RV-Archive.digest.vol-vv
March 16, 2015 - January 15, 2016
      Today's Message Index:
      http               -Matt Dralle, List Admin.======
Date: Mar 16, 2015
Subject: Re: RV-List Digest: 0 Msgs - 03/15/15
Really? Mike is usually spot on but I find this to be an unfounded asserti on. On what evidence does he base this opinion? If this is true, thousands of aircraft over the last 50 years have been fly ing in an unairworthy condition. -GV Note =93 Mike Busch has voiced his opinion (which I agree with) that engine cylinders cannot be properly removed/replace without removing the en gine from the aircraft as this impedes achieving correct cylinder bolt torq ue. -----Original Message----- From: Carl Froehlich <carl.froehlich(at)verizon.net> Sent: Mon, Mar 16, 2015 5:06 pm Subject: RE: RV-List: Re: RV-List Digest: 0 Msgs - 03/15/15 I=99ll defer to the guru mechanics out there, but if it was my plane the engine would get pulled, disassembled and repaired as needed. I would assume other bolts that had taken up the load of those bolts that you found loose had deformed =93 and perhaps this is what caused your sheared bolt. Note =93 Mike Busch has voiced his opinion (which I agree with) that engine cylinders cannot be properly removed/replace without removing the en gine from the aircraft as this impedes achieving correct cylinder bolt torq ue. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of d wntzl Sent: Monday, March 16, 2015 12:45 PM Subject: RV-List: Re: RV-List Digest: 0 Msgs - 03/15/15 Lycoming Cylinder problem Hello fellow RV'rs, Looking for advice, here's my situation \ problem. (I have an RV6, w an 0-320 A2B which was installed rebuilt, modified to 160 HP , during construction about 700 hrs ago). It has been running great, but I have been seeing a couple of small oil leaks, (which have gotten to be qui te annoying.) While doing an oil change recently, I discovered one of the t op cylinder bolts (small one - not the larger thru bolts) had sheared off. I had not done anything to it whatsoever, nor was there any evidence of loo seness or an oil leak in that area, the broken part was just sitting there, I then jiggled the other upper bolts by hand and . . . 2 of them were jus t finger tight!. Someone (a local A&P) suggested that a good welder could weld a nut to the broken stud and remove it that way - but that sounds way to "scary" to me. Any advice appreciated. Also . . . is the plane grounded until the repa ir?? Thanks in advance David Wentzell - N233DW On Monday, March 16, 2015 3:24 AM, RV-List Digest Server wrote: * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete RV-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=htm l&Chapter 15-03-15&Archive=RV Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt &Chapter 15-03-15&Archive=RV ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV-List Digest Archive --- Total Messages Posted Sun 03/15/15: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- http -Matt Dralle, List Admin.====== http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 16, 2015
Subject: Re: Cylinder stud repair
There are several ways to remove a broken stud. I would consult with a respected engine shop, like Barrett Performance, Lycon, Mattictuck, or case overhauler such as Divco as to how they recommend removing the broken stud, and consider also removing the other studs for that cylinder, depending on very close examination with ten power magnifying lens and/or some form of non-destructive testing to ensure nothing is wrong with those studs. As to reassemble on the airframe, Mike may be right about big Continentals in Beech or Cessna airframes, particularly the cradle type mount, but he is full of horse feathers on a Lycoming on a Dynafocal mount.You just need the right cylinder wrenches and a good torque wrench with long enough handle for the torque needed. The most important item is to not move the crankshaft/prop when there is no torque on the through bolts. Position the prop before removing torque to where it is needed to remove that cylinder. If more needs to come apart, use torque plate or stack of washers and nuts to retorque the case before moving to another cylinder. Keeps the bearings secured in position. On 3/16/2015 5:05 PM, Carl Froehlich wrote: > > Ill defer to the guru mechanics out there, but if it was my plane the > engine would get pulled, disassembled and repaired as needed. I would > assume other bolts that had taken up the load of those bolts that you > found loose had deformed and perhaps this is what caused your > sheared bolt. > > Note Mike Busch has voiced his opinion (which I agree with) that > engine cylinders cannot be properly removed/replace without removing > the engine from the aircraft as this impedes achieving correct > cylinder bolt torque. > > Carl > > *From:*owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *d wntzl > *Sent:* Monday, March 16, 2015 12:45 PM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Re: RV-List Digest: 0 Msgs - 03/15/15 > > Lycoming Cylinder problem > > Hello fellow RV'rs, Looking for advice, here's my situation \ > problem. (I have an RV6, w an 0-320 A2B which was installed rebuilt, > modified to 160 HP, during construction about 700 hrs ago). It has > been running great, but I have been seeing a couple of small oil > leaks, (which have gotten to be quite annoying.) While doing an oil > change recently, I discovered one of the top cylinder bolts (small one > - not the larger thru bolts) had sheared off. I had not done anything > to it whatsoever, nor was there any evidence of looseness or an oil > leak in that area, the broken part was just sitting there, I then > jiggled the other upper bolts by hand and . . . 2 of them were just > finger tight!. Someone (a local A&P) suggested that a good welder > could weld a nut to the broken stud and remove it that way - but that > sounds way to "scary" to me. > > Any advice appreciated. Also . . . is the plane grounded until the > repair?? > > Thanks in advance > > David Wentzell - N233DW > > ________________________________________________________________________________
Date: Mar 18, 2015
Subject: Re: RV-List Digest: 0 Msgs - 03/17/15
Hello fellow RV'rs, =C2-Looking for advice, here's my situation \ problem . (I have an RV6, w an 0-320 A2B which was installed rebuilt, modified to 1 60 HP, during construction about 700 hrs ago). It has been running great, b ut I have been seeing =C2-a couple of small oil leaks, (which have gotten to be quite annoying.) While doing an oil change recently, I discovered on e of the top cylinder bolts (small one - not the larger thru bolts) had she ared off. I had not done anything to it whatsoever, nor was there any evide nce of looseness or an oil leak in that area, the broken part was just sitt ing there, I then jiggled the other upper bolts by hand and =C2-. . . 2 o f them were just finger tight!. =C2-Someone (a local A&P) suggested that a good welder could weld a nut to the broken stud and remove it that way - but that sounds way to "scary" to me.=C2-=C2- =C2- Any advice appreci ated. Also . . . is the plane grounded until the repair??David Wentzell N23 3DWdwntzl(at)yahoo.com On Wednesday, March 18, 2015 3:24 AM, RV-List Digest Server wrote: * ======================== =C2- Online Versions of Today's List Digest Archive ======================== Today's complete RV-List Digest can also be found in either of the two Web Links listed below.=C2- The .html file includes the Digest format ted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.=C2- The .txt file includes the plain ASCII versio n of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=html&Chapter 15-03-17&Archive=RV Text Version: =C2- =C2- http://www.matronics.com/digest/digestview.php?Style=82701& View=txt&Chapter 15-03-17&Archive=RV ======================== ======================= =C2- EMail Version of Today's List Digest Archive ======================== ======================= =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- RV-List Digest Archive =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- --- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- Total Messages Posted Tue 03/17/15: 0 =C2- =C2- =C2- =C2- =C2- ---------------------------------------- ------------------ Today's Message Index: ---------------------- S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Mar 18, 2015
I still get a lot of questions on how to download the Airport Courtesy Cars app on an iPad. So here are some simple instructions on how to do so. The app is approaching 1400 car listings with over 6,400 pilots that have downloaded the app. Glenn Go to the app store on your iPad, Click the search box and search for Airport Courtesy Cars, The search will not show any results, however when the search is complete a bar of menus will appear along the top of the page, The very first one on the left says "Ipad only", Click it to show a drop down menu, Choose "iPhone only" and Airport Courtesy Cars" will be displayed, and you can download the app. -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439544#439544 ________________________________________________________________________________
Date: Mar 19, 2015
Subject: Re: RV-List Digest: 4 Msgs - 03/16/15
Dave, I would not even run your engine with broken cylinder hold down bolts, never mind fly in it. As an A&P since 1976, That cylinder has to come off and all of the nuts/ studs/ bolts that were loose, I would replace. I'd also inspect all of the rest with a dye penetrate black light inspection and magnifying glass. ANY SUSPECT STUDS/ BOLTS that look even a little wonky (very technical term) Replace them. If your not comfortable doing the work, Pull the engine and have an engine shop do the work. Check ALL of the cylinder hold down bolts on all of the cylinders. Anything loose? Fix them. The bolts are a very intricate part of the engine. They go through hell, trying to hold the engine together as it's trying to ripe itself apart. Treat them with respect and while your at it, take a real good look at that cylinder for cracks around the mounting flange. It now has been subjected to allot more vibration/ movement then it was designed for. The flange may not be straight and the bolt holes may have elongated. Check for cracks here as well. As for not pulling the engine to do the work, I've pulled many of cylinders and it's an approved method of repair. That being said, I've also pulled 2 engines to do the work just because we pulled more then 2 cylinders and it was way easier to do it that way. Your results may vary. Don't fly it till it's fixed. -- *Thomas =8BPhy, A&P=8B* *President/ Technical Counselor* *EAA Chapter 1345* *Bend OR* *RV-7 Builder (repeat offender)=8B* *541-306-1500* > I'll defer to the guru mechanics out there, but if it was my plane the > engine would get pulled, disassembled and repaired as needed. I would > assume other bolts that had taken up the load of those bolts that you fou nd > loose had deformed - and perhaps this is what caused your sheared bolt. > > > Note - Mike Busch has voiced his opinion (which I agree with) that engine > cylinders cannot be properly removed/replace without removing the engine > from the aircraft as this impedes achieving correct cylinder bolt torque. > > > Carl > > > Lycoming Cylinder problem > > > Hello fellow RV'rs, Looking for advice, here's my situation \ problem. ( I > have an RV6, w an 0-320 A2B which was installed rebuilt, modified to 160 > HP, > during construction about 700 hrs ago). It has been running great, but I > have been seeing a couple of small oil leaks, (which have gotten to be > quite annoying.) While doing an oil change recently, I discovered one of > the > top cylinder bolts (small one - not the larger thru bolts) had sheared of f. > I had not done anything to it whatsoever, nor was there any evidence of > looseness or an oil leak in that area, the broken part was just sitting > there, I then jiggled the other upper bolts by hand and . . . 2 of them > were just finger tight!. Someone (a local A&P) suggested that a good > welder > could weld a nut to the broken stud and remove it that way - but that > sounds > way to "scary" to me. > > Any advice appreciated. Also . . . is the plane grounded until the > repair?? > > Thanks in advance > > David Wentzell - N233DW > > ________________________________________________________________________________
Date: Mar 19, 2015
I had a broken stud on an older O320. We removed it by welding a washer to what was left of the stud, then welding a nut to the washer. O made bent the washer like a Belleville or a funnel to get it on to the stud. It didn't require a good weld, as the broken stud was not in tension and the thermal cycle from welding it caused it to loosen in the aluminum alloy case. Soon after the repair, we went ahead and overhauled the engine. Divco put in all new studs. mitch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439598#439598 ________________________________________________________________________________
Date: Mar 26, 2015
I can now insert photos of your courtesy cars into the app listings. Feel free to email me your photos, and please be sure to indicate in the title of the email the airport ID and/or city location, and if there is more than one FBO, which one the car is located at. The app has broken 1400 locations nationwide. Thanks, Glenn Email to airportcars101(at)gmail.com -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App. Over 1400 cars nationwide. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439924#439924 ________________________________________________________________________________
Date: Apr 01, 2015
Subject: Single fuse for two fuel guages only
I have been doing some rearranging of the wiring and circuit protection in my 6A. I found my two fuel guages ( Vans IE-VFL-15) wired directly to the starter power input on the key switch (I must have been lazy that day). The documentation calls for 18AWG wiring for this circuit - but does not specify circuit protection sizing. I am thinking a 3 amp fuse should allow sufficient current and provide protection for the wiring. Thoughts please! Ralph Capen ________________________________________________________________________________
Date: Apr 01, 2015
Ralph, I used a 2 amp CB for the fuel gauges and I have had no problems. Warren -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, April 1, 2015 1:30 PM Subject: RV-List: Single fuse for two fuel guages only I have been doing some rearranging of the wiring and circuit protection in my 6A. I found my two fuel guages ( Vans IE-VFL-15) wired directly to the starter power input on the key switch (I must have been lazy that day). The documentation calls for 18AWG wiring for this circuit - but does not specify circuit protection sizing. I am thinking a 3 amp fuse should allow sufficient current and provide protection for the wiring. Thoughts please! Ralph Capen ________________________________________________________________________________
Date: Apr 02, 2015
Thanks Warren! -----Original Message----- >From: Warren Brecheisen <n146wb(at)cfu.net> >Sent: Apr 1, 2015 9:45 PM >To: rv-list(at)matronics.com >Subject: RE: RV-List: Single fuse for two fuel guages only > > >Ralph, > >I used a 2 amp CB for the fuel gauges and I have had no problems. > >Warren > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, April 1, 2015 1:30 PM >To: rv-list; aeroelectric-list(at)matronics.com >Subject: RV-List: Single fuse for two fuel guages only > > >I have been doing some rearranging of the wiring and circuit protection in my 6A. > >I found my two fuel guages ( Vans IE-VFL-15) wired directly to the starter power input on the key switch (I must have been lazy that day). The documentation calls for 18AWG wiring for this circuit - but does not specify circuit protection sizing. I am thinking a 3 amp fuse should allow sufficient current and provide protection for the wiring. > >Thoughts please! > >Ralph Capen > > ________________________________________________________________________________
Subject: Eust
Date: Apr 20, 2015
Old-timers may remember Eustace Bohay, who was one of the early adopters of sharing RV building expertise with others online. He was a big poster on the Matronics list back in the day, and was quite active in the Western Canada wing of Vans Air Force. He died on this date 9 years ago, and as I recall, his passing didn't get the notice it probably should have because Scott Crossfield died on the same day. But I got this email today based on a post I'd written some years ago and because I never had the pleasure of meeting Mr. Bohay, I can't supply the answers he's seeking. But I'm hoping someone else can. ------------------- Quote: Sir; I was doing a bit of internet research on an old acquaintance named Eustace Bohay, and came across a post of yours from 2006 (!) referring to the death of someone with that name. The Eustace Bohay I remember used to fly in and out of Hay River, N.W.T. (in northern Canada) in a P-51. He was a friend of my employer at the time, and what I remember most about him was that Mustang, and the sound of that Merlin on takeoff. Our shop was right off the end of the runway, and he'd make sure he came over the roof at about 30', and full bore. I'd be all the rest of the day getting the grin off my face. I wonder if it could be the same guy - I was just a kid then (in the late '50s and early '60s) and admit I don't recall a lot more about him. It's not a very common name however, and adding the element of aviation makes it seem even more possible that it's the same guy. I'm not even sure what his business was up there, but it would have most likely been related to either the construction boom of that era, or the (then) thriving commercial fishery on Great Slave Lake. If you could shed any light on him, or point me toward any relevant information, I'd be most grateful. Thank You, Karl Krieger Whitecourt, Alberta ------------ If you can help,drop me an emailand I'll forward it. Bcollinsrv7a(at)comcast.net ________________________________________________________________________________
Subject: Eust
Date: Apr 20, 2015
I used to thoroughly enjoy Eustace Bohay's posts when I was building and the early years of flying my RV6. As I remember, he was an elegant wordsmith and I would so love to read some of his posts again. He had a way of describing the joys of flight like few can. I greatly miss his participation on this forum. The link below is a video I made with my son that reminds me of the many of Mr. Bohay's posts describing similar experiences. http://youtu.be/D2khEtxf8ak Best to all of you, Ken Cantrell RV-6, 1975 hours & on my way to the airport. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Collins Sent: Monday, April 20, 2015 8:47 AM Subject: RV-List: Eust Old-timers may remember Eustace Bohay, who was one of the early adopters of sharing RV building expertise with others online. He was a big poster on the Matronics list back in the day, and was quite active in the Western Canada wing of Vans Air Force. He died on this date 9 years ago, and as I recall, his passing didn't get the notice it probably should have because Scott Crossfield died on the same day. But I got this email today based on a post I'd written some years ago and because I never had the pleasure of meeting Mr. Bohay, I can't supply the answers he's seeking. But I'm hoping someone else can. ------------------- Quote: Sir; I was doing a bit of internet research on an old acquaintance named Eustace Bohay, and came across a post of yours from 2006 (!) referring to the death of someone with that name. The Eustace Bohay I remember used to fly in and out of Hay River, N.W.T. (in northern Canada) in a P-51. He was a friend of my employer at the time, and what I remember most about him was that Mustang, and the sound of that Merlin on takeoff. Our shop was right off the end of the runway, and he'd make sure he came over the roof at about 30', and full bore. I'd be all the rest of the day getting the grin off my face. I wonder if it could be the same guy - I was just a kid then (in the late '50s and early '60s) and admit I don't recall a lot more about him. It's not a very common name however, and adding the element of aviation makes it seem even more possible that it's the same guy. I'm not even sure what his business was up there, but it would have most likely been related to either the construction boom of that era, or the (then) thriving commercial fishery on Great Slave Lake. If you could shed any light on him, or point me toward any relevant information, I'd be most grateful. Thank You, Karl Krieger Whitecourt, Alberta ------------ If you can help,drop me an emailand I'll forward it. Bcollinsrv7a(at)comcast.net ________________________________________________________________________________
Date: Apr 21, 2015
Subject: Re: Eustace Bowhay
Eustace Bowhay (note spelling) would come down to the Arlington fly-in years ago and his RV-6 on amphib floats always drew a crowd. Friendly, soft-spoken, obviously knowledgeable, being in his company was always a pleasure. I believe he died April 18, 2006. Here's a nice piece/eulogy about him from Van's Air Force: http://www.vansairforce.com/community/showthread.php?t=7209 Mark > From: "Bob Collins"<bcollinsrv7a(at)comcast.net> > Subject: RV-List: Eust > > > Old-timers may remember Eustace Bohay, who was one of the early adopters of > sharing RV building expertise with others online. He was a big poster on the > Matronics list back in the day, and was quite active in the Western Canada > wing of Vans Air Force. > > He died on this date 9 years ago, and as I recall, his passing didn't get > the notice it probably should have because Scott Crossfield died on the same > day. > > But I got this email today based on a post I'd written some years ago and > because I never had the pleasure of meeting Mr. Bohay, I can't supply the > answers he's seeking. But I'm hoping someone else can. > > ------------------- > > Quote: > Sir; > > I was doing a bit of internet research on an old acquaintance named Eustace > Bohay, and came across a post of yours from 2006 (!) referring to the death > of someone with that name. > > The Eustace Bohay I remember used to fly in and out of Hay River, N.W.T. (in > northern Canada) in a P-51. He was a friend of my employer at the time, and > what I remember most about him was that Mustang, and the sound of that > Merlin on takeoff. Our shop was right off the end of the runway, and he'd > make sure he came over the roof at about 30', and full bore. I'd be all the > rest of the day getting the grin off my face. > > I wonder if it could be the same guy - I was just a kid then (in the late > '50s and early '60s) and admit I don't recall a lot more about him. It's not > a very common name however, and adding the element of aviation makes it seem > even more possible that it's the same guy. I'm not even sure what his > business was up there, but it would have most likely been related to either > the construction boom of that era, or the (then) thriving commercial fishery > on Great Slave Lake. > > If you could shed any light on him, or point me toward any relevant > information, I'd be most grateful. > > Thank You, > Karl Krieger > Whitecourt, Alberta On 04/21/2015 12:02 AM, RV-List Digest Server wrote: > From: "Bob Collins"<bcollinsrv7a(at)comcast.net> > Subject: RV-List: Eust > > > Old-timers may remember Eustace Bohay, who was one of the early adopters of > sharing RV building expertise with others online. He was a big poster on the > Matronics list back in the day, and was quite active in the Western Canada > wing of Vans Air Force. > > He died on this date 9 years ago, and as I recall, his passing didn't get > the notice it probably should have because Scott Crossfield died on the same > day. > > But I got this email today based on a post I'd written some years ago and > because I never had the pleasure of meeting Mr. Bohay, I can't supply the > answers he's seeking. But I'm hoping someone else can. > > ------------------- > > Quote: > Sir; > > I was doing a bit of internet research on an old acquaintance named Eustace > Bohay, and came across a post of yours from 2006 (!) referring to the death > of someone with that name. > > The Eustace Bohay I remember used to fly in and out of Hay River, N.W.T. (in > northern Canada) in a P-51. He was a friend of my employer at the time, and > what I remember most about him was that Mustang, and the sound of that > Merlin on takeoff. Our shop was right off the end of the runway, and he'd > make sure he came over the roof at about 30', and full bore. I'd be all the > rest of the day getting the grin off my face. > > I wonder if it could be the same guy - I was just a kid then (in the late > '50s and early '60s) and admit I don't recall a lot more about him. It's not > a very common name however, and adding the element of aviation makes it seem > even more possible that it's the same guy. I'm not even sure what his > business was up there, but it would have most likely been related to either > the construction boom of that era, or the (then) thriving commercial fishery > on Great Slave Lake. > > If you could shed any light on him, or point me toward any relevant > information, I'd be most grateful. > > Thank You, > Karl Krieger > Whitecourt, Alberta ________________________________________________________________________________
Date: Apr 30, 2015
Subject: EAA 21 Club First Saturday Fly-Ins at KEHR, Henderson, KY
We will be preparing Hamburgers, Brats and NATHANS FAMOUS Hot Dogs for all that fly in. Just as New Yorks 21 Club has become known as the HAPPENING PLACE to be and be seen, EAA 21 Club is the place to be on the first Saturday of each month. When: May 2, June 6, July 4, Aug 1, Sept 5, Oct 3, 2015 10:00 AM till 2:00 PM Central time. Where: Henderson Kentucky City-County Airport (KEHR) If KEHR is VFR then we will be cooking the best Gourmet Burgers, Brats and Dogs this side of Sporty's. EAA Chapter 21 will be flying Young Eagles at the May 2nd Fly-In. Young Eagles must be between 8 and 17 years of age and have a parent or guardian with them. http://www.eaa21.org ________________________________________________________________________________
From: "Stan and Eilene VanGrunsven" <stan(at)vangrunsven.us>
Subject: Official RV-List Usage Guidelines
Date: May 02, 2015
We need to have our email address changed to: sandevan(at)outlook.com Thank you, Stan & Eilene VanGrunsven ________________________________________________________________________________
Subject: Best glide speed RV6A
Date: May 20, 2015
Interesting article in Flying mag (may) re dead stick landings. I experime nted with determining that quite bit when I first got my 6A, based at LZU at the time. That was in late 04/early 05. I never felt I could absolutly put a number on it, but settled on 75/80 mph, pretty much speed on final. This article got me thinking about it again, but due to very recent rt shou lder surg, I will no be flying for a while. ( think I could manage everythi ng exept flaps but getting in and especially back out may take a while). An yway, would like to hear from 6A drivers what they would use for dead stick air speed? Charlie H --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Subject: Re: Best glide speed RV6A
Date: May 20, 2015
Charlie, I have a 6A, and I agree with your ball park figure; however I would caution there are many variables: prop (cs or fixed), power status (stopped prop or windmill), airplane weight, Idle rpm of your engine, etc. There are probably more. In my case I have an average weight 180hp with c/s prop and low idle speed. I use 80 to 90 knots for glide and across the fence 75K. That leaves a lot of speed to kill in the flare but I have a low idle speed and lots of drag if windmilling. This is what I practice with. It gives a rather steep glide and I am sure it would be quite different with a stopped prop or partial power, but I feel these would make for a better glide which I could deal with. I always practice with the prop in max RPM so I have max drag. One can practice for the zero thrust, min drag glide if you fiddle with the throttle to establish zero thrust, but I consider this to be too tough for me and of minimal value in an emergency which will almost certainly be different than you practiced any way! My opinion is the same about practicing with coarse pitch glides. I don=92t think you can count on having enough oil pressure to go coarse pitch in many engine failure scenarios. So I just practice the worst case, with low pitch low rpm, and glide at 80-90, until the field is made then flare, add drag and land. I figure if my emergency has better glide angle than I have practiced, I can put the flaps down sooner or side slip. Coming up short on final is, on the other hand usually not a good option. I certainly don=92t claim this is the best or the only way to practice, it=92 s just the way I do it, as you asked, based on a lot of practice over the past 18 years and 3100 hours in the 6A. You would have thought i would have worn it out by now but it is still going strong.. I hope your shoulder heals soon. Denis Walsh denis.walsh(at)comcast.net > On 20May, 2015, at 11:07, wrote: > > Interesting article in Flying mag (may) re dead stick landings. I experimented with determining that quite bit when I first got my 6A, based at LZU at the time. That was in late 04/early 05. I never felt I could absolutly put a number on it, but settled on 75/80 mph, pretty much speed on final. This article got me thinking about it again, but due to very recent rt shoulder surg, I will no be flying for a while. ( think I could manage everything exept flaps but getting in and especially back out may take a while). Anyway, would like to hear from 6A drivers what they would use for dead stick air speed? Charlie H > > > <http://www.avast.com/> > This email has been checked for viruses by Avast antivirus software. > www.avast.com <http://www.avast.com/> > > <http://www.matronics.com/Navigator?RV-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: May 22, 2015
When discussing best glide I am never sure if we are talking about best glid e endurance or best glide range. Which do we use? I have never tested these on my RV-6 but intend to do so now the engine has a couple of hundred hours. If someone can point me to a recommended procedure this would be helpful too. Doug Gray Sent from my iPad > On 21 May 2015, at 9:18 am, Denis Walsh wrote: > > Charlie, I have a 6A, and I agree with your ball park figure; however I w ould caution there are many variables: prop (cs or fixed), power status (sto pped prop or windmill), airplane weight, Idle rpm of your engine, etc. Ther e are probably more. > > In my case I have an average weight 180hp with c/s prop and low idle speed . I use 80 to 90 knots for glide and across the fence 75K. That leaves a l ot of speed to kill in the flare but I have a low idle speed and lots of dra g if windmilling. This is what I practice with. It gives a rather steep gl ide and I am sure it would be quite different with a stopped prop or partia l power, but I feel these would make for a better glide which I could deal w ith. I always practice with the prop in max RPM so I have max drag. > > One can practice for the zero thrust, min drag glide if you fiddle with t he throttle to establish zero thrust, but I consider this to be too tough fo r me and of minimal value in an emergency which will almost certainly be dif ferent than you practiced any way! My opinion is the same about practicing w ith coarse pitch glides. I don=99t think you can count on having enou gh oil pressure to go coarse pitch in many engine failure scenarios. So I j ust practice the worst case, with low pitch low rpm, and glide at 80-90, unt il the field is made then flare, add drag and land. I figure if my emergenc y has better glide angle than I have practiced, I can put the flaps down soo ner or side slip. Coming up short on final is, on the other hand usually no t a good option. > > I certainly don=99t claim this is the best or the only way to practi ce, it=99 s just the way I do it, as you asked, based on a lot of prac tice over the past 18 years and 3100 hours in the 6A. You would have though t i would have worn it out by now but it is still going strong.. > > I hope your shoulder heals soon. > > > Denis Walsh > denis.walsh(at)comcast.net > > > >> On 20May, 2015, at 11:07, wrote: >> >> Interesting article in Flying mag (may) re dead stick landings. I experi mented with determining that quite bit when I first got my 6A, based at LZU at the time. That was in late 04/early 05. I never felt I could absolutly p ut a number on it, but settled on 75/80 mph, pretty much speed on final. Th is article got me thinking about it again, but due to very recent rt shoulde r surg, I will no be flying for a while. ( think I could manage everything e xept flaps but getting in and especially back out may take a while). Anyway, would like to hear from 6A drivers what they would use for dead stick air s peed? Charlie H >> >> >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> >> >> >> class="">http://www.matronics.com/Navigator?RV-List >> class="">http://forums.matronics.com >> class="">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 21, 2015
I think best glide endurance and best glide range might be the same .... at least it is to me. What I do is start 10 miles out from my airport at 5000 feet .... in still air if I can find it. Pick an airspeed (I like 70 for the first try) and try to hold the airspeed steady. I want to be over the airport at 1000 feet ..... pattern altitude for me ..... but record the altitude (or distance from the airport if short) you get and you can figure the glide ratio. If you repeat the procedure for 65, 75, etc. you'll home in on the best glide ratio for your particular plane. It's something to do while you're flying off those 20 or 40 hours in phase 1. Linn On 5/21/2015 9:54 PM, Doug Gray wrote: > When discussing best glide I am never sure if we are talking about > best glide endurance or best glide range. Which do we use? > I have never tested these on my RV-6 but intend to do so now the > engine has a couple of hundred hours. If someone can point me to a > recommended procedure this would be helpful too. > Doug Gray > > Sent from my iPad > > On 21 May 2015, at 9:18 am, Denis Walsh > wrote: > >> Charlie, I have a 6A, and I agree with your ball park figure; >> however I would caution there are many variables: prop (cs or fixed), >> power status (stopped prop or windmill), airplane weight, Idle rpm of >> your engine, etc. There are probably more. >> >> In my case I have an average weight 180hp with c/s prop and low idle >> speed. I use 80 to 90 knots for glide and across the fence 75K. >> That leaves a lot of speed to kill in the flare but I have a low >> idle speed and lots of drag if windmilling. This is what I practice >> with. It gives a rather steep glide and I am sure it would be quite >> different with a stopped prop or partial power, but I feel these >> would make for a better glide which I could deal with. I always >> practice with the prop in max RPM so I have max drag. >> >> One can practice for the zero thrust, min drag glide if you fiddle >> with the throttle to establish zero thrust, but I consider this to be >> too tough for me and of minimal value in an emergency which will >> almost certainly be different than you practiced any way! My opinion >> is the same about practicing with coarse pitch glides. I dont think >> you can count on having enough oil pressure to go coarse pitch in >> many engine failure scenarios. So I just practice the worst case, >> with low pitch low rpm, and glide at 80-90, until the field is made >> then flare, add drag and land. I figure if my emergency has better >> glide angle than I have practiced, I can put the flaps down sooner or >> side slip. Coming up short on final is, on the other hand usually >> not a good option. >> >> I certainly dont claim this is the best or the only way to practice, >> it s just the way I do it, as you asked, based on a lot of practice >> over the past 18 years and 3100 hours in the 6A. You would have >> thought i would have worn it out by now but it is still going strong.. >> >> I hope your shoulder heals soon. >> >> >> Denis Walsh >> denis.walsh(at)comcast.net >> >> >> >>> On 20May, 2015, at 11:07, >> > >> > wrote: >>> >>> Interesting article in Flying mag (may) re dead stick landings. I >>> experimented with determining that quite bit when I first got my >>> 6A, based at LZU at the time. That was in late 04/early 05. I never >>> felt I could absolutly put a number on it, but settled on 75/80 mph, >>> pretty much speed on final. This article got me thinking about it >>> again, but due to very recent rt shoulder surg, I will no be flying >>> for a while. ( think I could manage everything exept flaps but >>> getting in and especially back out may take a while). Anyway, would >>> like to hear from 6A drivers what they would use for dead stick air >>> speed? Charlie H >>> >>> >>> ------------------------------------------------------------------------ >>> Avast logo <http://www.avast.com/> >>> >>> This email has been checked for viruses by Avast antivirus software. >>> www.avast.com <http://www.avast.com/> >>> >>> >>> * >>> >>> class="">http://www.matronics.com/Navigator?RV-List >>> class="">http://forums.matronics.com >>> class="">http://www.matronics.com/contribution >>> >>> * >> >> * >> >> D============================================ >> st"">http://www.matronics.com/Navigator?RV-List >> D============================================ >> //forums.matronics.com >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: May 21, 2015
"Best glide" usually refers to best glide angle, i.e. the speed at which the aircraft will cover the most distance for a given amount of altitude loss i n still air. In engine out situations, this is usually what we're intereste d in because we want to go the most distance possible with the amount of alt itude that we have. I believe best glide angle typically coincides with the speed at which L/D is the greatest in still air. Best endurance is the speed at which the rate of descent is minimum. This i s useful for getting the most time possible for troubleshooting, but not nec essarily traveling the greatest distance. Best endurance can occur at a sig nificantly lower airspeed than best angle, so while the rate of descent may b e minimized, less forward progress is made per unit time resulting in a stee per glide angle. Skylor Sent from my iPhone. > On May 21, 2015, at 6:54 PM, Doug Gray wrote: > > When discussing best glide I am never sure if we are talking about best gl ide endurance or best glide range. Which do we use? > I have never tested these on my RV-6 but intend to do so now the engine ha s a couple of hundred hours. If someone can point me to a recommended proced ure this would be helpful too. > Doug Gray > > Sent from my iPad > >> On 21 May 2015, at 9:18 am, Denis Walsh wrote: >> >> Charlie, I have a 6A, and I agree with your ball park figure; however I w ould caution there are many variables: prop (cs or fixed), power status (sto pped prop or windmill), airplane weight, Idle rpm of your engine, etc. Ther e are probably more. >> >> In my case I have an average weight 180hp with c/s prop and low idle spee d. I use 80 to 90 knots for glide and across the fence 75K. That leaves a l ot of speed to kill in the flare but I have a low idle speed and lots of dra g if windmilling. This is what I practice with. It gives a rather steep gl ide and I am sure it would be quite different with a stopped prop or partia l power, but I feel these would make for a better glide which I could deal w ith. I always practice with the prop in max RPM so I have max drag. >> >> One can practice for the zero thrust, min drag glide if you fiddle with t he throttle to establish zero thrust, but I consider this to be too tough fo r me and of minimal value in an emergency which will almost certainly be dif ferent than you practiced any way! My opinion is the same about practicing w ith coarse pitch glides. I don=99t think you can count on having enou gh oil pressure to go coarse pitch in many engine failure scenarios. So I j ust practice the worst case, with low pitch low rpm, and glide at 80-90, unt il the field is made then flare, add drag and land. I figure if my emergenc y has better glide angle than I have practiced, I can put the flaps down soo ner or side slip. Coming up short on final is, on the other hand usually no t a good option. >> >> I certainly don=99t claim this is the best or the only way to pract ice, it=99 s just the way I do it, as you asked, based on a lot of pra ctice over the past 18 years and 3100 hours in the 6A. You would have thoug ht i would have worn it out by now but it is still going strong.. >> >> I hope your shoulder heals soon. >> >> >> Denis Walsh >> denis.walsh(at)comcast.net >> >> >> >>> On 20May, 2015, at 11:07, wrote: >>> >>> Interesting article in Flying mag (may) re dead stick landings. I exper imented with determining that quite bit when I first got my 6A, based at LZ U at the time. That was in late 04/early 05. I never felt I could absolutly put a number on it, but settled on 75/80 mph, pretty much speed on final. T his article got me thinking about it again, but due to very recent rt should er surg, I will no be flying for a while. ( think I could manage everything e xept flaps but getting in and especially back out may take a while). Anyway, would like to hear from 6A drivers what they would use for dead stick air s peed? Charlie H >>> >>> >>> >>> This email has been checked for viruses by Avast antivirus software. >>> www.avast.com >>> >>> >>> >>> >>> class="">http://www.matronics.com/Navigator?RV-List >>> class="">http://forums.matronics.com >>> class="">http://www.matronics.com/contribution >>> >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> st"">http://www.matronics.com/Navigator?RV-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 23, 2015
Skylor, Yes that is as I recall, I think the best glide angle speed corresponds to t he tangent intercept drawn from the origin on the ROD plot. I will need to c heck my books to confirm. I need to figure out the best way to test these. Also I don't think I could h ave flown my aircraft anywhere near smoothly enough during phase 1 to have c ollected useful data. Thanks, Doug Sent from my iPhone > On 22 May 2015, at 1:31 pm, Skylor Piper wrote: > > "Best glide" usually refers to best glide angle, i.e. the speed at which t he aircraft will cover the most distance for a given amount of altitude loss in still air. In engine out situations, this is usually what we're interes ted in because we want to go the most distance possible with the amount of a ltitude that we have. I believe best glide angle typically coincides with t he speed at which L/D is the greatest in still air. > > Best endurance is the speed at which the rate of descent is minimum. This is useful for getting the most time possible for troubleshooting, but not n ecessarily traveling the greatest distance. Best endurance can occur at a s ignificantly lower airspeed than best angle, so while the rate of descent ma y be minimized, less forward progress is made per unit time resulting in a s teeper glide angle. > > Skylor > > Sent from my iPhone. > >> On May 21, 2015, at 6:54 PM, Doug Gray wrote: >> >> When discussing best glide I am never sure if we are talking about best g lide endurance or best glide range. Which do we use? >> I have never tested these on my RV-6 but intend to do so now the engine h as a couple of hundred hours. If someone can point me to a recommended proce dure this would be helpful too. >> Doug Gray >> >> Sent from my iPad >> >>> On 21 May 2015, at 9:18 am, Denis Walsh wrote: >>> >>> Charlie, I have a 6A, and I agree with your ball park figure; however I would caution there are many variables: prop (cs or fixed), power status (s topped prop or windmill), airplane weight, Idle rpm of your engine, etc. Th ere are probably more. >>> >>> In my case I have an average weight 180hp with c/s prop and low idle spe ed. I use 80 to 90 knots for glide and across the fence 75K. That leaves a lot of speed to kill in the flare but I have a low idle speed and lots of d rag if windmilling. This is what I practice with. It gives a rather steep g lide and I am sure it would be quite different with a stopped prop or parti al power, but I feel these would make for a better glide which I could deal w ith. I always practice with the prop in max RPM so I have max drag. >>> >>> One can practice for the zero thrust, min drag glide if you fiddle with the throttle to establish zero thrust, but I consider this to be too tough f or me and of minimal value in an emergency which will almost certainly be di fferent than you practiced any way! My opinion is the same about practicing with coarse pitch glides. I don=99t think you can count on having en ough oil pressure to go coarse pitch in many engine failure scenarios. So I just practice the worst case, with low pitch low rpm, and glide at 80-90, u ntil the field is made then flare, add drag and land. I figure if my emerge ncy has better glide angle than I have practiced, I can put the flaps down s ooner or side slip. Coming up short on final is, on the other hand usually n ot a good option. >>> >>> I certainly don=99t claim this is the best or the only way to prac tice, it=99 s just the way I do it, as you asked, based on a lot of pr actice over the past 18 years and 3100 hours in the 6A. You would have thou ght i would have worn it out by now but it is still going strong.. >>> >>> I hope your shoulder heals soon. >>> >>> >>> Denis Walsh >>> denis.walsh(at)comcast.net >>> >>> >>> >>>> On 20May, 2015, at 11:07, wrote: >>>> >>>> Interesting article in Flying mag (may) re dead stick landings. I expe rimented with determining that quite bit when I first got my 6A, based at L ZU at the time. That was in late 04/early 05. I never felt I could absolutl y put a number on it, but settled on 75/80 mph, pretty much speed on final. This article got me thinking about it again, but due to very recent rt shou lder surg, I will no be flying for a while. ( think I could manage everythin g exept flaps but getting in and especially back out may take a while). Anyw ay, would like to hear from 6A drivers what they would use for dead stick ai r speed? Charlie H >>>> >>>> >>>> >>>> This email has been checked for viruses by Avast antivirus software. >>>> www.avast.com >>>> >>>> >>>> >>>> >>>> class="">http://www.matronics.com/Navigator?RV-List >>>> class="">http://forums.matronics.com >>>> class="">http://www.matronics.com/contribution >>>> >>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> st"">http://www.matronics.com/Navigator?RV-List >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> //forums.matronics.com >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> ot;">http://www.matronics.com/contribution >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> st"">http://www.matronics.com/Navigator?RV-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 22, 2015
Hi Charlie, Look up CAFE foundation, they did a full review of the RV6 6A back in 1993. Regards Dave Burnham > On May 22, 2015, at 9:15 AM, Doug Gray wrote: > > Skylor, > Yes that is as I recall, I think the best glide angle speed corresponds to the tangent intercept drawn from the origin on the ROD plot. I will need to check my books to confirm. > I need to figure out the best way to test these. Also I don't think I coul d have flown my aircraft anywhere near smoothly enough during phase 1 to hav e collected useful data. > Thanks, > Doug > > Sent from my iPhone > >> On 22 May 2015, at 1:31 pm, Skylor Piper wrote: >> >> "Best glide" usually refers to best glide angle, i.e. the speed at which t he aircraft will cover the most distance for a given amount of altitude loss in still air. In engine out situations, this is usually what we're interes ted in because we want to go the most distance possible with the amount of a ltitude that we have. I believe best glide angle typically coincides with t he speed at which L/D is the greatest in still air. >> >> Best endurance is the speed at which the rate of descent is minimum. Thi s is useful for getting the most time possible for troubleshooting, but not n ecessarily traveling the greatest distance. Best endurance can occur at a s ignificantly lower airspeed than best angle, so while the rate of descent ma y be minimized, less forward progress is made per unit time resulting in a s teeper glide angle. >> >> Skylor >> >> Sent from my iPhone. >> >>> On May 21, 2015, at 6:54 PM, Doug Gray wrote: >>> >>> When discussing best glide I am never sure if we are talking about best g lide endurance or best glide range. Which do we use? >>> I have never tested these on my RV-6 but intend to do so now the engine h as a couple of hundred hours. If someone can point me to a recommended proce dure this would be helpful too. >>> Doug Gray >>> >>> Sent from my iPad >>> >>>> On 21 May 2015, at 9:18 am, Denis Walsh wrote : >>>> >>>> Charlie, I have a 6A, and I agree with your ball park figure; however I would caution there are many variables: prop (cs or fixed), power status (s topped prop or windmill), airplane weight, Idle rpm of your engine, etc. Th ere are probably more. >>>> >>>> In my case I have an average weight 180hp with c/s prop and low idle sp eed. I use 80 to 90 knots for glide and across the fence 75K. That leaves a lot of speed to kill in the flare but I have a low idle speed and lots of d rag if windmilling. This is what I practice with. It gives a rather steep g lide and I am sure it would be quite different with a stopped prop or parti al power, but I feel these would make for a better glide which I could deal w ith. I always practice with the prop in max RPM so I have max drag. >>>> >>>> One can practice for the zero thrust, min drag glide if you fiddle wit h the throttle to establish zero thrust, but I consider this to be too tough for me and of minimal value in an emergency which will almost certainly be d ifferent than you practiced any way! My opinion is the same about practicin g with coarse pitch glides. I don=99t think you can count on having e nough oil pressure to go coarse pitch in many engine failure scenarios. So I just practice the worst case, with low pitch low rpm, and glide at 80-90, u ntil the field is made then flare, add drag and land. I figure if my emerge ncy has better glide angle than I have practiced, I can put the flaps down s ooner or side slip. Coming up short on final is, on the other hand usually n ot a good option. >>>> >>>> I certainly don=99t claim this is the best or the only way to pra ctice, it=99 s just the way I do it, as you asked, based on a lot of p ractice over the past 18 years and 3100 hours in the 6A. You would have tho ught i would have worn it out by now but it is still going strong.. >>>> >>>> I hope your shoulder heals soon. >>>> >>>> >>>> Denis Walsh >>>> denis.walsh(at)comcast.net >>>> >>>> >>>> >>>>> On 20May, 2015, at 11:07, wrote: >>>>> >>>>> Interesting article in Flying mag (may) re dead stick landings. I exp erimented with determining that quite bit when I first got my 6A, based at L ZU at the time. That was in late 04/early 05. I never felt I could absolutl y put a number on it, but settled on 75/80 mph, pretty much speed on final. This article got me thinking about it again, but due to very recent rt shou lder surg, I will no be flying for a while. ( think I could manage everythin g exept flaps but getting in and especially back out may take a while). Anyw ay, would like to hear from 6A drivers what they would use for dead stick ai r speed? Charlie H >>>>> >>>>> >>>>> >>>>> This email has been checked for viruses by Avast antivirus software. >>>>> www.avast.com >>>>> >>>>> >>>>> >>>>> >>>>> class="">http://www.matronics.com/Navigator?RV-List >>>>> class="">http://forums.matronics.com >>>>> class="">http://www.matronics.com/contribution >>>>> >>>> >>>> >>>> >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> st"">http://www.matronics.com/Navigator?RV-List >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> //forums.matronics.com >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> ot;">http://www.matronics.com/contribution >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> st"">http://www.matronics.com/Navigator?RV-List >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> //forums.matronics.com >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> ot;">http://www.matronics.com/contribution >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> st"">http://www.matronics.com/Navigator?RV-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 25, 2015
Jack Dueck wrote a great article on testing your best glide speed. I've attached a copy. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442559#442559 Attachments: http://forums.matronics.com//files/best_glide_speed_176.pdf ________________________________________________________________________________
Date: May 26, 2015
Thanks, a useful article. Doug Sent from my iPad > On 26 May 2015, at 11:51 am, ianxbrown wrote: > > > Jack Dueck wrote a great article on testing your best glide speed. I've attached a copy. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442559#442559 > > > > > Attachments: > > http://forums.matronics.com//files/best_glide_speed_176.pdf > > > > > > > ________________________________________________________________________________
Date: May 26, 2015
On my RV-6 the rate of descent data indicated a maximum endurance true airspeed of about 70 knots and maximum range of about 85 knots. Warren -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Doug Gray Sent: Tuesday, May 26, 2015 4:52 AM Subject: Re: RV-List: Re: Best glide speed RV6A Thanks, a useful article. Doug Sent from my iPad > On 26 May 2015, at 11:51 am, ianxbrown wrote: > > > Jack Dueck wrote a great article on testing your best glide speed. I've attached a copy. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442559#442559 > > > > > Attachments: > > http://forums.matronics.com//files/best_glide_speed_176.pdf > > > > > > > ________________________________________________________________________________
Date: May 26, 2015
Subject: Re: Glide ratio, was Re: Best glide speed RV6A
Hi Guys- I took a look at the cited article and noticed a technical issue. Aside from some cross-border, or perhaps more likely cross-bureaucracy diction issues, the article implies that glide ratio varies with aircraft weight. As I'm sure most will recall, glide ratio is a function of form and speed. Changing the aircraft weight will result in a corresponding change in the speed at which best L/D occurs, but not the value of that ratio (not to any practical, or perhaps even measurable extent). If interested, one can take a look at the Fed's Glider Handbook, Aerodynamics of Flight chapter, Glide Ratio section for a good refresher including a graphical explanation of the effect. https://www.faa.gov/regulations_policies/handbooks_manuals/aircraft/glider_handbook/media/gfh_ch03.pdf ________________________________________________________________________________
Date: May 26, 2015
ianxbrown wrote: > Jack Dueck wrote a great article on testing your best glide speed. I've attached a copy. Are there more articles like this from Jack? He referenced one about airspeed in this one. Would be nice to see other Flight Test Cards from him. Dave -------- David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442577#442577 ________________________________________________________________________________
Date: May 26, 2015
The CAF foundation did a comprehensive flight review of the RV-6(a) in 1993. Here's the link: http://cafefoundation.org/v2/pdf_cafe_apr/RV-6A%20Final%20APR.pdf Basically, it says 70 knots for lowest sink, 92 knots for best glide ratio. ________________________________________________________________________________
Date: May 27, 2015
Kyle, thanks for this document. I think these will be more reliable figures than what I could measure & calculate even despite the difference in model. Mine being a 6. I am reading through the doc for any clues on their methodology. Doug Sent from my iPhone > On 27 May 2015, at 8:40 am, wrote: > > > The CAF foundation did a comprehensive flight review of the RV-6(a) in 1993. Here's the link: > > http://cafefoundation.org/v2/pdf_cafe_apr/RV-6A%20Final%20APR.pdf > > Basically, it says 70 knots for lowest sink, 92 knots for best glide ratio. > > > > ________________________________________________________________________________
From: Stan And Eilene Van <sandevan(at)outlook.com>
Subject: Eye Medication
Date: May 27, 2015
I am writing for a friend. A while back there was a discussion about eye medication to improve the eyesight to help with getting a person thru their bi-annual. I failed to write down the name of the medication but now I wish I had. Can anyone please tell me what was the suggested medication? Thank you, Eilene VanGrunsven ________________________________________________________________________________
Subject: Re: Eye Medication
Date: May 28, 2015
You may be referring to the nutrients zeaxanthin and lutein which are carote noids. One nutritional supplement that contains these nutrients is EyePromis e vizual EDGE. Dale Ensing On May 28, 2015, at 2:14, Stan And Eilene Van wrote: > > I am writing for a friend. A while back there was a discussion about eye m edication to improve the eyesight to help with getting a person thru their b i-annual. I failed to write down the name of the medication but now I wish I had. Can anyone please tell me what was the suggested medication? > > Thank you, > Eilene VanGrunsven > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: May 28, 2015
Thank you, I will pass this message on. Eilene From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: Thursday, May 28, 2015 7:27 AM Subject: Re: RV-List: Eye Medication You may be referring to the nutrients zeaxanthin and lutein which are carotenoids. One nutritional supplement that contains these nutrients is EyePromise vizual EDGE. Dale Ensing On May 28, 2015, at 2:14, Stan And Eilene Van > wrote: I am writing for a friend. A while back there was a discussion about eye medication to improve the eyesight to help with getting a person thru their bi-annual. I failed to write down the name of the medication but now I wish I had. Can anyone please tell me what was the suggested medication? Thank you, Eilene VanGrunsven ========= /www.matronics.com/Navigator?RV-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Date: May 28, 2015
You can also purchase these same eye nutrients, lutein and zeaxanthin, individually in various strengths from any health food store, or better yet, good old Walmart, and probably others, sell Lutein with zeaxanthin at a very reasonable price and in several different strengths. my personal experience is that I have used the latter for about three years and at 82 my eyesight has been improving steadily. Just my $0.02. Harry Crosby ----- Original Message ----- From: "Stan And Eilene Van" <sandevan(at)outlook.com> Sent: Thursday, May 28, 2015 3:32:34 PM Subject: RE: RV-List: Eye Medication Thank you, I will pass this message on. Eilene From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: Thursday, May 28, 2015 7:27 AM Subject: Re: RV-List: Eye Medication You may be referring to the nutrients zeaxanthin and lutein which are carotenoids. One nutritional supplement that contains these nutrients is EyePromise vizual EDGE. Dale Ensing On May 28, 2015, at 2:14, Stan And Eilene Van < sandevan(at)outlook.com > wrote: I am writing for a friend. A while back there was a discussion about eye medication to improve the eyesight to help with getting a person thru their bi-annual. I failed to write down the name of the medication but now I wish I had. Can anyone please tell me what was the suggested medication? Thank you, Eilene VanGrunsven =================================== /www.matronics.com/Navigator?RV-List =================================== cs.com =================================== matronics.com/contribution =================================== http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 28, 2015
Thanks Harry..good info! Dale Ensing On May 28, 2015, at 18:45, HCRV6(at)comcast.net wrote: > You can also purchase these same eye nutrients, lutein and zeaxanthin, ind ividually in various strengths from any health food store, or better yet, go od old Walmart, and probably others, sell Lutein with zeaxanthin at a very r easonable price and in several different strengths. my personal experience i s that I have used the latter for about three years and at 82 my eyesight ha s been improving steadily. Just my $0.02. > > Harry Crosby > > From: "Stan And Eilene Van" <sandevan(at)outlook.com> > To: "RV-List" > Sent: Thursday, May 28, 2015 3:32:34 PM > Subject: RE: RV-List: Eye Medication > > > Thank you, I will pass this message on. > Eilene > > > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matr onics.com] On Behalf Of Dale Ensing > Sent: Thursday, May 28, 2015 7:27 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Eye Medication > > You may be referring to the nutrients zeaxanthin and lutein which are caro tenoids. One nutritional supplement that contains these nutrients is EyeProm ise vizual EDGE. > > Dale Ensing > > On May 28, 2015, at 2:14, Stan And Eilene Van wrote : > > > I am writing for a friend. A while back there was a discussion about eye m edication to improve the eyesight to help with getting a person thru their b i-annual. I failed to write down the name of the medication but now I wish I had. Can anyone please tell me what was the suggested medication? > > Thank you, > Eilene VanGrunsven > > > > ========= > /www.matronics.com/Navigator?RV-List > ========================= ========= > cs.com > ========= > matronics.com/contribution > ========================= ========= > > > > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > t="_blank" data-mce-href="http://www.matronics.com/Navigator?RV-List"> http://www.matronics.com/Navigator?RV-List > ta-mce-href="http://forums.matronics.com">http://forums.matronics.com > _blank" data-mce-href="http://www.matronics.com/contribution">http://www .matronics.com/contribution > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: May 28, 2015
Date: May 28, 2015
Sadly, nutrients purchased from "health food stores" frequently have none of the advertized ingredients, or ingredients that are not in a useful form or other harmful ingredients added. In the case of Lutein in pill form the providers of this product would be doing you a great favor by not including any Lutein at all in the magic bottle you buy from them. Lutein in pill form increased your risk of cancer... Lutein and Zeanzanthin are fabulous for your vision, but only if you medicate yourself with them in their natural forms. Kale, carrots and peaches are a place to start. Enjoy them in good health. From: HCRV6(at)comcast.net Sent: Thursday, May 28, 2015 3:45 PM Subject: Re: RV-List: Eye Medication You can also purchase these same eye nutrients, lutein and zeaxanthin, individually in various strengths from any health food store, or better yet, good old Walmart, and probably others, sell Lutein with zeaxanthin at a very reasonable price and in several different strengths. my personal experience is that I have used the latter for about three years and at 82 my eyesight has been improving steadily. Just my $0.02. Harry Crosby ------------------------------------------------------------------------- ------- From: "Stan And Eilene Van" <sandevan(at)outlook.com> Sent: Thursday, May 28, 2015 3:32:34 PM Subject: RE: RV-List: Eye Medication Thank you, I will pass this message on. Eilene From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: Thursday, May 28, 2015 7:27 AM Subject: Re: RV-List: Eye Medication You may be referring to the nutrients zeaxanthin and lutein which are carotenoids. One nutritional supplement that contains these nutrients is EyePromise vizual EDGE. Dale Ensing On May 28, 2015, at 2:14, Stan And Eilene Van wrote: I am writing for a friend. A while back there was a discussion about eye medication to improve the eyesight to help with getting a person thru their bi-annual. I failed to write down the name of the medication but now I wish I had. Can anyone please tell me what was the suggested medication? Thank you, Eilene VanGrunsven ==========/www.matronics.com/Navigator?RV-List=== =======cs.com==========matronics.com/co ntribution===================== ============== http://www.matronics.com/Navigator?RV-Listhttp://forums.matronics.comhttp ://www.matronics.com/contribution t="_blank" data-mce-href="http://www.matronics.com/Navigator?RV-List">http://www.m atronics.com/Navigator?RV-List ta-mce-href="http://forums.matronics.com">http://forums.matronics.com _blank" data-mce-href="http://www.matronics.com/contribution">http://www.matron ics.com/contribution ________________________________________________________________________________
Date: Jun 02, 2015
Subject: pouring from 'paint cans'
I hope I'm not the only one that didn't know this trick ..... I bought a quart of 2-part hi-temp epoxy that came in small 'paint' cans. I was trying to figure a way to pour the resin (3.3 to 1 by weight mix) without having to clean out the 'groove' each time. What I ended up with was two pieces of blue painters tape in the shape of a 'V' that just covers the inner ring. I have to clean the inner ring before each pour so the tape will stick to it. I pour the thick part (the 1) first since it's more viscous than the other (3.3) and use a finger (wear your rubber gloves!) to wipe the outside residue into the paper cup on the scale. The resin on the underside of the tape will drain back into the can, and you just have to remove and dispose of the tape. Linn ________________________________________________________________________________
Date: Jun 03, 2015
Subject: Re: pouring from 'paint cans'
Good Trick! Thanks! - Paul On 6/2/2015 4:36 PM, Linn Walters wrote: > I hope I'm not the only one that didn't know this trick ..... > > I bought a quart of 2-part hi-temp epoxy that came in small 'paint' > cans. I was trying to figure a way to pour the resin (3.3 to 1 by > weight mix) without having to clean out the 'groove' each time. What > I ended up with was two pieces of blue painters tape in the shape of a > 'V' that just covers the inner ring. I have to clean the inner ring > before each pour so the tape will stick to it. I pour the thick part > (the 1) first since it's more viscous than the other (3.3) and use a > finger (wear your rubber gloves!) to wipe the outside residue into the > paper cup on the scale. The resin on the underside of the tape will > drain back into the can, and you just have to remove and dispose of > the tape. > Linn > > ________________________________________________________________________________
Date: Jun 03, 2015
Subject: Re: RV-List Digest: 1 Msgs - 06/02/15
Good common sense tip! Thanks Linn! > 1. 02:37 PM - pouring from 'paint cans' (Linn Walters) > > > ________________________________ Message 1 _____________________________________ > > > From: Linn Walters <flying-nut(at)cfl.rr.com> > Subject: RV-List: pouring from 'paint cans' > > I hope I'm not the only one that didn't know this trick ..... > > I bought a quart of 2-part hi-temp epoxy that came in small 'paint' > cans. I was trying to figure a way to pour the resin (3.3 to 1 by > weight mix) without having to clean out the 'groove' each time. What I > ended up with was two pieces of blue painters tape in the shape of a 'V' > that just covers the inner ring. I have to clean the inner ring before > each pour so the tape will stick to it. I pour the thick part (the 1) > first since it's more viscous than the other (3.3) and use a finger > (wear your rubber gloves!) to wipe the outside residue into the paper > cup on the scale. The resin on the underside of the tape will drain > back into the can, and you just have to remove and dispose of the tape. > Linn ________________________________________________________________________________
Subject: annual condition insp
Date: Jun 09, 2015
Due to shoulder injury, recent surgery, I have only flown my 6A around 15 h rs this past year, insp due in July. Hate to have to do it with such little time on her. Is there any kind of waver or some legal way to pass on it th at any one knows of? Tnx, Charlie Heathco --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 09, 2015
The short answer is no. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Tuesday, June 09, 2015 8:36 AM Subject: RV-List: annual condition insp Due to shoulder injury, recent surgery, I have only flown my 6A around 15 hrs this past year, insp due in July. Hate to have to do it with such little time on her. Is there any kind of waver or some legal way to pass on it that any one knows of? Tnx, Charlie Heathco _____ Avast logo This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Jun 09, 2015
Subject: Re: annual condition insp
The long answer is: "There is NO way." On 06-09-2015 8:36 AM, cheathco(at)cox.net wrote: > Due to shoulder injury, recent surgery, I have only flown my 6A around > 15 hrs this past year, insp due in July. Hate to have to do it with > such little time on her. Is there any kind of waver or some legal way > to pass on it that any one knows of? Tnx, Charlie Heathco > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > * > > > * ________________________________________________________________________________
Date: Jun 09, 2015
On Tue, Jun 9, 2015 at 7:36 AM, wrote: > Due to shoulder injury, recent surgery, I have only flown my 6A around > 15 hrs this past year, insp due in July. Hate to have to do it with such > little time on her. Is there any kind of waver or some legal way to pass on > it that any one knows of? Tnx, Charlie Heathco > > If you don't fly it, you can wait as long as you want. :-) I'm only half kidding; if you aren't going to fly it for another month (or year), you can legally wait until you're almost ready to fly again to do the inspection. Is this a money issue, or will you be doing the inspection yourself (repairman's cert)? If you're doing it yourself, it really isn't that big a deal to do an inspection on most RV's. Assuming no issues, I can do mine in less than a day, and I have to coordinate with an A&P friend to actually sign the logbook (purchased the plane so I don't have a repairman's cert). I don't know of any way to legally keep flying without a logbook entry showing an inspection within the past year. Charlie ________________________________________________________________________________
Date: Jun 09, 2015
You already have a bunch of good answers. Does not matter how few hours it has flown, the requirement is there to do, and plane can not fly after Aug. 1 without the condition inspection done. While you have to inspect the items in Part 43 Appendix D, you do not have to do any maintenance beyond the lubrication needed when you inspect things like wheel bearings and oil screens. As one other noted, you can wait to do the inspection until you have been medically released to fly. If that happens to be a little cooler weather than the middle of the summer, all the better. And remember, electric screw drivers with good torque control are your friend. Not to mention having a trusted friend or two help you with the labor. Kelly A&P/IA On 6/9/2015 5:36 AM, cheathco(at)cox.net wrote: > Due to shoulder injury, recent surgery, I have only flown my 6A around > 15 hrs this past year, insp due in July. Hate to have to do it with > such little time on her. Is there any kind of waver or some legal way > to pass on it that any one knows of? Tnx, Charlie Heathco > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > * > > > * ________________________________________________________________________________
Date: Jun 09, 2015
All the answers pretty much cover your situation. I had an unfortunate encounter with both NTSB and FAA years ago but one good thing came of it. In discussions with the FAA guy from FSDO 15 (Orlando FL) who was checking my logbooks .... which had condition inspections scattered throughout the year. I correct all squawks as they occur and am 'inspecting' many times a year. He said that as long as I covered all the inspection items throughout the year I could pick a month in which to make my logbook entry. However, you have to have the repairman certificate which allows YOU to do the inspection. I've been doing my inspections that way ever since. Most all of us flying homebuilts correct squawks as they occur instead of deferring them to 'annual time' like the factory-built guys so if you have the repairman certificate you may have this option. Also, if you have the repairman certificate, then you can enlist the help of a good friend (along with a case of beer :-) ) to make the plane 'inspectable' and then you can take a look at it. Unless you wish to have someone fly it while you're grounded, there's always the option (mentioned already .... ) to defer the inspection until you can do it yourself. Linn On 6/9/2015 8:36 AM, cheathco(at)cox.net wrote: > Due to shoulder injury, recent surgery, I have only flown my 6A around > 15 hrs this past year, insp due in July. Hate to have to do it with > such little time on her. Is there any kind of waver or some legal way > to pass on it that any one knows of? Tnx, Charlie Heathco ________________________________________________________________________________
Date: Jun 09, 2015
Q2hhcmxpZSdzIGxhc3QgcGFyYWdyYXBoIGlzIHRoZSBjb3JyZWN0IHJlc3BvbnNlLgoKU2VudCBm cm9tIGEgZ2FsYXh5IGZhciBmYXIgYXdheS4uLgoKQ2hhcmxpZSBFbmdsYW5kIDxjZWVuZ2xhbmQ3 QGdtYWlsLmNvbT4gd3JvdGU6Cgo+Cj4KPgo+T24gVHVlLCBKdW4gOSwgMjAxNSBhdCA3OjM2IEFN LCA8Y2hlYXRoY29AY294Lm5ldD4gd3JvdGU6Cj4KPkR1ZSB0byBzaG91bGRlciBpbmp1cnkswqBy ZWNlbnQgc3VyZ2VyeSwgSSBoYXZlIG9ubHkgZmxvd24gbXkgNkEgYXJvdW5kIDE1IGhycyB0aGlz IHBhc3QgeWVhciwgaW5zcCBkdWUgaW4gSnVseS4gSGF0ZSB0byBoYXZlIHRvIGRvIGl0IHdpdGgg c3VjaCBsaXR0bGUgdGltZSBvbiBoZXIuIElzIHRoZXJlIGFueSBraW5kIG9mIHdhdmVyIG9yIHNv bWUgbGVnYWwgd2F5IHRvIHBhc3Mgb24gaXQgdGhhdCBhbnkgb25lIGtub3dzIG9mPyBUbngsIENo YXJsaWUgSGVhdGhjbwo+Cj4KPklmIHlvdSBkb24ndCBmbHkgaXQsIHlvdSBjYW4gd2FpdCBhcyBs b25nIGFzIHlvdSB3YW50LiA6LSnCoAo+Cj5JJ20gb25seSBoYWxmIGtpZGRpbmc7IGlmIHlvdSBh cmVuJ3QgZ29pbmcgdG8gZmx5IGl0IGZvciBhbm90aGVyIG1vbnRoIChvciB5ZWFyKSwgeW91IGNh biBsZWdhbGx5IHdhaXQgdW50aWwgeW91J3JlIGFsbW9zdCByZWFkeSB0byBmbHkgYWdhaW4gdG8g ZG8gdGhlIGluc3BlY3Rpb24uwqAgSXMgdGhpcyBhIG1vbmV5IGlzc3VlLCBvciB3aWxsIHlvdSBi ZSBkb2luZyB0aGUgaW5zcGVjdGlvbiB5b3Vyc2VsZiAocmVwYWlybWFuJ3MgY2VydCk/IElmIHlv dSdyZSBkb2luZyBpdCB5b3Vyc2VsZiwgaXQgcmVhbGx5IGlzbid0IHRoYXQgYmlnIGEgZGVhbCB0 byBkbyBhbiBpbnNwZWN0aW9uIG9uIG1vc3QgUlYncy4gQXNzdW1pbmcgbm8gaXNzdWVzLCBJIGNh biBkbyBtaW5lIGluIGxlc3MgdGhhbiBhIGRheSwgYW5kIEkgaGF2ZSB0byBjb29yZGluYXRlIHdp dGggYW4gQSZQIGZyaWVuZCB0byBhY3R1YWxseSBzaWduIHRoZSBsb2dib29rIChwdXJjaGFzZWQg dGhlIHBsYW5lIHNvIEkgZG9uJ3QgaGF2ZSBhIHJlcGFpcm1hbidzIGNlcnQpLgo+Cj4KPkkgZG9u J3Qga25vdyBvZiBhbnkgd2F5IHRvIGxlZ2FsbHkga2VlcCBmbHlpbmcgd2l0aG91dCBhIGxvZ2Jv b2sgZW50cnkgc2hvd2luZyBhbiBpbnNwZWN0aW9uIHdpdGhpbiB0aGUgcGFzdCB5ZWFyLgo+Cj4K PkNoYXJsaWUKPgo+Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0gXy09IC0gVGhlIFJWLUxpc3QgRW1haWwgRm9ydW0gLSBfLT0gVXNl IHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlIF8tPSB0aGUg bWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLCBfLT0gQXJj aGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsIF8tPSBQaG90 b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6IF8tPSBfLT0gLS0+IGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/UlYtTGlzdCBfLT0gXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0gXy09IC0gTUFUUk9OSUNTIFdFQiBG T1JVTVMgLSBfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2Vi IEZvcnVtcyEgXy09IF8tPSAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIF8tPSBfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PSBfLT0gLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtIF8tPSBUaGFuayB5b3UgZm9yIHlv dXIgZ2VuZXJvdXMgc3VwcG9ydCEgXy09IC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4gXy09IC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uIF8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09IA= ________________________________________________________________________________
Subject: re anual C I
Date: Jun 10, 2015
Thanks for all the replies, I anticipated the answer, but then again, maybe ? I have been doing most of it, then my A&P finishes with me and does the logs. Now, re oil change with so little time.(thinking 100 hr comparison) W hat advise there? I am thinking change oil but not filter, or would you adv ise, not even changing oil? Thanks in advance, Charlie Heathco --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: re anual C I
Date: Jun 10, 2015
On my RV-8A (IO-360), I change oil based on calendar time (4 months) or run time (25 hrs), whichever occurs first. I consider this a cheap inv estment to protect a $20k engine. I also always change the filter, prim arily to do a check of the element for metal. I also get an oil analysi s. I also use Camguard. Pulling the cowl each four months also affords the opportunity to inspec t the entire engine compartment. I almost always find something that ne eds tightening or securing. I may be weird, but I enjoy working not the bird almost as much as flyin g. Just my 2 cents. Tom > On Jun 10, 2015, at 8:05 AM, cheathco(at)cox.net wrote: > > Thanks for all the replies, I anticipated the answer, but then again, maybe? I have been doing most of it, then my A&P finishes with me and d oes the logs. Now, re oil change with so little time.(thinking 100 hr co mparison) What advise there? I am thinking change oil but not filter, or would you advise, not even changing oil? Thanks in advance, Charlie Hea thco > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ======================== ============ ronics.com/Navigator?RV-List> ======================== ============ ======================== ============ s.com/contribution> ======================== ============ > > > > ____________________________________________________________ > ____________________________________________________________ Old School Yearbook Pics View Class Yearbooks Online Free. Search by School & Year. Look Now! http://thirdpartyoffers.juno.com/TGL3141/55782f398f2092f3944a0st01duc ________________________________________________________________________________
Date: Jun 10, 2015
Subject: Re: Oil change times
Here is an article on Aircraft Engine Oil change intervals. http://generalaviationnews.com/2004/12/24/the-no-1-question-of-oil-experts-how-often-should-oil-be-changed/ Lycoming recommends 25-hours with a screen and 50-hours with a spin on filter or a maximum of 4-months between changes. My experience with my GMC that I was only driving about 100 mile per month over a 3-year period, had the valves start making noise when it was cold. Oil changed fixed the problem. This is an example of where oil change based on time interval is needed. Does it apply to aircraft engines? I recommend following the manufacturers recommendation on oil changes. Oil and filter is a small cost compared to the cost of the engine or engine work. If we are having a hard time paying for oil and filter every 4 months, it is time to get rid of the airplane as it calls into question if we should be flying an aircraft we own at all On 06-10-2015 8:05 AM, cheathco(at)cox.net wrote: > Thanks for all the replies, I anticipated the answer, but then again, > maybe? I have been doing most of it, then my A&P finishes with me and > does the logs. Now, re oil change with so little time.(thinking 100 hr > comparison) What advise there? I am thinking change oil but not > filter, or would you advise, not even changing oil? Thanks in advance, > Charlie Heathco > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Date: Jun 10, 2015
Subject: re annual C I
Date: Jun 10, 2015
You cannot do the conditional inspection an log "I certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of Appendix D to Part 43, and was found to be in a condition for safe operation" without doing the oil change and filter inspection. See Part 43 Appendix D (d)(3). Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Wednesday, June 10, 2015 8:06 AM Subject: RV-List: re anual C I Thanks for all the replies, I anticipated the answer, but then again, maybe? I have been doing most of it, then my A&P finishes with me and does the logs. Now, re oil change with so little time.(thinking 100 hr comparison) What advise there? I am thinking change oil but not filter, or would you advise, not even changing oil? Thanks in advance, Charlie Heathco _____ Avast logo This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Jun 10, 2015
I think we=92ll get a debate going here, because Part 43 does not apply to: =93(1) Any aircraft for which the FAA has issued an experimental certificate, unless the FAA has previously issued a different kind of airworthiness certificate for that aircraft; or (2) Any aircraft for which the FAA has issued an experimental certificate under the provisions of =A721.191 (i)(3) of this chapter, and the aircraft was previously issued a special airworthiness certificate in the light-sport category under the provisions of =A721.190 of this chapter.=94 From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Wednesday, June 10, 2015 8:11 AM Subject: RE: RV-List: re annual C I You cannot do the conditional inspection an log =93I certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of Appendix D to Part 43, and was found to be in a condition for safe operation=94 without doing the oil change and filter inspection. See Part 43 Appendix D (d)(3). Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Wednesday, June 10, 2015 8:06 AM Subject: RV-List: re anual C I Thanks for all the replies, I anticipated the answer, but then again, maybe? I have been doing most of it, then my A&P finishes with me and does the logs. Now, re oil change with so little time.(thinking 100 hr comparison) What advise there? I am thinking change oil but not filter, or would you advise, not even changing oil? Thanks in advance, Charlie Heathco _____ This email has been checked for viruses by Avast antivirus software. www.avast.com http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 10, 2015
Subject: Re: re annual C I
Not much of a debate. It is in the standard operating limitations..which not everyone has, but in general you must use a checklist for your condition inspection that at a minimum includes everything in Part 43, Appendix D. The inspection is the same as type certified aircraft. Only the wording and who can do it are different. Kelly On 6/10/2015 7:25 AM, Bob Collins wrote: > > I think well get a debate going here, because Part 43 does not apply to: > > (1) Any aircraft for which the FAA has issued an experimental > certificate, unless the FAA has previously issued a different kind of > airworthiness certificate for that aircraft; or > > (2) Any aircraft for which the FAA has issued an experimental > certificate under the provisions of 21.191 (i)(3) of this chapter, > and the aircraft was previously issued a special airworthiness > certificate in the light-sport category under the provisions of > 21.190 of this chapter. > > *From:*owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Carl Froehlich > *Sent:* Wednesday, June 10, 2015 8:11 AM > *To:* rv-list(at)matronics.com > *Subject:* RE: RV-List: re annual C I > > You cannot do the conditional inspection an log I certify that this > aircraft has been inspected on [insert date] in accordance with the > scope and detail of Appendix D to Part 43, and was found to be in a > condition for safe operation without doing the oil change and filter > inspection. > > See Part 43 Appendix D (d)(3). > > Carl > > // > > *From:*owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of > *cheathco(at)cox.net > *Sent:* Wednesday, June 10, 2015 8:06 AM > *To:* RV-List Digest Server > *Subject:* RV-List: re anual C I > > Thanks for all the replies, I anticipated the answer, but then again, > maybe? I have been doing most of it, then my A&P finishes with me and > does the logs. Now, re oil change with so little time.(thinking 100 hr > comparison) What advise there? I am thinking change oil but not > filter, or would you advise, not even changing oil? Thanks in advance, > Charlie Heathco > > ------------------------------------------------------------------------ > > Avast logo > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > * * > * * > * * > *http://www.matronics.com/Navigator?RV-List* > * * > *http://forums.matronics.com* > * * > *http://www.matronics.com/contribution* > * * > * * > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Date: Jun 10, 2015
BUT the Operating Limitations that were issued with the 8130-7 Special Airworthiness Certificate says: > > Condition inspections must be recorded in the aircraft maintenance > records showing the following=2C or a similarly worded=2C statement: > > *=93I certify that this aircraft has been inspected on [insert date] in > accordance with the scope and detail of 14 CFR part 43 appendix D=2C and > was found to be in a condition for safe operation.=94* > > ** > > The entry will include the aircraft=92s total time-in-service=2C and the > name=2C signature=2C certificate number=2C and type of certificate held b y > the person performing the inspection. 43 Appendix D part (d)(3) says nothing about oil change. http://rgl.faa.gov/Regulatory_and_Guidance_Library%5CrgFAR.nsf/0/F7054277E4 C9DC9586257913006500B2?OpenDocument > (d) Each person performing an annual or 100-hour inspection shall > inspect (where applicable) components of the engine and nacelle group > as follows: > (3) Internal engine--for cylinder compression and for metal particles > or foreign matter on screens and sump drain plugs. If there is weak > cylinder compression=2C for improper internal condition and improper > internal tolerances. IF the owner operator recently did an oil change and the Repairman / A&P was not around to witness=2C the oil could be returned to the engine after the pickup screen is inspected. The pickup screen inspection would remove all the oil out of the engine. The cost for the labor to do the task in this manor could approach the price of new oil. On 06-10-2015 10:25 AM=2C Bob Collins wrote: > > I think we=92ll get a debate going here=2C because Part 43 does not apply to: > > =93(1) Any aircraft for which the FAA has issued an experimental > certificate=2C unless the FAA has previously issued a different kind of > airworthiness certificate for that aircraft=3B or > > (2) Any aircraft for which the FAA has issued an experimental > certificate under the provisions of =A721.191 (i)(3) of this chapter=2C > and the aircraft was previously issued a special airworthiness > certificate in the light-sport category under the provisions of > =A721.190 of this chapter.=94 > > *From:*owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Carl Froehlich > *Sent:* Wednesday=2C June 10=2C 2015 8:11 AM > *To:* rv-list(at)matronics.com > *Subject:* RE: RV-List: re annual C I > > You cannot do the conditional inspection an log =93I certify that this > aircraft has been inspected on [insert date] in accordance with the > scope and detail of Appendix D to Part 43=2C and was found to be in a > condition for safe operation=94 without doing the oil change and filter > inspection. > > See Part 43 Appendix D (d)(3). > > Carl > > // > > *From:*owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of > *cheathco(at)cox.net > *Sent:* Wednesday=2C June 10=2C 2015 8:06 AM > *To:* RV-List Digest Server > *Subject:* RV-List: re anual C I > > Thanks for all the replies=2C I anticipated the answer=2C but then again =2C > maybe? I have been doing most of it=2C then my A&P finishes with me and > does the logs. Now=2C re oil change with so little time.(thinking 100 hr > comparison) What advise there? I am thinking change oil but not > filter=2C or would you advise=2C not even changing oil? Thanks in advance =2C > Charlie Heathco > > ------------------------------------------------------------------------ > > Avast logo > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > * * > * * > * * > *http://www.matronics.com/Navigator?RV-List* > * * > *http://forums.matronics.com* > * * > *http://www.matronics.com/contribution* > * * > * * > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > =========== =========== =========== =========== > > * ________________________________________________________________________________
Date: Jun 10, 2015
Looking at Part 43, I do not see where it requires an oil change? It only mentions oil twice and neither time does it refer to changing the oil. On Wed, Jun 10, 2015 at 9:10 AM, Carl Froehlich wrote: > You cannot do the conditional inspection an log =9CI certify that t his > aircraft has been inspected on [insert date] in accordance with the scope > and detail of Appendix D to Part 43, and was found to be in a condition f or > safe operation=9D without doing the oil change and filter inspectio n. > > > See Part 43 Appendix D (d)(3). > > > Carl > > > *From:* owner-rv-list-server(at)matronics.com [mailto: > owner-rv-list-server(at)matronics.com] *On Behalf Of *cheathco(at)cox.net > *Sent:* Wednesday, June 10, 2015 8:06 AM > *To:* RV-List Digest Server > *Subject:* RV-List: re anual C I > > > Thanks for all the replies, I anticipated the answer, but then again, > maybe? I have been doing most of it, then my A&P finishes with me and do es > the logs. Now, re oil change with so little time.(thinking 100 hr > comparison) What advise there? I am thinking change oil but not filter, o r > would you advise, not even changing oil? Thanks in advance, Charlie Heath co > > > ------------------------------ > > [image: Avast logo] > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > *http://www.matronics.com/Navigator?RV-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > =========== ics.com/Navigator?RV-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 10, 2015
Good point =93 but it does say to look at screens and such for metal particles or foreign matter. I guess you can do this without changing the oil or you can drain the oil and reuse it. I=99d offer that the pain and mess to do either is not worth it. I also read this as needing to cut open the oil filter to look for metal particles. Other may disagree. So =93 while not optimal ground run the engine to get the oil temp up and just change the oil and filter. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Trollinger Sent: Wednesday, June 10, 2015 11:51 AM Subject: Re: RV-List: re annual C I Looking at Part 43, I do not see where it requires an oil change? It only mentions oil twice and neither time does it refer to changing the oil. On Wed, Jun 10, 2015 at 9:10 AM, Carl Froehlich wrote: You cannot do the conditional inspection an log =9CI certify that this aircraft has been inspected on [insert date] in accordance with the scope and detail of Appendix D to Part 43, and was found to be in a condition for safe operation=9D without doing the oil change and filter inspection. See Part 43 Appendix D (d)(3). Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Wednesday, June 10, 2015 8:06 AM Subject: RV-List: re anual C I Thanks for all the replies, I anticipated the answer, but then again, maybe? I have been doing most of it, then my A&P finishes with me and does the logs. Now, re oil change with so little time.(thinking 100 hr comparison) What advise there? I am thinking change oil but not filter, or would you advise, not even changing oil? Thanks in advance, Charlie Heathco _____ Avast logo This email has been checked for viruses by Avast antivirus software. www.avast.com http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://www.matronics.com/contribution t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re oil change
Date: Jun 11, 2015
I have the inspection list, 3 pages If I recall. I got it from an RV driver at LZU. Yesterday Morn I decided to just go ahead with same full annual t hat I have always done. I shoot for 1st week of jul a bit ahead of the real ly hot part of the month, that is about a month ahead of shoulder recovery time, so may have to have my A&P do a little more than ususal. Thanks for a ll your input. Charlie FYV --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 11, 2015
Subject: Re: Re oil change
Highly recommend you compare that list you have with what is listed in Part 43, Appendix D. You may be able to eliminate some of items on the list you have, while you need to know you are complying with the regulation of what must be inspected. Kelly A&P/IA EAA Tech Counselor On 6/11/2015 4:27 AM, cheathco(at)cox.net wrote: > I have the inspection list, 3 pages If I recall. I got it from an RV > driver at LZU. Yesterday Morn I decided to just go ahead with same > full annual that I have always done. I shoot for 1st week of jul a bit > ahead of the really hot part of the month, that is about a month ahead > of shoulder recovery time, so may have to have my A&P do a little more > than ususal. Thanks for all your input. Charlie FYV > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > * > > > * ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Jun 14, 2015
Quick update, 18,000 launches, more discounts being added for users, more positive national press coverage and keeping it free to pilots. Thanks, Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, "Airport Courtesy Cars" Smart Phone App. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443518#443518 ________________________________________________________________________________
Date: Jun 17, 2015
Subject: Reconsider Garmin Purchases
In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 17, 2015
This doesn't sound right. Sounds to me like someone just didn't want to deal with you (and it likely wasn't Garmin in this case). I don't know what or how you handled yourself, but sometimes you'll get more with honey than with vinegar - or perhaps the person you spoke with perhaps was slightly mis-informed. To be blunt, the lenses should be readily available (at least they were last time we got some). I'm sorry they aren't a $4 piece of plexi (there is some fancy schmancy coatings on them and such), but the GTX lens is around $26 and I think the SL lens around $65. My recommendation would be to calm down a bit, sit back and take a breath before indicting Garmin in their entirety based on a conversation with one person. Not defending anyone or indicting or flaming anyone, but your experience just sounds like we don't have the "whole story".....might I humbly suggest that before blasting this to every list you manage that you perhaps speak to someone else first (or maybe even Garmin directly)? Cheers, Stein -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Wednesday, June 17, 2015 1:11 PM Subject: RV-List: Reconsider Garmin Purchases In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: Reconsider Garmin Purchases
Date: Jun 17, 2015
Yep. I got the same message for a $0.50 part for my SL-30. I just wanted the part. It can be replaced without opening the unit. Amazing arrogance. > On Jun 17, 2015, at 11:10 AM, Matt Dralle wrote: > > > In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > > I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > > I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 182+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > > > > ________________________________________________________________________________
Date: Jun 17, 2015
A year ago=2C I replaced the lens on my SL-60. Garmin sold it to me for $2 0 or so. In May=2C I learned that after June 30=2C they will no longer ser vice the SL-60 and a number of other SL products (-50=2C -60=2C -70). I be grudgingly sent my (working) radio to Garmin and paid $550 for a flat rate repair. I hope this (expensive) step gives me a few more years before my r adio becomes worthless. It is very frustrating that Garmin will no longer work on it and no one else can. > Date: Wed=2C 17 Jun 2015 11:10:36 -0700 > To: rv-list(at)matronics.com > From: dralle(at)matronics.com > Subject: RV-List: Reconsider Garmin Purchases > > > In the rebuild of my RV-8 recently=2C I managed to get a scratch in the l ens of both the Garmin SL-30 and the Garmin GTX-327. No biggie=2C I thought =2C I'll just order up a replacement and stick them in=2C much like I did o n the King KX-125 on the RV-6. > > I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup=2C you hear that right. M y only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly=2C criminal behav ior. > > I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 182+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 17, 2015
Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:10 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 17, 2015
I'm kind of going through the same thing with Wag Aero here in Wisconsin. I need replacement landing gear springs, but all they sell is a "kit" with the springs AND gear leg blanks. I do NOT intend to build a whole new landing gear...my legs are fine...just the srpings are shot. What a CROCK when a company will not sell replacement parts for "complete assemblies" they sell. Chaps my a$$ (ie, $300 just to get a set of springs)... Ace On 6/17/2015 6:10 PM, Matt Dralle wrote: > --> RV-List message posted by: Matt Dralle > > In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > > I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > > I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 182+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > -- ________________________________________________________________________________
Date: Jun 17, 2015
Matt, No apology required or warranted, the only way suppliers will learn to treat their customers decently and to get their own house in order if that's the problem here, is to broadcast this kind of outrageous policy to the entire customer community. Maybe an abrupt drop in sales will get their attention. I for one just eliminated the G3X from consideration for my future panel upgrade unless this kind of BS ceases. Harry Crosby RV-6 N16CX, 1286 hours. ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Wednesday, June 17, 2015 2:36:32 PM Subject: RV-List: Re: Reconsider Garmin Purchases Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:10 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com>
Subject: Re: RE: Avionics-List: Re: Reconsider Garmin Purchases
Date: Jun 17, 2015
A few years ago I was able to get lenses for an SL-30 and SL-70. I went through Avionics Unlimited in Conroe, TX. (936) 788-7333. Talk to Johnny Blain. IIRC they were about $60 each. Yeah, that seems high but I hear Bendix charges $120 for theirs. The new ones were actually nicer than my originals circa 2001. They have the adhesive built in and install nicely once the old lens is pried off and the old adhesive cleaned off. Regards, Greg Young -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Wednesday, June 17, 2015 4:39 PM Subject: Avionics-List: Re: Reconsider Garmin Purchases --> Avionics-List message posted by: Matt Dralle Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:13 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 17, 2015
Subject: Re: Wag Aero springs was Reconsider Garmin Purchases
Ace, I would suggest you take your old units to a local spring manufacturer, OR try to source equivalent units from either MSC or McMaster-Carr. Charlie -------------------------------------------- On Wed, 6/17/15, Ace Pilot wrote: Subject: Re: RV-List: Reconsider Garmin Purchases To: rv-list(at)matronics.com Date: Wednesday, June 17, 2015, 5:59 PM I'm kind of going through the same thing with Wag Aero here in Wisconsin. I need replacement landing gear springs, but all they sell is a "kit" with the springs AND gear leg blanks. I do NOT intend to build a whole new landing gear...my legs are fine...just the srpings are shot. What a CROCK when a company will not sell replacement parts for "complete assemblies" they sell. Chaps my a$$ (ie, $300 just to get a set of springs)... Ace On 6/17/2015 6:10 PM, Matt Dralle wrote: In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com -- ________________________________________________________________________________
Date: Jun 17, 2015
My first thought, and I'm sure Ace has been down this path .... you really don't know the springs compression value ..... it's now less than when new .... or the rate ..... so trying to make or source one becomes problematical. I'm going to guess that Wag Aero doesn't build the gear/springs themselves but contracts with an outside source. If you can find them, then you'd have a better chance of getting just the springs. Linn On 6/17/2015 7:44 PM, Charles Kuss wrote: > > Ace, > I would suggest you take your old units to a local spring manufacturer, OR try to source equivalent units from either MSC or McMaster-Carr. > Charlie > -------------------------------------------- > On Wed, 6/17/15, Ace Pilot wrote: > > Subject: Re: RV-List: Reconsider Garmin Purchases > To: rv-list(at)matronics.com > Date: Wednesday, June 17, 2015, 5:59 PM > > > > > > > > I'm kind of going through the same thing with Wag > Aero here in > Wisconsin. I need replacement landing gear > springs, but all they > sell is a "kit" with the springs AND gear leg > blanks. I do NOT > intend to build a whole new landing gear...my legs are > fine...just > the srpings are shot. What a CROCK when a company > will not sell > replacement parts for "complete assemblies" > they sell. Chaps my a$$ > (ie, $300 just to get a set of springs)... > > > > Ace > > > > On 6/17/2015 6:10 PM, Matt Dralle wrote: > > > In the rebuild of my RV-8 recently, I managed to get a > scratch in the lens of both the Garmin SL-30 and the Garmin > GTX-327. No biggie, I thought, I'll just order up a > replacement and stick them in, much like I did on the King > KX-125 on the RV-6. > > I called up Pacific Coast Avionics today to order the parts > and was told the following: Garmin will not sell the lens. > Yup, you hear that right. My only option is to return both > units to Garmin for a "factory repair" and the > MINIMUM charge will be $535 for EACH unit! That is $1070 to > replace two $4 pieces of plastic! That is simply outrageous! > Frankly, criminal behavior. > > I will NOT be buying ANY future Garmin products. I refuse to > do business with a company that treats their customers this > way. Unacceptable. > > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 > Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV > YouTube Channel > Status: 182+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - > Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the > Livermore > Airport. Includes both Tower and Ground transmissions. > Archives too! > For entertainment purposes only. http://klvk.matronics.com > > > > > > > > > > > > > -- > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 18, 2015
I see no reason for an apology, and I'm glad you posted your experience. I've heard the exact same story (outrageous flat-rate fees for *any* repair, even a 'checkout') about Garmin for many years from many different owners. I've even experienced it myself, with Garmin wanting around $150 to replace the $4 backup battery in my GPS III Pilot portable. When I cornered a Garmin rep about it at a major flyin, he offered to give me a 'deal' at $70 if I sent it to his attention after the flyin. And the portable isn't even a 'certified' device. BTW, I'd like to thank Matt for keeping these lists up and running and avoiding the ugliness of censorship, which is rampant on the VAF forum. For those who don't follow it closely, Matt's recent thread on the Garmin service subject didn't last a day before it was deleted (can't have one of your advertisers called out in public, can you.....). I sometimes go for much longer than I should without donating to Matt, and incidents like that remind me why I should donate every year. Charlie On Wed, Jun 17, 2015 at 4:36 PM, Matt Dralle wrote: > > Before making my original post, I had contacted two different Avionics > shops and received the exact same story, so I didn't base my findings on a > single vendor. I have subsequently contacted Garmin directly and was told > that the parts are in fact orderable by dealers. But, when those same > avionics dealers call the Garmin parts department they are told they are > not allowed to order those parts. So, something is definitely not quite > lining up here. I guess I apologize to the community for venting my > frustration with this process, but this really shouldn't be this difficult. > I will follow up with more information on this debacle as it hopefully > progresses. > > Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for > the GTX-327 is 470-00034-00. > > Matt > > > At 11:10 AM 6/17/2015 Wednesday, Matt Dralle wrote: > >In the rebuild of my RV-8 recently, I managed to get a scratch in the > lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, > I'll just order up a replacement and stick them in, much like I did on the > King KX-125 on the RV-6. > > > >I called up Pacific Coast Avionics today to order the parts and was told > the following: Garmin will not sell the lens. Yup, you hear that right. My > only option is to return both units to Garmin for a "factory repair" and > the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two > $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > > > >I will NOT be buying ANY future Garmin products. I refuse to do business > with a company that treats their customers this way. Unacceptable. > > > > > >- > >Matt Dralle > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 182+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > ________________________________________________________________________________
Date: Jun 18, 2015
Just to put in my plug for the local guy. When I first read Matt=99s post, my thought was, =9Cdidn=99t buy it from Stein.=9D Which is why I was also interested in Stein=99s response. Remember, this is a guy who took a personal bath a few years ago when the alternative was a big company was going to screw his customers. So this is just a reminder to support those shops that have a history of supporting the RV community, especially those who ARE in the RV community. It makes a big difference. Glad all of this worked out. From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Wednesday, June 17, 2015 5:59 PM Subject: Re: RV-List: Re: Reconsider Garmin Purchases Matt, No apology required or warranted, the only way suppliers will learn to treat their customers decently and to get their own house in order if that's the problem here, is to broadcast this kind of outrageous policy to the entire customer community. Maybe an abrupt drop in sales will get their attention. I for one just eliminated the G3X from consideration for my future panel upgrade unless this kind of BS ceases. Harry Crosby RV-6 N16CX, 1286 hours. _____ From: "Matt Dralle" <dralle(at)matronics.com <mailto:dralle(at)matronics.com> > Sent: Wednesday, June 17, 2015 2:36:32 PM Subject: RV-List: Re: Reconsider Garmin Purchases > Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:10 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. h ________________________________________________________________________________
Date: Jun 18, 2015
I'd like to pipe up here and defend Matt as well. If we don't identify these issues, then we can't effect change. There are phases in the process of resolve issues. Near the top of the list is initial outrage at the injustice of a particular action. Matt strikes me as a smart responsible individual and his outrage is understandable. If we are going to get a large corporation to rethink their strategy then we too need to stand up as say we're mad as hell and are not gong t take this anymore. Let Garmin know that there are consequences to their actions. -GV -----Original Message----- From: Charlie England <ceengland7(at)gmail.com> Sent: Thu, Jun 18, 2015 5:00 am Subject: Re: RV-List: Re: Reconsider Garmin Purchases I see no reason for an apology, and I'm glad you posted your experience. I've heard the exact same story (outrageous flat-rate fees for *any* repair, even a 'checkout') about Garmin for many years from many different owners. I've even experienced it myself, with Garmin wanting around $150 to replace the $4 backup battery in my GPS III Pilot portable. When I cornered a Garmin rep about it at a major flyin, he offered to give me a 'deal' at $70 if I sent it to his attention after the flyin. And the portable isn't even a 'certified' device. BTW, I'd like to thank Matt for keeping these lists up and running and avoiding the ugliness of censorship, which is rampant on the VAF forum. For those who don't follow it closely, Matt's recent thread on the Garmin service subject didn't last a day before it was deleted (can't have one of your advertisers called out in public, can you.....). I sometimes go for much longer than I should without donating to Matt, and incidents like that remind me why I should donate every year. Charlie On Wed, Jun 17, 2015 at 4:36 PM, Matt Dralle wrote: Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:10 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com =========== ist" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =========== ________________________________________________________________________________
Date: Jun 18, 2015
I've also been successful with Wag Aero for replacement landing gear springs for my Corben. Their complete "kit" of gear leg blanks and springs is $307. I just got an email from them today and can get just what I need (the SPRINGS ONLY) for $49.50 each...so $100 vs $307. Another win getting the grease (concession) applied to the squeaky wheel (ME!)... Ace On 6/18/2015 3:47 PM, vanremog(at)aol.com wrote: > I'd like to pipe up here and defend Matt as well. If we don't > identify these issues, then we can't effect change. There are phases > in the process of resolve issues. Near the top of the list is initial > outrage at the injustice of a particular action. > Matt strikes me as a smart responsible individual and his outrage is > understandable. If we are going to get a large corporation to rethink > their strategy then we too need to stand up as say we're mad as hell > and are not gong t take this anymore. Let Garmin know that there are > consequences to their actions. > -GV > -----Original Message----- > From: Charlie England <ceengland7(at)gmail.com> > To: RV list > Sent: Thu, Jun 18, 2015 5:00 am > Subject: Re: RV-List: Re: Reconsider Garmin Purchases > > I see no reason for an apology, and I'm glad you posted your > experience. I've heard the exact same story (outrageous flat-rate fees > for *any* repair, even a 'checkout') about Garmin for many years from > many different owners. I've even experienced it myself, with Garmin > wanting around $150 to replace the $4 backup battery in my GPS III > Pilot portable. When I cornered a Garmin rep about it at a major > flyin, he offered to give me a 'deal' at $70 if I sent it to his > attention after the flyin. And the portable isn't even a 'certified' > device. > > BTW, I'd like to thank Matt for keeping these lists up and running and > avoiding the ugliness of censorship, which is rampant on the VAF > forum. For those who don't follow it closely, Matt's recent thread on > the Garmin service subject didn't last a day before it was deleted > (can't have one of your advertisers called out in public, can > you.....). I sometimes go for much longer than I should without > donating to Matt, and incidents like that remind me why I should > donate every year. > > Charlie > > On Wed, Jun 17, 2015 at 4:36 PM, Matt Dralle > wrote: > > > > > Before making my original post, I had contacted two different > Avionics shops and received the exact same story, so I didn't base > my findings on a single vendor. I have subsequently contacted > Garmin directly and was told that the parts are in fact orderable > by dealers. But, when those same avionics dealers call the Garmin > parts department they are told they are not allowed to order those > parts. So, something is definitely not quite lining up here. I > guess I apologize to the community for venting my frustration with > this process, but this really shouldn't be this difficult. I will > follow up with more information on this debacle as it hopefully > progresses. > > Btw, the lens part number for the SL-30 is 308-3201-42 and the > lens for the GTX-327 is 470-00034-00. > > Matt > > > At 11:10 AM 6/17/2015 Wednesday, Matt Dralle wrote: > >In the rebuild of my RV-8 recently, I managed to get a scratch in > the lens of both the Garmin SL-30 and the Garmin GTX-327. No > biggie, I thought, I'll just order up a replacement and stick them > in, much like I did on the King KX-125 on the RV-6. > > > >I called up Pacific Coast Avionics today to order the parts and > was told the following: Garmin will not sell the lens. Yup, you > hear that right. My only option is to return both units to Garmin > for a "factory repair" and the MINIMUM charge will be $535 for > EACH unit! That is $1070 to replace two $4 pieces of plastic! That > is simply outrageous! Frankly, criminal behavior. > > > >I will NOT be buying ANY future Garmin products. I refuse to do > business with a company that treats their customers this way. > Unacceptable. > > > > > >- > >Matt Dralle > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 182+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the > Livermore > Airport. Includes both Tower and Ground transmissions. Archives > too! > For entertainment purposes only. http://klvk.matronics.com > > > ========== > ist" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" > target="_blank">http://www.matronics.com/contribution > ========== > > > <http://www.matronics.com/Navigator?RV-List> > <http://www.matronics.com/Navigator?RV-List> > <http://www.matronics.com/Navigator?RV-List> > > * > > > * -- ________________________________________________________________________________
Date: Jun 21, 2015
Subject: Ruby Vixen 2.0 Flying?
Matt, I recently subscribed to the RV-List, and noticed on your signature that Ruby Vixen 2.0 is flying. The last builder's log entry showed she was ready for taxi tests, so I figured she was in the air by now, and I've been checking for updates. I'm hoping that you'll share more log entries and YouTube videos soon; it's been an interesting project to follow. I'm awaiting my first Tech Counselor inspection before I close up my horizontal stabilizer. Moving forward... and eventually upward. MJF Clarkston, MI ________________________________________________________________________________
Subject: NTSB releases Tony Kelly probable cause
Date: Jun 22, 2015
A lot of fans of VAF might be familiar with Tony Kelly's crash in Hamilton Township, NJ in September 2013. The discussion of the aftermath online seemed to focus on the RV-7 design. The length of time it took to come up with a probable cause only added to the speculation. But it was not, apparently, a design failure. It an improperly executed aerobatic maneuver, the NTSB says. http://rvnewsletter.blogspot.com/2015/06/ntsb-aerobatic-maneuver-killed-tony .html ________________________________________________________________________________
Date: Jun 29, 2015
Subject: Houston, we have a potential problem
I had a lights out total failure of my Bendix/King KLX135A a few months back during a day trip and returned NORDO back into LVK. LAC at SJC did the repair on it (failed electrolytic capacitors in the power section) for several hundred $$. The repaired unit operated fine until about halfway thru a recent flight, when just the receiver section failed, and again back to LVK. LAC honored the previous repair bill and fixed it again (this time leaky electrolytic caps on another CCA deeper within the unit). The tech told me there are more electrolytic caps throughout the unit that could fail in the future. I work with defense electronics so am comfortable with attempting repairs of this type in the future. I don't want this transceiver to nickel and dime me to death and would like to get my own copy of the KLX135A service or technical manual to assist in that endeavor if a .pdf copy exists anywhere. I talked to Shane at B/K customer service and he indicated that, since it is a discontinued unit, it would not be unlawful for a dealer or service center to give me a copy. I will be checking with LAC to see if they are willing to do this, but I also wanted to ask you all. I would be most appreciative. -Thx GV ________________________________________________________________________________
Date: Jun 29, 2015
Subject: Re: Houston, we have a potential problem
Boom! http://www.ebay.com/itm/King-KLX-135-and-KLX-135A-GPS-Comm-Service-Manual-/190635239443 Matt Dralle At 05:36 PM 6/29/2015 Monday, you wrote: >I had a lights out total failure of my Bendix/King KLX135A a few months back during a day trip and returned NORDO back into LVK. LAC at SJC did the repair on it (failed electrolytic capacitors in the power section) for several hundred $$. The repaired unit operated fine until about halfway thru a recent flight, when just the receiver section failed, and again back to LVK. LAC honored the previous repair bill and fixed it again (this time leaky electrolytic caps on another CCA deeper within the unit). > >The tech told me there are more electrolytic caps throughout the unit that could fail in the future. I work with defense electronics so am comfortable with attempting repairs of this type in the future. I don't want this transceiver to nickel and dime me to death and would like to get my own copy of the KLX135A service or technical manual to assist in that endeavor if a .pdf copy exists anywhere. > >I talked to Shane at B/K customer service and he indicated that, since it is a discontinued unit, it would not be unlawful for a dealer or service center to give me a copy. I will be checking with LAC to see if they are willing to do this, but I also wanted to ask you all. > >I would be most appreciative. > >-Thx > >GV Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jun 29, 2015
Matt, Did you send a copy to Bob N? I send him all the manuals I get for his library. Don On Jun 29, 2015 5:48 PM, "Matt Dralle" wrote: > > Boom! > > > http://www.ebay.com/itm/King-KLX-135-and-KLX-135A-GPS-Comm-Service-Manual-/190635239443 > > Matt Dralle > > > At 05:36 PM 6/29/2015 Monday, you wrote: > >I had a lights out total failure of my Bendix/King KLX135A a few months > back during a day trip and returned NORDO back into LVK. LAC at SJC did > the repair on it (failed electrolytic capacitors in the power section) for > several hundred $$. The repaired unit operated fine until about halfway > thru a recent flight, when just the receiver section failed, and again back > to LVK. LAC honored the previous repair bill and fixed it again (this time > leaky electrolytic caps on another CCA deeper within the unit). > > > >The tech told me there are more electrolytic caps throughout the unit > that could fail in the future. I work with defense electronics so am > comfortable with attempting repairs of this type in the future. I don't > want this transceiver to nickel and dime me to death and would like to get > my own copy of the KLX135A service or technical manual to assist in that > endeavor if a .pdf copy exists anywhere. > > > >I talked to Shane at B/K customer service and he indicated that, since it > is a discontinued unit, it would not be unlawful for a dealer or service > center to give me a copy. I will be checking with LAC to see if they are > willing to do this, but I also wanted to ask you all. > > > >I would be most appreciative. > > > >-Thx > > > >GV > > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > ________________________________________________________________________________
Date: Jun 29, 2015
Thx Matt! -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Mon, Jun 29, 2015 5:46 pm Subject: Re: RV-List: Houston, we have a potential problem Boom! http://www.ebay.com/itm/King-KLX-135-and-KLX-135A-GPS-Comm-Service-Manual-/190635239443 Matt Dralle At 05:36 PM 6/29/2015 Monday, you wrote: >I had a lights out total failure of my Bendix/King KLX135A a few months back during a day trip and returned NORDO back into LVK. LAC at SJC did the repair on it (failed electrolytic capacitors in the power section) for several hundred $$. The repaired unit operated fine until about halfway thru a recent flight, when just the receiver section failed, and again back to LVK. LAC honored the previous repair bill and fixed it again (this time leaky electrolytic caps on another CCA deeper within the unit). > >The tech told me there are more electrolytic caps throughout the unit that could fail in the future. I work with defense electronics so am comfortable with attempting repairs of this type in the future. I don't want this transceiver to nickel and dime me to death and would like to get my own copy of the KLX135A service or technical manual to assist in that endeavor if a .pdf copy exists anywhere. > >I talked to Shane at B/K customer service and he indicated that, since it is a discontinued unit, it would not be unlawful for a dealer or service center to give me a copy. I will be checking with LAC to see if they are willing to do this, but I also wanted to ask you all. > >I would be most appreciative. > >-Thx > >GV Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft - The RV-List Email Forum - browse Search & Download, 7-Day Browse, Chat, FAQ, more: http://www.matronics.com/Navigator?RV-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 29, 2015
If I can get this I will send Bob a copy. -GV -----Original Message----- From: don van santen <donvansanten(at)gmail.com> Sent: Mon, Jun 29, 2015 5:55 pm Subject: Re: RV-List: Houston, we have a potential problem Matt, Did you send a copy to Bob N? I send him all the manuals I get for his library. Don On Jun 29, 2015 5:48 PM, "Matt Dralle" < dralle(at)matronics.com> wrote: Boom! http://www.ebay.com/itm/King-KLX-135-and-KLX-135A-GPS-Comm-Service-Manual-/190635239443 Matt Dralle At 05:36 PM 6/29/2015 Monday, you wrote: >I had a lights out total failure of my Bendix/King KLX135A a few months back during a day trip and returned NORDO back into LVK. LAC at SJC did the repair on it (failed electrolytic capacitors in the power section) for several hundred $$. The repaired unit operated fine until about halfway thru a recent flight, when just the receiver section failed, and again back to LVK. LAC honored the previous repair bill and fixed it again (this time leaky electrolytic caps on another CCA deeper within the unit). > >The tech told me there are more electrolytic caps throughout the unit that could fail in the future. I work with defense electronics so am comfortable with attempting repairs of this type in the future. I don't want this transceiver to nickel and dime me to death and would like to get my own copy of the KLX135A service or technical manual to assist in that endeavor if a .pdf copy exists anywhere. > >I talked to Shane at B/K customer service and he indicated that, since it is a discontinued unit, it would not be unlawful for a dealer or service center to give me a copy. I will be checking with LAC to see if they are willing to do this, but I also wanted to ask you all. > >I would be most appreciative. > >-Thx > >GV Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft =========== ist" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =========== ________________________________________________________________________________
Date: Jun 30, 2015
Matt: please remove me from the list: dwhite17(at)columbus.rr.com thanks Dave > On Jun 29, 2015, at 8:44 PM, Matt Dralle wrote: > > This message cannot be displayed because of the way it is formatted. Ask the sender to send it again using a different format or email program. text/plain ________________________________________________________________________________
Date: Jul 17, 2015
Subject: RV6/7 Wanted
All- I have a friend who is looking for a tailwheel 6 or 7. You may contact him directly RV6 or 7 Lycoming 360 engine, either carb or fuel injected Constant speed prop Panel/avionics can be basic I would seriously consider a project if it is well along the completion path 650-504-4464 ________________________________________________________________________________
Date: Jul 18, 2015
Subject: Re: RV6/7 Wanted
Date: Jul 20, 2015
Doug, I have an rv6 , o-320, steam gauges. James On Sat, Jul 18, 2015 at 10:04 AM, Doug Weiler wrote: > > ________________________________________________________________________________
Subject: RV6A project
Date: Aug 02, 2015
I have an RV6A project for sale. I will not be able to complete it or fly it if completed. Everything to complete the project ready to fly is available. Instruments: Dynon D10, Apollo, MX20 GPS,GX60 radio, SL70 transponder, Truetrak 2 axis auto pilot, AOA, PS Intercom, CO monitor, vision engine monitor with carb temp and a few others plus extras for the firewall forward. The major items needed for completion are riveting on the top forward skin and adding the windscreen. This is a RV6A slider with a 0-360 lycoming and a Hartzell constant speed prop (both purchased new from Vans). If interested or know of someone interested, please contact me. Jerry Forrest 323-697-2044 heart911(at)adelphia.net heart911(at)roadrunner.com Location: So California ________________________________________________________________________________
Subject: ...a most mysterious RV...
Date: Aug 12, 2015
A quite unusual RVI believe it was an RV-6Avisited the Orcas Island Fly-In (WA) this past weekendone about which I would like to know much more. It is BY FAR the quietist RV I have EVER seen and just barely heardit was literally whisper-quiet. Ive been told it had a 4 bladed propeller though I could not confirm this to be true. In fact, it is the quietist airplane on take off Ive ever heard in my life, other than a couple of electrically powered ones. Id be most grateful for any information on its owner, power plant, and propeller anyone can post. Fred ________________________________________________________________________________
Date: Aug 12, 2015
A quite unusual RVI believe it was an RV-6Avisited the Orcas Island Fly-In (WA) this past weekendone about which I would like to know much more. It is BY FAR the quietist RV I have EVER seen and just barely heardit was literally whisper-quiet. Ive been told it had a 4 bladed propeller though I could not confirm this to be true. In fact, it is the quietist airplane on take off Ive ever heard in my life, other than a couple of electrically powered ones. Id be most grateful for any information on its owner, power plant, and propeller anyone can post. Fred Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445862#445862 ________________________________________________________________________________
Subject: Re: ...a most mysterious RV...
Date: Aug 12, 2015
It flew over my house and I too wondered if it had an alternate engine, a muffler or what. It was amazingly quiet. I usually can ID an RV flying by just by the sound. I would have had no idea what this was if I hadn't seen it too. Hopefully someone knows the plane and can tell us about it. It looked like it was headed in the direction of Puyallup on its way home from Orcas. -------------------------------------------------- From: "Fred Klein" <fklein(at)orcasonline.com> Sent: Wednesday, August 12, 2015 10:46 AM Subject: RV-List: ...a most mysterious RV... > > A quite unusual RVI believe it was an RV-6Avisited the Orcas Island > Fly-In (WA) this past weekendone about which I would like to know much > more. > > It is BY FAR the quietist RV I have EVER seen and just barely heardit was > literally whisper-quiet. Ive been told it had a 4 bladed propeller though > I could not confirm this to be true. > > In fact, it is the quietist airplane on take off Ive ever heard in my > life, other than a couple of electrically powered ones. > > Id be most grateful for any information on its owner, power plant, and > propeller anyone can post. > > Fred > > > ________________________________________________________________________________
Date: Aug 12, 2015
On 8/12/2015 12:46 PM, Fred Klein wrote: > > A quite unusual RVI believe it was an RV-6Avisited the Orcas Island Fly-In (WA) this past weekendone about which I would like to know much more. > > It is BY FAR the quietist RV I have EVER seen and just barely heardit was literally whisper-quiet. Ive been told it had a 4 bladed propeller though I could not confirm this to be true. > > In fact, it is the quietist airplane on take off Ive ever heard in my life, other than a couple of electrically powered ones. > > Id be most grateful for any information on its owner, power plant, and propeller anyone can post. > > Fred > > N number? Color? Paint scheme? Tipup or slider? I know of some quiet alt engine RV's, but need at least a few more hints. Charlie ________________________________________________________________________________
Date: Aug 12, 2015
N number: unk Color: white/off whitemaybe some minimal striping Tip up non-standard cowl inlets > On Aug 12, 2015, at 7:22 PM, Charlie England wrote: > > > On 8/12/2015 12:46 PM, Fred Klein wrote: >> >> A quite unusual RVI believe it was an RV-6Avisited the Orcas Island Fly-In (WA) this past weekendone about which I would like to know much more. >> >> It is BY FAR the quietist RV I have EVER seen and just barely heardit was literally whisper-quiet. Ive been told it had a 4 bladed propeller though I could not confirm this to be true. >> >> In fact, it is the quietist airplane on take off Ive ever heard in my life, other than a couple of electrically powered ones. >> >> Id be most grateful for any information on its owner, power plant, and propeller anyone can post. >> >> Fred >> >> >> >> > N number? Color? Paint scheme? Tipup or slider? > > I know of some quiet alt engine RV's, but need at least a few more hints. > > Charlie > > > ________________________________________________________________________________
Date: Aug 12, 2015
Sorry; can't help with so little info... Doesn't match any of the ones I'm familiar with. On 8/12/2015 9:31 PM, Fred Klein wrote: > > N number: unk > Color: white/off whitemaybe some minimal striping > Tip up > non-standard cowl inlets > >> On Aug 12, 2015, at 7:22 PM, Charlie England wrote: >> >> >> On 8/12/2015 12:46 PM, Fred Klein wrote: >>> >>> A quite unusual RVI believe it was an RV-6Avisited the Orcas Island Fly-In (WA) this past weekendone about which I would like to know much more. >>> >>> It is BY FAR the quietist RV I have EVER seen and just barely heardit was literally whisper-quiet. Ive been told it had a 4 bladed propeller though I could not confirm this to be true. >>> >>> In fact, it is the quietist airplane on take off Ive ever heard in my life, other than a couple of electrically powered ones. >>> >>> Id be most grateful for any information on its owner, power plant, and propeller anyone can post. >>> >>> Fred >>> >>> >>> >>> >> N number? Color? Paint scheme? Tipup or slider? >> >> I know of some quiet alt engine RV's, but need at least a few more hints. >> >> Charlie >> >> >> > ________________________________________________________________________________
Date: Aug 12, 2015
Charliesorry I cant give you more particulars I want to emphasize that the RV Im talking about was NOT just a sort of quiet variantthis puppy was WHISPER-QUIETalmost unbelievably soEXTREMELY LOW NOISE LEVELboth for engine noise and propeller noise. Fred > On Aug 12, 2015, at 8:12 PM, Charlie England wrote: > > > Sorry; can't help with so little info... > > Doesn't match any of the ones I'm familiar with. > > On 8/12/2015 9:31 PM, Fred Klein wrote: >> >> N number: unk >> Color: white/off whitemaybe some minimal striping >> Tip up >> non-standard cowl inlets >> >>> On Aug 12, 2015, at 7:22 PM, Charlie England wrote: >>> >>> >>> On 8/12/2015 12:46 PM, Fred Klein wrote: >>>> >>>> A quite unusual RVI believe it was an RV-6Avisited the Orcas Island Fly-In (WA) this past weekendone about which I would like to know much more. >>>> >>>> It is BY FAR the quietist RV I have EVER seen and just barely heardit was literally whisper-quiet. Ive been told it had a 4 bladed propeller though I could not confirm this to be true. >>>> >>>> In fact, it is the quietist airplane on take off Ive ever heard in my life, other than a couple of electrically powered ones. >>>> >>>> Id be most grateful for any information on its owner, power plant, and propeller anyone can post. >>>> >>>> Fred >>>> >>>> >>>> >>>> >>> N number? Color? Paint scheme? Tipup or slider? >>> >>> I know of some quiet alt engine RV's, but need at least a few more hints. >>> >>> Charlie >>> >>> >>> >> > > > > ________________________________________________________________________________
Subject: Re: RV10-List: drag video
Date: Aug 24, 2015
Thanks to everyone who replied to my query .... There appears to be a slew of drag-related videos done by Ascher H. Shapiro .... MIT professor. Not what I'm looking for. The video I'm searching for (as I remember it) had much simpler hardware and mounted the test pieces vertically with the fan blowing horizontally. As I remember it, the setup was far simpler than the balance beam. The video may not be on Youtube .... my searches there haven't found it ..... but on a website somewhere else. I'm just hoping somebody recalls it ...... I want to duplicate it for the Boy Scouts merit badge. Linn ________________________________________________________________________________
Subject: Bonanza Strut Pump?
Date: Aug 24, 2015
Hi All, I have a RV-4 but also a 1949 A-35 Bonanza. My strut pump just gave up do to old age. 50 years plus. Any suggestions on a replacement. Thank you very much. Bruce Bell Lubbock, Texas ________________________________________________________________________________
Subject: Re: Bonanza Strut Pump?
Date: Aug 24, 2015
Hi Bruce! I acquired a strut pump that wouldn't pump at all. I replaced the hardened, dried out leather seals and now it works fine. Linn On 8/24/2015 4:13 PM, Bruce Bell wrote: > Hi All, > I have a RV-4 but also a 1949 A-35 Bonanza. My strut pump just gave up > do to old age. 50 years plus. Any suggestions on a replacement. Thank > you very much. > Bruce Bell > Lubbock, Texas > http://www.matronics.com/contribution > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Aug 24, 2015
Thanks for the reply! My old one was a war surplus 24 volt job. I think it was used to charge guns on a bomber. It did work off my car battery with a jumper cable for years. I am going to check the wiring connections. Thanks for the reply! Check Six, Bruce Bell From: Linn Walters Sent: Monday, August 24, 2015 4:22 PM Subject: Re: RV-List: Bonanza Strut Pump? Hi Bruce! I acquired a strut pump that wouldn't pump at all. I replaced the hardened, dried out leather seals and now it works fine. Linn On 8/24/2015 4:13 PM, Bruce Bell wrote: Hi All, I have a RV-4 but also a 1949 A-35 Bonanza. My strut pump just gave up do to old age. 50 years plus. Any suggestions on a replacement. Thank you very much. Bruce Bell Lubbock, Texas No virus found in this message. Checked by AVG - www.avg.com Date: 08/24/15 ________________________________________________________________________________
Subject: One more RV flying
Date: Aug 25, 2015
I havent posted to this list serve in quite a while but I thought Id drop a note to the effect that another rare RV-3 took to the sky this weekend. Not my first RV or airplane to build and fly, but the grin is still remarkably infectious. She flies pretty much hands free except for the usual right rudder. The usual CHTs on the right side are also a tad warm on climb out, but Ill wait until break in is done to do too much sorting out. Its manageable if I dont keep the power at full blast with the nose up. Shes about 300lbs lighter than my -6 so handles noticeably lighter. The sight picture appears somewhat higher so finding that 1 inch wheel to ground zone is going to take a few landings. It may be that things are smaller which makes it feel higher and Im over correcting. The integrated Dynon Skyview system is pretty cool but the data density being presented is intense while flying the airplane. That will take some getting used to in spite of countless hours staring at it and pushing buttons. AA ________________________________________________________________________________
Date: Aug 25, 2015
Subject: Re: One more RV flying
Congratulations! I have given serious thought to building a -3. I would like to hear more about the differences and joy of flying it. I am using a GRT HX and am entirely addicted to all the information without a big instrument scan. Regards, Michael Wynn RV 8 Livermore, CA In a message dated 8/25/2015 1:12:15 P.M. Pacific Daylight Time, wnorth(at)sdccd.edu writes: --> RV-List message posted by: Wheeler North I haven=99t posted to this list serve in quite a while but I though t I=99d drop a note to the effect that another rare RV-3 took to the sky this weekend. Not my first RV or airplane to build and fly, but the grin is st ill remarkably infectious. She flies pretty much hands free except for the usual right rudder. The usual CHTs on the right side are also a tad warm on climb out, but I =99 ll wait until break in is done to do too much sorting out. It=99s manageable if I don=99t keep the power at full blast with the nose up. She=99s about 300lbs lighter than my -6 so handles noticeably light er. The sight picture appears somewhat higher so finding that 1 inch wheel to gro und zone is going to take a few landings. It may be that things are smaller which makes it feel higher and I=99m over correcting. The integrated Dynon Skyview system is pretty cool but the data density being presented is intense while flying the airplane. That will take some getting used to in spite of countless hours staring at it and pushing bu ttons. AA ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Subject: Pre buy inspection?
Date: Aug 25, 2015
I recently sold my RV-10 aircraft. As we all know an important aspect of any aircraft ownership change is the pre-buy inspection. In my case the pre-buy inspection was done on behalf of the buyer by Vic Syracuse of Base Leg Aviation. Vic, as most of us know, is a multiple repeat offending builder of several RVs and other experimental aircraft. He is also a DAR, AI, CFII, and probably one of the Van=99s families=99 most respected experts. He gave the keynote address at this year=99s Van=99s Banquet at Air Venture. Vic=99s inspection of my aircraft was through, and efficiently completed. The result of his work was instrumental in the sale being completed smoothly. I believe the buyer is confident he is getting a good airplane and I am confident he is in good hands as he becomes acclimated to his new airplane. So, if you are an RV shopper or seller I would certainly recommend Base Leg Aviation for the pre-buy inspection or any of their other many services.60 Dick Sipp RV-4 sold RV-10 sold RV-12 60 hours ________________________________________________________________________________
Date: Aug 25, 2015
> >I havent posted to this list serve in quite a while but I thought Id >drop a note to the effect that another rare RV-3 took to the sky this >weekend. Not my first RV or airplane to build and fly, but the grin is >still remarkably infectious. > >She flies pretty much hands free except for the usual right rudder. > >The usual CHTs on the right side are also a tad warm on climb out, but >Ill wait until break in is done to do too much sorting out. Its >manageable if I dont keep the power at full blast with the nose up. > >Shes about 300lbs lighter than my -6 so handles noticeably lighter. >The sight picture appears somewhat higher so finding that 1 inch wheel >to ground zone is going to take a few landings. It may be that things >are smaller which makes it feel higher and Im over correcting. > >The integrated Dynon Skyview system is pretty cool but the data density >being presented is intense while flying the airplane. That will take >some getting used to in spite of countless hours staring at it and >pushing buttons. > >AA > > Congrats on another leaving the nest. I hear the -3 flies the best; any truth to the rumor? -- Sent from my Android device with K-9 Mail. Please excuse my brevity. ________________________________________________________________________________
Subject: -3
Date: Aug 28, 2015
Well, I havent flown any of the two digit versions but for now the -3 is most certainly fun. Being 300 lbs lighter than my -6 is very noticeable. Im not inclined to say its the best thus implying anyone elses is worse. I will say it is an intensely personal kind of flying in part because of the obvious single place nature, but also because it is so light and small. AA ________________________________________________________________________________
Date: Sep 22, 2015
Subject: Alternative sources for MX20 and 400W databases
Anyone out there know of any alternative sources? Are we stuck with the expensive monopoly Jeppesen? ________________________________________________________________________________
Subject: Re: Alternative sources for MX20 and 400W databases
Date: Sep 22, 2015
On 9/22/2015 7:09 AM, Ralph E. Capen wrote: > > Anyone out there know of any alternative sources? > > Are we stuck with the expensive monopoly Jeppesen? > There's a guy on the VAF forum that frequently offers updates for 430s, if that helps. ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Oct 04, 2015
Thank you iPhone users for waiting out the IOS 9 upgrade while the Airport Courtesy Car app was down. The app is back up for all users and the layout and look of the app has been upgraded also. The listings continue to grow, currently at over 1,520, and approaches 25,000 launches. Please continue to send in listings I have missed or corrections that need to be made and I will get right on them. And if you use and like the app, please consider a small donation to help with expenses, even the tip that you leave on the lunch counter is appreciated. There are PayPal links on the app, and my mailing address is also listed within the app. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, "Airport Courtesy Cars" Smart Phone App. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447649#447649 ________________________________________________________________________________
Subject: RV9A for sale
Date: Oct 17, 2015
Lost Medical, flying quickbuild for sale, IFR capable, hagared Greeley Colorado (GXY), email for details. Mike Holland ________________________________________________________________________________
Date: Oct 21, 2015
Subject: A bad move
http://www.kathrynsreport.com/2014/06/toledo-lincoln-county-oregon.html Van's suit that I hadn't heard about. Stupid pilot tricks 101. Good luck with that... -GV ________________________________________________________________________________
Date: Oct 21, 2015
Subject: Re: A bad move
Very sad indeed. I hope I don't sound callous, but that's what the "Experimental" placard is for. It clearly states that the aircraft does not conform to normal FAA standards, yet she chose to fly aboard the aircraft. The survivor's claim that the aircraft was not required to meet normal standards is kind of redundant... On 10/21/2015 3:33 PM, vanremog(at)aol.com wrote: > http://www.kathrynsreport.com/2014/06/toledo-lincoln-county-oregon.html > Van's suit that I hadn't heard about. Stupid pilot tricks 101. > Good luck with that... > -GV > * > > > * -- ________________________________________________________________________________
From: "LARRY C. BOWLES" <SCHYBOLT(at)austin.rr.com>
Date: Oct 21, 2015
I WILL ALSO RISK SOUNDING CALLOUS. THE GUY WAS WARNED THAT RTV WAS NOT AN ACCEPTABLE SEALANT. IMHO VAN=99S NOR FLOSCAN HAS ANY LIABILITY. LARRY BOWLES ________________________________________________________________________________
Date: Oct 21, 2015
I would agree, but nothing keeps them from suing anyway. The only ones that win are the lawyers, and Judges used to be lawyers. We are in deep Kimchee and somebody is still filling the pot ..... Linn On 10/21/2015 2:40 PM, LARRY C. BOWLES wrote: > I WILL ALSO RISK SOUNDING CALLOUS. THE GUY WAS WARNED THAT RTV WAS > NOT AN ACCEPTABLE SEALANT. IMHO VANS NOR FLOSCAN HAS ANY LIABILITY. > LARRY BOWLES > http://www.matronics.com/contribution > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Nov 01, 2015
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 22 different gifts to choose from! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Andy is a very generous guy and I encourage you to visit his web site. I would like publicly to thank Andy for his generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 04, 2015
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2015
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2015
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2015
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2015
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 13, 2015
Subject: Make Sure You're Listed! List of Contributors Published in December!
Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2015
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 16, 2015
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 17, 2015
Subject: Lycoming Engine Fuel Flow Problem...
Dear Listers, I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out and isn't binding and does lean the engine. I came in and landed with no issues. I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? Mechanical Fuel Pump? Something in the Carb? Plugged fuel line? ?? Thanks for your feedback, Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 260+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 350+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: Lycoming Engine Fuel Flow Problem...
Date: Nov 17, 2015
You are correct. The FF is too low and it is reflected on the EGT and CHT. In fact, you undoubtedly were LOP, producing about 140-150hp. A bit surprising if it in fact still has a carburetor. IMHO, if EGT goes above 1350 on takeoff roll, it is cause to abort if feasible. It should be between 1200 and 1300, assuming sea level vicinity. Plugged fuel filter, failing mechanical pump diaphram, carb fuel inlet needle valve stuck, carb fuel vent plugged are all potential causes. If there is any seepage on the mech pump drain, the diaphram is bad and not generating the fuel pressure needed. The carb may or maynot have an inlet screen that could be partially plugged. If the data goes back far enough I would download the log from the Skyview and look for when the problem first occurred. That may help you isolate when/where it happened and what changed. On 11/17/2015 8:24 PM, Matt Dralle wrote: > > > Dear Listers, > > I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a! > nd isn't binding and does lean the engine. I came in and landed with no issues. > > I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? > > Mechanical Fuel Pump? > > Something in the Carb? > > Plugged fuel line? > > ?? > > Thanks for your feedback, > > Matt > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 260+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 350+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > ________________________________________________________________________________
Date: Nov 17, 2015
Sounds like you have a blockage in your fuel filters that just barely allows enough fuel to flow..... I had a similar issue with my AFP injected IO360B1F6. There is a small fuel inlet filter that was clogged with fine black goo. Cleaned that and added a larger capacity filter upstream that has a smaller micron rating than the inlet filter - it is on my annual list now. Cured the issue for me. Glad you had enough fuel flow to continue flying and safely land. Throttling back helped me - I didn't experience mine on take off though.....boost pump didn't help me.... -----Original Message----- >From: Matt Dralle <dralle(at)matronics.com> >Sent: Nov 17, 2015 10:24 PM >To: rv-list(at)matronics.com, lycoming-list(at)matronics.com, engines-list(at)matronics.com >Subject: RV-List: Lycoming Engine Fuel Flow Problem... > > >Dear Listers, > >I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a ! > nd isn't binding and does lean the engine. I came in and landed with no issues. > >I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? > >Mechanical Fuel Pump? > >Something in the Carb? > >Plugged fuel line? > >?? > >Thanks for your feedback, > >Matt > >- >Matt Dralle > >RV-8 #82880 N998RV "Ruby Vixen" >http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log >http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log >http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >Status: 260+ Hours TTSN - Version 2.0 Now Flying! > >RV-6 #20916 N360EM "The Flyer" >http://www.mattsrv6.com - Matt's RV-6 Revitalization Log >Status: 350+ Hours - Full Flyer Mode! > >Matt's Livermore Airport Live ATC Stream! >Check out the live ATC stream directly from my hangar at the Livermore >Airport. Includes both Tower and Ground transmissions. Archives too! >For entertainment purposes only. http://klvk.matronics.com > > ________________________________________________________________________________
Date: Nov 17, 2015
SGF2ZSB5b3UgY2xlYW5lZCBhbGwgeW91ciBzY3JlZW5zPwpEaWQgeW91IHN3aXRjaCB0YW5rcz8K RGlkIHlvdSBjaGVjayB5b3VyIHZlbnRzPwotR1YKClNlbnQgZnJvbSBhIGdhbGF4eSBmYXIgZmFy IGF3YXkuLi4KCk1hdHQgRHJhbGxlIDxkcmFsbGVAbWF0cm9uaWNzLmNvbT4gd3JvdGU6Cgo+LS0+ IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IE1hdHQgRHJhbGxlIDxkcmFsbGVAbWF0cm9uaWNz LmNvbT4KPgo+Cj5EZWFyIExpc3RlcnMsCj4KPkkgZmxldyB0aGUgUlYtNiB0b25pZ2h0IHRoYXQg aGFzIGEgMTY2MCBob3VyIEx5Y29taW5nIE8tMzYwQTFBIHdpdGggYSBIYXJ0emVsbCBDUyBwcm9w LiAgSSBmbGV3IGl0IDcgaG91cnMgb3ZlciBhIDMtZGF5IHBlcmlvZCBhYm91dCBhIHdlZWsgYW5k IGEgaGFsZiBhZ28gd2l0aCBubyBpc3N1ZXMgd2hhdHNvZXZlci4gIFRvbmlnaHQsIG9uIHRha2Ug b2ZmLCB0aGUgRUdUJ3MgYWxsIGNsaW1iZWQgaW50byB0aGUgMTQ1MCdzIHJpZ2h0IGFmdGVyIHRh a2Ugb2ZmIGFuZCB0aGUgQ0hUJ3Mgd2VyZSBpbiB0aGUgNDAwLTQ1MCByYW5nZS4gIFRoZSBtaXh0 dXJlIHdhcyBmdWxsIHJpY2guICBUaGUgZW5naW5lIGRpZG4ndCBzZWVtIHRvIGJlIHVuZGVycG93 ZXJlZCBvciByb3VnaCBidXQgdGhlIGZ1ZWwgZmxvdyB3YXMgYWJvdXQgOS0xMCBHUEggd2hlbiBp dCBzaG91bGQgaGF2ZSBiZWVuIGluIHRoZSAxNy0xOUdQSCByYW5nZS4gIE9uIHRoZSBkb3dud2lu ZCBJIHRyaWVkIGZpZGRsaW5nIHdpdGggdGhlIG1peHR1cmUgd2l0aCBubyBjaGFuZ2UgaW4gbWFr aW5nIGl0IHJpY2hlci4gIFRoZSBtaXh0dXJlIGRpZCBtYWtlIGl0IGxlYW5lci4gIEkgc3dpdGNo ZWQgZnJvbSB0aGUgcmlnaHQgdG8gdGhlIGxlZnQgZnVlbCB0YW5rcyB3aXRoIG5vIGNoYW5nZS4g IEkgaGF2ZSB0d28gZnVlbCBmbG93IHRyYW5zZHVjZXJzIG9uZSBmZWVkaW5nIHRoZSBTa3l2aWV3 IGFuZCB0aGUgb3RoZXIgZmVlZGluZyBhIE1hdHJvbmljcyBGdWVsQ2hlYyBEWC4gIEJvdGggd2Vy ZSByZWFkaW5nIHNpbWlsYXJseSBsb3cgZnVlbCBmbG93cyBhdCBmdWxsIHRocm90dGxlIC0gOS0x MGdwaC4gIEkgZGlkbid0IHRoaW5rIHRvIGZsaXAgb24gdGhlIGVsZWN0cmljIGJvb3N0IHB1bXAu ICBCdXQgdGhlIGZsb3cgZGVmaW5pdGVseSBzZWVtZWQgcmVzdHJpY3RlZC4gIFRoZSBtaXh0dXJl IGNvbnRyb2wgc2VlbXMgdG8gaGF2ZSBub3JtYWwgdGhyb3cgaW4gYW5kIG91dCBhIQo+IG5kIGlz bid0IGJpbmRpbmcgYW5kIGRvZXMgbGVhbiB0aGUgZW5naW5lLiAgSSBjYW1lIGluIGFuZCBsYW5k ZWQgd2l0aCBubyBpc3N1ZXMuCj4KPkkgaGF2ZW4ndCBwdWxsZWQgdGhlIGNvd2xpbmcgeWV0IHRv IGhhdmUgYSBsb29rIHRvIHNlZSBpZiBpdHMgc29tZXRoaW5nIG9idmlvdXMgd2l0aCB0aGUgbWl4 dHVyZSBjYWJsZSwgYnV0IHdoYXQgYXJlIHNvbWUgdGhvdWdodHMgb24gd2hhdCB0aGlzIGNvdWxk IGJlPyAgCj4KPk1lY2hhbmljYWwgRnVlbCBQdW1wPwo+Cj5Tb21ldGhpbmcgaW4gdGhlIENhcmI/ Cj4KPlBsdWdnZWQgZnVlbCBsaW5lPwo+Cj4/Pwo+Cj5UaGFua3MgZm9yIHlvdXIgZmVlZGJhY2ss Cj4KPk1hdHQKPgo+LQo+TWF0dCBEcmFsbGUKPgo+UlYtOCAjODI4ODAgTjk5OFJWICJSdWJ5IFZp eGVuIgo+aHR0cDovL3d3dy5tYXR0c3J2OC5jb20gLSBNYXR0J3MgQ29tcGxldGUgUlYtOCBDb25z dHJ1Y3Rpb24gTG9nCj5odHRwOi8vd3d3Lm1hdHRzcnY4LmNvbS9NaXNoYXAgLSBMYW5kaW5nIE1p c2hhcCBSZWJ1aWxkIExvZwo+aHR0cDovL3d3dy55b3V0dWJlLmNvbS9NYXR0c1JWOCAtIE1hdHQn cyBSVi04IEhEVFYgWW91VHViZSBDaGFubmVsCj5TdGF0dXM6IDI2MCsgSG91cnMgVFRTTiAtIFZl cnNpb24gMi4wIE5vdyBGbHlpbmchCj4KPlJWLTYgIzIwOTE2IE4zNjBFTSAiVGhlIEZseWVyIgo+ aHR0cDovL3d3dy5tYXR0c3J2Ni5jb20gLSBNYXR0J3MgUlYtNiBSZXZpdGFsaXphdGlvbiBMb2cK PlN0YXR1czogMzUwKyBIb3VycyAtIEZ1bGwgRmx5ZXIgTW9kZSEKPgo+TWF0dCdzIExpdmVybW9y ZSBBaXJwb3J0IExpdmUgQVRDIFN0cmVhbSEKPkNoZWNrIG91dCB0aGUgbGl2ZSBBVEMgc3RyZWFt IGRpcmVjdGx5IGZyb20gbXkgaGFuZ2FyIGF0IHRoZSBMaXZlcm1vcmUKPkFpcnBvcnQuICBJbmNs dWRlcyBib3RoIFRvd2VyIGFuZCBHcm91bmQgdHJhbnNtaXNzaW9ucy4gIEFyY2hpdmVzIHRvbyEK PkZvciBlbnRlcnRhaW5tZW50IHB1cnBvc2VzIG9ubHkuICBodHRwOi8va2x2ay5tYXRyb25pY3Mu Y29tCj4KPgo+Cj5fLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQo+Xy09Cj5fLT0gICAgICAgLS0gUGxlYXNlIFN1cHBvcnQgWW91ciBM aXN0cyBUaGlzIE1vbnRoIC0tCj5fLT0gICAgICAgICAgIChBbmQgR2V0IFNvbWUgQVdFU09NRSBG UkVFIEdpZnRzISkKPl8tPQo+Xy09ICAgTm92ZW1iZXIgaXMgdGhlIEFubnVhbCBMaXN0IEZ1bmQg UmFpc2VyLiAgQ2xpY2sgb24KPl8tPSAgIHRoZSBDb250cmlidXRpb24gbGluayBiZWxvdyB0byBm aW5kIG91dCBtb3JlIGFib3V0Cj5fLT0gICB0aGlzIHllYXIncyBUZXJyaWZpYyBGcmVlIEluY2Vu dGl2ZSBHaWZ0cyBwcm92aWRlZAo+Xy09ICAgYnk6Cj5fLT0gICAKPl8tPSAgICAgKiBUaGUgQnVp bGRlcidzIEJvb2tzdG9yZSB3d3cuYnVpbGRlcnNib29rcy5jb20KPl8tPQo+Xy09ICAgTGlzdCBD b250cmlidXRpb24gV2ViIFNpdGU6Cj5fLT0KPl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vY29udHJpYnV0aW9uCj5fLT0KPl8tPSAgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91 cyBzdXBwb3J0IQo+Xy09Cj5fLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uCj5fLT0KPl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj5fLT0gICAgICAgICAgLSBUaGUgUlYtTGlz dCBFbWFpbCBGb3J1bSAtCj5fLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZp Z2F0b3IgdG8gYnJvd3NlCj5fLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0 IFVuL1N1YnNjcmlwdGlvbiwKPl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBC cm93c2UsIENoYXQsIEZBUSwKPl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cj5f LT0KPl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWLUxpc3QK Pl8tPQo+Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0KPl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQo+ Xy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMh Cj5fLT0KPl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KPl8tPQo+Xy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Pl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KPl8tPSAgVGhh bmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCj5fLT0gICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCj5fLT0gICAtLT4gaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgo+Xy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KPgo+Cj4K ________________________________________________________________________________
Date: Nov 18, 2015
Admittedly, with all the readings on your monitoring giving abnormal numbers, it appears to be be a problem with the fuel system, but I would first check to see that the problem is real. Do you know what the engine pulled for static rpm, wot on the ground before the problem showed up? If so, then I would check the wot rpm now to see if you are getting full power. Did you fly long enough to check your real fuel usage by refueling and comparing usage against what you would normally expect? If you seem to get full rpm (power) and real fuel usage is normal then there MIGHT be an electrical problem that's affecting your monitoring system, like a bad ground. Warren > On Nov 18, 2015, at 12:48 AM, vanremog(at)aol.com wrote: > > switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a! > nd isn't binding and does lean the engine. I came in and landed with no issues. > > I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? > > Mechanical Fuel Pump? ________________________________________________________________________________
Date: Nov 18, 2015
I have a similar set up with an A1A. Your observations and deductions seem logical to me. I would do the easiest thing first, and check the boost pump on to see if it brings up the flow/pressure. This would point to the mechanical pump as a problem. By the way, it is my opinion that you should always take off with the boost pump on. I also use a procedure by which I check the boost pump for pressure before engine start, then start with only the mechanical pump. When the run up is complete, Then I turn on the boost pump for take off. Again this is another chance to catch a failed or failing mech pump before take off. Hope this helps. Denis Walsh denis.walsh(at)comcast.net > On 17Nov, 2015, at 20:24, Matt Dralle wrote: > > > > Dear Listers, > > I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a! > nd isn't binding and does lean the engine. I came in and landed with no issues. > > I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? > > Mechanical Fuel Pump? > > Something in the Carb? > > Plugged fuel line? > > ?? > > Thanks for your feedback, > > Matt > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 260+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 350+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > > > > > ________________________________________________________________________________
Date: Nov 18, 2015
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 18, 2015
Denis, I use your method for take-offs also! Ralph -----Original Message----- >From: Denis Walsh <denis.walsh(at)comcast.net> >Sent: Nov 18, 2015 11:37 AM >To: "rv list matronics.com" >Subject: Re: RV-List: Lycoming Engine Fuel Flow Problem... > > >I have a similar set up with an A1A. Your observations and deductions seem logical to me. I would do the easiest thing first, and check the boost pump on to see if it brings up the flow/pressure. This would point to the mechanical pump as a problem. > >By the way, it is my opinion that you should always take off with the boost pump on. I also use a procedure by which I check the boost pump for pressure before engine start, then start with only the mechanical pump. When the run up is complete, Then I turn on the boost pump for take off. Again this is another chance to catch a failed or failing mech pump before take off. > >Hope this helps. > > >Denis Walsh >denis.walsh(at)comcast.net > > >> On 17Nov, 2015, at 20:24, Matt Dralle wrote: >> >> >> >> Dear Listers, >> >> I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out ! > a! >> nd isn't binding and does lean the engine. I came in and landed with no issues. >> >> I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? >> >> Mechanical Fuel Pump? >> >> Something in the Carb? >> >> Plugged fuel line? >> >> ?? >> >> Thanks for your feedback, >> >> Matt >> >> - >> Matt Dralle >> >> RV-8 #82880 N998RV "Ruby Vixen" >> http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log >> http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log >> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >> Status: 260+ Hours TTSN - Version 2.0 Now Flying! >> >> RV-6 #20916 N360EM "The Flyer" >> http://www.mattsrv6.com - Matt's RV-6 Revitalization Log >> Status: 350+ Hours - Full Flyer Mode! >> >> Matt's Livermore Airport Live ATC Stream! >> Check out the live ATC stream directly from my hangar at the Livermore >> Airport. Includes both Tower and Ground transmissions. Archives too! >> For entertainment purposes only. http://klvk.matronics.com >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 18, 2015
I switched tanks with no change in flow. So it would seem to not to be related to the fuel tanks or their plumbing specifically. I'm anxious to dig in and figure out what's going on... Matt At 10:48 PM 11/17/2015 Tuesday, you wrote: >Have you cleaned all your screens? >Did you switch tanks? >Did you check your vents? >-GV >Sent from a galaxy far far away... > > >Matt Dralle wrote: > > >Dear Listers, > >I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a ! >nd isn't binding and does lean the engine. I came in and landed with no issues. > >I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? > >Mechanical Fuel Pump? > >Something in the Carb? > >Plugged fuel line? > >?? > >Thanks for your feedback, > >Matt > >- >Matt Dralle > >RV-8 #82880 N998RV "Ruby Vixen" >http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log >http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log >http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >Status: 260+ Hours TTSN - Version 2.0 Now Flying! > >RV-6 #20916 N360EM "The Flyer" >http://www.mattsrv6.com - Matt's RV-6 Revitalization Log >Status: 350+ Hours - Full Flyer Mode! > >Matt's Livermore Airport Live ATC Stream! >Check out the live ATC stream directly from my hangar at the Livermore >Airport. Includes both Tower and Ground transmissions. Archives too! >For entertainment purposes only. http://klvk.matronics.com > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 18, 2015
After ruling out visible leakage and ensuring the mixture cable gives full mixture range motion (to the stop on the carb), I think I'd disconnect the fuel hose right before the carb and use the boost pump to see the max available fuel flow rate to the carb. That could give you some insight into blockages prior to the carb. This test (fuel flow volume) is described in the old FAA Experimental Aircraft Flight Test AC on page 23 (AC 90-89A, available at https://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentID/23127). FAA recommends seeking 125% of normal max fuel flow (and they tell you how to estimate that value). VR Tim -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 650 hrs Matt Dralle wrote on 11/17/2015 10:24 PM: > > > Dear Listers, > > I flew the RV-6 tonight that has a 1660 hour Lycoming O-360A1A with a Hartzell CS prop. I flew it 7 hours over a 3-day period about a week and a half ago with no issues whatsoever. Tonight, on take off, the EGT's all climbed into the 1450's right after take off and the CHT's were in the 400-450 range. The mixture was full rich. The engine didn't seem to be underpowered or rough but the fuel flow was about 9-10 GPH when it should have been in the 17-19GPH range. On the downwind I tried fiddling with the mixture with no change in making it richer. The mixture did make it leaner. I switched from the right to the left fuel tanks with no change. I have two fuel flow transducers one feeding the Skyview and the other feeding a Matronics FuelChec DX. Both were reading similarly low fuel flows at full throttle - 9-10gph. I didn't think to flip on the electric boost pump. But the flow definitely seemed restricted. The mixture control seems to have normal throw in and out a! > nd isn't binding and does lean the engine. I came in and landed with no issues. > > I haven't pulled the cowling yet to have a look to see if its something obvious with the mixture cable, but what are some thoughts on what this could be? > > Mechanical Fuel Pump? > > Something in the Carb? > > Plugged fuel line? > > ?? > > Thanks for your feedback, > > Matt > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 260+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 350+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > ________________________________________________________________________________
Date: Nov 20, 2015
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Best gliud, 6A
Date: Nov 21, 2015
When I first got Tweetybird 11 yrs ago I experimented with various best gli de speeds, prety much thought 80mph best. I have flight review coming up, n eed to know if that is number most use ? Thanks Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Best gliud, 6A
Date: Nov 21, 2015
The CAFE foundation tested a 6a about 15 years ago and determined a best gli de of right at 100 mph. That is what I use. Sent from my iPhone > On Nov 21, 2015, at 5:23 PM, wrote: > > When I first got Tweetybird 11 yrs ago I experimented with various best gl ide speeds, prety much thought 80mph best. I have flight review coming up, n eed to know if that is number most use ? Thanks Charlie > This email has been sent from a virus-free computer protected by Avast. > www.avast.com ________________________________________________________________________________
Date: Nov 21, 2015
On my RV-6, Best Glide and Best Rate of climb are the same. 78 KIAS is wh at works best in my RV-6. On 11-21-2015 5:23 PM, cheathco(at)cox.net wrote: When I first got Tweetybird 11 yrs ago I experimented with various best gli de speeds, prety much thought 80mph best. I have flight review coming up, n eed to know if that is number most use ? Thanks Charlie [https://ipmcdn.avast.com/images/logo-avast-v1.png] This email has been sent from a virus-free computer pro tected by Avast. www.avast.com ________________________________________________________________________________
Subject: 6A gross wt
Date: Nov 21, 2015
something I have wondered about but never asked. My plane builder listed th e GW at 1650, empty is 1080, but I had seen other ones at 1750. I have been told the 6a has safely carried up to 1850, even tho GW at 1750. I once unk nowingly carried a psg who later told me he weighed 235lb, didn't look it, but landed much harder that usual. I usually carry 200 lb psr max with full fuel and min baggage. Over that I usually carry 3/4 to 1/2 fuel. as a mater of fact I have not had anyone with me over 150 lb for past 2 yea rs.. I have weighed 185 for several years. And at 75 that is not easy to do =2E BTW, knowing that Art xxxx racing in cherokee 140 used to carry his psgr in back seat, so when I did my first race I had 80 lb of batteries in bagage which gave me extra 5mph. Hope to get to bottom of this gross thing =2E Yhanks, Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 21, 2015
Subject: Re: 6A gross wt
I established and tested for 1900 lb utility gross weight with thirty hours on the Hobbs under the following condition, because I wanted to ensure ade quate margin for cross country flights loaded up with baggage. I weighed 185 lb at the time and my 241 lb buddy was along in case he neede d to grab one of the two 50 lb bags of sand out of the baggage area and hol d it in his lap. We worked our way up to this point slowly and performed a ll of our stalls and landings. I have an O-360-A1A and constant speed prop . The plane handled fine throughout the flight but I carried a little more sp eed on landing just in case. I'm not sure I would fly it to empty tanks th ough. An arm of 75.73 is right at 27% MAC. YMMV. Aircraft at Gross Weight Weight Arm Moment Basic Aircraft 1151 69.02 79438 38 gal Fuel in Wing Tanks 228 70.00 15960 Pilot and Passenger 421 87.40 36795.4 Baggage Area 100 117.00 11700 TOTAL 1900 75.73 143893.4 -GV -----Original Message----- From: cheathco <cheathco(at)cox.net> Sent: Sat, Nov 21, 2015 3:47 pm Subject: RV-List: 6A gross wt something I have wondered about but never asked. Myplane builder listed the GW at 1650, empty is 1080, but I had seen otherones at 1750. I have been t old the 6a has safely carried up to 1850, even tho GWat 1750. I once unknow ingly carried a psg who later told me he weighed 235lb,didn=C2=92t look it, but landed much harder that usual. I usually carry 200 lb psrmax with full fuel and min baggage. Over that I usually carry 3/4 to 1/2fuel. as a mater of fact I have not had anyone with meover 150 lb for past 2 year s.. I have weighed 185 for several years. And at 75that is not easy to do. BTW, knowing that Art xxxx racingin cherokee 140 used to carry his psgr in back seat, so when I did my first raceI had 80 lb of batteries in bagage which gave me extra 5mph. Hope to get tobottom of this gross thing. Yhank s, Charlie This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Date: Nov 21, 2015
As I understand it, you are pretty much stuck with what the original builder asked for. I don't know what a DAR would have to do to get you a changed gross wt. On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: > something I have wondered about but never asked. My plane builder > listed the GW at 1650, empty is 1080, but I had seen other ones at > 1750. I have been told the 6a has safely carried up to 1850, even tho > GW at 1750. I once unknowingly carried a psg who later told me he > weighed 235lb, didnt look it, but landed much harder that usual. I > usually carry 200 lb psr max with full fuel and min baggage. Over > that I usually carry 3/4 to 1/2 fuel. > as a mater of fact I have not had anyone with me over 150 lb for past > 2 years.. I have weighed 185 for several years. And at 75 that is not > easy to do. Smile emoticon BTW, knowing that Art xxxx racing in > cherokee 140 used to carry his psgr in back seat, so when I did my > first race I had 80 lb of batteries in bagage which gave me extra > 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > > > ________________________________________________________________________________
Date: Nov 21, 2015
Unless there has been a very recent change in the regs, the owner can raise gross weight by treating it as a major modification. Depending on which version of operating limitations are on the plane, it could be as simple as logging a return to phase one, flying 5 hrs of tests at the increased gross weight, and logging the successful results with a return to phase two (normal operation). Newer versions require notifying the local FSDO & getting their approval for the proposed test area (which might well be the same as the original test area). Not saying anyone should; just that it can be done. As mentioned, there are lots of 6's & 6A's with higher than 1600 lb gross weights in their oplims. Tangentially related to the subject of best glide, Van once wrote an article about best climb rate in the short wing RV's. He indicated that due to increased induced drag of the low aspect ratio wing at low airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere between around 90 mph & 130 mph (rough numbers from my flaky memory). His suggestion was for normal (not obstacle clearance) climb to be at around 130 mph because the rate would be the same but a lot more ground could be covered. I've never bothered to test it, but it seems reasonable that a slightly higher speed might extend the *range* of a glide, as well. Charlie On 11/21/2015 8:33 PM, Kelly McMullen wrote: > > As I understand it, you are pretty much stuck with what the original > builder asked for. I don't know what a DAR would have to do to get you > a changed gross wt. > > On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >> something I have wondered about but never asked. My plane builder >> listed the GW at 1650, empty is 1080, but I had seen other ones at >> 1750. I have been told the 6a has safely carried up to 1850, even tho >> GW at 1750. I once unknowingly carried a psg who later told me he >> weighed 235lb, didnt look it, but landed much harder that usual. I >> usually carry 200 lb psr max with full fuel and min baggage. Over >> that I usually carry 3/4 to 1/2 fuel. >> as a mater of fact I have not had anyone with me over 150 lb for past >> 2 years.. I have weighed 185 for several years. And at 75 that is not >> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >> cherokee 140 used to carry his psgr in back seat, so when I did my >> first race I had 80 lb of batteries in bagage which gave me extra >> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >> >> This email has been sent from a virus-free computer protected by >> Avast. >> www.avast.com >> >> >> > ________________________________________________________________________________
Date: Nov 22, 2015
I was concerned about the 1600 lb gross weight that Van's had on my -6. I knew that the limit was 1650 on the 6A. I worked with my DAR when I was doing the paperwork and we called Van's to find out if they would allow 1650 to be used on the 6. They, in essence, approved it so the DAR allowed me to use that figure. This was in 2007, so I don't know if they would do that today. Bottom line, my "certified" gross weight is set at 1650 which allows my wife and I to fly with full tanks and still have 50lbs for baggage. Warren -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Saturday, November 21, 2015 10:15 PM Subject: Re: RV-List: 6A gross wt Unless there has been a very recent change in the regs, the owner can raise gross weight by treating it as a major modification. Depending on which version of operating limitations are on the plane, it could be as simple as logging a return to phase one, flying 5 hrs of tests at the increased gross weight, and logging the successful results with a return to phase two (normal operation). Newer versions require notifying the local FSDO & getting their approval for the proposed test area (which might well be the same as the original test area). Not saying anyone should; just that it can be done. As mentioned, there are lots of 6's & 6A's with higher than 1600 lb gross weights in their oplims. Tangentially related to the subject of best glide, Van once wrote an article about best climb rate in the short wing RV's. He indicated that due to increased induced drag of the low aspect ratio wing at low airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere between around 90 mph & 130 mph (rough numbers from my flaky memory). His suggestion was for normal (not obstacle clearance) climb to be at around 130 mph because the rate would be the same but a lot more ground could be covered. I've never bothered to test it, but it seems reasonable that a slightly higher speed might extend the *range* of a glide, as well. Charlie On 11/21/2015 8:33 PM, Kelly McMullen wrote: > > As I understand it, you are pretty much stuck with what the original > builder asked for. I don't know what a DAR would have to do to get you > a changed gross wt. > > On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >> something I have wondered about but never asked. My plane builder >> listed the GW at 1650, empty is 1080, but I had seen other ones at >> 1750. I have been told the 6a has safely carried up to 1850, even tho >> GW at 1750. I once unknowingly carried a psg who later told me he >> weighed 235lb, didn't look it, but landed much harder that usual. I >> usually carry 200 lb psr max with full fuel and min baggage. Over >> that I usually carry 3/4 to 1/2 fuel. >> as a mater of fact I have not had anyone with me over 150 lb for past >> 2 years.. I have weighed 185 for several years. And at 75 that is not >> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >> cherokee 140 used to carry his psgr in back seat, so when I did my >> first race I had 80 lb of batteries in bagage which gave me extra >> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >> >> This email has been sent from a virus-free computer protected by >> Avast. >> www.avast.com >> >> >> > ________________________________________________________________________________
Date: Nov 22, 2015
Subject: 6A Gross Wt
I've been flying my RV-6A for 5 years now and the gross wt is above 1600, approved when inspected. I re-calculated what the GW limit would be in the Utility category, based on the aerobatic wt published by Vans of 1350# if my memory serves. Vans has commented that consideration to the design limit of the gear should be considered. So when operating above 1600# I'm very "gentle" with my landings, roll out and taxi. Always keep the nose wheel up on landing and roll out. Just saying......... Marty N826ME From: <cheathco(at)cox.net> Subject: RV-List: 6A gross wt something I have wondered about but never asked. My plane builder listed th e GW at 1650, empty is 1080, but I had seen other ones at 1750. I have been told the 6a has safely carried up to 1850, even tho GW at 1750. I once unk nowingly carried a psg who later told me he weighed 235lb, didn't look it, but landed much harder that usual. I usually carry 200 lb psr max with full fuel and min baggage. Over that I usually carry 3/4 to 1/2 fuel. as a mater of fact I have not had anyone with me over 150 lb for past 2 yea rs.. I have weighed 185 for several years. And at 75 that is not easy to do =2E BTW, knowing that Art xxxx racing in cherokee 140 used to carry his psgr in back seat, so when I did my first race I had 80 lb of batteries in bagage which gave me extra 5mph. Hope to get to bottom of this gross thing =2E Yhanks, Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: 6A Gross Wt
Date: Nov 22, 2015
I believe several folks with various RVs have calculated and gotten approved separate aerobatic, utility and normal gross wt limits. Vans tends to be very conservative with gross wt, especially because he wants the book figures to allow use of his farm strip at something like 600 ft. I don't think there is any need for input from Vans or other kit manufacturer for a DAR granting a higher gross wt if there is good logic behind that higher wt and it keeps the c.g. within an acceptable envelope. On 11/22/2015 6:37 AM, MLE wrote: > I've been flying my RV-6A for 5 years now and the gross wt is above > 1600, approved when inspected. I re-calculated what the GW limit > would be in the Utility category, based on the aerobatic wt published > by Vans of 1350# if my memory serves. Vans has commented that > consideration to the design limit of the gear should be considered. > So when operating above 1600# I'm very "gentle" with my landings, roll > out and taxi. Always keep the nose wheel up on landing and roll out. > Just saying......... > Marty N826ME > > From: <cheathco(at)cox.net <mailto:cheathco(at)cox.net>> > Subject: RV-List: 6A gross wt > > > something I have wondered about but never asked. My plane builder > listed th > e GW at 1650, empty is 1080, but I had seen other ones at 1750. I have > been > told the 6a has safely carried up to 1850, even tho GW at 1750. I > once unk > nowingly carried a psg who later told me he weighed 235lb, didn't look it, > but landed much harder that usual. I usually carry 200 lb psr max with > full > fuel and min baggage. Over that I usually carry 3/4 to 1/2 fuel. > as a mater of fact I have not had anyone with me over 150 lb for past > 2 yea > rs.. I have weighed 185 for several years. And at 75 that is not easy > to do > =2E BTW, knowing that Art xxxx racing in cherokee 140 used to carry his > psgr in back seat, so when I did my first race I had 80 lb of batteries in > bagage which gave me extra 5mph. Hope to get to bottom of this gross > thing > =2E Yhanks, Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 22, 2015
Given the wild variation in RV configurations, I.e. engine / prop combinatio ns, EW / MGW, etc. and the fact the CFI giving the BFR has no clue because t here is no "official" published information, the best glide speed is whatev er you tell your CFI. Have fun with the BFR. Reuven CFII. Sent from my I doohickey > On Nov 21, 2015, at 3:12 PM, RV6 Flyer wrote: > > On my RV-6, Best Glide and Best Rate of climb are the same. 78 KIAS is w hat works best in my RV-6. > > > >> On 11-21-2015 5:23 PM, cheathco(at)cox.net wrote: >> When I first got Tweetybird 11 yrs ago I experimented with various best g lide speeds, prety much thought 80mph best. I have flight review coming up, n eed to know if that is number most use ? Thanks Charlie >> This email has been sent from a virus-free computer protected by Av ast. >> www.avast.com > ________________________________________________________________________________
Date: Nov 22, 2015
I did a fair amount of glide testing on my 6 (engine idling, full fuel-1289lbs). After a good deal of data analysis and curve fitting, my data indicated the speed for minimum descent rate is 67 knots and for maximum range is 89 knots. In order to keep things simple, I use a figure of merit of 85 knots. Warren From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Reuven Sent: Sunday, November 22, 2015 10:35 AM Subject: Re: RV-List: Best gliud, 6A Given the wild variation in RV configurations, I.e. engine / prop combinations, EW / MGW, etc. and the fact the CFI giving the BFR has no clue because there is no "official" published information, the best glide speed is whatever you tell your CFI. Have fun with the BFR. Reuven CFII. Sent from my I doohickey On Nov 21, 2015, at 3:12 PM, RV6 Flyer wrote: On my RV-6, Best Glide and Best Rate of climb are the same. 78 KIAS is what works best in my RV-6. On 11-21-2015 5:23 PM, cheathco(at)cox.net wrote: When I first got Tweetybird 11 yrs ago I experimented with various best glide speeds, prety much thought 80mph best. I have flight review coming up, need to know if that is number most use ? Thanks Charlie This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Date: Nov 22, 2015
Date: Nov 22, 2015
In my RV-6A at my all-up cross-country weight of 1800 lbs, and 2550 rpm (pr op pulled back a bit due to rpm prop restriction), with a 180 hp 0-360-A1A and Hartzell blended airfoil prop, I find that my best rate of climb is abo ut 120 knots. I find that the short, broad cord wing has considerable indu ced drag if I try to fly slower (higher AOA) when I am heavy. Plus any tim e the temps are warm I need that kind of airspeed for engine cooling in a p rolonged climb to cruise altitude. Depending on air temperature, this resu lts in a rate of climb of anywhere from 600 fpm on a 90 degree day to about 1300 feet per minute on a 40 degree day. CHTs stay in the green, but when I am IFR, obstacle clearance must be paid attention to. 600 fpm at 120 k nots is only 300 feet per nautical mile. LeRoy Johnston RV-6A Esperanza, 970 hours. -----Original Message----- From: Charlie England <ceengland7(at)gmail.com> Sent: Sat, Nov 21, 2015 11:17 pm Subject: Re: RV-List: 6A gross wt Unless there has been a very recent change in the regs, the owner can raise gross weight by treating it as a major modification. Depending on which version of operating limitations are on the plane, it could be as simple as logging a return to phase one, flying 5 hrs of tests at the increased gross weight, and logging the successful results with a return to phase two (normal operation). Newer versions require notifying the local FSDO & getting their approval for the proposed test area (which might well be the same as the original test area). Not saying anyone should; just that it can be done. As mentioned, there are lots of 6's & 6A's with higher than 1600 lb gross weights in their oplims. Tangentially related to the subject of best glide, Van once wrote an article about best climb rate in the short wing RV's. He indicated that due to increased induced drag of the low aspect ratio wing at low airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere between around 90 mph & 130 mph (rough numbers from my flaky memory). His suggestion was for normal (not obstacle clearance) climb to be at around 130 mph because the rate would be the same but a lot more ground could be covered. I've never bothered to test it, but it seems reasonable that a slightly higher speed might extend the *range* of a glide, as well. Charlie On 11/21/2015 8:33 PM, Kelly McMullen wrote: > > As I understand it, you are pretty much stuck with what the original > builder asked for. I don't know what a DAR would have to do to get you > a changed gross wt. > > On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >> something I have wondered about but never asked. My plane builder >> listed the GW at 1650, empty is 1080, but I had seen other ones at >> 1750. I have been told the 6a has safely carried up to 1850, even tho >> GW at 1750. I once unknowingly carried a psg who later told me he >> weighed 235lb, didn=99t look it, but landed much harder that usual . I >> usually carry 200 lb psr max with full fuel and min baggage. Over >> that I usually carry 3/4 to 1/2 fuel. >> as a mater of fact I have not had anyone with me over 150 lb for past >> 2 years.. I have weighed 185 for several years. And at 75 that is not >> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >> cherokee 140 used to carry his psgr in back seat, so when I did my >> first race I had 80 lb of batteries in bagage which gave me extra >> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >> >> This email has been sent from a virus-free computer protected by >> Avast. >> www.avast.com >> >> >> > ________________________________________________________________________________
Date: Nov 22, 2015
What determines the gross weight of a homebuilt aircraft? Here is what EAA has to say: http://www.eaa.org/en/eaa/aviation-communities-and-interests/homebuilt-aircraft-and-homebuilt-aircraft-kits/frequently-asked-questions/gross-weight Copy/Paste from the above link: "From a regulatory standpoint, the builder of a homebuilt is in fact the "manufacturer" of that individual aircraft, and is allowed to set the weight limits, including gross weight, anyplace he/she cares to." ________________________________________ From: owner-rv-list-server(at)matronics.com <owner-rv-list-server(at)matronics.com> on behalf of Charlie England Sent: Sunday, November 22, 2015 4:14 AM Subject: Re: RV-List: 6A gross wt Unless there has been a very recent change in the regs, the owner can raise gross weight by treating it as a major modification. Depending on which version of operating limitations are on the plane, it could be as simple as logging a return to phase one, flying 5 hrs of tests at the increased gross weight, and logging the successful results with a return to phase two (normal operation). Newer versions require notifying the local FSDO & getting their approval for the proposed test area (which might well be the same as the original test area). Not saying anyone should; just that it can be done. As mentioned, there are lots of 6's & 6A's with higher than 1600 lb gross weights in their oplims. Tangentially related to the subject of best glide, Van once wrote an article about best climb rate in the short wing RV's. He indicated that due to increased induced drag of the low aspect ratio wing at low airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere between around 90 mph & 130 mph (rough numbers from my flaky memory). His suggestion was for normal (not obstacle clearance) climb to be at around 130 mph because the rate would be the same but a lot more ground could be covered. I've never bothered to test it, but it seems reasonable that a slightly higher speed might extend the *range* of a glide, as well. Charlie On 11/21/2015 8:33 PM, Kelly McMullen wrote: > > As I understand it, you are pretty much stuck with what the original > builder asked for. I don't know what a DAR would have to do to get you > a changed gross wt. > > On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >> something I have wondered about but never asked. My plane builder >> listed the GW at 1650, empty is 1080, but I had seen other ones at >> 1750. I have been told the 6a has safely carried up to 1850, even tho >> GW at 1750. I once unknowingly carried a psg who later told me he >> weighed 235lb, didnt look it, but landed much harder that usual. I >> usually carry 200 lb psr max with full fuel and min baggage. Over >> that I usually carry 3/4 to 1/2 fuel. >> as a mater of fact I have not had anyone with me over 150 lb for past >> 2 years.. I have weighed 185 for several years. And at 75 that is not >> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >> cherokee 140 used to carry his psgr in back seat, so when I did my >> first race I had 80 lb of batteries in bagage which gave me extra >> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >> >> This email has been sent from a virus-free computer protected by >> Avast. >> www.avast.com >> >> >> > ________________________________________________________________________________
Date: Nov 22, 2015
Correct and it behooves the manufacturer to have actually tested the claime d weight condition and found it to be reasonable. I believe that the origi nal RV-6A airframe is pretty robust. The 6 spar is good for 11g and the ge ar is good for 6g at the Van's claimed gross weight. IMO probably the weak est part of the airframe short of the landing gear is the horizontal stab, so don't go doing high g pullups or outside loops. The aircraft at any weight could be prone to failure of any element if prop er precautions are not taken (see Ralph Nader's "Unsafe and any Speed" and the story of failure of Van's own RV-8 at the hands of a potential buyer). Safety margin needs to be considered and a reasonable level of care taken in all flying endeavors. (he says, as if preaching to the choir...) -GV -----Original Message----- From: RV6 Flyer <rv6_flyer(at)hotmail.com> Sent: Sun, Nov 22, 2015 1:51 pm Subject: Re: RV-List: 6A gross wt What determines the gross weight of a homebuilt aircraft? Here is what EAA has to say: http://www.eaa.org/en/eaa/aviation-communities-and-interests/homebuilt-airc raft-and-homebuilt-aircraft-kits/frequently-asked-questions/gross-weight Copy/Paste from the above link: "From a regulatory standpoint, the builder of a homebuilt is in fact the "m anufacturer" of that individual aircraft, and is allowed to set the weight limits, including gross weight, anyplace he/she cares to." ________________________________________ From: owner-rv-list-server(at)matronics.com <owner-rv-list-server(at)matronics.co m> on behalf of Charlie England Sent: Sunday, November 22, 2015 4:14 AM Subject: Re: RV-List: 6A gross wt Unless there has been a very recent change in the regs, the owner can raise gross weight by treating it as a major modification. Depending on which version of operating limitations are on the plane, it could be as simple as logging a return to phase one, flying 5 hrs of tests at the increased gross weight, and logging the successful results with a return to phase two (normal operation). Newer versions require notifying the local FSDO & getting their approval for the proposed test area (which might well be the same as the original test area). Not saying anyone should; just that it can be done. As mentioned, there are lots of 6's & 6A's with higher than 1600 lb gross weights in their oplims. Tangentially related to the subject of best glide, Van once wrote an article about best climb rate in the short wing RV's. He indicated that due to increased induced drag of the low aspect ratio wing at low airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere between around 90 mph & 130 mph (rough numbers from my flaky memory). His suggestion was for normal (not obstacle clearance) climb to be at around 130 mph because the rate would be the same but a lot more ground could be covered. I've never bothered to test it, but it seems reasonable that a slightly higher speed might extend the *range* of a glide, as well. Charlie On 11/21/2015 8:33 PM, Kelly McMullen wrote: > > As I understand it, you are pretty much stuck with what the original > builder asked for. I don't know what a DAR would have to do to get you > a changed gross wt. > > On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >> something I have wondered about but never asked. My plane builder >> listed the GW at 1650, empty is 1080, but I had seen other ones at >> 1750. I have been told the 6a has safely carried up to 1850, even tho >> GW at 1750. I once unknowingly carried a psg who later told me he >> weighed 235lb, didn=99t look it, but landed much harder that usual . I >> usually carry 200 lb psr max with full fuel and min baggage. Over >> that I usually carry 3/4 to 1/2 fuel. >> as a mater of fact I have not had anyone with me over 150 lb for past >> 2 years.. I have weighed 185 for several years. And at 75 that is not >> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >> cherokee 140 used to carry his psgr in back seat, so when I did my >> first race I had 80 lb of batteries in bagage which gave me extra >> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >> >> This email has been sent from a virus-free computer protected by >> Avast. >> www.avast.com >> >> >> > ________________________________________________________________________________
Date: Nov 22, 2015
I think we all agree that a builder can request whatever gross wt they want from DAR. They need to show calculated W&B for several loading scenarios to show they can stay within the c.g. limits. DAR will use his judgement in how much he will go above kit maker's recommendation. What is not so clear is what it takes to get a revised gross wt later, after say Phase I, and who can approve such a change. On 11/22/2015 2:49 PM, RV6 Flyer wrote: > > What determines the gross weight of a homebuilt aircraft? > Here is what EAA has to say: > > http://www.eaa.org/en/eaa/aviation-communities-and-interests/homebuilt-aircraft-and-homebuilt-aircraft-kits/frequently-asked-questions/gross-weight > > Copy/Paste from the above link: > "From a regulatory standpoint, the builder of a homebuilt is in fact the "manufacturer" of that individual aircraft, and is allowed to set the weight limits, including gross weight, anyplace he/she cares to." > > > ________________________________________ > From: owner-rv-list-server(at)matronics.com <owner-rv-list-server(at)matronics.com> on behalf of Charlie England > Sent: Sunday, November 22, 2015 4:14 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: 6A gross wt > > > Unless there has been a very recent change in the regs, the owner can > raise gross weight by treating it as a major modification. Depending on > which version of operating limitations are on the plane, it could be as > simple as logging a return to phase one, flying 5 hrs of tests at the > increased gross weight, and logging the successful results with a return > to phase two (normal operation). Newer versions require notifying the > local FSDO & getting their approval for the proposed test area (which > might well be the same as the original test area). > > Not saying anyone should; just that it can be done. As mentioned, there > are lots of 6's & 6A's with higher than 1600 lb gross weights in their > oplims. > > Tangentially related to the subject of best glide, Van once wrote an > article about best climb rate in the short wing RV's. He indicated that > due to increased induced drag of the low aspect ratio wing at low > airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere > between around 90 mph & 130 mph (rough numbers from my flaky memory). > His suggestion was for normal (not obstacle clearance) climb to be at > around 130 mph because the rate would be the same but a lot more ground > could be covered. I've never bothered to test it, but it seems > reasonable that a slightly higher speed might extend the *range* of a > glide, as well. > > Charlie > > > On 11/21/2015 8:33 PM, Kelly McMullen wrote: >> >> As I understand it, you are pretty much stuck with what the original >> builder asked for. I don't know what a DAR would have to do to get you >> a changed gross wt. >> >> On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >>> something I have wondered about but never asked. My plane builder >>> listed the GW at 1650, empty is 1080, but I had seen other ones at >>> 1750. I have been told the 6a has safely carried up to 1850, even tho >>> GW at 1750. I once unknowingly carried a psg who later told me he >>> weighed 235lb, didnt look it, but landed much harder that usual. I >>> usually carry 200 lb psr max with full fuel and min baggage. Over >>> that I usually carry 3/4 to 1/2 fuel. >>> as a mater of fact I have not had anyone with me over 150 lb for past >>> 2 years.. I have weighed 185 for several years. And at 75 that is not >>> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >>> cherokee 140 used to carry his psgr in back seat, so when I did my >>> first race I had 80 lb of batteries in bagage which gave me extra >>> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >>> >>> This email has been sent from a virus-free computer protected by >>> Avast. >>> www.avast.com >>> >>> >>> > > ________________________________________________________________________________
Subject: Flt reveiw/ GW/best glide
Date: Nov 23, 2015
Thanks for all the usefull input to my inquiries. I did well on my FR, and we experimented with glide speeds and found 90 to 100 mph pretty much looke d the same, yielding 500/600 FPM. Visually it seemed we were covering a lot of ground as well. Re GW, I will leave it alone based on y'alls input. N ow I have to get into my radio problem. I started getting static on way bck to Instructors field and when coming in to Fayettville Drake, it got so ba d controler said it was nearly unreadable. Rec is ok tho. Chalie. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 23, 2015
I've been having an intermittent problem with transmitting. With mine it's I either transmit or I don't, not static. When it isn't working, mine sort of gives me a soft squeal and the transmit light stays off. So far I've checked the PTT switch and it's ground-ok, w/ 1 ohm resistance. I've also tried turning off the intercom, which will route the PTT output directly to the nav/com and bypass the intermcom (to eliminate the intercom as the problem). That isn't the problem either. I haven't determined what to do next. Intermittent problems are hard to resolve, but it sounds like yours is not intermittent but a real failure, which should be easier to track down. I would be interested in how you resolve the issue. Warren From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Monday, November 23, 2015 7:16 AM Subject: RV-List: Flt reveiw/ GW/best glide Thanks for all the usefull input to my inquiries. I did well on my FR, and we experimented with glide speeds and found 90 to 100 mph pretty much looked the same, yielding 500/600 FPM. Visually it seemed we were covering a lot of ground as well. Re GW, I will leave it alone based on y'alls input. Now I have to get into my radio problem. I started getting static on way bck to Instructors field and when coming in to Fayettville Drake, it got so bad controler said it was nearly unreadable. Rec is ok tho. Chalie. This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Date: Nov 23, 2015
-----Original Message----- From: Jhnstniii <jhnstniii(at)aol.com> Sent: Sun, Nov 22, 2015 3:48 pm Subject: Re: RV-List: 6A gross wt In my RV-6A at my all-up cross-country weight of 1800 lbs, and 2550 rpm (pr op pulled back a bit due to rpm prop restriction), with a 180 hp 0-360-A1A and Hartzell blended airfoil prop, I find that my best rate of climb is abo ut 120 knots. I find that the short, broad cord wing has considerable indu ced drag if I try to fly slower (higher AOA) when I am heavy. Plus any tim e the temps are warm I need that kind of airspeed for engine cooling in a p rolonged climb to cruise altitude. Depending on air temperature, this resu lts in a rate of climb of anywhere from 600 fpm on a 90 degree day to about 1300 feet per minute on a 40 degree day. CHTs stay in the green, but when I am IFR, obstacle clearance must be paid attention to. 600 fpm at 120 k nots is only 300 feet per nautical mile. LeRoy Johnston RV-6A Esperanza, 970 hours. -----Original Message----- From: Charlie England <ceengland7(at)gmail.com> Sent: Sat, Nov 21, 2015 11:17 pm Subject: Re: RV-List: 6A gross wt Unless there has been a very recent change in the regs, the owner can raise gross weight by treating it as a major modification. Depending on which version of operating limitations are on the plane, it could be as simple as logging a return to phase one, flying 5 hrs of tests at the increased gross weight, and logging the successful results with a return to phase two (normal operation). Newer versions require notifying the local FSDO & getting their approval for the proposed test area (which might well be the same as the original test area). Not saying anyone should; just that it can be done. As mentioned, there are lots of 6's & 6A's with higher than 1600 lb gross weights in their oplims. Tangentially related to the subject of best glide, Van once wrote an article about best climb rate in the short wing RV's. He indicated that due to increased induced drag of the low aspect ratio wing at low airspeeds, the 4/6/7/8 would climb at almost identical rates at anywhere between around 90 mph & 130 mph (rough numbers from my flaky memory). His suggestion was for normal (not obstacle clearance) climb to be at around 130 mph because the rate would be the same but a lot more ground could be covered. I've never bothered to test it, but it seems reasonable that a slightly higher speed might extend the *range* of a glide, as well. Charlie On 11/21/2015 8:33 PM, Kelly McMullen wrote: > > As I understand it, you are pretty much stuck with what the original > builder asked for. I don't know what a DAR would have to do to get you > a changed gross wt. > > On 11/21/2015 4:45 PM, cheathco(at)cox.net wrote: >> something I have wondered about but never asked. My plane builder >> listed the GW at 1650, empty is 1080, but I had seen other ones at >> 1750. I have been told the 6a has safely carried up to 1850, even tho >> GW at 1750. I once unknowingly carried a psg who later told me he >> weighed 235lb, didn=99t look it, but landed much harder that usual . I >> usually carry 200 lb psr max with full fuel and min baggage. Over >> that I usually carry 3/4 to 1/2 fuel. >> as a mater of fact I have not had anyone with me over 150 lb for past >> 2 years.. I have weighed 185 for several years. And at 75 that is not >> easy to do. Smile emoticon BTW, knowing that Art xxxx racing in >> cherokee 140 used to carry his psgr in back seat, so when I did my >> first race I had 80 lb of batteries in bagage which gave me extra >> 5mph. Hope to get to bottom of this gross thing. Yhanks, Charlie >> >> This email has been sent from a virus-free computer protected by >> Avast. >> www.avast.com >> >> >> > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Nov 23, 2015
First things to check: . Remove the radio from the rack, check rear connections (bent, off color), reset radio. . Make sure the power connections on the radio breaker(s) are tight and you have a good ground (I chased this exact problem too long before I found the power lead loose on the breaker screw). . Put an antenna analyzer on the radio end of the coax lead to the antenna. If nothing else, measure continuity on the antenna lead (no short between center pin and shield, no/low resistance between center pin and antenna itself). Wiggle the coax when doing this to see if you have an intermittent contact problem. Carl From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Warren Brecheisen Sent: Monday, November 23, 2015 8:30 AM Subject: RE: RV-List: Flt reveiw/ GW/best glide I've been having an intermittent problem with transmitting. With mine it's I either transmit or I don't, not static. When it isn't working, mine sort of gives me a soft squeal and the transmit light stays off. So far I've checked the PTT switch and it's ground-ok, w/ 1 ohm resistance. I've also tried turning off the intercom, which will route the PTT output directly to the nav/com and bypass the intermcom (to eliminate the intercom as the problem). That isn't the problem either. I haven't determined what to do next. Intermittent problems are hard to resolve, but it sounds like yours is not intermittent but a real failure, which should be easier to track down. I would be interested in how you resolve the issue. Warren From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net Sent: Monday, November 23, 2015 7:16 AM Subject: RV-List: Flt reveiw/ GW/best glide Thanks for all the usefull input to my inquiries. I did well on my FR, and we experimented with glide speeds and found 90 to 100 mph pretty much looked the same, yielding 500/600 FPM. Visually it seemed we were covering a lot of ground as well. Re GW, I will leave it alone based on y'alls input. Now I have to get into my radio problem. I started getting static on way bck to Instructors field and when coming in to Fayettville Drake, it got so bad controler said it was nearly unreadable. Rec is ok tho. Chalie. Image removed by sender. This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Date: Nov 23, 2015
Subject: Fund Raiser Behind By 22% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 22%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 24, 2015
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2015
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2015
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just three more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2015
Subject: Fund Raiser - Just Two Days Left! - Still Well Behind...
Dear Listers, There are just two more full days left in this year's List Fund Raiser. Over the last couple of weeks I have received some really nice comments from members on what the Lists have meant to them and I really appreciate the feedback! At this point, unfortunately, we are still well behind last year in total Contributions to support the continued operation of these services. I really want to keep providing these Lists and Forums to the home built community, but it takes resources. Since there's no advertising budget or deep pockets to keep the operation a float, it's *solely your generosity* during the yearly Fund Raiser that keeps things going. Please make a Contribution today so that I can keep the bills paid and the services and systems turned on. If you've been putting off showing your support for the Lists, now is the time to do it! To make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 USA Thank you in advance for your support! It is very much appreciated... Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2015
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 30, 2015
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 52, so don't remind me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 16, 2015
Subject: PBOR2
Cross posted from the Canard lists that I am also a member of..... In case anyone's been living under a rock, the Senate just passed S.571, Senator Inhofe's bill that would eliminate the 3rd class medical. That's right it's cleared committee and already passed the senate! This is a big deal for a lot of us, maybe you in a few years. I deal with a special issuance medical for a pretty minor issue and it's a hassle and expense every year. The next hurdle is the house (H.R. 1062) where it has 142 bipartisan cosponsors among the 435 members. If ever there was a good time to contact your representative it's now. Please take a minute a drop them a line. We don't want to lose this legislation this deep into the process. Here's a list of whose on board: http://www.aopa.org/Advocacy/Legislative-Affairs/Pilots-Bill-of-Rights-2 And a list of who is not: http://www.aopa.org/Advocacy/Legislative-Affairs/Non-CoSponsors-PBR2 And here's where you can contact your representative: http://govt.eaa.org/17422/support-pilots-bill-rights-2/ There, I've done everything I can to help! Please take a minute and help get this done! ________________________________________________________________________________
Date: Dec 17, 2015
Subject: Re: PBOR2
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Ralph... Thanks for posting this. PBOR2 is important milestone legislation that needs to pass. -chris stone On Wed, Dec 16, 2015 at 2:19 PM, Ralph E. Capen wrote: > > Cross posted from the Canard lists that I am also a member of..... > > > In case anyone's been living under a rock, the Senate just passed S.571, > Senator Inhofe's bill that would eliminate the 3rd class medical. That's > right it's cleared committee and already passed the senate! > This is a big deal for a lot of us, maybe you in a few years. I deal with > a special issuance medical for a pretty minor issue and it's a hassle and > expense every year. The next hurdle is the house (H.R. 1062) where it > has 142 bipartisan cosponsors among the 435 members. If ever there was a > good time to contact your representative it's now. Please take a minute a > drop them a line. We don't want to lose this legislation this deep into > the process. > Here's a list of whose on board: > http://www.aopa.org/Advocacy/Legislative-Affairs/Pilots-Bill-of-Rights-2 > > And a list of who is not: > http://www.aopa.org/Advocacy/Legislative-Affairs/Non-CoSponsors-PBR2 > > And here's where you can contact your representative: > http://govt.eaa.org/17422/support-pilots-bill-rights-2/ > > There, I've done everything I can to help! Please take a minute and help > get this done! > > ________________________________________________________________________________
Subject: RV pilots in San Diego?
Date: Dec 17, 2015
I am new to the San Diego area and looking to meet fellow RV pilots for flying and eventually buy one. -------- warbird and lover of all things that go fast and upside down! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=451007#451007 ________________________________________________________________________________
Date: Dec 18, 2015
Subject: Lycoming O-360 Fuel Flow Rate
I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? Thanks for the feedback, Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: Lycoming O-360 Fuel Flow Rate
Date: Dec 18, 2015
On 12/18/2015 4:38 PM, Matt Dralle wrote: > > > I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? > > I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? > > Thanks for the feedback, > > Matt > > - > Matt Dralle Never paid much attention to my flow when doing a static runup, but that doesn't sound too unreasonable. If CS & flat pitch, it won't take much power to get to 2400rpm. What's the MAP? You should be able to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is around 10 GPH, if leaned. Obviously lower fuel flow if you're under 24". I think that the FAA recommends 125% of max power flow if running a pump (150% for gravity feed). Max power flow would be (180 * .6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP per hour. So your electric pump flow sounds more than adequate. It's really odd that you didn't see any degraded performance when your flow went from 17 down to 9 gph in climbout, unless it's some sort of instrumentation issue giving false readings. Hard to explain two different flow monitors making the same error, but hard to explain the performance, too. :-) Having said that, if you were seeing 9gph in a full power (2700rpm, full rich, 29"MAP) before, and you're now seeing the same flow on the ground, with less than full throttle, flat pitch & 2400 rpm, then *something* must be better now. ________________________________________________________________________________
Date: Dec 18, 2015
While fuel flow numbers are good general indicators, EGT will tell you more. On takeoff at sea level you should see 1200-1300 EGT with 1250 optimal. If your fuel flow is too low EGT will go well above 1300. Assuming 180 hp version, Fuel flow for takeoff should be around 16-18 gph. Cruise at 75% should be 9-9.5 gph. On 12/18/2015 4:25 PM, Charlie England wrote: > > On 12/18/2015 4:38 PM, Matt Dralle wrote: >> >> >> I'm still chasing down this weird problem with low fuel flow rates on >> the RV-6. I've replaced the mechanical fuel pump and got a rebuilt >> 4-5 carburetor, both of which were well over do for >> replacement/overhaul anyway. I haven't put the cowling back on yet, >> but I did a static run up to about 2350-2400 and am seeing about >> 9gph, which seems low to me? >> >> I pulled the fuel line off the carburetor and turned the electric >> fuel pump on and saw about 21 GPH flow. Is that considered "normal" >> or too low? >> >> Thanks for the feedback, >> >> Matt >> >> - >> Matt Dralle > Never paid much attention to my flow when doing a static runup, but > that doesn't sound too unreasonable. If CS & flat pitch, it won't take > much power to get to 2400rpm. What's the MAP? You should be able to > use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is around 10 > GPH, if leaned. Obviously lower fuel flow if you're under 24". > > I think that the FAA recommends 125% of max power flow if running a > pump (150% for gravity feed). Max power flow would be (180 * > .6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP > per hour. So your electric pump flow sounds more than adequate. > > It's really odd that you didn't see any degraded performance when your > flow went from 17 down to 9 gph in climbout, unless it's some sort of > instrumentation issue giving false readings. Hard to explain two > different flow monitors making the same error, but hard to explain the > performance, too. :-) > > Having said that, if you were seeing 9gph in a full power (2700rpm, > full rich, 29"MAP) before, and you're now seeing the same flow on the > ground, with less than full throttle, flat pitch & 2400 rpm, then > *something* must be better now. > > ________________________________________________________________________________
Date: Dec 18, 2015
135 hp & 9 gph would be .4 lbs per hp per hour. That's pretty impressive, for an air cooled gasoline engine with 8.5-1 compression. What do the Lyc charts say? On 12/18/2015 6:28 PM, Kelly McMullen wrote: > > While fuel flow numbers are good general indicators, EGT will tell you > more. On takeoff at sea level you should see 1200-1300 EGT with 1250 > optimal. If your fuel flow is too low EGT will go well above 1300. > Assuming 180 hp version, Fuel flow for takeoff should be around 16-18 > gph. Cruise at 75% should be 9-9.5 gph. > > On 12/18/2015 4:25 PM, Charlie England wrote: >> >> On 12/18/2015 4:38 PM, Matt Dralle wrote: >>> >>> >>> I'm still chasing down this weird problem with low fuel flow rates >>> on the RV-6. I've replaced the mechanical fuel pump and got a >>> rebuilt 4-5 carburetor, both of which were well over do for >>> replacement/overhaul anyway. I haven't put the cowling back on yet, >>> but I did a static run up to about 2350-2400 and am seeing about >>> 9gph, which seems low to me? >>> >>> I pulled the fuel line off the carburetor and turned the electric >>> fuel pump on and saw about 21 GPH flow. Is that considered "normal" >>> or too low? >>> >>> Thanks for the feedback, >>> >>> Matt >>> >>> - >>> Matt Dralle >> Never paid much attention to my flow when doing a static runup, but >> that doesn't sound too unreasonable. If CS & flat pitch, it won't >> take much power to get to 2400rpm. What's the MAP? You should be able >> to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is >> around 10 GPH, if leaned. Obviously lower fuel flow if you're under 24". >> >> I think that the FAA recommends 125% of max power flow if running a >> pump (150% for gravity feed). Max power flow would be (180 * >> .6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP >> per hour. So your electric pump flow sounds more than adequate. >> >> It's really odd that you didn't see any degraded performance when >> your flow went from 17 down to 9 gph in climbout, unless it's some >> sort of instrumentation issue giving false readings. Hard to explain >> two different flow monitors making the same error, but hard to >> explain the performance, too. :-) >> >> Having said that, if you were seeing 9gph in a full power (2700rpm, >> full rich, 29"MAP) before, and you're now seeing the same flow on the >> ground, with less than full throttle, flat pitch & 2400 rpm, then >> *something* must be better now. >> >> ________________________________________________________________________________
Date: Dec 18, 2015
EGT varies significantly depending on where the probes are in relation to the flange, and also radially. EGT is most valuable as a comparison to the history ..... significant change in EGT will alert you to a change in that cylinders operation, but the actual number (historically) really doesn't tell you much. Properly calibrated FF and a MP gauge will tell you far more about power. Linn (IMHO) On 12/18/2015 7:28 PM, Kelly McMullen wrote: > > While fuel flow numbers are good general indicators, EGT will tell you > more. On takeoff at sea level you should see 1200-1300 EGT with 1250 > optimal. If your fuel flow is too low EGT will go well above 1300. > Assuming 180 hp version, Fuel flow for takeoff should be around 16-18 > gph. Cruise at 75% should be 9-9.5 gph. > > On 12/18/2015 4:25 PM, Charlie England wrote: >> >> On 12/18/2015 4:38 PM, Matt Dralle wrote: >>> >>> >>> I'm still chasing down this weird problem with low fuel flow rates >>> on the RV-6. I've replaced the mechanical fuel pump and got a >>> rebuilt 4-5 carburetor, both of which were well over do for >>> replacement/overhaul anyway. I haven't put the cowling back on yet, >>> but I did a static run up to about 2350-2400 and am seeing about >>> 9gph, which seems low to me? >>> >>> I pulled the fuel line off the carburetor and turned the electric >>> fuel pump on and saw about 21 GPH flow. Is that considered "normal" >>> or too low? >>> >>> Thanks for the feedback, >>> >>> Matt >>> >>> - >>> Matt Dralle >> Never paid much attention to my flow when doing a static runup, but >> that doesn't sound too unreasonable. If CS & flat pitch, it won't >> take much power to get to 2400rpm. What's the MAP? You should be able >> to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is >> around 10 GPH, if leaned. Obviously lower fuel flow if you're under 24". >> >> I think that the FAA recommends 125% of max power flow if running a >> pump (150% for gravity feed). Max power flow would be (180 * >> .6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP >> per hour. So your electric pump flow sounds more than adequate. >> >> It's really odd that you didn't see any degraded performance when >> your flow went from 17 down to 9 gph in climbout, unless it's some >> sort of instrumentation issue giving false readings. Hard to explain >> two different flow monitors making the same error, but hard to >> explain the performance, too. :-) >> >> Having said that, if you were seeing 9gph in a full power (2700rpm, >> full rich, 29"MAP) before, and you're now seeing the same flow on the >> ground, with less than full throttle, flat pitch & 2400 rpm, then >> *something* must be better now. >> >> >> >> > > ________________________________________________________________________________
Date: Dec 18, 2015
I don't disagree with your points in general, but they are not particularly relevant for this situation. 1. His fuel flow has demonstrated to be unreliable, so is not properly calibrated. 2. At full power installation variations are minimized due to the velocity and volume of exhaust, compared to cruise settings. 3. 1200-1300 are very reliable numbers. Whether it varies 25 degrees one way or the other is not important. It is important that it be within that 100 degree range to indicate combustion approximately 150-200 ROP. Given he does not know if his fuel flow is working, only the EGT will confirm fuel flow. The actual temp will vary from engine to engine and with OAT. That is why it is a range, not a single number. He wants to know if his fuel flow is in the ballpark to safely operate the engine, not if it is optimal. On 12/18/2015 7:55 PM, Linn Walters wrote: > > EGT varies significantly depending on where the probes are in relation > to the flange, and also radially. EGT is most valuable as a > comparison to the history ..... significant change in EGT will alert > you to a change in that cylinders operation, but the actual number > (historically) really doesn't tell you much. Properly calibrated FF > and a MP gauge will tell you far more about power. > Linn (IMHO) > > On 12/18/2015 7:28 PM, Kelly McMullen wrote: >> >> While fuel flow numbers are good general indicators, EGT will tell >> you more. On takeoff at sea level you should see 1200-1300 EGT with >> 1250 optimal. If your fuel flow is too low EGT will go well above 1300. >> Assuming 180 hp version, Fuel flow for takeoff should be around 16-18 >> gph. Cruise at 75% should be 9-9.5 gph. >> >> On 12/18/2015 4:25 PM, Charlie England wrote: >>> >>> On 12/18/2015 4:38 PM, Matt Dralle wrote: >>>> >>>> >>>> I'm still chasing down this weird problem with low fuel flow rates >>>> on the RV-6. I've replaced the mechanical fuel pump and got a >>>> rebuilt 4-5 carburetor, both of which were well over do for >>>> replacement/overhaul anyway. I haven't put the cowling back on >>>> yet, but I did a static run up to about 2350-2400 and am seeing >>>> about 9gph, which seems low to me? >>>> >>>> I pulled the fuel line off the carburetor and turned the electric >>>> fuel pump on and saw about 21 GPH flow. Is that considered >>>> "normal" or too low? >>>> >>>> Thanks for the feedback, >>>> >>>> Matt >>>> >>>> - >>>> Matt Dralle >>> Never paid much attention to my flow when doing a static runup, but >>> that doesn't sound too unreasonable. If CS & flat pitch, it won't >>> take much power to get to 2400rpm. What's the MAP? You should be >>> able to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 is >>> around 10 GPH, if leaned. Obviously lower fuel flow if you're under >>> 24". >>> >>> I think that the FAA recommends 125% of max power flow if running a >>> pump (150% for gravity feed). Max power flow would be (180 * >>> .6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP >>> per hour. So your electric pump flow sounds more than adequate. >>> >>> It's really odd that you didn't see any degraded performance when >>> your flow went from 17 down to 9 gph in climbout, unless it's some >>> sort of instrumentation issue giving false readings. Hard to explain >>> two different flow monitors making the same error, but hard to >>> explain the performance, too. :-) >>> >>> Having said that, if you were seeing 9gph in a full power (2700rpm, >>> full rich, 29"MAP) before, and you're now seeing the same flow on >>> the ground, with less than full throttle, flat pitch & 2400 rpm, >>> then *something* must be better now. >>> >>> >>> >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 19, 2015
We really do agree ..... for Matt's case. Too many listers (me included :-P ) read posts and take the content as being applicable in a broad sense. I didn't want a whole new thread to result because others aren't getting EGTs in that specific range. I have friends that are completely anal about their EGT readings ..... especially when they have a new (to them) engine monitoring system. Linn On 12/19/2015 12:05 AM, Kelly McMullen wrote: > > I don't disagree with your points in general, but they are not > particularly relevant for this situation. > 1. His fuel flow has demonstrated to be unreliable, so is not properly > calibrated. > 2. At full power installation variations are minimized due to the > velocity and volume of exhaust, compared to cruise settings. > 3. 1200-1300 are very reliable numbers. Whether it varies 25 degrees > one way or the other is not important. It is important that it be > within that 100 degree range to indicate combustion approximately > 150-200 ROP. Given he does not know if his fuel flow is working, only > the EGT will confirm fuel flow. > The actual temp will vary from engine to engine and with OAT. That is > why it is a range, not a single number. He wants to know if his fuel > flow is in the ballpark to safely operate the engine, not if it is > optimal. > > On 12/18/2015 7:55 PM, Linn Walters wrote: >> >> EGT varies significantly depending on where the probes are in >> relation to the flange, and also radially. EGT is most valuable as a >> comparison to the history ..... significant change in EGT will alert >> you to a change in that cylinders operation, but the actual number >> (historically) really doesn't tell you much. Properly calibrated FF >> and a MP gauge will tell you far more about power. >> Linn (IMHO) >> >> On 12/18/2015 7:28 PM, Kelly McMullen wrote: >>> >>> While fuel flow numbers are good general indicators, EGT will tell >>> you more. On takeoff at sea level you should see 1200-1300 EGT with >>> 1250 optimal. If your fuel flow is too low EGT will go well above 1300. >>> Assuming 180 hp version, Fuel flow for takeoff should be around >>> 16-18 gph. Cruise at 75% should be 9-9.5 gph. >>> >>> On 12/18/2015 4:25 PM, Charlie England wrote: >>>> >>>> On 12/18/2015 4:38 PM, Matt Dralle wrote: >>>>> >>>>> >>>>> I'm still chasing down this weird problem with low fuel flow rates >>>>> on the RV-6. I've replaced the mechanical fuel pump and got a >>>>> rebuilt 4-5 carburetor, both of which were well over do for >>>>> replacement/overhaul anyway. I haven't put the cowling back on >>>>> yet, but I did a static run up to about 2350-2400 and am seeing >>>>> about 9gph, which seems low to me? >>>>> >>>>> I pulled the fuel line off the carburetor and turned the electric >>>>> fuel pump on and saw about 21 GPH flow. Is that considered >>>>> "normal" or too low? >>>>> >>>>> Thanks for the feedback, >>>>> >>>>> Matt >>>>> >>>>> - >>>>> Matt Dralle >>>> Never paid much attention to my flow when doing a static runup, but >>>> that doesn't sound too unreasonable. If CS & flat pitch, it won't >>>> take much power to get to 2400rpm. What's the MAP? You should be >>>> able to use Lyc's power charts to see MAP/rpm/power. 75% on a 180 >>>> is around 10 GPH, if leaned. Obviously lower fuel flow if you're >>>> under 24". >>>> >>>> I think that the FAA recommends 125% of max power flow if running a >>>> pump (150% for gravity feed). Max power flow would be (180 * >>>> .6)/6=18GPH. That would assume a very rich mixture of .6 lbs per HP >>>> per hour. So your electric pump flow sounds more than adequate. >>>> >>>> It's really odd that you didn't see any degraded performance when >>>> your flow went from 17 down to 9 gph in climbout, unless it's some >>>> sort of instrumentation issue giving false readings. Hard to >>>> explain two different flow monitors making the same error, but hard >>>> to explain the performance, too. :-) >>>> >>>> Having said that, if you were seeing 9gph in a full power (2700rpm, >>>> full rich, 29"MAP) before, and you're now seeing the same flow on >>>> the ground, with less than full throttle, flat pitch & 2400 rpm, >>>> then *something* must be better now. >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 19, 2015
Hi Matt, It wouldn't be too hard to check the calibration of your fuel flow gauge including the sensor. Could you make a restricted fitting so that it flows about 10 to 14 GPH using the electric pump? See how long it takes to fill a 1 quart jar while observing the fuel flow meter. Divide 900 by the time in seconds for GPH. 60 seconds would be 15 GPH. Compare the calculated GPH with what your fuel flow gauge read during the test. Be careful, obviously! Just a wild idea, so take it for what its worth! I know someone (can't name the person!) who put the sensor in backwards while being distracted by a visitor. The readings were low! Dan RV-7A 766DH -- flying since 2004 In a message dated 12/18/2015 5:42:20 P.M. Eastern Standard Time, dralle(at)matronics.com writes: I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? Thanks for the feedback, Matt ________________________________________________________________________________
Date: Dec 19, 2015
Thank you to everyone that responded!! There were some great comments that got me going down the right path. Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? Thanks again for the great feedback! Matt Dralle At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: >I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? > >I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? > >Thanks for the feedback, > >Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Dec 19, 2015
For me, in the same situation,(in the pattern adding power from idle) this sag at 1700 has been very common. I have 2100+ hours on my O-360 precision carburetor RV-6. Always unsettling but never became a more serious issue. Ken Cantrell -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Saturday, December 19, 2015 12:45 PM rv6-list(at)matronics.com; rv10-list(at)matronics.com Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate Thank you to everyone that responded!! There were some great comments that got me going down the right path. Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? Thanks again for the great feedback! Matt Dralle At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: >I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? > >I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? > >Thanks for the feedback, > >Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Dec 19, 2015
Subject: Auction For P113 eMag To Support Matronics List Fund Raiser
Dear Listers, Bob Nuckolls of the AeroElectric fame has generously put a new eMag P113 electronic 4-cylinder mag up for sale on EBay. Bob has pledged to donate all of the proceeds from this auction in support of this year's Matronics Fund Raiser. If you are in the market for one of these great electronic ignitions (I have two eMags on my RV-8 and love them), please bid on this one! http://www.ebay.com/itm/151920582478 Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 19, 2015
Subject: 2015 List of Contributors
Dear Listers, The 2015 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, and George for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com George Race - Race Consulting - http://www.mrrace.com And finally, I'm proud to present The 2015 Fund Raiser List of Contributors: http://www.matronics.com/loc/2015.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Dec 19, 2015
Trying leaving the mixture a little lean in the pattern and I think you will find the issue stops happening. LeRoy Johnston RV-6A Esperanza 1000 hours. Sent from my iPhone > On Dec 19, 2015, at 4:30 PM, "Ken Cantrell" wrote: > > > For me, in the same situation,(in the pattern adding power from idle) this > sag at 1700 has been very common. I have 2100+ hours on my O-360 precision > carburetor RV-6. Always unsettling but never became a more serious issue. > > Ken Cantrell > > > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Saturday, December 19, 2015 12:45 PM > To: rv-list(at)matronics.com; LycomingEngines-list(at)matronics.com; > rv6-list(at)matronics.com; rv10-list(at)matronics.com > Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate > > > Thank you to everyone that responded!! There were some great comments that > got me going down the right path. > > Last night I got the cowling back on and took the RV-6 out on the runway and > ran it up to full power with the intent of carefully watching the flow rate > and aborting the take off if the flow wasn't sufficiently high enough. I'm > happy to report that the flow rate climbed nicely up though the teens as my > takeoff roll progressed. I lifted off around 15-16 gph and decided to take > it around the pattern. As I climbed through the crosswind to downwind turn > I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs > were low 1300's. After a few more loops around the pattern everything > seemed to be working as expected. I took it out of the pattern and dialed > it into my normal cruse configuration which is typically 75% power at 2250 > RPM and leaned to about 1425 on the hottest EGT. Everything sounded and > felt fine. Flow was right at 9.5 GPH per usual. > > The only weird thing I noticed was at about 1700 RPM. When I turn from > Downwind to Base and go from idle to about 2000 RPM like I usually do, right > about 1700 RPM the engine kind of sags and then picks back up. It is very > repeatable. Strangely there is no sag on the ground after a touch and go > when I push the throttle in fast going from idle to full power anymore like > there was with the old carb. > > Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on > the carb for this specifically? > > Thanks again for the great feedback! > > Matt Dralle > > > > At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: > >> I'm still chasing down this weird problem with low fuel flow rates on the > RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 > carburetor, both of which were well over do for replacement/overhaul anyway. > I haven't put the cowling back on yet, but I did a static run up to about > 2350-2400 and am seeing about 9gph, which seems low to me? >> >> I pulled the fuel line off the carburetor and turned the electric fuel pump > on and saw about 21 GPH flow. Is that considered "normal" or too low? >> >> Thanks for the feedback, >> >> Matt > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 210+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > > > > > > > > ________________________________________________________________________________
Date: Dec 20, 2015
I see your problem; you're powering up for landing. :-) I know that many will disagree with this (having been taught by airline pilot wannabe's instead of career flight instructors/freight dogs), but my primary instructor wouldn't let me touch the throttle after going to idle on downwind. His contention (which I agree with) was that if you ever have an engine out, how will you land the plane? You'll have no experience at the task. By staying at idle, it forces you to properly plan the pattern turns and approach while compensating for wind, etc. It will also make you adept at staying high (options) & slipping to your 'spot' on the runway. Yes, I know that a c/s prop has higher drag. I learned to fly in a f/p Luscombe, and used the same technique when I started flying a f/p T-18, and again in a 200hp, c/s, retract gear Swift (an elevator on final, compared to an RV). And again when I started flying RVs. Just a thought... Charlie On 12/19/2015 2:44 PM, Matt Dralle wrote: > > Thank you to everyone that responded!! There were some great comments that got me going down the right path. > > Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. > > The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. > > Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? > > Thanks again for the great feedback! > > Matt Dralle > > > At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: > >> I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? >> >> I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? >> >> Thanks for the feedback, >> >> Matt > - > Matt Dralle > > ________________________________________________________________________________
From: Steve Senegal <Ssenegal(at)sanbrunocable.com>
Date: Dec 20, 2015
I've been following this issue with interest but maybe I missed something. What fixed the problem? Steve 650.346.6967 Sent from my iPhone between flights. > On Dec 19, 2015, at 12:44, Matt Dralle wrote: > > > Thank you to everyone that responded!! There were some great comments that got me going down the right path. > > Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. > > The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. > > Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? > > Thanks again for the great feedback! > > Matt Dralle > > > > At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: > >> I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? >> >> I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? >> >> Thanks for the feedback, >> >> Matt > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 210+ Hours TTSN - Version 2.0 Now Flying! > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 300+ Hours - Full Flyer Mode! > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > > > > ________________________________________________________________________________
Date: Dec 21, 2015
So what did you do to fix the problem Matt? Harry Crosby ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Saturday, December 19, 2015 12:44:41 PM Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate Thank you to everyone that responded!! There were some great comments that got me going down the right path. Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? Thanks again for the great feedback! Matt Dralle At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: >I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? > >I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? > >Thanks for the feedback, > >Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Dec 22, 2015
Well, it was probably the fuel pump. I think my flow rates right after replacing the fuel pump (but before I replaced the carb) were probably alright as they were similar to what I saw after the new carb. But, it was time for a new carb anyway, so I guess it worked out. Btw, as if all of this debacle wasn't frustrating enough, last weekend while trying to test all of this, the battery went dead. Checking the logs it was 36 months ago since I replaced it the last time. Guess that's about right. Sigh. Is it time to fly it yet? I've been working on it enough lately. ;-) Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. At 10:24 AM 12/21/2015 Monday, you wrote: >So what did you do to fix the problem Matt? > >Harry Crosby > > >---------- >From: "Matt Dralle" <dralle(at)matronics.com> >To: "RV-List" , LycomingEngines-list(at)matronics.com, rv6-list(at)matronics.com, rv10-list(at)matronics.com >Sent: Saturday, December 19, 2015 12:44:41 PM >Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate > > >Thank you to everyone that responded!! There were some great comments that got me going down the right path. > >Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. > >The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. > >Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? > >Thanks again for the great feedback! > >Matt Dralle > > >At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: > >>I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? >> >>I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? >> >>Thanks for the feedback, >> >>Matt > >- >Matt Dralle ________________________________________________________________________________
Date: Dec 22, 2015
It's just the engineer in me, but I always like to do post mortems with failed components. In the case of the pump, I would want to understand what in the pump caused the blockage or failure to pump per spec. In the case of the carb I would want to understand if the main jet, float, filter or ??? were hosed. -GV -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Tue, Dec 22, 2015 12:21 pm Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate Well, it was probably the fuel pump. I think my flow rates right after replacing the fuel pump (but before I replaced the carb) were probably alright as they were similar to what I saw after the new carb. But, it was time for a new carb anyway, so I guess it worked out. Btw, as if all of this debacle wasn't frustrating enough, last weekend while trying to test all of this, the battery went dead. Checking the logs it was 36 months ago since I replaced it the last time. Guess that's about right. Sigh. Is it time to fly it yet? I've been working on it enough lately. ;-) Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. At 10:24 AM 12/21/2015 Monday, you wrote: >So what did you do to fix the problem Matt? > >Harry Crosby > > >---------- >From: "Matt Dralle" <dralle(at)matronics.com> >To: "RV-List" , LycomingEngines-list(at)matronics.com, rv6-list(at)matronics.com, rv10-list(at)matronics.com >Sent: Saturday, December 19, 2015 12:44:41 PM >Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate > > >Thank you to everyone that responded!! There were some great comments that got me going down the right path. > >Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual. > >The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb. > >Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically? > >Thanks again for the great feedback! > >Matt Dralle > > >At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote: > >>I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me? >> >>I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low? >> >>Thanks for the feedback, >> >>Matt > >- >Matt Dralle ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: FS new Slick 4372 & 4370 plus harnesses and plugs
Date: Dec 23, 2015
Removed from new Van's IO-390. Engine never run (other than the factor run). Includes eight Champion REB37E plugs, impulse coupler, gear and coupler standoff ring for the 4372 mag. Total cost of buying from Aircraft Spruce would be $2800+ (including the two $150 core charges). Will sell as a package for $2200. Carl ________________________________________________________________________________
Subject: Fwd: Matt Dralle (list admin)
Date: Dec 31, 2015
Retrying to a single list each time; first attempt at multiple lists seems to have failed. -------- Forwarded Message -------- Subject: Matt Dralle (list admin) Date: Thu, 31 Dec 2015 09:10:57 -0600 From: Charlie England <ceengland7(at)gmail.com> , kolb-list(at)matronics.com Just saw a post on the VAF forum that Matt had a stroke yesterday. The post quoted his facebook page: /Matt Update: He is responding to comments being made by squeezing Katie's hand and he was able to answer his age by using his one hand. All early indicators are that he is doing ok. Katie sends her thanks for the prayers and that they are definitely helping. / Please keep him in your thoughts and prayers, and remember that he won't be able to deal with list maintenance issues for some time. I'm trying to send this to the RV, aeroelectric, and kolb lists. If you're a member of additional lists, it might be good to pass it on. Charlie ________________________________________________________________________________
Subject: RE: RV-List Digest: 1 Msgs - 12/31/15
Date: Jan 01, 2016
I am very sorry to hear of this and I/we hope things go well for Matt. Paul Collins MD -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV-List Digest Server Sent: Friday, January 01, 2016 1:03 AM Subject: RV-List Digest: 1 Msgs - 12/31/15 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-12-31&Archive=RV Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2015-12-31&Archive=RV =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV-List Digest Archive --- Total Messages Posted Thu 12/31/15: 1 ---------------------------------------------------------- Today's Message Index:
March 16, 2015 - January 15, 2016
RV-Archive.digest.vol-vv
