RV10-Archive.digest.vol-bc
April 11, 2006 - April 29, 2006
      >> 11 & 12 early is that it will speed up final assembly.  In my garage I
      > would
      >> not be able to put the tail feathers on a fuselage with the engine.  Just
      >> not enough space.
      >> Sorry not a definitive answer, but some things to think about.
      >> Larry
      >> Eric_Kallio wrote:
      >>> For those of you who have allready moved on past the emmpenage kit and
      >> maybe even flying or close to it, what is your experience on sections 11
      > and
      >> 12. I am getting ready to rivet the tailcone in the upcoming weeks. Does
      > it
      >> make sense to complete the next 2 sections fully and then take it apart
      > and
      >> keep it dis-assembled for a while, or are those sections that should wait
      >> until perhaps the finishing kit when I am assuming all the controls are
      >> rigged to the cyclic (forgive that term it is the helicopter pilot in me
      >> coming out)? Just trying to stay ahead of the game here. Thanks.
      >>> Eric
      >>> 40518 Tailcone
      >>> Read this topic online here:
      >>> http://forums.matronics.com/viewtopic.php?p=27444#27444
Subject: Rain Repellant
Date: Apr 11, 2006
Cc: "Gray, Larry E" Does anyone know the name of the wind screen rain repellant product? Thank You Rick Conti Senior Engineering Manager The Boeing Company office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 ________________________________________________________________________________
Date: Apr 11, 2006
Subject: SnF Sound absorbing material vendor
I visited the booth of SoundEx products...the fellow there offered a demo of a loud speaker in an Igloo box closed and open showing his material absorbed sound...how that noise relates to an airplane engine I don't know...but anyway I took a sample home. I placed it in a dish with water and the foam really loaded up pretty quickly, plus it held the water pretty well while I hung it up...seems the cells are pretty available to water and sound absorption...I think I'd be a little concerned using this material in an aircraft...plus looking at it, it looks like something I could cobble together for a whole lot less than he was charging. The aluminium material bubble cells peeled off of the white celled material when it became wet. Don't know if the piece I receive, while a very small sample, was a good sample of the work or whether the cells glue was not applied on this small sample. But holding a lot of water would concern me more than noise. Patrick ________________________________________________________________________________
Subject: sections 11 and 12
Date: Apr 11, 2006
For what it's worth, last night I took a look at all the steps through Sections 11 & 12, while having the usual sophisticated after deburring cocktail (Bud), and I found nothing that would indicate that you needed to do either section after Section 10. You could hang those puppies up and forget about them. Having said that, I feel that I will proceed with at least 11. You have momentum and familiarity at that point. There will be issues to tackle, and at this point you aren't in the throws of "get it done ittus" which might make the process all that much more difficult at a later stage. If you don't have the room, then don't do this until you move to the airport. But if you do, you might think about it. You can always take it apart after you verify that it all fits and works. Such musings are worth what you paid for them, of course. John Jessen ~328 (really getting excited and pumped up for step #4, page #15, section 10! ) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Tuesday, April 11, 2006 5:49 AM Subject: Re: RV10-List: sections 11 and 12 Rob's comments triggered a memory. Another builder tipped me off to doublecheck my clearance on the bolt holding a rod end for the trim cable. We both had minimal clearance, and if you tweaked the rotating arm just right, you could snag the bolt on the trim bracket slot's edge as it rotated through. I had to file a little extra out of the slot to give it good clearance. Everyone doublecheck that you don't have that issue or you could end up with stuck trim. It's easy to see if you just use a small battery to have the trim actuate fully in both directions, and it doesn't require the trim bracket assembly to be mounted to the tailcone. Tim Olson - RV-10 N104CD - Flying Robert G. Wright wrote: > --> > > I've just completed this part, as much as I'm going to do for a while on it. > I went all the way up until where it starts you fitting gap seal and > the emp fairing, which I don't even have yet. > > I also completed the trim mechanism/assembly, and am glad I did. It > took me a while to get the adjustments correct for full travel on the > servo. I noticed the motor would slow down and bind itself to a stop > on one extreme, yet at the other extreme it would shut itself off very > smartly. My advice on that is to once again take the initial > measurements as a starting point only, then adjust to get full range > of travel both on the servo as well as on the trim tabs. > > My heartache with this though is having to remove the trim cables and > assembly - it sure was hard to get in there! Oh well, I've already > got some small gauge wire wrapped around the ends to pull back through later. > > Rob #392 > Working on QB shipment -- it's at Vans! > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Monday, April 10, 2006 7:54 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: sections 11 and 12 > > > I don't see any problem with doing it either way. There's nothing > really in section 11&12 that's too awful dependent on the rest of the > build. I did mine after the fact, and others did it in order. I > don't think there's a problem doing it and disassembling them either, > John...it just doesn't matter much at all. I, like you and others, > don't have room to have an assembled empennage sitting around, which > is why I did it that way. One other thing... > even if you assemble it all, it'll be a heck of a lot easier to join > the tailcone to the fuselage later if you don't have all those tail > feathers attached. That doesn't mean you can't complete them, just > something to think about. I guess I'd just do whatever feels best, > and if you choose to push on to the wings, but have a hold-up of some > sort, you can always touch on those > sections while you wait. One item that may be worth finishing off > in order is just to assemble the trim mechanism though...just so you > have fewer parts laying around to lose. > > Tim Olson - RV-10 N104CD - Flying > > > > John Jessen wrote: >> >> I appreciate the advice from Larry and Randy, but being at that same > stage, >> and even having the room, I do not see what the rationale is to take >> my pieces off the walls and expose them to hanger rash if I don't have to. >> What is the "have to" rationale behind doing those two steps at this >> time, other than Larry's good point about getting them done. I'd >> rather, I > think, >> move on to the wings and have the empennage pieces safely out of the way. >> Is it okay to assemble them, then take them apart and store them, or >> is > this >> not a good thing to do? >> >> John Jessen >> ~328 (Tailcone being disassembled soon for final deburrrrrrrring) >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry >> Rosen >> Sent: Monday, April 10, 2006 5:03 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: sections 11 and 12 >> >> >> Since I was waiting on my QB wings and Fuselage I did most of >> sections >> 11 & 12, and then took it apart for storage. Ideally you would >> complete > the >> sections and keep them together, and for those working in a hanger >> they > can >> do that. It will not work in my garage. Another advantage of doing >> most > of >> 11 & 12 early is that it will speed up final assembly. In my garage >> I > would >> not be able to put the tail feathers on a fuselage with the engine. >> Just not enough space. >> >> Sorry not a definitive answer, but some things to think about. >> >> Larry >> >> Eric_Kallio wrote: >> >>> >>> For those of you who have allready moved on past the emmpenage kit >>> and >> maybe even flying or close to it, what is your experience on sections >> 11 > and >> 12. I am getting ready to rivet the tailcone in the upcoming weeks. >> Does > it >> make sense to complete the next 2 sections fully and then take it >> apart > and >> keep it dis-assembled for a while, or are those sections that should >> wait until perhaps the finishing kit when I am assuming all the >> controls are rigged to the cyclic (forgive that term it is the >> helicopter pilot in me coming out)? Just trying to stay ahead of the game here. Thanks. >>> Eric >>> 40518 Tailcone >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=27444#27444 >>> >>> >>> >>> ________________________________________________________________________________
Subject: Re: Sun-N-Fun my comments
Date: Apr 11, 2006
Larry, Did you happen to see the new bluemountain geneation 4 EFIS? If you did, I'd be interested in your impressions. It looks pretty nice on their brochure (but then what product doesn't). I doubt I'll have the cabbage to go with double Cheltons so I'm going to have to decide between GRT, BMA and AFS. -Brian #40497 N211BD Iowa City, IA ----- Original Message ----- From: "Larry Rosen" <LarryRosen(at)comcast.net> Sent: Monday, April 10, 2006 4:45 PM Subject: RV10-List: Sun-N-Fun my comments > > > Advanced Flight Systems new EFIS & Engine monitoring graphics are > outstanding. Grand Rapids better watch out. Currently the AFS system > does not have all the functionality as the GRT system, but with the better > screen it has the potential to blow away the GRT and challenge the Chelton > systems. But, this will be too late for me. ________________________________________________________________________________
Subject: Oil Cooler Installation
Date: Apr 11, 2006
BlankMy plans call for riveting the oil cooler duct assembly to the firewall. Is there a different set of plans for this installation?? Cal Hoffman ________________________________________________________________________________
Date: Apr 11, 2006
Listers, It seems to me that it wouldn't be all that difficult to incorporate one of Van's NACA scoups onto the tail fairing rather than the one they showed in the pictures. That thing looks like it would create a lot of drag. Dave Hertner #40164 Emp Done. Bal of Kit Arrives June 1 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Sent: Tuesday, April 11, 2006 1:44 PM Subject: RE: RV10-List: Sun-N-Fun my comments > > Hey all - > > Is there a way to get air into the overhead panel without putting an > inlet on the intersection fairing? Does that inlet on the fairing seem > like a bummer to anyone else? I really like the look of the overhead > panel though. What is the difference between the 3 flavors? Anyone? > > cj > #40410 > wings > www.perfectlygoodairplane.net > ________________________________________________________________________________
Subject: Sun-N-Fun my comments
Date: Apr 11, 2006
Tim - I couldn't find it on your site - do you have air vents? Where? Can you weigh in on the potential importance and/or coolness (pun) of overhead fresh air? cj #40410 wings www.perfectlygoodairplane.net -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Hertner Sent: Tuesday, April 11, 2006 11:35 AM Subject: Re: RV10-List: Sun-N-Fun my comments Listers, It seems to me that it wouldn't be all that difficult to incorporate one of Van's NACA scoups onto the tail fairing rather than the one they showed in the pictures. That thing looks like it would create a lot of drag. Dave Hertner #40164 Emp Done. Bal of Kit Arrives June 1 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Sent: Tuesday, April 11, 2006 1:44 PM Subject: RE: RV10-List: Sun-N-Fun my comments > > Hey all - > > Is there a way to get air into the overhead panel without putting an > inlet on the intersection fairing? Does that inlet on the fairing seem > like a bummer to anyone else? I really like the look of the overhead > panel though. What is the difference between the 3 flavors? Anyone? > > cj > #40410 > wings > www.perfectlygoodairplane.net > ________________________________________________________________________________
Date: Apr 11, 2006
The Lancair ES uses a similar method to provide air to the cabin. Comes in the tail and uses an overhead duct for distribution. It also have a water collection point inside the tail area with a drain tube. Some of the ES folks have installed a fan in the tubing to help with ground cooling. I think the fan is actually a bilge pump of some sort. Bobby 40116 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Hertner Sent: Tuesday, April 11, 2006 1:35 PM Subject: Re: RV10-List: Sun-N-Fun my comments Listers, It seems to me that it wouldn't be all that difficult to incorporate one of Van's NACA scoups onto the tail fairing rather than the one they showed in the pictures. That thing looks like it would create a lot of drag. Dave Hertner #40164 Emp Done. Bal of Kit Arrives June 1 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Sent: Tuesday, April 11, 2006 1:44 PM Subject: RE: RV10-List: Sun-N-Fun my comments > > Hey all - > > Is there a way to get air into the overhead panel without putting an > inlet on the intersection fairing? Does that inlet on the fairing seem > like a bummer to anyone else? I really like the look of the overhead > panel though. What is the difference between the 3 flavors? Anyone? > > cj > #40410 > wings > www.perfectlygoodairplane.net > ________________________________________________________________________________
Date: Apr 11, 2006
Subject: Overhead panel
I'd also like to see a short version. No need for front vents, but room for GPS & XM radio antennas, DVD, and lights for the back. For those flying are the current rear vents inadequate? Wiring.... Perry Casson ________________________________________________________________________________
Date: Apr 11, 2006
My 1953 D35 Bonanza has an adjustable scoop that sits on the top centerline of the plane and controlled by a cable. It also has a section inside the cabin to place a wet sponge so that when the ram air passes over the wet sponge you get a swamp cooler style air conditioner. Works great! The added bonus is that in cool temps you just close the scoop and retain the original aerodynamics. I think the image of the scoop will probably look keen when complete but I sure don't want that hanging out all the time. Robin RV-6A 300 Hours RV-10 QB On Order ________________________________________________________________________________
Date: Apr 11, 2006
From: "Fred Williams, M.D." <drfred@cox-internet.com>
Subject: Step 4 page 10-15
John; Just took my tailcone apart today. I've been dreading taking it all back apart. Now comes the part where we get the cogsdill deburring tools to do their part. I am pumped at seeing a large section getting done. I saw where one of the web sites the person spent 7 hrs priming parts. Will have to get the big spray gun out. Fred Williams 40515 ________________________________________________________________________________
Subject: Door latch covering
Date: Apr 11, 2006
I am in the process of covering my door interior surfaces with material. Does any one have any good photos that you could post or forward of how best to cover the latch mechanism area. I have looked through several builder sites and couldn't find a photo that showed good detail. Also couldn't dig up anything in the archives. My goal is a cover that could be removed for fairly easy access to the mechanism but would make the door panel look clean with out seeing the latching gears. Any suggestions appreciated. Thanks, Byron #40253 finishing kit. ________________________________________________________________________________
Subject: Twenty Nine Palms
Date: Apr 11, 2006
I am heading to Twenty Nine Palms Ca. this Friday. Is there anyone who has used that airport? Any thing I should know about it. Thanks, Randy ________________________________________________________________________________
Date: Apr 11, 2006
I did not bother looking at the bluemountain stuff. IMHO it is to experimental for my taste. Also, I am already committed to the Cheltons. GRT has almost everything you could want, but their graphics just stink. ASF has the graphics and the potential if you are willing to wait. Just think all the choices we will have when we build our next airplane. :-) Larry -------------- Original message ---------------------- From: "Brian Sponcil" <bsponcil(at)belinblank.org> > > Larry, > > Did you happen to see the new bluemountain geneation 4 EFIS? If you did, > I'd be interested in your impressions. It looks pretty nice on their > brochure (but then what product doesn't). I doubt I'll have the cabbage to > go with double Cheltons so I'm going to have to decide between GRT, BMA and > AFS. > > > -Brian > > #40497 > N211BD > Iowa City, IA > > ----- Original Message ----- > From: "Larry Rosen" <LarryRosen(at)comcast.net> > To: > Sent: Monday, April 10, 2006 4:45 PM > Subject: RV10-List: Sun-N-Fun my comments > > > > > > > > Advanced Flight Systems new EFIS & Engine monitoring graphics are > > outstanding. Grand Rapids better watch out. Currently the AFS system > > does not have all the functionality as the GRT system, but with the better > > screen it has the potential to blow away the GRT and challenge the Chelton > > systems. But, this will be too late for me. > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 11, 2006
Subject: Re: Twenty Nine Palms
Nothing special about the airport itself, I took my multiegine training nearby @ salton sea (below sea level) and we used it for some IFR approaches. Depending upon your route takes you pass through the Banning Pass, just north of Palm Springs, you can expect some bumps, particularly if late in the day or if there is any wind (very common). if you come down through the Calif inland valleys and come on the backside of mtns you will avoid that and most of the Trafic associated with the LAX and Ontario/Riverside approaches. Deems Davis # 406 Fuse http://deemsrv10.com/ Randy DeBauw wrote: > I am heading to Twenty Nine Palms Ca. this Friday. Is there anyone who > has used that airport? Any thing I should know about it. Thanks, Randy > ________________________________________________________________________________
Date: Apr 11, 2006
I flew out of there a gozillion years ago while I was stationed at the Marine Corps base.. Look out for the wind - it can whip up and sandblast an airplane in a nanosecond.....the scenery from the air is great though! Ralph Capen Master Gunnery Sergeant US Marine Corps Retired! ----- Original Message ----- From: Randy DeBauw To: rv10-list(at)matronics.com Sent: Tuesday, April 11, 2006 7:05 PM Subject: RV10-List: Twenty Nine Palms I am heading to Twenty Nine Palms Ca. this Friday. Is there anyone who has used that airport? Any thing I should know about it. Thanks, Randy ________________________________________________________________________________
From: "John Hilger" <ninepapa(at)bendbroadband.com>
Date: Apr 11, 2006
Check the wind, it can be nasty. ----- Original Message ----- From: Randy DeBauw To: rv10-list(at)matronics.com Sent: Tuesday, April 11, 2006 4:05 PM Subject: RV10-List: Twenty Nine Palms I am heading to Twenty Nine Palms Ca. this Friday. Is there anyone who has used that airport? Any thing I should know about it. Thanks, Randy ________________________________________________________________________________
Subject: planning
Date: Apr 11, 2006
Hello everyone, I was looking for a bit of advice in planning. I am looking at purchasing an RV10 QBkit next month. I am starting to do some financial planning for this purchase and I was wondering realistically what I can figure on spending to complete this project. This will be my first aircraft project and I am looking for some direction. Any thoughts or insights would be greatly appreciated. Thanks ________________________________________________________________________________
Date: Apr 11, 2006
Subject: Re: planning
As you might expect there's a wide variation based upon options that you have available to you and the decisions you make relative to those options. Some rules of thumb: 1/3 cost = kit 1/3 cost = engine & prop 1/3 cost = panel The cost of the kit itself is pretty well established, however Van does increaase his prices at the beginning of every year. There are options available for the airframe, (lighting, fuel valve, cowls,plenum, interior panels/ducts/lights that all add cost. Engine, a WIDE variation from used Lycomings (teens $K) to new Lycomings ($40k+) and then Alternative (mostly auto conversions) and then there are options that will add to this (electronic ingition, balancing, cold air induction,oil coolers, & more) Props - again options used to new 2 blade vs 3 blade, metal vs composite, cost range (4-5kused - $15k) Panel - How much money have you got? basic VFR could be done relatively inexpensively, particularly if you scrounge for used instruments, new glass IFR upwards of$40-50k + Tools - you'll buy more along the way. Then add 10-15% for stuff you didn't think about. Deems Davis # 406 Fuse http://deemsrv10.com/ sean garrison wrote: > >Hello everyone, > >I was looking for a bit of advice in planning. I am looking at purchasing an >RV10 QBkit next month. I am starting to do some financial planning for this >purchase and I was wondering realistically what I can figure on spending to >complete this project. This will be my first aircraft project and I am >looking for some direction. Any thoughts or insights would be greatly >appreciated. > >Thanks > > > > > > > > > ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: planning
Date: Apr 11, 2006
QB, I started out with planning around $100K, have gone up to 125K, and now am back down to about 110K. But this includes upgrading a lot of my original panel choices and going with a cheaper (rebuilt/overhaul) option on the engine and prop, so the price changes equalize. If I were going all new I'd probably be up to around $150K (estimated) right now. Rob #392 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of sean garrison Sent: Tuesday, April 11, 2006 8:10 PM Subject: RV10-List: planning Hello everyone, I was looking for a bit of advice in planning. I am looking at purchasing an RV10 QBkit next month. I am starting to do some financial planning for this purchase and I was wondering realistically what I can figure on spending to complete this project. This will be my first aircraft project and I am looking for some direction. Any thoughts or insights would be greatly appreciated. Thanks ________________________________________________________________________________
Date: Apr 11, 2006
Subject: Re: Flap hing bracket bearings
Rob, They are or at least they look like bronze. You should have 6 of them somewhere with your kit. They look like little bronze donuts. I used sandpaper on a drill bit and lapped the hinge bracket just a little. I used a C-Clamp and two pieces of wood to press them into the bracket, once the one dise was fluch I used a socket on one side to allow the bushing to get to it's final position, they are wider than the hinge bracket and center on the hole with equal reveal on each side. Rick S. 40185 Fuse/Finish ________________________________________________________________________________
Date: Apr 12, 2006
Subject: Re: Rain Repellant
Just beware that Pledge has a high amount of alcohol in it plus a good slug of water...it could cause your plexiglass to soften or haze...I know the Pledge trick has been used by a lot of owners but it may not be the best way to clean or keep the windscreen clean...sort of an old wives tale cure...you might contact SC Johnson--they have a phone number on each can--and ask them for their advise on using using Pledge on Plexiglass/planes to see if they've tested it long term. Patrick ________________________________________________________________________________
Date: Apr 12, 2006
From: "Schroeder, Bob (Parts Clerk)" <BSchroeder(at)uta.cog.ut.us>
Motorcycle stores and aircraft suppliers have spray plexi cleaners and polish that are readily available for your windscreens. Also, mcguires makes similar products available at auto body supply store and auto parts stores. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Wednesday, April 12, 2006 5:53 AM Subject: Re: RV10-List: Rain Repellant Just beware that Pledge has a high amount of alcohol in it plus a good slug of water...it could cause your plexiglass to soften or haze...I know the Pledge trick has been used by a lot of owners but it may not be the best way to clean or keep the windscreen clean...sort of an old wives tale cure...you might contact SC Johnson--they have a phone number on each can--and ask them for their advise on using using Pledge on Plexiglass/planes to see if they've tested it long term. Patrick ________________________________________________________________________________
Subject: RE: Zenith-List Sun-N-Fun F-22/F-15/P-51 fly by pictures
Raptor
Date: Apr 12, 2006
Cc: , Can anyone host the two Raptor pictures from last week sun-n-fun for the group ?? ________________________________________________________________________________
Subject: IFR related cockpit stuff
Date: Apr 12, 2006
Hey all - For those going/have gone the chelton route - what are anyone's thoughts about displaying/viewing things like approach plates or enroute charts? I put my deposit down on the chelton stuff the day I got back from S-N-F, and I got to thinking about it. I'm a brand new instrument rated pilot (took my checkride the day I left for S-N-F), and I'm tired of lugging around the super-heavy flight bag. I know the chelton will tell you all you need to know about the approach, and the Trutrak autopilot will fly it for you, but I like the idea of being able to see the plate on the screen, possibly with a little airplane super-imposed on it. So do you go "electronic flightbag" with a tablet computer? MX20 is a thought but is a little pricey for what little I'd be using it for. Plus, I'll be using the freeflight IFR GPS, and 2 SL30s in the panel. No garmin GPS. Has anyone with more IFR experience than me thought about this and arrived at a comfortable, yet suitably cool solution? Be gentle with me. I'm new to this stuff. cj #40410 www.perfectlygoodairplane.net ________________________________________________________________________________
Date: Apr 12, 2006
You could look into the Flight Cheetah by true flight(www.aviationsafety.com). The problem we found out on using plates with the plane superimposed is that the plates are not to scale. I think Anywhere's Pocket Plates has that option, but you have to calibrate every plate before using it. That on a pocket PC or a tablet PC would also be good. True Flight's GPS, weather and plates are really nice to have. They have some great ways of displaying info like winds aloft, echo tops, metars, etc that I have not seen elsewhere. They will calculate for you the fastest and cheapest flight level based on winds aloft over your route, fuel burn at different altitudes (you plug in fuel available at the beginning of the flight), etc. I don't know how much the weather option costs for the Chelton, but this may be an alternative, with a backup moving map as well, and the plates, of course. The updates are the cheapest I have seen for the plates and the software. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Wednesday, April 12, 2006 1:27 PM Subject: RV10-List: IFR related cockpit stuff Hey all - For those going/have gone the chelton route - what are anyone's thoughts about displaying/viewing things like approach plates or enroute charts? I put my deposit down on the chelton stuff the day I got back from S-N-F, and I got to thinking about it. I'm a brand new instrument rated pilot (took my checkride the day I left for S-N-F), and I'm tired of lugging around the super-heavy flight bag. I know the chelton will tell you all you need to know about the approach, and the Trutrak autopilot will fly it for you, but I like the idea of being able to see the plate on the screen, possibly with a little airplane super-imposed on it. So do you go "electronic flightbag" with a tablet computer? MX20 is a thought but is a little pricey for what little I'd be using it for. Plus, I'll be using the freeflight IFR GPS, and 2 SL30s in the panel. No garmin GPS. Has anyone with more IFR experience than me thought about this and arrived at a comfortable, yet suitably cool solution? Be gentle with me. I'm new to this stuff. cj #40410 www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: 540 Crank drawing or dimensions
Date: Apr 12, 2006
Does anybody have a drawing or at least detailed dimensions of the 540 parallel valve crank shaft? We have found a case to use for fitting out cowl, but haven't found a crank yet. If we could have a piece machined that would fit from the case to where we will need to measure for the cowling, that would work for us. Or, does anybody have a bad crank that they would be willing to loan, donate or sell cheaply to the cause? Thanks. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org <http://www.itecusa.org> www.itecusa.org I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545. ________________________________________________________________________________
Subject: Re: IFR related cockpit stuff
Date: Apr 12, 2006
> From: "Chris Johnston" <CJohnston(at)popsound.com> > Date: 2006/04/12 Wed PM 02:27:13 EDT > To: > Subject: RV10-List: IFR related cockpit stuff > > Has anyone with more IFR experience than me thought > about this and arrived at a comfortable, yet suitably cool solution? Be gentle with me. I'm new to this stuff. My current solution is not elegant, but seems reasonably functional. I have an approach certified GPS (GX-60) and a Jepp online subscription for updates that includes nav data for approaches (but not electronic chart views); this is about $300/yr. Before an IFR flight I print just the destination plates and a couple of plausible alternate airport's approaches if it really looks like hardball IFR, from either Airnav.com or AOPA's sites. Now, this leaves me out in the cold if I have an emergency and have to make an IFR approach to some airport along the way, but at that point, since the approach fix names are in the GPS, I figure I would just ask ATC for the crossing altitudes and MDA/DH for the approach, and the missed approach procedure. Since I'm gonna be talking to them about the emergency anyway, and they're going to be watching me closer in this circumstance, it should plausibly work out. Have had two engine failures in the past 35 years of flying, (one IFR) and both times ATC was very accommodating about working with me to find a realtime way to minimize the risks and get down safely. Just my $0.02 until the economical perfect panel arrives... -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 12, 2006
So far there have been no problems with Lancairs running NACA ducts on the vertical with rear fed overhead plenums. The other location is to cut into the aluminum on the high pressure side of the vertical. Remember that N410RV and N220RV have differing forces due to lower engine output. Ed got a lot of help from VANS on the correct location. It's a great product offering. He is going with both left and right dual NACA fed sources. John Cox - KUAO -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Tuesday, April 11, 2006 11:12 AM Subject: RE: RV10-List: Sun-N-Fun my comments Yes, it does seem like a bummer to have that air inlet there and it looks much too large for air moving at say 180mph or more. (Drag bucket) I also wonder whether the propeller swirl (P-factor)will cause some of the exhaust gasses to find there way up into that air scoop. I also wonder about moisture. The overhead does look great however. John G. #409 No not archive >From: "Chris Johnston" <CJohnston(at)popsound.com> >Reply-To: rv10-list(at)matronics.com >To: >Subject: RE: RV10-List: Sun-N-Fun my comments >Date: Tue, 11 Apr 2006 10:44:36 -0700 > > >Hey all - > >Is there a way to get air into the overhead panel without putting an >inlet on the intersection fairing? Does that inlet on the fairing seem >like a bummer to anyone else? I really like the look of the overhead >panel though. What is the difference between the 3 flavors? Anyone? > >cj >#40410 >wings >www.perfectlygoodairplane.net > ________________________________________________________________________________
Date: Apr 12, 2006
Stay well away from the leeward back burbles, the turbulence can be teeth rattling. Be mindful of correct ridgeline crossing heading and altitudes. I had a friend who was knocked out cold from a smack from both an errant mike and baggage as we ventured through the pass. Early AM is best. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Tuesday, April 11, 2006 4:29 PM Subject: Re: RV10-List: Twenty Nine Palms Nothing special about the airport itself, I took my multiegine training nearby @ salton sea (below sea level) and we used it for some IFR approaches. Depending upon your route takes you pass through the Banning Pass, just north of Palm Springs, you can expect some bumps, particularly if late in the day or if there is any wind (very common). if you come down through the Calif inland valleys and come on the backside of mtns you will avoid that and most of the Trafic associated with the LAX and Ontario/Riverside approaches. Deems Davis # 406 Fuse http://deemsrv10.com/ Randy DeBauw wrote: > I am heading to Twenty Nine Palms Ca. this Friday. Is there anyone who > has used that airport? Any thing I should know about it. Thanks, Randy > ________________________________________________________________________________
Date: Apr 12, 2006
Subject: RE: ELT Antenna
>You Chelton EFIS guys should have an Artex ELT and an >S-Tec autopilot, since they all belong to the Chelton family! Tim, This is the second time you have made this statement, so I'm compelled to inquire. All my research indicates that the Chelton Group (Artex, Chelton Avionics, Comant, NAT, etc) and Meggitt (UK) Ltd. (Meggitt Avionics, S-Tec, etc) are NOT the same company. Also, D2A is NOT part of the Chelton group, they only have a dealer relationship with Chelton Flight Systems. Can you point me to the relationship between Meggitt (S-Tec) and Chelton? http://www.chelton.com/common/group_chart.asp Chelton has the EFIS SV line of EFIS, and Meggit has the MAGIC line (http://www.magic.aero/) of EFIS. William Curtis http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Apr 12, 2006
another approach. I print the origin/destination/planned alternates from Airnav or AOPA; update the DBs in the GPS twice a year and carry a DVD with the low altitude enroutes and approach plates for backup. A notebook computer allows retrieval of other info off the flight plan route. - Original Message ----- From: "Dan Masys" <dmasys(at)cox.net> Sent: Wednesday, April 12, 2006 5:45 PM Subject: Re: RV10-List: IFR related cockpit stuff > >> From: "Chris Johnston" <CJohnston(at)popsound.com> >> Date: 2006/04/12 Wed PM 02:27:13 EDT >> To: >> Subject: RV10-List: IFR related cockpit stuff >> >> Has anyone with more IFR experience than me thought >> about this and arrived at a comfortable, yet suitably cool solution? Be >> gentle with me. I'm new to this stuff. > > My current solution is not elegant, but seems reasonably functional. I > have an approach certified GPS (GX-60) and a Jepp online subscription for > updates that includes nav data for approaches (but not electronic chart > views); this is about $300/yr. Before an IFR flight I print just the > destination plates and a couple of plausible alternate airport's > approaches if it really looks like hardball IFR, from either Airnav.com or > AOPA's sites. > > Now, this leaves me out in the cold if I have an emergency and have to > make an IFR approach to some airport along the way, but at that point, > since the approach fix names are in the GPS, I figure I would just ask ATC > for the crossing altitudes and MDA/DH for the approach, and the missed > approach procedure. Since I'm gonna be talking to them about the > emergency anyway, and they're going to be watching me closer in this > circumstance, it should plausibly work out. Have had two engine failures > in the past 35 years of flying, (one IFR) and both times ATC was very > accommodating about working with me to find a realtime way to minimize the > risks and get down safely. > > Just my $0.02 until the economical perfect panel arrives... > > -Dan Masys > #40448 > > > ________________________________________________________________________________
Date: Apr 13, 2006
> > I keep doing the numbers and coming up with a range of 120 to 160, but never > below the 120 mark. And sometimes above the 160 fathom. Seems absolutely frugal compared to a new 140kt Skylane costing $300K or a Cirrus at $450K, doesn't it? Makes me think I should have kept the fully loaded IFR equipped C172 that I got for $15K in 1987 as a table ornament. As Gordon Baxter said, the price of aviation has always been the same: all you got. -Dan Masys #40448 ________________________________________________________________________________
Subject: Re: RV10-List Digest: 70 Msgs - 04/12/06
Date: Apr 13, 2006
Expect to see N533JD there. You'll like this one! BTW at SnF the Garmin rep hinted that they were looking at the possibility of offering the G1000 to the EXP group. Seems they have two employees building -10. the decision would be after OSH. He smiled and said they could ~probably~ do it for considerably less than chelton! On Apr 13, 2006, at 1:57 AM, RV10-List Digest Server wrote: > Thanks. All is well. Hope to see you again at OSH this year. You > planning > on being there? While we are on this, what new -10=92s are hoping > to be at > Osh this year that weren=92t last year? I hope to have N415EC > there, that=92s > kit 40415 built in Ecuador. I am sure we will be seeing N104CD there. ________________________________________________________________________________
Date: Apr 13, 2006
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Here you go: http://www.naco.faa.gov/index.asp?xml=3Dnaco/online/d_tpp TDT ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Thursday, April 13, 2006 8:21 AM Subject: Re: RV10-List: Re: IFR related cockpit stuff I'll try to see if I can locate a site from the Fed's...they now make this same information available to us, the public, for free...one of the guys from the Langley group spoke to local pilots via an FAA safety seminar recently...I'll see if I still have the reference...these updating disc are available from a number of places...but acording to a fellow presenting the information we can get it directly, vai a download, from the Fed also for free...it's somewhere out there!!! ________________________________________________________________________________
Date: Apr 13, 2006
Subject: Re: IFR related cockpit stuff - Avidyne - Jepp Flightdeck
Tim is this system a "real" active system or is it a TIS system and dependent upon radar returns from various centers? I believe that with the TCAS system one needs active interrogation system while in the G 1000 it's a TIS system. P ________________________________________________________________________________
Date: Apr 13, 2006
All of the Avidyne TAS series are true active sensors that send out their own "pings" and are not passive systems, nor TIS systems. TAS systems like the Avidyne TAS and L-3 Skywatch are active systems, as is TCAS, but TCAS has the extra capability of not only giving you Traffic Alerts (TAs), but also Resolution Advisories (RAs), where the system coordinates with the other aircraft (if also TCAS), telling one aircraft to climb and one aircraft to descend. TCAS is what the airliners use. BTW, G1000 is just a display in regards to traffic. I suppose it can display TIS from its remote GTX330 transponder, but it will also interface to an active Avidyne TAS600, or probably even an L-3 Skywatch. TDT ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Thursday, April 13, 2006 1:57 PM Subject: Re: RV10-List: Re: IFR related cockpit stuff - Avidyne - Jepp Flightdeck Tim is this system a "real" active system or is it a TIS system and dependent upon radar returns from various centers? I believe that with the TCAS system one needs active interrogation system while in the G 1000 it's a TIS system. P ________________________________________________________________________________
Date: Apr 13, 2006
Tim, the G 1000 gives you a trend line and altitude of the target also...but the signal is a return signal so the traffic is really never where it's pointed out...but a nice feature along with the 6 second trend line. P ________________________________________________________________________________
Date: Apr 13, 2006
----- Original Message ----- From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com> Sent: Thursday, April 13, 2006 12:30 PM Subject: RE: RV10-List: Re: IFR related cockpit stuff - Avidyne - Jepp Flightdeck > > > traffic system can be offered at $9990. (or in the package above) The > TAS600 plays with many/most MFDs out there, e.g. Cheltons, GNS430/530, > MX20, CNX80, KMD550. How about the GRT EFIS? Although 10k is a non-trivial amount for a slow, fat, aging computer dude such as myself, it's an upgrade I'd probably shell out for if it'll talk to one of the non-certified boxes. -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
Date: Apr 13, 2006
Again, the G1000 is just a display for the traffic sensor. In that case, the TIS transponder. TIS information is actually transmitted from a ground based Mode-S radar that is tracking the other aircraft and then sending the data to you. The track of the targets is calculated by the system on the ground before being sent up to you. The altitude is from the target's transponder, and almost all traffic systems will show you that. In order to get any traffic with TIS, you need to be within range of a Mode-S ground radar, which unfortunately they are not installing any more of, and actually are decommissioning some. I flew the G1000 in a Diamond out of Las Vegas, and about out near the Hoover Dam, all the traffic symbols went away, because we left the range of the Mode-S radar at Las Vegas. (And all of that traffic buzzing around the Grand Canyon would be nice to see!) The G1000 will happily display traffic from an active traffic sensor like the Avidyne TAS600 or L-3 Skywatch. TDT ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Thursday, April 13, 2006 4:14 PM Subject: Re: RV10-List: Re: IFR related cockpit stuff - Avidyne - Jepp Flightdeck Tim, the G 1000 gives you a trend line and altitude of the target also...but the signal is a return signal so the traffic is really never where it's pointed out...but a nice feature along with the 6 second trend line. P ________________________________________________________________________________
Date: Apr 13, 2006
Good question for GRT. The TAS600 will spit out standard ARINC 429 traffic information labels . . . TDT -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Sponcil Sent: Thursday, April 13, 2006 4:25 PM Subject: Re: RV10-List: Re: IFR related cockpit stuff - Avidyne - Jepp Flightdeck ----- Original Message ----- From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com> Sent: Thursday, April 13, 2006 12:30 PM Subject: RE: RV10-List: Re: IFR related cockpit stuff - Avidyne - Jepp Flightdeck > > > traffic system can be offered at $9990. (or in the package above) The > TAS600 plays with many/most MFDs out there, e.g. Cheltons, GNS430/530, > MX20, CNX80, KMD550. How about the GRT EFIS? Although 10k is a non-trivial amount for a slow, fat, aging computer dude such as myself, it's an upgrade I'd probably shell out for if it'll talk to one of the non-certified boxes. -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
From: "Barry Marz or Amy Marz" <blalmarz(at)earthlink.net>
Subject: Rear Windows
Date: Apr 13, 2006
Just finished my rear windows and wanted to share some info. Did the right side per plans; it went ok but the Weld-on 10 is messy. On the left side I put the glue on the window while it was flat; and had my helper guide the bottom to the correct position then flipped the window into position. Had a few drips but much better than the right side. Also found a place in LA( Gavrieli Plastics 818-982-0000) that sells Weld-on 10 in 16 oz. Kits for $17.00. Blue Skys. Barry ________________________________________________________________________________
Subject: Removable Rear Windows?
Date: Apr 13, 2006
Does anyone think there would be interest in removable/hinged rear windows similar to our Legacy windows? Please see: http://www.aircraftersllc.com/projects/legacyWindow/index.htm Cost would be around the same as for the Legacy, $579. The Legacy parts weigh 21 ounces. My QB arrives next week and I will develop the molds if I can get about 20 orders. Dave Saylor AirCrafters LLC 831-722-9141 ________________________________________________________________________________
Date: Apr 13, 2006
> From: Tim Olson <Tim(at)MyRV10.com> > Date: 2006/04/13 Thu AM 10:09:22 EDT > Building and upgrading later is an option, but it's a fun > thought. That's why people sweat it so much. As somebody who has had my first RV in the air for the past three years, I can tell you that upgrading is inevitable. Once your plane is paid off and you see the new cool toys coming out each year, it will be too much temptation to bear to not add a new gadget here and there. My -7A is all electric and started out with round guages. Swapped the artificial horizon for a TruTrak solid state AI, added a switch to the panel labelled "WX Radar" and plumbed in a NavAir XM weather display running on a Toshiba. The list goes on... Once a project, always a project. The EFIS are bigger ticket items, but a working system has some residual value and can be sold to some other builder to make way for an even cooler tool. It's why when people ask you when your plane is going to be done, the real answer is never. (And glad of it!) -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 13, 2006
Subject: Re: Removable Rear Windows?
Dave, I'm not all that keen on a removable window, BUT I expect there would be a much larger interest if you could make some molds for some window frame covers that could be attached to the inside of the RV10- cockpit windows, that could be installed on top of the headliner/upholstery fabric and give the plane a clean/finished look. From an appearance point of view this is one of the weak points (IMHO) on the kit, and I've been conjuring how I could address it myself by making some fiberglass covers/'rings'. Deems Davis # 406 Fuse http://deemsrv10.com/ Dave Saylor wrote: > >Does anyone think there would be interest in removable/hinged rear windows >similar to our Legacy windows? Please see: > >http://www.aircraftersllc.com/projects/legacyWindow/index.htm > >Cost would be around the same as for the Legacy, $579. The Legacy parts >weigh 21 ounces. > >My QB arrives next week and I will develop the molds if I can get about 20 >orders. > >Dave Saylor >AirCrafters LLC >831-722-9141 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Rear Windows
Date: Apr 13, 2006
If you haven't bonded in windows before I recommend a call to Phoenix Composites in Mesa AZ at FFZ. They do this all the time and have some good procedures that they will share in a phone call. ----- Original Message ----- From: "Barry Marz or Amy Marz" <blalmarz(at)earthlink.net> Sent: Thursday, April 13, 2006 4:29 AM Subject: RV10-List: Rear Windows > > > Just finished my rear windows and wanted to share some info. Did the right > side per plans; it went ok but the Weld-on 10 is messy. On the left side I > put the glue on the window while it was flat; and had my helper guide the > bottom to the correct position then flipped the window into position. Had > a > few drips but much better than the right side. Also found a place in LA( > Gavrieli Plastics 818-982-0000) that sells Weld-on 10 in 16 oz. Kits for > $17.00. Blue Skys. Barry > > > ________________________________________________________________________________
Subject: aileron trim tension
Date: Apr 13, 2006
Just installed the aileron trim servo/springs in and on the left aileron push rod and access plate---fairly easy installation but the amount of tension the spings place on the push rod seems excessive. Don't know how many ft/lbs it takes to displace the push rod but one has to give a pretty good tug. I rechecked the distances from the spring attachments and they are okay and the servo lever goes nicely from stop to stop. But it just seems too stiff. In fact displacing the rod causes some slight oil canning of the access plate skin. Does anyone know how "stiff" that action should be, or how to measure it? Or does anyone else have such concerns? Jay Rowe 40301 ________________________________________________________________________________
Date: Apr 14, 2006
Dave, Are you saying NOT to use the window (WELD ON) glue Van's recommends...........and use epoxy/resin instead? I agree the e-glass around the perimeter is a good idea,,,,,,,,,what WEGHT of e-glass do they recommend? Just one layer of E-glass and how do they feather it in to look flawless? Thanks, Dean 40449 Dave, Are you saying NOT to use the window (WELD ON)glue Van's recommends...........and use epoxy/resin instead? I agree the e-glass around the perimeter is a good idea,,,,,,,,,what WEGHT of e-glass do they recommend? Just one layer of E-glass and how do they feather it in to look flawless? Thanks, Dean 40449 ________________________________________________________________________________
Subject: Re: aileron trim tension
Date: Apr 14, 2006
Jay, I called Van's yesterday to order this trim system. I talked to Gus Funnel. He said that it is supposed to be mounted on the most inboard access plate (close to the wing root) where the skin thickness is 32 thous. He did not mention any spring tension rates. I have this very same type of spring system on my RV8. It does feel tight when assembled, but when you grab the stick and move the ailerons, you hardly notice it. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=28342#28342 ________________________________________________________________________________
Date: Apr 14, 2006
My cohort is reviewing our procedure to determine whether I forgot anything . we will put on it the list later today. If you want to see how it looks, my Glastar will be at OSH thurs through sat N48007. If required I could get a couple of pictures of the finished product. In the meantime a got the following note from a friend at the Big Airplane Company. Subject: C-5B Accident Dover FYI: Received from a personal friend who is often involved in investigations into mishaps of large planes such as this. > The old story -- nobody was flying the A/C......... > > "The current skinny on the crash--none of it official--until the board says so. > > It was not a bird ingestion but a "reverser unlock" on the #2 engine > that started this. They lost a C-5 with all aboard a few years back > in Germany for the same cause. This crew however shut down the engine > before an actual unstow took place. The airplane was well over 700K > gross weight with FOB of over 300K. The airplane had the newest > version of the C-5 flight deck with big panel glass. Unfortunately, > only one of the three pilots was really comfortable with the new equipment and FMS. > > The crew decided because of their weight to fly their approach to the > longest runway, which unfortunately was only being served that day by > a Tacan (fancy VOR for you civilian types) approach. They also > decided to fly a full flap approach to keep the approach speed down. > This isn't prohibited--just highly discouraged. The recommended flap > setting for a three engine approach is Flaps 40. During the approach > the crew became worried about not having enough power to fly a full > flap approach and selected flaps 40--which they were now too slow for. > Here's the point all you glass cockpit guys should sit up and take > notice about. The one guy who was familiar with the new glass and FMS > was also the one flying the aircraft. He became distracted inputting > the new approach speed in the FMS. There was also some confusion > about just who was flying the A/C while he had his head down updating > the speed. Long story short--they got way slow and into the shaker, > and actually stuck the tail into the trees and it departed the > aircraft first. The nose pitched down hard and the nose and left wing > impacted next snapping off the nose. Several cockpit occupants > suffered spinal compression injuries. The guys sitting at the crew table behind the cockpit actually came to a stop with their legs dangling out over the ground. > > The miracle of this was the left outboard fuel tank was broken open > and none of that fuel managed to find something hot enough to ignite > it and the other 300k. Again, a bunch of very lucky people. > > ----- Original Message ----- From: ddddsp1(at)juno.com To: rv10-list(at)matronics.com Sent: Thursday, April 13, 2006 11:28 PM Subject: Re: RV10-List: Rear Windows Dave, Are you saying NOT to use the window (WELD ON) glue Van's recommends...........and use epoxy/resin instead? I agree the e-glass around the perimeter is a good idea,,,,,,,,,what WEGHT of e-glass do they recommend? Just one layer of E-glass and how do they feather it in to look flawless? Thanks, Dean 40449 ________________________________________________________________________ ________________________________________________________________________________
Subject: Re: Vans VA-186 Oil cooler box assy
Date: Apr 14, 2006
Marcus: My oil cooler mounts to the firewall with rivets. It also looks as if Tim Olson mounted his with rivets also. Cal Hoffman (40119 canoe) ----- Original Message ----- From: Marcus Cooper To: rv10-list(at)matronics.com Sent: Sunday, April 09, 2006 9:08 PM Subject: RE: RV10-List: Vans VA-186 Oil cooler box assy Ralph, I got the Firewall Forward kit and it has the same oil cooler box you received. It uses the 20006A oil cooler and it works fits just fine. You bolt it to the firewall with the large duct fitting facing up using AN-3 bolts through the firewall into nut plates that should be in place by now. The oil cooler fits on the front with bolts to nut plates with the fittings on the top side. Hope this helps, if not I can zap a picture or two. Check out this link from Tim Olson's site of the box: http://www.myrv10.com/N104CD/engine/20051014/RV200510140214.html Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Sunday, April 09, 2006 8:11 PM To: rv10-list(at)matronics.com Subject: RV10-List: Vans VA-186 Oil cooler box assy Fellow listers, Has anyone out there used this thing for their oil cooler? It is supposed to be for the 20006A or 8604R oil cooler. I got this thing - no photos/instructions and it doesn't look right to do what I think its supposed to do. Any help would be appreciated, Ralph ________________________________________________________________________________
Subject: Windows
Date: Apr 14, 2006
Pictures to follow later today window procedure Although the procedure takes only about an hour to accomplish per window, setup and planning is substantially more.. I recommend that you do one window to get the procs correct and plan to do the windshield on a day by itself. (0) tape off the inside and outside flange area of the window using 3M Fineline (.5 width) (1) then signstrip blue on the center areas to protect the inside and outside of the window . Be generous when painting it on as this makes it easy to pull off. (2) sand the inside/outside edges of the window in the area of the flange to roughen the glass for adhesion. (3) sand the flanges of the lid; CLEAN ALL SANDED EDGES WITH ACETONE (4) prepare a set of aluminum "fingers" . Strips of .080 1" by 3" ; with a slight bend in the center. one end gets a #30 hole and the other is adequately taped. each is numbered. See the picture. (5) Trim the window to fit the frame and temporarily hold in place with the NUMBERED "fingers". Clecoes should be place about .50" outside the window. Drill #30 only through the external layer; NOT THROUGH THE LID. RETAPE OFF THE EDGES 3M FINELINE TAPE . (6) prepare a mixture of epoxy with chopped fibers and cabosil. Consistency should be peanut butter. Potlife should plan to be 30-40 minutes. We refrigerated it to further slow the cure. (7) putty the lid flanges, wet the window flanges with a small amount of catalyzed epoxy and place window in frame; holding in place with "fingers" at the preplanned locations. (8) inside person should be wiping excess putty away with a 50-50 mixture of mineral spirirts and acetone; outside person should be smoothing putty on outside flange. excess will be sanded off later. then PULL THE TAPES BEFORE IT CURES. (9) allow to cure 24 hours. (10) Inside lid , flange should be finished . If rough, tape glass and sand lightly. (11) outside the lid, RETAPE the edge at the flange line, then cover the flange with two 1" layers of glass (E-7782?). (Note this was the Glastar procedure.) Remember to pull the tape before the layered glass sets up. The windscreen on the RV10 requires a different layering of glass on the aluminum. (12) Retape the edge , then sand and fill external flange area for paint. The sanding can feather into the edge of the tape. (13) when painted , paint should cover the flange. (14) MUST BE DONE BEFORE THE MIXTURE CURES. If you accidentally get epoxy on the Plexiglas during the process, it can be safely removed using a clean cloth and the 50-50 mixture of mineral spirits and acetone. Have it handy. (15) 50-50 mixture is also good for removing any signstrip that does not come off when finally removing the protective covering before flight. ________________________________________________________________________________
Subject: Windows
Date: Apr 14, 2006
DO NOT FORGET TO PUT VASELINE ON THE CLECO TIP FOR EASY REMOVAL ________________________________________________________________________________
Date: Apr 14, 2006
On the Legacy the hinged rear windows are very useful for loading and accessing the baggage compartment. I realize the baggage door on the -10 serves that purpose, as does easier access from the passenger area. So this is a question for -10 users--if you find yourselves wanting easier access to the baggage compartment, perhaps from the right side, or if you think it might be useful as an emergency exit, please let me know. Some people expressed interest in trim rings, which are a much easier product to produce, so I will get started on those soon. Cost for trim rings will be about $100 each, oversized so you can "trim" to whatever size you think looks best. Dave Saylor AirCrafters LLC 831-722-9141 ________________________________________________________________________________
Subject: Windows
Date: Apr 14, 2006
pictures ________________________________________________________________________________
Date: Apr 14, 2006
Thanks Zack---good info. Would like to hear from you again after you have your aileron trim installed. I will talk to Gus about the buckling of the access plate skin as well. Jay ----- Original Message ----- From: "zackrv8" <zackrv8(at)verizon.net> Sent: Friday, April 14, 2006 8:43 AM Subject: RV10-List: Re: aileron trim tension > > Jay, > > I called Van's yesterday to order this trim system. I talked to Gus > Funnel. He said that it is supposed to be mounted on the most inboard > access plate (close to the wing root) where the skin thickness is 32 > thous. He did not mention any spring tension rates. > > I have this very same type of spring system on my RV8. It does feel > tight when assembled, but when you grab the stick and move the ailerons, > you hardly notice it. > > Zack > > -------- > RV8 #80125 > RV10 # 40512 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=28342#28342 > > > -- > > ________________________________________________________________________________
Date: Apr 14, 2006
I was reading something that suggested for the airworthiness inspection, the examiner was also going to be interested in seeing your test plan for flight testing the aircraft. What have folks been doing for that? A one-page outline of tasks, or an 80-page flight test plan with individual test cards, or something in-between? TDT 40025 ________________________________________________________________________________
Subject: Windows
Date: Apr 14, 2006
We used a very similar method, but used screws to hold the clips to keep them tight and used FE6026 Part A & B from Spruce as the glue. It was recommended to us by a guy who builds Lancairs and it seems to hold really well. We just filled around the edges with epoxy and micro and have not had any cracking after 200+ flying hours. No e-glass, but it wouldn't hurt. Just would take a lot more work to get faired into the windows well. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org <http://www.itecusa.org> www.itecusa.org I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Friday, April 14, 2006 11:21 AM Subject: RV10-List: Windows Pictures to follow later today window procedure Although the procedure takes only about an hour to accomplish per window, setup and planning is substantially more.. I recommend that you do one window to get the procs correct and plan to do the windshield on a day by itself. (0) tape off the inside and outside flange area of the window using 3M Fineline (.5 width) (1) then signstrip blue on the center areas to protect the inside and outside of the window . Be generous when painting it on as this makes it easy to pull off. (2) sand the inside/outside edges of the window in the area of the flange to roughen the glass for adhesion. (3) sand the flanges of the lid; CLEAN ALL SANDED EDGES WITH ACETONE (4) prepare a set of aluminum "fingers" . Strips of .080 1" by 3" ; with a slight bend in the center. one end gets a #30 hole and the other is adequately taped. each is numbered. See the picture. (5) Trim the window to fit the frame and temporarily hold in place with the NUMBERED "fingers". Clecoes should be place about .50" outside the window. Drill #30 only through the external layer; NOT THROUGH THE LID. RETAPE OFF THE EDGES 3M FINELINE TAPE . (6) prepare a mixture of epoxy with chopped fibers and cabosil. Consistency should be peanut butter. Potlife should plan to be 30-40 minutes. We refrigerated it to further slow the cure. (7) putty the lid flanges, wet the window flanges with a small amount of catalyzed epoxy and place window in frame; holding in place with "fingers" at the preplanned locations. (8) inside person should be wiping excess putty away with a 50-50 mixture of mineral spirirts and acetone; outside person should be smoothing putty on outside flange. excess will be sanded off later. then PULL THE TAPES BEFORE IT CURES. (9) allow to cure 24 hours. (10) Inside lid , flange should be finished . If rough, tape glass and sand lightly. (11) outside the lid, RETAPE the edge at the flange line, then cover the flange with two 1" layers of glass (E-7782?). (Note this was the Glastar procedure.) Remember to pull the tape before the layered glass sets up. The windscreen on the RV10 requires a different layering of glass on the aluminum. (12) Retape the edge , then sand and fill external flange area for paint. The sanding can feather into the edge of the tape. (13) when painted , paint should cover the flange. (14) MUST BE DONE BEFORE THE MIXTURE CURES. If you accidentally get epoxy on the Plexiglas during the process, it can be safely removed using a clean cloth and the 50-50 mixture of mineral spirits and acetone. Have it handy. (15) 50-50 mixture is also good for removing any signstrip that does not come off when finally removing the protective covering before flight. ________________________________________________________________________________
Date: Apr 14, 2006
Subject: Van's Fuel sender
Tonight I began to install the fuel sender unit in the Right tank, it appears to be exactly the same unit as the one in the Left tank. Not a "flopped" version or mirror copy. It appears that the factory miss-labeled a left hand version as a right and boxed it as a right so I have two left side senders. Can anyone tell me for sure that they are each supposed to angle down towards the bottom of the tank when installed? Thanks, Steve 40212 ________________________________________________________________________________
From: "Mark & Kelly Hanley" <2eyedocs(at)comcast.net>
Subject: RV-10 Screen Burn-In
Date: Dec 29, 2005
Funny story, I like Larry Feldhousen's Blue RV-10 so much that I set it up on my office computer as my Wallpaper and Screensaver and I now have a permanent image burned into my monitor. Oh well, I can think of worse things! Mark DNA ________________________________________________________________________________
Date: Apr 15, 2006
Subject: Re: Van's Fuel sender
Steve, Here are a couple pictures of the left and right senders when installed. -Jim 40384 Darton Steve wrote: > >Tonight I began to install the fuel sender unit in the >Right tank, it appears to be exactly the same unit as >the one in the Left tank. Not a "flopped" version or >mirror copy. It appears that the factory miss-labeled >a left hand version as a right and boxed it as a right >so I have two left side senders. Can anyone tell me >for sure that they are each supposed to angle down >towards the bottom of the tank when installed? > >Thanks, Steve 40212 > >__________________________________________________ > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2006
I'm interstead in trim rings! Sam Marlow Fuse Dave Saylor wrote: > >On the Legacy the hinged rear windows are very useful for loading and >accessing the baggage compartment. I realize the baggage door on the -10 >serves that purpose, as does easier access from the passenger area. > >So this is a question for -10 users--if you find yourselves wanting easier >access to the baggage compartment, perhaps from the right side, or if you >think it might be useful as an emergency exit, please let me know. > >Some people expressed interest in trim rings, which are a much easier >product to produce, so I will get started on those soon. Cost for trim >rings will be about $100 each, oversized so you can "trim" to whatever size >you think looks best. > >Dave Saylor >AirCrafters LLC >831-722-9141 > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2006
> From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com> > Date: 2006/04/14 Fri PM 04:28:00 EDT > To: > Subject: RE: RV10-List: Re: IFR related cockpit stuff > > I was reading something that suggested for the airworthiness inspection, > the examiner was also going to be interested in seeing your test plan > for flight testing the aircraft. What have folks been doing for that? > A one-page outline of tasks, or an 80-page flight test plan with > individual test cards, or something in-between? The only topic that came up at my -7's signoff was the boundaries of the flight test area. The DAR wanted to be sure I had a marked Sectional showing its limits (and a copy was included in his signoff paperwork for phase I) since the standard text description of it in the San Diego area was pretty complicated and bordered by restricted airspace. If I can infer from the silence on the topic of the flight test program, the general attitude was 'go out and kill yourself if you like, but please do it in this area. Rest is up to you.' Since DAR's and FSDO's seem to vary dramatically, this is just an anecdote... -Dan Masys ________________________________________________________________________________
Date: Apr 15, 2006
Speaking of room, what is the trend on mounting oil filters?? Standard horizontal, alternate 90 degree or remote? I am planning a pre-oiler installation but have not mounted my enging yet. Cal Hoffman (40119 - canoe) ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Monday, April 10, 2006 11:23 AM Subject: Re: RV10-List: Vans VA-186 Oil cooler box assy > > Dan, > > Thanks for the info. I really like the oil cooler (whichever one) mounted on the firewall as I am using a SamJames plenum and there just doesn't seem to be enough room for the cooler up on the back of the baffling. > > You are probably corect in that I could go with a smaller cooler - maybe a stewart warner 8406R like some of the other 6A O360 guys are using. > > Ralph > > -----Original Message----- > >From: Dan Masys <dmasys(at)cox.net> > >Sent: Apr 10, 2006 10:48 AM > >To: rv10-list(at)matronics.com > >Subject: Re: RV10-List: Vans VA-186 Oil cooler box assy > > > > > >> From: "Ralph E. Capen" <recapen(at)earthlink.net> > >> Date: 2006/04/10 Mon AM 08:17:12 EDT > > > >> Thanks Tim....that Oil cooler is Huge! > >> > >> Now I'm pretty sure I know how it works - I just gotta figure if it is the correct setup for my 6A. > >> > >> I have an Aerosport Power O360 with AFP injection and 9.2 pistons - so I think I need more oil cooler than the average bear. > > > >Ralph, > > > >For the O-360 you really don't need the giant oil cooler used on the -10. I have a 200hp IO-360 in my -7A and use a 7 row cooler (the O-320 model has 5 rows) mounted to the left rear cylinder. Oil temps essentially never get above 210 even with sustained full power climbs at best rate in summer conditions. In cruise the oil temp is always right at 170, which is the vernatherm opening temp. > > > >Both Dan Checkoway and I had problems with the weight of the larger cooler causing cracking of the baffle, so we both added a 3/4 angle brace from the inner flange of the baffle to a midline bolt on the engine case. > > > >On the other hand, mounting the oil cooler on the firewall rather than the engine certainly saves stress on the cylinder it is bolted to, and the baffles. > > > >-Dan Masys > >RV-7A N747DL flying > >RV-10A N104LD fuselage > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2006
James, Thanks for the pictures. That is what mine looks like, you see the back side of the sender on the right tank. That is how I installed mine too. Steve 40212 --- James Hein wrote: > Steve, > Here are a couple pictures of the left and right > senders when installed. > > -Jim 40384 > > Darton Steve wrote: > > > > > >Tonight I began to install the fuel sender unit in > the > >Right tank, it appears to be exactly the same unit > as > >the one in the Left tank. Not a "flopped" version > or > >mirror copy. It appears that the factory > miss-labeled > >a left hand version as a right and boxed it as a > right > >so I have two left side senders. Can anyone tell me > >for sure that they are each supposed to angle down > >towards the bottom of the tank when installed? > > > >Thanks, Steve 40212 > > > >__________________________________________________ > protection around > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Mounting Lasar unit
Date: Apr 15, 2006
Folks, I'm getting ready to put my Lasar computer on the firewall (where I've seen them before in pictures). for those of you that have this ignition system, are you putting some backing plates to spread the load out - or just nutplating it in? Thanks, Ralph ________________________________________________________________________________
Date: Apr 15, 2006
Subject: Re: Mounting Lasar unit
I just drilled #19 holes and used 4 #8 screws to attach it to the firewall. I used steel locknuts on the hot side of the firewall. -Jim 40134 In a message dated 4/15/2006 4:04:44 P.M. Mountain Daylight Time, recapen(at)earthlink.net writes: Folks, I'm getting ready to put my Lasar computer on the firewall (where I've seen them before in pictures). for those of you that have this ignition system, are you putting some backing plates to spread the load out - or just nutplating it in? Thanks, Ralph Jim "Scooter" McGrew jsmcgrew(at)aol.com ________________________________________________________________________________
Subject: FAB Instructions
Date: Apr 15, 2006
Can someone tell me where the Filtered Airbox Instructions are located? The FAB kit did not include any, and they are not in the FWF instructions that I have. Does someone have a set the can scan and e-mail to me? Or enlighten me on where I may find them? Thanks -Mike Kraus ________________________________________________________________________________
From: "Indran Chelvanayagam" <ichelva(at)netspace.net.au>
Date: Apr 16, 2006
I can email these instructions (577Kb file) to anyone else if requested - I haven't posted them here in deference to those with dial-up (Chris McG - you listening?) Indran Chelvanayagam _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Sent: Sunday, 16 April 2006 6:29 AM Subject: RV10-List: FAB Instructions Can someone tell me where the Filtered Airbox Instructions are located? The FAB kit did not include any, and they are not in the FWF instructions that I have. Does someone have a set the can scan and e-mail to me? Or enlighten me on where I may find them? Thanks -Mike Kraus ________________________________________________________________________________
Date: Apr 15, 2006
Subject: Re: FAB Instructions
Indran, I would be interested in a copy. THanks. Ed Godfrey Indran Chelvanayagam wrote: > I can email these instructions (577Kb file) to anyone else if > requested - I haven't posted them here in deference to those with > dial-up (Chris McG - you listening?) > > Indran Chelvanayagam > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus > Sent: Sunday, 16 April 2006 6:29 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: FAB Instructions > > Can someone tell me where the Filtered Airbox Instructions are > located? The FAB kit did not include any, and they are not in the FWF > instructions that I have. > > Does someone have a set the can scan and e-mail to me? Or enlighten > me on where I may find them? > > Thanks > -Mike Kraus ________________________________________________________________________________
Date: Apr 15, 2006
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
From: "Wayne Edgerton" <weeav8ter(at)grandecom.net>
Date: Apr 16, 2006
I would possible be interested in the window trim pieces also. Wayne Edgerton #40336 do no archive ________________________________________________________________________________
Subject: RV10 Fuel Tanks
Date: Apr 16, 2006
For those of you "lucky" enough to have the luxury of building your own fuel tanks, here's a tip that might save you some time. The plans have you rivet the J channel in the tanks after the ribs. Don't have to. Check it out for yourself before you proseal. Put the J channel in place with clecos. Now, put one or all of the ribs in place just to see if you can do it. It is very easy and you will find works. I prosealed and back riveted all bottom and top tank stiffners in first (as per plans) but also riveted and prosealed the J channel. Then I installed the ribs. With an "acid brush" with the hairs cut off half way, I painted the ribs and skin with proseal. Now, slide the rib onto skin. You cock the rib 45 degrees, put the J channel end on the skin first, then put the rib straight in place. It works guys! The best part about this procedure is that you can back rivet the J channel in place and not worry about sliding that proseal mess in later. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=28717#28717 ________________________________________________________________________________
Date: Apr 16, 2006
MessageI would also like a copy, please. Cal Hoffman (cehoffman(at)bellsouth.net) ----- Original Message ----- From: Indran Chelvanayagam To: rv10-list(at)matronics.com Sent: Saturday, April 15, 2006 7:49 PM Subject: RE: RV10-List: FAB Instructions I can email these instructions (577Kb file) to anyone else if requested - I haven't posted them here in deference to those with dial-up (Chris McG - you listening?) Indran Chelvanayagam From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Sent: Sunday, 16 April 2006 6:29 AM To: rv10-list(at)matronics.com Subject: RV10-List: FAB Instructions Can someone tell me where the Filtered Airbox Instructions are located? The FAB kit did not include any, and they are not in the FWF instructions that I have. Does someone have a set the can scan and e-mail to me? Or enlighten me on where I may find them? Thanks -Mike Kraus ________________________________________________________________________________
Subject: Low Drag VHF Antenna
Date: Apr 16, 2006
Message Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 16, 2006
Subject: Re: Low Drag VHF Antenna
Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew _jsmcgrew(at)aol.com_ (mailto:jsmcgrew(at)aol.com) In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 16, 2006
Jim, Thank you for the response. Very clever installation. One more question, what did you do about a "ground plane"? Is one recommended? Roger ----- Original Message ----- From: JSMcGrew(at)aol.com<mailto:JSMcGrew(at)aol.com> To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 12:01 PM Subject: Re: RV10-List: Low Drag VHF Antenna Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew jsmcgrew(at)aol.com In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 16, 2006
I believe the ground plane requirement is covered by the antenna coax connector (included in the antenna kit) which is bolted to the aluminum part of the airframe. There is no mention of ground plane in the sheet Van's included with the antenna kit. Jim In a message dated 4/16/2006 1:55:19 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Jim, Thank you for the response. Very clever installation. One more question, what did you do about a "ground plane"? Is one recommended? Roger ----- Original Message ----- From: _JSMcGrew(at)aol.com_ (mailto:JSMcGrew(at)aol.com) Sent: Sunday, April 16, 2006 12:01 PM Subject: Re: RV10-List: Low Drag VHF Antenna Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew _jsmcgrew(at)aol.com_ (mailto:jsmcgrew(at)aol.com) In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 17, 2006
Most antenas need ground planes....the connector would not be enough. Chris VK3GI 40388 ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Monday, April 17, 2006 7:49 AM Subject: Re: RV10-List: Low Drag VHF Antenna I believe the ground plane requirement is covered by the antenna coax connector (included in the antenna kit) which is bolted to the aluminum part of the airframe. There is no mention of ground plane in the sheet Van's included with the antenna kit. Jim In a message dated 4/16/2006 1:55:19 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Jim, Thank you for the response. Very clever installation. One more question, what did you do about a "ground plane"? Is one recommended? Roger ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 12:01 PM Subject: Re: RV10-List: Low Drag VHF Antenna Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew jsmcgrew(at)aol.com In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 17, 2006
MessageIndran are you sending a 4-6 meg picture? Thats what the drama was not very useful files like this ....please put on list Chris ----- Original Message ----- From: Indran Chelvanayagam To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 9:49 AM Subject: RE: RV10-List: FAB Instructions I can email these instructions (577Kb file) to anyone else if requested - I haven't posted them here in deference to those with dial-up (Chris McG - you listening?) Indran Chelvanayagam From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Sent: Sunday, 16 April 2006 6:29 AM To: rv10-list(at)matronics.com Subject: RV10-List: FAB Instructions Can someone tell me where the Filtered Airbox Instructions are located? The FAB kit did not include any, and they are not in the FWF instructions that I have. Does someone have a set the can scan and e-mail to me? Or enlighten me on where I may find them? Thanks -Mike Kraus ________________________________________________________________________________
Date: Apr 17, 2006
Woops read where connector is attached to airframe....this should be enough....so disregard chris ----- Original Message ----- From: Chris , Susie Darcy To: rv10-list(at)matronics.com Sent: Monday, April 17, 2006 8:18 AM Subject: Re: RV10-List: Low Drag VHF Antenna Most antenas need ground planes....the connector would not be enough. Chris VK3GI 40388 ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Monday, April 17, 2006 7:49 AM Subject: Re: RV10-List: Low Drag VHF Antenna I believe the ground plane requirement is covered by the antenna coax connector (included in the antenna kit) which is bolted to the aluminum part of the airframe. There is no mention of ground plane in the sheet Van's included with the antenna kit. Jim In a message dated 4/16/2006 1:55:19 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Jim, Thank you for the response. Very clever installation. One more question, what did you do about a "ground plane"? Is one recommended? Roger ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 12:01 PM Subject: Re: RV10-List: Low Drag VHF Antenna Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew jsmcgrew(at)aol.com In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 16, 2006
Jim, Makes sense that bolting the connector to the frame does the trick. I didn't receive a sheet with the kit from Vans. Guess that is why the questions. Could you please send a copy of it to me? Thanks a bunch. This list is great! Roger ----- Original Message ----- From: JSMcGrew(at)aol.com<mailto:JSMcGrew(at)aol.com> To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 2:49 PM Subject: Re: RV10-List: Low Drag VHF Antenna I believe the ground plane requirement is covered by the antenna coax connector (included in the antenna kit) which is bolted to the aluminum part of the airframe. There is no mention of ground plane in the sheet Van's included with the antenna kit. Jim In a message dated 4/16/2006 1:55:19 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Jim, Thank you for the response. Very clever installation. One more question, what did you do about a "ground plane"? Is one recommended? Roger ----- Original Message ----- From: JSMcGrew(at)aol.com<mailto:JSMcGrew(at)aol.com> To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 12:01 PM Subject: Re: RV10-List: Low Drag VHF Antenna Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew jsmcgrew(at)aol.com In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 16, 2006
I'll keep this short. The antenna ground plane is critical. If the antenna is mounted on the rear of the fuselage the radiation pattern will greater In the forward direction and visa versa. Thank You Rick Conti The Boeing Company -----Original Message----- From: Roger Standley Sent: Sun Apr 16 16:09:17 2006 Subject: Re: RV10-List: Low Drag VHF Antenna Jim, Makes sense that bolting the connector to the frame does the trick. I didn't receive a sheet with the kit from Vans. Guess that is why the questions. Could you please send a copy of it to me? Thanks a bunch. This list is great! Roger ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 2:49 PM Subject: Re: RV10-List: Low Drag VHF Antenna I believe the ground plane requirement is covered by the antenna coax connector (included in the antenna kit) which is bolted to the aluminum part of the airframe. There is no mention of ground plane in the sheet Van's included with the antenna kit. Jim In a message dated 4/16/2006 1:55:19 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Jim, Thank you for the response. Very clever installation. One more question, what did you do about a "ground plane"? Is one recommended? Roger ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Sunday, April 16, 2006 12:01 PM Subject: Re: RV10-List: Low Drag VHF Antenna Roger, I mounted the low drag VHF comm antenna in the canopy for use with my #2 radio. I have a bent whip on the belly of the plane for my #1 radio. I glassed it to the inside of the canopy top, just aft of the right door. This antenna is supposed to be vertical as much as possible and that is the best place I could find an almost vertical 23" surface. After sanding, filling and painting it just disappeared and looks great. I hooked it up to my VHF handheld and have been listening to airline traffic in and out of Boise from my garage... as far as I can tell it works great. Fiberglass does not blank VHF transmissions - however I believe certain exterior paints (metallics?) might have some effect. The reason I did not want to use this for my primary radio is the considerable blanking you get from the aluminum portion of the fuselage, but it should be fine for a backup. Additionally, I plan on glassing the VOR antenna in the wingtip. That is a horizontally polarized signal and should work great there. Plus there is much less blanking from aluminum structures way out on the wing tip. Pictures attached. Jim 40134 Jim "Scooter" McGrew jsmcgrew(at)aol.com In a message dated 4/16/2006 12:35:32 P.M. Mountain Daylight Time, taildragon(at)msn.com writes: Is anyone using the Van's Low Drag VHF Antenna? Any tips on installation? Roger Standley #40291 - fuselage, wiring ________________________________________________________________________________
Date: Apr 16, 2006
Subject: RV 10 Empenage Kit For Sale
HS complete and riveted. Rudder complete and ready to rivet. Remainder of empenage and rear fuse section still in crateAll parts primed and conditioned properly. Excellent workmanship. Easy assembly, but no time to build. Pictures available. Serious inquiries. Located in north central NJ 07090. $3000 Frank 908-577-1625 f.dombroski(at)yahoo.com ________________________________________________________________________________
Subject: light aircraft shootdown
Date: Apr 16, 2006
Hope our RV10 builder in Ecuador will be careful on his return to the states for OSH. Seems there is a news report of a Panamanian helicopter shooting down a suspected drug runner and killing one of the two occupants. Looked at the maps and see Ecuador is just south of Colombia and must cross Panamanian airspace to reach the US. ________________________________________________________________________________
Date: Apr 16, 2006
Subject: Re: Tru Trak's RV10
Anybody know what kind of a prop they have on it? It's 3 blade is it an MT? or Aero Composite? Deems Davis # 406 Fuse http://deemsrv10.com ________________________________________________________________________________
Date: Apr 17, 2006
If it was at Sin/Fun, it is a three blade MT. On 4/17/06, Deems Davis wrote: > > Anybody know what kind of a prop they have on it? It's 3 blade is it an > MT? or Aero Composite? > > Deems Davis # 406 > Fuse > http://deemsrv10.com > > ________________________________________________________________________________
Subject: Tru Trak's RV10
Date: Apr 17, 2006
It is aero composite. Andrew Barker General Manager TruTrak Flight Systems "You build it...We fly it!" PH:479-751-0250 Ext. 222 www.trutrakap.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Sent: Monday, April 17, 2006 5:33 AM Subject: Re: RV10-List: Tru Trak's RV10 If it was at Sin/Fun, it is a three blade MT. On 4/17/06, Deems Davis wrote: > > Anybody know what kind of a prop they have on it? It's 3 blade is it an > MT? or Aero Composite? > > Deems Davis # 406 > Fuse > http://deemsrv10.com > > ________________________________________________________________________________
Date: Apr 17, 2006
I talked with one of the TruTrak employees about the propeller. The propeller purchased is the most expensive propeller available. Aero Composites. Regards, Jim Ayers In a message dated 04/16/2006 10:05:39 PM Pacific Daylight Time, deemsdavis(at)cox.net writes: --> RV10-List message posted by: Deems Davis Anybody know what kind of a prop they have on it? It's 3 blade is it an MT? or Aero Composite? Deems Davis # 406 Fuse http://deemsrv10.com ________________________________________________________________________________
Date: Apr 17, 2006
Jim Ayers, call me sometime, I have a long lost cousin named Jim Ayers. I wonder????????????? #40545 Tom Deutsch Office 913 451-1222 Fax 913 451-6493 Cell 913 908-7752 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Monday, April 17, 2006 9:40 AM Subject: Re: RV10-List: Tru Trak's RV10 I talked with one of the TruTrak employees about the propeller. The propeller purchased is the most expensive propeller available. Aero Composites. Regards, Jim Ayers In a message dated 04/16/2006 10:05:39 PM Pacific Daylight Time, deemsdavis(at)cox.net writes: =09 Anybody know what kind of a prop they have on it? It's 3 blade is it an MT? or Aero Composite? =09 Deems Davis # 406 Fuse http://deemsrv10.com ________________________________________________________________________________
Date: Apr 17, 2006
Subject: Starting on firewall - gotchas?
I'm starting part prep on my slow build firewall. Anyone have input on what accouterments should be ordered and/or installed while there's still have good access to everything? How 'bout conduit run locations and/or access panel photos? I visited a fellow -10 builder Saturday and he mentioned it might be a good idea to fabricate a baggage floor panel to give access to the step bolts as some have seen them loosen up over time. Is there any concensus on installing the brake line bracket (or not) to allow for parking brake? If a parking brake is installed then what sort of bracket is required? Cheers, Jay ________________________________________________________________________________
Subject: low drag antenna
Date: Apr 17, 2006
Jim Could you send me pictures of your installation of the low drag antenna? Thanks Chris Hukill ________________________________________________________________________________
Date: Apr 17, 2006
Subject: SafeAir static ports & tubing
Is anyone flying using the SafeAir static ports? Searching the archives revealed some interesting comments both pro and con. I like the promise of one-stop-shopping, but would like to hear what others have to say before taking the plunge. Regards, Jay Message: #4747 Subject: Pitot lines - paper of plastic? Date: Jan 18, 2006 From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Personally, I am running SafeAir's tubing all the way to the pitot and the static heads. Can't remember what it's made of but it is plastic. They use the exact same tubing that is used for air brake lines so I'm guessing that they will be more than sufficient. I mainly went with theirs because it came with all of the connectors along with static ports. If I had to do it again I would probably just use 1/4" polyethylene tubing that you can get from any home improvement store. PEX (polyethylene) tubing, and it's fast on connectors, are more than adequate and I have yet to have a leak in one with water pressures around 100psi. Not to mention it is now being used as primary water lines in homes and is more commonly used as the hot glycol tubing in radiant concrete floors. Michael Sausen -10 #352 Fuselage ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Re: SafeAir static ports & tubing
Date: Apr 17, 2006
I have installed the SafeAir1 kit in my RV-9A and I am glad I did. When I had my pitot-static test done, the guy told me that the #1 problem with the static systems in RVs is the use of a pop rivet for the static port. Mine are flush mounted (installed with proseal). My pitot static system checked out perfectly the first time. Additionally, the kit includes "quick connect" T-fittings, which make maintenance an easy task. I like them a lot. Mike Schipper RV-9A - N63MS - Flying www.my9a.com On Apr 17, 2006, at 4:57 PM, Jay Brinkmeyer wrote: > > > Is anyone flying using the SafeAir static ports? Searching the > archives > revealed some interesting comments both pro and con. I like the > promise of > one-stop-shopping, but would like to hear what others have to say > before taking > the plunge. > > Regards, > Jay > > > Message: #4747 > Subject: Pitot lines - paper of plastic? > Date: Jan 18, 2006 > From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > > Personally, I am running SafeAir's tubing all the way to the > pitot and the > static heads. Can't remember what it's made of but it is plastic. > They use the > exact same tubing that is used for air brake lines so I'm guessing > that they > will be more than sufficient. I mainly went with theirs because it > came with > all of the connectors along with static ports. If I had to do it > again I would > probably just use 1/4" polyethylene tubing that you can get from > any home > improvement store. PEX (polyethylene) tubing, and it's fast on > connectors, are > more than adequate and I have yet to have a leak in one with water > pressures > around 100psi. Not to mention it is now being used as primary water > lines in > homes and is more commonly used as the hot glycol tubing in radiant > concrete > floors. Michael Sausen -10 #352 Fuselage > > __________________________________________________ > > ________________________________________________________________________________
Subject: Twenty Nine Palms
Date: Apr 17, 2006
We had a nice flight down. It was a little bumpy all of the way down. We flew at 13,500 to Yerington for fuel and then at 11,500 into Bullhead City for the night. We landed after dark. That MX20 terrain feature was just the ticket with all of the mountains around that field. Short 50 min flight to TNP the next day. Leaving tomorrow am and flying on the west side of the mountains this time. I have written down all of my performance numbers and will post them when I get back. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Wednesday, April 12, 2006 5:59 PM Subject: RE: RV10-List: Twenty Nine Palms Stay well away from the leeward back burbles, the turbulence can be teeth rattling. Be mindful of correct ridgeline crossing heading and altitudes. I had a friend who was knocked out cold from a smack from both an errant mike and baggage as we ventured through the pass. Early AM is best. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Tuesday, April 11, 2006 4:29 PM Subject: Re: RV10-List: Twenty Nine Palms Nothing special about the airport itself, I took my multiegine training nearby @ salton sea (below sea level) and we used it for some IFR approaches. Depending upon your route takes you pass through the Banning Pass, just north of Palm Springs, you can expect some bumps, particularly if late in the day or if there is any wind (very common). if you come down through the Calif inland valleys and come on the backside of mtns you will avoid that and most of the Trafic associated with the LAX and Ontario/Riverside approaches. Deems Davis # 406 Fuse http://deemsrv10.com/ Randy DeBauw wrote: > I am heading to Twenty Nine Palms Ca. this Friday. Is there anyone who > has used that airport? Any thing I should know about it. Thanks, Randy > ________________________________________________________________________________
Date: Apr 17, 2006
Andrew, there are a lot of lurkers on this list that would love to here the performance specs when Jim is ready. There has yet to be a comprehensive posting of the MT 3 blade performance and many of the 2 blade Hartzell's are just as silent. This will be the hottest topic at OSH '06. I for one would like to hear how Jim likes it. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Andrew Barker Sent: Monday, April 17, 2006 6:59 AM Subject: RE: RV10-List: Tru Trak's RV10 It is aero composite. Andrew Barker General Manager TruTrak Flight Systems "You build it...We fly it!" PH:479-751-0250 Ext. 222 www.trutrakap.com -----Original Message----- ________________________________________________________________________________
Date: Apr 17, 2006
The three blade MT is quiet, runs smooth and looks cool!!! What else do you want!! ________________________________________________________________________________
Date: Apr 17, 2006
Speed! Mark Chamberlain wrote: > > The three blade MT is quiet, runs smooth and looks cool!!! What else > do you want!! > > > http://www.matronics.com/Navigator?RV10-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Apr 17, 2006
On Apr 17, 2006, at 6:38 PM, Mark Chamberlain wrote: > <10flyer(at)verizon.net> > > The three blade MT is quiet, runs smooth and looks cool!!! What > else do you want!! > Performance numbers. -Sean #40303 (Closing Wings) ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: fuel caps
Date: Apr 17, 2006
Anyone who's received a QB kit recently - did you get the $100 fuel caps or the $105 locking fuel caps? Rob #392 ________________________________________________________________________________
Date: Apr 17, 2006
Subject: Re: Starting on firewall - gotchas?
Jay, Mike Howe and several others have what seems to be the standard for the parking brake valve. We used the bracket supplied by Vans for I think is a fuel pump on the O-540 vs. the IO-540 where you don't need the bracket. I did mine after the firewall was complete but you can save time by not putting the supplied brake line bracket in place then having to remove it and fill the holes. Deem's Davis has some good slow build pic's on his site too along with some of his "Gotchas" It's weird for me to check out his site because his project really mirrors my project to include the areas he removed the plastic and the primer color, now he is using the same dolly for the Fuselage so it looks even more like my garage! You can make some pretty nice rivets using the C-Frame to in effect back rivet areas where it is impractical to use the back rivet plate. Run your brake lines and transponder ant. (if your mounting it under the tunnel) after the bottom skin is on prior to joining the mid section. There are a lot of areas to watch out for over the next few chapters. Especially the riveting of the upper/lower fwd longerons to the firewall brackets. There is critical edge distance that clamping will prevent problems when you get to that step. If you going to use metal eyeball penetrations for your engine controls, don't follow Van's "Drill 3 each 5/8" holes in the recess", wait until you get the eyeballs to get proper spacing. That all I can think of currently....I could go page by page with you and point out a whole bunch of "and oh yeah on this step" stuff. Rick S. 40185 Fuse/Finish ________________________________________________________________________________
Date: Apr 18, 2006
How about a Hartzel blended airfoil three blade? Tom Deutsch -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Chamberlain Sent: Monday, April 17, 2006 8:38 PM Subject: Re: RV10-List: Tru Trak's RV10 <10flyer(at)verizon.net> The three blade MT is quiet, runs smooth and looks cool!!! What else do you want!! ________________________________________________________________________________
Subject: RE: RV10-List Digest: Help on Engine Overhaul Options
Date: Apr 18, 2006
My I/O 540 C4B5/E4B5 (Carb or FI - haven't decided yet) needs a IRAN and test cell run. I had the engine overhauled by a local known engine rebuilder A&I 5 years ago. The Gentleman has subsequently moved to Florida and has passed away and I have little to no proper paperwork on the work he did. He was in the process of moving when he did the overhaul and his records were shipped along with the contents of his hanger. If I sell the engine I have no real paperwork to go along with it. I know the case, crank, and cam went out to Oklahoma because I did the shipping and return to the mechanic (along with the paperwork....) Can anyone recommend any options or shops that do good work ? The usual suspects want over 20,000$ to IRAN the engine which I feel is a little pricy. ________________________________________________________________________________
Date: Apr 18, 2006
How about 90 pounds. Regards, Jim Ayers In a message dated 04/18/2006 6:38:20 AM Pacific Daylight Time, deutscht(at)rhwhotels.com writes: --> RV10-List message posted by: "Tom Deutsch" How about a Hartzel blended airfoil three blade? Tom Deutsch ________________________________________________________________________________
Subject: Cowl fasteners
Date: Apr 18, 2006
Where are people coming down on the decision of sticking with Van's cowl "hinge" design, or going with Cam-lok type cowl fasteners? Of the flying folks, anyone like to comment on the ease of use of the hinge fastener design? Thanks, TDT 40025 ________________________________________________________________________________
Date: Apr 18, 2006
Subject: Re: This thread is played out
Date: Apr 18, 2006
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
I haven't yet started on my RV-10, but I can add to what Tim said about the hinges. My RV-4 has the same type of cowling design, with piano hinges. It has been flying since 1989 and the hinges have not shown any appreciable wear. I concur with Tim that the bottom cowl is a real pain to install by yourself, but with help it is not too bad. Unfortunately, with the cheek cowls of the RV-4, it is not an option to leave the lower cowl in place for oil changes - just not enough room to work. Jack Phillips Raleigh, NC -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Tuesday, April 18, 2006 11:23 AM Subject: Re: RV10-List: Cowl fasteners I was originally a big proponent of the concept of switching to Camloc's. I didn't, because that would have slowed down my build while trying to figure out exactly how I wanted to do it, using the skybolt set, or smaller ones, and how many and for how much cost. They aren't cheap, but they are convenient. Now that I've had my cowl on and off a few times, I can comment better on the hinges though. I'm very surprised at how easy it is to deal with the hinges. The top ones you just loosen the holding bracket and pull the pins, very quick. The horizontal ones are a simple straight-in and out, very easy. The bottom cowl side pins are also pretty simple. I did NOT go with lower pins, but used nutplates and screws due to a large number of comments on other RV's about how the eyelits wear on the hinges. I'm glad I went the route I did for future issues. So the cowl is very easy to remove and re-install, in regards to the hinge pins. I do get a little black streaking coming out my cowl seam from the aluminum of the hinges. I don't know that it will get better, or worse, over time, but I'm sure there will eventually be more play in the hinges. Long-term I can see the hinges possibly being an issue for wear, and replacing them might not be fun, and would maybe require a cowl repaint. But I think it would be a long time to get to that point of wear. As far as the cowl going on and off, the lower cowl is a real pain. There isn't much clearance to get it up and down, with the spinner installed, and the FAB/inlet stuff isn't fun to align and keeps the cowl from going on smoothly. It's a hard job to do the lower cowl alone without banging things up....I just did it yesterday. The top one is simple. I did just change oil again too, with the lower cowl on. You have to protect your hands from the hot crankcase and exhaust, but it's definitely do-able with a quick-disconnect. I got a set from ACS that had the valve and a matching latch-on hose that works really well, and was pretty cheap I think. For those deciding on props, you may have noticed the post today regarding the 3 blade aerocomposite prop and it being hard to remove and replace the lower cowl. I personally haven't done a 3-blade, but I can definitely see the issue. Even with my 2-blade, I have to make sure my blades are horizontal or it can be a bear getting the cowl off and on again. I can't even imagine how it would be with 3 blades, although I'm sure it's something that 3-blade owners will manage fine. I'm betting that if 3-blade owners gave an honest statement, they'd say that cowl removal sucks, but they love the prop. I'd be suspicious if someone just says "no problem, easy"... just call a spade a spade....doesn't mean the prop, or the choice in props was bad. Just means there's a little more story to go along with it. So all in all, I'm more happy with the hinges than I thought I'd be, although I recognize that some day I might have to repaint the cowl after a hinge repair. The cowl definitely looks the best with hinges, but camlocs aren't awful looking either...just don't try to paint them. Tim Olson - RV-10 N104CD - Flying Working together. For life.(sm) or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. ________________________________________________________________________________
Date: Apr 18, 2006
I like speed as well!! However, lets say the two blade is 10kts faster(??). On a 3000nm trip the two blade guy will get there about an hour earlier. That's nice, but the trade-offs you get with the three blade might not make that 1 hr worth it. There are definately advantages/dissadvantages to both. The question becomes prioritizing them, speed/weight/smoothness(on your 40k engine)/ climb perf./ and of course looks. I will admit, taking the bottom cowl off with the three blade is not easy. So far I am very happy with my three blade MT. I know other guys are very happy with there blended Hartzells. Fortunately for all of us, the airplane is still the best part of this whole discussion. Cheers, Mark (55hrs) ________________________________________________________________________________
Date: Apr 18, 2006
Subject: Re: Cowl fasteners
Hey Tim, I have the Camloc system on my 10. The big advantage is that I can easily put on/ take off top and bottom cowl by myself. I can also do it in a matter of minutes. Disadvantages are obviously the cost, not as clean looking, and almost impossible not to eventually get a little scalloping between the camlocs around the firewall. I never have used pins before, but I can tell you the other guy on the field with a 10 has them and needs help putting the cowl on due to its size. He definately has a cleaner look!! ________________________________________________________________________________
Date: Apr 18, 2006
Mark, what is the issue in removing the bottom cowl with a 3 bld prop? Deems Mark Chamberlain wrote: > > I like speed as well!! However, lets say the two blade is 10kts > faster(??). On a 3000nm trip the two blade guy will get there about an > hour earlier. That's nice, but the trade-offs you get with the three > blade might not make that 1 hr worth it. There are definately > advantages/dissadvantages to both. The question becomes prioritizing > them, speed/weight/smoothness(on your 40k engine)/ climb perf./ and of > course looks. I will admit, taking the bottom cowl off with the three > blade is not easy. So far I am very happy with my three blade MT. I > know other guys are very happy with there blended Hartzells. > Fortunately for all of us, the airplane is still the best part of this > whole discussion. Cheers, Mark (55hrs) > > > http://www.matronics.com/Navigator?RV10-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Apr 18, 2006
Andrew, when you are talking about your speed; are you discussing a GPS--4 corner run or a ground track run? What type of test are you running...it could help us understand the speed numbers. ________________________________________________________________________________
Date: Apr 18, 2006
Guys, go to this web site regarding true airspeed testing. I've used it for years. It's easy and very accurate. http://reacomp.com/true_airspeed/ Tom Deutsch Vice President RHW Development and Construction Services 6704 W. 121st Street Overland Park, Kansas 66209 Office 913 451-1222 Fax 913 451-6493 Cell 913 908-7752 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Tuesday, April 18, 2006 1:51 PM Subject: Re: RV10-List: Tru Trak's RV10 Andrew, when you are talking about your speed; are you discussing a GPS--4 corner run or a ground track run? What type of test are you running...it could help us understand the speed numbers. ________________________________________________________________________________
Date: Apr 18, 2006
We did a 4 corner run. Andrew Barker General Manager TruTrak Flight Systems "You build it...We fly it!" PH:479-751-0250 Ext. 222 www.trutrakap.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Tuesday, April 18, 2006 1:51 PM Subject: Re: RV10-List: Tru Trak's RV10 Andrew, when you are talking about your speed; are you discussing a GPS--4 corner run or a ground track run? What type of test are you running...it could help us understand the speed numbers. ________________________________________________________________________________
Date: Apr 18, 2006
Subject: Throttle, Prop, and Mixture cable slack
Fellow listers, I'm working on my firewall foreward and since I had already made some decisions before the firewall foreward kit was available, I can't use the stock locations for my throttle and mixture cables. The prop cable went in to the stock location nicely with the one hole eyeball fitting. There seems to be just a little slack in that cable - just enough to allow flexibility to keep it out of the way. How much should I have? Upon measuring the cables that I got for the throttle and mixture after putting them in where I could, I have 6" too much throttle cable and 7" too much mixture cable. These are straight shot from the panel/console to the eyeball passthrough the firewall. on the firewall side, I have sufficient 'Lycoming wet dog shake room'. I'm thinking on the aft side of the firewall, I don't need much wiggle room other than to avoid stuff that could get in the way and wear the cable. Your thoughts please, Ralph RV6AQB N822AR @ N06 - fun firewall foreward! ________________________________________________________________________________
Date: Apr 18, 2006
Take a peek at Randy Lervold's site, he is using the SKybolt C-loks. I am leaning this way although not flying yet. He specs out the correct PN's of the recepticles, studs etc. I think they are a better but albeit a tad more expensive than the hinge route. Heres a link: http://www.romeolima.com/RV3works/Airframe/airframe.htm I really like the way they look and should outlast the hinges without any problem. Rick S. 40185 Fuse/Finish ________________________________________________________________________________
Date: Apr 18, 2006
Subject: Model
Date: Apr 18, 2006
I have a guy here in Ecuador who makes little models of planes like Tim Olson has of his -10. He has made them for us and the workmanship is first rate, even down to the antennas. He has 3 -10=92s made, just needs to be painted. If anybody is interest Jesse Saint I-TEC, Inc. HYPERLINK "mailto:jesse(at)itecusa.org"jesse(at)itecusa.org HYPERLINK "http://www.itecusa.org"www.itecusa.org 352-465-4545 -- ________________________________________________________________________________
Subject: Flap Motor
Date: Apr 18, 2006
Members, Does anyone know the power required for the Vans flap motor? Ideally I'd like to know the max steady state current draw in flight and the circuit breaker rating? Thanks Dave Hertner #40164 Emp Complete QB Fus and Wings Ordered ________________________________________________________________________________
Date: Apr 18, 2006
Maybe this is specific to how my cowl worked out, but once I've posisitioned the bottom half ( It sorta hangs on the baffle material around the air box) I can easily fasten the top camloc on each side of the bottom cowl. It then hangs by itself. Now it is a simple task to position the top and then go through a sequence of fastening each camloc with a quarter turn. Of course I still have the screws on either side of the spinner and under the cowl near the fuselage. Mark ________________________________________________________________________________
Date: Apr 18, 2006
The cowl is so big that the top ( side ) edges of the bottom cowl have trouble clearing the two blades facing 4 & 8 o'clock position. I put plastic guards on those two blades before I pull the cowl to prevent damage to them. I have now figured out to lengthen the slot in the bottom cowl over the nose gear strut fairing to allow the cowl to slide up that fairing with more clearance. This gives more clearance on the blades. I will eventually make a plate to cover this elongated slot. I have seen several RV-9As with this set-up. Mark. ________________________________________________________________________________
Subject: Re: Flap Motor
Date: Apr 18, 2006
If you are using the flap positioning system they specify a 5A breaker however I had already installed a 10A breaker. I have since returned the FPS to Van's and purchased a DPDT switch from McMaster Carr which is momentary on for down and on-off for up and center position off (flaps not moving). ----- Original Message ----- From: David Hertner To: RV10-List(at)matronics.com Sent: Tuesday, April 18, 2006 4:51 PM Subject: RV10-List: Flap Motor Members, Does anyone know the power required for the Vans flap motor? Ideally I'd like to know the max steady state current draw in flight and the circuit breaker rating? Thanks Dave Hertner #40164 Emp Complete QB Fus and Wings Ordered ________________________________________________________________________________
Subject: Rear floor pans
Date: Apr 19, 2006
Hi all, Listers have previously reported some issues with 'impossible rivets' on the rear floor pans - but I can't even get to that point. I am having some trouble fitting the F-1016C rear floor pans. It seems a fair bit of force is required to insert these panels to get the flanges past the seat belt attachand point. Once they are in place, there does not appear to be any way that they will come out - especially if there are any shop heads on the F1005A assembly. Has anyone else had trouble here? Is there a trick to inserting/removing these? thanks in advance Ron #187 fuse, finishing on the way. ________________________________________________________________________________
Date: Apr 19, 2006
Subject: Re: Rear floor pans
Just did those the other day. The key is to go slowly to avoid bending them. If possible, have a helper to force apart the side ribs so you can get the floor pans past the seatbelt anchors. To get them out, I put cleco's into the #19 nutplate holes, and lifted it up enough to get several into the #30 holes. I took some popsicle sticks and ground the ends to make little wedges and used them along the sides and back to help get the floor pan past the rivets and ribs. PJ RV-10 #40032 McGANN wrote: > Hi all, > > Listers have previously reported some issues with 'impossible rivets' on the rear floor pans - but I can't even get to that point. I am having some trouble fitting the F-1016C rear floor pans. It seems a fair bit of force is required to insert these panels to get the flanges past the seat belt attachand point. Once they are in place, there does not appear to be any way that they will come out - especially if there are any shop heads on the F1005A assembly. Has anyone else had trouble here? Is there a trick to inserting/removing these? > > thanks in advance > > Ron > #187 > fuse, finishing on the way. > ________________________________________________________________________________
Date: Apr 19, 2006
they lift out with difficulty from the rear; use several pieces of .020 aluminum strips so that the rear flange slip over the rear spar forward edge. Make sure you pop the holes for the forward flange through the main spar web before removing them now; that way you will be able to clean and deburr before final rear floor installation. ----- Original Message ----- From: "McGANN, Ron" <ron.mcgann(at)baesystems.com> Sent: Wednesday, April 19, 2006 4:17 AM Subject: RV10-List: Rear floor pans Hi all, Listers have previously reported some issues with 'impossible rivets' on the rear floor pans - but I can't even get to that point. I am having some trouble fitting the F-1016C rear floor pans. It seems a fair bit of force is required to insert these panels to get the flanges past the seat belt attachand point. Once they are in place, there does not appear to be any way that they will come out - especially if there are any shop heads on the F1005A assembly. Has anyone else had trouble here? Is there a trick to inserting/removing these? thanks in advance Ron #187 fuse, finishing on the way. ________________________________________________________________________________
Date: Apr 19, 2006
You're right!! It was a wag! I was just trying to say that I personally don't care about top speed all that much. I should have known that some of you more technically minded people would call me on it. ________________________________________________________________________________
Subject: RV Assembly Workshop
Date: Apr 19, 2006
As a prospective RV-10 builder, I have a question of this group: Have any of you taken the EAA Sportair Workshop on RV Assembly, and if so, how helpful was it? I've built an airplane before, but have not done a lot of sheetmetal work, and my wife has only bucked a handful of rivets. I can teach her, but wondered if this group recommends the workshops or to just dive in and get started. Jack Phillips Raleigh, NC Working together. For life.(sm) or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. ________________________________________________________________________________
Date: Apr 19, 2006
Subject: Re: RV Assembly Workshop
Jack, I built a couple of wood, tube and fabric planes before the 10 but had not done much metal work. I took the workshop and came out feeling very comfortable with my new found metal skills and went to work. Phil 40122, interior and final plumbing > >As a prospective RV-10 builder, I have a question of this group: Have >any of you taken the EAA Sportair Workshop on RV Assembly, and if so, >how helpful was it? I've built an airplane before, but have not done a >lot of sheetmetal work, and my wife has only bucked a handful of rivets. >I can teach her, but wondered if this group recommends the workshops or >to just dive in and get started. > >Jack Phillips >Raleigh, NC > >Working together. For life.(sm) >_________________________________________________ > >This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the > >Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - > > > > > > ________________________________________________________________________________
From: "Rich & Karol Hansen" <karolamy(at)adelphia.net>
Subject: Rudder Position/Strobe Mounting Plate
Date: Apr 19, 2006
Has anyone come across a mounting plate or bracket that will fit inside the rudder fairing and secure the A500 Position/Strobe? I had this same problem on my 6A ten years ago and DID find one! It has worked great, was easy to install and comes with the two nuts welded to it to secure the A500 assembly. Cannot find receipt where I got it - was only 10 or 15 dollars. Any help would be appreciated. Rich Hansen ________________________________________________________________________________
Subject: rear wing spar dimpled?
Date: Apr 19, 2006
ok all, here's a dumb question... i'm off all week, working on the airplane. i'm reading and re-reading the directions for the bottom wing skin install, and i don't see anywhere where it says to dimple the rear wing spar. is this just one of those things that they expect reasonably intelligent people to figure out on their own? what does that say about me? on a lighter note, we finished the second fuel tank yesterday! i could positively freak out with joy. by the by, i used the Skysports capacitive fuel senders, and they look like they'll work great. i've got them bent so they go diagonally through the inboard two bays, so they should get a pretty accurate measurement. cj #40410 wings www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: bottom wing skin overlap
Date: Apr 19, 2006
while i'm on the subject - i'm looking at the overlap in the bottom wing skins and wondering if i really want to work the joint as fully as i did the top skins. anyone have any thoughts or opinions on this? cj #40410 wings www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: Re: Rudder Position/Strobe Mounting Plate
Date: Apr 19, 2006
Rich, I made a mounting plate from .040 scrap and used nutserts ( #4 ) in the plate corresponding to the mounting holes in the light. Epoxied the plate onto the rudder fairing. Looks like it will work great! Mounting plate fits just inside the outer shell of the light. John Hasbrouck #40264 fuselage ________________________________________________________________________________
Date: Apr 19, 2006
> > As a prospective RV-10 builder, I have a question of this group: Have > any of you taken the EAA Sportair Workshop on RV Assembly, and if so, > how helpful was it? I've built an airplane before, but have not done a > lot of sheetmetal work, and my wife has only bucked a handful of rivets. > I can teach her, but wondered if this group recommends the workshops or > to just dive in and get started. Maybe I get a minute of fame here for saying that Dan Checkoway and I took the RV building workshop together back in 2001 (even parked my C182 next to his Mooney when we both flew into Corona for the event.) I was already about a month into building the -7 and have to say I didn't really learn that many new manual skills, though it was a great place to ask newbie questions. However, the best part was that I took my wife along and it made a dramatic difference in her ownership of the project and willingness to serve as "Rosie the Riveter." For that alone it was worth the price of admission. -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 19, 2006
I did the regular sheetmetal workshop instead of the RV one. Good class. I've taught my wife to buck rivets so you're already way ahead.... Rob #392 Awaiting QB ship. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: Wednesday, April 19, 2006 11:55 AM Subject: RV10-List: RV Assembly Workshop As a prospective RV-10 builder, I have a question of this group: Have any of you taken the EAA Sportair Workshop on RV Assembly, and if so, how helpful was it? I've built an airplane before, but have not done a lot of sheetmetal work, and my wife has only bucked a handful of rivets. I can teach her, but wondered if this group recommends the workshops or to just dive in and get started. Jack Phillips Raleigh, NC Working together. For life.(sm) This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - ________________________________________________________________________________
Date: Apr 19, 2006
Talk to David Czachorowski I hear that he is looking into supplying this type of bracket. Dave Hertner ----- Original Message ----- From: Rich & Karol Hansen To: rv10-list(at)matronics.com Sent: Wednesday, April 19, 2006 1:39 PM Subject: RV10-List: Rudder Position/Strobe Mounting Plate Has anyone come across a mounting plate or bracket that will fit inside the rudder fairing and secure the A500 Position/Strobe? I had this same problem on my 6A ten years ago and DID find one! It has worked great, was easy to install and comes with the two nuts welded to it to secure the A500 assembly. Cannot find receipt where I got it - was only 10 or 15 dollars. Any help would be appreciated. Rich Hansen ________________________________________________________________________________
Subject: panel
Date: Apr 19, 2006
Anyone willing to relate how much they paid to get their panels done for them? Thinking about using Stein or others and wondering what all of you have paid.. Rob #392 ________________________________________________________________________________
Date: Apr 19, 2006
Rich and Karol: All I did was mount the strobe/nav. lights using the screws supplied but then epoxyed two small lock nuts inside the fairing after screwing them down semi-tight. Pulled the screws after partial setup of the fiberglass/epoxy---after drying can now remove/replace the fixture at will. Jay ----- Original Message ----- From: Rich & Karol Hansen To: rv10-list(at)matronics.com Sent: Wednesday, April 19, 2006 1:39 PM Subject: RV10-List: Rudder Position/Strobe Mounting Plate Has anyone come across a mounting plate or bracket that will fit inside the rudder fairing and secure the A500 Position/Strobe? I had this same problem on my 6A ten years ago and DID find one! It has worked great, was easy to install and comes with the two nuts welded to it to secure the A500 assembly. Cannot find receipt where I got it - was only 10 or 15 dollars. Any help would be appreciated. Rich Hansen ________________________________________________________________________________
Subject: Re: panel
Date: Apr 19, 2006
Stein charges $5,000.00 for doing a panel, unless he has gone up on his price, and worth every penny. Russ Daves ----- Original Message ----- From: Robert G. Wright To: rv10-list(at)matronics.com Sent: Wednesday, April 19, 2006 6:10 PM Subject: RV10-List: panel Anyone willing to relate how much they paid to get their panels done for them? Thinking about using Stein or others and wondering what all of you have paid.. Rob #392 ________________________________________________________________________________
Date: Apr 19, 2006
Subject: Re: panel
Rob - you'll get what you pay for. I paid about $55k for mine from Avionics Systems. Think they have a picture of mine posted now. First time I've ever held a Lexus in my hands...... But, I designed and got what I asked for. Could not have done this same panel myself. Grumpy no not post In a message dated 4/19/2006 6:15:28 PM Central Standard Time, armywrights(at)adelphia.net writes: Anyone willing to relate how much they paid to get their panels done for them? Thinking about using Stein or others and wondering what all of you have paid =E2=80=A6. Rob #392 ________________________________________________________________________________
Subject: Re: panel
Date: Apr 19, 2006
Rob, The price to get the panel done will vary all over the place depending on the equipment ordered, etc. etc. I made up my equipment list and then sent the same email request for quotes to all the major shops so that I could compare apples to apples. The bids were amazingly close, so I ended up going with the folks I thought were most experienced and that I felt most comfortable with. I think any of the established major shops would do fine. You will be working with them extensively before the panel is done so look for folks you can work comfortably with. do not archieve Dick Sipp 40065 ----- Original Message ----- From: Robert G. Wright To: rv10-list(at)matronics.com Sent: Wednesday, April 19, 2006 7:10 PM Subject: RV10-List: panel Anyone willing to relate how much they paid to get their panels done for them? Thinking about using Stein or others and wondering what all of you have paid.. Rob #392 ________________________________________________________________________________
Date: Apr 19, 2006
In a message dated 4/19/06 1:04:26 PM Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes: wondered if this group recommends the workshops or to just dive in and get started. I spent an hour last year at Sun n Fun in the metal workshop tent, doing a few rivets, flush rivets, removing rivets (that is a good one to learn), then get started. The kit is excellent~!. I built the tool box kit from Van's.... fun project to do, but just get started after you drive a few practice rivets. Van's send you scrap metal in the empennage kit. Drill lots of holes in it and de bur, then rivet with the size you will use for practice. Us the rivet check gauge to verify that your shop head is coming out the right size. Then drill a few rivets out for practice. Simple! Steve Stephen Blank RV-10 Builder / Cessna 170B flyer 766 SE River Lane Port St. Lucie, FL 34983 772-475-5556 cell ________________________________________________________________________________
Date: Apr 19, 2006
I went to Synergy Air's builder's basic course (1 day) and would highly recommend it. I had started on the tail kit when I went and was doing fine. After the class, however, my confidence level, workmanship and speed went up 10 fold. There are so many little tricks you learn that can make an otherwise tedious/painful/difficult job a piece of cake. I also attended the 2 day fiberglass and painting class given at Synergy. That has certainly helped me get through the canopy and cowling work rapidly. I think I have made back all the time and money that I invested in the classes. Jim 40134 In a message dated 4/19/2006 8:22:35 P.M. Mountain Daylight Time, LIKE2L OOP(at)aol.com writes: In a message dated 4/19/06 1:04:26 PM Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes: wondered if this group recommends the workshops or to just dive in and get started. I spent an hour last year at Sun n Fun in the metal workshop tent, doing a few rivets, flush rivets, removing rivets (that is a good one to learn), then get started. The kit is excellent~!. I built the tool box kit from Van's.... fun project to do, but just get started after you drive a few practice rivets. Van's send you scrap metal in the empennage kit. Drill lots of holes in it and de bur, then rivet with the size you will use for practice. Us the rivet check gauge to verify that your shop head is coming out the right size. Then drill a few rivets out for practice. Simple! Steve Stephen Blank RV-10 Builder / Cessna 170B flyer 766 SE River Lane Port St. Lucie, FL 34983 772-475-5556 cell ________________________________________________________________________________
Date: Apr 20, 2006
Thanks for all the input. I think we'll try to go to the RV Assembly workshop they are offering in OSH the last week of August. We'll run up there in the RV-4 and swing by Mackinac Island on the way home for Karen to visit a friend. I like the idea of getting her to feel ownership in the RV-10 project (although every time we take a long trip in the RV-4 she asks "when are we going to build a bigger airplane?"). If I can pick up just one tip or technique that I don't know already it is probably worth it. Jack Phillips Raleigh, NC -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com Sent: Wednesday, April 19, 2006 11:24 PM Subject: Re: RV10-List: RV Assembly Workshop I went to Synergy Air's builder's basic course (1 day) and would highly recommend it. I had started on the tail kit when I went and was doing fine. After the class, however, my confidence level, workmanship and speed went up 10 fold. There are so many little tricks you learn that can make an otherwise tedious/painful/difficult job a piece of cake. I also attended the 2 day fiberglass and painting class given at Synergy. That has certainly helped me get through the canopy and cowling work rapidly. I think I have made back all the time and money that I invested in the classes. Jim 40134 In a message dated 4/19/2006 8:22:35 P.M. Mountain Daylight Time, LIKE2LOOP(at)aol.com writes: In a message dated 4/19/06 1:04:26 PM Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes: wondered if this group recommends the workshops or to just dive in and get started. I spent an hour last year at Sun n Fun in the metal workshop tent, doing a few rivets, flush rivets, removing rivets (that is a good one to learn), then get started. The kit is excellent~!. I built the tool box kit from Van's.... fun project to do, but just get started after you drive a few practice rivets. Van's send you scrap metal in the empennage kit. Drill lots of holes in it and de bur, then rivet with the size you will use for practice. Us the rivet check gauge to verify that your shop head is coming out the right size. Then drill a few rivets out for practice. Simple! Steve =09 Stephen Blank RV-10 Builder / Cessna 170B flyer 766 SE River Lane Port St. Lucie, FL 34983 =09 772-475-5556 cell Working together. For life.(sm) or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. ________________________________________________________________________________
Date: Apr 20, 2006
With no RV builders in my area as a resource, I obtained some tools and reference materials prior to ordering my kit to self-instruct. Just prior to my tail kit arriving I went to the Sportair Workshop in Oshkosh for the sheet metal class. I learned some very useful techniques and tips, and the biggest value was reinforcing what I had already learned, and the confidence that I wasn't launching into it with some terrible practices. While there I heard great reviews for the Electrical workshop and will probably look for an opportunity to attend that as well. By the way, a recent post had someone out east trying to sell their tail kit. FYI Phillips, Jack wrote: > >As a prospective RV-10 builder, I have a question of this group: Have >any of you taken the EAA Sportair Workshop on RV Assembly, and if so, >how helpful was it? I've built an airplane before, but have not done a >lot of sheetmetal work, and my wife has only bucked a handful of rivets. >I can teach her, but wondered if this group recommends the workshops or >to just dive in and get started. > >Jack Phillips >Raleigh, NC > >Working together. For life.(sm) >_________________________________________________ > proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. > > > > > > > > > > ________________________________________________________________________________
Date: Apr 20, 2006
Yeah, I saw that post about the tail kit for sale. Price was very close to the kit price, and I would rather just do it myself than have to deal with someone else's workmanship. When I was looking for an RV-4 to buy I looked at 7 airplanes before I found one with really good workmanship. I learned to look at the tail since that is always the first part built and any flaws usually show there. I figure building the tail will give me the experience necessary to tackle the wings and fuselage. Jack Phillips -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jwik Sent: Thursday, April 20, 2006 8:53 AM Subject: Re: RV10-List: RV Assembly Workshop With no RV builders in my area as a resource, I obtained some tools and reference materials prior to ordering my kit to self-instruct. Just prior to my tail kit arriving I went to the Sportair Workshop in Oshkosh for the sheet metal class. I learned some very useful techniques and tips, and the biggest value was reinforcing what I had already learned, and the confidence that I wasn't launching into it with some terrible practices. While there I heard great reviews for the Electrical workshop and will probably look for an opportunity to attend that as well. By the way, a recent post had someone out east trying to sell their tail kit. FYI Phillips, Jack wrote: > >As a prospective RV-10 builder, I have a question of this group: Have >any of you taken the EAA Sportair Workshop on RV Assembly, and if so, >how helpful was it? I've built an airplane before, but have not done a >lot of sheetmetal work, and my wife has only bucked a handful of rivets. >I can teach her, but wondered if this group recommends the workshops or >to just dive in and get started. > >Jack Phillips >Raleigh, NC > >Working together. For life.(sm) >_________________________________________________ > >This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete > >Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands > > > > > > > > > Working together. For life.(sm) or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. ________________________________________________________________________________
Date: Apr 19, 2006
Subject: 540 power settings
Just some general information on three different 540 power settings. This information was obtained in an unfinished (unpainted and some fairings missing) RV-10 with a 3 blade MT Propeller. The data was taken at 8,000' density altitude, at full throttle (around 23' MP) and leaned consistently: 2500 RPM 20 gph (Van's standard cruise performance power setting) 2300 RPM 15 gph - airspeed was 1 knot faster than at the 2500 RPM setting. 2100 RPM 12 gph - airspeed was 6 knots slower than at the 2500 RPM setting. Making the following assumptions: 60 gallons of fuel usable less a 1/2 hour reserve, and using Van's Aircraft RV-10 cruise performance of about 200 mph. At 2500 RPM, there is 2 1/2 hours of fuel available for a range of 500 miles. At 2300 RPM, there is 3 1/2 hours of fuel available for a range of just over 700 miles. At 2100 RPM, there is 4 1/2 hours of fuel available for a range of almost 870 miles. Or . . . At 2100 RPM, after flying for 2 1/2 hours and covering 480 plus miles, you would still have about half of your fuel remaining. According to MT Propeller (for a "natural composite" MT Propeller); running a Lycoming 200 RPM below the manifold pressure is acceptable. The 2100 RPM 23" MP power setting would be an acceptable cruise power setting with a "natural composite" MT Propeller. A commonly accepted lowest RPM power setting for an aluminum blade propeller would be 2300 RPM at 23" MP. (For anyone that is interested, MT Propeller does manufacture aluminum blade propellers.) Regards, Jim Ayers PS A reduction in airspeed with a higher RPM is expected. As an approximation, the RPM increase is linear, but the horsepower increase requirement is at a power of 2. ________________________________________________________________________________
Date: Apr 20, 2006
Subject: Re: panel
I did most of the wiring in my panel as far as switches and breakers. I installed an Approach Hub system after having the panel cut and painted. I was very happy with the simplicity. Tell them what equiptment you have, they will send the harnesses and Hub. One end goes in the avionics tray, the other in the hub. Just hook up PWR/GND/DIMR and you're good to go!!. I think the whole set-up was about $1800. Just another way to get it done. ________________________________________________________________________________
Date: Apr 20, 2006
For those who aren't there yet, it wouldn't hurt to plan ahead on these. We put them in and drilled the holes when we were clecoing the bottom skins, so it was easy to get them out by taking the bottom skin off. Then, when you get to the point where you need to put them in, you won't have to take them out again, just drop (read - carefully force) them in and rivet them. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PJ Seipel Sent: Wednesday, April 19, 2006 7:10 AM Subject: Re: RV10-List: Rear floor pans Just did those the other day. The key is to go slowly to avoid bending them. If possible, have a helper to force apart the side ribs so you can get the floor pans past the seatbelt anchors. To get them out, I put cleco's into the #19 nutplate holes, and lifted it up enough to get several into the #30 holes. I took some popsicle sticks and ground the ends to make little wedges and used them along the sides and back to help get the floor pan past the rivets and ribs. PJ RV-10 #40032 McGANN wrote: > Hi all, > > Listers have previously reported some issues with 'impossible rivets' on the rear floor pans - but I can't even get to that point. I am having some trouble fitting the F-1016C rear floor pans. It seems a fair bit of force is required to insert these panels to get the flanges past the seat belt attachand point. Once they are in place, there does not appear to be any way that they will come out - especially if there are any shop heads on the F1005A assembly. Has anyone else had trouble here? Is there a trick to inserting/removing these? > > thanks in advance > > Ron > #187 > fuse, finishing on the way. > -- -- ________________________________________________________________________________
Date: Apr 20, 2006
Subject: "Dual" take-off fuel pump fitting for pressure sender
Folks, I'm looking for a dual fitting that allows the fuel to flow and allows me to either attach my sender or attach another hose to the firewall mounted manifold...I've seen these - where do they come from and what's the part number. Anyone have any pictures? Thanks, Ralph ________________________________________________________________________________
Subject: Re: panel
Date: Apr 20, 2006
On Apr 20, 2006, at 11:22 AM, LIKE2LOOP(at)aol.com wrote: > > In a message dated 4/20/06 9:07 am, Tim(at)MyRV10.com writes: > << . I'm kind of surprised that with the -10 everyone just > assumes they have to have someone build is as opposed to doing it > theirself. >> > > Tim, > > Thanks for chiming in. I am planning to build my own panel...all > the posts > were making wonder if there was some mystery I was unaware of..... > > > Steve > Well, some of us have experience with metal work. Some of us have experience with fiberglass. Some of us have experience with wiring. Some of us have experience with engines. Some have experience with painting. The lucky few have experience with all the above or have a close resource who has experience to oversee. And some of us have experience with only one of the above and feel more comfortable paying someone else to do it. To each his own. -Sean #40303 ________________________________________________________________________________
Subject: Re: panel (homebuilders?)
Date: Apr 20, 2006
I too am a bit surprised about all the farming out, in everything for that matter, not just panels. Maybe the "do it all guys" stay quiet. I guess I feel like the poor guy with lots of time. I may end up with 5 years to get my plane done which is ok - I am a tinkerer and I want to know how every bit of that airplane was put together/designed. I will be doing my own interior, panel/wiring, some of the engine (depending on what ECI might put out), painting, and slow build kit. I am even utilizing the second hand/salvage yards when possible ($75 heated pitot probe and homemade mount). I will probably come up with a copy of that new overhead vent/light system rather than pay the $1200. I sold my 1951 Bonanza to try and escape some of the "aviation pricing". I was also thinking of finding that same 1951 Bonanza overhead ventilation scoop in salvage to use on the 10. I like making and fixing stuff and I like saying "I did that". I think the kit industry has really made the airplane building so much more accessible to the non-geeks with a willingness to part with money more than time. It is all supposed to be a learning experience and in todays industry there are opportunities to decide just how much you want to learn. Some have time some have money. Whatever works . Chris Lucas #40072 starting fuse and ending wings ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Thursday, April 20, 2006 9:02 AM Subject: Re: RV10-List: panel > > Not trying to cut any business from any of the panel builders, but... > I thought before when people posted their bios that there was a > pretty high percentage of geek builders on the list. ________________________________________________________________________________
Date: Apr 20, 2006
Jim, its great to have hard numbers. John - KUAO ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Wednesday, April 19, 2006 8:10 AM Subject: RV10-List: 540 power settings Just some general information on three different 540 power settings. This information was obtained in an unfinished (unpainted and some fairings missing) RV-10 with a 3 blade MT Propeller. The data was taken at 8,000' density altitude, at full throttle (around 23' MP) and leaned consistently: 2500 RPM 20 gph (Van's standard cruise performance power setting) 2300 RPM 15 gph - airspeed was 1 knot faster than at the 2500 RPM setting. 2100 RPM 12 gph - airspeed was 6 knots slower than at the 2500 RPM setting. Making the following assumptions: 60 gallons of fuel usable less a 1/2 hour reserve, and using Van's Aircraft RV-10 cruise performance of about 200 mph. At 2500 RPM, there is 2 1/2 hours of fuel available for a range of 500 miles. At 2300 RPM, there is 3 1/2 hours of fuel available for a range of just over 700 miles. At 2100 RPM, there is 4 1/2 hours of fuel available for a range of almost 870 miles. Or . . . At 2100 RPM, after flying for 2 1/2 hours and covering 480 plus miles, you would still have about half of your fuel remaining. According to MT Propeller (for a "natural composite" MT Propeller); running a Lycoming 200 RPM below the manifold pressure is acceptable. The 2100 RPM 23" MP power setting would be an acceptable cruise power setting with a "natural composite" MT Propeller. A commonly accepted lowest RPM power setting for an aluminum blade propeller would be 2300 RPM at 23" MP. (For anyone that is interested, MT Propeller does manufacture aluminum blade propellers.) Regards, Jim Ayers PS A reduction in airspeed with a higher RPM is expected. As an approximation, the RPM increase is linear, but the horsepower increase requirement is at a power of 2. ________________________________________________________________________________
Date: Apr 20, 2006
If you've done that one then you should be good to go. It's easy, and plans are great. There are some shortcuts to take that most of us will take about off line. Bob K Working on engine -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Masys Sent: Wednesday, April 19, 2006 1:30 PM Subject: Re: RV10-List: RV Assembly Workshop > > As a prospective RV-10 builder, I have a question of this group: Have > any of you taken the EAA Sportair Workshop on RV Assembly, and if so, > how helpful was it? I've built an airplane before, but have not done a > lot of sheetmetal work, and my wife has only bucked a handful of rivets. > I can teach her, but wondered if this group recommends the workshops or > to just dive in and get started. Maybe I get a minute of fame here for saying that Dan Checkoway and I took the RV building workshop together back in 2001 (even parked my C182 next to his Mooney when we both flew into Corona for the event.) I was already about a month into building the -7 and have to say I didn't really learn that many new manual skills, though it was a great place to ask newbie questions. However, the best part was that I took my wife along and it made a dramatic difference in her ownership of the project and willingness to serve as "Rosie the Riveter." For that alone it was worth the price of admission. -Dan Masys #40448 ________________________________________________________________________________
Subject: Re: 540 power settings
Date: Apr 20, 2006
Jim: Are the RPM limits you refer to in the second half of your message MT limits for their propellers? The Lycoming IO-540-D series charts from the engine operators manual provide much broader RPM vs. manifold pressure limits. Above 5500' there is no manifold pressure limitation for any RPM. Below 5500' manifold pressure limits are shown; as an example, at 1800 RPM 24 inches of manifold pressure is the limitation. At sea level and 2200 RPM the manifold pressure limit is 28.5", above 2200 RPM there is no manifold pressure limit. These charts show that the old wives tale of not operating "oversquare" is mostly legend and not a problem as far as Lycoming is concerned. While I am not suggesting that operating continuously at a limitation is prudent, very efficient operation does occur at full throttle settings and relatively low RPMs. An added benefit is smoother and quieter operation as well. It would be a shame if MT placed more restrictive limits on engine operation than does the engine manufacturer. Dick Sipp 40065 According to MT Propeller (for a "natural composite" MT Propeller); running a Lycoming 200 RPM below the manifold pressure is acceptable. The 2100 RPM 23" MP power setting would be an acceptable cruise power setting with a "natural composite" MT Propeller. A commonly accepted lowest RPM power setting for an aluminum blade propeller would be 2300 RPM at 23" MP. (For anyone that is interested, MT Propeller does manufacture aluminum blade propellers.) Regards, Jim Ayers PS A reduction in airspeed with a higher RPM is expected. As an approximation, the RPM increase is linear, but the horsepower increase requirement is at a power of 2. ________________________________________________________________________________
Subject: flap system install
Date: Apr 20, 2006
just finishing the flap system install. a couple of pointers Ream all weldment holes to size: AN3 =3D #12 ream AN4 =3D .249 ream although the plans show installing by inserting through the rear floor area; they can be inserted more easily via the external hole and pushed to the center. The outer skin hole should be deburred and smooth. The key is marking all parts to location and orientation. then wax the torque tubes and insert. with reference to the flap horn bolts. leave the tunnel parts together but don't install tunnel bolts. install the flap horn outboard bolt first after sliding the torque tube as far into the center weldment as possible. then a wrench underneath and a ratchet extension will allow tightening. Then position the torque tube properly; the other bolt can be reached with a ratchet extension.vertically when drilling the flap motor for safety wire you will probably need to drill vertically about .050 and then horizontally to meet the vertical hole. lastly this applies to all corrosion treatment of tubes. I clean the inside with an acetone rinse then spray primer in the end. on the other end is an operating shop vacuum. the primer is quickly distributed down the pipe. ________________________________________________________________________________
Date: Apr 21, 2006
This could be a dangerous practice. At least with my shop vac any vapors which make it through the filter (and the filter is designed to trap particles, not vapor) will be exposed to the motor brushes. This could result in a rather large bang! Jack & Cecilia Sargeant 1127 Patricia St. Wichita, KS 67208-2642 316/682-5268 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of David McNeill Sent: Thursday, April 20, 2006 10:54 PM To: rv10-list(at)matronics.com Subject: RV10-List: flap system install just finishing the flap system install. a couple of pointers Ream all weldment holes to size: AN3 = #12 ream AN4 = .249 ream although the plans show installing by inserting through the rear floor area; they can be inserted more easily via the external hole and pushed to the center. The outer skin hole should be deburred and smooth. The key is marking all parts to location and orientation. then wax the torque tubes and insert. with reference to the flap horn bolts. leave the tunnel parts together but don't install tunnel bolts. install the flap horn outboard bolt first after sliding the torque tube as far into the center weldment as possible. then a wrench underneath and a ratchet extension will allow tightening. Then position the torque tube properly; the other bolt can be reached with a ratchet extension.vertically when drilling the flap motor for safety wire you will probably need to drill vertically about .050 and then horizontally to meet the vertical hole. lastly this applies to all corrosion treatment of tubes. I clean the inside with an acetone rinse then spray primer in the end. on the other end is an operating shop vacuum. the primer is quickly distributed down the pipe. ________________________________________________________________________________
Date: Apr 21, 2006
Subject: Re: flap system install
Not true. Even with the most volatile stuff out there, there is so much air that the mixture is too lean to ignite. If I'm not totally mistaken .... 'Mythbusters' also came to the same conclusion. But having said that, all that paint in the vacuum cleaner can't be a good thing either. Linn Jack Sargeant wrote: > This could be a dangerous practice. At least with my shop vac any > vapors which make it through the filter (and the filter is designed to > trap particles, not vapor) will be exposed to the motor brushes. This > could result in a rather large bang! > > > Jack & Cecilia Sargeant > 1127 Patricia St. > Wichita, KS 67208-2642 > 316/682-5268 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of David > McNeill > Sent: Thursday, April 20, 2006 10:54 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: flap system install > > just finishing the flap system install. > > a couple of pointers > > Ream all weldment holes to size: AN3 = #12 ream AN4 = .249 ream > > although the plans show installing by inserting through the rear > floor area; they can be inserted more easily via the external hole > and pushed to the center. The outer skin hole should be deburred > and smooth. The key is marking all parts to location and > orientation. then wax the torque tubes and insert. > > with reference to the flap horn bolts. leave the tunnel parts > together but don't install tunnel bolts. install the flap horn > outboard bolt first after sliding the torque tube as far into the > center weldment as possible. then a wrench underneath and a > ratchet extension will allow tightening. Then position the torque > tube properly; the other bolt can be reached with a ratchet > extension.vertically > > when drilling the flap motor for safety wire you will probably > need to drill vertically about .050 and then horizontally to meet > the vertical hole. > > lastly this applies to all corrosion treatment of tubes. I clean > the inside with an acetone rinse then spray primer in the end. on > the other end is an operating shop vacuum. the primer is quickly > distributed down the pipe. > ________________________________________________________________________________
Date: Apr 21, 2006
Hey guy's, you can totally destroy a perfectly good vacuum, and scare the crap out of anyone within a 100ft or so, with flammable vapors. Don't ask me how I know! Sam Engine linn Walters wrote: > Not true. Even with the most volatile stuff out there, there is so > much air that the mixture is too lean to ignite. If I'm not totally > mistaken .... 'Mythbusters' also came to the same conclusion. But > having said that, all that paint in the vacuum cleaner can't be a good > thing either. > Linn > > > Jack Sargeant wrote: > >> This could be a dangerous practice. At least with my shop vac any >> vapors which make it through the filter (and the filter is designed >> to trap particles, not vapor) will be exposed to the motor brushes. >> This could result in a rather large bang! >> >> >> Jack & Cecilia Sargeant >> 1127 Patricia St. >> Wichita, KS 67208-2642 >> 316/682-5268 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of David >> McNeill >> Sent: Thursday, April 20, 2006 10:54 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: flap system install >> >> just finishing the flap system install. >> >> a couple of pointers >> >> Ream all weldment holes to size: AN3 = #12 ream AN4 = .249 ream >> >> although the plans show installing by inserting through the rear >> floor area; they can be inserted more easily via the external >> hole and pushed to the center. The outer skin hole should be >> deburred and smooth. The key is marking all parts to location and >> orientation. then wax the torque tubes and insert. >> >> with reference to the flap horn bolts. leave the tunnel parts >> together but don't install tunnel bolts. install the flap horn >> outboard bolt first after sliding the torque tube as far into the >> center weldment as possible. then a wrench underneath and a >> ratchet extension will allow tightening. Then position the torque >> tube properly; the other bolt can be reached with a ratchet >> extension.vertically >> >> when drilling the flap motor for safety wire you will probably >> need to drill vertically about .050 and then horizontally to >> meet the vertical hole. >> >> lastly this applies to all corrosion treatment of tubes. I clean >> the inside with an acetone rinse then spray primer in the end. on >> the other end is an operating shop vacuum. the primer is quickly >> distributed down the pipe. >> > > ________________________________________________________________________________
Date: Apr 21, 2006
Sure, and aluminum and steel grinding dust won't ignite cause there is too much air. Ask Hoyt Fleming of Boise how his brand new Lancair ES was burned to waste parts by just sanding. You need to do further research and not hold Myth Busters in such high esteem. That phrase " I didn't know it would do that.... Or Here, hold my beer and watch this" come to mind. John - $00.02 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters Sent: Friday, April 21, 2006 5:47 AM Subject: Re: RV10-List: flap system install Not true. Even with the most volatile stuff out there, there is so much air that the mixture is too lean to ignite. If I'm not totally mistaken .... 'Mythbusters' also came to the same conclusion. But having said that, all that paint in the vacuum cleaner can't be a good thing either. Linn Jack Sargeant wrote: This could be a dangerous practice. At least with my shop vac any vapors which make it through the filter (and the filter is designed to trap particles, not vapor) will be exposed to the motor brushes. This could result in a rather large bang! Jack & Cecilia Sargeant 1127 Patricia St. Wichita, KS 67208-2642 316/682-5268 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of David McNeill Sent: Thursday, April 20, 2006 10:54 PM To: rv10-list(at)matronics.com Subject: RV10-List: flap system install just finishing the flap system install. a couple of pointers Ream all weldment holes to size: AN3 =3D #12 ream AN4 =3D .249 ream although the plans show installing by inserting through the rear floor area; they can be inserted more easily via the external hole and pushed to the center. The outer skin hole should be deburred and smooth. The key is marking all parts to location and orientation. then wax the torque tubes and insert. with reference to the flap horn bolts. leave the tunnel parts together but don't install tunnel bolts. install the flap horn outboard bolt first after sliding the torque tube as far into the center weldment as possible. then a wrench underneath and a ratchet extension will allow tightening. Then position the torque tube properly; the other bolt can be reached with a ratchet extension.vertically when drilling the flap motor for safety wire you will probably need to drill vertically about .050 and then horizontally to meet the vertical hole. lastly this applies to all corrosion treatment of tubes. I clean the inside with an acetone rinse then spray primer in the end. on the other end is an operating shop vacuum. the primer is quickly distributed down the pipe. ________________________________________________________________________________
From: "Mike Lauritsen - Work" <mike(at)cleavelandtool.com>
Date: Apr 21, 2006
Just as a shameless self promotion... We teach a building class too. The last six months the schedule has been a little unpredictable but we have one going on yesterday and today. The next should be near the end of May, then one June 16th & 17th the days before Boone's annual RV Day Fly-In. We focus on teaching excellent quality of work, and what to look for when using tools. We have a high instructor to student ratio (usually 1:2) and are taught now by full time RV builders with multiple awards on their shelves. The class is located in a hangar with 8 RV's under construction (2 -10's). Everyone taking our classes have expressed that it was well worth the investment (including those that have taken other classes). Cost is $325 and if you bring your spouse, or building partner they are half price. I agree that this is a great way to motivate them. Please email me with any questions. Mike(at sign)CleavelandTool.com > > As a prospective RV-10 builder, I have a question of this group: Have > any of you taken the EAA Sportair Workshop on RV Assembly, and if so, > how helpful was it? I've built an airplane before, but have not done a > lot of sheetmetal work, and my wife has only bucked a handful of rivets. > I can teach her, but wondered if this group recommends the workshops or > to just dive in and get started. ________________________________________________________________________________
Date: Apr 21, 2006
Subject: Fuel Injection Choices
Listers, Can someone with more experience/knowledge of the available fuel injection systems available help shed some light on the relative merits of the Precision SilverHawk -vs- the Airflow Performance Injection systems for the IO-540 engine? Any opinions/thoughts on choosing one over the other will be greatly appreciated. Thanks, Tom Gesele #473 ________________________________________________________________________________
Subject: Cowl fasteners
Date: Apr 21, 2006
I would not change from that factory setup. It has been flawless, easy to install and remove. Randy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Sent: Tuesday, April 18, 2006 7:27 AM Subject: RV10-List: Cowl fasteners Where are people coming down on the decision of sticking with Van's cowl "hinge" design, or going with Cam-lok type cowl fasteners? Of the flying folks, anyone like to comment on the ease of use of the hinge fastener design? Thanks, TDT 40025 ________________________________________________________________________________
Subject: crotch strap bracket
Date: Apr 21, 2006
hey all - am i right in thinking that if i'm using only a 3 or 4 point harness that i don't need the crotch strap bracket installed? does it do anything else? i think i remember that some were omitting it or removing it in the case of quickbuilds. it doesn't do some other important task like hold the plane up in the air does it? :) cj #40410 fuse!!! www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: Attn Australians - tail kit and tools for sale
Date: Apr 22, 2006
Unfortunately I need to sell my completed tail kit and tools. I'll part with the lot for $AU4500. The buyer will need to pay for freight costs and I'd say this will be expensive because of the volume of the completed parts (probably about $2000). Considering that with our dollar v's the US dollar you will pay about $10000 for kit, tools, transport from the States, GST and you will have a completed kit, this is good value for money. I have detailed pictures and a builders log and, if I do say so myself, the build quality is really good. My only reason for selling is that in the past three days I had an investment go belly up and have lost every cent I have. Please send me an email if interested. ________________________________________________________________________________
Date: Apr 21, 2006
Subject: Overhead Console - Update
I spoke with Tony Sustare about the overhead console I ordered at Sun-N-Fun and they are finalizing the fit on Ed Hayden's plane and the overheads should be ready to ship in a few weeks. I anticipate that I will get mine mid May. They are also working on the interior window closeout rings to clean up interior boarder between the canopy liner and the windows. They are extending the Sun-N-Fun pricing. $994 (regular $1,295) for the overhead canopy straight from the mold and primed $1,995 (regular $2,295) for the overhead canopy with cockpit lights, eyeball vents and DVD player the components are not installed $2,195 (regular $2,495) canopy with the components above installed. Photos I took at SnF are on my website <http://lrosen.nerv10.com/Construct/SunNFun_2006/Overhead/index.html> along with contact information. Larry Rosen I am not associated with Tony or Accuracy Avionics. I am purchasing one of their overhead consoles. ________________________________________________________________________________
Subject: Re: Attn Australians - tail kit and tools for sale
Date: Apr 22, 2006
Hi mark, Where are you in Australia ? Paul Walter ----- Original Message ----- From: Mark Drury To: rv10-list(at)matronics.com Sent: Saturday, April 22, 2006 7:36 AM Subject: RV10-List: Attn Australians - tail kit and tools for sale Unfortunately I need to sell my completed tail kit and tools. I'll part with the lot for $AU4500. The buyer will need to pay for freight costs and I'd say this will be expensive because of the volume of the completed parts (probably about $2000). Considering that with our dollar v's the US dollar you will pay about $10000 for kit, tools, transport from the States, GST and you will have a completed kit, this is good value for money. I have detailed pictures and a builders log and, if I do say so myself, the build quality is really good. My only reason for selling is that in the past three days I had an investment go belly up and have lost every cent I have. Please send me an email if interested. ________________________________________________________________________________
Date: Apr 21, 2006
Subject: Your bucking bar input please.
I'm trying to finish off Sec 29 (fuse skins, !@#$$#@ %$!!!!!!! you know the one!) There are several rivets at the right angle juncture of the F -1041 fwd bottom longerons and the F1042 upright bulkhead. This is where a little triangular doubler goes to tie the pieces together (presumably) additionally there is a nutplate that gets fastened to the triangle and the whole joint. None of the bucking bars (or other shop paraphenalia that I have) will fit the limited access to use as bucking bars, what soulutions did some of you come up with? Deems Davis # 406 Fuse http://deemsrv10.com/ Sorry for the poor quality of the picture ________________________________________________________________________________
Date: Apr 21, 2006
Subject: Re: empty weight
Tim 1,685 Randy 1,625 Vic 1,665 Chuck 1,615 Rob 1,558 Chuck and Vic weight from <http://www.rvproject.com/wab/> Rob, looks like you have the light weight machine. Which prop? With or without wheel pants? Larry Rosen http://lrosen.nerv10.com ________________________________________________________________________________
Subject: Re: panel
Date: Apr 21, 2006
> FWIW, I'm also going to wire my own panel, and likely even > do all the cutouts myself as well. No great mystery, just > time and learning as with the rest of the project... :-) I cut the panel for my -7A and wired all of the avionics from schematics downloaded from the web. Result is at: http://array.ucsd.edu/rv7a/panel.html and http://array.ucsd.edu/rv7a/2003-02-16_panel2.jpg Took about 200 hours to do all of the design, cutting, wiring and painting, but it was one of the really fun parts of the project. Plan to do the same for the -10. -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 22, 2006
Subject: Re: Your bucking bar input please.
Hi Deems, I finished that section about 2 months ago and have allready forgotten exactly what I did. I did use the empennage bucking bar in a lot of places and a steel plate about 1/4 " thick by about 2 inches wide and about 8 inches long which a shoved into tight areas. I believe I might have squeezed some of the rivets in the area you are talking about. I would caution against using blind rivets in this area as some of the engine loads are coming through that joint. If you absolutely must use blind rivets make sure you use something like the CherryMax ones that have a locking feature that keeps the stem in place. The problem with most of the pop rivets is that if subjected to vibration the steel stem falls off and you are left with a hollow aluminum cylinder as your fastener that has a much reduced strength. Niko #188 fuselage ----- Original Message ---- From: Deems Davis <deemsdavis(at)cox.net> Sent: Friday, April 21, 2006 8:51:51 PM Subject: RV10-List: Your bucking bar input please. I'm trying to finish off Sec 29 (fuse skins, !@#$$#@ %$!!!!!!! you know the one!) There are several rivets at the right angle juncture of the F -1041 fwd bottom longerons and the F1042 upright bulkhead. This is where a little triangular doubler goes to tie the pieces together (presumably) additionally there is a nutplate that gets fastened to the triangle and the whole joint. None of the bucking bars (or other shop paraphenalia that I have) will fit the limited access to use as bucking bars, what soulutions did some of you come up with? Deems Davis # 406 Fuse http://deemsrv10.com/ Sorry for the poor quality of the picture ________________________________________________________________________________
Subject: Seat Belts
Date: Apr 22, 2006
Any body else out there besides David thinking about using these belts? http://www.inertialbelts.com/ I am one step away from installing the hard points and going this direction. I am looking for comments, either on or off list. Thanks for your comments in advance. Rene' rene(at)felker.com 40322 N423CF Fuselage and finish kit Wont be completed by Oskosh, maybe by January. 801-721-6080 ________________________________________________________________________________
Subject: Re: Seat Belts
Date: Apr 22, 2006
check with GenGrumpy(at)aol.com ; he has a set installed. ----- Original Message ----- From: Rene To: rv10-list(at)matronics.com Sent: Saturday, April 22, 2006 5:08 PM Subject: RV10-List: Seat Belts Any body else out there besides David thinking about using these belts? http://www.inertialbelts.com/ I am one step away from installing the hard points and going this direction. I am looking for comments, either on or off list. Thanks for your comments in advance. Rene' rene(at)felker.com 40322 N423CF Fuselage and finish kit Wont be completed by Oskosh, maybe by January. 801-721-6080 ________________________________________________________________________________
Date: Apr 22, 2006
Subject: Bucking Bar follow-up
Well after whining to everybody yesterday about my impossible to buck rivets, it finally occurred to me that I might be within an easy reach out of this pickle. There's enough material mass in the seldom used Elevator bucking bar to make another 1/2 dozen bucking bars, the problem was I didn't have the right tools to cut or machine the part ------ or did I ? --- I remembered a seldom used highspeed grinder/cutoff wheel tool and I wondered whether it would cut the massive bucking bar. Well a little test proved that it would/could and 20 minutes later I had 2 new bucking bars!!!! Another 30 minutes per side on the Fuse and the impossible rivets (and the nutplates), were completely subdued and driven into near perfect position ! (well close enough, and didn't have to resort to pops). I've attached a pic (reduced size) Moral to the story: Whining leads to inspiration!! Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Subject: Tim's panel
Date: Apr 22, 2006
Tim, As I was going thru the panel plans, it seems that the lower flange/strip of aluminum will be recessed slightly behind the panel. That triggered a memory from your site, so can you relate how you accomplished," One very nice thing I found with adding that extra layer of aluminum for the switch bar at the bottom of the panel." that made your panel "flush from top to bottom." Rob ________________________________________________________________________________
Subject: rv10 at snf
Date: Apr 23, 2006
Did anybody else notice the two angle of attack vanes on the tru track 10 at sun and fun. I'm curious to know if its part of the "new" system they're gonna announce at osh.. Steve dinieri ________________________________________________________________________________
Date: Apr 23, 2006
Subject: Re: rv10 at snf
They showed it in the booth at Sun-N-Fun. Regards, Jim Ayers In a message dated 04/22/2006 9:34:42 PM Pacific Daylight Time, capsteve(at)adelphia.net writes: Did anybody else notice the two angle of attack vanes on the tru track 10 at sun and fun. I=E2=80=99m curious to know if its part of the =E2=80=9Cnew=E2=80=9D system they=E2=80=99re gonna announce at osh.. Steve dinieri ________________________________________________________________________________
Subject: Gear mount bolts
Date: Apr 23, 2006
Those with QB fuses make sure you check the bolts that hold the mounts in the fuse. Some of mine were incorrect sizes ...some without washers and 2 without nuts on....beware! Chris ________________________________________________________________________________
Date: Apr 23, 2006
Subject: Re: Tim's panel
That's a simple one. I just bought some aluminum strips from Van's. They are I think .063 strips, and I think they may be 1.5" or 2" wide. Measure and see which fits better, or I can check at the hanger if I remember today when I'm there. You may have to call them to have them figure out which sizes they have standard. I can't seem to find them on the web at first glance. They were cheap, and I still have a couple extra that I ordered. Anyway, all I did was take 2 strips, and attach them to the lower part of the panel with about 4 screws for each strip. You can paint them separately and attach them even after the panel is done if you want to, but I'd really recommend having them for one reason. If you ever want to add more switches or change the layout of something, which has already happened to me, then at worst you just have to pull the strip and paint it and re-silkscreen/engrave/label that piece. It also makes the panel look nicer. I looked hard at my photos of the colorado RV-10's before I did that and was impressed that theirs looked more finished, which gave me the idea. Tim Olson - RV-10 N104CD - Flying Robert G. Wright wrote: > Tim, > > > > As I was going thru the panel plans, it seems that the lower > flange/strip of aluminum will be recessed slightly behind the panel. > That triggered a memory from your site, so can you relate how you > accomplished, One very nice thing I found with adding that extra layer > of aluminum for the switch bar at the bottom of the panel that made > your panel flush from top to bottom. > > > > Rob > ________________________________________________________________________________
Subject: .311 drill bit? (or 7.9mm?)
Date: Apr 23, 2006
hey all - there's a hole that needs to be drilled in the gear mount with a .311 drill bit. where do you get this? or 7.9mm. does this measurement correlate with a numbered drill bit? help. cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
From: "Indran Chelvanayagam" <ichelva(at)netspace.net.au>
Date: Apr 24, 2006
Avery Tools sell an undersized 5/16 reamer which is .3110 inch in diameter. Works nicely for a snug fit of the landing gear bolt Indran Chelvanayagam -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Sunday, 23 April 2006 11:51 PM Subject: RV10-List: .311 drill bit? (or 7.9mm?) hey all - there's a hole that needs to be drilled in the gear mount with a .311 drill bit. where do you get this? or 7.9mm. does this measurement correlate with a numbered drill bit? help. cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Date: Apr 23, 2006
Subject: Re: .311 drill bit? (or 7.9mm?)
Chris, You can buy one from McMaster-Carr. http://www.mcmaster.com/ items 2958A126 and 30565A304 seem to fit the bill. Enco is another good source for drills and things but their page is down this morning. There was some chatter several months ago concerning this size of bit. Someone proposed one builder buying a bit and passing it along to the next builder who needed it. Maybe that has happened. I intend to order a couple next time I need something from McMaster-Carr. The bits only cost $4.00 but the shipping will probably double the price. Mark Chris Johnston wrote: > hey all - > > there's a hole that needs to be drilled in the gear mount with a .311 drill bit. where do you get this? or 7.9mm. does this measurement correlate with a numbered drill bit? help. > > cj > #40410 > fuse > www.perfectlygoodairplane.net -- ________________________________________________________________________________
From: "John Hilger" <ninepapa(at)bendbroadband.com>
Date: Apr 23, 2006
Chris All number drills are too small No letter drills are close. 7.9mm is .311024", thats pretty close. John 40359 ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Sent: Sunday, April 23, 2006 8:51 AM Subject: RV10-List: .311 drill bit? (or 7.9mm?) hey all - there's a hole that needs to be drilled in the gear mount with a .311 drill bit. where do you get this? or 7.9mm. does this measurement correlate with a numbered drill bit? help. cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: Newest RV-10 kit
Date: Apr 23, 2006
I just ordered the empennage kit and wing kit on Friday #40579. Gonna pick up the emp kit this coming week. Van's is only a 20 min drive from my place. I have to remove some siding from the trailer to get the crates in it though (too long). While working on that today I snapped a bolt that holds the front panel on my trailer trying to remove it. Hopefully this isn't an omen of how the build process will go! The wife and I got our "free" $36K RV-10 ride at Van's on Friday. I have lots of RV-4 time and 1.2 hours in a 9A and now 15 minutes in a 10. Holy cow!!! I was very impressed that Van ended up creating such a big RV but still maintained the RV controllability and feel. Wish we could make OSH in 06'. maybe 07' if were lucky. Ben Westfall ________________________________________________________________________________
Date: Apr 23, 2006
Subject: Re: Newest RV-10 kit on the way to well over 600 by OSH
Congratulations Ben, hope you have as much fun as I'm having. It looks like John Cox's prediction of 600 kits sold by OSH is a slam dunk, when I spoke with Vans @ Copperstate they said they were averaging 17 RV10 kit sales per month, with 3 months remaining, should well exceed 600. I hope John's other prediction of 50 complete is also achieved, Watching w/ interest. Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
Date: Apr 23, 2006
Subject: Re: Bucking Bar follow-up
Not to rain on your parade Deems, I had great success by modifying the emmpenage bucking bar as per Van's instructions and have completed all the rivets on the fuse using it. I will admit hunting for the right bar was a long process until I remembered in the plans it said to use this bar to rivet the fuselage....hmmmm, WORKED!! I did use a cardboard shim on one side so it would lay correctly in the forward longeron channels without worrying if I was correctly postioned on those rivets. Don't think I didn't stare at my bucking bars with the idea of hacking them up though...I was very close to doing the same thing' PS-If you want a taste of what it was like to build an RV before prepunched kits came out, do the rear seat backs. I have a little experience in layout and drilling and forgot how nice the prepuched kits are...It all comes racing back doing the rear seats. Maybe 100 holes to layout and drill plus the metal angle fabrication...4 hours time. Imagine if the entire kit was like that! My hats off to the pioneers who laid out, drilled and fabricated their RV's......They are the "real" builders, I humbly accept the title of assembler. Just my .02 worth. Rick S. 40185 fuse/finish ________________________________________________________________________________
Date: Apr 24, 2006
Mine weighed 1613 with dual batteries and paint .No wheel pants ________________________________________________________________________________
Subject: empty weight
Date: Apr 24, 2006
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
I would like to get an idea what Gross Weight everyone has registered there plane for? Thank You Ray Doerr 40250 (At the airport and wings are on) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, April 21, 2006 7:49 PM Subject: Re: RV10-List: empty weight Tim 1,685 Randy 1,625 Vic 1,665 Chuck 1,615 Rob 1,558 Chuck and Vic weight from <http://www.rvproject.com/wab/> Rob, looks like you have the light weight machine. Which prop? With or without wheel pants? Larry Rosen http://lrosen.nerv10.com ________________________________________________________________________________
Date: Apr 24, 2006
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: Fiber Glass thickness at Door Bottoms.
Date: Apr 24, 2006
After sanding the doors into place I have almost no material left on the bottom of the doors where they were glued together. I have some separations that will require a couple of layers of glass to re-bond. I am well inside the bottom scribe lines. Did anyone else need to sand this far to make the doors fit. I have been looking at it for a week now and I do not see where I could have done anything different except maybe take more off the cabin top at the base of the doors. Bobby 40116 ________________________________________________________________________________
Date: Apr 25, 2006
Bob, I took an epoxy syringe from west marine and drilled small holes above the joint and pumped in thickened epoxy, then just filled the holes (#30). It Ended up making a fillet inside the door frame. I also pumped in expanding urethane foam into the larger cavities to insulate and glue. Just be careful not to guppy the thing....the expanding foam can easily deform the door. It didn't add much weight but it really seems to give the door a more solid feel... Fwiw Steve dinieri 40205 -----Original Message----- From: owner-rv10-list-swiwerver(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Monday, April 24, 2006 2:35 PM Subject: RV10-List: Fiber Glass thickness at Door Bottoms. After sanding the doors into place I have almost no material left on the bottom of the doors where they were glued together. I have some separations that will require a couple of layers of glass to re-bond. I am well inside the bottom scribe lines. Did anyone else need to sand this far to make the doors fit. I have been looking at it for a week now and I do not see where I could have done anything different except maybe take more off the cabin top at the base of the doors. Bobby 40116 ________________________________________________________________________________
Subject: Cabin
Date: Apr 25, 2006
i thouight i read that a company in the US may have been developing an alterative firber glass after market cabin section for the RV 10. Any one know of this ?. Paul Walter ________________________________________________________________________________
Subject: RE: RV10-List Digest - Fiber Glass thickness at Door Bottoms.
Date: Apr 25, 2006
There are many problems with the foam you mention over the years. The RV gear leg/fairing voids pumped with foam ended up attacking the metal gear rods and pitting them. I imagine water or trapped moisture was the culprit here. Foam can be hydroscopic and absorb moisture. Cessna had problems with foamed elevators absorbing water. Your door fill area might not be a problem area with foam, however I wanted to bring these points up for consideration ....................................................................... .................... Fiber Glass thickness at Door Bottoms. Bob, I took an epoxy syringe from west marine and drilled small holes above the joint and pumped in thickened epoxy, then just filled the holes (#30). It Ended up making a fillet inside the door frame. I also pumped in expanding urethane foam into the larger cavities to insulate and glue. Just be careful not to guppy the thing....the expanding foam can easily deform the door. It didn't add much weight but it really seems to give the door a more solid feel... Fwiw Steve dinieri 40205 ________________________________________________________________________________
Date: Apr 25, 2006
Subject: tunnel heat
Has anyone considered installing a small blast tube off the baffles and dumping the air directly into the tunnel? Seems like coupling that with some firewall insulation on the forward side would resolve the heat situation (or am I missing something)? Tom Gesele #473 ________________________________________________________________________________
Subject: Re: tunnel heat
Date: Apr 25, 2006
Well....I'm not at that point of construction yet, but the tunnel heat does concern me. Looking at many of the Rv10 projects on the web, it seems Van's has the 2 triangular shaped heat valves (same one I have in my RV8) aiming the exhaust port at each other. This hot air is always pointing at each other until you open the valve for cabin heat. Part of the tunnel heat problem could be as what Tim ond others have said...heat conducting through the valve and radiating into the tunnel. Also, if the heat valve(s) are the very same ones that I bought from Vans (I believe they are), then they don't "seal" very well. If you have a blast of hot air aiming at them constantly, (try experimenting with the valve in your hand and blow some air with your air hose at the outlet side and see what happens) they could possible leak and that hot air is forced down the tunnel through a "leaky" valve. Maybe a solution would be to not point the exhaust ports at each other and/or make a gasket to provide a better seal. Just a thought but it's possible. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=30585#30585 ________________________________________________________________________________
Date: Apr 25, 2006
Subject: Re: Cabin
I do not know of anyone making an after market cabin. However, Sam James of James Aircraft <http://www.jamesaircraft.com/About_Us.html> is making an after market cowl for the 10. Larry Rosen Paul Walter wrote: > i thouight i read that a company in the US may have been developing an > alterative firber glass after market cabin section for the RV 10. Any > one know of this ?. > > > Paul Walter ________________________________________________________________________________
Date: Apr 25, 2006
Subject: Re: GPS Antenna location
I'm just throwing this out because no one else has mentioned it - I'm putting my GPS antennas on the glareshield. The antennas will certainly have a great view of the sky up through the plexi-glass, the install is easy and there is no concern about engine heat cooking them. Jim McGrew 40134 In a message dated 4/25/2006 6:12:03 P.M. Mountain Daylight Time, coop85(at)bellsouth.net writes: --> RV10-List message posted by: "Marcus Cooper" I know this has been addressed before, but I was wondering if any of you that opted to put the GPS antenna under the cowling have any feedback, good or bad, on the idea? I suspect reception is okay, my biggest concern is the heat in that area affecting the not so cheap antenna. Thanks, Marcus Do not archive Jim "Scooter" McGrew jsmcgrew(at)aol.com ________________________________________________________________________________
Date: Apr 25, 2006
Are you speaking of your current #40415 project or your father's #40241 (N256H) or both when you say "We Have"? Randy's thought that both #241 and his #006 had the earlier cross muffler design was a logical answer to less of a problem comparison with either the valve design or scat ductwork. Rather new twin muffler design. John - $00.02 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Tuesday, April 25, 2006 5:40 PM Subject: RE: RV10-List: tunnel heat We have the dual muffler setup. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org 352-465-4545 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Sent: Tuesday, April 25, 2006 5:03 PM Subject: RE: RV10-List: tunnel heat Jesse, I am just fishing here. What exhaust system do you have? I have the AWI system with one muffler running crosswise under the engine and do not have a heating issue. Randy -- -- -- -- ________________________________________________________________________________
Subject: GPS Antenna location
Date: Apr 26, 2006
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
The reality is that GPS signals are basically immune to any type of fiberglass or plastic as long as it isn't covered with a metallic paint or anything else electrically conductive. Carbon fiber and metal will block most of the frequencies we deal with. Sure you will get some tiny amount of degradation from mounting it under glass but nothing worth mentioning usually. Lot's of people have made a little shelf just forward of the firewall to mount it on under the cowl and probably just as many have mounted it under their canopy. Both are as good of spots as mounting it on the exterior. If you do decide to mount on the exterior the drag will not amount to much, probably less than a knot depending on where you put it. It's more of a "clean look" type of decision. But if you are worried about it and on the fence, just mount it on the exterior as you can't go wrong. As far as the engine cooking the antenna, most GPS (and XM/Sirius) antennas are amplified so there are some electronics in the antenna head. As with any other piece of electronic gear performance can suffer if it becomes too hot, just make sure it isn't mounted next to anything that radiates a bunch of heat like the exhaust headers. Lastly GPS, and most satellite antennas we consumers deal with for that matter, are circularly polarized and do not require ground planes. Hope that helps. I'm not an expert but I slept at a Holiday Inn Express last night. Michael Sausen RV-10 #352 Working on Fuselage Recent RV-10 Build Activity <http://www.mykitlog.com/display_project.php?project_id=3D22> ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com Sent: Tuesday, April 25, 2006 10:35 PM Subject: Re: RV10-List: GPS Antenna location I'm just throwing this out because no one else has mentioned it - I'm putting my GPS antennas on the glareshield. The antennas will certainly have a great view of the sky up through the plexi-glass, the install is easy and there is no concern about engine heat cooking them. Jim McGrew 40134 In a message dated 4/25/2006 6:12:03 P.M. Mountain Daylight Time, coop85(at)bellsouth.net writes: =09 I know this has been addressed before, but I was wondering if any of you that opted to put the GPS antenna under the cowling have any feedback, good or bad, on the idea? I suspect reception is okay, my biggest concern is the heat in that area affecting the not so cheap antenna. =09 Thanks, Marcus =09 Do not =3D es Day --> - NEW MATRONICS LIST WIKI - p; - List Contribution Web Site =09 =09 =09 =09 =09 =09 =09 =09 =09 =09 Jim "Scooter" McGrew jsmcgrew(at)aol.com ________________________________________________________________________________
Date: Apr 26, 2006
Gents ... Check out Dan Checkoway's site on how he created removable glass panels between windshield and cowling area. http://www.rvproject.com/hidden_antennas.html Refer your questions to Dan ... dan(at)rvproject.com ... Jerry Grimmonpre' RV8A Electrical ________________________________________________________________________________
Date: Apr 26, 2006
N256H #40241 has the dual muffler and I assume 40415 will as well, but we don=92t have it yet. Jesse Saint I-TEC, Inc. HYPERLINK "mailto:jesse(at)itecusa.org"jesse(at)itecusa.org HYPERLINK "http://www.itecusa.org"www.itecusa.org 352-465-4545 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, April 25, 2006 11:38 PM Subject: RE: RV10-List: tunnel heat Are you speaking of your current #40415 project or your father=92s #40241 (N256H) or both when you say =93We Have=94? Randy=92s thought that both #241 and his #006 had the earlier cross muffler design was a logical answer to less of a problem comparison with either the valve design or scat ductwork. Rather new twin muffler design. John - $00.02 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Tuesday, April 25, 2006 5:40 PM Subject: RE: RV10-List: tunnel heat We have the dual muffler setup. Jesse Saint I-TEC, Inc. HYPERLINK "mailto:jesse(at)itecusa.org"jesse(at)itecusa.org HYPERLINK "http://www.itecusa.org"www.itecusa.org 352-465-4545 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw Sent: Tuesday, April 25, 2006 5:03 PM Subject: RE: RV10-List: tunnel heat Jesse, I am just fishing here. What exhaust system do you have? I have the AWI system with one muffler running crosswise under the engine and do not have a heating issue. Randy -- -- -- -- -- -- ________________________________________________________________________________
Subject: My 2 Cents on the Landing Gear
Date: Apr 26, 2006
Whenever I start a new "kit", I review the instructions several times, once to ensure I have the necessary tools and parts. The .311" drill bit appeared to be a problem. I called Van's and received an interesting answer: I was told a 5/16 bit would be okay. I haven't installed the gear yet and after reading about loose landing gear I had second thoughts. I received my .311" reamer from McMaster-Carr (thanks for the info) yesterday. But is has occurred to me, that 5/16" would be fine provided the bolt matched. Drilling with a 5/16" bit though the leg and support would not cause a problem. The problem would be from an undersized bolt. Would everyone agree 5/16" would be okay with a proper (precise fit) bolt? Thank You Rick Conti Senior Engineering Manager The Boeing Company office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 ________________________________________________________________________________
Date: Apr 26, 2006
Subject: Re: My 2 Cents on the Landing Gear
I used the same reamer as you have purchased. I found it easier to insert the reamer from the button, chuck it and pull it through the hole. If you decide to do this, you may need to grind the blade shoulders at the reamer stem side to be able to pull up through. On 4/26/06, Conti, Rick wrote: > > Whenever I start a new "kit", I review the instructions several times, > once to ensure I have the necessary tools and parts. The .311" drill > bit appeared to be a problem. I called Van's and received an > interesting answer: I was told a 5/16 bit would be okay. I haven't > installed the gear yet and after reading about loose landing gear I had > second thoughts. I received my .311" reamer from McMaster-Carr (thanks > for the info) yesterday. But is has occurred to me, that 5/16" would be > fine provided the bolt matched. Drilling with a 5/16" bit though the > leg and support would not cause a problem. The problem would be from an > undersized bolt. Would everyone agree 5/16" would be okay with a proper > (precise fit) bolt? > > Thank You > Rick Conti > Senior Engineering Manager > The Boeing Company > office: 703 - 414 - 6141 > blackberry: 571 - 215 - 6134 > > ________________________________________________________________________________
Date: Apr 26, 2006
One trick to determine your field of view is to tape a long piece of string to the center of the antenna and hold it a various angles. If at any point one of those angles intersect something that blocks that view of the sky you have your answer on if it's a good spot. Short of mounting the antenna at the absolute highest point of your airframe, you will have some of the sky view blocked. In most cases it's almost nothing but in some locations it can be substantial. Another thing to remember is those big sacs of water in the cabin (us) do a much better job at blocking many types of signals than the fiberglass or plastic. Keep that in mind as you decide where to put your antennas. In the same respect traveling below or around massive buildups (not someplace I would want to be anyway) would be much more effective at blocking your GPS than the fiberglass cabin lid. Either way if you are getting any amount of regular RAIM messages with modern GPS receivers you have a major installation problem in either the equipment or location. You can effectively block half of the sky view and you should still maintain a positive 3D lock almost the entire time with the possible exception of when sats are setting or rising over the horizon. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, April 26, 2006 6:49 AM Subject: Re: RV10-List: GPS Antenna location One thing that turns me off about mounting it under a panel somewhere (less of an issues perhaps than mounting it under the cabin top, is that it could be harder to get a total clear view of the sky in all directions. Imagine yourself digging a 6' deep square hole in your yard, 8' x 8' wide. Sure, you'll see some satellites, because a few of them are high above the horizon. Will you see those that are low on the horizon....well, at a certain point, no. I'm not saying that it's crazy to mount the antenna elsewhere. Certainly under the cowl will be better than under the aluminum of the forward fuselage from the above scenario. Everyone has their choice. The part that I find hard to swallow when I think about doing this myself is that I for the life of me can't figure out why anyone would accept even the slightest degradation from mounting location in a system that's designed to keep them locked into a system that supposedly is to help them stay alive by navigating to the runway through a cloud. If it was a VFR install, I'd have much less concern. Is "pretty good", or "fairly well", or "most of the time" reliable enough for you? Tim Olson - RV-10 N104CD - Flying RV Builder (Michael Sausen) wrote: > The reality is that GPS signals are basically immune to any type of > fiberglass or plastic as long as it isn't covered with a metallic > paint or anything else electrically conductive. Carbon fiber and > metal will block most of the frequencies we deal with. Sure you will > get some tiny amount of degradation from mounting it under glass but > nothing worth mentioning usually. Lot's of people have made a little > shelf just forward of the firewall to mount it on under the cowl and > probably just as many have mounted it under their canopy. Both are as > good of spots as mounting it on the exterior. If you do decide to > mount on the exterior the drag will not amount to much, probably less > than a knot depending on where you put it. It's more of a "clean > look" type of decision. But if you are worried about it and on the > fence, just mount it on the exterior as you can't go wrong. > > As far as the engine cooking the antenna, most GPS (and > XM/Sirius) antennas are amplified so there are some electronics in the > antenna head. As with any other piece of electronic gear performance > can suffer if it becomes too hot, just make sure it isn't mounted next > to anything that radiates a bunch of heat like the exhaust headers. > > Lastly GPS, and most satellite antennas we consumers deal with for > that matter, are circularly polarized and do not require ground planes. > > > Hope that helps. I'm not an expert but I slept at a Holiday Inn > Express last night. > > > Michael Sausen > > RV-10 #352 Working on Fuselage > > Recent RV-10 Build Activity > <http://www.mykitlog.com/display_project.php?project_id=3D22> > > > -- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of > *JSMcGrew(at)aol.com > *Sent:* Tuesday, April 25, 2006 10:35 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: GPS Antenna location > > I'm just throwing this out because no one else has mentioned it - I'm > putting my GPS antennas on the glareshield. The antennas will > certainly have a great view of the sky up through the plexi-glass, the > install is easy and there is no concern about engine heat cooking them. > > Jim McGrew > 40134 > > In a message dated 4/25/2006 6:12:03 P.M. Mountain Daylight Time, > coop85(at)bellsouth.net writes: > > > > I know this has been addressed before, but I was wondering if any of you > that opted to put the GPS antenna under the cowling have any > feedback, good > or bad, on the idea? I suspect reception is okay, my biggest > concern is the > heat in that area affecting the not so cheap antenna. > > Thanks, > Marcus > > Do not =3D es Day > > --> > -> p; - List > Contribution Web Site > > > > Jim "Scooter" McGrew > jsmcgrew(at)aol.com ________________________________________________________________________________
Date: Apr 26, 2006
That was slick. I thought the XM and GPS receivers could not be enclosed in metal. Thought they had to have a clear view of the sky. Thanks Jim Gore RV-10 Georgia > > From: "Jerry Grimmonpre" <jerry(at)mc.net> > Date: 2006/04/26 Wed AM 08:30:37 EDT > To: > Subject: Re: RV10-List: GPS Antenna location > > Gents ... > Check out Dan Checkoway's site on how he created removable glass panels between windshield and cowling area. > > http://www.rvproject.com/hidden_antennas.html > > Refer your questions to Dan ... dan(at)rvproject.com ... > > Jerry Grimmonpre' > RV8A Electrical > > > > > ________________________________________________________________________________
Date: Apr 26, 2006
Subject: Re: Weight in the front
I put a saw horse underneath one of the frames/bulkheads in the tailcone. I had foam padding on top of the saw horse to spread the load out a bit. Even with the engine in place, I keep it there when I am crawling in the tailcone. Keep it simple... Jim 40134 In a message dated 4/26/2006 12:22:50 P.M. Mountain Daylight Time, seanblair(at)adelphia.net writes: --> RV10-List message posted by: seanblair(at)adelphia.net I'm getting in the neighborhood of joining the fuselage to the tailcone and would like to put the plane on its gear. Does anyone have any creative ideas for placing weight on the engine mount until I get my engine bolted on? It will be awhile before I get to the engine, so I need a fairly long-term solution. I'm not a big fan of bracing the tail of the plane as a primary plan, only if needed. It seems with any movement, a tail brace could slip and/or cause damage. Lead shot bags? Any other ideas? About how much weight would be good to place replicating the engine and enough that I don't cause it to nose up getting in and out? Considerations also for working in the backseat area too. Thanks in advance for any help, Sean #40225 Do not archive Jim "Scooter" McGrew jsmcgrew(at)aol.com ________________________________________________________________________________
Subject: Partain Quick Build Delivery
Date: Apr 26, 2006
My son and I received our Quick Build fuselage and wings yesterday, at my home here in Walnut Creek, California, via Partain Transport and laptop GPS. All I can say is "super service". Be prepared - it arrived several hours sooner than anticipated. The trailer is 70 feet long (he had two RV-10 QB's and one RV-7 QB on board) - so don't expect him to back into your residential driveway. Make sure to have a couple of healthy helpers on hand - especially to lift the fuselage off of the transport stand onto your stand. The fuselage transport stand has rollers, and does in fact roll right down the driveway. The wings are carried in the trailer mounted via straps to the side wall, so you and your helper will need to lift them while the driver unstraps them and removes the pads. You and your helper then carry them off the trailer onto your wing stand. Bruce was very helpful - it was comforting to see his "Sun and Fun - 2006" tee shirt and know that he was a fellow aviation enthusiast (and helicopter pilot). But don't count on Bruce staying around too long - he is under DOT regulations as a truck driver and has to keep moving, lest he run out of duty time. Everything arrived in perfect order, well padded and protected. It was $1580 well spent - highly recommended. Bill & Jon Reining #40514 - elevators ________________________________________________________________________________
Subject: New fuel valve handle
Date: Apr 26, 2006
We have designed a new fuel handle for those using Van's stock fuel valve. They will be available in a few weeks for $47. See our website for more info or to pre-order at: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RVFS1 RV Fuel Selector Handle Mike Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com ________________________________________________________________________________
Subject: Extra fuel tanks
Date: Apr 26, 2006
Is it possible to add the 15 gallon extra fuel with the quickbuild wing? I know alot of the fuel system is in place. Thanks! Jim Gore RV-10 Griffin GA ________________________________________________________________________________
Date: Apr 26, 2006
Cc: Marcus Cooper ---- Marcus Cooper wrote: > > I know this has been addressed before, but I was wondering if any of you > that opted to put the GPS antenna under the cowling have any feedback, good > or bad, on the idea? I suspect reception is okay, my biggest concern is the > heat in that area affecting the not so cheap antenna. I have my GPS antenna under the cowl on my -7A, and connected to a GX-60. In 200 flight hours the GPS has never been anything but rock stable and available. It may be that whatever signal attenuation accrues to being beneath the cowl is offset by the fact that the cable run to the back of the GPS unit is only about 18 inches. In the SoCal RV group, there are at least 8 or 10 RVs configured this way and to my knowledge no one has ever reported and problems with the arrangement. Will do the same for the -10. -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 26, 2006
Subject: Re: Extra fuel tanks
How long did you want to sit? At full throttle at 2100 RPM and 60 gallons, you can sit for 4 1/2 hours and still have a half hour reserve. Jim Ayers In a message dated 04/26/2006 4:25:55 PM Pacific Daylight Time, gorejr(at)bellsouth.net writes: --> RV10-List message posted by: Is it possible to add the 15 gallon extra fuel with the quickbuild wing? I know alot of the fuel system is in place. Thanks! Jim Gore RV-10 Griffin GA ________________________________________________________________________________
Date: Apr 26, 2006
Yes, the system is designed to be added to aircraft already completed if you are talking about the ones in January's 2006 Sport Aviation by SafeAir1. JT Lenhardt #40262 ----- Original Message ----- From: gorejr(at)bellsouth.net To: rv10-list(at)matronics.com Sent: Wednesday, April 26, 2006 7:21 PM Subject: RV10-List: Extra fuel tanks Is it possible to add the 15 gallon extra fuel with the quickbuild wing? I know alot of the fuel system is in place. Thanks! Jim Gore RV-10 Griffin GA ________________________________________________________________________________
Date: Apr 26, 2006
I fly my C-170 with a Garmin 196 in WAAS mode, suction cupped to the windshield on the pilots side. We use the built in antenna and have never needed the external antenna ( and that is with a high wing). I would have a concern putting the antenna in a glass hole under forward of the windshield with metal on the sides and firewall. Base of windshield above the level of the front section or over head would be the logical choices. Steve Port St. Lucie, FL #40499 772-475-5556 Sent from my Treo 600 ________________________________________________________________________________
Date: Apr 27, 2006
Subject: Fuselage width on Gear dimension
Would someone please measure the maximum width of the fuselage after the landing gear is installed. I believe this would be the dimension from the outside of the landing gear. I have a 3 car garage but it is only 22' deep and there is a column between the bays. I am trying to figure out if I can put the plane on the gear and install the engine with the assembly on an angle and still get it out with out major surgery on something like the garage door opening. My alternate is to construct a temporary garage extension which I want to avoid if possible. -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Date: Apr 27, 2006
Check the three view drawing (available on Tim's site), it's 7' 4" to the center of the tires.. I have the same issue. Thank You Rick Conti Senior Engineering Manager The Boeing Company office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 -----Original Message----- From: Larry Rosen [mailto:LarryRosen(at)comcast.net] Sent: Thursday, April 27, 2006 8:27 AM Subject: RV10-List: Fuselage width on Gear dimension Would someone please measure the maximum width of the fuselage after the landing gear is installed. I believe this would be the dimension from the outside of the landing gear. I have a 3 car garage but it is only 22' deep and there is a column between the bays. I am trying to figure out if I can put the plane on the gear and install the engine with the assembly on an angle and still get it out with out major surgery on something like the garage door opening. My alternate is to construct a temporary garage extension which I want to avoid if possible. -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Date: Apr 27, 2006
7'9" on gear with no wheels or tires on. It may spread a little with the weight of the engine. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org 352-465-4545 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Thursday, April 27, 2006 7:27 AM Subject: RV10-List: Fuselage width on Gear dimension Would someone please measure the maximum width of the fuselage after the landing gear is installed. I believe this would be the dimension from the outside of the landing gear. I have a 3 car garage but it is only 22' deep and there is a column between the bays. I am trying to figure out if I can put the plane on the gear and install the engine with the assembly on an angle and still get it out with out major surgery on something like the garage door opening. My alternate is to construct a temporary garage extension which I want to avoid if possible. -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com -- -- ________________________________________________________________________________
Date: Apr 27, 2006
Subject: Gear width and garage openings
When we built our 3 Glastar's we did each of them in an area that ultimately required us to roll thru an 8' wide garage door opening. The gear on a Glastar is about 94" axel to axel when installed, but when you add an engine, prop and all the other goodies it spreads to more than 8'. The solution, which I believe will be applicable to the RV-10 is to attach a ratcheting tie-down strap between to the two axels, down low near the wheel and pull the two axels towards eachl together. We were able to very easily spring the gear in and roll right thru the door opening. :) Bob Newman ________________________________________________________________________________
Date: Apr 27, 2006
Our FBO here gives home-base pilots a excellent deal on avgas-at one point last year during the last run-up in prices, there was almost $2/gal difference in area gas prices. Bigger tanks would give me greater out and back range without having to refuel. Albert Gardner Yuma, AZ -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Wednesday, April 26, 2006 6:18 PM Subject: Re: RV10-List: Extra fuel tanks How long did you want to sit? At full throttle at 2100 RPM and 60 gallons, you can sit for 4 1/2 hours and still have a half hour reserve. Jim Ayers In a message dated 04/26/2006 4:25:55 PM Pacific Daylight Time, gorejr(at)bellsouth.net writes: Is it possible to add the 15 gallon extra fuel with the quickbuild wing? I know alot of the fuel system is in place. Thanks! Jim Gore RV-10 Griffin GA ________________________________________________________________________________
Date: Apr 27, 2006
Subject: Autogas for 540
100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years. Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane: 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*, -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*, -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5* I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar. Anyone else planning to run autogas in their Lycosaur? -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 27, 2006
Mike count me in. Please send another email when stock has arrived. Thanks, Randy ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Lauritsen - Work Sent: Wednesday, April 26, 2006 1:24 PM Subject: RV10-List: New fuel valve handle We have designed a new fuel handle for those using Van's stock fuel valve. They will be available in a few weeks for $47. See our website for more info or to pre-order at: http://www.cleavelandtoolstore.com/prodinfo.asp?number=3DRVFS1 Mike Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com ________________________________________________________________________________
Date: Apr 27, 2006
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Well, with injection you can lean that sucker out much more than with a carb. It would be interesting to run the numbers comparing that situation . . . TDT 40025 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Masys Sent: Thursday, April 27, 2006 12:19 PM Subject: RV10-List: Autogas for 540 100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years. Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane: 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*, -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*, -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5* I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar. Anyone else planning to run autogas in their Lycosaur? -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 27, 2006
It is my understanding that these STCs were intended to use alcohol free fuel (i.e. no methanol or ethanol). This may be an issue since MTBE is being phased out and replaced with ethanol. http://www.eaa.org/education/fuel/knopp_alcohol.html Tommy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Masys Sent: Thursday, April 27, 2006 11:19 AM Subject: RV10-List: Autogas for 540 100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years. Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane: 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*, -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*, -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5* I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar. Anyone else planning to run autogas in their Lycosaur? -Dan Masys #40448 ________________________________________________________________________________
Subject: Re: Autogas for 540
Date: Apr 27, 2006
My experience with the O-540 has been that the 235 hp versions run well on auto fuel, but the 250hp and 260 hp versions tend to ping. Cal ----- Original Message ----- From: "Dan Masys" <dmasys(at)cox.net> Sent: Thursday, April 27, 2006 12:18 PM Subject: RV10-List: Autogas for 540 > > 100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years. > > Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane: > 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*, > -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A 5*, > -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5* > > I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar. > > Anyone else planning to run autogas in their Lycosaur? > > -Dan Masys > #40448 > > ________________________________________________________________________________
Date: Apr 27, 2006
I'm thinking it as well. Keep in mind however, that the choice in engine isn't the only factor in safely running auto-gas. For instance, the Cherokee 235 with the 0-540-B4B5 has the autogas STC whereas an Apache running the very same engines does not. The same can be said for the mooneys and comanches. Pull the engines out of those planes and put them into a cherokee 180 and you go from no autogas to autogas approved. According to Petersen, the tighter the cowl and the higher the performance, the harder it was to pass their tests. I guess in the case of the mooneys and comanches, they had problems with the fuel boiling in the carb. If I remember correctly, one of the tests was to heat the fuel tanks (seems sort of dangerous) to 110 degrees and then do a MaxPerformance climb all the way to 12,500. Any hiccups in performance (loss of power, fuel pressure, etc) and it failed the test. Does that mean if you fly conservatively, ie - don't do maximum performance climbs to 12,500, you won't have problems? I don't know. I think auto-gas is a possibility in the RV-10s, but someone is going to have to be the beta tester :-( -Brian #40497 N211BD Iowa City, IA ----- Original Message ----- From: "Dan Masys" <dmasys(at)cox.net> Sent: Thursday, April 27, 2006 11:18 AM Subject: RV10-List: Autogas for 540 > > 100LL hit a psychological threshhold at my home airport (JWN) this week. > It is now at $5 per gallon. This got me thinking again about an autogas > STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, > saving more than $10K at 13.5 gal/hr over five years. > > Petersen lists autogas STCs for the following variants of the O-540, with > those having an asterisk needing 91 octane and all others ok on 87 octane: > 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, > -A1B5*, > -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*, > -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, > -H1B5D*, -H2B5D* -F1B5* > > I was going to go with an IO-540 but it might be worth going back to a > carburator to have a plane that is not hostage to the economics of greed, > where every time autogas goes up 20 cents a gallon, avgas goes up a > dollar. > > Anyone else planning to run autogas in their Lycosaur? > > -Dan Masys > #40448 > > > ________________________________________________________________________________
Date: Apr 27, 2006
Part of my plan is flexibility in choices, I'm using an O-540-E4B5 in RV-10. -Bob Newman >>> dmasys(at)cox.net 4/27/2006 12:18:42 PM >>> 100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years. Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane: 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*, -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*, -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5* I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar. Anyone else planning to run autogas in their Lycosaur? -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 27, 2006
Bob, I'm not sure I understand. I've never used a reamer and just realized I shouldn't use an air drill with a reamer. Maybe the hand wrench from my tap & die set. What under size hole did you drill before using the .311" reamer? Please explain the grinding of the shoulders at the reamer stem side to be able to pull up and through. Does any of this make sense without using a close tolerance bolt? Bill suggested using a .3125 reamer with a 5/16" close tolerance bolt. All of which sounds good. Thank You Rick Conti Senior Engineering Manager The Boeing Company office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 -----Original Message----- From: Rob Kermanj [mailto:flysrv10(at)gmail.com] Sent: Wednesday, April 26, 2006 10:30 AM Subject: Re: RV10-List: My 2 Cents on the Landing Gear I used the same reamer as you have purchased. I found it easier to insert the reamer from the button, chuck it and pull it through the hole. If you decide to do this, you may need to grind the blade shoulders at the reamer stem side to be able to pull up through. On 4/26/06, Conti, Rick wrote: > > Whenever I start a new "kit", I review the instructions several times, > once to ensure I have the necessary tools and parts. The .311" drill > bit appeared to be a problem. I called Van's and received an > interesting answer: I was told a 5/16 bit would be okay. I haven't > installed the gear yet and after reading about loose landing gear I had > second thoughts. I received my .311" reamer from McMaster-Carr (thanks > for the info) yesterday. But is has occurred to me, that 5/16" would be > fine provided the bolt matched. Drilling with a 5/16" bit though the > leg and support would not cause a problem. The problem would be from an > undersized bolt. Would everyone agree 5/16" would be okay with a proper > (precise fit) bolt? > > Thank You > Rick Conti > Senior Engineering Manager > The Boeing Company > office: 703 - 414 - 6141 > blackberry: 571 - 215 - 6134 > > ________________________________________________________________________________
Date: Apr 27, 2006
I've never owned a plane with an auto-gas STC. How do you refuel the plane? I wouldn't image the wings would fit under the canopy of an Exxon station. Thank You Rick Conti Senior Engineering Manager The Boeing Company office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 -----Original Message----- From: Bob Newman [mailto:rnewman(at)lutron.com] Sent: Thursday, April 27, 2006 2:32 PM Subject: Re: RV10-List: Autogas for 540 Part of my plan is flexibility in choices, I'm using an O-540-E4B5 in RV-10. -Bob Newman >>> dmasys(at)cox.net 4/27/2006 12:18:42 PM >>> 100LL hit a psychological threshhold at my home airport (JWN) this week. It is now at $5 per gallon. This got me thinking again about an autogas STC. Had one for my C-182 and flew it happily for 1100 hours on autogas, saving more than $10K at 13.5 gal/hr over five years. Petersen lists autogas STCs for the following variants of the O-540, with those having an asterisk needing 91 octane and all others ok on 87 octane: 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, -A1A5*, -A1B5*, -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, -D1A5*, -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, -H2A5D*, -H1B5D*, -H2B5D* -F1B5* I was going to go with an IO-540 but it might be worth going back to a carburator to have a plane that is not hostage to the economics of greed, where every time autogas goes up 20 cents a gallon, avgas goes up a dollar. Anyone else planning to run autogas in their Lycosaur? -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 27, 2006
ECi Titan IO-540 kit engine (~ 2007?) is supposed to be autofuel capable. This is partly because they are using a fuel spider with fixed orifice and not a fuel servo with some autogas sensitive components. Still they rec 100LL initial for valves. Note this system requires a return fuel line. I have built these fittings into my tanks just in case. Part of reason for return line is to return any vapor to tank. Autogas and ethanol autogas in particular has lower vapor pressure. Ethanol is also a good solvent for lots of things.... Deltahawk claims they sold out 2005 and 2006 production runs but I have never seen a builder site which makes me wonder if they really have that many out there. I saw one article that 2005 run was only two engines. A number of builders are looking at rotary engines as well. Eric ________________________________________________________________________________
Date: Apr 27, 2006
In a message dated 4/27/06 5:52:46 P.M. Eastern Daylight Time, ericmpmail-rv10(at)yahoo.com writes: Deltahawk claims they sold out 2005 and 2006 production runs but I have never seen a builder site which makes me wonder if they really have that many out there. I know the person that's #20 on the list has yet to smell diesel in the morning...promised for over a year ago...hope they make it... P ________________________________________________________________________________
Date: Apr 27, 2006
Just a quick note that I think applies - FYI... this is a section from a discussion on the Subaru list - > The wings are wide open. Lower wing skins are not bonded on yet. I can > run any size return line. Why float type?What's so special about that? > The fuel pick up lines are in. They should stay. They are 3/8 in size. > I hope I don't sound like an idiot. > Gary Hi Gary, The capacitance fuel level senders require re-calibration for each type of fuel you use. So, if you use mogas most of the time, but from time to time need to put in 100LL, then the fuel level will not read correctly. The very simple float senders don't have this problem. Another alternative to the fuel return lines is to install a header tank. From what I've read on the net, this seems to be a popular option. -- Mickey Coggins http://www.rv8.ch/ #82007 finishing -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Panning Sent: Thursday, April 27, 2006 2:42 PM Subject: RE: RV10-List: Autogas for 540 ECi Titan IO-540 kit engine (~ 2007?) is supposed to be autofuel capable. This is partly because they are using a fuel spider with fixed orifice and not a fuel servo with some autogas sensitive components. Still they rec 100LL initial for valves. Note this system requires a return fuel line. I have built these fittings into my tanks just in case. Part of reason for return line is to return any vapor to tank. Autogas and ethanol autogas in particular has lower vapor pressure. Ethanol is also a good solvent for lots of things.... Deltahawk claims they sold out 2005 and 2006 production runs but I have never seen a builder site which makes me wonder if they really have that many out there. I saw one article that 2005 run was only two engines. A number of builders are looking at rotary engines as well. Eric ________________________________________________________________________________
Date: Apr 27, 2006
What kind of speed and fuel burn do you get at these settings? Thanks Jim Gore > > From: LessDragProd(at)aol.com > Date: 2006/04/26 Wed PM 09:17:48 EDT > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Extra fuel tanks > > > How long did you want to sit? > At full throttle at 2100 RPM and 60 gallons, you can sit for 4 1/2 hours and > still have a half hour reserve. > > Jim Ayers > > In a message dated 04/26/2006 4:25:55 PM Pacific Daylight Time, > gorejr(at)bellsouth.net writes: > > --> RV10-List message posted by: > > Is it possible to add the 15 gallon extra fuel with the quickbuild wing? I > know alot of the fuel system is in place. Thanks! > Jim Gore RV-10 > Griffin GA > > > > > > ________________________________________________________________________________
Date: Apr 27, 2006
Subject: Re: Autogas for 540 (IO-540)
> > I've never owned a plane with an auto-gas STC. How do you refuel the > plane? I wouldn't image the wings would fit under the canopy of an > Exxon station. I use 93 octane in my RV-6A (O-360, 8.5/1 compression). I use one tank for avgas only, the other for auto gas and/or avgas. To fuel at the airport I use five gallon metal fuel cans with the spring loaded "safety nozzle." Manassas airport requires these nozzles for those of us who fuel our plans from fuel cans. Grounding wires and conductive funnels are also required at Manassas. I've been able to force the RV-6A to vapor lock on autogas, but it hasn't been a problem unless I set out to overheat the fuel (hot day, fly hard, land hot, long taxi, then try immediate takeoff). I have had the autogas ice up on me twice during winter flights. I think it happened because I had a Fram G3 paper fuel filter between the fuel tank and the fuel selector. I've spoken to a couple of experts in the field, who tell me the paper filters are susceptible to freezing if there's any water in the fuel. I'm replacing the Fram G3s with the Purolator Pro 806, which uses a nylon filter. IO-540 and auto gas: I spent quite a while talking to Dan from Airflow Performance (the folks who make the fuel pump that Van sells for IO-540 powered RV-10s) about autogas in the Bendix injection system. Dan used to be Bendix's project engineer on the Bendix RS and RSA fuel injection systems (that's the one on the IO-540). Don told me there's no materials compatability problem with using auto gas in the Bendix system, but you don't want to leave autogas sitting in the servo for a long time because when auto gas evaporates it'll leave "varnish" deposits. Dan said many people use auto gas in the Bendix injected engines, but he pointed out that vapor lock is a concern when using auto gas in an injected engine. I talked to Mr Petersen of the famous Petersen STC about injected engines and auto gas. He told me he'd never been able to get an injected installation to pass all the vapor lock tests, thus the lack of any Petersen STCs for the IO-XXX engines. I plan to try auto gas in my RV-10 (IO-540). To try to head off vapor lock issues I'll have no gascolator, fire sleeved fuel lines with lines kept as short as possible, and probably blast cooling of the engine driven fuel pump. And careful flight testing over an airport with one tank full of good old av ga$. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 830 hrs RV-10 #40059 under construction Conti, Rick wrote: > > I've never owned a plane with an auto-gas STC. How do you refuel the > plane? I wouldn't image the wings would fit under the canopy of an > Exxon station. > > Thank You > Rick Conti > Senior Engineering Manager > The Boeing Company > office: 703 - 414 - 6141 > blackberry: 571 - 215 - 6134 > > > -----Original Message----- > From: Bob Newman [mailto:rnewman(at)lutron.com] > Sent: Thursday, April 27, 2006 2:32 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Autogas for 540 > > > Part of my plan is flexibility in choices, I'm using an O-540-E4B5 in > RV-10. > > -Bob Newman > > > > >>>>dmasys(at)cox.net 4/27/2006 12:18:42 PM >>> > > > 100LL hit a psychological threshhold at my home airport (JWN) this > week. It is now at $5 per gallon. This got me thinking again about an > autogas STC. Had one for my C-182 and flew it happily for 1100 hours on > autogas, saving more than $10K at 13.5 gal/hr over five years. > > Petersen lists autogas STCs for the following variants of the O-540, > with those having an asterisk needing 91 octane and all others ok on 87 > octane: > 0-540-B1A5, -B1B5, -B1D5, -B2A5, -B2B5, -B2C5, -B4A5, -B4B5, -A1A*, > -A1A5*, -A1B5*, > -A1C5*, -A1D*, -A1D5*, -A2B*, -A3D5*, -A4A5*, -A4B5*, -A4C5*, -A4D5*, > -D1A5*, > -E4A5*, -E4B5*, -E4C5*, -G1A5*, -G2A5*, -H1A5*, -H2A5*, -H1A5D*, > -H2A5D*, -H1B5D*, -H2B5D* -F1B5* > > I was going to go with an IO-540 but it might be worth going back to a > carburator to have a plane that is not hostage to the economics of > greed, where every time autogas goes up 20 cents a gallon, avgas goes up > a dollar. > > Anyone else planning to run autogas in their Lycosaur? > > -Dan Masys > #40448 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 27, 2006
Umm, err, how do I put this? 100LL is 7.0 RVP. Most summer mogas is 7.6-9.0 RVP. Adding ethanol raises the RVP about 1 point. The higher the RVP the more hazard of vapor lock. That means mogas with ethanol has a higher vapor pressure. Even if you engine is fine with the fuel, how are you going to keep it in the wet wing tanks after it softens the PRC? Are you going to want to reseal those tanks every few years? Eric Panning wrote: > > ECi Titan IO-540 kit engine (~ 2007?) is supposed to > be autofuel capable. This is partly because they are > using a fuel spider with fixed orifice and not a fuel > servo with some autogas sensitive components. Still > they rec 100LL initial for valves. Note this system > requires a return fuel line. I have built these > fittings into my tanks just in case. Part of reason > for return line is to return any vapor to tank. > Autogas and ethanol autogas in particular has lower > vapor pressure. Ethanol is also a good solvent for > lots of things.... > > Deltahawk claims they sold out 2005 and 2006 > production runs but I have never seen a builder site > which makes me wonder if they really have that many > out there. I saw one article that 2005 run was only > two engines. > > A number of builders are looking at rotary engines as > well. > > Eric > > ________________________________________________________________________________
Date: Apr 27, 2006
Hi Jim, Just differential numbers for now, since my customers RV-10 doesn't have all of the fairing on and it isn't painted yet. This numbers were obtained at 8,000' density altitude at full throttle. 2500 RPM 20 gph 2300 RPM 15 gph +1 knot faster than 2500 RPM 2100 RPM 12 gph -6 knots slower than 2500 RPM Regards, Jim Ayers In a message dated 04/27/2006 6:15:36 PM Pacific Daylight Time, gorejr(at)bellsouth.net writes: --> RV10-List message posted by: What kind of speed and fuel burn do you get at these settings? Thanks Jim Gore ________________________________________________________________________________
Date: Apr 27, 2006
Jim, lets here the airspeed and MP at 8,000 DA, 2500 RPM, 20 gph, 3 blade MT and a Lyco at 260hp. My version was missing your answer to Jim Gore's request for SPEED data. John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Thursday, April 27, 2006 8:55 PM Subject: Re: RV10-List: Extra fuel tanks Hi Jim, Just differential numbers for now, since my customers RV-10 doesn't have all of the fairing on and it isn't painted yet. This numbers were obtained at 8,000' density altitude at full throttle. 2500 RPM 20 gph 2300 RPM 15 gph +1 knot faster than 2500 RPM 2100 RPM 12 gph -6 knots slower than 2500 RPM Regards, Jim Ayers In a message dated 04/27/2006 6:15:36 PM Pacific Daylight Time, gorejr(at)bellsouth.net writes: =09 What kind of speed and fuel burn do you get at these settings? Thanks Jim Gore ________________________________________________________________________________
Date: Apr 28, 2006
Hi John, The manifold pressure was 23". Regarding airspeed. IMHO, the ONLY way to get VALID comparison airspeed numbers between propellers is to fly them on the same aircraft and engine WITH NO OTHER CHA= NGES MADE. I have offered to pay the expenses and provide the 3 blade MT Propeller for=20= a Hartzell propeller equipped RV-10 to do the testing. I think it says a GREAT deal that there have been NO TAKERS from RV-10's with the RV-10 Hartz= ell propeller. What are you Hartzell drivers? CHICKEN? With Best Regards, Jim Ayers PS Was that gauntlet to subtle? In a message dated 04/27/2006 9:22:46 PM Pacific Daylight Time, johnwcox(at)pacificnw.com writes: Jim, lets here the airspeed and MP at 8,000 DA, 2500 RPM, 20 gph, 3 blade M= T and a Lyco at 260hp. My version was missing your answer to Jim Gore=E2=80= =99s request for SPEED data. John Cox ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Re: 540 power settings
Hi All, I received the following answer from MT Propeller engineering regarding the question Dick Sipp asked. "Hi Jim, As I told you yesterday on the telephone our propeller has no limitations in respect to rpm and MAP settings, like 28 inch and 2200 rpm. This problem is only with aluminum propellers. So, we have no limitations of our propeller operation except the engine limitations from the engine manufacture still apply. With best regards, MT - Propeller Entwicklung GmbH Martin Albrecht Engineering" So I hope this answers your question, Dick. The engine is the limiting factor with the 3 blade MT Propeller. For continuous operation; 1800 RPM at 25" mp to 2200 RPM at 29" mp. Whereas the aluminum blade propeller is the limiting factor on the Lycoming engine. And you're right. It is a shame if the propeller manufacturer "placed more restrictive limits on engine operation than does the engine manufacturer." Unfortunately, it appears to be a Hartzell problem. Regards, Jim Ayers In a message dated 04/20/2006 8:21:24 PM Pacific Daylight Time, rsipp(at)earthlink.net writes: Jim: Are the RPM limits you refer to in the second half of your message MT limits for their propellers? The Lycoming IO-540-D series charts from the engine operators manual provide much broader RPM vs. manifold pressure limits. Above 5500' there is no manifold pressure limitation for any RPM. Below 5500' manifold pressure limits are shown; as an example, at 1800 RPM 24 inches of manifold pressure is the limitation. At sea level and 2200 RPM the manifold pressure limit is 28.5", above 2200 RPM there is no manifold pressure limit. These charts show that the old wives tale of not operating "oversquare" is mostly legend and not a problem as far as Lycoming is concerned. While I am not suggesting that operating continuously at a limitation is prudent, very efficient operation does occur at full throttle settings and relatively low RPMs. An added benefit is smoother and quieter operation as well. It would be a shame if MT placed more restrictive limits on engine operation than does the engine manufacturer. Dick Sipp 40065 ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Re: Autogas for 540 - autogas vapor pressure
Hi Kelly, I completely agree. I typed lower but meant higher just as you described. With a hot tunnel at altitude potential for vapor lock is high. I think winter gas has an even higher vapor pressure. For sealing the tanks I was going to use friction stir welding - just like the Eclipse jet. Harbor Freight has a special on one and includes free pocket knife if you act now.... kidding! Eric --- Kelly McMullen wrote: > > > Umm, err, how do I put this? 100LL is 7.0 RVP. Most > summer mogas is > 7.6-9.0 RVP. Adding ethanol raises the RVP about 1 > point. The higher the > RVP the more hazard of vapor lock. That means mogas > with ethanol has a > higher vapor pressure. > Even if you engine is fine with the fuel, how are > you going to keep it > in the wet wing tanks after it softens the PRC? Are > you going to want to > reseal those tanks every few years? > Eric Panning wrote: > > > > > ECi Titan IO-540 kit engine (~ 2007?) is supposed > to > > be autofuel capable. This is partly because they > are > > using a fuel spider with fixed orifice and not a > fuel > > servo with some autogas sensitive components. > Still > > they rec 100LL initial for valves. Note this > system > > requires a return fuel line. I have built these > > fittings into my tanks just in case. Part of > reason > > for return line is to return any vapor to tank. > > Autogas and ethanol autogas in particular has > lower > > vapor pressure. Ethanol is also a good solvent for > > lots of things.... > > > > Deltahawk claims they sold out 2005 and 2006 > > production runs but I have never seen a builder > site > > which makes me wonder if they really have that > many > > out there. I saw one article that 2005 run was > only > > two engines. > > > > A number of builders are looking at rotary engines > as > > well. > > > > Eric > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Re: RV Assembly Workshop
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: Re: Auto engine conversion
Date: Apr 28, 2006
I decided to go with an auto conversion, so I yanked the hemi out of my Dodge 1/2 ton pickup. The low end power is great and it will cruise all day without a hitch. Acceleration and climb are a bit slow, but it really sounds pretty cool. I am having some cooling problems and am redesigning the air inlets which I hope will help. It's running mogas without any problems. Overall I think it will work out OK, but it burns a lot of gas and has cost me a lot. It's probably the first Dodge pickup running with an IO-540. Ohhhhh! You mean put a car engine in an airplane and fly around with my family in it? No thanks. :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=31419#31419 ________________________________________________________________________________
Subject: James Cowl
Date: Apr 28, 2006
Hey all - I'm going through the finish kit items looking at what I need and don't, and wondered if anyone is planning on using the james cowl? I've heard (very secondhand info) that the fit was a bit of a chore - just wondering if anyone's got any firsthand info or thoughts? cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: Close Tolerance Bolts
Date: Apr 28, 2006
Recommend Spencer Aircraft www.apenceraircraft.com 1-800-424-1160 (Jeff) Washington State AN175-24A for $6.95. No traceability paperwork back to the manufacturer, which is not an issue for me. It is in fact a close tolerance bolt. Same bolt elsewhere is $22.00 Thank You Rick Conti Senior Engineering Manager The Boeing Company office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Andair 20X7T fuel selector extension
I just asked this question via email... Sorry for the dely on replying to you, we have just got back from the Sun and Fun airshow. In response to your query,as you already have the valve you will require an EX-7 extention upgrade kit which although can be ordered from our website if you contact us via e-mail we can process this directly. The price of the EX-7 is 50 (50x1.73=$86.50)+ shipping .this is for a extention kit with a straight extention, if you require any UJ's or cuplers, or longer extention tubes prices may vary. Thank-you for your enquiry, if we can be of any further assistance please do not hesitate to contact us. We look forward to hearing from you. Kind Regards, Owen Phillips Andair LTD www.andair.co.uk Tel +44 (0)2392 473954 Fax +44 (0)2392 473956 ...snip... Sorry if this has already been covered......I'm having a heck of a time finding the six inch extension for the Andair valve. Do I have to get it from the folks in the UK? I tried the distributors and listed in the US with no luck. I bought the FS20X7. Is the extension universal? ...snip... ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Re: Auto engine conversion with good links for Lycoming operation
> --- "RV Builder (Michael Sausen)" > wrote: > >> I still think that it would be an > > excellent engine for any of the 2 seat RV's. Not > > flaming Egg, just stating my opinions along with > > some facts. It is amusing to see the Subie dialog applied to the -10 recapitulate virtually every issue that played out on the 2 seat RV lists over the past several years. Only difference was that the risk scenario was only one other soul on board, rather than three. It was the case that since dyno figures were never part of the discussion, most of the inference about horsepower was based on fuel flows. For me, the big deciding factors in an auto engine conversion are 1) no longevity data for years to come and 2) the resale stigma. This sucker is gonna be a substantial capital investment, and if putting a non-aircraft engine does anything reliably to an experimental, it is that it reliably decreases its resale value. That said, I am very glad there are pioneers who want to do this. (in recognition that the pioneers take the arrows and the settlers get the land). -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Re: RV handling
Cc: Tim Olson ---- Tim Olson wrote: > It just doesn't have the roll and > ultra-light feel that those planes would. The -10 controls > get VERY heavy at higher airspeeds. I don't think you'd > have a very easy time rolling the -10 at 140+ Kts. Your > stick takes a LOT of force in roll at those speeds. The controls get increasingly heavy on my -7A at increasing airspeeds also, especially above 180 KIAS. In fact, in power on descents when it rather easily gets to its 200kt Vne, the heavy stick forces are as reliable an the airspeed indicator. The 200hp -7A is already like the -10 in that it is more nose-heavy than the 180hp 2 seat RV's, and it is for that reason a little more stable IFR platform than the lightweight engine + prop combinations. -Dan Masys #40448 ________________________________________________________________________________
Date: Apr 28, 2006
The question remains... What was the airspeed in knots. I'm not engaging in the banter about valid airspeed. Just your number Please! The rest of the dialog is well known to the group about identical aircraft, identical engines, identical power settings. Am I the only one that has notices dozens of flying RV-10s and everyone is hiding their personal performance numbers? About the only positive response has been on empty weight. No one is identifying their change in CG from the factory spec. There are lots of question on component placement that would help builders if there was less secrecy. At least Tim mentioned he did not have the loading problem as quoted by VANS. We should all be able to ask, "And what did he do to solve that obstacle?" What is it about you MT prop twirlers that keeps data so close to the vest. I can't make out your whisper, could you shout it once again please... Airspeed that is. I got the chicken part. Today is Friday and it smells fishy. John - $-00.02 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Friday, April 28, 2006 8:09 AM Subject: Re: RV10-List: Extra fuel tanks Hi John, The manifold pressure was 23". Regarding airspeed. IMHO, the ONLY way to get VALID comparison airspeed numbers between propellers is to fly them on the same aircraft and engine WITH NO OTHER CHANGES MADE. I have offered to pay the expenses and provide the 3 blade MT Propeller for a Hartzell propeller equipped RV-10 to do the testing. I think it says a GREAT deal that there have been NO TAKERS from RV-10's with the RV-10 Hartzell propeller. What are you Hartzell drivers? CHICKEN? With Best Regards, Jim Ayers PS Was that gauntlet to subtle? In a message dated 04/27/2006 9:22:46 PM Pacific Daylight Time, johnwcox(at)pacificnw.com writes: Jim, lets here the airspeed and MP at 8,000 DA, 2500 RPM, 20 gph, 3 blade MT and a Lyco at 260hp. My version was missing your answer to Jim Gore's request for SPEED data. John Cox ________________________________________________________________________________
Date: Apr 28, 2006
Dan, I agree - Cessna is the way to go. If it was good enough for grandpa it's good enough for me. Would you believe people are putting "experimental" airplanes together in their garage??? Some of these people started building before the supplier even finished the kit or quoted the final cost. I've even read that some of the early pioneers started with just a bunch of raw materials and vague plans. Why they didn't wait for the pre-punched kits is a mystery.... :) I'm sure the Cessna and Piper owners discuss the risk scenario of building your own plane all the time. Acceptable risk is a complex decision that ultimately everyone has to make for themselves. I think for most builders, the risk tradeoffs are primarily made in panels. VFR/IFR/full IFR/ Glass cockpit/ autopilot/ Mode-S Traffic/Oxygen/ TCAS/ TAWS/ Forward looking IR/ ? How much is enough? Does the answer change if it is 2 or 4 souls? Another risk is too much plane and not enough money left for gas... Agree on resale value and lack of dyno data. I think the aquisition cost can be lower but the resale value is lower still. Even dyno is not sufficient as ultimate performance also depends on drag - tied closely to cooling drag, etc. Have a great weekend, Eric 40150 - Working on mating center and forward section of fuselage. --- Dan Masys wrote: > > > > --- "RV Builder (Michael Sausen)" > > wrote: > > > >> I still think that it would be an > > > excellent engine for any of the 2 seat RV's. > Not > > > flaming Egg, just stating my opinions along with > > > some facts. > > It is amusing to see the Subie dialog applied to the > -10 recapitulate virtually every issue that played > out on the 2 seat RV lists over the past several > years. Only difference was that the risk scenario > was only one other soul on board, rather than three. > > > It was the case that since dyno figures were never > part of the discussion, most of the inference about > horsepower was based on fuel flows. > > For me, the big deciding factors in an auto engine > conversion are 1) no longevity data for years to > come and 2) the resale stigma. This sucker is gonna > be a substantial capital investment, and if putting > a non-aircraft engine does anything reliably to an > experimental, it is that it reliably decreases its > resale value. > > That said, I am very glad there are pioneers who > want to do this. (in recognition that the pioneers > take the arrows and the settlers get the land). > > -Dan Masys > #40448 > > ________________________________________________________________________________
Date: Apr 28, 2006
Jay =96 I try to keep a few extensions on hand, but I=92m out at the moment. I=92ll be happy to order more, but I need to order at least a dozen to get the shipping cost down to a reasonable level. So=85 RV-10=92ers =96 If you need an EX-7 Extension kit for your FS20X7 fuel valve, or anything else from Andair (a specific valve, different fittings for your valve, gascolator, etc) please let me know. I=92d like to place an order early next week. Neal E. George 244 Andrews Street Maxwell AFB, AL 36113 Home - 334-262-8993 Cell - 334-546-2033 I just asked this question via email... Date: Wed, 26 Apr 2006 12:55:57 +0100 Sorry for the dely on replying to you, we have just got back from the Sun and Fun airshow. In response to your query,as you already have the valve you will require an EX-7 extention upgrade kit which although can be ordered from our website if you contact us via e-mail we can process this directly. The price of the EX-7 is =A350 (50x1.73=3D$86.50)+ shipping .this is for a extention kit with a straight extention, if you require any UJ's or cuplers, or longer extention tubes prices may vary. Thank-you for your enquiry, if we can be of any further assistance please do not hesitate to contact us. We look forward to hearing from you. Kind Regards, Owen Phillips Andair LTD www.andair.co.uk Tel +44 (0)2392 473954 Fax +44 (0)2392 473956 ...snip... Sorry if this has already been covered......I'm having a heck of a time finding the six inch extension for the Andair valve. Do I have to get it from the folks in the UK? I tried the distributors and listed in the US with no luck. I bought the FS20X7. Is the extension universal? ...snip... ________________________________________________________________________________
Subject: Re: Andair 20X7T fuel selector extension
Date: Apr 28, 2006
I need to ask this (for a friend) -- is this extension required? Why are folks putting it? I think Tim O. didn't put one in.. What's the final answer? :) -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=31514#31514 ________________________________________________________________________________
Subject: cowling alignment
Date: Apr 28, 2006
On the earlier RV models it was common to align the cowling so that the top edge of the forward cowling was 1/8" or so lower than the prop spinner. The theory was that the engine would settle about that amount in operation and "sag" into good alignment. Of those flying, did any of you do this? If not have you noticed and settling of the engine in the early operations? Like many subjects there was always a good bit of debate about whether or not this settling happened and if the technique worked or was necessary. Thanks Dick Sipp 40065 ________________________________________________________________________________
Date: Apr 28, 2006
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: Apr 28, 2006
Neal, If you don=92t mind keeping one in stock for a while, I=92ll be needing one in a couple of months or so. I=92m just a little south of you in Enterprise. Rob #392 QB delivery next week! _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neal George Sent: Friday, April 28, 2006 7:11 PM Subject: RE: RV10-List: Andair 20X7T fuel selector extension Jay =96 I try to keep a few extensions on hand, but I=92m out at the moment. I=92ll be happy to order more, but I need to order at least a dozen to get the shipping cost down to a reasonable level. So=85 RV-10=92ers =96 If you need an EX-7 Extension kit for your FS20X7 fuel valve, or anything else from Andair (a specific valve, different fittings for your valve, gascolator, etc) please let me know. I=92d like to place an order early next week. Neal E. George 244 Andrews Street Maxwell AFB, AL 36113 Home - 334-262-8993 Cell - 334-546-2033 I just asked this question via email... Date: Wed, 26 Apr 2006 12:55:57 +0100 Sorry for the dely on replying to you, we have just got back from the Sun and Fun airshow. In response to your query,as you already have the valve you will require an EX-7 extention upgrade kit which although can be ordered from our website if you contact us via e-mail we can process this directly. The price of the EX-7 is =A350 (50x1.73=3D$86.50)+ shipping .this is for a extention kit with a straight extention, if you require any UJ's or cuplers, or longer extention tubes prices may vary. Thank-you for your enquiry, if we can be of any further assistance please do not hesitate to contact us. We look forward to hearing from you. Kind Regards, Owen Phillips Andair LTD www.andair.co.uk Tel +44 (0)2392 473954 Fax +44 (0)2392 473956 ...snip... Sorry if this has already been covered......I'm having a heck of a time finding the six inch extension for the Andair valve. Do I have to get it from the folks in the UK? I tried the distributors and listed in the US with no luck. I bought the FS20X7. Is the extension universal? ...snip... ________________________________________________________________________________
Subject: Re: RV10-List :Fuel Economy
Date: Apr 28, 2006
Tim & list: Your comments on the operation of your airplane are great, good motivation and insight. With all the valid concern lately over fuel costs there are some operational techniques that will help save fuel. Many folks are uncomfortable with cruising "over square" (with the manifold pressure higher than the RPM). This type of operation is permitted by Lycoming (with limitations at low altitude) and does provide better fuel economy. A side benefit is quieter operation and often less vibration. For example, the same 65% best economy mixture power can be produced at both of these fuel flows: 2000 RPM & 11.8 GPH 2600 RPM & 13.3 GPH (page 3-35 operators manual) the difference of course is the throttle setting. Think of shifting into overdrive in a car. the same 65% at best power mixture results in fuel flows of 13.6 & 15.2 GPH for the respective RPM settings which demonstrates the importance of leaning below 75%. As for propellers, this should probably be in the catagory of whether or not to prime, everyone has good reasons for their choice. In my case I'll be a part of the minority using an MT; I'll accept a few knots less IF that is the case for the smooooth, quiet operation. I understand that the 3 blade props also become more efficient as altitude increases which is hopefully where much of cruising in an airplane like the 10 will be done. Dick Sipp #40065 Many years ago a respected RV test pilot, Chuck Berthe, wrote a great article in Kit Planes comparing constant speed and fixed pitch propellers. The article contained lots of good cost calculations. I asked him if he flew his airplane "oversquare" his answer was "as much as I can as much as I can." ________________________________________________________________________________
Date: Apr 28, 2006
Hi Tim, A little oops here. The Hartzell RV-10 propeller is unique to the RV-10. And only an RV-10 builder can buy one. Best Regards, Jim Ayers In a message dated 04/28/2006 8:39:14 AM Pacific Daylight Time, Tim(at)MyRV10.com writes: --> RV10-List message posted by: Tim Olson (Stuff Cut) Maybe it should go the other way....offer a Hartzell to someone flying an MT. It's a cheaper prop to ship, and to buy to send them. Tim Olson - RV-10 N104CD - Flying do not archive ________________________________________________________________________________
Subject: AF-3500
Date: Apr 28, 2006
Rob K - Do you guys have your extra info on the 3400/3500 for dissemination yet? I'm wondering if you'll have a simple CDI needle presentation, or if I need to plan on the external CDI for ILS. Or, can I legally fly a GPS-overlaid ILS on the 480 screen if there is no LNAV approach into the airport? What would really be nice is if AOPA could publish some figures on when they expect all ILSs to have an overlaid LNAV approach, which would make the ILS moot, redundant, outdated, cost-prohibitive, etc.. Rob Wright #392 ________________________________________________________________________________
Date: Apr 28, 2006
Subject: Re: Props
Hi Paul, MT Propeller will design a two blade, or four blade, or whatever you feel you want that is reasonable. They can even provide an aluminum 2 blade or 3 blade propeller. They designed a 3 blade "natural composite" propeller for the RV-10, because their engineering analysis showed this provided the best performance and overall characteristics. Especially being 18 pounds lighter than the 2 blade Hartzell. A 2 blade "natural composite" MT propeller would weigh about 1 pound lighted than the 3 blade propeller. The 2 blade hub is much bigger to handle bigger blades required, and the 2nd order harmonic vibration present with a 2 blade propeller. Regards, Jim Ayers In a message dated 04/28/2006 6:06:57 PM Pacific Daylight Time, pdwalter(at)bigpond.net.au writes: --> RV10-List message posted by: "Paul Walter" Is it correct that MT are manufacturing a two bladed composite prop for the 10 ________________________________________________________________________________
Date: Apr 29, 2006
Subject: Re: My 2 Cents on the Landing Gear
Part number / description below from _www.mcmaster.com_ (http://www.mcmaster.com/) : Line Quantity Part Number Description Unit Price Total Price Ships 1 1 Each _30565A304_ (http://www.mcmaster.com/nav/enter.asp?partnum=30565A304&pagenum=2291) Hvy Duty Metric Hss Jobbers' Twist Drill Bit 7.9 mm Size, 114mm O'all Length, 81mm Flute Length $4.13 $4.13 In a message dated 4/28/2006 9:08:23 A.M. Mountain Daylight Time, gommone7(at)bellsouth.net writes: --> RV10-List message posted by: Hi,can you post the par number for mc Master regarding the .311 drill bit. Hugo > > From: JSMcGrew(at)aol.com > Date: 2006/04/28 Fri AM 09:59:31 EDT > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: My 2 Cents on the Landing Gear > > > > For those of you that haven't gotten to drilling the landing gear mount yet, > I just wanted to put in my 2 cents as well. Please, don't take this the > wrong way, it's just another way to solve the same problem: I followed Van's > instructions exactly and used a .311 / 7.9 mm drill to mount the landing gear. It > was easy, I didn't have any problems, and the bolts fit great. I bought the > drill from McMaster-Carr for $8.63 including shipping. > > Jim > 40134 > > In a message dated 4/28/2006 5:39:04 A.M. Mountain Daylight Time, > flysrv10(at)gmail.com writes: > > --> RV10-List message posted by: "Rob Kermanj" > > You can use a rechargable drill with the reamer. Oil the bit well. I > did not have to drill before the reamer. In fact, I found it hard to > have space to drill anything from the top side. > > The reamers blades have a step to transition to the shank. Since I > used the reamer backward, I had to grind a slope to be able to pull > the reamer from the bottom of the hole through the top. > > Find this reamer and if you want, call me and I will walk you through. > > do not archive. > 772-460-3907 > Rob Kermanj > > On 4/27/06, Conti, Rick wrote: > > --> RV10-List message posted by: "Conti, Rick" > > > > Bob, > > > > I'm not sure I understand. I've never used a reamer and just realized I > > shouldn't use an air drill with a reamer. Maybe the hand wrench from my > > tap & die set. > > > > What under size hole did you drill before using the .311" reamer? > > Please explain the grinding of the shoulders at the reamer stem side to > > be able to pull up and through. > > > > Does any of this make sense without using a close tolerance bolt? > > > > Bill suggested using a .3125 reamer with a 5/16" close tolerance bolt. > > All of which sounds good. > > > > Thank You > > Rick Conti > > Senior Engineering Manager > > The Boeing Company > > office: 703 - 414 - 6141 > > blackberry: 571 - 215 - 6134 > > > > > > -----Original Message----- > > From: Rob Kermanj [mailto:flysrv10(at)gmail.com] > > Sent: Wednesday, April 26, 2006 10:30 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: My 2 Cents on the Landing Gear > > > > --> RV10-List message posted by: "Rob Kermanj" > > > > I used the same reamer as you have purchased. I found it easier to > > insert the reamer from the button, chuck it and pull it through the > > hole. If you decide to do this, you may need to grind the blade > > shoulders at the reamer stem side to be able to pull up through. > > > > > > On 4/26/06, Conti, Rick wrote: > > > --> RV10-List message posted by: "Conti, Rick" > > > > > > Whenever I start a new "kit", I review the instructions several times, > > > once to ensure I have the necessary tools and parts. The .311" drill > > > bit appeared to be a problem. I called Van's and received an > > > interesting answer: I was told a 5/16 bit would be okay. I haven't > > > installed the gear yet and after reading about loose landing gear I > > had > > > second thoughts. I received my .311" reamer from McMaster-Carr > > (thanks > > > for the info) yesterday. But is has occurred to me, that 5/16" would > > be > > > fine provided the bolt matched. Drilling with a 5/16" bit though the > > > leg and support would not cause a problem. The problem would be from > > an > > > undersized bolt. Would everyone agree 5/16" would be okay with a > > proper > > > (precise fit) bolt? > > > > > > Thank You > > > Rick Conti > > > Senior Engineering Manager > > > The Boeing Company > > > office: 703 - 414 - 6141 > > > blackberry: 571 - 215 - 6134 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Jim "Scooter" McGrew > jsmcgrew(at)aol.com > > Jim "Scooter" McGrew jsmcgrew(at)aol.com ________________________________________________________________________________
Date: Apr 29, 2006
Subject: Torque Wrench Extension
I just came across a great idea that I want to share with the group. There are a few times that a torque wrench won't fit on the nut/bolt (namely engine mounting bolts, prop nuts, supporting the starter/alternator wires on the engine case). Instead of purchasing expensive extensions or welding something up I found that if you take an ordinary combination wrench and put a bolt/nut with washers through the closed end you have a perfect extension. And you get to keep your wrench intact. See photo below. You'll need to set your torque wrench to the appropriate setting when using an extension. If you don't trust yourself with a calculator here's a website that will do the math for you: _http://www.norbar.com/torquewrenchextensioncalculator.php_ (http://www.norbar.com/torquewrenchextensioncalculator.php) This is too easy, but I struggled with a few of these before I came across this idea, so I figure it's worth sharing. Jim McGrew #40134 - Fire Wall Forward ________________________________________________________________________________
Date: Apr 29, 2006
Subject: Re: Torque Wrench Extension
Jim, that is a genius idea! I cobbled something together when I did my prop bolts, and used an online torque calculator to verify my own calculations on torque, but this wrench extension is pure genius compared to what I did. I'm going to put this directly into the tips section on my site for permanent viewing and for those who only get the daily digest. http://www.myrv10.com/tips/generaltips.html Tim Olson - RV-10 N104CD - Flying JSMcGrew(at)aol.com wrote: > I just came across a great idea that I want to share with the group. > There are a few times that a torque wrench won't fit on the nut/bolt > (namely engine mounting bolts, prop nuts, supporting the > starter/alternator wires on the engine case). Instead of purchasing > expensive extensions or welding something up I found that if you take an > ordinary combination wrench and put a bolt/nut with washers through the > closed end you have a perfect extension. And you get to keep your wrench > intact. See photo below. > > You'll need to set your torque wrench to the appropriate setting when > using an extension. If you don't trust yourself with a calculator here's > a website that will do the math for you: > > http://www.norbar.com/torquewrenchextensioncalculator.php > > This is too easy, but I struggled with a few of these before I came > across this idea, so I figure it's worth sharing. > > Jim McGrew > #40134 - Fire Wall Forward > ________________________________________________________________________________
Date: Apr 29, 2006
While it is an inventive way to do it, I wonder about the impact of the angle on the wrench shown, and might point out that a set of crow's foot wrenches from Sears isn't all that much money. The crow's foot works fine on Hartzel props. Tim Olson wrote: > > Jim, that is a genius idea! I cobbled something together when > I did my prop bolts, and used an online torque calculator to > verify my own calculations on torque, but this wrench extension > is pure genius compared to what I did. I'm going to put this > directly into the tips section on my site for permanent viewing > and for those who only get the daily digest. > > http://www.myrv10.com/tips/generaltips.html > > > Tim Olson - RV-10 N104CD - Flying > ________________________________________________________________________________
Date: Apr 29, 2006
Jesse, This falls in the category of waxing philosophical on a subject and that doesn't help get my plane in the air any faster BUT I'm totally with you. I=20= struggled with that as well so here goes. If you are working with a beam type torque wrench you must hold it on the handle and center the handle on its pivot in order to get an accurate readi= ng, in this case it is easy to understand why the calculation needs the torque wrench length. With the micrometer or "click" type torque wrenches you don'= t necessarily have to hold it by the handle to get an accurate torque because= the spring is set to the value you want - that is, unless you are using an extension. Hang with me and please excuse the math, this is how I understand it. Consider the following 2 cases: You are using a 20 inch long micrometer type torque wrench set at 100 in-lb= s attached to a 10 inch extension. 1) If you hold the torque wrench by the handle you must apply 5 lbs of forc= e to create 100 in-lbs of moment (torque) at the head and cause it to click (= 5 lbs x 20"). At the end of your 10" extension you are creating 150 in-lbs of= torque (5 lbs x 30 inches). 2) If you "choke" up on the torque wrench and hold it, say, 10" from the head you must apply 10 lbs of force in order to get it to click at 100 in-lb= s. Now at the end of your 10" extension you are applying 200 in-lbs of torque (= 10 lbs x 20 inches) As far as using the extension other than straight - I'm not an A&P, but I a= m an engineer and the math tells me that bending the torque wrench does make =20= a difference. Your moment arm now becomes the hypotenuse of the triangle created by the torque wrench and extension. The further you bend the extens= ion the shorter your moment arm becomes and, thus, the less torque you have at the end of your extension. This is a minor correction until the angle starts getting beyond about 45 degrees. I will skip the geometry involved. Conside= r the case if you bent the extension all the way back toward you, aligned with th= e torque wrench... now the moment arm is equal to the length of the torque wr=
April 11, 2006 - April 29, 2006
RV10-Archive.digest.vol-bc
