RV10-Archive.digest.vol-at
October 16, 2005 - November 02, 2005
            The part is one of the nose ribs for the HS.  Using the pneumatic
      squeezer,
            working too quickly, I punched a hole next to one that I was
      trying to
            dimple.  It was so close to the original hole that it made a
      bigger hole,
            about 3/8 inch, but oblong in shape.  Any suggestions as what to
      do?  An
            oops rivets could not fill it if I were to drill it out.  The
      picture shows
            the elongated hole in the foreground, with a correctly dimpled
      hole on the
            other side of the nose rib in the background.
            John Jessen
               40328 HS (Finally made up my mind and ordered the SB wings
      today)
From: "James Laura Riley" <JIMANDLAURA(at)peoplepc.com>
Subject: Re: Elongated hole
Date: Oct 16, 2005
There's no reason to replace that rib. It's not that big of deal, and it can be easily patched up. As for building the perfect plane, unless you're the almighty one, it's not going to happen. Every RV has an error or two on them. If you're lucky, you'll be the only one the ever notices it/them. The real question is, do you want to be a flyer or do you want to be a builder??? I'm lucky because I get to fly for a living. So, I kind of like the hobby of building. But, Van's makes it very easy for the average person to be a flyer in a solid aircraft. To each their own. Jim Riley Fuselage ________________________________________________________________________________
Subject: Bolt direction
Date: Oct 16, 2005
I'm just getting started on the fuselage and I ran into something that bothers me. Some of you will probably just scoff this and say that I'm too anal, but I figured one of you would know the answer. On the aft bulkhead that attaches to the spar, the plans calls for some of the bolts to point aft and some of them to point forward. In other words, if you look across the front you'll see some bolt heads and some nuts. The convention that I was taught is that bolts should point down or aft, if possible. I'm just wondering if it really matters which direction the bolts point or does Van's have some grand plan that I don't know about (most likely) and I should just stick to the plans;-) Thanks, Jim Riley ________________________________________________________________________________
Subject: Re: Air Box/Filter
Date: Oct 17, 2005
Jesse, After reading the non-RV10-style instructions more carefully, especially the chicken-scratch sketches, I realized the same. Thanks! It is fun stuff.:( Anh ----- Original Message ----- From: Jesse Saint To: rv10-list(at)matronics.com Sent: Sunday, October 16, 2005 2:37 PM Subject: RE: RV10-List: Air Box/Filter It's pinched in place by the glass box and the top plate, I believe. That pressure is part of making the airbox. Fun stuff! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Sent: Saturday, October 15, 2005 1:23 AM To: RV10 Subject: RV10-List: Air Box/Filter The airbox content includes a base plate which is above the filter, an airbox top plate which the base plate is screwed to. These two plates are attached to the injector body. And the glass box itself which is attached to the top plate via rivets on the side of the box. How is the air filter kept in its place? Anh #141 ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: wings problems
I've learned no more on this than the following from a month ago.... Perry Casson Just a short update regarding the report of Canadian inspectors failing RV-10 wings on preclose inspection. Unfortunately I've still not got names or kits numbers so I've not verified anything with the builders but here's the info I've received: - At least two kits were affected. - All reported defects were under driven shop heads on the 5/16 rivets on the main spars - The problems were only found on fast build wings. I'm got the calipers out to check my slow build spars and found all the rivets were well within spec. as I suspected. With the tanks off this should be no big deal to fix but I'd not be a happy guy to get this flagged as a defect during final inspection. gommone7(at)bellsouth.net wrote: > >About a month ago some body say where problems in Canada regarding spars riveting,was any follow up .I thinks I will recive mine an a month ,and like to know if the problem was real. >Hugo > > > > > > > > > ________________________________________________________________________________
Subject: Lycoming O/IO-540 For sale
Date: Oct 17, 2005
Since I have decided not to build a RV-10, my engine needs a new home. I have a O/IO-540 E4B5/C4B5 that is a match for a RV-10. This engine can be configured with a carb or fuel injection - everything else internal to the engine is the same according to the Lycoming data sheets and Vans. 21,900$ for a first run Mattituck new limits overhaul, 2800TT, 300 SMOH. I had the engine back to Mattituck for a IRAN and test cell run prior to my purchase. All accessories, starter, Bendix RSA fuel injector, correct carb should you want to run a low pressure fuel system, yellow tagged (RV-10/Rocket set up) prop governor, governor cable stand-off and paperwork. Pictures available and more detailed log data of course.......... Please contact off list. Phil in south NJ 609-654-9587 609-272-4037 Phil Condon RV-4 N41RV & RV-8 N800RV ________________________________________________________________________________
Date: Oct 17, 2005
Listers I have run into a problem making my single stage self etching primer adhere to some of the parts. At first I thought I had contaminated some of the parts with bad acetone. I dumped the rest and started a new can. I have changes to new cans of primer, replaced my scotch brite pads with new, and started a new roll of paper towels. I scuff each part and then clean it with acetone before spraying. This has worked well for the whole plane so far, and this is my third plane. Has anyone else run into this problem.? I'm starting to wonder if the aluminum is contaminated right from Van's. Problem first showed up when doing the rear spar bulkhead and has now re-appeared on the ribs that hold the seat belt anchors. Zinc chromate seems to stick OK, and thats what I ended up using on the bulkhead, but I prefer to use the primer. I'm going nuts with this.... Thoughts. Ted French RV-10 wings wiiting for inspection, fuselage started... ________________________________________________________________________________
Subject: Primer problems.....
Date: Oct 17, 2005
Listers I have run into a problem making my single stage self etching primer adhere to some of the parts. At first I thought I had contaminated some of the parts with bad acetone. I dumped the rest and started a new can. I have changes to new cans of primer, replaced my scotch brite pads with new, and started a new roll of paper towels. I scuff each part and then clean it with acetone before spraying. This has worked well for the whole plane so far, and this is my third plane. Has anyone else run into this problem.? I'm starting to wonder if the aluminum is contaminated right from Van's. Problem first showed up when doing the rear spar bulkhead and has now re-appeared on the ribs that hold the seat belt anchors. Zinc chromate seems to stick OK, and thats what I ended up using on the bulkhead, but I prefer to use the primer. I'm going nuts with this.... Thoughts. Ted French RV-10 wings waiting for inspection, fuselage started... ________________________________________________________________________________
Date: Oct 17, 2005
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I started out using acetone and found that it actually does a poor job cleaning because it flashes off very quickly frequently leaving a residue. Using a degreaser actually works much better, just about any of the paint manufactures also make a cleaner/degreaser. I've also heard of folks using naptha (Coleman lantern fluid) with good success. Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted on RV list Subject: RV10-List: Primer problems..... Listers I have run into a problem making my single stage self etching primer adhere to some of the parts. At first I thought I had contaminated some of the parts with bad acetone. I dumped the rest and started a new can. I have changes to new cans of primer, replaced my scotch brite pads with new, and started a new roll of paper towels. I scuff each part and then clean it with acetone before spraying. This has worked well for the whole plane so far, and this is my third plane. Has anyone else run into this problem.? I'm starting to wonder if the aluminum is contaminated right from Van's. Problem first showed up when doing the rear spar bulkhead and has now re-appeared on the ribs that hold the seat belt anchors. Zinc chromate seems to stick OK, and thats what I ended up using on the bulkhead, but I prefer to use the primer. I'm going nuts with this.... Thoughts. Ted French RV-10 wings waiting for inspection, fuselage started... ________________________________________________________________________________
Subject: Re: Primer problems.....
Date: Oct 17, 2005
The best is Isopropyl alcohol hugo > > From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com> > Date: 2005/10/17 Mon PM 03:32:00 EDT > To: > Subject: RE: RV10-List: Primer problems..... > > > I started out using acetone and found that it actually does a poor job > cleaning because it flashes off very quickly frequently leaving a > residue. Using a degreaser actually works much better, just about any > of the paint manufactures also make a cleaner/degreaser. I've also > heard of folks using naptha (Coleman lantern fluid) with good success. > > Bob #40105 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted on RV > list > Sent: Monday, October 17, 2005 2:01 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Primer problems..... > > > > > Listers > > I have run into a problem making my single stage self etching primer > adhere > to some of the parts. At first I thought I had contaminated some of the > parts with bad acetone. I dumped the rest and started a new can. I have > changes to new cans of primer, replaced my scotch brite pads with new, > and > started a new roll of paper towels. I scuff each part and then clean it > with > acetone before spraying. This has worked well for the whole plane so > far, > and this is my third plane. Has anyone else run into this problem.? I'm > starting to wonder if the aluminum is contaminated right from Van's. > Problem > first showed up when doing the rear spar bulkhead and has now > re-appeared on > the ribs that hold the seat belt anchors. Zinc chromate seems to stick > OK, > and thats what I ended up using on the bulkhead, but I prefer to use the > primer. > > I'm going nuts with this.... > > Thoughts. > > Ted French > RV-10 wings waiting for inspection, fuselage started... > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 17, 2005
Ted, Assuming you are using the rattle can primers. I too noticed this. One thing I noticed is moisture will affect the adhesion. If you take a part out of an air conditioned space (Cool / dry) to the outside for priming, you need to allow the part to warm up. As you prime it, the part will get pretty cool as the solvent evaporates. If it cools enough for moisture to condense from the air, the primer will not stick. I have found two methods to help with this problem: (1) Take the parts out to direct sunlight and allow them to heat up both before and after priming. (It helps the drying time a bunch!) You can even set up some heat lamps to warm up the parts outside. (2) If you can't do 1, then do light coats so the part does not cool significantly. Moisture seems to really affect end results. You may have a different issue, but this is what I have found. Jim Combs #40192, N312F - Fuselage ---------- Original Message ---------------------------------- From: "Ted on RV list" <ted_french(at)telus.net> Date: Mon, 17 Oct 2005 11:35:45 -0700 Listers I have run into a problem making my single stage self etching primer adhere to some of the parts. At first I thought I had contaminated some of the parts with bad acetone. I dumped the rest and started a new can. I have changes to new cans of primer, replaced my scotch brite pads with new, and started a new roll of paper towels. I scuff each part and then clean it with acetone before spraying. This has worked well for the whole plane so far, and this is my third plane. Has anyone else run into this problem.? I'm starting to wonder if the aluminum is contaminated right from Van's. Problem first showed up when doing the rear spar bulkhead and has now re-appeared on the ribs that hold the seat belt anchors. Zinc chromate seems to stick OK, and thats what I ended up using on the bulkhead, but I prefer to use the primer. I'm going nuts with this.... Thoughts. Ted French RV-10 wings wiiting for inspection, fuselage started... ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Re: Primer problems.....Primer problems.....
Having built two RV-4's over the past 20 years, the final cure to adhesion problems with primer is to wash your aluminum with Hydrofluoric Acid prior to priming. This is strong stuff. You need to wear a respirator and good gloves, but there is nothing better for etching and cleaning the alclad aluminum just before priming. My bottle is quite old now, but I obtained my acid from: Sierra Chemicals in West Sacramento, Ca. Their name of the product is Aluminex 200HF. Happy painting ! Craig P. ________________________________________________________________________________
Date: Oct 18, 2005
One followup on the hydrofluoric acid: always wear goggles and pull up the Material Safety Data Sheet (MSDS) and other related safety handling material before using this......it is potentially dangerous. craig p ________________________________________________________________________________
Subject: Air Box/Filter
Date: Oct 18, 2005
As I understand, the instructions for the airbox are pretty much the plans format used for building the lower-number RV's. I am glad that they got out of that format. What a pain. The -10 plans are awesome! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: Re: RV10-List: Air Box/Filter Jesse, After reading the non-RV10-style instructions more carefully, especially the chicken-scratch sketches, I realized the same. Thanks! It is fun stuff.:( Anh ----- Original Message ----- From: Jesse Saint <mailto:jesse(at)itecusa.org> Subject: RE: RV10-List: Air Box/Filter It's pinched in place by the glass box and the top plate, I believe. That pressure is part of making the airbox. Fun stuff! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: RV10-List: Air Box/Filter The airbox content includes a base plate which is above the filter, an airbox top plate which the base plate is screwed to. These two plates are attached to the injector body. And the glass box itself which is attached to the top plate via rivets on the side of the box. How is the air filter kept in its place? Anh #141 ________________________________________________________________________________
Subject: Re: solder or crimp??
Date: Oct 17, 2005
While I'm a ways away from serious wiring, you can bet I'll be soldering. I was an auto mechanic for 12 years and between cars and trailers I've seen my share of crimped connectors. They usually end up w/ dissimilar metals which over time tends to deteriorate the connectivity. ----- Original Message ----- From: Millsap, Dennis To: rv10-list(at)matronics.com Sent: Friday, October 14, 2005 9:50 AM Subject: Re: RV10-List: solder or crimp?? In the "For what it's worth department".. I'm a lurker on the list, but I couldn't let this one go by because of all the frustrations I'm having right now with my -6. I crimped all of the connections for my electric trim. But, lately I've had a series of "ghosts" in the trim wiring. I've decided that it was my faulty connections. As you all know, the wiring from the Mac Servos is tiny! So, now I am going back through every connection and soldering everything. I'm sure I'll get shot at about my crimping tool or some other thing, but I haven't had an issue anywhere else. I've got about 500 hours on my RV-6A now and this one maintenance issue has caused me more headaches than anything else. I will be soldering most if not all of the connections on the RV-10 and I will pay a lot of attention to strain relief. Again, just FWIW. Dennis W. Millsap N464DM, RV-6A Diceman ________________________________________________________________________________
Subject: proseal
Date: Oct 18, 2005
Any body need proseal? 1 qt can unopened Free,I order but finish using my own stuff,Vans will not accept returns in Proseal, expire 03-06, rather give free then go bad in my shelf.please you pay the shipp. Hugo ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Anyone have fit issues with bearing-com-3-5 ?
On page 15-2, did anyone have problems fitting the bearing into the W1013A parts? I deburred the W1013A only enough to remove the shear marks, but the bearing does not fit. The inside of the hole measures 0.632" (consistent on all 4 parts) but the bearing is only 0.625" diameter. Obviously, the bearing floats in the part, which could cause wear. Any suggestions? -Jim 40384 ________________________________________________________________________________
Date: Oct 18, 2005
Hey jim - I'm right at that step too, and I didn't deburr the ID of the hole because I wanted to test the press fit of the bearing first. After checking, I decided only to break the edges of the hole. I think if you smooth out the ID, it won't be a press fit any more. Not sure what the fix is for you. BTW, did you happen to straighten out that 1013A piece? Mine was really bent from the punching process... and someone posted recently that a QB (I think) set of wings had trouble with the aileron mounting due to a slightly curved W-1013A assembly. Hope that helps cj #40410 wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: RV10-List: Anyone have fit issues with bearing-com-3-5 ? On page 15-2, did anyone have problems fitting the bearing into the W1013A parts? I deburred the W1013A only enough to remove the shear marks, but the bearing does not fit. The inside of the hole measures 0.632" (consistent on all 4 parts) but the bearing is only 0.625" diameter. Obviously, the bearing floats in the part, which could cause wear. Any suggestions? -Jim 40384 ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Re: Anyone have fit issues with bearing-com-3-5 ?
Chris, Yep, mine were bent as well. I straightened them as best I could before deburring. I am thinking of "gluing" the bearings in with proseal. I'll call Van's later to see if that will be ok. If not, I'll order replacement parts :( BTW, I recently used Proseal to repair an engine mount in my car; The rubber was almost gone, no replacement could be found, so I tried it... Man is that tough stuff! It worked! -Jim 40384 Chris Johnston wrote: > >Hey jim - >I'm right at that step too, and I didn't deburr the ID of the hole >because I wanted to test the press fit of the bearing first. After >checking, I decided only to break the edges of the hole. I think if you >smooth out the ID, it won't be a press fit any more. Not sure what the >fix is for you. BTW, did you happen to straighten out that 1013A piece? >Mine was really bent from the punching process... and someone posted >recently that a QB (I think) set of wings had trouble with the aileron >mounting due to a slightly curved W-1013A assembly. > >Hope that helps >cj > >#40410 >wings > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein >Sent: Tuesday, October 18, 2005 12:49 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Anyone have fit issues with bearing-com-3-5 ? > > >On page 15-2, did anyone have problems fitting the bearing into the >W1013A parts? >I deburred the W1013A only enough to remove the shear marks, but the >bearing does not fit. The inside of the hole measures 0.632" (consistent > >on all 4 parts) but the bearing is only 0.625" diameter. Obviously, the >bearing floats in the part, which could cause wear. > >Any suggestions? > >-Jim 40384 > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Multi-Purpose MFD
Date: Oct 18, 2005
Hey all - Just thought I'd put this out there. I'm in the pondering stages of the panel (who isn't?) and I got to thinking about putting a big hi-res display in the panel at the copilot position. Possible uses include hacking the whatever EFIS I'm using to display on the monitor, inflight computer for this and that, movies to get the copilot to forget that she has to pee. I found a couple places that have sunlight readable stuff. http://www.argonautcomputer.com/displays_tflex.htm possible challenges or showstoppers include the 10,000 foot operating altitude, and possible lack of dim-ability for night flight. Thoughts? cj #40410 wings ________________________________________________________________________________
Date: Oct 18, 2005
Chris, You're right. I called Van's and that's one part that the hole DOES NOT GET DEBURRED. I made the mistake of reading "deburr the edged and holes in all parts" to mean that hole as well. Also on page 5-2, it says that "All shear or cut marks in aluminium must be removed". I should stop reading as much :) They're giving me new parts, and I told them i'd pay for next day shipping (I offered to pay for the parts, but they said that its not a problem.) Man, if you could get customer service like that elsewhere, the world would be a better place :) So, TIM: Please add this to the "Gotcha" page please!! -Jim 40384, Guess I'll rivet the rear spar tomorrow..... Chris Johnston wrote: > >Hey jim - >I'm right at that step too, and I didn't deburr the ID of the hole >because I wanted to test the press fit of the bearing first. After >checking, I decided only to break the edges of the hole. I think if you >smooth out the ID, it won't be a press fit any more. Not sure what the >fix is for you. BTW, did you happen to straighten out that 1013A piece? >Mine was really bent from the punching process... and someone posted >recently that a QB (I think) set of wings had trouble with the aileron >mounting due to a slightly curved W-1013A assembly. > >Hope that helps >cj > >#40410 >wings > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein >Sent: Tuesday, October 18, 2005 12:49 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Anyone have fit issues with bearing-com-3-5 ? > > >On page 15-2, did anyone have problems fitting the bearing into the >W1013A parts? >I deburred the W1013A only enough to remove the shear marks, but the >bearing does not fit. The inside of the hole measures 0.632" (consistent > >on all 4 parts) but the bearing is only 0.625" diameter. Obviously, the >bearing floats in the part, which could cause wear. > >Any suggestions? > >-Jim 40384 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 18, 2005
After final installation of the flaps and pivot bearings would it not be a good idea to "stake" the bearing in place? Dick Sipp 40065 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Subject: RE: RV10-List: Anyone have fit issues with bearing-com-3-5 ? > > Hey jim - > I'm right at that step too, and I didn't deburr the ID of the hole > because I wanted to test the press fit of the bearing first. After > checking, I decided only to break the edges of the hole. I think if you > smooth out the ID, it won't be a press fit any more. Not sure what the > fix is for you. BTW, did you happen to straighten out that 1013A piece? > Mine was really bent from the punching process... and someone posted > recently that a QB (I think) set of wings had trouble with the aileron > mounting due to a slightly curved W-1013A assembly. > > Hope that helps > cj > > #40410 > wings > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein > Sent: Tuesday, October 18, 2005 12:49 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Anyone have fit issues with bearing-com-3-5 ? > > > On page 15-2, did anyone have problems fitting the bearing into the > W1013A parts? > I deburred the W1013A only enough to remove the shear marks, but the > bearing does not fit. The inside of the hole measures 0.632" (consistent > > on all 4 parts) but the bearing is only 0.625" diameter. Obviously, the > bearing floats in the part, which could cause wear. > > Any suggestions? > > -Jim 40384 > > > ________________________________________________________________________________
Date: Oct 19, 2005
Yes Linn, you are mistaken: I indeed do mean Hydrofluoric and hence the warning about its use. I have used the stuff effectively and safely for 20 yrs and my paint ain't coming off for nothing. But, you are absolutely right-------it is nasty stuff and one MUST observe the precautions when using it. Never tried phosphoric acid. Does that acid work? craig p ________________________________________________________________________________
Subject: RV10 interial belts
Date: Oct 19, 2005
My notebook computer died the other night so with the exception of Nick Leonard I lost the list of interested people. I now have the particulars for the belts (pdfs, colors and costs) and procedures that we used to create the hardpoints. If interested just email me directly at dlm46007(at)cox.net . If you want to consider it later you probably ought to create the hard points now as its about 1000% easier with the lid upside down on the shop floor. ________________________________________________________________________________
Date: Oct 19, 2005
CJ, We installed an ELO 12.1" panel mount touch screen in our RV-10 Panel. So far, seems to be a good choice. The theory is that we have the Blue Mountain EFIS slaved into the monitor and a laptop computer. That way, either the co-pilot can see the normal nav displays or can watch a movie or navigate approach plates on the laptop/touchscreen. There is a 10K ft operating limitation on BOTH the hardrive in the laptop and the LCD display. However, that seems to be a small price to pay so far. The ELO touchpanel was about $150 on ebay and runs on 12v. To dim the display, we will have to hack into the lighting power supply and add a lighting control. However, the lighting in miniature fluorescent so that probably won't work. We're still not clear on how we're going to handle that one. Probably just turn it off at night for now. If all else fails, we could put a static cling piece of tint over the screen. Jeremy P. Harris Integrated Missile Defense BMDS Architectures Lab The Boeing Company Washington, DC Desk: (703) 414-6057 Dept: AV-2L-B27T Cell: (703) 627-6500 Fax: (703) 414-6372 MC: 793C-G007 Office: 825B -----Original Message-----
From: Chris Johnston [mailto:CJohnston(at)popsound.com]
Subject: RE: RV10-List: Multi-Purpose MFD --> Hey all - Just thought I'd put this out there. I'm in the pondering stages of the panel (who isn't?) and I got to thinking about putting a big hi-res display in the panel at the copilot position. Possible uses include hacking the whatever EFIS I'm using to display on the monitor, inflight computer for this and that, movies to get the copilot to forget that she has to pee. I found a couple places that have sunlight readable stuff. http://www.argonautcomputer.com/displays_tflex.htm possible challenges or showstoppers include the 10,000 foot operating altitude, and possible lack of dim-ability for night flight. Thoughts? cj #40410 wings ________________________________________________________________________________
Subject: Primers not to use??
Date: Oct 19, 2005
I realize I'm running the risk of opening a primer debate as well as numerous flames documenting my obvious ignorance, BUT I was at the local auto paint stop today looking to pick up some PPG 1791 self etching primer. Sadly they were out and the guy behind the counter recommended I use a rattle can of SEM 39683 self etching primer. He claims it's just as good but you don't have to futz with the catalyst and that he's had good results with the cars he's used it on. ($12/can btw). Now I realize that all primers are not created equal and that some people don't primer at all but it got me thinking (always dangerous). Are there primers to actually AVOID? If it says for use on steel and aluminum is that good enough? I seem to recall a guy at Vans telling me any ol metal primer will do, it's just not necessary. Opinions? -Brian Iowa City, IA ________________________________________________________________________________
Subject: Looking for recommendation for Firewall insulation.
Date: Oct 19, 2005
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
I'm looking for a recommendation for Firewall insulation. I would like to get it bought and cut to shape before I rivet on the upper skin section over the rudder pedals. Thank You Ray Doerr 40250 ________________________________________________________________________________
Date: Oct 19, 2005
Subject: Re: Primers not to use??
Brian, Thats what I am using. Working well for me so far. Only comments, Keep the parts warm before during and after spraying. I have used both 39683 (Gray) and 39693 (Green). Can't tell any difference (Other than color). Jim Combs #40192 - N312F ________________________________________________________________________________
Date: Oct 19, 2005
Brian, I am only paying $7.69 per can. The store I am buying from is giving my the wholesale price. Jim Combs #40192 - N312F ________________________________________________________________________________
Subject: RV-10 Engine for Sale
Date: Oct 19, 2005
Since I have decided not to build a RV-10, my engine needs a new home. I have a O/IO-540 E4B5/C4B5 that is a match for a RV-10. This engine can be configured with a carb or fuel injection - everything else internal to the engine is the same according to the Lycoming data sheets and Vans. 21,900$ for a first run Mattituck new limits overhaul, 2800TT, 300 SMOH. I had the engine back to Mattituck for a IRAN and test cell run prior to my purchase. All accessories, starter, Bendix RSA fuel injector, correct carb should you want to run a low pressure fuel system, yellow tagged (RV-10/Rocket set up) prop governor, governor cable stand-off and paperwork. Pictures available and more detailed log data of course.......... Please contact off list. Phil in south NJ 609-654-9587 609-272-4037 Phil Condon RV-4 N41RV & RV-8 N800RV (reposted by request) ________________________________________________________________________________
Date: Oct 19, 2005
For my RV-7 I used NAPA 7220 self etching primer. It comes in rattle cans and is probably the ultimate in no hassle priming, since it dries in about ten minutes and so priming is just a blink on the road between deburring, dimpling, and riveting. I scuffed all parts with Scotchbrite and then cleaned them with MEK before priming with 7220. HOWEVER, this and essentially all of the automotive rattle can primers will cover OK but not really bond chemically to Alclad, and subsequent MEK and some elbow grease will wipe the primer away. Not a problem for closed surfaces like the inside of the HS, VS, and elevators, but definitely a problem for any 'high traffic' areas where the primer remains exposed after the plane is done. For the RV-10 I reverted back to MEK cleaning (no Scotchbrite scuff this time) followed by AZKO sprayed with the disposable cup "zipgun" sold by Aircraft Spruce. (see http://www.aircraftspruce.com/catalog/topages/zipgun.php ). Works very well and except for having to have a full face respirator mask, is almost as fast as rattle can priming. The AZKO primer definitely bonds well and is very resistant to mechanical abrasion (such as that caused by a bouncing bucking bar hitting webs and flanges of various skeleton pieces). It's not the full phosphoric acid etch followed by Alodine conversion followed by epoxy, but seems a pretty good middle ground for durability vs. multiple tedious steps. (Also should say that even though the rattle can primer gets scratched or rubbed off, it's pretty simple to just spray a little more on when needed, even after the airplane is in regular use flying.) YMMV, -Dan Masys > I realize I'm running the risk of opening a primer debate as well as numerous flames documenting my obvious ignorance, BUT I was at the local auto paint stop today looking to pick up some PPG 1791 self etching primer. Sadly they were out and the guy behind the counter recommended I use a rattle can of SEM 39683 self etching primer. He claims it's just as good but you don't have to futz with the catalyst and that he's had good results with the cars he's used it on. ($12/can btw). > > Now I realize that all primers are not created equal and that some people don't primer at all but it got me thinking (always dangerous). Are there primers to actually AVOID? If it says for use on steel and aluminum is that good enough? I seem to recall a guy at Vans telling me any ol metal primer will do, it's just not necessary. > > Opinions? > > > -Brian > Iowa City, IA > > ________________________________________________________________________________
Date: Oct 20, 2005
Subject: The impossible rivets - 1 won, 1 lost
This is bit of an old issue, but I recently won the battle against the "impossible rivets" on the rear seat pans and I thought I would share my method. The forward-most hole is the problem because the front seat support gets in the way. I managed to set a solid rivet in these holes, but it took some trial and error. I ended up using a 12" piece of steel angle, with a hole drilled in one end to accept a 1/8" cupped set (I had to do some grinding on the end of the steel piece to get it to work out). I placed the cupped set on the rivet and blocked the aft end of the steel piece from the side panel with a piece of wood. Then I used a mushroom set in my rivet gun, placed it on the piece of steel as close to the rivet as possible and hammered away. I cranked up the PSI on the gun a bit. I used different pieces of wood to support the steel piece while I riveted to keep from scratching the floor and side panel aluminum. As a bucking bar for all the floor pan rivets along the left and right sides of the fuselage, I used the long RV-10 bucking bar with a 2x4 block taped in the middle (this gives you leverage against the outside skin for holding pressure on the back side of the rivets). It takes some adjusting of the size of the block, but once you get it right you can get through those rivets quickly. You might want to support the outside skin with something to keep it from denting as you're pushing on it. Send me an email if you want to see a picture of the rivet set up. Jim McGrew RV-10 #134 - Just starting to wire fuse -----Original Message----- > From: _owner-rv10-list-server(at)matronics.com_ (mailto:owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list- > _server(at)matronics.com]_ (mailto:server(at)matronics.com]) On Behalf Of Doerr, Ray R [NTK] > Sent: Tuesday, May 31, 2005 7:30 PM > To: _rv10-list(at)matronics.com_ (mailto:rv10-list(at)matronics.com) > Subject: RE: RV10-List: The impossible rivets - 1 won, 1 lost > > Tim, you and I seem to be at the same sport. I ended up doing > the same thing for the nutplates on the baggage door jam. I drilled the > rivet hole to come out the back and then enlarged this hole to 1/4" and > back riveted it using a hammer and punch on a backing plate. > As for the most forward rivet on the rear side seat pans, I also > left this rivet out. I called Van's about it and explain to Bruce there > is no way to get this rivet because you can't get to either side of the > rivet with the gun. He went on to say you can use a pop rivet at a 15 > degree angle, but I said it would be more like a 70 degree angle and it > wouldn't work. If you look at the drawing that show the rear floor pan, > you will notice they don't even show this hole exists, so I wonder if > this was added later not thinking about how it would be set. > > > > Thank You > Ray Doerr > 40250 Floor Pans all rivet on. > > > > > > -----Original Message----- > From: _owner-rv10-list-server(at)matronics.com_ (mailto:owner-rv10-list-server(at)matronics.com) > [mailto:_owner-rv10-list-server(at)matronics.com]_ (mailto:owner-rv10-list-server(at)matronics.com]) On Behalf Of Tim Olson > Sent: Monday, May 30, 2005 11:16 PM > To: RV10 > Subject: RV10-List: The impossible rivets - 1 won, 1 lost > > > I found 2 "impossible" rivets, and the solution to one of them. QB > fuse, by the way. > > #1 is on the baggage door latch bracket that goes on the fuselage. > There are 2 nutplates to attach. 2 of those 4 rivets are not > accessible by squeezer or bucking bar. I did, however, > find that I have a very small flat squeezer set and I could drill > a hole and enlarge with a unibit in the flange underneath the > rivet, and get the squeezer through. I just don't know how else > you'd do it. Here's a couple of photos. > > _http://www.myrv10.com/N104CD/fuselage/20050530/RV200505260017.html_ (http://www.myrv10.com/N104CD/fuselage/20050530/RV200505260017.html) > _http://www.myrv10.com/N104CD/fuselage/20050530/RV200505260016.html_ (http://www.myrv10.com/N104CD/fuselage/20050530/RV200505260016.html) > > > The other impossible rivets are on the very forward hole of the > rear seat panels, on the sidewalls. There are holes that are completely > inaccessible by rivet gun, or pop rivet tool. This photo shows the > location, a couple inches NorthEast of the rivet set. > _http://www.myrv10.com/N104CD/fuselage/20050530/RV200505250013.html_ (http://www.myrv10.com/N104CD/fuselage/20050530/RV200505250013.html) > Short of drilling a hole through my seat bracket, which is NOT > worth it, I can't find a way to fill that hole. The ones on the > other side of the floor panel by the tunnel could be popped in > from the tunnel side I suppose, but you'd have an ugle rivet > sticking into the seating area. For now I'm just going to leave > them empty. If I got desperate, I'd GLUE in a rivet for looks... > then everyone would think I figured out the secret. :) > > Tim > > -- > > Tim Olson -- RV-10 #170 ________________________________________________________________________________
Subject: Question for Tim: Gretz pitot
Date: Oct 20, 2005
Tim, Where is the control module for the Gretz pitot mounted? I see in your pictures some 2 conductor wire with LEDs attached. Is this for a seperate wire run to the pitot or module? Looks like two sets of wire coming from the pitot itself. Wire for power to the heating element is a seperate 14 AWG wire correct? Just trying to figure wire runs in my wings. Thanks in advance for the info! John Hasbrouck #40264 ________________________________________________________________________________ SPAM: If the email is for spam, please report to abuse(at)dnsExit.com -By mail relay service at: http://www.dnsExit.com/Direct.sv?cmd=mailRelay Accounts will be suspended immediately if found spamming.
Date: Oct 20, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Hmm, seeing how you addressed this to Tim maybe I shouldn't chime in. Na, I'll give you my 2 cents, especially as I don't think Tim has mounted his controller yet. I almost forgot myself. You can see a couple of pics here, <http://www.kitlog.com/mykitlog/index.php?pworklog&worklogid4723> but basically I made a small mount out of some excess material and riveted it to the rib next to the pitot. Warren was pretty adamant about not lengthening the wires, might affect the thermistor resistance which would screw with the controller. Michael Sausen -10 #352 Wing bottom skins -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: RV10-List: Question for Tim: Gretz pitot --> Tim, Where is the control module for the Gretz pitot mounted? I see in your pictures some 2 conductor wire with LEDs attached. Is this for a seperate wire run to the pitot or module? Looks like two sets of wire coming from the pitot itself. Wire for power to the heating element is a seperate 14 AWG wire correct? Just trying to figure wire runs in my wings. Thanks in advance for the info! John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: The impossible rivets - 1 won, 1 lost
Rick wrote: > > I have included a few shots to show how it was done and an idea of the > type of riveting I am refering too. > > Rick S. > 40185 > Fuselage Great pics!!! Linn ________________________________________________________________________________
Subject: gretz pitot module install
Date: Oct 21, 2005
Hello John: i have incl a pic of my module install . Brian Bollaert #40200 ________________________________________________________________________________
Subject: Wing Tip Antennae
Date: Oct 21, 2005
Folks, I see many wing tip comm antennae being installed. Wasn't there a problem with blind spots with these antennae? Are these better than traditional placement? Is it primarily a cosmetic thing, or do these somehow improve on the traditional? Do you need on per wing tip to cure the blind spots? Where can I read up on this topic? Thanks in advance, John Jessen 40328 HS (still in buildus interruptus) ________________________________________________________________________________
Date: Oct 21, 2005
Thanks for the tip Rick, Just starting my RV-10. I like the color of your primer, what brand did you use. Bruce Case RV-10, #446 ________________________________________________________________________________
Date: Oct 21, 2005
John, Conventional wisdom is that the wingtip comm antennae have poor performance. They require vertical polarization to perform well and there just isn't much room in the wingtip for that. The Archer wingtip nav antennae on the other hand are widely regarded as very good performers (horizontal polarization). You'd think that there would be shadowing issues, but most reports from the field claim outstanding performance. Bob Archer specifically recommends AGAINST any sort of hooking multiple antennae together to achieve some perceived benefit. I installed one nav antenna in each wingtip along with his recommended marker beacon antenna in one wingtip. They're light and inexpensive, and if performance becomes an issue I'll just go with something external later to cure it. Most folks are installing external, belly mounted bent whip antenna (like a CI-122) for comms. Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Subject: RV10-List: Wing Tip Antennae Folks, I see many wing tip comm antennae being installed. Wasn't there a problem with blind spots with these antennae? Are these better than traditional placement? Is it primarily a cosmetic thing, or do these somehow improve on the traditional? Do you need on per wing tip to cure the blind spots? Where can I read up on this topic? Thanks in advance, John Jessen 40328 HS (still in buildus interruptus) ________________________________________________________________________________
Subject: Re: Question for Tim: Gretz pitot
Date: Oct 21, 2005
Michael, Thanks for the pictures! I addressed first post to Tim because his was the only install I was aware of. Why not install the pitot mount to the outboard of that rib using a splice from the rib flange to the mount? I know the instructions call for an angle riveted to the other side of the rib but they indicate there's isn't the only way to get the job done. Thoughts? John Hasbrouck #40264 ________________________________________________________________________________
Subject: Re: gretz pitot module install
Date: Oct 21, 2005
Brian, Cool! Great picture! Is that the Archer antenna in the foreground? John ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Re: Wing Tip Antennae
Hi John and all, The Sportcraft wingtip NAV antenna is an improvement over the "traditional" bipole VOR antenna. This is my understanding of how the Sportcraft wingtip NAV antenna works. The Sportcraft wingtip antenna's are "gamma" antenna's. (Seems like just a fancy way to label a ground plane antenna with a Greek letter "G".) The base of the antenna, or the ground plane, receives the signal with the antenna element (small aluminum plate connected to the center wire on the coax) acting as a capacitor for the signal. This doesn't make a perfect NAV antenna, but it is better than the "traditional" NAV antenna. The Sportcraft NAV antenna needs to be mounted as far forward in the wingtip as possible. (A common mistake is to mount the antenna near the center of the wingtip.) Preferably, the base of the Sportcraft NAV antenna should be attached to the wing skin (either the top, or the bottom) with as many fasteners as possible. Including the antenna base as part of the wingtip nutplate attachment is a good thing. Having at least four good ground contacts with these fasteners from the antenna base to the wing skin is a good thing. Five or more is better. After painting, clean the paint out of the wing skin dimple so the wingtip screw is against bare metal. The wires for the NAV light, strobe light and landing light need to be routed along the front edge of the Sportcraft NAV antenna in the Adel clamps provided. This actually improves the operation of the Sportcraft NAV antenna. (Do not route any wires over the top of the antenna element.) One last comment. If your install a Sportcraft wingtip NAV antenna and the Sportcraft Marker Beacon antenna in the same wingtip, the Marker Beacon antenna only provides about a 10 mile range when connected to the NAV receiver. :-) Regards, Jim Ayers RV-3 N47RV with 2 Sportcraft antenna's (right wingtip COM and VS COM) RV-4 (HR2) with 3 Sportcraft antenna's (wingtip NAV, wingtip COM and VS COM) RV-6A with 3 Sportcraft antenna's (wingtip NAV, wingtip COM and VS COM) In a message dated 10/21/2005 9:18:16 AM Pacific Daylight Time, jjessen(at)rcn.com writes: Folks, I see many wing tip comm antennae being installed. Wasn't there a problem with blind spots with these antennae? Are these better than traditional placement? Is it primarily a cosmetic thing, or do these somehow improve on the traditional? Do you need on per wing tip to cure the blind spots? Where can I read up on this topic? Thanks in advance, John Jessen 40328 HS (still in buildus interruptus) ________________________________________________________________________________
Date: Oct 21, 2005
Jim, Great set of pointers! If I can summarize your words: Do: - Mount the Sportcraft NAV antenna as far forward in the wingtip as possible. (A common mistake is to mount the antenna near the center of the wingtip.) - The base of the Sportcraft NAV antenna should be attached to the wing skin (either the top, or the bottom) with as many fasteners as possible. - Include the antenna base as part of the wingtip nutplate attachment. - Use at least four good ground contacts with these fasteners from the antenna base to the wing skin (Five or more is better). - After painting, clean the paint out of the wing skin dimple so the wingtip screw is against bare metal. - Route the wires for the NAV light, strobe light and landing light along the front edge of the Sportcraft NAV antenna in the Adel clamps provided (This actually improves the operation of the Sportcraft NAV antenna). Don't: - Do not route any wires over the top of the antenna element. Question: - If your install a Sportcraft wingtip NAV antenna and the Sportcraft Marker Beacon antenna in the same wingtip, the Marker Beacon antenna ONLY provides about a 10 mile range when connected to the NAV receiver. (Is this a good thing or a bad thing?) Jim Combs #40192 - N312F ________________________________________________________________________________
Date: Oct 21, 2005
Hi Jim, It usually a bad thing to connect antenna's to the wrong radio connection. It gets more embarrassing when the antenna coax cables are also labeled wrong at the radio end. :-) It usually works better to connect the NAV antenna to the NAV receiver. However, almost anything will work. By design, the marker beacon antenna should not work very well. After all, what's the point of receiving the outer marker signal 5 miles out? For the COM radio; If you have a BNC connector on the end of the coax for the COM antenna, the center conductor of the BNC connector, when left disconnected from the antenna, will provide about a 1 mile range for the COM radio. Regards, Jim Ayers In a message dated 10/21/2005 10:30:06 AM Pacific Daylight Time, jimc(at)mail.infra-read.com writes: Question: - If your install a Sportcraft wingtip NAV antenna and the Sportcraft Marker Beacon antenna in the same wingtip, the Marker Beacon antenna ONLY provides about a 10 mile range when connected to the NAV receiver. (Is this a good thing or a bad thing?) Jim Combs #40192 - N312F ________________________________________________________________________________
Date: Oct 21, 2005
Just to reinforce: I talked personally with Bob Archer about installation of the nav antenna in the RV-10 wingtip because I was concerned about the adhesive backed foil from the Van's landing light causing an issue. Bob A. reinforced the importance of mounting as far forward as possible, and very close but not touching the foil from the light. He also emphasized the importance of routing the wires along the antenna in the provided nylon loops. I also installed a MB antenna per his directions. If you do that you'll need to mount the nav antenna on the top side of the wingtip instead of the bottom where it would normally go. There are two models of his antennae - one for left and another for right side mounting (assuming they're going on the bottom surface of the wingtip). If you mount on the top surface you'll need the opposite side antenna since they're mirror images. In other words, If the left antenna is going to be on the bottom surface and right antenna will be on the top, order two "left" versions. His directions for the MB antenna are to simply remove 53" of shield from a length of antenna coax and attach it to the bottom surface of the wingtip, parallel to the edge of the wing and 1" from the metal wing surface. I used a few dabs of epoxy to secure mine. Bob #40105 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Subject: Re: RV10-List: Wing Tip Antennae Jim, Great set of pointers! If I can summarize your words: Do: - Mount the Sportcraft NAV antenna as far forward in the wingtip as possible. (A common mistake is to mount the antenna near the center of the wingtip.) - The base of the Sportcraft NAV antenna should be attached to the wing skin (either the top, or the bottom) with as many fasteners as possible. - Include the antenna base as part of the wingtip nutplate attachment. - Use at least four good ground contacts with these fasteners from the antenna base to the wing skin (Five or more is better). - After painting, clean the paint out of the wing skin dimple so the wingtip screw is against bare metal. - Route the wires for the NAV light, strobe light and landing light along the front edge of the Sportcraft NAV antenna in the Adel clamps provided (This actually improves the operation of the Sportcraft NAV antenna). Don't: - Do not route any wires over the top of the antenna element. Question: - If your install a Sportcraft wingtip NAV antenna and the Sportcraft Marker Beacon antenna in the same wingtip, the Marker Beacon antenna ONLY provides about a 10 mile range when connected to the NAV receiver. (Is this a good thing or a bad thing?) Jim Combs #40192 - N312F ________________________________________________________________________________
Subject: engine prices
Date: Oct 21, 2005
Just got an email from Van Bortel that they are expecting a 7% increase on Lycoming and Continental engine prices. I guess a rising tide lifts all ships. ________________________________________________________________________________
Date: Oct 21, 2005
You can print out an identifier (name or number or function etc.) and use clear het shrink tubing to hold it on a wire. You can use labelmakers like the Brother and do the same thing, but when printing a wire list, you can control the font size easily. Linn Jim Combs wrote: > >Ahh! > >Marking and identifying wiring (of all kinds) at each end is a topic all by itself! > >Any good ideas for marking and labeling wiring? > >Jim C > > -- ________________________________________________________________________________
Subject: Another idea for Gretz mount
Date: Oct 21, 2005
Some pictures are attached that show my idea for pitot mount. I wanted to keep all access to the pitot and mount in the last bay so I doubled and extended the flange of the next to last rib to provide a mounting surface similar to that shown in the instructions for the Gretz mount. See what you all think. ________________________________________________________________________________
Date: Oct 21, 2005
I don't believe the price increase they are talking about is from Lycoming. They are no longer an authorized Lycoming distributor (see the very, very fine print in their ad.) It is common for all engine suppliers to put a price increase into effect at the beginning of the year, as we have discussed on the list before. This increase must coming from their alternate supplier, whomever that is . . . Rhonda ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Subject: RV10-List: engine prices Just got an email from Van Bortel that they are expecting a 7% increase on Lycoming and Continental engine prices. I guess a rising tide lifts all ships. ________________________________________________________________________________
Date: Oct 21, 2005
This thing rocks for making labels to put on wire ends: http://www.lanshack.com/tls2200.asp its a bit pricey, but we used one of these during a data center installation for the network cables and it prints so that the type is parallel to the direction the wire runs on a white square, then the label has clear plastic that wraps around it and sticks it together and protects the printing. James #40400 linn walters wrote: > > You can print out an identifier (name or number or function etc.) and > use clear het shrink tubing to hold it on a wire. You can use > labelmakers like the Brother and do the same thing, but when printing > a wire list, you can control the font size easily. > Linn > Jim Combs wrote: > >> >> Ahh! >> Marking and identifying wiring (of all kinds) at each end is a topic >> all by itself! >> >> Any good ideas for marking and labeling wiring? >> Jim C >> >> > > ________________________________________________________________________________
Date: Oct 21, 2005
For dual NAV radio's, this would work great. One NAV antenna into each NAV receiver will maximize the NAV radio signal. For two NAV antenna's into one NAV radio, it's a disaster. With a node (dead spot) for every two feet of wingspan, the reception will be very erratic. Regards, Jim Ayers In a message dated 10/21/2005 11:43:29 AM Pacific Daylight Time, schmoboy(at)cox.net writes: --> RV10-List message posted by: Sean Stephens Two wingtip nav antennas (one in each tip), plus a mb antenna in one of the tips. ________________________________________________________________________________
Date: Oct 21, 2005
Hey, I've got one of those! They do indeed rock. I tend to use them on my ham radio antenna/power wiring. They certainly do seem to last forever. As long as we're showing cool tools, how about a tool to check the resonant frequency and SWR of your antennas? http://www.mfjenterprises.com/products.php?prodid=MFJ-269 As for antennas, Try the antenna book! http://www.arrl.org/catalog/?category=Antennas%2C+Transmission+Lines+%26+Propagation&words= <http://www.arrl.org/catalog/?category=Antennas%2C+Transmission+Lines+%26+Propagation&words=> Now, as for the discussion on antennas and coupling, here are my views: 1. You CAN couple antennas (even transmitting antennas), however you must have: a) a proper balun to couple the signals and match the impedance of the antennas to the line b) proper spacing/phasing to get a good gain from the antenna pair 2. Coupling (identical) antennas will only result in a signal increase of +3db 3. If you mismatch polarization (for example, you have H polarity and the base station has V polarity), you will get a loss of about 20db, resulting in a signal level of about 1/6 of what you would have if you had the polarity the same. In the "real world" however, there are signal reflections, etc. that influence the signal level. Did I mention that I am *really* into ham radio? I have built my own antennas and by far the most important thing you can do to improve your signal is to match the antenna to the line and make sure your antenna is at the correct length to resonate efficently at the frequency you desire. -Jim 40384 (Ham radio call N8VIM) Now let the antenna wars begin! James Ochs wrote: > > This thing rocks for making labels to put on wire ends: > > http://www.lanshack.com/tls2200.asp > > its a bit pricey, but we used one of these during a data center > installation for the network cables and it prints so that the type is > parallel to the direction the wire runs on a white square, then the > label has clear plastic that wraps around it and sticks it together > and protects the printing. > > James > #40400 > > linn walters wrote: > >> >> You can print out an identifier (name or number or function etc.) and >> use clear het shrink tubing to hold it on a wire. You can use >> labelmakers like the Brother and do the same thing, but when printing >> a wire list, you can control the font size easily. >> Linn >> Jim Combs wrote: >> >>> >>> Ahh! >>> Marking and identifying wiring (of all kinds) at each end is a topic >>> all by itself! >>> >>> Any good ideas for marking and labeling wiring? >>> Jim C >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 21, 2005
Thanks for the response Rick, I am leaning towards just priming mating surfaces as well plus any non-Alcad pieces. I am an A&P student and basically most planes that come into the shop look really good inside if they have had a decent hangar and look pretty bad if they are stored outside. Cessna didn't prime at all for many years. I will look into the Tempo product, I have typically used Dupont Variprime on the job but would prefer the gray color. I think Zinc Chromate is inferior to any of the modern etching primers if you don't do a great job of prep. Bruce ----- Original Message ----- From: Rick To: rv10-list(at)matronics.com Sent: Friday, October 21, 2005 3:28 PM Subject: Re: RV10-List: The impossible rivets - 1 won, 1 lost Bruce, I used several brands but the one in the picture is Tempo self etching grey from Spruce. I have also used AKZO in the tail feathers...two part tough as nails but sorta a pain to mix, spray and clean up (insert lazy here) I have Zinc Chromate in the wings, SW 988 here and there...no particular reasons for any one of them. Rattle cans are OK but you will spend more money, if your into mixing and spraying SW has an epoxy primer that is really nice and very tough. AKZO has that aviation color that some prefer and it is good stuff as well....I'm sure you have heard of the "primer wars" there are so many different methods to choose from. FWIW I was originally was looking at the Zenith 601. I went to their factory and the method of choice for them is to brush Zinc Chromate on all mating surfaces and leave the rest of the protection to the alcad coating on the aluminum. The spray can primers can be a bit tender until they really cure well but in a day or two they are much less apt to scratch. I buff with the red scotch pad, clean with MEK and paint them in my back yard on a set of old saw horses with a 2' X 6' wood frame made from 2x2's covered with chicken wire. Only damage is the overspray has caused the humming birds to grow an extra head and now I have to refill the feeder twice as often. Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 21, 2005
Just a semantics issue. Aircraft antenna's need to be LOW gain antenna's so they can transmit and receive equally well in all directions. IMHO, HIGH gain is a bad thing for aircraft antenna's. (Even if it is a good thing for Ham operations.) Regards, Jim Ayers In a message dated 10/21/2005 2:19:56 PM Pacific Daylight Time, n8vim(at)arrl.net writes: Now, as for the discussion on antennas and coupling, here are my views: 1. You CAN couple antennas (even transmitting antennas), however you must have: a) a proper balun to couple the signals and match the impedance of the antennas to the line b) proper spacing/phasing to get a good gain from the antenna pair 2. Coupling (identical) antennas will only result in a signal increase of +3db 3. If you mismatch polarization (for example, you have H polarity and the base station has V polarity), you will get a loss of about 20db, resulting in a signal level of about 1/6 of what you would have if you had the polarity the same. In the "real world" however, there are signal reflections, etc. that influence the signal level. Did I mention that I am *really* into ham radio? I have built my own antennas and by far the most important thing you can do to improve your signal is to match the antenna to the line and make sure your antenna is at the correct length to resonate efficently at the frequency you desire. -Jim 40384 (Ham radio call N8VIM) Now let the antenna wars begin! ________________________________________________________________________________
Date: Oct 21, 2005
Gain can be omnidirectional as well. For example, a 1/4 wave omnidirectional antenna is said to have 0db (d) gain, but a 7/8 wave omnidirectional antenna has about 5.2db (d) gain. Both radiate equally in all directions. Now, you can increase gain in one direction by decreasing it in another, but you can increase gain in an omni antenna in other ways as well. -Jim 40384 LessDragProd(at)aol.com wrote: > Just a semantics issue. Aircraft antenna's need to be LOW gain > antenna's so they can transmit and receive equally well in all directions. > > IMHO, HIGH gain is a bad thing for aircraft antenna's. (Even if it is > a good thing for Ham operations.) > > Regards, > Jim Ayers > > In a message dated 10/21/2005 2:19:56 PM Pacific Daylight Time, > n8vim(at)arrl.net writes: > > Now, as for the discussion on antennas and coupling, here are my > views: > 1. You CAN couple antennas (even transmitting antennas), > however you > must have: > a) a proper balun to couple the signals and match the > impedance > of the antennas to the line > b) proper spacing/phasing to get a good gain from the > antenna pair > 2. Coupling (identical) antennas will only result in a signal > increase of +3db > 3. If you mismatch polarization (for example, you have H polarity > and the base station has V polarity), you will get a loss of about > 20db, > resulting in a signal level of about 1/6 of what you would have if > you > had the polarity the same. In the "real world" however, there are > signal > reflections, etc. that influence the signal level. > > Did I mention that I am *really* into ham radio? I have built my own > antennas and by far the most important thing you can do to improve > your > signal is to match the antenna to the line and make sure your > antenna is > at the correct length to resonate efficently at the frequency you > desire. > > -Jim 40384 (Ham radio call N8VIM) > > Now let the antenna wars begin! > > ________________________________________________________________________________
Date: Oct 21, 2005
The one thing to be careful of is using a thermal printer in conjunction with shrink wrap??? Heating the shrink wrap over the thermal label will damage the printing??? The question marks are because I'm not positive and am more just asking. -Sean #40303 James Ochs wrote: > > This thing rocks for making labels to put on wire ends: > > http://www.lanshack.com/tls2200.asp > > its a bit pricey, but we used one of these during a data center > installation for the network cables and it prints so that the type is > parallel to the direction the wire runs on a white square, then the > label has clear plastic that wraps around it and sticks it together > and protects the printing. > > James > #40400 > > linn walters wrote: > >> >> You can print out an identifier (name or number or function etc.) and >> use clear het shrink tubing to hold it on a wire. You can use >> labelmakers like the Brother and do the same thing, but when printing >> a wire list, you can control the font size easily. >> Linn >> Jim Combs wrote: >> >>> >>> Ahh! >>> Marking and identifying wiring (of all kinds) at each end is a topic >>> all by itself! >>> >>> Any good ideas for marking and labeling wiring? >>> Jim C >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 21, 2005
That printer doesn't use shrink wrap. Its an adhesive label and only a small portion of the label is printable area, the rest is clear... it just wraps around itself. James Sean Stephens wrote: > > The one thing to be careful of is using a thermal printer in > conjunction with shrink wrap??? Heating the shrink wrap over the > thermal label will damage the printing??? > > The question marks are because I'm not positive and am more just asking. > > -Sean #40303 > > James Ochs wrote: > >> >> This thing rocks for making labels to put on wire ends: >> >> http://www.lanshack.com/tls2200.asp >> >> its a bit pricey, but we used one of these during a data center >> installation for the network cables and it prints so that the type is >> parallel to the direction the wire runs on a white square, then the >> label has clear plastic that wraps around it and sticks it together >> and protects the printing. >> >> James >> #40400 >> >> linn walters wrote: >> >>> >>> You can print out an identifier (name or number or function etc.) >>> and use clear het shrink tubing to hold it on a wire. You can use >>> labelmakers like the Brother and do the same thing, but when >>> printing a wire list, you can control the font size easily. >>> Linn >>> Jim Combs wrote: >>> >>>> >>>> >>>> Ahh! >>>> Marking and identifying wiring (of all kinds) at each end is a >>>> topic all by itself! >>>> >>>> Any good ideas for marking and labeling wiring? >>>> Jim C >>>> >>>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 21, 2005
The TLS is not really a thermal printer. It is a thermal *transfer* printer. The difference is that in a thermal printer, a chemical coating on the label/paper itself turns black when heat is applied, but a thermal transfer printer actually uses a "ribbon" which is not ink, but something similar to a carbon tape. The print head heats the area up and it is thermally bonded to the backing (label stock). This method will not fade or darken with heat. Another point: the labels for the TLS printer are self laminating. What you do is print only on 1/3 of the label, while the other 2/3 is clear. When you wrap the label on the cable, you'll wrap the clear part over the printed part and that's how it gets laminated! -Jim 40384 Sean Stephens wrote: > > The one thing to be careful of is using a thermal printer in > conjunction with shrink wrap??? Heating the shrink wrap over the > thermal label will damage the printing??? > > The question marks are because I'm not positive and am more just asking. > > -Sean #40303 > > James Ochs wrote: > >> >> This thing rocks for making labels to put on wire ends: >> >> http://www.lanshack.com/tls2200.asp >> >> its a bit pricey, but we used one of these during a data center >> installation for the network cables and it prints so that the type is >> parallel to the direction the wire runs on a white square, then the >> label has clear plastic that wraps around it and sticks it together >> and protects the printing. >> >> James >> #40400 >> >> linn walters wrote: >> >>> >>> You can print out an identifier (name or number or function etc.) >>> and use clear het shrink tubing to hold it on a wire. You can use >>> labelmakers like the Brother and do the same thing, but when >>> printing a wire list, you can control the font size easily. >>> Linn >>> Jim Combs wrote: >>> >>>> >>>> >>>> Ahh! >>>> Marking and identifying wiring (of all kinds) at each end is a >>>> topic all by itself! >>>> >>>> Any good ideas for marking and labeling wiring? >>>> Jim C >>>> >>>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Air Box Recess
Date: Oct 21, 2005
Anyone successfully fluted the recess to fit the air box and top plate? I'm resorting to glassing the hole in. Anh #141 ________________________________________________________________________________
Date: Oct 21, 2005
LessDragProd(at)aol.com wrote: > Just a semantics issue. Aircraft antenna's need to be LOW gain > antenna's so they can transmit and receive equally well in all directions. > > IMHO, HIGH gain is a bad thing for aircraft antenna's. (Even if it is a > good thing for Ham operations.) > > Regards, > Jim Ayers Hi Jim, I'm certain I do not understand why this would be the case, but I'm willing to have it explained to me... :-) I believe the gain in an antenna works both ways, as in it will not only provide an increase in the signal being received, but it will also increase the signal being transmitted out. In other words, a 5db gain antenna should work much better than a 1db gain antenna, all other things being equal. I'm referring to omni-directional antennas (360 degrees), not uni-directional antennas (focused more in one direction than others). I don't see why an aircraft AM radio would be any different than a Ham AM radio in this context. Or am I misunderstanding how an antenna works? -Dj Ham operator N1JOV ________________________________________________________________________________
Date: Oct 22, 2005
DJ, You are correct in that the gain works for transmitting as well as receiving. Antennas are antennas, no matter what application they are used in. As Scotty once said "You cannot change the laws of physics!" -Jim, 40384, N8VIM Dj Merrill wrote: > >LessDragProd(at)aol.com wrote: > > >>Just a semantics issue. Aircraft antenna's need to be LOW gain >>antenna's so they can transmit and receive equally well in all directions. >> >>IMHO, HIGH gain is a bad thing for aircraft antenna's. (Even if it is a >>good thing for Ham operations.) >> >>Regards, >>Jim Ayers >> >> > >Hi Jim, > I'm certain I do not understand why this would be >the case, but I'm willing to have it explained to me... :-) >I believe the gain in an antenna works both >ways, as in it will not only provide an >increase in the signal being received, but it will >also increase the signal being transmitted out. >In other words, a 5db gain antenna should work much >better than a 1db gain antenna, all other things >being equal. I'm referring to omni-directional >antennas (360 degrees), not uni-directional antennas >(focused more in one direction than others). >I don't see why an aircraft AM radio would be any different >than a Ham AM radio in this context. > > Or am I misunderstanding how an antenna works? > >-Dj >Ham operator N1JOV > > > > > > > > > ________________________________________________________________________________
Subject: Torque Drag
Date: Oct 22, 2005
Back in August we had a protracted discussion about torque values and whether to add "torque drag" to the torque value table. I've gone back and read those posts and don't see a definitive answer to that question... so I'll pose it again in the context of my current dilema. I'm currently attaching the W-823PP Aileron Bellcrank Brackets to the spar web and W-1020 Tie-Down Bracket with AN3-5A Bolts into K1000-3 nutplates. At 25 in/lbs of torque the brackets are not at all tight to the spar web. I've attempted to measure the drag from the nutplate, but my wrench has a minimum setting of 25 in/lbs and I don't think interpreting below that is going to be accurate. Any ideas? Jeff Carpenter 40304 Wings ________________________________________________________________________________
Date: Oct 22, 2005
Did some digging in the archive.... The most inovative method I found in making the recess, other than using the provided metal recess, is to heat the glass and push it in with a pipe. Anh #141 ________________________________________________________________________________
Date: Oct 22, 2005
Subject: Engine Mount Clearance update
Van's got my engine mount this week and turned it around a.s.a.p. I have a few photos from Scott, and did a write-up here for you all. http://www.myrv10.com/N104CD/engine/20051022/index.html If you read the above link, you can disregard the rest of this email. It's just a repost of the text for the archives. Tim They have been very very good at dealing with this issue for me. I think that hearing it from a few people now, they determined that there may be a potential issue for some customers and they wanted to figure it out a.s.a.p. and come up with a correction or a plan. I sent them my engine mount via FedEx and they got it the same week. They actually analyzed it right away the first day they got it in, and dropped me a note. Then, on Friday (the next day), they actually had someone come in to perform the welding so they could ship it out that same day. (This is extra special, since the guys who do this work 4 tens, and don't usually work Friday). They also offered to powder coat the weld if I wanted to wait a week or so for powder coating, but I opted to get the mount back a.s.a.p. so they were going to try to ship it back Friday. Great service....turn around in one day. Here are some facts: When they placed the engine mount in their test case, they had 3/16" to almost 1/4" clearance. That's still not 1/2", but it's about double what I had (.063 to .125") They feel there must be a difference in the sumps. I gave them my sump numbers because they want to investigate what the difference is. My numbers were: REV G 78066 EQ-2 W and a number that looks like Z1902 They say they aren't seeing any problem with the brand new Lycoming engines they're selling. Their first-glance look seems to indicate that my sump may be an off number from what they are used to seeing. Remember that any engine you buy, Aerosport, or any other non-factory-new, will be a rebuild that will potentially be built out of cases and sumps from any model year or number. This could cause some of these small variations. There is no such thing as an "Aerosport IO-540" as one list member wrote. They are all just rebuilds of other IO-540's that aren't factory new....and can be of various previous lineages. It is also interesting to note that according to Van's, the cross bar in question was determined unnecessary by engineering, but someone working with the engine mounts decided to add it anyway to add more structure and support. Given the solid design, I'd believe this, but when you see the mount, I think it's still best to have the bar there. That said, I can't picture there being hardly any stress on this particular joint. I could picture the "fix" being done without welding....cutting the tube, and bolting in a curved piece. Of course, a bolted joint would give more opportunity for corrosion where the tubes meet, so I'm happy with the welding option. So my modded engine mount is now enroute back to me, and I should be able to hang the engine for next weekend. It was a bit of a pain, but at least it didn't cause a major slowdown. My advice? Get your engine and mount hung while you're working on the canopy and fuselage. Then you can tell if you have any issues, and can pull it immediately and send it out for rework without slowing anything down. I am under the impression that Van's might be willing to work with future builders on this problem. I am not sure if they plan to make this mod part of their general contstruction in the future. If anyone gets that answer, let me know. They have been very good dealing with this for me though. Thanks Scott! (and Bruce) -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Oct 22, 2005
Jeff, I think we usually set the torque on AN3 bolts at 40in/lb when going into a nut plate. That seemed to let them tighten down a little bit. There was nothing scientific about this number, it just seemed to let the bolt tighten down about as much as with a nyloc nut at 25in/lb. The other option would be tapping the nut plate, which we did on some of the smaller ones that would not allow us to get a bolt in without messing up the head, but I wouldn't recommend doing that on something that is important. A tunnel cover inside the cockpit is one thing, but an aileron bell crank it completely different. This is just my $.02, but we have over 100 hours on our -10 and the ailerons are still working (knock on wood). GOD BLESS! Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter Subject: RV10-List: Torque Drag Back in August we had a protracted discussion about torque values and whether to add "torque drag" to the torque value table. I've gone back and read those posts and don't see a definitive answer to that question... so I'll pose it again in the context of my current dilema. I'm currently attaching the W-823PP Aileron Bellcrank Brackets to the spar web and W-1020 Tie-Down Bracket with AN3-5A Bolts into K1000-3 nutplates. At 25 in/lbs of torque the brackets are not at all tight to the spar web. I've attempted to measure the drag from the nutplate, but my wrench has a minimum setting of 25 in/lbs and I don't think interpreting below that is going to be accurate. Any ideas? Jeff Carpenter 40304 Wings ________________________________________________________________________________
Date: Oct 22, 2005
Subject: Re: Torque Drag
No! Do not tap any nutplates! The nutplate is slightly oval for a reason, which is to act as a locknut. By tapping the nutplate, you make the hole round removing any locking properties of the nutplate. You wouldn't put a regular nut where the plans call for a nyloc nut, so why would you want to destroy the locking properties of the nutplate? Sorry to be so harsh, but i've asked this question to an experienced A&P and he was very adamant about not tapping nutplates. -Jim Jesse Saint wrote: > >Jeff, > >I think we usually set the torque on AN3 bolts at 40in/lb when going into a >nut plate. That seemed to let them tighten down a little bit. There was >nothing scientific about this number, it just seemed to let the bolt tighten >down about as much as with a nyloc nut at 25in/lb. The other option would >be tapping the nut plate, which we did on some of the smaller ones that >would not allow us to get a bolt in without messing up the head, but I >wouldn't recommend doing that on something that is important. A tunnel >cover inside the cockpit is one thing, but an aileron bell crank it >completely different. > >This is just my $.02, but we have over 100 hours on our -10 and the ailerons >are still working (knock on wood). > >GOD BLESS! > >Jesse Saint >I-TEC, Inc. >jesse(at)itecusa.org >www.itecusa.org >W: 352-465-4545 >C: 352-427-0285 >F: 815-377-3694 > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter >Sent: Saturday, October 22, 2005 10:22 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: Torque Drag > > >Back in August we had a protracted discussion about torque values and >whether to add "torque drag" to the torque value table. I've gone >back and read those posts and don't see a definitive answer to that >question... so I'll pose it again in the context of my current dilema. > >I'm currently attaching the W-823PP Aileron Bellcrank Brackets to the >spar web and W-1020 Tie-Down Bracket with AN3-5A Bolts into K1000-3 >nutplates. At 25 in/lbs of torque the brackets are not at all tight >to the spar web. I've attempted to measure the drag from the >nutplate, but my wrench has a minimum setting of 25 in/lbs and I >don't think interpreting below that is going to be accurate. Any ideas? > >Jeff Carpenter >40304 >Wings > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Glide sloap antenna
Date: Oct 22, 2005
I plan on putting the Nav antennas in my wing tips, but what do you use for the glide slope? Also, there are no links for the pictures that are referred to in many messages, what do I need to do to receive those? Thanks Chris Hukill finished HS starting Tail cone (elevators shall wait) flying RV8 http://members.cox.net/cjhukill/ ________________________________________________________________________________
Date: Oct 22, 2005
I agree completely, in the case of bolts in question, which is why I said, "...but I wouldn't recommend..." In non-important places this can be very helpful, however, like on the rear passenger side panel covers, where the screws are very hard to get at to put in or take out, especially with the extra torque required by the nutplates. Anything important or outside the airplane should obviously not be tapped. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: Torque Drag No! Do not tap any nutplates! The nutplate is slightly oval for a reason, which is to act as a locknut. By tapping the nutplate, you make the hole round removing any locking properties of the nutplate. You wouldn't put a regular nut where the plans call for a nyloc nut, so why would you want to destroy the locking properties of the nutplate? Sorry to be so harsh, but i've asked this question to an experienced A&P and he was very adamant about not tapping nutplates. -Jim Jesse Saint wrote: > >Jeff, > >I think we usually set the torque on AN3 bolts at 40in/lb when going into a >nut plate. That seemed to let them tighten down a little bit. There was >nothing scientific about this number, it just seemed to let the bolt tighten >down about as much as with a nyloc nut at 25in/lb. The other option would >be tapping the nut plate, which we did on some of the smaller ones that >would not allow us to get a bolt in without messing up the head, but I >wouldn't recommend doing that on something that is important. A tunnel >cover inside the cockpit is one thing, but an aileron bell crank it >completely different. > >This is just my $.02, but we have over 100 hours on our -10 and the ailerons >are still working (knock on wood). > >GOD BLESS! > >Jesse Saint >I-TEC, Inc. >jesse(at)itecusa.org >www.itecusa.org >W: 352-465-4545 >C: 352-427-0285 >F: 815-377-3694 > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter >Sent: Saturday, October 22, 2005 10:22 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: Torque Drag > > >Back in August we had a protracted discussion about torque values and >whether to add "torque drag" to the torque value table. I've gone >back and read those posts and don't see a definitive answer to that >question... so I'll pose it again in the context of my current dilema. > >I'm currently attaching the W-823PP Aileron Bellcrank Brackets to the >spar web and W-1020 Tie-Down Bracket with AN3-5A Bolts into K1000-3 >nutplates. At 25 in/lbs of torque the brackets are not at all tight >to the spar web. I've attempted to measure the drag from the >nutplate, but my wrench has a minimum setting of 25 in/lbs and I >don't think interpreting below that is going to be accurate. Any ideas? > >Jeff Carpenter >40304 >Wings > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 22, 2005
I can't let this one slide. Yes, gain is reciprocal: If an antenna has gain for transmitting it will have the same gain for receiving. But -- Antennas can not increase the total signal transmitted nor can they increase the recieved signal from all directions. Antenna gain is achieved by focusing the signal in a manner simular to the way the reflector in a flashlight focus the light in one area. Antennas which exibit gain in a 360 degree circle do it only at one elevation angle. If you think in terms of a conventional antenna on or near the surface of the earth the omnidirectional gain exibited is achieved by taking power which would be directed vertically and redirecting it toward the horizon. (For terrestial communications this is good, but not necessarily so for airborne work.) I could go on and on, but hopefully you get the message. Sarge - K5wiv -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of James Hein Subject: Re: RV10-List: Wing Tip Antennae DJ, You are correct in that the gain works for transmitting as well as receiving. Antennas are antennas, no matter what application they are used in. As Scotty once said "You cannot change the laws of physics!" -Jim, 40384, N8VIM Dj Merrill wrote: > >LessDragProd(at)aol.com wrote: > > >>Just a semantics issue. Aircraft antenna's need to be LOW gain >>antenna's so they can transmit and receive equally well in all directions. >> >>IMHO, HIGH gain is a bad thing for aircraft antenna's. (Even if it is a >>good thing for Ham operations.) >> >>Regards, >>Jim Ayers >> >> > >Hi Jim, > I'm certain I do not understand why this would be >the case, but I'm willing to have it explained to me... :-) >I believe the gain in an antenna works both >ways, as in it will not only provide an >increase in the signal being received, but it will >also increase the signal being transmitted out. >In other words, a 5db gain antenna should work much >better than a 1db gain antenna, all other things >being equal. I'm referring to omni-directional >antennas (360 degrees), not uni-directional antennas >(focused more in one direction than others). >I don't see why an aircraft AM radio would be any different >than a Ham AM radio in this context. > > Or am I misunderstanding how an antenna works? > >-Dj >Ham operator N1JOV > > ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: Wing Tip Antennae - Marker Beacon
Dan Checkoway has some information on his wing tip marker beacon installation here <http://www.rvproject.com/20040128.html> and here <http://www.rvproject.com/20040201.html> From Scott's photos it looks like he is installing a similar arrangement the photo is here <http://scottandranae.smugmug.com/gallery/124475/4/8847036> I am planning on having the Archer style nav antenna in each wing tip. Where does the marker beacon antenna go (in the wing tip) in relation to the nav antenna? Larry Rosen #356 ________________________________________________________________________________
From: "Robert E. Lynch" <rv6lynch(at)earthlink.net>
Subject: Re: Lycoming O/IO-540 For sale
Date: Oct 23, 2005
Hi Phil. Have you had any interest in your engine? I might know of a buyer. Contact me of line. Bob ________________________________________________________________________________
Date: Oct 23, 2005
Subject: back rivet plate rust
Hey all, I haven't done any back riveting for a little while and I just looked at my back rivet plate and theres a nice big rust spot on it. Amazingly enough, it looks almost exactly like a palm print :P Apparently I must have picked it up or something without wiping it down after using it. Anyway, any suggestions on how to polish that out? Thanks, James #40400 Elevators ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: Cherry Blind Rivets
I think I've figured out something that will work for me (hopefully). Van's has the AACQ-4-3 and AACQ-4-4 1/8 structural pop rivets (alum shank and alum mandrel), and Aircraft Spruce has BSC-34 3/32 non-structural pop rivets (alum shank and steel mandrel). All of these are 120 degree flush, not 100, so I've ordered an inexpensive 120 degree dimple tool from Aircraft Spruce p/n 17014 <http://www.aircraftspruce.com/catalog/topages/dimpltool.php> If anyone is interested, I'll report back after I get them and try them out. Thanks for all the help and advice! -Dj ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: back rivet plate rust
Should come off fine with your 3M wheel or pad, followed up by some acetone or similar. -Sean #40303 James Ochs wrote: > > Hey all, > > I haven't done any back riveting for a little while and I just looked > at my back rivet plate and theres a nice big rust spot on it. > Amazingly enough, it looks almost exactly like a palm print :P > Apparently I must have picked it up or something without wiping it > down after using it. Anyway, any suggestions on how to polish that out? > > Thanks, > James > #40400 > Elevators > > ________________________________________________________________________________
Date: Oct 23, 2005
James, I had a similar issue with mine and just used scotchbrite (green) then followed it up with a little oil (WD40). Make sure you sand with the grain. Seemed to work great and it's good as new. Sean 40225 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: RV10-List: back rivet plate rust Hey all, I haven't done any back riveting for a little while and I just looked at my back rivet plate and theres a nice big rust spot on it. Amazingly enough, it looks almost exactly like a palm print :P Apparently I must have picked it up or something without wiping it down after using it. Anyway, any suggestions on how to polish that out? Thanks, James #40400 Elevators ________________________________________________________________________________
Date: Oct 23, 2005
The marker beacon antenna mounts in the bottom of the wingtip 3" outboard of the wing skin. The trailing edge end is mounted as far back in the wingtip as possible. The rest of the antenna is mounted parallel with the wing skin. The NAV antenna should be mounted as far forward as possible in the top of the wingtip. Regards, Jim Ayers In a message dated 10/23/2005 9:16:53 AM Pacific Daylight Time, LarryRosen(at)comcast.net writes: --> RV10-List message posted by: Larry Rosen Dan Checkoway has some information on his wing tip marker beacon installation here <http://www.rvproject.com/20040128.html> and here <http://www.rvproject.com/20040201.html> From Scott's photos it looks like he is installing a similar arrangement the photo is here <http://scottandranae.smugmug.com/gallery/124475/4/8847036> I am planning on having the Archer style nav antenna in each wing tip. Where does the marker beacon antenna go (in the wing tip) in relation to the nav antenna? Larry Rosen #356 ________________________________________________________________________________ h=message-id:date:from:user-agent:x-accept-language: 2FPlx5Lz/rgnWJopJwMqg==
Date: Oct 23, 2005
Subject: Approximate hours
To those of you who have completed either the complete RV-10 or those that have completed complete sections such as the empennage, wings, fuselage and/or the finish kit, would you be able to you supply me with the approximate hours per section? Am trying to calculate a budgeting timeline. Thanks. Ed Godfrey ________________________________________________________________________________
Date: Oct 23, 2005
If it is small enough, grease it up and put it in your oven like you would a cast iron skillet. Season to taste!! This was a tip from my builders course. Bobby 40116 -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Blair Subject: RE: RV10-List: back rivet plate rust James, I had a similar issue with mine and just used scotchbrite (green) then followed it up with a little oil (WD40). Make sure you sand with the grain. Seemed to work great and it's good as new. Sean 40225 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: RV10-List: back rivet plate rust Hey all, I haven't done any back riveting for a little while and I just looked at my back rivet plate and theres a nice big rust spot on it. Amazingly enough, it looks almost exactly like a palm print :P Apparently I must have picked it up or something without wiping it down after using it. Anyway, any suggestions on how to polish that out? Thanks, James #40400 Elevators ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: Oct 23, 2005
It may be a little late for this, but I kept the original special paper that the plate was wrapped in to keep it looking good. No big spots yet, and never wiped down here in humid AL. If you've recently bought your special bucking bar commercially than you'll have some more paper you can keep to wrap it in. Rob 40392 Elevators -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Subject: RE: RV10-List: back rivet plate rust If it is small enough, grease it up and put it in your oven like you would a cast iron skillet. Season to taste!! This was a tip from my builders course. Bobby 40116 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Blair Subject: RE: RV10-List: back rivet plate rust James, I had a similar issue with mine and just used scotchbrite (green) then followed it up with a little oil (WD40). Make sure you sand with the grain. Seemed to work great and it's good as new. Sean 40225 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Ochs Subject: RV10-List: back rivet plate rust Hey all, I haven't done any back riveting for a little while and I just looked at my back rivet plate and theres a nice big rust spot on it. Amazingly enough, it looks almost exactly like a palm print :P Apparently I must have picked it up or something without wiping it down after using it. Anyway, any suggestions on how to polish that out? Thanks, James #40400 Elevators ________________________________________________________________________________
Date: Oct 23, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
So there's no reliable way to know about engine sump clearance until you try it, eh? TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Tim Olson Subject: RV10-List: Engine Mount Clearance update Van's got my engine mount this week and turned it around a.s.a.p. I have a few photos from Scott, and did a write-up here for you all. http://www.myrv10.com/N104CD/engine/20051022/index.html If you read the above link, you can disregard the rest of this email. It's just a repost of the text for the archives. Tim They have been very very good at dealing with this issue for me. I think that hearing it from a few people now, they determined that there may be a potential issue for some customers and they wanted to figure it out a.s.a.p. and come up with a correction or a plan. I sent them my engine mount via FedEx and they got it the same week. They actually analyzed it right away the first day they got it in, and dropped me a note. Then, on Friday (the next day), they actually had someone come in to perform the welding so they could ship it out that same day. (This is extra special, since the guys who do this work 4 tens, and don't usually work Friday). They also offered to powder coat the weld if I wanted to wait a week or so for powder coating, but I opted to get the mount back a.s.a.p. so they were going to try to ship it back Friday. Great service....turn around in one day. Here are some facts: When they placed the engine mount in their test case, they had 3/16" to almost 1/4" clearance. That's still not 1/2", but it's about double what I had (.063 to .125") They feel there must be a difference in the sumps. I gave them my sump numbers because they want to investigate what the difference is. My numbers were: REV G 78066 EQ-2 W and a number that looks like Z1902 They say they aren't seeing any problem with the brand new Lycoming engines they're selling. Their first-glance look seems to indicate that my sump may be an off number from what they are used to seeing. Remember that any engine you buy, Aerosport, or any other non-factory-new, will be a rebuild that will potentially be built out of cases and sumps from any model year or number. This could cause some of these small variations. There is no such thing as an "Aerosport IO-540" as one list member wrote. They are all just rebuilds of other IO-540's that aren't factory new....and can be of various previous lineages. It is also interesting to note that according to Van's, the cross bar in question was determined unnecessary by engineering, but someone working with the engine mounts decided to add it anyway to add more structure and support. Given the solid design, I'd believe this, but when you see the mount, I think it's still best to have the bar there. That said, I can't picture there being hardly any stress on this particular joint. I could picture the "fix" being done without welding....cutting the tube, and bolting in a curved piece. Of course, a bolted joint would give more opportunity for corrosion where the tubes meet, so I'm happy with the welding option. So my modded engine mount is now enroute back to me, and I should be able to hang the engine for next weekend. It was a bit of a pain, but at least it didn't cause a major slowdown. My advice? Get your engine and mount hung while you're working on the canopy and fuselage. Then you can tell if you have any issues, and can pull it immediately and send it out for rework without slowing anything down. I am under the impression that Van's might be willing to work with future builders on this problem. I am not sure if they plan to make this mod part of their general contstruction in the future. If anyone gets that answer, let me know. They have been very good dealing with this for me though. Thanks Scott! (and Bruce) -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Oct 24, 2005
Subject: F-1010, F-1008R - Cracks in inner reinforce flange
While cleaning up the tailcone bulkheads, noticed a couple of small cracks in the F-1010 & F-1008R bulkheads in the inner stiffener flange that appear to have been caused while the parts were being pressed. The cracks are very small, probably only a few 1000ths thick and < 1/4" long so you really need to look closely, and are located in the top radius of the bulkheads. I've kicked around replacing them, spoke to Vans who said not to worry but stop-drill the cracks if it gives me piece of mind. Probably will stop drill and put doubler on web (gross overkill but why not) but still undecided. My question is has anyone else noticed this? If this is a common occurrence, then replacing the bulkhead won't accomplish anything and my decision is easy. Thanks, Tom Gesele #40473 - Tailcone. ________________________________________________________________________________
Subject: Fwd: Torque values for AN3 Bolts into K1000-3 nutplates
Date: Oct 24, 2005
0.15 HTML_TEXT_AFTER_BODY BODY: HTML contains text after BODY close tag Here's my response from Vans to the question of torque drag... Begin forwarded message: > From: "Bruce Reynolds" <brucer(at)vansaircraft.com> > Date: October 21, 2005 12:12:16 PM PDT > To: Jeff Carpenter > Subject: Re: Torque values for AN3 Bolts into K1000-3 nutplates > > > Jeff, > > We don't have a torque chart for putting bolts into nutplates. Just > get the bolt tight by feel. The danger is not leaving them too loose, > but in breaking off the bolt if too tight. Once the parts are seated > snug to each other, then you can stop. You could always make a > test fixture and see what it takes to break off a bolt in a nutplate. > > > Bruce Reynolds > brucer(at)vansaircraft.com > > ________________________________________________________________________________
Date: Oct 24, 2005
Tom, post to this list the individual at VAN's telling you that stop-drilling corrects for using worn dies during the CNC manufacture. Your kidding yourself if you buy off that the problem ends with a stop drill. This exact problem began in the kit #350 range and I can now conclude it was not resolved by #475. Quality parts should be a reasonable expectation on the 10. It has been unfortunately too overlooked. Tom was the source of such direction back near #350. Even the replacement part was cracked. Go Figure. Builders in this series should know what to look for and request a correction. John - KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Gesele Subject: RV10-List: F-1010, F-1008R - Cracks in inner reinforce flange While cleaning up the tailcone bulkheads, noticed a couple of small cracks in the F-1010 & F-1008R bulkheads in the inner stiffener flange that appear to have been caused while the parts were being pressed. The cracks are very small, probably only a few 1000ths thick and < 1/4" long so you really need to look closely, and are located in the top radius of the bulkheads. I've kicked around replacing them, spoke to Vans who said not to worry but stop-drill the cracks if it gives me piece of mind. Probably will stop drill and put doubler on web (gross overkill but why not) but still undecided. My question is has anyone else noticed this? If this is a common occurrence, then replacing the bulkhead won't accomplish anything and my decision is easy. Thanks, Tom Gesele #40473 - Tailcone. ________________________________________________________________________________
Subject: Flap Positioning System Contact info
Date: Oct 25, 2005
From: "Harris, Jeremy P" <jeremy.p.harris(at)boeing.com>
Does anyone have the phone number to "Show Planes" in Medford, OR? It's printed on the flap positioning box for the RV-10. Jeremy P. Harris Integrated Missile Defense BMDS Architectures Lab The Boeing Company Washington, DC Desk: (703) 414-6057 Dept: AV-2L-B27T Cell: (703) 627-6500 Fax: (703) 414-6372 MC: 793C-G007 Office: 825B ________________________________________________________________________________
Date: Oct 25, 2005
You can get Brian Melani at 541 773-3344. I believe that's the office number. Bob K 40125 Fuselage, just joined the front to center section -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Harris, Jeremy P Subject: RV10-List: Flap Positioning System Contact info Does anyone have the phone number to "Show Planes" in Medford, OR? It's printed on the flap positioning box for the RV-10. Jeremy P. Harris Integrated Missile Defense BMDS Architectures Lab The Boeing Company Washington, DC Desk: (703) 414-6057 Dept: AV-2L-B27T Cell: (703) 627-6500 Fax: (703) 414-6372 MC: 793C-G007 Office: 825B ________________________________________________________________________________
Subject: Andair Fuel Valves
Date: Oct 25, 2005
Gentlemen - Like many of you, I wanted an aircraft-quality fuel valve for my RV. I met with Andair's rep at Sun'N'Fun and explained our dilemma - common fittings made the valves too big for the space provided and banjo fittings are expensive, hard to find and add unnecessary joints to the system. The result of that conversation is the Andair FS20x7t. Details and (poor) pictures here: www.appaero.com/andair.htm The first shipment arrived last week and I have a few left. Cost is $250 delivered. Neal RV-7 N8ZG (fuselage) RV-8 N998GM (canoe flipped) Home - 334-262-8993 Cell - 334-546-2033 ________________________________________________________________________________
Date: Oct 24, 2005
I had to do some filling in around the depression insert Anh. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Subject: RV10-List: Air Box Recess Anyone successfully fluted the recess to fit the air box and top plate? I'm resorting to glassing the hole in. Anh #141 ________________________________________________________________________________
Date: Oct 25, 2005
Subject: Wing Tip Light Lens Nut Plate Rivets
What technique did you use to rivet the nut plate that holds the wing tip light lenses in place? I have already drilled the hole to mount the nut plate. The rivet holes are 1/16" from the lenses recess edge which seems to close to get a flat set on. I cannot back rivet because the rivet gun with a back rivet set will not fit inside the wing tip. Help please. Larry Rosen #356 Wing Tips ________________________________________________________________________________
Subject: Aileron Bracket Bearing hole misalignment
Date: Oct 25, 2005
Hey all - Has anyone had problems with the alignment of the bearing hole when you try to cleco W-1013B-L to W-1013B-R with W-1013A in the middle? When I cleco together using the rivet holes, there's almost 1/8" of misalignment between the counterbored holes that capture the bearing. I called Vans, and they didn't see how it was possible, but I'm looking at the part and it's plain as day. My wing kit arrived in august, so it's fairly recent. Anyone with a recent wing kit delivery have the same issue? The problem (I think) is with the part W-1013C-L, because that same part is used for the inner bracket on one side, and the outer of the other, and they're both hosed. Thanks cj #40410 wings ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Subject: Re: Wing Tip Light Lens Nut Plate Rivets
Date: Oct 25, 2005
Hi, use a blind rivet. ----- Original Message ----- From: "Larry Rosen" <LarryRosen(at)comcast.net> Subject: RV10-List: Wing Tip Light Lens Nut Plate Rivets > > What technique did you use to rivet the nut plate that holds the wing > tip light lenses in place? > > I have already drilled the hole to mount the nut plate. The rivet holes > are 1/16" from the lenses recess edge which seems to close to get a flat > set on. I cannot back rivet because the rivet gun with a back rivet set > will not fit inside the wing tip. > > Help please. > > Larry Rosen > #356 > Wing Tips > > > > > > > > > > > ________________________________________________________________________________
From: "Jeffrey C. Van Dam, P.E." <jcvandam(at)mgci.com>
Subject: Re: Aileron Bracket Bearing hole misalignment
Date: Oct 25, 2005
I'm having the same problem with bearing hole. When I put the bearing in the rivet holes close to the bearing are off by almost 1/8". I drilled the rivet holes to final size and now have elongated holes. I haven't yet decided on a fix. Jeff Van Dam #40265 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Subject: RE: RV10-List: Aileron Bracket Bearing hole misalignment > > Hey all - > > Has anyone had problems with the alignment of the bearing hole when you > try to cleco W-1013B-L to W-1013B-R with W-1013A in the middle? When I > cleco together using the rivet holes, there's almost 1/8" of > misalignment between the counterbored holes that capture the bearing. I > called Vans, and they didn't see how it was possible, but I'm looking at > the part and it's plain as day. My wing kit arrived in august, so it's > fairly recent. Anyone with a recent wing kit delivery have the same > issue? The problem (I think) is with the part W-1013C-L, because that > same part is used for the inner bracket on one side, and the outer of > the other, and they're both hosed. > > Thanks > cj > #40410 > wings > > > ________________________________________________________________________________
Date: Oct 25, 2005
Hey Jeff - After I spoke with the tech guy, I ordered new parts, and I'm sending them my old misaligned brackets. I'm leaving them clecoed together with a note so that the problem is VERY apparent. Not sure what I'll do if the new ones have the same problem. cj #40410 wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeffrey C. Van Dam, P.E. Subject: Re: RV10-List: Aileron Bracket Bearing hole misalignment I'm having the same problem with bearing hole. When I put the bearing in the rivet holes close to the bearing are off by almost 1/8". I drilled the rivet holes to final size and now have elongated holes. I haven't yet decided on a fix. Jeff Van Dam #40265 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Subject: RE: RV10-List: Aileron Bracket Bearing hole misalignment > > Hey all - > > Has anyone had problems with the alignment of the bearing hole when you > try to cleco W-1013B-L to W-1013B-R with W-1013A in the middle? When I > cleco together using the rivet holes, there's almost 1/8" of > misalignment between the counterbored holes that capture the bearing. I > called Vans, and they didn't see how it was possible, but I'm looking at > the part and it's plain as day. My wing kit arrived in august, so it's > fairly recent. Anyone with a recent wing kit delivery have the same > issue? The problem (I think) is with the part W-1013C-L, because that > same part is used for the inner bracket on one side, and the outer of > the other, and they're both hosed. > > Thanks > cj > #40410 > wings > > > ________________________________________________________________________________
Date: Oct 25, 2005
Just so you know how mine did, My bearings were an almost perfect, machined fit, only slight pressure was needed for them to snap nicely in place and the two brackets lined up perfectly for drilling and riveting. For some reason several builders are having trouble and it has to be in the manufacture of the brackets or undersized OD on the bearing.( Unless there is a way you can mismatch your pieces somehow or over deburring as one member said he did.) This is a major hingepoint connection and you don't even want to second guess the integrity. Slop could lead to catastrophic failure from flutter and you may not see the slop until it is too late. Van's has always been responsive to me, get your parts, take photos, measurements and email them to support and wait for them to respond or setup a phone call after they have reviewed the pictures etc. so you can discuss. Make your case so you don't get the "that's not possible" response. Just my @ cents worth Rick S. 40185 Fuselage ________________________________________________________________________________
Date: Oct 25, 2005
Wish I had thought of that....I used what is called a suicide rivet set. Basically a set without the mushroom head on it. The back rivet set works well as a suicide, just drive out the roll pin and try it but heck the blind rivet is a perfect resolution to the problem. Rick S. 40185 Fuselage ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Oct 25, 2005
I turned the nutplate parallel to the edge - plenty of room to put in one good rivet. I then epoxyed the other nutplate lug to the fiberglass. Seems to work out just fine. John Testement jwt(at)roadmapscoaching.com 40321 Finishing QB wings, starting QB fuse -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RAS Subject: Re: RV10-List: Wing Tip Light Lens Nut Plate Rivets --> Hi, use a blind rivet. ----- Original Message ----- From: "Larry Rosen" <LarryRosen(at)comcast.net> Subject: RV10-List: Wing Tip Light Lens Nut Plate Rivets > > What technique did you use to rivet the nut plate that holds the wing > tip light lenses in place? > > I have already drilled the hole to mount the nut plate. The rivet holes > are 1/16" from the lenses recess edge which seems to close to get a flat > set on. I cannot back rivet because the rivet gun with a back rivet set > will not fit inside the wing tip. > > Help please. > > Larry Rosen > #356 > Wing Tips > > > > > > > > > > > ________________________________________________________________________________
"Jeff Carpenter"
Subject: Re: [RV10] Revisiting Torque
Date: Oct 25, 2005
You need a torque wrench with lower values. I have a 0-75 inch pound (dial gauge) that covers most areas. For self locking nuts either nylock or ovalized steel (nut plates) you should measure the torque required to turn the nut/bolt after at least a couple of threads have entered past the end of the nut. This is the run on torque. As the bolt/nut approaches clamping of the parts torque will rise. You SHOULD torque to the value in the table for the bolt PLUS the run on torque you measured. I measured several nylocks and decided they were consistent enough to use the same run on value then I just add this to the torque table value. So I don't always check the run on torque every time. Example: If the table is 25 in-lbs max, and run on torque is 7 in-lbs then max torque you actually should apply is 32 in-lbs. (This is the way the standard practices manual for GE engines explains it) Chris L #40072 N919AR ----- Original Message ----- From: Jeff Carpenter To: RV Group Sent: Friday, October 21, 2005 2:10 PM Subject: [RV10] Revisiting Torque Back in August we had a protracted discussion about torque values and whether to add "torque drag" to the torque value table. I've gone back and read those posts and don't see a definitive answer to that question... so I'll pose it again in the context of my current dilema. I'm currently attaching the W-823PP Aileron Bellcrank Brackets to the spar web and W-1020 Tie-Down Bracket with AN3-5A Bolts into K1000-3 nutplates. At 25 in/lbs of torque the brackets are not at all tight to the spar web. I've attempted to measure the drag from the nutplate, but my wrench has a minimum setting of 25 in/lbs and I don't think interpreting below that is going to be accurate. Any ideas? Jeff Carpenter 40304 Wings a.. Visit your group "RV10" on the web. b.. To unsubscribe from this group, send an email to: RV10-unsubscribe(at)yahoogroups.com ________________________________________________________________________________
Date: Oct 25, 2005
I had the same problem and Vans's replaced my parts after I e-mailed them. It was the W-1013B-L that was misaligned. The new ones fit perfectly. My wings were shipped around May of this year. A fellow builder in my area had the same problem. John Hasbrouck #40264 ________________________________________________________________________________
Subject: Wingtip lens
Date: Oct 25, 2005
While were on the subject of the wingtip lens, does it look to you all the two screws are enough? Every store bought plane with these types of lenses use multiple flush screws to hold the lens in place. If a stress crack developes at one of the screw holes, ( easy to do if you overtighten the screw) it wouldn't take long for the lens to depart the wingtip maybe taking some of the wingtip with it. Maybe I'm being paranoid, I have no experience with other Van's wingtips, but it looks like a weak point to me. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 25, 2005
Subject: Re: Wingtip lens
I just did my lenses tonight....post-painting. Have a tip, and want to comment on this thread. First, back on the riveting: Doing the lens fitting after painting (stupid me) I didn't want to risk riveting using pounded rivets. In fact, I think given the location, I'd rather never use pounded rivets in that location. I found my solution. I did everything as listed in the plans, including the nutplate orientation. But, then I substituted these rivets: CCR-264SS-3-2 We had them that I believe came with the tailcone section....don't know where they're supposed to be used. Anyway, they're heavy-duty rivets, but in this application, they aren't. What happens is when you pull the rivet, the fit isn't tight enough, especially in fiberglass, to snap the shaft. So, it expands the rivet shank, capturing the nutplate...then the shaft pulls right through. It should hold that nutplate plenty, with no worry since it's not structural anyway. Sure, the rivets are $.19 each, but it sure is more comfortable than hammering! Now, on to the thread... Yes John, after doing mine tonight, I totally agree with you that 2 screws, especially as placed, are not enough for me to be comfortable. There's a tiny bit of slop in the tip covers, and I can easily see that 200mph air sneaking under the front corner and ripping that thing right off. So, my plan is to order a few more of those rivets I mentioned above, and put in 2 more nutplates per side.... about 1/3 the way back from the leading edge, on top and bottom. Then I should feel pretty good about it, as the back side will not probably ever cause any problems. Part of that problem is made an issue because the lens doesn't make the same exact curve as that flange it rests on does. The lens contacts the corner of it, but isn't flush along the whole flange. Perhaps a tiny bit of heat on the lens, and a slight bend along the flange area to flush it up might help....I'm still considering it. Tim Olson -- RV-10 #40170 John Hasbrouck wrote: > > While were on the subject of the wingtip lens, does it look to you all > the two screws are enough? Every store bought plane with these types of > lenses use multiple flush screws to hold the lens in place. If a stress > crack developes at one of the screw holes, ( easy to do if you > overtighten the screw) it wouldn't take long for the lens to depart the > wingtip maybe taking some of the wingtip with it. Maybe I'm being > paranoid, I have no experience with other Van's wingtips, but it looks > like a weak point to me. > > John Hasbrouck > #40264 > ________________________________________________________________________________
Date: Oct 25, 2005
Tim, I did heat my lens with a heat gun and smoothed it into shape with a cloth. It worked great to fit the lens perfectly to the contour. John Testement jwt(at)roadmapscoaching.com 40321 Finishing QB wings, starting QB fuse -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: Re: RV10-List: Wingtip lens I just did my lenses tonight....post-painting. Have a tip, and want to comment on this thread. First, back on the riveting: Doing the lens fitting after painting (stupid me) I didn't want to risk riveting using pounded rivets. In fact, I think given the location, I'd rather never use pounded rivets in that location. I found my solution. I did everything as listed in the plans, including the nutplate orientation. But, then I substituted these rivets: CCR-264SS-3-2 We had them that I believe came with the tailcone section....don't know where they're supposed to be used. Anyway, they're heavy-duty rivets, but in this application, they aren't. What happens is when you pull the rivet, the fit isn't tight enough, especially in fiberglass, to snap the shaft. So, it expands the rivet shank, capturing the nutplate...then the shaft pulls right through. It should hold that nutplate plenty, with no worry since it's not structural anyway. Sure, the rivets are $.19 each, but it sure is more comfortable than hammering! Now, on to the thread... Yes John, after doing mine tonight, I totally agree with you that 2 screws, especially as placed, are not enough for me to be comfortable. There's a tiny bit of slop in the tip covers, and I can easily see that 200mph air sneaking under the front corner and ripping that thing right off. So, my plan is to order a few more of those rivets I mentioned above, and put in 2 more nutplates per side.... about 1/3 the way back from the leading edge, on top and bottom. Then I should feel pretty good about it, as the back side will not probably ever cause any problems. Part of that problem is made an issue because the lens doesn't make the same exact curve as that flange it rests on does. The lens contacts the corner of it, but isn't flush along the whole flange. Perhaps a tiny bit of heat on the lens, and a slight bend along the flange area to flush it up might help....I'm still considering it. Tim Olson -- RV-10 #40170 John Hasbrouck wrote: > --> > > While were on the subject of the wingtip lens, does it look to you all > the two screws are enough? Every store bought plane with these types > of lenses use multiple flush screws to hold the lens in place. If a > stress crack developes at one of the screw holes, ( easy to do if you > overtighten the screw) it wouldn't take long for the lens to depart > the wingtip maybe taking some of the wingtip with it. Maybe I'm being > paranoid, I have no experience with other Van's wingtips, but it looks > like a weak point to me. > > John Hasbrouck > #40264 > ________________________________________________________________________________
From: "Indran Chelvanayagam" <ichelva(at)netspace.net.au>
Date: Oct 26, 2005
Here's one solution I found amongst the multiple RVs parked at Oshkosh this year... Looks pretty secure to me ;-) Indran Chelvanayagam #40228 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: RV10-List: Wingtip lens --> While were on the subject of the wingtip lens, does it look to you all the two screws are enough? Every store bought plane with these types of lenses use multiple flush screws to hold the lens in place. If a stress crack developes at one of the screw holes, ( easy to do if you overtighten the screw) it wouldn't take long for the lens to depart the wingtip maybe taking some of the wingtip with it. Maybe I'm being paranoid, I have no experience with other Van's wingtips, but it looks like a weak point to me. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 25, 2005
Good to know. I'm sure that also helps add to the security if you only use 2 screws...it's harder for it to pop out if the front and rear edges are are tight to the wingtip. I'll try the heat gun approach, but I'll have to be careful of the paint. Tim Olson -- RV-10 #40170 John Testement wrote: > > Tim, > > I did heat my lens with a heat gun and smoothed it into shape with a cloth. > It worked great to fit the lens perfectly to the contour. > > John Testement > jwt(at)roadmapscoaching.com > 40321 > Finishing QB wings, starting QB fuse > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Tuesday, October 25, 2005 9:18 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Wingtip lens > > > I just did my lenses tonight....post-painting. Have a tip, and want to > comment on this thread. > > First, back on the riveting: Doing the lens fitting after painting (stupid > me) I didn't want to risk riveting using pounded rivets. > In fact, I think given the location, I'd rather never use pounded > rivets in that location. I found my solution. I did everything > as listed in the plans, including the nutplate orientation. But, > then I substituted these rivets: CCR-264SS-3-2 We had them that > I believe came with the tailcone section....don't know where they're > supposed to be used. Anyway, they're heavy-duty rivets, but in this > application, they aren't. What happens is when you pull the rivet, the fit > isn't tight enough, especially in fiberglass, to snap the shaft. So, it > expands the rivet shank, capturing the nutplate...then the shaft pulls right > through. It should hold that nutplate plenty, with no worry since it's not > structural anyway. > Sure, the rivets are $.19 each, but it sure is more comfortable than > hammering! > > Now, on to the thread... Yes John, after doing mine tonight, > I totally agree with you that 2 screws, especially as placed, are not enough > for me to be comfortable. There's a tiny bit of slop in the tip covers, and > I can easily see that 200mph air sneaking under the front corner and ripping > that thing > right off. So, my plan is to order a few more of those rivets > I mentioned above, and put in 2 more nutplates per side.... > about 1/3 the way back from the leading edge, on top and bottom. > Then I should feel pretty good about it, as the back side will not probably > ever cause any problems. > > Part of that problem is made an issue because the lens doesn't make the same > exact curve as that flange it rests on does. > The lens contacts the corner of it, but isn't flush along the whole flange. > Perhaps a tiny bit of heat on the lens, and a slight bend along the flange > area to flush it up might help....I'm still considering it. > > Tim Olson -- RV-10 #40170 > > > John Hasbrouck wrote: > >>--> >> >>While were on the subject of the wingtip lens, does it look to you all >>the two screws are enough? Every store bought plane with these types >>of lenses use multiple flush screws to hold the lens in place. If a >>stress crack developes at one of the screw holes, ( easy to do if you >>overtighten the screw) it wouldn't take long for the lens to depart >>the wingtip maybe taking some of the wingtip with it. Maybe I'm being >>paranoid, I have no experience with other Van's wingtips, but it looks >>like a weak point to me. >> >>John Hasbrouck >>#40264 >> > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Air Box Recess
Date: Oct 26, 2005
Thanks Randy. My insert did not work at all. It was not deep enough laterally to clear the fuel mixture arm. I made the recess out of glass. Anh ----- Original Message ----- From: Randy DeBauw To: rv10-list(at)matronics.com Sent: Monday, October 24, 2005 4:39 PM Subject: RE: RV10-List: Air Box Recess I had to do some filling in around the depression insert Anh. Randy From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Sent: Friday, October 21, 2005 6:46 PM To: RV10 Subject: RV10-List: Air Box Recess Anyone successfully fluted the recess to fit the air box and top plate? I'm resorting to glassing the hole in. Anh #141 ________________________________________________________________________________
Date: Oct 26, 2005
Subject: Incidentals
Another list member emailed me recently that they were keeping track of all of the incidentals and things that weren't in the kit...shipping, extra nuts and bolts from the hardware store, glues, and things like that. They're currently up to $5100 or so, working through the engine stage with a bunch of things left to go, so there will be a lot of other incidentals coming. That got me wondering where I came out. At this point, everything that I have left to buy is an incidental, and I'd never done any addition. My list isn't 100% complete either. So a quick rundown of my spreadsheet to remove things like engine, prop, all kit parts, including some things that I bought because I broke them, no tools, and all avionics, I have a rough total too. Mine does include paints, primers, and all those things....seat belts, lighting, and all that good stuff... even engine oil for the break in. My current total is $13,250 approx. I expect at least another $400-500, if not double or triple that much, as I complete the kit. (There are some extra nuts and bolts in there that I won't need, but it's nice to have a stock of them and it's not worth worrying about an extra $200-500 in hardware.) This all shouldn't be taken as a complaint at all, because I'm not intending to start a gripe about what isn't included....there are good reasons that these things are options for the most part. But, for those lurkers who are trying to come up with an estimate on kit costs, after purchasing the kit itself, these 2 data points might help form a good estimated starting point. Most of the costs are pretty predictible on the big items. I would caution the prospective builder though to not under estimate their panel and avionics costs. That's where you're most likely to blow your budget. Get a quote on what you think is a panel that fits you, and add $10,000 to it just in case...it goes fast. One word of warning....not everyone is comfortable with the idea of adding up their total kit costs, so think about it before you do it.....and then decide if you do, can you tell your wife. ;) -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Oct 26, 2005
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
ON my RV-9 I have 4 on top and 4 on bottom, 2 along each side of the lense. I think I am going to put 3 on my RV-10, one in the corner like Van's says and then one extra one half way between the leading edge and the aft edge. Thank You Ray Doerr 40250 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: RV10-List: Wingtip lens While were on the subject of the wingtip lens, does it look to you all the two screws are enough? Every store bought plane with these types of lenses use multiple flush screws to hold the lens in place. If a stress crack developes at one of the screw holes, ( easy to do if you overtighten the screw) it wouldn't take long for the lens to depart the wingtip maybe taking some of the wingtip with it. Maybe I'm being paranoid, I have no experience with other Van's wingtips, but it looks like a weak point to me. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 26, 2005
Be careful before you put the nutplates too close to the leading edge because the curve on the outside of the tip will be different then the curve on the inside where the nutplates are. This can cause the screw to be at an angle to the outside surface and looks bad when you have to countersink the lense and the screw is sticking up on one side and countersunk too deep on the other. I would stay at least 2 - 3 inches back from the leading edge. Thank You Ray Doerr 40250 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: Re: RV10-List: Wingtip lens I just did my lenses tonight....post-painting. Have a tip, and want to comment on this thread. First, back on the riveting: Doing the lens fitting after painting (stupid me) I didn't want to risk riveting using pounded rivets. In fact, I think given the location, I'd rather never use pounded rivets in that location. I found my solution. I did everything as listed in the plans, including the nutplate orientation. But, then I substituted these rivets: CCR-264SS-3-2 We had them that I believe came with the tailcone section....don't know where they're supposed to be used. Anyway, they're heavy-duty rivets, but in this application, they aren't. What happens is when you pull the rivet, the fit isn't tight enough, especially in fiberglass, to snap the shaft. So, it expands the rivet shank, capturing the nutplate...then the shaft pulls right through. It should hold that nutplate plenty, with no worry since it's not structural anyway. Sure, the rivets are $.19 each, but it sure is more comfortable than hammering! Now, on to the thread... Yes John, after doing mine tonight, I totally agree with you that 2 screws, especially as placed, are not enough for me to be comfortable. There's a tiny bit of slop in the tip covers, and I can easily see that 200mph air sneaking under the front corner and ripping that thing right off. So, my plan is to order a few more of those rivets I mentioned above, and put in 2 more nutplates per side.... about 1/3 the way back from the leading edge, on top and bottom. Then I should feel pretty good about it, as the back side will not probably ever cause any problems. Part of that problem is made an issue because the lens doesn't make the same exact curve as that flange it rests on does. The lens contacts the corner of it, but isn't flush along the whole flange. Perhaps a tiny bit of heat on the lens, and a slight bend along the flange area to flush it up might help....I'm still considering it. Tim Olson -- RV-10 #40170 John Hasbrouck wrote: > > While were on the subject of the wingtip lens, does it look to you all > the two screws are enough? Every store bought plane with these types of > lenses use multiple flush screws to hold the lens in place. If a stress > crack developes at one of the screw holes, ( easy to do if you > overtighten the screw) it wouldn't take long for the lens to depart the > wingtip maybe taking some of the wingtip with it. Maybe I'm being > paranoid, I have no experience with other Van's wingtips, but it looks > like a weak point to me. > > John Hasbrouck > #40264 > ________________________________________________________________________________
Date: Oct 26, 2005
Yeah, it's best to save your spreadsheet somewhere on the computer where your wife is not going to find it! Maybe give it a fake filename like "Baseball Stats" . . . : ) TDT 40025 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Incidentals Another list member emailed me recently that they were keeping track of all of the incidentals and things that weren't in the kit...shipping, extra nuts and bolts from the hardware store, glues, and things like that. They're currently up to $5100 or so, working through the engine stage with a bunch of things left to go, so there will be a lot of other incidentals coming. That got me wondering where I came out. At this point, everything that I have left to buy is an incidental, and I'd never done any addition. My list isn't 100% complete either. So a quick rundown of my spreadsheet to remove things like engine, prop, all kit parts, including some things that I bought because I broke them, no tools, and all avionics, I have a rough total too. Mine does include paints, primers, and all those things....seat belts, lighting, and all that good stuff... even engine oil for the break in. My current total is $13,250 approx. I expect at least another $400-500, if not double or triple that much, as I complete the kit. (There are some extra nuts and bolts in there that I won't need, but it's nice to have a stock of them and it's not worth worrying about an extra $200-500 in hardware.) This all shouldn't be taken as a complaint at all, because I'm not intending to start a gripe about what isn't included....there are good reasons that these things are options for the most part. But, for those lurkers who are trying to come up with an estimate on kit costs, after purchasing the kit itself, these 2 data points might help form a good estimated starting point. Most of the costs are pretty predictible on the big items. I would caution the prospective builder though to not under estimate their panel and avionics costs. That's where you're most likely to blow your budget. Get a quote on what you think is a panel that fits you, and add $10,000 to it just in case...it goes fast. One word of warning....not everyone is comfortable with the idea of adding up their total kit costs, so think about it before you do it.....and then decide if you do, can you tell your wife. ;) -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Subject: Re: Incidentals
Date: Oct 26, 2005
Now everyone knows where yours is. ----- Original Message ----- From: Tim Dawson-Townsend<mailto:Tdawson(at)avidyne.com> To: rv10-list(at)matronics.com Sent: Wednesday, October 26, 2005 10:26 AM Subject: RE: RV10-List: Incidentals Yeah, it's best to save your spreadsheet somewhere on the computer where your wife is not going to find it! Maybe give it a fake filename like "Baseball Stats" . . . : ) TDT 40025 -----Original Message----- From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server(at)matronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, October 26, 2005 10:11 AM To: RV10 Subject: RV10-List: Incidentals Another list member emailed me recently that they were keeping track of all of the incidentals and things that weren't in the kit...shipping, extra nuts and bolts from the hardware store, glues, and things like that. They're currently up to $5100 or so, working through the engine stage with a bunch of things left to go, so there will be a lot of other incidentals coming. That got me wondering where I came out. At this point, everything that I have left to buy is an incidental, and I'd never done any addition. My list isn't 100% complete either. So a quick rundown of my spreadsheet to remove things like engine, prop, all kit parts, including some things that I bought because I broke them, no tools, and all avionics, I have a rough total too. Mine does include paints, primers, and all those things....seat belts, lighting, and all that good stuff... even engine oil for the break in. My current total is $13,250 approx. I expect at least another $400-500, if not double or triple that much, as I complete the kit. (There are some extra nuts and bolts in there that I won't need, but it's nice to have a stock of them and it's not worth worrying about an extra $200-500 in hardware.) This all shouldn't be taken as a complaint at all, because I'm not intending to start a gripe about what isn't included....there are good reasons that these things are options for the most part. But, for those lurkers who are trying to come up with an estimate on kit costs, after purchasing the kit itself, these 2 data points might help form a good estimated starting point. Most of the costs are pretty predictible on the big items. I would caution the prospective builder though to not under estimate their panel and avionics costs. That's where you're most likely to blow your budget. Get a quote on what you think is a panel that fits you, and add $10,000 to it just in case...it goes fast. One word of warning....not everyone is comfortable with the idea of adding up their total kit costs, so think about it before you do it.....and then decide if you do, can you tell your wife. ;) -- Tim Olson -- RV-10 #40170 igator?RV10-List> ________________________________________________________________________________
Date: Oct 26, 2005
Subject: Re: Observations
Hi John, Great observations! Suggest 7a.) When you can't see the bucked side of the rivet, press on it with your finger tip, and then look at your finger tip to see what the bucked side of the rivet looks like. Your finger tip makes a good transfer tool. Regards, Jim Ayers PS Watch for sharp edges, where the bucking bar wasn't fully on the rivet. In a message dated 10/26/2005 1:17:59 AM Pacific Daylight Time, jjessen(at)rcn.com writes: Some general observations. (Stuff Cut) 7. Go buy the auto mechanic's version of a dental mirror with a long handle. Makes a great tool to see how those rivets that were out of sight and being set by feel actually turned out. (Stuff Cut) Just some observations. John Jessen 40328 HS do not archive ________________________________________________________________________________
Date: Oct 26, 2005
We put two extra screws on the inboard edge of the lenses, one on the top and one on the bottom. We felt the same way you did. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: RV10-List: Wingtip lens While were on the subject of the wingtip lens, does it look to you all the two screws are enough? Every store bought plane with these types of lenses use multiple flush screws to hold the lens in place. If a stress crack developes at one of the screw holes, ( easy to do if you overtighten the screw) it wouldn't take long for the lens to depart the wingtip maybe taking some of the wingtip with it. Maybe I'm being paranoid, I have no experience with other Van's wingtips, but it looks like a weak point to me. John Hasbrouck #40264 ________________________________________________________________________________
Date: Oct 26, 2005
I think I might be one of the first people that informed Vans of this as they appeared surprised when I mentioned it. Kit number 40188. I had cracks in the lower portion of the forward tailcone bulkhead only. I sent pictures to Vans so they could figure out what was causing it. They sent me a new part which did not have any cracks in it. Niko "John W. Cox" wrote: Tom, post to this list the individual at VAN's telling you that stop-drilling corrects for using worn dies during the CNC manufacture. Your kidding yourself if you buy off that the problem ends with a stop drill. This exact problem began in the kit #350 range and I can now conclude it was not resolved by #475. Quality parts should be a reasonable expectation on the 10. It has been unfortunately too overlooked. Tom was the source of such direction back near #350. Even the replacement part was cracked. Go Figure. Builders in this series should know what to look for and request a correction. John - KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Gesele Subject: RV10-List: F-1010, F-1008R - Cracks in inner reinforce flange While cleaning up the tailcone bulkheads, noticed a couple of small cracks in the F-1010 & F-1008R bulkheads in the inner stiffener flange that appear to have been caused while the parts were being pressed. The cracks are very small, probably only a few 1000ths thick and < 1/4" long so you really need to look closely, and are located in the top radius of the bulkheads. I've kicked around replacing them, spoke to Vans who said not to worry but stop-drill the cracks if it gives me piece of mind. Probably will stop drill and put doubler on web (gross overkill but why not) but still undecided. My question is has anyone else noticed this? If this is a common occurrence, then replacing the bulkhead won't accomplish anything and my decision is easy. Thanks, Tom Gesele #40473 - Tailcone. ________________________________________________________________________________
Subject: door securtiy kit
Date: Oct 26, 2005
Mine arrived to day unsolicited; 40168 ________________________________________________________________________________
Subject: RV-10 24v Flap Positioning System
Date: Oct 27, 2005
FYI - If anyone is putting together a 24 volt ship, Show planes now makes a 24 volt flap position kit variant nearly identical to the one Van's sells for the RV-10. If you've already purchased a 12 volt FPS from Vans, contact Brian (541-773-3344). He can swap control boxes for a nominal fee. Jeremy Harris ________________________________________________________________________________
Subject: Door check system
Date: Oct 27, 2005
Rob do you know if the system that Van's came up with is the same one that is working with the AF2500 in 410RV? Randy ________________________________________________________________________________
Date: Oct 27, 2005
Subject: FAB box service letter
Just saw on the general RV-List that the service letter previously written about the FAB (filtered air box?) has been updated this October. Apparently it isn't working out as well as previously thought. Everyone should read the bulletin at: http://www.vansaircraft.com/pdf/Fab-sb_05.pdf For those like me who live in the frozen Tundra for the next few months, doing this FAB Bypass is basically very good idea. Luckily I actually had just planned to start my FAB construction over the next week or two, so I quickly ordered my free kit today. They have a couple of different kits depending on if you already had the magnetic FAB bypass installed or not. More info is in the service bulletin. Tim -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Oct 27, 2005
Subject: Builder in OKC?
Any builders in the OKC area? I'm in town for an FAA class till 11/2. I'm willing to help or I would just like to stop by and meet another builder and see another project. Steve 40212 Wings __________________________________ ________________________________________________________________________________
Date: Oct 27, 2005
Steve, N256H #40241 will be in Tulsa on Sunday, Monday or Tuesday next week. I don't know what airport, but they are planning on going to Tulsa. I don't think they need any help, but you could check it out and may be able to talk Steve (Saint, that is) into giving you a ride if he is around and has time (or if you need a lift to Florida). Let me know and I can find out more details on where and when he will be there. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Darton Steve Subject: RV10-List: Builder in OKC? Any builders in the OKC area? I'm in town for an FAA class till 11/2. I'm willing to help or I would just like to stop by and meet another builder and see another project. Steve 40212 Wings ________________________________________________________________________________
Date: Oct 27, 2005
Subject: Plating steps question
I want to have the steps for the -10 chrome plated to prevent rusting and match the polished aluminum that they will be mounted on. The 4130 steel tubing comes with some sort of protective coating that gives it a dark gray appearance. Can anyone tell me what is the recommended method of removing that coating? Polishing, or some chemical to dissolve it? Phil #40220 in IL (fuse @ 60%, wings & emp done) ________________________________________________________________________________
Subject: Re: FAB box service letter
Date: Oct 27, 2005
I did wonder about that little magnet.... and what do you know, I had just finished installing the bypass door. Anh #141 ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Subject: RV10-List: FAB box service letter > > > Just saw on the general RV-List that the service letter previously > written about the FAB (filtered air box?) has been updated this > October. Apparently it isn't working out as well as previously > thought. Everyone should read the bulletin at: > > http://www.vansaircraft.com/pdf/Fab-sb_05.pdf > > For those like me who live in the frozen Tundra for the next few > months, doing this FAB Bypass is basically very good idea. Luckily > I actually had just planned to start my FAB construction over the > next week or two, so I quickly ordered my free kit today. > > They have a couple of different kits depending on if you already > had the magnetic FAB bypass installed or not. More info > is in the service bulletin. > > Tim > > -- > Tim Olson -- RV-10 #40170 > > ________________________________________________________________________________
Subject: FW: draw bead
Date: Oct 28, 2005
Here is the picture David sent to me that shows the baffle material used for his rivet technique. John Jessen 40328 HS _____ From: David McNeill [mailto:dlm46007(at)cox.net] Subject: draw bead baffling material is a silicone rubber material commonly used for directing airflow firewall forward. attached is a picture. I would send it to matronics but I don't know how well it handles pictures. Note that one handles only 40 rivets and the other was drilled for both 30 and 40 rivets. place the bead on the rear of the rivet and then hold the bucking bar against it. lightly set the rivet, remove the bead and set the rivet properly. Note the size of the bead by the size of the hole in it. ________________________________________________________________________________
Date: Oct 28, 2005
Any Pictures of the offending sites? Rob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Subject: RE: RV10-List: F-1010, F-1008R - Cracks in inner reinforce flange Tom, post to this list the individual at VAN's telling you that stop-drilling corrects for using worn dies during the CNC manufacture. Your kidding yourself if you buy off that the problem ends with a stop drill. This exact problem began in the kit #350 range and I can now conclude it was not resolved by #475. Quality parts should be a reasonable expectation on the 10. It has been unfortunately too overlooked. Tom was the source of such direction back near #350. Even the replacement part was cracked. Go Figure. Builders in this series should know what to look for and request a correction. John - KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Gesele Subject: RV10-List: F-1010, F-1008R - Cracks in inner reinforce flange While cleaning up the tailcone bulkheads, noticed a couple of small cracks in the F-1010 & F-1008R bulkheads in the inner stiffener flange that appear to have been caused while the parts were being pressed. The cracks are very small, probably only a few 1000ths thick and < 1/4" long so you really need to look closely, and are located in the top radius of the bulkheads. I've kicked around replacing them, spoke to Vans who said not to worry but stop-drill the cracks if it gives me piece of mind. Probably will stop drill and put doubler on web (gross overkill but why not) but still undecided. My question is has anyone else noticed this? If this is a common occurrence, then replacing the bulkhead won't accomplish anything and my decision is easy. Thanks, Tom Gesele #40473 - Tailcone. ________________________________________________________________________________
Subject: Coax
Date: Oct 28, 2005
What is the advantage of RG400 over RG58 coax? Quite a cost difference. Is there a enough difference in quality that would justify the cost of RG400/U? Thanks John Hasbrouck #40264 Wings ________________________________________________________________________________
Subject: Re: Coax
Date: Oct 28, 2005
short answer .... the RG58 is the cheapest and least conductive of available Coax (that's why RG-6 is recommended for long runs of cable or sattelite TV cable instead of RG-58). The higher quality cable will resist interference and have less signal degredation than the RG58. ----- Original Message ----- From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com> Subject: RV10-List: Coax > > What is the advantage of RG400 over RG58 coax? Quite a cost difference. > Is there a enough difference in quality that would justify the cost of > RG400/U? Thanks > > John Hasbrouck > #40264 > Wings > > > ________________________________________________________________________________
Subject: Oregon Aero Seats
Date: Oct 29, 2005
I received my seats the other day from Oregon Aero and I am very pleased with the quality. Perhaps I could have saved a little by shopping around but they saved me time and headaches. By sending Van's rear seat cushions to Oregon Aero, I saved a little. My total cost including shipping was about $3250. Rob ________________________________________________________________________________
Subject: Coax
Date: Oct 29, 2005
RG-58 has slightly better RF characteristics as compared to RG-400 (less attenuation per unit length), but RG-400 is far more mechanically durable and in 1950-1960 vintage panels with a lot of stuff going on, the shielding of RG-400 provided some interference avoidance benefits. Bottom line - you would not be able to tell a practical difference in application between the two - other than use where there the increase durability of RG-400 has an advantage. A good example of this is in the engine compartment. Klaus at LightSpeed changed to RG-400 coax awhile back for the run from his electronic Ignition module to the engine mounted coils. The advantage here is the better heat tolerance of RG-400 over RG-58 (RG-400 has a Teflon dielectric). For the little bit needed for an RV-10, just get the RG-400 and not worry about it. Carl Froehlich RV-8A (210 hrs), RV-10 on the wish list Dogwood Airpark (VA42) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Jeff Dalton Subject: Re: RV10-List: Coax short answer .... the RG58 is the cheapest and least conductive of available Coax (that's why RG-6 is recommended for long runs of cable or sattelite TV cable instead of RG-58). The higher quality cable will resist interference and have less signal degredation than the RG58. ----- Original Message ----- From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com> Subject: RV10-List: Coax > > What is the advantage of RG400 over RG58 coax? Quite a cost difference. > Is there a enough difference in quality that would justify the cost of > RG400/U? Thanks > > John Hasbrouck > #40264 > Wings > > ________________________________________________________________________________
Date: Oct 29, 2005
Was that $3,250 all for seats? Are they lined with gold? Actually, all kidding aside, I would love to see some pictures. Are they leather? How much was Van's foam for the rear seats? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rob kermanj Subject: RV10-List: Oregon Aero Seats I received my seats the other day from Oregon Aero and I am very pleased with the quality. Perhaps I could have saved a little by shopping around but they saved me time and headaches. By sending Van's rear seat cushions to Oregon Aero, I saved a little. My total cost including shipping was about $3250. Rob ________________________________________________________________________________
Subject: Coax
Date: Oct 29, 2005
We had an avionics expert put together our radio stack and he also made up our antenna cables. He is used to wiring up 206's, Caravans and King Airs for IFR flight. He made everything with RG-58 except the Transponder cable, which he made with RG-400. The main thing he said was that we should keep the transponder cable away from the other cables as much and as far as possible, which is why we put our transponder antenna on the bottom of the tunnel near the fuel pump and the other antennas are on the bottom aft of the luggage compartment, so the wires run down the right side of the plane or out into the wings for our wingtip antennas. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Subject: RE: RV10-List: Coax RG-58 has slightly better RF characteristics as compared to RG-400 (less attenuation per unit length), but RG-400 is far more mechanically durable and in 1950-1960 vintage panels with a lot of stuff going on, the shielding of RG-400 provided some interference avoidance benefits. Bottom line - you would not be able to tell a practical difference in application between the two - other than use where there the increase durability of RG-400 has an advantage. A good example of this is in the engine compartment. Klaus at LightSpeed changed to RG-400 coax awhile back for the run from his electronic Ignition module to the engine mounted coils. The advantage here is the better heat tolerance of RG-400 over RG-58 (RG-400 has a Teflon dielectric). For the little bit needed for an RV-10, just get the RG-400 and not worry about it. Carl Froehlich RV-8A (210 hrs), RV-10 on the wish list Dogwood Airpark (VA42) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Jeff Dalton Subject: Re: RV10-List: Coax short answer .... the RG58 is the cheapest and least conductive of available Coax (that's why RG-6 is recommended for long runs of cable or sattelite TV cable instead of RG-58). The higher quality cable will resist interference and have less signal degredation than the RG58. ----- Original Message ----- From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com> Subject: RV10-List: Coax > > What is the advantage of RG400 over RG58 coax? Quite a cost difference. > Is there a enough difference in quality that would justify the cost of > RG400/U? Thanks > > John Hasbrouck > #40264 > Wings > > ________________________________________________________________________________
Date: Oct 29, 2005
Subject: Re: Coax
Conductivity has nothing to do with it, they both have the same copper center conductor. What you are paying for in the RG-400 is slightly better shielding and much better environmental characteristics. It's kind of like plenum rated cable in the Ethernet world, electrically they are the same, but the plenum cable is 3 times as expensive due to different materials required so that when it burns, it does not release any toxic vapors. For this reason I plan to use RG-400 anywhere in the cabin and RG-58 in the wings and elswhere. > >short answer .... the RG58 is the cheapest and least conductive >of available Coax (that's why RG-6 is recommended for long runs >of cable or sattelite TV cable instead of RG-58). > >The higher quality cable will resist interference and have less >signal degredation than the RG58. William Curtis 40237 - wings http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Oct 29, 2005
> > http://www.vansaircraft.com/pdf/Fab-sb_05.pdf Every time I read this document (or the predecessor) I am struck by the following paragraph: (a) It is imperative to remember that, unless the individual aircraft operating limitations permit, experimental aircraft are not permitted to fly into known icing conditions. (b) Flight into forecast icing conditions is limited by the provisions of FAR 91.527. (c) Flight into icing conditions can be extremely dangerous since the rate of ice accumulation in the induction system and on the airframe are unpredictable and may change in seconds. Sentence (c) is true, and very much worth noting and heeding. So far as I know, sentence (a) is false. No such FAR applicable to our aircraft exists, and the normal operating limitations issued to RV's include no such prohibition. Sentence (b), with regard to RVs, is false. FAR 91.527 is part of FAR 91 Subpart F, which is applicable only to "Large and Turbine-Powered Multiengine Airplanes and Fractional Ownership Program Aircraft." The RV series of aircraft are not subject to FAR 91.527, or anything else under FAR 91.5xx. The intent of the paragraph in Van's service letter is good. The use of two sentences that are false detracts, IMO, from the credibility and impact of the letter. (Yes, I brought this to Van's attention two years ago). Tim ________________________________________________________________________________
Subject: Re: Oregon Aero Seats
Date: Oct 29, 2005
The amount was for the leather upholstery of all seats. It included around $175-185 for Van's rear seat foams. The leather is dyed through so that it will not show a different color once it is worn through the skin. The seats are still in plastic cover and not good for photograph. I am won't be removing the plastic for a while. Will post photos as soon as I do. Rob. Organ Aero charged $3120 for their work including shipping On Oct 29, 2005, at 9:00 AM, Jesse Saint wrote: > > Was that $3,250 all for seats? Are they lined with gold? > Actually, all > kidding aside, I would love to see some pictures. Are they > leather? How > much was Van's foam for the rear seats? > > Thanks. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > W: 352-465-4545 > C: 352-427-0285 > F: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rob kermanj > Sent: Saturday, October 29, 2005 6:08 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oregon Aero Seats > > > I received my seats the other day from Oregon Aero and I am very > pleased with the quality. Perhaps I could have saved a little by > shopping around but they saved me time and headaches. > > By sending Van's rear seat cushions to Oregon Aero, I saved a > little. My total cost including shipping was about $3250. > > Rob > > ________________________________________________________________________________
Subject: Cracks in flange
Date: Oct 29, 2005
I found the same cracks in two lightening hole flanges. They suggested that I stop drill but my experience has been that a stop drilled flange might continue to crack past the stop drill. A drill bit of 1/8 at least is required but even this is no guarentee. I had them send me a new one and it was fine. ________________________________________________________________________________
Subject: Vapor return for mechanical fuel injection
Date: Oct 30, 2005
I don't know much about this subject so my questions might even be off base. How does a vapor return line need to be sized for a 540 with a carb or mechanical fuel injection and where does the line enter into the tank. Is it just via a bulkhead fitting like the vent bulkhead fitting? Does it enter on the bottom or the top of the tank? I emailed ECI about their 540 system but it is not that far along enought for them to comment on. Their 360 experimental engine will/does have the option but I couldn't find practical details on the fuel system just schematics. TIA Chris Lucas #40072 fuel tanks ( I want to add a fitting now before I seal the tanks if I end up needing it down the road) ________________________________________________________________________________
Date: Oct 29, 2005
Subject: Re: Vapor return for mechanical fuel injection
Depends what fuel injection system you go with. Carbs don't need return line. Neither does the certified Bendix RSA system that Lycoming puts on their injected engines. Only Continental and some of the aftermarket/experimental fuel injection systems need a return line. There are exceptions, like some of the bigger Cessna singles had return line perhaps to deal with vapor lock issues. Chris said: > I don't know much about this subject so my questions might even be off > base. > How does a vapor return line need to be sized for a 540 with a carb or > mechanical fuel injection and where does the line enter into the tank. Is > it just via a bulkhead fitting like the vent bulkhead fitting? Does it > enter on the bottom or the top of the tank? I emailed ECI about their 540 > system but it is not that far along enought for them to comment on. Their > 360 experimental engine will/does have the option but I couldn't find > practical details on the fuel system just schematics. > TIA > Chris Lucas > #40072 > fuel tanks ( I want to add a fitting now before I seal the tanks if I end > up needing it down the road) ________________________________________________________________________________
Subject: cracks
Date: Oct 30, 2005
Hugo #40456,mine flanges have cracks too,allready send a email to Vans for replacments,thanks to the group I was able to found before going to the specific task,I guess save a couple of weeks in delay time. Thanks ,Hugo any news from bad rivets in the spars from Canada? ________________________________________________________________________________
Subject: need info
Date: Oct 30, 2005
By chance any body now the e mail or phone number of CHARLES BENNETT of Jupiter FL RV10 N410PB,he is only 30 minutes from me. Hugo do nort archive ________________________________________________________________________________
Date: Oct 30, 2005
Subject: Re: need info
Hugo, Did you try the phone book? :) He's listed: Bennett, Charles P III <http://www.whitepages.com/10001/search/Alpha_Limit?search_id=10300202835945905746&sort=&alpha_limit=&lower=3&more_info=1&old_search_type=Find_Person> 19001 SE Mack Dairy Rd Jupiter, FL 33478-2119 (561) 748-2963 I looked up the N number in the FAA database and matched the addresses. -Jim 40384, skinning the top wings today! gommone7(at)bellsouth.net wrote: > >By chance any body now the e mail or phone number of CHARLES BENNETT of Jupiter FL >RV10 N410PB,he is only 30 minutes from me. >Hugo >do nort archive > > > > > > > > > ________________________________________________________________________________
Date: Oct 30, 2005
Only needed for fuel injected engines, and then some of them you can skip adding the feature. Run a flex hose from the engine purge valve (same type of hose used for fuel) to a steel firewall bulkhead fitting. For Bendix installs where you are adding the purge valve, you may decide to mount the purge valve on the firewall. If so, then you just run a flex hose from the spider to the purge valve. As with all engine flex hoses, it is a good idea to have them in fire sleeve. From the aft side of the bulk head fitting, run 1/4" aluminum tubing to whichever fuel tank that is easiest. Mount a standard AN aluminum bulkhead fitting on the inboard end of the fuel tank, preferably high on the tank. No need to run another tube inside the tank like you do with the vent line as when the purge valve is open the pressure in the purge line is higher than that in the tank. I have the Airflow Performance fuel injection system on my RV-8A. It comes with a purge valve mounted on the spider. I use the purge line to shut down the engine, but I have never needed to use the purge system to vent the spider (i.e. vapor locked startup). Carl Froehlich RV-8A (200 hrs) Dogwood Airpark (VA-42) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Chris Sent: Sunday, October 30, 2005 12:02 AM To: rv10-list(at)matronics.com Subject: RV10-List: Vapor return for mechanical fuel injection I don't know much about this subject so my questions might even be off base. How does a vapor return line need to be sized for a 540 with a carb or mechanical fuel injection and where does the line enter into the tank. Is it just via a bulkhead fitting like the vent bulkhead fitting? Does it enter on the bottom or the top of the tank? I emailed ECI about their 540 system but it is not that far along enought for them to comment on. Their 360 experimental engine will/does have the option but I couldn't find practical details on the fuel system just schematics. TIA Chris Lucas #40072 fuel tanks ( I want to add a fitting now before I seal the tanks if I end up needing it down the road) ________________________________________________________________________________
Date: Oct 30, 2005
Subject: Handgrip to Instrument Panel Fit
I have fitted the instrument panel to the fuselage skin and the handgrip is slightly behind (forward) of the instrument panel at the forward portion of the grip. I have a visible gap of about .063 behind the panel at the rear of the hand grip. With the 0.63 thickness of the instrument panel, I end up with about 1/8" of hangover. I have checked behind the panel and the fit is tight. Both sides are like this. Does anyone else have a fit like this? It's purely cosmetic, but would like to know if this is "normal". Placing the handgrip about 1/4" more aft in the skin would fix the problem. But it attached to the supports behind the instrument panel. I don't think there is anything I can do to remidy this. (Fill the gap with some JB weld or proseal and smooth it out is the current plan.) Picture is attached. Thanks, Jim Combs #40192 - N312F ________________________________________________________________________________
Date: Oct 30, 2005
Rob, just got mine too! They did an excellent job. I have had 2 interiors done in leather in the last 2 years, and they were not anywhere near as well done as Oregon Aero. They offer many different options on color and seat stitch and panel pattern. I did mine in light and dark grey. I too put mine up, but will try in a few days to take a pick and post it. Jim 383 -------Original Message------- From: rob kermanj Date: 10/29/05 11:27:03 Subject: Re: RV10-List: Oregon Aero Seats The amount was for the leather upholstery of all seats. It included around $175-185 for Van's rear seat foams. The leather is dyed through so that it will not show a different color once it is worn through the skin. The seats are still in plastic cover and not good for photograph. I am won't be removing the plastic for a while. Will post photos as soon as I do. Rob. Organ Aero charged $3120 for their work including shipping On Oct 29, 2005, at 9:00 AM, Jesse Saint wrote: > > Was that $3,250 all for seats? Are they lined with gold? > Actually, all > kidding aside, I would love to see some pictures. Are they > leather? How > much was Van's foam for the rear seats? > > Thanks. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > W: 352-465-4545 > C: 352-427-0285 > F: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rob kermanj > Sent: Saturday, October 29, 2005 6:08 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oregon Aero Seats > > > I received my seats the other day from Oregon Aero and I am very > pleased with the quality. Perhaps I could have saved a little by > shopping around but they saved me time and headaches. > > By sending Van's rear seat cushions to Oregon Aero, I saved a > little. My total cost including shipping was about $3250. > > Rob > > ________________________________________________________________________________
Date: Oct 30, 2005
Michael ... Another option, an easier one, tie the purge line into the left or right tank feeder line. Jerry Grimmonpre' RV8A Sent: Sunday, October 30, 2005 3:34 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection Environmental concerns aside, it seem a lot easier than trying to get another bulkhead into a finished tank. Michael Sausen ________________________________________________________________________________
Subject: Final Drill before assembly
Date: Oct 30, 2005
A while ago a couple of you mentioned that you were final drilling, deburing, dimpling and painting before assembling first, so the first time of assembly you were riveting. How is this going? Any updates on potential problems? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Subject: static ports
Date: Oct 30, 2005
I'm coming to the point where I need to provision for static ports in the tailcone, and I am wondering if anyone whom is flying a 10 has SafeAir or Cleveland flush static ports installed, and has determined the accuracy of them, as compared to the pop-rivet? Or is there another after market port that allows for the bulge past the skin, as in a pop-rivet, that I'm unaware of? Thanks Chris Hukill ________________________________________________________________________________
Subject: RV Tool Kit
Date: Oct 30, 2005
For those who may have missed the September special, PlaneTools.com now has the DRDT-2 Dimpler as a FREE upgrade on the RV tool kit. This is a great tool that reflects the quality of the RV tool kit. In addition to the sheet metal tool kit, mechanic tools are being added. The website address is HYPERLINK "http://www.planetools.com"http://www.planetools.com <http://www.planetools.com> Shane Isham ________________________________________________________________________________
Date: Oct 30, 2005
if you do this then you do not have a purge line rather a parallel feed line, both lines will carry pressure, as the return line will have less pressure in it, so it will be overcome by the feed _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jerry Grimmonpre Subject: Re: RV10-List: Vapor return for mechanical fuel injection Michael ... Another option, an easier one, tie the purge line into the left or right tank feeder line. Jerry Grimmonpre' RV8A Sent: Sunday, October 30, 2005 3:34 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection Environmental concerns aside, it seem a lot easier than trying to get another bulkhead into a finished tank. Michael Sausen ________________________________________________________________________________
Date: Oct 30, 2005
When the engine is shutting down or purged, it has to be fed from the tank opposite the one the purge line is connected to. The purge fuel, on shut down, will go into the tank but opposite the normal flow direction. The flow,in the purge line, would be whatever is being put out by the engine driven pump, with engine running, or whatever the boost pump is putting out for purging, when the engine is not running. Since the purge fuel is going into the unused tank there is really no pressure ... just flow. Hope this helps. Jerry Grimmonpre' RV8A Sent: Sunday, October 30, 2005 9:21 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection if you do this then you do not have a purge line rather a parallel feed line, both lines will carry pressure, as the return line will have less pressure in it, so it will be overcome by the feed ________________________________________________________________________________
Date: Oct 31, 2005
Subject: Re: static ports
Putting the ptiot-static system from Safeair1 in this week. Tony was great to work with and knows what a RV10 needs. Safeair static port require a smaller hole cut in the skin versus the one Cleavland sells. Safeair uses a different tubing than normal...something to consider. Putting the ptiot-static system from Safeair1 in this week. Tony was great to work with and knows what a RV10 needs. Safeair static port require a smaller hole cut in the skin versus the one Cleavland sells. Safeair uses a different tubing than normal...something to consider. ________________________________________________________________________________
Date: Oct 30, 2005
Subject: Engine Mount Clearance Update
I got my engine mount back later last week and installed it. Van's did pretty good job of fixing it up. The service on this repair/mod. was fantastic, thanks to Bruce and Scott at Van's. The mount now has better clearance, although I think if they made the new curved section about 1 to 1.5" wider, it would be even better to clear the corners of the sump. It will absolutely be better than before though, as now there is 1/4" to 3/8" clearance, which is over double what I had before. I have some photos at: http://www.myrv10.com/N104CD/engine/20051022/index.html -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Oct 31, 2005
Subject: Re: Engine Mount Clearance Update
One thing after a few years the engine mounts, rubber isolators, will start to sag, and so you will need to watch this for vibration rub on the mount. We see this on all types of AC esp on C-182 with the front cowling and c-206's left front. Pat #257 Tim Olson wrote: I got my engine mount back later last week and installed it. Van's did pretty good job of fixing it up. The service on this repair/mod. was fantastic, thanks to Bruce and Scott at Van's. The mount now has better clearance, although I think if they made the new curved section about 1 to 1.5" wider, it would be even better to clear the corners of the sump. It will absolutely be better than before though, as now there is 1/4" to 3/8" clearance, which is over double what I had before. I have some photos at: http://www.myrv10.com/N104CD/engine/20051022/index.html -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Date: Oct 31, 2005
Subject: Re: Final Drill before assembly
On some jobs it works great. Sometimes you have to mostly assemble to get a feel for fit and such. I find the fit is ultimately better drilled first and put together, no hole slightly out of round. Predrilled and dimpled the fuselage halfs and the tail cone. All went together perfectly. Also have done the top wing skins that way. Jim Wade -------Original Message------- From: Jesse Saint Date: 10/30/05 18:56:26 Subject: RV10-List: Final Drill before assembly A while ago a couple of you mentioned that you were final drilling, deburing dimpling and painting before assembling first, so the first time of assembly you were riveting. How is this going? Any updates on potential problems? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Subject: Finished Painting
Date: Oct 31, 2005
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Beautiful job, Tim. As for registering your homebuilt, I followed the recommendations from the EAA's Homebuilders Headquarters when I finished my Pietenpol Air Camper last year. Registration and inspection went off without a hitch. You can find all the information you need on the EAA website, under "Members Only", then select Homebuilders Headquarters, then select "Registering" and "Articles". I had an inspector from the local FSDO come out and inspect mine. He spent several hours poking and prodding the airplane, before signing it off. The only paperwork he was interested in looking at was the registration (which you obviously already have since you've got your numbers painted on), and the weight and balance calculations. The inspection was free. It required about a 3 weeks notice to get the inspection lined up, where a DAR could have done it on a couple of days notice, but the DAR in our area wanted $500 to perform the inspection. Jack Phillips, Raleigh, NC Pietenpol Air Camper NX899JP RV-4 N18LR RV-10 on the wish list (hope to start building next winter) -----Original Message----- ...If anyone has a link to a good guide to getting your airworthiness certificate, I'd love to start reading. I don't think I'm all that far from needing to start getting paperwork together. I don't know how early I can start the registration process, but now that my N-Number is painted on, I feel much closer. ;) Tim -- Tim Olson -- RV-10 #40170 ________________________________________________________________________________
From: "Robert E. Lynch" <rv6lynch(at)earthlink.net>
Date: Oct 31, 2005
Jerry, if you still want the exhaust I have , get in touch. Bob ________________________________________________________________________________
Date: Oct 31, 2005
I thought the original post was also concerning a return line for fuel injection? and in this case it would not work, because if you fed back to the opposite tank, you could overfill and send fuel out the vent. The way to plumb for a return line is to the same tank you are feeding from, to prevent overfilling, and in this situation you can not just plumb it back into the feed line because of parallel paths for the fuel pump. another question, in your scenario what keeps fuel from flowing into the purge line during normal ops? if nothing, what keeps it from overfilling the tank? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jerry Grimmonpre Subject: Re: RV10-List: Vapor return for mechanical fuel injection When the engine is shutting down or purged, it has to be fed from the tank opposite the one the purge line is connected to. The purge fuel, on shut down, will go into the tank but opposite the normal flow direction. The flow,in the purge line, would be whatever is being put out by the engine driven pump, with engine running, or whatever the boost pump is putting out for purging, when the engine is not running. Since the purge fuel is going into the unused tank there is really no pressure ... just flow. Hope this helps. Jerry Grimmonpre' RV8A Sent: Sunday, October 30, 2005 9:21 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection if you do this then you do not have a purge line rather a parallel feed line, both lines will carry pressure, as the return line will have less pressure in it, so it will be overcome by the feed ________________________________________________________________________________
Subject: Canopy Dorr Trimming
Date: Oct 31, 2005
I'm currently at the stage of trimming the lip on the canopy for the door opening. The plans don't state which direct the cut is suppose to be. Along the bottom of the door lip, I trimmed it with the cut edge facing the opposite door, but on the vertical lip of the door, you could cut it facing the other door or you could cut it where the cur edge faces the front of the plane. Can someone please explain which way this is supposed to be cut? I can see the lines just fine, just need to know which way the cut surface is suppose to be. Thank You Ray Doerr 40250 ________________________________________________________________________________
Date: Oct 31, 2005
When the purge valve is opened to cool the injection plumbing or to purge cavitating bubbles, it requires very little fuel to accomplish the cooling. If the purging time is extended it is possible to over fill the receiving tank and experience a fuel loss out the venting system of the receiving tank. When the purging is completed by closing the purge valve, the purge plumbing path to the receiving tank is closed at the purge valve as well. Hope this helps. Jerry Grimmonpre' From: Lloyd, Daniel R. To: rv10-list(at)matronics.com Sent: Monday, October 31, 2005 8:01 AM Subject: RE: RV10-List: Vapor return for mechanical fuel injection I thought the original post was also concerning a return line for fuel injection? and in this case it would not work, because if you fed back to the opposite tank, you could overfill and send fuel out the vent. The way to plumb for a return line is to the same tank you are feeding from, to prevent overfilling, and in this situation you can not just plumb it back into the feed line because of parallel paths for the fuel pump. another question, in your scenario what keeps fuel from flowing into the purge line during normal ops? if nothing, what keeps it from overfilling the tank? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jerry Grimmonpre Sent: Sunday, October 30, 2005 11:17 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Vapor return for mechanical fuel injection When the engine is shutting down or purged, it has to be fed from the tank opposite the one the purge line is connected to. The purge fuel, on shut down, will go into the tank but opposite the normal flow direction. The flow,in the purge line, would be whatever is being put out by the engine driven pump, with engine running, or whatever the boost pump is putting out for purging, when the engine is not running. Since the purge fuel is going into the unused tank there is really no pressure ... just flow. Hope this helps. Jerry Grimmonpre' RV8A Sent: Sunday, October 30, 2005 9:21 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection if you do this then you do not have a purge line rather a parallel feed line, both lines will carry pressure, as the return line will have less pressure in it, so it will be overcome by the feed ________________________________________________________________________________
Date: Oct 31, 2005
It does, I did not realize there is a valve that is opened and closed. That makes more sense. I have not flown behind an IO engine, just standard. Now maybe you can explain to me, is it like in an auto, where there is allot more fuel going to the rail then is used, causing a return line to be necessary? or does it only pump what is required/ used? I thought fuel injection meant a looped system, where only the portion of fuel that went to the injectors was used and the rest sent back to the tank? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jerry Grimmonpre Subject: Re: RV10-List: Vapor return for mechanical fuel injection When the purge valve is opened to cool the injection plumbing or to purge cavitating bubbles, it requires very little fuel to accomplish the cooling. If the purging time is extended it is possible to over fill the receiving tank and experience a fuel loss out the venting system of the receiving tank. When the purging is completed by closing the purge valve, the purge plumbing path to the receiving tank is closed at the purge valve as well. Hope this helps. Jerry Grimmonpre' From: Lloyd, Daniel R. <mailto:LloydDR(at)wernerco.com> To: rv10-list(at)matronics.com Sent: Monday, October 31, 2005 8:01 AM Subject: RE: RV10-List: Vapor return for mechanical fuel injection I thought the original post was also concerning a return line for fuel injection? and in this case it would not work, because if you fed back to the opposite tank, you could overfill and send fuel out the vent. The way to plumb for a return line is to the same tank you are feeding from, to prevent overfilling, and in this situation you can not just plumb it back into the feed line because of parallel paths for the fuel pump. another question, in your scenario what keeps fuel from flowing into the purge line during normal ops? if nothing, what keeps it from overfilling the tank? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jerry Grimmonpre Sent: Sunday, October 30, 2005 11:17 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Vapor return for mechanical fuel injection =09 =09 When the engine is shutting down or purged, it has to be fed from the tank opposite the one the purge line is connected to. The purge fuel, on shut down, will go into the tank but opposite the normal flow direction. The flow,in the purge line, would be whatever is being put out by the engine driven pump, with engine running, or whatever the boost pump is putting out for purging, when the engine is not running. Since the purge fuel is going into the unused tank there is really no pressure ... just flow. Hope this helps. Jerry Grimmonpre' RV8A Sent: Sunday, October 30, 2005 9:21 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection if you do this then you do not have a purge line rather a parallel feed line, both lines will carry pressure, as the return line will have less pressure in it, so it will be overcome by the feed ________________________________________________________________________________
Date: Oct 31, 2005
It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: > It does, I did not realize there is a valve that is opened and closed. > That makes more sense. I have not flown behind an IO engine, just > standard. Now maybe you can explain to me, is it like in an auto, where > there is allot more fuel going to the rail then is used, causing a > return line to be necessary? or does it only pump what is required/ > used? I thought fuel injection meant a looped system, where only the > portion of fuel that went to the injectors was used and the rest sent > back to the tank? > > _____ > ________________________________________________________________________________
Date: Oct 31, 2005
I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: > It does, I did not realize there is a valve that is opened and closed. > That makes more sense. I have not flown behind an IO engine, just > standard. Now maybe you can explain to me, is it like in an auto, where > there is allot more fuel going to the rail then is used, causing a > return line to be necessary? or does it only pump what is required/ > used? I thought fuel injection meant a looped system, where only the > portion of fuel that went to the injectors was used and the rest sent > back to the tank? > > _____ > ________________________________________________________________________________
Date: Oct 31, 2005
Date: Oct 31, 2005
Subject: Re: Canopy Dorr Trimming
This is very hard to explain....and I can tell from your description that it's hard to interpret too. You're right, there isn't much guidance on that cut. What you kind of want is this: When you close the door, picture the cut face laying against the door itself. So in all cases almost, the angle of the plane you cut in, will match the angle of the inner surface of the door. On the bottom, I found myself cutting more than that, which was unnecessary. Now, here's the kicker.... Be careful about painting your interior at this point, because you'll probably file and sand that edge later again. Once you get the doors all in place, opening and closing, you'll want them to close and come very close to those edges. In fact, mine fit pretty good all the way around...I used a piece of paper between the door and the frame to make sure I had enough gap to slide the paper or thin steel ruler. But, then I added the fabric covering to my doors, so I ended up filing and sanding even more of the edge away so that the door would shut. You probably won't hurt anything by overdoing it in the end, as the rubber seal would be the sealing surface anyway, but it would help keep your outer door surface flush (in addition to the beveled edge). These are some older pics, but I don't have any recent ones that I can find. http://www.myrv10.com/N104CD/fuselage/20050702/RV200506230001.html http://www.myrv10.com/N104CD/fuselage/20050702/RV200506240007.html http://www.myrv10.com/N104CD/finishing/20050827/RV200508270062.html Tim Olson -- RV-10 #40170 Doerr, Ray R [NTK] wrote: > > I'm currently at the stage of trimming the lip on the canopy for > the door opening. The plans don't state which direct the cut is suppose > to be. Along the bottom of the door lip, I trimmed it with the cut edge > facing the opposite door, but on the vertical lip of the door, you could > cut it facing the other door or you could cut it where the cur edge > faces the front of the plane. Can someone please explain which way this > is supposed to be cut? I can see the lines just fine, just need to know > which way the cut surface is suppose to be. > > Thank You > Ray Doerr > 40250 > ________________________________________________________________________________ SPAM: If the email is for spam, please report to abuse(at)dnsExit.com -By mail relay service at: http://www.dnsExit.com/Direct.sv?cmd=mailRelay Accounts will be suspended immediately if found spamming.
Date: Oct 31, 2005
Jesse, The main issue here is for vapor lock instances during a start from a heat soaked engine where the injector lines run on top of the engine and fuel is supplied by a engine driven pump or the pump being in the cowl. This is a common problem for that type of setup in warm or hot climates and is usually caused by fuel pump cavitation due to the fuel temperature being raised above it's vapor pressure threshold. It's most commonly seen when you fly somewhere hot, get fuel, and then try a restart shortly after. Usually requires a 30 minutes sit with the oil door open to allow the fuel to condense again. Shouldn't be as much of a problem with our fuel pumps being back in the fuselage but it could still happen. In our case it would allow fuel to be circulated, cooling the lines back down and purging the fuel vapor out for easier start in this condition. If you aren't seeing a problem, no reason to worry about it, this is strictly an engine start event. There is a good chance none of us would really see this problem with the design of our fuel system having the fuel pump in the fuselage. The most that would probably happen is a rough start until the lines clear. Michael Sausen -10 #352 Waiting on fuselage -----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Subject: RE: RV10-List: Vapor return for mechanical fuel injection I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: > It does, I did not realize there is a valve that is opened and closed. > That makes more sense. I have not flown behind an IO engine, just > standard. Now maybe you can explain to me, is it like in an auto, > where there is allot more fuel going to the rail then is used, causing > a return line to be necessary? or does it only pump what is required/ > used? I thought fuel injection meant a looped system, where only the > portion of fuel that went to the injectors was used and the rest sent > back to the tank? > > _____ > ________________________________________________________________________________
From: "Mike Lauritsen - Work" <mike(at)cleavelandtool.com>
Subject: New RV-10 Seat Page
Date: Oct 31, 2005
Well we finally have an info page up for our RV-10 seats. Please spread it around to the other RV-10 related lists. Make sure to scroll down and see the installed interior. http://www.cleavelandtool.com/rvinteriors/2005/RV10.htm Thanks, Mike Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com ________________________________________________________________________________
Date: Oct 31, 2005
Mike, Looks great. Any idea when you will have more pictures and prices for the interior panels? Bobby Hughes 40116 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lauritsen - Work Subject: RV10-List: New RV-10 Seat Page Well we finally have an info page up for our RV-10 seats. Please spread it around to the other RV-10 related lists. Make sure to scroll down and see the installed interior. http://www.cleavelandtool.com/rvinteriors/2005/RV10.htm Thanks, Mike Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com ________________________________________________________________________________
Date: Oct 31, 2005
Subject: Re: Finished Painting
All "DNA's" removed .... going into the archives... > > Well, initially I drew it on the PC. It was pretty easy to make and > adjust the muliple section curves that way. So, I had all 4 views > (Top, Side, Front, Isometric) on a printout in front of me for masking > it off. Then, I ran the tape as smooth as possible by hand, trying > to estimate at which points on the airframe the lines crossed. It > was then just a matter of trial and error to get something that looked > real nice, since the original scheme wasn't really in 3D. After > we thought we had it, we tried to duplicate it on the other sides. > For the wing outer ends, I did actually tape one off and make a > paper template to transfer it to the bottom and other wing. > > Now, as for the durability, I think the basecoat/clearcoat will be > very durable. It's top quality auto paint. Even this a.m. after > spraying last night, it feels like it'll be nice and hard. I basically > used PPG because Randy had good luck with it, and it was available > at the most common local paint store. I think Imron would be a > fine choice too. The only negative I'd heard was that it doesn't/didn't > fill around the rivets as well. > > Through a chain of friends, a DuPont rep ended up looking at my website. > They have a newer aviation paint that they would have loved to have me > try...at a discount...and it supposedly fixes the rivet filling problem. > But, since I had sprayed the PPG already, I thought it best to color > coat it with something from the same paint line. > > I'll be helping another builder paint an RV-4 later this year and it > might be that we try the DuPont stuff on that project. As that > comes together, I'll make sure to let everyone know how that compares > if we spray it. I am very happy with the stuff that we sprayed though. > It seems to be very good paint. Hopefully though, the Concept will > be pretty chip resistant. I dinged a couple small nicks already, but > that was before it got a real good cure. The base/clear though seems > to be extremely tough for sure. > > > Tim Olson -- RV-10 #40170 > > > Jesse Saint wrote: > >> >>Tim, >> >>Did you just tape all of those lines by hand or did you have some sort of >>form? LOOKS AWESOME! What's the durability of the basecoat clearcoat PPG >>stuff compared to something like Imron, which doesn't seem to be a big >>choice in this group. PPG seems to be what everybody is using. >> >>Jesse Saint >>I-TEC, Inc. >>jesse(at)itecusa.org >>www.itecusa.org >>W: 352-465-4545 >>C: 352-427-0285 >>F: 815-377-3694 >> ________________________________________________________________________________
Subject: 540 fadec?
Date: Oct 31, 2005
Sort of on the topic - has anyone heard anything new about a fadec for the 540? Fadec.com hasn't changed in awhile, but I figured they'd want to tap the 540 market. ci #40410 wings ________________________________________________________________________________
Subject: Tim's comments about painting
Date: Oct 31, 2005
Jesse wanted this saved for the archives, and I agree. You words are now forever more, Tim. Tim wrote: Well, initially I drew it on the PC. It was pretty easy to make and adjust the muliple section curves that way. So, I had all 4 views (Top, Side, Front, Isometric) on a printout in front of me for masking it off. Then, I ran the tape as smooth as possible by hand, trying to estimate at which points on the airframe the lines crossed. It was then just a matter of trial and error to get something that looked real nice, since the original scheme wasn't really in 3D. After we thought we had it, we tried to duplicate it on the other sides. For the wing outer ends, I did actually tape one off and make a paper template to transfer it to the bottom and other wing. Now, as for the durability, I think the basecoat/clearcoat will be very durable. It's top quality auto paint. Even this a.m. after spraying last night, it feels like it'll be nice and hard. I basically used PPG because Randy had good luck with it, and it was available at the most common local paint store. I think Imron would be a fine choice too. The only negative I'd heard was that it doesn't/didn't fill around the rivets as well. Through a chain of friends, a DuPont rep ended up looking at my website. They have a newer aviation paint that they would have loved to have me try...at a discount...and it supposedly fixes the rivet filling problem. But, since I had sprayed the PPG already, I thought it best to color coat it with something from the same paint line. I'll be helping another builder paint an RV-4 later this year and it might be that we try the DuPont stuff on that project. As that comes together, I'll make sure to let everyone know how that compares if we spray it. I am very happy with the stuff that we sprayed though. It seems to be very good paint. Hopefully though, the Concept will be pretty chip resistant. I dinged a couple small nicks already, but that was before it got a real good cure. The base/clear though seems to be extremely tough for sure. Tim Olson -- RV-10 #40170 ________________________________________________________________________________
Subject: TruTrak AP
Date: Oct 31, 2005
Is it possible to purchase the mounting bracket for the roll servo seperate from the AP? I've asked TruTrak directly but thought I might get a faster response here. I'm undecided as to which of their two servo APs to use but as I understand it they all use the same bracket, depending on which side you place the servo of course. Would like to close the wings up and move on without committing to avionics just yet. John Hasbrouck #40264 ________________________________________________________________________________
Subject: Re: Tim's comments about painting
Date: Oct 31, 2005
----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Subject: Re: RV10-List: Tim's comments about painting > > Or, on the flip side of that question....I wonder how much longer it > would have taken to build the RV-10 if people didn't have the > information and tips available on the list.... ;) > > I for one, think I would have not nearly enjoyed this construction > as much if I had to suffer like the RV3,4,6 builders, with their plans, > and I can't imagine building one in a day and age where you had > to actually take Kodak photogaphs and mail the pictures to > someone if you had a question that needed visualization. Well said Tim. I built and have been enjoying an RV4 for almost 10 years now. I always tell people the best thing about the 10 is the plans and the fact that all the sequence questions have been answered. A close second is the precision of all the matched hole tooling. Doing a 10 "the old way" would be close to impossible. It would be extremely difficult to bend up parts that would then fit between other bent up parts. I am always amazed when these parts fit together so well. Your enthusiasm almost matches that of our departed Mr. McClow and I am sure is a great motivator to many on the list as is all of the helpful advice. Trust me, you will enjoy flying your airplane even more than building. Any RV always draws interested airport bums. For me, the only drawback will giving up aerobatics and the fun of flying the A4 of the RVs. In trade, we are looking forward to a capable WAAS equipped IFR traveler that will accommodate the family and dog. Dick Sipp RV4 N250DS RV10 40065 N110DV Do not archieve ________________________________________________________________________________
Subject: the 10 list
Date: Oct 31, 2005
Ditto on the last comments re: the -10 list : It is a university indeed , & the camaraderie that it entails is interesting also , Tim and all the others that have the web sites (thanks much) . i have contributed (a bit i think ) Brian Bollaert ________________________________________________________________________________
Date: Nov 01, 2005
The Ice water tubing I have seen will definitely get BRITTLE after 5 years and break under small vibration. Would hate to rerun pitot tubing every 3 years to keep it flexible. The Ice water tubing I have seen will definitely get BRITTLE after 5 years and break under small vibration. Would hate to rerun pitot tubing every 3 years to keep it flexible. ________________________________________________________________________________
Date: Oct 31, 2005
Subject: Re: TruTrak AP
> Is it possible to purchase the mounting bracket for the roll servo > seperate from the AP? Yes. That's what I did. $50 for the mount, as I recall. Includes connectors. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 790 hrs RV-10 #40059 under construction ________________________________________________________________________________
Date: Oct 31, 2005
Forget the connectors as supplied by TT. get the standard dsubs and barrel pins/sockets. soldering the cups is not the way to go especially if you have to switch pins due to servo rotation ----- Original Message ----- From: "Tim Lewis" <Tim_Lewis(at)msm.umr.edu> Subject: Re: RV10-List: TruTrak AP > > > Is it possible to purchase the mounting bracket for the roll servo > > seperate from the AP? > > Yes. That's what I did. $50 for the mount, as I recall. Includes > connectors. > > Tim > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 790 hrs > RV-10 #40059 under construction > > > ________________________________________________________________________________
Date: Oct 31, 2005
Subject: Placards/Nameplate
I was thinking that on my next order from ACS, I'd get whatever logbooks and placards I'll need. I see on this page of ACS's catalog they have a nameplate, and stainless steel ID tag on the top of the page. http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf I need both of these, right? I've seen the black on the side under the HS on -10's. Where would the nameplate go? Tim ________________________________________________________________________________
Date: Nov 01, 2005
Subject: Re: Placards/Nameplate
Per FAR 45.13 "Identification data" all that is required on the (fireproof) data plate is (1) Builder's name, (2) Model designation, and (3) Builder's serial number. For my RV-6A I got one of those stainless steel data plates from ACS, cut it down in size, and used the back side. Engravers charge by the letter, so I included only the information actually required by regulation. I didn't include the gross weight number (or other non-required numbers) because the FAA could conceivably use them against the operator in an enforcement matter. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 790 hrs RV-10 #40059 under construction Tim Olson wrote: > > I was thinking that on my next order from ACS, I'd get whatever logbooks > and placards I'll need. I see on this page of ACS's catalog they have a > nameplate, and stainless steel ID tag on the top of the page. > > http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf > > I need both of these, right? I've seen the black on the side under > the HS on -10's. Where would the nameplate go? > > Tim > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2005
Tim: A better option to the aircraft spruce data plate is: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1130844505-434-267&browse=personal&product=vaf Item number VAF EXPER DATA PLATE Why do with a generic data plate when you can go with a Vans Air Force Date Plate instead. Loved your painting pictures and can't wait to see both you and your 10 at OSK next year. Hopefully my 10 will be finished and present as well. Russ Daves ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Subject: RV10-List: Placards/Nameplate > > I was thinking that on my next order from ACS, I'd get whatever logbooks > and placards I'll need. I see on this page of ACS's catalog they have a > nameplate, and stainless steel ID tag on the top of the page. > > http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf > > I need both of these, right? I've seen the black on the side under > the HS on -10's. Where would the nameplate go? > > Tim > > > ________________________________________________________________________________
Subject: Frappr Map for the list
Date: Nov 01, 2005
Guys, Here is a Frappr map for north america. Add yourselves to it, both builders and finished ones. http://www.frappr.com/rv10snorthamerica Mani ________________________________________________________________________________
Date: Nov 01, 2005
Cool map, I like it. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mani Ravee Subject: RV10-List: Frappr Map for the list Guys, Here is a Frappr map for north america. Add yourselves to it, both builders and finished ones. http://www.frappr.com/rv10snorthamerica Mani ________________________________________________________________________________
Date: Nov 01, 2005
Did not know, but it could be from anywhere in the world. Google, you gotta love it. Mani Ravee -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mani Ravee Subject: RV10-List: Frappr Map for the list Guys, Here is a Frappr map for north america. Add yourselves to it, both builders and finished ones. http://www.frappr.com/rv10snorthamerica Mani ________________________________________________________________________________
Subject: TruTrak AP
Date: Nov 01, 2005
John, We put the bracket, servo and wiring in all after the wing was finished (we used the wiring harness that Stein makes for TruTrak). In fact, unless you are going to make a disconnect at the wing root, then you don't want the wiring in yet. I wouldn't hurt to put the bracket or even the servo in now, but if you still haven't made some decisions like what you are doing for aileron trim and what AP you are using, you might just want to wait until you are ordering the instruments and put the whole thing in then. It may be a little more work, but it won't be hard. It actually may end up being cheaper to buy the whole AP kit at once, and you never know what options may be on the market when you get to that point. As far as which AP to use, it is my understanding that the Digiflight II VSG is the most popular AP on the experimental market. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck Subject: RV10-List: TruTrak AP Is it possible to purchase the mounting bracket for the roll servo seperate from the AP? I've asked TruTrak directly but thought I might get a faster response here. I'm undecided as to which of their two servo APs to use but as I understand it they all use the same bracket, depending on which side you place the servo of course. Would like to close the wings up and move on without committing to avionics just yet. John Hasbrouck #40264 ________________________________________________________________________________
Date: Nov 01, 2005
Spruce has an anodized aluminum data plate for experimentals, but that doesn't seem to me to meet the fire-resistant need. When I called Spruce and ordered a stainless steel data plate with my information on it, they sent me the aluminum one. We put it on and when the inspector asked if it was steel, I just had to tell him that I ordered SS. He was happy with that, although I don't think is was SS. Why would Spruce sell one that is made of aluminum when you need steel? Anyway, just beware of this. It does look really good and the etching is great, but I wish it was SS. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Placards/Nameplate I was thinking that on my next order from ACS, I'd get whatever logbooks and placards I'll need. I see on this page of ACS's catalog they have a nameplate, and stainless steel ID tag on the top of the page. http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf I need both of these, right? I've seen the black on the side under the HS on -10's. Where would the nameplate go? Tim ________________________________________________________________________________ SPAM: If the email is for spam, please report to abuse(at)dnsExit.com -By mail relay service at: http://www.dnsExit.com/Direct.sv?cmd=mailRelay Accounts will be suspended immediately if found spamming.
Date: Nov 01, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Tim, Here is a checklist that a local DAR uses as published by EAA Chapter 670. Might come in handy. http://www.aerovents.com/eaa670/eaabldrcklst.htm Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Placards/Nameplate I was thinking that on my next order from ACS, I'd get whatever logbooks and placards I'll need. I see on this page of ACS's catalog they have a nameplate, and stainless steel ID tag on the top of the page. http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf I need both of these, right? I've seen the black on the side under the HS on -10's. Where would the nameplate go? Tim ________________________________________________________________________________
Date: Nov 01, 2005
From: bruce breckenridge <bbreckenridge(at)gmail.com>
Subject: RE: Frappr Map for the list
Mani; Excellent find! Can't believe how fast it's building! Bruce ________________________________________________________________________________
Date: Nov 01, 2005
Subject: Re: RE: Frappr Map for the list
Tim, maybe you can put a link in your site. I would say it will look awful crowded with >400 flags on it. Mani bruce breckenridge wrote: Mani; Excellent find! Can't believe how fast it's building! Bruce ________________________________________________________________________________
Date: Nov 01, 2005
That is building fast. I think we want as many people on there as possible. I agree that it will be difficult to see all of them on the big map, but you can use the zoom controls on the left side of the map to zoom in on an area. This will allow anybody to see how many builders there are along their route of travel or at their destination when traveling, which may promote some more face to face interaction in the group. It would be great if there could be some contact information too, but that can be found other places, I guess. Google does it again. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mani Ravee Subject: RV10-List: Frappr Map for the list Guys, Here is a Frappr map for north america. Add yourselves to it, both builders and finished ones. http://www.frappr.com/rv10snorthamerica Mani ________________________________________________________________________________
Date: Nov 01, 2005
Well let me tell you about one instance of my fuel system starting to vapor lock. It was a hot day this summer, about 96 deg. I was climbing out at about 1000 fpm from 150ft airport elev. to 9000ft. when I was passing through 5000ft I noticed the fuel pressure dropping from its normal 19 to 21 psi to around 17.5. I turned on the fuel pump and the pressure went to 28 psi. I lowered the nose and left the fuel pump on for 5 min or so. Lowering the nose did the trick. Turned the fuel pump off and the pressures were fine. I have a 1" scat tube running to the fuel pump to cool it. Remember that with the heater controls turned off that the unused heated air is dumped right around the fuel pump. I have had no issues starting the engine when hot - 100 plus deg. The trick is to leave the mix full lean and start cranking. After 5 revs or so if it isn't running already start bleeding in some fuel with the mix. Starts every time. 102 hours and counting. I am working on my IFR ticket for the next few months. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: Vapor return for mechanical fuel injection Vapor lock is NOT just a startup problem. The following is an NTSB report from a crash near where my parents live. The pilot and passengers were not hurt, and although it sounds like he did everything right vapor lock still bit him. -Jim 40384 NTSB Number: CHI04CA210 Narrative Type: NTSB FINAL NARRATIVE (6120.4) The airplane was destroyed during a post-impact ground fire, following a loss of engine power and subsequent forced landing. The pilot reported he had landed and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The airplane experienced a loss of engine power while on the second takeoff attempt. The pilot stated he maneuvered the airplane to land on a nearby road and it impacted a road sign prior to coming to stop. An on-ground fire engulfed the airplane shortly thereafter. There were no anomalies noted with the engine during a post-accident operational test. The outside temperature at the time of the accident was approximately 28 degrees Celsius. A condition known as vapor lock can occur when engine heats the fuel lines and the contained fuel becomes a vapor. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. The fuel vapor can result in partial or complete interruption of fuel flow to the engine. Narrative Type: NTSB PRELIMINARY NARRATIVE (6120.19) On July 31, 2004, at 1519 eastern daylight time, a Piper PA-28RT-201T, N77782, piloted by a private pilot, was destroyed during a post-impact ground fire following a loss of engine power and subsequent forced landing near Plymouth, Michigan. The airplane experienced the loss of engine power while on initial climb from runway 18 (2,556 feet by 75 feet, dry asphalt) at the Canton-Plymouth-Mettetal Airport (1DS). Visual meteorological conditions prevailed at the time of the accident. The personal flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The pilot and one passenger were not injured. One passenger reported minor injuries. The local area flight was originating at the time of the accident. The pilot reported he had landed at 1500 and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of 100 low-lead aviation fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The pilot reported he taxied onto runway 18 and set the engine power to 2,500 rpm and 38 inches of manifold pressure. The pilot stated the airplane became airborne and experienced a loss of engine power while on initial climb. The pilot reported he switched fuel tanks, but there was no increase in engine power. The pilot stated the airplane descended under some power lines as he maneuvered the airplane to land on a nearby road. The pilot reported the airplane impacted a road sign prior to coming to stop and an on-ground fire engulfed the airplane shortly thereafter. Federal Aviation Administration (FAA) inspectors performed the on-site investigation. The engine was removed from the accident airplane and mounted on a compatible airframe for an operational engine test. The engine started and idled without anomalies. The engine was then accelerated to 2,200 rpm which yielded approximately 80 lbs of oil pressure. The engine was then shut-off using the mixture idle cut-off. There were no anomalies noted with the engine during the operational test. The closest weather reporting station to the accident site was located at the Willow Run Airport (YIP), Detroit, Michigan, about 7.4 nautical miles (nm) southeast of the accident site. The airport is equipped with an Automated Surface Observing System (ASOS). The following weather conditions were reported prior to and at the time of the accident: At 1453 edt: Wind 230 degrees at 11 knots, visibility unrestricted at 10 statute miles (sm), few clouds at 5,000 feet above ground level (agl), temperature 28 degrees Celsius, dew point -01 degrees Celsius, altimeter setting 29.90 inches-of-mercury. According to FAA publication AC 65-12A, fuel normally remains in a liquid state until it is discharged into the air stream and changes into a vapor. Under certain conditions the fuel may vaporize in the lines, pumps, or other fuel components. The vapor pockets formed by the premature vaporization can restrict the fuel flow through units that were designed to handle liquids rather than gases. The resulting partial or complete interruption of the fuel flow is called vapor lock. Transfer of heat from the engine tends to cause vaporization of fuel in the lines and the pump. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. Vapor lock can become serious enough to block the fuel flow completely and stop the engine. Even small amounts of vapor in the inlet line can restrict the fuel flow to the engine driven pump and ultimately reduce its output pressure. Narrative Type: NTSB PROBABLE CAUSE NARRATIVE The loss of engine power at a low altitude due to a fuel flow restriction caused by vapor lock. Factors to the accident included the high atmospheric temperature and the road sign that the airplane impacted during the forced landing. Jesse Saint wrote: I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: It does, I did not realize there is a valve that is opened and closed. That makes more sense. I have not flown behind an IO engine, just standard. Now maybe you can explain to me, is it like in an auto, where there is allot more fuel going to the rail then is used, causing a return line to be necessary? or does it only pump what is required/ used? I thought fuel injection meant a looped system, where only the portion of fuel that went to the injectors was used and the rest sent back to the tank? _____ to and ________________________________________________________________________________
Subject: Re: Vapor return for mechanical fuel injection
Date: Nov 01, 2005
I was in a Cirrus SR22 for a while here in Dallas, and anytime the temp gets above 95 degrees, SOP was to leave the fuel pump on throughout the climb and also on descent. I had a couple of attention getting episodes doing IFR practice approaches with an instructor that said that it was dangerous to leave the fuel pump on continuously, that were resolved when the fuel pump was turned on. One one occassion, the engine went silent doing a procedure turn, but came back to life when the fuel pump was switched on. Do any of you see any problem with just leaving the pump on when it's hot in the 10? Thanks, Mark ----- Original Message ----- From: Randy DeBauw To: rv10-list(at)matronics.com Sent: Tuesday, November 01, 2005 12:53 PM Subject: RE: RV10-List: Vapor return for mechanical fuel injection Well let me tell you about one instance of my fuel system starting to vapor lock. It was a hot day this summer, about 96 deg. I was climbing out at about 1000 fpm from 150ft airport elev. to 9000ft. when I was passing through 5000ft I noticed the fuel pressure dropping from its normal 19 to 21 psi to around 17.5. I turned on the fuel pump and the pressure went to 28 psi. I lowered the nose and left the fuel pump on for 5 min or so. Lowering the nose did the trick. Turned the fuel pump off and the pressures were fine. I have a 1" scat tube running to the fuel pump to cool it. Remember that with the heater controls turned off that the unused heated air is dumped right around the fuel pump. I have had no issues starting the engine when hot - 100 plus deg. The trick is to leave the mix full lean and start cranking. After 5 revs or so if it isn't running already start bleeding in some fuel with the mix. Starts every time. 102 hours and counting. I am working on my IFR ticket for the next few months. Randy From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Sent: Tuesday, November 01, 2005 5:01 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Vapor return for mechanical fuel injection Vapor lock is NOT just a startup problem. The following is an NTSB report from a crash near where my parents live. The pilot and passengers were not hurt, and although it sounds like he did everything right vapor lock still bit him. -Jim 40384 NTSB Number: CHI04CA210 Narrative Type: NTSB FINAL NARRATIVE (6120.4) The airplane was destroyed during a post-impact ground fire, following a loss of engine power and subsequent forced landing. The pilot reported he had landed and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The airplane experienced a loss of engine power while on the second takeoff attempt. The pilot stated he maneuvered the airplane to land on a nearby road and it impacted a road sign prior to coming to stop. An on-ground fire engulfed the airplane shortly thereafter. There were no anomalies noted with the engine during a post-accident operational test. The outside temperature at the time of the accident was approximately 28 degrees Celsius. A condition known as vapor lock can occur when engine heats the fuel lines and the contained fuel becomes a vapor. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. The fuel vapor can result in partial or complete interruption of fuel flow to the engine. Narrative Type: NTSB PRELIMINARY NARRATIVE (6120.19) On July 31, 2004, at 1519 eastern daylight time, a Piper PA-28RT-201T, N77782, piloted by a private pilot, was destroyed during a post-impact ground fire following a loss of engine power and subsequent forced landing near Plymouth, Michigan. The airplane experienced the loss of engine power while on initial climb from runway 18 (2,556 feet by 75 feet, dry asphalt) at the Canton-Plymouth-Mettetal Airport (1DS). Visual meteorological conditions prevailed at the time of the accident. The personal flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The pilot and one passenger were not injured. One passenger reported minor injuries. The local area flight was originating at the time of the accident. The pilot reported he had landed at 1500 and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of 100 low-lead aviation fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The pilot reported he taxied onto runway 18 and set the engine power to 2,500 rpm and 38 inches of manifold pressure. The pilot stated the airplane became airborne and experienced a loss of engine power while on initial climb. The pilot reported he switched fuel tanks, but there was no increase in engine power. The pilot stated the airplane descended under some power lines as he maneuvered the airplane to land on a nearby road. The pilot reported the airplane impacted a road sign prior to coming to stop and an on-ground fire engulfed the airplane shortly thereafter. Federal Aviation Administration (FAA) inspectors performed the on-site investigation. The engine was removed from the accident airplane and mounted on a compatible airframe for an operational engine test. The engine started and idled without anomalies. The engine was then accelerated to 2,200 rpm which yielded approximately 80 lbs of oil pressure. The engine was then shut-off using the mixture idle cut-off. There were no anomalies noted with the engine during the operational test. The closest weather reporting station to the accident site was located at the Willow Run Airport (YIP), Detroit, Michigan, about 7.4 nautical miles (nm) southeast of the accident site. The airport is equipped with an Automated Surface Observing System (ASOS). The following weather conditions were reported prior to and at the time of the accident: At 1453 edt: Wind 230 degrees at 11 knots, visibility unrestricted at 10 statute miles (sm), few clouds at 5,000 feet above ground level (agl), temperature 28 degrees Celsius, dew point -01 degrees Celsius, altimeter setting 29.90 inches-of-mercury. According to FAA publication AC 65-12A, fuel normally remains in a liquid state until it is discharged into the air stream and changes into a vapor. Under certain conditions the fuel may vaporize in the lines, pumps, or other fuel components. The vapor pockets formed by the premature vaporization can restrict the fuel flow through units that were designed to handle liquids rather than gases. The resulting partial or complete interruption of the fuel flow is called vapor lock. Transfer of heat from the engine tends to cause vaporization of fuel in the lines and the pump. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. Vapor lock can become serious enough to block the fuel flow completely and stop the engine. Even small amounts of vapor in the inlet line can restrict the fuel flow to the engine driven pump and ultimately reduce its output pressure. Narrative Type: NTSB PROBABLE CAUSE NARRATIVE The loss of engine power at a low altitude due to a fuel flow restriction caused by vapor lock. Factors to the accident included the high atmospheric temperature and the road sign that the airplane impacted during the forced landing. Jesse Saint wrote: ________________________________________________________________________________
Date: Nov 01, 2005
Subject: Vapor return for mechanical fuel injection
Thanks for the information. Can you share what some of the features of the Eci system are, and why they are advantagous over the Bendix system? James Ball said: > > This whole discussion started with an inquiry about the ECi mechanical > fuel injection system for Lycoming engines. It is something like the > Continental design since it has a vane type of fuel pump as opposed to > the diaphragm Lycoming type and it requires a vapor return line. It has > a number or advantages over the Bendix type of fuel injection. ECi is > testing this system and it will be available sometime early next year. > For more information check out > > eci2fly.com. > > Kind Regards, > Jim Ball > ________________________________________________________________________________
Date: Nov 01, 2005
Randy, Please explain why when the heat controls are turned off the unused heat is dumped around the fuel pump Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 ________________________________
Subject: RE: RV10-List: Vapor return for mechanical fuel injection Well let me tell you about one instance of my fuel system starting to vapor lock. It was a hot day this summer, about 96 deg. I was climbing out at about 1000 fpm from 150ft airport elev. to 9000ft. when I was passing through 5000ft I noticed the fuel pressure dropping from its normal 19 to 21 psi to around 17.5. I turned on the fuel pump and the pressure went to 28 psi. I lowered the nose and left the fuel pump on for 5 min or so. Lowering the nose did the trick. Turned the fuel pump off and the pressures were fine. I have a 1" scat tube running to the fuel pump to cool it. Remember that with the heater controls turned off that the unused heated air is dumped right around the fuel pump. I have had no issues starting the engine when hot - 100 plus deg. The trick is to leave the mix full lean and start cranking. After 5 revs or so if it isn't running already start bleeding in some fuel with the mix. Starts every time. 102 hours and counting. I am working on my IFR ticket for the next few months. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: Vapor return for mechanical fuel injection Vapor lock is NOT just a startup problem. The following is an NTSB report from a crash near where my parents live. The pilot and passengers were not hurt, and although it sounds like he did everything right vapor lock still bit him. -Jim 40384 NTSB Number: CHI04CA210 Narrative Type: NTSB FINAL NARRATIVE (6120.4) The airplane was destroyed during a post-impact ground fire, following a loss of engine power and subsequent forced landing. The pilot reported he had landed and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The airplane experienced a loss of engine power while on the second takeoff attempt. The pilot stated he maneuvered the airplane to land on a nearby road and it impacted a road sign prior to coming to stop. An on-ground fire engulfed the airplane shortly thereafter. There were no anomalies noted with the engine during a post-accident operational test. The outside temperature at the time of the accident was approximately 28 degrees Celsius. A condition known as vapor lock can occur when engine heats the fuel lines and the contained fuel becomes a vapor. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. The fuel vapor can result in partial or complete interruption of fuel flow to the engine. Narrative Type: NTSB PRELIMINARY NARRATIVE (6120.19) On July 31, 2004, at 1519 eastern daylight time, a Piper PA-28RT-201T, N77782, piloted by a private pilot, was destroyed during a post-impact ground fire following a loss of engine power and subsequent forced landing near Plymouth, Michigan. The airplane experienced the loss of engine power while on initial climb from runway 18 (2,556 feet by 75 feet, dry asphalt) at the Canton-Plymouth-Mettetal Airport (1DS). Visual meteorological conditions prevailed at the time of the accident. The personal flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The pilot and one passenger were not injured. One passenger reported minor injuries. The local area flight was originating at the time of the accident. The pilot reported he had landed at 1500 and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of 100 low-lead aviation fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The pilot reported he taxied onto runway 18 and set the engine power to 2,500 rpm and 38 inches of manifold pressure. The pilot stated the airplane became airborne and experienced a loss of engine power while on initial climb. The pilot reported he switched fuel tanks, but there was no increase in engine power. The pilot stated the airplane descended under some power lines as he maneuvered the airplane to land on a nearby road. The pilot reported the airplane impacted a road sign prior to coming to stop and an on-ground fire engulfed the airplane shortly thereafter. Federal Aviation Administration (FAA) inspectors performed the on-site investigation. The engine was removed from the accident airplane and mounted on a compatible airframe for an operational engine test. The engine started and idled without anomalies. The engine was then accelerated to 2,200 rpm which yielded approximately 80 lbs of oil pressure. The engine was then shut-off using the mixture idle cut-off. There were no anomalies noted with the engine during the operational test. The closest weather reporting station to the accident site was located at the Willow Run Airport (YIP), Detroit, Michigan, about 7.4 nautical miles (nm) southeast of the accident site. The airport is equipped with an Automated Surface Observing System (ASOS). The following weather conditions were reported prior to and at the time of the accident: At 1453 edt: Wind 230 degrees at 11 knots, visibility unrestricted at 10 statute miles (sm), few clouds at 5,000 feet above ground level (agl), temperature 28 degrees Celsius, dew point -01 degrees Celsius, altimeter setting 29.90 inches-of-mercury. According to FAA publication AC 65-12A, fuel normally remains in a liquid state until it is discharged into the air stream and changes into a vapor. Under certain conditions the fuel may vaporize in the lines, pumps, or other fuel components. The vapor pockets formed by the premature vaporization can restrict the fuel flow through units that were designed to handle liquids rather than gases. The resulting partial or complete interruption of the fuel flow is called vapor lock. Transfer of heat from the engine tends to cause vaporization of fuel in the lines and the pump. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. Vapor lock can become serious enough to block the fuel flow completely and stop the engine. Even small amounts of vapor in the inlet line can restrict the fuel flow to the engine driven pump and ultimately reduce its output pressure. Narrative Type: NTSB PROBABLE CAUSE NARRATIVE The loss of engine power at a low altitude due to a fuel flow restriction caused by vapor lock. Factors to the accident included the high atmospheric temperature and the road sign that the airplane impacted during the forced landing. Jesse Saint wrote: I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: It does, I did not realize there is a valve that is opened and closed. That makes more sense. I have not flown behind an IO engine, just standard. Now maybe you can explain to me, is it like in an auto, where there is allot more fuel going to the rail then is used, causing a return line to be necessary? or does it only pump what is required/ used? I thought fuel injection meant a looped system, where only the portion of fuel that went to the injectors was used and the rest sent back to the tank? _____ ________________________________________________________________________________
Date: Nov 01, 2005
Reliability and lighter weight are the primary advantages. The mechanical type design is quite a bit older than the servo design and has a long track record of success. In the mechanical design, fuel flow is controlled by precision machined cams and orifices which are very stable once they are set. The servo systems are subject to variations due to changes in elasticity and/or the pressure of some very delicate springs in the regulator section. With the mechanical system, there are no sensors, solenoids, or black boxes to fail or require backup. That's it in a nutshell. J.B. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection Thanks for the information. Can you share what some of the features of the Eci system are, and why they are advantagous over the Bendix system? James Ball said: > > This whole discussion started with an inquiry about the ECi mechanical > fuel injection system for Lycoming engines. It is something like the > Continental design since it has a vane type of fuel pump as opposed to > the diaphragm Lycoming type and it requires a vapor return line. It > has a number or advantages over the Bendix type of fuel injection. ECi > is testing this system and it will be available sometime early next year. > For more information check out > > eci2fly.com. > > Kind Regards, > Jim Ball > ________________________________________________________________________________
Subject: For the new starters
Date: Nov 02, 2005
A lot of people are a long way into the project and there's a lot of talk about painting and engines etc which is years away for those just starting,so, for those who have just started I'll share a few things I've learned so far (I know you can look up the archive but who cares). Learning to rivet: it scares the crap out of all of us to begin with but here are a few tricks I've learned. I have the advantage of working for a GA airline and have access to LAME's and engineers etc and most of these tricks they gave me. 1. When riveting flush rivets (AN426), run a line of masking tape either side of the line of holes (on the gun side) and you'll find that the gun doesn't wander around anywhere near as much. 2. When riveting AN470 rivets put a piece of masking tape over the machined head of the rivet. You will very rarely miss another one or get another smiley. 3. When driving 3/32nd rivets use about 35-40PSI. The longer the rivet attachment the slightly higher the pressure. 4. When driving 1/8th rivets use about 65-70PSI. Again, when you need to use a longer rivet attachment increase the pressure slightly. 5. Try as best you can to drive the rivet in one go rather than multiple goes. Hold the rivet gun and bucking bar as square to the rivet as possible and just let the bucking bar do the work. If your pressures are right you'll see the head forming before your eyes and it will feel right. There's no other way to describe it. 6. Just have a go! By the time you get half way through the HS you'll wonder what all the fuss was about. Then again, when you get near the end of the elevators where you're expected to get your large hands into ridiculously awkward positions to drive a rivet you'll feel the frustration creeping back. Mark Drury 40436 (just finishing elevators) ________________________________________________________________________________
Date: Nov 01, 2005
He must mean the fuel pump mounted on the engine. That is where the heated air is dumped when the cabin heat is turned off. It goes right into the engine compartment below the mags and right by the fuel pump. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick Subject: RE: RV10-List: Vapor return for mechanical fuel injection Randy, Please explain why when the heat controls are turned off the unused heat is dumped around the fuel pump Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 _____ From: Randy DeBauw [mailto:Randy(at)abros.com] Subject: RE: RV10-List: Vapor return for mechanical fuel injection Well let me tell you about one instance of my fuel system starting to vapor lock. It was a hot day this summer, about 96 deg. I was climbing out at about 1000 fpm from 150ft airport elev. to 9000ft. when I was passing through 5000ft I noticed the fuel pressure dropping from its normal 19 to 21 psi to around 17.5. I turned on the fuel pump and the pressure went to 28 psi. I lowered the nose and left the fuel pump on for 5 min or so. Lowering the nose did the trick. Turned the fuel pump off and the pressures were fine. I have a 1" scat tube running to the fuel pump to cool it. Remember that with the heater controls turned off that the unused heated air is dumped right around the fuel pump. I have had no issues starting the engine when hot - 100 plus deg. The trick is to leave the mix full lean and start cranking. After 5 revs or so if it isn't running already start bleeding in some fuel with the mix. Starts every time. 102 hours and counting. I am working on my IFR ticket for the next few months. Randy _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: Vapor return for mechanical fuel injection Vapor lock is NOT just a startup problem. The following is an NTSB report from a crash near where my parents live. The pilot and passengers were not hurt, and although it sounds like he did everything right vapor lock still bit him. -Jim 40384 NTSB Number: CHI04CA210 Narrative Type: NTSB FINAL NARRATIVE (6120.4) The airplane was destroyed during a post-impact ground fire, following a loss of engine power and subsequent forced landing. The pilot reported he had landed and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The airplane experienced a loss of engine power while on the second takeoff attempt. The pilot stated he maneuvered the airplane to land on a nearby road and it impacted a road sign prior to coming to stop. An on-ground fire engulfed the airplane shortly thereafter. There were no anomalies noted with the engine during a post-accident operational test. The outside temperature at the time of the accident was approximately 28 degrees Celsius. A condition known as vapor lock can occur when engine heats the fuel lines and the contained fuel becomes a vapor. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. The fuel vapor can result in partial or complete interruption of fuel flow to the engine. Narrative Type: NTSB PRELIMINARY NARRATIVE (6120.19) On July 31, 2004, at 1519 eastern daylight time, a Piper PA-28RT-201T, N77782, piloted by a private pilot, was destroyed during a post-impact ground fire following a loss of engine power and subsequent forced landing near Plymouth, Michigan. The airplane experienced the loss of engine power while on initial climb from runway 18 (2,556 feet by 75 feet, dry asphalt) at the Canton-Plymouth-Mettetal Airport (1DS). Visual meteorological conditions prevailed at the time of the accident. The personal flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The pilot and one passenger were not injured. One passenger reported minor injuries. The local area flight was originating at the time of the accident. The pilot reported he had landed at 1500 and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of 100 low-lead aviation fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The pilot reported he taxied onto runway 18 and set the engine power to 2,500 rpm and 38 inches of manifold pressure. The pilot stated the airplane became airborne and experienced a loss of engine power while on initial climb. The pilot reported he switched fuel tanks, but there was no increase in engine power. The pilot stated the airplane descended under some power lines as he maneuvered the airplane to land on a nearby road. The pilot reported the airplane impacted a road sign prior to coming to stop and an on-ground fire engulfed the airplane shortly thereafter. Federal Aviation Administration (FAA) inspectors performed the on-site investigation. The engine was removed from the accident airplane and mounted on a compatible airframe for an operational engine test. The engine started and idled without anomalies. The engine was then accelerated to 2,200 rpm which yielded approximately 80 lbs of oil pressure. The engine was then shut-off using the mixture idle cut-off. There were no anomalies noted with the engine during the operational test. The closest weather reporting station to the accident site was located at the Willow Run Airport (YIP), Detroit, Michigan, about 7.4 nautical miles (nm) southeast of the accident site. The airport is equipped with an Automated Surface Observing System (ASOS). The following weather conditions were reported prior to and at the time of the accident: At 1453 edt: Wind 230 degrees at 11 knots, visibility unrestricted at 10 statute miles (sm), few clouds at 5,000 feet above ground level (agl), temperature 28 degrees Celsius, dew point -01 degrees Celsius, altimeter setting 29.90 inches-of-mercury. According to FAA publication AC 65-12A, fuel normally remains in a liquid state until it is discharged into the air stream and changes into a vapor. Under certain conditions the fuel may vaporize in the lines, pumps, or other fuel components. The vapor pockets formed by the premature vaporization can restrict the fuel flow through units that were designed to handle liquids rather than gases. The resulting partial or complete interruption of the fuel flow is called vapor lock. Transfer of heat from the engine tends to cause vaporization of fuel in the lines and the pump. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. Vapor lock can become serious enough to block the fuel flow completely and stop the engine. Even small amounts of vapor in the inlet line can restrict the fuel flow to the engine driven pump and ultimately reduce its output pressure. Narrative Type: NTSB PROBABLE CAUSE NARRATIVE The loss of engine power at a low altitude due to a fuel flow restriction caused by vapor lock. Factors to the accident included the high atmospheric temperature and the road sign that the airplane impacted during the forced landing. Jesse Saint wrote: I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: It does, I did not realize there is a valve that is opened and closed. That makes more sense. I have not flown behind an IO engine, just standard. Now maybe you can explain to me, is it like in an auto, where there is allot more fuel going to the rail then is used, causing a return line to be necessary? or does it only pump what is required/ used? I thought fuel injection meant a looped system, where only the portion of fuel that went to the injectors was used and the rest sent back to the tank? _____ ==================================== ==================================== ________________________________________________________________________________
Subject: Gear leg Socket - 7.9mm Drill
Date: Nov 02, 2005
G'day all, I have checked the archives and notice that this was discussed a little earlier in the year. Given the progress since, I was wondering what the concensus was on drilling the gear leg socket. Options appear to be: a. find a 7.9 mm (.311) drill and drill per plans. b. drill to 5/16 c. ream to 5/16 and install a close tolerance bolt Which is the best way to go?? cheers, Ron 187 fuse ________________________________________________________________________________
Date: Nov 02, 2005
Subject: Lycoming O 540 starter
I ran across this the other night on Ebay. Anyone seen these before? Appears to be equal to the Sky-tec HT model for $255. Anyone used these versus the other starters? Textron - Lycoming Starter Fits all engines up to .0540 1.4 kW gear reduction AIR-BOAT starter. 1 Year Warranty! 2 times stronger than the original!! 10 Lbs. Less! Starter weighs 9 lbs! All bearings no bushings! VERY STRONG AND SUPER LIGHT This is a direct replacement for the original unit. Will fit up to 540 Textron Lycoming Engines! May be used for Experimental Aircraft. (non-certified) This is for the 149 tooth flywheel. I ran across this the other night on Ebay. Anyone seen these before? Appears to be equal to the Sky-tec HT model for $255. Anyone used these versus the other starters? Textron - LycomingStarter Fits all engines up to .0540 1.4 kW gear reduction AIR-BOAT starter. 1 Year Warranty! 2 times stronger than the original!! 10Lbs. Less! Starter weighs 9 lbs! All bearings no bushings! VERY STRONG AND SUPER LIGHT This is a direct replacement for the original unit. Will fit up to 540 Textron Lycoming Engines! May be used for Experimental Aircraft. (non-certified) This is for the 149 tooth flywheel. /9j/6wBpRVBTAHicY2AYBaNgFIwCKPj+Hbv4//94tf36RQO30AM8eUJX616/fk1X+ygGP37QySJI Avr69Sud7BsFZIHDh1G4mzZtAtP3aVQA/BqyBcsIAWj59c6dOwPkkFEwCkYBPgAAVQ4eDv/gABBK RklGAAECAQBgAGAAAP/AABEIASwBkAMBIgACEQEDEQH/2wCEAAYEBQYFBAYGBQYHBwYIChELCgkJ ChUPEAwRGRYaGhgWGBcbHyghGx0lHhcYIi8jJSkqLC0sGyExNDArNCgrLCsBBwcHCgkKFAsLFCsc GBwcKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrK//EAaIA AAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEG E1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVW V1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLD xMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQID BAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1Lw FWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5 eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj 5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+qaKKKACiiigAooooAKKKKACoLv/AFY+tT1B d/6sfWk9hrcqUe1LTe3Wskai/wANKaZ/DSH60xDyaYTSEntTSaoBxaozQelNHBoAdigrjtTgRTgR jrQFyHpS5ptzLFCu6WRUH+0cVnSavaxngu30Wgm5p9qT+Gs1NXhYcqyj3xRJrNog5c8CpuFzUpuK 5ebxtpSs6ws9wV+95YyB9T0rmdU+MWiWDFWUFgcbfMyf0Bqg50em0V4heftBaVbymP8Asm4Zl4IM gGP0qGD9obTGb59FuAvqs4P9KLMnnR7oRSY4ry7SPjd4UvXCTyXNoT3kTI/MV6Bo+t6ZrMAl0u9g uo+v7twSPwoKU0zRAAoxS/w0VJQzHpS4pcUdhQMT+Gkp3akOKAGd6XHpRil6HFIBMDFL24pcUlFg NjTv+PWP8f51Zqtp3/HrH+P86s1qtjJ7hRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB UF3gRj61PUF5/qh9aT2GtyoT0ppxij+GiszQTgCkoNY/inX7Xw7ppu7vJJO1EB5Y0CvZGucYph9j Xzb4p+Ouryaitro8NrZW2/H2l/mJ/wDrVf8ACf7QafaRaeKdPwAdv2yz5H1Kn+n5VfKyPaI+gJXS OMu7BYxySegrnrnxbYRuyxB5gP4lwAa8913xkfEQD2j404/NEoP+sHYn/CsWW/8ALUDqxOABWbY9 z0u78bxwxbhbqv1bP8hWbL4q1K6H3ktIewQZc/U9q4W2kAk86Rw83r2X2FTteccHii4W0NrU/EMV jGZp5Dk/xMcs1YA8eRiTBhwp6HdzXmOv6zJf6pLIGPlISqD2rMa+dRnOK0VMm57Fc+PbSOIs0m3j jOSK5DVPHFlLGZLy8N3L1W2AZYx9fX8a8/mkeTTHu5W4MhjRf61gSOS3Bwc1fsrE3Og8ReKNc1f9 0ny2y/dhtzwB9BXHyzOznzWOe+TyKmkLBupB60SXblAk4En+/wAn8+tK1h6FdSXR33L8vYnk/Snx Sc03FvIMqWhPvyKclu+AYwHH+yc/pSaGizE5ByK3dI1K5sZ457K4lt5l5DxsVIrnIzjjP4Vo2r8D BzSBo+gPAHxourZorPxSn2iA8C7QfOv+8O9e9abf2upWUN3Yzxz20gyrocg18PWxBUAjiu5+H/jW 98H36NDun09z+/tc8N7r6GhrqgTsfWK0nFUdD1S01rS7fUNOkEltOu5WH8j7irtZmqF7U2ndlowM UXGIBxS4GetHApR06UAJgUGl/Cii4Grp3/HrH+P86s1WsP8Aj2j/AB/nVmtVsZPcKKKKYgooooAK KKKACiiigAooooAKKKKACiiigAooooAKgu/9WPrU9QXf+rH1pPYa3Kn4U3j0p38NNrJGo3tXzd8b /FYudTmt9x8hGaBBjgAHDH86+kj0r5j+Nngq9s9Z/tCCH7RB5zShcnDoTkqcd6uLV9TOSueV2+n2 U1w0V9exRQfKQAc7vevT/DPw88JXVmTHe3N4HA3qJNuPw614TqCkSzTWgCIvLRn+HnFQ2BvWmwtz cwH0DkYorUpS+GViYSt0PrLSvB+j6barBaRXAiHQNOTirJ8OabncElLEYP7w8V86aVaav5TzDWL3 hdqr9ob7x6flyfwqdrfxPAhKa5d/hOa43h6i+0bKb7H0Kug6ai48ufHs9N/sPTWQr5dyM8Z3188i bxkoyusXzD/ruaDq3jSHrql8f+2hqVQq/wAwOfkW9Q09rHUrm3myJIpChB9qpXVv8hOabNd6jJBH dapNJc3UjEEkZIA7k1Ul1BipQqfyr0Y3W5gPu5vM8PwWin/j2nZgvswGf5VP4X8KT63p2oaluWK1 tAAT6se1Y5nIl3AH3HrUkV/eWVpNFaXMqWkxzJGDxke1dCknuZNNbGbexeXK0ZbO0kVUuAD8oycC ppJQzZzk1WuZAp/dnn1FSy0VmGPp0pFkaNsxnH0NKxZz7nnJNRYOazKNBdUlZdsyrJ7sPm/PrV2O 4gUKwBiJ7HkVhKOR2qa4UoVUyBsd1OaXKgOw06ZJsLGwJ9BWlu+deteextJEA6kj3Fa1pr9zER5p EwH9/r+dTKLtoB738G/FreH9YXT7pz/Zl42Dk8RP2b8ehr6PUggEdO1fEWh6xb37hFyk2PuH+hr6 l+FXiM6x4fgiuHzc248tyT1x0P5Vzt8rszReR3PQdqTII4waOcY7UuOOlUWH8NC9elLzR3oASijt wKKANaw/49k/H+dWKrWH/HtH+P8AOrNbLYye4UUUUxBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQACoLsZiH1qcVBd/6sfWlLYa3KmMU0inUYrI1IzxVHV9PttSs3t7tA0Z7n+E+oq84zWD44u2sf C2ozRsVYRbQR2zxT6CbsfMPjzw1pNx4juliVWWJtvmQ8ByO9YcegQQ8xnIHrW3M+6eT03GorhwsT YPahdkRchslRrKPygQFZgcjHOcfyAqUAk7SOlPtkEVnEgOeM5+vNP4qnqxLyIWk2jAqndSvtwASx 4AFXioPWovJaa7iWMZCnc2OwFOMdRNlS7YLKttEF2xLsB9T3P55rOvrZWAZkUY4yO9Zfji7e2nt0 gYq6ndkVbtb43+mQyH/WA81bRKZG9rFnkColtkF5EhAMcnykGrUSGWQKg696ZIP+JhZRsQMzqD+d XTWopPQ4+/i8i4mjJ5Rip+o4qgWzz6VteLjEviXVPsvzQC6fZu7jNYZI5OB7VUlZijsOyeuaRcFS MVHuOelSHASL7v4VBYpUBByP8KTOTg80oHJB54pqfIwLUmInaYpB5an5SeRiq/bNISCxNJnjHFMC eGd4JEeJirKcgjtXvnwM8XLJqBhd9s5TLL/ex3H4Zr57U4q7pd/Ppt9DdWkrRTRNuVlPQ1jWpc8b Fxdnc/Re0mE9vG6nORU9eYfA/wAd2vi7QvLLBNRtgBPAT+TD2NenetYQbtqa6dBV/CjGfahaO9Ug DFJ/DSsQFyTgCmk4AFAGtYf8e0f4/wA6s1V005s4ycd+n1q1W62MnuFFFFMQUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFQXf+rH1qeoLv8A1Y+tJ7DjuVaT+GlxzSVkajT0rjvimT/wht5j+8g/ 8eFdgenaua+INubnwlqCAZIQN+RzQJnzfJaqXbyyqk84PQ/4Vlayktvp1y5jZSFwM9OvrXQTR/vO gqjrqM/h7VETOREHAHsRST1IZVkyEAHYCqxZvervDwRsAMFQR+VReWPStEJlYSNnGTUdtL/xMG5+ 7CxH14H9au+Sp7VVt4gNSm97Zsf99LWkSHocD42cyawFPZa0dCjKaZFz1rK8ZKV1tv8AdFbmlAf2 XCRVMFsbdvGgj3qmOOorNPz65aADO0lz9AMn+VWrWRlTac4qjE2NZwQMNA6j6leK0pvUiVzhryTf O7E5LHNVTxxU90oWdlQ8A4GaiOBnnOD+FS9y0M4ppbiloAzzUjANgcGg5YjuaRCVbIODS5pBYXGO vBpuR0pXIxxTfrQAHj2pwPFMycUCkB0ngjxPf+E/EFrq2mPiaE/MhPyyqeqn2Nfc/gPxZp3jHw/b 6tpb/I4xJCfvQv3U1+e6Niu9+E3j+88C+Io7uItJp8xC3dsDxIvqP9odqiUb6oadj7uoqhoWrWWu 6Rb6lpk6z2lwm5HXuP8AGtCsTZCFQylWAI9DSEcjBwB2p1JQBq2AxaoB7/zqxVew/wCPZPx/nVit 1sZPcKKKKYgooooAKKKKACiiigAooooAKKKKACiiigAooooAKhuv9WPrU1QXf+rH1pPYa3KvQUyl J7U0nistzUac1XvoFurOe3cfLIhU/iKnOcZqM5piZ816jbNbXc0Egw8TlGz2IOKpNCJoZ4WxtkjZ D+Ir0X4paKbbVBqEKfubrhiOzgf1H8q4BmES72OMUiTntLJk0q3BHzovlsPdeD/Kp0XtSgpBqt7A rKYpCLiEA9mHI/A1MY+QR0o2YivkDjiqRxHq9sezq8f5jP8ASr8iYYcVma1+4ijukBzA6ycegPP6 ZrSEtSZLQ4/xlBu1QPjqoqzpDZ0tU4+Vqk8aFE8iZT8m4rn9RWNpF+vmyQgjldwFaLYk6Hdt+4aq mQJqdvJ74qubnnvVe6uF8yN17EcVcXqS1oYmtbRceWkSps4Yj+I1lk10PiQK155qDCuoPAxWC/IO BxTktRrYj/hpO/ag8dKO3SoGgpSRtGBzTc+tKFLuFjBJJ4ApDGk0nOK2LbS444RNfOUB+6i/eaor pI0T93bBAehZuajnWyHymZ705ASQBT+Cf4fwNOeMqoYA49aq4EeMcGpEJGKi5zzThz0oEexfAb4n yeDtVXTdUlZtBunw4/593P8AGPb1/OvseCWOaGOWFg8bgMrLyCD0r820baOlfSX7NvxOIaDwlrk5 MZ4sJnPTv5RP8vy9KznHqioux9KUUUc4rI1NWw/49k/H+dWDVew/49k/H+dWDW8djJ7hRRRTEFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABUF5/qh9anqve/6ofWk9hrcp000v8ADTeMVmjUYelM I4p56U0iqEZ2s6dDqmnzWlwo2uOD/dPY181fEnTdQ027l064DQ27fKJI2wW+h7dK+o3HGK89+NMW np4Ivrq/QebEAsDDruJwBRYhs+UJrC6sN01veksM7TJ1/OjR/Gd3FciG/wBpiBwxxyKqX95NIGbL NHmsW7hE6GeH769VrZQutTNy7Hp0fifT3wRJx6kVNLqVhdRMnmKyMMEe1eQwrJICY3VR6E01rmS3 kwspJH901nyLoUmzuLu3F5olzZsd01v8uR3C/wCrP5cVwEE7W9xHJyCp5Fdj4W1X91dG4G5yoxk9 RzXM6vsYRSxqqZBG0Ljoe/qferiSa0VyJUVlPBFJLINtYVnOyKUzx1FW/OyKYWNKd/tOmhgMtFx9 BWIflJGBWjp9wFmMbZ8txgj1qpqMfk3TKOnb6VRKSKrCmHP0pScUwtxUlIXnNbOnWgtrNb6dPlLb Uz/ERWZaRPPPFFEpZ3IVVHc+ldlr9tDda/pmgWSqi2SJbTSKCd8nWV/Xgkj6LVqHMgvZmBeXqrGZ ZDvuX5XPRRWNI7SNuYkn3q5q7RPqU5tyvkBiqFRgFRwD26gZqrDG80qxxDLMcAVko8uhTZGBxU0U 7xqUUnYeo7GrSWCGTyzcR7u+0E4qC7tpLScxSDkYII6EHoadhCTBC26IELjoe1Rj2p2cim96VgHg VPbyvBMkkLsjqQVZTggjoRSQxoYmYuAw6D1q9c2cMej2d0LlGuZ3YGBc5jUcAn6807CufZnwI8cv 4y8IRm+YHU7M+RcH+/6N+I/XNek18q/svXj2d1rDEkQt5Y/HmvqS1mWeIMDXDzrncOx0JNJM27D/ AI9k/H+dWKr2P/Hsn4/zqxXWtjJ7hRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAAelV7 viIfWrB6VXvP9UPrSew0Uj0qre3lrZxh7ueKBOmXYCrJrzbxS0E+qPDemFy0jKiSAHOPTNZops09 Z+JHh3TlIW6a7f8Au2y7v1OBWPbfFzR5D+/sb+EdjhW/rWBeeG9Hm5NkqMe8TFf0HFYtz4PtS22C eZc9AcHFVdCPT7b4j+GLjA/tHySe0sbLj8cYrxb49+Mv7fvYdI0djNp9ud7SJysrkdj6AH9asXPg m4Kn7PewtJnhHBXP41ymt6LfaXL/AKdbNHzgODlT+PSnF2E0cZr1smk2UECP5ks0YeQAfdJ7Vj2m mXSxm4aF0jP3SRwa66WMHI2ioLmS7MW2K5dSOnernUk7cpMYJbnHS2QmJktcBs/MtZV3ZzRHeyFc etdTJHcJdh52t8k/eCbSfr61sXT6ZcoUlBH0Q8/kKmdVq2g4xXc4zTNQU3sQkt0BYhSycdfbpUmv WixyyeXjAG8fng/0q3Po9r9sjeznYYYHa6MO/rik8SMolPGcow/lVRd2JrQ5dM7sjtV9EO0ECqMY BJyOMV0Vjb5to2x/DVWEZgDKcjtzV7UAJ7GG4xyPlNPktsgjGPpTo4SdGvC2QqMpUY4Y5wcfnTSu JmG60zA61I/5U0Lk4HNIo634Y2SXXim3lmZ1t7RGu5GXqAgLfzArQ8AXsUOsa/rl7EJltrC4lXzP m/eP8i/q9P8ABFvDaeFvEl1P/rZ7X7NHl9oXJ3HP4L09xWZZmaDwJfpbyqGvbuNJIQfmZEBYcem4 j8RXZSlGMdTF6t2ORk5YmrmnlVhuyVzJ5QCHP3fmGT+Wfzqs0LqcEYp0JeGQOmMjsRXG5Ju5sy5a 4KADr2qTWJllS1AbcYlKHIGepP8AXvVY3OzmKII3qKqEljk0kxWuKtKoyaRachAFIZJsIPFS28ck 0qwxIzu5AVVGSTVrR9KvNYvYbPT4Gnnc4Cr/AF9BX0L8Pfh7Z+GY1urwJc6oRy+MrF7L/jXLicVC gvM1o0XMu/DDw2/hrwzFDcLi8nPmzex7D8BXsHha5Z4QrE8cVx4FdZ4UgKxhiOpzXi4epKdXmfU7 6kUoWO+sP+PZPx/nVg1Xsf8Aj2T8f51YNfRR2PNe4UUUUxBRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAHpVa9/1Q+tWT0qvdj90PrSew0UTXm/jPR4tQ13MsqwGEiVXY4HavSSK4X4g2nmypklRN CV3KcEEVMWou42rqxgllbiNw6dAw7+9VZQRyMUtjAbPT4YWfzGUYLetPYrt9azk10GkV5Mtg9/Wn zOZYTG+1ozwVYZBphyGHOB6U1k3A9alOxVjgPFvhIhXudKjwoGTAP/Zf8K81numjkaPym3qcEHjB r1rx3rN94ehsbu3CyWxuNlxGR95cE4B7Hj9K4b4iWcdncQanZBRbagNwwMfNjP69a3gm0Q7HJXaT XVuyFVVSO9Z9rohvLUS29wyOCQyk9CKdLcMzYJxUulXRtbiZMjB5GOhq+VxRF0yodI1K0njMu1og wywpl9vmuSsSK7MjIAVDdfTPetu61VltJQcZK4ArBt2Z72NlVigYEkdhQmBm2hmt7h7VUALnaS0Y 3enfpwa6WO38uIKM8DApsECNJ57qTPuYEt6Z4/SrmQVxnFNvQLFAxsq5xmoy5s/C92WjO69ulRGI /hTlscepXoau3IIj2qMk8AVXutN/cRNduYraEfKrNySeTgU1UUNxcrZz1pZTXb7IxgdST0FaUf2O x+SNBcz9NzDgfT1oluXlQW9ogihHp3+tQTSR2aFYxum7t/hWbvItWQ+e4lZSbmYhT/AD/Ss+e8JU JEDsHTcaZ5cs78AsSatf2csSbrmUIf7o5NOyW4tzPM0h4z+FJvcc5NWJVhXiNWPuah3p/dpproAJ K3fBHuKcoVhk4WmfIelBUigQ542VScceop0KPJIiRglmOAB3NNjPGGGVrrPhnpgv/HGjxOoaHzfM PodoLf0qZy5YuQ4q7se7/DTwhb+GNEiLxqdSnUNPJ3Gf4R7CuyApq5rZ0bS3u5AzDEdfKtyrTv1Z 7CtCJDpWnSXcowpEfrXd2FqttEFAHFOsrSO1iCxqBVivWw2GVNXe5xVKvMzUsf8Aj2T8f51YNV7H /j2T8f51YNepHY5XuFFFFMQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFQXf+rH1qeoLv/Vj 60nsNblKuW8dRbtOgl7rJjPsR/8AWrqz0rF8Ww+doVyAMlQHH4GsuhoebOCY8dcVF93j8KtqoCcH qKqysNpPesh2EkXBB7U9AMketVzOu3B60gnxyKAKnia2jl0K9WSGOcKvmKrdmXoR+Ga8+17ZrXw2 efaA9pJuTA6AHBH5E16S83mIysAQeCCODWRNpVt/ZN5p9vCIoZ1YbV9SK6IVLWRnKO7PnO5Tnpx/ KqjuUVQnXPWtG6ieNWV1wynafYjqKzZwQOmAOa6ZIwRKsFzcEKCNvcntWnFCkEYji5H8R9TVe3kB Qc54q3EQeCaxuaD488VOg4pqABc0x2MjCOIgZ4LHoKLjsQSThZ9+CQvTFZjeffXBeUsVzxk8Ct6W 2gWIRxPubvt5JqnrcZs0+yJtWUJ+9XAJUHsc9+nSlGLethtqOhkXMojYwQjGOp9aSxsJLhyxB24y T6CprOFrq4jQRr1A4HJ6DrVzWbkW7NZ2rAAfLJt6denuK0ei0IWpTlmjtgYrMDPeTv8AhVByWOck +5qVUyKb5TMcKKz5S7kXlgimLZO7cDFaawxWsYe45J6LVK6vGkbEQ2r2FCQhoso0Pzy8+gp0cFuR hZWB9xVVXbdnJpYwd3HJqrCuXW01yoaCRWz2PFavg7Wp/Cfia0vp7Y+Uhw8ZHVSMEj35qpa8jBYD j1qczfuvLmjWa3PVM9PcHtUyhzJpji7O59Y6LNBqkNrcWcgkt7hQ6OO4NelaTbLDbrgdK+cf2dNX Aml0R5jJAoMtozdQP4kP0PP419M24AhQCvKoYdUqrR1zqc0UPp1NpccV2mRp2P8Ax7J+P86sVXsv +PdPx/nViuhbGT3CiiimIKKKKACiiigAooooAKKKKACiiigAooooAKKKKACoLv8A1Y+tT1Ddf6sf Wk9hrcp1BeQia1miI4ZCKsYpMCs7Gh42H25Q9VODVeUYYj9K1NatvsusXseMDzCR9DzVAx5O7FZN DKcijt1po6YqedABkcVXXJ5IFMAGASMUY5yKRvlNKh4p2sI8E+INk2n+LNTQjAeTzV+jc/zJrlJy ZByScDA57V6h8ZbBvttpqGB5bwlCfdT/APXry4SR7CCTu7YFdyd0mcttSKw+0+eIoYy+TgKOtbTQ ywAiaMxsDghuMVF4TYp4isZQB8kobBAOcH34rtL69t9T8QTXUyf6xg0YaPJ3ZHpgevXt+FXGipLc UqvK9jm7LT76+YRxIwBIGcYHPAGa7vwz8PLzUJ7aObMULAM+8gY7HgEnjFJZ68tnblpbZsllOXAA YA8bs98EHOa7HQvHvh/7bH9skjt1w3Rfunsc9cc9q6oUKcTCVab2Rf1vQNH8N+GbrU4reHdp8UwV SxCyPwBjcCTj69a+a5pJLqd5JmLOzFmZjzn617B8aPFkV1ollYafcQzRTszPtAOVGRzn3P6Zryzw 9Zfb9QigwcOwQ49zilXs2ooqje15G7fWkXhrw5FekA3epKRao2CYoz1Y+/QDHrXERKWOT1rc8aam 2q69MquzWlp/o1sCeiLwKy4/lGK5qlr2RrDYeiDGMVOVFra/aZV4Jwoz1NS6XavfXsUEK5J5PHQD kn8BUGszC8umSAEW8R2R8Yyvr+PWs+XS5pfoY080lxJl2JPvS+Q5TIGR/Kr1vZZlXsDwa9rsvhrp sXgW11oP9puDcKr/AD4SFSDg9uSeOelZSmloaQhzHiOm6Te6jMI7Kyubgk4xCma0bLSLiHz1ltWM rKUAOMxnIyceuAfzr0JruTSr+OSxk+zzwHIkgbBHbqK7yz8A2d54DutfmvblNXw04DkEP7HjvXK8 S76HR9XS3PnW6It5DCIimD/H1NMScdDj6V7d8Mvh5B461OWXULeN7KB9s2Xw5OOnByPrXB/GbwfD 4M8cXWl6aXazCK6BjuMeRnbnv+NaUavO7WMpUOXqYfhLxDc+Gtes9TsjkwvllPRl6EflmvuDwdrl vrmjWl9avuguEDqa/P8AjY7sdK+kf2Y/ELNZXuiyyZ+zN5kKnsrdR+f86jER5ffRMNdD6PFKKZAw dARUlFyzSs/9Qn4/zqc1BZ/6hPx/nU5rojsZPcKKKKYgooooAKKKKACiiigAooooAKKKKACiiigA ooooAKiuPuD61LUU/wB0fWk9hrcq46UmKcvSlxxiszQ8+8aWjLrAlGArx5JPTiuUa8t0donkVXHG M1n69d6v4t8Z6ro08zLBbO3kxJIsK+WDg7mPJp02g6ZpULRS6hG8y8hLbLY9tzdaXspbk3SRogLJ HlcEVBJbYXI9aNM3fZ1eMjkdDUxu4wxSUeUQe/T86zuWUJEPXFQjIOK2CiuuRgg+lU5oCrE8iqQj z34uW5l8NCYAnyJATj0PH+FeEOSJPlzivpzxZYfb/Dt9b4JLwtgD1xkV8zSD5/T2rppO6sYyWpo6 FcSQ6hbyB9pjztPpXQT3YBzBnzW5AJHy47+1crbmW0nilXK91bsavpf73cqPvJ5YP45rohJ7GTS3 L2n6HrHiO8jjsYLm5LHACKT/APqFQ634S1HRnZZm/fIfmUHpX1b8CptKtfhqjs8VvMw8uSRfvYwO /wCNct8U9IsYo90Ti5hkh3byw8wNjjOB1HHXrit1BOTiiKs1DRHzHFP5qeW4wQa6TQC9hFc3rQri 3hZwxPU7SAPzINc/f25h1Mqq43Lk8VpvMf7DlhbJZyqg+gByaxWj1K3RiW6/KSeT61KOKeVVV+Wm 4GeelRuUjb0y5k03Qb+7iULLdH7Ij4GQCMvj8AB+NZ1lEp+XtVzxHbvY2GlwFl8t4jMoB55OMkdu BWXFMQR5Z5+lOo7KwQ11PQdN+H2qtpUGtRQs1k2drqOARUkNzdKn9m3N5MLWZgJFDZU89cV0Wi+O dRtPCT6K1yRaSQeXnaPlB64Fc1HZXOqHbpEX2pl6qnBA/HgV5E6j3Z6dOmrWR3mvfC6ylggbw1fX E0xTLpIBgn/Z6Vv+DvEl9Z6O3hnXbC2ubmFWhYgBdseP42BxxWJoHiDxDpekfYr+1MVy+I7Vmg2O fUk9+O4rpdd/0PTp3mgiza4EoUYE0+MkH1C/zFcD9s3ob3gl7xiaNNb+CNQn1CxkitnuOSQzYYey nqPwFY+maloWs+OZ9S8YyLeW9zyW2MPKcdCQP4cce2K57VbiSSM31+DcTzcwxM2Bj+83t6CsWe3v XfNxdiElSVSILhT6YHSuyjhKnI4yluc9TEq94oj+N2n+HdP8VKvhYItsyAkR/dz7VN8C7x7Px1al ZFWOeN4SC2CeMjj8KwdTtTeOkF9/rwMQzf0NM+HayW/j/RYmBDrdgEfnXTKjyUHFu+hhzc07o+4d GvRLEvNa/auM0GYpJszXY27boga5MHU5o2ZpUjZmrZ/6hPx/nU9QWn/Hun4/zqevTWxzPcKKKKYg ooooAKKKKACiiigAooooAKKKKACiiigAooooAKinHyD61LTJfu0nsNbkCimkVJgUhHNZlHk/jzwB eXPiL+3dEniiZ1IuEckZOOoxWFaeEJIXea/vGuJiAAqjaBXuLIGUgjIPFcLrEPkahLCMgdjWdZyt uXHsYAs0gAWNcKB0qle2qyE5AFa8xwxGapyqN31rBOxVjAEc9s/7tjj07VOLwOAsyEH1FX5IgQTi qc8CgEkAYpqbDluSJarNE20hh6CvlbxTYf2Z4k1CzbIEVw6gegzkfpivoa88S2WnXcUUUxkZuCY+ Qp968d+L9tt8RLfBQBeRByMdGHB/pXbQdzGehxCAbgDx9e1XZLOWKAS7T5T8hqpRKXYEsM8Dk12G jalNa6QRGqGM5Uo4JVvcjPUdq6Y2MJeRb8BfES78LvJDLEt1YyrtaEtg5HRgexH8jV3W/iFNqQuU eV4re55dVPL+grkG0u0mgi2O8U2MOx5U88YwOOKrR6HIGGJ42Xt7Vak1sS4p7jyxnuJLhhyx4A7D sKt3qGHRlicjzjJ5pA/hBBGP0FR3cQ06KMmRXlbkBegqJJRcW0oIOccfnmk3bcaXYob8jnFPgAMq hulRqOealt8CRDnvWdyybxAzPqCqCSEjVBz0wOlaXgTTrfUvE+l2d3jyJ51R8nAwT61m6wS13uIG Co6VFY3UlrNHJC5V1YMpXqCKmrqOnpY+g/iN4c8P6PoiSeGpvtc8E+y527pBGuP7w4HIrC8IeOrX TIIdPvESCAH57mFSS3cZHU1zOma3qUenskMsi2VwMOGHyt+NX/DPhG31WZ7q/mEWmQqXkdW+96Kv uf0ryK6i1Z7HpU31PW7XxpDd3mlz/uLqynjYQNjldnJDehyORWN4p1WK60zTNLi/dtdsryYP987j /SpLbTNP0vw3p9xDbCKGB2OdxbCucZyfrXI61ciHXNLlI2qoVG9ivy/0FRgZxc7CxEWo3R0GpW+k vczXiyxosUX+ieSMeVgFQGYj+6C2B3rze5mnnujMfMZid+7Gce5PrXQ3momfSIbUXEAcAq1siAMM ZUknGepzWBY3ktlJPGCyq/yyIc4I9K9+fKeXTvYr3ls01tKjJlghdDuC4Yc5/SrPhHTM/GCwAXgR C6Yen7r/ABq9Yxf2tqMNuqwlrhvKCMcEA8l/wGa6zwFaW+oeP/Eet2Z32UBWxtnHRgoAJH4iuPFy UcO2b0FeokeraadtxGc9eK7awOYsVw1kP30f1ruNMH7uvFwD1aO3EI3bT/ULUxqG04gWpjXuw2OF 7hRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTH+6KfSN0pMCLFNqTFJUlEZHFct4ug2 SQXAHB+Q/wBK6ojjpWX4gt/tGlTqBllG5fqKiSurDTszz6flic1AVypGOlTSMQc44NRqwyVxXBqb lfgHB71V1iJn0248sZfYce9WbvgcDvSxOrrgjk8VSBnH+CbbSY4JxqjyrGGyFgQb2B6jd6Vx3x5j sL7RbG60y2NvFaTmIgvuJU9z+IH513134XDXxltbp7eFs5RRzz6VleMfDkP/AAhGqWkO+Z9jOGcg sSDn+ld1LER0VjCdPrc+ZsYbrW3os25Jo2bJxkZrHKjkEHPb2q3pLOl2vICE4INdSMmjaTrU8bFc 449ajZdjkYxjrUka5PSmtAZT1iEy2m4D7vNZlhKfN+duvUmt66hEkLR8HIrmjuglIAIKn0ptiJp4 /KkK9u1JHwQc1blIurcSRgbl7CqIODWbKRev8PFHJ2C4rLjfZIM9Aa0QTLatF36rWWQMdMN3ouJH o/g7xrFo+iarpc1pbzx30JjSZ/vQZ649jWebiVbYwafdXEVsxzsjkOwn6VwyyvEQY2xir9rqkcal lV4Zf+mbYB/CuerSvsdEKtkeoeBbe7Yz6he3U7WNsBG8DuSJt3G3njGMn8K2NZl0y8mFhBfwPN1j CsCy4HQ9s4H6V5Wvji+TSZdOWKAQyOGd1BDED9K2fCXiLSYtQt3uCLZRlSZBwMgjr+NcM8NNPmR0 KtFqzNnUbC+inaa2Ki4P31PRz03D/Cqpk1J3BmsYY2UgvJLkKcDuM1wXibUDda/d3FpcM0W7ajqS MgUy51TUL6xitbi6eSFDlVYc/nXfB1OVXOSSjfQ7W718Waf2folw13qtyv2c3KjiNSfup+de7eBN ETw94asdPA+dF3SH1c8mvL/gv4JjiVde1CIl/wDl2Rh0/wBr/CvaYmyeleNmOK537NbI7cNRsrmt pqbrlR6Gu409MRVx+gx7pNxFdpaACIciqy+OlycQ9bGra/6halNRW3+pXFSmvahscT3CiiimIKKK KACiiigAooooAKKKKACiiigAooooAKKKKADtUVxKIUDH1xUtZ+rnECf74/kamTshxV2Bv09Kb/aC /wB2sotUZeuX2zNvZo1TqCgfdqKTUl2lSmRWUX4qN5Kl1mPkRzN9H5d1NGB8oY4+naqrYx79K0tW GLlZOzDH41nlRkioWuo9iCUEqCR7U0LgYHUVNjcpA6ikVOPpRawAucAH8KgvIBNA6EcMCDVoruQc Ubcrg00DPjvXrF9N1e9tGXaYJmTB9AeP0qijFWQknI6V6B8ZNMNl4znkVDi5VZBjvgYJ/QVwD4z7 V6ad0mcrOl3ebFFMOdygk1Kg+XI+lVdIfzdP2HGYuMe1W4lyp6cVQkL/AA96y9atFmUTxD98OGAH X3rTORxTDz1ouOxzthcfZ5gXBZe65xV25t45UEtuRz1UdqL+yBYvEB9KpwtLE2AD9KgCS34YA8Gl vLEyEyxHLHqKfE6SoWnG0/TGKniJQDbIrD3pXA5+RcZBBBHY0xE5xXSSpBMv71Bn1FSaZBpsFwGu wXj/ALoYA01roD2OXMZUbqaFzzXYa5YaW8Svplw3zZzG5Hy/j/8AWqz4T8CX+vyj7OQtuPvTkfKP x71NacaavJjhFy2ONht2kcLGpJ9BXrvw0+GUt1JDqOvRNFaj5kgYYZ/TPoK7zwj8PNI0Axzsv2u7 HPmSDhT7Cu5SvExWYuS5aex3UsNbWQW9ukaIkaBVUYUDoBVyKAFgAKZECeBWxYW2AGYCvJjScmdb lyosafAYlGAQK1o5XC4yappgcDFSoa9KinBWRxyfM7nTaWSbKIn3/mauDtVLSP8Ajwh/H+Zq6O1e 3T+FehxvcKKKK0EFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACGs/Wv8Aj2T/AHx/I1oGqGs/ 8eyf74/kaifwscdzExURHpU2OKTFcNjouVnBxUElXigIqGSEelS4hcxNVXfasR1X5hWBpi3TLP8A aSXj3ZR8YwD2rr7i3JUgDIx0rkb+5vbC4is0VntC+DjsOta0OWzTJnfRollYwEPjK5wcdqlwuAwH Hr7VIQrp0GO4pOPLxHhe1KwxyjjIppHHFJGWAxn9KQkhsU7Bc8c+P+m74NLvwM7XaJuPUZH8q8V8 s5IIxX018VdP/tDwffKq5aECVfwOf5Zr5yMQByOvvXdRd4nPNWY/RnMUxXswxWoSAcAEn0AzWVaj E8YzjLYzXZwCOFAsSgAe3NTUrcnQqnT5jIjsruU5EDKOxYYq7b6DPMczTxRewBY/0rRSQkgDk+gr RtbC+uMeTZ3De+wgVxyr1HsbKnFbmZF4WtCP3t5ck/7IUD+RrD8UaPBoyQyxzPNE7bSWAyp6jpXo tv4a1WZcsiwp/tNzUHi7wbdN4Wvn82FnhTzQoBJO3n+VTSlV5ld6BJQtoeQyNFMmAwPpzUS27Doy 1CAPSrtpGJoZUBww+YV6djluReSyj7w596Y8CMcyvn6VZFuGQPuUjOAAeaYY9jbSCMevFRqUW/Dx toNZsTNaxyW5nUSK/QqTg19N2kcUECxQIkUSjCqowAK+W0BGCDgivqPwPJDqukWU8uWLwK3B745r ycxpNtHVhpWuXIzxV+1tJJTwMD1NaNtaRITsjUEVdRcDiuBYfudDqEVrZpCATyavJxUYFPUVtGCW xm5XJEPFSKajUU4CtbEXOp0b/kHw/j/M1e7VR0b/AJB8P4/zNXu1etT+BehyvcKKKK0EFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFAAO1Z2s/8eyf74/ka0R2rO1n/j3j/wB8fyNRP4WUtzHyD2o4 BoApa5EbCYFIRxS0lOwhpXjGKzdU0uK9UMDsmX7rD+RrTNJilYRxjpJbymGdNjjp6EeoppQEEYrr 7u0iu4fLmQEdj3H0rnLyxmsCS2Xh7SAdPrTAgiXIwwpZUGAQDxSI2ec8VIrbiVI4oQGZqMCXNlcQ OuVkQqR9RXy1fWrW9zNCyjdE7IfwOK+m7rUxb60tjLCwjkXKy54z6EV4J8R7E2Hi+/QKAsjeauBg Yb/69ddDTQynqcxtwd4A47V3fg2yj1W+VZRmPGcVwo6EEgV3nwrm/wCJnHGcfdI/KnWjezCLsmep WtlaWahYLaKPH91RmrYI7q1PVBk8c06TCR7j+FHKRcaNvoaJ4UuLaWFx8silT9CMUsCkgnjFSKCO 1Kw0z5VvrRrO9uLaQENBIyEe4OK0PCN++k+ILO7jSFmB2/vU3AZ4zj1Fdt8WvC81vq0msWsZa0us ebgf6t8Y59jj86852GNww4INbxZm0aGpTRrqlw0QWVROxDMMbhnvj6dvWqUsrTzjK5duAqDJP4VL IxKTOUJ3EZfH3a1fCep6Xp6XwvLZmvpMLBNu/wBUuOQB7k9fYUlHmlqW3ZaGGVPYY7YI6V9B/BG4 eTw/aIR9zeg+gY14tqkEUWn2YCObqeR5s44KHAGPxDV798I9Law8P2wdcEJzx3Y5NcOOjay8zWg7 6neoSAOMVOAcU1QCuMU9SFADHrxXDY3FGQKkXNIAKepA9BRygKoqQDHc00U8UJAdNo3/ACD4fx/m avDpVHRv+QfD+P8AM1eHSvUp/CvQ5pbhRRRWggoopGOKAFophcKMkgVUW9MxdbaJpdpwSOB+tAF6 is/7Xc+Zs+xyZxnqMfnnFTW9yZHKPGY5AM7TQBaooooAKKKKACiiigAooooAQVR1f/j3T/f/AKGr wqjq/wDx7p/v/wBDUT+FjW5kYNJinUmK5ToGUYp+KTA7UCsMxSc04ikxSuKwLmgqHUgjIPUGk6UZ IFNMLHO6lo0luWmssvHnJh7j6f4Vl+YDhkY5BwR6V224+lZWraPHfHzIWENx/eA4b2NUI5rUIbN7 Q3F4uWg+Ye4//WBXinxis9+o2eqwoRBcxAbscAjtmvZ9TQx5s72PbvG3no30Ned/Fizt4PCVlAqt uglAiJP1zn8K6YVNFFmUoa3R4rt4rqvhu5j8R2aggbmIx+H/ANasGC2eWRYkUl26KoyT9AK9A8B+ D9SXVba9ubZ7a3hO/MnDOcYAA7de9U30Elbc9WRDg8fpT9m7BPPpUT28u3GX/Oo1trgOGDP9M1eh kWh8q8AcdqaZtvUCoZ7adxkbgc8YNRfZJ8c7jz61N0XYkubgGJk8pHBGCrcg15/4i8DWWplprONb Kc/woMofw7fhXeC1mIxj8KEsnJzjmqTijNxkfPWu+HdU0hWSeJzaZyXQkpx6/wBM1z0a+a48tQ7H oBzX1ZHppY8g1LZaNb28nmRWsEb5zuVADUyqRKjFnlfgHwLqOralDq2rxi2hQDy02beAMDA9q90s LZLS1jgiHyqMfWo4UZVAAB+tTlLloyIngRuxKlsfyrhqe87s6o6KxaQ8VKRuQqeKhiWUAbvKPHYG rEee4H4Vi0XcegwP604Ck2nHApyg1NgQ5c4pVzSYOOOKcAQOSKVhnTaId2mwnBHXg/U1fHSqOjca fD+P8zV4dK9Kn8K9DmluFFFFaCCqWr3DWti8qD5hV2q99CJ7Z4yOCKAKclpbRQ7764Lg4+Z32r+G KZcuzWCHRjGiGT5pBhQo79fwqvbN5mnGKQZmsm791/8A1Z/KoVSFy9y8BmPm+XFAo4ZsZyfw/lQB IL+WLT2ijvFuLrOQ6LkKPr0NXopTKLK4IGZE2uR6+n86jERCql79ghQniELyB7Nkc/hSrB9jstjk FUnzDz1B/wD1mgDWooooAKKKKACiiigAooooAQVQ1j/j2T/f/oaviqGsf8eyf7/9DUT+FjW5krR+ NAUDFNrkOgcvSimjgYpR0oAD6Un8NOpABQA3jFGBTtopFoAbtGOtG2nLSUByoq31pHdwmOaNXU9i K4bxH4DttUWKOYTPAjblj8wgA16LgbajI6CmqjhsQ4JnA6P4OttMXFlaW9t6lRyfqetbkWlFACzD 8BW6UX0ppUYodaTBUkjJewXHSmGyUc1sGNfSmsoA6VDk2acqMf7GMdBTTZAitny154pFUelHOxci MX7CM5xTvsQB6Vq7RjpSKBS52HIjOW0GM4qVLUdMVoMoGMCnbQBwKOdhyopJbKMcVMkAHarCqMdK ftGRSbBIgWHiniMelToBTsDH4UAQ+XS+XipgBS4GaAIfLpwSpcDFG0UWA3NKGLGIfX+Zq6O1U9M/ 484vx/nVwdq74fCvQ53uFFFFWIKRqWkagDEvAbHU4rpeIX+ST2HrVizihsTJALpd0zExqSMjjjHr Wgyq64YAiqosbVkKfZ4wp6gLigDNGlTmJlkSAM3+slZixPvU1oiXE0Kwgm1tl2xk/wAR9f8APvVh 7C3CqGDyL/dkkZl/InFXVUIFVQAPQUAf/9k= ________________________________________________________________________________
Subject: Re: Lycoming O 540 starter
Date: Nov 02, 2005
Can any of the group tell me if it is possible or if they have heard of any one that is considering a turbo Lycoming engine installation for RV 10 ? Paul Walter ----- Original Message ----- From: ddddsp1(at)juno.com To: rv10-list(at)matronics.com Sent: Wednesday, November 02, 2005 1:20 PM Subject: RV10-List: Lycoming O 540 starter I ran across this the other night on Ebay. Anyone seen these before? Appears to be equal to the Sky-tec HT model for $255. Anyone used these versus the other starters? Textron - Lycoming Starter Fits all engines up to .0540 1.4 kW gear reduction AIR-BOAT starter. 1 Year Warranty! 2 times stronger than the original!! 10 Lbs. Less! Starter weighs 9 lbs! All bearings no bushings! VERY STRONG AND SUPER LIGHT This is a direct replacement for the original unit. Will fit up to 540 Textron Lycoming Engines! May be used for Experimental Aircraft. (non-certified) This is for the 149 tooth flywheel. ________________________________________________________________________________
Subject: Frapper map
Date: Nov 02, 2005
Hello all. How do you edit your info on the map? Thanks. Rob. ________________________________________________________________________________
Subject: Cargo tiedown
Date: Nov 01, 2005
Group: Has anyone installed any cargo tiedown rings in the baggage area? Any recommendations on a type or a source? TDT ________________________________
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: Placards/Nameplate Tim, Here is a checklist that a local DAR uses as published by EAA Chapter 670. Might come in handy. http://www.aerovents.com/eaa670/eaabldrcklst.htm Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Placards/Nameplate I was thinking that on my next order from ACS, I'd get whatever logbooks and placards I'll need. I see on this page of ACS's catalog they have a nameplate, and stainless steel ID tag on the top of the page. http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf I need both of these, right? I've seen the black on the side under the HS on -10's. Where would the nameplate go? Tim RV10-List Email Forum - more: bsp; ________________________________________________________________________________
Subject: Placards/Nameplate
Date: Nov 01, 2005
Group: Did we discuss before what the meaning of "cruise speed" is, vis-=E0-vis if you need 12 inch N-numbers or 3-inch? The FAR doesn't say MAX speed - just "cruise speed". It would be close, anyway. I think I've seen -10's with both 12 and 3 inch numbers. TDT 40025 ________________________________
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Subject: Columbia, SC
Date: Nov 02, 2005
Is anybody on the list in Columbia, SC? We are flying in there tomorrow and are looking for a place to put the -10 in the shade, whether a hangar, T-hangar or shade hangar. If anybody is there or knows somebody there (KCAE preferably), please let us know. Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Nov 02, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
We are definitely on the line with that little rule. Van's top speed of 211mph is 183.353987 knots and 75% cruise is 201mph or 174.664225 knots. Probably could get away with three inch but you need 12 inch anyway if you leave the country. Michael Sausen -10 #352 waiting on fuselage ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Subject: RE: RV10-List: Placards/Nameplate Group: Did we discuss before what the meaning of "cruise speed" is, vis-=E0-vis if you need 12 inch N-numbers or 3-inch? The FAR doesn't say MAX speed - just "cruise speed". It would be close, anyway. I think I've seen -10's with both 12 and 3 inch numbers. TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: Placards/Nameplate Tim, Here is a checklist that a local DAR uses as published by EAA Chapter 670. Might come in handy. http://www.aerovents.com/eaa670/eaabldrcklst.htm Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Placards/Nameplate I was thinking that on my next order from ACS, I'd get whatever logbooks and placards I'll need. I see on this page of ACS's catalog they have a nameplate, and stainless steel ID tag on the top of the page. http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf I need both of these, right? I've seen the black on the side under the HS on -10's. Where would the nameplate go? Tim RV10-List Email Forum - more: bsp; ________________________________________________________________________________
Subject: Possible big mistake
Date: Nov 02, 2005
Hi all! I am just finishing the rudder and was unable to get a rivet into the skin and end of the R-1004. The plans call for putting in a CCR264SS-3-2 on the other side which I can do but I can't seem to get the other side because of the limited space. I thought of trying a CCR264SS-3-2 on both sides but they are too long. Any suggestions? -----Original Message--- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RV10-List: Columbia, SC Is anybody on the list in Columbia, SC? We are flying in there tomorrow and are looking for a place to put the -10 in the shade, whether a hangar, T-hangar or shade hangar. If anybody is there or knows somebody there (KCAE preferably), please let us know. Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Nov 02, 2005
Given that Van's published 75% cruise speed is 175kts at 2200lbs and 171 at 2700 with the 260 hp engine, unless you find some significant speed tweaks, you aren't going to exceed 180kts CAS in cruise. But as Tim mentions, there are considerations besides just going with the minimum. Tim Dawson-Townsend said: > Group: > > > Did we discuss before what the meaning of "cruise speed" is, vis--vis if > you need 12 inch N-numbers or 3-inch? The FAR doesn't say MAX speed - > just "cruise speed". It would be close, anyway. I think I've seen -10's > with both 12 and 3 inch numbers. > > > TDT > > 40025 ________________________________________________________________________________
Date: Nov 02, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Note: You don't need 12 inch for Canada. But then, that's not really a different country . . . : ) I like 3 inch "just because I can" - another way to set yourself apart from the certified "spam cans" . . . TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of RV Builder (Michael Sausen) Subject: RE: RV10-List: Placards/Nameplate We are definitely on the line with that little rule. Van's top speed of 211mph is 183.353987 knots and 75% cruise is 201mph or 174.664225 knots. Probably could get away with three inch but you need 12 inch anyway if you leave the country. Michael Sausen -10 #352 waiting on fuselage ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Subject: RE: RV10-List: Placards/Nameplate Group: Did we discuss before what the meaning of "cruise speed" is, vis-=E0-vis if you need 12 inch N-numbers or 3-inch? The FAR doesn't say MAX speed - just "cruise speed". It would be close, anyway. I think I've seen -10's with both 12 and 3 inch numbers. TDT 40025 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Subject: RE: RV10-List: Placards/Nameplate Tim, Here is a checklist that a local DAR uses as published by EAA Chapter 670. Might come in handy. http://www.aerovents.com/eaa670/eaabldrcklst.htm Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Subject: RV10-List: Placards/Nameplate I was thinking that on my next order from ACS, I'd get whatever logbooks and placards I'll need. I see on this page of ACS's catalog they have a nameplate, and stainless steel ID tag on the top of the page. http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf I need both of these, right? I've seen the black on the side under the HS on -10's. Where would the nameplate go? Tim RV10-List Email Forum - more: bsp; ________________________________________________________________________________
Date: Nov 02, 2005
A picture would help, but in absence, are you saying that you have no room to get a bucking bar in there? If this is the case for the solid rivet, have you tried to grind down an old cold chisel? Also with the stainless steel blind rivets, you can put one in, bottom it out, then pull up just enough to give you some more room, then push in again, etc. John Jessen 328 HS & Elevators _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Hunter Subject: RV10-List: Possible big mistake Hi all! I am just finishing the rudder and was unable to get a rivet into the skin and end of the R-1004. The plans call for putting in a CCR264SS-3-2 on the other side which I can do but I can't seem to get the other side because of the limited space. I thought of trying a CCR264SS-3-2 on both sides but they are too long. Any suggestions? -----Original Message--- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RV10-List: Columbia, SC Is anybody on the list in Columbia, SC? We are flying in there tomorrow and are looking for a place to put the -10 in the shade, whether a hangar, T-hangar or shade hangar. If anybody is there or knows somebody there (KCAE preferably), please let us know. Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Nov 02, 2005
Subject: Re: Columbia, SC
Call me after 11:30 AM today. I have a plane based at KCAE. James 803-238-2113 On 11/2/05, Jesse Saint wrote: > > Is anybody on the list in Columbia, SC? We are flying in there tomorrow > and are looking for a place to put the -10 in the shade, whether a hangar, > T-hangar or shade hangar. If anybody is there or knows somebody there (KCAE > preferably), please let us know. > > Thanks. > > Jesse Saint > > I-TEC, Inc. > > jesse(at)itecusa.org > > www.itecusa.org <http://www.itecusa.org/> > > W: 352-465-4545 > > C: 352-427-0285 > > F: 815-377-3694 > > -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
Subject: Louisville, KY
Date: Nov 02, 2005
Thanks, James, for your help. Our plane will also be in Louisville, KY from Monday through the following Monday. Does anybody have an empty hangar up in that area that we could park in? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Nov 02, 2005
Subject: Electric Aileron Trim #8 Screw Dimples
I am installing you Electric Aileron Trim in my RV-10 On page OP38-4 Step 4 the instructions have me dimple the wing access plate for #8 flush-head screws. I cannot find in the instructions a step to dimple the aileron trim actuation assembly. Are these #19 holes to be left un-dimpled? Is the assembly to sit only on the dimples in the access plate, because that is what will happen if the holes on the assembly are not dimpled. The response from Ken Scott at Vans is Good catch. We've added a line to Step 4 specifying that #19 holes in the Actuation Assembly should be dimpled for a #8 screw. Larry Rosen #40356 ________________________________________________________________________________
Date: Nov 02, 2005
Subject: TruTrak Roll Servo Update
TruTrak has modified the installation of the Roll Servo for the 10. Instead of the push-rod connecting to the bell crank, there is a bracket that attaches to the bell crank, and then the push-rod connects to the bracket. The new push rod is shorter. Also, you will need an AN3-15A bolt. According to TruTrak this modification was made to improve the torque characteristics of the servo. Fortunately, if you installed the servo the old way, the new bracket will utilize the hold you already drilled in the bellcrank assembly. Attached is a photo of the new installation. Larry Rosen #356 Installing roll servo ________________________________________________________________________________
Subject: Lasar Ignition Horror Story
Date: Nov 02, 2005
Listers: If you own or are considering the Lasar Ignition System for your airplane, read this and beware. Lasar Ignition came on my new Lycoming Engine from the factory. A screw on the distributor cap backed out of my left magneto and it took 364 hours of working back and forth to destroy the magneto. Unisons service manual doesn't even have you look at the points until 500 hours. After sending him pictures of the Magneto, the Service Representative at Unison said that it was beyond the warranty period and couldn't possibility be a manufacturing defect and they wouldn't pay for anything. This all started with a 300+ mag drop on the Left Magneto. While looking for the cause of the Mag drop, I removed the ignition lead caps and found the left magneto distributor cap moving up and down. Danny King and I took the magneto apart and found that one of the screws on the distributor had backed out and had been working in the hole in the case. There was plastic, carbon, and aluminum dust all over in the magneto. Lessons learned: Unison doesn't stand behind their top of the line Ignition System. None of their dealers stock the 4771 magneto meaning minimum of 3 weeks to get one. The only way you can get one sooner is say A.O.G. and the distributor can have it drop shipped from the factory overnight for another $45. Aircraft Spruce had the lowest price of $601 plus $150 core charge. I have bought my last Unison Product. If anything else goes wrong with the Lasar system, I will remove it from the airplane and install P-Mags. A P-Mag system is less than half the cost of the Lasar system and being a new company, I'll bet you they would be very interested in a premature failure of one of their components. Ron Grover ________________________________________________________________________________
Date: Nov 02, 2005
Subject: Re: TruTrak Roll Servo Update
I'm assuming that those of us who have the "old" hardware and have yet to install can request the "new" hardware? -Sean #40303 (top wing skins) Larry Rosen wrote: > TruTrak has modified the installation of the Roll Servo for the 10. > Instead of the push-rod connecting to the bell crank, there is a > bracket that attaches to the bell crank, and then the push-rod > connects to the bracket. The new push rod is shorter. Also, you will > need an AN3-15A bolt. According to TruTrak this modification was made > to improve the torque characteristics of the servo. Fortunately, if > you installed the servo the old way, the new bracket will utilize the > hold you already drilled in the bellcrank assembly. Attached is a > photo of the new installation. > > Larry Rosen > #356 > Installing roll servo > > ________________________________________________________________________________
Date: Nov 02, 2005
Yes, dimple the bracket. As you progress through the chapters, Van's stops telling you to do some things and they assume you will know what to do. Cut's back on the wording but it makes you spend more time wondering if you are forgetting something. BTW, those springs are a pain in the arse to attach. Just did it myself last weekend. Enjoy! Michael Sausen -10 #352 waiting on fuselage/odds and ends -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Subject: RV10-List: Electric Aileron Trim #8 Screw Dimples I am installing you Electric Aileron Trim in my RV-10 On page OP38-4 Step 4 the instructions have me dimple the wing access plate for #8 flush-head screws. I cannot find in the instructions a step to dimple the aileron trim actuation assembly. Are these #19 holes to be left un-dimpled? Is the assembly to sit only on the dimples in the access plate, because that is what will happen if the holes on the assembly are not dimpled. The response from Ken Scott at Vans is Good catch. We've added a line to Step 4 specifying that #19 holes in the Actuation Assembly should be dimpled for a #8 screw. Larry Rosen #40356 ________________________________________________________________________________
Date: Nov 02, 2005
Hey, Jesse, have you guys ordered a canopy cover for your airplane? : ) TDT ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Jesse Saint Subject: RV10-List: Louisville, KY Thanks, James, for your help. Our plane will also be in Louisville, KY from Monday through the following Monday. Does anybody have an empty hangar up in that area that we could park in? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Nov 02, 2005
We have a customer using two LASARs on a Lancair 320. A few months ago, with 120 hours on the mags, he reported a similar mag drop. He did the troubleshooting and isolated the mechanical mag. A brief inspection did not show any problems--points looked OK, all wires intact. He returned the mag to Unison and waited for 2 months. They eventually replaced the mag free of charge but would not tell us what was wrong. They were nice enough about it, but it did take a long time, and it did fail suddenly at 120 hours. The system is bulky and heavy, and it requires special tools to use. What is the advantage to a more efficient engine when it's down for months at a time? I'd have a hard time recommending LASAR even over standard mags. Dave Saylor AirCrafters LLC 831-722-9141 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ronald Grover Subject: RV10-List: Lasar Ignition Horror Story Listers: If you own or are considering the Lasar Ignition System for your airplane, read this and beware. Lasar Ignition came on my new Lycoming Engine from the factory. A screw on the distributor cap backed out of my left magneto and it took 364 hours of working back and forth to destroy the magneto. Unisons service manual doesn't even have you look at the points until 500 hours. After sending him pictures of the Magneto, the Service Representative at Unison said that it was beyond the warranty period and couldn't possibility be a manufacturing defect and they wouldn't pay for anything. This all started with a 300+ mag drop on the Left Magneto. While looking for the cause of the Mag drop, I removed the ignition lead caps and found the left magneto distributor cap moving up and down. Danny King and I took the magneto apart and found that one of the screws on the distributor had backed out and had been working in the hole in the case. There was plastic, carbon, and aluminum dust all over in the magneto. Lessons learned: Unison doesn't stand behind their top of the line Ignition System. None of their dealers stock the 4771 magneto meaning minimum of 3 weeks to get one. The only way you can get one sooner is say A.O.G. and the distributor can have it drop shipped from the factory overnight for another $45. Aircraft Spruce had the lowest price of $601 plus $150 core charge. I have bought my last Unison Product. If anything else goes wrong with the Lasar system, I will remove it from the airplane and install P-Mags. A P-Mag system is less than half the cost of the Lasar system and being a new company, I'll bet you they would be very interested in a premature failure of one of their components. Ron Grover ________________________________________________________________________________
Subject: Vapor return for mechanical fuel injection
Date: Nov 02, 2005
Do you have your heat boxes that fit on the firewall yet? Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick Subject: RE: RV10-List: Vapor return for mechanical fuel injection Randy, Please explain why when the heat controls are turned off the unused heat is dumped around the fuel pump Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 ________________________________ From: Randy DeBauw [mailto:Randy(at)abros.com] Subject: RE: RV10-List: Vapor return for mechanical fuel injection Well let me tell you about one instance of my fuel system starting to vapor lock. It was a hot day this summer, about 96 deg. I was climbing out at about 1000 fpm from 150ft airport elev. to 9000ft. when I was passing through 5000ft I noticed the fuel pressure dropping from its normal 19 to 21 psi to around 17.5. I turned on the fuel pump and the pressure went to 28 psi. I lowered the nose and left the fuel pump on for 5 min or so. Lowering the nose did the trick. Turned the fuel pump off and the pressures were fine. I have a 1" scat tube running to the fuel pump to cool it. Remember that with the heater controls turned off that the unused heated air is dumped right around the fuel pump. I have had no issues starting the engine when hot - 100 plus deg. The trick is to leave the mix full lean and start cranking. After 5 revs or so if it isn't running already start bleeding in some fuel with the mix. Starts every time. 102 hours and counting. I am working on my IFR ticket for the next few months. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: Vapor return for mechanical fuel injection Vapor lock is NOT just a startup problem. The following is an NTSB report from a crash near where my parents live. The pilot and passengers were not hurt, and although it sounds like he did everything right vapor lock still bit him. -Jim 40384 NTSB Number: CHI04CA210 Narrative Type: NTSB FINAL NARRATIVE (6120.4) The airplane was destroyed during a post-impact ground fire, following a loss of engine power and subsequent forced landing. The pilot reported he had landed and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The airplane experienced a loss of engine power while on the second takeoff attempt. The pilot stated he maneuvered the airplane to land on a nearby road and it impacted a road sign prior to coming to stop. An on-ground fire engulfed the airplane shortly thereafter. There were no anomalies noted with the engine during a post-accident operational test. The outside temperature at the time of the accident was approximately 28 degrees Celsius. A condition known as vapor lock can occur when engine heats the fuel lines and the contained fuel becomes a vapor. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. The fuel vapor can result in partial or complete interruption of fuel flow to the engine. Narrative Type: NTSB PRELIMINARY NARRATIVE (6120.19) On July 31, 2004, at 1519 eastern daylight time, a Piper PA-28RT-201T, N77782, piloted by a private pilot, was destroyed during a post-impact ground fire following a loss of engine power and subsequent forced landing near Plymouth, Michigan. The airplane experienced the loss of engine power while on initial climb from runway 18 (2,556 feet by 75 feet, dry asphalt) at the Canton-Plymouth-Mettetal Airport (1DS). Visual meteorological conditions prevailed at the time of the accident. The personal flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The pilot and one passenger were not injured. One passenger reported minor injuries. The local area flight was originating at the time of the accident. The pilot reported he had landed at 1500 and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of 100 low-lead aviation fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The pilot reported he taxied onto runway 18 and set the engine power to 2,500 rpm and 38 inches of manifold pressure. The pilot stated the airplane became airborne and experienced a loss of engine power while on initial climb. The pilot reported he switched fuel tanks, but there was no increase in engine power. The pilot stated the airplane descended under some power lines as he maneuvered the airplane to land on a nearby road. The pilot reported the airplane impacted a road sign prior to coming to stop and an on-ground fire engulfed the airplane shortly thereafter. Federal Aviation Administration (FAA) inspectors performed the on-site investigation. The engine was removed from the accident airplane and mounted on a compatible airframe for an operational engine test. The engine started and idled without anomalies. The engine was then accelerated to 2,200 rpm which yielded approximately 80 lbs of oil pressure. The engine was then shut-off using the mixture idle cut-off. There were no anomalies noted with the engine during the operational test. The closest weather reporting station to the accident site was located at the Willow Run Airport (YIP), Detroit, Michigan, about 7.4 nautical miles (nm) southeast of the accident site. The airport is equipped with an Automated Surface Observing System (ASOS). The following weather conditions were reported prior to and at the time of the accident: At 1453 edt: Wind 230 degrees at 11 knots, visibility unrestricted at 10 statute miles (sm), few clouds at 5,000 feet above ground level (agl), temperature 28 degrees Celsius, dew point -01 degrees Celsius, altimeter setting 29.90 inches-of-mercury. According to FAA publication AC 65-12A, fuel normally remains in a liquid state until it is discharged into the air stream and changes into a vapor. Under certain conditions the fuel may vaporize in the lines, pumps, or other fuel components. The vapor pockets formed by the premature vaporization can restrict the fuel flow through units that were designed to handle liquids rather than gases. The resulting partial or complete interruption of the fuel flow is called vapor lock. Transfer of heat from the engine tends to cause vaporization of fuel in the lines and the pump. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. Vapor lock can become serious enough to block the fuel flow completely and stop the engine. Even small amounts of vapor in the inlet line can restrict the fuel flow to the engine driven pump and ultimately reduce its output pressure. Narrative Type: NTSB PROBABLE CAUSE NARRATIVE The loss of engine power at a low altitude due to a fuel flow restriction caused by vapor lock. Factors to the accident included the high atmospheric temperature and the road sign that the airplane impacted during the forced landing. Jesse Saint wrote: I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: It does, I did not realize there is a valve that is opened and closed. That makes more sense. I have not flown behind an IO engine, just standard. Now maybe you can explain to me, is it like in an auto, where there is allot more fuel going to the rail then is used, causing a return line to be necessary? or does it only pump what is required/ used? I thought fuel injection meant a looped system, where only the portion of fuel that went to the injectors was used and the rest sent back to the tank? _____ ________________________________________________________________________________
Date: Nov 02, 2005
That is correct Jesse. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Subject: RE: RV10-List: Vapor return for mechanical fuel injection He must mean the fuel pump mounted on the engine. That is where the heated air is dumped when the cabin heat is turned off. It goes right into the engine compartment below the mags and right by the fuel pump. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org <http://www.itecusa.org/> W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick Subject: RE: RV10-List: Vapor return for mechanical fuel injection Randy, Please explain why when the heat controls are turned off the unused heat is dumped around the fuel pump Thank You Rick Conti office: 703-414-6141 cell: 571-215-6134 ________________________________ From: Randy DeBauw [mailto:Randy(at)abros.com] Subject: RE: RV10-List: Vapor return for mechanical fuel injection Well let me tell you about one instance of my fuel system starting to vapor lock. It was a hot day this summer, about 96 deg. I was climbing out at about 1000 fpm from 150ft airport elev. to 9000ft. when I was passing through 5000ft I noticed the fuel pressure dropping from its normal 19 to 21 psi to around 17.5. I turned on the fuel pump and the pressure went to 28 psi. I lowered the nose and left the fuel pump on for 5 min or so. Lowering the nose did the trick. Turned the fuel pump off and the pressures were fine. I have a 1" scat tube running to the fuel pump to cool it. Remember that with the heater controls turned off that the unused heated air is dumped right around the fuel pump. I have had no issues starting the engine when hot - 100 plus deg. The trick is to leave the mix full lean and start cranking. After 5 revs or so if it isn't running already start bleeding in some fuel with the mix. Starts every time. 102 hours and counting. I am working on my IFR ticket for the next few months. Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James Hein Subject: Re: RV10-List: Vapor return for mechanical fuel injection Vapor lock is NOT just a startup problem. The following is an NTSB report from a crash near where my parents live. The pilot and passengers were not hurt, and although it sounds like he did everything right vapor lock still bit him. -Jim 40384 NTSB Number: CHI04CA210 Narrative Type: NTSB FINAL NARRATIVE (6120.4) The airplane was destroyed during a post-impact ground fire, following a loss of engine power and subsequent forced landing. The pilot reported he had landed and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The airplane experienced a loss of engine power while on the second takeoff attempt. The pilot stated he maneuvered the airplane to land on a nearby road and it impacted a road sign prior to coming to stop. An on-ground fire engulfed the airplane shortly thereafter. There were no anomalies noted with the engine during a post-accident operational test. The outside temperature at the time of the accident was approximately 28 degrees Celsius. A condition known as vapor lock can occur when engine heats the fuel lines and the contained fuel becomes a vapor. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. The fuel vapor can result in partial or complete interruption of fuel flow to the engine. Narrative Type: NTSB PRELIMINARY NARRATIVE (6120.19) On July 31, 2004, at 1519 eastern daylight time, a Piper PA-28RT-201T, N77782, piloted by a private pilot, was destroyed during a post-impact ground fire following a loss of engine power and subsequent forced landing near Plymouth, Michigan. The airplane experienced the loss of engine power while on initial climb from runway 18 (2,556 feet by 75 feet, dry asphalt) at the Canton-Plymouth-Mettetal Airport (1DS). Visual meteorological conditions prevailed at the time of the accident. The personal flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The pilot and one passenger were not injured. One passenger reported minor injuries. The local area flight was originating at the time of the accident. The pilot reported he had landed at 1500 and shut down the engine for a few minutes prior to loading his two passengers for a local flight. The pilot stated the airplane contained 35 gallons of 100 low-lead aviation fuel prior to the accident flight. The pilot reported the engine "shuddered" during takeoff roll and he aborted the takeoff. The pilot stated he then performed an engine run-up check and the engine "felt fine." The pilot reported he taxied onto runway 18 and set the engine power to 2,500 rpm and 38 inches of manifold pressure. The pilot stated the airplane became airborne and experienced a loss of engine power while on initial climb. The pilot reported he switched fuel tanks, but there was no increase in engine power. The pilot stated the airplane descended under some power lines as he maneuvered the airplane to land on a nearby road. The pilot reported the airplane impacted a road sign prior to coming to stop and an on-ground fire engulfed the airplane shortly thereafter. Federal Aviation Administration (FAA) inspectors performed the on-site investigation. The engine was removed from the accident airplane and mounted on a compatible airframe for an operational engine test. The engine started and idled without anomalies. The engine was then accelerated to 2,200 rpm which yielded approximately 80 lbs of oil pressure. The engine was then shut-off using the mixture idle cut-off. There were no anomalies noted with the engine during the operational test. The closest weather reporting station to the accident site was located at the Willow Run Airport (YIP), Detroit, Michigan, about 7.4 nautical miles (nm) southeast of the accident site. The airport is equipped with an Automated Surface Observing System (ASOS). The following weather conditions were reported prior to and at the time of the accident: At 1453 edt: Wind 230 degrees at 11 knots, visibility unrestricted at 10 statute miles (sm), few clouds at 5,000 feet above ground level (agl), temperature 28 degrees Celsius, dew point -01 degrees Celsius, altimeter setting 29.90 inches-of-mercury. According to FAA publication AC 65-12A, fuel normally remains in a liquid state until it is discharged into the air stream and changes into a vapor. Under certain conditions the fuel may vaporize in the lines, pumps, or other fuel components. The vapor pockets formed by the premature vaporization can restrict the fuel flow through units that were designed to handle liquids rather than gases. The resulting partial or complete interruption of the fuel flow is called vapor lock. Transfer of heat from the engine tends to cause vaporization of fuel in the lines and the pump. This tendency is increased if the fuel in the tank is warm, commonly as a result of high atmospheric temperatures. Vapor lock can become serious enough to block the fuel flow completely and stop the engine. Even small amounts of vapor in the inlet line can restrict the fuel flow to the engine driven pump and ultimately reduce its output pressure. Narrative Type: NTSB PROBABLE CAUSE NARRATIVE The loss of engine power at a low altitude due to a fuel flow restriction caused by vapor lock. Factors to the accident included the high atmospheric temperature and the road sign that the airplane impacted during the forced landing. Jesse Saint wrote: I am a little confused as well. We have a Bendix injection system. We haven't put a return line in. We do have an overflow line that just runs out the back of the cowling. The system can't be pumping much more fuel that it is using or our fuel flows would be higher. When burning 6.5-7gph @ 17,500, I can't imagine that we are actually burning less than that and wasting a significant amount. Is the main issue here vapor lock? Would this system not work the same way whether you have a return line or an overflow drain line? Running the boost pump is going to do the same thing any, right. I am not much of an engine guy, so please let me know where I am wrong. Also, if vapor lock mainly a startup issue, or are we needing to worry about this while we are flying? We certainly haven't had any issues with the system during our 150 hours in the air, but if it is an accident waiting to happen, it doesn't matter how many hours we have flown the wrong way, we want to fix it. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: RE: RV10-List: Vapor return for mechanical fuel injection It depends on the brand fuel injection used. TCM and Bendix do not use a common rail, they send fuel to a distributor that sends it to individual injectors. Bendix regulates the fuel flow at the fuel servo, and only fuel needed goes to the distributor and injectors. Fuel pumps are self limiting, returning excess pressure to their low pressure side. TCM (Continental) is different, and does use a return loop. I don't know what aftermarket systems use. There isn't much in common between aircraft injection systems and auto systems. Aircraft still use continuous injection, most cars use individual timed injection for better emissions control. Aircraft distributors are pressure controled, so when pressure drops below a preset minimum, no fuel goes to the injectors, allowing idle cutoff. Lloyd, Daniel R. said: It does, I did not realize there is a valve that is opened and closed. That makes more sense. I have not flown behind an IO engine, just standard. Now maybe you can explain to me, is it like in an auto, where there is allot more fuel going to the rail then is used, causing a return line to be necessary? or does it only pump what is required/ used? I thought fuel injection meant a looped system, where only the portion of fuel that went to the injectors was used and the rest sent back to the tank? _____ ________________________________________________________________________________
Date: Nov 02, 2005
> We do not have a cover yet. Did anything happen with the guy on this > list who was going to look into getting a kit put together? We would > really like to get a cover, but would still like to be in a hangar whenever possible. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F:815-377-3694 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Subject: RE: RV10-List: Louisville, KY Hey, Jesse, have you guys ordered a canopy cover for your airplane? : ) TDT From: owner-rv10-list-server(at)matronics.com on behalf of Jesse Saint Subject: RV10-List: Louisville, KY Thanks, James, for your help. Our plane will also be in Louisville, KY from Monday through the following Monday. Does anybody have an empty hangar up in that area that we could park in? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F:815-377-3694 ________________________________________________________________________________
Subject: Re: Louisville, KY
Date: Nov 02, 2005
Jesse, What dates are you talking about? I'm going to be in Louisville the 7th-13th so if you want to show off your plane let me know. No big deal though if you're too busy. -Brian Iowa City, IA Empennage ----- Original Message ----- From: Jesse Saint To: rv10-list(at)matronics.com Sent: Wednesday, November 02, 2005 10:25 AM Subject: RV10-List: Louisville, KY Thanks, James, for your help. Our plane will also be in Louisville, KY from Monday through the following Monday. Does anybody have an empty hangar up in that area that we could park in? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Nov 02, 2005
The plane will be there the 7th through the 14th. My dad will be in Louisville at a conference, but he may be interested in showing it off a little. I can give you a cell phone number for the guy that will be with
October 16, 2005 - November 02, 2005
RV10-Archive.digest.vol-at
