RV10-Archive.digest.vol-bm
September 07, 2006 - September 26, 2006
      > Subject: RV10-List: Build times - time to get restarted?
      > I was one of the first to buy a tail kit (#22), but life intruded and
      > after
      > some initial progress the kid has been untouched for the last 2 years.
      I'm
      > now getting the itch to get hack into the project, but I'm wonder if
      I've
      > bit off more than I can chew.
      > I'd be interested in hearing from anyone who has completed, or nearly
      > completed a Quick-Build RV-10, regard times to completion for each of
      the
      > sub-kits (empecone, wings, etc). Did you try to optimize for lowest
      cost
      > of
      > fastest build time? What major obstacles did you hit? What words of
      > advice/encouragement would you offer?
      > Its getting depressing to see the tail parts hanging there every time
      I
      > pull
      > into the garage. Its time for me to either get my you-know-what in
      gear or
      > admit to myself that this isn't going to happen and sell the tail kit.
      > Replies directly to this email _lr_@yahoo.com are welcome.
      > Thanks in advance,
      > Larry Rachman
      > ISP
      > __________________________________________________
Subject: heat box
Date: Sep 07, 2006
Hi all, does some body replace the aluminum heat box provide with the kit with an Stain. steel one,if so please can you share manuf. and model and how you like it. Thanks, Hugo #40456 ________________________________________________________________________________
Subject: Washer Wrench
Date: Sep 07, 2006
This is my washer wrench made from a popsicle stick. It may not be an original idea but it works. Albert Gardner Yuma, AZ ________________________________________________________________________________
Subject: Re: Washer Wrench
Date: Sep 07, 2006
Thank you Albert,Hugo > > From: "Albert Gardner" <ibspud(at)adelphia.net> > Date: 2006/09/07 Thu PM 01:36:25 EDT > To: > Subject: RV10-List: Washer Wrench > > > This is my washer wrench made from a popsicle stick. It may not be an > original idea but it works. > Albert Gardner > Yuma, AZ > > > ________________________________________________________________________________
Subject: Re: heat box
Date: Sep 07, 2006
I saw this vendor, EPM.VA Corp., at OSH2006 that had SS heater boxes. I'm not to that stage yet, but here's a link to there webpage: http://www.epm-avcorp.com/ssdiv.html John #40262 Hi all, does some body replace the aluminum heat box provide with the kit with an Stain. steel one,if so please can you share manuf. and model and how you like it. Thanks, Hugo #40456 ________________________________________________________________________________
Subject: Dick Waters engine
Date: Sep 07, 2006
anyone considering a Dick Waters engine should contact me first!!! cjhukill(at)cox.net ________________________________________________________________________________
Date: Sep 07, 2006
I bought a set from EPM at Oshkosh, they are the same units that Avery sells. I don't have any installation pix handy but they form & fit identical to the aluminum units supplied in the kit. Bob #40105 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=60266#60266 ________________________________________________________________________________
Date: Sep 07, 2006
Subject: Instrument tilt?
*Might be a dumb question, but the instrument panel has a 7.3 degree tilt. Does that mean I should buy the instruments advertised with 8 degree tilt? Thanks, PJ Seipel RV-10 #40032 * ________________________________________________________________________________
Date: Sep 07, 2006
Please relate your info in the forum. Having one of his engines in hand along with a pleasant process definitely needs the other side of the coin. He said to call him prior to engine run for a phone walk-through. The engine is also unconditionally guaranteed for one year from first run on the airplane. Rob Wright #392 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Thursday, September 07, 2006 6:41 PM Subject: RV10-List: Dick Waters engine anyone considering a Dick Waters engine should contact me first!!! cjhukill(at)cox.net ________________________________________________________________________________
Subject: Re: Paint $$Build times - time to get restarted?
Date: Sep 08, 2006
The person I will use, Glo Custom Paint, has only painted one 10 and that is Russ's but he's done a ton of RV's. I'm in the queue at $8,000. Based on the planes I've seen Grady paint, which is quite a few, he really does excellent work. Wayne Edgerton #40336 ________________________________________________________________________________
Subject: engine tip
Date: Sep 08, 2006
Just got an email from www.skygeek.com. They are selling a Superior oil quick drain for $15. It is the Curtiss valve for IO540s. FAA PMA approved and compares to the SAF-DRAIN version for $50. ________________________________________________________________________________
Date: Sep 08, 2006
Wayne, Is he priming for you also? $8k seems high if you've already primed and there is no paint removal like an older plane getting a paint job. Will you be disassembling and re-assembling the control surfaces? If yes, then it really seems high. I know he does good work though. ----- Original Message ----- From: Wayne Edgerton To: rv10-list(at)matronics.com Sent: Friday, September 08, 2006 7:01 AM Subject: Re: RV10-List: Paint $$Build times - time to get restarted? The person I will use, Glo Custom Paint, has only painted one 10 and that is Russ's but he's done a ton of RV's. I'm in the queue at $8,000. Based on the planes I've seen Grady paint, which is quite a few, he really does excellent work. Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Window overspray
Date: Sep 08, 2006
From: "Scott Schmidt" <sschmidt(at)ussynthetic.com>
I had some overspray on my windows as well and used the "Scratch Off" kit that Van's sells. I used the last two steps and it cleaned up very nicely. In fact it looks like that section is more brilliant than the rest. I tried water and Cee Bailey's makes a cleaner for these windows but none of it worked. Also, I had a small section where my DA sander hit the back window and the scratch kit fixed it perfectly. So don't sweat it if you make a little scratch while building or get some overspray. It will clean up. Scott Schmidt sschmidt(at)ussynthetic.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of KiloPapa Sent: Tuesday, August 22, 2006 10:04 PM Subject: Re: RV10-List: Window overspray Read the reply from John Cox in this thread before you use any solvents: http://forums.matronics.com/viewtopic.php?t=5024 Kevin 40494 tail/empennage ----- Original Message ----- From: "Vern W. Smith" <Vern(at)teclabsinc.com> Sent: Tuesday, August 22, 2006 2:53 PM Subject: RE: RV10-List: Window overspray > > Hi, > > A product I had recommended to me by an A&P was DuPont's PrepSol ("5 > Star" brand has the similar product called Wax and Grease Remover.) It > should be available in the local car paint shop in quarts and gallons. I > used it on a Cessna to clean some overspray off and it worked well > without harming the Plexiglas. I have not used it on Van's windows so if > you go this way try it on a scrap first. > > Vern (#40324 wings) ________________________________________________________________________________
Subject: Static Ports / Airspeed Error
Date: Sep 08, 2006
I purchased two static ports from Aircraft Spruce and found them to be very thick. At least .080" . This seemed to be way too much so I had them machined down to .035. which looks to be more like Beeechcraft or others I have seen. Not flying yet so no detailed specifications on the install yet. I may put a small bead of Proseal around them. Len Fitting doors ________________________________________________________________________________
Subject: Seat adjustment lever
Date: Sep 09, 2006
This seat adjustment lever is great. Just bought if from Greg, I was to busy trying to finish to build one myself. His is well made and a good design. So much better that having to reach beside the seat and pull the lever. Here is his website, check it out for yourself. http://www.nwacaptain.com/ Blue Skies Jim 40383 DAR next saturday (I hope)!!!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=60549#60549 ________________________________________________________________________________
Date: Sep 09, 2006
I deliver the plane to him with no primer and walk away. He does all the disassembling and reassembling. I check around a little bit and I think he has a fair price for the quality of work that he does. I know of one 10 builder who paid $14,000 for his paint job, ouch. I think he's charging around $6,000 for the RV6's and 8's. I just want someone to paint my plane that I know does excellent work and that's Grady. Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Re: Flywheel to cowling front distance
Date: Sep 09, 2006
Hello Ted, I will have the Aero Composite three blade but I'm guessing that would be about the same as the MT for mounting purposes? We used a 1/8" spacer. I also don't have my propeller yet but Aero Composite sent me a mount plate to use so I can fit the cowling. Maybe MT can furnish you one also? I was just working on it yesterday and the top cowling went on fairly quickly, I had help. I've attached a few photo's for you to see what we've done thus far. I'm installing cam locks and will have them spaced at around 3". Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Paint $$Build times - time to get restarted?
Date: Sep 09, 2006
I painted my RV-8A - paint alone cost $2500 (I did some hard colors). $6000 for someone to do everything sounds like a really good deal. Carl Froehlich RV-8A (270 hrs) RV-10 (tail cone) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Wayne Edgerton Sent: Saturday, September 09, 2006 7:31 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Paint $$Build times - time to get restarted? I deliver the plane to him with no primer and walk away. He does all the disassembling and reassembling. I check around a little bit and I think he has a fair price for the quality of work that he does. I know of one 10 builder who paid $14,000 for his paint job, ouch. I think he's charging around $6,000 for the RV6's and 8's. I just want someone to paint my plane that I know does excellent work and that's Grady. Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Heat selector valve
Date: Sep 09, 2006
I concur completely that Don at Aviacomp is the man to see about anything for your heating system. At my request, he redesigned the T that goes in the forward tunnel to direct the heat to the forward footwell areas, to include a selector valve. It is a drop in replacement for the original, and with the use of a cable, I can now mix the forward heat to either side, a must have requirement for my cold blooded other half, flying partner. It was a true pleasure working with Don on this very simple, yet useful mod, that Vans should offer in their accessory catalog. If you need to see a picture, email me cjhukill(at)cox.net Chris Hukill fitting the plastic wheelpants, really out of sequence (cannot believe people actually build whole airplanes out of that stuff!) ________________________________________________________________________________
Date: Sep 09, 2006
That is the reason why Grady O'Neal at GLO Custom Paint is booked up through July of 2007. I know because an RV-8 I am helping finished up just booked his paint date and the earliest he could get with Grady was July 2007!!!! If you want the best at a reasonable price you really have to plan ahead. I booked my paint date (currently in Grady's paint booth) January of 2006. Grady requires a 10% deposit to hold a paint date. Pictures should be posted by next week. Russ Daves N710RV (RV-10 Flying) ----- Original Message ----- From: Carl Froehlich To: rv10-list(at)matronics.com Sent: Saturday, September 09, 2006 7:32 AM Subject: RE: RV10-List: Paint $$Build times - time to get restarted? I painted my RV-8A - paint alone cost $2500 (I did some hard colors). $6000 for someone to do everything sounds like a really good deal. Carl Froehlich RV-8A (270 hrs) RV-10 (tail cone) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Wayne Edgerton Sent: Saturday, September 09, 2006 7:31 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Paint $$Build times - time to get restarted? I deliver the plane to him with no primer and walk away. He does all the disassembling and reassembling. I check around a little bit and I think he has a fair price for the quality of work that he does. I know of one 10 builder who paid $14,000 for his paint job, ouch. I think he's charging around $6,000 for the RV6's and 8's. I just want someone to paint my plane that I know does excellent work and that's Grady. Wayne Edgerton #40336 s.com/Navigator?RV10-List ________________________________________________________________________________
Subject: 113" fuse longeron angle - mark it "don't cut"
Date: Sep 09, 2006
I did something similar as well with the tailcone J-Channel but x 6. I trimmed all 12 to length properly with no problems but didn't look that carefully at the plans to "Trim the ends at a 45 deg angle as shown in figure 2". After I finished cutting the angle on the last of 12 I looked at the one in my hand and said... "Huh? That doesn't look right!" Sure enough I cut the 45 not from the vertical edge but the horizontal so all of them came to a point at the corner. When I squared off the now messed up edges the 6 long ones were now too short. The messed up 93"ers became the 6 shorter ones. All the others became wall art. I robbed the wing kit, which I just picked up the day before, of the 6 8' J-Channel in it. Key word is "PICKED UP". Van's is a 20 minute drive from my place. Still soaked me for $13.75 x 6 = $82.50 but no down time or expensive freight snafu's. So the lesson learned is of course read the plans more carefully before cutting anything (or move closer to Van's). -Ben #40579 Tailcone (Darn there are a lot of rivets! Should be done this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Douglas Sent: Friday, September 08, 2006 8:59 PM Subject: Re: RV10-List: 113" fuse longeron angle - mark it "don't cut" Yeah, I'm in a similar boat with a tailcone J-Channel. Like a doofus (sp?) I cut one of the 93"ers too short and had to order a new one from Vans. Naturally it shows up the Friday before a long labor day weekend bent at about 35 degrees. I called vans the following week and they sent another one which arrived today so badly bent the driver didn't even bother to wait until I opened it. Looking at the tube he just said, "Oh man, I'd better send this back." Turns out that even PVC pipe is not enough to protect parts from the shipping people, who apparently spend a good deal of time smashing things with hammers. Now I'm headed off to Reno (Dago Red is running this year!) and am wondering what the chances are that I'll find a decent 8' length of J-channel waiting on my porch when I get back. Anyway, let that be a lesson to the guys/girls just starting. Cut the long pieces first!! -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
Date: Sep 09, 2006
What page of the plans is the cutting of these pieces on so I can b -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Saturday, September 09, 2006 4:53 PM Subject: RE: RV10-List: 113" fuse longeron angle - mark it "don't cut" I did something similar as well with the tailcone J-Channel but x 6. I trimmed all 12 to length properly with no problems but didn't look that carefully at the plans to "Trim the ends at a 45 deg angle as shown in figure 2". After I finished cutting the angle on the last of 12 I looked at the one in my hand and said... "Huh? That doesn't look right!" Sure enough I cut the 45 not from the vertical edge but the horizontal so all of them came to a point at the corner. When I squared off the now messed up edges the 6 long ones were now too short. The messed up 93"ers became the 6 shorter ones. All the others became wall art. I robbed the wing kit, which I just picked up the day before, of the 6 8' J-Channel in it. Key word is "PICKED UP". Van's is a 20 minute drive from my place. Still soaked me for $13.75 x 6 = $82.50 but no down time or expensive freight snafu's. So the lesson learned is of course read the plans more carefully before cutting anything (or move closer to Van's). -Ben #40579 Tailcone (Darn there are a lot of rivets! Should be done this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Douglas Sent: Friday, September 08, 2006 8:59 PM Subject: Re: RV10-List: 113" fuse longeron angle - mark it "don't cut" Yeah, I'm in a similar boat with a tailcone J-Channel. Like a doofus (sp?) I cut one of the 93"ers too short and had to order a new one from Vans. Naturally it shows up the Friday before a long labor day weekend bent at about 35 degrees. I called vans the following week and they sent another one which arrived today so badly bent the driver didn't even bother to wait until I opened it. Looking at the tube he just said, "Oh man, I'd better send this back." Turns out that even PVC pipe is not enough to protect parts from the shipping people, who apparently spend a good deal of time smashing things with hammers. Now I'm headed off to Reno (Dago Red is running this year!) and am wondering what the chances are that I'll find a decent 8' length of J-channel waiting on my porch when I get back. Anyway, let that be a lesson to the guys/girls just starting. Cut the long pieces first!! -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
Date: Sep 09, 2006
What page of the plans are the cutting of the J-Channels on so I don't make the same mistake. Rob Hunter Elevator 40432 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Saturday, September 09, 2006 4:53 PM Subject: RE: RV10-List: 113" fuse longeron angle - mark it "don't cut" I did something similar as well with the tailcone J-Channel but x 6. I trimmed all 12 to length properly with no problems but didn't look that carefully at the plans to "Trim the ends at a 45 deg angle as shown in figure 2". After I finished cutting the angle on the last of 12 I looked at the one in my hand and said... "Huh? That doesn't look right!" Sure enough I cut the 45 not from the vertical edge but the horizontal so all of them came to a point at the corner. When I squared off the now messed up edges the 6 long ones were now too short. The messed up 93"ers became the 6 shorter ones. All the others became wall art. I robbed the wing kit, which I just picked up the day before, of the 6 8' J-Channel in it. Key word is "PICKED UP". Van's is a 20 minute drive from my place. Still soaked me for $13.75 x 6 = $82.50 but no down time or expensive freight snafu's. So the lesson learned is of course read the plans more carefully before cutting anything (or move closer to Van's). -Ben #40579 Tailcone (Darn there are a lot of rivets! Should be done this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Douglas Sent: Friday, September 08, 2006 8:59 PM Subject: Re: RV10-List: 113" fuse longeron angle - mark it "don't cut" Yeah, I'm in a similar boat with a tailcone J-Channel. Like a doofus (sp?) I cut one of the 93"ers too short and had to order a new one from Vans. Naturally it shows up the Friday before a long labor day weekend bent at about 35 degrees. I called vans the following week and they sent another one which arrived today so badly bent the driver didn't even bother to wait until I opened it. Looking at the tube he just said, "Oh man, I'd better send this back." Turns out that even PVC pipe is not enough to protect parts from the shipping people, who apparently spend a good deal of time smashing things with hammers. Now I'm headed off to Reno (Dago Red is running this year!) and am wondering what the chances are that I'll find a decent 8' length of J-channel waiting on my porch when I get back. Anyway, let that be a lesson to the guys/girls just starting. Cut the long pieces first!! -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
Date: Sep 09, 2006
Where is Grady located? Jim > > From: "Russell Daves" <dav1111(at)cox.net> > Date: 2006/09/09 Sat PM 05:00:03 EDT > To: > Subject: Re: RV10-List: Paint $$Build times - time to get restarted? > > That is the reason why Grady O'Neal at GLO Custom Paint is booked up through July of 2007. I know because an RV-8 I am helping finished up just booked his paint date and the earliest he could get with Grady was July 2007!!!! > > If you want the best at a reasonable price you really have to plan ahead. I booked my paint date (currently in Grady's paint booth) January of 2006. Grady requires a 10% deposit to hold a paint date. > > Pictures should be posted by next week. > > Russ Daves > N710RV (RV-10 Flying) > ----- Original Message ----- > From: Carl Froehlich > To: rv10-list(at)matronics.com > Sent: Saturday, September 09, 2006 7:32 AM > Subject: RE: RV10-List: Paint $$Build times - time to get restarted? > > > I painted my RV-8A - paint alone cost $2500 (I did some hard colors). $6000 for someone to do everything sounds like a really good deal. > > Carl Froehlich > RV-8A (270 hrs) > RV-10 (tail cone) > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Wayne Edgerton > Sent: Saturday, September 09, 2006 7:31 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Paint $$Build times - time to get restarted? > > > I deliver the plane to him with no primer and walk away. He does all the disassembling and reassembling. I check around a little bit and I think he has a fair price for the quality of work that he does. I know of one 10 builder who paid $14,000 for his paint job, ouch. I think he's charging around $6,000 for the RV6's and 8's. > > I just want someone to paint my plane that I know does excellent work and that's Grady. > > Wayne Edgerton #40336 > > > s.com/Navigator?RV10-List > > > > > > ________________________________________________________________________________
Date: Sep 09, 2006
Section 10 Page 5 http://www.myrv10.com/Plans/RV10_Plans_sec10-pg05.html -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Hunter Sent: Saturday, September 09, 2006 3:20 PM Subject: RE: RV10-List: 113" fuse longeron angle - mark it "don't cut" What page of the plans are the cutting of the J-Channels on so I don't make the same mistake. Rob Hunter Elevator 40432 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Saturday, September 09, 2006 4:53 PM Subject: RE: RV10-List: 113" fuse longeron angle - mark it "don't cut" I did something similar as well with the tailcone J-Channel but x 6. I trimmed all 12 to length properly with no problems but didn't look that carefully at the plans to "Trim the ends at a 45 deg angle as shown in figure 2". After I finished cutting the angle on the last of 12 I looked at the one in my hand and said... "Huh? That doesn't look right!" Sure enough I cut the 45 not from the vertical edge but the horizontal so all of them came to a point at the corner. When I squared off the now messed up edges the 6 long ones were now too short. The messed up 93"ers became the 6 shorter ones. All the others became wall art. I robbed the wing kit, which I just picked up the day before, of the 6 8' J-Channel in it. Key word is "PICKED UP". Van's is a 20 minute drive from my place. Still soaked me for $13.75 x 6 = $82.50 but no down time or expensive freight snafu's. So the lesson learned is of course read the plans more carefully before cutting anything (or move closer to Van's). -Ben #40579 Tailcone (Darn there are a lot of rivets! Should be done this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Douglas Sent: Friday, September 08, 2006 8:59 PM Subject: Re: RV10-List: 113" fuse longeron angle - mark it "don't cut" Yeah, I'm in a similar boat with a tailcone J-Channel. Like a doofus (sp?) I cut one of the 93"ers too short and had to order a new one from Vans. Naturally it shows up the Friday before a long labor day weekend bent at about 35 degrees. I called vans the following week and they sent another one which arrived today so badly bent the driver didn't even bother to wait until I opened it. Looking at the tube he just said, "Oh man, I'd better send this back." Turns out that even PVC pipe is not enough to protect parts from the shipping people, who apparently spend a good deal of time smashing things with hammers. Now I'm headed off to Reno (Dago Red is running this year!) and am wondering what the chances are that I'll find a decent 8' length of J-channel waiting on my porch when I get back. Anyway, let that be a lesson to the guys/girls just starting. Cut the long pieces first!! -Brian #40497 N211BD Iowa City, IA ________________________________________________________________________________
Date: Sep 10, 2006
He's located in Roanoke, TX, which is just a little bit north and west of the DFW airport. Here is a web address for Northwest Regional where Grady is located. http://www.nwratx.org/ Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Parking Brake Bracket fro Matco Valve
Date: Sep 10, 2006
Guys, Below are pics of my parking brake valve setup for the Matco Parking Brake valve. The bracket uses the existing holes in the firewall except for the middle 2 which are filled. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=60787#60787 Attachments: http://forums.matronics.com//files/dsc05851_107.jpg http://forums.matronics.com//files/dsc05863_609.jpg http://forums.matronics.com//files/dsc05882_138.jpg http://forums.matronics.com//files/dsc05891_551.jpg http://forums.matronics.com//files/dsc05894_348.jpg http://forums.matronics.com//files/dsc05895_815.jpg ________________________________________________________________________________
Date: Sep 10, 2006
Subject: Compressor Recommendation
Hi I am starting to set up an area in my garage that I can use as a workshop. The only power I have in the garage is a single 15 amp circuit. This powers a fridge, a freezer as well as lights, power receptacles and the garage door opener. I have a single breaker slot open on my power panel and plan to run an additional circuit. Assuming I run all my intermittent use tools (band saw / drill press) off the new circuit, will the new 15 AMP 110V circuit be sufficient for a compressor as well. If so can anyone recommend an appropriate compressor given that I will not be painting? I have read about the Husky VT6315 from Home Depot on the list, but am wondering if this is overkill for my needs. I have also read that some 15 amp compressors can cause breaker trips. Any guidance most welcome. Les RV10 wannabe ________________________________________________________________________________
Date: Sep 10, 2006
Subject: Re: Compressor Recommendation
Les, A single 15A circuit will handle a good compressor. I have a single 15A circuit for the compressor I have, which I bought 10 years ago; Its a 20 Gal. "5 HP" Coleman Black Max oil lubed, belt driven compressor which then cost me about $500; Prices are very similar today. I put "5HP" in quotes since its not really 5HP.. The marketing folks did their spin on it. The 5HP is really the power produced at the moment of the motor stalling. If it were really 5HP... Lets see: 5HP = 3,728 Watts divided by 115v equals 32.4 AMPS !!! As for breaker trips, most can be avoided by not using undersized wire from your breaker panel, and also not using any extension cord. Watch out for similar "marketing" information when looking for a compressor. -Jim 40384 Les Kearney wrote: > Hi > > > > I am starting to set up an area in my garage that I can use as a > workshop. The only power I have in the garage is a single 15 amp > circuit. This powers a fridge, a freezer as well as lights, power > receptacles and the garage door opener. > > > > I have a single breaker slot open on my power panel and plan to run an > additional circuit. Assuming I run all my intermittent use tools (band > saw / drill press) off the new circuit, will the new 15 AMP 110V > circuit be sufficient for a compressor as well. If so can anyone > recommend an appropriate compressor given that I _will not_ be > painting? I have read about the Husky VT6315 from Home Depot on the > list, but am wondering if this is overkill for my needs. I have also > read that some 15 amp compressors can cause breaker trips. > > > > Any guidance most welcome. > > > > Les > > RV10 wannabe > > > > > > > > > >* > > >* > ________________________________________________________________________________
Date: Sep 10, 2006
I bought one from Harbor Freight for $149 that is a 21 Gallon upright with 3HP motor. It's pretty quiet and has worked for me for the past 9 months. It handles riveting tasks with no problem. If I'm drilling a lot of think aluminum (like the longerons) it does kick on quite a bit, but it keeps up. The die grinder slows down some if I'm using a lot. That said, like everything from Harbor Freight,it's not the greatest quality but it works just fine (I do love my pop rivet puller from them though). I thought about investing in a higher quality compressor since I was going to use it all the time, but I chose to put my money into a great Sioux drill, two ATS Rivet guns, and Main Squeeze rivet squeezer from Cleveland.. ----- Original Message ----- From: "James Hein" <n8vim(at)arrl.net> Sent: Sunday, September 10, 2006 1:19 PM Subject: Re: RV10-List: Compressor Recommendation > > Les, > A single 15A circuit will handle a good compressor. I have a single 15A > circuit for the compressor I have, which I bought 10 years ago; Its a 20 > Gal. "5 HP" Coleman Black Max oil lubed, belt driven compressor which then > cost me about $500; Prices are very similar today. > > I put "5HP" in quotes since its not really 5HP.. The marketing folks did > their spin on it. The 5HP is really the power produced at the moment of > the motor stalling. If it were really 5HP... Lets see: 5HP = 3,728 Watts > divided by 115v equals 32.4 AMPS !!! > > As for breaker trips, most can be avoided by not using undersized wire > from your breaker panel, and also not using any extension cord. > > Watch out for similar "marketing" information when looking for a > compressor. > > -Jim 40384 > > Les Kearney wrote: > >> Hi >> >> >> I am starting to set up an area in my garage that I can use as a >> workshop. The only power I have in the garage is a single 15 amp circuit. >> This powers a fridge, a freezer as well as lights, power receptacles and >> the garage door opener. >> >> >> I have a single breaker slot open on my power panel and plan to run an >> additional circuit. Assuming I run all my intermittent use tools (band >> saw / drill press) off the new circuit, will the new 15 AMP 110V circuit >> be sufficient for a compressor as well. If so can anyone recommend an >> appropriate compressor given that I _will not_ be painting? I have read >> about the Husky VT6315 from Home Depot on the list, but am wondering if >> this is overkill for my needs. I have also read that some 15 amp >> compressors can cause breaker trips. >> >> >> Any guidance most welcome. >> >> >> Les >> >> RV10 wannabe >> >> >> >> >> >>* >> >> >>* >> > > > ________________________________________________________________________________
Date: Sep 10, 2006
You can splice J-channel with no problem. Butt 2 pieces together and overlap a splice strip about 5 rivet on each side. Treat it as a repair and use the FAA Acceptable Methods book. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Sep 10, 2006
Les Kearney wrote: > about the Husky VT6315 from Home Depot on the list, but am wondering if Hi Les, FWIW this is the unit I am using. I am running it off a single 15A circuit with no troubles. I can run a few other small items off the same circuit at the same time, but nothing much bigger without nuisance trips. The compressor itself has been great running drills, cut-off tool, etc. It is also fairly quiet, as compressors go. I'm working in an attached garage, and with the door closed you can hardly hear the compressor in the house. I highly recommend it. -Dj ________________________________________________________________________________
Date: Sep 10, 2006
Hi Everyone Many thanks for all the informative replies. Based on my review of the archives and the comments received, I will go with the Husky. Cheers Les RV10 Wannabe -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Sunday, September 10, 2006 4:02 PM Subject: Re: RV10-List: Compressor Recommendation Les Kearney wrote: > about the Husky VT6315 from Home Depot on the list, but am wondering if Hi Les, FWIW this is the unit I am using. I am running it off a single 15A circuit with no troubles. I can run a few other small items off the same circuit at the same time, but nothing much bigger without nuisance trips. The compressor itself has been great running drills, cut-off tool, etc. It is also fairly quiet, as compressors go. I'm working in an attached garage, and with the door closed you can hardly hear the compressor in the house. I highly recommend it. -Dj ________________________________________________________________________________
From: "Mike Lauritsen - Work" <mike(at)cleavelandtool.com>
Date: Sep 11, 2006
I agree, I bought mine from him and it was exactly as specified. I feel like I practically stole it from him it was such a good deal. I immediately had the key components sent in and checked all were as specified. It sat in parts for about two years then was rebuilt and it runs smoother than any engine I have experience with. Now its sitting in the corner begging me to work on the airframe :-) Two other local builders bought their engines from him and have had nothing bad to say. Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Wright Sent: Thursday, September 07, 2006 10:09 PM Subject: RE: RV10-List: Dick Waters engine Please relate your info in the forum. Having one of his engines in hand along with a pleasant process definitely needs the other side of the coin. He said to call him prior to engine run for a phone walk-through. The engine is also unconditionally guaranteed for one year from first run on the airplane. Rob Wright #392 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Thursday, September 07, 2006 6:41 PM Subject: RV10-List: Dick Waters engine anyone considering a Dick Waters engine should contact me first!!! cjhukill(at)cox.net ________________________________________________________________________________
Date: Sep 11, 2006
interestly Homedepot has the VT6315 as 5 HP as well, it's interesting because the CH VT6315 in the Campbell Hausfeld website states "2HP" for the compressor, they are the same compressor, I guess putting the "Husky" label on the compressor gives it a 3HP boost! ----- Original Message ----- From: "James Hein" <n8vim(at)arrl.net> Sent: Sunday, September 10, 2006 10:19 AM Subject: Re: RV10-List: Compressor Recommendation > > Les, > A single 15A circuit will handle a good compressor. I have a single 15A > circuit for the compressor I have, which I bought 10 years ago; Its a 20 > Gal. "5 HP" Coleman Black Max oil lubed, belt driven compressor which then > cost me about $500; Prices are very similar today. > > I put "5HP" in quotes since its not really 5HP.. The marketing folks did > their spin on it. The 5HP is really the power produced at the moment of > the motor stalling. If it were really 5HP... Lets see: 5HP = 3,728 Watts > divided by 115v equals 32.4 AMPS !!! > > As for breaker trips, most can be avoided by not using undersized wire > from your breaker panel, and also not using any extension cord. > > Watch out for similar "marketing" information when looking for a > compressor. > > -Jim 40384 > > Les Kearney wrote: > >> Hi >> >> >> I am starting to set up an area in my garage that I can use as a >> workshop. The only power I have in the garage is a single 15 amp circuit. >> This powers a fridge, a freezer as well as lights, power receptacles and >> the garage door opener. >> >> >> I have a single breaker slot open on my power panel and plan to run an >> additional circuit. Assuming I run all my intermittent use tools (band >> saw / drill press) off the new circuit, will the new 15 AMP 110V circuit >> be sufficient for a compressor as well. If so can anyone recommend an >> appropriate compressor given that I _will not_ be painting? I have read >> about the Husky VT6315 from Home Depot on the list, but am wondering if >> this is overkill for my needs. I have also read that some 15 amp >> compressors can cause breaker trips. >> >> >> Any guidance most welcome. >> >> >> Les >> >> RV10 wannabe >> >> >> >> >> >>* >> >> >>* >> > > > ________________________________________________________________________________
Subject: Compressor Recommentation
Date: Sep 11, 2006
Eaton Compressor makes a quality and capable compressor. Here is the link: http://www.eatoncompressor.com/page/page/504747.htm Kevin 40494 empennage ________________________________________________________________________________
Date: Sep 11, 2006
Sure looks like they have the right design philosophy. Are you using one? Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kilopapa(at)antelecom.net Sent: Monday, September 11, 2006 1:41 PM Subject: RV10-List: Compressor Recommentation Eaton Compressor makes a quality and capable compressor. Here is the link: http://www.eatoncompressor.com/page/page/504747.htm Kevin 40494 empennage ________________________________________________________________________________
Date: Sep 11, 2006
Subject: Compressor Recommendation - Redux
Hi Here I was already to get a Husk compressor when I can across an oil free Porter Cable compressor with the following specs: Noise 82dba Tank 26 gal Max Pressure 175 psi Two stage, direct drive, twin cylinder 3 year warranty 1.6 running HP motor Model CPFC2TV3525VP This is also a bit cheaper than the Husky VT6315. Does anyone have experience with Porter Cable products (and perhaps this model in particular)? Cheers Les RV10 Wannabe ________________________________________________________________________________
Date: Sep 11, 2006
Subject: Re: Compressor Recommendation - Redux
Oil less? Run away! Run away! It is pretty loud to boot! -Jim Les Kearney wrote: > >Hi > >Here I was already to get a Husk compressor when I can across an oil free >Porter Cable compressor with the following specs: > >Noise 82dba >Tank 26 gal >Max Pressure 175 psi >Two stage, direct drive, twin cylinder >3 year warranty >1.6 running HP motor >Model CPFC2TV3525VP > >This is also a bit cheaper than the Husky VT6315. > >Does anyone have experience with Porter Cable products (and perhaps this >model in particular)? > >Cheers > >Les >RV10 Wannabe > > > > > ________________________________________________________________________________
Date: Sep 11, 2006
Yes, I bought the 5 HP, 2 Cylinder, 80-Gallon Vertical model. Performs as described. Heavy duty. Kevin 40494 empennage > > >Sure looks like they have the right design philosophy. Are >you using one? > >Mike Lauritsen >Cleaveland Aircraft Tool >2225 First St. >Boone, Iowa 50036 >515-432-6794 >mike(at)cleavelandtool.com > > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of >kilopapa(at)antelecom.net >Sent: Monday, September 11, 2006 1:41 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Compressor Recommentation > > >Eaton Compressor makes a quality and capable compressor. >Here is the link: > >http://www.eatoncompressor.com/page/page/504747.htm > >Kevin >40494 >empennage > > >== > > ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Sep 11, 2006
That Husky is a great unit - I'd go for that one. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Finish kit - wheel fairings, cowl prep -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Monday, September 11, 2006 6:54 PM Subject: RV10-List: Compressor Recommendation - Redux Hi Here I was already to get a Husk compressor when I can across an oil free Porter Cable compressor with the following specs: Noise 82dba Tank 26 gal Max Pressure 175 psi Two stage, direct drive, twin cylinder 3 year warranty 1.6 running HP motor Model CPFC2TV3525VP This is also a bit cheaper than the Husky VT6315. Does anyone have experience with Porter Cable products (and perhaps this model in particular)? Cheers Les RV10 Wannabe -- -- ________________________________________________________________________________
Date: Sep 11, 2006
same as the Craftsman #00916778000. Which received the following review Product Reviews Overall Rating: 5 5 August 8, 2006 By toolman from Massachusetts Reliability: 5 5 Value: 5 5 Performance: 5 5 Durability: 5 5 "It's the absolute best tool i've ever bought in my life. It run all the air tools." ----- Original Message ----- From: "Les Kearney" <kearney(at)shaw.ca> Sent: Monday, September 11, 2006 3:53 PM Subject: RV10-List: Compressor Recommendation - Redux > > Hi > > Here I was already to get a Husk compressor when I can across an oil free > Porter Cable compressor with the following specs: > > Noise 82dba > Tank 26 gal > Max Pressure 175 psi > Two stage, direct drive, twin cylinder > 3 year warranty > 1.6 running HP motor > Model CPFC2TV3525VP > > This is also a bit cheaper than the Husky VT6315. > > Does anyone have experience with Porter Cable products (and perhaps this > model in particular)? > > Cheers > > Les > RV10 Wannabe > > > ________________________________________________________________________________
Date: Sep 11, 2006
If you absolutely need a vertical than you'll do fine with this but for the same money, if space allows, I would encourage another Porter-cable- but in the Craftsman quise the #00919541000, SCFM Delivery At 40 psi 8.6 SCFM SCFM Delivery At 90 psi 6.8 SCFM compared to your choice SCFM Delivery At 40 psi 5.6 SCFM SCFM Delivery At 90 psi 5.1 SCFM same price but the best CFM I have found. Just something to consider. Pascal ----- Original Message ----- From: "Les Kearney" <kearney(at)shaw.ca> Sent: Monday, September 11, 2006 3:53 PM Subject: RV10-List: Compressor Recommendation - Redux > > Hi > > Here I was already to get a Husk compressor when I can across an oil free > Porter Cable compressor with the following specs: > > Noise 82dba > Tank 26 gal > Max Pressure 175 psi > Two stage, direct drive, twin cylinder > 3 year warranty > 1.6 running HP motor > Model CPFC2TV3525VP > > This is also a bit cheaper than the Husky VT6315. > > Does anyone have experience with Porter Cable products (and perhaps this > model in particular)? > > Cheers > > Les > RV10 Wannabe > > > ________________________________________________________________________________
Date: Sep 11, 2006
Is anybody building an aircraft? The last 50+ emails have been the same compressor subject. ----- Original Message ----- From: "Pascal" <pascalreid(at)verizon.net> Sent: Monday, September 11, 2006 5:23 PM Subject: Re: RV10-List: Compressor Recommendation - Redux > > If you absolutely need a vertical than you'll do fine with this but for > the same money, if space allows, I would encourage another Porter-cable- > but in the Craftsman quise the #00919541000, > > SCFM Delivery At 40 psi 8.6 SCFM > SCFM Delivery At 90 psi 6.8 SCFM > > compared to your choice > SCFM Delivery At 40 psi 5.6 SCFM > SCFM Delivery At 90 psi 5.1 SCFM > > same price but the best CFM I have found. Just something to consider. > > Pascal > ----- Original Message ----- > From: "Les Kearney" <kearney(at)shaw.ca> > To: > Sent: Monday, September 11, 2006 3:53 PM > Subject: RV10-List: Compressor Recommendation - Redux > > >> >> Hi >> >> Here I was already to get a Husk compressor when I can across an oil free >> Porter Cable compressor with the following specs: >> >> Noise 82dba >> Tank 26 gal >> Max Pressure 175 psi >> Two stage, direct drive, twin cylinder >> 3 year warranty >> 1.6 running HP motor >> Model CPFC2TV3525VP >> >> This is also a bit cheaper than the Husky VT6315. >> >> Does anyone have experience with Porter Cable products (and perhaps this >> model in particular)? >> >> Cheers >> >> Les >> RV10 Wannabe >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 11, 2006
yes, mostly using the compressors to do so ;-) ----- Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> Sent: Monday, September 11, 2006 5:34 PM Subject: Re: RV10-List: Compressor Recommendation - Redux > > Is anybody building an aircraft? The last 50+ emails have been the same > compressor subject. > ----- Original Message ----- > From: "Pascal" <pascalreid(at)verizon.net> > To: > Sent: Monday, September 11, 2006 5:23 PM > Subject: Re: RV10-List: Compressor Recommendation - Redux > > >> >> If you absolutely need a vertical than you'll do fine with this but for >> the same money, if space allows, I would encourage another Porter-cable- >> but in the Craftsman quise the #00919541000, >> >> SCFM Delivery At 40 psi 8.6 SCFM >> SCFM Delivery At 90 psi 6.8 SCFM >> >> compared to your choice >> SCFM Delivery At 40 psi 5.6 SCFM >> SCFM Delivery At 90 psi 5.1 SCFM >> >> same price but the best CFM I have found. Just something to consider. >> >> Pascal >> ----- Original Message ----- >> From: "Les Kearney" <kearney(at)shaw.ca> >> To: >> Sent: Monday, September 11, 2006 3:53 PM >> Subject: RV10-List: Compressor Recommendation - Redux >> >> >>> >>> Hi >>> >>> Here I was already to get a Husk compressor when I can across an oil >>> free >>> Porter Cable compressor with the following specs: >>> >>> Noise 82dba >>> Tank 26 gal >>> Max Pressure 175 psi >>> Two stage, direct drive, twin cylinder >>> 3 year warranty >>> 1.6 running HP motor >>> Model CPFC2TV3525VP >>> >>> This is also a bit cheaper than the Husky VT6315. >>> >>> Does anyone have experience with Porter Cable products (and perhaps this >>> model in particular)? >>> >>> Cheers >>> >>> Les >>> RV10 Wannabe >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 11, 2006
It's obvious that all the problems in the construction of the RV-10 have been solved. Any of you newbies want to ask about shimming up the nose ribs on the VS & HS or SOMETHING besides hot, compressed air. Hey....What kinda primer youse guys and gals using? Rick S. 40185 click click...thats my relays a working!!! -----Original Message----- >From: Les Kearney <kearney(at)shaw.ca> >Sent: Sep 11, 2006 3:53 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Compressor Recommendation - Redux > > >Hi > >Here I was already to get a Husk compressor when I can across an oil free >Porter Cable compressor with the following specs: > >Noise 82dba >Tank 26 gal >Max Pressure 175 psi >Two stage, direct drive, twin cylinder >3 year warranty >1.6 running HP motor >Model CPFC2TV3525VP > >This is also a bit cheaper than the Husky VT6315. > >Does anyone have experience with Porter Cable products (and perhaps this >model in particular)? > >Cheers > >Les >RV10 Wannabe > > > ________________________________________________________________________________
Subject: Fly-in planning
Date: Sep 11, 2006
SERFI is coming up October 6-8, www.serfi.org <http://www.serfi.org/> . I'll be able to make it in the afternoon on Saturday and what I can on Friday. I may even be able to fly an Army training helicopter over there for a while and be an impromptu static display. I'd love to see some RV-10s there; it was great seeing Vic and Carol's last year. So here's to plenty of planning time to see some of you completed guys there. Rob Wright #392 Wing tips Prop to be shipped 12 Oct! ________________________________________________________________________________
Subject: Re: Fly-in planning
Date: Sep 12, 2006
Rob, we are planning on being there. We should DAR this Saturday or the next. If flyoff goes well. We will be there. Jim Wade 40383 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=61143#61143 ________________________________________________________________________________
Subject: RV10 tail kit foe sale
Date: Sep 12, 2006
One of the local builders here in the Fayetteville, NC area bought an RV10 tail kit and finished all the tail feather work, but has decided to go in another direction, so we now have a tail kit for sale. The workmanship is very good. One picture is attached. The firm asking price is $3200,00. That's less than the cost of the kit tiself, much less getting it shipped to you. If you are interested, reply off list and I'll send more pictures, and we can talk from there. David Davenport RV-6 N168DD 228 Hours ddavenport5(at)nc.rr.com ________________________________________________________________________________
Date: Sep 13, 2006
Subject: C Type Pneumatic Rivet Squeezer
Anybody using one of these? Best size, type of yokes? Tool vendor source? Thanks, Link McGarity RV6/N42GF RV10/N41GF(rsvd)/#40622 Wellington, FL (FD38) ________________________________________________________________________________
Subject: Re: C Type Pneumatic Rivet Squeezer
Date: Sep 13, 2006
A pneumatic squeezer is a must to have even at the high price. I have three different yokes, and I use all of them. I got mine from "Plane Tools." I wouldn't be without it. They dimple very well also. Dave Leikam Muskego, WI #40496 N89DA Elevators ----- Original Message ----- From: "Link McGarity" <callsign(at)bellsouth.net> Sent: Wednesday, September 13, 2006 5:08 AM Subject: RV10-List: C Type Pneumatic Rivet Squeezer > > Anybody using one of these? Best size, type of yokes? Tool vendor source? > > Thanks, > > Link McGarity > RV6/N42GF > RV10/N41GF(rsvd)/#40622 > Wellington, FL (FD38) > > > ________________________________________________________________________________
Date: Sep 13, 2006
Link, I highly recommend that you purchase one of these tools. I purchased mine from Avery and it has performed beautifully. I purchased a 3" yoke, a 4" yoke that has a narrow tip for tight spots and the longeron yoke. The 3" yoke stays on the tool most of the time and the longeron yoke comes in second when it comes to usage. The narrow tip 4" yoke isn't used as much as the other two but is definitely worth purchasing. I use it for everything. I even designed an adapter plate that converts it into a large C-frame dimpler. Personally, I couldn't imagine building a metal airplane without this tool. Dave Hertner RV-10 C-GVMH #40164 London, Ontario Canada CYXU ----- Original Message ----- From: "Link McGarity" <callsign(at)bellsouth.net> Sent: Wednesday, September 13, 2006 6:08 AM Subject: RV10-List: C Type Pneumatic Rivet Squeezer > > Anybody using one of these? Best size, type of yokes? Tool vendor source? > > Thanks, > > Link McGarity > RV6/N42GF > RV10/N41GF(rsvd)/#40622 > Wellington, FL (FD38) > > > -- > > ________________________________________________________________________________
Date: Sep 13, 2006
You betcha!! It's worth every penny. I have a 4" no-hole, a 3" regular C and a 2.5" Longeron. If I did it again I would have gone with a 3" no-hole instead of the 4. The reason being is you can use the adjustable rivet set with the three but not the 4. Oh yeah, get the adjustable ram/rivet set too. Worth it's weight in shims. Can't say enough about the value of this tool. I used it to complete all my aluminum work on the RV-10. I don't have a hand squeezer in my collection of tools. Buyer beware off E-bay only because of the few stories I have heard about getting bad ones, but they did manage to get the bad ones rebuilt for some savings over a new one if your into taking that risk. I picked mine up at http://www.rivettools.com along with their 20 piece "RV" rivet sets. These are the BEST made sets I ever used and it has all the screw dimple dies you will need as well. My dimple dies are still intact (heard of nubs breaking off some) and I found they make cleaner dimples than many of the cheaper versions if you can call $28-30 cheap! The set is $150. No affiliation with them just great service and the tool is still going strong. Rick S. 40185 -----Original Message----- >From: Link McGarity <callsign(at)bellsouth.net> >Sent: Sep 13, 2006 3:08 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: C Type Pneumatic Rivet Squeezer > > >Anybody using one of these? Best size, type of yokes? Tool vendor source? > >Thanks, > >Link McGarity >RV6/N42GF >RV10/N41GF(rsvd)/#40622 >Wellington, FL (FD38) > > ________________________________________________________________________________
Date: Sep 13, 2006
Hi Link, I purchased a reconditioned one from the Yardstore at www.yardstore.com. Have two yokes a standard 3" deep one and a 4" thin nose (has no hole in the yoke just a flat surface for forming the shop head.) From time to time I wish I had a longeron yoke. Also an adjustable set holder (it threads in and out to adjust for working thickness) is a nice touch, compared to the fixed set holders that you add washers under the set for adjustment. Both will work though. One thing to keep in mind if you look into the Yardstore is most of their squeezers come with the fixed set holder. However the adjustable sets holders are available separately from Cleveland tools as are new squeezers. Vern (40324 wings) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Link McGarity Sent: Wednesday, September 13, 2006 3:09 AM Subject: RV10-List: C Type Pneumatic Rivet Squeezer Anybody using one of these? Best size, type of yokes? Tool vendor source? Thanks, Link McGarity RV6/N42GF RV10/N41GF(rsvd)/#40622 Wellington, FL (FD38) ________________________________________________________________________________
Date: Sep 13, 2006
Cleaveland (that's me) sells them at the following link. https://www.cleavelandtoolstore.com/products.asp?dept=52 In the order of most used yokes there is the 3", 2.5" Flange (longeron), and 4" thin nose. People like the 4" thin because you can reach in a little further with it and still have the thin nose for other tight areas. Our adjustable set holder will work with all of the yokes where others only work with the 1" thick base yokes. Ours also has a 32 pitch thread in the ram so if you switch from a -3.5 to a -4 rivet it is just a half turn. No measuring needed. We will match the competitions price as long as it is the exact same item & quality. Mike Lauritsen Cleaveland Aircraft Tool 2225 First St. Boone, Iowa 50036 515-432-6794 mike(at)cleavelandtool.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sent: Wednesday, September 13, 2006 9:04 AM Subject: Re: RV10-List: C Type Pneumatic Rivet Squeezer You betcha!! It's worth every penny. I have a 4" no-hole, a 3" regular C and a 2.5" Longeron. If I did it again I would have gone with a 3" no-hole instead of the 4. The reason being is you can use the adjustable rivet set with the three but not the 4. Oh yeah, get the adjustable ram/rivet set too. Worth it's weight in shims. Can't say enough about the value of this tool. I used it to complete all my aluminum work on the RV-10. I don't have a hand squeezer in my collection of tools. Buyer beware off E-bay only because of the few stories I have heard about getting bad ones, but they did manage to get the bad ones rebuilt for some savings over a new one if your into taking that risk. I picked mine up at http://www.rivettools.com along with their 20 piece "RV" rivet sets. These are the BEST made sets I ever used and it has all the screw dimple dies you will need as well. My dimple dies are still intact (heard of nubs breaking off some) and I found they make cleaner dimples than many of the cheaper versions if you can call $28-30 cheap! The set is $150. No affiliation with them just great service and the tool is still going strong. Rick S. 40185 -----Original Message----- >From: Link McGarity <callsign(at)bellsouth.net> >Sent: Sep 13, 2006 3:08 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: C Type Pneumatic Rivet Squeezer > > >Anybody using one of these? Best size, type of yokes? Tool vendor source? > >Thanks, > >Link McGarity >RV6/N42GF >RV10/N41GF(rsvd)/#40622 >Wellington, FL (FD38) > > ________________________________________________________________________________
Date: Sep 13, 2006
I had a hand squeezer from Avery, and loved it, and had great results. Unfortunately for my check book, a close friend went on vacation and loaned me his pneumatic squeezer from Avery, and I feel in love with it. He had to pry it out of my hands when he got back. My wife ordered me one for a present and included several yokes with it, the 4" no hole, a standard 3", and the longeron yoke. The two I use most are the 4" no-hole, and the longeron. I have the adjustable set and have used it with all of the yokes and it works great. I highly recommend Avery, both for the quality and for their customer service. I bent the adjustable set, because of something I did, and they replaced it for no charge. They are also competitive on their pricing, if you find it elsewhere cheaper, just call them on the phone and they will work with you. Dan Lloyd 40269 RV10E N289DT (Reserved) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Link McGarity Sent: Wednesday, September 13, 2006 6:09 AM Subject: RV10-List: C Type Pneumatic Rivet Squeezer Anybody using one of these? Best size, type of yokes? Tool vendor source? Thanks, Link McGarity RV6/N42GF RV10/N41GF(rsvd)/#40622 Wellington, FL (FD38) ________________________________________________________________________________
Date: Sep 13, 2006
From: "Fred Williams, M.D." <drfred@cox-internet.com>
Subject: Insurance rates
The rates have to be that high to finance all the junk mail. Trolling for suckers. Fred Williams 40515 Slow build wings. Top skins on.... stall switch in lt side. ________________________________________________________________________________
Date: Sep 13, 2006
Absolutely a must have, IMO. Nothing can give a consistently driven rivet like a pneumatic squeezer with an adjustable set. I use it on every rivet I can reach. 90% of the time I leave the longeron head in. I also use it for dimpling of ribs and stingers and anything I can get at. I have a double ram squeezer thats capable of up to -6 rivets. Its a bit heavy and I wished I had bought the single ram lighter version. I dont think I've used it on anything larger than a -4. Steve 40205 > > Anybody using one of these? Best size, type of yokes? Tool vendor source? > > Thanks, -- ________________________________________________________________________________
Date: Sep 13, 2006
Subject: RV10 tail kit for sale - Southeastern NY
After much consideration and soul-searching, I have decided to put my tail kit (S/N 400022) up for sale. Rudder, VS completed, HS in progress. Vans-provided documents included. Fasteners are sorted into chests of plastic drawers. Builder's log sent via email upon request. Buyer will need to pick this up in Centerport, NY, about 30 miles east of NYC. $3000. Interested parties, please contact me via email. Larry Rachman __________________________________________________ ________________________________________________________________________________
Subject: SportAir RV Workshop Nov 18/19 Watsonville, CA
Date: Sep 14, 2006
Good News! We are scheduled for a SportAir RV workshop, November 18/19, 2006 at AirCrafters in Watsonville, CA. If you would like to attend, please go to <http://www.sportair.org/> http://www.sportair.org/ to register, or call EAA at 1-800-967-5746 for more information. Please note: The Watsonville workshop is not listed on the SportAir web page as of this morning at 10:30PDT, but I have received confirmation from EAA that the workshop is planned and will be announced soon. Thanks to all those who have expressed interest! Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 www.AirCraftersLLC.com ________________________________________________________________________________
Subject: Lurker Flies RV-10
Date: Sep 14, 2006
I have been lurking on the Yahoo and Matronix RV-10 lists for two years...couldn't bring myself to commit $100K+ without ever flying an RV. Yesterday I had the chance to fly N220RV with Mike Seager in the right seat. I can sum up the experience with what I said to Mike at the end of the flight...I gotta get me one of these! I thought perhaps the thousands of other lurkers out there might appreciate the observations of this ex-lurker. I am a 300 hour instrument pilot, current but pretty rusty from not flying much over the past few years. Even so, after an hour with Mike I felt pretty comfortable in the 10, and the five landings I made were not bad, certainly better than my average landing in a spam can. One was in a 12 knot crosswind..."right rudder, right rudder, MORE right rudder". Hey, I said I was rusty. Other observations: Lots of power, even with the 210 hp in 220RV. The 260 hp must be a rocket. Much faster than the Cessna's and Pipers I have been flying...170 mph at 10 gph at 2500 msl was one of the datapoints I remember. Stick vs. yoke a non-issue after five minutes. My only stick time was in a super cub. Stalls at all the flap and power settings were slight nose drops and slight buffet...non-events actually. No wing drop at all. 220RV has electric pitch and roll trim on the stick coolie hat. You are going to love electric trim. Even though I had a few hours in aircraft with steering by differential braking, this takes some practice to steer precisely. Landings procedures in the RV-10 are different than spam cans, and 20 knots faster than the Cessna's and Pipers I have been flying. Not harder, just different than you might be used to. I would not advise flying the RV-10 for the first time without some transition training, even if you have thousands of hours. This is my opinion with regard to safety, not insurance requirements, your mileage may vary. Mike Seager is an excellent source for transition training; his website is http://www.rvshirtsnmore.com There were several pilots taking transition training from Mike prior to first flights. Thank you for taking the time to answer my endless questions. Also, thanks to John McMahon for setting up the training in Portland, TN. This airplane is responsive yet stable, a fast load hauler yet easy to fly. Fairly roomy inside yet economical. It is hard to believe you can get all these features in one airplane. Lastly, demo flights in the RV-10 cost between $100K and $150K, depending on your engine and panel selections. Steve Roberts Alpharetta, GA ________________________________________________________________________________
Date: Sep 14, 2006
Subject: Re: Lurker Flies RV-10
Steve, Was that 170 mph IAS (indicated air speed) or TAS (true airspeed)? Thanks Ed #40525 Steven Roberts wrote: > I have been lurking on the Yahoo and Matronix RV-10 lists for two > years...couldn't bring myself to commit $100K+ without ever flying an RV. > > Yesterday I had the chance to fly N220RV with Mike Seager in the right > seat. I can sum up the experience with what I said to Mike at the end > of the flight...I gotta get me one of these! > > I thought perhaps the thousands of other lurkers out there might > appreciate the observations of this ex-lurker. > > I am a 300 hour instrument pilot, current but pretty rusty from not > flying much over the past few years. Even so, after an hour with Mike > I felt pretty comfortable in the 10, and the five landings I made were > not bad, certainly better than my average landing in a spam can. One > was in a 12 knot crosswind..."right rudder, right rudder, MORE right > rudder". Hey, I said I was rusty. Other observations: > > Lots of power, even with the 210 hp in 220RV. The 260 hp must be a > rocket. > > Much faster than the Cessna's and Pipers I have been flying...170 mph > at 10 gph at 2500 msl was one of the datapoints I remember. > > Stick vs. yoke a non-issue after five minutes. My only stick time was > in a super cub. > > Stalls at all the flap and power settings were slight nose drops and > slight buffet...non-events actually. No wing drop at all. > > 220RV has electric pitch and roll trim on the stick coolie hat. You > are going to love electric trim. > > Even though I had a few hours in aircraft with steering by > differential braking, this takes some practice to steer precisely. > > Landings procedures in the RV-10 are different than spam cans, and 20 > knots faster than the Cessna's and Pipers I have been flying. Not > harder, just different than you might be used to. I would not advise > flying the RV-10 for the first time without some transition training, > even if you have thousands of hours. This is my opinion with regard > to safety, not insurance requirements, your mileage may vary. Mike > Seager is an excellent source for transition training; his website is > http://www.rvshirtsnmore.com > > There were several pilots taking transition training from Mike prior > to first flights. Thank you for taking the time to answer my endless > questions. Also, thanks to John McMahon for setting up the training > in Portland, TN. > > This airplane is responsive yet stable, a fast load hauler yet easy to > fly. Fairly roomy inside yet economical. It is hard to believe you > can get all these features in one airplane. > > Lastly, demo flights in the RV-10 cost between $100K and $150K, > depending on your engine and panel selections. > > Steve Roberts > Alpharetta, GA > * > > > * ________________________________________________________________________________
Subject: Mike Seager Training (1M5)
Date: Sep 14, 2006
For anyone close that needs some time in the RV-10,we have some slots open on Sat 16th at Portland,Tn (1M5).. Just give me a call and I will try to get you in!!!! John McMahon Home=615-452-8742 Cell=615-336-2340 ________________________________________________________________________________
Date: Sep 14, 2006
Ed, That was 170 mph indicated. I think MP/RPM was around 23-24 squared, and we were 2500 msl. As I recall Mike said you could lean to 8-9 gph and still get 165-170 mph at higher altitudes with the four banger. They will run the Lycoming lean of peak but not the Continental. The 220RV airspeed indicator is in mph. Steve > Steve, > > Was that 170 mph IAS (indicated air speed) or TAS (true airspeed)? > > Thanks > Ed > #40525 > > Steven Roberts wrote: >> I have been lurking on the Yahoo and Matronix RV-10 lists for two >> years...couldn't bring myself to commit $100K+ without ever flying an RV. >> Yesterday I had the chance to fly N220RV with Mike Seager in the right >> seat. I can sum up the experience with what I said to Mike at the end of >> the flight...I gotta get me one of these! >> I thought perhaps the thousands of other lurkers out there might >> appreciate the observations of this ex-lurker. >> I am a 300 hour instrument pilot, current but pretty rusty from not >> flying much over the past few years. Even so, after an hour with Mike I >> felt pretty comfortable in the 10, and the five landings I made were not >> bad, certainly better than my average landing in a spam can. One was in >> a 12 knot crosswind..."right rudder, right rudder, MORE right rudder". >> Hey, I said I was rusty. Other observations: Lots of power, even with >> the 210 hp in 220RV. The 260 hp must be a rocket. >> Much faster than the Cessna's and Pipers I have been flying...170 mph at >> 10 gph at 2500 msl was one of the datapoints I remember. >> Stick vs. yoke a non-issue after five minutes. My only stick time was >> in a super cub. >> Stalls at all the flap and power settings were slight nose drops and >> slight buffet...non-events actually. No wing drop at all. 220RV has >> electric pitch and roll trim on the stick coolie hat. You are going to >> love electric trim. >> Even though I had a few hours in aircraft with steering by differential >> braking, this takes some practice to steer precisely. >> Landings procedures in the RV-10 are different than spam cans, and 20 >> knots faster than the Cessna's and Pipers I have been flying. Not >> harder, just different than you might be used to. I would not advise >> flying the RV-10 for the first time without some transition training, >> even if you have thousands of hours. This is my opinion with regard to >> safety, not insurance requirements, your mileage may vary. Mike Seager >> is an excellent source for transition training; his website is >> http://www.rvshirtsnmore.com >> There were several pilots taking transition training from Mike prior to >> first flights. Thank you for taking the time to answer my endless >> questions. Also, thanks to John McMahon for setting up the training in >> Portland, TN. >> This airplane is responsive yet stable, a fast load hauler yet easy to >> fly. Fairly roomy inside yet economical. It is hard to believe you can >> get all these features in one airplane. >> Lastly, demo flights in the RV-10 cost between $100K and $150K, >> depending on your engine and panel selections. >> Steve Roberts Alpharetta, GA >> * >> >> >> * > > > ________________________________________________________________________________
Date: Sep 14, 2006
Subject: Re: Mike Seager Training (1M5)
How much $? David M. John McMahon wrote: > For anyone close that needs some time in the RV-10,we have > some slots open on Sat 16th at Portland,Tn (1M5).. > Just give me a call and I will try to get you in!!!! > > John McMahon > Home=615-452-8742 > Cell=615-336-2340 > ________________________________________________________________________________
Date: Sep 14, 2006
It's $155 an hour + minor travel expenses (~$10 - $20) per student to cover his hotel. I spent 2.3 hours with him yesterday and just grabbed another slot on Saturday. There's an article about Mike in SA this month; I can tell you the article is dead on. He REALLY knows that RV-10, and is a real joy to fly with! Brian 40308 David M. wrote: > How much $? > > David M. > > > John McMahon wrote: >> *For anyone close that needs some time in the RV-10,we have* >> *some slots open on Sat 16th at Portland,Tn (1M5)..* >> *Just give me a call and I will try to get you in!!!!* >> ** >> * John McMahon* >> * Home=615-452-8742* >> * Cell=615-336-2340* >> > * > > > * ________________________________________________________________________________
Date: Sep 14, 2006
Steve, It was great chatting with you yesterday! I warned you that it was gonna cost you more than the $155/hr advertised! Hope to see you join the ranks soon... Brian http://www.mykitlog.com/rv10builder Steven Roberts wrote: > I have been lurking on the Yahoo and Matronix RV-10 lists for two > years...couldn't bring myself to commit $100K+ without ever flying an RV. > > Yesterday I had the chance to fly N220RV with Mike Seager in the right > seat. I can sum up the experience with what I said to Mike at the end > of the flight...I gotta get me one of these! > > I thought perhaps the thousands of other lurkers out there might > appreciate the observations of this ex-lurker. > > I am a 300 hour instrument pilot, current but pretty rusty from not > flying much over the past few years. Even so, after an hour with Mike > I felt pretty comfortable in the 10, and the five landings I made were > not bad, certainly better than my average landing in a spam can. One > was in a 12 knot crosswind..."right rudder, right rudder, MORE right > rudder". Hey, I said I was rusty. Other observations: > > Lots of power, even with the 210 hp in 220RV. The 260 hp must be a > rocket. > > Much faster than the Cessna's and Pipers I have been flying...170 mph > at 10 gph at 2500 msl was one of the datapoints I remember. > > Stick vs. yoke a non-issue after five minutes. My only stick time was > in a super cub. > > Stalls at all the flap and power settings were slight nose drops and > slight buffet...non-events actually. No wing drop at all. > > 220RV has electric pitch and roll trim on the stick coolie hat. You > are going to love electric trim. > > Even though I had a few hours in aircraft with steering by > differential braking, this takes some practice to steer precisely. > > Landings procedures in the RV-10 are different than spam cans, and 20 > knots faster than the Cessna's and Pipers I have been flying. Not > harder, just different than you might be used to. I would not advise > flying the RV-10 for the first time without some transition training, > even if you have thousands of hours. This is my opinion with regard > to safety, not insurance requirements, your mileage may vary. Mike > Seager is an excellent source for transition training; his website is > http://www.rvshirtsnmore.com > > There were several pilots taking transition training from Mike prior > to first flights. Thank you for taking the time to answer my endless > questions. Also, thanks to John McMahon for setting up the training > in Portland, TN. > > This airplane is responsive yet stable, a fast load hauler yet easy to > fly. Fairly roomy inside yet economical. It is hard to believe you > can get all these features in one airplane. > > Lastly, demo flights in the RV-10 cost between $100K and $150K, > depending on your engine and panel selections. > > Steve Roberts > Alpharetta, GA > * > > > * ________________________________________________________________________________
Date: Sep 14, 2006
$192.00 1.5 Hrs ----- Original Message ----- From: David M. To: rv10-list(at)matronics.com Sent: Thursday, September 14, 2006 3:49 PM Subject: Re: RV10-List: Mike Seager Training (1M5) How much $? David M. John McMahon wrote: For anyone close that needs some time in the RV-10,we have some slots open on Sat 16th at Portland,Tn (1M5).. Just give me a call and I will try to get you in!!!! John McMahon Home=615-452-8742 Cell=615-336-2340 ________________________________________________________________________________
Date: Sep 15, 2006
Subject: C Type Pneumatic Squeezer
Thanks to all who replied. You saved me a lot of time and probably money. Rgds, Link McGarity RV-6/N42GF(bought flying) RV-10/N41GF(Rsvd)/#40622/horiz stab FD38/Wellington, FL ________________________________________________________________________________
Date: Sep 15, 2006
Subject: Plexi Attach
Has anyone used an alternate method of attaching the windows/windscreen to the cabin cover on the -10? Any comments pro/con specifically relating to using epoxy for the bonding with an layer of cloth on top to try and prevent the paint cracking issue would be greatly appreciated. - Tom Gesele #473 ________________________________________________________________________________
Date: Sep 15, 2006
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
I gave some serious thought to using Sikaflex which is very popular with the canopy guys on the 2 seat models. For some reason I ordered the Weldon when I was batch ordering though so I guess I'll probably go with that. Michael Sausen -10 #352 Fuselage -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Gesele Sent: Friday, September 15, 2006 3:47 PM Subject: RV10-List: Plexi Attach Has anyone used an alternate method of attaching the windows/windscreen to the cabin cover on the -10? Any comments pro/con specifically relating to using epoxy for the bonding with an layer of cloth on top to try and prevent the paint cracking issue would be greatly appreciated. - Tom Gesele #473 ________________________________________________________________________________
Subject: RV10 Window Junction Cracks - Any Advise?
Date: Sep 15, 2006
this is a message about installing the windows that i had saved from awhile ago. i think this is the way i'll go. cj #40410 fuse www.perfectlygoodairplane.net -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of David McNeill Sent: Wed 6/14/2006 7:53 AM Subject: Re: RV10-List: RV10 Window Junction Cracks - Any Advise? Several things I would add to the previous message. Glassing the windows in requires at least two people. One on the inside to clear the excess and one on the outside to clear the excess insert the clecoes. Additionally it helps to have some Teflon release cloth to place over the edges to create a nice matte finish, absorb excess and a nice smooth surface for further sanding. ----- Original Message ----- From: Rick To: rv10-list(at)matronics.com Sent: Tuesday, June 13, 2006 9:20 PM Subject: Re: RV10-List: RV10 Window Junction Cracks - Any Advise? Mark, Mat be too late for you but Davis McNeill provided this tidbit that is uesed with grat sucess on Glasairs...hopefullu it will help others if you can't use it. Rick S. 40185 As provided by David: Although the procedure takes only about an hour to accomplish per window, setup and planning is substantially more.. I recommend that you do one window to get the procs correct and plan to do the windshield on a day by itself. (0) tape off the inside and outside flange area of the window using 3M Fineline (.5 width) (1) then signstrip blue on the center areas to protect the inside and outside of the window . Be generous when painting it on as this makes it easy to pull off. (2) sand the inside/outside edges of the window in the area of the flange to roughen the glass for adhesion. (3) sand the flanges of the lid; CLEAN ALL SANDED EDGES WITH ACETONE (4) prepare a set of aluminum "fingers" . Strips of .080 1" by 3" ; with a slight bend in the center. one end gets a #30 hole and the other is adequately taped. each is numbered. See the picture. (5) Trim the window to fit the frame and temporarily hold in place with the NUMBERED "fingers". Clecoes should be place about .50" outside the window. Drill #30 only through the external layer; NOT THROUGH THE LID. RETAPE OFF THE EDGES 3M FINELINE TAPE . (6) prepare a mixture of epoxy with chopped fibers and cabosil. Consistency should be peanut butter. Potlife should plan to be 30-40 minutes. We refrigerated it to further slow the cure. (7) putty the lid flanges, wet the window flanges with a small amount of catalyzed epoxy and place window in frame; holding in place with "fingers" at the preplanned locations. (8) inside person should be wiping excess putty away with a 50-50 mixture of mineral spirirts and acetone; outside person should be smoothing putty on outside flange. excess will be sanded off later. then PULL THE TAPES BEFORE IT CURES. (9) allow to cure 24 hours. (10) Inside lid , flange should be finished . If rough, tape glass and sand lightly. (11) outside the lid, RETAPE the edge at the flange line, then cover the flange with two 1" layers of glass (E-7782?). (Note this was the Glastar procedure.) Remember to pull the tape before the layered glass sets up. The windscreen on the RV10 requires a different layering of glass on the aluminum. (12) Retape the edge , then sand and fill external flange area for paint. The sanding can feather into the edge of the tape. (13) when painted , paint should cover the flange. (14) MUST BE DONE BEFORE THE MIXTURE CURES. If you accidentally get epoxy on the Plexiglas during the process, it can be safely removed using a clean cloth and the 50-50 mixture of mineral spirits and acetone. Have it handy. (15) 50-50 mixture is also good for removing any signstrip that does not come off when finally removing the protective covering before flight. http://wiki.matronics.com =========== ________________________________________________________________________________
Subject: Re: Plexi Attach
Date: Sep 15, 2006
Tom, Use this stuff. After it cures, it stays flexible somewhat. Kitfox uses this stuff to bond the ribs onto the spar. I use it to bond my skins to the ribs (and then rivet them the next day). Several of my friends have bonded their RV8 canopy's to the frame with this product. I will use it to bond my windows on my RV10. May be better than Sikaflex. Don't know for sure because I have never used Sikaflex. Picture below. You can get it at MSC. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=61899#61899 Attachments: http://forums.matronics.com//files/dsc05931_117.jpg ________________________________________________________________________________
Subject: Piano Hinges
Date: Sep 15, 2006
Guys, Here's another tip.... If you want less sag on your baggage door, use the extruded piano hinge instead of the one supplied in the kit. The extruded version is 4 times the cost but is much, much stronger! The supplied version in the kit has the eyelets rolled. As you can see from the pics, the extrusion has the eyelets closed. Also, notice in the pictures the gap between eyelets. The extrusion has less than the rolled version. I have almost 1000 hours on my RV8 and have replaced 3 eyelets on my cowl piano hinge so far. Vibration does a number on them. I will install extruded hinges on my RV10 cowl for sure! Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=61902#61902 Attachments: http://forums.matronics.com//files/dsc05960_773.jpg http://forums.matronics.com//files/dsc05959_381.jpg http://forums.matronics.com//files/dsc05957_956.jpg ________________________________________________________________________________
Subject: Re: 51% Rule saga continues
Date: Sep 15, 2006
" I am trying to be REAL here, the problem is with the FAA who will certificate multiple builds of the exact same model aircraft to the same (slow learning / dim witted) OBAM aircraft owner. The DARs are to blame, the system is flawed, " The real problem is people on this "Builders List" complaining about a non-building issue day after day and clogging my e-mail box full of their mistaken opinions!!! We are not the FAA and can not change anything by e-mail. Sorry for beating around the bush. If the "Professional Builder" is using his brain, he will NEVER buy the kit or register it in his own name. I know a few guys that do this for a living for various different kits, and they prefer to think of themselves as "builder Assist programs", and usually have their client sign paperwork that states that they are assisting and not being contracted to do all the work in accorardance with the 51% rule. The actual owner still needs to be present and do some work..... WHO CARES??? I could care less about who builds what, as long as the finished plane is airworthy and safe. They (builder assistants) certainly in most cases will be much better then i am at building, you have to get better if you assist in the same project over and over. For many builders this can be very good, as they may lack some abilities that i may have yet they have enough cash to pay someone to assit them. Good for them!!! That is a sign of financial success. As for complaining about the "intent" of the rule, WHO cares? As long as they are NOT violating the rule and building MY entire plane when i am not looking, it will never effect me. I like building, some people don't, but yet they value the resulting plane. I congratulate them for not stuping so low and buying a plane with dome rivets from Cessna and Piper. Some of you even buy quick build kits... SO WHAT? I plan to build mine myself and will not bother judging you for hiring Phillipinos to do your work... even though your cash is going off shore when there are Americans here that are willing to help you with your project!!! How's that for a spin on the situation??? Please stop clogging the list with NON building stuff that if it lands in the hands of the FAA can only serve to light a fire of some beaurocrat that is bored and may jeopardize all homebuilders if the FAA decides a policy re-write is needed. I have never seen the FAA do anything helpful to me. Please dont call the FAA and complain about any issue related to homebuilt builder assitance. I would suggest you build more and type less. Repectfully - Steve Port St. Lucie, FL RV-10 Builder #40499 Finishing the Elevators.... ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. ________________________________________________________________________________
Date: Sep 15, 2006
FYI: Attached is the info sheet from 3M on the Scotch-Weld 2216 mentioned below. Kevin 40494 tail/empennage Sent: Friday, September 15, 2006 7:55 PM Subject: RV10-List: Re: Plexi Attach > > Tom, > > Use this stuff. After it cures, it stays flexible somewhat. Kitfox uses > this stuff to bond the ribs onto the spar. I use it to bond my skins to > the ribs (and then rivet them the next day). Several of my friends have > bonded their RV8 canopy's to the frame with this product. I will use it > to bond my windows on my RV10. May be better than Sikaflex. Don't know > for sure because I have never used Sikaflex. Picture below. > > You can get it at MSC. > > Zack > > -------- > RV8 #80125 > RV10 # 40512 > http://forums.matronics.com//files/dsc05931_117.jpg > ________________________________________________________________________________
Subject: engine inspections?
Date: Sep 15, 2006
hey all - i'm looking into buying an overhauled engine from a private seller, and wondered what cost is usually associated with having an engine shop disassemble and inspect the engine? i'm looking at an 0-540 E4B5 that i want to change over to fuel injection, and also install electronic ignition instead of mags. as an ex-drag race engine builder, i have a pretty good handle on engines in general, but i've never dealt with an aircraft engine, and would rather have a professional make sure all is good. any and all advice would be GREATLY appreciated. also the engine is an O-540 E4B5, which i think is appropriate for the RV-10 from the research that i did, but if somehow i've misread or misunderstood the engine identifiers that are comparable, please, someone let me know before i waste a bunch of money! thanks in advance! cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Date: Sep 16, 2006
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
$4000 to $5000 for tear-down, inspection, and re-assembly, assuming all is okay. Don't know on changing ignition or injection. TDT -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of Chris Johnston Sent: Fri 9/15/2006 11:52 PM Subject: RV10-List: engine inspections? hey all - i'm looking into buying an overhauled engine from a private seller, and wondered what cost is usually associated with having an engine shop disassemble and inspect the engine? i'm looking at an 0-540 E4B5 that i want to change over to fuel injection, and also install electronic ignition instead of mags. as an ex-drag race engine builder, i have a pretty good handle on engines in general, but i've never dealt with an aircraft engine, and would rather have a professional make sure all is good. any and all advice would be GREATLY appreciated. also the engine is an O-540 E4B5, which i think is appropriate for the RV-10 from the research that i did, but if somehow i've misread or misunderstood the engine identifiers that are comparable, please, someone let me know before i waste a bunch of money! thanks in advance! cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: Superior's engine build program
Date: Sep 16, 2006
For any one that is interested in the Superior engine build program similar to the XP-360, as I am, I contacted them about the possibility of an XP-540 program at their build center and was very politely told that it wasn't going to happen. I don't believe they understand the potential market for the 540 series engines. If anyone else may be interested send them an email at xp360info(at)superiorairparts.com and maybe if they see enough demand for the engine, we as a community may see another alternative engine source. It never hurts to ask right. Eric 40518 SB wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=61935#61935 ________________________________________________________________________________
Date: Sep 16, 2006
Subject: mostly completed -10 for sale
Just passing a note I saw on another forum for anyone interested. Mostly complete RV-10 for sale Posted by: "edmondperry(at)sbcglobal.net" edmondperry(at)sbcglobal.net edperry64 Fri Sep 15, 2006 9:01 am (PST) A friend of mine lives in Auburn Wa and is trying to buy a hanger from a lady whose husband just passed away. He was finishing up a -10 and from the pictures it looks real nice. Glass cockpit and real clean. Not flying yet but if anybody's looking for one I will forward the info to you. I will be at the airport most of today and will respond later tonight, Ed Perry ________________________________________________________________________________
Subject: 51% Rule saga continues
Date: Sep 16, 2006
John, >>If only Rick Schrameck was on that committee I could say "Fair and Balanced". << Rick is on the committee, along with those you mentioned (thanks) and: Frank Paskiewicz, FAA Production and Airworthiness Division, AIR-200 Earl Lawrence, Experimental Aircraft Association Kim Barnette, FAA Flight Standards Service, AFS-300 Mike Brown, FAA Flight Standards Service, AFS-800 Stephen Buczynski, FAA Aircraft Certification, Van Nuys MIDO Paul Fiduccia, Small Aircraft Manufacturers Association (SAMA) Joe Gauthier, Manufacturing DAR Paul Greer, Airworthiness Law Branch, AGC-210 Donald Lausman, FAA Airworthiness Certification Branch, AIR-230 Matt Tomsheck, FAA Aircraft Certification, Cleveland MIDO Mikael Via, Glasair Brian Whitehead, Transport Canada Civil Aviation Jeremy Monnett, Sonex It's as good a representation as I could ask for. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 www.AirCraftersLLC.com ________________________________________________________________________________
Subject: Re: Superior's engine build program
Date: Sep 16, 2006
Eric, I asked them the same question about a year and a half ago and got the same response. Sad to see nothing has changed. I am also interested in doing an engine build, will probably find a local IA and do it with his help. BTW: I have not been able to post anything to the list, everything gets bounced back. If by chance this makes it on the list, is anyone else having a problem? ________________________________________________________________________________
Date: Sep 16, 2006
Ed, Can you post some pictures and price info for those of us that don't want to join the SOCAL Yahoo group? I have a friend that may be interested. Thanks, Marcus 4.5 hours to 40 hr testing complete! _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, September 16, 2006 9:43 AM Subject: RV10-List: mostly completed -10 for sale Just passing a note I saw on another forum for anyone interested. <http://groups.yahoo.com/group/SoCAL-RVlist/message/19841;_ylc=X3oDMTJydWgxM m83BF9TAzk3MzU5NzE1BGdycElkAzE4NDQ1OTUEZ3Jwc3BJZAMxNjAwMDY1NjE4BG1zZ0lkAzE5O DQxBHNlYwNkbXNnBHNsawN2bXNnBHN0aW1lAzExNTg0MDcxODg-> Mostly complete RV-10 for sale Posted by: "edmondperry(at)sbcglobal.net" edmondperry(at)sbcglobal.net <http://profiles.yahoo.com/edperry64> edperry64 Fri Sep 15, 2006 9:01 am (PST) A friend of mine lives in Auburn Wa and is trying to buy a hanger from a lady whose husband just passed away. He was finishing up a -10 and from the pictures it looks real nice. Glass cockpit and real clean. Not flying yet but if anybody's looking for one I will forward the info to you. I will be at the airport most of today and will respond later tonight, Ed Perry ________________________________________________________________________________
Date: Sep 16, 2006
Do you want an engine before 2010? better try something that already exists and is tested ----- Original Message ----- From: "Eric_Kallio" <scout019(at)msn.com> Sent: Saturday, September 16, 2006 6:42 AM Subject: RV10-List: Superior's engine build program > > For any one that is interested in the Superior engine build program > similar to the XP-360, as I am, I contacted them about the possibility of > an XP-540 program at their build center and was very politely told that it > wasn't going to happen. I don't believe they understand the potential > market for the 540 series engines. If anyone else may be interested send > them an email at xp360info(at)superiorairparts.com and maybe if they see > enough demand for the engine, we as a community may see another > alternative engine source. It never hurts to ask right. > > Eric > 40518 SB wings > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=61935#61935 > > > ________________________________________________________________________________
Subject: Need Some Advice
Date: Sep 16, 2006
I had an unfortunate accident this afternoon when one of my Quick Build wings slipped from it's cradle. As you will see from the images, the inboard leading edge was dented and the inboard end of the fuel tank was deformed. I would like to hear some thoughts on recovering from this mistake. David Maib :( #40559 /Users/davidmaib/Desktop/IMG_0835.JPG /Users/davidmaib/Desktop/IMG_0836.JPG /Users/davidmaib/Desktop/IMG_0837.JPG /Users/davidmaib/Desktop/IMG_0838.JPG /Users/davidmaib/Desktop/IMG_0839.JPG /Users/davidmaib/Desktop/IMG_0840.JPG [/img] -------- David Maib Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62020#62020 ________________________________________________________________________________
Date: Sep 16, 2006
David I wasn't able to see the pictures. You might want to resend them. Hopefully you will be able to repair the damage. Sorry to hear about it. Marc Hudson -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dmaib(at)mac.com Sent: Saturday, September 16, 2006 7:54 PM Subject: RV10-List: Need Some Advice I had an unfortunate accident this afternoon when one of my Quick Build wings slipped from it's cradle. As you will see from the images, the inboard leading edge was dented and the inboard end of the fuel tank was deformed. I would like to hear some thoughts on recovering from this mistake. David Maib :( #40559 /Users/davidmaib/Desktop/IMG_0835.JPG /Users/davidmaib/Desktop/IMG_0836.JPG /Users/davidmaib/Desktop/IMG_0837.JPG /Users/davidmaib/Desktop/IMG_0838.JPG /Users/davidmaib/Desktop/IMG_0839.JPG /Users/davidmaib/Desktop/IMG_0840.JPG [/img] -------- David Maib Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62020#62020 ________________________________________________________________________________
Date: Sep 16, 2006
Ed Can you send me some info on RV that is for sale? Thanks Marc Hudson _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, September 16, 2006 8:43 AM Subject: RV10-List: mostly completed -10 for sale Just passing a note I saw on another forum for anyone interested. <http://groups.yahoo.com/group/SoCAL-RVlist/message/19841;_ylc=X3oDMTJydWgxM m83BF9TAzk3MzU5NzE1BGdycElkAzE4NDQ1OTUEZ3Jwc3BJZAMxNjAwMDY1NjE4BG1zZ0lkAzE5O DQxBHNlYwNkbXNnBHNsawN2bXNnBHN0aW1lAzExNTg0MDcxODg-> Mostly complete RV-10 for sale Posted by: "edmondperry(at)sbcglobal.net" edmondperry(at)sbcglobal.net <http://profiles.yahoo.com/edperry64> edperry64 Fri Sep 15, 2006 9:01 am (PST) A friend of mine lives in Auburn Wa and is trying to buy a hanger from a lady whose husband just passed away. He was finishing up a -10 and from the pictures it looks real nice. Glass cockpit and real clean. Not flying yet but if anybody's looking for one I will forward the info to you. I will be at the airport most of today and will respond later tonight, Ed Perry ________________________________________________________________________________
Date: Sep 16, 2006
Subject: Unfortunate Mistake
I had an accident this afternoon when on of my RV-10 Quick Build wings slip ped off the cradle. The inboard leading edge was dented and the inboard fue l tank panel was slightly deformed. I am looking for advice on how to grace fully recover from this (completely preventable) mistake. David Maib #40559 tailcone --------------------------------------------------- Get FREE 4x6 prints from my album(s)!* View my photos! I invite you to view the following photo album(s): Photos from dmaib(at)mac.com Here's how: http://www1.snapfish.com/getimageforshare/p=103161158460842281/l=210749 510/s=57221756/t=ISH/g=73078138/otsc=SYE/otsi=SAIS 1) Visit the link below to access my photos on Snapfish. Dmaib@mac....'s photos 2) You'll be asked to type in your name and email address and then choose a password. This ensures the privacy of my pictures and also sets up your ow n password-protected account on Snapfish. If the link above does not work, highlight the link below using your cursor . Then copy and paste the link into your browser address window and hit th e "Enter" or "Return" key on your keyboard. http://www1.snapfish.com/share/p=412161158460842234/l=210746949/g=730 78138/otsc=SYE/otsi=SAIS 3) If you'd like, you can easily order reprints or enlargements of my photo s, right from Snapfish for as low as 12¢ each -- every day! Just click the "order prints" button while viewing my photos to place an order. *First-time customers only. http://www.snapfish.com/infothreefree/otsc=SYE/otsi=SAIS Snapfish - the best value in photography. ________________________________________________________________________________
Date: Sep 16, 2006
This is awesome! I'm not alone! Sorry for sounding thankful for your plight but misery loves company. I logged my event in my builder's log but didn't want to immortalize it that much so I didn't take any pics. My wing slipped off the cradle and fell the few inches to the concrete floor of my shop, denting in the extreme inboard leading edge of the fuel tank, and pushing in the non-riveted front edge tabs on the inboard rib. This, of course, broke the QB pro-seal seal bead on the tank. After calming down (:]), I looked at it and decided that the skin wasn't compromised. About a 4" segment of the leading edge was just pitted from the roughness of the concrete floor, and the LE right at the rib was dented from the impact. To fix, I used my rivet gun on a rounded block of wood held against the front edge tabs to push them back into place. In some places I used just the rivet gun itself (flush head both times) to push the AL back into place. With the basic airfoil back into shape I used scotchbrite pads to scuff/smooth the pits in the LE and then just primed it until it gets to the paint shop to keep corrosion from forming, cuz I bet there was a lot of area that was gouged past the alclad. Then I mixed up a generous batch of proseal and resealed around every conceivable area that could have been compromised from the fall. Done! Yes my very inboard section of the wing is still a little flat, but after a root fairing and a good coat of body work and paint there should be no cosmetic residue. After leak testing my fuel sender/quick drain/fuel pickup install both tanks were very satisfactory to me. Rob Wright #392 L Wing Tip -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dmaib(at)mac.com Sent: Saturday, September 16, 2006 7:54 PM Subject: RV10-List: Need Some Advice I had an unfortunate accident this afternoon when one of my Quick Build wings slipped from it's cradle. As you will see from the images, the inboard leading edge was dented and the inboard end of the fuel tank was deformed. I would like to hear some thoughts on recovering from this mistake. David Maib :( #40559 /Users/davidmaib/Desktop/IMG_0835.JPG /Users/davidmaib/Desktop/IMG_0836.JPG /Users/davidmaib/Desktop/IMG_0837.JPG /Users/davidmaib/Desktop/IMG_0838.JPG /Users/davidmaib/Desktop/IMG_0839.JPG /Users/davidmaib/Desktop/IMG_0840.JPG [/img] -------- David Maib Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62020#62020 ________________________________________________________________________________
Date: Sep 16, 2006
David, After checking out your slideshow I personally believe that you have only cosmetic problems. The leading edge tabs on my rib were literally poking through the proseal bead; I didn't see that on yours. I think reshaping the inboard part of the airfoil will be your only necessary fix, but you may want to check for torn areas in your proseal and reseal them. Rob _____ ________________________________________________________________________________
Date: Sep 16, 2006
David - Rob is real close on the complete solution. The other more distant alternative, new components and a complete rebuild which is time consuming, expensive and unnecessary. If you need more clear and concise steps at returning to the original airfoil and the exact tools (under $15.00) to effect the change, email me offline to keep the whiners down and I will list out each step for you. Rob's right about the prosealed tank seam too. There is a little mold building involved, dent removal, planishing then prime, but it can be fun and informative (useful when you come to the canopy too). Repair of hangar rash is an all too common skill with many GA aircraft. After the recovery, no one should be able to tell a thing. Structurally it is a non issue. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Wright Sent: Saturday, September 16, 2006 7:58 PM Subject: RE: RV10-List: Need Some Advice This is awesome! I'm not alone! Sorry for sounding thankful for your plight but misery loves company. I had an unfortunate accident this afternoon when one of my Quick Build wings slipped from it's cradle. As you will see from the images, the inboard leading edge was dented and the inboard end of the fuel tank was deformed. I would like to hear some thoughts on recovering from this mistake. David Maib :( #40559 /Users/davidmaib/Desktop/IMG_0835.JPG /Users/davidmaib/Desktop/IMG_0836.JPG /Users/davidmaib/Desktop/IMG_0837.JPG /Users/davidmaib/Desktop/IMG_0838.JPG /Users/davidmaib/Desktop/IMG_0839.JPG /Users/davidmaib/Desktop/IMG_0840.JPG [/img] -------- David Maib Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62020#62020 ________________________________________________________________________________
Subject: Using Sikaflex to bond windows
Date: Sep 16, 2006
Here is one of several links I found detailing the use of Sikaflex 295 UV to bond the windows. http://www.rv8.ch/search.php?query=sika&type=all&mode=search Kevin 40494 ________________________________________________________________________________
Date: Sep 16, 2006
Subject: Re: mostly completed -10 for sale
----- Original Message ----- From: terry cronin To: pascalreid(at)verizon.net Sent: Saturday, September 16, 2006 9:05 PM Subject: Re: RV10-List: mostly completed -10 for sale Forwarding response for those interested: I will give her your name, and if she gives me more info will send it your way ----- Original Message ----- From: Marcus Cooper To: rv10-list(at)matronics.com Sent: Saturday, September 16, 2006 1:00 PM Subject: RE: RV10-List: mostly completed -10 for sale Ed, Can you post some pictures and price info for those of us that don't want to join the SOCAL Yahoo group? I have a friend that may be interested. Thanks, Marcus 4.5 hours to 40 hr testing complete! ------------------------------------------------------------------------- - From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, September 16, 2006 9:43 AM To: rv10-list(at)matronics.com Subject: RV10-List: mostly completed -10 for sale Just passing a note I saw on another forum for anyone interested. Mostly complete RV-10 for sale Posted by: "edmondperry(at)sbcglobal.net" edmondperry(at)sbcglobal.net edperry64 Fri Sep 15, 2006 9:01 am (PST) A friend of mine lives in Auburn Wa and is trying to buy a hanger from a lady whose husband just passed away. He was finishing up a -10 and from the pictures it looks real nice. Glass cockpit and real clean. Not flying yet but if anybody's looking for one I will forward the info to you. I will be at the airport most of today and will respond later tonight, Ed Perry << IMGP0813.JPG >> << BOLLAERT.jpg >> << IMGP0808.JPG >> << IMGP0809.JPG >> << IMGP0810.JPG >> << IMGP0811.JPG >> << IMGP0812.JPG >> ________________________________________________________________________________
Date: Sep 17, 2006
Subject: Re: Unfortunate Mistake
I had made the same mistake on one of my wings. The solution was to wire brush all of the proseal from the affected area, then I used a plastic hammer, wood block, fluting pliers, and the rivet gun to get it all back in shape. The hardest part was getting the rib somewhat straight. It took around 4-5 hours of repair, and applying a new coat of proseal over the area. Here is a pic AFTER the repair, but before the proseal: (I was too pissed to take pics before the repair, but it looked EXACTLY like yours) -Jim 40384 (Glad to see I'm not the only one who had this accident! My wing stand now has foam padded "crash bars") dmaib(at)mac.com wrote: ________________________________________________________________________________
Subject: Alternate window adhesive
Date: Sep 17, 2006
Has anyone used one of the alternate adhesives as discussed on the RV forums for installing the windows? I am interested in hearing from those who have actually used an alternate and what they liked or didn't like of the process. Kevin 40494 tail/empennage ________________________________________________________________________________
Date: Sep 17, 2006
Just forwarding Ed's response. I play no part at all in this. ----- Original Message ----- From: edmondperry(at)sbcglobal.net To: Pascal Cc: terry cronin Sent: Saturday, September 16, 2006 7:32 PM Subject: Re: RV10-List: mostly completed -10 for sale I will forward your message to my friend. He has the contact info. Neither one of us represent the owner. Ed Perry ----- Original Message ----- From: Pascal To: edmondperry(at)sbcglobal.net Sent: Saturday, September 16, 2006 2:36 PM Subject: Fw: RV10-List: mostly completed -10 for sale Ed; Not sure you saw this, just in case. Pascal ----- Original Message ----- From: Marcus Cooper To: rv10-list(at)matronics.com Sent: Saturday, September 16, 2006 1:00 PM Subject: RE: RV10-List: mostly completed -10 for sale Ed, Can you post some pictures and price info for those of us that don't want to join the SOCAL Yahoo group? I have a friend that may be interested. Thanks, Marcus 4.5 hours to 40 hr testing complete! ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, September 16, 2006 9:43 AM To: rv10-list(at)matronics.com Subject: RV10-List: mostly completed -10 for sale Just passing a note I saw on another forum for anyone interested. Mostly complete RV-10 for sale Posted by: "edmondperry(at)sbcglobal.net" edmondperry(at)sbcglobal.net edperry64 Fri Sep 15, 2006 9:01 am (PST) A friend of mine lives in Auburn Wa and is trying to buy a hanger from a lady whose husband just passed away. He was finishing up a -10 and from the pictures it looks real nice. Glass cockpit and real clean. Not flying yet but if anybody's looking for one I will forward the info to you. I will be at the airport most of today and will respond later tonight, Ed Perry ________________________________________________________________________________
Subject: Safety Alert WD-415 weldment
Date: Sep 18, 2006
All, Here is a repost from Vic Syracuse to the VAF forum. I have not seen the message on this list but think it is essential reading for all of us. Thanks Vic for the heads up! "I thought I should let everyone know that yesterday during a preflight I noticed that the left trim tab had a little more slop in it than usual. I took off the trim cable access cover plate, and it came completely off, meaning the nut was broken from the wd-415 weldment. I know we have talked in the past about that particular piece not looking quite sturdy enough, and right now that looks to be the case. I have a little over 320 hours on the airplane. I did not notice it on my post flight Sunday, but on my preflight prior to my commute home yesterday. alk about a miracle, though, and the advantages of the RV community. I live at Mallard's Landing in Georgia, and so does Aaron Sims, another RV-10 builder who is not flying yet. Guess who's parts I got to borrow? So, I am replacing both mine and Aarons with the parts from Dave at Rivethead-aero.com. Ordered them and 4 new cover plates from Van;s last night. I would recommend to those of you who are flying that you check these regularly. Now, for my opinion on the actual safety if a failure occurs? I think the trim cables are pretty stiff. I did go ahead and make the 15 minute flight home with no problem. If both of them broke, we might have a different story, but that's only conjecture. Here's the link for the parts: <http://www.rivethead-aero.com/rv10_005.htm> Vic" ________________________________________________________________________________
Date: Sep 17, 2006
When you take it apart, see if the nut is stainless and if the plate is ferrous steel (use a magnet). I had mine break before flight and determined that if they are both stainless, you cannot break them. But there are a bunch of ones out there that are mixed metal and if you try to bent it, the nut breaks right off..... We are building a few RV-s at our airport and we checked everyone's stock. They were mixed. I called Van's and explained my findings, they replaced them for free but I don't know if they did anything behind the scenes to fix the issue. -M -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron Sent: Sunday, September 17, 2006 6:20 PM Subject: RV10-List: Safety Alert WD-415 weldment All, Here is a repost from Vic Syracuse to the VAF forum. I have not seen the message on this list but think it is essential reading for all of us. Thanks Vic for the heads up! "I thought I should let everyone know that yesterday during a preflight I noticed that the left trim tab had a little more slop in it than usual. I took off the trim cable access cover plate, and it came completely off, meaning the nut was broken from the wd-415 weldment. I know we have talked in the past about that particular piece not looking quite sturdy enough, and right now that looks to be the case. I have a little over 320 hours on the airplane. I did not notice it on my post flight Sunday, but on my preflight prior to my commute home yesterday. alk about a miracle, though, and the advantages of the RV community. I live at Mallard's Landing in Georgia, and so does Aaron Sims, another RV-10 builder who is not flying yet. Guess who's parts I got to borrow? So, I am replacing both mine and Aarons with the parts from Dave at Rivethead-aero.com. Ordered them and 4 new cover plates from Van;s last night. I would recommend to those of you who are flying that you check these regularly. Now, for my opinion on the actual safety if a failure occurs? I think the trim cables are pretty stiff. I did go ahead and make the 15 minute flight home with no problem. If both of them broke, we might have a different story, but that's only conjecture. Here's the link for the parts: <http://www.rivethead-aero.com/rv10_005.htm> Vic" ________________________________________________________________________________
Subject: Re: Safety Alert WD-415 weldment
Date: Sep 17, 2006
Guys, Deems has a few pics of the trim tab weldment on his web site at http://www.deemsrv10.com/album/CNC%20Parts/index.html Also, I included a couple of pics of the part already mounted on my trim tab cover. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62165#62165 Attachments: http://forums.matronics.com//files/dsc03925_125.jpg http://forums.matronics.com//files/dsc03924_100.jpg ________________________________________________________________________________
Subject: Re: Lycoming IO-540 300-HP engines?
Date: Sep 17, 2006
The mount & cowl supplied with the RV-10 will accept parallel valve Lycomings (either narrow or wide deck). What won't work is an angle valve engine like the IO-540-K series mentioned. The engines mentioned that are in RV-10s and achieving greater than 260 HP are all parallel valve models with various mods - higher compression pistons, cold air induction, etc. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62169#62169 ________________________________________________________________________________
Date: Sep 17, 2006
Ed Is there any why I can get the phone number of the person selling this aircraft? Thanks Marc _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Sunday, September 17, 2006 2:25 PM Subject: Re: RV10-List: mostly completed -10 for sale Just forwarding Ed's response. I play no part at all in this. ----- Original Message ----- From: edmondperry(at)sbcglobal.net Cc: terry cronin Sent: Saturday, September 16, 2006 7:32 PM Subject: Re: RV10-List: mostly completed -10 for sale I will forward your message to my friend. He has the contact info. Neither one of us represent the owner. Ed Perry ----- Original Message ----- From: Pascal <mailto:pascalreid(at)verizon.net> Sent: Saturday, September 16, 2006 2:36 PM Subject: Fw: RV10-List: mostly completed -10 for sale Ed; Not sure you saw this, just in case. Pascal ----- Original Message ----- From: Marcus Cooper <mailto:coop85(at)bellsouth.net> Sent: Saturday, September 16, 2006 1:00 PM Subject: RE: RV10-List: mostly completed -10 for sale Ed, Can you post some pictures and price info for those of us that don't want to join the SOCAL Yahoo group? I have a friend that may be interested. Thanks, Marcus 4.5 hours to 40 hr testing complete! _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, September 16, 2006 9:43 AM Subject: RV10-List: mostly completed -10 for sale Just passing a note I saw on another forum for anyone interested. <http://groups.yahoo.com/group/SoCAL-RVlist/message/19841;_ylc=X3oDMTJydWgxM m83BF9TAzk3MzU5NzE1BGdycElkAzE4NDQ1OTUEZ3Jwc3BJZAMxNjAwMDY1NjE4BG1zZ0lkAzE5O DQxBHNlYwNkbXNnBHNsawN2bXNnBHN0aW1lAzExNTg0MDcxODg-> Mostly complete RV-10 for sale Posted by: "edmondperry(at)sbcglobal.net" edmondperry(at)sbcglobal.net <http://profiles.yahoo.com/edperry64> edperry64 Fri Sep 15, 2006 9:01 am (PST) A friend of mine lives in Auburn Wa and is trying to buy a hanger from a lady whose husband just passed away. He was finishing up a -10 and from the pictures it looks real nice. Glass cockpit and real clean. Not flying yet but if anybody's looking for one I will forward the info to you. I will be at the airport most of today and will respond later tonight, Ed Perry s.com/Navigator?RV10-List ________________________________________________________________________________
Date: Sep 17, 2006
All, Remember that when Vic completed his plane the parts available were only welded on the one side of the nut. Since then the nuts come welded on both sides. Good judgment always prevails, but with the new welded type there may be no structural reason to use the extruded aftermarket brackets. Of course, they would definitely add a degree or two of reliability to early failure, even if they don't increase the actual safety of the install. For instance, did Van's perhaps design into the system the ability to overpower the weld if there were a control binding issue? No way to do that with the extruded bracket. Rob Wright #392 Wing Tips -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of zackrv8 Sent: Sunday, September 17, 2006 7:30 PM Subject: RV10-List: Re: Safety Alert WD-415 weldment Guys, Deems has a few pics of the trim tab weldment on his web site at http://www.deemsrv10.com/album/CNC%20Parts/index.html Also, I included a couple of pics of the part already mounted on my trim tab cover. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62165#62165 Attachments: http://forums.matronics.com//files/dsc03925_125.jpg http://forums.matronics.com//files/dsc03924_100.jpg ________________________________________________________________________________
Date: Sep 18, 2006
Subject: HS-1008L/R Brackets
Take care to note that dimensions on these angled aluminum parts go from 1.5" on the long side end to 1.5" at angle to 1 21/32" at short side end. Also, note that the flare is only on one side of short angle side, not both. Not a big deal if caught early. Note that Air Parts has more AA6-187-3x3, as well as Van's, hi..... Link McGarity #40622 Thanks to Deems Davis' site for great pics of these parts (images 1,4,5): http://www.deemsrv10.com/album/CNC%20Parts/index.html ________________________________________________________________________________
Date: Sep 18, 2006
Subject: Re: HS-1008L/R Brackets
Read the plans, measure twice, cut outside the finished called out dimensions and file to the finished dimensions followed by proper deburring and polishing. Consider fabricating these parts as the EDUCATIONAL part of building your aircraft. If you screw up don't make the same mistake twice ;) Given that, the trim tab brackets suck and short of brazing up the provided ones I would opt for the nicely machined ones unless I had a mill handy. Do you think buying these parts will lower your build below the %51 percent mark? They are somewhat time consuming but when you do finish them they sure are a small rewarding part of the construction process. Rick S. 40185 -----Original Message----- >From: Link McGarity <wv4i(at)bellsouth.net> >Sent: Sep 18, 2006 2:47 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: HS-1008L/R Brackets > > >Take care to note that dimensions on these angled aluminum parts go from >1.5" on the long side end to 1.5" at angle to 1 21/32" at short side >end. Also, note that the flare is only on one side of short angle side, >not both. Not a big deal if caught early. Note that Air Parts has more >AA6-187-3x3, as well as Van's, hi..... > >Link McGarity >#40622 > >Thanks to Deems Davis' site for great pics of these parts (images 1,4,5): > >http://www.deemsrv10.com/album/CNC%20Parts/index.html > > ________________________________________________________________________________
Subject: 300 HP engines
Date: Sep 18, 2006
The angle head IO-540 can be ruled out as a candidate for the -10 because of the increase in both width and weight. Additionally, don't expect 290-300 HP from the standard vertical induction (D4A5-C4B5) sump as the inlet throat is too small requiring the 'smaller' RSA-5, AFP FM200, or Precision servo, and the inlet air is heated from the oil temps and is not very efficient, regardless of compression ratio. That being said, an increase in compression of 9:1 will net you an increase of about 6-8, possibly 10 HP without any detrimental effect on the engine. But, increase the compression to say, 9.5:1 and higher, and the bearing load particularly the rod bearings, increase substantially. This will affect the TBO of the engine. In a nut shell the higher the compression, the lower the TBO of the engine. The Cold Air Induction system that some builders are opting for has a three inch opening allowing the use of a bigger fuel servo. An engine configured with Cold Air, RSA-10 or AFP 300 A servo, 9:1 compression can and has dynoed at 290 plus sea level horsepower. The Cold Air Induction won't fit under the standard Van's cowl because of the plenum chamber depth and inlet air location, but there is an alternative cowl design in the works (James Cowl). Not meaning any disrespect to John as I value his knowledge and input and have had several very meaningful conversations with him (thanks John), but there is no significant difference in weight or width between the old narrow deck and current wide deck cases. The narrow deck cases of yesteryear have screw in =BD " case studs that were anchored in one half of the cases. The newer style wide deck cases have shouldered, or body fit through bolts. Also, the narrow deck cases have a narrower cylinder stud pattern than the wide decks and require plates under the cylinder base nuts for rigidity. I hope this clarifies just a few questions. Allen Barrett BPE, Inc. www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> ________________________________ I've stopped 54,091 spam messages. You can too! One month FREE spam protection at www.cloudmark.com <http://www.cloudmark.com/spamnet?v1&rc=gjw23> <http://www.cloudmark.com/spamnet?v1&rc=gjw23> ________________________________________________________________________________
Date: Sep 18, 2006
Subject: Re: Need Some Advice
If you'd like, send me the pictures directly. Telling people how to fix such problems is actually what I do for a living ;-). JKH. On 9/16/06, dmaib(at)mac.com wrote: > > > I had an unfortunate accident this afternoon when one of my Quick Build > wings slipped from it's cradle. As you will see from the images, the inboard > leading edge was dented and the inboard end of the fuel tank was deformed. I > would like to hear some thoughts on recovering from this mistake. > > David Maib :( > #40559 > /Users/davidmaib/Desktop/IMG_0835.JPG > /Users/davidmaib/Desktop/IMG_0836.JPG > /Users/davidmaib/Desktop/IMG_0837.JPG > /Users/davidmaib/Desktop/IMG_0838.JPG > /Users/davidmaib/Desktop/IMG_0839.JPG > /Users/davidmaib/Desktop/IMG_0840.JPG > [/img] > > -------- > David Maib > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=62020#62020 > > ________________________________________________________________________________
Date: Sep 18, 2006
Hi Chris, There is a lot you can learn about an engine before paying for an inspection. 1. Get the serial number and call Lycoming with it. They can tell you any dealing they have had with the engine. 2. Buy a copy of the overhaul and maintenance manual for the engine (available through Lycoming or at www.escoaircraft.com). 3. Get an ADs list from either Lycoming or the FAA website. See if these are complied with. Some people will say these are not need because of being an experimental, but most ADs are for you safety. 4. Go to Lycoming site and make bloody sure the crankshaft is not affected by the crank AD. This is a BIG ticket item. 5. Ensure the engine doesn't have ECI Classic Cast cylinders. Again, another big ticket item with an AD on them. 6. Get third party feedback about the overhualer. Also find out if the overhaul was to new of service limits. Call the EAA chapter in the area of the overhualer and ask them if they have any experience with them. 7. Ask for copies of the overhaul receipts. Was the engine case line board? Was the cam and crank reworked, replaced? Is it undersized and by how much? Are the cylinders new over overhauled? 8. Look through the log and find out how many hours total time and times it has been overhauled? I have been told three overhauls are about all that can be expected from a case. But this was one person's opinion. Check the logs for teardown inspection (read sudden stoppage) or thing related to prop strikes. Was it repaired correctly after such an event? 9. Look at how long and how the engine has been stored. 10. Also check the engine mounts the RV-10 uses the small holed mounts #70456. 11. If the engine is mounted and running get a hot compression test and oil analysis (about $19). Check what the plugs look like. If this isn't possible get a cold compression test. If the engine is preserved, neither of these will be meaningful or possible. 12. If possible fly behind it. Check cold oil pressure and hot oil pressure note the difference between these. Are they within limit for that specific engine? 13. Try and get the N number for the plane it came out of and look it up on the NTSB website for possible accident involvement. And now the disclaimer: This list is not an all inclusive inspection list and doesn't replace an inspection. But it will help you eliminate the "also runs" from your list for very little cash. I'm not an IA or an A&P but I have been in the same position you're in and these are a few points I have gleaned. Hope this is helpful, Vern (40324 wings; left ready to close right maybe another week:) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Friday, September 15, 2006 8:53 PM Subject: RV10-List: engine inspections? hey all - i'm looking into buying an overhauled engine from a private seller, and wondered what cost is usually associated with having an engine shop disassemble and inspect the engine? i'm looking at an 0-540 E4B5 that i want to change over to fuel injection, and also install electronic ignition instead of mags. as an ex-drag race engine builder, i have a pretty good handle on engines in general, but i've never dealt with an aircraft engine, and would rather have a professional make sure all is good. any and all advice would be GREATLY appreciated. also the engine is an O-540 E4B5, which i think is appropriate for the RV-10 from the research that i did, but if somehow i've misread or misunderstood the engine identifiers that are comparable, please, someone let me know before i waste a bunch of money! thanks in advance! cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Date: Sep 18, 2006
ordered the rivethead extruded parts, as well as several of the other products he has- will be delivered today, so haven't seen the quality, but other folks say they're great. After spending several hours on the horizontal stabilizer attach brackets, then misdrilling one of the holes, $20 for the set of HS brackets is just the right prove! phil RV10 horizontal stabilizer KSLC "McGANN, Ron" wrote: All, Here is a repost from Vic Syracuse to the VAF forum. I have not seen the message on this list but think it is essential reading for all of us. Thanks Vic for the heads up! "I thought I should let everyone know that yesterday during a preflight I noticed that the left trim tab had a little more slop in it than usual. I took off the trim cable access cover plate, and it came completely off, meaning the nut was broken from the wd-415 weldment. I know we have talked in the past about that particular piece not looking quite sturdy enough, and right now that looks to be the case. I have a little over 320 hours on the airplane. I did not notice it on my post flight Sunday, but on my preflight prior to my commute home yesterday. alk about a miracle, though, and the advantages of the RV community. I live at Mallard's Landing in Georgia, and so does Aaron Sims, another RV-10 builder who is not flying yet. Guess who's parts I got to borrow? So, I am replacing both mine and Aarons with the parts from Dave at Rivethead-aero.com. Ordered them and 4 new cover plates from Van;s last night. I would recommend to those of you who are flying that you check these regularly. Now, for my opinion on the actual safety if a failure occurs? I think the trim cables are pretty stiff. I did go ahead and make the 15 minute flight home with no problem. If both of them broke, we might have a different story, but that's only conjecture. Here's the link for the parts: <http://www.rivethead-aero.com/rv10_005.htm> Vic" --------------------------------- ________________________________________________________________________________
Subject: Countersink problem
Date: Sep 18, 2006
Well I went and blew it. I was countersinking the HS 1007 and went too deep on one hole. The metal is thick enough that it's still good, but the 1/8" rivet head sits too deep. Is there such a thing as an oversized flush head rivet? I live 5 minutes from Aircraft Spruce - would they have anything? John Goodman #40572 ________________________________________________________________________________
Date: Sep 18, 2006
Just for additional info for inquiring minds, I have one of Allen=92s cold air inductions on my engine and am using Van=92s standard cowl with some modification. I am a fiberglass builder of old, Glasair III, and I don=92t think that anyone should have any trouble modifying the cowl to make the cold air induction fit. If you are interested in the specfics of the mod, e-mail me and I will fill you in. Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BPA Sent: Monday, September 18, 2006 9:56 AM Subject: RV10-List: 300 HP engines The angle head IO-540 can be ruled out as a candidate for the -10 because of the increase in both width and weight. Additionally, don=92t expect 290-300 HP from the standard vertical induction (D4A5-C4B5) sump as the inlet throat is too small requiring the =91smaller=92 RSA-5, AFP FM200, or Precision servo, and the inlet air is heated from the oil temps and is not very efficient, regardless of compression ratio. That being said, an increase in compression of 9:1 will net you an increase of about 6-8, possibly 10 HP without any detrimental effect on the engine. But, increase the compression to say, 9.5:1 and higher, and the bearing load particularly the rod bearings, increase substantially. This will affect the TBO of the engine. In a nut shell the higher the compression, the lower the TBO of the engine. The Cold Air Induction system that some builders are opting for has a three inch opening allowing the use of a bigger fuel servo. An engine configured with Cold Air, RSA-10 or AFP 300 A servo, 9:1 compression can and has dynoed at 290 plus sea level horsepower. The Cold Air Induction won=92t fit under the standard Van=92s cowl because of the plenum chamber depth and inlet air location, but there is an alternative cowl design in the works (James Cowl). Not meaning any disrespect to John as I value his knowledge and input and have had several very meaningful conversations with him (thanks John), but there is no significant difference in weight or width between the old narrow deck and current wide deck cases. The narrow deck cases of yesteryear have screw in =BD =93 case studs that were anchored in one half of the cases. The newer style wide deck cases have shouldered, or body fit through bolts. Also, the narrow deck cases have a narrower cylinder stud pattern than the wide decks and require plates under the cylinder base nuts for rigidity. I hope this clarifies just a few questions. Allen Barrett BPE, Inc. www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> _____ I've stopped 54,091 spam messages. You can too! One month FREE spam protection at www.cloudmark.com <http://www.cloudmark.com/spamnet?v1&rc=gjw23> <http://www.cloudmark.com/spamnet?v1&rc=gjw23> Cloudmark SpamNet - Join the fight against spam! ________________________________________________________________________________
Date: Sep 18, 2006
Do you have a photo of the cowling mod? Thanks, Kevin 40494 ----- Original Message Follows ----- From: "gary" <speckter(at)comcast.net> Subject: RE: RV10-List: 300 HP engines Date: Mon, 18 Sep 2006 16:55:56 -0400 >Just for additional info for inquiring minds, I have one of >Allens cold air inductions on my engine and am using Vans >standard cowl with some modification. I am a fiberglass >builder of old, Glasair III, and I dont think that anyone >should have any trouble modifying the cowl to make the cold >air induction fit. If you are interested in the specfics >of the mod, e-mail me and I will fill you in. > >Gary ________________________________________________________________________________
Date: Sep 18, 2006
Please let us folks that don't sleep with the plans know what part is the HS 1007? If this a is a spar then the skin dimples need to sit in the counter sunk hole and the countersinks need to be deeper than the heads of the rivets anyway. Make dimples in all the different thicknesses of skin material you'll be using and then you can use these gauges to determine the correct depth of your countersunk hole. Be sure to tighten your countersinker thoroughly before starting as the depth can change and metal shaving stuck in the unit can change the depth also. Again, I don't remember what is HS 1007 so maybe this doesn't apply. JG. 409 Back from summer soaring to putting on the Tail Feathers to the cone. >From: John Goodman <johngoodman(at)earthlink.net> >Reply-To: rv10-list(at)matronics.com >To: rv10-list(at)matronics.com >Subject: RV10-List: Countersink problem >Date: Mon, 18 Sep 2006 16:53:17 -0400 > > >Well I went and blew it. I was countersinking the HS 1007 and went too deep >on one hole. The metal is thick enough that it's still good, but the 1/8" >rivet head sits too deep. Is there such a thing as an oversized flush head >rivet? I live 5 minutes from Aircraft Spruce - would they have anything? > >John Goodman >#40572 > > ________________________________________________________________________________
Date: Sep 18, 2006
Subject: Re: Countersink problem
John, You can go up to the next size rivet 5/32" or AN 426-5, Spruce sells them but you may have a minimum order of .25 pound or something. Depending on how deep you countersink is it may not be that big of a deal just to go ahead with the AN4 as called out. There are lots of rivets in that plate to the spar. Going up one size will give you the most piece of mind. Rick S. 40185 Waaaaaaaaaay past the HS Spar -----Original Message----- >From: John Goodman <johngoodman(at)earthlink.net> >Sent: Sep 18, 2006 4:53 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Countersink problem > > >Well I went and blew it. I was countersinking the HS 1007 and went too >deep on one hole. The metal is thick enough that it's still good, but >the 1/8" rivet head sits too deep. Is there such a thing as an >oversized flush head rivet? I live 5 minutes from Aircraft Spruce - >would they have anything? > >John Goodman >#40572 > > ________________________________________________________________________________
Date: Sep 18, 2006
When I get back in town I will take some pix. I haven't completed the glassing yet but will send what I have. GAry -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kilopapa(at)antelecom.net Sent: Monday, September 18, 2006 5:20 PM Subject: RE: RV10-List: 300 HP engines Do you have a photo of the cowling mod? Thanks, Kevin 40494 ----- Original Message Follows ----- From: "gary" <speckter(at)comcast.net> Subject: RE: RV10-List: 300 HP engines Date: Mon, 18 Sep 2006 16:55:56 -0400 >Just for additional info for inquiring minds, I have one of >Allen's cold air inductions on my engine and am using Van's >standard cowl with some modification. I am a fiberglass >builder of old, Glasair III, and I don't think that anyone >should have any trouble modifying the cowl to make the cold >air induction fit. If you are interested in the specfics >of the mod, e-mail me and I will fill you in. > >Gary ________________________________________________________________________________
Date: Sep 18, 2006
I didn't expect such a response. I am presently out of town on business, so I will describe what I did and then take pix when I get back and get the stuff complete. I purchased a Brackett #101 filter assembly from a Cessna 175 and other aircraft (Spruce). It has sufficient surface area to handle our 260++ Hp. I made a transitional piece from the servo to the filter by gluing Styrofoam together to make a solid block that I could carve to the correct shape. After it is carved and sanded nice and smooth, I glassed it with 4 layers of glass. After cure I dissolved the foam with lacquer thinner, cleaned up the inside and cut an alternate air door in the top. I then cut away the interfering part of Van's cowl to allow me to put the lower cowl on the airframe. I then hot glued foam on the left, right and bottom side of the filter outside the present inlet scoop on Vans. I plan on making a larger exit to handle the high cyl head temps that some have seen. When I left town I had just glued the foam in place and when I get back I will carve nice curves on it and glass it in place on the outside. Then I will remove excess foam on the inside and glass it in place. Sorry if this sounds confusing. I will take pix and post them when I get back. Gary -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kilopapa(at)antelecom.net Sent: Monday, September 18, 2006 5:20 PM Subject: RE: RV10-List: 300 HP engines Do you have a photo of the cowling mod? Thanks, Kevin 40494 ----- Original Message Follows ----- From: "gary" <speckter(at)comcast.net> Subject: RE: RV10-List: 300 HP engines Date: Mon, 18 Sep 2006 16:55:56 -0400 >Just for additional info for inquiring minds, I have one of >Allen's cold air inductions on my engine and am using Van's >standard cowl with some modification. I am a fiberglass >builder of old, Glasair III, and I don't think that anyone >should have any trouble modifying the cowl to make the cold >air induction fit. If you are interested in the specfics >of the mod, e-mail me and I will fill you in. > >Gary ________________________________________________________________________________
Date: Sep 18, 2006
Thanks, I am looking forward to seeing what you have done. Kevin 40494 > > >I didn't expect such a response. I am presently out of >town on business, so I will describe what I did and then >take pix when I get back and get the stuff complete. ________________________________________________________________________________
Date: Sep 18, 2006
Subject: Will James cowl plug for RV-10
I just received several pics of the cowl plug that Will has been working on for the RV-10 w/ BPE cold air induction, There are too many pics to include in this post and in deferrance to those wth dial-up. So I'm posting them at my web site http://deemsrv10.com/ go to the photo albums and then look for the Will James Cowl folder. (They are being published as I type this). Deems Davis # 406 Fuse/Panel/Finishing http://deemsrv10.com/ ________________________________________________________________________________
Subject: Re: 300 HP engines
Date: Sep 19, 2006
Hi gary I have ordered the cold air from Barretts, and so am very interested - please send pics & details of what you did. Thanks Neil On 19 Sep 2006, at 8:55, gary wrote: > > Just for additional info for inquiring minds, I have one of Allen=92s > cold air inductions on my engine and am using Van=92s standard cowl with > some modification.- I am a fiberglass builder of old, Glasair III, and > I don=92t think that anyone should have any trouble modifying the cowl > to make the cold air induction fit.- If you are interested in the > specfics of the mod, e-mail me and I will fill you in. > - > Gary > 40274 > - > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BPA > Sent: Monday, September 18, 2006 9:56 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: 300 HP engines > - > The angle head IO-540 can be ruled out as a candidate for the -10 > because of the increase in both width and weight. Additionally, don=92t > expect 290-300 HP from the standard vertical induction (D4A5-C4B5) > sump as the inlet throat is too small requiring the =91smaller=92 RSA-5, > AFP FM200, or Precision servo, and the inlet air is heated from the > oil temps and is not very efficient, regardless of compression ratio. > That being said, an increase in compression of 9:1 will net you an > increase of about 6-8, possibly 10 HP without any detrimental effect > on the engine. But, increase the compression to say, 9.5:1 and higher, > and the bearing load particularly the rod bearings, increase > substantially. This will affect the TBO of the engine. In a nut shell > the higher the compression, the lower the TBO of the engine. The Cold > Air Induction system that some builders are opting for has a three > inch opening allowing the use of a bigger fuel servo. An engine > configured with Cold Air, RSA-10 or AFP 300 A servo, 9:1 compression > can and has dynoed at 290 plus sea level horsepower. The Cold Air > Induction won=92t fit under the standard Van=92s cowl because of the > plenum chamber depth and inlet air location, but there is an > alternative cowl design in the works (James Cowl). > - > Not meaning any disrespect to John as I value his knowledge and input > and have had several very meaningful conversations with him (thanks > John), but there is no significant difference in weight or width > between the old narrow deck and current wide deck cases. The narrow > deck cases of yesteryear have screw in =BD =93 case studs that were > anchored in one half of the cases. The newer style wide deck cases > have shouldered, or body fit through bolts. Also, the narrow deck > cases have a narrower cylinder stud pattern than the wide decks and > require plates under the cylinder base nuts for rigidity. > - > I hope this clarifies just a few questions. > - > Allen Barrett > BPE, Inc. > www.barrettprecisionengines.com > - > - > ---- > - > > - > > > I've stopped 54,091 spam messages. You can too! > One month FREE spam protection at www.cloudmark.com > - > ________________________________________________________________________________
Subject: LED Nav Lights
Date: Sep 18, 2006
Anyone install the CreativAir LED/Strobe combo lights? I'm installing both the LED/Strobe combo as well as the Van's Ldg Light kit, so looking for ideas on how to fit it all in there. Rob Wright #392 ________________________________________________________________________________
Date: Sep 18, 2006
Here's a question - Do you have to be using BPEs cold air induction to use the cowl? May sound silly, but I get the feeling that the James cowl will cool the engine better (and look cooler!) cj #40410 fuse -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Monday, September 18, 2006 5:10 PM Subject: RV10-List: Will James cowl plug for RV-10 I just received several pics of the cowl plug that Will has been working on for the RV-10 w/ BPE cold air induction, There are too many pics to include in this post and in deferrance to those wth dial-up. So I'm posting them at my web site http://deemsrv10.com/ go to the photo albums and then look for the Will James Cowl folder. (They are being published as I type this). Deems Davis # 406 Fuse/Panel/Finishing http://deemsrv10.com/ ________________________________________________________________________________
Date: Sep 18, 2006
Check edge distances and if it looks good, plant a -5 rivit in place.. I've a few in various places where I boogered drilling out a poorly driven -4 rivets. Fwiw Steve 40205 Well I went and blew it. I was countersinking the HS 1007 and went too deep on one hole. The metal is thick enough that it's still good, but the 1/8" rivet head sits too deep. Is there such a thing as an oversized flush head rivet? I live 5 minutes from Aircraft Spruce - would they have anything? John Goodman #40572 -- -- ________________________________________________________________________________
Date: Sep 18, 2006
Subject: Re: Will James cowl plug for RV-10
Will already has a cowl made for the RV-10 w/o the Barrett CAS system, you can see pics of it on his site. Deems Davis # 406 Fuse/Finishing.Panel http://deemsrv10.com/ Chris Johnston wrote: > >Here's a question - > >Do you have to be using BPEs cold air induction to use the cowl? May >sound silly, but I get the feeling that the James cowl will cool the >engine better (and look cooler!) > >cj >#40410 >fuse > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis >Sent: Monday, September 18, 2006 5:10 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Will James cowl plug for RV-10 > > >I just received several pics of the cowl plug that Will has been working > >on for the RV-10 w/ BPE cold air induction, There are too many pics to >include in this post and in deferrance to those wth dial-up. So I'm >posting them at my web site http://deemsrv10.com/ go to the photo >albums and then look for the Will James Cowl folder. (They are being >published as I type this). > >Deems Davis # 406 >Fuse/Panel/Finishing >http://deemsrv10.com/ > > > > ________________________________________________________________________________
Subject: Lycoming Thunderbolt Factory FFW "Kit" for RV-10
Date: Sep 18, 2006
I am working with the Lycoming Thunderbolt Experimental Engine Shop to develop an engine and a firewall forward "Kit" for the RV-10. They are interested in what the RV-10 builders would want in this "Kit". Some options are: IO-540 parallel valve @ 260 to 300+ bhp IO-580 angle valve @ 315 to 340+ bhp TIO-540 parallel valve @ 260 to 300+ bhp TIO-360 angle valve @ 230 to 260 bhp or......? They have all the production Lycoming parts to mix and match plus any after market parts. They are also working with Sam James on a Cowl & Cooling Plenum to fit the engine of choice. What else would you like to see in a factory supplied "Kit"? Prop, Cooler, Hoses, Mounts, Filter, Sensors, Engine Monitor, Electronic Ign and/or FI, etc..... ERic-- 40014 FFW ________________________________________________________________________________
Date: Sep 19, 2006
Subject: Re: Lycoming Thunderbolt Factory FFW "Kit" for RV-10
How about a price less than that of the complete airframe? -Jim 40384 Eric Parlow wrote: > > I am working with the Lycoming Thunderbolt Experimental Engine Shop to > develop an engine and a firewall forward "Kit" for the RV-10. > > They are interested in what the RV-10 builders would want in this "Kit". > > Some options are: > IO-540 parallel valve @ 260 to 300+ bhp > IO-580 angle valve @ 315 to 340+ bhp > TIO-540 parallel valve @ 260 to 300+ bhp > TIO-360 angle valve @ 230 to 260 bhp > or......? > They have all the production Lycoming parts to mix and match plus any > after market parts. > They are also working with Sam James on a Cowl & Cooling Plenum to fit > the engine of choice. > What else would you like to see in a factory supplied "Kit"? > Prop, Cooler, Hoses, Mounts, Filter, Sensors, Engine Monitor, > Electronic Ign and/or FI, etc..... > > ERic-- > 40014 > FFW > > ________________________________________________________________________________
Date: Sep 19, 2006
I would pretty much want the whole "soup to nuts" FF kit similar to Van's with the IO-540 parallel valve setup. Would be interested in seeing the TIO-360 setup as well. Sam James cowl and plenum would be a big plus! David Maib 40559 On Sep 18, 2006, at 10:12 PM, Eric Parlow wrote: I am working with the Lycoming Thunderbolt Experimental Engine Shop to develop an engine and a firewall forward "Kit" for the RV-10. They are interested in what the RV-10 builders would want in this "Kit". Some options are: IO-540 parallel valve @ 260 to 300+ bhp IO-580 angle valve @ 315 to 340+ bhp TIO-540 parallel valve @ 260 to 300+ bhp TIO-360 angle valve @ 230 to 260 bhp or......? They have all the production Lycoming parts to mix and match plus any after market parts. They are also working with Sam James on a Cowl & Cooling Plenum to fit the engine of choice. What else would you like to see in a factory supplied "Kit"? Prop, Cooler, Hoses, Mounts, Filter, Sensors, Engine Monitor, Electronic Ign and/or FI, etc..... ERic-- 40014 FFW ________________________________________________________________________________
Subject: Re: LED Nav Lights
Date: Sep 19, 2006
I have LED/Strobes with Van's landing light kit on N710RV (flying). I am not very good at posting pictures to Matronics but if you want a couple contact me direct at dav1111 at cox.net. Best regards, Russ Daves ----- Original Message ----- From: Rob Wright To: rv10-list(at)matronics.com Sent: Monday, September 18, 2006 7:28 PM Subject: RV10-List: LED Nav Lights Anyone install the CreativAir LED/Strobe combo lights? I'm installing both the LED/Strobe combo as well as the Van's Ldg Light kit, so looking for ideas on how to fit it all in there. Rob Wright #392 ________________________________________________________________________________
Date: Sep 19, 2006
wv4i(at)bellsouth.net wrote: > Take care to note that dimensions on these angled aluminum parts go from > 1.5" on the long side end to 1.5" at angle to 1 21/32" at short side > end. Also, note that the flare is only on one side of short angle side, > not both. Not a big deal if caught early. Note that Air Parts has more > AA6-187-3x3, as well as Van's, hi..... > > Link McGarity > #40622 > > Thanks to Deems Davis' site for great pics of these parts (images 1,4,5): > > http://www.deemsrv10.com/album/CNC%20Parts/index.html Luckily, Van's provides enough AA6... to make one more (g). John -------- #40572 Empennage N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62514#62514 ________________________________________________________________________________
Subject: Number of 10 tails?
Date: Sep 19, 2006
The Oregon Aero seats in my finish kit had s/n 314. Do you suppose that corresponds in any way to the number of finish kits delivered? Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Date: Sep 19, 2006
Guys, this is off topic but it is the only way I can get through to the list. I've been unable to post directly to the list and e-mails to the webmaster have gone unanswered. The only way to get through is by replying to previous posts. Any one with suggestions for correcting this problem? BTW: the James cowl is awesome! John Hasbrouck #40264 ________________________________________________________________________________
Date: Sep 19, 2006
That would be great if there were that many coming on line... _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Tuesday, September 19, 2006 11:19 AM Subject: RE: RV10-List: Number of 10 tails? The Oregon Aero seats in my finish kit had s/n 314. Do you suppose that corresponds in any way to the number of finish kits delivered? Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Date: Sep 19, 2006
From: "Stovall Todd Lt Col AF/A4RX" <Todd.Stovall(at)pentagon.af.mil>
John, I ordered my empacone on the 12th and ABF says it will here on Thursday. Don't have have a clue as to what my kit number is though. Is it listed somewhere? Todd -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of John Jessen Sent: Tuesday, September 19, 2006 2:42 PM Subject: RE: RV10-List: Number of 10 tails? That would be great if there were that many coming on line... _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Tuesday, September 19, 2006 11:19 AM Subject: RE: RV10-List: Number of 10 tails? The Oregon Aero seats in my finish kit had s/n 314. Do you suppose that corresponds in any way to the number of finish kits delivered? Albert Gardner Yuma, AZ 40-422 s.com/Navigator?RV10-List ________________________________________________________________________________
Subject: Re: Can't get through except by replying.
Date: Sep 19, 2006
Jesse, Nope. Same e-mail address for last five years and no others ( boring ). Can't get through to Matt either. Can't figure it out. Correct address for matronics in address book, it's worked many times before. John Hasbrouck ________________________________________________________________________________
Date: Sep 19, 2006
Subject: Cylinder head temps
I have 31 hours on my IO-540 and the oil consumption is very low. Engine monitor is an EIS 6000 and I have set the cylinder head temp limit to 435F. Problem is the #1 cylinder is 30F degrees hotter than all the others and will quickly reach its limit on an 80 degree ambient day climbing at 120mph, 25"/2600 rpm. Pushing the nose down to 140mph and backing off the power will of course help. But, its still quite a dance to just keep the temps from increasing and the aircraft climbing. The #1 cylinder is always the hottest and the #3 the coldest. From this I assume the front dam needs to be trimmed down. I talked to another pilot at Vans Homecoming and the highest CHT he has seen is 360. His high EGT's were also in the low 1300, whereas I am seeing EGT's of 1525. Cowling inlet and outlet are purely stock. I do not have the hot tunnel problem. Climbing at full rich or leaned conservately (~1250 EGT) does not seem to make much difference. What is the experience of others flying? Is the temp distribution such that the #1 is hottest and #3 coolest? Looking at my CHT & EGT is my engine monitor out of calibration? Is watching the CHT's during climb a normal activity or never of interest? Would appreciate your experiences, Bill DeRouchey billderou(at)yahoo.com flying fast, climbing slow ________________________________________________________________________________
Date: Sep 19, 2006
Bill, The CHT on cyl. #1 and #2 were running in the 415 - 420 degree range with the other cyl running under 400 degrees. I took the air dams off and the CHT on 1 and 2 are now in line with cyl 3, 4 ,5 and 6 at approx 365 - 375 degrees. I had a high EGT on a couple of cyl but after cleaning the injectors its no longer a problem. EGT's are running well below 1400 so I'm happy. I believe Lycoming recommends keeping the CHT under 400 and the EGT under 1400. I have right at 30 hours on my IO-540 also with very low oil consumption. Oil sample analysis looked good at 25 hour oil change. Mark >From: Bill DeRouchey <billderou(at)yahoo.com> >Reply-To: rv10-list(at)matronics.com >To: rv10-list(at)matronics.com >Subject: RV10-List: Cylinder head temps >Date: Tue, 19 Sep 2006 17:11:14 -0700 (PDT) > >I have 31 hours on my IO-540 and the oil consumption is very low. Engine >monitor is an EIS 6000 and I have set the cylinder head temp limit to 435F. >Problem is the #1 cylinder is 30F degrees hotter than all the others and >will quickly reach its limit on an 80 degree ambient day climbing at >120mph, 25"/2600 rpm. Pushing the nose down to 140mph and backing off the >power will of course help. But, its still quite a dance to just keep the >temps from increasing and the aircraft climbing. > > The #1 cylinder is always the hottest and the #3 the coldest. From this >I assume the front dam needs to be trimmed down. I talked to another pilot >at Vans Homecoming and the highest CHT he has seen is 360. His high EGT's >were also in the low 1300, whereas I am seeing EGT's of 1525. > > Cowling inlet and outlet are purely stock. I do not have the hot tunnel >problem. Climbing at full rich or leaned conservately (~1250 EGT) does not >seem to make much difference. > > What is the experience of others flying? Is the temp distribution such >that the #1 is hottest and #3 coolest? Looking at my CHT & EGT is my engine >monitor out of calibration? Is watching the CHT's during climb a normal >activity or never of interest? > > Would appreciate your experiences, > Bill DeRouchey > billderou(at)yahoo.com > flying fast, climbing slow > > ________________________________________________________________________________
Date: Sep 19, 2006
Subject: Re: Cylinder head temps
Bill, I had very similar CHT issues initially. My #1 cylinder was (and still is) a bit hotter than the others. I had problems with CHT over temps in a climb. The first thing I looked at was the entrance vs exit area of the cowl. I've heard recommendations that the cowl exit area should be 120 to 133% of the inlet area. This is because the air is being heated and expands on its way through. I looked at some rough estimates on the stock design and it is somewhere between 110 and 120% depending on how you estimate it. Therefore, I took the approach of increasing the exit area to about 133% of the inlet (see my post titled: My tunnel heat fix for details). Although it did reduce the heat in my tunnel, the reason for and result of the change was to reduce my CHTs in a climb. After the fix I climbed from T/O to 11500' full power at 105 knots and never saw CHTs above about 420 or so. I am reluctant to trim the #1 cylinder baffle air dam until I fly in some cold weather this winter. I don't want to create a winter over cooling problem while trying to fix a summer over heating problem. Jim 40134 In a message dated 9/19/2006 8:14:58 P.M. Eastern Daylight Time, billderou(at)yahoo.com writes: I have 31 hours on my IO-540 and the oil consumption is very low. Engine monitor is an EIS 6000 and I have set the cylinder head temp limit to 435F. Problem is the #1 cylinder is 30F degrees hotter than all the others and will quickly reach its limit on an 80 degree ambient day climbing at 120mph, 25"/2600 rpm. Pushing the nose down to 140mph and backing off the power will of course help. But, its still quite a dance to just keep the temps from increasing and the aircraft climbing. The #1 cylinder is always the hottest and the #3 the coldest. From this I assume the front dam needs to be trimmed down. I talked to another pilot at Vans Homecoming and the highest CHT he has seen is 360. His high EGT's were also in the low 1300, whereas I am seeing EGT's of 1525. Cowling inlet and outlet are purely stock. I do not have the hot tunnel problem. Climbing at full rich or leaned conservately (~1250 EGT) does not seem to make much difference. What is the experience of others flying? Is the temp distribution such that the #1 is hottest and #3 coolest? Looking at my CHT & EGT is my engine monitor out of calibration? Is watching the CHT's during climb a normal activity or never of interest? Would appreciate your experiences, Bill DeRouchey _billderou(at)yahoo.com_ (mailto:billderou(at)yahoo.com) flying fast, climbing slow (http://www.matronics.com/Navigator?RV10-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Sep 19, 2006
John or other engine guys, Can you really overcool an engine? I understand about shock cooling the insides but keeping your whole engine in a nice cool temperature environment sounds like a worthwhile goose chase. I'd keep mine at room temperature if I could help it for tolerances, TBO, etc. Rob Wright #392 Dreaming about hooking a big vacuum to the lower cowl........ _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com Sent: Tuesday, September 19, 2006 9:01 PM Subject: Re: RV10-List: Cylinder head temps Bill, I had very similar CHT issues initially. My #1 cylinder was (and still is) a bit hotter than the others. I had problems with CHT over temps in a climb. The first thing I looked at was the entrance vs exit area of the cowl. I've heard recommendations that the cowl exit area should be 120 to 133% of the inlet area. This is because the air is being heated and expands on its way through. I looked at some rough estimates on the stock design and it is somewhere between 110 and 120% depending on how you estimate it. Therefore, I took the approach of increasing the exit area to about 133% of the inlet (see my post titled: My tunnel heat fix for details). Although it did reduce the heat in my tunnel, the reason for and result of the change was to reduce my CHTs in a climb. After the fix I climbed from T/O to 11500' full power at 105 knots and never saw CHTs above about 420 or so. I am reluctant to trim the #1 cylinder baffle air dam until I fly in some cold weather this winter. I don't want to create a winter over cooling problem while trying to fix a summer over heating problem. Jim 40134 In a message dated 9/19/2006 8:14:58 P.M. Eastern Daylight Time, billderou(at)yahoo.com writes: I have 31 hours on my IO-540 and the oil consumption is very low. Engine monitor is an EIS 6000 and I have set the cylinder head temp limit to 435F. Problem is the #1 cylinder is 30F degrees hotter than all the others and will quickly reach its limit on an 80 degree ambient day climbing at 120mph, 25"/2600 rpm. Pushing the nose down to 140mph and backing off the power will of course help. But, its still quite a dance to just keep the temps from increasing and the aircraft climbing. The #1 cylinder is always the hottest and the #3 the coldest. From this I assume the front dam needs to be trimmed down. I talked to another pilot at Vans Homecoming and the highest CHT he has seen is 360. His high EGT's were also in the low 1300, whereas I am seeing EGT's of 1525. Cowling inlet and outlet are purely stock. I do not have the hot tunnel problem. Climbing at full rich or leaned conservately (~1250 EGT) does not seem to make much difference. What is the experience of others flying? Is the temp distribution such that the #1 is hottest and #3 coolest? Looking at my CHT & EGT is my engine monitor out of calibration? Is watching the CHT's during climb a normal activity or never of interest? Would appreciate your experiences, Bill DeRouchey billderou(at)yahoo.com flying fast, climbing slow ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Nav igator?RV10-List .matronics.com/">http://forums.matronics.com ronics.com/">http://wiki.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: I'm back
Date: Sep 19, 2006
ALLCON: I'm back online! No longer with Avidyne, but I stuck around long enough to get the employee discount . . . TDT 40025 tdtpilot(at)aim.com ________________________________________________________________________ Check Out the new free AIM(R) Mail -- 2 GB of storage and industry-leading spam and email virus protection. ________________________________________________________________________________
Date: Sep 19, 2006
Subject: Re: I'm back
tdtpilot(at)aim.com wrote: > ALLCON: > I'm back online! No longer with Avidyne, but I stuck around long > enough to get the employee discount . . . > > TDT > 40025 > tdtpilot(at)aim.com > ------------------------------------------------------------------------ > ** > <http://pr.atwola.com/promoclk/100122638x1081283466x1074645346/aol?redir=http%3A%2F%2Fwww%2Eaim%2Ecom%2Ffun%2Fmail%2F> *Dang! I was hoping for an inside straight into some Avidyne stuff. :) -Sean #40303 * ________________________________________________________________________________
Subject: Tru Trak Pitch Servo
Date: Sep 20, 2006
Installing my Tru Trak pitch servo, with the mod 2 torque enhanced version arm with wheel and cable and apart from the lack of installation detail, (well documented in the archives) I'm missing the centre screw to fix the wheel in place. Can anyone who may have this version, tell me how long that screw is and how is it locked or fixed in place? Tight, Loctite, lock washer, she'll be right? John 40315 (finishing) ________________________________________________________________________________
Subject: test
Date: Sep 20, 2006
Testing to see if this e-mail shows up on the list. I resubscribed but did not receive a confirmation e-mail. John Hasbrouck #40264 ________________________________________________________________________________
Subject: Baggage door cut out
Date: Sep 20, 2006
Great to have com restored! Been on last assigned heading and alt. for a while! The question that I want to ask concerns the baggage door cut out. Is there a use for it in the future plans or can I cut it up for doublers? Can't find anything in my plans so far. John Hasbrouck #40264 fuselage ________________________________________________________________________________
Date: Sep 20, 2006
In a message dated 9/17/2006 10:17:29 PM Eastern Standard Time, armywrights(at)adelphia.net writes: when Vic completed his plane the parts available were only welded on the one side of the nut. Since then the nuts come welded on both sides. Good judgment always prevails, but with the new welded type there may be no structural reason to use the extruded aftermarket brackets. The all aluminum (after kit market) parts are MUCH thicker, more threads to grip, no weld to break (or adjacent weak metal) and have a much more solid base that will accept a countersink and allow the cover plate to be dimpled and flush riveted. This is a no brainer to buy the part for a few bucks and get peace of mind and a better part. Steve Stephen G. Blank,DDS RV-10 #40499 Finishing the Elevators Cessna 170b Flyer Port St Lucie, FL 772-475-5556 cell ________________________________________________________________________________
Subject: Cutting an oval hole
Date: Sep 20, 2006
I'm in the early stages of the Horizontal Stab and the plans show cutting an oval hole in two of the leading ribs for the trim cables. the plans show the hole to be 1.5" by .5". I can think of lots of ways to do it and each one gives me nightmares of a buggered job. Any suggestions? John -------- #40572 Empennage N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62844#62844 ________________________________________________________________________________
Date: Sep 20, 2006
Subject: Re: Baggage door cut out
John, Mine is still in the scrap bin and I only need to build the doors, windows and fairings. I can't see anywhere in any other parts of the plans that it gets used. I used the trim package for doublers and such but I always eyed that piece and held off because I didn't think there was ANYWAY Van's could have just given me a free SF of aluminum :) Rick S. 40185 -----Original Message----- >From: John Hasbrouck <jhasbrouck(at)woh.rr.com> >Sent: Sep 20, 2006 2:08 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Baggage door cut out > > >Great to have com restored! Been on last assigned heading and alt. for a >while! The question that I want to ask concerns the baggage door cut out. >Is there a use for it in the future plans or can I cut it up for doublers? >Can't find anything in my plans so far. > >John Hasbrouck >#40264 fuselage > > ________________________________________________________________________________
Date: Sep 20, 2006
Subject: Re: Cutting an oval hole
John, It's only for the passing of the trim cables and not that critical. I hand drew mine and just used a uni bit in the middle then nibbled it out with a nibbler and deburred. you can pass the trim cable through to se if you have any areas that may hang up. It is fun to route these when your done, actually it's a pain but I used a clothes hanger to pull it through. Rick S. 40185 -----Original Message----- >From: johngoodman <johngoodman(at)earthlink.net> >Sent: Sep 20, 2006 2:24 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Cutting an oval hole > > >I'm in the early stages of the Horizontal Stab and the plans show cutting an oval hole in two of the leading ribs for the trim cables. the plans show the hole to be 1.5" by .5". I can think of lots of ways to do it and each one gives me nightmares of a buggered job. >Any suggestions? > >John > >-------- >#40572 Empennage >N711JG reserved > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=62844#62844 > > ________________________________________________________________________________
Date: Sep 20, 2006
John, Go here ( http://www.jessen-RV10.com ) and go to Empennage, HS, Page 8-7, then see step #4. Click on the picture to get a better view. John Jessen #40328 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Wednesday, September 20, 2006 2:25 PM Subject: RV10-List: Cutting an oval hole --> I'm in the early stages of the Horizontal Stab and the plans show cutting an oval hole in two of the leading ribs for the trim cables. the plans show the hole to be 1.5" by .5". I can think of lots of ways to do it and each one gives me nightmares of a buggered job. Any suggestions? John -------- #40572 Empennage N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62844#62844 ________________________________________________________________________________
Date: Sep 20, 2006
Rick, Tim et. al. Thanks for the reply. I also found it hard to believe Van would supply such a nice piece of scrap . On to antenna doublers I go. John Hasbrouck #40264 ________________________________________________________________________________
Date: Sep 20, 2006
John, in retrospect, this looks a lot worse than it is - like so many things on the 10. I found that the left hole needs to be enlarged anyway, to keep from cutting the trim cable housing. Others probably know better methods, but I drilled a stater hole, then cut to the line with a carbide burr on a cheap ($5.00!!) die grinder from Harbor Freight and deburred. John Ackerman 40458 wings On Sep 20, 2006, at 2:24 PM, johngoodman wrote: > > > I'm in the early stages of the Horizontal Stab and the plans show > cutting an oval hole in two of the leading ribs for the trim cables. > the plans show the hole to be 1.5" by .5". I can think of lots of ways > to do it and each one gives me nightmares of a buggered job. > Any suggestions? > > John > > -------- > #40572 Empennage > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=62844#62844 > > ________________________________________________________________________________
Date: Sep 20, 2006
Subject: Questions from a beginner
Hi As an RV10 wannabe, I am close to ordering the empennage kit. In anticipation of this I have been organizing a garage work space and reading about the required tools. To that I have a few questions for the list experts. They are: * I have been thinking of using epoxy paint on my garage floor. Application is going to be problematic as I can only do 1 bay of a 3 car garage. I am wondering if I should be putting a foam pad down (versus painting) as it will be easier on the feet when working. Any comments or recommendations as to workspace floor treatment? * With a quick build kit does the DRDT-2 hand dimpling tool still represent a worthwhile advantage over the "standard" c-frame dimplier? * Is the Cleaveland Tools "Main Squeeze" as good as they claim (versus other hand squeezers)? * I have read a number of positive posts about pneumatic squeezers. Again with a QB kit, is this a worthwhile investment? Is the use of pneumatic squeezers difficult to master? * Are their any decisions that I need to make (i.e. lighting systems etc) when completing the empennage kit? Cheers Les RV wannabe ________________________________________________________________________________
Subject: Re: Questions from a beginner
Date: Sep 20, 2006
Hi Les, I'm in a two car garage, built all thru the wings on just one side, the fuse needed both halves. See the rest below. Rick S. 40185 ----- Original Message ----- From: Les Kearney To: rv10-list(at)matronics.com Sent: Wednesday, September 20, 2006 8:29 PM Subject: RV10-List: Questions from a beginner Hi As an RV10 wannabe, I am close to ordering the empennage kit. In anticipation of this I have been organizing a garage work space and reading about the required tools. To that I have a few questions for the list experts. They are: =B7 I have been thinking of using epoxy paint on my garage floor. Application is going to be problematic as I can only do 1 bay of a 3 car garage. I am wondering if I should be putting a foam pad down (versus painting) as it will be easier on the feet when working. Any comments or recommendations as to workspace floor treatment? I painted my floor with Rustolium garage floor kit, but it takes more than they say...needed? Not really If I were to do it again I would hire a pro and have it done with commercial epoxy urethane. I did put down interlocking floor matts and found them to be very beneficial for the legs and feet. Picked them up at Sears. =B7 With a quick build kit does the DRDT-2 hand dimpling tool still represent a worthwhile advantage over the "standard" c-frame dimplier? I used the standard C-frame but everyone I talked to said they love the DRDT-2. I would go with the DRDT if I were to do it again just for the noise factor!!! =B7 Is the Cleaveland Tools "Main Squeeze" as good as they claim (versus other hand squeezers)? Don't know, I used a pneumatic squeezer from start to finish and you would have to pry that from my cold dead hands, it's that good. =B7 I have read a number of positive posts about pneumatic squeezers. Again with a QB kit, is this a worthwhile investment? Is the use of pneumatic squeezers difficult to master? I'm slow build....I would still get it, sell it in an hour on the RV list when your done, they are in demand when used and from another RV builder...that good...really. =B7 Are their any decisions that I need to make (i.e. lighting systems etc) when completing the empennage kit? Lighting? not really but wiring for it yes, static ports and runs. Others will chime but for the tail if you can do your wiring runs and put in your rudder cables before the top is on it's easier. I crawled into mine later..not that big of a deal. Maybe your antennas could be drilled and doublers put in, strobe power pack mounts if your putting it in there. lot of little but doable later things. Cheers Les RV wannabe ________________________________________________________________________________
Date: Sep 21, 2006
Subject: Carbon Fiber tape
I was discussing HOW to put the windows in the rV 10 with a guy currentl y building a Lancair IV retract/pressurized. He suggested putting 1 1/2 inch wide Carbon Fiber tape over the window edges to help prevent them from cracking. He also said he would put it over the seam between the c abin cover and fuselage and the cabin cover and empenage. Does any one have experience with Carbon tape? I knwo West Systems sells some that is compatitble with their epoxy. Would this be a good idea? What has everbody used to fill in the seam between the cabin cover and fuselage/e mpenage? I think Microballoons would eventually crack in these areas. VIC.........are you seeing any stress cracks on your plane? What did you use in these areas? Thanks, DEAN 40449 Cowling/Baffling ________________________________________________________________________
I was discussing HOW to put the windows in the rV 10 with a guy currently building a Lancair IV retract/pressurized.  He suggested putting 1 1/2 inch wide Carbon Fiber tape over the window edges to help prevent them from cracking.  He also said he would put it over the seam between the cabin cover and fuselage and the cabin cover and empen age.   Does any one have experience with Carbon tape?  I knwo West Systems sells some that is compatitble with their epoxy.  Would this be a good idea?   What has everbody used to fill i n the seam between the cabin cover and fuselage/empenage?   I think Microballoons would eventually crack in these areas.   V IC.........are you seeing any stress cracks on your plane?  What di d you use in these areas?
DEAN
______________________ __________________________________________________
Visit http://www.juno.com/value to sign up today!
Subject: Re: Carbon Fiber tape
Date: Sep 20, 2006
Far better to use fiberglass (see my previous posting) especially where the tape would be put over aluminum. Carbon fiber on alumiuium is corrosive. ----- Original Message ----- From: ddddsp1(at)juno.com To: rv10-list(at)matronics.com Sent: Wednesday, September 20, 2006 10:05 PM Subject: RV10-List: Carbon Fiber tape I was discussing HOW to put the windows in the rV 10 with a guy currently building a Lancair IV retract/pressurized. He suggested putting 1 1/2 inch wide Carbon Fiber tape over the window edges to help prevent them from cracking. He also said he would put it over the seam between the cabin cover and fuselage and the cabin cover and empenage. Does any one have experience with Carbon tape? I knwo West Systems sells some that is compatitble with their epoxy. Would this be a good idea? What has everbody used to fill in the seam between the cabin cover and fuselage/empenage? I think Microballoons would eventually crack in these areas. VIC.........are you seeing any stress cracks on your plane? What did you use in these areas? Thanks, DEAN 40449 Cowling/Baffling ________________________________________________________________________ ________________________________________________________________________________
Date: Sep 21, 2006
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
I'm at the same stage John, and will cut those holes tonight. I plan to use a hole saw and then elongate the holes with a rat-tail file. Jack Phillips #40610 N142KW reserved -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Wednesday, September 20, 2006 5:25 PM Subject: RV10-List: Cutting an oval hole I'm in the early stages of the Horizontal Stab and the plans show cutting an oval hole in two of the leading ribs for the trim cables. the plans show the hole to be 1.5" by .5". I can think of lots of ways to do it and each one gives me nightmares of a buggered job. Any suggestions? John -------- #40572 Empennage N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=62844#62844 _________________________________________________ ________________________________________________________________________________
Date: Sep 21, 2006
A file didn't work so well for me - I used a step drill and a dremel tool. Worked great but was loud! ----- Original Message ----- From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com> Sent: Thursday, September 21, 2006 7:26 AM Subject: RE: RV10-List: Cutting an oval hole > > > I'm at the same stage John, and will cut those holes tonight. I plan to > use a hole saw and then elongate the holes with a rat-tail file. > > Jack Phillips > #40610 > N142KW reserved > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman > Sent: Wednesday, September 20, 2006 5:25 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Cutting an oval hole > > > > I'm in the early stages of the Horizontal Stab and the plans show > cutting an oval hole in two of the leading ribs for the trim cables. the > plans show the hole to be 1.5" by .5". I can think of lots of ways to do > it and each one gives me nightmares of a buggered job. > Any suggestions? > > John > > -------- > #40572 Empennage > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=62844#62844 > > > _________________________________________________ > > > ________________________________________________________________________________
Date: Sep 21, 2006
Les, Welcome! First of all, just do it! order that kit! I have the "Main Squeeze" and it is light-years ahead of any of the other squeezers. It's light, and it's very easy to squeeze with. I had planned on buying a pneumatic squeezer but so far I haven't needed it (working on Tailcone) - the MS is so simple to squeeze. I also have the DRDT-2 and a highly recommend it. It's way easier (and quieter) than the C-Frame. It's also an extremely well-made tool. Good luck! Jeff ----- Original Message ----- From: Les Kearney To: rv10-list(at)matronics.com Sent: Wednesday, September 20, 2006 11:29 PM Subject: RV10-List: Questions from a beginner Hi As an RV10 wannabe, I am close to ordering the empennage kit. In anticipation of this I have been organizing a garage work space and reading about the required tools. To that I have a few questions for the list experts. They are: =B7 I have been thinking of using epoxy paint on my garage floor. Application is going to be problematic as I can only do 1 bay of a 3 car garage. I am wondering if I should be putting a foam pad down (versus painting) as it will be easier on the feet when working. Any comments or recommendations as to workspace floor treatment? =B7 With a quick build kit does the DRDT-2 hand dimpling tool still represent a worthwhile advantage over the "standard" c-frame dimplier? =B7 Is the Cleaveland Tools "Main Squeeze" as good as they claim (versus other hand squeezers)? =B7 I have read a number of positive posts about pneumatic squeezers. Again with a QB kit, is this a worthwhile investment? Is the use of pneumatic squeezers difficult to master? =B7 Are their any decisions that I need to make (i.e. lighting systems etc) when completing the empennage kit? Cheers Les RV wannabe ________________________________________________________________________________
Date: Sep 21, 2006
> > > I have been thinking of using epoxy paint on my garage > floor. Application is going to be problematic as I can only do 1 bay > of a 3 car garage. I am wondering if I should be putting a foam pad > down (versus painting) as it will be easier on the feet when working. > Any comments or recommendations as to workspace floor treatment? > Hi Les, I bought some foam pad flooring at Sam's Club (or similar) and it has made a world of difference in my ability to stand and work at the bench for hours on end. It comes in approximately 2 foot square pieces that have interlocking tabs around the edges, so you just hook them together in whatever pattern you want on your floor. I don't have the packaging anymore or I would send you the brand name, but you should be able to find this at Walmart or similar, perhaps even an autoparts store. Not very expensive, either, which is a nice bonus. > > > Is the Cleaveland Tools Main Squeeze as good as they claim > (versus other hand squeezers)? > YES!!! I love this hand squeezer. It is very easy to use. I don't have a pneumatic squeezer, and have been using the Main Squeeze for everything that I can get a squeezer on, otherwise buck buck buck... :-) -Dj ________________________________________________________________________________
Date: Sep 21, 2006
I'd like to thank everyone for the quick responses and good ideas. I've been looking at the Uni Bit thinking it was the solution, but now I'm gonna go for it. I really appreciated the JJessen web site - you have a new lurker [Wink] -------- #40572 Empennage N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63020#63020 ________________________________________________________________________________
Date: Sep 21, 2006
Les, Definitely get the foam pad. I have some and will definitely get more. I spend a lot of time on my feet on this project. I've also used a lot of scrap carpet to keep off the hard concrete. Don't forget a chair. You can't have too much light. John [quote="kearney(at)shaw.ca"]Hi As an RV10 wannabe, I am close to ordering the empennage kit. In anticipation of this I have been organizing a garage work space and reading about the required tools. To that I have a few questions for the list experts. They are: I have been thinking of using epoxy paint on my garage floor. Application is going to be problematic as I can only do 1 bay of a 3 car garage. I am wondering if I should be putting a foam pad down (versus painting) as it will be easier on the feet when working. Any comments or recommendations as to workspace floor treatment? With a quick build kit does the DRDT-2 hand dimpling tool still represent a worthwhile advantage over the standard c-frame dimplier? Is the Cleaveland Tools Main Squeeze as good as they claim (versus other hand squeezers)? I have read a number of positive posts about pneumatic squeezers. Again with a QB kit, is this a worthwhile investment? Is the use of pneumatic squeezers difficult to master? Are their any decisions that I need to make (i.e. lighting systems etc) when completing the empennage kit? Cheers Les RV wannabe > [b] -------- #40572 Empennage N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63023#63023 ________________________________________________________________________________
Date: Sep 21, 2006
I'm a QB beginner too as of August 21. If you can, I would highly recommend the week-long tail kit program at the Alexander Tech Center offers in Griffin GA. In addition to getting my fin, rudder and 80% of the HS built, I learned that: 1) rubber padding is preferable over a hard, raw concrete floor in those high use areas 2) the DRDT-2 is more than worth the premium. (I've had a chance to use both devices - both get it done but there is no comparison) 3) the 'main squeeze' takes less force than the common alternatives and appears to be a very fine tool. But having used 3 different hand squeezers, I actually preferred one of the alternatives while others preferred the main squeeze. The lesson; there's great value in getting a chance to try a variety of tools, which was an unexpected benefit of the Tech Center experience. 4) The pneumatic squeezer is more than worth the premium. Consider it mandatory. I guess you don't really need a hand squeezer after all as others have said. The Alexander Tech Center class seems to be an excellent way to start a '10 for first timers. You get a lot done (actually too much for this still hurting and injured builder) and 1:1 instruction from an experienced staff including a remarkable 20yo young man. Bill in Durham ________________________________________________________________________________
Date: Sep 21, 2006
Subject: Re: FW: Production schedule for future engine output
Don't know what this means to this group...but my friend who's been waiting for his Delta Hawk 180hp engine is about ready to receive it in the next week. I understand that this is one of the first batches to be shipped to builders. P ________________________________________________________________________________
Subject: FW: Production schedule for future engine output
Date: Sep 21, 2006
Some builders have been curious about engine alternatives beyond rotary. Diesel, radial, water-cooled, corvette and other variants than Lycosaurus. If Deltahawk floats your boat at 180hp - Good Sailing and keep us informed. Some did not know of the Zoche. JC ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Thursday, September 21, 2006 11:18 AM Subject: Re: RV10-List: FW: Production schedule for future engine output Don't know what this means to this group...but my friend who's been waiting for his Delta Hawk 180hp engine is about ready to receive it in the next week. I understand that this is one of the first batches to be shipped to builders. P ________________________________________________________________________________
Date: Sep 21, 2006
Zoche - I think it was 1997 when I actually touched their engines at OSH and they were already legends for being a year away from certification when they told me "next year" Interesting guys, they don't seem to want your money, the engines looked well engineered and googling Usenet shows they been around since at least 1993 with the same basic plan. Whoever is paying the bills over there certainly has a lot of patience. Perry Casson - Wiring ________________________________________________________________________________
Date: Sep 21, 2006
Carbon tape would be a bit of overkill since it isn't really doing anything structural. IV-P windows have to hold back a lot of pressure. One layer of this P/N from Aircraft Spruce would function the same way: 01-06600 Keep in mind you will now have an epoxied layer right up to the transparent part of the window. You will probably need to paint at least a small margin past the fiberglass, taking away from the clear part. If you're careful you can probably make it 1/4" or less. I don't think youi need to worry about the cabin roof/fuselage joint. There will be a natrual seam there so paint cracks shouldn't be a problem. Paint cracks are pretty common almost anywhere there are two materials butted together without a stress relief (think groove in a sidewalk), in this case window and Weld-on . On my 10 I am installing the windows with Silpruf. They are a ways from flying but I will report. It has worked great on other planes but doesn't look quite as clean and smooth as epoxied windows. Just depends on what you want. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Sent: Wednesday, September 20, 2006 10:05 PM Subject: RV10-List: Carbon Fiber tape I was discussing HOW to put the windows in the rV 10 with a guy currently building a Lancair IV retract/pressurized. He suggested putting 1 1/2 inch wide Carbon Fiber tape over the window edges to help prevent them from cracking. He also said he would put it over the seam between the cabin cover and fuselage and the cabin cover and empenage. Does any one have experience with Carbon tape? I knwo West Systems sells some that is compatitble with their epoxy. Would this be a good idea? What has everbody used to fill in the seam between the cabin cover and fuselage/empenage? I think Microballoons would eventually crack in these areas. VIC.........are you seeing any stress cracks on your plane? What did you use in these areas? Thanks, DEAN 40449 Cowling/Baffling ________________________________________________________________________ ________________________________________________________________________________
Subject: trim brackets
Date: Sep 21, 2006
I read with interest ,about the trim brackets problems,today I recive from Dave Czachorowsky the parts he customize for me,basically he customize the custom part.when I recive about 4 months ago the first ones I install them ,then when remove for paint I realize its is imposible to do it without removing the rivets,we discuss this issue and he build a new ones and install ss inserts for screws ,living some space for the dimple in the cover plate,here are the pictures,he charge me 25 dol.for the two brackets with the inserts,now I thinks I have the rigth ones for set up the trims ,and inspection with no hassle. here are the pictures. Hugo 40 456 ________________________________________________________________________________
Subject: Re: trim brackets
Date: Sep 21, 2006
cool! is there some reason they have to be removed for painting? ----- Original Message ----- From: <gommone7(at)bellsouth.net> Sent: Thursday, September 21, 2006 4:52 PM Subject: RV10-List: trim brackets >I read with interest ,about the trim brackets problems,today I recive from >Dave Czachorowsky the parts he customize for me,basically he customize the >custom part.when I recive about 4 months ago the first ones I install them >,then when remove for paint I realize its is imposible to do it without >removing the rivets,we discuss this issue and he build a new ones and >install ss inserts for screws ,living some space for the dimple in the >cover plate,here are the pictures,he charge me 25 dol.for the two brackets >with the inserts,now I thinks I have the rigth ones for set up the trims >,and inspection with no hassle. > here are the pictures. > Hugo 40 456 > ________________________________________________________________________________
Date: Sep 21, 2006
Yes if you whant to paint beetwen the Hs and the elevator,you cannot remove the elevator without removing the trim tabs attachments brackets. hugo40456 > > From: "jdalton77" <jdalton77(at)comcast.net> > Date: 2006/09/21 Thu PM 06:48:27 EDT > To: > Subject: Re: RV10-List: trim brackets > > > cool! is there some reason they have to be removed for painting? > ----- Original Message ----- > From: <gommone7(at)bellsouth.net> > To: > Sent: Thursday, September 21, 2006 4:52 PM > Subject: RV10-List: trim brackets > > > >I read with interest ,about the trim brackets problems,today I recive from > >Dave Czachorowsky the parts he customize for me,basically he customize the > >custom part.when I recive about 4 months ago the first ones I install them > >,then when remove for paint I realize its is imposible to do it without > >removing the rivets,we discuss this issue and he build a new ones and > >install ss inserts for screws ,living some space for the dimple in the > >cover plate,here are the pictures,he charge me 25 dol.for the two brackets > >with the inserts,now I thinks I have the rigth ones for set up the trims > >,and inspection with no hassle. > > here are the pictures. > > Hugo 40 456 > > > > > > > > ________________________________________________________________________________
Date: Sep 21, 2006
Below are my 2 cents, much of which has already been stated. I agree with Bill, Alexander Tech Center does offer a great way to get started and the opportunity to try out all the different brands of aircraft tools. You can see some of my photos from my build here <http://lrosen.nerv10.com/Construct/Log/Emp/Alexander/index.html> Also a write up from Mike Crow, one of the instructors at Alexander here <http://lrosen.nerv10.com/Construct/tools/Tools/index.html> at the bottom of the page. Les Kearney wrote: > > Hi > > > > As an RV10 wannabe, I am close to ordering the empennage kit. In > anticipation of this I have been organizing a garage work space and > reading about the required tools. To that I have a few questions for > the list experts. They are: > > > > I have been thinking of using epoxy paint on my garage > floor. Application is going to be problematic as I can only do 1 bay > of a 3 car garage. I am wondering if I should be putting a foam pad > down (versus painting) as it will be easier on the feet when working. > Any comments or recommendations as to workspace floor treatment? > I wish I had finished my garage floor. The concrete never seems to stop dusting. > > > > With a quick build kit does the DRDT-2 hand dimpling tool > still represent a worthwhile advantage over the "standard" c-frame > dimplier? > -I used the DRDT-2 at Alexander for the tail and tail cone it was the 2nd best tool (Pneumatic squeezer is number 1), But after the tail kit and going quickbuild there is not much need for a c-frame dimplier, so I purchased a "standard" c-frame. I only need the c-frame for the wing skins. If it comes down to money invest in a pneumatic squeezer first and then the DRDT-2 > > > Is the Cleaveland Tools "Main Squeeze" as good as they claim > (versus other hand squeezers)? > > > I agree with Jesse's comment " I like the fact that it is easier to squeeze, but to do so you have to "throw" the handle a lot more, so I think it would be a little harder to work with. I think the pneumatic squeezer is a good choice, and either way, the Avery squeezer has been a very useful tool, for riveting and dimpling." Since I invested in a pneumatic squeezer and I still wanted a standard squeezer, I saved some money and got the Avery. > I have read a number of positive posts about pneumatic > squeezers. Again with a QB kit, is this a worthwhile investment? Is > the use of pneumatic squeezers difficult to master? > > > Get one, well worth the investment. At the end of the project you can easily sell it and recoup most of the investment. You can look for one on ebay to save some money. > Are their any decisions that I need to make (i.e. lighting > systems etc) when completing the empennage kit? > > > Tail light and strobe Static ports cable fairings to alodine, prime, alodine & prime or do nothing (no primer wars please) > Cheers > > > > Les > > RV wannabe > Buy the kit and get started! -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Date: Sep 21, 2006
Subject: One Small Victory...
<http://www.eaa.org/communications/eaanews/060919_meigs.html> -Sean #40303 (House in Phoenix sold! Get to move back to kit!) ________________________________________________________________________________
Date: Sep 21, 2006
Hi Many thanks to all who contributed their insights. Based on the info, I am going to pass on the epoxy floor finish and use padding instead. Provisionally, I plan to use the DRDT-2 instead of the standard C Frame as well as a pneumatic squeezer. I say provisionally as I plan to be in Oregon for a Van's test flight in a week or so and then plan do to a builder workshop in the Portland area. Hopefully I will be able to try out both these tools. Asumming all goes well with the test flight and with the workshop, I will become the proud owner of a tail kit before I head back to Alberta. For the record, I would like to say thanks to the efforts of people like Tim Olson and others who have made available a tremendous amount of building info on the 'net. I don't think I would even consider this project without the online support network that is available. Cheers Les RV10 Wannabe -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Wednesday, September 20, 2006 9:30 PM Subject: RV10-List: Questions from a beginner Hi As an RV10 wannabe, I am close to ordering the empennage kit. In anticipation of this I have been organizing a garage work space and reading about the required tools. To that I have a few questions for the list experts. They are: * I have been thinking of using epoxy paint on my garage floor. Application is going to be problematic as I can only do 1 bay of a 3 car garage. I am wondering if I should be putting a foam pad down (versus painting) as it will be easier on the feet when working. Any comments or recommendations as to workspace floor treatment? * With a quick build kit does the DRDT-2 hand dimpling tool still represent a worthwhile advantage over the "standard" c-frame dimplier? * Is the Cleaveland Tools "Main Squeeze" as good as they claim (versus other hand squeezers)? * I have read a number of positive posts about pneumatic squeezers. Again with a QB kit, is this a worthwhile investment? Is the use of pneumatic squeezers difficult to master? * Are their any decisions that I need to make (i.e. lighting systems etc) when completing the empennage kit? Cheers Les RV wannabe ________________________________________________________________________________
Date: Sep 21, 2006
Enjoy the workshop. Be careful, the Van's flight test will be an expensive adventure. It will just be a short time after the flight that you put down your deposit on the emp kit. ;-) Les Kearney wrote: > > Hi > > Many thanks to all who contributed their insights. Based on the info, > I am going to pass on the epoxy floor finish and use padding instead. > > Provisionally, I plan to use the DRDT-2 instead of the standard C > Frame as well as a pneumatic squeezer. I say provisionally as I plan > to be in Oregon for a Van's test flight in a week or so and then plan > do to a builder workshop in the Portland area. Hopefully I will be > able to try out both these tools. Asumming all goes well with the test > flight and with the workshop, I will become the proud owner of a tail > kit before I head back to Alberta. > > For the record, I would like to say thanks to the efforts of people > like Tim Olson and others who have made available a tremendous amount > of building info on the 'net. I don't think I would even consider this > project without the online support network that is available. > > Cheers > > Les > > RV10 Wannabe > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Les Kearney > *Sent:* Wednesday, September 20, 2006 9:30 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Questions from a beginner > > Hi > > As an RV10 wannabe, I am close to ordering the empennage kit. In > anticipation of this I have been organizing a garage work space and > reading about the required tools. To that I have a few questions for > the list experts. They are: > > I have been thinking of using epoxy paint on my garage floor. > Application is going to be problematic as I can only do 1 bay of a 3 > car garage. I am wondering if I should be putting a foam pad down > (versus painting) as it will be easier on the feet when working. Any > comments or recommendations as to workspace floor treatment? > > With a quick build kit does the DRDT-2 hand dimpling tool still > represent a worthwhile advantage over the standard c-frame dimplier? > > Is the Cleaveland Tools Main Squeeze as good as they claim (versus > other hand squeezers)? > > I have read a number of positive posts about pneumatic squeezers. > Again with a QB kit, is this a worthwhile investment? Is the use of > pneumatic squeezers difficult to master? > > Are their any decisions that I need to make (i.e. lighting systems > etc) when completing the empennage kit? > > Cheers > > Les > > RV wannabe > > * * > * * > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > * * > * > > > * ________________________________________________________________________________
Subject: seat belts
Date: Sep 21, 2006
For the new builders: if you are considering inertial belts for your 10, the AMSAFE belts are shown on www.inertialbelts.com ________________________________________________________________________________
Date: Sep 21, 2006
I paid for the emp kit about 30 minutes after the test flight. Most expensive "FREE" test flight yet for me. -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Thursday, September 21, 2006 6:32 PM Subject: Re: RV10-List: Questions from a beginner Enjoy the workshop. Be careful, the Van's flight test will be an expensive adventure. It will just be a short time after the flight that you put down your deposit on the emp kit. ;-) Les Kearney wrote: > > Hi > > Many thanks to all who contributed their insights. Based on the info, > I am going to pass on the epoxy floor finish and use padding instead. > > Provisionally, I plan to use the DRDT-2 instead of the standard C > Frame as well as a pneumatic squeezer. I say provisionally as I plan > to be in Oregon for a Van's test flight in a week or so and then plan > do to a builder workshop in the Portland area. Hopefully I will be > able to try out both these tools. Asumming all goes well with the test > flight and with the workshop, I will become the proud owner of a tail > kit before I head back to Alberta. > > For the record, I would like to say thanks to the efforts of people > like Tim Olson and others who have made available a tremendous amount > of building info on the 'net. I don't think I would even consider this > project without the online support network that is available. > > Cheers > > Les > > RV10 Wannabe > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Les Kearney > *Sent:* Wednesday, September 20, 2006 9:30 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Questions from a beginner > > Hi > > As an RV10 wannabe, I am close to ordering the empennage kit. In > anticipation of this I have been organizing a garage work space and > reading about the required tools. To that I have a few questions for > the list experts. They are: > > . I have been thinking of using epoxy paint on my garage floor. > Application is going to be problematic as I can only do 1 bay of a 3 > car garage. I am wondering if I should be putting a foam pad down > (versus painting) as it will be easier on the feet when working. Any > comments or recommendations as to workspace floor treatment? > > . With a quick build kit does the DRDT-2 hand dimpling tool still > represent a worthwhile advantage over the "standard" c-frame dimplier? > > . Is the Cleaveland Tools "Main Squeeze" as good as they claim (versus > other hand squeezers)? > > . I have read a number of positive posts about pneumatic squeezers. > Again with a QB kit, is this a worthwhile investment? Is the use of > pneumatic squeezers difficult to master? > > . Are their any decisions that I need to make (i.e. lighting systems > etc) when completing the empennage kit? > > Cheers > > Les > > RV wannabe > > * * > * * > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > ** > * * > * > > > * ________________________________________________________________________________
Date: Sep 22, 2006
You can remove the cover plate without removing the rivets. You have to loosen the nuts at the servo end of the cable, trim the servo full nose down (trim tab up), push the sleeve of the cable aft allowing the cover plate to move away from the bottom of the elevator, bend the cable down and carefully turn the cover plate until it falls off of the sleeve. The new design does seem to reduce the pain of doing it this way. Anh ----- Original Message ----- From: <gommone7(at)bellsouth.net> Sent: Thursday, September 21, 2006 4:52 PM Subject: RV10-List: trim brackets >I read with interest ,about the trim brackets problems,today I recive from >Dave Czachorowsky the parts he customize for me,basically he customize the >custom part.when I recive about 4 months ago the first ones I install them >,then when remove for paint I realize its is imposible to do it without >removing the rivets,we discuss this issue and he build a new ones and >install ss inserts for screws ,living some space for the dimple in the >cover plate,here are the pictures,he charge me 25 dol.for the two brackets >with the inserts,now I thinks I have the rigth ones for set up the trims >,and inspection with no hassle. > here are the pictures. > Hugo 40 456 > ________________________________________________________________________________
Subject: Gas struts
Date: Sep 22, 2006
Hi my door gas strutts will not compress , I mean I cannot make them collapse at all!! Anyone had this problem?? Chris 388 ________________________________________________________________________________
Subject: Re: Gas struts
Date: Sep 22, 2006
I just tried putting all my weight on one and it did colapse...are they meant to have this much pressure!! regards Chris > Hi my door gas strutts will not compress , I mean I cannot make them > collapse at all!! > > Anyone had this problem?? > > Chris 388 ________________________________________________________________________________
Date: Sep 22, 2006
I just tried putting all my weight on one and it did colapse...are they meant to have this much pressure!! regards Chris ----- Original Message ----- From: "Chris , Susie Darcy" <VHMUM(at)bigpond.com> Sent: Friday, September 22, 2006 9:50 PM Subject: Re: Gas struts > > I just tried putting all my weight on one and it did colapse...are they > meant to have this much pressure!! > > regards Chris > >> Hi my door gas strutts will not compress , I mean I cannot make them >> collapse at all!! >> >> Anyone had this problem?? >> >> Chris 388 > ________________________________________________________________________________
Date: Sep 22, 2006
Can someone give me contact information for the milled trim brackets? Tom Deutsch, #405 Office 913 451-1222 Fax 913 451-6493 Cell 913 908-7752 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gommone7(at)bellsouth.net Sent: Thursday, September 21, 2006 3:52 PM Subject: RV10-List: trim brackets I read with interest ,about the trim brackets problems,today I recive from Dave Czachorowsky the parts he customize for me,basically he customize the custom part.when I recive about 4 months ago the first ones I install them ,then when remove for paint I realize its is imposible to do it without removing the rivets,we discuss this issue and he build a new ones and install ss inserts for screws ,living some space for the dimple in the cover plate,here are the pictures,he charge me 25 dol.for the two brackets with the inserts,now I thinks I have the rigth ones for set up the trims ,and inspection with no hassle. here are the pictures. Hugo 40 456 ________________________________________________________________________________
Date: Sep 22, 2006
deutscht(at)rhwhotels.com wrote: > Can someone give me contact information for the milled trim brackets? > > Tom Deutsch, #405 > > Office 913 451-1222 > Fax 913 451-6493 > Cell 913 908-7752 > > -- Tom, Contact Dave at 302-437-6087 or visit his website at http://www.rivethead-aero.com/ Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63191#63191 ________________________________________________________________________________
Date: Sep 22, 2006
They work 'as advertised' when installed on the door. Install them and move on :^). Rick Gray in Ohio at the Buffalo Farm - Mattituck IO540 TMX looks great - finishing the cowls :^). http://rv6rick.tripod.com/ohiovalleyrvators/ > I just tried putting all my weight on one and it did colapse...are they > meant to have this much pressure!! > > regards Chris > > ----- Original Message ----- > From: "Chris , Susie Darcy" <VHMUM(at)bigpond.com> > To: "Chris , Susie Darcy" ; > Sent: Friday, September 22, 2006 9:50 PM > Subject: Re: Gas struts > > > > > > I just tried putting all my weight on one and it did colapse...are they > > meant to have this much pressure!! > > > > regards Chris > > > >> Hi my door gas strutts will not compress , I mean I cannot make them > >> collapse at all!! > >> > >> Anyone had this problem?? > >> > >> Chris 388 > > > > > > > ________________________________________________________________________________
Subject:
Date: Sep 22, 2006
Lead in the form of tetraethylead raises the octane level of avgas and mogas. It is one of several anti-detonates but is the most effective. Contrary to popular opinion it is not a lubricant. There are some theories that the lead condenses as it is scavenged and provides a "cushion" of the exhaust valve but the condensate is a by-product of combustion and is a bromine salt, which Walter correctly states is abrasive. This topic is better suited for a chemist. :-) Monty B. ________________________________ I've stopped 54,443 spam messages. You can too! One month FREE spam protection at www.cloudmark.com <http://www.cloudmark.com/spamnet?v1&rc=gjw23> <http://www.cloudmark.com/spamnet?v1&rc=gjw23> ________________________________________________________________________________
Subject: Great Articles few copies
Date: Sep 22, 2006
Between running to my weekly aviation dinner on Thursday nights and dashing to the airport to see a friend off to China, my wife slipped me the latest issue of Kitplanes - October. My friend is part of the Chinese project to modify three more Boeing 747 cargos into the world's largest shuttle transports. The prototype flew into Boeing Field this month. Their variant is 13.5" wider than the modified Airbus who stole it from the Russian AN-124s. These will become freighters for the 787 fuselages being autoclaved in South Carolina then shipped to and final assembled in Everett. I set the magazine in a pile. Back to the magazine. I have been a little frustrated lately after renewing my subscription for another 3 years to see all the disingenuous text on Sheetmetal babble for the last few months and the dwindling number of pages to turn. Enter this issue. A bright fresh start. It is available on newsstands such as Barnes and Noble or Borders with about 3 copies per store. It was like a recap on every single issue on the RV-10 site this week. There is a great article on the aircraft and the factory owner (rumored to have led to all the sparks against the Epic LT that led to and what created the 51% taskforce study). It's Ron Lueck's - and his Colossal 650hp turbine CompAir, this is his chance to blow his horn while the sparks fly behind the closed door/smoke filled room. There is an excellent letter to the editor called "Wired for Safety" on previous incomplete reporting of proper safety wiring techniques. Most builders would just gloss this side note away. Another detailed article by editor, Marc Cook on seeking the perfect Panel construction. He might have excused himself and posted Tim's or Deem's journey for us guys. There is a remarkable article on Detonation and Pre-ignition by none other that the source of definitive engine research - GAMI and APS instructor Walter Atkinson. The Hand Grenade on the header should get your attention. There are two great articles on Oil Cooler Basics and Anatomy of a Vernatherm by new reporter, Norm Ellis. There is even a product review of the DRDT-2 dimpler for lurkers selecting tools. Guess I must be a Gearhead. This is one copy you should get before the newsstands are stripped bare. If you can't find a copy, let me know which article you want to read and I will PDF you the pages. They won't last the weekend on the newsstand. Enjoy the read. Turbanator ________________________________________________________________________________
Subject: Motor Mount
Date: Sep 22, 2006
Guys, Anybody else have this problem? I pinned the motor mount onto the firewall today. With the top 2 motor mount holes up flush against the firewall, the bottom 2 outboard holes are about a 3/16 of an inch from the firewall. This is because the 2 bottom inboard mounting holes of the motor mount won't allow the 2 outboard mounts to sit flush. What did you guys do about it? Send it back? Make shims? Just pulled it tight with the bolts? Reweld it? I'm inclined to make shims. I don't want undue stress on the mount by pulling it tight with the bolts. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63295#63295 ________________________________________________________________________________
Date: Sep 22, 2006
I do not remember having that problem. If I remember right mine all sat pretty flat. Rene' Felker 40322 Finish N423CF -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of zackrv8 Sent: Friday, September 22, 2006 4:15 PM Subject: RV10-List: Motor Mount Guys, Anybody else have this problem? I pinned the motor mount onto the firewall today. With the top 2 motor mount holes up flush against the firewall, the bottom 2 outboard holes are about a 3/16 of an inch from the firewall. This is because the 2 bottom inboard mounting holes of the motor mount won't allow the 2 outboard mounts to sit flush. What did you guys do about it? Send it back? Make shims? Just pulled it tight with the bolts? Reweld it? I'm inclined to make shims. I don't want undue stress on the mount by pulling it tight with the bolts. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63295#63295 ________________________________________________________________________________
Date: Sep 23, 2006
Zack, my concerns were more to do with the alignment of the outer holes being up to half a hole out, but found when I began to pull the bolts up it easily stretched and moved into place, well below any torque value required on the nuts. You'll find some information in the archives reporting the fact that there seems to be a bit of twist in some frames. John 40315 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of zackrv8 Sent: Saturday, 23 September 2006 8:15 AM Subject: RV10-List: Motor Mount Guys, Anybody else have this problem? I pinned the motor mount onto the firewall today. With the top 2 motor mount holes up flush against the firewall, the bottom 2 outboard holes are about a 3/16 of an inch from the firewall. This is because the 2 bottom inboard mounting holes of the motor mount won't allow the 2 outboard mounts to sit flush. What did you guys do about it? Send it back? Make shims? Just pulled it tight with the bolts? Reweld it? I'm inclined to make shims. I don't want undue stress on the mount by pulling it tight with the bolts. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63295#63295 ________________________________________________________________________________
Subject: Isham Planetools for RV-10 kits
Date: Sep 22, 2006
I'm not trying to ignore the obvious but I am curious. Most posters recommend either Avery or Cleveland for the RV-10 tool kit with certain substitutions. I'm interested in the Isham Planetools package. Their tools all seem to be namebrand. One of the things that puzzles me is that they don't seem to be very straightforward with the physical location of their business or how to contact them other than the internet. Can anyone comment on their experience with Isham Planetools?? Thanks in advance, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63309#63309 ________________________________________________________________________________
Date: Sep 22, 2006
I ordered Isham's kit. It was complete, as advertised, but at the time (last January-February) his method of marking for ease of inventory wasn't too good. Rob Wright #392 Wing tips - can't wait to start on QB fuse! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway Sent: Friday, September 22, 2006 7:50 PM Subject: RV10-List: Isham Planetools for RV-10 kits I'm not trying to ignore the obvious but I am curious. Most posters recommend either Avery or Cleveland for the RV-10 tool kit with certain substitutions. I'm interested in the Isham Planetools package. Their tools all seem to be namebrand. One of the things that puzzles me is that they don't seem to be very straightforward with the physical location of their business or how to contact them other than the internet. Can anyone comment on their experience with Isham Planetools?? Thanks in advance, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63309#63309 ________________________________________________________________________________
Subject: When to order QB wings & Fuselage
Date: Sep 22, 2006
It's been sneaking up on me but I'm on page 8-8 and I've got some skins in some ugly (but functional) cradles with a few clecos in them. I've been pretty religious about 3 to 4 hours a day and plan to continue through Christmas. I arrived at page 8-8 with about 120 hours of build time (I'm very stingy with calling shop time build time, so that's pure fabrication hours). I've read John Jessen's comments on what build time really is and I agree, but I need a little friendly guessing from you pros. Vans needs up to 4 months for QB wings & fus. Apparently you need to order both at the same time if you want a QB - I guess they are matched? Anyway, I need to plan some lead time so I'm not sitting in the garage with nothing to do. Also, I've got a little twist - the "CFO" is taking me on a two month cruise Jan 9 thru Mar 9th. Bad timing for the arrival of a big QB kit. Also, two months of dead time. Here are my decision points: Should I order a QB set right now? If it doesn't come before Jan 7th, can I delay it to a set date such as March? If I don't actually get it until after Mar 9th, would I be better off (and $10k richer) getting the slow build wings ASAP? The "CFO" has plans for me in May & June. My goal is to be ready for some serious fire wall forward buying at Oshkosh next summer. If I finish the empennage before Thanksgiving, would I be better off getting the slow build and ending up in the same place (hopefully)? A lot of advice would be appreciated. John -------- #40572 Empennage HS N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63323#63323 ________________________________________________________________________________
Date: Sep 22, 2006
Tom I purchased from Planetools and was very pleased. I had a problem with one of the tools and Shaun sent me one out immediately without me even sending the other one back. Very friendly and got a FREE pneumatic squeezer with my order :) Marc Hudson www.marcandkathy.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway Sent: Friday, September 22, 2006 7:50 PM Subject: RV10-List: Isham Planetools for RV-10 kits I'm not trying to ignore the obvious but I am curious. Most posters recommend either Avery or Cleveland for the RV-10 tool kit with certain substitutions. I'm interested in the Isham Planetools package. Their tools all seem to be namebrand. One of the things that puzzles me is that they don't seem to be very straightforward with the physical location of their business or how to contact them other than the internet. Can anyone comment on their experience with Isham Planetools?? Thanks in advance, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63309#63309 ________________________________________________________________________________
Subject: Re: Isham Planetools for RV-10 kits
Date: Sep 22, 2006
I purchased my tools from Planetools as well and am satisfied. I purchased a DRDT-2 and really like it although I never used the hammer method. Also got the squeezer and love it. Good stuff, no problems. Very fast service. Dave Leikam Muskego, WI #40496 N89DA Elevators ----- Original Message ----- From: "Marc" <marchudson(at)comcast.net> Sent: Friday, September 22, 2006 9:04 PM Subject: RE: RV10-List: Isham Planetools for RV-10 kits > > Tom > > I purchased from Planetools and was very pleased. I had a problem with > one > of the tools and Shaun sent me one out immediately without me even sending > the other one back. Very friendly and got a FREE pneumatic squeezer with > my > order :) > > Marc Hudson > www.marcandkathy.com > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway > Sent: Friday, September 22, 2006 7:50 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Isham Planetools for RV-10 kits > > > I'm not trying to ignore the obvious but I am curious. > Most posters recommend either Avery or Cleveland for the RV-10 tool kit > with > certain substitutions. > I'm interested in the Isham Planetools package. Their tools all seem to > be > namebrand. > One of the things that puzzles me is that they don't seem to be very > straightforward with the physical location of their business or how to > contact them other than the internet. > > Can anyone comment on their experience with Isham Planetools?? > > Thanks in advance, > Tom Hanaway > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=63309#63309 > > > ________________________________________________________________________________
Date: Sep 22, 2006
Subject: Isham Planetools for RV-10 kits)
Hi Someone who I trust a great deal and who has a great deal of experience doing major maintenance on heavy jets (my brother), suggested I look to the yard shop (www.yardstore.com)for tools. Their pricing seems quite a bit better than the Avery & Cleaveland. According to my brother who orders clecos 10 gross at a time, he has never had a problem with the tools he buys for his crews at the Yard Store. If you take the tool kit list from Avery / Cleaveland and price it using the Yard Store web site, you can save perhaps another 10%. Does anyone else have an opinion? Cheers Les RV Wannabe -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marc Sent: Friday, September 22, 2006 8:05 PM Subject: RE: RV10-List: Isham Planetools for RV-10 kits Tom I purchased from Planetools and was very pleased. I had a problem with one of the tools and Shaun sent me one out immediately without me even sending the other one back. Very friendly and got a FREE pneumatic squeezer with my order :) Marc Hudson www.marcandkathy.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway Sent: Friday, September 22, 2006 7:50 PM Subject: RV10-List: Isham Planetools for RV-10 kits I'm not trying to ignore the obvious but I am curious. Most posters recommend either Avery or Cleveland for the RV-10 tool kit with certain substitutions. I'm interested in the Isham Planetools package. Their tools all seem to be namebrand. One of the things that puzzles me is that they don't seem to be very straightforward with the physical location of their business or how to contact them other than the internet. Can anyone comment on their experience with Isham Planetools?? Thanks in advance, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63309#63309 ________________________________________________________________________________
Subject: Re: Great Articles few copies
Date: Sep 22, 2006
John: Thanks for the comments. Let's hope this creates a "run" on the October issue. I assume the comment about sheetmetal babble has to do with Dan's metal-skills series. While I accept that you might not have appreciated it, that series has been hugely popular among our readers. We've received more kudos on that than on the rest of the magazine's contents combined. Glad, also, that you like Walter's piece for us. We've got more coming from him. --Marc > > Back to the magazine. I have been a little frustrated lately after > renewing my subscription for another 3 years to see all the > disingenuous text on Sheetmetal babble for the last few months and > the dwindling number of pages to turn. Enter this issue. A bright > fresh start. > > It is available on newsstands such as Barnes and Noble or Borders > with about 3 copies per store. It was like a recap on every single > issue on the RV-10 site this week. There is a great article on the > aircraft and the factory owner (rumored to have led to all the > sparks against the Epic LT that led to and what created the 51% > taskforce study). It=92s Ron Lueck=92s ' and his Colossal 650hp > turbine CompAir, this is his chance to blow his horn while the > sparks fly behind the closed door/smoke filled room. There is an > excellent letter to the editor called =93Wired for Safety=94 on > previous incomplete reporting of proper safety wiring techniques. > Most builders would just gloss this side note away. Another > detailed article by editor, Marc Cook on seeking the perfect Panel > construction. He might have excused himself and posted Tim=92s or > Deem=92s journey for us guys. There is a remarkable article on > Detonation and Pre-ignition by none other that the source of > definitive engine research - GAMI and APS instructor Walter > Atkinson. The Hand Grenade on the header should get your > attention. There are two great articles on Oil Cooler Basics and > Anatomy of a Vernatherm by new reporter, Norm Ellis. There is even > a product review of the DRDT-2 dimpler for lurkers selecting tools. > Guess I must be a Gearhead. > > This is one copy you should get before the newsstands are stripped > bare. If you can=92t find a copy, let me know which article you want > to read and I will PDF you the pages. They won=92t last the weekend > on the newsstand. Enjoy the read. > > Turbanator > ________________________________________________________________________________
Date: Sep 23, 2006
Subject: Spinner Gotcha TIP
Looking at several RV 10 builder logs and final aircraft I was wondering why so many chose to use round head screws in the spinner. I think I k now now. IF you do not rivet your nutplates on the spinner back plate f orward enough..........you do not have room on the aft of the spinner fo r the #8 screw with Tinneman washer. The normal thought when mounting n utplates to the spinner back plate is to CENTER the nutplate. However, i f you do this you will not have enough spinner left for the hardware cal led out. IF you just put in a round head #8 screw all is well ....but n ow you have an ugly round head vs a FLUSH head. Another tip is drill ou t a #6 Tinneman and use with a #8 flush screw on your Spinner IF you are a little short on real estate on the aft of your spinner. Hope this he lps those buliders who have yet to get to this part in the building proc ess. So next time you see a RV 10 with round head screws in the spinner...... .....will you ask the builder WHY he used those when almost the entire o utside of the plane is put together with FLUSH style hardware? :) Ke ep banging and sanding..........it really starts to look like a plane wi th the motor and cowling mounted!!!!! Dean 40449 ________________________________________________________________________
Looking at several RV 10 builder logs and final aircraft I was wondering why so many chose to use round head screws in the spinner.&nbs p; I think I know now.  IF you do not rivet your nutplates on the s pinner back plate forward enough..........you do not have room on the af t of the spinner for the #8 screw with Tinneman washer.  The normal thought when mounting nutplates to the spinner back plate is to CENTER the nutplate. However, if you do this you will not have enough spinner l eft for the hardware called out.  IF you just put in a round head # 8 screw all is well ....but now you have an ugly round head vs a FLUSH head.  Another tip is drill out a #6 Tinneman and use with a #8 flush screw on your Spinner IF you are a little short on real esta te on the aft of your spinner.  Hope this helps those buliders who have yet to get to this part in the building process.
So next time you see a RV 10 with round head screws in the spinner... ........will you ask the builder WHY he used those when almost the entir e outside of the plane is put together with FLUSH style hardware?  :)    Keep banging and sanding..........it really starts to look like a plane with the motor and cowling mounted!!!!!
Dean
40449
Date: Sep 23, 2006
Subject: Re: When to order QB wings & Fuselage
Van's will let you delay the order, but it would be best to tell them upon order, delivery before Jan 7 or after March. Van's is very good at hitting their promise date. The only time there are issues is when the kits are first introduced. Then there are typically delays. > If it doesn't come before Jan 7th, can I delay it to a set date such as March? > > -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Date: Sep 23, 2006
Subject: Re: Isham Planetools for RV-10 kits)
Another source for tools that is not a popular in the RV community is Brown Aviation Tool Supply Company <http://www.browntool.com/>. They do have some good prices and free shipping on orders over $85. I got my air drill, drill bits, yoke, countersinks, etc from them. Their "REX" yokes are pre-drilled and tapped for use with a bench mount option. Also there longeron and 4" yokes do not need any special adapters for the adjustable set. Larry #356 Les Kearney wrote: > > Hi > > Someone who I trust a great deal and who has a great deal of experience > doing major maintenance on heavy jets (my brother), suggested I look to the > yard shop (www.yardstore.com)for tools. > > Their pricing seems quite a bit better than the Avery & Cleaveland. > According to my brother who orders clecos 10 gross at a time, he has never > had a problem with the tools he buys for his crews at the Yard Store. > > If you take the tool kit list from Avery / Cleaveland and price it using the > Yard Store web site, you can save perhaps another 10%. > > Does anyone else have an opinion? > > Cheers > > Les > RV Wannabe > > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marc > Sent: Friday, September 22, 2006 8:05 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Isham Planetools for RV-10 kits > > > Tom > > I purchased from Planetools and was very pleased. I had a problem with one > of the tools and Shaun sent me one out immediately without me even sending > the other one back. Very friendly and got a FREE pneumatic squeezer with my > order :) > > Marc Hudson > www.marcandkathy.com > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway > Sent: Friday, September 22, 2006 7:50 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Isham Planetools for RV-10 kits > > > I'm not trying to ignore the obvious but I am curious. > Most posters recommend either Avery or Cleveland for the RV-10 tool kit with > certain substitutions. > I'm interested in the Isham Planetools package. Their tools all seem to be > namebrand. > One of the things that puzzles me is that they don't seem to be very > straightforward with the physical location of their business or how to > contact them other than the internet. > > Can anyone comment on their experience with Isham Planetools?? > > Thanks in advance, > Tom Hanaway > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=63309#63309 > > > ________________________________________________________________________________
Subject: Lower cowl air inlets
Date: Sep 23, 2006
I am finishing up fitting my cowling and I had someone suggest that I not install the air inlets on the bottom until after I'm flying. The logic of this being that if I do my fly off and don't have a heat problem then I could possible eliminated some drag. Does anyone have any thoughts on this idea? By the way I have installed the Skybolt cam locks on the cowling and they really turned out great. I bought their RV10 kit and installed the cam locks a tad over 3 inch's apart, based on talking to them, and I came up about 9 cam locks short so I had to order a few more. I think the 3 inch's is a good distance and turned out well. Wayne Edgerton #40336 ________________________________________________________________________________
Date: Sep 23, 2006
I have #8 SS screws with drilled out #6 SS tinnerman washers on my 8A. Works fine. I'll do the same on the 10. Carl Froehlich RV-8A (270 hrs) RV-10 (tail cone - still) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of ddddsp1(at)juno.com Sent: Saturday, September 23, 2006 3:18 AM To: rv10-list(at)matronics.com Subject: RV10-List: Spinner Gotcha TIP Looking at several RV 10 builder logs and final aircraft I was wondering why so many chose to use round head screws in the spinner. I think I know now. IF you do not rivet your nutplates on the spinner back plate forward enough..........you do not have room on the aft of the spinner for the #8 screw with Tinneman washer. The normal thought when mounting nutplates to the spinner back plate is to CENTER the nutplate. However, if you do this you will not have enough spinner left for the hardware called out. IF you just put in a round head #8 screw all is well ....but now you have an ugly round head vs a FLUSH head. Another tip is drill out a #6 Tinneman and use with a #8 flush screw on your Spinner IF you are a little short on real estate on the aft of your spinner. Hope this helps those buliders who have yet to get to this part in the building process. So next time you see a RV 10 with round head screws in the spinner...........will you ask the builder WHY he used those when almost the entire outside of the plane is put together with FLUSH style hardware? :) Keep banging and sanding..........it really starts to look like a plane with the motor and cowling mounted!!!!! Dean 40449 ________________________________________________________________________ ________________________________________________________________________________
Date: Sep 23, 2006
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
I also got a couple things from the yard store and found them good to deal with. I got my original kit from Avery but if I had to do it again I would get it from Cleaveland or Planetools. There were a few things in Avery's that were not really needed and his double sided deburr tool has broke on me twice and isn't a very good design. To top it off he kept insisting it was my fault even though the deburr tip just popped off while I was using it both times. YMMV Michael ________________________________________________________________________________
Subject: Isham Planetools for RV-10 kits]
Date: Sep 23, 2006
This is a good point to ask the group in a group query. Which specific bucking bars are your most favorites, did they come in whose kit and which specialty bars do you recommend adding for the RV-10 newbies that have been recently asking? Back in the days of James McClow (I know, I still miss his webcam) and Tim's early pursuits, this was mentioned and has fallen by silent times. Scott Schmidt had some great Tool pics in his early days. Isn't everyone's shop, dog, wife, bike, home, hangar and bicycle as nice? There goes that Lusting again Jesse. I buy lots of stuff from the Yard, they are more reasonable than Avery. Brown for hard to get stuff cause they are more expensive. 10-20% can be saved by comparison shopping between the top six vendors and their periodic sales. The brand new 4X Cleco gun (limited quantity at Brown) is considered the Rolls Royce at work. The trigger will allow a simple tap, a gentle 1X hit all the way up to a 4X slap and everything between. They are so desired most guys buy reconditioned in the $200-300 range. I run a Deutsch 2X and a cheapo US Tool 4X with their TP176 kit which was 25% off at OSH on a daily special. John -40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Maule Driver Sent: Saturday, September 23, 2006 8:34 AM Subject: [Re: RV10-List: Isham Planetools for RV-10 kits] I bought my tool kit from Isham and am quite happy. Now I'm buying other stuff from Avery and Cleaveland. Per Larry's advice, if you follow his link to his tool writeup you'll see Mike's (from Alexander Tech Center) very positive writeups on the Avery and Cleaveland tool kits. By the time I met Mike, he seemed to think that the Isham kit might be an equally good selection. Especially because it included the DRDT-2 and a pnematic squeezer (free so to speak). I spoke to Isahm about the '10 and he seemed to know how many additional clecos were initially required, the additional bucking bar needed for the HS, etc. It seemed to be a good deal for me. It appears that Isham has some DRDT-2 inventory set aside for him and Mike suggested if not buying the device from him, it might be best to go directly to the manufacturer. Only complaint I have about Isham's kit is the inclusion (dumping) of 2" wide rivet tape. I'll probably use it to pad my rivet gun set. For this newbie, everyone seems to be helpful and knowledgeable. Isham, Avery and Cleaveland have all been a pleasure to deal with. Same with the people at the Alexander Tech Center. The Vans folks seem a bit quirky but hey, we're married now. Bill in Durham Skinning the HS and match drilling the elevator ________________________________________________________________________________
Subject: Re: Wrong elevator counterweights shipped
Date: Sep 23, 2006
That's interesting! I'm builder #40264 and received my emp. kit in 2004. It also had the wrong elevator counterweights. When I talked to Van's back then with the dimensions they couldn't figure out where they came from. They suggested I cut and drill them to fit but I fianlly had the right ones sent. Cutting and drilling through lead is no fun at all. Another potential trouble spot is in the wing kit with the aileron brackets. The W1013C-L didn't line up with its counterpart. The rivet holes were okay but the bearing recess was off about 1/32". This should be corrected by now but if you bought the slo-build wings in the 2005 time frame and have been sitting on them, check this out. With all the parts in these kits an occasional glitch can be expected. Overall they do a great job. John Hasbrouck #40264 fuse. ________________________________________________________________________________
Subject: RE: Cowl
Date: Sep 23, 2006
I have photos of my cowl for the cold air induction. Unfortunately I am not very good with this stuff so I need you to go to the following link to see them. http://pg.photos.yahoo.com/ph/brendadawg/album?.dir=/eb64re2&.src=ph&.tok=ph CuCjFB4K34TJwB Gary 40274 ________________________________________________________________________________
Subject: HID lights
Date: Sep 23, 2006
Tim and others with DW installed, Do the DW lights light up well enough for you? My original idea was to use the DW for ldg and the Van's ldg light kit for taxi. I'm at a point that I can forego the Vans kit but would like some field research on how well the DW lights do with one pointed for ldg and one pointed for taxi. Rob Wright #392 Wingtips ________________________________________________________________________________
Date: Sep 23, 2006
Subject: Re: HID lights
Well, this might not be exactly what you're looking for but.... I've got 2 Duckworks HID's. From the time that I've installed them, I haven't gotten around to properly aiming them. Right now they are way too low, maybe 30' in front of the plane or so...not what you'd necessarily want for night landings. But here's the big "however". HOWEVER, with those HID's, even with them so mis-aimed that they really shouldn't be too good, they are so darn bright that they are much better than my old plane that had 2 100W halogen standard aviation lamps in it, or the single 250W that it originally had. One of these days I'll get around to aiming them a bit further forward, and based on what I'm seeing now, I think it will really be impressive. I'm not really one who cares for separate landing and taxi lights, but I think if you aimed one for taxi, it will still be plenty of help for landing. The coolest part about the HIDs isn't even the brightness....it's the fact that my ammeter only goes up by 6A when both are lit up! Tim Olson - RV-10 N104CD - Flying Rob Wright wrote: > Tim and others with DW installed, > > > > Do the DW lights light up well enough for you? My original idea was to > use the DW for ldg and the Vans ldg light kit for taxi. Im at a point > that I can forego the Vans kit but would like some field research on how > well the DW lights do with one pointed for ldg and one pointed for taxi. > > > > Rob Wright > > #392 > > Wingtips > ________________________________________________________________________________
Date: Sep 24, 2006
Rob, I installed the DW HID's but I'm not flying yet, so can't comment on coverage. But I went ahead and installed Van's also because I wanted to have the ability to install a Wig Wag system to allow me to flash my lights (wig wag) when I'm coming in to land. The fellow at DW told me I couldn't WigWag the HID's so I will use the Van's lights for that. Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Re: Isham Planetools for RV-10 kits][Isham Planetools for RV-10
kits]
Date: Sep 24, 2006
Does any one have a cheaper source than Brown's $.36 for 3/32" clecos? used would be quite fine Or anyone have 100-200 3/32" clecos that they would sell thanks Murray Randall ________________________________________________________________________________
Date: Sep 24, 2006
I have already installed Vans lights, but after reading on VAF about light coverage and working on my electrical load analysis, I have decided to add one DW HID light for landing and use the Vans lights for taxi. -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Date: Sep 24, 2006
RV-10 kits] You can try CountrySidewalk Trading Post <http://www.countrysidewalk.com/index.html> in the Tool Shed <http://www.countrysidewalk.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=C&Category_Code=TSUT> They have used 3/32 cleco fasteners for $0.25 each. I purchased many from them and ~98% are good. I also got some counter sinks and counter sink cages from them. Watch out for the shipping charge, but if your order is large enough they will be less expensive. Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Date: Sep 24, 2006
Subject: Isham Planetools for RV-10 kits][Isham Planetools for
RV-10 kits] Murray The Yard Store (www.yardstore.com <http://www.yardstore.com/> ) has them for $0.35 each ($4.20 / doz). I believe they also sell used. Cheers Les RV10 Wannabe -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Murray Randall Sent: Sunday, September 24, 2006 6:54 AM Subject: Re: RV10-List: Isham Planetools for RV-10 kits][Isham Planetools for RV-10 kits] Does any one have a cheaper source than Brown's $.36 for 3/32" clecos? used would be quite fine Or anyone have 100-200 3/32" clecos that they would sell thanks Murray Randall ________________________________________________________________________________
Subject: HID lights
Date: Sep 24, 2006
Yeah, that's my original plan. I thought I could adapt Bill VonDane's LED Nav lights for installing sideways but they just don't put out the light in that orientation. So now I working on converting my hardware to the ldg light/nav light combo and I'll put my strobe heads in by themselves. In this case I'm measuring about 6 times before I cut (hopefully) once! Rob Wright #392 Wingtips -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Sunday, September 24, 2006 8:01 AM Subject: Re: RV10-List: HID lights I have already installed Vans lights, but after reading on VAF about light coverage and working on my electrical load analysis, I have decided to add one DW HID light for landing and use the Vans lights for taxi. -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
Subject: Re: Motor Mount
Date: Sep 24, 2006
Just drilled up the motor mount this morning; another possible gotcha is the top two pilot holes on the QB (#8 Mar/2005) fuselage were about .050 different in distances from the outboard edge. When we drilled the right top pilot hole the left top was almost out of the mount hole. After pinning the other four holes with rivet sets which fit the 3/16" on one end 3/8" on the other and 3/16" bolts we were able to flex the mount on the top left hole to use as a drill bushing for an off center drilling of the pilot hole. Also its best to test fit the motor mount (section 47) before riveting the front deck (section 41) as the access for cleaning and deburring the mount holes inside is much easier. ----- Original Message ----- From: "zackrv8" <zackrv8(at)verizon.net> Sent: Friday, September 22, 2006 3:15 PM Subject: RV10-List: Motor Mount > > Guys, > > Anybody else have this problem? > > I pinned the motor mount onto the firewall today. With the top 2 motor > mount holes up flush against the firewall, the bottom 2 outboard holes are > about a 3/16 of an inch from the firewall. This is because the 2 bottom > inboard mounting holes of the motor mount won't allow the 2 outboard > mounts to sit flush. > > What did you guys do about it? Send it back? Make shims? Just pulled it > tight with the bolts? Reweld it? > > I'm inclined to make shims. I don't want undue stress on the mount by > pulling it tight with the bolts. > > Zack > > -------- > RV8 #80125 > RV10 # 40512 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=63295#63295 > > > ________________________________________________________________________________
Date: Sep 24, 2006
Subject: Re: The Yard Store & Brown tools -- Customer Service
Just to add to the others' opinions. When I started on my RV7, I bought most of my 'toolkit' from from The Yard, with a little from Avery, Brown Tools, and Cleaveland. It took quite a bit of research to figure out exactly what to buy, and from who, but in the end I was very pleased with the amount of 'bang for the buck' I got. Among other things, this allowed me to include a used pneumatic squeezer with my 'kit' for the same price of a 'regular' kit at other places (with only a hand-squeezer). So here are my 'customer service' experiences with Brown and The Yard: When I got my adjustable set holder from Brown Tools, it wouldn't fit in my pneumatic squeezer because of two 'ears' sticking out from the base. I ground these off to make it fit. Shortly after starting to use it, the set broke (not because of my mods, though). I emailed them, and received a reply from Michael Brown asking for a picture and a description of what happened. He apologize from the inconvenience and sent me a new holder within a week. A few months after starting building, my pneumatic squeezer started to misbehave. It sounded like something wasn't right in the air valve at the bottom of the unit. I emailed the guys at the Yard, and they had their tools guy call me and asked for a description of the problem. He asked me to send the squeezer back. When he got it, he called me to tell me how he would be fixing it, and when I should expect it back. Again, it all happened within about a week. Definitely a refreshing experience after dealing with big companies' 'customer support' departments! After this experience with The Yard, I will probably buy any 'expensive' tools I might need from them, used. So, I am definitely happy with both. Luis RV7-A ________________________________________________________________________________
Date: Sep 24, 2006
I didn't buy a kit. I had quite a few wood working tools and at first I thought they would not be useful, but, except for the table saw, most of them are fine. I use the same drill press, radial arm saw (cuts angled aluminum great), sanding station (perfect for deburing). I bought a Sioux drill and a "Main Squeeze" used off of ebay and bought clecos from the Yard for .32 apiece. I also bought a lot of "light-use" tools from Harbor Freight. Not great quality, but if you have to pull 500 rivets, their $34 pneumatic rivet puller is perfect. I also bought a DRDT-2 brand new. All in all I don't think I have more than $1000 in new tools. ----- Original Message ----- From: Luis To: rv10-list(at)matronics.com Sent: Sunday, September 24, 2006 5:35 PM Subject: RV10-List: Re: The Yard Store & Brown tools -- Customer Service Just to add to the others' opinions. When I started on my RV7, I bought most of my 'toolkit' from from The Yard, with a little from Avery, Brown Tools, and Cleaveland. It took quite a bit of research to figure out exactly what to buy, and from who, but in the end I was very pleased with the amount of 'bang for the buck' I got. Among other things, this allowed me to include a used pneumatic squeezer with my 'kit' for the same price of a 'regular' kit at other places (with only a hand-squeezer). So here are my 'customer service' experiences with Brown and The Yard: When I got my adjustable set holder from Brown Tools, it wouldn't fit in my pneumatic squeezer because of two 'ears' sticking out from the base. I ground these off to make it fit. Shortly after starting to use it, the set broke (not because of my mods, though). I emailed them, and received a reply from Michael Brown asking for a picture and a description of what happened. He apologize from the inconvenience and sent me a new holder within a week. A few months after starting building, my pneumatic squeezer started to misbehave. It sounded like something wasn't right in the air valve at the bottom of the unit. I emailed the guys at the Yard, and they had their tools guy call me and asked for a description of the problem. He asked me to send the squeezer back. When he got it, he called me to tell me how he would be fixing it, and when I should expect it back. Again, it all happened within about a week. Definitely a refreshing experience after dealing with big companies' 'customer support' departments! After this experience with The Yard, I will probably buy any 'expensive' tools I might need from them, used. So, I am definitely happy with both. Luis RV7-A ________________________________________________________________________________
Date: Sep 24, 2006
I bought some small items (used rulers) from the Yard store worth less than $20- I do this usually when I am preparing for a large purchase from a vendor. The Yard store was excellent! they shipped out the items within 2 days of ordering, sent with no shipping or handling costs and sent me an e-mail to trace the order. For a company with inexpensive tools selling such a small amount of merchadise I was more than pleasantly surprised being treated as if I purchased $100's worth. I plan to do the bulk of my tool purchase from Brown, than Cleveland, ATS, Avery and Yard Store. because they have the tools I want for the least amount of money. I am finding out that Cleveland offers the best "custom builder's kit". if the prices were competitive with Brown and Yard store I would buy almost everything from Mike @ Cleveland.- I may do so anyway, at least try first, when the time comes as they do price match and I plan to buy the tools during Sun n fun (mail order not in person) so they prices may be closer in range. ----- Original Message ----- From: Luis To: rv10-list(at)matronics.com Sent: Sunday, September 24, 2006 2:35 PM Subject: RV10-List: Re: The Yard Store & Brown tools -- Customer Service Just to add to the others' opinions. When I started on my RV7, I bought most of my 'toolkit' from from The Yard, with a little from Avery, Brown Tools, and Cleaveland. It took quite a bit of research to figure out exactly what to buy, and from who, but in the end I was very pleased with the amount of 'bang for the buck' I got. Among other things, this allowed me to include a used pneumatic squeezer with my 'kit' for the same price of a 'regular' kit at other places (with only a hand-squeezer). So here are my 'customer service' experiences with Brown and The Yard: When I got my adjustable set holder from Brown Tools, it wouldn't fit in my pneumatic squeezer because of two 'ears' sticking out from the base. I ground these off to make it fit. Shortly after starting to use it, the set broke (not because of my mods, though). I emailed them, and received a reply from Michael Brown asking for a picture and a description of what happened. He apologize from the inconvenience and sent me a new holder within a week. A few months after starting building, my pneumatic squeezer started to misbehave. It sounded like something wasn't right in the air valve at the bottom of the unit. I emailed the guys at the Yard, and they had their tools guy call me and asked for a description of the problem. He asked me to send the squeezer back. When he got it, he called me to tell me how he would be fixing it, and when I should expect it back. Again, it all happened within about a week. Definitely a refreshing experience after dealing with big companies' 'customer support' departments! After this experience with The Yard, I will probably buy any 'expensive' tools I might need from them, used. So, I am definitely happy with both. Luis RV7-A ________________________________________________________________________________
Date: Sep 24, 2006
For those just beginning the journey, five years of OSH price comparisons showed daily sales prices the lowest in the entire year. Avionics is not much different. You can't beat planning and persistent price evaluation. Sun 'N Fun has offered the second lowest (both mail-order and on the field) and then the closeout and specials monthly at each vendor. Some want it quick and just hit me with one big shipment on the whole package right now. Others will piece out the desired final package over six months and save a bundle. There have been few complaints with any vendor accept Avery blaming the purchaser on misuse when things break. Still looking for all the lurkers to answer up on their favorite bucking bars and kits. Knowing the use of those bars will help the newbies as well. John - 40600 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Sunday, September 24, 2006 4:56 PM Subject: Re: RV10-List: Re: The Yard Store & Brown tools -- Customer Service I bought some small items (used rulers) from the Yard store worth less than $20- I do this usually when I am preparing for a large purchase from a vendor. The Yard store was excellent! they shipped out the items within 2 days of ordering, sent with no shipping or handling costs and sent me an e-mail to trace the order. For a company with inexpensive tools selling such a small amount of merchadise I was more than pleasantly surprised being treated as if I purchased $100's worth. I plan to do the bulk of my tool purchase from Brown, than Cleveland, ATS, Avery and Yard Store. because they have the tools I want for the least amount of money. I am finding out that Cleveland offers the best "custom builder's kit". if the prices were competitive with Brown and Yard store I would buy almost everything from Mike @ Cleveland.- I may do so anyway, at least try first, when the time comes as they do price match and I plan to buy the tools during Sun n fun (mail order not in person) so they prices may be closer in range. ----- Original Message ----- From: Luis <mailto:luis.orozco(at)gmail.com> To: rv10-list(at)matronics.com Sent: Sunday, September 24, 2006 2:35 PM Subject: RV10-List: Re: The Yard Store & Brown tools -- Customer Service Just to add to the others' opinions. When I started on my RV7, I bought most of my 'toolkit' from from The Yard, with a little from Avery, Brown Tools, and Cleaveland. It took quite a bit of research to figure out exactly what to buy, and from who, but in the end I was very pleased with the amount of 'bang for the buck' I got. Among other things, this allowed me to include a used pneumatic squeezer with my 'kit' for the same price of a 'regular' kit at other places (with only a hand-squeezer). So here are my 'customer service' experiences with Brown and The Yard: When I got my adjustable set holder from Brown Tools, it wouldn't fit in my pneumatic squeezer because of two 'ears' sticking out from the base. I ground these off to make it fit. Shortly after starting to use it, the set broke (not because of my mods, though). I emailed them, and received a reply from Michael Brown asking for a picture and a description of what happened. He apologize from the inconvenience and sent me a new holder within a week. A few months after starting building, my pneumatic squeezer started to misbehave. It sounded like something wasn't right in the air valve at the bottom of the unit. I emailed the guys at the Yard, and they had their tools guy call me and asked for a description of the problem. He asked me to send the squeezer back. When he got it, he called me to tell me how he would be fixing it, and when I should expect it back. Again, it all happened within about a week. Definitely a refreshing experience after dealing with big companies' 'customer support' departments! After this experience with The Yard, I will probably buy any 'expensive' tools I might need from them, used. So, I am definitely happy with both. Luis RV7-A s.com/Navigator?RV10-List ________________________________________________________________________________
Date: Sep 25, 2006
Subject: Re: Static port airspeed error updateStatic port airspeed
error update/tail position-strobe lt Airspeed, mode C, altitude errors....Gradually these got worse on my RV6. Finally had pro check out system. Altimeter failed leak test, mode C was off, and static system had leaks near ports. Would have saved a lot of time if I had gotten this fellow, with proper equipment, to check out at the outset. Also, probably some error due slipstream differences on each side of fuselage, differs by airspeed. Sure RV-10 is similar. Need check everything hooked to pitot-static for leaks, etc.. Think most important to verify indicated stall speed is reasonably accurate early on in phase 1 flight test, or any time after pitot static system work has been done. Need adjust for density altitude/weight of course. Tail posn/strobe light. Put a combo Whelen posn/strobe light on tail of my RV6, and it's never missed a beat. For power supply, I used one from Strobes N More, ditto never missing a beat, and half the price of a Whelen power supply. Link Mcgarity #40622 FD38, Wellington, FL ________________________________________________________________________________
From: "Mike Lauritsen - Work" <mike(at)cleavelandtool.com>
Date: Sep 25, 2006
We have Wedge-Loc brand on sale now at $.32 each brand new. This is our cost and we have them on sale to lower our stock level. Only in bags of 100. You will not find cheaper Wedge-Loc clekos anywhere. https://www.cleavelandtoolstore .com/specials.asp -- Mike Lauritsen Cleaveland Aircraft Tool 515-432-6794 www.cleavelandtool.com -----Original Message----- From: owner-rv10-list-server@matronic s.com [mailto:owner-rv10-list-server@matronic s.com] On Behalf Of Murray Randall Sent: Sunday, September 24, 2006 6:54 AM Subject: Re: RV10-List: Isham Planetools for RV-10 kits][Isham Planetools for RV-10 kits] Does any one have a cheaper source than Brown's $.36 for 3/32" clecos? used would be quite fine Or anyone have 100-200 3/32" clecos that they would sell thanks Murray Randall ________________________________________________________________________________
Date: Sep 25, 2006
Hi John, I'll bite! I have three I like. First one is a standard universal footed bucking bar (Ceaveland #BB30 but others carry it.) Didn't like it at first but have grown to appreciate it. Second is (Yardstore #71007). It's long and thin, works great for the rivets in between the closely spaced ribs in the wing root. My other favorite is one I picked up from Boeing Surplus, but never have seen it anywhere else. It is approximately 1" by 2 ". by 4" Has a 45=B0 angle on one end and =BD" notch machined in the other to create a foot for working around flanges. Doesn't work everywhere but where it does it works like a charm. Vern (#40324) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Sunday, September 24, 2006 7:26 PM Subject: RE: RV10-List: Re: The Yard Store & Brown tools -- Customer Service For those just beginning the journey, five years of OSH price comparisons showed daily sales prices the lowest in the entire year. Avionics is not much different. You can't beat planning and persistent price evaluation. Sun 'N Fun has offered the second lowest (both mail-order and on the field) and then the closeout and specials monthly at each vendor. Some want it quick and just hit me with one big shipment on the whole package right now. Others will piece out the desired final package over six months and save a bundle. There have been few complaints with any vendor accept Avery blaming the purchaser on misuse when things break. Still looking for all the lurkers to answer up on their favorite bucking bars and kits. Knowing the use of those bars will help the newbies as well. John - 40600 ________________________________________________________________________________
Subject: elevator control horn drilling
Date: Sep 25, 2006
I finished the drilling of the elevator horns yesterday and followed the direction to the tee. I indexed one of the horns(the most aft horn with the size hole which was specified, then made the block of wood for betwen the two horns to keep the drill bit going pependicular to the horn faces. All went well, however once complete, I noticed in addition to there being a front/aft discrepancy, there also was a up/down descrepancy. This means that although the length of each horn is the same, one is higher than the other. This must be due to the jigging and welding up of the horns. In anycase, the hole on the second horn ovbiously has a different spacing than the first hole which was used as an index. The edge dimension on the first horn are called out as 1/2" from the L.E. of the horn and 3/8" from the bottom edge of the horn. The hole on the secong horn was okay on the front/aft spacing which is probably the most critical, but the spacing from the bottom edge of the horn was only 6/32". 6/32 vs 3/8, roughly 50% less material. As stated above the main forces on the horn will be in the pull-front edge or push-rear edge of the horn. The bottom edge distance should not be so critical, but I obviously would hate to have a crack form down the line in this right horn. I imagine everything is sinched tight with washers and a bolt, but has anyone else noticed something like this? >From my analysis, nothing I did would have caused this. This is simply the variation in the fabrication of these control horns and the V which is riveted to the elevator spar and the inboard elevator rib. There are a lot of welds making up these parts. John G. #409 ________________________________________________________________________________
Date: Sep 25, 2006
Subject: RV-10 landing characteristics
Although I am still trying to sell my Vans RV-10 (lack of time---I have a toddler), I have decided that I will keep it if I don't get any nice offers. (in case anyone is interested, http://welch.econ.brown.edu/n325hp/; also, if you know someone else who wants a flawless RV-10, please forward this). Now, I am still flying once a month with it to familiarize myself with it. Flight characteristics are wonderfully simple---as easy as a piper cherokee, and this at 50% faster and with fuel consumption that is fairly similar at comparable speeds. Vans make amazing airplanes. Alas, I find that the ground handling, like any other nose-steerable plain with wheels close together and castoring front-wheel (eg SR-22), is less pleasant. I am a low-time 300 hour pilot (half in an RV-9), and not flying often does not help. So, I would love to ask some other RV-10 pilots what practices they like best about landing. At 75 knots, the airplane seems in slow-flight mode---behind the power curve. still very easily controllable, but not as crisp as it is at 110 knots. When I land with *full* flaps, I also think it is not as easily controllable (tends to be a little fidgety; it wants to jump up again; not a big deal) as when I land with 2/3 flaps. I presume this means that I should land at slower speeds. What have others found to be best (speed + flap setting; as function of weight, sidewind, etc)? Aside, I find that an RV-10 lands nicer with a passenger than without one. In fact, it is very easy to grease the landing *with* passenger and then control it on the ground, but seems more difficult alone. Am I imagining these characteristics, or do other RV-10 pilots have the same experience? I was thinking about landing another 10 knots slower for easier ground handling, but even though this is still about 20 knots above stall speed, the fact that it is in slow flight makes me hesitate. Any other pilot experiences would be appreciated. FWIW, I would sacrifice 5 knots in flying speed for wheels further apart, bigger, and perhaps front wheel steerable. If nothing else, it would make soft-field landings safer. I wish Vans and Cirrus and everyone else offered some options to improve ground handling--- wheels farther apart, a nose wheel that wants to stay straight even in cross-wind landings, perhaps bigger tires or shock absorber. Has anyone come up with something better than Vans? Regards, /iaw ________________________________________________________________________________
Subject: james plenum?
Date: Sep 25, 2006
Hey all - Anyone using the James Aircraft plenum? I'm looking into it, and just kind of wondering how well it works. It basically takes the place of baffles right? Doesn't the glass get hot being right on the engine? If it works so well, why doesn't everyone use it? is it a pain in the butt? I'd love to get some real-world info about this... Thanks! cj #40401 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
Subject: WIG-WAG HIDS
Date: Sep 26, 2006
From: "Neville Boyle" <nevilleboyle(at)bencomm.com.au>
If you are prepared to potentially sacrifice some bulb light it is possible to WIG-WAG the HID Xenon globes.You need to be aware that the globes have a warm up time while the gas is ionising and they need to warm fully to burn the deposit left while warming up off the glass (this means the flash rate needs to be longer than 3 seconds per side) The second problem is that most of the commercial flash units rely on a low impedance through the filament of the traditional globe that does not exist with the xenon alternative.On my plane I increased the capacitor size to slow the flash rate and provided a additional earth in stead of the traditional path through the globe filament Neville Boyle VH-NVL 33 hours ________________________________________________________________________________
Date: Sep 25, 2006
In short, slow down! Well, initially you want to go back to basics. Many critical V speeds are calculated at 1.2, 1.3 or so X Vso, so you really don't need to go 20-30 knots faster to approach to land. No wonder you're ballooning up. It must take a lot of power to land that fast at full flaps as well. Then when you round out the wing+flaps combo has so much camber that you've got one awesome angle of attack going. The extra weight of a passenger is giving you the slight advantage of helping the aircraft settle onto the runway, but you're still developing too much lift. Most folks you talk to use a rule of thumb of stall + 5 knots in calm winds, stall + 10 knots in crosswinds or gusty winds. Do a little research in the light to medium twins and you find yourself looking at VRef speeds. The one I fly is Ref + 20 at partial flaps, then Ref +10 at full flaps, then Ref across the threshold; Ref being the standard Stall + X as necessary for the conditions. I can't help you on the ground handling thing. No castering nosewheel experience yet. Rob Wright #392 Starting QB Fuse... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ivo welch Sent: Monday, September 25, 2006 4:44 PM Subject: RV10-List: RV-10 landing characteristics Although I am still trying to sell my Vans RV-10 (lack of time---I have a toddler), I have decided that I will keep it if I don't get any nice offers. (in case anyone is interested, http://welch.econ.brown.edu/n325hp/; also, if you know someone else who wants a flawless RV-10, please forward this). Now, I am still flying once a month with it to familiarize myself with it. Flight characteristics are wonderfully simple---as easy as a piper cherokee, and this at 50% faster and with fuel consumption that is fairly similar at comparable speeds. Vans make amazing airplanes. Alas, I find that the ground handling, like any other nose-steerable plain with wheels close together and castoring front-wheel (eg SR-22), is less pleasant. I am a low-time 300 hour pilot (half in an RV-9), and not flying often does not help. So, I would love to ask some other RV-10 pilots what practices they like best about landing. At 75 knots, the airplane seems in slow-flight mode---behind the power curve. still very easily controllable, but not as crisp as it is at 110 knots. When I land with *full* flaps, I also think it is not as easily controllable (tends to be a little fidgety; it wants to jump up again; not a big deal) as when I land with 2/3 flaps. I presume this means that I should land at slower speeds. What have others found to be best (speed + flap setting; as function of weight, sidewind, etc)? Aside, I find that an RV-10 lands nicer with a passenger than without one. In fact, it is very easy to grease the landing *with* passenger and then control it on the ground, but seems more difficult alone. Am I imagining these characteristics, or do other RV-10 pilots have the same experience? I was thinking about landing another 10 knots slower for easier ground handling, but even though this is still about 20 knots above stall speed, the fact that it is in slow flight makes me hesitate. Any other pilot experiences would be appreciated. FWIW, I would sacrifice 5 knots in flying speed for wheels further apart, bigger, and perhaps front wheel steerable. If nothing else, it would make soft-field landings safer. I wish Vans and Cirrus and everyone else offered some options to improve ground handling--- wheels farther apart, a nose wheel that wants to stay straight even in cross-wind landings, perhaps bigger tires or shock absorber. Has anyone come up with something better than Vans? Regards, /iaw ________________________________________________________________________________
Subject: Re: james plenum?
Date: Sep 25, 2006
It doesn't replace baffling.. you still need side baffling walls... this is more of a lid on top of baffling. From what I'm told by people who have it, it works pretty good. I'll be putting it in my -7A. -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=63830#63830 ________________________________________________________________________________
Subject: James Cowl and Plenum - Web Site?
Date: Sep 25, 2006
I've read a lot about the James cowl and plenum on the list. Not having stayed in a Holiday Inn Express last night - what is it and why would I want/need it? I have not been able to find any web information on this. Does "James" have a website? Jeff 455 ________________________________________________________________________________
Date: Sep 25, 2006
Date: Sep 25, 2006
Start by searching the archives, it's been discussed a couple times. Website can be found at www.jamesaircraft.com. I will be using both the plenum and the cowl, not flying yet though. The plenum is very efficient at cooling the engine by reducing the volume and directing the flow of air through the cowl. The cowl does a few things. First is it is aerodynamically cleaner than the stock Van's cowl. Also it is much better at matching the inlet and exhaust pressure of the air. You ideally want 1:1 for those pressures which results in no drag. Anything higher and the airstream is transferring its energy to the airframe somewhere in the engine compartment. It, combined with the plenum, also does a good job at slowing the volume of air down to extract the maximum amount of heat from the engine and then speeding it back up to the airstream speed as it exists. Again that 1:1 thing. Many people swear by the combination, or even each individually. There are plenty of examples of documented top speed increases from using the cowl. Hope that helps. Michael Sausen -10 #352 Buildus Interuptus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jdalton77 Sent: Monday, September 25, 2006 7:06 PM Subject: RV10-List: James Cowl and Plenum - Web Site? I've read a lot about the James cowl and plenum on the list. Not having stayed in a Holiday Inn Express last night - what is it and why would I want/need it? I have not been able to find any web information on this. Does "James" have a website? Jeff 455 ________________________________________________________________________________
Date: Sep 25, 2006
The BB30 is also known as the AT670 which was part of the standard 3X and 4X US Tool kit. One of my recent "Want it" was the #71007 which had been modified by bending the chisel end UP about 20 degrees. We were replacing a gasket track on a pressurized avionics door which had about 0.125" between the final shop head and the pressure locking mechanism. The veteran shoved it into the limited space and pried as he hit the rivet head. It worked exceptionally for really, really tight spaces. I was amazed. John ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vern W. Smith Sent: Monday, September 25, 2006 9:57 AM Subject: RE: RV10-List: Re: The Yard Store & Brown tools -- Customer Service Hi John, I'll bite! I have three I like. First one is a standard universal footed bucking bar (Ceaveland #BB30 but others carry it.) Didn't like it at first but have grown to appreciate it. Second is (Yardstore #71007). It's long and thin, works great for the rivets in between the closely spaced ribs in the wing root. My other favorite is one I picked up from Boeing Surplus, but never have seen it anywhere else. It is approximately 1" by 2 ". by 4" Has a 45=B0 angle on one end and =BD" notch machined in the other to create a foot for working around flanges. Doesn't work everywhere but where it does it works like a charm. Vern (#40324) ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Sunday, September 24, 2006 7:26 PM Subject: RE: RV10-List: Re: The Yard Store & Brown tools -- Customer Service For those just beginning the journey, five years of OSH price comparisons showed daily sales prices the lowest in the entire year. Avionics is not much different. You can't beat planning and persistent price evaluation. Sun 'N Fun has offered the second lowest (both mail-order and on the field) and then the closeout and specials monthly at each vendor. Some want it quick and just hit me with one big shipment on the whole package right now. Others will piece out the desired final package over six months and save a bundle. There have been few complaints with any vendor accept Avery blaming the purchaser on misuse when things break. Still looking for all the lurkers to answer up on their favorite bucking bars and kits. Knowing the use of those bars will help the newbies as well. John - 40600 ________________________________________________________________________________
Subject: Ray Allen Trim Servo
Date: Sep 25, 2006
Was wondering if anyone else had this problem or not? Before I mount the elevator trim servo bracket with the Ray Allen trim servo, I wanted to think about the wiring. The wires make a real sharp bend due to the closeness of the mounting bracket. See attached picture. Did anyone cut out a half circle in the bracket or just bend the wires and cover with protective material? Also, what wire did you guys use to hook up the servo? I was thinking of ordering the WC2 5 wire Teflon Installation Cable from Ray Allen at $1.10 per foot. Thanks for the input Marc Hudson #560 ________________________________________________________________________________
Date: Sep 25, 2006
Michael, thank you again for posting the second generation of Wholly Cowl, your shots show a marked improvement over the first Generation one for John Goodlad's RV-10 from the below website. Hopefully it's yours or Deems and we will be hearing more soon. John 600 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Monday, September 25, 2006 6:06 PM Subject: RE: RV10-List: James Cowl and Plenum - Web Site? Start by searching the archives, it's been discussed a couple times. Website can be found at www.jamesaircraft.com. I will be using both the plenum and the cowl, not flying yet though. The plenum is very efficient at cooling the engine by reducing the volume and directing the flow of air through the cowl. The cowl does a few things. First is it is aerodynamically cleaner than the stock Van's cowl. Also it is much better at matching the inlet and exhaust pressure of the air. You ideally want 1:1 for those pressures which results in no drag. Anything higher and the airstream is transferring its energy to the airframe somewhere in the engine compartment. It, combined with the plenum, also does a good job at slowing the volume of air down to extract the maximum amount of heat from the engine and then speeding it back up to the airstream speed as it exists. Again that 1:1 thing. Many people swear by the combination, or even each individually. There are plenty of examples of documented top speed increases from using the cowl. Hope that helps. Michael Sausen -10 #352 Buildus Interuptus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jdalton77 Sent: Monday, September 25, 2006 7:06 PM Subject: RV10-List: James Cowl and Plenum - Web Site? I've read a lot about the James cowl and plenum on the list. Not having stayed in a Holiday Inn Express last night - what is it and why would I want/need it? I have not been able to find any web information on this. Does "James" have a website? Jeff 455 ________________________________________________________________________________
Date: Sep 25, 2006
I left the sharp bend in mine, but the half circle is a good idea. There's definitely enough structure to support cutting such a small relief for the wires. Rob Wright #392 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marc Sent: Monday, September 25, 2006 8:44 PM Subject: RV10-List: Ray Allen Trim Servo Was wondering if anyone else had this problem or not? Before I mount the elevator trim servo bracket with the Ray Allen trim servo, I wanted to think about the wiring. The wires make a real sharp bend due to the closeness of the mounting bracket. See attached picture. Did anyone cut out a half circle in the bracket or just bend the wires and cover with protective material? Also, what wire did you guys use to hook up the servo? I was thinking of ordering the WC2 5 wire Teflon Installation Cable from Ray Allen at $1.10 per foot. Thanks for the input Marc Hudson #560 ________________________________________________________________________________
Subject: Re: Ray Allen Trim Servo
Date: Sep 25, 2006
I can't recall cutting the bracket but for wiring you might consider a shielded quad and a shielded pair of 22G wire. probably less expensive that the trim cable and shield can be grounded on one end if there are stray electrons running around in your airplane. Come to think of it I bought the cable and decided not to use it. ----- Original Message ----- From: Marc To: rv10-list(at)matronics.com Sent: Monday, September 25, 2006 6:44 PM Subject: RV10-List: Ray Allen Trim Servo Was wondering if anyone else had this problem or not? Before I mount the elevator trim servo bracket with the Ray Allen trim servo, I wanted to think about the wiring. The wires make a real sharp bend due to the closeness of the mounting bracket. See attached picture. Did anyone cut out a half circle in the bracket or just bend the wires and cover with protective material? Also, what wire did you guys use to hook up the servo? I was thinking of ordering the WC2 5 wire Teflon Installation Cable from Ray Allen at $1.10 per foot. Thanks for the input Marc Hudson #560 ________________________________________________________________________________
Subject: Apologies to Deems
Date: Sep 25, 2006
It was not Michael's site but Deems in his Will James folder (under photos) with the second generation mold product for the RV-10. First generation being John Goodlad. Now pipe in here Ed, aren't you #1 behind the auto engine, with Michael and Deems waiting in the Que too? John ________________________________________________________________________________
Date: Sep 25, 2006
Subject: No appology required.
I'm somewhere @ the top of the queue, My BPA engine is due to get built Oct 3-4, I believe that Gary Foster is getting the 1st James Cowl w/ the Cold Air accommodation, I think that Will , Alan and Gary are trying to finalize just how the filtered air will be accommodated. When that's sorted out I expect Will to begin working off the backlog. In the meantime, I'm trying to finish up this panel so I can get back out into the shop and get the engine mount on and the gear legs on. Trying to get ready for the engine when it arrives. I know that I'm not the fastest wiring dude, but I never in my life expected that wiring the panel could take this long. I have a whole new appreciation for what Stein and others like him do!!!! Deems Davis # 406 Panel/Finishing http://deemsrv10.com/ John W. Cox wrote: > It was not Michaels site but Deems in his Will James folder (under > photos) with the second generation mold product for the RV-10. First > generation being John Goodlad. Now pipe in here Ed, arent you #1 > behind the auto engine, with Michael and Deems waiting in the Que too? > > John > >* > > >* > ________________________________________________________________________________
Date: Sep 26, 2006
To the best of my knowledge the James cowl is also being used by Eggenfellner Subaru, I have one on order( The engine and cowl package) and should be receiving it in DEC. Dan Lloyd RV10E (N289DT) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Monday, September 25, 2006 10:43 PM Subject: RV10-List: Apologies to Deems It was not Michael's site but Deems in his Will James folder (under photos) with the second generation mold product for the RV-10. First generation being John Goodlad. Now pipe in here Ed, aren't you #1 behind the auto engine, with Michael and Deems waiting in the Que too? John ________________________________________________________________________________
Date: Sep 26, 2006
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
I drilled mine for a small hole and inserted a snap bushing so the wires come out of the side. Just drill the hole in the center of the side metal so as not to weaken it. Thank You Ray Doerr -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marc Sent: Monday, September 25, 2006 8:44 PM Subject: RV10-List: Ray Allen Trim Servo Was wondering if anyone else had this problem or not? Before I mount the elevator trim servo bracket with the Ray Allen trim servo, I wanted to think about the wiring. The wires make a real sharp bend due to the closeness of the mounting bracket. See attached picture. Did anyone cut out a half circle in the bracket or just bend the wires and cover with protective material? Also, what wire did you guys use to hook up the servo? I was thinking of ordering the WC2 5 wire Teflon Installation Cable from Ray Allen at $1.10 per foot. Thanks for the input Marc Hudson #560 ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Subject: Prop
Date: Sep 26, 2006
Gentlemen, I reinstated my e-mail subscription to the RV-10 list so I can sell a prop. Due to a hole in our schedule we have had to work on a Piper UUGG. Anyway I have a hartsle prop that has been setting on a Cherokee 235 hanger queen. This prop has had 10 hours or so on it over the past 10-15 years and is due for the 5 year AD overhaul mind you 0 time since overhaul, no one has taken a file to it, it is perfect. The owner wants to put a shiny three blade on it and wants me to sell this prop; of coarse the 5 year overhaul will be done. Make me an offer, Van's has new props for 6000.00 so buy this one and a transponder for the same price. Noel Simmons RV-10 325HP among 21 others I have a NICE rv-9A for sale too. ________________________________________________________________________________
Date: Sep 26, 2006
Hi all, Since we are talking about Allen trim servos, what kind of wire connectors are people using to hook it to the wiring? Knife splice, butt splice, AMP PIDG or what? I ask primarily because the aileron trim servo is mounted on the left wing's inboard inspection cover. And it seems like it would be nice to be able to "unplug it" in the future without cutting the wires. Vern Smith (#40324 wings)
September 07, 2006 - September 26, 2006
RV10-Archive.digest.vol-bm
