RV-Archive.digest.vol-vt
February 24, 2014 - June 29, 2014
      =0A
      =0A
      The gist of the install was to use 4 pieces of 1x2 inch profile angle=2C ea
      ch about an inch long. I think the thickness was 0.125.
      use those on each corner of the cooler to grab the coolers mounting holes.
      shorter side of the angle on the engine baffles=2C longer side on the coole
      r.=0A
      =0A
      =0A
      In an effort to isolate the cooler from vibration I over sized the holes an
      d put in rubber bushings so that the cooler didn't touch anything but the b
      olts and rubber bushings and then I sealed the perimeter with RTV. The RTV
      is probably what is actually holding the cooler in place.=0A
      =0A
      =0A
      Below my sentence got cut off=2C I meant to say I didn't do the firewall mo
      unt because I didn't like the idea of the hoses "working" as the engine vib
      rated.
      Bill=0A
      =0A
      =0A
       =0A
      =0A
      =0A
=0A
Subject: Re: Oil Cooler's...
=0A =0A I have one with ~ 4 hours on it. Will sell for an hours worth of fuel plus =0A shipping. Had unrelated cooling issues on first few flights=2C but ev er =0A yone pointed to the non- standard configuration (on firewall) so I changed =0A to SW clone on baffling and still hard other problems to resolve.... Now l =0A ife is cool at 175 oil temp and < 330 CHT. =0A =0A Contact off line at 703-732-3264 =0A =0A Marty =0A RV-7=2C 150 hrs=2C KSUT =0A =0A
=0A Subject: RV-List: Re: Oil Cooler's... =0A =0A I just dug back through my emails to find the skinny on the Setrab cooler. =0A I'm pretty sure it is this one: =0A =0A =0A http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-ta =0A ll-m22-ports.html =0A =0A =0A It comes with straight on AN fittings but I couldn't get them to work =0A =0A in the space I had so I used these:http://www.hrpworld.com/store/default/an =0A -10-x-m22-hose-fitting-90.html =0A =0A These fitting are mega expensive but swivel which takes alot of the =0A =0A stress off the attach points. I went this route for a few reasons: =0A =0A I had the stock cooler completely covered with AL tape and stillcouldn't ge =0A t over 200 F temps.(Too much cooling) =0A =0A My baffles cracked from the weight of the stock cooler.(too much weight)I k =0A new of a rv-6 built by 3 engineers(one is a DER) and they've flown =0A =0A 400 hrs trouble free with this cooler.I didn't do the firewall mount becaus =0A e i didn't want the hoses =0A =0A Even still when its cold I can't get over 160 F. =0A =0A Bill =0A =0A =0A On Thu=2C Feb 20=2C 2014 at 7:29 AM=2C Bill Judge wrote: =0A =0A =0A I've been running a Setrab 10 row for around 750 hrs=2C no problems=2C temp =0A s often run too low and so its half covered with AL tape. It's about 1/3 th =0A e size of the standard Vans cooler. =0A =0A =0A They are made of aluminum rather than brass and AL just works better for a =0A heat exchanger. =0A =0A You can get aircraft fittings on them too=2C they even have swivel fittin gs =0A at 90 and 45 degrees available. =0A =0A =0A Bill =0A N84WJ=2C RV-8=2C 980 hrs =0A =0A =0A rv-8.blogspot.com =0A =0A =0A =0A =0A From: Matt Dralle <dralle(at)matronics.com> =0A =0A Subject: RV-List: Oil Cooler's... =0A =0A =0A Greetings RV'ers=2C =0A =0A =0A On the RV-8=2C I've got Stewart/Warner 10610R 10 row oil cooler for the I O- =0A 390. =0A =0A It's mounted on the rear baffle and its worked well and kept the oil temps =0A in =0A =0A the low 180's under all conditions. =0A =0A =0A I noticed today=2C that the outside mounting flange that goes next to the b =0A affle =0A =0A is cracked. I suppose I could get it welded or brazed or whatever they do =0A to =0A =0A aluminium=2C but that seems like a hack. =0A =0A =0A Apparently=2C Chief doesn't carry the Stewart/Warner brand anymore and ha s =0A to different =0A =0A variants of the Aero Classic brand in the 10 Row 10610R compatible unit. =0A =0A =0A One is the "Standard" model for $269: =0A =0A =0A http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler =0A s/standard/aec-8000081.html =0A =0A =0A The other is the "HE" (High Efficiency) models are $575: =0A =0A =0A http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler =0A s/he-series/aec-8001646.html =0A =0A =0A Any thought's on either of these two options? Pros and cons. The HE model =0A s look =0A =0A a lot like the S&W model I have=2C assuming the pictures are accurate. =0A =0A =0A Thanks for the feedback. =0A =0A =0A Matt =0A =0A =0A - =0A =0A Matt Dralle =0A =0A =0A RV-8 #82880 N998RV "Ruby Vixen" =0A =0A http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log =0A =0A http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log =0A =0A http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel =0A =0A Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... =0A =0A =0A RV-6 #20916 N360EM "The Flyer" =0A =0A http://www.mattsrv6.com - Matt's RV-6 Revitalization Log =0A =0A Status: 200+ Hours Since Purchase - Upgrades Complete=3B Now In Full Flye r =0A Mode =0A =0A =0A Matt's Livermore Airport Live ATC Stream! =0A =0A Check out the live ATC stream directly from my hangar at the Livermore =0A =0A Airport. Includes both Tower and Ground transmissions. Archives too! =0A =0A For entertainment purposes only. http://klvk.matronics.com =0A =0A =0A =0A =0A ________________________________ Message 7 ______________________________ _______ =0A =0A =0A =0A From: Marty Helller <marty_away(at)hotmail.com> =0A Subject: RE: RV-List: Re: Oil Cooler's... =0A =0A Also had this configuration....I'll send you photos when home=2C next wee k. =0A In short=2C mounted 2 parallel pieces of angle aluminum on firewall= 2C a =0A nd mounted Setrab to that. Then built a fiberglass 'vulcano' to funnel the =0A air. Had a butterfly valve at the attachment to the baffling.... =0A =0A Marty =0A RV-7=2C KSUT 150 hrs =0A =0A ( P.s. Hi Bill..... Still owe you a ride....) =0A =0A Subject: Re: RV-List: Re: Oil Cooler's... =0A From: larry(at)bowenaero.com =0A =0A Bill - =0A =0A How did you mount the setrab? Any pictures?-- =0A Larry Bowen =0A Larry(at)BowenAero.com =0A http://BowenAero.com =0A =0A =0A On Thu=2C Feb 20=2C 2014 at 10:29 AM=2C Bill Judge wrote =0A : =0A =0A I've been running a Setrab 10 row for around 750 hrs=2C no problems=2C temp =0A s often run too low and so its half covered with AL tape. It's about 1/3 th =0A e size of the standard Vans cooler. =0A =0A =0A They are made of aluminum rather than brass and AL just works better for a =0A heat exchanger. =0A =0A You can get aircraft fittings on them too=2C they even have swivel fittin gs =0A at 90 and 45 degrees available. =0A =0A =0A Bill =0A N84WJ=2C RV-8=2C 980 hrs =0A =0A =0A rv-8.blogspot.com =0A =0A =0A =0A =0A From: Matt Dralle <dralle(at)matronics.com> =0A =0A Subject: RV-List: Oil Cooler's... =0A =0A =0A Greetings RV'ers=2C =0A =0A =0A On the RV-8=2C I've got Stewart/Warner 10610R 10 row oil cooler for the I O- =0A 390. =0A =0A It's mounted on the rear baffle and its worked well and kept the oil temps =0A in =0A =0A the low 180's under all conditions. =0A =0A =0A I noticed today=2C that the outside mounting flange that goes next to the b =0A affle =0A =0A is cracked. I suppose I could get it welded or brazed or whatever they do =0A to =0A =0A aluminium=2C but that seems like a hack. =0A =0A =0A Apparently=2C Chief doesn't carry the Stewart/Warner brand anymore and ha s =0A to different =0A =0A variants of the Aero Classic brand in the 10 Row 10610R compatible unit. =0A =0A =0A One is the "Standard" model for $269: =0A =0A =0A http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler =0A s/standard/aec-8000081.html =0A =0A =0A The other is the "HE" (High Efficiency) models are $575: =0A =0A =0A http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler =0A s/he-series/aec-8001646.html =0A =0A =0A Any thought's on either of these two options? Pros and cons. The HE model =0A s look =0A =0A a lot like the S&W model I have=2C assuming the pictures are accurate. =0A =0A =0A Thanks for the feedback. =0A =0A =0A Matt =0A =0A =0A - =0A =0A Matt Dralle =0A =0A =0A RV-8 #82880 N998RV "Ruby Vixen" =0A =0A http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log =0A =0A http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log =0A =0A http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel =0A =0A Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... =0A =0A =0A RV-6 #20916 N360EM "The Flyer" =0A =0A http://www.mattsrv6.com - Matt's RV-6 Revitalization Log =0A =0A Status: 200+ Hours Since Purchase - Upgrades Complete=3B Now In Full Flye r =0A Mode =0A =0A =0A Matt's Livermore Airport Live ATC Stream! =0A =0A Check out the live ATC stream directly from my hangar at the Livermore =0A =0A Airport. Includes both Tower and Ground transmissions. Archives too! =0A =0A For entertainment purposes only. http://klvk.matronics.com =0A =0A =0A t="_blank">http://www.matronics.com/Navigator?RV-List =0A tp://forums.matronics.com =0A _blank">http://www.matronics.com/contribution =0A =0A =0A =0A =0A ________________________________ Message 8 ______________________________ _______ =0A =0A =0A =0A From: RV6 Flyer <rv6_flyer(at)hotmail.com> =0A Subject: RE: RV-List: Oil Cooler's... =0A =0A I originally flew my O-320 RV-6 in Southern California heat during Septembe =0A r 1997 with an oil cooler mounted on the firewall with 3" SCAT tubing runni =0A ng to it. =0A =0A I constantly had high oil temperature. Relocating the oil cooler to the en =0A gine mount behind cylinder #4 with a full size opening duct to it just an i =0A nch behind the cylinder lowered oil temp 30 degrees F. =0A =0A In a high heat environment with high power settings=2C I would not use a fi =0A rewall mounted oil cooler and 3" SCAT to it. There is not enough air flow =0A going through the oil cooler with the setup that I originally had. =0A =0A Gary A. Sobek =0A "My Sanity" RV-6 N157GS O-320 Hartzell=2C =0A 2=2C810+ Flying Hours So. CA=2C USA =0A =0A =0A =0A =0A =0A =0A =0A =0A get="_blank">http://www.matronics.com/Navigator?RV-List =0A =0A http://forums.matronics.com =0A =0A le=2C List Admin. =0A ="_blank">http://www.matronics.com/contribution =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A t="_blank">http://www.matronics.com/Navigator?RV-List=0A tp://forums.matronics.com=0A _blank">http://www.matronics.com/contribution=0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Feb 24, 2014
Subject: Re: flight guide publications
John: where are you getting the airport info if not from flight guide? I really like the airport diagrams in flight guide, otherwise I just get the FAA facilities book. On Wed, Feb 19, 2014 at 11:55 PM, wrote: > > -- Tom Sargent ________________________________________________________________________________
Date: Feb 24, 2014
I get airport diagrams and information from WingX on my Ipad, and also on my backup HP 4700 using Anywhere Map...also additional info from Air Nav web site. John ----- Original Message ----- From: Thomas Sargent To: rv-list Sent: Monday, February 24, 2014 8:36 AM Subject: Re: RV-List: flight guide publications John: where are you getting the airport info if not from flight guide? I really like the airport diagrams in flight guide, otherwise I just get the FAA facilities book. On Wed, Feb 19, 2014 at 11:55 PM, wrote: -- Tom Sargent ________________________________________________________________________________
Date: Feb 24, 2014
I've had back luck with them too, ever since they made the big change in their paper format. Since then their right hand doesn't know what their left foot is doing. I wish they would quit trying to sell retail. Instead, wholesale their excellent airport maps to WingX, ForeFlight, etc., to replace the poor quality airport diagrams in those apps. They could also wholesale their maps to someone who could properly print and distribute them. On Sun, Feb 16, 2014 at 11:36 AM, Thomas Sargent wrote: > About 14 months ago I ordered a copy of the spiral bound paper edition of > the trusty old "flight guide" from airguide publications (flightguide.com). > They still list it on their website, but they still haven't shipped it. > Every few months I send them an email asking where it is and they respond > telling me it will ship in "a couple months". > > They are pushing an electronic version of the flight guide (for IPads or > Kindles), but I am loathe to become dependent on yet another battery powered > device that's hard to read in daylight. My old flight guide is falling > apart. > > Has any one else had this experience with these people or is it just me that > they hate? Are they going broke? Being sued out of existence? What? > > > -- > Tom Sargent > > ________________________________________________________________________________
Subject: flight guide publications
Date: Feb 24, 2014
If everyone that has had problems with them posts something=2C this will be a very long thread. I tried their new paper product=2C it was late=2C and not user friendly. I had the entire US or all 6 books in the new format. Started using Forefli ght but kept the local book for one year. I may have opened it once in a y ear but I may have never opened it. Dropped all their products and do not miss it. Years ago=2C I had a difficult time reading documents on a computer but sin ce everything at work was available as a soft copy or I could print and hav e a hard copy=2C I taught myself to read on the computer screen without the hard copy. Since the iPad has come out=2C I read almost everything as a e Copy. IF the eCopy of Flight Guide was FREE or a couple of bucks=2C I may use it but have been able to get everything I need from Foreflight so will use the money I save for AvGas and fly more. BTW=2C I have 1=2C635 Cross Country hours and do use the latest info for fl ight planning and execution. Flight Guide is not one of the products that I have used since they changed the format. Yes I tried it=2C did not like it=2C found Foreflight to be an EXCELLENT replacement. Respectfully=2C Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C820+ Flying Hours So. CA=2C USA > From: ralphmariafinch(at)gmail.com > Date: Mon=2C 24 Feb 2014 12:53:37 -0800 > Subject: Re: RV-List: flight guide publications > To: rv-list(at)matronics.com > > > I've had back luck with them too=2C ever since they made the big change > in their paper format. Since then their right hand doesn't know what > their left foot is doing. > > I wish they would quit trying to sell retail. Instead=2C wholesale their > excellent airport maps to WingX=2C ForeFlight=2C etc.=2C to replace the p oor > quality airport diagrams in those apps. They could also wholesale > their maps to someone who could properly print and distribute them. > > On Sun=2C Feb 16=2C 2014 at 11:36 AM=2C Thomas Sargent wrote: > > About 14 months ago I ordered a copy of the spiral bound paper edition of > > the trusty old "flight guide" from airguide publications (flightguide.c om). > > They still list it on their website=2C but they still haven't shipped i t. > > Every few months I send them an email asking where it is and they respo nd > > telling me it will ship in "a couple months". > > > > They are pushing an electronic version of the flight guide (for IPads o r > > Kindles)=2C but I am loathe to become dependent on yet another battery powered > > device that's hard to read in daylight. My old flight guide is falling > > apart. > > > > Has any one else had this experience with these people or is it just me that > > they hate? Are they going broke? Being sued out of existence? What? > > > > > > > > -- > > Tom Sargent > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Feb 24, 2014
They do license their diagrams to Dynon, AFS, Aspen and a bunch of portable units via Seattle Avionics. On 2/24/2014 1:53 PM, Ralph Finch wrote: > > I've had back luck with them too, ever since they made the big change > in their paper format. Since then their right hand doesn't know what > their left foot is doing. > > I wish they would quit trying to sell retail. Instead, wholesale their > excellent airport maps to WingX, ForeFlight, etc., to replace the poor > quality airport diagrams in those apps. They could also wholesale > their maps to someone who could properly print and distribute them. > > On Sun, Feb 16, 2014 at 11:36 AM, Thomas Sargent wrote: >> About 14 months ago I ordered a copy of the spiral bound paper edition of >> the trusty old "flight guide" from airguide publications (flightguide.com). >> They still list it on their website, but they still haven't shipped it. >> Every few months I send them an email asking where it is and they respond >> telling me it will ship in "a couple months". >> >> They are pushing an electronic version of the flight guide (for IPads or >> Kindles), but I am loathe to become dependent on yet another battery powered >> device that's hard to read in daylight. My old flight guide is falling >> apart. >> >> Has any one else had this experience with these people or is it just me that >> they hate? Are they going broke? Being sued out of existence? What? >> >> >> >> -- >> Tom Sargent >> >> > > ________________________________________________________________________________
Date: Feb 24, 2014
Is there something like foreflight that works with an android phone? Apparently they deal only with Apple stuff. On Mon, Feb 24, 2014 at 2:18 PM, Kelly McMullen wrote: > > They do license their diagrams to Dynon, AFS, Aspen and a bunch of > portable units via Seattle Avionics. > > > On 2/24/2014 1:53 PM, Ralph Finch wrote: > >> >> I've had back luck with them too, ever since they made the big change >> in their paper format. Since then their right hand doesn't know what >> their left foot is doing. >> >> I wish they would quit trying to sell retail. Instead, wholesale their >> excellent airport maps to WingX, ForeFlight, etc., to replace the poor >> quality airport diagrams in those apps. They could also wholesale >> their maps to someone who could properly print and distribute them. >> >> On Sun, Feb 16, 2014 at 11:36 AM, Thomas Sargent >> wrote: >> >>> About 14 months ago I ordered a copy of the spiral bound paper edition of >>> the trusty old "flight guide" from airguide publications ( >>> flightguide.com). >>> They still list it on their website, but they still haven't shipped it. >>> Every few months I send them an email asking where it is and they respond >>> telling me it will ship in "a couple months". >>> >>> They are pushing an electronic version of the flight guide (for IPads or >>> Kindles), but I am loathe to become dependent on yet another battery >>> powered >>> device that's hard to read in daylight. My old flight guide is falling >>> apart. >>> >>> Has any one else had this experience with these people or is it just me >>> that >>> they hate? Are they going broke? Being sued out of existence? What? >>> >>> >>> >>> -- >>> Tom Sargent >>> >>> >>> >> >> >> > > -- Tom Sargent ________________________________________________________________________________
From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com>
Date: Feb 25, 2014
R2FybWluIFBpbG90IHdvcmtzIG9uIEFuZHJvaWQuIFRoZXkgcHJldHR5IG11Y2ggbWF0Y2ggZmVh dHVyZXMgd2l0aCBGb3JlZmxpZ2h0LiBJIHVzZWQgaXQgYmVjYXVzZSBJIGhhdmUgYSBHREwtMzkg Zm9yIEFEU0IuIEkgZGlzcGxheSBBRFNCIG9uIG15IDc5NiBpbiBmbGlnaHQgYW5kIHJlYWxpemVk IEkgb25seSB1c2UgbXkgSXBhZCBmb3IgcHJlZmxpZ2h0IHBsYW5uaW5nLiBTbyBJIHN3aXRjaGVk IGJhY2sgdG8gRm9yZWZsaWdodCB3aGVuIEkgaGFkIHRvIHJlbmV3LiBJdOKAmXMgYSBnb29kIHBy b2R1Y3QgYnV0IEkgdGhpbmsgRm9yZWZsaWdodCBpcyBiZXR0ZXIgaW4gc29tZSBhcmVhcy4NCg0K UmVnYXJkcywNCkdyZWcgWW91bmcNCg0KDQpGcm9tOiBvd25lci1ydi1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tIFttYWlsdG86b3duZXItcnYtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24g QmVoYWxmIE9mIFRob21hcyBTYXJnZW50DQpTZW50OiBNb25kYXksIEZlYnJ1YXJ5IDI0LCAyMDE0 IDU6NDEgUE0NClRvOiBydi1saXN0DQpTdWJqZWN0OiBSZTogUlYtTGlzdDogZmxpZ2h0IGd1aWRl IHB1YmxpY2F0aW9ucw0KDQpJcyB0aGVyZSBzb21ldGhpbmcgbGlrZSBmb3JlZmxpZ2h0IHRoYXQg d29ya3Mgd2l0aCBhbiBhbmRyb2lkIHBob25lPyAgQXBwYXJlbnRseSB0aGV5IGRlYWwgb25seSB3 aXRoIEFwcGxlIHN0dWZmLg0KDQpPbiBNb24sIEZlYiAyNCwgMjAxNCBhdCAyOjE4IFBNLCBLZWxs eSBNY011bGxlbiA8a2VsbHltQGF2aWF0aW5nLmNvbTxtYWlsdG86a2VsbHltQGF2aWF0aW5nLmNv bT4+IHdyb3RlOg0KLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEtlbGx5IE1jTXVsbGVu IDxrZWxseW1AYXZpYXRpbmcuY29tPG1haWx0bzprZWxseW1AYXZpYXRpbmcuY29tPj4NCg0KVGhl eSBkbyBsaWNlbnNlIHRoZWlyIGRpYWdyYW1zIHRvIER5bm9uLCBBRlMsIEFzcGVuIGFuZCBhIGJ1 bmNoIG9mIHBvcnRhYmxlIHVuaXRzIHZpYSBTZWF0dGxlIEF2aW9uaWNzLg0KDQoNCk9uIDIvMjQv MjAxNCAxOjUzIFBNLCBSYWxwaCBGaW5jaCB3cm90ZToNCi0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9z dGVkIGJ5OiBSYWxwaCBGaW5jaCA8cmFscGhtYXJpYWZpbmNoQGdtYWlsLmNvbTxtYWlsdG86cmFs cGhtYXJpYWZpbmNoQGdtYWlsLmNvbT4+DQoNCkkndmUgaGFkIGJhY2sgbHVjayB3aXRoIHRoZW0g dG9vLCBldmVyIHNpbmNlIHRoZXkgbWFkZSB0aGUgYmlnIGNoYW5nZQ0KaW4gdGhlaXIgcGFwZXIg Zm9ybWF0LiBTaW5jZSB0aGVuIHRoZWlyIHJpZ2h0IGhhbmQgZG9lc24ndCBrbm93IHdoYXQNCnRo ZWlyIGxlZnQgZm9vdCBpcyBkb2luZy4NCg0KSSB3aXNoIHRoZXkgd291bGQgcXVpdCB0cnlpbmcg dG8gc2VsbCByZXRhaWwuIEluc3RlYWQsIHdob2xlc2FsZSB0aGVpcg0KZXhjZWxsZW50IGFpcnBv cnQgbWFwcyB0byBXaW5nWCwgRm9yZUZsaWdodCwgZXRjLiwgdG8gcmVwbGFjZSB0aGUgcG9vcg0K cXVhbGl0eSBhaXJwb3J0IGRpYWdyYW1zIGluIHRob3NlIGFwcHMuIFRoZXkgY291bGQgYWxzbyB3 aG9sZXNhbGUNCnRoZWlyIG1hcHMgdG8gc29tZW9uZSB3aG8gY291bGQgcHJvcGVybHkgcHJpbnQg YW5kIGRpc3RyaWJ1dGUgdGhlbS4NCg0KT24gU3VuLCBGZWIgMTYsIDIwMTQgYXQgMTE6MzYgQU0s IFRob21hcyBTYXJnZW50IDxzYXJnMzE0QGdtYWlsLmNvbTxtYWlsdG86c2FyZzMxNEBnbWFpbC5j b20+PiB3cm90ZToNCkFib3V0IDE0IG1vbnRocyBhZ28gSSBvcmRlcmVkIGEgY29weSBvZiB0aGUg c3BpcmFsIGJvdW5kIHBhcGVyIGVkaXRpb24gb2YNCnRoZSB0cnVzdHkgb2xkICJmbGlnaHQgZ3Vp ZGUiIGZyb20gYWlyZ3VpZGUgcHVibGljYXRpb25zIChmbGlnaHRndWlkZS5jb208aHR0cDovL2Zs aWdodGd1aWRlLmNvbT4pLg0KVGhleSBzdGlsbCBsaXN0IGl0IG9uIHRoZWlyIHdlYnNpdGUsIGJ1 dCB0aGV5IHN0aWxsIGhhdmVuJ3Qgc2hpcHBlZCBpdC4NCkV2ZXJ5IGZldyBtb250aHMgSSBzZW5k IHRoZW0gYW4gZW1haWwgYXNraW5nIHdoZXJlIGl0IGlzIGFuZCB0aGV5IHJlc3BvbmQNCnRlbGxp bmcgbWUgaXQgd2lsbCBzaGlwIGluICJhIGNvdXBsZSBtb250aHMiLg0KDQpUaGV5IGFyZSBwdXNo aW5nIGFuIGVsZWN0cm9uaWMgdmVyc2lvbiBvZiB0aGUgZmxpZ2h0IGd1aWRlIChmb3IgSVBhZHMg b3INCktpbmRsZXMpLCBidXQgSSBhbSBsb2F0aGUgdG8gYmVjb21lIGRlcGVuZGVudCBvbiB5ZXQg YW5vdGhlciBiYXR0ZXJ5IHBvd2VyZWQNCmRldmljZSB0aGF0J3MgaGFyZCB0byByZWFkIGluIGRh eWxpZ2h0LiAgTXkgb2xkIGZsaWdodCBndWlkZSBpcyBmYWxsaW5nDQphcGFydC4NCg0KSGFzIGFu eSBvbmUgZWxzZSBoYWQgdGhpcyBleHBlcmllbmNlIHdpdGggdGhlc2UgcGVvcGxlIG9yIGlzIGl0 IGp1c3QgbWUgdGhhdA0KdGhleSBoYXRlPyAgQXJlIHRoZXkgZ29pbmcgYnJva2U/IEJlaW5nIHN1 ZWQgb3V0IG9mIGV4aXN0ZW5jZT8gV2hhdD8NCg0KDQoNCi0tDQpUb20gU2FyZ2VudA0KDQoNCg0K DQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCnRhcmdldD0iX2JsYW5rIj5o dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWLUxpc3QNCj09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KTVMgLQ0KayI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tDQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCmUgLQ0KICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KdD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vY29udHJpYnV0aW9uDQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KDQoNCg0KDQotLQ0KVG9tIFNhcmdlbnQNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAg ICAgLSBUaGUgUlYtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRoZSBtYW55IExpc3QgdXRp bGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8tPSBBcmNoaXZlIFNlYXJj aCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0KXy09IFBob3Rvc2hhcmUs IGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP1JWLUxpc3QNCg0KXy09DQoNCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAg ICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KDQpfLT0gU2FtZSBncmVhdCBjb250ZW50 IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09DQoNCl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KXy09DQoNCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAg ICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCg0KXy09ICBUaGFuayB5b3UgZm9y IHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCg0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg= ________________________________________________________________________________
Date: Feb 24, 2014
I have been using the Garmin app on a Nexus 7 tablet. I have also used Fore flight, and are using WingX and Garmin on an iphone 5. The android garmin a pp is definitely not as nice as whats available on the Apple devices, howeve r, its still good and better than the other android apps I have looked at. O ne nice thing about the Nexus 7 is that it has a good built in GPS. I have n ot had a problem with it losing satellites. Nikolaos Napoli > On Feb 24, 2014, at 7:02 PM, "bigdog(at)bentwing.com" w rote: > > Garmin Pilot works on Android. They pretty much match features with Forefl ight. I used it because I have a GDL-39 for ADSB. I display ADSB on my 796 i n flight and realized I only use my Ipad for preflight planning. So I switch ed back to Foreflight when I had to renew. It=C3=A2=82=AC=84=A2s a goo d product but I think Foreflight is better in some areas. > > Regards, > Greg Young > > > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matr onics.com] On Behalf Of Thomas Sargent > Sent: Monday, February 24, 2014 5:41 PM > To: rv-list > Subject: Re: RV-List: flight guide publications > > Is there something like foreflight that works with an android phone? Appa rently they deal only with Apple stuff. > > > On Mon, Feb 24, 2014 at 2:18 PM, Kelly McMullen wrot e: > > They do license their diagrams to Dynon, AFS, Aspen and a bunch of portabl e units via Seattle Avionics. > > > On 2/24/2014 1:53 PM, Ralph Finch wrote: > > I've had back luck with them too, ever since they made the big change > in their paper format. Since then their right hand doesn't know what > their left foot is doing. > > I wish they would quit trying to sell retail. Instead, wholesale their > excellent airport maps to WingX, ForeFlight, etc., to replace the poor > quality airport diagrams in those apps. They could also wholesale > their maps to someone who could properly print and distribute them. > > On Sun, Feb 16, 2014 at 11:36 AM, Thomas Sargent wrote : > About 14 months ago I ordered a copy of the spiral bound paper edition of > the trusty old "flight guide" from airguide publications (flightguide.com) . > They still list it on their website, but they still haven't shipped it. > Every few months I send them an email asking where it is and they respond > telling me it will ship in "a couple months". > > They are pushing an electronic version of the flight guide (for IPads or > Kindles), but I am loathe to become dependent on yet another battery power ed > device that's hard to read in daylight. My old flight guide is falling > apart. > > Has any one else had this experience with these people or is it just me th at > they hate? Are they going broke? Being sued out of existence? What? > > > > -- > Tom Sargent > > > > > > > > ========================= > target="_blank">http://www.matronics.com/Navigator?RV-List > ========================= > MS - > k">http://forums.matronics.com > ========================= > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========================= > > > > > > > -- > Tom Sargent > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > ky=C2=B7=C3=A8=C5=BE=C3=9B"=C3=8D=C3=AD=C5=93=C2=A2Z+=C3=93M4=C3=93G=C3=9A q=C3=A7(=C2=BA=C2=B8=C5=BE=C2=AEw=C2=B0r=B9=C2=AB=B0=C3=C3=93 =C3=A4U.+-=12f=C2=A2=9DZ+=C2=BAe,z=C3=98^1=C2=ABk=C2=A2x=C5=93 =C2=B0=C2=B8=C2=AC=C2=B4W=C5=A1=C2=B6=C3=C3=9E=C2=B0=C3'=C2=AF=C5-=06 =C2=AD=C2=A2=C2=BBhn=C2=BA0=C2=B1=C3=ABazf=C2=A7=C3=88=C2=B8=C2=AC=C2=B6=C3=AB b=93+bz=C3=8B.r=16=C2=AC.+-R=7F=C3=92=C2=B9=C2=BB=1C=C2=AE*m=C5- =B0=C3=C2=AD=C3=88b=C2=BD=C3=A4=C5=BEj=C2=B7!=0E=C5=92'=93- =C2=9D=C3=AC6=C2=B2=06=C2=BA0=C2=B1=C3-=C2=A1j=C3=91@@=C3=B8h=C2=B6=B9 !j=C2=B7=C5=A1=C2=9D=C3=99=C2=AEr=19=C2=AEr=19=C2=A8=C2=AD=C3=C2=A1=C2=AD =C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=0C0=84=A2=C2=ABk=C2=A2x=C5=93=C2=B1=C3=8A &=C3=BC=C3'=C2=AF=C5-=06=C2=AD=C2=A2=C2=B4U.+--=C3=9Bi=C3=C3=BC 0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87(=BA=C3=B3Z=C2=BE(=1A=C2=B6=C5 -=C3=91T=C2=B8=C2=AC=C2=B7=C3=B6=C5=92=014N4=82=AC=99X@E9=15=0CI& =C2z =C3=9Ej=C3=97(=C5=BE=C3=97=C2=A7=C2=B5=C2=A9l=C2=A1=C2=AB=C3=9A=C5- V=BA=A2=C3=AB=C3=A2j=C3=98^Y=C3=C3=85=C2=A2=C2=BB=C2=C2=B1 =C2=A8ky=C3=B8m=C2=B6=C5=B8=C3~=C5-=C3=AE=C5=A1=C3=89=C5=A1=C2=B6=C2=BA '=B0=C3=8B=1C=C2=A2hm=C2=B6=C5=B8=C3~=C5-=C3=AE=C5=A1=C3=89=C5=A1 =C2=B6=C2=BA'=B0=C3=8B=1C=C2=A2o=C3=9A.+- =B0=C3=AD=C2=AE&=C3=AE =C2=B6*'Y=C3=C3=92=C5-=C3=97=9C=C2=A9=C3=A4=C3=8A=B9 =C5=B8=C2=A2=C2=BC=C2=A8=C2=BA=C2=B8=1E=C2=9D=C3=C3=A8=C2=BA=C3=8B.=C2 =C5=A1+=C2=B4=C3=86=C2=AD=C2=B4:=C3=9A=93W=B9=C5-=C3=8B@vh=C2=A7 j=1A=C3=9E~=1Bm=C2=A7=C3=C3=B0=C3=83 =C5=A1=C2=B6=C2=BA'=B0=C3=8B=1C =C2=A2o=C3=9C=C2=A2{k=B0=C2=BB=C2=AD=C5-=B0=C3=A1=C2=B6=C3=9A=7F =C3=0C0=84=A2=C2=ABk=C2=A2x=C5=93=C2=B1=C3=8A&=C3=BD=C3=8A'=C2=B6=C2=B8 =BA=C2=BA=C3=98=C2=A8=C5=B8=C3=B6=C2o=C3=B7=C3=A8=C5=BE=C3=9F=C3=A9 =C2=AD=C3=AF=C3=9B=C2=A1=C3=9C=C2-=C3=99=C2=A5 ________________________________________________________________________________
Date: Feb 24, 2014
Subject: Re: Van's SBs
Just inspected my circa 1994 RV-6 for both the stab spar and elevator spar cracks per the respective SB's and found nothing questionable. Whew. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode ________________________________________________________________________________
From: "Fisher Paul A." <FisherPaulA(at)johndeere.com>
Date: Feb 25, 2014
SXTigJlzIG5vdCBzcGVjaWZpY2FsbHkgdGhlIEZsaWdodCBHdWlkZSwgYnV0IGZvciBhbiBBbmRy b2lkIGRldmljZSBJIHJlY29tbWVuZCBOYXZpYXRvci4gIEJ1dCB0aGVyZSBpcyBhbHNvIEZsdFBs YW4gTW9iaWxlIGFuZCBBdmFyZSB0aGF0IGhhdmUgbW92aW5nIG1hcCBkaXNwbGF5cy4gIEFuZCBG bHlRIFBvY2tldCBpZiB5b3UganVzdCB3YW50IHRoZSBBaXJwb3J0IGZhY2lsaXRpZXMgZGF0YS4g IEkgdXNlIE5hdmlhdG9yIG9uIG15IEFuZHJvaWQgdGFibGV0IGFzIG15IG1vdmluZyBtYXAgKHNl Y3Rpb25hbCByZXBsYWNlbWVudCksIGJ1dCBJIHVzZSB0aGVtIGFsbCB0byBvbmUgZXh0ZW50IG9y IGFub3RoZXIg4oCTIHRoYXQgaXMsIEkgaGF2ZW7igJl0IGRlbGV0ZWQgYW55IG9mIHRoZW0geWV0 ISAgQWxsIGJ1dCBOYXZpYXRvciBhcmUgZnJlZS4NCg0KUGF1bCBBLiBGaXNoZXINClJWLTdBIE4x OFBGDQoNCkZyb206IG93bmVyLXJ2LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpv d25lci1ydi1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgVGhvbWFzIFNh cmdlbnQNClNlbnQ6IE1vbmRheSwgRmVicnVhcnkgMjQsIDIwMTQgNTo0MSBQTQ0KVG86IHJ2LWxp c3QNClN1YmplY3Q6IFJlOiBSVi1MaXN0OiBmbGlnaHQgZ3VpZGUgcHVibGljYXRpb25zDQoNCklz IHRoZXJlIHNvbWV0aGluZyBsaWtlIGZvcmVmbGlnaHQgdGhhdCB3b3JrcyB3aXRoIGFuIGFuZHJv aWQgcGhvbmU/ICBBcHBhcmVudGx5IHRoZXkgZGVhbCBvbmx5IHdpdGggQXBwbGUgc3R1ZmYuDQoN Ck9uIE1vbiwgRmViIDI0LCAyMDE0IGF0IDI6MTggUE0sIEtlbGx5IE1jTXVsbGVuIDxrZWxseW1A YXZpYXRpbmcuY29tPG1haWx0bzprZWxseW1AYXZpYXRpbmcuY29tPj4gd3JvdGU6DQotLT4gUlYt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogS2VsbHkgTWNNdWxsZW4gPGtlbGx5bUBhdmlhdGluZy5j b208bWFpbHRvOmtlbGx5bUBhdmlhdGluZy5jb20+Pg0KDQpUaGV5IGRvIGxpY2Vuc2UgdGhlaXIg ZGlhZ3JhbXMgdG8gRHlub24sIEFGUywgQXNwZW4gYW5kIGEgYnVuY2ggb2YgcG9ydGFibGUgdW5p dHMgdmlhIFNlYXR0bGUgQXZpb25pY3MuDQoNCg0KT24gMi8yNC8yMDE0IDE6NTMgUE0sIFJhbHBo IEZpbmNoIHdyb3RlOg0KLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFJhbHBoIEZpbmNo IDxyYWxwaG1hcmlhZmluY2hAZ21haWwuY29tPG1haWx0bzpyYWxwaG1hcmlhZmluY2hAZ21haWwu Y29tPj4NCg0KSSd2ZSBoYWQgYmFjayBsdWNrIHdpdGggdGhlbSB0b28sIGV2ZXIgc2luY2UgdGhl eSBtYWRlIHRoZSBiaWcgY2hhbmdlDQppbiB0aGVpciBwYXBlciBmb3JtYXQuIFNpbmNlIHRoZW4g dGhlaXIgcmlnaHQgaGFuZCBkb2Vzbid0IGtub3cgd2hhdA0KdGhlaXIgbGVmdCBmb290IGlzIGRv aW5nLg0KDQpJIHdpc2ggdGhleSB3b3VsZCBxdWl0IHRyeWluZyB0byBzZWxsIHJldGFpbC4gSW5z dGVhZCwgd2hvbGVzYWxlIHRoZWlyDQpleGNlbGxlbnQgYWlycG9ydCBtYXBzIHRvIFdpbmdYLCBG b3JlRmxpZ2h0LCBldGMuLCB0byByZXBsYWNlIHRoZSBwb29yDQpxdWFsaXR5IGFpcnBvcnQgZGlh Z3JhbXMgaW4gdGhvc2UgYXBwcy4gVGhleSBjb3VsZCBhbHNvIHdob2xlc2FsZQ0KdGhlaXIgbWFw cyB0byBzb21lb25lIHdobyBjb3VsZCBwcm9wZXJseSBwcmludCBhbmQgZGlzdHJpYnV0ZSB0aGVt Lg0KDQpPbiBTdW4sIEZlYiAxNiwgMjAxNCBhdCAxMTozNiBBTSwgVGhvbWFzIFNhcmdlbnQgPHNh cmczMTRAZ21haWwuY29tPG1haWx0bzpzYXJnMzE0QGdtYWlsLmNvbT4+IHdyb3RlOg0KQWJvdXQg MTQgbW9udGhzIGFnbyBJIG9yZGVyZWQgYSBjb3B5IG9mIHRoZSBzcGlyYWwgYm91bmQgcGFwZXIg ZWRpdGlvbiBvZg0KdGhlIHRydXN0eSBvbGQgImZsaWdodCBndWlkZSIgZnJvbSBhaXJndWlkZSBw dWJsaWNhdGlvbnMgKGZsaWdodGd1aWRlLmNvbTxodHRwOi8vZmxpZ2h0Z3VpZGUuY29tPikuDQpU aGV5IHN0aWxsIGxpc3QgaXQgb24gdGhlaXIgd2Vic2l0ZSwgYnV0IHRoZXkgc3RpbGwgaGF2ZW4n dCBzaGlwcGVkIGl0Lg0KRXZlcnkgZmV3IG1vbnRocyBJIHNlbmQgdGhlbSBhbiBlbWFpbCBhc2tp bmcgd2hlcmUgaXQgaXMgYW5kIHRoZXkgcmVzcG9uZA0KdGVsbGluZyBtZSBpdCB3aWxsIHNoaXAg aW4gImEgY291cGxlIG1vbnRocyIuDQoNClRoZXkgYXJlIHB1c2hpbmcgYW4gZWxlY3Ryb25pYyB2 ZXJzaW9uIG9mIHRoZSBmbGlnaHQgZ3VpZGUgKGZvciBJUGFkcyBvcg0KS2luZGxlcyksIGJ1dCBJ IGFtIGxvYXRoZSB0byBiZWNvbWUgZGVwZW5kZW50IG9uIHlldCBhbm90aGVyIGJhdHRlcnkgcG93 ZXJlZA0KZGV2aWNlIHRoYXQncyBoYXJkIHRvIHJlYWQgaW4gZGF5bGlnaHQuICBNeSBvbGQgZmxp Z2h0IGd1aWRlIGlzIGZhbGxpbmcNCmFwYXJ0Lg0KDQpIYXMgYW55IG9uZSBlbHNlIGhhZCB0aGlz IGV4cGVyaWVuY2Ugd2l0aCB0aGVzZSBwZW9wbGUgb3IgaXMgaXQganVzdCBtZSB0aGF0DQp0aGV5 IGhhdGU/ICBBcmUgdGhleSBnb2luZyBicm9rZT8gQmVpbmcgc3VlZCBvdXQgb2YgZXhpc3RlbmNl PyBXaGF0Pw0KDQoNCg0KLS0NClRvbSBTYXJnZW50DQoNCg0KDQoNCj09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9OYXZpZ2F0b3I/UlYtTGlzdA0KPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpNUyAtDQprIj5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCj09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KZSAtDQogICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3Qg QWRtaW4uDQp0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24N Cj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQoNCi0tDQpUb20g U2FyZ2VudA0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAgICAtIFRoZSBSVi1MaXN0IEVt YWlsIEZvcnVtIC0NCg0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdh dG9yIHRvIGJyb3dzZQ0KDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0 IFVuL1N1YnNjcmlwdGlvbiwNCg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5 IEJyb3dzZSwgQ2hhdCwgRkFRLA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3Jl Og0KDQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ UlYtTGlzdA0KDQpfLT0NCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1Mg V0VCIEZPUlVNUyAtDQoNCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlh IHRoZSBXZWIgRm9ydW1zIQ0KDQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbQ0KDQpfLT0NCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmli dXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBw b3J0IQ0KDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Subject: Re: RV8-List: Re: Van's SBs
Date: Feb 25, 2014
Any idea how many planes with cracks have been found to date? grumpy On Feb 24, 2014, at 9:16 PM, Matt Dralle wrote: > --> RV8-List message posted by: Matt Dralle > > > Just inspected my circa 1994 RV-6 for both the stab spar and elevator spar cracks per the respective SB's and found nothing questionable. Whew. > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode > > > > > ________________________________________________________________________________
Date: Feb 25, 2014
But that's probably a pretty high percentage of "cracks found" because its more likely that someone finding a crack would report it to Van's than someone not finding a crack. 10% seems crazy high especially considering that it took this long to "discover". Seems like everyone should report their findings to Van's good or bad so that their stats are realistic. Just send them to "support@vansaircraft". Included my N number and Serial number. Matt Dralle At 06:43 PM 2/25/2014 Tuesday, Alan Searle wrote: >--> RV8-List message posted by: Alan Searle > >Roughly 10% of those reporting their inspection. > >AKS > > >On 26/02/2014, at 12:33 PM, Miller John wrote: > >> --> RV8-List message posted by: Miller John >> >> Any idea how many planes with cracks have been found to date? >> >> grumpy >> >> On Feb 24, 2014, at 9:16 PM, Matt Dralle wrote: >> >>> --> RV8-List message posted by: Matt Dralle >>> >>> >>> Just inspected my circa 1994 RV-6 for both the stab spar and elevator spar cracks per the respective SB's and found nothing questionable. Whew. >>> >>> >>> - >>> Matt Dralle >>> Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Feb 26, 2014
According to those on the RV-List, none. I would like Van's to publish bet ter info on this issue and report under what conditions these problems seem to manifest themselves. -GV -----Original Message----- From: Miller John <gengrumpy(at)aol.com> Sent: Tue, Feb 25, 2014 5:34 pm Subject: RV-List: Re: RV8-List: Re: Van's SBs Any idea how many planes with cracks have been found to date? grumpy On Feb 24, 2014, at 9:16 PM, Matt Dralle wrote: > --> RV8-List message posted by: Matt Dralle > > > Just inspected my circa 1994 RV-6 for both the stab spar and elevator spa r cracks per the respective SB's and found nothing questionable. Whew. > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode > > > > > ________________________________________________________________________________
Date: Feb 26, 2014
According to VAF, not a few :( > On Feb 26, 2014, at 12:19 AM, vanremog(at)aol.com wrote: > > According to those on the RV-List, none. I would like Van's to publish be tter info on this issue and report under what conditions these problems seem to manifest themselves. > > -GV > -----Original Message----- > From: Miller John <gengrumpy(at)aol.com> > To: rv8-list > Sent: Tue, Feb 25, 2014 5:34 pm > Subject: RV-List: Re: RV8-List: Re: Van's SBs > > > Any idea how many planes with cracks have been found to date? > > grumpy > > On Feb 24, 2014, at 9:16 PM, Matt Dralle wrote: > > > --> RV8-List message posted by: Matt Dralle > > > > > > Just inspected my circa 1994 RV-6 for both the stab spar and elevator sp ar > cracks per the respective SB's and found nothing questionable. Whew. > > > > > > - > > Matt Dralle > > > > RV-8 #82880 N998RV "Ruby Vixen" > > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > > > RV-6 #20916 N360EM "The Flyer" > > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > > Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode > > > > > > > > > > > > > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 18, 2014
Subject: Re: Vertical Power move to Everett, WA and Oshkosh, WI
At 01:24 PM 3/18/2014 Tuesday, you wrote: >--> Avionics-List message posted by: "c1jensen" > >Hi folks, > >Just wanted to put a post out there to be sure the news is on Matronics that the Vertical Power product line was purchased by Astronics Ballard Technology in Everett, WA, and I am the new customer support rep, based in Oshkosh, WI. Marc Ausman is working with me during the transition to get me up to speed on support issues and if you need anything, please don't hesitate to contact me at 425-328-1658 or 920-216-3699. Email is support(at)verticalpower.com > >-------- >Chad Jensen >Vertical Power Support >RV-7, built, flown, sold Great to see you on the List, Chad. I have a VP-200 in my RV-8 and another one in my RV-6. Absolutely love them. I can't imagine flying without the electrical automation features of the VP-200 specifically. Will Astronics be working on a new version of the VP-200 with those automation features? Marc had said that they were going to add them to the VP-300/400 models, but I understand that Astronics won't be carrying those models. For me, the real utility and strength in the Vertical Power products is/was the automation. If I were in the market for a new experimental electrical system, I'm not sure I'd be all that interesting in the VP-x, but I'd buy another VP-200 in a heartbeat. Please keep us up to date on Astronics' current and future product updates. Big Fan of Vertical Power Products, - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: How to determine drill bit sharpness?
Date: Mar 20, 2014
Working on drilling longerons. Any general guidelines for determining when a #40 has lost its edge? 10, 50, 100. 300 holes? -------- RV-10. Built and sold RV-8a. Building Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420665#420665 ________________________________________________________________________________
Subject: Re: How to determine drill bit sharpness?
Date: Mar 20, 2014
Hi Tom, I think you should be able to get a few hundred pretty easily. When in doubt, try a new bit to see how it compares. When it starts taking significantly longer to drill a hole, change it out. Hal Benjamin RV-4 Flying Sent from my iPad > On Mar 20, 2014, at 8:19 AM, "tomhanaway" wrote: > > > Working on drilling longerons. Any general guidelines for determining when a #40 has lost its edge? > 10, 50, 100. 300 holes? > > -------- > RV-10. Built and sold > RV-8a. Building > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420665#420665 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 20, 2014
On Thu, 20 Mar 2014, tomhanaway wrote: > > Working on drilling longerons. Any general guidelines for determining when a #40 has lost its edge? > 10, 50, 100. 300 holes? Go by how it drills. If you are getting long spirals of aluminum it is sharp. If you are getting small chips it is dull. Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 baffling. ________________________________________________________________________________
Date: Mar 21, 2014
At 05:24 PM 3/20/2014 Thursday, you wrote: >--> Avionics-List message posted by: Ralph Finch > >Why did I want the -200? For the same reasons Matt cited. I just >don't see the benefit of merely replacing some circuit breakers that >is essentially the role of the VP-X. I think the biggest downfall of the VP-200 was that potential customers didn't really understand just how *awesome* the automation functionality is and how it really works. Many times at fly-ins or other events where I've had an opportunity to show off the VP-200, fellow homebuilders are in awe of the automation after I've take a few minutes to explain just how it works and how it significantly reduces my workload during the various phases of flight. The fact that the VP-200 knows, based on GPS/RPM/AHRS data exactly what mode of flight that I'm in - Start/Taxi/Runup/Takeoff/Cruse/Landing - and switches on or off the electrical circuits that I've pre-programmed for each mode of flight is simply genius. Not only is the concept certainly revolutionary in the market, but the VP-200's implementation of it just works and works great. The only external input that is missing to the logic, IMHO, is the determination of Day vs. Night. I have to manually turn the position lights on. It seems like either the input from the exiting dimmer electric eye or from some sort of real time clock could make this happen. Ralph's idea of adding automation to the VP-x though the use of an external embedded processor and display is a good one. Maybe when I get the RV-8 back in the air, I'll start working on something along those lines... :-) Best regards, - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
From: "Fisher Paul A." <FisherPaulA(at)JohnDeere.com>
Date: Mar 21, 2014
Not to be argumentative, but I still don't get it. I'm all for reducing workload in critical phases of flight, but I've only got three circuit switches that I use in that situation - flaps, fuel pump, and landing light wigwag. Everything else is on at start up and off at shutdown, both of which are low stress, low workload phases. I'm not turning over control of flaps, so that really just leaves two circuits that I would want to control using this type of device. Doesn't seem like much of a workload reduction. Maybe I just don't have enough toys in my plane. I agree it is cool technology, and I believe you that it works. I just don't see the benefit to offset the cost. ...although arguably that could also apply to my entire airplane! ;-) Paul A. Fisher RV7A N18PF -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, March 21, 2014 10:57 AM Subject: RV-List: Re: Vertical Power move to Everett, WA and Oshkosh, WI At 05:24 PM 3/20/2014 Thursday, you wrote: >--> Avionics-List message posted by: Ralph Finch >--> > >Why did I want the -200? For the same reasons Matt cited. I just don't >see the benefit of merely replacing some circuit breakers that is >essentially the role of the VP-X. I think the biggest downfall of the VP-200 was that potential customers didn't really understand just how *awesome* the automation functionality is and how it really works. Many times at fly-ins or other events where I've had an opportunity to show off the VP-200, fellow homebuilders are in awe of the automation after I've take a few minutes to explain just how it works and how it significantly reduces my workload during the various phases of flight. The fact that the VP-200 knows, based on GPS/RPM/AHRS data exactly what mode of flight that I'm in - Start/Taxi/Runup/Takeoff/Cruse/Landing - and switches on or off the electrical circuits that I've pre-programmed for each mode of flight is simply genius. Not only is the concept certainly revolutionary in the market, but the VP-200's implementation of it just works and works great. The only external input that is missing to the logic, IMHO, is the determination of Day vs. Night. I have to manually turn the position lights o! n. It seems like either the input from the exiting dimmer electric eye or from some sort of real time clock could make this happen. Ralph's idea of adding automation to the VP-x though the use of an external embedded processor and display is a good one. Maybe when I get the RV-8 back in the air, I'll start working on something along those lines... :-) Best regards, - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Mar 21, 2014
Subject: Re: RV8-List: Re: Vertical Power move to Everett, WA and Oshkosh,
WI Based on GPS information (position and time), you can know whether you are in Day or night, no problem, without having to resort to external devices such as a light sensor (which can break). I would think that sort of thing would be quite easy. Shaun On Fri, Mar 21, 2014 at 8:56 AM, Matt Dralle wrote: > --> RV8-List message posted by: Matt Dralle > > At 05:24 PM 3/20/2014 Thursday, you wrote: > >--> Avionics-List message posted by: Ralph Finch < > ralphmariafinch(at)gmail.com> > > > >Why did I want the -200? For the same reasons Matt cited. I just > >don't see the benefit of merely replacing some circuit breakers that > >is essentially the role of the VP-X. > > > I think the biggest downfall of the VP-200 was that potential customers > didn't really understand just how *awesome* the automation functionality is > and how it really works. Many times at fly-ins or other events where I've > had an opportunity to show off the VP-200, fellow homebuilders are in awe > of the automation after I've take a few minutes to explain just how it > works and how it significantly reduces my workload during the various > phases of flight. The fact that the VP-200 knows, based on GPS/RPM/AHRS > data exactly what mode of flight that I'm in - > Start/Taxi/Runup/Takeoff/Cruse/Landing - and switches on or off the > electrical circuits that I've pre-programmed for each mode of flight is > simply genius. Not only is the concept certainly revolutionary in the > market, but the VP-200's implementation of it just works and works great. > The only external input that is missing to the logic, IMHO, is the > determination of Day vs. Night. I have to manually turn the position > lights o! > n. It seems like either the input from the exiting dimmer electric eye > or from some sort of real time clock could make this happen. > > Ralph's idea of adding automation to the VP-x though the use of an > external embedded processor and display is a good one. Maybe when I get > the RV-8 back in the air, I'll start working on something along those > lines... :-) > > Best regards, > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer > Mode > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > ________________________________________________________________________________
Date: Mar 21, 2014
The same could be said for autopilots, GPS navigation, and so on. Not needed, but a convenience. Furthermore the VP-200 can be set up to easily provide a separate bus for main alternator or battery failure, automatically shedding unimportant load and switching on your alternate battery and/or alternator, so that's a safety feature. No VP-*** product actually moves flaps, to my knowledge, but they will prevent movement I think if you are over the maximum flap speed. On Fri, Mar 21, 2014 at 9:41 AM, Fisher Paul A. wrote: > > Not to be argumentative, but I still don't get it. I'm all for reducing workload in critical phases of flight, but I've only got three circuit switches that I use in that situation - flaps, fuel pump, and landing light wigwag. Everything else is on at start up and off at shutdown, both of which are low stress, low workload phases. I'm not turning over control of flaps, so that really just leaves two circuits that I would want to control using this type of device. Doesn't seem like much of a workload reduction. ________________________________________________________________________________
Date: Mar 21, 2014
Oshkosh, WI I traded some emails with Marc about the day/night thing a year or two ago. The way the VP-200 is now, I think we concluded your best bet is to repurpose the VMC/IMC switch to this use. But yeah, a new feature for this would be great. RF On Fri, Mar 21, 2014 at 10:10 AM, Shaun Dawson wrote: > Based on GPS information (position and time), you can know whether you are > in Day or night, no problem, without having to resort to external devices > such as a light sensor (which can break). I would think that sort of thing > would be quite easy. ________________________________________________________________________________
Date: Mar 21, 2014
The other responders have it right - if you don't think it's cutting through fast enough, it's probably dull... try a new one. For those of you (like me), always looking for an excuse to buy another tool, you might invest $50 on a Drill Doctor bit sharpener. Mine works great and it saves trips to the DIY store aviation aisle. Just follow the instructions that come with it closely and practice with a few old broken bits if you have any. The cam action puts a beautiful, sharp edge on the bit, perfectly beveled. I give it four and a half stars, and looks swell on the tool shelf. http://www.drilldoctor.com/drill-sharpeners-and-accessories/drill-sharpeners/drill-doctor-model-350x.html Ken Brooks Really Slow RV-8 QB Pushing to the end! ________________________________________________________________________________
Date: Mar 21, 2014
I have a Drill Doctor DD500X and agree w/ Ken - it is very handy.- It is really great for bits greater than about 3/16 in. (and those are the more e xpensive bits so being able to re-sharpen them is great).- But I don't ha ve much luck w/ drills smaller than 3/16 in.=0A=0AWhen it comes to #30 or # 40 drill bits, I buy them in the jobber 5-pack from my local industrial sup ply.- IIRC it's usually around $1 per bit.- Nothing beats the factory e dge on an industrial-quality drill bit.=0A=0A-Jeff=0A=0APS - I recommend th e DD500X even thought it's more expensive (you can find them on sale for ar ound $100).- It has a jig that makes it quick & easy to position the bit to be sharpened in the sharpening mandrel.- It only takes a couple of sec onds to get the bit chucked-up in the mandrel correctly.- I don't think t he lower models have this feature.- It's worth the extra 50 bucks.=0A=0A =0A=0A________________________________=0A From: Ken Brooks <kenbrooks@chart er.net>=0ATo: rv-list(at)matronics.com =0ASent: Friday, March 21, 2014 2:22 PM =0ASubject: RV-List: Re: How to determine drill bit sharpness?=0A =0A=0A--> RV-List message posted by: Ken Brooks =0A=0AThe oth er responders have it right - if you don't think it's cutting through fast enough, it's probably dull... try a new one.- For those of you (like me), always looking for an excuse to buy another tool, you might invest $50 on a Drill Doctor bit sharpener.- Mine works great and it saves trips to the DIY store aviation aisle.- Just follow the instructions that come with i t closely and practice with a few old broken bits if you have any.- The c am action puts a beautiful, sharp edge on the bit, perfectly beveled.- I give it four and a half stars, and looks swell on the tool shelf.=0Ahttp:// www.drilldoctor.com/drill-sharpeners-and-accessories/drill-sharpeners/drill -doctor-model-350x.html=0A=0AKen Brooks=0AReally Slow RV-8 QB=0APushing to =============== ________________________________________________________________________________
Date: Mar 22, 2014
I do not consider an AP a convenience. I'm more and more convinced that one should be in every plane. Safety. > On Mar 21, 2014, at 10:33 AM, Ralph Finch wrote: > > > The same could be said for autopilots, GPS navigation, and so on. Not > needed, but a convenience. Furthermore the VP-200 can be set up to > easily provide a separate bus for main alternator or battery failure, > automatically shedding unimportant load and switching on your > alternate battery and/or alternator, so that's a safety feature. > > No VP-*** product actually moves flaps, to my knowledge, but they will > prevent movement I think if you are over the maximum flap speed. > > On Fri, Mar 21, 2014 at 9:41 AM, Fisher Paul A. > wrote: >> >> Not to be argumentative, but I still don't get it. I'm all for reducing workload in critical phases of flight, but I've only got three circuit switches that I use in that situation - flaps, fuel pump, and landing light wigwag. Everything else is on at start up and off at shutdown, both of which are low stress, low workload phases. I'm not turning over control of flaps, so that really just leaves two circuits that I would want to control using this type of device. Doesn't seem like much of a workload reduction. > > > > > ________________________________________________________________________________
From: "=?utf-8?B?Qm9iIENvbGxpbnM=?=" <bcollinsrv7a(at)comcast.net>
Subject: =?utf-8?B?UmU6IFJWLUxpc3Q6IFJlOiBWZXJ0aWNhbCBQb3dlciBtb3ZlIHRvIEV2ZXJldHQs?=
=?utf-8?B?IFdBIGFuZCBPc2hrb3NoLCBXSQ==?
Date: Mar 22, 2014
SSB1c2UgYSBWUC01MCBhbmQgbG92ZSBpdC4gRWFzeSB0byB3aXJlIGFuZCBiZWluZyBhYmxlIHRv IGNoYW5nZSBzd2l0Y2hlcyBncm91cGluZyBpcyBhIG5pY2UgdG91Y2guIEFkZGVkIHdpZyB3YWcg b24gdGhlIGxpZ2h0cyBieSBqdXN0IGEgc29mdHdhcmUgdXBkYXRlLgoKSXQgbW9uaXRvcnMgbXkg ZWxlY3RyaWNhbCBzeXN0ZW0uIElmIHRoZXJlJ3MgYSBwcm9ibGVtLCBhIGxpZ2h0IGZsYXNoZXMg YW5kIHRoZSBkaXNwbGF5IHRlbGxzIG1lIGV4YWN0bHkgd2hhdCB0aGUgcHJvYmxlbSBhbmQgY2ly Y3VpdCBpcy4gCgpJIHNhdmVkIHJlYWwgZXN0YXRlIG9uIG15IHBhbmVsICB0b28uCgpJIHdhcyBz b3JyeSB0byBzZWUgVlAtNTAuZGlzY29udGludWVkIGluIGZhdm9yIG9mIHByb2R1Y3RzIHRoYXQg ZG9uJ3Qgc3RyaWtlIG1lIGFzIHRoYXQgaGVscGZ1bC4gSSBhbHNvIGRvbid0IGxpa2Ugb3duaW5n IG9ycGhhbmVkIHByb2R1Y3RzIGJ1dCBJIGtuZXcgd2hlbiBJIGJvdWdodCBpdCB0aGF0IE1hcmMg c3RhcnRzIGNvbXBhbmllcyBhbmQgc2VsbHMgdGhlbS4KCkhlY2ssIHdpdGggdGhlIG5lZWQgdG8g aW5zdGFsbCBBRFMtQi5pbiBhIGZldyBoZWFycywgSSBmaWd1cmUgSSdtIGdvbm5hIGhhdmUgdG8g cmlwIGV2ZXJ5dGhpbmcgb3V0IGFuZCBzdGFydCBvdmVyIGFueXdheS4KClNlbnQgZnJvbSBteSBW ZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lCgotLS0tLSBSZXBseSBtZXNzYWdlIC0t LS0tCkZyb206ICJKb2huIEplc3NlbiIgPG4yMTJwakBnbWFpbC5jb20+ClRvOiAicnYtbGlzdEBt YXRyb25pY3MuY29tIiA8cnYtbGlzdEBtYXRyb25pY3MuY29tPgpTdWJqZWN0OiBSVi1MaXN0OiBS ZTogVmVydGljYWwgUG93ZXIgbW92ZSB0byBFdmVyZXR0LCBXQSBhbmQgT3Noa29zaCwgV0kKRGF0 ZTogU2F0LCBNYXIgMjIsIDIwMTQgNDoxMiBQTQoKLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQg Ynk6IEpvaG4gSmVzc2VuIDxuMjEycGpAZ21haWwuY29tPgoKSSBkbyBub3QgY29uc2lkZXIgYW4g QVAgYSBjb252ZW5pZW5jZS4gIEknbSBtb3JlIGFuZCBtb3JlIGNvbnZpbmNlZCB0aGF0IG9uZSBz aG91bGQgYmUgaW4gZXZlcnkgcGxhbmUuICBTYWZldHkuICAKCj4gT24gTWFyIDIxLCAyMDE0LCBh dCAxMDozMyBBTSwgUmFscGggRmluY2ggPHJhbHBobWFyaWFmaW5jaEBnbWFpbC5jb20+IHdyb3Rl Ogo+IAo+IC0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBSYWxwaCBGaW5jaCA8cmFscGht YXJpYWZpbmNoQGdtYWlsLmNvbT4KPiAKPiBUaGUgc2FtZSBjb3VsZCBiZSBzYWlkIGZvciBhdXRv cGlsb3RzLCBHUFMgbmF2aWdhdGlvbiwgYW5kIHNvIG9uLiBOb3QKPiBuZWVkZWQsIGJ1dCBhIGNv bnZlbmllbmNlLiBGdXJ0aGVybW9yZSB0aGUgVlAtMjAwIGNhbiBiZSBzZXQgdXAgdG8KPiBlYXNp bHkgcHJvdmlkZSBhIHNlcGFyYXRlIGJ1cyBmb3IgbWFpbiBhbHRlcm5hdG9yIG9yIGJhdHRlcnkg ZmFpbHVyZSwKPiBhdXRvbWF0aWNhbGx5IHNoZWRkaW5nIHVuaW1wb3J0YW50IGxvYWQgYW5kIHN3 aXRjaGluZyBvbiB5b3VyCj4gYWx0ZXJuYXRlIGJhdHRlcnkgYW5kL29yIGFsdGVybmF0b3IsIHNv IHRoYXQncyBhIHNhZmV0eSBmZWF0dXJlLgo+IAo+IE5vIFZQLSoqKiBwcm9kdWN0IGFjdHVhbGx5 IG1vdmVzIGZsYXBzLCB0byBteSBrbm93bGVkZ2UsIGJ1dCB0aGV5IHdpbGwKPiBwcmV2ZW50IG1v dmVtZW50IEkgdGhpbmsgaWYgeW91IGFyZSBvdmVyIHRoZSBtYXhpbXVtIGZsYXAgc3BlZWQuCj4g Cj4gT24gRnJpLCBNYXIgMjEsIDIwMTQgYXQgOTo0MSBBTSwgRmlzaGVyIFBhdWwgQS4KPiA8Rmlz aGVyUGF1bEFAam9obmRlZXJlLmNvbT4gd3JvdGU6Cj4+IC0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9z dGVkIGJ5OiAiRmlzaGVyIFBhdWwgQS4iIDxGaXNoZXJQYXVsQUBqb2huZGVlcmUuY29tPgo+PiAK Pj4gTm90IHRvIGJlIGFyZ3VtZW50YXRpdmUsIGJ1dCBJIHN0aWxsIGRvbid0IGdldCBpdC4gIEkn bSBhbGwgZm9yIHJlZHVjaW5nIHdvcmtsb2FkIGluIGNyaXRpY2FsIHBoYXNlcyBvZiBmbGlnaHQs IGJ1dCBJJ3ZlIG9ubHkgZ290IHRocmVlIGNpcmN1aXQgc3dpdGNoZXMgdGhhdCBJIHVzZSBpbiB0 aGF0IHNpdHVhdGlvbiAtIGZsYXBzLCBmdWVsIHB1bXAsIGFuZCBsYW5kaW5nIGxpZ2h0IHdpZ3dh Zy4gIEV2ZXJ5dGhpbmcgZWxzZSBpcyBvbiBhdCBzdGFydCB1cCBhbmQgb2ZmIGF0IHNodXRkb3du LCBib3RoIG9mIHdoaWNoIGFyZSBsb3cgc3RyZXNzLCBsb3cgd29ya2xvYWQgcGhhc2VzLiAgSSdt IG5vdCB0dXJuaW5nIG92ZXIgY29udHJvbCBvZiBmbGFwcywgc28gdGhhdCByZWFsbHkganVzdCBs ZWF2ZXMgdHdvIGNpcmN1aXRzIHRoYXQgSSB3b3VsZCB3YW50IHRvIGNvbnRyb2wgdXNpbmcgdGhp cyB0eXBlIG9mIGRldmljZS4gIERvZXNuJ3Qgc2VlbSBsaWtlIG11Y2ggb2YgYSB3b3JrbG9hZCBy ZWR1Y3Rpb24uCj4gCj4gCj4gCj4gCj4gCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIFJWLUxp c3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZp Z2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3Qg VW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJv d3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpf LT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVi1MaXN0Cl8tPQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUg Z3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0g ICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAg ICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3Vy IGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0 IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0 ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Re: Oil Coolers...
I finally got some pictures of my setrab oil cooler install: https://drive.google.com/folderview?id=0BxGKHfbAGXHxcVNxTTZneTJQNFU&usp=sharing It is this model: http://www.lpiracing.com/Setrab-Oil-Cooler-Series-1-10-row-M22-Ports-1071p25418.htm with a 45 and 90 swivel adapter to AN: http://www.setrabusa.com/images/fittings/Formatted/AN/22-M22AN08-45.JPG http://www.setrabusa.com/images/fittings/Formatted/AN/22-M22AN06-90.JPG It may be that Setrab isn't selling that model any longer, I couldn't find it on their web page but there appears to an equivalent, 50-107-7612: http://www.setrabusa.com/products/oilcoolers/powersteering/index.html Power steering cooler... not sure what the difference is between that and an engine cooler. I've got about 900 hrs on this set up, I went this route because I was getting too much cooling from the standard cooler and the standard cooler weight caused cracking on the baffles. I also had a DER friend running one successfully for several hundred hours. I beefed up the baffles also. Even now I'm running the cooler with about 1/2 covered with AL tape, so you could probably go smaller if there was a smaller one. Bottom line is that Aluminum is a superior material for an oil cooler, brass which I believe is what the stock cooler is made of. This is on a parallel valve IO-360, angle valve may be different. I know Gary mentioned of one failure of these, I have no idea why that one failed. I've had good luck, in fact I just ticked over to 4 digits on the hobbs: 1000 hrs as of last weekend. Bill Judge RV-8.blogspot.com N84WJ, RV-8, 1000 hrs On Fri, Feb 21, 2014 at 8:09 AM, Bill Judge wrote: > Hey Marty, good to see you're doing well. > > Larry, I'll have to dig around for pictures of the install. It wasn't too > different than the stock, on the baffle install. I did beef up the baffles > in that corner at the same time as going to the smaller cooler. No cracking > since I made this change. > > The gist of the install was to use 4 pieces of 1x2 inch profile angle, > each about an inch long. I think the thickness was 0.125. > > use those on each corner of the cooler to grab the coolers mounting holes. > shorter side of the angle on the engine baffles, longer side on the cooler. > > In an effort to isolate the cooler from vibration I over sized the holes > and put in rubber bushings so that the cooler didn't touch anything but the > bolts and rubber bushings and then I sealed the perimeter with RTV. The RTV > is probably what is actually holding the cooler in place. > > Below my sentence got cut off, I meant to say I didn't do the firewall > mount because I didn't like the idea of the hoses "working" as the engine > vibrated. > > Bill > > >> >> From: Marty Helller <marty_away(at)hotmail.com> >> Subject: RE: RV-List: Re: Oil Cooler's... >> >> I have one with ~ 4 hours on it. Will sell for an hours worth of fuel >> plus >> shipping. Had unrelated cooling issues on first few flights=2C but >> ever >> yone pointed to the non- standard configuration (on firewall) so I changed >> to SW clone on baffling and still hard other problems to resolve.... Now >> l >> ife is cool at 175 oil temp and < 330 CHT. >> >> Contact off line at 703-732-3264 >> >> Marty >> RV-7=2C 150 hrs=2C KSUT >> >> From: bjudge(at)gmail.com >> Subject: RV-List: Re: Oil Cooler's... >> >> I just dug back through my emails to find the skinny on the Setrab cooler. >> I'm pretty sure it is this one: >> >> >> >> http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-ta >> ll-m22-ports.html<http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-tall-m22-ports.html> >> >> >> It comes with straight on AN fittings but I couldn't get them to work >> >> in the space I had so I used these: >> http://www.hrpworld.com/store/default/an >> -10-x-m22-hose-fitting-90.html<http://www.hrpworld.com/store/default/an-10-x-m22-hose-fitting-90.html> >> >> These fitting are mega expensive but swivel which takes alot of the >> >> stress off the attach points. I went this route for a few reasons: >> >> I had the stock cooler completely covered with AL tape and stillcouldn't >> ge >> t over 200 F temps.(Too much cooling) >> >> My baffles cracked from the weight of the stock cooler.(too much weight)I >> k >> new of a rv-6 built by 3 engineers(one is a DER) and they've flown >> >> 400 hrs trouble free with this cooler.I didn't do the firewall mount >> becaus >> e i didn't want the hoses working with engine movement relative to the >> firewall. >> >> Even still when its cold I can't get over 160 F. >> >> Bill >> >> >> On Thu=2C Feb 20=2C 2014 at 7:29 AM=2C Bill Judge >> wrote: >> >> >> I've been running a Setrab 10 row for around 750 hrs=2C no problems=2C >> temp >> s often run too low and so its half covered with AL tape. It's about 1/3 >> th >> e size of the standard Vans cooler. >> >> >> They are made of aluminum rather than brass and AL just works better for a >> heat exchanger. >> >> You can get aircraft fittings on them too=2C they even have swivel >> fittings >> at 90 and 45 degrees available. >> >> >> Bill >> N84WJ=2C RV-8=2C 980 hrs >> >> >> rv-8.blogspot.com >> >> >> >> From: Matt Dralle <dralle(at)matronics.com> >> >> Subject: RV-List: Oil Cooler's... >> >> >> Greetings RV'ers=2C >> >> >> On the RV-8=2C I've got Stewart/Warner 10610R 10 row oil cooler for the >> IO- >> 390. >> >> It's mounted on the rear baffle and its worked well and kept the oil temps >> in >> >> the low 180's under all conditions. >> >> >> I noticed today=2C that the outside mounting flange that goes next to the >> b >> affle >> >> is cracked. I suppose I could get it welded or brazed or whatever they do >> to >> >> aluminium=2C but that seems like a hack. >> >> >> Apparently=2C Chief doesn't carry the Stewart/Warner brand anymore and has >> to different >> >> variants of the Aero Classic brand in the 10 Row 10610R compatible unit. >> >> >> One is the "Standard" model for $269: >> >> >> >> http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler >> s/standard/aec-8000081.html<http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-coolers/standard/aec-8000081.html> >> >> >> The other is the "HE" (High Efficiency) models are $575: >> >> >> >> http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler >> s/he-series/aec-8001646.html<http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-coolers/he-series/aec-8001646.html> >> >> >> Any thought's on either of these two options? Pros and cons. The HE >> model >> s look >> >> a lot like the S&W model I have=2C assuming the pictures are accurate. >> >> >> Thanks for the feedback. >> >> >> Matt >> >> >> - >> >> Matt Dralle >> >> >> RV-8 #82880 N998RV "Ruby Vixen" >> >> http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log >> >> http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log >> >> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >> >> Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... >> >> >> RV-6 #20916 N360EM "The Flyer" >> >> http://www.mattsrv6.com - Matt's RV-6 Revitalization Log >> >> Status: 200+ Hours Since Purchase - Upgrades Complete=3B Now In Full Flyer >> Mode >> >> >> Matt's Livermore Airport Live ATC Stream! >> >> Check out the live ATC stream directly from my hangar at the Livermore >> >> Airport. Includes both Tower and Ground transmissions. Archives too! >> >> For entertainment purposes only. http://klvk.matronics.com >> >> ________________________________________________________________________________
Date: Mar 27, 2014
Nice. Looks like a good option. I'm surprised we don't see this used more often. On Thursday, March 27, 2014, Bill Judge wrote: > I finally got some pictures of my setrab oil cooler install: > > https://drive.google.com/folderview?id=0BxGKHfbAGXHxcVNxTTZneTJQNFU&usp=sharing > > It is this model: > > http://www.lpiracing.com/Setrab-Oil-Cooler-Series-1-10-row-M22-Ports-1071p25418.htm > > with a 45 and 90 swivel adapter to AN: > http://www.setrabusa.com/images/fittings/Formatted/AN/22-M22AN08-45.JPG > http://www.setrabusa.com/images/fittings/Formatted/AN/22-M22AN06-90.JPG > > It may be that Setrab isn't selling that model any longer, I couldn't find > it on their web page but there appears to an equivalent, 50-107-7612: > http://www.setrabusa.com/products/oilcoolers/powersteering/index.html > > Power steering cooler... not sure what the difference is between that and > an engine cooler. > > I've got about 900 hrs on this set up, I went this route because I was > getting too much cooling from the standard cooler and the standard cooler > weight caused cracking on the baffles. I also had a DER friend running one > successfully for several hundred hours. > > I beefed up the baffles also. > > Even now I'm running the cooler with about 1/2 covered with AL tape, so > you could probably go smaller if there was a smaller one. > > Bottom line is that Aluminum is a superior material for an oil cooler, > brass which I believe is what the stock cooler is made of. > > This is on a parallel valve IO-360, angle valve may be different. > > I know Gary mentioned of one failure of these, I have no idea why that one > failed. I've had good luck, in fact I just ticked over to 4 digits on the > hobbs: 1000 hrs as of last weekend. > > Bill Judge > RV-8.blogspot.com > N84WJ, RV-8, 1000 hrs > > > On Fri, Feb 21, 2014 at 8:09 AM, Bill Judge > > wrote: > >> Hey Marty, good to see you're doing well. >> >> Larry, I'll have to dig around for pictures of the install. It wasn't too >> different than the stock, on the baffle install. I did beef up the baffles >> in that corner at the same time as going to the smaller cooler. No cracking >> since I made this change. >> >> The gist of the install was to use 4 pieces of 1x2 inch profile angle, >> each about an inch long. I think the thickness was 0.125. >> >> use those on each corner of the cooler to grab the coolers mounting >> holes. shorter side of the angle on the engine baffles, longer side on the >> cooler. >> >> In an effort to isolate the cooler from vibration I over sized the holes >> and put in rubber bushings so that the cooler didn't touch anything but the >> bolts and rubber bushings and then I sealed the perimeter with RTV. The RTV >> is probably what is actually holding the cooler in place. >> >> Below my sentence got cut off, I meant to say I didn't do the firewall >> mount because I didn't like the idea of the hoses "working" as the engine >> vibrated. >> >> Bill >> >> >> >> >>> >>> From: Marty Helller <marty_away(at)hotmail.com<javascript:_e(%7B%7D,'cvml','marty_away(at)hotmail.com');> >>> > >>> Subject: RE: RV-List: Re: Oil Cooler's... >>> >>> I have one with ~ 4 hours on it. Will sell for an hours worth of fuel >>> plus >>> shipping. Had unrelated cooling issues on first few flights=2C but >>> ever >>> yone pointed to the non- standard configuration (on firewall) so I >>> changed >>> to SW clone on baffling and still hard other problems to resolve.... >>> Now l >>> ife is cool at 175 oil temp and < 330 CHT. >>> >>> Contact off line at 703-732-3264 >>> >>> Marty >>> RV-7=2C 150 hrs=2C KSUT >>> >>> From: bjudge(at)gmail.com<javascript:_e(%7B%7D,'cvml','bjudge(at)gmail.com');> >>> Subject: RV-List: Re: Oil Cooler's... >>> >>> I just dug back through my emails to find the skinny on the Setrab >>> cooler. >>> I'm pretty sure it is this one: >>> >>> >>> >>> http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-ta >>> ll-m22-ports.html<http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-tall-m22-ports.html> >>> >>> >>> It comes with straight on AN fittings but I couldn't get them to work >>> >>> in the space I had so I used these: >>> http://www.hrpworld.com/store/default/an >>> -10-x-m22-hose-fitting-90.html<http://www.hrpworld.com/store/default/an-10-x-m22-hose-fitting-90.html> >>> >>> These fitting are mega expensive but swivel which takes alot of the >>> >>> stress off the attach points. I went this route for a few reasons: >>> >>> I had the stock cooler completely covered with AL tape and stillcouldn't >>> ge >>> t over 200 F temps.(Too much cooling) >>> >>> My baffles cracked from the weight of the stock cooler.(too much >>> weight)I k >>> new of a rv-6 built by 3 engineers(one is a DER) and they've flown >>> >>> 400 hrs trouble free with this cooler.I didn't do the firewall mount >>> becaus >>> e i didn't want the hoses working with engine movement relative to the >>> firewall. >>> >>> Even still when its cold I can't get over 160 F. >>> >>> Bill >>> >>> >>> On Thu=2C Feb 20=2C 2014 at 7:29 AM=2C Bill Judge > >>> wrote: >>> >>> >>> I've been running a Setrab 10 row for around 750 hrs=2C no problems=2C >>> temp >>> s often run too low and so its half covered with AL tape. It's about 1/3 >>> th >>> e size of the standard Vans cooler. >>> >>> >>> They are made of aluminum rather than brass and AL just works better for >>> a >>> heat exchanger. >>> >>> You can get aircraft fittings on them too=2C they even have swivel >>> fittings >>> at 90 and 45 degrees available. >>> >>> >>> Bill >>> N84WJ=2C RV-8=2C 980 hrs >>> >>> >>> rv-8.blogspot.com >>> >>> >>> >>> From: Matt Dralle <dralle(at)matronics.com<javascript:_e(%7B%7D,'cvml','dralle(at)matronics.com');> >>> > >>> >>> Subject: RV-List: Oil Cooler's... >>> >>> >>> Greetings RV'ers=2C >>> >>> >>> On the RV-8=2C I've got Stewart/Warner 10610R 10 row oil cooler for the >>> IO- >>> 390. >>> >>> It's mounted on the rear baffle and its worked well and kept the oil >>> temps >>> in >>> >>> the low 180's under all conditions. >>> >>> >>> I noticed today=2C that the outside mounting flange that goes next to >>> the b >>> affle >>> >>> is cracked. I suppose I could get it welded or brazed or whatever they >>> do >>> to >>> >>> aluminium=2C but that seems like a hack. >>> >>> >>> Apparently=2C Chief doesn't carry the Stewart/Warner brand anymore and >>> has >>> to different >>> >>> variants of the Aero Classic brand in the 10 Row 10610R compatible unit. >>> >>> >>> One is the "Standard" model for $269: >>> >>> >>> >>> http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler >>> s/standard/aec-8000081.html<http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-coolers/standard/aec-8000081.html> >>> >>> >>> The other is the "HE" (High Efficiency) models are $575: >>> >>> >>> >>> http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler >>> s/he-series/aec-8001646.html<http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-coolers/he-series/aec-8001646.html> >>> >>> >>> Any thought's on either of these two options? Pros and cons. The HE >>> model >>> s look >>> >>> a lot like the S&W model I have=2C assuming the pictures are accurate. >>> >>> >>> Thanks for the feedback. >>> >>> >>> Matt >>> >>> >>> - >>> >>> Matt Dralle >>> >>> >>> RV-8 #82880 N998RV "Ruby Vixen" >>> >>> http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log >>> >>> http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log >>> >>> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >>> >>> Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... >>> >>> >>> RV-6 #20916 N360EM "The Flyer" >>> >>> http://www.mattsrv6.com - Matt's RV-6 Revitalization Log >>> >>> Status: 200+ Hours Since Purchase - Upgrades Complete=3B Now In Full >>> Flyer >>> Mode >>> >>> >>> Matt's Livermore Airport Live ATC Stream! >>> >>> Check out the live ATC stream directly from my hangar at the Livermore >>> >>> Airport. Includes both Tower and Ground transmissions. Archives too! >>> >>> For entertainment purposes only. http://klvk.matronics.com >>> >>> * > > > * > > -- -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Mar 27, 2014
Probably because most RVers are almost as conservative as spam can drivers when it comes to changing stuff in front of the firewall. :-) One more valid reason is that they are only 2" thick, and 4" is a better match for RV speeds. The thinner one *theoretically* will flow a lot more air, potentially meaning more cooling drag. If the thinner unit appeals to you, read on. For those who are interested in this type of cooler, they can be had for a lot less money and in many different sizes, if you can use fixed A/N fittings. This cooler: http://www.cxracing.com/mm5/merchant.mvc?Screen=PROD&Store_Code=CXR&Product_Code=OC-248-30-AN10&Category_Code=RDOC has been flying on a Mazda 3rotor (~280HP) on an RV-8 for several years. It's available from that vendor through their ebay store at: http://www.ebay.com/itm/160578859562?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 for $79.00. If you explore the CX Racing site, you'll find a 30 row, 28 row, 25 row, 19 row, etc. They are all usually available through the ebay store for less money than the price listed on the CX Racing site. This series is ~10" center to center on the fittings; ~13" overall. Height varies depending on the number of rows. They also sell some with smaller spacing between the fittings. If anyone's interested, I've got a 19 row that I won't be using on my rotary installation. On 3/27/2014 12:41 PM, Larry Bowen wrote: > Nice. Looks like a good option. I'm surprised we don't see this used > more often. > > > On Thursday, March 27, 2014, Bill Judge > wrote: > > I finally got some pictures of my setrab oil cooler install: > https://drive.google.com/folderview?id=0BxGKHfbAGXHxcVNxTTZneTJQNFU&usp=sharing > > It is this model: > http://www.lpiracing.com/Setrab-Oil-Cooler-Series-1-10-row-M22-Ports-1071p25418.htm > > with a 45 and 90 swivel adapter to AN: > http://www.setrabusa.com/images/fittings/Formatted/AN/22-M22AN08-45.JPG > http://www.setrabusa.com/images/fittings/Formatted/AN/22-M22AN06-90.JPG > > It may be that Setrab isn't selling that model any longer, I > couldn't find it on their web page but there appears to an > equivalent, 50-107-7612: > http://www.setrabusa.com/products/oilcoolers/powersteering/index.html > > Power steering cooler... not sure what the difference is between > that and an engine cooler. > > I've got about 900 hrs on this set up, I went this route because I > was getting too much cooling from the standard cooler and the > standard cooler weight caused cracking on the baffles. I also had > a DER friend running one successfully for several hundred hours. > > I beefed up the baffles also. > > Even now I'm running the cooler with about 1/2 covered with AL > tape, so you could probably go smaller if there was a smaller one. > > Bottom line is that Aluminum is a superior material for an oil > cooler, brass which I believe is what the stock cooler is made of. > > This is on a parallel valve IO-360, angle valve may be different. > > I know Gary mentioned of one failure of these, I have no idea why > that one failed. I've had good luck, in fact I just ticked over to > 4 digits on the hobbs: 1000 hrs as of last weekend. > > Bill Judge > RV-8.blogspot.com <http://RV-8.blogspot.com> > N84WJ, RV-8, 1000 hrs > > > On Fri, Feb 21, 2014 at 8:09 AM, Bill Judge > wrote: > > Hey Marty, good to see you're doing well. > > Larry, I'll have to dig around for pictures of the install. It > wasn't too different than the stock, on the baffle install. I > did beef up the baffles in that corner at the same time as > going to the smaller cooler. No cracking since I made this change. > > The gist of the install was to use 4 pieces of 1x2 inch > profile angle, each about an inch long. I think the thickness > was 0.125. > > use those on each corner of the cooler to grab the coolers > mounting holes. shorter side of the angle on the engine > baffles, longer side on the cooler. > > In an effort to isolate the cooler from vibration I over sized > the holes and put in rubber bushings so that the cooler didn't > touch anything but the bolts and rubber bushings and then I > sealed the perimeter with RTV. The RTV is probably what is > actually holding the cooler in place. > > Below my sentence got cut off, I meant to say I didn't do the > firewall mount because I didn't like the idea of the hoses > "working" as the engine vibrated. > > Bill > > > From: Marty Helller <marty_away(at)hotmail.com > > > Subject: RE: RV-List: Re: Oil Cooler's... > > I have one with ~ 4 hours on it. Will sell for an hours > worth of fuel plus > shipping. Had unrelated cooling issues on first few > flights=2C but ever > yone pointed to the non- standard configuration (on > firewall) so I changed > to SW clone on baffling and still hard other problems to > resolve.... Now l > ife is cool at 175 oil temp and < 330 CHT. > > Contact off line at 703-732-3264 > > Marty > RV-7=2C 150 hrs=2C KSUT > > From: bjudge(at)gmail.com > > Subject: RV-List: Re: Oil Cooler's... > > I just dug back through my emails to find the skinny on > the Setrab cooler. > I'm pretty sure it is this one: > > > http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-ta > ll-m22-ports.html > <http://www.hrpworld.com/store/default/100-series-std-10-row-oil-cooler-3-tall-m22-ports.html> > > > It comes with straight on AN fittings but I couldn't get > them to work > > in the space I had so I used > these:http://www.hrpworld.com/store/default/an > -10-x-m22-hose-fitting-90.html > <http://www.hrpworld.com/store/default/an-10-x-m22-hose-fitting-90.html> > > These fitting are mega expensive but swivel which takes > alot of the > > stress off the attach points. I went this route for a few > reasons: > > I had the stock cooler completely covered with AL tape and > stillcouldn't ge > t over 200 F temps.(Too much cooling) > > My baffles cracked from the weight of the stock > cooler.(too much weight)I k > new of a rv-6 built by 3 engineers(one is a DER) and > they've flown > > 400 hrs trouble free with this cooler.I didn't do the > firewall mount becaus > e i didn't want the hoses working with engine movement > relative to the firewall. > > Even still when its cold I can't get over 160 F. > > Bill > > > On Thu=2C Feb 20=2C 2014 at 7:29 AM=2C Bill Judge > > wrote: > > > I've been running a Setrab 10 row for around 750 hrs=2C no > problems=2C temp > s often run too low and so its half covered with AL tape. > It's about 1/3 th > e size of the standard Vans cooler. > > > They are made of aluminum rather than brass and AL just > works better for a > heat exchanger. > > You can get aircraft fittings on them too=2C they even > have swivel fittings > at 90 and 45 degrees available. > > > Bill > N84WJ=2C RV-8=2C 980 hrs > > > rv-8.blogspot.com <http://rv-8.blogspot.com> > > > > From: Matt Dralle <dralle(at)matronics.com > > > > Subject: RV-List: Oil Cooler's... > > > Greetings RV'ers=2C > > > On the RV-8=2C I've got Stewart/Warner 10610R 10 row oil > cooler for the IO- > 390. > > It's mounted on the rear baffle and its worked well and > kept the oil temps > in > > the low 180's under all conditions. > > > I noticed today=2C that the outside mounting flange that > goes next to the b > affle > > is cracked. I suppose I could get it welded or brazed or > whatever they do > to > > aluminium=2C but that seems like a hack. > > > Apparently=2C Chief doesn't carry the Stewart/Warner brand > anymore and has > to different > > variants of the Aero Classic brand in the 10 Row 10610R > compatible unit. > > > One is the "Standard" model for $269: > > > http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler > s/standard/aec-8000081.html > <http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-coolers/standard/aec-8000081.html> > > > The other is the "HE" (High Efficiency) models are $575: > > > http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-cooler > s/he-series/aec-8001646.html > <http://www.chiefaircraft.com/aircraft/oil-system-filters/oil-coolers/he-series/aec-8001646.html> > > > Any thought's on either of these two options? Pros and > cons. The HE model > s look > > a lot like the S&W model I have=2C assuming the pictures > are accurate. > > > Thanks for the feedback. > > > Matt > > > - > > Matt Dralle > > > RV-8 #82880 N998RV "Ruby Vixen" > > http://www.mattsrv8.com - Matt's Complete RV-8 > Construction Log > > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube > Channel > > Status: 172+ Hours TTSN - Rebuilding Fuselage After > Landing Mishap... > > > RV-6 #20916 N360EM "The Flyer" > > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > > Status: 200+ Hours Since Purchase - Upgrades Complete=3B > Now In Full Flyer > Mode > > > Matt's Livermore Airport Live ATC Stream! > > Check out the live ATC stream directly from my hangar at > the Livermore > > Airport. Includes both Tower and Ground transmissions. > Archives too! > > For entertainment purposes only. http://klvk.matronics.com > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > -- > -- > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > ________________________________________________________________________________
Date: Mar 27, 2014
Gary mentioned a failure in the past of the setrab oil cooler. That was me back in June 2000. There was a bunch of discussion then about it then. Would recommend searching that time frame in the archives. I'll copy my original post. Personally, I wouldn't recommend anyone to use one, but that's the great thing about homebuilts. You can do whatever YOU want. Laird (and yes, I shouldn't have over flown a perfectly good airport, but that's what I did as the oil temp and pressure were still in the green). >From June 2000 #67570 Date: Jun 02, 2000 From: "Owens, Laird" Subject: Setrab Oil Cooler Failure (long) Hi all, Yesterday on the 3rd flight of my RV-6, I had an interesting thing happen. I was out to break in my new 0-360 (and have a little fun) and out about 30nm from the departure airport, 5500', 2550 rpm just cruising along about ready to turn for a run back. I was going to do this back and forth thing for 2 hours to let the motor work a little. I have a 16 row Setrab oil cooler mounted behind the #4 cyl on the baffle. Setrab oil coolers had been recommended in the past as a low cost alternative to S/W's (see post from archives below). Oil temps have been consistent at 225 deg F (75 deg F ambient at 0 MSL). I was hoping that would come down a little once the engine broke in. Oil pressure had been stable at 90 psi. Just before I was going to turn, with about 3 hrs total on the tach, I noticed a little puddle of oil on the floorboard in front of the rudder peddles. That's weird.....I don't have any oil lines in under the dash.....OH @#$@! Oil must be leaking in the engine compartment and seeping thru the wire pass thru's. I looked up just in time to see oil starting to come out of the upper cowling at the fuse/cowl junction. Oil pressure had dropped 5 psi, but was stable, and temp was still 225. First, pull the power to 1800 and think. OK....decision time. I was just north of Valencia, about 15nm from Whiteman or Van Nuys, and about 17nm out of Santa Paula (gawd I love that GPS). Lots of houses between me Whiteman, and a river bed between me and Santa Paula.....let's see, if the engine fails, I can land on a house, or a river bed. That's a no brainer. And if I can make Santa Paula, Camarillo is just around the corner. Maybe I can make it all the way back to home base...... I keep the power low, watch the oil pressure and temp and head for Santa Paula decending at about 200 fpm to keep the speed up while the motors still running. I pass over Santa Paula at 2500' with good oil pressure so I decide to press on to Camarillo. Tower was helpful getting me on the ground quickly without having to declare the "E" word. I taxied back to the hangar and shut down. I climbed out to find oil dripping from the lower firewall to the tailwheel, on the side of the fuse and on the wing root and no oil on the dipstick. Guess it lost a little more oil than I thought, duh. What a mess in the "engine compartment formally know as clean". I pulled the cowl and cleaned up the airplane up (I'm sure the EPA would like to talk to me bout now....). The oil lines were tight, that only leaves the oil cooler. Pulled that and put an air nozzle to it. Sounds like a big hole up where the tubes get welded to the main plenum. Hello, Van's......Can I order a Positech oil cooler and have it delivered over night? Thank you. So much for trying to save a couple of bucks on the cooler. Just thought anyone out there with one of these might like to know about it. I hadn't seen any failure reports in the archives. Laird RV-6 (with a well lubed paint job) SoCal >From the Archives: From: Mlfred(at)aol.com Date: Aug 16, 1996 Subject: Re: Oil cooler location & low cost option Hi all: PLEASE don't think you need one of those expensive coolers on your bird! Rob Lee will tell you, and so will I. I use a small & inexpensive ($65) cooler (with male -8 AN fittings already installed) from TMR, Inc in Orange, Calif. (714) 771-1348. Talk to Mike and tell him I sent you ( he'll only charge you an extra 10%). The 19 row ($70 "Setrab" brand- malmo in Sweden) unit I use on my Rocket keeps the temps on the 540 to 185F in cruise, and I think I used a 13 row on the -4, and it was usually too much. Rob Lee has the exact part # for the 320/360 unit. How about posting it, along with installation tips, Rob? I mounted mine on the back baffle, on the left side. I used the expanding-slowing air/increasing pressure idea, and the inlet to the cooler is sort of a reverse funnel. Check six! Mark Frederick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421186#421186 ________________________________________________________________________________
Date: Mar 28, 2014
Subject: Oil Coolers
Yikes! Glad that hasn't happened to me! I've been blissfully running around for 900 or so hrs. I did a little looking around and it's been said that the SWs are tested to 180 PSI(off of VAF) and the Setrabs from what I can find are only tested to 145 PSI, max operating pressure is 174 PSI and design limit pressure is 536 PSI. http://www.setrab.com/products/proline/technical-specifications/std/ 1 Bar = 14.5 Psi. So 90 PSI shouldn't have been a problem but evidently it was. There is also some speculation that on startup Lyc Oil pressure surges very high, I could see this especially when it's cold. I'm in SoCal now but I was in DC for 4 years before that and started up on some 10 F mornings with no issues. I run about 72 PSI, 60 PSI would be better. Recommended range is 50-95 PSI according to the vantage engine manual which is pretty much the XP-360 that I have. Did it fail where the lines connect? Do you think there was any binding? I hadn't thought about the airflow difference. I've got 1/2 of it taped over anyway so it probably doesn't much matter. Bill > > > Subject: RV-List: Re: Oil Coolers... > From: "Laird" <owens.laird(at)gmail.com> > > > Gary mentioned a failure in the past of the setrab oil cooler. That was > me back > in June 2000. There was a bunch of discussion then about it then. Would > recommend > searching that time frame in the archives. I'll copy my original post. > > Personally, I wouldn't recommend anyone to use one, but that's the great > thing > about homebuilts. You can do whatever YOU want. > > Laird > (and yes, I shouldn't have over flown a perfectly good airport, but that's > what > I did as the oil temp and pressure were still in the green). > > >From June 2000 > > #67570 > Date: Jun 02, 2000 > From: "Owens, Laird" > Subject: Setrab Oil Cooler Failure (long) > > Hi all, > > Yesterday on the 3rd flight of my RV-6, I had an interesting thing happen. > I was > out to break in my new 0-360 (and have a little fun) and out about 30nm > from > the departure airport, 5500', 2550 rpm just cruising along about ready to > turn > for a run back. I was going to do this back and forth thing for 2 hours to > let the motor work a little. > > I have a 16 row Setrab oil cooler mounted behind the #4 cyl on the baffle. > Setrab > oil coolers had been recommended in the past as a low cost alternative to > S/W's (see post from archives below). Oil temps have been consistent at > 225 deg > F (75 deg F ambient at 0 MSL). I was hoping that would come down a little > once > the engine broke in. Oil pressure had been stable at 90 psi. > > Just before I was going to turn, with about 3 hrs total on the tach, I > noticed > a little puddle of oil on the floorboard in front of the rudder peddles. > That's > weird.....I don't have any oil lines in under the dash.....OH @#$@! Oil > must > be leaking in the engine compartment and seeping thru the wire pass thru's. > I looked up just in time to see oil starting to come out of the upper > cowling > at the fuse/cowl junction. Oil pressure had dropped 5 psi, but was stable, > and temp was still 225. First, pull the power to 1800 and think. > > OK....decision time. I was just north of Valencia, about 15nm from > Whiteman or > Van Nuys, and about 17nm out of Santa Paula (gawd I love that GPS). Lots > of > houses between me Whiteman, and a river bed between me and Santa > Paula.....let's > see, if the engine fails, I can land on a house, or a river bed. That's a > no brainer. And if I can make Santa Paula, Camarillo is just around the > corner. > Maybe I can make it all the way back to home base...... > > I keep the power low, watch the oil pressure and temp and head for Santa > Paula > decending at about 200 fpm to keep the speed up while the motors still > running. > > I pass over Santa Paula at 2500' with good oil pressure so I decide to > press on > to Camarillo. Tower was helpful getting me on the ground quickly without > having > to declare the "E" word. > > I taxied back to the hangar and shut down. I climbed out to find oil > dripping > from the lower firewall to the tailwheel, on the side of the fuse and on > the wing > root and no oil on the dipstick. Guess it lost a little more oil than I > thought, > duh. What a mess in the "engine compartment formally know as clean". > > I pulled the cowl and cleaned up the airplane up (I'm sure the EPA would > like to > talk to me bout now....). > > The oil lines were tight, that only leaves the oil cooler. Pulled that > and put > an air nozzle to it. Sounds like a big hole up where the tubes get welded > to > the main plenum. > > Hello, Van's......Can I order a Positech oil cooler and have it delivered > over > night? Thank you. > > So much for trying to save a couple of bucks on the cooler. > > Just thought anyone out there with one of these might like to know about > it. I > hadn't seen any failure reports in the archives. > > Laird RV-6 (with a well lubed paint job) > SoCal > > >From the Archives: > > From: Mlfred(at)aol.com > Subject: Re: Oil cooler location & low cost option > Hi all: > > PLEASE don't think you need one of those expensive coolers on your bird! > Rob > Lee will tell you, and so will I. > I use a small & inexpensive ($65) cooler (with male -8 AN fittings already > installed) from TMR, Inc in Orange, Calif. (714) 771-1348. Talk to Mike > and > tell him I sent you ( he'll only charge you an extra 10%). The 19 row ($70 > "Setrab" brand- malmo in Sweden) unit I use on my Rocket keeps the temps on > the 540 to 185F in cruise, and I think I used a 13 row on the -4, and it > was > usually too much. Rob Lee has the exact part # for the 320/360 unit. How > about posting it, along with installation tips, Rob? > > I mounted mine on the back baffle, on the left side. I used the > expanding-slowing air/increasing pressure idea, and the inlet to the cooler > is sort of a reverse funnel. > > Check six! > Mark Frederick > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421186#421186 > > ________________________________________________________________________________
Date: Apr 02, 2014
Subject: RV 10 Empanage for sale
Unfortunately due to the economic situation I am unable to complete my project. I have an RV10 empenage 90% complete. I have attached pictures and if you are interested and will be at sun - n - fun I live nearby and can make arrangements for you to see it. I'm asking $2500. R Leach Rick.leach@polk-fl.net ________________________________________________________________________________
Subject: Engine out over KOCF
Date: Apr 04, 2014
Fellow RVs, Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! Now for the important details that I believe can have a positive effect on others building or flying RV's. Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. Pictures attached are of the drilled retention nuts and the updated installation. Bob Newman N541RV 200 hrs ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Apr 04, 2014
Subject: Re: Engine out over KOCF
Great work, Bob. I'm happy to hear you did everything by the book--including PRACTICE. And, I don't think that FAB is going anywhere any time soon! Blue Skies, Dave Saylor 831-750-0284 CL On Fri, Apr 4, 2014 at 3:58 PM, Bob-tcw wrote: > Fellow RV=99s, > > Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I ha d > the opportunity to put all that engine-out training to work. The good new s > first: This was the best case possible, no one hurt, no airplane damage, > flew the plane, declared emergency, landed on the paved runway, made the > first taxiway. Guardian angle working overtime!! > > Now for the important details that I believe can have a positive effect o n > others building or flying RV's. > > Root cause of the engine failure was that the filtered airbox came off th e > throttle body, wedged under the intake portion of the throttle body and > disrupted the airflow through the metering venturi. This caused the mixtu re > to go way out of wack as the engine went to an extreme rich condition, I > saw fuel flow rates pegged at >30 gph as soon as the event occurred. > > My airplane is an RV-10 with a stock engine install and a stock cowling. I > have the Airflow Performance fuel injection system with a vertical mount > FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminu m > clamping doughnut to retain the filtered airbox assembly. This system doe s > not use safety-wired bolts on the filtered side of the airbox, just this > clamping doughnut. If the doughnut looses it's grip on the throttle body > the whole filtered airbox can slide downwards and fall off, in this case > that is exactly what happened. When we pulled the top cowling off, there in > the bottom sat the entire filtered airbox, clamping doughnut and all. > > Now for the fix: The filtered airbox bolts are located right underneath > the mounting studs for the throttle body assembly. I simply replaced thes e > bolts with drilled head bolts and made some drilled coupling nuts to put on > the throttle body studs, there was plenty of extra threads exposed on the se > studs so I didn't have to make any changes to the studs or the nuts that > hold the throttle body in place. Then just safety wire the whole thing > together. I used 0.040 wire to tie each filtered airbox bolt up to the > mounting studs. Below are pictures of the drilled nuts and the final > installation. > > Obviously I would highly recommend that if you have an Airflow Performanc e > fuel injection system with a vertically mounted fuel servo you take a loo k > at your installation and consider adding some securing means to ensure th is > thing can't come apart on your airplane. They key issue is that disruptin g > the airflow inside the fuel servo can make the engine STOP RUNNING! > > Lastly, I've collected the flight data out of my AFS EFIS system which I > just happened to have running at 2 second intervals. Its been very > instructive to see exactly how the whole event played out. I could see my > various attempts to get the engine to run properly by changing throttle > positions and the hopeless lack of actual power. You could see the excess > fuel just crater the EGTs, and now in hind sight I may have been able to > get some power back if I had the insight to try and close the mixture > radically. However, I can say with confidence my total focus after about 1 > or so minutes of trying to get power was on flying the plane to a safe > landing.... mission accomplished. > > > Pictures attached are of the drilled retention nuts and the updated > installation. > > > Bob Newman > N541RV 200 hrs > > ________________________________________________________________________________
Date: Apr 04, 2014
Bob, really, REALLY great to hear you made a safe landing! I have the AFS system on my IO-360 RV-9 but the setup is different. Have you called Don to discuss? Bret Smith N16BL -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob-tcw Sent: Friday, April 4, 2014 6:58 PM Subject: RV-List: Engine out over KOCF Fellow RVs, Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! Now for the important details that I believe can have a positive effect on others building or flying RV's. Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. Pictures attached are of the drilled retention nuts and the updated installation. Bob Newman N541RV 200 hrs ________________________________________________________________________________
Date: Apr 04, 2014
I did contact Don at AFP. He said he hadn't heard of an airbox falling off and that the primary problem is that the vans cowling snout is too tight to the air box. He also suggested that some have come up with ways to secure the fab. That's about it. Bob Sent from my iPhone On Apr 4, 2014, at 8:08 PM, "Bret Smith" wrote: > > Bob, really, REALLY great to hear you made a safe landing! I have the AFS system on my IO-360 RV-9 but the setup is different. Have you called Don to discuss? > > Bret Smith > N16BL > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob-tcw > Sent: Friday, April 4, 2014 6:58 PM > To: rv-list(at)matronics.com > Subject: RV-List: Engine out over KOCF > > Fellow RVs, > > Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news > first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! > > Now for the important details that I believe can have a positive effect on others building or flying RV's. > > Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. > > My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount > FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. > > Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. > > Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! > > Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. > However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... > mission accomplished. > > > Pictures attached are of the drilled retention nuts and the updated installation. > > > Bob Newman > N541RV 200 hrs > > > > > > > > > > ________________________________________________________________________________
Date: Apr 04, 2014
Great job Bob! Thanks for the report. Dick Sipp RV-10 535 hours -----Original Message----- From: Bob-tcw Sent: Friday, April 04, 2014 6:58 PM Subject: RV-List: Engine out over KOCF Fellow RVs, Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! Now for the important details that I believe can have a positive effect on others building or flying RV's. Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. Pictures attached are of the drilled retention nuts and the updated installation. Bob Newman N541RV 200 hrs ________________________________________________________________________________
Date: Apr 05, 2014
Bob, Great job and great report. No photos attached, however. Any chance of a url or a web site to show the photos? Charlie Brame RV-6A N11CB - with a vertical mount AFP fuel injection. San Antonio ----------------------------------------------------- > From: "Bob-tcw" <rnewman(at)tcwtech.com> > Subject: RV-List: Engine out over KOCF > > Fellow RVs, > > Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had > the opportunity to put all that engine-out training to work. The good news > first: This was the best case possible, no one hurt, no airplane damage, > flew the plane, declared emergency, landed on the paved runway, made the > first taxiway. Guardian angle working overtime!! > > Now for the important details that I believe can have a positive effect on > others building or flying RV's. > > Root cause of the engine failure was that the filtered airbox came off the > throttle body, wedged under the intake portion of the throttle body and > disrupted the airflow through the metering venturi. This caused the mixture > to go way out of wack as the engine went to an extreme rich condition, I saw > fuel flow rates pegged at >30 gph as soon as the event occurred. > > My airplane is an RV-10 with a stock engine install and a stock cowling. I > have the Airflow Performance fuel injection system with a vertical mount > FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum > clamping doughnut to retain the filtered airbox assembly. This system does > not use safety-wired bolts on the filtered side of the airbox, just this > clamping doughnut. If the doughnut looses it's grip on the throttle body the > whole filtered airbox can slide downwards and fall off, in this case that is > exactly what happened. When we pulled the top cowling off, there in the > bottom sat the entire filtered airbox, clamping doughnut and all. > > Now for the fix: The filtered airbox bolts are located right underneath the > mounting studs for the throttle body assembly. I simply replaced these bolts > with drilled head bolts and made some drilled coupling nuts to put on the > throttle body studs, there was plenty of extra threads exposed on these > studs so I didn't have to make any changes to the studs or the nuts that > hold the throttle body in place. Then just safety wire the whole thing > together. I used 0.040 wire to tie each filtered airbox bolt up to the > mounting studs. Below are pictures of the drilled nuts and the final > installation. > > Obviously I would highly recommend that if you have an Airflow Performance > fuel injection system with a vertically mounted fuel servo you take a look > at your installation and consider adding some securing means to ensure this > thing can't come apart on your airplane. They key issue is that disrupting > the airflow inside the fuel servo can make the engine STOP RUNNING! > > Lastly, I've collected the flight data out of my AFS EFIS system which I > just happened to have running at 2 second intervals. Its been very > instructive to see exactly how the whole event played out. I could see my > various attempts to get the engine to run properly by changing throttle > positions and the hopeless lack of actual power. You could see the excess > fuel just crater the EGTs, and now in hind sight I may have been able to get > some power back if I had the insight to try and close the mixture radically. > However, I can say with confidence my total focus after about 1 or so > minutes of trying to get power was on flying the plane to a safe landing.... > mission accomplished. > > > Pictures attached are of the drilled retention nuts and the updated > installation. > > > Bob Newman > N541RV 200 hrs ________________________________________________________________________________
Date: Apr 05, 2014
The original listing had pictures when I posted it. Did anyone else see them? Here=99s a url to one of the pics I put on my google+ album. https://lh3.googleusercontent.com/-36L4ELs0R10/Uz8rUckKBfI/AAAAAAAAUCE/Fu 3xneaqtWQ/w769-h577-no/2014-04-03+13.22.23.jpg Bob From: Charles Brame Sent: Saturday, April 05, 2014 11:06 AM Subject: RV-List: Engine out over KOCF Bob, Great job and great report. No photos attached, however. Any chance of a url or a web site to show the photos? Charlie Brame RV-6A N11CB - with a vertical mount AFP fuel injection. San Antonio ----------------------------------------------------- From: "Bob-tcw" <rnewman(at)tcwtech.com> Subject: RV-List: Engine out over KOCF Fellow RVs, Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! Now for the important details that I believe can have a positive effect on others building or flying RV's. Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. Pictures attached are of the drilled retention nuts and the updated installation. Bob Newman N541RV 200 hrs ________________________________________________________________________________
Date: Apr 05, 2014
Yes, they were there. All the way at the bottom. Sent from my Verizon iPhone > On Apr 5, 2014, at 1:50 PM, "Bob-tcw" wrote: > > The original listing had pictures when I posted it. Did anyone else see them? > > Here=99s a url to one of the pics I put on my google+ album. > > https://lh3.googleusercontent.com/-36L4ELs0R10/Uz8rUckKBfI/AAAAAAAAUCE/Fu 3xneaqtWQ/w769-h577-no/2014-04-03+13.22.23.jpg > > > Bob > > From: Charles Brame > Sent: Saturday, April 05, 2014 11:06 AM > To: List RV > Subject: RV-List: Engine out over KOCF > > Bob, > > Great job and great report. No photos attached, however. Any chance of a u rl or a web site to show the photos? > > Charlie Brame > RV-6A N11CB - with a vertical mount AFP fuel injection. > San Antonio > > ----------------------------------------------------- > > >> From: "Bob-tcw" <rnewman(at)tcwtech.com> >> Subject: RV-List: Engine out over KOCF >> >> Fellow RVs, >> >> Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I ha d >> the opportunity to put all that engine-out training to work. The good new s >> first: This was the best case possible, no one hurt, no airplane damage, >> flew the plane, declared emergency, landed on the paved runway, made the >> first taxiway. Guardian angle working overtime!! >> >> Now for the important details that I believe can have a positive effec t on >> others building or flying RV's. >> >> Root cause of the engine failure was that the filtered airbox came off th e >> throttle body, wedged under the intake portion of the throttle body and >> disrupted the airflow through the metering venturi. This caused the mixtu re >> to go way out of wack as the engine went to an extreme rich condition, I s aw >> fuel flow rates pegged at >30 gph as soon as the event occurred. >> >> My airplane is an RV-10 with a stock engine install and a stock cowling. I >> have the Airflow Performance fuel injection system with a vertical mount >> FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminu m >> clamping doughnut to retain the filtered airbox assembly. This system doe s >> not use safety-wired bolts on the filtered side of the airbox, just this >> clamping doughnut. If the doughnut looses it's grip on the throttle body t he >> whole filtered airbox can slide downwards and fall off, in this case that is >> exactly what happened. When we pulled the top cowling off, there in the >> bottom sat the entire filtered airbox, clamping doughnut and all. >> >> Now for the fix: The filtered airbox bolts are located right underneath t he >> mounting studs for the throttle body assembly. I simply replaced these bolts >> with drilled head bolts and made some drilled coupling nuts to put on the >> throttle body studs, there was plenty of extra threads exposed on these >> studs so I didn't have to make any changes to the studs or the nuts that >> hold the throttle body in place. Then just safety wire the whole thing >> together. I used 0.040 wire to tie each filtered airbox bolt up to the >> mounting studs. Below are pictures of the drilled nuts and the final >> installation. >> >> Obviously I would highly recommend that if you have an Airflow Performanc e >> fuel injection system with a vertically mounted fuel servo you take a loo k >> at your installation and consider adding some securing means to ensure th is >> thing can't come apart on your airplane. They key issue is that disruptin g >> the airflow inside the fuel servo can make the engine STOP RUNNING! >> >> Lastly, I've collected the flight data out of my AFS EFIS system which I >> just happened to have running at 2 second intervals. Its been very >> instructive to see exactly how the whole event played out. I could see my >> various attempts to get the engine to run properly by changing throttle >> positions and the hopeless lack of actual power. You could see the excess >> fuel just crater the EGTs, and now in hind sight I may have been able to g et >> some power back if I had the insight to try and close the mixture radical ly. >> However, I can say with confidence my total focus after about 1 or so >> minutes of trying to get power was on flying the plane to a safe landing. ... >> mission accomplished. >> >> >> Pictures attached are of the drilled retention nuts and the updated >> installation. >> >> >> Bob Newman >> N541RV 200 hrs > > > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.c om/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
From: "=?utf-8?B?Qm9iIENvbGxpbnM=?=" <bcollinsrv7a(at)comcast.net>
Subject: =?utf-8?B?UmU6IFJWLUxpc3Q6IEVuZ2luZSBvdXQgb3ZlciBLT0NG?
Date: Apr 05, 2014
VGhleSB3ZXJlIGF0dGFjaGVkIHRvIHRoZSBtZXNzYWdlIEkgZ290LgoKRG8gbm90IGFyY2hpdmUK ClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBTbWFydHBob25lCgotLS0tLSBS ZXBseSBtZXNzYWdlIC0tLS0tCkZyb206ICJCb2ItdGN3IiA8cm5ld21hbkB0Y3d0ZWNoLmNvbT4K VG86IDxydi1saXN0QG1hdHJvbmljcy5jb20+ClN1YmplY3Q6IFJWLUxpc3Q6IEVuZ2luZSBvdXQg b3ZlciBLT0NGCkRhdGU6IFNhdCwgQXByIDUsIDIwMTQgMTI6NTAgUE0KClRoZSBvcmlnaW5hbCBs aXN0aW5nIGhhZCBwaWN0dXJlcyB3aGVuIEkgcG9zdGVkIGl0LiAgICBEaWQgCmFueW9uZSBlbHNl IHNlZSB0aGVtPwoKSGVyZeKAmXMgYSB1cmwgdG8gb25lIG9mIHRoZSBwaWNzIEkgcHV0IG9uIG15 IGdvb2dsZSsgYWxidW0uICAKCmh0dHBzOi8vbGgzLmdvb2dsZXVzZXJjb250ZW50LmNvbS8tMzZM NEVMczBSMTAvVXo4clVja0tCZkkvQUFBQUFBQUFVQ0UvRnUzeG5lYXF0V1Evdzc2OS1oNTc3LW5v LzIwMTQtMDQtMDMrMTMuMjIuMjMuanBnCgoKQm9iCgoKCgpGcm9tOiBDaGFybGVzIEJyYW1lIApT ZW50OiBTYXR1cmRheSwgQXByaWwgMDUsIDIwMTQgMTE6MDYgQU0KVG86IExpc3QgUlYgClN1Ympl Y3Q6IFJWLUxpc3Q6IEVuZ2luZSBvdXQgb3ZlciBLT0NGCgoKQm9iLAoKR3JlYXQgam9iIGFuZCBn cmVhdCByZXBvcnQuIE5vIHBob3RvcyBhdHRhY2hlZCwgaG93ZXZlci4gQW55IGNoYW5jZSBvZiBh IAp1cmwgb3IgYSB3ZWIgc2l0ZSB0byBzaG93IHRoZSBwaG90b3M/CgpDaGFybGllIEJyYW1lClJW LTZBICBOMTFDQiAtIHdpdGggYSB2ZXJ0aWNhbCBtb3VudCBBRlAgZnVlbCBpbmplY3Rpb24uClNh biBBbnRvbmlvCgotLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLQoKCgpUaW1lOiAwMzo1OTo1OSBQTSBQU1QgVVNGcm9tOiAiQm9iLXRjdyIgCjxybmV3 bWFuQHRjd3RlY2guY29tPlN1YmplY3Q6IApSVi1MaXN0OiBFbmdpbmUgb3V0IG92ZXIgS09DRkZl bGxvdyBSVnMsTW9uZGF5IGFmdGVybm9vbiBhdCAKNzAwMCBmdC4gcmlnaHQgb3ZlciBLT0NGIG9u IG91ciB3YXkgdG8gU3VuLW4tRnVuIEkgaGFkIHRoZSBvcHBvcnR1bml0eSB0byAKcHV0IGFsbCB0 aGF0IGVuZ2luZS1vdXQgdHJhaW5pbmcgdG8gd29yay4gVGhlIGdvb2QgbmV3cyBmaXJzdDogVGhp cyB3YXMgCnRoZSBiZXN0IGNhc2UgcG9zc2libGUsIG5vIG9uZSBodXJ0LCBubyBhaXJwbGFuZSBk YW1hZ2UsIGZsZXcgdGhlIHBsYW5lLCAKZGVjbGFyZWQgZW1lcmdlbmN5LCBsYW5kZWQgb24gdGhl IHBhdmVkIHJ1bndheSwgbWFkZSB0aGUgZmlyc3QgdGF4aXdheS4gCkd1YXJkaWFuIGFuZ2xlIHdv cmtpbmcgb3ZlcnRpbWUhIU5vdyBmb3IgdGhlIGltcG9ydGFudCBkZXRhaWxzIHRoYXQgSSAKYmVs aWV2ZSBjYW4gaGF2ZSBhIHBvc2l0aXZlIGVmZmVjdCBvbiBvdGhlcnMgYnVpbGRpbmcgb3IgZmx5 aW5nIApSVidzLlJvb3QgY2F1c2Ugb2YgdGhlIGVuZ2luZSBmYWlsdXJlIHdhcyB0aGF0IHRoZSBm aWx0ZXJlZCBhaXJib3ggCmNhbWUgb2ZmIHRoZSB0aHJvdHRsZSBib2R5LCB3ZWRnZWQgdW5kZXIg dGhlIGludGFrZSBwb3J0aW9uIG9mIHRoZQp0aHJvdHRsZSBib2R5IGFuZCBkaXNydXB0ZWQgdGhl IGFpcmZsb3cgdGhyb3VnaCB0aGUgbWV0ZXJpbmcgdmVudHVyaS4gVGhpcyAKY2F1c2VkIHRoZSBt aXh0dXJlIHRvIGdvIHdheSBvdXQgb2Ygd2FjayBhcyB0aGUgZW5naW5lIHdlbnQgdG8gYW4gZXh0 cmVtZSAKcmljaCBjb25kaXRpb24sIEkgc2F3IGZ1ZWwgZmxvdyByYXRlcyBwZWdnZWQgYXQgPjMw IGdwaCBhcyBzb29uIGFzIHRoZSAKZXZlbnQgb2NjdXJyZWQuTXkgYWlycGxhbmUgaXMgYW4gUlYt MTAgd2l0aCBhIHN0b2NrIGVuZ2luZSBpbnN0YWxsIGFuZCAKYSBzdG9jayBjb3dsaW5nLiBJIGhh dmUgdGhlIEFpcmZsb3cgUGVyZm9ybWFuY2UgZnVlbCBpbmplY3Rpb24gc3lzdGVtIHdpdGggCmEg dmVydGljYWwgbW91bnQgRk0tMjAwIGZ1ZWwgc2Vydm8uIFRoaXMgaXMgdGhlIGNyaXRpY2FsIGlz c3VlLiBUaGUgRk0tMjAwIAp1c2VzIGFuIGFsdW1pbnVtIGNsYW1waW5nIGRvdWdobnV0IHRvIHJl dGFpbiB0aGUgZmlsdGVyZWQgYWlyYm94IGFzc2VtYmx5LiAKVGhpcyBzeXN0ZW0gZG9lcyBub3Qg dXNlIHNhZmV0eS13aXJlZCBib2x0cyBvbiB0aGUgZmlsdGVyZWQgc2lkZSBvZiB0aGUgCmFpcmJv eCwganVzdCB0aGlzIGNsYW1waW5nIGRvdWdobnV0LiBJZiB0aGUgZG91Z2hudXQgbG9vc2VzIGl0 J3MgZ3JpcCBvbiAKdGhlIHRocm90dGxlIGJvZHkgdGhlIHdob2xlIGZpbHRlcmVkIGFpcmJveCBj YW4gc2xpZGUgZG93bndhcmRzIGFuZCBmYWxsIApvZmYsIGluIHRoaXMgY2FzZSB0aGF0IGlzIGV4 YWN0bHkgd2hhdCBoYXBwZW5lZC4gV2hlbiB3ZSBwdWxsZWQgdGhlIHRvcCAKY293bGluZyBvZmYs IHRoZXJlIGluIHRoZSBib3R0b20gc2F0IHRoZSBlbnRpcmUgZmlsdGVyZWQgYWlyYm94LCBjbGFt cGluZyAKZG91Z2hudXQgYW5kIGFsbC5Ob3cgZm9yIHRoZSBmaXg6IFRoZSBmaWx0ZXJlZCBhaXJi b3ggYm9sdHMgYXJlIApsb2NhdGVkIHJpZ2h0IHVuZGVybmVhdGggdGhlIG1vdW50aW5nIHN0dWRz IGZvciB0aGUgdGhyb3R0bGUgYm9keSAKYXNzZW1ibHkuIEkgc2ltcGx5IHJlcGxhY2VkIHRoZXNl IGJvbHRzIHdpdGggZHJpbGxlZCBoZWFkIGJvbHRzIGFuZCBtYWRlIApzb21lIGRyaWxsZWQgY291 cGxpbmcgbnV0cyB0byBwdXQgb24gdGhlIHRocm90dGxlIGJvZHkgc3R1ZHMsIHRoZXJlIHdhcyAK cGxlbnR5IG9mIGV4dHJhIHRocmVhZHMgZXhwb3NlZCBvbiB0aGVzZSBzdHVkcyBzbyBJIGRpZG4n dCBoYXZlIHRvIG1ha2UgCmFueSBjaGFuZ2VzIHRvIHRoZSBzdHVkcyBvciB0aGUgbnV0cyB0aGF0 IGhvbGQgdGhlIHRocm90dGxlIGJvZHkgaW4gcGxhY2UuIApUaGVuIGp1c3Qgc2FmZXR5IHdpcmUg dGhlIHdob2xlIHRoaW5nIHRvZ2V0aGVyLiBJIHVzZWQgMC4wNDAgd2lyZSB0byB0aWUgCmVhY2gg ZmlsdGVyZWQgYWlyYm94IGJvbHQgdXAgdG8gdGhlIG1vdW50aW5nIHN0dWRzLiBCZWxvdyBhcmUg cGljdHVyZXMgb2YgCnRoZSBkcmlsbGVkIG51dHMgYW5kIHRoZSBmaW5hbCBpbnN0YWxsYXRpb24u T2J2aW91c2x5IEkgd291bGQgCmhpZ2hseSByZWNvbW1lbmQgdGhhdCBpZiB5b3UgaGF2ZSBhbiBB aXJmbG93IFBlcmZvcm1hbmNlIGZ1ZWwgaW5qZWN0aW9uIApzeXN0ZW0gd2l0aCBhIHZlcnRpY2Fs bHkgbW91bnRlZCBmdWVsIHNlcnZvIHlvdSB0YWtlIGEgbG9vayBhdCB5b3VyIAppbnN0YWxsYXRp b24gYW5kIGNvbnNpZGVyIGFkZGluZyBzb21lIHNlY3VyaW5nIG1lYW5zIHRvIGVuc3VyZSB0aGlz IHRoaW5nIApjYW4ndCBjb21lIGFwYXJ0IG9uIHlvdXIgYWlycGxhbmUuIFRoZXkga2V5IGlzc3Vl IGlzIHRoYXQgZGlzcnVwdGluZyB0aGUgCmFpcmZsb3cgaW5zaWRlIHRoZSBmdWVsIHNlcnZvIGNh biBtYWtlIHRoZSBlbmdpbmUgU1RPUCBSVU5OSU5HIUxhc3RseSwgCkkndmUgY29sbGVjdGVkIHRo ZSBmbGlnaHQgZGF0YSBvdXQgb2YgbXkgQUZTIEVGSVMgc3lzdGVtIHdoaWNoIEkganVzdCAKaGFw cGVuZWQgdG8gaGF2ZSBydW5uaW5nIGF0IDIgc2Vjb25kIGludGVydmFscy4gSXRzIGJlZW4gdmVy eSBpbnN0cnVjdGl2ZSAKdG8gc2VlIGV4YWN0bHkgaG93IHRoZSB3aG9sZSBldmVudCBwbGF5ZWQg b3V0LiBJIGNvdWxkIHNlZSBteSB2YXJpb3VzIAphdHRlbXB0cyB0byBnZXQgdGhlIGVuZ2luZSB0 byBydW4gcHJvcGVybHkgYnkgY2hhbmdpbmcgdGhyb3R0bGUgcG9zaXRpb25zIAphbmQgdGhlIGhv cGVsZXNzIGxhY2sgb2YgYWN0dWFsIHBvd2VyLiBZb3UgY291bGQgc2VlIHRoZSBleGNlc3MgZnVl bCBqdXN0IApjcmF0ZXIgdGhlIEVHVHMsIGFuZCBub3cgaW4gaGluZCBzaWdodCBJIG1heSBoYXZl IGJlZW4gYWJsZSB0byBnZXQgc29tZSAKcG93ZXIgYmFjayBpZiBJIGhhZCB0aGUgaW5zaWdodCB0 byB0cnkgYW5kIGNsb3NlIHRoZSBtaXh0dXJlIHJhZGljYWxseS4gCkhvd2V2ZXIsIEkgY2FuIHNh eSB3aXRoIGNvbmZpZGVuY2UgbXkgdG90YWwgZm9jdXMgYWZ0ZXIgYWJvdXQgMSBvciBzbyAKbWlu dXRlcyBvZiB0cnlpbmcgdG8gZ2V0IHBvd2VyIHdhcyBvbiBmbHlpbmcgdGhlIHBsYW5lIHRvIGEg c2FmZSAKbGFuZGluZy4uLi4gbWlzc2lvbiBhY2NvbXBsaXNoZWQuUGljdHVyZXMgYXR0YWNoZWQg YXJlIG9mIHRoZSAKZHJpbGxlZCByZXRlbnRpb24gbnV0cyBhbmQgdGhlIHVwZGF0ZWQgaW5zdGFs bGF0aW9uLkJvYiAKTmV3bWFuTjU0MVJWIDIwMCBocnMKCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/UlYtTGlzdCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmln YXRvcj9SVi1MaXN0CmhyZWY9Imh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbSI+aHR0cDovL2Zv cnVtcy5tYXRyb25pY3MuY29tCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmli dXRpb24iPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jCgoKCgoKXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAg IC0gVGhlIFJWLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBz dWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9h ZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNo IG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9S Vi1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1T IC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1 bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpf LT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsg eW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0 ________________________________________________________________________________
Date: Apr 06, 2014
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Apr 06, 2014
I second that, the vertical safeties are not needed and the wraps are not tight near the bolt heads. Refer to the drawings Sent from my Verizon iPhone > On Apr 6, 2014, at 2:22 PM, Tim Lewis wrote: > > Bob, > > An involuntary glider ride is no fun -- I'm glad you were able to land safely. Thanks for sharing your experience (and the cause) with the group. > > I'm confused by the safety wire shown in your photos (particularly the vertical runs of safety wire up to the coupling nuts). Is your primary intent to safety the 4 drilled-head AN-3 bolts that penetrate down through the FAB aluminum cover? If so, normal practice as I understand it would be to just safety wire those AN-3 bolts to each other in pairs (as shown in AC 43.13-1B, page 7-20, Figure 7-3, for example). > > > > Thanks, > > Tim > -- > Tim Lewis -- HEF (Manassas, VA) > A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 500 hrs > Bob-tcw said the following on 4/4/2014 6:58 PM: >> Fellow RVs, >> >> Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! >> >> Now for the important details that I believe can have a positive effect on others building or flying RV's. >> >> Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. >> >> My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. >> >> Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. >> >> Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! >> >> Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. >> >> >> Pictures attached are of the drilled retention nuts and the updated installation. >> >> >> Bob Newman >> N541RV 200 hrs > ________________________________________________________________________________
Date: Apr 06, 2014
I've got no experience with that system, but I read the original post as saying that the stock setup only uses a clamp around the inlet neck of the throttle body to hold the airbox on the throttle body. I thought that he was using the vertical runs of safety wire as a safety to keep the airbox up if the clamp releases its grip (again). On 4/6/2014 2:14 PM, Bobby Hester wrote: > > I second that, the vertical safeties are not needed and the wraps are not tight near the bolt heads. Refer to the drawings > > Sent from my Verizon iPhone > >> On Apr 6, 2014, at 2:22 PM, Tim Lewis wrote: >> >> Bob, >> >> An involuntary glider ride is no fun -- I'm glad you were able to land safely. Thanks for sharing your experience (and the cause) with the group. >> >> I'm confused by the safety wire shown in your photos (particularly the vertical runs of safety wire up to the coupling nuts). Is your primary intent to safety the 4 drilled-head AN-3 bolts that penetrate down through the FAB aluminum cover? If so, normal practice as I understand it would be to just safety wire those AN-3 bolts to each other in pairs (as shown in AC 43.13-1B, page 7-20, Figure 7-3, for example). >> >> >> >> Thanks, >> >> Tim >> -- >> Tim Lewis -- HEF (Manassas, VA) >> A&P >> RV-6A N47TD -- 1104 hrs - sold >> RV-10 N31TD -- 500 hrs >> Bob-tcw said the following on 4/4/2014 6:58 PM: >>> Fellow RVs, >>> >>> Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! >>> >>> Now for the important details that I believe can have a positive effect on others building or flying RV's. >>> >>> Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. >>> >>> My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. >>> >>> Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. >>> >>> Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! >>> >>> Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. >>> >>> >>> Pictures attached are of the drilled retention nuts and the updated installation. >>> >>> >>> Bob Newman >>> N541RV 200 hrs > > ________________________________________________________________________________
Date: Apr 06, 2014
Charlie has it right. The whole point is to provide a safety means in the vertical direction. The clamping doughnut is below the filtered airbox plate and not visible in the picture. The four bolts that I safety wired to thread into the doughnut. I safety wired between the bolts to provide additional protection against them backing out. However, those four bolts could be removed and as long as the clamping doughnut remained tight the box can't come off. Lastly the vertical safety wire doesn't exactly need to be crazy tight as it would require about 3/4" of travel before the doughnut comes disengaged from the fuel servo. Bob Newman. On Apr 6, 2014, at 4:10 PM, Charlie England wrote: > > I've got no experience with that system, but I read the original post as saying that the stock setup only uses a clamp around the inlet neck of the throttle body to hold the airbox on the throttle body. I thought that he was using the vertical runs of safety wire as a safety to keep the airbox up if the clamp releases its grip (again). > > On 4/6/2014 2:14 PM, Bobby Hester wrote: >> >> I second that, the vertical safeties are not needed and the wraps are not tight near the bolt heads. Refer to the drawings >> >> Sent from my Verizon iPhone >> >>> On Apr 6, 2014, at 2:22 PM, Tim Lewis wrote: >>> >>> Bob, >>> >>> An involuntary glider ride is no fun -- I'm glad you were able to land safely. Thanks for sharing your experience (and the cause) with the group. >>> >>> I'm confused by the safety wire shown in your photos (particularly the vertical runs of safety wire up to the coupling nuts). Is your primary intent to safety the 4 drilled-head AN-3 bolts that penetrate down through the FAB aluminum cover? If so, normal practice as I understand it would be to just safety wire those AN-3 bolts to each other in pairs (as shown in AC 43.13-1B, page 7-20, Figure 7-3, for example). >>> >>> >>> >>> Thanks, >>> >>> Tim >>> -- >>> Tim Lewis -- HEF (Manassas, VA) >>> A&P >>> RV-6A N47TD -- 1104 hrs - sold >>> RV-10 N31TD -- 500 hrs >>> Bob-tcw said the following on 4/4/2014 6:58 PM: >>>> Fellow RVs, >>>> >>>> Monday afternoon at 7000 ft. right over KOCF on our way to Sun-n-Fun I had the opportunity to put all that engine-out training to work. The good news first: This was the best case possible, no one hurt, no airplane damage, flew the plane, declared emergency, landed on the paved runway, made the first taxiway. Guardian angle working overtime!! >>>> >>>> Now for the important details that I believe can have a positive effect on others building or flying RV's. >>>> >>>> Root cause of the engine failure was that the filtered airbox came off the throttle body, wedged under the intake portion of the throttle body and disrupted the airflow through the metering venturi. This caused the mixture to go way out of wack as the engine went to an extreme rich condition, I saw fuel flow rates pegged at >30 gph as soon as the event occurred. >>>> >>>> My airplane is an RV-10 with a stock engine install and a stock cowling. I have the Airflow Performance fuel injection system with a vertical mount FM-200 fuel servo. This is the critical issue. The FM-200 uses an aluminum clamping doughnut to retain the filtered airbox assembly. This system does not use safety-wired bolts on the filtered side of the airbox, just this clamping doughnut. If the doughnut looses it's grip on the throttle body the whole filtered airbox can slide downwards and fall off, in this case that is exactly what happened. When we pulled the top cowling off, there in the bottom sat the entire filtered airbox, clamping doughnut and all. >>>> >>>> Now for the fix: The filtered airbox bolts are located right underneath the mounting studs for the throttle body assembly. I simply replaced these bolts with drilled head bolts and made some drilled coupling nuts to put on the throttle body studs, there was plenty of extra threads exposed on these studs so I didn't have to make any changes to the studs or the nuts that hold the throttle body in place. Then just safety wire the whole thing together. I used 0.040 wire to tie each filtered airbox bolt up to the mounting studs. Below are pictures of the drilled nuts and the final installation. >>>> >>>> Obviously I would highly recommend that if you have an Airflow Performance fuel injection system with a vertically mounted fuel servo you take a look at your installation and consider adding some securing means to ensure this thing can't come apart on your airplane. They key issue is that disrupting the airflow inside the fuel servo can make the engine STOP RUNNING! >>>> >>>> Lastly, I've collected the flight data out of my AFS EFIS system which I just happened to have running at 2 second intervals. Its been very instructive to see exactly how the whole event played out. I could see my various attempts to get the engine to run properly by changing throttle positions and the hopeless lack of actual power. You could see the excess fuel just crater the EGTs, and now in hind sight I may have been able to get some power back if I had the insight to try and close the mixture radically. However, I can say with confidence my total focus after about 1 or so minutes of trying to get power was on flying the plane to a safe landing.... mission accomplished. >>>> >>>> >>>> Pictures attached are of the drilled retention nuts and the updated installation. >>>> >>>> >>>> Bob Newman >>>> N541RV 200 hrs > > > > > ________________________________________________________________________________
Subject: Horz stab and elv hinge SB's
Date: Apr 07, 2014
2 part question. I am not builder but think I can make these inspections and hopefully enter that no problems found. If problems found I should be able to make repairs, OR get help from my A&P who signs off my annual to help if needed. Am I right about this? 2000 flying RV6A under 400 hr TT ________________________________________________________________________________
Date: Apr 07, 2014
Subject: Re: Horz stab and elv hinge SB's
On 4/7/2014 10:29 AM, cheathco(at)cox.net wrote: > 2 part question. I am not builder but think I can make these > inspections and hopefully enter that no problems found. If problems > found I should be able to make repairs, OR get help from my A&P who > signs off my annual to help if needed. Am I right about this? 2000 > flying RV6A under 400 hr TT > On any homebuilt experimental in the USA, *anyone* can do *anything* that's maintenance or repair related, *except* the annual condition inspection, which must be signed off by either the repairman's certificate holder or someone holding at least an A&P ticket. As the owner, you can sign off any other repairs or inspections. Hope that helps, Charlie ________________________________________________________________________________
Date: Apr 07, 2014
On an amateur-built aircraft anybody may do the maintenance but only the bu ilder=2C certificated as a repairman=2C or an A&P may conduct the yearly co ndition inspection (annual). Make sure you check the aircraft's operating limitations (which are supposed to be in the aircraft at all times) to see any restrictions and limitations. Mike Robertson Das Fed From: cheathco(at)cox.net Subject: RV-List: Horz stab and elv hinge SB's Date: Mon=2C 7 Apr 2014 10:29:11 -0500 2 part question. I am not builder but think I can make these inspections an d hopefully enter that no problems found. If problems found I should be abl e to make repairs=2C OR get help from my A&P who signs off my annual to hel p if needed. Am I right about this? 2000 flying RV6A under 400 hr TT ________________________________________________________________________________
Date: Apr 07, 2014
As the guys have said, you can do the work, if you can do the work that is. The disassembly and repair involves drilling out a bunch of rivets, some of which will be hard to get to and will require the skillful use of an angle drill. Do yourself a favor and get some experienced/qualified help, if repairs are required. Seems unlikely that a 400hr airplane will have cracks, but it does need to be looked at closely. Ed Holyoke On 4/7/2014 8:29 AM, cheathco(at)cox.net wrote: > 2 part question. I am not builder but think I can make these inspections > and hopefully enter that no problems found. If problems found I should > be able to make repairs, OR get help from my A&P who signs off my annual > to help if needed. Am I right about this? 2000 flying RV6A under 400 hr TT > > * > > > * > ________________________________________________________________________________
Date: Apr 14, 2014
Subject: Re: Flap mod
At 09:42 AM 4/14/2014 Monday, you wrote: > Saw your flap mod in the current RV-8 thread. I like what you did. Any pictures showing the inside or top of the addition? > >Blain Stumpf Hi Blain, Here are some additional pictures of the flap seals I made. They really clean up the underside nicely. Recommend. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: RV-6A shaky nose wheel
Date: Apr 15, 2014
I've occasionally felt some strange vibes coming from the front of the airplane on landing but wasn't sure what it was because it happened so seldom. I put a camera under the wing tip and caught it red handed a few weeks ago. It hadn't happened for quite some time before then and coincided with me filling the nose tire (~35 PSI) prior to the flight. Check out the you tube link below (first 2 minutes) and tell me what you think . Is it caused by higher pressure in the tire or? The thought of the gear leg coming apart from all that shaking makes me a bit nervous. Like to find a cure so that doesn't happen. I noticed at the last annual that the nose tire is wearing much more in the center and I have NOT installed a wood stiffener on the leg. www.youtube.com/watch?v=p_CaaRJh3pA Dean Psiropoulos RV-6A N197DM 200+ hours of flying fun ________________________________________________________________________________
Subject: Re: RV-6A shaky nose wheel
Date: Apr 15, 2014
Scary...Looks like inadequate tensioning of the nose gear breakout force to me. I found that I had to double up on the Belleville washers to get mine to be in the right range. I also keep all my tires around 31 psig. -----Original Message----- From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> Sent: Mon, Apr 14, 2014 9:33 pm Subject: RV-List: RV-6A shaky nose wheel .net> I've occasionally felt some strange vibes coming from the front of the airplane on landing but wasn't sure what it was because it happened so seldom. I put a camera under the wing tip and caught it red handed a few weeks ago. It hadn't happened for quite some time before then and coincided with me filling the nose tire (~35 PSI) prior to the flight. Check out the you tube link below (first 2 minutes) and tell me what you think . Is it caused by higher pressure in the tire or? The thought of the gear leg comin g apart from all that shaking makes me a bit nervous. Like to find a cure so that doesn't happen. I noticed at the last annual that the nose tire is wearing much more in the center and I have NOT installed a wood stiffener o n the leg. www.youtube.com/watch?v=p_CaaRJh3pA Dean Psiropoulos RV-6A N197DM 200+ hours of flying fun ________________________________________________________________________________
Date: Apr 14, 2014
I agree.- Dismantle the whole nose wheel / gear leg attachment system.- Check that the washers are positioned correctly (per the plans), reassembl e and tighten the nut until you get the book breakout force - then cotter k ey it.- ( disassembled you can also check the condition of the fork bushi ngs). Just had an errant thought.- Are you using the smaller nose wheel f ork, and if so, did you cut off the excess thread and re thread the gear le g? - If your using the small fork and have not modified the gear leg then the nut is bottoming out on the threads and you will never get the right t ension. =0A=0AReuven =0A=0A=0A-=0AEnjoy life now=0AIt has an expiration d ate.=0AOn Monday, April 14, 2014 10:19 PM, "vanremog(at)aol.com" wrote:=0A =0AScary...Looks like inadequate tensioning of the nose gea r breakout force to me.- I found that I had to double up on-the Bellevi lle washers to get mine to be in the right range.- I also keep all-my t ires around 31 psig.=0A-----Original Message-----=0AFrom: DEAN PSIROPOULOS =0ATo: rv-list =0ASent : Mon, Apr 14, 2014 9:33 pm=0ASubject: RV-List: RV-6A shaky nose wheel=0A erizon.net> I've occasionally felt some strange vibes coming from the front of the=0Aairplane on landing but wasn't sure what it was because it happen ed so=0Aseldom. I put a camera under the wing tip and caught it red handed a few=0Aweeks ago. It hadn't happened for quite some time before then and c oincided=0Awith me filling the nose tire (~35 PSI) prior to the flight. Che ck out the=0Ayou tube link below (first 2 minutes) and tell me what you thi nk . Is it=0Acaused by higher pressure in the tire or? The thought of the g ear leg coming=0Aapart from all that shaking makes me a bit nervous. Like t o find a cure so=0Athat doesn't happen. I noticed at the last annual that t he nose tire is=0Awearing much more in the center and I have NOT installed a wood stiffener on=0Athe leg. www.youtube.com/watch?v=p_CaaRJh3pA Dean P siropoulos=0ARV-6A N197DM=0A200+ hours of flying fun t="_blank">http:/ /www.matronics.com/Navigator?RV-List=0Atp://forums.matronics.com=0A_blank"> ________________________________________________________________________________
Date: Apr 15, 2014
I agree too! I haven't got there yet (fiberglass hell on a -10), but my little Grumman has a similar nose wheel setup. Grumman specs 25 Lbs pull at the axle but 28-30 works better. As for the short nose fork, wouldn't adding more belleville washers be an easier fix??? Just thinking out loud ..... the Grumman washers are thinner than Vans and they stack more of them. Linn On 4/15/2014 1:31 AM, Reuven Silberman wrote: > I agree. Dismantle the whole nose wheel / gear leg attachment > system. Check that the washers are positioned correctly (per the > plans), reassemble and tighten the nut until you get the book breakout > force - then cotter key it. ( disassembled you can also check the > condition of the fork bushings). Just had an errant thought. Are you > using the smaller nose wheel fork, and if so, did you cut off the > excess thread and re thread the gear leg? If your using the small > fork and have not modified the gear leg then the nut is bottoming out > on the threads and you will never get the right tension. > > Reuven > > Enjoy life now > It has an expiration date. > On Monday, April 14, 2014 10:19 PM, "vanremog(at)aol.com" > wrote: > Scary...Looks like inadequate tensioning of the nose gear breakout > force to me. I found that I had to double up on the Belleville > washers to get mine to be in the right range. I also keep all my > tires around 31 psig. > -----Original Message----- > From: DEAN PSIROPOULOS <dean.psiropoulos(at)verizon.net> > To: rv-list > Sent: Mon, Apr 14, 2014 9:33 pm > Subject: RV-List: RV-6A shaky nose wheel > > > I've occasionally felt some strange vibes coming from the front of the > airplane on landing but wasn't sure what it was because it happened so > seldom. I put a camera under the wing tip and caught it red handed a few > weeks ago. It hadn't happened for quite some time before then and coincided > with me filling the nose tire (~35 PSI) prior to the flight. Check out the > you tube link below (first 2 minutes) and tell me what you think . Is it > caused by higher pressure in the tire or? The thought of the gear leg coming > apart from all that shaking makes me a bit nervous. Like to find a cure so > that doesn't happen. I noticed at the last annual that the nose tire is > wearing much more in the center and I have NOT installed a wood stiffener on > the leg. > > www.youtube.com/watch?v=p_CaaRJh3pA <http://www.youtube.com/watch?v=p_CaaRJh3pA> > > > Dean Psiropoulos > RV-6A N197DM > 200+ hours of flying fun > > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > *http://www.matronics.com/contribution============ > > * > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Apr 15, 2014
I've been flying my RV-7A for about 10 years now out of a not too smooth grass strip. Every couple of years I have to replace the bolt at the top of the nose gear leg. You can see this looseness by rocking the plane side to side with the prop. Its a rotation of the gear leg in the engine mount socket. When I remove the bolt it is crushed a little. I've tried LockTite around the gear leg, etc., but greasing it and replacing the bolt seems to be as good as anything I've tried. I'm tempted to weld it to the engine mount at the top thinking that if I bend the gear leg, I'll probably have to replace the engine mount anyway. Rather than using the axle bolt to adjust the bearing, I made a spacer out of 3/4 dia. rod to go inside the nose wheel so that I could tighten the axle bolt. This makes a much stronger assembly. Its a little hard to get the length of the spacer right, but well worth the effort. It must be (should be anyway) faced off in a lathe. To keep it in place during installation, use a piece of 3/8 dia. rod a little shorter than the space the wheel fits in. Then the axle bolt will push the rod out as you push the axle bolt in without letting the spacer drop out of position. Not part of the solution, but the Nose Job gear leg brace is a good investment IMHO. Just the way I did it. Hope this helps someone. Dan Hopper RV-7A N766DH ________________________________________________________________________________
Subject: Shaky Nose Wheel
Date: Apr 15, 2014
Wow. That video really shows some problems. While most of your vibration seems to be lateral, I noticed some rapid fore and aft oscillations of the wheel and strut assembly immediately after the nose wheel touches the runway. That tells me that the tire and wheel may not be not spinning freely. If the tire doesn't spin freely, it causes the nose strut to move aft and then rebound, resulting in up and down oscillations and associated vibrations until the speed is slowed down greatly. Second, as mentioned by several others, make sure the breakout force of the nose wheel is tightened according to Van's instructions. Better too tight than too loose. Third. Around a 100 hours in my bird, I found the bolt at the top of the nose gear strut was a bit loose and had slightly wallowed out the hole in the nose gear trunion on the motor mount. I debated pulling the engine and the motor mount and over sizing the hole in the trunion and the strut. Ultimately, I just super tightened the nut on the firewall side of the strut. I check it frequently by raising the nose gear off the ground and trying to twist the strut in the mount. Fortunately, it has remained tight for the last 200 hours. Lastly, Van's cure for vibrating wheels is to reduce the tire pressure. Applies both to nose gear and the main gear also. I generally carry about 20 to 25 psi in all my tires. Charlie Brame RV-6A N11CB 300 hours San Antonio ---------------------------------------------------- > From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> > Subject: RV-List: RV-6A shaky nose wheel > > I've occasionally felt some strange vibes coming from the front of the > airplane on landing but wasn't sure what it was because it happened so > seldom. I put a camera under the wing tip and caught it red handed a few > weeks ago. It hadn't happened for quite some time before then and coincided > with me filling the nose tire (~35 PSI) prior to the flight. Check out the > you tube link below (first 2 minutes) and tell me what you think . Is it > caused by higher pressure in the tire or? The thought of the gear leg coming > apart from all that shaking makes me a bit nervous. Like to find a cure so > that doesn't happen. I noticed at the last annual that the nose tire is > wearing much more in the center and I have NOT installed a wood stiffener on > the leg. > > www.youtube.com/watch?v=p_CaaRJh3pA > > Dean Psiropoulos > RV-6A N197DM > 200+ hours of flying fun ________________________________________________________________________________
Date: Apr 15, 2014
My 6A nose wheel tends to wiggle at high (35ps) air pressure. I keep it below 30 and it seems to be OK. RV-6A, N811WT On Tue, Apr 15, 2014 at 5:23 AM, wrote: > > > I've been flying my RV-7A for about 10 years now out of a not too smooth > grass strip. Every couple of years I have to replace the bolt at the top > of the nose gear leg. You can see this looseness by rocking the plane side > to side with the prop. Its a rotation of the gear leg in the engine mount > socket. When I remove the bolt it is crushed a little. I've tried > LockTite around the gear leg, etc., but greasing it and replacing the bolt > seems to be as good as anything I've tried. I'm tempted to weld it to the > engine mount at the top thinking that if I bend the gear leg, I'll probably > have to replace the engine mount anyway. > > Rather than using the axle bolt to adjust the bearing, I made a spacer out > of 3/4 dia. rod to go inside the nose wheel so that I could tighten the > axle bolt. This makes a much stronger assembly. Its a little hard to get > the length of the spacer right, but well worth the effort. It must be > (should be anyway) faced off in a lathe. To keep it in place during > installation, use a piece of 3/8 dia. rod a little shorter than the space > the wheel fits in. Then the axle bolt will push the rod out as you push > the axle bolt in without letting the spacer drop out of position. > > Not part of the solution, but the Nose Job gear leg brace is a good > investment IMHO. > > Just the way I did it. Hope this helps someone. > > Dan Hopper > RV-7A N766DH > > > * > > > * > > -- Tom Sargent ________________________________________________________________________________
Date: Apr 16, 2014
Subject: Matronics Web Server Down for Repair (PLEASE READ)...
Dear Listers, Late Tuesday night 4/15/2014, the Matronics Web server crashed due to a multi-disk RAID 5 failure. The system has complete data backups, but I will likely have to order some replacement disks to rebuild the system. I'll work as quickly as I can to restore the Matronics Web Server. The Matronics EMAIL server is NOT impacted by this issue. All normal Matronics Email List mail will flow as usual. However, the Matronics Web Forums interface will not be available. Also impacted by the Web Server outage will be the AeroElectric web site. I will try to post daily updates on the Web Server restoration status. I apologize for the inconvenience... :-( Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 16, 2014
Dean, I've studied this issue to some depth, and the problem is the design of the nose wheel bearings. The forward-backward oscillations mentioned by Charles Brame are due to pinching of the wheel by the bearings as it rotates. The bearings bind when weight is put on the wheel. But you don't dare loosen up the bearings too much either. The solution is a solid axle and spacer, new maintenance-free bearings, and precision balancing of the wheel and tire. I had this service done on mine by Antisplat-Aero, and a local friend has some before-and-after video, like yours, showing exactly how yours behaves (the before) and the dramatic difference and smoothness after it's done. It was so nice to torque my axle down nice and tight, and the wheel spins freely by hand. I pump up the nose wheel to 35 psi or even more. Take a look at this video, and see what it's all about. https://www.youtube.com/watch?v=JpfazTrtbyY It cost me a little over $200 to get this done, and I've never felt like money was better spent. I should mention I have no affiliation with these people and nothing to gain by this. I'm just a very happy customer of this service. Best to you, Bruce Swayze At 09:31 PM 4/14/2014, you wrote: > > > >I've occasionally felt some strange vibes coming from the front of the >airplane on landing but wasn't sure what it was because it happened so >seldom. I put a camera under the wing tip and caught it red handed a few >weeks ago. It hadn't happened for quite some time before then and coincided >with me filling the nose tire (~35 PSI) prior to the flight. Check out the >you tube link below (first 2 minutes) and tell me what you think . Is it >caused by higher pressure in the tire or? The thought of the gear leg coming >apart from all that shaking makes me a bit nervous. Like to find a cure so >that doesn't happen. I noticed at the last annual that the nose tire is >wearing much more in the center and I have NOT installed a wood stiffener on >the leg. > >www.youtube.com/watch?v=p_CaaRJh3pA > > >Dean Psiropoulos >RV-6A N197DM >200+ hours of flying fun ________________________________________________________________________________
Date: Apr 16, 2014
Dean, Bruce, and all, I hate to be argumentative but it appears to me that the wheel is on the wrong end of the airplane. :-) Jon http://jdfinley.com P.S. Ya just knew some doink was going to bring this up... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bruce Swayze Sent: Wednesday, April 16, 2014 6:35 AM Subject: Re: RV-List: RV-6A shaky nose wheel Dean, I've studied this issue to some depth, and the problem is the design of the nose wheel bearings. The forward-backward oscillations mentioned by Charles Brame are due to pinching of the wheel by the bearings as it rotates. The bearings bind when weight is put on the wheel. But you don't dare loosen up the bearings too much either. The solution is a solid axle and spacer, new maintenance-free bearings, and precision balancing of the wheel and tire. I had this service done on mine by Antisplat-Aero, and a local friend has some before-and-after video, like yours, showing exactly how yours behaves (the before) and the dramatic difference and smoothness after it's done. It was so nice to torque my axle down nice and tight, and the wheel spins freely by hand. I pump up the nose wheel to 35 psi or even more. Take a look at this video, and see what it's all about. https://www.youtube.com/watch?v=JpfazTrtbyY It cost me a little over $200 to get this done, and I've never felt like money was better spent. I should mention I have no affiliation with these people and nothing to gain by this. I'm just a very happy customer of this service. Best to you, Bruce Swayze At 09:31 PM 4/14/2014, you wrote: > > > >I've occasionally felt some strange vibes coming from the front of the >airplane on landing but wasn't sure what it was because it happened so >seldom. I put a camera under the wing tip and caught it red handed a >few weeks ago. It hadn't happened for quite some time before then and >coincided with me filling the nose tire (~35 PSI) prior to the flight. >Check out the you tube link below (first 2 minutes) and tell me what >you think . Is it caused by higher pressure in the tire or? The thought >of the gear leg coming apart from all that shaking makes me a bit >nervous. Like to find a cure so that doesn't happen. I noticed at the >last annual that the nose tire is wearing much more in the center and I >have NOT installed a wood stiffener on the leg. > >www.youtube.com/watch?v=p_CaaRJh3pA > > >Dean Psiropoulos >RV-6A N197DM >200+ hours of flying fun ________________________________________________________________________________
Date: Apr 16, 2014
I mentioned a friend who had the nose wheel bearing mod done on his RV, and he took before-and-after videos of the nose wheel behavior on some of his landings. I looked up the video for you, so you can see the difference the modification made for his RV. I know him personally, and he swears by this. Take a look: https://www.youtube.com/watch?v=W0kHXOIop5Y At 09:31 PM 4/14/2014, you wrote: > > > >I've occasionally felt some strange vibes coming from the front of the >airplane on landing but wasn't sure what it was because it happened so >seldom. I put a camera under the wing tip and caught it red handed a few >weeks ago. It hadn't happened for quite some time before then and coincided >with me filling the nose tire (~35 PSI) prior to the flight. Check out the >you tube link below (first 2 minutes) and tell me what you think . Is it >caused by higher pressure in the tire or? The thought of the gear leg coming >apart from all that shaking makes me a bit nervous. Like to find a cure so >that doesn't happen. I noticed at the last annual that the nose tire is >wearing much more in the center and I have NOT installed a wood stiffener on >the leg. > >www.youtube.com/watch?v=p_CaaRJh3pA > > >Dean Psiropoulos >RV-6A N197DM >200+ hours of flying fun ________________________________________________________________________________
Date: Apr 16, 2014
Hello Bruce and Dean, I certainly agree that it is good to be able to tighten the axle nut. But, I can't see why this relatively expensive fix is any better than the spacer idea I posted earlier which I copied and pasted here: Rather than using the axle bolt to adjust the bearing, I made a spacer out of 3/4 dia. rod to go inside the nose wheel so that I could tighten the axle bolt. This makes a much stronger assembly. Its a little hard to get the length of the spacer right, but well worth the effort. It must be (should be anyway) faced off in a lathe. To keep it in place during installation, use a piece of 3/8 dia. rod a little shorter than the space the wheel fits in. Then the axle bolt will push the rod out as you push the axle bolt in without letting the spacer drop out of position. What I am talking about is a small spool that holds the inner bearing cones apart so that the bearings have a fixed "adjustment" determined by the length of the spacer. Tapered roller bearings are used in almost all cars on the road and in all certificated airplanes. There surely is nothing wrong with the basic design. Sincerely, Dan RV7A N766DH In a message dated 4/16/2014 8:45:04 A.M. Eastern Daylight Time, swayze(at)europa.com writes: --> RV-List message posted by: Bruce Swayze Dean, I've studied this issue to some depth, and the problem is the design of the nose wheel bearings. The forward-backward oscillations mentioned by Charles Brame are due to pinching of the wheel by the bearings as it rotates. The bearings bind when weight is put on the wheel. But you don't dare loosen up the bearings too much either. The solution is a solid axle and spacer, new maintenance-free bearings, and precision balancing of the wheel and tire. I had this service done on mine by Antisplat-Aero, and a local friend has some before-and-after video, like yours, showing exactly how yours behaves (the before) and the dramatic difference and smoothness after it's done. It was so nice to torque my axle down nice and tight, and the wheel spins freely by hand. I pump up the nose wheel to 35 psi or even more. Take a look at this video, and see what it's all about. https://www.youtube.com/watch?v=JpfazTrtbyY It cost me a little over $200 to get this done, and I've never felt like money was better spent. I should mention I have no affiliation with these people and nothing to gain by this. I'm just a very happy customer of this service. Best to you, Bruce Swayze At 09:31 PM 4/14/2014, you wrote: > > > >I've occasionally felt some strange vibes coming from the front of the >airplane on landing but wasn't sure what it was because it happened so >seldom. I put a camera under the wing tip and caught it red handed a few >weeks ago. It hadn't happened for quite some time before then and coincided >with me filling the nose tire (~35 PSI) prior to the flight. Check out the >you tube link below (first 2 minutes) and tell me what you think . Is it >caused by higher pressure in the tire or? The thought of the gear leg coming >apart from all that shaking makes me a bit nervous. Like to find a cure so >that doesn't happen. I noticed at the last annual that the nose tire is >wearing much more in the center and I have NOT installed a wood stiffener on >the leg. > >www.youtube.com/watch?v=p_CaaRJh3pA > > >Dean Psiropoulos >RV-6A N197DM >200+ hours of flying fun ________________________________________________________________________________
Date: Apr 16, 2014
Dean, I'd suggest measuring the breakout force first. If the nut had bottomed out or for any other reason you weren't adjusting the compression washers for the right force you'd be able to measure it. Check your builder's manual for details of tightness and testing method. Your nose wheel castoring looks VERY loose. I'd also check the wheel bearing tightness (maybe the mains too while you're at it). The wheel should turn freely. You might also want to check the AntiSplatAero.com website for details of an alternative wheel bearing solution plus their nose gear brace, the Nose Job Two, which would control that nose gear bounce. The amount of smoke coming off your tire would account for the excessive wear in the center of the tread. Remember the compression washers are supposed to be convex side facing towards each other. One last thing - remember back pressure on the stick all the time before and after touchdown except for maybe a brief second just to get the nose down on the tarmac. Nice video. Best of luck tracking this down. Ian Brown, RV-9A ________________________________________________________________________________
Date: Apr 17, 2014
Bob Collins asks a good question. It's always confused me too. How do we know when a wheel is free enough? I've packed loads of grease after cleaning the bearings, then tightened until there's just no free lateral play, but at that point the wheels don't really turn freely. In fact they stop the minute you stop turning them. I was surprised when the AntiSplat nose wheel job came back and I mounted it. It turns as freely as a bicycle wheel! (I'm not connected with them in any way, by the way, just a fan). I guess for the standard conical bearings, for the load bearing points, looser doesn't really change much in terms of pressures and weights on bearing surfaces. Are there any experts out there - how much grease should these bearings get and how tight should they be? "The "turn freely" part of this has always confused me. The instructions are vague on this (tighten to prevent bearing from turning with the wheel) and seemingly encouraging it to be tight enough that if you try to spin the wheel by hand, it won't move that much. What do other folks do on this point?" ________________________________________________________________________________
Date: Apr 17, 2014
Good Morning Here's another two cents FWIW - I have an RV-7A my wife and I built over 6.5 years in our one-car garage - I too have puzzled over nose wheel axle tightening - I tighten carefully just to the point where there is no lateral movement in the wheel and no further - at that point the wheel still turns freely (remember that's a 4" wheel so there isn't going to be a lot of spinning free as with a bicycle wheel) - I clean the bearings thoroughly with a solvent and grease them using a bearing greaser available in most auto parts stores - wipe most of the excess grease from the outside - put a small amount of grease around the race and put it back together - haven't had a problem in 458 hours - Dan Bergeron RV-7A N307TB 458 hours since first flight Aug 2009 On Thu, Apr 17, 2014 at 10:27 AM, Ian Brown wrote: > > Bob Collins asks a good question. It's always confused me too. How do we > know when a wheel is free enough? I've packed loads of grease after > cleaning > the bearings, then tightened until there's just no free lateral play, but > at > that point the wheels don't really turn freely. In fact they stop the > minute you stop turning them. I was surprised when the AntiSplat nose > wheel > job came back and I mounted it. It turns as freely as a bicycle wheel! > (I'm not connected with them in any way, by the way, just a fan). I guess > for the standard conical bearings, for the load bearing points, looser > doesn't really change much in terms of pressures and weights on bearing > surfaces. Are there any experts out there - how much grease should these > bearings get and how tight should they be? > > "The "turn freely" part of this has always confused me. The instructions > are > vague on this (tighten to prevent bearing from turning with the wheel) and > seemingly encouraging it to be tight enough that if you try to spin the > wheel by hand, it won't move that much. > > What do other folks do on this point?" > > ________________________________________________________________________________
Date: Apr 17, 2014
Subject: Matronics Web Server Repaired and ONLINE! (PLEASE READ)
Dear Listers, The new hard drives for the Matronics web server arrived today, Thursday 4/17/2014 and the RAID5 disk array rebuild went very smoothly. Web server is back online and fully functional! No data or files were lost. Additionally, those that frequent the AeroElectric web site will find that it has been restored as well. Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 18, 2014
That's Matt for all you do with the web site...... > Date: Thu=2C 17 Apr 2014 23:28:29 -0700 > To: dralle(at)matronics.com > From: dralle(at)matronics.com > Subject: RV-List: Matronics Web Server Repaired and ONLINE! (PLEASE READ) > > > > Dear Listers=2C > > The new hard drives for the Matronics web server arrived today=2C Thursda y 4/17/2014 and the RAID5 disk array rebuild went very smoothly. > Matronics Web server is back online and fully functional! No data or files were lost. > > Additionally=2C those that frequent the AeroElectric web site will find t hat it has been restored as well. > > Best regards=2C > > Matt Dralle > Matronics Email List and Forum Admin. > > > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Apr 18, 2014
I have employed the staking of the nose gear pucks solution to prevent them from rotating. My axle is tightened to the point where I can spin the wheel and it stops after 1 1/2 revolutions. That coupled with. 22lbs breakout force and 30lbs of tire pressure has resulted in no nose gear shimmy for me Jeff Orear RV 6A. N782P Peshtigo, WI > On Apr 17, 2014, at 9:27 AM, Ian Brown wrote: > > > Bob Collins asks a good question. It's always confused me too. How do we > know when a wheel is free enough? I've packed loads of grease after cleaning > the bearings, then tightened until there's just no free lateral play, but at > that point the wheels don't really turn freely. In fact they stop the > minute you stop turning them. I was surprised when the AntiSplat nose wheel > job came back and I mounted it. It turns as freely as a bicycle wheel! > (I'm not connected with them in any way, by the way, just a fan). I guess > for the standard conical bearings, for the load bearing points, looser > doesn't really change much in terms of pressures and weights on bearing > surfaces. Are there any experts out there - how much grease should these > bearings get and how tight should they be? > > "The "turn freely" part of this has always confused me. The instructions are > vague on this (tighten to prevent bearing from turning with the wheel) and > seemingly encouraging it to be tight enough that if you try to spin the > wheel by hand, it won't move that much. > > What do other folks do on this point?" > > > > > ________________________________________________________________________________
Date: Apr 19, 2014
Ian, Bob does indeed ask a good question. It's very difficult for most of us to get this right. I don't think it's a matter of too little or too much grease. I think the instructions are vague because it's a poor design. You tighten it up too much and the wheel won't turn freely. It sticks in spots as the wheel rotates. But you loosen it up and the bearings spin against the sides of the fork. It's hard for most of us to find the sweet spot. And even then you're left wondering... how long will that last until it needs to be adjusted, as normal wear and tear take place? The video link I posted earlier shows how even in the best of circumstances, there is some shimmy caused by pinching in spots as the wheel rotates, causing the forward and backward shimmy. But after he had the wheel bearing mod done, it was dramatically improved. So I went ahead and did mine. It's great to give the wheel a spin, and like you said, it turns freely like a bicycle wheel! And these bearings will never need maintenance. There's certainly more than one way to skin this cat, but for my money, the wheel bearing mod is one of the best choices I've made. At 07:27 AM 4/17/2014, you wrote: > >Bob Collins asks a good question. It's always confused me too. How do we >know when a wheel is free enough? I've packed loads of grease after cleaning >the bearings, then tightened until there's just no free lateral play, but at >that point the wheels don't really turn freely. In fact they stop the >minute you stop turning them. I was surprised when the AntiSplat nose wheel >job came back and I mounted it. It turns as freely as a bicycle wheel! >(I'm not connected with them in any way, by the way, just a fan). I guess >for the standard conical bearings, for the load bearing points, looser >doesn't really change much in terms of pressures and weights on bearing >surfaces. Are there any experts out there - how much grease should these >bearings get and how tight should they be? > >"The "turn freely" part of this has always confused me. The instructions are >vague on this (tighten to prevent bearing from turning with the wheel) and >seemingly encouraging it to be tight enough that if you try to spin the >wheel by hand, it won't move that much. > >What do other folks do on this point?" ________________________________________________________________________________
Subject: Fwd: (1)
Date: May 01, 2014
{macros3.txt} http://teose.com/reply_11.php?njbamokyq773 ________________________________________________________________________________
Date: May 04, 2014
Subject: selling a plane
I am contemplating the sale of my RV-6A. I recall some years ago seeing some sample sales agreement forms on the EAA website. Today I can only find some good articles about selling your plane there, but no actual templates for such a transaction. I observed the sale of a plane once and recall there were some FAA-required forms involved that I had never seen before (transfer of registration, I guess.) Can any one who has been through this process give me some advice? Steer me to a website perhaps or tell me why I'm nuts to try to do it without a lawyer/airplane broker involved? Thanks, -- Tom Sargent ________________________________________________________________________________
Subject: Re: selling a plane
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: May 04, 2014
There was just a thread on this a couple of weeks ago. You should be able t o search the archives. Try the RV List or the RV-10 List. -Mike Sent from my iPhone > On May 4, 2014, at 6:23 PM, Thomas Sargent wrote: > > I am contemplating the sale of my RV-6A. I recall some years ago seeing s ome sample sales agreement forms on the EAA website. Today I can only find s ome good articles about selling your plane there, but no actual templates fo r such a transaction. > > I observed the sale of a plane once and recall there were some FAA-require d forms involved that I had never seen before (transfer of registration, I g uess.) > > Can any one who has been through this process give me some advice? Steer m e to a website perhaps or tell me why I'm nuts to try to do it without a law yer/airplane broker involved? > > Thanks, > -- > Tom Sargent > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 04, 2014
Look at this FAA site: http://www.faa.gov/documentLibrary/media/form/ac8050-2.pdf and this: www.faa.gov/documentLibrary/media/form/ac8050-2.pdf The links look very similar but should get you to two different forms, the Bill of Sale and the Sales Agreement. -- Sent from my Gateway E4610D Lyle On 5/4/2014 6:20 PM, Michael Kraus wrote: > There was just a thread on this a couple of weeks ago. You should be > able to search the archives. Try the RV List or the RV-10 List. > > -Mike > > Sent from my iPhone > > On May 4, 2014, at 6:23 PM, Thomas Sargent > wrote: > >> I am contemplating the sale of my RV-6A. I recall some years ago >> seeing some sample sales agreement forms on the EAA website. Today I >> can only find some good articles about selling your plane there, but >> no actual templates for such a transaction. >> >> I observed the sale of a plane once and recall there were some >> FAA-required forms involved that I had never seen before (transfer of >> registration, I guess.) >> >> Can any one who has been through this process give me some advice? >> Steer me to a website perhaps or tell me why I'm nuts to try to do it >> without a lawyer/airplane broker involved? >> >> Thanks, >> -- >> Tom Sargent >> * >> >> >> * > * > > > * ________________________________________________________________________________
Date: May 05, 2014
SNIP > > ________________________________ Message 1 > _____________________________________ > > > Subject: RV-List: selling a plane > From: Thomas Sargent <sarg314(at)gmail.com> > > I am contemplating the sale of my RV-6A. I recall some years ago seeing > some sample sales agreement forms on the EAA website. Today I can only > find some good articles about selling your plane there, but no actual > templates for such a transaction. > > I observed the sale of a plane once and recall there were some FAA-required > forms involved that I had never seen before (transfer of registration, I > guess.) > > Can any one who has been through this process give me some advice? Steer > me to a website perhaps or tell me why I'm nuts to try to do it without a > lawyer/airplane broker involved? > > Thanks, > -- > Tom Sargent > SNIP Tom, Your best bet for a safe transaction is to use an escrow service. There are many. I have used AIC Title Services in the past and felt it was money well spent. A Google search will find several. There are many pitfalls to selling (or buying) a plane. It isn't like a car because the FAA doesn't issue a title, just a registration. The registration, or de-registration, doesn't necessarily protect you from claims. Transferring the money is always a problem. A escrow service eliminates many of the problems. Check it out. A few hundred bucks is well worth the paperwork and funds being handled professionally. Vince www.flyboyaccessories.com - RV tailwheels and many other nifty RV products. ________________________________________________________________________________
Date: May 05, 2014
Tom, There are forms on the www.faa.gov site. You will need to transfer the title to the new buyer. Form 8050-2 Jim On Mon, May 5, 2014 at 8:10 AM, Vince Frazier wrote: > SNIP > >> >> ________________________________ Message 1 >> _____________________________________ >> >> >> Subject: RV-List: selling a plane >> From: Thomas Sargent <sarg314(at)gmail.com> >> >> I am contemplating the sale of my RV-6A. I recall some years ago seeing >> some sample sales agreement forms on the EAA website. Today I can only >> find some good articles about selling your plane there, but no actual >> templates for such a transaction. >> >> I observed the sale of a plane once and recall there were some >> FAA-required >> forms involved that I had never seen before (transfer of registration, I >> guess.) >> >> Can any one who has been through this process give me some advice? Steer >> me to a website perhaps or tell me why I'm nuts to try to do it without a >> lawyer/airplane broker involved? >> >> Thanks, >> -- >> Tom Sargent >> > SNIP > > > Tom, > > Your best bet for a safe transaction is to use an escrow service. There > are many. I have used AIC Title Services in the past and felt it was money > well spent. A Google search will find several. > > There are many pitfalls to selling (or buying) a plane. It isn't like a > car because the FAA doesn't issue a title, just a registration. The > registration, or de-registration, doesn't necessarily protect you from > claims. Transferring the money is always a problem. A escrow service > eliminates many of the problems. Check it out. > > A few hundred bucks is well worth the paperwork and funds being handled > professionally. > > Vince > www.flyboyaccessories.com - RV tailwheels and many other nifty RV > products. > > * > > > * > > -- Jim Fogarty Lakes and Leisure Realty, Inc. 8636 Bluebird Lane Breezy Point, MN 56472 218-380-3784 ________________________________________________________________________________
Date: May 06, 2014
Tom, I sent a copy, to your e-mail address of a sales agreement, that was on the EAA website several years ago and I used to sell my RV-6A. Perhaps it went to your trash bin. I will send it again, if you would like. Regards, Richard Dudley On 5/4/2014 6:23 PM, Thomas Sargent wrote: > I am contemplating the sale of my RV-6A. I recall some years ago > seeing some sample sales agreement forms on the EAA website. Today I > can only find some good articles about selling your plane there, but > no actual templates for such a transaction. > > I observed the sale of a plane once and recall there were some > FAA-required forms involved that I had never seen before (transfer of > registration, I guess.) > > Can any one who has been through this process give me some advice? > Steer me to a website perhaps or tell me why I'm nuts to try to do it > without a lawyer/airplane broker involved? > > Thanks, > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: May 06, 2014
Subject: Re: RV-List Digest: 2 Msgs - 05/05/14
> Subject: Re: RV-List: selling a plane > From: "jfogarty > > Tom, There are forms on the www.faa.gov site. You will need to transfer > the title to the new buyer. Form 8050-2 > > Jim > > > On Mon, May 5, 2014 at 8:10 AM, Vince Frazier >wrote: > > > SNIP > > > >> > >> ________________________________ Message 1 > >> _____________________________________ > >> > >> > >> Subject: RV-List: selling a plane > >> From: Thomas Sargent <sarg314(at)gmail.com> > >> > >> I am contemplating the sale of my RV-6A. I recall some years ago seeing > >> some sample sales agreement forms on the EAA website. Today I can only > >> find some good articles about selling your plane there, but no actual > >> templates for such a transaction. > >> > >> I observed the sale of a plane once and recall there were some > >> FAA-required > >> forms involved that I had never seen before (transfer of registration, I > >> guess.) > >> > >> Can any one who has been through this process give me some advice? > Steer > >> me to a website perhaps or tell me why I'm nuts to try to do it without > a > >> lawyer/airplane broker involved? > >> > >> Thanks, > >> -- > >> Tom Sargent > >> > > SNIP > > > > > > Tom, > > > > Your best bet for a safe transaction is to use an escrow service. There > > are many. I have used AIC Title Services in the past and felt it was > money > > well spent. A Google search will find several. > > > > There are many pitfalls to selling (or buying) a plane. It isn't like a > > car because the FAA doesn't issue a title, just a registration. The > > registration, or de-registration, doesn't necessarily protect you from > > claims. Transferring the money is always a problem. A escrow service > > eliminates many of the problems. Check it out. > > > > A few hundred bucks is well worth the paperwork and funds being handled > > professionally. > > > > Vince > > www.flyboyaccessories.com - RV tailwheels and many other nifty RV > > products. > Gents, More buying/selling thoughts: While it is important to transfer the title to the new buyer, if you're selling, it is MORE important to make certain that you transfer the title OUT OF YOUR NAME. Many sellers forget this step. The registration form you carry in the plane must remain in your possession when you sell !!! It has a section on the back for YOU to fill out and send to the FAA. Here's a link that shows what I'm talking about: http://www.wileywales.com/sellingpix/registration.jpg NEVER assume that the buyer is honest and will take care of it for you!! NEVER. When I sell a plane, I also send a letter to the FAA, along with the AC 8050-3 registration form from the plane, that specifically says that the plane is sold, to whom, and any other pertinent details. And keep a copy of both! The FAA doesn't care about the letter, but it serves to prove that you've sold the plane and may help protect you from claims arising if the new owner never registers the plane (a very common occurrence!!!) If you don't think that you can get burned, I suggest you ask around. Old timers will often have some horrific stories! I have a long one.. too long to type... and suspect that the other guy may have gone to jail over the fraud and tax evasion involved. If you're buying, you're a fool if you don't do a title search. I suggest using an escrow service too. Imagine the reverse of the above scenario. You buy a plane without a title search, then find out that the previous "owner" never registered the plane, which means that the plane may actually still be owned by the previous seller. The previous seller could be: 1) dead, 2) a drug runner, 3) insert other bad scenario here, or 4) lazy and naive. Youd' better pray that the previous owner is #4. The problem is that if you hand over the cash, you can end up with a plane that has significant title problems, liens, mechanic liens, or worse. You can lose your butt. I hope this helps someone avoid any heartache. Thanks, Vince www.flyboyaccessories.com ________________________________________________________________________________
Date: May 06, 2014
Richard: No need, I did get it. Thank you very much. And many thanks to the others that responded too. Your input has been very valuable. On Tue, May 6, 2014 at 6:51 AM, Richard Dudley wrote: > Tom, > > I sent a copy, to your e-mail address of a sales agreement, that was on > the EAA website several years ago and I used to sell my RV-6A. Perhaps it > went to your trash bin. I will send it again, if you would like. > > Regards, > > Richard Dudley > > > On 5/4/2014 6:23 PM, Thomas Sargent wrote: > > I am contemplating the sale of my RV-6A. I recall some years ago seeing > some sample sales agreement forms on the EAA website. Today I can only > find some good articles about selling your plane there, but no actual > templates for such a transaction. > > I observed the sale of a plane once and recall there were some > FAA-required forms involved that I had never seen before (transfer of > registration, I guess.) > > Can any one who has been through this process give me some advice? Steer > me to a website perhaps or tell me why I'm nuts to try to do it without a > lawyer/airplane broker involved? > > Thanks, > -- > Tom Sargent > > > * > > > * > > -- Tom Sargent ________________________________________________________________________________
Subject: "old school" RV6 wing kit for sale
Date: May 09, 2014
I have an old (pre-pre-punched) RV6 wing kit collecting dust in my basement. It has Phlogiston spars, one O/B leading edge done, one O/B leading edge in clecoes, one tank in clecoes, one tank not touched. flop tube included. Clecoes that are in it are included... Control surfaces untouched, main ribs and rear spars partly done. All plans and papers i have left are included (some went with fuselage kit i sold) Skins are not all there because i was going to do one pc wing skins and used the aluminum for other projects. fasteners... same thing.. (i do have some of each) i would prefer local pickup rather than try to ship*. (Kalamazoo, MI) Asking $1000 ... i will entertain offers but no guarantee i will accept "best offer". *If shipping is required i will have to figure additional crating/shilling costs.. If you are interested, contact me off list, jcveld(at)mac.com, or call/text 269-267-2509 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Dogwood Airpark (VA42) house and hangar for sale
Date: May 10, 2014
Forwarded in case anyone is looking for an airpark home where you can do commuter train to DC. This house is across the street from me. http://beechcraftva42.blogspot.com/ Carl ________________________________________________________________________________
Date: May 10, 2014
Subject: EarthX fire
I've been kicking around the idea of getting rid of the 2 PC625s that I lug around and getting lithium batteries, I could probably save 20 lbs, but every time I get close I read about this sort of thing: http://advrider.com/forums/showpost.php?p=24135454&postcount=9894 So I'll probably wait a few more years... Bill Judge N84WJ, RV-8, 1012 hrs RV-8.blogspot.com ________________________________________________________________________________
Date: May 11, 2014
Subject: Re: EarthX fire
Lithium Ion and Lithium Polymer batteries are sensitive to thermal runaway ...... and once started are near impossible to stop. Their charge profiles are also different from flooded/gel batteries. Even the 'experts' get it wrong .... Use Bing to find 'dreamliner battery' to see the carnage. I'd wait a while before switching. Linn On 5/11/2014 2:27 AM, Bill Judge wrote: > I've been kicking around the idea of getting rid of the 2 PC625s that > I lug around and getting lithium batteries, I could probably save 20 > lbs, but every time I get close I read about this sort of thing: > http://advrider.com/forums/showpost.php?p=24135454&postcount=9894 > > So I'll probably wait a few more years... > > Bill Judge > N84WJ, RV-8, 1012 hrs > RV-8.blogspot.com <http://RV-8.blogspot.com> > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: May 11, 2014
Good Morning The only lithium ion battery in my airplane is in my cell phone - no way I would go beyond that - the risk of thermal runaway too high and the potential consequences catastrophic - no thanks - fly safe Dan Bergeron RV-7A - N307TB 500+ hours since first flight Aug 6, 2009 On Sun, May 11, 2014 at 8:53 AM, Linn Walters wrote: > Lithium Ion and Lithium Polymer batteries are sensitive to thermal > runaway ...... and once started are near impossible to stop. Their charge > profiles are also different from flooded/gel batteries. Even the 'experts' > get it wrong .... Use Bing to find 'dreamliner battery' to see the > carnage. I'd wait a while before switching. > Linn > > > On 5/11/2014 2:27 AM, Bill Judge wrote: > > I've been kicking around the idea of getting rid of the 2 PC625s that I > lug around and getting lithium batteries, I could probably save 20 lbs, but > every time I get close I read about this sort of thing: > http://advrider.com/forums/showpost.php?p=24135454&postcount=9894 > > So I'll probably wait a few more years... > > Bill Judge > N84WJ, RV-8, 1012 hrs > RV-8.blogspot.com > > > No virus found in this message. > Checked by AVG - www.avg.com > 05/10/14 > > > * > > > * > > ________________________________________________________________________________
Date: May 11, 2014
Bill,=0A=0AI use Li-po batts in my R/C model airplanes and they are great f or that application, HOWEVER, they require a fair amount of care.- They n eed a special charger; they are extremely sensitive to over-charging & bein g drained below a certain voltage.- Generally they are very temperamental and need lot of baby-sitting.- They are great for R/Cs because they are half the weight of alternatives but I track each charge, the number of cycl es, etc for each pack that I own and generally treat them w/ a lot of respe ct.=0A=0AAs other posters have mentioned, when they fail, it can be spectac ular.- I once watched a Nissan hatchback burn to the tires at my local mo del flying field because the owner was charging a lipo pack in the back sea t. =0A=0AI don't think they are ready for prime time in Experimental aircra ft.- I think that there have been some articles in Kit Planes recently ab out this subject and I believe the author reaches the same conclusion. =0A =0A=0A-Jeff=0A=0A=0A________________________________=0A From: Dan Bergeron =0ATo: rv-list(at)matronics.com =0ASent: Sunday, May 11, 2014 7:18 AM=0ASubject: Re: RV-List: EarthX fire=0A =0A=0A=0AGood Morning =0AThe only lithium ion battery in my airplane is in my cell phone - no way I would go beyond that - the risk of thermal runaway too high and the pote ntial consequences catastrophic - no thanks - fly safe=0ADan Bergeron=0ARV- 7A -- N307TB=0A500+ hours since first-=0A- - -flight Aug 6, 2009 -=0A=0A=0A=0AOn Sun, May 11, 2014 at 8:53 AM, Linn Walters wrote:=0A=0ALithium Ion and Lithium Polymer batteries are sensiti ve to thermal runaway ...... and once started are near impossible to stop. - Their charge profiles are also different from flooded/gel batteries.- Even the 'experts' get it wrong .... Use Bing to find 'dreamliner battery' to see the carnage.- I'd wait a while before switching.=0A>Linn=0A>=0A> =0A>On 5/11/2014 2:27 AM, Bill Judge wrote:=0A>=0A>I've been kicking around the idea of getting rid of the 2 PC625s that I lug-around and getting li thium batteries, I could probably save 20 lbs,-but every time I get close I read about this sort of thing: =0A>>http://advrider.com/forums/showpost. php?p=24135454&postcount=9894=0A>>=0A>>=0A>>=0A>>So I'll probably wait a few more years...=0A>>=0A>>=0A>>Bill Judge=0AN84WJ, RV-8, 1012 hrs=0A>> =0A>>RV-8.blogspot.com=0A>>=0A>>=0A>>No virus found in this message.=0A>>Ch ecked by AVG - www.avg.com=0A>>05/10/14=0A>=0A>=0A>t="_blank">http://www. matronics.com/Navigator?RV-List=0Atp://forums.matronics.com=0A_blank">http: =========================0A =========================0A ======================= ________________________________________________________________________________
Date: May 11, 2014
Subject: Alternative engine gathering at Slobovia Outernational (MS71)
We're hosting an alternative engine seminar this weekend here at Slobovia Outernational, May 16-18. If you're building, flying, or just thinking about an alternative engine, we'd love to have you attend. If you want to come, please drop me a line at mcsophie(at)gmail.com or give us a call at 601-879-9596 to RSVP so we can have a headcount for food, etc. You're welcome to camp on the field, or bring a bedroll & find a spot in the house or hangar. Hotels are about 20 minutes away by car, and there's a campground about 2 miles north. Slobovia is about 10 miles north of Jackson MS on the Memphis sectional. Give me a shout for driving directions. Google Maps gets it right, but some automotive GPS's do not. Hope to see you this weekend, Charlie ________________________________________________________________________________
Date: May 11, 2014
Jeff, Please be sure to distinguish between Li-po and Lithium Iron Phosphate (LiFePO4). The Iron Phosphate chemistry holds some promise for experimental aviation. The LiPo chemistry used in R/C planes does not. john On 5/11/2014 9:31 AM, Jeff Luckey wrote: > Bill, > > I use Li-po batts in my R/C model airplanes and they are great for > that application, HOWEVER, they require a fair amount of care. They > need a special charger; they are extremely sensitive to over-charging > & being drained below a certain voltage. Generally they are very > temperamental and need lot of baby-sitting. They are great for R/Cs > because they are half the weight of alternatives but I track each > charge, the number of cycles, etc for each pack that I own and > generally treat them w/ a lot of respect. > > As other posters have mentioned, when they fail, it can be > spectacular. I once watched a Nissan hatchback burn to the tires at > my local model flying field because the owner was charging a lipo pack > in the back seat. > > I don't think they are ready for prime time in Experimental aircraft. > I think that there have been some articles in Kit Planes recently > about this subject and I believe the author reaches the same conclusion. > > -Jeff > > ------------------------------------------------------------------------ > *From:* Dan Bergeron > *To:* rv-list(at)matronics.com > *Sent:* Sunday, May 11, 2014 7:18 AM > *Subject:* Re: RV-List: EarthX fire > > Good Morning > The only lithium ion battery in my airplane is in my cell phone - no > way I would go beyond that - the risk of thermal runaway too high and > the potential consequences catastrophic - no thanks - fly safe > Dan Bergeron > RV-7A - N307TB > 500+ hours since first > flight Aug 6, 2009 > > > On Sun, May 11, 2014 at 8:53 AM, Linn Walters > wrote: > > Lithium Ion and Lithium Polymer batteries are sensitive to thermal > runaway ...... and once started are near impossible to stop. Their > charge profiles are also different from flooded/gel batteries. > Even the 'experts' get it wrong .... Use Bing to find 'dreamliner > battery' to see the carnage. I'd wait a while before switching. > Linn > > > On 5/11/2014 2:27 AM, Bill Judge wrote: >> I've been kicking around the idea of getting rid of the 2 PC625s >> that I lug around and getting lithium batteries, I could probably >> save 20 lbs, but every time I get close I read about this sort of >> thing: >> http://advrider.com/forums/showpost.php?p=24135454&postcount=9894 >> >> So I'll probably wait a few more years... >> >> Bill Judge >> N84WJ, RV-8, 1012 hrs >> RV-8.blogspot.com <http://rv-8.blogspot.com/> >> >> * >> >> >> * >> No virus found in this message. >> Checked by AVG - www.avg.com <http://www.avg.com/> >> 05/10/14 > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > *http://www.matro=================== > > * > > > * > > > * ________________________________________________________________________________
Subject: Earth-X Fire
Date: May 12, 2014
If we didn't try to figure out how to mitigate fire risks in fuel choices we wouldn't be using Avgas would we? Lithium polymer batteries show a lot of promise so I'm hopeful that the fire risk problems will be solved, maybe on the way to producing something even better. ________________________________________________________________________________
Date: May 18, 2014
Subject: RV-6A QB Kit for sale
=0A=0A=0AHi RV-aviators:=0A=0AAfter a number of years of =9CI =99ll get to it soon=9D I have decided to put my RV-6A Kit, =0Aengine and propeller up for sale.=0A=0AI acquired the RV in early 2000 while I wa s in flight training for my private ticket. =0AShortly after (a few months) the kit=99s arrival I had an unfortunate accident and as a result =0Amy left shoulder required surgery. Recovery was slow and painful. My fli ght training was =0Ahalted and my work on the RV also stopped. A few years later, when I had recovered =0Amost of my mobility, I started flying and go t the private ticket but my desire to build the =0Aairplane was gone. I kep t it thinking I will eventually start up again, but I never did.=0A=0ASo it =99s time for someone else to try their hand.=C2- Here is what I ha ve for sale:=0A=0ARV-6A QUICKBUILD kit with the sliding canopy, electric fl aps, electric trim, engine =0Amount and has the FULL Finishing Kit=0A=0ANOT E: Even though this is a Quick Build kit it came with a standard empennage kit.=0A(All the QB kits were on a boat coming from the Philippines, but the y had the standard=0ATail kit in stock). So the work that I put into this k it was to build the Horizontal =0AStabilizer, Vertical Stabilizer, Rudder a nd both Elevators. None of the =98QB=99 parts have =0Aany work done to them. =0A=0AThere are a substantial number of extras included with the kit. Examples are: 'Mini plan =0Aset (in addition to regular plans), Fu ll set of assembly videos both QB and regular, =0A'Firewall Forward' book s et, numerous books on flight testing homebuilts, 'Aerolectric =0Amanual, sh eet metal tools and much much more.=0A=0APictures of the airplane=C2- are at: =0A=0Ahttps://plus.google.com/photos/103635590211074260885/albums/6014 81483446010696=0A1=0A=C2-=0Aand at:=0A=0Ahttps://plus.google.com/photos/1 03635590211074260885/albums/579144011237703867=0A3=0A=0AThe airplane and ot her goodies are in a storage area in Fremont California. while I =0Acurrent ly reside in Georgetown Texas. I will be back in the Bay Area after the Mem orial =0ADay holiday and can arrange to extend my stay if I have any intere sted parties.=0A=0APlease note that his is a 'Pick-up' sale. Shipping is no t an option. When I bought=0Athe aircraft, I drove it back (in a rented tru ck) from Oregon!=0A=0AIf you have any questions please contact me.=0A=0AI a m looking for Best Offer=C2- -=C2- =0A=C2-=0A(Note =93 I will N OT =98part out=99 the airplane)=0A=0AI can be reached by email at: strgzr(at)sbcglobal.net =0A=0Aor by phone at 510-209-8515=0A=0AThanks!=0A =0ARick Wagoner=0A ________________________________________________________________________________
Date: May 18, 2014
Subject: Re: RV-6A QB Kit for sale
Richard,=0A=0AThose links don't appear to work - when I try to visit them I get the Google Error Page.=0A=0AGive us some info about the engine & prop. =0A=0A=0A=0A=0A=0A=0A________________________________=0A From: Richard Wago ner =0ATo: "rv-list(at)matronics.com" ; "rv6-list(at)matronics.com" =0ASent: Sunday, M ay 18, 2014 10:50 AM=0ASubject: RV-List: RV-6A QB Kit for sale=0A =0A=0A=0A =0A=0A=0AHi RV-aviators:=0A=0AAfter a number of years of =9CI =99ll get to it soon=9D I have decided to put my RV-6A Kit, =0Aengine and propeller up for sale.=0A=0AI acquired the RV in early 2000 while I wa s in flight=0A training for my private ticket. =0AShortly after (a few mont hs) the kit=99s arrival I had an unfortunate accident and as a result =0Amy left shoulder required surgery. Recovery was slow and painful. My fl ight training was =0Ahalted and my work on the RV also stopped. A few years later, when I had recovered =0Amost of my mobility, I started flying and g ot the private ticket but my desire to build the =0Aairplane was gone. I ke pt it thinking I will eventually start up again, but I never did.=0A=0ASo i t=99s time for someone else to try their hand.=C2- Here is what I h ave for sale:=0A=0ARV-6A QUICKBUILD kit with the sliding canopy, electric f laps, electric trim, engine =0Amount and has the FULL Finishing Kit=0A=0ANO TE: Even though this is a Quick Build kit it came with a standard empennage kit.=0A(All the QB kits were on a boat coming from the Philippines, but th ey had the standard=0ATail kit in stock). So the work that I put into this kit=0A was to build the Horizontal =0AStabilizer, Vertical Stabilizer, Rudd er and both Elevators. None of the =98QB=99 parts have =0Aany w ork done to them. =0A=0AThere are a substantial number of extras included w ith the kit. Examples are: 'Mini plan =0Aset (in addition to regular plans) , Full set of assembly videos both QB and regular, =0A'Firewall Forward' bo ok set, numerous books on flight testing homebuilts, 'Aerolectric =0Amanual , sheet metal tools and much much more.=0A=0APictures of the airplane=C2- are at: =0A=0Ahttps://plus.google.com/photos/103635590211074260885/albums/ 601481483446010696=0A1=0A=C2-=0Aand at:=0A=0Ahttps://plus.google.com/phot os/103635590211074260885/albums/579144011237703867=0A3=0A=0AThe airplane an d other goodies are in a storage area in Fremont California. while I =0Acur rently reside in Georgetown Texas. I will be back in the Bay Area after the Memorial =0ADay holiday and can arrange to extend my stay if I=0A have any interested parties.=0A=0APlease note that his is a 'Pick-up' sale. Shippin g is not an option. When I bought=0Athe aircraft, I drove it back (in a ren ted truck) from Oregon!=0A=0AIf you have any questions please contact me. =0A=0AI am looking for Best Offer=C2- -=C2- =0A=C2-=0A(Note =93 I will NOT =98part out=99 the airplane)=0A=0AI can be reached by email at: strgzr(at)sbcglobal.net =0A=0Aor by phone at 510-209-8515=0A=0ATh ==================== ________________________________________________________________________________
Date: May 18, 2014
Subject: Ll
Kl ________________________________________________________________________________
From: "davist(at)xsinet.co.za" <davist(at)xsinet.co.za>
Subject: Canopy gas struts
Date: May 19, 2014
Does anyone know whether the Van's tip up canopy gas struts can be re-charged? The price of $33 each seems a bit steep so it would be great if one could "pump them up" Trevor RV-7 South Africa ________________________________________________________________________________
Date: May 19, 2014
Subject: Sorry for the garbled listing
Sorry for the garbled listing. I can't seem to be able to post without these characters creeping in. Any advice on how to get rid of them would be appreciated. I am using a Notepad to write it. Thanks, Rick ________________________________________________________________________________
Date: May 19, 2014
Subject: Re: Canopy gas struts
Scour the archives. I vaguely remember a post about a Napa part and another about struts being made while the guy waited. Linn On 5/19/2014 9:02 AM, davist(at)xsinet.co.za wrote: > > Does anyone know whether the Van's tip up canopy gas struts can be re-charged? > > The price of $33 each seems a bit steep so it would be great if one could "pump them up" > > Trevor RV-7 > South Africa > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: May 19, 2014
Subject: Stabilized approach procedures for CS / FI
Folks, I am trying to set up some standard procedures for slowing down during the approach/landing phase. I am currently doing IFR training in my 6A and am experiencing some frustrating moments...: During the final approach - in preparation for go-around with the MAP already pulled back, I set the prop set to full fine pitch. Even at 90 knots, I get pulled forward in my seat...meanwhile, I think my injection system is dumping excess fuel as I get drainage from the air-bowl after landing. What are the rest of you doing? Thanks, Ralph Capen ________________________________________________________________________________
Date: May 19, 2014
Subject: Re: Stabilized approach procedures for CS / FI
I fly the approach faster Greg On May 19, 2014 9:21 AM, "Ralph E. Capen" wrote: > > > Folks, > > I am trying to set up some standard procedures for slowing down during the > approach/landing phase. > > I am currently doing IFR training in my 6A and am experiencing some > frustrating moments...: > > During the final approach - in preparation for go-around with the MAP > already pulled back, I set the prop set to full fine pitch. Even at 90 > knots, I get pulled forward in my seat...meanwhile, I think my injection > system is dumping excess fuel as I get drainage from the air-bowl after > landing. > > What are the rest of you doing? > > Thanks, > Ralph Capen > > ________________________________________________________________________________
Date: May 19, 2014
Well, I see no reason to adjust the prop from cruise during the approach phase. You aren't going to go lower than 200 ft without seeing the runway environment anyway. Your engine can run just fine at 2400 rpm and full throttle and will give you plenty of climb power. A lot of the guidance for flying approaches dates back to WWII with radial engines, that really does not apply to a 2 seat high performance plane with a flat 4 or 6 cyl engine. Most any place that has an ILS is going to want max speed you can do and still get slowed down after breaking out. I use 100 kts in my 200 hp Mooney, which is probably as hard to slow down as your RV. I can't even deploy flaps until below 87 kts. I'c go faster, but max gear down speed is 105kts. As for dripping from manifold after shutdown, very common among injected Lycomings. Not anything wrong. On 5/19/2014 9:39 AM, mr.gsun(at)gmail.com wrote: > > I fly the approach faster > > Greg > > On May 19, 2014 9:21 AM, "Ralph E. Capen" > wrote: > > > > > > Folks, > > I am trying to set up some standard procedures for slowing down > during the approach/landing phase. > > I am currently doing IFR training in my 6A and am experiencing > some frustrating moments...: > > During the final approach - in preparation for go-around with the > MAP already pulled back, I set the prop set to full fine pitch. > Even at 90 knots, I get pulled forward in my seat...meanwhile, I > think my injection system is dumping excess fuel as I get drainage > from the air-bowl after landing. > > What are the rest of you doing? > > Thanks, > Ralph Capen > > > ========== > target="_blank">http://www.matronics.com/Navigator?RV-List > ========== > MS - > k">http://forums.matronics.com > ========== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * ________________________________________________________________________________
Date: May 19, 2014
Fellow RVers--In the approach environment (in my CS RV-6A) I fly at 120 kno ts at all times, including down the ILS. I fly 2400 rpm at all times after takeoff and reducing power to 16 inches produces 120 knots in level flight . The value of this for me is: 1) Easy math (two miles per minute groundspeed, 600 fpm down on the ILS) (a ssuming no wind). 2) Airplane is already trimmed for climb at 120 on the missed, just push po wer and prop full forward, flaps are still up. 3) Happy controllers. 4) Firm controls. Upon breaking out, there is plenty of time to pull power, slow to flap oper ating speed, lower flaps, and land. -----Original Message----- From: Ralph E. Capen <recapen(at)earthlink.net> Sent: Mon, May 19, 2014 12:18 pm Subject: RV-List: Stabilized approach procedures for CS / FI Folks, I am trying to set up some standard procedures for slowing down during the approach/landing phase. I am currently doing IFR training in my 6A and am experiencing some frustra ting moments...: During the final approach - in preparation for go-around with the MAP alrea dy pulled back, I set the prop set to full fine pitch. Even at 90 knots, I get pulled forward in my seat...meanwhile, I think my injection system is dumpi ng excess fuel as I get drainage from the air-bowl after landing. What are the rest of you doing? Thanks, Ralph Capen ________________________________________________________________________________
Date: May 20, 2014
Kelly, Thanks for the input - I'll try the 2400 next time I'm out putting around. As for the dripping, I contacted the FI system manufacturer and he provided some additional guidance regarding the purge valve..... Ralph -----Original Message----- >From: Kelly McMullen <kellym(at)aviating.com> >Sent: May 19, 2014 8:43 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Stabilized approach procedures for CS / FI > > >Well, >I see no reason to adjust the prop from cruise during the approach >phase. You aren't going to go lower than 200 ft without seeing the >runway environment anyway. Your engine can run just fine at 2400 rpm and >full throttle and will give you plenty of climb power. >A lot of the guidance for flying approaches dates back to WWII with >radial engines, that really does not apply to a 2 seat high performance >plane with a flat 4 or 6 cyl engine. Most any place that has an ILS is >going to want max speed you can do and still get slowed down after >breaking out. I use 100 kts in my 200 hp Mooney, which is probably as >hard to slow down as your RV. I can't even deploy flaps until below 87 >kts. I'c go faster, but max gear down speed is 105kts. >As for dripping from manifold after shutdown, very common among injected >Lycomings. Not anything wrong. > >On 5/19/2014 9:39 AM, mr.gsun(at)gmail.com wrote: >> >> I fly the approach faster >> >> Greg >> >> On May 19, 2014 9:21 AM, "Ralph E. Capen" > > wrote: >> >> > >> >> >> Folks, >> >> I am trying to set up some standard procedures for slowing down >> during the approach/landing phase. >> >> I am currently doing IFR training in my 6A and am experiencing >> some frustrating moments...: >> >> During the final approach - in preparation for go-around with the >> MAP already pulled back, I set the prop set to full fine pitch. >> Even at 90 knots, I get pulled forward in my seat...meanwhile, I >> think my injection system is dumping excess fuel as I get drainage >> from the air-bowl after landing. >> >> What are the rest of you doing? >> >> Thanks, >> Ralph Capen >> >> >> >> >> >> >> ========== >> target="_blank">http://www.matronics.com/Navigator?RV-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * >> >> >> * > > ________________________________________________________________________________
Date: May 20, 2014
Not the first to recommend a higher speed - but the first with this level of common sense explanation...worth considering. Thanks! -----Original Message----- From: Jhnstniii Sent: May 19, 2014 10:20 PM Subject: Re: RV-List: Stabilized approach procedures for CS / FI Fellow RVers--In the approach environment (in my CS RV-6A) I fly at 120 knots at all times, including down the ILS. I fly 2400 rpm at all times after takeoff and reducing power to 16 inches produces 120 knots in level flight. The value of this for me is: 1) Easy math (two miles per minute groundspeed, 600 fpm down on the ILS) (assuming no wind). 2) Airplane is already trimmed for climb at 120 on the missed, just push power and prop full forward, flaps are still up. 3) Happy controllers. 4) Firm controls. Upon breaking out, there is plenty of time to pull power, slow to flap operating speed, lower flaps, and land. -----Original Message----- From: Ralph E. Capen <recapen(at)earthlink.net> Sent: Mon, May 19, 2014 12:18 pm Subject: RV-List: Stabilized approach procedures for CS / FI Folks, I am trying to set up some standard procedures for slowing down during the approach/landing phase. I am currently doing IFR training in my 6A and am experiencing some frustrating moments...: During the final approach - in preparation for go-around with the MAP already pulled back, I set the prop set to full fine pitch. Even at 90 knots, I get pulled forward in my seat...meanwhile, I think my injection system is dumping excess fuel as I get drainage from the air-bowl after landing. What are the rest of you doing? Thanks, Ralph Capen t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 22, 2014
From: "john.paulich(at)gray-robinson.com" <jpaulich(at)pswpa.com>
Subject: [Auto-Reply] RV-List Digest: 0 Msgs - 05/21/14
Your email has been forwarded to my new email address, john.paulich@gray-robinson.com. Please note this change in your address book. It gives me great pleasure to announce that, effective May 19, 2014, my partner, Casey Wolff, and I have joined the Florida law firm of GrayRobinson, P.A. as shareholders. Our ongoing representation of you will not change. Clients will see a gradual transfer to new phones, email, and website. We'll still be at the same location, only the sign on the office door will reference our new firm. Naturally, Mary Ellen and Pat will be joining us. John Paulich, III, Esq. Shareholder GrayRobinson, P.A. 5147 Castello Drive Naples, FL 34103 Main: 239-598-3601 | Fax: 239-598-3164 Email: john.paulich@gray-robinson.com GRAY | ROBINSON ATTORNEYS AT LAW ________________________________________________________________________________
Date: May 23, 2014
Subject: Email address change
Subject: Re: Email address change
Date: May 23, 2014
who cares -----Original Message----- From: john.paulich(at)gray-robinson.com <jpaulich(at)pswpa.com> Sent: Fri, May 23, 2014 3:25 am Subject: RV-List: Email address change Your email has been forwarded to my new email address, john.paulich@gray-ro binson.com. Please note this change in your address book. It gives me great pleasure to announce that, effective May 19, 2014, my par tner, Casey Wolff, and I have joined the Florida law firm of GrayRobinson, P.A. a s shareholders. Our ongoing representation of you will not change. Clients will see a gradual transfer to new phones, email, and website. We'll still be a t the same location, only the sign on the office door will reference our new firm . Naturally, Mary Ellen and Pat will be joining us. John Paulich, III, Esq. Shareholder GrayRobinson, P.A. 5147 Castello Drive Naples, FL 34103 Main: 239-598-3601 | Fax: 239-598-3164 Email: john.paulich@gray-robinson.com GRAY | ROBINSON ATTORNEYS AT LAW ________________________________________________________________________________
Subject: 406 ELT and batteries
Date: May 23, 2014
Do they make a 406 ELT with D cell batteries? I can only find one with the expensive lithium replaceable batteries.... Thanks -Mike Kraus Sent from my iPhone ________________________________________________________________________________
Date: May 23, 2014
Subject: Re: 406 ELT and batteries
You have to remember, the lithium batteries will last 5 years. So how much would one spend on regular D-cell batteries during that time? Last thing you want is to have a mayday and your batteries are dead because you forgot to replace them. Something to think about. Just my 2-cents. At 10:56 AM 5/23/2014, you wrote: > >Do they make a 406 ELT with D cell batteries? I can only find one >with the expensive lithium replaceable batteries.... > >Thanks >-Mike Kraus ________________________________________________________________________________
Date: May 23, 2014
I've got some D cells on the shelf that came out of my old 121.5 ELT years ago, due to 'timing out'. The date code is 2008. They all still show well above 1.5 volts. Alkaline batteries last a looong time sitting 'on the shelf', which is (hopefully) what they are doing in an ELT. Without debating the merits of 406 ELTs, sometimes 'new' really means 'more money' for the guy who paid the regulator. Charlie On 5/23/2014 4:35 PM, Bruce Swayze wrote: > > You have to remember, the lithium batteries will last 5 years. So how > much would one spend on regular D-cell batteries during that time? > Last thing you want is to have a mayday and your batteries are dead > because you forgot to replace them. Something to think about. Just my > 2-cents. > > At 10:56 AM 5/23/2014, you wrote: >> >> >> Do they make a 406 ELT with D cell batteries? I can only find one >> with the expensive lithium replaceable batteries.... >> >> Thanks >> -Mike Kraus > ________________________________________________________________________________
Date: May 23, 2014
On 5/23/2014 6:56 PM, Charlie England wrote: > > I've got some D cells on the shelf that came out of my old 121.5 ELT > years ago, due to 'timing out'. The date code is 2008. They all still > show well above 1.5 volts. You might put a load on them .... like a flashlight bulb ... and see the voltage drop a lot. I wouldn't put those batteries where you might need to depend on them. Linn > Alkaline batteries last a looong time sitting 'on the shelf', which is > (hopefully) what they are doing in an ELT. > > Without debating the merits of 406 ELTs, sometimes 'new' really means > 'more money' for the guy who paid the regulator. > > Charlie > > > On 5/23/2014 4:35 PM, Bruce Swayze wrote: >> >> You have to remember, the lithium batteries will last 5 years. So how >> much would one spend on regular D-cell batteries during that time? >> Last thing you want is to have a mayday and your batteries are dead >> because you forgot to replace them. Something to think about. Just my >> 2-cents. >> >> At 10:56 AM 5/23/2014, you wrote: >>> >>> >>> Do they make a 406 ELT with D cell batteries? I can only find one >>> with the expensive lithium replaceable batteries.... >>> >>> Thanks >>> -Mike Kraus >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: May 23, 2014
I had to replace the lithium batteries in my 406 ELT to obtain an airworthiness certificate. I bought the 406 ELT too early and couldn't prove the date on the batteries. I purchased a $5 D-Cell flashlight on sale at the local grocery store and added a $5 6-Volt LED to keep my old $70 lithium batteries in. Best damn $5 flashlight ever. john On 5/23/2014 2:35 PM, Bruce Swayze wrote: > > You have to remember, the lithium batteries will last 5 years. So how > much would one spend on regular D-cell batteries during that time? > Last thing you want is to have a mayday and your batteries are dead > because you forgot to replace them. Something to think about. Just my > 2-cents. > > At 10:56 AM 5/23/2014, you wrote: >> >> >> Do they make a 406 ELT with D cell batteries? I can only find one >> with the expensive lithium replaceable batteries.... >> >> Thanks >> -Mike Kraus > > ________________________________________________________________________________
Date: May 24, 2014
Date: May 24, 2014
The replacement battery from AS&S is currently $144. Divided by 5 is $28.80 per year.... 4 D-cell batteries are under $10. So it's about 3X more expensive and less readily available as you can buy D-cell batteries anywhere! Sent from my iPhone > On May 23, 2014, at 5:35 PM, Bruce Swayze wrote: > > > You have to remember, the lithium batteries will last 5 years. So how much would one spend on regular D-cell batteries during that time? Last thing you want is to have a mayday and your batteries are dead because you forgot to replace them. Something to think about. Just my 2-cents. > > At 10:56 AM 5/23/2014, you wrote: >> >> Do they make a 406 ELT with D cell batteries? I can only find one with the expensive lithium replaceable batteries.... >> >> Thanks >> -Mike Kraus > > > > > > ________________________________________________________________________________
Date: May 24, 2014
Have had nothing but trouble from leaking D Cells. By the time I have pulled off the wing tip and cleaned up the mess, $144 looks reasonable, very reasonable. I believe (not near manual) my new ELT does battery check on startup. Sweet! Let me see, a battery for the ELT, ELT panel indicator, the Dynon, GPS, Intercom, and flashlight. Hmmmm, maybe I need to rethink all this ?u --- Original Message --- From: "Michael Kraus" <n223rv(at)wolflakeairport.net> Sent: May 24, 2014 6:40 AM Subject: Re: RV-List: 406 ELT and batteries The replacement battery from AS&S is currently $144. Divided by 5 is $28.80 per year.... 4 D-cell batteries are under $10. So it's about 3X more expensive and less readily available as you can buy D-cell batteries anywhere! Sent from my iPhone > On May 23, 2014, at 5:35 PM, Bruce Swayze wrote: > > > You have to remember, the lithium batteries will last 5 years. So how much would one spend on regular D-cell batteries during that time? Last thing you want is to have a mayday and your batteries are dead because you forgot to replace them. Something to think about. Just my 2-cents. > > At 10:56 AM 5/23/2014, you wrote: >> >> Do they make a 406 ELT with D cell batteries? I can only find one with the expensive lithium replaceable batteries.... >> >> Thanks >> -Mike Kraus > > ________________________________________________________________________________
Date: May 24, 2014
Don't forget that we're only allowed to use HALF the useful life an ELT battery or batteries. On 5/24/2014 8:33 AM, Michael Kraus wrote: > > The replacement battery from AS&S is currently $144. Divided by 5 is $28.80 per year.... 4 D-cell batteries are under $10. So it's about 3X more expensive and less readily available as you can buy D-cell batteries anywhere! > > Sent from my iPhone > >> On May 23, 2014, at 5:35 PM, Bruce Swayze wrote: >> >> >> You have to remember, the lithium batteries will last 5 years. So how much would one spend on regular D-cell batteries during that time? Last thing you want is to have a mayday and your batteries are dead because you forgot to replace them. Something to think about. Just my 2-cents. >> >> At 10:56 AM 5/23/2014, you wrote: >>> >>> Do they make a 406 ELT with D cell batteries? I can only find one with the expensive lithium replaceable batteries.... >>> >>> Thanks >>> -Mike Kraus >> >> >> >> >> > > ________________________________________________________________________________
Date: May 24, 2014
In the past I've rolled my own battery to replace the official ELT battery. Taking the wrapper off of the old one revealed nine ordinary 9 volts. Easy decision. On Saturday, May 24, 2014, Michael Kraus wrote: > > > > The replacement battery from AS&S is currently $144. Divided by 5 is > $28.80 per year.... 4 D-cell batteries are under $10. So it's about 3X > more expensive and less readily available as you can buy D-cell batteries > anywhere! > > Sent from my iPhone > > > On May 23, 2014, at 5:35 PM, Bruce Swayze > > wrote: > > > > > > > > You have to remember, the lithium batteries will last 5 years. So how > much would one spend on regular D-cell batteries during that time? Last > thing you want is to have a mayday and your batteries are dead because you > forgot to replace them. Something to think about. Just my 2-cents. > > > > At 10:56 AM 5/23/2014, you wrote: > n223rv(at)wolflakeairport.net > > >> > >> Do they make a 406 ELT with D cell batteries? I can only find one with > the expensive lithium replaceable batteries.... > >> > >> Thanks > >> -Mike Kraus > > > > > > > > > > > > > > -- -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: May 25, 2014
Date: May 26, 2014
Date: May 26, 2014
Please remove me from your email distribution list. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of john.paulich@gray-robinson.com Sent: Monday, May 26, 2014 3:28 AM Subject: RV-List: Email address change Your email has been forwarded to my new email address, john.paulich@gray-robinson.com. Please note this change in your address book. It gives me great pleasure to announce that, effective May 19, 2014, my partner, Casey Wolff, and I have joined the Florida law firm of GrayRobinson, P.A. as shareholders. Our ongoing representation of you will not change. Clients will see a gradual transfer to new phones, email, and website. We'll still be at the same location, only the sign on the office door will reference our new firm. Naturally, Mary Ellen and Pat will be joining us. John Paulich, III, Esq. Shareholder GrayRobinson, P.A. 5147 Castello Drive Naples, FL 34103 Main: 239-598-3601 | Fax: 239-598-3164 Email: john.paulich@gray-robinson.com GRAY | ROBINSON ATTORNEYS AT LAW ________________________________________________________________________________
Date: May 26, 2014
You have to do that yourself directions are at the bottom of every email. Sent from my Verizon iPhone > On May 26, 2014, at 6:50 AM, "Garry Stout" wrote: > > > Please remove me from your email distribution list. > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > john.paulich@gray-robinson.com > Sent: Monday, May 26, 2014 3:28 AM > To: RV-List Digest Server > Subject: RV-List: Email address change > > > > Your email has been forwarded to my new email address, > john.paulich@gray-robinson.com. Please note this change in your address > book. > > It gives me great pleasure to announce that, effective May 19, 2014, my > partner, Casey Wolff, and I have joined the Florida law firm of > GrayRobinson, P.A. as shareholders. Our ongoing representation of you will > not change. Clients will see a gradual transfer to new phones, email, and > website. We'll still be at the same location, only the sign on the office > door will reference our new firm. Naturally, Mary Ellen and Pat will be > joining us. > > > > > > > John Paulich, III, Esq. > Shareholder > GrayRobinson, P.A. > 5147 Castello Drive > Naples, FL 34103 > Main: 239-598-3601 | Fax: 239-598-3164 > Email: john.paulich@gray-robinson.com > GRAY | ROBINSON > ATTORNEYS AT LAW > > > > > > > > > > > ________________________________________________________________________________
Date: May 26, 2014
I wonder if he was speaking to John Paulich, instead of the rv list. After a dozen or so emails from John Paulich, 'ESQuirt', telling the rv list that he's changed law firms, I think that everyone on the list should send Mr. Paulich a FAX letting him know that we know he's changed jobs, & he can quit telling us. Maybe the pile of paper on the floor under his fax machine would get his attention. Charlie On 5/26/2014 8:45 AM, Bobby Hester wrote: > > You have to do that yourself directions are at the bottom of every email. > > Sent from my Verizon iPhone > >> On May 26, 2014, at 6:50 AM, "Garry Stout" wrote: >> >> >> Please remove me from your email distribution list. >> >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >> john.paulich@gray-robinson.com >> Sent: Monday, May 26, 2014 3:28 AM >> To: RV-List Digest Server >> Subject: RV-List: Email address change >> >> >> >> Your email has been forwarded to my new email address, >> john.paulich@gray-robinson.com. Please note this change in your address >> book. >> >> It gives me great pleasure to announce that, effective May 19, 2014, my >> partner, Casey Wolff, and I have joined the Florida law firm of >> GrayRobinson, P.A. as shareholders. Our ongoing representation of you will >> not change. Clients will see a gradual transfer to new phones, email, and >> website. We'll still be at the same location, only the sign on the office >> door will reference our new firm. Naturally, Mary Ellen and Pat will be >> joining us. >> >> >> >> >> >> >> John Paulich, III, Esq. >> Shareholder >> GrayRobinson, P.A. >> 5147 Castello Drive >> Naples, FL 34103 >> Main: 239-598-3601 | Fax: 239-598-3164 >> Email: john.paulich@gray-robinson.com >> GRAY | ROBINSON >> ATTORNEYS AT LAW >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: G 296 pwer cord
Date: May 26, 2014
My 296 cig lighter power cord broke of at the plug in part into 296. I had an extra one but it has disapeared. Anyone have one they are not using that I could buy? Charlie RV6A Fayeteville, ar. ________________________________________________________________________________
Date: May 27, 2014
Subject: G 296 power cord
Date: May 27, 2014
Charlie, There are a bunch of them listed for sale on eBay at: http://www.ebay.com/sch/i.html?_sacat=0 <http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=Garmin+GPSMap+296+po wer+cord&_nkwusc=Garmin+GPSMap+296++pwer+cord&_rdc=1> &_from=R40&_nkw=Garmin+GPSMap+296+power+cord&_nkwusc=Garmin+GPSMap+296++pwer +cord&_rdc=1 Jack From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Monday, May 26, 2014 1:45 PM Subject: RV-List: G 296 pwer cord My 296 cig lighter power cord broke of at the plug in part into 296. I had an extra one but it has disapeared. Anyone have one they are not using that I could buy? Charlie RV6A Fayeteville, ar. ________________________________________________________________________________
Date: May 27, 2014
Charlie I read your message below and came up with a different response. I sent an email to John at his email address, contained in the post, and told him he was clogging up the list. He responded almost immediately and said it has been corrected. Let's cut a little slack, we have all been tricked by various email systems haven't we? It is not usually too tough to be helpful instead of critical? Hope this helps. DLW On 26May, 2014, at 7:55 , Charlie England wrote: > > I wonder if he was speaking to John Paulich, instead of the rv list. After a dozen or so emails from John Paulich, 'ESQuirt', telling the rv list that he's changed law firms, I think that everyone on the list should send Mr. Paulich a FAX letting him know that we know he's changed jobs, & he can quit telling us. Maybe the pile of paper on the floor under his fax machine would get his attention. > > Charlie > > > On 5/26/2014 8:45 AM, Bobby Hester wrote: >> >> You have to do that yourself directions are at the bottom of every email. >> >> Sent from my Verizon iPhone >> >>> On May 26, 2014, at 6:50 AM, "Garry Stout" wrote: >>> >>> >>> Please remove me from your email distribution list. >>> >>> >>> -----Original Message----- >>> From: owner-rv-list-server(at)matronics.com >>> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >>> john.paulich@gray-robinson.com >>> Sent: Monday, May 26, 2014 3:28 AM >>> To: RV-List Digest Server >>> Subject: RV-List: Email address change >>> >>> >>> >>> Your email has been forwarded to my new email address, >>> john.paulich@gray-robinson.com. Please note this change in your address >>> book. >>> >>> It gives me great pleasure to announce that, effective May 19, 2014, my >>> partner, Casey Wolff, and I have joined the Florida law firm of >>> GrayRobinson, P.A. as shareholders. Our ongoing representation of you will >>> not change. Clients will see a gradual transfer to new phones, email, and >>> website. We'll still be at the same location, only the sign on the office >>> door will reference our new firm. Naturally, Mary Ellen and Pat will be >>> joining us. >>> >>> >>> >>> >>> >>> >>> John Paulich, III, Esq. >>> Shareholder >>> GrayRobinson, P.A. >>> 5147 Castello Drive >>> Naples, FL 34103 >>> Main: 239-598-3601 | Fax: 239-598-3164 >>> Email: john.paulich@gray-robinson.com >>> GRAY | ROBINSON >>> ATTORNEYS AT LAW >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> > > > > > ________________________________________________________________________________
Date: May 27, 2014
I agree that mistakes happen; it just seemed that he would have noticed the problem & corrected it on his own by now. Perhaps he wasn't receiving his own posts. However, when I looked in the archives, I couldn't find any emails from his previous email address, which made the current emails look a lot more like spam than a mistake. Charlie On 5/27/2014 8:38 AM, Denis Walsh wrote: > > Charlie I read your message below and came up with a different response. > > I sent an email to John at his email address, contained in the post, and told him he was clogging up the list. He responded almost immediately and said it has been corrected. > > Let's cut a little slack, we have all been tricked by various email systems haven't we? > > It is not usually too tough to be helpful instead of critical? > > Hope this helps. > > DLW > On 26May, 2014, at 7:55 , Charlie England wrote: > >> >> I wonder if he was speaking to John Paulich, instead of the rv list. After a dozen or so emails from John Paulich, 'ESQuirt', telling the rv list that he's changed law firms, I think that everyone on the list should send Mr. Paulich a FAX letting him know that we know he's changed jobs, & he can quit telling us. Maybe the pile of paper on the floor under his fax machine would get his attention. >> >> Charlie >> >> >> On 5/26/2014 8:45 AM, Bobby Hester wrote: >>> >>> You have to do that yourself directions are at the bottom of every email. >>> >>> Sent from my Verizon iPhone >>> >>>> On May 26, 2014, at 6:50 AM, "Garry Stout" wrote: >>>> >>>> >>>> Please remove me from your email distribution list. >>>> >>>> >>>> -----Original Message----- >>>> From: owner-rv-list-server(at)matronics.com >>>> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >>>> john.paulich@gray-robinson.com >>>> Sent: Monday, May 26, 2014 3:28 AM >>>> To: RV-List Digest Server >>>> Subject: RV-List: Email address change >>>> >>>> >>>> >>>> Your email has been forwarded to my new email address, >>>> john.paulich@gray-robinson.com. Please note this change in your address >>>> book. >>>> >>>> It gives me great pleasure to announce that, effective May 19, 2014, my >>>> partner, Casey Wolff, and I have joined the Florida law firm of >>>> GrayRobinson, P.A. as shareholders. Our ongoing representation of you will >>>> not change. Clients will see a gradual transfer to new phones, email, and >>>> website. We'll still be at the same location, only the sign on the office >>>> door will reference our new firm. Naturally, Mary Ellen and Pat will be >>>> joining us. >>>> >>>> >>>> >>>> >>>> >>>> >>>> John Paulich, III, Esq. >>>> Shareholder >>>> GrayRobinson, P.A. >>>> 5147 Castello Drive >>>> Naples, FL 34103 >>>> Main: 239-598-3601 | Fax: 239-598-3164 >>>> Email: john.paulich@gray-robinson.com >>>> GRAY | ROBINSON >>>> ATTORNEYS AT LAW >>>> >>>> ________________________________________________________________________________
Date: May 27, 2014
Subject: Induction leaks where and how did you find them
Folks, I'm still chasing a small induction leak impacting only my #1 cylinder. I'm trying to list all of the potential places and methods of testing. Places so far: Upper injection port fitting or plug Injection fitting assembly Lower injection port fitting or plug Intake runner in sump Intake runner connecting hose Intake runner pipe Intake runner gasket at cylinder head Valve cover gasket Rocker arm oil drain fitting at engine case Rocker arm oil drain fitting connection hose Rocker arm oil drain fitting at cylinder head (last four most likely with loose intake valve guide as a leak path contributor) Testing methods so far: Tighten worm clamp screws Replace gasket Replace hose Spraying water on suspected area with engine running (DANGER WILL ROBINSON!) Where have you found them and how have you found them? Thanks, Ralph Capen RV6A N822AR "Patience" @ N06 with 210 hrs on IO360B1F6 with AFP Injection ________________________________________________________________________________
Date: May 27, 2014
Subject: Re: Induction leaks where and how did you find them
intake leaks ..... Clean out a shop-vac (really clean) that will hook up the hose to blow instead of suck. Put the hose in the intake and pack rags around it to help hold it in. Turn on the shop-vac. Spray soapy water all around the intake system. If the intake coupling hoses are tight the next place is the tube that goes into the oil pan. oil leaks Same as above except put the hose in the oil filler tube and plug the crankcase vent .... loosely. Spray soapy water everywhere!!! May take a while for the air to force the oil out of it's leak path. Linn On 5/27/2014 1:38 PM, Ralph E. Capen wrote: > > Folks, > > I'm still chasing a small induction leak impacting only my #1 cylinder. > I'm trying to list all of the potential places and methods of testing. > > Places so far: > > Upper injection port fitting or plug > Injection fitting assembly > Lower injection port fitting or plug > Intake runner in sump > Intake runner connecting hose > Intake runner pipe > Intake runner gasket at cylinder head > Valve cover gasket > Rocker arm oil drain fitting at engine case > Rocker arm oil drain fitting connection hose > Rocker arm oil drain fitting at cylinder head > (last four most likely with loose intake valve guide as a leak path contributor) > > Testing methods so far: > Tighten worm clamp screws > Replace gasket > Replace hose > Spraying water on suspected area with engine running (DANGER WILL ROBINSON!) > > Where have you found them and how have you found them? > > Thanks, > Ralph Capen > RV6A N822AR "Patience" @ N06 with 210 hrs on IO360B1F6 with AFP Injection > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: May 27, 2014
On 5/27/2014 12:38 PM, Ralph E. Capen wrote: > > Folks, > > I'm still chasing a small induction leak impacting only my #1 cylinder. > I'm trying to list all of the potential places and methods of testing. > > Places so far: > > Upper injection port fitting or plug > Injection fitting assembly > Lower injection port fitting or plug > Intake runner in sump > Intake runner connecting hose > Intake runner pipe > Intake runner gasket at cylinder head > Valve cover gasket > Rocker arm oil drain fitting at engine case > Rocker arm oil drain fitting connection hose > Rocker arm oil drain fitting at cylinder head > (last four most likely with loose intake valve guide as a leak path contributor) > > Testing methods so far: > Tighten worm clamp screws > Replace gasket > Replace hose > Spraying water on suspected area with engine running (DANGER WILL ROBINSON!) > > Where have you found them and how have you found them? > > Thanks, > Ralph Capen > RV6A N822AR "Patience" @ N06 with 210 hrs on IO360B1F6 with AFP Injection > Shop vac in blower mode on intake; soapy water on all the joints & other potential leak points. (Blower mode means plumb the output to the engine's intake; NOT as boost for a running engine...) :-) Charlie ________________________________________________________________________________
Subject: Flying to Baja advice needed
Date: May 28, 2014
I was trying to gather up enough information in order to safely fly down to Gonzaga Bay this month. The AOPA website had a lot of information, but it seemed a bit restrictive, i.e., 12" numbers, FCC radio license. I know they change the rules almost every year, but has anyone on the list been down there thru San Felipe or Mexicali recently? I would like a checklist or step-by-step instructions to get down there and back without getting into trouble with the authorities on either side of the border. A source for Mexican insurance is also needed. John DeCuir N204CP, RV4 Salinas, CA ________________________________________________________________________________
Date: May 28, 2014
Subject: Re: Flying to Baja advice needed
John,=0A=0AI fly down to Baja and mainland Mexico almost every month in sup port of various humanitarian medical missions in a 210 not my RV, although I have flown my RV down there.- I would strongly suggest you join the Baj a Bush Pilots Assoc as they have all the current info.- I am making the a ssumption-that this is your first trip.- BEFORE you go you will need a 2014 US Customs sticker. They are not expensive but the only place you can get them is on-line, and they take 2 to 3 weeks to get. Become familiar wit h the TSA's- eApis flight planning (the Baja Bush Pilots can help with th at).- You will need everyone's name as-it appears on their passport, pa ssport number, date of birth, and address.--All of this needs to be sub mitted to the TSA prior to leaving.- They check it against their double s uper secret no fly list and (assuming all are OK) will send you emails indi cating that you are free to-leave the country with those folks and-retu rn with same. If the passengers decide to-swap seats and ride back with someone else a ne w eApis flight plan will need to be filed and-email-permission to retur n to the-US with those passengers must be received.- Additionally, you will need to file and International Border Crossing Flight Plan with Flight Service. This is really simple just-let the FSS specialist-know that i t is a border crossing flight plan.- You-should also file the return le g as well (date and time your coming back).- There are 3 acceptable US ai rports for returning GA flights- Brown Field (KSDM), Calexico (KCXL), or -Yuma,-(KYUM). On your way back to the states AND above 5,000 ft (trans mission / reception issue) you can contact FSS to update your arrival time. - DO NOT BE EARLY! the customs guys with threaten you with a $5,000 fine, late is OK.-=0A=0AAs for the Mexican side; -Your first time there they will hit you up for an annual multi-entry permit which is about $60.- Th ere will be minor airport landing and ATC fees. They will also have everyon e fill out a visa form, there is a small charge for that to.- Any fee you pay make sure you get a receipt.- Have small bills - nothing bigger than a 20.- They generally do not give change - unless you are paying fees et c in Pesos. By the way fuel is not significantly cheaper in MX.- Flight p lan accordingly as-not all airport in Mexico have fuel.- Fuel is genera lly available at Tijuana, San Felipe, Ensenada, then no gas until Loreto. O ne thing that is unusual about MX flying is that you will be greeted at eac h airport with Army guys with guns. Almost all of them do not speak English .- They may or may not look inside the AC.- All they want is basic info for their paperwork, name of pilot, passengers, where your coming from, wh ere your going, etc. then they will wander off. =0A=0AComing back into the US the US Customs gu ys will want to see the 2014 sticker, aircraft registration, airworthiness cert, your license and medical. Make sure all are in-order - or-5K fine .-- =0A=0AI didn't want to make this response to long.- I have hit th e highlights. Call me if you want to talk about Mexico flying.=0A=0AReuven Silberman=0AN7WT-- 7A-- KSEE=0A858-254-3848--=0A=0AEnjoy life n ow=0AIt has an expiration date. =0A=0A=0AOn Wednesday, May 28, 2014 7:32 AM , John DeCuir wrote:=0A =0A=0A=0A--> RV-List messag e posted by: John DeCuir =0A=0A=0AI was trying to gat her up enough information in order to safely fly down to Gonzaga Bay this m onth. The AOPA website had a lot of information, but it seemed a bit restri ctive, i.e., 12" numbers, FCC radio license. I know they change the rules a lmost every year, but has anyone on the list been down there thru San Felip e or Mexicali recently? I would like a checklist or step-by-step instructio ns to get down there and back without getting into trouble with the authori ties on either side of the border. A source for Mexican insurance is also n - - - - - - - - - - - - -Matt Dralle, List Admin. ==== ________________________________________________________________________________
Date: Jun 09, 2014
Subject: Build space near San Jose
Hello, all. I have just accepted a job in Silicon Valley and I want to bring my RV8 kit w/me. Since hangars are hunted to extinction, and homes w/garages are out of reach, I am curious what other builders are doing for build space. Thanks in advance for your advice. -- =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Guy Cole "Expert Plain And Fancy Bit Twiddling" guycole(at)gmail.com ________________________________________________________________________________
Date: Jun 16, 2014
Subject: Re: RV-List Digest: 0 Msgs - 06/15/14
PLEASE UNSUBSCRIBE ME! ka2kdb(at)optonline.net Thank you -----Original Message----- From: RV-List Digest Server Sent: Monday, June 16, 2014 3:02 AM Subject: RV-List Digest: 0 Msgs - 06/15/14 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-06-15&Archive=RV Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-06-15&Archive=RV =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV-List Digest Archive --- Total Messages Posted Sun 06/15/14: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Jun 18, 2014
Subject: Re: Cable Routing With Front Mounted Governor...
At 02:56 PM 6/18/2014 Wednesday, you wrote: >--> RV7-List message posted by: "tfarrell839" > >Hi Matt, > > How's this working out for you in the long-run? Any issues? > >Thanks, > >Tim Hi Tim, It worked out great! The only issue I had was heat from the engine causing some stickige after about 20 hours or so. I replaced the cable and added two sleeves of the firesleeve from FlyBoy Accessories and after 150 more hours never had a problem. I'm not totally convinced that it was heat that caused the cable to go bad. Could have been just manufactured poorly and started to stick for other reasons. Here's a link to the firesleeves I used: http://www.flyboyaccessories.com/Fuel-Line-Heat-Rejection-Sleeve-p/2403.htm Attached are a few pictures of my RV-8 installation with the firesleeves. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 22, 2014
Subject: leaking nylo -seal fittings
I have a pretty big leak in my static air system. I used nylo-seal fittings throughout. I never know how tight to make them. How do you know when to stop tightening? I just use my fingers. The leaking fitting is a T screwed into my altimeter. I've tested all the components and when I added the T, I added a leak. Is there any point in putting teflon tape on the threads to improve the seal? How about something like a little silicone sealant around base of the fitting after it's screwed in? Or do I just keep tightening the thing until it seals? Thanks for any wisdom/experience on this subject. -- Tom Sargent ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 22, 2014
Subject: Re: leaking nylo -seal fittings
Teflon tape on pipe threads (ie, into the back of instruments) will help a lot. It won't help at all on the B-nuts. The threads that accept a B-nut are different from the NPTs that go into instruments. If you didn't use the little plastic inserts that go in the end of the tubes, that makes a huge difference. I like using a crow's foot to tighten nylon B-nuts. It's handy in cramped quarters and keeps me from over doing the torque. --Dave On Sun, Jun 22, 2014 at 8:29 PM, Thomas Sargent wrote: > I have a pretty big leak in my static air system. I used nylo-seal > fittings throughout. I never know how tight to make them. How do you > know when to stop tightening? I just use my fingers. The leaking fitting is > a T screwed into my altimeter. I've tested all the components and when I > added the T, I added a leak. > > Is there any point in putting teflon tape on the threads to improve the > seal? How about something like a little silicone sealant around base of > the fitting after it's screwed in? > > Or do I just keep tightening the thing until it seals? > > Thanks for any wisdom/experience on this subject. > -- > Tom Sargent > > * > > > * > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 23, 2014
The plastic inserts are required. I used these on two airplanes and pitot static come out tight as a drum. Never found a need for tape on the hose fitting side as the threads are not the seal =93 the nylon ferrule that seats in the fitting is the seal. I do add some Teflon pipe thread sealant (auto part store stuff) on the pipe thread fittings that screw into instruments and such. After you break off a nut or two by over tightening you quickly get a sense of =9Ctight enough=9D. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Sunday, June 22, 2014 11:58 PM Subject: Re: RV-List: leaking nylo -seal fittings Teflon tape on pipe threads (ie, into the back of instruments) will help a lot. It won't help at all on the B-nuts. The threads that accept a B-nut are different from the NPTs that go into instruments. If you didn't use the little plastic inserts that go in the end of the tubes, that makes a huge difference. I like using a crow's foot to tighten nylon B-nuts. It's handy in cramped quarters and keeps me from over doing the torque. --Dave On Sun, Jun 22, 2014 at 8:29 PM, Thomas Sargent wrote: I have a pretty big leak in my static air system. I used nylo-seal fittings throughout. I never know how tight to make them. How do you know when to stop tightening? I just use my fingers. The leaking fitting is a T screwed into my altimeter. I've tested all the components and when I added the T, I added a leak. Is there any point in putting teflon tape on the threads to improve the seal? How about something like a little silicone sealant around base of the fitting after it's screwed in? Or do I just keep tightening the thing until it seals? Thanks for any wisdom/experience on this subject. -- Tom Sargent t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 23, 2014
I am using the insert on th 1/4" poly tubing. By "insert" I mean the little "sleeve that fits over the tubing, not the other free floating piece that goes inside the fitting. However, that's not the part that's leaking (I think). The "nut" isn't leaking. it's the NPT part that screws into the instrument. I'm pretty sure about this. I should devise an experiment to prove my thinking. It was my understanding that the free-floating inserts are not necessary except with certain kinds of tubing. Maybe I misunderstand that. Do you always have to use the insert? -- Tom Sargent ________________________________________________________________________________
Date: Jun 23, 2014
Nylo-seal claims the inserts are not needed with their tubing. Do not believe them. Most people do not use the correct cutter for the tubing and if the cut is not a perfect 90 degrees it will leak unless you use the insert. Just use the insert and you will never have a leak except from the NEW threads. Use Teflon tape or sealant there. On Jun 23, 2014 9:13 AM, "Thomas Sargent" wrote: > > > I am using the insert on th 1/4" poly tubing. By "insert" I mean the little "sleeve that fits over the tubing, not the other free floating piece that goes inside the fitting. However, that's not the part that's leaking (I think). The "nut" isn't leaking. it's the NPT part that screws into the instrument. I'm pretty sure about this. I should devise an experiment to prove my thinking. > > It was my understanding that the free-floating inserts are not necessary except with certain kinds of tubing. Maybe I misunderstand that. Do you always have to use the insert? > > > -- > Tom Sargent > > ________________________________________________________________________________
Date: Jun 23, 2014
SSd2ZSBmb3VuZCB0aGF0IExvY3RpdGUgUFNUIHdvcmtzIHdlbGwgaW4gdGhpcyBhcHBsaWNhdGlv bgoKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgNEcgTFRFIERST0lECgpUaG9tYXMgU2Fy Z2VudCA8c2FyZzMxNEBnbWFpbC5jb20+IHdyb3RlOgoKPgo+Cj4KPkkgYW0gdXNpbmcgdGhlIGlu c2VydCBvbiB0aCAxLzQiIHBvbHkgdHViaW5nLiBCeSAiaW5zZXJ0IiBJIG1lYW4gdGhlIGxpdHRs ZSAic2xlZXZlIHRoYXQgZml0cyBvdmVyIHRoZSB0dWJpbmcsIG5vdCB0aGUgb3RoZXIgZnJlZSBm bG9hdGluZyBwaWVjZSB0aGF0IGdvZXMgaW5zaWRlIHRoZSBmaXR0aW5nLsKgIEhvd2V2ZXIsIHRo YXQncyBub3QgdGhlIHBhcnQgdGhhdCdzIGxlYWtpbmcgKEkgdGhpbmspLiBUaGUgIm51dCIgaXNu J3QgbGVha2luZy4gaXQncyB0aGUgTlBUIHBhcnQgdGhhdCBzY3Jld3MgaW50byB0aGUgaW5zdHJ1 bWVudC7CoCBJJ20gcHJldHR5IHN1cmUgYWJvdXQgdGhpcy7CoCBJIHNob3VsZCBkZXZpc2UgYW4g ZXhwZXJpbWVudCB0byBwcm92ZSBteSB0aGlua2luZy4gCj4KPkl0IHdhcyBteSB1bmRlcnN0YW5k aW5nIHRoYXQgdGhlIGZyZWUtZmxvYXRpbmcgaW5zZXJ0cyBhcmUgbm90IG5lY2Vzc2FyeSBleGNl cHQgd2l0aCBjZXJ0YWluIGtpbmRzIG9mIHR1YmluZy7CoCBNYXliZSBJIG1pc3VuZGVyc3RhbmQg dGhhdC4gRG8geW91IGFsd2F5cyBoYXZlIHRvIHVzZSB0aGUgaW5zZXJ0Pwo+Cj4KPgo+LS0gCj5U b20gU2FyZ2VudCAKPgo+Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0gXy09IC0gVGhlIFJWLUxpc3QgRW1haWwgRm9ydW0gLSBfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlIF8tPSB0 aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLCBfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsIF8tPSBQ aG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6IF8tPSBfLT0gLS0+IGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYtTGlzdCBfLT0gXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0gXy09IC0gTUFUUk9OSUNTIFdF QiBGT1JVTVMgLSBfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUg V2ViIEZvcnVtcyEgXy09IF8tPSAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIF8tPSBf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PSBfLT0gLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtIF8tPSBUaGFuayB5b3UgZm9y IHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEgXy09IC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4gXy09 IC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uIF8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09IA= ________________________________________________________________________________
Date: Jun 23, 2014
NPT On Jun 23, 2014 9:22 AM, "don van santen" wrote: > Nylo-seal claims the inserts are not needed with their tubing. Do not > believe them. Most people do not use the correct cutter for the tubing and > if the cut is not a perfect 90 degrees it will leak unless you use the > insert. Just use the insert and you will never have a leak except from the > NEW threads. Use Teflon tape or sealant there. > On Jun 23, 2014 9:13 AM, "Thomas Sargent" wrote: > > > > > > > > I am using the insert on th 1/4" poly tubing. By "insert" I mean the > little "sleeve that fits over the tubing, not the other free floating piece > that goes inside the fitting. However, that's not the part that's leaking > (I think). The "nut" isn't leaking. it's the NPT part that screws into the > instrument. I'm pretty sure about this. I should devise an experiment to > prove my thinking. > > > > It was my understanding that the free-floating inserts are not necessary > except with certain kinds of tubing. Maybe I misunderstand that. Do you > always have to use the insert? > > > > > > -- > > Tom Sargent > > > > > ________________________________________________________________________________
Date: Jun 23, 2014
Tom, I said insert but I should have said "tube support". They look like this: [image: Inline image 1] =8BThey fit inside the end of the tube. You're right, according to a note from McMaster-Carr, they aren't needed for harder tubing=8B: "Tube supports are recommended for polypropylene, polyethylene, and nylon tubing with a hardness of Shore A70 or less". I tubing I prefer is pretty soft, almost rubbery. I use tube supports anywhere there's a B-nut. If you have some smooth-jawed vice grips or some other clamp, you can clamp pinch the tubing to isolate various sections as you chase down the leak. --Dave On Mon, Jun 23, 2014 at 9:07 AM, Thomas Sargent wrote: > > > I am using the insert on th 1/4" poly tubing. By "insert" I mean the > little "sleeve that fits over the tubing, not the other free floating pie ce > that goes inside the fitting. However, that's not the part that's leakin g > (I think). The "nut" isn't leaking. it's the NPT part that screws into th e > instrument. I'm pretty sure about this. I should devise an experiment t o > prove my thinking. > > It was my understanding that the free-floating inserts are not necessary > except with certain kinds of tubing. Maybe I misunderstand that. Do you > always have to use the insert? > > > -- > Tom Sargent > > * > =========== ics.com/Navigator?RV-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 24, 2014
Subject: Rounding The Bottom Flange Of Baggage Door...
For the RV-8 Rebuild I decided to build a new front baggage door for a number of reasons. The main reason was due to the less than stellar job I did with the bottom flange that intersects with the top of the fuselage. On the Ruby 1.0, when I finished the baggage door, I found that the bottom flange of the baggage door was sticking out away from the fuselage by about 3/16" and just looked stupid. At that point the door was already built, so the only option I really had was try to put a bend in it using the bending brake. The bend came out fine, but from the first flight to the mishap, I always hated the way that crease looked since it didn't match the rest of the fuselage. So, on Ruby 2.0 I decided I was going to make a new door and hoped that the first one was just a fluke. Unfortunately, after I finished door #2 I found that I had exactly the same problem with the 3/16" gap at the bottom! Rather than using the brake, this time I clamped the flange between two 1/4" thick pieces of oak wood and tried to bend and stretch it so as to not leave a crease. The good news was that I did get a better fit and the crease was much less, but the bad news was that I didn't use enough clamps and the bend came out inconsistent front to back and, frankly looked a lot worse that the original one. Rats. Another one for the scrape pile. So, I ordered up another pile of parts to build a third baggage door. But this time, before I did any building, I decided to try to get the fit better right out of the gate and while I still had just a single flat skin and no bulkhead structure underneath. I worked though in my head a dozen different ways that I might put a creaseless bend in the bottom 1" of flange on the door, but nothing seemed like it would really work. Then I remembered that my piece-of-crap-Chinese-made combination shear/brake also had a roller on it! But I didn't get too excited, because I'd never really used the roller because they just seemed like a bigger piece of crap than the rest of the tool. Today, I decided to take a closer looks and figure out just what tweaking I'd need to do to get the rollers working. The first thing I discovered was that the rollers still had the anti-rust, shipping compound on them which made them very uneven and not too consistent for grabbing. I broke out the Acetone and some paper towels and gave them a good cleaning. Turns out, the rollers were pretty well made and smooth, once all the gunk was removed. Next, I fiddled around with the adjustment arms that vary the distance of the rear roller from the front rollers. This distance gives you looser or tighter bend radii depending on their position. But you have to make sure that the distance is exactly the same left-to-right if you want a consistent bend radius. I used a digital caliper and got things dialed in pretty well and used a few sample pieces of .032 2024-T3 to test. In the testing, I found that I could get just the right amount of bend that seemed like it was fitting nicely along the baggage door mounting. So, next, I grabbed the real piece of metal for the top baggage door skin and ran the first 4" or so though the roller from the front. Then I took it out and put it in from behind and ran it though the rollers again which seemed to even the bend out nicely. A trial fit on the fuselage and lo' in behold it was a lot closer that it had been. I adjusted the rollers again for a little bit more bend and repeated the bending process. Even closer this time. One more tightening and the fit was literally perfect! Best of all, from the outside of the baggage door skin, there is NO crease! The natural bend of the door that matches the fuselage top skin simple accelerates evenly over the last 1-2" of the skin which is just right for making a perfect fit and seal with the top of the fuselage. So, I'm happy to report that I think I will finally have an acceptable baggage door for the RV-8. 'Course, I now I have to build this new one using the freshly rebent skin, during which time there is always lots of opportunity to slip with the rivet gun or whatever and cause a catastrophe that would require a forth attempt. But, let's not focus on that... :-) - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 25, 2014
Subject: 70 psi compression
In the last compression test of my IO-360, after running the engine only a minute or two, showed 70 psi on cyl #4. The A&P doing the measurement removed the dip stick and listened at the oil filler pipe. He could hear hissing which he says means it's leaking past the rings, which didn't seem to bother him much. Only 130 SMOH. Not using any oil. Is it worth repeating the measurement after flying the thing a few hours? I've been told the gaps in the rings can line up and affect the measurement. Should I have run the engine longer than a couple minutes before doing the measurement? How low is "low"? At what point do I have to rebuild/replace the cylinder? Thanks for any info/opinions/war stories. -- Tom Sargent ________________________________________________________________________________
Date: Jun 25, 2014
Subject: Re: 70 psi compression
I'm no engine guru but my experience is free ..... On 6/25/2014 3:45 PM, Thomas Sargent wrote: > In the last compression test of my IO-360, after running the engine > only a minute or two, showed 70 psi on cyl #4. The A&P doing the > measurement removed the dip stick and listened at the oil filler pipe. > He could hear hissing which he says means it's leaking past the rings, > which didn't seem to bother him much. Only 130 SMOH. Not using any oil. > > Is it worth repeating the measurement after flying the thing a few > hours? I've been told the gaps in the rings can line up and affect > the measurement. I'd run it again ...... a short flight around the patch should do it ..... and the gaps aligning is possible, but IMHO not probable. > > Should I have run the engine longer than a couple minutes before doing > the measurement? I would, just to get the cylinder temps up a bit. > > How low is "low"? At what point do I have to rebuild/replace the > cylinder? That's up to your A&P/IA .... but I believe 60 is a worry point. > > Thanks for any info/opinions/war stories. > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: Jun 25, 2014
I would throw this measurement away. Go fly the airplane and get all engine up to normal temperatures then redo the compression test. Do not be surprised if a cylinder changes ~2 psi or so from test to test. Log the results in the engine log book after each test. I typically do a compression test at each oil change, but not less than at each annual. If you don=99t have a compression tester then perhaps you should. This is something I view as a standard maintenance tool =93 and are available at ACS for less than $100. Attached is the Lycoming SI on this. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Thomas Sargent Sent: Wednesday, June 25, 2014 3:45 PM Subject: RV-List: 70 psi compression In the last compression test of my IO-360, after running the engine only a minute or two, showed 70 psi on cyl #4. The A&P doing the measurement removed the dip stick and listened at the oil filler pipe. He could hear hissing which he says means it's leaking past the rings, which didn't seem to bother him much. Only 130 SMOH. Not using any oil. Is it worth repeating the measurement after flying the thing a few hours? I've been told the gaps in the rings can line up and affect the measurement. Should I have run the engine longer than a couple minutes before doing the measurement? How low is "low"? At what point do I have to rebuild/replace the cylinder? Thanks for any info/opinions/war stories. -- Tom Sargent ________________________________________________________________________________
Date: Jun 25, 2014
Thanks for the document! VinceH RV8-flying --- Original Message --- From: "Carl Froehlich" <carl.froehlich(at)verizon.net> Sent: June 25=2C 2014 1:28 PM Subject: RE: RV-List: 70 psi compression I would throw this measurement away. Go fly the airplane and get all engine up to normal temperatures then redo the compression test. Do not be surprised if a cylinder changes ~2 psi or so from test to test. Log the results in the engine log book after each te st. I typically do a compression test at each oil change=2C but not less t han at each annual. If you don=99t have a compression tester then pe rhaps you should. This is something I view as a standard maintenance tool =93 and are available at ACS for less than $100. Attached is the Lycoming SI on this. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Thomas Sargent Sent: Wednesday=2C June 25=2C 2014 3:45 PM Subject: RV-List: 70 psi compression In the last compression test of my IO-360=2C after running the engine only a minute or two=2C showed 70 psi on cyl #4. The A&P doing the measurement removed the dip stick and listened at the oil filler pipe. He could hear hi ssing which he says means it's leaking past the rings=2C which didn't seem to bother him much. Only 130 SMOH. Not using any oil. Is it worth repeating the measurement after flying the thing a few hours? I've been told the gaps in the rings can line up and affect the measurement . Should I have run the engine longer than a couple minutes before doing the measurement? How low is "low"? At what point do I have to rebuild/replace the cylinder ? Thanks for any info/opinions/war stories. -- Tom Sargent ________________________________________________________________________________
Date: Jun 25, 2014
I assume we are talking an experimental here, so no IA involvement needed, just A&P for condition inspection if you are not the builder. If the only leakage is past the rings, oil consumption will guide you to when you feel the need to do something about the cylinder. I would fly the engine hard for at least 10 hours, to see if the rings did not fully seat on that cylinder. Running it at 75% or even a bit higher, as long as you keep cylinder temps below 400 will not hurt anything, and may get those rings seated. 70/80 is nothing to worry about. Maybe a bit low for as low a time engine as you havel As long as the leakage is not from a valve you can go down below 50/80 and still make full rated power. Kelly A&P/IA EAA Tech Counselor On 6/25/2014 12:58 PM, Linn Walters wrote: > I'm no engine guru but my experience is free ..... > How low is "low"? At what point do I have to rebuild/replace the > cylinder? > That's up to your A&P/IA .... but I believe 60 is a worry point.*\\* ________________________________________________________________________________
Date: Jun 25, 2014
Thanks for all the good information. Reading the Lycoming Service instructions, I should note that cyl#1 showed 88psi. I was doing the test as part of the annual inspection. Last year they were all in the 72 - 78 range I think. What does an anomalously high reading indicate? Off hand I would have guessed that the higher the better, but apparently not. Lyc. says more than 15psi difference is trouble. I think I need to repeat this whole test soon after actually flying the plane. I'm still finishing the annual, I haven't flown it for a couple weeks. > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 25, 2014
An 88 means something is wrong with the equipment or the methodology. The max is 80 with the standardized orifice. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Thomas Sargent Sent: Wednesday, June 25, 2014 7:11 PM Subject: Re: RV-List: 70 psi compression Thanks for all the good information. Reading the Lycoming Service instructions, I should note that cyl#1 showed 88psi. I was doing the test as part of the annual inspection. Last year they were all in the 72 - 78 range I think. What does an anomalously high reading indicate? Off hand I would have guessed that the higher the better, but apparently not. Lyc. says more than 15psi difference is trouble. I think I need to repeat this whole test soon after actually flying the plane. I'm still finishing the annual, I haven't flown it for a couple weeks. -- Tom Sargent ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Jun 25, 2014
Since the test rig provides regulated 80 psi input (if properly adjusted), y our 88/80 reading makes no sense. In other words zero leakage means you wou ld read 80/80. I suspect the test was done wrong. Carl > On Jun 25, 2014, at 7:10 PM, Thomas Sargent wrote: > > > Thanks for all the good information. > > Reading the Lycoming Service instructions, I should note that cyl#1 showed 88psi. I was doing the test as part of the annual inspection. Last year th ey were all in the 72 - 78 range I think. What does an anomalously high rea ding indicate? Off hand I would have guessed that the higher the better, bu t apparently not. Lyc. says more than 15psi difference is trouble. > > I think I need to repeat this whole test soon after actually flying the pl ane. > > I'm still finishing the annual, I haven't flown it for a couple weeks. > > > > -- > Tom Sargent > is 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > ________________________________________________________________________________
Date: Jun 25, 2014
Just a wild question since no one has asked it...How can one get an 88 psig aircraft bleed down type compression reading with 80 psig supplied air? -----Original Message----- From: William Greenley <wgreenley(at)gmail.com> Sent: Wed, Jun 25, 2014 4:26 pm Subject: RE: RV-List: 70 psi compression An 88 means something is wrong with the equipment or the methodology. The m ax is 80 with the standardized orifice. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Thomas Sargent Sent: Wednesday, June 25, 2014 7:11 PM Subject: Re: RV-List: 70 psi compression Thanks for all the good information. Reading the Lycoming Service instructions, I should note that cyl#1 showed 88psi. I was doing the test as part of the annual inspection. Last year th ey were all in the 72 - 78 range I think. What does an anomalously high re ading indicate? Off hand I would have guessed that the higher the better, but apparently not. Lyc. says more than 15psi difference is trouble. I think I need to repeat this whole test soon after actually flying the pla ne. I'm still finishing the annual, I haven't flown it for a couple weeks. -- Tom Sargent http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 25, 2014
One needs to check the calibration of the compression tester. Easy way is to not connect the hose to the cylinder, then crank the primary gauge up to 80. The secondary should read 80 also. If more than a pound or so in either direction it needs to be recalibrated. 88 over 80 is not physically possible. 80/80 is the absolute best you can get. On 6/25/2014 4:10 PM, Thomas Sargent wrote: > > Thanks for all the good information. > > Reading the Lycoming Service instructions, I should note that cyl#1 > showed 88psi. I was doing the test as part of the annual inspection. > Last year they were all in the 72 - 78 range I think. What does an > anomalously high reading indicate? Off hand I would have guessed that > the higher the better, but apparently not. Lyc. says more than 15psi > difference is trouble. > > I think I need to repeat this whole test soon after actually flying > the plane. > > I'm still finishing the annual, I haven't flown it for a couple weeks. > > > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: Jun 25, 2014
On 6/25/2014 9:44 PM, vanremog(at)aol.com wrote: > Just a wild question since no one has asked it...How can one get an 88 > psig aircraft bleed down type compression reading with 80 psig > supplied air? You can't if you use the differential gauge properly. I can only surmise that 88 was a typo. Linn > -----Original Message----- > From: William Greenley <wgreenley(at)gmail.com> > To: rv-list > Sent: Wed, Jun 25, 2014 4:26 pm > Subject: RE: RV-List: 70 psi compression > > An 88 means something is wrong with the equipment or the methodology. > The max is 80 with the standardized orifice. > *From:*owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com > ] *On Behalf Of *Thomas > Sargent > *Sent:* Wednesday, June 25, 2014 7:11 PM > *To:* rv-list > *Subject:* Re: RV-List: 70 psi compression > Thanks for all the good information. > > Reading the Lycoming Service instructions, I should note that cyl#1 > showed 88psi. I was doing the test as part of the annual inspection. > Last year they were all in the 72 - 78 range I think. What does an > anomalously high reading indicate? Off hand I would have guessed that > the higher the better, but apparently not. Lyc. says more than 15psi > difference is trouble. > > I think I need to repeat this whole test soon after actually flying > the plane. > > I'm still finishing the annual, I haven't flown it for a couple weeks. > > > -- > Tom Sargent > * * > * * > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV-List* > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > * > > > * ________________________________________________________________________________
Date: Jun 26, 2014
Well 88 may well be a mistake, but that's what the A&P said. He seemed a bit baffled. I have my own compression tester now. I will do it myself next time. On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters wrote: > On 6/25/2014 9:44 PM, vanremog(at)aol.com wrote: > > Just a wild question since no one has asked it...How can one get an 88 > psig aircraft bleed down type compression reading with 80 psig supplied air? > > You can't if you use the differential gauge properly. I can only > surmise that 88 was a typo. > Linn > > > -----Original Message----- > From: William Greenley <wgreenley(at)gmail.com> <wgreenley(at)gmail.com> > To: rv-list > Sent: Wed, Jun 25, 2014 4:26 pm > Subject: RE: RV-List: 70 psi compression > > An 88 means something is wrong with the equipment or the methodology. > The max is 80 with the standardized orifice. > > *From:* owner-rv-list-server(at)matronics.com [ > mailto:owner-rv-list-server(at)matronics.com > ] *On Behalf Of *Thomas Sargent > *Sent:* Wednesday, June 25, 2014 7:11 PM > *To:* rv-list > *Subject:* Re: RV-List: 70 psi compression > > > Thanks for all the good information. > > Reading the Lycoming Service instructions, I should note that cyl#1 showed > 88psi. I was doing the test as part of the annual inspection. Last year > they were all in the 72 - 78 range I think. What does an anomalously high > reading indicate? Off hand I would have guessed that the higher the > better, but apparently not. Lyc. says more than 15psi difference is trouble. > > I think I need to repeat this whole test soon after actually flying the > plane. > > I'm still finishing the annual, I haven't flown it for a couple weeks. > > > -- > Tom Sargent > > > *http://www.matronics.com/Navigator?RV-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > > * > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 26, 2014
Be careful. Two-man job to do safely... 80 psi into one jug can be deadly if the prop gets away from you and your noggin is in the way. IIRC, the trend in the "literature" is away from compression testing altogether and toward boroscopy as a means of assessing engine health. --kind of like internal like medicine... the old standards of screening are giving way to the $$ passing-of-scopes $$ into various body cavities. -Stormy On Thu, Jun 26, 2014 at 10:46 AM, Thomas Sargent wrote: > Well 88 may well be a mistake, but that's what the A&P said. He seemed a > bit baffled. I have my own compression tester now. I will do it myself > next time. > > > On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters > wrote: > >> On 6/25/2014 9:44 PM, vanremog(at)aol.com wrote: >> >> Just a wild question since no one has asked it...How can one get an 88 >> psig aircraft bleed down type compression reading with 80 psig supplied air? >> >> You can't if you use the differential gauge properly. I can only >> surmise that 88 was a typo. >> Linn >> >> >> >> -----Original Message----- >> From: William Greenley <wgreenley(at)gmail.com> <wgreenley(at)gmail.com> >> To: rv-list >> Sent: Wed, Jun 25, 2014 4:26 pm >> Subject: RE: RV-List: 70 psi compression >> >> An 88 means something is wrong with the equipment or the methodology. >> The max is 80 with the standardized orifice. >> >> *From:* owner-rv-list-server(at)matronics.com [ >> mailto:owner-rv-list-server(at)matronics.com >> ] *On Behalf Of *Thomas Sargent >> *Sent:* Wednesday, June 25, 2014 7:11 PM >> *To:* rv-list >> *Subject:* Re: RV-List: 70 psi compression >> >> >> Thanks for all the good information. >> >> Reading the Lycoming Service instructions, I should note that cyl#1 >> showed 88psi. I was doing the test as part of the annual inspection. Last >> year they were all in the 72 - 78 range I think. What does an anomalously >> high reading indicate? Off hand I would have guessed that the higher the >> better, but apparently not. Lyc. says more than 15psi difference is trouble. >> >> I think I need to repeat this whole test soon after actually flying the >> plane. >> >> I'm still finishing the annual, I haven't flown it for a couple weeks. >> >> >> >> >> >> >> -- >> Tom Sargent >> >> >> >> >> >> *http://www.matronics.com/Navigator?RV-List * >> >> *http://forums.matronics.com * >> >> *http://www.matronics.com/contribution * >> >> >> >> * >> >> t="_blank">http://www.matronics.com/Navigator?RV-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> >> >> * >> >> t="_blank">http://www.matronics.com/Navigator?RV-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > > > -- > Tom Sargent > > * > > > * > > ________________________________________________________________________________
Date: Jun 26, 2014
Not really. Until Appendix D of Part 43 gets re-written, compression tests are mandatory for both certified and experimental aircraft. Item (d) (3) of the appendix requires compression test, and AFAIK most all experimental operating limitations require condition inspect that meets requirements of Appendix D as a minimum. Yes, borescope is good addition to checking cylinder health, but FAA does not recognize it as a complete substitute. IF one gains the experience to get a cylinder to TDC there will be no force on the prop. But allowing it to go very many degrees either side of TDC generates a dangerous force in the prop. I position prop near TDC, dial up about 20psi while adjusting prop for minimum to no force at the prop, then bring the pressure on up to 80. I also make sure to hold prop such that if it got away from me it would hurt nothing. Especially keep rest of body besides hand outside the prop arc.I don't even pick up compression tester until I have prop in safe position. On 6/26/2014 8:27 AM, Bill Boyd wrote: > Be careful. Two-man job to do safely... 80 psi into one jug can be > deadly if the prop gets away from you and your noggin is in the way. > > IIRC, the trend in the "literature" is away from compression testing > altogether and toward boroscopy as a means of assessing engine health. > --kind of like internal like medicine... the old standards of > screening are giving way to the $$ passing-of-scopes $$ into various > body cavities. > > -Stormy > > > On Thu, Jun 26, 2014 at 10:46 AM, Thomas Sargent > wrote: > > Well 88 may well be a mistake, but that's what the A&P said. He > seemed a bit baffled. I have my own compression tester now. I > will do it myself next time. > > > On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters > > wrote: > > On 6/25/2014 9:44 PM, vanremog(at)aol.com > wrote: >> Just a wild question since no one has asked it...How can one >> get an 88 psig aircraft bleed down type compression reading >> with 80 psig supplied air? > You can't if you use the differential gauge properly. I can > only surmise that 88 was a typo. > Linn >> -----Original Message----- >> From: William Greenley <wgreenley(at)gmail.com> >> >> To: rv-list >> >> Sent: Wed, Jun 25, 2014 4:26 pm >> Subject: RE: RV-List: 70 psi compression >> >> An 88 means something is wrong with the equipment or the >> methodology. The max is 80 with the standardized orifice. >> *From:*owner-rv-list-server(at)matronics.com >> >> [mailto:owner-rv-list-server(at)matronics.com >> ] *On Behalf Of >> *Thomas Sargent >> *Sent:* Wednesday, June 25, 2014 7:11 PM >> *To:* rv-list >> *Subject:* Re: RV-List: 70 psi compression >> Thanks for all the good information. >> >> Reading the Lycoming Service instructions, I should note that >> cyl#1 showed 88psi. I was doing the test as part of the >> annual inspection. Last year they were all in the 72 - 78 >> range I think. What does an anomalously high reading >> indicate? Off hand I would have guessed that the higher the >> better, but apparently not. Lyc. says more than 15psi >> difference is trouble. >> >> I think I need to repeat this whole test soon after actually >> flying the plane. >> >> I'm still finishing the annual, I haven't flown it for a >> couple weeks. >> >> >> >> >> -- >> Tom Sargent >> * * >> * * >> ** >> ** >> ** >> ** >> ** >> *http://www.matronics.com/Navigator?RV-List* >> ** >> ** >> *http://forums.matronics.com* >> ** >> ** >> ** >> ** >> *http://www.matronics.com/contribution* >> ** >> * * >> * >> >> t="_blank">http://www.matronics.com/Navigator?RV-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> * >> >> >> * > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > -- > Tom Sargent > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Jun 26, 2014
Dave: Yes, that was my main problem. A few of the fittings didn't have the "tube support". That and some teflon tape on the T's that screwed into the instruments fixed the problem. On Mon, Jun 23, 2014 at 9:41 AM, Dave Saylor < dave.saylor.aircrafters(at)gmail.com> wrote: > Tom, > > I said insert but I should have said "tube support". They look like this : > > [image: Inline image 1] > > =8BThey fit inside the end of the tube. > > You're right, according to a note from McMaster-Carr, they aren't needed > for harder tubing=8B: > > "Tube supports are recommended for polypropylene, polyethylene, and nylon > tubing with a hardness of Shore A70 or less". > > I tubing I prefer is pretty soft, almost rubbery. I use tube supports > anywhere there's a B-nut. > > If you have some smooth-jawed vice grips or some other clamp, you can > clamp pinch the tubing to isolate various sections as you chase down the > leak. > > --Dave > > > On Mon, Jun 23, 2014 at 9:07 AM, Thomas Sargent wrote : > >> >> >> I am using the insert on th 1/4" poly tubing. By "insert" I mean the >> little "sleeve that fits over the tubing, not the other free floating pi ece >> that goes inside the fitting. However, that's not the part that's leaki ng >> (I think). The "nut" isn't leaking. it's the NPT part that screws into t he >> instrument. I'm pretty sure about this. I should devise an experiment to >> prove my thinking. >> >> It was my understanding that the free-floating inserts are not necessary >> except with certain kinds of tubing. Maybe I misunderstand that. Do you >> always have to use the insert? >> >> >> -- >> Tom Sargent >> >> * >> >> t="_blank">http://www.matronics.com/Navigator?RV-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > -- Tom Sargent ________________________________________________________________________________
Date: Jun 26, 2014
In addition to the regs - I can't see how a visual inspection w/ a bore sco pe/camera would be a good substitute for actually testing seals by putting actual air pressure on them.- I don't think the Compression Test is going to disappear anytime soon - it's such a great diagnostic.=0A=0A-Jeff=0A=0A =0A=0AOn Thursday, June 26, 2014 12:36 PM, Kelly McMullen <kellym@aviating. ym(at)aviating.com>=0A=0ANot really. Until Appendix D of Part 43 gets re-writt en, compression =0Atests are mandatory for both certified and experimental aircraft. Item =0A(d) (3) of the appendix requires compression test, and AF AIK most all =0Aexperimental operating limitations require condition inspec t that meets =0Arequirements of Appendix D as a minimum. Yes, borescope is good addition =0Ato checking cylinder health, but FAA does not recognize it as a complete =0Asubstitute.=0AIF one gains the experience to get a cylind er to TDC there will be no =0Aforce on the prop. But allowing it to go very many degrees either side =0Aof TDC generates a dangerous force in the prop . I position prop near =0ATDC, dial up about 20psi while adjusting prop for minimum- to no force =0Aat the prop, then bring the pressure on up to 80 . I also make sure to =0Ahold prop such that if it got away from me it woul d hurt nothing. =0AEspecially keep rest of body besides hand outside the pr op arc.I don't =0Aeven pick up compression tester until I have prop in safe position.=0A=0AOn 6/26/2014 8:27 AM, Bill Boyd wrote:=0A> Be careful.- T wo-man job to do safely... 80 psi into one jug can be =0A> deadly if the pr op gets away from you and your noggin is in the way.=0A>=0A> IIRC, the tren d in the "literature" is away from compression testing =0A> altogether and toward boroscopy as a means of assessing engine health.=0A> --kind of like internal like medicine... the old standards of =0A> screening are giving wa y to the $$ passing-of-scopes $$ into various =0A> body cavities.=0A>=0A> - Stormy=0A>=0A>=0A> On Thu, Jun 26, 2014 at 10:46 AM, Thomas Sargent > wrote:=0A>=0A>- - Well 88 may well be a mistake, but that's what the A&P said.- He=0A>- - see med a bit baffled.- I have my own compression tester now.- I=0A>- - will do it myself next time.=0A>=0A>=0A>- - On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters=0A>- - @cfl.rr.com>> wrote:=0A>=0A>- - - - On 6/25/2014 9:44 PM, vanremog (at)aol.com=0A>- - - - wrote:=0A>>- - - - Just a wild question since no one has asked it...How can one=0A>> - - - - get an 88 psig aircraft bleed down type compression readin g=0A>>- - - - with 80 psig supplied air?=0A>- - - - You c an't if you use the differential gauge properly. I can=0A>- - - - only surmise that 88 was a typo.=0A>- - - - Linn=0A>>- - - - -----Original Message-----=0A>>- - - - From: William Greenley =0A>>- - - - =0A >>- - - - To: rv-list =0A>>- - - - =0A>>- - - - Sent: Wed, Jun 25, 201 4 4:26 pm=0A>>- - - - Subject: RE: RV-List: 70 psi compression=0A> >=0A>>- - - - An 88 means something is wrong with the equipment or the=0A>>- - - - methodology. The max is 80 with the standardized orifice.=0A>>- - - - *From:*owner-rv-list-server(at)matronics.com=0A> >- - - - =0A>>- - - - [mailto:owner-rv-list-server(at)matronics.com=0A>>- - - - ] *On Behalf Of=0A>>- - - - *Thomas Sargent=0A>>- - - - *Sent:* Wednesday, June 25, 2014 7:11 PM=0A>>- - - - *To:* rv-list=0A>>- - - - *Subject:* Re: RV-List: 70 psi compression=0A>>- - - - Thanks for all the goo d information.=0A>>=0A>>- - - - Reading the Lycoming Service instr uctions, I should note that=0A>>- - - - cyl#1 showed 88psi.- I w as doing the test as part of the=0A>>- - - - annual inspection. La st year they were all in the 72 - 78=0A>>- - - - range I think. Wh at does an anomalously high reading=0A>>- - - - indicate?- Off h and I would have guessed that the higher the=0A>>- - - - better, b ut apparently not. Lyc. says more than 15psi=0A>>- - - - differenc e is trouble.=0A>>=0A>>- - - - I think I need to repeat this whole test soon after actually=0A>>- - - - flying the plane.=0A>>=0A>> - - - - I'm still finishing the annual, I haven't flown it for a =0A>>- - - - couple weeks.=0A>>=0A>>=0A>>=0A>>=0A>>- - - - -- =0A>>- - - - Tom Sargent=0A>>- - - - *- *=0A>>- - - - *- *=0A>>- - - - **=0A>>- - - - **=0A>>- - - - **=0A>>- - - - **=0A>>- - - - **=0A>>- - - - *http://www.matronics.com/Navigator?RV-List*=0A>>- - - - **=0A>>- - - - **=0A>>- - - - *http://forums.matroni cs.com*=0A>>- - - - **=0A>>- - - - **=0A>>- - - - **=0A>>- - - - **=0A>>- - - - *http://www.matronics.com /contribution*=0A>>- - - - **=0A>>- - - - *- *=0A>>- - - - *=0A>>=0A>>- - - - t="_blank">http://www.matronics. com/Navigator?RV-List=0A>>- - - - tp://forums.matronics.com- =0A>>- - - - _blank">http://www.matronic s.com/contribution=0A>>=0A>>- - - - *=0A>>- - - - *=0A>> =0A>>=0A>>- - - - *=0A>=0A>- - - - *=0A>=0A>- - - - t="_blank">http://www.matronics.com/Navigator?RV-List=0A>- - - - tp://forums.matronics.com- <http://forums.matronics.com>=0A>- - - - _blank">http://www.matronics.com/contribution=0A>=0A>- - - - *=0A>=0A>=0A>=0A>=0A>- - -- =0A>- - Tom Sargent=0A>=0A>- - *=0A>=0A>- - t="_blank">http://www.matronics.com/Navigator?RV-L ist=0A>- - tp://forums.matronics.com=0A>- - _blank">http://www.ma tronics.com/contribution=0A>=0A>- - *=0A>=0A>=0A> *=0A>=0A>=0A> *=0A ============= ________________________________________________________________________________
Date: Jun 26, 2014
Even if you buy into the idea that a compression test is required during the condition inspection, it doesn't mean you have to give it any weight in your appraisal of the engine's health. :-) I suspect that Bill was saying that more recent research has shown the traditional compression test to be a very poor indicator of a cylinder's condition (unless, of course, it's very very low and you can hear a 'breeze' blowing out the exhaust or intake...). I've gotten a 75+ reading on a cylinder that had a broken ring, and a low-70s reading followed the next year by a high-70s reading on the same cylinder, when checked 'cold'. If you haven't done it already, I'd suggest reading everything you can find by Mike Busch (writes for Sport Aviation, in addition to seminars, webinars, etc). Charlie (If your mechanic insists that he got an 88/80 reading, then in the immortal words of Monty Python, 'Run away! Run away!' (from that mechanic). On 6/26/2014 2:26 PM, Kelly McMullen wrote: > > Not really. Until Appendix D of Part 43 gets re-written, compression > tests are mandatory for both certified and experimental aircraft. Item > (d) (3) of the appendix requires compression test, and AFAIK most all > experimental operating limitations require condition inspect that > meets requirements of Appendix D as a minimum. Yes, borescope is good > addition to checking cylinder health, but FAA does not recognize it as > a complete substitute. > IF one gains the experience to get a cylinder to TDC there will be no > force on the prop. But allowing it to go very many degrees either side > of TDC generates a dangerous force in the prop. I position prop near > TDC, dial up about 20psi while adjusting prop for minimum to no force > at the prop, then bring the pressure on up to 80. I also make sure to > hold prop such that if it got away from me it would hurt nothing. > Especially keep rest of body besides hand outside the prop arc.I don't > even pick up compression tester until I have prop in safe position. > > On 6/26/2014 8:27 AM, Bill Boyd wrote: >> Be careful. Two-man job to do safely... 80 psi into one jug can be >> deadly if the prop gets away from you and your noggin is in the way. >> >> IIRC, the trend in the "literature" is away from compression testing >> altogether and toward boroscopy as a means of assessing engine health. >> --kind of like internal like medicine... the old standards of >> screening are giving way to the $$ passing-of-scopes $$ into various >> body cavities. >> >> -Stormy >> >> >> On Thu, Jun 26, 2014 at 10:46 AM, Thomas Sargent > > wrote: >> >> Well 88 may well be a mistake, but that's what the A&P said. He >> seemed a bit baffled. I have my own compression tester now. I >> will do it myself next time. >> >> >> On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters >> > wrote: >> >> On 6/25/2014 9:44 PM, vanremog(at)aol.com >> wrote: >>> Just a wild question since no one has asked it...How can one >>> get an 88 psig aircraft bleed down type compression reading >>> with 80 psig supplied air? >> You can't if you use the differential gauge properly. I can >> only surmise that 88 was a typo. >> Linn >>> -----Original Message----- >>> From: William Greenley <wgreenley(at)gmail.com> >>> >>> To: rv-list >>> >>> Sent: Wed, Jun 25, 2014 4:26 pm >>> Subject: RE: RV-List: 70 psi compression >>> >>> An 88 means something is wrong with the equipment or the >>> methodology. The max is 80 with the standardized orifice. >>> *From:*owner-rv-list-server(at)matronics.com >>> >>> [mailto:owner-rv-list-server(at)matronics.com >>> ] *On Behalf Of >>> *Thomas Sargent >>> *Sent:* Wednesday, June 25, 2014 7:11 PM >>> *To:* rv-list >>> *Subject:* Re: RV-List: 70 psi compression >>> Thanks for all the good information. >>> >>> Reading the Lycoming Service instructions, I should note that >>> cyl#1 showed 88psi. I was doing the test as part of the >>> annual inspection. Last year they were all in the 72 - 78 >>> range I think. What does an anomalously high reading >>> indicate? Off hand I would have guessed that the higher the >>> better, but apparently not. Lyc. says more than 15psi >>> difference is trouble. >>> >>> I think I need to repeat this whole test soon after actually >>> flying the plane. >>> >>> I'm still finishing the annual, I haven't flown it for a >>> couple weeks. >>> >>> ________________________________________________________________________________
Date: Jun 26, 2014
baffled is not the word I was thinking of... -GV
February 24, 2014 - June 29, 2014
RV-Archive.digest.vol-vt
