RV10-Archive.digest.vol-cd
March 07, 2007 - March 30, 2007
It's been suggested that RG-58 is not acceptable and the cable length is
critical. Also that the antenna needs to change.
ERic--
RV-10, 40014
N104EP
From: | "Eric Parlow" <ericparlow(at)hotmail.com> |
Subject: | Garmin 430/530 and WAAS |
Has anyone had the 430/530 WAAS conversion done and installed it?
We need to know if there were any modification needed to the plane's wiring
or antennas.
ERic--
RV-10, 40014
N104EP
Hello All,
I am replacing my SL30 with a Gramin 530. Stein has offered me $2800
in trade for the 530. It is yours for the same price if you are
interested. Just trying to save someone a little money.
The SL30 was purchased in June of 2006 and has been installed in my
RV10 since then. It comes with the tray and wiring for Fast Stack
Hub. It is still under warranty and the warranty Card has not been
mailed. Contact me off-line.
Thanks, Rob.
Subject: | Re: Overhead Liner |
Niko, THANKS for the link, I'm very interested in what you find/learn as
the finishing of the headliner around the cabin door openings and door
posts is one of the (many) things I haven't got a solution to yet. I'd
appreciate your posting what you find when you receive your material
samples.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Niko wrote:
> I haven't tested it. I am currently waiting for samples of all of
> their binding material.
> Niko
Subject: | Please use my new email address. |
I had to close this email account due to an excessive amount of spam. Click http://aspzone.com/JohnsNewEmail.jpg to view my new address. You will have to resend your message in order for me to receive it.
Subject: | Re: Garmin 430/530 and WAAS |
I am Getting the upgrade in two weeks. The box is a
slide in because it is your own box that is sent to
Garmin in Kansas. The antenna is replaced. The antenna
coax has to have a specific gain? The shop doing my
upgrade purchased the test equipment to measure this.
Without that device Garmin is recommending to install
(if I recall correctly) 20 or 30 foot coax to the new
antenna. With a non WAAS antenna you want to use a
short coax. Also if you have multiple units, 430/430
or 530/430, if you only upgrade one unit the crossfil
function will no longer work.
Steve 40212
> installed it?
> or antennas.
> the cable length is
> ERic--
> RV-10, 40014
> N104EP
> browse
> Subscriptions page,
> FAQ,
> http://www.matronics.com/Navigator?RV10-List
> Web Forums!
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel
bargains.
http://farechase.yahoo.com/promo-generic-14795097
From: | "Albert Gardner" <ibspud(at)roadrunner.com> |
Subject: | Dynon and MAC Servos |
I'm wiring up my Dynon 180 and finding that it doesn't seem to be
directly
compatible with the MAC servos that we use for trim control. MAC outputs
position indication on 3 wires to their LED indicator but if you want to
put
that into the Dynon, their input is from a variable pot that they excite
with 5 volts and use the variable input on one of the 3 general purpose
inputs. I don't see a problem with this except using the MAC output
would be
a lot cleaner. I guess I will have to backtrack and add a pot to measure
position to each of the MAC servos. Anyone else have a better idea?
Albert Gardner
Yuma, AZ
RV-10 #10-422
Wow! I posted this message a minute ago and it doesn't have any line feeds
in it so I'm trying again-should be more readable, I hope now,
Albert.
I'm wiring up my Dynon 180 and finding that it doesn't seem to be directly
position indication on 3 wires to their LED indicator but if you want to put
inputs. I don't see a problem with this except using the MAC output would be
Albert Gardner
Yuma, AZ
RV-10 #10-422
Here's what we've learned about the WAAS upgrade so far from Aviation
Consumer.
Garmin is holding to its offering of $1500 box upgrades
New 430W/530W are selling for $10,750/$16495 respectively
While 430/530 are still selling for $9253/$14998 respectively
The installation is covered by an AML/STC
This AML/STC required specific standards and requirements for the
installation
If you aircraft is on the AML it requires a field approval(certified
aircraft)
The GA56 antenna supplied with the 430/530 will not work
The A34 is approved antenna with the same foot print but different
connector, BNC vs TNC
The TNC connectors are in short supply due to demand
Other antennas that are approved are" GA35W, GA56W, and GA56A
The swap is pin-for-pin, except for with certain autopilots and EHSI systems
Pigtail lengths for terminating shields at the receiver must be less then 3"
Cable loss must be < 7db which requires replacement of RG-58 cable with
RG400 or RG142
Bendix/King KFC225 and KAP140 required discrete outputs to capture the GPS
glidepath
The New WAAS boxes will not crossfill with older boxes
Remote annunciation may be required if box is not in the pilot's field of
view
Field of view Horz: edge of the WAAS box < 13.8" from the center of the
primary instruments
Field of view Vert: edge of the WAAS box is no lower than the bottom of the
primary instruments
ERic--
RV-10, 40014
N104EP
Sure thing, I will post my findings when I get the material and play with i
t.=0A=0ANiko=0A=0A=0A----- Original Message ----=0AFrom: Deems Davis <deems
davis(at)cox.net>=0ATo: rv10-list(at)matronics.com=0ASent: Wednesday, March 7, 20
07 11:14:26 AM=0ASubject: Re: RV10-List: Overhead Liner=0A=0A=0A--> RV10-Li
st message posted by: Deems Davis =0A=0ANiko, THANKS fo
r the link, I'm very interested in what you find/learn as =0Athe finishing
of the headliner around the cabin door openings and door =0Aposts is one of
the (many) things I haven't got a solution to yet. I'd =0Aappreciate your
posting what you find when you receive your material =0Asamples.=0A=0ADeems
Davis # 406=0AFinishing - ( A Misnomer ! )=0Ahttp://deemsrv10.com/=0A=0ANi
ko wrote:=0A> I haven't tested it. I am currently waiting for samples of a
ll of =0A> their binding material. =0A> =0A> Niko=0A>=0A> --=0A> *=0A> *
From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
Subject: | Re: Dynon and MAC Servos |
Dynon updatede the install manual for the trim indicators. you do NOT
need a pot......I am not at the hanger but I have the info there as we c
onnected both trim and aileron to these indicator on the D120.
DEAN 40449
FREE Reminder Service - NEW from AmericanGreetings.com
Click HERE and never forget a Birthday or Anniversary again!
http://track.juno.com/s/lc?s=197335&u=http://www.americangreetings.c
om/products/online_calendar.pd?c=uol5752
; you do NOT need a pot......I am not at the hanger but I have the
info there as we connected both trim and aileron to these indicator on
the D120.
DEAN 40449
FREE Remin
Click HERE and never forget a Birthday or Anniversary again!<
br>
