RV10-Archive.digest.vol-cg
May 07, 2007 - May 19, 2007
Email the information above and your files and photos to:
pictures(at)matronics.com
Subject: | Re: : RV10-List:14" Spinner - was James Cowling |
Anyone looked at the UHS fiberglass spinners that Aircraft Spruce
sells? http://www.aircraftspruce.com/catalog/appages/uhs.php
Looks like they have a 14" spinner. Don't know if it would work, but at
$174 it might be worth a try.
PJ
RV-10 #40032
evmeg(at)snowcrest.net wrote:
> Really!....I had no idea! thanks for the heads up on that one....Goes to
> show you that the rule holds true about deviatiating from the plans...
> small change=BIG price difference. There must be a reasonable solution to
> this one. Seems too simple to me.
> Evan
>> I'm interested in the James Cowl. I sent a note to them however about the
>> 14" spinner required with this cowl. The Hartzell spinner, at $1400, cost
>> more than the cowl itself. I asked them if they could do a Van's like 14"
>> fiberglass spinner kit to replace the ridiculously overpriced Hartzell
>> spinner. They said no.
>> Carl Froehlich
>> RV-8A (320 hrs)
>> RV-10 (wings)
>> -----Original Message-----
>> From: owner-rv10-list-server(at)matronics.com
>> [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of
>> Sent: Sunday, May 06, 2007 11:53 AM
>> To: rv10-list(at)matronics.com
>> Subject: Re: RV10-List: James Cowling
>> Anybody using the James Cowl on their 10 yet? Besides looking a bit
>> sexier, I am wondering if gives the added benefits of the 2 place
>> versions. On the smaller airplanes it adds a few knots of speed by
>> reducing cooling drag. On the 4 place it may also help with the hot tunnel
>> syndrome as there seems to be some merit in the argument that the airflow
>> through the cowl is a major part of the problem. At $1200.00 it does not
>> seem to expensive if it solves problems.....I dont know how much the
>> standard cowling costs. There is obviously an offset in cost if I just
>> dont order that with my finish kit. So.....anybody tried it yet?
>> Cheers...
>> Evan
>> This message was sent using SnowCrest WebMail.
>> http://www.snowcrest.net
Subject: | : RV10-List:14" Spinner - was James Cowling |
I contacted them a while back to inquire about using it with the hartzell
that Van's sells and they said it would not work. The hartzell uses a back
plate aft of the propeller and their 14" spinner is designed to with a
mounting plate in front of the propeller.
-Ben
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PJ Seipel
Sent: Monday, May 07, 2007 2:43 PM
Subject: Re: RV10-List:14" Spinner - was James Cowling
PJ
RV-10 #40032
> Evan
the
cost
14"
>> Carl Froehlich
>> RV-8A (320 hrs)
>> RV-10 (wings)
tunnel
>> Cheers...
>> Evan
From: | "John Hasbrouck" <jhasbrouck(at)woh.rr.com> |
Subject: | Tru-Trak pitch servo |
Quick question for those with the pitch servos from Tru Trak for the -10.
Is the hole in the elevator bellcrank sized for an AN-3 bolt? Plans on Tru
Trak site give a hole size of .200 if I'm reading it correctly. Doesn't
make much sense. Want to drill hole now while installing elevators but
don't have the servo yet....john
John Hasbrouck
#40264
Subject: | Trutrak pitch servo |
Size should be 10 or 11 for the AN3. Also be advised that the hole should be
.25" aft of specified location for use of the torque enhancer. Also the
pitch reversal loop in the programmer connector should be in place. I would
call TT. 479-751-0250.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hasbrouck
Sent: Monday, May 07, 2007 6:50 PM
Subject: RV10-List: Tru-Trak pitch servo
John Hasbrouck
#40264
What recommendations do folks have for the different models of Air/Oil
Separators? Airflow Performance just came out with one that claims to
be "designed for the IO-540".
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
Subject: | Shipping companies and insurance |
For those who have shipped an engine: What freight company
did you use, were you happy with them, and did you insure it
through the shipper or another source?
Kevin
40494
Pearblossom, CA
From: | "Wayne Edgerton" <wayne.e(at)grandecom.net> |
Subject: | Re: Oil Separator |
I have a close A&P friend who's worked on my plane and he told me that I
would be wasting my money on an oil separator. He seems to feel they
don't really work that well.
For what ever it's worth.
Wayne Edgerton #40336
getting close
From: | "Jesse Saint" <jesse(at)saintaviation.com> |
I have used a cheap ACS (or Van's) one as someone else mentioned, but it
doesn't have a return. It is just mounted between the breather port and the
breather tube and I think it gravity feeds back into the engine when it
stops. It seems to have helped a little, but not measurably. I also
terminate the tube on the exhaust stack to try to burn off any oil that gets
out there to keep it off the belly. I think most belly oil comes from leaks
elsewhere if you keep the oil in the sump below 9 or 10 Qts. It seems to
blow off down to 9 or so pretty quickly. We usually add a Qt when it gets
down to 8.5. If you put 12 in, you will blow a LOT of it off very quickly
in our experience.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
_____
tdawson-townsend(at)aurora.aero
Sent: Monday, May 07, 2007 11:53 PM
Subject: RV10-List: Oil Separator
Separators? Airflow Performance just came out with one that claims to be
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
From: | "Albert Gardner" <ibspud(at)roadrunner.com> |
My engine came from Indiana and I used Freightquote.com and insurance
obtained through them. It was considerably less expensive and it turned out
that it came on one of the carriers that gave me a much higher price when I
contacted them directly. Things went well but apparently Freightquote.com
has their webpage oriented toward the shipper arranging things instead of
the receiver so it was a little awkward for me to set things up but went
well and I'm happy and less poor that could have been.
Albert Gardner
Yuma, AZ
PS: Just passed through Pearblossom last weekend on a trip from Yuma to
Chowchilla. Stopped in at Mojave airport to look around at Scaled Composites
layout as well as the Rotary Rocket on display.
Kevin
40494
Pearblossom, CA
From: | "Lloyd, Daniel R." <LloydDR(at)wernerco.com> |
All of this talk about greasy belly's, just another reason to go Subaru,
no noticeable oil burn between oil changes...or so I have heard, my
engine will be shipping this week and I will be able to give a first
flight report in the next month or so and let you all know how clean the
belly is!
Dan
N289DT RV10E
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Tuesday, May 08, 2007 9:18 AM
Subject: RE: RV10-List: Oil Separator
the breather tube and I think it gravity feeds back into the engine when
it stops. It seems to have helped a little, but not measurably. I also
gets out there to keep it off the belly. I think most belly oil comes
from leaks elsewhere if you keep the oil in the sump below 9 or 10 Qts.
It seems to blow off down to 9 or so pretty quickly. We usually add a
Qt when it gets down to 8.5. If you put 12 in, you will blow a LOT of
it off very quickly in our experience.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
_____
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
http://forums.matronics.com
I've used Roadway on two different occasions. I've been happy with them
and the shipments were insured through them. Keep in mind standard
shipments are only insured for a maximum of $25 per pound. For the
additional coverage needed trucking companies charge ~.30 to .40 cents
per $100 of the value.
To save money it may be possible to get a one time rider on your home
insurance or builders insurance for the shipment. On other money saving
tip is look into picking the engine up at the trucking terminal. This
saves home delivery charge and possibly a "lift gate charge".
Also determine where the FOB (freight on board) point is. If it is FOB
origin then you are completely responsibly for the shipment, however if
it is FOB destination then it is the sellers responsibility.
Upon receiving (before you sign for it) carefully check the crate for
any damage. This includes damage to the bottom corners just in case it
was dropped. Open up the crate if they will let you (some large
terminals don't allow for this but you can ask in advance.) If there is
any damage note it on the bill of lading. The phrase "Subject to
inspection" can be added to your signature if there is any physical
damage to the crate. Report any damage the same day!
Vern (#324)
kilopapa(at)antelecom.net
Sent: Monday, May 07, 2007 9:33 PM
Subject: RV10-List: Shipping companies and insurance
Kevin
40494
Pearblossom, CA
Lots of good comments on this subject by everyone. I installed a "certified" unit
on my Piper Archer and it made no change to the oily belly or oil consumption
rate (seperated oil routed back to case).
My RV-10 belly stays fairly clean and I have not cleaned it yet (80 hrs). I keep
oil level at 10qts and routed breather exit close to the muffler and ended
tube 1/4" above muffler. I believe this exit location away from fast air flow
and close to the hottest end of the exhaust pipe lets the drops hit the hot tube
and provides more burn time as the residue migrates down and out.
I have this unproven theory that the drops are flying into the airstream and
end up on the belly rather than gently dropping onto the exhaust pipe and burning.
Perhaps the breather exit geometry accounts for the different experiences.
If I were to do this again I would squeeze the end of the breather tube into
an oval shape with the long axis of the oval parallel with the exhaust pipe to
increase the probability that the drops will fall onto the top center of the
exhaust pipe.
Bill DeRouchey
WTD Aviation Technology
N939SB, flying
Jesse Saint wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);}
st1\:*{behavior:url(#default#ieooui) } I have used a cheap ACS
(or Vans) one as someone else mentioned, but it doesnt have a return. It is
just mounted between the breather port and the breather tube and I think it
gravity feeds back into the engine when it stops. It seems to have helped a little,
but not measurably. I also terminate the tube on the exhaust stack to
try to burn off any oil that gets out there to keep it off the belly. I think
most belly oil comes from leaks elsewhere if you keep the oil in the sump below
9 or 10 Qts. It seems to blow off down to 9 or so pretty quickly. We usually
add a Qt when it gets down to 8.5. If you put 12 in, you will blow a LOT
of it off very quickly in our experience.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tdawson-townsend(at)aurora.aero
What recommendations do folks have for the different models of Air/Oil Separators?
Airflow Performance just came out with one that claims to be designed for
the IO-540.
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
Subject: | Wiring Harness from Vans - should I plan to get it? |
I'm still a ways from the fuselage but looking ahead, is the RV10
harness from Vans something I should plan on? What did you do?
Just curious at this point.
Bill "just ordered TT servos and trying to get QB wings ready for bottom
sheet rivet" Watson
Everyone,
Thanks for all of the replys! Talked to Tru-Trak this morning and
this is what I found out. First, the pdf on the website for the -10
pitch servo is WRONG. It is the older version. How about that for
keeping things up to date? According to Zach at TT the hole for the
elevator bellcrank is to be 2.5" up from the center bearing AND .25" aft
as was mentioned in an earlier post. Hole size is for an AN-3 bolt
which should be a #12 drill. ( Zach said of the hole size, " we try to
keep it around .200", about a #8" ) Well Zach's way off on that one.
Tim posted earlier that the later versions of the torque multiplier
worked OK with the original hole location. Zach said it should work at
that location as long as there is full control movement. So here's my
dilema. I drilled the hole assuming that the drawing on the web site
was correct. I only drilled a guide hole (#30) though. According to
Tim this location works fine and if there is plenty of movement in the
servo to allow full control movement I'll leave it where it is. Does
.25" make that much difference? If it's going to be a problem later
I'll just make a new bellcrank. BTW: The servo bracket for the pitch
servo is included in the fuselage kit from Vans....John
John, I as well as Tim installed the update kit later after the hole was
drilled. It works fine. I would move forward. Randy
Hasbrouck
Sent: Tuesday, May 08, 2007 10:57 AM
Subject: RV10-List: Pitch Servo
Everyone,
One note, if I remember right the servo bracket that Vans provided did not
work for me. I had received another one with my servo that did work. I got
mine with my servo from Stein...
Rene' Felker
N423CF
40322
801-721-6080
_____
Sent: Tuesday, May 08, 2007 11:57 AM
Everyone,
Thanks for all of the replys! Talked to Tru-Trak this morning and this
is what I found out. First, the pdf on the website for the -10 pitch servo
is WRONG. It is the older version. How about that for keeping things up to
date? According to Zach at TT the hole for the elevator bellcrank is to be
2.5" up from the center bearing AND .25" aft as was mentioned in an earlier
post. Hole size is for an AN-3 bolt which should be a #12 drill. ( Zach
said of the hole size, " we try to keep it around .200", about a #8" ) Well
Zach's way off on that one. Tim posted earlier that the later versions of
the torque multiplier worked OK with the original hole location. Zach said
it should work at that location as long as there is full control movement.
So here's my dilema. I drilled the hole assuming that the drawing on the
web site was correct. I only drilled a guide hole (#30) though. According
to Tim this location works fine and if there is plenty of movement in the
servo to allow full control movement I'll leave it where it is. Does .25"
make that much difference? If it's going to be a problem later I'll just
make a new bellcrank. BTW: The servo bracket for the pitch servo is
I also used the original hole and it works great.
>From: "John Hasbrouck" <jhasbrouck(at)woh.rr.com>
>Reply-To: rv10-list(at)matronics.com
>To: "RV LIST"
>Subject: RV10-List: Pitch Servo Date: Tue, 8 May 2007 13:57:00 -0400
>Everyone,
>to date? According to Zach at TT the hole for the elevator bellcrank is to
>be 2.5" up from the center bearing AND .25" aft as was mentioned in an
>earlier post. Hole size is for an AN-3 bolt which should be a #12 drill.
>( Zach said of the hole size, " we try to keep it around .200", about a #8"
>) Well Zach's way off on that one. Tim posted earlier that the later
>versions of the torque multiplier worked OK with the original hole
>location. Zach said it should work at that location as long as there is
>full control movement. So here's my dilema. I drilled the hole assuming
>that the drawing on the web site was correct. I only drilled a guide hole
>(#30) though. According to Tim this location works fine and if there is
>plenty of movement in the servo to allow full control movement I'll leave
>it where it is. Does .25" make that much difference? If it's going to be
>a problem later I'll just make a new bellcrank. BTW: The servo bracket
>for the pitch servo is included in the fuselage kit from Vans....John
Like the way Microsoft Office Outlook works? Youll love Windows Live
Hotmail.
The bracket in the kit is not the same one as is need for the new Torque
multiplier, they sent me a new bracket when I got my servo's from Stein
and I used the original bracket to make a parking brake mount. I can
take pictures of the mount and servo if you want, or I think Deem's has
some excellent photo's on his site.
Dan
N289DT RV10E
_____
Hasbrouck
Sent: Tuesday, May 08, 2007 1:57 PM
Everyone,
Here's the link to several pic's in this album.
http://deemsrv10.com/album/Wiring/slides/DSC03208.html
Deems Davis # 406
Finishing - ( A Misnomer ! )
> Torque multiplier, they sent me a new bracket when I got my servo's
> from Stein and I used the original bracket to make a parking brake
> mount. I can take pictures of the mount and servo if you want, or I
> think Deem's has some excellent photo's on his site.
> Dan
> N289DT RV10E
Maybe yes, maybe no. Van's harness is for a basic VFR plane. Tim Olsen's
website has a PDF file of the instructions and a schematic that come
with it. It's in the builders section with the plans. I think most
people are not using this harness because it doesn't meet their needs.
If you are just on the wings, one option is to run just the wing wiring.
Start with what you want in the wings some possibilities are: strobes,
nav lights, pitot heat, aileron trim, auto pilot servo, landing lights,
stall warning, AOA kit, wing tip antennas (nav, com, marker beacon). At
this point some run conduit, other use snap rings or a combination.
William Curtis has some nice pictures and schematics on his site.
http://wcurtis.nerv10.com/ And by all means check out the matronics
archives. If you go with conduit Vans' sells corrugated stuff (it can be
a pain to pull it through the ribs), other people have used light
sprinkler water line. Somewhere on Van's site is a wing rib diagram
showing different possible locations for wire runs. John Cox had a
marvelous idea of running a length of weed wacker cord with any wire run
so that it is easier to pull an extra wire in the future.
My EAA Tech. consoler didn't like seeing the strobe wires ran in the
same conduit as electrical wiring so I pulled it separately through snap
rings and then ran one conduit for antenna wire and another for
electrical wiring with a spacing of greater than 6 inch between the
runs. As far as supplies there are a number of venders. SteinAir has
been very helpful.
This is probably more info than you want:)
Hope it's helps,
Vern Smith (#324 tail cone attachment)
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver
Sent: Tuesday, May 08, 2007 10:43 AM
Subject: RV10-List: Wiring Harness from Vans - should I plan to get it?
sheet rivet" Watson
Subject: | Re: Shipping companies and insurance |
To all who have responded so far:
Thanks for the info and advice. Albert Gardner noted Freightquote.com and
they had a good quote thru Roadway however the stock insurance coverage was
$10,000 max. A search for third-party shipping/freight insurance found
Ramon, Inc http://www.ramonins-usa.com who quoted 25 per $100 for $70 on
$28,000. Learning as I go.
Kevin
40494
tail/empennage
----- Original Message -----
Albert Gardner
Yuma, AZ
> Vern (#324)
Subject: | Re: Wiring Harness from Vans - should I plan to get it? |
I purchased the wiring kit from Van's. It was great to get all the pieces
and parts in one kit with instructions; in that sense it was a great place to
start when I wasn't quite sure about many of the details. I made lots of
changes and added many circuits and features. Now that I know how it goes
together, if I was to build a second plane, I would design the electrical system
from
scratch... but that's the thing about experience, you don't get it until
just after you need it.
-Jim
40134
In a message dated 5/8/2007 1:55:55 P.M. Eastern Daylight Time,
MauleDriver(at)nc.rr.com writes:
--> RV10-List message posted by: MauleDriver
sheet rivet" Watson
************************************** See what's free at http://www.aol.com.
Might also be worth talking to Tony Partain. His trucks generally haul
cars and similar stuff on the back hauls to Oregon after delivering RV
parts to all y'all.
> Kevin
> 40494
> tail/empennage
> Albert Gardner
> Yuma, AZ
> > Vern (#324)
Thanks for the info Ben. If anyone hears of an option better than the
$1700 that Hartzell wants, I'd sure love to hear about it.
PJ Seipel
RV-10 #40032
> -Ben
> PJ
> RV-10 #40032
>> Evan
> the
> cost
> 14"
>>> Carl Froehlich
>>> RV-8A (320 hrs)
>>> RV-10 (wings)
> tunnel
>>> Cheers...
>>> Evan
More info than I want? Right!
I had come to the same conclusion, that is, the Van's harness is
designed from a basic VFR perspective and yet, it's probably a good
start even for an IFR setup. I'm finding that accepting a bit of
"wastage" is a good way to get up the learning curve at times.
You've confirmed I'm hitting all the right resources because I've
managed to see most of the references below. (Still don't know what a
snap ring is yet). I'm installing the Gretz pitot, aileron trim,
Duckworth lights (cutting holes in the wings is so much fun I'm doing it
twice - thanks for HFreight saw Tim). I bought the Vans lighting kit but
returned everything except the tail lights. Waiting on an LED kit from
Jeff. I've ordered the Trutrak servos from Stein. I'm skipping the
AOA probe. I'm thinking archer nav attenna, don't know about comm but
want it in the fuse. William's wiring layout in the wings is becoming
my model and his wiring schematics/plan is in my notebook. Connectors
are a big ? Need to buy some basic crimpers, wire and termination stuff.
Slowing getting my head into a electrical plan/schematic but I'm getting
a headache.
Thanks.
Bill "real glad I've got a QB wing because there is more than enought
drill/deburr/dimple/priming to do with what's left" Watson
> been very helpful.
> Hope it's helps,
> To: RV10-List Digest Server
> sheet rivet" Watson
Aero Composites offers a 14" spinner. For $1000. I'm not sure if it will
fit a prop other than their's. The one I have spinner backplate is
machined for mounting studs that are integral to their prop hub. Give
them a call and find out for sure.
Deems Davis # 406
> PJ Seipel
Subject: | nose wheel cocked in flight |
Just one thing that some of you may not have experienced yet. I have on
2 occasions had the nose wheel cock a little on takeoff. It has been
related to dealing with a crosswind and the nose wheel touching just
before takeoff. I try to get the nose wheel off early and carry it till
lift off but sometimes with a gust of wind or loss of wind the nose
wheel will touch just a little and get moved off of straight. I checked
the tightness of the nut and all is fine. This past weekend I mentioned
it to Van and he said it has happen to him in flight. We both agreed it
is annoying because if you have the rudder trimmed to fly nice and true
and you end up holding left rudder in to keep from crabbing through the
air. He said it happened on a long trip before to him. Anyone else.
Van said they looked for a reason like the washers had some wear that
may have caused a notch but they were fine. Anyone else had this happen?
Randy 006
Why did your tech counselor not want the stobe wires in the same conduit?
Chris Lucas
#40072 Fuselage top
Sent: Tuesday, May 08, 2007 4:33 PM
Subject: RE: RV10-List: Wiring Harness from Vans - should I plan to get it?
> been very helpful.
> Hope it's helps,
Thanks all for the advice. From what I've seen on Deems' and Tim's sites
this thing should fly ( pun intended ) as is. And Tim's right, a new
bellcrank is short money and very little time to make up. Maybe I could
exchange the old bracket for new bellcrank parts. Hmmmmmmmm. Did I mention
I'm cheap? Another example of the wealth of info this board
provides....john
John Hasbrouck
#40264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UmVhZCAic25hcCBidXNoaW5nIiBub3Qgc25hcCByaW5nLiBUaGFua3MgZm9yIGNhdGNoaW5nIHRo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: | Crack in WD-1017 |
A couple of weeks ago while I was working on my nose wheel fairing, I
discovered a crack in my WD-1017 (see pictures). I had inspected the 1017
before I installed it last fall and other than pushing the airplane in and
out of the hanger once, it has just sat there. You might want to inspect
yours. I returned it to Vans and they have provided me a new one.
After removing the 1017 to send it back, it looked like the left flange was
angled out slightly.
Rene'
N423CF
40322
801-721-6080
From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
Subject: | Re: nose wheel cocked in flight |
Just a brief note to say THANKS to Randy and Cheryl tonite once we got i
nto Portland for T Training with Mike S. this week. If you have not se
een Randy's RV 10 you need too..he did a great job building it. What is
most amazing is he PAVED the way for the rest of us and had no one else
s to look at for help. Randy gave us a ride then treated us to a BBQ w
ith his new GRILL at the hanger. What a great couple to have in the RV
family.
Thanks again,
DEAN 40449
we got into Portland for T Training with Mike S. this week.
If you have not seeen Randy's RV 10 you need too..he did a great job bu
ilding it. What is most amazing is he PAVED the way for the rest o
f us and had no one elses to look at for help. Ran
dy gave us a ride then treated us to a BBQ with his new GRILL at&nb
sp;the hanger. What a great couple to have in the RV family.
Thanks again,
DEAN 40449
