RV10-Archive.digest.vol-bi
June 27, 2006 - July 17, 2006
      I used J B Weld on my rudder and it didn't hold despite roughing the
      surface with steel wool then cleaning with acetone before clecoing
      together.
      ----- Original Message -----
      Sent: Monday, June 26, 2006 4:05 PM
      In a message dated 6/26/2006 11:43:19 AM Eastern Standard Time,
      mdoyle2(at)gmail.com writes:
      I used an inexpensive caulking gun.
          I did the same and my caulk gun fit in the new self mixing cartridge
      with no adjustments needed.  There was nothing on the back end to clean
      up. I found a HUGE amount of waste doing the rudder this way, as the
      entire tube gets mixed and then you only use a little.
          Is there a suitable substitute, like JB Weld for the elevators and
      other parts that use proseal??? I dont want to use anything that would
      cause corrosion for the trailing edge pieces.
      For the fuel tank i will stick with the Proseal, and would expect to
      finish a tube or two.
      Steve
      Stephen Blank             RV-10 Builder #40499 / Cessna 170B flyer
      766 SE River Lane
      Port St. Lucie, FL 34983
      772-475-5556 cell - evenings and weekends
Date: Jun 27, 2006
Subject: SIKAFLEX WINDSCREEN
For those thinking of using an alternative for the windscreen , someone mentioned Sikaflex -252 , i called the company tech line and they only reccomend there -295 UV product http://www.sikaindustry.com/ind/ipd-marine/ipd-ma-products.htm along with the 226 cleaner http://www.sikaindustry.com/ipd-marine-surface-primerchart & 209 primer , this is what i think that i will use (very important to use the correct one and prepare the surfaces ). Brian Bollaert ________________________________________________________________________________
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Date: Jun 27, 2006
Subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL
THIS IS NOT "SPAM", but comes from 600+ hours of research I did while building my RV-8A. ------------------------------------------------------------ SAVE YOURSELF hundreds of hours of research time that can be better spent "building your project", by using the comprehensive "Guide to Painting & Corrosion Control of Aluminum and Composite Aircraft" (In 3rd printing) Contains 66 pages of the latest, practical information - summarized and gathered from MIL Standards, Paint Shops, Builders like you (what worked or didn't), Airframe Mfgs, etc. Covers products from - PP&G, Dupont, Sherwin W'ms, Sterling, Poly Fiber, Deft, Randolph Paints, PRC De Soto, US Paints, Aircraft Finishing Systems, 3M, etc. Some of the Topics covered in the 30 Sections are: * Aircraft Paints vs Auto Paints * Corrosion Control * Primers for Fiberglass & Steel * Prep Methods for Painting - Fiberglass, Aluminum and Steel * Epoxy Primers for Aluminum - MIL & Commercial, Solvent & Water Reducible * Wash Primers & Self Etching Primers * Other Primers - Zinc Chromate, Zinc Oxide, Enamel * Paint Types : MIL & Non MIL Polyurethanes, Enamel * Acid Etch / Conversion Coatings (Alodine) * Spray Guns - selecting, adjusting, using & painting problems * Brushes / Rollers used with Primers & Paints * Selecting a Paint Shop * 3M Cleaning Pads & Cleaners * Paint Booths and their Construction * References - MIL Standard & Tech Orders * Directory of Aircraft Paint Mfgs, Distributors - phone numbers, E- Mail addresses, Application Notes YOUR AIRPLANE is judged by it's "Paint Job", so have the latest "Information" in order to make good decisions. Contains "Do's" and "Don'ts" that save you time, $$$ and frustration. Send check for $26 (includes postage within US) to: Garey Wittich 58 Village Pkwy Santa Monica, CA. 90405 __________________________________________________ ________________________________________________________________________________
Date: Jun 27, 2006
Subject: Re: Hot Tunnel suggestion
With all the tunnel heat discussions lately, I thought I would write something up, and I incorporated some of Dean's stuff, along with a nice drawing Bob Condrey sent me, and some photos I snagged from Scott's Schmidt. It may be a good read for those of you who are overly concerned as to the whole "Hot Tunnel" issue. http://www.myrv10.com/tips/mods/HotTunnel/index.html Sorry I haven't been keeping up on the tips as much as I wanted, but this one is a good one, IMHO. Tim - N104CD - Flying ________________________________________________________________________________
Date: Jun 27, 2006
Subject: Parts Priming & Corrosion
On my RV-4 I spent a HUGE amount of time acid washing, alodining, and epoxy priming every single part. On the RV-10 I have been using self etching primer to help reduce the work. We just bought a 1947 Cessna 140 for the kids to lean to fly and I was installing shoulder belts in it this weekend. We had the head liner, carpet, seats, ..... out of it. There is no primer on any of the Aluminum anywhere and there is absolutely no corrosion on it, yes in over 59 years! I think I should immediately take it apart and prime it before it starts to fall apart J Rob Hickman N401RH RV-4 N1877V C-140 ________________________________________________________________________________
Date: Jun 27, 2006
Subject: Re: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL
If it isn't copyrighted, then go for it!! grumpy #40404 In a message dated 6/27/2006 8:17:45 PM Central Standard Time, johnwcox(at)pacificnw.com writes: Maybe I should buy a copy of this duck, convert it to PDF and send it to Tim for the RV University library. What say the masses? Has someone already contributed to Garey's retirement fund in the Bahamas? I am at over 4,000 hours of research and wouldn't consider charging for personal opinion, even when backed by actual documentation and life experience. John - $00.02 ________________________________________________________________________________
Date: Jun 29, 2006
Subject: Re: finishing kit ommisions
Chris, Could you please re-fax the list of the things you are going to omit. Just got the laptop working again! I am going to get wheel pants from James also. I saw them at Lakeland. Thanks!!! Jim Gore > > From: "Chris Hukill" <cjhukill(at)cox.net> > Date: 2006/06/09 Fri AM 11:58:26 EDT > To: > Subject: RV10-List: finishing kit ommisions > > I just sent Barb at Vans a list of the items to omit from my finishing kit. I previously had her send me an inventory list of the kit, so I knew what was there. As I want to leave my options open for a James cowl, I omitted the cowl top, bottom, left/ right inlets, oil door and core, and all the spinner parts (7 items). I also omitted the tires and tubes, as I like the leakguard tubes and better tires. If anyone wants the actual part numbers of the cowl / spinner parts to omit, I would be happy to fax the list, and save you and Vans the trouble. > > Chris Hukill > completing Andair installation > 702 591-7551 cel > ________________________________________________________________________________
Date: Jun 29, 2006
Subject: RYO Center console - Sharing time
For the past couple of weeks I've been working on a fiberglass center console, to accompany the panel that I bought from Aerotronics. Originally I had planned to make my own panel, but when I found the Aerotronics panel, it was better than what I had planned. however that left the issue of the console. I was a bit nervous starting out, and yes the fiberglass itches and the resin is messy, and it turns the garage/shop into a disaster relief area, but it turned out pretty well for a rookie. I though I'd post some links it in case others of you were thinking of doing something similar. (Its sure a lot cheaper than buying the Lancair parts). Link to section which details the setps and time http://deemsrv10.com/upperfwdfuseinstallationlogindex.html Link to Photo Album, which contains thumbs & pics of all the panel and console pics. http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/index.html Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
Date: Jun 29, 2006
Subject: Re: RYO Center console - Sharing time
Nice job Deem's!! How many plys? And how undersized did you make the foam to allow for the layup? Really nice. I was following your daily progress. Can't you remove the foam with Acetone instead of digging it out? You should have made a plug then you could make all of us one!! ;) Rick S. 40185 ________________________________________________________________________________
Date: Jun 30, 2006
I made a center tunnel also but for the throttle quadrant instead of the cables, and I do make a mold, what you see is the plug. http://www.mykitlog.com/users/display_log.php?user=phzme&project=1&categ ory=1632&log=15194&row=1 Henkjan van der Zouw #355 -----Oorspronkelijk bericht----- Van: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Namens Deems Davis Verzonden: vrijdag 30 juni 2006 1:45 Aan: rv10-list(at)matronics.com Onderwerp: RV10-List: RYO Center console - Sharing time For the past couple of weeks I've been working on a fiberglass center console, to accompany the panel that I bought from Aerotronics. Originally I had planned to make my own panel, but when I found the Aerotronics panel, it was better than what I had planned. however that left the issue of the console. I was a bit nervous starting out, and yes the fiberglass itches and the resin is messy, and it turns the garage/shop into a disaster relief area, but it turned out pretty well for a rookie. I though I'd post some links it in case others of you were thinking of doing something similar. (Its sure a lot cheaper than buying the Lancair parts). Link to section which details the setps and time http://deemsrv10.com/upperfwdfuseinstallationlogindex.html Link to Photo Album, which contains thumbs & pics of all the panel and console pics. http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/index .html Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
Date: Jun 30, 2006
Boy, thats a beautiful setup, well done. I looked at lancair iv panels and cant seem to find that particular one. Where did you find it and how much?? Steve 40205 For the past couple of weeks I've been working on a fiberglass center console, to accompany the panel that I bought from Aerotronics. Originally I had planned to make my own panel, but when I found the Aerotronics panel, it was better than what I had planned. however that left the issue of the console. I was a bit nervous starting out, and yes the fiberglass itches and the resin is messy, and it turns the garage/shop into a disaster relief area, but it turned out pretty well for a rookie. I though I'd post some links it in case others of you were thinking of doing something similar. (Its sure a lot cheaper than buying the Lancair parts). Link to section which details the setps and time http://deemsrv10.com/upperfwdfuseinstallationlogindex.html Link to Photo Album, which contains thumbs & pics of all the panel and console pics. http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/index.htm l Deems Davis # 406 Fuse http://deemsrv10.com/ -- -- ________________________________________________________________________________
Date: Jun 30, 2006
Subject: Re: RYO Center console - Responses
Thanks to all for the kind words. I'm really not interested in another career or job, (I finally got to the point I could retire, and I'm having too much fun building an airplane!). My purpose in posting the info was to encourage anybody that was inclined to do some RYO (Roll Your Own) composite work to go ahead and do it. (I'm now thinking about some cockpit/canopy panels and a rear seat console). I'd be happy to talk to anybody who's so inclined off line and let them know what I learned and what I'd do differently. I did send a note to Aerotronics who makes the instrument panel, who asked me to keep them abreast of my progress mounting their panel (Aerotronic cost = $600) and asked them if they had any interest in pulling a mold off of it. We'll see if they have any interest. I saw a picture of the panel on Henkejan's Kitlog website. Apparently he saw it @ SNF. Since the console is built to match their panel, I doubt it has much utility with any other panel. They are marketing the panel to RV-10 owners HOWEVER, the panel was originally built for Lancair IV's and it required some noodeling to install it in a -10 as it's NOT a perfect fit. They are very upfront about this when you talk to them. I built the panel using 8 plys of 6 oz cloth. in hind sight that's probably too much, it looks like the panel was built with 5-6 plys. I didn't make the patterns undersize, I used the fwd fuse tunnel cap as a base and built the foam plugs directly on them using some bondo to hold them in place temporarily, that way the glass can be drilled so that it matches the screw/nutplates that hold the cap on the tunnel when the foam is removed. The foam I used as Last-A-Foam from ACS and doesn't dissolve in acetone (I sent a note to Last a Foam to see if there was something that would dissolve it, but got no reply). Disolvable rigid foam would have been a big help I still have 1 3/4 - 2 inchs of room from the top of the untrimmed stick in the full forward position to the bottom edge of the panel. I understand that you need to cut the control stick to mount the grips, so I'm thinking I should be OK. Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
Date: Jun 30, 2006
Subject: RV-10 database
Currently I have 343 of the worldwide 604 RV-10 builders listed. It would sure be nice if more of the lurkers would update on Tim's site for OSH (either in the Positive or the negative). John Cox #40600 #70454 ________________________________________________________________________________
Date: Jun 30, 2006
Subject: Heat Vent
Current experience in my RV-9A indicated that my wife and I require different amounts of heat so I made a sliding cover for the heat vent that could be installed on either side. The sliding cover, at this point, is much longer than necessary as I'm thinking about how I want to control it. All the parts are made from .032" so the slide fits snugly and should not move due to vibration, etc. I'm thinking that once it's set, it may not have to ever be readjusted so perhaps I'll just shorten the slide and adjust it manually. Albert Gardner 40-422 Yuma, AZ ________________________________________________________________________________
Date: Jun 30, 2006
Hey guys, just back in town after a week long trip and am catching up on the tunnel heat issue. I have been actively addressing the issuue myself as it is warming up down here in SoCal. I think the ideas regarding the heat boxes on the firewall are all good ones, but I'm starting from the inside. If I recall correctly, the folks with the Vetterman (two exhaust pipes) have a little more heat issue than those of us with the other style ( one pipe). Judging by the discolored metal of my unpainted belly (90 hrs flying) directly aft of the lower cowl, I'm banking that a lot of this heat is radiating up through the tunnel from below. It seems it would only be worse for the guys with two pipes protruding out the bottom. I actually believe that it is all of the engine compt. heat venting out that big hole underneath as well as the exhaust. In addition, if the vents were leaking badly (I still believe this is part of the problem) wouldn't you be feeling heat coming out of the openings in the cabin....I don't in mine. Bottom line, I have insulated the firewall and floor in the tunnel all the way to the back seats and also firesleeved my tunnel fuel lines to try to insulate them a bit ( Having a little bit of a fuel vapor problem and pump cavitation at idle). I hope to fly in the next few days. If I don't see an improvement then I will be disconnecting the scats to the heat vents and routing them overboard for a flight to see if that helps. Maybe they should just be disconnected in the Summer time!!! Mark ________________________________________________________________________________
Date: Jun 30, 2006
Deems, That's sweet! How much does that bad boy weigh? John Hasbrouck #40264 ________________________________________________________________________________
Date: Jun 30, 2006
Good question: according to the bathroom digital scale 3.4 lbs Deems John Hasbrouck wrote: > > Deems, > > That's sweet! How much does that bad boy weigh? > > John Hasbrouck > #40264 > > > http://www.matronics.com/Navigator?RV10-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jun 30, 2006
Deems, Wow, is that all. 3.4 lbs. ain't bad at all. Thanks for sharing. I've been contemplating doing the same thing. ________________________________________________________________________________
Date: Jun 30, 2006
Subject: Re: : RV10-List:Quick Build Wings Bottom skin
John, I did the slo'build wings but the bottom skins are the same. Followed the sequence that is in the plans. Inboard skin first starting at the rear spar about the middle as I recall. Take a look at the orientation of the rib flanges and you'll see that the most inboard ones can be accessed from the wing root. Outboard skin sequence per plans. Last three ribs outboard can be reached with the skin curled back and through the holes in the outboard ribs. I had help for the left wing but did the right wing myself. Turned out great just took my time. Hope this helps....john ________________________________________________________________________________
Date: Jul 01, 2006
Subject: Kit for sale
RV-10 Quick Build kits. Empennage, wings and fuselage. Empennage is built. Tail cone is not. Wings and Fuselage are in the crates as received. Empennage work has been Technical Counselor reviewed. $31,500 Transportation by buyer. Contact by e-mail is easiest. atirburgess(at)msn.com or lyleap(at)comcast.net <http://by107fd.bay107.hotmail.msn.com/cgi-bin/compose?mailto=1&msg=4 0622CE3 -27D2-4C2B-A5C6-12599F6D6092&start=0&len 758&src=&type=x&to=l yleap@comcast .net&cc=&bcc=&subject=&body=&curmbox=00000000-0000-0000-0000-00 0000000001&a 1b79a0b8f61dd8f6a09add832a92d0e8976abd4b832f6ba1c4cb9c39d473a9eb> ________________________________________________________________________________
Date: Jul 01, 2006
Date: Jul 01, 2006
Subject: Re: Kit for sale
Gary, Would you be willing to sell me just the fuselage? If yes, how much $? I have completed my empennage and wings. I'm ready to order the fuse. Hank Gary Specketer wrote: RV-10 Quick Build kits. Empennage, wings and fuselage. Empennage is built. Tail cone is not. Wings and Fuselage are in the crates as received. Empennage work has been Technical Counselor reviewed. $31,500 Transportation by buyer. Contact by e-mail is easiest. atirburgess(at)msn.com or lyleap(at)comcast.net ________________________________________________________________________________
Date: Jul 01, 2006
Subject: Spinner Position Reference Info
I've had a request for some measurements and thought I'd post for all. The installation of the upper and lower cowl halves is referenced to the aft edge of the spinner. Several folks have made a spacer and a plywood disk to simulate this but measurements are difficult to locate. My prop is on the plane at the moment so each measurement is referenced to a location on the flywheel assembly. Caution: I'm not sure how much variability there is in the flywheel assembly. spinner aft edge to forward face of flywheel (at crankshaft flange): 1 18/32" spinner aft edge to forward edge of ring gear: 3 1/32" spinner aft edge to aft edge of ring gear: 3 15/32" Ring gear aligned with aft edge of flywheel. Bob #40105 ________________________________________________________________________________
Date: Jul 01, 2006
Subject: Re: RV-!0 Fuselage Dolly
I would like to see some pics. Maybe you could attach them to the end of your post where we could pic and choose which to download/view. Shrink them down some and they won't be too large for those with slow connections (me). Thanks for sharing your idea. Kevin #40494 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=44225#44225 ________________________________________________________________________________
Date: Jul 01, 2006
Subject: Aero lift
Have any multiple airplane owners out there considered the Aero-Lift that Van's recently started using? Any comments? What was the price? What options would you recommend? Roger Standley #40291 - Engine Cowling and beginning to think beyond the garage....about hangar space ________________________________________________________________________________
Date: Jul 02, 2006
Subject: Aero Lift
I have an Aerolift that the RV8 is on, while I build my 10. First let me say the lift works as advertised. The only complaint I have is the crappy customer support that you get, in that when I arranged the shipping, I was very, very adamant that I receive the lift when promised. This is important because you need at least two helpers (all day), and a rented fork lift with an extension. This is after you have previously prepared the hangar (several days for mine). After repeated assurances that mine will ship as promised, I was told at the last minute that I won't receive it until the following week, because basically I was de-prioritized by a multiple FBO order. The FBO I would assume have employees and a forklift available during any business day, unlike a one man show like mine. This really irritated me, and if you buy one, be sure and remind them of my displeasure. By the way I have never heard back from them since they have been paid. Lousy customer support for a $14,000 specialty purchase. As for the lift, I would not recommend the $500 castor option, as once the lift is installed you don't need the wheels, and you can rent them for initial positioning. I had visions of wheeling this thing around the airport to another hangar if I ever needed too, but the reality is you would have to dis-assemble it to move it anyway, as it barely moves around on my perfectly flat, smooth, concrete floor. My vision of rolling out the hangar, and down the asphalt ramp without tweeking the lift is a pipe dream. I bought both the nose and tailwheel hardware, and either the 8 or 10 can go on the lift. The 8 is difficult to get on single handed, as the tailwheel needs to go up the ramp, be secured to the dolly, and rolled back before you can determine if the mains are in the exact position they need to be in, so as not to damage the wheelpants, as there is only 1 inch clearance on each side of the pant. I have the painted lines, etc., but getting it exactly right usually takes several tries. With a helper pushing, and pulling on the prop, it's not bad going back and forth up the ramp until you get it just right, but solo it's exhausting, and potentially dangerous, as the tailwheel can jump the sides of the ramp, and fall, which would cause major damage to the tailcone. I won't even try it solo anymore, as I have had a couple of close calls. Get a helper! If you think I'm directionally challenged, mark a spot on a ramp, and pull your taildragger back by the tail and try to get the mains on exactly the mark, and you'll see what I'm talking about. I think wider wheel cradles may be an option now, if so, buy them! Pushing a nosewheel back on the rig should be much easier, as you can just drive the mains right into the slots, but you will need to come in at angle with the 10, as the horizontal stab will hit the vertical column if you came strait back. The 8 has since been moved into another hangar, as it was not getting flown regularly because I'm too lazy to roll the 10 fuselage, all the tables, etc. outside, lower the 8, replace the 10 stuff, go fly, and repeat the process to put it all away. Just a parked airplane under the lift would be easy to move, however it can't be a taildragger, unless you had enough room in front of the lift, as the tailwheel has to go over the horizontal support leg of the lift. The lift has proved very handy as a lifting devise for the 10 project. I use it to lift, and flip the 10 fuselage which is mounted to a steel rack I made. This way I work on the 10 in a comfortable position. I just installed tunnel parts while sitting in a chair, with the tunnel at eye level. Sweet! Chris Hukill milking the QB fuselage ________________________________________________________________________________
Date: Jul 02, 2006
Subject: F1070 roll construction angles
For those with slo-build fuse: What angle stock did you use to make the roll construction angles ( 1070A & B ) used to roll the side skins? These are only used for rolling the skins I think so would some angle from the aviation dept of Lowes suffice? Looks like 3/4 X 3/4 angle, maybe .125 thickness but I can't find the answer in the plans. Any help greatly appreciated.........thanks....john John Hasbrouck #40264 soon to be rolling side skins ________________________________________________________________________________
Date: Jul 02, 2006
Subject: Re: F1070 roll construction angles
John, Use the 3/4 x 3/4 x 1/8" angle stock. Rick S. 40185 ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Re: Aero Lift
Hi Chris, I'm interested in the rack you made for the fuselage. I've considered mounting the fuse on a couple of engine stands so I could rotate it just as you've described. Can you show a picture or better explain how you accomplished this? Thank You Ed Mueller # 40525 Chris Hukill wrote: > I have an Aerolift that the RV8 is on, while I build my 10. First let > me say the lift works as advertised. The only complaint I have is the > crappy customer support that you get, in that when I arranged the > shipping, I was *_very, very _*adamant that I receive the lift when > promised. This is important because you need at least two helpers (all > day), and a rented fork lift with an extension. This is after you have > previously prepared the hangar (several days for mine). After repeated > assurances that mine will ship as promised, I was told at the last > minute that I won't receive it until the following week, because > basically I was de-prioritized by a multiple FBO order. The FBO I > would assume have employees and a forklift available during any > business day, unlike a one man show like mine. This really irritated > me, and if you buy one, be sure and remind them of my displeasure. By > the way I have never heard back from them since they have been paid. > Lousy customer support for a $14,000 specialty purchase. > As for the lift, I would not recommend the $500 castor option, as once > the lift is installed you don't need the wheels, and you can rent them > for initial positioning. I had visions of wheeling this thing around > the airport to another hangar if I ever needed too, but the reality is > you would have to dis-assemble it to move it anyway, as it barely > moves around on my perfectly flat, smooth, concrete floor. My vision > of rolling out the hangar, and down the asphalt ramp without tweeking > the lift is a pipe dream. > I bought both the nose and tailwheel hardware, and either the 8 or 10 > can go on the lift. > The 8 is difficult to get on single handed, as the tailwheel needs to > go up the ramp, be secured to the dolly, and rolled back before you > can determine if the mains are in the exact position they need to be > in, so as not to damage the wheelpants, as there is only 1 inch > clearance on each side of the pant. I have the painted lines, etc., > but getting it exactly right usually takes several tries. With a > helper pushing, and pulling on the prop, it's not bad going back and > forth up the ramp until you get it just right, but solo it's > exhausting, and potentially dangerous, as the tailwheel can jump the > sides of the ramp, and fall, which would cause major damage to the > tailcone. I won't even try it solo anymore, as I have had a couple of > close calls. Get a helper! If you think I'm directionally challenged, > mark a spot on a ramp, and pull your taildragger back by the tail and > try to get the mains on exactly the mark, and you'll see what I'm > talking about. I think wider wheel cradles may be an option now, if > so, buy them! > Pushing a nosewheel back on the rig should be much easier, as you can > just drive the mains right into the slots, but you will need to come > in at angle with the 10, as the horizontal stab will hit the vertical > column if you came strait back. > The 8 has since been moved into another hangar, as it was not getting > flown regularly because I'm too lazy to roll the 10 fuselage, all the > tables, etc. outside, lower the 8, replace the 10 stuff, go fly, and > repeat the process to put it all away. Just a parked airplane under > the lift would be easy to move, however it can't be a taildragger, > unless you had enough room in front of the lift, as the tailwheel has > to go over the horizontal support leg of the lift. > The lift has proved very handy as a lifting devise for the 10 project. > I use it to lift, and flip the 10 fuselage which is mounted to a steel > rack I made. This way I work on the 10 in a comfortable position. I > just installed tunnel parts while sitting in a chair, with the tunnel > at eye level. Sweet! > > Chris Hukill > milking the QB fuselage ________________________________________________________________________________
Date: Jul 03, 2006
Subject: EAA106 + NEVAF fly in July 15th.
EAA106 + NEVAF fly in July 15th. RVers!! It's coming up!!!!!! EAA106 is hosting an RV and Canard fly-in at Lawrence Airport on July 15th. This is the fifth year that we've held the fly-in and it's bigger and better than ever. Attached is the poster from EAA106. Please help us get the word out and plan to come yourselves. Here are some things to note: There is a charge this year but breakfast, lunch and handouts are included. Pilots flying in their RVs or Canards get a big discount! My RV is not quite ready yet so I'm going to miss out this year. EAA 106 has negotiated a discount rate at the Comfort Suites for those who chose to stay overnight. EAA106 will provide transportation. There are 11 Seminars this year; more than ever before. Although the file says 'Draft' it's official enough that you can print it out and post it at an airport near you. I would appreciate it if everyone who has a good color printer would print one out and post it at their airport. Regards ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: EAA106 + NEVAF fly in July 15th.
I know you know where Lawrence Airport is, but how much trouble would it be to add " Massachusetts" Richard Reynolds On Jul 3, 2006, at 4:22 PM, James Hein wrote: > EAA106 + NEVAF fly in July 15th. > > RVers!! It's coming up!!!!!! > > EAA106 is hosting an RV and Canard fly-in at Lawrence Airport on > July 15th. > This is the fifth year that we've held the fly-in and it's bigger > and better > than ever. Attached is the poster from EAA106. Please help us get > the word > out and plan to come yourselves. Here are some things to note: > > There is a charge this year but breakfast, lunch and handouts are > included. Pilots flying in their RVs or Canards get a big discount! > My RV > is not quite ready yet so I'm going to miss out this year. > > EAA 106 has negotiated a discount rate at the Comfort Suites for > those who > chose to stay overnight. EAA106 will provide transportation. > There are 11 Seminars this year; more than ever before. > > Although the file says 'Draft' it's official enough that you can > print it > out and post it at an airport near you. I would appreciate it if > everyone > who has a good color printer would print one out and post it at their > airport. > > Regards > > <2006 NorthEast RV and Canard Fly-In Poster.pdf> > <2006 NorthEast RV and Canard Fly-In Poster.doc> > ________________________________________________________________________________
Date: Jul 04, 2006
Point noted for future reference :) Most of the details are in the flyer, except where LWM is ! Sorry 'bout that :) Anybody going to bring an RV-10? It would be the first one around here we could drool over! -Jim 40384 Richard Reynolds wrote: > > I know you know where Lawrence Airport is, but how much trouble would > it be to add " Massachusetts" > > Richard Reynolds > > On Jul 3, 2006, at 4:22 PM, James Hein wrote: > >> EAA106 + NEVAF fly in July 15th. >> >> RVers!! It's coming up!!!!!! >> >> EAA106 is hosting an RV and Canard fly-in at Lawrence Airport on >> July 15th. >> This is the fifth year that we've held the fly-in and it's bigger >> and better >> than ever. Attached is the poster from EAA106. Please help us get >> the word >> out and plan to come yourselves. Here are some things to note: >> >> There is a charge this year but breakfast, lunch and handouts are >> included. Pilots flying in their RVs or Canards get a big discount! >> My RV >> is not quite ready yet so I'm going to miss out this year. >> >> EAA 106 has negotiated a discount rate at the Comfort Suites for >> those who >> chose to stay overnight. EAA106 will provide transportation. >> There are 11 Seminars this year; more than ever before. >> >> Although the file says 'Draft' it's official enough that you can >> print it >> out and post it at an airport near you. I would appreciate it if >> everyone >> who has a good color printer would print one out and post it at their >> airport. >> >> Regards >> >> <2006 NorthEast RV and Canard Fly-In Poster.pdf> >> <2006 NorthEast RV and Canard Fly-In Poster.doc> >> > > > http://www.matronics.com/Navigator?RV10-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Deburring - A useful tool for edge cleanup
I have found this small belt/disk sander (pic attached) to be a useful tool for initial edge cleanup on the heaver stock such as spar caps and stiffeners. Cleans up edges nicely on fabricated pieces cut with a bandsaw. Used with a fine belt it is very easy to control material removal. I use the belt more than the disk. An edge deburr and then polish on the 3M unitized wheel leaves a finished edge. Kevin 40494 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=44797#44797 Attachments: http://forums.matronics.com//files/belt_disk_sander_1_213.jpg ________________________________________________________________________________
Date: Jul 04, 2006
http://wcurtis.nerv10.com/fusestand/index.html >I would like to see some pics. Maybe you could attach them to >the end of your post where we could pic and choose which to >download/view. Shrink them down some and they won't be too large >for those with slow connections (me). Thanks >for sharing your idea. > >Kevin >#40494 William Curtis http://nerv10.com/ ________________________________________________________________________________
Date: Jul 04, 2006
Subject: help locating hard points
I need some help: I am at the point of installing the front seat shoulder harnesses and realized that I cannot locate the hard points referenced on (page 49-02) of the RV-10 plans. The head liner is already installed and the cabin cover is primed covering up the location of the hard points. I sure would appreciate someone measuring the location. This could be accomplished measuring aft of the door and up from the window. Thanks for your help. Bob ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: help locating hard points
The two hard points on my top are 11 1/8 inches behind the rear edge of the door opening (Measured to the center of the circular area of the hard point). The hard points are 2 feet apart (center to center). Another measurement is 5 1/2" up from the rear window lip. although yours may be covered / painted over at this point. A third measurement is to drop a straight edge back from the two door hinges (on the top). The center of the hard point is 5 1/2" down (perpendicular) from that line. I don't know if this is going to help or not. Jim Combs N312F 40192 =========================================================== I need some help: I am at the point of installing the front seat shoulder harnesses and realized that I cannot locate the hard points referenced on (page 49-02) of the RV-10 plans. The head liner is already installed and the cabin cover is primed covering up the location of the hard points. I sure would appreciate someone measuring the location. This could be accomplished measuring aft of the door and up from the window. Thanks for your help. Bob =========================================================== ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Lightspeed with Keyswitch and 1 Mag Wiring
This is a repost of previous info. I had a builder ask me about it and I couldn't find it in the archives well, so I thought I'd resend it with a good subject line. ----- Wiring a Keyswitch Ignition - Lightspeed Plasma III/II+ ignition and a Mag Another non-RV10 builder, Dave Sundberg passed this on to me previously, and I wired mine this way and it indeed works fine. It does seem a bit like black magic, but seeing as it works fine I won't be complaining. Test it out before and after you run the engine, but it should work fine. The configuration is a Mag on the Left side, feeding the lower plugs, and a Lightspeed Plasma III (or II+) feeding the top plugs as the Right system. Note that allthough Lightspeed calls it a keyswitch "Option", it's always on the system, just optional to connect. * The P-Lead from the Mag goes to the L-Terminal on the Switch with the shield connected to the GRN terminal on the mag and not connected to anything on the switch end. * The P-Lead from the LS (Pin 1) goes to the R-Terminal on the switch and the shield (Pin 9) goes to the GRN-Terminal in the center of the switch. * Do not connect the jumper from the R-Term to the GRN-Terminal next to it. * Do not connect the center GRN-Terminal on the switch to aircraft ground. Both ignitions are grounded out with the switch in the OFF position. Dave had been flying and it was working for him. I am flying too and it's working great for me. I had previously spent time hooking mine up and ohming things out and was confused as heck. I also was confused in that the P-Lead on the mag is seemingly shorted to ground even with the wire disconnected, so I couldn't easily tell that it would be grounded by the switch. (Turns out this is normal) If you hook it all up, except for the mag P-Lead, you can indeed see that they ground the way their supposed to by using your ohmmeter. I also have this posted on my Electrical Tips section on my site. Tim -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Windscreen sanding tool
This may seem a bit trivial, however .... The plans call for a 7" radius at the windscreen to front fuselage intersection. I found inexpensive rubber sanding blocks have a rounded handle about 6" radius. Just install the sandpaper on the top side instead of the flat side. It does a good job of creating a uniform radius fillet. Who knows? Maybe this is where the 7" radius originated. Bill DeRouchey 40029/N939SB Fly in 2 weeks ________________________________________________________________________________
Date: Jul 05, 2006
Chris, My experience with AeroLift folks have been great. I had the same issue with shipping but I think it was more a problem with the shipping folks (as with shipping anything at all). The contraption made it to within 50 miles of me in two days and took another 6 days to get to me. Luckily the folk lift was available on my field and could flex. AeroLift tracked the shipment and informed me of its whereabouts everyday. I feel that they did the best possible. Anh ----- Original Message ----- Sent: Monday, July 03, 2006 1:33 PM > > > Hi Chris, > > I'm interested in the rack you made for the fuselage. I've considered > mounting the fuse on a couple of engine stands so I could rotate it just > as you've described. Can you show a picture or better explain how you > accomplished this? > > Thank You > Ed Mueller > # 40525 > > > Chris Hukill wrote: >> I have an Aerolift that the RV8 is on, while I build my 10. First let me >> say the lift works as advertised. The only complaint I have is the crappy >> customer support that you get, in that when I arranged the shipping, I >> was *_very, very _*adamant that I receive the lift when promised. This is >> important because you need at least two helpers (all day), and a rented >> fork lift with an extension. This is after you have previously prepared >> the hangar (several days for mine). After repeated assurances that mine >> will ship as promised, I was told at the last minute that I won't receive >> it until the following week, because basically I was de-prioritized by a >> multiple FBO order. The FBO I would assume have employees and a forklift >> available during any business day, unlike a one man show like mine. This >> really irritated me, and if you buy one, be sure and remind them of my >> displeasure. By the way I have never heard back from them since they have >> been paid. Lousy customer support for a $14,000 specialty purchase. >> As for the lift, I would not recommend the $500 castor option, as once >> the lift is installed you don't need the wheels, and you can rent them >> for initial positioning. I had visions of wheeling this thing around the >> airport to another hangar if I ever needed too, but the reality is you >> would have to dis-assemble it to move it anyway, as it barely moves >> around on my perfectly flat, smooth, concrete floor. My vision of rolling >> out the hangar, and down the asphalt ramp without tweeking the lift is a >> pipe dream. >> I bought both the nose and tailwheel hardware, and either the 8 or 10 can >> go on the lift. >> The 8 is difficult to get on single handed, as the tailwheel needs to go >> up the ramp, be secured to the dolly, and rolled back before you can >> determine if the mains are in the exact position they need to be in, so >> as not to damage the wheelpants, as there is only 1 inch clearance on >> each side of the pant. I have the painted lines, etc., but getting it >> exactly right usually takes several tries. With a helper pushing, and >> pulling on the prop, it's not bad going back and forth up the ramp until >> you get it just right, but solo it's exhausting, and potentially >> dangerous, as the tailwheel can jump the sides of the ramp, and fall, >> which would cause major damage to the tailcone. I won't even try it solo >> anymore, as I have had a couple of close calls. Get a helper! If you >> think I'm directionally challenged, mark a spot on a ramp, and pull your >> taildragger back by the tail and try to get the mains on exactly the >> mark, and you'll see what I'm talking about. I think wider wheel cradles >> may be an option now, if so, buy them! >> Pushing a nosewheel back on the rig should be much easier, as you can >> just drive the mains right into the slots, but you will need to come in >> at angle with the 10, as the horizontal stab will hit the vertical column >> if you came strait back. >> The 8 has since been moved into another hangar, as it was not getting >> flown regularly because I'm too lazy to roll the 10 fuselage, all the >> tables, etc. outside, lower the 8, replace the 10 stuff, go fly, and >> repeat the process to put it all away. Just a parked airplane under the >> lift would be easy to move, however it can't be a taildragger, unless you >> had enough room in front of the lift, as the tailwheel has to go over the >> horizontal support leg of the lift. >> The lift has proved very handy as a lifting devise for the 10 project. I >> use it to lift, and flip the 10 fuselage which is mounted to a steel rack >> I made. This way I work on the 10 in a comfortable position. I just >> installed tunnel parts while sitting in a chair, with the tunnel at eye >> level. Sweet! >> Chris Hukill >> milking the QB fuselage > > > http://www.matronics.com/Navigator?RV10-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 05, 2006
Subject: IO-540 crate size
Van's just called to say my engine is shipping momentarily from Lycoming. Does anyone have one sitting in a crate at their place who could tell me the dimensions of the box it will arrive in? Need to know whether it will fit in the back of my SUV, or whether I need to rent a truck like I did to pick up the finish kit at the freight dock. Thanks, -Dan Masys #40448 ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: IO-540 crate size
Dan saw a IO-540 at our local FBO recently seems to me it was about a 4x4x2.5 sitting on a standard wooden pallet...I did not measure it just eyeballing it... P ________________________________________________________________________________
Date: Jul 05, 2006
Rent a truck -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Masys Sent: Wednesday, July 05, 2006 10:52 AM Van's just called to say my engine is shipping momentarily from Lycoming. Does anyone have one sitting in a crate at their place who could tell me the dimensions of the box it will arrive in? Need to know whether it will fit in the back of my SUV, or whether I need to rent a truck like I did to pick up the finish kit at the freight dock. Thanks, -Dan Masys #40448 ________________________________________________________________________________
Date: Jul 05, 2006
If you ordered through Van's they are going to drop ship at your location be it house or hangar. ----- Original Message ----- Sent: Wednesday, July 05, 2006 9:52 AM > > Van's just called to say my engine is shipping momentarily from Lycoming. > Does anyone have one sitting in a crate at their place who could tell me > the dimensions of the box it will arrive in? Need to know whether it will > fit in the back of my SUV, or whether I need to rent a truck like I did to > pick up the finish kit at the freight dock. > > Thanks, > -Dan Masys > #40448 > > > ________________________________________________________________________________
Date: Jul 05, 2006
Subject: seats
Just got my seats back; sending a few pictures. If anyone is interested I can supply details on material amounts costs etc. After looking at the size of the pictures I decided to send pictures to anyone interested but not to the list.. ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: seats
Please send pictures of seats. ----- Original Message ----- From: David McNeill To: rv10-list(at)matronics.com Sent: Wednesday, July 05, 2006 3:46 PM Subject: RV10-List: seats Just got my seats back; sending a few pictures. If anyone is interested I can supply details on material amounts costs etc. After looking at the size of the pictures I decided to send pictures to anyone interested but not to the list.. ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: Jul 05, 2006
Subject: Bob's Ground Power Plug button
I've been slowly working on Bob Nuckolls' design for the ground power plug made out of the Cole-Hersey Piper-style plug/socket. I couldn't get the insulating button out with pliers or other methods so I figured I'd try to be careful as I heated up the rear screw for solder. Of course, it got too hot and melted. I emailed Cole-Hersey (CH) on the website and got a message to call local dealers. Dealers, come to find out, don't carry little parts, just the end item. I finally talked to someone at CH who had to go down to the assembly line/warehouse to find the little buttons, then sent me four for free when I only requested one that I would pay for, and who was also kind enough to write the part number on the little baggie when she sent them to me. Awesome job at customer service. If anyone else has had this problem, before you go buy a new plug or find a decades-old salvage part, call CH up and ask for part number 11055-25. Rob Wright RV-10 #392 ________________________________________________________________________________
Date: Jul 05, 2006
Subject: RV-10 Stats
I'm doing some research for a project and need to know a few Stats on the RV-10. I know this is "The Place" to come to get this info! Any and all info is greatly appreciated! I'll post the results along with some details of our project(s). How many RV-10 kits have been sold? How many are flying? How many kits have an engine, but are not flying yet? ( i.e. How big is the current RV-10 engine market? ) What are the most popular engine options, O-540, IO-540, IO-550, IO-360......? What are the top 5 engine modifications? Who are seen as the best engine builders? What's a good/fair price for a new engine? Sincerely, Eric Parlow ericparlow(at)hotmail.com ________________________________________________________________________________
Date: Jul 05, 2006
The highest kit number I have seen in 602 Vans site says 37 flying I have kit 322, not flying, have engine I have an IO-540 I performed no mods to the engine I have no opinion on the best builders, I bought a used engine and a local shop id overhauling it for me $35,000 Rene' Felker 40322 N423cf Finish kit -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Parlow Sent: Wednesday, July 05, 2006 5:39 PM I'm doing some research for a project and need to know a few Stats on the RV-10. I know this is "The Place" to come to get this info! Any and all info is greatly appreciated! I'll post the results along with some details of our project(s). How many RV-10 kits have been sold? How many are flying? How many kits have an engine, but are not flying yet? ( i.e. How big is the current RV-10 engine market? ) What are the most popular engine options, O-540, IO-540, IO-550, IO-360......? What are the top 5 engine modifications? Who are seen as the best engine builders? What's a good/fair price for a new engine? Sincerely, Eric Parlow ericparlow(at)hotmail.com ________________________________________________________________________________
Date: Jul 05, 2006
As of last Friday, 604 kits sold. The 37 is conservatives under reported. I have nearly fifty finished. You get what you pay for with builders. Until you define what you want. Aerosport has sold the most IO540 rebuilds for the RV-10. John -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Wednesday, July 05, 2006 4:55 PM The highest kit number I have seen in 602 Vans site says 37 flying I have kit 322, not flying, have engine I have an IO-540 I performed no mods to the engine I have no opinion on the best builders, I bought a used engine and a local shop id overhauling it for me $35,000 Rene' Felker 40322 N423cf Finish kit -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Parlow Sent: Wednesday, July 05, 2006 5:39 PM I'm doing some research for a project and need to know a few Stats on the RV-10. I know this is "The Place" to come to get this info! Any and all info is greatly appreciated! I'll post the results along with some details of our project(s). How many RV-10 kits have been sold? How many are flying? How many kits have an engine, but are not flying yet? ( i.e. How big is the current RV-10 engine market? ) What are the most popular engine options, O-540, IO-540, IO-550, IO-360......? What are the top 5 engine modifications? Who are seen as the best engine builders? What's a good/fair price for a new engine? Sincerely, Eric Parlow ericparlow(at)hotmail.com ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jul 05, 2006
Subject: TruTrak Pitch Servo Quality
Bill, Good info. I think the QC problems are because of growing pains as several other vendors are seeing from the boom in homebuilt's and specifically high end models like the -10. No one should mistake my comments with a dislike of their products, I would still use their AP over anyone else's I would have like to have heard something out of TruTrak about my, and others, posts on this subject though. I know Andrew Barker trolls this list and I'm 99.9% sure he probably read it first thing this morning. Hopefully they are just trying to figure out the best way to address it. Michael Sausen -10 #352 Fuselage [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Sent: Wednesday, July 05, 2006 7:03 PM Mike, mine for the 7 were perfect but shipped a year ago and I just talked to John today. They answered on the third ring. Helpful as usual. Just another data point. Bill S 7a wiring/engine ________________________________ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Wednesday, July 05, 2006 6:58 AM Has anyone else had any problems with the newer model of the TruTrak pitch servo? Mine looks like it was thrown together where the DB9 connector is and the wire grommet is split, the mounting bracket aft hole is off by =BC", the bolt they sent to attach to the bellcrank is too short, and the entire instructions comprised two fuzzy pictures. Not what I would expect for a $1300 servo. And no, I haven't talked to them. The last couple of times I emailed or left a VM, no one ever returned my call. Michael Sausen RV-10 #352 Working on Fuselage Recent RV-10 Build Activity <http://www.mykitlog.com/display_project.php?project_id=22> ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: Bob's Ground Power Plug button
You will probably need the MALE connector with you for the Piper style GPU plug. Been flying GA and Corporate for over 40 years and don't recall ever seeing a GPU at FBO with Piper type plug. We installed the "UNIVERSAL" style receptacle in or RV & will carry the male jumper plug in the A/C. _http://www.aircraftspruce.com/catalog/elpages/plugnjump.php_ (http://www.aircraftspruce.com/catalog/elpages/plugnjump.php) Good luck. Doug Preston RV-7A - 19 hrs. ________________________________________________________________________________
Date: Jul 05, 2006
Yeah, I bought the male end as well and will adapt it to a set of jumper cables for the emergency kit in the plane. Rob Wright #392 _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DOUGPFLYRV(at)aol.com Sent: Wednesday, July 05, 2006 8:17 PM You will probably need the MALE connector with you for the Piper style GPU plug. Been flying GA and Corporate for over 40 years and don't recall ever seeing a GPU at FBO with Piper type plug. We installed the "UNIVERSAL" style receptacle in or RV & will carry the male jumper plug in the A/C. http://www.aircraftspruce.com/catalog/elpages/plugnjump.php Good luck. Doug Preston RV-7A - 19 hrs. ________________________________________________________________________________
Date: Jul 06, 2006
Lycoming shipped me a "container" for SB 566 crankshaft replacement....41.5" X 44" X 33" high for a IO540 V4A5 in a Maule ________________________________________________________________________________
Date: Jul 06, 2006
By "universal" I gather you mean the receptacle that mates with the AN2551 plug as sold here: <http://www.aircraftspruce.com/catalog/elpages/extpowerrect.php> Since my 177RG has the "universal" receptacle, a few years ago I ordered the wooden AN2551 plug from Aircraft Spruce (~$30) and attached it to a chepo set of jumper cables(~$10). <http://www.aircraftspruce.com/catalog/elpages/woodplug.php> The Piper style Plug & receptacle is even cheaper at $20 and $16 respectively. <http://www.aircraftspruce.com/catalog/elpages/piperplugsock.php> The nice thing about the AN2551 "universal" style is that it has built in protection from polarity reversal. I'm not sure how the Piper sytle accomplishes this, if at all. The Plug-N-Jump ($70 or $75)is nice but you still require cables to attach to it. >You will probably need the MALE connector with you for the Piper >style GPU plug. Been flying GA and Corporate for over 40 years and >don't recall ever seeing a GPU at FBO with Piper type plug. We >installed the "UNIVERSAL" style receptacle in or RV & will carry >the male jumper plug in the A/C. > >http://www.aircraftspruce.com/catalog/elpages/plugnjump.php > >Good luck. > >Doug Preston >RV-7A - 19 hrs. William Curtis 40237 - SB Fuselage side skins http://nerv10.com/ ________________________________________________________________________________
Date: Jul 06, 2006
Guys & Gals, I wanted to post some follow-up conversations I had with Andrew this morning. He contacted me once he had some answers. Good stuff that gives me the warm fuzzy's. Michael Sausen RV-10 #352 Working on Fuselage Recent RV-10 Build Activity <http://www.mykitlog.com/display_project.php?project_id=22> Sent: Thursday, July 06, 2006 10:06 AM No worries! My only concern with the split washer is that if they cut too much away, then the servo wires might work their way into the split. This is why we are thinking about changing it. We have not had any problem with chafing, at least not that I have been told about. Thanks for the bolt length help I will get back with shipping again today and check on that. You are more than welcome to post my reply to the list. Once again thanks for the help and I certainly do appreciate the constructive criticism. Andrew Barker General Manager TruTrak Flight Systems "You build it...We fly it!" PH:479-751-0250 Ext. 222 www.trutrakap.com ________________________________ (Michael Sausen) Sent: Thursday, July 06, 2006 9:54 AM Andrew, Thanks for the reply. As I said in one of my later posts I figured you were looking into things. Don't worry about shipping out a new mounting bracket as long as you don't have any alignment concerns. Everything looked pretty good on my install once I drilled a new hole. I didn't notice the split grommet on the roll servo way back when I did that one but my concern was that the wire could eventually work into the split and chafe. If you haven't seen this in a few thousand servos, I'm not too concerned. I also put a dab of E6000 on it to make sure it couldn't wiggle. The length of bolt I got was a -11A and the one that I used was a -13A, although a -12A probably would have also worked. I'm glad you didn't see my post as bashing TruTrak. It was really meant to see if my circumstance was a one off or a wider problem that needed your attention. I have dealt with more than one vendor that could not take ANY criticism of their product or answer any of the tough questions I would hit them with. Eggenfeller is the first to come to mind with this type of mentality. He actually banned me from purchasing one of his engines because I criticized him for changing the advertised HP on his H6 engine almost weekly. J Anyway, I wouldn't fly with anyone else's AP. Michael Sausen RV-10 #352 PS, you mind if I post this over to the -10 list? Sent: Thursday, July 06, 2006 9:16 AM Yes, I do "troll" the list. You were also correct that I read your post first thing. The biggest reason that I didn't get a reply off to you yesterday was that I had to get some information on the things that you posted about. So, here goes... Yes, we have a small issue in the fit of the new cover over the servo amp board. We have a new vendor for this part, and they had the DB-9 hole a little too far down. This problem has been addressed, but the manufacturer of the part needed some time to get me the new parts. Since the old parts are still useable, they just don't fit as perfectly as I would like, I elected to use them until they could get me new parts. The split grommet has been used since the first servo was produced...that is somewhere between seven and eight thousand servos ago. We were however talking about his problem just a few days ago. We are looking at this problem. As to the pitch servo bracket, I was completely unaware of a problem. Thank you very much for bringing this to my attention. In my research yesterday, it appears that some of our new pitch brackets were not properly bent. I apologize for this mistake, and would be more than happy to send you, and anyone else that has an incorrectly bent bracket, a new bracket that is properly bent as soon as I see them. I should have an update on when I will get the new brackets today. I am still checking on the length of the bolt to attach the pushrod to the bellcrank. I don't yet know if that was just a shipping department mistake or not. I would assume so, because I haven't heard of this being a problem yet. I should have more information on that today as well. You are correct, we do not yet have all of the drawings together for the RV-10 pitch installation. I do not like that we are sending out picture instead of drawings, but I decided that this was certainly better than no documentation. We are working on these drawings, and should soon have them out. Things are certainly a little tight right now with Oshkosh coming up in 2 weeks and all. Last but not least, I do appreciate you keeping us in check and pointing out the problems to me. I always appreciate it when people do not just accept what they get as "what it is supposed to be". Without customer input, we would not have half of the products that we do today. It is the customer that makes our business, and I am very glad that we have such a great group of customers in the RV community. If you or anyone has any problems, you are more than welcome to call me personally. If you can't get me at my extension, please check with the operator. Many times I am either in a meeting or away from my desk. If I am available, she will round me up. Thanks again. Andrew Barker General Manager TruTrak Flight Systems "You build it...We fly it!" PH:479-751-0250 Ext. 222 www.trutrakap.com ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: Lightspeed with Keyswitch and 1 Mag Wiring
I have a similar, but slightly different solution for this. I have an IO-540 with a single (left) mag with impulse coupler and a Lightspeed II+. I am using the standard Van's key switch for the ignition. I am starting using the Lightspeed. Since I'm starting on the Lightspeed I want to ground out (disable) the Left mag during start. If you connect the mag to the R-terminal with jumper to GRN-terminal installed, the mag will be grounded out during start. I connected the L-terminal to the keyswitch option on the Lightspeed. All other keyswitch connections were normal per the instructions included. Then (this is important) I relabeled the key switch. It now says OFF-L-E-BOTH-START (L for left mag and E for electronic ignition). -Jim 40134 In a message dated 7/5/2006 9:54:13 A.M. Mountain Daylight Time, Tim(at)MyRV10.com writes: --> RV10-List message posted by: Tim Olson This is a repost of previous info. I had a builder ask me about it and I couldn't find it in the archives well, so I thought I'd resend it with a good subject line. ----- Wiring a Keyswitch Ignition - Lightspeed Plasma III/II+ ignition and a Mag Another non-RV10 builder, Dave Sundberg passed this on to me previously, and I wired mine this way and it indeed works fine. It does seem a bit like black magic, but seeing as it works fine I won't be complaining. Test it out before and after you run the engine, but it should work fine. The configuration is a Mag on the Left side, feeding the lower plugs, and a Lightspeed Plasma III (or II+) feeding the top plugs as the Right system. Note that allthough Lightspeed calls it a keyswitch "Option", it's always on the system, just optional to connect. * The P-Lead from the Mag goes to the L-Terminal on the Switch with the shield connected to the GRN terminal on the mag and not connected to anything on the switch end. * The P-Lead from the LS (Pin 1) goes to the R-Terminal on the switch and the shield (Pin 9) goes to the GRN-Terminal in the center of the switch. * Do not connect the jumper from the R-Term to the GRN-Terminal next to it. * Do not connect the center GRN-Terminal on the switch to aircraft ground. Both ignitions are grounded out with the switch in the OFF position. Dave had been flying and it was working for him. I am flying too and it's working great for me. I had previously spent time hooking mine up and ohming things out and was confused as heck. I also was confused in that the P-Lead on the mag is seemingly shorted to ground even with the wire disconnected, so I couldn't easily tell that it would be grounded by the switch. (Turns out this is normal) If you hook it all up, except for the mag P-Lead, you can indeed see that they ground the way their supposed to by using your ohmmeter. I also have this posted on my Electrical Tips section on my site. Tim -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 06, 2006
I was hoping I'd hear some input on this. Thanks Jim. Question: Why did you want to ground the mag during start? I've been starting on both and it's been starting very well. Is there something bad about starting with both? I see why you included "this is important" on the relabeling portion, as the standard operation is: OFF-R-L-BOTH-START so the "E" isn't taking place of the "R", it's taking place of the "L" and the "L" is where the "R" is normally. One more question: From what you can tell then, the NORMALLY RIGHT mag portion is grounded during start, correct? This is the problem I tried to overcome. The switching diagram provided really doesn't seem to indicate exactly what is going on. I didn't find that the switch, if wired "normally" without the "GND" jumper in place, would allow for proper operation in all modes. I believe it was START that was the one that didn't behave. Also, another builder contacted me off-list who believes the way I have it wired may be using the switch's case as the ground, and that it wouldn't be safe if the ground wasn't solid. I'm not sure if this is or isn't true. The original guy who gave me the tip, and I myself, seem to think that the ground source might be the Lightspeed itself. Not 100% sure about this though. The only 100% sure thing I am, is that at least the way it's wired right now it operates the way I want it to. Left and Right are grounded when the opposite is chosen, both ungrounds both, and so does start. And most importantly, they are both grounded when OFF is chosen. Tim Olson - RV-10 N104CD - Flying JSMcGrew(at)aol.com wrote: > I have a similar, but slightly different solution for this. I have an > IO-540 with a single (left) mag with impulse coupler and a Lightspeed > II+. I am using the standard Van's key switch for the ignition. I am > starting using the Lightspeed. > > Since I'm starting on the Lightspeed I want to ground out (disable) the > Left mag during start. If you connect the mag to the R-terminal with > jumper to GRN-terminal installed, the mag will be grounded out during > start. I connected the L-terminal to the keyswitch option on the > Lightspeed. All other keyswitch connections were normal per the > instructions included. Then (this is important) I relabeled the key > switch. It now says OFF-L-E-BOTH-START (L for left mag and E for > electronic ignition). > > -Jim > 40134 > > In a message dated 7/5/2006 9:54:13 A.M. Mountain Daylight Time, > Tim(at)MyRV10.com writes: > > > This is a repost of previous info. I had a builder ask me about it > and I couldn't find it in the archives well, so I thought I'd > resend it with a good subject line. > > ----- > > Wiring a Keyswitch Ignition - Lightspeed Plasma III/II+ ignition and > a Mag > > Another non-RV10 builder, Dave Sundberg passed this on to me > previously, > and I wired mine this way and it indeed works fine. It does seem a bit > like black magic, but seeing as it works fine I won't be complaining. > Test it out before and after you run the engine, but it should work > fine. > The configuration is a Mag on the Left side, feeding the lower plugs, > and a Lightspeed Plasma III (or II+) feeding the top plugs as the Right > system. Note that allthough Lightspeed calls it a keyswitch "Option", > it's always on the system, just optional to connect. > > * The P-Lead from the Mag goes to the L-Terminal on the Switch > with > the shield connected to the GRN terminal on the mag and not > connected to > anything on the switch end. > * The P-Lead from the LS (Pin 1) goes to the R-Terminal on the > switch and the shield (Pin 9) goes to the GRN-Terminal in the center of > the switch. > * Do not connect the jumper from the R-Term to the GRN-Terminal > next to it. > * Do not connect the center GRN-Terminal on the switch to aircraft > ground. Both ignitions are grounded out with the switch in the OFF > position. > > Dave had been flying and it was working for him. I am flying too and > it's working great for me. I had previously spent time hooking mine up > and ohming things out and was confused as heck. I also was confused in > that the P-Lead on the mag is seemingly shorted to ground even with > the > wire disconnected, so I couldn't easily tell that it would be grounded > by the switch. (Turns out this is normal) If you hook it all up, > except > for the mag P-Lead, you can indeed see that they ground the way their > supposed to by using your ohmmeter. > > I also have this posted on my Electrical Tips section on my site. > Tim > > -- > Tim Olson - RV-10 N104CD - ========================= es Day > > --> ================================================== - > NEW MATRONICS LIST WIKI - > - List Contribution Web Site > ================================================= > > > > > > > > > > ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: seats
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Jul 06, 2006
Tim I'm not an expert, but it is my understanding when you are retarding the spark for starting it is best to only have one system doing that for you. I suppose if the impulse mag and electronic ignition are doing approximately the same thing you would never know the difference. I spent a lot of time with a multi-meter and the ignition switch. I don't have it or my notes in front of me right now, but I recall that there are 2 GRN-terminals (as far as I could tell they are labeled exactly the same) - one is in the center (for connection to aircraft ground) and one is for the jumper to the R-terminal. In the START position the GRN-terminal next to the R terminal is internally connected to the center aircraft ground GRN-terminal - so if the jumper is in place, the R-terminal will be grounded. Without the jumper it will not be grounded. If you are still with me, here is what I found to be strange: In R - L or BOTH the R-terminal is INTERNALLY connected to the GRN-terminal (the one next to the R-terminal), however the internal connection with the aircraft ground GRN terminal has been broken. What I am getting at, is if you were to put a jumper from the L-terminal to the GRN terminal thinking that you were going to start on the right mag and ground out the left mag, it wouldn't quite work that way and you would have trouble when doing a mag check (as the L and R terminal would be connected together). This is why I ended up switching L for R and E for L on the markings. I realize that this isn't the exact problem that you are having, but I think the way yours is set up is related to the unexpected internal connections inside the switch. I'm not certain whether your ground is coming from the switch case or the LS, but it doesn't seem right to not be grounded to aircraft ground. All that and now I must caveat this with the fact that, although my ignition system works great on paper and with a multi-meter... I haven't started it yet. I'll let you know. -Jim 40134 In a message dated 7/6/2006 12:02:38 P.M. Mountain Daylight Time, Tim(at)MyRV10.com writes: --> RV10-List message posted by: Tim Olson I was hoping I'd hear some input on this. Thanks Jim. Question: Why did you want to ground the mag during start? I've been starting on both and it's been starting very well. Is there something bad about starting with both? I see why you included "this is important" on the relabeling portion, as the standard operation is: OFF-R-L-BOTH-START so the "E" isn't taking place of the "R", it's taking place of the "L" and the "L" is where the "R" is normally. One more question: From what you can tell then, the NORMALLY RIGHT mag portion is grounded during start, correct? This is the problem I tried to overcome. The switching diagram provided really doesn't seem to indicate exactly what is going on. I didn't find that the switch, if wired "normally" without the "GND" jumper in place, would allow for proper operation in all modes. I believe it was START that was the one that didn't behave. Also, another builder contacted me off-list who believes the way I have it wired may be using the switch's case as the ground, and that it wouldn't be safe if the ground wasn't solid. I'm not sure if this is or isn't true. The original guy who gave me the tip, and I myself, seem to think that the ground source might be the Lightspeed itself. Not 100% sure about this though. The only 100% sure thing I am, is that at least the way it's wired right now it operates the way I want it to. Left and Right are grounded when the opposite is chosen, both ungrounds both, and so does start. And most importantly, they are both grounded when OFF is chosen. Tim Olson - RV-10 N104CD - Flying JSMcGrew(at)aol.com wrote: > I have a similar, but slightly different solution for this. I have an > IO-540 with a single (left) mag with impulse coupler and a Lightspeed > II+. I am using the standard Van's key switch for the ignition. I am > starting using the Lightspeed. > > Since I'm starting on the Lightspeed I want to ground out (disable) the > Left mag during start. If you connect the mag to the R-terminal with > jumper to GRN-terminal installed, the mag will be grounded out during > start. I connected the L-terminal to the keyswitch option on the > Lightspeed. All other keyswitch connections were normal per the > instructions included. Then (this is important) I relabeled the key > switch. It now says OFF-L-E-BOTH-START (L for left mag and E for > electronic ignition). > > -Jim > 40134 > > In a message dated 7/5/2006 9:54:13 A.M. Mountain Daylight Time, > Tim(at)MyRV10.com writes: > > --> RV10-List message posted by: Tim Olson > > This is a repost of previous info. I had a builder ask me about it > and I couldn't find it in the archives well, so I thought I'd > resend it with a good subject line. > > ----- > > Wiring a Keyswitch Ignition - Lightspeed Plasma III/II+ ignition and > a Mag > > Another non-RV10 builder, Dave Sundberg passed this on to me > previously, > and I wired mine this way and it indeed works fine. It does seem a bit > like black magic, but seeing as it works fine I won't be complaining. > Test it out before and after you run the engine, but it should work > fine. > The configuration is a Mag on the Left side, feeding the lower plugs, > and a Lightspeed Plasma III (or II+) feeding the top plugs as the Right > system. Note that allthough Lightspeed calls it a keyswitch "Option", > it's always on the system, just optional to connect. > > * The P-Lead from the Mag goes to the L-Terminal on the Switch > with > the shield connected to the GRN terminal on the mag and not > connected to > anything on the switch end. > * The P-Lead from the LS (Pin 1) goes to the R-Terminal on the > switch and the shield (Pin 9) goes to the GRN-Terminal in the center of > the switch. > * Do not connect the jumper from the R-Term to the GRN-Terminal > next to it. > * Do not connect the center GRN-Terminal on the switch to aircraft > ground. Both ignitions are grounded out with the switch in the OFF > position. > > Dave had been flying and it was working for him. I am flying too and > it's working great for me. I had previously spent time hooking mine up > and ohming things out and was confused as heck. I also was confused in > that the P-Lead on the mag is seemingly shorted to ground even with > the > wire disconnected, so I couldn't easily tell that it would be grounded > by the switch. (Turns out this is normal) If you hook it all up, > except > for the mag P-Lead, you can indeed see that they ground the way their > supposed to by using your ohmmeter. > > I also have this posted on my Electrical Tips section on my site. > Tim > > -- > Tim Olson - RV-10 N104CD - ========================= es Day > > --> ================================================== - > NEW MATRONICS LIST WIKI - > - List Contribution Web Site > ================================================= > > > > > > > > > > ________________________________________________________________________________
Date: Jul 06, 2006
Subject: IO-540 Engine Question
I have a used IO-540 engine and today I removed the intake / induction tubes that run from the sides of the oil sump up to the cylinders. Down at the oil sump there is a flexible hose that joins the metal tubes together. After removing the tubes I noticed that three of the six stubs coming out of the oil sump were loose and could be moved in and out about an 1/8 inch. I talked to a local EAA member and he said the tubes were "rolled" in order to slightly expand them and hold them in place. So the questions are: (1) Do I need to get / borrow a tool to roll these again? (2) Can this be done while the sump is attached? (3) What about using a sealant (Fuel tank sealant comes to mind) to seal up the tubes to the oil sump vs "rolling" them again? Also, Where is a good place to order gaskets? I would like to replace the valve cover gaskets while I am cleaning up the outside. Need new cylinder intake gaskets as well. I have ordered manuals for the engine from Lycoming but they are not here yet. I need to get part numbers. Thanks, Jim Combs N40192 ________________________________________________________________________________
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Date: Jul 06, 2006
Aircraft Specialties has lots of parts for Lycoming and Continental, including Gaskets . . . Or even Spruce has the basic ones . . . TDT 40025 -----Original Message----- jim(at)CombsFive.Com Sent: Thu 7/6/2006 8:55 PM I have a used IO-540 engine and today I removed the intake / induction tubes that run from the sides of the oil sump up to the cylinders. Down at the oil sump there is a flexible hose that joins the metal tubes together. After removing the tubes I noticed that three of the six stubs coming out of the oil sump were loose and could be moved in and out about an 1/8 inch. I talked to a local EAA member and he said the tubes were "rolled" in order to slightly expand them and hold them in place. So the questions are: (1) Do I need to get / borrow a tool to roll these again? (2) Can this be done while the sump is attached? (3) What about using a sealant (Fuel tank sealant comes to mind) to seal up the tubes to the oil sump vs "rolling" them again? Also, Where is a good place to order gaskets? I would like to replace the valve cover gaskets while I am cleaning up the outside. Need new cylinder intake gaskets as well. I have ordered manuals for the engine from Lycoming but they are not here yet. I need to get part numbers. Thanks, Jim Combs N40192 ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Here I go again - console finished
I finished the center console today, and can't resist gloating just a little 8-) . http://deemsrv10.com/41-2consolefinished.htm http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slides/DSC03024.html Deems Davis # 406 Fuse/Finish http://deemsrv10.com/ ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Flap position sensor
I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ________________________________________________________________________________
Date: Jul 06, 2006
Without getting into the details of the switch per se....the switches are manufactured to allow you the choice of starting on both mags or on left mag only. I don't believe right mag only is an option. This originates with certified aircraft, where you can have a shower of sparks ignition on the left mag, and no retard on the right, or you can have impulse coupling on the left mag and none on the right, or you can have two impulse coupled mags. You want any mag (or electronic equivalent) that fires during cranking to do so at TDC. If a mag fires at the normal 20-25 degrees during cranking, you risk a cylinder firing enough before TDC to drive the engine backwards, also called a kickback..which can destroy your starter and vacuum pump. This is prevented by having the right mag grounded during the time the key is in the start position, and the left mag fired by retard breaker or impulse coupling. Obviously your experimental doesn't have to adhere to convention, but it is harder to swim upstream when the boat points the other way. Tim Olson wrote: > > I was hoping I'd hear some input on this. Thanks Jim. > > Question: Why did you want to ground the mag during start? > I've been starting on both and it's been starting very > well. Is there something bad about starting with both? > > I see why you included "this is important" on the relabeling > portion, as the standard operation is: OFF-R-L-BOTH-START > so the "E" isn't taking place of the "R", it's taking place > of the "L" and the "L" is where the "R" is normally. > > One more question: From what you can tell then, the > NORMALLY RIGHT mag portion is grounded during start, > correct? This is the problem I tried to overcome. The > switching diagram provided really doesn't seem to indicate > exactly what is going on. I didn't find that the switch, > if wired "normally" without the "GND" jumper in place, > would allow for proper operation in all modes. I believe > it was START that was the one that didn't behave. > > Also, another builder contacted me off-list who believes > the way I have it wired may be using the switch's case > as the ground, and that it wouldn't be safe if the ground > wasn't solid. I'm not sure if this is or isn't true. The > original guy who gave me the tip, and I myself, seem to > think that the ground source might be the Lightspeed > itself. Not 100% sure about this though. The only > 100% sure thing I am, is that at least the way it's wired > right now it operates the way I want it to. Left and > Right are grounded when the opposite is chosen, both > ungrounds both, and so does start. And most importantly, > they are both grounded when OFF is chosen. > > > Tim Olson - RV-10 N104CD - Flying > > > JSMcGrew(at)aol.com wrote: >> I have a similar, but slightly different solution for this. I have an >> IO-540 with a single (left) mag with impulse coupler and a Lightspeed >> II+. I am using the standard Van's key switch for the ignition. I am >> starting using the Lightspeed. >> >> Since I'm starting on the Lightspeed I want to ground out (disable) >> the Left mag during start. If you connect the mag to the R-terminal >> with jumper to GRN-terminal installed, the mag will be grounded out >> during start. I connected the L-terminal to the keyswitch option on >> the Lightspeed. All other keyswitch connections were normal per the >> instructions included. Then (this is important) I relabeled the key >> switch. It now says OFF-L-E-BOTH-START (L for left mag and E for >> electronic ignition). >> >> -Jim >> 40134 >> >> In a message dated 7/5/2006 9:54:13 A.M. Mountain Daylight Time, >> Tim(at)MyRV10.com writes: >> >> >> This is a repost of previous info. I had a builder ask me about it >> and I couldn't find it in the archives well, so I thought I'd >> resend it with a good subject line. >> >> ----- >> >> Wiring a Keyswitch Ignition - Lightspeed Plasma III/II+ ignition and >> a Mag >> >> Another non-RV10 builder, Dave Sundberg passed this on to me >> previously, >> and I wired mine this way and it indeed works fine. It does seem >> a bit >> like black magic, but seeing as it works fine I won't be >> complaining. >> Test it out before and after you run the engine, but it should work >> fine. >> The configuration is a Mag on the Left side, feeding the lower >> plugs, >> and a Lightspeed Plasma III (or II+) feeding the top plugs as the >> Right >> system. Note that allthough Lightspeed calls it a keyswitch >> "Option", >> it's always on the system, just optional to connect. >> >> * The P-Lead from the Mag goes to the L-Terminal on the Switch >> with >> the shield connected to the GRN terminal on the mag and not >> connected to >> anything on the switch end. >> * The P-Lead from the LS (Pin 1) goes to the R-Terminal on the >> switch and the shield (Pin 9) goes to the GRN-Terminal in the >> center of >> the switch. >> * Do not connect the jumper from the R-Term to the GRN-Terminal >> next to it. >> * Do not connect the center GRN-Terminal on the switch to >> aircraft >> ground. Both ignitions are grounded out with the switch in the OFF >> position. >> >> Dave had been flying and it was working for him. I am flying too >> and >> it's working great for me. I had previously spent time hooking >> mine up >> and ohming things out and was confused as heck. I also was >> confused in >> that the P-Lead on the mag is seemingly shorted to ground even with >> the >> wire disconnected, so I couldn't easily tell that it would be >> grounded >> by the switch. (Turns out this is normal) If you hook it all up, >> except >> for the mag P-Lead, you can indeed see that they ground the way >> their >> supposed to by using your ohmmeter. >> >> I also have this posted on my Electrical Tips section on my site. >> Tim >> >> -- Tim Olson - RV-10 N104CD - ========================= es >> Day --> >> ================================================== - >> NEW MATRONICS LIST WIKI - >> - List Contribution Web Site >> ================================================= >> >> >> >> >> >> >> >> >> >> > > > http://www.matronics.com/Navigator?RV10-List > http://wiki.matronics.com > > ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Jul 07, 2006
Very nice! Bob #40105 Firewall fwd and paint prep -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Thursday, July 06, 2006 10:38 PM I finished the center console today, and can't resist gloating just a little 8-) . http://deemsrv10.com/41-2consolefinished.htm http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slide s/DSC03024.html Deems Davis # 406 Fuse/Finish http://deemsrv10.com/ ________________________________________________________________________________
Date: Jul 07, 2006
Subject: PDF files
I'm planing to paint my own aircraft and just wondered where I might fined a plain drawing of the RV10 to doodle on? Sam Finish kit ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Elevator trim servo
I have a question for the group. I am finishing up section 12 and am to the point of adjusting the elevator trim tab servo. The instructions say to move the servo are through the necessary range of motion (don't have my plans available right now to get the exact wording). My question is what kind of power sources have been used to motor the servo, or what other method has been used? I would appreciate any assistance and suggestions on this matter as I wasn't able to track down much through the archives. Thank you. Eric Kallio #518 finishing up the tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45513#45513 ________________________________________________________________________________
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Date: Jul 07, 2006
Using the white wires, you can run the motor off any ~12v source. I used my 14.4 volt battery off my cordless drill for this motor and the flap motor. Just flip the wires around to run the motor the other way. Mike -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric_Kallio Sent: Friday, July 07, 2006 1:52 PM I have a question for the group. I am finishing up section 12 and am to the point of adjusting the elevator trim tab servo. The instructions say to move the servo are through the necessary range of motion (don't have my plans available right now to get the exact wording). My question is what kind of power sources have been used to motor the servo, or what other method has been used? I would appreciate any assistance and suggestions on this matter as I wasn't able to track down much through the archives. Thank you. Eric Kallio #518 finishing up the tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45513#45513 ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: Flap position sensor
Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: --> RV10-List message posted by: "Richard Sipp" I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: Elevator trim servo
9 volt rectangular battery works just fine. Use the two unmarked leads of the servo. Swap the leads to change direction. The servo will stop on it's own when travel limits are reached. Note: The left and right trim tabs move different amounts. Jim Combs 40192 =========================================================== I have a question for the group. I am finishing up section 12 and am to the point of adjusting the elevator trim tab servo. The instructions say to move the servo are through the necessary range of motion (don't have my plans available right now to get the exact wording). My question is what kind of power sources have been used to motor the servo, or what other method has been used? I would appreciate any assistance and suggestions on this matter as I wasn't able to track down much through the archives. Thank you. Eric Kallio #518 finishing up the tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45513#45513 =========================================================== ________________________________________________________________________________
Date: Jul 07, 2006
In addition to the answers you already received, I believe several people in the past simply used a 9 volt battery. I think I used a auto battery charger. Michael Sausen RV-10 #352 Working on Fuselage -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric_Kallio Sent: Friday, July 07, 2006 12:52 PM I have a question for the group. I am finishing up section 12 and am to the point of adjusting the elevator trim tab servo. The instructions say to move the servo are through the necessary range of motion (don't have my plans available right now to get the exact wording). My question is what kind of power sources have been used to motor the servo, or what other method has been used? I would appreciate any assistance and suggestions on this matter as I wasn't able to track down much through the archives. Thank you. Eric Kallio #518 finishing up the tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45513#45513 ________________________________________________________________________________
Date: Jul 07, 2006
Subject: New (sort of) Builder and Wing Build Questions
Hi Everyone, I just discovered the matronics rv-10 list, and thought I would add my name to the forum. I had been using the search engine for some time, but for some reason, did not realize the list was still active. Some of the names here are pretty familiar to me (especially Tim Olson's) thru builder websites, which are pure gold for newbies like me. However, while browsing some of the builder sites, I noticed many are adding leading edge lights and wiring conduit while assembling the ribs. I am still countersinking the main spars, but the ribs are next. I do want LE lights and probably wiring conduit. LE lights. Should I order these now? I am hoping to order with halogen bulbs with the option to upgrade to HID in the future? Should I install the lights along with the ribs? Conduit. I didn't get any in the kit, and i don't think it's on the parts list. Van's catalog has Nylon wiring conduit as part # DUCT NT5/8, but it says it's included in the wiring kit!? Should I be ordering this too while building the wings? Fuel caps. Also, has anyone ordered the lockable fuel caps? I was just at Van's a couple weeks ago for a demo flight, and noticed the deluxe and lockable fuel caps on the counter. I wish I had inspected them more carefully, but the upgrade seems nice to have - esp. if it's lockable. Thank you for the advice! Jae Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45536#45536 ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: New (sort of) Builder and Wing Build Questions
---- jchang10 wrote: > However, while browsing some of the builder sites, I noticed many are adding leading edge lights and wiring conduit while assembling the ribs. I am still countersinking the main spars, but the ribs are next. I do want LE lights and probably wiring conduit. > LE lights. Should I order these now? I am hoping to order with halogen bulbs with the option to upgrade to HID in the future? Should I install the lights along with the ribs? I have Duckworks leading edge lights on both wings in my RV-7A and for my $0.02 I don't think they are as good a solution as the wingtip lights in the -10 kit. Lotsa work to install, impossible to get a completely smooth surface transition, the lenses are easy to scratch when you are wiping bug hits off the leading edge, and they get whacked with FOD and crack (have one needing replacement currently). Light dispersion pattern isn't really any better than the wingtip lights if you mount them in either of the 2 most outboard bays. Other than that they are wonderful ;-). > Conduit. I didn't get any in the kit, and i don't think it's on the parts list. Van's catalog has Nylon wiring conduit as part # DUCT NT5/8, but it says it's included in the wiring kit!? Should I be ordering this too while building the wings? Van's flex conduit is easy to snake around various places, and has the benefit that it will more or less latch itself into a 7/8 inch hole in a rib and not need to be lashed to stay put. You can order it separately from the web store; no need to get a whole wiring kit to get some. YMMV, -Dan Masys 40448 finish kit & panel. Autopilot harness just fabricated, installed and it works! ________________________________________________________________________________
Date: Jul 07, 2006
jchang10 wrote: > > > Hi Everyone, > > I just discovered the matronics rv-10 list, and thought I would add > my name to the forum. I had been using the search engine for some > time, but for some reason, did not realize the list was still active. > Some of the names here are pretty familiar to me (especially Tim > Olson's) thru builder websites, which are pure gold for newbies like > me. > > However, while browsing some of the builder sites, I noticed many are > adding leading edge lights and wiring conduit while assembling the > ribs. I am still countersinking the main spars, but the ribs are > next. I do want LE lights and probably wiring conduit. > > LE lights. Should I order these now? I am hoping to order with > halogen bulbs with the option to upgrade to HID in the future? Should > I install the lights along with the ribs? > Jae, I think it would be easiest to install them either after the wing is built, or after the leading edge is built at least. You could order them, but I wouldn't start installing them until then. > Conduit. I didn't get any in the kit, and i don't think it's on the > parts list. Van's catalog has Nylon wiring conduit as part # DUCT > NT5/8, but it says it's included in the wiring kit!? Should I be > ordering this too while building the wings? > I don't know what comes in the wiring kit regarding conduit, but it's pretty cheap, and it's pretty nice stuff for doing the wings. A 25' roll will take care of you. -Tim > Fuel caps. Also, has anyone ordered the lockable fuel caps? I was > just at Van's a couple weeks ago for a demo flight, and noticed the > deluxe and lockable fuel caps on the counter. I wish I had inspected > them more carefully, but the upgrade seems nice to have - esp. if > it's lockable. > > Thank you for the advice! > > Jae > > ________________________________________________________________________________
Date: Jul 08, 2006
Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Saturday, July 08, 2006 4:48 AM Subject: Re: RV10-List: Flap position sensor Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ========================= ========================= - NEW MATRONICS LIST WIKI - ========================= p; - List Contribution Web Site ========================= ========================= ------------------------------------------------------------------------- ----- ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Jul 07, 2006
Eric, I picked up a 12 volt 1000 Mah DC power supply from Radio Shack. It was like $20. I have used it to operate and test all the electrical items I have installed to date to include lights, strobes, flap motor, trim servos, trim relays and it even kicks over the main battery relays. Pick up a set of aligator clips and install them on the leads. Very easy and cheap way to ops check things as you go. Rick S. 40185 Wiring ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Jul 07, 2006
I can tell you my approach....The landing lights I am planning on are the wing tip mounted type, so I am not buying them until the wings are mounted to the fuse. I did not run a conduit (I may regret this) but so far I have had no problems pulling wires through the snap bushing by reaching through the inspection plates. I can definitively tell you that the lockable deluxe fuel caps are a good deal. I did not install them on my tanks and I really wish I had. I have installed them for several clients and they are much nicer hardware....worth an extra $100.00. Small change in the scope of this project. Cheers.. Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- Sent: Friday, July 07, 2006 12:29 PM > > Hi Everyone, > > I just discovered the matronics rv-10 list, and thought I would add my name to the forum. I had been using the search engine for some time, but for some reason, did not realize the list was still active. Some of the names here are pretty familiar to me (especially Tim Olson's) thru builder websites, which are pure gold for newbies like me. > > However, while browsing some of the builder sites, I noticed many are adding leading edge lights and wiring conduit while assembling the ribs. I am still countersinking the main spars, but the ribs are next. I do want LE lights and probably wiring conduit. > > LE lights. Should I order these now? I am hoping to order with halogen bulbs with the option to upgrade to HID in the future? Should I install the lights along with the ribs? > > Conduit. I didn't get any in the kit, and i don't think it's on the parts list. Van's catalog has Nylon wiring conduit as part # DUCT NT5/8, but it says it's included in the wiring kit!? Should I be ordering this too while building the wings? > > Fuel caps. Also, has anyone ordered the lockable fuel caps? I was just at Van's a couple weeks ago for a demo flight, and noticed the deluxe and lockable fuel caps on the counter. I wish I had inspected them more carefully, but the upgrade seems nice to have - esp. if it's lockable. > > Thank you for the advice! > > Jae > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=45536#45536 > > ________________________________________________________________________________
Date: Jul 07, 2006
Date: Jul 08, 2006
Chris I didn't see the original post but if you're referring to the stick on cable blocks that are used in conjunction with the cable ties to tidy up your electrical wiring, I found the only place to have them was the big auto barns, at least in Brisbane anyway. John 40315 [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris , Susie Darcy Sent: Saturday, 8 July 2006 7:20 AM Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- Sent: Saturday, July 08, 2006 4:48 AM Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ================================================= -> =========================p; - List Contribution Web Site ================================================= _____ _____ ________________________________________________________________________________
Date: Jul 07, 2006
Be advised that you need to get versions that use industrial adhesive. The kind that you get from a home store have a tendency to let go after a while. Not something you want to have happen in an area of a lot of moving parts. Michael [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne Sent: Friday, July 07, 2006 5:39 PM Chris I didn't see the original post but if you're referring to the stick on cable blocks that are used in conjunction with the cable ties to tidy up your electrical wiring, I found the only place to have them was the big auto barns, at least in Brisbane anyway. John 40315 [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris , Susie Darcy Sent: Saturday, 8 July 2006 7:20 AM Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Saturday, July 08, 2006 4:48 AM Subject: Re: RV10-List: Flap position sensor Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ========================= ========================= -> ========================= p; - List Contribution Web Site ========================= ========================= ________________________________ ________________________________ ________________________________________________________________________________
Date: Jul 07, 2006
Jim, The intake tubes are swaged into the crankcase. There is a tool that can re-swage the induction tubes, improving the retention, but an application of proseal around the joint will help prevent induction leaks. When I rebuilt my O-360 I found a similar condition on two of the four tubes. My local Lycon shop fixed the problem for about twenty bucks. Carl Franz N410FS (reserved), N215CF RV-6 flying -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com Sent: Thursday, July 06, 2006 8:56 PM I have a used IO-540 engine and today I removed the intake / induction tubes that run from the sides of the oil sump up to the cylinders. Down at the oil sump there is a flexible hose that joins the metal tubes together. After removing the tubes I noticed that three of the six stubs coming out of the oil sump were loose and could be moved in and out about an 1/8 inch. I talked to a local EAA member and he said the tubes were "rolled" in order to slightly expand them and hold them in place. So the questions are: (1) Do I need to get / borrow a tool to roll these again? (2) Can this be done while the sump is attached? (3) What about using a sealant (Fuel tank sealant comes to mind) to seal up the tubes to the oil sump vs "rolling" them again? Also, Where is a good place to order gaskets? I would like to replace the valve cover gaskets while I am cleaning up the outside. Need new cylinder intake gaskets as well. I have ordered manuals for the engine from Lycoming but they are not here yet. I need to get part numbers. Thanks, Jim Combs N40192 ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: IO-540 Engine Question
When I rebuilt my IO-540 I had several loose induction tubes. My IA said to send it to Divco for repair. As I recall, I had to replace one tube and get 3 tightened so they wouldn't rotate (and leak air). Cost, including inspection, repair, part, and return shipping, was about $180. Tim Carl Franz wrote: > > Jim, > > The intake tubes are swaged into the crankcase. There is a tool > that can re-swage the induction tubes, improving the retention, but an > application of proseal around the joint will help prevent induction leaks. > When I rebuilt my O-360 I found a similar condition on two of the four > tubes. My local Lycon shop fixed the problem for about twenty bucks. Carl > Franz N410FS (reserved), N215CF RV-6 flying > > -----Original Message----- > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com > Sent: Thursday, July 06, 2006 8:56 PM > > > > I have a used IO-540 engine and today I removed the intake / induction tubes > that run from the sides of the oil sump up to the cylinders. > > Down at the oil sump there is a flexible hose that joins the metal tubes > together. After removing the tubes I noticed that three of the six stubs > coming out of the oil sump were loose and could be moved in and out about an > 1/8 inch. I talked to a local EAA member and he said the tubes were > "rolled" in order to slightly expand them and hold them in place. > > So the questions are: > > (1) Do I need to get / borrow a tool to roll these again? (2) Can this be > done while the sump is attached? > (3) What about using a sealant (Fuel tank sealant comes to mind) to seal up > the tubes to the oil sump vs "rolling" them again? > > Also, Where is a good place to order gaskets? I would like to replace the > valve cover gaskets while I am cleaning up the outside. Need new cylinder > intake gaskets as well. > > I have ordered manuals for the engine from Lycoming but they are not here > yet. I need to get part numbers. > > Thanks, > > Jim Combs > N40192 > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2006
I buy the cable tie mounting bases from Stein Air. _http://www.steinair.com/cableties.htm_ (http://www.steinair.com/cableties.htm) Jim In a message dated 7/7/2006 3:23:45 P.M. Mountain Daylight Time, VHMUM(at)bigpond.com writes: Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- Sent: Saturday, July 08, 2006 4:48 AM Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ================================================== -> =========================p; - List Contribution Web Site ================================================= ____________________________________ ____________________________________ ________________________________________________________________________________
From: "Harris, Jeremy P" <jeremy.p.harris(at)boeing.com>
Date: Jul 07, 2006
We mounted ours in the tunnel near the flap torque tube. We attached a bell crank/control horn fabricated from some light AL angle and held onto the torque tube with a pipe clamp so no additional holes were drilled in the torque tube. The horn was then linked via 1/4 scale (large) RC aircraft push rod to the 1.2" throw Ray allen potentiometer. The ray allen potentiometer was mounted on another peice of angle on the side wall of the inside of the tunnel. You'll have to work the geometry out to get the correct throw on the control horn mounted to the torque tube. We got about 1/4-1/3" up the horn from the surface of the tube to get the 1.2" of throw for full flap movement. There's some pics on the website but they aren't very good. Hope this helps. Jeremy http://jharris.net/Aviation/RV_10.htm if you go about 3/4 down the page, click on the picture of the tunnel. The sensor and brackets are on the bottom of the pic (starboard side of airplane). http://jharris.net/Aviation/Flap%20Position%20Sensors.JPG Jeremy P. Harris Ground Based Mid-Course Defense WSOPS Engineering The Boeing Company Washington, DC Desk: (703) 414-6057 Office: 825B Huntsville, AL Desk (256) 464-4530 Cube: 1225 Cell: (703) 627-6500 Fax: (703) 414-6372 MC: 793C-G007 ________________________________ Sent: Friday, July 07, 2006 5:20 PM Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Saturday, July 08, 2006 4:48 AM Subject: Re: RV10-List: Flap position sensor Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ========================= ========================= -> ========================= p; - List Contribution Web Site ========================= ========================= ________________________________ ________________________________ ________________________________________________________________________________
Date: Jul 07, 2006
Outstanding Jim, thanks very much. Dick Sipp ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Friday, July 07, 2006 2:48 PM Subject: Re: RV10-List: Flap position sensor Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ========================= ========================= - NEW MATRONICS LIST WIKI - ========================= p; - List Contribution Web Site ========================= ========================= ------------------------------------------------------------------------- ----- ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Jul 07, 2006
Thanks everyone for the replies. It's amazing how much one can swing back and forth on some of these options - hopefully, it's not just me! ;) It looks like i'll be ordering the conduit from Van's. as far as i can see, it looks like there is plenty of room to drill the conduit holes even after the ribs are riveted. I am going to have to think some more on the lights, but it sounds like i have time. Thanks again for the insights! Jae Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45641#45641 ________________________________________________________________________________
Date: Jul 09, 2006
---- "RV Builder (Michael Sausen)" wrote: > Dan, > > Did you have the HID lights or just standard halogen for the Duckworks? I would agree with you on the halogen's but it would be interesting to hear that the stock -10 halogens are better than the HID's. They throw way more light than any halogen. My -7A has the halogen bulbs; built in 2003 when there was no HID option. > Incidentally, I checked my log and spent 5.5 hours installing both the Duckworks HID and the AOA ports. I also installed the nutplates in the other wing for a second HID light should I want two. Much easier to put them in ahead of time but you need the template that comes with the kit. The hardest part on the -7A was pulling the lens snugly against the curve of the leading edge while drilling the mounting holes. Too loose and there is a gap right at the leading edge. Too tight and your lenses crack in the first hundred flight hours or so. Been there, done that for both conditions! -Dan Masys #40448 finish kit ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Mounting the engine
I'm feeling a little pumped tonight in that we got the engine mounted today, picture attached. Other than wanting to toot our horn I wanted to pass along what experience we had in mounting the engine. I have a friend from Iowa who came down this weekend to help me install the engine. He is an A&P and runs a small airport just outside of Des Moines. So when I say we, I actually should probably be saying he, since he did the bulk of the thinking on this, since he's done this many times. Anyway we began by attaching the upper two mounts, because he said that this method normal works the best. But in doing this we ran into a problem where we couldn't seem to get the bottom two mounts aligned to get the bolts in. I had remembered reading something about this on Tim Olson's web site and so I pulled out the instructions he had on his web site from my file and Walla, he had experienced the same problem. The solution that he found that worked for him was to attach the lower two mounts first and the work on the upper mounts. So we tried this method and it work on the first try. Thanks Tim, I might still be out there had I not read that tip. It only took us about 1 1/2 to 2 hours to have the engine mounted even with the false start. So, based on our experience, and Tim's, I would suggest using this method when installing your engine. Wayne Edgerton $40336 putting on the prop tomorrow ________________________________________________________________________________
Date: Jul 08, 2006
Dan, I'm not sure if yours is the old or the new style lens and retainer, but the lens in the new ones isn't drilled at all, but is kind of floating trapped. It's not the easiest to pull the lens in place, but once it's there, it's probably not going to crack easily, and should be pretty good. The only gap is there because of a small amount of foam seal, but the gap is pretty small. For people doing HIDS, the chance that you'll be pulling the lens to replace a lamp is much much smaller anyway. So, if you have the old style, you may have had more troubles. I heard those cracked lenses all the time. But, that's the old way. Tim Olson - RV-10 N104CD - Flying Dan Masys wrote: > > > ---- "RV Builder (Michael Sausen)" wrote: > >> Dan, >> >> Did you have the HID lights or just standard halogen for the >> Duckworks? I would agree with you on the halogen's but it would be >> interesting to hear that the stock -10 halogens are better than the >> HID's. They throw way more light than any halogen. > > My -7A has the halogen bulbs; built in 2003 when there was no HID > option. > >> Incidentally, I checked my log and spent 5.5 hours installing both >> the Duckworks HID and the AOA ports. I also installed the nutplates >> in the other wing for a second HID light should I want two. Much >> easier to put them in ahead of time but you need the template that >> comes with the kit. > > The hardest part on the -7A was pulling the lens snugly against the > curve of the leading edge while drilling the mounting holes. Too > loose and there is a gap right at the leading edge. Too tight and > your lenses crack in the first hundred flight hours or so. Been > there, done that for both conditions! > > -Dan Masys #40448 finish kit > > ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: Jul 09, 2006
Drill the conduit holes before you assemble the wing skeleton! I at least doubled the amount of time doing it on the QB wings. Just not enough easy clearance for my tools. Rob #392 QB Wings -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jchang10 Sent: Friday, July 07, 2006 11:53 PM Thanks everyone for the replies. It's amazing how much one can swing back and forth on some of these options - hopefully, it's not just me! ;) It looks like i'll be ordering the conduit from Van's. as far as i can see, it looks like there is plenty of room to drill the conduit holes even after the ribs are riveted. I am going to have to think some more on the lights, but it sounds like i have time. Thanks again for the insights! Jae Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45641#45641 ________________________________________________________________________________
Date: Jul 09, 2006
Drip irrigation tubing 5/8 makes excellent wire channel. it is smooth inside and out and is extremely lite Dennis Mangan 109DM RV-6a ----- Original Message ----- From: Robert G. Wright<mailto:armywrights(at)adelphia.net> To: rv10-list(at)matronics.com Sent: Sunday, July 09, 2006 6:41 AM Subject: RE: RV10-List: Re: New (sort of) Builder and Wing Build Questions > Drill the conduit holes before you assemble the wing skeleton! I at least doubled the amount of time doing it on the QB wings. Just not enough easy clearance for my tools. Rob #392 QB Wings -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jchang10 Sent: Friday, July 07, 2006 11:53 PM > Thanks everyone for the replies. It's amazing how much one can swing back and forth on some of these options - hopefully, it's not just me! ;) It looks like i'll be ordering the conduit from Van's. as far as i can see, it looks like there is plenty of room to drill the conduit holes even after the ribs are riveted. I am going to have to think some more on the lights, but it sounds like i have time. Thanks again for the insights! Jae Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45641#45641 atronics.com/viewtopic.php?p=45641#45641> ========================= ========== http://www.matronics.com/Navigator?RV10-List igator?RV10-List> ========================= ========== ========================= ========== http://www.matronics.com/contribution on> ========================= ========== ________________________________________________________________________________
Date: Jul 09, 2006
Subject: Wheel Fairings Question for those who have completed these
steps A question for those who have installed the Wheel Fairings. Is the vertical line on the rear fairing marked in 48-2 fig 4 actually vertical in flight attitude as referenced in 48-6 fig 2? Or is the top of the vertical line actually kicked outboard at the top of the fairing in 48-6 fig 2? 48-5 fig3 and 48-7 fig1 seem to indicated it would be kicked outboard. Thanks, Bobby Hughes 40116 ________________________________________________________________________________
Date: Jul 10, 2006
Chris - these are readily available from Dick Smith outlets. I soak them in toluene to remove the adhesive and proseal them to the skins/ribs/bulkheads. They ain't going anywhere. cheers, Ron #187 wiring -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Chris , Susie Darcy Sent: Saturday, 8 July 2006 6:50 AM Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- Sent: Saturday, July 08, 2006 4:48 AM Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ========================= ========================= -> ========================= p; - List Contribution Web Site ========================= ========================= _____ _____ ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Jul 09, 2006
I drilled out the smaller holes along the rear spar to run my strobe wire - and keep it away from the other wires in the conduit. This would have been MUCH easier if the skin were not on yet. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Engine mount and gear -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert G. Wright Sent: Sunday, July 09, 2006 9:41 AM --> Drill the conduit holes before you assemble the wing skeleton! I at least doubled the amount of time doing it on the QB wings. Just not enough easy clearance for my tools. Rob #392 QB Wings -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jchang10 Sent: Friday, July 07, 2006 11:53 PM --> Thanks everyone for the replies. It's amazing how much one can swing back and forth on some of these options - hopefully, it's not just me! ;) It looks like i'll be ordering the conduit from Van's. as far as i can see, it looks like there is plenty of room to drill the conduit holes even after the ribs are riveted. I am going to have to think some more on the lights, but it sounds like i have time. Thanks again for the insights! Jae Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=45641#45641 -- -- ________________________________________________________________________________
Date: Jul 10, 2006
Thanks Ron will have a look . Do not archive ----- Original Message ----- From: McGANN, Ron To: rv10-list(at)matronics.com Sent: Monday, July 10, 2006 8:57 AM Subject: RE: RV10-List: Flap position sensor Chris - these are readily available from Dick Smith outlets. I soak them in toluene to remove the adhesive and proseal them to the skins/ribs/bulkheads. They ain't going anywhere. cheers, Ron #187 wiring -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Chris , Susie Darcy Sent: Saturday, 8 July 2006 6:50 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Flap position sensor Jim those stick on things that hold the wires ...what are they called as I cant seem to find them out here in OZ regards Chris ----- Original Message ----- From: JSMcGrew(at)aol.com To: rv10-list(at)matronics.com Sent: Saturday, July 08, 2006 4:48 AM Subject: Re: RV10-List: Flap position sensor Photos attached of my POS 12 mount. I used 2 pieces of .032 angle, one screwed to the tunnel wall and one pop-riveted to the flap actuator. I connected them with a piece of threated model aircraft pushrod with a brass clevis on one end and a Z bend on the other. You can also see the flap switch I installed for my Advanced Flight Systems AOA Sport systems. -Jim McGrew 40134 In a message dated 7/6/2006 9:42:21 P.M. Mountain Daylight Time, rsipp(at)earthlink.net writes: I would like to hear from anyone who has mounted a Ray Allan flap position sensor (POS 12) on the flap system to drive a Ray Allan LED indicator. A picture or description of where and how you mounted it would be most appreciated. Thanks Dick Sipp 40065 ========================= es Day --> ========================= ========================= -> ========================= p; - List Contribution Web Site ========================= ========================= ------------------------------------------------------------------------- - ------------------------------------------------------------------------- - ________________________________________________________________________________
Date: Jul 10, 2006
Subject: RV10 rack
Ed Sorry it took a while to respond, as I just got home from vacation. This is the best picture I have of the rack handy, but it shows that the wood between the main spars is used to mount to the rack, and supports it in any position you need, if you have a lifting device. The supports attaching to the step receptacles are there for when I attach the tailcone primarily, as the fuselage is pretty much balanced on just the spars. I made the rack low, so it can roll under things , but I place jackstands under the lower rails when working on the plane in the normal level position. I can easily roll under it with a creaper when needed. ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: Wheel Fairings Question for those who have completed
---- Tim Olson wrote: > My plane flew almost perfect with no rudder correction before I added > wheel fairings. I put the fairings on and they weren't aligned as > good as I wanted...they were toed out. I re-worked them to try to > correct it. Ended up still not perfect. Now the ball is something > like 1/2-3/4 out to the right when flying. Had to add a rudder > block for the time being. If the -10 has similar aerodynamic forces to the 2 place RV's, it will be the alignment of the gear leg fairings that is more important even than the wheel fairings. Seems counterintuitive given their sizes, but the positioning of the gear leg fairings up in the prop disc airflow makes them pretty efficient flight control surfaces. You can get more effect on the centering of the ball by playing with a quarter to half inch of movement of the trailing edge of the leg fairing than an inch or more of repositioning of the wheel fairing trailing edge. Try it. You might like it :-). That said, I also have a permanent wedge on the rudder of my -7A. :-( -Dan Masys 40448 ________________________________________________________________________________
Date: Jul 10, 2006
Subject: torque tube support attach to wing root rib
Group, Has anyone run into the problem of the rear aileron torque tube support brackets interfering with the bead in the forward most lightening hole of the wing root ribs? Thanks Todd #362 --------------------------------- at 1/min. ________________________________________________________________________________
Date: Jul 10, 2006
Hi Jae, Welcome to the group! Something to think about is the locking gas caps will only keep the honest ones out. If someone really wants your fuel they will just pull the drain valve at the bottom of the tank and drain it into a container. It also may be worth thinking about running a spare conduit out to the wing tips. It doesn't add much weight and may come in handy if you decide to run a wing tip antenna later. Vern -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jchang10 Sent: Friday, July 07, 2006 12:30 PM Conduit. I didn't get any in the kit, and i don't think it's on the parts list. Van's catalog has Nylon wiring conduit as part # DUCT NT5/8, but it says it's included in the wiring kit!? Should I be ordering this too while building the wings? Fuel caps. Also, has anyone ordered the lockable fuel caps? I was just at Van's a couple weeks ago for a demo flight, and noticed the deluxe and lockable fuel caps on the counter. I wish I had inspected them more carefully, but the upgrade seems nice to have - esp. if it's lockable. Thank you for the advice! Jae Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45536#45536 ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: torque tube support attach to wing root rib
Todd, Yes, You have to cut it back to open up the space. Even the hinge gets cut back a little. Factory plane has this mod, so does every other flying plane I have seen. Van's changed the opening from rectangle to teardrop at some build #. It would be nice if they sent out a revision notice as it would be much easier to fix when you have the rear spar on the bench as opposed to riveted to the wing. If you search back I had more detail about this about 6-9 months ago. Bottom line is if you have a retangular opening in your wing rear spar for your aileron push tube you will need to widen the opening for clearance. Another area where I have noticed clearance issues is between the small landing gear front tube and one of the seat supports. If you don't increase dia of the existing opening then the tube wll rub against the support and wear thru the powdercoat into the metal. Overall, I think we are spoiled that everything fits so well... :) Eric #40150 --- todd agold wrote: > Group, > > Has anyone run into the problem of the rear aileron > torque tube support brackets interfering with the > bead in the forward most lightening hole of the wing > root ribs? > > Thanks > > Todd > #362 > > > --------------------------------- > Talk is cheap. Use Yahoo! Messenger to make ________________________________________________________________________________
Date: Jul 10, 2006
Eric, Thanks for the reply, but I'm referring to a different issue. See picture... Todd #362 Eric Panning wrote: Todd, Yes, You have to cut it back to open up the space. Even the hinge gets cut back a little. Factory plane has this mod, so does every other flying plane I have seen. Van's changed the opening from rectangle to teardrop at some build #. It would be nice if they sent out a revision notice as it would be much easier to fix when you have the rear spar on the bench as opposed to riveted to the wing. If you search back I had more detail about this about 6-9 months ago. Bottom line is if you have a retangular opening in your wing rear spar for your aileron push tube you will need to widen the opening for clearance. Another area where I have noticed clearance issues is between the small landing gear front tube and one of the seat supports. If you don't increase dia of the existing opening then the tube wll rub against the support and wear thru the powdercoat into the metal. Overall, I think we are spoiled that everything fits so well... :) Eric #40150 --- todd agold wrote: > Group, > > Has anyone run into the problem of the rear aileron > torque tube support brackets interfering with the > bead in the forward most lightening hole of the wing > root ribs? > > Thanks > > Todd > #362 > > > --------------------------------- > Talk is cheap. Use Yahoo! Messenger to make --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs.Try it free. ________________________________________________________________________________
Date: Jul 10, 2006
I am not 100% sure, I will look tonight, but I think I had to shape that piece in order to get it to fit flat on the rib. Rene' Felker 40322 N423CF Finish Kit....going slow :-( _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of todd agold Sent: Monday, July 10, 2006 11:28 AM Eric, Thanks for the reply, but I'm referring to a different issue. See picture... Todd #362 Eric Panning wrote: Todd, Yes, You have to cut it back to open up the space. Even the hinge gets cut back a little. Factory plane has this mod, so does every other flying plane I have seen. Van's changed the opening from rectangle to teardrop at some build #. It would be nice if they sent out a revision notice as it would be much easier to fix when you have the rear spar on the bench as opposed to riveted to the wing. If you search back I had more detail about this about 6-9 months ago. Bottom line is if you have a retangular opening in your wing rear spar for your aileron push tube you will need to widen the opening for clearance. Another area where I have noticed clearance issues is between the small landing gear front tube and one of the seat supports. If you don't increase dia of the existing opening then the tube wll rub against the support and wear thru the powdercoat into the metal. Overall, I think we are spoiled that everything fits so well... :) Eric #40150 --- todd agold wrote: > Group, > > Has anyone run into the problem of the rear aileron > torque tube support brackets interfering with the > bead in the forward most lightening hole of the wing > root ribs? > > Thanks > > _____ Yahoo! Music Unlimited - Access over 1 million songs. Try <http://pa.yahoo.com/*http:/us.rd.yahoo.com/evt=36035/*http:/music.yahoo.com /unlimited/%20%0d%0a> it free. ________________________________________________________________________________
Date: Jul 11, 2006
Hey Todd, Just did this a couple of days ago and also sat scratching my head for some time after striking the same problem. I also spent some time searching through the lists thinking "Surely someone else has had this problem!!" In the end I ground the bottom of the support brackets back to provide clearance at which point they sat in there semi-nicely (still had headaches getting the holes common to the flanges even close to lining up). Have fun, Scott Lewis RV-10 40172 Adelaide, South Australia Quoting todd agold : > Group, > > Has anyone run into the problem of the rear aileron torque tube > support brackets interfering with the bead in the forward most > lightening hole of the wing root ribs? > > Thanks > > Todd > #362 ________________________________________________________________________________
Date: Jul 10, 2006
The old Yahoo list had a bunch of info about this but alas it tis gone so for us old Yahoo guys who remember, this is what I recall: Some had clearance issues, some didn't, and if you do, it's a VERY LITTLE amount of interference. My right bracket just interfered (only right) with the bead so I buffed off the slightest amount of material off the bottom of the bracket and it worked fine. Later someone posted that Van's said to flatten the bead slightly to allow the bracket to sit properly. I know this sounds dumb but make sure the angle is aft of the bracket and not forward which would make it sit right on top of the bead. Carefully line up the spacer and bracket to make sure your not to far forward when you match drill. If the bracket is sitting really high up on the bead, something is wrong somewhere. You should only have to round the edge of the bracket a small amount for it to come together correctly. Rick S. 40185 ________________________________________________________________________________
Date: Jul 10, 2006
That problem is common. My kit #40192 had it too. Van support will tell you to flatten out the rib. Jim C =========================================================== Eric, Thanks for the reply, but I'm referring to a different issue. See picture... Todd #362 Eric Panning wrote: Todd, Yes, You have to cut it back to open up the space. Even the hinge gets cut back a little. Factory plane has this mod, so does every other flying plane I have seen. Van's changed the opening from rectangle to teardrop at some build #. It would be nice if they sent out a revision notice as it would be much easier to fix when you have the rear spar on the bench as opposed to riveted to the wing. If you search back I had more detail about this about 6-9 months ago. Bottom line is if you have a retangular opening in your wing rear spar for your aileron push tube you will need to widen the opening for clearance. Another area where I have noticed clearance issues is between the small landing gear front tube and one of the seat supports. If you don't increase dia of the existing opening then the tube wll rub against the support and wear thru the powdercoat into the metal. Overall, I think we are spoiled that everything fits so well... :) Eric #40150 --- todd agold wrote: > Group, > > Has anyone run into the problem of the rear aileron > torque tube support brackets interfering with the > bead in the forward most lightening hole of the wing > root ribs? > > Thanks > > Todd > #362 > > > --------------------------------- > Talk is cheap. Use Yahoo! Messenger to make --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs.Try it free. =========================================================== ________________________________________________________________________________
Date: Jul 11, 2006
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Here I go again - console finished
Deems, Can you give us the rough pricing on the panel and center console from Aerotronics? Less electronics... It helps me to start choking early on the panel, motor & prop so that when it's time to write the check I am already resigned to coughing up the $. Oh and BTY your panel looks sharp. Robin Marks RV-4 Sold RV-6A 300 Hours RV-10 Full QB to be delivered this week. -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, July 07, 2006 9:58 AM Sort of, I saw a pic of the panel on Henkejen's kitlog site, e-mailed him to find out where he got it, then called Aerotronics, where I talked to Gary Wirrell, who offered to do a graphic layout to see if it would fit, (I think he was aiming at selling me more than just the panel), when he e-mailed back the layout that sort of sealed the deal. Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
Date: Jul 11, 2006
Robin: Our kit came with a perfectly serviceable panel made of aluminum, God's favorite material, included in the price! : ) TDT 40025 Painfully slowly working on wiring and firewall forward -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Tuesday, July 11, 2006 1:49 PM Deems, Can you give us the rough pricing on the panel and center console from Aerotronics? Less electronics... It helps me to start choking early on the panel, motor & prop so that when it's time to write the check I am already resigned to coughing up the $. Oh and BTY your panel looks sharp. Robin Marks RV-4 Sold RV-6A 300 Hours RV-10 Full QB to be delivered this week. -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, July 07, 2006 9:58 AM Sort of, I saw a pic of the panel on Henkejen's kitlog site, e-mailed him to find out where he got it, then called Aerotronics, where I talked to Gary Wirrell, who offered to do a graphic layout to see if it would fit, (I think he was aiming at selling me more than just the panel), when he e-mailed back the layout that sort of sealed the deal. Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: Here I go again - console finished
The Aerotronics panel is $600 (just the fiberglass portion), the Center console is something that I made myself, I have about $200-250 + into it for materials. Labor = priceless :-) Deems Davis # 406 Fuse/Finishing http://deemsrv10.com/ Robin Marks wrote: > >Deems, > Can you give us the rough pricing on the panel and center >console from Aerotronics? Less electronics... It helps me to start >choking early on the panel, motor & prop so that when it's time to write >the check I am already resigned to coughing up the $. Oh and BTY your >panel looks sharp. > >Robin Marks >RV-4 Sold >RV-6A 300 Hours >RV-10 Full QB to be delivered this week. > > > >-----Original Message----- >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis >Sent: Friday, July 07, 2006 9:58 AM > > >Sort of, I saw a pic of the panel on Henkejen's kitlog site, e-mailed >him to find out where he got it, then called Aerotronics, where I talked > >to Gary Wirrell, who offered to do a graphic layout to see if it would >fit, (I think he was aiming at selling me more than just the panel), >when he e-mailed back the layout that sort of sealed the deal. > >Deems Davis # 406 >Fuse >http://deemsrv10.com/ > > > > > > > > > ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: RV-10 Builders List / RV-10's to OSH / RV-10 Parking-Camping
Tim, Last year we had set 10:00 am each day as a time where any of the -10 guys could get together, we met in front of Van's tent. I was able to meet several of the group at that gathering, and ask questions and gather advice. Anybody want to repeat this this year? Perhaps we could meet in front of your plane? Also Cleveland Tool (Mike are you there?) had an ice cream social one evening at their site, which was another good group opportunity. Deems Davis # 406 Fuse http://deemsrv10.com/ Tim Olson wrote: > > With less than 2 weeks until OSH, I need to put out another > post regarding a few topics: > > * RV-10 Builder List > * RV-10's Flying to OSH > * RV-10 Parking / Camping at OSH > > BUILDERS LIST > ------------- > First, regarding the builder list. I'm both impressed with > the response, but also surprised. I'm impressed because > we got over 100 responses and people added on to the builder > list. Some from last year never responded with their info. > It was a bit of work, but the list has already made it possible > for a couple people to meet up who were in the same area. > I'm kind of surprised, because with 600+ kits sold, and only > getting just over 100 replies, that means that the huge > majority is unknown or at least non-responsive or possibly > not even watching any online groups. If the same ratio of > responders were to go to OSH in the remaining 500 builders, > we're going to have over 480 RV-10 builder at OSH this year!! > I'm also surprised that out of 35+ RV-10's flying, we only > have 7 for sure, and 9 possible listed as flying to OSH > on the list. Here I don't think we'll see 5X that number > show, but if the ratio holds true, we may see at least > a fair share of the 35. > > If you haven't put your name on the list, you can sign up > here. Remember that you can be on the builders list even > if you aren't going to OSH: > http://www.myrv10.com/osh.html > > Don't forget if you're going to OSH to list if you're bringing > kids. I'm really hoping we can have some gatherings of > families if it works out. > > Once you're on the list, you'll get an access code to the > complete list. To see a list without the contact info, > look here: http://www.myrv10.com/osh2/index.html > That one may be less up to date than the full list. > > I think the builders who are on the list would tell you that > there are nice things about being part of the community. > > > FLYING TO OSH > ------------- > If you're flying your completed RV-10 to OSH, please try > to put your name on the list....for a couple good reasons. > > A) So the other builders can get pumped up a bit > B) Because the EAA really wants/needs to know our numbers for > space reasons. (see below) > > If you're flying from a Westward direction, or even if > you want to join in and are coming from the East or South, > I'd like to invite you to meet me at KLUM for the flight > over. I am currently planning to fly in Monday a.m., but > if the overwhelming majority wanted to go Sunday night, > I might be swayed. Fuel is currently running $3.609 on > our field, so it's a *more* economical fuel stop. > > > PARKING/CAMPING at OSH > ---------------------- > After some initial confusion over who was in control of parking > our planes, I got in contact with Jeff Point, who has it all > figured out. He's requesting as complete and accurate of > a -10 count as we can get, and whether they will be camping or > parking. They are making some larger sized spaces available for > our larger planes and they really need to know what to allow. > I will use the RV-10 builders list to give him the final > headcount that I come up with, and he's hoping to use that, plus > some good estimation skills to allow enough space. If you're > bringing a -10, it will help "guarantee" (there is no such thing) > that an attempt at space is left. The lots we park and camp in > are notoriously tight on space. > > Here is a note from Jeff: > --- > "We finally got the RV-10 arrangements figured out. We were up > at Oshkosh last week taking measurements etc for how we are going > to lay out the field this year. It's going to be differenet from > last year in several respects. > > The RV-10 campers will be as previously discussed, in their own row > on the east end of the Homebuilt camping area. Those arrangements > haven't changed from what you and Kreth worked out. Just as a > reminder, anyone who parks in the camping area will be assessed the > $18/ day camping fee, whether they pitch a tent or not. Anyone > parked in this area but not camping will be asked to park elsewhere. > This real estate is just to scarce, in the camping area. > > The RV-10 parking area (non-camping) will not be adjacent to the > campers. It will be where it was last year, at the east end of the > RV parking area, just west of the north commercial displays (where > Van's tent it.) RV-10ers who are not camping should display the > HBP sign to all the ornage vests that they see. The welcome > wagon service can give rides from the parking areas to Camp > Scholler, the bus terminal, etc. to anyone who is parking and > staying elsewhere. > > Any other questions feel free to contact me. I trust that you'll > get this info out to the RV-10 community. > > Jeff" > --- > > So there you have it folks, the requests are out there. I may > post one more reminder next week, but it's so close to OSH now > that my mind is wandering off daydreaming a lot....so I > may miss that one. ;) > ________________________________________________________________________________
Date: Jul 11, 2006
Date: Jul 11, 2006
Date: Jul 11, 2006
Date: Jul 11, 2006
Tim, I've been thinking about doing something similar. The aluminum may be easier to finish off with the materials Abby supplys as well. Do you have any dimensions or pic's? Rick S. 40185 ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: AL Center Console
Tim Dawson-Townsend wrote: > > > We made an AL center console from the panel down to the tunnel and it's > got room for an SL15, SL30, GX60, and a GTX330 transponder, so there > should be room for such things . . . > > TDT > 40025 > I would be interested in seeing pics of that if you have them. This is the route I was planning on taking for a center console. -Sean #40303 (Kit moved to Illinois, me still in AZ, obviously no work getting done) ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Jul 11, 2006
Subject: RV-10 Builders List / RV-10's to OSH / RV-10 Parking-Camping
I second the thought about a daily meeting time/place. It was very convenient way to sync up. It's not necessary for everybody to meet everyday, but nice to have a prearranged meeting. Bob #40105 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Tuesday, July 11, 2006 1:16 PM Parking-Camping Tim, Last year we had set 10:00 am each day as a time where any of the -10 guys could get together, we met in front of Van's tent. I was able to meet several of the group at that gathering, and ask questions and gather advice. Anybody want to repeat this this year? Perhaps we could meet in front of your plane? Also Cleveland Tool (Mike are you there?) had an ice cream social one evening at their site, which was another good group opportunity. Deems Davis # 406 Fuse http://deemsrv10.com/ Tim Olson wrote: > > With less than 2 weeks until OSH, I need to put out another > post regarding a few topics: > > * RV-10 Builder List > * RV-10's Flying to OSH > * RV-10 Parking / Camping at OSH > > BUILDERS LIST > ------------- > First, regarding the builder list. I'm both impressed with > the response, but also surprised. I'm impressed because > we got over 100 responses and people added on to the builder > list. Some from last year never responded with their info. > It was a bit of work, but the list has already made it possible > for a couple people to meet up who were in the same area. > I'm kind of surprised, because with 600+ kits sold, and only > getting just over 100 replies, that means that the huge > majority is unknown or at least non-responsive or possibly > not even watching any online groups. If the same ratio of > responders were to go to OSH in the remaining 500 builders, > we're going to have over 480 RV-10 builder at OSH this year!! > I'm also surprised that out of 35+ RV-10's flying, we only > have 7 for sure, and 9 possible listed as flying to OSH > on the list. Here I don't think we'll see 5X that number > show, but if the ratio holds true, we may see at least > a fair share of the 35. > > If you haven't put your name on the list, you can sign up > here. Remember that you can be on the builders list even > if you aren't going to OSH: > http://www.myrv10.com/osh.html > > Don't forget if you're going to OSH to list if you're bringing > kids. I'm really hoping we can have some gatherings of > families if it works out. > > Once you're on the list, you'll get an access code to the > complete list. To see a list without the contact info, > look here: http://www.myrv10.com/osh2/index.html > That one may be less up to date than the full list. > > I think the builders who are on the list would tell you that > there are nice things about being part of the community. > > > FLYING TO OSH > ------------- > If you're flying your completed RV-10 to OSH, please try > to put your name on the list....for a couple good reasons. > > A) So the other builders can get pumped up a bit > B) Because the EAA really wants/needs to know our numbers for > space reasons. (see below) > > If you're flying from a Westward direction, or even if > you want to join in and are coming from the East or South, > I'd like to invite you to meet me at KLUM for the flight > over. I am currently planning to fly in Monday a.m., but > if the overwhelming majority wanted to go Sunday night, > I might be swayed. Fuel is currently running $3.609 on > our field, so it's a *more* economical fuel stop. > > > PARKING/CAMPING at OSH > ---------------------- > After some initial confusion over who was in control of parking > our planes, I got in contact with Jeff Point, who has it all > figured out. He's requesting as complete and accurate of > a -10 count as we can get, and whether they will be camping or > parking. They are making some larger sized spaces available for > our larger planes and they really need to know what to allow. > I will use the RV-10 builders list to give him the final > headcount that I come up with, and he's hoping to use that, plus > some good estimation skills to allow enough space. If you're > bringing a -10, it will help "guarantee" (there is no such thing) > that an attempt at space is left. The lots we park and camp in > are notoriously tight on space. > > Here is a note from Jeff: > --- > "We finally got the RV-10 arrangements figured out. We were up > at Oshkosh last week taking measurements etc for how we are going > to lay out the field this year. It's going to be differenet from > last year in several respects. > > The RV-10 campers will be as previously discussed, in their own row > on the east end of the Homebuilt camping area. Those arrangements > haven't changed from what you and Kreth worked out. Just as a > reminder, anyone who parks in the camping area will be assessed the > $18/ day camping fee, whether they pitch a tent or not. Anyone > parked in this area but not camping will be asked to park elsewhere. > This real estate is just to scarce, in the camping area. > > The RV-10 parking area (non-camping) will not be adjacent to the > campers. It will be where it was last year, at the east end of the > RV parking area, just west of the north commercial displays (where > Van's tent it.) RV-10ers who are not camping should display the > HBP sign to all the ornage vests that they see. The welcome > wagon service can give rides from the parking areas to Camp > Scholler, the bus terminal, etc. to anyone who is parking and > staying elsewhere. > > Any other questions feel free to contact me. I trust that you'll > get this info out to the RV-10 community. > > Jeff" > --- > > So there you have it folks, the requests are out there. I may > post one more reminder next week, but it's so close to OSH now > that my mind is wandering off daydreaming a lot....so I > may miss that one. ;) > ________________________________________________________________________________
Date: Jul 11, 2006
Deems, Tim et al. I'd love to meet with you folks during KOSH, I'm going there with my son and am still in the lurking stage...the J 5 is going very slowly...want to get this down the road before jumping into the 10...hard to have two projects! Patrick Scott 610-745-6057 ________________________________________________________________________________
Date: Jul 11, 2006
Subject: B&C SD-20 and Oil Filter Adapter Update
I've been negligent in providing an update to the interference issue between the subject components. There are actually 2 solutions: If you need these two items to play together within the next 6-8 weeks then you need the SD-20S version of the alternator and a "clocking adapter" to rotate the alternator 45 degrees on the vacuum pad. The SD-20S version is 5/8" shorter than the regular SD-20 to account for the 5/8" depth of the clocking adapter. The 45 degree rotation largely solves the interference problem, balance of issue is resolved by changing a bolt to a cap head screw on one corner of the filter adapter. This solution was provided to an RV-10 builder someplace in Oregon that needed a fix immediately to keep a scheduled date with a paint shop. Long term solution is that B&C is going to manufacture a =BE" spacer and new shear coupling for their SD-20 alternator which also solves the interference issue. Simply moving the alternator back solves the problem. People that want to use both products would simply order the additional spacer (replacement studs for the vacuum pad would be included). This is what B&C sees as the preferred solution. Delay time is due to tooling and manufacturing lead times. I've elected to go with the final solution and will report back when it's installed. What a great company to work with! Bob #40105 FWF - fighting with baffling... ________________________________________________________________________________
Date: Jul 11, 2006
Subject: RE: consoles
I'll dig out some pics tonight. Unfortunately, we didn't really record the dimensions. We just sort of did it on the fly to fit. Hey, I just found one picture here at work: TDT 40025 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sent: Tuesday, July 11, 2006 2:48 PM Tim, I've been thinking about doing something similar. The aluminum may be easier to finish off with the materials Abby supplys as well. Do you have any dimensions or pic's? Rick S. 40185 ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jul 11, 2006
Bob: Thanks for the leg work on this. Just to clarify, the preferred option #2 involves no change to the oil filter adaptor, just the SD-20 mount? (So I can go ahead and mount that and wait on the alternator?) Thanks, TDT 40025 ________________________________ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Tuesday, July 11, 2006 3:16 PM I've been negligent in providing an update to the interference issue between the subject components. There are actually 2 solutions: If you need these two items to play together within the next 6-8 weeks then you need the SD-20S version of the alternator and a "clocking adapter" to rotate the alternator 45 degrees on the vacuum pad. The SD-20S version is 5/8" shorter than the regular SD-20 to account for the 5/8" depth of the clocking adapter. The 45 degree rotation largely solves the interference problem, balance of issue is resolved by changing a bolt to a cap head screw on one corner of the filter adapter. This solution was provided to an RV-10 builder someplace in Oregon that needed a fix immediately to keep a scheduled date with a paint shop. Long term solution is that B&C is going to manufacture a =BE" spacer and new shear coupling for their SD-20 alternator which also solves the interference issue. Simply moving the alternator back solves the problem. People that want to use both products would simply order the additional spacer (replacement studs for the vacuum pad would be included). This is what B&C sees as the preferred solution. Delay time is due to tooling and manufacturing lead times. I've elected to go with the final solution and will report back when it's installed. What a great company to work with! Bob #40105 FWF - fighting with baffling... ________________________________________________________________________________
Date: Jul 11, 2006
Deems, Make sure when you redo those sticks that you get enough aft stick if your going to move the grip back. If I recall on my flight, darn near full aft stick was needed on the flare so make sure "you" meaning your body doesn't stop that from happening. How much forward motion have you lost with the stick hitting the panel? Does it hit the elevator stops? Like you, my HS is not mounted yet to check but someone may be able to tell you how far forward from plumb the stick moves before hitting the stop. Besides you will only need full down for the outside loop. ;) Rick S. 40185 ________________________________________________________________________________
Date: Jul 11, 2006
Tim, Correct. Bill said that you might need to make sure that the lower right bolt on the OFA has the flat oriented correctly but he wants to test fit the final production stuff to make sure. If there's an issue they'll send out a cap head screw to replace that single bolt. BTW, very nice job on the center console - I might have to duplicate... Bob _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend Sent: Tuesday, July 11, 2006 2:25 PM Bob: Thanks for the leg work on this. Just to clarify, the preferred option #2 involves no change to the oil filter adaptor, just the SD-20 mount? (So I can go ahead and mount that and wait on the alternator?) Thanks, TDT 40025 _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Tuesday, July 11, 2006 3:16 PM I've been negligent in providing an update to the interference issue between the subject components. There are actually 2 solutions: If you need these two items to play together within the next 6-8 weeks then you need the SD-20S version of the alternator and a "clocking adapter" to rotate the alternator 45 degrees on the vacuum pad. The SD-20S version is 5/8" shorter than the regular SD-20 to account for the 5/8" depth of the clocking adapter. The 45 degree rotation largely solves the interference problem, balance of issue is resolved by changing a bolt to a cap head screw on one corner of the filter adapter. This solution was provided to an RV-10 builder someplace in Oregon that needed a fix immediately to keep a scheduled date with a paint shop. Long term solution is that B&C is going to manufacture a =BE" spacer and new shear coupling for their SD-20 alternator which also solves the interference issue. Simply moving the alternator back solves the problem. People that want to use both products would simply order the additional spacer (replacement studs for the vacuum pad would be included). This is what B&C sees as the preferred solution. Delay time is due to tooling and manufacturing lead times. I've elected to go with the final solution and will report back when it's installed. What a great company to work with! Bob #40105 FWF - fighting with baffling... ________________________________________________________________________________
Date: Jul 11, 2006
Another good suggestion, I think I'll remount the HS and an elevator to find out if this is a real or perceived problem. (The size of my gut is real, the amount of elevator throw is perceived. :-D THANKS Deems Rick wrote: > >Deems, > >Make sure when you redo those sticks that you get enough aft stick if your going to move the grip back. If I recall on my flight, darn near full aft stick was needed on the flare so make sure "you" meaning your body doesn't stop that from happening. How much forward motion have you lost with the stick hitting the panel? Does it hit the elevator stops? Like you, my HS is not mounted yet to check but someone may be able to tell you how far forward from plumb the stick moves before hitting the stop. > >Besides you will only need full down for the outside loop. ;) > > >Rick S. >40185 > > > > > > > > > ________________________________________________________________________________
Date: Jul 11, 2006
I'm sure this decision is too late for you Deems, as you made your beautiful console, but, for the other list people.... I am finding that the quadrant control is very smooth and precise and I can pinpoint my RPM and MP much closer using the quadrant than I did with N220RV with the vernier for my transition training. I know vernier is normally the way to go for precise control, but I can definitely tell you that I had a much-less-than-perfect experience with the vernier in that RV-10, but from day one I've had great precision with mine. So don't let the lack of smooth and precise power/mix/prop control steer you away from a quadrant....I found it to be the opposite. I'm sure that things such as where the linkage attaches to the lever, and the quality of the control can have a huge factor in this, but this quadrant is great....far better than the one that was in my Beech. If anyone has any doubts, just come on over to KLUM on the weekend before OSH and I'll let you do a little flying to see for yourself. You just have to help me get the bugs off it before I leave for the show. ;) Tim Olson - RV-10 N104CD - Flying Deems Davis wrote: > > I'm going w/ the vernier controls, I had the 'big plane feel' on 2 > Barons with the quadrants and while it made me feel more like an airline > jockey, I always missed the precision of the vernier controls > (especially on landings) that I had w/ the Bonanza, so I'm swallowing my > ego and going back to the vernier controls. There's plenty of room for > transponder,autopilot/switches or ? in the console, in fact the past > couple of day's I've been noodling around the center stack arrangement, > the radios and transponder are over 11" deep and not withstanding the > mod that I already made to the fwd fuse ribs, will require a cutout in > the sub-panel to allow for their depth. This has some influence over > where the various components get placed in the stack, so I've been doing > the 'cut-n-paste' routine with the various components to see which works > best. I'm also reconsidering the 3 steam gages. John Cox pointed out > that since they are 'back-up' instruments that they should not occupy > such expensive panel real estate (ie. they are high and prominent). so > I've been experimenting there also, additionally, I'm thinking about > scraping the steam gages and putting in a Dynon -10A for back-up, for > slightly more $'s I get 7 more instruments. Decisions, decisions, > decisions..... > > btw Rick, Thanks for the info re th CH sticks Kevin sent me a sample for > a test fit, and it turns out that they do indeed interfere with the > panel in the most fwd position, BUT, I like them sooooooo... much I'm > looking for a welder that can cut and reweld the sticks so that the > upright portion is about 20 degrees back, which should give me the > clearance I need. > > > Deems Davis # 406 > Fuse > http://deemsrv10.com/ > Rick wrote: > >> >> Deems, >> >> Are you going with the throttle quadrant? And is there room to place >> switches and or maybe the trransponder in your console? >> >> Rick S. >> 40185 >> ________________________________________________________________________________
Date: Jul 11, 2006
Tim, thanks for the continueing hard work. First, when talking to Jeff Point get to an agreement that unannounced RV-10 arrivals are not going to be corralled with those who showed the courtesy of posting in advance. Those in advance get better placement and the others go "At Large". As a former producer of Air Shows the only thing more disgusting are the guys who sneak in, say they are with a show to get free fuel and bennies (never to have announced and never participating). They should be in the general North 40 parking masses and learn the value of the school bus shuttle. There is plenty of room for every flying RV-10 but they should at least line up parking in advance. I am ready to eat my words, but I still feel strongly that 50 will be flying by OSH and 20 will be on the ground there. It is tragic that so many remain lurkers or felt there was little value in being part of the Matronics Advantage. Now if you can just work on the Wisconsin heat, humidity and thundercloud activity too. John Cox -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Tuesday, July 11, 2006 10:45 AM Parking-Camping With less than 2 weeks until OSH, I need to put out another post regarding a few topics: * RV-10 Builder List * RV-10's Flying to OSH * RV-10 Parking / Camping at OSH BUILDERS LIST ------------- First, regarding the builder list. I'm both impressed with the response, but also surprised. I'm impressed because we got over 100 responses and people added on to the builder list. Some from last year never responded with their info. It was a bit of work, but the list has already made it possible for a couple people to meet up who were in the same area. I'm kind of surprised, because with 600+ kits sold, and only getting just over 100 replies, that means that the huge majority is unknown or at least non-responsive or possibly not even watching any online groups. If the same ratio of responders were to go to OSH in the remaining 500 builders, we're going to have over 480 RV-10 builder at OSH this year!! I'm also surprised that out of 35+ RV-10's flying, we only have 7 for sure, and 9 possible listed as flying to OSH on the list. Here I don't think we'll see 5X that number show, but if the ratio holds true, we may see at least a fair share of the 35. If you haven't put your name on the list, you can sign up here. Remember that you can be on the builders list even if you aren't going to OSH: http://www.myrv10.com/osh.html ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: RE: consoles
Very Nice! Jim C =========================================================== I'll dig out some pics tonight. Unfortunately, we didn't really record the dimensions. We just sort of did it on the fly to fit. Hey, I just found one picture here at work: TDT 40025 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sent: Tuesday, July 11, 2006 2:48 PM Tim, I've been thinking about doing something similar. The aluminum may be easier to finish off with the materials Abby supplys as well. Do you have any dimensions or pic's? Rick S. 40185 =================================== =================================== =================================== =================================== =========================================================== ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: Flap position sensor
Here is how we've mounted the one in N184JM. The push rod comes from a remote controlled airplane store. Grumpy #40404 60 days or less to first flight! ________________________________________________________________________________
Date: Jul 11, 2006
John, Your not far off...I checked the FAA data base and there were 58 RV-10's registered, I think, there were two pages of them, some may be waiting for a DAR??? But none the less, almost 60 of them in the database. Rick S. 40185 ________________________________________________________________________________
Date: Jul 11, 2006
I only left about 1.50 inches on the stick, the rest is all CH grip. Rick S. 40185 ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Instruments for Sale
I am re-doing my RV-4 instrument panel and I am selling my old instruments. Below is what I have for sale, first come first serve..... The rest will go to eBay. Also, if you feel the price is too high, feel free to make an offer, I'll take the highest offer or I'll eBay them. All instruments were new 168 hours ago, except the Dynon has less than 100 hours and the KX155, KI209, and the KT76A were used when I purchased them. Please respond off list to n223rv (at) wolflakeairport.net. Pictures available upon request, but I will most likely only be able to respond in the evenings. All prices include FedEx ground shipping. Item Current Price Asking Price UMA 1.25" CHT gauge $117.95 $82.00 UMA 1.25" Oil Pressure gauge $118.95 $83.00 UMA 1.25" Ammeter gauge $154.95 $108.00 UMA 1.25" EGT gauge $117.95 $82.00 UMA 1.25" Fuel Pressure gauge $118.95 $83.00 UMA 1.25" Volt Meter gauge $118.95 $83.00 UMA 1.25" Oil Temp gauge $118.95 $83.00 Price for all 7 gauges $866.65 $570.00 King KX155 14V w/ G/S $2,000.00 King KI209 Indicator (VOR/Glideslope Indicator) $750.00 King KT76A 14V Transponder $750.00 Garmin 295, color GPS, all original accy's, extra power cords, manuals, and original box $625.00 Comant Diplexer CI 1125 (Dual VOR and Dual G/S to one antenna) $125.95 $75.00 Van's Fuel Gauges (2) $70.00 $45.00 NavAid Autopilot $1,300.00 $650.00 Smart Coupler II LE $249.00 $200.00 UMA Tachometer PN TU 3041 and 19-806-11G (odometer showing 196 hours) $198.75 $110.00 UMA Airspeed PN 16-310-241D $160.00 $125.00 Van's Manifold Pressure Gauge (gauge only, no sender) $73.40 $25.00 Falcon Altimeter PN ALT20INF-3N 0-20K' $196.95 $130.00 Dynon D10 w/ magnetometer,OAT sensor, and flush mount $2,285.00 $1,500.00 Westach Carb Mix and OAT Temp gauge PN 2DA3-8 $83.25 $50.00 EI Fuel Flow Gauge (gauge only, no sender) $518.00 $310.00 P.S. - I'm no scammer, feel free to read my feedback on eBay (user ID mkraus01) Also, anyone is welcome to fly into my house and pick up the instruments, I live at 26W near Jackson, Michigan. Look us up on AirNav.com or just come visit sometime. I love guests and I have a flying RV-4 and building an RV-10. Thanks, Mike Kraus ________________________________________________________________________________
Date: Jul 11, 2006
You may well be right Rick, but also unless I am mistaken as soon as someone applies (not reserves) for the N number it goes on the registry. So there might be lots of folks who have applied for thier number but still have a ways to go before flight. When I built the 4 I had the number a year early. Dick Sipp 40065 110DV reserved top & wiring ----- Original Message ----- Sent: Tuesday, July 11, 2006 10:35 PM > > John, > > Your not far off...I checked the FAA data base and there were 58 RV-10's > registered, I think, there were two pages of them, some may be waiting for > a DAR??? But none the less, almost 60 of them in the database. > > Rick S. > 40185 > > > ________________________________________________________________________________
Date: Jul 12, 2006
No actually it is a two step process. My N number N49CX is reserved but you will not find it on the registry because I have not requested the Airworthiness Inspection yet. John -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Sipp Sent: Tuesday, July 11, 2006 7:56 PM You may well be right Rick, but also unless I am mistaken as soon as someone applies (not reserves) for the N number it goes on the registry. So there might be lots of folks who have applied for thier number but still have a ways to go before flight. When I built the 4 I had the number a year early. Dick Sipp 40065 110DV reserved top & wiring ----- Original Message ----- Sent: Tuesday, July 11, 2006 10:35 PM > > John, > > Your not far off...I checked the FAA data base and there were 58 RV-10's > registered, I think, there were two pages of them, some may be waiting for > a DAR??? But none the less, almost 60 of them in the database. > > Rick S. > 40185 > > > ________________________________________________________________________________
Date: Jul 12, 2006
It's a three-step process: 1) Reserve N-number. There airplane is not yet "registered", but the number is recorded in the "registry" as reserved. If fact, there may not even be an aircraft, it might just be someone hoarding numbers. 2) Register your aircraft. 3) Get your inspection. Don't wait until you're ready for an inspection to submit your registration, or you will be cooling your heels for 3-4 weeks while the FAA processes it. No inspection without an approved registration form in hand. TDT 40025 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Wednesday, July 12, 2006 11:12 AM No actually it is a two step process. My N number N49CX is reserved but you will not find it on the registry because I have not requested the Airworthiness Inspection yet. John -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Sipp Sent: Tuesday, July 11, 2006 7:56 PM You may well be right Rick, but also unless I am mistaken as soon as someone applies (not reserves) for the N number it goes on the registry. So there might be lots of folks who have applied for thier number but still have a ways to go before flight. When I built the 4 I had the number a year early. Dick Sipp 40065 110DV reserved top & wiring ----- Original Message ----- Sent: Tuesday, July 11, 2006 10:35 PM > > John, > > Your not far off...I checked the FAA data base and there were 58 RV-10's > registered, I think, there were two pages of them, some may be waiting for > a DAR??? But none the less, almost 60 of them in the database. > > Rick S. > 40185 > > > ________________________________________________________________________________
Date: Jul 12, 2006
Hello, I joined this mailing list for RV 10 Builders and it is huge, 200+ emails a day. Do you have a link to the unsubcribe page, it way to much. Thanks for your help Future RV 10 Builder Deems Davis wrote: Another good suggestion, I think I'll remount the HS and an elevator to find out if this is a real or perceived problem. (The size of my gut is real, the amount of elevator throw is perceived. :-D THANKS Deems Rick wrote: > >Deems, > >Make sure when you redo those sticks that you get enough aft stick if your going to move the grip back. If I recall on my flight, darn near full aft stick was needed on the flare so make sure "you" meaning your body doesn't stop that from happening. How much forward motion have you lost with the stick hitting the panel? Does it hit the elevator stops? Like you, my HS is not mounted yet to check but someone may be able to tell you how far forward from plumb the stick moves before hitting the stop. > >Besides you will only need full down for the outside loop. ;) > > >Rick S. >40185 > > > > > > > > > Please Visit http://www.eatonindiana.net ________________________________________________________________________________
Date: Jul 13, 2006
Subject: QB FUSE VANS
Guys if anyone has had problems with there QB fuse could they send an email to me VHMUM at bigpond.com Thanks Chris ________________________________________________________________________________
Date: Jul 12, 2006
How does one go about reserving an N number? Jim > > From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com> > Date: 2006/07/12 Wed AM 11:25:08 EDT > To: > Subject: RE: RV10-List: RV-10 Builders List / RV-10's to OSH / RV-10 > > > > It's a three-step process: > 1) Reserve N-number. There airplane is not yet "registered", but the > number is recorded in the "registry" as reserved. If fact, there may > not even be an aircraft, it might just be someone hoarding numbers. > 2) Register your aircraft. > 3) Get your inspection. > > Don't wait until you're ready for an inspection to submit your > registration, or you will be cooling your heels for 3-4 weeks while the > FAA processes it. No inspection without an approved registration form > in hand. > > TDT > 40025 > > -----Original Message----- > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox > Sent: Wednesday, July 12, 2006 11:12 AM > > > No actually it is a two step process. My N number N49CX is reserved but > you will not find it on the registry because I have not requested the > Airworthiness Inspection yet. > > John > > -----Original Message----- > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Sipp > Sent: Tuesday, July 11, 2006 7:56 PM > > > You may well be right Rick, but also unless I am mistaken as soon as > someone applies (not reserves) for the N number it goes on the registry. > So there might be lots of folks who have applied for thier number but > still have a ways to go before flight. When I built the 4 I had the > number a year early. > > Dick Sipp > 40065 110DV reserved > top & wiring > ----- Original Message ----- > Sent: Tuesday, July 11, 2006 10:35 PM > > > > > > John, > > > > Your not far off...I checked the FAA data base and there were 58 > RV-10's > > registered, I think, there were two pages of them, some may be waiting > for > > a DAR??? But none the less, almost 60 of them in the database. > > > > Rick S. > > 40185 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jul 12, 2006
Subject: N-Number Reservations
Go here: http://www.faa.gov/licenses_certificates/aircraft_certification/aircraft _registry/n_numbers/ Michael Sausen RV-10 #352 Working on Fuselage PS: Look I changed the subject and even trimmed it down. :-D -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gorejr(at)bellsouth.net Sent: Wednesday, July 12, 2006 4:06 PM How does one go about reserving an N number? Jim ________________________________________________________________________________
Date: Jul 12, 2006
Subject: instrument sub-panel, fwd fuse and cabin cover questions
I'd like any input regarding the installation of the above items. I don't bend like I used to and want to avoid as many contortions as possible, to that end I'd like to leave the fuse opened up as long as possible. 1. What things can I go ahead and attach to the instrument sub-panel while it's 'transportable' i.e not riveted to the Fuse? a. Other than the modifications to open up areas for avionics mounting, what other access holes have builders put in the sub-panel? b. has anybody installed anything on the FORWARD side of the sub-panel? What? c. Any other recommendations for sub-panel work before installing the upper fwd fuse? 2. How long can I leave the Cabin cover drilled/clecoed' before riveting it to the fuse? can the doors be(accurately) fit to the cabin w/ the cover only clecoed vs riveted? 3. Is it easier to install the windows with the cover on or off of the Fuse? I appreciate any input you might have. THANKS Deems Davis # 406 Finishing Fuse / Finishing http://deemsrv10.com/ ________________________________________________________________________________
Date: Jul 12, 2006
Subject: RV-10 vs RV-9 or 7 or 6 build time
I would like comments from any repeat builders as to the comparison of build times for the RV-10 verses any other previous RV they built. Comments like 20% more or half as much would be helpful. whd721(at)msn.com ________________________________________________________________________________
Date: Jul 12, 2006
Subject: Re: instrument sub-panel, fwd fuse and cabin cover questions
Deems Davis wrote: > > I'd like any input regarding the installation of the above items. I > don't bend like I used to and want to avoid as many contortions as > possible, to that end I'd like to leave the fuse opened up as long as > possible. > > 1. What things can I go ahead and attach to the instrument sub-panel > while it's 'transportable' i.e not riveted to the Fuse? > a. Other than the modifications to open up areas for avionics > mounting, what other access holes have builders put in the sub-panel? I put a larger one in. No huge reason, but it ended up coming in handy to use as arm and vision access while mounting the Lightspeed and WSI stuff on the aft side of the upper firewall. I put a bunch ov various holes in the subpanel for wire passthroughs. > b. has anybody installed anything on the FORWARD side of the > sub-panel? What? I have an E-Bus schottky diode there, in a protective case. And, I put the stall buzzer there too. > c. Any other recommendations for sub-panel work before > installing the upper fwd fuse? > > 2. How long can I leave the Cabin cover drilled/clecoed' before riveting > it to the fuse? can the doors be(accurately) fit to the cabin w/ the > cover only clecoed vs riveted? > I think you'll naturally feel when you need to have it riveted by just working along through the plans. I can't see why you wouldn't be able to fit the doors without riveted, but you should probably install the countersunk bolts before fitting the doors so that everything is at least in the exact place. > 3. Is it easier to install the windows with the cover on or off of the > Fuse? > I don't know. It may be easier to install the windows with it off, but it may make it harder to work with the canopy when putting it on, and it would sure not be fun if you dislodged or scratched them in some freak happening while reattaching the canopy. > I appreciate any input you might have. > You're getting to the point where some of the things start to get a little tougher for the tall/older/slightly oversized. I fit into a couple of those categories well, and one slightly. ;) I wired my panel almost fully while installed. Not that I think that's best....I had my reasons, but I can definitely see benefits of doing it out of the plane too. But anyway, you're reaching the point where you start physically suffering a bit more in the build. I would just say try to have anything placed on the firewall inside that you intend to leave there. Ground tab blocks, large wire passthroughs, and anything like that. You can actually attach the canopy and leave the forward fuse off for a while if you wish. I think I did the canopy on mine before the forward fuse, and just slid it in place later. So I think it's plenty do-able. It won't be too long though after where you're at and you'll be putting a windshield in, and other things, so access will definitely get harder. You're coming up on what I think is about the 1/2 way point of the kit in terms of hours pretty soon...about the time you put the windshield in. So now things start to get both harder, and more fun. Just hang in there. One thing you DON'T want to attach until the last minute is the sticks. Leave the seats out as long as possible too. That way you can lay a board down over the seat area and lay on it. Tim > THANKS > > > Deems Davis # 406 > Finishing Fuse / Finishing > http://deemsrv10.com/ > > ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Re: instrument sub-panel,long
Deems: I have been thinking the same way you have. I want to complete as much of the instrument panel and electrical installation as possible PRIOR to riveting on the forward top skin and the cabin cover. I have done the inittial trial fitting of the cabin cover with the forward skin cleocoed on and stopped there. I have a subcontracted Aerotronics panel and so have the advantage that it was completed and operationally tested on the bench by them. I also had them do several optional harnesses and subsystems like the stick grips, autopilot harnesses, elt harness, interphone etc. The panel is supplied with multiple cannon plug type connectors that you complete by installing airframe wires into the panel mating plug. The step by step documentation is provided. Completing the airframe side of the installation has been easy with forward top skin off, cabin top off, and the fuselage at floor level. Nearly all of the many miscellaneous little boxes (altitude encoder, Freeflight GPS sensor, AOA computer, lighting control boards, voltage regulator etc etc are mounted on the subpanel and longitudinal ribs. I found there is plenty of room. Thankfully most of these are connected with various size d-sub connectors at the unit. The Chelton displays were positioned to not conflict with the longitudinal rigs and there were only two minor cut-outs required to the sub panel. So...the plan is to complete everything including temporary hook up of the GPS antennas, roll the "canoe" out in the driveway, and functionally test everything I possibly can. Then the finished cables will be discounted, the panel removed, top skin riveted to the substructure and finally the panel will be reinstalled to the substructure ON THE BENCH and the hopefully the nearly finished assemble will be final riveted to the fuselage per the plans. Sounds confusing I know. Here are 3 pictures with most of the components mounted but the cables still loose; I'll try to remember to post a few more when its finished after OSH. This whole process works in my head, we'll see about actuality. Ideally from a system and electrical standpoint everything will be done and tested before the top, doors, or windows are finished. Hope it works. Apologies for the long post. Dick Sipp 40065 N110DV reserved ________________________________________________________________________________
Date: Jul 13, 2006
Thanks for breaking my day Tim :-< I am at the same point as Deems, and after 2.3 years and more than 1700hrs (Slow build), the reality of still being less than 1/2 way there is bit hard to deal with. I was really hoping to be done by this time next year. Ron 187 - finishing kit is somewhere in Oz. -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Tim Olson Sent: Thursday, 13 July 2006 1:35 PM questions Deems Davis wrote: > > I'd like any input regarding the installation of the above items. I > don't bend like I used to and want to avoid as many contortions as > possible, to that end I'd like to leave the fuse opened up as long as > possible. > > 1. What things can I go ahead and attach to the instrument sub-panel > while it's 'transportable' i.e not riveted to the Fuse? > a. Other than the modifications to open up areas for avionics > mounting, what other access holes have builders put in the sub-panel? I put a larger one in. No huge reason, but it ended up coming in handy to use as arm and vision access while mounting the Lightspeed and WSI stuff on the aft side of the upper firewall. I put a bunch ov various holes in the subpanel for wire passthroughs. > b. has anybody installed anything on the FORWARD side of the > sub-panel? What? I have an E-Bus schottky diode there, in a protective case. And, I put the stall buzzer there too. > c. Any other recommendations for sub-panel work before > installing the upper fwd fuse? > > 2. How long can I leave the Cabin cover drilled/clecoed' before riveting > it to the fuse? can the doors be(accurately) fit to the cabin w/ the > cover only clecoed vs riveted? > I think you'll naturally feel when you need to have it riveted by just working along through the plans. I can't see why you wouldn't be able to fit the doors without riveted, but you should probably install the countersunk bolts before fitting the doors so that everything is at least in the exact place. > 3. Is it easier to install the windows with the cover on or off of the > Fuse? > I don't know. It may be easier to install the windows with it off, but it may make it harder to work with the canopy when putting it on, and it would sure not be fun if you dislodged or scratched them in some freak happening while reattaching the canopy. > I appreciate any input you might have. > You're getting to the point where some of the things start to get a little tougher for the tall/older/slightly oversized. I fit into a couple of those categories well, and one slightly. ;) I wired my panel almost fully while installed. Not that I think that's best....I had my reasons, but I can definitely see benefits of doing it out of the plane too. But anyway, you're reaching the point where you start physically suffering a bit more in the build. I would just say try to have anything placed on the firewall inside that you intend to leave there. Ground tab blocks, large wire passthroughs, and anything like that. You can actually attach the canopy and leave the forward fuse off for a while if you wish. I think I did the canopy on mine before the forward fuse, and just slid it in place later. So I think it's plenty do-able. It won't be too long though after where you're at and you'll be putting a windshield in, and other things, so access will definitely get harder. You're coming up on what I think is about the 1/2 way point of the kit in terms of hours pretty soon...about the time you put the windshield in. So now things start to get both harder, and more fun. Just hang in there. One thing you DON'T want to attach until the last minute is the sticks. Leave the seats out as long as possible too. That way you can lay a board down over the seat area and lay on it. Tim > THANKS > > > Deems Davis # 406 > Finishing Fuse / Finishing > http://deemsrv10.com/ > > ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jul 12, 2006
I approached the fwd upper fuselage, panel, and cabin in the following order and in hindsight it worked well. Before the panel & fwd upper fuse were riveted to the lower fuselage I installed avionics, glass PFD, autopilot, engine monitor, voltage regulator, switch, and map box while the unit was on the bench. Three wire bundles [engine bay, left side run, right side run] were collected with long tails and each wire labeled with masking tape. A 37pin Amp plug was mounted to the sub-panel and all panel wiring passes through this plug. My fuse box, from West Marine, was installed on the sub-panel with only three fuses on the outer panel to shed load during an electrical emergency. Rivet the unit to the fuselage and run the bundles into the engine compartment and down the left and right sides. Now two work areas can be addressed independently - engine compartment and cabin. The wires on the side were either spliced or routed to one of my three connectors [L & R wing, tail]. The cabin was permanently installed next. I do not think the doors can be fitted properly unless the fiberglass cabin is in its final resting place. The doors are seated into the cabin opening by beveling both/either edges and small changes in the outer shell can have big effects on the door fit. Before I cemented the front windscreen, I installed the GPS antenna far forward in line with the co-pilot. Note that I also left vertical space so the antenna could be replaced with a newer antenna that supports WAAS. Windows, cabin doors, and FWF were next. Last item riveted were the two top tail skins. Leaving this to last was a big help routing wires through the tail. Bill DeRouchey - billderou(at)yahoo.com N939SB, Kit #40029 Fly next week Deems Davis wrote: I'd like any input regarding the installation of the above items. I don't bend like I used to and want to avoid as many contortions as possible, to that end I'd like to leave the fuse opened up as long as possible. 1. What things can I go ahead and attach to the instrument sub-panel while it's 'transportable' i.e not riveted to the Fuse? a. Other than the modifications to open up areas for avionics mounting, what other access holes have builders put in the sub-panel? b. has anybody installed anything on the FORWARD side of the sub-panel? What? c. Any other recommendations for sub-panel work before installing the upper fwd fuse? 2. How long can I leave the Cabin cover drilled/clecoed' before riveting it to the fuse? can the doors be(accurately) fit to the cabin w/ the cover only clecoed vs riveted? 3. Is it easier to install the windows with the cover on or off of the Fuse? I appreciate any input you might have. THANKS Deems Davis # 406 Finishing Fuse / Finishing http://deemsrv10.com/ ________________________________________________________________________________
Date: Jul 13, 2006
I buit a -6 to the point of needing to hang engine/install avionics and am currently at the exact same place on the -10 so my perspective is the construction of the kit as Van's supplied. On the -6, I had roughly 2500 hours in and on the -10 I've got 1150 in. My guess is engine and avionics will be roughly the same between the two. Both kits were slow builds, the -6 was pre-punched emp/wings. Keep in mind that the experience gained bulding the -6 translated into substantially faster build time on the -10 with far fewer mistakes. Hope this helps. - Tom Gesele #40473 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of William DeLacey Sent: Wednesday, July 12, 2006 11:20 PM I would like comments from any repeat builders as to the comparison of build times for the RV-10 verses any other previous RV they built. Comments like 20% more or half as much would be helpful. whd721(at)msn.com ________________________________________________________________________________
Date: Jul 13, 2006
Deems, One of the local builders here didn't install the forward deck until he was a couple weeks from flying. Why? Thank a certain panel builder for their timely delivery. ;-) He had everything done, hung, installed except for the windscreen, cowl, and anything that would attach to the deck. Michael Sausen RV-10 #352 Working on Fuselage -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Wednesday, July 12, 2006 9:46 PM questions I'd like any input regarding the installation of the above items. I don't bend like I used to and want to avoid as many contortions as possible, to that end I'd like to leave the fuse opened up as long as possible. 1. What things can I go ahead and attach to the instrument sub-panel while it's 'transportable' i.e not riveted to the Fuse? a. Other than the modifications to open up areas for avionics mounting, what other access holes have builders put in the sub-panel? b. has anybody installed anything on the FORWARD side of the sub-panel? What? c. Any other recommendations for sub-panel work before installing the upper fwd fuse? 2. How long can I leave the Cabin cover drilled/clecoed' before riveting it to the fuse? can the doors be(accurately) fit to the cabin w/ the cover only clecoed vs riveted? 3. Is it easier to install the windows with the cover on or off of the Fuse? I appreciate any input you might have. THANKS Deems Davis # 406 Finishing Fuse / Finishing http://deemsrv10.com/ ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Jul 13, 2006
Bill, can you post photos of the connector locations. Your description was helpful. Thanks. John Testement HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com 40321 Richmond, VA Finish kit - gear legs and wheels _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey Sent: Thursday, July 13, 2006 12:56 AM questions I approached the fwd upper fuselage, panel, and cabin in the following order and in hindsight it worked well. Before the panel & fwd upper fuse were riveted to the lower fuselage I installed avionics, glass PFD, autopilot, engine monitor, voltage regulator, switch, and map box while the unit was on the bench. Three wire bundles [engine bay, left side run, right side run] were collected with long tails and each wire labeled with masking tape. A 37pin Amp plug was mounted to the sub-panel and all panel wiring passes through this plug. My fuse box, from West Marine, was installed on the sub-panel with only three fuses on the outer panel to shed load during an electrical emergency. Rivet the unit to the fuselage and run the bundles into the engine compartment and down the left and right sides. Now two work areas can be addressed independently - engine compartment and cabin. The wires on the side were either spliced or routed to one of my three connectors [L & R wing, tail]. The cabin was permanently installed next. I do not think the doors can be fitted properly unless the fiberglass cabin is in its final resting place. The doors are seated into the cabin opening by beveling both/either edges and small changes in the outer shell can have big effects on the door fit. Before I cemented the front windscreen, I installed the GPS antenna far forward in line with the co-pilot. Note that I also left vertical space so the antenna could be replaced with a newer antenna that supports WAAS. Windows, cabin doors, and FWF were next. Last item riveted were the two top tail skins. Leaving this to last was a big help routing wires through the tail. Bill DeRouchey - HYPERLINK "mailto:billderou(at)yahoo.com"billderou(at)yahoo.com N939SB, Kit #40029 Fly next week Deems Davis wrote: I'd like any input regarding the installation of the above items. I don't bend like I used to and want to avoid as many contortions as possible, to that end I'd like to leave the fuse opened up as long as possible. 1. What things can I go ahead and attach to the instrument sub-panel while it's 'transportable' i.e not riveted to the Fuse? a. Other than the modifications to open up areas for avionics mounting, what other access holes have builders put in the -- -- ________________________________________________________________________________
Date: Jul 13, 2006
1. What things can I go ahead and attach to the instrument sub-panel while it's 'transportable' i.e not riveted to the Fuse? a. Other than the modifications to open up areas for avionics mounting, what other access holes have builders put in the sub-panel? b. has anybody installed anything on the FORWARD side of the sub-panel? What? c. Any other recommendations for sub-panel work before installing the upper fwd fuse? Jesse: I just put in one big hole for the radio stack, then used the bottom of the sub-panel to hold adel clamps that all of my wires go through, then put holes and snap bushings in the sub-panel to route wires through to the firewall and down to the sides of the plane. I have my instrument cooling fan, power distribution bus block, MAP Sensor, Ammeter Shunt, and dimmer boards all on the sub-panel. That makes it really nice to work on the wiring just by removing the panel. Also, I have the crossbar under the instrument panel (although removeable with screws) there as an armrest if/when needed. In N256H we almost completely removed the sub-panel and then used angles to stiffen it back up, but then we had no good place to mount all of the things mentioned above. To each his own, but this worked great for us. 2. How long can I leave the Cabin cover drilled/clecoed' before riveting it to the fuse? can the doors be(accurately) fit to the cabin w/ the cover only clecoed vs riveted? Jesse: You can leave it there for as long as you want, but it will limit the amount of work that you can do. You may be able to fit the doors safely, but I don't know it I recommend it. Fitting the doors is a pretty important part. I guess, if you were to go ahead and bolt/screw the cabin top in where the door goes, then cleco it where all the pop rivets go, it should be pretty good. What are you trying to avoid by leaving it off. It is possible to install the upper forward fuse section after the cabin top is in place, although it is not quite as easy. 3. Is it easier to install the windows with the cover on or off of the Fuse? Jesse: I am sure it would be a fair bit easier with the cover off, but much safer with it on, because you really want to have it in the exact form that it will stay in before gluing the windows in IMHO. Hope this helps. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org W: 352-465-4545 C: 352-427-0285 -- ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Date: Jul 13, 2006
Subject: Re: RV-10 vs RV-9 or 7 or 6 build time
Compared to the RV-9A, the RV-10 kit is very similar. The instructions, however, are far superior so far. It took about 1500 hours to complete my RV-9A slow build. Given the larger size of the RV-10 I figure it will take about 25% more time. The quickbuild would save a lot of time, but I enjoy building. Mike Schipper RV-9A - N63MS - Flying RV-10 #40576 - Working on Empennage http://www.rvten.com On Jul 12, 2006, at 10:20 PM, William DeLacey wrote: > > I would like comments from any repeat builders as to the comparison > of build times for the RV-10 verses any other previous RV they > built. Comments like 20% more or half as much would be helpful. > > whd721(at)msn.com > ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Relative Value for Complete RV-10's?
As noted before I've been lurking absorbing the material before I actually make the plunge and get a RV-10 kit. One question I'd like to post to you here is what you think the relative value for a completed RV-10 would be if one was to sell their aircraft on the open market? I know that type of question would probably lead to many different answers since each airplane built is a little different from the next based on builder preferences and such. For example, one guy could build a strictly VFR machine while his buddy a few hangers away has a hard IFR capable machine. What I'm thinking is a moderate to high hp engine (235 to 260 hp) and probably light duty IFR capable (i.e. basic gauges with maybe one or two EFIS displays and engine monitor). If I can reasonably assure the household finance minister that I can get a good return on my investment, it might sway her towards my thinking. I've seen one RV-10 offered for $220,000 and a partially finished a/c for $175,000. I'd assume there hasn't been many sold since finished birds haven't been flying long, but any info from the list is helpful. Thanks. James K. Hovis ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Re: Relative Value for Complete RV-10's?
James, I have a 10 that is close to being done and have $125,000 invested in it and I have to sell it. I will sell it for $125,000. I0-540, MT prop, dual GRT EFIS, etc. The only thing left to purchase is upholstery and paint Phil 40122 888-583-5155 > > As noted before I've been lurking absorbing the material before I actually > make the plunge and get a RV-10 kit. One question I'd like to post to you > here is what you think the relative value for a completed RV-10 would be if > one was to sell their aircraft on the open market? I know that type of > question would probably lead to many different answers since each airplane > built is a little different from the next based on builder preferences and > such. For example, one guy could build a strictly VFR machine while his buddy > a few hangers away has a hard IFR capable machine. What I'm thinking is a > moderate to high hp engine (235 to 260 hp) and probably light duty IFR > capable ( i.e. basic gauges with maybe one or two EFIS displays and engine > monitor). If I can reasonably assure the household finance minister that I > can get a good return on my investment, it might sway her towards my > thinking. I've seen one RV-10 offered for $220,000 and a partially finished > a/c for $175,000. I'd assume there hasn't been many sold since finished birds > haven't been flying long, but any info from the list is helpful. > > Thanks. > > James K. Hovis ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Door fitting
For those of you that have fitted your doors... I am finding that a considerable amount of material must be removed from the door perimeter to get them to where they'll recess into the canopy opening. By considerable I mean that possibly 1/8 to 1/4 further than the scribe line is removed. Is this normal? Just being cautious! Brian 40308 (doors) http://www.mykitlog.com/rv10builder ________________________________________________________________________________
Date: Jul 13, 2006
I see you questions are focused on resale. I have a few for you however (but there are hundreds of questions I assume you have reviewed before reaching the finacial piece) - Do you have a strong desire to build a plane? 1250 or so hours of your life is a lot of time to be spending for good resale value - Does the finance minister like to fly- will she look forward to going on trips that take too long to get to by auto? - Do you understand that the price to build the plane is only the start of the finances you'll be spending (Taxes, hangar, maintenance (oil, etc) that can add up to 10% yearly. With that said, I have not started the building but I have a stronger desire to build the plane than to fly it and one day will be ready to sell it for another reason. I have no doubt I'll get my time and money back when the plane is sold. Simply put my CFO supports the RV-10 because she knows I love to build and have spent 7 years planning and saving for a kit plane. She also really wants to take trips we simply can not go on due to distance and time to get there, those two and not the resale works for me, if your answer to the three questions is "yes" and your wife understands the implication of your time building, the resale value should be an easy sale for you. Just don't get caught up with the money and forget why your building the plane to start with- unless of course it is as an investment with hopes of making money on your labor and not for the pleasure it will bring. Best of success with your propostion to the finance minister Pascal ----- Original Message ----- From: James K Hovis To: rv10-list(at)matronics.com Sent: Thursday, July 13, 2006 11:28 AM Subject: RV10-List: Relative Value for Complete RV-10's? As noted before I've been lurking absorbing the material before I actually make the plunge and get a RV-10 kit. One question I'd like to post to you here is what you think the relative value for a completed RV-10 would be if one was to sell their aircraft on the open market? I know that type of question would probably lead to many different answers since each airplane built is a little different from the next based on builder preferences and such. For example, one guy could build a strictly VFR machine while his buddy a few hangers away has a hard IFR capable machine. What I'm thinking is a moderate to high hp engine (235 to 260 hp) and probably light duty IFR capable ( i.e. basic gauges with maybe one or two EFIS displays and engine monitor). If I can reasonably assure the household finance minister that I can get a good return on my investment, it might sway her towards my thinking. I've seen one RV-10 offered for $220,000 and a partially finished a/c for $175,000. I'd assume there hasn't been many sold since finished birds haven't been flying long, but any info from the list is helpful. Thanks. James K. Hovis ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Quick Build (QB) Wings & Fuse - Steps Remaining
Has anyone posted a detailed list of what has already been done, and what remains to be done, for the QB wings and fuselage? Ideally something that references the plans, such as: for the wings, sections xx all complete, steps yy in section zz. need to be finished. I checked the archive, but had no luck. Bill Reining - going to OSH all week Tail cone 40514 N475R reserved ________________________________________________________________________________
Date: Jul 13, 2006
The RV-10 is taking at least 25% to 40% longer to complete than the 9A did. There are always lots of variables in comparisons but it does take longer. --- Michael Schipper wrote: > > > Compared to the RV-9A, the RV-10 kit is very > similar. The > instructions, however, are far superior so far. > > It took about 1500 hours to complete my RV-9A slow > build. Given the > larger size of the RV-10 I figure it will take about > 25% more time. > The quickbuild would save a lot of time, but I enjoy > building. > > Mike Schipper > RV-9A - N63MS - Flying > RV-10 #40576 - Working on Empennage > http://www.rvten.com > > > On Jul 12, 2006, at 10:20 PM, William DeLacey wrote: > > > > > > I would like comments from any repeat builders as > to the comparison > > of build times for the RV-10 verses any other > previous RV they > > built. Comments like 20% more or half as much > would be helpful. > > > > whd721(at)msn.com > > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jul 13, 2006
Subject: covers
In section 35 of the plans, there is a F-1042G-R and -L but below those "wire covers" is a rectangular area where most of my wiring appears. Does Van's supply or do we just fabricate? ________________________________________________________________________________
Date: Jul 13, 2006
Subject: covers
You can order these from Vans. They also come in their wiring kit (which I don't recommend unless you are doing a very basic panel). The wiring kit plans are available separately (to get part numbers from). Tim O. can give you access to a part of his site with the plans. John Testement HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com 40321 Richmond, VA Finish kit - gear legs and wheels _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Thursday, July 13, 2006 10:25 PM In section 35 of the plans, there is a F-1042G-R and -L but below those "wire covers" is a rectangular area where most of my wiring appears. Does Van's supply or do we just fabricate? -- -- ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: Jul 13, 2006
Bill, good luck on this one. When my QB Wings and Fuse arrived, I went through the plans as thoroughly as I thought I could, noting what was left to do, but didn't make a separate list. Even if I had, I've found lately that I've had to go back and do things that I overlooked, and then go back and fit the thing I was working on in the first place! It's not bad because it's kind of a checks and balances, but it sure throws you off of your rhythm when it happens. For me, these incidental things just "get done" and I've not tried to annotate them when I come across them, because it's all in the name of getting back to the original task. So a good, thorough, complete list seems like pie in the sky. There are parts of the plans, however, that do say for Slowbuild, do this, for QB, do this. That's not everywhere in the plans, but seems to be the author's choice when he wrote that section. Probably wouldn't be hard for Vans to make a separate set of plans since the QB stuff is done the same way every time, but then we wouldn't have the slow-build sections to reference in case we needed to redo a part or needed to modify something to suit our own missions. Rob Wright #392 QB Wings Tru-Trak Servos delivered yesterday! Finishing kit delivery next Thurs! Engine paid for awaiting delivery! Need more money/time/arms! _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Reining Sent: Thursday, July 13, 2006 8:42 PM Has anyone posted a detailed list of what has already been done, and what remains to be done, for the QB wings and fuselage? Ideally something that references the plans, such as: for the wings, sections xx all complete, steps yy in section zz. need to be finished. I checked the archive, but had no luck. Bill Reining - going to OSH all week Tail cone 40514 N475R reserved ________________________________________________________________________________
Date: Jul 14, 2006
Bill this would be extremely helpful but you'll find most likely it doesn't exist. The problem as I see it, is you don't really want to encourage someone starting out from point x without the intellectual catch up on what has been done for you already, particularly when the potential is for minor variations and discrepancies between QB's which shouldn't happen with good QC but nonetheless does. You will see on certain pages of the plans, references to Standard build and QB but it's my experience that you need to read and re-read everything that's gone before in any case to be on the safe side and to feel mentally "up to speed" with the project. Identify everything page by page as per the standard plans and verify it has been completed correctly is best engineering practice. John 40315 ACS * John Dunne Managing Director acs(at)acspropeller.com.au Aviation Component Services (Qld) Pty Ltd. Building 612 Lores Bonney Drive, Archerfield Airport Queensland Australia. PH:61 7 3274 4500 FAX:61 7 3274 4010 "Everything Propeller" _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Reining Sent: Friday, 14 July 2006 11:42 AM Has anyone posted a detailed list of what has already been done, and what remains to be done, for the QB wings and fuselage? Ideally something that references the plans, such as: for the wings, sections xx all complete, steps yy in section zz. need to be finished. I checked the archive, but had no luck. Bill Reining - going to OSH all week Tail cone 40514 N475R reserved ________________________________________________________________________________
Date: Jul 14, 2006
Subject:
My apologies to the list, I didn't mean to have all the business email tag on the end Sorry! John 40315 ________________________________________________________________________________
Date: Jul 14, 2006
Reply not necessarily aimed at Pascal! Pascal wrote: > I see you questions are focused on resale. I have a few for you > however (but there are hundreds of questions I assume you have > reviewed before reaching the finacial piece) > - Do you have a strong desire to build a plane? 1250 or so hours of > your life is a lot of time to be spending for good resale value > - Does the finance minister like to fly- will she look forward to > going on trips that take too long to get to by auto? > - Do you understand that the price to build the plane is only the > start of the finances you'll be spending (Taxes, hangar, maintenance > (oil, etc) that can add up to 10% yearly. > > With that said, I have not started the building but I have a stronger > desire to build the plane than to fly it and one day will be ready to > sell it for another reason. I have no doubt I'll get my time and money > back when the plane is sold. Initially this may be so, but as the -10 becomes more available you'll be hard pressed to get value for your labor and maybe not the money you've spent. I had a small business brokering airplanes, and there are two kinds of folks out there. There are owners that are selling a 'gold bar' and buyers looking for a 'lead bar'. Very rarely are the two folks close to reality. There are those that will pay a nice price for a homebuilt because they have more money than time ..... but as the market sees more airplanes for sale then the competition for buyers heats up and sales prices fall. Profit (or breaking even) shouldn't be a part of the decision to build any homebuilt. Satisfaction and the ability to legally 'tweak' your pride and joy to improve it's looks, speed, or efficiency go a long way. Linn > Simply put my CFO supports the RV-10 because she knows I love to build > and have spent 7 years planning and saving for a kit plane. She also > really wants to take trips we simply can not go on due to distance and > time to get there, those two and not the resale works for me, if your > answer to the three questions is "yes" and your wife understands the > implication of your time building, the resale value should be an easy > sale for you. Just don't get caught up with the money and forget why > your building the plane to start with- unless of course it is as an > investment with hopes of making money on your labor and not for the > pleasure it will bring. > > Best of success with your propostion to the finance minister > > Pascal > > > > ----- Original Message ----- > > From: James K Hovis <mailto:james.k.hovis(at)gmail.com> > To: rv10-list(at)matronics.com > Sent: Thursday, July 13, 2006 11:28 AM > Subject: RV10-List: Relative Value for Complete RV-10's? > > As noted before I've been lurking absorbing the material before I > actually make the plunge and get a RV-10 kit. One question I'd > like to post to you here is what you think the relative value > for a completed RV-10 would be if one was to sell their aircraft > on the open market? I know that type of question would probably > lead to many different answers since each airplane built is a > little different from the next based on builder preferences and > such. For example, one guy could build a strictly VFR machine > while his buddy a few hangers away has a hard IFR capable machine. > What I'm thinking is a moderate to high hp engine (235 to 260 hp) > and probably light duty IFR capable ( i.e. basic gauges with maybe > one or two EFIS displays and engine monitor). If I can reasonably > assure the household finance minister that I can get a good return > on my investment, it might sway her towards my thinking. I've seen > one RV-10 offered for $220,000 and a partially finished a/c for > $175,000. I'd assume there hasn't been many sold since finished > birds haven't been flying long, but any info from the list is > helpful. > > Thanks. > > James K. Hovis > ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: covers
I got the wire cover from Van's and was REAL disappointed in it to the point I decided to design my own. I got built covers to go over the entire side from the front seat up under the panel to the next upright (left and right). Bent the top over at a 90 degree angle and attached to the top, bottom and front upright with nutplates I installed. My wife who did the interior covered it and put in map pockets. As soon as my DAR does my sign off and I button the -10 up for first flight I will take some pictures and post. Russ N710RV - Hopefullying first flight within the next few days. ----- Original Message ----- From: David McNeill To: rv10-list(at)matronics.com Sent: Thursday, July 13, 2006 9:25 PM Subject: RV10-List: covers In section 35 of the plans, there is a F-1042G-R and -L but below those "wire covers" is a rectangular area where most of my wiring appears. Does Van's supply or do we just fabricate? ________________________________________________________________________________
Date: Jul 14, 2006
John, I am having Stein's group build my panel and they will be using the modular type panel like the photos that are attached. Apparently it is a very flexible unit, depending on what you want. The pictures shows it as already being cut but they obviously cut it to whatever you need. It's also, I believe, about 2" longer than the panel from Van's, allowing a little more room to fit stuff in. I like the idea that I will be able to take section apart to get at the equipment. Wayne Edgerton #40336 working on the baffling baffles ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: Quick Build (QB) Wings
I just received from Van's a quick build type flow chart, I don't have it here at home, it's at the hangar. I didn't study it in detail but I believe with my quick perusal that it showed what you have to do and what's already been done. If you haven't received one I would suggest you give Van's a call. Wayne Edgerton #40336 ________________________________________________________________________________
Date: Jul 14, 2006
Pascal, Thanks for the kind words. As stated before, I owned an AA-1A for nearly ten years, so as far as the sustaining costs of ownership I know what it takes. Holding a repairman's cert for my own airplane is a real benefit to me too. And being a past part of the airport board for H-88, only about 5 miles from the house, I can deal with those issues too. The desire for building has been there for quite awhile (somewhat simmered while I actually owned an airplane) and now that the rug rats are older (can actually buck a few rivets) and I'm seriously missing being able to go to the airport and pull out MY airplane anytime I want. Learning how to build an airplane was one reason I went to college for an AE degree (boy was I in for a shock!). And the dear wife does like to fly. The first time I took her for a ride, I ran a C-172 off the side of an ice-covered runway while taxiing for take off and it didn't scare her off (wasn't serious, just got a wheel of the runway edge and stuck in a snow/slush bank). Anyway, if I have a reasonable assurance that what money I put into an airplane I can get back out if I sell it (and as an added benefit get enough to build a SECOND ship), it'll help seal the deal. I figure $100K - $125K at least. If you figure $125 /hr (not a Cessna figure mind you...) at 1250 hrs your labor is "worth" around $156K. So with $125K in materials and equipment a fairly well equipped -10 could be "worth" $280K or so. Put in a $60K "amateur built" knock-down factor, you get to that $220K asking price I've seen. Still not bad! JKH On 7/13/06, Pascal wrote: > > I see you questions are focused on resale. I have a few for you however > (but there are hundreds of questions I assume you have reviewed before > reaching the finacial piece) > - Do you have a strong desire to build a plane? 1250 or so hours of your > life is a lot of time to be spending for good resale value > - Does the finance minister like to fly- will she look forward to going on > trips that take too long to get to by auto? > - Do you understand that the price to build the plane is only the start of > the finances you'll be spending (Taxes, hangar, maintenance (oil, etc) that > can add up to 10% yearly. > > With that said, I have not started the building but I have a stronger > desire to build the plane than to fly it and one day will be ready to sell > it for another reason. I have no doubt I'll get my time and money back when > the plane is sold. Simply put my CFO supports the RV-10 because she knows I > love to build and have spent 7 years planning and saving for a kit plane. > She also really wants to take trips we simply can not go on due to distance > and time to get there, those two and not the resale works for me, if your > answer to the three questions is "yes" and your wife understands the > implication of your time building, the resale value should be an easy sale > for you. Just don't get caught up with the money and forget why your > building the plane to start with- unless of course it is as an investment > with hopes of making money on your labor and not for the pleasure it will > bring. > > Best of success with your propostion to the finance minister > > Pascal > > > ----- Original Message ----- > > *From:* James K Hovis > *To:* rv10-list(at)matronics.com > *Sent:* Thursday, July 13, 2006 11:28 AM > *Subject:* RV10-List: Relative Value for Complete RV-10's? > > > As noted before I've been lurking absorbing the material before I > actually make the plunge and get a RV-10 kit. One question I'd like to post > to you here is what you think the relative value for a completed RV-10 would > be if one was to sell their aircraft on the open market? I know that type of > question would probably lead to many different answers since each airplane > built is a little different from the next based on builder preferences and > such. For example, one guy could build a strictly VFR machine while his > buddy a few hangers away has a hard IFR capable machine. What I'm thinking > is a moderate to high hp engine (235 to 260 hp) and probably light duty IFR > capable ( i.e. basic gauges with maybe one or two EFIS displays and engine > monitor). If I can reasonably assure the household finance minister that I > can get a good return on my investment, it might sway her towards my > thinking. I've seen one RV-10 offered for $220,000 and a partially finished > a/c for $175,000. I'd assume there hasn't been many sold since finished > birds haven't been flying long, but any info from the list is helpful. > > Thanks. > > James K. Hovis > > ________________________________________________________________________________
Date: Jul 14, 2006
Very nice! Cost? Jesse Saint I-TEC, Inc. HYPERLINK "mailto:jesse(at)itecusa.org"jesse(at)itecusa.org HYPERLINK "http://www.itecusa.org"www.itecusa.org W: 352-465-4545 C: 352-427-0285 _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Friday, July 14, 2006 7:42 AM John, I am having Stein's group build my panel and they will be using the modular type panel like the photos that are attached. Apparently it is a very flexible unit, depending on what you want. The pictures shows it as already being cut but they obviously cut it to whatever you need. It's also, I believe, about 2" longer than the panel from Van's, allowing a little more room to fit stuff in. I like the idea that I will be able to take section apart to get at the equipment. Wayne Edgerton #40336 working on the baffling baffles -- -- ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Overhead Console Vent Inlet
Ed Hayden, who had his canopy at SNF for display at Tony Sustare's booth for the overhead console, sent me some photos to post. The overhead console is pressurized via a tail inlet scoop, and Tony has that completed now. Ed also has A/C installed in his tail, that works with the vents. Should be impressive to see when he's flying. Here is a link to the Mod's page where I stuck everything. http://www.myrv10.com/tips/mods/index.html -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 14, 2006
This may be personal, but I don't see building a model or anything else I do for education, edification and enjoyment as being "billable time". Building a large project is going to be a significantly larger undertaking financially and time wise but I'm not building this project as a "professional" I am building for the purpose of what this "experimental" class was designed for. When I state " I have no doubt I'll get my time and money back when the plane is sold" I am really saying "the enjoyment building, teaching my daughter about engineering and flying, and the memories we will have flying everywhere will make up for any costs associated with the RV-10" If I get back what I put into it (currently expected 125K) I will have come out ahead in the end. I am not looking to make money on my plane, assuming I even sold it in the next 20 years, I'm looking to enjoy MY work and talking to others about how to "tweak it". In the end I agree with you Linn, this is about the journey not the destination to a hopeful pot of gold. Thanks! Pascal ----- Original Message ----- From: linn Walters To: rv10-list(at)matronics.com Sent: Thursday, July 13, 2006 10:15 PM Subject: Re: RV10-List: Relative Value for Complete RV-10's? Reply not necessarily aimed at Pascal! Pascal wrote: I see you questions are focused on resale. I have a few for you however (but there are hundreds of questions I assume you have reviewed before reaching the finacial piece) - Do you have a strong desire to build a plane? 1250 or so hours of your life is a lot of time to be spending for good resale value - Does the finance minister like to fly- will she look forward to going on trips that take too long to get to by auto? - Do you understand that the price to build the plane is only the start of the finances you'll be spending (Taxes, hangar, maintenance (oil, etc) that can add up to 10% yearly. With that said, I have not started the building but I have a stronger desire to build the plane than to fly it and one day will be ready to sell it for another reason. I have no doubt I'll get my time and money back when the plane is sold. Initially this may be so, but as the -10 becomes more available you'll be hard pressed to get value for your labor and maybe not the money you've spent. I had a small business brokering airplanes, and there are two kinds of folks out there. There are owners that are selling a 'gold bar' and buyers looking for a 'lead bar'. Very rarely are the two folks close to reality. There are those that will pay a nice price for a homebuilt because they have more money than time ..... but as the market sees more airplanes for sale then the competition for buyers heats up and sales prices fall. Profit (or breaking even) shouldn't be a part of the decision to build any homebuilt. Satisfaction and the ability to legally 'tweak' your pride and joy to improve it's looks, speed, or efficiency go a long way. Linn Simply put my CFO supports the RV-10 because she knows I love to build and have spent 7 years planning and saving for a kit plane. She also really wants to take trips we simply can not go on due to distance and time to get there, those two and not the resale works for me, if your answer to the three questions is "yes" and your wife understands the implication of your time building, the resale value should be an easy sale for you. Just don't get caught up with the money and forget why your building the plane to start with- unless of course it is as an investment with hopes of making money on your labor and not for the pleasure it will bring. Best of success with your propostion to the finance minister Pascal ----- Original Message ----- From: James K Hovis To: rv10-list(at)matronics.com Sent: Thursday, July 13, 2006 11:28 AM Subject: RV10-List: Relative Value for Complete RV-10's? As noted before I've been lurking absorbing the material before I actually make the plunge and get a RV-10 kit. One question I'd like to post to you here is what you think the relative value for a completed RV-10 would be if one was to sell their aircraft on the open market? I know that type of question would probably lead to many different answers since each airplane built is a little different from the next based on builder preferences and such. For example, one guy could build a strictly VFR machine while his buddy a few hangers away has a hard IFR capable machine. What I'm thinking is a moderate to high hp engine (235 to 260 hp) and probably light duty IFR capable ( i.e. basic gauges with maybe one or two EFIS displays and engine monitor). If I can reasonably assure the household finance minister that I can get a good return on my investment, it might sway her towards my thinking. I've seen one RV-10 offered for $220,000 and a partially finished a/c for $175,000. I'd assume there hasn't been many sold since finished birds haven't been flying long, but any info from the list is helpful. Thanks. James K. Hovis ________________________________________________________________________________
Date: Jul 14, 2006
In a message dated 7/13/06 3:30:33 P.M. Eastern Daylight Time, jjessen(at)rcn.com writes: Or, just take her down to a Cirrus dealer and show her the price tag. a fellow around the corner from us has a Cirrus 22, I believe he said he's tied up about $370k, our CAP C 182 with a G 1000 cost in the $385k area...but it's got a bunch of extra's one would not normally order...dual audio panel, SAT phone etc... Patrick ________________________________________________________________________________
Date: Jul 14, 2006
I built a Glasair III in 1990 for about $100,000. I flew it for 850 hours over 15 years and sold it for $125,000. I think that I got a great deal on the return on my investment. I too felt the labor is not billable. It is my hobby, no fisherman or golfer that is not professional figures in his time in the equation. Build and enjoy, if you don't like the building, go buy a factory built and fly tomorrow. Building can be very relaxing, gratifying and enjoyable, a great hobby. This is my 4th one. Gary 40274 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Friday, July 14, 2006 10:19 AM This may be personal, but I don't see building a model or anything else I do for education, edification and enjoyment as being "billable time". Building a large project is going to be a significantly larger undertaking financially and time wise but I'm not building this project as a "professional" I am building for the purpose of what this "experimental" class was designed for. When I state " I have no doubt I'll get my time and money back when the plane is sold" I am really saying "the enjoyment building, teaching my daughter about engineering and flying, and the memories we will have flying everywhere will make up for any costs associated with the RV-10" If I get back what I put into it (currently expected 125K) I will have come out ahead in the end. I am not looking to make money on my plane, assuming I even sold it in the next 20 years, I'm looking to enjoy MY work and talking to others about how to "tweak it". In the end I agree with you Linn, this is about the journey not the destination to a hopeful pot of gold. Thanks! Pascal ----- Original Message ----- Sent: Thursday, July 13, 2006 10:15 PM Reply not necessarily aimed at Pascal! Pascal wrote: I see you questions are focused on resale. I have a few for you however (but there are hundreds of questions I assume you have reviewed before reaching the finacial piece) - Do you have a strong desire to build a plane? 1250 or so hours of your life is a lot of time to be spending for good resale value - Does the finance minister like to fly- will she look forward to going on trips that take too long to get to by auto? - Do you understand that the price to build the plane is only the start of the finances you'll be spending (Taxes, hangar, maintenance (oil, etc) that can add up to 10% yearly. With that said, I have not started the building but I have a stronger desire to build the plane than to fly it and one day will be ready to sell it for another reason. I have no doubt I'll get my time and money back when the plane is sold. Initially this may be so, but as the -10 becomes more available you'll be hard pressed to get value for your labor and maybe not the money you've spent. I had a small business brokering airplanes, and there are two kinds of folks out there. There are owners that are selling a 'gold bar' and buyers looking for a 'lead bar'. Very rarely are the two folks close to reality. There are those that will pay a nice price for a homebuilt because they have more money than time ..... but as the market sees more airplanes for sale then the competition for buyers heats up and sales prices fall. Profit (or breaking even) shouldn't be a part of the decision to build any homebuilt. Satisfaction and the ability to legally 'tweak' your pride and joy to improve it's looks, speed, or efficiency go a long way. Linn Simply put my CFO supports the RV-10 because she knows I love to build and have spent 7 years planning and saving for a kit plane. She also really wants to take trips we simply can not go on due to distance and time to get there, those two and not the resale works for me, if your answer to the three questions is "yes" and your wife understands the implication of your time building, the resale value should be an easy sale for you. Just don't get caught up with the money and forget why your building the plane to start with- unless of course it is as an investment with hopes of making money on your labor and not for the pleasure it will bring. Best of success with your propostion to the finance minister Pascal ----- Original Message ----- Sent: Thursday, July 13, 2006 11:28 AM As noted before I've been lurking absorbing the material before I actually make the plunge and get a RV-10 kit. One question I'd like to post to you here is what you think the relative value for a completed RV-10 would be if one was to sell their aircraft on the open market? I know that type of question would probably lead to many different answers since each airplane built is a little different from the next based on builder preferences and such. For example, one guy could build a strictly VFR machine while his buddy a few hangers away has a hard IFR capable machine. What I'm thinking is a moderate to high hp engine (235 to 260 hp) and probably light duty IFR capable ( i.e. basic gauges with maybe one or two EFIS displays and engine monitor). If I can reasonably assure the household finance minister that I can get a good return on my investment, it might sway her towards my thinking. I've seen one RV-10 offered for $220,000 and a partially finished a/c for $175,000. I'd assume there hasn't been many sold since finished birds haven't been flying long, but any info from the list is helpful. Thanks. James K. Hovis ________________________________________________________________________________
Date: Jul 14, 2006
That a great attitude about it Pascal. When it comes to the future outlook of aviation and plane prices, I tend to think of myself as a realist. (Note: "Pessimist" is the word an optimist uses to describe a realist) ;) In my opinion, with the looming issues ahead: * Declining pilot population (soon to become more rapid due to the end of the boomers) * Increase in old plane sales due to removal of boomers from the flying population * Drastic increases in fuel costs * Increase in regulation and restriction of aviation (i.e. TFR / ADIZ propogation and general public security fears) * Increases in insurance rates * Limited or uncertain future of 100LL * The almost complete loss of the concept of "personal responsibility" causing huge lawsuit payouts in aviation. * Economic concerns of the US Economy, which may be set off by a drop in the housing market, forcing sales of "toys" like planes. I personally feel that we're probably living a limited-timed charmed lifestyle and that the days probably aren't that far away that aviation will be very hard to both get into and stay in. We all need to just stop and fully appreciate the time we have with our health and our aircraft, that will allow us, for this possibly short time, to have experiences that many people will never get. To give our families memories that they may never have the opportunity to pass on to their children. To build up many stories of the "days when you used to be able to fly your own airplane" that you can tell your grandkids. I have done a fairly good financial analysis of the costs of flying and maintaining my RV-10. It did cost me a good chunk of change to build, but I have that all paid off now. Surprisingly, I am finding that after being completed....the mere cost of operation has a definitely larger impact on my savings growth than aviation did a few years ago. The RV-10 is fast and efficient, and "reasonable" to maintain. It is not, however, inexpensive to fly and own. This is not the fault of the company, the plane, the avionics I bought, or anything like that. It's the insurance, the fuel, the oil, the hanger (not for me but for some people), and those types of things that will keep people from racking up thousands of hours on the RV-10's. So when those other Cessna's/Piper's/Beeches, and all those other old planes start to be dumped on the market at a faster rate, due to the above concerns, I fully expect the value of my RV-10 to drop along with the market. Depending on what natural, man-made, legislative, or economic disaster falls on us, we could literally see our airplanes become nearly worthless almost overnight. So building and planning for resale value being equal or higher probably isn't the way to view it. With luck, all of those above things will prove false, and our values will climb, our costs will drop, and we'll be able to some day sell our RV-10's at 125-150% of our initial costs, for the new RV-25 kits shipping starting in 2030....but I just wouldn't plan it that way. A good and applicable quote to our entire building and flying experience is this one by Albert Einstein: Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. Cheers, Tim Olson - RV-10 N104CD - Flying Pascal wrote: > This may be personal, but I don't see building a model or anything else > I do for education, edification and enjoyment as being "billable time". > Building a large project is going to be a significantly larger > undertaking financially and time wise but I'm not building this project > as a "professional" I am building for the purpose of what this > "experimental" class was designed for. When I state " I have no doubt > I'll get my time and money back when the plane is sold" I am really > saying "the enjoyment building, teaching my daughter about engineering > and flying, and the memories we will have flying everywhere will make up > for any costs associated with the RV-10" If I get back what I put into > it (currently expected 125K) I will have come out ahead in the end. I am > not looking to make money on my plane, assuming I even sold it in the > next 20 years, I'm looking to enjoy MY work and talking to others about > how to "tweak it". > In the end I agree with you Linn, this is about the journey not the > destination to a hopeful pot of gold. > Thanks! > Pascal > > ----- Original Message ----- > *From:* linn Walters > *To:* rv10-list(at)matronics.com > *Sent:* Thursday, July 13, 2006 10:15 PM > *Subject:* Re: RV10-List: Relative Value for Complete RV-10's? > > Reply not necessarily aimed at Pascal! > > Pascal wrote: >> I see you questions are focused on resale. I have a few for you >> however (but there are hundreds of questions I assume you have >> reviewed before reaching the finacial piece) >> - Do you have a strong desire to build a plane? 1250 or so hours >> of your life is a lot of time to be spending for good resale value >> - Does the finance minister like to fly- will she look forward to >> going on trips that take too long to get to by auto? >> - Do you understand that the price to build the plane is only the >> start of the finances you'll be spending (Taxes, hangar, >> maintenance (oil, etc) that can add up to 10% yearly. >> >> With that said, I have not started the building but I have a >> stronger desire to build the plane than to fly it and one day will >> be ready to sell it for another reason. I have no doubt I'll get >> my time and money back when the plane is sold. > Initially this may be so, but as the -10 becomes more available > you'll be hard pressed to get value for your labor and maybe not the > money you've spent. I had a small business brokering airplanes, and > there are two kinds of folks out there. There are owners that are > selling a 'gold bar' and buyers looking for a 'lead bar'. Very > rarely are the two folks close to reality. There are those that > will pay a nice price for a homebuilt because they have more money > than time ..... but as the market sees more airplanes for sale then > the competition for buyers heats up and sales prices fall. Profit > (or breaking even) shouldn't be a part of the decision to build any > homebuilt. Satisfaction and the ability to legally 'tweak' your > pride and joy to improve it's looks, speed, or efficiency go a long way. > Linn >> Simply put my CFO supports the RV-10 because she knows I love to >> build and have spent 7 years planning and saving for a kit plane. >> She also really wants to take trips we simply can not go on due to >> distance and time to get there, those two and not the resale works >> for me, if your answer to the three questions is "yes" and your >> wife understands the implication of your time building, the resale >> value should be an easy sale for you. Just don't get caught up >> with the money and forget why your building the plane to start >> with- unless of course it is as an investment with hopes of making >> money on your labor and not for the pleasure it will bring. >> >> Best of success with your propostion to the finance minister >> >> Pascal >> >> >> >> ----- Original Message ----- >> >> *From:* James K Hovis >> *To:* rv10-list(at)matronics.com >> *Sent:* Thursday, July 13, 2006 11:28 AM >> *Subject:* RV10-List: Relative Value for Complete RV-10's? >> >> As noted before I've been lurking absorbing the material >> before I actually make the plunge and get a RV-10 kit. One >> question I'd like to post to you here is what you think the >> relative value for a completed RV-10 would be if one was to >> sell their aircraft on the open market? I know that type of >> question would probably lead to many different answers since >> each airplane built is a little different from the next based >> on builder preferences and such. For example, one guy could >> build a strictly VFR machine while his buddy a few hangers >> away has a hard IFR capable machine. What I'm thinking is a >> moderate to high hp engine (235 to 260 hp) and probably light >> duty IFR capable ( i.e. basic gauges with maybe one or two >> EFIS displays and engine monitor). If I can reasonably assure >> the household finance minister that I can get a good return on >> my investment, it might sway her towards my thinking. I've >> seen one RV-10 offered for $220,000 and a partially finished >> a/c for $175,000. I'd assume there hasn't been many sold >> since finished birds haven't been flying long, but any info >> from the list is helpful. >> >> Thanks. >> >> James K. Hovis > > ________________________________________________________________________________
Date: Jul 14, 2006
I agree with most of the assessments I've read in this thread. My plane is almost ready to fly and I'm at $130K out of pocket. But I'll comment on the building time... I've seen the number of 1250 hours of build time thrown out a couple of times, I'm not sure what other people are seeing for build time but... I am a first time builder and I'm sure that I could build faster next time: I've put in almost 2500 hours in just over 2.5 years on my quickbuild RV-10. Something to think about for those who are considering starting. -Jim 40134 In a message dated 7/14/2006 9:46:58 A.M. Mountain Daylight Time, james.k.hovis(at)gmail.com writes: Pascal, Thanks for the kind words. As stated before, I owned an AA-1A for nearly ten years, so as far as the sustaining costs of ownership I know what it takes. Holding a repairman's cert for my own airplane is a real benefit to me too. And being a past part of the airport board for H-88, only about 5 miles from the house, I can deal with those issues too. The desire for building has been there for quite awhile (somewhat simmered while I actually owned an airplane) and now that the rug rats are older (can actually buck a few rivets) and I'm seriously missing being able to go to the airport and pull out MY airplane anytime I want. Learning how to build an airplane was one reason I went to college for an AE degree (boy was I in for a shock!). And the dear wife does like to fly. The first time I took her for a ride, I ran a C-172 off the side of an ice-covered runway while taxiing for take off and it didn't scare her off (wasn't serious, just got a wheel of the runway edge and stuck in a snow/slush bank). Anyway, if I have a reasonable assurance that what money I put into an airplane I can get back out if I sell it (and as an added benefit get enough to build a SECOND ship), it'll help seal the deal. I figure $100K - $125K at least. If you figure $125 /hr (not a Cessna figure mind you...) at 1250 hrs your labor is "worth" around $156K. So with $125K in materials and equipment a fairly well equipped -10 could be "worth" $280K or so. Put in a $60K "amateur built" knock-down factor, you get to that $220K asking price I've seen. Still not bad! JKH ________________________________________________________________________________
Date: Jul 14, 2006
Does Tony Sustare have a website or contact info? cj #40410 fuse -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, July 14, 2006 7:34 AM Ed Hayden, who had his canopy at SNF for display at Tony Sustare's booth for the overhead console, sent me some photos to post. The overhead console is pressurized via a tail inlet scoop, and Tony has that completed now. Ed also has A/C installed in his tail, that works with the vents. Should be impressive to see when he's flying. Here is a link to the Mod's page where I stuck everything. http://www.myrv10.com/tips/mods/index.html -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Hours to complete an RV-10
I don't understand the high build times, especially for QB. That's not a judgement, just a curiosity. I suppose people work and measure their efforts at different rates. Just for info, I built a slow-build RV-6A from start to complete (flying) in 1500 hrs. I'm building a slow-build RV-10 and have 760 hrs at the point of installing the doors and expect to finish at around 1500-1700 hrs. I count the time from walking in the shop to leaving the shop and write it down when I go through the door. The only time I study the plans is when I'm in the shop, but I'm busy working when I'm in the shop. Do any of you count thinking/dreaming time away from the shop? Resale values: I think of the labor as my enjoyment and challenge of the experience as some of you have said. I do not think of counting the hours and charging for that as part of the resale value. But I would want the market rate for what it should be worth. I wonder if any RV-10's have been sold yet? I'd like to know what the market rate will be for an RV-10, not that I want to sell mine. As bad as the outlook is, I agree with what Tim Olson said about the future. Let's hope he is wrong! Kevin _____ Sent: Friday, July 14, 2006 12:36 PM I agree with most of the assessments I've read in this thread. My plane is almost ready to fly and I'm at $130K out of pocket. But I'll comment on the building time... I've seen the number of 1250 hours of build time thrown out a couple of times, I'm not sure what other people are seeing for build time but... I am a first time builder and I'm sure that I could build faster next time: I've put in almost 2500 hours in just over 2.5 years on my quickbuild RV-10. Something to think about for those who are considering starting. -Jim 40134 In a message dated 7/14/2006 9:46:58 A.M. Mountain Daylight Time, james.k.hovis(at)gmail.com writes: Pascal, Thanks for the kind words. As stated before, I owned an AA-1A for nearly ten years, so as far as the sustaining costs of ownership I know what it takes. Holding a repairman's cert for my own airplane is a real benefit to me too. And being a past part of the airport board for H-88, only about 5 miles from the house, I can deal with those issues too. The desire for building has been there for quite awhile (somewhat simmered while I actually owned an airplane) and now that the rug rats are older (can actually buck a few rivets) and I'm seriously missing being able to go to the airport and pull out MY airplane anytime I want. Learning how to build an airplane was one reason I went to college for an AE degree (boy was I in for a shock!). And the dear wife does like to fly. The first time I took her for a ride, I ran a C-172 off the side of an ice-covered runway while taxiing for take off and it didn't scare her off (wasn't serious, just got a wheel of the runway edge and stuck in a snow/slush bank). Anyway, if I have a reasonable assurance that what money I put into an airplane I can get back out if I sell it (and as an added benefit get enough to build a SECOND ship), it'll help seal the deal. I figure $100K - $125K at least. If you figure $125 /hr (not a Cessna figure mind you...) at 1250 hrs your labor is "worth" around $156K. So with $125K in materials and equipment a fairly well equipped -10 could be "worth" $280K or so. Put in a $60K "amateur built" knock-down factor, you get to that $220K asking price I've seen. Still not bad! JKH http://www.w3.org/TR/REC-html40">
Kevin
From: JSMcGrew(at)aol.com [mailto:JSMcGrew(at)aol.com]
-Jim
40134
Pascal,
JKH
Date: Jul 14, 2006
Subject: time to build
Here's another data point for those thinking about build times. For my Dad and I, we are about way through this plane project, with no QB options. We are well into the the Fuse kit and have the Finish kit on hand. We've built 4 airplanes (three Glastars and one Glass Goose.) , so I think we are pretty far up the learning curve. We really like to build and enjoy the whole process, ( yes, even the glass work).. We are at about 1400 hrs so far. When complete, I expect we'll be in the 3000 hr. neighborhood... -Bob Newman 40176.. ________________________________________________________________________________
Date: Jul 14, 2006
I am at 1280/hrs (my build time only) and I have hung the doors and other finish kit options. I am thinking I am 6 - 9 months away and I do about 80-100 hours a month. My best guess is ~2000 hours. Slow build No paint Somebody else is doing the panel Engine being done by someone else. Rene' Felker 40322 N423CF Finish Kit _____ [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Belue, Kevin Sent: Friday, July 14, 2006 12:18 PM I don't understand the high build times, especially for QB. That's not a judgement, just a curiosity. I suppose people work and measure their efforts at different rates. Just for info, I built a slow-build RV-6A from start to complete (flying) in 1500 hrs. I'm building a slow-build RV-10 and have 760 hrs at the point of installing the doors and expect to finish at around 1500-1700 hrs. I count the time from walking in the shop to leaving the shop and write it down when I go through the door. The only time I study the plans is when I'm in the shop, but I'm busy working when I'm in the shop. Do any of you count thinking/dreaming time away from the shop? Resale values: I think of the labor as my enjoyment and challenge of the experience as some of you have said. I do not think of counting the hours and charging for that as part of the resale value. But I would want the market rate for what it should be worth. I wonder if any RV-10's have been sold yet? I'd like to know what the market rate will be for an RV-10, not that I want to sell mine. As bad as the outlook is, I agree with what Tim Olson said about the future. Let's hope he is wrong! Kevin _____ Sent: Friday, July 14, 2006 12:36 PM I agree with most of the assessments I've read in this thread. My plane is almost ready to fly and I'm at $130K out of pocket. But I'll comment on the building time... I've seen the number of 1250 hours of build time thrown out a couple of times, I'm not sure what other people are seeing for build time but... I am a first time builder and I'm sure that I could build faster next time: I've put in almost 2500 hours in just over 2.5 years on my quickbuild RV-10. Something to think about for those who are considering starting. -Jim 40134 In a message dated 7/14/2006 9:46:58 A.M. Mountain Daylight Time, james.k.hovis(at)gmail.com writes: Pascal, Thanks for the kind words. As stated before, I owned an AA-1A for nearly ten years, so as far as the sustaining costs of ownership I know what it takes. Holding a repairman's cert for my own airplane is a real benefit to me too. And being a past part of the airport board for H-88, only about 5 miles from the house, I can deal with those issues too. The desire for building has been there for quite awhile (somewhat simmered while I actually owned an airplane) and now that the rug rats are older (can actually buck a few rivets) and I'm seriously missing being able to go to the airport and pull out MY airplane anytime I want. Learning how to build an airplane was one reason I went to college for an AE degree (boy was I in for a shock!). And the dear wife does like to fly. The first time I took her for a ride, I ran a C-172 off the side of an ice-covered runway while taxiing for take off and it didn't scare her off (wasn't serious, just got a wheel of the runway edge and stuck in a snow/slush bank). Anyway, if I have a reasonable assurance that what money I put into an airplane I can get back out if I sell it (and as an added benefit get enough to build a SECOND ship), it'll help seal the deal. I figure $100K - $125K at least. If you figure $125 /hr (not a Cessna figure mind you...) at 1250 hrs your labor is "worth" around $156K. So with $125K in materials and equipment a fairly well equipped -10 could be "worth" $280K or so. Put in a $60K "amateur built" knock-down factor, you get to that $220K asking price I've seen. Still not bad! JKH ________________________________________________________________________________
Date: Jul 14, 2006
Hopefully we will get to meet up with Tony at OSH, I believe he was the force behind that nice fiberglass panel/console that Lancair was/is?? offering for the RV-10. I have looked but not found a website for them but I believe if you go to Larry Rosen's site he has pics of the console and contact ingo there. Rick S. 40185 ________________________________________________________________________________
Date: Jul 14, 2006
Bob, Are you flying the Glass Goose? Thank You Rick Conti The Boeing Company Senior Engineering Manager office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 -----Original Message----- Sent: Friday, July 14, 2006 2:32 PM Here's another data point for those thinking about build times. For my Dad and I, we are about way through this plane project, with no QB options. We are well into the the Fuse kit and have the Finish kit on hand. We've built 4 airplanes (three Glastars and one Glass Goose.) , so I think we are pretty far up the learning curve. We really like to build and enjoy the whole process, ( yes, even the glass work).. We are at about 1400 hrs so far. When complete, I expect we'll be in the 3000 hr. neighborhood... -Bob Newman 40176.. ________________________________________________________________________________
Date: Jul 14, 2006
Subject: instrument sub-panel, fwd fuse and cabin cover
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Jul 14, 2006
long story, but NO... we had it all the way thru high speed taxi tests, airworthyness certificate in hand. And others started having trouble with the wings coming off in flight. After a lot of research we decided it would never be safe. we CUT her up and took her away.. all 10 yrs worth of building time gone, but our lives in tact.... All useable hardware then went into the Glastars, which do fly. !! nicely. -Bob >>> rick.conti(at)boeing.com 7/14/2006 3:09:30 PM >>> Bob, Are you flying the Glass Goose? Thank You Rick Conti The Boeing Company Senior Engineering Manager office: 703 - 414 - 6141 blackberry: 571 - 215 - 6134 -----Original Message----- Sent: Friday, July 14, 2006 2:32 PM Here's another data point for those thinking about build times. For my Dad and I, we are about way through this plane project, with no QB options. We are well into the the Fuse kit and have the Finish kit on hand. We've built 4 airplanes (three Glastars and one Glass Goose.) , so I think we are pretty far up the learning curve. We really like to build and enjoy the whole process, ( yes, even the glass work).. We are at about 1400 hrs so far. When complete, I expect we'll be in the 3000 hr. neighborhood... -Bob Newman 40176.. ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: instrument sub-panel and electrical
Thanks for the reply Dick (and others as well). I think I'm going to end up doing the same. but for a slightly different reason. It's 116 here in AZ today, and will continue hot and $#@!@! for several more weeks before starting back down the thermometer. Makes working in the garage tough, so I ordered my radios, trnspndr, audio panel, yesterday, the Op Tech EFIS are being built this week and will ship next week, I'm re-reading my Aero-electric manual, So I'm going to take the next 6-? weeks and plan and install do the electrical/radio/panel. The amount of actual time in the garage will be limited as I can do a lot of the work indoors. btw the pics of your install are helpful, I'd love to see anybody else with similar pics. Deems Davis # 406 Fuse http://deemsrv10.com/ ________________________________________________________________________________
From: "Fred Williams, M.D." <drfred@cox-internet.com>
Date: Jul 14, 2006
Subject: Wings/Duckworks lights.
I'm working on the slo-build wings. Getting close to section 17 and the outboard leading edge. I helped a friend install his Duckworks lights in his RV 6 that he just about has complete. So far, I think I will go just with the lighting system 6 as is recommended by Vans and place the landing lights in the wingtips. I would, however, like to cheat a little and install the nutplates and extra wires in the left wing so that if I decide to add a duckworks landing light at a later date, most of the hard work will be done. Could someone who has installed the duckworks light fax me a copy of the template for the nutplate locations? I would be much abliged. Fax; 903 784 3200 See you'all at Oshgosh. Wed thru Sat. Thanks Fred Williams slo-building in Texas 40515 drfred@cox-internet.com ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Tony's Overhead Console Vent Inlet
To the -10 net on the overhead console: I bought one of Tony's overhead consoles and have installed it in N184JM already. I am pleased with the console, and it goes in nicely if you pop rivet it into the cabin top and then use simple silicone caulk to fill in the gaps. However, there is a potential problem we need to address (and shame on me for not thinking of it ahead of time). It has to do with placement of the air inlet scoop versus the exhaust swirl caused by prop flow coupled with the aerodynamics of the bird. The concern is that if we are not careful in placement of the inleet scoop to feed the tubes and console, that we will bring exhaust gases (and carbon monoxide) into the cabin through the console. At present, I have Tony's first production scoop that mounts directly in front of the vertical tail. There is significant concern that prop and exhaust swirl will suck CO into the cabin with this placement. Van's has no data to support or disapprove of such a cabin air inlet mounting. I am looking at alternative placement of either Tony's scoop or installation of a NACA scoop elsewhere on the aft fuselage to supply the air. However, thus far we (I have a couple of aero engineers helping me) have not been able to find any definitivie studies on this issue from either the academic or corporate (Van's, Piper, etc) flight test world that shows what the exhaust swirl actually looks like. If I cannot find any definitive studies, then I will flight test a NACA vent on the fuselage to see what CO it draws into the console/cockpit. However, that probably won't happen till late Aug or mid Sep due to other circumstances getting my bird into the air. If anyone on the net has one of Tony's consoles and can test an inlet location for CO prior to that, please let me know and I'll give you my best guess where to mount your scoop should you decide not to use Tony's scoop and its mounting location. grumpy #40404.....soon to fly! In a message dated 7/14/2006 12:48:12 PM Central Standard Time, CJohnston(at)popsound.com writes: Does Tony Sustare have a website or contact info? cj #40410 fuse -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, July 14, 2006 7:34 AM Ed Hayden, who had his canopy at SNF for display at Tony Sustare's booth for the overhead console, sent me some photos to post. The overhead console is pressurized via a tail inlet scoop, and Tony has that completed now. Ed also has A/C installed in his tail, that works with the vents. Should be impressive to see when he's flying. Here is a link to the Mod's page where I stuck everything. http://www.myrv10.com/tips/mods/index.html -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: Tony's Overhead Console Vent Inlet
Date: Jul 15, 2006
Subject: Re: instrument sub-panel, fuse and cabin cover questions
I'm not exactly sure what their price is right now, I ordered it quite awhile back, but I think it would be in the $1,000 area. You would have to give Stein a call to make find out for sure. ________________________________________________________________________________
Date: Jul 15, 2006
Sorry about the previous post, I forgot to sign it. Not awake yet I quess :>} I'm not exactly sure what their price is right now, I ordered it quite awhile back, but I think it would be in the $1,000 range. You would have to give Stein a call to make find out for sure. Wayne Edgerton #40336 working on the baffling baffles ________________________________________________________________________________
Date: Jul 15, 2006
John, I wish I were talented enough to build that panel but unfortunately I'm not. I bought the panel from Stein. Wayne Edgerton #40336 working on the baffling baffle ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Re: Overhead Console Vent Inlet
Tony Sustare Accuracy Avionics 541-388-1788 Wayne Edgerton #40336 Baffling ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Oil Cooler Mount
Does anyone have a suggestion on how to drive the rivet holding the oil cooler mount to the firewall that sits behind the flange for the cooling duct? The best I can come up with is to back-rivet while holding the plate tight with some heavy bucking bars but if anyone has a better solution, I'd appreciate hearing it. Thanks, Tom Gesele #40473 ________________________________________________________________________________
Date: Jul 15, 2006
Hello grumpy, I also have Tony's overhead console installed. My install didn't go quite as easy as it sounds like your did because the plane the mold was made from appeared to have had quite a bit of sanding work done on the canopy before the mold was made, so we had to modify it somewhat to get it to fit. I like the console and I'm not sorry I got it, but we couldn't just stick it on and go. I'm still working on sealing the back area that should abut to the baggage compartment bulkhead. I've owned a Bonanza and a Baron and they both had air inlets around the area where Tony has his, based on the pictures, I haven't received anything yet, except that Beech has theirs on the side of the fairing. On the Bonanza I never had any problem of exhaust coming into the cabin. It would be more closely related to the 10 in that the Baron's engines obviously wouldn't be inline with the VS. I've attached a photo of the Bonanza placement of their air inlet. Are you thinking that the exhaust will come under the plane and then swirl up around the VS area? I'm not an engineer by any stretch of the imagination, so I'm not questioning your concern, but it seems like the exhaust would travel down and back, not down and up over the VS ?? Wayne Edgerton #40336 Engine baffling ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Re: Oil Cooler Mount
Tom, That's what I did, I used the tapered foot of a "Z' Shaped bucking bar and back riveted it. Matter of fact I back riveted the entire assmbly to the firewall. Rick S. 40185 ________________________________________________________________________________
Date: Jul 15, 2006
Subject: instrument sub-panel, fuse and cabin cover questions
Okay, that makes it two respected builders endorsements. Make note to self, visit SteinAir booth 2030 on the Northside Wall of Exhibit Hall B, and review their website site at www.steinair.com before departing for OSH. Endorsement by Tim Olson - 2005. Endorsement by Wayne Edgerton - 2006... no commercial connection. That is enough for me to consider the supplier. John $00.02 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Saturday, July 15, 2006 4:24 AM questions John, I wish I were talented enough to build that panel but unfortunately I'm not. I bought the panel from Stein. Wayne Edgerton #40336 working on the baffling baffle ________________________________________________________________________________
Date: Jul 15, 2006
Subject: RE: Relative Value for Complete RV-10's?
James' question has gotten a lot of responses, but I thought I'd throw in my two cents. When I finally complete my RV-10, it's resale value is limited to three possibilities: What is the most an insurance company will pay for a hull loss. What will my wife accept for that "thing" out back after I croak. What do I need out of it so I can move up to building an RV-13. I sure hope that the third one is the one that comes to pass (g). John #40572 Vertical Stab & Rudder complete. N711JG reserved ________________________________________________________________________________
Date: Jul 15, 2006
Only problem with dealing with Stein is that they are old fashioned honest, and a handshake or their word is solid. They have my business and a lot of others. Bob K Working engine and instruments ________________________________________________________________________________
Date: Jul 15, 2006
How about a third endorsement for SteinAir. Stein built my panel, great price, wonderful service, great follow-up after delivery. I wouldn't buy from anyone else, even if they told me they would beat Stein's price. Two of my buddies also bought from Stein and one of them who is flying his RV-6 with a duel screen GRT system he got from Stein has had nothing but great things to say about Stein. My first pick for a DAR fail through for me so I am waiting on a new DAR to come down and inspect my -10 and it doesn't look like I will make OSH2006, but if I did you would find me hanging out at Stein's booth. Russ Daves N710RV waiting on DAR signoff. ----- Original Message ----- Sent: Saturday, July 15, 2006 11:31 AM > > Okay, that makes it two respected builders endorsements. Make note to > self, visit SteinAir booth 2030 on the Northside Wall of Exhibit Hall B, > and review their website site at www.steinair.com before departing for > OSH. > > Endorsement by Tim Olson - 2005. Endorsement by Wayne Edgerton - 2006... > no commercial connection. That is enough for me to consider the > supplier. > > John $00.02 > > -----Original Message----- > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne > Edgerton > Sent: Saturday, July 15, 2006 4:24 AM > questions > > John, > > I wish I were talented enough to build that panel but unfortunately I'm > not. I bought the panel from Stein. > > Wayne Edgerton #40336 > working on the baffling baffle > > > ________________________________________________________________________________
From: "Robert G. Wright" <armywrights(at)adelphia.net>
Date: Jul 15, 2006
Subject: autopilot
Installing the roll servo in the right wing. I've got the neutral position jig in place. How do I find out what "neutral" is for the connecting rod that joins the servo to the bellcrank? My servos were drop shipped with pictures only, and after reviewing the drawings online I still couldn't find a neutral setting/measurement. Rob Wright #392 QB Wings ________________________________________________________________________________
Date: Jul 16, 2006
Back rivet.....easy! ----- Original Message ----- Sent: Saturday, July 15, 2006 10:15 PM > > Does anyone have a suggestion on how to drive the rivet holding the oil > cooler mount to the firewall that sits behind the flange for the cooling > duct? The best I can come up with is to back-rivet while holding the plate > tight with some heavy bucking bars but if anyone has a better solution, > I'd > appreciate hearing it. > > Thanks, > Tom Gesele #40473 > > > ________________________________________________________________________________
Date: Jul 15, 2006
Date: Jul 15, 2006
Subject: Re: autopilot
I adjusted it so that the arm of the servo was straight up when the ailerons were neutral. PJ #40032 Robert G. Wright wrote: > > Installing the roll servo in the right wing. > > Ive got the neutral position jig in place. > > How do I find out what neutral is for the connecting rod that joins > the servo to the bellcrank? > > My servos were drop shipped with pictures only, and after reviewing > the drawings online I still couldnt find a neutral setting/measurement. > > Rob Wright > > #392 > > QB Wings > ________________________________________________________________________________
Date: Jul 15, 2006
I second and third this statement. I have nothing but good things to say about Stein and his staff. He has given me his honest assessment of any of the toys I have wanted to add to my plane. He has even steered me to his competitors to buy things, as he likes to spread the dollars to others. I think this fact alone leads to his high customer satisfaction, and the fact that what he says he will do, he does. A very happy customer of Steins. Dan Lloyd 40269 (N289DT) Fuselage -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob.kaufmann Sent: Saturday, July 15, 2006 4:45 PM Only problem with dealing with Stein is that they are old fashioned honest, and a handshake or their word is solid. They have my business and a lot of others. Bob K Working engine and instruments ________________________________________________________________________________
Date: Jul 15, 2006
Look at the scoop on this Bo, if you have ever seen the retractable scoops on the early Bonanza's thats what I am going to look into doing. It is on the center of the roof just aft or near the grab handle which is on the right upper side of the fuselage. I am thing of a retractable scoop just behind the lid...we'll see. Experimental and all. http://www.beechcraft.org/vtail/p436jb/ http://www.beechcraft.org/vtail/p774S/ Chris Lucas #40072 ----- Original Message ----- From: GenGrumpy(at)aol.com To: rv10-list(at)matronics.com Sent: Friday, July 14, 2006 11:31 PM Subject: RV10-List: Tony's Overhead Console Vent Inlet To the -10 net on the overhead console: I bought one of Tony's overhead consoles and have installed it in N184JM already. I am pleased with the console, and it goes in nicely if you pop rivet it into the cabin top and then use simple silicone caulk to fill in the gaps. However, there is a potential problem we need to address (and shame on me for not thinking of it ahead of time). It has to do with placement of the air inlet scoop versus the exhaust swirl caused by prop flow coupled with the aerodynamics of the bird. The concern is that if we are not careful in placement of the inleet scoop to feed the tubes and console, that we will bring exhaust gases (and carbon monoxide) into the cabin through the console. At present, I have Tony's first production scoop that mounts directly in front of the vertical tail. There is significant concern that prop and exhaust swirl will suck CO into the cabin with this placement. Van's has no data to support or disapprove of such a cabin air inlet mounting. I am looking at alternative placement of either Tony's scoop or installation of a NACA scoop elsewhere on the aft fuselage to supply the air. However, thus far we (I have a couple of aero engineers helping me) have not been able to find any definitivie studies on this issue from either the academic or corporate (Van's, Piper, etc) flight test world that shows what the exhaust swirl actually looks like. If I cannot find any definitive studies, then I will flight test a NACA vent on the fuselage to see what CO it draws into the console/cockpit. However, that probably won't happen till late Aug or mid Sep due to other circumstances getting my bird into the air. If anyone on the net has one of Tony's consoles and can test an inlet location for CO prior to that, please let me know and I'll give you my best guess where to mount your scoop should you decide not to use Tony's scoop and its mounting location. grumpy #40404.....soon to fly! In a message dated 7/14/2006 12:48:12 PM Central Standard Time, CJohnston(at)popsound.com writes: Does Tony Sustare have a website or contact info? cj #40410 fuse -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, July 14, 2006 7:34 AM Ed Hayden, who had his canopy at SNF for display at Tony Sustare's booth for the overhead console, sent me some photos to post. The overhead console is pressurized via a tail inlet scoop, and Tony has that completed now. Ed also has A/C installed in his tail, that works with the vents. Should be impressive to see when he's flying. Here is a link to the Mod's page where I stuck everything. http://www.myrv10.com/tips/mods/index.html -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 16, 2006
Subject: Re: Relative Value for Complete RV-10's?
---- Tim Olson wrote: > To combine replies to another, I agree, if anyone can > build an RV-10 to the point of finishing, in less > than 1500 hours, I'd be pretty surprised, even if > completely QB. My estimates would be more like: > > QB Complete: 1500-1700 > 1/2 QB Options: 1700-2000 > 100% Standard: 1900-2500 Not sure, but I think my QB may come in under 1000 hrs total since I am fitting the canopy cover now, all wing construction including lighting, wiring, antennas and servos are done, have the electrical & lighting systems in the fuse and tested, and some avionics done. The engine is sitting a few feet away from the firewall, and the KitLog program tells me total shop hours are currently at 487 (started the project last August 26th). At the same point on my slow build -7A I had about 1000 shop hours in the project. I think the difference is knowing exactly what you want to do and how to get it done on your second RV. But then, I might be underestimating the cabin completion issues. Will see... -Dan Masys #40448 ________________________________________________________________________________
Date: Jul 16, 2006
Date: Jul 15, 2006
Subject: Rvator Announcement
The latest Rvator arrived the other day and even though it had been worked over unusually hard by the gorillas at the post office, I did manage to decipher an interesting little nugget on page 10. "If all goes well, we will have a SIGNIFICANT PRODUCT INTRODUCTION at AirVenture 2006 - the result of over a year's intensive work. No, not the RV-12." Hmmmmmmmm. Anyone "in the know" want to spoil their surprise??? -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
Date: Jul 15, 2006
John, What area on the plane are you looking at for the NACA duct? Kevin 40494 ________________________________________________________________________________
Date: Jul 16, 2006
Subject: RV-10 vs RV-9 or 7 or 6 build time
Thanks to all who replied. I thought that the times would be close to the same as most tasks to complete are similar. However, the biggest variable appears to be the skill of the builder. well duh! ________________________________________________________________________________
Date: Jul 16, 2006
Fred, Why don't you contact the nice folks at Duckworks and see if they can help? BTW, that would be me! Don 'The Duck' Wentz duckworks(at)comcast.net -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Friday, July 14, 2006 3:47 PM --> <drfred@cox-internet.com> I'm working on the slo-build wings. Getting close to section 17 and the outboard leading edge. I helped a friend install his Duckworks lights in his RV 6 that he just about has complete. So far, I think I will go just with the lighting system 6 as is recommended by Vans and place the landing lights in the wingtips. I would, however, like to cheat a little and install the nutplates and extra wires in the left wing so that if I decide to add a duckworks landing light at a later date, most of the hard work will be done. Could someone who has installed the duckworks light fax me a copy of the template for the nutplate locations? I would be much abliged. Fax; 903 784 3200 See you'all at Oshgosh. Wed thru Sat. Thanks Fred Williams slo-building in Texas 40515 drfred@cox-internet.com ________________________________________________________________________________
Date: Jul 16, 2006
Subject: Duckworks lights.
Oops! Put in the wrong fax number Correct one is : 903 784 7405 Thanks: Fred Williams I'm working on the slo-build wings. Getting close to section 17 and the outboard leading edge. I helped a friend install his Duckworks lights in his RV 6 that he just about has complete. So far, I think I will go just with the lighting system 6 as is recommended by Vans and place the landing lights in the wingtips. I would, however, like to cheat a little and install the nutplates and extra wires in the left wing so that if I decide to add a duckworks landing light at a later date, most of the hard work will be done. Could someone who has installed the duckworks light fax me a copy of the template for the nutplate locations? I would be much abliged. Fax; 903 784 3200 See you'all at Oshgosh. Wed thru Sat. Thanks Fred Williams slo-building in Texas 40515 drfred@cox-internet.com ________________________________________________________________________________
Date: Jul 16, 2006
Don, Would you FAX a copy of the nutplate location template to Fred, please? Lyle Peterson lyleap(at)comcast.net 651-653-2063 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of Wentz, Don > Sent: Sunday, July 16, 2006 1:07 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Wings/Duckworks lights. > > > Fred, > Why don't you contact the nice folks at Duckworks and see if they can > help? > > BTW, that would be me! > Don 'The Duck' Wentz > duckworks(at)comcast.net > > > > -----Original Message----- > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred > Williams, M.D. > Sent: Friday, July 14, 2006 3:47 PM > > --> <drfred@cox-internet.com> > > I'm working on the slo-build wings. Getting close to section 17 and the > outboard leading edge. I helped a friend install his Duckworks lights > in his RV 6 that he just about has complete. So far, I think I will go > just with the lighting system 6 as is recommended by Vans and place the > landing lights in the wingtips. I would, however, like to cheat a > little and install the nutplates and extra wires in the left wing so > that if I decide to add a duckworks landing light at a later date, most > of the hard work will be done. Could someone who has installed the > duckworks light fax me a copy of the template for the nutplate > locations? I would be much abliged. > > Fax; 903 784 3200 > > See you'all at Oshgosh. Wed thru Sat. > > > Thanks > > Fred Williams > slo-building in Texas > 40515 > drfred@cox-internet.com > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 16, 2006
Subject: IO-540 Engine Question
Jim, The rolling tool is used to swage the tubes in place. Basically a mandrel with three rollers that are expanded in the tube while twisting the tool to enlarge the intake tube enough to be retained by the crank case groove surrounding the tube. So, yes, you need to borrow the tool in order to expand the stubs where they exit the case. -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Franz Sent: Friday, July 07, 2006 7:51 PM --> Jim, The intake tubes are swaged into the crankcase. There is a tool that can re-swage the induction tubes, improving the retention, but an application of proseal around the joint will help prevent induction leaks. When I rebuilt my O-360 I found a similar condition on two of the four tubes. My local Lycon shop fixed the problem for about twenty bucks. Carl Franz N410FS (reserved), N215CF RV-6 flying -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com Sent: Thursday, July 06, 2006 8:56 PM I have a used IO-540 engine and today I removed the intake / induction tubes that run from the sides of the oil sump up to the cylinders. Down at the oil sump there is a flexible hose that joins the metal tubes together. After removing the tubes I noticed that three of the six stubs coming out of the oil sump were loose and could be moved in and out about an 1/8 inch. I talked to a local EAA member and he said the tubes were "rolled" in order to slightly expand them and hold them in place. The sealant around the tubes is the second level of sealing, kind of the suspenders and belt routine, if you're not sure you can keep your pants up. The parts (gaskets etc.) you'd get from your local engine repair facility. I get a lot of parts from AERO in the Chicago area (800-910-1281) Sorry for the delay, I've been busy working on the RV-10 and not keeping up with the e-mail. Carl So the questions are: (1) Do I need to get / borrow a tool to roll these again? (2) Can this be done while the sump is attached? (3) What about using a sealant (Fuel tank sealant comes to mind) to seal up the tubes to the oil sump vs "rolling" them again? Also, Where is a good place to order gaskets? I would like to replace the valve cover gaskets while I am cleaning up the outside. Need new cylinder intake gaskets as well. I have ordered manuals for the engine from Lycoming but they are not here yet. I need to get part numbers. Thanks, Jim Combs N40192 ________________________________________________________________________________
Date: Jul 16, 2006
On a NON-Vans modified Empennage to Vertical/Horizontal fairing. If necessary, will have a DER determine move to the vertical with necessary reinforcement and running of airflow through a composite 180 degree duct down through the lightening hole and then back forward onto the aft baggage bulkhead for the conditioning/control plenum. Fairings are getting lots of attention due to drag and QOW on the composite parts. John 40600 -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of KiloPapa Sent: Saturday, July 15, 2006 10:18 PM John, What area on the plane are you looking at for the NACA duct? Kevin 40494 ________________________________________________________________________________
Date: Jul 16, 2006
Subject: Gear Mount install
hey all - made tons of progress on the fuse this weekend, but i left off at the temp install of the gear mount (where you mark and drill the holes for the floor rib. i cursed a bit, and wiggled, pushed, tapped, and otherwise made my best effort to cajole the things into place, but they are fighting me... anyone else have any trouble with this part? i have the left one in, but i don't know how i'll get it back out - the bolts were really tight to get in... the right one won't line up at all. anyone have to apply a bit of judicious buffing or clearancing of things in the neighborhood? harrumph. cj #40410 fuse ________________________________________________________________________________
Date: Jul 17, 2006
Chris, Fear not - you are not alone. I too had to work pretty hard to get the gear mounts installed. First thing to check is that you have no interference with the forward gear mount brace against the outboard forward seat rail support. I needed to grind a bit off (the seat support) for clearance. I also found that I needed to sacrifice a few AN3-14 or -15 bolts to make alignment pins. Once the holes were aligned, the bolts went in with a bit of Boelube. I think I needed to run the drill through a few holes that were out by a few thou'. cheers, Ron #187 fuse/finishing -----Original Message----- [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Chris Johnston Sent: Monday, 17 July 2006 2:48 PM hey all - made tons of progress on the fuse this weekend, but i left off at the temp install of the gear mount (where you mark and drill the holes for the floor rib. i cursed a bit, and wiggled, pushed, tapped, and otherwise made my best effort to cajole the things into place, but they are fighting me... anyone else have any trouble with this part? i have the left one in, but i don't know how i'll get it back out - the bolts were really tight to get in... the right one won't line up at all. anyone have to apply a bit of judicious buffing or clearancing of things in the neighborhood? harrumph. cj #40410 fuse ________________________________________________________________________________ ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: Quick Build (QB) Wings
They just sent it out to me. I didn't even realize that it existed until I received it. Maybe you could give them a call and see where yours is. Wayne Edgerton # 40336 baffling ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: Oshkosh Subaru Engine Specials
I have been asked to announce that Eggenfellner Does have turbocharged 220HP
June 27, 2006 - July 17, 2006
RV10-Archive.digest.vol-bi
