RV10-Archive.digest.vol-am
June 28, 2005 - July 14, 2005
      >From: owner-rv10-list-server(at)matronics.com
      >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
      >Sent: Tuesday, June 28, 2005 3:53 PM
      >To: rv10-list(at)matronics.com
      >Subject: Re: RV10-List: De-burr help ..... Please!
      >OK, I''ve read Van's Manual about how hard 2024 Al is and how the slightest
      >scratch and turn into a crack, and how EVERYTHING needs to be deburred, Ok I
      >get the picture, BUT !!!  what bout the spaces between the flanges on ribs,
      >bulkheads etc. you know the ones, the ones that only have about 1/8 in
      >between them, No way to get a scotchbright wheel in there, I've tried a
      >number of dremel bits, but not found none that leaves a smooth edge. i'vve
      >tried a variety of fingernail files as well.
      >So for some of you repeat offenders, and otherwise experienced and skilled
      >workers of aluminum magic, just how important is it that these 'flange gaps'
      >get deburred? I can get the Scotchbrite wheel/s to do both edges of the
      >flanges themselves, but these 'gaps' are driving me crazy.
      >I'm starting my HS and looking at a number of them and thinking there's got
      >be be a better way. (Or perhaps no way?) The thoughts of dong the wings nexy
      >bring tears to my eyes.
      >Deems Davis #406
      >HS
Subject: Re: De-burr help ..... Please!
Date: Jun 28, 2005
>OK, I''ve read Van's Manual about how hard 2024 Al is and how the slightest >scratch and turn into a crack, and how EVERYTHING needs to be deburred, Ok >I get the picture, BUT !!! what bout the spaces between the flanges on >ribs, bulkheads etc. you know the ones, the ones that only have about 1/8 >in between them, No way to get a scotchbright wheel in there, I've tried a >number of dremel bits, but not found none that leaves a smooth edge. i'vve >tried a variety of fingernail files as well. So for some of you repeat >offenders, and otherwise experienced and skilled workers of aluminum magic, >just how important is it that these 'flange gaps' get deburred? I can get >the Scotchbrite wheel/s to do both edges of the flanges themselves, but >these 'gaps' are driving me crazy. I'm starting my HS and looking at a >number of them and thinking there's got be be a better way. (Or perhaps no >way?) The thoughts of dong the wings nexy bring tears to my eyes. > >Deems Davis #406 > >HS Easy now, don't lose your mind over it. (Too late? ;) For the nooks and crannies I use jewelers files...the rat tail ones. Harbor freight sells them in sets for dirt cheap. Just draw the file through the notch and knock off the burr caused from the shearing process. Chain saw sharpening files also work very well and are larger and easier to grasp. To be quite honest, I don't do much in these flange notch recesses. My edge and hole deburring on my -8 was far from perfect and the airplane has not a single crack anywhere in the airframe after five years of flying fun. I'm not too concerned with stress crack propagation in the internal ribs and formers as they are locked down and not subject to any significant amount of movement or flexion. Unsupported skin edges (trailing edge of wing skins, HS, VS skins, etc) can get some buzzing from engine vibrations and airflow. I try to buff these down to a smooth finish. To each his own, and you have to be comfortable with your degree of effort applied to this process. Just remember you're not building a Swiss watch, and do you think the airframe builders in WWII spent any significant amount of time deburring every single piece of the thousands of airframes they built? I think not! Are many of these airframes still airworthy to this very day? You betcha. Oh and don't sweat the scratches and scuffs. You'll hangar rash the parts through the years of handling and movements during construction and you'll just drive yourself bonkers trying to keep everything pristine. Primer and paint takes care of all but the worst deep gouges or scratches. Disclaimer: These are my opinions only. Van's mantra applies nicely here: "Just build the plane." Hang in there. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Date: Jun 28, 2005
Subject: De-burr help ..... Please!
Sears sells small deburring bits for motor tools (aka Dremel) that appear to be very similar in material to scotchbrite. They are pointed shape and green in color. I used about 5 of them since the beginning and they work perfectly in those exact same areas. I just run them at around half speed, push the point into the hole on both sides, works great for all small areas that need a little polishing. They run about $4 bucks a peice but they are invaluable for doing the cracks and crevices, don't run them at a high RPM, they wear out too fast. Rick S. 40185 Wings ________________________________________________________________________________
Date: Jun 28, 2005
I don't remember exactly where I got them, but they have lasted forever! I seem to think I got them at a local hobby shop. Might want to check out http://www.towerhobbies.com As everyone has said: Just take the burrs off so that you don't cut yourself and build it. I think someone said that Vans says that 20% of people don't even deburr at all, and that their parts ship in better condition than most manufacturers assemble with. -Jim John Jessen wrote: > >Deburring bit? In the Dremel? Is this a Dremel deburring bit? I've been >looking for such. Can you be more specific. > >Thanks, > >John Jessen > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein >Sent: Tuesday, June 28, 2005 4:20 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: De-burr help ..... Please! > > >Been there, Done that.... > > I went to the hardware store and got a roll of "Plumbers Abrasive Roll". >It's a 1" wide roll of, well, basically sandpaper, except its on a cloth >backing so it doesn't rip easy. Take the parts and a piece of that roll and >"floss away" :) > The other thing I did is get a 1/8" round chainsaw file; It works well >for the rounded parts between the flanges where they meet the web. > Other than that, I've also used a deburring bit in the Dremel (it's only >1/8" diameter.. good for tight spots.) > >Enjoy! Those are alot of ribs! > >-Jim 40384, just finished H.S. > > >Deems Davis wrote: > > > >> >>OK, I''ve read Van's Manual about how hard 2024 Al is and how the >>slightest scratch and turn into a crack, and how EVERYTHING needs to >>be deburred, Ok I get the picture, BUT !!! what bout the spaces >>between the flanges on ribs, bulkheads etc. you know the ones, the >>ones that only have about 1/8 in between them, No way to get a >>scotchbright wheel in there, I've tried a number of dremel bits, but >>not found none that leaves a smooth edge. i'vve tried a variety of >>fingernail files as well. So for some of you repeat offenders, and >>otherwise experienced and skilled workers of aluminum magic, just how >>important is it that these 'flange gaps' get deburred? I can get the >>Scotchbrite wheel/s to do both edges of the flanges themselves, but >>these 'gaps' are driving me crazy. I'm starting my HS and looking at >>a number of them and thinking there's got be be a better way. (Or >>perhaps no way?) The thoughts of dong the wings nexy bring tears to my >>eyes. >> >>Deems Davis #406 >> >>HS >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 28, 2005
Subject: Re: Aux fuel tanks?
Guys, I'm a newcomer to building the -10, but have years of flight test experience in high performance aircraft. I would not - repeat not - add anything to the outboard section of the wing that Van has not done structural analysis on to include flight tests. I specifically recall a problem with flight test of the F-16 and outboard stores that nearly took the outboard section of the wing off. The structures guys said it would never happen (the torsional loads) until we showed them on videotape. They then said "if you let that continue, it would probably rip the wing off......" Just a thought from a guy who requires both the design engineer and flight test folks to say "it's ok"...... grumpy In a message dated 6/28/2005 4:09:11 PM Central Standard Time, gyoung@cs-sol.com writes: Having the weight at the end of the spar is typically a benefit to the load distribution in flight. It can be a detriment to the landing loads though. Case in point, my Navion tip tanks allow me to increase my gross weight BUT only by the amount of fuel carried in the tip tanks. We are also cautioned to land gently if the tips are filled. It was likely a no-analysis item back when the STC was approved. Bending loads are one thing but it will also change the handling and fore-aft sloshing will affect CG and may impart torsional loads to the wing. Look at Van's write-up on the wing design and load testing before you think about modifying it. Regards, Greg Young ________________________________ Having owned and flown a Cessna 310 for the last three years and 500 hours I'm not concerned about stability issues. C310 main tanks are the tip tanks, 50 gallons per side, the aux tanks are in the wings only 15 gallons per side. This is a very stable aircraft. My question would be about adding the loading to the end of the spar? Steve 40212 Wings ________________________________________________________________________________
Subject: Gauntlet to Scott
Date: Jun 28, 2005
Add twenty years to your personal skeleton and it will resemble the condition I am in after such activity in my mid 20's over in the desert of Central Oregon. With CRS, it won't be long before those memory's are gone. Thanks for the response on the limp glove (Gauntlet). It was interesting how Silent Jim resurfaced just long enough to avoid the appropriate challenge. Showing Hartzell purchasers another alternative and design consideration should awaken the masses. It has always amused me that weight is always an attempt in aviation to be held to a minimum - just the inverse of more usable Brake Mean Horsepower, more runway , more fuel and adequate air under the wings. Why would anyone regularly carry ballast to effect a safe flight. Must be like those European ships of old that carried Belgian Cobblestones in there holds on the way to plundering the lumber of the Pacific NW. W & Balance options, harmonic suppression and just the general appearance of a well painted MT should move a few fence sitters from the Tried and True Grey Metal props into the world of a high performance three blade MT. Looking forward to Gerd's presentation at OSH on Wednesday, July 27 (just four weeks from tomorrow). I spent part of this weekend re-reading your posts on your progress. The fitment on the windscreen is looking good. John 503-453-6016 ________________________________
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Subject: RE: RV10-List: Gaunlet to Scott Well John I probably will not fly until November at the earliest. My panel is 8-10 weeks out from Aerocrafter but things are coming along nicely. I hope to start with paint sometime in August or September, do final panel install and finish work in October / November. I actually thing November is pushing it for me. The finishing work really does take a lot of time. I don't see why there will be any problems with the MT though. With 1-3 people I will not need any weight in the back. With 4 and baggage I may build a place in the engine compartment that can be easily outfitted with 15-20 lbs. of tungsten carbide. Anyway, I am working on the cowling right now so I can get the proper measurements needed to order the MT. Unfortunately you hit the nail on the head when I came to bike riding though. As you were sending out your e-mail I was in the middle of this year's 24 hour Utah 1088 endurance motorcycle ride. Placed 6th this year (a little disappointing for me). I had so much fun this year, it was worth the time it took away from the plane. I rode 1418 miles in 23.5 hours. After I get the feeling back into my right hand I will be able to start working on the plane again. Scott Schmidt Cell: 801-319-3094 sschmidt(at)ussynthetic.com ________________________________ ________________________________________________________________________________
Date: Jun 28, 2005
Subject: Re: -10 Static Ports
Kind of odd that he sells the static ports, but hasn't tested the installation on his own aircraft. The test is easy, and cheap. Instructions are at <http://www.kilohotel.com/rv8/phplinks/index.php?&PID=48>. This test is what showed me that my RV-6 had unacceptable airspeed (and altitude) errors as a result of using the static source on the certified heated pitot-static tube. I went to the standard Van's pop rivet approach and dropped my errors by two thirds or so. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 740 hrs RV-10 #40059 under construction RV Builder (Michael Sausen) wrote: > Randy, Jesse, and anyone else that is flying, > > What did you use for your static ports? I am looking at using the > safair1 kit but have heard that flush, or near flush, mount static ports > introduce a large error in the 1 and 2 seat RV's. I asked Tony at > SafeAir1 this question and got a bit of the run around (posted below for > reference). The quality of his stuff looks to be quite good and I can > live with a couple knot discrepancy, but I don't want to introduce a > couple hundred foot error in my altimeter. > > Michael Sausen > -10 #352 > Tailcone > > > > Michael, > > Thank you for your interest in SafeAir1 products. > > Like the great "primer wars", this subject comes up about every 6 months. > > Our static ports protrude beyond the skin by about .015" (skin thickness > = .032"). We have sold hundreds static ports and NEVER had a single > complaint from customer or a returned kit. I used flush ports on my > RV-6 and have been flying since the spring of 2000 without an accident. > Are my readings improper? I'm not sure how I'd know? All of my > performance parameters are where Van predicted they should be. Perhaps > my system is off 1 knot, 3 knots, or .005 knots? Or maybe it's the > chase airplane with the pop rivets that's off by 2.7 knots? Are all pop > rivets squeezed to the exact same thickness before the mandrel shears? > Has Van's changed pop rivet suppliers? How thick is the boundary layer > along the RV-X side skins where the ports are mounted? Are the boundary > layers always the same? What if the aircraft with flush ports had a > leaky static system? I'm not trying to beat you up for asking the > question. I can only point to my success, and the success of our > customers and say our ports seem to work in a satisfactory manner. > Having said that, We've sold a lot of ports to RV-10 builders, but I > don't know if any of them have flown yet. > > I am not aware of any static ports, including Van's /pop rivet of the > day/, that have been designed and tested for use in experimental > aircraft static systems. If you're not comfortable with our static > ports, I suggest you stick with pop rivets per Van's plans. > > Regards, > > Tony Munday > SafeAir1 > > > -----Original Message----- > *From:* Michael Sausen > *Sent:* Monday, June 27, 2005 9:42 PM > *To:* CustomerCare(at)SafeAir1.com > *Subject:* RV-10 pitot-static kit > > I'm interested in your pitot-static kit for the -10 I am building > and was wondering if your machined static ports protrude above the > skin similar to the Van's pop rivet style. The reason I ask is the > flush mounts have shown to cause an improper reading on other RV models. > > Thanks, > Michael Sausen ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: rudder vent
Date: Jun 28, 2005
Ok, I've got mixed emotions from my work session this evening. I riveted the trailing edge of my rudder, tried to follow al the steps as best I could, but I'm sure how I feel about the outcome. Translate that to: It's flyable, but it's a long way from what I was working toward. For those of you heading that direction, at least two things: make sure you barely smear the thinnest coating of proseal possible along the wedge, and don't use the bulky popsicle stick. Use a brush or gloved finger. I learned a couple of nights ago on the board here (too late) that the proseal is definitely non-structural. I made sure to get the goop all the way down the length of the edge. I've got a few spots that, although not horrible, I definitely had to use more rivet gun attention to get that part to lay down flatter, so I had to be even more cautious about causing a hook. The other thing is closely related. I made lap joints, but I bent the skins (in retrospect) more than the few degrees called for in the instructions. I thought I was giving myself extra goof-up room to squeeze the rivets without upturning the edges, but in reality all I did was allow more proseal to stay accumulated under the edges that caused the major of the two problems. While I was riveting this evening, I was working against the proseal under the lapped edge, which made it that much harder to get the nice, straight, flat edge. In short, 1) don't try to use all the proseal (I didn't do that either, but I still used too much) and only smear that barest adequate quantity, and 2) make the bends on your lap joints either barely or not at all perceptible; it'll still work out. Rob Wright 40392 On to rolling rudder leading edges tomorrow.. ________________________________________________________________________________
Subject: -10 Static Ports
Date: Jun 28, 2005
Remind me not to buy from SafeAir1. what kind of business-generating reply is that? Rob Wright _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) rv10-list(at)matronics.com Subject: RV10-List: -10 Static Ports Randy, Jesse, and anyone else that is flying, What did you use for your static ports? I am looking at using the safair1 kit but have heard that flush, or near flush, mount static ports introduce a large error in the 1 and 2 seat RV's. I asked Tony at SafeAir1 this question and got a bit of the run around (posted below for reference). The quality of his stuff looks to be quite good and I can live with a couple knot discrepancy, but I don't want to introduce a couple hundred foot error in my altimeter. Michael Sausen -10 #352 Tailcone Michael, Thank you for your interest in SafeAir1 products. Like the great "primer wars", this subject comes up about every 6 months. Our static ports protrude beyond the skin by about .015" (skin thickness .032"). We have sold hundreds static ports and NEVER had a single complaint from customer or a returned kit. I used flush ports on my RV-6 and have been flying since the spring of 2000 without an accident. Are my readings improper? I'm not sure how I'd know? All of my performance parameters are where Van predicted they should be. Perhaps my system is off 1 knot, 3 knots, or .005 knots? Or maybe it's the chase airplane with the pop rivets that's off by 2.7 knots? Are all pop rivets squeezed to the exact same thickness before the mandrel shears? Has Van's changed pop rivet suppliers? How thick is the boundary layer along the RV-X side skins where the ports are mounted? Are the boundary layers always the same? What if the aircraft with flush ports had a leaky static system? I'm not trying to beat you up for asking the question. I can only point to my success, and the success of our customers and say our ports seem to work in a satisfactory manner. Having said that, We've sold a lot of ports to RV-10 builders, but I don't know if any of them have flown yet. I am not aware of any static ports, including Van's pop rivet of the day, that have been designed and tested for use in experimental aircraft static systems. If you're not comfortable with our static ports, I suggest you stick with pop rivets per Van's plans. Regards, Tony Munday SafeAir1 -----Original Message----- From: Michael Sausen Subject: RV-10 pitot-static kit I'm interested in your pitot-static kit for the -10 I am building and was wondering if your machined static ports protrude above the skin similar to the Van's pop rivet style. The reason I ask is the flush mounts have shown to cause an improper reading on other RV models. Thanks, Michael Sausen ________________________________________________________________________________
Subject: QB Fuse Gear Mount Bolts
Date: Jun 28, 2005
I was putting the main gear mounts in for the final drilling and was just about to rig a long wrench as several others have indicated. Just for kicks I took out the wood spacer at the end of the spar carry through and it turns out you can reach in there from the side and get to all the bolts you need to. Hopefully this will help those who haven't spent hours on this aspect yet. Marcus 40286 Wings & Finishing kit ship next week ________________________________________________________________________________
Date: Jun 29, 2005
Subject: Re: -10 Static Ports. Just my opinion
<001301c57c5a$f5e20b60$e3926947@starnfamily> G'day all, JOHN STARN wrote: > I almost sure that the Safeair1 static vents are NOT flush All respect to you John, but as someone with the Safeair1 ports firmly fixed to my side skins, they ARE flush. The kit is fantastic quality and I have absolutely no regrets about going with Safeair1. Will let you know in 3-4 years how accurate they are, but in all my research I have only found 3-4 comments about problems, and there's gotta be more flush ports flying than that. Pic attached (Actually looks a little recessed in the pic, but that is just because of the angle it is taken from). Seeya, Scott Lewis RV-10 40172 VH-DRS Adelaide, South Australia ________________________________________________________________________________
Subject: Tube Flaring technique
Date: Jun 29, 2005
What's the trick to good flares? I did fine for half of the tubes and then managed to crack every one. I tried to carefully cut with a tube cutter, a little at a time, make sure the ends are squared, deburred. I have one of those sliding block flaring tools (37deg). One fella in the archive mentioned leaving 5/16" of the tube protruding through the block and turn 7 half turns. Anh #141 ________________________________________________________________________________
Date: Jun 28, 2005
Subject: Tank Sealant Quantity?
What quantity of tank sealant was required to seal the tanks? Was the quart kit enough to complete both tanks? Thanks... -Sean #40303 ________________________________________________________________________________
Date: Jun 28, 2005
Subject: Re: Gauntlet to Scott
<9F819487C44F0B4DBDB0CC0450824CEB019B5316@ehost005-2.exch005intermedia.net> Well I guess I'll just have to permanently attach the 16 oz water bottle I carry with me in the cockpit. As you said, size does not matter. Does the permanently attachment rule also apply to tool bags, golf bags, luggage etc. etc. that is carried & used in the W&B calculations. But the whole idea is NOT to carry bricks, lead shot etc. ALL the time, moving them about as required. I'm sure that the same netting that holds down bricks, lead, extra oil etc would hold down a water bottle. (Like the ones off-roaders use) The whole idea was to carry an empty container until needed, fill it and emptied when no longer required. The MT four blade prop we have is not the same one recommended for the RV-10. HRII N561FS is powered by Lyc. IO-540 250 HP. We didn't do a full set of engineering studies on the props, (nor are we likely to do so just for your edification) we just like to fly in the Rocket. John Harmon might have some data as our prop is the same one he tried on his Reno HRIII racer. Not "fast" enough to race behind but great for our use. This debate sounds a lot like the old Bonanza aft tank that was required to be emptied first so as to not move the envelope beyond the rear limits. BUT I agree with your comment that it would be "nice" if we could just kick the tires, light the fire & zoom away without W&B considerations in the RV-10 and most every other airplane. I know the W&B numbers on N561FS and will care again when I get closer to building the -10 kit. KABONG Do Not Archive ----- Original Message ----- From: "John W. Cox" <johnwcox(at)pacificnw.com> Subject: RE: RV10-List: Gauntlet to Scott > > As a certificated LTA pilot I know a lot about both hot air and the use of > water ballast with airships. The retaining containers must be permanently > fixed into the aircraft and listed in the empty weight calculation. With > Amphibs the floats often require some creative, permanent lead or other > fixed (and declared) weights. Often found as little total weight as > possible and as far aft as practical (like the tie down eyelet). However, > I seem to remember the need that ballast be secured for all possible > turbulence that can be encountered in flight. I don't think a collapsible > plastic water container whether how small or large would pass an official > ramp test. Can't imagine VAN supporting that either. But then, that was > the whole issue of the post. Why carry ballast again.... KABONG? > > Can't respond to the MT query till Jim lets someone test the darn thing > and establish the new arm and moment. Scott has a valid Hall Pass till > this fall. Wouldn't it be novel if a 10 could fly lighter without the use > of 70 pounds of hot water bottles shoved into all the little storage > places. I can just see the NTSB reconstructing the accident report on W&B > after the fact. "Oh well, I popped my water, had to execute an immediate > landing till I could take on more fuel.... The pains got too close > together, I guess I did not make it". ;-). > > Okay, John - three on the same plane, lets here some speeds, MP and rpm > reports. I know the 3 blade is better harmonically and the additional > drag with the fourth is oh well. I can show you a Garrett TPE on a LIV > with Five, but that's another matter. Let's do hear. > > This water won't float my boat. > > $00.019 > Just a random comment on W & B. Buy a 5 gallon collapsible plastic water ________________________________________________________________________________
Date: Jun 28, 2005
<001301c57c5a$f5e20b60$e3926947@starnfamily> <42C21E48.2000603(at)tpg.com.au> Sorry, I did say "almost sure", but I had not seen the part up close nor of the installation, only the photo's of the kit. It would appear that some more material needs to be ground off the face so the end sticks thru further. SAFEAIR are you lurking out there ?. We used the ACS part# 15160, page #348 but changed out the attaching fitting to a Nylo-seal fitting# 269-N 1/4 tube X 1/8 pipe thread 90 degree elbow page# 115. As noted these ACS units do protrude thru the skin (with paint) about the same as the head of a "pop" rivet. You might want to drill out those three (times 2) rivets & grind or have the depth of the cut increased. It's got to be easier now than in a few years and after paint. Again I'm sorry for my assumption. So as not make another error, Scott you did countersink the face of the port ? KABONG ----- Original Message ----- From: "Scott Lewis" <rv10(at)tpg.com.au> Subject: Re: RV10-List: -10 Static Ports. Just my opinion > G'day all, > > JOHN STARN wrote: >> I almost sure that the Safeair1 static vents are NOT flush > > All respect to you John, but as someone with the Safeair1 ports firmly > fixed to my side skins, they ARE flush. The kit is fantastic quality > and I have absolutely no regrets about going with Safeair1. Will let > you know in 3-4 years how accurate they are, but in all my research I > have only found 3-4 comments about problems, and there's gotta be more > flush ports flying than that. > > Pic attached (Actually looks a little recessed in the pic, but that is > just because of the angle it is taken from). > > Seeya, > Scott Lewis > RV-10 40172 VH-DRS > Adelaide, South Australia > ________________________________________________________________________________
Subject: Instrument Panel Cutouts
Date: Jun 29, 2005
Does anyone have any experience with the folks at Experimental Air with generating a CAD picture of the panel and then cutting it with the water jet. Seems like a pretty neat deal and reasonably priced assuming they do good work. Thanks, Marcus ________________________________________________________________________________
Date: Jun 29, 2005
One of the tricks is to have fresh tubing. My Glasair kit had tubing that would not flair. I had to get replacement tubing. Cut a sample or two and bring them to a friend and have him try it. That will tell you if it is technique or tubing. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: RV10-List: Tube Flaring technique What's the trick to good flares? I did fine for half of the tubes and then managed to crack every one. I tried to carefully cut with a tube cutter, a little at a time, make sure the ends are squared, deburred. I have one of those sliding block flaring tools (37deg). One fella in the archive mentioned leaving 5/16" of the tube protruding through the block and turn 7 half turns. Anh #141 ________________________________________________________________________________
Date: Jun 29, 2005
I have gone a diferent route. I purchaced a 2 blade Aero Composites propeller aerocomposites.com It is way lighter than the Hartzel and some lighter than the MT because it is only 2 blade. I am hoping that it will solvew the CG issue without balast. Gary Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JOHN STARN Subject: Re: RV10-List: Gauntlet to Scott Well I guess I'll just have to permanently attach the 16 oz water bottle I carry with me in the cockpit. As you said, size does not matter. Does the permanently attachment rule also apply to tool bags, golf bags, luggage etc. etc. that is carried & used in the W&B calculations. But the whole idea is NOT to carry bricks, lead shot etc. ALL the time, moving them about as required. I'm sure that the same netting that holds down bricks, lead, extra oil etc would hold down a water bottle. (Like the ones off-roaders use) The whole idea was to carry an empty container until needed, fill it and emptied when no longer required. The MT four blade prop we have is not the same one recommended for the RV-10. HRII N561FS is powered by Lyc. IO-540 250 HP. We didn't do a full set of engineering studies on the props, (nor are we likely to do so just for your edification) we just like to fly in the Rocket. John Harmon might have some data as our prop is the same one he tried on his Reno HRIII racer. Not "fast" enough to race behind but great for our use. This debate sounds a lot like the old Bonanza aft tank that was required to be emptied first so as to not move the envelope beyond the rear limits. BUT I agree with your comment that it would be "nice" if we could just kick the tires, light the fire & zoom away without W&B considerations in the RV-10 and most every other airplane. I know the W&B numbers on N561FS and will care again when I get closer to building the -10 kit. KABONG Do Not Archive ----- Original Message ----- From: "John W. Cox" <johnwcox(at)pacificnw.com> Subject: RE: RV10-List: Gauntlet to Scott > --> > > As a certificated LTA pilot I know a lot about both hot air and the > use of > water ballast with airships. The retaining containers must be permanently > fixed into the aircraft and listed in the empty weight calculation. With > Amphibs the floats often require some creative, permanent lead or other > fixed (and declared) weights. Often found as little total weight as > possible and as far aft as practical (like the tie down eyelet). However, > I seem to remember the need that ballast be secured for all possible > turbulence that can be encountered in flight. I don't think a collapsible > plastic water container whether how small or large would pass an official > ramp test. Can't imagine VAN supporting that either. But then, that was > the whole issue of the post. Why carry ballast again.... KABONG? > > Can't respond to the MT query till Jim lets someone test the darn > thing > and establish the new arm and moment. Scott has a valid Hall Pass till > this fall. Wouldn't it be novel if a 10 could fly lighter without the use > of 70 pounds of hot water bottles shoved into all the little storage > places. I can just see the NTSB reconstructing the accident report on W&B > after the fact. "Oh well, I popped my water, had to execute an immediate > landing till I could take on more fuel.... The pains got too close > together, I guess I did not make it". ;-). > > Okay, John - three on the same plane, lets here some speeds, MP and > rpm > reports. I know the 3 blade is better harmonically and the additional > drag with the fourth is oh well. I can show you a Garrett TPE on a LIV > with Five, but that's another matter. Let's do hear. > > This water won't float my boat. > > $00.019 > Just a random comment on W & B. Buy a 5 gallon collapsible plastic > water ________________________________________________________________________________
Date: Jun 29, 2005
Subject: Re: Tank Sealant Quantity?
<42C222F8.1010800(at)cox.net> If you're really careful with it, you may get by on one can. I know I wasn't quite as conservative as I could have been, and I used a fair share of 2 cans. If a builder was reasonably careful, 2 cans could do all of the control surfaces and the tanks, and they could buy the 2 cans right away. Store them in the freezer for increased shelf life. To me, I'd rather spend an extra $40 and not get slowed down. You'll actually use a little on the firewall, and a couple other places down the road too. I used some to seal my hot air intake vent gaps. Tim Tim Olson -- RV-10 #170 Current project: Fuselage Sean Stephens wrote: > > What quantity of tank sealant was required to seal the tanks? Was the > quart kit enough to complete both tanks? > > Thanks... > > -Sean #40303 > ________________________________________________________________________________
Date: Jun 29, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Until you get to the other end of the scale and have four adults on board and low fuel, then your c.g. could be too far aft . . . I vote that Van's includes their weight and balance information earlier in the kit process, instead of just in the finish kit. It would be interesting to try and get W&B for the aircraft shell, not counting engine, electrical, or anything. Then one could do a mental exercise of adding components and see where your c.g. ends up. TDT -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Gary Specketer Subject: RE: RV10-List: Gauntlet to Scott I have gone a diferent route. I purchaced a 2 blade Aero Composites propeller aerocomposites.com It is way lighter than the Hartzel and some lighter than the MT because it is only 2 blade. I am hoping that it will solvew the CG issue without balast. Gary Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JOHN STARN Subject: Re: RV10-List: Gauntlet to Scott Well I guess I'll just have to permanently attach the 16 oz water bottle I carry with me in the cockpit. As you said, size does not matter. Does the permanently attachment rule also apply to tool bags, golf bags, luggage etc. etc. that is carried & used in the W&B calculations. But the whole idea is NOT to carry bricks, lead shot etc. ALL the time, moving them about as required. I'm sure that the same netting that holds down bricks, lead, extra oil etc would hold down a water bottle. (Like the ones off-roaders use) The whole idea was to carry an empty container until needed, fill it and emptied when no longer required. The MT four blade prop we have is not the same one recommended for the RV-10. HRII N561FS is powered by Lyc. IO-540 250 HP. We didn't do a full set of engineering studies on the props, (nor are we likely to do so just for your edification) we just like to fly in the Rocket. John Harmon might have some data as our prop is the same one he tried on his Reno HRIII racer. Not "fast" enough to race behind but great for our use. This debate sounds a lot like the old Bonanza aft tank that was required to be emptied first so as to not move the envelope beyond the rear limits. BUT I agree with your comment that it would be "nice" if we could just kick the tires, light the fire & zoom away without W&B considerations in the RV-10 and most every other airplane. I know the W&B numbers on N561FS and will care again when I get closer to building the -10 kit. KABONG Do Not Archive ----- Original Message ----- From: "John W. Cox" <johnwcox(at)pacificnw.com> Subject: RE: RV10-List: Gauntlet to Scott > --> > > As a certificated LTA pilot I know a lot about both hot air and the > use of > water ballast with airships. The retaining containers must be permanently > fixed into the aircraft and listed in the empty weight calculation. With > Amphibs the floats often require some creative, permanent lead or other > fixed (and declared) weights. Often found as little total weight as > possible and as far aft as practical (like the tie down eyelet). However, > I seem to remember the need that ballast be secured for all possible > turbulence that can be encountered in flight. I don't think a collapsible > plastic water container whether how small or large would pass an official > ramp test. Can't imagine VAN supporting that either. But then, that was > the whole issue of the post. Why carry ballast again.... KABONG? > > Can't respond to the MT query till Jim lets someone test the darn > thing > and establish the new arm and moment. Scott has a valid Hall Pass till > this fall. Wouldn't it be novel if a 10 could fly lighter without the use > of 70 pounds of hot water bottles shoved into all the little storage > places. I can just see the NTSB reconstructing the accident report on W&B > after the fact. "Oh well, I popped my water, had to execute an immediate > landing till I could take on more fuel.... The pains got too close > together, I guess I did not make it". ;-). > > Okay, John - three on the same plane, lets here some speeds, MP and > rpm > reports. I know the 3 blade is better harmonically and the additional > drag with the fourth is oh well. I can show you a Garrett TPE on a LIV > with Five, but that's another matter. Let's do hear. > > This water won't float my boat. > > $00.019 > Just a random comment on W & B. Buy a 5 gallon collapsible plastic > water ________________________________________________________________________________
Date: Jun 29, 2005
I have not yet installed my Safe Air vents, but I did a test fit and the port does stick out past the skin. It sticks out at least as far as paint would. I will make a measurement when I get back to the shop in a couple of days. Larry Rosen #356 -------------- Original message -------------- > > Sorry, I did say "almost sure", but I had not seen the part up close nor of > the installation, only the photo's of the kit. It would appear that some > more material needs to be ground off the face so the end sticks thru > further. SAFEAIR are you lurking out there ?. > We used the ACS part# 15160, page #348 but changed out the attaching fitting > to a Nylo-seal fitting# 269-N 1/4 tube X 1/8 pipe thread 90 degree elbow > page# 115. As noted these ACS units do protrude thru the skin (with paint) > about the same as the head of a "pop" rivet. You might want to drill out > those three (times 2) rivets & grind or have the depth of the cut increased. > It's got to be easier now than in a few years and after paint. > Again I'm sorry for my assumption. So as not make another error, Scott you > did countersink the face of the port ? KABONG > > ----- Original Message ----- > From: "Scott Lewis" > To: > Sent: Tuesday, June 28, 2005 9:06 PM > Subject: Re: RV10-List: -10 Static Ports. Just my opinion > > > > G'day all, > > > > JOHN STARN wrote: > >> I almost sure that the Safeair1 static vents are NOT flush > > > > All respect to you John, but as someone with the Safeair1 ports firmly > > fixed to my side skins, they ARE flush. The kit is fantastic quality > > and I have absolutely no regrets about going with Safeair1. Will let > > you know in 3-4 years how accurate they are, but in all my research I > > have only found 3-4 comments about problems, and there's gotta be more > > flush ports flying than that. > > > > Pic attached (Actually looks a little recessed in the pic, but that is > > just because of the angle it is taken from). > > > > Seeya, > > Scott Lewis > > RV-10 40172 VH-DRS > > Adelaide, South Australia > > > > > > > > > > > > > > > > > > > I have not yet installed my Safe Air vents, but I did a test fit and the port does stick out past the skin. It sticks out at least as far as paint would. I will make a measurement when I get back to the shop in a couple of days. Larry Rosen #356 -------------- Original message -------------- -- RV10-List message posted by: "JOHN STARN" Sorry, I did say "almost sure", but I had not seen the part up close nor of the installation, only the photo's of the kit. It would appear that some more material needs to be ground off the face so the end sticks thru further. SAFEAIR are you lurking out there ?. We used the ACS part# 15160, page #348 but changed out the attaching fitting to a Nylo-seal fitting# 269-N 1/4 tube X 1/8 pipe thread 90 degree elbow page# 115. As noted these ACS units do protrude thru the skin (with paint) about the same as the head of a "pop" rivet. You might want to drill out those three (times 2) rivets grind or have the depth of the cut increased. It's got to be easier now than in a few years and after paint. Again I'm sorry for my assumption. So as not make another error, Scott you did countersink the face of the port ? KABONG ----- Original Message ----- From: "Scott Lewis" <RV10(at)TPG.COM.AU> To: Sent: Tuesday, June 28, 2005 9:06 PM Subject: Re: RV10-List: -10 Static Ports. Just my opinion G'day all, JOHN STARN wrote: I almost sure that the Safeair1 static vents are NOT flush All respect to you John, but as someone with the Safeair1 ports firmly fixed to my side skins, they ARE flush. The kit is fantastic quality and I have absolutely no regrets about going with Safeair1. Will let you know in 3-4 years how accurate they are, but in all my research I have only found 3-4 comments about problems, ________________________________________________________________________________
Subject: Firewall Insualtion?
Date: Jun 29, 2005
I have not installed the firewall sound insulation yet. What is interesting is that a good friend of mine flew with me in 10 the other day and was astounded at how quite the 10 is without the insulation in place. He was sure it would be one of the first things that I would want to get done after the first flights. Now we said he wouldn't think you would even need it. I will be putting it in. The material I have is from Hi Tec foams. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Byron Gillespie Subject: RV10-List: Firewall Insualtion? What are any of you doing relative to firewall insulation? I have searched the archives and have found very little info. I am putting together an order to Aircraft Spruce and noticed that they have several different types. Thought that I would add it on to the floor insulation order. Just ordered my fuel pumps, etc from Vans yesterday. Just looking to those who have (and are) forged ahead for the usual guidance. Thanks, Byron More fuselage decisions - # 40253 ________________________________________________________________________________
Date: Jun 29, 2005
W & B, Something to kick around ... Has anyone considered building-in a small tool compartment into the empanage to help with W&B? A compartment designed for dedicated storage of individual tools. Whereby individual tools could have their special "nest" to fit into and would not rattle around. They wouldn't weigh much but their moment arm would have an influence on resolving balance issues. Please recall how some components are packed and shipped in molded styrofoam and have their own little molded space the shape of that component. Could something like this be done safely if considered part of an MEL (minimum equipment list)? Regards ... Jerry Grimmonpre 7A ... still shop building > > Well I guess I'll just have to permanently attach the 16 oz water > bottle I > carry with me in the cockpit. As you said, size does not matter. Does > the > permanently attachment rule also apply to tool bags, golf bags, luggage > etc. > etc. that is carried & used in the W&B calculations. > But the whole idea is NOT to carry bricks, lead shot etc. ALL the time, > moving them about as required. I'm sure that the same netting that holds > > down bricks, lead, extra oil etc would hold down a water bottle. (Like > the > ones off-roaders use) The whole idea was to carry an empty container > until > needed, fill it and emptied when no longer required. ________________________________________________________________________________
Date: Jun 29, 2005
<42C222F8.1010800(at)cox.net> <42C2A171.3030503(at)MyRV10.com> Thanks Tim, I read the writeup on your site. I was hoping to be able to use the 6 oz. cartridges as I've got a ProSeal air gun and it works really well. Unfortunately the 6 oz. cartridges are pricey (~$23 each) compared to the quart kit. Maybe I can just pick up one 6 oz. cartridge and re-use the cartridge/plunger/nozzle with the quart kit. -Sean #40303 Tim Olson wrote: > > If you're really careful with it, you may get by on one can. > I know I wasn't quite as conservative as I could have been, > and I used a fair share of 2 cans. If a builder was > reasonably careful, 2 cans could do all of the control > surfaces and the tanks, and they could buy the 2 cans > right away. Store them in the freezer for increased > shelf life. To me, I'd rather spend an extra $40 and > not get slowed down. You'll actually use a little on > the firewall, and a couple other places down the road too. > I used some to seal my hot air intake vent gaps. > > Tim > > Tim Olson -- RV-10 #170 > Current project: Fuselage > > Sean Stephens wrote: >> >> What quantity of tank sealant was required to seal the tanks? Was >> the quart kit enough to complete both tanks? >> >> Thanks... >> >> -Sean #40303 >> > > ________________________________________________________________________________
Subject: QB in my future
Date: Jun 29, 2005
Ok. I figured I wouldn't do a QB because it would save me almost $10,000 big ones. However, while doing some heavy thinking in the shower, I now have come up with a way to rationalize my way into a QB. It really will cost only $3,000 big ones because, and let me know if this is false economics, I'm not spending close to $7,000 during the year's time it saves me in building, on a 172 rental and staying current. I'm in the air one year sooner, hopefully, and since I typically fly 60-70 hours per year, at $110 per hour rental charge, and since the operating costs will be there for the -10 no matter what, the $$$ for the QB replaces $$$ for the rental guys. I have in my head from somewhere that the QB saves around 800 hours build time, and for me that'd be about 40 weeks. So, given travel and vacations and whatever, that's about a year. Waddya think? John Jessen (doing priming of VS and Rudder and big time rationalizing) ________________________________________________________________________________
Date: Jun 29, 2005
SSA)" Sounds like you might have a plan! Other option is to go QB with only one of the kits (wings or fuselage). This has been discussed previously, but my recommendation would definitely be the fuselage. Bob #40105 -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: QB in my future Ok. I figured I wouldn't do a QB because it would save me almost $10,000 big ones. However, while doing some heavy thinking in the shower, I now have come up with a way to rationalize my way into a QB. It really will cost only $3,000 big ones because, and let me know if this is false economics, I'm not spending close to $7,000 during the year's time it saves me in building, on a 172 rental and staying current. I'm in the air one year sooner, hopefully, and since I typically fly 60-70 hours per year, at $110 per hour rental charge, and since the operating costs will be there for the -10 no matter what, the $$$ for the QB replaces $$$ for the rental guys. I have in my head from somewhere that the QB saves around 800 hours build time, and for me that'd be about 40 weeks. So, given travel and vacations and whatever, that's about a year. Waddya think? John Jessen (doing priming of VS and Rudder and big time rationalizing) ________________________________________________________________________________ ;
Date: Jun 29, 2005
Sean, The other downside of the tubes is for many sections you have alot left over and for the tanks you will be pressed to dispense and rivet before it sets up on you. I started with the tubes but switched to mixing small batches from the cans and things are much easier. I use a small digital postal scale ($25) for getting the mix right and mix ~ 40 gram batches. I've read about at least one person thinning proseal with MEK to ease application. Is this accepted practice? It may be messy, I think the whole tank sealing process is more tedious than difficult. Based on my experience with the tubes it would be very difficult to reuse them. Your cost and time with MEK, etc to clean them out would be better spent on popsicle sticks and clecos... :) Most of the mess is in the riveting anyway. Eric --- Sean Stephens wrote: > > > Thanks Tim, > > I read the writeup on your site. I was hoping to be > able to use the 6 > oz. cartridges as I've got a ProSeal air gun and it > works really well. > Unfortunately the 6 oz. cartridges are pricey (~$23 > each) compared to > the quart kit. Maybe I can just pick up one 6 oz. > cartridge and re-use > the cartridge/plunger/nozzle with the quart kit. > > -Sean #40303 > ________________________________________________________________________________
Date: Jun 29, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I concur with Eric. I started out on the tail kit with a couple of the cartridges to use on trailing edges. You not only spend a lot for them, you don't use most of it (cartridges also have a faster cure time than the quart kits). It's actually really handy to be able to just mix a very small batch from the quart cans. Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Panning Subject: Re: RV10-List: Tank Sealant Quantity? Sean, The other downside of the tubes is for many sections you have alot left over and for the tanks you will be pressed to dispense and rivet before it sets up on you. I started with the tubes but switched to mixing small batches from the cans and things are much easier. I use a small digital postal scale ($25) for getting the mix right and mix ~ 40 gram batches. I've read about at least one person thinning proseal with MEK to ease application. Is this accepted practice? It may be messy, I think the whole tank sealing process is more tedious than difficult. Based on my experience with the tubes it would be very difficult to reuse them. Your cost and time with MEK, etc to clean them out would be better spent on popsicle sticks and clecos... :) Most of the mess is in the riveting anyway. Eric --- Sean Stephens wrote: > > > Thanks Tim, > > I read the writeup on your site. I was hoping to be > able to use the 6 > oz. cartridges as I've got a ProSeal air gun and it > works really well. > Unfortunately the 6 oz. cartridges are pricey (~$23 > each) compared to > the quart kit. Maybe I can just pick up one 6 oz. > cartridge and re-use > the cartridge/plunger/nozzle with the quart kit. > > -Sean #40303 > ________________________________________________________________________________
Subject: Flightline Interiors need a 10 to fit some upholstery in.
Date: Jun 29, 2005
I just go off of the phone with Abby at Flightline Interiors. She is looking for one additional RV10 that she can use to test fit some interior panels in. She is looking for someone in a 150 mile radius of Milwaukee WI.. You can call here at 262-364-6166. This may be an opportunity to save a little on your interior. I used her for my seats and she is a pleasure to work with. Randy ________________________________________________________________________________
Date: Jun 29, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
I believe you are supposed to use Toluene for thinning Proseal. Don't know if MEK is compatible but wouldn't want to find out on the tanks. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Panning Subject: Re: RV10-List: Tank Sealant Quantity? --> Sean, The other downside of the tubes is for many sections you have alot left over and for the tanks you will be pressed to dispense and rivet before it sets up on you. I started with the tubes but switched to mixing small batches from the cans and things are much easier. I use a small digital postal scale ($25) for getting the mix right and mix ~ 40 gram batches. I've read about at least one person thinning proseal with MEK to ease application. Is this accepted practice? It may be messy, I think the whole tank sealing process is more tedious than difficult. Based on my experience with the tubes it would be very difficult to reuse them. Your cost and time with MEK, etc to clean them out would be better spent on popsicle sticks and clecos... :) Most of the mess is in the riveting anyway. Eric --- Sean Stephens wrote: > > > Thanks Tim, > > I read the writeup on your site. I was hoping to be able to use the 6 > oz. cartridges as I've got a ProSeal air gun and it works really well. > Unfortunately the 6 oz. cartridges are pricey (~$23 > each) compared to > the quart kit. Maybe I can just pick up one 6 oz. > cartridge and re-use > the cartridge/plunger/nozzle with the quart kit. > > -Sean #40303 > ________________________________________________________________________________
Date: Jun 29, 2005
I used 6 tubes and 1 can, which also did the ailerons and flap trailing edges. FWIW, order the B-2 sealant in the tubes, it gives you the same working time as the can stuff. The B-2 = 2 hours...B-1/2 = 1/2 hour etc.The tubes are good for doing the rear baffle and going over the rivets after your finished. The can works good for doing the ribs a few at a time and the little pieces when only 1 or 2 oz is needed. The tube and air gun make a real neat job when you have a large area such as the baffles and it is real nice to use over the dimples, cut a small notch in the tip so it will glide over the dimples. I would do it the same way again but I admit two cans would have been much less money than going with the tubes. Oh yeah, I also used the ATS mixer adapter to stir the tubes...chuck it up in a 1/2" drill and it mixes the material perfectly. You can also buy empty tubes for around three bucks each from ATS. Lots of options but the bottom line is either way it's a mess and you'll be elated when finished. Rick S. 40185 Wings ________________________________________________________________________________
Date: Jun 29, 2005
Sounds good except for the 800 hour savings. It took me 300 hours to get my Fuse to the Quick build stage and around 250 hours for the wings. I would except the savings to be more like 600 hour savings. Thank You Ray Doerr 40250 -----Original Message-----
Date: Jun 29, 2005
Thanks, Ray. How many hours per week are you averaging? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK] Subject: RE: RV10-List: QB in my future --> Sounds good except for the 800 hour savings. It took me 300 hours to get my Fuse to the Quick build stage and around 250 hours for the wings. I would except the savings to be more like 600 hour savings. Thank You Ray Doerr 40250 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: QB in my future Ok. I figured I wouldn't do a QB because it would save me almost $10,000 big ones. However, while doing some heavy thinking in the shower, I now have come up with a way to rationalize my way into a QB. It really will cost only $3,000 big ones because, and let me know if this is false economics, I'm not spending close to $7,000 during the year's time it saves me in building, on a 172 rental and staying current. I'm in the air one year sooner, hopefully, and since I typically fly 60-70 hours per year, at $110 per hour rental charge, and since the operating costs will be there for the -10 no matter what, the $$$ for the QB replaces $$$ for the rental guys. I have in my head from somewhere that the QB saves around 800 hours build time, and for me that'd be about 40 weeks. So, given travel and vacations and whatever, that's about a year. Waddya think? John Jessen (doing priming of VS and Rudder and big time rationalizing) ________________________________________________________________________________
Date: Jun 29, 2005
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)mail.sprint.com>
I have been averaging just over 20 hours per week. On July 19th, I will have been working at it for 1 year and will have just over 1,000 hours in. I have planned on 20 hours per week for 50 weeks per year. I hope to be flying at the 2,000 mark. (Oshkosh 2006) Thank You Ray Doerr 40250 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: QB in my future Thanks, Ray. How many hours per week are you averaging? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK] Subject: RE: RV10-List: QB in my future --> Sounds good except for the 800 hour savings. It took me 300 hours to get my Fuse to the Quick build stage and around 250 hours for the wings. I would except the savings to be more like 600 hour savings. Thank You Ray Doerr 40250 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: QB in my future Ok. I figured I wouldn't do a QB because it would save me almost $10,000 big ones. However, while doing some heavy thinking in the shower, I now have come up with a way to rationalize my way into a QB. It really will cost only $3,000 big ones because, and let me know if this is false economics, I'm not spending close to $7,000 during the year's time it saves me in building, on a 172 rental and staying current. I'm in the air one year sooner, hopefully, and since I typically fly 60-70 hours per year, at $110 per hour rental charge, and since the operating costs will be there for the -10 no matter what, the $$$ for the QB replaces $$$ for the rental guys. I have in my head from somewhere that the QB saves around 800 hours build time, and for me that'd be about 40 weeks. So, given travel and vacations and whatever, that's about a year. Waddya think? John Jessen (doing priming of VS and Rudder and big time rationalizing) ________________________________________________________________________________
Date: Jun 29, 2005
<42C222F8.1010800(at)cox.net> <42C2A171.3030503(at)MyRV10.com> <42C2C6A6.7010803(at)cox.net> You can get empty cartridges in several sizes from Aircraft Spruce. They're pretty inexpensive. The 2 1/2 oz size works pretty well if you're going to go that route. I never used anything larger than that. Fill them from your quart can and you get the convenience of the gun without the huge price. If you go that route don't forget the nozzles and sealing piece that goes in the back 'cause they come separately. PJ 40032 Sean Stephens wrote: > > Thanks Tim, > > I read the writeup on your site. I was hoping to be able to use the 6 > oz. cartridges as I've got a ProSeal air gun and it works really > well. Unfortunately the 6 oz. cartridges are pricey (~$23 each) > compared to the quart kit. Maybe I can just pick up one 6 oz. > cartridge and re-use the cartridge/plunger/nozzle with the quart kit. > > -Sean #40303 > > > Tim Olson wrote: > >> >> If you're really careful with it, you may get by on one can. >> I know I wasn't quite as conservative as I could have been, >> and I used a fair share of 2 cans. If a builder was >> reasonably careful, 2 cans could do all of the control >> surfaces and the tanks, and they could buy the 2 cans >> right away. Store them in the freezer for increased >> shelf life. To me, I'd rather spend an extra $40 and >> not get slowed down. You'll actually use a little on >> the firewall, and a couple other places down the road too. >> I used some to seal my hot air intake vent gaps. >> >> Tim >> >> Tim Olson -- RV-10 #170 >> Current project: Fuselage >> >> Sean Stephens wrote: >> >>> >>> What quantity of tank sealant was required to seal the tanks? Was >>> the quart kit enough to complete both tanks? >>> >>> Thanks... >>> >>> -Sean #40303 >>> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Aux fuel tanks?
Date: Jun 29, 2005
Grumpy, I am not going to argue the point with you, but I think probably the only similarities between the RV-10 and the F-16 is that they both fly. There are a lot of certified airplanes that are much more similar to the RV-10 than the F-16 that have added tip tanks as an STC, without restructuring the wing. These planes aren't pulling 8G's in an outside loop, though, which may require a little more engineering. We have actually discovered that we can fly at 12,000 feet burning 9.5 gal/hour and cruising at 178 without the wheel or gear fairings. Adding those should take us up to about 190 at least (from the reports we have read - namely Dan Checkoway). This will give us over 1,000 miles of range with an hour of reserve. We have thought all along that we wanted aux tanks, but just realized that we can probably get by without them. Just food for thought. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com Subject: Re: RV10-List: Aux fuel tanks? Guys, I'm a newcomer to building the -10, but have years of flight test experience in high performance aircraft. I would not - repeat not - add anything to the outboard section of the wing that Van has not done structural analysis on to include flight tests. I specifically recall a problem with flight test of the F-16 and outboard stores that nearly took the outboard section of the wing off. The structures guys said it would never happen (the torsional loads) until we showed them on videotape. They then said "if you let that continue, it would probably rip the wing off......" Just a thought from a guy who requires both the design engineer and flight test folks to say "it's ok"...... grumpy In a message dated 6/28/2005 4:09:11 PM Central Standard Time, gyoung@cs-sol.com writes: Having the weight at the end of the spar is typically a benefit to the load distribution in flight. It can be a detriment to the landing loads though. Case in point, my Navion tip tanks allow me to increase my gross weight BUT only by the amount of fuel carried in the tip tanks. We are also cautioned to land gently if the tips are filled. It was likely a no-analysis item back when the STC was approved. Bending loads are one thing but it will also change the handling and fore-aft sloshing will affect CG and may impart torsional loads to the wing. Look at Van's write-up on the wing design and load testing before you think about modifying it. Regards, Greg Young ________________________________ Having owned and flown a Cessna 310 for the last three years and 500 hours I'm not concerned about stability issues. C310 main tanks are the tip tanks, 50 gallons per side, the aux tanks are in the wings only 15 gallons per side. This is a very stable aircraft. My question would be about adding the loading to the end of the spar? Steve 40212 Wings ________________________________________________________________________________
Subject: Gaunlet to Scott
Date: Jun 29, 2005
From: "Scott Schmidt" <sschmidt(at)ussynthetic.com>
You basically just give them the dimensions from the front of the flange where the prop bolts on to the front of the cowling. They then cut the spinner to match this. You are still OK though. You will just have measure the distance from the end of your spinner to the mounting area, add =BC" and then fit your cowling to that dimension. Hope that makes sense. I am hoping I will be able set up the plane so that I will never have a CG problem as long as I have 50% of the fuel in the wings and full seats and baggage. With four people in the plane, someone will probably have to use the bathroom before long anyway unless we all have stadium pals or stadium gals (check these out, they are great for endurance motorcycle riding). http://www.stadiumpal.com/ Scott Schmidt sschmidt(at)ussynthetic.com ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Ritter Subject: RE: RV10-List: Gaunlet to Scott Scott - - Help me understand what cowling measurements you need before ordering the MT prop. Have I screwed up ordering the MT prop before even thinking about fitting the cowling? Mark >From: "Scott Schmidt" <sschmidt(at)ussynthetic.com> >Reply-To: rv10-list(at)matronics.com >To: >Subject: RE: RV10-List: Gaunlet to Scott >Date: Tue, 28 Jun 2005 11:40:36 -0600 > >Well John I probably will not fly until November at the earliest. My >panel is 8-10 weeks out from Aerocrafter but things are coming along >nicely. I hope to start with paint sometime in August or September, do >final panel install and finish work in October / November. I actually >thing November is pushing it for me. The finishing work really does >take a lot of time. I don't see why there will be any problems with the >MT though. With 1-3 people I will not need any weight in the back. With >4 and baggage I may build a place in the engine compartment that can be >easily outfitted with 15-20 lbs. of tungsten carbide. Anyway, I am >working on the cowling right now so I can get the proper measurements >needed to order the MT. > >Unfortunately you hit the nail on the head when I came to bike riding >though. As you were sending out your e-mail I was in the middle of this >year's 24 hour Utah 1088 endurance motorcycle ride. Placed 6th this >year (a little disappointing for me). I had so much fun this year, it >was worth the time it took away from the plane. I rode 1418 miles in >23.5 hours. After I get the feeling back into my right hand I will be >able to start working on the plane again. > >Scott Schmidt >Cell: 801-319-3094 >sschmidt(at)ussynthetic.com > _____ > >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox >Sent: Saturday, June 25, 2005 10:19 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Gaunlet to Scott > >Jim Ayers has posted repeatedly about (4X) forward commitments on the MT >prop option. His hand has been out for money but no product to >challenge Hartzell fore with. Vapor ware (for props), I know better with >MT. Gerd must have all of his dealers on a really short leash. The high >ground is getting even steeper by each day with the inaction. Orders >are being placed. Now, 95% of all the RV-10s on the radar screen are >going with Hartzell. This is a travesty. I fly an MT and it is a >quantum jump over the Whirlwind. I Can't believe no MT is available to >take on this opportunity. MORE THAN 400 opportunities lost (maybe 500 >by September). I just have to believe it can outperform a metal two >blade on resonance alone. > >When it came to the rubber meeting the road, there has been no traction >on a demonstration of the merits of an MT prop over Hartzell on ANY >RV-10 powered by either a carbureted (Doug) or fuel injected Lycoming >540 CID over the heavier Hartzell (regardless of airfoil design). Scott >the baton is in now in your court. PLEASE. Many of us are now waiting >with anticipation for your first flight and the day when you can take on >all comers with Hartzell metal just to blow the BS from the questions >and produce results on the lighter and sexier prop option. Don't tell >us its still November 2005 for the first flight. Jim is in hiding. We >know VAN is tied to Hartzell, Jim remains safely silent in his cave. Do >all of you guys really believe he doesn't read these posts. > > Don't tell us you have another bike ride taking priority over this >important build issue. Lets kick the dog and see the bite or at least >hear a muffled bark. Renae would want nothing less. > >John - KUAO ________________________________________________________________________________
Date: Jun 29, 2005
Subject: Re: Aux fuel tanks?
Jesse - not to argue a point either. The huge transients we saw were in 1g level flight, and were totally related to airspeed and weight in the outboard section of the wing as compared to inner weight (such as full inner tanks and full outer tanks????). I run the world's largest ground wind tunnel test facility (Arnold Air Force Base), so I've seen some very strange things happen when all of the engineers said that it would not happen. And you do not want to have this happen to you for the first time in actual flight (you'd rather that Van's guys prove it first). My thoughts for whatever they're worth. Grumpy - #40404 In a message dated 6/29/2005 4:39:47 PM Central Standard Time, jesse(at)itecusa.org writes: Grumpy, I am not going to argue the point with you, but I think probably the only similarities between the RV-10 and the F-16 is that they both fly. There are a lot of certified airplanes that are much more similar to the RV-10 than the F-16 that have added tip tanks as an STC, without restructuring the wing. These planes aren=E2=80=99t pulling 8G=E2=80=99s in an outside loop, though, which may require a little more engineering. We have actually discovered that we can fly at 12,000 feet burning 9.5 gal/hour and cruising at 178 without the wheel or gear fairings. Adding those should take us up to about 190 at least (from the reports we have read =E2=80=93 namely Dan Checkoway). This will give us over 1,000 miles of range with an hour of reserve. We have thought all along that we wanted aux tanks, but just realized that we can probably get by without them. Just food for thought. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org http://www.itecusa.org/ W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Jun 29, 2005
<42C222F8.1010800(at)cox.net> <42C2A171.3030503(at)MyRV10.com> <42C2C6A6.7010803(at)cox.net> <42C31246.5050406(at)seznam.cz> <42C3259D.1080408(at)cox.net> You're right! That's funny because they used to be listed; that's how I found them. You can search on the part numbers below if you want to order online. 09-00758 PLUNGER FOR PRO SEAL CARTRIDGE $.67 09-00759 PRO SEAL CARTRIDGE ONLY 2-1/2 $.66 09-00760 PRO SEAL CARTRIDGE ONLY 6 OZ $.58 EA4180 NOZZLE FOR PRO-SEAL KITS $1.20 PJ 40032 Sean Stephens wrote: > > Thanks PJ, that sounds exactly like what I need. For others looking > for these, the cartridge components aren't listed in their online > catalog. Have to call and get the part number or have the print > catalog handy, which I don't, so I ordered the free print catalog. > > -Sean #40303 - Doing the "yuk" work on the flaps. > > > PJ Seipel wrote: > >> >> You can get empty cartridges in several sizes from Aircraft Spruce. >> They're pretty inexpensive. The 2 1/2 oz size works pretty well if >> you're going to go that route. I never used anything larger than >> that. Fill them from your quart can and you get the convenience of >> the gun without the huge price. >> If you go that route don't forget the nozzles and sealing piece that >> goes in the back 'cause they come separately. >> >> PJ >> 40032 >> > > ________________________________________________________________________________
Date: Jun 30, 2005
Link below supports Michael's position to thin with Toluene and not MEK. < http://www.vansairforce.net/articles/tank_sealant.pdf <http://www.vansairforce.net/articles/tank_sealant.pdf> > cheers, Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: Tank Sealant Quantity? I believe you are supposed to use Toluene for thinning Proseal. Don't know if MEK is compatible but wouldn't want to find out on the tanks. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [ mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of Eric Panning Subject: Re: RV10-List: Tank Sealant Quantity? --> Sean, The other downside of the tubes is for many sections you have alot left over and for the tanks you will be pressed to dispense and rivet before it sets up on you. I started with the tubes but switched to mixing small batches from the cans and things are much easier. I use a small digital postal scale ($25) for getting the mix right and mix ~ 40 gram batches. I've read about at least one person thinning proseal with MEK to ease application. Is this accepted practice? It may be messy, I think the whole tank sealing process is more tedious than difficult. Based on my experience with the tubes it would be very difficult to reuse them. Your cost and time with MEK, etc to clean them out would be better spent on popsicle sticks and clecos... :) Most of the mess is in the riveting anyway. Eric --- Sean Stephens wrote: > > > Thanks Tim, > > I read the writeup on your site. I was hoping to be able to use the 6 > oz. cartridges as I've got a ProSeal air gun and it works really well. > Unfortunately the 6 oz. cartridges are pricey (~$23 > each) compared to > the quart kit. Maybe I can just pick up one 6 oz. > cartridge and re-use > the cartridge/plunger/nozzle with the quart kit. > > -Sean #40303 > ==================================== RV10-List Email Forum - more: bsp; s.com/Navigator?RV10-List ==================================== ________________________________________________________________________________
Subject: Re: Tube Flaring technique
Date: Jun 30, 2005
MessageI had a friend A&P mechanic come by the house tonight with his tool, which was the same as mine. He tried about a dozen times and everyone of his cracked also. He also tried to dip the tube in Alodine for about 15min to soften it some-no joy. He tried a couple more while taking note of the position of the crack. They all cracked about the same place along the tube. He also looked at the lip with a magnifying glass after only one turn and could detect the crack starting. Couldn't see any obvious defect to the tube. He concluded that it was a bad batch of tubing that I got. Anh #141 ----- Original Message ----- From: Gary Specketer To: rv10-list(at)matronics.com Sent: Wednesday, June 29, 2005 8:46 AM Subject: RE: RV10-List: Tube Flaring technique One of the tricks is to have fresh tubing. My Glasair kit had tubing that would not flair. I had to get replacement tubing. Cut a sample or two and bring them to a friend and have him try it. That will tell you if it is technique or tubing. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Sent: Tuesday, June 28, 2005 11:12 PM To: RV10 Subject: RV10-List: Tube Flaring technique What's the trick to good flares? I did fine for half of the tubes and then managed to crack every one. I tried to carefully cut with a tube cutter, a little at a time, make sure the ends are squared, deburred. I have one of those sliding block flaring tools (37deg). One fella in the archive mentioned leaving 5/16" of the tube protruding through the block and turn 7 half turns. Anh #141 ________________________________________________________________________________ ;
Date: Jun 29, 2005
Thanks, I didn't thin it on the left tank. Wasn't that bad so I will likely use it straight on the right. Good to know though. Perhaps I will try it on something none critical like the trailing edges. The web site I saw the builder thinned out until he could spread with a small acid brush. (Also used for applying flux for welding, etc) As to the tubes, I guess if you have the air gun and get the empty tubes, then fill them in small batches, this might be the best way. However, the messy part is still mostly riveting and not the application. Eric --- "McGANN, Ron" wrote: > > > Link below supports Michael's position to thin with > Toluene and not MEK. > > < > http://www.vansairforce.net/articles/tank_sealant.pdf > <http://www.vansairforce.net/articles/tank_sealant.pdf> > > > > cheers, > Ron > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com]On > Behalf Of RV Builder > (Michael Sausen) > Sent: Thursday, 30 June 2005 3:34 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Tank Sealant Quantity? > > > > I believe you are supposed to use Toluene for > thinning Proseal. Don't know > if MEK is compatible but wouldn't want to find out > on the tanks. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [ > mailto:owner-rv10-list-server(at)matronics.com > ] On > Behalf Of Eric Panning > Sent: Wednesday, June 29, 2005 11:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Tank Sealant Quantity? > > --> > > Sean, > > The other downside of the tubes is for many sections > you have alot left over > and for the tanks you will be pressed to dispense > and rivet before it sets > up on you. I started with the tubes but switched to > mixing small batches > from the cans and things are much easier. I use a > small digital postal scale > ($25) for getting the mix right and mix ~ 40 gram > batches. > > I've read about at least one person thinning proseal > with MEK to ease > application. Is this accepted practice? It may be > messy, I think the whole > tank sealing process is more tedious than difficult. > > Based on my experience with the tubes it would be > very difficult to reuse > them. Your cost and time with MEK, etc to clean them > out would be better > spent on popsicle sticks and clecos... :) Most of > the mess is in the > riveting anyway. > > Eric > > --- Sean Stephens wrote: > > > > > > > Thanks Tim, > > > > I read the writeup on your site. I was hoping to > be able to use the 6 > > oz. cartridges as I've got a ProSeal air gun and > it works really well. > > Unfortunately the 6 oz. cartridges are pricey > (~$23 > > each) compared to > > the quart kit. Maybe I can just pick up one 6 oz. > > cartridge and re-use > > the cartridge/plunger/nozzle with the quart kit. > > > > -Sean #40303 > > > > > > ==================================== > RV10-List Email Forum - > more: > bsp; > s.com/Navigator?RV10-List > ==================================== > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > > > > > ________________________________________________________________________________ ;
Date: Jun 29, 2005
Subject: Re: Van's Conduit In Wing
More conduit questions.... I've decided to use the van's conduit and picked up 50 feet of it from them today. Looks like I need to drill the rib holes from the current 5/8ths to 11/16ths for the smaller outer radius of the corrigated conduit. The other option would be to drill to the outer radius of the conduit and then hold it in place somehow. Which is the preferred method? I'm guessing drill 11/16ths, stuff it though and it will self lock. Is this correct? Thanks! Eric ________________________________________________________________________________
Date: Jun 29, 2005
Ron, thanks for sharing the hard work, accurate research and reason why MEK should be avoided as a viscosity reducer. John Cox - KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron Subject: RE: RV10-List: Tank Sealant Quantity? Link below supports Michael's position to thin with Toluene and not MEK. < http://www.vansairforce.net/articles/tank_sealant.pdf <http://www.vansairforce.net/articles/tank_sealant.pdf> > cheers, Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: Tank Sealant Quantity? I believe you are supposed to use Toluene for thinning Proseal. Don't know if MEK is compatible but wouldn't want to find out on the tanks. Michael ________________________________________________________________________________
Date: Jun 30, 2005
I don't remember the exact measurement I drilled to, but I drilled to the outer measurement of the smaller diameter of the conduit (in the low spots) but then deburred it slightly larger because that was hard to pull. I didn't go all the way to the outer diameter of the conduit. By the time I got done, it wasn't too bad to pull, with 2 people. It was pretty close to that outer diameter, just not all the way there. Tim Olson -- RV-10 #170 Current project: Fuselage Eric Panning wrote: > > More conduit questions.... > > I've decided to use the van's conduit and picked up 50 > feet of it from them today. > > Looks like I need to drill the rib holes from the > current 5/8ths to 11/16ths for the smaller outer > radius of the corrigated conduit. The other option > would be to drill to the outer radius of the conduit > and then hold it in place somehow. > > Which is the preferred method? I'm guessing drill > 11/16ths, stuff it though and it will self lock. Is > this correct? > > Thanks! > > Eric > ________________________________________________________________________________
Subject: Tube Flaring technique
Date: Jun 30, 2005
Glad I could help. Hope you get some good stuff to replace it. Check some samples of the new batch before you pay for it. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: Re: RV10-List: Tube Flaring technique I had a friend A&P mechanic come by the house tonight with his tool, which was the same as mine. He tried about a dozen times and everyone of his cracked also. He also tried to dip the tube in Alodine for about 15min to soften it some-no joy. He tried a couple more while taking note of the position of the crack. They all cracked about the same place along the tube. He also looked at the lip with a magnifying glass after only one turn and could detect the crack starting. Couldn't see any obvious defect to the tube. He concluded that it was a bad batch of tubing that I got. Anh #141 ----- Original Message ----- From: Gary <mailto:speckter(at)comcast.net> Specketer Subject: RE: RV10-List: Tube Flaring technique One of the tricks is to have fresh tubing. My Glasair kit had tubing that would not flair. I had to get replacement tubing. Cut a sample or two and bring them to a friend and have him try it. That will tell you if it is technique or tubing. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: RV10-List: Tube Flaring technique What's the trick to good flares? I did fine for half of the tubes and then managed to crack every one. I tried to carefully cut with a tube cutter, a little at a time, make sure the ends are squared, deburred. I have one of those sliding block flaring tools (37deg). One fella in the archive mentioned leaving 5/16" of the tube protruding through the block and turn 7 half turns. Anh #141 ________________________________________________________________________________ ;
Date: Jun 30, 2005
Thanks for the quick reponses, I think I will follow Tim's input. I wish I had made up my mind prior to assembling the wings (except for the bottom skins) as it is a tight fit for some of the holes (+ the chips!) I built it to plans but it is a real tight fit through the stock bushings. I have strobe, AoA, autopilot harness, nav lighting, pitot heat and landing lights to run. Eric --- wlucas(at)nc.rr.com wrote: --------------------------------- I read on some RV construction sites where the conduit holes have been drilled out to the OD of the conduit. This makes it easy to pull the conduit through the holes in the ribs. Then, electrical cable zip ties are placed on each side of a rib, tighten to ensure a good grip on the conduit, and the excess snipped off. With a zip tie fastened to each side of the rib, that baby's not going anywhere. Just a thought! Wade ----- Original Message ----- From: Tim Olson <Tim(at)MyRV10.com> Date: Thursday, June 30, 2005 7:37 am Subject: Re: RV10-List: Van's Conduit In Wing > > I don't remember the exact measurement I drilled to, but I > drilled to the outer measurement of the smaller diameter of > the conduit (in the low spots) but then deburred it slightly > larger because that was hard to pull. I didn't go all the way > to the outer diameter of the conduit. By the time I got done, > it wasn't too bad to pull, with 2 people. It was pretty close > to that outer diameter, just not all the way there. > > Tim Olson -- RV-10 #170 > Current project: Fuselage > > > Eric Panning wrote: rv10(at)yahoo.com>> > > More conduit questions.... > > > > I've decided to use the van's conduit and picked up 50 > > feet of it from them today. > > > ________________________________________________________________________________
Date: Jun 30, 2005
I would be cautious about putting cable ties where you can't get to them later. In my experience, a cable tie outdoors does not last more than a few years; Indoors they may last 5 years or so. What happens is that they get brittle and just come apart in pieces. One more tip: Avoid the black ties anyplace where there can be sunlight. Even the "UV Stabilized" black ties seem to fail very quickly (on the order of a year or so.) -Jim 40384 wlucas(at)nc.rr.com wrote: > > I read on some RV construction sites where the conduit holes have been > drilled out to the OD of the conduit. This makes it easy to pull the > conduit through the holes in the ribs. Then, electrical cable zip > ties are placed on each side of a rib, tighten to ensure a good grip > on the conduit, and the excess snipped off. With a zip tie fastened > to each side of the rib, that baby's not going anywhere. Just a thought! > > Wade > > *----- Original Message -----* > > *From*: Tim Olson *Date*: Thursday, June 30, 2005 > 7:37 am *Subject*: Re: RV10-List: Van's Conduit In Wing > --> > > > > I don't remember the exact measurement I drilled to, but I > > drilled to the outer measurement of the smaller diameter of > > the conduit (in the low spots) but then deburred it slightly > > larger because that was hard to pull. I didn't go all the way > > to the outer diameter of the conduit. By the time I got done, > > it wasn't too bad to pull, with 2 people. It was pretty close > > to that outer diameter, just not all the way there. > > > > Tim Olson -- RV-10 #170 > > Current project: Fuselage > > > > > > Eric Panning wrote: > > rv10(at)yahoo.com>> > > > More conduit questions.... > > > > > > I've decided to use the van's conduit and picked up 50 > > > feet of it from them today. ________________________________________________________________________________
Subject: Van's Conduit In Wing
Date: Jun 30, 2005
I used a 13/16" first but had a hard time pulling the conduit through. I then opened it up to 7/8" and that seemed to work much better. It is much easier to pull through but is not going to go anywhere. http://freedomflyers.com/forums/showthread.php?p=25#post25 Scott Schmidt Cell: 801-319-3094 sschmidt(at)ussynthetic.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Panning Subject: Re: RV10-List: Van's Conduit In Wing More conduit questions.... I've decided to use the van's conduit and picked up 50 feet of it from them today. Looks like I need to drill the rib holes from the current 5/8ths to 11/16ths for the smaller outer radius of the corrigated conduit. The other option would be to drill to the outer radius of the conduit and then hold it in place somehow. Which is the preferred method? I'm guessing drill 11/16ths, stuff it though and it will self lock. Is this correct? Thanks! Eric ________________________________________________________________________________
Date: Jun 30, 2005
Subject: Newbe!!!!!
Just wanted to introduce Julie and I to you. We have been following your emails with great interest, but have never posted any of our own. We started our RV-10 empenage April 25th finished yesterday. Waiting for fuselage and wings end of July. Slow build. We have learned a lot just reading your posts thanks for all the info. We will have all glass panel, new lycoming, tip tanks, aero composite 2 blade prop. This is the first kit plane we have built. We have restored several antique aircraft. Working with all new parts is a dream!!!! Julie, my wife works right along with me everyday and couldn t get it done without her. Keep us the good work, you all are a great inspiration. Blue Skies Jim & Julie Wade 40383 ________________________________________________________________________________
Date: Jun 30, 2005
Subject: Re: Newbe!!!!!
Welcome neighbor! I'm just starting the Elevators, and am working totally alone so it appears you're way ahead of me now! What tip tanks are you going to use? -Jim 40384 Jim Wade wrote: > Just wanted to introduce Julie and I to you. We have been following > your emails with great interest, but have never posted any of our own. > We started our RV-10 empenage April 25th finished yesterday. Waiting > for fuselage and wings end of July. Slow build. We have learned a lot > just reading your posts, thanks for all the info. We will have all > glass panel, new lycoming, tip tanks, aero composite 2 blade prop. > This is the first kit plane we have built. We have restored several > antique aircraft. Working with all new parts is a dream!!!! Julie, my > wife works right along with me everyday and couldn't get it done > without her. Keep us the good work, you all are a great inspiration. > Blue Skies > Jim & Julie Wade > 40383 > > > > ________________________________________________________________________________
Date: Jun 30, 2005
report You claim to be a newbie yet you've already finished the empenage!! I JUST ordered my tail kit so I've got to be the newest RV10 builder (at least for the next day or two). Strangely I think my wife Christine is more pumped about the project than I am and I hate to admit it, but at this point she's a better riveter than I am. Oh well. I'm sure to get plenty of practice in the next month or two. Anyway, good luck and keep us posted on your progress.... -Brian Iowa City, IA ----- Original Message ----- From: Jim Wade To: rv10-list(at)matronics.com Sent: Thursday, June 30, 2005 12:45 PM Subject: RV10-List: Newbe!!!!! Just wanted to introduce Julie and I to you. We have been following your emails with great interest, but have never posted any of our own. We started our RV-10 empenage April 25th finished yesterday. Waiting for fuselage and wings end of July. Slow build. We have learned a lot just reading your posts, thanks for all the info. We will have all glass panel, new lycoming, tip tanks, aero composite 2 blade prop. This is the first kit plane we have built. We have restored several antique aircraft. Working with all new parts is a dream!!!! Julie, my wife works right along with me everyday and couldn't get it done without her. Keep us the good work, you all are a great inspiration. Blue Skies Jim & Julie Wade 40383 ________________________________________________________________________________ ;
Date: Jun 30, 2005
In general I agree with Grumpy. The idea that if you add weight to the outboard wing you will eventually have problems is a given. The only unknown is for a particular design at what point it occurs. I don't think any of the builders know this at this time and Van's might not have a good handle on it either. The problem is considerably more complex than one might envision, which is brought to light by the statement that what happened to the F16 wing was surprising to the engineers working on it. Once a few RV10s with mods accumulate some hours we will have a better idea of how strong the wing is and how much more load it can safely take if any. It is also not a matter of if the aircraft are similar or not. Its simply a matter of what the static and fatigue margins are, what the aeroelastic response of the wing is, how much the loads are increased and how the load distributions have changed. I would advise extreme caution during any deviation from what Van's intended. In most cases small changes work out okay because the margins are usually high but not always. We know of at least one RV8 crash where the wing broke. To my knowledge the cause has not been determined. In fact, I remember reading another case in the Rviator where one of the 2 seater RV's encountered flutter. Also keep in mind that as a general rule of thumb a 10% increase in load (stress) will halve the fatigue life. Developing a fatigue crack in the spar is usually not a good thing. I am not saying that adding the outboard tanks is a problem or not a problem. I simple suggesting that builders take any mods seriously. Also remember that Vans did not test the wing to failure. The structure was clearly straining during the test as evidenced by all the noise per the test report, and your wing might not be as strong as the one that was tested. The above is just my opinion, I know not all agree with it and thats ok. GenGrumpy(at)aol.com wrote: Jesse - not to argue a point either. The huge transients we saw were in 1g level flight, and were totally related to airspeed and weight in the outboard section of the wing as compared to inner weight (such as full inner tanks and full outer tanks????). I run the world's largest ground wind tunnel test facility (Arnold Air Force Base), so I've seen some very strange things happen when all of the engineers said that it would not happen. And you do not want to have this happen to you for the first time in actual flight (you'd rather that Van's guys prove it first). My thoughts for whatever they're worth. Grumpy - #40404 In a message dated 6/29/2005 4:39:47 PM Central Standard Time, jesse(at)itecusa.org writes: Grumpy, I am not going to argue the point with you, but I think probably the only similarities between the RV-10 and the F-16 is that they both fly. There are a lot of certified airplanes that are much more similar to the RV-10 than the F-16 that have added tip tanks as an STC, without restructuring the wing. These planes arent pulling 8Gs in an outside loop, though, which may require a little more engineering. We have actually discovered that we can fly at 12,000 feet burning 9.5 gal/hour and cruising at 178 without the wheel or gear fairings. Adding those should take us up to about 190 at least (from the reports we have read namely Dan Checkoway). This will give us over 1,000 miles of range with an hour of reserve. We have thought all along that we wanted aux tanks, but just realized that we can probably get by without them. Just food for thought. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org http://www.itecusa.org/ W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Jun 30, 2005
Thanks for the reply; My interest is probably more for the insulation characteristics. I am in the South Georgia area and the heat can be nasty. Can't seem to get to altitude quick enough. Aircraft Spruce has something called "The Insulator" that looks interesting. May give it a try and see how it works. Has anyone else tried this material? Thanks, Byron Starting on the fuselage sides # 40253 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: Firewall Insualtion? I have not installed the firewall sound insulation yet. What is interesting is that a good friend of mine flew with me in 10 the other day and was astounded at how quite the 10 is without the insulation in place. He was sure it would be one of the first things that I would want to get done after the first flights. Now we said he wouldn't think you would even need it. I will be putting it in. The material I have is from Hi Tec foams. Randy _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Byron Gillespie Subject: RV10-List: Firewall Insualtion? What are any of you doing relative to firewall insulation? I have searched the archives and have found very little info. I am putting together an order to Aircraft Spruce and noticed that they have several different types. Thought that I would add it on to the floor insulation order. Just ordered my fuel pumps, etc from Vans yesterday. Just looking to those who have (and are) forged ahead for the usual guidance. Thanks, Byron More fuselage decisions - # 40253 ________________________________________________________________________________
Subject: Second Battery
Date: Jun 30, 2005
I have searched the archives and not found an answer to the following questions. To those of you who are going to use a dual electrical system, where have you placed the second battery? What is the effect does the placement have on weight and balance. Thanks for you help Dick Gurley #40414 ________________________________________________________________________________
Subject: Re: Second Battery
Date: Jun 30, 2005
I modified the battery tray to accept a pair of PC-680s (17 AH each) instead of the stock single 25 AH battery. Adds a few pounds total weight but I opted for extra redundancy that will partially offset the ballast that the factory carries. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: RV10-List: Second Battery I have searched the archives and not found an answer to the following questions. To those of you who are going to use a dual electrical system, where have you placed the second battery? What is the effect does the placement have on weight and balance. Thanks for you help Dick Gurley #40414 ________________________________________________________________________________
Date: Jul 01, 2005
Hey Bob, Do you have any photos of your tray mod? cheers, Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Condrey, Bob (US SSA) Subject: Re: RV10-List: Second Battery I modified the battery tray to accept a pair of PC-680s (17 AH each) instead of the stock single 25 AH battery. Adds a few pounds total weight but I opted for extra redundancy that will partially offset the ballast that the factory carries. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com Subject: RV10-List: Second Battery I have searched the archives and not found an answer to the following questions. To those of you who are going to use a dual electrical system, where have you placed the second battery? What is the effect does the placement have on weight and balance. Thanks for you help Dick Gurley #40414 ________________________________________________________________________________
Date: Jun 30, 2005
Subject: Tank Sealant Quantity?
As a bonafide card carrying OSHA compliance officer I can give you several reasons to avoid BOTH of these chemicals. Anyone ever have a low grade headache for a few days after working on your tanks? If not you didn't get your head into the mix good enough, or you had an SCBA, organic masks provide a low level (read not much) of protection and over a period of two hours your polluted. Toulene makes wonderful explosions, MEK is less volatile due to a higher boiling point. Guys, get outside if possible. I finished hazardous materials refresher this week. Explained my low grade 5 day headache. (Tanks!!!!) I won't open the old aluminum dust explosion conversations again. If you have a pile of that dust around your grinder, ground yourself and carefully sweep it into the trash bin. DON'T use your shop vac...static electricity can work wonders to light off that stuff. Damn videos scare the crap outta ya!! Rick S. 40185 Wings (Almost done,...staring at the tips) waiting for the fuse. ________________________________________________________________________________
Date: Jun 30, 2005
Eric, 7/8" worked perfect for me...remember you need to allow the ribs to move when doing the bottom skins. Try to get them at a perfect 90 to the spar prior to siliconing the conduit to the ribs. I applied silicone prior to clecoing the skins on and match drilling to make sure the conduit was straight and not to loose or tight prior to completing the bottom skins. Rick S. 40185 Tips ________________________________________________________________________________
Date: Jun 30, 2005
Um9uLA0KIA0KUGljdHVyZXMgYXR0YWNoZWQuICBJIGFsc28ganVzdCBjaGVja2VkIHRoZSBzcGVj cyAtIHRoZSBDb25jb3JkZSBSRy0yNVhDIGlzIDI0IEFIIGFuZCB3ZWlnaHMgMjMuNSBsYnMuICBF YWNoIFBDLTY4MCBpcyAxNiBBSCBhbmQgd2VpZ2hzIDE0LjUgbGJzLiAgRGltZW5zaW9uYWxseSwg dGhlIGJhdHRlcnkgdHJheSBoYWQgdG8gYmUgd2lkZW5lZCBieSBhbiBpbmNoIG9yIHNvIGFuZCBt YWRlIHNoYWxsb3dlciBieSBhIGZyYWN0aW9uIG9mIGFuIGluY2guICBJIGNob3NlIHRvIHVzZSBz b21lIDMvNCIgLjA2MyBzdG9jayB0byBtb3VudCB0aGUgcGFpciBvZiBjb250YWN0b3JzIG9uIHVz aW5nIHRoZSBzdG9jayBudXRwbGF0ZXMgdG8gYXR0YWNoIHRvIHRoZSBiYXR0ZXJ5IHRyYXkuICBU cmF5IHdhcyB3aWRlbmVkIHdpdGggLjA2MyBzaGVldCBhbmQgYW5nbGUuDQogDQpCb2IgIzQwMTA1 DQogDQoNCgktLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLSANCglGcm9tOiBvd25lci1ydjEwLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20gb24gYmVoYWxmIG9mIE1jR0FOTiwgUm9uIA0KCVNlbnQ6 IFRodSAwNi8zMC8yMDA1IDA2OjI2IFBNIA0KCVRvOiAncnYxMC1saXN0QG1hdHJvbmljcy5jb20n IA0KCUNjOiANCglTdWJqZWN0OiBSRTogUlYxMC1MaXN0OiBTZWNvbmQgQmF0dGVyeQ0KCQ0KCQ0K DQoJLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIk1jR0FOTiwgUm9uIiA8cm9uLm1j Z2FubkBiYWVzeXN0ZW1zLmNvbT4gDQoNCglIZXkgQm9iLCANCg0KCURvIHlvdSBoYXZlIGFueSBw aG90b3Mgb2YgeW91ciB0cmF5IG1vZD8gDQoNCgljaGVlcnMsIA0KCVJvbiANCg0KCS0tLS0tT3Jp Z2luYWwgTWVzc2FnZS0tLS0tIA0KCUZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbSANCglbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV1P biBCZWhhbGYgT2YgQ29uZHJleSwgQm9iIA0KCShVUyBTU0EpIA0KCVNlbnQ6IEZyaWRheSwgMSBK dWx5IDIwMDUgODo1MCBBTSANCglUbzogUlYxMC1MaXN0QG1hdHJvbmljcy5jb20gDQoJU3ViamVj dDogUmU6IFJWMTAtTGlzdDogU2Vjb25kIEJhdHRlcnkgDQoNCg0KCS0tPiBSVjEwLUxpc3QgbWVz c2FnZSBwb3N0ZWQgYnk6ICJDb25kcmV5LCBCb2IgKFVTIFNTQSkiIA0KCTxib2IuY29uZHJleUBi YWVzeXN0ZW1zLmNvbT4gDQoNCglJIG1vZGlmaWVkIHRoZSBiYXR0ZXJ5IHRyYXkgdG8gYWNjZXB0 IGEgcGFpciBvZiBQQy02ODBzICgxNyBBSCBlYWNoKSBpbnN0ZWFkIA0KCW9mIHRoZSBzdG9jayBz aW5nbGUgMjUgQUggYmF0dGVyeS4gIEFkZHMgYSBmZXcgcG91bmRzIHRvdGFsIHdlaWdodCBidXQg SSANCglvcHRlZCBmb3IgZXh0cmEgcmVkdW5kYW5jeSB0aGF0IHdpbGwgcGFydGlhbGx5IG9mZnNl dCB0aGUgYmFsbGFzdCB0aGF0IHRoZSANCglmYWN0b3J5IGNhcnJpZXMuIA0KDQoJQm9iIA0KCS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tIA0KCVNlbnQgZnJvbSBteSBCbGFja0JlcnJ5IFdpcmVs ZXNzIEhhbmRoZWxkIA0KDQoNCgktLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLSANCglGcm9tOiBv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gDQoJPG93bmVyLXJ2MTAtbGlzdC1z ZXJ2ZXJAbWF0cm9uaWNzLmNvbT4gDQoJVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIDxydjEw LWxpc3RAbWF0cm9uaWNzLmNvbT4gDQoJU2VudDogVGh1IEp1biAzMCAxNjowMToyNCAyMDA1IA0K CVN1YmplY3Q6IFJWMTAtTGlzdDogU2Vjb25kIEJhdHRlcnkgDQoNCglJIGhhdmUgc2VhcmNoZWQg dGhlIGFyY2hpdmVzIGFuZCBub3QgZm91bmQgYW4gYW5zd2VyIHRvIHRoZSBmb2xsb3dpbmcgDQoJ cXVlc3Rpb25zLiAgVG8gdGhvc2Ugb2YgeW91IHdobyBhcmUgZ29pbmcgdG8gdXNlIGEgZHVhbCBl bGVjdHJpY2FsIHN5c3RlbSwgDQoJd2hlcmUgaGF2ZSB5b3UgcGxhY2VkIHRoZSBzZWNvbmQgYmF0 dGVyeT8gIFdoYXQgaXMgdGhlIGVmZmVjdCBkb2VzIHRoZSANCglwbGFjZW1lbnQgaGF2ZSBvbiB3 ZWlnaHQgYW5kIGJhbGFuY2UuIA0KDQoJDQoNCglUaGFua3MgZm9yIHlvdSBoZWxwIA0KDQoJDQoN CglEaWNrIEd1cmxleSANCg0KCSM0MDQxNCANCg0KDQoNCg0KDQoNCg0KDQoNCgkNCgkgIA0KCSAg DQoNCg0KDQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0gDQoJXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1 bSAtIA0KCV8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBi cm93c2UgDQoJXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgdGhlIFN1YnNjcmlw dGlvbnMgcGFnZSwgDQoJXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dz ZSwgQ2hhdCwgRkFRLCANCglfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOiANCglf LT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgDQoJXy09IC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdCANCglfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PSAN Cg0KDQoNCgkNCgkgIA0KCSAgDQoNCg0K ________________________________________________________________________________
From: "Neville Murray" <alpinesr(at)onthenet.com.au>
Subject: cancellation
Date: Jun 01, 2005
Please remove my email address from your list. Thank you for the information that you have provided. Regards Neville ________________________________________________________________________________
Date: Jul 01, 2005
The dual Odyssey batteries seem like a pretty slick idea. Anyone have any practical CG numbers that could see if there's any potential situation with too aft a CG with the extra 5.5lbs at the battery location? To further the question, I know there was a PDF file posted from the finishing kit weight & balance info but I can't find it in the archives. Could someone steer me in the right direction? Thanks, Marcus 40286 QB wings & finishing kit shipping next week -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Subject: Re: RV10-List: Second Battery I modified the battery tray to accept a pair of PC-680s (17 AH each) instead of the stock single 25 AH battery. Adds a few pounds total weight but I opted for extra redundancy that will partially offset the ballast that the factory carries. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com Subject: RV10-List: Second Battery I have searched the archives and not found an answer to the following questions. To those of you who are going to use a dual electrical system, where have you placed the second battery? What is the effect does the placement have on weight and balance. Thanks for you help Dick Gurley #40414 ________________________________________________________________________________
Date: Jun 30, 2005
<http://www.myrv10.com/tips/index.html> Posted April 30th at 7:42PM from Tim's site. I have created a nifty excel sheet which allows unlimited manipulation of weights and balance changes. And I have requested Tim give me the datum arm to the rear tie down mount for that 70 pound jettisonable water bottle idea. That's 12147 inch pounds to relocate along the longitudinal somewhere. Shaking the bush. John _ KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Subject: RE: RV10-List: Second Battery The dual Odyssey batteries seem like a pretty slick idea. Anyone have any practical CG numbers that could see if there's any potential situation with too aft a CG with the extra 5.5lbs at the battery location? To further the question, I know there was a PDF file posted from the finishing kit weight & balance info but I can't find it in the archives. Could someone steer me in the right direction? Thanks, Marcus 40286 QB wings & finishing kit shipping next week ________________________________________________________________________________
Date: Jul 01, 2005
Not sure how to reply to this,hope this works.Using Safeair1 tip tanks. -------Original Message------- From: James Hein Date: 06/30/05 13:17:18 Subject: Re: RV10-List: Newbe!!!!! Welcome neighbor! I'm just starting the Elevators, and am working totally alone so it appears you're way ahead of me now! What tip tanks are you going to use? -Jim 40384 Jim Wade wrote: > Just wanted to introduce Julie and I to you. We have been following > your emails with great interest, but have never posted any of our own. > We started our RV-10 empenage April 25th finished yesterday. Waiting > for fuselage and wings end of July. Slow build. We have learned a lot > just reading your posts, thanks for all the info. We will have all > glass panel, new lycoming, tip tanks, aero composite 2 blade prop. > This is the first kit plane we have built. We have restored several > antique aircraft. Working with all new parts is a dream!!!! Julie, my > wife works right along with me everyday and couldn't get it done > without her. Keep us the good work, you all are a great inspiration. > Blue Skies > Jim & Julie Wade > 40383 > > ________________________________________________________________________________
Date: Jul 01, 2005
W&B info is on Tim's website at www.myrv10.com/tips/index.html along with a bunch of other useful info. Also, it's it bit more than 5.5 lbs as a total if you figure in the battery contactor. With that said though, it was Van's intent to have the CG as far forward as possibly because it's easy to move it aft (ballast, luggage, etc). It would be pretty difficult to move it the other way though. Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Subject: RE: RV10-List: Second Battery The dual Odyssey batteries seem like a pretty slick idea. Anyone have any practical CG numbers that could see if there's any potential situation with too aft a CG with the extra 5.5lbs at the battery location? To further the question, I know there was a PDF file posted from the finishing kit weight & balance info but I can't find it in the archives. Could someone steer me in the right direction? Thanks, Marcus 40286 QB wings & finishing kit shipping next week -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Subject: Re: RV10-List: Second Battery I modified the battery tray to accept a pair of PC-680s (17 AH each) instead of the stock single 25 AH battery. Adds a few pounds total weight but I opted for extra redundancy that will partially offset the ballast that the factory carries. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com Subject: RV10-List: Second Battery I have searched the archives and not found an answer to the following questions. To those of you who are going to use a dual electrical system, where have you placed the second battery? What is the effect does the placement have on weight and balance. Thanks for you help Dick Gurley #40414 ________________________________________________________________________________
Date: Jul 01, 2005
Subject: Re: -10 Static Ports. Just my opinion
<001301c57c5a$f5e20b60$e3926947@starnfamily> <42C21E48.2000603(at)tpg.com.au> <003801c57c70$396f6430$e3926947@starnfamily> G'day, JOHN STARN wrote: > Again I'm sorry for my assumption. So as not make another error, Scott > you did countersink the face of the port ? KABONG Short answer - Yes. Long answer - The Safeair1 ports have a series of dimples on their rear surface (see the Safeair1 website for pics). This allows the easy drilling of the port to suit 2, 3, 4 or 6 rivet spacing. I chose 3 as I figured it was aesthetically best with good attachment of the port to the skin. I then match-drilled the skin to the port (after Unibit-ing Van's pre-punched static hole to 1/4"), dimpled the skin and countersunk the holes on the ports until they sat flush to the skin. Rivets were easily squeezed. Have fun, Scott Lewis RV-10 40172 VH-DRS Adelaide, South Australia ________________________________________________________________________________ ;
Date: Jul 01, 2005
Subject: Toxic Solvents - Tank Sealant Quantity?
Here is another reason to avoid excess chemicals. Early this year I was doing some refinish work on my glider with the usual automotive paints. I was using the same precautions I had always used when building the glider (painted with Delstar automotive paints) and the RV-6A (primed with self etching primer inside painted with Imron on the outside). These consisted spraying with a respirator for most of the automotive paint and a positive pressure mask for the Imron. Cleanup was usually done with acetone or the paint thinner. Some effort was made to protect my hands from exposure to the solvents. When spraying small quantities, I generally did not set up the positive pressure system, but had fans to ventilate the area. I probably have used 100 gallons of acetone in my workshop. About February I started having strange feelings in my feet. Was originally diagnosed as a ruptured disk and treated with rest and physical therapy. When this did nothing, they did the MRI which found nothing in the back. Further work came to the conclusion of nerve damage due to exposure to toxic solvents. So now I can't wear tight shoes, and have this feeling like my feet are asleep. According to the Dr's It may or may not go away, in another year or so. I am fortunate that the arms and hands were not impacted, would prevent me from doing a -10 when I retire. (I plan on minimal priming and using an Alodine pencil.) This is suppose to happen only with "chronic" exposure to solvents, except when it takes less. Just a warning. Bruce Patton Rick wrote: As a bonafide card carrying OSHA compliance officer I can give you several reasons to avoid BOTH of these chemicals. ________________________________________________________________________________ ;
Date: Jul 01, 2005
Subject: Re: - Aileron bearing
When assembling the aileron hinge bracket assemblies I'm looking at the inside of the bearing mount hole on W-1013A. I have deburred the edge of the hole. Do I need to LIGHTLY dress the inside of the hole surface before pressing the bearing in? I realize the hole still needs to be the correct size for a "press fit". Steve 40212 ________________________________________________________________________________
Date: Jul 01, 2005
I made sure the edges of the parts were debured. (I am using rattle can self etching primer, as part of the get it ready to prime, I use 3M Scotchbright on a palm sander to scuff the part for a few seconds then prime). Following that operation I pressed the three parts together (with bearing in place). Clecoed and riveted accordingly. The result was a good fit with the three bracket parts closed at the bearing edge. You just don't want the outside bearing race to freely turn. It did take some force to press the three parts together (I used a vise with appropriate sized 3/8" sockets to localize the clamping force on the area around the outside perimeter of the bearing). Jim C N312F Reserved, Fuselage ---------- Original Message ---------------------------------- From: Darton Steve <sfdarton(at)yahoo.com> Date: Fri, 1 Jul 2005 08:14:06 -0700 (PDT) When assembling the aileron hinge bracket assemblies I'm looking at the inside of the bearing mount hole on W-1013A. I have deburred the edge of the hole. Do I need to LIGHTLY dress the inside of the hole surface before pressing the bearing in? I realize the hole still needs to be the correct size for a "press fit". Steve 40212 ________________________________________________________________________________
Subject: New medical condition to report
Date: Jul 01, 2005
Ok. There's a new medical condition that has come to my attention only recently, directly ascribable to RV construction. It's called Buildis Interruptus, and it rears its ugly head whenever the builder first realizes that travel or deck building or some other obligation will put him/her in a position away from the project by more than a 24 hour period. Symptoms generally include: 1. reading saved RV-10 email more than twice; 2. searching the web for more RV-10 sites; 3. while traveling, reading the new tool and avionics catalogs cover to cover; 4. cursing that you didn't bring the build manual with you on the trip; 5. not talking to your significant other who demanded the (take your pick) deck, patio, addition, vacation, house painting, tree removal...; 6. making sounds as if you are the pneumatic squeezer and drill (but coming up with interesting staccato beats, nonetheless); 7. sketching out the storage stand yet to be built for your Empennage and Cone and Wings; 8. scheming how to put up your own builder's web site (you mean there's computer languages beyond Fortran, Cobol and Lisp?); 9. general malaise and inconsolable depression, and 10. obsessive whining and pleading to your significant other (thereby losing all future positions of negotiating strength) that you want to quit whatever it is you've been forced to do and get back to Baby. There is no known cure other than reconnection with the project. Once back at the project, however, there is a problem often suffered by those who have contracted Buildis Interruptus. It's called Cleco Oversqueezus. It occurs when the recovering Buildis Interruptus patient, deprived of the habit forming project drug, over indulges by staying at the build site for more than 15 hours straight, cutting, clecoing and deburring everything in sight. Happy 4th, all. John Jessen (3200 miles from my project, and 8 days away from getting back) ________________________________________________________________________________
Date: Jul 01, 2005
Funny post, but yet so true. I'm leaving for a two week vacation in a week and going to stop by Oshkosh on my way back. Right now I'm finding myself hoping the two weeks of vacation goes really fast so I can get to Oshkosh and back to my project. I don't think I can remember wishing a vacation would ever go fast before! Thank You Ray Doerr 40250 -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: New medical condition to report Ok. There's a new medical condition that has come to my attention only recently, directly ascribable to RV construction. It's called Buildis Interruptus, and it rears its ugly head whenever the builder first realizes that travel or deck building or some other obligation will put him/her in a position away from the project by more than a 24 hour period. Symptoms generally include: 1. reading saved RV-10 email more than twice; 2. searching the web for more RV-10 sites; 3. while traveling, reading the new tool and avionics catalogs cover to cover; 4. cursing that you didn't bring the build manual with you on the trip; 5. not talking to your significant other who demanded the (take your pick) deck, patio, addition, vacation, house painting, tree removal...; 6. making sounds as if you are the pneumatic squeezer and drill (but coming up with interesting staccato beats, nonetheless); 7. sketching out the storage stand yet to be built for your Empennage and Cone and Wings; 8. scheming how to put up your own builder's web site (you mean there's computer languages beyond Fortran, Cobol and Lisp?); 9. general malaise and inconsolable depression, and 10. obsessive whining and pleading to your significant other (thereby losing all future positions of negotiating strength) that you want to quit whatever it is you've been forced to do and get back to Baby. There is no known cure other than reconnection with the project. Once back at the project, however, there is a problem often suffered by those who have contracted Buildis Interruptus. It's called Cleco Oversqueezus. It occurs when the recovering Buildis Interruptus patient, deprived of the habit forming project drug, over indulges by staying at the build site for more than 15 hours straight, cutting, clecoing and deburring everything in sight. Happy 4th, all. John Jessen (3200 miles from my project, and 8 days away from getting back) ________________________________________________________________________________
Date: Jul 01, 2005
Subject: SB wing kit and impending builder interuptus
I recently saw a post that mentioned someone had recently ordered their wings and was given a ship date of early Aug (8?) which is much sooner than the 14-15 weeks posted on their web site. I just got off the phone with Van's and was told that 14-15 weeks IS the current lead time for wing kits!. I'm making progress at a rate that's going to have me ready for my next kit in 6-7 weeks. I spoke with builder support about ordering the fuse kit which only has an 8 week lead time, but they informed me that the centersection spar is required for the fuse kit! and while you could make some progress without it, you'd obviously be limited at some point. Apparently, it is the wing spars that are causing the 14-15 week lead times. So: Anybody out there with a SB wing kit delivery position that wants to delay delivery that would be willing to trade 'positions'? or alternately: How much work (hours) can you complete on the SB Fuse without having the spar available? I'm averaging 35-40 hours per week, wondering if there's enough work to keep busy until the spars/wings are available? Deems Davis #406 ________________________________________________________________________________
Date: Jul 01, 2005
Then a few years after you are flying your completed project, it will hit again and you will have to start another to satisfy the urge. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK] Subject: RE: RV10-List: New medical condition to report --> Funny post, but yet so true. I'm leaving for a two week vacation in a week and going to stop by Oshkosh on my way back. Right now I'm finding myself hoping the two weeks of vacation goes really fast so I can get to Oshkosh and back to my project. I don't think I can remember wishing a vacation would ever go fast before! Thank You Ray Doerr 40250 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: New medical condition to report Ok. There's a new medical condition that has come to my attention only recently, directly ascribable to RV construction. It's called Buildis Interruptus, and it rears its ugly head whenever the builder first realizes that travel or deck building or some other obligation will put him/her in a position away from the project by more than a 24 hour period. Symptoms generally include: 1. reading saved RV-10 email more than twice; 2. searching the web for more RV-10 sites; 3. while traveling, reading the new tool and avionics catalogs cover to cover; 4. cursing that you didn't bring the build manual with you on the trip; 5. not talking to your significant other who demanded the (take your pick) deck, patio, addition, vacation, house painting, tree removal...; 6. making sounds as if you are the pneumatic squeezer and drill (but coming up with interesting staccato beats, nonetheless); 7. sketching out the storage stand yet to be built for your Empennage and Cone and Wings; 8. scheming how to put up your own builder's web site (you mean there's computer languages beyond Fortran, Cobol and Lisp?); 9. general malaise and inconsolable depression, and 10. obsessive whining and pleading to your significant other (thereby losing all future positions of negotiating strength) that you want to quit whatever it is you've been forced to do and get back to Baby. There is no known cure other than reconnection with the project. Once back at the project, however, there is a problem often suffered by those who have contracted Buildis Interruptus. It's called Cleco Oversqueezus. It occurs when the recovering Buildis Interruptus patient, deprived of the habit forming project drug, over indulges by staying at the build site for more than 15 hours straight, cutting, clecoing and deburring everything in sight. Happy 4th, all. John Jessen (3200 miles from my project, and 8 days away from getting back) ________________________________________________________________________________
Date: Jul 01, 2005
Subject: Re: SB wing kit and impending builder interuptus
Deems Davis, That was me. I called Van's, was told 15 weeks so I put my deposit down (2 weeks or so ago), and got a letter saying my scheduled ship date is August 8th. Put your deposit on the wing kit and see what date is on the letter. I rushed to put a deposit on it since the lead time I was told was 15 weeks. Let me know what your scheduled date is, and if I'm not yet ready when the time comes maybe we can swap kits. -Jim 40384, Starting Elevators. Deems Davis wrote: > > I recently saw a post that mentioned someone had recently ordered > their wings and was given a ship date of early Aug (8?) which is much > sooner than the 14-15 weeks posted on their web site. I just got off > the phone with Van's and was told that 14-15 weeks IS the current lead > time for wing kits!. I'm making progress at a rate that's going to > have me ready for my next kit in 6-7 weeks. I spoke with builder > support about ordering the fuse kit which only has an 8 week lead > time, but they informed me that the centersection spar is required for > the fuse kit! and while you could make some progress without it, you'd > obviously be limited at some point. Apparently, it is the wing spars > that are causing the 14-15 week lead times. > > So: > Anybody out there with a SB wing kit delivery position that wants to > delay delivery that would be willing to trade 'positions'? or > alternately: > > How much work (hours) can you complete on the SB Fuse without having > the spar available? I'm averaging 35-40 hours per week, wondering if > there's enough work to keep busy until the spars/wings are available? > > Deems Davis > > #406 > > ________________________________________________________________________________
Date: Jul 01, 2005
Attached is how my Safe Air Static port fits. The port does stick out from the skin. Not much, but at least as much as paint. (still need to dimple, counter sink and rivit, I wish I did it when I was putting together the tail cone) Larry Rosen #356 LarryRosen(at)comcast.net wrote: > I have not yet installed my Safe Air vents, but I did a test fit and > the port does stick out past the skin. It sticks out at least as far > as paint would. I will make a measurement when I get back to the shop > in a couple of days. > > Larry Rosen > #356 > ________________________________________________________________________________
Date: Jul 01, 2005
I ordered my QB wings and fuselage back in March and was promised a August ship date. They were ready 2 weeks ago. So, don't be suprised if the wings are ready early. If anyone is planning on ordering, I would suggest you do it before Oshkosh. There will be a surge of orders during the show. James Hein wrote: > > Deems Davis, > That was me. > I called Van's, was told 15 weeks so I put my deposit down (2 weeks > or so ago), and got a letter saying my scheduled ship date is August 8th. > > Put your deposit on the wing kit and see what date is on the > letter. I rushed to put a deposit on it since the lead time I was told > was 15 weeks. > > Let me know what your scheduled date is, and if I'm not yet ready > when the time comes maybe we can swap kits. > > -Jim 40384, Starting Elevators. > > Deems Davis wrote: > >> >> I recently saw a post that mentioned someone had recently ordered >> their wings and was given a ship date of early Aug (8?) which is >> much sooner than the 14-15 weeks posted on their web site. I just got >> off the phone with Van's and was told that 14-15 weeks IS the current >> lead time for wing kits!. I'm making progress at a rate that's going >> to have me ready for my next kit in 6-7 weeks. I spoke with builder >> support about ordering the fuse kit which only has an 8 week lead >> time, but they informed me that the centersection spar is required >> for the fuse kit! and while you could make some progress without it, >> you'd obviously be limited at some point. Apparently, it is the wing >> spars that are causing the 14-15 week lead times. >> >> So: >> Anybody out there with a SB wing kit delivery position that wants to >> delay delivery that would be willing to trade 'positions'? or >> alternately: >> >> How much work (hours) can you complete on the SB Fuse without having >> the spar available? I'm averaging 35-40 hours per week, wondering if >> there's enough work to keep busy until the spars/wings are available? >> >> Deems Davis >> >> #406 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Bendix Magneto's
Date: Jul 01, 2005
Hi all: This was posted to the Cardinal Flyers Online (CFO)digest a couple of days ago. I don't know if it's applicable to anyone but certainly looks like it includes Lycoming 540's. Regards, Rick ________________________________________________________________________________ ;
Date: Jul 01, 2005
Subject: Tip for storing bottom wing skins
Hi, If you are working on the SB wing kit and have finished riveting the top skin, you can store the bottom skins on the top skin side by clecoing them to the gap seal holes. (This assumes you are storing the wings vert.) The rivet holes are not all aligned but at least 3 to 4 should be - plenty to hold the skin. Eric ________________________________________________________________________________
Subject: Weld-On 10 Gouge
Date: Jul 01, 2005
I had so much fun glueing the windows on that I thought I'd pass some gouge along. Weld-On 10 gives you more time to work with than I thought. I spent about 4 minutes per window to smear it on and all were fine. The jar says pot life is about 30 minutes. It is runny as others have said. However, a thin film builds quickly and that stops the runniness soon after you apply it. I used the popcycle sticks that they give you to apply. The rear windows being vertical were harder to prevent the glue from running. Once I put it on the flange of the cabin top I held the stick there at the bottom momentarily to stop the flow then continue. You can go over the glue once after the initial application. After that it bunches up and gets ugly. I used about 60% of a jar for each window. Too bad they don't make smaller jars. Anh #141 ________________________________________________________________________________
Subject: Re: Weld-On 10 Gouge
Date: Jul 02, 2005
I should add some clarification and retract something to my post. 3-4 minutes to apply the glue was probably a bit too long. I didn't time myself but it was probably half that. It is best to work as quickly as you can. The important thing is that fresh glue is needed to chemically dissolve the plexi to make a good bond. I don't want to give the impression that you have 30minutes of pot life to work with. Anh #141 ________________________________________________________________________________
Date: Jul 02, 2005
Subject: New Toy - Chelton Screenshots
Well, I finally found the perfect Levitra/viagara substitute for pilots.....yesterday I went and picked up one of my 3 Chelton screens!! http://www.myrv10.com/N104CD/panel/20050702/index.html I got it powered up by a 2.75A 12V Radio Shack supply, and today I interfaced it with a keyboard. I was able to boot it up, and even update the operating software to version 5.0C from 5.0B. The Terrain now looks far better than before. For those who remember the blacks and browns of the terrain, they're now much more vivid and pretty. I took some awful crappy pictures while I was playing with it tonight so you could see some of the screens. It's even better than the training DVD and demo video shows. Also, after playing with it, I can see that my primary Nav/Com is going to be my SL-30, not the GNS-480.....let me tell you that this thing is SLICK! That GNS-480's looking mighty weak compared to this thing. Also (and please don't be offended or take it personally if you bought GRT stuff), I was able to hold in my hands, side by side, a Chelton and GRT screen. Let me say that there is really no comparison. The manufacturing quality is much better on the Chelton, and you can tell they take better care during assembly. The screen is much nicer looking, especially the lighted and labeled buttons. The Chelton weighs a little more, but you can tell you're getting some substantial power there. I think it uses a 650Mhz or so Celeron processor. When you power them on, the graphics are also no comparison. That Chelton blows the doors of the GRT. I'm extremely glad I went this way, and if I should have my snip job fail, I'll name my next kid Stein, in thanks for his taking the time to educate me as to the benefits of this beautiful system. Some of the stuff from Stark is a little delayed in coming in so far, but we're still planning to have my panel on display at OSH at booth 2030 in Hanger B (SteinAir's Booth). My engine will also be at Aerosport....look for the Gold and Chrome IO-540. I also took a minute to take some photos of something else I think I forgot to post a long time ago. If you remember back in about October there was a hand carved RV-10 model on Ebay that took what seemed like forever to sell. Turns out my dad bought it back then, and gave it to me for my birthday later last year. It was a great surprise. I'm going to try to talk to the guy who made it and see if he'll repaint it with my paint scheme, now that I have it picked out. Here are some photos of that: http://www.myrv10.com/N104CD/misc/index.html Also, I added some additional photos of my fuel lines, and some of that junk in the fuselage section. http://www.myrv10.com/N104CD/fuselage/20050702/index.html Tim -- Tim Olson -- RV-10 #170 Current project: Fuselage ________________________________________________________________________________
Date: Jul 02, 2005
Subject: Skybolt Cowling Fastener kit
When I was at Stein's a couple days ago, I noticed the camloc fasteners on one of his planes. I'd been kind of skeptical about the hinge system used to install the canopy, and Stein confirmed that yes, there are issues. * Hinge pins can work their way out and into the prop on the horizontal pin. * eyelits will eventually break off the lower hinge sections. * It's inconvenient to get inside the cowl with your hands and pull out those pins and it isn't that easy to get them back in. The hinge pin system does look nice though, as there's not much exposed and it's real smooth. My Sundowner had/has camlocs on the cowl, and at least for the top cowl cover, I can't imagine an easier way to do things. At minimum, I intend to put camlocs or screws and nutplates on the top cowl. Screws would be cheaper, but you'll replace screws and maybe some nutplates over time, as it will be hard to keep from chewing up screwheads. I'm seriously considering the camloc kit from Skybolt. http://www.skybolt.com/store/ProductDetail.asp?ProductID=502 I know Jesse said they put screws on top and hinge on bottom. Anyone else do anything different so far? This skybolt kit, although more money, would definitely make popping the top cover a very quick job. I can have my sundowner top off in about 90 seconds. Tim -- Tim Olson -- RV-10 #170 Current project: Fuselage ________________________________________________________________________________
Date: Jul 02, 2005
I have had the hinges on my aircraft cowl for the last 18 years. I generally like them, both for the looks and the ease of removal. They are however, a bugger to get fit right the first time and for the first few hours of flight until everything gets settled in. I have not had the hinges work themselves out. You lock them in with either a screw or hook it around the front lip on the cowel. I have not had any eyeltes break off. I have had the paint over the rivets used to secure the hinges to the cowel pop off after 5 years of usage. I was able to solve that by putting a thin (4 oz) cloth and fiberglass over the row of rivets. Some more imput for your consideration. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Skybolt Cowling Fastener kit When I was at Stein's a couple days ago, I noticed the camloc fasteners on one of his planes. I'd been kind of skeptical about the hinge system used to install the canopy, and Stein confirmed that yes, there are issues. * Hinge pins can work their way out and into the prop on the horizontal pin. * eyelits will eventually break off the lower hinge sections. * It's inconvenient to get inside the cowl with your hands and pull out those pins and it isn't that easy to get them back in. The hinge pin system does look nice though, as there's not much exposed and it's real smooth. My Sundowner had/has camlocs on the cowl, and at least for the top cowl cover, I can't imagine an easier way to do things. At minimum, I intend to put camlocs or screws and nutplates on the top cowl. Screws would be cheaper, but you'll replace screws and maybe some nutplates over time, as it will be hard to keep from chewing up screwheads. I'm seriously considering the camloc kit from Skybolt. http://www.skybolt.com/store/ProductDetail.asp?ProductID=502 I know Jesse said they put screws on top and hinge on bottom. Anyone else do anything different so far? This skybolt kit, although more money, would definitely make popping the top cover a very quick job. I can have my sundowner top off in about 90 seconds. Tim -- Tim Olson -- RV-10 #170 Current project: Fuselage ________________________________________________________________________________
Subject: Re: Skybolt Cowling Fastener kit
Date: Jul 02, 2005
> * Hinge pins can work their way out and into the prop on the > horizontal pin. Which is why you build some sort of retainer in at the front. > * eyelits will eventually break off the lower hinge sections. Which is why you use screws & nutplates on the bottom. > * It's inconvenient to get inside the cowl with your hands and > pull out those pins and it isn't that easy to get them back in. Are you speaking from experience? The only pin that is even remotely difficult is the one going from the oil door to the right side, along the top firewall flange. And what I've seen a lot of people do is just have the top hinges join in the center, and have a little two-screw panel (flush, of course), which is removed to expose the hinges. Everything can be done from the exterior that way. Note that if you use camloc fasteners, you might see "bulging" or "scalloping" between fasteners, since the air has got to escape somehow...and it's hot air no less. I've spoken to more than one builder whose cowl took a permanent "form" to the heated scalloping, and they said they'd go with hinges next time. Not saying that's the case for everybody, just the ones I've spoken to. Hinges are really cheap, trivial to build in, and don't take any longer to insert/remove than camlocs. Camlocs are expensive, more difficult to build in, but are really easy to deal with -- once installed. Your mileage may vary. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: weight and balance
Date: Jul 02, 2005
I also modified the battery box to accept two 680s and an extra contactor. I just used the Jeppesen Flitestar program to calculate some WBs. Using the finishing kit number of approx. 1615 pounds an 106 cg, I input various scenarios. I assumed an extra 6 pounds at 190" for the different battery arrangement. One thing becomes apparent almost immediately. The RV10 has the same "problem" as the Bonanza. The CG moves aft with fuel burn. It appears to be about .50-.75" going from full tanks to minimum fuel of about 5 gal. So initial loading at takeoff at the aft limit may mean landing aft of the limit and the resultant light pitch forces. When landing at the aft limit keep the speed up until the flare. The extra battery matters almost nothing; less than .25" in the CG. Using 4 170 pounders and 50 pounds of baggage and full fuel results in a loading of about 115" CG (116.24" limit) at takeoff. A four hour trip at 12 gal/hour results in a landing CG of about 116". Put the ladies in the back; Lower fuel loads do nothing to avert the move aft of the CG due to burn. ________________________________________________________________________________
Subject: Re: New Toy - Chelton Screenshots
Date: Jul 02, 2005
Tim, Well, now you've got my heart pumping! Question, on the first PFD picture (RV200507010112.jpg), it looks like the magenta path line is rising in space. Is this my imagination, or does the course line actually have the proper height perspective above ground like the HITS presentation? The colors on the moving map are much better. The others were too dark. Thanks, Mark ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Subject: RV10-List: New Toy - Chelton Screenshots > > Well, I finally found the perfect Levitra/viagara substitute for > pilots.....yesterday I went and picked up one of my 3 Chelton > screens!! > > http://www.myrv10.com/N104CD/panel/20050702/index.html > > I got it powered up by a 2.75A 12V Radio Shack supply, and today I > interfaced it with a keyboard. I was able to boot it up, and > even update the operating software to version 5.0C from 5.0B. > The Terrain now looks far better than before. For those who > remember the blacks and browns of the terrain, they're now much > more vivid and pretty. I took some awful crappy pictures while > I was playing with it tonight so you could see some of the screens. > It's even better than the training DVD and demo video shows. > Also, after playing with it, I can see that my primary Nav/Com > is going to be my SL-30, not the GNS-480.....let me tell you that > this thing is SLICK! That GNS-480's looking mighty weak compared > to this thing. Also (and please don't be offended or take it > personally if you bought GRT stuff), I was able to hold in my > hands, side by side, a Chelton and GRT screen. Let me say > that there is really no comparison. The manufacturing quality > is much better on the Chelton, and you can tell they take better > care during assembly. The screen is much nicer looking, especially > the lighted and labeled buttons. The Chelton weighs a little more, > but you can tell you're getting some substantial power there. > I think it uses a 650Mhz or so Celeron processor. When you power > them on, the graphics are also no comparison. That Chelton blows > the doors of the GRT. I'm extremely glad I went this way, and > if I should have my snip job fail, I'll name my next kid Stein, > in thanks for his taking the time to educate me as to the benefits > of this beautiful system. Some of the stuff from Stark is a little > delayed in coming in so far, but we're still planning to have my > panel on display at OSH at booth 2030 in Hanger B (SteinAir's Booth). > My engine will also be at Aerosport....look for the Gold and Chrome > IO-540. > > I also took a minute to take some photos of something else I think > I forgot to post a long time ago. If you remember back in about > October there was a hand carved RV-10 model on Ebay that took > what seemed like forever to sell. Turns out my dad bought it > back then, and gave it to me for my birthday later last year. > It was a great surprise. I'm going to try to talk to the guy > who made it and see if he'll repaint it with my paint scheme, now > that I have it picked out. > > Here are some photos of that: > http://www.myrv10.com/N104CD/misc/index.html > > Also, I added some additional photos of my fuel lines, and > some of that junk in the fuselage section. > http://www.myrv10.com/N104CD/fuselage/20050702/index.html > > Tim > > -- > > Tim Olson -- RV-10 #170 > Current project: Fuselage > > > ________________________________________________________________________________
Date: Jul 02, 2005
Dan Checkoway wrote: > >>* Hinge pins can work their way out and into the prop on the >>horizontal pin. > > > Which is why you build some sort of retainer in at the front. > > >>* eyelits will eventually break off the lower hinge sections. > > > Which is why you use screws & nutplates on the bottom. > > >>* It's inconvenient to get inside the cowl with your hands and >>pull out those pins and it isn't that easy to get them back in. > > > Are you speaking from experience? The only pin that is even remotely > difficult is the one going from the oil door to the right side, along the > top firewall flange. And what I've seen a lot of people do is just have the > top hinges join in the center, and have a little two-screw panel (flush, of > course), which is removed to expose the hinges. Everything can be done from > the exterior that way. > No, I'm not speaking from experience, but Stein did show me and allow us to reach in thru the oil door where the pin on the firewall gets pulled out and I can easily see how it wouldn't be as fun as quick 1/4 turn camlocs. That's a great trick with having the little removable panel. Would be a big improvement I think. > Note that if you use camloc fasteners, you might see "bulging" or > "scalloping" between fasteners, since the air has got to escape > somehow...and it's hot air no less. I've spoken to more than one builder > whose cowl took a permanent "form" to the heated scalloping, and they said > they'd go with hinges next time. Not saying that's the case for everybody, > just the ones I've spoken to. > I wonder if starting with a good fit would prevent that? Or perhaps a thin coat of RTV inside the seam. > Hinges are really cheap, trivial to build in, and don't take any longer to > insert/remove than camlocs. Camlocs are expensive, more difficult to build > in, but are really easy to deal with -- once installed. Your mileage may > vary. > Yep, the camlocs would definitely be a much more expensive solution. I think they're great from what I've seen, but it's all I've ever used. Tim > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 02, 2005
Hey Mark, That magenta line is a pointer that is showing you which way to turn when it has an ILS signal. Look to the right of it and you'll see the VNAV glideslope indicator..you can tell it's not on glideslope perfectly. After having it shoot a couple of approaches, I think it actually is very readable....I was worried the glideslope display wouldn't look so good, but it's fantastic. Once you get on the approach, the HITS boxes will also be visible, so you get that guidance too. You're right about the moving map colors...they're fantastic. Release 6.0 is coming out very soon and I hear that's got many more improvements. Can't wait to see that. I think it's only a couple weeks away possibly. Tim Mark & Kelly wrote: > > Tim, > > Well, now you've got my heart pumping! Question, on the first PFD > picture (RV200507010112.jpg), it looks like the magenta path line is > rising in space. Is this my imagination, or does the course line > actually have the proper height perspective above ground like the HITS > presentation? The colors on the moving map are much better. The > others were too dark. > > Thanks, > Mark > > ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> > To: "RV10" > Sent: Saturday, July 02, 2005 12:55 AM > Subject: RV10-List: New Toy - Chelton Screenshots > > >> >> Well, I finally found the perfect Levitra/viagara substitute for >> pilots.....yesterday I went and picked up one of my 3 Chelton >> screens!! >> >> http://www.myrv10.com/N104CD/panel/20050702/index.html >> >> I got it powered up by a 2.75A 12V Radio Shack supply, and today I >> interfaced it with a keyboard. I was able to boot it up, and >> even update the operating software to version 5.0C from 5.0B. >> The Terrain now looks far better than before. For those who >> remember the blacks and browns of the terrain, they're now much >> more vivid and pretty. I took some awful crappy pictures while >> I was playing with it tonight so you could see some of the screens. >> It's even better than the training DVD and demo video shows. >> Also, after playing with it, I can see that my primary Nav/Com >> is going to be my SL-30, not the GNS-480.....let me tell you that >> this thing is SLICK! That GNS-480's looking mighty weak compared >> to this thing. Also (and please don't be offended or take it >> personally if you bought GRT stuff), I was able to hold in my >> hands, side by side, a Chelton and GRT screen. Let me say >> that there is really no comparison. The manufacturing quality >> is much better on the Chelton, and you can tell they take better >> care during assembly. The screen is much nicer looking, especially >> the lighted and labeled buttons. The Chelton weighs a little more, >> but you can tell you're getting some substantial power there. >> I think it uses a 650Mhz or so Celeron processor. When you power >> them on, the graphics are also no comparison. That Chelton blows >> the doors of the GRT. I'm extremely glad I went this way, and >> if I should have my snip job fail, I'll name my next kid Stein, >> in thanks for his taking the time to educate me as to the benefits >> of this beautiful system. Some of the stuff from Stark is a little >> delayed in coming in so far, but we're still planning to have my >> panel on display at OSH at booth 2030 in Hanger B (SteinAir's Booth). >> My engine will also be at Aerosport....look for the Gold and Chrome >> IO-540. >> >> I also took a minute to take some photos of something else I think >> I forgot to post a long time ago. If you remember back in about >> October there was a hand carved RV-10 model on Ebay that took >> what seemed like forever to sell. Turns out my dad bought it >> back then, and gave it to me for my birthday later last year. >> It was a great surprise. I'm going to try to talk to the guy >> who made it and see if he'll repaint it with my paint scheme, now >> that I have it picked out. >> >> Here are some photos of that: >> http://www.myrv10.com/N104CD/misc/index.html >> >> Also, I added some additional photos of my fuel lines, and >> some of that junk in the fuselage section. >> http://www.myrv10.com/N104CD/fuselage/20050702/index.html >> >> Tim >> >> -- >> >> Tim Olson -- RV-10 #170 >> Current project: Fuselage >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 02, 2005
Subject: [ eanderson(at)carolina.rr.com ] : New Email List Photo Share
Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: eanderson(at)carolina.rr.com Lists: RV-List,RV3-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Brake Line Failure http://www.matronics.com/photoshare/eanderson@carolina.rr.com.07.02.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jul 02, 2005
Subject: Looking for Engine
looking for used Rotax 912/912S...cash buyer. sportflyer(at)emcity.net ________________________________________________________________________________
<42C6DC3C.1000608(at)MyRV10.com>
Date: Jul 02, 2005
> > Note that if you use camloc fasteners, you might see "bulging" or > > "scalloping" between fasteners, since the air has got to escape > > somehow...and it's hot air no less. I've spoken to more than one builder > > whose cowl took a permanent "form" to the heated scalloping, and they said > > they'd go with hinges next time. Not saying that's the case for everybody, > > just the ones I've spoken to. > > I wonder if starting with a good fit would prevent that? > Or perhaps a thin coat of RTV inside the seam. I don't see how RTV would counteract the cowl flange bulging. The point is that with heat, the material expands. If you have a camloc every 4" or whatever, when you add hot, pressurized air to the mix, the material will bulge between fasteners. Since you're talking about heating fiberglass, the cowl may "take a set" in that shape. I suppose a potential "solution" would be to install stiffeners on the cowl flange between camlocs, in order to keep it from bulging in between. You'd want to do that before you fly, before the material takes a set in the scalloped form. Or you could just use hinges like Van's does on their planes. ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Wanted: 3/32 clecos
Date: Jul 02, 2005
I'm just starting a RV-10 kit and find I need additional silver clecos. If anyone has 1 or 2 hundred for sale, I'm interested. Albert Gardner RV-9A N872RV Yuma, AZ ________________________________________________________________________________ spamd4.ruraltel.net * -4.0 RCVD_FROM_NEXTECH_5 Message came from 204.96.144-152.x network * 0.0 UNPARSEABLE_RELAY Informational: message has unparseable relay * lines * -0.8 BAYES_00 BODY: Bayesian spam probability is 0 to 1% * -0.2 AWL AWL: From: address is in the auto white-list
From: "Bill and Tami Britton" <william(at)gbta.net>
Date: Jul 02, 2005
Deems, I ordered my SB wing kit with the fuel senders (no lights yet) the last day of march to beat the price increase. I am only starting on the elevators now so It'll be quite a while before I need the wing. I would be willing to trade shipment dates with you if you will cover the extra cost of the price increase. If you are interested contact me privately at william(at)gbta.net and we'll see if we can work something out. BTW: I have not talked to Vans lately about the delivery date but I did receive a letter from them about 1 1/2 months ago stating that the estimated delivery date was July 10-12. Let me know if you are interested Bill Britton Ready to start Elevators!!! ----- Original Message ----- From: "Deems Davis" <deemsdavis(at)cox.net> Subject: RV10-List: SB wing kit and impending builder interuptus > > I recently saw a post that mentioned someone had recently ordered their > wings and was given a ship date of early Aug (8?) which is much sooner > than the 14-15 weeks posted on their web site. I just got off the phone > with Van's and was told that 14-15 weeks IS the current lead time for > wing kits!. I'm making progress at a rate that's going to have me ready > for my next kit in 6-7 weeks. I spoke with builder support about > ordering the fuse kit which only has an 8 week lead time, but they > informed me that the centersection spar is required for the fuse kit! > and while you could make some progress without it, you'd obviously be > limited at some point. Apparently, it is the wing spars that are > causing the 14-15 week lead times. > > So: > Anybody out there with a SB wing kit delivery position that wants to > delay delivery that would be willing to trade 'positions'? or alternately: > > How much work (hours) can you complete on the SB Fuse without having the > spar available? I'm averaging 35-40 hours per week, wondering if there's > enough work to keep busy until the spars/wings are available? > > Deems Davis > > #406 > > ________________________________________________________________________________
Date: Jul 02, 2005
<000f01c57f1e$5b2e13e0$6400a8c0@inspinc.ad> <42C6DC3C.1000608(at)MyRV10.com> I have installed the skybolt camlocs on my cowl and I see what Dan is talking about. Most of the installation is very tight, but I do have a few areas between fasteners that have a slight buldge. I was very careful to have the fit as tight as possible before drilling the final hole size for the stud and receptacle. The hinge pins have a constant grip around the perimeter of the cowl while there is really nothing between the fasteners. At this point I am committed to the camlocs. It is not as clean a look, but I have enjoyed the easy operation already. I hope I don't encounter the other problems Dan mentioned. Just thought I'd throw in my two cents. Mark (40016) -- ________________________________________________________________________________
Date: Jul 03, 2005
Subject: Just wonderin'
<42C6DC3C.1000608(at)MyRV10.com> <002501c57f90$933cca20$f5006e47@Office> Am I the only one in the group contemplating switching jobs to a higher paying one you are going to hate just to pay off the project faster ? ________________________________________________________________________________
Date: Jul 04, 2005
Subject: Door bonding
Quick question... When bonding the door halves, do you use cab-o-sil in all areas including where you use the glass cloth in the cranium and other cavities, or is it just epoxy and cloth in those areas? Door bonding today. The paint looks as if it came out pretty good on the canopy. Man that SmoothPrime is nice stuff. It seems that basically you roll it on, and then sand most of it off, since it doesn't roll smoothly, but it acts as a very hard, thin, body filler along with pinhole filler....and it's got a tenacious grip. Tim -- Tim Olson -- RV-10 #170 ________________________________________________________________________________
Date: Jul 04, 2005
Tim, Looks like Aircraft Spruce is pretty proud of SmoothPrime too. How much do you need for the project? I'd sure rather get a quart than a gallon+. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Door bonding Quick question... When bonding the door halves, do you use cab-o-sil in all areas including where you use the glass cloth in the cranium and other cavities, or is it just epoxy and cloth in those areas? Door bonding today. The paint looks as if it came out pretty good on the canopy. Man that SmoothPrime is nice stuff. It seems that basically you roll it on, and then sand most of it off, since it doesn't roll smoothly, but it acts as a very hard, thin, body filler along with pinhole filler....and it's got a tenacious grip. Tim -- Tim Olson -- RV-10 #170 ________________________________________________________________________________
Date: Jul 04, 2005
Subject: Re: Door bonding
I've only done the very small amount inside the canopy so far. I think I've heard reference to 3 quarts doing a whole airplane, but it sure doesn't seem like if you roll it on that this stuff goes too far. I can see easily using 1 QT for the project as a whole, possibly 2. Depends on how much other filler you use too I'm sure. Tim Olson -- RV-10 #170 Marcus Cooper wrote: > > Tim, > Looks like Aircraft Spruce is pretty proud of SmoothPrime too. How much > do you need for the project? I'd sure rather get a quart than a gallon+. > > Marcus > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Monday, July 04, 2005 9:05 AM > To: RV10 > Subject: RV10-List: Door bonding > > > Quick question... > > When bonding the door halves, do you use cab-o-sil in all areas > including where you use the glass cloth in the cranium and > other cavities, or is it just epoxy and cloth in those areas? > > Door bonding today. The paint looks as if it came out pretty good > on the canopy. Man that SmoothPrime is nice stuff. It seems > that basically you roll it on, and then sand most of it off, > since it doesn't roll smoothly, but it acts as a very hard, > thin, body filler along with pinhole filler....and it's > got a tenacious grip. > > Tim ________________________________________________________________________________
Date: Jul 05, 2005
Subject: Chelton in AOPA 2005 Commander Sweepstakes plane
I ran across an interesting article this weekend regarding the current month's status of the AOPA sweepstakes plane. They're using a dual Chelton system in that plane, and had great things to say. In particular though, this caught my attention: "Chelton recently achieved two milestones with their FlightLogic system. It released software version 5.0B and announced that the new software had passed RTCA DO-178B Level A software design compliance standards. The latter, in particular, is a big feather in Chelton's cap--Level A compliance is the same standard that FAA requires for FAR 25 aircraft, those Boeing and Airbus widebodies that fly up where there's not much to see. The Chelton GPS also is WAAS (Wide Aera Augmentation System) compliant, meaning it is approved to take advantage of both vertical and horizontal guidance during GPS approaches. The terrain awareness warning system (TAWS) installed in the AOPA commander is the "C" version: this version provides plenty of terrain warning for the low-and-slow capabilities of the Commander. The Chelton FlightLogic TAWS system can be configured to provide TAWS-B- and TAWS-A-level capabilities for turbine and passenger-for-hire aircraft. FOr a look at the future of general vaiation navigation and HITS technology, sign up on the website for a free DVD from Chelton (http://www.cheltonflightsystems.com/Prod_cert_request_info.html) " There was more good stuff before this section, but reading the notes about the software certification was nice...but, it's hard for me not to notice the WAAS comment. I'm now wondering if it might not be possible that I didn't need that GNS480 after-all to be WAAS legal...or perhaps that would happen soon. My current software release is 5.0C, and 6.0 is coming out soon. A couple people asked me over the last couple of days about my GNS480 in the stack. I actually had a funny comment back in that now that I have a Chelton in-hand, I don't know if I'd have put the 480 in there at all. The integration will be fantastic with the SL30, and the Chelton will be a great box to use. The GNS480 will definitely be relegated to the COM2/NAV2 position for me, because I can tell right now that I'm going to use my Chelton to do many/most of my frequency changes...except possibly during enroute handoffs. It is kind of nice having a 2nd GPS on board, but I'm now wondering if possibly a panel-mount or handheld Garmin 296 wouldn't have given me plenty of emergency function. If the GNS480 had as nice a tuner integration as the SL30, it would be great, but without that, I am just thinking that I'll probably be so hands-off the 480 that I will never keep proficient in it's operation. The Chelton is just so darn integrated and seemingly easy to use. Just thought I'd pass on that article clip and some post-4th comments. Tim -- Tim Olson -- RV-10 #170 Current project: Fuselage ________________________________________________________________________________
Date: Jul 05, 2005
Subject: Lower aft rivets on the RV-10 rudder
RV10ers, I've had my 10 tail kit for a few months now and I've been building along and reading the RV lists. The vertical stab is done. The rudder is almost done and I've made some progress on the horizontal stab. I had not yet posted anything to the list and introduced myself, but I've run into a problem I could use some help with so now's the time. All you people who have finished RV-10 rudders will recall the very aft rivets that hold the rudder skins to the lower rib, the rib with the control horn attached. This is the place where you don't have enough room to set a solid rivet in (I think) the left skin because of interference with the rivet in the right skin;so you use a blind flush rivet on the left. Well, how did you guys set the solid rivet in the right skin? There's no way I'm going to get even my thinnest squeezer yoke between the rivet and the opposite side of the rib. I've thought about several schemes to deal with this but a lot of you must have already solved the problem. What's the secret? (I did try searching the RV-10 archive but I came up dry.) Thanks in advance for any help. Plowing ahead with the H-stab, Nick Gautier Altadena, Californis RV-10 #40363 ________________________________________________________________________________
Date: Jul 05, 2005
Subject: Re: Lower aft rivets on the RV-10 rudder
I used a blind pop rivet on both sides. Looks good. -Jim 40384 ngautier(at)earthlink.net wrote: > >RV10ers, > > I've had my 10 tail kit for a few months now and I've been building along and reading the RV lists. >The vertical stab is done. The rudder is almost done and I've made some progress on the horizontal >stab. I had not yet posted anything to the list and introduced myself, but I've run into a >problem I could use some help with so now's the time. > > All you people who have finished RV-10 rudders will recall the very aft rivets that hold the >rudder skins to the lower rib, the rib with the control horn attached. This is the place where >you don't have enough room to set a solid rivet in (I think) the left skin because of interference >with the rivet in the right skin;so you use a blind flush rivet on the left. > > Well, how did you guys set the solid rivet in the right skin? There's no way I'm going to get >even my thinnest squeezer yoke between the rivet and the opposite side of the rib. I've thought >about several schemes to deal with this but a lot of you must have already solved the problem. >What's the secret? (I did try searching the RV-10 archive but I came up dry.) > > Thanks in advance for any help. > >Plowing ahead with the H-stab, >Nick Gautier >Altadena, Californis >RV-10 #40363 > > > > > > > > > ________________________________________________________________________________
Date: Jul 05, 2005
Hi Nick, It just so happens I'm in Altadena and have made a bucking bar that will get into that spot. Come by and borrow it. You can reach me at 626-622-7716. Jeff Carpenter 40304 On Jul 5, 2005, at 1:35 PM, ngautier(at)earthlink.net wrote: > > RV10ers, > > I've had my 10 tail kit for a few months now and I've been > building along and reading the RV lists. > The vertical stab is done. The rudder is almost done and I've made > some progress on the horizontal > stab. I had not yet posted anything to the list and introduced > myself, but I've run into a > problem I could use some help with so now's the time. > > All you people who have finished RV-10 rudders will recall the > very aft rivets that hold the > rudder skins to the lower rib, the rib with the control horn > attached. This is the place where > you don't have enough room to set a solid rivet in (I think) the > left skin because of interference > with the rivet in the right skin;so you use a blind flush rivet on > the left. > > Well, how did you guys set the solid rivet in the right skin? > There's no way I'm going to get > even my thinnest squeezer yoke between the rivet and the opposite > side of the rib. I've thought > about several schemes to deal with this but a lot of you must have > already solved the problem. > What's the secret? (I did try searching the RV-10 archive but I > came up dry.) > > Thanks in advance for any help. > > Plowing ahead with the H-stab, > Nick Gautier > Altadena, Californis > RV-10 #40363 > > ________________________________________________________________________________
Date: Jul 05, 2005
<42CAF3FD.4010500(at)arrl.net> Same here. MK-319-BS I believe. James Hein wrote: > > I used a blind pop rivet on both sides. Looks good. > > -Jim 40384 > > ngautier(at)earthlink.net wrote: > >> >> RV10ers, >> >> I've had my 10 tail kit for a few months now and I've been >> building along and reading the RV lists. The vertical stab is done. >> The rudder is almost done and I've made some progress on the >> horizontal stab. I had not yet posted anything to the list and >> introduced myself, but I've run into a problem I could use some help >> with so now's the time. >> >> All you people who have finished RV-10 rudders will recall the >> very aft rivets that hold the rudder skins to the lower rib, the rib >> with the control horn attached. This is the place where you don't >> have enough room to set a solid rivet in (I think) the left skin >> because of interference with the rivet in the right skin;so you use a >> blind flush rivet on the left. >> >> Well, how did you guys set the solid rivet in the right skin? >> There's no way I'm going to get even my thinnest squeezer yoke >> between the rivet and the opposite side of the rib. I've thought >> about several schemes to deal with this but a lot of you must have >> already solved the problem. What's the secret? (I did try searching >> the RV-10 archive but I came up dry.) >> >> Thanks in advance for any help. >> >> Plowing ahead with the H-stab, >> Nick Gautier >> Altadena, Californis >> RV-10 #40363 >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 05, 2005
YEP, POOP rivet it and continue on ---------- Original Message ---------------------------------- From: Sean Stephens <schmoboy(at)cox.net> Date: Tue, 05 Jul 2005 14:18:12 -0700 Same here. MK-319-BS I believe. James Hein wrote: > > I used a blind pop rivet on both sides. Looks good. > > -Jim 40384 > > ngautier(at)earthlink.net wrote: > >> >> RV10ers, >> >> I've had my 10 tail kit for a few months now and I've been >> building along and reading the RV lists. The vertical stab is done. >> The rudder is almost done and I've made some progress on the >> horizontal stab. I had not yet posted anything to the list and >> introduced myself, but I've run into a problem I could use some help >> with so now's the time. >> >> All you people who have finished RV-10 rudders will recall the >> very aft rivets that hold the rudder skins to the lower rib, the rib >> with the control horn attached. This is the place where you don't >> have enough room to set a solid rivet in (I think) the left skin >> because of interference with the rivet in the right skin;so you use a >> blind flush rivet on the left. >> >> Well, how did you guys set the solid rivet in the right skin? >> There's no way I'm going to get even my thinnest squeezer yoke >> between the rivet and the opposite side of the rib. I've thought >> about several schemes to deal with this but a lot of you must have >> already solved the problem. What's the secret? (I did try searching >> the RV-10 archive but I came up dry.) >> >> Thanks in advance for any help. >> >> Plowing ahead with the H-stab, >> Nick Gautier >> Altadena, Californis >> RV-10 #40363 >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 06, 2005
I back rivetted it using a cold chisel resting on a pivot. Ron #187 finishing wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Jim Combs Subject: Re: RV10-List: Lower aft rivets on the RV-10 rudder YEP, POOP rivet it and continue on ---------- Original Message ---------------------------------- From: Sean Stephens <schmoboy(at)cox.net> Date: Tue, 05 Jul 2005 14:18:12 -0700 Same here. MK-319-BS I believe. James Hein wrote: > > I used a blind pop rivet on both sides. Looks good. > > -Jim 40384 > > ngautier(at)earthlink.net wrote: > >> >> RV10ers, >> >> I've had my 10 tail kit for a few months now and I've been >> building along and reading the RV lists. The vertical stab is done. >> The rudder is almost done and I've made some progress on the >> horizontal stab. I had not yet posted anything to the list and >> introduced myself, but I've run into a problem I could use some help >> with so now's the time. >> >> All you people who have finished RV-10 rudders will recall the >> very aft rivets that hold the rudder skins to the lower rib, the rib >> with the control horn attached. This is the place where you don't >> have enough room to set a solid rivet in (I think) the left skin >> because of interference with the rivet in the right skin;so you use a >> blind flush rivet on the left. >> >> Well, how did you guys set the solid rivet in the right skin? >> There's no way I'm going to get even my thinnest squeezer yoke >> between the rivet and the opposite side of the rib. I've thought >> about several schemes to deal with this but a lot of you must have >> already solved the problem. What's the secret? (I did try searching >> the RV-10 archive but I came up dry.) >> >> Thanks in advance for any help. >> >> Plowing ahead with the H-stab, >> Nick Gautier >> Altadena, Californis >> RV-10 #40363 >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 05, 2005
I have also heard of using a vise grip type of pliers to set the small rivets in this instance as well. You would have to grind the face of the pliers to remove the teeth. I too realized the squeezer would not fit and was more afraid of damaging the thin skins with the rivet gun approach. So I went the pulled rivet (MK-319-BS) approach. Jim Combs N312F Reserved - Fuselage ---------- Original Message ---------------------------------- From: "McGANN, Ron" <ron.mcgann(at)baesystems.com> Date: Wed, 6 Jul 2005 09:53:08 +0930 I back rivetted it using a cold chisel resting on a pivot. Ron #187 finishing wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Jim Combs Subject: Re: RV10-List: Lower aft rivets on the RV-10 rudder YEP, POOP rivet it and continue on ---------- Original Message ---------------------------------- From: Sean Stephens <schmoboy(at)cox.net> Date: Tue, 05 Jul 2005 14:18:12 -0700 Same here. MK-319-BS I believe. James Hein wrote: > > I used a blind pop rivet on both sides. Looks good. > > -Jim 40384 > > ngautier(at)earthlink.net wrote: > >> >> RV10ers, >> >> I've had my 10 tail kit for a few months now and I've been >> building along and reading the RV lists. The vertical stab is done. >> The rudder is almost done and I've made some progress on the >> horizontal stab. I had not yet posted anything to the list and >> introduced myself, but I've run into a problem I could use some help >> with so now's the time. >> >> All you people who have finished RV-10 rudders will recall the >> very aft rivets that hold the rudder skins to the lower rib, the rib >> with the control horn attached. This is the place where you don't >> have enough room to set a solid rivet in (I think) the left skin >> because of interference with the rivet in the right skin;so you use a >> blind flush rivet on the left. >> >> Well, how did you guys set the solid rivet in the right skin? >> There's no way I'm going to get even my thinnest squeezer yoke >> between the rivet and the opposite side of the rib. I've thought >> about several schemes to deal with this but a lot of you must have >> already solved the problem. What's the secret? (I did try searching >> the RV-10 archive but I came up dry.) >> >> Thanks in advance for any help. >> >> Plowing ahead with the H-stab, >> Nick Gautier >> Altadena, Californis >> RV-10 #40363 >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 05, 2005
Ditto.... Rick S. 40185 Waiting on the fuse ----- Original Message ----- From: "McGANN, Ron" <ron.mcgann(at)baesystems.com> Subject: RE: RV10-List: Lower aft rivets on the RV-10 rudder > > I back rivetted it using a cold chisel resting on a pivot. > > Ron > #187 > finishing wings > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Jim Combs > Sent: Wednesday, 6 July 2005 8:32 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Lower aft rivets on the RV-10 rudder > > > YEP, POOP rivet it and continue on > > ---------- Original Message ---------------------------------- > From: Sean Stephens <schmoboy(at)cox.net> > Reply-To: rv10-list(at)matronics.com > Date: Tue, 05 Jul 2005 14:18:12 -0700 > > > Same here. MK-319-BS I believe. > > James Hein wrote: >> >> I used a blind pop rivet on both sides. Looks good. >> >> -Jim 40384 >> >> ngautier(at)earthlink.net wrote: >> >>> >>> RV10ers, >>> >>> I've had my 10 tail kit for a few months now and I've been >>> building along and reading the RV lists. The vertical stab is done. >>> The rudder is almost done and I've made some progress on the >>> horizontal stab. I had not yet posted anything to the list and >>> introduced myself, but I've run into a problem I could use some help >>> with so now's the time. >>> >>> All you people who have finished RV-10 rudders will recall the >>> very aft rivets that hold the rudder skins to the lower rib, the rib >>> with the control horn attached. This is the place where you don't >>> have enough room to set a solid rivet in (I think) the left skin >>> because of interference with the rivet in the right skin;so you use a >>> blind flush rivet on the left. >>> >>> Well, how did you guys set the solid rivet in the right skin? >>> There's no way I'm going to get even my thinnest squeezer yoke >>> between the rivet and the opposite side of the rib. I've thought >>> about several schemes to deal with this but a lot of you must have >>> already solved the problem. What's the secret? (I did try searching >>> the RV-10 archive but I came up dry.) >>> >>> Thanks in advance for any help. >>> >>> Plowing ahead with the H-stab, >>> Nick Gautier >>> Altadena, Californis >>> RV-10 #40363 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 06, 2005
From: "Scott Schmidt" <sschmidt(at)ussynthetic.com>
If I remember right Tim, I just used the epoxy in the areas where the thick fiberglass clothe is and than added the cab-o-sil in the areas where the two halves bond together. Scott Schmidt Cell: 801-319-3094 sschmidt(at)ussynthetic.com > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Monday, July 04, 2005 9:05 AM > To: RV10 > Subject: RV10-List: Door bonding > > > Quick question... > > When bonding the door halves, do you use cab-o-sil in all areas > including where you use the glass cloth in the cranium and > other cavities, or is it just epoxy and cloth in those areas? > > Door bonding today. The paint looks as if it came out pretty good > on the canopy. Man that SmoothPrime is nice stuff. It seems > that basically you roll it on, and then sand most of it off, > since it doesn't roll smoothly, but it acts as a very hard, > thin, body filler along with pinhole filler....and it's > got a tenacious grip. > > Tim ________________________________________________________________________________
Date: Jul 06, 2005
Thanks Scott, that sounds like a plan. I skipped the bonding yesterday after I saw the note that epoxy with 30 minute pot life should be used. I had fast hardner (205), so today I'm skipping out early to go get some slow (206) for doing that step. Tonight should be bonding night. Tim Tim Olson -- RV-10 #170 Current project: Fuselage Scott Schmidt wrote: > > If I remember right Tim, I just used the epoxy in the areas where the > thick fiberglass clothe is and than added the cab-o-sil in the areas > where the two halves bond together. > > Scott Schmidt > Cell: 801-319-3094 > sschmidt(at)ussynthetic.com > >>-----Original Message----- >>From: owner-rv10-list-server(at)matronics.com >>[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson >>Sent: Monday, July 04, 2005 9:05 AM >>To: RV10 >>Subject: RV10-List: Door bonding >> >> >>Quick question... >> >>When bonding the door halves, do you use cab-o-sil in all areas >>including where you use the glass cloth in the cranium and >>other cavities, or is it just epoxy and cloth in those areas? >> >>Door bonding today. The paint looks as if it came out pretty good >>on the canopy. Man that SmoothPrime is nice stuff. It seems >>that basically you roll it on, and then sand most of it off, >>since it doesn't roll smoothly, but it acts as a very hard, >>thin, body filler along with pinhole filler....and it's >>got a tenacious grip. >> >>Tim > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Garmin 396 - Interesting Link
Date: Jul 06, 2005
http://shop.jaair.com/?stepproductinfo&productNum010-00425-00 Looks like it might be a very capable portable! Mark ________________________________________________________________________________
Subject: Re: Garmin 396 - Interesting Link
Date: Jul 06, 2005
I`m sure it is a nice gps, But for $2495 IT BETTER BE!!!! :) John Skorczewski ________________________________________________________________________________ ;
Subject: Elevator Trim Tabs
Date: Jul 06, 2005
Greetings to everyone: I have been struggling with the electric trim cable adjustments and cannot seem to get them to come out right. If I am reading this correctly, the manual indicates that the trim motor should be ran to the full nose up position and the cables should be adjusted to achieve a 35 degree angle measuring from the top of the trim tab to the top of the elevator. When adjusted in this manner, the left trim tab will not come to a full neutral position. Even when the motor is ran to the full nose down position, the trailing edge of the trim tab is still 3/8ths of an inch lower than the trailing edge of the elevator. Has anyone experienced a problem like this? I know that I have been a quiet participant on this list, however, I have learned a great deal from all of you and appreciate your views and enthusiasm. We are on a wonderful journey, one that few people have an opportunity to explore. I have learned how exceptional we all can be when we have opportunity to create and develop the dream. I have a great deal of respect for what we have all decided to do together. We represent 1/1000 of the population, a pretty unique crowd. While I don't know you personally, I admire your choices and interest. Hope to see you all at OSH. Jack ________________________________________________________________________________
Subject: Fuel Tank Nose rivets
Date: Jul 07, 2005
Hi all, Just finishing off the tanks and was doing a final inspection of the rivets before installing the baffle. I noticed that the shop heads in the nose of the skin seemed to be much higher than the rest (ie the rivets had not been fully set). This is hard to confirm during rivetting with proseal everywhere. Once the proseal had set, the rivets were pretty solid but were still obviously dodgy. I took to them with the gun and bar again, and despite the right banging noises, the rivets would still not set properly. Closer investigation found that the bucking bar was contacting the raised flutes on the ribs - not the rivet tail. A change in bucking bar set the rivets properly and an extra dab of proseal seems to have done the job. I found that I needed to flute the forward part of the ribs quite a bit to have them fit properly, so the probability of whacking the flute was quite high. I guess I'm just a dummy for not tweaking earlier, and not noticing that the rivets were not set properly when I initially bucked them. Just thought I would pass on a lesson learned for those about to get there. cheers, Ron ________________________________________________________________________________
Date: Jul 06, 2005
Subject: Re: Elevator Trim Tabs
There was a thread a while back regarding this. If memory serves me correctly, one side does not travel as far as the other "by design"? -Sean #40303 flaps Rick wrote: > Jack, > > I don't know to be honest, When I set mine up a year ago I don't > recall any problems. It may be possible that the potentiometer inside > the servo may be outta alignment. I have seen that happen with other > servos where you only get half the throw in one drection and full > throw in the other, make sure the tirangle horn isn't binding as well, > I recall that as a pretty close fit in the mechanisim. Is it a matter > of not having enough travel? Are the cables set to the correct > lengths? I remember being very attentive to details putting that > together. Short of taking everything apart and redoing it that's all I > can offer. > > Rick S. > 40185 > Wings ________________________________________________________________________________ ;
Date: Jul 06, 2005
Thanks for the link. I think it will offer a lower cost route for a very capable VFR panel. Looks like weather, XM radio audio, SL30 integration and TIS with the right transponder. That's alot of additional capability over a 296 for an additional 1k. Garmin 396 + SL30 would be ~ 6000. This is close to the price of a GNS-430 without the GPS IFR capability. I've been using anywhere map for years but I think this Garmin product is far superior. I think Anywhere map is tough to use in turb and the display contrast and color choices leave alot to be desired. Mountain Scope has a better display but more limited features and a higher price. Eric --- Mark <2eyedocs(at)comcast.net> wrote: > http://shop.jaair.com/?step=productinfo&productNum=010-00425-00 > > Looks like it might be a very capable portable! > > Mark ________________________________________________________________________________
Date: Jul 07, 2005
Subject: Aileron deflection
Hi All, I know I've seen this but I think it was back on Yahoo because I could not find it in this list. When the aileron deflects down, what is the maximum degree of travel? And those who have past this most likely know why I'm asking I'm sure. The alieron pushrod will hit the hinge bracket at some point close to full down throw. Without both wings control systems tied into each other (I assume the stop for the opposite alieron in the "up" position works as the stop for the opposite in down) there is nothing limiting the throw short of the pushrod hitting the bracket. I just want to check the amount of throw to make sure hitting the bracket is not an issue before I close up the bottom skins. Rick S. 40185 Wings ________________________________________________________________________________ ;
Date: Jul 07, 2005
Jack, I had the same issues when working on my trim tabs. I just happened to be traveling to Portland at that time so I stopped in at Van's to see how N410RV's tabs operated for my self. This is what I learned. The right tab is the one to set the up/down deflection parameters. Set the left tab so it is at neutral when the right tab is neutral. The left tab will approximately follow the right through the down travel. Don't worry about full travel for the left tab. Essentially what I was told at Van's is that all the other RV's have only one tab. The RV-10 is nose heavy so the trim system was designed to give more nose up only. Both tabs provide nose up, right tab provides nose up and down. Steve wings 40212 --- Jack Sparling wrote: > Greetings to everyone: > > > > I have been struggling with the electric trim cable > adjustments and cannot > seem to get them to come out right. If I am reading > this correctly, the > manual indicates that the trim motor should be ran > to the full nose up > position and the cables should be adjusted to > achieve a 35 degree angle > measuring from the top of the trim tab to the top of > the elevator. When > adjusted in this manner, the left trim tab will not > come to a full neutral > position. Even when the motor is ran to the full > nose down position, the > trailing edge of the trim tab is still 3/8ths of an > inch lower than the > trailing edge of the elevator. Has anyone > experienced a problem like this? > > > > I know that I have been a quiet participant on this > list, however, I have > learned a great deal from all of you and appreciate > your views and > enthusiasm. We are on a wonderful journey, one that > few people have an > opportunity to explore. I have learned how > exceptional we all can be when > we have opportunity to create and develop the dream. > I have a great deal of > respect for what we have all decided to do together. > We represent 1/1000 of > the population, a pretty unique crowd. While I > don't know you personally, I > admire your choices and interest. > > > > Hope to see you all at OSH. > > > > Jack > > ________________________________________________________________________________
Subject: FW: [RV10] Aileron Control Clearances
Date: Jul 07, 2005
0.01 URI_REDIRECTOR Message has HTTP redirector URI Rick, I think this was the thread from Yahoo you were asking about... John #40208 Wings ________________________________ From: Randy DeBauw [mailto:randy(at)abros.com] Subject: RE: [RV10] Aileron Control Clearances Doug, the flap in the full up position is suppose to be nag. 3 deg.. Is that part of the problem or is it more of the aileron rod lengths. Randy -----Original Message----- From: Doug Peterson [mailto:rvator(at)cox.net] Subject: RE: [RV10] Aileron Control Clearances Randy is correct, due to design where one aileron rises more then it falls with movement, it does allow the tube to clear the hinge brace, but you really don't know this until both wings are installed and all controls are installed. I tested mine this weekend and the tube clears fine. But I do have an alignment problem with the wing tip TE to aileron TE to flap TE to fuselage that im going to scratch my head on for awhile. Doug _____ From: Randy DeBauw [mailto:randy(at)abros.com] Subject: RE: [RV10] Aileron Control Clearances Bob I ran into the same thing but after enlarging the hole some I stopped. I think what will happen will be that when the ailerons are connected together the opposite side will hit the stop before the rod will hit. At least that is what I am thinking. I won't know until both wings are installed and connected. Randy -----Original Message----- From: Bob Condrey [mailto:bob.condrey(at)baesystems.com] Subject: [RV10] Aileron Control Clearances When I was replacing washers in the aileron mount brackets (page 11 in last RVator) I noticed a potential clearance issue. When the ailerons are deflected down, the control tube comes extremely close to the some of the rivet heads on the inboard aileron bracket and the outboard edge of the spar hole. I talked to Van's yesterday AM and they suggested that I enlarge the hole slightly. Even if I enlarge the hole a bit there's not much clearance between the rivet heads and the control tube. Anybody else run into this? How much clearance do others have? Finally, anybody know what the max downward deflection limit will be for the ailerons? Bob #40105 < http://us.ard.yahoo.com/SIG129hj05qf/M296572.5585671.6651487.3001176/D gr oups/S1705340085:HM/EXP1101326633/A2343726/R0/SIG12i9n6otc/* http://clk. atdmt.com/VON/go/yhxxxvon01900091von/direct/01/ < http://us.ard.yahoo.com/SIG129hj05qf/M296572.5585671.6651487.3001176/D gr oups/S1705340085:HM/EXP1101326633/A2343726/R0/SIG12i9n6otc/*http:/c lk.a tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time1101240233371483> &time1101240233371483> < http://us.ard.yahoo.com/SIG129hj05qf/M296572.5585671.6651487.3001176/D gr oups/S1705340085:HM/EXP1101326633/A2343726/R1/SIG12i9n6otc/* http://clk. atdmt.com/VON/go/yhxxxvon01900091von/direct/01/ < http://us.ard.yahoo.com/SIG129hj05qf/M296572.5585671.6651487.3001176/D gr oups/S1705340085:HM/EXP1101326633/A2343726/R1/SIG12i9n6otc/*http:/c lk.a tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time1101240233371483> &time1101240233371483> Get unlimited calls to U.S./Canada < http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/ < http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/ <http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time1101 2402> &time11012402 33371483> &time1101240233371483> < http://us.adserver.yahoo.com/l?M296572.5585671.6651487.3001176/Dgroups /S :HM/A2343726/rand488345675> _____ * To visit your group on the web, go to: http://groups.yahoo.com/group/RV10/ * To unsubscribe from this group, send an email to: RV10-unsubscribe(at)yahoogroups.com Service < http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] < http://us.ard.yahoo.com/SIG129i34dl1/M281955.5600462.6665252.3001176/D gr oups/S1705340085:HM/EXP1101335558/A2343726/R0/SIG12ibvvqun/*http:/c lk.a tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time1101249158022986> < http://us.ard.yahoo.com/SIG129i34dl1/M281955.5600462.6665252.3001176/D gr oups/S1705340085:HM/EXP1101335558/A2343726/R1/SIG12ibvvqun/*http:/c lk.a tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time1101249158022986> Get unlimited calls to < http://us.ard.yahoo.com/SIG129i34dl1/M281955.5600462.6665252.3001176/D gr oups/S1705340085:HM/EXP1101335558/A2343726/R1/SIG12ibvvqun/*http:/c lk.a tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time1101249158022986> U.S./Canada < http://us.ard.yahoo.com/SIG129i34dl1/M281955.5600462.6665252.3001176/D gr oups/S1705340085:HM/EXP1101335558/A2343726/R1/SIG12ibvvqun/*http:/c lk.a tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time1101249158022986> < http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/ <http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time1101 2491> &time11012491 58022986> < http://us.adserver.yahoo.com/l?M281955.5600462.6665252.3001176/Dgroups /S :HM/A2343726/rand448612823> _____ * To visit your group on the web, go to: http://groups.yahoo.com/group/RV10/ * To unsubscribe from this group, send an email to: RV10-unsubscribe(at)yahoogroups.com < http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] ADVERTISEMENT <http://us.ard.yahoo.com/SIG1291o8v2n/M298184.5639630.6699735.3001176/ Dgroups/S1705340085:HM/EXP1101344234/A2434971/R0/SIG11eeoolb0/*htt p://www.netflix.com/Default?mqso60185400> click here <http://us.adserver.yahoo.com/l?M298184.5639630.6699735.3001176/Dgroup s/S:HM/A2434971/rand321251891> _____ * To visit your group on the web, go to: http://groups.yahoo.com/group/RV10/ * To unsubscribe from this group, send an email to: RV10-unsubscribe(at)yahoogroups.com Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] ADVERTISEMENT click here <http://us.ard.yahoo.com/SIG1290sge7l/M298184.5639630.6699735.3001176/ Dgroups/S1705340085:HM/EXP1101408911/A2434970/R0/SIG11edksnhv/*htt p://www.netflix.com/Default?mqso60185402> =09 <http://us.adserver.yahoo.com/l?M298184.5639630.6699735.3001176/Dgroup s/S:HM/A2434970/rand916028413> =09 ________________________________ * To visit your group on the web, go to: http://groups.yahoo.com/group/RV10/ * To unsubscribe from this group, send an email to: RV10-unsubscribe(at)yahoogroups.com Service <http://docs.yahoo.com/info/terms/> . ________________________________________________________________________________
Subject: mt prop
Date: Jul 07, 2005
? to the group : Is anyone buying the mt prop ? has anyone installed it yet ? How does it work perform ?, i am now deciding to put the money down on a prop , finish & engine forward kit coming in sept 05 also Aerosport io 540 in sept .Also not shure about the group buy that i have seen mail on , i know that vans sells therm also however you have to pick them up at a assembly center & would probably be extra $ not shure how much. Brian Bollaert 40200 ________________________________________________________________________________
Date: Jul 07, 2005
Subject: Door Bonding Photos/Info and More
I just updated my site and added the latest work.... Door Trimming, Cabin Top interior prep, Headliner, Cabin top interior paint, Autopilot Pitch Servo, and Door Bonding. I took the time to write up a bit of good info on a couple of points, so it might be worth reading if you're getting near that stage. I got REAL lucky last night on my first door, and mixed up just the right amount of epoxy almost to the drop. On the 2nd door, I added one more pump just to be safe. Total is about 20 pumps per door. Total quantity is about 80-85% of a full can of 105A/206A West System Epoxy, plus maybe about 1/2 to 2/3 of a can of colloidal Silica #406. I tried to detail a bunch of stuff on this page so that it's there for reference for others. Also, I'm glad I went with 206A hardner. 205A might have worked, but this allowed a leisurly but quick job. http://www.myrv10.com/N104CD/fuselage/20050706/index.html Enjoy! (and as always, if you have more to add, just send it on over) Tim -- Tim Olson -- RV-10 #170 Current project: Fuselage ________________________________________________________________________________
Subject: mt prop
Date: Jul 07, 2005
My buddy just put on a MT 3 blade prop on his Harmon Rocket (he had a 2 blade Hartzell). He said it now runs as smooth as an electric motor! He said it was very noticeably smoother and quieter. It is also about 45lbs lighter as I understand which is nice as the -10 is nose heavy (or should I say flies better with weight in the back). We are building 2 RV-10's in my hanger and they will both have the MT props..... -Mike Kraus RV-4 - Flying RV-10 - Wings and fuse.... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of brian bollaert Subject: RV10-List: mt prop ? to the group : Is anyone buying the mt prop ? has anyone installed it yet ? How does it work perform ?, i am now deciding to put the money down on a prop , finish & engine forward kit coming in sept 05 also Aerosport io 540 in sept .Also not shure about the group buy that i have seen mail on a assembly center & would probably be extra $ not shure how much. Brian Bollaert 40200 ________________________________________________________________________________ ;
Date: Jul 07, 2005
Thanks for the help, I appreciate the responses. All the best, Jack -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Darton Steve Subject: Re: RV10-List: Elevator Trim Tabs Jack, I had the same issues when working on my trim tabs. I just happened to be traveling to Portland at that time so I stopped in at Van's to see how N410RV's tabs operated for my self. This is what I learned. The right tab is the one to set the up/down deflection parameters. Set the left tab so it is at neutral when the right tab is neutral. The left tab will approximately follow the right through the down travel. Don't worry about full travel for the left tab. Essentially what I was told at Van's is that all the other RV's have only one tab. The RV-10 is nose heavy so the trim system was designed to give more nose up only. Both tabs provide nose up, right tab provides nose up and down. Steve wings 40212 --- Jack Sparling wrote: > Greetings to everyone: > > > > I have been struggling with the electric trim cable > adjustments and cannot > seem to get them to come out right. If I am reading > this correctly, the > manual indicates that the trim motor should be ran > to the full nose up > position and the cables should be adjusted to > achieve a 35 degree angle > measuring from the top of the trim tab to the top of > the elevator. When > adjusted in this manner, the left trim tab will not > come to a full neutral > position. Even when the motor is ran to the full > nose down position, the > trailing edge of the trim tab is still 3/8ths of an > inch lower than the > trailing edge of the elevator. Has anyone > experienced a problem like this? > > > > I know that I have been a quiet participant on this > list, however, I have > learned a great deal from all of you and appreciate > your views and > enthusiasm. We are on a wonderful journey, one that > few people have an > opportunity to explore. I have learned how > exceptional we all can be when > we have opportunity to create and develop the dream. > I have a great deal of > respect for what we have all decided to do together. > We represent 1/1000 of > the population, a pretty unique crowd. While I > don't know you personally, I > admire your choices and interest. > > > > Hope to see you all at OSH. > > > > Jack > > ________________________________________________________________________________
Subject: Fuel tank leak test
Date: Jul 07, 2005
All, I've started the leak check on my left fuel tank using Van's kit and a water manometer. I have a very slow drop in the water level of the manometer and have sprayed the tank with soapy water but can't find the leak. The fuel cap is taped over, I did find a few bubbles from that at first but the leak persists. Any hints? Thought about imersing the tank in the bath tub while pressurized. Suggestions appreciated.... John Hasbrouck #40264 ________________________________________________________________________________
Date: Jul 07, 2005
Subject: Re: Fuel tank leak test
Can you put a definition on "very slow"....if it's just a tiny leak, it could be the taped over fuel cap. I think it would be hard to get a perfect seal. Tim Tim Olson -- RV-10 #170 Current project: Fuselage John Hasbrouck wrote: > > All, > I've started the leak check on my left fuel tank using Van's kit and > a water manometer. I have a very slow drop in the water level of the > manometer and have sprayed the tank with soapy water but can't find the > leak. The fuel cap is taped over, I did find a few bubbles from that at > first but the leak persists. Any hints? Thought about imersing the > tank in the bath tub while pressurized. Suggestions appreciated.... > > John Hasbrouck > #40264 > ________________________________________________________________________________
Date: Jul 07, 2005
If you're already flying something else, or have lots of flying buddies around, jig it up real good so it doesn't tip over, block off vents and lines, and fill it with gas. Either auto or avgas. If it leaks, you'll know it. Using gas won't risk contamination by something that doesn't belong in it anyway, when done transfer the gas to vehicle(s) that need it. Or use the bathtub method and give the wife another test... John Kirkland #40333 ________________________________________________________________________________
Date: Jul 07, 2005
John, Remove the tape from the cap and remove the cap. Clean the opeing and use a good quality vinyl packing tape to seal the opeing. Leave the cap off if you like, I did. Use fuel lube on all threaded fittings and make sure your not getting erroneous readings from temperture changes, yes it's the manometer is that sensative. I had the same indication you did, it turned out that the cap was leaking and a small leak from the threads where I installed the schrader valve. Fuel lube solved that, sealing the fuel opeing real well also contributed to sucess. I was helping another builder and his leak came from the schrader valve to tank fitting as well. It was a small drop on the manometer just like you describe, it made big bubbles so if you have a leak and it's small...you can still expect big bubbles to appear with the soapy water...don't digress just yet. An area to check is where the forward tank spar exits the tank on the inboard side. This area has a large void that must get prosealed pretty well from the inside. This is the piece that holds the bearing for the alieron pushrod motion transfer bar. I had a small leak at the intersection of the fore and aft ribs and that brace/spar. I found it with a flashlight inside the tank in a dark room prior to installing the rear baffle. Hope this helps. Rick S. 40185 Wings ________________________________________________________________________________
Date: Jul 08, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
John, Using the manometer method you'll see the level rise and fall as a function of ambient air temp and pressure. I let mine sit for about a 24 hour period when the weather was benign (no fronts moving through) and took periodic readings of the level and air temp. Doing this you'll see the level drop when the temp goes down in the evening/night and rise when the temp rises. The filler cap area seems to be a common place for leaks - just tape over it. You may also see some very small air leaks around a rivet or two. Green Locktite will fix these easily. Just put a drop on the rivet and it wicks into voids. Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: RV10-List: Fuel tank leak test All, I've started the leak check on my left fuel tank using Van's kit and a water manometer. I have a very slow drop in the water level of the manometer and have sprayed the tank with soapy water but can't find the leak. The fuel cap is taped over, I did find a few bubbles from that at first but the leak persists. Any hints? Thought about imersing the tank in the bath tub while pressurized. Suggestions appreciated.... John Hasbrouck #40264 ________________________________________________________________________________
Date: Jul 08, 2005
Thanks for your responses. Seems I may have jumped the gun. After pumping the manometer ( just some vinyl clear hose ) to the level suggested by Van's ( 2' 3" difference between meniscii ) I saw a 1" drop over the period of an hour. Small leaks at the fittings found and corrected then the tank pumped again and hosed down with soapy water. Slow drop noticed again ( about 1" in an hour ) but could find no bubbles anywhere. By then it's late and I left it as is, wrote the e-mail and went to bed. Got up this morning fully expecting all the pressure to have leaked out and to my surprise it was just where I left it last night. Trying to figure out the reason for the initial drop in the water level. Tank is in a controlled enviornment and baro pressure has been steady. Posssible explanation might be expansion of the tank itself? Anyhow, given the above, I guessing there is no leak. BTW, gave some thought to the idea of filling it up with avgas but nixed that due to fire hazzard here at home. ________________________________________________________________________________
Subject: Plane parking at Oshkosh
Date: Jul 08, 2005
Does anybody know the procedure is to park our -10 with the other -10's at Oshkosh? Is any planning or reservation required? Cost for parking for the whole show? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Jul 08, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Check the vansairforce.net RV-10 Forum. There's a note there from the guy in charge of RV parking for Oshkosh, and he's looking to have a special area for -10's, relatively near Van's booth. Be sure to get the Oshkosh NOTAM document from the EAA web site and read the whole thing . . . TDT ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Jesse Saint Subject: RV10-List: Plane parking at Oshkosh Does anybody know the procedure is to park our -10 with the other -10's at Oshkosh? Is any planning or reservation required? Cost for parking for the whole show? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Jul 08, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Actually, being one of the first couple -10's completed you might want to check with Van's or Vans Airforce to see if they have anything in mind. Maybe you can get some sort of special handling. ;-) Michael ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RV10-List: Plane parking at Oshkosh Does anybody know the procedure is to park our -10 with the other -10's at Oshkosh? Is any planning or reservation required? Cost for parking for the whole show? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Subject: Oshkosh bound
Date: Jul 08, 2005
Ok, so we are just over 2 weeks away and I thought I would see if anyone is planning anything for Oshkosh. I'll be up there the whole week as I am from the immediate area and want to visit some friends and family. Tim, you up to putting together a list again like you did for Sun n Fun? Michael ________________________________________________________________________________
Date: Jul 08, 2005
Michael - Ditto, Maybe Tim can post the attendees and a rendezvous point. I will be flying out of PDX for ORD for a ten day rental car. I have an Air Boss obligation in Manitowok with the Red Pilots Association from Thursday, July 21 through Sunday, July 24 then have a house with Cascade Warbirds friends on the lake in OSH. Will be there the entire week and looking forward to seeing friends and meeting RV-10 rivet pounders. Still shy by two flying RV-10 but it should be a great presentation as the number of kits is inching towards that 500 I forecast. John - KUAO ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RV10-List: Oshkosh bound Ok, so we are just over 2 weeks away and I thought I would see if anyone is planning anything for Oshkosh. I'll be up there the whole week as I am from the immediate area and want to visit some friends and family. Tim, you up to putting together a list again like you did for Sun n Fun? Michael ________________________________________________________________________________
Date: Jul 08, 2005
Tim, Maybe just change the Sun-N-Fun spreadsheet to reflect Oshkosh? Last year several of us met immediately following Van's RV-10 forum just outside the pavilion - as a starting point, how 'bout that? What about adding a column on the spreadsheet to also indicate who all is attending Van's banquet? FWIW, I'll be attending the entire week. We were initially planning to bring our trailer and camping but have changed and are now renting a house. Plan is to drive up Sat 7/22 and depart Sun 7/30 AM. Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RV10-List: Oshkosh bound Ok, so we are just over 2 weeks away and I thought I would see if anyone is planning anything for Oshkosh. I'll be up there the whole week as I am from the immediate area and want to visit some friends and family. Tim, you up to putting together a list again like you did for Sun n Fun? Michael ________________________________________________________________________________
Date: Jul 08, 2005
Subject: Re: RV10-List Digest: mt prop
Hi All, The cost for assembly varies by the assembly center. Anywhere from $300 to $500 or more. You'll want to contact the assembly center closest to you for an estimate. The MT Propeller distributors are listed on _www.MT-Propeller.com_ (http://www.MT-Propeller.com) , then the "Contact" page and then the "Distributors" page. Regards, Jim Ayers In a message dated 07/07/2005 11:59:07 PM Pacific Daylight Time, rv10-list-digest(at)matronics.com writes: From: "brian bollaert" <bbollaert(at)comcast.net> Subject: RV10-List: mt prop ? to the group : Is anyone buying the mt prop ? has anyone installed it yet ? How does it work perform ?, i am now deciding to put the money down on a prop , finish & engine forward kit coming in sept 05 also Aerosport io 540 in sept .Also not shure about the group buy that i have seen mail on , i know that vans sells therm also however you have to pick them up at a assembly center & would probably be extra $ not shure how much. Brian Bollaert 40200 ________________________________________________________________________________
Date: Jul 08, 2005
Bob I'll be there camping in a 5th wheel by the sea plane area. Bob K Cell is the same as in Vegas 707-767-3587 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Subject: RE: RV10-List: Oshkosh bound Tim, Maybe just change the Sun-N-Fun spreadsheet to reflect Oshkosh? Last year several of us met immediately following Van's RV-10 forum just outside the pavilion - as a starting point, how 'bout that? What about adding a column on the spreadsheet to also indicate who all is attending Van's banquet? FWIW, I'll be attending the entire week. We were initially planning to bring our trailer and camping but have changed and are now renting a house. Plan is to drive up Sat 7/22 and depart Sun 7/30 AM. Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RV10-List: Oshkosh bound Ok, so we are just over 2 weeks away and I thought I would see if anyone is planning anything for Oshkosh. I'll be up there the whole week as I am from the immediate area and want to visit some friends and family. Tim, you up to putting together a list again like you did for Sun n Fun? Michael ________________________________________________________________________________
From: "Chris , Susie McGough" <VHMUM(at)bigpond.com>
Subject: Aussie visit to Vans
Date: Jul 09, 2005
Hi all we will be staying close to Vans aircraft for about a week from Aug3 and would like to catch up with any 10 builders in the area....we will have a car. Realy just want to take photos of peoples 10 in the latter stages of construction and also finished ones to get some ideas! You can reply directly if you wish Chris Susie Darcy vhmum(at)bigpond.com ----- Original Message ----- From: John W. Cox To: rv10-list(at)matronics.com Sent: Saturday, July 09, 2005 5:27 AM Subject: RE: RV10-List: Oshkosh bound Michael - Ditto, Maybe Tim can post the attendees and a rendezvous point. I will be flying out of PDX for ORD for a ten day rental car. I have an Air Boss obligation in Manitowok with the Red Pilots Association from Thursday, July 21 through Sunday, July 24 then have a house with Cascade Warbirds friends on the lake in OSH. Will be there the entire week and looking forward to seeing friends and meeting RV-10 rivet pounders. Still shy by two flying RV-10 but it should be a great presentation as the number of kits is inching towards that 500 I forecast. John - KUAO From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Friday, July 08, 2005 11:33 AM To: rv10-list(at)matronics.com Subject: RV10-List: Oshkosh bound Ok, so we are just over 2 weeks away and I thought I would see if anyone is planning anything for Oshkosh. I'll be up there the whole week as I am from the immediate area and want to visit some friends and family. Tim, you up to putting together a list again like you did for Sun n Fun? Michael ________________________________________________________________________________
Date: Jul 08, 2005
Subject: Re: Plane parking at Oshkosh
I saw something recently about parking 10's together. It was from eaa. Check with them. Doug 40372 ________________________________________________________________________________
Date: Jul 08, 2005
Subject: Re: Oshkosh bound
Just for consistency sake, the username will instead be "rv10list" for the OSH builder thing....sorry about that. That way it's the same as it was for snf. The password is different, so email me....it was based on "snf" before, so I went more generic this time so I can use this username/password combo elsewhere on the site if needed. Tim bob.kaufmann wrote: > Bob > > > > Ill be there camping in a 5 th wheel by the sea plane area. Bob K > > Cell is the same as in Vegas 707-767-3587 > > > > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Condrey, > Bob (US SSA) > *Sent:* Friday, July 08, 2005 12:03 PM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Oshkosh bound > > > > Tim, > > > > Maybe just change the Sun-N-Fun spreadsheet to reflect Oshkosh? Last > year several of us met immediately following Vans RV-10 forum just > outside the pavilion as a starting point, how bout that? > > > > What about adding a column on the spreadsheet to also indicate who all > is attending Vans banquet? > > > > FWIW, Ill be attending the entire week. We were initially planning to > bring our trailer and camping but have changed and are now renting a > house. Plan is to drive up Sat 7/22 and depart Sun 7/30 AM. > > > > Bob #40105 > > > > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *RV Builder > (Michael Sausen) > *Sent:* Friday, July 08, 2005 1:33 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Oshkosh bound > > > > Ok, so we are just over 2 weeks away and I thought I would see if anyone > is planning anything for Oshkosh. I'll be up there the whole week as I > am from the immediate area and want to visit some friends and family. > Tim, you up to putting together a list again like you did for Sun n Fun? > > > > Michael > ________________________________________________________________________________
Subject: fuel tank leak test
Date: Jul 08, 2005
Thanks for your replies! I posted this earlier today but it hasn't shown up on the e-mail so I'll try again. Thought I had a problem with a tank leak but turns out I jumped the gun a bit. Late last night and frustrated I had been searching for a leak. Using a water manometer as suggested by Van's ( just a loop of clear hose with a 2' 3" diference between the meniscii ) to establish 1 PSI in the tank, I pumped the tank up with a bicycle pump. Over a period of about 45 minutes the level of the water would drop about 1". So I'd pump it up again and douse the thing with soapy water. Couldn't find a leak to save my life so I went to bed fully expecting that in the morning the pressure would have bled off. To my surprise ( and relief ) , the pressure had stabilized and remained constant for the next 24 hours. Guess I don't have a leak afterall! Trying to figure out the initial pressure drop and an engineer friend of mine suggested that what I might have seen was the temperature change ( decrease ) of the compressed air as the tank cooled it. Moral of the story is to let things stabilize. John Hasbrouck #40264 One tank done! ________________________________________________________________________________
Date: Jul 08, 2005
Subject: Re: fuel tank leak test
And you thought you built a fuel tank huh??? With the manometer attached you really built a barometer!!! I had the same concerns...glad we all seem to have the same paths of construction... Now If someone can tell me how far down the ailerons deflect at full throw I'll be even happier!! Rick S. 40185 Wings ________________________________________________________________________________
Subject: I really really want to build an airplane.....
Date: Jul 08, 2005
Ohhh boy.... I thought I had the sickness bad before. I went to the EAA airshow up in Arlington, WA yesterday. After seeing the Vans line of experimental aircraft, my wife is totally on-board with the idea of building our own aircraft. It is a certainty that this will happen, probably in a couple of years. A few things in our lives need to be finished first before we can take on a project like this. Premature RV-Grin http://aspzone.com/photos/john/picture1244.aspx Rivet bucking help? http://aspzone.com/photos/john/picture1245.aspx ________________________________________________________________________________ spamd3.ruraltel.net * -4.0 RCVD_FROM_NEXTECH_2 Message came from 24.225.10-29.x network * 0.0 UNPARSEABLE_RELAY Informational: message has unparseable relay * lines * 0.0 HTML_MESSAGE BODY: HTML included in message * -0.8 BAYES_00 BODY: Bayesian spam probability is 0 to 1% * -0.1 AWL AWL: From: address is in the auto white-list
From: "Bill and Tami Britton" <william(at)gbta.net>
Date: Jul 09, 2005
Tim, I don't know when anybody else will be there but I am going to be there on Thursday through Saturday (2nd half of the show). If anybody is there during this time I would sure like to meet some of the guys on the matronics and Yahoo lists. This is my first show so I'm a new face in the crowd. Anyone else going to be there at that time??? Bill Britton RV-10 #40137 ----- Original Message ----- From: bob.kaufmann To: rv10-list(at)matronics.com Sent: Friday, July 08, 2005 3:30 PM Subject: RE: RV10-List: Oshkosh bound Bob I'll be there camping in a 5th wheel by the sea plane area. Bob K Cell is the same as in Vegas 707-767-3587 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Friday, July 08, 2005 12:03 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Oshkosh bound Tim, Maybe just change the Sun-N-Fun spreadsheet to reflect Oshkosh? Last year several of us met immediately following Van's RV-10 forum just outside the pavilion - as a starting point, how 'bout that? What about adding a column on the spreadsheet to also indicate who all is attending Van's banquet? FWIW, I'll be attending the entire week. We were initially planning to bring our trailer and camping but have changed and are now renting a house. Plan is to drive up Sat 7/22 and depart Sun 7/30 AM. Bob #40105 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Friday, July 08, 2005 1:33 PM To: rv10-list(at)matronics.com Subject: RV10-List: Oshkosh bound Ok, so we are just over 2 weeks away and I thought I would see if anyone is planning anything for Oshkosh. I'll be up there the whole week as I am from the immediate area and want to visit some friends and family. Tim, you up to putting together a list again like you did for Sun n Fun? Michael ________________________________________________________________________________
From: "Indran Chelvanayagam" <ichelva(at)netspace.net.au>
Date: Jul 09, 2005
I wonder if many of you guys who are going to Oshkosh are interested in getting together one night for food, drinks and chat about the RV-10 building experience - perhaps Wed/Thur night. From Tim's list so far, it doesn't look like many are going to Van's Banquet on Saturday night. Also, as the RV-10 forum is late in the week (1pm, 30 July, 08 GAMA pavilion), I second the notion of meeting at Van's booth at a predetermined time each day - 10.30am sounds good to me. Indran Chelvanayagam Bunbury, Western Australia #40228 Tailcone ________________________________________________________________________________
Date: Jul 09, 2005
Thursday would be a better night for me to get out for a dinner. Count me in. Mugshot is attached. I will have to be wearing a hat at the show (Reason should be obvious!). I will be wandering around the avionics and engine booths looking for stuff to put in the bird. Love to meet any and all. Looking for a cure for this "Disease". Don't think there is one. Oh Well! I will be over at Van's booth at the time suggested by Tim. Thanks, Tim for setting up the web page. Really useful! Can't wait! Jim Combs #40192 - Fuselage N312F Reserved Jim Combs ________________________________________________________________________________ ;
Date: Jul 09, 2005
Bill, I will likely be there for Fri-Sun. Steve 40212 wings --- Bill and Tami Britton wrote: > Tim, I don't know when anybody else will be there > but I am going to be there on Thursday through > Saturday (2nd half of the show). If anybody is > there during this time I would sure like to meet > some of the guys on the matronics and Yahoo lists. > This is my first show so I'm a new face in the > crowd. Anyone else going to be there at that > time??? > > Bill Britton > RV-10 #40137 > ----- Original Message ----- > From: bob.kaufmann > To: rv10-list(at)matronics.com > Sent: Friday, July 08, 2005 3:30 PM > Subject: RE: RV10-List: Oshkosh bound > > > Bob > > > > I'll be there camping in a 5th wheel by the sea > plane area. Bob K > > Cell is the same as in Vegas 707-767-3587 > > > > > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On > Behalf Of Condrey, Bob (US SSA) > Sent: Friday, July 08, 2005 12:03 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Oshkosh bound > > > > Tim, > > > > Maybe just change the Sun-N-Fun spreadsheet to > reflect Oshkosh? Last year several of us met > immediately following Van's RV-10 forum just outside > the pavilion - as a starting point, how 'bout that? > > > > What about adding a column on the spreadsheet to > also indicate who all is attending Van's banquet? > > > > FWIW, I'll be attending the entire week. We were > initially planning to bring our trailer and camping > but have changed and are now renting a house. Plan > is to drive up Sat 7/22 and depart Sun 7/30 AM. > > > > Bob #40105 > > > > > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On > Behalf Of RV Builder (Michael Sausen) > Sent: Friday, July 08, 2005 1:33 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oshkosh bound > > > > Ok, so we are just over 2 weeks away and I thought > I would see if anyone is planning anything for > Oshkosh. I'll be up there the whole week as I am > from the immediate area and want to visit some > friends and family. Tim, you up to putting together > a list again like you did for Sun n Fun? > > > > Michael > > __________________________________ http://discover.yahoo.com/ ________________________________________________________________________________
Subject: wireless intercom
Date: Jul 09, 2005
Anybody seen the www.aveousa.com product? If there's a way to avoid running another 8 twisted triplets I am going to buy it. ________________________________________________________________________________
Date: Jul 09, 2005
Tim, Point me to the website and I'll log in. I'll be there Sun and Mon but have to leave Tues am. John "Grumpy" Miller #40404 In a message dated 7/8/2005 6:19:52 PM Central Standard Time, Tim(at)MyRV10.com writes: Just for consistency sake, the username will instead be "rv10list" for the OSH builder thing....sorry about that. That way it's the same as it was for snf. The password is different, so email me....it was based on "snf" before, so I went more generic this time so I can use this username/password combo elsewhere on the site if needed. Tim ________________________________________________________________________________
Date: Jul 09, 2005
SSdtIHVwIGZvciBzb21ldGhpbmcgYW5kIHdpbGwgYmUgdGhlcmUgYWxsIHdlZWsgd2l0aCBubyBl dmVuaW5nIHBsYW5zIG90aGVyIHRoYW4gdGhlIGJhbnF1ZXQgU2F0dXJkYXkgbmlnaHQuDQogDQpC b2IgIzQwMTA1DQoNCgktLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLSANCglGcm9tOiBvd25lci1y djEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gb24gYmVoYWxmIG9mIEluZHJhbiBDaGVsdmFu YXlhZ2FtIA0KCVNlbnQ6IFNhdCAwNy8wOS8yMDA1IDA4OjE4IEFNIA0KCVRvOiBydjEwLWxpc3RA bWF0cm9uaWNzLmNvbSANCglDYzogDQoJU3ViamVjdDogUmU6IFJWMTAtTGlzdDogT3Noa29zaCBi b3VuZA0KCQ0KCQ0KCUkgd29uZGVyIGlmIG1hbnkgb2YgeW91IGd1eXMgd2hvIGFyZSBnb2luZyB0 byBPc2hrb3NoIGFyZSBpbnRlcmVzdGVkIGluIGdldHRpbmcgdG9nZXRoZXIgb25lIG5pZ2h0IGZv ciBmb29kLCBkcmlua3MgYW5kIGNoYXQgYWJvdXQgdGhlIFJWLTEwIGJ1aWxkaW5nIGV4cGVyaWVu Y2UgLSBwZXJoYXBzIFdlZC9UaHVyIG5pZ2h0LiBGcm9tIFRpbSdzIGxpc3Qgc28gZmFyLCBpdCBk b2Vzbid0IGxvb2sgbGlrZSBtYW55IGFyZSBnb2luZyB0byBWYW4ncyBCYW5xdWV0IG9uIFNhdHVy ZGF5IG5pZ2h0Lg0KCSANCglBbHNvLCBhcyB0aGUgUlYtMTAgZm9ydW0gaXMgbGF0ZSBpbiB0aGUg d2VlayAoMXBtLCAzMCBKdWx5LCAwOCBHQU1BIHBhdmlsaW9uKSwgSSBzZWNvbmQgdGhlIG5vdGlv biBvZiBtZWV0aW5nIGF0IFZhbidzIGJvb3RoIGF0IGEgcHJlZGV0ZXJtaW5lZCB0aW1lIGVhY2gg ZGF5IC0gMTAuMzBhbSBzb3VuZHMgZ29vZCB0byBtZS4NCgkgDQoJSW5kcmFuIENoZWx2YW5heWFn YW0NCglCdW5idXJ5LCBXZXN0ZXJuIEF1c3RyYWxpYQ0KCSM0MDIyOCBUYWlsY29uZQ0KDQo ________________________________________________________________________________
Date: Jul 11, 2005
Subject: Re: VERY bad news today
In a message dated 7/11/2005 12:27:26 A.M. Central Standard Time, Tim(at)MyRV10.com writes: http://www.saskatchewanairshow.com/main.php?group=/entertainment&action=/flyin g Know for sure that Jimmy Franklin was one of the pilots. ________________________________________________________________________________
Subject: VERY bad news today
Date: Jul 11, 2005
Bobby was the other. Prayers to all of the family. These are the people who make us dream of being better. ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of UFOBUCK(at)aol.com Subject: Re: RV10-List: VERY bad news today In a message dated 7/11/2005 12:27:26 A.M. Central Standard Time, Tim(at)MyRV10.com writes: http://www.saskatchewanairshow.com/main.php?group/entertainment&action/flying Know for sure that Jimmy Franklin was one of the pilots. ________________________________________________________________________________
Subject: fly-in Breakfast Aug. 28th Please post. Falls City, NE (FNB)
Currus Aircraft scheduled to attend
Date: Jul 11, 2005
From: "Schawang, Darrin" <SchawangD(at)macequipment.com>
=20<> Attached is a flyer for a Fly-in Breakfast=20on Aug. 28th at Falls City Nebraska (FNB) Brenner Field. The breakfast is provided by and benefits the Falls City Volunteer Rural Firemen. The fly-in is held in conjunction with the Cobblestone Festival. If you have any questions please call. If you have an event please forward the information and I will make sure that it is posted. Last year we had 45 plus aircraft, and served over 350 people breakfast. =20This year Cirrus is scheduled to have a airplane at our event. > Thanks for your assistance in making our event a success. > > Darrin Schawang > (402) 245-4020 ##################################################################################### The information contained in this communication is intended solely for the use of the individual or entity to whom it is addressed and others authorized to receive it. If you have received this communication in error, you must notify us immediately by responding to this e-mail and then deleting it from your system, and further you are hereby notified that any disclosure, copying, distribution or taking any action in reliance on the contents of this information without written permission from MAC Equipment, Inc. is strictly prohibited and may be unlawful. Any views, opinions, or authorizations contained in this email are solely those of the author and do not necessarily represent those of MAC Equipment, Inc. ##################################################################################### ________________________________________________________________________________
Subject: Elevator fit problem
Date: Jul 11, 2005
Ok guys, time for me to tap that vast knowledge out there as this one has me stumped. I have started the emp assembly part and immediately ran into a problem. My left elevator counterbalance arm has 0 clearance fore and almost an 1/8th inch aft on the top. On the bottom I have 1/16th fore and an 1/8th aft. My right elevator counterbalance arm has about 1/64th fore and 3/32nd aft on the top. The bottom has 3/32nd fore and aft. I also have some contact on the leading edge on the right elevator in full up position. I have triple checked the rod end bearings and they are all at 7/8th from the spar to the center of the bearing hole. I don't recall any fit problems during HS or elevator construction. It's almost like the top, fore, edge of the counterbalance arms have a slight canter in. Suggestions? Michael Sausen -10 #352 Emp Assembly ________________________________________________________________________________
Subject: RE: Elevator fit problem
Date: Jul 11, 2005
Sausen)" 0.03 HTML_TEXT_AFTER_HTML BODY": rv10-list(at)matronics.com Hmm, had a bit of a duh moment there. Gave them both a little oomph and, wouldn't you know it, gap was perfect. I really need to make sure I don't over think things. ;-) I do have one more little question that I forgot to include in the first post. The elevator horns are a little off in alignment with both in trail. One looks like it is a little lower and aft. Should I try to make sure they line up before drilling them or should I just leave them a little off? Michael Sausen -10 #352 Emp Assembly (slow build wings arrived today!) ________________________________
Subject: Elevator fit problem Ok guys, time for me to tap that vast knowledge out there as this one has me stumped. I have started the emp assembly part and immediately ran into a problem. My left elevator counterbalance arm has 0 clearance fore and almost an 1/8th inch aft on the top. On the bottom I have 1/16th fore and an 1/8th aft. My right elevator counterbalance arm has about 1/64th fore and 3/32nd aft on the top. The bottom has 3/32nd fore and aft. I also have some contact on the leading edge on the right elevator in full up position. I have triple checked the rod end bearings and they are all at 7/8th from the spar to the center of the bearing hole. I don't recall any fit problems during HS or elevator construction. It's almost like the top, fore, edge of the counterbalance arms have a slight canter in. Suggestions? Michael Sausen -10 #352 Emp Assembly ________________________________________________________________________________
Date: Jul 11, 2005
Subject: Re: RV-10 Rolling Height
Tim, What's the lenght from the end of the tail cone to the firewall? My fuse is due in a few weeks and I am wondering if I need to rearrange things. Rick S. 40185 Wings ________________________________________________________________________________
Date: Jul 11, 2005
It looks like about 214" from tip to tip after you get the 2 little cabin heat vents installed. Add maybe 1.5-2' I suppose for an engine mount later too, but up to this point where I am now, 214" about covers it all. Tim Olson -- RV-10 #40170 Rick wrote: > > Tim, > > What's the lenght from the end of the tail cone to the firewall? My fuse is due in a few weeks and I am wondering if I need to rearrange things. > > Rick S. > 40185 > Wings > ________________________________________________________________________________
Date: Jul 12, 2005
Subject: N610RV News?
Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 12, 2005
Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 12, 2005
That's actually not very great news, 10.5 @ 125. Is this typical? I used to do 12 @ 135 in the 182. I was hoping for better. John Jessen (riveting the VS and rudder) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Subject: Re: N610RV News?
Date: Jul 12, 2005
Before anybody jumps to any conclusions, let's quantify all of this. Randy, you mentioned "10.5 gal an hour at 125 kts." Can you be more specific? Indicated airspeed, altitude, OAT, altimeter setting for starters, and then whether "125 kts" means indicated or groundspeed, and how you arrived at that -- i.e. a 4-way GPS average, 3-way vector, etc. Also would be curious how you leaned it, i.e. "X degrees rich of cylinder #N's peak EGT" or something like that. Precision! )_( Dan RV-7 N714D (which burns ~4gph at 120KTAS 40*LOP 8000'DA) http://www.rvproject.com ----- Original Message ----- From: "John Jessen" <jjessen(at)rcn.com> Subject: RE: RV10-List: N610RV News? > > That's actually not very great news, 10.5 @ 125. Is this typical? I used > to do 12 @ 135 in the 182. I was hoping for better. > > John Jessen > (riveting the VS and rudder) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw > Sent: Tuesday, July 12, 2005 12:04 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: N610RV News? > > > Well I am in the final phase of painting the wheel pants. It is time for > another oil change. The oxy bottle will get purchased and hopefully > installed before Osh. The carpet is going in soon. > > I don't have enough time with the wheel pants on to get some true numbers > but Osh is coming up and should have some real numbers on a long trip like > that. I appears that if you pull back on the power at you can get about > 10.5 gal an hour at 125 kts. > I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. > It really handles 4 people well. In fact I prefer 4 people. > Myself, full fuel and 50 lbs in the back is fine. More trim and hold some > back pressure for the flare. Keep the speed up. Full flaps on all landings > seems to work best. Slower speed at touch down. The tires look great. Almost > no wear at 42 hours. Everyone that has ridden says how quiet it is. I have > the single mufflers system. Even people standing next to it when I had the > prop balanced said it was quite and that was running at 2300 RPM for 10 > seconds or so. The prop balance was a big help. I could feel it in the > rudder peddles before. Can't wait to get to Osh. With it but I have a lot of > work to still do in 1 weekend and a few weeknights. After Osh. It will be > almost done and I can get back to that > lawn. Where was that mower? I saw it 21 months ago.... Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2005 11:10 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: N610RV News? > > > Hey Randy, any more little tidbits of interesting info since the flyoff? > Just wondering how things are going. Hope you are having a blast! > > I just need a little "builder boost". :) > > -Sean #40303 nearing end of flaps > > ________________________________________________________________________________
Date: Jul 12, 2005
Keep it in perspective though......my Sundowner does 9-9.5 @ 110-112 Kts. Who really cares what the fuel flow is when you pull it way back that far. Fuel flow is directly related to speed...and speed is distance and time. For instance, would you rather rent a plane for $50/hr that goes 100kts, or one that goes 150Kts for $75/hr if you were going on a 1000Nm trip? Do the math and sure, the fuel burn may be much higher on the $75/hr plane, but the cost of the flight will be identical, and you'll get there over 3 hours quicker. Sure, you can get some slight economies by pulling the power back...Van's charts show the range increase as you reduce to lower % of power, but, is it really that big of a difference in the big scheme of things? I myself would rather get there before the kids get whiny, and pay the extra couple bucks. As for Randy's performance numbers, I'm not at all concerned what the fuel flow is at 125kts. I'd be much more interested to know what it flows at 165, 175, and 185Kts. Tim Tim Olson -- RV-10 #40170 Current project: Fuselage John Jessen wrote: > > That's actually not very great news, 10.5 @ 125. Is this typical? I used > to do 12 @ 135 in the 182. I was hoping for better. > > John Jessen > (riveting the VS and rudder) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw > Sent: Tuesday, July 12, 2005 12:04 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: N610RV News? > > > Well I am in the final phase of painting the wheel pants. It is time for > another oil change. The oxy bottle will get purchased and hopefully > installed before Osh. The carpet is going in soon. > > I don't have enough time with the wheel pants on to get some true numbers > but Osh is coming up and should have some real numbers on a long trip like > that. I appears that if you pull back on the power at you can get about > 10.5 gal an hour at 125 kts. > I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. > It really handles 4 people well. In fact I prefer 4 people. > Myself, full fuel and 50 lbs in the back is fine. More trim and hold some > back pressure for the flare. Keep the speed up. Full flaps on all landings > seems to work best. Slower speed at touch down. The tires look great. Almost > no wear at 42 hours. Everyone that has ridden says how quiet it is. I have > the single mufflers system. Even people standing next to it when I had the > prop balanced said it was quite and that was running at 2300 RPM for 10 > seconds or so. The prop balance was a big help. I could feel it in the > rudder peddles before. Can't wait to get to Osh. With it but I have a lot of > work to still do in 1 weekend and a few weeknights. After Osh. It will be > almost done and I can get back to that > lawn. Where was that mower? I saw it 21 months ago.... Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2005 11:10 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: N610RV News? > > > Hey Randy, any more little tidbits of interesting info since the flyoff? > Just wondering how things are going. Hope you are having a blast! > > I just need a little "builder boost". :) > > -Sean #40303 nearing end of flaps > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2005
Subject: N610RV Fuel Burn?
Randy, Are you still going with us Friday morning to OSH? This trip will make a great comparison for fuel burn and speed as we have 4 RV's going. 1. RV-4 IO-360 180HP, Fuel Injected Hartzell Prop, Mags. 2. RV-4 IO-320 170HP, Fuel Injected MT Prop, 1 Lighspeed 1 Mag. 3. RV-4 O-320 160HP, Carb, Hartzell Prop, Mags 4. RV-10 IO-540 260HP 5. V-35B Bonanza with GAMI Injectors (Very Aggressive Lean Of Peak Operator??) First Stop Helena, MT - home of $2.79 gas. Of course Randy will have all the baggage :) Rob Hickman ________________________________________________________________________________
Date: Jul 12, 2005
Yea but what would you do at 10.5? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: N610RV News? That's actually not very great news, 10.5 @ 125. Is this typical? I used to do 12 @ 135 in the 182. I was hoping for better. John Jessen (riveting the VS and rudder) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 12, 2005
Kts or mph -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: N610RV News? That's actually not very great news, 10.5 @ 125. Is this typical? I used to do 12 @ 135 in the 182. I was hoping for better. John Jessen (riveting the VS and rudder) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 12, 2005
I would love to give everyone some hard numbers but my flying to date mainly has been without wheel pants and would not be useful. I am about 1 week a way from doing some decent testing. I leave for osh in 1 week and 2 days. Come and see me there and I will have some good numbers. I think one question is what is everyone expecting for fuel burn. I can tell you my best guess is that if you get Van's numbers at 8000ft. you will be burning 15.5 gph. Or maybe 16.5. We will see. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Checkoway Subject: Re: RV10-List: N610RV News? Before anybody jumps to any conclusions, let's quantify all of this. Randy, you mentioned "10.5 gal an hour at 125 kts." Can you be more specific? Indicated airspeed, altitude, OAT, altimeter setting for starters, and then whether "125 kts" means indicated or groundspeed, and how you arrived at that -- i.e. a 4-way GPS average, 3-way vector, etc. Also would be curious how you leaned it, i.e. "X degrees rich of cylinder #N's peak EGT" or something like that. Precision! )_( Dan RV-7 N714D (which burns ~4gph at 120KTAS 40*LOP 8000'DA) http://www.rvproject.com ----- Original Message ----- From: "John Jessen" <jjessen(at)rcn.com> Subject: RE: RV10-List: N610RV News? > > That's actually not very great news, 10.5 @ 125. Is this typical? I used > to do 12 @ 135 in the 182. I was hoping for better. > > John Jessen > (riveting the VS and rudder) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw > Sent: Tuesday, July 12, 2005 12:04 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: N610RV News? > > > Well I am in the final phase of painting the wheel pants. It is time for > another oil change. The oxy bottle will get purchased and hopefully > installed before Osh. The carpet is going in soon. > > I don't have enough time with the wheel pants on to get some true numbers > but Osh is coming up and should have some real numbers on a long trip like > that. I appears that if you pull back on the power at you can get about > 10.5 gal an hour at 125 kts. > I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. > It really handles 4 people well. In fact I prefer 4 people. > Myself, full fuel and 50 lbs in the back is fine. More trim and hold some > back pressure for the flare. Keep the speed up. Full flaps on all landings > seems to work best. Slower speed at touch down. The tires look great. Almost > no wear at 42 hours. Everyone that has ridden says how quiet it is. I have > the single mufflers system. Even people standing next to it when I had the > prop balanced said it was quite and that was running at 2300 RPM for 10 > seconds or so. The prop balance was a big help. I could feel it in the > rudder peddles before. Can't wait to get to Osh. With it but I have a lot of > work to still do in 1 weekend and a few weeknights. After Osh. It will be > almost done and I can get back to that > lawn. Where was that mower? I saw it 21 months ago.... Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2005 11:10 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: N610RV News? > > > Hey Randy, any more little tidbits of interesting info since the flyoff? > Just wondering how things are going. Hope you are having a blast! > > I just need a little "builder boost". :) > > -Sean #40303 nearing end of flaps > > ________________________________________________________________________________
Subject: OSH
Date: Jul 12, 2005
I have been out of town and have missed some posts. What did the group deside about meeting early and where? Gary ________________________________________________________________________________
Date: Jul 12, 2005
Wow, did I open a can of worms? My fuel burn number at 125 kts is a very rough recollection. I see flew back from central Oregon in very bumpy conditions two weeks ago. I would not use the numbers for any thing but mindless chatter. It did show me that if I wanted to fly with 4 people full fuel and stay with my friend in his 172 I am guessing 9.5 gph or maybe 9.0. That is about that same as his 4cyl. My friend and I were talking the other day about a trip we are going to take in 3 weeks or so. He will have his 172. Just some conversation. It looks like that if you wanted to you could get the same fuel burn as the 172 with true 4 place and baggage ability. Crank it up get there soon. Your choice. This reminds me of a magazine article I read a few years back about a guy who owned an FBO. When ever he had to fly somewhere he almost always flew his Super cub. When asked by his employees why he didn't take one of the fast twin or fast retractable singles he ask them "What you guys don't like to fly." His point was flying fun. If you only want to go fast and land soon that is fine but it cuts down on the fun flying time. Just rambling. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: Re: RV10-List: N610RV News? Keep it in perspective though......my Sundowner does 9-9.5 @ 110-112 Kts. Who really cares what the fuel flow is when you pull it way back that far. Fuel flow is directly related to speed...and speed is distance and time. For instance, would you rather rent a plane for $50/hr that goes 100kts, or one that goes 150Kts for $75/hr if you were going on a 1000Nm trip? Do the math and sure, the fuel burn may be much higher on the $75/hr plane, but the cost of the flight will be identical, and you'll get there over 3 hours quicker. Sure, you can get some slight economies by pulling the power back...Van's charts show the range increase as you reduce to lower % of power, but, is it really that big of a difference in the big scheme of things? I myself would rather get there before the kids get whiny, and pay the extra couple bucks. As for Randy's performance numbers, I'm not at all concerned what the fuel flow is at 125kts. I'd be much more interested to know what it flows at 165, 175, and 185Kts. Tim Tim Olson -- RV-10 #40170 Current project: Fuselage John Jessen wrote: > > That's actually not very great news, 10.5 @ 125. Is this typical? I > used to do 12 @ 135 in the 182. I was hoping for better. > > John Jessen > (riveting the VS and rudder) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy > DeBauw > Sent: Tuesday, July 12, 2005 12:04 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: N610RV News? > > > Well I am in the final phase of painting the wheel pants. It is time > for another oil change. The oxy bottle will get purchased and > hopefully installed before Osh. The carpet is going in soon. > > I don't have enough time with the wheel pants on to get some true > numbers but Osh is coming up and should have some real numbers on a > long trip like that. I appears that if you pull back on the power at > you can get about > 10.5 gal an hour at 125 kts. > I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. > It really handles 4 people well. In fact I prefer 4 people. > Myself, full fuel and 50 lbs in the back is fine. More trim and hold > some back pressure for the flare. Keep the speed up. Full flaps on > all landings seems to work best. Slower speed at touch down. The tires > look great. Almost no wear at 42 hours. Everyone that has ridden says > how quiet it is. I have the single mufflers system. Even people > standing next to it when I had the prop balanced said it was quite and > that was running at 2300 RPM for 10 seconds or so. The prop balance > was a big help. I could feel it in the rudder peddles before. Can't > wait to get to Osh. With it but I have a lot of work to still do in 1 > weekend and a few weeknights. After Osh. It will be almost done and I can get back to that > lawn. Where was that mower? I saw it 21 months ago.... Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean > Stephens > Sent: Tuesday, July 12, 2005 11:10 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: N610RV News? > > > Hey Randy, any more little tidbits of interesting info since the flyoff? > Just wondering how things are going. Hope you are having a blast! > > I just need a little "builder boost". :) > > -Sean #40303 nearing end of flaps > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2005
Yes we are buddy. My wife and I are very excited to be with the group of experienced distance cruisers. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RobHickman(at)aol.com Subject: RV10-List: N610RV Fuel Burn? Randy, Are you still going with us Friday morning to OSH? This trip will make a great comparison for fuel burn and speed as we have 4 RV's going. 1. RV-4 IO-360 180HP, Fuel Injected Hartzell Prop, Mags. 2. RV-4 IO-320 170HP, Fuel Injected MT Prop, 1 Lighspeed 1 Mag. 3. RV-4 O-320 160HP, Carb, Hartzell Prop, Mags 4. RV-10 IO-540 260HP 5. V-35B Bonanza with GAMI Injectors (Very Aggressive Lean Of Peak Operator??) First Stop Helena, MT - home of $2.79 gas. Of course Randy will have all the baggage :) Rob Hickman ________________________________________________________________________________
Date: Jul 12, 2005
Randy, I'm not knocking your performance. The numbers just took me by surprise, and only because of the 182 performance (in kts, always in kts). That's all I have with that type of engine to reference it by. Of course burning 15-16 gph in the 182 would net me 140 max. There's no comparison at the top end. Dan is correct. I'll wait until you and others have a full set of numbers at speed at altitude, etc. My apologies for jumping the gun. Those countersinks came in, btw, in case you need them. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Yea but what would you do at 10.5? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: N610RV News? That's actually not very great news, 10.5 @ 125. Is this typical? I used to do 12 @ 135 in the 182. I was hoping for better. John Jessen (riveting the VS and rudder) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 12, 2005
"Randy DeBauw" Well you will go with me this weekend for a little testing. I will be at the hanger tonight. For the C/S if you will be around. -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: N610RV News? Randy, I'm not knocking your performance. The numbers just took me by surprise, and only because of the 182 performance (in kts, always in kts). That's all I have with that type of engine to reference it by. Of course burning 15-16 gph in the 182 would net me 140 max. There's no comparison at the top end. Dan is correct. I'll wait until you and others have a full set of numbers at speed at altitude, etc. My apologies for jumping the gun. Those countersinks came in, btw, in case you need them. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Yea but what would you do at 10.5? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: N610RV News? That's actually not very great news, 10.5 @ 125. Is this typical? I used to do 12 @ 135 in the 182. I was hoping for better. John Jessen (riveting the VS and rudder) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 12, 2005
report Yeah it seems kind of low on both counts. My friend's PA-28-235 running at 23 squared and leaned burns nearly 14 GPH so 10.5 GPH seems like it'd have to be WAY down the power chart. But then perhaps the injected 540 is WAY more efficient than the carburated B3B4. Anyone got the performance/power chart for an IO-540? -Brian Iowa City, IA ----- Original Message ----- From: "John Jessen" <jjessen(at)rcn.com> Subject: RE: RV10-List: N610RV News? > > That's actually not very great news, 10.5 @ 125. Is this typical? I used > to do 12 @ 135 in the 182. I was hoping for better. > > John Jessen > (riveting the VS and rudder) ________________________________________________________________________________
Date: Jul 12, 2005
Randy (and others), I'm attaching a spreadsheet that an RV friend of mine gave me. It correlates OATs and altitudes to specific density altitudes (8k, 10k, and 12k). If you're trying to fly at 8000' DA, then this spreadsheet is handy in the cockpit for determining the best altitude to fly to achieve that based on temperature. It's not 100% scientific, but it's close enough for our purposes. Hope this helps, and I look forward to seeing some test results. )_( Dan RV-7 N714D (558 hours) http://www.rvproject.com ----- Original Message ----- From: "Randy DeBauw" <Randy(at)abros.com> Subject: RE: RV10-List: N610RV News? > > Wow, did I open a can of worms? My fuel burn number at 125 kts is a very > rough recollection. I see flew back from central Oregon in very bumpy > conditions two weeks ago. I would not use the numbers for any thing but > mindless chatter. It did show me that if I wanted to fly with 4 people > full fuel and stay with my friend in his 172 I am guessing 9.5 gph or > maybe 9.0. That is about that same as his 4cyl. My friend and I were > talking the other day about a trip we are going to take in 3 weeks or > so. He will have his 172. Just some conversation. It looks like that if > you wanted to you could get the same fuel burn as the 172 with true 4 > place and baggage ability. Crank it up get there soon. Your choice. > This reminds me of a magazine article I read a few years back about a > guy who owned an FBO. When ever he had to fly somewhere he almost always > flew his Super cub. When asked by his employees why he didn't take one > of the fast twin or fast retractable singles he ask them "What you guys > don't like to fly." His point was flying fun. If you only want to go > fast and land soon that is fine but it cuts down on the fun flying time. > Just rambling. Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Tuesday, July 12, 2005 1:24 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: N610RV News? > > > Keep it in perspective though......my Sundowner does 9-9.5 @ > 110-112 Kts. Who really cares what the fuel flow is when > you pull it way back that far. Fuel flow is directly related to > speed...and speed is distance and time. > > For instance, would you rather rent a plane for $50/hr that goes 100kts, > or one that goes 150Kts for $75/hr if you were going on a 1000Nm trip? > > Do the math and sure, the fuel burn may be much higher on the $75/hr > plane, but the cost of the flight will be identical, and you'll get > there over 3 hours quicker. > > Sure, you can get some slight economies by pulling the power > back...Van's charts show the range increase as you reduce to lower % of > power, but, is it really that big of a difference in the big scheme of > things? I myself would rather get there before the kids get whiny, and > pay the extra couple bucks. > > As for Randy's performance numbers, I'm not at all concerned what the > fuel flow is at 125kts. I'd be much more interested to know what it > flows at 165, 175, and 185Kts. > > Tim > > > Tim Olson -- RV-10 #40170 > Current project: Fuselage > > > John Jessen wrote: > > > > That's actually not very great news, 10.5 @ 125. Is this typical? I > > used to do 12 @ 135 in the 182. I was hoping for better. > > > > John Jessen > > (riveting the VS and rudder) > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy > > DeBauw > > Sent: Tuesday, July 12, 2005 12:04 PM > > To: rv10-list(at)matronics.com > > Subject: RE: RV10-List: N610RV News? > > > > > > Well I am in the final phase of painting the wheel pants. It is time > > for another oil change. The oxy bottle will get purchased and > > hopefully installed before Osh. The carpet is going in soon. > > > > I don't have enough time with the wheel pants on to get some true > > numbers but Osh is coming up and should have some real numbers on a > > long trip like that. I appears that if you pull back on the power at > > you can get about > > 10.5 gal an hour at 125 kts. > > I still carry about 50 lbs in the baggage area when 2 up and pull it > with 4. > > It really handles 4 people well. In fact I prefer 4 people. > > Myself, full fuel and 50 lbs in the back is fine. More trim and hold > > some back pressure for the flare. Keep the speed up. Full flaps on > > all landings seems to work best. Slower speed at touch down. The tires > > > look great. Almost no wear at 42 hours. Everyone that has ridden says > > how quiet it is. I have the single mufflers system. Even people > > standing next to it when I had the prop balanced said it was quite and > > > that was running at 2300 RPM for 10 seconds or so. The prop balance > > was a big help. I could feel it in the rudder peddles before. Can't > > wait to get to Osh. With it but I have a lot of work to still do in 1 > > weekend and a few weeknights. After Osh. It will be almost done and I > can get back to that > > lawn. Where was that mower? I saw it 21 months ago.... Randy > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean > > Stephens > > Sent: Tuesday, July 12, 2005 11:10 AM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: N610RV News? > > > > > > Hey Randy, any more little tidbits of interesting info since the > flyoff? > > Just wondering how things are going. Hope you are having a blast! > > > > I just need a little "builder boost". :) > > > > -Sean #40303 nearing end of flaps > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: RV-10 for sale
Date: Jul 12, 2005
Just before Sun n Fun there was a -10 advertised for sale, finished in the $200K price range. Anyone know if it sold and for what $? Just curious. John Hasbrouck One tank down, one to go! ________________________________________________________________________________
Subject: Re: RV-10 for sale
Date: Jul 12, 2005
Linn, You're right, is was a spec but I wondered if anyone took the bait. Randy and I talked about it at SnF thinking the price was steep. But then again, Cessna wants $250K for a glassed up 172. Van was interested in the result as I recall. Nice to know what the rest of the market ( non-builders ) thinks of the -10. John Hasbrouck #40264 ________________________________________________________________________________
Date: Jul 12, 2005
Subject: Re: OSH
Sorry Gary, but I don't know if there's a real big consensus yet. The general feeling I get is that Thursday night would probably be the largest atteendance night if we have a gathering. It also sounds like there should be a fair turnout at the daily 10:30am meet-up at Van's booth. I do encourage y'all to take a quick jaunt and meet up daily at 10:30. At least from that point if there's something spur-of-the-moment being planned, everyone can hear it and spread the word. Many things tend to happen once a group meets eachother a bit. I don't have the resouces or schedule to be able to get a lid on planning a gathering other than the 10:30am thing, but anyone else who does is welcome to take the bull by the horns. I'm planning to skip probably 2 weekdays or maybe 3 myself. I don't think I'll show on Monday, and unless I stay overnight Thursday it's questionable about Friday. But, I'm absolutely going to be there Saturday, likely on Sunday, and try to for sure be there Tuesday and Thursday. If Tuesday's weather is crappy, I'll push until Wednesday. Wow, what a confusing mouthful. Anyway, if I'm not there on a day or two, y'all keep the stuff going for me. I just need to coordinate my flying back and forth, and the kids schedule while I'm gone. Tim Gary Specketer wrote: > I have been out of town and have missed some posts. What did the group > deside about meeting early and where? > Gary ________________________________________________________________________________
Subject: Lycoming Engine Mount Ears for Swap
Date: Jul 12, 2005
There is a guy on the Rocket list with a set of the small Lycoming engine mounting ears he would like to trade for the large ones. If you have a Lycoming with the Large diameter engine mounting ears, you will need the small ones for an RV-10. Please contact him for more information. >>Hi Mike, >>Yes, it would be great if you post my info on the RV10 website. >>They can contact me at: >>Peter van Schoonhoven >>360-901-7611 >>email pvans(at)pacifier.com >>My mounting ears are part number 70456. ________________________________________________________________________________
Subject: Hartzell CS Prop For Sale
Date: Jul 13, 2005
My RV-10 buddy Terry Cole, (builder #40045) who passed away of a heart attack at age 52 has a Hartzell CS Prop HC-C2YK-1BF-F8474-D-4, Serial #CH11073, 80" length, that has had the blades rolled, hub disassembled, serviced, all AD's complied with, and new seals installed by certified prop shop in Lubbock, Texas, available for $3000.00. Picture of hubs before reassembly, and custom blades paint job done by prop shop is attached. The prop shop is Porterfield Propellers, owned and operated by Tom Porterfield, (806) 749-8000. If you have any other questions please feel free to contact me on my cell phone (806) 535-1019. Best regards, Russ Daves #40044 (Fuselage on main gear) ________________________________________________________________________________
Subject: IO-540 Camshaft For Sale
Date: Jul 13, 2005
My RV-10 buddy Terry Cole, (builder #40045) who passed away of a heart attack at age 52 also has an IO-540 Camshaft, with the gears, for sale that has been overhauled and yellow tagged. Will sale for $400.00 or swap for an servicable camshaft for $200.00. If you have any other questions please feel free to contact me on my cell phone (806) 535-1019. Best regards, Russ Daves #40044 (Fuselage on main gear) ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Subject: Oshkosh bound
Date: Jul 13, 2005
I will be there for most of the show mug shot included will have some with the RV-10 soon. Noel RV-10 40091 paint -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Subject: Re: RV10-List: Oshkosh bound Thursday would be a better night for me to get out for a dinner. Count me in. Mugshot is attached. I will have to be wearing a hat at the show (Reason should be obvious!). I will be wandering around the avionics and engine booths looking for stuff to put in the bird. Love to meet any and all. Looking for a cure for this "Disease". Don't think there is one. Oh Well! I will be over at Van's booth at the time suggested by Tim. Thanks, Tim for setting up the web page. Really useful! Can't wait! Jim Combs #40192 - Fuselage N312F Reserved Jim Combs ________________________________________________________________________________
From: "stevenflys1(at)juno.com" <stevenflys1(at)juno.com>
Date: Jul 13, 2005
Subject: Oshkosh Question
I am planning on buying my RV-10 kit on or soon after October 31st (the day my divorce is settled). I plan to attend Oshkosh July 30th & 31st. I have been to Oshkosh twice before, but just to look, never to buy anything. Now that I am almost in a position to build I wanted some advice. Besides shopping and seeing things up close, what kind of deals can one typically find on tools, building material, etc. at Oshkosh? Does Vans offer any deals at the show? Another words, is it worth my time and money to buy things at Oshkosh or should I just order it all and have it shipped to South Carolina? Thanks for your input. Steven J Morris wanna-be builder ________________________________________________________________________________
Date: Jul 13, 2005
Van's never has deals. Feel free to order anytime and not loose out. You can save on avionics but don't' buy anything yet. Tools will be your big savings or at least you can checkout all of the vendors. I bought my Pnum. Squeezer at Oshkosh in 03. I sold it 195.00. The guy I bought it from says he gets 300.00 for the same thing now. There is so much to see that I spent 6 days there and still missed some. That is if you take in a dozen or so forums. The forums will be a big help. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of stevenflys1(at)juno.com Subject: RV10-List: Oshkosh Question --> I am planning on buying my RV-10 kit on or soon after October 31st (the day my divorce is settled). I plan to attend Oshkosh July 30th & 31st. I have been to Oshkosh twice before, but just to look, never to buy anything. Now that I am almost in a position to build I wanted some advice. Besides shopping and seeing things up close, what kind of deals can one typically find on tools, building material, etc. at Oshkosh? Does Vans offer any deals at the show? Another words, is it worth my time and money to buy things at Oshkosh or should I just order it all and have it shipped to South Carolina? Thanks for your input. Steven J Morris wanna-be builder ________________________________________________________________________________
Date: Jul 13, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Van's doesn't offer any discount for ordering at OSH. I'm sure you could find deals on tools piecemeal, but (my opinion) you're probably just as well off calling Avery and/or Cleaveland and asking them if they'll have a show special and if so, if you can get it now. Then spend your time at OSH talking with other builders, sitting in the fuselage mock-up dreaming, attending forums, and drooling over cool avionics. BTW, I upgraded my compressor from a 26 gal, 5 HP vertical to a 60 gal, 7HP. The 26 gal is a model VT6315 (from Home Depot, made by Campbell Hausfeld) now collecting dust. It's not quite 2 years old and I'd make somebody a heck of a deal if they want it. I've also got a Ryobi 9" bandsaw that somebody can have for free it they want it:) I was never satisfied with it but it would certainly get somebody started! I'll be driving up and can bring either or both along - email me offline if interested. Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of stevenflys1(at)juno.com Subject: RV10-List: Oshkosh Question I am planning on buying my RV-10 kit on or soon after October 31st (the day my divorce is settled). I plan to attend Oshkosh July 30th & 31st. I have been to Oshkosh twice before, but just to look, never to buy anything. Now that I am almost in a position to build I wanted some advice. Besides shopping and seeing things up close, what kind of deals can one typically find on tools, building material, etc. at Oshkosh? Does Vans offer any deals at the show? Another words, is it worth my time and money to buy things at Oshkosh or should I just order it all and have it shipped to South Carolina? Thanks for your input. Steven J Morris wanna-be builder ________________________________________________________________________________
Subject: Re: Oshkosh Question
Date: Jul 13, 2005
Hi,my name is Hugo,I 'm a new suscriber at this forum,since the RV10 is in the market I look to order one,Just sold my Socata Rallye 180,I have a few questions before order one ,but the mos important is ,yesterday somebody mention the best he can have is 10,5 GPH at 125 .the reason I will suffer for at least 5 years with not flying(I love building too) is because the advertise 175 mph at cruise.four adults and full fuel,its this something realistic or will be a myth.. Hugo > > From: "Randy DeBauw" <Randy(at)abros.com> > Date: 2005/07/13 Wed AM 10:41:35 EDT > To: > Subject: RE: RV10-List: Oshkosh Question > > > Van's never has deals. Feel free to order anytime and not loose out. You > can save on avionics but don't' buy anything yet. Tools will be your big > savings or at least you can checkout all of the vendors. I bought my > Pnum. Squeezer at Oshkosh in 03. I sold it 195.00. The guy I bought it > from says he gets 300.00 for the same thing now. There is so much to see > that I spent 6 days there and still missed some. That is if you take in > a dozen or so forums. The forums will be a big help. Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > stevenflys1(at)juno.com > Sent: Wednesday, July 13, 2005 7:27 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oshkosh Question > > --> > > > I am planning on buying my RV-10 kit on or soon after October 31st (the > day my divorce is settled). I plan to attend Oshkosh July 30th & 31st. > I have been to Oshkosh twice before, but just to look, never to buy > anything. Now that I am almost in a position to build I wanted some > advice. Besides shopping and seeing things up close, what kind of deals > can one typically find on tools, building material, etc. at Oshkosh? > Does Vans offer any deals at the show? Another words, is it worth my > time and money to buy things at Oshkosh or should I just order it all > and have it shipped to South Carolina? Thanks for your input. > Steven J Morris > wanna-be builder > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2005
You didn't pickup on the fact that I was at a very low power setting. Something like 45%. If you push the black knob in you will cruse at high speed. I was making a statement that if you wanted to run low power you can get very reasonable fuel burn and still get 125 kts. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gommone7(at)bellsouth.net Subject: Re: RE: RV10-List: Oshkosh Question Hi,my name is Hugo,I 'm a new suscriber at this forum,since the RV10 is in the market I look to order one,Just sold my Socata Rallye 180,I have a few questions before order one ,but the mos important is ,yesterday somebody mention the best he can have is 10,5 GPH at 125 .the reason I will suffer for at least 5 years with not flying(I love building too) is because the advertise 175 mph at cruise.four adults and full fuel,its this something realistic or will be a myth.. Hugo > > From: "Randy DeBauw" <Randy(at)abros.com> > Date: 2005/07/13 Wed AM 10:41:35 EDT > To: > Subject: RE: RV10-List: Oshkosh Question > > > Van's never has deals. Feel free to order anytime and not loose out. > You can save on avionics but don't' buy anything yet. Tools will be > your big savings or at least you can checkout all of the vendors. I > bought my Pnum. Squeezer at Oshkosh in 03. I sold it 195.00. The guy I > bought it from says he gets 300.00 for the same thing now. There is so > much to see that I spent 6 days there and still missed some. That is > if you take in a dozen or so forums. The forums will be a big help. > Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > stevenflys1(at)juno.com > Sent: Wednesday, July 13, 2005 7:27 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oshkosh Question > > --> > > > I am planning on buying my RV-10 kit on or soon after October 31st > (the day my divorce is settled). I plan to attend Oshkosh July 30th & 31st. > I have been to Oshkosh twice before, but just to look, never to buy > anything. Now that I am almost in a position to build I wanted some > advice. Besides shopping and seeing things up close, what kind of > deals can one typically find on tools, building material, etc. at Oshkosh? > Does Vans offer any deals at the show? Another words, is it worth my > time and money to buy things at Oshkosh or should I just order it all > and have it shipped to South Carolina? Thanks for your input. > Steven J Morris > wanna-be builder > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2005
John, Yep, that's the one. Did it sell? Randy and I had the same conversation about -10 values. ________________________________________________________________________________
Subject: speed
Date: Jul 13, 2005
Off course I understand if you push you will go fast ,my question was if somebody flying see the advertise numbers speed and payload. Hugo ________________________________________________________________________________
Date: Jul 13, 2005
Cleaveland Tools had a show special last year on their tool kit. That's when I bought mine. Other than that not many other deals that you'd be interested in. As mentioned before, Van's doesn't discount. The price is right already. OSH is a good chance to look around at what's available but I'd concentrate on basic building info and any seminars concerning your project. Avionics, interiors, instruments ect. are a ways down the road. One caution, unless you know for sure what you're buying, stay out of the fly market...........john ________________________________________________________________________________
Subject: speed
Date: Jul 13, 2005
I just received a call from Van's. They will have some true numbers for you at Oshkosh in a customers plane. I can't tell you who's. I'll be busy next Wed am. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gommone7(at)bellsouth.net Subject: RV10-List: speed Off course I understand if you push you will go fast ,my question was if somebody flying see the advertise numbers speed and payload. Hugo ________________________________________________________________________________
Date: Jul 13, 2005
Subject: Re: speed
Hugo, Randy is flying, he is in the test stages, although he has flown off his hours to allow passengers. All of us are waiting for his info, which he is graciously going to provide as soon as he works through his detailed testing. I'm sure it will be posted here right away. Until then you have to go by Van's numbers and the matronics archives for other builders input and or speculation as to the performance. Rick s. 40185 Wings ________________________________________________________________________________
Subject: Re: speed
Date: Jul 13, 2005
Thanks, Hugo PS. if anybody need fiberglass work ,or special molds .,I'm building boats(inflatables) in Ft Lauderdale,anythings will take me out of work for airplanes will do me a favor > > From: "Randy DeBauw" <Randy(at)abros.com> > Date: 2005/07/13 Wed PM 01:23:33 EDT > To: > Subject: RE: RV10-List: speed > > > I just received a call from Van's. They will have some true numbers for > you at Oshkosh in a customers plane. I can't tell you who's. I'll be > busy next Wed am. Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > gommone7(at)bellsouth.net > Sent: Wednesday, July 13, 2005 10:03 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: speed > > > Off course I understand if you push you will go fast ,my question was if > somebody flying see the advertise numbers speed and payload. > Hugo > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Rudder Pedal Cable Attach
Date: Jul 13, 2005
SSA)" Randy, What was the final solution that you used for the cable attach to the pedals? I found reference to the issue but not the solution in either the archives or on Tim's website. Bob #40105 ________________________________________________________________________________
Date: Jul 13, 2005
Speaking of pedals (rudder). Has anyone connected a rudder trim system in a 10? If so, what method did you us? Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 -----Original Message----- From: Condrey, Bob (US SSA) [mailto:bob.condrey(at)baesystems.com] Subject: RV10-List: Rudder Pedal Cable Attach Randy, What was the final solution that you used for the cable attach to the pedals? I found reference to the issue but not the solution in either the archives or on Tim's website. Bob #40105 ________________________________________________________________________________
Date: Jul 13, 2005
Of the other RV variants, those that I have seen that have needed them use a small wedge placed/glued on the trailing edge of the rudder. I have also heard of people using springs for this, but have not seen any in person. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick Subject: RE: RV10-List: Rudder Pedal Cable Attach Speaking of pedals (rudder). Has anyone connected a rudder trim system in a 10? If so, what method did you us? Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 -----Original Message----- From: Condrey, Bob (US SSA) [mailto:bob.condrey(at)baesystems.com] Subject: RV10-List: Rudder Pedal Cable Attach Randy, What was the final solution that you used for the cable attach to the pedals? I found reference to the issue but not the solution in either the archives or on Tim's website. Bob #40105 ________________________________________________________________________________
Date: Jul 13, 2005
I attached just like the plans. No issue. Just make sure that you install the master cyl bolts so the nuts are facing away from your shoe. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Subject: RV10-List: Rudder Pedal Cable Attach --> Randy, What was the final solution that you used for the cable attach to the pedals? I found reference to the issue but not the solution in either the archives or on Tim's website. Bob #40105 ________________________________________________________________________________
Date: Jul 13, 2005
Thanks - I thought the issue was where the cable attached to the pedals and that you couldn't put the bolt in the other direction due to clearance with the tunnel wall. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: Rudder Pedal Cable Attach I attached just like the plans. No issue. Just make sure that you install the master cyl bolts so the nuts are facing away from your shoe. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Subject: RV10-List: Rudder Pedal Cable Attach --> Randy, What was the final solution that you used for the cable attach to the pedals? I found reference to the issue but not the solution in either the archives or on Tim's website. Bob #40105 ________________________________________________________________________________
Subject: N610RV News?
Date: Jul 13, 2005
We've been getting number like 175mph (sorry for the statue numbers) at 9.5gph at 12,000 with no gear leg fairings. We've seen 175ish @ 8.5gph @ 14,500. It likes high. We should get some good number on the trip to Osh. Osh will be the first cross-country. Weight-wise, it does take full back stick on the flare with one or 2 in the front. Interestingly, if Tom's spreadsheet is accurate, adding another person in the front seat actually moves the CG back a little bit (of course you have a forward CG with more weight in that case). We were putting 80lbs in the luggage to the first couple of hours, but removed it and haven't put it back in. We installed two AeroTrim servos for the rudder and aileron and we love them. You can trip that baby out no matter where the weight is then fly with you feet on the floor. The ball stays almost pegged in the center. The servos aren't impressive-looking, but it is a super-easy install (especially after everything is closed up and the plane is flying) and they seem to work great. We got them for $175 each plus about $35 for the relay decks to be able to use the SPST action of the coolie hat. We have an Infinity Aerospace stick grip with 3 axis trim, flaps, PTT, Auto Pilot connect/disconnect and flight timer start/stop. Boost pump switch is between the throttle and prop knobs. That way everything's at the fingertips. The Dynons are great instruments and the TruTrak ADI is quite impressive. It sounds like Dynon is going to be shipping their 7" EFIS by Oshkosh and the EMS by the end of the year. For those wanting a glass cockpit on a budget, $5,000 will take the whole setup home. They don't have a GPS yet in the product line, but they hope to in the future. I realize they aren't Cheltons, but they don't cost $25,900 for a pair either. See you at Osh. I am in St. Louis right now on the way to WI for a wedding (yes, I am driving 3 days with the family while my dad flies it in a day, could almost do it non-stop, in the -10). Then a week of vacation in the north woods and Osh on the 24th. GOD BLESS! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: N610RV News? That's actually not very great news, 10.5 @ 125. Is this typical? I used to do 12 @ 135 in the 182. I was hoping for better. John Jessen (riveting the VS and rudder) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Subject: RE: RV10-List: N610RV News? Well I am in the final phase of painting the wheel pants. It is time for another oil change. The oxy bottle will get purchased and hopefully installed before Osh. The carpet is going in soon. I don't have enough time with the wheel pants on to get some true numbers but Osh is coming up and should have some real numbers on a long trip like that. I appears that if you pull back on the power at you can get about 10.5 gal an hour at 125 kts. I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. It really handles 4 people well. In fact I prefer 4 people. Myself, full fuel and 50 lbs in the back is fine. More trim and hold some back pressure for the flare. Keep the speed up. Full flaps on all landings seems to work best. Slower speed at touch down. The tires look great. Almost no wear at 42 hours. Everyone that has ridden says how quiet it is. I have the single mufflers system. Even people standing next to it when I had the prop balanced said it was quite and that was running at 2300 RPM for 10 seconds or so. The prop balance was a big help. I could feel it in the rudder peddles before. Can't wait to get to Osh. With it but I have a lot of work to still do in 1 weekend and a few weeknights. After Osh. It will be almost done and I can get back to that lawn. Where was that mower? I saw it 21 months ago.... Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: N610RV News? Hey Randy, any more little tidbits of interesting info since the flyoff? Just wondering how things are going. Hope you are having a blast! I just need a little "builder boost". :) -Sean #40303 nearing end of flaps ________________________________________________________________________________
Date: Jul 13, 2005
One of the big issues for us on fuel burn vs. flight time is whether or not you will have to make a stop. If you are going 1,000 miles (yes, I am talking statue number as always, sorry), it would be better to back it off to wherever it is required to make it non-stop. Descending and buying fuel, and getting back in for another hour or two actually adds about and hour or two to the flight and might add more whining to the kids. You know, a little bit of nitros-oxide added to the rear seat passengers' oxygen would take care of most of the whining, but then I guess you are increasing your cost again. OH YEAH, invest in a DVD player and they can sit forever, right? IT ALL DEPENDS ON THE USE! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: Re: RV10-List: N610RV News? Keep it in perspective though......my Sundowner does 9-9.5 @ 110-112 Kts. Who really cares what the fuel flow is when you pull it way back that far. Fuel flow is directly related to speed...and speed is distance and time. For instance, would you rather rent a plane for $50/hr that goes 100kts, or one that goes 150Kts for $75/hr if you were going on a 1000Nm trip? Do the math and sure, the fuel burn may be much higher on the $75/hr plane, but the cost of the flight will be identical, and you'll get there over 3 hours quicker. Sure, you can get some slight economies by pulling the power back...Van's charts show the range increase as you reduce to lower % of power, but, is it really that big of a difference in the big scheme of things? I myself would rather get there before the kids get whiny, and pay the extra couple bucks. As for Randy's performance numbers, I'm not at all concerned what the fuel flow is at 125kts. I'd be much more interested to know what it flows at 165, 175, and 185Kts. Tim Tim Olson -- RV-10 #40170 Current project: Fuselage John Jessen wrote: > > That's actually not very great news, 10.5 @ 125. Is this typical? I used > to do 12 @ 135 in the 182. I was hoping for better. > > John Jessen > (riveting the VS and rudder) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw > Sent: Tuesday, July 12, 2005 12:04 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: N610RV News? > > > Well I am in the final phase of painting the wheel pants. It is time for > another oil change. The oxy bottle will get purchased and hopefully > installed before Osh. The carpet is going in soon. > > I don't have enough time with the wheel pants on to get some true numbers > but Osh is coming up and should have some real numbers on a long trip like > that. I appears that if you pull back on the power at you can get about > 10.5 gal an hour at 125 kts. > I still carry about 50 lbs in the baggage area when 2 up and pull it with 4. > It really handles 4 people well. In fact I prefer 4 people. > Myself, full fuel and 50 lbs in the back is fine. More trim and hold some > back pressure for the flare. Keep the speed up. Full flaps on all landings > seems to work best. Slower speed at touch down. The tires look great. Almost > no wear at 42 hours. Everyone that has ridden says how quiet it is. I have > the single mufflers system. Even people standing next to it when I had the > prop balanced said it was quite and that was running at 2300 RPM for 10 > seconds or so. The prop balance was a big help. I could feel it in the > rudder peddles before. Can't wait to get to Osh. With it but I have a lot of > work to still do in 1 weekend and a few weeknights. After Osh. It will be > almost done and I can get back to that > lawn. Where was that mower? I saw it 21 months ago.... Randy > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2005 11:10 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: N610RV News? > > > Hey Randy, any more little tidbits of interesting info since the flyoff? > Just wondering how things are going. Hope you are having a blast! > > I just need a little "builder boost". :) > > -Sean #40303 nearing end of flaps > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2005
We have an AeroTrim for both rudder and aileron. We love 'em. No matter where your fuel or passengers are, whether your are climbing or descending, you can get it trimmed out and hand's off. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick Subject: RE: RV10-List: Rudder Pedal Cable Attach Speaking of pedals (rudder). Has anyone connected a rudder trim system in a 10? If so, what method did you us? Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 -----Original Message----- From: Condrey, Bob (US SSA) [mailto:bob.condrey(at)baesystems.com] Subject: RV10-List: Rudder Pedal Cable Attach Randy, What was the final solution that you used for the cable attach to the pedals? I found reference to the issue but not the solution in either the archives or on Tim's website. Bob #40105 ________________________________________________________________________________
Date: Jul 13, 2005
I will be there Fri-Sun (29-31st). Would love to meet some you guys. Mug shot attached. Jeff -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Noel & Yoshie Simmons Subject: RE: RV10-List: Oshkosh bound I will be there for most of the show mug shot included will have some with the RV-10 soon. Noel RV-10 40091 paint -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Subject: Re: RV10-List: Oshkosh bound Thursday would be a better night for me to get out for a dinner. Count me in. Mugshot is attached. I will have to be wearing a hat at the show (Reason should be obvious!). I will be wandering around the avionics and engine booths looking for stuff to put in the bird. Love to meet any and all. Looking for a cure for this "Disease". Don't think there is one. Oh Well! I will be over at Van's booth at the time suggested by Tim. Thanks, Tim for setting up the web page. Really useful! Can't wait! Jim Combs #40192 - Fuselage N312F Reserved Jim Combs ________________________________________________________________________________
Date: Jul 13, 2005
Jesse, Can you provide link or contact info for this? Rick S. N246RS 40185 Da Wings...waiting on Da Fuse...Sorry, in Chicago this week and next. ________________________________________________________________________________
Date: Jul 13, 2005
Subject: Re: N610RV News?
I LOVE the nitrous idea....I suppose I could always give them extra dramamine. ;) I'm planning to put in rear seat movies, but as a post-flying install. I definitely see your point about the stops. Usually I can keep the stops with the kids to under 30 minutes, but it does add to the trip. I didn't care in the past because on a 1000 mile trip, I wanted to land and get a weather radar picture, but, now I'll have that in my cockpit.....so I may as well keep the range up and move along. Hey, post a shot or two of your trim system...would be interesting to all. Definitely look me up at OSH...can't wait to see your -10! Tim Jesse Saint wrote: > > One of the big issues for us on fuel burn vs. flight time is whether or not > you will have to make a stop. If you are going 1,000 miles (yes, I am > talking statue number as always, sorry), it would be better to back it off > to wherever it is required to make it non-stop. Descending and buying fuel, > and getting back in for another hour or two actually adds about and hour or > two to the flight and might add more whining to the kids. You know, a > little bit of nitros-oxide added to the rear seat passengers' oxygen would > take care of most of the whining, but then I guess you are increasing your > cost again. OH YEAH, invest in a DVD player and they can sit forever, > right? > > IT ALL DEPENDS ON THE USE! > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > W: 352-465-4545 > C: 352-427-0285 > F: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Tuesday, July 12, 2005 4:24 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: N610RV News? > > > Keep it in perspective though......my Sundowner does 9-9.5 @ > 110-112 Kts. Who really cares what the fuel flow is when > you pull it way back that far. Fuel flow is directly related > to speed...and speed is distance and time. > > For instance, would you rather rent a plane for $50/hr > that goes 100kts, or one that goes 150Kts for $75/hr > if you were going on a 1000Nm trip? > > Do the math and sure, the fuel burn may be much higher > on the $75/hr plane, but the cost of the flight will > be identical, and you'll get there over 3 hours quicker. > > Sure, you can get some slight economies by pulling the power > back...Van's charts show the range increase as you > reduce to lower % of power, but, is it really that big > of a difference in the big scheme of things? I myself > would rather get there before the kids get whiny, and > pay the extra couple bucks. > > As for Randy's performance numbers, I'm not at all > concerned what the fuel flow is at 125kts. I'd > be much more interested to know what it flows > at 165, 175, and 185Kts. > > Tim > > > Tim Olson -- RV-10 #40170
June 28, 2005 - July 14, 2005
RV10-Archive.digest.vol-am
