RV10-Archive.digest.vol-as
October 07, 2005 - October 16, 2005
      [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Subject: Re: Real time and cost to build? From a new subscriber
I'll throw a nickel on the grass (as the old fighter pilot song goes). Going the QB route, with some great (and RV experienced helpers). At least a year to complete, some of which is lead time for Van to deliver QB kits. With new engine (rather than some clunker rebuild), new prop and REAL IFR package (with backup), probably $150k is a good ball park. You can do it for less, but with increased risk. I figure.....$120k and a 2nd class machine that is VFR or $150k and a first class machine with reall IFR capability. And you'll be head to head with the Cirrus and Lancair bubbas, who have $500k+ in their machines. It's your call..... Probably get strafed by others for my opinion. Grumpy 40404 In a message dated 10/5/2005 9:29:49 PM Central Standard Time, jjessen(at)rcn.com writes: Mike, Good questions. A trip through the land of RV web sites will help you, greatly. Also, search the archives. There are many references there as to the time to build and costs. I cannot do anything but give you a projected cost range that I came up with for my purposes (IFR panel, new engine, etc), and that was between $120,000 to $140,000. I hope the estimated range is high; I doubt it. But to me, the one thing that disturbed me about your post was the "need" to get this done within a year or less. Randy, the first totally completed RV-10 to fly, was finished in 20 months, with help, both in terms of physical labor, but also in terms of subsections being farmed out, such as the panel. (Randy can fill you in on exactly what were his shortcuts.) Twenty months is fast, my friend. I expect to take between 24 and 48 months, depending if I, too, go QB, which is still being debated. For a plane of this complexity, anything south of 24 months would be proud to crow about, but less than 12? Please don't set that as your goal. This stuff is doable, but it is not strictly a Lego or erector set. By the way, I work on it each evening for 2 hours (when I'm not traveling on business) and each and every weekend for at least 6 hours (when I'm not being pulled away by others who don't understand the passion and addiction, but whose needs must be recognized - none of us are total recluses, yet), and there's no way that I could get it done in less time than Randy's 20 months. I have all the tools, and the requisite knowledge and skills, and there's no way. In short, enjoy the process, build well and have some fun...or, buy one already built. I'm sure there will be a few up for sale soon. My best, John Jessen 40328 HS -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lee
Subject: Real time and cost to build? From a new subscriber
OK I am sure this has been asked before, but maybe someoneone could send me copies of any list digests with information on this, or just reply directly. I am ver seriously considering an RV-10 project. What I would like is information from real builders on the following: Assuming the following: 1) RV-10 Quick build kit 2) Builder has good mechanical aptitude and electonics experience. 3) Never built an airplane before, or any project of this size. 4) Planning to keep customizations to a minimum. 5) Need to keep costs down, planning on finding a used mid time engine, CS prop, analog engine gauges, basic JPI engine monitor, will shell out $ for a Garmin 530 / 430 combo and indicators. 6) Want an IFR platform (hence the 530 / 430 combo) 7) GPS / Nav coupled auto pilot with altitude hold. 8) Will paint myself, will have uphoulstry done. 9) Basic sound proofing. 10) Wingtip stobes, plus stobe beacon, otherwise standard lighting with taxi / landing light. Can I get an estimate of build time and costs? What types of unexpected costs that are not in the above are there? Anyone else out there with similar goals / expectaions? What are other builders doing to keep costs down? I know I can save some $$ by buying a standard kit instead of a quick build, but I have a need to have the aircraft done in less than a year, working evenings and weekends. THANKS!!!!! for any and all help! Mike ________________________________________________________________________________
Subject: Engine
Date: Oct 07, 2005
As im not that experienced in regards to all of the lycoming engine models etc and realize Vans recomends 540. I thought i'd read that there are both 560 and 580 Lycoming models. Could these be fitted and are they the same engine block with larger bore or stroke and hence fit under cowl. I gues inrease in horse power would be a no no. Paul Walter ________________________________________________________________________________
Subject: aileron trim
Date: Oct 07, 2005
Can't answer that. I don't know anything about Van's kit. All I know is that we paid $175 each for our trims, installed them in 2 hours each after the plane had already been flying, and they work great. Beyond that, I can't say much. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Subject: RE: RV10-List: aileron trim The trim servo kit from Van's is $275. Why is AEROTRIM servo trim kit only $175? DEAN ________________________________________________________________________________
Date: Oct 07, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
There's not much to it, just a MAC servo, a tab, and linkage, but I'm surprised as well. I believe it was much more than the Van's trim at EAA when I looked. Must have a cheaper version for experimental. Michael Sausen -10 #352 Flaps ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Subject: RE: RV10-List: aileron trim The trim servo kit from Van's is $275. Why is AEROTRIM servo trim kit only $175? DEAN ________________________________________________________________________________
Subject: RE: Lycoming Engines
Date: Oct 07, 2005
Have you seen the new prices on the Aerosport site? $37,500. Do you think the number of RV-10 kits being built is driving up the price? I am starting to look and the price increase are causing me to look at other alternatives....maybe I will end up with a Subaru. But, I really want to stay with the IO-540. Rene' Felker 40322 N423CF Wings - 90% Fuslage - 10% _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Subject: RV10-List: RE: Lycoming Engines Yup, they raised the price of the 260HP IO-540 from $38,990 to $42,650, an over $3,600 increase. However they now have an offering of the 250HP O-540 for $37,500. Other than fuel injection, anyone know what else is different between these engines? It would seem you could get the O and add fuel injection for a lot less than $5,150 or FADEC for a little more. I think I'll be looking at the IO-540 clone from Aerosport. Maybe in these days of $5 avgas, they will reconsider the 210HP Continental IO-360. >Back to the engine question. I am getting close to ordering one and noticed >that Vans prices went up considerably for the IO540. Does anyone know if >this has the new tapped technology? William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Re: Lycoming Engines
Paul, It will take some practice but here are a few tips. If you look at the head of each rivet there is a tiny dimple for you bit to start in, make sure your right on it when you get going. I use the same size drill as the rivet. Start slow and strive to keep the bit perpendicular to the head as possible. Once you get into the head about the depth of the drill bit plus a tad more, stop and use a punch either 3/32 or 1/8 inch inserted in to the hole to snap off the head. Now you may find that the hole will just round out instead of snapping off, it happens so next time go a little deeper. Now it's decision time. If you can back up the area behind the shop head, use the punch to drive out the remaining piece of the rivet, many times if you have snapped the head off just right it will come out easily. Or you can drill out the last piece, key here is to get that bit to follow your original hole VERY CLOSE if not exact. A very slightly undersized bit can help but not really needed as much as a good round of drilling out bad rivets to practice. I don't recommend using the bit to snap off the head, I tried twice, first time put a slight bend in the bit, and second time broke the tip. No need to waste bits and the sharp end of the punch works well to bite into the base of your hole to snap off the rivet head. I find that when I drill them out now, once the head is off I have almost removed the balance of the rivet or it comes out just before I get ready to snap off the head. Of course I have only drilled out bad rivets that other builders have set, not on my own airplane because I have not set a bad rivet yet :D. If Bob Kaufmann tries to say otherwise and point to that silly picture he has hanging in shop that he "alleges" is me drilling out a bad rivet on my RV-10 pay no attention, it's photoshopped. Rick S. 40185 Fuselage ________________________________________________________________________________
Subject: Engine
Date: Oct 07, 2005
Lycoming does offer an experimental 580 engine, at 323 hp. It would not be suitable for the RV-10 however, because it is an angle head engine and is too wide for the standard cowling. We have built some for the higher powered aerobatic performers. Peter Besenyai flys one, and so does Patty Wagstaff. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone ((18) 835-1754 fax www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Walter Subject: RV10-List: Engine As im not that experienced in regards to all of the lycoming engine models etc and realize Vans recomends 540. I thought i'd read that there are both 560 and 580 Lycoming models. Could these be fitted and are they the same engine block with larger bore or stroke and hence fit under cowl. I gues inrease in horse power would be a no no. Paul Walter ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Avery Tool Sale
Avery Tools is having a sale on tools. 5% off and free shipping. The free shipping would help if you need only a few tools. I have no relation to Avery, but in my experience they provide high quality tools. Larry Rosen N205EN (reserved) ________________________________________________________________________________
Date: Oct 07, 2005
"Start slow" I turn the chuck by hand to get the drill started, and then after the bit starts to bite then I slowly pull the trigger. Larry Rosen N205EN (reserved) Rick wrote: > >Paul, > >It will take some practice but here are a few tips. If you look at the head of each rivet there is a tiny dimple for you bit to start in, make sure your right on it when you get going. I use the same size drill as the rivet. Start slow and strive to keep the bit perpendicular to the head as possible. Once you get into the head about the depth of the drill bit plus a tad more, stop and use a punch either 3/32 or 1/8 inch inserted in to the hole to snap off the head. Now you may find that the hole will just round out instead of snapping off, it happens so next time go a little deeper. Now it's decision time. If you can back up the area behind the shop head, use the punch to drive out the remaining piece of the rivet, many times if you have snapped the head off just right it will come out easily. Or you can drill out the last piece, key here is to get that bit to follow your original hole VERY CLOSE if not exact. > >A very slightly undersized bit can help but not really needed as much as a good round of drilling out bad rivets to practice. I don't recommend using the bit to snap off the head, I tried twice, first time put a slight bend in the bit, and second time broke the tip. No need to waste bits and the sharp end of the punch works well to bite into the base of your hole to snap off the rivet head. > >I find that when I drill them out now, once the head is off I have almost removed the balance of the rivet or it comes out just before I get ready to snap off the head. Of course I have only drilled out bad rivets that other builders have set, not on my own airplane because I have not set a bad rivet yet :D. If Bob Kaufmann tries to say otherwise and point to that silly picture he has hanging in shop that he "alleges" is me drilling out a bad rivet on my RV-10 pay no attention, it's photoshopped. > >Rick S. >40185 >Fuselage > > > > > > > > > ________________________________________________________________________________
Subject: TMXIO-540
Date: Oct 07, 2005
Is there a reason that people are talking about the Aerosport engine at $37,500 over the Teledyne engine at $34,150? Am I missing something? What are the differences that make it worth spending $3,200 more for the Aerosport engine? By the way, my dad is up in MN right now, flew up there yesterday. He made it 917 statute miles on 50 gallons with headwinds. Our experience has been that Van's fuel burn numbers are conservative. Of course, they only list numbers up to 8,000 feet, at which altitude it burns a lot. We burn about 10.5gph at 10,500 with true airspeeds between 185 and 195mph. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Oct 07, 2005
What is the $37,500 for, one of their overhauls or a clone? Ive always questioned the wisdom of paying 80-90% of the cost of a new engine from Vans, for an overhauled engine by ANY shop in the field. Before they started offering Lycoming clones, they were selling overhauled IO-540 engines for about $33,500 when Vans was selling new IO-540s for $38,990. 85% of the cost of new for a field overhauled engine. The peace of mind of a new crankshaft alone is worth the extra 15% ($5,500), at least to me. How many field overhauls include a new crankshaft. Tim, does you engine have a new crankshaft? All the porting and balancing in the world won't help when a questionable crank fails. If this is the cost for a clone IO-540 with ALL new parts on the other hand, that would be another story and a fair deal. >Have you seen the new prices on the Aerosport site? $37,500. Do you >think the number of RV-10 kits being built is driving up the price? I am >starting to look and the price increase are causing me to look at other >alternatives....maybe I will end up with a Subaru. But, I really want to >stay with the IO-540. William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Oct 07, 2005
Bob, Are you a member of the Fly Rotary Group? "Rotary motors in aircraft [flyrotary(at)lancaironline.net]" Three of us on the list are putting Rotary's in the 10. Bobby Hughes 40116 ________________________________
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob.kaufmann Subject: RE: RV10-List: Real time and cost to build? From a new subscriber My nickel after talking to Misty pilot, is IFR, rotary 20B, all glass, and under 100 Bob K ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com Subject: Re: RV10-List: Real time and cost to build? From a new subscriber I'll throw a nickel on the grass (as the old fighter pilot song goes). Going the QB route, with some great (and RV experienced helpers). At least a year to complete, some of which is lead time for Van to deliver QB kits. With new engine (rather than some clunker rebuild), new prop and REAL IFR package (with backup), probably $150k is a good ball park. You can do it for less, but with increased risk. I figure.....$120k and a 2nd class machine that is VFR or $150k and a first class machine with reall IFR capability. And you'll be head to head with the Cirrus and Lancair bubbas, who have $500k+ in their machines. It's your call..... Probably get strafed by others for my opinion. Grumpy 40404 In a message dated 10/5/2005 9:29:49 PM Central Standard Time, jjessen(at)rcn.com writes: =09 Mike, =09 Good questions. A trip through the land of RV web sites will help you, greatly. Also, search the archives. There are many references there as to the time to build and costs. =09 I cannot do anything but give you a projected cost range that I came up with between $120,000 to $140,000. I hope the estimated range is high; I doubt it. =09 But to me, the one thing that disturbed me about your post was the "need" to get this done within a year or less. Randy, the first totally completed RV-10 to fly, was finished in 20 months, with help, both in terms of physical labor, but also in terms of subsections being farmed out, such as the panel. (Randy can fill you in on exactly what were his shortcuts.) Twenty months is fast, my friend. I expect to take between 24 and 48 months, depending if I, too, go QB, which is still being debated. For a plane of this complexity, anything south of 24 months would be proud to crow about, but less than 12? Please don't set that as your goal. This stuff is doable, but it is not strictly a Lego or erector set. =09 traveling on business) and each and every weekend for at least 6 hours (when I'm not being pulled away by others who don't understand the passion and addiction, but whose needs must be recognized - none of us are total recluses, yet), and there's no way that I could get it done in less time than Randy's 20 months. I have all the tools, and the requisite knowledge and skills, and there's no way. In short, enjoy the process, build well and have some fun...or, buy one already built. I'm sure there will be a few up for sale soon. =09 My best, =09 John Jessen 40328 HS =09 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lee Sent: Wednesday, October 05, 2005 4:49 PM To: rv10-list(at)matronics.com Subject: RV10-List: Real time and cost to build? From a new subscriber =09 =09 OK I am sure this has been asked before, but maybe someoneone could send me copies of any list digests with information on this, or just reply directly. =09 I am ver seriously considering an RV-10 project. What I would like is information from real builders on the following: =09 Assuming the following: 1) RV-10 Quick build kit 2) Builder has good mechanical aptitude and electonics experience. 3) Never built an airplane before, or any project of this size. 4) Planning to keep customizations to a minimum. 5) Need to keep costs down, planning on finding a used mid time engine, CS prop, analog engine gauges, basic JPI engine monitor, will shell out $ for a Garmin 530 / 430 combo and indicators. 6) Want an IFR platform (hence the 530 / 430 combo) 7) GPS / Nav coupled auto pilot with altitude hold. 8) Will paint myself, will have uphoulstry done. 9) Basic sound proofing. 10) Wingtip stobes, plus stobe beacon, otherwise standard lighting with taxi / landing light. =09 Can I get an estimate of build time and costs? What types of unexpected costs that are not in the above are there? =09 Anyone else out there with similar goals / expectaions? =09 What are other builders doing to keep costs down? =09 I know I can save some $$ by buying a standard kit instead of a quick build, but I have a need to have the aircraft done in less than a year, working evenings and weekends. =09 THANKS!!!!! for any and all help! =09 Mike ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Re: TMXIO-540
I think getting the 1yr warranty for the TMXIO-540 upgraded to match the 3 year offered by Aerosport is at least $2K ($2K is what they charge for the 360 engine) so that gets it closer. Timely topic - going to have to make the big leap to get into the queue for one of these darn things soon. Perry Casson Regina Canada Jesse Saint wrote: > Is there a reason that people are talking about the Aerosport engine > at $37,500 over the Teledyne engine at $34,150? Am I missing > something? What are the differences that make it worth spending $3,200 > more for the Aerosport engine? > > By the way, my dad is up in MN right now, flew up there yesterday. He > made it 917 statute miles on 50 gallons with headwinds. Our experience > has been that Vans fuel burn numbers are conservative. Of course, > they only list numbers up to 8,000 feet, at which altitude it burns a > lot. We burn about 10.5gph at 10,500 with true airspeeds between 185 > and 195mph. > > Jesse Saint > > I-TEC, Inc. > > jesse(at)itecusa.org > > www.itecusa.org <http://www.itecusa.org/> > > W: 352-465-4545 > > C: 352-427-0285 > > F: 815-377-3694 > ________________________________________________________________________________
Date: Oct 07, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Ironically, with Lycoming's track record, some may prefer a good "old" crankshaft to a brand-new one from Lycoming . . . he he TDT 40025 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Subject: RV10-List: RE: Lycoming Engines What is the $37,500 for, one of their overhauls or a clone? I've always questioned the wisdom of paying 80-90% of the cost of a new engine from Van's, for an overhauled engine by ANY shop in the field. Before they started offering Lycoming clones, they were selling overhauled IO-540 engines for about $33,500 when Van's was selling new IO-540s for $38,990. 85% of the cost of new for a field overhauled engine. The peace of mind of a new crankshaft alone is worth the extra 15% ($5,500), at least to me. How many field overhauls include a new crankshaft. Tim, does you engine have a new crankshaft? All the porting and balancing in the world won't help when a questionable crank fails. If this is the cost for a clone IO-540 with ALL new parts on the other hand, that would be another story and a fair deal. >Have you seen the new prices on the Aerosport site? $37,500. Do you >think the number of RV-10 kits being built is driving up the price? I am >starting to look and the price increase are causing me to look at other >alternatives....maybe I will end up with a Subaru. But, I really want to >stay with the IO-540. William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Subject:
Date: Oct 07, 2005
0.20 FROM_NO_LOWER From address has no lower-case characters List, Jesse brought to my attention the wrong URL listing on my earlier post. Our website address is www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> . Sorry for any inconvenience this may have caused. Allen Barrett BPE, Inc. ________________________________ I've stopped 37,350 spam messages. You can too! One month FREE spam protection at www.cloudmark.com <http://www.cloudmark.com/spamnet?v1&rcgjw23> <http://www.cloudmark.com/spamnet?v1&rcgjw23> ________________________________________________________________________________
Subject: Aileron trim
Date: Oct 07, 2005
The Aerotrim unit requires you to cut a small square out of the control surface. It then sit's in that hole as a complete unit acting as the access plate. You then attach a small tab to the trailing edge of the control surface and the linkage then controls that. You would route the control wires out the back of the control surface into the aircraft. It is a very straight forward system when you want to add trim to an existing system that has no other option. For me the clean install of the Van's system inside the wing, moving the whole surface, is a better option. I may still consider Aerotrim for the rudder should the need arise. Michael Sausen -10 #352 Flaps ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: RV10-List: Aileron trim Jesse, Did your aileron trim require cutting into the aileron itself or does is move the entire roll control? Rick s. 40185 Fuselage ________________________________________________________________________________
Date: Oct 07, 2005
You have to cut a square hole in the control surface and it operates a hinge that you rivet onto the trailing edge of the aileron and/or rudder. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: RV10-List: Aileron trim Jesse, Did your aileron trim require cutting into the aileron itself or does is move the entire roll control? Rick s. 40185 Fuselage ________________________________________________________________________________
Date: Oct 07, 2005
Both of those prices are for brand new clone engines. I think they are even certified Lycoming parts, just not a certified data plate. It was my understanding from Lycoming after speaking to them at Oshkosh that their certified engines are now shipping with the roller lifters, which might account for the difference in price. That is just what they told me, but I don't understand all of the details about that. I think $34,500 is a decent price for a new engine considering what certified ones cost. Aerosport has been charging about $1,000 less than that for an overhauled one. I wonder what the insurance ramifications would be for an experimental new engine. Any thoughts? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Subject: RV10-List: RE: Lycoming Engines What is the $37,500 for, one of their overhauls or a clone? I've always questioned the wisdom of paying 80-90% of the cost of a new engine from Van's, for an overhauled engine by ANY shop in the field. Before they started offering Lycoming clones, they were selling overhauled IO-540 engines for about $33,500 when Van's was selling new IO-540s for $38,990. 85% of the cost of new for a field overhauled engine. The peace of mind of a new crankshaft alone is worth the extra 15% ($5,500), at least to me. How many field overhauls include a new crankshaft. Tim, does you engine have a new crankshaft? All the porting and balancing in the world won't help when a questionable crank fails. If this is the cost for a clone IO-540 with ALL new parts on the other hand, that would be another story and a fair deal. >Have you seen the new prices on the Aerosport site? $37,500. Do you >think the number of RV-10 kits being built is driving up the price? I am >starting to look and the price increase are causing me to look at other >alternatives....maybe I will end up with a Subaru. But, I really want to >stay with the IO-540. William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Re: RE: Lycoming Engines
There is the extra 15 hours of test period for non-certified engine/prop. The fuel could cost $700 and up for that extra time. Doug Preston ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Wing order + components
Ok, I'm getting ready to order the wings. I'd like to get whatever I might need to put in the wing while I'm at it so I don't forget something or have to wait to continue building because I'm waiting for a part. So, I guess this is where a lot of the decisions come ;) The question is, did I miss anything that will be difficult or impossible after the wing is closed: Conduit / bushings for the wiring AOA / pitot tubing coax cable for the wingtip nav / comm antennas aileron trim kit A couple of other questions... having not made an engine decision yet, and suspecting there will be some interesting things happening in the next 2 - 3 years before I'm ready for an engine installation, what would I need to do differently to the fuel plumbing / tanks if I were to use something that required JET-A as opposed to 100LL or mogas? Is there a way to build the tanks / plumbing so that you could use any of the above? Or does it not matter, and the real question is quantity? (I'll leave the traditional vs. non-traditional engine choice discussion for much later when I have acquired a nice nomex suit;) If I have two systems that have AOA (like a dynon or a chelton and the AOA indicator that AFS sells) do I need separate plumbing for both of them or can they share the same ports in the wings the way a pitot-static system can? I like the display of the AOA pro but a lot of the glass units have that feature built in so it would be nice to have them both working. Where are people putting their OAT sensor(s)? What kind of wiring does it require? I'm planning on going with the duckworks light kit, is it easier to install before or after the wing is closed? Thanks James #40400 elevators ________________________________________________________________________________
Subject: Lycoming Engines
Date: Oct 07, 2005
PS. A plug on the Barrett Cold Induction Option and Forsling Tuned Exhaust are important areas for consideration by the mass of RV-10 builders. Many of whom would look to a Subie or Innodyne before fully understanding the approved Firewall Forward choices (Insurable) that fit with VANS cowl and mount. Since you are listening and posting. Thanks for the data. Any chance that the cowl mod you are working on would allow an IO-580X to be hung? John - KUAO ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BPA Subject: RE: RV10-List: Lycoming Engines John, everyone that knows me knows I'm not one to be very quiet! :-) I am in agreement with your statement of choice, feature and quality. Let's clear the air a bit. First, the recent price increase of a crate engine from Vans makes the experimental kits the most cost effective choice. The three shops that are regularly being talked about, BPE, Aerosport & Mattittuck all build very fine engines. We all are on the Lycoming kit engine program for several reasons. We build quality engines, have a good reputation, are dedicated to the GA industry and support our products. If you choose any one of these shops to build your engine, you are going to get a quality product. While some shops offer a base engine purchase price with several performance enhancing upgrades such as balancing, custom painting, porting and polishing, etc etc, and add these costs as you choose, here at BPE we build our experimental engines incorporating these features. We feel this is the right way to build an engine. What I'm trying to say is that while you can purchase a basic engine and add the cost of upgrades, by the time you have an engine that is comparable in options and performance, you'll realize that the price differences are minimal at best. Since the kit engines have become available, the shops in the program have adjusted their prices to take into account their costs. Labor is probably the biggest cost factor in the price differences. We have done some very close evaluation of our costs, and we have adjusted our pricing so that we are very competitive with Aerosport without sacrificing the build quality that we are well known for. The standard IO-540-X engine from us sells for $38,300. A few of the price differences, include our balancing, port/flow match on cylinders, Champion plugs (instead of Unison), all fittings and hoses included, silicon rocker box covers and a 1.5 hour dynamometer test, including a full power run. If you haven't received a quote from us on an engine since September, we'd be happy to review our pricing with you. Here's a price saving tip for anyone - if you are going to need your engine prior to June of 06, go ahead and order your engine before the end of the year. Historically, price increases have come on January 1. Allen Barrett BPE, Inc. www.barrettpreceisionengines.com <http://www.barrettpreceisionengines.com/> (918) 835-1089 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Subject: RE: RV10-List: Lycoming Engines Brian, if you knew the differences between the Mattituck TMX540 and BPA's product, you would know the price difference and answer your own question. It's a mater of choice, feature and quality. Now don't forget a Forsling Exhaust System while you are at the Apples and Oranges comparison. I am sure Alan would agree quietly on the side. You will get what you pay for. John - $00.02 ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Re: Aileron trim
How does one cut a small square hole ??? Glad you asked. AFTER I drilled out a round hole, used Dremel disk, bits & then a file to create a somewhat square hole an ole hand showed me his "nibbling tool". Ya start with a 7/16" drilled hole. Insert the (Aircraft Spruce p/n 12-10400 page 548) nibbler and cut away. Have used it many times where I didn't want to take the chance of having a grinding disk, wheel or bit "jump & run". Great for those "odd" shaped holes or corners, trimming inside for a perfect fit. For $16.75 it works wonders and it's a great pilot gag gift. Without the instructions given it's riot to watch someone try to figger out what it is, how it works and what it's for. Wonderful for that "know it all" at the airport. Works on up to 18 Ga steel. KABONG ----- Original Message ----- From: RV Builder (Michael Sausen) To: rv10-list(at)matronics.com Sent: Friday, October 07, 2005 8:53 AM Subject: RE: RV10-List: Aileron trim The Aerotrim unit requires you to cut a small square out of the control surface. ________________________________________________________________________________
Date: Oct 07, 2005
From: "Harris, Jeremy P" <jeremy.p.harris(at)boeing.com>
Re- Wing Parts to have on hand Autopilot servo / wiring if you are going to mount in the wings! -----Original Message----- From: James Ochs [mailto:jochs(at)froody.org] Subject: RV10-List: Wing order + components Ok, I'm getting ready to order the wings. I'd like to get whatever I might need to put in the wing while I'm at it so I don't forget something or have to wait to continue building because I'm waiting for a part. So, I guess this is where a lot of the decisions come ;) The question is, did I miss anything that will be difficult or impossible after the wing is closed: Conduit / bushings for the wiring AOA / pitot tubing coax cable for the wingtip nav / comm antennas aileron trim kit A couple of other questions... having not made an engine decision yet, and suspecting there will be some interesting things happening in the next 2 - 3 years before I'm ready for an engine installation, what would I need to do differently to the fuel plumbing / tanks if I were to use something that required JET-A as opposed to 100LL or mogas? Is there a way to build the tanks / plumbing so that you could use any of the above? Or does it not matter, and the real question is quantity? (I'll leave the traditional vs. non-traditional engine choice discussion for much later when I have acquired a nice nomex suit;) If I have two systems that have AOA (like a dynon or a chelton and the AOA indicator that AFS sells) do I need separate plumbing for both of them or can they share the same ports in the wings the way a pitot-static system can? I like the display of the AOA pro but a lot of the glass units have that feature built in so it would be nice to have them both working. Where are people putting their OAT sensor(s)? What kind of wiring does it require? I'm planning on going with the duckworks light kit, is it easier to install before or after the wing is closed? Thanks James #40400 elevators ________________________________________________________________________________
Date: Oct 07, 2005
BPE's Cold Air Induction WILL work for the IO-580, IO-540 parallel and IO-540 Angle head engines respectfully, However, because of the width of both the angle head I0-540 and IO-580, the cowling is being designed to work with the parallel head IO-540. I'm sure some folks are interested in the angle head engines for the RV-10, but I haven't heard of it being done at this time. Allen Barrett BPE, Inc. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Subject: RE: RV10-List: Lycoming Engines PS. A plug on the Barrett Cold Induction Option and Forsling Tuned Exhaust are important areas for consideration by the mass of RV-10 builders. Many of whom would look to a Subie or Innodyne before fully understanding the approved Firewall Forward choices (Insurable) that fit with VANS cowl and mount. Since you are listening and posting. Thanks for the data. Any chance that the cowl mod you are working on would allow an IO-580X to be hung? John - KUAO ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BPA Subject: RE: RV10-List: Lycoming Engines John, everyone that knows me knows I'm not one to be very quiet! :-) I am in agreement with your statement of choice, feature and quality. Let's clear the air a bit. First, the recent price increase of a crate engine from Vans makes the experimental kits the most cost effective choice. The three shops that are regularly being talked about, BPE, Aerosport & Mattittuck all build very fine engines. We all are on the Lycoming kit engine program for several reasons. We build quality engines, have a good reputation, are dedicated to the GA industry and support our products. If you choose any one of these shops to build your engine, you are going to get a quality product. While some shops offer a base engine purchase price with several performance enhancing upgrades such as balancing, custom painting, porting and polishing, etc etc, and add these costs as you choose, here at BPE we build our experimental engines incorporating these features. We feel this is the right way to build an engine. What I'm trying to say is that while you can purchase a basic engine and add the cost of upgrades, by the time you have an engine that is comparable in options and performance, you'll realize that the price differences are minimal at best. Since the kit engines have become available, the shops in the program have adjusted their prices to take into account their costs. Labor is probably the biggest cost factor in the price differences. We have done some very close evaluation of our costs, and we have adjusted our pricing so that we are very competitive with Aerosport without sacrificing the build quality that we are well known for. The standard IO-540-X engine from us sells for $38,300. A few of the price differences, include our balancing, port/flow match on cylinders, Champion plugs (instead of Unison), all fittings and hoses included, silicon rocker box covers and a 1.5 hour dynamometer test, including a full power run. If you haven't received a quote from us on an engine since September, we'd be happy to review our pricing with you. Here's a price saving tip for anyone - if you are going to need your engine prior to June of 06, go ahead and order your engine before the end of the year. Historically, price increases have come on January 1. Allen Barrett BPE, Inc. www.barrettpreceisionengines.com <http://www.barrettpreceisionengines.com/> (918) 835-1089 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Subject: RE: RV10-List: Lycoming Engines Brian, if you knew the differences between the Mattituck TMX540 and BPA's product, you would know the price difference and answer your own question. It's a mater of choice, feature and quality. Now don't forget a Forsling Exhaust System while you are at the Apples and Oranges comparison. I am sure Alan would agree quietly on the side. You will get what you pay for. John - $00.02 ________________________________________________________________________________
Date: Oct 07, 2005
I think the $34,150 price from Lycoming is an overhauled cost with a core trade in. What is the value of a IO-540 core these days? $10-12K? >Is there a reason that people are talking about the Aerosport >engine at $37,500 over the Teledyne engine at $34,150? William Curtis http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Oct 07, 2005
Allen, This is great information and I will now also consider the BPA IO-540- X. You should add this information and your price list to your web page and loose the music -IMHO. I think you would get some more converts as a result. Just a thought. >Since the kit engines have become available, the shops in the program >have adjusted their prices to take into account their costs. Labor is >probably the biggest cost factor in the price differences. We have done >some very close evaluation of our costs, and we have adjusted our >pricing so that we are very competitive with Aerosport without >sacrificing the build quality that we are well known for. The standard >IO-540-X engine from us sells for $38,300. A few of the price >differences, include our balancing, port/flow match on cylinders, >Champion plugs (instead of Unison), all fittings and hoses included, >silicon rocker box covers and a 1.5 hour dynamometer test, including a >full power run ________________________________________________________________________________
Subject: Re: Wing order + components
Date: Oct 07, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Only absolutely critical item is the pitot mount. Everything else can be added after the wings are closed. It's certainly easier to put the AP roll servo in berfore closing. Pitot tubing and snap bushings come w/the kit. If you go the conduit route instead you'll need to do that before closing. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: RV10-List: Wing order + components Ok, I'm getting ready to order the wings. I'd like to get whatever I might need to put in the wing while I'm at it so I don't forget something or have to wait to continue building because I'm waiting for a part. So, I guess this is where a lot of the decisions come ;) The question is, did I miss anything that will be difficult or impossible after the wing is closed: Conduit / bushings for the wiring AOA / pitot tubing coax cable for the wingtip nav / comm antennas aileron trim kit A couple of other questions... having not made an engine decision yet, and suspecting there will be some interesting things happening in the next 2 - 3 years before I'm ready for an engine installation, what would I need to do differently to the fuel plumbing / tanks if I were to use something that required JET-A as opposed to 100LL or mogas? Is there a way to build the tanks / plumbing so that you could use any of the above? Or does it not matter, and the real question is quantity? (I'll leave the traditional vs. non-traditional engine choice discussion for much later when I have acquired a nice nomex suit;) If I have two systems that have AOA (like a dynon or a chelton and the AOA indicator that AFS sells) do I need separate plumbing for both of them or can they share the same ports in the wings the way a pitot-static system can? I like the display of the AOA pro but a lot of the glass units have that feature built in so it would be nice to have them both working. Where are people putting their OAT sensor(s)? What kind of wiring does it require? I'm planning on going with the duckworks light kit, is it easier to install before or after the wing is closed? Thanks James #40400 elevators ________________________________________________________________________________
Date: Oct 07, 2005
I will quote the Mattituck website: As with all TMX series engines, the TMX-540 will be assembled using 100% new FAA approved and certified parts. The all new part TMX-540 includes the latest roller tappet technology available from Textron Lycoming. The TMXO-540 engine producing 250/260 horsepower is attractively priced at $33,250.00 outright and complete with new Unison/Slick magnetos, new Unison/Slick ignition harness, new Unison/Slick spark plugs, new lightweight Sky-Tec starter, new Lycoming fuel pump and a rebuilt Precision Airmotive carburetor. The TMXIO-540 engine producing 250/260 horsepower is attractively priced at $34,150.00 outright, complete with new Unison/Slick magnetos, new Unison/Slick ignition harness, new Unison/Slick spark plugs, new lightweight Sky-Tec starter, new Lycoming fuel pump and a complete new Precision Airmotive SilverHawk EX or Airflow Performance EX fuel injection system. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Subject: RV10-List: RE: Lycoming Engines I think the $34,150 price from Lycoming is an overhauled cost with a core trade in. What is the value of a IO-540 core these days? $10-12K? >Is there a reason that people are talking about the Aerosport >engine at $37,500 over the Teledyne engine at $34,150? William Curtis http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Oct 07, 2005
Not if you are burning 10 or less GPH of mogas @$3 or less a gallon. Probably equals out or even comes in under the cost of Avgas for a cert engine combo. Michael Sausen -10 # 352 Flaps ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DOUGPFLYRV(at)aol.com Subject: Re: RV10-List: RE: Lycoming Engines There is the extra 15 hours of test period for non-certified engine/prop. The fuel could cost $700 and up for that extra time. Doug Preston ________________________________________________________________________________
Date: Oct 07, 2005
I did the duckworks HID while I was working on that part of the wing. It will be easier to get the nutplates and mounting bracket in place before you rivet on the leading edge. I even put nutplates in place in the opposite wing in case I decide to add a second kit down the road. Don't forget position lights also. If you go with the AoA from Rob, you can also get the wing kit and put that in at the same time as the duckworks HID. It sits just aft of the HID. Others have already mentioned the Pitot and AP. Just don't forget to order the AP servo for the opposite wing if you get Van's Aileron trim. For fuel tanks you could do a couple things. First, JetA or any other heavy fuel needs positive ventilation so you will need to work that out. I would talk to the guys at Deltahawk for specifics. Second, if you go with an engine conversion like Eggs Subaru you will need a return line for the fuel as they are constant supply. There is info on Egg's website but basically it's just an additional bulkhead in the -5 size in the vicinity of the vent connected to a tube that dumps into the second bay from the supply line so you don't get bubbles. If you are considering it you can put in the bulkhead and just cap it if you don't use it. Michael Sausen -10 #352 Flaps -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: RV10-List: Wing order + components Ok, I'm getting ready to order the wings. I'd like to get whatever I might need to put in the wing while I'm at it so I don't forget something or have to wait to continue building because I'm waiting for a part. So, I guess this is where a lot of the decisions come ;) The question is, did I miss anything that will be difficult or impossible after the wing is closed: Conduit / bushings for the wiring AOA / pitot tubing coax cable for the wingtip nav / comm antennas aileron trim kit A couple of other questions... having not made an engine decision yet, and suspecting there will be some interesting things happening in the next 2 - 3 years before I'm ready for an engine installation, what would I need to do differently to the fuel plumbing / tanks if I were to use something that required JET-A as opposed to 100LL or mogas? Is there a way to build the tanks / plumbing so that you could use any of the above? Or does it not matter, and the real question is quantity? (I'll leave the traditional vs. non-traditional engine choice discussion for much later when I have acquired a nice nomex suit;) If I have two systems that have AOA (like a dynon or a chelton and the AOA indicator that AFS sells) do I need separate plumbing for both of them or can they share the same ports in the wings the way a pitot-static system can? I like the display of the AOA pro but a lot of the glass units have that feature built in so it would be nice to have them both working. Where are people putting their OAT sensor(s)? What kind of wiring does it require? I'm planning on going with the duckworks light kit, is it easier to install before or after the wing is closed? Thanks James #40400 elevators ________________________________________________________________________________
Date: Oct 07, 2005
I did not see fuel level senders mentioned, which are another item for the list. I believe Randy has his OAT in the fuselage fresh air inlet and William Curtis is putting it somewhere on the wing (per his electrical schematic) Larry Rosen RV Builder (Michael Sausen) wrote: > I did the duckworks HID while I was working on that part of the > wing. It will be easier to get the nutplates and mounting bracket in > place before you rivet on the leading edge. I even put nutplates in > place in the opposite wing in case I decide to add a second kit down > the road. > > Don't forget position lights also. If you go with the AoA from Rob, > you can also get the wing kit and put that in at the same time as the > duckworks HID. It sits just aft of the HID. Others have already > mentioned the Pitot and AP. Just don't forget to order the AP > servo for the opposite wing if you get Van's Aileron trim. > > For fuel tanks you could do a couple things. First, JetA or any > other heavy fuel needs positive ventilation so you will need to work > that out. I would talk to the guys at Deltahawk for specifics. > Second, if you go with an engine conversion like Eggs Subaru you will > need a return line for the fuel as they are constant supply. There is > info on Egg's website but basically it's just an additional bulkhead > in the -5 size in the vicinity of the vent connected to a tube that > dumps into the second bay from the supply line so you don't get > bubbles. If you are considering it you can put in the bulkhead and > just cap it if you don't use it. > > Michael Sausen > -10 #352 Flaps > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs > Sent: Friday, October 07, 2005 12:16 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Wing order + components > > > Ok, I'm getting ready to order the wings. I'd like to get whatever I > might need to put in the wing while I'm at it so I don't forget > something or have to wait to continue building because I'm waiting for > a part. > > So, I guess this is where a lot of the decisions come ;) > > The question is, did I miss anything that will be difficult or > impossible after the wing is closed: > > Conduit / bushings for the wiring > AOA / pitot tubing > coax cable for the wingtip nav / comm antennas aileron trim kit > > A couple of other questions... having not made an engine decision yet, > and suspecting there will be some interesting things happening in the > next 2 - 3 years before I'm ready for an engine installation, what > would I need to do differently to the fuel plumbing / tanks if I were > to use something that required JET-A as opposed to 100LL or mogas? Is > there a way to build the tanks / plumbing so that you could use any of > the above? Or does it not matter, and the real question is quantity? > (I'll leave the traditional vs. non-traditional engine choice > discussion for much later when I have acquired a nice nomex suit;) > > If I have two systems that have AOA (like a dynon or a chelton and the > AOA indicator that AFS sells) do I need separate plumbing for both of > them or can they share the same ports in the wings the way a > pitot-static system can? I like the display of the AOA pro but a lot > of the glass units have that feature built in so it would be nice to > have them both working. > > Where are people putting their OAT sensor(s)? What kind of wiring > does it require? > > I'm planning on going with the duckworks light kit, is it easier to > install before or after the wing is closed? > > Thanks > James > #40400 > elevators > > > ==================================== > RV10-List Email Forum - > more: > bsp; > ==================================== > > ________________________________________________________________________________
Date: Oct 07, 2005
I guess I did not fully understand the question. I guess we would need to know what is included in the Matituck engine at 34,150 vs. the Aerosport or BPA engine at $37,500 and $38,300 respectively. All the major components would be the same as they would be all new Lycoming parts. Here is my summary of the engine options so far: Lyc(Airpower)- IO-540-D4A5 - $31,417 Factory rebuilt with core trade in Lyc (Vans) - IO-540-D4A5 - $42,650 Certified Lycoming Mattituck - TMXIO-540-X - $34,150 all new Clone Aerosport - IO-540-X - $37,500 all new Clone BPA - IO-540-X - $38,300 all new Clone Lyc(Airpower)- O-540-E4A5 - $27,000 Factory rebuilt with core trade in Lyc (Vans) - O-540-A4D5 - $37,500 Certified Lycoming Mattituck - TMXO-540-X - $33,250 all new Clone Aerosport - O-540-X - $36,000 all new Clone BPA - O-540-X - $??,000 all new Clone >Is there a reason that people are talking about the Aerosport >engine at $37,500 over the Teledyne engine at $34,150? William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Subject: Quick build
Date: Oct 08, 2005
Just wondering, when assembling my 7A empennage I polished, anodised and primed every component before assembly. upon receiving my quick build kit and with regard to corrosion protection, I thought that the quality of the priming job of the kit left a little to be desired, granted the quality of riveting was A1. Do any of the other members of the group have any reservations at all about going the Quick Build route ?. I would like to hear your thoughts. If it were not for this minor gripe I would go the A/B on my 10 or any other RV in a heart beat - the saving in time alone makes the Q/K unbeatable value. Paul Walter ________________________________________________________________________________
Date: Oct 07, 2005
You have great goals. Here is my recommendations to anyone building a RV10. 1 Go quick build unless you have a plane that you fly now or you are retired and love to build. It will take months off of most peoples build times. 2 Plan on 150,000.00 for a good IFR platform. If you save a buck here and there, great. you won't be upset when it comes in a little more. 3 Have the panel built by someone, anyone. It will cut 2 monthes off of the project. I would also recommend that the person wiring the panel is also someone who wires entire planes as well. If you do the airframe wiring yourself and they are doing the panel, the wire gauges can all be worked out very easily. Don't know what wire gets run for the pitot heat? Just ask them, they do it all day long. 4 Get help. Deburing isn't hard and a local kid that want's to get involved in the project, or as I lucked into a great retired guy that also want to build a plane. The plane isn't hard to build but it does require the hours to be spent. 5 You must build at home or live in the hanger. Do not take the kids to socker practice, do not go out to dinner more the 1 night a week. Do not cut the grass until you absolutly have to. It is a major waste of time that could be better spent working on the plane. Do not fix up the house, that can come after the plane is built. 6 Oh one more thing. Leave the Web sites to someone else. There as some great ones out there you can't compete with them, and it is time that would be better spent reading the plans for tomorrows tasks. 7 If you want to build fast - don't prime. I primed and I would do it again but I am not convinced it the best thing since sliced bread. 2200 hours slow build. 1800 hours QB. I think one year is doable but you better stay away from that lawn or it will be 1 1/2 years. Randy ________________________________
From: owner-rv10-list-server(at)matronics.com on behalf of John Jessen
Subject: RE: RV10-List: Real time and cost to build? From a new subscriber Mike, Good questions. A trip through the land of RV web sites will help you, greatly. Also, search the archives. There are many references there as to the time to build and costs. I cannot do anything but give you a projected cost range that I came up with for my purposes (IFR panel, new engine, etc), and that was between $120,000 to $140,000. I hope the estimated range is high; I doubt it. But to me, the one thing that disturbed me about your post was the "need" to get this done within a year or less. Randy, the first totally completed RV-10 to fly, was finished in 20 months, with help, both in terms of physical labor, but also in terms of subsections being farmed out, such as the panel. (Randy can fill you in on exactly what were his shortcuts.) Twenty months is fast, my friend. I expect to take between 24 and 48 months, depending if I, too, go QB, which is still being debated. For a plane of this complexity, anything south of 24 months would be proud to crow about, but less than 12? Please don't set that as your goal. This stuff is doable, but it is not strictly a Lego or erector set. By the way, I work on it each evening for 2 hours (when I'm not traveling on business) and each and every weekend for at least 6 hours (when I'm not being pulled away by others who don't understand the passion and addiction, but whose needs must be recognized - none of us are total recluses, yet), and there's no way that I could get it done in less time than Randy's 20 months. I have all the tools, and the requisite knowledge and skills, and there's no way. In short, enjoy the process, build well and have some fun...or, buy one already built. I'm sure there will be a few up for sale soon. My best, John Jessen 40328 HS -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lee Subject: RV10-List: Real time and cost to build? From a new subscriber OK I am sure this has been asked before, but maybe someoneone could send me copies of any list digests with information on this, or just reply directly. I am ver seriously considering an RV-10 project. What I would like is information from real builders on the following: Assuming the following: 1) RV-10 Quick build kit 2) Builder has good mechanical aptitude and electonics experience. 3) Never built an airplane before, or any project of this size. 4) Planning to keep customizations to a minimum. 5) Need to keep costs down, planning on finding a used mid time engine, CS prop, analog engine gauges, basic JPI engine monitor, will shell out $ for a Garmin 530 / 430 combo and indicators. 6) Want an IFR platform (hence the 530 / 430 combo) 7) GPS / Nav coupled auto pilot with altitude hold. 8) Will paint myself, will have uphoulstry done. 9) Basic sound proofing. 10) Wingtip stobes, plus stobe beacon, otherwise standard lighting with taxi / landing light. Can I get an estimate of build time and costs? What types of unexpected costs that are not in the above are there? Anyone else out there with similar goals / expectaions? What are other builders doing to keep costs down? I know I can save some $$ by buying a standard kit instead of a quick build, but I have a need to have the aircraft done in less than a year, working evenings and weekends. THANKS!!!!! for any and all help! Mike ________________________________________________________________________________
Subject: FW: Group buy on covers.
Date: Oct 07, 2005
Yes. It is a 7" piece of tapered wood painted white. It is adjustable with a saw and more paint. It is being modified about every 4th flight. I think it will end up 4" tall by 1" front to back and 1/4" thick in the back of the rudder and tapers down to nothing on the front. After that I will glass and paint in a permanent piece. Most of my longer trips are on autopilot so the use of trim other than elevator has not been needed. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Conti, Rick Subject: RE: RV10-List: FW: Group buy on covers. Randy, I have surfed your site and watched your videos. Excellent job. Do you have a rudder trim assembly on your 10? Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 ________________________________ From: Randy DeBauw [mailto:Randy(at)abros.com] Subject: RV10-List: FW: Group buy on covers. Here is a response from Abby on the light weight travel covers. Randy ________________________________ From: FLIGHTLINE INTERIORS [mailto:flightline(at)tds.net] Subject: Fw: Group buy on covers. ----- Original Message ----- From: FLIGHTLINE INTERIORS <mailto:flightline(at)tds.net> Subject: Re: Group buy on covers. Sorry, I didn't even really answer your questions. I don't have it patterned right now, but given a little time I could have it patterned. It is made of Ripstop Nylon fabric. It would come with its own storage bag. They would probably be somewhere around $225 each. Thanks, Abby ----- Original Message ----- From: Erdmann's <mailto:erdmannb(at)execpc.com> To: FLIGHTLINE INTERIORS Sent: Saturday, October 01, 2005 7:47 AM Subject: Fw: Group buy on covers. ----- Original Message ----- From: Randy's Abros mail <mailto:randy(at)abros.com> To: erdmannb(at)execpc.com Sent: Thursday, September 29, 2005 1:20 PM Subject: Group buy on covers. The RV10 list is all a flutter with people wanting to be involved in a group buy (my guess is 15 to 20) on canopy covers for the 10. They have been taking to Bruce at Bruce's Covers. I think most don't want the heavy cover. I think if you give your regular price and what it is made of and what includes I can relay it to the group and give them an option. Thanks and I hope things are will. Randy ________________________________________________________________________________
Subject: Engine
Date: Oct 08, 2005
While on the engine subject, does the 540 come in any variant that does not require that ugly snorkel under front of engine cowl. I think the 200 hp version of the 360 for RV 7 & 8 does away with snorkel so thought it may be possible. Paul ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Re: Quick build
It is the same with the quick build for the 10. The quality of the fabrication is top rate. But, the priming leaves much to be desired. It seem that most structure was put together and then it was primed. I am going to re-prime with AKZO the areas that get sealed up. This will leave the areas where you want the protection the most, where the ribs meet the skin un-primed. This is the trade off that in my opinion is well worth if for the amount of time the quick build will save. Larry Rosen 40356 Paul Walter wrote: > Just wondering, > when assembling my 7A empennage I polished, anodised and primed every > component before assembly. > upon receiving my quick build kit and with regard to corrosion > protection, I thought that the quality of the priming job of the kit > left a little to be desired, granted the quality of riveting was A1. > > Do any of the other members of the group have any reservations at all > about going the Quick Build route ?. I would like to hear your thoughts. > If it were not for this minor gripe I would go the A/B on my 10 or > any other RV in a heart beat - the saving in time alone makes the Q/K > unbeatable value. > > Paul Walter > > > ________________________________________________________________________________
Subject: Quick build -> Akzo
Date: Oct 08, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
I'm guessing Paul meant alodined below. But I digress. My question is this, with Azko is it truly a primer/sealer? I haven't done a whole lot of digging but the only references I have ever seen are to it being a primer. The PPG DP40 I use is also a epoxy primer and only becomes a sealer when its mixed with a reducer. Presumably to make it flow out better. Not trying to start a controversy or anything, just trying to raise the observation. Either way I'm sure it's more than adequate for our use. Michael Sausen -10 #352 Flaps -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Subject: Re: RV10-List: Quick build It is the same with the quick build for the 10. The quality of the fabrication is top rate. But, the priming leaves much to be desired. It seem that most structure was put together and then it was primed. I am going to re-prime with AKZO the areas that get sealed up. This will leave the areas where you want the protection the most, where the ribs meet the skin un-primed. This is the trade off that in my opinion is well worth if for the amount of time the quick build will save. Larry Rosen 40356 Paul Walter wrote: > Just wondering, > when assembling my 7A empennage I polished, anodised and primed every > component before assembly. > upon receiving my quick build kit and with regard to corrosion > protection, I thought that the quality of the priming job of the kit > left a little to be desired, granted the quality of riveting was A1. > > Do any of the other members of the group have any reservations at all > about going the Quick Build route ?. I would like to hear your thoughts. > If it were not for this minor gripe I would go the A/B on my 10 or > any other RV in a heart beat - the saving in time alone makes the Q/K > unbeatable value. > > Paul Walter > > ________________________________________________________________________________
Subject: Engine
Date: Oct 08, 2005
Paul, By "ugly snorkel" do you mean that sweet-looking air intake underneath the spinner? I think part of the purpose of that is to get quasi ram-air (even though it is going through the filter) and to get cooler air into the engine that isn't being preheated by cooling the cylinders. I could be way off, but I wouldn't trade that look for a smooth bottom cowl unless performance would noticeable increase. $.02 Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Walter Subject: RV10-List: Engine While on the engine subject, does the 540 come in any variant that does not require that ugly snorkel under front of engine cowl. I think the 200 hp version of the 360 for RV 7 & 8 does away with snorkel so thought it may be possible. Paul ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Real time and cost to build? From a new subscriber
Randy forgot one last thing, Get a good divorce lawyer unless you are single or have a great spouse that will totally understand and support you in the process. I highly suggest reading Dan Checkoway's "The married dudes guide to aircraft building". Link is pasted below. I thank my better half on a daily basis for understanding this obsession, which it will become, trust me. http://www.rvproject.com/wife.html Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 08, 2005
The Grezt mount is a great product, mine came out perfectly and you get an appreciation for what it is like to have to lay out a few rivet holes with a ruler. Heres a shot of mine with Jon Johanson heated pitot. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Re: Engine
Take a good look at the front of a HRII Rocket (RV-4 on steroids). IO-540 with the P-51 Mustang style intake. Would take a little glass work but worth (IMNSHO) it. John Harmon makes two separate adaptors to fit the cowl to the intake. You would need the 90 degree "elbow" for the engine and the fiberglass "smiley" for the cowl. N561FS with the MT 4 blade too really looks "goood". KABONG Do Not Archive. ----- Original Message ----- From: Paul Walter To: rv10-list(at)matronics.com Sent: Saturday, October 08, 2005 2:20 AM Subject: RV10-List: Engine While on the engine subject, does the 540 come in any variant that does not require that ugly snorkel under front of engine cowl. I think the 200 hp version of the 360 for RV 7 & 8 does away with snorkel so thought it may be possible. Paul ________________________________________________________________________________
Date: Oct 08, 2005
Wait a second! That's a pretty sick to suggest choosing an airplane over a wife. If you do start getting AIDS, then get rid of the source of the problem (the airplane) not the victim of the problem (the wife). Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: RE: RV10-List: Real time and cost to build? From a new subscriber Randy forgot one last thing, Get a good divorce lawyer unless you are single or have a great spouse that will totally understand and support you in the process. I highly suggest reading Dan Checkoway's "The married dudes guide to aircraft building". Link is pasted below. I thank my better half on a daily basis for understanding this obsession, which it will become, trust me. http://www.rvproject.com/wife.html Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 08, 2005
Nice work. We added the Gretz mount after the wing was finished which was a fair bit more work. We also just added a heated pitot to replace the Dynon AOA pitot. Fortunately we were able to fish the heated pitot power wire through the AOA pitot tube which was not needed anymore. Wiring that thing up and hooking up the pitot line was a lot of work with the wing closed up and on the plane. All this to say, everybody should decide what pitot they are going with before they finish their wings so they can do something like you did and make it fairly easy to remove and replace if there is a problem. I really like Tim's idea of putting it further out the wing where it can be accessed from the open wingtip. It is a pain working around the aileron controls to get a the pitot to replace it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: Re: RV10-List: Wing order + components The Grezt mount is a great product, mine came out perfectly and you get an appreciation for what it is like to have to lay out a few rivet holes with a ruler. Heres a shot of mine with Jon Johanson heated pitot. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Heated Pitot, AoA ports
Anyone know the price of the Gretz heated Pitot? Their website doesn't even list it! Also, when should you buy/install the Angle of Attack ports? Any info on this would be helpful, since I've never dealt with AoA instruments before. -Jim 40384 ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Re: Heated Pitot, AoA ports
You can get it from SteinAir here <http://www.steinair.com/accessories.htm>. Cost is $425. Do not know what the cost is if you get it directly from Gretz. I believe you need to call or email Gretz. If you get a price from Gretz email back to the list an let us know. Stein also has the mount. $118 for chrome, $95 unpainted. Larry Rosen 40256 N205EN (reserved) Working on the bagage door today James Hein wrote: > > Anyone know the price of the Gretz heated Pitot? Their website doesn't > even list it! > > Also, when should you buy/install the Angle of Attack ports? Any info > on this would be helpful, since I've never dealt with AoA instruments > before. > > -Jim 40384 > > ________________________________________________________________________________
Date: Oct 08, 2005
Jim, Try Stein. http://www.steinair.com/accessories.htm Rob Hunter 40432 H/S -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of James Hein Subject: RV10-List: Heated Pitot, AoA ports Anyone know the price of the Gretz heated Pitot? Their website doesn't even list it! Also, when should you buy/install the Angle of Attack ports? Any info on this would be helpful, since I've never dealt with AoA instruments before. -Jim 40384 ________________________________________________________________________________
Date: Oct 08, 2005
I just talked to him the other day and I think he said it was $425. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: RV10-List: Heated Pitot, AoA ports Anyone know the price of the Gretz heated Pitot? Their website doesn't even list it! Also, when should you buy/install the Angle of Attack ports? Any info on this would be helpful, since I've never dealt with AoA instruments before. -Jim 40384 ________________________________________________________________________________
Date: Oct 08, 2005
Same price directly from him. Go with who ever has them in stock. Warren just got more in about 2 weeks ago after a couple month wait on his molder so make sure you order it well before you need it. Mounts shouldn't be a problem and I would just go with the paintable one if you get his pitot as it's a type of plastic so you can't chrome it. Michael Sausen -10 #352 Flaps -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Subject: Re: RV10-List: Heated Pitot, AoA ports You can get it from SteinAir here <http://www.steinair.com/accessories.htm>. Cost is $425. Do not know what the cost is if you get it directly from Gretz. I believe you need to call or email Gretz. If you get a price from Gretz email back to the list an let us know. Stein also has the mount. $118 for chrome, $95 unpainted. Larry Rosen 40256 N205EN (reserved) Working on the bagage door today James Hein wrote: > > Anyone know the price of the Gretz heated Pitot? Their website doesn't > even list it! > > Also, when should you buy/install the Angle of Attack ports? Any info > on this would be helpful, since I've never dealt with AoA instruments > before. > > -Jim 40384 > > ________________________________________________________________________________
Date: Oct 08, 2005
$425.00, and the mount is sold separately (some want a chrome mount and some want un-painted mounts) Same price whether you buy them from me or Gretz or his other dealers. The AOA ports are most easily installed during wing construction, but can be retro-fitted later if need be. It's just easier to do both when working on the wings. Cheers, Stein. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of James Hein Subject: RV10-List: Heated Pitot, AoA ports Anyone know the price of the Gretz heated Pitot? Their website doesn't even list it! Also, when should you buy/install the Angle of Attack ports? Any info on this would be helpful, since I've never dealt with AoA instruments before. -Jim 40384 ________________________________________________________________________________
Subject: Van's stall warning switch
Date: Oct 08, 2005
To anyone who has installed Vans's stall warning switch: Instructions call for adjusting the switch for minimal travel for activation/deactivation. I have adjusted for 1/8 inch travel for activation, is that about right? Still plenty of room for the vane to travel in the slot I'm not sure what dimension "minimal" is. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Re: Van's stall warning switch
John, I adjusted mine so the switch closure occurs (when the switch is mounted in the wing) at mid travel in the opening. There are instructions indicating a preferred angle as the tab comes from the leading edge. You just need to make sure the switch is going to activate, de-activate for the given mounting position and skin opening. However, I am not flying yet, so there may be some adjusting required. Also, I am planning on using an Angle Of Attack sensor as well. I still question why put in the stall warning switch if AOA is installed too. I just didn't have a good reason not to go ahead in put it in. Jim Combs #40192 - N312F - Fuselage ---------- Original Message ---------------------------------- From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com> Date: Sat, 8 Oct 2005 15:37:23 -0400 To anyone who has installed Vans's stall warning switch: Instructions call for adjusting the switch for minimal travel for activation/deactivation. I have adjusted for 1/8 inch travel for activation, is that about right? Still plenty of room for the vane to travel in the slot I'm not sure what dimension "minimal" is. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 08, 2005
Hello Listers, The GA-1000 is $425 if you purchase it directly from me or Stein Air. I do have them in stock currently, but they have been going fast. It is a good idea to order the GA-1000 before you really need it to make sure it is available. I am working on getting the manufacturing process done faster, but it is taking time to gear up to the demand. The mounting bracket kits are nearly always in stock. I have been soooo busy in getting the GA-1000 made and out the door I have not had time to complete the new website. It should be done shortly however. Meanwhile, you can call me or e-mail me to order or to ask questions. The best number to call me is 208-834-2312 which is the Gretz Aero office phone. I will be traveling Sunday 10-9-05 to Thursday 10-13-05. You can call my cell phone while I am traveling. The cell phone is 720-308-0010. When I am at my home or office the cell phone does not work (no cell site here). I will be checking the 208 number while traveling and will return calls once I pick them up. I will accept VISA or MASTERCARD for payment. I hope this helps. Warren Gretz Gretz Aero ---- wrote: > > > Anyone know the price of the Gretz heated Pitot? Their website doesn't > even list it! > > Also, when should you buy/install the Angle of Attack ports? Any info on > this would be helpful, since I've never dealt with AoA instruments before. > > -Jim 40384 > > > > > > > > > > > > > Warren Gretz Gretz Aero ________________________________________________________________________________
Date: Oct 08, 2005
Subject: Re: RE: Lycoming Engines Copperstate visit
Well: good news,bad news, 1st the bad news, Jan wasn't @ Copperstate, They had a booth but the girl in the booth said he was out of the country. The only person available to ask questions to was an RV 7A Builder with an H6 installation who had his plane there (nice!) and has been working w/ Jan doing some recent testing (There's a recent blurb on the Egg website). He really wasn't knowledgeable regarding any plans for a-10 installation. And neither was anybody else in the booth. It seems their sweet spot is the 4cly Lyc 360 market and for that application I think it's a good fit, it would also be a good fit for anybody that had been thinking about the Continental for the RV-10. After thinking on this some more, not withstanding the benefits of lower cost, reliability(implied), smoothness, newer technology,Mogas etc. I'm uncomfortable with a), a lesser rated HP (240-??). and b). in order to get even that HP they have to spin the engine a lot faster than they do for the 200 hp versions. Close to or @ redline. And then they have to supercharge it. Seems that's pushing the envelope towards an edge that hasn't been proved (in aircraft) yet. It may be that this all proves to be non issues in the future, but I'm looking to get as close to 200mph out of my 10 as I can (just ego). And going to a less powerful platform, that's already pushed towards the upperend of it's performance envelope, isn't where I think I want to be. I'll continue to watch and listen to any developments, but won't be putting the Subie in any critical path on my project plan. If theres an RV-10 program in the future @ Egg, then Jan is probably the only person who knows about it. (And the looks of those tow mufflers hanging below the cowl also turns me off) Talked with a couple of other engine builders who were all quoting prices and functions similar to what has been reported on this list. They, are sending quotes and options via snail mail. The good news, (depending on when you need your engine), I spoke with the ECI/Titan folks and they are well into their 540 program and if you can wait til next Sept for your engine, they will be ready with all of the parts, They were partnered with an engine rebuilder from SanAntinio Tx. who was in the booth next to them, and he indicated that he expected the price to be just under 30k. His costs estimates were derived from a combination of 1. what his cost are to build an Titan 360 currently using ECI parts, and 2. What his cost are to rebuild a 540 using the ECI cyl assemblies. That's all new everything. with a stronger case, some improvements where the case and crank mate. That will not include the roller tappet technology that Lyc is now pushing. (heard a RUMOR that its not as rosy as hoped for and the added complexity is taking a toll) I've got some information and a CD that I will need to wade through over the next few days in order to better compare apples to apples, but it certainly sounds interesting, and while the timeline is a bit longer than I'd like, As most projects seem to go that'll probably still end up within my window. I looked for an insurance underwriter or agent to ask Michaels question to, but none were there. Deems Davis # 406 Wing Ribs http://deemsrv10.com/ Bill and Tami Britton wrote: > >Deems, get all the info you can get out of Jan at Copperstate and please >report back. I've been interested in his engines since I first found out >about them a couple years back. I was ready to buy one of his 2.5's when I >was planning on a RV-7, but now that I'm building a -10 I really hope he can >make the H-6 work. The only thing that still bugs me a little is the high >RPM's on take off. I know the engines do that all the time in the cars, but >it just sounds too high. Probably won't be a problem. > >Anyway, please report back if you have time. > >Bill Britton >RV-10 #40137 >Elevators in progress >----- Original Message ----- >From: "Deems Davis" <deemsdavis(at)cox.net> >To: >Sent: Thursday, October 06, 2005 3:35 PM >Subject: Re: RV10-List: RE: Lycoming Engines > > > > >> >>This is making the Egg/Subie look more and more interesting to me. He' >>going to be @ Copperstate this weekend, and I look forward to hearing >>1st hand about his plans for the RV-10 installation. >>(I just saw on ANN an AD for Lyc 360 & 540 cranks, maybe this is how Lyc >>expects to pay for it) >> >>Deems Davis # 406 >>Wing Main Spar >>http://deemsrv10.com/ >> >>William Curtis wrote: >> >> >> >>>Yup, they raised the price of the 260HP IO-540 from $38,990 to >>>$42,650, an over $3,600 increase. However they now have an offering of >>>the 250HP O-540 for $37,500. Other than fuel injection, anyone know >>>what else is different between these engines? It would seem you could >>>get the O and add fuel injection for a lot less than $5,150 or FADEC >>>for a little more. I think Ill be looking at the IO-540 clone from >>>Aerosport. Maybe in these days of $5 avgas, they will reconsider the >>>210HP Continental IO-360. >>> >>> >>> >>>>Back to the engine question. I am getting close to ordering one and >>>> >>>> >>>noticed >>> >>> >>>>that Vans prices went up considerably for the IO540. Does anyone know >>>> >>>> >if > > >>>>this has the new tapped technology? >>>> >>>> >>>William Curtis >>>40237 - wings >>>http://wcurtis.nerv10.com/ >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > ________________________________________________________________________________
Subject: Re: Real time and cost to build? From a new subscriber
Date: Oct 08, 2005
I took the SportAir course on sheet metal building last week. The question of QB vs SB came up. The EAA guy said "why should I spend twice as much for half the fun?" While some people are indeed in a hurry to fly - and there certainly is nothing wrong with that - some seem to like the process of building as much as flying. ----- Original Message ----- From: "Randy DeBauw" <Randy(at)abros.com> Subject: RE: RV10-List: Real time and cost to build? From a new subscriber You have great goals. Here is my recommendations to anyone building a RV10. 1 Go quick build unless you have a plane that you fly now or you are retired and love to build. It will take months off of most peoples build times. 2 Plan on 150,000.00 for a good IFR platform. If you save a buck here and there, great. you won't be upset when it comes in a little more. 3 Have the panel built by someone, anyone. It will cut 2 monthes off of the project. I would also recommend that the person wiring the panel is also someone who wires entire planes as well. If you do the airframe wiring yourself and they are doing the panel, the wire gauges can all be worked out very easily. Don't know what wire gets run for the pitot heat? Just ask them, they do it all day long. 4 Get help. Deburing isn't hard and a local kid that want's to get involved in the project, or as I lucked into a great retired guy that also want to build a plane. The plane isn't hard to build but it does require the hours to be spent. 5 You must build at home or live in the hanger. Do not take the kids to socker practice, do not go out to dinner more the 1 night a week. Do not cut the grass until you absolutly have to. It is a major waste of time that could be better spent working on the plane. Do not fix up the house, that can come after the plane is built. 6 Oh one more thing. Leave the Web sites to someone else. There as some great ones out there you can't compete with them, and it is time that would be better spent reading the plans for tomorrows tasks. 7 If you want to build fast - don't prime. I primed and I would do it again but I am not convinced it the best thing since sliced bread. 2200 hours slow build. 1800 hours QB. I think one year is doable but you better stay away from that lawn or it will be 1 1/2 years. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of John Jessen Subject: RE: RV10-List: Real time and cost to build? From a new subscriber Mike, Good questions. A trip through the land of RV web sites will help you, greatly. Also, search the archives. There are many references there as to the time to build and costs. I cannot do anything but give you a projected cost range that I came up with for my purposes (IFR panel, new engine, etc), and that was between $120,000 to $140,000. I hope the estimated range is high; I doubt it. But to me, the one thing that disturbed me about your post was the "need" to get this done within a year or less. Randy, the first totally completed RV-10 to fly, was finished in 20 months, with help, both in terms of physical labor, but also in terms of subsections being farmed out, such as the panel. (Randy can fill you in on exactly what were his shortcuts.) Twenty months is fast, my friend. I expect to take between 24 and 48 months, depending if I, too, go QB, which is still being debated. For a plane of this complexity, anything south of 24 months would be proud to crow about, but less than 12? Please don't set that as your goal. This stuff is doable, but it is not strictly a Lego or erector set. By the way, I work on it each evening for 2 hours (when I'm not traveling on business) and each and every weekend for at least 6 hours (when I'm not being pulled away by others who don't understand the passion and addiction, but whose needs must be recognized - none of us are total recluses, yet), and there's no way that I could get it done in less time than Randy's 20 months. I have all the tools, and the requisite knowledge and skills, and there's no way. In short, enjoy the process, build well and have some fun...or, buy one already built. I'm sure there will be a few up for sale soon. My best, John Jessen 40328 HS -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lee Subject: RV10-List: Real time and cost to build? From a new subscriber OK I am sure this has been asked before, but maybe someoneone could send me copies of any list digests with information on this, or just reply directly. I am ver seriously considering an RV-10 project. What I would like is information from real builders on the following: Assuming the following: 1) RV-10 Quick build kit 2) Builder has good mechanical aptitude and electonics experience. 3) Never built an airplane before, or any project of this size. 4) Planning to keep customizations to a minimum. 5) Need to keep costs down, planning on finding a used mid time engine, CS prop, analog engine gauges, basic JPI engine monitor, will shell out $ for a Garmin 530 / 430 combo and indicators. 6) Want an IFR platform (hence the 530 / 430 combo) 7) GPS / Nav coupled auto pilot with altitude hold. 8) Will paint myself, will have uphoulstry done. 9) Basic sound proofing. 10) Wingtip stobes, plus stobe beacon, otherwise standard lighting with taxi / landing light. Can I get an estimate of build time and costs? What types of unexpected costs that are not in the above are there? Anyone else out there with similar goals / expectaions? What are other builders doing to keep costs down? I know I can save some $$ by buying a standard kit instead of a quick build, but I have a need to have the aircraft done in less than a year, working evenings and weekends. THANKS!!!!! for any and all help! Mike ==================================== ==================================== ________________________________________________________________________________
Date: Oct 08, 2005
For me, it was their performance work plus the 3 year parts and warranty.... grumpy #40404 In a message dated 10/7/2005 3:44:06 PM Central Standard Time, wcurtis(at)core.com writes: >Is there a reason that people are talking about the Aerosport >engine at $37,500 over the Teledyne engine at $34,150? William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Subject: Engine Talk...
Date: Oct 08, 2005
All this engine talk makes me wonder... is there any data out there which compares the average time on wing or time to major maintenance (top overhaul, new cylinder required, something flat out fails) for all of the more popular engine builders or the factory. Granted there are a lot of variables on the engine once it leaves the builder but it would be interesting to see who has the least failures overall regardless of who is maintaining the engine or what aircraft it is flying in etc. Chris Lucas #40072 ________________________________________________________________________________
Subject: Re: Engine Talk...
Date: Oct 08, 2005
----- Original Message ----- From: Chris To: rv10-list(at)matronics.com Sent: Saturday, October 08, 2005 10:36 PM Subject: RV10-List: Engine Talk... All this engine talk makes me wonder... is there any data out there which compares the average time on wing or time to major maintenance (top overhaul, new cylinder required, something flat out fails) for all of the more popular engine builders or the factory............. Great question Chris, I can't think of any source that might have reliable data. Aviation Consumer and similar pubs do a good bit of surveying but they are still taking a small sample. Reputations, good and bad, are quickly magnified by lists like ours. To add another data point; G&N Aircraft in Griffith, IN www.gnaircraft.com/ is another of the authorized Lycoming clone builders. (Ask for Dennis Wyman) A friend of mine and I had very similar 0-320 run-outs overhauled there. Both engines are still running strong at 700 hours (80/80 compression) for me and my friend who must be around 1000 hours now. I think any of the major reputable re-builders would be a safe choice. I am sure also that there are many small local shops that do quality rebuilds as well. Even the best will probably suffer a rare engine that does not do well early in its service cycle. This is one reason why for me at least, I want an engine that has been through a test cell run prior to delivery. As you mentioned , I think the biggest factor is the operator. A great engine rebuild can be destroyed in the first few hours if it is abused. Dick Sipp RV4 N250DS RV10 40065 ________________________________________________________________________________
Date: Oct 09, 2005
Subject: Re: Heated Pitot Gretz mount
What do you do, just center the aluminum tubing in the mount, cut it long, and then trim to fit when you install the heated pitot tube? Larry Rosen N205EN (reserved) Tim Olson wrote: > > > 1. You can just install the pitot mount, but you really > wouldn't need the pitot itself until after the wing is > even closed up...as long as you mount it in an accessible place. > I like that 1st or 2nd bay from the tip. > ________________________________________________________________________________
Subject: F1069 Skins
Date: Oct 09, 2005
Can anyone tell me how they bent the roll in the F1069 fwd side skins I've tried vans way but the skin thickness wont allow it to roll Terry 40034 ________________________________________________________________________________
Date: Oct 09, 2005
Subject: Re: wing build sequence questions
Sean, if I recall correct, you skipped ahead in the wings section and worked on the tanks, outboard LE and flaps and ailerons, before doing the ribs and skins. My 'shop' i somewhat limited in size (15'x15') The size and weight of these spars coupled with the vision of how much room these will take up when coupled to the skins, makes me think I want to get all of the other wing assemblies complete 1st and then do the ribs and skins just before integrating the other components, then I can move the whole wing assembly to storage when starting on the fuse. 1. Have you encountered any gotcha's in this approach? 2. I also recall a discussion that when you do get to doing the ribs and skins, that this was a good place (wings, ribs & skins) to apply the ream,dimple, deburr, cleco and rivet sequence rather than the double cleco and match drill as per plans, anybody verify that this saved some time? Thanks as always Deems Davis # 406 Wing Ribs / Other? http://deemsrv10.com/ ________________________________________________________________________________
Date: Oct 09, 2005
Yes, I did the main spar section, then skipped ahead and did all the control surfaces, leading edge, and tanks before doing the main ribs and top skin. This allowed me to have ample workspace available without cluttering the space up with the main wing structure. I am now into the main ribs and rear spar sections and I am glad I did the other sections first. I have run into no issues doing it this way and I would recommend it to anyone that has a small workspace. (I'm doing construction in one side of a two car garage.) -Sean #40303 (tanks done!!! working on rear spar) Deems Davis wrote: > > > Sean, if I recall correct, you skipped ahead in the wings section and > worked on the tanks, outboard LE and flaps and ailerons, before doing > the ribs and skins. My 'shop' i somewhat limited in size (15'x15') The > size and weight of these spars coupled with the vision of how much > room these will take up when coupled to the skins, makes me think I > want to get all of the other wing assemblies complete 1st and then do > the ribs and skins just before integrating the other components, then > I can move the whole wing assembly to storage when starting on the fuse. > 1. Have you encountered any gotcha's in this approach? > > 2. I also recall a discussion that when you do get to doing the ribs > and skins, that this was a good place (wings, ribs & skins) to apply > the ream,dimple, deburr, cleco and rivet sequence rather than the > double cleco and match drill as per plans, anybody verify that this > saved some time? > > Thanks as always > > Deems Davis # 406 > Wing Ribs / Other? > http://deemsrv10.com/ > > ________________________________________________________________________________
Date: Oct 09, 2005
I second Sean's response. I'm cramped for workspace also and finished the tanks, leading edges, ailerons, flaps, torque tubes and aileron pushrods before the main wing. Now top skins are on both wings and I'm comtemplating the necessary wiring before closing. No gotchas at all with this route. Did discover some missing parts, however, that weren't on my inventory list but are in the plans. Minor stuff, but no more than an annoyance since I didn't need them to move ahead. John Hasbrouck #40264 ________________________________________________________________________________
Subject: Wing order + components
Date: Oct 09, 2005
I don't think I've ever seen a pitot that far out. Is there a reason why they are in closer? I don't have a clue what that reason might be, given that it's there to be pressurized. You just don't want to block it. John Jessen 40328 HS -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RE: RV10-List: Wing order + components Nice work. We added the Gretz mount after the wing was finished which was a fair bit more work. We also just added a heated pitot to replace the Dynon AOA pitot. Fortunately we were able to fish the heated pitot power wire through the AOA pitot tube which was not needed anymore. Wiring that thing up and hooking up the pitot line was a lot of work with the wing closed up and on the plane. All this to say, everybody should decide what pitot they are going with before they finish their wings so they can do something like you did and make it fairly easy to remove and replace if there is a problem. I really like Tim's idea of putting it further out the wing where it can be accessed from the open wingtip. It is a pain working around the aileron controls to get a the pitot to replace it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: Re: RV10-List: Wing order + components The Grezt mount is a great product, mine came out perfectly and you get an appreciation for what it is like to have to lay out a few rivet holes with a ruler. Heres a shot of mine with Jon Johanson heated pitot. Rick S. 40185 Fuselage ________________________________________________________________________________
Subject: RE: Lycoming Engines Copperstate visit
Date: Oct 10, 2005
Was there any conversation regarding the FAA's proposed AD on ECI rods for their clone 360 and pma parts for 540 engines? I believe the part number is AEL 11750. Parts alone to replace those parts will be $700/cylinder. Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Subject: Re: RV10-List: RE: Lycoming Engines Copperstate visit Well: good news,bad news, 1st the bad news, Jan wasn't @ Copperstate, They had a booth but the girl in the booth said he was out of the country. The only person available to ask questions to was an RV 7A Builder with an H6 installation who had his plane there (nice!) and has been working w/ Jan doing some recent testing (There's a recent blurb on the Egg website). He really wasn't knowledgeable regarding any plans for a-10 installation. And neither was anybody else in the booth. It seems their sweet spot is the 4cly Lyc 360 market and for that application I think it's a good fit, it would also be a good fit for anybody that had been thinking about the Continental for the RV-10. After thinking on this some more, not withstanding the benefits of lower cost, reliability(implied), smoothness, newer technology,Mogas etc. I'm uncomfortable with a), a lesser rated HP (240-??). and b). in order to get even that HP they have to spin the engine a lot faster than they do for the 200 hp versions. Close to or @ redline. And then they have to supercharge it. Seems that's pushing the envelope towards an edge that hasn't been proved (in aircraft) yet. It may be that this all proves to be non issues in the future, but I'm looking to get as close to 200mph out of my 10 as I can (just ego). And going to a less powerful platform, that's already pushed towards the upperend of it's performance envelope, isn't where I think I want to be. I'll continue to watch and listen to any developments, but won't be putting the Subie in any critical path on my project plan. If theres an RV-10 program in the future @ Egg, then Jan is probably the only person who knows about it. (And the looks of those tow mufflers hanging below the cowl also turns me off) Talked with a couple of other engine builders who were all quoting prices and functions similar to what has been reported on this list. They, are sending quotes and options via snail mail. The good news, (depending on when you need your engine), I spoke with the ECI/Titan folks and they are well into their 540 program and if you can wait til next Sept for your engine, they will be ready with all of the parts, They were partnered with an engine rebuilder from SanAntinio Tx. who was in the booth next to them, and he indicated that he expected the price to be just under 30k. His costs estimates were derived from a combination of 1. what his cost are to build an Titan 360 currently using ECI parts, and 2. What his cost are to rebuild a 540 using the ECI cyl assemblies. That's all new everything. with a stronger case, some improvements where the case and crank mate. That will not include the roller tappet technology that Lyc is now pushing. (heard a RUMOR that its not as rosy as hoped for and the added complexity is taking a toll) I've got some information and a CD that I will need to wade through over the next few days in order to better compare apples to apples, but it certainly sounds interesting, and while the timeline is a bit longer than I'd like, As most projects seem to go that'll probably still end up within my window. I looked for an insurance underwriter or agent to ask Michaels question to, but none were there. Deems Davis # 406 Wing Ribs http://deemsrv10.com/ Bill and Tami Britton wrote: > >Deems, get all the info you can get out of Jan at Copperstate and please >report back. I've been interested in his engines since I first found out >about them a couple years back. I was ready to buy one of his 2.5's when I >was planning on a RV-7, but now that I'm building a -10 I really hope he can >make the H-6 work. The only thing that still bugs me a little is the high >RPM's on take off. I know the engines do that all the time in the cars, but >it just sounds too high. Probably won't be a problem. > >Anyway, please report back if you have time. > >Bill Britton >RV-10 #40137 >Elevators in progress >----- Original Message ----- >From: "Deems Davis" <deemsdavis(at)cox.net> >To: >Sent: Thursday, October 06, 2005 3:35 PM >Subject: Re: RV10-List: RE: Lycoming Engines > > > > >> >>This is making the Egg/Subie look more and more interesting to me. He' >>going to be @ Copperstate this weekend, and I look forward to hearing >>1st hand about his plans for the RV-10 installation. >>(I just saw on ANN an AD for Lyc 360 & 540 cranks, maybe this is how Lyc >>expects to pay for it) >> >>Deems Davis # 406 >>Wing Main Spar >>http://deemsrv10.com/ >> >>William Curtis wrote: >> >> >> >>>Yup, they raised the price of the 260HP IO-540 from $38,990 to >>>$42,650, an over $3,600 increase. However they now have an offering of >>>the 250HP O-540 for $37,500. Other than fuel injection, anyone know >>>what else is different between these engines? It would seem you could >>>get the O and add fuel injection for a lot less than $5,150 or FADEC >>>for a little more. I think I'll be looking at the IO-540 clone from >>>Aerosport. Maybe in these days of $5 avgas, they will reconsider the >>>210HP Continental IO-360. >>> >>> >>> >>>>Back to the engine question. I am getting close to ordering one and >>>> >>>> >>>noticed >>> >>> >>>>that Vans prices went up considerably for the IO540. Does anyone know >>>> >>>> >if > > >>>>this has the new tapped technology? >>>> >>>> >>>William Curtis >>>40237 - wings >>>http://wcurtis.nerv10.com/ >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > ________________________________________________________________________________
Date: Oct 10, 2005
Dear ECi Customer, As you may know, the FAA has issued a Notice of Proposed Rule Making (NPRM) against ECi connecting rods AEL11750. It is Eci's position that this NPRM and possible A.D. is totally unnecessary and that no safety of flight concerns exist. We have been "working" with the FAA for the past 18 months to convince them of this but to no avail. If there is a conformity of the OD of the bearing shell to the bore of the connecting rod, significant enough to increase the bearing operating temperature, the failure would occur fairly rapidly ( 1 million cycles or 10 hours of operation). Certainly within the first 100 hours. No failures have occurred. We urge you to comment to the docket recommending against the AD or, at worst case, to make it effective at TBO. We are evaluating legal options to address this situation and will keep you informed. Regards, Ed Salmeron -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rhonda Bewley Subject: RE: RV10-List: RE: Lycoming Engines Copperstate visit Was there any conversation regarding the FAA's proposed AD on ECI rods for their clone 360 and pma parts for 540 engines? I believe the part number is AEL 11750. Parts alone to replace those parts will be $700/cylinder. Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Subject: Re: RV10-List: RE: Lycoming Engines Copperstate visit Well: good news,bad news, 1st the bad news, Jan wasn't @ Copperstate, They had a booth but the girl in the booth said he was out of the country. The only person available to ask questions to was an RV 7A Builder with an H6 installation who had his plane there (nice!) and has been working w/ Jan doing some recent testing (There's a recent blurb on the Egg website). He really wasn't knowledgeable regarding any plans for a-10 installation. And neither was anybody else in the booth. It seems their sweet spot is the 4cly Lyc 360 market and for that application I think it's a good fit, it would also be a good fit for anybody that had been thinking about the Continental for the RV-10. After thinking on this some more, not withstanding the benefits of lower cost, reliability(implied), smoothness, newer technology,Mogas etc. I'm uncomfortable with a), a lesser rated HP (240-??). and b). in order to get even that HP they have to spin the engine a lot faster than they do for the 200 hp versions. Close to or @ redline. And then they have to supercharge it. Seems that's pushing the envelope towards an edge that hasn't been proved (in aircraft) yet. It may be that this all proves to be non issues in the future, but I'm looking to get as close to 200mph out of my 10 as I can (just ego). And going to a less powerful platform, that's already pushed towards the upperend of it's performance envelope, isn't where I think I want to be. I'll continue to watch and listen to any developments, but won't be putting the Subie in any critical path on my project plan. If theres an RV-10 program in the future @ Egg, then Jan is probably the only person who knows about it. (And the looks of those tow mufflers hanging below the cowl also turns me off) Talked with a couple of other engine builders who were all quoting prices and functions similar to what has been reported on this list. They, are sending quotes and options via snail mail. The good news, (depending on when you need your engine), I spoke with the ECI/Titan folks and they are well into their 540 program and if you can wait til next Sept for your engine, they will be ready with all of the parts, They were partnered with an engine rebuilder from SanAntinio Tx. who was in the booth next to them, and he indicated that he expected the price to be just under 30k. His costs estimates were derived from a combination of 1. what his cost are to build an Titan 360 currently using ECI parts, and 2. What his cost are to rebuild a 540 using the ECI cyl assemblies. That's all new everything. with a stronger case, some improvements where the case and crank mate. That will not include the roller tappet technology that Lyc is now pushing. (heard a RUMOR that its not as rosy as hoped for and the added complexity is taking a toll) I've got some information and a CD that I will need to wade through over the next few days in order to better compare apples to apples, but it certainly sounds interesting, and while the timeline is a bit longer than I'd like, As most projects seem to go that'll probably still end up within my window. I looked for an insurance underwriter or agent to ask Michaels question to, but none were there. Deems Davis # 406 Wing Ribs http://deemsrv10.com/ Bill and Tami Britton wrote: > >Deems, get all the info you can get out of Jan at Copperstate and please >report back. I've been interested in his engines since I first found out >about them a couple years back. I was ready to buy one of his 2.5's when I >was planning on a RV-7, but now that I'm building a -10 I really hope he can >make the H-6 work. The only thing that still bugs me a little is the high >RPM's on take off. I know the engines do that all the time in the cars, but >it just sounds too high. Probably won't be a problem. > >Anyway, please report back if you have time. > >Bill Britton >RV-10 #40137 >Elevators in progress >----- Original Message ----- >From: "Deems Davis" <deemsdavis(at)cox.net> >To: >Sent: Thursday, October 06, 2005 3:35 PM >Subject: Re: RV10-List: RE: Lycoming Engines > > > > >> >>This is making the Egg/Subie look more and more interesting to me. He' >>going to be @ Copperstate this weekend, and I look forward to hearing >>1st hand about his plans for the RV-10 installation. >>(I just saw on ANN an AD for Lyc 360 & 540 cranks, maybe this is how Lyc >>expects to pay for it) >> >>Deems Davis # 406 >>Wing Main Spar >>http://deemsrv10.com/ >> >>William Curtis wrote: >> >> >> >>>Yup, they raised the price of the 260HP IO-540 from $38,990 to >>>$42,650, an over $3,600 increase. However they now have an offering of >>>the 250HP O-540 for $37,500. Other than fuel injection, anyone know >>>what else is different between these engines? It would seem you could >>>get the O and add fuel injection for a lot less than $5,150 or FADEC >>>for a little more. I think I'll be looking at the IO-540 clone from >>>Aerosport. Maybe in these days of $5 avgas, they will reconsider the >>>210HP Continental IO-360. >>> >>> >>> >>>>Back to the engine question. I am getting close to ordering one and >>>> >>>> >>>noticed >>> >>> >>>>that Vans prices went up considerably for the IO540. Does anyone know >>>> >>>> >if > > >>>>this has the new tapped technology? >>>> >>>> >>>William Curtis >>>40237 - wings >>>http://wcurtis.nerv10.com/ >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > ________________________________________________________________________________
Date: Oct 10, 2005
What were your reason for replacing the Dynon Pitot/AoA. Is it simply because you had to have a heated Pitot and Dynon still hasn't delivered one? I wanted to close up my wings and was waiting for Dynon to release there heated pitot, but no luck, so I purchased there unheated one in hopes to replace it with there heated one down the road. Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com -----Original Message-----
Date: Oct 10, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Terry, I went through the same thing. I posted the solution over on the old Yahoo Group list but am reposting here for archive purposes. I've also asked Tim to put in his building tips area for future slow builders. Of course, now that he's got paint on his plane it might not be a priority :) Bob #40105 > First the problem: > The picture on page 29-11 illustrates how to roll the forward > fuselage skins. It involves clamping a piece of wood to a workbench, > clamping a couple of "construction angles" to the skin and then > rolling the skin. Finally, while holding the skin in a "rolled > state" you give a sharp whack with a rubber mallet. > > Here's a couple of hints: > 1) The angles are shown held to the skins with vice grips (the kind > that form a "C"). There really isn't much of the angle to grab > onto. It turns out to be MUCH easier if you use the kind without > the "pads". C clamps and other methods of holding the angles to the > skin are difficult at best. You either don't have enough surface to > clamp or there won't be clearance while rolling. The exception is at > the small end of the "cone" - there is a small C clamp there holding > the ends of the construction angles together. > > 2) Use actual C clamps to hold the skin and wood form down to the > workbench. I was originally using the "quick grip" type of sliding > clamps. You get a lot more clamping force with C clamps. > > I spent a long time last night working on the first forward skin and > the result was poor. Making the above two changes allowed me to do > the other side in only about 15-20 minutes! I then reclamped the > first skin and "touched it up". > > In the final analysis the picture on 29-11 is very good. If you do > it EXACTLY like it shows without tool substitutions it will turn out > great. Using the vice grips without the pads makes it even easier! > Do yourself a favor - if you don't have the right clamps, go get them > before starting! _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of terry doe Subject: RV10-List: F1069 Skins Can anyone tell me how they bent the roll in the F1069 fwd side skins I've tried vans way but the skin thickness wont allow it to roll Terry 40034 ________________________________________________________________________________
Date: Oct 10, 2005
Ray, I am using the ACS AOA system and plan on using the GRT EFIS. Jon's tube was $325 at the time and is machined out of solid aluminum, with a beefy tube and nicly polished. Nothing against Dynon but the delay was the main reason. I like the thermostatic control. I don't plan on needing my pitot heat too much but it will be there if I need it. Rick S. 40185 Fuselage ________________________________________________________________________________
Subject: Wing Tip Installation.
Date: Oct 10, 2005
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
When I installed my wing tips on my RV-9A, we had to make a template that marked the chord line of the wing on a piece of wood that was bolted to the tooling holes of the tip rib. You then extended these lines on the template. Then you installed the ailron and made sure the trailing lined up with this chord line. Then you lock the ailron in this position and install the tip tip trailing edge to match. I don't see any of this in the manual for the RV-10 and wonder how you are suppose to ensure the trailing edge of the ailron line up with the trailing edge of the wing tip when the ailron is in it's neutral position. Any help would be appreciated. Thank You Ray Doerr 40250 ________________________________________________________________________________
Date: Oct 10, 2005
You can install it anywhere you can get it secure, plumbed, in line with the aircraft datum line and the location allows unobstructed true ram airflow, i.e. no propwash or turbulent air. For optimum location run it out the front of your spinner ;) but the top of the rudder would look cool too as would on the tip...your choice really. I just followed the rest of the RV crowd. It make a nice handle to move qaround the wing stand too :D. Rick S. ________________________________________________________________________________
Date: Oct 10, 2005
Ray, See if you can return your pitot. I have a Dynon AOA pitot in a drawer that I am trying to find a home for. I think it is a great option for those who don't need heat. They are working on a heated version, but don't even have an estimated date of completion. In the flight up to MN the other day my dad descended through a little layer (only 2,500 feet thick) and had ice build-up on the tie-down ring when he landed and checked it out. He would have had to turn back without the heat. If you are flying VFR, though, you will never need it. Dynon does offer the AOA feature for a great price, though, which is only the cost for the pitot. Maybe I should install their AOA pitot in the other wing and use it for AOA and then the heated pitot for the other instruments....OK, maybe that's going a little too far. Anyway, the AOA Pitot is for sale for half of the Dynon retail price if anybody wants it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK] Subject: RE: RV10-List: Wing order + components What were your reason for replacing the Dynon Pitot/AoA. Is it simply because you had to have a heated Pitot and Dynon still hasn't delivered one? I wanted to close up my wings and was waiting for Dynon to release there heated pitot, but no luck, so I purchased there unheated one in hopes to replace it with there heated one down the road. Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RE: RV10-List: Wing order + components Nice work. We added the Gretz mount after the wing was finished which was a fair bit more work. We also just added a heated pitot to replace the Dynon AOA pitot. Fortunately we were able to fish the heated pitot power wire through the AOA pitot tube which was not needed anymore. Wiring that thing up and hooking up the pitot line was a lot of work with the wing closed up and on the plane. All this to say, everybody should decide what pitot they are going with before they finish their wings so they can do something like you did and make it fairly easy to remove and replace if there is a problem. I really like Tim's idea of putting it further out the wing where it can be accessed from the open wingtip. It is a pain working around the aileron controls to get a the pitot to replace it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: Re: RV10-List: Wing order + components The Grezt mount is a great product, mine came out perfectly and you get an appreciation for what it is like to have to lay out a few rivet holes with a ruler. Heres a shot of mine with Jon Johanson heated pitot. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 10, 2005
No, there wasn't. But, it seems that the ever expanding Lycoming AD on crankshafts indicates that they are not imune from the long arm of the FAA either. Rhonda Bewley wrote: > >Was there any conversation regarding the FAA's proposed AD on ECI rods >for their clone 360 and pma parts for 540 engines? I believe the part >number is AEL 11750. Parts alone to replace those parts will be >$700/cylinder. > >Rhonda >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis >Sent: Saturday, October 08, 2005 5:34 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: RE: Lycoming Engines Copperstate visit > > >Well: good news,bad news, >1st the bad news, Jan wasn't @ Copperstate, They had a booth but the >girl in the booth said he was out of the country. The only person >available to ask questions to was an RV 7A Builder with an H6 >installation who had his plane there (nice!) and has been working w/ Jan > >doing some recent testing (There's a recent blurb on the Egg website). >He really wasn't knowledgeable regarding any plans for a-10 >installation. And neither was anybody else in the booth. It seems their >sweet spot is the 4cly Lyc 360 market and for that application I think >it's a good fit, it would also be a good fit for anybody that had been >thinking about the Continental for the RV-10. After thinking on this >some more, not withstanding the benefits of lower cost, >reliability(implied), smoothness, newer technology,Mogas etc. I'm >uncomfortable with a), a lesser rated HP (240-??). and b). in order to >get even that HP they have to spin the engine a lot faster than they do >for the 200 hp versions. Close to or @ redline. And then they have to >supercharge it. Seems that's pushing the envelope towards an edge that >hasn't been proved (in aircraft) yet. It may be that this all proves to >be non issues in the future, but I'm looking to get as close to 200mph >out of my 10 as I can (just ego). And going to a less powerful platform, > >that's already pushed towards the upperend of it's performance envelope, > >isn't where I think I want to be. I'll continue to watch and listen to >any developments, but won't be putting the Subie in any critical path on > >my project plan. If theres an RV-10 program in the future @ Egg, then >Jan is probably the only person who knows about it. (And the looks of >those tow mufflers hanging below the cowl also turns me off) >Talked with a couple of other engine builders who were all quoting >prices and functions similar to what has been reported on this list. >They, are sending quotes and options via snail mail. >The good news, (depending on when you need your engine), I spoke with >the ECI/Titan folks and they are well into their 540 program and if you > >can wait til next Sept for your engine, they will be ready with all of >the parts, They were partnered with an engine rebuilder from SanAntinio >Tx. who was in the booth next to them, and he indicated that he expected > >the price to be just under 30k. His costs estimates were derived from a >combination of 1. what his cost are to build an Titan 360 currently >using ECI parts, and 2. What his cost are to rebuild a 540 using the ECI > >cyl assemblies. That's all new everything. with a stronger case, some >improvements where the case and crank mate. That will not include the >roller tappet technology that Lyc is now pushing. (heard a RUMOR that >its not as rosy as hoped for and the added complexity is taking a toll) >I've got some information and a CD that I will need to wade through over > >the next few days in order to better compare apples to apples, but it >certainly sounds interesting, and while the timeline is a bit longer >than I'd like, As most projects seem to go that'll probably still end up > >within my window. >I looked for an insurance underwriter or agent to ask Michaels question >to, but none were there. > >Deems Davis # 406 >Wing Ribs >http://deemsrv10.com/ > > >Bill and Tami Britton wrote: > > > >> >> > > > >>Deems, get all the info you can get out of Jan at Copperstate and >> >> >please > > >>report back. I've been interested in his engines since I first found >> >> >out > > >>about them a couple years back. I was ready to buy one of his 2.5's >> >> >when I > > >>was planning on a RV-7, but now that I'm building a -10 I really hope >> >> >he can > > >>make the H-6 work. The only thing that still bugs me a little is the >> >> >high > > >>RPM's on take off. I know the engines do that all the time in the >> >> >cars, but > > >>it just sounds too high. Probably won't be a problem. >> >>Anyway, please report back if you have time. >> >>Bill Britton >>RV-10 #40137 >>Elevators in progress >>----- Original Message ----- >>From: "Deems Davis" <deemsdavis(at)cox.net> >>To: >>Sent: Thursday, October 06, 2005 3:35 PM >>Subject: Re: RV10-List: RE: Lycoming Engines >> >> >> >> >> >> >>> >>>This is making the Egg/Subie look more and more interesting to me. He' >>>going to be @ Copperstate this weekend, and I look forward to hearing >>>1st hand about his plans for the RV-10 installation. >>>(I just saw on ANN an AD for Lyc 360 & 540 cranks, maybe this is how >>> >>> >Lyc > > >>>expects to pay for it) >>> >>>Deems Davis # 406 >>>Wing Main Spar >>>http://deemsrv10.com/ >>> >>>William Curtis wrote: >>> >>> >>> >>> >>> >>>>Yup, they raised the price of the 260HP IO-540 from $38,990 to >>>>$42,650, an over $3,600 increase. However they now have an offering >>>> >>>> >of > > >>>>the 250HP O-540 for $37,500. Other than fuel injection, anyone know >>>>what else is different between these engines? It would seem you could >>>>get the O and add fuel injection for a lot less than $5,150 or FADEC >>>>for a little more. I think I'll be looking at the IO-540 clone from >>>>Aerosport. Maybe in these days of $5 avgas, they will reconsider the >>>>210HP Continental IO-360. >>>> >>>> >>>> >>>> >>>> >>>>>Back to the engine question. I am getting close to ordering one and >>>>> >>>>> >>>>> >>>>> >>>>noticed >>>> >>>> >>>> >>>> >>>>>that Vans prices went up considerably for the IO540. Does anyone >>>>> >>>>> >know > > >>>>> >>>>> >>>>> >>>>> >>if >> >> >> >> >>>>>this has the new tapped technology? >>>>> >>>>> >>>>> >>>>> >>>>William Curtis >>>>40237 - wings >>>>http://wcurtis.nerv10.com/ >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Fw: RV10 kit
Date: Oct 10, 2005
----- Original Message ----- From: Sam Mazzotta Subject: Re: RV10 kit Hi David: The items in the RV10 kit (P/N: RV67910-C1P) are itentical to your Cessna 177 conversion kit except the firewall mounts are different. The RV Kit does not use the SK2003-36 rubber mount. The are 48 assemblies in the RV10 kit. Let me know if I can help your further. Sam Mazotta Skybolt Aeromotive Corp. ----- Original Message ----- From: David McNeill To: smazzotta(at)skybolt.com Sent: Tuesday, October 04, 2005 7:34 PM Subject: RV10 kit What's the Bill of Material for the kit. I have previously installed the skybolt kit on my C177RG and Glastar and have already have some spare parts. ________________________________________________________________________________
Date: Oct 10, 2005
Subject: re: Heated AOA Ports~ 10/08/05
Gentlemen: Unless you have a fully de/anti iced wing it will do you no good to have heated ports / vanes on your AOA system. I would not sell a heated AOA system to any aircraft unless it was fully certified to fly in icing conditions. Reason as follows: Do you want to believe your AOA vane if it is clean of ice and the wing has ice on it?? Do you want to believe your AOA pressure port computed system if the wing has ice on it, even if the port is clear? Do you want to believe your AOA pressure differential system if it is heated and the wing has ice on it? What do you know that Boeing, and all the other manufactures don't?? If you try to follow an AOA with ice on the wing it will lead you down a path that could very well be fatal. Boeing & Douglas (back when I was flying them) had no data for how icing would actually affect the lift~~other than lift would decrease and amount unknown, Rime, clear, mixed all create a different problem. In my certification paperwork on the RiteAngle it is stated: ANY evidence of icing on airframe, RiteAngle system must be turned off until clear of icing! IF you have a de/anti iced wing it is a different story, but I don't know of many homebuilts that have them! It is evident many haven't been as iced up as I have in the past 43 years!! And this includes aircarriers with full anti ice. ICE = most serious problem except possibly fire in the air. SAFETY FIRST Elbie Mendenhall EM Aviation, LLC www.riteangle.com ________________________________________________________________________________
Subject: Re: re: Heated AOA Ports~ 10/08/05
Date: Oct 10, 2005
Elbie, Point well taken re: heated AOA ports but that's not the way I interpreted the initial post. We were talking about heated pitot tubes and as an aside AOA. Many of us have waited for Dynon to come forward with their heated pitot which also includes the AOA info for their instrument. I'm most concerned with the heating for the pitot portion. Unable to understand Dynon's hesitation unless product liability has reared its ugly head. I can see where the company lawyers would get heartburn over the thought of us using their instrument IFR. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 10, 2005
Subject: RV10 Kit for Sale
From: "McIntosh, Todd" <McIntoshT(at)health.missouri.edu>
1.53 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO Two RVs is one two many. The tail is done and the wing kit is inventoried but not started. Contact me at mcintoshtw(at)direcway.com if interested. Todd McIntosh RV9A N369TM ________________________________________________________________________________
Subject: 80% Painted (paint gun???)
Date: Oct 10, 2005
Tim, Great information and a beautiful job painting, very impressive. One question that you may have already covered, but what paint gun did you use? Can't wait to get painting, but still a long way off, Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: 80% Painted This weekend went off without a hitch. The weather was great and the pre-work got done just in time. I got the fuselage, wings, and cowls painted. All that's left is the VS, HS, and Rudder, along with the colored striping and letters. There is a LOT of prep work to paint the -10. I know I spent over 100 man hours getting it ready. ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: Wing Tips Don't Line Up
Date: Oct 10, 2005
I am attaching my wing tips and have all of the nutplates complete on one and the other drilled and clecoed. Neither of the wing tips line up with the ailerons in neutral position. I have clamped the ailerons in line with the flaps in full up position. The trailing edge of the right wing tip is about 1/2" lower than the trailing edge of the aileron. The trailing edge of the left wing tip is about 1/4" higher than the aileron. The trailing edges of the wing tips are about 1/4" - 3/8" too long. I can trim them without breaking the trailing edge joint. I cannot see any simple way of bending/aligning the wing tips except for perhaps cutting the trailing edge in half and reattaching them while trying to twist them into alignment. I would love to hear what others have done to deal with this. I really hope it is not bad parts cause I have put a lot of hours into these wingtips. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB Wing Tips ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Re: Wing Tip Installation.
I spoke to Scott McDaniels at Copperstate this weekend about this very subject. After trimming my wing tips to fit it looked like the trailing edges were not lining up well. My first thought was that I would have to cut the ends of the wing tips open and then epoxy them back together in the right position. (Which would be the thing to do if you have already drilled the holes) Scott says that the leading edge of the tip can be sort of rotated inside the leading edge of the wing. A little movement there produces a pretty big change in the position of the trailing edge. Sure enough I tried it when I got home and it works. I am going to clamp some boards along the trailing edge of the flap, aileron and wing tip to keep everything lined up before i drill the tips. The full up position of the flap defines the neutral position of the aileron. If you would like I can take some pictures and send them to you. Andrew Rayhill 40078 Finishing wings. ________________________________________________________________________________
Subject: Reaming question
Date: Oct 11, 2005
I looked at the past posts on reaming, but wanted to try this question out on the group anyway. Working on the HS and am now at the stage of deburring all my reamed holes. Do I need to debur if using a reamer? I'm doing so, and I don't really mind it since I have the Cogsdill and it goes fast, but am wondering if it's necessary. Has anyone gotten out a magnifying glass and taken a careful look? Any thoughts? John Jessen 40328 HS ________________________________________________________________________________
Subject: Re: F1069 Skins
Date: Oct 11, 2005
Thanks Bob i'll give it a go Terry ----- Original Message ----- From: Condrey, Bob (US SSA) To: rv10-list(at)matronics.com Sent: Monday, October 10, 2005 9:54 PM Subject: RE: RV10-List: F1069 Skins Terry, I went through the same thing. I posted the solution over on the old Yahoo Group list but am reposting here for archive purposes. I've also asked Tim to put in his building tips area for future slow builders. Of course, now that he's got paint on his plane it might not be a priority :) Bob #40105 > First the problem: > The picture on page 29-11 illustrates how to roll the forward > fuselage skins. It involves clamping a piece of wood to a workbench, > clamping a couple of "construction angles" to the skin and then > rolling the skin. Finally, while holding the skin in a "rolled > state" you give a sharp whack with a rubber mallet. > > Here's a couple of hints: > 1) The angles are shown held to the skins with vice grips (the kind > that form a "C"). There really isn't much of the angle to grab > onto. It turns out to be MUCH easier if you use the kind without > the "pads". C clamps and other methods of holding the angles to the > skin are difficult at best. You either don't have enough surface to > clamp or there won't be clearance while rolling. The exception is at > the small end of the "cone" - there is a small C clamp there holding > the ends of the construction angles together. > > 2) Use actual C clamps to hold the skin and wood form down to the > workbench. I was originally using the "quick grip" type of sliding > clamps. You get a lot more clamping force with C clamps. > > I spent a long time last night working on the first forward skin and > the result was poor. Making the above two changes allowed me to do > the other side in only about 15-20 minutes! I then reclamped the > first skin and "touched it up". > > In the final analysis the picture on 29-11 is very good. If you do > it EXACTLY like it shows without tool substitutions it will turn out > great. Using the vice grips without the pads makes it even easier! > Do yourself a favor - if you don't have the right clamps, go get them > before starting! From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of terry doe Sent: Sunday, October 09, 2005 4:30 AM To: rv10-list(at)matronics.com Subject: RV10-List: F1069 Skins Can anyone tell me how they bent the roll in the F1069 fwd side skins I've tried vans way but the skin thickness wont allow it to roll Terry 40034 ________________________________________________________________________________
Date: Oct 11, 2005
I'm reaming, and haven't used a glass. Doing the reaming still goes very and cogdill will save a lot. Bob K 40125 Forward fuselage -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: Reaming question I looked at the past posts on reaming, but wanted to try this question out on the group anyway. Working on the HS and am now at the stage of deburring all my reamed holes. Do I need to debur if using a reamer? I'm doing so, and I don't really mind it since I have the Cogsdill and it goes fast, but am wondering if it's necessary. Has anyone gotten out a magnifying glass and taken a careful look? Any thoughts? John Jessen 40328 HS ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Re: Reaming question
FWIW, no sharp edges. A 0.010 edge break is a "standard". This would apply to the edge of a part, or the edge of a hole. Regards, Jim Ayers In a message dated 10/11/2005 12:43:42 AM Pacific Daylight Time, jjessen(at)rcn.com writes: --> RV10-List message posted by: "John Jessen" I looked at the past posts on reaming, but wanted to try this question out on the group anyway. Working on the HS and am now at the stage of deburring all my reamed holes. Do I need to debur if using a reamer? I'm doing so, and I don't really mind it since I have the Cogsdill and it goes fast, but am wondering if it's necessary. Has anyone gotten out a magnifying glass and taken a careful look? Any thoughts? John Jessen 40328 HS ________________________________________________________________________________
Date: Oct 11, 2005
I roughly checked my wingtip the other night and they are =BC" too short. Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Subject: RV10-List: Wing Tips Don't Line Up I am attaching my wing tips and have all of the nutplates complete on one and the other drilled and clecoed. Neither of the wing tips line up with the ailerons in neutral position. I have clamped the ailerons in line with the flaps in full up position. The trailing edge of the right wing tip is about 1/2" lower than the trailing edge of the aileron. The trailing edge of the left wing tip is about 1/4" higher than the aileron. The trailing edges of the wing tips are about 1/4" - 3/8" too long. I can trim them without breaking the trailing edge joint. I cannot see any simple way of bending/aligning the wing tips except for perhaps cutting the trailing edge in half and reattaching them while trying to twist them into alignment. I would love to hear what others have done to deal with this. I really hope it is not bad parts cause I have put a lot of hours into these wingtips. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB Wing Tips ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Re: Very minor parts shortage
Howdy Ray, Thanks for the comment. I did miss the note to "Do not install nutplate..." on page 44-2 Figure 1. Maybe that's why that one was harder to rivet in place. ;) The nutplate that I'm worried about is the one that goes between the center sections F1004A and F1004B (or F & H). Right exactly where the main spar goes. Do you really put one in that location? I looked at it with the wings on and there's almost no room for a nutplate or screw to come out the nutplate. But, the fairing is punched there. I just wanted to verify that the wings won't actually hit it. Since I did install one where I shouldn't have, I can easily just drill that one out. I'm betting, now that I look at it, that the reason for no nutplate in that 2nd to the last space is because once you put the bolt in for your flap linkage, I bet there would be interference as the flaps moved...or something like that. Anyway, that's an easy fix. Another funny thing is, that front skin support, F1099G-L... that one doesn't seem to get any form of attachment to the skin. Not only that, but on mine I don't think the skin actually even came up high enough to touch it. It must just be there to prevent some massive cave-in of the fairing. All of this is on page 44-2. Tim Doerr, Ray R [NTK] wrote: > > Tim I have slow build fuse and just riveted on these nutplates on the > bottom center skin this weekend. There are 9 nutplates on the bottom > center skin. One is aft of the rear spar attachment and then the next > one is forward of the rear spar with the last one between the center > section main spars. I beliebe the one you are referring to is right at > the rear spar. My instruction indicate that no nutplate is to be > installed in this position and my skin does not even have the holes for > it anyway. I think the earlier bottom skins had this drilled, but the > newer ones like mine do not. > > > > Thank You > Ray Doerr > CDNI Principal Engineer > Sprint PCS > 16020 West 113th Street > Lenexa, KS 66219 > Mailstop KSLNXK0101 > (913) 859-1414 (Office) > (913) 226-0106 (Pcs) > (913) 859-1234 (Fax) > Ray.R.Doerr(at)sprint.com > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Tuesday, October 11, 2005 9:13 AM > To: RV10 > Subject: RV10-List: Very minor parts shortage > > > I have slow wings, QB fuse. Last week when I went to do my wing root > fairings I found that I was around 40 K1100-08 nutplates short. > I had just closed my wings, and thus had also just installed > all of them on the wings and access panels, having just freshly > opened those hardware bags. Gus verified that the quantity listed in > the various kits does not add up, and he sent me 40 more, which > arrived very very quickly I must say, by USPS. > If you're in the same postion as me, with slow wings, and QB fuse, > you should check your count and get some when you talk to them > next. I think the quantity supplied with the fuse kit was something > like 22. Required are at least 9 on each bottom, 12 on each top, plus > I think 7 around the nose. I think there were a few others, too. > > On a side note, does anyone who's completed the fuse know what's up > with the one nutplate that is predrilled that goes on the bottom > skin in the middle of the center section, where the wing spar goes? > It sure seems like this nutplate, if installed, would scrape > the spar. Gus seemed to think it may have been a set of holes that > was drilled by accident that won't be used. Just looking > for confirmation. I left mine empty. > > Tim > > ________________________________________________________________________________
Date: Oct 11, 2005
What type or brand of reamer is being used? Where did you purchase them? Steve 40212 --- LessDragProd(at)aol.com wrote: > > FWIW, no sharp edges. > > A 0.010 edge break is a "standard". This would > apply to the edge of a part, > or the edge of a hole. > > Regards, > Jim Ayers > > In a message dated 10/11/2005 12:43:42 AM Pacific > Daylight Time, > jjessen(at)rcn.com writes: > > --> RV10-List message posted by: "John Jessen" > > > I looked at the past posts on reaming, but wanted > to try this question out > on the group anyway. > > Working on the HS and am now at the stage of > deburring all my reamed holes. > Do I need to debur if using a reamer? I'm doing > so, and I don't really mind > it since I have the Cogsdill and it goes fast, but > am wondering if it's > necessary. Has anyone gotten out a magnifying > glass and taken a careful > look? Any thoughts? > > John Jessen > 40328 HS > > > > > > __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
Date: Oct 11, 2005
Try mcmaster.com Thats where I bought mine. Chris #40072 -----Original Message----- From: Darton Steve <sfdarton(at)yahoo.com> Subject: Re: RV10-List: Reaming question What type or brand of reamer is being used? Where did you purchase them? Steve 40212 --- LessDragProd(at)aol.com wrote: > > FWIW, no sharp edges. > > A 0.010 edge break is a "standard". This would > apply to the edge of a part, > or the edge of a hole. > > Regards, > Jim Ayers > > In a message dated 10/11/2005 12:43:42 AM Pacific > Daylight Time, > jjessen(at)rcn.com writes: > > --> RV10-List message posted by: "John Jessen" > > > I looked at the past posts on reaming, but wanted > to try this question out > on the group anyway. > > Working on the HS and am now at the stage of > deburring all my reamed holes. > Do I need to debur if using a reamer? I'm doing > so, and I don't really mind > it since I have the Cogsdill and it goes fast, but > am wondering if it's > necessary. Has anyone gotten out a magnifying > glass and taken a careful > look? Any thoughts? > > John Jessen > 40328 HS > > > > > > __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
Date: Oct 11, 2005
I don't have the reamers within reach right now, but they were purchased from Avery. #30 and #40. Description follows: CHUCKING REAMERS FOR PRE-PUNCHED HOLES #30 REAMER (.1280") Many kit manufacturers today are CNC match hole punching their kit parts,and recommend the builder open the holes up to the proper rivet hole size.One method is to ream the pre-punched holes to the correct size.Reamers give you a rounder,closer tolerance finished hole with less burrs around the holes, and can be used just like a drill bit. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Darton Steve Subject: Re: RV10-List: Reaming question What type or brand of reamer is being used? Where did you purchase them? Steve 40212 --- LessDragProd(at)aol.com wrote: > > FWIW, no sharp edges. > > A 0.010 edge break is a "standard". This would apply to the edge of > a part, or the edge of a hole. > > Regards, > Jim Ayers > > In a message dated 10/11/2005 12:43:42 AM Pacific Daylight Time, > jjessen(at)rcn.com writes: > > --> RV10-List message posted by: "John Jessen" > > > I looked at the past posts on reaming, but wanted to try this > question out on the group anyway. > > Working on the HS and am now at the stage of deburring all my reamed > holes. > Do I need to debur if using a reamer? I'm doing > so, and I don't really mind > it since I have the Cogsdill and it goes fast, but am wondering if > it's necessary. Has anyone gotten out a magnifying glass and taken a > careful > look? Any thoughts? > > John Jessen > 40328 HS > > > > > > __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
Date: Oct 11, 2005
Are you saying that the reamer is leaving the edge as if it were deburred? "No sharp edges" Or, that one must debur and not leave a sharp edge. The question is, if using a reamer, does one have to then follow with deburring? Or, does the reamer use a smooth enough edge / hole. John Jessen 40328 HS _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Subject: Re: RV10-List: Reaming question FWIW, no sharp edges. A 0.010 edge break is a "standard". This would apply to the edge of a part, or the edge of a hole. Regards, Jim Ayers In a message dated 10/11/2005 12:43:42 AM Pacific Daylight Time, jjessen(at)rcn.com writes: I looked at the past posts on reaming, but wanted to try this question out on the group anyway. Working on the HS and am now at the stage of deburring all my reamed holes. Do I need to debur if using a reamer? I'm doing so, and I don't really mind it since I have the Cogsdill and it goes fast, but am wondering if it's necessary. Has anyone gotten out a magnifying glass and taken a careful look? Any thoughts? John Jessen 40328 HS ________________________________________________________________________________
Subject: Very minor parts shortage
Date: Oct 11, 2005
Yes, you need the nutplate between the center section spars. This nutplate should not interfere because with the dihedral of wing, it should not hit, worst case, use a shorter screw. Thank You Ray Doerr CDNI Principal Engineer Sprint PCS 16020 West 113th Street Lenexa, KS 66219 Mailstop KSLNXK0101 (913) 859-1414 (Office) (913) 226-0106 (Pcs) (913) 859-1234 (Fax) Ray.R.Doerr(at)sprint.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: Re: RV10-List: Very minor parts shortage Howdy Ray, Thanks for the comment. I did miss the note to "Do not install nutplate..." on page 44-2 Figure 1. Maybe that's why that one was harder to rivet in place. ;) The nutplate that I'm worried about is the one that goes between the center sections F1004A and F1004B (or F & H). Right exactly where the main spar goes. Do you really put one in that location? I looked at it with the wings on and there's almost no room for a nutplate or screw to come out the nutplate. But, the fairing is punched there. I just wanted to verify that the wings won't actually hit it. Since I did install one where I shouldn't have, I can easily just drill that one out. I'm betting, now that I look at it, that the reason for no nutplate in that 2nd to the last space is because once you put the bolt in for your flap linkage, I bet there would be interference as the flaps moved...or something like that. Anyway, that's an easy fix. Another funny thing is, that front skin support, F1099G-L... that one doesn't seem to get any form of attachment to the skin. Not only that, but on mine I don't think the skin actually even came up high enough to touch it. It must just be there to prevent some massive cave-in of the fairing. All of this is on page 44-2. Tim Doerr, Ray R [NTK] wrote: > > Tim I have slow build fuse and just riveted on these nutplates on the > bottom center skin this weekend. There are 9 nutplates on the bottom > center skin. One is aft of the rear spar attachment and then the next > one is forward of the rear spar with the last one between the center > section main spars. I beliebe the one you are referring to is right at > the rear spar. My instruction indicate that no nutplate is to be > installed in this position and my skin does not even have the holes for > it anyway. I think the earlier bottom skins had this drilled, but the > newer ones like mine do not. > > > > Thank You > Ray Doerr > CDNI Principal Engineer > Sprint PCS > 16020 West 113th Street > Lenexa, KS 66219 > Mailstop KSLNXK0101 > (913) 859-1414 (Office) > (913) 226-0106 (Pcs) > (913) 859-1234 (Fax) > Ray.R.Doerr(at)sprint.com > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Tuesday, October 11, 2005 9:13 AM > To: RV10 > Subject: RV10-List: Very minor parts shortage > > > I have slow wings, QB fuse. Last week when I went to do my wing root > fairings I found that I was around 40 K1100-08 nutplates short. > I had just closed my wings, and thus had also just installed > all of them on the wings and access panels, having just freshly > opened those hardware bags. Gus verified that the quantity listed in > the various kits does not add up, and he sent me 40 more, which > arrived very very quickly I must say, by USPS. > If you're in the same postion as me, with slow wings, and QB fuse, > you should check your count and get some when you talk to them > next. I think the quantity supplied with the fuse kit was something > like 22. Required are at least 9 on each bottom, 12 on each top, plus > I think 7 around the nose. I think there were a few others, too. > > On a side note, does anyone who's completed the fuse know what's up > with the one nutplate that is predrilled that goes on the bottom > skin in the middle of the center section, where the wing spar goes? > It sure seems like this nutplate, if installed, would scrape > the spar. Gus seemed to think it may have been a set of holes that > was drilled by accident that won't be used. Just looking > for confirmation. I left mine empty. > > Tim > > ________________________________________________________________________________
Date: Oct 11, 2005
Best way I have found in 3 planes built is to save the wing tips until the wings are on the fuse. Line up the flaps perfectly in trail and be sure they mate to your fuse as you expect, then be sure the ailerons to match the flaps (or adjust to make them match), then fit the wing tips to match the ailerons. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Subject: RV10-List: Wing Tips Don't Line Up I am attaching my wing tips and have all of the nutplates complete on one and the other drilled and clecoed. Neither of the wing tips line up with the ailerons in neutral position. I have clamped the ailerons in line with the flaps in full up position. The trailing edge of the right wing tip is about 1/2" lower than the trailing edge of the aileron. The trailing edge of the left wing tip is about 1/4" higher than the aileron. The trailing edges of the wing tips are about 1/4" - 3/8" too long. I can trim them without breaking the trailing edge joint. I cannot see any simple way of bending/aligning the wing tips except for perhaps cutting the trailing edge in half and reattaching them while trying to twist them into alignment. I would love to hear what others have done to deal with this. I really hope it is not bad parts cause I have put a lot of hours into these wingtips. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB Wing Tips ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Re: Wing order + components
James, All the trutrak servos are the same, it goes easily in the right wing with the supplied brackets. I picked mine up from Less Drag products but there are other dealers, his service and the ability to buy just one servo at a time was cool. Sit down before you read the price though. I need some more info on Vans roll trim. My wings are done and wired so I'm in no hurry to add my roll trim just yet but it looks easy to install on the inboard access panel. Email me off line for my phone number if you want to discuss and I can tell you a lot more than typing it. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Aileron trim
I was just looking at Vans site for their electric aileron trim and it appears that the servo is mounted inside the fuselage not the wing. Am I missing something here? "RV Builder (Michael Sausen)" wrote: The Aerotrim unit requires you to cut a small square out of the control surface. It then sit's in that hole as a complete unit acting as the access plate. You then attach a small tab to the trailing edge of the control surface and the linkage then controls that. You would route the control wires out the back of the control surface into the aircraft. It is a very straight forward system when you want to add trim to an existing system that has no other option. For me the clean install of the Van's system inside the wing, moving the whole surface, is a better option. I may still consider Aerotrim for the rudder should the need arise. Michael Sausen -10 #352 Flaps --------------------------------- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: RV10-List: Aileron trim Did your aileron trim require cutting into the aileron itself or does is move the entire roll control? Rick s. 40185 ========================================== Photoshare, and much ==================================== ________________________________________________________________________________
Date: Oct 11, 2005
Subject: For your bookshelf
John Jessen wrote: > > > Ah well, I guess it's time for me to buy one of the standard aluminum > aircraft building books that gives the definitive answers to such > questions. Any suggestions as to the best out there? > > John Jessen > 40328 HS (and enjoying the learning as well as the doing) Standard Aircraft Handbook from Aero isbn 0-8306-8634-7 This is my favorite. Lots of information crammed into a compact book. Mark ________________________________________________________________________________
Subject: RV-10 Door Incident
Date: Oct 11, 2005
Anyone seen this? http://www.vansairforce.com/community/showthread.php?t3637 Yikes! Brian #40308 ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: tail light LED combo
Date: Oct 11, 2005
Thought you might like to know; I visited perihelion's site from Tim's link and figured it would be nice to have this option.. Rob, I am now looking seriously at the LED strobe approach for a combo. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 ----- Original Message ----- From: Robert G. <mailto:armywrights(at)adelphia.net> Wright Subject: tail LED Is there any way you guys can also make a combo tail strobe/LED position light? Rob Wright, RV-10 builder ________________________________________________________________________________
Subject: Elevator horn
Date: Oct 11, 2005
I was following an earlier tip of spraying primer into the steel tube portion of the elevator horn then swishing it around for coverage, when I had primer run out of the weld. I have very limited welding experience and wouldn't think a pinhole miss during the weld would be a big deal. Any comments on the integrity of the weld? Oh, got to see Vic and Carol Syracuse's -10 at the SERFI this past weekend at Evergreen, AL. I wasn't expecting to see a -10 there, so I was awesomely surprised, especially since my wife was there and she could finally see the end product of all my time out in the workshop. He's got a beautiful piece of workmanship. Rob Riveting elevators ________________________________________________________________________________
Subject: rv10 fuel senders
Date: Oct 11, 2005
Does anyone have any information on capacitive fuel systems for the RV10. I'm sure I saw a mention of it on someone's construction site but I can't find that site. ________________________________________________________________________________
Date: Oct 12, 2005
Hello Rick and James, sorry to put things here in a bit a different light, the servos are all the same from the dimension, however, they are different in torque they do supply (and Amps they use), so best thing is just to call/email them up and ask for the type you need for the aileron. br Werner Rick wrote: > >James, > >All the trutrak servos are the same, it goes easily in the right wing with the supplied brackets. I picked mine up from Less Drag products but there are other dealers, his service and the ability to buy just one servo at a time was cool. Sit down before you read the price though. I need some more info on Vans roll trim. My wings are done and wired so I'm in no hurry to add my roll trim just yet but it looks easy to install on the inboard access panel. > >Email me off line for my phone number if you want to discuss and I can tell you a lot more than typing it. > >Rick S. >40185 >Fuselage > > > > > > > > > ________________________________________________________________________________
Date: Oct 12, 2005
A bit more clarification. Trutrak has a series of servos to accomodate different aircraft. Additionally the servo for pitch is different than for roll. For the RV-10 they use Type C servos. Purchasing these with the install kits will allow you to defer the decision about which exact model of digital AP to go with. The servos would be different if you were building a Lancair IV. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: Re: RV10-List: Wing order + components Hello Rick and James, sorry to put things here in a bit a different light, the servos are all the same from the dimension, however, they are different in torque they do supply (and Amps they use), so best thing is just to call/email them up and ask for the type you need for the aileron. br Werner Rick wrote: > >James, > >All the trutrak servos are the same, it goes easily in the right wing with the supplied brackets. I picked mine up from Less Drag products but there are other dealers, his service and the ability to buy just one servo at a time was cool. Sit down before you read the price though. I need some more info on Vans roll trim. My wings are done and wired so I'm in no hurry to add my roll trim just yet but it looks easy to install on the inboard access panel. > >Email me off line for my phone number if you want to discuss and I can tell you a lot more than typing it. > >Rick S. >40185 >Fuselage > > > > > > > > > ________________________________________________________________________________
Date: Oct 12, 2005
Just a note on RUSHING to put warning systems on your gull wing doors that are not closed completely. There are several warning systems on planes today that still are ignored every day.............landing gear, stall, etc. WHY do we still have planes land GEAR UP? Warning lites/horns are nice but is still comes down to PILOT error! Then you have to consider a MALFUNCTIONING warning system, weight, and more electrical wire/potential problems. Can we and should we put a WARNING system on everything in our plane? Would that eliminate all incidents! JMHO DEAN Just a note on RUSHING to put warning systems on your gull wing doors that are not closed completely. There are several warning systems on planes today that still are ignored every day.............landing gear, stall, etc. WHY do we still have planes land GEAR UP? Warning lites/horns are nice but is still comes down to PILOT error! Then you have to consider a MALFUNCTIONING warning system, weight, and more electrical wire/potential problems. Can we and should we put a WARNING system on everything in our plane? Would that eliminate all incidents! JMHO DEAN ________________________________________________________________________________
Date: Oct 12, 2005
I did this same thing and had the same "problem", I thought I would out think Vans and removed the powder coating to see what was missed, found that over 1/4" was not welded, so took it to the local welding shop, had them "fix it" and called Vans the next morning to report the problem. I was then told that this was designed this way according to the drawing they purposely do not weld that area on both Horns. The powder coating usually covers it, but we all have those gaps. Needless to say, I ordered a new horn, and I quit trying to outthink them. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert G. Wright Subject: RV10-List: Elevator horn I was following an earlier tip of spraying primer into the steel tube portion of the elevator horn then swishing it around for coverage, when I had primer run out of the weld. I have very limited welding experience and wouldn't think a pinhole miss during the weld would be a big deal. Any comments on the integrity of the weld? Oh, got to see Vic and Carol Syracuse's -10 at the SERFI this past weekend at Evergreen, AL. I wasn't expecting to see a -10 there, so I was awesomely surprised, especially since my wife was there and she could finally see the end product of all my time out in the workshop. He's got a beautiful piece of workmanship. Rob Riveting elevators ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Subject: Re: RV-10 Door Incident
Date: Oct 12, 2005
Hi all, Is it a good suggestion not to use a warning if the door in question suffers a catastrophic failure when not properly latched? I think the microswitch option suggested is a good one, but rather than wire it to a warning light, wire it into the starter circuit, no locked door is no start in that case. The only problem you have left then, is when the door unlatches in flight and the engine stalls at the same time, you would have to try to latch the door and then restart, on the other hand, if that all happens in that sequence you might want to vacate the aircraft whilst the door is open anyway........... ----- Original Message ----- From: ddddsp1(at)juno.com To: rv10-list(at)matronics.com Sent: Wednesday, October 12, 2005 1:53 PM Subject: RE: RV10-List: RV-10 Door Incident Just a note on RUSHING to put warning systems on your gull wing doors that are not closed completely. There are several warning systems on planes today that still are ignored every day.............landing gear, stall, etc. WHY do we still have planes land GEAR UP? Warning lites/horns are nice but is still comes down to PILOT error! Then you have to consider a MALFUNCTIONING warning system, weight, and more electrical wire/potential problems. Can we and should we put a WARNING system on everything in our plane? Would that eliminate all incidents! JMHO DEAN ________________________________________________________________________________
Date: Oct 12, 2005
The gull wing doors on a Velocity usually won't depart in flight if one forgets to latch it due to a high pressure in the door region. Nonetheless, most builders position a microswitch such that the latching pin actuates it when it travels into the proper receiving hole. Velos drivers would never tie the door switch to the engine. Being a pusher, we taxi around with the gull doors open for au natural air conditioning. I have the door microswitches tied to a red light on the panel. No red lights allowed for takeoff. Chuck Do Not Archvie ________________________________________________________________________________
Date: Oct 12, 2005
The problem with this is that if you are sitting in the sun on a nice Florida summer day (or any summer day, for that matter), you don't want to latch yourself in before spinning that starter. You don't want to latch the doors until you are ready to taxi at the earliest, and usually not until you are ready to enter the runway. Further, after you land, you will want to open the doors while you are taxiing as well. Linking the doors to the starter switch would be a big "NO-NO" in my book. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RAS Subject: Re: RV10-List: RV-10 Door Incident Hi all, Is it a good suggestion not to use a warning if the door in question suffers a catastrophic failure when not properly latched? I think the microswitch option suggested is a good one, but rather than wire it to a warning light, wire it into the starter circuit, no locked door is no start in that case. The only problem you have left then, is when the door unlatches in flight and the engine stalls at the same time, you would have to try to latch the door and then restart, on the other hand, if that all happens in that sequence you might want to vacate the aircraft whilst the door is open anyway........... ----- Original Message ----- From: ddddsp1(at)juno.com Subject: RE: RV10-List: RV-10 Door Incident Just a note on RUSHING to put warning systems on your gull wing doors that are not closed completely. There are several warning systems on planes today that still are ignored every day.............landing gear, stall, etc. WHY do we still have planes land GEAR UP? Warning lites/horns are nice but is still comes down to PILOT error! Then you have to consider a MALFUNCTIONING warning system, weight, and more electrical wire/potential problems. Can we and should we put a WARNING system on everything in our plane? Would that eliminate all incidents! JMHO DEAN ________________________________________________________________________________
Date: Oct 12, 2005
Good point Werner, I did kinda lump that together in a whiz bang statement. I should have said it didn't matter which control head (in the digital models) all the servos for the RV-10 were the same were the same. Best bet like Werner said is to write or talk to your dealer for the inside scoop. For all you working on other than the fuselage, if your uncomfortable with 470 rivets ya better get over it!!! Lots of them on the Fuse. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 12, 2005
Subject: snap bushings...
Hi all, I just had a snap bushing pop out of the hole on my horizontal stabilizer... having blindly followed the plans, the snap bushing is now rolling around in between the nose ribs where I will never be able to pull it out (well I can probably grab it with some needle nosed pliers and pull it out in peices) or put it back into place. Looking at the bushings that are supposed to go into the elevators, it looks like the plans call them out the same way... it seems like they are supposed to be installed in the direction that you would not be able to remove them once the part is closed up. Is there a reason for this? I don't see why for all the future ones I have to do I couldn't install them facing the other way so that they can be removed or replaced without dropping them into the part... or am I missing something here? thanks, James #40400 - elevators ________________________________________________________________________________
Subject: Counter sinking - just how much really to get a good fit
Date: Oct 12, 2005
Well, let's see if we can bury this topic. As such, this is a long post. Last night I took a careful look at the countersinking. Some were cockeyed, that is, they were not uniformly round and thus might have blocked a good fit. Some weren't countersunk enough. Some weren't countersunk at all (how I missed 3 holes entirely I thought would be beyond me, but apparently not...don't work too late into the night may be the moral). So, I fixed all this and made them all uniformly a wee bit deeper. Then I refit the piece. Fit fine. However, I think I may have actually not done it correctly. This morning I was catching up on the RV mail bag and found a whole discussion on countersinking. Would have answered all my questions at once (and by the way, thanks for the information on what books to buy...they are ordered) had I been up-to-date in my reading! For those who do not subscribe or read the general RV Matronics list, I've copied the conversation here so we can have it on file and others who are just on this list can search on the topic and be done with it. I think the discussion was a good one. (I've removed some of the material to make it shorter, but none of the good stuff.) There was more discussion that followed what I've copied here, but I'll ask that you go to the Matronics RV site for yourself to read the rest. The basics are below. Three links that might be helpful and/or informative, one to the Matronics RV site with the follow-on discussions, one to a university / government publication mentioned in the follow on discussion, and one to Scott Bilinski's work on the strength of rivets set incorrectly, which I found very informative. <http://www.matronics.com/digest/rv-list/Digest.RV-List.2005-10-07.html> http://www.matronics.com/digest/rv-list/Digest.RV-List.2005-10-07.html <http://www.tech.purdue.edu/at/courses/at308/Technical_Links/MMPDS/OptionsMe nu.pdf> http://www.tech.purdue.edu/at/courses/at308/Technical_Links/MMPDS/OptionsMen u.pdf <http://www.kilohotel.com/rv8/rvlinks/marvelrivets.html> http://www.kilohotel.com/rv8/rvlinks/marvelrivets.html Thanks for you patience and help John Jessen 40328 HS ========== From: Dan Charrois <danlist(at)syz.com> Subject: RV-List: Properly setting rivets with dimpled surfaces --> RV-List message posted by: Dan Charrois Hi everyone. I'm just getting started on an RV-10 project and practiced riveting a bit on scrap material first last night. And I've run into a couple of problems/questions that I'm sure at least some of you have had, but I couldn't find anything in a search of the archives. First question - riveting two dimpled surfaces together: I've seen all kinds of resources saying that a rivet is set properly if the shop head is at least 1.5 times the diameter of the rivet and has a height of 0.5 times the diameter. That's fine and straightforward when riveting two flat (non-dimpled) pieces. But when measuring the shop head height formed against the back side of a dimpled piece, is the shop height measured as the amount the back of the rivet extends from the maximum height of the dimple, or from the amount the rivet extends from the non-dimpled surface? (not sure if I'm explaining this clearly, but hopefully you can get what I mean) If the shop head height is measured from the surrounding non-dimpled surface, I suspect that it may not be thick enough since some of the rivet that would normally be formed in a shop head on flat surfaces would be within the dimple itself and wouldn't contribute to the head. If it's measured from the "crown" of the dimple, it would seem as though the rivet would need to be a bit longer (by an amount equal to the depth of the dimple) to form the same size of shop head as if it were on undimpled material. But I haven't seen any references in the reading I've done indicating that the rivets made to join two dimpled surfaces should be longer than if the shop head is to form on an undimpled surface. Second question - countersinking to receive a dimpled surface:I read that when countersinking to receive a dimpled surface, it should be drilled about 0.005" deeper than if the countersink was to just receive the head of a flush rivet, so that the dimple will fit properly into the countersink. But in the test pieces I was trying to join, I had to drill substantially deeper than this so that the dimple would fit within the countersink to allow the pieces to lay flush against each other. And I don't want to have "loose" holes by drilling the countersink deeper than necessary. It seemed to be due to the underside of the dimple (the part formed by the female die) starting out with a larger diameter than the starting diameter of the countersunk hole when the hole was drilled to 0.005" deeper than required to receive the head of the flush rivet. And I'm pretty sure that I used the same size countersink bit as dimple die - of course, I could have made a mistake, but the pilot/guide of both the countersink bit and dimple die fit perfectly into the hole that I had drilled. Does anyone have an idea what I'm doing wrong? Am I dimpling too deep or something? I was under the impression that I had to press the dimple die so that the flat surface of the die was flush with the flat surface of the surrounding metal, but I presume that if I dimple less it may fit within the countersink better. In either case, a flush rivet seems to fit very nicely on the surface of the dimple as it is, and if I dimple less, it may protrude a bit out. I've also found that even when riveting flat sheets together, the range of the shop head being hit or squeezed enough to have a large enough diameter while not too much that it ends up too thin is very small - smaller than I anticipated. I'm sure I'll get used to exactly the right amount with practice, but does anyone else find it to be this way? In any case, I'm glad that I decided to try practicing a bit first before getting into the real construction. And lastly, I've read in the archives that some people prefer to drill a hole slightly smaller than required when dimpling a skin (using a #41 instead of #40, for example), since the hole will expand slightly while dimpling. Is this just being overzealous, or is there a good case to be made for this? I'm thinking that if the hole were slightly smaller, the rivet would expand a bit less while filling the hole, leaving a bit more material for the shop head, making the tolerances for setting it just the right amount a bit less fine. Any advice that anyone can provide to a beginner like myself? Thanks! Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 ________________________________ Message 15 _________________________________ From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-List: Properly setting rivets with dimpled surfaces --> RV-List message posted by: "Dan Checkoway" > when measuring the shop head height formed against the back side of a > dimpled piece, is the shop height measured as the amount the back of > the rivet extends from the maximum height of the dimple, or from the > amount the rivet extends from the non-dimpled surface? (not sure if Measure the shop head height *not including* the height of the dimple. Pick up a copy of "Aircraft Sheet Metal." Great book! Also keep in mind that there is a *range* of acceptable dimensions for rivet heads. <http://images.rvproject.com/MIL-R-47196A_MI.pdf> http://images.rvproject.com/MIL-R-47196A_MI.pdf Take a peek at that Mil-Spec for reference. > drilled. Does anyone have an idea what I'm doing wrong? Am I > dimpling too deep or something? I was under the impression that I You're not doing anything wrong. Just countersink deep enough to get a good FIT, without "bottoming out" through the material. Kitplanes magazine is running a series called "Build Your Skills," and in the 4th and 5th installments it goes into gory detail about dimpling and countersinking. > had to press the dimple die so that the flat surface of the die was > flush with the flat surface of the surrounding metal, but I presume > that if I dimple less it may fit within the countersink better. In Don't dimple "less." Whack the crap out of it and get yourself a nice crisp dimple. > I've also found that even when riveting flat sheets together, the > range of the shop head being hit or squeezed enough to have a large > enough diameter while not too much that it ends up too thin is very > small - smaller than I anticipated. I'm sure I'll get used to > exactly the right amount with practice, but does anyone else find it > to be this way? In any case, I'm glad that I decided to try > practicing a bit first before getting into the real construction. Again, reference that Mil-Spec link above. Sometimes you just have to "average" it out. There is a range of acceptable dimensions, and if I recall, the height dimension varies based on tension or shear (I could be mistaken about that). > And lastly, I've read in the archives that some people prefer to > drill a hole slightly smaller than required when dimpling a skin > (using a #41 instead of #40, for example), since the hole will expand > slightly while dimpling. Is this just being overzealous, or is there > a good case to be made for this? I'm thinking that if the hole were I'm sure people will argue one way or the other, but why not do what the kit manufacturer recommends, which is to use a #40 drill? Keep it simple. Don't overthink this stuff. You're building a light airplane, not the space shuttle or a Swiss watch. ;-) )_( Dan RV-7 N714D <http://www.rvproject.com/> http://www.rvproject.com ________________________________ Message 16 _________________________________ From: PJ Seipel <seipel(at)seznam.cz> Subject: Re: RV-List: Properly setting rivets with dimpled surfaces --> RV-List message posted by: PJ Seipel Dan, 1) Measure from the top of the dimple. The rivet doesn't need to be longer. On the RV-10 Vans does a pretty decent job of calling out the right size rivets. 2) Countersink deep enough that the dimple sits flush in the countersink after you rivet it. It's probably going to be more than .005". 3) With practice you'll be able to look at them and tell if they're good. I've been told that it's better to have them a bit flat than under-driven. 4) I don't have experience with drilling a smaller hole, but there are thousands of RV's flying who's builders didn't drill undersize holes, so I doubt it's necessary. PJ 40032 ________________________________ Message 17 _________________________________ From: "D.Bristol" <dbris200(at)sbcglobal.net> Subject: Re: RV-List: Properly setting rivets with dimpled surfaces --> RV-List message posted by: "D.Bristol" Be careful here. With a quality dimpling die, the under side of a dimpled hole is the same size as the top. You can see this when you put 2 dimpled sheets together - they fit just fine. However, when fitting the dimpled sheet into a countersunk piece you can have a problem with fit because the edge of the countersunk hole is sharp and the corresponding point on the bottom of the dimple is not, (quality "spring back" dies may give a sharper transition than cheap dies) especially if you didn't use enough force when forming the dimple. Also, dimpling can distort the sheet of aluminum making it look like the dimple/countersink is a poor fit. It's very easy to make the countersunk hole too big, trying to compensate for this miss fit and then you've got a mess. In theory at least, the countersunk hole should fit the rivet. Don't arbitrarily make it bigger, figure out why it doesn't fit and fix it Dave Bristol, -6 So Cal EAA Technical Counselor ________________________________ Message 18 _________________________________ From: "Rob Prior (rv7)" <rv7(at)b4.ca> Subject: Re: RV-List: Properly setting rivets with dimpled surfaces --> RV-List message posted by: "Rob Prior (rv7)" On 18:57:18 2005-10-06 "D.Bristol" wrote: > --> RV-List message posted by: "D.Bristol" > Be careful here. With a quality dimpling die, the under side of a > dimpled hole is the same size as the top. You can see this when you > put 2 dimpled sheets together - they fit just fine. However, when > fitting the dimpled sheet into a countersunk piece you can have a > problem with fit because the edge of the countersunk hole is sharp > and the corresponding point on the bottom of the dimple is not, > (quality "spring back" dies may give a sharper transition than cheap > dies) especially if you didn't use enough force when forming the > dimple. The engineer in me must speak up: A countersunk hole will always have a sharp transition at the top corner, unless you remove it. A dimpled piece of aluminum will always have a rounded (or filleted) corner in the corresponding location. This means you will end up with one of two situations: One, you can countersink until the skin sits flat, in which case there will be an air gap under the dimpled skin in the "cone" of the countersink. You don't want this. It's not as strong a joint, and can lead to corrosion in the cavities, well beyond where you can see it happening. Two, you can countersink to fit the rivet, in which case the skin will *not* sit flat in the countersink. This is not a problem, if your dimple is good. When you drive the rivet it will drive that rounded corner into a sharp one and it will all become flush. This is what you want. So: Countersink only far enough to fit the head of the rivet. There's no reason to go further As for drilling a smaller hole so everything is "tighter", the engineer in me says you will end up with a smaller diameter of "meat" in the hole once the rivet is driven. This means that every rivet joint will be slightly less strong than it was designed to be. Which means your airplane is slightly less strong than it was designed to be. Why would you want that? Stop second-guessing the designer. -Rob ________________________________ Message 19 _________________________________ From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-List: Properly setting rivets with dimpled surfaces --> RV-List message posted by: "Dan Checkoway" Remind me tomorrow to put an AN426AD3-x rivet in my female dimple die. I honestly haven't even tried that yet...but I intend to! I wonder if the rivet will sit flush or sit low. My $.02 bet is that it will sit low. I'll try to remember to check it out tomorrow... Also, there is a distinction between "spring back" dimple dies and the regular flavor. The end result is supposed to be the same but it may not be. )_( Dan RV-7 N714D <http://www.rvproject.com/> http://www.rvproject.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Subject: Re: RV10-List: Counter sinking - just how much really to get a good fit You can deepen them a bit more just watch out for the hole enlarging and really making a mess of the countersink and hole. I think you will find that when you rivet the skins to the flange everything will suck up tight in the assembly. Get ready to rivet and see what happens, if it still sits high drill it out and deepen the countersink, I had several areas like this and it worked out OK as I riveted. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 12, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Easier solution is to put a dab of E6000 on them to hold them tight. Michael Sausen -10 #352 Wing assembly -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: RV10-List: snap bushings... Hi all, I just had a snap bushing pop out of the hole on my horizontal stabilizer... having blindly followed the plans, the snap bushing is now rolling around in between the nose ribs where I will never be able to pull it out (well I can probably grab it with some needle nosed pliers and pull it out in peices) or put it back into place. Looking at the bushings that are supposed to go into the elevators, it looks like the plans call them out the same way... it seems like they are supposed to be installed in the direction that you would not be able to remove them once the part is closed up. Is there a reason for this? I don't see why for all the future ones I have to do I couldn't install them facing the other way so that they can be removed or replaced without dropping them into the part... or am I missing something here? thanks, James #40400 - elevators ________________________________________________________________________________
Date: Oct 12, 2005
So, should we all be "cementing" snap bushings in place? Should this be standard practice? John Jessen 40328 HS _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: snap bushings... Easier solution is to put a dab of E6000 on them to hold them tight. Michael Sausen -10 #352 Wing assembly -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: RV10-List: snap bushings... Hi all, I just had a snap bushing pop out of the hole on my horizontal stabilizer... having blindly followed the plans, the snap bushing is now rolling around in between the nose ribs where I will never be able to pull it out (well I can probably grab it with some needle nosed pliers and pull it out in peices) or put it back into place. Looking at the bushings that are supposed to go into the elevators, it looks like the plans call them out the same way... it seems like they are supposed to be installed in the direction that you would not be able to remove them once the part is closed up. Is there a reason for this? I don't see why for all the future ones I have to do I couldn't install them facing the other way so that they can be removed or replaced without dropping them into the part... or am I missing something here? thanks, James #40400 - elevators ==================================== RV10-List Email Forum - more: bsp; ==================================== ________________________________________________________________________________
Date: Oct 12, 2005
Subject: Re: snap bushings...
Hrm, just to be clear, this is the plastic snap bushings that the elevator trim cables go through. Is there a reason that they point in the direction they do on the plans? Thanks, James JOHN STARN wrote: > Not sure of the area but to work loose "metal" items to an open hole, > use a strong magnet on the outside (magnet will not stick to > aluminum) to drag the part over to the opening. It's works on washers, > screws etc on HRII N561FS so it should work on -10's too. KABONG Do > Not Archive > > ----- Original Message ----- > *From:* RV Builder (Michael Sausen) > *To:* rv10-list(at)matronics.com > *Sent:* Wednesday, October 12, 2005 11:53 AM > *Subject:* RE: RV10-List: snap bushings... > > Easier solution is to put a dab of E6000 on them to hold them tight. > > Michael Sausen > -10 #352 Wing assembly > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs > Sent: Wednesday, October 12, 2005 11:42 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: snap bushings... > > > Hi all, > > I just had a snap bushing pop out of the hole on my horizontal > stabilizer... having blindly followed the plans, the snap bushing > is now rolling around in between the nose ribs where I will never > be able to pull it out (well I can probably grab it with some > needle nosed pliers and pull it out in peices) or put it back > into place. > > Looking at the bushings that are supposed to go into the > elevators, it looks like the plans call them out the same way... > it seems like they are supposed to be installed in the direction > that you would not be able to remove them once the part is closed > up. Is there a reason for this? > I don't see why for all the future ones I have to do I couldn't > install them facing the other way so that they can be removed or > replaced without dropping them into the part... or am I missing > something here? > > thanks, > James > #40400 - elevators > > > ==================================== > RV10-List Email Forum - > more: > bsp; > ==================================== > > ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: Wing Tips Don't Line Up
Date: Oct 12, 2005
Thanks for this idea. Unfortunately I have already drilled the wingtips in place and on one of them have the nutplates attached. I think I will either have to bend the tips with heat or cut the trailing edges and re-epoxy them. John Testement jwt(at)roadmapscoaching.com 40321 Working on wing tips _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Subject: RE: RV10-List: Wing Tips Don't Line Up Best way I have found in 3 planes built is to save the wing tips until the wings are on the fuse. Line up the flaps perfectly in trail and be sure they mate to your fuse as you expect, then be sure the ailerons to match the flaps (or adjust to make them match), then fit the wing tips to match the ailerons. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Subject: RV10-List: Wing Tips Don't Line Up I am attaching my wing tips and have all of the nutplates complete on one and the other drilled and clecoed. Neither of the wing tips line up with the ailerons in neutral position. I have clamped the ailerons in line with the flaps in full up position. The trailing edge of the right wing tip is about 1/2" lower than the trailing edge of the aileron. The trailing edge of the left wing tip is about 1/4" higher than the aileron. The trailing edges of the wing tips are about 1/4" - 3/8" too long. I can trim them without breaking the trailing edge joint. I cannot see any simple way of bending/aligning the wing tips except for perhaps cutting the trailing edge in half and reattaching them while trying to twist them into alignment. I would love to hear what others have done to deal with this. I really hope it is not bad parts cause I have put a lot of hours into these wingtips. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB Wing Tips ________________________________________________________________________________
Date: Oct 12, 2005
If you have installed the AF-2500 engine monitor you have digital inputs that can be used for the door switch. The system allows you to select a Prop RPM that will activate the verbal "CHECK CANOPY LATCH" and a screen warning if the input is not made. This will enable you to taxi out with the doors open and if don't get the doors shut you will get a warning on the run-up. Red LEDS might work fine if you look at them before take off, for me I want a verbal warning in the headset as I advanced the throttle. You should use 4 switches all wired in series. On the next software release we will add the option of a verbal warning "CHECK DOOR LATCH". Rob Hickman Advanced Flight Systems ________________________________________________________________________________
Date: Oct 12, 2005
In a message dated 10/12/2005 3:06:18 PM Pacific Standard Time, n8vim(at)arrl.net writes: How many "extra" inputs are there? It would be cool to have "Check CoPilot Door...." or "Check Pilot Door...." so you don't ask your passenger to fiddle with the door if the problem is the pilots door... We have 4 digital inputs. That is a great idea, I will add both of the messages to the software. Rob Hickman Advanced Flight Systems RV-4 N401RH (Flying) RV-10 N402RH (Elevators finally finished) ________________________________________________________________________________
Date: Oct 13, 2005
James, I had finished the HS and poked my fingers through the rib holes to ensure the bushings were secure. I felt one had 'worked loose' and gave it a gentle push to re-seat it - only to find it was already seated properly and in fact I pushed it out of the hole ;-<. I then had your problem of a bushing rolling around between the ribs. After much dicking around with a pair of needle nose pliers and not being able to extract it, I removed the inboard most nose rib. I think there are are about 7 rivets to remove and the rib is very easy to reinstall. The job took me about 10 minutes total. cheers Ron Fuse. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of James Ochs Subject: RV10-List: snap bushings... Hi all, I just had a snap bushing pop out of the hole on my horizontal stabilizer... having blindly followed the plans, the snap bushing is now rolling around in between the nose ribs where I will never be able to pull it out (well I can probably grab it with some needle nosed pliers and pull it out in peices) or put it back into place. Looking at the bushings that are supposed to go into the elevators, it looks like the plans call them out the same way... it seems like they are supposed to be installed in the direction that you would not be able to remove them once the part is closed up. Is there a reason for this? I don't see why for all the future ones I have to do I couldn't install them facing the other way so that they can be removed or replaced without dropping them into the part... or am I missing something here? thanks, James #40400 - elevators ________________________________________________________________________________
Subject: solder or crimp??
Date: Oct 12, 2005
How many builders with Tru-Trak servos are using the solder type D-Sub connectors that they provide. I've been taught and it's my experience that soldered connections fail prematurely when exposed to vibration. The heat hardens the copper strands and they get brittle from repeated work hardening vibrations. It's a definite no-no to solder wires in a certificated aircraft. Anybody want to voice an opinion here? It will cost me about $44 for the crimpers and about $.40 per pin/socket plus a couple bucks per plug/receptacle to go the crimped route, which I'll probably do because there will be many more D-Sub connectors. Paul Hahn ________________________________________________________________________________
Date: Oct 12, 2005
Subject: Re: solder or crimp??
I took the easy route and went with Stein's harness. It's put together very nicely. Worth the $time$ saved in my opinion. <http://www.steinair.com/trutrak.htm> -Sean #40303 (wing rear spars) eagerlee wrote: > > > How many builders with Tru-Trak servos are using the solder type D-Sub > connectors that they provide. I've been taught and it's my experience that > soldered connections fail prematurely when exposed to vibration. The heat > hardens the copper strands and they get brittle from repeated work hardening > vibrations. It's a definite no-no to solder wires in a certificated > aircraft. Anybody want to voice an opinion here? It will cost me about $44 > for the crimpers and about $.40 per pin/socket plus a couple bucks per > plug/receptacle to go the crimped route, which I'll probably do because > there will be many more D-Sub connectors. > > Paul Hahn > > > > > > > > ________________________________________________________________________________
Date: Oct 12, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I used crimped connections. Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: RV10-List: solder or crimp?? How many builders with Tru-Trak servos are using the solder type D-Sub connectors that they provide. I've been taught and it's my experience that soldered connections fail prematurely when exposed to vibration. The heat hardens the copper strands and they get brittle from repeated work hardening vibrations. It's a definite no-no to solder wires in a certificated aircraft. Anybody want to voice an opinion here? It will cost me about $44 for the crimpers and about $.40 per pin/socket plus a couple bucks per plug/receptacle to go the crimped route, which I'll probably do because there will be many more D-Sub connectors. Paul Hahn ________________________________________________________________________________
Date: Oct 12, 2005
definitely crimp them. Try http://www.affordablepanels.com/ or http://www.steinair.com/ for better prices on the connectors, sockets, and tool. I spoke to TT about the fact that I was just pitching their solder cup connector and they agreed that they probably ought to provide the crimp connectors. They have apparently not followed through yet. ----- Original Message ----- From: "eagerlee" <eagerlee(at)comcast.net> Subject: RV10-List: solder or crimp?? > > > How many builders with Tru-Trak servos are using the solder type D-Sub > connectors that they provide. I've been taught and it's my experience that > soldered connections fail prematurely when exposed to vibration. The heat > hardens the copper strands and they get brittle from repeated work > hardening > vibrations. It's a definite no-no to solder wires in a certificated > aircraft. Anybody want to voice an opinion here? It will cost me about > $44 > for the crimpers and about $.40 per pin/socket plus a couple bucks per > plug/receptacle to go the crimped route, which I'll probably do because > there will be many more D-Sub connectors. > > Paul Hahn > > > ________________________________________________________________________________
Date: Oct 12, 2005
Simple always seems to work, how about VELCRO. Bob K ________________________________________________________________________________
Date: Oct 13, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
We got some custom capacitive probes from SkySports. (8 inches bendable, 8 inches measuring, which we bent into an 'S' shape to get most of the tank. We haven't tested them yet, but we will let people know how they work. Skysports will make custom lengths for about $75 or $80 each - not bad. They will also customize the output circuit as needed for your favorite EFIS, engine system, etc. (0-5 volts, x-y Ohms, etc) TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of L Aune Subject: RV10-List: rv10 fuel senders Does anyone have any information on capacitive fuel systems for the RV10. I'm sure I saw a mention of it on someone's construction site but I can't find that site. ________________________________________________________________________________
Date: Oct 13, 2005
I soldered mine but then again I have a lot of experience soldering cup/wire assemblies. The key as Linn wrote is to get the cup filled and a nice fillet of solder that just starts into the strands and not up into the insulation. There used to be a tool available for all you tool nuts that looked like a tweezers clamp. It had the shape of the insulation and wires milled on the inside halves and you would clamp it onto the wire then inset the wire into the cup and solder away. I think the USAF called it an anti wicking tool. On the older analog bomb racks this was how all the relay connections were made. Those racks took a beating and I never saw too many wire failures but the method was a bunch more work than crimping pins and inserting them into a rubber connector. The top of the relay had all the pin cups sticking out of it, I never did figure out why a cannon type connection was never developed to make the change a quick and easy one. After the wires were assembled they were tied and the wires were "potted". This involved wrapping tape around the connector to form a dam then the potting material was poured into the dam and it filled the gap between all the wires and sealed the connector as well as providing strain relief. I never replace a connector because of wire failure it was because the part failed. As in the old days I potted my connection with RTV, and I am using Dacron to tie my wire bundles where it is not an access issue. There is something about a hand tied and laced bundle of wires that says craftsmanship. FWIW I only soldered my servo end of the harness, I bought crimp connectors for the fuselage end. I would not even soldered mine but since I had the pins and the time, what the heck. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 13, 2005
Subject: Trutrak servo install
If you wait to install the servo until after the bottom skins are installed, be sure to attach the db9 connector first as it can't be screwed on (or off) with the servo in place. There was no "safety wire" shown for the installation bolts. Is that a problem? Jay 40011 From: Werner Schneider <glastar(at)gmx.net> Subject: Re: Wing order + components Rick wrote: James, All the trutrak servos are the same, it goes easily in the right wing with the supplied brackets. I picked mine up from Less Drag products but there are other dealers, his service and the ability to buy just one servo at a time was cool. Sit down before you read the price though. I need some more info on Vans roll trim. My wings are done and wired so I'm in no hurry to add my roll trim just yet but it looks easy to install on the inboard access panel. __________________________________ ________________________________________________________________________________
Subject: Re: Trutrak servo install
Date: Oct 13, 2005
In my mind not having the bolts safetied is an issue. Every other bolt in the plane either has a locking nut, nut plate, safety wire or cotter pin - why wouldn't you use drilled head bolts and safety wire them? Bob -------------------------- -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Subject: RV10-List: Trutrak servo install If you wait to install the servo until after the bottom skins are installed, be sure to attach the db9 connector first as it can't be screwed on (or off) with the servo in place. There was no "safety wire" shown for the installation bolts. Is that a problem? Jay 40011 From: Werner Schneider <glastar(at)gmx.net> Subject: Re: Wing order + components Rick wrote: James, All the trutrak servos are the same, it goes easily in the right wing with the supplied brackets. I picked mine up from Less Drag products but there are other dealers, his service and the ability to buy just one servo at a time was cool. Sit down before you read the price though. I need some more info on Vans roll trim. My wings are done and wired so I'm in no hurry to add my roll trim just yet but it looks easy to install on the inboard access panel. __________________________________ ________________________________________________________________________________
Date: Oct 13, 2005
I second this. We went with as many wiring harnesses as were available. Stein's harness is great. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: Re: RV10-List: solder or crimp?? I took the easy route and went with Stein's harness. It's put together very nicely. Worth the $time$ saved in my opinion. <http://www.steinair.com/trutrak.htm> -Sean #40303 (wing rear spars) eagerlee wrote: > > > How many builders with Tru-Trak servos are using the solder type D-Sub > connectors that they provide. I've been taught and it's my experience that > soldered connections fail prematurely when exposed to vibration. The heat > hardens the copper strands and they get brittle from repeated work hardening > vibrations. It's a definite no-no to solder wires in a certificated > aircraft. Anybody want to voice an opinion here? It will cost me about $44 > for the crimpers and about $.40 per pin/socket plus a couple bucks per > plug/receptacle to go the crimped route, which I'll probably do because > there will be many more D-Sub connectors. > > Paul Hahn > > > > > > > > ________________________________________________________________________________
Date: Oct 13, 2005
Do these probes mount on the baffle? Are they built specifically for the 10? I looked into these awhile ago, and wondered how the mount works out. Thoughts? cj wings #40410 -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Subject: RE: RV10-List: rv10 fuel senders We got some custom capacitive probes from SkySports. (8 inches bendable, 8 inches measuring, which we bent into an 'S' shape to get most of the tank. We haven't tested them yet, but we will let people know how they work. Skysports will make custom lengths for about $75 or $80 each - not bad. They will also customize the output circuit as needed for your favorite EFIS, engine system, etc. (0-5 volts, x-y Ohms, etc) TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of L Aune Subject: RV10-List: rv10 fuel senders Does anyone have any information on capacitive fuel systems for the RV10. I'm sure I saw a mention of it on someone's construction site but I can't find that site. ________________________________________________________________________________
Date: Oct 13, 2005
That probe mount configuration is an industry standard, so they bolt right on. The 8 inch/8 inch length was our spec to fit in the first chamber of the RV-10 tank. If you were starting early enough, you could maybe use a longer probe diagonally through the entire length of the tank. You'd have to feed it through the structural ribs without touching. TDT ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Subject: RE: RV10-List: rv10 fuel senders Do these probes mount on the baffle? Are they built specifically for the 10? I looked into these awhile ago, and wondered how the mount works out. Thoughts? cj wings #40410 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Subject: RE: RV10-List: rv10 fuel senders We got some custom capacitive probes from SkySports. (8 inches bendable, 8 inches measuring, which we bent into an 'S' shape to get most of the tank. We haven't tested them yet, but we will let people know how they work. Skysports will make custom lengths for about $75 or $80 each - not bad. They will also customize the output circuit as needed for your favorite EFIS, engine system, etc. (0-5 volts, x-y Ohms, etc) TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of L Aune Subject: RV10-List: rv10 fuel senders Does anyone have any information on capacitive fuel systems for the RV10. I'm sure I saw a mention of it on someone's construction site but I can't find that site. RV10-List Email Forum - bsp; ________________________________________________________________________________
Date: Oct 13, 2005
Subject: Re: Engine Mount Clearance issue
Tim, I have done welding, and know a few very experienced welders. In short, Don't trust a local welder; There are too many variables in the welding process (even the humidity or the rate that the weld cools have a *big* effect on the quality) I'd also do an eddy current test (if you can borrow the equipment, and the knowledge of how to do it) to detect microscopic cracks. But that's just me. -Jim 40384 Tim Olson wrote: > > I thought I'd pass this along, because I know that there are at > least a few parties that this applies to. > > I sent Van's a note asking about the required clearance on the > rear crossbar of the RV-10 Engine Mount. Mine is between > 1/16" and 1/8". A piece of .063 does fit thru the gap, and > a piece of .125 does not. Here is their reply: > > ------- > > Tim, > > I'm sorry to report that the tube on your mount that is to close to > the sump must be moved. You can cut it off and re-weld it yourself > or return the mount to us and we will do it. There should be finger > clearance between the tube and the sump, about 1/2" should do it. > > > Bruce Reynolds > brucer(at)vansaircraft.com > > -------- > > So, I guess I have a project to do before I can continue. I'm very > glad I haven't hooked up my cabling yet. Question: Is this a > weld that you would trust your local welder with, or not? > > ________________________________________________________________________________
Subject: Engine fittings
Date: Oct 13, 2005
Can someone look at the picture of my C4B5 and tell me what fitting is what. In particular, the one fwd of the brass oil temp sensor (behind the sensor in the pic) and the fitting below the R/H mag pointing to the right. ________________________________________________________________________________
Subject: FW: tail LED
Date: Oct 13, 2005
More info on a possible forthcoming combo LED tail light/strobe Rob Wright _____ From: Eric M. Jones [mailto:emjones(at)charter.net] Subject: Re: tail LED Rob, You have my permission to repost anything of mine you like. Since many customers don't like my "Buy the Whelen then throw away the inside$" approach. I plan to build the whole thing along the lines of the attached (without the xenon flash tube). One big advantage is that there is no HV wiring and no big power supply box. The "Other Brand" LED position lights being touted are certainly wrong photometrically. See my website: http://www.periheliondesign.com/downloads/aircraft_beacons_using_leds.pdf http://www.periheliondesign.com/downloads/redandgreenledpositionlights.pdf Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 ----- Original Message ----- From: Robert <mailto:armywrights(at)adelphia.net> G. Wright Subject: RE: tail LED ________________________________________________________________________________
Subject: Elongated hole
Date: Oct 14, 2005
Folks, I know this has been discussed before, but my search came up with examples not quite the same. So, am asking anew. The part is one of the nose ribs for the HS. Using the pneumatic squeezer, working too quickly, I punched a hole next to one that I was trying to dimple. It was so close to the original hole that it made a bigger hole, about 3/8 inch, but oblong in shape. Any suggestions as what to do? An oops rivets could not fill it if I were to drill it out. The picture shows the elongated hole in the foreground, with a correctly dimpled hole on the other side of the nose rib in the background. John Jessen 40328 HS (Finally made up my mind and ordered the SB wings today) ________________________________________________________________________________
Subject: Elongated Hole - 2
Date: Oct 14, 2005
This view might be better. John Jessen 40328 HS ________________________________________________________________________________
Subject: Re: Elongated hole
Date: Oct 14, 2005
Replace the rib. Paul Walter ----- Original Message ----- From: John Jessen To: rv10-list(at)matronics.com Sent: Friday, October 14, 2005 6:22 PM Subject: RV10-List: Elongated hole Folks, I know this has been discussed before, but my search came up with examples not quite the same. So, am asking anew. The part is one of the nose ribs for the HS. Using the pneumatic squeezer, working too quickly, I punched a hole next to one that I was trying to dimple. It was so close to the original hole that it made a bigger hole, about 3/8 inch, but oblong in shape. Any suggestions as what to do? An oops rivets could not fill it if I were to drill it out. The picture shows the elongated hole in the foreground, with a correctly dimpled hole on the other side of the nose rib in the background. John Jessen 40328 HS (Finally made up my mind and ordered the SB wings today) ________________________________________________________________________________
Date: Oct 14, 2005
From: "Harris, Jeremy P" <jeremy.p.harris(at)boeing.com>
John, I'd probably flatten it, ream it out round to remove and potential sharp corners, make a new tab to be used as a doubler, and and rivet the two pieces together with #4 c/s rivets clear of the hole that needs to be drilled to mate the tab to the skin, and finally dimple. I don't know how much room you have on the tab but there might be enough room for an extra rivet or two to hold the doubler in place. Of course if you have access to a lathe and liquid nitrogen, there is a more fun fix. You could enlarge the hole to say 0.375" dia round cleaning up all the damage, machine a hat crossection freeze plug with a small diameter of .379" x skin thickness and a lip of .400", dip it in LN2, and install the plug in the hole. When it warms up, it will never come out and the hole would be filled. The larger diameter side goes on the opposite mating surface so it doesn't interfere with the parts you're riveting together. You can then machine countersink in the freeze plug if you made it thick enough. It works in .032"-.125 767 skins. Don't know about .016 or .020 skin though... Good luck! Jeremy ________________________________ From: John Jessen [mailto:jjessen(at)rcn.com] Subject: RV10-List: Elongated Hole - 2 This view might be better. John Jessen 40328 HS ________________________________________________________________________________
Date: Oct 14, 2005
From: Dave Lammers <lammers.david(at)mcleodusa.net>
Subject: Re: Elongated Hole - 2
John, I'd flatten the hole--then rivet a patch on the backside--then start all over. It is not a real critical area--nor is it seen by anyone. Dave Lammers HS John Jessen wrote: > This view might be better. > > John Jessen > 40328 HS > > Text inserted by Panda Platinum 2005 Internet Security: > > This message has NOT been classified as spam. If it is unsolicited > mail (spam), click on the following link to reclassify it: It is spam! > <http://127.0.0.1:6083/Panda?ID=pav_12748&SPAM=true> > > /9j/4AAQSkZJRgABAQEAYABgAAD/4RWDRXhpZgAASUkqAAgAAAAQAA8BAgAGAAAAzgAAABAB AgAUAAAA1AAAABIBAwABAAAAAQDB2BoBBQABAAAA6AAAABsBBQABAAAA8AAAACgBAwABAAAA AgBLOjIBAgAUAAAA+AAAABMCAwABAAAAAQAAAAEQAwABAAAAIAoFBAIQAwABAAAAmAcRBWmH BAABAAAAFAEAAAGkAwABAAAAAABS0QKkAwABAAAAAAAYGQOkAwABAAAAAAA3OASkBQABAAAA DAEAAAakAwABAAAAAABnaBQGAABDYW5vbgBDYW5vbiBQb3dlclNob3QgUzUwALQAAAABAAAA tAAAAAEAAAAyMDA1OjEwOjEzIDIzOjU2OjQzACAKAAAgCgAAGQCaggUAAQAAAEYCAACdggUA AQAAAE4CAAAAkAcABAAAADAyMjADkAIAFAAAAFYCAAAEkAIAFAAAAGoCAAABkQcABAAAAAEC AwACkQUAAQAAAH4CAAABkgoAAQAAAIYCAAACkgUAAQAAAI4CAAAEkgoAAQAAAJYCAAAFkgUA AQAAAJ4CAAAHkgMAAQAAAAUANZ4JkgMAAQAAABAABF4KkgUAAQAAAKYCAAB8kgcATgIAAK4C AACGkgcACAEAAPwEAAAAoAcABAAAADAxMDABoAMAAQAAAAEAyOgCoAMAAQAAACAK848DoAMA AQAAAJgHG20OogUAAQAAAAQGAAAPogUAAQAAAAwGAAAQogMAAQAAAAIABgIXogMAAQAAAAIA OgAAowcAAQAAAAP/CgAAAAAACgAAAAoAAABQAAAACgAAADIwMDU6MTA6MTMgMjM6NTY6NDMA MjAwNToxMDoxMyAyMzo1Njo0MwADAAAAAQAAAAAAAAAgAAAAwAAAACAAAAAAAAAAAwAAAF8A AAAgAAAA4wAAACAAAAAOAAEAAwAuAAAAXAQAAAIAAwAEAAAAuAQAAAMAAwAEAAAAwAQAAAQA AwAiAAAAyAQAAAAAAwAGAAAADAUAAAAAAwAEAAAAGAUAABIAAwAcAAAAIAUAABMAAwAEAAAA WAUAAAYAAgAgAAAAYAUAAAcAAgAYAAAAgAUAAAgABAABAAAAYPUSAAkAAgAgAAAAmAUAABAA BAABAAAAAAAxAQ0AAwAiAAAAuAUAAAAAAABcAAEAAAADAAAAAAAAAAQAAAABAAAABAAAAAAA AAAAAA8AAwADAAUgAAD/////qgLjACAAYwDAAAAAAAAAAAAAAAAAAP//AAAgCiAKAAABAAAA AAD/fwAAAQAAAAIA4wAiAdkAAAQAAAAAAABEAAAAgABEAMAAAAAAAAAAAgAAAAAAAAAAAAAA AAAAAAAAAAABAA8AAADAAAQAAAAAAAAA+gAAAAAAAAAAAAAAAAAMAAAAAAAAAAAAAAAAAAAA AAAAAAAACQAJACAKmAcgCtcA0wEnAAAAAADUASz+AADUASz+AADUAQAA1v/W/wAAAAAAACoA KgAqAAEAAAAAAAAAAAAAAElNRzpQb3dlclNob3QgUzUwIEpQRUcAAAAAAAAAAAAARmlybXdh cmUgVmVyc2lvbiAxLjAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABEAAkA swEBgAGAAYABgAGAAYABgAGAQAAAAAAAgQAAAAAACgAAAAAACgCVAhz/DgAAAJQD8AMAAAAA AAAAAHIAAADH/wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAACNJwAbAQAAwKkdANQAAAAGAAMBAwABAAAABgCSkxoBBQABAAAAYgYAABsBBQABAAAA agYAACgBAwABAAAAAgDS0wECBAABAAAAcgYAAAICBAABAAAACQ8AAAAAAAC0AAAAAQAAALQA AAABAAAA/9j/2wCEAAkGBggGBQkIBwgKCQkLDRYPDQwMDRwTFRAWIR0jIiEcIB8kKTQsJCcx Jx4fLT0tMTY3Ojo6Iio/RD44QjM3OTYBCQkJDAoMFAwMFA8KCgoPGhoKChoaTxoaGhoaT09P T09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT//AABEIAHgAoAMBIQACEQEDEQH/ xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAE EQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNE RUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeo qaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEB AQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFR B2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpT VFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1 tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/ AKCaVc7f3YDA+nFWrXRrtDu89YR3wc0aPf7gp4ectfhXcuvDCsey4uGl9s1H9ujt7Roo4wRu 3AnrUXS0R0qlGm+7I5rmV4kAVUUcg96xfEcATU0vVl4kjAOTgVnUd4m+Fly4hPZIo/bLee7j 2ZMvl4cj7px0rQjnwnHXHWpp7GeYNOs7dxv2kg47Uv2gYyTmtjzx0c43gDpmvRLU7bVOQMqD +lceL2R24Pd+hMjbTyR9ackgZs8Ht0riTO5oeSQeoGPypPNzksc/hmqTJsIZVxgg8d8VGZM8 9PSi4rEJkYZK4xn0prSglRvyAMYFFyWjl31Bzn5lUf7IzUJuXkPyh3Puf6CvVbZlzSltou4p jnxlsR59flqsyRRNueXzW9F5GaSXcym4rreXca80kjZZiSayfFUKvoCyq/zwyYK+mabWhipv mujnfDchOsorHIcEV0zjaSvSkiJtt6kTk03cenatEzNkkLZlUdyRXplo3+jR4IOVA9e1cWM2 Xqd2C3foTJIVBwuRmnjn5ixGK4T0Bu7B6nbjv1pSWJ+b7uOKZLBmXgggZ49KiYjJBOefTmgk Y78bcnOOKil27gd2Dj+EdKZLOTN9AgPkWu4j+KQ5qOTUrll/1qwr6IMV7FvkcEqrf+RV3+a+ V82Zv9nJqzDJJZ83KwW0LjDeewzj2HrRt5LuRZ9dL9DPudc0ixnB+2vckHO2BOPzNc34h8SH V3MdvCLa23btmckn1NQ3f07lKKXqZ+kOU1OEg4JbGa651KuwY5OaEZT3IZGP4U0EkVZJc02x nvLtBDGz4I3EDhRnvXo8GFjRSRhOBk1w4t6pdT0MFG15PZ7EwxIpOOCfSkwydycn9K4juY8n C4z71C0hI7Z7U0SwZjtORuHfB6VGZcjJzg9+9Mlgzb48KR6jtTSTuBA69T0/Cglnn9zq2jWx PmXsk5H8FunH/fRrOn8Y20R/0HTI8/37hi5/LpXruXb7zz4q22nn1My88W6rdjabpok/uwgI P0rIkmeVt0jsxPcnJqfXVhtt95GW9KaRmgB8EnkTo4/hYGvb9J0LStR0SC8kty0kkYZv3h64 +tROTjsVCEZPXWy0NeeLwdolqHvLa0DYB2EGRvy5rl9T+IelW526FoFohHSaeJf5D/GnFyl5 LuKbjD17GTD441uZnaW4QwOeYREqp+QFdfpd0l9pyTqNueoznHrXNi6aSUlfzN8HVcm4v5F4 NhTnPXoKD84J3Y2+1cKO9gxAHB/Xmm+dgckAY9KpEgc5wpGcc561DvAbjBPPFBLGO57ABsdx xinAjBycjHPeqIZ4OXyaYSSa9U88MUm2gBCKSgBrda6/RNe1FtCW3iu5VSM7doOOKLJ76kSk 4q607lhlwnzszMRzuHNV3hRvarM2OX92oUdK7DwjeZ02RApZ43yozisMUr035M6MI7VV5o6P zSyqWUgkcj0pGuFzhTt+oryj1xVI2/KBn6U0H5Mn6etMliyEsQM444qFW3PlsjHpQiWBfbLt PQ57Uiudy9l6de9MhnhWKbivXPOFxSUAGKaRQA0itnw22ZZYT0dcj60EyV0bDN65PuTmoy6n pVmQ77Q/l7CcjGBkZx9PSt7wbNtvZYT0dayrq9N+hrQdqkfU7MlduecA8f41CW3uTkDj3ryE e2OTKnG5j7jp9KWUkx4bKjtg4oJYBypA+8R3qLEinIyuOPSmSxpBJydw5znjP4UrP6DpznGK ZDPD8UhFeueaOAJqaOxnlGUidh6heKTaW+gi3HoFzIMsFT6nmpRoKKuZJyf91aydVdNRXBtM toufLZj/ALVT2qRwSI8a4OccDtU87e4t0X5k++AO+QataN4V1HXlke2EcUUZ2l5TgE+ldEp8 quKnBzdkO1Twlquk27XE8SvCv3njbdj607wv5i6msiK2AOfelOSlB+hcYOFRJ90dqsp3DIAH 5U9DmRyuVPf/AOtXjHtEgZcDHDZ6GmvwmHwT7DrQJkDEowU5IPrS73G7fggHgHjAqiBFCybu oyM4J6UhJUlnZcjr+XSmiGeTwaDcOcSYj9c8mtCLw/bIP3kruR1AGBXpynbbU8rmLkOn28C5 jiTjvt5/WpiG5wcD0xWEnffUBkgXj5up6kdqgliUnHIPapvYCKRcDjBPXJqu7YYcD8+lUhmp aNHJtE2QjLtLDse1dRoOsafbabcwz309s7rjbGmQx6bgexxXVyqSV9iYScXpo0LN4hs9H8LS 6bZfapPOzkz4wAe4OT/KsLw4CtwzrnkYx61MkoU31VjaMnOou9zrElLRj16+lOjf5htbDHtz XkHrjxuL8Z684pCROSem3qxNMljMhmzyc+lDKCG6ITjJx/OgliSS4XHyjHemtN8/UEeh6imi GciI8bsAYz3FMEYB46nr6V3XPJHKmIyCSefpUJJL54HNSMR0ZSDkbR1FQuN3Jz+dICA91J6n sagdeTgYFUBo6Xb/AGzzAWXbGpkIZsZAqO/iNuVZgUR/uhga3VWK9179ClSk1zLbqXNH01L6 JZGdiu7G0cZrooLYQKFjTaoGOOp/GuKvWc3yrSKO/D0FBc28mW45cReWrbgOp9alD4OdrHHt 3rlOsekrLjKFjjtSr8rsc4HYN1BpiYb8MuVKkDrSAjL4Iz6ntTIYz72QMFhyDjg1A2+Rdyg5 Un7y9aaIZzCtvyARx+tNQ84B5712s8kQoWBb+HPTrmkCEH37cYpMYjpyeT0446VE4JIGGPFS Mjki+dTgjNReTyRkDHA460XGIIiF3Hj26VYvLl71Y0lVQIuCRServ2NYSaTj/MbegQmLTPMA JZmOVz2zWnhl5ySpOFzz9RXLJ+8z0qafIvQmZdvHTHOD/LrUoyoTcnX3xj8KllocUccA5BPr TgwXaA2R220CZEx2v0OD1yaQOzrt+8D368VRDG/flAJA9OxpfMG3arDjnr1NMhnJ+WOwOfQ0 /bgDpnsBXceSCoY+QSTnnNINzfMADmpARlAUALgj3601fvZYEEdRUjRDJIFyQcDPJPam2qC8 ukjByufmx3pPRX7FwV2l3Z1C6dbTgReR5YHCnvVVdFtEkDSKSykZHYVzczXU9P2Ub7ao0EX9 3GhUBVBzgYx+FORsRogC7h1+bOajc2WhPHLG/wArqGUHjHGKkaPdyNpfoPXFSVuIyImFP3h/ dFBTA5YAevpTTE0QyEFiBkj6f0pAXMfCH6k9D9KtGbEUSSOrMoRuchTnP+FPZNybQcHnr2qt L6aIyb77nNLEykAgc9xSNFgEljkccdMV2nlCgbUz1PcHvTWVdnAAyeRUgRSMA59cZqCRiUzy akpFVyxyqH5SK1/DVqDO0rKCCNoPbPpUzfum9BXmvI6B2I2SIBuX5cEHI+lRKWccZJbO4njH OMVzHoj5FEiKPu7W7ccCpl2mbAA98+lIdxwjVSWUbgDj7tWYioXJ5X3OaTQKQ/IZuAB3NKQW OQF56k0rD5iMRoxUvyBwBikZCJGAGeM/SqSIkxi5xu5AHbrUcjBgEBYtnqOtWjJnPbSRlsAD pk9aTbgdQDnoK7WeWAAEhyB78U2VM5JXg1LAr+U0mAG3MOPSptQtltbdEBG9hknNRJ62NoR9 1y7bGSYpHO1MsXOAAa6uws1srNIyFyF53cc+tZ1XokdGFjq5dg3h3Dgbuex6fSpkAQE4BLdc H9KxOwkD+UgWRcFRgYOQaVX3KSASSO5oQmSmXAw3GRwcYFAchgAePTvTIZIJACSxOewxjIp0 cqqDgn6miw0xRKC+M9OlG/LclWJ9KQxnVMjKqemKquCH3lNzKTyDj+VUiGY8bDZ8w57Uihsf dK9+a7rHkgoGMYAz6USBdp5JI9aloZFafJc5foOlVtSna5n3B+B0z6VDXvehsn7lu7Lek2Sx /wClMMEfd5xWxJcExDzByDjJ64rnm7v0O6jHlgvPchcAXSOOoxkEdKeoRiylyQTkEVBsPIaQ KVIMS9ttOwHJwMNu/MUCYx8ibfksMdBzRKzJtMTYJ/OmiWPkmeSPDMenXrQ0xTB5Ze570APi mZZSSQQeeeop4cSNn5uuDQAp2gYCqx9T6VGA0jtg7QOcHvVIlmRgZ460pHY5zXceSLGuOBio ynzH2qWMqTbg5IJx6Hio7eBbi8TePlBy2PSolor+RpTV5JeZvFMAbeB/DkdB703eqoWB+btk VyHqIWHa+xlPy5zmrAAAV13HnOTx1pDITJkMCCo6Dcc804/f37h8q8CmASuSPm+U46joaQle FQDAGDg0CGuwwqKSBjGcYyabIwPAJUr6dqZJJHO20FwXweMdRSpKwlY5AHYmnYQ+OZS+12Ge eR0P4UKQIskkk5+6e3TiqSJbP//Z/9sAQwAIBgYHBgUIBwcHCQkICgwUDQwLCwwZEhMPFB0a Hx4dGhwcICQuJyAiLCMcHCg3KSwwMTQ0NB8nOT04MjwuMzQy/9sAQwEJCQkMCwwYDQ0YMiEc ITIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy/8AA EQgCqQOMAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQ AAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJ ChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SF hoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk 5ebn6Onq8fLz9PX29/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALUR AAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoW JDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKD hIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj 5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A5wpuX39KVIduMmnR81JjIrXYyvckjaNe 7flU5mG3qKpggU/fuqWhkjNz6UiyDB3DNR8g5BppGRxxTSFcWMgeYPVTTOacgPOfSk7U2CNa 0vmjt1UZwBVtNQ9c/nXPpLg9amE3vWTpq9y+Y6JNRUgA4qUagnXC/lXOCfB60/zial00HMdG LhJBkAY9KQTwhjwKxIpnEZGcULK2cjJpezKubxliK8Vi35G8kd6miZmHQ5qKS1kmbpxThTsx 8rexRiPzMOx7U/aQMEVfg0xlYE9qmmtAuOAK2GqUjPKEoMda7zwWUuNNntJR0PA9jXJxxKOK 6Dwy4h1JQONwwaG1axtTptO5RvNFFldMGHAYiofJHKrnHpXS+JsCRSO4rnVnWJtxGazTTOqy sRraIYmUioNMRreZ1T1q39rVs44FQWTj7YfeqbIa0LwJM2W60+6iDx5xTJsCWpBKvlkMalMu WsTCmUKxqNEGTVq7aPceRWebgKOO1VdHHJWOr0Vt1hPbHkEdKzYo0FvLGw5GaZ4fvs33lk/f GKln+TVZYuzcii+pS1jY8y8QsILuWMetZGj3Zt9SRs963PHVs1tqAfGAwrkYHZbhGAPBrBrc 7KVblcWei3kgmRXAHSqiE5qKGbzLVQfSnIfmFcrPpqT0L8B45rTeFbnTJFI5xWOj/NXTaJCL yF4gcNihK5OJXuHlMaeRqboeMNXTRHKAisjxDYy6dr8qOpXJyKvWMuVAPSuh7I+dprlk4mqH zHSKfmFCjikA2tVR2OOv8Rc2jaCKcq8YqNWymKlVuBVnMRAHfir8MIIBNV41BkBPSrEkwVdq /pVJpEsdJIsa4Bqoz7yaZIxbmmg4pD2JA2KkGDUAbNG/HNAEyH5sUpzkiq5c7gadv5zmgCRc GgsAaj3YwRSMTmiwExbNMb5uPSmK3ajdhsUxChacoLUDBB5pVcoeO9AyNhxQp7Upamcg0ASH rmpM5GKhzkU9DQIXoaTOTmlJpo5I9KQzc0sZT8a663j2xYiBEjrjcB0965LSziMfWuqs5mUs ZF+XZ8pxz0x17VyYrZHbhHqyPSILi3iukuMvtkLZ5+7jt+VX0HnxmXa5GcgZxj2qONJDZt+8 OGyOmCKdDMoHlADjgDvXG7M7VsWYWAkUdeMcf561WjjSWC5Q/wATYyR+VQzmdpAAMkkE54z+ NWIXP2eV8YPIOOh5pbDRC4X7xwHHGAevvzSACZeMlxzgg/pUpaNYowRt3HI3DJNCz7pSEfDK C2AO3amA2Ly5EDOrBgSQpHI/pTpik1nmB2QvwTjH/wCrnPSkhZijZbLk4II9qmjhjaIhBjkN yehH/wCvpQJi26uIjFPlsYCvjNOl3gldh+bOSp6VEx33cOGfaOTjoR/WpBNiVZCx2MdpJPI4 4zRdBZjI4F8wgx4zggY6+9SSxxKo2Alu+ByKkafbKpymzbuzmqjyFGVHy3G4O3r61XoLcQLN KQrR/uwvzb8n9KLWBPMKwbASMlcd6lF35xjCgKrjp1OfcUNHvkLHsOOw60aAPVR5h8zOMdOx /wDr81E/lPHJImUydq4HP0/Gp5k3xqAW2HkY9+1RlGEbZRivovDD8O/WheQh0SMyFPLbbxkk Y5/wp7QpGNwRV2nOc8/nUsU+9WU8heQuOapSXDSSupXbxnijRhqWAu8BwwAX7waq4BDFo3HX q54X2+lQRl3kYNjymAG0fpVsH5CqFQuR1FHkBKIVVY2AR2brkU8MpRt/BBxggjj2qBgDvVG2 oOTSmZdqtvZkI7ijcQ1ZY474AoWBHHpmp2mjfcy9ccd6hBTduC5z3IxiqcV/Fd2kM1pb5PmE Tb3wUwfT1qox5hN2JpkklyFY47Y7+tW/7MjS0RgW5X5+OvSoFcKCC3XpmrKTj7MFXfv64LVK dhspR74JQEGdvBBPH0p6swbMQCxhsoc4+v0qKaSUkugBjbh17g1Mv7t12YMMh+Yf3T6+1HXU B6osu75Qy5wynkHHT9ajVGjAxuKHsTyv496seeI8iMqxTug/rSPJ55ZdgI/iKjbyRT3ERMrO W8s4H8QqHzJdy8kFeD9M8VMxljLJ8qAjj/P4UwRKVcFd7deTjNO6ABKjk/Mu8dcfT0pZULqy 7RtP8J6GnoFf5goJIxnoc9qiLP5ZJbcwGD71KAQwp5CqMgZ6Zyc/5zSN8owsg2k5K+vHanfa UkticEbW5b8OlNtikwdguPr1pAND5KbIuAD82e9PiPGwkBhwQetNuIWLB8Z5+6eMj1xTOUd0 CAA9MDqOw/nT0AUo6SNJLtEYGScZqECOZsKh+YbiB1P+RUzXIaOSCUMGbjcehGf/AK1RyQSL AgU7lXptA6+/rTELDbpC8jE5B9ulP8nYuWhAPXP9KieeaOJF4DngNjI/H0qZ5gsG8xgIOGIP Si4ajbdWthPOFIB5C56juR/hUqSKieYcY2jGeuaRbmI2oAIBzgKOhPSoQsaOIW+YMCRxgdel DEQpcKb3aIQfM6erCtS6jjljXcAI1OSmOtZwhhJjSJyxj/hbqPbip7i5litxJg4zjA5IpdRv yIfLlhUq5UoDuX1A9M96cZdydNyEAA56deDUM9zKY2uI/urj5cVDaBJJnyeG+6mfunrxQyS0 Yo2Rt5XBxxioVWIDaI1O3jpTw5W6SHaAj52l+efr+dPZvLYhAqjqQR3/AAouGp5QoZMgg04N k4zxWwbIelV5rADkLXs8yZ5HK0UTwRgfnRknnaBj0q5Hp7O3J4pJbRozweDTugsypu46U5Bn mkZdrYxU6Rlk4FMEiM47VCwIzVtLOVjkDrVqPS3k6jFCRapyeyMbYSakWJ2PCmuhg0ZQPmFX YtMjQ9Kd0axwsnuculnKxyAavRaZK2DkiukW1jToKkCBeAKXMjaOES3MiHSzgZq7DpaoMk1c AxS+YQOMVNzZUYorizRckLxTxGq9FFSiXAqMtxSuyrJCMO9Vpxmpi+OpqCaRcUNkSIRwau6f MILuOTPQ1nPOpPWozcEuADUtkrc6LXdRScptIJxXPyXC8Ci7jcKHLZrPlzjNQjRyTZpZXaGU 9RUcUhS4BHrVBZyMDNWbdvMcVaYpGhd36xkZP41RlvXPKniotRjZ5VHamLHtUVKRLnZaETs0 nUmhYs81MUoEZ6irOaTbJtOTy72IqcHcK2Nbt5bTUoJm6OtYkZKSKw6g5rq9ab7bodvc4+ZM MT+lJs0p6bnEeNrBb2zjlA5GK4uDTUicFhXpWqQ+fpROOgrh3Oayk2mdlCKEH7tcDpUitgA0 jLlAaZHuLYxXPJanv0p+6mWUkw1dHol8ILhGRsGuaitpXbocVowyLZEMTzS23NJzjJWOh8Ra Vaa/FnhbgdD3rimsZdNuPJm6joR3qxqeszhDNBIUZDkc1ROsS6pIkkwG4DHFaxk2tjxK8Ywn Y2I8FBSSjBFRwv8AIBUjHcKuJ51d3ZLGcCnqwFQI3GKfnpWlzkZOWOOKQt8tMDYpCM80CHE0 0mgnim9RTAUNilJFN6mmMStADi/OKcG4qszc05HyaYiwG4xRv7UzIbkUHpigCVRlxg9qSTIO O4pI32tzT8iR8Ci4xgc04GmOCjYpu7mhgWFALY9aSTCMQaiD4IqWZg8Knv3pBoMD0LJ81Qg9 eaQHmnYC0WyDTFJphPy0gbAFJgdLpePLWuti2/ZjuXIKjp6Z5+vauP0o/uB611HkSzQRIrBc DIY1yYnZHdhFqy3b3Ec8ao2V3Z2jGG4qRnRHwkWGxnnv/SoILQQusxZmIHp0zU3lCRQCThOc Y61xHdYSQeagRtyueeD0qPBRVUZYHoCcZxwDUyzBiWCnIByCDxx1pYwr4kYKrHpxjrSAiEgI Ynnkru9KityyXWWAHXB6nuOQOtWxbkLJyCHbgen1pRtVVHycdgcn3ouDt0K6HEjLgqCQxfHT 6VZiuVuJkVQpCHBPGR/kVHLztw5GfX/PNMiUxxsXUAHDbguOn/66dhEkrpATG7li+QC3T0A9 qVn+VBHuUrwwIHXt/n2pzTwXLggOScZ3DpTpXWOEsMPgYI9fai4EE+TCSWwxOGPanq42qsbF wuevpjnH+HHFNaLypNu1QpxjIxz70SiJAQoAHcHOaYhyL5T5jC/MMsMce3NLP+8VGOAO+DkE 0iTJLCqx47kgDAxSyxL9maQAEpgqD2OD+dFwsSwDBaPI2nGd46HHanoGLN+8BGcZzyPpVMMR KJMO0LIBlTwB9ParAUGNUeTJIyAaVwsV/NaNyYSeRjb3qaOJ2zICAGIBUc0kVooYhGOM5zmn 3EiBCobAHGR1Bp37Axoj7upUE5J7fWmvN87YUfL936ilimBRfMJyT1we1CgNMVkXIB4x6UCI gWVSzDAOTgHkU5GdFQrymegNK5fLbVBCN1pwjMZGWyrDj2xRewaD45WaWRSMgg8AfdqOKa4S QRSGPy8tgIvLehJPoKAgdMkEsOnOD+dRRvvbozAdQTyKpN9BOKe5ZPzPvADcHAxjHvimsjIy N05BKjtUqADKCQBgOQw7VDJnBKuC69DnNCAne3ySVbZv5B6HNQ3EDwRh8qGAHPY05pT5S8bC Rgjupp2U8o5yzDIJ/lSvYLDYy7HLKAB1A/z2qwsSuN4fPcjGM1nKxWQDdvT7w9fr/wDWqZmZ gQJ8EkYwMds0XCxK4DKuBudW79OP/wBVMEabWKLyecDJFEUlwMF5EwP7o6+9CSp8+wAhjyAe c+1AhoiMfzFyxxgk8celK20AKSW+pxxSNMmSo+Rl5qoDJJelonVsLnLd+1C8wHqsbyPhCpyO M8H3H0pzyJEQqsAFPr1P+FJuRJGQtknBYDt/gKmlEIKO0ajcMEnt/Si4yAXQlh5VyyjcATnP +fT3p0jSmKPARSDwwOTj0qR1QzHA3HaQMelV7kNvSQZPOM9NtAgmuJIk3SRbgOu5ev0NPd5z IoMqpAw4QDofWnzTRvGNwLYUEge/pVeVFlgRh8wOAp9KLu4WViuj/ZGZmVn3E/eGfm9aVt00 BCjymfj5TwaUASFkkjymAoDcnPrVlkiaFPLyX28e2OlO+uoilOjKGxlVBz8o79jVgy+fawu3 Yhs4z0/lzUUUjNaktIDk9WPT8aZCc2ix5Pl7sHaOtK9waLipGt05Ct5j87k6A0rXQYkbOVJH J4yO1Mtopp98sZ4zx/ex6GpBaBLgM23J5fb3PahdxMpyo0kLje6FuCOnepYYYY1Dq2w98D+Y /rS3RXzECSIFJyUYZHvTgIhgbtoGSuBz+P8AKgGRrkyyLJ90kEZ/mKleIK2POzjuTmo7gbkX crM7HrnnFI09up24cY44FNEs41br5QDUquH7VJHp2ByKtR2qrjIr1+RHJGhJ7kCR7RkZFRyW 7ztyuBWnsAHApQBmhJI1WHXUyxpKkgkCrKWEadqu56Ckbg1VzRUoroRJAinG0VN5QUdBTcgU 5pcjmlc00WwY4qZFUpnvVcSDcMnikmlVMYPWk2FycAGmOcHFVGvQBwahN7Sch6mgHHeoZZgh xVCS8446VVe4dqV2LQ0jdKM81G13heDVAsWT3oWNz60tSHOJM12W4zUbuxHJpY7bmiROduaT M3MqHfu781LGuDvJ5qyxhWDBxnFZxmLNhTxQ3fREKWpfluDIoUngVWnIxgU0MAOtN3gMcmhK xd7lbo/JrU02MsS3pWds824wBxXS2lg8doXGOOtV0uDelijcRh2z6U0xhQM9Kmbg89c1FI67 etQnqNpcpHIo7U1WKg5pxw/Sq8jtEcEYqzmZMCoOeK37OX7To0sAIJUGuTac1paReFJHXsw5 oBMsxDzrGSM9hXFT2uy5dW7Guzspc3UsZGMk1yniWZbS8ZeATyKyn3O2i9bERhjWLcWFM+12 8XoTWDNqMjAqHODVXzyTyaxakzuhUS0bOibVuyAVXe6aVsk1kLN70/7SFHWlyHVHEQiixqL5 tHwearaS2QKq3V1vQrU2jg5H1reEdDyMXWU6t0dTCRipQ2CaSGLCAn0ocYNVY4akrjgcU8t6 VDnpUiimZEgYEU7OBUfQ0/dkYpgHFMY4NG/AxmkOKYhWJFJnNN3UmcGgBGUGkAIOaXPNJnim IeGwBTi+WqHORikVj607BcsBsHNG4qdwNRE570rE45osFyQykk5PWo92CDTSRik3c0CJGc7h Ti3HWod1OzlcUBccH5o70QyxKxWQdRwabvw3HSgZICTwaUDkUzPFPVulIZ0WlECJfXNdvbxE QIwIOR0NcLpnEa13EcoFvHy2VHCgda4MX0O/B9SSWeG2CyTsVXnGMmnCZvl8uTKyY2nA/Kqs 7DCLHGruScLnoDyf/wBVTIQYwSShUZ3AcVyJXO4Rt6TFkU7T1UdRinNIAoBVU/3uKQrIsSru ZstkZPXPaqs3mNLvkG1iAoRefxpBa5ZEkigpLIgHoDjFESrOMlAjZyflAyfWnKCuxJNrM3BI FNinRC0akyHOCccDmgQspj2iJsqxPBFI8TAInmZH8RPP/wCqh0AlwmN3JPcf/r4/WoTHJ5/m orjIIYDpVAXkgZBtC/e45+lNfYseVZcLxhx/SoJrmSJUQ5LhvlBzz9R6VHCZnDxSneOTkDGf xp9BAZXObdwXJyC6jp6U6OP5ixYsAMEH73+falELFGyvzFQDnqD7UxbSRYm3EFh/CO5oQ7Dg kjvsQFAB04qwxZNwPzBRyT+X9KhtWZFjAYlSccnJWp7l44nMTH537Y654/Kk0IWGWMgwLGxy uQvYk1JHGfLG5DG3T/64qKGOSBvmkUq4yf8AZ5PT1qYTqzomcANhge3pSYXI23I3+sOemMcY qOQ7IvMc5Ct/CPXoashkGWIwQSvPb0OaZOXCNEWPvznP0piuOCgoPIkBYAEZ4BppdFbdIQG3 dM/170yNgyYLDDHAOOuabPFFkbRkjqcdaLhYnIVV3xjbnkqDx79aqy/aGizDHGzk5CscChN0 UZ8hDtxkL1wP8KZDmU+UZwGzwvccUbasOhPH5iQJ5vzORhiP4ah3FWbB4U9uOP8AGppRLa53 lWQ9WxyPrUQizL5gClDw2O59ab0BCzAKyEKeT1xz0pssblQVUqx43AdAcdamlZknZWI7FSPp 0qv58ewmR/mXIwDgj2P5U09RDTczLJgqcgYO32//AFVIskjllQEq3GPUfWnQEG3cyu+VIxup 8VzvjkDEbkyQO5AouBUPmwxlNpUt1BHem+bKjBGAZD3I6VYLEMrHfh2yc5wPpUmYJpC6rjC4 DKR82fUGldMLleOaRHYqh25yCDyKYWijcM0pQ/w5xk1ctYUi3Al8+jHrSSRx3EZUAMe655zj 8qasJshmRZbqMwsB8pJIHDDtTJFeIO+F3NwOnPqDTktUDRuLgK54CL0PGOfTFK1yACsgEmDg MQcGkA1bd/NgO8hlUAlupH+PNPhjGCj7iAcAdeM8VOgLw/eyxGQ3cH2PcVQE1xuKtjqcEjGR /kinugHB5jes4UYT5cqOp96nLEzKAeGXLKf8+tMt5eSkQwwUFlOffNQpcg3d1lSQAFUjp1o9 BFlmADyAHaVxz0rPt/tEQYIGdA2SmfmHfIqV45pWmQ5jDZKDs1WYohb7JGyZOjjjH19adtAu EU8d3E+0BsKMcYINRrOInQqjPknheSPfFTQK0cxMcQEbElgT3/8Ar014/JZpQeBywxk8elIR GyrGfMXoT0z2P/16g86CKZigZFchXBH+r96l5Me4ZZSck469+lNnh83Eg4PckcH60XAn3Zsz 5cyrIcgOOhqCN2gjSSd3OcA5OcAjt9P6VXVWYNbrcxBlXjJ5zRtKRv8Aa1OWIO1efyo3EWCS jNMSWVBjJXmmTO5mYRD53G1WHY+pqmt1eSWjqsYBBI56kH696khE7KlwrIEIHynrRZiJ9rW6 CQsTITg7jxmpYjHOpaVnDg4O3pUaxtcyM7kqjDb9T61aNrEwU5OcDOO/vRoBhnrSjFRlwO9R NOAete02FyyWAFMLgVVe5AHWoDdA9DUcw9TRL8ZqMzKOprNe7YcVAZnY96XMw06mo90o71A1 2e1VCGZc55ojVj1ouyeeKHyXjdqjE7yHqTT/ALOSemakjhC9qWgvaPoRJG79M1PLCvkhgORU qbUOc9aglnQP149KTZm5tjljVoPm6/zNIkIA5qF79FXAqu167DCg0XZDkaBEaDqKBcRIecYr KLTSd8VZsbVZpwsrduPei3mLV7E8t9GpO3FUZbsycLUt5apDNtB+XGee1VGIXpUqxXJIDvf7 x/Cmlgn1qMyMe1J1NUJQsL5jE0oDucGnxwsz9K07e0Cjc1NLuDYWFrsIdhWmdVNshQAFRVCa cINqVRml3jg0S1EnYsXN0JAWU8nqargs4ySarFWB56VIrlRiko2CcybzTHgipVlScYcAGqYb K4PWlIxyDV2MeYSWPax9KfZsY7hT2Jpw/fRkdxUCybGA7g0IVzYkIt79WH8Vcv47hO+KcdDx W/dEnyZPpVPxbb/aNF8wDO0ZqJx0OiEzzQsaTfTW4NNJqbFe0ZL5mDTDIcHmo80hNFiXUYjt WrpLAOtZBrQ01sOKpGMmd3bgOmO2KbJHtJGKTS23AZNWrxPnyB2pbGbZn45qRTxTTyaVaoBz nuKQNxzSlhjFMBzxQgY1mpyNmo29O9Kp4piHHimE5NOY8U0YNNAKTxmmZ9qGz0FNzTJJD0pn elBytBGRTQhQ3OKfu4qEnaRT0NOwCkjNNHQ+1BOTSsfSkAg+9TwQrVEuQwz0qSToDQA2RQWy KkTAXkc1EOe9SYzQNDyRt96RW6UxsinKDxUsZ0elnhM+tdzE3yK5OQB0BrhdKziOu3tQwhGT uAGdtcOL6HoYPqRSzIk4YAruO4kgfrV6PHmvIpARsEKO3WsxZVuLtYZfkd0JU44GOx+tWYCk 9gUKsD93fjGa47He9USzxtvDFshTleelSzRloAUbHIJaoTI6KV2tu4B9KmSQtC0ayc9emcUC uVnkO8CR1AGec0sSCJQSRk/xdeO1KpVQwkPB6ZANCfKGiJPBIyRjjPpRsIbHKnnlTI0mSdue K1FeIAAKFycYPrWWyDepYfMgOSv86uKFMURGF3ZYEihhYkYI5UugJU/Kx7e3vURAiT+Ic8im CUxXCLINyueHPRf88VOVUr8p+UnOTT9RbEbXiFAGyvBPQjmnmTzV+8pBXKnPIzUEsSswYSMF Hr/WqyxvFcDg7GIBycYoHYl2eViQE7c4wDnH1oubhI7rzGOQmAJMZwfQ0y4SeDcxOVBO4c0y N2mcAYXA+6fzzQBeEkU0QyAGU8Dt9ar3MslvcXJjVGYMuFJ68VHscXqdlwflH061eMSPhhGp DAZBGQf/AK9AbFKPUUlDgBlZxgKTjBqSS2luIxIW+aMZKZx+lSJbxmIrKoARsjA5HuKrm4WU Ns3h8kAqcZPpTViSaBjLbqZEKt0HP5GicGIHaWOD8hPWkScSJtf92SOvepY38xDysig59eaA GJeBx8xG1BhiOOMU2DbnzwoJJ9O1ACTb4woUBuVPPU+tPifa3lKvC9s980mgRKxLkquWUAnB oV0jQFyAc9BUVzgEOcDJHU9Peq0l0rkDHyjqDRYCVpTJKTIMKflU9amW3XyzwucE8HOT9aih KPnqqjoT34zTxHncUcNjOCTgZ9M09RFWKG4Dt+9BiJAw2T0JGKumKFZlcqwYYBzVdJNwMTFl /vex6/lkmrWIzFvBXzMDOTgNRfULDbiJ1ibbjIOQRVP7Os2yaB/JfGevAOeR+dXXErhGUgM3 DA44H+RUdrG8AlBUBWORj37j8qHpsHQjhkKymOVVWXb84UcH3qzKkToHjf5+nTiqwVZ7uV5A 0b7doyM4qOe3lCsscjuqc7hxQA9pFiOZULlB8r596c6pKRgYGMnHaklwYE3EmVgWIP6/1qF3 eFcEfODjHqPf3piFVkSCTzs/L80dTCM3IzNndnKSBe/bjsf58iqshbhmj+U8jbznH8jVqKaQ Mp3KofhVxSvYCKeFvOLCTbwDjoDUUUbB53YHJOCDwGyas3ZQSJKSQmOcDiq8WZmaJlUAHjnq MjoaYrgtxDLKkZOWBypPvV0sEiZ2jLY6ZI71Ua2eN9xAKN97j071KsoZZYznYVwQeopbDGPf E2DsigyKQMfWopJWkiSdRJgfeYcfhStALdwC4ZpWBwV4FTxRyXL7YmCIOoxx/nmgRV86WVQr EKEwN2MbjUksococbRu2sv6ZFS3CL9kaBowAM4Gfun2qihQ3PmA4jYbuen507WBu5YFhAH8w KBIGJ+v1pJhGu0ldnODmrIaORPL3p5nqOtVXXbJKwZ3VAflXnJ+nagkiut8kOIlIYjIQj+tV yktvtDyblHLcd+4FEdxI1yOCnXI6e4z9KstO3mBggdWAygIz17ev0oBkSX6RxM0ybUPCL1LU 9bgSDc7Sx+gC5yPXNOmNvcR52hh24wyms5EnIO08A470WEY8ty30qAyO3ep5Y1eXI9OaVYBm vWM/avoVcu3FPijJPNWfLVabvQHtSuiXN9WMMWTmn+Wo7Ux7lV9Kge7JGAKV2RzIvBE25zTD JGg61nebM3AOBSeWzfeYmgPeeyNFNRjQFT+lVJL1mY7BUYjUdetL8oHSloUqcmN86ZxjJFNE LFssTUu6mMSehpcxoqPcf5CA54qWKASttXFRISRg1NE0kLh0/wD1ihNspQihkqvC+xgM1CXb qKuSK9y25hjAwAKQWR6mmoN7g3FFQszdSTTCma3ILKNojnrRBpamTLcjPSqULE+0Rix2TysN q1cGkOuC1bIEFqexx6VVutRD/KvHsKrRbGMpkUUEUP3iMipLlTGFYHK5w3tWc7sSTux7VHNe SGDyySQOgpNmd7jrshWGw9aouHQ5zTJJ2yM1bhBuI/mwD/WhbCuRhy4GRihgVoYbeKcT8vNM hyuRds1IeRTXBCihDkYNBIsD7ZcdjUcq4lP1qWJMzim3OBLTFc3BpksmhrcjkAbuPT1qKSH7 VoskbDPy1r6BrdrFo0tnO34eo9Kq6cElilUdOcUr810baRSZ4pdxGG5kjPVWIqqTzW54ngEG tTqBgE5rDas0UxM0lFJTJENXLBsPVSrFmcS0yWdto8hLrW5cr8oNc7pDYkT0rqXUPFkVLM2Y hXDmmtxzUsww5xTD8wqkA3rSkDqKbngihWpjAqCM96QcDNOApCMigQ0800KetPHA5px4X60A QFsGmd6kxnimMME0xMdH1OadwTUSnFPzxTENkHpTUYjGaeV4pjLimhEn3qDjFRBiOKeKAuOD ZXGKUEFcGmbSO9B4YUAKDg1KrdCaYFB5zRnGRSGTSkEDFMRvmxTQT0NOiXLikM6TS/8Aln9a 7dcKgAUKMcknmuK01cGMd812f2TMW6ST7wweeK4MXuj0cFsySDymiZkXgg8ehz1pWWZFUB9w HXPb3qpiWNPJSAusfzB8gZ/D8auNI4jIyrZGMkcetch2jcKjAS5yx446+1VZY5PPbyMp/eJ7 j2q1GzMrlsoP4Sw6H1pZWiY7mK55xknk0tgI2ZVEchG4jj2J9/elZ2LbthweeaSS0MZ8obSA wxgfeB55qOUyrGrRnbtbkcUDJj5Q8vAz1DZ7dutKxVSI2clAMDIzn6/pVdFnadXYqPlwR6+4 qfyEMDsxfcpI+pHt3pthYVpNse9QSCOfY0guPkAEj43YB9PWqsNwBvtpFYljkDH6j86eP3Gf lLFec/1NBNid5PMfYEDopGT6ZHpSSOPMAcsAWATcflNPhedY/OCLvKHHX17/AKU2VWk3YAJ+ 8M84NGnUEXLtkVkRcktwR7VCUQRgIFIIIJ9KUNIm1m2uV4wDyfoadI5RyBESGXOc8/T+tCuI I4VQsVJyfU9BUqyLEWAjD9OVPSoIVdlJ2lOvDHGPcVCH3JMC+9gcEAd6NQJXuM5VYzuK/KAK rxx5JYsUbowQYx71LHlyjMCB0x1p006w9GUjGDxk07gU54ZBI27ccHIB/unvmrGkHyUlaXDq eB0544pIpDJiRgDlAME9R2p6PHBIqkEbs/KB0PHU07iaJJVGVYxt1x83cetQSRukxdWx688E f5/lT573zVIZTnd8pPIb1H5GmRQSSq4JBUH923XIPY0gJXEc0W2VRuH5/hVeeJSFIlTJ5Qlc kjpU5fcDI8blScLgZ2/WqirLGjK8e6AglW/XkGnqMltoURBHnKt3Xp9ae8EVszKwYAng7ucc VBEyRxnEkjq2MEjof85qzcAhVDHnOc98+1F9REhjllQOvBbq6dGHvTUDI2xiSoxkNyQaSC4k WJgW+TODgc8+gpH1BEOApGDyx/kaBbE7ZfeAwCdOOnQVXZZTsIYsBxlSQPyqxktCyoAdxPLC o7STZ5yygbYzgvjgcDNJhcguEnLh1YOVxtA4qeeSQImNpcjlemBmoJAsuGgYSMCSpB46dPar ETHyd0gAJGAW649zQBXggSeTZLLnY2Qh/wDr1bmhj3BiVyOVHqapmCYyPPkCMj5lxgfQUi2s MuXeQruAIUnkU7gRzTDyWkI4QFHjGefx/wD1VHpUXmpI2TjOQG5x/nNXYYIYFZnUSMc4cHvS wywTAqu1SMY4x69DTbEJeyLs2BgDx2qGIKCCVAz12/TqaWZ2SQo4DI/Rs96ekZRmfZnOB1pA MmWcTKI3YgAjA/rUNoohUKSQ8YwSckYPYVatpRcyumNkifdB7ikvoGEZx8rEjB3Y/wA4oQhv M1szL8xQZQHpx2P5VLE/IVF+VlyD6fX3qKCUG3KsnlEZXdjP41Se4Mg2xsodeG5wCPUUAWLu 0V4zPIzswXGAcDmkzGYjHGPlUgg9vwp0BmR5JZpC6sPuEDH+HNV/KRjJKE2bfuqTwRQxE1ud 0siLGMAArIRjnvTkjlt7k52kSL8wP6VNaPBs3uSrD5So5HWlu2Z0ILhRk44zR6gMljjH7sAM 5OMY+79apwQokZyAUPU44BqabbErSEqTtxwcZ9Kr2ZlhBmOwpJ1Dfwj6UXCxK6KroyFQRgHB /lSyoiv85cMeflFIjxSBngBLlvm9h16fjQ0fmkNLIVbGOCaaJ6nKNcqDkYqB7xiflzTPLApB t5xXquxzKnJ7iGSVz6UFGJyTQJOelDMc0rmio9xdgHWglRTeSKcsTN0FLVmihFCb+OBSBsir KWcjfwmrCaax7GnytjvFGbtJp6xkjpWzFpR79KuppkagZxRyrqJ1Ec6tu5xwasJYu3OK3TFB F1IqGS8giyBin7qIdUoR6dzzVhbRVHNQTaqo+7+lUZtTdu9O5jKozXPlRjGRUEk8Y4FYb3zn +KoTcM38Rp3Zm5G79rReQaY+rELtU1lCYCI5Iziqply2e1J6i5maMl4XUktUCXA3gdqrsNw+ WiKFwwNCQrdya6ldGGOhHeq8bu5INdI+nJfWKvGAXWsr7KYmIZcMPWnyg5FVYizfN2qYHy1I B5oYFWNMBzmghsXO4c9aBnp1ppU9qep29adhXGscjFC9aUnJz2p6JucUAWI0CKXNUJ23SE1u tbqtoT7VzFxLslKik3qPlJll2sADXV6MpW3LHuK5OygaaQNiuvVha6eSf7tD0jctRPLvGm1t acr6VzBrX8QXQudVmYHIBwKxzWUdjRjTRSmkqiQqW2OJhUVPhOJRQSzrdLcgiuug+aIA9xXF 6a+3BrroLgG2HHQUpGTKM6bZmqIZzU13ICciq6yZpoEBHNIBignNJu7UxjwfypM4akyKQmmA p60meMUexpvtQADOeKGBIz3pAcN7UrNQIiAzTifSkz1pO1MQ+k9DSA0Hg00MVlFAHFL1FNJo ELn3oPamCnKKAHA4HWkDGmkmlzgUAODc1LCfnzVcNzVmEZHvmkxnTWUwbyyByK6yPUI2gySQ VwCD+nFcfpw2lAa6lNPWUZ8zGCG44yO1cGLS0PRwT0ZoBoxAJSvygZwR09elSNNHC0S4OXHy tTocIMbBgjb7EVUnjjjiwu5ow3Tsma5DuICsk1zLJLkxBwArHr9BV6WBLgJk7iRkfj3qikkg R+kib/mI7D29quh5/KXygsTDgbhu4/OlqBHdQCMRjOW3csT/AJ4/woEhjUoG3AckdTg0GyYt mWaWVxzknv34qOe3WELNI5xnPXn2H86YFkEOkZJy45Y98f41GQLra0q4KE7R0zSpJ5jOEAKE DOTyf89KkaUABY4ypAxjPPX1pXAiAVn24Cy9FYY/Sp0jBiyrqXUYIIyD1qleXaRkK0YRlxuO Pyoty5usq5VAnKg8E4/z+lMTLEdy4m2MpRfbO0D0zU4jCqCAG5zlSDxTGEcMbSlxj+Ig8ioc SljMrbAxAAIPShsVhyJLIgLY3hgfrVqUhEJKgYGOB0B4qBJWV12/M4zxUhlM0mDgKR+IpCsR R3JE7Ih3Y6f4UBIjceanGSN3GKIYRI8kUkfI6MD27VAsU6kdCoO3gcMfWmBJLG4SPawRA3Hp SwAkZmwznIDdselMcHZHGp3AkdT1q/F5TptBG9T+XFK9hlEui3ixLIuAMkEdD/TrTblriB0m S3DqzYY5yBU7wp9qBG3djBGKSWRUAhlUnfkHA4IpiFk8q6iiGMRg4O3qKhjjm2mOGUIRkhdu Vbj+fWi3he3kELttU5Ct/n8qcWWGUsp3tuyrDv6079AsWkSXzMSPs3D+Hp0omt1UBmZiNwxk 8E+tPm3bQQQ3cA/w8fyqBZ3uY/JHUdVI6UeYkLG8Srs4DgHKkdaRzllTywSR9DVdoEcB3mKF DyGOMimnhyYdzK5yCXJGPbPWgB92rm2l8tiWXAKfjnNLEuS7Sk7RwF9qYk4MgWTcMkgMDkEH 0qYQ7lJZzsXqScnp/nimJj5HjQIi8jAKEd6WNRFiIj73J3d+9VmgQzM6ltq5Ozn9KLLz5Jft c6NySI1zwF9KLASNcpbS7WVAjHOR34/SoP7UjlnEaoCp5OOntS3MMTLvUnzB1A5wapFl8wrH w+7HTGKGFjVbLQrCq4yc5J6ZNVrp5IR5YBfA+9VmMtIqM6gBF545zSytHbqGZhzgAsfWkgM2 1il8pHUlwB8y5I7d6sW8zo3MeDz1AqRY1jVmRghzhA/Q4qKFpftAjnRV3Zw2MAim/INCsssk l0xkAwp+UHp+VX3f7RlIz26HimO4+1CMKrrjG8Hpx/hTCjROi7ztDd+1DEVBaSx3SfOysOQx PRa0ruKS9iwHx2znuOR/n3qKVxGwBBY54PX/ACKigkY3Q+QhWHTdxSv1CxFZ3ayL5W3EoGCv c9sfpTA375gtvtwuSSMkNnuK0Z4IIg06RgnqxxzzULi3IWZGk3EY5BHHoadkK4m7GyM8bj1H Y9f8adGsMysHGD/Fk9aruyF03/IT0YnHHemtHIWLAq3ruXAb3+tAD5ZI4JRCoYR9AynJH+c1 ZklEcZbbuwc5P86jlWMTJgkhl4Cjjjrkf0ptyVI+VFI6qpONxoWoirdXPnyQxNGrQyDJbH3S c/4U6yeQSzI6DylxtZj29P8A69PDySK8auuc5bIPI9KW1lRZmSYl0Y7VYqevpTdhFe3kY3rB +TzgqeB/9b2phNwrMEbKgnGKvSRxwyvhiE6qQef/AK1OWPeN0KnYfU9aTetgt1OGJJpUiZjw DWzFpY4yKuxWcUY5xXr8qM3US2MCOwlc9DVyPSWbrWzvgi9OKgl1KKPoRS0JdRlePSlHUVYj s4k64qhNrHXafyqlJqbknHFO7Ic+7OjzbRr1FV5dQhj6Yrm5LyRurmqzXHPJNBDmdFJrQ52/ pVOXV5WBxx9ax3m9KiaZh1pWJ5mX5dSkJOX/ACqsbkueTn61WLbxQInIBp2F6slkdh3qBpDz VpEDLg0426nnFOxN0UPmanLG/pV7yFUZFKuOmKdieYriJiME8VIIBUzYxQCMc0BzMRUUY4qZ iNvGKhyKRpMCgm5q6RqX2O6XfzHnkV3WtaNpmq6KL2zdFnC5DKeG46N6GvKmmCnOav2OrzRD ykmYI3BAPFJybVkUvMZIMMVI5FRlcDIrRuIUe1Zx94DNYpndhgClcORku9QeTUUtwqNiq5jm kzgGn/2fJIAeaerKVPuN+2YqzDdF5FwDTk0d2jyAavWWmskgLCnyvqUopHQaZafb7fY3Bxiu e1DQWhvG6kZrrNNBt2BXio9WniQl5CuaV0gfkYNrbpbR5bHFY3ifxFHFamCJvmIxVTXvE6Rq 0ULZPTiuDubmS5lLuxJNZSk5lLTcjkcu5YnJNRmlJpM0xDaSlopiENOQ4cGm9qUcGgTOl05s Ac101rKBFt7GuRsH+Va3reRjjFDVzJk85wSM1CpxTpSd1MXkUISJgygZNN6tx0o28UoqrDBe TSkc0n3WpxOcUCExxTDQzY4pN1MBueaMimO2DRnIoAU9aM4pooZqAHZ5pTTOcUo5FMQ/IxTM 0mTml75pAAOOKcGppFKoG7mgBc9jTSae2N2BTelADlGcetTxgh1HvUCHDVPCcyCgZ02no2+L I5PrXY2wbaURjtA/XiuW0kNNLGxGQtdS9vFMqSQA4D5PO3H19RXn4t3aR6WCVotjlgJAdpDw cNk8+xphWSOJd25znBHpjv8A/rpsN47BZWRFQEqQTjFMjKi88tZJHjJP0HB/P9K5EdoqLI1o wjUxOfmJBwD9KsWymUKSzOpHQvjnofarActGwGMEFhkdaqI6QXHk4Yhzu3DJGeOKGBZRwsb5 BU9AWJx71FPGJtsJRig5BPqP/rZqUmOdjuVgc9AePY+1VJvMhlLJvltwMFdxJB+v4015CJkS N1JiBUK3K4Bz+NLIsd5ueRC23IZM8dalBDxIWTIH8JPb8O9RQsn2h4QQCedgH3fx96WwyK+4 hDEDcflG05yOw+lIscSou1W5wSR71aMamby1GQVwRjp6VVSRluDEUzxnBbnP9aTAiujskRXl xEOq4PB+vepft+2LDSIQePlGc/09KV4UZiHYiMY69vxqBLeB5XHmYQSdCOrY/wAKasDLsIBR ZAckndwQKZMjS3CiMEleWAbGRT0iWKAMsY8pyyja3fHP8x+dQSbbeZkZyqclX7H2p8rW5N09 iVLjBAYFJFypXGKdFGZHLKzKcdD6+tVgjTy741DEgDLVaZvKl2gHcFwDmk9AIpQJ5owCuFYn OehqSztxBcMjPkgHBHcdqY0btGXjQlwcEeo9ant8TKX5AHBOO/X/AD9Ke4dB0rAgxnkj+Fe/ saiZYUCsUAY/wsen/wBensyYwnJzklhzkH/61QzQ7E3qR5rckHp7f1o0FqF0PtPl8ncONq8k elLHEkcuASEHPXdjn/8AXTYXXbJglpgdvPHNRtPEse2V0RiCwx34oHsXWuVG5XK56A9jmqVv 5lteMrYYZ45zj/OalhQqHilxtKAkt0Y0TQKcs0x8zGVxjA/z/SmtrEsWaDzGZ1lA3g5VuRzS QxpgoFX5STwelMWYpDiWRCpG5mz0+lMdZESRcCR8YBPDc+lACukaTeaTlQw5H8HA4p8jncGB bypAdwP8/bvVW0uI/MXziBKSV2jp+I/rWlIgaQtEQVPVD0/A0MCley7vkRjlsd+VHf69qtiQ iMqz4yOHxxVRFXBcqx+Y5VMZUfjU6uioHA+VeB/KhiJPLWQMQ2JSMErxms65h2oMHcWbn1zV +1ZCu7btDHBpsiZuAQgKr05z7/zoTHcjsnccDBVscvwc980t7D50Xysflz8p4/So764kj2sU ZAOCOoP+Bpiq0sbOJBhgMHPJPvTEOjQCNbfLDnJz296kEaszQ7m2kd+/+eKht5njYyPh1i+U 46ge1TyXBnIMIG6MnIP8Xt+opANhj8piz5ynGP61FI/mTZhbcd3zH09ad529kZCAx+Uk0yO3 jRlf7kh5J7frQhMlRDKjYkJbGMj60gUAqz5U9CelK8sUY8tnIwx+6KWSRSpVSHIbJ55FGgFq G7imZ4trAkDkjg1BJBKZJELMEznAHbHFU45H3lthyH+VhzkVeuZWkjjlTJLDbtPOO/8AOhdh W1MqQ7FiZzueGTBI6MPWr1nN5iSkgfKTle9VodlxE0ToVYk59wO/+fSlmcwzI0QBVgA5/vAf /r/WhhYsbY3uSV5XaHBHTP8A+rH51Df3IHlBRtDE7SOR+QqVHeKYbEBicfOB6+opi/ZrgblU Misc4P3aL6hYeHeO3G0B2ZcMPU/402IiIrJICITyYyM7TU0Lo/zRqGBHBHFRyxRXNoQ6ZkX7 rBsUkr7iGyTRXF8rqMwkEEEYGf8AIpHuZVbGwcDp6VWS2EU0Qjd/vbiCcitl1UEYz05xTQjk 5tVCnANUpdUkbpWS1wX6GojMQCDXsHDzMvvfOx+Z6gknyc5JNUi5JzTwj5V9pKg800hEkkpW oGmYHpVy4AkjXb97OfoPSq/lButFhXQwSFiBUrwbuQTSrCo5qQscYz0p2FzlcQMKk8okVMp9 acTkcUWJ5mRLAuM1KMBSKaTjim5weaBXH9KTzCOMUxnA6momuEFFxWZZL5FGRtzms2a8x0qH 7W7Cp5ilBs1GlUDqKrtdhc81nM0rnvTltZn7HmjVmipPqWZL7jioPtjsOOlWIdIlkxkVqW/h 9lALLxT5GPlitznz5sh4Bq7Y283nKdpwDXSRaTGg5A/KrUVpHHzgCqUUhOSJFs/MtcjuOlZS 6W0cxBU7TW9FdQw4DuAKuT6vpAhG+RNwqVOMZXYrN7GXFpcQjycU821vGmePxrC1jxba2rEQ yqR6Kc1yl74wlkzszz71Eqt37pai+p6IdStYYyhZeKqSa9ZxDcWAryqfW7uVifMIzVKS6lf7 zsfxqLzY7I9RvPGtvbofLcZ9q43WPFt1fkqrFVPvXNFyepNNJpct9wv2HSSM7FiSTUZNKTTa skWkopKAEopfpSUEhS96SgUwNiwO5VFddpdusm0sa4/S27e9drpWAFbNMykNvY1SUgCqimtT UVVjuHWs0KS3yihMhD1PajHNN5B5ob1plgc0gOBRnn2pvc0xCNTfpUjYwKYBkcUARsO9IDg4 p5XNMI9aBAOtBGRQBwaQZoGKppw4pFGKWgBOxoGSKUDr7UoHOKBCYyaPSnAcZpMelAx+N3Sm sNrU9WwvvTW5FACDpmpoPmkUDnNRLyMAV0nhzSRNNulxjtmpnNRV2XCDm7I6LRLGRLIyDAYg Y3ccVo3UN0ypFHLgjnocEVGrKrJEDhGJXjtj19KkVLk3nmn5EIxjPPtXkTk5Suz2acVCNkPg s2MZDAFlAIwec96suixoDEqh2U7iT2NUI5Ly7DkII9pIJHXH9anZ5oI0+Xzi2cYIHH1qSxss lxBt2Bdu3g4zn/JzVmz3Xdpvk/1inaDjjGTU1qq3sgitiZGJ5wMc4/wxTFEkV2wA2RqxVh0w 2fTtT5Hbm6BzLbqPDkKMrmQDr64//VVQuxufmd1YAnKj5ce9MkuyrMwcHkKMnH0pbe9S98x7 XD+SSCjjkg9/p1/KkkDJHiMjxsjPvyWPPHTH9asQwrvk3nlwMj04xQHkaIuAiqFxn3/DtUIV hdM6uVjePJOAMenNG4XLcKxjfJko3RmJxz0qrNBFLdFzIN3QjHrwf60wRyTWqAyHzEbcx6hw Rx/P86dHdxsXIiOcgL3Lep/OjVANuYy4WJc7vVfSiCwjRtu/c5H5+9TWabUQtKSSM7WPzfjU kjRBydil0J56GgW423iWDcMAsc/eH8vyqlPH5r9QdpwVbjH+NT200ktwsM2PmTAPTB/pUVyH WDfBErvu2nB+6QOv400IdZy4nCxkYT5QMYP/ANepnjZnLI2JSc89OlU7YSSRkSBUOSWxz6f4 H86fLcpIUVZT5hYYKjt70XsMmU3E7LtLo3QjPykVYkmCQsiw4w3QntzToH8httwq4KZDjgH/ AApJBG0md2WLEcHtQSRB1UhSvCjJI7/54plxIsku87o1AAJb/PPWkKqYZXcjjlcHp7U6ORJA EwcpjeM5z9D7VKKfkK8IYhnK5Byccce9QyWoivNzhJI8DZjsP/1VbvHIdREdrMPTGT6Gs2OS 4+0JKylsEq4xn6AVRIt+D5qyKAyL8pU9Mc84/KpYG3TK3llGU/Njqc9P60SARgjedgYcE8Y/ zimSRushl3lTt2Djtn3+tNAyWXyDG8YhX3BXIOexHeq3lvIEcruKgDEecD3qxJO0lqPkaN2G 0kDIzUdtOzyvGFJdQCNv054ouLqV9sMZlcuBKuT83f3z61PAJbiyfySQVzj1P/6+tSMqIg/d cSevB+tEZZJx5KY/hJ6YobCxHDIwh2MoEknc/wB6pAHuIWiYfMQeCMc5/H/JqZoz54duFPOc dP8A69JDHFFK8ycsVPyk5J/H60rgUrjzrSHKgo5PY5wPWpLK4murZ9x37SPn9fqKkuZhLb+W Od/yqSDxVMxPBaPGkm5lOVwMZ4/XrT0sBeR/lO8YHp6ilJgeBI2QEbf4eorPE4gLqCVUH5j7 9On5UsU2JgyfMwP4c0aoQGZBcGKPPfcpPOc4NWmfJBRD5ir27/Wq7WuyUygb3J3HA454P0qd LkwoGYEr0z0waAYzz0CiSNMuxyRipI5PtALPhT3T0NQTsnmB41G4jIK+tLC++Ni6deoqWNeZ JchpyAAEJI2kDuKfFCpRWHysw+ZffvzUEVx+8WOXbtj7k4Jz0FWpZAvKbvm7e9MRFDiO6ZMZ R+Rj+X1qZnaH5WGUYkhh6Y5+nWqtwiyBZfuscE88n/PWrGQq7XypP3WzxnvxTEQAZjxGSGHt zg9v0qjZtLbuIJSWRT8shH+f8itFQYJdzEElcZPrn/8AXSzwKFcE7UY7mOc7T/kUXurCJ4Rt iyQM9AR61QityLppmAGODt4z9aSyn8x2bedoYKq8YwP8f6VbR0W8UOMKw2qevPpQgbsVppFt cbYwFJ+fjgD1xVVb6WZkDIQp4JHTJ7j2qS7L3E/lW+18HDZ5BPp7U9Hj8sRFNu8gY9celPS4 h0Nuse4pHtbbtLZ44qYm6cBoNpQj+Id6bkiLAYlgCpI6VDEbqCMKSG7ggdam7A4FYirHtTmQ EVJkk03nOD1r3DyuZiCJcVbEyCDYRzjGP61V6UE+9AXJCw24xTRye1RtIBTfPGcUg1ZN0oOB VWS6xUBuWPTNLmGoNl8uAOtMNwq96oBpZCRzUkVjcSn7pou2aKi+pK94O1QPdsTxmtG30KVx yK0rfw0DjcKOVsvkitzmt0sg4BpY7OeU/dNd1b+H4o+oFXF022h5IH41XKuoueC2OFTRpXxk Vdg8PnPINdPLLaw91FUJ9cs7ckl1/E0uaCF7R9CCLRI1HKircVhDH1ArBvvGlrGT5bg+wrAu vG0z58pD9TUOsuiE3JnoqtaW+CSoqC71+ygjPzLn3NeUXPiK/nz+9Kj2rNkupZSS8jMfc1Ln Ni9n3PRL7xnbxkiNtx/2awrnxpO+fKXH1NckWJpM1Or3ZSika9x4iv5yczED2qhLezyHLysf xqtSZo5UVexIXLdTmm5ppNFMVxc0hpCaSmIWkozSE0AFIaDQaAEzRmkpKBC0UnWgc0xDs0lF FAGlpjYeux0tz93NcPYNiau00o5K0WuZzNW4RhFluaz0Yxy7gK27sq9qoxhqxZBg5oRmhJGM hJxim84p6kY5ppKg8GqKE2jaTnmmEU52B70zcDRcYAcYOaToaXnPQ05Uc/wH8qAsNFRsOatr bTsw2RMfoKf/AGXeMeLeQ/hTHysokfLwaZ0Na6aDqT4AtZD/AMBqT/hFdVfpaSflQPkl2MbG RxSjtXSp4G1loTILc7QQp9s9OKsw/D7V5OsYX6mjoHs5HJggZp0gBAKjBrsx8ONRCjeVGRke 9aNn8MppGTz5flOQcetJtFKlLqedgAD5u9AX0r2q1+GekxxfvS7tmnzfDbSJIgYwyuMcjuKL qwci7niW054FWrTS7u9lCQxMcnGcV7bb+ANDtwpaLcx/vHg1u2ul6baR4t4Ik4AyAKXMh8sU ebaF8PfLtpLi/wCqqSF98ZqK0s2SdmDbETAK57/SvTbxwLS5AAGIzx6VwDQsUWMZbocZ5x1z 71yYqV0jswqV2WEghVvMZQHIyAD14qqZme52CYFycICM/gKWWVft0ab+ApHB5HpkelVCga5G 95Izy6sp+ZjkdMciuH1O00rdk8l0hyTyTkdD71JNFJ5AIK8ZIA6e9RPJFBs8iISyyDJBPzEA 9ffv+VKrtvZnRkAGcKOP0oYFVtQubNo7y0do3ikTfsAYsnQ8fTIrQku4b7U3mRJFd0GGYYJP uDVS2UWruV+cyckngkdcU5JIzK8SxfKxOwnqeM1Sm1HlRLppz5hBYmK6jAbe0h+6w6H+VNsr KHTb92juMg8SIfTqOPzqaDAAYurz7cru7ii4nKTxrt2mXksccEUr7lWuWI2MjOEfp2P9fzqZ YnlVYzww5OOhAqDdsAlKgEja5AIzjvUlvPtOdpEeeWPAAIP/ANapGMN2I7sqT+9IIJxnP0Pp /KnSvIkWIgN7EYIGR7/1qrJ5aGSNJEBXHlsepqS3VmBBJQD72eM0XES+fG2FcFZDwHA+91/L NSlNiHaoLMCVJPf3qLa0rlFAQyE4J5HHeljhaJHcybzvyuTwB0qgZWQOHAmj23BIJbtipY4p JIWYMyuH4Ax83vjHpQ1x5UzI+dxB5HbpVSObeW8xjG6Dpnr70WAtsyJtWYFZCSQV4OPenSmN Lf5IljkPUADPWoWlzaEmPc7DII5GKdc7ktxMQ5Yr1HbHbnpR00F6k0kpkjUnClejY/kKiYfu lwuSf4jwcn2+lLbyR3AMe4CQqDx/nrSTRF2G05jONwJ5UjvUxBoZHBmJURycelPKxxqGXAK8 Mc8rTkBSLyoHHmdyeajCQJliPmY8sRnpTEOMyyoGc7QvPHTpVdr5LdTu3Nuxtxycev0q3sRS AGDFhnGOCP8AJqpHaCSGJnHVF2kHkjGMGgCWVlZwxwMYKuRxnNJO8izB3jDR9AAx+8fb/PSn tHDCEUXDDHzYY54/wqURqsieccgHcrZ4yen/ANamGhWuGEBiQvnJy3QgD1xUMSH7T5oZsZwV B4K+tXRF56mXAIxwPUEc0qwxqgwcbVJIPc+xpARushOxPmT+6eOKRWC7VLjjPXr16UjuYjPK 77mK4UA8g/5/lUotI1ihCor9AWznHtTEys89xJthG0EHJycZFOgUJK7uWdwCSvTDeo+uDVeY y2l/IFQFG6d9v+eKsJI7S7wgYsoBH+H+e1D0AsLsmgCbvmJ5yOlRbUaBYmBUdgP4vxqW0hV5 GmZTkZG3P4ZxVRbjfO4xnbuyD149PWjXqIrtAssu37Vl2OApHOemf0/WktQpLHzRvLEOMY/l 7/zq0QjAPGo3MS3P9arRxMJDI5Dy5yyAYOKbYWLkchiIZ8MmeT0zUYnjuS8TldoyDkdPxpbp RtOJiqeuM/lVUeTBB82fMByFI+8vrSQmTOyQLtiO7Gec9KiictCqncrE9G7/AJfzqWOFhvl8 vLgYZfbnjNK1q0YE0OcdfLJzRuBVltnkmPmY2nHPr/nmrfkHb8wYY+5/k0jhXkWRwRgYKjkD 61Ixa4Q4wzqMAg9D9Kd7gR2zPJO5JJjyAg7D3p0zr5yoecH5gP8ACoIBNGjRldrLl/qadBJH Ndi4QRgFQevO7vmj1EyW4lYx4KktjI498DmhlW4gJGQxypJPbHpTZczKo3ANuIDY4qJYrlQ6 ShWY9GBxxSbAsQ23kWmzI4PbuP8AOaZBEsE5lUbznIyc4+lIZfKjjhnbO48MBz+NOSSFH3Io L7uMdKAHnaXMluoSQn5gw70yORbmWMSxHAzkMMEEUCe58394hMLN36qfaluPuiUxszHJ4XnO OtMljZ0je6RVJ9cA9afc3kdtL5a5UYBwFqpHPIIcvG4ZBwzDr6/0qSC3iuIhJLwx7HPAp31E cOqtnhSaa+Q3zDFWHv4oz8oycdhVSZ5bl8pGR9a9ptdDzY0pMjeUKetV2nJPFXE0u4lPOcVo WvhxnILA0rNmypxjuYL72xgGnR2k7nIU812cegIgG4CrcWnwRjkCjlHzQRyMOjyy43DFaMHh zuVzXTK9rB1Kiql1rtlbqfnXj3ovGJLrPoitb6HDGQWUVopYW0Y6CuVvvG1tDkI4J9q5678c zyEiIHHqTU+2XQT52ekvNbQdWUVRn8QWdsDmRfzrym58R39wSTKV+lZst3LKcvIxPuahzkxc vc9OvPHdvECEbJ/2a5298c3EuRGD+JrjS5Pem5qbN7saikbFxr9/c5/ekD2rNkuZZD87sT7m ocmm5osih7H3zTc0maQGmIUnnrSUo5NN6UALRuyBmk64pKYhetJRRQAUZxSUUAFB4NJmkzQI U0maO1IOaACkNHWjHNACUYyaXFLtoCw2lAzS7aWgdhMcUUvekNAE1q4SUE12Ol3KIUZjxXD9 66LSZBLbjcfunFDbtoQ4p7npcVnJqcKCBOMdaVfBd1I3zNgZq94HuxJbmInOw8V2+TuIH1rH 2rOiOHgkefJ4Hl3YeTg1O3gNAc+Ya7diNw9qRyMGn7WRXsYnGS+CLeOMNuOelWdL8IWLyDzV yveumuRm3JHYio9LcLdKGzt3DOPTNNVJCdOKJP8AhDdIilAFupGAefpV+38NaWsWPskY9yor TkwNjAjJQEYPtj+lJuJLBcjIBHNKUncFqhkGjaehBECA4HG0cGrbWdoHXbFGpGOQKaflJcZG RzUbl1Vye3PP4U+cmzb3LElvCjRgou0sRjHqP/1Ujwxkn92uc+n40kjHYshwdrdO5pWIwzcY BHT6YqmyFclSMBSi4zjHTrjFNYbclR05H5f40ecBMjFuAWyTWfe6zYWEhFxMqgZB59M//Woc klqJRbZdkO0A5HSmhwigMeOT1/CuF1f4jWMCMtuTI/YjoOlcLqvxB1O8yscnlJnjb1rLmlJ+ 6jS0UveZ7RdeIdP0+KZ5rhAVOcE/yrjdV+KltaZW0TzTjAzwBXj1xqlzdOWlldie5OarFy55 NWqc38T+4zdSC+FfedjqvxG1i/kys7RAdNvFZ8HjfW4X3fbJG+bJya5zGDTkXcapYeHVEfWJ 9Gek6Z8Qrpomju13q67SRW59t0yQRNb3C+YYg3B+6fSvKYyVAA6VOspBHJGOhpSoJqyNYYhp 3Z6VLHJc6g84GUWMDjqfUj8TUtvD5M7LL8y/eUkfd9RnFclo+vyW7rHcMWiPqeldcXhkgWZL lthBYjOcj+lcFWk4M9ClVjUWg2aOJkZrcEseBjOGx/n9KmW0ZrVFllc8AH12/Xv0pLeePcVT O3sFHfPWrJUOjr1A4zmsbmxG9si223zC+wZC9Mgc1G25lUkBNhwgPIOPftTTIsqLtBCrkhs9 OlJIJhbN5km5OgB70DLcar5WWhGFwQw4PTrUF9Ek3leadwDAjnHrz7dalswyQCM8nPHPJGP/ AK1QSb5LjY8ZBAwMik3YErliOKaAxqkwkiOcDqPbP+frUzMnkkyoqE/KQxzkVChZJGiyAOfl PJBqaJUngB3Bhu5Ldj+NJPUGim8bZKojAZ44H1qeZy8W0xFgyYdfXPpTpYZCQFlKuGOcenbH tUYiaV2TeCCRz/FkfpTsLoETOscIlI8xvlK5x0P9RSeexMka9VO0LgHv19qWWZY7iJHKtuJ7 DsR/jUczyGcuhABOMKBzz6fXFO1gHSI7QRmTAlkJXI7cf/Wqmod2fezFkwAy9D6j6dKv72a1 jI6rznrjBqNLQreGcLkMOWU5+uR/hRzBYUqPlkXClvmbJx+FJJKJV8pJyBnGByG/HtUF/FDK VQu0isMBVAz+VP0ZUFqu5AChYAH1B60/MRPDbKjZKquCSpXjj0NRNEt/EqrJ+8DliG79e1XJ AXhO8/I2e2MD+h5qqZfKKybQpVgM47DB5psWpKLdY3QFtzMmMEduuDUUlq4y29toOVBHI6f1 qyx3CN4m3q/UnqCKrySoJQ4ckIMjn7xzikC1I7cSRxSvvKkg4Y9FPsKvwvGxLK2AePlAGT68 evWooVNzuEib1cBlwP0z9c1nzq00ghLGMg4AP8vrR0CxchUyOBPGPOQnBXjjP+FPY+WCH27N wHA5FVgZ47ncpOFXBHvQ832mNhcIUXoSTtwaNRD4b3ZIIMLKCDt9VNXtvyo7gIOSOvJ6c1k2 cQkuA8a71BO3j1HIq5fpcE5Vty7eUB59uexpisNvTtYRx7XdeSM9D2qvb3F0sayJ8wYkbc4/ OpGnt1kQyIUd1wrHv9f0qSQQwRq5lIAbbxyAT60XQxq7pXbzFIlQAAg9R6+9SRKBHxwM/KfS ntCw8p9x+VcHnqf8/wBKpJOd2GLLzz3H5UmIlSclmWQYLc7wODUyBGhyyhsNw/YVnS3bKV28 7uCQDx+FWFuwflBAVslSPuk0ASRx7JHUcZO44Pc+ntUF27JdxRjb8xwzZOKhEM95cpIGZI4h 8jL1PrUl/PFaSxwXBeSTqWxnac4p2ETXm5YkZVEkZGOe4J7flmoBzOXPLonyov8AEP8AJq1w LXy1QARkbBnnryMfjUCxb7hLreylMnGTxnrSAkhuHMZYxhfnKBSKthttvIzqQueg6/nUDkSj kZCnofWmXTSWokGC8ZAcDOfrTQmJbxGUsxXcQOmME1FHIdoVMA5PDdcU2O7uBPG8UQZX4bnP 4/596nlgdmaZApKkkqcYBoSBhJC1zEyI5Rc5DDg+1VIEji1Ixj5XKfMo7+v61bjZpIRIXMTn nbwSv+NV7xGV4roj5lzuKjrR00EXLjdbQTMqbuPlQd6r2l95wYyrswOQeQPaqLapcuxVUJQA Ett6f5/rTlJEkTDKibOcD7p+lFhj/MN1f7wwMGNu30Iq99mjZfMhAVnGMjmoWWMR5VcYO444 JPb+n5U62Yx7gqk85BIxtPemSzPW8mt7lopndlzgBh054b8q17SUzRktCV24zn+ntVGeQSEC Ni8hcAHGQeentn1+lXzL5axqF4K/NkcZzjFD8hMhljiilDIjAudxwcBjn+dQXBfzBtDAY7Lm ppFEwyTyDt68UIiQRqqsSCM53U9wZgR6CoAJAq9FpkEX3sVh3vjW1hBCsM+xzXN3njmWQkRA 17DqLoebzTkejs9pbjkqMVXm16ytlzvXj3ryW58R31x/y1Kj2rNlvJ5SS8rH8alzk9h8l92e oX/jm2jyEYE+1c3d+OZnJEQP41xhcnvTSajV7spRSNy48T38+f3m0H0rMmvZ5+ZJGP1NVc0m aVkUPLZPJppPNJmkJpiFzxjmkzSE0UALnikzRmkoAWko70nemAUUUdKQhaQ9aM0E57UwDNJS UZoAWkpM80UAB4oOcUmaKACij6dKKAExRS9qO/NABj0oxk0Z9KB1FAC4waXFITzRkUDFOMU0 mlyaaaAuHNJSUpoJDNaujS4maInhhWVViyk8q7jftupiex6l4Gvmh1Y27HhhivVycOje2K8Z 01Ta39tex9MjOPSvYfMDWqyDoQDXPUVpHTQlzRH4/ec01+QeaUEM2R6Uj4Kn8azNWRyH/R5P oDVayfbLkjlWGOKsNjyn+hqlbuVnFUiWdeH+SM8d+/uT/WlVhvBPc84qqQXtoiGB255/Klju EhJ82RRznGcHFOT1JUdC7nAA4446fhSOSYxnryK5+98WafYqQX3MM8fjXFa38Rp2JS1G1exN F2/hQnZbs9Pnv7dbaRXlVSo3Dn0H+H8q5vUvHemWYYLIZCR0U+9eP33iK/vWLSTuc+9ZD3Ej n5mJq/ZTluzJ1Yr4Ueg6t8Sbu4bba/uueo61x1/rl5fzGSeZ3Y+prNznmmnnrWsaUUYyqykP aVm5zTC+4HPWkwMU08GtEjO45RSleeKaOKduoENLHNWbYZ5qFFLMK01gHkjAwadxJajcYOc0 hPy0EEdaQ9KCyaNyFBrq/D14HH2eXDIwwA3SuTiwY609JlKz+9ZVI3VjSnNxd0egWYRGZ3j2 yZK5Bzxxj+tam+KNSegI+tZmmkz27BwPmGM55qzJDgqp2kKCDx3rx56No9uHvJMimUM5lj2R ZT06kjuKkly0EO/DocE/UCkkhOIolk2AMSWz146fyNNilSBfJXfknoR09QKXQY+8LLbOycOI wMAdM9f0qNZTJaIGRmdlypYdOeQf896ezyiSNVG2DBaQHr2AH9fwqtIrvcfupZEJ+6AOMD17 UPQFqWYBIYH35aYttdj2HqPwxUyRiCF0Dbi5zn07f0pUiKjCON7nP1P0p806RWv74IcnqOua LBcryzbIoyDvfAOBg7vUVG7yoqzqm2MLl/UccfSqyO8TyMI/mL/dJ46DvVi3IeWVSxaM4KjP QHsfwo1CxOywySxsQr7wQM/w9P19qWcJDNG8mRHsK7uoFRRZwiGQMMttYj0Pc1SvNRkLtAIl dd3zA546Yx7VSd2TY1I4DACvDKGbp3Uk8frT/KVyGjkZVHqcYqrprSordEjzuAbnA/zmrM09 qzptBG84OOcf56UnqCGSiJ7x2UZYY/yKSQBCvBKAcADODjrRcLsiZo3ByOox1H+RVaO6y8Uc qSLvAI2jgZ/+vSWo7F6MGdS8nT8s+nSoo5VeQI75IBCn0H9DxT1XAJ37QxA4pnlwsyknHlk5 DdDnPf8AGqEEsgaIrFkJ2Prx1/PFVZIGxHC4Llx8zJxjHtVhrm3ikRWYfMQAp6Y/xqUSMJGG FGeF9aQiJZpLIRwjmM5G8jJHsaZeGNX818FlbGR64PJ96gumnlY4fCZGCtKltOQcODG/LcHr TET2YjaFhO+dxOC5zxRcoZYTGrKigjKt/EKrvbG3w6Pn2YZ4qQBmjQnONvIP9KFdAMYSQgIv CZHz9/erqyCbcdwwTtOOo4qq2ZbpU4aI/e56daayrueEsQUGVOevHH86LAPjLb8TICv0zn6V IZNsYbySV5BTIGMVCoklO4/dYc4/h/zzUzoUt1JVfMTjcBz+GOo5oAnyhV2BJ77cdfUYqAJE r7wB8wGeM9O+fXFQyoiRRJI5VFI/i5z/AJ/lUks+JmZHXeCDt7H3/HpQFiE2ySKyRMQzEg8d aXYEi8oxMyAfMGPJ/KrpRV+aNWVgxOO49v51WLEtId28A9VH3fT/AD9KLiJWRVgEkeVQdMdq qNbx3Mv2jcGZSAw3A8D+XrSys86JCsuFHLtjAOf/AK9MtoUtDLGAXJGRlupoQMsOYmkU+btb B6LyMd6gEyKW3NwScEjpz0NN85LmQZQB1z5ZwQSPTim3F3Gse1EXdxvBHPbkfjTTJZC0UhVk VySMHhutWJpd8CebIqpuxknB7d6IJGaJmAbeVyoYcH/GnrElygLxqsjLyPXnp+lC3G9SO2st qy/vmMTKQuOx9AaiR5ZolLBl5O8KevXp+n601IzaszbWERztVO7fSrEayx/M4Xy2YA47E9j/ AI0ybCRNGsccQRXkXoHGSwp6XUU7PEOQowVPvVLUlMV1a+Uh3AE4X2/nT45VBaV4iHzwAOTi hoLkptxYxfaGDHthe3/1qrNbzl/n+ZAwkQjjt09quR363BSNgo659c+n0ps2bVAhb733QMnA 7ChMCSO1S4XzWLIMfdzjHcfrSiQIWG7PQ9ealmVIYI1L9U5J6GqxkhiLOAFZR1PBo6CGmCaW 5LwqUOejHHHrjvVq8hdfJC43EAEe9QtcR4XGcnOwjsc1IWlJE0mAF+XPY0XuIdIki5KOqqR0 x1NNfy5SGXpgDHp7Uj+XJG0IYqrcj2+v41jTmSzlaF9shHO7mqXkI8UZiTyaaaDSGvTOEM0f WkpOaBik0lGeKT3oAM0UdKKAA0lFFIApKM0maYhaSjNJmgBc0ZpuaO/NAC5ozSUh4+lAC5pO 1KD1FJQAZo60CjtQAlFLzijJ29aAA4z6UnSlpKACgUtB5NACHP0o9qXigDJAyBQAlB60u0k4 HNJQAUHg8+lHJ6UmfWgAyfWkNL24FIefrQIKSl60lMApynBBpMiikB6Do135+lKM8ivXtFl+ 1aFbtnOY8fjXgPh+8KK8ecV6r4X8TWtnpYt7mTDKx2/Q1lVXU0oNJtHbR4+X8qc33PwrBHii 2z+75GeCap3HimJQQXA9s1kk2buSR0SyqEIOKy2uooH3u6gY9a5O/wDFTqn7vv3rmrrWLi6c 5kOPStY05GMq0eh6PdeNVtofJiIJByDXLX3im7u2P7wgfWuZWZmJySacoOSa0VGO7MnWk9EX pLv7R99jn1rPuIzuz1FS4yc0jnj1FaJWMm77lApg010xVpkDdKj29qZJXXpSY5qZo8HikKYw aBEWDimn+VTYphSmBECadQVpyISwFAFyzj/iIq5vAOO1QRfIm2lzzxSGOYdaYvDe1SAjHNMw QfamA5Ttc+lW7FttwvNUxyalt32y5qWNHoel3Pl2vmFsrGcsnqMc/wCfatOB5GV/M++ecE5w SOcfnWFoTo6sHUOCucHvWhdLMt4rqmwFVyg+6OOnFeTiI2mezhZJ00XZ5xBbu5JORkbRzn1q vb2/nul1cOxBU4CDgf4UsF4znyJoAinhWPIz7+g/Cr0LhlyqjYGA+XtWRvoMkwqeUzHLHcD7 /wCc05YmVVVMmQnce9S3BildvKKmZF+VSwzx6io0m3RkpkPgk49cVPUOhA886vHKfniLssiB fu9uPyomkVncjGQy4ANWEUM4dZY9mc8E8nk59qjljZR8jjevbHSq6hoItukYMocMH6qTgDt0 /OnM8aylRwWwMYPH1qleO8cQmjOxl+9GDkHnJH0IqcXCQ2gki2lWXMeOw96Lah0JGC28bruL hGIVNvPXpn8aqxLObpXbaocAoCnbGT9DU0BAQMy+YmR94dD61MZ1MwXHyqCS2DwadySwpjEQ Mg+v1qCKQb1bAXHqajknQFMMQ0o+XvkYNLHGfkRgSOMkfrSAfdQu6/uAqlsYOPvE9aY6hLeM vIA4Oee49/0qXcsIMZ+ZegYHkE1We1FwrrI29T908cUANjvoQ0kIJZyN2W+6PXn9ajfy76HC SEFTnI7H3pTDEsjRyIAVRl3jtkY/rT7K3a3UQuxO7G0kDJx2oHaxAkDSOGeJvkPU+vrVtpM3 KKEZuBgj09KQ74pwqzZXPzAnkDP9KnR0d4yvRFbcwPek9NhbhJamaMr5wwfXg1VuCILMgTMk g5z9PWnXIaeBXjYB+xHt71HEpW5SXAlPKspPy8+tUTckhlZkDStv3qG3YwOaVopBgeYN/wDd PSnG7tokEJQI/RVC8VRvPMkfcrEMOVC+tAbkllC6tIXAD9FOfxp9+s0kgZNih1KkOpwTj26d OtNspJrljHLGqtGfmIPWrbweZCyhiAO5NAGPY/aNjhZGEagDaxyK3Y5S6AvHjA5x0+tZ4VbS IB3Yk53ZGcj3NWoW3rG2GAXsfSh9wZFNburGRBgnDFSOtVbzTnkkS5+0MJFHI7kdRW0XWYKF OXxyR61Ru5PIQtKuW4UADJ9KaBMmSYyWySK+S4HPXoKYJkTITBIOHBIHJ+tVIpI1Y5cAOD97 g44/WluFit383ZkSYUgj070kIsCdW4zgjjJxx+IqjcNP984IiG7av3v/AK4rQi8qW2yEWRG6 7h19qrzSRiI+VGHZPu5zxntTWu4Mq2qTSS+b5bqFHyI2M9f51E0Vs6ATKYyCd23vjsR/ntWg JnaBUQAT4+Ze9VkUo3yriVWy7OM5H9f/AK1ICRfJidZdrIxIKDnLHHoKJka7jByFkzxtXHB7 06aBppvkO4ow2yKMhQQP/r8U22mfyXJKuU5BUdV9adydyy6u77iozHzj1PeoDKjzYYjdkBh2 /AUyC6e5ljAOE3YYjsPf8ajniiF6Js4kXKqSMjJ9T60gsSS2W9vP3ggNkA9hikWdovs7MhZe cnPKkHofbk8e1SOxdURkYDPIYdalwAQnQHng807isVlVhLK/yJHId0eeKZqClIIpdxkkDDcF 6EZ6H0q9LAs8m+QHC/dwewFVGCsZiD85XseDyKd3uDIpWJt/OVxKp5KdGT1BHpnv0qaJY3id 2x5bgbTjp9abE8RkliCKm75iFPWrELwnMbZIXjihvsJLuVra1EUe2RsknIJ7H1+lXNpliPmy hQDnaOTn0oby5GBjb7vp6VU86NnbBUyg4L9P50vNgNInS/XdGmwliWPoe38qsrbwTZeRCW6f dB/nUgP2i1DON5HAIHJIOP6VFLLIj4VBjHsP5mqT7Es+e+9JQelIa9Q4QopuaN1AgxSUbqQm gYpNJuptJmgB26jdTfeigBaSlx6UYoASjFLijtwaAE7dKKKUdD60AJxQRnvRR9aQB2o7UHg0 djQAUZ4xijFH1oAKKU0negBOcUEU72xSUAJ1NA65pSpHXNJnpimAUCkpfrxQAdOlJ1PSj8aP pQAmccUpGKQjvRj8aBCcUd6KDxQAEDOAeKQ0ueaTimAUdOtJ0o4oEWbSZopQQcV1NjJ5igse a48ZWuh0ufIXng0WJkdGtw4i2hjWXPLIJMlj1q8oz0qrdxd8URRldjWZ5YhySBTE5Oe9RrKy /KMYqdAM5FWNMeoxUygkZzU1vZSXCb0BIzip206SGIyt0BxRYZXypUYGD0NBXimhsZpWpDGM oB4ppUU/OeKaRQIZtBHvUeMHBqboaR13DjrTAgMfPFMZTzVgAmkKc4NMkqhDnNWYYwOcUCPn FSL8vFAxexpFJ60pHemBsHFICQnuKPvdaaGGMUZIoAeRhc96ap2yUoYEHFMducUhna+HbkRy xOTx0rrJlVndkIA4JA6t6H8K8/0SXCr7Gu8ilEgQhslsDp0PrXnYtNNM9PAyumh0igsu1VVX H3W4Dfh/Skt/LsGlCOUaRssjksPoB2FNu7yGePhhncMH3qDUb21gjNxcA/LjLdyfSuVa6HYX vNWXZKHRmJJ4Xkj0/DpTDGshb5cgNyo6j3HrUNk9rPaLcWbg78fN1wD1B9OlTWzsWZmIRskd M/kKTKQ2GMwgsG3qvG0dQPX+VIzxR7ZjuXLAYB+7njOKkhe3R5CJAT1Axzj0/wA+tUhcLHdl FVmR3GR6D68801qSzT2QPbP5vKYzj6VBBFDHaSR2q70ADKobr3I5olaPeq5zu+Ukn8f1xUqm OLDR5OegHY0AhXK29qGBC8DaCOvqKUrC8qRllw3Gw4w340qkSvsdRwOp+lU5oJI1YqTlfu7F 3ZHtST7Ay2Vt1UiJdsqjtgkf/Xqh5xkORbySSZ6nsQeuRU0gW1X985ZgpG4cEn1x60W08rAh nEqM3LDgkfT8DRYLjPN8ve00gAUHam7P5mo/OmRIHmbO4g+Wq4XkZpZFzMRjcobcflHHHAz6 c06T54mjyhjYYAIyQTQAvmSyXTxNFtYt1xkHirMcheQuRtAHHHH1psVufJ2eYGXoCD8wpqAR sYVB2qT1PftmmJjZQoQyxojKTktkZzTxJHGq5IJbBx1I9ahCKvzMm1FYnK5GB6Y7/wA6ktck mWUg4Y+W4H3hQxEjIEVmi2B29+1VJ7N5bSRmUCQp1U4ouYHkZ2TG4D7hPGPb3qC0vWUNC7MD 1+fqPWn5gTRWqu26UtnaM896tDylyGJAHQnpUAnUiRQSML9xh0AwOPzFDv5pEZXcwOdoPT3/ AJULUGOaOTzcKGUEZBzk0qAyROqEq4BZSTzjt+FWlSFoVYnkDHXkjj9c1nv5skrosgzGfvDh qV0BIHkjmAkXeki87v4T7VLJ+7jyHHGAOOKgZJpMBiMoDkdm/wA8U6KM2xbaS8ZA+RgT9eaL AS3DsgR0UKFA3EdcelQyXibnQOsjqeW7qevI/SrMOY7TLvubqSRz/nFU5J7eMJ5UeGJ2sCOc etNCIpHBmQOhEa/xHnFWLsNKI3iXzAVIbPT2zn0p8yRKv32SQnAI55NQDzkuFibjd91lXGR/ n+VFwI7GLajLvZSDtMefunvj2/xqwES1cj523Nuyx4JqrKsy3uV3lMZZgvftj/69SpepJvML 5wOWYHH+SeKOohdQmAaOWFlZ+AMDgd6bDmRJCXLKTjDjpVaKFn+cr8jgnAPQ5qxLbgLujJdi fmx7UMQ17ULMqpIyc54PX8asW8JgZ0dg2eg29ffNFvOxLLNtC7QRkY4/xGMflVqWPfGSp2OB kY5x+HfvTVmBXCJF2yGI9uAP/rD8hVeQCKVo48FepXA/z1qbdJMECoFkXBYnovbP0PaoUjAu SgzhOmf4uMH+tLoIVLllOxoVK5wSh6fhQJjLJgkKeNrDqfeh2WMyK0QLMeCAOfTOap3Lfu96 lgudxIGWHt+eadhGja3Mk8jRoUwByWPbsR+tRywFZeHILkOcj+79PXIP50+0VXO7y9jqSFIG Mg/05p8byNcEOvrsP86EAwQxT3JDkZXnaeOOSP8AGnInktINvzDIBzncPXNVpQIkbBIPQZ5x nnj9aUssBjlaVvmGD1ouBXvZjlgsKohQ5JY854I4qTTjDHGQyl8gkAncR7ZpHnga4dVj5QdS M9eQamt32hfMjAYZ5A4/L6Zo9QbVtBsc9xHKknlNs3YKk9PerghDD5xnBwCqZGPzqK2u4Z7c +YTkt0b+lJIu0jCSOCMja3T2qk7kNHz0Tg4pN3FNNGK9Q4QPSk7UtGKAsIOvagnOM0pFJQFg wMH1ptOOPSkOOlAB2zR2oooGA4FH4UHrxS44zmgBKFGTgUc0d6BB39KMZperDccjvTtmQ7K3 yr0zwTQAzvQRS0nTvSACeKOlKaTFABQSTjPaijimAnejp1FFFIANFHtSdaAFPIyTRnAwKKT6 UwA9KMe9BopAB/WkPPQUp6dKKYCZ5o6DPOaPoKOn40AHB68U3PalwfwpMYGaBCUGlNAGARjO f0oATnFJS+tJntTEKD61p6ZLhse9ZYz1q1YvtnFAnsdtaneg55pblMofWq9k5KAirr/OOlLq YMyI4g0uDwKueQsa5DZqAjbPntmrJt2kXchJ9q0Gi5a3strERG42tyRUraijghlJB5NUo7SY r904oMLL1FKxdy2r2cqkbSrHpVR8BtuajCHdT9gxyeaAuM6HNLkfjSEY700HNAhxGRSA0pOK bkAmmAHqD0p/ysM1HntQDigB2aQ+vegnmhjwCKBBupsgyc09F357U1uKAGKexpxODSAfP7Gl kGGx6UAJ3NMY8jPFOOduRTPvDNAza0eX5iM13+nyl7FGR8AfLIOnH1rzXS323CjPB4rv9HZZ bV42fbzn2PHeuTFRvA68HK1Sxbit4sSu8kjSdGUjjr1H4fzrH8SQXN9pUYhT50YeagOc4GMg 1qBGvUYxuwfgkMMZzVmKNbeJ0dC2R355+npXnQlyyuerKKlHc57wTLLBFcrKdsfHX1rsYyXi JXIz0H9TWNJpKSWcSxL5YYhpNo61ofaOViSTYMYJ9+9VOXM7kxjyqwKYZJ8OSJh054Ix60jS RGXzEB27cFSMZ/zzVZ4JykaRR4kQna54IHXinRTOqGOaTzHOd/TIHT+lSUMMP2shmLEK3Jz/ AJ5qzEDbDbuLncSUHue1RJJIGKhQq4xkckH6UxoXZy0yoydj0I9s/WktQZM0kUOZGlcEHf06 A/zp8NyJpS+4rnHQ5HtVSSz84oXZvlQkx45HYc/lVYRSm3mmlO08tuQ+nT8KaSE2zSvpwqKr gyLyAQv3SOcmo45o4UDgFCXznPAGelRSSSGKOQk555xjtTGlieQxvkQPjjHfHUf7PFG60EaM ZjYsxZt2cBj/ABdqjMDRsQ+5o/QdvcVU+0O4Ck70kPBQ9BTbmSa3kgheTczZIY9WP0+lCAnZ VW5AjJQ7eVyeR/SrrbJ0CyRlXxyV4yKqNE7tDI8iopTkP0HvmnRzhgzRzb13Ywg/T6UeYaDo g6KiqcoCd3Oe5qV1QEMDjGdw7Dg//WquyGCRZYwHV/8AWYHIp8qtFHuQO0fBK5ByM57+1Ta2 4/QitZ43eTznMeDtDMcgHr/UfnTruygmO7JUtkEjv3/KppbaJo3JTajtvDMOfx/T8qp4u1Rf LwYyMLtOQ3Pr+P6Vey0J3Zahit/PHzEuoKnOT1x/hUZidXk2g4yD9f8AOarQM0d6xZ9qOMjJ xitB1jBVRMys44J6470lqGxCFMqKyAZByPQ0qyJDFKfLCzBclc5z9D+VPRcuBHLx1KjuPSq5 jMcixs3QEKTyfof0/CloA3T7nzkYk4HB5HQmrbMz+ZCNoGPxPvVWzSMxxrGPLVQA1OCKL3Ku A3HTp/nk0bBuSxSKqBOeDgADPH1qC6uIinn+WomXqU6ACtO5ZEUCMDO3jb3rKu44UiOSQjAl vl9etNBuTQMs6qW4wP3inp0/yatuzI4JblTwjL+n41mae6PJIY4mUYAck8NjuPzrQndU2FgS H44FCEyAzSJO6GXfHICBntms9EQRMhk2tI/btjqf06VbKoZ90mF2k4OehpCInjDyoFbGShPO famuwnYj05XF2kZYLE54x0Hc/mOatIsTQh9xIJJHPfNZ5eQ/LEMOuHfcvP8Anmh4Lh7WOIuN shGARjA9v50MC7LvKLMqqVGAwHcZ5zT471pmZWO0beD3pYl8qxdGO9lPOev1/Ws6FluQVkLr z8rdCrHj/P1pIRpRSLtbncG79OfSqiTxoJjJIXwcgdwO1WgskUKBo1dzjLAY3D+lUo90oLZi YKSGJ43KDn8DTAdNK3nFoyXBxuGOme+aY3byZV3DOY2GQfUUTS+TcpLG26I/KwU8DNV3Ls6h TH1PzM2GNN36isXbe6gndlUFHjPzZP5/hToJRJK0iEqynbtY9cdjTYAis0iRlTnOD2p1zCo2 MmCwb5x1yO9LcCmXlOpMHL7emzPT3qyEEkaBo2BO4EHrio3jeKXznzsGAPc57/56VPHdL58Z dgc/KAvP502xGfJbCRxG8g3xjci57A4x71oQSK6HcMZ4Gf8APsaW4Ae7UrGFweHBBz65H0qt NDGElOWWIj7obbhj7+9DAsFYBCkPIPRX78+lRT2haTLBnOOqmn2KK0ZR2Z2UZCv1X8avR3iL uUYBU4OQeuPamibnzbR2pcd6K9U4RKKPpR7UAFJilx+VB6e1ACelBFHQmg8DFAhMcUUcE+lG DkigAHTpS460lL9KAE70Zpwx1PX0oIG3ikA0dM04j5FO4HPb0pNpA6YFKVIAJHXpTAT2Ioxx SGnZJAoAQYpKUHHYUvUikAhySSaKXBNIDg5xmgBOtJSnpikoAKMYpcfl60Y60AJ3pKd+NJig A70hFKaSgA47Ufzoo/CmAnI5oo+oooAMmk70vUZwcUmKBCUlOyeaSgBKOM+tBpSMKPWgQ00+ JtkgYU3il47UwOt0yXco9611BOa5vR5shQT0rpUPy5pdTGSKEzeW5O3OavWF38mNgLVBcr8p bGSKqxSSM/yMFxVrYSNud5gu/cqr6VRkldhw2RVUySOMO5anK3GKCrjzuPJNR5OaeDzzTduH 60ABORTfcU7GGpWX5eKAEzkU0HqD1pcZpMEGgBT6ikzk0vT6U3HHFMBdx6CrFvGJTywFVc96 MkdDQBv/ANhZs1uElU5/hrNnsp4hyhx6ioIp5BgB2A9jV6HVZoDtbEiehpa9R6MztkiclTTW bc+TW+mq2MmFmhwD1wOlZuox2oIe2k3A9vSi4NFLdwVpgyD7Um7HHenLgimIntmKTq3vXcaN KA+GfCsOc964KNufpXX6RIriPdggjBB71jVV4s1oy5ZpnWqZJCiQbSjAkHPygjHHH1/Sq0vn PcqJXcSeZ823JAUY45696ljaGwgj8r5gjjCL0HGOfbmmtcfarljHIqB0Dhm7DFeQe2XElgGE 8wIB0Hr7e1JHcsJWIjBRuFbuD6H64qu9qriNWBkUjGccipVh8iIDzVZAdqg/40rjsiy06pgT ZwTgEf402SHALKFLn7q8DNVpp2hZI1Xex6DHbPX60143mkWNsbQOW/HvQIpwz+TOFuQAC24O Bkeh/pWmbhXWQSkFNxADDtxUDQwzOY2xnYGyD0GT2/OpoNkO23LBgP4uvv8A41TEiNCrsY4j lQOrHJA9KSRY2sREz7d2cZ69elTqhRggxtJxk8596r39i0hAL4GCVOc889PrmktxlS5cSSRx FmJBB54GMc/j/wDXq1LCJkt5cqojUtluD0/LFVom8q5VJGNwsiEMCeVI64p0QnMrKrbomyu3 OSo9f5VRI+1ihDsyEYA2qoPX1p88zPJG4iTK4wCM7T/TiiNUtzyvADYUj04yPyqvFJM1jvDA lm5bPOP85qUNl9preVSkrqcYyePlPvVcW0duJYo8ON4K46gnpzUUk9vPCII0Mjcneq8k49ac 0UjHEWVIG3cB/EP8j86bEX4jJIqLLtbcP4Rxgio1RoJEtWDNGx+VgcYHoait5Wt4XQIJWwSo B6H6VHPcXE5RFiCspBYg4Kj0/wDr0hmvfyRCFIGZX3kKvrzxWRatIl6Yk+eAMSCeDz/M8Us0 V2Lguqq/eMngLVqC6S4lXzEQfNgsB/Kh3SsKwXSCPe67RvwQSegzyP1qQhI3Utyp7g8imzqJ ctIgcDOAvTjvUZj811EeVUDkDj8PpQBO3kq2TlXyBkHNVLsYDRRbXAOGb0xRLcvvKFBGp5GO v5/4VmWryNqDASyFlO5d3AxVWEXorxJZg0aN5Mgwx/z9anjdnRgqLsyBhhyKypbh4HaOFk8m UsVxyRnkg/Q5FXpJ2is0k3bkXG4juKTVhrUuMiopLkHkDGc8cD9Ki1GbyrVkZc7vlJboD71C lyPPXcRtYAgnoB0I+lWbgG6UpG4KcgnGdp9aFYRWjEi28LQRgDIyV5B55zUwuIG7uQGwRj2/ /XT7VXBXayrGg2hfX3pY4oxdMACTwce/rSB6kV3BHLb7go3/AHlLdOR/PFUpVujw8YkAxn5e PT8u9Xrh/OtJY9obacqQcbsVWsbwCKRHyBH/AC/wHNVsiSRE8tkVFQ7lyxI79/8APpUUzTTx l1ZNyHcqjrjPelmufMZJlcfOCAQOAR2IqtBZzCYShyjDqcdaASNSLZdRDymHOB+lK8ccaeWV yzHBAHc1QtpDGZYpsKIzwwGAwIyM+/Wpl1BJJDGWHovrke9ILF1LgsqqUPTOQfu+lU5riCKV wHjVn6qKV5Z50JDKuAcnFVbOWG7fEjK0uTgEdqfQVh63KGeSML868HHQf5Paq0ayR3Jbyt5k 4YDkA/5/lVmMw2U2TtcytneR7f8A66kWRVPmImBjJI6Y9cUxFWKdX1BoH3KythTnIrQjgcIC yH5GwcDB4HSsdrlY5t4jw24H7uf1q3Z6zIZUjm3tubAfGc5pPcGnYdNE9xdsAD5Sjg+tRJcC zCZQyPnaXxjt1/Krcl0kTDCMYc//AK6sybGts/LteTcD6ehpiKhK28nmMgZnBGwf07VHLI7q sbRARg7pMnJA9Pfv+lWHO+VIz17NiopcvFyuA4weecUkGw1T5cjGUNyxCkdQAOhqU27ZyobB 56ChBH5e1myqd85qs9pNI24anEAe2Bx7U0I8EGenrR7UUnevWPPDvRk5zS0UAHWkp275SMDm m+1IAI4pDxRS0wG0hPNPKntyKafTFAmLn2owQaBTwBg5OKBjT06Gk7cU76GjtkZz60gAnPVi SOgpuaCSSSec0dOtABSAe9KfbpSgcZyPpQAmMY5zR0oOM8frQMnNAAPelzz7UdKO1ADT8xoH Wl4xSA+1AC+1JS564/GjPGKAEoo5705lwoIOc9fagBnJpMY706mnrQAoBpBnORS5IoPfIoAC TzkmkxkH2pM0UwDnBHP0pDk807GRQVoEMxR0p3H40EcdOlADaMUd80ooAT8KAOfSloAoA0dK k2Tba7G3YMg9a4a0by51PrXY2T5RSPSlIzmizcplSR0rLMW6QBa2XUFT9KzHxC5POauLMi3F p4ZAQ46c0Pa+UN24EetQ+ftUNG5BPUUwyuR1OPSqLVh0g5zmkGKbuz1oH3qQC8g49aUZHGKC e9IGGetACnhvakfGKU4NNPK0DE6igH3pOc8dKQ+tMQYxmjtS54poNACq2KkaUiIpxhu/pUJx QTkYoATPPNKTkU0e1L0FACYz9aVaQHBz2pW9RQA7kHIro9GkzEueqmubz8vvWvo8xLMtTIaZ 6JC4ktXy3U4HHc4xzTpdPjKx+YAS3J//AFVU02YrDG6gsyk8Z4+v1p8scksqslxgvkgr+eK8 ea5ZNHuU3zRTLMMQWRAj5Bb5cN1q41uz53gkAZCeue//ANeokQIA8m7cOoH3jgfzqCXUIkjD IS5dvl3DB696gsczR+Z83GcdR09hUu0gPsb5eMHbyaa2Lh1d8ZPHI7/5zTYZGSV1kURr0Uue p9KSGyS0jiHzFcSEFcnqPaqVwAL0FZCkwOB757D8aswDYVCrlsnaxPTOaSWGNSJH5C4GR1zR ewh63JDrlSX67cdRUNxcyCE7yjMT90cDPtTkZY38sKXUHlu4NVJImL7JGxnOxuwz6/ShIGR2 0y5lkKgEybcPyQpHNWGDwoRCQCcBSoyPXH6frTDbxW5j3EBlIO7Pf1qba80jxpgDdkSA9fyq txDjceZFmWMqT8vbdzxkVXN1FDasiuGK4U54OP8AOajk0l57ozPJhw5cA5OPQ/yqe+to3DFk V0A5YjB/yKdtQuVDG0MnnQtmXBIG3APTIx9DVoWRa1kgtXxHI4bbnkccgVIsBeKCME7htAHU 9vz70Wq+W7QbSo8wgHPI+XOfxpCFSzl8hvMwrgkIR2FNS6eIxCWAyTMCAU4yBwDT47j7R5kb S4MZAyP4h3+uD/OnqI1+9l2jOUOM4HXg1NrMq4lncSyzSJcKiheq45B/wqGW2kjdVhA+f5cd uf5dasSp5k4lRlbGflJwCCelMu1KywCEgMG346UxE0du8KhCwZh057YqowkAEYf587/l4x7D +dSzS7CZGcglj8vfHtVK5NzJeoY1d49mQmNvB/rQFjUWSNnVJNyjj5+2fp1qG6siJA0Kb3IK 7sYFTLDFsG4DkcZ5JHvVKd7m13CP5go+UZznrjP+e1CEVvsH2fzZDJtOOFHrVuYl7YJswhVT weD7U2CRSoe7UI7r83p70r2yvbOkQJVeytjn/ChO7C1hY5I1hx5Y6BUHX/8AXVlYxbqI4cKC 3XOcVVgV/ssRcZBI4JGV/wDr0XN2zsh8pmTcAcdvegNyUu0Fx5IXcVXIYc5OT/jUsdxIzh2Q BBxweaokXDHepG7HQjIYfX/PSnRNIrlrllDO2fLx2x2PvQtdRND7shXxGh+YHc8Z4GeAT9ai ldYYhBHGpZ1G5ugOP8inNC/2WJYwMHlsd+KrmVJQVjciVMkjru/+vVXEkWbeP7OEyi+YeflH GfWoI7tzcSqH8wg7ck8J6inWUqtaeY7K+0c5zn3qOe2WV2mwUfPDZwGY9KFqJj9RjlRIpoiv mRtyW6Ef3W9qVIIUVLkjy8Enbnocd6We4WInaDKu3ac9yPX3qG3uVdHLoyxMSi5HXPHFFguW Los9mwTMokxkehzVcW1uZFPLsp5GQcZqeNvKtpftMi4X+71x6/jxT/sqCINbyBWBG5fUDtRf QRFLYJlDIWKJ05PHf+VLcXRjVVj/AHmVwQPvcf8A1qN2yKSeZjtHK8ElfwpLSS3uLiYCIKQT 8/8AQe1F9LgJbgXUMTTIA3IPGMdv5U6HT3tZc7t0YH7obe9TSWUAlMkRCMeAcjg4xTopdxMa yEYOPnwc98j/AD2oFqQXMLSzwlJDEudzAHALDt+NOS4RgYmUhN33epzj/wCtUzy7IdolUy5w pbjcCcHH+f501tguhwDt491PegLkn2iEsm3AyPlI/pVN/MNxEmSIQSD6dc8/nTdShTfFJG3l cnDLxT9oMcD7z5pUAnPB7c0Pawh37i3Dxsyru7McU4WkDqrOEDYHaoJoxJ5gYnATBznOansr lbi1R2iRSPlHJ5Ap6Ets+fgMmkoor1jgDrQetFFAC4GDk8jtSUcjOKMcdPqaAEPPXml9eaMc UAetACUhpSPSkxg0hAKdg45pp6807k45pgJ9aP5U4ik4FIYh/Skx3p3SlPQYH1oAZQf507FJ TATqKXHFAwOoP4UAcY9aQB0pMnPbNOGMc8+1JjqOh7UALjPQ0hGBQeaOc9aAA7c5A49M03nN OHGD1xQPf86YCqqnO4kenFJkDjvS4PHHXpScA8ikAh9O1NI6U7HNKeelADMkADFKSCBhQMCh uuRkUYJFADc4FL264o284pcCmIaM0Ypc8e9AGBQA00hY9B0p3HNIQMZxQAmBS8D6UYxR2oAM elOx7Uinj+VOA6Uikh0YwwNdVpkm+Jea5dRzit7SZMLj0NLoTVWiOkBG3B71RmjVZBv+7mri YZQaiu0BQU4uxzsz2Ko5KDgnilR/UURsFfBAPoTUzJn5gw+lajRAxJPA4pRuxnFOYN2NMy44 7UhituyOKbtOcg4NDlgAT0qPJ3UwJAzHigPjj86aw8tgwOfamltxJ7mkBIW9OlLkYxnioFOO tPDCgB4OQaQHikyO1HvQAc/hSe1FHSmAU4nNJmk9qAF7EdqFPajFAwaQA5xjmr2lki5HvVIj eat2StHcISeM0PYZ3mlTFIWwm4rzWtp9yl4WbykjmUEgHq3qc/55rF0iR458RgEnpmtyRbl0 VxCIiSd+Tx+FeViI2mz18K700WjcERofLGOhJ6L/AJ/rWdHYxtdyFmDIR9zOCD6/lRJFGIyn L4YnZn+f+NDQh4ZZiFy7bRzjArnTOlovqmEk+ZWUng+naoB+/eRh0R+eOvAqS1gSGIR8tHjv yCf600yJC6qo+XJYgdsDp+OaNxFXzy928LqUhIPUZ/EUkjxWwcSSglBjAOSQOhqUSl7mIAFA QTg9+cdf89aiuInluGVoCGxiP/e9PxpgL5wuRkEo+Mgjv7j1oMzSQoHYMyYYkdOOn48mmOFa ytUZhGzLjaB/n0qAXHmXMSqq4lA56EjuKAH3bTORNFnaucEDkelXVG+JN3yuRuLbeh4pgQWe 3aGfPylR0xUMV20kjNExKscGNxx/Ljv3o8xFhL1VjQu6iQgqBnJOM4qM3S3COkjLuK8Hrye1 NuizSKYoUcqcFtvyqD7jnt1p8J80jKrGduBkA8+lAWLtuVWESZ3EYOSeh9jVK/YyS/ukIQFW ZhnOOfT8eRT0ndQ0TbTKBkKvQ/n/AJ5qsGke5YSRbIzwSDn3/KhabhuVoY7mRpGglBBYPvXs R259RxWtcXJhjjLRDaMbiDnIPehbdYhhFCoeir0+tRIiJL5O/IPG1s5HeiXcENDvsmRhu3ZV Avfjg57VKsf2qzDHekhBw5PQg9RTDC0csRX5VJ2tzxz0NT2rIrtHMBtHRX6g+maSB+RSkjlu BIlywUxYG5f4lNaKMGjEkWB5YxtA5x6VXuULygqNpBw+G6dKmjj8uLbJIhLtxzz+n8qoTM6e 8n8+VJYisZO4MWA/LOKnW5MkaxhTvKEICP8APtUkwUxxR/Kzr/e9v/rVSkuvIiGzBZc9efwz Rp0AnhLC42TRhlcYLEd+/wBauhRHGdsYEY+63pWYfMuFBBMcYI2k8npz/wDrq0wknmlQyYCj AQ46+tGwmFzcCKaGNyCvGWA7/wCf5VHc30IlWGNd0h6c4/8A1UyW3YSAPmVyNoDDj3p6Q25I lCqZFXBYDOP8aBDbSS4jnJlBKlehGAPYVHdyMzAbEdCCCC3Xvxx1p0IJm5kPyuAwHcc1bkWJ NzuAV69OP/18Uk9RhCfOgUhcgfeU+n+NZs+6LVI5Ytq2+DkAZzgcmtUxpJATbuAwU5wOQKqt ZEA4faWGMnOB3yBTWwiJCjQOqrsV8scHHP0/GnSQNImwdvmUk8r/AJOKn+yBLMoWbcrg5XGc elSO+75sghfl4/Si9gK0UMZIcncwA+Y0woJlCwbTGgB46++Kltikk8pddqryNw60wXcFuZSg fjOcjpjPT86NQGksk8MjhQrZQ46H04/z0qLdLbSO0zfK5yCvRalaeDUIf3cpVlG4jHIqYuMg YLggcMM/j+dG4jLlvp4pkEkZ2u3JxweOo+v+NadtbxofkEeW5AHU460+eS2EcZkAQA55Xpji oZY4o5CyzYYZ8twwOTj9afUL6EV5GRESZwATlAo6n0pNMh2MyzSKduDGW44pIsXD7GlQuG5B /h9fxqxJIxiG0DMZyB7e9AiBrhjdMrqmzeQmwYOemaYyu8rsrl2OAMnp3qa3hZJg1wAxDb4y ccD0pJ5ls3JMZcSDlx13fT6YouA/aJ0nVxmMEMueKrq4RBIU+QH92BkYJ9c/zqwkO63yGyuc j64pPs6m2AIAXjOfTNArjbhwLZgxMangn0zwD+tLBBLbRLCsTyKgwHA+970MsbxyhSDHt5Gc 9P8ADimLM5HMqIOwPGaL6EnglJT2KlVATaQOTnrTcc1655wUdqXoaXGBtyMdaAG8ZoH6UU4j CAnHPvQA2ijNGMAEGgANJ3pc/hRtJUsOg60ANp6n2qOnKRn1FAh2aQ/j707OaQdRjk+lIoMZ BPHHYmjtSex60vQ4P+NACcUmKXJo74zigBcD1yfSkJyemPpQMZzSjPIzxQAmOT60Dr0o4/Kn A5OcCgBv4UuBjrRijByR1oAO1N56U8DgUYzQA0jgUmKlCgDkUhX2ouA0Ej2oHIPPB5pD1pVx QICSBScZpzHPNR9+KAHYHam496cOn8qQ8dKAG0c4p4iZjwpI9qnFjMRym30zQ2BSIo7VpR6X Kwy3yj6U9NNKTbXGVxyaXMhXMoKfwp3ltnGDzXQLp0UbhSMcZ+lIlskZOQ3XgkVLqILmIlvI TkL3qwlnIQGNairErbc4z0OanZVaMKDkdeKTqDuzKS3VNykbnB5zxitG0jER+tMlysuCAzMA TjjipoyDhh68ihSbJlqbVo25MZqSYfIeO1U7WTDDng1eYFlq0Ysx9g80hjgVOIlfAjOTTZ12 yE4oijYLvBIPtW1xoVoXA7/Som3D196uq+MEvzUU0ic4wTSKICWaMAnpULZzxUrOGGMYppB4 xQA3G7rRj1p+Sophfii4CHp0pueMUeZjNM35ouFiRWweakDAg5qvmnA0CJCAaCcLzTAaXPFA Cq3OKd05qMjuKcGBFMB1KBzxUanDYp3TmkBIpHXvVq1be3AXj1qlnuKfG7I+RnmkNHb6bIfO iOcniupaJPn2kgn7uTz/APrrh9Klby42PWu1jZLiaF9hbC5PXqK8/GLVM9LAvRoqvaSSzZiI DcglzjP0qZpGtLYxyZ2oAAVGRnHP9afc3LQzRkbZT125wR2pEnMf7xstA6j7w+v61xHeJZTJ Irv5oB3fcbg5+lPuC6YkCOdpyVA5NRTW0MrqEwvmAkADIP8AhSxPd2u3fho8H7y5IA9qegiN brDK8aYjfghhkcZ/+vVnzWljDiRSh5BGD/Oo47mC5zEoRlJIwAfzp7WhjtnjDDaACAeDnOfy 4oYDLxVaEyIV3oMr+HNZBhleeO4d1CkEqQccDpx29K3g4Y7NgB6EFe9Zd7BNApYKRITlWPVR x+HrVR2F1LbGS8hV42B2fw989eadBavsbeQ2ST045yPb1qlbXJOFj4YkGQnnPHU+grXgmCOU Z1dun171PkA1INjYaXaQOfrTJ9SgQkPgBCBkL3/yKpSXzfbLrZbhjGdql+h5qdpbe9sY/LQb jIEcY6dc/wBKNg33K0rPHd2lwQMFyWPGApyB/OtNGBjEkceSQTnpj60y4SMoEU/c+6oHX2zS xWmyMMGfB6jPQ0XYtCL7ZL5pR1VTjgr1NEcglkIkjCNng4647Zp0ksUa5SMyEDP4/X86a93G 9r5jqQV/hAweuO/qKFcHboSSGSKyaJf3kinBH4/z6UIqTokk6uAvc+o5GafDslfcmfMGCc9x jg+//wBaoVnME8hVh85OVznH/wBanugIxdfaLlQpyCSpTsPf/PpUsayxrtcE8fKG65+tV4U8 5tzs0bvgkRMAPpV1StuojdXOc45yf0o1EREpLEW2lSOCD1BFU5rO3jikPKoQNwJ6Zq8Ci8Ow MhHRuCcUwwtMh2ptHoepoSswb0KkcZFsikkRtjYR16dDTIUk/tCeYr1Vec55B59ulGqI7xRT I20RsCMH36U+e9JVFRQWYDZ33d8U7B6lt7gNPyVQYwNx55qOYtCrNFHuJfkk1TMTMMO+Y85D MQ2AR+o/wqSJnefyZGVkRAyNnBJHBotYTLUA3L57D5nPGB0qreyutsyyKx5KgqMYJ6d6fNIY JFkjkYwryUHGafdLDc2/mZzEfnBJHOPUUJJMRFYCQwhwABzznPTtVwvnCyFY88ISf881DbBA 0YU/IVwT3/OquvArBChfhnUY65XPf8aErgzSdWSSNTuye46VXkv/ALFdERwgiThgfWksrkw3 D28rFYyflJPT2pz3KvqMgcqwXoxAOB6ilYdwvV+dJFU/M4ySefeqXnlLryyuyDbkkr0Pp9cV oldkgaU8uApI5Ue/60stukXl7hwMKSDnnpTbJIPs8cSmQEkMNuMY9DSR3IjjMiufl4DkdOaq 3sVy1uEV2Of4cc9eoqR4mi07KMCrncxf5QCfWhLYGMurpnJIJVQSc+o/GrRtopYUVFPHTiql vaoUQ7djo2XQnjBPX3Bq5bq6SNHEoVBnLHJOabauO+hTvoILWNWEeFc/M4PIHvUzq9nFAkWJ izjcfUZ5/TNVruOe6h2M3IbgZ6eh96W1E0b/AGd1dmRgCecDjJ/Q0NCNQRRI4m527cY9Kzp2 jKlfMDFug9auQSMkpWRwyY4wOcDpVQzRC7jYeWEK/vCccelNE7Bbzy25YTgeUxBUryc4xj60 W98DCzxRFcv5aK3Ukn/9dWEhSdCSxCsenXA6j+lVZXg8zC7wkWXZyejjgf1qegWRNAuLh14c sCR26dh+tSQxzhSGihbk4L9cdfWnkiOPKRq7dgP4ianSaBlG+QLjgDH/ANfimiWfO3ejmijP rXrnnBxjg9qMZNHpRn3pDExS9uelJmlJ9AOaAGmj8aXp2oDY/hB+tMQnajJ6DNBPNJSATpwc Ug4pcHrSYIPrTAepwc5xR9DSKfXmnAe/50gEJo5PSnbTjkcUbaBiY4zijFOxTtvFADAfX0ow Tx2HpTwmeTUiIN4BIGe/pQBX2+tOA9RUpwDjPFIxxSAYV74pdoHNHUZpDnjvTAXHHtQCAKfE jScIpY9gBmpTZzjC+VgtwATyfwpCK240E1pjRZwm5uG7qB0q5BosHlAyEszHjPGPWpc4oVzn cHP+FSJBI5AWNiTz0rqU0q2jYlFy2flp4tHlKyBl3Dhhjoan2qC5zS6dcHG5NoPdqtLokvBJ yvX5RXTSIOSCGUDGO9RS3YhAJRgBxzUe1bC5hw6H5kJO/wDeKxBFBtreA42DeOCO+a27V4ZZ WZfMAb5ju6fhTpIrd7hnfHHBDD1FHO76iZThtkKDI6rzxginNaqro2APlwMnqadI6boliOVO RuH6U9ZWJAdeByCaht7gVpj8u5cKAMuPWmiIy85G45wQehp0+yaVscODjntUYieKdWI+Xo30 poYMWiYCQLlCAfelkjWPPlygbuQhNQ3M3KBl3SYwCD0puDKElxgBhwP1NPzEJPDE23a2HPHt 0qdITHGFJJI4HHSo5UU4XA3LwBmrO4yKFBJPfFDY7CNZPctiNQWwBx096S4jigYQQ/MqEhmz nJ/wq2bl4LIxoMSPwWPf/CsmKTyd4m4LHjFKLdy3ZRsX7dsEe1a8Zyg9aw4ZFLjaeK14X+QH 0rdHPJEN5GeT0qG0BZ+v1zV25IeEmstZCr8HA74raJKNULbFCSRuFULmNTlkdTSiPdHuR+D1 FNMWByaZZXApd3FPIAqJyASOtIYrBvKMgPA4Iqs8lNkmI+XtTFRmYUg3FDknFSbdh+atnTPC uoakA8UTbPU10cXw7umj3NIocDkGpckaKlJ9DhQvHWnbOOK7C58A6jHEzIoYKdp5/wA+1Zkv hXVrdQWtXKnOCBnP+eKOZdAdOXYwRxS5zV2XTbqP70Lj8Khe2ljGWjYA+1WmjNxaIs54603B FLjBpKZIuCenarW1VALDIxzVTcR0qVZP3fJ6UATeXER8rY+tOjidSMEFaq5J6VNbkGRfn2kG kM6DTXYJtIIweldjay+ZZhk++v8AMetc7Gu61EhIZuMkVo2dytsuSN2Ryo6muTFK8bnbgnab RqNGjH7VvVpVOMBsH1/L3oVoorMIoDRnBC9hzxVCG3c3QmCsYTH90+p7j3FWxbpHIFlLYcAY B4H4V5z7HpjWdUkBkuxvU8KCfXgYq213FAR5mRlc4b0x1qJ4CsJMciSsJN27rkdTVUSzNcmN uYxgkkcYzz04oBIspJbySia32B2UhlZtpx71cuFaD5pX+c4IKtkAHkDj+tZ6QxQ2shO1sMSO M4GelSXU4tII/MTMZ+UqOn4enpRo9At1LQKiJGkc7wdy+3p9aQXIuFztbBbbk9QabI1rBaRu xzldwI7ZqkuyJSUdREzFj6E++P8AGhLQV9S2LG2iiLRy7ZNpVgOcVDDtilScrJhTzu7dulMs Vc3ZuIYisEiHcD6irtxFvt5HwQwU4x1ND7AiKyBV2jMZdmfv2Hc5qSSyit5VnE5j5JwpI3dh n1plpsa1GxwQW+YOc4p7xJOrIWEZ+8mPT+VJA3qPVJlKmT5tgBDDp+NTjMgV0znHQHt2qh9t 8u8WOQkKwwCeuenb61faLyw0ikr/ABMc9R/nFMCGJkildJo3jkPUN0x7dqh+xwpI5lKFdu0A gdPepnneYICu5N3ysRz71DNkkFFyucH6miwD0mACLGvzD5QTwF5xg/l+FVJpWKu2Qu5jgdcV ZFoFtXEzsNmMhSMkelBtfOSJY3KEndkDBP596Ykypp9rsVnDEOBuB3cH6f8A1q1FfMG9AMsM AjOM1QgjWOWS1JZfLOQRnJBPH9KsnNuGDEbScqx4wfSgGyrDbTTz+ZceWVTIdM+vpj35p7zy 2EjPKC8JAXA7VZkkNu6YKiOQEZHr7/WlkuInEchZQNuVJP3h60nuHQrzQr5Dg52vyO3NVpLd YoAoj3shypPH5fmamjvo3lEeFIPTJyPb+dSyNw43YL84HUfTtVaklZonBCCEnA2kE/KAe9TF ljKbo1baNuev51HqE/l20axlmLNkYOOlVPP/AHDeVOwJIJ7kfWmJIsyWqzRu8TksQRjPJB64 qTygbZFB9MnGNv8A+us6EtHHmF2MYHzJk8H1/Gn23nm684y5DjjJ4A9KT7jLhintoBlgyKc5 PUCq94UuYDP97yCCAfWrryuoUYEi8hyOg/OqF/ai4tSsDEBW3OoONwPXNC3EQxSSXVqZTHhg 38J6HjHNT2tvIAiuWIDFuDzx1/mP1pbCM2sTwMwwxGR3X/PpVu13rPKxkAQHanrgd6Vx+QqX v7kiaHqxVQOlRwaktykkMkQQgdD3/PvxUdxAVlRA7ZkYD6D/ACarLDMlzmM5j+824cjjBp6C N7fHLZFBjfgheec9KqudsDqAMkEHIwPxrJw9veZt4CygZAHOPQ1ct7n7enmckKSrIf8AP+c0 9ibFWxE87mLzspggMqgbfb3FaqIsUccSfeLYO0dOahYJBbvth27V6Zx75OPpUSyquyOPczyo GD7cA+1Fr7g/IueVifCuN+c+tUm8+O6EykDblQmMBu9WLTK4E6kyAHB9c/Smb2mic/e2liBn GDnt/jQIzmu7iG7dZOedyrnj04Pei4siqq4xslILpnkdyRVuR1jtnuQNzjqo6E08uJ9NScRM CPmZG/pTV7gxURFtl3SYz8qt6/WnfZEQTCVcKWyQBzjrxTR5UdqqscLgFkI6VWWK7nnYmXLK 2PqO2aWyuG+wqutrG0iISkeTnp2pQglUPLGDIwy2T0q5FBshVpNvmKuGyOvNVpp0t5PLlEr4 +6UX+Ht2qk9CHueEfhzSetL265pBxXqnni44pMUtB6/WkAgBJ470ntTu2KTtQAlBFLjIoxTA aRzRipAODxSbTSAbltpUEgHqBSbak24oI4oAj24p6jPH6Uh6UKcUCuSDIOBSnk5wAfamE80b uwBJ+lFhjsYNOz2p8dvNKRtiOSe/FaEOhXLgNI4RcZPHSk2luFzLPHShck+5rfi0FAwEnOD1 J4IrStLW1iJSNFDg+g4NS5xFc5SO0nk+7G3PPPHH41N/Zk2zdIQmRwME5rrWChtjKqnuT6UP AH5fGAMEEdRUe1DVnMWukiUfMXCgZPFaDaLbqqhcqeuW6mtC3hMRkbOFD9PX2qfCTEhgCAu4 H1qZTfQEVrOwSLkKMH0qy9lC1z5rY3AYyO1RhpYg7DGTwADULXZM8ZxhWJzkYHFRd3AndXU/ LkYOCAOop32ZWQhhjB4IPWpPMAILnGfT/PSlc7U+Ug5J75qdUBTnjYOrBsKpP/6qrteKGDMp +XIIPBJ6ZpXYmcqX2g9TnpTnt4S7Mz5fA4HfFUvMLFxJkRSAhX1B/KqFwrteqWbKYzU8QSdA dxG/07Ul06whWK7VHygseWo2YhhIijkkXhYxjAGTUYZJziNwykZPqakjlExkQrgY/SqKo1je Bc7opAQD+HNCQxxtiVB83btzgZ6fjUeJ44vMhfeF4dTz+VaiCFlyFUhhg59ahRUgXOzAHUZy DQmIpx/vz5rDaQfmX0z3onLhfLUkk557kYqaQqJZJkiGQuc+vtUKMZADIpDgcDPrTXcZTeAF EkRi2BiQYwQQM/iPepYflkYYKZALK/Y9QcVahRvPJBGQwJU9zUF1HM+oSXU0hZnOfwGAB+Va uUWiUncbIPMmyGB9fpUsQYSiVCEGMAdx61AYne7V1O5MZJ6de1TeXxtP384ODWbKJstK2d3y gelUhH+95O5c4AA5x3q6MonqarTMYpU2pk45NKIydI9hBAwD2rRtGzxVHeWRQVOB61Zt22uK 0i7mckXpgrREYrIlTYwAHWtkjcvFUZcI+SufpXRF3MxbUkRnEdK6u4LBeO9SWpaTO0Y9qJ/N Qn5SoNUWim/0ppgLqWX8adzk55q/bQb0yoqWBhvH8/Sux8G+GhqUv2mdcRRkHnua59rNvtJU L1NeteEII4vD6FRyVyfqDWNSTsdGHimzYit4bZWihjCR9QAOnf8AlmiQFyMdhz9cmrAXekTY wQdv65/rUdzLHawfPw33Qo6k+lc7budqQ+bYjSDduyAV/Ef/AKqiNzHGmG2HthiB2H+AqJLO a8ElxczLbWiru3Hj5QMZPt+QrKutc8J2XlxNeySMx5ZFJH8qvl6snmWyNJorScEPbIwOemD/ AJ/+vVe80GxvbV4Io0+XkZHarOnfYNTTdpt2sgAJKnhvy4NaMdswOHU706nHI9/pV2dtGTdN 6nkGu+D5rFnZF4B7dK5KRGjYq4IYV9G3FgHiKzIGTv7j1FeSeL/DjWd85jX349K1pzezOatT XxI4sLnoKVo3jcq6kH0NT+RKGI2Y9zUjK80m6eUZAxmtTnKwVmIAGTV23tXE6iSI8+1JCYIW 3Fy3PGK2f7Y+1tEpjUYG3JGDSbGkaNlbM9vIE+UIucHuK1LCGNo0lf8AgPQ96sW3h6caFPey OQgXIxyKi05ka1WJ8DccAnvXLin7mh24WDjPUklv5jkwqNisAe5PuB6VJOIym+QYkCgl/Yd/ 0p8axpIDkOw4ZsY5+lF5CJ7fKHr8pz6H/JrzUz0SJHhngM0NuyEOdzLyzZxnj8ahjYQXJdN5 hDZJH3icA4x/npWgkRgUIoU45IA6jpxj6CmWoLGRWY7mUA59s8/jQMet39oid44tm1yvzdwO /t0p8QjkRhOw/ec7G/pWR5s8EZjQSB/MZ24/h7fnitGF5ruJVkTYUI3DGM980ag0h1z/AKpV T+EfKnrVG1klaO43WvzxnhM4Le4NW5p/KiD8E7srnt+FK7ZYup3RhQcD7wNCbQmRx3bC0Qwx hVH+sU8GtWzmivLVXbGM/Nx3rOsFEdzIZCdx5HGMrgdf884p43rOzIAofiRU6A+opaBuQ3ED RXhMJOw9l4AGetW5Gjt41WWRc/dBXoPapTCPK+/nodrd/wDDNVbhUKpNtZSuG9hj1Heno9QK /wBhXzTukXcoLRnPXocfT/Grtncx3I3jgZKuG4wQeh/GkSYSCESQgSY2qY+jDsfyqjNIbG7d UCBJGVkbbkfNkH6DpT1YNmpcMA5SIFcsVyfUHt7VXkvLG1d4y+SDgqATg/8A181CsM1xDukn 2qEwCo6jJGTn8KcIY7d7cYzluWC8kY4H0o8yQWZrt90EbmIHJL5AyOgrS2gwqzNluc/melVj cK4eEMF8vk/579aIRcLmTC7Vz8vqfWlfUdgkniW42HDMw2A4x83bmmMxlneKRSsfRQw6+tKv lyP5reWJB94Zpt7dFUL4C/L8rspxj1oauCYk8ojySMqhwOOcH0/GoLhbV4BIzYVRgbex+lVb a4QxP5M6zESZdPUEdMVfzCr7hECj43KecDp0oTsDK0FjC04TILMAynHzY6H8etTtG0WowIkr Mrow57kY6+lPYlbklAd7jj0AqRVhmffn5gB+BxzTv3JsMZY7uONpFJjycJnj8fWqkkcJWRDb gSbwMj0xkGpGjSAYifahcMR12j/I/SomnKXDAjcSAC68Z4z7/wCRTuLYZHt89CqNFL8yMo5H +HtTgXVYhKmWBAYr1P8AkZqKaIvD5iEq7HjJAJYd8/jTjLdNJhYgCTzgYJz/AF/CmwLpeMTH ywfmXB9Se1V440WSTe7M7cFCMD2+tTxk+THJJgycHGMHHSrFxNEiB+F28fNxj8aQGbArJdM8 wCxuD1PP4/zqx5cgKpEV2Lzk87qrS31tNOI97NvIyR0/+tzUjIIJFaBiBnlS3FAiz50vluGB IA3cc4/z6VFDMzviVVR92F78H1q1EG8kysRkDJ2msXUJnju0dN6qWxxyQevSjfYC1O9xaSBw qPG/yZBwOuKWyjENyVZyRIvyk9j3BpgmmNvI0qK2HDbcYGD3/Op2hW5aKdBvVcdfryKd+gDb q9iaB1B3KTjoeeetSMpSJI5It247QM/d96p3PlEzReWw3DKqDnB9R/KrYMkqxzR4CMBjJ5ND AtRsxX5seYpwMjqKqyxxh9zD73C7enqasTNGYHXaNxPG4Z/GoLIK0s3msuw8qM9aTbWhNluT WVvCEdUPyls7ccCobqYJILYRqyup+U1JHFGj5VmCbske9VXjvVbHliXBysme+elUtA6iiMSQ 7I2CsoIwwz07VcGV+YHDlANueT+Peq8JUFmkG0uwAbHWqlwpmvHKnaIQDnpigRZuZ5lQK0hQ A/ex296rf2hCAN/z+jZAyKPtMxgRLiPzdxxuBxke/vTItOa63yLIoj3YQEA4H+c0X0EeJY9a BjPPSgilIweue9esecLgdqXA2n1zxSClJycscmkAm3A6UbcCnYDEBckmlA7Y596AGhQMU7ZQ T6YpRknHJ78c0AIOKMgjrTkt5pT8kT4PfFW4dFuZJhGzBCfagVym4UL94Z9Kj3dBjPoK6FfD qxOWmYyAc5FW0sLe2Rf3aiQ84xU88RXOaW0uZguyEnPrV6Pw/dSqC+FBHGK6MyQiP5lwQM4X jFJDKZbhgHym3pUOo+iC5kpokCbhM28qM8+tXIrCKKQpCq/dAzjrWpcrGELHGdpGTVaOTe6l UIcj7w6Z+tTztiBoorWDAUkkhWJ5qWOBDtkjb5cZ46Go5opJ1CL09T1qW1OEaI5yOFFQ3oOw s048ryhgO36U0BYkVW+Yt371XnhkWbf99z0qAyE/65mVhwVpJNjRpPEuFwp2NnPOKimmwoUD oM/pUr58narAbKqj5oTNIBycD8aLMByyExLsTCsSPpx1pqfMAo4xwTTwUkkCKoDKMg4pRvRW km2sR8zc/doYg8v96UVyOPnB/OongR5UePuSTg8Co2YSy7kBOeoB6fSrW2QKoQEL3z60DKOH EjFmyzHC+wqyc7Qr59SRxjnrSTmNTngdyeaa/wC8KoJMHHC5zkYPP8qN0BDKgkiMDNjLc4HW pEhMciPvGwDk+tQusnmDfKBjpxVlQWKhJMZ+8T0/KgRTVJFyw5ff94H+Gi8ljEGJAXWMc4HO auRwMjmMxrtHTnOaguoBMwGDtXJwR1ouBQ0+683eUzhVPvxUkpaUeUYxtDbsZwcd6tWtpa28 b+VncfvDPIpkwh8xHLlWCkbsDmqbTegIW0KHdEjZUfdJPWo9QZoZFIYkE7doOafCIYcZVQcf eXJzTJFmluM7QVDjgjoD3qeox8cD+Yob8h6U1giysGIGTxnvVlXIyxIX1zUUoDSYVdw253Ci 4ESQthgj43fxZ5p3kOsbecQUI79ajCs0xYH5VHAFO/dywiGVy7dQc0agKcBSIR8pHFViWhl/ eKSTU5CAlY+CuBzSzSJkA8t/IUwGCaFmAdmUgenFVmV3Y7DuU9Kmn8oYUAAt8vWpYPJQ7CuB ijYCJEmjQbpS3sasRtyKbLGrITvP4GmxngGrg7kyNmA7kFRyou454HamWr8AdqnmUMvFbQep mytblom3DvV2d3lgyUxWSQ73GAxBrorXzEg2kB8jvWrKic+VKyYNbFgvyVWvYgp3KmD3qbTZ ASBnBpMdhb+CVJRKpx9K7HwdrkcVo9rOwBySpPf2rMe0F3DgDnFZwspbaTKA8VjKPMrGkJum 7nrsDKIJZMA7cMpz+H9RVHT4Wvda86RQY4Bna3Qk9P6VzGn6nevaeVG5yAVIIzxWjD4gubW3 uV8kGV8HcT6DFZqlK+qOl14cr1OI8feLZ9S1CWxspD9igbbwf9YwP3sfy9B75ri7Y/6UjTPl sjrya6geEXcFmkPzc/jWLe6NPp90FkRgQRhuuaJwktyYVFJ6M7XTblooYZYN0TocrIPUcjH6 165peoW+p6Vb6gdofG2YDsejfhnmvI9MwbbYo59COD0r0fRF+zeFLmR1Hzv8hPGS2B/hWWGk 1JxN8VFOCkdC1zDNC6qBx2OOK8+8W5BeQAEpHyTW9aXYHmPI3VTk/hxXJeKtQQWUxc/vJOFP tXXH3pK5xzahB26nnFzcKXOTVIxAn73WnSB3ckYIpCm1QScGtDAWOIKcE1et2iEoy2cdKzwy qeua0rGSGSTBUZx3oY0dlpmrOuk3dpLLL5TIdiA8Z+lNsYtwimJY+WwIUf3jwP8AD8vWox9n XRUaNkMvRh3qS1QkogmChxnbjPvXHitIaHdhW5S16F4KHlIAYEcbSen4+tWlhMkkbp9xBgg9 CfWqM0wikd5pApchc+nHU/jV7zgLYSRtkMARz2NcB6Gov8ZjfKjkLgd//r0qkIS0h2DbjPc/ 5zVGRpI5QQd2R8wlOcDIGePerLPLGxxDlNowvrkdKQ32HSSRK6ySfd67j+Rz7VKXjCsVLOBj GOp96pSu95aEhdsiKRsAJOCMf5+gqxb2nkWkaSSAyqnBz0H+AoEQ3MlukivGxZyGBB646/zp LdxJbk8o7cEnrkdP8+9Nl0/NzHJK+9gw2jPJ55/TimypiJYkkTzIwWOR15/wBFIrQgFzcRSs rEHJAC9MH1/Hj2rUWUJsViVLAEn0Pf8AlTEaIxncgXaBwB69DVbUZgkSytEjFeUU8Feeuae4 i+LgSttt1ztXDydMD+ppJYneNFztDdSDk9ajgm8m2jcx7V2q3HOcjmlhuo5Iy8bKm4cbux70 IVuw15bawlAlchgc/Khxj3pHeGZ9yoskagbSrZpzZmkDyPHvOVx2OPSqlyAl4s8cRVlQqSo6 54x+tFwUS9DDgMTlQeBg5qB5St35Kguof5QVzg9f8aZcXs0E0ESqowuSxHBAH/6/ypIbqJJN 5OXYhmIBAxj3qktLsl7kt9ex24BH+sOfk9/8K0vNWWHdCMOBgg9u1UJrSLDSou533ct2z0xT LQSRLIobBVOeOvr+FDsBZNpAxHAbJy2D3x2psU32jzIVILR/3hwQfT15pi3A+YOxikyQp60q tLGWRRlwmN2OPqfSkLUzo9Pt5po5lUxTRcsynbk0t7cNBz5TZLZ3gdOR2q7Ekclsxc7nkYtg DP6VUS0L3IYuWgwTs3H5j0pra429SaJpw6v8su0AFlbBP4VZ8txIFZlxjjHWoPLaRSi4jYAF cDpipJbkXFuJUXYSMnOPlb+n+FKwrlaS+ED/AClGwvPGCDT440ijLsVDt+8Ge+RmmpYw+R85 V3PUg9T/AEP+FJLbYCFRvEX95sEY9PWhWuAqyJMxYoSGUEHPXHX+YpGuXtwpAOxm43YJpLZk h2ADcjk/NnI/D3xVmWNpISsfzkvhHI+7VeRJXDlt0k4YMBhSvZKtGKGa38l1LKFJUnucYpIY Wt42Erls8lcZwen+FNjdxKVZR5aErtBwT9KnzGZlvosiXZcHEQIOc9cVo+X5buck5PHHNEtw 0hOf3MQ5JY9R60Xa+VKjhgQ0YYEnjr/9cfnT3YNsRpCwlWORChQbz1wfX8s1RtFE1x57zDzA oyG7irkFqB5ki8O4I59PT+VVLl7S0cB4i8oGDtGfx9qPQLmlcFFUb1AXkZU9RUkBSC1ERXeV yQM4NVltI3jQoSoIzkc1YhDxyPJIwKknap/gGT3/ABoF0FXT0uAJQ209uKgvLbFu6oVMcYwB 05HWrnmFl8pXDKVyGHc1TLiWUxzFg23kg8HjqRTFqRW1xC9qLdGIZATzn/Pf9KWO2MkkYQkr nJYdQvcfjUcCxo0m3btR+SBjcp6H/PvSQ6zGAyKj7uQBjJI9fypWsBaDyeYRFDmMMQGY4yOR RLdyo6Fo08peM5xTZ0e5gUAMkYIPBwaZPHcwoFIEsPQk9RTQmSbo5Qkyknd95Rz1pXiWYMjb SrHHy9x7moIysMUhRVTLDryfwpyXMaNJHGw59O3vQLUlKpFEsLSfOVI64zj+tETSJGoQZGM5 x1qA25laPe7YALbwOhFTG4kU7Y4dwHHToaVmwdlseCjGc8Y96TsRinbWYfIpP0GasQ2M0rY2 Ed8E44r2LHmFfPT1ppzjORzxW1Foy7juVz/dy+AO/PHPGfStJFksIQluYYHO4l4owJCDjguc nHyjjjr70Xj1YmznoNLvrgB1t3WM/wDLSTCL+bYFXl0Fx8puonfAwIcsPpuwBn6ce9azTtKo efdLMWPzyMWbPrk1ctiqQNvVgVPfGc1MqiWyFdmKmgxggvISO+O1adtplurqEgHHViK0FEWw KMn6mki2RIWGMnqPWsnNsBJIURVKhQM+lNW0wd8fPOcnpTrdvMLhgp7DdSyeY+MNtUdh0xUX aAjhtgVPmSEbTnJPWmtEjMxwcsMD2+lL5glBjUgOO54xUqkRgB+uPX9aV2OxSt7AqQZ5MgHJ UUjxi1DLFtBPcdK0JCpCr/G3eq8ce7DONyg845wadxDEkAQZZn2gfdHX6UEhcFSUB6KV5qxt CqCu7g4PrUcieYwLZxkbvSkxoUq5UMg+YdAKUIGcRtiNuoPTJqvtlaXZE7KF5Zv/AK3ekuBK HjSTknqVHBH0osBY2NGCWVixY5wegqubdJixSQk5z83apCWl2kMfXLc0m1x8wADDj/GkMqSQ TpOpHI5XI709baUkp5pGRuGD1FTxyuZDHJiMuOD2qaRRbDJYFew64p3aQEVrDsfzCSSQFK9f xp0u6aPbGwIwd2R+nuKYs4jl5KhcdT6/Wp7eVZYm2AYDHBxgGpdwsQpbJICu0KBxx/Opo96j YCWGejHNI7mGFmUAseuKbBI0kSKDyc7vp60tQK14QwjMab2xke4qGxj+d3aMgZ+8B09qdJGU JjLuobhT1FXIgYYlyxLdveneyAZOiAhnQgk9jke1MuCzoiwgIeMgc9OpqaU5gKc7s96iZzDF 5mMnnmlzMLEdvMRNJ5nzHgZA56VFcNJMGEQ+XoWPalt2kJEgHzBumO1OllKzswYeWBnk4p9R DvsiyRttPAPysetQXtuhiWNSN38JzjNWLa6eZQTHjOee1QMVacF1+XGVwffBou7jIrdG8pE2 52/eyeDSh5LUneo2A7QMflVm3RY5SzSMFzyAMnp0AyKZvaWXEyYHBzjPNF7gKMSpllwp61AH 3oyxD5B0OKiuZiz+VC2VkHzAdvrVhESBQqEspHPvT6AUlMqZC59zTGcODuGG6AirNzMVjKRo T7gdKZCoJVXTPsKa7jHrH5gA8wEY4x1oaPywGkxn60wRKk7SZwvYjqKbcnzIuHB54wOtAht7 hAu1ARz83vUS7WYuchsZ+tPhYyBkbK7vyJqEI0cuJD06etUguSeblgVJAOKtJ0OapN+6uoSm SpfPI9uKvjGM1SVlcmRPBIVarwcOuD1rMjOGzV5DuFaRRDIJYmE6sOBmum0sGSJkhw/r7VzN ySRyTgVZ0W6kgYtG20d62CJ0U1pEYmDDJJ5x2rDkjFrcfu2yOv0reEk12f3ZX5gB1rKuYvs7 Nv4OcGkUbOmXO9Rz8w6101lZR3bICBzXnNrftDKQCQSeDXU6P4g8twJSMjoc1LRpFrqenaZ4 es4YvNCDew/I1nanoC+aJg33vvDHSl0rxfYx2bJOzBhyp7Gob7xdZSRKocEjiqUiZQbKT6MJ Itlu4MuTx60lhb6ZqDQ6dqcChiTiRume3NZdx4rhjYNBw6nPXBrmNQ1e4vJDsyOcg0m3IIxU Nj11fBWixpiCF4vQq/f1pdZs/wBxa2MbBLZPmYDqTXmGj+N9b0eIxb1liA+VJuR+FV774i6v eltyRoT3UGkoxT2LlKTXxXO11O5s9Hgdnl3YHAPevMdR8Sfar8u0StF0Cn0qK58SX09u8Myr JubcGbqPYVn7ra4Q7oWR/UdKv0MUrO7epJc3dvIGZINoPoarJPakYkibPtTBbnna34UeTwcY yPepKbu7l500yaNfJWVX/iyOKWGy2ZeI7s8YNVYY3yP3mBW5Yx5iAc49GpibND7JONHtZnRA u7Zlep+tbOnwQQxEFGEucsfbOP8AP1rHgLTXQQH91GOcfzqbU0DpvidguOMNgZ9K4cVK8lE9 DCRtHm7l+6jhMx/egliFMZXjB9fypVtDAzxxttDg4UnIX6Ht9KztJljLbHf51B+YnJGa0rmS ZVTypQ4BBb5f0rjZ2pFy1gQLukAYgAD2HpUkknmwso2xrn5g4zms23upQsgk3Dc2B6fSrFxF 50aFZNoYj5lHIqdhjbOX7RAZC6mWEkB1HP8A9frUdxvOocuoRB8rKOW9aiTR3icNbyn1ZT0Z up/PFS3qLJbYAKsGOwucHGP1oY1uXAYII2xKWYtuDeo6cfpVVZEmf7TFnayAYbjLA9CM9qjW GNrWFNzRupDDOMbs9Px/rV+GJZVMsKYkbBzg8fUdqEN6DcuxaMuAFAPI9+eO1U5JzczPAV2M 3G0jIYjrj8Kuqkk8hMhCKQRnOBn+vSmvbxfaoZACHQYyeNw9frQSNhimLMFkjAQDC7cbT/s+ 1IkLtdvPGI4sEZyOCehOO3ep5owYHk5JAwRnFQ2yrKilAAF+RSpznHODR0BFh50Qb5AiIHPy ycbsZHFNtHguZW8g/d65PTnFUdWjHlCEIPMfBLY4Ge4H86fY2l5p6ASxr+853Y+Yscd89P8A Gq5VYlMl1SKIShmKERg7h3GeD+Y/lUTNaW938yuAwDgY454/pTppEmjQyxJ5quULdyOx46dO 9LeRqZohJGWyOgHIA7/Sl5FItefvm2OGAZAxUdqjYGK5TkCJ125Gc460k7KZraQDAYMhJ9BS XMskc0YCq0YJPHXOM0tSSSRlVwhXDdOlTJLEuUCk4B3kjkHvz3rIutQWNTOkTeYMYJHb1x6Z z+NMjvJrws43DbyQy43ev4U9tQ3Lj3RhifZ+8SMcKOML6ZH86cgd5lcN9+PaVB49alhgHzI8 bBmXIfGFqb7CDF5R6hQNw4I9DSDQo2yXLSQ3Eildqg4Hf1z+tJOrNDdRAgMR+7wPvEc81bJM a7Q+ApGRj+dMYRq6zeYFVW+YZ5KniqQmVLSXywstwqLIBtOBx+NX9ySIVznA/h7nHaobiGJ/ 38W/ORuGeD+FQLFMsokjfCL0XHLd+aLahe5XtIRDevbAOYmUsBnIGD+hq+WNurAMDJjHI61H POyKshQjIPzKOQff+dNSR7gIpABdCX3dcZxx+n50aXES+dIYS0hIbGdw5p8V4HQSsB1Kg+2O tQG0zDG6TPlRtGTkPyc5x/nigiSaKIqgEisBhRwR70WEirfJhY7k/MOMrjqpq9EjTaciOCWV MDj19fyFJeypZ24eSMGOIcJnpx0zUsd6kkpYMMIoBAHU4o13BkNwssatHAcFl2gt0U/zqglt d3hmMgUFT0L8H2/KtOPJnl3Mpj3YBPX/APXTookLbEbnrgd/xp36IL2KSM+nmCDe3lk5JPpz /iKlvbxZIplgYbkIVww7HoferF7sbZEUXDA4z61UubYXN6t1DhS0W2RM8NjoD7ijRB5j40e3 gE6gthQrIvUc54/OnzyNNMsSxZBGN+MFKgXUVWAJyHHB98Hnj8KeHQlAsh3cMuMkYpB5kSN/ oEglb5i7DeOuATio7NGlRpcKAPQDOcdvbrU7xIQImLDLB8sMeox+uaSO0FlFlGynTHoPUf4U 76CNH7SihVyDu/hPP/6qyXuJnkYl8Q5wpx39KtzOomilUSO/dh06c0yCFblXhYAgSHGRgY6/ 1oENnZ0WNt43S5AOCB3qkmbdlVQZZnwTtPQd6vOkkRZCSSh3DP0/+t+lU7WMQFRJkOCx+Y88 +nt/9anbQVzShkwkoTIyA2G5xz/9aqU0ks8heO4MK9NoA/PpUvnGS1KxlRnDs+MYYYyDULxT O2fIWXj7zGgRx/8AZzGPE0pddv3BhUBA4O0YGR6471BFax2yg8AnIB9aLmdnmZEL7Rxlex9a WVY5SdshO3gDnP5V6DlLdnlD42DMQADzng5zSPAJJEOF2jIYAdv6c4qOIKvCoxJ4z0qyuUtg nV8ZzUt2CwkKxsSPKA2N1P8AOleATNvBKjG0nsfekQeZB5a5LDuD/OoQ04kKHcUBGGA70kMs IscahN2DnAHqaiuQsLBwMpu7n+VV7iRpXYr8uByTTQHnHmsQRGMYH+FHmwLNtN55BcFcZJUj r71NLu3bkBVT1OahH707yRleig/eqSJ2WPLhhkcZPShsCCJJo0w67mYn8OlPZpWiKfewMGlO SokbITJGf50h3hPkYbSNwb29KTGiK2xJIy72LoM7T0ANW7eMw7kU4U84xUUEeATGpLMo61Mi TAJt6gHA6ZpNgSMGKcYL+tRTIwi4OSOhJpwz94ghhx7A0loxYtFJkljlSR2pAVi8kJUlwecb R0AqVG3T5JPT14+lStGkc2WOQAeoqIEFiScY6AU73AJF8vy2XKqvWnhgYm5GR3pkpL4KleB1 aqyEzsSM5z+YxStdDLKBFmQ7cFhn5u+Klm2SKV5Qn3qCIlNpmzgHIB7+n86VT5krHJGOme1F hFGWDayAsc9/WrqyrBGIguQOpFLMq/LIoBKA9T1zUUc2yVCwAVxhh2zn/wDXRurAMU3DXIXg IPmGemP8akHmSxyrHmME43MMce1TTSBYSYwDIB8oHYVABLc4cnYvt3FC1AZI5jTbk8EbTnv6 UyG9Mk3lSJkHgjuKfceU1ww+cx5OwsOR6ZAyM02G2EUp3Nl2HDY6UaASrE4kBEh2AkfWpJmW NRGmTnqMVEqSBlb+AZHI6GpWjIYN37mpYEalQ2Oh7gHkVWuH8tGIIZj1Uj8KsCTzmZhgknBU jjIqvPEI2DRj5skEYzTQEtsqR42jtjPenSKgZcnceg9v84qvFch38ogrIOc9jUjHa7Jn73Of Wh3uOxAmY2cYJCn7x6j1qywZkLDJA7DvUKSBZM9VJKsO4NMubtQhjjzuPAKmnuDCVYFWURqF Y9R6+1IkgCqWAVQDwfSnIhIXcAJAD05AJo5ZlWRMg55oASJkJCq2N56twKXzUywTG4DNTPsV c43e2KquU8p5O554HINADFAj37lOT2JyKYHJyuNqjt60vm5TMgUYHI96j3RyMV3kP9OKpASE IrLkDB4AHrUbKkrlmBBHHXtTdzhyjLtAIxilaFicljuPUg0xEzvEq4JA7inI25CRyDzmqn2d sKWOQM8H0q1bMvl7OpUkVURSHIcHNaEXK4HWqOMdqsRPyKtMhk81q7RbuxqvsFttVz74rUju VFuA4HFZN6yyy9a3WxCbuadtcSMvyyGMDpg1HLcPKxQyA+/rVRLgJb7SMjsagG9myoOT6UM0 RYkV8+w6UguXRhyeKfEZV5JX/gVI80bNuYDPsKRRZXUptmN5xS/a3fADnmqTzwgEKlRG4O7I AFAXNmCIPMPMl4PcmtW100Xd+LWKVSxGevBrkjduepIpUv5lOUcgjkEUAdbqei3GnwxyyqTF ISFOQeR1FY0tnJLbs6R/LHyT7VS/tS/mjWJ7qVo1JKqzEgE+gqaLUplXyg+A4wc0IHboRzSJ H5YVQSR1qnNM6nBwPpU11Hu2BOoHaoPKdhgjn3oEQ+YSeSaUKzNxViOxY8swA+tWI7aANgzA HFAiK1gJb5yQK3InFvblOORxmksktEB/eF34wAOtTpZrNcozkjJ4XuPT+tROpGCuzSnSlN6I t6XZyMGy4jJAYEnn8q0VKvIY/LRJU4IPKke2PxqCaGCMxEyKXI4/Lv8ApVuCFPLWPcWKjDN0 LV5M5uTuevCCjGw2GC2jnCsI4nkGxQDyfx7U8W0ySLl2K9fXj3/CqSQWc1zEVjPyvnf0Nab3 CGMlGBbgAg9R3/KpZdyK4mDFAB5cYHzcdenT3AzU1qfNjfJYohyr5xv9P50Q2cN1A7kl1AJy G4zT2tIzj958y/NheAfYikxoJY5ZIC0E2GHQN6+9RXCW8saw3JOYjjJHXNF/mNUBO5WOG+bm ogyeYsJUMxGwhup75z3pIroLc2MjMHEjhY1GCHyS38j2qRr26az3B/KfJAYHnI9KbLFm1CQy sXHUE9qiula2sjIXyWkV2IPYd/0ppisJIgvWQwzM21AzMxIwe/8AIcU12mkcwyFX+zkMQM/K c461oR2y+SfL3qxxuP0qjakJNNDIu58Fl3fxD0qua5Ni7ZlyHMqH5l3KO3YcfrUkAEAmOQIg GYkdVOBj+v5VDbTNHAjxFvvZAPUjOTUjyiLzbgt+7bjH/wBapHYguZvOi80Yk28A9iKe1xcl 9q/cIDjPO0Z6+/8A9epLeS3CCUDahOBnnr7VK8ZN0JEfACcjrg+uKEglYgEKXNxvXguoJbOA T/jzUsoYiNVOeTh8/d47D+tVUe7NwGCBlzjPQH6c/wCcVdgmCSSyXIKAjCKBnn/OKBbEUgMk rRqHAUZV8fhnmq7zpbwlZVMhP3m29Pwq2lxJGinbuXd8+O3+f6025DyEOY96M3JxyB2NAIyr 65eOcxmNXt3UKjL6Y5/z7Vq2xt/s6iMgfLlFOM/lVBks7uA2yO0bIxJQnv04NXoLa3eBIzuI Xgg4B/GncWhPskPz4OQMAEHinieURksFP1HJqnNdJbPCibmDMYzzkgikJlkaVSflb5cDsCP5 0gGzTeZZzSSRBfL689fx9KoRx211I5mDK4YqATw3er8lq0kJhH+rdQWz1Vv/ANdRRW0Dxvau rH5s59CPSm9gTHtNLJ5cSDaX4VicA4+tRWEM0kxJn5DfOBzirMCjZsuFw6DaT/eHY+9MDeSr W8rLH5hJUZwTRuK7Ir6Rtp2rmPzD0OMjHIqS2QRBi0ZO0DYM/Nt/xqGMy/aVtJQjxyHBOO/J yc1pALGfLTLAnYM84H+FCB7FdVJRzD644OcehIp1siPGp8z95GSN3epLZUtpCrEjPcnhunP+ fWmoy24CAjO9sZ57/wD6qAZDdpFefIJA5wDjPr/n9afaKqWseYxvHLe5HGf0qjLblJPNUqZE JZdvcen+farilyEJwdxJC4wT9KbQrkd7bKYHmQ/vAOgbGT6fn0pkM8ccnmPJtCgA7h6nofTm rMm2OAo53hixx0yM9PwqukcbgSGPBZVVgwznFDEmXZokkJdZQWAwvPFRYjLRglskk5PTI61T ks4vmQlxjJVl649PwouILswEJKSmAScYOPalcLIdLYM14rFwy85B7j/JpREizIgjLKPnDA9K bbMGuXZ2cgRkkHIUH6dqWxjeGaSSb5hJxgcBaPMCO5nIiCkkndvVsfwjsahv52up0gt2THmd uvQ//Wqa5UO82FARY2jYds9v6VPbw28U6mPbuDBnA7HHP59ab0EVIoZYfMy0+VORhs4BH8qd HqG23XaAHzuIJxyOP6VakZxcgqh3lv8AWIcAYzwadt3zncQyOoPTp/kUNILlU3aXkRYyNG6v 8yH07fUUrBZfKlVi0SZOPU/5JqG7tokuXRpFQEZHsBSxyfZmt0kiXy5chsdmxn+VVqtCXYna 7trW1Kj5izbNo5IyM/lUZu5VO1IWKjoc4yKpXQhaJ5STvVxgDjAzzW2lxlFZUzuUN1A6j3od thNdTgZgsUm9A5B5yTkGoogHkL72QMMAnt1xVouBG0ZXKg4yRVVdtw4OSvAAAOOPeu5PQ8qx bEKfZkiDbD69TT7mFoYsheoxu61UBUXh6sPQVaU7pFizmPbnA7VL1GRomzBI2ydAacBLuAUA gdB2JqLz0jneNzkKcg4/KlaURQny2LgZ6HJPPWjUBghjWQnfyByh9T1p0EYYhAqhSMHHSm29 spXe0m52PX1P+NM+zS2zblkZj2HpT8gK72ixXJ/f8KRgVeYRSRnzDyOignp/nFQm2aKFflHm Ox3EryakuiIYgFAZu64/Wh6gM+SRgmCYx1GaS5CRxbAWUDkEdB7VLHE7xqdu0qfmGaS+BwY1 XOQcipe4yGK8GFDYJ9R0q3DN5oVs4PeswW0sYDcH2NXYcCONR97I5P602kBadvMIVTnjJFU5 JGSbaFznnB/nVzyMksABt7g1DsLyhieo69TUrQCna29xI/muW2Zzyau+WqEkg8DBz/hUoQRo QhIUg1EGyRlv6k027gV3VBHsDEMe/Qe1LEi2gJz95ugHrSXBZyABlAcHNRySOqsmCXP3RjpQ gIp5HaXES9+R0NXIIvKj8txkn71RKYoyAmRwQwJzn3qOOYRFjztB6HtQ+yAmlAEJTBDsccCq xtypKKfl6HdzVpLuBsnDZbnJ/wA81DKFdl2yHJPI6ZpRTQychUjWPYeoB59KrGOSR/vFAueB 3zVhyfJVpGGUAJ4qh5xlid5HwTnGOKaEWlQKhK5Zl4bFOdVQspJ37QwOeoqlZy+RcbnJKnrz noKvAx3MeBkLtI64OKUlYY0M5tMkEPnvUTyMfnYHdnAOamWQb9gyUA4OetBhjnGOhxjjpSAr iVXEYXhy+eKW481ZQsb7c849ajVxwojAUZX3BpLdJHdS+5mAzk+1Owhk8Es3zBlWQHnFVpFl iCGR93v3q+YpWuwVYAEZPPSpHt0kfJAPHTtmhOwyBJALUylcbjiqsURjf5l3HGck8VZuYlCK 7EDymzt7N7VXimEkhdwQpOBnp9Ka11QFuOXOVZNrfXrRLkjCnDAZ+lQhNrjJbco4qS4jlVPO Ugqp6AdKXUCq0lwBkqH96jlLNHlifXA7D0qaON5Z2WNyp7g9qfFasjNuO7dVbARGKKeMbS+e 5H9armJVdWQfN271qsqiECMYJGMDsaqwqC3K9OM0uYCMnzk+ZsOO3vRFOFgDlCTj1okYRTHd g7sflQGG1oxjKtjp260+gEVxJL94dCO/vUlqWBw/X19aagGcE5UHHP8ASpQygDB6nAppiexK T6U+I5NRfSnJw1aEF3quM1RnUg1bQlhinGJHdRJkDPatYNksZbxmWEArk9qlMUkXB4PtWxbe UIvkXGKrXbt5nyp1HOatjizIdcN8xJqFm6gdKtTI2ASBVchRnnNIoYOlBUnoKM5BwKTzD26U gE24bBp6hFNRsd3PemDJNAFzeBzgYpGlBGNnPrUIVm4GeasJAxxk4oGRGWTHy8UmZmIzmr0V mSQFRmNa9lo0tyAcbcdscmpnUjDdlwpynsjCjt3cZYnHpW3pmjQz5819rY45rTk02CyiWV9z qSOgBHXr+VSJbQzzkRMVjXnIXDY9fauOpiukTtp4RLWRINHggiUofmI64yaLRY2l8lmQ3H94 HJX+taMZKAKrFyvzZPce5rnJJHttS81ZEiZn3F8cqDXJrLVnWlbRGi9s32lEXGwHLKx7HqB7 GpJHCTjkrtYYyMh/UH+VMtbZry8a5YxleoJPIz/IdanvIkDLHtJx8pbscmjcd9Sjby+dqCW6 j92E3qG67sjv71dFq+IxFMThjtAwfmP/ANY1nRxzJdpEGDTlCir2PJK/1H41rWETQ2bNcJ+9 Y7iAOmO9KT6gTWmVs44dwjcOWfgYz/kVdDZ8uRhuR2yQuODjp+YqvE28+cyAnBBX1GP8n8Kh eKaZnSNTHCEDCRTyDSWoMcrmSMEuGZecbc81CNs8r5UYJG08/wCetVbNpLVw8gcqQfLcnkgj I570puVgu43TzTFKT8vTBPb8KTKVzRSPyxKtwu1CMeYO1U9Pd7iO6jMY8o5CucYyM4GKvG4S 8ZRyAp/eIRgnjqRS+Vbyq8ZVQFxlfY9D78ihaAxNPnj8ryycPGoVstwD0/HOKrXFssk5VZSj oRgqO56fSmSWqi9VVVkDLtcL0YY659elW4hAhKqAW2leScn8/wAKdtRXGaVbyCN/Ok3MT909 qsXojlgOyPodqk9CwpTEEZTGvblySO/P6msySRbac7STGVLtu6Zz/wDr60o73BlyKSDZLaOV 2owkXtkd/wAqntI0ilcq7NEwG1mIwMZ4/wA+lQ26JdTF1ADr99Dj5QRj9eP0qNrQxMZ2ZUhi UjYPX1piJjL5Fskr7gpbeMDkc1Ms0quxuADAfu8dPxqG4TeloYmXaCOc9vrWgkisuNwbcMMr DOaLgRQ/vYisJUuULDJ7A4/rVO+83yykMpEqtuwo+9jt/wDWp8qgTGPGwIgww/3qahkics+C SpUsO3p/KjoHUzp2ZXaSa3XLKux+6nPOf896tookWOVZAJVHzOnTB+7kf560l3btNblHJA24 yD94/wCFU2a4soohsONv7wP0xjpketNAzUWBZWXeAX7lemfU1LbWrq7Sthk+7t9cd81WtJji VUBZCAQAOQD/APrqWS6MZVI/mAGCCT81LS4tWrIadQgBZQv8XT1qRJ4ZAz7QQRlc5B//AFVV vvLWHzktwSx+bI5Un/OackUckSygEMFK4B6Gq0EW8x3MJXH73BOAeQP61UeFpTtuGG/BUHoG yOSPQ1cSJbYrIH+RVC8Z6elNu4QYgYpcYO7ewzjNLUNCpHBbvcIFlUbPvKeuBVpbiITeWqrt ztyvriq3lm53/ZiWI4Y54P0/KnvZwlN8gO1R8wPAx6/XmmD8yVrmKZSFO4r8rcfkaz70mEWv ks4G48nnI9/1qx5UYjk8jK7G2knqQORzQkImkQuzEJngr0NAitJauHXyiQxG9QOOfWrN3A0g iCcMrZ2k9Pyp5uMXUcmQY0XLnGMZ/wD1U2yuJH1KQYJiUZBxwemOe9LYPMsqeC2csox05wah QpGSrZU7sBj/ABZ/yakvJoYMyNJsHIyOmKpXEcxZTHKSuNwHr3A/T9aGtNBLzLMziN5iJMER jaO54qGK48xUiYkMvzEHrz/kUwQvchRJGpcDO4n7vtURt1jv5GAUhvnQHkZ6EUbg9NC8VmRy ytlG+8CPbn86p6gjlVa1ONoAeP1yAQasG8MigkbXzkgHp69abcW8kqC8tjsk2jd6YpoCO0gZ rZopT+8cct685P8AKp2hWG43gkqxz+n+A/Slc2kNq9w53Pt6EkjP0qvZ3hvViDhUkUnzUHfI PSkloJiXLxhSqyxpycevPI+uDSyJFKkZJyrMBlG6VVvbVIZY7hbcfJnJ559M/wD1qs21yqhE aNS27JHqcdR7VWwntcbeW9vbFSTgH1ySMVC8yOttuGd0gcLjjHQg/gT+VWr2SOeRIQcCXIL4 7dMZ9+KzJGjiuvnJJiUsRjBz3/Sn6C9TTe3ja3III3kAsecH6/nU32WJVVGy+wBQR2HpWHLq E3nLCV3QyD5jnoKdJNJbuUwzKeVJz0/rQlcGrGMDvXZu5Jy3bFQyWYBVh8m08kdxTiXZlblk YdccCormcSMsIb7p6Z4xxXYeULbIFO45PJGT6H/9X60RqwuciQYViWx3+tWEiZkdMYI45qLy WhUonzFyCT16UbAFyqyBhwG9hyPrTVUbBtUBc/Nnv9KmWNATx83dqGiVoyiuBgdT+ppXAqfI Z8pkKMfKfu/h71PEgnJdnK7Tggk4qOBPs6KcM+eOKnQLKrF2IAyCF7+lV6CG3IKRgqzNjoQa rwxl4nbfvJHU9qnLJE3Eiuh/hY8ioT87N5G0KOCM/jSuMSQyiICIsexPp71MT5sYLt82MDA6 GltbhvIKNFgAnqO9NiLb9rZVz2x3pPsMFVWZUK4IPfnmmsjC5hLHcCCfpjFSxnew4BYDlv71 OusIoCjLKM//AFqAJxKrIyjJ45Iqk8TAE7mAGCPrVm2Kgsrd+ORUL8rk7gAf++vSk07gLxIg HOTk/Sqsscqcpznqe9OleUJxI2QTnFMd5Y7UvuLMTgE0IdiJzM7+UB8p6jNSNHLFJvGGXAB9 RSwyhVwxGeMjHU4qx5gkV8Y24/M0xFWEhCxkIznqf0qFosT71G4HGRjvnp/KnzqiMz8HzFxg j7pHce/b8als5mc8/TnvR5jHyxRsyHaAPbtSLnesJX7vQkdcCnyxggMkg2g5IFBwZUdc8c9e lK+oDJiPNBKliBgjGfeoJrVJotyxlOp/+vV5QJHkbaTjjjoaRxtQAMTkY6Ur2EY0No4mK7wQ Opx1FXrbHzIVbaowCeKVYwEMW4JIT1Pf2p7YBCuwBVeh7027gJI4iQyELtA4qFZQ0bNkjeeA B07VFMZX/dyBcY6P6e9OSNo41d1+UcD6U7aDJTGkkKMSQemCaDIkSHG7aRk4FRQXKzpksN5P P1qyImkhOQM9CFPX2qWu4FNCbhG8o9G4Ld/apYnEUTbhjHQgdfakIYZHlbQpwoBpYxvcluFX 7vNMCs9wpJbBOTgKTxSXEbGHdtURvjPsfWpZYFJEm1iAwVgR2J6/rS3ytHEqgrIjAcd8+lAF ch3uEK4ZAMNipyzhcsdobjHtRbOx52YB46YpJcSPuYggZGDQ97APklQKfL5Zfbk5qFXmSEuj Aq3OGoRQnDhgobhhz+NL5iJb4ZGJPXjg0dBDfOddzEqFAOR2qFJZWlzuUqRkipHC4IHIYYwa bGihQVAA7n0PpTQyO5zKilsA8daIQTGGBGRwQammUSKAQDxjNQKvlSbd27PqetNbAPkQRxtI XG1eSMc1EpSZVZM5XnaKeZSpMTDPPUjinJHGoJiOMHBx60ASehFOz6UxWG0gnPNPXDCtTOxc th8m41cJBA+TkVHYqgxurv7HR9PmtkfyQdy9SaTqtbHTToXWpxi3QD524HpTnuUkGB1B4zWn 4w0yDS7WOe2G1mkCEexBP9K5Fb5mlCGNiTwCBVKvfcmVBJ2NC9gMkJde5rMe2kVd3UVqeTMV GcjIzjNQyu0CqXXg9KarQfUTozXQzQWXIxTSjEDA5qd9RVSVaEc85IqodSDuUQYOKrniTyMs JAx5bgVILdQN+4cdqqmdtnLVFHKWUkHJzjntUOsuiGqZsWtqLhiIjk9a2bHS4iS9wSEB4J43 etZGjHZOChAycHNdI7BCzSqsUcRBC54Pp9K5Ktebdlod9CjC12iuse65mSzONg2nPX3x+Iqe xuWadFZmaROEDNtwT3z64FWbFIy2EY/Od30BHaovsLTTE7lWNWxkjqfSuVu71OyySsi/dSyG 3Z8M6hur9cGqEVxKJ2UxgIy5HGePp+fH0qzbF0lkguH5cgR88N6j69KlNorJlR8vUA4X+dSG hThnL3ToJRCIum44DZ7fmKdcW1qVZnkO2Q/ez6Zx+lRj99NIbgcxPwrdxjjHr0P51Zt4ZLnf HIEMQwI1xj68dutVsIWwVbeV41kUBlBGepHGPwxTVvp7pZkSMJJHIVDsONuSQCP0qWOR3Dqt uBLFjKnjB/8A1VVjhnuWZJjtDEgqoxRdJak2uy89tG0G/wAoF4jxg80kN4IvMMzFmQ4HuPXP 51IFEMfkM5G0kbe+PSi4+xGTyXZCx4weMjrQncdrEEl75kwMS7dp5/2c8U7z/NDBVIzwOgye vBpYzbP+5jXOOGCjGO350vnWsdxHCkW0IMKB3zx0pXG0CXr7WinARoyGYHp+H+e1TXBRdO82 aPdGHAIUZIB6EVX1HTjeuqwybCVOQP0/HP8AKpDKz2clvcfLOwGFH8RwM/hkUgJLeW1LI43b yxCkryMDoT+IpbpDakz79yAhQo4+XIx+tQ20UNrDI5U7pEB2t/FjjPPvUHm/aJVjjwYkyJCB kYwOnvn+fvR5jsXhdGKVVkcbC2MEcYwTkfpUO2Se5kkVhgDhienoP/r0yK8jbdGI8svyqWGe 3+fzFSGSWxgZp5RJCPmAyAT7fz/OmtRbF6HBgZZZ92BjPsRWLdEv5ltGyfM+3zG7jpj+VQ2t 6rNEzAoD8rEr0Xp9OB/KtbyRk4VcyjcrgcBsf5/OlsPUYtvb20rw2zCLYg288nPA/pn6ilNw 8enLtO6TCja/Y5wetKIlvFCSOolQ/eA6EZpjsyho2QmbcPunHfOaaFuRWk6g7yNiK3zKMkHP +QauLcPLIVRxGTxGzfKD04+tV7RVMTqkeRk5crg/j+f6U1A08s8VwhkKFgrr0xjtz9aBFq0v 4LuJ9smSTwAOo4qwWSQAK6qyEfe9K520iW3nBUsh6goeH55z+FatutwC0kjYjDYHYr6fzoaA s3Vy0PESK7k44ztHvWZOLy8xE4KqRkj09fwq2J4422hw3zAnHQnuPrVxkcCSVMMsg6enFF9d A6Ffc9uIZUUsQ44Veo9KSK0m8wtKR1LBR3PpVi32qw5GGPUcjGP/ANdSxSxJNs84Fzyue5x2 oeq1BabEUqKZ0wf3bDawPXPb+tViy2twqiQbAPn4yD6f1GfakuXfa778AYcMOcEH0pnnRXMa fIV8xeW7DPYn1oEWI7gXMbIp/dnI4HOaDLK1tsgCtIo27WPvVVjPAkcUAQAvje4PoeKjmS8C yOzgOOQVTOaEOxZsra4trGRlVt27cQen+fep4Q89vF5qnDrl93p/jVS3fUDDGJdohcfMEG3B 9eOlWZHeHYiykgEgD2Ixn8KZJIIgAYw21SefpxgGmxQCC5ZIZPlbluc/jUKl5VDR/KqL87A8 /TFPt2FvNGHUlEO3dnnmmIpwxst9LCykoSQGboRnP/1quW9vIkDI7AKThVHAHtQ7AFsqzq/z Zxzmlld1RCpyA43Y9KOoMi1DTnurXaV3cYwelMhE/wBmUMpR0VVbceOAKnMk0Llnw6N36Y/z mp3kSW13Ke+D78Urh0KwSVovN2gDGMjqTiq8NssbMJPm35wM8IK1N/lRbSyhSMAdqz4zLHdO mN0ePvEdB2Ap7onqRzWasoC4wCPnI9uprQt5EO+3Jyxjwfes83Xn7ombHJXBbjNV3e6h1CBo yAuCrADv2/WiwM0ZLNVlBGDAVwynuax4bQi8cRyEMp4Azk88Yz2x/WuguCZYgQgWQcZ7GqCR CG5+UuP3Y4HOMen86Yrjysk8C+Y48xWH3uAfwoV1t9ztCVwvUdT+NYV9rN/JJ5ZjWPOQcLlg PerGk2uoyS+dNcySRP3YghqpxSFfuW4mMOwrHvXozKOcdv0pNQcP5VzLFHsLYcnqOcVc8yCK RYwWD5IODVTUWWVtixk7gCHB+XGaSuF0R3Zs5tkcckRbGQ49PT/61CeaiKkThlUYyRmrrwxC z+ZIpTtHVep/pWVayz28Rj+yMRuJGSeB+VS9kwWphvK8AWPnOcHPrTXs1dg5f5iPm46mmzsY 23ISWOMJUsD5TjqeuTnmu5XPKJFzGSVK7m7e1Is6M208Hn/69QqHFxtcDDH5QKmZY0kyBlm4 wP1/lRYBolVXwOmcjnGRUVw77x5aL0x1yDT5WWNApVSyjHvVbBjIAJUnks3INJDsWGkaQBVG Bn5iOMU2Ld5UiO5AJIBB5pmyRUyMZPJA7HPX6UM8bSBNzxnH3j34piIpLJHIO7PGeOlWLCFY kLY3E55PtT4GKrySV6kmkuGLAJFklueBQ5PYLALlWkMIwePyNOVDvYHBJ+dfao4Yo4ZlZ1Pm 45weBVh2RVSR1OwZHA5OfWpYyp5cio7ICSWBIqSBvNUq4w2OWaob6crGsaOCpHTOKkiRynzD BOMYPXjpTAk8tAoQy9CO/WmqXkAReGjOQDzmlUiMsdoLeh6UxW+QOBzu496QEhljaNhJAu4D GQcfhUMYDMDgqOtVLied7gOpDKhzg+vvToRMG77ujH0otpdgiaWFtysAGO4ZI7CmIpU7Qc4P OPSluGl8lvLY5XlvXHtRAvlxnBG4jbx2/GmnoBDcwM9uJlk+YfMBjGfapUXdb7oxgAgcjnOK JHOQhLDA4BPBqwkn7oIwXjnP9KVxkOdqqwGA/wB72OamKocyEhcDBHtQqRq7IGYluRntUMgZ HBLAKcAg9/WkwHxSypLtI2xUqXKO+xSDjjPrUsqCQKyEjkdO9UlKSX8ihVO1MinuImuSi/M0 THuTnpUNwZLhUVE2gnkt1x7VMyyMDnbz/L6/hUKuypjHA6E80kMhVZnLO7qT6AZ4q2bqMoUD LjFIhCrwAQByB1zTooYjGGMfztnr1FDYFKGzSBgjBmZjuzjpTy8Xlt5EgwM8+lX3mRSp43e9 UYwrlwqgHvjApXuA1cSBuSCBjJPWmLbqisA2cjKnPSlIWBGLgMB1JPOaekWJI2iXAZcnHQGq 06CIlm3xbWcl1IOCetRTttjEkTMzAj5ccVduc+WQiDcTziqqxhoSpBZVOSR3NCaASWcQxZcn cR90etVSJTmZTlMZI9PerSW6bY5XbIJO7PvUbuZXCoMDvxninfsMda3DToNqksoycDrSyI0c fmOwBPGQOQM1OqCNVEeFPfvmorriM5yxPYrSurgQSIZoBlzz0Y8ZqZVSNGA59c1WEMjLHlcx j14qxsD22xDtIHrzTYEc06x4yh2HqV5waWSH92WUg5w2OnNMdDHMWbdt747VLCpnRtvAPIJ7 UPTUER7BNGwLHfyMr0qFF+zoUkZQMdqsLbtGC5OHz26Gm+ShDNJ1bAyT3ouFiJQMkjIU4xmp UbHSpHQCIjqRzmo40ZvYVpCWhMlqX7aX5eT0rvvDWoA6XiR8BCRn2615qZDBGxGSR+VTm8ll sTHvYI3RR0rOW51U6vKtTqPGmtQ3tnBa2zrIRJvYqcgcEfnzWXo1lC1u00jAuOAPrWNuCJgH oOc9q6PS0iWICNAzAbh6gn/9dY1JWRtSfPO7NV7e3jigWJN8rHbnb0Hfj8qzdSto7iOWKMHd 0zjHOa040eMRvIS8yEBgv93n/wCtUWrO5uI5EIZN4V29z7VijqklY4W7UBf3n+sGQC1U1ZA2 7Z9TV/VY2a8dPlPXBqjHB+8w7ZJ5211weh581qSM2QNoyD0Bpigq+wkADk1ajiYNyuTkjPpS tEqsWxjPJPrRckuaSHin83b8gPOD07V1+oW1tPEGRyCWO1e3Y5/LFclplwi3L/vARgDb610v nyi5Rg0exlHynuvf+Vc9Randh3oS20PlxC2tWDfL95h2PPHsM/pWlbLhBEUwVx9T70+1QAvK H3EoEBH+e9RMku+N0wrjqjdKxZvcbdKzqiRQDekgbb6Y/oaWC2vDMWmYln48kH5WHf8AGpJp QCBG5ZyMNt7fjUN1eLBMZGkKuvRVHXt/WmtRMll07DDaCsQOdjfnxUsUscaZO8SKT90ZPt9f rT/MWWIlVHoeeMmqQb7PdhXlbJX7vUev9aQDXvJJ0MiAq3mKDu6kA85/OtCYKxyjtG3f1PtU E7o1szeXlmwuVOcjPBpl0ZI4SUwWY7ic884z/QU3uJIoxTzPdSx3JMgbgMF+YUl3YSG9Fysu 8qPnXODjHH8qsWyLDIJpPmmMW/7vQZxReTafE5mlnZZAgUKzY3jPHNEbvRFTklqMsJTKxBiY ypyWYcH6VoGyj8os2WLrubuR34/z2pbUWhY3FnL5isPxHfn/AOtUckgt3RSwaOQYPPA9KJRa dmJST1QxH+y3Qt32qrnnrgemT6nH51IkDr5iXAcxbvl3dj65rPv5ILy5iiWTEinHz9G/p7Vo tJLJp7RiPaQMPn19f60mrDJvM8yXEjDDIML1BPOcenb8qbBHHZKZUAbzOuBz27VVSOUJCwAc xk/PHyB1/ocfhVu0mRrWEBQSW7Dp/wDWqbjsJHLb7klwqDOA/Y56fqDTo7GOSZ2nJkc89eBn 2/Koo5oYPtBeMlfM3KuONrf4HIpX1BYWl/dkbQMLxk+n8qAsPvLcIEQYG/5RgZxkEcgdRz+V Rh7iBArpjJGVxkcDqp/zikilkmZfMXIPzKoNW3kSFgZHIK8AtzTvfQNgiHmqXTIYnp6dDUNw 2biMS7hGSACO5J4z7YpssywWo2yg5OWf29u1WokV4WRxnYc5bPI/OjYlvUrSPJFdHcVEZALY 7/54p1uf9JKFCEA4Gc9ef61YbymLGQ7ht5BPpmorS6iht2kjj37W+c4zgev/AOqm2BMtkkcS +YANuSDj1/8A1mnTbREzsRsxg47cVUluXmneNWBIGMjoeM9P61VuXu44lkkVGXOGIbnpxii2 oy6lgJbMIzDfy6nOQD9ajh82JhazSIN+Sp3c/wCeakjuXe1jc2ziT+6BwaRlia8DTRZLAqGH Y8Yx7c0heRGsVxZyOjyNJEU4GO/9cii+cvapLEoYhh9z0FXZ03LhSRjkbu/aq9psZ3iRskfw jjk+p9KoVxtijbGmlQbz1Gf8+1SrbxqTGq7d3zbc8fjViPFtHjPyY/I1nG+Ec/ktEwkbkkdj j/AUkgLg8n5h/EWzhuOelZ80RkE0kTSg4KMDx+n6UtwCVD3JXdE275Rw2cjj8aZb3LveBJEK B1UE9+eQf/107dguWYMRRbGbLMM5GcfTmopy0Rj8qPzHGXGe46kZ/lU4CjcwCnngDpx/n2qv dFlKq4xGfusW6N2oXmL0Ldo+5Ytse0fMZAe/bH65/Cs7VElWcCNiqthhu/vAnrVkXCi98sK3 OCGHTb1/lVrzFlQB0RnznB6jmnqhIqKjTNCki7jsOZBx69/wpv2eYuY0Iiy2WcD71XEicRN8 gjRfuFTn8Kr3ExDIFT5eSaQE6R7ISGdmABDKflz71WvJpPLjkhCqCNwB6H3NS6lI6aSbiNis sRB5HUdD7VVvJXlhimjZvLliyuOoJ6/rj9aqKQhyXH23K4KkDOMA5p1tuhcws5fA5JGRUFir Lb7zH32k9cd+a0mgtZmBaVhx0XvU9RsoN9lV2WYYYcll5xjp9at232dYvOWQMARgA5AqlPbX FquIpi6ucbmXO315qGWAQWvnWRLnBLLnHP8AjVW1JZqPceZcNGyqqkZ68kfT+tPlhjeIAHbJ g7CDWZbq4t3LBVyAQQMkjrz+lXJFSeBJdzY2hlcDpx1o3YgRFCCdmjeRG2tuGM/j+VUDppSc XUV3Kv7wZweOvoOtTO8jQzLtMrEExtjhjx/XNTIwuLdWMZDoOVBwAQe1FxWCWGNbiJmddwzv Ygj8qnMNuIiu5ATgbQeg9qniZJYwJz8wJwzDrVPVfs3lNHnMnBwAPXr+FCVxXEijKwSxkEoe A1RkXynEOxkHQsKs2uFjKeZxHgYGcfUVXlvJ42CxMhUDqUJyfwoSYPU5IKpVXb5mU4oePYqb FweciomcRbieASeR2+lPhmeRVc/MCSOetdp5YsqF0Eg/1oPBzmkZWGJhtdmByM/xelRXSBZE bOCeDk4py2xSRGI8w/eLH+goTCwqOsp6KWwBzUsuw2jRJGPk+6vf61FLEZCArKGXJAA6n3qI 3TSRbQPnJAIb19jS32GSo2VEmP4QPl7UrRqgMzk/cywI9qrbZ4wQ33WGMgg4zVtDlUjJycdO 3HbNOwiol3Gj5Tftbk7u1WkuUmO2NOBycmlDxZ3gRhc4OR0qKcq6ExKinIUgDHU+tLQZIjAs cEMR2J5xT3j8xW5LB+MHt6GoXiRZI179c/SpijxgOnK9PehrQCjPZ+XIjiTJ3AbSOMd81NLf JFI2VJI6Af0pwiE0PP3uoOcVXa2E9qCzDdIcq3p7UJgOuL0EF127mP5CoI1aUq7FjjOeehHo KthIkKh48MBxgVTuGkkuQqblTIB2/wA6a7IRoBYwgcEMzYORUUkwiRmI+cnpjpUlusce6GM5 YDlj3qCRlu43L5AXgMo6VFtSiSAeZEW5IbgmhYEi8wRuc7wck8YxyMfXHP19eKtlJM8eA5+6 cAjoc1OYpiGaRhnH3fX61T02ELcJ5iBgTweAKfb5aEeaoHzY5NNthMu2Modp/iFOkQBwMfOe h9KkYh3vNnbtwTx7Ut0iiNgTlevI5qOOX97sySO5/DrUrA7Buy4HUkcmgCha3bRKqNkxdBx3 qdI0N7OQAWKBjilkt1SSRNu1cBh9arWwc3zmXO0rtz0p7gXftMSuFXcxPoMiq73KmRVkDBWB xgf0q4sEQjCqu1SM4xzVO6iMg/dIGcNwfalpcCNlET8yFCQN5x0H+NTJMjgyAsyKPlI4z+FV ZDM7+VOdnGRt5rSitVWLa53lehAxmm7WAragqyW3nBjujIIWo41yhZ9xIPbipdnmwvE+AVXB A9e9KkZeB4mbAf5hg0n5AQlftCjeMhePmGCTRFI8AVCv3lyGHT/61SSR70BUn5CDTAd0aSnD ejD60APeBjbsiMVc9/X8ajt02xum3BYjn9KnWYOxOCq5HJpsiO0mUbavUn8aQIgaJocEYZUJ O096qSS28iOTlWyCU71pzx7oz859wO9ULlPIcvEgRsgEkZ700+4EsTFrYeUqh8Yx6Ux0yoEh bcOeKcrMpUJGNrcde/tRvRi0bsGI4weKGnuAwSEOACu3pg8VKgjySHBz0A61DJCvVW+7nApw VVt/MHGaAEchSI2kLhuq06OTylbIwAeg5zVNCJrzcox65q39m8wsSpDtnp0psBRcRu27+Ae1 RO4eQKACp5FNeNoYkRNpI+8SKkgjaKMO7rkjpihWQxp2rwAd3SliDHDOcAcYyKZIXlQkYUr9 04604OzRlGi4IwcdTSQx10oY7N33xjr0xUcSSJFlmzgcdu/FPMYZFO4ll6ZPI+tSMY2t9xHB 4/EUXGROqx9RkN1FdFprlYE8srlepPUVhqqyKMgAYwCaWC4aKUo2/BXqP6VElzKxrSnyu518 LSXDKkbsSo3OGHLDPajUXW1t3YfcOGHPesnTLlInaXJJxgAtyBVTWNRN5OEz+7HoelZcup1O qlEx7pmllLR/eBOW7D1qSOMrEHbBB/iqVtjBVz3ycGovMLsBCSEyQB61smcjuETkyMSDtAGK BIUwkygsTjI9D0qVy2xAFBbHPaq9wkhZWbC9wQcmmhFyxs1UrKMqAcHA5HBFdOVs2s92C7xA hGA+6T2B6c5rK0L9+Q/Yj7prov7KgjgyXIYA4APA/wDrVz1G7ndQ+EbYvKlrcyKpLRDywnJJ AAwf1zU/2W4n/wBdcMC3Ycn9KIp3jiDeWFQngqc5461HHdBl2qzYb5gQvOf85rPmub2YSWcs SosEjENk7j/Kqs0KxjzJVYoeOpPPJ5/z2FaNpJtD4+VWO7a4yOwxUN+4PlQlWWN2y4HBH+TQ g1vqLFeLPbNtXLjAC98YqACO8t2cFoipA6YOT3/OmTxJbPEEfy84YsT1B/8A11YnVra1ixGJ P4yMffbGfz700hNoS18lEYxsSFOHBH3SPT3q2jDz3RoySMAgc9s4qozyrsljTERX5hj5wc/e /DiiC4SF1Ut5kxOGC/rTaC5oIguMyRZAK7VOOo74qobSyu2Zb0qI4gNjN1JzyPerNpOsUCo6 sjglQAORj1qjqVncXsCFFywkyB04Oc/rik9BJJ6F941+yhLWPy48YVcYJqJDa3ZIHQDqG6Y9 /wA6nCSlG2qd4O3rWYbG5DbECqR94fXr/n61PXUpJWLa20EgIG1jkhGfkg+xH4VdjHkIsW87 zjAbntz9e/NYUUUsU5UIyOuRt/uggZP61at5bpUMsikyFNnPJBHbH4fjmqFY0YUEM88KONpI cLjocDNQ2sUfnb1DAs/yBv71UUvZ/wC2g7hlLYUr7Edf61oQFhve5cIV6N6kVDWpa2HzW8Ud u6yEjoSQffj+tV47eKa4D7TySQSSATnn+vFLczRXO5XYpCNoYHqDn/8AVV5Lm1AWEtjsD057 0CGzKkESupUKi4Unt/n+tRR7WkZEmEi5y6sckGpWkjkifaCw2/dboPWq2MXHnqMeYOp6H8ve mhMptYuDOIpGkQ5ITPQc/wAiavWTXBwCMKpIppJtb5lBAjk5HPT6/jVbUr+6trMhQyO7/wAI zxn/AOvVb6CLptzJGyvg72PA7df8aijsTaJuG5iwO5QeD+PrxTrAtHbrK+emCe2eOR+vFMYS xTiRGbaxIYA5wT3qbjS1sR+aqTysmF4yB0J6DirVwsLo2XMbMvXnA+vtUNpHBFYea675sFiG 7HuB+nFT23DCE7XxykmOo96F3Bi2Nw4tgkgXqVyGyDjHIx9RUsrqFLsuCBjcOeaqLFJBeuFR BGi8EHv3OPX/AAqaGNyo5CsVJcseMZqtCRllei4kYTDq3y5/iGOcGoljW2uZYI2bCRI5x/Fy Ov51Z8pIUVsAbG3hhz25/MVIjxvIJHiAeRipODnH+HFJbDZDbyvdK8e4KiHbGxHJ9arzW6xS pLIQzJ947uvHOPSrbJHaowjByeFDHrnnrTJUE8MhV1dACCB1yPWmtNxMqBRPLuw/lMowAMKv Gen5VIrw723IVkPAk6g8jp+dWrVIzCqMCFdehPPTH8qoTwi1lC5aRQNyEdMdwaQIsQwvDLJI 7YQjOB0P0p22O9hjScFlC5OTz7VBEzP5plK+VjZg5+XI4x/nvVmCB4N5dnxvwvTnjA/lRsD1 ZDMk6LDHvLMpyJcckDPX8/0qN52imRisZMmMluvHp/nvVq5Plx5bCE9CTnJ7VSEoaMFxuLPg nbkxsTg8UboLW3LcFzI4ZpQiKp+/nhqSFlFx5zu21/lCMKjWTfYo+wSbPk2rxkZ6j9KSe5UK qoACWBGOgHrVJaE6dC7dqjQuCSgZNjZ6AVWhkgit1UpuQYAwfun1/Gmuy3Noxc46rwc4I70k UaCxUSNggBC3pzwSO9HYQ+JgtuF3fuwxGe496lhdSGZcNs6H271RhtrgRN5n3g+dy8BvX8aW W7jghdYUZ3GfudFo3YWLEt0I185Y8IDgqPz/ACqFL+FpPKjUksehHXj/AAFMt4r2TT5QMRSO Plz6/wCFJExEEM0keHTOCRkjHOPr/hTvoIWa4ijtJygYKE4Po3+elQWdsVvQZA6hTwMn06/n UtlZCLTpZnUb5Ofw78VeuLmIrEkgcDnBU9Md6XoBFFB50aRl8/MV6kYI6fy/Wi1EyPM8rOFV yuGOc47j9f0pbJoikqAhyDkMDyw+tLMY1UxvJsZwcHvz7UbiuTKEE4eRmJPAX+Ee5qndQi9S WOBttwnDbh/KpoZVKqHcZfG044pghZLpWEgIUEkt/L8BTWgBY7pLMkxHaihQSeeP/r1EYDGT gEFvmb5iOenb6VIb1mgjcbl3HBJ4wKgW8lZQf3THuWcg00SczNHmANIMOOnFRQxGAZx8h+YZ PvTpZy8mAhBAOfpjrVUrIXi3E7M9D/Dn1rt8jyyxEEu1xN8rjp7VYRdsQ3OMdKhidI8RybQ3 f6f5/nToCvmkR5XK9SMgUgCGNHkIRi6Hqaa8KRu7A5Ck9aljdY+u2M9x6Uk6BlII3c544pAM jKy7cAZ7mh1Ylo42+c8ZPao0glglLICULDhmzt/yadPEZJVCygS9SB6Gj0AdKY45VU4ZSQpG M+tNmMDRjJCx5yDnHIqK1VgjO4K4bjIzn8Kn8vdMDnKY5BHU0WGGW2hmGQBwR6U6VmEfmM2F 4AGalkyq7AF255x2qC5RZgIzhPlJO3r14pAUGu5TcgJjGcDj+dWrRC0JUgFA5Kcdv85pYYET y843twTn9am8r7LcARnKv0Hv3p3WwMjnjZnZwpwFOO5p4XCsFTaSuN2c1KzM8oj2kIOSe5/w psu2FVAyFBwT7+tICjaownlIfkA4wO9XVTrwORg1VmEkAd40L7jnipbS8DsA42kEcetKzGyo 29L9SuOf4TwKvyKpXc5O1hjrxTIwj7i6neCcD0qCR98oRgVVD8wPQ090Ikub4WrrtGQOc/4U eY0gSQFg55IPpSvEgYb0yvTJPAFSFUkckjBAwMUugFSFZQ/nYBGcEHk47VpxvG3ylTnGelQJ sKum0FSSpx1pjI6svzklQMg9/ei99AGKN7vMQ2c8g9sccUrRQybpGQtkYxUJSWSR4S5RWBAJ HANSZlwqMyxtkcAcEUrWGTW83LW7qWUAEeoFNaNTxHwV/vGqayOly4jRtmcZbv71OjMUZznH 1zTaERKS/nbxkqeDnkEVL58xDbGQNjoTzUbqIkcMSUY5DAYP0qaJFMas20hs44wT7UAVWuoY mZ3ySx+fB74pPNUyhkf5ScDjGKLuIrIR8uepPvzUiRx3NuRu2HA59KE0UNWfdGWU48xeAw9+ P51HvdGKEKRgY9vWo/LcXcSM23AJDD+KrL7SvyqcLyGH4f8A1qH5CGMV8gOiHIbJyaCx8wRb tpOG/CpsLuxuDKvUY/X6U2KJS+9pBIW5Uml6jI55GSJtiZAHPr1qOSRpHzkgZIxjOTVqaMu+ FdAzY+XuR7VTn3ws8BiJAxhsinoJCxqTLn+HqR7+tSS28ckgMqNtC53dKSzk3rswGbBJPsOf 5VOUMijDZXGD60aoCB/LKKoPXpVSdBDMqnO3qAO9XpYWXkYYgHAxUU0KPcKWfLbQQe1CASK3 UR7kwvIwTU8Z8wGRTkbtvPTFMYLBAd5HHfHb1pIpYgrLkEB8+2aVroZNLhSFKjJbb0rKlLrd kOenQev0rV81GdXI3KoJxVO9UTskyAg9PpmiIxTNt+XZkcYPvUpj/jRMOBjJ6VXUPCPmAbjA PqO2avRg/ZipJ+7xTegFZYMyb3ZdxOAQf8+9S+QrB9wPzEk49Rx/KmuuQqlQMDlh1FSn92qE EurcZznHoalsLFJpFE+WQbBwvOMVI8UsyBkwgTnnv6fhUSQIZQJjh+eM8MKvGLegULgr0x0p vQdytFIY4huYbucke9Ruh8lWjbjOM565pbmORYgwYDB+bPrToVLDIjAj254NHS40QzQfZoEw cMzdf8asxIyRRtsUsWO4/pxSvH9qVAWZMDIz2NJMjosUMZG5QC3OPyqb30LElDvbsqxkEtgG oN7W+Nw3HbjZ3+oq1C63KAndGckD3welUWNw11JsQfK2M46VS7DR0WgxyKUZl4Y5x2HNdaYg dzozFyQOO1YPh+NgQJgSvUYroYZDJK5jUlRu4zgnHH9Ca5Z6yO6kmomfcF7nTXQgq6Z+YHHI qra3yrpckRkD7sNkHJAOM1q3EHnW3mjIlJw4HA9+KzEsbO2KHy1zIeA5z6/zqb2VmbJXLAuF uY0eJWIUgAr3wOn5GpL1BexI7ZEkYPAHX6im/ZWsGle32smcKP7nfBx1HNPjud0yKVUpIeM9 SfrRfsFiKTTmaeHDHy9owvXGOc/pVycCKEBFQYXJB9up5qKCyTe3+tA6KATjnrzVee1mgme5 VgiDJyWJYe3NFxWLUk0XkqA+5s9Yz2PWoGtbLMTs6idPm5OB+PvVeylbzmaLaUCgbSDx61ak khu1hRpN3nDciMvJHpn8DQFrEjS/Z1xGhkkJUuQPurkc+1Xjt+zptOV2k54z9aqmGS3cSrlg 4CspwePr+FWWAggwHVAT/EucmgRVOoRwktO3lswIVvb3+tLFItwnmZWQA/M2fr/9eoHsIpLj 5ycnEeB2OM/r7+lSQQxwrJDGiyfP84U4IPuOn5GjQCzK8KKZVJY8L07VFNsaISZIZeSRwGH+ elWJbdTlVJDuM5Udcf8A1qwL60FsmBJJI+7cEB5HOevp1oSTDXoaKXazsJUjWM4wzP1PYbfX pVsFBcoJT8oX5VPY980y3kF1HueDDeYQRx2PXFX/AC45A24gk85OM0nboVczrm7gN3FEIizu Mk46jj9eeDVKazWXGZGDQ8bgc9zgY/EVpvBGL4HjCKFUn/PpVUzGFQzdC56rg8UxIW22xwK8 IZ0jXDLnO4HHHvjFW57mAaXE8Z3CMAAnt9cfhUESrPCR8o+bhwOODn/P41KLSMQSR+WWDr8y 7uv/ANbNCBjmMIihkkbcztgKVIxxz9O/Wm37sIAiQeauAWQnlh6D36VYaEyW5jfh4wNuT09j 6iooY5GgZJ/lyMBSecH+f+fWlfURGqG5hVrZ8BBhYyuCp6Yb8apxefGHSaZ1YdMkY/DPStLz AlxshUl2Ubn6jP19arPbeSHeaQum4k4XIPf8PpQNDDHJd2yCIuqMw3HpkZ61oeSYLMYVdgXj b1B9cHmo0uUgSOErhMAq2eCMcGoVmEl2txuYoqk4Ix14xSuDRbhm84PIwH93J47Z/rUCggfL MUPOR3I5PerRmZ/kK7wx45xjn1qveBmgkQxKJBjYfXp096pCZAl1ESI57gFcccdfxqxIrqwR WGByOcfrWZFZpOYTJu3Dja/WrEZjv4SBchZouhBwy8YH1/8Ar0Ay2GExkiKklRuGeCKgtXSK a6Mo2hmyucAggdKciyxIz+cHKJ82QDnGfT2NVdSyLZ2VEljfazZ79Rn/AD6UAO1B3MipHhY/ lQkjG0nnt+FSzoHtwHcLGwJZh3HHNLbT27i/muFcjYfLixjLgAAD06dD17U2S4Wa3Cso8txh UPBINVy6cxN9bFa2MtxdzQz7DCoKqoOcAMDxRqE98GhFs+3aQWVwCHGeRn1FEUEKTzuzl2MZ bb645z+FWFSG5t1d32qwyp5AOf5GkhvcW6kSZBGzKzBjjHI9wfQ1F5cEsQJAIABbk/KetNhE NiZYy6o5bcobnPYH9auJbsuFZlaRuwHX2o20EyhYAr8xZmR1zuJ5K/5PWrzSwmI4CqDwrN/n rVW5eFbd3C7XhH3m6AZ5B/D+dJJAbxAvlDyuG4459R+lNITKrQrtjKuQrybWCtjaSSefyNat m+UlgkU7M4UP9BzUf2eGWNVcbpQc7/Wo5hPgRxON2eWK5OPcUtRE8jhVaGP5nVQTjoB6ms5o 5LRZTCiuJAGUZ4z7/rUjzz2r7mnifJ+Y4x/k1bUNLAZUAU9jnOf/AK1NOwNEMpa4shHG6qzA HIbv7fyqpbtJCwkLMUwVC4ww9D+tW00xoYmeTa4UFtm38ePQ0lvLvu3Yspjdc5x6dc03sTcm UvcKkcmNjoRkDGPb8aUARSurKWwhHIz/APrpZlAkZ96uoAIGc4xn/wDV+AqfMchO35hjg+v0 pO4aEFtDcQqx2wmNgGABwF/T8arTRKkMpKqXkOQQeQOnB/Opre/CSNFI/sT0x6VE0QjkcnkL 8pDds/8A1/5Uw66jgn2aGNiw2IOhH3aXKusrxtuEo2oy98YNV/3srTLNGXjx1zwef8/lVqBp VZXWBSNxCqT+v5UbCFaNGYgoAqIArH8jxVOOKFIkDRiY4+8ydPar1/IjwTxBMOeFC/54plpC be1SJvmZRg7uxpiOHmtysYZWPmA1DA4csZWO5+AR04FPEsk0ZiQ7W37m+lOhi8lQj5YH7vHI H+TXa9jy0RTloyrkq4JIy3b2NXhtMIZZFG4Dk9qikjE9sxywHJ69fWoI9yokcSknoVft9KXk Bc+TBOSSPvMfSo/NcglCeRkZqKJWQN82DnoTxSlmLKWYow+XkcHih+QDTOZZCXYqGB4z0pg3 s7GMsSB2qZYFAUHLM2eQOKueSpiAwFXqQvFIdyg8rxnEhJZlY8DgYBNOtnEieaCzFCM/TFS7 I32qsqAgfL608JHawgbOR37GgVxz4LB12kMMH3qtcFwDIo+crtx/n61JFKzsXyyIOcHHNSCU yQ+YSjKM8+lFrAZ9veDePPjO8D+H/Cr/ANpRwkkSK+M4YjlaazQPKnQyN7dqjkQxSb4huOCN voM020+gFpptyAqNpPGMcfhUM8Ra3AYb3ByCDSIDJhnfCnp6ipY2jIyRxnNQMIoZVhVHIORS RWoEowB144qwz7drDpgk49KZ9ojNw6QM5j/h8wBW/IEimk9xFfzI7bc82VbdwuM5zTXZJYdw baFbODyeKR4TO2HBLE9e3XNTPEqlgGISQYJxwKBkCBLiRQ2GGM8+1SQoFQiJgyEkcjoabKv2 e6EWBt2Ag/0FTQna20riMrwPekxoiVgsbIjMQp+Zs45qE3qkOUXew9DVuSNBu24+fhh6ms+J fIvxGIyRjn2oQi5JJHHGJjzkAgGo4xvAmfazg/Kc9qnfZKvllSV/WqgLqAojztypHuKVgLeW XdvwR/Sq6bI2YpyD/OomuJo4csjEhemOlJFcSvCjhPnHD5GM4FO3UCaZGktiCCpByMY5FOtb g/ZXVU3MpIHGfepQpmQIw4xyv4VDcTR2MW1E2swBAHfFAdAmgLsJNwCJgMo5NV5JljkiQoQp Pyv29MU+KX7TCrEMHfIIpyxq8IjYKXjbg+/HT8MUW7jFniWR1IbbtPX+7UwUGFVTBDDaW9u1 QS7SEz1Yc47mrEabYCgYZUYNJ7AL5MaKEH3SuGJPtVKSGAXIjiGecMM9PpUhWRZWAJyOmfSq 32kYDHakgJGKNegF+NAmOCCByRziqFwFnuCrvtye3Xj/APXVvexiDryTg49qhuFEUgmKjkgv 7fh+VGtwQv2YhNoIx6980ZYAKkf3QOamaZBOUbOCAQaVvlY8g49e9J3AqyPLJECIlV845PbN QSeYsuN2Nx49cY6VPNMrFiBwOM+/tUUMu7MT5LoOpHf1prYY+UCRQJAdg6g96ZNaxyyRSRcf LhhmrUa4PPU8/wCNVJDMjnbKgAPHy849KEAJEtrJl5OGGAT29Kd50W0l1PCg9MZoWI+WJHl3 yDGVPY0W8X2wsjRqzDKjH1ov3GldihY71lljJOB0xgf54qaRXRfKiG5sZOegrX0XR5EjIeLZ 6AnnHP8An8anmVbeQwQxKWXhwR0rKVTWyOmNB2Oda2KruaRn5PGKWV3t7cEgDJAxjpWtd6PK CPmPmA/wdDVaSGSAlZ1LZHHfmhTJlTaMdovNj2KmWJ+Yir+8JZbo3/eRiplTKeZHtCsM8jmq PkEArGGwr4kx71fNcz5GRRg3Vu3mZHzHn1zTEdreAYydpxj1rSEIVMbj9PWsy6bFx8r9OCo6 5pp3GostQ3MbDL4XPQE02a3aSVXjdQx4wec0i2S3CK7MQg+bAFVF3yXse12+QjGOuPWhW6Fq LL9jGyvIjdV5/PrR++kuykUIYNxWrDo8rzCUkBiAWOeAOef51qRaPEuGwwlHy/Kcf561k5I3 hTuyezsHW2tpd21lT5gOme/NTxmSMTO0LCTB2nPOBnoPrViMhYI7aQjgADd19PzqW4k8u0kC su4ZC8Hjt0rHrc6lorGVbXsv2Ry0qO28HB6k4zkfjVgtaywBXx8wQ7SOVPp/n1qoWmLx+dBG BuxvT09SKmco9ypdVZ0wd3QkD8KW5V+xYUiPJ25jJDFj06AZ+vFUpJBbzRqybp3f5APup9ff BzS3F0gjNo2XBfdxwcD09afBJaiB5lgMzhhtZj74OPpxTtZahe5rW06pCrOwLEDvkE1DdIl5 DKkkm3BDLg8kDnFMMaInmJHmTO5Qei8D/D9TTYnMjTMibbkYzvPA9v8APrUlFa3t1M5KKxRg OM/7OSP5flUrWMT3ERkkyhJdVByE9h+NOEJaYSOzQMrDkHvnkfmQfxpJ7l2ukKRqzIShwccn px+FAbs0FG+2lhAKooB4GAAPT/PeqO9pI2jXdLhtqOBjg/4cj8Kla3mlk8yd/lPIhU9R0xn8 etOtUMEZdyzxoPkAXnHenfsKyFSxkjEju7OyqpUnsR6nuOKguBbtI0qOI5uCx7E5PU/UVqbz LbsscmUlUgeo9f51RSKKeNDLuVRGNzHgZPWlcLGda3k4eWG5wEycs3Y9wParywRhHugN0mzg Z6gdqr3NqgBmnicwoVK4XJPOMAVbsoY51IiZgjjcp9OnHv8A/XpO71K0LkEfmWwZwEYDdz3y KRSACQSF6Dj73Gcj8/0pi7rWWRWYOj84Y5/T0xmmtLcSQ3PlxlTjMWeNwHUCn5E26lRriNbt UYfMoLH5snH+PtRK0WqxGMNtZeUU9R71Ug0tpGSYM0Q4LdcsT9auCzhSR7lWIdDwo4IPpj3F PToBNaxrZwFeSxOOufzqD7c3ngmJgEzn6VaDuy4YhflAwCcjI9az7iCbewaQBGbP4/5NIC3L qCSybWIR9uHYkjH+c9frVpJXWYrIjmNFHznociqgtra/t2jkULLgAE4z9DTt/wBjs7dJ5tzo QjY/QZP4VRJaLKqNInQclfU+1Vba5a8SWBkI3MV3j+vvWebiY3EkJZ0MikA+n+IqdnW1Ac7k PoeQTnoPrSt0DbUutc2wtY47kpkfLtIyRjoPyxTL608+0HlSCNFw4zwpz6+lJZ+TdpulQrlt rhuob0IokRpJ/ILBlB4IGd3B46+lG2oblLTHuftMqqdqkZG45GOmV9ewrRRmu4yFldCDtLFh ng9Dx9KYioGSLy+EHysvGPqPWq5YpdIqyE4XLDHBJOOf5flR5gywY40uI1mnhLOfkByCT3xz 7VHDasLm5xAY2+5gDHQdf1pbjSlvJhccMrrkE8Y/Drn/AAqS2ae3EsUsjMiAbRktjNO4WVri ic2zNuQP5uAxReB6mn/aoXRgu3bjGOoNRy3ULQyBMfKenTdTLZV8t3uNg38quf8APPakDFRF kieNWK5yACOW9D/KmSWKXVnGu5hJG2M9CD1/+tUd9cSRmCSADauGJxkkdB/X/Iou7yeIlfJD AgE885z0qiRi3JdNscQCF9km44Oe/wCY/nRcfZ2EcILl0dQ0QPbPB6dBzzTrlFcxNEjqkxyz 5P4fX61M0D2yNL/rU4xnqMZ70bMd7mVe2rXjTT27seMADqpHPSrbXEkMts84DH5HABz6Z/Wn xIJpZbmKV/8AbUjg/hUzQec8cqsHUA7QDTumJ6aMHAkmkypEbrgE9x706CKWMeW4ICjaPcZ6 fypjT/Z3x5oyOSG6N64P9KWK6heb5GbKjnihk2EdvLvI181ozzjI4OBmpmn3jcpSQHnKGq07 s0nCbnBG3I7Hj/Co4LF1fneqk8gHqeKNhlqeOC8tQ3kBmPBLNjBqu0UsEMEazZb+JTnp0OPa tKaPyIsqCoxj8ay5UaSUSs2TGoBB7Z9zQiWPa5kSVYnkLEkAEcf5NZ8UXkSOJJZAUAIK8Ekn Jx+tXXSCaSFXLK/G1l7kVHqMz27bPs3nRqAd/Qj6H14P500w9C21laiNXX5pE+ZJGOefcd6L aSXyVabGXxhQcBcdRUemmOVgqTEbVzhqkvLgW0piEW4DBT3P+eaSdxNFK502a8k8xJcLjIB4 H4Go0ubrb5Mkfm4DLy2G4BNW8ObbegbdglAPTtmrypHI/lsQZFAG49cECna7DmINk6wB4HAX ksjjOc+/bvVOAiKFHxLGA5Vju6Ht+fStKKRRDI0bZVeOD1qit+bSYQSw/LuO1hjBHP60W01J IdMnNzdTFpWZkJyhHX0Iq0vmFBubn/awcVFLEbK4e8VQg7FuN/qP608pbXSrK4KsRypJGKdt Quce8TLOJYRvXOWGKWUyf61VI3dieBVtdkiOpO3ByVFNaMzIEXAVeldjZ5JRadlJyQuTwAOp 70PLI00UwUCMcDPermEA3EBcHDd6G8uRMI4BPr2o5gGFYHD7yfn4DYPHtTTb5JCEg45zTmAV Rh+cZpiyh1LkPv8Au9eCaBjhI6qEkwH6qAOTUhnCQFQpaQ44xVco6yBi5Lr69x7U62USTSAf dY5/D/Gjcdh7Rq4V/LVd3PToajeWU7uwBztarMUZSMLIdxOMEdKZcgkAYGSwBHoKQheERMx8 Sdj/ADqHaVlkKfdIO5e3epWOQN2MD0pGZDHsViAeMikxoy2lNs4YP+8bgZGce9XoIXicy72f HQepqcQIEXcN8v8ACD0X3qco+xl3DOe1NsCtcSbF3N8oYHGe9R20rCNIcByzdeuPc1LcwK9u qyLgjgc9Kjt22MI9xZuccYzSQFlIl82Rt/QAYpkgESb15ZePQ4qKO6JdlaMqTymO9FzJKU8z 5crwR1o1uBLLJE3ykqMHv6VFsMUixHezFSOoxTx5caBpGGe5Ixn6VEWEkskkbFW2YXPbNOwE wEkkvmum04xhjnGKlVkLbkyxQHKg/wA6oQz+ZEZo3eSQkrgjpz/9anWyNvDH5VJyT3aiwiaV gk+8KAWxx3FSEGaQbdwz97PFV7hlwsjPjbk4xyR6VYSdfOVkBBxlvf2qUUSpB5C45K8nk5NQ u+1QrRuRzywwakluNxOGAfoox1ouptzLxgg8UXEVoneOCQsQ+84RQMY4xjmnFSrMi4wuMHpT xIsl2isMYU4FR3UiRSpIwDID0H86V2BJHOUdVLoSemetRXNsLhQSCXB4PSs7LtsWNsysgP8A u5HWtRX8y1CiQFlxlh61TTArRhGwqH7vGMf1qZo40tgWXheOKe8cXmDbwwGDx1qJojKPLIdQ 3Jwe+aTYIIyrbCg5Axg1MEALsM5I/p/+uoLNBC3UnkgndnOMc/zFXJAzwfIATjLVMvIZDgjE pYfNzj2qhNF5r7I0Qsx+Zifu/h+ArQSJGgG8MSOQv9KrpD5cjSfdOMDHfNJaMB8ETBgS+5gm 0jHGfWmXLIIGYDL4IAXv/wDWqO5ufsseEyDKSc9e1V45XeMyrGqnptJ/rVLuIJDlfn+VovmO 081OSDHgZ+deDn/PNNE8LxrKqOrbtpyOQe/4UihN20EEBtwB6c9abGRCVZDH8vzE4OR09atz xeZGXUjOOw61Wutq30aRvwAQSo4xVl2EGQW49M0mMgM6m3Ktww64NZk00x3NncoAPtirmzfP vTABORinSrts2VUDc7SCOAKadgsPS3Y28exvmJ6/Wun0XR1szG8jfPOSeByP8BWNpFuZTGZS VRDjk111hafZ13q7OVGAXPJFY1JdDsw9P7TJnJjmLBD5YPTPI/zzUCW0k7TSN5bEkFDjoP8A GnzTpbPMd+5WXoBwMj/IqC8eSK1hlgONwBkz1ABGc/iP1rFq51li7V2hUhB5vOF7A8c1QuLW WYLHtGWYKZAOV4BwffmrM/8Ap9rGyggsARn69Prjj86sJPDAWBOHkOWz14GP6UaoVkznLmzN sjwkZkAAUY9On4UjxRNFlogrNjeAec/1rpJoftbNJt3PGOMfexXPvALu9VGXy2RhjPBPempX H7JMqy2XzFIULuTggtjbx60Wvh2Nl8yRQsucHJya3jDLHdMhwRKgcPtx06g0ljhLh5Ebc2Th f8/55pqRPs0jDv7MxYhhj3YPzEVd07R1eUTSwDn5VBwK1zYr5zufmRssWJ5zUUd05vXjZdsU agqo5I/2feldlKKWwx3k0uIMVV0YABQSTj3NJFqDSQBgmGcYUMcZ+n0qXUApKyRj5F+YnOfY VRFlGzKIp28yMFyoHrU3KsjaKG6iXccNgHrnHvTbm3keFY45CBj5nx1qW2UW9rvkPzyYJBPT joKzptQmF2Y1BVYwQ2RwPc+3SlZt3HcksjGLmZVY7YsAE9z/AJFKwQ3uGRdkvAOO9V9OuBcy SWzRAsnMjK3ygknH16VoeWskuRykZwpxnJ7kU7Bcy3t0a+ikU5+bDRZxtwDn8OBV3TLOOOe7 jYZEhV0B6AkDI/MCq95MYb2B1TLM3lSDpgHOG/pTbW+kS/CMRt6BuxHr+mKGtATNpdisIym7 jO3vUNyhFvLNEqmQnOBx+FK9wySkKikYyD/e6f8A16o37z3WY7UgB1BfPGBSSQ9SSRt6xR55 UAtjt6n6ZqaxS2UysBtYtyCSQvANVUWSOBY1QjAwZGPJ7n+QP4VAZHtYhHJIpkYneQeee/64 odtho2FmDB3zjGdme/8A9aq9tfyTxuoAD7sZ67R64/OpJmVbRIlZVlRMKW/i9qrR2xtInK8g kFiw6DJJ/wA+9FguW7WWJ7/yVMgIUZ7KSRVq5S3WFVmZcknOT0+tUllVp8ICGlj37x1XBGOK et1CywvIU8xMqWI/EfyqWUi0YBOm1JJNgwck4/KqssMkCJHboFTuSOnI6VcWWK4jGyRXc/Nj p+n406V1dEUplt3cfdNC01BvoZdm0f21WleWVsYDMoUA4HA/z3q5IzRowyQT90n36d6r6jAo wxJUBwfbH/6zVe/gu74xPbzdsFMcZySD9KpEsvtDshJ37iCQGB/T9KgltljtGQjzGIGS5/rT dOtp7Ztkkg5fcw684wP6VM9w09xsiDBMfLKACNwPSpe+40VbCeS4DhtvfDYzjFMuiJotkTfN knHXcRyaW+uVhtDBAPJdz8xUYwaWDTpLVHXzV84kENjpjtTBlqJ1RRISecfLjJPue5NWmgV1 ztDDbkZGccf4VSNuhOAWEnTr0PXrTLEXUAeNl/dpMyopOTsPIyfx/IU90TazJ4oITcM0gLYH yseTzyf1qO8tYbxTDknGOvXFWTA7MQRj6elJFbzxzFjKAnI564/yKTYJGcsjrO1vMisM4Lg9 +1SXMbG+EW0QBl3IwYjJ4z7d6sZjE2+VRIDjay44IPT+RqRlW4Ro5c7sZBxzzxTQMq290sQW CdHXH8RwQw9QadJLCl3s2/M+PnxxnqB9eBVa3neJmgu8lEOQ/t6j8MipUURWE29NzIdmG5DD sfbg5oEXJ5pIodqKWdyQuPTv/OqEljKUll80szDgKPTt+tSsJ7R9oJlhClhk8qR2z370sd5L 9iafytwYDAH1/wDr00+gvMjt7S2ktDDO/wC8Cg5PUA9MVKbRY7Ux+btQd0/kKSKyF1M8jHaZ 1AIXqtSyIke5Q2Yh8vXoR3/lQgZVg+zQgcttBIzJyc+lFu5kuphKjBWIIz2qa3tShkMwUsxy DmmiUzRzxMpAUDDHgnHXFCBjNhWOSMTI0SOSpH8PsPbtVKXWJ4YpI5kYAISFIzuHIz/n2qa0 CSZjkPmSuCy5GCV9f15+hqaKNJ5Y2Usm8YYByQCMjGPyqtncm4lpEkVs2x+UAJ2c8eo/SoYi 90rSRqfLWTJUDBBPpjtxVi7RrGQMRmN12mQfw/WoZy9ngqR5EuCWx0PfFIY825ZbiFvMbcfl Zk6cdPyqYWwSAsEA+bBA+v8AhSyX+y1WWJ1kyNo5wSfemxX8jSIrxKqsOSe9K2txXbQ+SOYQ FbfBkz0ft7VTm1Ce20l/NVjcZClug+oq5dXkFvchJpyrNyB2x70uopHcWThSCHXcpH86tbol 7Bbaxd6jpdt58PmKjFGucYGTjCsOnbqPWq6w4W5QbGk5EijOARz9e1c5aajcRW0dv5jCASeY 64HDdMjjJre0zX9O0/VfNvWMsMsbq6ou5s5BDY6ZyOPYmt1yyspbmPM0vdZZjPkuIZlVplGR z7daoSm5a5D8De23k4H+7V7UL5NTuIL63h2qy4EffHPGfxNVY7Oa5jAJAkXoT0Ye/vWUoqLs nc0Urq7I7W9L3IiVecc8fp0/zirzzxzmHIwG5z6Ed/51WjjSxuAHjYNxxnOMnr9KsTShZA0a EpH8xAHORztFT1GQj91pjI4ZpFJVCBg7f/ripIryJhl4GVwMsV54FTRvHcg4JLAnAI5HqP5U /wAqMSclQw4xjmjUWgy3a3X7jlQ+T8w55pt8IwpkjxIE5xnnFKbMnMn3k44DdKimUW8BGRJO VGARjJqrE9Rk0i3EaeYMoV288gVnTaIzvlJCBjGC3pV4xFbQPHAysRuMeTkHPOfy/SqwtriL OLxgX+Yj3P41Ow1qc0WRk85vllI4IPP401Z7pSzBmZQRzjrn2qdbQDJDMW65I6Cn24YM28Lt HbuR6123PKJFJQM8jAuVHy9fxqpJDHNIFjYh2OMHv7fpVmeMGYSI2Ny4OD/n1pCkKTL3kYjG OcGl1AjMDKmwviRhhc1ASIpF852LEgNgcGrlwZHZPu4B5PemPbtIQdgyOd39KcQLEUKyhWIP QYx3qOSJesX3l4wByfXinGb7Iu1QTkAUsAAnaQEHpwKXUAVG3sxzhuMDpUUsojYgIvmE9TnG KJbmUyPu37c/IewqHK7UklLY3ZA55oSGOdzJEzEYU8AjtigRIEEauBjPap1xIiF8hG+bj1NL KUOVTqB245pO4AkMsFqzrl5CCVJ/lSRzylBvUCRhk8c05WLRxoWYDr+FNjZluCCvDjC+wFPq Ia5LnaQOnI9OKB5XGSOBjjrT5ixaN0JGQc+nWo0VpbrY6H5eeOlJDHRxRmbcDgdQBxzUCyI5 cgbQOpNT3LNAnK56fN2qrHFsVslWBI46Y4oWuoAqiIFYo94Pdu9SxRIqeWV7DLgc1Ikga0Eg C9OAP8asK0cyNI67cAYz70XArTQRqjAfKePucE9v6VAxb5EEWyMNwM89/wAqsyRhiOpAOOO3 qakhQK4LfMvY9cUkwKb2jSrv+XcDxn+tSg7FCRrg4GcDgGnmPyPmLsQSc57f5/xpxZI2QBSQ /Gccf/WouBnZklndBKPNU/LxwatmLapVmAf1bvTkskZ8rwEYsOenPanTqSm91HDdT1z0obuB FAPOlVi2SoI3CmSWiXFq8bMQpbg+lOErRhRwpwc59RSRP5o2gnGdwx3/AM5pa7jIJoREUH8R fnA7D/8AVRnyZ+BtLLnA43c/4VJLDJdS/wC6MZ6c5p4tvKkDzMGdRnJ6AH600+4FeG+nuZCU QKnQ5GcVci2RM/mNlym76CiNoNjSwoc5ycDGfcVVb97eqMZBz1HFD10AuPGGURx5G8cEdhUM DeSsrbixwMn0GP8A9dOUuIVlQqWjPYcGowGcHewUnIwPU0gGT3cke3KMAw4YdKsW8olQluCP lxnIqIxYh2S43AYBB61RtUnSd9g2RDggnrRZAWWUSAGX7wUgKP4TVVHkiRiYMfNsZc+nU1KL oLKYiMvkkZ7c9qtQtvDF1G49R6GjYCtHJFcSnblWA+ZDxTk2M7YULt7+tULpkivJA25VYjHF WbaTeRGzgqwzyPmptXV0NDb944riNlQ42jktnnPb0GMcc/4Tb4rlfMYD7uMmqN9sS5DRtngY Gen0oVnjYfONrEbuOuRTtoFhIVLZLs23PHPJq/vAKrJxzjPrTUW3WNUK7Tng+tS2yi6kWNR8 wbipkVHVl5ne1t0IjJGclgOpHaukt9RUQIAu4CMMWJ4Axz/Oq2mmNrVo0CsyMAytRb2UpYhm Xep+TGRjvg+vP8q5m77npwjZWKt21zczeZEuyNwpZV5YDHT0FTn/AEeHY8oMJU445J68H+lW RC1nDLuBCs4IUnkt/nHFPt7ZzItxIg86KTcqnkeoOKTa2LHWMoNt5W3DYGGbj3HWpWiUODEq yHblt5/nVa8AmulRiyyN853EnJ6/nyamhDeX5eXGQVJz0OOopBbqX7WNk+fCrJ0JQnBPas1/ s8+plWhO5BuMg4x2x/8AWrWtzm2yMbfQ+tUJrQhjPF8kvViRnd+VLTYAkuIMqQ6tEVI3DnH+ f6VRdZbWZpYVBcLlSf4iO35f0qK3mNvB/pRXy0fZnGM89PyrQcJcRokLLjp5gPI9KrUBVuZG SJBwGHLdcn0P5VUkXzJ3kRg21vmXrnnjpSx3DL5uUKGMYG4fe96radI1nfzSIh8mddx3D+ID gfzqX6jWho3AWWDIBdJFQ7Rxjk5PFQ2Sot1O0pClWG0dD0/Wore8ee3QbNsoVt24cg5/wJp3 kSXMrP8AKspUDLDAJHekykujLhlSSfyyvyJ827HGDUF/p/mzLI0pQJzgdximtb3UMbMUBI6Y P8qtXMUa2jF+ZYxhOck8kgfrj8Ke5OxlWkTWV9IYRgOf9YBnjsDW0pWVPKXhvY9+uarwqskW 5W+cnDYGfbIqYL5DMW4B+63qB7frQncGrFCWTzRJAqs00alw45BI5A/T9Ka0TXK/adnlEA7s rgH0x+FTWMsk4lCReVIi4JI6noPfsaneRlBjG3LDld34E/QdabGnZiWsLRp5Zy8h67udv0FM SynhLoJCqFyQSPnGeec+9J9oRb0RRAFtpJfcOCOoqYXSTtIQ/mSR5zGDwR/U/wCFJAyCB41u 1twzNg539CO3FLJYyRsXALocsI26g9sf4dOai8qO8n/eRlQNpXb6YyDV+4EsKxyROTgbBGee D3FF7AROY7mCNJwBM2Tk9cAilnZpYhaliGbIJA49/wClV2mmiWTz2czK2QVUHI//AFfypjXE zyIzqBGcHcSM+/H50WGXLa1PmC4ZiCYBGB24zj+dQXUSx20V0MLOjDcR0I6HP86EihmiQPcb QDwAcDbnIH61NDMm+S2XY7OCdvJGPfPWpaGiOIPBdFiXETMBsLAqCf5c4rRV5GMm4KE2b956 jvVWZIzCjBUcMcAqemO386UbI9PnjZGVUcrkEnvjj8+lGvQLrqSeS7MYmfeqqrMxPJx0Pv0p bOVQxfgIM/d7jrkUqy/uC5ciQBWYg4wMj+lNuWFoHljUtuJ6DjH9P85pNlInlVGEdzyxU5Ug 8Zzjp34NRrC0aMDux2A4H4+9JbXW9QEcLHJlhkfeJ9PSiW7i80I6sF2HgAkj347Umg2KGo2d 1NfxiMDYwUMR0/GtJYsTSXLxFnY52g8A9MAUtq2SZycJJgj5uMgetTNDMUkVTt7gYyCetG4N kFozTTyg7uG6HqBUlxsjd9zbS2BuJ4PXqfypYzthfzBgxsfnPcdc5qkZ1una1JAGCQSPQ8H+ VC11DQljvWigDynay5zleDxz/KmfbkmQr1LsFwDnP+f61TeKWOZIbyXcNpACk9cfep1jCbaT aGKlskMy8Aen61SaSE1clihiKSTKvyDJ2dB+FTLnam+VSxPGCBwD2qFrcx3XnRSDy2OHCk4B +lOtngaVAYdmzkse2cf40m+grdS1PCZSpVFKdCrcZ75pkgDRt8+Nw+bjpj/OKsTyQrHGDJlG YAMD61ArLPLKjDC44I/lT1EQIu5t8u/ai+ZjPTP8/wD69S+d5QhWOMupJBPQjFNmMkdwZA4z sEZDDg46Y/M055fNaLkoyqNue59PrTQmPhnkceYDGrHBw7bQpz6mobxPMWRMoHb0PB+n5VLD dxyzlfK3DPl59Tgk8f1rPQ+RHJKUd0dsJt6j/OKrZEj715rSWIkgoE6AdOemfSmatIYtP81J VDsu1CWz+P8An1pkLTMwSdvMULnB69Og7H6UmoeTLbxFLcnyzj5hjAIxj37UluMmh2u1vKF2 sUJTnjOOR+tSl4w8cqqAzHJxxzjp9KjtJpBDskjz5Zw5U5HQYI/MUTxhwTEW3AbinemthNa6 lee/aWcQDb+8YgKTkHttNPkYTWf2dUCxKuxVzncw7Z/Cov7OmkbzEA+ZieF46Y4pBZyRQmOR yxiKvlT3zx1p3DQkgsoYLRQwJdcptB+U+hI9ajaeK4jCx/M5AZkzyv41eg8kqGmYna24+3Hf 86esXnbvs7DY5OWI5FJMTMO+tZy8YkdGUcFs8oDz/ke1XtLVyj2zNlV4U9ie4/KrqxMJpI7h Udm4B29QMn86RoleUSRHEgGdo6HH9abYk+hn3GkR24u5hkfJlc9PQ1S0bRVvDJcXHzovyAe/ H+fxrXb7RcW0qshCnjqfn9al0+SNFFmhUyhcnb6evvVN6GThqV5I/s/Ctgp9xVH4f408MAyN IpAwoPOPfH60oaZrhyVB7oCMFR/n+dKT+9gkkYMincVA6nn/AD+FTsU0KkySSM8S9FDIW52k kZ4+lTvLErjLqOm7FNjgilBWM/TjnjsaGjKFo5I96HdkdDjt+I5oArSXQZ1lhlK5lETYGc5/ +tVvdI7yOCpAbChRySD3pklhCEWOKUqvEikdcqev5Uy1aKJFncPlgSM/WnqImErsSm6NeclT 1PfrUIgSa5WZkYbOCScfhTb2USOk8YYlT8wxgEdxmnxtHLHvV/lJxnGQPSmIsRRYuHRm3Ky5 69PpWRfWUv2pvLyR7t3rSXzI4jK7gkAg4XtnrVK+vrqOVBCw2MgYEnrnNNJSCLaehzCyTR7U jO9epJOdtPZcsJI2AY8Ee3eiUAJshXIbtn8aqqtzGm0RjZnPo2K6zy7izxGQbFJ+vqaspA4h ZSNr7cll6jHqait4Xx5ju2OwPWrjSoFILFT6jrRfoDIYySvy4IC8h/WpMvHD8pB2jLA+tKvz OR97jqOOKjmQmTGB5YOcDv8A5FK4BBtnm3bvTn1p85V3KRnaBwaga2aEbo3A3Ajcf8/5xUjx AQFG/wBYfQ8GnoBWEyltq7lC/dY881JLmRIn2htpwV6darfaZI4sBeScgfSru/fbpgBQBk+/ FD01QCXH7qAlufRe9PaQLany/nfHPGKrMhkKtIcKORjrmi2zHDk4J5DA+lIZPIZWEeDtYEZ3 elJM+4ARyfM3cD+dEipIiyGQqqnhh1/z1pkcJhuFdeS33u2fekBbgKlWU5b5d1BjKKxXk447 VF8jOCp6EDg98025eYYw+Rg9jSvdhYryvJJldpJAAce9EsK7Akqldw2k+tX4isttujT5yeff 3prRljiRdxPUfhVX11EZlhcNH5loUAjGdj9sEVayscyJndGQe/GP8kVCtsTM7DhgCFDDjp+t WISkkHlT8svH0pys9QRJky4AXG3kn1qnPdSBikQKEZwSavGQpbssY3MBnOODWbHGZ5JUkISQ 4OCODUx31G2XRItxiOMEqvVic81YOFAUHKjnNVo2yJIwmzA7dTTo2kj3DO/npSe4ECXDR3bL kgZ6E8mm3qyLJFJGxOTggnipCxuJiufuAHnjJp6oUfDBsYBwRkGi47FcTRzSICH37uQeox6/ pVwRhcFMDAOPQ1SuYg0/mwfLOBjPUY9DU0JeT5TmMAfcI/OloA+2uN92IyoA7H6dqLsLOdhG VOctnpUJLpIrJGzbD82eKjnu/KuGSUnYVyOKNwtqIkZtmjgD7izEgDsKnJWOYKGAjC88dRSj ZLAvA5XKt71BFGzSsGbDc4HtxR6ghFmRcoG+U/LsB4HWnzMkcQJBwDkYFV57NlYtv5LE4A/z iiNZZzJFKwDIuVI7fWjTcBLq4aRNqLkjqO47/wCFKtypQEsA+ANuMHrUawmFSUIZgecDrST2 6zSoxXGOTT02GSPFG9w0hUH3PXPrVmPaqFBj5e9VROrI0KrnnGTyQaWVjCokkPtkUrdAGXkc zY2KrZ9az5ImQZGfOTnGc5rTN1HNKWUkqFDLx1BqnNskdpY92R1HofWqV0BBDDhN8zkOTlRj kU67JYp5fJPPHapEZm+chWOOQTimySIHG375HA9KOoyAiRrhd4f5cE4PAP8AkV0mkxrxMwOT 0XvWWIgeT1bHyjufWumsbfybOJ2wWB5x6VnVlob0I3kW5pHsYSLVQZJGz05BI61LZyMsnl7m Ziep7cdP5/lVuG4S4tY9qZdgSD6YOD+oqOS1DK/mbg3VmP8ADXLex6KJbg7gpDcgZOfUY5xS TBoZPtKbm+YfLnjHT+tJFI7wxbWDucZYDBHOM/TpU9wVihbzPud8/wANMRnSXZY5MY3rwSOf xFSWNyZJHhYleSFBOenXH51VdA9zH5Y3IGyxz1z1/wD1Vek09Z9TF1LE4WFQyt+Gc0bAacSB YSDIrYY4IPB96ge7jjbYzgNtyMnilXYYncuO+e3FUrghnXaMFWLs56DjgfqaLCTI9Uto5rOX y9vQYJ7HP3sVXWZYklEzGMrjLx8bu/PqKsxXVtlLRJ/ML/KAATj6kfSmtZK1+qu25RkbM9Cf 85/Oldp2KsTzRPdJGj4VSu4ydBkDgEUyQSRsoeIFVAztPXt+PSnu8gDSFiFCkIBwD6ZqJQsY EZZSVwo3nOD/AE+tG472B1VrlZkjc4X0zj2+tNh1RFjJ+9k4xjrjqfaoo9Qj+3gGJh8/zN/t c9vTmrcdrCtyQ8Q8r77A/wCelOwr9y2H+0wiSPHqOe3rWRcny7tzPK4hJAJU52nsf1rVm2pM GTCBQFHNQFbeZpl8tW2sucjqeeaExWFurkW2Cqg5x8w7jtVJNRdpcTKrKe4HSq89y8LtHNHl tpB4wAPY1AxIdS33WPDL3H+NJ+RcYq2prfYmjneVCHLocZP05/n+dIIbtXilkXczHJA42+9P gnV7Y5JKAjkd+fan6hvUpcJNhAeU67hQiWVL0QIyoVKg4eNzwM9fyqN4baO4F1FIkeANyb+/ r71ryWtnqNtBEVJKZKkdOcZ/DpVe50aCN/lxkj05/wA5oT6D0J7OFIJGZ5GLsuMHjpk/41Xg CppcYlkYtIMRrnD4ycY/SnrdobyVRHISihkyOD6inX+nbzbyrkGIgKMdueKLK+orsqGKd5BI u0EsBhzuB546VDFIzTPJJbIhD/MCTjr2PvzU5uWt4FaSMlS3Tdgj/wCtnGParTyzurSbduTg qevTg/pQ0UpFaeQbw8kCgn7pAzn8PamGV1dTIERScF8YJHfH4UrxyMI5Aru3GT2HOeB26VcF krbJZzk5BDMeQcYpBcZKwlt22HaIyGVQMEL0/wAKggaV5ZNpZiSrAE9/WrgtIbdl2yFsqFO4 +/T+lSvbbVIj2gKOoOCQOgp6iuhqkqMyfO8vXb068cVcaSKJDITkbfunpWVFdWyNl3IY8gE/ pUt46TW7KHzuXzFOeQAOpx6f1pWHcnt4I5oCjMBuzlV4Ue9EY8jdM8bF4/l6cEE9fzosGlCR tGsZU8kHJyvXjmrDq1zuKnbtzjIyDkdD7UrIdynaNBAZZY5CUJJMangNz/PNXI5LkDOP3S4w M8gf/Wqr/Zf2W73wYZH5/AckH8uK0UMgDYT5MZwetS73KTVjO1CO4umVR9wqQQv5HNMhikjm WMSbioyWcZ69qnsbWaK9eZ3LB2J57/5/pVhpo1uR5bfvCcYA6/j+FO4GU6yQl0uS0YDALLs3 YHYY/KrBtAC0kbq0ZGMDOD/QVoTNvieKeMEvnO3kfSqySiKDcgOX+YYGR+dMnUq27TRW7RfZ yXxjbjGR25q/9ljlGWUBAvA6dPT0qC3lS4zOCQyna6qO+M/5+tSyTOsKMse6Nzw57CkDKl6U ZSpjYhEBGOOM9fyoSTyl4Us5yACep9M9+/5Gr/lJOhbYTmNk/P8AyKr2caJZokjLIF/eAgen /wCqgLkTrO9qGaQbSAcsPu9+KYtpPdndKQsZxhf7pz/nn2qe7ZZoJI4m3E9O+auKdkCEr1B4 9DQr7CfcxL+0KqZoSUaFvm28HJ4/Acj86II72aJvmU9cKMck1oXMLXdyELFABuJ202Gbe7wq WBiba/GAT61VyQjSNoHEyAbPlZQc4x/Wobq082RGeUhW4ABHv1q6ir8yu/zMMlfXFZJST7XP HvYwnIUH+Hp09uKFa2oa30Hx3dzECvkBIx/y1mPb6dT9apfaZItQEjKslsTt3oPuH196vWtl cNpyyo4dMkeW47e1SLZtEsIWEZcASIDkY/GqvpoJWJLUCKZYRJ8jjKBScceh/Kq8ttNO11gs FOzbnjkZzWhLGY44o4kQDdwvYjBxVeKa4YAuNmM5QD9R+tCWhNyGySeMvG5RQxBGfYf/AK6v 4REA3gydSR3qm140RUmIMuSu44znAqr5dzfu4lJUYO0g457UtkPcvTv5lswGGmXgDPvjP6/r UFjFIkasQyqGwQP4gD2qWO2is7eNJMsG6v3Ge+aLi4S3VWbJG7ble1Friv0JN4ZlkXaE5J9/ r/OoY7FFv2uNpyv3F6YOOSP8+lQiFJi0YZlRwWUjgDHX9c/nUpEoiWVXJMYyMdx2+lWQK0cf 2lSd2GGMbiD1oa2ZvN2KTjDDPXIPai1kjuLXcE2urE/N1Bzz+FP1K+FjaOyIzyKvYcjikk29 AbHRR5jEgyrKArjuMe1SNI64aXoBg4FRQWs6M5uJAzlFZcHlfWopGyGRc+fsDEH+XvTQtB0y RttZmbKnKgfljA7c1I8B/s+OGFvLZFwrE/oahhlWeIwhh56qzbvx6f0xToci0LrkKeMMOnrV XtqSRMqtpkfmkrxmTcfzqDTlDTeZCu2DoFIxyB39+1XrpVmWOAgCJgQSB+ODSHKQNBAuGXof WlugGzXAlgGGC+YhUg468dadsCoi/u+FHYVnwxTyF1ON4UfeGRkc9qhlinumEifKMAEYB5po djm2uzHAihecjDA9fepxeREk4HykbVHqe1RNZqRtRyRuyFzjp/8Aqp0dsjthk28fertdjyiW CQvN90FvTPAFK0UbylhtGTgknvSOfsqAKMu4xux0/wAimrkCPYAzj5iM9qmwwXzIp1JOAR0z xTLpizmNTkAckdBnjFPEjs2DGODg5OcVcaH/AEUHCjcRu9D/AJNK1guZ85lRYmZGWLkBj0Yj GQPfkfnU9qVuQWTCr3LdetQTQIQwKkHsT2p8USRImcdcHHc+tPSwEYgkb7zLgkjgc08WsruR kIoDFQT1xz1/zmr5Ixk8gdSOc+n9aZJJtCj5eBhRSuBnrM7SE+WG9yOnpxRLbiYgqMtjLDd1 Oen8qnlhLxuAQMjJCnFMuoQkKBfvSnDAfn/OmmDAYtZWR4/k5ZW64qyZEMeSpyB09BUZAQpE FycDljnnHSpYkBRi+Bx1zwaGrgisqN9o3KpCY49zU86sVUlgCORn+VOu9xCRRDlmHA4475qt MvmTqm4hhhs9uO3+fWoWrGTRTBQSoww42+lTFw0vzkZxgYqi8rJIxhxuc4bI4pqyO8sag7WQ kMeufX+VO1xFgCRXUNtAHDMelOypyrZUnjpzn1qSPZImCcMckZ+lM4eUAsGAORgfdpWGSKSj Ks2QrDGRVO+jRWjw+ST97vx2qYsx+VgNgGDzkn6VRKCZTLErEqcEE00hFpQHgLFctjipFQtC 5Od5HenIcYTIwRk9+Kbkxk5bIzx71LGVH8p3C7AD09DU8pjghGxTkjpnk0TJG4JAIcg55/Sk S4jdfnxjAbLCjcZBbv8AKV4DE8nPSp55BC29cMCMEVXR4YWd4o2btn0zUr4ZlU+hYAdB6UwI jKTcR5OQ2cY6DvSXcbM8bBNy4+Yk8Dio45NlxseMqnPJGcH2p3nRkTRoSUX73PeiwBcApAET HzYxzwKhnZhBA7OS2eSO9S24OxSVJU/dyRkVZ2hUyVBAGOeeKV3cZRhmIZgrk5bnPb/61OKE 2zo8h8yUjJHBx2pjygvuwAqn7yjGT70z7UbkH5R8jZU9OM1VriY90lgQscEn5UA65qNrhlQB 1LEkBWHQ+pNWguW81mHA7+nrRmOQMyKMAYA+lK4zPab7M+2NQfM6t6mmx3E0pWF4ySp4/Co7 oO0nCgKvr1z7VNazTMOgDAZBx1HvVdAFCNGxCfKd2cdsd6jMc0oZmUxhjhvU/wCFEiTMqguS M5J/WkE7SPKjZCnG30+lIYvnRjbFzgfLketTvGNpJjDEGqjwPHOQoO1jkKR+lXT+4kBf7jHr 6GkwQ+1svNlj2OxK8gA111hY7LWT7XNITIMYz0FcxaP5Db4RyTnPoa6vTNt7DEXbc6feYnA+ v1rCo2d2Hhpc0LWK3gAWI/Ko4yeaWC+hecqpDfLg7v5U5/KCZ8ocYw46/wD16x3iWG/zDGRj bgrjkk8k/wAvzrM6TSk3RndASqiTmMY6Yo1CdWiBTcjyAbQADkf4dqdbZadZMq3y/Ls/kamu 1iO8OhJ6EDque4pXtuIzIYo1825dGDp95QflHfP0NWjqtvGircOuf4FHpVZxMbeeHyx86kYH SQYPIPrmskRpC4VYCTERu3DJB7gmmrXGaEjfar2P5cRLkZPGfbP5Ut7eQ2UMi+X5hmBJ3n5c 0qSi6t0R4ijqwOAfz/TNPYQS3ZjnXKONp9DS1QaGdZWs3lwyJIqbsskQBA68Z/LOfetKHz7i VluPLj6ZC8kkHP8An61eURxSImVUkkKcdfx/ComYF2cnAC429xjvQ7gmV7q8X7SkO3K5G8em O9DQRNemRm2ncBjGc8f/AF/0rNEpuZMow3t13jPP+cVZUyfaUTGTIRjPJDAY/rQhtWJnj+23 CxNEY5Y+Q4GO5Gf0q1K5JKbyGiX5mx1qOzu1d5UkZslv3bbevJ7j3pEfdFMk2FuGz8gOR9fp /KnYVxyOJ0MLLgqVAHQ89D+vX3qyiGGDdhQC2MHtx6/h1qlAkzXXmcYCAK3UH8fbmtV4Q8LL uYblIODxzU+YPsYV7IJbza6/u2BAIGelVbYGSZbdUdysgUMnIAx3/WtO5hwY43c7c7iyd26D P5CiKRbKd/NjUOwPzxrnOB1I/wAKTepadloXLbT0ii2ocbgc5/z61BNpjBAhmMkO8N845X1x +NTR3AlcMznZkbcHr1oe7BBaPLDBHTABHUfz/KqSJuVhEHVobe5VdrfeVSCCD0PPtUyHyFeU O8wKgMOvTPTn3p9rH5rvKyKDvzleQ3/1+KguldbghRlWO7aOueAPp3pLcB8N2kxaLyikoU89 uv8A+qpZNREgk2ZzH/D0LD1qppyv9qVHYCIoxUKvXGM/yNaC2ypLiQ5iOAvqMZ7/AOelJjdi GZVCo8gf72zZ1B5yCfw/pUIzbwJ5pOwnaz9ecnAPetMLEWm5Dg4YZ6ZHXn14pjSK0bK0akdc jpkdqEK5kR6idPupbWUvPbToHSQH7vcEfmQR6H6Vel1KK7VIUgEUHQvvJzx+GKVRBI8cLRCT PMZUfL/+uiRIi8SBCueVGOD/AJ5rVTsrWM3G73IcKbxLI/d2kB+ck4z/AC71baxZgrJIyqTl uOW4xzVe5jmFxDLChJTpn0/zkU+cXDhth2Ecr83XjpzWd9S7aEk+nwyRCQquBklh6UKLdbcC Ng6kbeD0/CmWmoSBXS43MA20HH86txx4AG/eSM5ODn8qnqPYQnyrUGMhdiYXjIAqP7TNlQ8i qrME2joGPSmWs4ninjkAV1bGw9vQ0/yYZAY3+YkDAXgg+v8AKjoO+pdgiKy7vN3Dk+pznpUc d2k025vkDfxHvUiF1tSolHH8X9aqnYqiSMmQL1PX8aLDuWTbpHchxna4+YbsgHPWqzOZLlYw QpB6+tSxXKCEyu27eT82Og9DiqFxdRi4CQKHL4wV5XrjJ/KnYVyc2krThpWDo+VZjxxnj8f/ AK1QsZI2VVLHacNnOfqPzH51c+1SxshRGZWPylj1/L8vwqGS8F1ezJF8r4x5nUFhxj+VK10U pWFtDFDdckRGWPDRgYBPY/XrVmeWOC2WB2+9nLA8r6GoY/m25UYUcsV4B7EenJqO6tZcP5My RkDLMw3bhj9KcdCXZsnERUKyOSjEcAUsaBZiZMhW6KoqOK4MEAkZ9ydScdB3IqOa5a5t3MUe 10bCnuy4yT+lJIGyysSxybgQvXAzVG6vEE0rq/zQxHABwT06Z/zxSRmWV0kwXTYS/oh9f0/z mhIxcyB4lTafkG7nI7/oaa0C5bSX/R22uRJjqe/UcfrVeO7t4IZC8iZZjlcdDj/61WCsUAkV 8hNvTHf69efSoAmmO7IyZYDLY9+w96aXcTaYtpO08TSI24EfK2Oh9/8AGqqxzE3CpgSiPKsf 7x/+tVqC4ijQqluUhHBk9Pc1YSQKzMPLbOGxnGQOlJA2VdMkeCKOJzuBTdIG42nOf8/SpZFk mvQ0LFUAAznhu9Sxsp3rKoYNzwMZ+tJbfuXkb5irZ2huo9P600SLKjEgNnI5ypwAaXCJIN7A ydD6EEUXkyx2hZk3Mw+UAE8/SqtvEZoBLKGWQHkZ4P8AnP8AnFVsTuV7bzbW3lNwd8TfOTU9 nPHdSluQBgYHb0qaYxRW6xM28FsDAyOcVmm5ktdzNaqfLkAyDgbccZ/z6UIGacUokhmEikHG MkfUD+QqtPLGZ1VXw6PuIPQjGMnj0NXRdJPbq3BQnO7t71QhjS2nlkmJVpWCgZyAPWmTuWym XicMML8rKOQ3qfyppgNpK0qkGADDDuPQ/wCfSs6e+kaRlWMNGhA47dvyrQt5TNbSwyHczkYI PY44H60baBYykObkTwlvJYjKn6cirMim4u8qj7j97HHHrUrIJXksiuxF+Qv3PAwaltiIJ3E0 fBxg9e1PYTdyOS6e3eKFsNK7EYDDcMckflViQJcx/IhWQDIbj5ufX14FMfT7E3G+NMzAEjJ4 BNQxW/lSrvYx7CcBOQT/AIU79UJ2Fht4Udt5USYzjuPf/PrSWtq8czr56sshwyHOeajmtsBp Gdi7v94dh/8AqqXT4lMbSTPgHhccc++algT3m+1j8wIGCgFvU/SqbstwEureQqqDJXoMdDmp ivmpsYnYW2g9xz0/rTVaO2JiQgRgsoB7c8qaq6tYVjG8pX1GQRyMu8lhsPY8j8ulacCTxR7A u4DuSQamhlt/7QdU2mQ4bJ6981MbqDJDMqEcYJpOLb3ByOOMKhllZm+Undn070PCDu2nkYK8 +tSodjADo3cDoKAP30ag7VHBB6n0rsfY8tEcrBLdyF3lRhgR3qkgnYmQKq5+6AMc1ruwLHYB lSdw7H2qmxkldjAoPGTn+lO9gGwxPGqsWy2fmwKsjawKNtKkYI7/AEpYpSMb12s3cetRmJRP lmO0HPPHNAEksMIiURoVbjA61XJZI2YYDc/K/pTv3sjltxSMEAc9f/rU6RVVFyee9TYCO3eQ Ju+9t6rkHNNl8+J2lTLxsPu+lSQjdDlTgnn3qXKfNEcBsZH1ovcZXRhJGQqkZ+XPr/8Aqqpc yAvEoUq6fLn1p3muqK6khI2UgDt2P6Gpbh3E6LICSDgArxTW4E2I2YBeoHLU9JsSrGVIzwc9 qR4gql4XIYgdR+lQS7pBuUfMo/A0uoFt+NxQEt3561UkeNcuUCSE4JP8VS28h8oBoyGGcj/C mThWKggYJHX1PpSsMYkGXUBcH73PaoJ0dCzxnY+7J+mauRlw2S3Pb1qG68142OOMjtTWjAc0 u4oB8jIcFgKmiVRxlstzwKiiPCg4IPXI5H1pvzG6jO7bGo5zU+QErskSnPUdOD09P50yGNYo ijoAwAzj+lOuhuMOzjBJyemaqpcFX3OQST909gD1ppXAlCFJ2wc54HP58fhSfZvJuVlILoOd uOAaEj8uZ5d+Rz06/SpkaWUFRIOAB8w/Ki4Edx80yFF4XO454HGaroIC7IfmGTg5pbuOSKzk hjmG7PJJxVKKRFAAwceg600BcVowcQphQMtxwCKeZU3upOMAZPpSQ8OzonbBUdKqhBOkijeW c/Nx0qdBlh51MmwKATypqN4olc7ggLDnjmq8duy4wctGTjn34p0UU5lXd95Rhcmiy6ATBVgB VssrD5R60+NJEURSKzRsPlx1A9KlkR5SgTHXn8KYlwwhk82TIHAwOQetTe5SRn3cTxqNgJcE cdRj/Go1ZUiVQmNwBxj3q9bn7QrOytgdMHtSTJviIx9T7eop3toNorgyxFv41I6DtTWuTGhj RDlTggCmpLIJH2ElVIGPSi3klmuXZiMrgEY61RNiQHdBIzBQQMCoEYxeWWYCPPPqP/rU942n uMHKoDkgDg80JbxwzDI+U5II7+1K9gH/AL2VWwjIg7k4oNuilWbBbuamclIx5f3cdCagkdyd hQHjqR1qdRkpnQZbOQOlQszTAlhuA6CoZT5ZQZVNzAe2Ku2O+RkRYtwJwfY9qbslcqMbuxsW GluLRdgzj5w3cHtWjpdosUokkk8uVs/Krfeznt7VZtoJo7fy2IUnrjnAFV5CAHlIxPE25TnI Yc/L/KuZy1PTpq0bGuiP5QHUDv1PNRyJbrN8w+fB5PBFRWl1LdhWUbQqgMvUcjP581anRJIB JKUKg4II5P8AnmlYZkS3M1vdsv2mQmTBUL0IHqBx61qWU7XTkudzJjaex/yP6+lZ9pZpOHTq pHyZ6qe/4dOtW47prIrbDYZj1XPAx7073Bl5hEkexjtzyuT09aybe8gjgaGYbnDsfl53d+P8 KtXSSSJ5iIHZvvAdvpVZLKKOISS/JMvyne35EVC31H0K5likmWRgY2CgqARzkdP1/Wo3Qwh5 JUC5iAxuPJLKPzzg/hV+FknSB0XL7TlsdADj/GodXH+gSSbTwVAx/FyOT+VNPWwEOkX7XYmh uYw8SMEEh6gkd/b396u3v7iJp4UL715U98VR0W3lGnSunlszStld2CQOOPY4q7NJJM8O5THh iGBI/WqYupW06xSdZJC43rJ1zge4q08QimUlQ4XOSeq56fWlsrYLHMSzKxbe23jJxSTIbiJJ Sw8zG0Bahdxt6kkCIquFTe23BDce/wCdQybElZyAZkTcpP8Adx0J+lWQ21lCsPNXh8ds/wCR VS4gLO8AOW2nDZ7ZP6/4U7CuFiZJPmcgSKuVX1HqadJNO4JUfOvIA9+P60mnQxKkgkdd+dod T0x61aYMkjRup28kc9O54/KjqMalsDIssjDecdD/ADp7TJMZY0Ch1JUgjnrg1RRpZw0ZKsu4 Nt7MPrUn2ZdOWSRELu5IG48r3B9+/wCdFkK4eVJ5ErIwjLNuK5zkg9vSr8caywksmwv1A65r OtpBdMUiUqmcHaOnuT+IqxOZEtVlR/3iZXf+nNDDcguXa1sY/LlMciyFc44bLE4/I0thzJEz D95klyxPXuPxBpNv2+JJiwZkk2k44Pvj6U23uWjuJrKeLnklh0I9vw5/Cm9gTLLRPDqBljdi EJLRj0bPIqcmZ5QJwscEo2qCed3/ANeoXaTyo5I5QQmFfy/4vx61cuPKuLYeaV5I+v1pWC4/ bEUWAEZGTuz3xjP1rP3PavmOdZFYn5c5FSOswtVJl3eWD8ynB5/nVdIItkdzC3QHPt7/AFzi mkK5ZjYvKkiQmJdpYcZwfp+FPmkGF5Ds4wCOqHt+dOjhkLLI+EOd2xT8uKfE0eTmIqTnG1Tg Y9aQXM3U7xzp5WTaXBXleDgNV3S5C9mgYkMuV+Ydvr+VRXNvA0zTSyKyMcKu09fSpnhKQOYp 9uw5Iz0H/wCqn5BcbbK1nJNv+dW557dR079amtZd0bNCu1lHzqRwD1xVKy1GK4tGJw8yfwt1 z7VqSt+8Ycgn3z6k0rDbtuQkpc7vkVkbA5GCD6Z7U63QhF81suqhSfcUlortbA7w7N/EP0P5 U4usMixkjc/tnJ7UON9BKVh4Ta+/eBxj6fn9aEjFojeWpYP1UnIz7fnVEu3mK8gEpcEFVOMe h/OnwZ8o+YWUBVX7+cc9v89qnksVzgttLNKAqFQxwXVun0rRSMwsPk2DbtLYHI7g/iAc+1UF P2SOR7cOcZL5y2cDr7//AFqdc3ExKqo3SZzz0AB64/lmqSE5XH3ZDQrtI37iyY9jgg/XpUFr 5AkbMRjc8sD2OaZppIQrMy7iu/J7g81seXBIBLIVwAMjtS8h3Klw/kKZog21iBJj17Gp0kim tEK52EZ9wPSoGvI5maFeVX7pHRh6flS+W/kTCWQCNx8sa8bTj1p2EQ3UAubuGKN1EaZJj45P +c1YktmMSeXhXiYbT7dKpaSJnRpG2M65UHHOfcmr8krs5HyhyD37etFrMbfQZ9mS1tpsDl3z wcZyOabBCsSxnauGyw7dafKoIR2kDpnjccZNKZWUHKZwuOn8s0mhJoUbpWU5wmMuP8/Ws8Oh unKkySA8Ajt6ir9o7SQhmCtn7qjuMZqnPIUvo4kJWJl3ADkg9KErod7FuKbGFIzjI2jv6496 bHbRzxbgGXKlcHHr/wDWqr9mlmlCNIpKkOWx3HAq7JmCPf1A64OKPICIeXHKkSthVU5XPXp+ frS3E2+IiJh8i444+tUPIEkpit2zJIN+7OQw5/8A1fiKnaOO1WIsA0gO0HrT0WxLLFtNGQEl K+YFGABwQAOf5VJOWeNkijypXg55GfWnJukbzAisEyWPftwPy/lTJoZQk3kvgE8A8fr6c/pQ tRdSI3SSAKVUu5wNo3bc+v8AntVKySOe3IkyQ5IKluo+v5fiKtpbyxNgIroUxhOMEc5qpZ23 ll98bqGcyFXHAyTx+FPpoIm0+3ks5Z4JPmhHzK3r7/l/KrEqxYCuAIyMZqwmFVX2gr0Oeoqs 5S6j2xyoVBIwf4hRqIybC1hF7cQxvkr8ygHIIOeD69P1qSWL7I4O0sjdGZvur/jxVhrZFm81 HVXYgFlP+fXNW8wXEAgcADlVB701qwegKimMAZ3nq685I4/pRcxOwEqS7SowR+WKy47N1njL MwjEK4BbO1hj/CtaabzkeELh9pwSOM9aeidhGcbpY4kmkjYyONwMZ6Y/pVmGSJ3EMkiiRixU kgbh170sUUVqiq2M43MCfuZz+lVLyzFzrMBZSbdVB3YyM5yeaSsFi1JIUTEiZ4ww/rVaItKQ UO2AKQeedx6/lTp5ZTIzRN5sLgJtYcgnGDn0+tQ2t/ATJbtExCk/MDy2KGgRJNdRPGFtlyYy qN83Jx3z3x+tJd30T2pKqhDj5cqPveh9MVGzWkm5gWURjaoBwagewke+w1wjLgEBsA/iKdxa dRLWNY5CsiEylBhxzkdjWhaWsi26iQhm/vdc+/WpSEFruT/WKOAR0NQwyzpCi+WenY+/1ojc mWpzfmGFDn05zz1pqebJdBwucfeJ7cfr/wDXqJ5PPhZVDHB29OtXoDsiVSQDjkda7H3PMEuW VrZ0TKyYBBHUVQgmcXILEmNcnH61ZdWeVXc4BBGPbtTYbYRyecrqYyBhSOlCfYBI2E0W3oR2 pTNI0YR0WVMYJPX86I4FhuC2cgHsfxqZArZOCMmpGVgyTRYAKFDwH55x1pkG5trMSUZiC2e/ sKlu9n7vJOFftRAY03qoLKzZAxjbTAJEKKCh4TlsdgT1/CjGw7pMNxkNTnRpIXVO4yP8/hVW Jm8qSF1OEHyj29KEgLTRxyhkUAq4wV+tLdxSvBGMHzExz61Xt12SMXbCFxg/hVuVn83DMNqf Nkc5FP0EVzJIrARRH5uGAHBNVk85LrM8pGBgBavPcBhjd2+WoktxKuXcE988YoQxPMVpEUZc L9445GRTby3lKIQOh4P06f1qad4bdgSc7QMYqRlNzB8jEbuR3xmp1GRwsJX2Ejnkj3qSWNzx 9xRyoHHNPtoFQZY5fAGR2p87g4TPHc+npQ0K5nPJIJW+UEADrx/npR963w/Jb5xjp9KWRWln EajPr6U+9V9sSRAF8/lS6DI3jlkijVH5HOO9IYjGmWbfwMlu3t9KkhjMKbC25iCSe9LNvZFR eg6im5AZ0UqusKqASrnLA8sDg4P0x+pq186MqgEA8kD09KrCFYnZiRkcMFPWlt712G2bGO2B 0qpa6iRdmt4pUDuR5ncelUzCqBig5ByGPApySF13lRtHJHqKW4IuIJVChOAoYHOanYdhkM4k tpMff5A2jn61HFKViCgk8VHFEbcmQZJYYGO1TQSJcREEcjqD3PWiXdAhUWQKSrbQB0PtmmtP CtwrDIyByeMirQcgqjIuP4dtVWtt8m5hkjg9wDU3LjG7LSS738tEYLj8veontgIlLIQoc72D Z7VrWkQRCuRuxgH1qtcW7NbSxRxksWyfbnk1HMuhuqdtynHn5dkZjUAHn+KoLuQFCAwUsCOT U0iSGZUJwIxgtnvWfJsRwXJ2Ox2nv1qoq7M5EiIEUNGmTxntTxGoclcZx8xFQ2zfNuLdehBq nd3EonEMEbFAeW9TV2uzMswXBTznkBILbRkcH6VKhSeLcpxtPINZ1riOYpdOXwOh7GtB3S3h l2AlfQ0NWAS5ZRCYpDgnuO1QxBBFtkkYshySO3/1qUKzxPIBy4+UHnH1qrHlYvLfqTjr6etC 7AE5YTCSUtsPykHjH0rotCiOxCoGD24rIWBLq5iWUls8bRzXaWFl5ECbEUIpHzEYwM/zrOrK ysdNCF3ces0sKSzN8pbOA6noPpUxt12ybkyZE+UE/wDAvpUc95I2+MxqXUk8Hp+dTW8XmCCW SM7wi5weB6Vyu53rYo6cb2IqIInMIXaA/BwPc1pqplT94VOP4W/kfzqcxHZlRtAOGx2qJLZW lMrFfk5z03eg/Cqv3EyoqfZ9SkKv5W9QeTxgZyKHtFuLv7Tv3YbGCc846+3WoXtmWV4g5LMr NGzdSO/8+lVEvZ0dI5FfyY87vfjGc/h+lEbBqxIbzULdfKO5rktkhskY9qcsk/2kpdYkEikS IxztX39q0zc/Z4TK+FZl+UEc/X+dU4NNL3PnK7skg3tuGCD2H4U7jui1p1yiQeQG3AHb79+P cU37czO6EsWjJAUDPPY8ClNrH9qBLbdwJAA5PXmkgj8uOVH+aRWDgipuJorXLGKBfLXZLImA qDHUUxPORgS8jKxIJLZK/wD16nm8tEbYys0e3IP93Of60q27NI/m4CMcoce1NbB5ljTYhBG7 NG4lLZD7ixI6ce3+NEjyRYeNUDJjg9h3qwtytrCiEfMOM/rSDy7jG4c5xkjGO/40MEVrr94T Pu+4vRDz0o0xg8bSTBs553eh7fhUD6eBKJlY5ZNp+bHI/p/hTotPVLaK4WUodwLg85Hpmlcp 7FyVIrazkCqSAQ/A/hyM/pTi7vPGsRR4ypyc846f4VbMiNEg4BPb1qkImsZZp1GIXG4Kf4W4 z+H+NLQkrTRyacVO7e8mct/kdKuxL5hzJnLKBz16UyPf5yrcKScDoMj1/wDrU9QtvdiGRiN3 +rYc7lHbPqP8KrcRFZuIJnSMscsFOR36/wAgauFlfJ2YUjHTjn1FU4kVHuQDhU+bOOoqnDqE kN3JGVMru4VO2R/k0JaCY66zYlo2kZVnkCsqp90nuD6VbuXjt7MuuwOCOQMkD1/nSXMkUlvO r/NLEPmAPKn+tVra3kuoN2XKrIoG7nAH+TR0A0j5NtCxA+XOTgcZ/wAiqN9cRzW6LAS2fmX6 c9atXilEC4O0dWUdufzpbOygtT5pceWVDbSOenvRsAtn5/l+XIQAOWA5phi8pvKTKxMwcMO3 rV4XMU27y1CkDqeP89ailnBIEY3bTkN3H0+mafqIfcM7LsRgpXlWHQ9jUMLSmyKSMGfnYQeo FRzS+UEinm3KxO0nt9atW4SPahOck8dv88/nSAqLOguDC742YYORwCOME0tyGnEkG0GFouZk 9cYqWaICNsLGzSg5B7//AF6rwr9nVsJwoIIzjI4/lzxRfQCK20qOxc3PmoyYO1g3PPYjFWE+ zsuRcOGl6Y+pHfqPf3pl+8dvY7CjN5i4GOw/+tRbyxrF5ZVyc7jkcrnv9KaYNlvT5gsMKBHy nDsRgVFeRlb0OGVnVuATyAen64p1yGmtWSJwoztcHqee1VLwy30i7MIFztLdSD6+nP8AOhbA ty7b2zReYHAO4Zbnkf5OaWKCJS5diSDzx1A5H17VHbTSSb0kYMxyAufpTJrh0iYpG27egAIw Tzg1Nguy9HdNKGOMIeDk8H6exqhejykHlJyAAV68E/8A6qttIkGwEFo+BhhzVSScjCqmdzD7 3IxuyOKaAZbzLs3rCwjC49geM49q0FmDszbtsQT7u3qO38qaqn7IViRNzjnnue9Z1nHcRXRB xt5U/hQ7FRuXntzI4SDbxzu/unpn9adeOVhVQhkYjkA4A96WVUttsxwAAdzdwOn+FU5p50RZ C4EBXaDjggd6aBBa3X2WGBY1B84s7EnPfp+NWmgaZDIk5VkUnCnrn2P41WtEVb1ZHRt5GeOn HH8qfGo+ySybyXaQhV7ntj86PQC1GJHtsTgMv3Ts9R3p29olDySgljhSBj8xTbZxDF5c4VUc 8E9+D1pWAMrbHVmK9Acjnv8A0qQJI57d4d+0AY6AY/SqrNayRb8FJdp2nHHU4P6VYleNYY1K r5jj5sDjNMtbdYoVEhXCrhVPryePehPuN7DLK1iihZ2OSy/Md5wc1LPIj2uYmXJx8ucjHv8A hSyOFidlC7+N/GMgDI/Q1SUxzSERYMcjASFRggdaBXuRnzIJkvPLK9SQOwPX/GtGIJNCDIOG JPzdajhfascLouQCoI9B/k1Ru7PzD+6csrEqVY/dHJ4o9R7mxDMkaSxoMrnHuaqkkXJJBxjj A9adahI9PTnauOuep/xqEkNeD96YyVAHy5BOT/PihbElh5njWVkwpXnB6H2qsLpv9W8bLIyZ QN0Y9qVIZonaZcOejx5ycc8j3p1wzSQLJbAySRZGBjIz0yKaYFSC5vre1jjni3MOMEYIq5JA iFYQgUHrnoSRjGakaaaONgX552L71VeXzMSbcyA4ZSOnv/n0pXBoZ9kDKQJFjcjYoP8AERw3 0zRYWUpkaSf5ADtRM5wOmaS4ilBjuFLMvA5HKt61Ou9kCRuBIgGeM/LT8iSF7KSC6NxBKHi3 ZKZyOvp61aWUllU/IQCpAPIB6H9MVUNxundVZonJGGAyD9R+dRy2chuXuUkOQMBIzzk8d+3N N7gaOoRh0wmeejqTkelUrWeZrcxLISFwNxXhhz2pbSUraPC6vJJERvOOSSetVVvJUuZCArqr tgEYOOn8qegtS4PNEUhaMK79Mcj/ADzWdFEbeSVVGZi28c545P8AMCrl5dtb2wkOGyMMAcEH 2ptpKktuLhRgbsfN1HNJgtjPubQLHFLEMyO2VkB6EY4I78D9KqR3k8MpnnAaQDb+Rz/X9Kvz XUQjeIxTbd2UDDGc9x75qJrNZ2UkMr5GT1+YjP8A9b8KteZJbt9TS7EayqUJOQR3Harvnxgk GUKc9MVUisY7Lc0Ktu4AVuRgdQKtRvFJufySpLc5HWlexOhyssHlSE4I7gdiKkWc7NwVQc4w T09aZLcC4LIwdWDYI77e1U5YYoJCWjHzH64rsS6HmlopHPlw2AOevFQLaCRRLvwyjdtb60+H EFsoCZBJXaD7mrGTIkmVwCucj29PyoC4bVe2LP8AJgkEjqfao1b968PmgluQpHQVci8p0IPA HY9j61Quos3QcEjIwCB71NkmMZcQsqKyscjjjufrUyzSFNqgh1457/WkOXjTfkEZAx6UkSKw Kqx3Eke4qlsImbfGxMS53deelRrHIbh/O5HqDx61cQAptUgkdc+lQSMBIrAgMg4FSMgmjyVK 7Q3Ybu5qeaR4wm7yymMEr1H41XbbP5auCp5w4NWGhMdkyINw6ZY9jVJWEQFmb50QFRyNvenP GisMsck4I9s1LDtgUfOCfUdzTRqL2tyk0I2zJ8ycA4b8eKSWtgIJdhliGwMMkcjgirDSkSIM 7cKQQo4OMf8A16hjYOFwcbSCf/r1LkyuAuCyHJpPQaJPM3snlMVDdVNDKQu1SGwOT1zTpXQM CgOV6AjPJqGYsqt0GB29akaHW3lvG0ozgfhVaSXG+SV9qjpjrU4kIgQAf6wD2xUbRxxorFQS wPXvQBGGD25lQsqKe5qyoR1B+Ztw/wA/59qoz7khjttp9c+vtU8N60SBJIwMcg+1OwFWdPIv C5zsZdoUVCIBcuzYKHoAKvTsjpyeg+961DbDcz5UlR91l6H3pagCwoIwgywPG7PIpEhigTy5 ZM8dCcVYcCK3YREbjyWPr61BbuZfklQMwxyR0oASRUmZoyNoIypH61HAht1CmMYzzk9Kll8i NiNu1x0IHrTJ0jJGSRgdMYpFLUgeWeS5AQgpu4IP6V0FjZhY9zRshkwZFY9O+c/WsvTbJLq4 CRkqAdwauhjSXzfLm4iOPnP8PsamcktDqpU7aiXVmFVTF/D39KoajOlnbhmAaSQjaOhNad5c rFD5anIfhawLxIhdT3dxIJBnbGAM7Rg9azSNJvQo3JbzYZ3G1D1UnvVe7likZQV+UK3I6E1a 3LNCrTLgoeAfWq0oBiKxqPnzx1/GtkcchhiV5I5IyAwH5n0qVJ0O5cAlQM5qOGBoQhJO0Ice xJqKGKVXV+oPXI6jtT0EMEkc8qqYthBxkiicCfcsRLOjZ4qxdRpDHJOoAkK8kCqqDbGgh3Yz nIOSaPQCZpPLVIZCV3HAI6VSS3LXbCT5VII6+nFS3JkmTByAnzZbipLd/PmTAdiyjjHQ072V xpXZp+Hbdn1QI0KgY3Ek88H/AOvXcXQg+zTKxwQmAQec9v51l2Gmx2lqsrgs5yTg4wPTNXLq 3S8Fu6OF6nPGT6fXmuWcuZno0oKKKdhaBibpkBcccnLbh1HvzmtKGRiXE0BiAYkHIIPbpUH2 G3mAd1+dwTlSQN3tj86W3j3RmK5DI65CkN94c/r/ADqDV6jhdHBITMrMAfTn/wCtUMszqJDH h1XAOeD6+9QSxStHbyQSNhk2hdoJHI6g+mKjuPOgvI3bBiIBYtxjHf6nI/KjceiJr0u8S+bG xXPVeoyP5USK7xLhAxZuQR1B61O+oJKVjjZcAgg9cjH60yO8MqtKhDQrHvzjPbOPwwf0odxI p3P7qXZtLxFgzmQ8pk4wPp1/Crk15BJMtpEW8wZ5HQY6Z+tJcst5bEgrh+Gbrnisl5IxewC2 VhhwDg4OM9MU1fqJm1aOsjMztskHAUDO0df8/WoUm8qaaMyAohBY46e2f89KSZENwX+YlRkA cAnNRfZnS5lcsx81hkIf89Mmj1DQHVbrfH5Ss8ZIP8O4Dp/Sr0EMUttFLHuxtAAzyMf/AFxU 0VoEUoASjLyeh7//AFqz9/8AZ1yiW8waOQ4Ku33T0/8Ar0ILkzH50jlhIQt1zz0OOfx/Spoo 2jhePeC+duO3Pp+dNaRLnGeMk4ye3X+hqCeVonMixlwPmP4jH6c0mCRZWB4Lfy2YEJ0PXGfT 8f51lrcq1yEaVyJTgKpyobPWmxTXly7rGfusCCegHoPerUelSLBK+5DO2WBUYyfSjRbFW7ml aIyzAsQ2z0/rSXciyxS5JUZOARjLdqzLXUVTBnPlscxknqQOAfwq88sf2oOG3fJncOi45/z9 aLdSWSGRftK/NgJCvfrkn+WKS4Vn2TbQdgycDilUiS7eRYwQ8IA6cHJOP8+tRys6RgSbihOX GecfWmImju1ZPMjQtGMK3HemwwfvJSrLgH5AwyMdQc9c/wCFUJbuS22RWvERBZuO2f8APNTJ qG1SJ0I29G/vDtQ0KxJNaD7Y9yxUKy4b3OOv5gVajZbeIINhCqd+eBk1D9pj+zBXYOrEhh7j sKrGeQzBLfKBvmIdeGPp+NCTGXEuDLJsEHyLwz9uen6VW1GV0ngMZIQ5Vs8kDgZ/maekhkPl 4C7vvHH8NV7NpTJMZkUMn3QMdKLdQEhDvcbQCvHJByB05zVp7i4idYYIlVdpKu/fHb61LaXB k8zyivljP8PBNT+eojM8iDcq4OBmndiI5MEiRF3hRndnr3zUwSO9UyEbSDldv9KzEvIfLMqr nZJknGMKe/H0/WnQzGORlZig5w3rjkH8v60WEXScRyLJ2OOD0rO813na3Us7KQpBPTHP5YFX BN9osdzjkjax4O7tmknszFcrcxDlYwrBRktzxj6c0gLV1EklscqSACAPSoFVViUn5GB2nI6i kS7KF4T/AKwqTyMZPpUEtzNI0SBA0bnDFe2aLWBaiTyxiO4kTkMAFU+vQ/0oMoit7aZ/mRxs dzzjrjP4VGLUuywhj1+8e+Ov41YubWSVDHjEYG1l9cd6pC2HrAEMFtv6DezDvzxz+P6VbWEs 67GDJ1+9kf5/wquiRqieW+SBt+Zs5AGP8/SpAi29qQpK9yD29fw60twK017dQ6kyvaO1qxG1 1+bGPaqlw5urxfs7lJQdwA46Y6g1dtL2QyAToDGThSD3psnlTXm+OQqSTg44/OncaRo2KOtr GZD8wGCO/FUzHm5kmaRgjNlFB6A+taLCLaFYhWIyRnGfeqzMFSRtyuqrkqex56f4VNtATI5Z mMLRkBxnB46CmXjR3Folqu1QTgHBGCBmo4A/lNuBBYY3dcmrM8tvFJGzpt+bdj7xGDQrvYHo NtBJsSKeHayjAPqBSEiSYqqFY887epPrxT7zUPs4B6kLnB4xg9qh0+8j2O+5ipYkhhjb9Pbm hp2GmWbmBktUZgURSOM9T/WmySRwTIXXYAAGxx1xz9P8aW5lywCK0ny5IzgEdsf571HDOioW uY8OOMNnP0/LmhKwN3GSCa2vWLLujPQA4GKsT2sbIXILMcMAhyCf85/Om3QjulRlyeOGU80z 7aFtVBRmkHRNoy3tTAfB56ziJ3BVR8zE549KrrFNseMSAgs3lnsMdv50sRkunW58tArAgA8M PX+tNu3eFFWBhtaQDBHQnJB/MYpLyBlqyZgrh0JQjjI6Hof8+wqTZvj3IpCYO8dTn2qCKQxR rEwLLIOFY/d9QT7VJCk0iM2+OLPzbQckc9/zpDITcoUmtZdqmMgocg5561XF1ILNmaIiUc5x xkn/AOvTHdnAwCzLMMnHIwRz/MVsOsExZXUZYY4Pb1FF1eyBozNP+0SxGJ3ZZFAKnvjrVlbu GCR/3fzuPnwOpzimMotpC0Zy6nj6ZpiMDczKVZ0JJGcYzn+nrT9RXJZY2k1GKRsGILgqM8de envU6GKTKjaB3Gc89iKqBP8ASd/mErkHOcAYGKkkhEq7rcqjDjcp4INDAtQt5cMib9xDFeR7 9KoCFbaWKeMkyS427uRyOlFss8MDCV1Idid2enoc02486KzjwRGvQnqV9MetMSFs3cXk6LGi hcBhnk8Z/wAaluJjAp2RoSOCd3JPQcCqawyyyRrtDucbn/i25z2+v8qvSW0RlVXIQudp9zwK TavoFhjQSytHPkqpQh4x0Ynj+WKgbS5WuCSEWEn8qknv4EjMayEsmAFU98Yq0EMyIzs3Khif 6cU32YldanP6jG6rvRZDCwVWVl75657dav6ezq6QFIzGU6DqpPX69adOzsZVjZWAHzL7eh/L rVK2iiZZJ/OkjfByo/pVPoK1y8Askx3BGEZJUA89uPzzSG6VLxVmUGMj7wHAOahsHE9s3lMP MQ/Lu5OO4P1qpdzyTaY08Z4b5SoH3STzQlqSzWku0kg3xMG2/KPz/wD1UWvzREtgnJ71hWL7 oTYMvzsBtbd1Gf6VorbpAPLEhwDxng0t2KxhqI3fcEIfPUmnSWZmHLIwzkLyabHbszK7tg9T 70pkZZlG8qvU8fpXcjzCQKgxHtBwfTipdq+WY1ULjke9RCZ4kIOTk5I7jmh3UKzhjjbSYDQ5 MJUALngj/wCvTDGkoEbFgeoKnpUarKYIzuOWYkgikt4pNzBiCM/LzzmkBaaADYpYk44yKbDE sbKAeGHUnrTLi5YqDuKgYRSee+aWUFQhYnnnAofkBNG5WGXcuCrk9arbA5aXdjccYHpjH86a d7ltrbSF3En1PQfoaltFYQeWdpZTxQthjYoVMocEHg49j/jVhSQWB5TuPaq0aErhs5BJAX8a eg2RMgY7j0UnrQBHdAMxIO1WG36e9V7mRvNGwZUYUE+tW2kCALIoOfTmoDLHOHRhsIY9u4oQ EsTqwPmKQ3bsDVkBUUugGGOMH1qF4mdcgj5R+FJC/wA3llTkjPPTPrUvVgBKRyMZJcseoHao zI0t15SfcOM57mkcRtdKGf5n6LjnirBiEZ9lGM9+1AxjwFxjcwGRg+lOYAFFB4UbQTU0ZCR7 iD1PuRUTRqVd2PykYwaVguDIiyASEFseuarSQO0bFwMe/wCn8qe0du8p25OR3J6elOPyoV3E gnJB/wA/X86NAKUlxwsaR4wOoP6VNC7CH5xjBPIHWnxqgbzCRnpkDpUJmcysIQWbnO4fL+B/ OnvsASTFgNq5z04qzGqoxkIG9hn6VQh86SVRz5n8IPH1FTJK4Oxj8wbA3Dn6UmMlkRHyzbgx POe9LFYxzDJyAM4Gar3M0vysiENnHPar0Nxtt3j8rfMQR8nWpe2hrTjqaGntAkMkzhfkHA7g 9602MRjV1wVIB642/wD1+tZOnxP9hVig3Y+f5c4Pr9a0fLtfsjljtBHUH8axloztWxT1Cwju r6Oc7g+QxI6AD/8AVWTqkkZKxYIXG7IHAq7JdFV5jkAC7QR6VjXUn35SrOp6c5zzVRMarVrE MoM5SML8vBII4onVldJB0JCmoLeeaS4DYPllTx6USzyG42Ff3WfzPtWtjlJLhhIrDPRcFR60 ka7Y0Usd3GKjlMvIAAXHGeMkU35dyu2Tgbs579v60kgLPmbdyEAt/CPWkaMpk8BcZUdgarGS J3Dlm64PsRz/ACqzL89so25yucA8mnYRSjIvhIgIGTgketatjpMttbtcup35G1kP8qo6fYNd XhS1idTw3+znrXeJamOKGByA2CcgE54x/Ws6kuiOuhDqyngv5bWySCCRMkMOQc/p1qaFiLdb WVczKMjJ6ZAz/KtGQFYw0ZDDbwAMcYqBY/JtTM0bGQHcRxu98H6VgdiehFHJ+4GwgOG5Gc7R UowWOWLsi53bTt9OKz4r1ZfPjSPaMMQSOTx3P8vwqy0r/wBiRG5+dynzEdTmgdmWFQSzgN0R c8+veqVzCuyYSykK2N2CKjtbpWjiMgkLJujUnoRjOPy/lWdJLcK8luQT8rBmdeSO2PwHWhW3 AmFtFDPFPE5O04O4/XP+farckEfkYY+Qrf3SBt6jp+v5VRhFzNbBJNqKriQOwzwOf6frTpU3 STQxs2HBxJJzu6Ede2CR+FMTNP8As9Il/dcDGRg9T64rOTThcBpMlZc5JDEBeh61Ol4sVsmW ZtnHy8/l69afaSw3MieUSoKk4zgZ7/rRrcOhWMM1rGhiB8qIkyM3O7HQVJbSXJuo2Yho5AcA DheM/nzViGL/AE2TLswY5UD2qyIhCigfUjOTnJouLqWN/wC7UNtJ4HOc9Dz/AEP1qjcWUV0v mPENwAwR1z/+usy+kmu7xFhnaOTPbjithJ/OT59yGRtoA+nX2o0HZoq3CPDBbKgzMSASw+9j 73FWY4YoVdEUMCuQD06nihoWK+aZirxuY93XGef1BqlI13AzFZYjkE8nPH+f5UB0LYeKECFY mG9sblHyirszRxxJs3OvTK9+1VbWePyxvdARjIJ+6cdKnll82NtvQAj2I5z+NJxYXKL6ZBe7 mIeN93fof/r02WyeyC+S5clgC+Og75FXvKNs2M70ZiAD2yM5zUClzcmQMzAjhOoI7nH0pIG7 jW+0ySbYdsaEZ3Y4bjj8cVBLchkjt/NLSsDtQjnHr+NJOyQqJCzt5I+VW4wOgGaYkkT3NpIR jCvvI7jBBAqwJrZY47jG0EquMtyAcdvzp6w+W7xOfMYtkgDgN6fhmq4R3uA0KMuAx3ZyCR/j wfwqeKRlVnnbyw7YyB3POaV0KwQyWySlDMozyEYYwc4z+tW5YB5qSbDJk4yvYdf8KqiOGWd0 miXzlzhl7jr+PY1JBP8AYIykYLRkliSPoB/WhWBonQrGkj5wg4UH0H+TVe8WF1UvxOVPCkjA 7c1LPiSRWJ+UDfjPJFNiME0chAw7Hncep6UC9R1uxSNfMjzGwACjBHPUEfnToz5d28Lt8rcq D+mP0pkTTW2zyx6gqeuT0q7JaK8ySGUBgQQMc+v9KLsVihcWZncNAAMth8fr+dMaFkkLjdtI OSB+tWLhybloll28ZLqegzx/n3qOWW7DPIFUonAycl/8mhaAFzIkFqWKsWIz3H61Y82TzVkB ABGGGenFZlxI0yxylihUDBA+UjjIx9eKsxSSP1fzG6sx7E+n51T0EOWT7ZdSRplAqjLFfve9 XXijt4GjQHGMkjnrxzVe2ljikjUjlh1P+NQzTTSXDxRgCEjBOMk8UtN2Gt7IsW8iCKNAuSpy cnquTUHkzu+3eTkdGftSJFJDDiMqzjDEE8n1A/CkF063BkH+rA4z1HTr+tPYCVIhZ+S5i+9g OewxUW4zXx3liOcgjgc8VZtY7lUY7yVfnYTlcVNOzeZEscbAkj5h3B6/zouDRWjj2XBUg7du OfqR/WmtZCInFwQn3mGPu1YhjdpT5kakZIHzEd6VkiEg2s4JfAGeM+/tSTG2Q29z5ty+9sAL wjdlOQc1LLZrIWMUnllo8Arxg5zn+lUry0XyWuFUncNre3UHPoaiif7NbRRSlyc5wP4B/wDr ptXEvIszJIbceTKyyxuONxNSLO0N3H9oCuSM5x1pySxTESQscYww6ZNVri1u5pZkHl+X0jZT 86Hr+IoT01Bl2+WOe5TcXXHIx2/zis22Pm4QbyAMEqORg5A/U1cuGkiZpCS8a5UrgdfUUWE0 U8W5Ew6/ex29P50PYdyZiIGUknOegHA9MelF4GY+ZncjBdwH3t3QH+X5UskkUqebHJkpkHP8 qquRLZrsjKzKSGcPndzkduPTv26UkrgXI7dYXUN84Q7ue49KJrny7Z5IgxYH+JT+H+FU2ubo oVjRWbkAno3vU9uHmwbmJkLrtI5+v+FLRIfUoiW4tiUlbazybgwXIGevHFaKtCYsSbDvIKHP HtTZLdfMV/MDbO+eh9cVWkhTyY49okRWILA8/X609wdidZw2qJH5QMYTcGPrnoPfmrKyLG8r fcjY4bI6/wCc1nQFo7tYX+dcgg9+fb2xzVny3NxIskxDFj5Y6AD1+vX8qQEi5NxKcKoADYHv nn8wanUrt2PskYnOB1x6iq10mF3BQMDAbOPwB7VBFZl1V7lyufu85NFuo90Wkn8y8dWRsKME n9D/AE/CluG8iMNHywJwM9/Sq1izStIsjHO3fnPX61Wvoyu64tzvZfmC9Se3PtR1EXI9jMJm DIMZb5sYPpg1LBAsMrlW27cZXA9+fxqCBTfbmXMbhh8pHVe2auyOmwHbsPAG3oT0xQkLcx9W lxGLdQoOMhegPrV3T83WlRK6llaMDcT3xVW9YSurM22UOSue4GOP61fidQo28QqeFH+fWm30 AeqfZlijjBBfOGxnpg4zUV6ksscZXClm+8p+6Sc5+op730aQByCNv8J/Kmfb4klCpMAxGAjn 71C0WgFS3tSjSbwkk8WCzdDyepqaN7iQxqcohmX5R7Dcc+3FOkuYYVklKESSjZuzg+w9KitJ pZF+z52TEeYC3pzn+h/Gi3UQXUcsc7SxD5HGS3GMDtUaWxDCGRjGMOASexII+uOasSLI7Ijs ThW6dDVe6TzY4iWwYyQT9fb8KpMTQ9bOKxhEfmFTgkOvHanWnlrZ5jDeW3DbhznvURjMyQRZ bgYZh0wP8irM0aJaeVztydvOCTipvcRnXFjFZyxXQk2lW5x1Ymqd1ezPOx8rj3XNah+zXMBg AbCcMe4JpmTbkxxAMoPXk/0qkDZhRkufLG4jI57fjUsQb5gc5XnJ5pAyBSqEBuCDStIBb7iQ pHA967Njyty06xrGqyMSG456c1SkCxwsiEshOPwpXYkJ8zMGGBzwD6YqfyBsX5cdvXNJqwEG 9yygINmOAeOlK8yKGOCrY+hq1MiqF8xcdqgZfk2bVJHAFAFORftKrKzMFBOQOvBp0jyToViz sOMhu9S+W3ljaNrDtjrmkRJJOVO3Gc/7VUhEqQ7m3FcblAIPfH/66dHAS4L5G0YUEdaRpmjG 0MXz0HcGofPO8IWILcD1HelYY/CmVlm2jkkEd6rli0xYEFF4U9qmVNk2J2VQe5OPxNOKgSfK B8ueppWHcrZZlJTcXGcDGcH1qPT4GMrE4IXrn1rTM0cEDOvIHP0FMtJoZNzpgBRz+VGvQB8i qhIU4YDgHvVZyyK0pA3Yx0p5KlizMefUU9mjIVW+b096nqBDHG4jDlMvgDdjrxUgZQcNjPUZ piTh3wCcAY/z+dMkyxxGm4o3emBO1ykYwxUIcc5pJpEniCh/kPIIqGCMFgrElTyAR0zT5bXy nZgMr7dhSdrAiCRYowuOGHBP+fpT1ijBMrOSKGs0J3bTk8kE+tSSRloAFXaRjA9aWnQZWuH8 mFTHwrtyPb/9VFuEcHZkLnJpk0cjkq5CjI5xmknDW8OIwznPUcfpTQE1xHiMFMgqAAVPNQST q8LiQFpByOMnNRw3z3A2LuyOtEEU0EpaQkjuWHb0NO1twRfs7iO4tzHMAuOc/wBa0LOOJllx kSOen+fWshGxfhlRmA6Bf4hW9FCA4bJRuPxFZT8jqpEsbGCCRVGADhRjA3d8VJ5qRARlfmcc Men0rOu3uhcIowYwQ24j+v8AnrRJdYTzGGWB4Kt2+lZWOm+gmo3mFZc7VJyT6fWudkQyQYZs DPGB0FPvL11QGRSGYls9Riq29pmEZUqx6kHj8a2imjim7snjwj4Qr06012DBHUB9p28Hoaqi Mxn924QkbsGo0kk80RBsBjvIWrsmZlm7iZ4QN4wB0HqagtiJ0XdkbQMDHGBV5YRNbEkgkDFU 0kSIeTtOUbGQO+aXkCGS2nlu+xvlc/NjpUJkk+0FFbkY2LnjFaMUWSRI3ynnmtiw0VC28KPm 7nv/AJ/pUufKa048zsaWmIltbojL1QFiByDitAToJEeKTOenqP8AJxVGFmSEELuyxB39+T/n 8KUt5SPdJGGkdiQOyjHP8q5nbc9GKsrI2Ym3RkoVweRgcD6/jRHCxlyxwAvTs3v+Nc/Dbz3N 4JJpXRP4gp4FbUlyotmhgl/eKRt47enNJJNXQ9nYZfCCKxkcoIyAQdvpjGcVSj1SOa4FsqDy QVXc3P3umB3rZiTfFudQTIOue2Kw7uwjtZw8exPl3PngA5HNCSW4JlqZFtwXZi20liMe1RK8 F2fNUfNgBcnHBHT8KkjmF5tjyWTB+bHTFUZDawHLsCzNwqcjnHUdqXkBp+QEttnVgd3P8VZF 8u7yyQfKUZYr14PWtFjLb/Pl3RR90n0FZVwzvIVb5YyrYVRz14NNBYZIphMIVCsBi2Eg84zn p+v/AOqmWyT29yixQgqDuU4zuU9802dnuLnyY+PmHy44xk8f0z7CtWaRIs20bkMhH1HP+RVN AmXLW0LHzklJKgDBHDY9adfxMbYyITG2DnbSWt6m3YUIPQH0/GqLXiyXctqw+VlJLYPB6VKT C+pFY3Jtr2MSMxRgBuJyVPYirVsY0itxI/77GRwQOeP6VVFkLS1aaSYvtJKnHIHX+tWFkRmj eVPlPbHYjt+NP1G7dCSV1tJZJHTcHOWUGq9zKVTMCqrrGBtOPXIxUk6yO628Crvds9fugcc/ yqncqHuZbdDhGwpU9MjuD6UtgSuOsrVLvTWZWB5LM568YFWLaCSe3DFjG/GccBsN/himRP8A YLaBI45CiuQePvZPT8+1XZJt+EZdjj8CMHOR69KNwLaOJI27gYHTofSmyLGqs5cjdz8vb/Gk iHl27qRy43Z6cn/69ZEmpb3lIK4J5Ruhz2FCWorX2LUlst4nMh2AHIVsEY/z0qPyYmEcZUlk IwoPIxkZzVRovKCz28nl55ZOu2px573kVzG0bFVwWGcHj/GhtFJPoy1AbpJBtUMp+X7vT/Iq e6jjdNkx2l+mPUfWnosiSKxHOATjvj0qpPcvcXmzy1IjHy8nkmloK1yskEkdwsZGAcGOUDOR 3qa6trgXRmVwFSMgLjg1YtZptpjkg2IBhSOcdaSUj7OAXZhL8o57GmnqJkMl1HEsMatliuCG POB7+tOiWLyvPmwqMxUsOAQOKjuNPV7IBW2yRnKs3+NN0y2FxaLG+T5TsNuPvAnOaq+gi0bu NFU/whgVPc45/Gpr2VwjiFyZexOenrUNzawgKwXHln5fqeMUlqS8pmMmFJ2bD0BpXFoZUsWY Sszl5CfmcnnOP8P5VdW7kksoztV2A+Zs4wRwf5frWLrXmnxSkaZSIRgsp+6wPU/kK1tqpGEt zH5b55ZuCf8A69VKLSTBO5ZjUXNqGwqgnBP93kg/rzViWLynTDZBIVhnrjGP5VVhi+zWbxmQ lWbcpHXJHp+FT2yuEIOB1YE89anoJkYjd7sSxPvjRvnTupPJqGR3jWR7TMoc4B/unpRbyyJd 5nbYVOzeB94HoDVsxyIobaNjPyVPUdaGNOxWilMlswkGG3bj6qfX+dSNAJnLsAkin14Yev50 xoI/LMk0yxux7HgkdP6VPGqPbNtGXYDgciqJHx3LJKqBQeMjJ4z6VM13DuRm3As+0Ke3/wBa sKa9jt5cxE/OBuDHIX61dhlmuY8wpmPGwlx973/LNNxsJO5vefEhZyCR6kVTF8CxC2yowPII 61Xggka5WWXPCANt/Tikd1jlLHJ3kAFTgE9qi/YpJdSa7VrmQGKQBCvTjOaebeKUKu1ACvUd x/nNUJJJFeRkUhV3FsnkDvj9KZZXKqnkvkRk7oz3U/8A66rpqK3Yju71NNnZI498TgDAOCP8 mrEN7tYxDd8xZwR24X/GqUkjagbhVQoORk8YII/+v+dWdLjBLPMuFYfJ8xJBxyKba6DsjQgh WJHaSXO/nB9agnVbeFniXaz8hx059qhuJUll2AgsnGB698U1r4RPFFJnHHXkE1I7dS1FGUQb QmWYM47DjmopZHBdY41aI/eI7Dv/ADFWCC8LSIwLEHAHHSqSXEiCGIg7n4NK76jsXYmhkjUt ncrHBXPH+eKY975szRxCcyRcZK8A0SISHljcR4GW+vTp+X51JueW22LKEkJ4cLyfbNNEkV80 fMiearFAzFSRn2IqKzED5AbBif5WPGQfb6VjWV5dtcbNshRztc4JPcfzroYZlkjeSLGxx3GO c032AkMAeVDsB28hw2CKseWhcM4Bxg5PY1Ue/SMCFhI3YYXqcZ/lU0N0H3bY2KEYzxUWGSFo o3KtlmYfKT0xUM8ipbtMEOGbaFc9/Wi4WNnAVZFIPccfTjNRFFuUwu7jkow6EdKYh5ljt4yx X94yEkA/nj86r210JVR2/diZ2VR6HGf6UxmaRIpgSCrKp+Xp1B/DkVJeCO1uIyf9UrfulH98 nnj6U12QxqTfYjAsSySN0Kluijv/AJPekkuDcP8AuAxYnkdMVcFtHJbxzxuyyD5ldRjj6VWY pdlnWNdqttyowQ2M0gTGxwEE3Fw6NtIGAc4NTedHLbLBG2WccMOMA9fx56U6NF3lJjlgCDu9 +xxVQWjjU1kUllJ5XoMYwR+VCQmywwIdrZwzE4JIxyMcVWvdOkvLyKKMYYnlv8+3NXm2lzcZ O5SQ59gSKttNCCsh4kxuUeuKe2wFJ7NUjK4WeLBz6j/OKqXFostlGYXdJVILeoz6/nV21zl2 ZuAMMvYk/wCTST+Q8bEbhk7GYDkcf/qoQmQxzSJaqdhDKMMrdznBx/ntUFw0ksJ8qMklsSgn BB4I/wAal1O4n06yErosoLgbh29PxqW2DShLlyoWQg7Bxx/nNVZ7iuMtn2Wwi8r5wfmDHgr6 flmnT3EbQ+WGzIPQ4x6VXupJoWZEYDMmenXPGP0qhZSMbwyTeWWlXHoMD+vXijoJmgkexmkR kkXgsVPUY5H51bt7ZXgUvEGbnJGD3z/Ks+0iADosmCCwGB94dquw3cUKbfu85IJHFNEyORi/ dxglAmVxnv16YpY28wt5n3VIyB0GamjwpZpO6jr9Og/KkR1MDkR5D/e/lXazyy2wAIXaMA5A +lTFh9mXeeQOo7VQhcBxJglcc81cldJV2KR05HSoaYxZZw0Wxhn1NQSFVAUMu0A4IpQuFJJG 3OB/jVG7z9oComQwyefSmtXYC5ExWAEnjGV75FQgul1KHBwsjLgHOMcdR71DGGWLcj5O3gdK ELRgAbcnnBqrCLckwXDbeSOD3NRSRNJIZEOJAOAKRN5fcQvByeKsLgZbsT+VLbUe435ZdglX ZK3X0qK5CCExqCFUEgDtj/8AVU7DYiykj5WDEN/dHNVxKz3DgrhGBAPsBU6tgKJAlqAQRhcb aWIo0ZVgFYjoB+NETjeuRuJ4wRxmrAQAsCckD5fbvRcBAkanY2G68e3r+tKAN4yMqME4HNRX wOFlVuF4wPqP8aljk/dq3UN2NSUN2KHMUY2jAJPoKezje0ZT5vX+VMAQSq5wzH7qmpWkRQso Rc9sc807XQivaWrxtLuZipO4Fv4avNGY4SvmL7LVSWaQOWEi7MAYB96ZGWDFCQCTwCeDS3AD 5j5AOPoOtNLGRRtf7pJLD1qw0cu4LgEf3hUcsGxWVSCx4J6UbBcrzSMi5YE5xjn/AD61CZdq MFCvkEg9yO9TuBIwEhPyjgA45quwWFCgjO9uO5wKd1YCpFciJS8UYBP3sdRVwyK6bZHADfe/ mKhljEJWMqF3AHIqSKOOZVyCDyMY6ihtNFJal0qEjjKbAc5BHqelXop/MBVVO5fvk479eKz7 aaOViChwhzhhVy3EchcIjLn5t3rWMjqpmhGqSxuGEgQdOcZrFv4o3uDHHnYozjdxV67mynko cDcN5/pWFJcyQ3jLjMWMg96UY3Y6k9LCXMAaYA42454qn56RQiU5SQ/KAfbvV9LlLh2ZO+M+ 3FUbqBiynho85GeSDjrWiVtGctypOzXEPnSJjZkbhwPapVVgqyvGCw447irPlfa7bynYhe/G M+lNlgkgVXjO8KRhBxx3qr9ARIAsbht2N38Oe3NDIrMHIG7dgfSmzyExfdO88YHU0WRM3lwb 3V/9odT0xUlJXZftbX7S4AxkZIz24zV+2gvYblgZVIUggDnAqS0RYpod0p27sOhXkds5/wA9 DVnULWa3u4HgAFuRsZsfUfyzXPNs76MOXQskolvtlcKqnBA6AkZ/rUVtcfYLYvI+8ZyQB2z0 /nUE6XF1G1tbIwZWzuPQ+/8AKm3Ekb3LwMirGcB8cduPyzUm3kWd1rIDLDMu45Kpk5IqG1ke d0gZR+8UNux90HqKGhWN22EIQMggD5j1p9rLHHFPPKhRshWbdnHt+v60PUNkaKXkC2ytvCxq MD5vfHWsvVb2KYKFbcpHJB/z6VYgghEX+rjw6h8FecdT+v6mq138sIMNrvjfkFjjHbGPwFTI cS1YAQ2u4QnyGUHd/F70sltaAGZPnZxuX6VVmv72KaCCQIIwu1lReB/9bH86ZPNHaOjoG3so Khc/KCeM+/8AjT5VYVzU8nzoQucAgBgBjJqnd28ixiQAnDdB6d+foKmt58ziCVuTjGCR3Ax+ ZqRZZGkkQjehJA9hiiwdTGt5UnuJVjUJ82Xzxx7D8qZJEyoodvnVvnYLnnsPpmn2kaGZ95Jl Lsvuoxj8s9/enmOTeJGdCpBDbeQSDx+NV5iLcFuxVpppmbeQQ3GQvpU8dkqztcCI/NxIM596 rWrLe2HlglSH/eeoPXH07VoPcvBAEiAd8HA69x1peo/QytSDzwnzZhsjl+TK4GADx/n0p1qI ZoFZZG4XIVj0PaluIlmunieMSRh/MAPQZGR/OrkN1buBFaxRqBkPkYOKTuPoSRLFFPvDE7wA c88/0omjUynKh8ckHH61FutrGYbSWY4z706dpJPL2MVR2G9sc4OOKW4hZUS4aSOIlAPmGOjH 60SWi3TRz7xlB69h2psxeOOKQQkqqdP8/ShY5Y5cDG184UdgfT+dG49iOa2uJQQkxTdwxz1G eg/OsyXS3jjZF3Els5H5/wA6tsxF2YVkLJGdgyemBWhaQskeJyQSS3Xp6D8qNe4XsY8Eci3K 3U0cjxAeXjGMj1x+FWBcGK/CZH2dhwAOnvVhzdSTsYyrRHIEYHIqC3gNrcYmVUXfnLDJU56f Q9ad7uw+hpLcoHMZbDqcqGPWojNFucHgqD83rz2pkpie7jLAmTO3P93/ABqKe1/eiQSfIrDc rdOlGlyegfaLkmPMYUudoGeT3/lWmR5a4XBP3cE1lRSSAv5qspifeuRnoOuR9MVZnuyZrd4C P3hwVHTPenYlkN8ZIbJomOTySO+M9vem6bcKbKMMo2FipbofrVm6vEBP7kZIBPXAqK1ULEAI /lYblOeuRnH60bDtoEcvmb3YfuiARk9f/r08byWEGQu7LYGMnPOKjX53gZON2CAR932/PIq1 diUFFjAzn/vr/JoE2Zk6GWVTLg7lKEY+ZQPU/j+lPi06CS32pJkLjBH8L9f61IzA28rOrK8L ZPvkdPfnNUoUuIFzkgMuWPox4p+obF7zN0sTSL8sCnJ/vYHWpGnJmKQZHGS7dAOhqHVJntYh KoXLMAynoOlRQXkMSIkhC9SccgUJaAXUWGe2wdrLgZJ6qRVm6mdrcxxIhJxhc9ORUDO0yKII woZT90dR+FVVhNjN8isScnn+If40thWuR3tmzsiyPhGPHt2I/CqUtrqFr8iAbT0bPy/Wt5ik 9tuifGc84+6fWszfczQlTKDGrFeMc4/pVJjTZXh0yExq7ybnIIYg/e7mrSM5hgVPli3bMqc4 B6H9TVe5jKoojYBt3yDqM8ED+lWYY/8AQk2MH3jaB120N9WJEqZszvZnDlcNk5zinpcLfZIU q6EfNnODj0/Ko52WZktg+Xb5VJ560W9vHFLsjlZXJJYDuRSAtW8j42OBvII4HXHeqM9sIkZn YiWMsy578Z/xqdZhmQsCGQkK2P4fanQOZpWllAMaRgYAJOe5HtQBXtbdo5ZCXUucnaT2bt+G Kum2O8AOU8vBIA6g9f51Sjhgur03G04yQobpircbA3XlO+xWXABPLD/P86GA2S0iku1RX+cg sO3T/wDXT74RhkG1MA8YbnGKG2/a4pc8YYe/T/61VbzyBNHL6DGT68Ug1Es7mSVpmlQRnfkk jIPb+lSW7RyXpQvve35YEdM1UF5GJZE8p3WTPIHfGajiiGnNJKmW+1uA+5s5OP8AIFPRj1N7 dGpk3c9cjGc/5FUJ/MuSsEZMduhzkD2x+dRXKmaOAFpFJIxgc1LawPG8oaRnQOdh9AKQhZ0Z IiY+Yv4lI++xI5rLa/miVYoomUA4JLbuD1JrckRpRGFYKQckA9QMcVUFoj3crMgEafMR+Hb2 /wAKab6DuTW06lFSYZY9D6kVLKfLdFQYJOAOgxioZLWQ3MbxlSuDlT3+lTNkKfN+VGGA4/h+ tSF0SveR7juXaQMA4x/nn+lMhVi24AoDgsQc5I4IqOazmux5asvl7cg98/4VXF2qJ5ALGRfl zn7y9j6Zqt0SaDlvMVUkRIz1OO/rUV/bm7kijZeQd+5OxxQk4cx7Svy87D3FRNMViaYP8zBQ pHfoKEhkzs9zb+WjGMgE4HbjrTtOX7LObZjGXA3MB978aht5W82UyW+NgyGzwc9vzpfIdr23 uGJVxzuB6+x9aHa1gH3yskamRWJkYlsLyDkY/D3pTPI0zBhhIzzx6cdatmPzwpIYBSec9OnF UmukmH2e3UlWB3MR0PPNPoInSRI1MrjMZYgt16+v41DeyxT/ALhS2VbII7fT1qMyvDCML5gZ z7Z70+SITXbFG/dj5mz0B4PH9aS7gMMohtizyKSAScdD6/jTVcSyBgrokgUjnjIBz+YApl5a b4RcofmX+EdBn/Jq1YQyQwqJFAIHK+lDBDZpmLQ2+377EMrDOVqC7Edjp8iwuXuLdRjJzjkd B6c1DfLJc3TzklFh+WLHGH9agTz3k8tVZ5n4Ibv65qr2FbUdGrXV6Y2R/K/1pYduw/xrSksI EhZgHLD7rA8gjoRUFrHFa27pEcs3G4qRk1YsoHgjZzIZEfkBjwOaGxPUrWSosMmHUujHPPHP 4cUrwRkKxgjYlQTuOce1TT2S8NFEMHlh05pIzLbxqgjZB1Cld2P1pJiscz5bl9jFWABwTTjG pQKhOehqTysBwrjJ6HtSx7IlYMSCoznvXfY8ojaIxHKDBxyp74p8LxooDnBbnpTZrgSKjAgF jx71FLbkkvhhg9QaFfZgWZJeCBjGePcVWdJZm2lQAoyCeD/nirCbJYVZPmIFT20v710aPAI4 OfzpLQZStY1D8bgwPQirt3bRsgfYowOlL8z7lXC4I5HaoFeTzgjHMe6i92Kw2QhABGCef4aV F3QgSHCNkEj2P/6qkkxFKdvRu1EaAwcH7uR+fNJ7AMkTEgGSynoDToyuGByNuQMdqH5aMhTn GB9aq+aztlTtDdQfUe9JX2GSxoGLM4BB4BpZbxoMxmPnr9cVXt2dpMucAgtkDrVhpC4whycE njrTejDcjMhuMoyhEJHAOaWJPKiOCGdTuVc5wKlRysQ807n3cjvR5YZ3bHyE5A9OKLpAR/LI WdlwM5U1K7BUVShYjg9gCKedqBR+lRySKxUOBg9VzU3GQLul3xnAXqp7D3NSLuTbuQFj396S IM0xJ3Bex6ZHpUrZQEKOM9T0xiiwC7mwSW5qteOUQgLlsgk0x5mSRFnOOwCjrUwVP9czZGOp 7+2KLNAVoyJnEsmd3ZR6CppEZ38zdgKOMDpUhhRsSbtuSCcjHHamIsxi2q6uBnIHB/L8KGBW jO6fLkuQpABHT1qQK0aEpjfnAB/pTLYsNxJ2kMcj/PtUq/PIxDblDdB6ds/rQ0NbjGnlkCwx gLJ1Zs8kc8VoJZyrCAtww2nOc8VQuInV0mSTLgAD9c1PHcStAQ7Kp7gjqMVlJdjohOyG3M4w yNhlXAwKzw8hyCGYnkEjgClLLNOFEat/E3t6DP8AnpUrRmKM7X3Y6Z7U9kZt3ZU2NbkFGyzc svb6VNFOjQorlN54bsPpUTNvgkDEADkMOuazkzsjcqcZG7jv3q7aakmujws7MjkHGcdunWqQ nnkmYELsAGM96du2ElEwVGR6HI4ot42KOsoUM34ilsCEtN82XfBcZ2gfl/8AWrat7dHRJJ4m BUZ471X0q0WSbzGUBRkYPetyztzM+51wu4BWbnK9+P8APesZSvojrpU/tMetvbKgk3MxJC4f kn61IblBEFMMmCcBMdvem3ZUeYisVkDg/L24/wDrVF9oM+0S/Ix4yp+9Wd+51qN0WvtNsWIh Y/u1yydCOwGKymZXuTtcSE4DsOmev4cECrMCb035UqxyrYwcDoTSw222VlXbsyrKMfw0m+gL RitbFZgwLLhVBOM//rplxbm3iuJ3kLO5GI845JHP5VqLchId75AB79fT/CssTvqOoKXQJGW2 xuD0I6A0WYXuaFqDDFHEEwypy2evH8qha+gO9piPlJ2IW+9UF0zpcIJHbyUAJCnrk9OOuPT0 qJYY7uDCAI0UgxIAM7Tgjr7EUWAryT7Y2D4Z2yWP93Hb6EVat7dZf9IVWAlUqQwyVxgfnz+l RQ2Xn2lyc+WxfhlOCfYfhWnFceTp8Um8sV4c99w44/EUX7C3GmJPtqzOV659nNVReN5jxTOG k3FvTA7dKGvxdHZAAXBBPsTkD9RUK2zPfAOCsi4bcDwR/jT9R2FWIm38+Mo0zoAxBwEB9Kls 4mVWhKgwjDZPY5PA/KnQ2j21tdMZAzH7pbAOQoxn15qrazzRJJFIrKxyy+YcHP8AQVN+gyS1 mVbi4hVW5fd0/I/mKtQyhJkmkPKt/EOPTB/OnW0IkuGKgcLsds89eDTLnT/NgKSOuJMZyeDj /Ipp2AIkikK3YkDOCASTgN9RVSRHknmJTY/T5ehPHI9sGmx2ItpjHJLypKgEkgDA7e1a8Bie OaJyvyMcEdiO1L0GzHso5mtrqE9QcEkZ5HH+frWnHK40gMZckrgttHH/ANfpUVsuwFXT5ixf hgQQfX8MVNLHFfWbwMWiweTjFJNrUbsyKK4lk0tZZ3IIyyhVHQVXid5L/dPM7MvJXPHH/wBY 1ae1FpYx4kw6D5WxwT9Kr/YoYLeRyT5koAGe2egFNMkWRAUZkiw0i7iQD3Of61pKkksZAIJz y3NReW4SMEli2Afp6H2p0mpRRTokaF8g7mAx34x607Bdsj8pUmjt8kNt4Kdc/wCNPv1dNPf7 OimSEZG7kN7f1pxIEiXCtvAOQf7ueD9aiS8ea+jAOImQszHjOOnH+eKUVYTdyGynM2mvIFRr mPllzwT1p6XPkWzicK7HAAIyD/n+lQQy24kmS3Y+a7biduAR3H8/0qybVJLKOJ1BCDOOh6f/ AF/0pvfQFtqMh3m2kuByJWAGckYxycflVVJk89FWMxBB/rMgEngcj1q80kltbFIiGIYBARjG egI7d6ggu4JF8tljE3U8feFOzEXEuFuo9wGSB8yYHP8AjSQMZEJUFVyOG6jtiqL3P2K6TCs0 cjFQFFaTyIkYMbYZsEZ4zzn+lTYNirM/2NyWXO4tt+Xp359qngujsYKrysckMeNvHQ0TKJ1z EwTd3NNlsECtGJGUlSpcHnH+cVSE9SpPPJd3UdtJH5cZxJMOp2g/41MwSW5K5YLIRz2Ix0/T NVhdrbXLSucLjYflyevU1olYXjbc2Cg7du44obHYp3kUpJcDKpyAT971P9KqPbCWWIFNpJ3g Y6n3rWiIuOQ4O3nIBrOvrmKCTMrZjAJJVeg9zRZsLk8VxKxBVTlAVPY/hVuSQ3FmqyAjA4I6 is/TLrzPmVP9GddyMCeQfrzViQmdXiifaVY8+oHJpbD3HvGLeEJExXruLD7xPOc+tUEDy7pQ iqDnapOOe/0qaKNCyrMxZnGQxPKnOQf8+1JBCXlMrOVO4pgdCf8A9X86LgVmEpv4GmUBHYjc DnOARg1qToirB5bKq4bgHqQOP8+1NkjSNQGYDGck9cn0/Gs3VVMNukqSlXRGOT3z6D8DTWpJ ZtELlPPJeZBgv3J9amli+zxl4CpdTjcaj0ySZJgk0se2QDB4+Y4yR/OjfE/mwiQ4HYjGR70W YXFjmWKBfPkJdm5Tj72Ofzqb7LJBBIu7YGwNqHPbj9Kr7ftMDB4CrI2VJGSQDxyP61eikYwL 5rgKuMlvTsaA2MqWTbFCqK2wtsJbg/5NW0tlmzE7+YmM5zyKZdwefPmMrIgYfgPwqvd3TQTC BEDKwyTvweDj+tGuwbksvnQmeNQHKkMAxOcE9AauBI2jVRiSHG5QeCPY96rW4uGjZpE2tjaR +uRS3Ek0UGVUsQcsCOevNJ2YFhYYjjywAFJCoO2etUJlMlq0WCsichh+dTSXEYZNuBL3VqbE DMoUqVfHzbfX3o2Ag2iZDMA43IB8rEbWx/Sr9lJnMJVvu9SQfxqEI0UUUcaggNh9p+v+NW44 kkljuO6Ag544oYFe7mlglW3iYiU85J+6Mf54pLectNmN85GGyeT9KsXFqb1/M2gIpPI6kc4z VcWwtgAwzKDlCO9DbC1x828yK6yghST+BFSxPIIykzDI5LY461TlV0uI2lUb5Btx/Kr0FwMx xsgJAJY+vpTuKxFBd7oXwWyAQR2PHp61WubXNrFdOTuQfOR371dkt28qQ+Ztyenqufu0yb/S dL3IRG20oV6g4NPyF5iQIPsqSRnaNuQR70w28m6NHwCi/Kxz82TkZ/I1TQtCEjXe0affC9Ov WtySeKa0UgZORkAd6XkMq78XS+YQqgZYHoeO351aiLfKGcbUHp19DWfcl5ZFQRb1jI3FuT0x mtCNVZkEZ4HGB2yP50m7BYZL+6uYpIpdqSZDox49j7VJHHFbQsxwwAyT05/r2qnJaojKJAWU KOSeh7/hmq00k6BYNoMAIYEntnIB/IU1ruNlrbnzGbB4LKFOOMnBxT4pJIbeUtECm7JHUkHG T+pp0zxqYyEyZBs3diO1MdHS7kil3MhHynAA/wA8/pTJvcRWOyIQhcTLgD0x/wDWqdt6gKHP fPr2qs0KwRpIxbYmMFe1Oiuo5ZJJ4yWbIOGGPwFAadCOKUyq8N2oVvlxnozdBj9KbFJNDEhh Xe0mFBxyRUl1cQNKgcYif5iMcgjtUkaqsseG/djoR2z0NNi8yKOSPztkjN5ZxvXHzIfXPftV mOYywlIxyOqk4yPWqdyqx3Qu1JaIrub/AGh0xVxGimRXjHytnAznH1ptWFcevmR2+9xnntQz DcWJY7uRg8Dt/SobqSdYF8gBm6spPUf5/lTYrohACyA9xjOD3oFa5hLHILndwU6cdOaY2FVl YjJP4gUBijYI6HHSnsrSzKoIx3Ndmx5ZCIFkXcvBGRnrz7VKuUAQ9cbc+tOS1Rd21ig/i9/e nMqqpXGQpGTTYChVt4guACT0FRSH5j5ajJbqaQJJGX83aQBw3tQ0blh8w2Y5OKS3GyVJWZ84 zxj64qMkyPvUHAGS3qcf/rpEiO7OSfmyOaducu5AXbnB9RigRKqAurt83GWFRKw8wxLyoGWz UmW6FgFxVdF8oliSSfu9uP8AOKVxk0koTBIyvT5e1U5IzhwoG0t8g79asGOQMpfk7cDnimiN lbeWLqpOAB1qroQtsHVMlAFz1I5FSLEvIyoJ64zSIRhtqH5sde1Od2UFmO09jjqKl6spDpIc gMMKw6Y708MY8ljtPr2xUCTM/wAwIwvY+lKkilsEA8dDzUtASSKXfeygrjJI4OOe1QzxplSp PPU8fnU7Sr5LPku2Og7VCY2VUB5XbyPen6ARxCYRBjt27cgfypNgk3ZJznAz24pwcKpRSoA7 f56Uwbk6jIJ61Lu2A4bQiK2CGP8AF3poWGJHzIzAHOCPu/SnllMYRRyFJXd0zVdx+5ZiMMR0 z0PpTAlk3ysrH5QeSOwpA21jtBx29aWEsYxuG0Z+UHtTJMwrlnGSemOtJp30AYysu5gT8w9O /NUrUyLdyGQlUxhc9/Sp2naV22r8o5zn+dV5GY4cqcZOAenuf5VSTDYtyTqswiUb+Oueneo5 bjdHsQnJxyRimpGxmEijC47dzx/9eppUjdRkkgtkYOOaiyTLbGRssf7qNRk8nA6+tEnyoV3A bweG9KekUSuQsjEg5wKZdNGEZUxu7A0noxFeS3jigYliVA54qrNKxjTyEXGCxFaL/Z3Tyhjk dM9BWfLaz24wpLBiSABmqXmBCkso3ROCAPu5HTmtC2WWRFUAOCcH16VCZDN8jQsOg69D710m lWgSRFZQVb7xA6GonKyNqcLsltrMwN5JQ442+59Knt1uJLZVGbeLbtBJ+Y8U++tmgZZQ5254 B5wR3qnFfeVHK8r/ACk7SwzjPQACubc74rQseSsNpmGRpxjyzuyM8/8A16zVAnnkgLMsmSOR woH+cfjWhayslu7SkyIWPXjPOB1qSOzCGWX5S0rCTGMc+lDKTsPNvJsV43GEXAU9OBxUCeYr RiUoJUQgTDpnPSo59QFvIiSZBJ+4eMj/ADioLib7VNmBirIOVIyRg8GjzHboS3lwY7naF3yv GE244HXJpsFtHbxtEDvlyCDngsMEf1/KriSPGhabaFL/ACv6ZFMXyyHZ8iULyQPfI/lRcGrI gSYzaXcO219rl/mHHHfFW4JFtmVAQqsvHHTgjr+NRq5s7WKJYwVcYC/U8n6c0+UxhDEvzsxJ UDtxSuIniVba02OflYHcBzn2/Wqgks5IJI2JWIHG3P8An3prTM9uURyGU48wdAeuPf0pq2O5 fMSNYXLDO4Zxj096El1G2JYWcsEsl1EwWNxu2sMAjtx2q4smJCj4Z0Xdt9MdP51VuWntbNgZ w7bwzFxxt6Dj/PWrNrEJL0TyFS7LgsOFA7UxGZFdXF5LcyiXbbgDk9+cfyqzHFLKjGaRpOMK 5PTnoPyqYWyJZ3kKpsyxztGeOOlVAstxpU1tCXEwZVDNxjkHp9DRd9R6dDUtMLcTKwz6nHPN I85Vdk7BfvAfoQPxNMg8yOPzQxwzuGDHJHPGP5VXu9MadQ6MoMZJ5ODnP/6qBDgszM8iMfNb ru4HXPH8vxqe3tI0jkj3orkBnAOe3Wq5a5NxJiUGNZGEYK8kZwP51prGjZmKA8FeeoHHH04p DZiTwwwxjyZdrxsRh+49f/r1fgZNyiQ7lkUYTHU+9JeWq3duFMSpt5i2nr/hUsaKsiPuO9Rt AznB/rQwF1CGWYQqjbVVwcYGfpVUykyiLaUEO52Lc9MYH61bhbY7IzE7jlTjOO/NRz29wWVl VWVgwOT+NUTsNjnKSKlzgvJlkboB6U23uJnumil2BQCowMY7ilkIdYIguJAo+909OtMkkjQS SxktKAMEnGT0/rU3ew7It2MZHmqHTI+YAD04/wAKz7hYkllWWRg77cH+6Rx/IVOv7qaydtkc jAqQDgbQDx+oqS4eJ7ZvJdN4P3m5C47U/QSK9tAPLO0KJD91gf0/nVxJVwwYkmMjj19/6VQs ngEOxE2SSLyMZzyR19jn9avxWbN5UsrLw3AJxj/PWhKw277le6jkYzENgkZRh26Z/rWZDKHZ BcS7DkgMcfMOPyNaN5NHb3K5J3gHKg5wPWqb2wnus42gDd834UN23CKuXfNWS3xEW81WIUlc hfr71NaiZRsuEjkJKkODUFvIFm8vC/OMBiMZxT7hDPhIrgxyqcxkdM+9JAyWRibkQxoNgIPA 5FWJUeSQ4IGfQ1TtrnapEkZEoGWK/wCehqeS8TBlMoX5fuY5p69BAtpGzlpEBYdj3H+RVDUL 2KzlSKTKmRfl4zkHj+VXN7yoJANzdcbsY9qzrm0e81KCd+I0xhXPIAOaFZahv1LFtD5FuqO5 Qr8wz1xVa+hEskIZipAL5POM1fkj3TmWR0UngYH58VThuFu5zGyhVBwMkc44yKfmAWllKrrk uFK9eg/L6Vrx2ojRVHGM4P8AeJ//AFVEzyJAwY42HIYDtViCOZW8osWx8wYnnNSIxpUcX622 3ACDc4HJHbn0zU0MrrOsLFNgHDetPuoZorwtvjKBfvHqB/h0qGRpGjOLaPapHTvn/wCvVMLk 9/bNeyJGXCKv3WA6ntn8ay4rqGRCjRF5VbJSUnLDHP0rYZ7hDnasiYwwHc1isrS6pJKAq7MF WxwpPT9aE11HY0tlpe7U2sHBDIwHKdPy6Y/CtGCDbG/mgF/ulx3qvD5i24eRV3ZIkx3A6EH8 6e7SPC8kR2kj7vYe9K/cRFc3KqfL2BsfLnjrjIqqu652wXJcbuV9/UfrWbG1xbSSySBmbAwu Oo9fzragZ/8AWSoASOmcim9NgRn/AGd9OjliR1zywbdxz/nFWtPhSW0SdcFlU4PfrVDUVdrh FLFSzBT6P6CteyR4F27AygcgHtTbEyG1uJmeUN0DY68q2e/qMcVMJZppP3YQkEiQN6djTfIg LyOpPTkevvVGN5DdmXy3UsMYPTOD/n8aV9QEuDHdODEd0w+ZVzjGPU1Fp9yrLiRZF3MTuByB x+laMCCKcI+GZh99ex/+uKz7eJ7Tz90JIaXKEcZBHP8AKq0DUnbEsMqW8mJF+bbnG6p7O8ll CCZcNtIPfntxWXYl4dTdRGfnUk+uOv8AKtNoPMulMU2xsDIBwTU27DbNCK83qxR87Thgf4T0 qG+V0aO6i2mReoOeh9Pesdr2OO5miRAqFiwbHGff61vRyRfZYwuJl2gp7/jTs0xGdcyNNdxO QWlIxHgHHY5z0q5IB5jIpAdRkFTyCaLaKNFbDZXOQGHKe3tUfkSLI52s0bndlB39KLCuTrtS DzGZtqr35NVDeEuYmiESnOw54bPb8s0+ScPIII1ZeuQQRg1WvoJUlVmbepTKn8Mj+VFhouTG C2sWzhGPqePrmq9jOTGqNtWJR8zj+I8Af4/hVd3N1pse9SsxYJjHqOv0xWjLJa2tp+5KbVIX HWjyQBpzNal0lbLSNxgZ4qSUxosiAsMkvlepA9KrpIN7SITwFJA6D/CknaNZoSjkMP4cdjj9 OlFhdS/ZxRXUKzRsyllByw4IODVKQ+TqbwlBgocHPX6H0qlqd3drP5Nu2FVVIAHf3/IVYsLl rnTf3uTKjMkhxyATkD+VVZBra7JZj5hQAMzRkMcdMcelRQXE1zfMmQwPX0A9a0IPLSLIJ9Kp iEiNlhzGpHzEHJI9KSAtSTMFUBcgcgnofrUQUPH5cR+ZSDg00xutikZjIIwF79KfcoqWbSLl ZVHy84Oe1HkIp3YeO5gLRbnK/MM44Hf69KL6+Se3kjVNrpjcVzjIHt+f5UzMsqoZCGk5DHr8 p47fWp7KNLSQ+dty+0OcdB0B+nNHUGSWI8yCEtkRLCEYEc5zn+tVjaSxQXMCPslDiSMg/eUZ 49s1oWkSSw72QBovvA8dPT2ps8gYiQnEpJG3uBxx/Wq1JKa30radG7xP5inY2RjPB5FOezW8 bzzM8ZbqIzkH3q1LuuVGVIAboOo/zms2602Zbl/IRvLJyMj+VG4J2IdimTdxxkj601WxIQQw I5ytRurp8+ThevFOQucfNkCuw8sAsjAkMS3T6UxlZgOD93nHGKnUeUuVON3QGoCzSOzFuAfm +mKTuALKwmCFAM8k+vFSFuRjkZwKI441BmdsoMkAdTTVV3fEYCIOSzDmh2AlZirYwowM4Prm meeN7tsHzHnJ/Wm8jfs/i6nuaRVyvm84z0x/OiwXJjtJYsMAj0qMnc2F+UHuetKHDScnCquD noagw0kqxxtnvn0p2AuyRbYQ2ctkjk+1RhdsLndnGee/1pLo+WFUnkYG7NEszXAiSVyUiTao HQDJJH4k0ktxkMcxYOVwBgbQ3c0kuZVAwQrE4IHOKc9ujHdu+VuePp6VZgCAkOBkD5RS9AIx HtVUHG3CnNRy2sp27eMHrjOae8m+JiAeCOO+M1ZEqDdtzvCj5f5UkwsQxxlochlOeajDMGCY x7njpVmEspOATgkc96R5FZ2Xac9SPSgCm5CghgoCnI47U1t3DRhtueTmnSRIx3AZxn8qFjC7 W7Ec5oYDkG5j/MHHNKqLuPyjnkk/gP8AGkVSJN+CFznnrmpCjMS5IUVL12GIFCryMqvrzVdl jmQiQZz93PWk83kyEkjHPNQrGTtcuSFHAPSqsAfZooWJ3HaRjBqFlKbEAyT1yOKmyJAVdDnl h71EZkhKhC7nIAGM96SuBDcvcNDti+VO5HU1XheWF1UsGJPQHJrVLNKNwAVc9BVZFS0JCocY 4Y0J9BiOZFZkVTnI+YDr3qqY90qmVlAbjNTTStNLuCuU25ODinKm64UFRhevPQ+tLYZGdsM/ yMGVBipnldt7lTlRwKdcRCRtzvtCnt+tU7uQJCdsjLuO35fSp1KWo/T5UjDpPzu5bHXNdlpy BY2Oclvfg1zmhW8IQOx35BA3dcdzXQC5jgmZE4z6jv7VlUabOyjHQ1Rcq8ROPmVMlcZNc0iR yX7K4JijIVQMYJ/xFSW0t8s0pQxjcwZsnov/AOurdrZPDcRzNjvlT796zdkbpCS26OySvJuT 7ye3f/GrIlIOSBsI+YE9BUQaOO/KhsJKpYA/dJznj86rXsOy5nmWQNG6kbAM8nHP86L23Glc rrZpdgi5kxLk+WR12irEWmfZomETHJXHmD7zDH6GgXltA4ticOgKhiOD/nNWZr5LZAozJtIU jpjnvSeg9QhJk/0aQK4jAIYjvTL2CTyPkIBJ544rPmvLu1kj2hAXbkNyNueDn8R+dXYNQlFx 5Tor4QkqpJGPXJ96LX1AfHbKkZj37F3bkbqCT2PpU7KY4fKCxibII2ng+v6VDJL5d2pYE28w 44GOtNvZPKeMIpOF4Oe//wCrI/E0C8hlxJDGApALgblGDjODmsvTZrjznDvujZgME52nnn6V fgtUZ3ee5DS8gLj+ftTTJGtyUlCxKxLM0f8AFxjPtQrrYonECXlwY5DlFBIYn74zx9feh1Fm 4cHCrJz7/X1pbrUreCBTEYZTtIj8vHy8cfXtxT3xNpqS4zvCvkj1ByP5U7OOrFe+hBLdTeeX hjCmdS3ovA9O1JDbq12sjSeW+wFyOc88/r/SrEKrJdQI/wB8Rk49BtHX8jUE4ggYN5hiYNwo 5yPShu+oRVtDT3hPLEoUEnKbeQanLqlsURxuJIyRwKowwoyl3YnAztB+7xj86gW7U3v3sgHP T5WGM/h0/M0kFuxYsoNzSuWMm1twx2OadJKyXLAk7gR75zx0pYZgW4Usw53L0I9arJcyPdM4 i3Rj7zgcgjt+NJD1JZmRMJuJeJeQT6Dp6dAabcuVkiCMVDnJfHAH4e1RTMtxMGMWfm2gZwcd KszW8axE7sYXagyRn0poWxXtpyySz4BYkkYGGGOo/nTzdnbuQmTLnBHAH+FE58i1LLHiQHn8 eOlY8gmlmMD/ALpUZWVWJALE8Ee/H60wW+pqT3cTBRMoLhcrk7sn29aqwzwMg8qJju5+buQf SmOolEcJjZZBnBzgEY5wfw6U61k2CMq48tXAYd6hmmiRfaE3OyRiO5zn+QqtPDGls0as77uf l46VckjMcpaIqAMbh7eoqmbqFrg2kRBYk98Z/wDr07EqRPHa+XZfvHy/3i3Q5zn/ABpFvZII 5co0gDFQQOpGRj9Kcq/uiolJbnccZ596mtbRLe3TMpOWzt65OelOPZEvYpGxj3ieSJiXxwDg KSOeas2jCaE4jEbAlc5yR9fwonu1WALNsChiJGY7QB0z7mpoExK5jICjaVzx+NDVguRSWchk hVpec9gMex/OoxIqzq2/5iw3KACBkdKu3DR7lJ2bw3C9OaxGgWzuVjAJSViwJ598Uth3uWZ8 Syu0e8XAwpVTg7c9/wBamt4Xt7g+a6Hcf4uSCecfrTra3kDl2wxYHBPP0yfY1FcReWWmcENw WOepHQ/nVLUnyGIju7LcnyyvAI4zz0NWljjyHk54wGB5FUNQj+1xq0btyQc+h/xqeykZ7aSC 7+YKcLIew7fWgdmT3V1DFcKmzdKq7hkdPeqohtJG+0xAhkTLqvb/AOuDTtRSSZnkwdycgDuv cD/Pam2dm8LNtA8mVc5f+E56UOwLa5biikQvum8xdo2gj/OaiL3D3QZXJYxgBR0znH8iKlJa 3iMbY4XKMvtxUN0RDKpjdsFcA9cjsPw60WERNLM1x5UsauJWAHoKRTdywvGzhM9FVcAYPerT sZIovLjGQAcMQSWznr+lRpdSXal1XaibgCR1HrRruA23eRZWWKXaeCUI4P0NWVW3jjczAKZF +f0+n61ScNE9sqMgV2CknuatSkqhZsbTwwPTFK3cNyZblIY9iyJIR90f3gRkH9ahv7oxpL9m jEayEmNSc7QTwM/p+VQ3Kp5sSqeCgUd+M+v5Us5jSBI8qSAV5Pr/APXxTWugtgRVe1MhkLyD IwfT0qLzmRooixLMoIHUc9qjhjulkKeaht3AKgjlPapoJ/IjVJFyUVmznqB/I0AMuoN2JS4b Z8wB6Z/yKkm1EREuUZWIPlgd6niCBQQrE85/U9P0qIwDy1VApkBIDH6df/r0xCWruB5gib5m O4Z7HkVLNLgAJhSOSCOvpSQFo7hVkOE24I98YqC+hPmoAWIAG3accc80gLGNzq0nDMoPcc/1 pLmXyikQxIR3Jxn3/M/rVJZWnLxrnKrgA/1/z2p8UDyIgcrgrwOp68/ypphYcqxJtumDecFG 0enrVeFYcxTvNsYNsyfTsKmSL7TEZMsiJIQD3zRZ21v5jsUAQnnceuOh+vAppgQTacZXcDd8 5JBxkYx+lWoUMLiFX+U5bcegXFO+0JK5iV2QqoJA681JFAu3zfMMuBkH1zUu9x9B24TWEjJJ vOChZuP89als7soCjHDqMjHQ+orOuBJAHjQBY+CpJJwTVTzJbuFITkur73fuF9qvQg6CW7jE o+TDZ+YkZIHrWdeNM8YjGAwfMbKchgT0/lTBqEfmsjowjI2rJjotWGnhgiCFd4ALKByQRzg/ 0oDYrOuw+cH2+UflTuo7/oTxVWC1l8l4+Fh3KyyEHBx/+upr+FmRLkhhnllH481JHI9tA8wA kCn5o8ZypxQ/IaL2w2UAZCZMjn0NV3h3qj/dcDOPStFLuCW3Qxr8pUEfSo5HhmQMjgdxkc/S l5C8yJIg6rKUG8AA5psDrHqM4A3K4GZAeAR/9b+VKg3xExyOVb7yDgj2qSSBFVWGU8shtq9x /wDqoW43sZtreSWbSrIdyhjuGeVPfHtWrG8M22VSxjcZyen5VXS0juFm8zYGdm59uxqs8P2m UW6ts8kBflP6+/T86H3EbUJj372J5JxzwT/kVU1G3S7WNgSDF8wwe9SrC8EEYyzKhwSep5PP 6020RZ43SdSOTtYnrznHWmnYXmZsTGOFIY9xKBt5HfB4+tW4PMk+zythwccYwR1xn+Ro1EeR GojIDAgE5zx6VaSBJLYxM5LuDkgkEZ64NO3cTZJKrtbSrHhXZRtPt3FZ88UctxbpdKyyI3Ho 1NksmtwskV7c7V/hY5I/Grxj3Wf7ybc3UNjkUn5AMMKSbgJCoyMDtn3qO7nUSKHmYEKB8qBh +tUXmk87YrKSoyFPP0z+tN/tU4AeHDjhs9z61UUJ6FUSfOFcEHrg1JIirATH94jcVz2zz/P9 agm+9/wEVLD/AKh/+uZ/mK6zzCvhUDMx3cYw1WoSJI4zxg9apy/cb6f4VYtf9UP93/GnuApB IPB2ZOBT42kbB4CheQPpSQ/6lv8AdNSW3+rSovYBHCFvLxywGW6AU7zM7k6Anke9RXfV/wDe pIv9c/4VQIS4jBJCLjOaZahbdVZuM8nPqast95/981Rf7kv1oi+gF1gZGOVG0jP0pgTIGAM5 wDTrf7q/7xpj/fH4/wAqT0KGBmL4AII6Y6Zp5WQruwo9/wDCpB/q3/3v606b/j3T/e/rSTEQ /P5yFQCSPmqaFcPI7dwO/FVk/wBe/wDnvVh/vn6UXHYWFxFIQ7cN09qZfFYjE6s2T6dKjuP9 ZH9F/wDQaiu/+PWH6/40W0uLqWIQJIw68tUbHbwy5VjjOelJH/ql/wBymj/Vf8BP8qdgZOHA UYYHd0zSsp8sKOx/z0rMtf8AWD6D+dXZP9Y/++f51L0Gge3JhOSCuMH+lRGEBQrEhVHFXB/x 7D/eH86hb7rfjSArMoI3DOAcgjvUSWyOZGOAzcKQeRUy/wCqX6mqv/Lwv+8P51SC1yaO5CZi PDADfjsaZIY2xzuyM5J5qI/6+b6rVZfvN/1yf+RqV7wy0dkURQKQmD+NQFpFdBCATxuUnGak n+7F+FQQf8fbf8B/nSQyXMrGdZvmQsGBA/zzUmm2scgXz/m7bc/zpsf+of8A3j/OptP/ANZN /vGkzSCu7GikcaTR/Z12IFO49gACc/TNDyzTeafIUSoAoHX05P6/pVn+F/8Arif6VHpf/H3f /wC+v/oNcz7ndDYntLOWAo6/vFfhvm6e/vV9ZGlleFVDNGoPXqT/APqqvZfcj/3alX/j8uvp RuyiKaE3cQVSyyqQwfHOe/FR2z+Y77kIMhKHd1/znNX4+/0FVpP9Y/1qJNouNmQwx/ZJEiCq dykOSAR9P0p1zJCWLSEFk7FeMe4qJP8AXL/10/pUF9/x9P8AVP50/IHuNvY/tiwW/wB1iQWY D7vHT68VatSkEYRmJYDaGPJpn8UX0FSt/wAfsv8AuVPPqDWhWuVmezkjjySrHaR+v8qXLTvC GGBEo3kn7xx/Pv8AjUx/481/3j/OqC/ci/66f1qot7FPa5LG8LzPKqFcsVxzn3yarzwRncFk PmH5NoHQ9R/Kp7vpa/8AXR/61NH/AK60/wCu3/spo21Fd2MaxspLR5Vv4N8TSLhT05JJPt/9 eulSYTQuLdlRVkKAY7D2qtcf6tf981Rs/wDUSf8AXZv503LmdmCXU1pkaNQ3mozbcAhMH/8A VT7MLPEjusYbr9O2cUt1/qP+2gqK2++P9ykkthNimdhPLKNpjxtAB561XsYEjmeMsGUnPI7e 3pUTf66P/dFXLPo/1pzVgiyXdHLcuoBQAEMB3HarJiRIht+VFON2eo7ZH4GoF/5Z/wCe9N1D 7kn+9/UUqSuE30JmSMEkAB8feOOap3K+ZcqTL+6Vcoq9enSp5/8AjzSq13/x7Q/7y/1pPQIo sxNEbVhK5JC5XPIz1wfTNJcyxRxRvcgZi+YHGc+n1qKT7jfQVF4g/wCPO3/3aaaaQOOpFDKJ 8ugcrvJXIwU3Hv7Z/nVuKZWiTfAobJUdMN/kUyDpJ9RTH+6n1apVnqV5C3E23eMhSFGcDkep qophmukMAX7xEj+46Y+tWJP9Y/8A1zP8qydP/wBXcf8AXR//AGStNyNjflkTy3Ma5IUkYP3v WooLhZkjJkKKG/iBB4//AFUlh/qH/wB6qk/+tb6t/wCzUkrbAX7m3W9tmBCtsyVBGcjvUWg3 vnxzRT7WeMDaTkfLU2mdG/3mrN0X/kJzf9cX/nTbBLRmq8ZLH5vmB4J749aqxahHPEBLE4cA ErjIP+H0q2fvp/visw/8f7/UfzFJ6AtWadnLElv5glypYgAnH14p0sa3kKMsgBJyoI4IrKuf 9Vb/APXQ/wBK1v8Al2k+g/nSTvYdrFN4Wt2SN1K5yD6N+NPnYQ2qMFOEIyM89Qf5VcuP9VD+ H/oIqrP/AMg6f6r/AFpajWpBc3QJnWA7nVflGc89f8/Wmm9c7l34jHLR99wH+H8qr2f/ACFb n/db+lNk/wCQgn/XU/1q72JNSO4icFm6gYB9eKqrdIsS+XEWkLEEY7evtVVf+Qcv/Xb+oqXT uk3/AF1/pQrNXAdaJIbphvzEygk5z+vbp+tWgqqivE5ZFYkgd6WD/Ut/11P8xUFv9yH/AHk/ lSTvqNomljjjW2wpYeYCGI6ZP/16sE+XGwD5DYG4DvUMn/Hpbf8AXdf51K3/AB6t/vH+dNkm VKlw80lvGCqsMZUdvrU8dhJGjLIC4PyyJ14rRPWP/cH8qmToPqP6VN3cbd0YskU0UqsTviPB 9/rVZVea4mkjfbCgI+Yk9vStqb/j9uf92sW0/wBdc/8AAv51SEXyyxQoCmN4GDng1bQNs3Jj I65/pUE3/HrD+FSWXSb6n+tJPQTMrUHFjhhLiRnLru5HJ5qS3kl+0JIGZkdBvB6LnriqGq/8 hKP/AHl/9Crah7f7q/yqnoBBbW37wOzOZAMbs44PQ++KZdRyWf8ApZ+YRsFcL/dPenWP/H3N 9D/WrE3/AB53f+6P5ii2oX1IluB5UsBQIG+aNv73Qg/59KrzWbS3HmIxOHDYzwPTFJd/6q2/ 31/9BrSbo3+9/QUXCxTiW0S+ebdiThWI7545q7MQIx5YZSzDlT29aoWn+qvf+B1aHSH/AK5L S2Aa+64dN4Ji3BQO5Oe5qyltFFP+6VFJHQDg+lRWf3x/v/41b/5eE+poaF5GZPlbgLcgRtnc HQfeIx1qZLfzr5F2gIFDA55ODn/CpNR6J/11X+dJp/3H/wCuZ/pVMm43UbhAjZRsjgjH8qNP SI2Spv3kDPHHGe9QTf8AHnF/uj+dS6d9+X/dNTfWxXQivr1rZ3WOEls8Een0qS0YmPE6Aq3Q H0PYVbuv9YPxqqn+oX/cT+lPmvoJqzH3yq0bSxrIGPOU7Edzis8Xdx9oOLnJC4AcbQc9ue9X U/1y/wDAf5CqWpf8fJ/D+RqttBE53QQp5g3NjGFPO01CXltLkvCXDMueedy9fxNLd/8AHxF/ 1xT+tW7v/XJ/uClfQEJaXcs0+GdmTkNnoeOPzFLHdtDHHFL5mTwehwenX8Klsv8Aj3T/AK5/ 1p199w/Rf60cwrmVcIIZnjYl2cEMCT17Gt2xlAtlLjDqoBz3+lc9qv8AyEZPr/7KK2Yv9Wv+ fWhsbVxZr2NyI4nUICdzscAYwMfqKf8AaGdC6KswbgbDxkfSqD/8g+5+h/mtO0bpD/vf4U29 EyEya1tD5zyFctgsPY9Dz9DVSayLyszIXz0PStdOo/H+dVbn/XH6CnEZ/9k= ________________________________________________________________________________
Subject: Re: solder or crimp??
Date: Oct 14, 2005
In the "For what it's worth department".... I'm a lurker on the list, but I couldn't let this one go by because of all the frustrations I'm having right now with my -6. I crimped all of the connections for my electric trim. But, lately I've had a series of "ghosts" in the trim wiring. I've decided that it was my faulty connections. As you all know, the wiring from the Mac Servos is tiny! So, now I am going back through every connection and soldering everything. I'm sure I'll get shot at about my crimping tool or some other thing, but I haven't had an issue anywhere else. I've got about 500 hours on my RV-6A now and this one maintenance issue has caused me more headaches than anything else. I will be soldering most if not all of the connections on the RV-10 and I will pay a lot of attention to strain relief. Again, just FWIW. Dennis W. Millsap N464DM, RV-6A Diceman ________________________________________________________________________________
Date: Oct 14, 2005
Subject: Reaming Flap Bracket
For those with the slow build wings, I need to ream the 3/8 hole in the flap brackets. As this is probably the only place I'll need a 3/8 reamer, has anyone used something else? Has anyone tried a Unibit from each side? Just looking for other options before ordering a "one use" reamer. Thanks, Sean #40303 (wing top skins) ________________________________________________________________________________
Date: Oct 14, 2005
Subject: Re: Reaming Flap Bracket
I used a unibit in a drill press from each side. Worked out great and looks good. -Jim 40384 Sean Stephens wrote: > > For those with the slow build wings, I need to ream the 3/8 hole in > the flap brackets. As this is probably the only place I'll need a 3/8 > reamer, has anyone used something else? Has anyone tried a Unibit > from each side? > > Just looking for other options before ordering a "one use" reamer. > > Thanks, > > Sean #40303 (wing top skins) > > ________________________________________________________________________________
Date: Oct 14, 2005
Sean, Myself, and another at my location will be doing SB wings. If you don't find a solution, buy the reamer, then I'll buy it from you, plus shipping. It'll be the floating reamer. Or, check with your local EAA chapter. They may have such a tool. John Jessen 40328 HS (hoping to get it mounted on the mantel this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: Reaming Flap Bracket For those with the slow build wings, I need to ream the 3/8 hole in the flap brackets. As this is probably the only place I'll need a 3/8 reamer, has anyone used something else? Has anyone tried a Unibit from each side? Just looking for other options before ordering a "one use" reamer. Thanks, Sean #40303 (wing top skins) ________________________________________________________________________________
Date: Oct 14, 2005
I just passed the 3/8 bit through the hole while on the drill press. I then pressed the bushing into the horn (wait until after the bottom skins are on) with a C-clamp and a socket to allow the bushing to center...not big deal easily done no need to ream on mine. The bushng has to be pressed into place. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 14, 2005
Subject: Re: Elongated hole
John, cut off the tab flush with the rib web, then fabricate a new tab the same width as the old one but with about 3/4 " extra material (length), bend the tab into an L shape, rivet it to the rib web (2 rivets should do), match drill and dimple the new tab. Deems Davis # 406 Wing Main Spar http://deemsrv10.com/ John Jessen wrote: > Folks, I know this has been discussed before, but my search came up > with examples not quite the same. So, am asking anew. > > The part is one of the nose ribs for the HS. Using the pneumatic > squeezer, working too quickly, I punched a hole next to one that I was > trying to dimple. It was so close to the original hole that it made a > bigger hole, about 3/8 inch, but oblong in shape. Any suggestions as > what to do? An oops rivets could not fill it if I were to drill it > out. The picture shows the elongated hole in the foreground, with a > correctly dimpled hole on the other side of the nose rib in the > background. > > John Jessen > 40328 HS (Finally made up my mind and ordered the SB wings today) > > ________________________________________________________________________________
Date: Oct 14, 2005
Here's a link to a similar problem that I had and the "fix" I'm suggesting http://deemsrv10.com/9-13and14s1-3and1-3.html John Jessen wrote: > Folks, I know this has been discussed before, but my search came up > with examples not quite the same. So, am asking anew. > > The part is one of the nose ribs for the HS. Using the pneumatic > squeezer, working too quickly, I punched a hole next to one that I was > trying to dimple. It was so close to the original hole that it made a > bigger hole, about 3/8 inch, but oblong in shape. Any suggestions as > what to do? An oops rivets could not fill it if I were to drill it > out. The picture shows the elongated hole in the foreground, with a > correctly dimpled hole on the other side of the nose rib in the > background. > > John Jessen > 40328 HS (Finally made up my mind and ordered the SB wings today) > > ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: Wing Tips Don't Line Up
Date: Oct 14, 2005
Called Vans on this and they recommended cutting and re- epoxying the trailing edge to line up with the ailerons. Scott said you may also have to cut a few inches up the rear outboard edge a little bit as well. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB wings _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Subject: RE: RV10-List: Wing Tips Don't Line Up Best way I have found in 3 planes built is to save the wing tips until the wings are on the fuse. Line up the flaps perfectly in trail and be sure they mate to your fuse as you expect, then be sure the ailerons to match the flaps (or adjust to make them match), then fit the wing tips to match the ailerons. -Mike -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Subject: RV10-List: Wing Tips Don't Line Up I am attaching my wing tips and have all of the nutplates complete on one and the other drilled and clecoed. Neither of the wing tips line up with the ailerons in neutral position. I have clamped the ailerons in line with the flaps in full up position. The trailing edge of the right wing tip is about 1/2" lower than the trailing edge of the aileron. The trailing edge of the left wing tip is about 1/4" higher than the aileron. The trailing edges of the wing tips are about 1/4" - 3/8" too long. I can trim them without breaking the trailing edge joint. I cannot see any simple way of bending/aligning the wing tips except for perhaps cutting the trailing edge in half and reattaching them while trying to twist them into alignment. I would love to hear what others have done to deal with this. I really hope it is not bad parts cause I have put a lot of hours into these wingtips. John Testement jwt(at)roadmapscoaching.com 40321 Working on QB Wing Tips ________________________________________________________________________________
Subject: Right Landing Gear Mount
Date: Oct 14, 2005
Page 28-17 details the Left gear mounting steps but I can not find any reference to the Right gear mount. Is it done at this time (no note that right should mirror the left steps) or is their a later section that covers this? John Testement jwt(at)roadmapscoaching.com 40321 Working on QB wings and QB initial fuse steps ________________________________________________________________________________
Subject: nylon wiring conduit
Date: Oct 14, 2005
Hey all - just a quick question - is the nylon conduit for wing wiring the "split" variety? i'm at that point, and i haven't recieved the conduit i ordered from vans. would like to get a moveon this weekend, so i'll try to find some locally. thoughts? thanks cj #40410 wings ________________________________________________________________________________
Date: Oct 14, 2005
Subject: Parallel Fuel Line for IO-540 (that bypasses the engine driven
fuel pump) Listers, There are some intersting fuel system design suggestions in <http://www.rv8.ch/staticpages/index.php?page=20030914230507849> (or <http://www.ellison-fluid- systems.com/article/fuelsystemsforhomebuilts/fuelsystems.htm>) In particular, to minimize the chance of vapor lock, "Fuel Routing should be direct from boost pump through filter to carburetor or fuel injector servo. Have engine driven pump plumbed in parallel, not series, so that possible vapor lock in engine driven pump will be bypassed. A check valve may be necessary, depending on pump type." I'm considering using this approach on my RV-10 (IO-540). In the approach I'm considering the fuel line will "T" after the high pressure boost pump output (aft of firewall). One branch will go thru the engine driven pump. The other branch will go thru an Andair check valve then "T" with the output of the engine driven fuel pump, at which point a single line will go forward to the injection system servo/throttle. With this setup the boost pump will be able to supply fuel to the injection system even if the engine drive boost pump is blocked. Does anybody know of any significant downside to this approach? Thanks, Tim Lewis RV-6A N47TD - 790 hrs RV-10 N31TD (reserved) - under construction ________________________________________________________________________________
Subject: Re: nylon wiring conduit
Date: Oct 14, 2005
Chris, The conduit from Van's is solid. I've seen the split kind in the auto parts stores and thought about using is myself. Chose the Van's stuff instead and plan to make holes as necessary for AP, Pitot heat, ect. Anyone have a reason not to use the split conduit? ________________________________________________________________________________
Subject: nylon wiring conduit & AOA
Date: Oct 14, 2005
arrrrghhh. just went around to see if i could find any locally, and no joy. after perusing a few of the websites, i think i see that the stuff from vans is solid, and i think it's better quality than the stuff from the auto parts stores. anyone have any ideas on where to find this stuff? also - for those who've installed the AFS AOA what size snap bushing did you use to run the two 1/8" lines through? i think i'm putting it in the opposite wing as the pitot, using the same tooling holes. thanks cj #40410 wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of John Hasbrouck Subject: Re: RV10-List: nylon wiring conduit Chris, The conduit from Van's is solid. I've seen the split kind in the auto parts stores and thought about using is myself. Chose the Van's stuff instead and plan to make holes as necessary for AP, Pitot heat, ect. Anyone have a reason not to use the split conduit? ________________________________________________________________________________
Date: Oct 14, 2005
Van's conduit is not split. Bruce Snyder #40353 QB fuselage uncrated -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Subject: RE: RV10-List: nylon wiring conduit Hey all - just a quick question - is the nylon conduit for wing wiring the "split" variety? i'm at that point, and i haven't recieved the conduit i ordered from vans. would like to get a moveon this weekend, so i'll try to find some locally. thoughts? thanks cj #40410 wings ________________________________________________________________________________
Date: Oct 14, 2005
I bought a Cleveland 3/8 in reamer at Oshkosh and 2 RV-10 builders have used it already for these holes. If you want to buy mine, I paid $13 for it and will ship it out for $13. Bruce Snyder #40353 QB fuselage -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RE: RV10-List: Reaming Flap Bracket Sean, Myself, and another at my location will be doing SB wings. If you don't find a solution, buy the reamer, then I'll buy it from you, plus shipping. It'll be the floating reamer. Or, check with your local EAA chapter. They may have such a tool. John Jessen 40328 HS (hoping to get it mounted on the mantel this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Subject: RV10-List: Reaming Flap Bracket For those with the slow build wings, I need to ream the 3/8 hole in the flap brackets. As this is probably the only place I'll need a 3/8 reamer, has anyone used something else? Has anyone tried a Unibit from each side? Just looking for other options before ordering a "one use" reamer. Thanks, Sean #40303 (wing top skins) ________________________________________________________________________________
Subject: Re: nylon wiring conduit & AOA
Date: Oct 14, 2005
I ran the AOA tubing along with the other wires. I did upsize the snap bushings from 625-7 to 625-8 though. Bob -------------------------- -----Original Message-----
From: Chris Johnston <owner-rv10-list-server(at)matronics.com>
Subject: RE: RV10-List: nylon wiring conduit & AOA arrrrghhh. just went around to see if i could find any locally, and no joy. after perusing a few of the websites, i think i see that the stuff from vans is solid, and i think it's better quality than the stuff from the auto parts stores. anyone have any ideas on where to find this stuff? also - for those who've installed the AFS AOA what size snap bushing did you use to run the two 1/8" lines through? i think i'm putting it in the opposite wing as the pitot, using the same tooling holes. thanks cj #40410 wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of John Hasbrouck Subject: Re: RV10-List: nylon wiring conduit Chris, The conduit from Van's is solid. I've seen the split kind in the auto parts stores and thought about using is myself. Chose the Van's stuff instead and plan to make holes as necessary for AP, Pitot heat, ect. Anyone have a reason not to use the split conduit? ________________________________________________________________________________
Subject: Elongated Hole - 2
Date: Oct 15, 2005
Just smear a little structural epoxy or even proseal on the tab and rivet the thang.. If its invisible from the outside and you've satisfied your personal comfort level for a repair, than no harm no foul... you are the person responsible for building a safe and structurally sound airframe. That being said, there going to be many times during the construction of your aircraft in which this same philosophy will prevail. You may not be a structural engineer, but you can use your best judgment in overcoming the small problems encountered during the normal construction process. After building almost 3 rv's and owning a classic spam can. I was appalled at the quality of the faa certified airframe. The lack of deburring, smashed rivets, and poor priming has convinced me that a carefully built obam aircraft even with minor flaws is still far superior than an airframe built by a " professional" from Wichita or Vero Beach. Just .02 Steven dinieri --Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: Elongated Hole - 2 This view might be better. John Jessen 40328 HS ________________________________________________________________________________
Subject: Air Box/Filter
Date: Oct 15, 2005
7.50 BARRACUDA_HEADER_FP56 RBL: Blacklist bl.spamcop [Blocked - see <http://www.spamcop.net/bl.shtml?65.161.23.63>] The airbox content includes a base plate which is above the filter, an airbox top plate which the base plate is screwed to. These two plates are attached to the injector body. And the glass box itself which is attached to the top plate via rivets on the side of the box. How is the air filter kept in its place? Anh #141 ________________________________________________________________________________
Subject: Door latch warning light
Date: Oct 15, 2005
I saw mention of this earlier. Did you request it or did it just show up? I have my finishing kit and would like to take advantage of the system. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Ritter Subject: RV10-List: Door latch warning light Received door latch warning light kit from Vans today. No charge. Mark to and much ________________________________________________________________________________
Date: Oct 15, 2005
Subject: Re: Door latch warning light
I saw the following post on Vans Airforce. /I exchanged emails with Tom Green & Ken Krueger about this today. There is a door latch indicator kit which has been incorporated into all RV-10 kits shipping out now and the kit has been sent to all holders of kits already in the field. As others have said, a checklist item to physically verify full closed is appropriate. Even without a door latch indicator system, both RV-10 rear pins can easily be checked from the pilot's seat by reaching around the F-1005C Bulkhead Side Channel and feeling for the end of the pin protruding through. In my RV-6, my before-crossing-the-runway-threshold verbal callout is: / Deems Davis # 406 Wing Leading Edges http://deemsrv10.com/ Marcus Cooper wrote: > > I saw mention of this earlier. Did you request it or did it just show > up? I have my finishing kit and would like to take advantage of the > system. > > > > Marcus > > > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Mark Ritter > *Sent:* Saturday, October 15, 2005 9:16 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Door latch warning light > > > > Received door latch warning light kit from Vans today. No charge. > > > > Mark > > ==================================== ==================================== ________________________________________________________________________________
Date: Oct 16, 2005
I've had soldered D-sub connectors on my TruTrak servos running for about 175 flight hours on my RV-7A without any problem. Just use a length of heat shrink tubing that slides over the soldered pin and the attached wire, and embed everything in some Shoe Goo after all wires are soldered, and it is a very substantial while flexible connection. I did adopt a simple rule on the -7 after having a few flaky wiring connections on things like the trim indicator and a couple of instrument backlights, and that is to use 20 ga. wire as the minimum wire size in the plane. It is much easier to work with and more resistant to mechanical breaks than 22 ga and higher. Cheap insurance for durability and the weight difference is negligible. Just my $0.02 based on one RV flying and another abuilding'. -Dan Masys > > How many builders with Tru-Trak servos are using the solder type D-Sub > connectors that they provide. I've been taught and it's my experience that > soldered connections fail prematurely when exposed to vibration. The heat > hardens the copper strands and they get brittle from repeated work hardening > vibrations. It's a definite no-no to solder wires in a certificated > aircraft. Anybody want to voice an opinion here? It will cost me about $44 > for the crimpers and about $.40 per pin/socket plus a couple bucks per > plug/receptacle to go the crimped route, which I'll probably do because > there will be many more D-Sub connectors. > > Paul Hahn > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 16, 2005
It's pinched in place by the glass box and the top plate, I believe. That pressure is part of making the airbox. Fun stuff! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: RV10-List: Air Box/Filter The airbox content includes a base plate which is above the filter, an airbox top plate which the base plate is screwed to. These two plates are attached to the injector body. And the glass box itself which is attached to the top plate via rivets on the side of the box. How is the air filter kept in its place? Anh #141 ________________________________________________________________________________
Subject: inertial belts update
Date: Oct 16, 2005
we have now established the hardpoints for the inertial belts for the 10. I have enclosed two pictures and a pdf of the drawings for the belts. ________________________________________________________________________________
Subject: wings problems
Date: Oct 16, 2005
About a month ago some body say where problems in Canada regarding spars riveting,was any follow up .I thinks I will recive mine an a month ,and like to know if the problem was real. Hugo ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Re: wings problems
No idea on the story, but I took my rivet gauge and checked all my spar rivets. They're all okay. -Jim 40384, done priming rear spar. watching paint dry now :) gommone7(at)bellsouth.net wrote: > >About a month ago some body say where problems in Canada regarding spars riveting,was any follow up .I thinks I will recive mine an a month ,and like to know if the problem was real. >Hugo > > > > > > > > > ________________________________________________________________________________
From: "James Laura Riley" <JIMANDLAURA(at)peoplepc.com>
Date: Oct 16, 2005
John, It's not really that big of a deal. I would just put a doubler piece in behind the elongated hole. Take some scrap and cut a piece 1.5"x.5" and rivet it to the rib only using two flush rivets. Drill and dimple the original hole where it should be and walla, good to go. You just have to use a slightly longer rivet in that hole. Jim Riley Fuselage Folks, I know this has been discussed before, but my search came up with examples not quite the same. So, am asking anew.
October 07, 2005 - October 16, 2005
RV10-Archive.digest.vol-as
