RV-Archive.digest.vol-vu
June 29, 2014 - March 16, 2015
      -----Original Message-----
Sent: Thu, Jun 26, 2014 8:17 am
Subject: Re: 70 psi compression
Well 88 may well be a mistake, but that's what the A&P said. He seemed a b it baffled. I have my own compression tester now. I will do it myself nex t time. On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters wrote : On 6/25/2014 9:44 PM, vanremog(at)aol.com wrote: Just a wild question since no one has asked it...How can one get an 88 psig aircraft bleed down type compression reading with 80 psig supplied air? You can't if you use the differential gauge properly. I can only surmise that 88 was a typo. Linn -----Original Message----- From: William Greenley <wgreenley(at)gmail.com> To: rv-list Sent: Wed, Jun 25, 2014 4:26 pm Subject: RE: RV-List: 70 psi compression An 88 means something is wrong with the equipment or the methodology. The max is 80 with the standardized orific e.
From: owner-rv-list-server(at)matronics.com [mailto:owner-r
v-list-server(at)matronics.com] On Behalf Of Thomas Sargent Sent: Wednesday, June 25, 2014 7:11 PM To: rv-list Subject: Re: RV-List: 70 psi compression Thanks for all the good information. Reading the Lycoming Service instructions, I should note that cyl#1 showed 88psi. I was doing the test as part of the annual inspection. Last year they were all in the 72 - 78 range I think. What does an anomalously high reading indicate? Off hand I would h ave guessed that the higher the better, but apparently n ot. Lyc. says more than 15psi difference is trouble. I think I need to repeat this whole test soon after actually flying the plane. I'm still finishing the annual, I haven't flown it for a couple weeks. -- Tom Sargent http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Tom Sargent ________________________________________________________________________________
Date: Jun 29, 2014
I repeated the measurement myself this afternoon after running the engine until cyl. head temp hit 400 deg. (not hard when it's 105 outside). I got all cylinders between 73 and 76. The guy who did the first, obviously wrong,measurement is definitely an old hand, I don't know what went wrong - I wasn't watching - but something certainly did.. On Thu, Jun 26, 2014 at 3:28 PM, Charlie England wrote: > > Even if you buy into the idea that a compression test is required during > the condition inspection, it doesn't mean you have to give it any weight in > your appraisal of the engine's health. :-) I suspect that Bill was saying > that more recent research has shown the traditional compression test to be > a very poor indicator of a cylinder's condition (unless, of course, it's > very very low and you can hear a 'breeze' blowing out the exhaust or > intake...). > > I've gotten a 75+ reading on a cylinder that had a broken ring, and a > low-70s reading followed the next year by a high-70s reading on the same > cylinder, when checked 'cold'. > > If you haven't done it already, I'd suggest reading everything you can > find by Mike Busch (writes for Sport Aviation, in addition to seminars, > webinars, etc). > > Charlie > (If your mechanic insists that he got an 88/80 reading, then in the > immortal words of Monty Python, 'Run away! Run away!' (from that mechanic). > > > On 6/26/2014 2:26 PM, Kelly McMullen wrote: > >> >> Not really. Until Appendix D of Part 43 gets re-written, compression >> tests are mandatory for both certified and experimental aircraft. Item (d) >> (3) of the appendix requires compression test, and AFAIK most all >> experimental operating limitations require condition inspect that meets >> requirements of Appendix D as a minimum. Yes, borescope is good addition to >> checking cylinder health, but FAA does not recognize it as a complete >> substitute. >> IF one gains the experience to get a cylinder to TDC there will be no >> force on the prop. But allowing it to go very many degrees either side of >> TDC generates a dangerous force in the prop. I position prop near TDC, dial >> up about 20psi while adjusting prop for minimum to no force at the prop, >> then bring the pressure on up to 80. I also make sure to hold prop such >> that if it got away from me it would hurt nothing. Especially keep rest of >> body besides hand outside the prop arc.I don't even pick up compression >> tester until I have prop in safe position. >> >> On 6/26/2014 8:27 AM, Bill Boyd wrote: >> >>> Be careful. Two-man job to do safely... 80 psi into one jug can be >>> deadly if the prop gets away from you and your noggin is in the way. >>> >>> IIRC, the trend in the "literature" is away from compression testing >>> altogether and toward boroscopy as a means of assessing engine health. >>> --kind of like internal like medicine... the old standards of screening >>> are giving way to the $$ passing-of-scopes $$ into various body cavities. >>> >>> -Stormy >>> >>> >>> On Thu, Jun 26, 2014 at 10:46 AM, Thomas Sargent >> > wrote: >>> >>> Well 88 may well be a mistake, but that's what the A&P said. He >>> seemed a bit baffled. I have my own compression tester now. I >>> will do it myself next time. >>> >>> >>> On Wed, Jun 25, 2014 at 8:11 PM, Linn Walters >>> > wrote: >>> >>> On 6/25/2014 9:44 PM, vanremog(at)aol.com >>> wrote: >>> >>>> Just a wild question since no one has asked it...How can one >>>> get an 88 psig aircraft bleed down type compression reading >>>> with 80 psig supplied air? >>>> >>> You can't if you use the differential gauge properly. I can >>> only surmise that 88 was a typo. >>> Linn >>> >>>> -----Original Message----- >>>> From: William Greenley <wgreenley(at)gmail.com> >>>> >>>> To: rv-list >>>> >>>> Sent: Wed, Jun 25, 2014 4:26 pm >>>> Subject: RE: RV-List: 70 psi compression >>>> >>>> An 88 means something is wrong with the equipment or the >>>> methodology. The max is 80 with the standardized orifice. >>>> *From:*owner-rv-list-server(at)matronics.com >>>> >>>> [mailto:owner-rv-list-server(at)matronics.com >>>> ] *On Behalf Of >>>> *Thomas Sargent >>>> *Sent:* Wednesday, June 25, 2014 7:11 PM >>>> *To:* rv-list >>>> *Subject:* Re: RV-List: 70 psi compression >>>> Thanks for all the good information. >>>> >>>> Reading the Lycoming Service instructions, I should note that >>>> cyl#1 showed 88psi. I was doing the test as part of the >>>> annual inspection. Last year they were all in the 72 - 78 >>>> range I think. What does an anomalously high reading >>>> indicate? Off hand I would have guessed that the higher the >>>> better, but apparently not. Lyc. says more than 15psi >>>> difference is trouble. >>>> >>>> I think I need to repeat this whole test soon after actually >>>> flying the plane. >>>> >>>> I'm still finishing the annual, I haven't flown it for a >>>> couple weeks. >>>> >>>> >>>> > > -- Tom Sargent ________________________________________________________________________________
Date: Jun 29, 2014
Subject: Baggage Door Assembly and Lift Strut Install
Continuing the construction of the new, new baggage door for the RV-8, I worked on the hinge at the top and riveted the whole thing together. I am very happy to report that the fit of the door is nearly perfect! Frankly, it is pretty amazing that something made out of bent sheet metal could fit that well. But alas, I'm not complaining. I spent a fair amount of time and a couple of tries on the top hinge to get the bottom edge of the door to line up perfectly with the bottom of the top fuselage skin. The door comes down and lines up perfectly along both the front and back edges as well as along the bottom as previously described. I'm so happy I redid this baggage door no less than three times to finally get a perfect one! Such is that story of this project it seems... The stock front baggage door on the RV-8 doesn't come with any means of holding it open other than your arm. Since I'd already experienced what happens when the latch pins are in the "latched" position and the door suddenly slams shut (dents and scratches), I really wanted to find a nice strut of some kind that would hold the door open, yet be relatively easy to install/replace/use. Some browsing in the McMaster-Carr on-line catalog turned up what turn out to be the absolute *perfect* part for the job. The strut unit is made for tool box lids and has pre-installed mounts on each end that work perfectly on the RV-8 baggage door with no modifications whatsoever. Incredible, really. The best part is that in operation, the strut will securely hold the door open AND closed! Its amazing actually! At about 2" from closed the geometry of the system has nearly zero pressure open/closed and then at the last 1" or so, slightly pulls the door down. Note that the latch pins are still needed to hold the door securely closed. Conversely, after about 3" open, there is enough push in the spring to gently open the door all the way and then hold it open very nicely. If you have an RV-8 and want a baggage door strut, look no further. This is the just ticket: McMaster-Carr Part Number:11615A14 Here is the on-line web page for the part: http://www.mcmaster.com/#11615A14 At $53.00 (circa 2014) its a little pricey, but its stainless steel, a spring - not hydraulic, and did I mention - works PERFECTLY on the RV-8 front baggage door! Buy one now! Next up is mounting the nylon blocks for the latch pins. Who knew this baggage door would turn into such a project! - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: Baggage Door Assembly and Lift Strut Install
Date: Jun 30, 2014
Nice work Matt. Very well done! Dale Ensing On Jun 30, 2014, at 12:06 AM, Matt Dralle wrote: > > Continuing the construction of the new, new baggage door for the RV-8, I worked on the hinge at the top and riveted the whole thing together. I am very happy to report that the fit of the door is nearly perfect! Frankly, it is pretty amazing that something made out of bent sheet metal could fit that well. But alas, I'm not complaining. I spent a fair amount of time and a couple of tries on the top hinge to get the bottom edge of the door to line up perfectly with the bottom of the top fuselage skin. The door comes down and lines up perfectly along both the front and back edges as well as along the bottom as previously described. I'm so happy I redid this baggage door no less than three times to finally get a perfect one! Such is that story of this project it seems... > > The stock front baggage door on the RV-8 doesn't come with any means of holding it open other than your arm. Since I'd already experienced what happens when the latch pins are in the "latched" position and the door suddenly slams shut (dents and scratches), I really wanted to find a nice strut of some kind that would hold the door open, yet be relatively easy to install/replace/use. > > Some browsing in the McMaster-Carr on-line catalog turned up what turn out to be the absolute *perfect* part for the job. The strut unit is made for tool box lids and has pre-installed mounts on each end that work perfectly on the RV-8 baggage door with no modifications whatsoever. Incredible, really. The best part is that in operation, the strut will securely hold the door open AND closed! Its amazing actually! At about 2" from closed the geometry of the system has nearly zero pressure open/closed and then at the last 1" or so, slightly pulls the door down. Note that the latch pins are still needed to hold the door securely closed. Conversely, after about 3" open, there is enough push in the spring to gently open the door all the way and then hold it open very nicely. If you have an RV-8 and want a baggage door strut, look no further. This is the just ticket: > > McMaster-Carr Part Number:11615A14 > > Here is the on-line web page for the part: > > http://www.mcmaster.com/#11615A14 > > At $53.00 (circa 2014) its a little pricey, but its stainless steel, a spring - not hydraulic, and did I mention - works PERFECTLY on the RV-8 front baggage door! Buy one now! > > Next up is mounting the nylon blocks for the latch pins. Who knew this baggage door would turn into such a project! > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (1).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (2).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (3).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (4).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (5).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (6).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (7).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (8).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (9).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (10).jpg> > <2014.06.29 - RV-8 - Rebuild - Front Baggage Door - Assembly & Lift Strut Installation (11).jpg> ________________________________________________________________________________
Subject: running tubing for lift reserve indicator.
Date: Jul 07, 2014
I have had this for a while, had the probe and gauge installed for a while. I am trying to run the tubbing while down for annual. I had planned to use a 3/4 in pvc pipe to put the two tubes thru, cant get it into the wing. tu bes to flexible to thread thru the holes. Any Ideas? This is an RV6A. charlie Heathco --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 07, 2014
Subject: Re: running tubing for lift reserve indicator.
You might try to fix a step drill to the end of the PVC and rotate the PVC slowly so the step drill catches in the hole and lifts the PVC up. Make sure that the step drill is firmly attached .... getting that sucker out of the wing might be a real exercise. You might also try to fix a tapered piece of wood dowel in the end of the PVC ..... anything to lift the PVC up enough to slide through. Linn On 7/7/2014 10:54 AM, cheathco(at)cox.net wrote: > I have had this for a while, had the probe and gauge installed for a > while. I am trying to run the tubbing while down for annual. I had > planned to use a 3/4 in pvc pipe to put the two tubes thru, cant get > it into the wing. tubes to flexible to thread thru the holes. Any > Ideas? This is an RV6A. > charlie Heathco > > > ------------------------------------------------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus > <http://www.avast.com/> protection is active. > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: Lift reserve indicator
Date: Jul 12, 2014
I have run the tubing now for my Kelly Meiste unit, and have a tight fit wh ere thr tubes hook to the probe. I have read that starting point is 50 deg, but kelly's says start at 60 deg. I have an RV6a, anyone on here that has put one on? --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Rusty RV-8 Steel Parts
I sent this email to Van's today. Something to watch out for... >Date: Sun, 13 Jul 2014 11:23:02 -0700 >To: support(at)vansaircraft.com >From: Matt Dralle <dralle(at)matronics.com> >Subject: Rusty RV-8 Steel Parts > > >Dear Van's, > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certain areas, primarily the ones made from the 4130 plate (see attached pictures). This will eventually cause the powder to flake off. > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possible protection from future rust break through. Additionally, the adhesion of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters usually do these steps by default. > >Many builders faced with changing the color of their steel parts will simply choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above. > >FYI. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: Rusty RV-8 Steel Parts
Date: Jul 13, 2014
Go back and look at the archives. I warned about this very issue when Van' s first began this "new" process and no one was interested. The only prope r way to protect steel parts from corrosion by painting (not plating) is b y blasting the surface rust free, applying a well bonded (clean with tooth) , tight (epoxy) sacrificial (chromate) layer and, if you like, a well bonde d (within the required time to crosslink) a good top coat. This has been we ll established. Powder coating is decorative, not protective. -GV -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Sun, Jul 13, 2014 11:31 am Subject: RV-List: Rusty RV-8 Steel Parts I sent this email to Van's today. Something to watch out for... >Date: Sun, 13 Jul 2014 11:23:02 -0700 >To: support(at)vansaircraft.com >From: Matt Dralle <dralle(at)matronics.com> >Subject: Rusty RV-8 Steel Parts > > >Dear Van's, > >I am stripping all of the steel parts on my RV-8 to have them re-powder co ated in a textured black to match the rest of my interior. While stripping, I h ave noticed a couple of things regarding factory powder coating. Perhaps the m ost disturbing was the high build up rust under parts in certain areas, primari ly the ones made from the 4130 plate (see attached pictures). This will event ually cause the powder to flake off. > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparati on such as scuffing and/or phosphating. All of my steel parts will be undergo ing these steps prior to powder coating for the absolute best possible protecti on from future rust break through. Additionally, the adhesion of the powder c oat is significantly better with these additional surface preparations. The co st differential is minimal, since high-end coaters usually do these steps by default. > >Many builders faced with changing the color of their steel parts will simp ly choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons out lined above. > >FYI. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mo de Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jul 13, 2014
I had the same problem back in 2002 and 2003 with the canopy frame for my RV-6, which at that time was the only powder coated part I received. after that I ordered the engine mount bare and painted it myself. Sound like not much has changed with Van's powder coating supplier. Harry Crosby ----- Original Message ----- From: "Dralle, Matt" <dralle(at)matronics.com> Sent: Sunday, July 13, 2014 11:27:09 AM Subject: RV-List: Rusty RV-8 Steel Parts I sent this email to Van's today. Something to watch out for... >Date: Sun, 13 Jul 2014 11:23:02 -0700 >To: support(at)vansaircraft.com >From: Matt Dralle <dralle(at)matronics.com> >Subject: Rusty RV-8 Steel Parts > > >Dear Van's, > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certain areas, primarily the ones made from the 4130 plate (see attached pictures). This will eventually cause the powder to flake off. > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possible protection from future rust break through. Additionally, the adhesion of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters usually do these steps by default. > >Many builders faced with changing the color of their steel parts will simply choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above. > >FYI. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jul 14, 2014
Same here. When I was working on my canopy frame to make it fit, the powder coating cracked and flaked off showing bare metal with a little rust. Made me not a big believer in powder coating, but maybe its OK with the right prep. When I hear people talking about the greatness of powder coating it always brings back memories! This was in about 2003 because my 7A has been flying since 2004. To be honest I scraped off the loose coating, touched it up with a spray can, and have pretty much forgotten about it. Wow! Has it been 10 years? Thanks, Matt for bringing this to Van's attention. I enjoy following your building progress. Dan Hopper N766DH In a message dated 7/13/2014 7:03:07 P.M. Eastern Daylight Time, HCRV6(at)comcast.net writes: I had the same problem back in 2002 and 2003 with the canopy frame for my RV-6, which at that time was the only powder coated part I received. after that I ordered the engine mount bare and painted it myself. Sound like not much has changed with Van's powder coating supplier. Harry Crosby ____________________________________ From: "Dralle, Matt" <dralle(at)matronics.com> Sent: Sunday, July 13, 2014 11:27:09 AM Subject: RV-List: Rusty RV-8 Steel Parts I sent this email to Van's today. Something to watch out for... >Date: Sun, 13 Jul 2014 11:23:02 -0700 >To: support(at)vansaircraft.com >From: Matt Dralle <dralle(at)matronics.com> >Subject: Rusty RV-8 Steel Parts > > >Dear Van's, > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certain areas, primarily the ones made from the 4130 plate (see attached pictures). This will eventually cause the powder to flake off. > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possible protection from future rust break through. Additionally, the adhesion of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters usually do these steps by default. > >Many builders faced with changing the color of their steel parts will simply choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above. > >FYI. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jul 25, 2014
Subject: Brass Insert F63-PT3-25
Hi List,=0A=0AThe brass inserts that come with my kit seem small. It went i nto my tube and won't stay in the brass elbow for the b-nut to secure it in place.-=0A=0AAdvise?=0A=0ARobin=0A ________________________________________________________________________________
Date: Jul 25, 2014
Subject: Re: Brass Insert F63-PT3-25
Well, hard to tell from the picture ..... but the ferrule should fit a little snug in the tube .... if it falls out of the tube when you hold the tube upside down .... either the ferrule is too small or the tube too large. The sleeve should just fit over the tube. Ace has the ferrule .... and more tube .... in the aircraft isle, of course!!! Linn On 7/25/2014 2:12 PM, Robin Hou wrote: > Hi List, > > The brass inserts that come with my kit seem small. It went into my > tube and won't stay in the brass elbow for the b-nut to secure it in > place. > > Advise? > > Robin > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jul 25, 2014
That is the wrong tube. Look for the =BC=94 tubing. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Hou Sent: Friday, July 25, 2014 2:13 PM Subject: RV-List: Brass Insert F63-PT3-25 Hi List, The brass inserts that come with my kit seem small. It went into my tube and won't stay in the brass elbow for the b-nut to secure it in place. Advise? Robin ________________________________________________________________________________
Date: Jul 28, 2014
Hi Robin, If you get the tubing from Vans, it will be .060" wall thickness and the inserts will fit it. The tubing you get locally is usually thinner wall. Dan Hopper RV7A N766DH In a message dated 7/25/2014 4:13:55 P.M. Eastern Daylight Time, carl.froehlich(at)verizon.net writes: That is the wrong tube. Look for the =C2=BC=9D tubing. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Hou Sent: Friday, July 25, 2014 2:13 PM Subject: RV-List: Brass Insert F63-PT3-25 Hi List, The brass inserts that come with my kit seem small. It went into my tube and won't stay in the brass elbow for the b-nut to secure it in place. Advise? Robin ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Aug 10, 2014
Subject: KEVV - Evansville Indiana EAA Chapter 21 Wings and Wheels this
weekend Our Fourth Annual Wings and Wheels event is Saturday, August 16, 2014 We have had over 200 Cruisers at each of our first two Wings and Wheels This year should continue building on our great start. Cruise-In or Fly-In and help us set a new attendance record this year 10:00 AM till 3:00 PM Central time. Tri-State Aero (KEVV), Ramp and Parking Lot. Here are some pics of previous Wings and wheels. Our 2014 Wings and Wheels event will be at Tri-State Aero, Evansville, IN August 16th, 2014. http://www.eaa21.org/WingsandWheels.jpg <http://www.youtube.com/watch?v=ka1Sg7tmULc> http://www.youtube.com/watch?v=ka1Sg7tmULc http://www.eaa21.org/coppermine1/thumbnails.php?album=2 ________________________________________________________________________________
Date: Aug 11, 2014
Subject: Johannsen tip tanks for the RV6A
Anyone (else) flying with a set of these? I have them installed and plumbed in as gravity feed (with check-valves) to the main tanks. I know that the HW guys recommend check-valve-pumps to keep the fuel out there and pump it all in at once - I don't remember if they have gauges built in to their tanks - which might be helpful if you only pump a partial Trying to determine what others have seen as the usable capacity and if there have been any issues with feeding the tips to the mains causing them to dump fuel out the main vents. I have my main vents cut a little shallower than the vents built in to the tip-tanks. I have only used them a couple of times - and only once did I take off with a full fuel load. On a recent flight when I actually used them (full fuel load), I put more fuel in during the refuel evolution than my fuel computer said that I flowed - so I'm thinking I might have dumped some due to over-pressurization. How are your main vents relative to the tip vents? I need to level the plane, block the outlets, and fill them up to see anyway - but I thought I would try to get some feedback... Any experiences will be appreciated! Thanks, Ralph Capen ________________________________________________________________________________
Date: Aug 12, 2014
Subject: Re: Johannsen tip tanks for the RV6A
I have no experience with the tip tanks. But, maybe the capacity of your vent line is less than the expansion volume of your new fuel capacity. Add some more mileage to you vent system. 2 cents. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Mon, Aug 11, 2014 at 9:51 AM, Ralph E. Capen wrote: > > Anyone (else) flying with a set of these? I have them installed and > plumbed in as gravity feed (with check-valves) to the main tanks. I know > that the HW guys recommend check-valve-pumps to keep the fuel out there and > pump it all in at once - I don't remember if they have gauges built in to > their tanks - which might be helpful if you only pump a partial > > Trying to determine what others have seen as the usable capacity and if > there have been any issues with feeding the tips to the mains causing them > to dump fuel out the main vents. I have my main vents cut a little > shallower than the vents built in to the tip-tanks. I have only used them > a couple of times - and only once did I take off with a full fuel load. On > a recent flight when I actually used them (full fuel load), I put more fuel > in during the refuel evolution than my fuel computer said that I flowed - > so I'm thinking I might have dumped some due to over-pressurization. How > are your main vents relative to the tip vents? > > I need to level the plane, block the outlets, and fill them up to see > anyway - but I thought I would try to get some feedback... > > Any experiences will be appreciated! > > Thanks, > Ralph Capen > > ________________________________________________________________________________
Date: Aug 12, 2014
Interesting thought - thanks! -----Original Message----- From: Larry Bowen Sent: Aug 12, 2014 8:18 AM Subject: Re: RV-List: Johannsen tip tanks for the RV6A I have no experience with the tip tanks. But, maybe the capacity of your vent line is less than the expansion volume of your new fuel capacity. Add some more mileage to you vent system. 2 cents. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Mon, Aug 11, 2014 at 9:51 AM, Ralph E. Capen wrote: Anyone (else) flying with a set of these? I have them installed and plumbed in as gravity feed (with check-valves) to the main tanks. I know that the HW guys recommend check-valve-pumps to keep the fuel out there and pump it all in at once - I don't remember if they have gauges built in to their tanks - which might be helpful if you only pump a partial Trying to determine what others have seen as the usable capacity and if there have been any issues with feeding the tips to the mains causing them to dump fuel out the main vents. I have my main vents cut a little shallower than the vents built in to the tip-tanks. I have only used them a couple of times - and only once did I take off with a full fuel load. On a recent flight when I actually used them (full fuel load), I put more fuel in during the refuel evolution than my fuel computer said that I flowed - so I'm thinking I might have dumped some due to over-pressurization. How are your main vents relative to the tip vents? I need to level the plane, block the outlets, and fill them up to see anyway - but I thought I would try to get some feedback... Any experiences will be appreciated! Thanks, Ralph Capen ========== target="_blank">http://www.matronics.com/Navigator?RV-List ========== MS - k">http://forums.matronics.com ========== e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Navaid AP-1 gyro motor
Date: Aug 18, 2014
=0AWell it has finally happened again. The gyro motor on my ancient Navaid Devices wing leveler has burned out. Nava id Devices went TU in 2008 and their proprietary motor (Micr omo 1624L012S692) is no longer available. Does anyone know if these motors are available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) wa s the last to do the repairs before they closed their door s.=0A=0AIs the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada?=0A=0A Comments from those who have gone thru this would be most helpful.=0A=0A-Thx=0A=0AGV=0A ________________________________________________________________________________
Subject: Re: Navaid AP-1 gyro motor
Date: Aug 18, 2014
I have two NAVAID control heads (one I got as a spare) and a servo that I removed from my RV-8A. I replaced it with a Dynon Skyview and Autopil ot. I have been planning to put them on EBAY, but haven=92t gotten around to it. Are you interested? Thanks, Tom On Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote: > Well it has finally happened again. The gyro motor on my ancient Nava id Devices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer availabl e. Does anyone know if these motors are available elsewhere in someone' s stash? I heard that one of the Navaid people (Horace, I think) was th e last to do the repairs before they closed their doors. > > Is the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada? > > Comments from those who have gone thru this would be most helpful. > > -Thx > > GV > > ======================== ============ ======================== ============ ======================== ============ ======================== ============ > > > > ____________________________________________________________ > ____________________________________________________________ Fast, Secure, NetZero 4G Mobile Broadband. Try it. http://www.netzero.net/?refcd=NZINTISP0512T4GOUT2 ________________________________________________________________________________
Date: Aug 18, 2014
GV, The same thing happened to me on the way to OSH two years ago. I bought a T rio head while there and installed it after I got home, using the old Navai d servo. The Trio works OK and has some features that were not available in the Navaid, but it has an annoying tendency that I have never been able to trim out of hunting back and forth around the GPS course. If I could have obtained a new motor for the Navaid I would have gone that way and been com pletely satisfied (until it died again). The Trio folks insist that the pro blem is because the servo is mounted under the passenger seat, just like yo urs, and that they highly recommend mounting the servo in the wing tip. Bot tom line is you will probably be happy if you go with a Trio and use the ol d servo like I did, and just as happy if you find a replacement motor. Harry Crosby ----- Original Message ----- From: "Thomas Doran" <dorante(at)juno.com> Sent: Monday, August 18, 2014 3:58:20 PM Subject: Re: RV-List: Navaid AP-1 gyro motor I have two NAVAID control heads (one I got as a spare) and a servo that I r emoved from my RV-8A. I replaced it with a Dynon Skyview and Autopilot. I have been planning to put them on EBAY, but haven=99t gotten around to it. Are you interested? Thanks, Tom On Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote: Well it has finally happened again. The gyro motor on my ancient Navaid Dev ices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. Does anyon e know if these motors are available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) was the last to do the repa irs before they closed their doors. Is the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada? Comments from those who have gone thru this would be most helpful. -Thx GV href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.co m/Navigator?RV-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution ____________________________________________________________ === ________________________________________________________________________________
Date: Aug 18, 2014
=0ATom-=0A =0AI maybe interested if I strike out with MIcromo. I'm still pursuing the replacement motor until they say no. It's the Scotsman in me that hates to throw away ha rdware without attempting to fix it first.=0A =0AAt that point it becomes a "throwing good money after bad" situation and like Rocketman (Harry Crosby) wisely says "it'll only be good until next time".=0A =0AI will wait a week or so before ch oosing a path.=0A =0A-GV=0A =0A =0A-----Original Message-----=0AFrom : Thomas Doran =0ATo: rv-list =0ASent: Mon, Aug 18, 2014 4:00 pm=0ASubject: Re: RV-List: Na vaid AP-1 gyro motor=0A=0A=0A=0A=0A=0AI have two NAVAID control heads (one I got as a spare) and a servo that I removed from my RV-8A. I replaced it with a Dynon Skyview and A utopilot.=0A=0A=0AI have been planning to put them on EBAY, bu t haven=99t gotten around to it.=0A=0A=0AAre you interested? =0A=0A=0AThanks, =0A=0A=0A=0A=0ATom=0A=0A=0A=0A=0AOn Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:=0A=0A=0AWell it has f inally happened again. The gyro motor on my ancient Navaid Devices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. Does anyone know if these motors ar e available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) was the last to do the repairs before they closed their doors.=0A =0AIs the right solution to go with the Trio head and keep the Navaid S 1 servo or replace the whole enchilada?=0A =0AComments from th ose who have gone thru this would be most helpful.=0A =0A-Th x=0A =0AGV=0A=0A=0Ahref="http://www.matronics.com/Navigator?RV-List">http:// www.matronics.com/Navigator?RV-List=0Ahref="http://forums.matronics.com/">http ://forums.matronics.com=0Ahref="http://www.matronics.com/contribution">http:// www.matronics.com/contribution=0A=0A=0A=0A=0A___________________________________ =========================== =========================== =========================== -Matt Dralle, Li =========================== =========================== =====0A=0A=0A=0A ________________________________________________________________________________
Date: Aug 18, 2014
Harry: I did the same as you. I can dampen out the hunting by adding some aileron trim bias to one side. (Turn manual aileron trim as far as it will go to one side.) The load on the control helps with hunting. Gary: There is a thread on VAF about the motor replacement. http://www.vansairforce.com/community/showthread.php?t=38078 I recommend reading post #5. It says almost any motor can be used as a replacement but stated that the Micromo was the longest lasting. There is a link to a less expensive item on eBay. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C900+ Flying Hours Pennsylvania=2C USA On 08-18-2014=2C 7:24 PM=2C HCRV6(at)comcast.net wrote: > GV=2C > > The same thing happened to me on the way to OSH two years ago. I > bought a Trio head while there and installed it after I got home=2C > using the old Navaid servo. The Trio works OK and has some features > that were not available in the Navaid=2C but it has an annoying tendency > that I have never been able to trim out of hunting back and forth > around the GPS course. If I could have obtained a new motor for the > Navaid I would have gone that way and been completely satisfied (until > it died again). The Trio folks insist that the problem is because the > servo is mounted under the passenger seat=2C just like yours=2C and that > they highly recommend mounting the servo in the wing tip. Bottom line > is you will probably be happy if you go with a Trio and use the old > servo like I did=2C and just as happy if you find a replacement motor. > > Harry Crosby > > ------------------------------------------------------------------------ > *From: *"Thomas Doran" <dorante(at)juno.com> > *To: *"RV-List" > *Sent: *Monday=2C August 18=2C 2014 3:58:20 PM > *Subject: *Re: RV-List: Navaid AP-1 gyro motor > > > I have two NAVAID control heads (one I got as a spare) and a servo > that I removed from my RV-8A. I replaced it with a Dynon Skyview and > Autopilot. > > I have been planning to put them on EBAY=2C but haven=99t gotten ar ound to it. > > Are you interested? > > Thanks=2C > > > Tom > > > On Aug 18=2C 2014=2C at 12:56 PM=2C vanremog(at)aol.com > wrote: > > Well it has finally happened again. The gyro motor on my ancient > Navaid Devices wing leveler has burned out. Navaid Devices went > TU in 2008 and their proprietary motor (Micromo 1624L012S692) is > no longer available. Does anyone know if these motors are > available elsewhere in someone's stash? I heard that one of the > Navaid people (Horace=2C I think) was the last to do the repairs > before they closed their doors. > > Is the right solution to go with the Trio head and keep the Navaid > S1 servo or replace the whole enchilada? > > Comments from those who have gone thru this would be most helpful. > > -Thx > > GV > > * > > href="http://www.matronics.com/Navigator?RV-List">http://www.matron ics.com/Navigator?RV-List > href="http://forums.matronics.com/">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.c om/contribution > > * > > > ____________________________________________________________ > > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > * > =========== =========== =========== =========== > > * ________________________________________________________________________________
Date: Aug 18, 2014
=0AGary-=0A =0AYeah, I read that thread and that post in par ticular and am looking into it. Once again I prefer to restore the AP-1 to it's original condition so my preferenc e is to get the same motor. I am not an expert in e lectric motors so am underqualified to select a suitable equiv alent. For example with my limited knowledge I would have preferred a brushless DC motor whereas this one is brush typ e, so I'm already unclear as to what the original selection criteria were.=0A =0A-GV=0A =0A-----Original Message-----=0AFrom: Gary A. Sobek =0ATo: rv-list =0ASent: Mon, Aug 18, 2014 4:50 pm=0ASubject: Re: RV-List: Na vaid AP-1 gyro motor=0A=0A=0A =0A Harry:=0A I did the same as you. I can dampen ou t the hunting by adding some aileron trim bias to o ne side. (Turn manual aileron trim as far as it will go to one side.) The load on the control helps wit h hunting.=0A =0A Gary:=0A There i s a thread on VAF about the motor replacement.=0A htt p://www.vansairforce.com/community/showthread.php?t=38078=0A =0A I recommend reading post #5. It says almost any mo tor can be used as a replacement but stated that th e Micromo was the longest lasting. There is a link to a less expensive item on eBay.=0A =0A =0A Gary A. Sobek =0A "My Sanity" RV-6 N 157GS O-320 Hartzell, =0A 2,900+ Flying Hour s Pennsylvania, USA =0A =0A =0A =0A =0A =0AOn 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote:=0A =0A =0A =0A =0AGV,=0A =0A=0A =0A =0AThe same thing happened to m e on the way to OSH two years ago. I bought a Trio head while there and installed it after I got home, using the old Navaid servo. The Trio works OK and has some featu res that were not available in the Navaid, but it has an annoying tendency that I have never been able to trim out of hunting back and forth around the GPS course. If I could have obtained a new motor for the Navaid I would hav e gone that way and been completely sat isfied (until it died again). The Trio folks insist that the problem is because the servo is mounted under the passenger seat, just like yours, and that they highly recommend mou nting the servo in the wing tip. Bot tom line is you will probably be happy if you go with a Trio and use the old servo like I di d, and just as happy if you find a replacement motor.=0A =0A =0A=0A =0A =0AHarry Crosby=0A =0A =0A=0A =0A =0A =0AFrom: "Thomas Doran" =0A To: " RV-List" =0A Sent: Monda y, August 18, 2014 3:58:20 PM=0A Subject: Re: RV-List: Navaid AP-1 gyro motor=0A =0A=0A =0A =0A=0A =0A I have two NAVAID control heads (one I got as a spare) and a servo that I removed from my RV-8A. I replaced it with a Dynon Skyview and Autopilot. =0A=0A =0A =0AI have been planning to put them on EBAY, bu t haven=99t gotten around to it .=0A =0A=0A =0A =0AAre you interested? =0A =0A=0A =0A =0A Thanks, =0A =0A=0A =0A =0A=0A =0A =0ATom=0A =0A=0A =0A =0A=0A =0A =0AOn Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:=0A =0A =0A =0AWell it has finally happened again. The gyro mo tor on my a ncient Navaid Devices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. D oes anyone know if these motors are available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) was the last to do the repairs befo re they closed their doors.=0A =0A =0A =0AIs the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada?=0A =0A =0A =0AComments from th ose who have gone thru this would be most helpful.=0A =0A =0A =0A-Thx=0A =0A =0A =0AGV=0A =0A=0A=0A href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Nav igator?RV-List=0Ahref="http://forums.matronics.com/">http://forums.matronics.c om=0Ahref="http://www.matronics.com/contribution">http://www.matronics.com/con tribution=0A=0A=0A =0A =0A=0A =0A ____________________ ________________________________________=0A =0A =0A =0A =0A =0A=0A=0At="_blank ">http://www.matronics.com/Navigator?RV-List=0Atp://forums.matronics.com=0A_blan k">http://www.matronics.com/contribution=0A=0A=0A =0A =0A=0A =0A =0A =0A=0A=0Aom/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li st=0As.com">http://forums.matronics.com=0Aom/contribution">http://www.matronics. =========================== =========================== =========================== =========================== - List Contribution Web Site -=0A -Matt =========================== ===========0A=0A=0A=0A ________________________________________________________________________________
Date: Aug 18, 2014
=0AFirst, a couple of shots of the original motor Micromo 16 24L012S692 044.=0A=0A=0A=0A=0A=0A=0A=0A=0ASo far the closest items t o the original motor that I can track down easily are the following and my known criteria are:=0A=0A12VDC=0A15,000 to 20,000 rpm =0A1620 to 1625 size (dia/bodyL)=0Adouble shaft 1.5mm dia or greater (to allow use of the original flywheels)12VDC=0A =0A =0Ahttp://www.hollywoodfoundry.com/MHK1624.htm=0A =0Ahttp://www.hollywoo dfoundry.com/MHK1620.htm=0A =0A -GV=0A =0A-----Original Message-----=0AF rom: Gary A. Sobek =0ATo: rv-list =0ASent: Mon, Aug 18, 2014 4:50 pm=0ASubject: Re: RV -List: Navaid AP-1 gyro motor=0A=0A=0A =0A Harry:=0A I did the same as you. I can da mpen out the hunting by adding some aileron trim bias to one side. (Turn manual aileron trim as far as it will go to one side.) The load on the control hel ps with hunting.=0A =0A Gary:=0A T here is a thread on VAF about the motor replacement.=0A http://www.vansairforce.com/community/showthread.php?t=38078=0A =0A I recommend reading post #5. It says almost an y motor can be used as a replacement but stated tha t the Micromo was the longest lasting. There is a l ink to a less expensive item on eBay.=0A =0A =0A Gary A. Sobek =0A "My Sanity" RV -6 N157GS O-320 Hartzell, =0A 2,900+ Flying Hours Pennsylvania, USA =0A =0A =0A =0A =0A =0AOn 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote:=0A =0A =0A =0A =0AGV,=0A =0A=0A =0A =0AThe same thing happened to me on the way to OSH two years ago. I bought a Trio head while there and installed it after I got home, using the old Navaid servo. The Trio works OK and has some featu res that were not available in the Navaid, but it has an annoying tendency that I have never been able to trim out of hunting back and forth around the GPS course. If I could have obtained a new motor for the Navaid I would hav e gone that way and been completely sat isfied (until it died again). The Trio folks insist that the problem is because the servo is mounted under the passenger seat, just like yours, and that they highly recommend mou nting the servo in the wing tip. Bot tom line is you will probably be happy if you go with a Trio and use the old servo like I di d, and just as happy if you find a replacement motor.=0A =0A =0A=0A =0A =0AHarry Crosby=0A =0A =0A=0A =0A =0A =0AFrom: "Thomas Doran" =0A To: " RV-List" =0A Sent: Monda y, August 18, 2014 3:58:20 PM=0A Subject: Re: RV-List: Navaid AP-1 gyro motor=0A =0A=0A =0A =0A=0A =0A I have two NAVAID control heads (one I got as a spare) and a servo that I removed from my RV-8A. I replaced it with a Dynon Skyview and Autopilot. =0A=0A =0A =0AI have been planning to put them on EBAY, bu t haven=99t gotten around to it .=0A =0A=0A =0A =0AAre you interested? =0A =0A=0A =0A =0A Thanks, =0A =0A=0A =0A =0A=0A =0A =0ATom=0A =0A=0A =0A =0A=0A =0A =0AOn Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:=0A =0A =0A =0AWell it has finally happened again. The gyro mo tor on my a ncient Navaid Devices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. D oes anyone know if these motors are available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) was the last to do the repairs befo re they closed their doors.=0A =0A =0A =0AIs the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada?=0A =0A =0A =0AComments from th ose who have gone thru this would be most helpful.=0A =0A =0A =0A-Thx=0A =0A =0A =0AGV=0A =0A=0A=0A href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Nav igator?RV-List=0Ahref="http://forums.matronics.com/">http://forums.matronics.c om=0Ahref="http://www.matronics.com/contribution">http://www.matronics.com/con tribution=0A=0A=0A =0A =0A=0A =0A ____________________ ________________________________________=0A =0A =0A =0A =0A =0A=0A=0At="_blank ">http://www.matronics.com/Navigator?RV-List=0Atp://forums.matronics.com=0A_blan k">http://www.matronics.com/contribution=0A=0A=0A =0A =0A=0A =0A =0A =0A=0A=0Aom/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li st=0As.com">http://forums.matronics.com=0Aom/contribution">http://www.matronics. =========================== =========================== =========================== =========================== - List Contribution Web Site -=0A -Matt =========================== ===========0A=0A=0A=0A ________________________________________________________________________________
Date: Aug 18, 2014
I happen to have an extra Tru-Trak servo that I won't be using (I have 3 of them, don't need this one). It's a model # DSB-B, part # 8100-006. It's brand new, in the box, never used. I bought two of them for my autopilot installation, but bought a 3rd one later that has vertical contol for the pitch axis, so this one is extra. I'll let it go for about half the price of a new one. If this will fit for your application, let me know privately. Email me: swayze "at" europa.com and I'll send you photos and answer all your questions. I hope this can help you out! At 09:56 AM 8/18/2014, you wrote: >Well it has finally happened again. The gyro motor on my ancient >Navaid Devices wing leveler has burned out. Navaid Devices went TU >in 2008 and their proprietary motor (Micromo 1624L012S692) is no >longer available. Does anyone know if these motors are available >elsewhere in someone's stash? I heard that one of the Navaid people >(Horace, I think) was the last to do the repairs before they closed >their doors. > >Is the right solution to go with the Trio head and keep the Navaid >S1 servo or replace the whole enchilada? > >Comments from those who have gone thru this would be most helpful. > >-Thx > >GV ________________________________________________________________________________
Date: Aug 18, 2014
=0ABruce-=0A =0AMy servo is fine. I need the AP head gyro motor. Thx anyway.=0A =0A-GV=0A =0A =0A-----Original Message-- ---=0AFrom: Bruce Swayze <swayze(at)europa.com>=0ATo: rv-list <rv-list@ma tronics.com>=0ASent: Mon, Aug 18, 2014 7:29 pm=0ASubject: RV-List: Re: Navaid AP-1 gyro motor=0A=0A=0A--> RV-List message posted by: Bruce Swayze =0A=0AI happen to have an ex tra Tru-Trak servo that I won't be using (I =0Ahave 3 of them, don't need this one). It's a model # DSB-B, part # =0A8100-006. It's brand new, in the box, never used. I bough t two of =0Athem for my autopilot installation, but bought a 3rd one later that =0Ahas vertical contol for the pitch a xis, so this one is extra. I'll =0Alet it go for about h alf the price of a new one. If this will fit for =0Ayour application, let me know privately. Email me: swayze "at" =0Aeuropa.com and I'll send you photos and answer all your =0Aquestions. I hope this can help you out!=0A=0A=0AAt 09:56 AM 8/18/2014, you wrote:=0A>Well it has finally happened again. The gyro motor on my ancient =0A>Navaid Devices wing levele r has burned out. Navaid Devices went TU =0A>in 2008 and their proprietary motor (Micromo 1624L012S692) is no =0A>longer available. Does anyone know if these motors are available =0A >elsewhere in someone's stash? I heard that one of the Na vaid people =0A>(Horace, I think) was the last to do the r epairs before they closed =0A>their doors.=0A>=0A>Is the right s olution to go with the Trio head and keep the Navaid =0A>S 1 servo or replace the whole enchilada?=0A>=0A>Comments from tho se who have gone thru this would be most helpful.=0A>=0A>-Thx=0A =========================== =========================== =========================== =========================== =========================== ======================0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Subject: All you wanted to know about DC motors
Date: Aug 18, 2014
=0AAnd afraid to ask...=0A=0Ahttp://www.delta-line.com/data/download/Porte scap_Technology.pdf=0A=0A ________________________________________________________________________________
Date: Aug 19, 2014
Wow, thanks Gary I will try that right away. Harry Crosby RV-6 N16CX, 1200 hours (as of last flight.) ----- Original Message ----- From: "Gary A. Sobek" <RV6_Flyer(at)hotmail.com> Sent: Monday, August 18, 2014 4:48:06 PM Subject: Re: RV-List: Navaid AP-1 gyro motor Harry: I did the same as you. I can dampen out the hunting by adding some aileron trim bias to one side. (Turn manual aileron trim as far as it will go to on e side.) The load on the control helps with hunting. Gary: There is a thread on VAF about the motor replacement. http://www.vansairforce.com/community/showthread.php?t=38078 I recommend reading post #5. It says almost any motor can be used as a repl acement but stated that the Micromo was the longest lasting. There is a lin k to a less expensive item on eBay. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,900+ Flying Hours Pennsylvania, USA On 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote: GV, The same thing happened to me on the way to OSH two years ago. I bought a T rio head while there and installed it after I got home, using the old Navai d servo. The Trio works OK and has some features that were not available in the Navaid, but it has an annoying tendency that I have never been able to trim out of hunting back and forth around the GPS course. If I could have obtained a new motor for the Navaid I would have gone that way and been com pletely satisfied (until it died again). The Trio folks insist that the pro blem is because the servo is mounted under the passenger seat, just like yo urs, and that they highly recommend mounting the servo in the wing tip. Bot tom line is you will probably be happy if you go with a Trio and use the ol d servo like I did, and just as happy if you find a replacement motor. Harry Crosby ----- Original Message ----- From: "Thomas Doran" <dorante(at)juno.com> Sent: Monday, August 18, 2014 3:58:20 PM Subject: Re: RV-List: Navaid AP-1 gyro motor I have two NAVAID control heads (one I got as a spare) and a servo that I r emoved from my RV-8A. I replaced it with a Dynon Skyview and Autopilot. I have been planning to put them on EBAY, but haven=99t gotten around to it. Are you interested? Thanks, Tom On Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:
Well it has finally happened again. The gyro motor on my ancient Navaid Dev ices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. Does anyon e know if these motors are available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) was the last to do the repa irs before they closed their doors. Is the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada? Comments from those who have gone thru this would be most helpful. -Thx GV href= "http://www.matronics.com/Navigator?RV-List" > http://www.matronics .com/Navigator?RV-List href= "http://forums.matronics.com/" > http://foru ms.matronics.com href= "http://www.matronics.com/contribution" > http://w ww.matronics.com/contribution ____________________________________________________________ t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution om/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List s.com">http://forums.matronics.com om/contribution">http://www.matronics.com/contribution
Subject: Re: All you wanted to know about DC motors
Date: Aug 20, 2014
GV - thanks, excellent info. Good luck getting the Navaid ap working. Keep us posted on your decision, I v alue your contributions to the RV community. Doug Gray RV6 flying since mid 2010 Sent from my iPhone > On 19 Aug 2014, at 12:34 pm, vanremog(at)aol.com wrote: > > And afraid to ask... > > http://www.delta-line.com/data/download/Portescap_Technology.pdf > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Aug 19, 2014
=0AThank you and I will.=0A =0A =0A-----Original Message-----=0AFr om: Doug Gray =0ATo: rv-list =0ASent: Tue, Aug 19, 2014 5:19 pm=0ASubject: Re: RV-List : All you wanted to know about DC motors=0A=0A=0A=0AGV - tha nks, excellent info.=0AGood luck getting the Navaid ap working. Keep us posted on your decision, I value your contributions to the RV community.=0ADoug Gray=0ARV6 flying since mid 2010=0A=0A Sent from my iPhone=0A=0AOn 19 Aug 2014, at 12:34 pm, vanrem og@aol.com wrote:=0A=0A=0A=0AAnd afraid to ask...=0A =0Ahttp://www.del ta-line.com/data/download/Portescap_Technology.pdf=0A =0A=0A=0A=0A=0A=0A=0A=0A 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=0A=0A=0A=0A ________________________________________________________________________________
Date: Aug 19, 2014
=0AThis is exactly what I do but I usually end up just t rimming into the wind.=0A =0A-GV=0A =0A =0A-----Original Message-- ---=0AFrom: Gary A. Sobek <RV6_Flyer(at)hotmail.com>=0ATo: rv-list <rv- list(at)matronics.com>=0ASent: Mon, Aug 18, 2014 4:50 pm=0ASubject: R e: RV-List: Navaid AP-1 gyro motor=0A=0A=0A =0A Harry:=0A I did the same as you. I can dampen out the hunting by adding some aileron tri m bias to one side. (Turn manual aileron trim as far as it will go to one side.) The load on the cont rol helps with hunting.=0A =0A Gary:=0A There is a thread on VAF about the motor replacement.=0A http://www.vansairforce.com/community/showthread.php?t=38078=0A =0A I recommend reading post #5. It says al most any motor can be used as a replacement but sta ted that the Micromo was the longest lasting. There i s a link to a less expensive item on eBay.=0A =0A =0A Gary A. Sobek =0A "My San ity" RV-6 N157GS O-320 Hartzell, =0A 2,900+ Flying Hours Pennsylvania, USA =0A =0A =0A =0A =0A =0AOn 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote:=0A =0A =0A =0A =0AGV,=0A =0A=0A =0A =0AThe same thing happe ned to me on the way to OSH two years ago. I bought a Trio head while there and installed it after I got home, using the old Nava id servo. The Trio works OK and has s ome features that were not available in the Navaid, but it has an annoying tendency that I have nev er been able to trim out of hunting b ack and forth around the GPS course. If I could have obtained a new motor for the Navaid I w ould have gone that way and been comple tely satisfied (until it died again). The Trio folks insist that the problem is because the servo is mounted under the passenger seat, ju st like yours, and that they highly rec ommend mounting the servo in the wing t ip. Bottom line is you will probably be happy if you go with a Trio and use the old servo like I did, and just as happy if you find a replacement motor.=0A =0A =0A=0A =0A =0AHarry Crosby=0A =0A =0A=0A =0A =0A =0AFrom: "Thomas Doran" =0A Monday, August 18, 2014 3:58:20 PM=0A Sub ject: Re: RV-List: Navaid AP-1 gyro motor=0A =0A=0A =0A =0A=0A =0A I have two NAVAID control heads (one I got as a spare) and a servo that I removed from my RV-8A. I repla ced it with a Dynon Skyview and Autopil ot. =0A=0A =0A =0AI have been planning to put them on EBAY , but haven=99t gotten around t o it.=0A =0A=0A =0A =0AAre you interested? =0A =0A=0A =0A =0AThanks, =0A =0A=0A =0A =0A=0A =0A =0ATom=0A =0A=0A =0A =0A=0A =0A =0AOn Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:=0A =0A =0A =0AWell it has finally happened again. The gyr o motor on my ancient Navaid Devices wing leveler has burned out. Navaid Devices wen t TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. Does anyone know if these motors are available elsewhere in someone's stash? I hear d that one of the Navaid people (Horace, I think) was the last to do the repairs b efore they closed their doors.=0A =0A =0A =0A Is the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada?=0A =0A =0A =0AComments from th ose who have gone thru this would be most helpful.=0A =0A =0A =0A-Thx=0A =0A =0A =0AGV=0A =0A=0A=0A href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Nav igator?RV-List=0Ahref="http://forums.matronics.com/">http://forums.matronics.c om=0Ahref="http://www.matronics.com/contribution">http://www.matronics.com/con tribution=0A=0A=0A =0A =0A=0A =0A ____________________ ________________________________________=0A =0A =0A =0A =0A =0A=0A=0At="_blank ">http://www.matronics.com/Navigator?RV-List=0Atp://forums.matronics.com=0A_blan k">http://www.matronics.com/contribution=0A=0A=0A =0A =0A=0A =0A =0A =0A=0A=0Aom/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li st=0As.com">http://forums.matronics.com=0Aom/contribution">http://www.matronics. =========================== =========================== =========================== =========================== - List Contribution Web Site -=0A -Matt =========================== ===========0A=0A=0A=0A ________________________________________________________________________________
Date: Aug 20, 2014
Hi Harry, I also have an old Navaid control head sitting around that I would let go for a song (like a good show tune or something). But I actually recommend going with the Trio. In my experience it has been very useful and works much better than the Navaid ever did. I do get some minimal hunting while on GPS flight plan (servo is in wing at aileron bellcrank), but when using GPS course as guidance (a ground course as opposed to trying to stay dead center of the flight plan) it is rock solid and there is no hunting at all. I find that is the way I usually fly anyway, as I am always making deviations for airspace or traffic or what-not anyway and never bother to fly all the way back to the flight plan path. Dave Leonard On Tue, Aug 19, 2014 at 12:04 PM, wrote: > Wow, thanks Gary I will try that right away. > > Harry Crosby > RV-6 N16CX, 1200 hours (as of last flight.) > > ------------------------------ > *From: *"Gary A. Sobek" <RV6_Flyer(at)hotmail.com> > *To: *"RV-List" > *Sent: *Monday, August 18, 2014 4:48:06 PM > > *Subject: *Re: RV-List: Navaid AP-1 gyro motor > > Harry: > I did the same as you. I can dampen out the hunting by adding some > aileron trim bias to one side. (Turn manual aileron trim as far as it wi ll > go to one side.) The load on the control helps with hunting. > > Gary: > There is a thread on VAF about the motor replacement. > http://www.vansairforce.com/community/showthread.php?t=38078 > > I recommend reading post #5. It says almost any motor can be used as a > replacement but stated that the Micromo was the longest lasting. There is a > link to a less expensive item on eBay. > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 2,900+ Flying Hours Pennsylvania, USA > > > On 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote: > > GV, > > The same thing happened to me on the way to OSH two years ago. I bought > a Trio head while there and installed it after I got home, using the old > Navaid servo. The Trio works OK and has some features that were not > available in the Navaid, but it has an annoying tendency that I have neve r > been able to trim out of hunting back and forth around the GPS course. I f > I could have obtained a new motor for the Navaid I would have gone that w ay > and been completely satisfied (until it died again). The Trio folks insi st > that the problem is because the servo is mounted under the passenger seat , > just like yours, and that they highly recommend mounting the servo in the > wing tip. Bottom line is you will probably be happy if you go with a Tri o > and use the old servo like I did, and just as happy if you find a > replacement motor. > > Harry Crosby > > ------------------------------ > *From: *"Thomas Doran" <dorante(at)juno.com> <dorante(at)juno.com> > *To: *"RV-List" > *Sent: *Monday, August 18, 2014 3:58:20 PM > *Subject: *Re: RV-List: Navaid AP-1 gyro motor > > > I have two NAVAID control heads (one I got as a spare) and a servo that I > removed from my RV-8A. I replaced it with a Dynon Skyview and Autopilot. > > I have been planning to put them on EBAY, but haven=99t gotten aro und to > it. > > Are you interested? > > Thanks, > > > Tom > > > On Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote: > > Well it has finally happened again. The gyro motor on my ancient Navaid > Devices wing leveler has burned out. Navaid Devices went TU in 2008 and > their proprietary motor (Micromo 1624L012S692) is no longer available. > Does anyone know if these motors are available elsewhere in someone's > stash? I heard that one of the Navaid people (Horace, I think) was the > last to do the repairs before they closed their doors. > > Is the right solution to go with the Trio head and keep the Navaid S1 > servo or replace the whole enchilada? > > Comments from those who have gone thru this would be most helpful. > > -Thx > > GV > > * > > href="http://www.matronics.com/Navigator?RV-List" >http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com/" >http ://forums.matronics.com <http://forums.matronics.com> > href="http://www.matronics.com/contribution" >http://www.matronics.com/contribution > > * > > > ____________________________________________________________ > > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > om/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > s.com <http://www.matronics.com/Navigator?RV-Lists.com>">http://forums.ma tronics.com <http://forums.matronics.com> > om/contribution">http://www.matronics.com/contribution > > * > > > * > > t="_blank">http://www.matronics.com/Navigator?RV-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > =========== ics.com/Navigator?RV-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Aug 20, 2014
Subject: Re: Unsuscribe. Re: RV-List Digest: 0 Msgs - 06/03/14
On Jun 4, 2014 3:24 AM, "RV-List Digest Server" wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-06-03&Archive=RV > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-06-03&Archive=RV > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV-List Digest Archive > --- > Total Messages Posted Tue 06/03/14: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Date: Aug 22, 2014
Subject: log book errro
When doing my annual this year I checked back on the previous log entries I made for my other annual inspections. I was amazed to discover that a couple years ago I did not make the standard entry about "i gave inspected... it complies with..." etc. I just wrote "completed annual inspection". Is this really a mistake? Do you need the standard verbiage? If it is a mistake, how do I make it right? I also keep a separate, unofficial document for each inspection. It's a long check list of everything I did along with with notes, my signature and certificate number. Probably has no standing with the FAA, but it exists. -- Tom Sargent ________________________________________________________________________________
Date: Aug 22, 2014
Subject: Re: log book errro
On 8/22/2014 11:22 AM, Thomas Sargent wrote: > When doing my annual this year I checked back on the previous log > entries I made for my other annual inspections. I was amazed to > discover that a couple years ago I did not make the standard entry > about "i gave inspected... it complies with..." etc. I just wrote > "completed annual inspection". > > Is this really a mistake? Do you need the standard verbiage? If there was ever a problem ..... the standard verbiage would be better. And remember it's not an 'annual', but a 'conditional inspection' > > If it is a mistake, how do I make it right? Use the standard verbiage next time. > > I also keep a separate, unofficial document for each inspection. It's > a long check list of everything I did along with with notes, my > signature and certificate number. Probably has no standing with the > FAA, but it exists. Actually, this is what my FSDO recommended as long as it's kept with the logbooks .... especially since my 'conditional inspection' occurs over the year (mostly). Anything not covered during the year is covered in Jan ... when my entry in the logbook occurs. It's amazing what you do throughout the year making improvements/mods and doing normal maintenance. Linn > > -- > Tom Sargent > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Aug 22, 2014
Perhaps I should clarify that the separate document I keep is everything I did during the inspection - what I inspected and what the results were. It's not a record of oil changes or repairs. Those are in the log book. -- Tom Sargent ________________________________________________________________________________
Date: Aug 22, 2014
Conditional Inspection? Where in FAA Orders / Operating Limitations does it call out Conditional other than for a sale of an aircraft? FAA Order 8130.2G Change 1 <http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/7a09d53f b0d5325586257885004d9e1b/$FILE/8130.2G_CHG1.pdf> calls out a Condition Inspection. If you look at your Operating Limitations=2C it will also. > No person must operate this aircraft unless within the preceding 12 > calendar months it has had a *condition inspection* performed in > accordance with the scope and detail of 14 CFR part 43=2C appendix D=2C o r > other FAA-approved programs=2C and was found to be in a condition for > safe operation. As part of the condition inspection=2C cockpit > instruments must be appropriately marked and needed placards installed > in accordance with 14 CFR =C2=A7 91.9. In addition=2C system-essential > controls must be in good condition=2C securely mounted=2C clearly marked =2C > and provide for ease of operation. This inspection will be recorded in > the aircraft logbook and maintenance records. > *Condition inspections* must be recorded in the aircraft logbook and > maintenance records showing the following=2C or a similarly worded=2C > statement: =9CI certify that this aircraft has been inspected on [i nsert > date] in accordance with the scope and detail of 14 CFR part 43=2C > appendix D=2C and was found to be in a condition for safe operation. =9D > The entry will include the aircraft=99s total time-in-service (cycl es if > appropriate)=2C and the name=2C signature=2C certificate number=2C and ty pe of > certificate held by the person performing the inspection. On 08-22-2014=2C 11:40 AM=2C Linn Walters wrote: > On 8/22/2014 11:22 AM=2C Thomas Sargent wrote: >> When doing my annual this year I checked back on the previous log >> entries I made for my other annual inspections. I was amazed to >> discover that a couple years ago I did not make the standard entry >> about "i gave inspected... it complies with..." etc. I just wrote >> "completed annual inspection". >> >> Is this really a mistake? Do you need the standard verbiage? > If there was ever a problem ..... the standard verbiage would be > better. And remember it's not an 'annual'=2C but a '*conditional > inspection*' >> >> If it is a mistake=2C how do I make it right? > Use the standard verbiage next time. >> >> I also keep a separate=2C unofficial document for each inspection. >> It's a long check list of everything I did along with with notes=2C my >> signature and certificate number. Probably has no standing with the >> FAA=2C but it exists. > Actually=2C this is what my FSDO recommended as long as it's kept with > the logbooks .... especially since my 'conditional inspection' occurs > over the year (mostly). Anything not covered during the year is > covered in Jan ... when my entry in the logbook occurs. It's amazing > what you do throughout the year making improvements/mods and doing > normal maintenance. > Linn > >> >> -- >> Tom Sargent >> * >> * ________________________________________________________________________________
Date: Aug 22, 2014
The easiest fix....do a computer generated labeln sticker with the correct language quoted directly from your operating limitations. Place the sticker right over the incorrect entry and sign it. Experimentals do not get an annual inspection, just a condition inspection that occurs annually. KellyM A&P/IA On 8/22/2014 8:22 AM, Thomas Sargent wrote: > When doing my annual this year I checked back on the previous log > entries I made for my other annual inspections. I was amazed to > discover that a couple years ago I did not make the standard entry > about "i gave inspected... it complies with..." etc. I just wrote > "completed annual inspection". > > Is this really a mistake? Do you need the standard verbiage? > > If it is a mistake, how do I make it right? > > I also keep a separate, unofficial document for each inspection. It's > a long check list of everything I did along with with notes, my > signature and certificate number. Probably has no standing with the > FAA, but it exists. > > -- > Tom Sargent > * > > > * ________________________________________________________________________________
Date: Aug 22, 2014
Sorry ... typing faster than the brain works. Thanks for the heads up. Linn On 8/22/2014 12:10 PM, Gary A. Sobek wrote: > Conditional Inspection? Where in FAA Orders / Operating Limitations > does it call out Conditional other than for a sale of an aircraft? > > FAA Order 8130.2G Change 1 > <http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/7a09d53fb0d5325586257885004d9e1b/$FILE/8130.2G_CHG1.pdf> > calls out a Condition Inspection. If you look at your Operating > Limitations, it will also. > >> No person must operate this aircraft unless within the preceding 12 >> calendar months it has had a *condition inspection* performed in >> accordance with the scope and detail of 14 CFR part 43, appendix D, >> or other FAA-approved programs, and was found to be in a condition >> for safe operation. As part of the condition inspection, cockpit >> instruments must be appropriately marked and needed placards >> installed in accordance with 14 CFR 91.9. In addition, >> system-essential controls must be in good condition, securely >> mounted, clearly marked, and provide for ease of operation. This >> inspection will be recorded in the aircraft logbook and maintenance >> records. > >> *Condition inspections* must be recorded in the aircraft logbook and >> maintenance records showing the following, or a similarly worded, >> statement: I certify that this aircraft has been inspected on >> [insert date] in accordance with the scope and detail of 14 CFR part >> 43, appendix D, and was found to be in a condition for safe >> operation. The entry will include the aircrafts total >> time-in-service (cycles if appropriate), and the name, signature, >> certificate number, and type of certificate held by the person >> performing the inspection. > > > On 08-22-2014, 11:40 AM, Linn Walters wrote: >> On 8/22/2014 11:22 AM, Thomas Sargent wrote: >>> When doing my annual this year I checked back on the previous log >>> entries I made for my other annual inspections. I was amazed to >>> discover that a couple years ago I did not make the standard entry >>> about "i gave inspected... it complies with..." etc. I just wrote >>> "completed annual inspection". >>> >>> Is this really a mistake? Do you need the standard verbiage? >> If there was ever a problem ..... the standard verbiage would be >> better. And remember it's not an 'annual', but a '*conditional >> inspection*' >>> >>> If it is a mistake, how do I make it right? >> Use the standard verbiage next time. >>> >>> I also keep a separate, unofficial document for each inspection. >>> It's a long check list of everything I did along with with notes, >>> my signature and certificate number. Probably has no standing with >>> the FAA, but it exists. >> Actually, this is what my FSDO recommended as long as it's kept with >> the logbooks .... especially since my 'conditional inspection' occurs >> over the year (mostly). Anything not covered during the year is >> covered in Jan ... when my entry in the logbook occurs. It's amazing >> what you do throughout the year making improvements/mods and doing >> normal maintenance. >> Linn >> >>> >>> -- >>> Tom Sargent >>> * >>> * > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Aug 22, 2014
Hi Dave, Interesting that you still get some hunting about the GPS course even with your servo at the aileron bellcrank. Anyway, I agree that this is not a ser ious drawback for the Trio and that the additional capabilities of the Trio are definitely worth the minor annoyance it causes. The only time it reall y bugs me is if I have one or more planes in loose formation trying to stay with me questioning why I'm wandering about the course. Harry Crosby ----- Original Message ----- From: "David Leonard" <wdleonard(at)gmail.com> Sent: Wednesday, August 20, 2014 12:50:38 PM Subject: Re: RV-List: Navaid AP-1 gyro motor Hi Harry, I also have an old Navaid control head sitting around that I would let go f or a song (like a good show tune or something). But I actually recommend go ing with the Trio. In my experience it has been very useful and works much better than the Navaid ever did. I do get some minimal hunting while on GPS flight plan (servo is in wing at aileron bellcrank), but when using GPS co urse as guidance (a ground course as opposed to trying to stay dead center of the flight plan) it is rock solid and there is no hunting at all. I find that is the way I usually fly anyway, as I am always making deviations for airspace or traffic or what-not anyway and never bother to fly all the way back to the flight plan path. Dave Leonard On Tue, Aug 19, 2014 at 12:04 PM, < HCRV6(at)comcast.net > wrote: Wow, thanks Gary I will try that right away. Harry Crosby RV-6 N16CX, 1200 hours (as of last flight.) From: "Gary A. Sobek" < RV6_Flyer(at)hotmail.com > Sent: Monday, August 18, 2014 4:48:06 PM Subject: Re: RV-List: Navaid AP-1 gyro motor Harry: I did the same as you. I can dampen out the hunting by adding some aileron trim bias to one side. (Turn manual aileron trim as far as it will go to on e side.) The load on the control helps with hunting. Gary: There is a thread on VAF about the motor replacement. http://www.vansairforce.com/community/showthread.php?t=38078 I recommend reading post #5. It says almost any motor can be used as a repl acement but stated that the Micromo was the longest lasting. There is a lin k to a less expensive item on eBay. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,900+ Flying Hours Pennsylvania, USA On 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote:
GV, The same thing happened to me on the way to OSH two years ago. I bought a T rio head while there and installed it after I got home, using the old Navai d servo. The Trio works OK and has some features that were not available in the Navaid, but it has an annoying tendency that I have never been able to trim out of hunting back and forth around the GPS course. If I could have obtained a new motor for the Navaid I would have gone that way and been com pletely satisfied (until it died again). The Trio folks insist that the pro blem is because the servo is mounted under the passenger seat, just like yo urs, and that they highly recommend mounting the servo in the wing tip. Bot tom line is you will probably be happy if you go with a Trio and use the ol d servo like I did, and just as happy if you find a replacement motor. Harry Crosby From: "Thomas Doran" <dorante(at)juno.com> Sent: Monday, August 18, 2014 3:58:20 PM Subject: Re: RV-List: Navaid AP-1 gyro motor I have two NAVAID control heads (one I got as a spare) and a servo that I r emoved from my RV-8A. I replaced it with a Dynon Skyview and Autopilot. I have been planning to put them on EBAY, but haven=99t gotten around to it. Are you interested? Thanks, Tom On Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:
Well it has finally happened again. The gyro motor on my ancient Navaid Dev ices wing leveler has burned out. Navaid Devices went TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. Does anyon e know if these motors are available elsewhere in someone's stash? I heard that one of the Navaid people (Horace, I think) was the last to do the repa irs before they closed their doors. Is the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada? Comments from those who have gone thru this would be most helpful. -Thx GV href= "http://www.matronics.com/Navigator?RV-List" > http://www.matronics .com/Navigator?RV-List href= "http://forums.matronics.com/" > http://foru ms.matronics.com href= "http://www.matronics.com/contribution" > http://w ww.matronics.com/contribution ____________________________________________________________ t="_blank"> http://www.matronics.com/Navigator?RV-List tp:// forums.matro nics.com _blank"> http://www.matronics.com/contribution om/Navigator?RV-List"> http://www.matronics.com/Navigator?RV-List s.com "> http://forums.matronics.com om/contribution"> http://www.matronics .com/contribution
t="_blank"> http://www.matronics.com/Navigator?RV-List tp:// forums.matro nics.com _blank"> http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution
Date: Aug 22, 2014
=0ASo, what I have found out is that the original motor fr om Micromo is no longer available. The closest thing to t he original is their 1624T012S123-277. It differs from the ori ginal in the kind of grease used and the back shaft is 1 mm shorter. George Hunt and Jani Glover at Micromo were v ery helpful in helping me nail down the details.=0A =0AThe r eplacement motor is $110 and was in stock. I should have it in a week or so and will advise whether I have the AP-1 working again or it and the new motor have gone off to Valhalla.=0A=0AThe challenge will be to install the .149" t hick flywheel on the 4mm back shaft. I will rough up th e shafts, apply some Loctite 271 and press the front flywhee l on until flush then press the back flywheel on only .125 " or so. Once that is done and I have reassembled the unit, balanced the gyro/motor/flywheel on its shaft and wired it up I should be good to go. It's not nearly as comp lex as the multilayer high density surface mounted defense boa rds I work on every day, but does require a steady hand, good soldering skills and a microscope. Hope for the best.=0A =0A-GV=0A =0A =0A-----Original Message-----=0AFrom: vanremog <vanremog (at)aol.com>=0ATo: rv-list =0ASent: Mon, Aug 18, 2014 5:45 pm=0ASubject: Re: RV-List: Navaid AP-1 gyro motor=0A=0A =0AFirst, a couple of shots of the original motor Micromo 16 24L012S692 044.=0A =0A=0A=0A=0A=0A=0A=0A =0ASo far the closest ite ms to the original motor that I can track down easily are the following and my known criteria are:=0A =0A12VDC=0A15,000 to 20,000 rpm =0A1620 to 1625 size (dia/bodyL)=0Adouble shaft 1. 5mm dia or greater (to allow use of the original flywheel s)12VDC=0A=0A =0Ahttp://www.hollywoodfoundry.com/MHK1624.htm=0A =0Ahttp://ww w.hollywoodfoundry.com/MHK1620.htm=0A =0A -GV=0A =0A-----Original Messag e-----=0AFrom: Gary A. Sobek <RV6_Flyer(at)hotmail.com>=0ATo: rv-list < rv-list(at)matronics.com>=0ASent: Mon, Aug 18, 2014 4:50 pm=0ASubject: Re: RV-List: Navaid AP-1 gyro motor=0A=0A=0A =0A Harry:=0A I did the same as you. I can dampen out the hunting by adding some aileron tri m bias to one side. (Turn manual aileron trim as far as it will go to one side.) The load on the cont rol helps with hunting.=0A =0A Gary:=0A There is a thread on VAF about the motor replacement.=0A http://www.vansairforce.com/community/showthread.php?t=38078=0A =0A I recommend reading post #5. It says al most any motor can be used as a replacement but sta ted that the Micromo was the longest lasting. There i s a link to a less expensive item on eBay.=0A =0A =0A Gary A. Sobek =0A "My San ity" RV-6 N157GS O-320 Hartzell, =0A 2,900+ Flying Hours Pennsylvania, USA =0A =0A =0A =0A =0A =0AOn 08-18-2014, 7:24 PM, HCRV6(at)comcast.net wrote:=0A =0A =0A =0A =0AGV,=0A =0A=0A =0A =0AThe same thing happe ned to me on the way to OSH two years ago. I bought a Trio head while there and installed it after I got home, using the old Nava id servo. The Trio works OK and has s ome features that were not available in the Navaid, but it has an annoying tendency that I have nev er been able to trim out of hunting b ack and forth around the GPS course. If I could have obtained a new motor for the Navaid I w ould have gone that way and been comple tely satisfied (until it died again). The Trio folks insist that the problem is because the servo is mounted under the passenger seat, ju st like yours, and that they highly rec ommend mounting the servo in the wing t ip. Bottom line is you will probably be happy if you go with a Trio and use the old servo like I did, and just as happy if you find a replacement motor.=0A =0A =0A=0A =0A =0AHarry Crosby=0A =0A =0A=0A =0A =0A =0AFrom: "Thomas Doran" =0A Monday, August 18, 2014 3:58:20 PM=0A Sub ject: Re: RV-List: Navaid AP-1 gyro motor=0A =0A=0A =0A =0A=0A =0A I have two NAVAID control heads (one I got as a spare) and a servo that I removed from my RV-8A. I repla ced it with a Dynon Skyview and Autopil ot. =0A=0A =0A =0AI have been planning to put them on EBAY , but haven=99t gotten around t o it.=0A =0A=0A =0A =0AAre you interested? =0A =0A=0A =0A =0AThanks, =0A =0A=0A =0A =0A=0A =0A =0ATom=0A =0A=0A =0A =0A=0A =0A =0AOn Aug 18, 2014, at 12:56 PM, vanremog(at)aol.com wrote:=0A =0A =0A =0AWell it has finally happened again. The gyr o motor on my ancient Navaid Devices wing leveler has burned out. Navaid Devices wen t TU in 2008 and their proprietary motor (Micromo 1624L012S692) is no longer available. Does anyone know if these motors are available elsewhere in someone's stash? I hear d that one of the Navaid people (Horace, I think) was the last to do the repairs b efore they closed their doors.=0A =0A =0A =0A Is the right solution to go with the Trio head and keep the Navaid S1 servo or replace the whole enchilada?=0A =0A =0A =0AComments from th ose who have gone thru this would be most helpful.=0A =0A =0A =0A-Thx=0A =0A =0A =0AGV=0A =0A=0A=0A href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Nav igator?RV-List=0Ahref="http://forums.matronics.com/">http://forums.matronics.c om=0Ahref="http://www.matronics.com/contribution">http://www.matronics.com/con tribution=0A=0A=0A =0A =0A=0A =0A ____________________ ________________________________________=0A =0A =0A =0A =0A =0A=0A=0At="_blank ">http://www.matronics.com/Navigator?RV-List=0Atp://forums.matronics.com=0A_blan k">http://www.matronics.com/contribution=0A=0A=0A =0A =0A=0A =0A =0A =0A=0A=0Aom/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li st=0As.com">http://forums.matronics.com=0Aom/contribution">http://www.matronics. =========================== =========================== =========================== =========================== - List Contribution Web Site -=0A -Matt =========================== ===========0A=0A=0A=0A=0A ________________________________________________________________________________
Date: Aug 23, 2014
Tom=2C Don't worry about it. Anybody=2C including the FAA=2C will know what you m eant. And as soon as you write/wrote a new condition inspection entry=2C the old one was superseded. Mike Robertson Retired Das Fed Date: Fri=2C 22 Aug 2014 08:22:28 -0700 Subject: RV-List: log book errro From: sarg314(at)gmail.com When doing my annual this year I checked back on the previous log entries I made for my other annual inspections. I was amazed to discover that a cou ple years ago I did not make the standard entry about "i gave inspected... it complies with..." etc. I just wrote "completed annual inspection". =0A Is this really a mistake? Do you need the standard verbiage? If it is a mistake=2C how do I make it right? I also keep a separate=2C unofficial document for each inspection. It's a long check list of everything I did along with with notes=2C my signature a nd certificate number. Probably has no standing with the FAA=2C but it exi sts.=0A -- Tom Sargent=0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Sep 02, 2014
Subject: Rv6 project
I am selling my RV 6 project. 90 % complete . Call for photos and details Frank 530-391-9760 Sent from my iPhone ________________________________________________________________________________
Date: Sep 06, 2014
Subject: Wing walk adhesive removal
I checked the archives and was able to easily remove the wing walk...from the glue still stuck to the paint.... Is there an easy way to remove the glue? I have tried Avgas, bug and tar remover, MEK, and paint thinner. None really break down the glue....the Avgas does a real good job of final cleaning of the areas that I have been able to remove the glue manually - by rubbing it in to boogers with my hands and manually picking the boogers off! Any other ideas would be appreciated..... ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Sep 06, 2014
Replacing the UHMW tape on the flaps I found a SMALL about of heat from a hot air gun loosens up the glue well enough to come off the tape. Too much heat and you soften the paint. For the last bit of residue I used Coleman Fuel as the cleaner. You might try Goo Gone for what you have. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Saturday, September 06, 2014 11:39 AM Subject: RV-List: Wing walk adhesive removal I checked the archives and was able to easily remove the wing walk...from the glue still stuck to the paint.... Is there an easy way to remove the glue? I have tried Avgas, bug and tar remover, MEK, and paint thinner. None really break down the glue....the Avgas does a real good job of final cleaning of the areas that I have been able to remove the glue manually - by rubbing it in to boogers with my hands and manually picking the boogers off! Any other ideas would be appreciated..... ________________________________________________________________________________
Date: Sep 06, 2014
Try 3m woodgrain and stripe adhesive remover. On Sep 6, 2014 9:04 AM, "Carl Froehlich" wrote: > carl.froehlich(at)verizon.net> > > Replacing the UHMW tape on the flaps I found a SMALL about of heat from a > hot air gun loosens up the glue well enough to come off the tape. Too much > heat and you soften the paint. For the last bit of residue I used Coleman > Fuel as the cleaner. > > You might try Goo Gone for what you have. > > Carl > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen > Sent: Saturday, September 06, 2014 11:39 AM > To: rv-list > Subject: RV-List: Wing walk adhesive removal > > > I checked the archives and was able to easily remove the wing walk...from > the glue still stuck to the paint.... > > Is there an easy way to remove the glue? > I have tried Avgas, bug and tar remover, MEK, and paint thinner. None > really break down the glue....the Avgas does a real good job of final > cleaning of the areas that I have been able to remove the glue manually - > by > rubbing it in to boogers with my hands and manually picking the boogers > off! > > Any other ideas would be appreciated..... > > ________________________________________________________________________________
Subject: Re: Wing walk adhesive removal
Date: Sep 06, 2014
Try Goof-off from Loews or Home Depot=0A=0ALarry=0A=0A =0A=0A =0A =0A =0A=0A-----Original Message-----=0AFrom: Carl Froehlich <carl.froe hlich(at)verizon.net>=0ATo: rv-list =0ASent: Sat, Se p 6, 2014 12:00 pm=0ASubject: RE: RV-List: Wing walk adhesive arl.froehlich(at)verizon.net>=0A=0AReplacing the UHMW tape on the flaps I found a SMALL about of heat from a=0Ahot air gun loos ens up the glue well enough to come off the tape. Too much=0Aheat and you soften the paint. For the last bit of residue I used Coleman=0AFuel as the cleaner.=0A=0AYou might try Goo Gone for what you have.=0A=0ACarl=0A-----Original Message- ----=0AFrom: owner-rv-list-server(at)matronics.com=0A[mailto:owner-rv-list-server @matronics.com] On Behalf Of Ralph E. Capen=0ASent: Saturday, Se ptember 06, 2014 11:39 AM=0ATo: rv-list=0ASubject: RV-List: Wing E. Capen" =0A=0AI checked the archives and was able to easily remove the wing walk...from=0Athe glue stil l stuck to the paint....=0A=0AIs there an easy way to remove the glue?=0AI have tried Avgas, bug and tar remover, MEK, and paint thinner. None=0Areally break down the glue....the A vgas does a real good job of final=0Acleaning of the areas that I have been able to remove the glue manually - by=0Ar ubbing it in to boogers with my hands and manually pickin g the boogers=0Aoff!=0A=0AAny other ideas would be appreciated.... =========================== =========================== =========================== =========================== =========================0A=0A=0A =0A=0A =0A ________________________________________________________________________________
Date: Sep 06, 2014
Thanks to all who provided suggestions. I was able to remove the adhesive with Avgas after letting it soak for a couple of minutes and rubbing it off with a paper towel. I tried the Avgas one more time before going out to buy something else as it was available here at the hangar. Now I need to clean it well before putting on the new one! Ralph RV6A N822AR "Patience" @ N06 220hrs..... -----Original Message----- >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Sent: Sep 6, 2014 11:38 AM >To: rv-list >Subject: RV-List: Wing walk adhesive removal > > >I checked the archives and was able to easily remove the wing walk...from the glue still stuck to the paint.... > >Is there an easy way to remove the glue? >I have tried Avgas, bug and tar remover, MEK, and paint thinner. None really break down the glue....the Avgas does a real good job of final cleaning of the areas that I have been able to remove the glue manually - by rubbing it in to boogers with my hands and manually picking the boogers off! > >Any other ideas would be appreciated..... > > ________________________________________________________________________________
Date: Sep 06, 2014
This works really well. The friction heats the UHMW and glue and then shears it right off. http://www.amazon.com/Eraser-Pad-Pinstripe-Adhesive-Removal/dp/B0020HQRQC /ref=sr_1_2?s=automotive&ie=UTF8&qid=1314142476&sr=1-2 Probably takes 1/2 hour per flap. I tried scraping, solvent, and everything else, but this was the solution. Your local auto body shop probably has =98em too. From: don van santen Sent: Saturday, September 06, 2014 12:48 PM Subject: RE: RV-List: Wing walk adhesive removal Try 3m woodgrain and stripe adhesive remover. On Sep 6, 2014 9:04 AM, "Carl Froehlich" wrote: Replacing the UHMW tape on the flaps I found a SMALL about of heat from a hot air gun loosens up the glue well enough to come off the tape. Too much heat and you soften the paint. For the last bit of residue I used Coleman Fuel as the cleaner. You might try Goo Gone for what you have. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Saturday, September 06, 2014 11:39 AM To: rv-list Subject: RV-List: Wing walk adhesive removal I checked the archives and was able to easily remove the wing walk...from the glue still stuck to the paint.... Is there an easy way to remove the glue? I have tried Avgas, bug and tar remover, MEK, and paint thinner. None really break down the glue....the Avgas does a real good job of final cleaning of the areas that I have been able to remove the glue manually - by rubbing it in to boogers with my hands and manually picking the boogers off! Any other ideas would be appreciated..... ========== ist" target="_blank">http://www.matronics.com/Navigator?RV-List ========== FORUMS - _blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Sep 06, 2014
I'll remember that for the next time....there will be! -----Original Message----- From: kboatright1(at)comcast.net Sent: Sep 6, 2014 3:12 PM Subject: Re: RV-List: Wing walk adhesive removal This works really well. The friction heats the UHMW and glue and then shears it right off. http://www.amazon.com/Eraser-Pad-Pinstripe-Adhesive-Removal/dp/B0020HQRQC/ref=sr_1_2?s=automotive&ie=UTF8&qid=1314142476&sr=1-2 Probably takes 1/2 hour per flap. I tried scraping, solvent, and everything else, but this was the solution. Your local auto body shop probably has em too. From: don van santen Sent: Saturday, September 06, 2014 12:48 PM Subject: RE: RV-List: Wing walk adhesive removal Try 3m woodgrain and stripe adhesive remover. On Sep 6, 2014 9:04 AM, "Carl Froehlich" wrote: Replacing the UHMW tape on the flaps I found a SMALL about of heat from a hot air gun loosens up the glue well enough to come off the tape. Too much heat and you soften the paint. For the last bit of residue I used Coleman Fuel as the cleaner. You might try Goo Gone for what you have. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Saturday, September 06, 2014 11:39 AM Subject: RV-List: Wing walk adhesive removal I checked the archives and was able to easily remove the wing walk...from the glue still stuck to the paint.... Is there an easy way to remove the glue? I have tried Avgas, bug and tar remover, MEK, and paint thinner. None really break down the glue....the Avgas does a real good job of final cleaning of the areas that I have been able to remove the glue manually - by rubbing it in to boogers with my hands and manually picking the boogers off! Any other ideas would be appreciated..... ========== ist" target="_blank">http://www.matronics.com/Navigator?RV-List ========== FORUMS - _blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Sep 06, 2014
3M and others make an adhesive removing solvent which is safe for most paints and plastics. It's mostly Naphtha and Linoleic acid (the chemical extracted from citrus). You can purchase spray cans of it and it works great. It also is good a dissolving old lubricant from mechanisms. I rinse afterwards with alcohol to remove any residue that is left. You may have luck finding spray cans of it at an auto paint store. I believe Granger carries it. I purchase it by the gallon from Ace Hardware. My branch has to order it, but it shipping is free. That's significant since a gallon of it in a heavy can would be expensive to ship. One of the nice features of this product is that it has almost no health risks associated with its use... David -------------------------------------------------- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Saturday, September 06, 2014 8:38 AM Subject: RV-List: Wing walk adhesive removal > > I checked the archives and was able to easily remove the wing walk...from > the glue still stuck to the paint.... > > Is there an easy way to remove the glue? > I have tried Avgas, bug and tar remover, MEK, and paint thinner. None > really break down the glue....the Avgas does a real good job of final > cleaning of the areas that I have been able to remove the glue manually - > by rubbing it in to boogers with my hands and manually picking the > boogers off! > > Any other ideas would be appreciated..... > > > ________________________________________________________________________________
Date: Sep 06, 2014
Try Goofoff..... Works great. On Saturday, September 6, 2014 1:57 PM, David Burton wrote: 3M and others make an adhesive removing solvent which is safe for most paints and plastics. It's mostly Naphtha and Linoleic acid (the chemical extracted from citrus). You can purchase spray cans of it and it works great. It also is good a dissolving old lubricant from mechanisms. I rinse afterwards with alcohol to remove any residue that is left. You may have luck finding spray cans of it at an auto paint store. I believe Granger carries it. I purchase it by the gallon from Ace Hardware. My branch has to order it, but it shipping is free. That's significant since a gallon of it in a heavy can would be expensive to ship. One of the nice features of this product is that it has almost no health risks associated with its use... David -------------------------------------------------- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Saturday, September 06, 2014 8:38 AM Subject: RV-List: Wing walk adhesive removal > > I checked the archives and was able to easily remove the wing walk...from > the glue still stuck to the paint.... > > Is there an easy way to remove the glue? > I have tried Avgas, bug and tar remover, MEK, and paint thinner. None > really break down the glue....the Avgas does a real good job of final > cleaning of the areas that I have been able to remove the glue manually - > by rubbing it in to boogers with my hands and manually picking the > boogers off! > > Any other ideas would be appreciated..... > > > ________________________________________________________________________________
Subject: Anyone based at New Garden, PA (N57)?
Date: Sep 14, 2014
My wife has asked me to take her to Dover Saddlery in Hockessin, DE. N57 appears to be the closest airport - I'm thinking we'll fly in and get a cab for her shopping trip. My thoughts are that when asked to use the plane for a purpose - make it happen! Does the airport have an airport car? Any RV-ers based there wanting to go to Dover Saddlery? Thanks, Ralph Capen RV6A N822AR "Patience" @ N06 220+ hrs ________________________________________________________________________________
Subject: Want your input on iphone vs android
Date: Sep 18, 2014
My contract is up, I used hardly any data paying $91. also thinking about p ay as you go. Android has good reviews on flying apps as well as iphone. le t me know what you are using/thinking. Charlie --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Sep 18, 2014
Subject: Re: Want your input on iphone vs android
iPhone and iPad with Foreflight for over 3-years. Had an Android tablet a little over a year ago and I got rid of it after a short time as there were only bad aviation apps. On 09-18-2014 10:29 AM, cheathco(at)cox.net wrote: > My contract is up, I used hardly any data paying $91. also thinking > about pay as you go. Android has good reviews on flying apps as well > as iphone. let me know what you are using/thinking. Charlie > ________________________________________________________________________________
Date: Sep 18, 2014
I prefer Android in general and tried to be content with the flying apps, but they all fell short compared to those available on Apple. I eventually went Ipad mini and iPhone 5S. I still think it was the right choice, at least as far a flying related apps go. It might be a good opportunity to try the iPhone 6 Plus to meet your phone and tablet needs in one device. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Thu, Sep 18, 2014 at 10:29 AM, wrote: > My contract is up, I used hardly any data paying $91. also thinking > about pay as you go. Android has good reviews on flying apps as well as > iphone. let me know what you are using/thinking. Charlie > > > ------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus > <http://www.avast.com/> protection is active. > > * > > > * > > ________________________________________________________________________________
Date: Sep 18, 2014
On 9/18/2014 9:29 AM, cheathco(at)cox.net wrote: > My contract is up, I used hardly any data paying $91. also thinking > about pay as you go. Android has good reviews on flying apps as well > as iphone. let me know what you are using/thinking. Charlie > I'm currently using an iphone 4 (with no data plan) on ATT prepaid: $100 per year for 1000 minutes, and they roll over each year as long as you renew before the end of the year. You can also go month-to-month, but it's easier for me to pay once a year. I have SkyCharts Pro on the phone (I think it was a one-time charge of $20). Works great for my vfr cross country flying, but limited features; unlike the higher dollar programs. I also have a Nexus 7 tablet (1st generation) that works fine in the cockpit. 2nd gen are supposed to be even better. I'm running Avare on it (free); also works great, again with somewhat limited features. I've considered buying an android phone and switching phone service to one of the prepaid $50/month unlimited voice/data plans, but I don't need data on-the-go often enough to justify an extra $40/month for data. There are cheaper data plans out there for low volume use, especially for just phone use (no tablet connectivity). These days, a phone contract makes no sense unless you're 'grandfathered' into one of the old no-limit, no-throttle programs that no one sells anymore. If you have one of the grandfathered unlimited data plans, I'd bet you could 'sublet' your number to a friend/relative who needs lots of data, for enough money to get yourself a new phone/number/prepaid plan for free. :-) Charlie ________________________________________________________________________________
Date: Sep 18, 2014
On 9/18/2014 10:29 AM, cheathco(at)cox.net wrote: > My contract is up, I used hardly any data paying $91. also thinking > about pay as you go. Android has good reviews on flying apps as well > as iphone. let me know what you are using/thinking. Charlie Can't comment on iphone ..... I have AT&T service but like my buddy's T-mobile contract better. I might switch since they'll buy your contract. I don't use much data (2 GB) either, doing most stuff on my home wifi. Only time I seem to use data is looking at weather when I'm away from home. Also, when you're away from home, almost any fast food place has wifi. If you're a Brighthouse subscriber they have free wifi spread around too. I have android phone and tablet. I have anywheremap on the tablet that I fly with, but also have avare on both. I have lifetime IFR/VFR subscription for anywheremap, but that seems to be their lifetime, not mine. Avare is free, and is constantly being upgraded .... by volunteers who write the code so it should always be free ..... donations accepted. Linn ________________________________________________________________________________
Date: Sep 18, 2014
I got addicted to ForeFlight on the iPad. I got a WiFi only iPad with a Bad Elf GPS. While WiFi is needed for flight planning weather, I never had a situation where I was not able to find WiFi when needed. This of course eliminates the monthly data bill. I like the set up. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Thursday, September 18, 2014 10:30 AM Subject: RV-List: Want your input on iphone vs android My contract is up, I used hardly any data paying $91. also thinking about pay as you go. Android has good reviews on flying apps as well as iphone. let me know what you are using/thinking. Charlie _____ <http://www.avast.com/> This email is free from viruses and malware because avast! Antivirus <http://www.avast.com/> protection is active. ________________________________________________________________________________
Date: Sep 18, 2014
If you are using a newer iPhone 5or 5s and your contact is up you can use St raight talk for $45 a mouth unlimited talk/text and I think 2 gigs of Data. Sent from my Verizon iPhone > On Sep 18, 2014, at 9:29 AM, wrote: > > My contract is up, I used hardly any data paying $91. also thinking about p ay as you go. Android has good reviews on flying apps as well as iphone. let me know what you are using/thinking. Charlie > > > > This email is free from viruses and malware because avast! Antivirus prote ction is active. > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Sep 18, 2014
I am using an iPad Mini in the cockpit with Foreflight Pro. I love the software but the Mini screen is almost impossible to read on all but a very cloudy day. Does anyone know of a tablet or whatever that will run Foreflight, but has a sunlight readable screen? Garry Stout From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Thursday, September 18, 2014 11:30 AM Subject: Re: RV-List: Want your input on iphone vs android On 9/18/2014 9:29 AM, cheathco(at)cox.net wrote: My contract is up, I used hardly any data paying $91. also thinking about pay as you go. Android has good reviews on flying apps as well as iphone. let me know what you are using/thinking. Charlie I'm currently using an iphone 4 (with no data plan) on ATT prepaid: $100 per year for 1000 minutes, and they roll over each year as long as you renew before the end of the year. You can also go month-to-month, but it's easier for me to pay once a year. I have SkyCharts Pro on the phone (I think it was a one-time charge of $20). Works great for my vfr cross country flying, but limited features; unlike the higher dollar programs. I also have a Nexus 7 tablet (1st generation) that works fine in the cockpit. 2nd gen are supposed to be even better. I'm running Avare on it (free); also works great, again with somewhat limited features. I've considered buying an android phone and switching phone service to one of the prepaid $50/month unlimited voice/data plans, but I don't need data on-the-go often enough to justify an extra $40/month for data. There are cheaper data plans out there for low volume use, especially for just phone use (no tablet connectivity). These days, a phone contract makes no sense unless you're 'grandfathered' into one of the old no-limit, no-throttle programs that no one sells anymore. If you have one of the grandfathered unlimited data plans, I'd bet you could 'sublet' your number to a friend/relative who needs lots of data, for enough money to get yourself a new phone/number/prepaid plan for free. :-) Charlie ________________________________________________________________________________
Date: Sep 18, 2014
Have had an AT&T iPhone so long that I have UNLIMITED data plus get a 25% discount from the company I retired from on my AT&T data and voice plans. 32GB iPad2 is AT&T but was never activated. Only used on WiFi networks at home, hotels, and FBOs. Thought it was worth the $130 Apple premium to get a built in GPS that will not break off or require an additional charger. BTW, I typically use less than 1GB data per month on my iPhone 5S except for when I travel or am on vacation. Could move to cheaper dataplan but cannot get 25% discount on the cheaper data plan. With the discount, I am only $2.50 a month more than the limited data plan. When traveling or on vacation, I save by keeping my unlimited iPhone data. Replacement iPad was / is 64GB iPad Mini with Retina on T-Mobile. T-Mobile has FREE 200 MB each month for life. Have used iPad Mini a few times on Cell network but T-Mobile typically only has data in big cities. Foreflight is my standard App. Have SkyCharts Pro but quit using it as Foreflight has the best user interface. WingX, Garmin Pilot, and FlyQ (Seattle Avionics) are all good but I like Foreflight best so I pay Foreflight for a subscription the past 3-years. Any iPad you get for aviation use REQUIRES Anti Glare Screen protector. iPad is not very usable in the RV Cockpit without the Anti Glare Screen Protector. Gary > On Sep 18, 2014, at 9:29 AM, > > wrote: > >> My contract is up, I used hardly any data paying $91. also thinking >> about pay as you go. Android has good reviews on flying apps as well >> as iphone. let me know what you are using/thinking. Charlie >> ________________________________________________________________________________
From: "Fisher Paul A." <FisherPaulA(at)johndeere.com>
Date: Sep 18, 2014
I use an Android tablet that is WiFi only (no data contract at all!) and ru n Naviator (http://www.naviatorapp.com/) as my primary flight application. It's not free ($35/year), but it has been worth the price from my perspect ive. The developer is very responsive to issues that people bring up on th e forum. As someone else mentioned, I too have been experimenting with Avare (http:/ /apps4av.com/avare-overview/), but I don't think it is quite there yet. Bu t as was also mentioned it is being upgraded regularly, so maybe it will ge t there soon! I've also been playing with Fltpln Go (http://fltplan.com) which is also fr ee. It has a lot of nice features as well. As long as you have WiFi available on the ground, I don't see a big need fo r a data plan on my tablet. I also have an Android phone, but all of my fl ight planning is done on the tablet. Just my $0.02. Paul A. Fisher RV-7A N18PF ________________________________________________________________________________
Date: Sep 18, 2014
Garry: You must get an Anti Glare screen protector. I typically use a CHEAP one. Here is a link to one that is reasonable in cost. http://smile.amazon.com/Halo-Screen-Protector-Anti-Glare-Retina/dp/B00AOK54MA/ref=sr_1_2?ie=UTF8&qid=1411058952&sr=8-2&keywords=iPad+mini+anti+glare+screen+protector I agree that the iPad is not very useful in the cockpit without an Anti Glare Screen protector. I used an iPad with an Anti Glare screen protector in Southern California for more than two years with very few viewing issues in my RV. Yes I fly over 100 hours per year. Gary On 09-18-2014 12:07 PM, Garry Stout wrote: > > I am using an iPad Mini in the cockpit with Foreflight Pro. I love > the software but the Mini screen is almost impossible to read on all > but a very cloudy day. Does anyone know of a tablet or whatever that > will run Foreflight, but has a sunlight readable screen? > > > > Garry Stout > > > > > > *From:*owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Charlie England > *Sent:* Thursday, September 18, 2014 11:30 AM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: Want your input on iphone vs android > > > > On 9/18/2014 9:29 AM, cheathco(at)cox.net wrote: > > My contract is up, I used hardly any data paying $91. also > thinking about pay as you go. Android has good reviews on flying > apps as well as iphone. let me know what you are using/thinking. > Charlie > > > > I'm currently using an iphone 4 (with no data plan) on ATT prepaid: > $100 per year for 1000 minutes, and they roll over each year as long > as you renew before the end of the year. You can also go > month-to-month, but it's easier for me to pay once a year. > > I have SkyCharts Pro on the phone (I think it was a one-time charge of > $20). Works great for my vfr cross country flying, but limited > features; unlike the higher dollar programs. > > I also have a Nexus 7 tablet (1st generation) that works fine in the > cockpit. 2nd gen are supposed to be even better. I'm running Avare on > it (free); also works great, again with somewhat limited features. > > I've considered buying an android phone and switching phone service to > one of the prepaid $50/month unlimited voice/data plans, but I don't > need data on-the-go often enough to justify an extra $40/month for > data. There are cheaper data plans out there for low volume use, > especially for just phone use (no tablet connectivity). > > These days, a phone contract makes no sense unless you're > 'grandfathered' into one of the old no-limit, no-throttle programs > that no one sells anymore. > > If you have one of the grandfathered unlimited data plans, I'd bet you > could 'sublet' your number to a friend/relative who needs lots of > data, for enough money to get yourself a new phone/number/prepaid plan > for free. :-) > > Charlie > > * * > ========================http://www.matronics.=============== > http://forums.matronics.com - List Contribution Web generous > nbsp; --> http://www.matronics.com/c > * * > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > * > > > * ________________________________________________________________________________
Date: Sep 18, 2014
I use Brando anti-glare protectors on everything. They work real well. Rumor has it the next iPad Air will have an anti glare screen, so I may not h ave to anymore. I like the way the Brando feels, too. Tim > On Sep 18, 2014, at 11:53 AM, "Gary A. Sobek" wrot e: > > Garry: > > You must get an Anti Glare screen protector. I typically use a CHEAP one. > > Here is a link to one that is reasonable in cost. > http://smile.amazon.com/Halo-Screen-Protector-Anti-Glare-Retina/dp/B00AOK5 4MA/ref=sr_1_2?ie=UTF8&qid=1411058952&sr=8-2&keywords=iPad+mini+an ti+glare+screen+protector > > I agree that the iPad is not very useful in the cockpit without an Anti Gl are Screen protector. I used an iPad with an Anti Glare screen protecto r in Southern California for more than two years with very few viewing issue s in my RV. Yes I fly over 100 hours per year. > > Gary > >> On 09-18-2014 12:07 PM, Garry Stout wrote: >> I am using an iPad Mini in the cockpit with Foreflight Pro. I love the s oftware but the Mini screen is almost impossible to read on all but a very c loudy day. Does anyone know of a tablet or whatever that will run Forefligh t, but has a sunlight readable screen? >> >> Garry Stout >> >> >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@mat ronics.com] On Behalf Of Charlie England >> Sent: Thursday, September 18, 2014 11:30 AM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: Want your input on iphone vs android >> >> On 9/18/2014 9:29 AM, cheathco(at)cox.net wrote: >> My contract is up, I used hardly any data paying $91. also thinking about pay as you go. Android has good reviews on flying apps as well as iphone. l et me know what you are using/thinking. Charlie >> >> I'm currently using an iphone 4 (with no data plan) on ATT prepaid: $100 p er year for 1000 minutes, and they roll over each year as long as you renew b efore the end of the year. You can also go month-to-month, but it's easier f or me to pay once a year. >> >> I have SkyCharts Pro on the phone (I think it was a one-time charge of $2 0). Works great for my vfr cross country flying, but limited features; unlik e the higher dollar programs. >> >> I also have a Nexus 7 tablet (1st generation) that works fine in the cock pit. 2nd gen are supposed to be even better. I'm running Avare on it (free); also works great, again with somewhat limited features. >> >> I've considered buying an android phone and switching phone service to on e of the prepaid $50/month unlimited voice/data plans, but I don't need data on-the-go often enough to justify an extra $40/month for data. There are ch eaper data plans out there for low volume use, especially for just phone use (no tablet connectivity). >> >> These days, a phone contract makes no sense unless you're 'grandfathered' into one of the old no-limit, no-throttle programs that no one sells anymor e. >> >> If you have one of the grandfathered unlimited data plans, I'd bet you co uld 'sublet' your number to a friend/relative who needs lots of data, for en ough money to get yourself a new phone/number/prepaid plan for free. :-) >> >> Charlie >> >> ========================h ttp://www.matronics.=============== >> http://forums.matronics.com - List Contribution Web generous nbsp ; --> http://www.matronics.com/c >> >> >> >> new,courier" size="2">http://www.matronics.com/Navigator?RV-List >> s.com">http://forums.matronics.com >> om/contribution">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Sep 18, 2014
Subject: prepaid android phone pireps?
Since Charlie H brought it up.... Anyone have a recommendation for an inexpensive android phone with, at minimum, the hardware capabilities of something like an iphone 4/4s? I'm considering the replacement of my iphone 4 with an android device. I'd like the ability to move between carriers, but be able to continue using my ATT gophone sim card at present. A potential future use would be as a 'hot spot' for my Nexus 7 tablet & my wife's ipad. Any thoughts on an inexpensive unlocked phone? I don't need 'tomorrow's state of the art'. Buying used doesn't necessarily bother me, as long as it's truly unlocked and I can use my ATT prepaid (gophone) sim card in the short term. Thanks, Charlie ________________________________________________________________________________
Date: Sep 18, 2014
Subject: Re: prepaid android phone pireps?
Go on ebay ..... lots of hits for android phone ..... You should do some homework to find what models have the capabilities you want. The Samsung S5 has a pressure sensor .... my S4 doesn't. I upgraded from an old flip phone and didn't know what I really had! Linn On 9/18/2014 9:42 PM, Charlie England wrote: > > Since Charlie H brought it up.... > > Anyone have a recommendation for an inexpensive android phone with, at > minimum, the hardware capabilities of something like an iphone 4/4s? > I'm considering the replacement of my iphone 4 with an android device. > I'd like the ability to move between carriers, but be able to continue > using my ATT gophone sim card at present. A potential future use would > be as a 'hot spot' for my Nexus 7 tablet & my wife's ipad. > > Any thoughts on an inexpensive unlocked phone? I don't need > 'tomorrow's state of the art'. Buying used doesn't necessarily bother > me, as long as it's truly unlocked and I can use my ATT prepaid > (gophone) sim card in the short term. > > Thanks, > > Charlie > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Sep 18, 2014
I was hoping someone had already done that research. :-) Seriously, I have been looking, but there are so many choices, it's just about impossible to sort through them. Thanks, Charlie On 9/18/2014 9:45 PM, Linn Walters wrote: > > Go on ebay ..... lots of hits for android phone ..... > You should do some homework to find what models have the capabilities > you want. The Samsung S5 has a pressure sensor .... my S4 doesn't. I > upgraded from an old flip phone and didn't know what I really had! > Linn > > On 9/18/2014 9:42 PM, Charlie England wrote: >> >> Since Charlie H brought it up.... >> >> Anyone have a recommendation for an inexpensive android phone with, >> at minimum, the hardware capabilities of something like an iphone >> 4/4s? I'm considering the replacement of my iphone 4 with an android >> device. I'd like the ability to move between carriers, but be able to >> continue using my ATT gophone sim card at present. A potential future >> use would be as a 'hot spot' for my Nexus 7 tablet & my wife's ipad. >> >> Any thoughts on an inexpensive unlocked phone? I don't need >> 'tomorrow's state of the art'. Buying used doesn't necessarily bother >> me, as long as it's truly unlocked and I can use my ATT prepaid >> (gophone) sim card in the short term. >> >> Thanks, >> >> Charlie >> >> >> >> >> >> ________________________________________________________________________________
Date: Sep 19, 2014
Thanks Tim. Garry From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 18, 2014 1:25 PM Subject: Re: RV-List: Want your input on iphone vs android I use Brando anti-glare protectors on everything. They work real well. Rumor has it the next iPad Air will have an anti glare screen, so I may not have to anymore. I like the way the Brando feels, too. Tim On Sep 18, 2014, at 11:53 AM, "Gary A. Sobek" > wrote: Garry: You must get an Anti Glare screen protector. I typically use a CHEAP one. Here is a link to one that is reasonable in cost. http://smile.amazon.com/Halo-Screen-Protector-Anti-Glare-Retina/dp/B00AOK 54MA/ref=sr_1_2?ie=UTF8 <http://smile.amazon.com/Halo-Screen-Protector-Anti-Glare-Retina/dp/B00AO K54MA/ref=sr_1_2?ie=UTF8&qid=1411058952&sr=8-2&keywords=iPad+mi ni+anti+glare+screen+protector> &qid=1411058952&sr=8-2&keywords=iPad+mini+anti+glare+screen+protect or ________________________________________________________________________________
Date: Sep 19, 2014
You need a Skyguardz shield. No glare and no finger prints. Sent from my iPad > On Sep 18, 2014, at 12:07 PM, "Garry Stout" wrote : > > I am using an iPad Mini in the cockpit with Foreflight Pro. I love the so ftware but the Mini screen is almost impossible to read on all but a very cl oudy day. Does anyone know of a tablet or whatever that will run Foreflight , but has a sunlight readable screen? > > Garry Stout > > > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matr onics.com] On Behalf Of Charlie England > Sent: Thursday, September 18, 2014 11:30 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Want your input on iphone vs android > > On 9/18/2014 9:29 AM, cheathco(at)cox.net wrote: > My contract is up, I used hardly any data paying $91. also thinking about p ay as you go. Android has good reviews on flying apps as well as iphone. let me know what you are using/thinking. Charlie > > I'm currently using an iphone 4 (with no data plan) on ATT prepaid: $100 p er year for 1000 minutes, and they roll over each year as long as you renew b efore the end of the year. You can also go month-to-month, but it's easier f or me to pay once a year. > > I have SkyCharts Pro on the phone (I think it was a one-time charge of $20 ). Works great for my vfr cross country flying, but limited features; unlike the higher dollar programs. > > I also have a Nexus 7 tablet (1st generation) that works fine in the cockp it. 2nd gen are supposed to be even better. I'm running Avare on it (free); a lso works great, again with somewhat limited features. > > I've considered buying an android phone and switching phone service to one of the prepaid $50/month unlimited voice/data plans, but I don't need data o n-the-go often enough to justify an extra $40/month for data. There are chea per data plans out there for low volume use, especially for just phone use ( no tablet connectivity). > > These days, a phone contract makes no sense unless you're 'grandfathered' i nto one of the old no-limit, no-throttle programs that no one sells anymore. > > If you have one of the grandfathered unlimited data plans, I'd bet you cou ld 'sublet' your number to a friend/relative who needs lots of data, for eno ugh money to get yourself a new phone/number/prepaid plan for free. :-) > > Charlie > > ========================ht tp://www.matronics.=============== > http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Sep 19, 2014
Subject: an outfit called Select Vehicle Marketing
I have an ad to sell my plane on Barnstormers. A salesman from Select Vehicle Marketing saw it and called me and wants me to pay him $350 to sell my plane. He has a story that sounds good. Of course everybody has a good story. Has any one heard of these guys? Is this a scam? If it's not a scam, are they competent? Thanks, --- Tom Sargent ________________________________________________________________________________
Date: Sep 19, 2014
Subject: Re: an outfit called Select Vehicle Marketing
On 9/19/2014 12:38 PM, Thomas Sargent wrote: > I have an ad to sell my plane on Barnstormers. A salesman from Select > Vehicle Marketing saw it and called me and wants me to pay him $350 to > sell my plane. He has a story that sounds good. Of course everybody > has a good story. > > Has any one heard of these guys? Is this a scam? If it's not a scam, > are they competent? > > Thanks, > > --- > Tom Sargent Not that BBB is particularly reliable as an evaluator (the businesses pay their bills), but: http://www.bbb.org/nebraska/business-reviews/internet-marketing-services/select-vehicle-marketing-in-omaha-ne-300079104/complaints The 1st complaint I read, said that the company basically took the guy's money and advertised his vehicle on the same sites where he was already advertising. I'd tell him that if he has a buyer, bring you a contract and you'll pay a *commission* of $350 at closing, but you won't pay him to advertise for you. Charlie ________________________________________________________________________________
Date: Sep 19, 2014
I had them do the same thing when I advertised my Rans. The thing they tou ted was voice over video for your advertisement plus a bunch of other things . So I visited their web site and clicked on other airplane advertisement s to check out this feature. I was very unimpressed, their robot like voic e over was lame and clearly didn't know the vernacular so the ad sounded jun ky, they didn't take the time to pronounce the abbreviations often used, s o for example 100 hp was not pronounced as horse power but as "hp". So I de cided no to them. Bob Newman TCW Technologies, LLC 610-928-3420 > On Sep 19, 2014, at 1:38 PM, Thomas Sargent wrote: > > I have an ad to sell my plane on Barnstormers. A salesman from Select Veh icle Marketing saw it and called me and wants me to pay him $350 to sell my p lane. He has a story that sounds good. Of course everybody has a good story . > > Has any one heard of these guys? Is this a scam? If it's not a scam, are they competent? > > Thanks, > > --- > Tom Sargent > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Sep 22, 2014
Subject: testing (no reply needed)
charlie ________________________________________________________________________________
Date: Oct 08, 2014
Subject: WTB Grand Rapids EIS (and EFIS?)
Anyone have an EIS 4000 or EIS 6000 that's lying around after a panel upgrade? I need more sensor inputs than I have available with my EIS 2000. And if you have an EFIS, I might be interested in that, as well. Thanks, Charlie ________________________________________________________________________________
Date: Oct 08, 2014
Subject: Re: WTB Grand Rapids EIS (and EFIS?)
Let me know if you find two of 'em, Charlie. I'm upgrading to GRT glass this winter and need a 4000 to replace my 2000 as well ;-) -Stormy On Wed, Oct 8, 2014 at 8:39 AM, Charlie England wrote: > Anyone have an EIS 4000 or EIS 6000 that's lying around after a panel > upgrade? I need more sensor inputs than I have available with my EIS 2000. > > And if you have an EFIS, I might be interested in that, as well. > > Thanks, > > Charlie > > * > > > * > > ________________________________________________________________________________
Date: Oct 08, 2014
R3J0IHdpbGwgdXNlIDIgRWlzIG1vZHVsZXMgaWYgeW91IGhhdmUgYSBzcGFyZSBzZXJpYWwgcG9y dAoKClNlbnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBzbWFydHBob25lCgo8ZGl2 Pi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS08L2Rpdj48ZGl2PkZyb206IEJpbGwg Qm95ZCA8c3BvcnRhdjhyQGdtYWlsLmNvbT4gPC9kaXY+PGRpdj5EYXRlOjEwLzA4LzIwMTQgIDA2 OjMyICAoR01ULTA4OjAwKSA8L2Rpdj48ZGl2PlRvOiBydi1saXN0QG1hdHJvbmljcy5jb20gPC9k aXY+PGRpdj5TdWJqZWN0OiBSZTogUlYtTGlzdDogV1RCIEdyYW5kIFJhcGlkcyBFSVMgKGFuZCBF RklTPykgPC9kaXY+PGRpdj4KPC9kaXY+TGV0IG1lIGtub3cgaWYgeW91IGZpbmQgdHdvIG9mICdl bSwgQ2hhcmxpZS4gIEknbSB1cGdyYWRpbmcgdG8gR1JUIGdsYXNzIHRoaXMgd2ludGVyIGFuZCBu ZWVkIGEgNDAwMCB0byByZXBsYWNlIG15IDIwMDAgYXMgd2VsbCA7LSkKCi1TdG9ybXkKCk9uIFdl ZCwgT2N0IDgsIDIwMTQgYXQgODozOSBBTSwgQ2hhcmxpZSBFbmdsYW5kIDxjZWVuZ2xhbmQ3QGdt YWlsLmNvbT4gd3JvdGU6CkFueW9uZSBoYXZlIGFuIEVJUyA0MDAwIG9yIEVJUyA2MDAwIHRoYXQn cyBseWluZyBhcm91bmQgYWZ0ZXIgYSBwYW5lbCB1cGdyYWRlPyBJIG5lZWQgbW9yZSBzZW5zb3Ig aW5wdXRzIHRoYW4gSSBoYXZlIGF2YWlsYWJsZSB3aXRoIG15IEVJUyAyMDAwLgoKQW5kIGlmIHlv dSBoYXZlIGFuIEVGSVMsIEkgbWlnaHQgYmUgaW50ZXJlc3RlZCBpbiB0aGF0LCBhcyB3ZWxsLgoK VGhhbmtzLAoKQ2hhcmxpZQoKCnQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9SVi1MaXN0CnRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KX2JsYW5rIj5odHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCgoKCgpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBU aGUgUlYtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1 cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2gg YXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3 LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9y ZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWLUxp c3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpf LT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEK Xy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAg ICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3Ug Zm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQoK ________________________________________________________________________________
Date: Oct 09, 2014
Interesting; I'll keep that in mind. Thanks, Charlie On 10/8/2014 11:33 PM, Rob Henderson wrote: > Grt will use 2 Eis modules if you have a spare serial port > > > Sent from my Verizon Wireless 4G LTE smartphone > > > -------- Original message -------- > From: Bill Boyd > Date:10/08/2014 06:32 (GMT-08:00) > To: rv-list(at)matronics.com > Subject: Re: RV-List: WTB Grand Rapids EIS (and EFIS?) > > Let me know if you find two of 'em, Charlie. I'm upgrading to GRT > glass this winter and need a 4000 to replace my 2000 as well ;-) > > -Stormy > > On Wed, Oct 8, 2014 at 8:39 AM, Charlie England > wrote: > > Anyone have an EIS 4000 or EIS 6000 that's lying around after a > panel upgrade? I need more sensor inputs than I have available > with my EIS 2000. > > And if you have an EFIS, I might be interested in that, as well. > > Thanks, > > Charlie > ________________________________________________________________________________
Date: Oct 23, 2014
Subject: Anyone want to get rid of their LASAR system
I have one in my 6A and like it a lot. Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. Anyone out there replaced their LASAR and have it sitting on their shelf? Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. Ralph Capen ________________________________________________________________________________
Date: Oct 23, 2014
Subject: Re: Anyone want to get rid of their LASAR system
On 10/23/2014 8:06 AM, Ralph E. Capen wrote: > > > I have one in my 6A and like it a lot. > Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. > > Anyone out there replaced their LASAR and have it sitting on their shelf? > Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. > > Ralph Capen > There were a couple on ebay recently; don't know if they are still there. ________________________________________________________________________________
Date: Oct 23, 2014
Thanks Charlie - I'll look. -----Original Message----- >From: Charlie England <ceengland7(at)gmail.com> >Sent: Oct 23, 2014 9:17 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Anyone want to get rid of their LASAR system > > >On 10/23/2014 8:06 AM, Ralph E. Capen wrote: >> >> >> I have one in my 6A and like it a lot. >> Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. >> >> Anyone out there replaced their LASAR and have it sitting on their shelf? >> Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. >> >> Ralph Capen >> >There were a couple on ebay recently; don't know if they are still there. > > ________________________________________________________________________________
Date: Oct 23, 2014
I recommend just jumping to dual Pmags. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, October 23, 2014 9:07 AM Subject: RV-List: Anyone want to get rid of their LASAR system I have one in my 6A and like it a lot. Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. Anyone out there replaced their LASAR and have it sitting on their shelf? Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. Ralph Capen ________________________________________________________________________________
Date: Oct 23, 2014
>From time to time, VAF has listed LASAR parts and systems for sale. Champion sells the publications needed for overhaul. Typically all that needs replaced is the PLASTIC Cam that activates the points. When the cam wears down, the points do not open and then the electronic ignition part no longer works. http://www.championaerospace.com/products/slick-magnetos/ On 10-23-2014 9:29 AM, Ralph E. Capen wrote: > > > Thanks Charlie - I'll look. > > > -----Original Message----- >> From: Charlie England <ceengland7(at)gmail.com> >> Sent: Oct 23, 2014 9:17 AM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: Anyone want to get rid of their LASAR system >> >> >> On 10/23/2014 8:06 AM, Ralph E. Capen wrote: >>> >>> >>> I have one in my 6A and like it a lot. >>> Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. >>> >>> Anyone out there replaced their LASAR and have it sitting on their shelf? >>> Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. >>> >>> Ralph Capen >>> >> There were a couple on ebay recently; don't know if they are still there. >> >> >> >> > > ________________________________________________________________________________
Date: Oct 23, 2014
Good thought Gary - after building an airplane, maybe, I CAN overhaul a mag.... -----Original Message----- >From: "Gary A. Sobek" <RV6_Flyer(at)hotmail.com> >Sent: Oct 23, 2014 10:07 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Anyone want to get rid of their LASAR system > > >>From time to time, VAF has listed LASAR parts and systems for sale. > >Champion sells the publications needed for overhaul. Typically all that >needs replaced is the PLASTIC Cam that activates the points. When the >cam wears down, the points do not open and then the electronic ignition >part no longer works. >http://www.championaerospace.com/products/slick-magnetos/ > > >On 10-23-2014 9:29 AM, Ralph E. Capen wrote: >> >> >> Thanks Charlie - I'll look. >> >> >> >> >> -----Original Message----- >>> From: Charlie England <ceengland7(at)gmail.com> >>> Sent: Oct 23, 2014 9:17 AM >>> To: rv-list(at)matronics.com >>> Subject: Re: RV-List: Anyone want to get rid of their LASAR system >>> >>> >>> On 10/23/2014 8:06 AM, Ralph E. Capen wrote: >>>> >>>> >>>> I have one in my 6A and like it a lot. >>>> Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. >>>> >>>> Anyone out there replaced their LASAR and have it sitting on their shelf? >>>> Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. >>>> >>>> Ralph Capen >>>> >>> There were a couple on ebay recently; don't know if they are still there. >>> >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 23, 2014
For the price - potentially good idea! -----Original Message----- >From: Carl Froehlich <carl.froehlich(at)verizon.net> >Sent: Oct 23, 2014 9:52 AM >To: rv-list(at)matronics.com, 'lycoming engine list' >Subject: RE: RV-List: Anyone want to get rid of their LASAR system > > >I recommend just jumping to dual Pmags. > >Carl > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Thursday, October 23, 2014 9:07 AM >To: rv-list; lycoming engine list >Subject: RV-List: Anyone want to get rid of their LASAR system > > >I have one in my 6A and like it a lot. >Knowing that the magneto portions will need to be inspected / overhauled at >the 500 hr mark - I am thinking that having spares would keep me in the air >while I await the refurbishment...if the price is halfway right. > >Anyone out there replaced their LASAR and have it sitting on their shelf? >Let me know if there was a failure mode, you wore it out, didn't like some >of its 'features' or whatever...along with what you want for it. > >Ralph Capen > > ________________________________________________________________________________
Date: Nov 01, 2014
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2014
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2014
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2014
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 10, 2014
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 12, 2014
Subject: Make Sure You're Listed! List of Contributors Published in December!
Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 14, 2014
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 16, 2014
If anybody is interested I have a complete Lazar ignition test kit with case. Tom On Thu, Oct 23, 2014 at 9:17 AM, Charlie England wrote: > > On 10/23/2014 8:06 AM, Ralph E. Capen wrote: > >> >> >> I have one in my 6A and like it a lot. >> Knowing that the magneto portions will need to be inspected / overhauled >> at the 500 hr mark - I am thinking that having spares would keep me in the >> air while I await the refurbishment...if the price is halfway right. >> >> Anyone out there replaced their LASAR and have it sitting on their shelf? >> Let me know if there was a failure mode, you wore it out, didn't like >> some of its 'features' or whatever...along with what you want for it. >> >> Ralph Capen >> >> There were a couple on ebay recently; don't know if they are still there. > > ________________________________________________________________________________
Date: Nov 16, 2014
Are you talking about the T300 Timing tool? From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tom Wright Sent: Sunday, November 16, 2014 7:07 PM Subject: Re: RV-List: Anyone want to get rid of their LASAR system If anybody is interested I have a complete Lazar ignition test kit with case. Tom On Thu, Oct 23, 2014 at 9:17 AM, Charlie England > wrote: > On 10/23/2014 8:06 AM, Ralph E. Capen wrote: > I have one in my 6A and like it a lot. Knowing that the magneto portions will need to be inspected / overhauled at the 500 hr mark - I am thinking that having spares would keep me in the air while I await the refurbishment...if the price is halfway right. Anyone out there replaced their LASAR and have it sitting on their shelf? Let me know if there was a failure mode, you wore it out, didn't like some of its 'features' or whatever...along with what you want for it. Ralph Capen There were a couple on ebay recently; don't know if they are still there. ist" target="_blank">http://www.matronics.com/Navigator?RV-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution <http://www.aeroelectric.com> <http://www.buildersbooks.com> <http://www.homebuilthelp.com> <http://www.mypilotstore.com> ________________________________________________________________________________
Date: Nov 17, 2014
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2014
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 21, 2014
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 23, 2014
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2014
Subject: Fund Raiser Behind By 20% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 20%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 25, 2014
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 26, 2014
Subject: Giving Thanks - Your List Contribution...
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2014
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2014
Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2014
Subject: rv8 canopy keeper rivet
What is the best way to remove the canopy keeper rivets? =C2-The usual tr ick of turning the drill chuck slowing by hand doesn't work because the ple xi is so soft it allows the rivet to spin with the drill even at low speeds . Thanks,Sam RayRV8 ________________________________________________________________________________
Date: Nov 30, 2014
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 51, so don't reminde me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 07, 2014
Subject: 3 RV items for sale
I am cleaning out the hangar and have 3 items that might be of use to some one. All are new, never used, but pretty old. All prices include shipping! Anybody interested? Make an offer. I can't bring my self to throw them out. 1- Koger Sun Shade for RV-6A (7A, too, I guess). Probably 8 years old. New. $35. 2- A fuel filter that was shipped with my AirFlow Performance fuel injection system. I used an AndAir gascolator which has a finer screen than the AFP unit, so I never used it. This is from 1999. $35. 3- The RV-6A battery box circa 2000. This mounts in the cabin, up against the fire wall and is large - to hold a Gill or Concorde battery (NOT a PC-680). I put my PC-680 in that same place, but made my own mount to hold it. $20 -- Tom Sargent ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: Re: 3 RV items for sale
Date: Dec 07, 2014
Hi Tom....I=99ll take the sunshade if you still have it. Please email/call me or send your number. Evan evmeg(at)snowcrest.net 530-247-0375 home 530-351-1776 cell From: Thomas Sargent Sent: Sunday, December 07, 2014 8:47 AM Subject: RV-List: 3 RV items for sale I am cleaning out the hangar and have 3 items that might be of use to some one. All are new, never used, but pretty old. All prices include shipping! Anybody interested? Make an offer. I can't bring my self to throw them out. 1- Koger Sun Shade for RV-6A (7A, too, I guess). Probably 8 years old. New. $35. 2- A fuel filter that was shipped with my AirFlow Performance fuel injection system. I used an AndAir gascolator which has a finer screen than the AFP unit, so I never used it. This is from 1999. $35. 3- The RV-6A battery box circa 2000. This mounts in the cabin, up against the fire wall and is large - to hold a Gill or Concorde battery (NOT a PC-680). I put my PC-680 in that same place, but made my own mount to hold it. $20 -- Tom Sargent ________________________________________________________________________________
Date: Dec 08, 2014
The Koger sun shade and the AFP filter have been spoken for. On Sun, Dec 7, 2014 at 9:47 AM, Thomas Sargent wrote: > I am cleaning out the hangar and have 3 items that might be of use to some > one. All are new, never used, but pretty old. All prices include > shipping! Anybody interested? Make an offer. I can't bring my self to > throw them out. > > 1- Koger Sun Shade for RV-6A (7A, too, I guess). Probably 8 years old. > New. $35. > > 2- A fuel filter that was shipped with my AirFlow Performance fuel > injection system. I used an AndAir gascolator which has a finer screen than > the AFP unit, so I never used it. This is from 1999. $35. > > 3- The RV-6A battery box circa 2000. This mounts in the cabin, up against > the fire wall and is large - to hold a Gill or Concorde battery (NOT a > PC-680). I put my PC-680 in that same place, but made my own mount to hold > it. $20 > > -- > Tom Sargent > -- Tom Sargent ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Re: RV-List Digest: 2 Msgs - 12/07/14
Tom, I'll take the filter and sunshade if still available. Or either if one is already gone. Let me know where to send a check or Paypal. Thanks, Vince Frazier Flyboy Accessories 3963 Caborn Road North Mount Vernon, IN 47620 812-464-1839 office 812-449-0230 cell www.flyboyaccessories.com > > ________________________________ Message 1 > _____________________________________ > > > Subject: RV-List: 3 RV items for sale > From: Thomas Sargent <sarg314(at)gmail.com> > > I am cleaning out the hangar and have 3 items that might be of use to some > one. All are new, never used, but pretty old. All prices include > shipping! Anybody interested? Make an offer. I can't bring my self to > throw them out. > > 1- Koger Sun Shade for RV-6A (7A, too, I guess). Probably 8 years old. > New. $35. > > 2- A fuel filter that was shipped with my AirFlow Performance fuel > injection system. I used an AndAir gascolator which has a finer screen than > the AFP unit, so I never used it. This is from 1999. $35. > > 3- The RV-6A battery box circa 2000. This mounts in the cabin, up against > the fire wall and is large - to hold a Gill or Concorde battery (NOT a > PC-680). I put my PC-680 in that same place, but made my own mount to hold > it. $20 > > -- > Tom Sargent > > ________________________________________________________________________________
Date: Dec 24, 2014
Subject: 2014 List of Contributors
Dear Listers, The 2014 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2014 Fund Raiser List of Contributors: http://www.matronics.com/loc/2014.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: New (Free) Aviation App
Date: Jan 03, 2015
"Airport Courtesy Cars" is a new Google Play/Apple iPhone app that lists over 1100 airports nationwide that have crew/courtesy cars. Make sure you search for it in the phone store, as searching from a tablet won't work. You can load it on an iPad by changing the search function in the app store from iPad apps to iPhone apps.You can dial the listing directly from the app to see if a car is available. If you have a listing that I missed, or a correction, you can email me via the app, or to airportcars101(at)gmail.com. Thanks for looking. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Driver Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436581#436581 Attachments: http://forums.matronics.com//files/appcoverpage_531.png ________________________________________________________________________________
Subject: Cleaning fuel injectors
Date: Jan 04, 2015
I have an Air Flow Performance fuel injection system on my Lycoming O-320. The AFP manual recommends cleaning the fuel injectors every 100 hours. Other than soaking in Hoppes #9, no detailed instructions are given for cleaning the injectors. What is the best, approved, method for cleaning fuel injectors? Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Subject: Re: Cleaning fuel injectors
Date: Jan 04, 2015
=0AWhy not ask the expert?=0A =0Adon(at)airflowperformance.com=0A=0A =0A =0A =0A-----Original Message-----=0AFrom: Charles Brame <ChasB@satx .rr.com>=0ATo: List RV =0ASent: Sun, Jan 4, 2015 11:22 am=0ASubject: RV-List: Cleaning fuel injectors=0A=0A=0A-- I have an Air Flow Performance fuel injection system on my Lycoming O-320. The =0AAFP manual recommends cleaning the fuel injectors every 100 hours. Other than =0Asoaking in Hoppes #9, no detailed instructions are given for cleaning the =0Ainject ors.=0A=0AWhat is the best, approved, method for cleaning fuel =========================== =========================== -Matt =========================== =========================== =========================== ================0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Jan 04, 2015
I soak mine for an hour, careful not to mix them up. Blow out with compressed air No poking with wire or anything. Greg On Jan 4, 2015 11:26 AM, "Charles Brame" wrote: > > I have an Air Flow Performance fuel injection system on my Lycoming O-320. > The AFP manual recommends cleaning the fuel injectors every 100 hours. > Other than soaking in Hoppes #9, no detailed instructions are given for > cleaning the injectors. > > What is the best, approved, method for cleaning fuel injectors? > > Charlie Brame > RV-6A N11CB > San Antonio > > ________________________________________________________________________________
Date: Jan 04, 2015
My IO-390 has been running as smooth as a Swiss Watch for the past 1600 hours and I have never cleaned the injectors. I guess that will be on my list next annual. Bill Sent from my iPhone > On Jan 4, 2015, at 1:21 PM, Charles Brame wrote: > > > I have an Air Flow Performance fuel injection system on my Lycoming O-320. The AFP manual recommends cleaning the fuel injectors every 100 hours. Other than soaking in Hoppes #9, no detailed instructions are given for cleaning the injectors. > > What is the best, approved, method for cleaning fuel injectors? > > Charlie Brame > RV-6A N11CB > San Antonio > > > > ________________________________________________________________________________
Date: Jan 04, 2015
Bill, Don't fix it if it ain't broke or you may end up fixing it until it is broke. -- Lyle Sent from my Gateway E4610D desktop On 1/4/2015 5:45 PM, Bill Gill wrote: > > My IO-390 has been running as smooth as a Swiss Watch for the past 1600 hours and I have never cleaned the injectors. I guess that will be on my list next annual. > > Bill > > Sent from my iPhone > >> On Jan 4, 2015, at 1:21 PM, Charles Brame wrote: >> >> >> I have an Air Flow Performance fuel injection system on my Lycoming O-320. The AFP manual recommends cleaning the fuel injectors every 100 hours. Other than soaking in Hoppes #9, no detailed instructions are given for cleaning the injectors. >> >> What is the best, approved, method for cleaning fuel injectors? >> >> Charlie Brame >> RV-6A N11CB >> San Antonio >> >> >> >> > > ________________________________________________________________________________
Date: Jan 04, 2015
Charlie, These documents should help you. Charlie -------------------------------------------- On Sun, 1/4/15, Charles Brame wrote: Subject: RV-List: Cleaning fuel injectors To: "List RV" Date: Sunday, January 4, 2015, 2:21 PM Charles Brame I have an Air Flow Performance fuel injection system on my Lycoming O-320. The AFP manual recommends cleaning the fuel injectors every 100 hours. Other than soaking in Hoppes #9, no detailed instructions are given for cleaning the injectors. What is the best, approved, method for cleaning fuel injectors? Charlie Brame RV-6A- N11CB San Antonio Lists This Month -- Some AWESOME FREE Gifts!) Raiser.- Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com - - - - - - - -Matt Dralle, List Admin. Forum - ---- MATRONICS WEB FORUMS - ________________________________________________________________________________
Date: Jan 04, 2015
Date: Jan 05, 2015
Subject: Injector Cleaning
Lycoming instructions are here: http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201275C%20%2809-23-2008%29/Cleaning%20Fuel%20Injector%20Nozzles.pdf I cleaned mine after 1000 hrs of operation and my fuel burn dropped by 0.5 gph when running lean of peak. Gradually they got worse at atomizing the fuel and I wasn't able to run as lean. Its easy enough to do that I'll probably do it at each annual. 1 hr is a bit long for the hoppes, 20 minutes is recommended, at $30 ultrasonic cleaner might be worthwhile also: http://www.amazon.com/Professional-Ultrasonic-Jewelry-Eyeglass-Cleaning/dp/B001DKDAVW Bill N84WJ, RV-8, 1097 hrs RV-8.blogspot.com > > 1. 11:22 AM - Cleaning fuel injectors (Charles Brame) > 2. 11:49 AM - Re: Cleaning fuel injectors (vanremog(at)aol.com) > 3. 02:13 PM - Re: Cleaning fuel injectors () > 4. 03:46 PM - Re: Cleaning fuel injectors (Bill Gill) > 5. 03:51 PM - Re: Cleaning fuel injectors (Lyle Peterson) > 6. 04:59 PM - Re: Cleaning fuel injectors (Charles Kuss) > 7. 04:59 PM - Re: Cleaning fuel injectors (Charles Kuss) > > > ________________________________ Message 1 > _____________________________________ > > > From: Charles Brame <ChasB(at)satx.rr.com> > Subject: RV-List: Cleaning fuel injectors > > > I have an Air Flow Performance fuel injection system on my Lycoming O-320. > The > AFP manual recommends cleaning the fuel injectors every 100 hours. Other > than > soaking in Hoppes #9, no detailed instructions are given for cleaning the > injectors. > > What is the best, approved, method for cleaning fuel injectors? > > Charlie Brame > RV-6A N11CB > San Antonio > > ________________________________________________________________________________
Date: Jan 05, 2015
Subject: Re: Injector Cleaning
Any idea on a recommended solution to use in an ultrasonic? I have seen admonitions against using volatile solutions like Hoppe's #9 or MEK but no information on what should be used. I use an ultrasonic for cleaning rifle cartridges and the solution is intended for brass but I don't know if it would be ok for injectors. john RV9A On 1/5/2015 8:02 AM, Bill Judge wrote: > Lycoming instructions are here: > http://www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201275C%20%2809-23-2008%29/Cleaning%20Fuel%20Injector%20Nozzles.pdf > > I cleaned mine after 1000 hrs of operation and my fuel burn dropped by > 0.5 gph when running lean of peak. > > Gradually they got worse at atomizing the fuel and I wasn't able to > run as lean. > > Its easy enough to do that I'll probably do it at each annual. > > 1 hr is a bit long for the hoppes, 20 minutes is recommended, at $30 > ultrasonic cleaner might be worthwhile also: > http://www.amazon.com/Professional-Ultrasonic-Jewelry-Eyeglass-Cleaning/dp/B001DKDAVW > > Bill > N84WJ, RV-8, 1097 hrs > RV-8.blogspot.com <http://RV-8.blogspot.com> > > ________________________________________________________________________________
Date: Jan 05, 2015
=0AYou might want to give this juice a try.=0A =0Ahttp://www.u ltrasonicsdirect.com/12decacl.html?productid=12decacl&channelid=FROOG=0A =0A =0A =0A-----Original Message-----=0AFrom: John Morgensen <john@morg ensen.com>=0ATo: rv-list =0ASent: Mon, Jan 5, 2015 11:07 am=0ASubject: Re: RV-List: Injector Cleaning=0A=0A=0A =0A Any idea on a recommended solut ion to use in an ultrasonic? I have seen admonitio ns against using volatile solutions like Hoppe's #9 or MEK but no information on what should be used. I use an ultrasonic for cleaning rifle cartridges and the solut ion is intended for brass but I don't know if it would be ok for injectors.=0A =0A john=0A RV9A=0A =0A =0AOn 1/5/2015 8:02 AM, Bill Judg e wrote:=0A =0A =0A =0A =0ALycoming instructions are here:=0A http:// www.lycoming.com/Portals/0/techpublications/serviceinstructions/SI%201275C%20%28 09-23-2008%29/Cleaning%20Fuel%20Injector%20Nozzles.pdf=0A =0A=0A =0A =0AI cleaned mine after 1000 hrs of operation and my fuel burn dropped by 0.5 gph when running lean of peak.=0A =0A=0A =0A =0AGradu ally they got worse at atomizing the fuel and I wasn't able to run as lean.=0A =0A =0A =0A =0AIts easy enough t o do that I'll probably do it at each annual.=0A =0A=0A =0A =0A1 hr is a bit long for the hoppes, 20 minutes is recommended, at $30 ultrasonic cleane r might be worthwhile also:=0A =0Ahttp://www.amazon.com/Professional-Ultrasonic-Jewelry-Eyeglass-Clean ing/dp/B001DKDAVW=0A =0A =0A=0A =0A =0ABill=0A =0AN84WJ, RV-8, 1097 hrs=0A =0ARV-8.blogspot.com=0A =0A =0A =0A=0A =0A =0A =0A =0A =========================== =========================== =========================== =========================== ====================0A=0A=0A=0A ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Jan 17, 2015
Thank you AOPA for reviewing the Airport Courtesy Car app in the February issue on page 37. The review states the app is only available for iPhone, however that is incorrect. And thanks also to AvWeb who reviewed it earlier. The app is available for Android in the Google Play Store, so you Android users, please check it out. The app is totally free and now lists over 1100 locations nationwide. And thanks to all the folks on this forum who contributed listings. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437179#437179 ________________________________________________________________________________
Date: Jan 20, 2015
Subject: Delta-Pop ADS-B antenna placement
Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. Thoughts please? Thanks, Ralph RV6A N822AR @ N06 "Patience" 240 hrs.... ________________________________________________________________________________
Date: Jan 20, 2015
Subject: Re: Delta-Pop ADS-B antenna placement
I put mine back in the empenage without a doubbler and have not had any noticeable issues. Dave Leonard On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen wrote: > > Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to > figure out where to install the antenna.... > > Since the Delta-Pop is a blade-type antenna, it will need to be mounted > along the fuselage direction of flight axis. There are a couple of places > where bulkheads mount to the bottom skin and are aligned correctly. I'm > thinking of taking advantage of one of these bulkheads instead of mounting > a doubler plate to the underside. > > Thoughts please? > > Thanks, > Ralph > RV6A N822AR @ N06 "Patience" 240 hrs.... > > ________________________________________________________________________________
Date: Jan 20, 2015
Inside or outside? > On Jan 20, 2015, at 9:19 AM, David Leonard wrote: > > I put mine back in the empenage without a doubbler and have not had any no ticeable issues. > > Dave Leonard > >> On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen w rote: >> >> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... >> >> Since the Delta-Pop is a blade-type antenna, it will need to be mounted a long the fuselage direction of flight axis. There are a couple of places wh ere bulkheads mount to the bottom skin and are aligned correctly. I'm think ing of taking advantage of one of these bulkheads instead of mounting a doub ler plate to the underside. >> >> Thoughts please? >> >> Thanks, >> Ralph >> RV6A N822AR @ N06 "Patience" 240 hrs.... >> >> >> >> >> ========== >> br> fts!) >> r> > com" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" target="_blank">www.buildersbooks.com >> p.com" target="_blank">www.homebuilthelp.com >> e.com" target="_blank">www.mypilotstore.com >> " target="_blank">www.mrrace.com >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 20, 2015
John, The navworx unit requires two antennas. One for the UAT and one for the GPS . The blade antenna they are talking about the UAT output which is similar to a transponder antenna. I wouldn't recommend locating that internally. Bob Sent from my iPhone On Jan 20, 2015, at 12:35 PM, John Jessen wrote: Inside or outside? > On Jan 20, 2015, at 9:19 AM, David Leonard wrote: > > I put mine back in the empenage without a doubbler and have not had any no ticeable issues. > > Dave Leonard > >> On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen w rote: >> >> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... >> >> Since the Delta-Pop is a blade-type antenna, it will need to be mounted a long the fuselage direction of flight axis. There are a couple of places wh ere bulkheads mount to the bottom skin and are aligned correctly. I'm think ing of taking advantage of one of these bulkheads instead of mounting a doub ler plate to the underside. >> >> Thoughts please? >> >> Thanks, >> Ralph >> RV6A N822AR @ N06 "Patience" 240 hrs.... >> >> >> >> >> ========== >> br> fts!) >> r> > com" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" target="_blank">www.buildersbooks.com >> p.com" target="_blank">www.homebuilthelp.com >> e.com" target="_blank">www.mypilotstore.com >> " target="_blank">www.mrrace.com >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> >> >> > > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jan 20, 2015
Any pictures?! -----Original Message----- From: David Leonard Sent: Jan 20, 2015 12:19 PM Subject: Re: RV-List: Delta-Pop ADS-B antenna placement I put mine back in the empenage without a doubbler and have not had any noticeable issues. Dave Leonard On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen wrote: Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. Thoughts please? Thanks, Ralph RV6A N822AR @ N06 "Patience" 240 hrs.... ========== br> fts!) r> > com" target="_blank">www.aeroelectric.com w.buildersbooks.com" target="_blank">www.buildersbooks.com p.com" target="_blank">www.homebuilthelp.com e.com" target="_blank">www.mypilotstore.com " target="_blank">www.mrrace.com target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== ist" target="_blank">http://www.matronics.com/Navigator?RV-List ========== FORUMS - _blank">http://forums.matronics.com ========== ________________________________________________________________________________
Date: Jan 20, 2015
I'm planning on getting my position data from my 420W - so I shouldn't need the second GPS antenna...but that sounds like a good plan b place to put it. -----Original Message----- From: Bob Leffler Sent: Jan 20, 2015 12:56 PM Subject: Re: RV-List: Delta-Pop ADS-B antenna placement John, The navworx unit requires two antennas. One for the UAT and one for the GPS. The blade antenna they are talking about the UAT output which is similar to a transponder antenna. I wouldn't recommend locating that internally. Bob Sent from my iPhone On Jan 20, 2015, at 12:35 PM, John Jessen wrote: Inside or outside? On Jan 20, 2015, at 9:19 AM, David Leonard wrote: I put mine back in the empenage without a doubbler and have not had any noticeable issues. Dave Leonard On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen wrote: Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. Thoughts please? Thanks, Ralph RV6A N822AR @ N06 "Patience" 240 hrs.... ========== br> fts!) r> > com" target="_blank">www.aeroelectric.com w.buildersbooks.com" target="_blank">www.buildersbooks.com p.com" target="_blank">www.homebuilthelp.com e.com" target="_blank">www.mypilotstore.com " target="_blank">www.mrrace.com target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== ist" target="_blank">http://www.matronics.com/Navigator?RV-List ========== FORUMS - _blank">http://forums.matronics.com ========== D============================================ ot;">www.aeroelectric.com books.com"">www.buildersbooks.com quot;">www.homebuilthelp.com quot;">www.mypilotstore.com ">www.mrrace.com ot;">http://www.matronics.com/contribution D============================================ st"">http://www.matronics.com/Navigator?RV-List D============================================ //forums.matronics.com D============================================ ________________________________________________________________________________
Date: Jan 20, 2015
Ah! Ok. Thanks. I'm very interested in this topic and product, although not sure it works with Foreflight. > On Jan 20, 2015, at 9:56 AM, Bob Leffler wrote: > > John, > > The navworx unit requires two antennas. One for the UAT and one for the G PS. The blade antenna they are talking about the UAT output which is simil ar to a transponder antenna. I wouldn't recommend locating that internally. > > Bob > > Sent from my iPhone > > On Jan 20, 2015, at 12:35 PM, John Jessen wrote: > > Inside or outside? > >> On Jan 20, 2015, at 9:19 AM, David Leonard wrote: >> >> I put mine back in the empenage without a doubbler and have not had any n oticeable issues. >> >> Dave Leonard >> >>> On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen w rote: >>> >>> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying t o figure out where to install the antenna.... >>> >>> Since the Delta-Pop is a blade-type antenna, it will need to be mounted a long the fuselage direction of flight axis. There are a couple of places wh ere bulkheads mount to the bottom skin and are aligned correctly. I'm think ing of taking advantage of one of these bulkheads instead of mounting a doub ler plate to the underside. >>> >>> Thoughts please? >>> >>> Thanks, >>> Ralph >>> RV6A N822AR @ N06 "Patience" 240 hrs.... >>> >>> >>> >>> >>> ========== >>> br> fts!) >>> r> > com" target="_blank">www.aeroelectric.com >>> w.buildersbooks.com" target="_blank">www.buildersbooks.com >>> p.com" target="_blank">www.homebuilthelp.com >>> e.com" target="_blank">www.mypilotstore.com >>> " target="_blank">www.mrrace.com >>> target="_blank">http://www.matronics.com/contribution >>> -Matt Dralle, List Admin. >>> ========== >>> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> >>> >>> >> >> >> >> > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">www.aeroelectric.com > books.com"">www.buildersbooks.com > quot;">www.homebuilthelp.com > quot;">www.mypilotstore.com > ">www.mrrace.com > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > st"">http://www.matronics.com/Navigator?RV-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 20, 2015
Nothing works with foreflight, but stratus. That's why I use wingx. Sent from my iPhone On Jan 20, 2015, at 1:22 PM, John Jessen wrote: Ah! Ok. Thanks. I'm very interested in this topic and product, although not sure it works with Foreflight. > On Jan 20, 2015, at 9:56 AM, Bob Leffler wrote: > > John, > > The navworx unit requires two antennas. One for the UAT and one for the G PS. The blade antenna they are talking about the UAT output which is simil ar to a transponder antenna. I wouldn't recommend locating that internally. > > Bob > > Sent from my iPhone > > On Jan 20, 2015, at 12:35 PM, John Jessen wrote: > > Inside or outside? > >> On Jan 20, 2015, at 9:19 AM, David Leonard wrote: >> >> I put mine back in the empenage without a doubbler and have not had any n oticeable issues. >> >> Dave Leonard >> >>> On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen w rote: >>> >>> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying t o figure out where to install the antenna.... >>> >>> Since the Delta-Pop is a blade-type antenna, it will need to be mounted a long the fuselage direction of flight axis. There are a couple of places wh ere bulkheads mount to the bottom skin and are aligned correctly. I'm think ing of taking advantage of one of these bulkheads instead of mounting a doub ler plate to the underside. >>> >>> Thoughts please? >>> >>> Thanks, >>> Ralph >>> RV6A N822AR @ N06 "Patience" 240 hrs.... >>> >>> >>> >>> >>> ========== >>> br> fts!) >>> r> > com" target="_blank">www.aeroelectric.com >>> w.buildersbooks.com" target="_blank">www.buildersbooks.com >>> p.com" target="_blank">www.homebuilthelp.com >>> e.com" target="_blank">www.mypilotstore.com >>> " target="_blank">www.mrrace.com >>> target="_blank">http://www.matronics.com/contribution >>> -Matt Dralle, List Admin. >>> ========== >>> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> >>> >>> >> >> >> >> > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">www.aeroelectric.com > books.com"">www.buildersbooks.com > quot;">www.homebuilthelp.com > quot;">www.mypilotstore.com > ">www.mrrace.com > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > st"">http://www.matronics.com/Navigator?RV-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">www.aeroelectric.com > books.com"">www.buildersbooks.com > quot;">www.homebuilthelp.com > quot;">www.mypilotstore.com > ">www.mrrace.com > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > st"">http://www.matronics.com/Navigator?RV-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jan 20, 2015
Unfortunately that's not supported with the current navworx units. The GPS is internal to the unit. In 2016, for experimentals you be able to do the opposite. Send GPS position data to your EFIS from navworx. Other vendors may work differently. Sent from my iPhone On Jan 20, 2015, at 1:21 PM, Ralph E. Capen wrote: I'm planning on getting my position data from my 420W - so I shouldn't need the second GPS antenna...but that sounds like a good plan b place to put it. -----Original Message----- From: Bob Leffler Sent: Jan 20, 2015 12:56 PM Subject: Re: RV-List: Delta-Pop ADS-B antenna placement John, The navworx unit requires two antennas. One for the UAT and one for the GPS. The blade antenna they are talking about the UAT output which is similar to a transponder antenna. I wouldn't recommend locating that internally. Bob Sent from my iPhone On Jan 20, 2015, at 12:35 PM, John Jessen wrote: Inside or outside? On Jan 20, 2015, at 9:19 AM, David Leonard wrote: I put mine back in the empenage without a doubbler and have not had any noticeable issues. Dave Leonard On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen wrote: Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. Thoughts please? Thanks, Ralph RV6A N822AR @ N06 "Patience" 240 hrs.... ========== br> fts!) r> > com" target="_blank">www.aeroelectric.com w.buildersbooks.com" target="_blank">www.buildersbooks.com p.com" target="_blank">www.homebuilthelp.com e.com" target="_blank">www.mypilotstore.com " target="_blank">www.mrrace.com target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== ist" target="_blank">http://www.matronics.com/Navigator?RV-List ========== FORUMS - _blank">http://forums.matronics.com ========== D============================================ ot;">www.aeroelectric.com books.com"">www.buildersbooks.com quot;">www.homebuilthelp.com quot;">www.mypilotstore.com ">www.mrrace.com ot;">http://www.matronics.com/contribution D============================================ st"">http://www.matronics.com/Navigator?RV-List D============================================ //forums.matronics.com D============================================ ________________________________________________________________________________
Date: Jan 20, 2015
Yes, I'd probably have to switch over. I don't like WingX, but could get use d to it, I suppose. On Jan 20, 2015, at 10:36 AM, Bob Leffler wrote: > Nothing works with foreflight, but stratus. That's why I use wingx. > > Sent from my iPhone > > On Jan 20, 2015, at 1:22 PM, John Jessen wrote: > > Ah! Ok. Thanks. I'm very interested in this topic and product, although n ot sure it works with Foreflight. > > > > On Jan 20, 2015, at 9:56 AM, Bob Leffler wrote: > >> John, >> >> The navworx unit requires two antennas. One for the UAT and one for the G PS. The blade antenna they are talking about the UAT output which is simil ar to a transponder antenna. I wouldn't recommend locating that internally. >> >> Bob >> >> Sent from my iPhone >> >> On Jan 20, 2015, at 12:35 PM, John Jessen wrote: >> >> Inside or outside? >> >> On Jan 20, 2015, at 9:19 AM, David Leonard wrote: >> >>> I put mine back in the empenage without a doubbler and have not had any n oticeable issues. >>> >>> Dave Leonard >>> >>> On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen w rote: >>>> >>>> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying t o figure out where to install the antenna.... >>>> >>>> Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places w here bulkheads mount to the bottom skin and are aligned correctly. I'm thin king of taking advantage of one of these bulkheads instead of mounting a dou bler plate to the underside. >>>> >>>> Thoughts please? >>>> >>>> Thanks, >>>> Ralph >>>> RV6A N822AR @ N06 "Patience" 240 hrs.... >>>> >>>> >>>> >>>> >>>> ========== >>>> br> fts!) >>>> r> > com" target="_blank">www.aeroelectric.com >>>> w.buildersbooks.com" target="_blank">www.buildersbooks.com >>>> p.com" target="_blank">www.homebuilthelp.com >>>> e.com" target="_blank">www.mypilotstore.com >>>> " target="_blank">www.mrrace.com >>>> target="_blank">http://www.matronics.com/contribution >>>> -Matt Dralle, List Admin. >>>> ========== >>>> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >>>> ========== >>>> FORUMS - >>>> _blank">http://forums.matronics.com >>>> ========== >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">www.aeroelectric.com >> books.com"">www.buildersbooks.com >> quot;">www.homebuilthelp.com >> quot;">www.mypilotstore.com >> ">www.mrrace.com >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> st"">http://www.matronics.com/Navigator?RV-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">www.aeroelectric.com >> books.com"">www.buildersbooks.com >> quot;">www.homebuilthelp.com >> quot;">www.mypilotstore.com >> ">www.mrrace.com >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> st"">http://www.matronics.com/Navigator?RV-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">www.aeroelectric.com > books.com"">www.buildersbooks.com > quot;">www.homebuilthelp.com > quot;">www.mypilotstore.com > ">www.mrrace.com > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > st"">http://www.matronics.com/Navigator?RV-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 20, 2015
Outside lower, of course, just like a blade xpdr antenna. Nothing special to see in a picture. I did not use a doubler (like I did for my ship comm antenna) because the forces are relatively small the fore/aft mounting holes will not allow for twisting of the skin the way a single hole would. My GPS antenna is top interior with a view of the sky just like the other satellite antennas. I like my Navworx. I have had it installed for 2 years now. Was worth purchasing early (long before 2020). I use it with an e-ink/lcd (pixel Qi - the more sunlight the easier to read) windows tablet (solid state hard drive, not an HHD) and Chartflier software. The system just needs to have audible traffic alerts from either the software or the Navworx. Seems easy enough to do but still not available. Dave Leonard On Tue, Jan 20, 2015 at 9:35 AM, John Jessen wrote: > Inside or outside? > > On Jan 20, 2015, at 9:19 AM, David Leonard wrote: > > I put mine back in the empenage without a doubbler and have not had any > noticeable issues. > > Dave Leonard > > On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen > wrote: > >> >> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to >> figure out where to install the antenna.... >> >> Since the Delta-Pop is a blade-type antenna, it will need to be mounted >> along the fuselage direction of flight axis. There are a couple of places >> where bulkheads mount to the bottom skin and are aligned correctly. I'm >> thinking of taking advantage of one of these bulkheads instead of mounting >> a doubler plate to the underside. >> >> Thoughts please? >> >> Thanks, >> Ralph >> RV6A N822AR @ N06 "Patience" 240 hrs.... >> >> >> >> >> ========== >> br> fts!) >> r> > com" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" target="_blank">www.buildersbooks.com >> p.com" target="_blank">www.homebuilthelp.com >> e.com" target="_blank">www.mypilotstore.com >> " target="_blank">www.mrrace.com >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> >> >> >> > > > * > > > * > > ________________________________________________________________________________
Date: Jan 20, 2015
I recently switched to Garmin Pilot because I didn't want to be tied to Stratus (with Foreflight). GP has been good overall, though I have to admit Foreflight seems to set the pace of innovation when it comes to this class of apps on the ipad. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Tue, Jan 20, 2015 at 2:23 PM, David Leonard wrote: > Outside lower, of course, just like a blade xpdr antenna. Nothing special > to see in a picture. I did not use a doubler (like I did for my ship comm > antenna) because the forces are relatively small the fore/aft mounting > holes will not allow for twisting of the skin the way a single hole would. > > My GPS antenna is top interior with a view of the sky just like the other > satellite antennas. > > I like my Navworx. I have had it installed for 2 years now. Was worth > purchasing early (long before 2020). I use it with an e-ink/lcd (pixel Qi > - the more sunlight the easier to read) windows tablet (solid state hard > drive, not an HHD) and Chartflier software. > > The system just needs to have audible traffic alerts from either the > software or the Navworx. Seems easy enough to do but still not available. > > Dave Leonard > > On Tue, Jan 20, 2015 at 9:35 AM, John Jessen wrote: > >> Inside or outside? >> >> On Jan 20, 2015, at 9:19 AM, David Leonard wrote: >> >> I put mine back in the empenage without a doubbler and have not had any >> noticeable issues. >> >> Dave Leonard >> >> On Tue, Jan 20, 2015 at 8:44 AM, Ralph E. Capen >> wrote: >> >>> >>> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying >>> to figure out where to install the antenna.... >>> >>> Since the Delta-Pop is a blade-type antenna, it will need to be mounted >>> along the fuselage direction of flight axis. There are a couple of places >>> where bulkheads mount to the bottom skin and are aligned correctly. I'm >>> thinking of taking advantage of one of these bulkheads instead of mounting >>> a doubler plate to the underside. >>> >>> Thoughts please? >>> >>> Thanks, >>> Ralph >>> RV6A N822AR @ N06 "Patience" 240 hrs.... >>> >>> >>> >>> >>> ========== >>> br> fts!) >>> r> > com" target="_blank">www.aeroelectric.com >>> w.buildersbooks.com" target="_blank">www.buildersbooks.com >>> p.com" target="_blank">www.homebuilthelp.com >>> e.com" target="_blank">www.mypilotstore.com >>> " target="_blank">www.mrrace.com >>> target="_blank">http://www.matronics.com/contribution >>> -Matt Dralle, List Admin. >>> ========== >>> ist" target="_blank">http://www.matronics.com/Navigator?RV-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> >>> >>> >>> >> >> >> * >> >> 3D============================================ >> 3D============================================ >> 3D============================================ >> 3D============================================ >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: Jan 20, 2015
For what it's worth, the RV-14 (unless I missed something in construction) doesn't use doublers for the UAT and Transponder antennas, but it does for the 2 COM antennas. If true, then I don't think Van's thinks you need one for the blades. I'm still considering if I should add one, but with the fairly low drag maybe it's not worth worrying about it. Tim ________________________________________________________________________________
Date: Jan 20, 2015
Subject: Re: RV-List Digest: 0 Msgs - 01/19/15
Please stop sending emails! Sent from AOL Mobile Mail -----Original Message----- From: RV-List Digest Server <rv-list(at)matronics.com> Sent: Tue, Jan 20, 2015 12:15 AM Subject: RV-List Digest: 0 Msgs - 01/19/15
      Today's complete RV-List Digest can also be found in either of the
      two Web Links listed below.  The .html file includes the Digest formatted
      and Message Navigation.  The .txt file includes the plain ASCII version
      of the RV-List Digest and can be viewed with a generic text editor
      HTML Version:
          http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-01-19&Archive=RV
      Text Version:
          http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-01-19&Archive=RV
                           RV-List Digest Archive
                    Total Messages Posted Mon 01/19/15: 0
      Today's Message Index:
Date: Jan 20, 2015
Jim, you must un- subscribe. Go to bottom of message and look for instructio n. Dale Ensing On Jan 20, 2015, at 19:18, Jim Clark wrote: > Please stop sending emails! > > > Sent from AOL Mobile Mail > > > -----Original Message----- > From: RV-List Digest Server <rv-list(at)matronics.com> > To: RV-List Digest List > Sent: Tue, Jan 20, 2015 12:15 AM > Subject: RV-List Digest: 0 Msgs - 01/19/15 > > > * > > ========================= ======================== > Online Versions of Today's List Digest Archive > ========================= ======================== > > Today's complete RV-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=ht ml&Chapter 15-01-19&Archive=RV > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=tx t&Chapter 15-01-19&Archive=RV > > > ========================= ====================== > EMail Version of Today's List Digest Archive > ========================= ====================== > > > ---------------------------------------------------------- > RV-List Digest Archive > --- > Total Messages Posted Mon 01/19/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 21, 2015
Subject: Leakguard tubes belong in the trash
Folks, I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner. The tube just wore through and leaked. I've never seen this happen to any other brand of tube. Of course it happened at a rather inconvenient time, I was landing at Brown Field, coming back from Mexico, when you are not supposed to get out the the aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun. Fly Safe, Bill Judge N84WJ, RV-8, 1103 hrs http://rv-8.blogspot.com/ ________________________________________________________________________________
Subject: Re: Leakguard tubes belong in the trash
Date: Jan 21, 2015
Did you put talc in when installing? Tough times don't last Tough people do!! Mike 931-993-7623 > On Jan 21, 2015, at 10:12, Bill Judge wrote: > > Folks, > I just got a second flat and the culprit was again the leakguard inner tub e. If you're using these I recommend you get rid of them the next time you h ave your tires off or sooner. > > The tube just wore through and leaked. I've never seen this happen to any o ther brand of tube. > > Of course it happened at a rather inconvenient time, I was landing at Brow n Field, coming back from Mexico, when you are not supposed to get out the t he aircraft until the customs agent authorizes... I limped off the runway, p ulled the wheel pant, and then limped to the customs box... fun fun. > > Fly Safe, > > > Bill Judge > N84WJ, RV-8, 1103 hrs > http://rv-8.blogspot.com/ > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 21, 2015
I had a flat once on landing rollout - ended up being caused by a sticker inside the tire rubbing the tube. I first thought the tube was junk - until I saw the wear pattern and the respective sticker.... Might not be your case here - but I thought I would share my failure mode..... -----Original Message----- From: Bill Judge Sent: Jan 21, 2015 11:12 AM Subject: RV-List: Leakguard tubes belong in the trash Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner. The tube just wore through and leaked. I've never seen this happen to any other brand of tube. Of course it happened at a rather inconvenient time, I was landing at Brown Field, coming back from Mexico, when you are not supposed to get out the the aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun. Fly Safe, Bill JudgeN84WJ, RV-8, 1103 hrshttp://rv-8.blogspot.com/ ________________________________________________________________________________
Date: Jan 21, 2015
And I had used talc..... -----Original Message----- >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Sent: Jan 21, 2015 11:48 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Leakguard tubes belong in the trash > > >I had a flat once on landing rollout - ended up being caused by a sticker inside the tire rubbing the tube. I first thought the tube was junk - until I saw the wear pattern and the respective sticker.... > >Might not be your case here - but I thought I would share my failure mode..... > > >-----Original Message----- > >From: Bill Judge > >Sent: Jan 21, 2015 11:12 AM > >To: rv-list(at)matronics.com > >Subject: RV-List: Leakguard tubes belong in the trash > > >Folks,I just got a second flat and the culprit was again the leakguard inner tube. If you're using these I recommend you get rid of them the next time you have your tires off or sooner. >The tube just wore through and leaked. I've never seen this happen to any other brand of tube. >Of course it happened at a rather inconvenient time, I was landing at Brown Field, coming back from Mexico, when you are not supposed to get out the the aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun. >Fly Safe, > >Bill JudgeN84WJ, RV-8, 1103 hrshttp://rv-8.blogspot.com/ > > ________________________________________________________________________________
Date: Jan 21, 2015
All of the talc in the world will not prevent an inner tube leak if there i s dirt/sand/stickers/grass/rocks/etc between the tube and tire. Even a smal l grain of sand will cause a leak.=C2- Imagine the pressure between the t ube and tire and then add the punishment of high speed taxi/takoffs, brakin g and landings.=C2- Steve On Wednesday, January 21, 2015 11:07 AM, Ralph E. Capen wrote: And I had used talc..... -----Original Message----- >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Sent: Jan 21, 2015 11:48 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Leakguard tubes belong in the trash > > >I had a flat once on landing rollout - ended up being caused by a sticker inside the tire rubbing the tube.=C2- I first thought the tube was junk - until I saw the wear pattern and the respective sticker.... > >Might not be your case here - but I thought I would share my failure mode. .... > > >-----Original Message----- > >From: Bill Judge > >Sent: Jan 21, 2015 11:12 AM > >To: rv-list(at)matronics.com > >Subject: RV-List: Leakguard tubes belong in the trash > > >Folks,I just got a second flat and the culprit was again the leakguard inn er tube. If you're using these I recommend you get rid of them the next tim e you have your tires off or sooner. >The tube just wore through and leaked. I've never seen this happen to any other brand of tube. >Of course it happened at a rather inconvenient time, I was landing at Brow n Field, coming back from Mexico, when you are not supposed to get out the the aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun. >Fly Safe, > >Bill JudgeN84WJ, RV-8, 1103 hrshttp://rv-8.blogspot.com/ > > =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. S - ________________________________________________________________________________
Date: Jan 21, 2015
In my (limited) experience, a tube will only wear through if assembled without talc or was underinflated. I talc everything .... tube, inside of tire and even the wheel hub. Extra talc on the tire bead will make tire removal much easier down the road ... er ... airway :-D . Linn On 1/21/2015 11:12 AM, Bill Judge wrote: > Folks, > I just got a second flat and the culprit was again the leakguard inner > tube. If you're using these I recommend you get rid of them the next > time you have your tires off or sooner. > > The tube just wore through and leaked. I've never seen this happen to > any other brand of tube. > > Of course it happened at a rather inconvenient time, I was landing at > Brown Field, coming back from Mexico, when you are not supposed to get > out the the aircraft until the customs agent authorizes... I limped > off the runway, pulled the wheel pant, and then limped to the customs > box... fun fun. > > Fly Safe, > > > Bill Judge > N84WJ, RV-8, 1103 hrs > http://rv-8.blogspot.com/ > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jan 21, 2015
Had the exact same problem a few years ago with the Dresser No Leaks. 2 of t hem let go on landings (about a month apart). One split on a seam, the othe r had cracks like it was old rubber and very poor quality. I don't buy Dresser tubes anymore. Mitchel in much better quality. 7A 7WT Sent from my I doohickey > On Jan 21, 2015, at 12:48 PM, Linn Walters wrote: > > In my (limited) experience, a tube will only wear through if assembled wit hout talc or was underinflated. > I talc everything .... tube, inside of tire and even the wheel hub. Extra talc on the tire bead will make tire removal much easier down the road ... e r ... airway :-D . > Linn > > >> On 1/21/2015 11:12 AM, Bill Judge wrote: >> Folks, >> I just got a second flat and the culprit was again the leakguard inner tu be. If you're using these I recommend you get rid of them the next time you h ave your tires off or sooner. >> >> The tube just wore through and leaked. I've never seen this happen to any other brand of tube. >> >> Of course it happened at a rather inconvenient time, I was landing at Bro wn Field, coming back from Mexico, when you are not supposed to get out the t he aircraft until the customs agent authorizes... I limped off the runway, p ulled the wheel pant, and then limped to the customs box... fun fun. >> >> Fly Safe, >> >> >> Bill Judge >> N84WJ, RV-8, 1103 hrs >> http://rv-8.blogspot.com/ >> >> >> >> >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> 01/21/15 >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 22, 2015
What Linn said, but more so. I have over 1200 hours on a set of leakguard t ubes that have been through three sets of tires so far. Use copious amounts of talc, in my case plain ole' baby powder on all surfaces, always very sl ightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it ar ound to make sure, then deflate just enough to mate the wheel halves, makin g certain that the tube doesn't get pinched between the wheel halves. With all the talc you should have spread on the tube and inside the tire casing the tube moves around easily. After the bolts are tight, partially inflate the tube again and bounce it on the floor a couple of times to again make s ure the tube has no kinks or folds, then deflate once more and do it again for good measure before finally inflating to your desired pressure. Takes a few minutes longer but sure beats flat tires. BTW, with my leakguards my tires lose one psi or less in six or eight weeks . Harry Crosby RV-6, coming up on 1300 hours ----- Original Message ----- From: "Linn Walters" <flying-nut(at)cfl.rr.com> Sent: Wednesday, January 21, 2015 12:48:26 PM Subject: Re: RV-List: Leakguard tubes belong in the trash In my (limited) experience, a tube will only wear through if assembled with out talc or was underinflated. I talc everything .... tube, inside of tire and even the wheel hub. Extra t alc on the tire bead will make tire removal much easier down the road ... e r ... airway :-D . Linn On 1/21/2015 11:12 AM, Bill Judge wrote: Folks, I just got a second flat and the culprit was again the leakguard inner tube . If you're using these I recommend you get rid of them the next time you h ave your tires off or sooner. The tube just wore through and leaked. I've never seen this happen to any o ther brand of tube. Of course it happened at a rather inconvenient time, I was landing at Brown Field, coming back from Mexico, when you are not supposed to get out the t he aircraft until the customs agent authorizes... I limped off the runway, pulled the wheel pant, and then limped to the customs box... fun fun. Fly Safe, Bill Judge N84WJ, RV-8, 1103 hrs http://rv-8.blogspot.com/ No virus found in this message. Checked by AVG - www.avg.com 01/21/15 =========== ________________________________________________________________________________
Date: Jan 21, 2015
Just to expand .... pun intended .... when the valve core is removed I inflate/deflate the tube often using my air gun to prevent folds that Harry talks about. One other problem I've seen are the wrong size tube installed .... both too small and too big. Happens a lot when the plane uses 5.00-5 on the nose and 6.00-6 on the mains. Not all that hard to switch tubes. Linn On 1/21/2015 7:29 PM, HCRV6(at)comcast.net wrote: > What Linn said, but more so. I have over 1200 hours on a set of > leakguard tubes that have been through three sets of tires so far. > Use copious amounts of talc, in my case plain ole' baby powder on all > surfaces, always very slightly inflate the tube before mating the > wheel halves to make certain that the tube is straight in the tire > with no folds or kinks, even wiggle it around to make sure, then > deflate just enough to mate the wheel halves, making certain that the > tube doesn't get pinched between the wheel halves. With all the talc > you should have spread on the tube and inside the tire casing the tube > moves around easily. After the bolts are tight, partially inflate the > tube again and bounce it on the floor a couple of times to again make > sure the tube has no kinks or folds, then deflate once more and do it > again for good measure before finally inflating to your desired > pressure. Takes a few minutes longer but sure beats flat tires. > > BTW, with my leakguards my tires lose one psi or less in six or eight > weeks. > > Harry Crosby > RV-6, coming up on 1300 hours > > ------------------------------------------------------------------------ > *From: *"Linn Walters" <flying-nut(at)cfl.rr.com> > *To: *"RV-List" > *Sent: *Wednesday, January 21, 2015 12:48:26 PM > *Subject: *Re: RV-List: Leakguard tubes belong in the trash > > In my (limited) experience, a tube will only wear through if assembled > without talc or was underinflated. > I talc everything .... tube, inside of tire and even the wheel hub. > Extra talc on the tire bead will make tire removal much easier down > the road ... er ... airway :-D . > Linn > > > On 1/21/2015 11:12 AM, Bill Judge wrote: > > Folks, > I just got a second flat and the culprit was again the leakguard > inner tube. If you're using these I recommend you get rid of them > the next time you have your tires off or sooner. > > The tube just wore through and leaked. I've never seen this happen > to any other brand of tube. > > Of course it happened at a rather inconvenient time, I was landing > at Brown Field, coming back from Mexico, when you are not supposed > to get out the the aircraft until the customs agent authorizes... > I limped off the runway, pulled the wheel pant, and then limped to > the customs box... fun fun. > > Fly Safe, > > > Bill Judge > N84WJ, RV-8, 1103 hrs > http://rv-8.blogspot.com/ > ________________________________________________________________________________
Date: Jan 22, 2015
Been running Michelim Air Stop tubes since May 2005. Almost 1=2C300 flight hours on the tubes according to log and not sure how many tires without go ing through the log more. Also using plain old baby talc with procedures a nd service like Harry Crosby. Looks like I had 1=2C671 hours on the tubes that Van provided. They needed air once a month. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell=2C 2=2C954+ Flying Hours Pennsylvania=2C USA Date: Wed=2C 21 Jan 2015 19:52:22 -0500 From: flying-nut(at)cfl.rr.com Subject: Re: RV-List: Leakguard tubes belong in the trash =0A =0A =0A =0A =0A Just to expand .... pun intended ....=0A when the valve core is removed I inflate/deflate the tube often=0A using my air gun to prevent folds that Harry talks about. One=0A other problem I've seen are the wrong size tube installed ....=0A both too small and too big. Happens a lot when the plane uses=0A 5.00-5 on the nose and 6.00-6 on the mains. Not all that hard to=0A switch tubes. =0A Linn =0A =0A On 1/21/2015 7:29 PM=2C HCRV6(at)comcast.net wrote: =0A =0A =0A =0A What Linn said=2C but more so. I=0A have over 1200 hours on a set of leakguard tubes that have=0A been through three sets of tires so far. Use copious amounts=0A of talc=2C in my case plain ole' baby powder on all surfaces=2C =0A always very slightly inflate the tube before mating the wheel=0A halves to make certain that the tube is straight in the tire=0A with no folds or kinks=2C even wiggle it around to make sure=2C =0A then deflate just enough to mate the wheel halves=2C making=0A certain that the tube doesn't get pinched between the wheel=0A halves. With all the talc you should have spread on the tube=0A and inside the tire casing the tube moves around easily. =0A After the bolts are tight=2C partially inflate the tube again=0A and bounce it on the floor a couple of times to again make=0A sure the tube has no kinks or folds=2C then deflate once more=0A and do it again for good measure before finally inflating to=0A your desired pressure. Takes a few minutes longer but sure=0A beats flat tires. =0A =0A =0A =0A BTW=2C with my leakguards my tires=0A lose one psi or less in six or eight weeks. =0A =0A =0A =0A Harry Crosby =0A =0A RV-6=2C coming up on 1300 hours =0A =0A =0A =0A =0A From: "Linn=0A Walters" =0A To: "RV-List" =0A Sent: Wednesday=2C January 21=2C 2015 12:48:26 PM =0A Subject: Re: RV-List: Leakguard tubes belong in the=0A trash =0A =0A =0A In my (limited) experience=2C a=0A tube will only wear through if assembled without talc or was=0A underinflated. =0A I talc everything .... tube=2C inside of tire and even the=0A wheel hub. Extra talc on the tire bead will make tire=0A removal much easier down the road ... er ... airway :-D . =0A Linn =0A =0A =0A On 1/21/2015 11:12 AM=2C Bill Judge wrote: =0A =0A =0A Folks=2C=0A I just got a second flat and the culprit was again=0A the leakguard inner tube. If you're using these I=0A recommend you get rid of them the next time you have=0A your tires off or sooner.=0A =0A =0A The tube just wore through and leaked. I've never=0A seen this happen to any other brand of tube.=0A =0A =0A Of course it happened at a rather inconvenient time=2C=0A I was landing at Brown Field=2C coming back from Mexico=2C =0A when you are not supposed to get out the the aircraft=0A until the customs agent authorizes... I limped off the=0A runway=2C pulled the wheel pant=2C and then limped to the =0A customs box... fun fun.=0A =0A =0A Fly Safe=2C=0A =0A =0A =0A =0A Bill Judge=0A N84WJ=2C RV-8=2C 1103 hrs=0A http://rv-8.blogspot.com/ =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Jan 22, 2015
I'm with you Harry, I've had the same results. I do carry a spare nose tire t ube. Ollie Sent from my iPad > On Jan 21, 2015, at 7:29 PM, HCRV6(at)comcast.net wrote: > > What Linn said, but more so. I have over 1200 hours on a set of leakguard tubes that have been through three sets of tires so far. Use copious amou nts of talc, in my case plain ole' baby powder on all surfaces, always very s lightly inflate the tube before mating the wheel halves to make certain that the tube is straight in the tire with no folds or kinks, even wiggle it aro und to make sure, then deflate just enough to mate the wheel halves, making c ertain that the tube doesn't get pinched between the wheel halves. With all the talc you should have spread on the tube and inside the tire casing the t ube moves around easily. After the bolts are tight, partially inflate the t ube again and bounce it on the floor a couple of times to again make sure th e tube has no kinks or folds, then deflate once more and do it again for goo d measure before finally inflating to your desired pressure. Takes a few mi nutes longer but sure beats flat tires. > > BTW, with my leakguards my tires lose one psi or less in six or eight week s. > > Harry Crosby > RV-6, coming up on 1300 hours > > From: "Linn Walters" <flying-nut(at)cfl.rr.com> > To: "RV-List" > Sent: Wednesday, January 21, 2015 12:48:26 PM > Subject: Re: RV-List: Leakguard tubes belong in the trash > > In my (limited) experience, a tube will only wear through if assembled wit hout talc or was underinflated. > I talc everything .... tube, inside of tire and even the wheel hub. Extra talc on the tire bead will make tire removal much easier down the road ... e r ... airway :-D . > Linn > > > On 1/21/2015 11:12 AM, Bill Judge wrote: > Folks, > I just got a second flat and the culprit was again the leakguard inner tub e. If you're using these I recommend you get rid of them the next time you h ave your tires off or sooner. > > The tube just wore through and leaked. I've never seen this happen to any o ther brand of tube. > > Of course it happened at a rather inconvenient time, I was landing at Brow n Field, coming back from Mexico, when you are not supposed to get out the t he aircraft until the customs agent authorizes... I limped off the runway, p ulled the wheel pant, and then limped to the customs box... fun fun. > > Fly Safe, > > > Bill Judge > N84WJ, RV-8, 1103 hrs > http://rv-8.blogspot.com/ > > > > > > No virus found in this message. > Checked by AVG - www.avg.com > 01/21/15 > > > > > _blank" data-mce-href="http://www.aeroelectric.com">www.aeroelectric.com > " target="_blank" data-mce-href="http://www.buildersbooks.com">www.bui ldersbooks.com > ="_blank" data-mce-href="http://www.homebuilthelp.com">www.homebuilthe lp.com > ="_blank" data-mce-href="http://www.mypilotstore.com">www.mypilotstore .com > ank" data-mce-href="http://www.mrrace.com">www.mrrace.com > _blank" data-mce-href="http://www.matronics.com/contribution">http://www .matronics.com/contribution > t="_blank" data-mce-href="http://www.matronics.com/Navigator?RV-List"> http://www.matronics.com/Navigator?RV-List > ta-mce-href="http://forums.matronics.com">http://forums.matronics.com > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 22, 2015
Subject: Lasercut Labels For Panel & Interior (With Pics)
I spent a day or so on the CAD laying out all the new panel and interior labels for the RV-8 and also the RV-6 while I was at it. Lot's of precision pays off here. I emailed PDF files of the labels to Ms Carita in Livermore, a label making company, and ordered up some labels. I marked in red where I wanted them cut out. Today, I picked them up and they are pretty amazing! All I have to do is peal them off the backing and apply! They are similar to what I had on the RV-8 v1.0, but it seems that they did a better job than the first company. Nothing makes an interior more professional than professional looking labels, IMHO. These cost me $25/sheet. Well worth it!! - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jan 23, 2015
I had stick-on vinyl labels made for my -6. They are the same material that they use for "wraps" on vehicles. They look good and weigh next to nothing however they cost more than the laser cut labels. Warren -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Thursday, January 22, 2015 8:11 PM Subject: RV-List: Lasercut Labels For Panel & Interior (With Pics) I spent a day or so on the CAD laying out all the new panel and interior labels for the RV-8 and also the RV-6 while I was at it. Lot's of precision pays off here. I emailed PDF files of the labels to Ms Carita in Livermore, a label making company, and ordered up some labels. I marked in red where I wanted them cut out. Today, I picked them up and they are pretty amazing! All I have to do is peal them off the backing and apply! They are similar to what I had on the RV-8 v1.0, but it seems that they did a better job than the first company. Nothing makes an interior more professional than professional looking labels, IMHO. These cost me $25/sheet. Well worth it!! - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Feb 04, 2015
Subject: Navworx ADS600b and SL70
Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. What say ye oh "been there, done that" t-shirt wearers? Thanks, Ralph ________________________________________________________________________________
From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com>
Date: Feb 04, 2015
I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". Regards, Greg Young -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, February 04, 2015 3:54 PM Subject: RV-List: Navworx ADS600b and SL70 Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. What say ye oh "been there, done that" t-shirt wearers? Thanks, Ralph ________________________________________________________________________________
Date: Feb 04, 2015
I've got Rev. 33 of the NavWorx install manual and can't find any reference to extended and remote modes. Where did you find the reference to programming the SL-70? Greg -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bigdog(at)bentwing.com Sent: Wednesday, February 04, 2015 5:16 PM Subject: RE: RV-List: Navworx ADS600b and SL70 --> I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". Regards, Greg Young -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, February 04, 2015 3:54 PM Subject: RV-List: Navworx ADS600b and SL70 Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. What say ye oh "been there, done that" t-shirt wearers? Thanks, Ralph ________________________________________________________________________________
Date: Feb 05, 2015
Cross-posted to make sure everyone can see responses..... I was initially asking them about the differences between connecting pins 3 and 5 of the SL70 to pins 32 and 33 of the ADS600B for control versus connecting pins 3 and 5 of the SL70 to pins 6 and 7 of the ADS600B for altitude data. Their initial response indicated that I only need 3 and 5 to 32 and 33 as that connection will pass control and data messages. They followed up with indicating extended mode or remote mode were also required - I haven't been able to get a direct response to that question. I sent them pdf's of the SL70 install and user guides - my Navworx manual is rev 33 (guessing from the part number) - it doesn't have any references to remote mode for the SL70...but it does reference a remote mode for the GNS480 and GTX330 units. There is a remote ident supress feature common to the ADS600B (pin 35) and the SL70 (pin 19), which NavWorx recommended to connect also. >From reading everyone's manuals, my gut tells me that connecting pins 3, 5, and 19 of the SL70 to pins 32, 33, and 35 (respectively) of the ADS600B is all that is required....no 'programming' in the SL70 - but there are settings in the ADS600B.... This is how I'm planning my installation - unless I get additional/contrary guidance from NavWorx. Ralph -----Original Message----- >From: "bigdog(at)bentwing.com" >Sent: Feb 4, 2015 6:54 PM >To: "rv-list(at)matronics.com" >Subject: RE: RV-List: Navworx ADS600b and SL70 > > >I've got Rev. 33 of the NavWorx install manual and can't find any reference to extended and remote modes. Where did you find the reference to programming the SL-70? > >Greg > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bigdog(at)bentwing.com >Sent: Wednesday, February 04, 2015 5:16 PM >To: rv-list(at)matronics.com; avionics-list(at)matronics.com >Subject: RE: RV-List: Navworx ADS600b and SL70 > >--> > >I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". > >Regards, >Greg Young > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, February 04, 2015 3:54 PM >To: avionics-list(at)matronics.com; rv-list >Subject: RV-List: Navworx ADS600b and SL70 > > >Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear > >The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. > >What say ye oh "been there, done that" t-shirt wearers? > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Feb 05, 2015
Subject: Re: Navworx ADS600b and SL70
Greg, I have similar equipment (420W instead of 430W) in my 6A. >From what I have read in everyone's manuals, the position out from the 400W/500W series does not carry the same formatting (message number) that the NavWorx box is expecting (even though it is a standard ARINC message) - so plan on the additional GPS antenna for the NavWorx box and don't waste your time trying to get position data out of the 400W/500W series units. Since the MX20 will take in both traffic and weather data streams from the ADS600B and the 400W/500W series will only take traffic, I am seriously considering NOT burdening the 400W/500W box's processor with the data stream. Ralph -----Original Message----- >From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com> >Sent: Feb 4, 2015 6:15 PM >To: "rv-list(at)matronics.com" , "avionics-list(at)matronics.com" >Subject: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 > >--> Avionics-List message posted by: "bigdog(at)bentwing.com" > >I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". > >Regards, >Greg Young > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, February 04, 2015 3:54 PM >To: avionics-list(at)matronics.com; rv-list >Subject: RV-List: Navworx ADS600b and SL70 > > >Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear > >The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. > >What say ye oh "been there, done that" t-shirt wearers? > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Feb 05, 2015
Subject: NavWorx / SL 70 -> Extended mode
>From the folks at NavWorx - kudos to them for documenting this...I expect to find it in a NavWorx manual update soon. The SL70 IM is missing the instructions on how to configure it for extended mode. On page 31 of the 2003 Garmin SL70 installation manual, Appendix E Serial Interface Specification, there is reference/clue in the paragraph Message Definitions. Messages are divided into two groups, the Standard Message which is simply the pressure altitude and system status and the Extended Message group which includes the squawk code and all the other good stuff listed in Appendix E. The last sentence references that this is accomplished in the setup mode and saved in the EEPROM. What is missing is exactly how to do this. The procedure is as follows: Reference page 12 of the 2003 Apollo SL70 Installation Manual Post Installation Checkout 1. Put the unit in setup mode: A. To operate the SL70 in the setup mode hold down the IDENT and ALT buttons while turning the power on 2. Turn the large knob to the SL70 config page a. This should be one click clockwise and change from set up to SL70 config 3. Using the small knob: a. Turn to ASRC This is the altitude source page b. The two choices for altitude INPUT are gray or serial i. Unless Navworx can update its software to run at 1200 baud, an encoder capable of gray code and or a serial to gray code convertor such as Dynon Manufactures will need to be used to interface with the SL70. The SL70 will only accept altitude data from an encoder at 1200 baud. ii. So at this point assuming you use the serial to gray converter, set the input to GRAY by: 1. Press the ident button the serial or gray field will start to flash 2. Set to gray if not already indicating gray 3. Press ident again to set into the memory if the setting was changed, if not proceed 4. Turn the small knob one click to set the baud rate a. To select and change the baud rate, press the ident button once, the baud rate field will start to flash b. To interface with the Navworx unit, at present, the baud rate will need to be set to 9,600 c. Turn the small knob until 9600 in displayed and press the ident button again to set into memory 5. Here is what is missing from the manual Turn the small knob clockwise one click to the next input screen a. The next screen is the TX screen The TX is for the message transmit format used on the serial port b. There are two options Standard STD and Extended EXT c. Press the ident button to highlight the field. It will start to flash d. Turn the small knob to set the EXT into the field e. Press the ident button again to set the field 6. Cycle the SL70 power off and turn back on. The SL70 is good to go and should now be set up to control the Navworx unit a. Using the maintenance port on the Navworx, set the Input screen to SL70 and DB37 pin 33. I have not verified this from a functionality standpoint yet. In my installation, the SL70 port referenced above is currently being used to provide altitude data to my MX20 - so I have a couple of if scenarios.....: If the baud rate on the SL70 port is currently at 9600 and if my MX20 ignores the extended stuff and parses out just the altitude, I'm OK by simply forking the serial output to both the MX20 and the ADS600B. Otherwise, if the MX20 is version 5.6 or later, it should take altitude data along with the Lat/Long it is already receiving from the 420W and freeing up the port for dedicated communication with the ADS600B. I prefer the latter - but I'll take whatever I can get! Hope this helps - and thanks again to the NavWorx crew! Ralph ________________________________________________________________________________
Date: Feb 09, 2015
Subject: NavWorx ADS600B integration to Garmin based panel -> the saga
continues Folks, Here's another update since getting the details on implementing the "Extended" mode from the NavWorx folks: I was able to get the SL70 configured for the "Extended" mode per their instructions. The extended mode data did not interfere with passing altitude data to the MX20 as currently connected. Their additional requirements are causing some interoperability issues.... The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud - which the SL70 is capable of delivering. The 9600 baud setting is not compatible with the MX20 - which only allows 1200 baud communications. I have a note in to NavWorx to see if they are going to allow 1200 baud in the future...I'm not the only one with this issue! As a potential workaround, I looked at the documentation for my GNC420W. It indicates that it is capable of transmitting the altitude data to the MX20 along with the existing connection that provides lat/long. I tried that too - it doesn't work. I have a note in to Garmin to see if there is a configuration setting that I missed or if there was a printing error. If all else fails - throw money at it.....I can replace the installed altitude encoder with one that has a 1200 baud serial port as well as the Gray code. I'm starting to see why everyone is screaming about the cost vs benefit of ADS-B in the first place..... Ralph ________________________________________________________________________________
saga continues
Date: Feb 09, 2015
I was originally going to use their TransMonSPE instead of hard wiring to my transponder. It's a device that clips over the transponder cable and picks up the altitude and code from the RF leakage. Since it looked like I could wire everything I backed off that but have that as an option if I hit the same snags as you. It's fairly cheap, <$80 I think. Greg Young -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, February 09, 2015 11:53 AM Subject: RV-List: NavWorx ADS600B integration to Garmin based panel -> the saga continues Folks, Here's another update since getting the details on implementing the "Extended" mode from the NavWorx folks: I was able to get the SL70 configured for the "Extended" mode per their instructions. The extended mode data did not interfere with passing altitude data to the MX20 as currently connected. Their additional requirements are causing some interoperability issues.... The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud - which the SL70 is capable of delivering. The 9600 baud setting is not compatible with the MX20 - which only allows 1200 baud communications. I have a note in to NavWorx to see if they are going to allow 1200 baud in the future...I'm not the only one with this issue! As a potential workaround, I looked at the documentation for my GNC420W. It indicates that it is capable of transmitting the altitude data to the MX20 along with the existing connection that provides lat/long. I tried that too - it doesn't work. I have a note in to Garmin to see if there is a configuration setting that I missed or if there was a printing error. If all else fails - throw money at it.....I can replace the installed altitude encoder with one that has a 1200 baud serial port as well as the Gray code. I'm starting to see why everyone is screaming about the cost vs benefit of ADS-B in the first place..... Ralph ________________________________________________________________________________
Date: Feb 09, 2015
Subject: Re: NavWorx ADS600B integration to Garmin based panel -> the
saga continues An update from NavWorx - they support 1200 baud communications. Should solve all of the issues I am experiencing! -----Original Message----- >From: "'Ralph E. Capen' recapen(at)earthlink.net [RV7A]" <RV7A(at)yahoogroups.com> >Sent: Feb 9, 2015 12:52 PM >To: rv-list , "avionics-list(at)matronics.com" >Cc: RV7 Yahoo list , EXP-AVIONICS >Subject: [RV Builders] NavWorx ADS600B integration to Garmin based panel -> the saga continues > >Folks, > >Here's another update since getting the details on implementing the "Extended" mode from the NavWorx folks: > >I was able to get the SL70 configured for the "Extended" mode per their instructions. The extended mode data did not interfere with passing altitude data to the MX20 as currently connected. > >Their additional requirements are causing some interoperability issues.... The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud - which the SL70 is capable of delivering. The 9600 baud setting is not compatible with the MX20 - which only allows 1200 baud communications. I have a note in to NavWorx to see if they are going to allow 1200 baud in the future...I'm not the only one with this issue! > >As a potential workaround, I looked at the documentation for my GNC420W. It indicates that it is capable of transmitting the altitude data to the MX20 along with the existing connection that provides lat/long. I tried that too - it doesn't work. I have a note in to Garmin to see if there is a configuration setting that I missed or if there was a printing error. > >If all else fails - throw money at it.....I can replace the installed altitude encoder with one that has a 1200 baud serial port as well as the Gray code. > >I'm starting to see why everyone is screaming about the cost vs benefit of ADS-B in the first place..... > >Ralph ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Feb 15, 2015
Wanted to update the list with the following, the Airport Courtesy Car app as of this date has over 1300 listings nationwide with over 5000 pilots that have downloaded the app. It continues to be covered by major publications. Since AvWeb covered it and AOPA Pilot magazine in the February issue, it has most recently been favored by G.A. News. Also I can now upload pictures of your favorite crew cars to the state listings, so email those pictures to me at airportcars101(at)gmail.com. And keep those entries coming! -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438391#438391 ________________________________________________________________________________
Date: Feb 21, 2015
saga continues
I have the TransMonSPE and it works great! Very easy to install. Dave Leonard On Mon, Feb 9, 2015 at 10:13 AM, bigdog(at)bentwing.com wrote: > > I was originally going to use their TransMonSPE instead of hard wiring to > my transponder. It's a device that clips over the transponder cable and > picks up the altitude and code from the RF leakage. Since it looked like I > could wire everything I backed off that but have that as an option if I hit > the same snags as you. It's fairly cheap, <$80 I think. > > Greg Young > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto: > owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen > Sent: Monday, February 09, 2015 11:53 AM > To: rv-list; avionics-list(at)matronics.com > Subject: RV-List: NavWorx ADS600B integration to Garmin based panel -> the > saga continues > > > Folks, > > Here's another update since getting the details on implementing the > "Extended" mode from the NavWorx folks: > > I was able to get the SL70 configured for the "Extended" mode per their > instructions. The extended mode data did not interfere with passing > altitude data to the MX20 as currently connected. > > Their additional requirements are causing some interoperability issues.... > The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud > - which the SL70 is capable of delivering. The 9600 baud setting is not > compatible with the MX20 - which only allows 1200 baud communications. I > have a note in to NavWorx to see if they are going to allow 1200 baud in > the future...I'm not the only one with this issue! > > As a potential workaround, I looked at the documentation for my GNC420W. > It indicates that it is capable of transmitting the altitude data to the > MX20 along with the existing connection that provides lat/long. I tried > that too - it doesn't work. I have a note in to Garmin to see if there is > a configuration setting that I missed or if there was a printing error. > > If all else fails - throw money at it.....I can replace the installed > altitude encoder with one that has a 1200 baud serial port as well as the > Gray code. > > I'm starting to see why everyone is screaming about the cost vs benefit of > ADS-B in the first place..... > > Ralph > > ________________________________________________________________________________
Date: Mar 01, 2015
Now approaching 6000 pilots using the app with over 1350 listings, and a recent review on the EAA website. And in a feeble attempt to recoup my costs, I am now offering very reasonably priced ad's for aviation related businesses as I keep my word to keep this app free for pilots. If you or someone you know may be interested, please email me at airportcars101(at)gmail.com for rates. And please tell your FBO where you found them. Thank you. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438836#438836 ________________________________________________________________________________
Date: Mar 03, 2015
Subject: Infinity grip switch driving S702 starter relay
Anyone else using an Infinity grip switch to actuate a S702 starter relay? According to the specs of the Infinity grip switches, the contacts are rated at 6Amp. >From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out to 5.6Amps...and that would be a max since the battery would provide less at cranking time. The numbers say it should be OK - I'm looking to find out if anyone is doing it for real - and how is it working for you? Thanks, Ralph Capen ________________________________________________________________________________
Subject: Re: Infinity grip switch driving S702 starter relay
Date: Mar 03, 2015
Ralph. I would recommend you look at our Smartstart module for doing this function if you want to use the stick grip switch to drive the start contactor. The switches used in the stick grip may be rated at 6 amps, but that would be for a resistive load. The start contactor is an inductive load and has a significantly different effect in switches than a pure resistor. Additionally, our module has a built in one minute timer and an interlock feature, making the stick grip starting concept safer and more useful. All the info is at www.tcwtech.com Bob Newman TCW Technologies, LLC 610-928-3420 > On Mar 3, 2015, at 8:07 AM, Ralph E. Capen wrote: > > > > Anyone else using an Infinity grip switch to actuate a S702 starter relay? > > According to the specs of the Infinity grip switches, the contacts are rated at 6Amp. >> From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out > to 5.6Amps...and that would be a max since the battery would provide less at cranking > time. > > The numbers say it should be OK - I'm looking to find out if anyone is doing it for > real - and how is it working for you? > > Thanks, > Ralph Capen > > > > > > ________________________________________________________________________________
Date: Mar 03, 2015
Interesting - I'll look in to this.... How many are out there interfacing the Infinity grip switch to the Starter relay? Still want to hear if anyone is using my stated configuration though.... Thanks -----Original Message----- >From: Tcwtech <rnewman(at)tcwtech.com> >Sent: Mar 3, 2015 8:30 AM >To: "rv-list(at)matronics.com" >Subject: Re: RV-List: Infinity grip switch driving S702 starter relay > > >Ralph. I would recommend you look at our Smartstart module for doing this function if you want to use the stick grip switch to drive the start contactor. The switches used in the stick grip may be rated at 6 amps, but that would be for a resistive load. The start contactor is an inductive load and has a significantly different effect in switches than a pure resistor. >Additionally, our module has a built in one minute timer and an interlock feature, making the stick grip starting concept safer and more useful. > >All the info is at www.tcwtech.com > > >Bob Newman >TCW Technologies, LLC >610-928-3420 > >> On Mar 3, 2015, at 8:07 AM, Ralph E. Capen wrote: >> >> >> >> Anyone else using an Infinity grip switch to actuate a S702 starter relay? >> >> According to the specs of the Infinity grip switches, the contacts are rated at 6Amp. >>> From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out >> to 5.6Amps...and that would be a max since the battery would provide less at cranking >> time. >> >> The numbers say it should be OK - I'm looking to find out if anyone is doing it for >> real - and how is it working for you? >> >> Thanks, >> Ralph Capen >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 03, 2015
Ralph, you may find some folks that are using the infinity switch direct for the starter contactor but our fleet is relatively young. Problems won't surface 'till down the road a ways. My start switch is is on the key so I didn't have your same situation. However, it's far better to wire in a relay now than later, IMHO. My question is why put the starter on the grip anyway? You only use it once each flight and typically don't need to have your hand on the grip at that time. Plus, what keeps you from accidentally hitting that switch while you're in the air??? Linn On 3/3/2015 8:48 AM, Ralph E. Capen wrote: > > > Interesting - I'll look in to this.... > How many are out there interfacing the Infinity grip switch to the Starter relay? > > Still want to hear if anyone is using my stated configuration though.... > > Thanks > > > -----Original Message----- >> From: Tcwtech <rnewman(at)tcwtech.com> >> Sent: Mar 3, 2015 8:30 AM >> To: "rv-list(at)matronics.com" >> Subject: Re: RV-List: Infinity grip switch driving S702 starter relay >> >> >> Ralph. I would recommend you look at our Smartstart module for doing this function if you want to use the stick grip switch to drive the start contactor. The switches used in the stick grip may be rated at 6 amps, but that would be for a resistive load. The start contactor is an inductive load and has a significantly different effect in switches than a pure resistor. >> Additionally, our module has a built in one minute timer and an interlock feature, making the stick grip starting concept safer and more useful. >> >> All the info is at www.tcwtech.com >> >> >> Bob Newman >> TCW Technologies, LLC >> 610-928-3420 >> >>> On Mar 3, 2015, at 8:07 AM, Ralph E. Capen wrote: >>> >>> >>> >>> Anyone else using an Infinity grip switch to actuate a S702 starter relay? >>> >>> According to the specs of the Infinity grip switches, the contacts are rated at 6Amp. >>>> From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out >>> to 5.6Amps...and that would be a max since the battery would provide less at cranking >>> time. >>> >>> The numbers say it should be OK - I'm looking to find out if anyone is doing it for >>> real - and how is it working for you? >>> >>> Thanks, >>> Ralph Capen >>> >>> >>> >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 03, 2015
Linn, Good points made! I currently have it on a relay that the hand-grip activates with a safety interlock switch - my line of thinking is to simplify by removing the relay and driving it direct. My initial line of thinking for putting it on the hand-grip was for an in-flight restart - which would require one hand on the stick while the other works throttle and mixture. What I currently have works very well - but it is complex and I am trying to simplify... Looking for evidence of the problem you alluded to. Thanks, Ralph -----Original Message----- >From: Linn Walters <flying-nut(at)cfl.rr.com> >Sent: Mar 3, 2015 9:20 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Infinity grip switch driving S702 starter relay > > >Ralph, you may find some folks that are using the infinity switch direct >for the starter contactor but our fleet is relatively young. Problems >won't surface 'till down the road a ways. My start switch is is on the >key so I didn't have your same situation. However, it's far better to >wire in a relay now than later, IMHO. > >My question is why put the starter on the grip anyway? You only use it >once each flight and typically don't need to have your hand on the grip >at that time. Plus, what keeps you from accidentally hitting that >switch while you're in the air??? >Linn > >On 3/3/2015 8:48 AM, Ralph E. Capen wrote: >> >> >> Interesting - I'll look in to this.... >> How many are out there interfacing the Infinity grip switch to the Starter relay? >> >> Still want to hear if anyone is using my stated configuration though.... >> >> Thanks >> >> >> >> >> -----Original Message----- >>> From: Tcwtech <rnewman(at)tcwtech.com> >>> Sent: Mar 3, 2015 8:30 AM >>> To: "rv-list(at)matronics.com" >>> Subject: Re: RV-List: Infinity grip switch driving S702 starter relay >>> >>> >>> Ralph. I would recommend you look at our Smartstart module for doing this function if you want to use the stick grip switch to drive the start contactor. The switches used in the stick grip may be rated at 6 amps, but that would be for a resistive load. The start contactor is an inductive load and has a significantly different effect in switches than a pure resistor. >>> Additionally, our module has a built in one minute timer and an interlock feature, making the stick grip starting concept safer and more useful. >>> >>> All the info is at www.tcwtech.com >>> >>> >>> Bob Newman >>> TCW Technologies, LLC >>> 610-928-3420 >>> >>>> On Mar 3, 2015, at 8:07 AM, Ralph E. Capen wrote: >>>> >>>> >>>> >>>> Anyone else using an Infinity grip switch to actuate a S702 starter relay? >>>> >>>> According to the specs of the Infinity grip switches, the contacts are rated at 6Amp. >>>>> From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out >>>> to 5.6Amps...and that would be a max since the battery would provide less at cranking >>>> time. >>>> >>>> The numbers say it should be OK - I'm looking to find out if anyone is doing it for >>>> real - and how is it working for you? >>>> >>>> Thanks, >>>> Ralph Capen >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 03, 2015
I agree with Linn and others concerning the need for a relay. I wish I had used one of my Infinity Grip buttons for starting. I do want to hold the stick when starting, and I find that for activating my start button, manipulating mixture and throttle, and holding the stick, I am short one hand. (especially starting when the engine is hot) In my case, the VP-200 would take care of the issue of activating the starter when you don't want it activated. Otherwise, I would use Bob's TcwTech start protection switch. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438936#438936 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Mar 03, 2015
Ralph, On the RV-8A the first version had the bottom push button on the stick being the start button, providing power to the starter solenoid. This button does not have the capacity to operate the starter solenoid directly. I installed a small 12VDC relay (100ma coil, ~$1.50 from Allied Electronics) in the circuit such that the stick button operated the relay, the relay then provided power to the starter solenoid. But - this setup was quickly changed as twice during the first flights I inadvertently bumped the stick start button while the engine was running. I kept the relay set up and just added a small momentary pushbutton out of the way at the top of the right side switch/breaker panel to use instead of the stick button. On the RV-10 I just used the standard 10amp panel pushbutton for engine start to directly provide power to the starter solenoid. Bottom line - recommend not using the stick buttons to operate the starter solenoid. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Tuesday, March 03, 2015 8:08 AM Subject: RV-List: Infinity grip switch driving S702 starter relay Anyone else using an Infinity grip switch to actuate a S702 starter relay? According to the specs of the Infinity grip switches, the contacts are rated at 6Amp. >From the B and C site, the S702 has a 2.5Ohm coil - so the math at >14volts works out to 5.6Amps...and that would be a max since the battery would provide less at cranking time. The numbers say it should be OK - I'm looking to find out if anyone is doing it for real - and how is it working for you? Thanks, Ralph Capen ________________________________________________________________________________
Date: Mar 03, 2015
Carl, Thanks for your input. I have a secondary safety switch to prevent the accidental activation along with the relay like you described currently installed. My intent was to simplify by removing the relay. Sounds like my best bet is to leave it as is! It works great for me..... Ralph -----Original Message----- >From: Carl Froehlich <carl.froehlich(at)verizon.net> >Sent: Mar 3, 2015 9:54 AM >To: rv-list(at)matronics.com, aeroelectric-list(at)matronics.com >Subject: RE: RV-List: Infinity grip switch driving S702 starter relay > > >Ralph, > >On the RV-8A the first version had the bottom push button on the stick being >the start button, providing power to the starter solenoid. This button does >not have the capacity to operate the starter solenoid directly. I installed >a small 12VDC relay (100ma coil, ~$1.50 from Allied Electronics) in the >circuit such that the stick button operated the relay, the relay then >provided power to the starter solenoid. > >But - this setup was quickly changed as twice during the first flights I >inadvertently bumped the stick start button while the engine was running. I >kept the relay set up and just added a small momentary pushbutton out of the >way at the top of the right side switch/breaker panel to use instead of the >stick button. > >On the RV-10 I just used the standard 10amp panel pushbutton for engine >start to directly provide power to the starter solenoid. > >Bottom line - recommend not using the stick buttons to operate the starter >solenoid. > >Carl > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Tuesday, March 03, 2015 8:08 AM >To: aeroelectric-list(at)matronics.com; rv-list >Subject: RV-List: Infinity grip switch driving S702 starter relay > > >Anyone else using an Infinity grip switch to actuate a S702 starter relay? > >According to the specs of the Infinity grip switches, the contacts are rated >at 6Amp. >>From the B and C site, the S702 has a 2.5Ohm coil - so the math at >>14volts works out >to 5.6Amps...and that would be a max since the battery would provide less at >cranking time. > >The numbers say it should be OK - I'm looking to find out if anyone is doing >it for real - and how is it working for you? > >Thanks, >Ralph Capen > > ________________________________________________________________________________
Date: Mar 03, 2015
David, Thanks for the info. I'll probably leave mine as is since the relay and safety switch work well! Ralph -----Original Message----- >From: "dmaib(at)me.com" <dmaib(at)me.com> >Sent: Mar 3, 2015 9:53 AM >To: rv-list(at)matronics.com >Subject: RV-List: Re: Infinity grip switch driving S702 starter relay > > >I agree with Linn and others concerning the need for a relay. I wish I had used one of my Infinity Grip buttons for starting. I do want to hold the stick when starting, and I find that for activating my start button, manipulating mixture and throttle, and holding the stick, I am short one hand. (especially starting when the engine is hot) In my case, the VP-200 would take care of the issue of activating the starter when you don't want it activated. Otherwise, I would use Bob's TcwTech start protection switch. > >-------- >David Maib >RV-10 #40559 >New Smyrna Beach, FL > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=438936#438936 > > ________________________________________________________________________________
Date: Mar 03, 2015
This post since it was cross posted, may not have gotten the same follow-up on all lists, but I'll add my reply to another poster's comment on prop windmilling being enough in-flight... --- I know in my case I've done complete mixture cut-off tests in the plane where I've stopped the engine completely, and also flown it dry on tanks for testing, and the prop keeps spinning so fast that you may even perceive that the engine is still making power. You just feel the loss of thrust. So unless you happen to pull the nose up and near-stall the plane, I doubt the starter will ever need to be cranked to re-start. For me, as soon as the fuel supply was there again, it roared back to life. Also, the start operation isn't *that* complicated. I understand the want to have a hand on the stick and one on the throttle/mixture, but my knees do a fine job of holding the stick for a normal start. Additionally, if the plane is in trim, I don't see the worry about holding the stick with a hand while doing that once-in-a-hundred-years in-flight restart that you may do. The knees would do ok there too, but in actuality, you're not going to be manipulating the mixture and throttle much if you're doing an in-flight start. It's not like you'll be doing a hot-start procedure at 7,000'. Tim ________________________________________________________________________________
Date: Mar 03, 2015
S702 starter relay I guess I am missing the need for any of this. In flight use of starter?? Maybe if you had a full feathering prop, otherwise the prop is your starter, just push the nose over. Need to hold stick while starting? Unless you are facing into winds that approach rotation speed, what does holding the stick accomplish? While some like switches for mags.EI and a button for starting, the old twist to start ignition switch does simply things a lot. Unless you have 3 hands, you are always going to need one to activate starter and one on the throttle/mixture knobs. I guess having button on stick lets you use one hand to holde stick and activate starter with the other on throttle, but I still don't see the need to hold the stick. It is the brakes that will hold the plane from going anywhere. If wind is strong enough to need stick input, you probably need wing walkers to keep the wing tips and wheels near the ground. On 3/3/2015 8:16 AM, Ralph E. Capen wrote: > --> AeroElectric-List message posted by: "Ralph E. Capen" > > > David, > > Thanks for the info. I'll probably leave mine as is since the relay and safety switch work well! > > Ralph > > > -----Original Message----- >> From: "dmaib(at)me.com" <dmaib(at)me.com> >> Sent: Mar 3, 2015 9:53 AM >> To: rv-list(at)matronics.com >> Subject: RV-List: Re: Infinity grip switch driving S702 starter relay >> >> >> I agree with Linn and others concerning the need for a relay. I wish I had used one of my Infinity Grip buttons for starting. I do want to hold the stick when starting, and I find that for activating my start button, manipulating mixture and throttle, and holding the stick, I am short one hand. (especially starting when the engine is hot) In my case, the VP-200 would take care of the issue of activating the starter when you don't want it activated. Otherwise, I would use Bob's TcwTech start protection switch. >> >> -------- >> David Maib >> RV-10 #40559 >> New Smyrna Beach, FL >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=438936#438936 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 03, 2015
=0AIt may also be an AC rating. DC is significantly harde r on contacts during switching. The combination of DC switc hing and collapsing flux field from a large inductive would be death fro the switch. In DC applications always ensure that you have a back biased catch diode installed across an inductive load or the back EMF can take out the switching component in short order.=0A=0A-GV=0A =0A =0A-----Original Message-- ---=0AFrom: Tcwtech <rnewman(at)tcwtech.com>=0ATo: rv-list <rv-list@matroni cs.com>=0ASent: Tue, Mar 3, 2015 5:32 am=0ASubject: Re: RV-List: Infinity grip switch driving S702 starter relay=0A=0A=0A--> RV- List message posted by: Tcwtech =0A=0ARalph. I would recommend you look at our Smartstart module for doin g this =0Afunction if you want to use the stick grip switc h to drive the start contactor. =0AThe switches used in the stick grip may be rated at 6 amps, but that would be =0Afor a resistive load. The start contactor is an inductive load and has a =0Asignificantly different effect in switches than a pure resistor. =0AAdditionally, our module has a built in one minute timer and an interlock =0Afeature, making the stick grip starting concept safer and more usefu l. =0A=0AAll the info is at www.tcwtech.com =0A=0A=0ABob Newm an=0ATCW Technologies, LLC=0A610-928-3420=0A=0A> On Mar 3, 2015, a t 8:07 AM, Ralph E. Capen wrote:=0A> =0A thlink.net>=0A> =0A> =0A> Anyone else using an Infinity grip s witch to actuate a S702 starter relay?=0A> =0A> According to the specs of the Infinity grip switches, the contacts are ra ted =0Aat 6Amp.=0A>> From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts =0Aworks out=0A> to 5.6Amps...and that would be a max since the battery would provide less at =0Acranking =0A> time.=0A> =0A> The numbers sa y it should be OK - I'm looking to find out if anyone is doing =0Ait for =0A> real - and how is it working for you?=0A> =0A> Thanks,=0A> Ralph Capen=0A> =0A> =0A> =0A> =0A> =========================== =========================== =========================== =========================== =========================== ======================0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Mar 16, 2015
Subject: Re: RV-List Digest: 0 Msgs - 03/15/15
Lycoming Cylinder problem Hello fellow RV'rs, =C2-Looking for advice, here's my situation \ problem . (I have an RV6, w an 0-320 A2B which was installed rebuilt, modified to 1 60 HP, during construction about 700 hrs ago). It has been running great, b ut I have been seeing =C2-a couple of small oil leaks, (which have gotten to be quite annoying.) While doing an oil change recently, I discovered on e of the top cylinder bolts (small one - not the larger thru bolts) had she ared off. I had not done anything to it whatsoever, nor was there any evide nce of looseness or an oil leak in that area, the broken part was just sitt ing there, I then jiggled the other upper bolts by hand and =C2-. . . 2 o f them were just finger tight!. =C2-Someone (a local A&P) suggested that a good welder could weld a nut to the broken stud and remove it that way - but that sounds way to "scary" to me.=C2-=C2- =C2- Any advice appreci ated. Also . . . is the plane grounded until the repair??=C2- =C2-Thank s in advance=C2- =C2-David Wentzell - =C2-N233DW On Monday, March 16, 2015 3:24 AM, RV-List Digest Server wrote: * ======================== =C2- Online Versions of Today's List Digest Archive ======================== Today's complete RV-List Digest can also be found in either of the two Web Links listed below.=C2- The .html file includes the Digest format ted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.=C2- The .txt file includes the plain ASCII versio n of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=html&Chapter 15-03-15&Archive=RV Text Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=txt&Chapter 15-03-15&Archive=RV ======================== ======================= =C2- EMail Version of Today's List Digest Archive ======================== ======================= =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- RV-List Digest Archive =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- --- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Total Messages Posted Sun 03/15/15: 0 =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ Today's Message Index: ---------------------- S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Mar 16, 2015
I'll defer to the guru mechanics out there, but if it was my plane the engine would get pulled, disassembled and repaired as needed. I would assume other bolts that had taken up the load of those bolts that you found loose had deformed - and perhaps this is what caused your sheared bolt. Note - Mike Busch has voiced his opinion (which I agree with) that engine cylinders cannot be properly removed/replace without removing the engine from the aircraft as this impedes achieving correct cylinder bolt torque. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of d wntzl Sent: Monday, March 16, 2015 12:45 PM Subject: RV-List: Re: RV-List Digest: 0 Msgs - 03/15/15 Lycoming Cylinder problem Hello fellow RV'rs, Looking for advice, here's my situation \ problem. (I have an RV6, w an 0-320 A2B which was installed rebuilt, modified to 160 HP, during construction about 700 hrs ago). It has been running great, but I have been seeing a couple of small oil leaks, (which have gotten to be quite annoying.) While doing an oil change recently, I discovered one of the top cylinder bolts (small one - not the larger thru bolts) had sheared off. I had not done anything to it whatsoever, nor was there any evidence of looseness or an oil leak in that area, the broken part was just sitting there, I then jiggled the other upper bolts by hand and . . . 2 of them were just finger tight!. Someone (a local A&P) suggested that a good welder could weld a nut to the broken stud and remove it that way - but that sounds way to "scary" to me. Any advice appreciated. Also . . . is the plane grounded until the repair?? Thanks in advance David Wentzell - N233DW On Monday, March 16, 2015 3:24 AM, RV-List Digest Server wrote: * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete RV-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte r 15-03-15&Archive=RV> &View=html&Chapter 15-03-15&Archive=RV Text Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-03-15&Archive=RV> &View=txt&Chapter 15-03-15&Archive=RV ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV-List Digest Archive --- Total Messages Posted Sun 03/15/15: 0 ----------------------------------------------------------
June 29, 2014 - March 16, 2015
RV-Archive.digest.vol-vu
