless steel. It ran under the right side
cylinders, then around to the back. It went through a space just above
the lower right mount point, and would hit the tube going between that and
the upper right side mount. I can take a picture tonight.
Thanks for that document, I could try to make a cover plate like the one
shown (or just buy if not too expensive). I note that on the starduster,
there is a similar cover plate, with a fitting in the center that then is
connected by a hose to the inverted oil setup. Presumably some kind of
gasket is required to bolt on the plate, the engine I have does have
mounting studs for the prop govenor.
As for the other comments, while the speed range of an RV really does
call for a constant speed, I can't justify the extra $5-10k right now.
I'm hoping fly with only another $10k or so spent, still need to buy
instruments, radios, exhaust, magnetos, and probably other stuff I'm not
remebering.
RV-8A 80091 Thinking about engine.
Brian,=0A I look forward to seeing that photo. Please also take photos of t
he area on the rear of the engine where the SS line attaches, and your blan
king plate.=0A To ease the interference issue, you could simply omit the go
vernor adapter [and the shaft/gear inside it], install the block off plate
and gasket directly to the rear of the accessory housing. You can simply dr
ill and tap for a 45 or 90 degree fitting [whichever works best for your ap
plication] anywhere on the new blanking plate. FYI, you can make your own g
asket, or simply buy one.=0ACheck out the two photos in the link below. The
y show the rear of a Lycoming engine with a prop governor [flaked off black
paint] installed. The governor adapter is the part [better view in the bot
tom photo] which goes between the black governor and the accessory housing.
See=0A=0Ahttp://www.vansairforce.com/community/showpost.php?p=389128&pos
tcount=1=0A=0AThe gray part with the steel AN816 [straight] fitting point
ing to the right, is where your SS tube is supposed to attach. If you have
interference issues, you could do any or any combination of the following t
o cure the problem.=0A#1- Replace the AN816 [straight] fitting with an AN
82 [90 degree] or AN823 [45 degree] fitting.=0A#2- Obtain a new, longer p
iece of SS tube and bend it as required to make it work. This is experiment
al aviation, after all.=0A#3- Replace the SS tube with a fire sleeved fle
xible oil hose. This is even approved by Lycoming for certified aircraft. S
ee Lycoming SI 1435. [Brian, I've sent a copy of SI 1435 to you]=0A=0AFYI L
ycoming SI1462A also shows a nice drawing of the rear of the engine, with a
governor adapter & blanking plate. It the one on the right, on page three.
See=0A=0Ahttp://www.lycoming.textron.com/support/publications/service-inst
ructions/pdfs/SI1462A.pdf=0A=0ACharlie=0A=0A--- On Tue, 8/2/11, Brian Huffa
ker <bifft(at)xmission.com> wrote:=0A=0A> From: Brian Huffaker <bifft@xmission
.com>=0A> Subject: Re: RV-List: Engine mounted.=0A> To: "Charles Kuss" =0A> Cc: rv-list(at)matronics.com=0A> Date: Tuesday, August 2,
2011, 2:47 PM=0A> On Tue, 2 Aug 2011, Charles Kuss=0A> wrote:=0A> =0A> > B
rian,=0A> > Perhaps you could email me a photo of the area where=0A> the mo
unt and the=0A> >oil line collide? Would a change of fitting at the=0A> gov
ernor adapter help=0A> >ease this issue? Is the problematic line rigid=0A>
stainless steel? Or is it=0A> >a flex hose? I am enclosing an attachment wh
ich details=0A> a small=0A> >modification you "might" have to make to the b
lock off=0A> plate at the rear=0A> >of the governor adapter.=0A> =0A> - T
he line is rigid stainless steel.- It ran=0A> under the right side=0A> cy
linders, then around to the back.- It went through a=0A> space just above
=0A> the lower right mount point, and would hit the tube going=0A> between
that and=0A> the upper right side mount.- I can take a picture=0A> tonigh
t.=0A> =0A> - Thanks for that document, I could try to make a=0A> cover p
late like the one=0A> shown (or just buy if not too expensive).- I note t
hat=0A> on the starduster,=0A> there is a similar cover plate, with a fitti
ng in the=0A> center that then is=0A> connected by a hose to the inverted o
il setup.-=0A> Presumably some kind of=0A> gasket is required to bolt on
the plate, the engine I have=0A> does have=0A> mounting studs for the prop
govenor.=0A> =0A> - As for the other comments, while the speed range of
=0A> an RV really does=0A> call for a constant speed, I can't justify the e
xtra $5-10k=0A> right now.=0A> I'm hoping fly with only another $10k or so
spent, still=0A> need to buy=0A> instruments, radios, exhaust, magnetos, an
d probably other=0A> stuff I'm not=0A> remebering.=0A> =0A> - Brian Huffa
ker, DSWL (bifft(at)xmission.com)=0A> - RV-8A 80091- Thinking about engine
.=0A> - 1/4 Starduster II N23UT flying=0A>
> Brian,
> I look forward to seeing that photo. Please also take photos of the area
>on the rear of the engine where the SS line attaches, and your blanking
>plate.
http://www.xmission.com/~bifft/img_2329.jpg
this shows the line as close as I can get to where I took it off of. It
was attached to where the red plug now is. Looking at it, it may be an
aluminum line instead of stainless. The fittings are all Al.
http://www.xmission.com/~bifft/img_2326.jpg
shows the governor adaptor. No blocking plate, whoever pickled the engine
took off the accessories and then covered the holes with aluminum tape.
> To ease the interference issue, you could simply omit the governor
>adapter [and the shaft/gear inside it], install the block off plate and
>drill and tap for a 45 or 90 degree fitting [whichever works best for
>your application] anywhere on the new blanking plate. FYI, you can make
>your own gasket, or simply buy one.
That would probably be best, why carry the weight if I'm not going to use
it. Could even T off of that line and hook it up to the inverted oil
seperator like on the Starduster. As for making a gasket, I suppose the
auto form-a-gasket stuff would work?
>Check out the two photos in the link below. They show the rear of a
>Lycoming engine with a prop governor [flaked off black paint] installed.
>The governor adapter is the part [better view in the bottom photo] which
>goes between the black governor and the accessory housing. See
>http://www.vansairforce.com/community/showpost.php?p=389128&postcount=
>The gray part with the steel AN816 [straight] fitting pointing to the
>to cure the problem.
yep, except the fitting is Al instead of steel.
>#1- Replace the AN816 [straight] fitting with an AN82 [90 degree] or
>#2- Obtain a new, longer piece of SS tube and bend it as required to mak
e
> it work. This is experimental aviation, after all.
this would probably be the easiest, cheapest and lightest way to go. Be
a bit tricky to route around the mount, I know the engine moves alot on
shutdown and startup.
>#3- Replace the SS tube with a fire sleeved flexible oil hose. This is
> even approved by Lycoming for certified aircraft. See Lycoming SI
Thanks for all the help, this is clearing up my questions very well.
RV-8A 80091
