RV10-Archive.digest.vol-bn
September 26, 2006 - October 14, 2006
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R
[NTK]
Sent: Tuesday, September 26, 2006 7:23 AM
Subject: | Ray Allen Trim Servo |
I drilled mine for a small hole and inserted a snap bushing
so the wires come out of the side. Just drill the hole in the center of
the side metal so as not to weaken it.
Thank You
Ray Doerr
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marc
Sent: Monday, September 25, 2006 8:44 PM
Subject: RV10-List: Ray Allen Trim Servo
Was wondering if anyone else had this problem or not?
Before I mount the elevator trim servo bracket with the Ray Allen trim
servo, I wanted to
think about the wiring. The wires make a real sharp bend due to the
closeness of the mounting bracket.
See attached picture. Did anyone cut out a half circle in the bracket
or just bend the wires and
cover with protective material?
Also, what wire did you guys use to hook up the servo?
I was thinking of ordering the WC2 5 wire Teflon Installation Cable from
Ray Allen
at $1.10 per foot.
Thanks for the input
Marc Hudson
#560
Subject: | Re: Ray Allen Trim Servo |
I've seen two approaches used. 1. is on Aeroelectic.com where Bob
illustrates how to use a 9 pin d-sub with the flanges ground off and
then bound with shrinkwrap. 2. Ted French has used what I believe are
RJ45 connectors (I assume this requires a special crimp tool, but looked
like a nice solution.
Deems Davis # 406
Panel/Finishing
http://deemsrv10.com/
Vern W. Smith wrote:
> Hi all,
> Since we are talking about Allen trim servos, what kind of wire
> connectors are people using to hook it to the wiring? Knife splice,
> butt splice, AMP PIDG or what? I ask primarily because the aileron
> trim servo is mounted on the left wings inboard inspection cover. And
> it seems like it would be nice to be able to unplug it in the future
> without cutting the wires.
> Vern Smith (#40324 wings)
> *From:* owner-rv10-list-server(at)matronics.com
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Doerr,
> Ray R [NTK]
> *Sent:* Tuesday, September 26, 2006 7:23 AM
> *To:* rv10-list(at)matronics.com
> *Subject:* RE: RV10-List: Ray Allen Trim Servo
> I drilled mine for a small hole and inserted a snap bushing so the
> wires come out of the side. Just drill the hole in the center of the
> Thank You
> *Ray Doerr*
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Marc
> *Sent:* Monday, September 25, 2006 8:44 PM
> *Subject:* RV10-List: Ray Allen Trim Servo
> servo, I wanted to
> from Ray Allen
> at $1.10 per foot.
> Marc Hudson
> #560
From: | "John Gonzalez" <indigoonlatigo(at)msn.com> |
Subject: | Elevator control horn drill spacing |
Richard,
Thank you for your reply. I agree with you and I am sure that many others
have had the same problem and have not realized it. It is a shame Van's has
not made this correction in the manual or on the jigging of the parts in
this assembly.
By your expanation of AC43, it seems I am under the required amount of
material by 3/32" if my math is correct.
I sent a previous email but it seems it got lost in cyberspace.
Rather than disassembling the skins and getting new horn parts, I am going
to contact Van's and find out whether welding a plate onto the offending
horn would be a viable option. Of course, arc welding with no flame would
be needed and I have a neighbor who is a world renown metal sculpter that
can do the work perfectly. I need to still study the hardware connection to
determine whether this will work with the required connection method.
My apologies if the first email finally comes through.
JOhn G. 409
From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
Subject: | RV 10s in Scottsdale, AZ |
I am in Scottsdale all week.was curious if anyone was building in the ar
ea. Would love to see your project and help build if you are working on
it. respond to my email......will have most time on thursday nite.
Dean
40449
in the area. Would love to see your project and help build if you
are working on it. respond to my email......will have most t
Dean
40449
Visit http://www.juno.com/value to sign up today!
