RV10-Archive.digest.vol-aq
August 28, 2005 - September 19, 2005
      > 2.000 AN5-4A BOLT
      > BAG 971 RV-10 WIRING HARNESS
      > 4.000 AN960-10L WASHER, THIN
      > 4.000 AN960-416 WASHER 1/4
      > 2.000 AN960-516L WASHER (032) 5/16
      > 12.000 AN960-8 WASHER #8
      > 2.000 K1000-08 PLATENUT 8-32
      > 4.000 MS21042-3 1032 ALL METAL L/NUT
      > 2.000 MS21045-5 HW PINCH NUT 5/16
      > 2.000 MS21919DG12 CUSHIONED CLAMP
      > 7.000 MS21919DG2 1/8" CUSHION CLAMP
      > 5.000 MS21919DG4 1/4" CUSHION CLAMP
      > 5.000 MS21919WDG6 3/8" CUSHION CLAMP
      > 1.000 MS21919DG8 CUSHIONED CLAMP
      > 1.000 MS21919DG10 CUSHIONED CLAMP
      > 3.000 MS21919WDG3 3/16" CUSHIONED CLAMP
      > 1.000 MS35206-248 832X3/4 PAN HD SCREW
      > 1.000 MS35206-250 832X1 1/4 PAN HD SCR.
      > BAG 972 RV-10 WIRING HARNESS
      > 6.000 BUSHING SB375-3 SNAP-IN 3/16ID 3/8 OD
      > 4.000 BUSHING SB500-6 SNAP-IN 3/8 ID 1/2 OD
      > 2.000 BUSHING SB625-8 SNAP-IN 1/2ID 5/8 OD
      > 6.000 BUSHING SB750-10 SNAP-IN 5/8 ID 3/4 OD
      > 12.000 RIVET LP4-3 POP RIVET
      > 2.000 BUSH AL-058X5/16X1 ALUMINUM BUSHING -8
      > 2.000 C-606 LINK
      > 2.000 F-1016H GUIDE BRACKET
      > 1.000 BAG 995 WIRING KIT HW
      > 20.000 AN365-832A NUT,STOP 8-32
      > 5.000 MS35206-248 832X3/4 PAN HD SCREW
      > 7.000 MS35206-250 832X1 1/4 PAN HD SCR.
      > 17.000 AN960-8 WASHER #8
      > 1.000 AN5-5A BOLT
      > 1.000 AN960-516 WASHER 5/16
      > 1.000 AN365-524 NUT,STOP 5/16-24
      > 4.000 MS35333-39 3/16 INT TOOTH L/W
      > 1.000 BAG 997 SPARE WIRE LABELS
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL F1
      > 1.000 WH SM35-3/8-9X0.5J SHRINK LABEL J1
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL J2
      > 1.000 WH SM35-1/8-9X.25J HEAT SHRINK LABEL
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL J5
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL K1
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL K2
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L1
      > 1.000 WH SM35-1/8-9X0.5L SHRINK LABEL L2
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L3
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L4
      > 1.000 WH SM35-1/8-9X0.5L SHRINK LABEL L5
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L6
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L7
      > 1.000 WH SM35-3/8-9X0.5P SHRINK LABEL P1
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL P2
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL P3
      > 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P7
      > 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P8
      > 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P9
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL P12
      > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL Q1
      > 1.000 WH SM35-3/32-9X.25
      > 1.000 F-10110-L WIRE COVER
      > 1.000 F-10111 ANGLE BRACKETS
      > 1.000 WH-800A TERMINAL BLOCK BASE
      > 1.000 WH-800B TERMINAL BLOCK TOP
      > 1.000 WH-801 RT.CONSOLE TEMPLATE
      > 1.000 WH-P13 BUSS BAR JUMPER #8
      > 1.000 WH-P17 #2 ELEC.CABLE 37.25"
      > 2.000 WH-P25 #2 AWG BRAIDED 7.25"
      > 1.000 WH-P27 #2 AWG ELEC.CABLE
      > 1.000 WH-P4F #2 ELEC.CABLE 7.75"
      > 1.000 WH-P5 #2 ELEC.CABLE 11"
      > 1.000 ES 24021 STARTER SOLENOID 2OUT
      > 1.000 ES 24115 MASTER RELAY
      > 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF KIT------
Date: Aug 28, 2005
Subject: Firewall Forward Cables
I just wanted to verify the cables that I'll have on an IO-540. I have the Mixture, Prop, Throttle cables...all nice heavy green covered ones. I also have 3 plain push-pull cables with black knobs. I know one is front seat and one is rear seat heat, but the 3rd....all I can see is that it looks to be going to the FAB under the engine. I do see references to "carb heat", and "alternate air". Is this just the cable that opens the air bypass from the FAB? If so, would it be labeled "Alternate Air"? I wouldn't need to be asking so soon, but I'm trying to plan for where these cables will mount before I silkscreen my panel lables. Not sure if I should just mount them on that bottom panel support bar, or build a separate bracket....or build a console under the throttle quadrant. Tim -- Tim Olson -- RV-10 #40170 Current project: Spinner ________________________________________________________________________________
Subject: Antennas
Date: Aug 28, 2005
Put your gps antenna on a bracket off of the firewall under the cowling. I've done it on 2 planes and it works great. I think the XM can go there too. I can send a picture if you need to see the set-up. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Subject: RV10-List: Antennas Randy and others. I am to the point of having to commit on my antennas and wanted to see how yours are working. Here is my general plan. Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 Whip comm antenna on the belly Transponder antenna on the belly ELT antenna in tail Archer marker antenna in left wing tip Archer comm antenna in left wingtip GPS antenna on top of canopy or on glare shield XM radio antenna on glare shield Thanks in advance for any comments. Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Subject: Antennas
Date: Aug 28, 2005
Yes the pictures would help and I think it is a great idea. Rene' 40322 N423CF rene(at)felker.com 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Subject: RE: RV10-List: Antennas Put your gps antenna on a bracket off of the firewall under the cowling. I've done it on 2 planes and it works great. I think the XM can go there too. I can send a picture if you need to see the set-up. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Subject: RV10-List: Antennas Randy and others. I am to the point of having to commit on my antennas and wanted to see how yours are working. Here is my general plan. Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 Whip comm antenna on the belly Transponder antenna on the belly ELT antenna in tail Archer marker antenna in left wing tip Archer comm antenna in left wingtip GPS antenna on top of canopy or on glare shield XM radio antenna on glare shield Thanks in advance for any comments. Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Subject: Re: Antennas
Date: Aug 28, 2005
Check the Archer documentation. I believe I read that putting two navs on a splitter with his antenna will damage the radios, ----- Original Message ----- From: Rene To: rv10-list(at)matronics.com Sent: Saturday, August 27, 2005 9:04 PM Subject: RV10-List: Antennas Randy and others. I am to the point of having to commit on my antennas and wanted to see how yours are working. Here is my general plan. Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 Whip comm antenna on the belly Transponder antenna on the belly ELT antenna in tail Archer marker antenna in left wing tip Archer comm antenna in left wingtip GPS antenna on top of canopy or on glare shield XM radio antenna on glare shield Thanks in advance for any comments. Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: Van's RV-10 Wiring kit/fuel floats
Date: Aug 28, 2005
Tim, Thanks for the tip to hold off riveting bottom skins until painting. I had a heck of a time adjusting the fuel floats in the QB - have to look through the tiny drain hole to see where the float hits. And just when I get it centered between the top stiffener and vent line it hits the stiffener on the bottom - couple hours of trial and error getting the arch of the travel just right. It is still a little too close to the stiffeners for my liking. Did you get ample clearance on both ends? The final resistance readings were 30.1 to 248.9 - that should work. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: Re: RV10-List: Van's RV-10 Wiring kit John, I would think that for most -10 builders, it will be hard to stick with a "standard" wiring kit. They're including a lot of stuff in the area of switches and things that you may not want, depending on how you wire your panel and what components you go with. The wiring, in my mind, is a pretty custom thing for most builders, and doesn't seem to go well with making a "kit", unless maybe you had them trim the kit down to some bare essentials that you know you'll do as stock. A comforting thing is that you have lots of time to think this through, as you can get all the way through the engine install before you have to worry about pulling any wires (just leave your bottom wing skins off until painting time). How far are you on the tailcone? It says "finishing tail", but is that including the tailcone? If so, you're moving along well and congrats! Tim Tim Olson -- RV-10 #40170 Current project: spinner jwt(at)roadmapscoaching.com wrote: > Vans now has a wiring kit out for the 10 (details below). Has anyone > purchased it or given it serious consideration? Is this a reasonable > route to go or do you believe it better to go thru Stein or another source? > > > John Testement > jwt(at)roadmapscoaching.com > 40321 > Finishing tail > > > > *ES WH 10 KIT I(O)-540 RV-10 WIRING HARNESS */1.000 WH-10 HARNESS > I(O)-540/ 1.000 WH-F1 INSTR BKR-TB #16 1.000 WH-J1 ALT BKR-ALT #8 > 1.000 WH-J2 ALT SW-V REG-ALT #18 1.000 WH-J3 IG SW LEFT-PLEAD #18S > 1.000 WH-J4 IG SW R-PLEAD #18S 1.000 WH-J5 IG SW-TB GND 1.000 WH-K1 IG > SW-START RELAY #18 1.000 WH-K2 IG SW-INST TB #18 1.000 WH-L1 NAV LT > SW-PNL LT #18 1.000 WH-L2 LAND/TAXI SW-R TB #14 1.000 WH-L3-1 STROBE > SWITCH >POWER 1.000 WH-L4 NAV LT SW-R TB #18 1.000 WH-L5 LAND/TAXI > SW-L TB #14 1.000 WH-L7 NAV SW-L TB #18 1.000 WH-L8 NAV.LT TO TAIL > LIGHT 1.000 WH-P12 RADIO SW-TB #16 1.000 WH-P2 MASTER SW-GND #18 1.000 > WH-P3 MASTER SW-M RELAY #18 1.000 WH-P8 FLAP SW-MOTOR #18 1.000 WH-P9 > FLAP SW-MOTOR #18 1.000 WH-P28 BUSS BAR JUMPER 1.000 WH-Q1 PUMP > SW-PUMP #18 40.000 PLASTIC TIE WRAP 4 4" PLASTIC TIE WRAP 1.000 WH-P7 > FLAP CIRCUIT WIRE 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF SUBKIT------ > > /1.000 ES WH-SK HARNESS SUPPLEMENT/ > 20.000 PLASTIC TIE WRAP 4 4" PLASTIC TIE WRAP 55.000 WIRE M22759/16-18 > #18 GAUGE ELECT WIRE 55.000 WIRE M22759/16-16 #16 GAUGE ELECT WIRE > 25.000 WIRE M22759/16-14 #14 GAUGE ELECT WIRE 25.000 WIRE M22759/16-22 > 22 GA ELECT WIRE $/FT 12.000 ES 36152 TERMINAL #20 WR #6 TR 35.000 ES > 31890 #18 TERMINAL 5.000 ES 36154 TERMINAL #20WR #10STD 20.000 ES > 320565 #14-16 TERMINAL 1.000 ES 324082 #8 RING/ 1/4 STUD 8.000 ES > 320559 #18 SPLICE 7.000 ES 320562 #14-16 SPLICE 1.000 ES HST-3/8X1' > HEAT SHRINK TUBE 1.000 ES HST-3/16X1' HEAT SHRINK TUBE 1.000 ES > HST-1/4X1' HEAT SHRINK TUBE 2.000 ES BUSS BAR-063X.5 1/16X1/2X12 > COPPER BR 25.000 DUCT NT5/8 NYLON 5/8 TUBE ($/FT) 4.000 MS25171-1S > NIPPLE (BOOT) SMALL 7.000 MS25171-3S NIPPLE (BOOT) LARGE 6.000 BUSHING > SB750-10 SNAP-IN 5/8 ID 3/4 OD 4.000 BUSHING SB437-4 SNAP-IN 1/4ID > 7/16 OD 1.000 TAPE UHMW 3"X12" INSULATING TAPE 1.000 ES 324044 #8L > TERMINAL 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF SUBKIT------ > > /1.000 ES WH-SW 10 BREAKER SET RV-10A/ 2.000 ES PBB-5 TOGGLE SWITCH > BREAKER 3.000 ES PBB-10 TOGGLE SWITCH BREAKER 1.000 ES PBB-20 TOGGLE > SWITCH BREAKER 1.000 ES PBB-5A CB PLAIN CIRCUIT BREAKER 1.000 ES > PBB-10A CB PLAIN CIRCUIT BREAKER 1.000 ES CB 1648-009-060 60 AMP > CIRCUIT BRKER 1.000 ES 2GK54-73 SWITCH DPST SWITCH (ON/OFF) 1.000 > ZZZZZZZ EOK ZZZZZZ -----END OF SUBKIT------ > > 1.000 DOC ES HARNESS-10 WIRING DWGS AND TEXT > > BAG 970 RV-10 WIRING HARNESS > 1.000 AN3-4A BOLT > 3.000 AN3-3A BOLT > 1.000 AN365-428 NUT,STOP 1/4-28 > 12.000 AN365-832A NUT,STOP 8-32 > 2.000 AN4-4A BOLT > 1.000 AN4-5A BOLT > 1.000 AN509-10R12 SCREW,FLT HD STRUCT > 1.000 AN509-8R8 SCREW,FLT HD STRUCT > 10.000 AN515-8R8 SCREW,ROUND HD > 2.000 AN526C832R8 SCREW,TRUSS HD SS > 2.000 AN5-4A BOLT > > BAG 971 RV-10 WIRING HARNESS > 4.000 AN960-10L WASHER, THIN > 4.000 AN960-416 WASHER 1/4 > 2.000 AN960-516L WASHER (032) 5/16 > 12.000 AN960-8 WASHER #8 > 2.000 K1000-08 PLATENUT 8-32 > 4.000 MS21042-3 1032 ALL METAL L/NUT > 2.000 MS21045-5 HW PINCH NUT 5/16 > 2.000 MS21919DG12 CUSHIONED CLAMP > 7.000 MS21919DG2 1/8" CUSHION CLAMP > 5.000 MS21919DG4 1/4" CUSHION CLAMP > 5.000 MS21919WDG6 3/8" CUSHION CLAMP > 1.000 MS21919DG8 CUSHIONED CLAMP > 1.000 MS21919DG10 CUSHIONED CLAMP > 3.000 MS21919WDG3 3/16" CUSHIONED CLAMP 1.000 MS35206-248 832X3/4 PAN > HD SCREW 1.000 MS35206-250 832X1 1/4 PAN HD SCR. > > BAG 972 RV-10 WIRING HARNESS > 6.000 BUSHING SB375-3 SNAP-IN 3/16ID 3/8 OD 4.000 BUSHING SB500-6 > SNAP-IN 3/8 ID 1/2 OD 2.000 BUSHING SB625-8 SNAP-IN 1/2ID 5/8 OD 6.000 > BUSHING SB750-10 SNAP-IN 5/8 ID 3/4 OD 12.000 RIVET LP4-3 POP RIVET > 2.000 BUSH AL-058X5/16X1 ALUMINUM BUSHING -8 2.000 C-606 LINK 2.000 > F-1016H GUIDE BRACKET > > 1.000 BAG 995 WIRING KIT HW > 20.000 AN365-832A NUT,STOP 8-32 > 5.000 MS35206-248 832X3/4 PAN HD SCREW 7.000 MS35206-250 832X1 1/4 PAN > HD SCR. > 17.000 AN960-8 WASHER #8 > 1.000 AN5-5A BOLT > 1.000 AN960-516 WASHER 5/16 > 1.000 AN365-524 NUT,STOP 5/16-24 > 4.000 MS35333-39 3/16 INT TOOTH L/W > > 1.000 BAG 997 SPARE WIRE LABELS > 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL F1 1.000 WH SM35-3/8-9X0.5J > SHRINK LABEL J1 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL J2 1.000 WH > SM35-1/8-9X.25J HEAT SHRINK LABEL 1.000 WH SM35-1/8-9X.25J HEAT SHRINK > LABEL 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL J5 1.000 WH > SM35-3/32-9X0.5 SHRINK LABEL K1 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL > K2 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L1 1.000 WH SM35-1/8-9X0.5L > SHRINK LABEL L2 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L3 1.000 WH > SM35-3/32-9X0.5 SHRINK LABEL L4 1.000 WH SM35-1/8-9X0.5L SHRINK LABEL > L5 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L6 1.000 WH SM35-3/32-9X0.5 > SHRINK LABEL L7 1.000 WH SM35-3/8-9X0.5P SHRINK LABEL P1 1.000 WH > SM35-3/32-9X0.5 SHRINK LABEL P2 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL > P3 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P7 1.000 WH SM35-1/8-9X0.5P > SHRINK LABEL P8 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P9 1.000 WH > SM35-3/32-9X0.5 SHRINK LABEL P12 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL > Q1 1.000 WH SM35-3/32-9X.25 > > 1.000 F-10110-L WIRE COVER > 1.000 F-10111 ANGLE BRACKETS > 1.000 WH-800A TERMINAL BLOCK BASE > 1.000 WH-800B TERMINAL BLOCK TOP > 1.000 WH-801 RT.CONSOLE TEMPLATE > 1.000 WH-P13 BUSS BAR JUMPER #8 > 1.000 WH-P17 #2 ELEC.CABLE 37.25" > 2.000 WH-P25 #2 AWG BRAIDED 7.25" > 1.000 WH-P27 #2 AWG ELEC.CABLE > 1.000 WH-P4F #2 ELEC.CABLE 7.75" > 1.000 WH-P5 #2 ELEC.CABLE 11" > 1.000 ES 24021 STARTER SOLENOID 2OUT > 1.000 ES 24115 MASTER RELAY > 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF KIT------ > ________________________________________________________________________________
Subject: Fuel strainer and drain plug seal
Date: Aug 28, 2005
What do you use to seal the fuel strainer and drain plug on the tanks? Plans just say install them. Do you put Proseal on them or some other type of sealant. Seem like just metal on metal won't be a good seal. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins ________________________________________________________________________________
Subject: Re: Fuel strainer and drain plug seal
Date: Aug 28, 2005
John, Amazingly it does seal - metal to metal. Anh #141 Cowling ----- Original Message ----- From: jwt(at)roadmapscoaching.com To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 11:01 AM Subject: RV10-List: Fuel strainer and drain plug seal What do you use to seal the fuel strainer and drain plug on the tanks? Plans just say install them. Do you put Proseal on them or some other type of sealant. Seem like just metal on metal won't be a good seal. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins ________________________________________________________________________________
Date: Aug 28, 2005
MessagePhotos of an under-cowl GPS antenna installation: http://www.rvproject.com/20030824.html See the bottom of the page. It works flawlessly...although somebody did say something about metallic paint being problematic. I can't vouch for that, just what I heard. )_( Dan RV-7 N714D (605 hours) http://www.rvproject.com ----- Original Message ----- From: Rene To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 6:15 AM Subject: RE: RV10-List: Antennas Yes the pictures would help and I think it is a great idea. Rene' 40322 N423CF rene(at)felker.com 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Sent: Sunday, August 28, 2005 6:35 AM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Antennas Put your gps antenna on a bracket off of the firewall under the cowling. I've done it on 2 planes and it works great. I think the XM can go there too. I can send a picture if you need to see the set-up. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Sunday, August 28, 2005 12:04 AM To: rv10-list(at)matronics.com Subject: RV10-List: Antennas Randy and others. I am to the point of having to commit on my antennas and wanted to see how yours are working. Here is my general plan. Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 Whip comm antenna on the belly Transponder antenna on the belly ELT antenna in tail Archer marker antenna in left wing tip Archer comm antenna in left wingtip GPS antenna on top of canopy or on glare shield XM radio antenna on glare shield Thanks in advance for any comments. Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Date: Aug 28, 2005
LOL..... Finally a reason to NOT order the QB wings, adjusting the float arms. Rick S. 40185 Fuse ________________________________________________________________________________
Date: Aug 28, 2005
Subject: Re: Van's wiring kit
On one of the other lists some time ago, Wiremasters<http://www.wiremasters.net/>in TN was recommended as an inexpensive place for RG-400 (and all 22759 wire). Please note that I have NO experience with them, just passing on a previous recommendation--so please do some homework. -Jim > > Where did you buy the wire? Any place special? I need to start the > wiring. > ________________________________________________________________________________
Date: Aug 28, 2005
Everywhere outside of the tank, use thread sealant on all threaded fluid fittings. The best I have found it the "Teflon" type thread sealant sold at Napa auto part stores. This is the stuff in a tube, not Teflon tape. Keep it a thread or two away from the end of the fitting so that no sealant contacts fluid. No sealant on flared fittings. Carl Froehlich RV-8A (200hrs) Dogwood Airpark (VA-42) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of jwt(at)roadmapscoaching.com Sent: Sunday, August 28, 2005 11:02 AM To: rv10-list(at)matronics.com Subject: RV10-List: Fuel strainer and drain plug seal What do you use to seal the fuel strainer and drain plug on the tanks? Plans just say install them. Do you put Proseal on them or some other type of sealant. Seem like just metal on metal won't be a good seal. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins ________________________________________________________________________________
Date: Aug 28, 2005
Hi All, The general plan looks good. Bob Archer recommends that his Marker Beacon antenna should be mounted in the same wingtip with the NAV antenna. Regards, Jim Ayers In a message dated 08/27/2005 11:59:07 PM Pacific Daylight Time, rv10-list-digest(at)matronics.com writes: From: "Rene" <rene(at)felker.com> Subject: RV10-List: Antennas Randy and others. I am to the point of having to commit on my antennas and wanted to see how yours are working. Here is my general plan. Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 Whip comm antenna on the belly Transponder antenna on the belly ELT antenna in tail Archer marker antenna in left wing tip Archer comm antenna in left wingtip GPS antenna on top of canopy or on glare shield XM radio antenna on glare shield Thanks in advance for any comments. Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Date: Aug 28, 2005
Subject: AHRS proximity to GPS/WSI antennas
Anyone know if there's a limitation on how close you can mount an AHRS to a GPS antenna, or a WSI antenna? I see all sorts of restrictions on proximity to steel, and high current devices, but not to things like antennas and shielded wires like that. The WSI does a transmit and receive, but the others are receive only. Tim -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Aug 28, 2005
----- Original Message ----- From: Carl Froehlich To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 9:09 AM Subject: RE: RV10-List: Fuel strainer and drain plug seal Everywhere outside of the tank, use thread sealant on all threaded fluid fittings. The best I have found it the "Teflon" type thread sealant sold at Napa auto part stores. This is the stuff in a tube, not Teflon tape. Keep it a thread or two away from the end of the fitting so that no sealant contacts fluid. No sealant on flared fittings. Carl Froehlich RV-8A (200hrs) Dogwood Airpark (VA-42) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of jwt(at)roadmapscoaching.com Sent: Sunday, August 28, 2005 11:02 AM To: rv10-list(at)matronics.com Subject: RV10-List: Fuel strainer and drain plug seal What do you use to seal the fuel strainer and drain plug on the tanks? Plans just say install them. Do you put Proseal on them or some other type of sealant. Seem like just metal on metal won't be a good seal. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins ________________________________________________________________________________
Date: Aug 28, 2005
suggest you put fuel lube on those fittings. then no chance of Teflon migrating anywhere in the fuel system and causing fuel blockage...----- Original Message ----- From: Carl Froehlich To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 9:09 AM Subject: RE: RV10-List: Fuel strainer and drain plug seal Everywhere outside of the tank, use thread sealant on all threaded fluid fittings. The best I have found it the "Teflon" type thread sealant sold at Napa auto part stores. This is the stuff in a tube, not Teflon tape. Keep it a thread or two away from the end of the fitting so that no sealant contacts fluid. No sealant on flared fittings. Carl Froehlich RV-8A (200hrs) Dogwood Airpark (VA-42) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of jwt(at)roadmapscoaching.com Sent: Sunday, August 28, 2005 11:02 AM To: rv10-list(at)matronics.com Subject: RV10-List: Fuel strainer and drain plug seal What do you use to seal the fuel strainer and drain plug on the tanks? Plans just say install them. Do you put Proseal on them or some other type of sealant. Seem like just metal on metal won't be a good seal. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins ________________________________________________________________________________
Date: Aug 28, 2005
If I recall correctly (IIRC) Bob Archer states in his documentation for the nav antenna that it may not be split as will damage the radios. Better check that with him. ----- Original Message ----- From: CustomACProp(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 11:19 AM Subject: Re: RV10-List: Antennas Hi All, The general plan looks good. Bob Archer recommends that his Marker Beacon antenna should be mounted in the same wingtip with the NAV antenna. Regards, Jim Ayers In a message dated 08/27/2005 11:59:07 PM Pacific Daylight Time, rv10-list-digest(at)matronics.com writes: From: "Rene" <rene(at)felker.com> Subject: RV10-List: Antennas Randy and others. I am to the point of having to commit on my antennas and wanted to see how yours are working. Here is my general plan. Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 Whip comm antenna on the belly Transponder antenna on the belly ELT antenna in tail Archer marker antenna in left wing tip Archer comm antenna in left wingtip GPS antenna on top of canopy or on glare shield XM radio antenna on glare shield Thanks in advance for any comments. Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Date: Aug 28, 2005
Here's the stuff on Aircraft Spruce... <http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php> They also have a smaller 5 oz. tube not shown on the website. PN 09-00306 -Sean #40303 David McNeill wrote: > suggest you put fuel lube on those fittings. then no chance of Teflon > migrating anywhere in the fuel system and causing fuel > blockage...----- Original Message ----- > > *From:* Carl Froehlich > *To:* rv10-list(at)matronics.com > *Sent:* Sunday, August 28, 2005 9:09 AM > *Subject:* RE: RV10-List: Fuel strainer and drain plug seal > > Everywhere outside of the tank, use thread sealant on all threaded > fluid fittings. The best I have found it the "Teflon" type thread > sealant sold at Napa auto part stores. This is the stuff in a > tube, not Teflon tape. Keep it a thread or two away from the end > of the fitting so that no sealant contacts fluid. > > No sealant on flared fittings. > > Carl Froehlich > RV-8A (200hrs) > Dogwood Airpark (VA-42) > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com]*On Behalf Of > *jwt(at)roadmapscoaching.com > *Sent:* Sunday, August 28, 2005 11:02 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Fuel strainer and drain plug seal > > What do you use to seal the fuel strainer and drain plug on > the tanks? Plans just say install them. Do you put Proseal on > them or some other type of sealant. Seem like just metal on > metal won't be a good seal. > > > John Testement > jwt(at)roadmapscoaching.com > 40321 > Working on QB bottom skins > > > > > ________________________________________________________________________________
Subject: Van's wiring kit
Date: Aug 28, 2005
Since people are asking for RG400, I found a company on Ebay that deals in surplus wiring, he has RG400 at a great deal, I got 120 feet plus shipping for $60, I asked if it was ok to post his email for the RV group and he said he would be happy to sell to us, tell him you heard it from Dan Lloyd, and his email is s.mogle [s.mogle(at)insightbb.com] very fast turn around and great communication! I do not have an affiliation with him, other than a satisfied customer. Dan 40269 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Beyer Subject: Re: RV10-List: Van's wiring kit On one of the other lists some time ago, Wiremasters <http://www.wiremasters.net/> in TN was recommended as an inexpensive place for RG-400 (and all 22759 wire). Please note that I have NO experience with them, just passing on a previous recommendation--so please do some homework. -Jim jimc(at)mail.infra-read.com > > Where did you buy the wire? Any place special? I need to start the wiring. =09 ________________________________________________________________________________
Date: Aug 28, 2005
Yes Tim, I labeled mine alt air. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Firewall Forward Cables I just wanted to verify the cables that I'll have on an IO-540. I have the Mixture, Prop, Throttle cables...all nice heavy green covered ones. I also have 3 plain push-pull cables with black knobs. I know one is front seat and one is rear seat heat, but the 3rd....all I can see is that it looks to be going to the FAB under the engine. I do see references to "carb heat", and "alternate air". Is this just the cable that opens the air bypass from the FAB? If so, would it be labeled "Alternate Air"? I wouldn't need to be asking so soon, but I'm trying to plan for where these cables will mount before I silkscreen my panel lables. Not sure if I should just mount them on that bottom panel support bar, or build a separate bracket....or build a console under the throttle quadrant. Tim -- Tim Olson -- RV-10 #40170 Current project: Spinner ________________________________________________________________________________
Subject: Antennas
Date: Aug 29, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I specifically asked Bob A. about splitting the signal when trying to decide what to do for antennas. His only comment was that you'd have much less signal due to loss from the splitter. The nav antenna was no more expensive than a splitter so I just decided to put a nav antenna in each wingtip. Not sure I'll ever use both, but they're there. Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Subject: Re: RV10-List: Antennas If I recall correctly (IIRC) Bob Archer states in his documentation for the nav antenna that it may not be split as will damage the radios. Better check that with him. ----- Original Message ----- From: CustomACProp(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 11:19 AM Subject: Re: RV10-List: Antennas Hi All, The general plan looks good. Bob Archer recommends that his Marker Beacon antenna should be mounted in the same wingtip with the NAV antenna. Regards, Jim Ayers In a message dated 08/27/2005 11:59:07 PM Pacific Daylight Time, rv10-list-digest(at)matronics.com writes: From: "Rene" <rene(at)felker.com> Subject: RV10-List: Antennas =09 Randy and others. =09 I am to the point of having to commit on my antennas and wanted to see how yours are working. =09 Here is my general plan. =09 Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 =09 Whip comm antenna on the belly =09 Transponder antenna on the belly =09 ELT antenna in tail =09 Archer marker antenna in left wing tip =09 Archer comm antenna in left wingtip =09 GPS antenna on top of canopy or on glare shield =09 XM radio antenna on glare shield =09 Thanks in advance for any comments. =09 Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Subject: Antennas
Date: Aug 29, 2005
As far as I know you can split them just fine. You end up with about 50% of the signal but that's it. The thing you can not do is combine two antennas into one thinking you will get coverage better. Big no no. Michael Sausen -10 #352 Wing LE's ________________________________
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Subject: RE: RV10-List: Antennas I specifically asked Bob A. about splitting the signal when trying to decide what to do for antennas. His only comment was that you'd have much less signal due to loss from the splitter. The nav antenna was no more expensive than a splitter so I just decided to put a nav antenna in each wingtip. Not sure I'll ever use both, but they're there. Bob #40105 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Subject: Re: RV10-List: Antennas If I recall correctly (IIRC) Bob Archer states in his documentation for the nav antenna that it may not be split as will damage the radios. Better check that with him. ----- Original Message ----- From: CustomACProp(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, August 28, 2005 11:19 AM Subject: Re: RV10-List: Antennas Hi All, The general plan looks good. Bob Archer recommends that his Marker Beacon antenna should be mounted in the same wingtip with the NAV antenna. Regards, Jim Ayers In a message dated 08/27/2005 11:59:07 PM Pacific Daylight Time, rv10-list-digest(at)matronics.com writes: From: "Rene" <rene(at)felker.com> Subject: RV10-List: Antennas =09 Randy and others. =09 I am to the point of having to commit on my antennas and wanted to see how yours are working. =09 Here is my general plan. =09 Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 =09 Whip comm antenna on the belly =09 Transponder antenna on the belly =09 ELT antenna in tail =09 Archer marker antenna in left wing tip =09 Archer comm antenna in left wingtip =09 GPS antenna on top of canopy or on glare shield =09 XM radio antenna on glare shield =09 Thanks in advance for any comments. =09 Rene' 40322 N423CF 80% wings...10% Fuslage 801-721-6080 ________________________________________________________________________________
Subject: RFI /EMI in flying 10s
Date: Aug 29, 2005
Anyone experiencing EMI/RFI in flying aircraft with the belly mounted RAMI AV17 com antenna? Specifically any twitching of the TT autopilot or Ray Allen trim LED? Currently experiencing same in Glastar and am trying to deicide whether to shield all digital traffic in the 10. ________________________________________________________________________________
Subject: IO-540 questions
Date: Aug 29, 2005
I am looking at a rebuilt engine for purchase and have a couple questions: > Is there any advantage of a narrow or wide deck IO-540 configuration (or what's the difference)? >Mounting ears I believe need to be the # 70456 - 30 degree ears? >When specifying the mount style for the finishing kit is the "dynafocal I "- the typical one and again what are you looking for to tell the difference? >Anything else to look out for? Thanks for all the help! Byron # 40253 - Installing fuselage floors. ________________________________________________________________________________
Date: Aug 29, 2005
It seems that most 10 builders are putting there com and transponder antennas on the belly under the baggage compartment or the rear seats. Anyone putting there transponder or com antenna under the front floorboards? Are you putting in any access panels to get to the antenna or wiring in the future? Larry Rosen #356 Rene wrote: > Randy and others. > > I am to the point of having to commit on my antennas and wanted to see > how yours are working. > > Here is my general plan. > > Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 > > Whip comm antenna on the belly > > Transponder antenna on the belly > > ELT antenna in tail > > Archer marker antenna in left wing tip > > Archer comm antenna in left wingtip > > GPS antenna on top of canopy or on glare shield > > XM radio antenna on glare shield > > Thanks in advance for any comments. > > Rene' > > 40322 > > N423CF > > 80% wings..10% Fuslage > > 801-721-6080 > ________________________________________________________________________________
Subject: Antennas
Date: Aug 29, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Not under the front floorboards, but under the front seats, yes, comm on left side and transponder on the right. Com #2 on top, at front of tailcone, with GPS behind that. Bob Archer Nav in the wingtip. TDT 40025 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Larry Rosen Subject: Re: RV10-List: Antennas It seems that most 10 builders are putting there com and transponder antennas on the belly under the baggage compartment or the rear seats. Anyone putting there transponder or com antenna under the front floorboards? Are you putting in any access panels to get to the antenna or wiring in the future? Larry Rosen #356 Rene wrote: > Randy and others. > > I am to the point of having to commit on my antennas and wanted to see > how yours are working. > > Here is my general plan. > > Archer Nav antenna in the right wingtip, will be shared by a 430 and SL30 > > Whip comm antenna on the belly > > Transponder antenna on the belly > > ELT antenna in tail > > Archer marker antenna in left wing tip > > Archer comm antenna in left wingtip > > GPS antenna on top of canopy or on glare shield > > XM radio antenna on glare shield > > Thanks in advance for any comments. > > Rene' > > 40322 > > N423CF > > 80% wings..10% Fuslage > > 801-721-6080 > ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Re: RV10-List Digest: 25 Msgs - 08/28/05
Hi All, I believe what you remember is that one COM antenna should not use a splitter for two COM radios. It is a common practice to split the signal from one NAV antenna into two NAV receivers. (Usually only one NAV antenna mounted outside on the factory built aircraft.) Regards, Jim Ayers PS Bob Archer has an active COM radio splitter (pn SA-010) that allows two COM radio's to operate from one COM antenna. In a message dated 08/28/2005 11:59:49 PM Pacific Daylight Time, rv10-list-digest(at)matronics.com writes: From: "David McNeill" <dlm46007(at)cox.net> Subject: Re: RV10-List: Antennas If I recall correctly (IIRC) Bob Archer states in his documentation for the nav antenna that it may not be split as will damage the radios. Better check that with him. ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Antennas
Date: Aug 29, 2005
I hate the thought of comm. Antennas under my feet. Don't you know that it causes athletes feet and bad toe nails. Bob K _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: RE: RV10-List: Antennas lol....hanger tales of transponder antenna's frying the ol' brain are still around, what say all about that theroy? I heard it was unfounded but I can see why it is point of concern. Rick S. 40185 Fuse ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Anyone Know The Story Behind This Crash?
Hi Listers, Does anyone know the story behind this aircraft and the crash? Almost looks like an RC model especially given the cameraman's rather unemotional comment following the crash. Kind of looks like the elevator may have been hooked up backwards following a rebuild. http://media4.big-boys.com/content/oldplanecrash.wmv Any information on this video would be intersting. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Aug 30, 2005
Subject: Build your own wingtip antenna?
Hi All, Does Bob Nuckols instructions include the capacitance between the antenna element and ground plane element? If the capacitance is wrong the antenna is bad. Even if the antenna's are physically identical in shape. Regards, Jim Ayers Subject: RE: RV10-List: Antennas From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> (Stuff Cut) For anyone that has Bob Knuckols Aeroelectric Connection handbook and is interested in the Archer antenna, save yourself $70 and spend the $10 in parts and use the diagram in Bob's book to build your own. It's identical. I was wondering if there was any difference and decided to order them anyway from Stein. Got one and the other was on backorder, compared it to the book, promptly called Stein and canceled the backordered one. Absolutely nothing against Stein, he just gets them from Archer and resells them. As far as the carbon fiber canopy goes, easy to find out just stick a GPS antenna to the inside top. If it works no carbon. Michael Sausen -10 #352 Wing LE's ________________________________________________________________________________
Date: Aug 30, 2005
http://aviation-safety.net/database/record.php?id=19920827-1 http://www.asasi.org/papers/2001/Four%20Unrelated%20Accidents.pdf From a web forum: that crashed happened in gimli manitoba canada, and the pilots died, they forgot to remove the flight control locks, resulting in a very agressive pitch angle causing a stall. it was the final test flight before the turbine engine mod was fully approved for commercial use. ... Submitted by: HANKJR84 at 8/30/2005 12:30:06 AM Just a note to all of you idiots out there who dont understand what really happened. First, YES IT"S REAL. Second, the crewmembers were killed instantly. This Caribou was experimental and had just been converted to P&W turbo prop engines from P&W R-2000 piston engines. Third, this was a test flight. Fourth, the aircraft took off with the GUST LOCKS ENGAGED for a reason that 99 out of 100 of you nitwits wouldnt even understand. Fifth, the pilots were unable to release the GUST LOCKS after becoming airborne because of airloads on the flight controls. Sixth,the aircraft flew ... Submitted by: KIM1942 at 8/30/2005 12:28:42 AM -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Matt Dralle Subject: RV10-List: Anyone Know The Story Behind This Crash? Hi Listers, Does anyone know the story behind this aircraft and the crash? Almost looks like an RC model especially given the cameraman's rather unemotional comment following the crash. Kind of looks like the elevator may have been hooked up backwards following a rebuild. http://media4.big-boys.com/content/oldplanecrash.wmv Any information on this video would be intersting. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Aug 30, 2005
There have been a lot of replies to this, but I will give it a shot since we did actually install Van's kit in our -10. We had never done wiring before and had absolutely no clue where to start. The price wasn't bad considering that in included switches and breakers, but it would have been a little cheaper just doing it ourselves. I will list some of my Pros and Cons: Pros: - It gave me a clue of where to start. I didn't completely follow the directions, but I would have been floundering without that good initial direction. - The wiring schematic that came with the kit was incredibly helpful and I used that as a basis for our other wiring as well. Cons: - The breakers that came with it were not the push-pull type which is what I installed for all of our avionics and stuff. I will probably replace them. - Unless you plan on routing the wires and having the switches and breakers exactly where they recommend, you may be in trouble. We routed all of our wires down the right side so we can access them later. The Starter cable was about 2 feet too short. I got one from Stein and it was much nicer and more flexible cable. - Everything is white so without the labels on the ends of the wire you have no clue what that's for. I went to a forum at Oshkosh (the guy from Blue Mountain did it) and I agree completely that using all white wiring is stupid. You have no clue what things are for. He recommends taking the red and black (or whatever colors you are using) and twisting them together with a drill. He also recommends running every ground straight back to the battery, which I very well may do next time. - You will need more wires in almost every direction that this harness goes, so you may want to disassemble it at some point anyway to join other wires to it. This is not a really big deal. - They put the kit together for a Carbureted engine so the fuel pump only had a 5A switch. The Injected pump needs a 10A switch and possibly heavier wire. This isn't a really big deal either if you make sure they send the switch that you need. I think for the length of the run the wire that they include is sufficient. I think you can probably have Van's leave out some parts of it, like the breakers, switches and maybe even the starter cable. Overall, I would say that if you haven't done wiring before and you don't really know where to start, this is a good investment. The instructions for putting together a buss bar for breakers and switches and stuff like that is a huge help if you are going to do things that way, which we did. Hope this helps. GOD BLESS! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jwt(at)roadmapscoaching.com Subject: RV10-List: Van's RV-10 Wiring kit Vans now has a wiring kit out for the 10 (details below). Has anyone purchased it or given it serious consideration? Is this a reasonable route to go or do you believe it better to go thru Stein or another source? John Testement jwt(at)roadmapscoaching.com 40321 Finishing tail ES WH 10 KIT I(O)-540 RV-10 WIRING HARNESS 1.000 WH-10 HARNESS I(O)-540 1.000 WH-F1 INSTR BKR-TB #16 1.000 WH-J1 ALT BKR-ALT #8 1.000 WH-J2 ALT SW-V REG-ALT #18 1.000 WH-J3 IG SW LEFT-PLEAD #18S 1.000 WH-J4 IG SW R-PLEAD #18S 1.000 WH-J5 IG SW-TB GND 1.000 WH-K1 IG SW-START RELAY #18 1.000 WH-K2 IG SW-INST TB #18 1.000 WH-L1 NAV LT SW-PNL LT #18 1.000 WH-L2 LAND/TAXI SW-R TB #14 1.000 WH-L3-1 STROBE SWITCH >POWER 1.000 WH-L4 NAV LT SW-R TB #18 1.000 WH-L5 LAND/TAXI SW-L TB #14 1.000 WH-L7 NAV SW-L TB #18 1.000 WH-L8 NAV.LT TO TAIL LIGHT 1.000 WH-P12 RADIO SW-TB #16 1.000 WH-P2 MASTER SW-GND #18 1.000 WH-P3 MASTER SW-M RELAY #18 1.000 WH-P8 FLAP SW-MOTOR #18 1.000 WH-P9 FLAP SW-MOTOR #18 1.000 WH-P28 BUSS BAR JUMPER 1.000 WH-Q1 PUMP SW-PUMP #18 40.000 PLASTIC TIE WRAP 4 4" PLASTIC TIE WRAP 1.000 WH-P7 FLAP CIRCUIT WIRE 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF SUBKIT------ 1.000 ES WH-SK HARNESS SUPPLEMENT 20.000 PLASTIC TIE WRAP 4 4" PLASTIC TIE WRAP 55.000 WIRE M22759/16-18 #18 GAUGE ELECT WIRE 55.000 WIRE M22759/16-16 #16 GAUGE ELECT WIRE 25.000 WIRE M22759/16-14 #14 GAUGE ELECT WIRE 25.000 WIRE M22759/16-22 22 GA ELECT WIRE $/FT 12.000 ES 36152 TERMINAL #20 WR #6 TR 35.000 ES 31890 #18 TERMINAL 5.000 ES 36154 TERMINAL #20WR #10STD 20.000 ES 320565 #14-16 TERMINAL 1.000 ES 324082 #8 RING/ 1/4 STUD 8.000 ES 320559 #18 SPLICE 7.000 ES 320562 #14-16 SPLICE 1.000 ES HST-3/8X1' HEAT SHRINK TUBE 1.000 ES HST-3/16X1' HEAT SHRINK TUBE 1.000 ES HST-1/4X1' HEAT SHRINK TUBE 2.000 ES BUSS BAR-063X.5 1/16X1/2X12 COPPER BR 25.000 DUCT NT5/8 NYLON 5/8 TUBE ($/FT) 4.000 MS25171-1S NIPPLE (BOOT) SMALL 7.000 MS25171-3S NIPPLE (BOOT) LARGE 6.000 BUSHING SB750-10 SNAP-IN 5/8 ID 3/4 OD 4.000 BUSHING SB437-4 SNAP-IN 1/4ID 7/16 OD 1.000 TAPE UHMW 3"X12" INSULATING TAPE 1.000 ES 324044 #8L TERMINAL 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF SUBKIT------ 1.000 ES WH-SW 10 BREAKER SET RV-10A 2.000 ES PBB-5 TOGGLE SWITCH BREAKER 3.000 ES PBB-10 TOGGLE SWITCH BREAKER 1.000 ES PBB-20 TOGGLE SWITCH BREAKER 1.000 ES PBB-5A CB PLAIN CIRCUIT BREAKER 1.000 ES PBB-10A CB PLAIN CIRCUIT BREAKER 1.000 ES CB 1648-009-060 60 AMP CIRCUIT BRKER 1.000 ES 2GK54-73 SWITCH DPST SWITCH (ON/OFF) 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF SUBKIT------ 1.000 DOC ES HARNESS-10 WIRING DWGS AND TEXT BAG 970 RV-10 WIRING HARNESS 1.000 AN3-4A BOLT 3.000 AN3-3A BOLT 1.000 AN365-428 NUT,STOP 1/4-28 12.000 AN365-832A NUT,STOP 8-32 2.000 AN4-4A BOLT 1.000 AN4-5A BOLT 1.000 AN509-10R12 SCREW,FLT HD STRUCT 1.000 AN509-8R8 SCREW,FLT HD STRUCT 10.000 AN515-8R8 SCREW,ROUND HD 2.000 AN526C832R8 SCREW,TRUSS HD SS 2.000 AN5-4A BOLT BAG 971 RV-10 WIRING HARNESS 4.000 AN960-10L WASHER, THIN 4.000 AN960-416 WASHER 1/4 2.000 AN960-516L WASHER (032) 5/16 12.000 AN960-8 WASHER #8 2.000 K1000-08 PLATENUT 8-32 4.000 MS21042-3 1032 ALL METAL L/NUT 2.000 MS21045-5 HW PINCH NUT 5/16 2.000 MS21919DG12 CUSHIONED CLAMP 7.000 MS21919DG2 1/8" CUSHION CLAMP 5.000 MS21919DG4 1/4" CUSHION CLAMP 5.000 MS21919WDG6 3/8" CUSHION CLAMP 1.000 MS21919DG8 CUSHIONED CLAMP 1.000 MS21919DG10 CUSHIONED CLAMP 3.000 MS21919WDG3 3/16" CUSHIONED CLAMP 1.000 MS35206-248 832X3/4 PAN HD SCREW 1.000 MS35206-250 832X1 1/4 PAN HD SCR. BAG 972 RV-10 WIRING HARNESS 6.000 BUSHING SB375-3 SNAP-IN 3/16ID 3/8 OD 4.000 BUSHING SB500-6 SNAP-IN 3/8 ID 1/2 OD 2.000 BUSHING SB625-8 SNAP-IN 1/2ID 5/8 OD 6.000 BUSHING SB750-10 SNAP-IN 5/8 ID 3/4 OD 12.000 RIVET LP4-3 POP RIVET 2.000 BUSH AL-058X5/16X1 ALUMINUM BUSHING -8 2.000 C-606 LINK 2.000 F-1016H GUIDE BRACKET 1.000 BAG 995 WIRING KIT HW 20.000 AN365-832A NUT,STOP 8-32 5.000 MS35206-248 832X3/4 PAN HD SCREW 7.000 MS35206-250 832X1 1/4 PAN HD SCR. 17.000 AN960-8 WASHER #8 1.000 AN5-5A BOLT 1.000 AN960-516 WASHER 5/16 1.000 AN365-524 NUT,STOP 5/16-24 4.000 MS35333-39 3/16 INT TOOTH L/W 1.000 BAG 997 SPARE WIRE LABELS 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL F1 1.000 WH SM35-3/8-9X0.5J SHRINK LABEL J1 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL J2 1.000 WH SM35-1/8-9X.25J HEAT SHRINK LABEL 1.000 WH SM35-1/8-9X.25J HEAT SHRINK LABEL 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL J5 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL K1 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL K2 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L1 1.000 WH SM35-1/8-9X0.5L SHRINK LABEL L2 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L3 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L4 1.000 WH SM35-1/8-9X0.5L SHRINK LABEL L5 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L6 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL L7 1.000 WH SM35-3/8-9X0.5P SHRINK LABEL P1 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL P2 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL P3 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P7 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P8 1.000 WH SM35-1/8-9X0.5P SHRINK LABEL P9 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL P12 1.000 WH SM35-3/32-9X0.5 SHRINK LABEL Q1 1.000 WH SM35-3/32-9X.25 1.000 F-10110-L WIRE COVER 1.000 F-10111 ANGLE BRACKETS 1.000 WH-800A TERMINAL BLOCK BASE 1.000 WH-800B TERMINAL BLOCK TOP 1.000 WH-801 RT.CONSOLE TEMPLATE 1.000 WH-P13 BUSS BAR JUMPER #8 1.000 WH-P17 #2 ELEC.CABLE 37.25" 2.000 WH-P25 #2 AWG BRAIDED 7.25" 1.000 WH-P27 #2 AWG ELEC.CABLE 1.000 WH-P4F #2 ELEC.CABLE 7.75" 1.000 WH-P5 #2 ELEC.CABLE 11" 1.000 ES 24021 STARTER SOLENOID 2OUT 1.000 ES 24115 MASTER RELAY 1.000 ZZZZZZZ EOK ZZZZZZ -----END OF KIT------ ________________________________________________________________________________
Subject: Re: IO-540 questions
Date: Aug 29, 2005
Byron, Van's only has one mount style and it is the Dynafocal I. The ears on this mount seem to point at the C.G. where the Dyno II seem to point somewhere near the tip of the spinner. Anh ----- Original Message ----- From: Byron Gillespie To: rv10-list(at)matronics.com Sent: Monday, August 29, 2005 5:43 PM Subject: RV10-List: IO-540 questions I am looking at a rebuilt engine for purchase and have a couple questions: > Is there any advantage of a narrow or wide deck IO-540 configuration (or what's the difference)? >Mounting ears I believe need to be the # 70456 - 30 degree ears? >When specifying the mount style for the finishing kit is the "dynafocal I "- the typical one and again what are you looking for to tell the difference? >Anything else to look out for? Thanks for all the help! Byron # 40253 - Installing fuselage floors. ________________________________________________________________________________
Date: Aug 30, 2005
Subject: 3 view line drawings
I recall seeing some RV10 3view line drawings some where but for the life of me I can't find them, checked Van's site and Tim's. anybody know where I can find copies? Deems Davis # 406 Empennage attach (waiting for wings!) http://deemsrv10.com/ ________________________________________________________________________________
Subject: Re: 3 view line drawings
Date: Aug 30, 2005
I recive mine with the tail cone ,just made a plastic lamination of the three view and the Cad full schematic of the RV10,in that way I can play over ,if you whant I will sen a copy ,pay 5 dol, at Kinkos for each one Hugo > > From: Deems Davis <deemsdavis(at)cox.net> > Date: 2005/08/30 Tue PM 04:26:42 EDT > To: rv10-list(at)matronics.com > Subject: RV10-List: 3 view line drawings > > > I recall seeing some RV10 3view line drawings some where but for the > life of me I can't find them, checked Van's site and Tim's. anybody know > where I can find copies? > > Deems Davis # 406 > Empennage attach (waiting for wings!) > http://deemsrv10.com/ > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 30, 2005
It's on Tim's site under the photo section. Try this link: http://www.myrv10.com/miscphotos/rv_drawings/index.html Marcus Fuselage slowly progressing -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Subject: RV10-List: 3 view line drawings I recall seeing some RV10 3view line drawings some where but for the life of me I can't find them, checked Van's site and Tim's. anybody know where I can find copies? Deems Davis # 406 Empennage attach (waiting for wings!) http://deemsrv10.com/ ________________________________________________________________________________
Date: Aug 30, 2005
Subject: Strobe power supplies and kits
Date: Aug 30, 2005
Has anyone gotten more detailed info on the strobe power supply options? There is the CreativeAir AviPak and the Nova SuperPak 606 that seem to be similar in functionality but with a big cost difference. Is there any real difference or just a relabeling for an aviation product? Any experience with the StrobesNMore product? - looks like an attractive deal. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB bottom skins ________________________________________________________________________________
Date: Aug 30, 2005
Subject: Re: Build your own wingtip antenna?
I feel the exact same way Rick. I bought 2 NAVs. One for each wing. NAV1 and NAV2. At that price and a known effectiveness. Why mess around? Well, unless you want a learning experience I guess. -Sean #40303 Rick wrote: > FWIW, > > I called Bob and purchased his antenna's. He sent them to me in a week > and on the honor system. > > I believe that if someone has developed a product that works as good > as everyone says, I'm not going to reinvent the wheel. Yes the > antennas are sheet aluminum and one may be able to fabricate a clone > but what if it doesn't work right, are you going to pickup the phone > and call Bob and ask for help? Think about what you have to do to > build one of these as well.....The sheet metal material is perfectly > sheared to a dimension that I'm sure is not pulled out of a hat, the > placement of the components may or may not be critical, I don't want > to deal with it, hunt down the stuff to make them, cut it out and hope > it works? I'm glassing mine into the tips, I want them to work from > the start. I am only using comm 2 in the tip and using a Comant whip > for Comm 1 on the belly. For $134 for both in comparison to the total > cost, I'll stick with the real McCoy and the help line that comes with > it if needed. I spent more than that on my 4" no hole squeezer yoke. > > Rick S. > 40185 > Fuse ________________________________________________________________________________ spamd3.ruraltel.net * -4.0 RCVD_FROM_NEXTECH_5 Message came from 204.96.144-152.x network * 0.0 UNPARSEABLE_RELAY Informational: message has unparseable relay * lines * 0.1 HTML_50_60 BODY: Message is 50% to 60% HTML * 0.0 HTML_MESSAGE BODY: HTML included in message * -1.0 BAYES_00 BODY: Bayesian spam probability is 0 to 1% * 0.1 AWL AWL: From: address is in the auto white-list
From: "Bill and Tami Britton" <william(at)gbta.net>
Subject: Elevator question
Date: Aug 30, 2005
I'm on page 9-7 step 5. It says to dimple the E-616 cover plates for the AN507-6R6 screws. Does this mean I use the #6 screw dimple dies on these dimples??? It also says to dimple the E-615 reinforcement plate to accept the dimple in the cover plate. Do I use the same dimple die as above??? Bill Britton RV-10 Elevators Wings still in their crates ________________________________________________________________________________
Subject: Re: Elevator question
Date: Aug 30, 2005
Yes and Yes Bill. If you're not sure, try it on some scraps to make sure everything will fit. Anh #141 ----- Original Message ----- From: Bill and Tami Britton To: RV10-list(at)matronics.com Sent: Tuesday, August 30, 2005 10:52 PM Subject: RV10-List: Elevator question I'm on page 9-7 step 5. It says to dimple the E-616 cover plates for the AN507-6R6 screws. Does this mean I use the #6 screw dimple dies on these dimples??? It also says to dimple the E-615 reinforcement plate to accept the dimple in the cover plate. Do I use the same dimple die as above??? Bill Britton RV-10 Elevators Wings still in their crates ________________________________________________________________________________
Date: Aug 31, 2005
Subject: FWF/Finishing Missing Parts to date
I've had people contact me hoping to hear more about the missing parts I've found recently, so I updated my page to list some of them. I'm sure there's more than what I have listed, but I'm trying to keep a good list for you to refer to so you can doublecheck your inventory. In at least one case, the bag has been changed from 523 to 523-1, indicating that they changed the list. Of course, the only way you'll ever know that is if we pass the info along, because they're sure not going to suddenly ship you a package of your shorted hardware without asking. http://www.myrv10.com/N104CD/finishing/20050827/index.html Check it out...in my case, I wouldn't have been able to mount the engine if I hadn't anticipated some missing bolts. I also added on a small update last night regarding a battery box enlargement for the PC925 and spinner initial fitting. Tim -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Subject: Re: FWF/Finishing Missing Parts to date
Date: Aug 31, 2005
> here. How many AN7-26 bolts for mounting an engine is a person > supposed to buy and have on hand? And, since we're going to That sucks. Didn't realize it was stuff like engine mount bolts or wing bolts. > I don't think we're being "spoiled puppies" though when we Definitely not. > Also, nobody said they were a "bad kit manufacturer"...but, > their ability to deliver on parts for the -10 is definitely > not in the "worlds class" category. Although my experience with Van's is that during the winter (especially around inventory time) they tend to be reeeeally slow to ship out little piddly orders, they were always responsive when I had to call in missing stuff. Half the time I didn't bother...regardless of whether I was "entitled" to it or not. I just ordered stuff from Spruce and had it the next day. Path of least resistance at the time. Two weeks ago I placed an order from Van's for 50 K1100-06 nutplates, and I was kind of shocked when I got the order like 3 business days later. It's usually not that quick. Anyway, I agree that Van's sometimes leaves something to be desired in the "slow shipping" dept. But it seems to me that a thorough inventory of your kit as soon as you receive it (something I'm guilty of not always doing) would preclude most of the "now I need to wait for a shipment to arrive" issues down the road. Seems like engine or wing bolts would be something you'd inventory right away. If slow shipping and a few missing parts are Van's worst traits, then we're in good shape. ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Subject: 325HP
Date: Aug 31, 2005
List, 325HP past inspection yesterday with no problems!!! Bad weather and insurance hold up today for the fist flight Any recommendations on insurance? Noel Simmons Blue Sky Aviation, Inc. www.blueskyaviation.net <http://www.blueskyaviation.net/> ________________________________________________________________________________
Subject: Re: 325HP
Date: Aug 31, 2005
Skysmith - great bunch of folks. I had some issues with the other major RV insurer when it came time to renew my builder's policy. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: RV10-List: 325HP List, 325HP past inspection yesterday with no problems!!! Bad weather and insurance hold up today for the fist flight Any recommendations on insurance? Noel Simmons Blue Sky Aviation, Inc. www.blueskyaviation.net <http://www.blueskyaviation.net/> ________________________________________________________________________________
Subject: 325HP
Date: Aug 31, 2005
Is that a 325 HP engine? Jeez, will wait for the 1st flight and report. Maybe tomorrow???? What engine is it? Please elaborate. Mani Ravee, MD Indianapolis, KUMP #40339. N528AR _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Noel & Yoshie Simmons Subject: RV10-List: 325HP List, 325HP past inspection yesterday with no problems!!! Bad weather and insurance hold up today for the fist flight Any recommendations on insurance? Noel Simmons Blue Sky Aviation, Inc. www.blueskyaviation.net <http://www.blueskyaviation.net/> ________________________________________________________________________________
Date: Aug 31, 2005
Mark Ritter wrote: > > My two cents - Van is delivering a great product at a great price. I > can live with a few missing rivets, cotter keys and bolts. Besides I > like talking to Jessica and she has never failed to have the missing > items in the mail --- its not like I don't have anything left to do > while waiting for the brown truck to show up. > > Hope the whining stops soon and we can get back to posting building tips. > Here's a builder tip... Don't count on getting all the hardware you need to finish a kit section. Order extra from ACS. ________________________________________________________________________________
Subject: Three bladed props
Date: Sep 01, 2005
Hi All, Has anyone heard any reports on the performance of the MT three bladed prop? John Dunne. RV-10 #40315 (Finishing Tailcone) acs(at)acspropeller.com.au ________________________________________________________________________________
Date: Aug 31, 2005
Subject: Re: 325HP
Nope, it's his N number... N325HP (confirmed on the FAA's database) Is that a 325 HP engine? > ________________________________________________________________________________
Date: Sep 01, 2005
Hello John John Jessen wrote: > >The reasons I think that Van's should have higher quality control (like the >individual bubble wrap or even fill the bags more carefully, thus hiring a >couple more people to put in the time or check how the process is done in >the first place) are the following: > > > agree, I was over more then two years in close contact with the folks building up NewGlasair after they've restarted, I think the main points are, NG is still a much smaller company then Van's is so more down to a controllable bunch of people and NG has Lori =(;o). This said, they had a very hard and tough time to find people with the right attitude to get their shipping to a good standard and this might just be the problem at Van's getting enough good people who them selfs feel responsible and are not just working to have their bucks in the pocket in the evening. This is always a problem when companies begin to growth in a way where the personal touch of people can not follow and if you look at sales numbers you can tell, that Van's grew a lot the last years. I agree, a better quality control would suite them, but you might (as you mentioned) see also prices raise when this happens (good people need to be paid better so they remain). It was and is always a nuisance being short of a part and having (inpatient) to wait for delivery of needed parts, however when done and having your project in the air all this will be forgotten and let behind!! Werner ________________________________________________________________________________
Date: Sep 01, 2005
Subject: Re: Three bladed props
Has anyone investigated a 3-blade Hartzell? Maybe the 3-blade designed for the F1 Rocket? 78" 3-blade HC-F3YR-1ARF/F7693DF <http://www.hartzellprop.com/kitplane/index_kitplane.htm> -Sean #40303 Mark Ritter wrote: > > Yes and the report was disappointing. Vic Syracuse is flying with a > three blade MT prop and I believe he is seeing a TAS of 161 - 162 > knots at 8,000'. Vic is working with the folks at MT but have not > heard anything lately. Jim Ayers (Less Drag guy) is suppose to have > access to an RV-10 and will be doing a comparison of performance > between a two blade Hartzell and the three blade MT. When I talked to > Jim about Vic's performance his reply was "its easy to blame the > prop". He also told me MT stands behind their product and that I had > not purchased a lemon. Here's hoping! > > Mark > > From: /"John Dunne" <acs(at)acspropeller.com.au>/ > Reply-To: /rv10-list(at)matronics.com/ > To: // > Subject: /RV10-List: Three bladed props/ > Date: /Thu, 1 Sep 2005 12:35:43 +1000/ > > Hi All, > > Has anyone heard any reports on the performance of the MT three > bladed prop? > > > > John Dunne. > > RV-10 #40315 (Finishing Tailcone) > > > > acs(at)acspropeller.com.au > > ________________________________________________________________________________
Date: Sep 01, 2005
Subject: Tank Rib Tooling Holes
I remember a discussion a while back regarding other options for closing up the tooling holes in the inboard and outboard most tank ribs. Can someone refresh my memory? Thanks... -Sean #40303 ________________________________________________________________________________
Date: Sep 01, 2005
Sean - I have used 470AD5-5 rivets to close those holes on RV-7 and RV-8 tanks. A Careful "Pre-squeeze" fattens the rivet a little so it won't wobble around or cleat when it's time to set it in the hole. neal I remember a discussion a while back regarding other options for closing up the tooling holes in the inboard and outboard most tank ribs. -Sean #40303 ________________________________________________________________________________
Date: Sep 01, 2005
On my -6, I set 3/16" rivets set into the tooling holes. Providing the hole size hasn't changed for the -10, I'll be doing the same thing. - Tom -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Sean Stephens Subject: RV10-List: Tank Rib Tooling Holes I remember a discussion a while back regarding other options for closing up the tooling holes in the inboard and outboard most tank ribs. Can someone refresh my memory? Thanks... -Sean #40303 ________________________________________________________________________________
Subject: Re: Tank Rib Tooling Holes
Date: Sep 01, 2005
Sean Don't remember the whole discussion which included suggestions to use "pop" rivets from Lowes but as for me I used an AN470A-5 solid rivet cut to the appropriate length and covered with proseal. The AN470A is a "soft" rivet and I used it because I had some. Worked great. Suppose you could use an AD "hard" rivet also. John Hasbrouck #40264 ________________________________________________________________________________
Date: Sep 01, 2005
Excellent. I have some extra -5s laying around. Thanks all for the info... -Sean #40303 > > From: "Neal George" <neal(at)appaero.com> > Date: 2005/09/01 Thu PM 01:00:36 EDT > To: > Subject: RE: RV10-List: Tank Rib Tooling Holes > > > Sean - > > I have used 470AD5-5 rivets to close those holes on RV-7 and RV-8 tanks. > A Careful "Pre-squeeze" fattens the rivet a little so it won't wobble > around or cleat when it's time to set it in the hole. > > neal > > > I remember a discussion a while back regarding other options for closing > > up the tooling holes in the inboard and outboard most tank ribs. > > -Sean #40303 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 01, 2005
Sean make sure they are AD5-5 or they will turn out to small, the easiest to do is to make a plate like Dan Checkoway did, and flush rivet it place and seal it up. That is what I did, took all of 5 extra minutes -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of schmoboy(at)cox.net Subject: Re: RE: RV10-List: Tank Rib Tooling Holes Excellent. I have some extra -5s laying around. Thanks all for the info... -Sean #40303 > > From: "Neal George" <neal(at)appaero.com> > Date: 2005/09/01 Thu PM 01:00:36 EDT > To: > Subject: RE: RV10-List: Tank Rib Tooling Holes > > > Sean - > > I have used 470AD5-5 rivets to close those holes on RV-7 and RV-8 tanks. > A Careful "Pre-squeeze" fattens the rivet a little so it won't wobble > around or cleat when it's time to set it in the hole. > > neal > > > I remember a discussion a while back regarding other options for closing > > up the tooling holes in the inboard and outboard most tank ribs. > > -Sean #40303 > > > > > > > > > > > > > > ________________________________________________________________________________
From: "Chris , Susie McGough" <VHMUM(at)bigpond.com>
Date: Sep 02, 2005
3 for show two for go!! Having said that if the flaps are not set corectly you will lose about 8 knots... regards Chris ----- Original Message ----- From: Mark Ritter To: rv10-list(at)matronics.com Sent: Friday, September 02, 2005 12:08 AM Subject: RE: RV10-List: Three bladed props Yes and the report was disappointing. Vic Syracuse is flying with a three blade MT prop and I believe he is seeing a TAS of 161 - 162 knots at 8,000'. Vic is working with the folks at MT but have not heard anything lately. Jim Ayers (Less Drag guy) is suppose to have access to an RV-10 and will be doing a comparison of performance between a two blade Hartzell and the three blade MT. When I talked to Jim about Vic's performance his reply was "its easy to blame the prop". He also told me MT stands behind their product and that I had not purchased a lemon. Here's hoping! Mark From: "John Dunne" <acs(at)acspropeller.com.au> Reply-To: rv10-list(at)matronics.com To: Subject: RV10-List: Three bladed props Date: Thu, 1 Sep 2005 12:35:43 +1000 Hi All, Has anyone heard any reports on the performance of the MT three bladed prop? John Dunne. RV-10 #40315 (Finishing Tailcone) acs(at)acspropeller.com.au ________________________________________________________________________________
Date: Sep 02, 2005
Subject: Converting O-540 235 HP to 260 HP
Looking for any info (STC) on converting a 235 HP O-540 to 260 HP. Any help or websites/engine builders that do this would be greatly appreciated. I believe all that is needed are new pistons/rings to go from a 7.250 compression to a 8.50 compression. Thanks, DEAN Looking for any info (STC) on converting a 235 HP O-540 to 260 HP. Any help or websites/engine builders that do this would be greatly appreciated. I believe all that is needed are new pistons/rings to go from a 7.250 compression to a 8.50 compression. Thanks, DEAN ________________________________________________________________________________
Date: Sep 02, 2005
Subject: Re: Converting O-540 235 HP to 260 HP
The first thing you lneed is a lycoming OVH manual and a Parts book! When in doubt read the book. But this is why you are called experimental. "ddddsp1(at)juno.com" wrote: Looking for any info (STC) on converting a 235 HP O-540 to 260 HP. Any help or websites/engine builders that do this would be greatly appreciated. I believe all that is needed are new pistons/rings to go from a 7.250 compression to a 8.50 compression. Thanks, DEAN ________________________________________________________________________________
Date: Sep 02, 2005
Dean, It all depends on exact model that you're converting from and to. A copy of the parts catalog would absolutely verify for you, but I went through this to convert an O-540-B4B5 to an IO-540-D4A5. Differences included pistons, mags and carb to FI system. The other common thing that might be different is the counterweights - you want the counterweight configuration for the "Hartzell Compact Hub" which I believe is indicated by the 2nd digit in the suffix being a "4". There are actually multiple parts catalogs: wide and standard/narrow deck and at least for the narrow deck there's a catalog each for carbureted and fuel injected models Part numbers for the narrow deck are PC-115-2 for the carb engines and PC-215-1 for the fuel injected. They aren't expense and I've actually got a copy of both. I'd be happy to look up a detail or two for you, but you really need a copy for your engine if you're going to work on it. Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Subject: RV10-List: Converting O-540 235 HP to 260 HP Looking for any info (STC) on converting a 235 HP O-540 to 260 HP. Any help or websites/engine builders that do this would be greatly appreciated. I believe all that is needed are new pistons/rings to go from a 7.250 compression to a 8.50 compression. Thanks, DEAN ________________________________________________________________________________
Date: Sep 02, 2005
Subject: Crow's Foot Torque
Crow's foot adapter? I assume this is what I need to torque the AN flare fittings for my fuel lines? If so, can someone point me to a good source to purchase them? Also, what needs to be added to the torque amount when using one of these? Thanks, Sean #40303 ________________________________________________________________________________
Date: Sep 02, 2005
Subject: Re: Crow's Foot Torque
Sean Stephens wrote: > > Crow's foot adapter? I assume this is what I need to torque the AN > flare fittings for my fuel lines? > > If so, can someone point me to a good source to purchase them? Also, > what needs to be added to the torque amount when using one of these? I got my set from Sears. There is a chart with my torque wrench that tells you the adjustment to make when using a crow's foot or similar thing depending on the length of the offset. -Dj ________________________________________________________________________________
Date: Sep 02, 2005
Harbor Freight sells cheap sets of crowfoot wrenches, flare nut and straight variety. I only see metric on their web site but they do sell SAE. Here's a cheap set: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4368152763&category=29527 And here's a calculator that lets you determine torque settings when using a torque wrench extension: http://www.rvproject.com/mechanic.html AC43.13 has a table of torques for AN fluid fittings. Most people I know use German Torque on AN fittings ("guddenteit"). )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Sean Stephens" <schmoboy(at)cox.net> Subject: RV10-List: Crow's Foot Torque > > Crow's foot adapter? I assume this is what I need to torque the AN flare > fittings for my fuel lines? > > If so, can someone point me to a good source to purchase them? Also, what > needs to be added to the torque amount when using one of these? > > Thanks, > > Sean #40303 > > ________________________________________________________________________________
Date: Sep 02, 2005
Sears sells a good kit, and for torque just use the formula that is in the book -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: Crow's Foot Torque Crow's foot adapter? I assume this is what I need to torque the AN flare fittings for my fuel lines? If so, can someone point me to a good source to purchase them? Also, what needs to be added to the torque amount when using one of these? Thanks, Sean #40303 ________________________________________________________________________________
Date: Sep 02, 2005
Sean: I just went through the same exercise. I found a good set at Sears but purchased a cheap set (~$15 shipped) off eBay that will do the job. There is a section on use and calculations in Chapter 7 of the "Aircraft Inspections & Repair Book. I saw a link to a .pdf file the other day on the list but don't remember who posted. Byron Vacation day - working on the fuselage floors #40253 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: Crow's Foot Torque Crow's foot adapter? I assume this is what I need to torque the AN flare fittings for my fuel lines? If so, can someone point me to a good source to purchase them? Also, what needs to be added to the torque amount when using one of these? Thanks, Sean #40303 ________________________________________________________________________________
Date: Sep 02, 2005
You can purchase crow's feet at a variety of places including Sears. If you mount the crow's foot on your torque wrench at a right angle to the wrench body you don't need to do any additional calculation to compensate for the length of the crow's foot, just read the torque directly, otherwise you need to do some compensation. Bruce Case, #40446, A&P student ________________________________________________________________________________
Date: Sep 02, 2005
Thanks everyone for the replies. As always, this community is something special... -Sean #40303 Dan Checkoway wrote: > > Harbor Freight sells cheap sets of crowfoot wrenches, flare nut and > straight variety. I only see metric on their web site but they do > sell SAE. > > Here's a cheap set: > http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4368152763&category=29527 > > > And here's a calculator that lets you determine torque settings when > using a torque wrench extension: > http://www.rvproject.com/mechanic.html > > AC43.13 has a table of torques for AN fluid fittings. Most people I > know use German Torque on AN fittings ("guddenteit"). > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ----- Original Message ----- From: "Sean Stephens" <schmoboy(at)cox.net> > To: > Sent: Friday, September 02, 2005 11:03 AM > Subject: RV10-List: Crow's Foot Torque > > >> >> Crow's foot adapter? I assume this is what I need to torque the AN >> flare fittings for my fuel lines? >> >> If so, can someone point me to a good source to purchase them? Also, >> what needs to be added to the torque amount when using one of these? >> >> Thanks, >> >> Sean #40303 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 02, 2005
the goodntite is great, thats why they call you experimental. Harbor Freight sells cheap sets of crowfoot wrenches, flare nut and straight variety. I only see metric on their web site but they do sell SAE. Here's a cheap set: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4368152763&category=29527 And here's a calculator that lets you determine torque settings when using a torque wrench extension: http://www.rvproject.com/mechanic.html AC43.13 has a table of torques for AN fluid fittings. Most people I know use German Torque on AN fittings ("guddenteit"). )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Sean Stephens" Subject: RV10-List: Crow's Foot Torque > > Crow's foot adapter? I assume this is what I need to torque the AN flare > fittings for my fuel lines? > > If so, can someone point me to a good source to purchase them? Also, what > needs to be added to the torque amount when using one of these? > > Thanks, > > Sean #40303 > > ________________________________________________________________________________
Date: Sep 03, 2005
From: "Scott Schmidt" <sschmidt(at)ussynthetic.com>
I'm going to give Jim a call tomorrow and talk to him about this. Last I heard was Vic's engine wasn't making full power. When Van's did their study the MT prop was about 1-2 mph slower but 8 knots is either the engine, or other airframe issues. Scott Schmidt sschmidt(at)ussynthetic.com ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris , Susie McGough Subject: Re: RV10-List: Three bladed props 3 for show two for go!! Having said that if the flaps are not set corectly you will lose about 8 knots... regards Chris ----- Original Message ----- From: Mark Ritter <mailto:mritter509(at)msn.com> To: rv10-list(at)matronics.com Sent: Friday, September 02, 2005 12:08 AM Subject: RE: RV10-List: Three bladed props Yes and the report was disappointing. Vic Syracuse is flying with a three blade MT prop and I believe he is seeing a TAS of 161 - 162 knots at 8,000'. Vic is working with the folks at MT but have not heard anything lately. Jim Ayers (Less Drag guy) is suppose to have access to an RV-10 and will be doing a comparison of performance between a two blade Hartzell and the three blade MT. When I talked to Jim about Vic's performance his reply was "its easy to blame the prop". He also told me MT stands behind their product and that I had not purchased a lemon. Here's hoping! Mark =09 ________________________________ From: "John Dunne" <acs(at)acspropeller.com.au> Reply-To: rv10-list(at)matronics.com To: Subject: RV10-List: Three bladed props Date: Thu, 1 Sep 2005 12:35:43 +1000 Hi All, Has anyone heard any reports on the performance of the MT three bladed prop? John Dunne. RV-10 #40315 (Finishing Tailcone) acs(at)acspropeller.com.au Features Subscriptions ________________________________________________________________________________
Date: Sep 03, 2005
Ah but I do work on airplanes and I do see things that you would not believe and 90% is by the owners and other mechanics who think good and tight is the only way of doing. And when was the last time you had you own torque qrench checked? you amature!!! Rick wrote: I've torqued AN fittings to specs and found leaks, as Dan says tongue in cheek "goodintight" with a bit of a German accent, is correct and has nothing to do with "experimental" unless you are calling our front line fighter aircraft "experimental" The proecedure I have used, is to start with the spec torque and during engine run up you do a leak check (required to check for leaks), mainly on our "experimental F-100/110 engines" and hydraulic powered M61A1 20MM cannons, (GAU-8 as well but that's another story) funny I always tried to figure out after we applied the proper torque to all those fittings we had to do an engine run to check for leaks, seeing how we torqued them and all. Shoot!!!! Look there a "leak"!!!! IT'S BECAUSE THEY NEED TO BE SNUGGED, maybe past the desired torque to stop leaks. Why do you think there is a range of torque you dipstick!! Experimental my A**. Rick S. 40185 Fuse ________________________________________________________________________________
Date: Sep 03, 2005
Subject: Canadain inspectors rejecting some re-assembled parts?
I was speaking to the guy who does homebuilt inspections in my area and he tells me that it was reported to him that several Canadian RV-10 builders have had either their fast build wings or wing spars fail inspection due to poor riveting quality in the pre-done assemblies. From what he could recall he thought the issue was under driven rivets. I'd sure like to hear from those who had this problem and what was done to resolve the issue. Perry Casson - top skin on wing #2 Regina, Canada ________________________________________________________________________________
Subject: Re: Canadain inspectors rejecting some re-assembled parts?
Date: Sep 04, 2005
Perry this is of serious concern...do you have any more details as I would like to follow it up at Vans. Chris ----- Original Message ----- From: "Perry Casson" <pcasson(at)sasktel.net> Subject: RV10-List: Canadain inspectors rejecting some re-assembled parts? > > I was speaking to the guy who does homebuilt inspections in my area and he > tells me that it was reported to him that several Canadian RV-10 builders > have had either their fast build wings or wing spars fail inspection due > to poor riveting quality in the pre-done assemblies. From what he could > recall he thought the issue was under driven rivets. I'd sure like to > hear from those who had this problem and what was done to resolve the > issue. > > Perry Casson - top skin on wing #2 > Regina, Canada > > > ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: electric help
Date: Sep 03, 2005
All, Even though I'm only 70% done with the tail kit, I've been thinking a lot lately about wiring. I'm about to order Bob's book, but I'm asking you guys, the ones who've never done wiring before (except minor home repair), what other sources, if any, do I need to buy to get a foundation on simple schematic reading and building up from there? I don't know of any SportAir workshops any time soon in my area (lower AL) on the subject. Or will Bob's book start me out right? Rob #392 Short break between HS (61 hours) and Elevators. ________________________________________________________________________________
Subject: Re: electric help
Date: Sep 03, 2005
Bob's book covers a lot of theory, as well as providing some rock solid system diagrams and suggestions, but it doesn't really teach you the hands-on techniques. How to use crimpers on various pins and sockets, how to solder this and that. A lot of the fundamentals it just kind of assumes you have already. If you need "from square one" type instruction, I suggest getting together with somebody who has experience and tools and can show you the ropes. Something else to consider would be to scour every bit of the articles here: http://www.aeroelectric.com/articles.html Lots to be learned there for the uninitiated. Great stuff. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: Robert G. Wright To: rv10-list(at)matronics.com Sent: Saturday, September 03, 2005 3:13 PM Subject: RV10-List: electric help All, Even though I'm only 70% done with the tail kit, I've been thinking a lot lately about wiring. I'm about to order Bob's book, but I'm asking you guys, the ones who've never done wiring before (except minor home repair), what other sources, if any, do I need to buy to get a foundation on simple schematic reading and building up from there? I don't know of any SportAir workshops any time soon in my area (lower AL) on the subject. Or will Bob's book start me out right? Rob #392 Short break between HS (61 hours) and Elevators. ________________________________________________________________________________
Date: Sep 03, 2005
> Even though I'm only 70% done with the tail kit, I've been thinking a lot > lately about wiring. I'm about to order Bob's book, but I'm asking you > guys, the ones who've never done wiring before (except minor home repair), > what other sources, if any, do I need to buy to get a foundation on simple > schematic reading and building up from there? I don't know of any SportAir > workshops any time soon in my area (lower AL) on the subject. Electric Bob also holds weekend workshops that cover the same material as his book, but can help you to see the big picture. I went to one in Camarillo when I was building the -7A and it helped quite a bit. When I read the book and looked at the schematics, I didn't get the Eureka effect until I realized that every time Bob refers to a bus, what he really means is a fuse block. Main bus = 10 position fuse block in my -7A, Essential bus = 20 position fuse block. Once you get that, the rest of it is just point to point wiring with the correct AWG wire size. -Dan Masys RV7A N747DL flying RV10 rudder ________________________________________________________________________________
Subject: Minimum practical runway length for an RV-10
Date: Sep 03, 2005
Hi everyone. I've recently decided to join the ranks of RV-10 builders, having ordered my tail/emp kit a week or so ago. It's due to arrive some time next week, and I'm excited to get started. There are a couple of airports within a 30 minute drive that I could base the plane out of (and finish the construction at when it gets too big for the garage). However, I would much prefer to be able to keep the plane at home if it's at all practical - to benefit both the construction process as well as operating the plane later when completed. Having the plane literally just outside the door when I want to go flying would be a huge contributor to "just because" flying. So ideally, what I'd like to do is build a hanger at home and a grass strip. But I have some questions. First of all, how is the RV-10 expected to be able to handle a grass strip? Secondly, what would a "practical" runway length be for such a strip? I've read the fully loaded specs with a 260 hp engine (which I'm planning for) to be 500 ft takeoff and 650 ft landing (and in the factory demo ride I recently had, I can believe those numbers). But of course, that's assuming a perfectly performing plane, hard surface, etc. The land we own is approximately 2500 feet long, but there are several houses adjacent to the far south end. Because of this, I would plan on using it as a one-way runway to the north, to minimize any disturbance to the people there (takeoffs would be away from the houses, and landings over the houses to the strip would be at low power). Fortunately, there are no obstructions at all towards the north, nor are there likely to ever be - just flat field for miles, and the prevailing winds would almost always favor a northerly takeoff/landing anyway. To minimize the disturbance to our southern neighbours, I was thinking of a runway about 1300 feet long at the north end of the property, so there would be about 1200 feet between the houses at the south end of the property and the threshold. There is about a 0.9% gradient uphill towards the north. Obviously, the gradient and grass strip would reduce performance from the quoted figures, but I'm wondering what you folks out there would consider "appropriate" from a safety standpoint. Would this work? Also, how wide of a strip would be practical? I've landed at countless 75 foot wide strips, but would 50 feet wide be okay? Of course, the longer and wider the better, but I'm looking for practical minimums here, which I would probably increase a bit anyway. The other question pertains to our climate up here in Canada - for a large part of the year, the ground is covered in snow. Clearing the snow wouldn't be too much trouble - we can borrow the equipment for that. But not having landed anything on a grass strip with a plowed snow surface, would I just be asking for trouble? Or would it be better to fly in the winter with skis and forget about plowing (in that vein, could skis be outfitted to an RV-10?) The two airports within 30 minutes are both maintained summer and winter with asphalt runways, so I could always use them if returning from a flight somewhere and conditions at home aren't conducive to a safe landing. And of course, if operating an RV-10 out of a grass strip with the limitations I've mentioned isn't practical, I may be basing my plane out of one of those airports anyway. But since it would be so much more convenient (and less costly) to keep everything at home, I thought I'd write for advice on the matter. Thanks for any help you can give! Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 ________________________________________________________________________________
Date: Sep 03, 2005
Subject: Re: Canadain inspectors rejecting some pre-assembled parts?
I don't know much more than my 1st post and keep in mind this is 3rd hand news. My inspector was not sure if it was the spars or other riveting on fast build wings that was the issue during the pre-close inspections. I'll be following this up when I get home next week and report what ever I learn but with some luck the guys that had the problem are on the list and will set the story straight. The other thing I plan to do is get out my calipers and be sure the tails of the spar rivets are driven enough to meet *MIL-R-47196A * (found a copy at: <http://home.flash.net/~gila/rivet_spec/rivet_a.htm>)* *Perry Casson Chris , Susie McGough wrote: > > > Perry this is of serious concern...do you have any more details as I > would like to follow it up at Vans. ________________________________________________________________________________
Subject: tail cone questions
Date: Sep 04, 2005
Hi, guys I'm a the point of put the VS togheter,and have two problems (this questions is for the builders allready finish the empennage ,and may be help the begginers). when try to fit the skin at VS the leading edge do not close at the nose rib part,due to the nose rib is whider then the leading edge ,need a small fluting where the machine hole is at front?.do I start from the LE back or from back to LE. second, at page 6-2- fig 2- step 6, say ,machine countersink all #30 holes below upper attach bolt holes,but in page 6-4 fig4-step 7 say leave open the upper bottom rudder hinge bracket for later made a #12 hole,due I have to countersink these two holes? sorry for the stupid questions ,at this early stages of constuction I try to understand the general idea. Hugo #40456 ________________________________________________________________________________
Date: Sep 04, 2005
Subject: Re: tail cone questions
This question has come up many times before. What you really DON'T want to do is try to force the ribs tighter into the leading edge. You WILL cause an outward dent if you do that. I don't remember if you will need any fluting, but I don't think so. What you want to do is take maybe 1/8" or maybe more (leave yourself enough rivet hole edge clearance on that first tab), and remove a bit of the nose rib. Many builders who I've talked to online and at OSH have admitted that they too are a victim of this problem. That should answer the first part of your questions. As for the rest regarding the conutersinking, perhaps another person who is more recently done with the tailcone could jump in and give some good info on that...I'm a bit rusty on the tailcone. As far as I remember, there aren't too many gotchas on the tailcone, and if you just do everything per plans, only riveting the called out areas, and only countersinking the called out areas, you should come out just great. The nose rib not fitting in the front skin is one of the exceptions. Good luck Hugo....keep it going! Glad to hear you're coming along with your kit. Tim Olson -- RV-10 #40170 gommone7(at)bellsouth.net wrote: > > Hi, guys I'm a the point of put the VS togheter,and have two problems > (this questions is for the builders allready finish the empennage > ,and may be help the begginers). when try to fit the skin at VS the > leading edge do not close at the nose rib part,due to the nose rib is > whider then the leading edge ,need a small fluting where the machine > hole is at front?.do I start from the LE back or from back to LE. > second, at page 6-2- fig 2- step 6, say ,machine countersink all #30 > holes below upper attach bolt holes,but in page 6-4 fig4-step 7 say > leave open the upper bottom rudder hinge bracket for later made a #12 > hole,due I have to countersink these two holes? sorry for the stupid > questions ,at this early stages of constuction I try to understand > the general idea. Hugo #40456 > ________________________________________________________________________________
Date: Sep 04, 2005
If you look forward in the instructions for the HS, they tell you to trim/ reduce the nose rib on the leading edge so it will fit better. Read how they tell you to do it, and do it for the VS, you will be one of the few us that do not have the ridges in their VS skin. For your second question, I held off, because I looked at the attach sequence and it shows you putting bolts there, but if you do need to ctsk them later you can still get to them if needed. Dan 40269 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gommone7(at)bellsouth.net Subject: RV10-List: tail cone questions Hi, guys I'm a the point of put the VS togheter,and have two problems (this questions is for the builders allready finish the empennage ,and may be help the begginers). when try to fit the skin at VS the leading edge do not close at the nose rib part,due to the nose rib is whider then the leading edge ,need a small fluting where the machine hole is at front?.do I start from the LE back or from back to LE. second, at page 6-2- fig 2- step 6, say ,machine countersink all #30 holes below upper attach bolt holes,but in page 6-4 fig4-step 7 say leave open the upper bottom rudder hinge bracket for later made a #12 hole,due I have to countersink these two holes? sorry for the stupid questions ,at this early stages of constuction I try to understand the general idea. Hugo #40456 ________________________________________________________________________________
Date: Sep 04, 2005
Go to William Curits's site, he has a nice wiring diagram, link to it off Tim Olsons site www.myrv10.com, I beleive he has so good wiring info there as well. Rick S. 40185 Fuse ________________________________________________________________________________
Date: Sep 05, 2005
Thanks Perry we need to follow his sor of stuff up as if Vans does not know he cant fix it. Chris ----- Original Message ----- From: "Perry Casson" <pcasson(at)sasktel.net> Subject: Re: RV10-List: Canadain inspectors rejecting some pre-assembled parts? > > I don't know much more than my 1st post and keep in mind this is 3rd hand > news. My inspector was not sure if it was the spars or other riveting on > fast build wings that was the issue during the pre-close inspections. > I'll be following this up when I get home next week and report what ever I > learn but with some luck the guys that had the problem are on the list and > will set the story straight. > > The other thing I plan to do is get out my calipers and be sure the tails > of the spar rivets are driven enough to meet *MIL-R-47196A * (found a copy > at: <http://home.flash.net/~gila/rivet_spec/rivet_a.htm>)* > > *Perry Casson > > > Chris , Susie McGough wrote: > >> >> >> Perry this is of serious concern...do you have any more details as I >> would like to follow it up at Vans. > > > ________________________________________________________________________________
Subject: Re: Friggin tank ribs
Date: Sep 04, 2005
Michael, I wouldn't try bending things just yet. Flute the ribs and cleco them in place starting with the noses first and working back to the trailing edge. Put one rib in, couple of clecos on the nose, next rib couple of clecos on the nose ect. then come back and add a few toward the trailing edge of each rib. Do this with the skins spread out and the ribs will pull the skins in as you go. Eventually they will slide into the cradles. After drilling and dimpling they go back together much easier, ( or at least somewhat easier ). If you try bending things now you'll add to your problems IMHO. Yes, they all fit that way as far as I know... John Hasbrouck #40264 Tanks Done! ________________________________________________________________________________
Subject: tail cone thanks
Date: Sep 04, 2005
Thanks a lot to all . The skin is in position,now I have to learn countersink and dimple,I was reading Van use to put some discards in the kits for practising,not in mine. Another stupid question ,how you prevent scratches when use the microstop countersink tool,the chips you create scratch the surfece around the hole. Thanks . Ps.I have to apoligeze,this internet group it is really more valuable then what I thinks before recive the kit. Hugo another Ps.how you made a round hole in the thin materials,I made beatifuls triangles with a round bit,I must to be good. ________________________________________________________________________________
Date: Sep 04, 2005
Subject: Re: tail cone thanks
>Van use to put some discards in the kits for practising,not in mine. Its the stack labeled "Trim pack". It looks too nice to cut up though :) >Another stupid question ,how you prevent scratches when use the microstop countersink tool,the chips you create scratch the surfece around the hole. Thanks . After you do one hole, brush the chips off and then move to the next one. >Ps.how you made a round hole in the thin materials,I made beatifuls triangles with a round bit,I must to be good. I had received a tip on this one; You need to use a SLOW drill. What you want to do is shave the material away. Too fast and the bit chatters, resulting in what you describe. -Jim 40384, Riveting Tailcone tonight gommone7(at)bellsouth.net wrote: > >Thanks a lot to all . >The skin is in position,now I have to learn countersink and dimple,I was reading Van use to put some discards in the kits for practising,not in mine. >Another stupid question ,how you prevent scratches when use the microstop countersink tool,the chips you create scratch the surfece around the hole. >Thanks . >Ps.I have to apoligeze,this internet group it is really more valuable then what I thinks before recive the kit. >Hugo >another Ps.how you made a round hole in the thin materials,I made beatifuls triangles with a round bit,I must to be good. > > > > > > > > > ________________________________________________________________________________
Date: Sep 04, 2005
If you're using the single hole countersink bits, they tend to leave more and deeper marks (at least mine do). I prefer the 3 flute model. Either way, you're going to get a few scratches. PJ 40032 gommone7(at)bellsouth.net wrote: > >Thanks a lot to all . >The skin is in position,now I have to learn countersink and dimple,I was reading Van use to put some discards in the kits for practising,not in mine. >Another stupid question ,how you prevent scratches when use the microstop countersink tool,the chips you create scratch the surfece around the hole. >Thanks . >Ps.I have to apoligeze,this internet group it is really more valuable then what I thinks before recive the kit. >Hugo >another Ps.how you made a round hole in the thin materials,I made beatifuls triangles with a round bit,I must to be good. > > > > > > > > > ________________________________________________________________________________
Subject: Re: Minimum practical runway length for an RV-10
Date: Sep 04, 2005
Having flown a 150hp CS RV-6A, and having flown Van's RV-10 demo I would recommend thinking about a minimum of 2000 foot strip for safety purposes. That is not to say that you couldn't get in or our of a 1000 foot strip, just that for day in and day out operations this 1400 + hour pilot wouldn't recommend it. In addition, for the initial fly off hours I would NEVER consider even a 2000 foot strip. The bigger the better, with cross runways as well. I would recommend that you build in your garage, move to a big airport for final assembly and fly off. If after that you want to risk a 1300 foot strip you would have a lot better feel for both the -10 and your abilities. ----- Original Message ----- From: "Dan Charrois" <danlist(at)syz.com> Subject: RV10-List: Minimum practical runway length for an RV-10 > > Hi everyone. I've recently decided to join the ranks of RV-10 builders, > having ordered my tail/emp kit a week or so ago. It's due to arrive some > time next week, and I'm excited to get started. > > There are a couple of airports within a 30 minute drive that I could base > the plane out of (and finish the construction at when it gets too big for > the garage). However, I would much prefer to be able to keep the plane > at home if it's at all practical - to benefit both the construction > process as well as operating the plane later when completed. Having the > plane literally just outside the door when I want to go flying would be a > huge contributor to "just because" flying. > > So ideally, what I'd like to do is build a hanger at home and a grass > strip. But I have some questions. First of all, how is the RV-10 > expected to be able to handle a grass strip? Secondly, what would a > "practical" runway length be for such a strip? I've read the fully > loaded specs with a 260 hp engine (which I'm planning for) to be 500 ft > takeoff and 650 ft landing (and in the factory demo ride I recently had, > I can believe those numbers). But of course, that's assuming a perfectly > performing plane, hard surface, etc. > > The land we own is approximately 2500 feet long, but there are several > houses adjacent to the far south end. Because of this, I would plan on > using it as a one-way runway to the north, to minimize any disturbance to > the people there (takeoffs would be away from the houses, and landings > over the houses to the strip would be at low power). Fortunately, there > are no obstructions at all towards the north, nor are there likely to > ever be - just flat field for miles, and the prevailing winds would > almost always favor a northerly takeoff/landing anyway. To minimize the > disturbance to our southern neighbours, I was thinking of a runway about > 1300 feet long at the north end of the property, so there would be about > 1200 feet between the houses at the south end of the property and the > threshold. There is about a 0.9% gradient uphill towards the north. > > Obviously, the gradient and grass strip would reduce performance from the > quoted figures, but I'm wondering what you folks out there would consider > "appropriate" from a safety standpoint. Would this work? Also, how wide > of a strip would be practical? I've landed at countless 75 foot wide > strips, but would 50 feet wide be okay? Of course, the longer and wider > the better, but I'm looking for practical minimums here, which I would > probably increase a bit anyway. > > The other question pertains to our climate up here in Canada - for a > large part of the year, the ground is covered in snow. Clearing the snow > wouldn't be too much trouble - we can borrow the equipment for that. But > not having landed anything on a grass strip with a plowed snow surface, > would I just be asking for trouble? Or would it be better to fly in the > winter with skis and forget about plowing (in that vein, could skis be > outfitted to an RV-10?) > > The two airports within 30 minutes are both maintained summer and winter > with asphalt runways, so I could always use them if returning from a > flight somewhere and conditions at home aren't conducive to a safe > landing. And of course, if operating an RV-10 out of a grass strip with > the limitations I've mentioned isn't practical, I may be basing my plane > out of one of those airports anyway. But since it would be so much more > convenient (and less costly) to keep everything at home, I thought I'd > write for advice on the matter. > > Thanks for any help you can give! > > Dan > -- > Syzygy Research & Technology > Box 83, Legal, AB T0G 1L0 Canada > Phone: 780-961-2213 > > > ________________________________________________________________________________
Subject: Friggin tank ribs
Date: Sep 04, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
John, Thanks for the reply. I did all of the below on the left tank and I still needed to literally use a dead blow to get them to line up. I looked at my inventory pictures and noticed that the tank skins were sitting inside the regular LE skins and had a considerable amount of space between them and the LE's. I.e. more of a bend. That really doesn't make sense as the geometry should be the same. For the right tank skin I just took two 8ft 2x4's and clamped the skin in place right behind the LE with one. I took the other 2x4 and gently bent the skin back closer to a 90 but something like a 75 to 80. When I then proceeded to put the ribs in place they all lined up perfectly. No expletives, no hammers, no persuading, all the holes were right where they were supposed to be. Worked great! Took me all of about 20 minutes to cleco all of the right tank ribs in place where it took me 2 hours to do the left. I put a cleco in the first and third hole on all the ribs and dropped it in the cradle, the skin sucked up to the ribs no problem. I'm sure everyone had a problem fitting their ribs but mine was excessive. I had ribs distorting and starting to bend trying to get them lined up. Everything pointed to the firs 2 inches of the ribs being squeezed to much into the space. Looks like that was it. Michael Sausen -10 #352 Friggin Tanks :-) ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: Re: RV10-List: Friggin tank ribs Michael, I wouldn't try bending things just yet. Flute the ribs and cleco them in place starting with the noses first and working back to the trailing edge. Put one rib in, couple of clecos on the nose, next rib couple of clecos on the nose ect. then come back and add a few toward the trailing edge of each rib. Do this with the skins spread out and the ribs will pull the skins in as you go. Eventually they will slide into the cradles. After drilling and dimpling they go back together much easier, ( or at least somewhat easier ). If you try bending things now you'll add to your problems IMHO. Yes, they all fit that way as far as I know... John Hasbrouck #40264 Tanks Done! ________________________________________________________________________________
Date: Sep 04, 2005
Michael, Great save! That's the 51% they talk about. Even though we're building the same kit it should be understood that Van's can make a mistake from time to time. Looks like you solved the problem. BTW while we're on the subject of mistakes, I had a problem with the W-1013C-L aileron bracket. It was not manufactured right. A fellow builder in the area had the same problem. We received our wings about mid May. Van's sent us replacements. ________________________________________________________________________________
Date: Sep 04, 2005
Subject: Cowling Trim question
Is there someone who's done the front cowling who can answer a quick question? I'm about to trim it. The directions aren't bad, but a little vague. You center the spinner in the hole for the cowling top. Does the spinner face slope smoothly into that ridge in the cowl, so they should be level and flow together, or is the cowling supposed to be raised up at all above the spinner height? On my Sundowner, the cowl is about 1/2" taller than the spinner is, but that's a whole different plane. It can seem logically centered either way...flush, or the cowl circle about 1/4" outside of the spinner. The reason is, the area with the 3 screws on each side sticks out a bit more, so it makes it look like it could possibly not be flush. 2nd question: The cowl as supplied must not overlap the top and bottom surfaces, huh? When they're put together, it looks as if it's going to end up with the top half and bottom half butting up against eachother along the side of the cowl. I suppose that's expected since it's a hinge joint.....duh. Oh well, I guess we're all allowed a few stupid questions. Tip of the day: When drilling those UHMW blocks that the door lock pins go through....the ones that mount to the outside of the doorframe, not to the door... If you follow the directions and shim the block up on the side they say to do, you will be drilling the 3.4 degree offset hole so that it slopes in the WRONG direction to do what you need it to do. Also, if you follow the drawing and centerpunch for the 2 small holes on the side they show to punch, you'll end up with a part that doesn't work because of this slope. Read the directions, look at the pictures, then test the concept on the door and you'll see what I mean. Just try to remember this issue before you get to this point. Tim -- Tim Olson -- RV-10 #40170 Current project: Cowling ________________________________________________________________________________
Date: Sep 04, 2005
Tim, I may not have the question right, but when I installed the cowling on my RV-6 the plans had me intentionally set the cowling slightly lower that the spinner(1/4", maybe more???????) to allow for the engine mounts to settle. I suspect that is why your Sundowner cowl is taller, the engine has settled more that what the manufacture allowed for (not that you have a problem with the Sundowner though, this is normal). Hopefully someone who has done this with the RV-10 will give you a solid answer, I'm rapidly approaching the cowling part, but not there yet. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Cowling Trim question Is there someone who's done the front cowling who can answer a quick question? I'm about to trim it. The directions aren't bad, but a little vague. You center the spinner in the hole for the cowling top. Does the spinner face slope smoothly into that ridge in the cowl, so they should be level and flow together, or is the cowling supposed to be raised up at all above the spinner height? On my Sundowner, the cowl is about 1/2" taller than the spinner is, but that's a whole different plane. It can seem logically centered either way...flush, or the cowl circle about 1/4" outside of the spinner. The reason is, the area with the 3 screws on each side sticks out a bit more, so it makes it look like it could possibly not be flush. 2nd question: The cowl as supplied must not overlap the top and bottom surfaces, huh? When they're put together, it looks as if it's going to end up with the top half and bottom half butting up against eachother along the side of the cowl. I suppose that's expected since it's a hinge joint.....duh. Oh well, I guess we're all allowed a few stupid questions. Tip of the day: When drilling those UHMW blocks that the door lock pins go through....the ones that mount to the outside of the doorframe, not to the door... If you follow the directions and shim the block up on the side they say to do, you will be drilling the 3.4 degree offset hole so that it slopes in the WRONG direction to do what you need it to do. Also, if you follow the drawing and centerpunch for the 2 small holes on the side they show to punch, you'll end up with a part that doesn't work because of this slope. Read the directions, look at the pictures, then test the concept on the door and you'll see what I mean. Just try to remember this issue before you get to this point. Tim -- Tim Olson -- RV-10 #40170 Current project: Cowling ________________________________________________________________________________
Subject: wire
Date: Sep 04, 2005
About how much wire will really be used? It doesn't seem that expensive at around $15 for 100' of 18 AWG. Other sizes of wire will be priced differently, but using this as an indicator seems good. I just don't want a whole bunch of wire hanging around afterward, and I do plan on wiring one or two extra empty lengths per bundle. Rob Checked the archives, but missed it if it's there ________________________________________________________________________________
Date: Sep 05, 2005
Subject: IO-540 engine mounts needed - part number 70456
Listers, I'm overhauling an elderly IO-540-C4B5 for my RV-10. I have 4 engine mount brackets, Lycoming part number 72306 (Piper Aztec compatible, I believe). I'm looking for an economical source for the 4 brackets that Van's engine mount expects, Lycoming part number 70456. Does anybody know of a supplier who'd be interested in some sort of exchange? Thanks, Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 790 hrs RV-10 #40059 under construction ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Subject: Re: IO-540 engine mounts needed - part number 70456
Date: Sep 05, 2005
Hi, try some of the airboat specialists. Marcel ----- Original Message ----- From: "Tim Lewis" <Tim_Lewis(at)msm.umr.edu> Subject: RV10-List: IO-540 engine mounts needed - part number 70456 > > Listers, > > I'm overhauling an elderly IO-540-C4B5 for my RV-10. I have 4 engine > mount brackets, Lycoming part number 72306 (Piper Aztec compatible, I > believe). I'm looking for an economical source for the 4 brackets that > Van's engine mount expects, Lycoming part number 70456. > > Does anybody know of a supplier who'd be interested in some sort of > exchange? > > Thanks, > > Tim > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 790 hrs > RV-10 #40059 under construction > > > > > > > > > > > > ________________________________________________________________________________
Subject: Gretz
Date: Sep 05, 2005
For those who bought heated pitots from Gretz, how much were they? I've tried to contact them by e-mail but haven't received any response. Wanted a price and ordering info. Thanks John Hasbrouck #40264 ________________________________________________________________________________
Subject: FW: Elevator question
Date: Sep 05, 2005
Quick question please....I'm almost ready to start dimpling and priming the elevator skins and noticed an extra hole (3/32) that is very near the trailing edge in the top of the left and right skin. There doesn't seem to be anything under it, so I'm confused by this. Has anyone else seen this? What should I do? Just dimple it and fill with a flush rivet? Sorry if this in the archives, couldn't find it. Thanks, Sean Blair N967SB(reserved) ________________________________________________________________________________
Date: Sep 05, 2005
Subject: Re: FW: Elevator question
Got a picture? I've just finished my elevators a few weeks ago, and after taking another look at them I still can't figure out what you're referring to. A picture's worth a thousand words..... -Jim 40384, Riveting Tailcone Sean Blair wrote: > Quick question please.Im almost ready to start dimpling and > priming the elevator skins and noticed an extra hole (3/32) that is > very near the trailing edge in the top of the left and right skin. > There doesnt seem to be anything under it, so Im confused by this. > Has anyone else seen this? What should I do? Just dimple it and fill > with a flush rivet? > > Sorry if this in the archives, couldnt find it. > > Thanks, > > Sean Blair > > N967SB(reserved) > ________________________________________________________________________________
Date: Sep 05, 2005
Thanks for the wonderful responses I received about my posting for the minimum practical runway length for an RV-10. One thing I forgot to mention in my posting was our elevation. We're not terribly high, but not at sea level either - at about 2300 feet ASL. From the advice I've been given, coupled with the altitude, I've come to the conclusion that for safety's sake, I will either: - need to find land in the area I can lease that will give me at least 3000 feet of distance (maybe even more), especially during the testing phases - rent some hanger space in one of the nearest airports to finish up construction of the plane and do flight testing at. This would without doubt be the safest option. Then, once everything is done and I'm comfortable with the plane, I can test things on existing long grass strips to see if a strip on our land is feasible and comfortable or just asking for trouble. It's not anywhere near as convenient as just being able to use the land we already have, but I'd rather trade off safety for convenience :-) Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 ________________________________________________________________________________
Date: Sep 05, 2005
Sorry Jim, no picture with me. This extra hole is within an inch or two forward of the rivet line where you Pro Seal the trailing edge. It shows up on the top skins only for both the left and right skins. Next time I'm at the hangar I'll get a picture of this if needed. Thanks for taking a look. Sean B. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: FW: Elevator question Got a picture? I've just finished my elevators a few weeks ago, and after taking another look at them I still can't figure out what you're referring to. A picture's worth a thousand words..... -Jim 40384, Riveting Tailcone Sean Blair wrote: > Quick question please....I'm almost ready to start dimpling and > priming the elevator skins and noticed an extra hole (3/32) that is > very near the trailing edge in the top of the left and right skin. > There doesn't seem to be anything under it, so I'm confused by this. > Has anyone else seen this? What should I do? Just dimple it and fill > with a flush rivet? > > Sorry if this in the archives, couldn't find it. > > Thanks, > > Sean Blair > > N967SB(reserved) > ________________________________________________________________________________
Date: Sep 05, 2005
You're not refering to one of the holes on the tab you bend down/up right next to where the trim tab attaches, are you? Those are the only holes I could find on my elevators that kinda matches your description. If so, once you bend the tabs from the top and bottom together, a pop rivet goes through to hold the two together. (Forms the verticle edge between the elevator proper and the trim tab) If that's not it, I am out of ideas... John #40208 Wings -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Blair Subject: RE: RV10-List: FW: Elevator question Sorry Jim, no picture with me. This extra hole is within an inch or two forward of the rivet line where you Pro Seal the trailing edge. It shows up on the top skins only for both the left and right skins. Next time I'm at the hangar I'll get a picture of this if needed. Thanks for taking a look. Sean B. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: FW: Elevator question Got a picture? I've just finished my elevators a few weeks ago, and after taking another look at them I still can't figure out what you're referring to. A picture's worth a thousand words..... -Jim 40384, Riveting Tailcone Sean Blair wrote: > Quick question please....I'm almost ready to start dimpling and > priming the elevator skins and noticed an extra hole (3/32) that is > very near the trailing edge in the top of the left and right skin. > There doesn't seem to be anything under it, so I'm confused by this. > Has anyone else seen this? What should I do? Just dimple it and fill > with a flush rivet? > > Sorry if this in the archives, couldn't find it. > > Thanks, > > Sean Blair > > N967SB(reserved) > ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Sep 05, 2005
John What was wrong with your aileron bracket John Testement jwt(at)roadmapscoaching.com 40321 Working on ailerons _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: Re: RV10-List: Friggin tank ribs Michael, Great save! That's the 51% they talk about. Even though we're building the same kit it should be understood that Van's can make a mistake from time to time. Looks like you solved the problem. BTW while we're on the subject of mistakes, I had a problem with the W-1013C-L aileron bracket. It was not manufactured right. A fellow builder in the area had the same problem. We received our wings about mid May. Van's sent us replacements. ________________________________________________________________________________
Date: Sep 06, 2005
Subject: Re: Plans revisions - Don't trust your plans
Oooops, too late for that. It might be gone Friday for good. I'm not tooooo frustrated over the plans, because they are probably the best part about the kit. I was just surprised that with a change done practically at the beginning of shipping that kit, they still delivered all of their kits with a known revision missing. The comment is mainly directed towards new builders... be diligent, and assume you do not have the latest plans, and check their site for all revisions....because you probably actually do not have the latest plans, even if you're a guy just starting his tailcone kit today. I would have assumed differently, so I'm just hoping to save some frustration to the 300+ people who are building after me. Tim Olson -- RV-10 #40170 Randy DeBauw wrote: > > I agree Tim! I think you would be better off without all the aggravation > having to deal with all of this. I'll make you a deal. I'll buy your kit > and those junk plans, pay you for all of the extra freight charges you > encountered. You can go fly the beloved Sundowner and no longer have to > deal with the frustration. I call you next year when I am 3 hours out > from Oshkosh and give you a head start so we can land at the same time. > > Get back to building! Say hi to the family. Randy > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Monday, September 05, 2005 8:39 PM > To: RV10 > Subject: RV10-List: Plans revisions - Don't trust your plans > > > A note about revisions: You cannot trust the plans that come with your > kit, so verify your plans revisions!!! I bought my FWF kit on > 5/25/2005. My plans on page FF1-4 were dated something like 1/26/2005. > One of the recent parts that I thought I was missing has turned up... > > I had almost called to complain to Van's about a missing fitting, but as > > it turned out, the plans had changed on 2/22/05, and now that fitting > was no longer required. Don't ask me why when I purchased plans on > 5/25, 3 months after the revision, they didn't send me a complete set of > > plans with the revision in them. This to me is another spectacular > example of where customer service should absolutely be improved. In > addition, it would be no major deal for any organized company to send > out email notices to their RV-10 builders to notify them of plans > changes.....but I suppose why bother, from what it appears, usually when > > they have problems with the plans or parts, they thend to just ignore > the people who call and tell them anyway. > > I'm not trying to beat them up, but I'd think that when someone > puts down over $40,000 with a company, they'd send them with current > set of plans, or at least send the revision along with them. > That said, I do check their site periodically for updates, and I > had downloaded and printed them all. At the time, I hadn't even > received the FWF kit plans, so the paper was still stuffed with my > finishing kit plans, so it got overlooked. I guess I assumed that > when you buy a kit, you're receiving the latest and greatest plans. > ________________________________________________________________________________
Date: Sep 06, 2005
John, The recess for the bearing was of about 1/32 so that when you put the three peices together after the bearing was in place, the rivet holes would not line back up. This after having match drilled the three pieces without the bearing in place as per the plans. The new one that Van's sent went together perfectly. ________________________________________________________________________________
Subject: vent eyeball placement
Date: Sep 06, 2005
Hi Tim: I Don't have my panel at this point , so i can't glu the vent in place till i get it back , i did buy the vent and some hose in anticapation of haveing a small problem in where to put the black eyeball , i am including 2 pic from the Idaho -10 that stoped into Auburn 3 weeks ago , hope this helps . Waiting for the engine , should be here this week ! Brian Bollaert #40200 ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Subject: N325HP
Date: Sep 06, 2005
Hi all, Just a quick note that I flew N325HP last Thursday! WOW, flew hands off. Stable but when commanded to turn it turns and stays there, can't wait to shoot and ILS. The most impressive part was the noise level in the cockpit. I had to remove one ear cup to here the engine on take off, other than that just a purr of the engine and wind flowing over the airframe. I sound deadened it and have a performance aero engine, 325 horse power and on the front of that a Catto three blade prop. Supper smooth and fast is all I can say at this time will get some real numbers in a few weeks. For those of you building keep on it is worth it Noel Simmons www.blueskyaviation.net <http://www.blueskyaviation.net/> ________________________________________________________________________________
Subject: RFI/EMI
Date: Sep 06, 2005
For flying RV10s, anybody experiencing RFI/EMI in the electric trim unshieled or Autopilot unshielded harnesses??? ________________________________________________________________________________
Date: Sep 06, 2005
Subject: Re: N325HP
Noel, What did you use for sound deadening and where all did you install it? How many pounds of it? Thanks - John #40404 -----Original Message----- From: Noel & Yoshie Simmons <noel(at)blueskyaviation.net> Subject: RV10-List: N325HP Hi all, Just a quick note that I flew N325HP last Thursday! WOW, flew hands off. Stable but when commanded to turn it turns and stays there, can?t wait to shoot and ILS. The most impressive part was the noise level in the cockpit. I had to remove one ear cup to here the engine on take off, other than that just a purr of the engine and wind flowing over the airframe. I sound deadened it and have a performance aero engine, 325 horse power and on the front of that a Catto three blade prop. Supper smooth and fast is all I can say at this time will get some real numbers in a few weeks. For those of you building keep on it is worth it Noel Simmons www.blueskyaviation.net Attached Image: DSCF3333.JPG [Image removed] ________________________________________________________________________________
Subject: N325HP
Date: Sep 06, 2005
Noel, Congrats! She's a good looking ship. Can't wait to see the numbers with that 325 and catto prop. Michael Sausen -10 #352 Tanks ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Noel & Yoshie Simmons Subject: RV10-List: N325HP Hi all, Just a quick note that I flew N325HP last Thursday! WOW, flew hands off. Stable but when commanded to turn it turns and stays there, can't wait to shoot and ILS. The most impressive part was the noise level in the cockpit. I had to remove one ear cup to here the engine on take off, other than that just a purr of the engine and wind flowing over the airframe. I sound deadened it and have a performance aero engine, 325 horse power and on the front of that a Catto three blade prop. Supper smooth and fast is all I can say at this time will get some real numbers in a few weeks. For those of you building keep on it is worth it Noel Simmons www.blueskyaviation.net <http://www.blueskyaviation.net/> ________________________________________________________________________________
Subject: N325HP
Date: Sep 06, 2005
Beautiful plane! Congratulations. 325 HP ! How did this happen? What type engine? What was the weight? John Jessen (#40328 HS) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Noel & Yoshie Simmons Subject: RV10-List: N325HP Hi all, Just a quick note that I flew N325HP last Thursday! WOW, flew hands off. Stable but when commanded to turn it turns and stays there, can't wait to shoot and ILS. The most impressive part was the noise level in the cockpit. I had to remove one ear cup to here the engine on take off, other than that just a purr of the engine and wind flowing over the airframe. I sound deadened it and have a performance aero engine, 325 horse power and on the front of that a Catto three blade prop. Supper smooth and fast is all I can say at this time will get some real numbers in a few weeks. For those of you building keep on it is worth it Noel Simmons www.blueskyaviation.net <http://www.blueskyaviation.net/> ________________________________________________________________________________
Subject: N325HP
Date: Sep 06, 2005
Did you do any airframe mods to allow mounting of more horsepower? ________________________________________________________________________________
Date: Sep 06, 2005
Dear Listers, I will be taking the Matronics Web Server down for a few hours today, Tuesday September 6 2005 for a chassis upgrade. Archive browsing and searching along with subscription services will be unavailable for be processed normally during the upgrade. Please check the Matronics System Status Page for updates (although this page resides on the web server and won't be available during the upgrade): http://www.matronics.com/SystemStatus/ Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: RFI/EMI
Date: Sep 06, 2005
At a picnic in Redmond, Or this weekend, one pilot reported extraneous hits on his L3 scope which were only attributed to possible EMI from his STec trim servos. FYI John - KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Subject: RV10-List: RFI/EMI For flying RV10s, anybody experiencing RFI/EMI in the electric trim unshieled or Autopilot unshielded harnesses??? ________________________________________________________________________________
Subject: Re: N325HP
Date: Sep 06, 2005
Congrats on a beautiful project. "Three bladed props for the 540 engines will run from $1850 up to $2350." Got that from cattoprops.com...now that definitely warrants some performance numbers! ----- Original Message ----- From: Noel & Yoshie Simmons To: rv10-list(at)matronics.com Sent: Tuesday, September 06, 2005 11:54 AM Subject: RV10-List: N325HP Hi all, Just a quick note that I flew N325HP last Thursday! WOW, flew hands off. Stable but when commanded to turn it turns and stays there, can't wait to shoot and ILS. The most impressive part was the noise level in the cockpit. I had to remove one ear cup to here the engine on take off, other than that just a purr of the engine and wind flowing over the airframe. I sound deadened it and have a performance aero engine, 325 horse power and on the front of that a Catto three blade prop. Supper smooth and fast is all I can say at this time will get some real numbers in a few weeks. For those of you building keep on it is worth it Noel Simmons www.blueskyaviation.net ________________________________________________________________________________
Subject: Flap rivetting
Date: Sep 07, 2005
G'day all, Just finishing off the flaps and installing the -319 pop rivets. I have the stanley swivel head puller from Avery, but find it won't quite fit against the hinge assemblies on the flap bottom, so the rivets do not go in straight. Any hints? I am reluctant to grind the side off my rivet puller . . . cheers, Ron ________________________________________________________________________________
Date: Sep 06, 2005
Subject: Re: Flap rivetting
That's exactly what I did. Grind flat the face of the puller head. If you don't want to do it to your nice puller, go get a cheap one from somewhere and grind that one flat. -Sean #40303 McGANN, Ron wrote: > > G'day all, > > Just finishing off the flaps and installing the -319 pop rivets. I > have the stanley swivel head puller from Avery, but find it won't > quite fit against the hinge assemblies on the flap bottom, so the > rivets do not go in straight. Any hints? I am reluctant to grind the > side off my rivet puller . . . > > cheers, > Ron > ________________________________________________________________________________ spamd2.ruraltel.net * -4.0 RCVD_FROM_NEXTECH_2 Message came from 24.225.10-29.x network * 0.0 UNPARSEABLE_RELAY Informational: message has unparseable relay * lines * 0.4 HTML_30_40 BODY: Message is 30% to 40% HTML * 0.0 HTML_MESSAGE BODY: HTML included in message * -2.6 BAYES_00 BODY: Bayesian spam probability is 0 to 1% * 0.8 AWL AWL: From: address is in the auto white-list
From: "Bill and Tami Britton" <william(at)gbta.net>
Subject: Static Wicks--need suggestions
Date: Sep 06, 2005
I purchased my tail kit from a previous builder. The Rudder/VS were done. He put a static wick on the top of the rudder. I am wondering if this is necessary. I'm to the point of construction on the elevators that I either need to install static wicks on them or I will fill the holes on the rudder and just not have wicks at all. To my knowledge, nobody has put them on any finished -10's yet, right??? If somebody has that I have overlooked, how many did you use? Is one on each control surface enough (ie. one on rudder, one on each elevator, ailerons, etc...)??? Does anybody have any remarks/comments on why I should use/not use the static wicks. From previous conversations, and from listening to people talk about todays technology in shielded cables and built in circuitry protection from static electricity, I think I may just fill the holes on the rudder and not have the wicks at all. Bill Britton ________________________________________________________________________________
Date: Sep 07, 2005
Static wicks are a black art. There is no doubt they can help with a discharge problem (insert joke here) but if you don't get them in the right place they will only add drag. The only options are to sprinkle them liberally on the airframe making sure you have bonding straps on all moveable surfaces or wait until you actually experience the problem and then deal with it. I'll opt for the second. Michael Sausen -10 #352 Tanks ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton Subject: RV10-List: Static Wicks--need suggestions I purchased my tail kit from a previous builder. The Rudder/VS were done. He put a static wick on the top of the rudder. I am wondering if this is necessary. I'm to the point of construction on the elevators that I either need to install static wicks on them or I will fill the holes on the rudder and just not have wicks at all. To my knowledge, nobody has put them on any finished -10's yet, right??? If somebody has that I have overlooked, how many did you use? Is one on each control surface enough (ie. one on rudder, one on each elevator, ailerons, etc...)??? Does anybody have any remarks/comments on why I should use/not use the static wicks. From previous conversations, and from listening to people talk about todays technology in shielded cables and built in circuitry protection from static electricity, I think I may just fill the holes on the rudder and not have the wicks at all. Bill Britton ________________________________________________________________________________
Subject: Re: Static Wicks--need suggestionsStatic Wicks--need suggestions
Date: Sep 07, 2005
Precipitation static is most commonly found in precipitation (duh) near the freezing level. P-static affects most low frequency radios, such as ADFs. However, any number of glass ships have encountered P-static so severe as to affect VHF radios and to apply strong shocks to occupants. VFR only? Probably don't need 'em. IFR? Go check out what factory built ships do, including grounding straps between control surfaces and airframe. Ed Wischmeyer elevators ________________________________________________________________________________
Date: Sep 07, 2005
I have decided to see it I have a problem and then fix it. I have had a static problem in a 182 before and I am concerned but not enough to mod the airplane without any testing. T. Rene' Felker N423CF 40322 80% wings 10% fuselage -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: Static Wicks--need suggestions Static wicks are a black art. There is no doubt they can help with a discharge problem (insert joke here) but if you don't get them in the right place they will only add drag. The only options are to sprinkle them liberally on the airframe making sure you have bonding straps on all moveable surfaces or wait until you actually experience the problem and then deal with it. I'll opt for the second. Michael Sausen -10 #352 Tanks _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton Subject: RV10-List: Static Wicks--need suggestions I purchased my tail kit from a previous builder. The Rudder/VS were done. He put a static wick on the top of the rudder. I am wondering if this is necessary. I'm to the point of construction on the elevators that I either need to install static wicks on them or I will fill the holes on the rudder and just not have wicks at all. To my knowledge, nobody has put them on any finished -10's yet, right??? If somebody has that I have overlooked, how many did you use? Is one on each control surface enough (ie. one on rudder, one on each elevator, ailerons, etc...)??? Does anybody have any remarks/comments on why I should use/not use the static wicks. From previous conversations, and from listening to people talk about todays technology in shielded cables and built in circuitry protection from static electricity, I think I may just fill the holes on the rudder and not have the wicks at all. Bill Britton ________________________________________________________________________________
Date: Sep 07, 2005
Subject: Firewall Recess Box F1001K
It seems that the F1001K recess box that attaches on to the firewall is a mirror image of what is shown on the plans. Has anyone had this same problem? Niko 40188 ________________________________________________________________________________
Subject: Static wicks
Date: Sep 07, 2005
I have installed 6/32 nutplates on the two top to stiffeners of the rudder (left side), and will also place them on the elevators, when I get to that point, for later installation of static wicks (latest Cessna type), if they turn out to be needed. EQUALLY IMPORTANT is the installation of nutplates in lieu of the rivets above the hinges on the rudder bearing doublers, that will allow for the installation of braided grounding straps on each bearing bolt, which allows for high current flows around the bearings, instead of thru them, which can cause WELDED bearings on your primary control surfaces! Chris Hukill starting the elevator ________________________________________________________________________________
Date: Sep 07, 2005
Look on Tim's website. Static wick manufacturer's (Dayton Granger) recommendation for the RV-10 airframe has been posted there. No need to wonder or flounder... John Kirkland #40333 ________________________________________________________________________________
Date: Sep 07, 2005
These locations are untested and again don't mean anything unless you can actually map your airframe resistance and the most likely locations for build up and a path for discharge (not likely). Putting them on in those locations in the diagram may or may not help. Not trying to tell people to not do it but I do want them to understand that it may not do squat and the chance of the wicks contributing to control surface flutter is increased. It's one of those things where if you put them on and don't ever have P static problems they must be working. Good work, you got that pink elephant. P-static does exist and it may cause problems but putting static wicks on without any type of testing against your airframe may or may not help. Also, the likeliness of a static arc welding a bearing is extreeemly remote and would take a jolt on the order of a lightning bolt. The main job of bonding straps is to get the charge over to the wicks. This subject was broached back on the old Yahoo list and Paul Besing pinged Bob Knuckolls on the subject, here was his response: Static wicks have nothing to do with radio quality or reliability. EVERY time dissimilar materials slide across each other, there is a tendency for one material with a stronger affinity for electrons than the other to acquire a negative charge. Common manifestations include sparks that jump between fingertip and doorknob after walking across carpet. In the winter especially, I have to remind myself to keep part of my body touching the frame of my 1" vertical belt stander while sculpting a piece of metal . . . the Van DeGraff like nature of the belt sander will charge the ol' bod with a significant kick if I don't bleed it off during the sanding operations. Precipitation static is unique to airborne particles sliding past any conductor. Radio receivers can be severely affected by dust storms usually associated with high winds. I used to work with an amateur radio repeater installation 1200 feet up on KTVH-TV in Hutchinson, KS. A blowing snow storm would severely de-sense our receivers. Airplanes have unique problems in that they generate their own wind. Airplanes flying through dust, rain or snow can pick up significant charges. When the charge reaches sufficient magnitude, it begins to form coronas at the sharp (usually trailing edges) of wings and flight control surfaces. The static wick is a sharp-ended conductor (enhances tendency for charge to concentrate and form corona) connected to the airframe through some nominal but rather high resistance. The idea is to put sufficient static wicks in the right places so that they force lots of small, low current discharges to form and dissipate the energy at much lower (read less noisy) levels than if the wicks were not present. The faster the airplane flies, the more likely it is to experience the effects of p-static. Further, the finish and skin materials have an influence on tendency to build and concentrate static charges. These effects are present and potentially troublesome irrespective of the vintage of radios carried aboard the airplane. VHF radios are less susceptible than HF or ADF receivers. Grounded antennas are quieter than isolated antennas. There are some modern digital signal processing techniques that can reduce the audible effects of p-static but ultimately, locally generated static noises will overwhelm a receiver looking for weaker signals. The number, style and placement of static wicks on our bizjets is as much an art as a science. We spent a great deal of $time$ selecting the right products and installations. Further, there's a comprehensive incoming inspection of static wicks . . . seems that a performance of a static wick is very sensitive to production variability. If your airplane suffers from the effects of p-static, it may take a lot of effort over a long period of time to deduce the optimum solution. Bob . . . Michael Sausen -10 #352 Tanks -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Kirkland Subject: RV10-List: Re: Static Wicks --> Look on Tim's website. Static wick manufacturer's (Dayton Granger) recommendation for the RV-10 airframe has been posted there. No need to wonder or flounder... John Kirkland #40333 ________________________________________________________________________________
Date: Sep 07, 2005
Do you have the numbers of said stiffeners. I'm not quite getting the picture in my limited brain. Actually, any pictures? John Jessen (#40382 HS) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Subject: RV10-List: Static wicks I have installed 6/32 nutplates on the two top to stiffeners of the rudder (left side), and will also place them on the elevators, when I get to that point, for later installation of static wicks (latest Cessna type), if they turn out to be needed. EQUALLY IMPORTANT is the installation of nutplates in lieu of the rivets above the hinges on the rudder bearing doublers, that will allow for the installation of braided grounding straps on each bearing bolt, which allows for high current flows around the bearings, instead of thru them, which can cause WELDED bearings on your primary control surfaces! Chris Hukill starting the elevator ________________________________________________________________________________
Subject: Re: Firewall Recess Box F1001K
Date: Sep 07, 2005
I don't know about yours, but I almost did the same thing until I realized I was looking at the firewall backwards. I initially thought the flanges should point rearward on the fuse (my natural tendency), but the flanges go forward and the recess sticks out in the opposite direction. Aaron -- Aaron Sims RV-10 #40036 (Firewall) http://canopyroad.org/rv10/ n217gt(at)gmail.com On Sep 7, 2005, at 9:36 AM, Nikolaos Napoli wrote: > It seems that the F1001K recess box that attaches on to the > firewall is a mirror image of what is shown on the plans. Has > anyone had this same problem? > > Niko > 40188 ________________________________________________________________________________
Date: Sep 07, 2005
Thanks for the reply Aaron. I am looking at it the same way you are. Firewall flanges forward and the box is extending aft of the firewall. The only way for me to fit it is for the box to extend forward of the firewall. Because of the nut plate holes on the top edge of the box there is really only one way for it to fit on the Firewall. If I align the holes it sticks out in the same direction as the firewall flanges. Niko Aaron Sims wrote: I don't know about yours, but I almost did the same thing until I realized I was looking at the firewall backwards. I initially thought the flanges should point rearward on the fuse (my natural tendency), but the flanges go forward and the recess sticks out in the opposite direction. Aaron -- Aaron Sims RV-10 #40036 (Firewall) http://canopyroad.org/rv10/ n217gt(at)gmail.com On Sep 7, 2005, at 9:36 AM, Nikolaos Napoli wrote: It seems that the F1001K recess box that attaches on to the firewall is a mirror image of what is shown on the plans. Has anyone had this same problem? Niko 40188 ________________________________________________________________________________
Date: Sep 07, 2005
I just talked to Vans about this. Apparently some of these parts were folded the wrong way. They did try to pull them out of the kits but some of them got out. So if anyone else has the same problem they can give Vans a call. Niko Nikolaos Napoli wrote: It seems that the F1001K recess box that attaches on to the firewall is a mirror image of what is shown on the plans. Has anyone had this same problem? Niko 40188 ________________________________________________________________________________
Date: Sep 07, 2005
THe link John is mentioning is this one: http://www.myrv10.com/tips/staticwicks/staticwicks.html I plan to put them on mine, although I haven't started yet and need to really soon. You can see by the photo on the page that it looks like this did some burning on the tail, and probably across the bearings. Tim Tim Olson -- RV-10 #40170 John Kirkland wrote: > > Look on Tim's website. Static wick manufacturer's (Dayton Granger) > recommendation for the RV-10 airframe has been posted there. No need to > wonder or flounder... > John Kirkland > #40333 ________________________________________________________________________________
Date: Sep 07, 2005
Here's a couple pics of Randy's that may help you... <http://www.myrv10.com/N610RV/20040927/DSCN1956.html> <http://www.myrv10.com/N610RV/20041009/DSCN1958.html> -Sean #40303 Nikolaos Napoli wrote: > Thanks for the reply Aaron. > > I am looking at it the same way you are. Firewall flanges forward and > the box is extending aft of the firewall. The only way for me to fit > it is for the box to extend forward of the firewall. Because of the > nut plate holes on the top edge of the box there is really only one > way for it to fit on the Firewall. If I align the holes it sticks out > in the same direction as the firewall flanges. > > > Niko > > */Aaron Sims /* wrote: > > I don't know about yours, but I almost did the same thing until I > realized I was looking at the firewall backwards. I initially > thought the flanges should point rearward on the fuse (my natural > tendency), but the flanges go forward and the recess sticks out in > the opposite direction. > > Aaron > -- > Aaron Sims > RV-10 #40036 (Firewall) > http://canopyroad.org/rv10/ > n217gt(at)gmail.com > > > On Sep 7, 2005, at 9:36 AM, Nikolaos Napoli wrote: > >> It seems that the F1001K recess box that attaches on to the >> firewall is a mirror image of what is shown on the plans. Has >> anyone had this same problem? >> >> Niko >> 40188 > ________________________________________________________________________________
Date: Sep 07, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Just remember that static wicks don't really have much to do with lightning protection. When a big a-- bolt of lightning comes through, a little bit of carbon and plastic is not going to affect its progress. Hopefully your EFIS, etc is lightning hardened and tested . . . TDT 40025 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Tim Olson Subject: Re: RV10-List: Re: Static Wicks THe link John is mentioning is this one: http://www.myrv10.com/tips/staticwicks/staticwicks.html I plan to put them on mine, although I haven't started yet and need to really soon. You can see by the photo on the page that it looks like this did some burning on the tail, and probably across the bearings. Tim Tim Olson -- RV-10 #40170 John Kirkland wrote: > > Look on Tim's website. Static wick manufacturer's (Dayton Granger) > recommendation for the RV-10 airframe has been posted there. No need to > wonder or flounder... > John Kirkland > #40333 ________________________________________________________________________________
Date: Sep 07, 2005
Just did that part this weekend, No problems at all. And you thought drilling the aileron counterweights was fun, wait until you get to the three 5/8" holes in that recess box on stainless steel! I backed up mine against some hard wood to support it. It is as appears on the plans. Jim Combs #40192 N312F ---------- Original Message ---------------------------------- From: Nikolaos Napoli <owl40188(at)yahoo.com> Date: Wed, 7 Sep 2005 06:36:53 -0700 (PDT) It seems that the F1001K recess box that attaches on to the firewall is a mirror image of what is shown on the plans. Has anyone had this same problem? Niko 40188 ________________________________________________________________________________
Date: Sep 07, 2005
I bought one for $5 from Harbor Freight and ground the heck out of it for use in tight spaces. Know what? It works better and with less effort than the $35 one I got from Avery. PJ 40032 Sean Stephens wrote: > > That's exactly what I did. Grind flat the face of the puller head. > If you don't want to do it to your nice puller, go get a cheap one > from somewhere and grind that one flat. > > -Sean #40303 > > McGANN, Ron wrote: > >> >> G'day all, >> >> Just finishing off the flaps and installing the -319 pop rivets. I >> have the stanley swivel head puller from Avery, but find it won't >> quite fit against the hinge assemblies on the flap bottom, so the >> rivets do not go in straight. Any hints? I am reluctant to grind >> the side off my rivet puller . . . >> cheers, >> Ron >> > > ________________________________________________________________________________
Date: Sep 07, 2005
I have an cheap Arrow tool that is very thin and works in tight spaces. I broke down and bought a pneumatic gun once I started the cabin floors. I purchased mine at Home Depot http://www.jensentools.com/product/group.asp?parent_id=419602 Bobby Hughes 40116 Fus\ Engine -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PJ Seipel Subject: Re: RV10-List: Flap rivetting I bought one for $5 from Harbor Freight and ground the heck out of it for use in tight spaces. Know what? It works better and with less effort than the $35 one I got from Avery. PJ 40032 Sean Stephens wrote: > > That's exactly what I did. Grind flat the face of the puller head. > If you don't want to do it to your nice puller, go get a cheap one > from somewhere and grind that one flat. > > -Sean #40303 > > McGANN, Ron wrote: > >> >> G'day all, >> >> Just finishing off the flaps and installing the -319 pop rivets. I >> have the stanley swivel head puller from Avery, but find it won't >> quite fit against the hinge assemblies on the flap bottom, so the >> rivets do not go in straight. Any hints? I am reluctant to grind >> the side off my rivet puller . . . >> cheers, >> Ron >> > > ________________________________________________________________________________
Date: Sep 08, 2005
I took this advice from Sean Stephens' and splurged about US$5 on a cheapie from the local hardware store. Ground it down and it pulled the rivets beautifully. Pulled most of the bottom rivets on the left flap and noticed the heads came out a little domed. Checked the rivet insert and found that it was for cup head rivets. Doh !! Ground the insert flat and the rest came out fine. Geez it's hard to remember to double check everything! Ron #187 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of PJ Seipel Subject: Re: RV10-List: Flap rivetting I bought one for $5 from Harbor Freight and ground the heck out of it for use in tight spaces. Know what? It works better and with less effort than the $35 one I got from Avery. PJ 40032 Sean Stephens wrote: > > That's exactly what I did. Grind flat the face of the puller head. > If you don't want to do it to your nice puller, go get a cheap one > from somewhere and grind that one flat. > > -Sean #40303 > > McGANN, Ron wrote: > >> >> G'day all, >> >> Just finishing off the flaps and installing the -319 pop rivets. I >> have the stanley swivel head puller from Avery, but find it won't >> quite fit against the hinge assemblies on the flap bottom, so the >> rivets do not go in straight. Any hints? I am reluctant to grind >> the side off my rivet puller . . . >> cheers, >> Ron >> > > ________________________________________________________________________________
Subject: Flap trailing edge
Date: Sep 08, 2005
G'day all, Planning the assembly of the flap trailing edges. I have used the angle iron back rivet method (with Proseal)on the rudder, elevators and ailerons with great success. But the flaps are much longer and exceed the length of my angle iron setup. Has any one uncovered any gotchas or experienced any straightness issues with the flap TEs? I note that the plans call for setting the TE before the bottom rivets are pulled. Is there any reason for this? Thanks in advance Ron ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: fiberglass
Date: Sep 07, 2005
What size (width) fiberglass cloth did you get for the fairing buildup? What size would you recommend? Rob ________________________________________________________________________________
Date: Sep 07, 2005
Subject: Re: fiberglass
Windshield Fairing? I just did a write up of the stuff here: http://www.myrv10.com/N104CD/fuselage/20050821/index.html I think it was maybe 4" width....remember that it's E-Glass you want. The part number is listed....thanks to Scott Schmidt. Don't forget the rotary cutting tool. It's PERFECT for this job. Tim Olson -- RV-10 #40170 Robert G. Wright wrote: > What size (width) fiberglass cloth did you get for the fairing buildup? > What size would you recommend? > > > > Rob > ________________________________________________________________________________
From: "Chris , Susie McGough" <VHMUM(at)bigpond.com>
Subject: Re: Flap trailing edge
Date: Sep 08, 2005
Flap trailing edgeWhile on our trip in the states I was lucky enough to work with Ken K (engineer at Vans) and we built a Aileron and he showed me how to do trailing edge...no proseal glue or anything. He did it and perfectly straight. So I used a large angle iron which you rest trailing edge on...put a weight on each end and start anywhere you like and just back rivet.No proseal. I did the elevators and rudder this way...dead straight and no messy proseal or that extra weight. No discussion needed took about 4 minutes each elevator!! Done no dramas!! Chris RV6 Sold RV10 cone ----- Original Message ----- From: McGANN, Ron To: rv10-list(at)matronics.com Sent: Thursday, September 08, 2005 10:31 AM Subject: RV10-List: Flap trailing edge G'day all, Planning the assembly of the flap trailing edges. I have used the angle iron back rivet method (with Proseal)on the rudder, elevators and ailerons with great success. But the flaps are much longer and exceed the length of my angle iron setup. Has any one uncovered any gotchas or experienced any straightness issues with the flap TEs? I note that the plans call for setting the TE before the bottom rivets are pulled. Is there any reason for this? Thanks in advance Ron ________________________________________________________________________________
Date: Sep 08, 2005
Nope, not spending nearly enough time on the -10. Writing articles, physical therapy, taking a few classes, and looking for a new job. (resume is on line). However, the stabilizer *is* finished. Elevator is almost ready to rivet. Ed ________________________________________________________________________________
Date: Sep 08, 2005
Subject: Props
For those who might be interested in having a custom built prop, I'm having a 3 bladed c/s prop built by Johnny Downs of Millennium Propellers in Lancaster, TX., tel 469-231-6225, for considerably cheaper than either Hartzel, McCaulley or MT. I am not soliciting for Johnny, but he has been in the prop business for years. He has an FAA action pending, but you need to talk to him about it. Cheers - John #40404 ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Props
What is CONSIDERABLY cheaper? $2000, $3000? What is CONSIDERABLY cheaper? $2000, $3000? ________________________________________________________________________________
Date: Sep 08, 2005
Subject: Re: Props
I suggest that you contact Mr. Downs for a quote for you. Let's just say that compared to what the 3 manufactures quoted me at Osh for their new ones, I could probably buy 2 of his. He makes his experimental props with either new or overhauled Hartzel components. Mine will be a 6 year or 2,000 hr hub. In a message dated 9/8/2005 10:27:52 PM Central Standard Time, ddddsp1(at)juno.com writes: What is CONSIDERABLY cheaper? $2000, $3000? ________________________________________________________________________________
Date: Sep 08, 2005
Subject: Re: Props
I can't seem to find any contact info on the web for a Mr. Downs that does propellers. Can you point us in the right direction? Thanks, Sean #40303 GenGrumpy(at)aol.com wrote: > I suggest that you contact Mr. Downs for a quote for you. Let's just > say that compared to what the 3 manufactures quoted me at Osh for > their new ones, I could probably buy 2 of his. > > He makes his experimental props with either new or overhauled Hartzel > components. > > Mine will be a 6 year or 2,000 hr hub. > > In a message dated 9/8/2005 10:27:52 PM Central Standard Time, > ddddsp1(at)juno.com writes: > > What is CONSIDERABLY cheaper? $2000, $3000? > ________________________________________________________________________________
Subject: Re: Props
Date: Sep 08, 2005
IIRC Van's price for a new prop is about $5500. Each of us will have at least 100K in the 10 when finished. I am having difficulty understanding the desire to buy a prop that has an unknown history. I read the accident reports for experimentals and a very significant percentage of the accidents are not related to the airframe/construction but propulsion. alternative engines/alternative props and unapproved engine/prop combination. My only request is please don't increase the insurance rates for the rest of us. ----- Original Message ----- From: "Sean Stephens" <schmoboy(at)cox.net> Subject: Re: RV10-List: Props > > I can't seem to find any contact info on the web for a Mr. Downs that does > propellers. > > Can you point us in the right direction? > > Thanks, > > Sean #40303 > > GenGrumpy(at)aol.com wrote: >> I suggest that you contact Mr. Downs for a quote for you. Let's just say >> that compared to what the 3 manufactures quoted me at Osh for their new >> ones, I could probably buy 2 of his. >> He makes his experimental props with either new or overhauled Hartzel >> components. >> Mine will be a 6 year or 2,000 hr hub. In a message dated 9/8/2005 >> 10:27:52 PM Central Standard Time, ddddsp1(at)juno.com writes: >> >> What is CONSIDERABLY cheaper? $2000, $3000? > > > ________________________________________________________________________________
Subject: Hugo Rv10
Date: Sep 09, 2005
I'm ready to close the VS ,it is any provision for a red rotating (LED)beacon in the RV10 tail,I identified the white in the lower part of the rudder,any body install traditional VOR antennas at the top of the VS? Hugo I;m working a three blocks from the wicks manufacturer at Ft >Lauderdale,Today I will made a cortesy visit(may be I can purchase direct) ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Hugo Rv10
Hugo, Check the archives; I asked this question once and was laughed into oblivion! Seriously though, there is none. The white strobe is your anticollision lighting (instead of the beacon). -Jim 40384 gommone7(at)bellsouth.net wrote: > >I'm ready to close the VS ,it is any provision for a red rotating (LED)beacon in the RV10 tail,I identified the white in the lower part of the rudder,any body install traditional VOR antennas at the top of the VS? >Hugo >I;m working a three blocks from the wicks manufacturer at Ft >Lauderdale,Today I will made a cortesy visit(may be I can purchase direct) > > > > > > > > > ________________________________________________________________________________ spamd3.ruraltel.net * -4.0 RCVD_FROM_NEXTECH_5 Message came from 204.96.144-152.x network * 0.0 UNPARSEABLE_RELAY Informational: message has unparseable relay * lines * -2.6 BAYES_00 BODY: Bayesian spam probability is 0 to 1% * 0.9 AWL AWL: From: address is in the auto white-list
Date: Sep 09, 2005
I have a cats whisker vor/loc/gs antenna mounted on top of my VS. Bill Britton ----- Original Message ----- From: <gommone7(at)bellsouth.net> Subject: RV10-List: Hugo Rv10 > > I'm ready to close the VS ,it is any provision for a red rotating (LED)beacon in the RV10 tail,I identified the white in the lower part of the rudder,any body install traditional VOR antennas at the top of the VS? > Hugo > I;m working a three blocks from the wicks manufacturer at Ft >Lauderdale,Today I will made a cortesy visit(may be I can purchase direct) > > ________________________________________________________________________________ spamd1.ruraltel.net * -4.0 RCVD_FROM_NEXTECH_5 Message came from 204.96.144-152.x network * 0.0 UNPARSEABLE_RELAY Informational: message has unparseable relay * lines * 0.5 HTML_40_50 BODY: Message is 40% to 50% HTML * 0.0 HTML_MESSAGE BODY: HTML included in message * -2.6 BAYES_00 BODY: Bayesian spam probability is 0 to 1% * 0.6 AWL AWL: From: address is in the auto white-list
Subject: Bonding Straps
Date: Sep 09, 2005
Amid all the conversation going on about the static wicks and bonding straps, I realized I forgot to put the nutplates on the hinges of the HS to attach the bonding straps to. Now, it's riveted. Does anybody see any reason I couldn't drill them out now and just use blind rivets to hold the nutplates in place??? A couple obvious problems would be metal shavings between the hinge and rear spar from drilling, and deburring. I have the #30 and #40 cogsdill tools so deburring the small holes would be no problem. As for the larger hole, I could probably use a small file on it. I know it's not as good as doing it right the first time but I guess I was just in too big of a hurry to get my first piece completed. Anybody see any bigger problems I may be overlooking??? Bill Britton RV-10 Elevators PS Sorry for dragging this whole static wick/bonding strap thing out further. ________________________________________________________________________________
Date: Sep 09, 2005
You could use a click bond nutplate and thus only have to deal with one hole. A little pricy, but easy to install. T. Rene' Felker 40322 N423CF -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton Subject: RV10-List: Bonding Straps Amid all the conversation going on about the static wicks and bonding straps, I realized I forgot to put the nutplates on the hinges of the HS to attach the bonding straps to. Now, it's riveted. Does anybody see any reason I couldn't drill them out now and just use blind rivets to hold the nutplates in place??? A couple obvious problems would be metal shavings between the hinge and rear spar from drilling, and deburring. I have the #30 and #40 cogsdill tools so deburring the small holes would be no problem. As for the larger hole, I could probably use a small file on it. I know it's not as good as doing it right the first time but I guess I was just in too big of a hurry to get my first piece completed. Anybody see any bigger problems I may be overlooking??? Bill Britton RV-10 Elevators PS Sorry for dragging this whole static wick/bonding strap thing out further. ________________________________________________________________________________
Subject: Re: Props
Date: Sep 09, 2005
Here's the FAA link http://www.faa.gov/aircraft/safety/programs/sups/upn/media/UPN%202004-00041.pdf Sounds like he's in a bit of trouble..... -Brian Iowa City, IA ----- Original Message ----- From: GenGrumpy(at)aol.com To: rv10-list(at)matronics.com Sent: Thursday, September 08, 2005 9:06 PM Subject: RV10-List: Props For those who might be interested in having a custom built prop, I'm having a 3 bladed c/s prop built by Johnny Downs of Millennium Propellers in Lancaster, TX., tel 469-231-6225, for considerably cheaper than either Hartzel, McCaulley or MT. I am not soliciting for Johnny, but he has been in the prop business for years. He has an FAA action pending, but you need to talk to him about it. Cheers - John #40404 ________________________________________________________________________________
Subject: Props
Date: Sep 09, 2005
Here is the action pending on that prop shop down south, FYI -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Sponcil Subject: Re: RV10-List: Props Here's the FAA link http://www.faa.gov/aircraft/safety/programs/sups/upn/media/UPN%202004-00 041.pdf Sounds like he's in a bit of trouble..... -Brian Iowa City, IA ----- Original Message ----- From: GenGrumpy(at)aol.com To: rv10-list(at)matronics.com Sent: Thursday, September 08, 2005 9:06 PM Subject: RV10-List: Props I'm having a 3 bladed c/s prop built by Johnny Downs of Millennium Propellers in Lancaster, TX., tel 469-231-6225, for considerably cheaper than either Hartzel, McCaulley or MT. I am not soliciting for Johnny, but he has been in the prop business for years. He has an FAA action pending, but you need to talk to him about it. Cheers - John #40404 ________________________________________________________________________________
Subject: static wicks
Date: Sep 09, 2005
Bill I used 6/32 nuplates on R101G-L and R1010F-L stiffeners. They are mounted with 1 1/8 inch spacing and the aft nutplate is 2 1/4 inches from the trailing edge. This allows me to use some older Cessna type static wicks that I had on hand, but is also the same spacing that the newer Cessna wicks use. They don't screw in, rather the base is mounted to the control surface as a single piece. The bonding straps are attached to the rudder using the hole that the plans calls for a rivet in the upper hole on the R608PP and R607PP doublers. The lower bearing strap attaches to the bottom hole in the rudder spar. This allows for a strap that goes under the bolt head of the bearing pivot bolt, and attaches to the rudder at those points, to the nutplates that where installed in the holes. I will do this on all primary control surfaces. If your rudder is already closed up, it would be acceptable to pop rivet the straps to the control surface, as many production airplane manufacturers have done. I will have to do this on my ailerons, as they are quickbuild, and closed up. Irregardless of what some posters may think, it is very important to have these straps, as close to the bearings as possible, to help protect those bearings from not only welding tight, but also from electrolic corrosion produced from years of service, flying in clouds. At least that was what I was taught 25 years ago while attending A&P school. Maybe things have changed since then? Chris Hukill Starting RV-10 HS Flying RV-8 ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Bonding Straps
Bill, I have some larger size used Burraway bits I will sell at a reasonable cost. If you are interested e-mail me off list. Steve 40212 --- Bill and Tami Britton wrote: > Amid all the conversation going on about the static > wicks and bonding straps, I realized I forgot to put > the nutplates on the hinges of the HS to attach the > bonding straps to. Now, it's riveted. Does anybody > see any reason I couldn't drill them out now and > just use blind rivets to hold the nutplates in > place??? A couple obvious problems would be metal > shavings between the hinge and rear spar from > drilling, and deburring. I have the #30 and #40 > cogsdill tools so deburring the small holes would be > no problem. As for the larger hole, I could > probably use a small file on it. > > I know it's not as good as doing it right the first > time but I guess I was just in too big of a hurry to > get my first piece completed. > > Anybody see any bigger problems I may be > overlooking??? > > Bill Britton > RV-10 Elevators > > PS Sorry for dragging this whole static wick/bonding > strap thing out further. > ________________________________________________________________________________
Subject: Door Safety Straps
Date: Sep 09, 2005
Has anybody heard of someone making safety straps for the RV-10 doors? We recently heard that a Lancair had a door come open on takeoff and if it hadn't been for their safety device the door would have flown open and who knows what other damage would have been caused. Has anybody even though about this option? Thanks for any help you can offer. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Door Safety Straps
Jesse, I recently saw a baggage door on a certified aircraft that was hinged at the bottom. The good thing about that was when it was open, it was always out of the way during loading / unloading operations. The downside was that if it opened in flight, depending on airplane flight configuration, it was going to slam all the way open or stay "almost" closed due to the direction of the airstream. Now the -10 door is hinged at the front and regardless of the airplane flight configuration, should be held almost closed. Loading and unloading are a little bit of a pain because the door is free to swing (I have not seen anyone put a gas strut on one yet!). My take is the door hinge is ok where it's at and the use of a safety strap is not needed. I would like to see a gas strut to hold the door open (or some other method). However, given that I am not flying just yet, my opinion may change after flying. Others who are in the air already can give us the real story. Later, Jim C #40192 - N312F (Fuselage) ________________________________________________________________________________
Date: Sep 09, 2005
Hrm, since they are attached with adhesive, doesn't that mean that they wont make a good electrical connection for the bonding straps? Someone else suggested putting the strap on the bolt that goes through the hinge and the bracket, but if I'm interpreting this correctly it seems like that would force the current flow through the bearing which is what we are trying to avoid... Or did he mean to fasten it underneath the bolt that has the bearing on one end and goes through the spar at the spar side? If one was to retrofit the nutplates with blind rivets, how will you get the nutplate behind the spar? I think I can do that on the HS through the lightening holes but it looks like it wouldn't be possilbe on the completed VS/rudder. Rene Felker wrote: > You could use a click bond nutplate and thus only have to deal with > one hole. A little pricy, but easy to install. > > > > T. Rene' Felker > > 40322 > > N423CF > > > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bill and > Tami Britton > *Sent:* Friday, September 09, 2005 7:15 AM > *To:* RV10-list(at)matronics.com > *Subject:* RV10-List: Bonding Straps > > > > Amid all the conversation going on about the static wicks and bonding > straps, I realized I forgot to put the nutplates on the hinges of the > HS to attach the bonding straps to. Now, it's riveted. Does anybody > see any reason I couldn't drill them out now and just use blind rivets > to hold the nutplates in place??? A couple obvious problems would be > metal shavings between the hinge and rear spar from drilling, and > deburring. I have the #30 and #40 cogsdill tools so deburring the > small holes would be no problem. As for the larger hole, I could > probably use a small file on it. > > > > I know it's not as good as doing it right the first time but I guess I > was just in too big of a hurry to get my first piece completed. > > > > Anybody see any bigger problems I may be overlooking??? > > > > Bill Britton > > RV-10 Elevators > > > > PS Sorry for dragging this whole static wick/bonding strap thing out > further. > ________________________________________________________________________________
Date: Sep 09, 2005
As far as the adhesive is concerned, you would have to make a contact area on the bolt side and not depend on the nutplate providing the current path. I would think you would want to do that anyway. Rene 40322 N423CF -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: Re: RV10-List: Bonding Straps Hrm, since they are attached with adhesive, doesn't that mean that they wont make a good electrical connection for the bonding straps? Someone else suggested putting the strap on the bolt that goes through the hinge and the bracket, but if I'm interpreting this correctly it seems like that would force the current flow through the bearing which is what we are trying to avoid... Or did he mean to fasten it underneath the bolt that has the bearing on one end and goes through the spar at the spar side? If one was to retrofit the nutplates with blind rivets, how will you get the nutplate behind the spar? I think I can do that on the HS through the lightening holes but it looks like it wouldn't be possilbe on the completed VS/rudder. Rene Felker wrote: > You could use a click bond nutplate and thus only have to deal with > one hole. A little pricy, but easy to install. > > > > T. Rene' Felker > > 40322 > > N423CF > > > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bill and > Tami Britton > *Sent:* Friday, September 09, 2005 7:15 AM > *To:* RV10-list(at)matronics.com > *Subject:* RV10-List: Bonding Straps > > > > Amid all the conversation going on about the static wicks and bonding > straps, I realized I forgot to put the nutplates on the hinges of the > HS to attach the bonding straps to. Now, it's riveted. Does anybody > see any reason I couldn't drill them out now and just use blind rivets > to hold the nutplates in place??? A couple obvious problems would be > metal shavings between the hinge and rear spar from drilling, and > deburring. I have the #30 and #40 cogsdill tools so deburring the > small holes would be no problem. As for the larger hole, I could > probably use a small file on it. > > > > I know it's not as good as doing it right the first time but I guess I > was just in too big of a hurry to get my first piece completed. > > > > Anybody see any bigger problems I may be overlooking??? > > > > Bill Britton > > RV-10 Elevators > > > > PS Sorry for dragging this whole static wick/bonding strap thing out > further. > ________________________________________________________________________________
Date: Sep 09, 2005
I thought about putting in either a snap on strap, or Velcro, you have to be careful that it will be a breakaway type item in case of a crash or fire. I thought a properly placed Velcro strip would be enough to hold it shut just in case but not long enough to cause egress problems, but it would be a fine line... Dan _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RV10-List: Door Safety Straps Has anybody heard of someone making safety straps for the RV-10 doors? We recently heard that a Lancair had a door come open on takeoff and if it hadn't been for their safety device the door would have flown open and who knows what other damage would have been caused. Has anybody even though about this option? Thanks for any help you can offer. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Props
Again. I suggest that you contact Mr Downs for the "rest of the story" as the saying goes. I am more than happy having him build me a prop. cheers - grumpy ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Millennium Props
For those who want to contact my prop maker, it is Johnny Downs of Millennium Propellers in Lancaster, TX., tel 469-231-6225. He can tell you the "rest of the story" on the FAA action. grumpy - 40404 In a message dated 9/8/2005 10:52:24 PM Central Standard Time, schmoboy(at)cox.net writes: I can't seem to find any contact info on the web for a Mr. Downs that does propellers. Can you point us in the right direction? Thanks, Sean #40303 ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Trim Tab Bend
All, I am working on the elevator trim tabs and have come to the point of bending the skin 15 degrees (Page 9-17 step 2). How did you get this thing bent? I can't figure out what I can get in there to hold the small portion of skin flat against the workbench to get it bent over. Now that the end tabs are bent over, they hit against any piece of wood that I try to put there. Any suggestions would be helpful. Thanks. --Shawn 40366 ________________________________________________________________________________
Date: Sep 10, 2005
Use your seamers, and get it close, this bend is to make sure it clears the bottom of the elevator, do several test fits, and make sure it is far enough _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Shawn Moon Subject: RV10-List: Trim Tab Bend All, I am working on the elevator trim tabs and have come to the point of bending the skin 15 degrees (Page 9-17 step 2). How did you get this thing bent? I can't figure out what I can get in there to hold the small portion of skin flat against the workbench to get it bent over. Now that the end tabs are bent over, they hit against any piece of wood that I try to put there. Any suggestions would be helpful. Thanks. --Shawn 40366 ________________________________________________________________________________
Date: Sep 10, 2005
HI,GUYS,Hugo here .If any body will like to test an strap of rubber coated fabric(I'm a Inflatables boat builder)the Hypalon fabric is very tough ,very soft,no way will broke if the dor open,when glued together the comercial style it is not way of brake it.if somebody will experiment I will be happy to sen pieces(free),the only problem is the glue ,cannot be shipp by air,eventually I will made some parts in the way I intend to do for me and shipp together,let me know Hugo > > From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com> > Date: 2005/09/09 Fri PM 08:43:38 EDT > To: > Subject: RE: RV10-List: Door Safety Straps > > I thought about putting in either a snap on strap, or Velcro, you have > to be careful that it will be a breakaway type item in case of a crash > or fire. I thought a properly placed Velcro strip would be enough to > hold it shut just in case but not long enough to cause egress problems, > but it would be a fine line... > Dan > > _____ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint > Sent: Friday, September 09, 2005 4:37 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Door Safety Straps > > > > Has anybody heard of someone making safety straps for the RV-10 doors? > We recently heard that a Lancair had a door come open on takeoff and if > it hadn't been for their safety device the door would have flown open > and who knows what other damage would have been caused. Has anybody > even though about this option? > > > > Thanks for any help you can offer. > > > > Jesse Saint > > I-TEC, Inc. > > jesse(at)itecusa.org > > www.itecusa.org <http://www.itecusa.org/> > > W: 352-465-4545 > > C: 352-427-0285 > > F: 815-377-3694 > > > > > ________________________________________________________________________________
Date: Sep 10, 2005
Subject: Re: Trim Tab Bend
Shawn, I took a piece of 2X6 cut to the length of the trim tab minus 1/8" for clearance. Then I ran it through my table saw (use the thinnest cutting blade you can find) making a slot the depth of the bent flange about one inch from the edge. Then trim the 2X6 off from the slot on an angle outward for clearance so when you slip the flange into the slot and bend the whole flange at once you have clearance. I thought a picture would describe it easier so I dug the board out of the scrap wood stack, it's a little beat up but you get the idea. Steve 40212 --- Shawn Moon wrote: > All, > I am working on the elevator trim tabs and have > come to the point of bending the skin 15 degrees > (Page 9-17 step 2). How did you get this thing > bent? I can't figure out what I can get in there to > hold the small portion of skin flat against the > workbench to get it bent over. Now that the end > tabs are bent over, they hit against any piece of > wood that I try to put there. Any suggestions would > be helpful. Thanks. > > --Shawn > 40366 > > __________________________________________________ > protection around Click here to donate to the Hurricane Katrina relief effort. http://store.yahoo.com/redcross-donate3/ ________________________________________________________________________________
Subject: Gear elastomers
Date: Sep 10, 2005
Can anyone tell me how you installed the nose gear rubber donuts? I am having a heck of the time squeezing them to install the top bolt. I even use a clamp and some wood blocking but cannot squeeze them enough before the clamp bend and wants to give. I am using one aluminum washer under the top collar. This part is not identified but is the only part that fits under it. Thanks. Ro. ________________________________________________________________________________
Date: Sep 10, 2005
As mentioned you can use the seamers. I built my trim tabs twice. On my first set I used the seamer and ended up with a 15 degree bend that was wavy as hell and my little end tabs came out very badly. If you use the seamer be careful and go slowly or it'll make a mess. When I built my second set I cut them apart along the trailing edge and riveted the trailing edge with AEX wedge just like all the other control surfaces on the plane. One of the big advantages of doing it that way is that I could do the little end rib bends and the 15 degree bend with ease because I didn't have to deal with the rest of the tab being in the way. Came out much better, and I'm disappointed that Van's didn't just have us do it this way to begin with. PJ 40032 Shawn Moon wrote: > All, > I am working on the elevator trim tabs and have come to the point of > bending the skin 15 degrees (Page 9-17 step 2). How did you get this > thing bent? I can't figure out what I can get in there to hold the > small portion of skin flat against the workbench to get it bent over. > Now that the end tabs are bent over, they hit against any piece of > wood that I try to put there. Any suggestions would be helpful. Thanks. > > --Shawn > 40366 > > __________________________________________________ > ________________________________________________________________________________
Subject: Re: Gear elastomers
Date: Sep 10, 2005
Hi Rob: I had the same problem until i figured out that the powder coating was up to far on the (rod ) cant' remember the part number at home ! take it off about an inch or so and it will go right thru that hole , and then you can insert the bolt . The tolerances are real close . Brian Bollaert #40200 ----- Original Message ----- From: "Rob Kermanj" <rv10es(at)earthlink.net> Subject: RV10-List: Gear elastomers > > Can anyone tell me how you installed the nose gear rubber donuts? I am > having a heck of the time squeezing them to install the top bolt. I > even use a clamp and some wood blocking but cannot squeeze them enough > before the clamp bend and wants to give. > > I am using one aluminum washer under the top collar. This part is not > identified but is the only part that fits under it. > > Thanks. Ro. > > ________________________________________________________________________________
From: "Dave & Brenda Emond" <d_emond(at)mweb.co.za>
Subject: Re: Cabin Air - vents
Date: Sep 10, 2005
Vans had a pair of aluminum "eyeball" type air vents on show at Oshkosh, has anyone fitted these to their RV 10 yet. I would be interested to hear what vents are being used by other builders Dave Emond busy on the fuse #40159 ----- Original Message ----- From: "brian bollaert" <bbollaert(at)comcast.net> Subject: Re: RV10-List: Gear elastomers > > Hi Rob: > > I had the same problem until i figured out that the powder coating was up > to > far on the (rod ) cant' remember the part number at home ! take it off > about > an inch or so and it will go right thru that hole , and then you can > insert > the bolt . The tolerances are real close . > > Brian Bollaert > #40200 > > ----- Original Message ----- > From: "Rob Kermanj" <rv10es(at)earthlink.net> > To: > Sent: Saturday, September 10, 2005 8:18 AM > Subject: RV10-List: Gear elastomers > > >> >> Can anyone tell me how you installed the nose gear rubber donuts? I am >> having a heck of the time squeezing them to install the top bolt. I >> even use a clamp and some wood blocking but cannot squeeze them enough >> before the clamp bend and wants to give. >> >> I am using one aluminum washer under the top collar. This part is not >> identified but is the only part that fits under it. >> >> Thanks. Ro. >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 10, 2005
Bill and Tami Britton writes: > I know it's not as good as doing it right the first time but I guess I was just in too big of a hurry to get my first piece completed. > You ought to go out to the airport and see what the factories did when they built the Cessnas, Pipers, and Beechcrafts. Bonding straps and static wicks were obviously added as an option once the aircraft was completely assembled and painted. Last things they did before flying it out of the factory for delivery. No problem. The C-182 I flew yesterday has the wicks pop riveted thru the skins, squeezing them together a bit, the bonding strap lugs go thru the hinge bolt and the other end is just a machine screw drilled randomly into the spar where it was convenient. Go look at the ramp for ideas before drilling apart anything you've got done. John Kirkland #40333 ________________________________________________________________________________
Date: Sep 10, 2005
I'm talking about the main doors, not the baggage door. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Subject: Re: RV10-List: Door Safety Straps Jesse, I recently saw a baggage door on a certified aircraft that was hinged at the bottom. The good thing about that was when it was open, it was always out of the way during loading / unloading operations. The downside was that if it opened in flight, depending on airplane flight configuration, it was going to slam all the way open or stay "almost" closed due to the direction of the airstream. Now the -10 door is hinged at the front and regardless of the airplane flight configuration, should be held almost closed. Loading and unloading are a little bit of a pain because the door is free to swing (I have not seen anyone put a gas strut on one yet!). My take is the door hinge is ok where it's at and the use of a safety strap is not needed. I would like to see a gas strut to hold the door open (or some other method). However, given that I am not flying just yet, my opinion may change after flying. Others who are in the air already can give us the real story. Later, Jim C #40192 - N312F (Fuselage) ________________________________________________________________________________
Date: Sep 10, 2005
We did it by lifting on the tail. That give you the necessary leverage to compress the rubbers and get the nut installed. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Subject: RV10-List: Gear elastomers Can anyone tell me how you installed the nose gear rubber donuts? I am having a heck of the time squeezing them to install the top bolt. I even use a clamp and some wood blocking but cannot squeeze them enough before the clamp bend and wants to give. I am using one aluminum washer under the top collar. This part is not identified but is the only part that fits under it. Thanks. Ro. ________________________________________________________________________________
Subject: Oil Filter Adapter
Date: Sep 10, 2005
We just did our 50-hour oil change (actually at about 57 hours). One thing we noticed is that it is going to be a pain in the neck taking off that oil fliter that is sticking straight out the back of the engine without getting oil all over everything. Unless there is a good way to drain the oil filter before taking it off, we need to find a trick to make this possible. For those of you who have engines that don't yet have an oil filter adapter on them, I think there is a right angle one that will have the filter pointing straight up. This would help in a couple of ways. One, it would drain the oil out of the filter before you take it off. Second, it will be very much easier to get at to install, safety wire, remove, etc. The oil filter sticks aft to flush with the firewall (right there where the recessed box is). If there seems to be something I am missing, please let me know. That is a really messy process. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Sep 10, 2005
Subject: Re: Oil Filter Adapter
There are a couple of things you can do. Make a tray out of a plastic milk jug to 'funnel' spilled oil from the seal end towards the firewall where it can be collected in a can or bottle. Of course, if you have stuff in the way you'll have to find another direction to 'funnel' it to. It make a custom fiberglas part with a drain hose down to a container. Be creative, because you're going to use this a lot if you fly a lot!!! The second thing is to take a nail and punch a hole in the top side of the filter. This lets air in so the oil can drain. After a (undertimed) duration of time, turn the filter 1/2 turn so that the nail hole is over your 'funnel' so the rest of the oil can drain out. You'll have to poke another hole in the top to let the air in again. After the filter had drained (no more drips) then remove the filter and your 'funnel'. Best of luck. Linn Jesse Saint wrote: > We just did our 50-hour oil change (actually at about 57 hours). One > thing we noticed is that it is going to be a pain in the neck taking > off that oil fliter that is sticking straight out the back of the > engine without getting oil all over everything. Unless there is a > good way to drain the oil filter before taking it off, we need to find > a trick to make this possible. For those of you who have engines that > don't yet have an oil filter adapter on them, I think there is a right > angle one that will have the filter pointing straight up. This would > help in a couple of ways. One, it would drain the oil out of the > filter before you take it off. Second, it will be very much easier to > get at to install, safety wire, remove, etc. The oil filter sticks > aft to flush with the firewall (right there where the recessed box is). > > > > If there seems to be something I am missing, please let me know. That > is a really messy process. > > > > Jesse Saint > > I-TEC, Inc. > > jesse(at)itecusa.org > > www.itecusa.org <http://www.itecusa.org/> > > W: 352-465-4545 > > C: 352-427-0285 > > F: 815-377-3694 > > > > > > ________________________________________________________________________________
Date: Sep 10, 2005
Awesome suggestion with the nail. Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn walters Subject: Re: RV10-List: Oil Filter Adapter There are a couple of things you can do. Make a tray out of a plastic milk jug to 'funnel' spilled oil from the seal end towards the firewall where it can be collected in a can or bottle. Of course, if you have stuff in the way you'll have to find another direction to 'funnel' it to. It make a custom fiberglas part with a drain hose down to a container. Be creative, because you're going to use this a lot if you fly a lot!!! The second thing is to take a nail and punch a hole in the top side of the filter. This lets air in so the oil can drain. After a (undertimed) duration of time, turn the filter 1/2 turn so that the nail hole is over your 'funnel' so the rest of the oil can drain out. You'll have to poke another hole in the top to let the air in again. After the filter had drained (no more drips) then remove the filter and your 'funnel'. Best of luck. Linn Jesse Saint wrote: We just did our 50-hour oil change (actually at about 57 hours). One thing we noticed is that it is going to be a pain in the neck taking off that oil fliter that is sticking straight out the back of the engine without getting oil all over everything. Unless there is a good way to drain the oil filter before taking it off, we need to find a trick to make this possible. For those of you who have engines that don't yet have an oil filter adapter on them, I think there is a right angle one that will have the filter pointing straight up. This would help in a couple of ways. One, it would drain the oil out of the filter before you take it off. Second, it will be very much easier to get at to install, safety wire, remove, etc. The oil filter sticks aft to flush with the firewall (right there where the recessed box is). If there seems to be something I am missing, please let me know. That is a really messy process. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ ________________________________________________________________________________
Date: Sep 10, 2005
Avery has an oil filter drain kit: http://www.averytools.com/cart/p-86-oil-filter-drain-kit.aspx Seems like I have seen them elsewhere as well. Brian 40308 (QB and finish arrived 09/09/05!) ----- Original Message ----- From: Jesse Saint To: rv10-list(at)matronics.com Sent: Saturday, September 10, 2005 5:00 PM Subject: RV10-List: Oil Filter Adapter We just did our 50-hour oil change (actually at about 57 hours). One thing we noticed is that it is going to be a pain in the neck taking off that oil fliter that is sticking straight out the back of the engine without getting oil all over everything. Unless there is a good way to drain the oil filter before taking it off, we need to find a trick to make this possible. For those of you who have engines that don't yet have an oil filter adapter on them, I think there is a right angle one that will have the filter pointing straight up. This would help in a couple of ways. One, it would drain the oil out of the filter before you take it off. Second, it will be very much easier to get at to install, safety wire, remove, etc. The oil filter sticks aft to flush with the firewall (right there where the recessed box is). If there seems to be something I am missing, please let me know. That is a really messy process. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Subject: Riveting rudder pedal brace
Date: Sep 10, 2005
I'm ready to rivet the rudder pedal brace to the firewall (connects to the recess on the firewall). However, my rivet gun won't fit inside the recess to shoot the rivet. I'm tempted to use pop rivets here since I can't think of a good way to drive the rivets. Anyone have any tips to this using a solid AD rivet? Aaron -- Aaron Sims RV-10 #40036 (Firewall) http://canopyroad.org/rv10/ n217gt(at)gmail.com ________________________________________________________________________________
Date: Sep 10, 2005
I wondered about the trailing edge of these things myself. Thought it might look a little bit odd having all of the other trailing edges being the wedge type and these ones being bent. I think what I will end up doing is running out this week to get the steel angle iron that I planned on getting for the rest of the trailing edges. I should be able to clamp that with the skin between it and the workbench. It will be thin enough to bend. Anybody know of a good place to pick that up in Phoenix? --Shawn 40366 PJ Seipel wrote: As mentioned you can use the seamers. I built my trim tabs twice. On my first set I used the seamer and ended up with a 15 degree bend that was wavy as hell and my little end tabs came out very badly. If you use the seamer be careful and go slowly or it'll make a mess. When I built my second set I cut them apart along the trailing edge and riveted the trailing edge with AEX wedge just like all the other control surfaces on the plane. One of the big advantages of doing it that way is that I could do the little end rib bends and the 15 degree bend with ease because I didn't have to deal with the rest of the tab being in the way. Came out much better, and I'm disappointed that Van's didn't just have us do it this way to begin with. PJ 40032 Shawn Moon wrote: > All, > I am working on the elevator trim tabs and have come to the point of > bending the skin 15 degrees (Page 9-17 step 2). How did you get this > thing bent? I can't figure out what I can get in there to hold the > small portion of skin flat against the workbench to get it bent over. > Now that the end tabs are bent over, they hit against any piece of > wood that I try to put there. Any suggestions would be helpful. Thanks. > > --Shawn > 40366 > > __________________________________________________ > ________________________________________________________________________________
Date: Sep 10, 2005
Subject: Re: Riveting rudder pedal brace
I back riveted them by having a partner hold a bucking bar on the manufactured head. PJ 40032 Aaron Sims wrote: > > I'm ready to rivet the rudder pedal brace to the firewall (connects > to the recess on the firewall). However, my rivet gun won't fit > inside the recess to shoot the rivet. I'm tempted to use pop rivets > here since I can't think of a good way to drive the rivets. Anyone > have any tips to this using a solid AD rivet? > > Aaron > -- > Aaron Sims > RV-10 #40036 (Firewall) > http://canopyroad.org/rv10/ > n217gt(at)gmail.com > > ________________________________________________________________________________
Date: Sep 10, 2005
Home Depot or Ace Hardware usually have angle iron in stock. -Sean #40303 Cave Creek Shawn Moon wrote: > I wondered about the trailing edge of these things myself. Thought it > might look a little bit odd having all of the other trailing edges > being the wedge type and these ones being bent. I think what I will > end up doing is running out this week to get the steel angle iron that > I planned on getting for the rest of the trailing edges. I should be > able to clamp that with the skin between it and the workbench. It > will be thin enough to bend. Anybody know of a good place to pick > that up in Phoenix? > > --Shawn > 40366 > > */PJ Seipel /* wrote: > > > As mentioned you can use the seamers. I built my trim tabs twice. On > my first set I used the seamer and ended up with a 15 degree bend > that > was wavy as hell and my little end tabs came out very badly. If > you use > the seamer be careful and go slowly or it'll make a mess. > > When I built my second set I cut them apart along the trailing > edge and > riveted the trailing edge with AEX wedge just like all the other > control > surfaces on the plane. One of the big advantages of doing it that way > is that I could do the little end rib bends and the 15 degree bend > with > ease because I didn't have to deal with the rest of the tab being > in the > way. Came out much better, and I'm disappointed that Van's didn't > just > have us do it this way to begin with. > > PJ > 40032 > > Shawn Moo n amp; > ________________________________________________________________________________
Date: Sep 11, 2005
Thanks for the reply brian. I did the same thing with the paint but having trouble installing the assembly on the mount. the donuts do not want to squeeze enough to get the bolt holes and the cap aligned. It seem like that you did not have the same problem. Rob. On Sep 10, 2005, at 11:35 AM, brian bollaert wrote: > > > Hi Rob: > > I had the same problem until i figured out that the powder coating was > up to > far on the (rod ) cant' remember the part number at home ! take it off > about > an inch or so and it will go right thru that hole , and then you can > insert > the bolt . The tolerances are real close . > > Brian Bollaert > #40200 > > ----- Original Message ----- > From: "Rob Kermanj" <rv10es(at)earthlink.net> > To: > Sent: Saturday, September 10, 2005 8:18 AM > Subject: RV10-List: Gear elastomers > > >> >> Can anyone tell me how you installed the nose gear rubber donuts? I >> am >> having a heck of the time squeezing them to install the top bolt. I >> even use a clamp and some wood blocking but cannot squeeze them enough >> before the clamp bend and wants to give. >> >> I am using one aluminum washer under the top collar. This part is not >> identified but is the only part that fits under it. >> >> Thanks. Ro. >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 11, 2005
Thanks for the reply. I will try it. Did you have the engine on the mount at the time you lifted the tail? Thanks, Rob. On Sep 10, 2005, at 5:54 PM, Jesse Saint wrote: > > We did it by lifting on the tail. That give you the necessary > leverage to > compress the rubbers and get the nut installed. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > W: 352-465-4545 > C: 352-427-0285 > F: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj > Sent: Saturday, September 10, 2005 11:18 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Gear elastomers > > > Can anyone tell me how you installed the nose gear rubber donuts? I am > having a heck of the time squeezing them to install the top bolt. I > even use a clamp and some wood blocking but cannot squeeze them enough > before the clamp bend and wants to give. > > I am using one aluminum washer under the top collar. This part is not > identified but is the only part that fits under it. > > Thanks. Ro. > > ________________________________________________________________________________
Date: Sep 11, 2005
Subject: ExperCraft build log
Fellow builders, This is an invite to those who need a method for creating a project log and Web site. Even if you've already started your log using another system this one is worth a look. ExperCraft Simple Log is free for builders and is a great way to create a comprehensive log and Web site. It's very easy to use. http://www.expercraft.com Enjoy! Rob -- Rob Riggen building a Vans RV7 http://websites.expercraft.com/rriggen -- -- ________________________________________________________________________________
Subject: RG400U diameter
Date: Sep 11, 2005
All, Anyone know what the outside diameter of RG400U coax is? Trying to figure wire runs in the wings. Thanks John Hasbrouck #40264 ________________________________________________________________________________
Date: Sep 11, 2005
Officially the OD of RG-400 is .195, but it's better to figure on 1/4" for coax runs. Cheers, Stein. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of John Hasbrouck Subject: RV10-List: RG400U diameter All, Anyone know what the outside diameter of RG400U coax is? Trying to figure wire runs in the wings. Thanks John Hasbrouck #40264 ________________________________________________________________________________
Date: Sep 12, 2005
No, we didn't have the engine on. It would be pretty hard to work on that with the engine on. The suggestion of climbing on the engine mount and pushing against the ceiling would probably work as well, and it would certainly be better for pictures for the builder's log. Either way, it should work. It does take a lot of pressure to compress them, which is the way you want it. Have fun. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Subject: Re: RV10-List: Gear elastomers Thanks for the reply. I will try it. Did you have the engine on the mount at the time you lifted the tail? Thanks, Rob. On Sep 10, 2005, at 5:54 PM, Jesse Saint wrote: > > We did it by lifting on the tail. That give you the necessary > leverage to > compress the rubbers and get the nut installed. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > W: 352-465-4545 > C: 352-427-0285 > F: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj > Sent: Saturday, September 10, 2005 11:18 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Gear elastomers > > > Can anyone tell me how you installed the nose gear rubber donuts? I am > having a heck of the time squeezing them to install the top bolt. I > even use a clamp and some wood blocking but cannot squeeze them enough > before the clamp bend and wants to give. > > I am using one aluminum washer under the top collar. This part is not > identified but is the only part that fits under it. > > Thanks. Ro. > > ________________________________________________________________________________
Subject: trimtab trailing edges
Date: Sep 12, 2005
I used the combination angle iron, and ground rivet squeezer method (no Proseal) on my rudder trailing edge, and it came out perfect. I like the idea of using the same technique for the trim tabs, however I wonder if the additional weight of the AEX and rivets out there could be a concern ? Is there a balance issue with trim tabs as well? Before I call Vans and ask them, I would sure like to hear anyone's opinion on this concern. Thanks Chris Hukill ________________________________________________________________________________
Subject: Where to buy...
Date: Sep 12, 2005
0.15 HTML_TEXT_AFTER_BODY BODY: HTML contains text after BODY close tag Folks, Got back from a two week trip to my mother-in-laws (!) and I had over 700 emails in my RV-10 account. Just got caught up on Sunday. Here's a couple of answers to some questions: Clecos: I got mine at ATS, they had the lowest prices for NEW ones. This was around last Christmas... Wire: Contact the following guy at wire masters: "Glenn Hill" Note: when we buy wire we buy in 1000 foot or 500 foot increments. The BIG (read expensive) stuff we usually get in 100 foot increments. If wire masters can't do it for for contact S.E.A. wire and cable. Here are the links: http://www.sea-wire.com/ http://www.wiremasters.net/ http://www.aircraft-tool.com/ Remember, when you buy in quantities, these folks will usually give you a better price. It doesn't hurt to ASK! Some of you builders that are NEAR each other should get together and make a bulk buy and then distribute the materials yourselves. Remember, cheap prices are nice! Take care and keep pounding those rivets! :) Dave Talley San Antonio, TX ________________________________________________________________________________
Date: Sep 12, 2005
Thanks Jesse. Rob. On Sep 12, 2005, at 9:44 AM, Jesse Saint wrote: > > No, we didn't have the engine on. It would be pretty hard to work on > that > with the engine on. The suggestion of climbing on the engine mount and > pushing against the ceiling would probably work as well, and it would > certainly be better for pictures for the builder's log. Either way, it > should work. It does take a lot of pressure to compress them, which > is the > way you want it. > > Have fun. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > W: 352-465-4545 > C: 352-427-0285 > F: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj > Sent: Sunday, September 11, 2005 7:31 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Gear elastomers > > > Thanks for the reply. I will try it. Did you have the engine on the > mount at the time you lifted the tail? > > Thanks, Rob. > > On Sep 10, 2005, at 5:54 PM, Jesse Saint wrote: > >> >> We did it by lifting on the tail. That give you the necessary >> leverage to >> compress the rubbers and get the nut installed. >> >> Jesse Saint >> I-TEC, Inc. >> jesse(at)itecusa.org >> www.itecusa.org >> W: 352-465-4545 >> C: 352-427-0285 >> F: 815-377-3694 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj >> Sent: Saturday, September 10, 2005 11:18 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Gear elastomers >> >> >> Can anyone tell me how you installed the nose gear rubber donuts? I >> am >> having a heck of the time squeezing them to install the top bolt. I >> even use a clamp and some wood blocking but cannot squeeze them enough >> before the clamp bend and wants to give. >> >> I am using one aluminum washer under the top collar. This part is not >> identified but is the only part that fits under it. >> >> Thanks. Ro. >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Oil FIlter Adapter
Date: Sep 12, 2005
The way I learned to changed a crowded oil filter in A&P school was to punch a small hole in the top of the filter and then use a blow nozzle (use the one with a rubber tip) to pressure the filter with shop air. This blows from clean side of the filter back into the oil galley and magically your filter will be practically empty when you spin it off. RV-10 #446 Bruce Case ________________________________________________________________________________
Subject: Re: Oil FIlter Adapter
Date: Sep 12, 2005
regards the oil filter; be careful how you make the hole in the filter. shavings/fragments that fall inside can give false impression of an engine making metal. ----- Original Message ----- From: Bruce Case To: RV10-List(at)matronics.com Sent: Monday, September 12, 2005 11:35 AM Subject: RV10-List: Oil FIlter Adapter The way I learned to changed a crowded oil filter in A&P school was to punch a small hole in the top of the filter and then use a blow nozzle (use the one with a rubber tip) to pressure the filter with shop air. This blows from clean side of the filter back into the oil galley and magically your filter will be practically empty when you spin it off. RV-10 #446 Bruce Case ________________________________________________________________________________
Subject: AC power
Date: Sep 12, 2005
Anyone giving consideration of providing 110AC outlets in the 10. My plan involves a two plug 400W inverter mounted on the pilot side sub panel. It will be internally fused at 20A a plug and will be connected to the hot side of the starter relay and controlled by its own off/on switch and ultimately the master switch. That way I can run the laptop /cell phone/handheld radio or just charge their batteries. I have a similar system as an after thought in the Glastar and allows back up use for www.myairplane.com DVDs of enroute/IAPs and VFR sectionals without fear of battery failure. Of course the destination and alternates I print and carry in paper. ----- Original Message ----- From: Bruce Case To: RV10-List(at)matronics.com Sent: Monday, September 12, 2005 11:35 AM Subject: RV10-List: Oil FIlter Adapter The way I learned to changed a crowded oil filter in A&P school was to punch a small hole in the top of the filter and then use a blow nozzle (use the one with a rubber tip) to pressure the filter with shop air. This blows from clean side of the filter back into the oil galley and magically your filter will be practically empty when you spin it off. RV-10 #446 Bruce Case ________________________________________________________________________________
Date: Sep 12, 2005
Bruce, is there not a chance, that if you do that, that also all the filtered out particles are blown back into the engine again? br Werner Bruce Case wrote: > > The way I learned to changed a crowded oil filter in A&P school was to > punch a small hole in the top of the filter and then use a blow nozzle > (use the one with a rubber tip) to pressure the filter with shop air. > This blows from clean side of the filter back into the oil galley and > magically your filter will be practically empty when you spin it off. > > RV-10 #446 > > Bruce Case ________________________________________________________________________________
Date: Sep 12, 2005
The outside wall of the oil filter is adjacent to the filtered or clean oil, blowing back from this location only pushes clean oil back into the engine. Use a sharp awl to pierce the filter and you will end up with a clean hole with no fragments. This technique works well on any tight engine compartment which is usually the case for any 6 cylinder engine. Bruce Case RV-10, #446 ________________________________________________________________________________
Date: Sep 12, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I notice a lot of discussion about working around the situation - is there a reason that remote oil filter setups aren't mentioned? Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Case Subject: RV10-List: Oil FIlter Adapter The outside wall of the oil filter is adjacent to the filtered or clean oil, blowing back from this location only pushes clean oil back into the engine. Use a sharp awl to pierce the filter and you will end up with a clean hole with no fragments. This technique works well on any tight engine compartment which is usually the case for any 6 cylinder engine. Bruce Case RV-10, #446 ________________________________________________________________________________
Date: Sep 12, 2005
> I notice a lot of discussion about working around the situation is there > a reason that remote oil filter setups arent mentioned? The "down sides" seem to include: - more stuff that can fail (hoses, fittings, connections) - more weight - more up front expense - more recurring expense (hoses) - one more thing consuming firewall "real estate" That said, they certainly seem to help with convenience. And one could argue that by adding "surface area" to the entire system it won't hurt in the oil cooling department. FWIW, I use the poke & drain/funnel method when changing my "standard" horizontally mounted oil filter. It's cheap, mess free, and introduces the least amount of complexity and points of failure into the system. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Sep 12, 2005
Subject: Re: trimtab trailing edges
I have been told by Don Forrest, #40114, that Van's does not endorse the AEX method. You would indeed have to take the additional weight into account when balancing your elevators, and its effect on the flutter margin is unknown. As always, you must do your own risk analysis and your mileage may vary. PJ #40032 Chris Hukill wrote: > I used the combination angle iron, and ground rivet squeezer method > (no Proseal) on my rudder trailing edge, and it came out perfect. I > like the idea of using the same technique for the trim tabs, however I > wonder if the additional weight of the AEX and rivets out there could > be a concern ? Is there a balance issue with trim tabs as well? > Before I call Vans and ask them, I would sure like to hear anyone's > opinion on this concern. Thanks > Chris Hukill ________________________________________________________________________________
Date: Sep 12, 2005
Subject: 2006 Calendar
I have thought about making a 2006 calendar (RV-10 Style!) Several questions: (1) I would need to get some great pictures for use on the Calendar. These would need to be high resolution digital if at all possible. I would also need to have the photographers permision to use them on the calendar and a small paragraph about the picture. (2) Anyone care to list any important dates they would like to see highlighted on the Calendar (First Flight Anniversaries, Holidays, etc.) (3) Distribution? - PDF (Personal use only), Printed - Not stapled for wall hanging, Printed / Stapled. Comments? Jim Combs #40192, N312F - Fuselage ________________________________________________________________________________
Date: Sep 12, 2005
Dan has several great points. One thing about the reoccurring expenses; one can purchase teflon LIFE-TIME hoses. Check with John at Airwolf. They're not cheap, but a one time buy is good. Also, you can take them off every five years or so (yes, five years) and have them re-certified if you don't trust them. Take care, David Talley San Antonio, TX ________________________________________________________________________________
Date: Sep 12, 2005
Subject: CABIN DOORS
For those who have already fitted the cabin doors, is there a convenient (and out of the way) place to put a micro switch (and wiring) on both doors that could be tied into a "door ajar" light on the panel? Haven't yet gotten my QB kit, but finishing up my panel specs with my builder, so would be nice to know now. Thanks - John #40404 ________________________________________________________________________________
Date: Sep 12, 2005
Subject: RE: AC power
>My plan involves a two plug 400W inverter mounted on the pilot side sub panel You're kidding right? Even mid sized turbines don't have inverters anymore. All those devices you mention ultimately use DC power. Why introduce the noise of AC just to convert it back to DC? Wouldn't you be better off looking into DC to DC converters of the appropriate voltages? Just trying to understand why. William Curtis http://members.core.com/~wcurtis/ ________________________________________________________________________________
Date: Sep 12, 2005
That is what I did on mine, looks 10x better than the folded edge, in my opinion of course.... Van's will tell you not to do it, like they do with everything that is not exactly as on the plans..... They did not test their airplane in this fashion so they will not give you any advice except not to do it. I did mine this way, I will be sure the control surfaces are balances and I will check it for flutter during the first 40 hours. In the slight chance it won't work, it is very easy to swap out the trim tabs.... P.S. - a lot of the -9 guys did it too, and I have never heard of any issues. Maybe you want to cross post on the -9 list and ask them specifically. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Subject: RV10-List: trimtab trailing edges I used the combination angle iron, and ground rivet squeezer method (no Proseal) on my rudder trailing edge, and it came out perfect. I like the idea of using the same technique for the trim tabs, however I wonder if the additional weight of the AEX and rivets out there could be a concern ? Is there a balance issue with trim tabs as well? Before I call Vans and ask them, I would sure like to hear anyone's opinion on this concern. Thanks Chris Hukill ________________________________________________________________________________
Subject: Fuselage building question
Date: Sep 12, 2005
On page 29-12 on the left inset it shows the F-1042-EL to be riveted to the F-1040-L. The picture does not show this, but there are some rivets for some nut plates and one of the rivets is shadowed by the F-1040-EL. I was hoping to install the nut plates prior to the riveting the F=1-42-EL to the F-1040-L, but I can not seem to find what size nut plates and what they are used for? I assume there is a cover plate or something that goes over this, but could not find anything in the plans. I looked up on some builders web sites without much luck either. Any help would be greatly appreciated. -Mike ________________________________________________________________________________
Subject: Fuse wiring question
Date: Sep 12, 2005
Where is everyone running the wire runs from the firewall (or behind the IP) to the wings and to the tail in the RV-10? Down through the center area, down the sides, or under the floors? I am interested in getting my floors riveted down but wanted to make sure I don't seal off any area that would need conduit. Thanks -Mike ________________________________________________________________________________
Date: Sep 12, 2005
Subject: Re: CABIN DOORS
I believe it would be easy to put the microswitch just on the front side of the vertical doorpost on the front of the door, and have it click up when the door latch pin is extended all the way in to the locked position. Then you'd have a warning if the door wasn't latched tight. In fact, I was thinking that instead of adding a cabin lock that would cause a chelton thief to wreck my entire plane to try to get to it, I'd just install a big loud a$$ horn that would go off if someone opened the door without deactivating it. You could then either use a remote key FOB or an externally mounted keyed security electrical switch. If it was loud and obnoxious enough, it should work as well as a lock in preventing the theft. Tim GenGrumpy(at)aol.com wrote: > For those who have already fitted the cabin doors, is there a convenient > (and out of the way) place to put a micro switch (and wiring) on both > doors that could be tied into a "door ajar" light on the panel? > > Haven't yet gotten my QB kit, but finishing up my panel specs with my > builder, so would be nice to know now. > > Thanks - John #40404 ________________________________________________________________________________
Date: Sep 12, 2005
From: "Scott Schmidt" <sschmidt(at)ussynthetic.com>
I am running mine down the sides. I did put in wiring conduit under the rear baggage compartment. I didn't want to run anything down the middle that might jam the controls. -Scott ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Mike Kraus Subject: RV10-List: Fuse wiring question Where is everyone running the wire runs from the firewall (or behind the IP) to the wings and to the tail in the RV-10? Down through the center area, down the sides, or under the floors? I am interested in getting my floors riveted down but wanted to make sure I don't seal off any area that would need conduit. Thanks -Mike ________________________________________________________________________________
Date: Sep 12, 2005
They are for a cover. They nutplates are K1000-08. The screws are called out on page 35-7 515-8R8 and 509-8R*. But you are right, I have no idea where it says to put those on. I faintly remember having the same problem. Anyway, I see no problem in putting them on right now and you definately have to do it before the 1040-EL. -Scott ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Mike Kraus Subject: RV10-List: Fuselage building question On page 29-12 on the left inset it shows the F-1042-EL to be riveted to the F-1040-L. The picture does not show this, but there are some rivets for some nut plates and one of the rivets is shadowed by the F-1040-EL. I was hoping to install the nut plates prior to the riveting the F1-42-EL to the F-1040-L, but I can not seem to find what size nut plates and what they are used for? I assume there is a cover plate or something that goes over this, but could not find anything in the plans. I looked up on some builders web sites without much luck either. Any help would be greatly appreciated. -Mike ________________________________________________________________________________
Subject: Re: Fuse wiring question
Date: Sep 12, 2005
MessageI am running all down the side panels so that they can be accessed later if necessary. DC and high current on the left side and digital signals down the right, ----- Original Message ----- From: Mike Kraus To: rv10-list(at)matronics.com Sent: Monday, September 12, 2005 8:16 PM Subject: RV10-List: Fuse wiring question Where is everyone running the wire runs from the firewall (or behind the IP) to the wings and to the tail in the RV-10? Down through the center area, down the sides, or under the floors? I am interested in getting my floors riveted down but wanted to make sure I don't seal off any area that would need conduit. Thanks -Mike ________________________________________________________________________________
Date: Sep 13, 2005
I have run all my wiring down the sides. It can get crowded but seem to have shorter runs. I had to enlarge the holes in the rear spar and the cone bulkhead to fit a #2 Cable, a VOR antenna and a Marker Beacon antenna. On Sep 12, 2005, at 11:16 PM, Mike Kraus wrote: > Where is everyone running the wire runs from the firewall (or behind > the IP) to the wings and to the tail in the RV-10?=A0 Down through the > center area, down the sides, or under the floors?=A0 I am interested in > getting my floors riveted down but wanted to make sure I don't seal > off any area that would need conduit. > > Thanks > -Mike > ________________________________________________________________________________
Subject: I have a question Scott.
Date: Sep 13, 2005
Hello scott. I am working on the door latches and have found the pins to be way too long. I either have to cut the pins or provide a hole for the rack in the opposite wall of the latch pocket. I looked at your pictures and noticed that your pins are fully retracted with the latch in a vertical position. This looks correct to me. I think that I can only do this by providing four holes for the racks in each latch pocket walls. What do you think? Thanks, Rob. ________________________________________________________________________________
Date: Sep 13, 2005
Hi,what is a angle iron combination-ground rivet squeezer sorry for the question ,Hugo > > From: "Mike Kraus" <n223rv(at)wolflakeairport.net> > Date: 2005/09/12 Mon PM 10:59:09 EDT > To: > Subject: RE: RV10-List: trimtab trailing edges > > That is what I did on mine, looks 10x better than the folded edge, in my > opinion of course.... Van's will tell you not to do it, like they do > with everything that is not exactly as on the plans..... They did not > test their airplane in this fashion so they will not give you any advice > except not to do it. > > I did mine this way, I will be sure the control surfaces are balances > and I will check it for flutter during the first 40 hours. In the > slight chance it won't work, it is very easy to swap out the trim > tabs.... > > P.S. - a lot of the -9 guys did it too, and I have never heard of any > issues. Maybe you want to cross post on the -9 list and ask them > specifically. > > -Mike > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill > Sent: Monday, September 12, 2005 11:50 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: trimtab trailing edges > > > I used the combination angle iron, and ground rivet squeezer method (no > Proseal) on my rudder trailing edge, and it came out perfect. I like the > idea of using the same technique for the trim tabs, however I wonder if > the additional weight of the AEX and rivets out there could be a concern > ? Is there a balance issue with trim tabs as well? Before I call Vans > and ask them, I would sure like to hear anyone's opinion on this > concern. Thanks > Chris Hukill > > > ________________________________________________________________________________
Date: Sep 13, 2005
We wired the entire plane after it was built, so all of the closed off areas were already closed off. We ran CPVC conduit in the wings to push wires through, but everything in the fuse we did with snap bushings. We made the right side panel in the baggage compartment removable (nutplates instead of rivets) and ran all of the wires down that side. We didn't run anything in the center tunnel or under the seat or baggage floors. If you are wondering, it wouldn't hurt to put some conduit in there just in case you decide to wire through there. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Subject: RV10-List: Fuse wiring question Where is everyone running the wire runs from the firewall (or behind the IP) to the wings and to the tail in the RV-10? Down through the center area, down the sides, or under the floors? I am interested in getting my floors riveted down but wanted to make sure I don't seal off any area that would need conduit. Thanks -Mike ________________________________________________________________________________
Subject: RV-10 Prop and question about polished spinner
Date: Sep 13, 2005
Tim and others, I decided to order the Hartzell blended airfoil prop. I placed my order last week. I think the MT prop would have been great and many people think the smoothness is worth 5 mph but I went back and reviewed the article that Van's wrote a few years ago on the different props and he found that the Hartzell had speeds of 205 mph, the blended Hartzell was 208 mph, and the MT was 200 mph. It sounds like Vic is seeing a decrease of about 8mph as well. It isn't a huge speed difference and if the MT was $5800 I would have still ordered the MT but when you pay $2300 more you expect more. I also feel that I can switch to the MT down the line if things are more proven by then but I really didn't want to be one of the firsts and then be disappointed in my prop when I know the performance of the Hartzell will be great. So, I am back in the two blade club with most of you. My question is now, who sells a nice polished spinner for this prop? I really want a polished spinner. I am having my step chromed to match. Scott Schmidt sschmidt(at)ussynthetic.com ________________________________________________________________________________
Date: Sep 13, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
This company makes some seriously wicked paints: http://alsacorp.com/chrome.htm, including one that replicates chrome to a T. I especially think the MultiChrome would rock on a spinner. Check it out but watch out for sticker shock. You thought that some chromatic paints were expensive. I may incorporate some of their stranger paints for trim and will probably order their sample pack shortly before. Michael Sausen -10 #352 tanks ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Subject: RV10-List: RV-10 Prop and question about polished spinner Tim and others, I decided to order the Hartzell blended airfoil prop. I placed my order last week. I think the MT prop would have been great and many people think the smoothness is worth 5 mph but I went back and reviewed the article that Van's wrote a few years ago on the different props and he found that the Hartzell had speeds of 205 mph, the blended Hartzell was 208 mph, and the MT was 200 mph. It sounds like Vic is seeing a decrease of about 8mph as well. It isn't a huge speed difference and if the MT was $5800 I would have still ordered the MT but when you pay $2300 more you expect more. I also feel that I can switch to the MT down the line if things are more proven by then but I really didn't want to be one of the firsts and then be disappointed in my prop when I know the performance of the Hartzell will be great. So, I am back in the two blade club with most of you. My question is now, who sells a nice polished spinner for this prop? I really want a polished spinner. I am having my step chromed to match. Scott Schmidt sschmidt(at)ussynthetic.com ________________________________________________________________________________
Date: Sep 13, 2005
Subject: Elevator mismatch
Has anyone had one elevator trailing edge not align with the other after hanging them on the horizontal stabilizer. I understand that the horns might not align ( per plans ), but I'm not sure that the elevators themselves should be misaligned. If I fair the elevator counterbalances to the horizontal on both sides outboard and lay a straight edge across the trailing edge of both elevators, there is about a 3/8 inch diff. with the left elevator hanging slightly low. I am perplexed!! I did not create the hinge points, It was all match holed construction and I used plenty of clecoes while riveteing the skins. I dont know how the left elevator seems to tuck low as it nears the inbd end. I did discover that a slight pressure down on the right elev horn and slight up press on the left nearly brings them into alignment, but this obviously adds a preload that doesn't seem right. Any thoughts/ suggestions appreciated. Thanks, Mark (40016) ________________________________________________________________________________
Date: Sep 13, 2005
Maybe I can make the switch do double duty..... Can you take a picture of where how this would fit? Thanks In a message dated 9/12/2005 10:45:38 PM Central Standard Time, Tim(at)MyRV10.com writes: I believe it would be easy to put the microswitch just on the front side of the vertical doorpost on the front of the door, and have it click up when the door latch pin is extended all the way in to the locked position. Then you'd have a warning if the door wasn't latched tight. In fact, I was thinking that instead of adding a cabin lock that would cause a chelton thief to wreck my entire plane to try to get to it, I'd just install a big loud a$$ horn that would go off if someone opened the door without deactivating it. You could then either use a remote key FOB or an externally mounted keyed security electrical switch. If it was loud and obnoxious enough, it should work as well as a lock in preventing the theft. Tim GenGrumpy(at)aol.com wrote: > For those who have already fitted the cabin doors, is there a convenient > (and out of the way) place to put a micro switch (and wiring) on both > doors that could be tied into a "door ajar" light on the panel? > > Haven't yet gotten my QB kit, but finishing up my panel specs with my > builder, so would be nice to know now. > > Thanks - John #40404 ________________________________________________________________________________
Date: Sep 13, 2005
Subject: Re: Elevator mismatch
Mark, I had a small amount of difference in my elevators also. I called Van's about it, their response was "if it's less than 3/4" don't worry about it, just build the airplane!" Soon after I was at Van's and eyeballed their elevators very closely. They didn't match perfectly either. Steve --- Mark Chamberlain <10flyer(at)verizon.net> wrote: > Has anyone had one elevator trailing edge not align > with the other after hanging them on the horizontal > stabilizer. I understand that the horns might not > align ( per plans ), but I'm not sure that the > elevators themselves should be misaligned. If I fair > the elevator counterbalances to the horizontal on > both sides outboard and lay a straight edge across > the trailing edge of both elevators, there is about > a 3/8 inch diff. with the left elevator hanging > slightly low. I am perplexed!! I did not create the > hinge points, It was all match holed construction > and I used plenty of clecoes while riveteing the > skins. I dont know how the left elevator seems to > tuck low as it nears the inbd end. I did discover > that a slight pressure down on the right elev horn > and slight up press on the left nearly brings them > into alignment, but this obviously adds a preload > that doesn't seem right. Any thoughts/ suggestions > appreciated. Thanks, Mark (40016) ________________________________________________________________________________
Date: Sep 13, 2005
Mark Chamberlain wrote: > Has anyone had one elevator trailing edge not align with the other > after hanging them on the horizontal stabilizer. I understand that the > horns might not align ( per plans ), but I'm not sure that the > elevators themselves should be misaligned. If I fair the elevator > counterbalances to the horizontal on both sides outboard and lay a > straight edge across the trailing edge of both elevators, there is > about a 3/8 inch diff. with the left elevator hanging slightly low. I > am perplexed!! I did not create the hinge points, It was all match > holed construction and I used plenty of clecoes while riveteing the > skins. I dont know how the left elevator seems to tuck low as it nears > the inbd end. I did discover that a slight pressure down on the right > elev horn and slight up press on the left nearly brings them into > alignment, but this obviously adds a preload that doesn't seem right. > Any thoughts/ suggestions appreciated. Thanks, Mark (40016) I may not be following you, but as i recall, the plans say to allign the elevator trailing edges with the HS and then to clamp the horns and drill, as you mention 9and as I also found in my case0 the horns don't align, but the whole process is designed to ensure that the trailing edges are aligned. What am I missing? Deems Davis # 406 waiting on wings to ship ________________________________________________________________________________
Date: Sep 14, 2005
What I used was some 1" ratchet straps off of the engine mount. 2 worked but a third would even be better. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Subject: RV10-List: Gear elastomers Can anyone tell me how you installed the nose gear rubber donuts? I am having a heck of the time squeezing them to install the top bolt. I even use a clamp and some wood blocking but cannot squeeze them enough before the clamp bend and wants to give. I am using one aluminum washer under the top collar. This part is not identified but is the only part that fits under it. Thanks. Ro. ________________________________________________________________________________
Date: Sep 14, 2005
Subject: -10 POH
I ran across a great POH for a -6A here... <http://rv.supermatrix.com/frame1-docs.html> Any of the flying -10s have a good POH example yet? -Sean #40303 ________________________________________________________________________________
Subject: Strobe wiring
Date: Sep 14, 2005
I'm working on the wing wiring. Assuming I place the strobe power supply in the tailcone near the battery, how long of a wire run should I plan on for the wing tip strobes? I'm using Whelen strobes with shielded cable, any problems running that with the rest of the power supply wires through conduit in the wings? Coax for nav antenna will be run seperately. John Hasbrouck #40264 ________________________________________________________________________________
Date: Sep 15, 2005
John, Your wiring sounds a lot like mine. I installed 4-pin molex quick disconnects at the wing root for the strobes. I want to say it took 13-14 feet from tip to root including service loop. I ran my wires all in a single conduit - including nav. It's unlikely that shielded wire will radiate much except at the point where it's been cut. Regards, Jay 40011 > From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com> > Subject: RV10-List: Strobe wiring > > > I'm working on the wing wiring. Assuming I place the strobe power supply in > the tailcone near the battery, how long of a wire run should I plan on for > the wing tip strobes? I'm using Whelen strobes with shielded cable, any > problems running that with the rest of the power supply wires through > conduit in the wings? Coax for nav antenna will be run seperately. > > John Hasbrouck > #40264 __________________________________ ________________________________________________________________________________
Subject: Re: Strobe wiring
Date: Sep 15, 2005
I have the Whelen stip and tail strobes connected to a single power supply that is located just behind the baggage bulkhead in my -7A. There are Amp MateNLok connectors at the wing roots, and the wiring runs in a separate conduit from the Nav antenna. The systems works perfectly without any electrical pop or whine (unlike my C182 strobe setup). Doesn't answer the cable length question, but just a confirmation that the long strobe wire setup if done by the directions (ground the shield at the power supply, leave it ungrounded at the strobe end) works great. Dan Masys RV-10 HS RV-7A flying > > I'm working on the wing wiring. Assuming I place the strobe power supply in > > the tailcone near the battery, how long of a wire run should I plan on for > > the wing tip strobes? I'm using Whelen strobes with shielded cable, any > > problems running that with the rest of the power supply wires through > > conduit in the wings? Coax for nav antenna will be run seperately. > > > > John Hasbrouck > > #40264 > > > > > > __________________________________ > > > > > > > > > > > > ________________________________________________________________________________
Subject: Wheel Base and Tread
Date: Sep 15, 2005
OK, I'm planning my shop which will go in the back yard and I'm going to have to rebuild the fence and put in a new gate. Can anyone tell me the width between the outside of the main tires, and the distance from the nosewheel to the mains? I need to know how wide to make the shop doorway and the gate. I don't know when the kit will be ordered, but the tools are slowly being acquired and the planning is underway. ________________________________________________________________________________
Subject: Re: Wheel Base and Tread
Date: Sep 16, 2005
Figure on 8' wheelbase and 7' from main to nose gear. On Sep 15, 2005, at 8:52 PM, Jack Sargeant wrote: > > OK, I'm planning my shop which will go in the back yard and I'm going > to > have to rebuild the fence and put in a new gate. Can anyone tell me > the > width between the outside of the main tires, and the distance from the > nosewheel to the mains? I need to know how wide to make the shop > doorway > and the gate. I don't know when the kit will be ordered, but the > tools are > slowly being acquired and the planning is underway. > > ________________________________________________________________________________
Date: Sep 16, 2005
While we're on the subject of measurements - does anybody have the height to the bottom of the fuselage when the plane is on its gear with tires inflated? Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Subject: Re: RV10-List: Wheel Base and Tread Figure on 8' wheelbase and 7' from main to nose gear. On Sep 15, 2005, at 8:52 PM, Jack Sargeant wrote: > > OK, I'm planning my shop which will go in the back yard and I'm going > to > have to rebuild the fence and put in a new gate. Can anyone tell me > the > width between the outside of the main tires, and the distance from the > nosewheel to the mains? I need to know how wide to make the shop > doorway > and the gate. I don't know when the kit will be ordered, but the > tools are > slowly being acquired and the planning is underway. > > ________________________________________________________________________________
Date: Sep 16, 2005
Also make the opening 9'0" high. Steve 40212 --- Rob Kermanj wrote: > > > Figure on 8' wheelbase and 7' from main to nose > gear. > > > On Sep 15, 2005, at 8:52 PM, Jack Sargeant wrote: > > > > > > OK, I'm planning my shop which will go in the back > yard and I'm going > > to > > have to rebuild the fence and put in a new gate. > Can anyone tell me > > the > > width between the outside of the main tires, and > the distance from the > > nosewheel to the mains? I need to know how wide > to make the shop > > doorway > > and the gate. I don't know when the kit will be > ordered, but the > > tools are > > slowly being acquired and the planning is > underway. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > > > > > __________________________________ ________________________________________________________________________________
Date: Sep 16, 2005
Vans is working on system now. You may contact them about the delivery time. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com Subject: RV10-List: CABIN DOORS For those who have already fitted the cabin doors, is there a convenient (and out of the way) place to put a micro switch (and wiring) on both doors that could be tied into a "door ajar" light on the panel? Haven't yet gotten my QB kit, but finishing up my panel specs with my builder, so would be nice to know now. Thanks - John #40404 ________________________________________________________________________________
Date: Sep 16, 2005
I am running mine in one conduit. I asked Dan Checkoway if he had any issues since his are run the same and he said it worked fine. There are some rules regarding the grounding that were already addressed such as grounding the sheilds at the power supply not at the strobe. I think the use of RG-400 which has a double sheild will also help to eliminate an RF interference and if I have problems I'll just drill off the bottom skins and run new conduit NOT!!! Rick S. 40185 ________________________________________________________________________________
Date: Sep 16, 2005
I'm going to guess that you mean 8' tread (Wheel to wheel of the main gear), and 8' wheelbase (Nose gear to mains) as it would be for cars and trucks. Thanks for the info. I think that I will have (just) enough room. One tree may have to go, but while I really like its shade it is too close to the porch and overhangs the roof! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Rob Kermanj Subject: Re: RV10-List: Wheel Base and Tread Figure on 8' wheelbase and 7' from main to nose gear. On Sep 15, 2005, at 8:52 PM, Jack Sargeant wrote: > > OK, I'm planning my shop which will go in the back yard and I'm going > to > have to rebuild the fence and put in a new gate. Can anyone tell me > the > width between the outside of the main tires, and the distance from the > nosewheel to the mains? I need to know how wide to make the shop > doorway > and the gate. I don't know when the kit will be ordered, but the > tools are > slowly being acquired and the planning is underway. > > ________________________________________________________________________________
Date: Sep 17, 2005
For what its worth - when I built my RV-4 originally I had Aeroflash powerpacks in both wings - ran all wires together unshielded. I had some whine in the headset when they were on but eliminated that when I isolated all audio grounds to a single point. If youy follow the recommendations from Bob at Aeroelectric and isolate the grounds for your audio system you shouldn't have any problem. There is a good article on his site (www.aeroelectric.com) that addresses this topic I seem to recall..... ----- Original Message ----- From: "Rick" <ricksked(at)earthlink.net> Subject: Re: RV10-List: Strobe wiring > > I am running mine in one conduit. I asked Dan Checkoway if he had any issues since his are run the same and he said it worked fine. There are some rules regarding the grounding that were already addressed such as grounding the sheilds at the power supply not at the strobe. I think the use of RG-400 which has a double sheild will also help to eliminate an RF interference and if I have problems I'll just drill off the bottom skins and run new conduit NOT!!! > > Rick S. > 40185 > > ________________________________________________________________________________
Date: Sep 17, 2005
Yup, good advice Richard, I think we tend to get into grounding issues when trying to reinvent the wheel. Bob's book and the Aerolectric matronics list are a great resource, I don't recommend getting the Aerolectric stuff dumped to your email cause there is lots of stuff every day but the archives are packed with good info. Bob's web site has some really good talking papers as well, print them in color so they look nice on the nightstand next to the bed....just for a laugh...how many of group have SOME kinda aviation literature on the nightstand that understanding better halfs put up with until it gets about 6 inches high? Rick S. 40185 Fuse ________________________________________________________________________________
Date: Sep 17, 2005
Guys, I am sure we have been here before. Just my .02$ How much does about 30ft x2 (for each wing) and another 20ft (for the tail) of shielded cables for these strobes weigh? There is an option of running regular 18g wire and having a strobe power supply in the wing tip and the root of the tail. These PW supplies weigh only a pound and there is no issue of interference or running high voltage lines past tanks or other wires (com antenna wires or etc) Is this a reasonable route? I am not an engineer of any sort, just a dumb homebuilder. I think there will be a weight saving which can be allocated to other stuff. Mani Ravee Indianapolis, KUMP #40339. N528AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Bibb Subject: Re: RV10-List: Strobe wiring For what its worth - when I built my RV-4 originally I had Aeroflash powerpacks in both wings - ran all wires together unshielded. I had some whine in the headset when they were on but eliminated that when I isolated all audio grounds to a single point. If youy follow the recommendations from Bob at Aeroelectric and isolate the grounds for your audio system you shouldn't have any problem. There is a good article on his site (www.aeroelectric.com) that addresses this topic I seem to recall..... ----- Original Message ----- From: "Rick" <ricksked(at)earthlink.net> Subject: Re: RV10-List: Strobe wiring > > I am running mine in one conduit. I asked Dan Checkoway if he had any issues since his are run the same and he said it worked fine. There are some rules regarding the grounding that were already addressed such as grounding the sheilds at the power supply not at the strobe. I think the use of RG-400 which has a double sheild will also help to eliminate an RF interference and if I have problems I'll just drill off the bottom skins and run new conduit NOT!!! > > Rick S. > 40185 > > ________________________________________________________________________________
Date: Sep 17, 2005
I have a reduced size (8 1/2 x 11) set of plans that I take everywhere. Larry 40356 wings Rick wrote: >....just for a laugh...how many of group have SOME kinda aviation literature on the nightstand that understanding better halfs put up with until it gets about 6 inches high? > >Rick S. >40185 >Fuse > > > > > > > > > ________________________________________________________________________________
Date: Sep 18, 2005
Mani, Absolute good point, I have a coil still in the supply bin and it's not too heavy, not much more or less than the power supply. My main reason is I have a cheap side that says the wire is cheaper than three power supplies....and since I have wing tip antennas, Com 2, Nav and marker beacon I figure if it interferes it would do it with the power supply at the tip as well. Good hanger conversation though. If I get any problems I'll pull my coax and install conventional Comants on the belly (already using one for Com 1) and whiskers in the tail for Nav. Everyone I talked to that is using my proposed/their setup has not had any problems. I am not concerned about the fuel tank/high voltage issue. It would take a lot of things to go wrong for my stobe wiring to get to my tanks....but yeah I know, Murphy rides on everyones shoulder. Rick S. 40185 Wings ________________________________________________________________________________
Date: Sep 18, 2005
Subject: Connector for Trim Servo?
Hi all, What connector is everyone using to connect to the trim servo? -Jim 40384 ________________________________________________________________________________
Subject: Fuel Tank info needed
Date: Sep 18, 2005
0.15 HTML_TEXT_AFTER_BODY BODY": rv10-list(at)matronics.com This is for anyone that has their wings on and sitting on the main gear. I am going with the Aircraft Extras optical sensor for a backup to the fuel gauge/totalizer. In order to put this in the tank I have to replicate, fairly closely, the position the tanks will be sitting in straight and level flight. So what I need is the relative angles in X and Y from the forward outboard edge of the tanks when the aircraft is level. Readings from a swing protractor should be close enough but an electronic level would be great. These things are a bit of a catch 22 as you need to be able to put water into the tanks in order to get the sensor to indicate at a known quantity but you can't get to the business end of the tank once they are closed up. You could wait to put the floats in but I also don't know what kind of error, if any, the float may introduce. So I will be putting these in the rear baffle below the fuel cap. I'll share the exact location with the group so anyone else using these won't have to go through the trouble. Thanks, Michael Sausen -10 #352 Tanks ________________________________________________________________________________
Date: Sep 18, 2005
Connect to what? If you are talking at the servo pigtail to the cable, a subD works great. Bob has an article on how to do this on his site. http://www.aeroelectric.com/articles/macservo/macservo.html Michael Sausen -10 #352 Tanks -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: RV10-List: Connector for Trim Servo? Hi all, What connector is everyone using to connect to the trim servo? -Jim 40384 ________________________________________________________________________________
Subject: Tailcone Attachment
Date: Sep 18, 2005
In step four of page 32-3 (tailcone attach) the instructions say to "match drill the four #30 holes in the aft end of the mid fuse longeron into the tailcone longeron". Problem is my QB didn't have these drilled from the factory and I cannot locate in the plans anywhere the dimensions of these. Can anyone point me to the section/page of the dimensions? Brian #40308 (trying to join the tailcone to the fuselage!) ________________________________________________________________________________
Subject: bolt designation help!
Date: Sep 18, 2005
hey all - let me preface this question by admitting that i might be an idiot. ok then. i'm getting to the end of riveting together the tailcone, and there are a couple of bolts that need installation. my question - what does the "A" designation mean? example: AN3-6A. 6A? what's the difference between AN3-6 and AN3-6A? i searched the archives and couldn't figure it out. also looked through the standard aircraft handbook etc... help anyone? thanks cj #40410 tailcone ________________________________________________________________________________
Subject: Re: bolt designation help!
Date: Sep 18, 2005
A indicates absent . that is the drilled shank is not there. Should be secured by a fibrous or metal locknut. ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Subject: RV10-List: bolt designation help! hey all - let me preface this question by admitting that i might be an idiot. ok then. i'm getting to the end of riveting together the tailcone, and there are a couple of bolts that need installation. my question - what does the "A" designation mean? example: AN3-6A. 6A? what's the difference between AN3-6 and AN3-6A? i searched the archives and couldn't figure it out. also looked through the standard aircraft handbook etc... help anyone? thanks cj #40410 tailcone ________________________________________________________________________________
Subject: RE: bolt designation help!
Date: Sep 18, 2005
The "A" indicates there is no hole drilled in the threaded part of the bolt. If you have an Aircraft Spruce catalog I think it discusses this as well to back me up. AN3-6 - hole AN3-6A - no hole Happy Bolting, Marcus -----Original Message----- From: Chris Johnston [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Subject: bolt designation help! hey all - let me preface this question by admitting that i might be an idiot. ok then. i'm getting to the end of riveting together the tailcone, and there are a couple of bolts that need installation. my question - what does the "A" designation mean? example: AN3-6A. 6A? what's the difference between AN3-6 and AN3-6A? i searched the archives and couldn't figure it out. also looked through the standard aircraft handbook etc... help anyone? thanks cj #40410 tailcone ________________________________________________________________________________
Date: Sep 18, 2005
Another suggestion. Get an aviation mechanics handbook. All the part number digits are explained as well as all the drill sizes and other interesting info like the size of a hole that you are going drill so that you can tap with new threads. ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Subject: RV10-List: bolt designation help! hey all - let me preface this question by admitting that i might be an idiot. ok then. i'm getting to the end of riveting together the tailcone, and there are a couple of bolts that need installation. my question - what does the "A" designation mean? example: AN3-6A. 6A? what's the difference between AN3-6 and AN3-6A? i searched the archives and couldn't figure it out. also looked through the standard aircraft handbook etc... help anyone? thanks cj #40410 tailcone ________________________________________________________________________________
Date: Sep 18, 2005
Here's the text from Aircraft Spruce's website regarding the bolts as a further reference: Hex head aircraft bolts are made of high-strength type 4037 or 8740 alloy steel (type 8740 is most commonly used). The bolts are centerless ground and threaded after heat treatment. Minimum tensile strength 125,000 PSI. Cadmium plated per specification QQ-P-416A, Type II, Class 3. Available with shank drilled for cotter pin or undrilled for stop nut application, and with or without drilled head for safety wire. Specify bolts to have undrilled shank by adding letter "A" after the dash number. For bolts with drilled head add letter "H" after the AN number. See illustrated examples. The length of AN aircraft bolts is measured from under the head to the end of the shank. The "grip" is the unthreaded portion of the shank. See table for conversion of length and/or grip to proper AN callout. Marcus 40286 (working on the workshop, outgrown the garage) -----Original Message----- From: Chris Johnston [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Subject: bolt designation help! hey all - let me preface this question by admitting that i might be an idiot. ok then. i'm getting to the end of riveting together the tailcone, and there are a couple of bolts that need installation. my question - what does the "A" designation mean? example: AN3-6A. 6A? what's the difference between AN3-6 and AN3-6A? i searched the archives and couldn't figure it out. also looked through the standard aircraft handbook etc... help anyone? thanks cj #40410 tailcone ________________________________________________________________________________
Date: Sep 18, 2005
Subject: Re: Tailcone Attachment
I'm a bit fuzzy on this already, but, I think those won't be drilled at all, and you just need to lay out a good 4 hole pattern. Just leave a good end edge distance on the rear one, and a little working space behind the bulkhead on the front one, and then space the other 2 holes evenly. I think you'll end up with something in the 1" spacing arena or so. Other than making sure you have strength there, nothing else makes it critical one way or the other. Tim Brian wrote: > In step four of page 32-3 (tailcone attach) the instructions say to > "match drill the four #30 holes in the aft end of the mid fuse longeron > into the tailcone longeron". Problem is my QB didn't have these drilled > from the factory and I cannot locate in the plans anywhere the > dimensions of these. Can anyone point me to the section/page of the > dimensions? > > Brian > #40308 (trying to join the tailcone to the fuselage!) ________________________________________________________________________________
Date: Sep 18, 2005
Interestingly, this is the second time in the last couple weeks this question has come up. The initial holes are match drilled using the F1046-B template on page 29-3. They are then match drilled to the tailcone sections and enlarged on page 32-3 step 4. Tim: this appears to be a potential gotcha for QB fuselage folks. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: Re: RV10-List: Tailcone Attachment I'm a bit fuzzy on this already, but, I think those won't be drilled at all, and you just need to lay out a good 4 hole pattern. Just leave a good end edge distance on the rear one, and a little working space behind the bulkhead on the front one, and then space the other 2 holes evenly. I think you'll end up with something in the 1" spacing arena or so. Other than making sure you have strength there, nothing else makes it critical one way or the other. Tim Brian wrote: > In step four of page 32-3 (tailcone attach) the instructions say to > "match drill the four #30 holes in the aft end of the mid fuse longeron > into the tailcone longeron". Problem is my QB didn't have these drilled > from the factory and I cannot locate in the plans anywhere the > dimensions of these. Can anyone point me to the section/page of the > dimensions? > > Brian > #40308 (trying to join the tailcone to the fuselage!) ________________________________________________________________________________
Date: Sep 18, 2005
Funny this should come up now. Here's my recent (1 week ago) email to Van's on this topic. I got a "that's fine" response from Van's. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 790 hrs RV-10 #40059 under construction -------- Original Message -------- Subject: RV-10 QB F-1046 aft end bolt holes Date: Sun, 11 Sep 2005 15:21:23 -0400 From: Tim Lewis <Tim_Lewis(at)msm.umr.edu> Vans, Please see picture 1, attached. This is the aft end of F-1046L, the mid fuselage longeron. Per plans page 32-3, upper balloon, there need to be four holes in the aft portion of this longeron for four AN-5 bolts. Per plans page 29-2, those four holes should be drilled with the aid of F-1046B, longeron bending template. I didn't receive F-1046B (because I have the QB fuselage, I presume). I called a local builder and got approximate hole location measurements from him. He'd already thrown away his template, but was able to give me approximate dimensions by measuring the bolts in place. I consulted my RV-6 plans for similar situations and ended up with the hole pattern shown in photo 2, attached. The hole distance from the inner edge of the longeron is from 5/16" to 3/8". Hole distance from the aft end of the longeron is 3/8". Inter-hole spacing (on centers) is 11/16" to 3/4". Is this solution acceptable? Thanks, Tim Lewis ________________________________________________________________________________
Subject: Re: Hugo Rv10
Date: Sep 18, 2005
Hey there! I'm building a -10 up north of Orlando, but get down to Ft. Lauderdale a few times a year either on business or to visit my brother. Would love to stop by if you're interested in meeting another -10 builder. My next confirmed trip south is week of Dec 5, but will probably come down at least once before then. Look forward to hearing from you. Ken Peck 31 Rosedown Blvd Debary, FL 386-846-4184 ----- Original Message ----- From: <gommone7(at)bellsouth.net> Subject: RV10-List: Hugo Rv10 > > I'm ready to close the VS ,it is any provision for a red rotating > (LED)beacon in the RV10 tail,I identified the white in the lower part of > the rudder,any body install traditional VOR antennas at the top of the VS? > Hugo > I;m working a three blocks from the wicks manufacturer at Ft > >Lauderdale,Today I will made a cortesy visit(may be I can purchase > direct) > > > ________________________________________________________________________________
Subject: Re: 2006 Calendar
Date: Sep 18, 2005
Gosh, a great inspirational tool for those of us in the process! I'd gladly cough up a few $$ for something I could put on my office wall! Ken ----- Original Message ----- From: "Jim Combs" <jimc(at)mail.infra-read.com> Subject: RV10-List: 2006 Calendar > > I have thought about making a 2006 calendar (RV-10 Style!) > > Several questions: > > (1) I would need to get some great pictures for use on the Calendar. > These would need to be high resolution digital if at all possible. I > would also need to have the photographers permision to use them on the > calendar and a small paragraph about the picture. > > (2) Anyone care to list any important dates they would like to see > highlighted on the Calendar (First Flight Anniversaries, Holidays, etc.) > > (3) Distribution? - PDF (Personal use only), Printed - Not stapled for > wall hanging, Printed / Stapled. > > Comments? > > Jim Combs > #40192, N312F - Fuselage > > > ________________________________________________________________________________
Subject: NACA Vent cutout on side skin is too high!
Date: Sep 19, 2005
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com I have a question for the list. I cleco'ed on the upper deck and switch/breaker panel to the fuse yesterday and tried to fit the NACA vents and the expensive aluminum vents I bought from Van's. The Vent cutouts in the skin are too high on the side skin and hit the underside of the switch/breaker panel. Even if you trim the naca vent as much as possible it is still not enough. Van's should have lowered the skin cutout another 1/4" to 3"8", than it would have fit. Now I am not sure what I am going to do. I was thinking of ordered the NACA vent pieces from Van's for the RV-9 which come in two pieces and then you join them together with 2" scat tube and clamps. This might make it longer and require a different mounting scheme. This sucks that at builder 40250, this kind of stuff isn't already corrected. Any thoughts? Ray Doerr 40250 Engine and Prop arrived. Working on Finishing Kit. ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Date: Sep 19, 2005
This caught me by surprise too. This is what I did There is an angle aluminum that is riveted to the side skin like an RV-9A with the vent bolted to it, a flex duct that connects the two. Noel -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK] Subject: RV10-List: NACA Vent cutout on side skin is too high! Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com I have a question for the list. I cleco'ed on the upper deck and switch/breaker panel to the fuse yesterday and tried to fit the NACA vents and the expensive aluminum vents I bought from Van's. The Vent cutouts in the skin are too high on the side skin and hit the underside of the switch/breaker panel. Even if you trim the naca vent as much as possible it is still not enough. Van's should have lowered the skin cutout another 1/4" to 3"8", than it would have fit. Now I am not sure what I am going to do. I was thinking of ordered the NACA vent pieces from Van's for the RV-9 which come in two pieces and then you join them together with 2" scat tube and clamps. This might make it longer and require a different mounting scheme. This sucks that at builder 40250, this kind of stuff isn't already corrected. Any thoughts? Ray Doerr 40250 Engine and Prop arrived. Working on Finishing Kit. ________________________________________________________________________________
Date: Sep 19, 2005
We have the normal Whelen strobe power supply in the tail and run the wire that came with the kit from Van's. I think we get a tiny bit of noise when the strobes are on, but it is hardly noticeable. We also have a Nav in one wingtip and a Com in the other. It's certainly not bad enough to be a problem. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: RE: RV10-List: Strobe wiring Mani, Absolute good point, I have a coil still in the supply bin and it's not too heavy, not much more or less than the power supply. My main reason is I have a cheap side that says the wire is cheaper than three power supplies....and since I have wing tip antennas, Com 2, Nav and marker beacon I figure if it interferes it would do it with the power supply at the tip as well. Good hanger conversation though. If I get any problems I'll pull my coax and install conventional Comants on the belly (already using one for Com 1) and whiskers in the tail for Nav. Everyone I talked to that is using my proposed/their setup has not had any problems. I am not concerned about the fuel tank/high voltage issue. It would take a lot of things to go wrong for my stobe wiring to get to my tanks....but yeah I know, Murphy rides on everyones shoulder. Rick S. 40185 Wings ________________________________________________________________________________
Date: Sep 19, 2005
We used a 9-pin D-sub connector from Radio Shack. We ended up going with relay decks, though, which makes wiring the servo, the indicator, the switch in the panel and the switch on the control stick a little bit of a pain, really almost defeating the purpose for making them a quick disconnect. For the Aileron and Rudder trims we used the same relay deck (that Van's sells) and just soldered/crimped the wires. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: RV10-List: Connector for Trim Servo? Hi all, What connector is everyone using to connect to the trim servo? -Jim 40384 ________________________________________________________________________________
Subject: Hugo Rv10
Date: Sep 19, 2005
Ken, If you are north of Orlando, then you are not far from us. You would we welcome to stop by X35 and look at our -10. It gets back today from a trip to Ohio, Pennsylvania, Tennessee and North Carolina. It will probably have the better part of 75 hours on it by then. It's been running great. It might inspire you to keep up the work. GOD BLESS! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Comcast Subject: Re: RV10-List: Hugo Rv10 Hey there! I'm building a -10 up north of Orlando, but get down to Ft. Lauderdale a few times a year either on business or to visit my brother. Would love to stop by if you're interested in meeting another -10 builder. My next confirmed trip south is week of Dec 5, but will probably come down at least once before then. Look forward to hearing from you. Ken Peck 31 Rosedown Blvd Debary, FL 386-846-4184 ----- Original Message ----- From: <gommone7(at)bellsouth.net> Subject: RV10-List: Hugo Rv10 > > I'm ready to close the VS ,it is any provision for a red rotating > (LED)beacon in the RV10 tail,I identified the white in the lower part of > the rudder,any body install traditional VOR antennas at the top of the VS? > Hugo > I;m working a three blocks from the wicks manufacturer at Ft > >Lauderdale,Today I will made a cortesy visit(may be I can purchase > direct) > > > ________________________________________________________________________________
Subject: Madera MAE
Date: Sep 19, 2005
I will be at the MAE airport for a week starting on Wednesday. Are there any RV-10 builders in the area? Noel 325HP ________________________________________________________________________________
Date: Sep 19, 2005
Absolutely! My home no. is 772-460-3907. You can reach me at my home no. anytime. What is your phone no.? Rob. On Sep 18, 2005, at 9:08 PM, Comcast wrote: > > Hey there! > > I'm building a -10 up north of Orlando, but get down to Ft. Lauderdale > a few times a year either on business or to visit my brother. Would > love to stop by if you're interested in meeting another -10 builder. > > My next confirmed trip south is week of Dec 5, but will probably come > down at least once before then. > > Look forward to hearing from you. > > Ken Peck > 31 Rosedown Blvd > Debary, FL > 386-846-4184 > > > ----- Original Message ----- From: <gommone7(at)bellsouth.net> > To: > Sent: Friday, September 09, 2005 6:56 AM > Subject: RV10-List: Hugo Rv10 > > >> >> I'm ready to close the VS ,it is any provision for a red rotating >> (LED)beacon in the RV10 tail,I identified the white in the lower part >> of the rudder,any body install traditional VOR antennas at the top of >> the VS? >> Hugo >> I;m working a three blocks from the wicks manufacturer at Ft >> >Lauderdale,Today I will made a cortesy visit(may be I can purchase >> direct) >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 19, 2005
I believe the hole placement on the side skin was based on the smaller 1" vents. The feeling was, as I understand it, that the 1" vents did not allow enough air flow. The 2" vents fit but you have to trim off one ear. This makes it nice and close to the panel if you want to make a cover that will hide everything except the vent itself. The cover will end up right next to the lower edge of the panel. Randy -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK] Subject: RV10-List: NACA Vent cutout on side skin is too high! --> Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com I have a question for the list. I cleco'ed on the upper deck and switch/breaker panel to the fuse yesterday and tried to fit the NACA vents and the expensive aluminum vents I bought from Van's. The Vent cutouts in the skin are too high on the side skin and hit the underside of the switch/breaker panel. Even if you trim the naca vent as much as possible it is still not enough. Van's should have lowered the skin cutout another 1/4" to 3"8", than it would have fit. Now I am not sure what I am going to do. I was thinking of ordered the NACA vent pieces from Van's for the RV-9 which come in two pieces and then you join them together with 2" scat tube and clamps. This might make it longer and require a different mounting scheme. This sucks that at builder 40250, this kind of stuff isn't already corrected. Any thoughts? Ray Doerr 40250 Engine and Prop arrived. Working on Finishing Kit. ________________________________________________________________________________
Subject: tailcone riveting!!
Date: Sep 19, 2005
Hey all - First, thanks to everyone who responded to my bolt ident query yesterday. This list rocks. Now the new question: when riveting the top skin on the tailcone, is it ok to climb in there to buck? I know I've seen pics of people inside the tailcone bucking and goofing around, but I'm scared of bending j-stiffners, dinging the skins, or otherwise screwing stuff up. Thoughts? Thanks cj
August 28, 2005 - September 19, 2005
RV10-Archive.digest.vol-aq
