RV10-Archive.digest.vol-ci
May 25, 2007 - May 31, 2007
      > For those who aren't instrument rated though, my recommendation
      > backs up a step....I really think you'd benefit from the rating
      > before you build the panel.  No insult intended, but you really
      > don't have a clue about IFR flight until you've been through
      > it with training and even some experience...where it's YOU
      > at the controls with the sweat on your brow.  Then, at that
      > point, you'll have enough of a concept to begin flying some
      > systems and seeing how well you can do, and if they do everything
      > you would hope for.
      Totally agree with this!
      Just as "Friends don't let friends drive drunk",  I'd also suggest that
      "Friends should not let VFR friends build IFR panels."  Even after you
      have the rating, you really need time "in the system" to determine what
      is really important.  You see some panels supposedly built for IFR and
      you know the person who designed it dose not actually fly IFR.
      I also agree with Scott's earlier comment that a glass panel ironically
      allows you more time looking out the window.  For the CIA, you spend
      much less time on the C and the I, leaving more time for the A and
      William
      http://wcurtis.nerv10.com/
Subject: Re: The Perfect Panel - The Perfect airplane
Date: May 25, 2007
I was under the impression that GRT EFIS, since they have a good relationship with Trutrak and have rewritten some of the control laws, would drive the DII VSGV from an SL30 either VOR or ILS and could set ALT off of the EFIS also. Of course pilot controls climb or decent rate. Also I believe the GRT will fly a silulated ILS at a non ILS airport. I hope I've understood correctly since that is what I bought but have'nt put to use yet. Randy ----- Original Message ----- From: "Jesse Saint" <jesse(at)saintaviation.com> Sent: Friday, May 25, 2007 11:41 AM Subject: RE: RV10-List: The Perfect Panel - The Perfect airplane > > You are right for the most part. The Sorcerer, I believe, doesn't have an > internal heading source, while the Digiflight II does (which isn't worth > anything on the ones that I have flown). If you lose heading info from > the > external GPS, the Sorcerer will let you decide a bank angle, whereas the > DII > will let you select a Heading ("HDG" will display instead of "TRK" when it > gets the info from a GPS). The Sorcerer will let you select a target > altitude for climb or descent, and how you want to get there, indicated > airspeed for climb and distance for descent, or vertical speed for either. > This comes in very handy when being vectored by ATC and they say to > maintain > at or above a certain altitude, you just punch it in and tell it a > distance > and you are done (3 seconds). Vector change is just a rotation of the > knob > on either. The Sorcerer will fly the NAV radio, whether VOR's or ILS. Do > all ILS approach airports have a precision GPS approach also? Does > anything > except the GRT offer "artificial GPS approaches" on an ILS? This may not > matter to some, but there are a lot of pilots who still want to be able to > fly an actual ILS, although this is probably changing with the WAAS > approaches. When going missed approach, a toggle of the UP/DOWN switch > will > automatically take you into a 500fpm climb while you figure out what to do > next. With separate buttons for everything, it is much easier to navigate > and get just what you want, when you want it. > > The RV-10 AP is just the Sorcerer without the analog NAV functions, and > both > the Sorcerer and the RV-10 AP have the Yaw Dampener as an option, although > I > don't believe it is standard with the RV-10 AP, although they mentioned it > as such in the beginning. The AP-100 is the Sorcerer without the Altitude > Select or VNAV functions, but it includes the analog NAV functions. > > The extra $4K for the Sorcerer is a chunk of change, but for many I think > the peace of mind of having almost all controls right on the unit instead > of > having to tell it what to do through the GPS or EFIS is worth it. If you > don't want the altitude select but do want the analog NAV, go with the > AP-100 for $6,900. If you don't want the analog NAV and do want the > altitude select, go with the RV-10 AP. If you want both, go with the > Sorcerer. If you don't want either, then the DII VSG or VSGV are for you, > at $4,725 and $5,225 respectively. > > Of course, they are all fantastic auto pilots. Monitor your trim, though, > unless you want to get into aerobatics. :-) > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > www.saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis > Sent: Friday, May 25, 2007 11:37 AM > To: rv10-list(at)matronics.com; rsipp(at)earthlink.net > Subject: Re: RV10-List: The Perfect Panel - The Perfect airplane > > > Richard, > >> Just one example that took a awhile to understand was the significant >> differences between the DigiFlight and Sorcerer autopilots. One has it's >> own brain (Sorcerer) and can fly most any scenario on it's own while the >> DigiFlight requires some other component to do the heavy thinking. > > Just a minor correction. Both the DigiFlight and the Sorcerer "have a > brain." Each can fly the airplane on its own using the built in heading > gyro and altitude sensor. What the Sorcerer adds is VHF/NAV capability. > That is, it can fly a coupled VOR/LOC/ILS approach from any plain old > VHF/NAV radio. The DigiFlight can do this only if you are flying an > overlay > approach on your IFR GPS and it is controlling the autopilot. Since most > IFR GPS will provide a lateral overlay, and now the "W" GPS will also > provide vertical guidance, the benefits of the Sorcerer over a DigiFlight > II > VSGV are not worth the extra $5K IMHO. Also if you truly want the > DigiFlight to fly a VOR/LOC/ILS, not just the overlay, you could drive if > from any HSI/EFIS with an ARINC 429 interface and GPSS-V. > > The TruTrak RV-10 Autopilot is the Sorcerer with the VHF/NAV capability > removed and a yaw dampener added. > >> The costs envolved in a modern safe IFR EFIS panel are probably the > biggest >> single expense catagory in the project, but if well planned and executed >> should provide and equally valuable sense of acomplishment. > > I've seen many use this term -- What exactly is an "IFR EFIS"? I know > what > an IFR GPS is as there are many TSOs and documents relating to it but for > those that use this term, can you explain what makes one EFIS IFR and one > not? > > William > http://wcurtis.nerv10.com/ > > > -- > 4:01 PM > > > ________________________________________________________________________________
Date: May 25, 2007
Subject: Re: The Perfect Panel...how to decide - was GNS-430W
Well said William. I think I'd totally agree even though I haven't seen any of those panels. What's CIA? William Curtis wrote: > Just as "Friends don't let friends drive drunk", I'd also suggest that "Friends should not let VFR friends build IFR panels." Even after you have the rating, you really need time "in the system" to determine what is really important. You see some panels supposedly built for IFR and you know the person who designed it dose not actually fly IFR. > > I also agree with Scott's earlier comment that a glass panel ironically allows you more time looking out the window. For the CIA, you spend much less time on the C and the I, leaving more time for the A and looking out the window. > > > William > http://wcurtis.nerv10.com/ > > > > Totally agree with this! ________________________________________________________________________________
Subject: Re: FS: MT Prop Gov
Date: May 26, 2007
Jesse, or anyone. Is this a common governor model supplied with other Vans kits with constant speed props? John 40315 ----- Original Message ----- From: "Jesse Saint" <jesse(at)saintaviation.com> Sent: Saturday, May 26, 2007 2:57 AM Subject: RE: RV10-List: FS: MT Prop Gov > > We had problems with an RPM surge at a certain RPM setting with the MT, > but > it was fixed with a stronger spring. I think the new units should all > have > the stronger spring now, but am not sure. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > www.saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis > Sent: Friday, May 25, 2007 12:29 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: FS: MT Prop Gov > > > Some folks are opting for the PCU5000/X (http://pcu5000.com). It > supposedly > governs better than the MT provided in the FF kit. Someone on > Vansairforce > is doing a group buy of the PCU5000. Since the PCU5000X ($1350) is more > expensive than the MT ($Van's $1100), this may be another case of a > solution looking for a problem. Has anyone flying had issues with the MT > P-860-3? > > http://www.vansairforce.com/community/showthread.php?t=17279&page=1&pp=10&hi > ghlight=pcu > > William > http://wcurtis.nerv10.com/ > > -------- Original Message -------- >> X-Rcpt-To: >> >> Why would you sell? What are you going to run with? >> >> John >> ________________________________ >> >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neal George >> Sent: Wednesday, May 23, 2007 7:40 PM >> To: rv-list(at)matronics.com; RV7A(at)yahoogroups.com; rv10-list(at)matronics.com >> Subject: RV10-List: FS: MT Prop Gov >> >> >> >> Listers - >> >> >> >> I have a new MT prop governor for sale. >> >> $1075, shipped. >> >> >> >> Neal E. George >> 2023 Everglades Drive >> Navarre, FL 32566 >> Home - 850-515-0640 >> Cell - 850-218-4838 > > > -- > 4:01 PM > > > ________________________________________________________________________________
Subject: The Perfect Panel...how to decide - was GNS-430W
Date: May 25, 2007
So, do we have to take a test before we comment, or do we just submit a bio with every comment? Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Friday, May 25, 2007 1:43 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W Inexperienced or non-IFR pilots should not be giving advise to the masses in how to build panels or selection of avionics components. I whole-heartedly concur with your advise. The masses need to know the quality of the source before giving it consideration on something so vitally important. Learn to clear out the clutter quickly. I will let the experienced IFR pilots chime in on Vertical Stacking versus Horizontal Stacking and its importance being placed as high on the panel as practical. Not withholding the importance of a Back Seat WSO with the armament screen between his/her legs. Some panel layouts aid in resale, others lend themselves to being scrapped and rebuilt for resale. The eye is in the beholder (purchaser). Till then rejoice in your choice and fly often/ fly safe. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Friday, May 25, 2007 12:26 PM Subject: Re: RV10-List: The Perfect Panel...how to decide - was GNS-430W > For those who aren't instrument rated though, my recommendation > backs up a step....I really think you'd benefit from the rating > before you build the panel. No insult intended, but you really > don't have a clue about IFR flight until you've been through > it with training and even some experience...where it's YOU > at the controls with the sweat on your brow. Then, at that > point, you'll have enough of a concept to begin flying some > systems and seeing how well you can do, and if they do everything > you would hope for. Totally agree with this! Just as "Friends don't let friends drive drunk", I'd also suggest that "Friends should not let VFR friends build IFR panels." Even after you have the rating, you really need time "in the system" to determine what is really important. You see some panels supposedly built for IFR and you know the person who designed it dose not actually fly IFR. I also agree with Scott's earlier comment that a glass panel ironically allows you more time looking out the window. For the CIA, you spend much less time on the C and the I, leaving more time for the A and looking out the window. William http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: May 25, 2007
Yes Tim, I think we are on the same page and basically agree.... -- Hands on experience is extremely valuable and is the key to making informed decisions -- You can put together the right panel if you take advantage of some hands-on and all the other info sources -- Putting an IFR panel together screams for first having a rating, some experience using it, plus some hands-on with current equipment I feel like I have the IFR experience and so with some study and some hands-on with the current equipment, I'll be able to design the panel of my dreams and pocketbook. At the same time, I'm suggesting that if I didn't have the previous IFR time, it might make sense to either get it, or put together a good VFR machine. Fly it, confirm that I want IFR capability to expand my mission, then somehow get the rating, some experience, and then retrofit my panel. And if VFR in the '10 completely floats my boat which is highly likely in this super ship - I have what I want along with quite a few saved $$$ for fuel. WANTED, any RV10 pilot (including Tim) who is passing thru the Carolinas. Please stop by 8NC8 and say Hi! I've got hangar space and a fuel tank... I top you off for a ride! That's 8NC8, exactly 10nm mag north of RDU. AKA, Lake Ridge Aero Park in Durham NC. Bill "in the hangar building but still able to post" Watson Tim Olson wrote: > > Bill, while it's definitely an option to outfit minimally, as > Gary S. mentioned before, and flying for a while until you > know your mission or goals, I'm not sure if it would help. > Doing that would prevent you from getting hands-on experience > that would help you form your goals. > > > > For those who aren't instrument rated though, my recommendation > backs up a step....I really think you'd benefit from the rating > before you build the panel. No insult intended, but you really > don't have a clue about IFR flight until you've been through > it with training and even some experience...where it's YOU > at the controls with the sweat on your brow. Then, at that > point, you'll have enough of a concept to begin flying some > systems and seeing how well you can do, and if they do everything > you would hope for. > > Tim > > >> But the point I'm getting to is this - properly equipping a used GA >> plane for IFR required IFR experience in the old 6 pack days. >> Figuring out how you would combine existing equipment with a major >> upgrade, and coming out the back end with what you wanted took some >> experience. Perhaps properly equipping a homebuilt for IFR requires >> IFR experience too. There are many choices, many alternatives, and >> many approaches in a constantly changing environment. Would that >> make the prudent course to equip for VFR, get experience with plane, >> mission, and self., then upgrade as desired? Inefficient? maybe. >> Some dollars may be wasted. But the bottom line may in fact >> benefit. Just a thought. >> > > ________________________________________________________________________________
Date: May 25, 2007
On May 25, 2007, at 2:26 PM, William Curtis wrote: > Just as "Friends don't let friends drive drunk", I'd also suggest > that "Friends should not let VFR friends build IFR panels." Even > after you have the rating, you really need time "in the system" to > determine what is really important. You see some panels supposedly > built for IFR and you know the person who designed it dose not > actually fly IFR. What? You're telling me that just because I don't have my ticket *yet* that I shouldn't build a panel for when I *do* get it? My currently VFR skills will have an IFR panel including Chelton/Op + associated *stuff*. The EFIS can be used for VFR too and I don't have to spend a lot of $$time$$ adding *stuff* when my IFR ticket is mailed. Confused and maybe missing the point. -Sean #40303 ________________________________________________________________________________
Date: May 25, 2007
The great thing is we get to rebuild our panels as often as we like. Going home to work on my instrument rating using ASA IP PC based software :) Bobby 40116 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Friday, May 25, 2007 2:03 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W So, do we have to take a test before we comment, or do we just submit a bio with every comment? Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Friday, May 25, 2007 1:43 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W Inexperienced or non-IFR pilots should not be giving advise to the masses in how to build panels or selection of avionics components. I whole-heartedly concur with your advise. The masses need to know the quality of the source before giving it consideration on something so vitally important. Learn to clear out the clutter quickly. I will let the experienced IFR pilots chime in on Vertical Stacking versus Horizontal Stacking and its importance being placed as high on the panel as practical. Not withholding the importance of a Back Seat WSO with the armament screen between his/her legs. Some panel layouts aid in resale, others lend themselves to being scrapped and rebuilt for resale. The eye is in the beholder (purchaser). Till then rejoice in your choice and fly often/ fly safe. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Friday, May 25, 2007 12:26 PM Subject: Re: RV10-List: The Perfect Panel...how to decide - was GNS-430W > For those who aren't instrument rated though, my recommendation backs > up a step....I really think you'd benefit from the rating before you > build the panel. No insult intended, but you really don't have a clue > about IFR flight until you've been through it with training and even > some experience...where it's YOU at the controls with the sweat on > your brow. Then, at that point, you'll have enough of a concept to > begin flying some systems and seeing how well you can do, and if they > do everything you would hope for. Totally agree with this! Just as "Friends don't let friends drive drunk", I'd also suggest that "Friends should not let VFR friends build IFR panels." Even after you have the rating, you really need time "in the system" to determine what is really important. You see some panels supposedly built for IFR and you know the person who designed it dose not actually fly IFR. I also agree with Scott's earlier comment that a glass panel ironically allows you more time looking out the window. For the CIA, you spend much less time on the C and the I, leaving more time for the A and looking out the window. William http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: May 25, 2007
This should be part of the test:-) The basic tenant of IFR flying: Cross-check, Instrument interpretation and Aircraft control. William http://wcurtis.nerv10.com/ -------- Original Message -------- > > > Well said William. I think I'd totally agree even though I haven't seen > any of those panels. > > What's CIA? > > William Curtis wrote: > > Just as "Friends don't let friends drive drunk", I'd also suggest that "Friends should not let VFR friends build IFR panels." Even after you have the rating, you really need time "in the system" to determine what is really important. You see some panels supposedly built for IFR and you know the person who designed it dose not actually fly IFR. > > > > I also agree with Scott's earlier comment that a glass panel ironically allows you more time looking out the window. For the CIA, you spend much less time on the C and the I, leaving more time for the A and looking out the window. > > > > > > William > > http://wcurtis.nerv10.com/ > > > > > > > > > > > > > > > > > > > > Totally agree with this! > > ________________________________________________________________________________
Date: May 25, 2007
LOL I don't really want to do a 2-phased panel. I want to put in what I'm going to be flying, VFR and IFR, for the foreseeable future. I've been looking at well equipped panels of Bonanzas and Mooney's of not too long ago, and almost anything we come up with today can blow most of those away for better situational awareness and ease of use. It would be simple for me to do something like this: AFS 3500 with engine monitoring, G430W, SL30, GMA340 or comparable, GTX330, GMX200 with weather and traffic, TT Sourcer, some back up gauges...not too shabby given what was available even a few years ago. However, is it the best bang for the buck; does it give me the most utility for the money? And, how does one define utility? I'm VFR rated with some IFR training under my belt, but not the ticket. I have no advice to give, other than if you have experience about what works out there because you've used it, please help us learn. John J 328 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Friday, May 25, 2007 1:03 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W So, do we have to take a test before we comment, or do we just submit a bio with every comment? Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Friday, May 25, 2007 1:43 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W Inexperienced or non-IFR pilots should not be giving advise to the masses in how to build panels or selection of avionics components. I whole-heartedly concur with your advise. The masses need to know the quality of the source before giving it consideration on something so vitally important. Learn to clear out the clutter quickly. I will let the experienced IFR pilots chime in on Vertical Stacking versus Horizontal Stacking and its importance being placed as high on the panel as practical. Not withholding the importance of a Back Seat WSO with the armament screen between his/her legs. Some panel layouts aid in resale, others lend themselves to being scrapped and rebuilt for resale. The eye is in the beholder (purchaser). Till then rejoice in your choice and fly often/ fly safe. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Friday, May 25, 2007 12:26 PM Subject: Re: RV10-List: The Perfect Panel...how to decide - was GNS-430W > For those who aren't instrument rated though, my recommendation backs > up a step....I really think you'd benefit from the rating before you > build the panel. No insult intended, but you really don't have a clue > about IFR flight until you've been through it with training and even > some experience...where it's YOU at the controls with the sweat on > your brow. Then, at that point, you'll have enough of a concept to > begin flying some systems and seeing how well you can do, and if they > do everything you would hope for. Totally agree with this! Just as "Friends don't let friends drive drunk", I'd also suggest that "Friends should not let VFR friends build IFR panels." Even after you have the rating, you really need time "in the system" to determine what is really important. You see some panels supposedly built for IFR and you know the person who designed it dose not actually fly IFR. I also agree with Scott's earlier comment that a glass panel ironically allows you more time looking out the window. For the CIA, you spend much less time on the C and the I, leaving more time for the A and looking out the window. William http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: May 25, 2007
As best I can tell, the RV-10 AP doesn't include the yaw damper in the base price. According to <http://www.trutrakflightsystems.com/autopilot2_2.htm> the RV-10 AP ($7250) has the yaw damper as an option (another $2500). A weather/traffic/terrain/airspace display option for the lower-cost-than-perfect panel: Garmin 496 (handheld - around $2800) will display WxWorx from XM and also TIS info from the appropriate mode S Garmin transponder (GTX 330). To integrate the 496 with the Nav/Com/IFR GPS one can run a serial line from the IFR-certified GNS-430(W) or GNS-530(W) to the 496. This will automatically transfer the active flight plan and waypoint from the 430/530 to the 496. The 496 is also a pretty good street navigator for use at your destination (includes audible turn guidance in automobile mode). Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 900 hrs RV-10 #40059 under construction William Curtis wrote: > > Richard, > > >> Just one example that took a awhile to understand was the significant >> differences between the DigiFlight and Sorcerer autopilots. One has it's >> own brain (Sorcerer) and can fly most any scenario on it's own while the >> DigiFlight requires some other component to do the heavy thinking. >> > > Just a minor correction. Both the DigiFlight and the Sorcerer "have a brain." Each can fly the airplane on its own using the built in heading gyro and altitude sensor. What the Sorcerer adds is VHF/NAV capability. That is, it can fly a coupled VOR/LOC/ILS approach from any plain old VHF/NAV radio. The DigiFlight can do this only if you are flying an overlay approach on your IFR GPS and it is controlling the autopilot. Since most IFR GPS will provide a lateral overlay, and now the "W" GPS will also provide vertical guidance, the benefits of the Sorcerer over a DigiFlight II VSGV are not worth the extra $5K IMHO. Also if you truly want the DigiFlight to fly a VOR/LOC/ILS, not just the overlay, you could drive if from any HSI/EFIS with an ARINC 429 interface and GPSS-V. > > The TruTrak RV-10 Autopilot is the Sorcerer with the VHF/NAV capability removed and a yaw dampener added. > > >> The costs envolved in a modern safe IFR EFIS panel are probably the biggest >> single expense catagory in the project, but if well planned and executed >> should provide and equally valuable sense of acomplishment. >> > > I've seen many use this term -- What exactly is an "IFR EFIS"? I know what an IFR GPS is as there are many TSOs and documents relating to it but for those that use this term, can you explain what makes one EFIS IFR and one not? > > William > http://wcurtis.nerv10.com/ > > > ________________________________________________________________________________
Date: May 25, 2007
Great statement Bobby. Now here is a new question that goes to the heart of Amateur Built (current rules). Does a total change-out of engine type, prop type or major alteration to an airframe (Down the Road) require a revisit by a DAR or PAI? Or does the repairman have the latitude to alter the engine/prop/panel from basic VFR to EFIS/IFR without a trail of paperwork and new set of eyes? What latitude for modification is legal and appropriate for a kit designed and tested VAN's RV-10? "Round Two" - No bio required "Do you feel Lucky?" John Cox A&P with IA 40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Friday, May 25, 2007 2:26 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W The great thing is we get to rebuild our panels as often as we like. Going home to work on my instrument rating using ASA IP PC based software :) Bobby 40116 ________________________________________________________________________________
Date: May 25, 2007
One of the local DAR's visited our last EAA chapter meetings and if I remember correctly, engine and props were on the list of major mods. You would have to reenter your "phase 1". But I was a little unclear about how to do that. It did not sound like you would be visited again, but would need a new program letter.....but I really wasn't paying to much attention at that time since I never plan to changing the engine or prop...... Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Friday, May 25, 2007 3:24 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W Great statement Bobby. Now here is a new question that goes to the heart of Amateur Built (current rules). Does a total change-out of engine type, prop type or major alteration to an airframe (Down the Road) require a revisit by a DAR or PAI? Or does the repairman have the latitude to alter the engine/prop/panel from basic VFR to EFIS/IFR without a trail of paperwork and new set of eyes? What latitude for modification is legal and appropriate for a kit designed and tested VAN's RV-10? "Round Two" - No bio required "Do you feel Lucky?" John Cox A&P with IA 40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Friday, May 25, 2007 2:26 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W The great thing is we get to rebuild our panels as often as we like. Going home to work on my instrument rating using ASA IP PC based software :) Bobby 40116 ________________________________________________________________________________
Date: May 25, 2007
Subject: Re: Trueflight 190The Perfect Panel
Kevin...please keep in mind that 2 minute old "radar" is not radar but good recent history information...if you say I have radar to the ATC they are going to believe you and may not give you a pop up advisory assuming that you have active radar on board...telling ATC you have equipment that you do not have I think is a bit misleading and over playing your hand. But hat's just my opinion...having this information is valuable and certainly much better than flying blind...but it ain't radar... P ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: GPS News Alert
Date: May 25, 2007
AVweb News Alert: May 24, 2007 Having trouble viewing this AVwebAlert newsletter? Go online for the latest coverage. To ensure that you continue to receive this newsletter, please add avweb(at)e.avflash.com to your address book. May 24, 2007 AVweb | Register | Forward This E-Mail | Advertise | Help | Contact | Privacy Policy FAA POLICY CHANGE VOIDS MANY IFR GPS UNITS Many previously IFR-certified GPS receivers might now be unapproved for flying many instrument procedures due to recent FAA policy changes, according to AOPA. On Thursday, the association said the FAA's Advisory Circular 90-100A, issued in March, indicates that only three GPS models -- the Garmin 400, 500 and G1000 series -- are now legal. Other models made by Garmin, including the new GNS 480 WAAS receiver, as well as receivers manufactured by Chelton, Honeywell, Northstar, and Trimble are listed as "noncompliant," AOPA said. The action means up to 26,000 GPS users no longer comply with a 1996 FAA policy that allows GPS to be used in lieu of ADF or DME. More... You are subscribed to AVweb Breaking News Alerts at tlc2(at)telus.net. Unsubscribe from AVweb Alerts here. Subscribe, change your password, or edit your newsletter preferences here. Questions concerning delivery of this newsletter? Please contact our customer service department at: http://www.avweb.com/help_desk AVweb | Register | Forward This E-Mail | Advertise | Help | Contact | Privacy Policy copyright =A9 2007 Belvoir Media Group, LLC / Aviation Publishing Group All rights reserved. Belvoir Media Group | 800 Connecticut Avenue | Norwalk, CT 06854 ________________________________________________________________________________
Date: May 25, 2007
I've got almost identical plans as John's plans at the moment. I'm just waiting for Osh to get some hands on experience with the booth demos. I'm also keeping an eye on MGL and their new 10" Odyssey due at OSH and WTD's offering. Although WTD is a little more pricey at the moment. I am IFR rated and really like both Chelton and OP Technologies. Unfortunately, my budget won't allow it at the moment. Something about the wife wanting to remodel the house and two kids in college. Sounds like we got the makings of a large RV-10 consortium to make the rounds at Osh. It would be humorous for a group of us to visit the vendors as a horde. Even better, develop a common script for an IFR demo to give to the vendors beforehand and tell them we expect to see the demo script in their booth. Bob 684 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Friday, May 25, 2007 4:32 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W I don't really want to do a 2-phased panel. I want to put in what I'm going to be flying, VFR and IFR, for the foreseeable future. I've been looking at well equipped panels of Bonanzas and Mooney's of not too long ago, and almost anything we come up with today can blow most of those away for better situational awareness and ease of use. It would be simple for me to do something like this: AFS 3500 with engine monitoring, G430W, SL30, GMA340 or comparable, GTX330, GMX200 with weather and traffic, TT Sourcer, some back up gauges...not too shabby given what was available even a few years ago. However, is it the best bang for the buck; does it give me the most utility for the money? And, how does one define utility? John J 328 ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: May 25, 2007
OK, well here are a couple of thoughts on the "should I or shouldn't I build IFR" decision. It's all a chain of connected decisions. A) If you are routinely traveling any distance or into a heavy traffic area, you want the option to be able to file IFR for traffic and ease of fitting into the traffic flow. Don't have to but you will like it if you do! B) Lots of eyes on you. C) Also there are MANY VFR days that are crummy flying days because of haze and cloud but if you want to go somewhere, to be able to file IFR /G and go is wonderful. AND D) you will be a lot better pilot after you get your IFR ticket. I thought that was a joke until I did it and it's just true. Few folks really learn anything until they NEED to know and getting the ticket requires you to upgrade your weather management skills, ATC system skills, risk assessment, AND your appreciation of how good you really are when it hits the fan. Understanding how easy it is to die in the soup had made me a lot better pilot and much more critical of my decision making process. >> So how about equipment? Here was my thought process after a lot of IFR hours in a nice spam can. I like flying VFR/IFR which means flying on an IFR plan but looking outside instead of inside to see the sights. I love to be able to dial in an altitude and have the plane climb or descend and capture it. I love to drive the plane with the heading bug. I wanted to be able to fly a coupled approach from the final approach course( don't care about a full approach, hold, etc cause it almost never happens that way). The funny part is that I wanted the plane to do all that so that I could look outside for the view and other traffic. >> That lead me to the EFIS and Autopilot decisions: a) GRT because they are airplane folks writing code and not computer guys learning to fly B) GRT systems are tightly integrated to Tru-Trak Auto pilots and Jim Younts is here in Arkansas :-) AND builds a fabulous AP c) the GRT system is less expensive than a 6 pack with an HIS and heading bug d) the GRT and TT VSVG allow you to fly the way I like to fly with altitude preselect and capture. HIS/OBS indicators built-in. D) Customer support and knowledge about systems is 10+++ >> That lead me to the NAV/Comm Decision : A) Gotta have a Garmin 430 because it is IFR certified and you need that to fly an approach at the end of the trip b) it is reasonably priced and can be kept current on a reasonable price basis C) WAAS is gravy and I like gravy. D) Great NAV and Great COMM and you need at least one great one of each e) 430 does a great job of driving the TT AP >> That leads to the On-Board Wx decision: I simply can't explain how different flying in any weather is when you have a Gods-eye view of everything around you, full Metars at airports 360 degrees around you. Etc. I wouldn't go VFR without it anymore. Soooo, I bought the Garmin 396 so that I can take it to the spam can, travel with friends, play with it in the house, whatever. I really really like NOT having it in the panel. I am lucky to also be able to drive a Baron with on-board radar and I never turn it on, complete waste of money. Always take the Garmin. >> Other IFR related decisions: 1) TPX330 because I wanted to see traffic displayed on the GRT screens, 2) P-Mag and Slick because I wanted electronic ignition but was "skeared" of not having a mag if everything died. 3) Garmin 396 with Wx (see above) 4) full 2 1/4 analog Alt, AS, Compass, with electronic T&B backup gauges 5) ICOM A24 radio in my flight bag in case everything electronic dies (never used it) 6) AeroElectric Nuckell-Head Z13/8 electric system with Heavy duty everything This allows me to fly the way I like 99% of the time and fits my Worst worst worst case IFR scenario: Flying along at night in the soup, everything electronic craps out despite all the redundant systems, what to do? I fly the plane on analog for a minute, (it's trimmed so nothing should change), switch the Garmin to the artificial panel as a back up, turn 180 and head home or to VFR, pull out my ICOM and shout for help! That's my most basic TU "back-up/out" plan but even that is not a low risk exit, but at least I have found my own balance between risk, mission, dollars, and safety. My opinion and it's only that on the most basic IFR ride is this. GRT system (or one that has and HIS and heading bug NAV to AP), basic AP of your choice that will track NAV, GNS430 not WAAS or at least the SL40(?) NAV/COM, basic analog backups, other usual stuff of choice. I think if you price it out, you will be within about 5K of a nice VFR ride and that's not much compared to the total cost of the airplane. This gets you enough to be safe, get your ticket, fly great VFR/IFR and be very safe as long as you make good decisions. BUT the first thing I would add is a Garmin 496 with Wx. Funny, this just moved from the Perfect IFR Panel to the Minimal IFR Panel ? How'd dat happen" Hope this helps! Bill S -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: Friday, May 25, 2007 12:33 PM Subject: Re: RV10-List: The Perfect Panel...how to decide - was GNS-430W It's starting to make sense to me too! Taking it a step further, does it make sense to even try to do a basic IFR setup in one's '10 before one has the rating and has had a chance to use it for awhile? You raised the point of button pushing versus proficiency and currency. That's a big question for me. One one hand, I've seen our local package express/check cashing pilots train. These folks can fly a failed engine twin with the standard 6 pack thru an approach, miss, and hold and still talk about "I like keeping it a half needle to the right so my landing light will be on the centerline when I break out". I just try to fly straight enough to avoid embarassing myself on the controllers radar. On the other hand, I found use of my 2nd generation IFR cert'd Garmin 300XL a total challenge. Flying a standard GPS T approach with it is a piece of cake. Flying an ADF or VOR overlay is more challenging. Trying to use it to aid in a typical vector-to-ILS situation can also be challenging. With proficiency, I can use it to great advantage in these situations. When a bit rusty, rust being a very real challenge to us non-pros, it was best to just fly vectors and use it exactly as an ADF or DME might be used. But forget the moving map, programming interim points, or even trying to use it as a second VOR in those situations. I learned that often less was more. It's pretty crude technology compared to the modern systems. Tim and others are convincing me that the *some* of the current stuff is actually easy to use even when mixed with a bit of rust. I need some hands-on to confirm that for me. I'm sure some of the current stuff is more challenging. We are certainly on the verge of having these systems actually make *all* aspects of IFR flight easier and safer for the non-pro. But the point I'm getting to is this - properly equipping a used GA plane for IFR required IFR experience in the old 6 pack days. Figuring out how you would combine existing equipment with a major upgrade, and coming out the back end with what you wanted took some experience. Perhaps properly equipping a homebuilt for IFR requires IFR experience too. There are many choices, many alternatives, and many approaches in a constantly changing environment. Would that make the prudent course to equip for VFR, get experience with plane, mission, and self., then upgrade as desired? Inefficient? maybe. Some dollars may be wasted. But the bottom line may in fact benefit. Just a thought. I feel like I have some experience but frankly, I stand here lost in the face of all the choices. My dream is an IFR cruiser that will put my 'ol Maule to shame. So I will try to take advantage of those that have gone before and end up with a Cheltonesque panel and as few unused redundancies as possible. We'll see. Bill "heading to the hangar for a long weekend of progress" Watson John Jessen wrote: > > Yes! > > I think that the point is well presented and well taken. I've said to > more than one person that "I don't get it" in terms of all the higher end panels. > Tim, Deems and others have explained their rationale to me and I'm > slowly getting it, but Bill finally put into words what I haven't been > able to. I love flying for the sake of flying, and to me this means > VFR most of the time. This is what has been in the back of my mind > and I couldn't explain it. Thanks, Bill !! > > I will get my IFR rating, because I honestly do believe it will make > me a better pilot (and insurance companies might like me better) just > as a tail wheel endorsement will also. I have a float plane rating > and that certainly has made me better (landing floats on glassy waters > requires some precision that I wasn't used to before). However, I love the ability to just fly. > Get in and go. Sure you want to have a flight plan and file it, and > sure you'd like flight following, but there's something about keeping > it simple that appeals to me. > > So, my big challenge has been what to put in that works well in the > assumed IFR future that I know I'll be involved in, but also doesn't > bust the bank, and doesn't just sit there while I have fun looking out > the window and down at my maps occasionally. And will I keep current > enough in real IMC that I could, honestly, safely, take advantage of > the IFR system? This is a big, big question. I think for those who > are already IFR trained and that's what they normally fly, it isn't > such an issue to think in terms of the more advanced systems. If they can afford it, it probably is a no brainer. > > But there's the rub. A high end system can make IFR simpler during > the high workload, high risk scenarios that one will, if they fly > IFR/IMC, eventually find. That's when a current, but not super > current, IFR pilot needs that electronic horsepower. So, getting a > glass panel 6-pack substitute, such as the AFS EFIS, coupled with a > (for example) G430W and some type of MFD, may not be the safest thing > for someone who spends most of his/her time flying VFR, with only the > occasional IFR/IMC usage. This is why I'm so interested in the > combination of equipment that can bridge that gap between basic IFR > and the high end systems. You want minimal button pushing and mental > gyrations in those situations that are the highest stress/workload > situations. It's easy to do enroute with almost any system. It gets > progressively more difficult for take offs, holdings, approaches, but all of these have been done for decades on steam gauges, so it's not impossible. > It's just that with all the goodies out there, one wants to put > together something that works well, doesn't bust the bank (for me and > I bet many who are not commenting on the list), but can be effective. > This is why I've been begging for situational descriptions about how > systems work well or not. Tim is correct, this is so hard to discuss > because everyone is working for such minimal examples, both in terms > of situations and in terms of equipment. However, the situations do > exist, whether you've experienced them or read about them, and you > know your system, so you can give at least some type of evaluation how > it should work given the situation. To some it might also be > embarrassing to discuss what has happened and how their system > responded, but we need to discuss these things in order for all of us > to gain. I want all of us to benefit, and really the only way is to get the stories out and discuss them. > > Money will be the limiting factor for many of us. Someone is going to > have to give me oxygen when I plunk down my bucks for the panel. And > that's after I've been let out of the intensive care unit for the engine payment. > However, when all is said and done, I'll be happy with whatever I have > and practice with it as much as possible. True enough. But until > then lots of decisions have to be made. Bill has helped me understand > what it was that I couldn't get put into words, that I couldn't get > past a generalized feeling about. That's the beauty of this list and of sharing thoughts. Please! > Those silent ones out there. Jump in! The water is fine. > > John Jessen > #328 > > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver > Sent: Friday, May 25, 2007 8:20 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: The Perfect Panel...how to decide - was > GNS-430W > > > This has all made me try to think around this issue a different way. > Give a realistic assessment of a future the owner's capabilities, > missions and desires, perhaps a less considered sweet spot is the VFR cruiser. > > Assume for a minute that the owner is not instrument rated (but plans > to be sometime in the future), or is not able/willing to always remain > current per the regs (me). Assume that the '10 will be a serious > cross country machine (weekender bag, cooler, mate, extra shoes for > mate), and you live in the eastern US (just can't comment on > fly-styles west of the Mississip). I've been thinking of a guy I've > been listening to on Rec.aviation.pilot for a few years. He's been > flying a VFR Pathfinder quite happily for some years - Jay Honeck: > http://www.alexisparkinn.com/welcome_to_the_inn.htm > Many times Jay has been asked to defend his VFR-only flying, as in > "Jay, you need an IFR rating - it will make your travels so much > easier". But he argues that VFR is right for him and his family and > frankly he makes a lot of sense. Following his flying exploits, I > wonder if many/most of us will end up doing what he does. And if we do, we'll die very happy. > > What is out there weather-wise is a lot of very flyable VFR weather > and destinations. A simple steam guage VFR '10 like Van's is a super machine. > But as homebuilders, we are sorely tempted to juice it up. So how > would you juice up a VFR '10? > > Weather is still the issue. A 396 or better is practically mandatory > from a cost-benefit standpoint. It turns many marginal VFR sky gropes > out over the horizon, into more safer, fully informed journeys into > calm waters. > > What is also needed are tools to fly in the near-IFR conditions we all > fly in every summer. I'm not talking clouds or fog, or flying into > deteriorating conditions but just plain summer haze. Make it > westbound in the evening with smoke from a few distant fires and you > really can benefit from use of the gyro panel... or a low end glass > EFIS. Add an autopilot - anywhere from a wing leveler to a sorcerer > - and you can truly remain VFR because you are actually looking out the window. > Remember, anyone can trim a cruiser to maintain altitude, it's the wing > leveling that you really need. And if it's driven by your GPS, wow! > So a low end glass EFIS, GPS, autopilot, and a backup GPS with > Satellite weather and 101 music channels makes this a very comfortable > and capable VFR cruiser. > > To complete the safety package, add traffic awareness. > > It looks state of the art, it flys state of the art, it is state of the art. > And it may realistically reflect the true capabilities, mission, and > desires of many of us owner/pilots to be. > > You've skipped heated pitots, some Nav equipment, extensive backups, > certification(?), and the costs of getting and staying instrument > proficient. > > So how many $$ are needed to realize this dream? I don't know but > it's maybe it's worth a run. > > Below is one of Jay's latest postings to rec.aviation.piloting: > > We were flying back from Springfield last Sunday, arcing into a > setting sun the size of a pie tin. It was one of those flights where > you keep catching yourself turning off course, just to get the sun > behind the windshield post and out of your eyes... > > We'd been silent most of the way, just enjoying the ride and the > afterglow of a day well-spent visiting old friends, when my daughter, > age 13, asked me to play the theme song from "One Six Right" on the CD player. > > Mary and I both looked at each other, shocked that Becca even knew the > name of the album, much less the song itself -- but I quickly slid the > disk into the player, and listened as the fabulous opening bars began to play... > > (For those who don't know the music, listen to it here, for free: > http://www.onesixright.com/ ) > > There was a scattered layer of clouds below, and a few above, and the > sun played behind them, scattering the light into a million separate > beams, lighting the verdant farmland far below with a burning, > heavenly glow. The view was simply breath-taking. > > My daughter, usually oblivious to the flying she has done so often > since birth, suddenly asked me to "Do the soaring thing to the music, > Dad, like you did before..." > > Hesitant to deviate from straight and level while talking to Chicago > Center, I started a little dipping and rolling to the music. I > glanced over to see that her eyes were closed, the sunshine was > lighting her face like an angel, and she was simply *feeling* the > flight with all of her senses. She was grinning from ear to ear. > > Inspired, I let my inhibitions go, and began giant swoops and gentle > push-overs, all in time to the orchestral crescendos of "One Six > Right". Soon, I found myself closing *my* eyes, and feeling the > weightlessness at the top of the arc, and the one-G steep turns, back > and forth, all to the beat of the music. It was magical. > > Throat tightening, chest bursting, I wanted to cry with joy. If there > is a heaven, it must feel very much like this. > > And my daughter was "getting it"! > > When we landed, Becca -- vocally against the very notion of learning > to fly for so many years -- said "Dad, maybe I *will* learn to fly some day..." > > :-) > -- > Jay Honeck > Iowa City, IA > Pathfinder N56993 > www.AlexisParkInn.com > "Your Aviation Destination" > > > ________________________________________________________________________________
Date: May 25, 2007
Bill Schlatterer wrote: > -........ Few folks really learn anything until they NEED to know and > getting the ticket requires you to upgrade your weather management skills, > ATC system skills, risk assessment, AND your appreciation of how good you > really are when it hits the fan. Understanding how easy it is to die in the > soup had made me a lot better pilot and much more critical of my decision > making process. > > AMEN !!!!!!!! Deems Davis # 406 Finishing - ( A Misnomer ! ) http://deemsrv10.com/ IFR, but NOT current ________________________________________________________________________________
Date: May 25, 2007
Subject: Magneto to sparkplug routing
Anybody up for a temporary break from panel discussions? (which I'm enjoying thoroughly!) I'm into the engine install, and working on baffling and plenum, and I'm trying to think ahead so I know I've got clearance for spark plug leads, how to attach, baffling penetration etc.. I've got dual Slick mags 6350/6351 (I may be willing to be an early adopter on some things, but I couldn't get comfortable (yet) with conflicting info I was hearing on EI ). My engine shipped with the mag harnesses uncoupled from the plugs, And I'm at a loss on how to reconnect the leads. I've searched the Internet for information about how to connect them and I've come up empty. I know I can get the info from Allen @ BPE on Monday AM, but am hoping someone might have the answer over the weekend. (My Lycoming manual depicts 2 different methods for dual mags.) Thanks Deems Davis # 406 Finishing - ( A Misnomer ! ) http://deemsrv10.com/ ________________________________________________________________________________
Date: May 25, 2007
Subject: Re: Magneto to sparkplug routing
Boy, do I feel stupid :-[ I'm assuming that the answer must have something to do with the B3 (bottom cyl # 3 ?), T5 top Cyl #5?) , B6 ........etc stamped on the end of the leads that connects to the plug.... Too long in a 100 degree garage! Deems Deems Davis wrote: > > Anybody up for a temporary break from panel discussions? (which I'm > enjoying thoroughly!) > > I'm into the engine install, and working on baffling and plenum, and > I'm trying to think ahead so I know I've got clearance for spark plug > leads, how to attach, baffling penetration etc.. I've got dual Slick > mags 6350/6351 (I may be willing to be an early adopter on some > things, but I couldn't get comfortable (yet) with conflicting info I > was hearing on EI ). > > My engine shipped with the mag harnesses uncoupled from the plugs, And > I'm at a loss on how to reconnect the leads. I've searched the > Internet for information about how to connect them and I've come up > empty. I know I can get the info from Allen @ BPE on Monday AM, but am > hoping someone might have the answer over the weekend. > > (My Lycoming manual depicts 2 different methods for dual mags.) > > Thanks > > Deems Davis # 406 > Finishing - ( A Misnomer ! ) > http://deemsrv10.com/ > > ________________________________________________________________________________
Date: May 26, 2007
Just for the sake of clarification, the Lyc. IO-540-C4B5 engine has two different governor gear ratios. The NARROW deck has a 0.895:1 gear ratio and uses the MT governor P-860-3 or P-420-17. The WIDE deck has a 0.947:1 gear ratio and uses the MT governor P-860-5 or P-420-5. The cylinders on the NARROW deck engine are mounted with round nuts having an internal Allen wrench drive. The cylinders on the WIDE deck engine are mounted with standard hex nuts. I have not seen the WIDE deck MT governors being offered for sale by Van's Aircraft. I have only seen them offer the MT governors designed for the NARROW deck Lyc. 540 engine. Regards, Jim Ayers In a message dated 05/25/2007 9:26:16 A.M. Pacific Daylight Time, wcurtis(at)nerv10.com writes: --> RV10-List message posted by: "William Curtis" Some folks are opting for the PCU5000/X (http://pcu5000.com). It supposedly governs better than the MT provided in the FF kit. Someone on Vansairforce is doing a group buy of the PCU5000. Since the PCU5000X ($1350) is more expensive than the MT ($Van's $1100), this may be another case of a solution looking for a problem. Has anyone flying had issues with the MT P-860-3? http://www.vansairforce.com/community/showthread.php?t=17279&page=1&pp=10&high light=pcu William http://wcurtis.nerv10.com/ ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 25, 2007
Bob your concept of a meaningful IFR demo script for equipment in the RV-10 would be of value. Common denominator, basic features, same target audience and reinforcement of the principals mentioned here. Only 80 flying aircraft, 639 yet to be completed with 35% IFR rated pilots. That is over 200 viable customers walking the same walk and asking to talk the same talk from captive salespeople. Great idea. One month, Three weeks and six days. John 600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Friday, May 25, 2007 5:00 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W I've got almost identical plans as John's plans at the moment. I'm just waiting for Osh to get some hands on experience with the booth demos. I'm also keeping an eye on MGL and their new 10" Odyssey due at OSH and WTD's offering. Although WTD is a little more pricey at the moment. I am IFR rated and really like both Chelton and OP Technologies. Unfortunately, my budget won't allow it at the moment. Something about the wife wanting to remodel the house and two kids in college. Sounds like we got the makings of a large RV-10 consortium to make the rounds at Osh. It would be humorous for a group of us to visit the vendors as a horde. Even better, develop a common script for an IFR demo to give to the vendors beforehand and tell them we expect to see the demo script in their booth. Bob 684 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Friday, May 25, 2007 4:32 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W I don't really want to do a 2-phased panel. I want to put in what I'm going to be flying, VFR and IFR, for the foreseeable future. I've been looking at well equipped panels of Bonanzas and Mooney's of not too long ago, and almost anything we come up with today can blow most of those away for better situational awareness and ease of use. It would be simple for me to do something like this: AFS 3500 with engine monitoring, G430W, SL30, GMA340 or comparable, GTX330, GMX200 with weather and traffic, TT Sourcer, some back up gauges...not too shabby given what was available even a few years ago. However, is it the best bang for the buck; does it give me the most utility for the money? And, how does one define utility? John J 328 ________________________________________________________________________________
Subject: Traffic
Date: May 26, 2007
Has anyone had any experience with the passive Monroy or ProxAlert systems? I've been looking at the passive systems as a possible supplement to 330 TIS outside of TIS service areas. I think the price of the Avidyne's or L3's can probably be better spent elsewhere. I've seen good remarks on the Zaon XRX, but wanted to find a panel mounted solution rather than portable. I really don't want to park a unit atop the glareshield. With the RS232 output, the XRX would be the one to get if there are panel mount options. They allude that someday they may offer such a mounting option. From their web site: "Options are or may soon be available for installing XRX into the panel with significant reconfiguration of the hardware." ...Article Id: 30 - Version: 1 - Created: 05-12-2006: http://www.zaonflight.com/component/option,com_kb/page,articles/articleid ,30 /Itemid,1/ But a year later the only panel mount accessory they offer on their site is for the MRX. Any 3rd parties offering improved mounting options for the XRX? Best Regards, Patrick -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Friday, May 25, 2007 9:15 AM Subject: Re: RV10-List: Traffic Not much I can add. I am always too late on these responses. I need to plug my brain into this forum like others have. Seriously, TIS is totally awesome, even around Salt Lake where I don't get alot of coverage. But you get coverage typically when you need it. It is so nice to come home from a trip and look down at the screen and before Salt Lake Approach even tells me anything, I can see how many planes are in the pattern at my home airport which is right next to Class B airspace. Because of the Garmin 330, lately I don't call approach because I can see all the planes as good as he can which was the only reason why I called in when I was getting close and half the time when I do call in they only give you traffic warnings when they are within 500 feet of yourself it seems. Of course the best way to go is to be IFR or talking to approach control or flight following while using the traffic system. I have both the 330 and the TrafficScope VRX system which I also like. I'd like to upgrade to the Zaon XRX. When my TIS isn't working I watch that close and when it tells me about traffic that is close I can normally find them. It all helps and is not distracting. One thing really nice about today's EFIS systems is the ability look out the window more. You would think you be looking inside more with all that equipment but on the ground you input your flight plan so that as you are flying you actually look outside more because you are not having to worry about airspace violations and you really don't have to monitor the engine because it will talk to you if anything gets in the yellow or red depending on how you have it set up. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> Sent: Friday, May 25, 2007 8:14:36 AM Subject: RE: RV10-List: Traffic Jesse, I would suggest you acquire a better understanding on what exactly ATC is required to provide under different conditions and flight rules. Might I suggest a pilot?s license as a starting point. Bottom line is don?t EVER trust that ATC is 100% keeping you out of harm?s way. The PIC has ultimate responsibility for safety of flight, including rejecting vectors if ATC decides to drive you into another aircraft and your MARK1 eyeballs or onboard equipment tell you it?s a bad idea. Michael Sausen -10 #352 Limbo From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Friday, May 25, 2007 9:03 AM Subject: RE: RV10-List: Traffic I understand that it would be nice having traffic in the panel, but isn?t that what ATC is there for? They can give you weather info, but not nearly as well as seeing it in color on your moving map, but is it distracting seeing all of the planes that are around you? I have talked to a number of pilots who don?t want to know about traffic. ATC will tell you about the ones that matter, but the others, well, don?t matter. This may prompt a nice discussion about what traffic options are available and how helpful they are. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com www.saintaviation.com <http://www.saintaviation.com/> Cell: 352-427-0285 Fax: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tdawson-townsend(at)aurora.aero Sent: Friday, May 25, 2007 9:02 AM Subject: RV10-List: Traffic To go with your fancy panel, don?t forget to get an active traffic system, so you don?t get whacked by somebody while you?re both heads-down looking at the pretty HITS displays. Avidyne TAS system will display on Garmin, Avidyne, and Chelton displays, amongst others. Jeez, and I don?t even work there anymore! P.S. Your life will be easier if you consider this before you install a headliner, since the top antenna needs a foil ground plane installed . . . Cheers, TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-401-2522 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com y List utilities such as the Subscriptions page, http://www.matronics.bsp; - NEW MATRONICS WEB FO; http://forums.matronics.com http://www.matronics.com/Navigator?RV10-Li=== ________________________________________________________________________________
Date: May 26, 2007
Subject: My transition training experience
For those interested I posted a writeup on my TT with Mike Seager on Vansairfoce.net under RV10 posts. Dean 40449 ________________________________________________________________________________
Subject: Re: TrafficTraffic
Date: May 26, 2007
Once you've flown with a Traffic Avoidance System you realize that sometimes ATC misses a few and you also are aware of the traffic much sooner. But you are correct that they will alert you to traffic for free, NOW. Wayne Edgerton #40336 soon to be DARed From: "Jesse Saint" <jesse(at)saintaviation.com> Subject: Traffic I understand that it would be nice having traffic in the panel, but isn't that what ATC is there for? They can give you weather info, but not nearly as well as seeing it in color on your moving map, but is it distracting seeing all of the planes that are around you? I have talked to a number of pilots who don't want to know about traffic. ATC will tell you about the ones that matter, but the others, well, don't matter. This may prompt a nice discussion about what traffic options are available and how helpful they are. Jesse Saint ________________________________________________________________________________
Subject: Traffic
Date: May 26, 2007
Zaon had a panel mount prototype at their booth at SNF. Perhaps ready by OSH??? I'm building a Lancair ES (lurking here) and am currently planning on recessing the XRX into the top of the fiberglass glareshield, so it barely sticks up, but still has unobstructed visibility. The XRX display is disabled when it is in garmin comm (rs232) mode so there is nothing to see anyway. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill Sent: Saturday, May 26, 2007 3:04 AM Subject: RE: RV10-List: Traffic Has anyone had any experience with the passive Monroy or ProxAlert systems? I've been looking at the passive systems as a possible supplement to 330 TIS outside of TIS service areas. I think the price of the Avidyne's or L3's can probably be better spent elsewhere. I've seen good remarks on the Zaon XRX, but wanted to find a panel mounted solution rather than portable. I really don't want to park a unit atop the glareshield. With the RS232 output, the XRX would be the one to get if there are panel mount options. They allude that someday they may offer such a mounting option. From their web site: "Options are or may soon be available for installing XRX into the panel with significant reconfiguration of the hardware." ...Article Id: 30 - Version: 1 - Created: 05-12-2006: http://www.zaonflight.com/component/option,com_kb/page,articles/articleid,30 /Itemid,1/ But a year later the only panel mount accessory they offer on their site is for the MRX. Any 3rd parties offering improved mounting options for the XRX? Best Regards, Patrick -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Friday, May 25, 2007 9:15 AM Subject: Re: RV10-List: Traffic Not much I can add. I am always too late on these responses. I need to plug my brain into this forum like others have. Seriously, TIS is totally awesome, even around Salt Lake where I don't get alot of coverage. But you get coverage typically when you need it. It is so nice to come home from a trip and look down at the screen and before Salt Lake Approach even tells me anything, I can see how many planes are in the pattern at my home airport which is right next to Class B airspace. Because of the Garmin 330, lately I don't call approach because I can see all the planes as good as he can which was the only reason why I called in when I was getting close and half the time when I do call in they only give you traffic warnings when they are within 500 feet of yourself it seems. Of course the best way to go is to be IFR or talking to approach control or flight following while using the traffic system. I have both the 330 and the TrafficScope VRX system which I also like. I'd like to upgrade to the Zaon XRX. When my TIS isn't working I watch that close and when it tells me about traffic that is close I can normally find them. It all helps and is not distracting. One thing really nice about today's EFIS systems is the ability look out the window more. You would think you be looking inside more with all that equipment but on the ground you input your flight plan so that as you are flying you actually look outside more because you are not having to worry about airspace violations and you really don't have to monitor the engine because it will talk to you if anything gets in the yellow or red depending on how you have it set up. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> Sent: Friday, May 25, 2007 8:14:36 AM Subject: RE: RV10-List: Traffic Jesse, I would suggest you acquire a better understanding on what exactly ATC is required to provide under different conditions and flight rules. Might I suggest a pilot?s license as a starting point. Bottom line is don?t EVER trust that ATC is 100% keeping you out of harm?s way. The PIC has ultimate responsibility for safety of flight, including rejecting vectors if ATC decides to drive you into another aircraft and your MARK1 eyeballs or onboard equipment tell you it?s a bad idea. Michael Sausen -10 #352 Limbo From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Friday, May 25, 2007 9:03 AM Subject: RE: RV10-List: Traffic I understand that it would be nice having traffic in the panel, but isn?t that what ATC is there for? They can give you weather info, but not nearly as well as seeing it in color on your moving map, but is it distracting seeing all of the planes that are around you? I have talked to a number of pilots who don?t want to know about traffic. ATC will tell you about the ones that matter, but the others, well, don?t matter. This may prompt a nice discussion about what traffic options are available and how helpful they are. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com www.saintaviation.com <http://www.saintaviation.com/> Cell: 352-427-0285 Fax: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tdawson-townsend(at)aurora.aero Sent: Friday, May 25, 2007 9:02 AM Subject: RV10-List: Traffic To go with your fancy panel, don?t forget to get an active traffic system, so you don?t get whacked by somebody while you?re both heads-down looking at the pretty HITS displays. Avidyne TAS system will display on Garmin, Avidyne, and Chelton displays, amongst others. Jeez, and I don?t even work there anymore! P.S. Your life will be easier if you consider this before you install a headliner, since the top antenna needs a foil ground plane installed . . . Cheers, TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-401-2522 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com y List utilities such as the Subscriptions page, http://www.matronics.bsp; - NEW MATRONICS WEB FO; http://forums.matronics.com http://www.matronics.com/Navigator?RV10-Li=== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: May 26, 2007
Subject: Re: My transition training experience
Tim, I would post it here but do not wanna resize the pics smaller............too time consuming for my PC literate mind LOL ... Dean 40449 ________________________________________________________________________________
Date: May 26, 2007
Subject: Aileron pushrod rubbing against aileron mounting bracket on
QB Wings After mounting my LH aileron and connecting the bellcrank to aileron pushrod, I find that the pushrod rubs against a rivet shop head that is part of the aileron mounting bracket. Anyone else run into this? So far, I've dismounted it, checked all the spacers and washers per the plans and remounted. It is still rubbing. This shouldn't be too difficult to resolve but a solution isn't obvious yet. Just looking for any similar experiences and approaches. Bill "trying to close up the QB wings" Watson ________________________________________________________________________________
Date: May 26, 2007
Subject: Re: The Perfect Panel - The Perfect airplane
Her is my Idea of a panel. You'll see Srikefinder for legal weather but there will be a garmin 496 also on board until ADSB or some other form comes in. Fully intergrated 8.4 and an extra 1201 wass approved GPS. We're fitting it in now. Patrick Thyssen 257 Deems Davis wrote: Re. Op Tech and Jepps Yes they do use Jepps database, you have 2 options: a. an annual subscription, or b. 'pay as you go' I'm not sure what the current pricing is, but from memory the annual subscription was aprox $700 and the 'pay as you go' was $90 per update. You download the updates from their website and place them on an SD card and update the EFIS. They just published a new website, and I can't find the current pricing, perhaps they moved it to the download section which requires a password and user id. (I haven't activated mine yet to preserve the '1 year' trigger.) Deems Davis # 406 Finishing - ( A Misnomer ! ) http://deemsrv10.com/ Tim Olson wrote: > --> A regular subscription update is a key too. > That's one question that's been gnawing at me about OP Tech too...and > perhaps Deems or someone can answer. ............ ________________________________________________________________________________
Date: May 26, 2007
Subject: I recommend making a 90degree angle drill part of anyone's
initial tool kit. I've been pleasantly surprised how well the RV10 tool kit I bought from Isham 9 months ago has worked out. But it's been a lot of fun adding more tools. One particularly useful addition has been the Angle Drill Attachment and its kit from Cleaveland - ADA-30 or ADA-Kit respectively" http://www.cleavelandtoolstore.com/prodinfo.asp?number=ADAKITW The first use is drilling holes in the elevator for a trim tab attach bracket. However, I keep finding additional uses once I discovered that my countersink bit and my deburring bit from by favorite deburring tool both fit the 1/4-28 threads that the drill attachment has. (There's a 3 jawed chuck included in the kit that enables you to use any bit up to 1/4" but I've never used the chuck) The countersink bit is great for those few holes where getting the whole countersink cage and a straight drill in place is impossible. I just used it to countersink a pesky rivet on my aileron bracket. The deburring bit is ideal for deburring things like the rib flange on the QB wing before riveting on the bottom skin. Anywhere that access with the whole tool is impossible. I generally mount it in the air drill and hand turn the chuck on the drill a half turn. Or just wrap tape around the angle drill shaft so I can just hand turn it. If you find yourself hand twirling your deburring bit to get to hard to reach holes, this can work better and save some skin. I need to fabricate a small collar to make turning the shaft easier. Just FYI. ________________________________________________________________________________
Subject: IFR EFIS
Date: May 26, 2007
You guys are confusing EFIS with FMS. An EFIS system (electronic flight instrumentation system) is just an electronic visual presentation of the required flight instruments for IFR (or VFR) flight. The first EFIS systems I flew in jets only gave you attitude and heading info, as the pitot static instruments were still steam gauges. There are still lots of JurassicJets out there flying with these early systems. There is no such thing as an "IFR EFIS" system, as if it's legal for Part 23 or 25 aircraft it's STC'd, and if it's legal for a homebuilt, it must be approved by the builder (you). The FAA only cares that the EFIS provides the flight instrument information to the pilot that's specified in the regs. Sorry Tim, a Dynon is just as "legal" as your Chelton. The FMS (flight management system) however is required to be certified IFR and has to have a current database, even in a homebuilt. A G430 is a FMS for example. When Chelton or whomever decides to combine the functions of both an EFIS system and FMS, then the requirement still stands that the FMS function be IFR certified (with or without approach capability), and the database be current. Does anyone know of a RV10 forum that reasonably limits itself to builder's issues, as this was at one time? Wading thru 92 rambling posts searching for some useful information for my build is becoming too time consuming to continue my daily lurk! Chris Hukill ________________________________________________________________________________
Date: May 26, 2007
Subject: Re: IFR EFIS
>Does anyone know of a RV10 forum that reasonably limits itself to builder's issues, as this was at one time? I hear Van's has email support for builder issues :) Other than that, the "search messages" in my email program works wonders for filtering what I want to find information on. I now have 20,148 messages in my archive (from even before the Yahoo!s came over) -Jim 40384 Chris Hukill wrote: > You guys are confusing EFIS with FMS. An EFIS system (electronic > flight instrumentation system) is just an electronic visual > presentation of the required flight instruments for IFR (or VFR) > flight. The first EFIS systems I flew in jets only gave you attitude > and heading info, as the pitot static instruments were still steam > gauges. There are still lots of JurassicJets out there flying with > these early systems. There is no such thing as an > "IFR EFIS" system, as if it's legal for Part 23 or 25 aircraft it's > STC'd, and if it's legal for a homebuilt, it must be approved by the > builder (you). The FAA only cares that the EFIS provides the flight > instrument information to the pilot that's specified in the > regs. Sorry Tim, a Dynon is just as "legal" as your Chelton. > The FMS (flight management system) however is required to be > certified IFR and has to have a current database, even in a homebuilt. > A G430 is a FMS for example. When Chelton or whomever decides to > combine the functions of both an EFIS system and FMS, then the > requirement still stands that the FMS function be IFR certified (with > or without approach capability), and the database be current. > Does anyone know of a RV10 forum that reasonably limits itself to > builder's issues, as this was at one time? > Wading thru 92 rambling posts searching for some useful information > for my build is becoming too time consuming to continue my daily lurk! > Chris Hukill > >* > > >* > ________________________________________________________________________________
Date: May 26, 2007
Chris Hukill wrote: > You guys are confusing EFIS with FMS. An EFIS system (electronic flight > instrumentation system) is just an electronic visual presentation of the > required flight instruments for IFR (or VFR) flight. The first EFIS > systems I flew in jets only gave you attitude and heading info, as the > pitot static instruments were still steam gauges. There are still lots > of JurassicJets out there flying with these early systems. There is no > such thing as an > "IFR EFIS" system, as if it's legal for Part 23 or 25 aircraft it's > STC'd, and if it's legal for a homebuilt, it must be approved by the > builder (you). The FAA only cares that the EFIS provides the flight > instrument information to the pilot that's specified in the regs. Sorry > Tim, a Dynon is just as "legal" as your Chelton. Oh no, I don't disagree one iota that a Dynon is just as "legal". You're also bringing in a term (FMS) that I was hesitant to add to the discussion. IMHO, the CFS system is pretty much the better definition of the Chelton. The problem is, although you can call a G430 and FMS, it is NOT and EFIS....but the Chelton does meet the definition as you state it below of an FMS. So then although I admit, there is no solid definition of an "IFR EFIS", if you have a true FMS with full EFIS capabilities, then by extension doesn't that make it an "IFR EFIS"? Admittedly we're playing with words a bit and coining new terms, but that's in the good intentions of trying to better define a system. How do you define "Good family airplane", or "Great x/c cruiser"? There is no official definition, so you have to look at what goes into the term and eliminate the ones that don't fit....is a Champ a "good family airplane"? etc... Sorry for making you miserable with the thread, but I think there are far more people happy to see it here than there are people who just don't want to hit the delete button a couple dozen more times. This has been one of the better discussions we've had in months, and yet at the same time, building related questions are being answered daily.....it's a far far far cry from reading some topics on the generic RV list. Of course, feel free to filter people or delete as necessary. Tim > The FMS (flight management system) however is required to be certified > IFR and has to have a current database, even in a homebuilt. A G430 is a > FMS for example. When Chelton or whomever decides to combine the > functions of both an EFIS system and FMS, then the requirement still > stands that the FMS function be IFR certified (with or without approach > capability), and the database be current. > Does anyone know of a RV10 forum that reasonably limits itself to > builder's issues, as this was at one time? > Wading thru 92 rambling posts searching for some useful information for > my build is becoming too time consuming to continue my daily lurk! > Chris Hukill > > * ________________________________________________________________________________
Subject: Aero Composit Prop
Date: May 26, 2007
I picked up my prop in Redding, CA, Thursday at American Propeller. AeroComposites send the blades and hub there for assembly. It was crated very well but the size of the box made me wonder if I needed a bigger engine. Fortunately, when I opened the box the prop was much smaller than the box. Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Date: May 26, 2007
The Zaon remote mount at S&F had a empty slot in the box fo an ADS B receiver. The install was very similar to the Avadyne with a transponder on top and bottom. It sure would be nice if it would be able to interface with my Chelton. Larry -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=114962#114962 ________________________________________________________________________________
Date: May 26, 2007
I got the 2 blade version. They covered my blades with a non see through material, and since I wanted to leave the protection in place, I still haven't uncovered them. They do look perdy. Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Saturday, May 26, 2007 1:17 PM Subject: RV10-List: Aero Composit Prop I picked up my prop in Redding, CA, Thursday at American Propeller. AeroComposites send the blades and hub there for assembly. It was crated very well but the size of the box made me wonder if I needed a bigger engine. Fortunately, when I opened the box the prop was much smaller than the box. Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Subject: Aero Composits Prop
Date: May 26, 2007
Oops, my intent was to add the dimensions of the box for any who might be interested. Each leg is about 12" wide and 22" deep. The overall diameter is 8' and the widest dimension is 98". Prop is 55 lbs and the package was about 80 lbs total but I didn't weigh it. Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Subject: FW: AeroElectric-List: Electronics stolen
Date: May 26, 2007
This was just posted on one of the other matronics sites. Check your serial numbers if you think the deal you get is too good to be true. John Cox ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Daniel De Winter Sent: Saturday, May 26, 2007 11:42 AM Subject: AeroElectric-List: Electronics stolen To all pilots and aviation enthousiastics, On May 25, my engine and panel with 2*EFIS and EIS6000 from GRT were stolen from my airceraft VM-1 Esqual at EBST in Belgium. The aircraft was severely damaged. You can find all serial numbers below. If anyone of you would recognize these numbers, please let me know ASAP. I woild be very grateful. Equipment Description Part # Serial # Jabiru 3300 cc Engine 33A559 Electric Gyro Corp. Turn & Bank indicator 1394T100-7Z 2310-484 United Instruments, INC. Airspeed indicator (0-200 knots/250mph) 8025 185256 United Instruments, INC. Altimeter (-1,000 to 20,000 feet) 5934PM-3 432773 Garmin SL30 NavComm 013-00105-01 25902119 Garmin GTX330 Transponder Mode S 010-00230-01 84113957 Flightcom 403MC Intercom 403mc 9796 Grand Rapids Technologies, Inc. EFIS Horizon Series 1 Multi Function Display MFD-01-03001 45 Grand Rapids Technologies, Inc. EFIS Horizon Series 2 Multi Function Display MFD-01-03002 46 Grand Rapids Technologies, Inc. EIS6000 Engine monitor EIS-6000J 15873 VDO Trading AG RPM/hours indicator (0-4000 rpm) 999 165 009 021 449 Danny De Winter PH-DWD VM-1 Esqual ________________________________ Yahoo! Answers - Got a question? Someone out there knows the answer. Try it now <http://uk.answers.yahoo.com/;_ylc=X3oDMTEzaDRkZGdlBF9TAzIxMTQ3MTcxOTAE c 2VjA01haWwEc2xrA3RhZ2xpbmVz> . ________________________________________________________________________________
Subject: Re: Aero Composit Prop
Date: May 27, 2007
Now thats funny!! ----- Original Message ----- From: Albert Gardner To: ibspud(at)roadrunner.com Sent: Sunday, May 27, 2007 4:16 AM Subject: RV10-List: Aero Composit Prop I picked up my prop in Redding, CA, Thursday at American Propeller. AeroComposites send the blades and hub there for assembly. It was crated very well but the size of the box made me wonder if I needed a bigger engine. Fortunately, when I opened the box the prop was much smaller than the box. Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Date: May 26, 2007
Patrick, What is "legal weather?" William http://wcurtis.nerv10.com/ -------- Original Message -------- > > Her is my Idea of a panel. You'll see Srikefinder for legal weather but there will be a garmin 496 also on board until ADSB or some other form comes in. > Fully intergrated 8.4 and an extra 1201 wass approved GPS. > We're fitting it in now. > Patrick Thyssen 257 > > Deems Davis wrote: > > Re. Op Tech and Jepps > > Yes they do use Jepps database, you have 2 options: > > a. an annual subscription, or > b. 'pay as you go' > > I'm not sure what the current pricing is, but from memory the annual > subscription was aprox $700 and the 'pay as you go' was $90 per update. > You download the updates from their website and place them on an SD card > and update the EFIS. > > They just published a new website, and I can't find the current pricing, > perhaps they moved it to the download section which requires a password > and user id. (I haven't activated mine yet to preserve the '1 year' > trigger.) > > Deems Davis # 406 > Finishing - ( A Misnomer ! ) > http://deemsrv10.com/ > > Tim Olson wrote: > > --> A regular subscription update is a key too. > > That's one question that's been gnawing at me about OP Tech too...and > > perhaps Deems or someone can answer. ............ ________________________________________________________________________________
Date: May 26, 2007
I will correct myself as per 135 or 121 far, you have to have in the case of known or forecast thunderstorn weather you have to have on board a airborn radar or a lighting detector (wx500,strikefinder etc.). That means real time not 15 minutes old weather. And no this is not 135 but I have enough experience to know not to just rely on ground base systems if I want to go. patrick thyssen William Curtis wrote: Patrick, What is "legal weather?" William http://wcurtis.nerv10.com/ -------- Original Message -------- > > Her is my Idea of a panel. You'll see Srikefinder for legal weather but there will be a garmin 496 also on board until ADSB or some other form comes in. > Fully intergrated 8.4 and an extra 1201 wass approved GPS. > We're fitting it in now. > Patrick Thyssen 257 > > Deems Davis wrote: > > Re. Op Tech and Jepps > > Yes they do use Jepps database, you have 2 options: > > a. an annual subscription, or > b. 'pay as you go' > > I'm not sure what the current pricing is, but from memory the annual > subscription was aprox $700 and the 'pay as you go' was $90 per update. > You download the updates from their website and place them on an SD card > and update the EFIS. > > They just published a new website, and I can't find the current pricing, > perhaps they moved it to the download section which requires a password > and user id. (I haven't activated mine yet to preserve the '1 year' > trigger.) > > Deems Davis # 406 > Finishing - ( A Misnomer ! ) > http://deemsrv10.com/ > > Tim Olson wrote: > > --> A regular subscription update is a key too. > > That's one question that's been gnawing at me about OP Tech too...and > > perhaps Deems or someone can answer. ............ ________________________________________________________________________________
Date: May 26, 2007
Good on ya! I just saw Deem's two days ago - It is beautiful, too. I suspect it's nearly time to order mine. How long between order and delivery for you? Best John Ackerman 40458 QB fuselage, just beginning cabin cover On May 26, 2007, at 11:16 AM, Albert Gardner wrote: > I picked up my prop in Redding, CA, Thursday at American Propeller. > AeroComposites send the blades and hub there for assembly. It was > crated very well but the size of the box made me wonder if I needed > a bigger engine. Fortunately, when I opened the box the prop was > much smaller than the box. > > Albert Gardner > > Yuma, AZ > > 40-422 > > > > > > ________________________________________________________________________________
Subject: The Perfect Panel...how to decide - was GNS-430W
Date: May 26, 2007
My understanding is you write a test plan and submit it to the local FSDO. Yes there is always a trail of paperwork. I believe VRF to IFR requires proof of calibration and a revisit. Might not be the correct term. Not sure about engine change. Different engine type or just a replacement? But we still have the freedom to change anything we like. Just need to follow the rules and ask questions first. Unless you're a real A&P and stay current on the regs. Darn flight simulator is hard to trim.. eer. Bobby 40116 (spray can primer) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Friday, May 25, 2007 3:24 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W Great statement Bobby. Now here is a new question that goes to the heart of Amateur Built (current rules). Does a total change-out of engine type, prop type or major alteration to an airframe (Down the Road) require a revisit by a DAR or PAI? Or does the repairman have the latitude to alter the engine/prop/panel from basic VFR to EFIS/IFR without a trail of paperwork and new set of eyes? What latitude for modification is legal and appropriate for a kit designed and tested VAN's RV-10? "Round Two" - No bio required "Do you feel Lucky?" John Cox A&P with IA 40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Friday, May 25, 2007 2:26 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W The great thing is we get to rebuild our panels as often as we like. Going home to work on my instrument rating using ASA IP PC based software :) Bobby 40116 ________________________________________________________________________________
Date: May 26, 2007
Subject: Re: Rosen Sun Visor Group Buy
Jesse, I am confirmed for the visors. Do not send them, however, due to the damage on the plane. I will probably be sending you the plane on a flat-bed truck shortly, if it is confirmed that you can help me rebuild the damage. Can you give me a rough estimate from the pics? For insurance. Of course we don't know how much damage is done until we thoroughly inspect it. Anyhow we can make this installation of the visors at that time. Don F. On 5/22/07, Jesse Saint wrote: > > > I have you on my list for the Rosen Visors. Please reply to this e-mail > and > let me know if you want a full set for $317.97 plus shipping or a half set > for $168.99. Please include on your e-mail the desired shipping address > and > phone number. I will e-mail an invoice that you can send in with a check > after I figure out the shipping charges. I should be able to do a > flat-rate > USPS box or something like that. I do accept paypal, but they charge a > fee, > so I would need the fee added to the amount you send. > > GOD BLESS! > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > www.saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim berry > Sent: Thursday, April 12, 2007 11:24 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Rosen Sun Visor Group Buy > > > Jesse, > > The holes on my brace are 3/4" ctc in both axes. And please put me down > for > a set also. > > Jim Berry > 40482 Finishing > > > Read this topic online here: > >
http://forums.matronics.com/viewtopic.php?p=106637#106637 > > > -- > 11:52 AM > > -- Don Liberty University Of: 434-592-4127 Cel: 434-944-5347 email: drdonfa(at)gmail.com Skype: drdonfanning MSN Messenger: dfanning(at)liberty.edu Web: www.luglobal.com ________________________________________________________________________________
Date: May 26, 2007
Patrick, Thanks for the clarification. That's a nice looking panel you have there. I've been meaning to reply to the other thread where folks are confusing XM weather as airborne radar. They should understand the lag time (2 to 15 minutes) involved with XM weather so as NOT to use it to try to closely navigate around weather cells. William http://wcurtis.nerv10.com/ -------- Original Message -------- > X-Rcpt-To: > > I will correct myself as per 135 or 121 far, you have to have in the case of known or forecast thunderstorn weather you have to have on board a airborn radar or a lighting detector (wx500,strikefinder etc.). That means real time not 15 minutes old weather. And no this is not 135 but I have enough experience to know not to just rely on ground base systems if I want to go. > patrick thyssen > > William Curtis wrote: > > Patrick, > > What is "legal weather?" > > William > http://wcurtis.nerv10.com/ > > -------- Original Message -------- > > > > Her is my Idea of a panel. You'll see Srikefinder for legal weather but there will be a garmin 496 also on board until ADSB or some other form comes in. > > Fully intergrated 8.4 and an extra 1201 wass approved GPS. > > We're fitting it in now. > > Patrick Thyssen 257 > > > > Deems Davis wrote: > > > > Re. Op Tech and Jepps > > > > Yes they do use Jepps database, you have 2 options: > > > > a. an annual subscription, or > > b. 'pay as you go' > > > > I'm not sure what the current pricing is, but from memory the annual > > subscription was aprox $700 and the 'pay as you go' was $90 per update. > > You download the updates from their website and place them on an SD card > > and update the EFIS. > > > > They just published a new website, and I can't find the current pricing, > > perhaps they moved it to the download section which requires a password > > and user id. (I haven't activated mine yet to preserve the '1 year' > > trigger.) > > > > Deems Davis # 406 > > Finishing - ( A Misnomer ! ) > > http://deemsrv10.com/ > > > > Tim Olson wrote: > > > --> A regular subscription update is a key too. > > > That's one question that's been gnawing at me about OP Tech too...and > > > perhaps Deems or someone can answer. ............ ________________________________________________________________________________
Date: May 26, 2007
OK, this really got my attention. was it a 10 and what type of damage? John Cram 40569 (stuff) ----- Original Message ----- From: Don Fanning<mailto:drdonfa(at)gmail.com> To: rv10-list(at)matronics.com Sent: Saturday, May 26, 2007 8:08 PM Subject: Re: RV10-List: Re: Rosen Sun Visor Group Buy Jesse, I am confirmed for the visors. Do not send them, however, due to the damage on the plane. I will probably be sending you the plane on a flat-bed truck shortly, if it is confirmed that you can help me rebuild the damage. Can you give me a rough estimate from the pics? For insurance. Of course we don't know how much damage is done until we thoroughly inspect it. Anyhow we can make this installation of the visors at that time. Don F. On 5/22/07, Jesse Saint > wrote: > I have you on my list for the Rosen Visors. Please reply to this e-mail and let me know if you want a full set for $317.97 plus shipping or a half set for $168.99. Please include on your e-mail the desired shipping address and phone number. I will e-mail an invoice that you can send in with a check after I figure out the shipping charges. I should be able to do a flat-rate USPS box or something like that. I do accept paypal, but they charge a fee, so I would need the fee added to the amount you send. GOD BLESS! Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com www.saintaviation.com<http://www.saintaviation.com/> Cell: 352-427-0285 Fax: 815-377-3694 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of jim berry Sent: Thursday, April 12, 2007 11:24 PM To: rv10-list(at)matronics.com Subject: RV10-List: Re: Rosen Sun Visor Group Buy > Jesse, The holes on my brace are 3/4" ctc in both axes. And please put me down for a set also. Jim Berry 40482 Finishing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=106637#106637 Liberty University Of: 434-592-4127 Cel: 434-944-5347 email: <http://forums.matronics.com/viewtopic.php?p=106637#106637>drdonfa@gmai l.com Skype: drdonfanning MSN Messenger: dfanning(at)liberty.edu Web: www.luglobal.com<http://www.luglobal.com/> http://www.matronics.com/Navigator?RV10-List igator?RV10-List> ________________________________________________________________________________
Date: May 26, 2007
Subject: Re: FS: MT Prop Gov
Jim, I hope this is not correct since my TMX IO-540 engine has the same standard hex nuts as the engine in 410RV which would make it a WIDE deck engine. N410RV
http://www.myrv10.com/miscphotos/TerryCole/abilene/Abilene_04_RV10_072.jpg My TMX IO-540 http://wcurtis.nerv10.com/20Engine/Engine02.jpg The governor I just received in the Van's firewall forward kit is MT P-860-3. According to the you, I should need the P-860-5. Does Van's use a -3 or a -5 in N401RV? I'll have to check with Mattituck on this. William http://wcurtis.nerv10.com/ -------- Original Message -------- > X-Rcpt-To: > > Just for the sake of clarification, the Lyc. IO-540-C4B5 engine has two > different governor gear ratios. > > The NARROW deck has a 0.895:1 gear ratio and uses the MT governor P-860-3 or > P-420-17. > > The WIDE deck has a 0.947:1 gear ratio and uses the MT governor P-860-5 or > P-420-5. > > The cylinders on the NARROW deck engine are mounted with round nuts having > an internal Allen wrench drive. > The cylinders on the WIDE deck engine are mounted with standard hex nuts. > > I have not seen the WIDE deck MT governors being offered for sale by Van's > Aircraft. I have only seen them offer the MT governors designed for the > NARROW deck Lyc. 540 engine. > > Regards, > Jim Ayers > > In a message dated 05/25/2007 9:26:16 A.M. Pacific Daylight Time, > wcurtis(at)nerv10.com writes: > > --> RV10-List message posted by: "William Curtis" > > Some folks are opting for the PCU5000/X (http://pcu5000.com). It supposedly > governs better than the MT provided in the FF kit. Someone on Vansairforce > is doing a group buy of the PCU5000. Since the PCU5000X ($1350) is more > expensive than the MT ($Van's $1100), this may be another case of a solution > looking for a problem. Has anyone flying had issues with the MT P-860-3? > > http://www.vansairforce.com/community/showthread.php?t=17279&page=1&pp=10&high > light=pcu > > William > http://wcurtis.nerv10.com/ > > > > > > > ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 26, 2007
Subject: IFR EFIS
Chris, Thanks for your comments but I guess to some, the decision on what to put in the panel is a "builder issue" and I think most on this list benefit from the discussion. If you want a PURE airframe builder issue dialog then it is probably best to converse with Van's factory. I don't think it takes too much effort to click next or delete on those long winded ramblings. Certainly the non-RV(10) or political post are inappropriate on this list, but just because a thread is of no value to you, does not mean that there are a hundred other out there who find value in it. William http://wcurtis.nerv10.com/ -------- Original Message -------- > X-Rcpt-To: > > You guys are confusing EFIS with FMS. An EFIS system (electronic flight instrumentation system) is just an electronic visual presentation of the required flight instruments for IFR (or VFR) flight. The first EFIS systems I flew in jets only gave you attitude and heading info, as the pitot static instruments were still steam gauges. There are still lots of JurassicJets out there flying with these early systems. There is no such thing as an > "IFR EFIS" system, as if it's legal for Part 23 or 25 aircraft it's STC'd, and if it's legal for a homebuilt, it must be approved by the builder (you). The FAA only cares that the EFIS provides the flight instrument information to the pilot that's specified in the regs. Sorry Tim, a Dynon is just as "legal" as your Chelton. > The FMS (flight management system) however is required to be certified IFR and has to have a current database, even in a homebuilt. A G430 is a FMS for example. When Chelton or whomever decides to combine the functions of both an EFIS system and FMS, then the requirement still stands that the FMS function be IFR certified (with or without approach capability), and the database be current. > Does anyone know of a RV10 forum that reasonably limits itself to builder's issues, as this was at one time? > Wading thru 92 rambling posts searching for some useful information for my build is becoming too time consuming to continue my daily lurk! > Chris Hukill ________________________________________________________________________________
Subject: Climb rates at full gross
Date: May 26, 2007
Folks I have the three blade MTV-12-B/193-93 prop mated to an I0-540-D4A5 Lycoming. Question is, what climb rates are you getting at full gross. I'm about to do my climb test and would like to know what to expect. Ted French C-FXCS RV-10 Flying with 13 hrs. Had to take a break due to a hernia operation.... ________________________________________________________________________________
Subject: Mods to Amateur Built
Date: May 26, 2007
http://eaa.org/communications/eaanews/070514_faarelease.html Here is the first tangible and productive improvement to Amateur built. More coming. Hopefully we get what we deserve. John Cox #600 ________________________________________________________________________________
Date: May 27, 2007
Subject: Paint scheme
I have received a few replies on my Transition training write-up and wanted to clarify the pic of my RV10 in the paint booth. I have also attached a few pics of the RV10 in the sun today. This paint scheme is a slight modification of a work or art that Deems Davis put together some time ago. When I visited Deems at his house last year I asked him if I could copy his scheme with different colors. He was gracious enough to send me the file and SIREF draw4.0 to make the scheme my own. If you look at Deems scheme vs mine........I have more color on the belly, a longer, stretched swoosh. Also, the wings have more color at the fuselage and they have solid stripes versus coming to a point at the leading edge. I also made the accent stripes shorter. I have received several kudos from pilots in the area and at the field already with this scheme. I want to publicly thank Deems for his Work of Art that he shared freely and for his great website that continues to help hundreds of builders everyday! Dean 40449 /9j/4SaNRXhpZgAASUkqAAgAAAALAA8BAgAJAAAAkgAAABABAgAPAAAAnAAAABIBAwABAAAAAQAA ABoBBQABAAAArAAAABsBBQABAAAAtAAAACgBAwABAAAAAgAAADEBAgAWAAAAvAAAADIBAgAUAAAA 0gAAABMCAwABAAAAAgAAAJiCAgAFAAAA5gAAAGmHBAABAAAA7AAAAEoEAABGVUpJRklMTQAARmlu ZVBpeCBBMjA1ICAAAEgAAAABAAAASAAAAAEAAABGaW5lUGl4Vmlld2VyIFZlci40LjAAMjAwNzow NToyNiAyMzozMDoxMwAgICAgAAAjAJqCBQABAAAAlgIAAJ2CBQABAAAAngIAACKIAwABAAAAAgAA ACeIAwABAAAAZAAAAACQBwAEAAAAMDIyMAOQAgAUAAAApgIAAASQAgAUAAAAugIAAAGRBwAEAAAA AQIDAAGSCgABAAAAzgIAAAKSBQABAAAA1gIAAAOSCgABAAAA3gIAAASSCgABAAAA5gIAAAWSBQAB AAAA7gIAAAeSAwABAAAABQAAAAiSAwABAAAAAAAAAAmSAwABAAAAGAAAAAqSBQABAAAA9gIAAHyS BwAeAQAA/gIAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAABAAAAgAIAAAOgBAABAAAA4AEA AAWgBAABAAAALAQAAA6iBQABAAAAHAQAAA+iBQABAAAAJAQAABCiAwABAAAAAwAAABeiAwABAAAA AgAAAACjBwABAAAAAwAAAAGjBwABAAAAAQAAAAGkAwABAAAAAAAAAAKkAwABAAAAAAAAAAOkAwAB AAAAAAAAAAakAwABAAAAAAAAAAqkAwABAAAAAAAAAAykAwABAAAAAAAAAAAAAAAKAAAAQB8AALwC AABkAAAAMjAwNzowNToyNiAwNDo1NDoxMwAyMDA3OjA1OjI2IDA0OjU0OjEzAMADAABkAAAAMAIA AGQAAAAQBAAAZAAAAAAAAABkAAAAQAEAAGQAAAAmAgAAZAAAAEZVSklGSUxNDAAAABUAAAAHAAQA AAAwMTMwABACAAgAAAAOAQAAARADAAEAAAADAAAAAhADAAEAAAAAAAAAAxADAAEAAAAAAAAAEBAD AAEAAAAAAAAAERAKAAEAAAAWAQAAIBADAAEAAAAAAAAAIRADAAEAAAAAAAAAIhADAAEAAAAAAAAA IxADAAIAAABAAfAAMBADAAEAAAAAAAAAMRADAAEAAAAAAAAAMhADAAEAAAABAAAAABEDAAEAAAAA AAAAAREDAAEAAAAAAAAAABIDAAEAAAAAAAAAEBIDAAEAAAAAAAAAABMDAAEAAAAAAAAAARMDAAEA AAAAAAAAAhMDAAEAAAAAAAAAAAAAAE5PUk1BTCAAAAAAAAoAAAB7CQAAAQAAAHsJAAABAAAAAgAB AAIABAAAAFI5OAACAAcABAAAADAxMDAAAAAABgADAQMAAQAAAAYAAAAaAQUAAQAAAJgEAAAbAQUA AQAAAKAEAAAoAQMAAQAAAAIAAAABAgQAAQAAAKgEAAACAgQAAQAAAN0hAAAAAAAAgPwKABAnAACA /AoAECcAAP/Y/9sAxQACAQEBAQECAQEBAgICAgMEAwMCAgMFBAQDBAYFBgYGBQYGBwgKCAcHCQcG BggLCQkKCgsLCwcIDA0MCw0KCwsKAQICAgMCAwUDAwUKBwYHCgoKCgoKCgoKCgoKCgoKCgoKCgoK CgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoCAgICAwIDBQMDBQoHBgcKCgoKCgoKCgoKCgoK CgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCv/EAaIAAAEFAQEBAQEBAAAAAAAA AAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0Kx wRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ 2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQE AwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBka JicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWW l5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5 +v/AABEIAHgAoAMBIQACEQEDEQL/2gAMAwEAAhEDEQA/AJUsAeNufrUi6cD2/Cv2rmPxq1h66bye DzThpfYLRzDtccNLOOFpRpnTCmk2Fhf7M/2elOGlnuvA7Gk3YdhRpeP4c0f2Yo/hxj0pXKUQGmAH haP7Oyc7Tn3pNjS6CNpgzgLSDTSuPlGfWk3pYFGzuKbKQgDAA9ajfSwD0z9KwjNQ2NXBy3GPpq9k IPvTBp+1v9WD7Gqc7rViULPRCvZbhkoi/QCq0um8nGOfWsqdTlfc2nDmWuhux2HXCdO1SrYcdAPp XQpnIokq2JI+709KeLAf3RxRzjUSRdPz1UCnDTv9g1LmUoh/Z2O2KX+zsAcHmk6liowb2A6fgABc fWg6eAOgOOwqZVeV2LVK6uIdP4OVPPakFioJ3KSD6VM6tkONNNifYecbcZpw0yQjKxlh7DmsKmJV N6m9PDuorojfT2B5THuantNJtJF/ePyfVa58ViZRjeJvhsPGUrTHP4bxl4GyewOKrPol4rZ+zEj0 HSuSGOjP49GdM8HKHwakiW0cCgTW8YI6hlOagudPtbkgxQgZ7hcVlGvKMuaLNnRjKPLJFqKz9qlS 1J4C5HtXuOdzwOUkW16cZ9hUgtuM44P4VLqDUR6W7cfLgH1p62pHAAJPaolUstTSMeaVkrjvsp7q MjtTzYuBuKEfSsJ4mmmrs6YYaq0+VDRagnoMehoa2Ctg4APepWLitBywk3qw+x9SGBx270021sB8 yuMelctXGOfw/idlHBxp6v8AAlhitRypB9nWp8iL/Vrt9hwK8ypNyep6MIqK0G3H2aVf3sIB98Co 4fKt1OIyFPoc1DqSty30Bwipc1tQkljz8srqD6YNQzSDeG+0ZB9FGaSXkDaXUjN8sZ2Bt+ez8USS xRqZEAUjqOMGnyyQlJMEWPOCD+VTIsfPykYr6RyPmlBskVUxwufpQ0ft09DUymi40xoT5ueMetSB kDc5B9q4q1ZvQ9GhSSsxzPHgbo8k+tKskQHyqwB/umuKVRvTod0YRWoN5DHILD6mmsqYALMB7VHt XYp04sR1QAKQSPUjFMEjKPkXB9GwRWcptotRS2F89sZNqq+6043W3aFTA9zzWbZWw2S7YkeZakgc 880zz49xP2ZRnutK7QOzGvcwEhTbgH1FRTTRDJlgwD65ppslpdiEm0JBaDGcckZpk8tmrFRt56A4 Iq1ORFonJW37SPwEuwJI/jF4dAJPL38SfzIq5F8e/gc2Cnxi8MHPf+1IP/iq9R4mnL7S+882OGqR +w/uJR8evgdgk/Gbwvj1/tS3/wDi63fDPi7wn40s21Hwh4p0/VbeNtjTadcJMqtjOCVJAOCDis3W jN2Ul95sqbgrtfgaO085Y/SgMQD8+PaokrlqVgLrwTnPtSh06n9awkrG0ZXFUqBnjB9aPkYZMY49 ahotMjkdACcEE1H565Pyk49MCokrlKVhTdrtwFwPQYpul6L498c+NtC8BfDfT7Se7v55Jr241PdH bWWmxRs09w8i5KkO0CL8rAmQA46iNI6y2HzN6Lc6n4xfDDWfg14yl8Ga3dQXEqRRTLNArqro6hh8 rAEEdCCOCDXIS3aKCFjGT61NJqrFSXUKi9m7PoRvdsVIGAD2FQS3GcYAG304rRRsQ3cjecNzyCPe onuWByzcDueRVKNyHI8l17/gmVrOgy6NHF8IvBl8dcvYbG3fTvEF+QXlB2uTIygpgZyu488CmeKP +CVvxE8HeHrvxT4i/ZtsIbS0VCwh8TOzNukVAFG5ucsDyQMA98A/MyxSg7X/AAPUU5+R0J/4JB+J Fba3wp0hiOog8Vzpn/vq0NekfDz4H6V8CfDafDrSdC/s9rRybm3F19qxcEDzP3uxN4yMA7RwAO1e vlcnUq3b2Ry46o4ws+rNuSzfH3Tx6VCbaQHhSa95nlKRROsaOdXOgjV7U3yruNkJl84Lwc7M7scg 9O9ZviP4ieGfDFwbPULwmZBuaOLBKDrk8jt+PtXNUlGCu2b04Tk0kjjLv9sb4H6V4zsPBeqXmrGW 8aLfcWtskkdujsQCx39enHbPOK+4G/YO0W8+Hem/EjSfjTE2napDHNBLcaayjDjIVtshKkcgjHBB FefWxypW0OynhZS6nlfxg/Zy8bfCHQYfF2ratpF7o1zOttHqdncjYZWzsjIfaQzbSABnJ4HNedyw 3VtI8U8bRuhKsjggg+hFb0a0MRHmiY1YypPlkRusij7wJNfY3/BOT4Zabd/DbWfiBqGmxNPNqS28 c7jLFII0kCg/3d8gY+rRp/drHGvlouxrhXepG5wX/BSbSPsHxm0vUo1AW60iLOP7yzTKf02183Mx Yk5xRg1elEWKly1GRNKc8MOKbI/HXI9q6+U5XO5BIc5AOcd6gncjofxrSMbkOVz8n/gv+0t8V/Dn jLwdpvhb4nXVtJper2t3YSxXLyrbXIZVV0gZtvGcbeM9M9K/oI8LfGXQ/H/we07QPiX4lt55ry0h N3NqapaXUzq65d44mCIS6j5VGPSvyzK6apym60mlpZP/ADfY+h9i3G8U/uOxXXdNldni1K3fBIYJ IpCkcEda/Ov9pX4xfFXRf2ivFuleHPiS8VmNZvEWBo0lEah2IUFkJA4xwa9TMs2nldKNWhLVu2ln pZmFSlGbtVX6GRafGn40TaRdawniK3ltNMVDcXZtm2RgnALngcnP+Rx53rv7fWv6PrlvoEd3qV9c 3bpFEtnpbgyM5wuxZHRpMnABQMDngmuTL87zfMmlSbs+rSt99jSOGw89VTX3v/M7zSPg340+GvxV 1v8AaF+M0fxKFnpatqGpWWixg27RyW626SxxuDGWjjkbd8+UCOTjivsj9l/9g/8AZD/bo+F6/FP4 TfGLXb22MrW95HcFPtFrcbQWjnjwrBsEMCGIbghiK+io1q9Sm3VfvJnbjKNKnKnGltyq+t9ddCr8 U/8AghR4g8DIfEfwb1az8STQMrLFdSi2umyQHAWQ+WRtUEZk+8ARjnP2hoPwu10fsx6N8LpALO7i hLtDP1hLyvLsIGQCofBHbFZTlKejMFC2yPMf2nvgD4suv2DPiP8ACbT9Nm8Q6ndaTJPY2FlCZJJ7 uKQTxLGnJL70UADrgCvA/wDgl1+zN8dfEngDXfD/AO2p8KNQ0zR4Bb/2BLrsoi1KA/OssQAbzVhA 8shZPlB+6OWrbCVnhqThcxrUVWabO0+Mn7Ln7PHh7xRLoegftC6pod5ayqs1nd2Md9GSVSTaGUKR hJFJJJwMk9DXuPwk+Nf7Mv7J/wCzPbQ+PfjJbQ6fY6hLZ3OuXFrIkUl3LumCFUDFcR7VyeMrjOTi nVxFSqvekuXtb9SadGnSfurX1PFv20fjB+y78X/iL4bj1f8AaWsfDNpb6ZcyTXE2mSTXBd3ga2Hk yNE3lujTtvBONq8fNkfKXxm+G3g3xba3+k/DH/go54bitXiZolt9ClgvZSF3eWp81lQkjbu3AY5O ORWMsXXpwcISSXnv9/8AwC3hKdaalNO2l7dj598d/EjxX+zW2labe/FTxT41W/Xbeanp8MV1Fpsf mErIyiJ8nAYEeYWwM45WvVPGXxH8I6v8Gr7VPhR8em1TWbsxvZ3Men2saxxEBWXHnOdwOWJK5GCu AeR4eMzrH4DDwlOas3095qz0Td1uvI+1w/DuQ1liKlCs/wB3Bte1ahztxfwx5X70XsuZ3djhf2Uf 2dP2g/jt4n1DW/GH/BQ/wJ4JudDeANp3jW9ayjvopfMIMW5TFJtKMGAyV3JnGVrrP2kfCvxf/Z2v LyDWf2vfhlr6pZvfWkvg2G41WO6U7h5Jkii2JKrRH5WZchwSSCCNsFnuIVL2vto2f8z1XQ+GlgKH Mknfbut/zt19Dn9N/wCCJHwX8Iawms+A7vw/PPDIssMup6lPI6upBHyspXggfWvbL74T/t/eFPD1 1L4F+K0Op3JDyRWr6moEjk9PMkjOwfTp0GK8XE5Vjq9RP2ycb+Wi66Wsd0atSGqk0el6x4b+NM/g vT47X4i3ya9aRJHetqlvOhvmUEl0e1WWELliAHKkdCeMt83fHP4N/E/wv4ivPFuh/C7T/F1ull/a urSaDf2t1OiR3KtdS7d5fzVi3MIlG9x0U4IH0lfAYWpQVGEFKzW+/m/U55TnOX75to8Guf21/gBe 6Bqsfwu8b6nY3t/BPZX2ny3stk0kEiKGIj3BJOVA53ErHGDwBVL9kv4b/BvxP8WPAPxch8aeJG8R aFq9re60NcWKeHU5UzJvt/mV0VWQHLbzhlGAea7sPUeHhGNJLs79tdjrpU4RU3Vvt7tu+m/la5+q Oj+JPC3jTTLrXtE8Ri/sijRy2qGN4D8mCv3cspznqe49q+cv+Df34hfErWdI+I2jfBjxP4e0mGyv I7d9QutButUhu4EeUwlEgnt+VDth3LMVYA4GAKirwlYiCipXqXaW6Ts/vs/yP0WmT9p2ScT6r+0r p9vEFOY7LwFcxgkkc5kupMYwfzqhqmrfESxRGvf2yTakMfMDeFrdMjB4BcYB6cnP0rFQlLY7HisJ FWVF/OT/AESOd1f40WOhpnVP2+NKgZe2o2+h24J9w7pj8647W/27/h14Pkdr79tn4X6ls4Iit7O8 lX1P+i6pgH22/hV+xqPp+BlLE4ee1K3pL/O54X4p/wCCgH/BO9/GF3q/iT9oRtT128lleRdDsdQE ru+CQiJbTAYIGP3vOADuAqj8a/2pP2Xviz+znr/wa8C+GfFrRasYp7Z9XsY4IIZ0ZD92RkkVWCEH Mf8AEa4cdiKeBhevJLsur9Ecqp3leJ5N4z+K2o+Ovgp4R+EOveFdIup/CIkig16QCS6ltmJKW5z0 RNxAGT26c54WLR1t5Vki8O2qOM4kjjRT6YzjNfCZjms8VVc6d0trXNYwcFYLpN2BPYMCe4QkVA1t Cqjy7IoCc/K2wE15rk5IUlbdEW1RuZAwB/hMmT/Oqc0j4Ym0BUcZYjP4/NUptEOBVtfF93p+5gZ1 YAcxNj8OBU8nxd8W2lq0ieKLu1hh5LyXboqj65wBXHTxeIp/BNr5mTqSeiRjan+3LqXgwm6/4XvF GRgc6kshUjjHJJ49ulXNH/4KBfFDx5HJpdv8WdD1C2UgtDftbzIckdd6EAcgckele7hMwzSK+1bu 1+tgjKpN8qseAfto/D6P4sWY+KPhnwZp0fiBYxLdW3h/S7eSO+jG+MyzQphQwDO3mAK2CCckIVyP g9onxs/Z5/aG8HXOo+GdBt9Uv7eayW0jtvtunGwFug88vHcmRpuDGd2w4O3cV+UfWZRjZ43lVTfm tf8Ar1O/C13TpVFPa34rVenyPrzxF8ffjP44trzwD/wldno0k9uFmtPCti8E6RkFd0bSvJyQGCle QcFcEZr4/wDif4U+MfgrTtM8H/s1/Cz4kLCl/f3s0F9oUst1bxypbLbwz7UZS4SJnOVU4lGRjBP2 NaisBUhyy913vfytY83B4lY2nNTjaSat6a3ucvrWif8ABQTU7B7zVv2dPFcsFunmPcyeBxtRACSz M1rwMAknOK9L/Z10bxPa+KdF+G37R37N/jXSb6/mW6utStfDN9bzWulmRY3uRBAis6R7jwqAltoL gNx0VMbTlGyevrcp4dLY+1tGb/gjVpOtxaT4t8CfFGGzghZ2vdW/4SZJbh/MdVQIjqinagkc7QB5 iquSrMNCXxN/wbx6reRRN4M1a6lf5o4rpfEUzyYByQGlJI4PQV57r1Zav8v+AU4KCSi9ep1nhb4t f8ER/DG2z8FeDdT04yAAR2Gh6uGfvzwS345rroPjz/wSqtQ1s3hXxRIAoZkm8Naw5APQ8x8ZxXj4 jAYOcnOvBNvq2/8AMcVVn8Lv9wyT4/8A/BJ5EaJfBfiOPY2GMfhXWQQemDiKoLj9pL/gkxZlBdaF 4jiLkhTP4X1kbiFLHGYf7oJ+gJrOOX5ctqUf6+Y3Srvv+BYT9o7/AIJWsyiLQdaDEbgreF9UBx64 8msb4lftdf8ABNnwj4K1HX/CXwx1rxDqsEWbbR4/DmoQm5lJCgNI8JCKM7mbBIAOAxwDrHCYKK0p x+4mFGrOSUm0m9X2OSsv2pv2Bm1Oy0vXJ70CWDz77UrDwTqUVrBJnAt7WPyDKWxyXndl77Mnavwv +1H/AMFIvjp4v8WXulfs8/sxP4M8NxyMkF7qPhw3up3UYOBJMzxGGMsADtijXbkjc33j2Yehlqf7 ylC3+Ff5Fyw9SUna/L0139TqnufEd9akx6XIQ/8AErElWxnHUY6E9KzNY0bx9PCLSXw3dXdm2Q6R DCjPTkt/nHtX5Zh8pr1nZrl82dFLCSXxaHnmt/siWfjyKW5/4VneadMD/wAfFpKY269dgiZTnPoT +VctqP8AwT7+I+mxSX3h7UobpY8FYJZNrqfTdjGf+Aivvcvw8sNTtVrRkred1+GoSp68qi/wt+Zu fCP4Cftn+E/EMWgfCzTtTub6VGdbOw1OBlWPHzuY2cKFAHLMAAOpxXs/hX9rS+tNc0D9mqTXbDUd cuL2VPEd9pMTCxgFuxKRRziZo5yzpvZ0RUGVCs3zV6eFoYatUjKMdbp6aX9THERqUYSV9LMzPHnx x0G08aePNd8NWB0u98OaFd2xvQxAvbuKOe5jmBGNpAmijHJP7vOeQBzHgL/gtJ8ftA8PwtqfgXwl qesSsZbrWp0uRNdSiNIQ7hZlAYRxRr3B256k16+ZQVVxUvP8zhyxOCk4+X5Gpef8FwP2qL6IxW1r 4ZslIwFjsWk4+ruxrhvGf/BU79qnxxJY3GpfEi2tp9KmFxZXNjYW8MtrJgqdkiqGwVJRhnDKSCCD XHGjTj0O+TlLqWLP9qj9uX4p28t9rvx51rSdJiiNzJqGq6k2n2whHDOFyC4GQPlDdR612XwZ+B/h D426YPHviP493Hi2MSFJX06Ro1WRRyrvJ+8zgg8qpwQRWFbFKgv3cVfujSnhVVfvs9n0X4PfAXw/ p40geCtGlWT5MX4FxI564DSFmPrj9KvXfw4+EUGIzorW2VCiKzmuLbgdANrqMDJryniKknzNncqF OK0RoaD4a8MeHoQdJg1qVRyd+oTzDHoQ0pBHtT9X0+/1nVLC6sJbcQWEjSm0mOWctFJFgsoOBiQn HOcdaiVRyd3+BSgoqyLgTVUfz5LO1LoCisjklQSMjOMgcDp6CmTPqbZRsgE9Ijzj05oU+wrWKN3Z NM4a7mvAF6bMDB9sCo/syQR7ItYu2OSds9w276Dnj9a0UmxM5p4fFFvrT6jLa2uowRKBBDC4jeIk EO21vlJPTO4ccY5NXYPGscEq293oGqxysT8rQErgf7akoPxam0pbAnbcy9V0Tw34lvX1GyhmsLtM g3Gm6i0Ekee7qh2kn/aU5ry34p/BD4reII3upv2jJoRExWESgwhIz91HaHBY9snr6U4VlTfvK4pR cl7rsZPwY8EeFvh14D8d/DL46ftHQ+F7fxRLp1z/AGnaLczNqMdsl2fsc0YCyCOSSVG+f5SYVODV bTPAvgf4Q/GLTNS+Fvi2x1dtR8Mi/wDKjSMSWjzXIVElQMwRisZcAncFcZ7V6mCk62Jgo6K552NX sqE35GJ8PfBX/C79P8YTwy3dlb+ILy6jmu5Iw7KjvgBM4yNgCjHQcdqsaL/wT1+FVt5a3Ova7cqr AERzQICM9cbCcfQ1ecYt0pwjFa2v97ZGU0E4Tcu6X3JGtqn/AATm+Gupxj+xta1qwcjoJUkX2JDI D+Rrl9a/4JxabYRPLZ/HeK0kjGSmoWqAD6sJRj8jXkQx9TZq56zw8ejPLPHfww8S+DYE8MTeL/C/ jC1+2wyLLZ6msksCqrq0YjdwoV96luCcxryBnPez+Bf2ivBWpPrPwC8A61pfh+eCHZHC1tO0rAFv mVCd2wuUDYDMFDHk4HRKrB251ZPuZKnJP3XexJL+0b+1L4ftH034gaFdvbMMPBqmmNCpA5H3FTB4 ByDnpzxXSeHP+CinxD0eVU1bwrpV3AAAY182N8+zksfzBoeHpVF7rE6so7nRXf8AwUzZYUa1+GyQ OP8AWGW9Mq4/2cIpH1OatWP/AAUl8G3sQPiLwbexquP+PGSNx9cSKM/mKj6lZaPUft77rQ39L/b2 +AGpMGk1zX9Ob0nt0IH4JuH6V0ekftWfBXVV8yz+MtkW5IW/H2diOmNzqozz6VnLDVI9Lle1i+pq 6J8cPCXiOS5Gk+JLeeOAgC4t7yBklJ/u5wTjp0xVrUvFdzeWEhtrloPNGFuCQSpBzngYI7dR9RWb XI/eKTvscraeJdF0ZpT4i8b2J8ogfvbqKP5+wKl8j8QKz9a+O3wq09pLZfiFpEbquHljuFlKk4Hy gAgn8T9K0VKU3dITkluzn5v2p/gbo15IkfiGW4dVI+1pau8jj03lQSPbpXGXP7T/AMJ3v7l72XXN REgOJEtwuQf4QXmIA7cID05NbRwtR7oh1odznPFX7RPwp11hBD8BbG5CABZtRaMuQDkcbD3GepNe eeOPiGniHxLb6/ongDS9MECJEYbaRlEqqxYByoUnqQeRkYB6Cuijh50Zqpzaoxq1I1IuNtGLYftF fGnw5dzQ+G9dg0S0nuGumtrK0jkiLsSSuWBcJycKW2jPAFWrr9ob41a3CUm+LF6CeosligOfqig/ rTeHjJ3lq/MI1WtI6Ip3nxJ+IGq7BrHxB1m42nK/aL+ZgD04y2BWfLNDeP515IJZH6vJ87H8TWsa cY7aESm5bsYzRK5IG4Hgk1teEPiD438E3An8H+KLzTmJyVt5WVGP+0udp/EGlKkpKzQRm4vQ9X8I /tv+P9J2Q+L9LstYjHWRR5Ev5rlf/HRXXRfHP9m34rAReMtKsrG4YjEer2iuPfDqrD88V51XBuHv UvuOmGIUtJFvW/2ev2ZPElidQstO06OKbGy7s7zy0OcdNrbfX+GuD8Wfs3fsv2MTtafEu+gkAHFm 63SAnsQFJH4tXOsVVp/F+JtKjGWx574m+Ang7TyZtK8e3N1AFDhpLGNNwOMEZmyevoO9ZafD7wTp 6kPJd6hOcEMkpWMj0KgZHbo+KcM0VTSK+fRfkZKjfrodZo1nq+j28Q8N6DZWjHIDWksSXBGDnJzv 7HqetP3alf3JbX7q+Mpi8wCdmb5OeR83Ix2+lcFXMoSUuSXvLvp91yk0tFoeMW1xK03m+aGJ43E4 P6dabPeX1lI0yyNcW7HJVfvx/h0I/WvsLWPPRG2qx3TbbacMTxsX5WB9x1qxa38MSqsk6KT3JGal PUCS41CPkw3CvjspqE6pKjDKA47g4/pSegIadWuWPBQDPUnJ/kKjmvNwBklhA9MDP65qW7lJdh1v qenxOrLPsb1dz09cZouPE1jG5VSZAT1UAAke9S2kVytlSXxo0WTHAwI7iQ8fh0qufH2pLKQyhQcb eM/0qXOxShfcfY614r8T3f2LTpIEcKWJkmSMED/fbBPsOa91+EH/AAT++J3xY0C38V6v8UtI03T7 lkUC18y6lGUVjlRsTI3BSA/BDDtS5ZSjz9L2IqTVJ2tqcl8V/gfF8F/Hl/4U0D4j3d89kY42me28 gTOVViuws3ALY5J6ZrBs/i54j0e8hj8SWcTpGynbGwSXbgLg4OOg/A1jmGAvSU29191wo4xNtNan c6P8fPh7e4TU9La3ijCjyGQMG4AyCCTxjPvW3b/Ej4e624tYtb05IyirArReW8WQNxJxj0wTzkc5 r4KrhMXQk3FtryfX0NfbJa7m5puvQxXKX+j6VHKpUQvcnkD5i2du7GOP89tcXmnwTzX2p6JBE0yF kmCDDErkbSPfGPWvEr4irUleUnzbf8A5J4iTej0Pk5kupGDE7TnqOKieaW2J/fA56kkmv2V6bmi1 GtLbTqBO6ZI6kc/nTftdpbsfs8uV9H55+vWk2hqLZImoXEoKRIAexUZFNaLWZCGS3lkfrhFyaltg kuo9NE8TXJCtZhQTwZWAP5Vbg8BapMwlvL4Jkfw81DTZTmlsW7b4dxSMPtGquBjOAMVJceBdGtFL tNK5A6g55+tPl7k+0bM648Mx8m2jdB0znNR2/hqVCZBcMuCcZHHr60nG5amMvvD109uZ40LsCTth XBP1BrY+HH7Rvxi+EIGk+FvGepafaRlitnK/mQozZyyxPlQeSc461jUi46xG5c8bGJrPjHxJ4m1S fXNX8TT3lxcMHknu5SWc+pPc/wD1qoXMV24L7ohjvnBbpwf0rz6lSUn7zZi0k9itJNe+W/n2oAB6 ocYx/wDqpsF5esFEMRJ/hJycD0qeRA0jX0zxh4k0A+ZpOvXlm4OQIJSBkHPTPqK6XSf2j/H9n+6v rxbuNUAYTLglRxyR+VcGJyyhik7x179SXFM5hLHxHcgjayBvRat2fhO6wBcMhLdWkAY/kQa+sab3 LcraIvW/hPTYSXuY1djnhRgflVtNH0mEDy7KMH/dzSasLmbJ0ito33LEoHoAKmEqxggJjPOTQlYB /nuSDvxikM4OVdi3ueabdhWsILluAo46ZHpTkVQQWAJ/vd6lahYk88bSgiVge5qtJbxNluFJ7qcU bAm0PIQIVJJz3PNUNS0TTtSBW6tEcnuOCKlopNo5rVPBs1mskulXTHHIhcc4+tY6vfWLiK5iZeQf m4rnqUbmqamtRqX8ryhZHDKwxyeCe9XAoeNmidlLDG0Edq45wsZNWBi+zEiq5GSCB0qKOVBCVnti 2RyU5qXGy0Ekj//Z/9sAxQAHBQUGBQQHBgUGCAcHCAoRCwoJCQoVDxAMERgVGhkYFRgXGx4nIRsd JR0XGCIuIiUoKSssKxogMDMvKjMnKysqAQcICAoJChQLCxQqHBgcKioqKioqKioqKioqKioqKioq KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioCBwgICgkKFAsLFCocGBwqKioqKioqKioq KioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKv/EAaIAAAEFAQEBAQEBAAAA AAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEI I0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlq c3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIB AgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEX GBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKT lJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX2 9/j5+v/AABEIAeACgAMBIQACEQEDEQL/2gAMAwEAAhEDEQA/AG4oxXvnhBijHHNAC4oxQAYoxQAu KMUAGKMUDACjFAgxRigAAoxSAXFGKBhijFABijFABijFABjmjFFwDFLjigAxRigAxRigAxRigAxR igAxRigAxRjigAx3paTQB2pCKLDbDFGKBBijFABj2pMcUwDHFLigAANLt4qGUhQBRgVJQEDrTcU0 JiEcUYqyBMUYpgGOaTigAxRigAxRilcYAZpQhPak2NK4vlcdaDGBUcxfIJtGKNoxT5hcqGke1Jjm qRDDHNJiqEPpaBBilxTAMUYpAAFLigAxRjigAxRigBcUYpgFGKQBjijFABijFABijHNABilxQMTA xS4oAMUYoAMUYoAMUYoAMUYoAXFGKADFAHNAABSYpBYXHNGKYBijFABjijFIYmKMUCDFGKBhijFA gxxRjvQAYpMUtB3F5oosFwpMUbAGOKMUwDb70beKm40gwKNopXY7ITFGKpMQmPag0AKKXPFS0O9g yaTJpWHdhikI96EDEIpMVaZLQYpKYmPxmlxTJDFLigAxS4oAMUYFABijFAC45oxQMMUYoEGKMUAG PSlxQAmKXFABijFAwxRigAxg4oxSAMUYpgGOKXFABijHFIAxRjigAxRigAxRj0oHYAKMc0CDFBWg AxRjmgYYox+FAgxRigYYoxxQAmKMcUAGKMUMQY5oxSGBFGKQ7Bt5o2cZobsCVxdopMUr3KskJzRi mSFJimAYoIpCExxRimFgxRikMME9qXae9JtDSDFGBUlCEUhFNAJijbxTuKw7FLWhmGOKXHNIAxxR imIXFGKADFFAxcc0YpAGKMUwDFLikAYoxTAKMUAGOeaMGkAYowaADHFGKAFxSYoAXFGKBhiigQYo xQMMUYoAMGjtQFwxQRQDDFGKACjFABijFABRikAYoxQOwYpMUCClxQMT6UYoANtL2qBpiUU7DuFG KBBikwKVx2DHNJincVgxRii4WDBxSYp3CwuKMZqWxoB1oqbDTDmkp2Qm2JRgU2AlHOadguOxQOtW Zi45oxQAu2jFAC4oxQAuKMUAGKMUAGKMUAGKXFABijFABijFAwpQKADFGKADBNIRQIWigYYoxSAM UYpgGKMUAGKMUgDAxRjigAxRincAxRSuCDFGOaLgGKMUBYMUYoGGKTFILC45oxQACkxmmAuKKQCY oxQAd6KQxMUYobQWFCk0beKlyRXKxMUY9KYndAAKXioZasGB1pO9CuDsFAXNF7BYNmRThHmpcilF C+VR5XtU8xXKhDFTDEatTJcBpQ0m01opIzcWOoxWhkLijvSAXFFABilximAY5oxQAtGKBhijFIBc UY70AGKMUAGKMUALRigAxRigAxRigAxjmjFFwDFLikAmKMUxhjmjFAgxxRQMMUfhSAWkxQIMd6MU xhigCkAY4pKBigGlK1DlYpR0G4oxVJkhRjIxRewBilxSuOyEoxTuIMUYoAMUlSxoXGaXYR2qHKxo o3HAHHSlKd6zvY0sMMZpCp71opkSgIVowafMmTy2DtSYppCbDpSgik0OLHAilDCs2jRMdvFG6psU BOaaaEAwjJpCvFXcmwmKMV0HIGKXFMYYpaACjFAC4oxQAYpRRcQY5zRjigYYyaXFAWDFGKADHNLQ AYoxSGGOKMUCDFGDQMNtGKADFLigQhFBFAwoxQAYoweKTdhi7aNtTzFcomKMU7isGKMc02wsBFGO KE2DsGKTvQxC85oqbFcwmKO9MW4AUcZ4qG9TRJC4zSbTRcHEMc0YpkiYNGDTFYMUYpAOAFSAjvWM mzaNh3FHHaoNBO9IfpQIQj2phSqTE0NK0mD6VopGcoibTRtqrohJ3FC+tPCjFZNmqQbBmlwAKm7K sGRSHGKAG9+lGBTEhuOaMV1nIhcUY9KADFLjnrQAY9qKAClxigAxRii4xcCigAoxQAuKMUAGKWgL BRikAYoxQAYopgFGOaQBilxUtlpCHrRimiWLikxxVAFGKhlLcMY6GikkNuwYNGKuyIDFGKADHtRj AoATFGMipbKSDFHSkpDcQop3RNmJjNLj2qWy0AFO2ntWbNELsJPSgxHrQpWBxuNKEdqTFWpXM3Gw YpCOKokMZpQp96iVjSI4bhTgT6Vk7Gmoo5pakYZ9qMe1IYhXNIYx1p3CweVSeXRzC5RPLprKfWnc LCYamkNVJokTFKFNNsBQhpcGpGkM7UY5rsORi4pcUgsAFFMBcUYpXAKKAFxRQAuOKMUAGKMUAFLj FAwxRigAoFK4WDFLRcLBijFABigDnmk2UldhiipKtYMUYo1FoFHemmwaQY4oxVEBijHtQh3DFFAg ooAMc0YNFwExRUstMSjFQ2aJCgCl21DZSQoWnbKlsrlDyzSjjqKTY7Ds0vtUgIQDTdgpp2BpMaUp m2tVUMnATnPSnrnuKlu+pUVYeB7UuB6VmWJgUZpABxRkUDFwPWmke9AhOfrRmmAZFLxmgBePSkKi gBpjFN2U7hYcBS44xRcCvRj3rtOIXFLSGFGKYhcUfhSGAFGOKAFxRQAtGKBBRQMMEClpXHYOlFMQ YzRQxoXtR3qditGFH41SZAY5o6GkAYoxQO4UYoELjjpSYoGHPSl+ooDQKSi4g60uOKLjsJjikxg0 mOIUtRdmnKhQDS7KXOP2YmzmjZUuRSiL5ZxSYqWyrWF5pwJxUlC4NIc0AH4UZ9qQh2eOlJ+FIYH6 UmAe1MQmAO1AzjpRcdhQDS4OKQCbSaQxkDrTCw3Y3rSbD60XFYNpHemncOlNMTAFqUZ9KGCDHrS0 rgKCaXdx0oGGMijbSHYYUOeKMkU7iIwKAK7TjFAoxQAYooAU9aMUALijFABRgUXAWilcAo70gQda KLFN3FxRimSLiigAwaSkUnYXHFLihCYYpDRcErhS0rlOLDiijmEou4fjRU8xfIHNGMnpQph7MXBp Pwqk0yXFoKMA1EpMuMUG33o2jFTzFcobQBSdKd7hazDNLuqXErmF3LigMPWpsx3QoYetLkVLKEwP WjB9aAD5hRuP1oAMtSbm7CgQb2Hal8w56UWGG4ntTSzUgE3PnpRub0oELk0BjTGLuIo3HNIBNxpd xoEG72pD9KAEyPSjNMA3CkJpAxueKTk0wHAmlBNFgAk4xTSTRYVxtLXYcgYpRRcAoxRcBcUYouAd 6OKQBijFAC4oxQAYooAUCjFAwFLigEgxRmgLBkGl4z0qHI0UUHFGOetJSY3FCDFKMA1LbuUkh3B9 KNoPepuXZBsNNK+1NMTVgxRVWJTCioKDtRimmJq6EODQPeqZK0AEClDAVBomGRij5TSsw0YmBmjF O4uVMTFIRmi4WDHagD3pMaHfjQD71LGO/Gg5pDEyRS5PpTAOvakNACZNG72oEG6lyPWkAcYppIzQ guLxik4pgIfY0ZNAgycUZNFgEyfSkzxTsK4nSkJphcTdTgwoaBDgwxRmpKuBbjrTCfeqSFcdijFd JyC9qMdqYBigCkAooxQAuKMUAGKMd6ACigLBRmlcqwUUwsFLyDSauNaC0h61OqRWjDj0pc1DLQvH pQelJDEx7UmKvQjUMc0oJFQy02KGNG72pWKuG4Y6U3PNAtAz7UdqYCjijNAhKOMUgQcUuPakyhMY pBTuIMjvSjB71LHuO2igLmlcoTYfSjbincLBsoxzSuIBTscUhiZ5oz7UALn2pOvagBpGaApxQAFO aQoR0ppisKAaMcUXANtG2i4WG4waXAxQIMcU3kcUXGwOaQgimmKwlJg00xNCbTRtPSi4WF2sBR+N K4BtpDH707jsSUYrpOQWigBaKBi4ooAPxpcUgsFGKYBRxSATAowKCgxSYpMaF/GgE0k7DtcWipch qIYo4zSbLsKKMn2qRiik3c0hi7hijNAxcDFGAaLhZBtHrSbRii4WE2jpmjbzRcVhNtG2ncLBtFG2 k2Fg20DgYpDQcUcUAGAaTbSCwnINAegY8ScdaXIpAJxSde9ACge9LnFACZFGVoAXcKTcKLgGfejd 70AG/FJvBNACgikJ9KAFDH0pd4x0oATIpuKADgdaTdmgQZFLkUDEwPWkxxQIM+1GfUUALTSvPWmt AEwaQk0CHUua6jlsGaXNABmgGgBaKBhS0AGSKTcaACg0DEopMBSKOallpoKKllIXPtSc+tIYvPc0 vPrSKE/Cl49KQCcUA/WgAzRk+lIYbj6Uu49xRYBQwoLZpbDuJSnjvTATNGR3JoAOPWjj1pCuLx60 00DE3DuKPwoENzz3pQ3HSgA3c9KQ/SkAnNHNMBQPejJpAOBJoznvQMTHvRjjrQAnOKTPNAgz70bj QMXOaT8KAuKDgUZxQIUmm7ueaAFDCjNACZo3c0AGRQSMc0wE70An0pAw3EdqXd7UALn2phOO1AMN 3vSbh3zTC48CjFdRyhilAoAPwoxQAtLQAhyASOfalHSkMUfSjAzSuFg/CgH2ouAZFGRQ2NIKSkUk HSlpFITvQc4qRhzRg+tIBQPejmkMTvR26mgYdKO/WkMXBo5x0oFqJ+FFAw4pRQAoIpPlz0pAHFHX tQAY96Cpx1oAQA+lGaADPrRxQMTFLQAUuAaQCFQKT8aADtSnHpQAnFAxQAuAe9IU9DQAbDSYOaBA A1Lz3FACY+tHPagYc46Uh+lACYpeMdaBWFAB9KQqPWgLDWAUdabwe9MBQP8AapefWkAnOOtHzfWm AbmHWk3H0osIZvOaXfxRYCfNITXTc5gzS5NIoM0c0XCwZpQfelcdgzRmi40kFH40XDlFBzR+NK5V g4opXCwZpN1DGLmjikACjIpDFz2ozQAd6M89aQxuaXPHOaADOeoo+lIGwyc9KMmnYA5IoxzmkMX+ lGKADHvSYPrQIMGjBz1oGHekx70AHOetHPrSAXbzSY9jQMCOMUYFITDGe9KAaBi7aQjFACfjS0AJ zRjI6UABQ4oAPrQIAT0pOaADB7Gk59aAF5PSkwaADJ7UAk9aAFz7U3Ge1AAAaDkUwGZ9aUY9qAD5 fakJ560gEyc9aXcfWmK4uaTOKQxOtGBTAl/GjHvXQc4UuKB3CgdetIApepoAKKBoUUmKRQY+tFIB cZoIoATAzRgUgDFGMigYtJzSAX2pPxNFgF5zS0hid6KADtS59aBh2o6UAJ2paTAO9GfegbYc/wCT S5oEGRSUDDFGOetIBCKTFMAxx1o+hpALg560DI5pAHvRn0oGHIGOaTk0CEIPpRg+lAzM1jXINGaI TxPIJP7hHAqzY6naajCr2s6OSMlNw3L9RVcrtcm6vYt89qMn0qBhu9qQkZpgALZ4pcnvQA0nnpRv IoAN/FIWyMYoC4hpCcdzQIMml3Z70wGkg9aBtoGKNtB256UgG4FHFMQnHrSdaAD6GjJpgTUtbGAY oFAC0UDQtFABRSKFzx0oFA7hRjikAUYoAKOtIA7daPwoAKKAFpBSGHaikMOaM0Ag/CigYtJSAKKY C0UAJn3paTAM0n4UAJ0paQxOlGfegBKQmgAyRRk0AGSKXJoAM4pN3vSAXcaNxoC5y3jnVbe5s7HS 4rVVnt3eSWfAy+7btHrgAH867Hwt8L9Gh06zutaa8ur+4iWb7JDmPygem4jkfUkVUpOEVYStJ6nb S+C9NktAltHLaOBwTKZPz3E5/OuJvLZ7K9mtpCC0TlSR0OKxhJt6mjVtSufrSc4rQgTNGcjrTsAh PvSZ5oExc4pOKACjPtTASjvSAT8aTGKYmHNHHrSGL+NJj3oQCYopiAY9aOOuaAOBbxtqrP8AJ5Sj 0CZz+dWF8c32APIgJ78Ef1pe0K9mOHjy8H3rWDH1NSDx9P8A8+kR+jGn7UXsmOHj2UjmxTP++f8A Cnjx45/5cV/77P8AhR7RB7NiHx64bH2FT/20P+FPHjzjmyGf+un/ANaj2iD2bEPj/GM2PP8A10/+ tSjx9nn7B/5E/wDrUe0QcjD/AIT/ANLD/wAif/WpP+E+YjiyUfWQ/wCFHtEHs2Efj1mHz2Sj6SH/ AArX0bxL/bF35EdqVwpZn35C/p+FCncORm8PrRWhAmKKACilYApM4oAWkzQAZ5ozSGgzRSGH50ZP rQCYfjRn3oC4uaM8UDCigA/GjtSAXtSGgBKKAEpKACikAUZoGJmlJ5oAAaKGAlL9KQFbwV4cj1zx peazqERksNMYNtxkSyfwL7+v5DvXpt3d3dveLa2oSbWLxfMcuSY7WIH7zY6gHIA6s2azqvWxdJdT VsrP7LEPMuJ7mVh88szk7j7L91R7ACvP/FMXleJLsY+8VYfioqYblS2MYg0nTvWxkJ2pDTEH40g+ lMQUuaQwyPSk60AJ3opgFJ0pAFJ36UxBR+FABSUAFIaYjyPZnkZ/E0CNyTzg1zHSGCeGGSO4p7IQ oIIFFwIgcdRnml78imAoHPU+2KCpzQA4jPBBA9adsA4LZzQA3bg4wcd8Gl4x/hQFhyKccEH+deke GNN/s7TV8xcTygPKe4z91fy5/GrgrsmbsjboroOYPeigApKBhRSYCZpaAAUlJgFL7UhhRTAKKQ0F L+VABk0fhSC4AUUALSH60DEz6UZOKAEpKAEpaQNgKCaAuJmigA4ooHcBT0jkkYJAhkkbhEHVieg/ OgR6NpGk23hHwskVx8wtlNxcsgyZJT1x69gPwqfSLGW2glur8D7fet5tzg52cfLGPZRx9cnvXNJ3 dzeKtE00BCDJzXA+No9uvK39+FT+RI/pTh8QS2Ob/GkP1roMROKTigQnaloAKTigA6mimAmaKQgN IfpTAToKPrQAmaB160WC4UmeKYrhmkoAyhq3w6xj+yph/wAAkH/s1L/anw3PXS5h6cSj/wBmrjvL ub38hDqPw2YY/s+cf9/f8aBefDU8m1ufwaX/AOvRdi5vIQy/DBjzDej6SOP/AGWmsPhmzcS6iq+m /P8A7JRdgpCi3+GWcrdaiv8A20/+10otPhq2M399+Mn/ANrp3Y7oeun/AA2YYGqXo+sn/wBrpRo/ w3PTWrtc/wC3/wDa6LsOZCjQvhyxJHiC6H/A1/8AiKf/AMI58PWGB4in/wC+lH/stK8uwcyLdh4R 8ENKLuHVrq4gtnQykFHC5OFBGO5GOtXooyiHc252JZj6k1vSu2RUaaH4oxXQZBijtQITGaMUDDFJ ikAUUAFJSYBS9qAEpaADvRmiw7h2pce1IA2ueik/hThDKekbflSAeLW4PSGQ/wDATSm1uB1hkH/A TRceoxkZfvKR9RTKAEpM0AITSZ5p2C4UnNIBfejPtQAlFMApKAFzW54QtxceKbJSMhHMh/4CCf5g VMth7nod7GL3Uo4SMwWzCaT0Z/4F/D731CVK9ch0Dx9wfSuH8eRgXlnL/ejZfyI/xq4fETLY5I8U 3NdCMLgabQAUYoAKTNMVxKM80BcXvR2oGJRQISimAlJQIKQ0wCkJosBB/wAK1m7XUH5Gmn4aT/8A PxAfzrkujexi694ZOg36WssDXBaJZN8XA5HTkU7SPC/9rW19NHA8f2KISsjdXywGB+eai6BJkf8A wjpx/wAek4/4CKQ+HfW2uP8Avkf40cyEWrDwgb9rgLG8XkW7znzFxkL1A96xzZ2w629zx/sD/Gjm Q1qdQPhrdtFFIkkG2WNZAC2CAwB5/OkPw0v+xgP/AAOquh2Yw/DXUeywH/gdNPw11MceXCf+BijQ LMvaV4Sv9DdproIIGYAxhsqzYOMj25I961a6aS0uYVHrYKStiLhQaQCUUBcSigdxM0dqAuFJikAU fjQMKCQBknigCs+oQo2Buf8A3RxUSX1xIC0UUITONzsTj8MVDaRSi2D635JI8yJiOu1BxUd94lur AxNOnlJICyDcQSPU88D3qLl2M2bx45INs8yrnnbKefpnNdF4d8W30sm6KaC8TG4wTldxHfJAyp9+ R7UpN2GlqeqaLdWWsacl1Zj5SSrow+aNx1Vvcf4GtA2af3R+VY3NLEEtpbMCHRD7EVQn0PTZwd9t Hz3Ax/KmpNCcUZdz4Ns5cm3leM+mcisW88I39vlodsyj04NaxqdzJw7GJNbzW77J42jb0YYqKtCG BopgFJigBcUYNIdhKKAAda6/4fwZ1W5uCMiKDH4sR/gamezGtzuYovKQ5++xLOfUn/OPoBTHFcp0 DgPkFcn49izZWcv92Rl/MZ/9lqo/EJ7HDGmmuk5xp60CmIOaKB3EooEJRQIWkoGHbrSfjQAUlMQU UAJRximAhpMUAdhpuqWuqWwns5Q6E469/wA6uZB6MPz/APr1wp3V0dBz3iu+s4dXRZrmIMLePK7h npWn4P2Si8dDlWgUg/8AAhWTa5rDizodgpdgqbEjXjH2S74/5d5On0rgHiXngVXQpM7Yj9zbYOP3 Eff/AGB70n5/n/8AXrVbA9wGPelAGO9MRQ1zjTEGDgzdf+A1zuK6qXwmE/iDAx0pMD3rUgMCjHtQ MTAowKQCUmBQAYGKMDPSgBCKxbnxJBFeTW1ra3F5JBxJ5Cg4PoMnk/Sk3YuMXJ2Q6x8R2l5dfZJ4 5rG7PSC5TaW+nrWvgUr3QSi4uzGs21SVXdtGSc4Cj3PasW7vRLIVLiTnhU+6P8amUhqJW84k8ndt /JaZd3Ujt5CPzjLYPSs7mhWtb+G0jKrB9quN3ybh8kfufU+1c3rk817fOZJmk4GWJ644oTAqRwEw Mm7aUOee/tWz4fkvbG7W5aLfGpwT1ODwcH1pNjR7V4F1DyvEKRAkQapATtP/AD1QZB/FN2f90V6U R8uaxLMnVUxHuFYRu5Y2xHLj24pMXUsQ6q6sBLGpB6sOK1opldth9MiiL6AzmvHcd/p+mf2pp6xX EEA/0m1miDqVz98HqCM84PT6Vwlnr2h6q4iZ20u4Y9JTvhY+zdV/EY966YarQymrMvXOn3Fpgyx5 jYZWRTuVh6gjiq2K0vczsGDSfhQAtGRjpSHcTNGeaYXFHWvQvh9b7NKu7gjmSUIPoo/+yqJvQqPx HUGonHFcxuKPuiuc8bp5mghgPuTKf0I/rTjuJ7HnhFNrqOYSkHFMAPWjJ70WC40n2pO9AhaOaYBm igApMUAGfak5oAKKAEpKYCUUAePafrOoaROslrdyRN0Uhu9dRoXxB1e1a3F3dSzWiybnXdhj7Z9K 8BVnD0N7Gd4p8QDVPF0t/YIxhZRjJ9q9H+FHie2eSWzZ7ue4uIwg3EFVIYH2wOtP2i9pzdyoxtse rD9KXFdO5I2T/j0uv+vd/wCVcC465qug0dgGJgg/64R9/wDZHvTc/X8//r1sthvcAR7/AJ//AF6d n3P5/wD16YjI8VajBp+jwSXJYI9xt3AZwdveuZg1mwuceVdJkno3y/zranNJWZhNXZZFzDtLeamB 1O4Yppu4Mf65PwatuZE2YgvICQBIOTgcGnyXEESK0kyKWOAC1TzxK5JLcYby2C7vPjwf9oUqXMMj YSVGJ7Bs0+ZCsxn2u2yR58fHB+YUhvLYD/Xx8f7Qo5kFmIt7bEkC4jOOo3Dig31r/wA/EXTP3xS5 0FmVdT1WCz0u5uVuIw0cTMvzDrjj9a8t0zxPc6QG8pond2Ls8mSSTj39qickjehzJ3ial54uudft 7a0kjRZDMuJI2OMZ9D3z3r0e4uobaINK5y3RR1Pv7UoyVtC6zlN3kZNzeyXwEanbGDwo4Aqq0BCs sQJ7lqi5KRWBkjTzHVVRT8q55Y1WuWu0upN/7tlyGKdTkdPegCk0x8vyo/lOfnI649M023szdQSB ecMCQepApAR2cKpGRcqSJZMD1GK27S0W3QBQCM4PvSYLY9B0ZWtNW8OFTnbcxqrAYyrqw/kxr1vP FQUZ2pHMB+lcddFd5BbBqZ7DW5VM00Q+SZSD2aun0658t4BIrGV4h06Cs4vUb2NqaGK7tZILhA8U qFHU91IwR+VfMer6f/ZetXmnynL2szRhv7wBxn8a66bszOS0NHQ/Fmo6E3lxuJ7Un57ab5kP+B9x XoGlf2N4utml0lzaXaDMlq/JX3HqPcflW0u6MutiC70S+s2IkgLr/eQZFZ7KQcEYNCdxNDSKQ0CE yacCSelACjk16p4St/s/hW1GMGTdIfxJx+mKzqbFw+I1j0qJxWCNwBHlg461i+KY/N8OXYx90K35 MKa3EeaH2phrqOYKQttGSRimFxpkTaW3Lj1zxXO3/iyGCQJbpvbODurKpPkVxpXEg8YWslyElTyo scuTnn/CrzeItNVNwuA3GcD8qmFaMgaL9tcx3Vus0ROxuhIxmpNy5AyMnp71ummrki8Uo5IHFKUk ldlQi5yUV1AqQM4GPrUFzcrbW7yv91Bk49KiFWM1eLNKtCpSdpoz5dfs44o5fMUozYbnlc+1UNQ8 X2cETC2bfIOvHAqZVkkZJXI4vGMXkfvY/wB6w+UDp+NdBb3SXFusw+UEZwadOqp6CehKGBGQQfpS B1b7rA/Q1vcQgZScd8ZxSeYm3duGPXNK4zwm3medzhQQp5atCK8C20sTRRyFnG2ZmIKAe3T+deBK KTsdLViGSWSQJtdQncirmmahd2lyhs3k80dSgwD/AIVko2A9m+H9prsNz/amtyiRZB8kEsrnHocB h+ua9GGrSf8APC2/Jv8A4qvSpw93ULWBtSZkZTBb4dSp+9yD1/iql9nsiOdPtj/wJ/8A4utOVBcm aQPgbUjVVCqqngADA703jH3h+f8A9eqFcNw67h+f/wBelyP7w/P/AOvTA5r4gkf8Izb5IObrnOf7 vtmvMGjR2zheB6t/hXHWupXQ4rUryKN7xgqBsBHzvxzg1PGnlPuQLnHd2qHOdty7dS3b3k8KnBTH 1P8AhUv9rXPYRn8T/hU80i1JijVbn+7F9MmgavcqThYgf980KUh8zAatOTllh/77NH9rS5+dI/8A vv8A+tT55IOYBqjgEhY/m6/MOf0oOqN3hhPb7w/wo55C5/Ip6xcC80qaFooxkAjaRng1mQ+FtIkh hnurq5y7AOiR8DPvyf0raE5WOihGM27jtO8EXY1WGK0njk86QCNs8qc5+Ydq9PHgzW5zvmns2Zup Lkk/pXTTd1cxxEOSVieHwJqY4MlmM9TvbP8AKpz4A1gq4inssMcgF249ulNnOiGX4da45idobaYx MGCxSgbsHODuqG48I6y1w0t9o87kjAeNw2O38NJspGU/h+ziLxy20sLng71IwKh/sDyMNpzoOckP /F7GlzW3Hy32I7ixS7t2eZPIlhY+WgUYJ7jPpjJ/D3qnbqzkhVLEEfL6+1Nsk9D0mJ5dZ8N2zA5i kDEH+EJE7H9f516YTjgHNIaM+/O6Jvp0rkLxDvbipnsC3KaoGkAK5JPGRXSw5F6gI4VAOO1ZxWpT ehvREmMV8/fFWMWvxAv2UY8wRyD6lFz+ua6IvUh7HLK5cZzzV3R9Uu9J1WK8sXKSwsCDng+oPsRx XRzaGTR9G2E8OqaXbXsS4juIlkAPbIzj8OlMuNHtLkYmt43/AN5awu0y7XRj3XgeymcyQNJC2OAr ZUfgcisXUfAV+dzW90WUnO0fIfpmhye6GorqczfeGr+wybiC/wBo/ijJcfpmqtnDcT+YtnHf3Gzh 9kTOVz64HFYupUTL5aZfFnqjSEmwv1yen2NgB/47XttpbfY9OtrbvFEqH6gAVUZyluJxinoSFeKh cUxDDyorN11d3h+/HpbyH8lJ/pQM8bhurm5LNbQyyoOCyRFgPyp5e8C8QTA/9cWqVXl2FyQ7lG8v dThO23tZJPfySAP1rIuda1OS2eF7bL7uoHb0olXaIcVfQyLrUNVaIxxQSJGOq885/wD1VjC1u5rk zPG0LA/dYdfwrNTUt2a06Tm7RHrptzPGkG4tIWwu3vk10MfgvWfKQLJAdnQb/wCdZTqQpndTy6tU 7GhYaJr+n23lqInbcSD5gwO3eo00rxRC8bgKxj6DzVPvjk0/rS5bIbyiulsX9/ihVObSFsjjpx+T VJ4ei16fVG/teCRI1jO0YGM8elFXE88GkwpZfWpVIycdjS8SC4stGmeEFJDhVJ9yBXnetLrSQ+bP cROmcskTnPA64NY4efJFovMYqdRehgfbnzkuMAcYponWQs7E8jrirs7nktDoGdjtBPtzW7pw1Bf3 luzEAYIyTn6U4y5ZE8t3Y07nUtQEKrdKYrbZtby32tmotP8AESW4mS0Mrk8qrc849K6HX1uivZpb la21G9tpJBMk0jO27dgnr/npTrrX7yIPbJv8krgt5ZAGffHWh1etyuVWscYkcrRlVVFjU8cdKjMU cmAOSeMc81wqWugrieSdh2q8caHrng+tdJ4LntIPEtpPqBdrSMksiruJYDjj64q002rlrU9p0fxQ 2p6sYIrcrbkHa5ODx3PP6CuoV8fxD8//AK9eh0Jdx4P+2Pz/APr07PHDj8//AK9BIu7H8Q/76/8A r0FhjO4fn/8AXoATd/tD8/8A69G4f3x+f/16AOf8d5bw7b7ZNv8ApJ56/wAP1rzorNn/AI+hx/s/ /Xrz8S0pAtyncCQXTf6SDmIfwnn5vrVzZOQD9qX/AL5P+Nc7krFDis46XiZ/3D/jQBPt/wCPpQfX Yf8AGpugFzcLx9r/APIf/wBekDznrd/+Of8A16fMguNMsy5/0kcdymP61SvNet7A4m1GNm67UXef 0NXFcz0Q0ZcnjeJTiFZpPcxhf/Zqmt/F6ylTJHcKD1+Qf/FV2RwzkGp0DJc3/hR9TtNskb7kZCxL Lzj6fhTdFubWWGJmkhjljQqRIcHkfrQ4KHuo78Okld9TTsLi3sIbzVbe+gtjBiONZbd3EpIzww+6 eMc0+1+KdzE/+lWkUqDr5bMp/DOa66WkTlxGs9DtvDnjbQ9clS3ad7K6f7sVw2Ax9A3T88V26WZX +Jvzqmc6RZSBl6Mfzqwhde+agpIkeOK4TZcRJIvo6gisDVfAejaooKLLaSKdytA+Bn3U5BHtSsM5 3V/AOpR25OmzR3Dqcr0Q/k2R+tcLJZanocjx39jNbPKSuXiyDn+6emfpQJnf+F1+0+L/ADBnbaWT E5OcM7Ko/RHruSelC2KRXnhaRT2B71ltpcTSfvcEelDVydmOXS7QYwDwcipzbhZt6rnPWklqD2Lc bfLXhHxn2w+NlZjgPaxk/qP6VQ+h58LtQAof5ugINXbGCe5uUiijkld2wERSxJ9gKu5LPpTwrZz6 Z4U02zvFKzRQDep6qSScfhnH4Vsgqep4qGxrYMjOFzVY6pZm18/7Snk7/LL54DZxj86ABLy1mupL aOaN5ov9ZHnJWq5l0qa2N0JoBETtMyybRn0JzTE2gtvsMd0s0OoSECJnMfn7kZM4LY9AR1+tasGp QXJPlTRyYAY7WzgEZB/EUWEmiwZV25Izn0qJ3Vl4yM9jSKI9wAAzUNykc1rLE5+V42U8diMUhnDf Dsaj4VF/b6rp9wIJ/LeIxEP8wyG7gjjb+VdyPENtKpVUuYmI4LxEAflmko6E8wz+2FB/4+G/75b/ AArm7jwx4VuZpJZrBDJIxZ23SDJJyelDjcfMVm8GeEXPNkR9JpR/WsrxJoWnWVtapomnSzsSd5Qb 9igDGc+uf0rOdK8dEdeDxCo1VJ7dTnBp1wWx/ZFyuO5tx/Sob6wvPs4QWE6ox+eRl2CIdcn2rh+r VT6VZhhWtGeXatrOpWerXKrqUoRJNq+XMccdwM1u+GvFMN+wtdRvLiKc8LJ5mA3+FelVow9ikl7x 8/SrSVe0pPlueqR+IVjRU/sfTm2qBloCScdz81SDxKqsGGj6eD6iJx/7NXme2XY+h+oNrSbK+oa/ az2F0J9GsAzQuFdYTuDbTtIJJxzivOJ1FwpSeJ5A3UEqf50/aKS7Hh5hhVh2tb3KB8P2DEk2UnPX Dr/jWz4Y8KeHb3X7DT9SjlWG7l8rMcvzBiDt9utVGblJK5z4enCcZyl0Vz1b/hRHhZQRFLfJnr86 /wDxNTx/BnR4VCwalexgDAGxD/7LXY6aZyc0exXn+CWmTuGbVbgkdC0CnH8q47V/hXDoHiWC0sHe aKWLzTOY8bOSCMc+351LpLoLTUtP4DtiMC7ugP8Armtcr4i0nSNL1ey0u6nnuDcn94rbVCZ+7n6n 9KJ0YpXRdG0ppS2PHhdyLJmbIZOozjPtUhvXI5Cop6EdqydNPYi19hhu0nH78MdvTBPP1rpfCJiu 9UERMcShCzNI23gdh70eza9EVGLPYNP0q1truC8s4FmTAO17lSB7jH9a6C61e8Ur9jgjPqssoH5E NWvtlYp030GWms3/ANnla4t4hI3MRE2V+h54pkWr6y93umt7QQ4AwlwTt55OD1NHtiHTka9zqapF m2AkYEZUtjjvzmlXVLYkRyShZSu7aAW4zjsa0VVN2D2bJBewHGJGOf8AYag3sCjmR/r5b1fMieVn O+O72CTw3alJc5uiPmBB4UZ6/UV52ZTnjOPpXm4rWSM+pFKpaYndyV2gY981ZDEgHdx9K5r6FdBN zD/9VKiyPIFjQszHaFAySaIxcnZAjqIfDb22mPPfWN3Oe/2Yoxj47pnJrkr+S9XzG0e0N6kf38ZV 4v8AeTGR9eld7wq5UPZmE+l+INdYRNiOJjymcD8qzrjSLfSXkS4ZJJl6KDnPPt0rpp00tEaKyRXk nBzsjWMH+FegrR8MaDceJNZSzgbaq/NI56Inc/rXbZRWhN22e5WehWWmaYthaQhYQME93Pqfeucv Ph9az3vn28rRoWy0eAR+HpXHJczubwqOKsb2neG7S1017KaNZ4JB8yuM5rzHxf4YuvDF79ogBexl Y+U/Xb/st7/zrSn7uhlUlzO5hJM0qLLGG3fxEdjXtfwn8fSX7poOszF5AP8ARZnPJx/AT/L8qpro Q97nraqKdgCoGLxS5oAQtUUirIhSRQynqrDIP4UhlK20yysbmee0t1hkuAolK5w23OOOg+8enrVn NADW3E9j6ZNN2sB0WgAwe+KTGOc0CFHXmuR8W/DzS/GGoR3l/c3UEkcfl/uSuGAJIzkHnk0AzJtP gx4VtpQ8zXtzj+GSUAH/AL5UH9a67S9D0rQ026Pp8Ntxgui5c/Vjkn86GxWNDerj0Pp60gkCnn+d AxXvIrW3knZc+Wpc89gM153pV/8Aa9JhtDk/aNVjyM9sAsf0FNCZCNSW3nu72IP9rVLpro5PBdtk a+mcnP8A+qpLqS30qxu9Pk8zyBcWiy7Wyd2wtIRn6D9KdxWRoSatp2k3yLHKRAmlsITJkly7bwOB 71e8LXDieYFMCKztYm/3thYj8NwpXCxm/Ei91a30q3vtIu3t3hkKSDqrKemR7EfrXmT+O/EMEZe4 vcKCMsrN/LNTexVjvPD9nruvaR9uttXaRgxDQfbHiYemflYc1iax4i1LSdRezkl1FZEVS2+8buM8 ccj3psSSZnN4x1RiPLvL1R/19saZ/wAJhrPbUL3/AMCTS5ilFCjxlrQ66je/+BH/ANal/wCE01kH /kI33/f/AP8ArUczDlQo8aa2XVV1K8yTgZlH+FWT4m8QjldVuj+R/pUubQ+VDT4s8RJjOp3GPXap /pWR4jv9V8R2CWWp6jcvEjiRQqgAnBHOBz1pKo1qNQRzN14ammtIYkvC/lZARrZVxk5+8OW/Gsq5 8MXMA3ockdSBitZVnLcIxUdjZ0bxbf6ZAtpfRLOqnCyOSCB6E+ldQmt3jKGWxhZSMgrLwf0rzMRT SlzLqexSzWdKCg1exK2qzSRFTaqpYYJ35x+lUTI/dR+Vc1rHHjcZ9aadrWAyN/cz7YrNuLeddRtb yxiEMsEok3CMZJznOc+1aU5cslI4Lu1j1eL40XwUCbQY2YAZKzFQT3PQ1PH8aW34l8OvjGcrdfp9 2u76xAzV7Fo/Ga0VctoV23tHOp/niud8beM7HxZp9p9ls7u0uIJC2ZGXO09sg+oH60pV4uOj1Li9 dTz2eG4+by77VFyc4juTgfhmsnVdOluJBNHFezSKOskqkkjGPmJyayWIm1ZlQaizzsmRgQ2cZzz6 0ixyOMKpP4V1qyRSaL8Gi3spG2BsH14rpvCuiyRaiGvD5C9AzDI/H2rKVaC0uHOrnr134ysbOBI7 aNbqSNcFolKoT7ZrRsPFOkT2oubhlhLHHlt94e9cnOr2L9rFsvxeIdDkUEXcK4PcYofxPoaRbkvE 47bearmRXtIk0XiHRpIvMiulKg84Qk5qC+uUTULO5tITMsw8sbTgnr6+9aU4Sk7oTqRGz63DbXTQ XaSQuvUcHH5Uz+3rPdhZXP8AwE10qlNmftInN+KZZdUg+z2scdxA3zFZVAMbDHzIeoJ6H6Vy50+6 tIyZIZMDqw+YVhXoVGrmEnrdF2DQdSuLAXcKeZFnpkFvy/yagt7VnkO9WAHYqRXMqEk1cpLUnZYw pSWMNGeGA4P4Ec1WtNRm8H6ml15kVxG33I5ozkxkjBDevXP0967qaSloimrG14W8aW+lahdvcxu1 tKpMsUbDO4/dIBPb09Cap+M9YXVLoXdl4clg2EeZfyfLIVB5+Uce2STXS7EpM5DV/FU8sDQaU8tv G4xL8wzIPr1Fc55pOc9c1vGPKhi7gevavW/hBYxJo95ebf3ss3l7vRQB/U0p7DR6JtANRFkRsFlD eneucY9ZVJABIJ6Agj+dVNZ0231fSJ7K7UNHKvBxyp7Ee4p7CPCLSzmTXZNL82OOTzvK3yNtUHOM k9hXVQ+H9b8P3VvfNaSlYXEgmh+dOD/fXIFaS6MR9G6RqceraRa30RG24jD8dAe4/PNXd/vWbKE8 yk83jrSAQymk3k0ANJ5ozQAUp60ANOM0hxnigAJ4xTRjnNADWGOajYkdKAGbejN1NSA7Rk9BSEYn i28KeHrrYPmkURIPUscfyzXGvG2l+INRETEJp1u8iY7MUWMH/wAeB/CmhMVLOO1vl09WPlNNZLdM zZBkO53P86tLe2b6dqF1dwb7icT3sDOMhQx8pQPc49OlAiBtMhn0i4NxEHuTcQafAxJ+QqFQ47et b3h2+s5Zb1Y50M893LIsQPzBBhV/QCgCfxLZi/8AD15BjJMZZR7ryP5V4VqNiLiFotxUEjkexzUM u513gPWG0rxDCHciGY+VIM8YPf8AA4Neq674a0vxHHGupwkvGflljO1wPTOOntVvZELdnkWveH7X TddvLSBpBHFJhAzAnbgEZ/Os3+zY/wDnofzrinVkpNGg3+zV/wCeppf7MUjPmH8qj277AIumAMG8 3kHPSrRiwfvEVE6jkAmwDOTmkKDPQAVldgNwoHc0zbEf4c/hTvLuA17aGU5Mat9VBpyJ5ShY1CqO gA4qW29wF3Pjk4/Ck3sD1GPpSsKwnmqDgjn6UeaD91SfwouIcH45WguOpU1VwGhwexxQduOvaloA nGKaVz0wPxouFhJvCllG+2WKIHqcxH/Coo9Ftom2JFGgJxkjaKqVOS0uJJWF+wRJjaAw9jnFNNpt PyhW49ay5dQ5RDAwIUxjJ67TmgxAHG080uXUFBCGJ+oj57c1HJJHb83Dqg/2q0pwc5KMQskjZ8J6 fe6zcO+kq3kIcSTOcIPb3rtI326lp0agyRwu4Eqg7HI9D3r2adF0o2bM7nO6hdG61KeU8l5Cf1qE ShRx8x9q6E9BWJYpkLjcCOeRjpVPXJR5aQxk8jc3bNZVZWizRRWhS0y5uo9O1GG3uFhkS3aRQ+MH HUc+1T6HPPe6aZJCIrhVIba/DDHBH1zXNB3iW0y81qb2FVaPyY1baJmI+b+tEdhBPAyyILk2yEj5 N2Fz1x6f41pCGt2J7WKc7aeJxmNdyY2/KBiszxJ9qv7G4e0vmVzHho2Od478+9buKZCbRyPhfRD4 guXj8wxrGQHH8WT/AC+tdo3wy017QOupzQyjl2eMFUA4OR7HHesqtdxlZHfRw6nG7Z55qtlPomry affKVmQ8Y5Dg9GB7givY/hZE0fhEluN8zsB6DitXPmicso8raO3BEkZAJz6jis9dHSLO2aQgknDE /rgjP41mSObSIXVQzsMHOV4NXJeIsAZ4pt3A+ffErhPGeqEcD7Q/866fwrfNDp0l1b3N9NfmQKLW ElY41yP3kjdxzjHBzVvWIJHo0fxTtNE83Tv7MmuHglkG9ZginLE+h9aY/wAY53/49tAJ9N1wT/Ja xudsMLdXbIz8UvEc3/Hr4cRvT5JG/limP498e3IxB4ZKg947SXdj6kmi5p9WpLeZBp/ib4o/ZvLX RJT87ENNaMzYJJAyx7dKuDV/ixJ93TlT/t3iH86Tb7FxpYVL3pDvtHxakA/cov8AwG3FPEPxYkGT Ii+263FO7Jf1VbFO6n+JNvOkEmoSmZ8lY44lJI6Z4X1qVdO+KsyhheyKCMgtPEp/LtRdkqeGvsSL ovxTP/MWC4/vXCH+lPGj/FNR8urRH6zRn+a0tQcsN2EOm/FZfu6hA3/bSH/CgRfFqEcS20mPUwHN PUL4Z9GPTUvilbf67S7Wf6LHz/3ywpx8WeOoCftfhMOO/lRv/Qmi5DhQezLMPxB1OED+0vB+oxqO rR7j+hT+tSn4maUz4uLDUrUf7cGcfkaZnKivsu4268VeHtZe2jGrxQLBMk7CdCgfGflycVaS00jU bnU5odVtpzqMaptilVjHgex55AP4UamDhJDh4Qtzof2B7iUs0omecLyzYx09McVZn8N2E95YzsrA WShUjB+Vgv3Qfp+tIzsTJotrHBDETIwhnNwpZuS5JOT69aZp+g6dpc5nsoCkhXYWaRm4/E+1A7F2 QDGCMjuDXi2sWQstTubfHEUjKPpnj9KnqV0KdrlZN3HX8q9j0bxbp7aDbTX95HHMF2SKzfMSOM4H PPWtG0kZpanAeK9UtNV12W90+Jo0kADh2zlhxkexAFYYc54H5GvKqtObaNB25+47etL5j54XH/Aq zuAgL54PH1pV3/xMD+NFxillxzjNBdMcCkAm5fT9KblAT8v6UALkY+6fyowucjNAAUGeCfypNvHB P5UhBtOQeTj2pmWA9D9KADceuTRlweCfzoQhC5B5BpPMbouPbNAAZX6MoP0NJ5gB5RaYHoMmiK42 veTuPdqp3HhSO44N7Js7rjOf1r03STAgbwaREY4Lzb3G5f8A69Vm8F3jHm6hcDpkGsXhl0C5G3gu /wA8TQMOxyR/SmSeENSAyojOfRulZPCy7jIX8L6pEB+53c87WBrjdc8E+KJbp7hLJp4s/KI2BIH0 rfCxdCfM0TJXPSdK1vSdN8NaVoXl3FhEcC8eWJlJ4ywz7nj6VvWeq6Xr2vvDFeQrp2mqoihV9olk YHn/AHVHA9ya73PmdxJK4up+A7G9jZ9LumtpGOcFtyH19/1rm7zwLrNk6JAq3atnDRN0x65xilzE 2sM/sPWoBtXTJ2YDshI/OsHxNpWr2qwXOo2v2ZZcomTnp1yO3WoqO8XYcdHc5ye5kgtLuSKMuwgY bY1J7dfpWT4S11bUyQXEhDSMCMnsKwgtGbbnVJ4z0+ziubDV5Wt5oP8AUsgJWXPParmk6zazzebb zoGKkHn7wI6EGt4shpmXqbnz2dCCuO3aspr4xN8zEqeCc9Kq4ktCDTdUfQ9XF1CFmgk4kQ8b17iu mTxxa3FyEcOqdjj72Rg5+o6+4zWNWm5PmR3YeqoR5WamoXW60tL24t7aeNkCkvECwGOn4VueHr5/ tJtp0RPNjMkJj+66Djj3HAI/xFaLY5JNcx0Ecyofn4HerGQygqcg96BAPaoZ3Kgc8A80AfP/AIxs 20/xRMwmW4a6H2khWyY95J2sfXv9CKt+C/Mm8S2FsXystzGGUdCAwNaR1jqOSSeh9I+FrW3bQIZR bxbpZJX3bAScyseuK3EGz7ny/TisQcmyTe3difxo696YhaOe1ADgD6H8qXB9DQA1m2jk4z71G08a 9ZEH1YUCuRm+tVPz3UC/WQf40xtU09fvX9qP+2y/40WC6GHW9MT/AJiNp/3+X/GoX8Q6OoOdSt/o Gz/KnZhdEJ8R6SfuXTSH/pnC5/8AZaaNbtZT+6t76Qeq2j/1FKwriS607EJb6VqBUDqY1XP5tTP7 Svm+7pdyB/tzRj/2aiwXYxnu5h+90yDB6+ZOD/JTUDaLZ3XN1ounN/2zD/8AsgoK5pDToWi2Y3LA ll7wzvB/6CwqrJqOh2PXxIsOOz6isn6OWoSbDmvuV38e+GLVf3viSKbHUBCx/wDHEqjcfFnwtC2I p7q4I/55W5/9mIp8rERH4mW9yubDRr6QHo0xWJf5muU1m+m1TVjdyWyQibAZEYvtwvUnA9BXPOpG A0iuIEXoR+NKRj+LA9q4ZVJT3HYbtIGd2RTeSMdfxrJsdhCGxnp+NIS64JGc9+aVxWE3OchTj1pc SfhSuId+9ByT+lKDIB1BqrhqG9weM+3ejzCRj+YoQaibsdW4pCcDhs/Q09B7iZPTeR7ZpvX+I/jS EHmHP+OaUMpPPGPagELlRxgU0uAcYHqTRcYwyArnGce9NLp0KnFFybh5qgAbCefSjzM8LGOKYz0k arbBf9ao/wCBDilGp2wGfOX869bmQCjVLY/8tV5/2hT11CF1yrKc+h6UcyCxItyuODmpjMrAYb9a q4WAyoTw1IJV6bu/XNACMYyuG+YHqDyD+FU5tE0m5OZbCBmx1CbT+YosBW/4R6CI5sL6+sj6RXBI /Js1MkfiS1B+ya6k4H8N1B/UH+lO7RPKTJ4i8U2xAn0q2vF/vW0+CfwbFQal4p0/VLB7PxHod/BE TyxiJCH1DDIzTumS0QeFT4H0uS4azvxPNcqY3+2MMhD1QDAGD39a574p+BtP1HSINX8I2tqJrMHz re1RR5idd20dSP5UWsrBd7nhl0JZmMk4AxnhUC/oKZDqV1bHEEjD09qg3WqNu18Xny0j1GJpSODK uAR+Henza5pk7mKOSQbjwzp1NUJoImhlbb9ojKnkfN3q/p9vF5uWZHYcjDdKq4nFnSnVbS50f7K9 xFvRuF3j1rotPvJItJtHBKm2lMibh1DKVIB7jp+VBNtSceJBNLskRl9wM1s6PdssjwnJjPzJkdKk ZtBhiq15IkdnNJI2ESNmY+gAOaBHzTeao+oiBCFiSBPLVVUAkZJJJ78nqa3vBFu9z4s0+JJ2t2Mo IlQDcmATkZ78VtB6FOx9J+G7a+uPDWnzNqToZYFkKx28agZ544961P7Lu266pd/8BVR/SsibB/Yt weupagc+jgf0pG0N8/NqGpD/ALbY/pRcVhraNAB+81G+/G6xUTabpaf63UpR/v32P609QsiJoPDa f67VIP8Ageoj/wCKqA/8IWn39T084/vakP8A4unaTF7pDJe+Akb59S0n/wADQf8A2aoX1z4eRD59 S0k/9tN38s0csw90rv4w+G0H/L/pxI/u27t/7LUL/Ej4dQZC3Fu5H9yxb+q0/ZzC6K7/ABf8BwjE cUr4/uWKj+ZFQN8cfCUf/HvYX7H2gjX/ANmp+zY7lab4+abjFrol3L6b51X+QNZ0/wAb9Rm40/w0 oyOryu/8gKPZpbsNSjN8VvGEvEWj2sIx1ML/ANWrOuPiN41kB331naj02xLj88mi0QRi3vjfxQwP m+J3H+zDIR/6CKwrnxNrV05E+qXkqnrunYg/rT07DSRSM88znczuWPfJJrQt9E1S6wfJMSf3pjt/ Tr+lZzqqK1KskbVn4ThjGb24Mzf3U+UfnWzbWVraAfZ7dEI6MACT+PWvNq4hy0QyzuYnOM+5oEvY xg+pzXM9RiiU4yFzjtijzhk/uh+PegQocPnCqvtmlBBOQq8dKQAUGfurQVXA3EDgUWAQqONqjPc5 oCAngCgYwwnkgkAmkaPGB5pI78U9xDGgG7Ikbr6UCIBcMx/KgVhAn+235U8KnGWJPuKLCsIwjB5I 646jmjfCqnhTzwc9KLAN82PJ5GPpQHjwOM/hSGmJujBBAb8qCyMAecfSmkAxii4Clun92lVgR0Yc dTS6hYA3qrEY46UwlNwO1xiiwWHqeQAXHHXNO3t13scDpnNCqNC0JkuiowcMf9qnpdug+WNd3rk1 oqzGSDUJEOdhB9N2eKsLrsqoAEZQBxzmrWISF0EGuzqcrw3fOaX/AISOcuCcKTw23PNUsSIsR+Kp I1IlG/PQ/wCRTl8Slm5eRQf7p5FaLEIZaj8QOQCXLL1JHb8qtR+IMqhwXLf3emK2VRDLB11I1BMU hB9COani1YOWYgrt6etXzoLEdylhdj/S7S2lB/56RqT+orNuPDmlT/NYxSWMmQQ9tKy49eAcU1Ls Kxlar4BtNVtXh/tK5j3HO6aJHOf94AHFeR+KfCl94VvvJukEtq5zHOgO1/b2PtTumNaGTrNlBa3i fZMiGaJZVHmrJjI55H8jyOh5qW80jTE0O1vtP1Zrq6dgJ7QwFGhOOxyQwzn07Vdirss+GltJ754t QVXR4ygVvU9x70++spPDF2JYp1mjlJCepUdCe3/6q53JqfL0Z2uCdBTW6L3g+w0rW/EwE4kSIESe STnzG75PZc8+vavWpbZtTnSKyXdBAgj3J0GOwrfocTNC1sVtAERB75HNPT91eljnpn60hE0upwqP LMwiZjwzDgfXFcz4s8Tx6FpbSXd1Dezzgpb2ca/I3HLSE8lfYAZziqRO54zCVmy+1QWYscLjr2Ht XX+Ak/4qqOQf8sreeT6Yiatl8IPQZJq/ihbqRLTXHht1ciJP7VRQqg8DG/j6YqxFqHiKdwLrxCir jtqy/rh6qLSSMy39l1GUZ/4SC2YEfeOpbh/M1HJpMhGLjxJpq+z3ZJqlLyJaKc2jWCnMnijT899r s1VjpmhD7/iqEY/uW8jf0qm5PoCQ1bDwyhJfxLO3+5ZNz+ZpjReFQcHVtSk/3bdRn8zSvIZIi+Ew wBk1mQ+gSMZpDceFIzj7Jq7/AO9Igz+VT7ww+3+GhymiXkn+/dEfyFDanpIx5PhrP+/cuf6U7PuF ho1iFP8AVeG7Mf76u/8AM08axdkAwaVZxZ/uWuf51LWgK1xG1PW5Gwisme0cAX+QqN316b7zXrZ9 mpWRehBLp2rTHMlvdvn1VjTo/D+qyY26fc8/9Mm/wpNhdF+38F6tM2ZLWWMe6HNa9t4JeIKZbW5m Ynp5ZArjqVJbRRXMbNpo9xbR7bbTJEx3WA5/PFWF07Ue+mztnpiFq4ZQqyeorokGmX+7nTLo4HP7 puP0qaPSLx2AXTLsnrjyj/hSVGfYfMiT/hH9TkY+Xpl2c/8ATFuKZJ4Z1QZ/4lt1+ETUvYzfQd0M HhnVsjFhdZ/64t/hSr4W1nO46dcn/tnin7CfYV0K/h7U4mAlsJ0z6rjNNGh6getpL+lP6vN9A5kO XRNRwB9jf3Jx/jQdC1Loto/4sP8AGmsNUFzIX/hH9SYYNs4/4EP8aUeHtRx/x6v/AN9L/jT+qzDm RIPDmoE48hgMeq/40Hw3fj7sQ/FhVLDTFzIRfDmogcwqfq9OHh3Uc/6qP2+eqWFkHMiQeHL1lIMU Y/4FSf8ACM6hv+5Bj3PP8qr6tIXOh3/CM3+OFg/z+FNPhS9J+7B+Z/wo+qyDnQn/AAiN4eoh/wC+ j/hT18HzkciLPsxoWEl3Fzorz6LbWbbLm/tIm/uNL835daVNEabH2dZ5VPQiBlH5uAKawcu5XNYf J4alSPdcOkCDkGV1FQLokUxxFdrOR2giZ8fiBin9Sb6kuokTr4SuJhhUce7AD9M1Ru9L07TyRfax ZwMOqb9zf98jn9KawN3ow5zG3Et047cU4Y3AM2Pw614w9CTagfBc9OOKdww4cj8KY9BgaMnAc8eo pN6Bh8wI70g0GNKhH3uaQOoxufoegFMV0LJInJRx9KYZCTkPTByXQazuV659BS+ZIF+8V57GrUmh XEN9IqEGZvb5qY1/KQqrM3t83GatVJdw5hBqFzxmZtvbmnR6ndRkqLqRfXHT9KpTfcnmZat9R1N4 t0EzsD1+c/y/Co7nVpL2zls9SiW5hlGGSTnHuPQj1rVTnHUd2ea63oEunzNJb5ktyflYfw+x96yI 7mW3lDxO8bg8Mhwa7ac1ONzZao6G08XIthLb6ro+n6gWRljuDCIpo2I4bcmN2Pfn3qhFqiXNqtnq QZ4A4ZWU/Mn0z2qpxutDooy5ZWezG6Nqj6JrourLyplUsoWZNyup9RXpdj8StYe1i8nRIBg/KVl2 Iw9MEf1rSC5lYxq2i3Y1YviF4geLc/h61dzyu28Ax9eKpSeK/FWoTKBpFnEmejTH9cVqqZhzohGs eJLxxHKtjp0R+88UZlcfTccD8qxR4am1bUFF9K88Bcb7wfLg/wB0sRwSB06c1FWDjC6NaE4Slyss eJvAA0exa80xnlto1zKjfeQf3s9x6+lL4BZbWz1m5cAvHp8p3nOQCVUD8dxrOFTmga1qXs5eR548 hdy5J3Mck5pm5getdSZz2JoruWL7khX6UGffyx5PetFIloaxOM54pm4AnmqbBC+cij5gefSu78N3 PgmK0BvNH1TU70rlUeVY0J+i5OPfis229EN7G49xPc3STWNnp2gqn3BaoWlH/Agc/m1aFug1C+it 5tQv9Ru5CFSMy/M3/AVGf1rJ6bE6noumeBbOxtftOsNtAGWjEjEL9WYnP4VqWelW1yFax0y0t7ft NLEHd/oMfqTWd7jsQLcWdzfvZaLbQXk0XE1y6Dyovb3PsK1YdNVFBurh5m/uqixIPoqgfqTSuW0k WRDDEuIQE/A/0qItOCQrAj1wf8aCGxmLg9ZB/wB8inBpwuNw+uKegXY0m4I/1h/AUxoJHHzMTT0E NNqxPLE/U037HnrRdCsH2KlFiOpp3Cwv2ZgMAkfQ07yZcf6x/wDvo0roLB5Mn/PR/wDvo0oil/56 P+ZougEaB3GHdmHoTTPsQ9KOYLB9jHpR9jHpT5gsJ9jHpR9jHpRzBYDZr0xxSfZB6UuYLB9kX0o+ yD0o5gsJ9lHpQLUelHMFhfso9KjnSC2gee4kSKKMbnd2Cqo9yaOYajd6HF3Hjd9U1E6b4N05tSnH 3riTKxKPXHHHuSK07bwhqF8PM8T6xNcFutraN5UI9iRgt+lPmNpQVJWe5Jc3Hh/wsPJs7SIXA/5Z W6jcP95j0/E5pltb+INcAllddJtW6BFzKw+p5/Hiqv1Zzy/EuNoGjaTbyX2osjLEN0l1fSbgo9ST wK888S/Gmxs2a28L2YuivAubgFYx/upwT+OPpVRvIah1Z5rq/j3xBrTN9u1KYxt/yxjOxP8AvlcD 86wjfSn+LrW8ZW2KcT08SFQFySpHWhjD/EWJ9MdK+Q0FoPDJg84x+tMaSNTwxagHYaXU5wce9LlM 5DAnPAoACp3ZboB0xilMRdeM80WCwgiJAKLxmiRfLTORkHFAWsVy7YJEm3AzimGRufm4YYxmjUl3 ImGE+/kkjkdqYYTK2Y5dpB9eaqJSVyymn3MigRruz0G8H8cUJZXQl2Yww64PatFF7lezdhjNeWjY yQCcfK1WpFuxAkz4aM/dbePyq7S2Fyy2M7ULkw6fcSKqhljJXK5//XXCTXP2xsvZwiSU/KyKVx9M HH5+tdGGTd2xw1ZdHhyeBHbU1ktcA7Syjax9ASeT9M1e8O67BoJcx6fFcv8AxykAuB7Z6fhXQ253 R1UqijK7Rj63dWupaxLd2EP2dJCCUx/F3P516BocEFvpMMT7tpQFtxzknqRxmuqhHuYYmSeqLiQW cZzC20/3Tjn8xVopvKr5gjIOQB9K7eh56vcjEbxxqruHPqKVvsdrDLfXdoLtoE8xImHybl5y3sMZ 464qJ6wdjSlZVFcw7/xvJqF5BGIhdadE/mXAlXb9oPU5weF7AdhVrUte8Lx+ENSk0NJrK+volhez kYyKF3gkqxXjp0JP14rz4RtoejVk5u55nv56UoOTXUZCkZphBBppiaDJxikyaq4WHwGETIbkM0ef mC9TW1petW1gGHlv8x+8Bzj0pcysJp9C8/ieBomWNpUJBwdvT9a9U+Dmo+HtL0WfUru8jF/LIY/3 hwyKMc/jn9KmTXLoKzR1WseM9I1LXrSw/tBFtV+eQhuGOM4z+GPxqv49+IVnp/hSRNHvY/tE7CEN Gw/dqQckfgMfjWJpTjeauafh7WvD+i6FbWUOpQuVQNLJvGZHI5b/AA9sVpf8Jdoh/wCX+H/voUWY pu8mw/4S3Rcf8f8AD/32KT/hLNF/5/4f++xTsyGH/CV6N/z/AMP/AH0KP+Er0b/n+h/76FAB/wAJ Vo//AD/Q/wDfYo/4SnR/+f6L/voUgF/4SnSP+f2L/voUf8JRpB/5fYv++hQAf8JLpJ/5fIv++hS/ 8JLpWP8Aj7j/AO+qBB/wk2k/8/sX/fQo/wCEm0r/AJ/Iv++qAsL/AMJJpX/P5F/30KP+Ek0r/n8i /wC+hQAn/CSaX/z+Rf8AfQo/4SPS/wDn8i/76FAC/wDCRaX/AM/cf/fVH/CRaX/z9x/99UBYP+Eh 0z/n7j/76pP+Eh03/n6j/wC+qBB/wkGmn/l6j/76pP7f07/n6j/76oHYT+3tO/5+Y/zo/t7T/wDn 5j/OgQf29p//AD8x/nR/b2n/APPyn50AJ/b+nZx9pj/OvGvFPjGbxn4ji0u3uVt7AziKFC2Aecb2 9T/L+YztwkY8zlLoep6AdA8O6Wllp0sYUcySE/NK394/4dqreJfGdrZW629pdxpLMDmTd91fb3pp HLKTlJyZm+GDpDZ1C8uIpXDfu1JBGf7x9TXWnxDpoBLXSep5psyS1PnDx/8AEG88Yao6mYw6bC5F vbBuMf3m9WP6dBXGNImfvj863i0kbNMbvTH3xT1aIt80iiqTjfcl3PWQY8DofYUzarH5Bgjqc18o AeUA2SeR3zTNu4hlYe49aLCsO4KElckZ79aaoG3dt6Giw0iUnGc/MPUVRudYtbbcsrgMOqjr+VNR bGyjJ4pso0Hls5PPaqx8VWzqS4YgE4GOtbfV52uIq3PitCuy2hPHdjWefEt1/cXGe1bRw2mouW5Y TxM2wgwnB4ABqS38Q24RxNHIuem00fV2Wl3Niz1nTZInkW5McgGcS/L0H6/nVy28RaftBtMmVuGz Jx+RocHFbFuSS0FjuUuZS0wbaG52AcD3NWdR1CK4jSK3SRYoxjrkH36daz59zJyuiqtk19amNiQs g2nPXmsbU/B13YpbSQSw3MVucnbkP1zyv+BrooaLUqEWlc7rTdathYIEuIn8wESQyorr+KsKzPET WD2Ny9mlqs+wlQkSjn2wOK0V7mh5rbaTd3UgFvaTyknpHGWz+Qr0bTYAkKHaykLyHUBl+uK7qL1M K2yL0sTSp8krKcdgCP1FYWpzSWMIa3mzOW2hjwK6r6HKlqaWnyyy2qefJvfHUADNaMljJqFlJZxy CKS4Row7dFyMZNKTshpe8ZNr8KtTtkZGvLKYH7u1m/kRWbc+E73Wrq40fSTCiaY6i7mmbiSUkjgg HpyPw9q4U9bndqMX4Qa0et3YD/to2f8A0GrCfBvVyMtqNiox6v8A/E0+cGSx/BnU2Izqtn+Cucfp UjfBi8XAfWLb/vy1V7QnUlHwUmxk65B7AW7H+tZ+u/Ce60fSXvodQS7EZHmIISpCnv1PSj2nkGpo w/BNWRXudcAJAJEVtnBx6lh+dZnib4T3elW6z6NcvfoqFpQ6hCCPTk9v5fSlzXK1Mrwl4ITxVbSG 31JYbqFv3lvICDjsR6j+VdE/wk1W1RzZX8ckijO3fgH65obSJuyCX4d60hwyySY5zHhv5Gq83gnU 0GJYrlhgH/VE9ar3X1FzSXQqnw1c2/Ba4UKOQyninNoboAXaZcjIJ4H8qfL2YnPyM0RL9vNrJ5yN jKtvBDD8qfLbNFAsiJcSOeqK4yv6UuVhzRIRcs86QS294hc4G4rj88VpfYIgObiYH044oUZDcooF s4GJAupwRxgqP8ac9nCg5vJuOuFH+NJxaFzob9miLgLczt33bBgfrVuPTNOeQRtrywscZ8yJgAfq BUtND5ol5PCySwNNBrcMqqf4Mkmq8/h+SG8S1e/YMejFflrNzs7Glla5MvhSVyoXU1bJ5wM4HrTP +EVm8vd9vYfNt2lean2o7BP4SuIlBGoeZnORGM4qIeFrppNovH+pXAp+0YWJH8IXakhtRUAd+o/S ov8AhE7sk7NQVvcCq5mLlQv/AAiN91/tAD8Kb/wiN/21BfyNLmYcqKV1od/bX1raC83Pc52nnAxV i48OajbRB2vC2SAFRSWJ9h1NHMNomj8Mam8aut8jBhkEHqKdL4d1KCJpHvBtUZOM5o5mTyBDoWo3 ECyx3iFWGQd1P/4RzVc/8fS/99GnzC5dBD4d1Xtcr/30aQ+HdVz/AMfAH/AzT5w5CN/DmrEf8fI/ 77NUJPBN/v8AMSRFbOcgnrS5ikmiUeF9dUY+0Kw/66EVHL4Q1ac5lYNjoS+aHJhyoSPwjrMIxFNt HoHpx8Ma1g/vifpIaLsOVFCTwFqEjEqFBPvUDfD/AFTt5Z/Gkpdyhh8Aatj7ifnTG8CasDxED9Gp 8wHdM4yRuzim+buJAA5rxTnQGRkQnB57ioWmdQ2eN3Qf1oGhBPImGAJ3cZFTCbZGSTgsOhPBoRSZ FLcEKF28HORnk1nXVtbHfmLJYknB5z9aadthGLPoit8sEhBznDA9PTPrWbdaZeW5+aItxnKnNd1O stpDtYokFSQeD3BpOfWuoEGST/8AXpwlweRk07ALmRz1OPpxU8ZhQ5YsSOeKaS6hYkjupoS3kXck KvwQGIzWpY+JJbaIxzEXA6hiMEVnOlGQLQ3NM8W6c0oe+WaNgcjy8EYrol8RaFeAKl2iFgMg8H9a hUXFFpoVV0eR1l8x5izYCptJJrRgWPzMDTcqTjb5igj6+lTtoNm5BfKFMcWnzAoOgAAPvnvXK20i zTyyCPaWcnC88E9K66G5hV2RLdJG8fzEkHsDiuW8QaSbI6bfkp9nuDMvlFMhSu3Dc9c7j6dK7W7I 50tTV04sYEMaLsHcNmr97qz6JbLfxqrsjqNjdGBOCPbjNKpsENzuLHWtPv8ARX1SBgsUKMZkkPzx FRllYdjgfjWD4B0sy+GG1C/UCfVJ3uHyecE4A/Qn8a4Wjuua3lmGcRnaApwcyfMfQgYq+k5K4aOU jH9wjNShskErhRiFvXkjn9anDE8gKoPUYpisADA4OBUcqNPE8MoRo3BVlxwVI5FAiO3BhhEDvxEA oLHqAOP0p/mIqFi8aDrywphscH4u0W1tZ/8AhIPDN3b2uqQne8SyKqzjvx/e/n9a1tD+IGj6jpSS XswtrxVHnQlSct3IwOlNJsm6RZk8baPHgI0joVxhI8YP4kVUl+ImmBisFrM+OBkL+vNV7Nic0Z15 8S2CFbSwxjPLSf4Cs+X4kX7R+WIbRVznDqWB/M1XsxOZkS+M7ia7WRrXS1Kg4b7JGSM/UGsW41IP PvWRcHJbC4/IAVSSROrKk97LJINr4A6YHI/Omi6uQMeaz/7yjinzPYOVDke9uJisQdmboFXJrYt9 A1S8CGWNIQON0h5/IVm5W3KULmgvhSRFyt3hgMZK9P1qtL4MuGbIuY2Y+uRms+dGnsyWHQ9bsUC2 kw2g5wsnH5GkubfxBIoW4E0m05BBBIPsRTXIxWklZCtqGtxn9/bFiO72/wD9aoRrt9G3zRRjHYoV /kafJAOaS3Hx+JZkA3QqR7O39Sauwa5cyruS2uSD3VQwP5KKHBWGpXL0WsTFVEmlXRz1ZF/xxVoX tvMuZraeP/rrAwx+OP61la3UpMmURSLuhkH1BzUmH/hZenGRSuUYWsb08QaQ7bch3A2/hWvNGJtu /wA2NkbKvG2CO3b2ph1HR+VFEsaFlRBgAg8D8aGZSPvgj3NIRDaW32NGRXLIWLKGx8oPYVYJbdnP 4UwEDN06/U0GSQDoKADzXx90UwuxGCMZ4pgAPHQ/nzTGkXHVx+JoAheRxgJKwz6800XUiffkjx/t EA/0oAP7TIICwlwf4kG4fpmnrqAJIMMwI7bMfzoAd9sLAEW8v47R/M0i3cjH5YUz6GQf0BosBj7l zgv04oSeMDgrj3714ph1BrkbD8nA5OO1QtJuXPbrz/SgNyNrlCRDgZ68cflTJLmMkh2+6OaqzKsM 89ZPmALdOPapsBlG4nJ7BaEh8rIhDvbAnVecc8UfZo2OPOwV6EjitFC6uaKOmpBcaPYXYKkIW7Oo xmsebwm5Um3uEY9lbjP41tCq4OzJcShcaBd2m4yqGA7odw/SqOwBsBSfeu+LUloKzJRCxGScfWlE B9a0sIDahs8Dpwakjt9hGC2euc8UWEWhtAB8tT65Ap2VJy9umB6E1orMg1tG8RfYGdFtLeYE9Jos /r1rtvD2u3Or3SWun6BHPKR/yzcoF92znArN0ovUpSaKfiXxbeySy6ZDELFI2McwR9zNg4I3cYH0 qXSGGyJwc5GCfUVtSikjKo7st3ZGCcd+lQfEBBDY6FbqQWijkZkzjPCZ/U1cnsRHqzL05gmPJHBP rg1X8d6jPZaFElvK0RuX2Pg/eUDJH0zinUegobnOWPji+i0jUNPW3g3X8SxSXPIfAPJ64PBI6V6R b/EjSLSxgtLK2kZLeNUQbwOAMc4zXKo3Oxu3Qjb4o7WG3Tcj1M3/ANao5fipM5Pl6bEAezSk0/Zi 5is3xVvyDtt7VT64Of51Vk+JerySbhJAgPZUGP1p8iE5MrSfEXWGb/j8Awf4Y1H9KrP471aRsvf3 B4/hbH8qpRiS3JlCfxJcTtmRpJDjGXcmq0mtTuOBj8ad0hcrI21a4x8u0frVNrqZZzOuA3X5aTY1 EedRu2QNIxGR0B6U37VIesr/AJmjmYcqQ0uW43Hn3oyMdfzoHYBICfvDPtViC3muG2QRs59FXNJu yGbVn4VvpWH2hkgB6gnLfkK3bXwvYQEGVXnYf3jgfkKxlU7FqHc14oIIFCQxJGDxhRjNTjC4GM1k 2abCgkcYxRuYnOeMelABuJ70m7HGGPPWgBV69Dk0pwwAdQc9R1oAia1tm5e3hP1QVIkcUYwiKg9E AFO7FawuBnOetKCRnB570hjXijflowx9SOarXXk2Nu0808kEa4ywYsB+HP8AKmhGDd3E+palpz2M V1NHDKWaWS3KKAcc5/A+ldFumVcvGrf7jUeQhPOYMVMMyk/7Gf5U1rqFeJJAG9GUg/qKYDw0YXcE YjGQdp5oEq44Rz+FIBrTAKTsk49FpqyyMMpG59M4H8zTARzcdFRB9X/wFG2cgnfH9NhP9RRdANKy NnM//fKgfzzTTbf89JZW45G7A/TFO4ALOIjmPdz3+bP50q2yqfkRFXHOF60rhYRrFHX5A0Z7FDjF OW3mXAYq4x16Gi4WGkxocSb09yOPzpyrBIuAyvg9iDijUDmogJiE3gY5O48tUjCLI3qAQfu+teRY w5eoxJEb5TuIJyD3NKd8xVfKYgGqQ0mwMaRna4K4PsT9KjeSFQNoJGeoPWtFG9jeyRTZ8uzpH06E nFOS6uQ22QjHUda6Fh1JasbsQyyM8gO8HtgLxT1sbyYZDqAx43NXTSoRtYylLlRKNP1AOQk2OOue KkGlXAA8y7CA8HmtXhosj2o46Q5fMdwXI6lh0ol0maT5WETL3yoyat0OwvbdypJ4ajIJWNlY9Cr8 frWXdaFcxPtjcMOwbjNTyyjuWpRk9CEaPqWMi1aQD+6c1HJZ6hAMS2UyAdSUPFJSQ3G25Hsuh96J 1z/smkEkgbBH+NUpCsjpbDw3fxR2t/rNncW2mSOMzbcF19s/1rutb+I2heEtN/srwVDHJJt+accg H1J/iND1RGlzyWXVJ7y6eSWUmSZ9zOepJPWvR9EQraLHNjzIvlJHetqeqM6isO1a6+zWsszHlELA fQVwVrqF7fzNLcTyXDxjjzXJ47gZ6Vct0RDZnWaa8EgXysgZyQ3UGsj4jTfPp9qByEaQ+3IA/rSq bBT+I4iMHJBOM8VcMJtJhh8nH0rnR1sBOxHU/nSea2cYNUJWF8w57/hTllXuSMeooAf5q/3hijcM dfypiE3KBxml3jrSVgF3g+ho3gDIpgCyow2uPl9agzISTESUzgEjil1sBYhgknkCIHkduAqjr+Fb 9j4PvLn5rhUt1HXdy35VLkkNJs3rXwtp9rtZ0a4Ydd5wPyFa8MUUKBIY0jQdlGK53Js0UUibJ9R+ ApV6ck0igGFbOMketPDZOelIABLGnZ9+vvTsAqZZgNwHOOeKUgBipbOPQ0AI2QCVVnPoDUbToo/e wyRjrkgEfoTRYVxq31k3K3UXH95wD+RpwvLdhmOTePVEZv5CnZhcY12Cf3dvcOf+uLD+eKUXM7D5 LGQH/adV/qaLANMt6+T5UEYH96Rj/IUrLcucyXKKPRIj/VqNAI3hlcHF5MD6hV/wpi2koOHvpmx6 nGfyIpXAcbRXGCxkH+27/wAt1KLCNSCIIWx3K9KdwsKIWAwIIlPoM/4UhhkzwwU+m4/0pXAcI5AS GfI+vT9KQLJ2kH/fH/16AFZpRkME69iRTSXzgISDxwRTAUOq8lXGB6Z/kaRp4+QZQp/2lx/OhIQq uxAMbo/r70omfdnymH5GgBd8hPX8+1LubAyfyFMBoYjJLVHJFA3zSojHsdvP+NAGItsu0NHFMX9T zmpYYwrnzbcEnu3UVyex0KtEfdWkYIHmLGTztLUpt0IAOAQOCDzTVFWFpYesCLGVXYyEdWGT+tIL FGckBskdq1UUgHSaXCgwMHPYjiom0xAMmNhiq1AT+x0lbMSZB5znn9Kkh0lVcFsjJxyxxVKTQNJ7 lmPS12OSjBmHylWx39Kh/sSQSFlnAbHR+av2siVBEohNsNt1CXyPvxndj3xTlNlJGNkq9ccnb+ea ftJvZi5I9iV7eMAjYpz2J7VX+yqGyscYH0rNyb3LSS2BCVYhVVVHXC1FLd28BzPLEowfvMBUpDuS aXE2u3gh0pxcTddqY4HqfSu1g0DRvDMMd74nmhnuGcCKJhldx6cdzVqLTIlJHnHxH8d6prN5PpAQ WtlE+DGjBi+OhJH8q87ZOOprZEJE9hAJb+FCm4FxlfUV6Vps7IGCJNKnd9vAroprRmFXdFXxDLv0 i9OM4iOT254ridEjZ7p1D7cLupy0kiafws6KyE8N0G3jB/Wsv4gXgfWrZMfct1z+JNOrpEVPWRyx kUfMrc9hVkSswBkOWxyTXKdbF30m/POaq4g3j1pd/fNACbx1pQ4A6U7iYGRR0yKNx6gn8qQxfMI6 fypDIzAjbRcResdF1G9IMFq7qedzcL+ZraTwtqMUOHjSQk8Kjgioc0mVZs2dG1KxiL2ttYSxzxcS rFHuI+vOayPEnjh45TaaI+3H352XkH0AP8/yqHG71LT0OYj8Q6wJfMGpXOc55kJH5dK7zwt4nbVy ba92C6RchlGA4+nY05JNBfU6YEA80G5hU4MsYPuwrIob9pjxlG34/uqT/IU0XbE5S3kfPtjH54oA in1CSDG+0dQTy5IKj64zT455p1zE9vj1BLY/lTAl2SsRm5Cg/wB2PH8yaZIFXPm3U3/AQB/IUrhY i82zIx+9c5z8zsQfzNOU23/LKzhz23Lz/Kndi0J0lkzxBGvtilVY3bMluoJOOAKVxjhDhv3byL/w Mn+dI0dyTxMGB7MuP1FFwDdOi/NCT/uOD/PFMEyH/WB4x6Oh/n0oETI0bEGNgfWlwoODQApKkZVa QFsdB+dIYpLsACeKZgjJ689zTEHQDJ+tGAe/0oAbgHqP1pdnoR+FACeX9c+tIEwfvUxDGgjJJaME +uOaTywv3C68dAxpoAxNtwrg4/vr/higPMOJIo2x0KN/jQAnngf6yN199uf5UvnQA8uq59eP50AR 5c/62c468UjTWttG0kxO09fegNjPEMd/deen3F7leuPT2rTWMHHXA6AdKbBDiCMjYoI9RSbm25yB U6DHB5ACA2M9fejL+uc9eaQFe4tJZwSl1LAwHBU5H5Vk3P8AwkkC/wCj3Szov91QD/LmrVupLutj OTxHq1ncAXwIA6h4sH+laqeKdNlOZjIp/wBtM/yzVOF9Ygpdy/a6nY3R/wBFuI2JH3c4P5VU1K/0 mIEXckTMOy8t+lQou5TaOen8TGBwdLEu0dVmYFT+Haq8vjHUmJIWKHjHypn+daKHcjm7FCbXL66J Et5Kc9gcD9Kqr8z5Y/n3q0khO57rqPiK28CeBrCfTLCJZryJQoXAAO3OW7mvG9U1nU/EOotd307y y5yCTgJ9PSp63JS1KZspXGVO73xUdzaS26B2AZT/ABIc4+vpRzIuxq+FY45p5lfgkAA4/wA+1dys SopiZgyOo4QkFTXTHZHLU+I5zxXdfY9JaGNifPIjJY846n+Vczo6PzKh4YlW47VUtZoUNINnTWcY Louc88GuY8aOsniJ1Q5McSKfY4z/AFpVW7BR+IwEQhs4JqcBjXMjrFwcUAcdaBWFxz1o4pgLk0m7 mi4Bupd/vRcLCh/elSVlYMrEMOhB5FAFpNUvY33JeTg+olP+NXbbxLqcMqk3krKGywYg5HfrmpaT GmytqNndCCPUHVlgvXbY2/JODyDVJNMaeRUhfLMcAH1oYLUs6fpIkmkF2CqRNtK5wWb0zVwQxaPq tneRq6QGTDpk5Hrz16UmF7M66PxBo7ghbmRR237j/MGrMOrWXAh1NAO4baP6Cs3FroXdF2O7kkP7 m6tpAfbOPyapfNvFx+7ifnsxU/yNSMXz5QcS20hB67WVh/OsS7jlsrj7TpxZdxw8ToR/PqKaEzat byC7jG1tsndSeR9KtKF3ZAPH96k9AuSADIwB1yKUjHUDmkMM464oOB1wKAFDdRkfQUB8DHUUAICO 2ee2aMg8flTBkbxRsBujU4745pgtwMmOSVPbOR+tCEBEwGFkRv8AeBBpDPIpAkhY+8ZDf/X/AEo3 AFuoGbb5yqT2fg/rUm4nlcH6HmmApc7c7OT7U3zBnaeD6GgA3ZHJ49RT+MZAOKQhu5VIH49KaZVz hTmmAF8/4GjcDwBn1oGBORkr+lMIVSoZuW9DQApAUZyAB1PpUD3kKpkFnBPG1CQadwIPtEkf+uhb A7ryKyZbtb+8WOTCxZx1wB7mqS6kt9DciTZEqwDbGOmOAKeT6PyO4NSUAKgfMxH1NSKi53LzmhgL nByQOe9OxnkYzSAGKKAoznHPPWm7sf8A1qAGOonUo6IynqHGRWddeHdOnBYwLGfWM4/ShNrYTSZy muaQdPvP3EcvkY4cnNUIdPvLtC9vbySKD94Lx+dbqWlzPrYjnsru3GZ7eSMDuVNVDIoJBPPpTTuA wsG6ISfpT7a3nuLhYYdgZjgBnCj8zgUDPWviFBcX/hHQ7SzCTPAgMhhcPj5cdq4aDTpYYs3EMkcK 8kuhG6obEtHqW4NOv9UX/iWWk0yr/cXgfjWZqEF1aRTw3UbxuFw6OMEVmkaXRN4SBFvK4yAzYP4D /wCvW5LdyQzEZ4HQ13wV0jiqO0jM8VWtzexwtDC8iRhmdlXIXp1qjpqFNOSNQMn5iaa1qBtTNi0y m0nrnGK5rUNK1G+1S4mSzmxJISMrjjt1qa7SQ6KuxYvCGryYzAqZ/vSKP61ZTwXf8b5oVz/tE4/S uR1EdaiydPBL5/e3iL64TP65q3b+C7QKfPuJG9CpAB/MVDqD5CyvhXSEOGjlkz3Mn+FVpPCGmFTs ubmM/wC1g/pgUvaSHyoz5fB53kW94GH+3GV/kTVKXwrqSfdSOQf7L4/nirVTuLlZWbw/qoOPsMp/ 3Rn+VQyaPqUfMljcLjuYj/hVKaYrMrPFIjYdWU+hGKbtOfSmIO/c0+GXyp0fAbawOCMg0wZueKPE UWuS2otYHt4bdCAhAA3HGSAOB0FUdNlC3sTdgc89qlgkddqPhxbjQNM1m0PyyySrNnvIDx9PlK1z mvuifZ7Vi3mD5yCR8n6ZojewvtGapJHBwfpThIyH5hn3FWMeswPQ/nVqLULiH/V3EqEf3XIpAXId f1GNsrdyH/e5/nWhD4u1BBiQQyg9d0f+BFS4pj5mTjxVFIc3GnRE5zmNtpFPPisx4EBnC90kIbH4 0uQOYvWnjOzlYLckxHpuwcVrRa1YzHMN9Cf+BYz+dQ4tFJotLMkv3JFck8bTTvujk8CpsxlKbWtP t32y3MYOegOfzxTU8QadKxWGbe3oBj+eKpRYrpEyXsrnENuGU+sqj88Zp4a9bJK28ePct/hRawXF 8u6cc3KD1xH/AImgwSkZe8lznkoFX+lK6APswBOZp2z6ykZ/Kg2sZJBaQn1MzHP5mi4DHsbeRSHV mGejOxH6mm/2dCI9qGSIZ6IxA/Ki7QWITYSLwBDKp6eanP505YVQ4ksYmA/uYP6HFO9wBnsR1iSM joXjxipEgtJeUSNhn+EZpagP+x2wHESj0AGKQwwH/lmOfei4gNvD8vyAH6mk+zRKcgMAPR2/xpgI YYgBjOP98j+tIyxuoUIzqTngn+dIByiTBUcJ/tHOaybktYXeFkEkbnJTcf15qogzV2r0O456mqE+ i280hdGaI55AOQfehOwWuRfYby3+W3uA46gMSKYbvVYW+e0Dr32jn9KejFqiZdaiUD7VBLGSenB/ +vVqLULWR1Ec2CeACcUnFjTTHy3McZ/ezKB/dLc0w6ggIMSSScfwof60khiGa9Zcw2yIPV2A/lSr /aR+Zntx/s4Y0WQXYm6/+9uhHPof8aVFvzne9uoPXCk0tA1HlLplxLOqjr8kef51H9gOMG5mwT/C 4UD8qL9gIX0iBxiV5X/3pBiq03hexmHI+YnOeM/pQpMXKUpfCFt8zC4VFUdSSMVlW+gSLfLLbl7i CNwWkQADAPOCxGfwrWMu4mrbHq/h5XkkAXzMEDODg4rU16Bd0a3BDRnP3hxWT3DocpBq9rdSNp1v bK9shPOz5VPXOAMjPNVPiVprWfhm3nuY2iuMFVEgIbYQCM5578Z9au1iehx3hUFdILADPmMevbir 8zF5MjHUV6FNe6cVX4mc/wCIbx31iSISMsaqqlQeDxn+tXtOljnCoh6DjHpURtzs0kv3aNeEDeoR CcH06VqjeTlcZ+vSscU1dGmH2Y2Vp1XzDjA7UKzMmZJduR/CucVxnXcYzg5VpWx3AGKkijiCHIO0 nIGaLCJBEmOuB1xTzAoTIUH+f8qQxixyq+FhBGPXpTyhP3lCkDmgBQjM2cHH5c07a2/KjaT0zQA5 4xIgWXD56qwyDVGbQtNmJ82xhI7lUAP5ihPsFjNufBmmSkNArxeoVzg/nmufufBeoxxvJD5UoB4j WTLY/EAGtYztuQ4mDd2lxakpcwSRN6OpFMs7ny5Ru496vcSOt0rxZf6fot5ptvPELS5wzRyqGCuO jrnofeuTkmknuXmncvIx5Y96S7A11Hg8d6cCfc/hViAhm7YHrTx8o6k0CHg4709W/wBo0DF3+/Wl 3Ac8/nQICVJ+4KNqZyMjHoaBWFWSVTmOZh9ambUbzywjSO6DsHOPyoGhFvF6HjjuKcLlT6fnTEOF xjGGYHHY1PHqlzGR5dxMFHYSGk0NOxYTxHqcOBHdFh6OA39KsR+M71H/AHqQvxg8EfyqORFJl2Lx vgfvLUf8Bkx/SrMfjKycgvHLGfbBpcnYOZFtPE+mSNn7QUB5+dDxViPWrCVRtvIuegLYNS4yKuiw k0U2GR1bj+FsipA656k4qbAG/jjoe3rVeWC2Y5NshYc5VcE/iKAIzbMseYJpUbGQpkJ/nWcNUu45 QshDDoeOv5Va1E9DRjmuWUM0LnPPDDikaS4DAGEjA4LSDmlZBe40y3YORDbL7kk0Ge4P+suY0H+x HnFPRABClgXupX/IUoSBBvgjBI7lSTSb7BYtGTnAGPwppbHzEAc8UAP3Ky8kcH1pdwxuXoec4pDI poIp12zJuAPfpVN9GsmclQyHthuM072FYrLobw3ImiusMDkEir4W7Bw08DHPeMjH607pgroPNuow T5cUuP7rEfzqOPVgH2XMTQn/AHc0rJ7AW1lDRhlb5fXikNxlCDjOc57/AJUhimXEOXBOeMYpjSNu AVQuO1ICGWXZHuuCqKBnLHFUhezXHy2cRcf89XJVfw7n8KaXVg/IQWpdg97J52OgbhR/wH/HNV9R 1R4WWC2h80upDP5nEf8AvYHAp7vQNkY+oazGLeOGbULmaSMYJt5WGPYMaotr088QigadsfwGVmGP dic1eqFudP4P1Kz0yFxqtrI7FvMie3lx9Qc/hzVP4h+ObnxGsFmxxBDny0LFioz3Y8knufahO5LR V8NsP7JRU/hZt3Fa6BAhL4wa9Kn8JwVPjOLvo5rrXJkAwzSkDPQD/wDVW9o1jZ2168K3iSBgOhGc 96whbmbNp35Ejp1SNf3cIGF64pwVskgkEegrmxDvM2oRtATzD3y3b3pSEDF0BHsen1rnsbkitC5y 8ZGOCQcg/hSJHATkHHPc4oDQlEIyArZx2FOAKPu3n8qBj1IdcE/n1p20FSMg/U0gI2YKeeR3Oary ahaxH97cKjD1ppXAP7WsQmftUZ981Wl8SaZCPnuVYj0p8jYroyrnxrAr7baFpffGKpP4xvGB8qzV fdmq1T7ickVLjxLqs6lT5KKeoCZz+dQ20+mSSBtUst5JyWjAA/Kny6aE311Oj09fDsgH2WCBH9JB k/rWwlhYun/HrbsvbMan+lZvmT1LSRDN4e0qRebGMe6Er/I1Ql8HabI37syxeytn+dCm0DiilN4J UEiC959Hj/wNUZfB98hIjeGTH+1j+Yq1UXUnlZUl8PanF1tHYDumG/lVOWyuYf8AWQSxj1ZCKtST JtYiKt0IP4UhDZ56fSmhBnHU4pAT0PP40xjtxHpge9HmYA560CEZ1YY61EeG4P4ZpDsG4HuwP1pQ W7Mce5xTEO3MOcn/AL6phcA45z9aAAOR0H50u/1yPpQA4SkcDmnecOuWpgPW5kU5QHmrUWr30YxH PKqjsJDj8qQkW7TxTf2zESBp1xgB24HvxzVlfGt6M7reDgerf41LimVcJPFtxP8ALKoVT18s8Y/z 71Ztdc0lcGVpiw7uvAP0BNLl7Dvc14/EWmMvyXcSnsCcE/nTl1QTtmER3Cg9Y2rNpoZIJbpiALYI vbkcVMhk6l1BJ54zigdyNxCHy0oVs/w/KDTTcIG/4+FwOwx/Oi4WHG4JXKqhPfI6UC6kJUcYz1xT sArzk5BZmDcccU9GwgGW2gdTSsAq7c9Q3HHNJhAdrYJ9ieKBChSQQGOKVsImT82OScdKBlVr4EAQ guxHCoM//qpW0+7vSHnmSFR0U8kfjT23FuSW1klof+PhnPYM3yg49BUruoPBBYDOQO9LcaKs980K s8+BGB8pGAM+9ZsmryhtseI93R5fl/IdTVJLcVySGNJ2EksU10/Z5BhR9AeP0NJdeemGkuY495+W OPLuf8/SjdgRpp19ONzF1X1uHzj/AIAOPzqK80aC4g8iW9csDnCHOPbaP8KOa2wWfUo/8InA0DIi 3Bl/hkchF/75xmqyeEb+2YyQXELDvkEZoc+4JF+HQdQ2/vpYI88ZBJFZPiHQ5LGSKVpGkVgRnZjB pReo3sVofJtlX7PPMzlcsAdoB/rU9pc393cJbwsgBYcM5/Ou9S5Y6HI43epc123XTNUjvIZ0llkP MJTIPGDn2NbOh2ui30Amu47aA5+aLaBj3rlVSyub+zu7XNe5v9EsYVg025jCqOOTj9TSQXguYA6S RhO7qc5//V/WsZKT1ZorLRAJ4WODcpkAjKkAfie9Q/bbRc+dcJgfhzSsxlebXtPjB2TYAOCM5zVJ /GNtGcAMw9zVqDYrjT44gxgREn8j+lRnxw5BCW2R7in7MOYoz+JtRmYNHvjX0AH9aZ/wkOrGPaJB z6nmq5ETzED6nqMoJe5x64FVXeeQ5ediT7VSVhXG+STy0rkfWk+zxqMkHPvQK5JgBfkC/hTPcj8a AHKMjHOT04pNpxSAXbg5zjHpVu21K8s2zBO4x0BORQxp2Nm08XyoQLqEOPVeDW5a+IbC56SGNj2c YrJwLUjQDxyAMhUg91OaXuc9DWdihMe2McUFQF5JPrxwaAIHsraU5mt45AfVRn+VUZ9B0+YndAiH 1jJFUpNCsmZNx4atGYiGSVcepBFUpPCzk4guVY996Yx/OrU2S0VpfC+oINyxo4/2W/xqnLpGow8y WkuPULn+VWpJktMrNEyHDqyn3GKjKHPAp3BiYNLhqBCAN0oxz2zQApBIwf8A9VGB3JpjGkLkEMeP ak2nPBoAXMgGMH8KbvagBQ7nqKUFyeVzmgRat7C5uXGyAKP7znArSh0BCu6e6hHqEBP9KhySHa5Z jtLO1bcipIMdXGf0q22ryRAJE7KOyhQBU3bKSQ3+251TYryGTuTgAVUl1O5mBDM5PbJ4pWGQefKV A2k4680vmM8QChV2nkljz7Yp3QHQpLKp5BHvU6yEuwxvx6dKbEWo0+df3S89cVOVCLkkbahjFX51 wuOec4oEDMScbQoyRnGR7U7gRs6RkARl2B4ANVJ0v7pxGyqsXXCsOfqf6YoQizHa/ZkCocKepAAo yqoVMh9M4yfwo3GOULt67QOeVoOwAbWJPpikBk3Y334knt7qSOLlDbDPze4Bz+IpYtQAbFtpd0CR gloNoP1Pereq3JJ1kvbpm3Rtbpn5UDAEj3bk/pUsVlNH/qXiiJ4LRpuY/Vm6/lUtpaIosiFMATq0 3HUuW/Q8fpShoUQ43RgjGAvH6VIyub22DY85Ae2e1VvtNupyZlYE4GHxinYQ2XULSOLebkBvQPWR qmrade2MkTSvIxGVU/3u2DRGLuDZgRbI4wHwW6nJq1p2qw6dfec0Af5CBxmuh7WMk1cnvfEs90pR YkVCMbSnFYsjyO24Eoe+DxWajYtsrMzo+QwY/Wpory7RCquQp5IHSrEANy3O4jPcmneXMfvSmgVx fIyMu7H6mlWGMDJXOaAJFUDooqTdx15oANzHA56elBPHU8+tAhwBxnpQOBx3oAM8d80YJxjrQAYB HPWjABzk0DuJn3698U4k9aBDd/brkUu84oHcCcqO1G7I6mkBZt724t2zBNImOmGOK1rbxVdRMFnU Sr39aTjcalY2LbxJYznErGJj6itSK5hmQGF1cH3rJxaLTuPJyR8vA4x6VAymU7WGADzUjHN5AAG1 Qe+RUCpCzld5B9DihAyU2646v06etN2gLtGc+9AEf2VZEIdVbJ54zVCbRtPaY/u03EZK7eD+VK7W wWIT4e02VMGF4WzyVY4P0zVaTwlbM2Ibtl9MqGx/KrU2TylWXwfdBiIbmJx2zkZqlJ4a1OLIFtvA 7oQatTQmmUpNOvIeZbeVfqhqu6MOoP0PFWmmIQIcnn8qXbjnufegVySOCaXiKKR/91SauxaDdvzM Etx3MjYP5daHJINyy+i2sCqWuzMe+wYFIn2O3lxsG0A57ms+Zsu1iQThgAq8HtjFO83llPTvmpGR s5YknoPTtSZBTAG7kH6007AMLhU4A4oZvk3MenHAqXICWNEdd7xvjHyknA9/8+9KxgZldXVAQeCv Nc8pSuTqdg6QqCzKSMngnGKh3gjMaZA/u11IZPGz4VmTrRNNuk8rBGfbr9KGhjo/NSIRqRgEnIUZ +metRv5rOcOyjHH/ANeiwDFikVsKxJP3fenoTjDABj1oYD3k2x5d+WHfgVSk1C3iTCyLnoQ3ahIQ i6rACCZI29jgikfWbOLBaaJTnsc4p2HcifxDYBS/mg887V5qg/jBUbbHbl/cnFVy3JukIvjAdTbf MOnNRTeLruQfu0VOPxFPkDnKcviS+kH3wPpVGXULmZtzTOPo2KpRRLkRm5nbAaZ2HuTTWZnHJJ9a aQXuMMYIzgUwwqRleD+dDQrkTQTk8On1pVgZgPMbn/Z4oaHpYR4ZFJ2sSv1qI4Dckt9aBE8bxk9l P0qYKDyOc0ALgbc+lOzuXigBGwMZGfwoOPSgYo9R+dByB1P5UAO3HPTj1o25780CADNO4PBoAAB+ HoaXI6cU7AxMjHT8PWmnBOelSAgxjJ/nS9hj8qYAGGOR7UDn7o7UAGDn2pdvOc0BcXHGcCnA8cgi gA4xnA9qfHcTQNuhkK4/utSsFzTh8R3iDEp81R6nmtey8R28mBOTGfccVnKHYtS7mtFLaTjKSK+7 tnpUvkRDB2jJ9RWWqLHfcHA6deahM0RkZFUsV67QTj8aQxdzEAiMgY/iIFRxwsJvNZ13MMYUUCJx lT25H501iu75kB9c0AAdVHAUE+1RSXEaYLsq596AIJL+KOPduPHPTr9Kz5tZtpOFtw7ZP3hmhBoU nvVKGT7LAVDY3eWKrnUm3cKo3H7wQD+lNeotBfPupQwaXYA+Ov8AhUM0LR7isxKEdQP05/zxUe1V 7BcjPk+Vjc+8HA9D61E8qgJsVRgYyBz19fWtFcBNxYAFuQcLxinC1umchlICrkk+lJyS3C4xvOjh U4O1hkHFHmSRykMu4Z64601JMVxyyKX2yIMk9CcfyqYyxrtCx5wcEsc5FJ6jLCSICNsqY25IAA9O Dx1pYpLZnbGU3ggYGOo6VzST6COilvrK35lk3Dt0NQr4k00E5dlH6Gu5RYNoSTxRpyplJGftgDNV E8V2qSM5iZ26A45p8jE2iObxgmMRQN+NZ0nie9kfKsF9BiqUEJyE/wCEnvyu3d+Q6VA+t3rfKZSM mmooXMyBtQu5FO6dgKrs245eQtn1NVZCuxoZR0xSFlwOR9MUAIWUn7ufwoyBg8mhgKM/w8D+dL25 oAMdQcfn0pduOnaiwCc5yadnjrQAdP8A9VNzk46UWADg4PpQORSEHfPtSMgccqDQMhMA7ZHtSCOR Pu0AL50i/eGfXinLOncYxQBKJVJ4IP1pQeeOaAAsMUuc4JB49KAEL8HGfxoEgzkcHp0oAXzM8ZB+ lLyAecfSi4CbiVPOOelKuSM5oAD2zQBz1NACH2HApQW28DtxigBRkdMUc980AGQKduwM/wBaGCE3 AUbsHBzQAnOep/Ol/CgLCHHYn8KPMUdc/SkA9LiWJ90W5SO4OKv2+vX0bgvKzKBjbkj9aTVyk7Gz aeJbFtouYdrdNx+b+dasWqWEq/u5owB0BYCspQsWncZJqdujBRIDnpj0qH+27Y58sliBuPbgfX+l TYZX/wCElg2FQryHHXGMVVk1+4dgsWxc9CfmNFu4XK1xc3UkhJuHBYZXYeF/z+NVSLoRl2Acng7W 5B61HMgZZsJZ2nELq75UgAj17fpTnNsG3KOQdhzjj1NYSm1L3SbNsI72K3vAoRSkS4yw3An6e9Uz IQVbYDhcbevJ7+lVFN7lJWGG6kII6ehx1+tM2u7YbOT33ZFaKKiA1I2cfIfTnOOtOWJop8MA+CGx 65+lW2hFtTFBFkR7s4Alwfl7/mastfJHJkgKdgBcjgelctSEpCcSNruFk+aMgKcDjPPpU7hZCNsR f5cscYDDHb+VZWlFkKLRXhtYpJZD80aLJjB5wCahuraKFFe3Y5U855yK3VV3SLQyFEedWlQ7QMnj jv8ApxU10izKkcIDpEckcqevv9aJzfMJtoxGZmbLSFvTmonB3HvXqGYJI6kcVKHJGSOaEwuN8wqC TgH0oWQlc45PXFDGG8kd6XOSMH8aLgIFGOfWkPB69KQgLDGcU0yL0INAxVJwPrSjk4oEO6DAB4pf QZpjDPc0Hgf/AF6LCEyW574pN3AA4xSGOBz3zTcDHHSjUQpwcUoxmgdwyvU8ZoHNACHGQKCwHfn6 0MBucjg0m1c5IB+opAIY0bnGPpR5WzlZCKBjDK+Mb80CWXPyjp7UAOWSVn56+hqYFtuSBmgQu3cM MAfw6U0Kozk9/WgBdoxnApoAHIY/nRYBckHBPbrSeY6nkAg9cUAL546YIpQ5KgjB+hoAdubPJ69K Cw3dKADK4HI/GlyAc/15oCwnmDHP4nNMab5sKpP4UAJ5rnlVA+ppGkK8F1oHYYZlCn94T6AdKjNx GDkLk0gQjXbH7ufzphuJD/EaBieaxGcmgSOpyrY/GlcC3DqksabWwegDc5FW0uEkI+Yhh0qGhpl+ 1ZAxeSNXCrk5yRREscsbyqwBVj8mM59MGudt3bKI2kABYhVJGR/n1qYyxrDkSSSlWBHzDIyPftil JO2g2yWxguGkSaNwQqsSc898ZqURwidvtO4tkOGYcH2/TFYSdnoQ5MaLeIjzMYJdix659BUZtAhZ ASDnk47Y/wD1U41QTJLeygMxV5CFX5Txw2Rnr3q1LaCJ3WPBkZdvT+HPb044pSq+8DZRSyP2zy43 UAOVAYcPik2Mk6rKFIOQCV4XrgfpWvOpMZLGjPcRIWSQOOEI+Uio7yMxzyCGIsIsqQ55I9cU1NBc sadGhhYsgDlTwc8H1q2kTbS6ZXbycDg4zzXNUbuyW7Dbi0IUGJwu7D8+mapfYEdF8xiQQDnPQ1EJ 2VxqWhLFYYLW53CNoyUkzg7ufTtTwgQfZ96l1HDNHnp9acp3Jcjj/LYfdbp1oD7cBvzr2ySQODz6 07cOhP607jI5Y1kXngjoarK7wOR+h6UmIspKJRxjOeafyB7UxiEkHNNJOOeRSEJkkEZ60E89aBh0 bIPSng5GevFMQ4McADNHPc80IBd3PNJxnikwEOC2QT+NITxgikABgeBQCfpTACeccnPtTgDn7x5o GNI46ik+795x+dAxPMjzgt9aBLHnl/yFAgMy4+UE0GUgfcIHuKQDNxb7uB70ojH8RzQBIu0dAKdn I6CgBMnFLnIJJFAAOOo69MUnIIIoAOc8UoGRkfrQAmcNxijcD/jTAXeveoyV3fKD+BpAIztj7xH1 qL7Rg4JH1oKH7lJGX/I0GZRxnNIQ37WRwqjH1oN2cEbeRSuFiFppGOd2PpTclsbjk0XKAgg4YYoO CcgUCDPOOxpRk8AHJ6e9AbFiKwvZ1BhtZ5B6pGT/ACpr2N1HkyW8iAcHcuMU7E8yG/ZnHOO2STSr HKylgcYqbFXJ47yaFCm/K9cA9akh1IRFSEZWByTniolBalKRZN0tyn+syD82COR1q/Yusm2J4xgA 7mIGcY9e3PH41zTTUQZordRKMIUVxhTjnOO3HWojhrkOWO6QBQp6j3/SuSz6ifYbF5gO6d3I8xg6 MRjk5znHpVxnh2l41fc/bHIGKiTsS9CMvvjdArdRgY6dqzzdmNcyBg7gqwYcLzxVxipGkbWL4Id1 lfDd8nkcjrUEzG9hKZIdMlSBx6U47+gk0h6SMky7QjMEC/L/AA5qedoEYOF3NIBx9euamT10IbGx Xa73AG7cAFOO460n25ASAGLE5xgYI9qnchslaQvHndyOF3Hr7ZpqPuBWVc7iVznHaosK5LDMEeKW PD7eGz1B6ZpbpmB2kBimVjY96GNI4gncBnIx70p5OBgZr6FoYBMd85pyoACaYDgdwwB2pskaSDBG PfvQFio8TxHcpyPWpEuuNsgx70thk4ZCODn3pDgrjJ5psCPke9BbJyM+4qRDhyeOacQcZApgKhzk N1FOyc4xTAdzt600jmkA1l/u0zk8dPbFAwIJGNwH4UhBA5fNACfjR8xGCTQINhI9/rR5an7xNIYG NAe/50oCgcKPyoAUZIwB+OKUhu+aAEK8dOtHOM5oAN2fqKcH9c0XACc/SnKBwMH2x3oGLuHTPQVG ZkA+XP4GkAwzEDjdSGZyOxouBHvfGc0m589f0oGN+cH7xo3SA/ePSgBpLk5JNJwDjdSAUEZ4Of6U u5cHcTkDjigBpYBuBTSTQAAtjGeO9SJFLIPkjZsdwKEribSNPSPDWoazcGK3VUKjLNKcAVvaX4Ci ubmWK71JS0XDpbxscH0LEY6YptNMlyvsdBH4I0K0TdJG74P3pZf8MCtm0sLK0VRb2sUewYBVBkfj QTZk8jhUPOFHPJ4rza9n+0yS72DI7E4xgVrSim3cmWhWCQmERvGCAMZ71SuAqgiIbSACQVpzppbD jLUz2bzScK2cc4oCKQCWO48Vzmo/G37vOKmhu5UHVunAzUOKe4XLMWpvEC23JIIOB+tSw6u7TxtK A+1uOPWud0luFzRW6tmiVFXdJIMl+u0nOePypYdQJRA5VtgCufuk9elczpt7l7FmO7iaAqgAfO7g DnBz/SmYjubMpK/XGG247/yzipUeXUlskQeTCLdioTaQSevr+VOWN2jUlyQU+U5z1qZPqRcjadU2 ncNvRii9eainmDrjlkPT2qPMVyF2eGRGWTaAACdufwHHv/OrMcryu7eWGICjIwDxVPa4nsPicbCg LYyCMnHQ9efbNR+aUdAVfBO7GzjFJJMTLZkTJ8oKiscYB5Jp1yyMFKMGOcOAMc4qEUtdjjN/y4br SgjYD+ea+hGKWz0Y8e9O4xyadwG7mU8Dj+VODArkEA+9AxCiuMHpULxRngcfSkIjKNGfkbIpVuGX gqDQO48SbzkDmpBtwT0OOtACKcdO1KZR6igBrSrnIJzThPn+E0XAPNbH3cfU0glfGOKGxWFy570m fXOfrQMXHPTj3pCRzk80hBweAKDx2oGICfQgetG7j/61FwF9+BSB1xjOaAF38nb29KPMCnqDii4x POHXIJ9KaXZh8q8+tACLkHpk+uaGlGeQc0AIJlBGT+lL9oIHy0gsI0jn/wCsaaM44PTjrQxjcjHW lzj/APXQAm7j0pNxIyOtABzmmtuGMCkAoBxxnmmmInmmO4mGXnGaACRnpSAdxnnPHSlzk8Ci4WLt hdw20qGa3WQL1BHWtSfWEvCQoSGMH5YlG0D8K0ptJ6mU4t7GjomuppDTyyMCjRnaAMkt2rrvD6Sr pS3Ny5ee7PnOc9M9APYCnVtzEJOxoShZF2yKrL6MMiki2opVVCgdABgVkUZ+tif+zZ3iuGjVIySq oCW/E/4V5+0mQWJ68k1vRtqTK5C8gRCCS3GaZDt8wnJJIxVyackLoNKQW5LAAswqtJIgcbMAGsaj S0RSuV95J44NJ5jEYySBziuZ7lkgbA6/Wmhsc9geKgCTz2DZDHB4pWkJbfuxmiwD4rl0yAx+b735 0838gVwrcN1BqHFMCWHUGZV82Rjt4Iz1X6/nVuDVt0exvvY+Vj/DxWUqd9gexMbqFpFG4crwQOh/ /XVqJrdlZeRgDcfTH+f0rmlFomxNcQmSbzYmTyyc+uaTgTFyrhzlwg7YrNMRZgkjux8wKnAYDGN3 egW/lswDbxglQTnNGw9ysDsbAAKnoCO9MaRHco7EDfuKgY57H9Ka8hJ2OZI5BB59abweM175oIWw 2AaFlIJOKAEMpOR0+lAc46ZBoAfuOe350ZBPJAoEID83T86Ro1dvmHPbmgY0RMudjjBHTrUZWVPX HsaLAKHAHzhqemxvu4NCAdt4yBzSjkf1pAKFHc0uAB/jTEAwO/Sk4zjp+FIA3ZHJ49aZkfWgYZAN KCfX9aAEDnpyPpQWycDA/nQMRie5pueOlAC7/l5wMelNLDbwQKQDUYHOM/X1pdxPBJpDAkDBJJ+l DMCef5YpgGRjjH4ik3+goANzYpME8ng0MBduB1+lA6UgDqetGe1MBcAHJodiWOAB9BikAjcgc4o8 wDgDr1zQAqsoPA/WpF24O9eD3oAVokK5U4OfSo9vltkOB2pWBMbvJUAknHrRnAoKE3HI54Hauv07 x9dxBUvoI5o14JjGxsfy/QUXJaubsPi3T77ZGJGgdmAKyDH69K2TdD7I8tsUlOPlwwwx9M0zOxyG p+KvPtmtp0MTkssixsHBHbk45zXLG8G4t39KfNZA4jRdMeD3pBM3KjgnnFQ6jCxHlydzMcYxTNvU 4zzUNjEB2HFIAWJwM0hj9uAc96aMrxnrSEKQc4zxiot5Bx2HamkCHJJ8x+lPzxk96QCL1JyCOwp+ 4gEA80MBd7KwOeanj1CSEkZJznvWcoJhuXbfW3h4Jyg6Kat23iAeezPzuAGSOnNYOhroKxds7+Bg S2F2tyOm6nNOFuWaNsqDuzx09P1rBwaYW0JBMXGGjTIAbOOR/nio5WWRm8kYPO73FRbUWlzktwA9 6CQMgGvfLG9xx+NKMdSvWgA49KAR6fjSAM4A60ZHGRTQCgjrj8KXg8gGgBM5Ppij+L+tADjhhggU x0x8yE5FAgDkDDjBpd2OhBB7UDFLHbjj160B1OMknP6UXAQnHqKaSQepH0NIBu4kdTS5bGKGMQZz zRjA5NAAeOM/hSbgO3JpAG4ZFHmAHIoGN3ZPNIFYngUgHCNs9Dj2pREQemKAFEZAzS+Sd3AJHrTF cUQux4B+mKkW0kPVcfU0BceLUjril+zN2x/jRYLgLU85oFuo+bP50WFcPJUDcVHB79KYyhicDaCc 8UAM8vjqenpTGQr3zQMQjnAyKMErt2jr170hihMHBHI7UEEEcfhmi4A7bpS2NuTnHpTxIPL2nBHv TERvEQQU5DDoO1MKspwwIPoakpMOBTlK/kalvUTZKk7I+6MDcM/Mwyf1qV7y5uBme4kfjPzMTRex Nys+cHcMZ9KjIUDOTSuO47J7D6UB84PoOakQpPbrjrQJAAQc+1ILDCxKkkHHY0ZIxzVWAC+AaFYE ZJpWEPDAk/Tim4UHIPWgBD60oOUznvxR0AGYAUeYDgcdO1FrjHAlkHXrRgMevJPWiwgZDkjrim4Y NnsKQEiysG69KmF5IGB3nI/Ok4pgWl1WTauHOQOe1W4NUQxhXbHXPHvXPOl2E/IxscZxkUqnGeOv tXpjDBJ6UoRm/pQMNp3ZH5UhVge1ADcENjFHOTmkAKfmp44GOTmmAAAdRjNKoHDHH0oAUsB+FMZy RjFAhAQRyBxSEigYhBA3CkAIb2PekA7JJP8AKk4yAelACBTnjp9KXacZJ696B3EIweophYDpk0rj DJP40BCaQCiFj2qQWzDsTTQmyRLZuu0D61IIORvb6YosK49YEHqc+9PCqDwi/lTAB/uhT7U4JkZx SEPWM7RjpTimDg9TTATZ60hAHbFACZ7Mcmon6cjPtQxjGA4OaZ0GAc/SgBNvJOcUAZbAoGJwDjbn NKgB6jBpAx2wgn5uKNgA3EZHrRYVxpjjJ9DSm3XHU0AMkURrhAaheaTaB1xSY15kDuS2T1NNMhz3 qLAkPjkKtnOPWp1YAcAUmhNClgVCt6UwgYAXPripEhVifAI55/KkEbq5AHemArxtvJGD0xzTfL+X B4PWkgFEZCZFNkQqAQCeOcU09Rp6kTq3PtShSBwab2K0sLgjGaQ5PHQ9s0IlCDPTNKfkwKQC8MvN Iq5+YZ49qaAkBwdrcZoGc7h+IpPcQ7eSQfUUjNnJzzSsA3dkE96C2DmnYADHORTi2TSAsbcfSlAA OD0rqAT0wSB7UoB6g8CkAhJ7fpTN2PpSGhGYAZwabu5oGAI6ZNLuLdT9MUCYgYjAzQWPoOfSgYm7 nNG+gLAWApCwPAoAduZsA5IHQelKEYnoaBChT2AFOVOM0AO8rjNBiNADltdw+7+dKtmvXNFguSC1 ix3z9aUIqDAUUCFI7rj6YpyktQA7b3xinbRjrx1oEJlcUcAZxQMAV6jBpc+ppgIpyeDxTgxAxSsA F+OaQlSf8aAGfKM89ajbJ+7k+9AxBGccnil2L9KQXEKjsKCp4pgNPbd0pdo7nmgBSOACR70hDY25 O3rigLIbsOfQ+tPA9P50gFKgj5h+NRvbqTkcUAQPbAcg5P0qu6YPv70ikNYgDoc0gc5qWgtccG3D rT1cng9uKlolofvOM46daaJmK5GeKVhEisGTcxJ9qUOuTwPu96mwWE34X5eMjFIZCeOeaLANblgS SM0GMdj+dO4BsGOv51EygZyfemgEw3pmnsqsOOwFMYFCenAp+wEEg9ulK4gdcngZ9aCcJjGO1IBn YZozn60wExg8U1gQf60DHqCVz2pH+XGaEHUtMxPIGR9aByx7V0CAtz1wPWmtIucZNFx2IjITwBxS LvcgKpNSMkW3lbByqj3NHkcZMoB+lOwrjXj2k7ZAwHt1puxyATz9BQFxREzcc08wtgAselAxRb5A yxNKIFJwQfxosK477OB0FPFuAOcCgQ/yR6/lQIwDkmgBwRQMkDml2joMCgYp6ev0pQePb6UCF3EH pSgHPpTAX5R9aOD1AoAQ8dMUu4egzQwAyHGKASRRcLDSTgjvQRkDNDGKCBwBxQf59qQhR14ozz7d 6YDTk+n1xTTz3/KkAuMjmlHy8UAOxxwKFUY+akA7YOige9MZSCaYxhX+VN+YdcEfrQAYz9KNxUc5 x9KYbjwcnoaAQDwKQC9TTSuTQAmw9zUTwKwORSC5Xe3IHHNQNEV6ikUmM5BGKcDnseaTQND0faTm jIwwqRWGhtijNOU4kyTkEUBYczYPXn0oGAmGqbEikghR3pC3UnoentQAKxB4pHXc24jmhAAGMccD +VI2AxwKAHh8Jg+tMLkYHakA8nbjk80u0sme4oAZjJ5GKCu0YGDmmAgAIBPrTsLyOtDARR8xXpxT Cp3YzmgZKZMjqcU3eSMc1uMQtk8E0hORn9KAAKT0GalVWAxnigVxwXC9SBRsGOnPvQAobHO0U9EZ jwaAJREc5OPoKeIkY/NyRQJi7FXAAo5HQD25oAXBI6dKTnp3oACpC5zSds8UAKPenfL2oAAQecUo wMkDk0AG480hJz60wDJz1o5A60AJznPSjnFAxfzpBmgQ7A4yaM/p60gAnGe1JnJouAZ//XRyehoA QAqTlic9j2p2fwo6AAPPpS4GeB+dAATx3oycetFgFyCMYpu4Y9qBWEySOlIclucUDE2BRxSbSW5I xQMXac804A5oEL36U05zQMM88g0h60hCEA9qYyKeOM+9AyvJbH+GqxjdTgjmkxpjSMOOenOKTLDq MClYYdsnvTlIB/zxSCw4sMnHXNOQjBBOakkYpJJUUjEgY9DTsA5T8nQ5FOU5JHapsDHjgAHBGDUZ Qljt9OtAhypuQDGPX8KYecYHWgBcsTgDgdjTo2bJHb0osMcpGCccUwktlj0oAYWJHTpUq7c/KOSu KGgHDhssQeMU3A+83YfnSAaEJOOfxpfLA6kAV0Bdjggxml2j0FADwhA9KVYW3deKAHiAY5NSCJcZ P5GmhDtijgAYpeB0zSAXnHSkIx1FAC4yPrRjtQAZ96Tv0oAO2KCcDPagA7detHSgELnHejPfFABu 5xSCgBeg6UAmn0AXIPejjFIApKbACcHilz7UgGn9KMgfT1FAwzg9KUHikIX2o5HXnt0pgHQ8Uv0o AOnekJ4oAQ89aUUAFHP+NAAfpSA/NQAuTjkdOlHbrQAEgHr0o3CkMTIJIIP1xSEGgQlGPSmAhNNI U9cUDGSQKw5AqlJGFbvSGmMxjpmkwPepZQoAIyTmlU45FITDnhun4U0/eyaQhVOPoepqTAADDHBG RQJiluehpwbsQPrUsA5DYB5HSm8j196AAL824jg+9KQdx4xkU0Ahyc9iDxQeEIPJ6iiwIYqlQehz 0oUk4yOe9DG9RxkOelBfLexGKVhFryD3PFKIOBk5rosFx4hGMHnFKsYHQdKLCH7R1FLjkmiwCHpx S49aQC8YoJ9qbAaCcY6UuetG4BzijmkAnOaKAAnnFL1FAwpOpx3FADscUn05oEHbAoJOfbvT3AUU UgDPFHANMLBkYpMmgA49aD0pbAAYflRweaAFx3o/zxQMUHnB60tNCE5HFH40hic44NFDELn2pce1 AxM0cdh+tFhATjikJz2oAXtSH2oACeP/AK1AzntQMMmjI6UCEyDRjOeeaBiED8aay80ANGSMGmPG Mc4NAyPyRtOOKhaJ14xmlYLkZBDc8GgFQDkc0mhjdwPrSjkHipFYTJBAPOP1p4ZSSNu38eKAsKCM 8+tSbspggDmkxCBgegII4pzEMMDPNTYTEVvk2dQOaOGOQTz2p7ANAG7BP69KGXPPTFFxiKR909TQ B3P50AAAI2nv3puzDAA5wOKEB//Z /9j/4SeIRXhpZgAASUkqAAgAAAALAA8BAgAJAAAAkgAAABABAgAPAAAAnAAAABIBAwABAAAAAQAA ABoBBQABAAAArAAAABsBBQABAAAAtAAAACgBAwABAAAAAgAAADEBAgAWAAAAvAAAADIBAgAUAAAA 0gAAABMCAwABAAAAAgAAAJiCAgAFAAAA5gAAAGmHBAABAAAA7AAAAEoEAABGVUpJRklMTQAARmlu ZVBpeCBBMjA1ICAAAEgAAAABAAAASAAAAAEAAABGaW5lUGl4Vmlld2VyIFZlci40LjAAMjAwNzow NToyNiAyMzozMTowMQAgICAgAAAjAJqCBQABAAAAlgIAAJ2CBQABAAAAngIAACKIAwABAAAAAgAA ACeIAwABAAAAZAAAAACQBwAEAAAAMDIyMAOQAgAUAAAApgIAAASQAgAUAAAAugIAAAGRBwAEAAAA AQIDAAGSCgABAAAAzgIAAAKSBQABAAAA1gIAAAOSCgABAAAA3gIAAASSCgABAAAA5gIAAAWSBQAB AAAA7gIAAAeSAwABAAAABQAAAAiSAwABAAAAAAAAAAmSAwABAAAAGAAAAAqSBQABAAAA9gIAAHyS BwAeAQAA/gIAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAABAAAAgAIAAAOgBAABAAAA4AEA AAWgBAABAAAALAQAAA6iBQABAAAAHAQAAA+iBQABAAAAJAQAABCiAwABAAAAAwAAABeiAwABAAAA AgAAAACjBwABAAAAAwAAAAGjBwABAAAAAQAAAAGkAwABAAAAAAAAAAKkAwABAAAAAAAAAAOkAwAB AAAAAAAAAAakAwABAAAAAAAAAAqkAwABAAAAAAAAAAykAwABAAAAAAAAAAAAAAAKAAAAKCMAALwC AABkAAAAMjAwNzowNToyNiAwNDo1NDoyNQAyMDA3OjA1OjI2IDA0OjU0OjI1ANQDAABkAAAAMAIA AGQAAAAmBAAAZAAAAAAAAABkAAAAQAEAAGQAAAAmAgAAZAAAAEZVSklGSUxNDAAAABUAAAAHAAQA AAAwMTMwABACAAgAAAAOAQAAARADAAEAAAADAAAAAhADAAEAAAAAAAAAAxADAAEAAAAAAAAAEBAD AAEAAAAAAAAAERAKAAEAAAAWAQAAIBADAAEAAAAAAAAAIRADAAEAAAAAAAAAIhADAAEAAAAAAAAA IxADAAIAAABAAfAAMBADAAEAAAAAAAAAMRADAAEAAAAAAAAAMhADAAEAAAABAAAAABEDAAEAAAAA AAAAAREDAAEAAAAAAAAAABIDAAEAAAAAAAAAEBIDAAEAAAAAAAAAABMDAAEAAAAAAAAAARMDAAEA AAAAAAAAAhMDAAEAAAAAAAAAAAAAAE5PUk1BTCAAAAAAAAoAAAB7CQAAAQAAAHsJAAABAAAAAgAB AAIABAAAAFI5OAACAAcABAAAADAxMDAAAAAABgADAQMAAQAAAAYAAAAaAQUAAQAAAJgEAAAbAQUA AQAAAKAEAAAoAQMAAQAAAAIAAAABAgQAAQAAAKgEAAACAgQAAQAAANgiAAAAAAAAgPwKABAnAACA /AoAECcAAP/Y/9sAxQACAQEBAQECAQEBAgICAgMEAwMCAgMFBAQDBAYFBgYGBQYGBwgKCAcHCQcG BggLCQkKCgsLCwcIDA0MCw0KCwsKAQICAgMCAwUDAwUKBwYHCgoKCgoKCgoKCgoKCgoKCgoKCgoK CgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoCAgICAwIDBQMDBQoHBgcKCgoKCgoKCgoKCgoK CgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCv/EAaIAAAEFAQEBAQEBAAAAAAAA AAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0Kx wRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ 2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQE AwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBka JicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWW l5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5 +v/AABEIAHgAoAMBIQACEQEDEQL/2gAMAwEAAhEDEQA/AOFjsOc7QalTTQTnaDiv2i9j8aUbEi6Y vGFHFSDTOny0Nlctx4031XI9qeum5A4wKLjURw00Z+7wfSnrpo7qOKOYfKPXTQcYXp604aZ04z7i lzA4ijTB/czinDTR2WnzBygNM7BRQdNHICmlzIXLYBph7qBSnTRyNnNNMTQh00ZwBR/Zi4xs/Onc VhraaPTmmnTBj7tNSCw2Ow6YUjPepksMdBXM5GyiSpZngbfwNSJZHrjj0pc1ilG5ItiCM4604WPA 4GfSi4+UcLDjhRz3py2A7jFPmsLlHix9QSTThZDoB0o5h8o4WPQbRk0osTwMY96TlYTiKLHvtyKU aeQBnJJPehSFyi/2ecfd5pf7PP8Acz70+ewnET+z/bkd6Q2HUbcn0pqbYuWwhsOT8v4imtYDsuB6 U1MFAqRW2cZGamS19FrlUjaxMlmcYK4p6WjYHFLnGlckWzx24FSrZnB4zjvRzpha44WZwQQCfWnC zX0/A0ucaQ5bMYOB1py2ZHVRxS9oDjYcLTgDGKcLPnAGSafPcVhfsR6Y4PelFn7c0c4NC/Y1A+71 pfso/u9aPaA1YPsnT5aY1uvcZ+nah1LAo3Gta5xhcD2prWucnbx6kUnUaZUYJ+pnxWx4wMGp0tjj OMGsXItRJFtwGALDJ7GpBbkHpSciuUesDZ+YD6GpVtyRj0pc4cpIttxg9vWnJabj7+oo5kw5LDxZ Hn096VbPByRn60cyHy3Hi1H92nrbD+7n3o5wcbjhajPCn6ClFoeMgc0KYuUDZcDI49TQbIdzgGjn QuUY0CKDkg59KiePHIA+tTKpyoqFLmdhjRrj5ic+wzTSFUckkVx1q3MehRpchkp5wPAOPep42k7p jHc10ORyKCBo915FMcggEYzwe9W0P+wPrUJ2bL5bjlboPLHHrUiYyP3ec9waOZoFEnhRT1jIqYRx jAKkZqXMfKPEuyVFUDAVuCB6jrQWiHcfSpTs7g1ogEsP94cdzUiyJ/eH40+Zi5biNIuD8wNMMgAz gn6mjmY1C4jMWx0pJHdUZ9jNtBO1AST7AdzSlUZapJ7ncfsx/wDBNi+07XJ/iF+0FrnivUfFviJ/ 7R/4QbSNUms7DR7RmIi+2lGX5uMH5gRtdUjl2Oy+h/tl/s5eCvhD4e0HxP4G0mSxW9ke3urc3Ulz GrBFZCjuNxyA+SevHA7+LPNJ1sVyRfuXtt+J6sMujRoKc/iav/X9fofO8xcN0Bz+NQOxwRgAGvSe pxqyHx6RP0EfX1ovPD/ia7sJoPC2mzXWpsuLa0hhSUyv6YeWJemTy69Ota1ajhByW6Rx00pySZ4N 4o+Ff7T3xG+Jcnw8i+K/ijTtct1lm/sDQ7DTrZ4URIHfITUtzALcwE7mPEi/gmnfsp/tQ6j4h1jw lovxy+Jeo6t4dnhttWsba0ts6fLNbrcRLIW1IA7onVht3DBHPNfLVMzrSle+/mfR08LSjG3L82Z9 /wDs9ftE6bdajDqfxj+Kyro6sb3ZaQnyQqq5zjUsfddTwe/1ovv2e/jnoemJ4h1z44fFawsXZlS4 voLeFSQcHAbVASPpmpWYVZvlUnf1K9jSX2F9x6H+yn+w/wDGX9qn4mJ4C8D/ALYXi6CGGOSa9v76 3nU2saqMMIxdktltq8lQC45NfRXiL/gjRd+Er4aRrX/BR7xxa3wXlktZtmCMHpc8Z570Tx1SF7yf 3lxw9NpPkRh6j/wQ6+P+uSDUfhr/AMFCdQ1G3cZAvIruNlX0BW5fIyD6V84a9+xt8V5vFt/4R+HX 7bV74w1TTbia1utD8IahHJfQSxOyOv2OS/juGwylcqjcjrTjjqs1eMm/mN4eit4L7jlNf/Zy/aV8 KWk2oeJfH/xrsYbX55Z73RLiJIxkAFib3jk/rVCf4TfH2z857n4yfFaGCJSzvc2NwgRR1LH7WQMV Eswqw+KT+8l0aPSH4GlJ+zT+1BNAlwPHnxekRlDK50W/ZWUjIIInIwfUVb/Z+074heGPj1Y+DLjx Prms2sQvF1O81h5ldHSN1CCCRj5SiQBTuG8sOdvK1rRxVarOKTe66+ZlXhThTb5bfI+n/sTHBAPH rXs/7C3w2l8Z/HS11aWwimg0CCTUCtwMx+aMJDn3Ejq+OvyGvfxU+SlOXkzyKDU6kY92j7atPDVl oMEi2yl5rmQzXF1J/rLiYgAu57nAVQOiqqqAFUAeN/8ABQnw+dT+AT6gFGdN1C3uMgcgHfF/7UFf K4WXLVh6o9/EPnUvQ+C7jPXIH1qpMzY6kivsErnz3Oj5ug+On7QFq25fiFbTD38g4/8AHa9R/ZL+ NvxY179oDw3pvjHxtYvpzzOJo9kaF/3T7QCFGTu29K/HsNxXjMRUjSc27tLaPz6Ht08HQX2Vf1Pp bxT49/Zy8E/Eq7+IdhP4b/4SWO3lFxfwyLNdyK6QqymNDu5FtAvTJ8sDjHPVab+0V+ytq3xLg0v4 daLLo3inxrGuo6zLqVndWsl80FtDb2rsZmCbzEnCoAduzI5BP1TkpP0OyNKSie16J+xmPHGhz6y9 ppVtD4lt1mnuNrSvKkkabSynAJ2qnGR0rhvEH/BKXxDP4s/t7WfGg8RaQsbPOtqFt75MYISCCVxD yc/8tV57YJxUlGOsd2TTp2d5Hsf7InwG8FfBN9a1Pwh8P73QBKVto11YD7VKDiWSRyAFYEmNcrxm IgdMnO+NXwa+IPxF8Wz6ppt9aRxEAAzMf0wDWNWLqQaW5rflaO4+CvhHWPAFo+majc+YBHGiuCW3 FVGTk88sWP41+Gf/AAUY+F+lT/tU+Orbwl4amudUl8Rarcquk2kjTLK99Odp28dwcjBP5VdBOkoo ia5kz68/4Io337fviTxXqvw5/ar8E+KNV+FY0uR7S8+IVjIWtrpZIhFFbz3A8yVCpfKZZVCgjbj5 v0T8TfAv4c+LvD8/h2582CzuYxG8dtLjCgjAGc46DpV11Co9VclQTRy2pfA74a6bNLp9v8Vraymt Wgie3vnjLxvL/qlYZUgvg7Qfvc4zXyL4r/4JlfEKP4lal8UvgV+0t4AvJ/EdxeTQQamGVZA8rzSI jI0gYqz8kDgA8DPGtKpKj70Fr07GFaj7RcrZyfiv9nD/AIKAaJM914b8I+BPEdooRt+jazbkKPMV Sf3jozAnKgAAgsOp4r7U/wCCbnwx8c+E/hPqPjD4r+FLXQda126UJp8dylw0dpEuEZnX5QWd5DgZ 4CknnA0nmOKrJ06kEk+qf/AOelgYUpqaex73rUMCpuSdCOxRgea8l/bKQz/s1eNL1LL7X9i02S9+ zwkBnFuROQPf93XNGTp+921O5pT07n5A+N/25Phl4F1a10Txhps2mXl8paGK+kEauAcffI2j8SO/ pV2P9qnwvdxrPb+HJpIWAIlimRwR68CumXFKo041alGSjLZ3X9feebLK1eyqfh/wTzKTxP8ACXwv 4ys9f8KeCF1HSfLD3Gnayy3Em5WbK7vlAyDkEAdRk/LXJ+Mv2nPAmg/CTQfAHhH9lKzt/GCQrNff EbxBPDLL50dsJPsUUAQoisijDkRMzxsMsQRXyOWYzK4RpQw1lNrXq736vv2PXwlF15SVNK+r9Elq ReEP2pf2kLKKabQnE0dhGbK8msbhp0hu8uAxKRHIcxO6gYwrDk99f4a/tCfGLxv+0FN4Hk1CRb97 ODTb64gt1doNXW6UrC29CHdo9o2OrfNDJ8p2mvoKrdWNo7nfgXGhWUqiurNO/mmj9pfh54q/a8m8 AaIuifEz4dW1oLC28iO58KamzJH5S7QWF+gYgY5CqD1AHSti31L9s9pnluPjD8MnR8AR/wDCL6ig GPT/AImOcnvkntgDnI+Z/wBf8E2VbLVZOnUv19+P4fu9PvZaim/axwXk+Jvwtcn+FtHv4v53rVB/ b37WKKBP4m+EshHZft6D895ppSsJ1Mtb0jUS/wAUX/7aiKXxr+1ha5C2HwguSO8niC/tgfytZMVT m+M37SNgBDrPwj+G04X/AJa6R4/mcsP9ybTYsf8AfVS1NdPx/wCADhls46VaifnCLX3qaf4EEP7R XxBs3FzrXwD1AovWTRPEWizBj7Ge5gz+OKv2v7U+mBmS9+GfiTSz/wA9bprG4IPsLS6m/rSTfYwq YWilenXi/JqSf5W/E8H1fwz4t8YeJ9T8bQ+IL+8uNbgjuL+xNhqADXXnTxbIy9uVURWVxJGjEEeZ tbHFS6F8IPEtisrXniTQrwQGNxAmqNb3M2+LZJCrSLvi2tPcvuIG8rb/ACgJgdCqJHDOhNa6P0af 5M0/+FG/GOTw5Gul+K7O4v4AkQt7S8At1hgHmW38O5iLp2lycbliQMMnI9Z1LwRB4v8AgW3wg8Ra fLp1jPpw082cF0ZWtkVdsbLIAuXXarg4GGHtUTndaGSXK9T8gfjhoX7R/wAGvi3d+Fbz4v8AiS2k 0W9KTW8V7P5V1CFbZhN2ArBkcEDJAA719WfBHwKv7RnwyuviFpH7bWtfDjV7JBHf6Fd3KSWkcqod ksLSzIyxSBckMzEMJOcYAV3GDk3b5lTmlJKx8RXnwU+HWu6zqeo/EfwVa+JJtQIDvqCypJE+5i5X ZICpYnnB7A9an8PfB/4feD3L/DBdV8NQnBawsrya5tWP+1FcNIB7lCp96+HxfE9bEuVKpTUovSzb b+/8uxfMm7cuhy0RZcT5T5j92NlyvoeKZrOn2usaVLYPAJhICpViBuU9ScFc8HkZGcYzzXx1Jck4 vbXdGdJzozU6btJdUcN8UfAXxB8B+C4vCPhHUm12zYNbPLoOpXDfZLeVgQIbeZCEAHDn5m3ZIYA5 rX+FniHwd+zfcReFZbWaFpnlmt55LaSW6SMxkSO6xyKlwQ0UIRtsbjnD5IWv0/C5nRrqNJVE5NP8 O/ZnpyqQvfdv+uluvQ8Ouv2vP2kNJ8W6pqugeMtVl0+S8uGhmiieGN0MrEEYCsB7E5H4V1mgf8FI v2kbLFvN421WJlxwmsarCfx8u6Wvu8Hi6E7QbTa0ezf3M8qvhm1zLc/RX9jf4Wf8FCP2o/Cel+Mt P/aIbQbG/hE6Q6d4o126nMXync5XUVRDhhwCxBPQ4IH0RdfsS/t526G28Pft4av58a/NDJrHiW5A YDkMU1EbefYn2NZYjFUIVGowTXov8jCnQqNat39X/mea/ET9lT/gsrpjtceC/wBqe0vdv3Y7jxX4 nti49QrTED8WHNfPPxmuv+C8/wAJHA8Q+OtTWFi2yWDx5Ogkx/dE1+rN9ACaFVwlXRRs/RfojSEZ w+J/ieMt+1P/AMFl9U1RdJt/EHxPvpztAew1fVpogT28xLkoPzr0jwLof/Bb74gkQXfxm17w87kD brHjPUVkAPQlYbiVl6HqBWGJnQw3uyjr6frY2pRVXZnf6N+yD/wV31lxL4s/4KVeJNLRsZj0fXta ugv03vFn867Pw9+xN+2HAVPjb/grL8a7vpuj0jU7y2Iz2Ba7kP44/CvPnjIv4YL7kdKppHWQ/sQ/ EmSMJ/w8X/aOuJSBte98Z3O0N3wEKnH49utY+s/sX/tOaMjT+Ff2tfHmvlmC7dY8XayhxzkkfaGU +leXjniq8f3E1H/t1fmTKKW2h5540/ZY/aDt528Q+NPC13rE67QdRa/N9cYUHAJdmciuJ1Dwd4l0 qIz6l4YvrAxMyu1zbuASvoRx2r4nMMJj1rXbl821/kZeycjIQrNI7PcNGUGWMqOB3wcEZ/KiO+WF xK17bXEcg+UuGUn3DDAP4ivC9m4stU5ROR1L4WwqftWleJLi0AORGlvFIi56gc5x1xnpWj4Q+BcP j5L65g+Lcum2ekeWLvVr5lEIdw22JI4keV5CFc7UVsAHJAGa+wXDdKT0m7eZ2zoR3/A6Pw54X8De Fo7uXwVN/wAJbexzbLfWvEJ/0aNQqnP2ONipkD7v9a8iMu3MYORXnPirwb4Y0nxvbWviDx5b22s6 y6lYoof3rhWLKQFXEcandtGAq8gAAYGyyVQh7KhJq+76v/JLt95McLFL3mzH1/wTaaJq872XxP8A D8F7qswkuGkudryOAA0smG25wFy2ASfVic5kui+FDK1vqnxd8G3MkYLeV5yOEAHY+YD09a66eT0q 0ues5Xtul20uaVKaXwJP1Z5df/Hv4i/sx/EWPxN+zN8cbrTJrwvMR4bvpUihlBGdycqQxAbHI+9x ivtP9mX/AIOPv2jPhhpUHh/46eGNO8VwTAifUbaFLa7IIIcgrmPzMkHdtU5575r6DDw5YKN3ppru Y1Iq55X+0N/wWU/aP/aM8SPpGmfEzUPB2hyuzrFoieVL82AI2miVWKqM/MRuODxyAPNfEPg3wl4s tRqPif8Aah0HUJr6ON3urmXUWmsiwZt0ryQYyNrKVDd89Ov02CxmHwtO0Itytq+39dLHl4jDVPju t9ur8/8AM8YurDwRa3ciWHx406URsVWZPOUOAcBhlQecV23gX9qn47/C8JB4A/a9vYLdOlk2pytb kDsYpMoR9RXtTq4OrGzrp36PU8+NbEN+/hpLzVv87ntfgD/gsp+1H4IjjtvEXiHwX4kiTjzJFitp dvsYiqZ92Rq90+HH/Bdz4H3Hlx/F74Q6tZXABDX+hajY3gyf4grLGR9MtmvCxeWYOprSqRT/AMSt 9zd1+J6FLEVn9mXzi/zSO+0n/gp7+y949uJZPCn7ZNx4c3KzRW3iPwr9pcnGRHm3CoDnjJbA4rkv EX/BSf47Cwl0vwrrXg26iSQeVr1lcW4lmjGetu87bScjqo9B615k8HTpfG16qSf4bmjnWey/A5gf 8FV/jn4K1SN/HYtryCNgxt5dPVFuE7hHQAn0ypOD2r6Y+DX/AAUY+A3xW8KW+sX96NGvXDebps00 csqbRnICkNtOCBuVT7dM8eKVOlHmgm/RNlUfaylyzR02o/E39lvxvcSXepz6Nezogf7TJaDzgecB X27t3XgHPNYGqx/sY65Gf7T06zuFdSDKVnWQdOA3Bz82cZ4wx7ceTOnhqt3OG++jOr2dRbHxNdfE HVdZ02Wz07QLudp98OVUwOBgglS2Dn8B/WqVl4y1f4e/De88C2Hw0j12KWIbLKa4mjXzAWG8+W4b cFkc8fTBzWq5YK1zva5jG8VeMF0z4paVrfwZ+DHiu102fSxDqNm6Naxvdk9VaeUggcDfkZ252jJz z3i39mUfEbxBceLfEev6lZrNHGEt0cTyRNzuEj4wTkkcfXJzT9rGm+aJKg5K0jMh/Yf8KXSvNH4w 1kyN2iCMB+GM1lXH7Bkupzs+i/Ei8SPn5J7EMV/4F5o9u386bx0lugWHS2ZkXv8AwT08Q3O3PxIB CnhjZ4YH2/eVxPib9lL4p+FtduPB2j3aXMNnbrf3F3BE7tFblzGsmwAsAXIQ9fmK845qqWMU5Was E6XLG72POtattY8Ka/d+GdXukmuLR1BmhPysGUMp/IirI1zUtQRoby9nkhkxuiLEKw+nTtXdGVzn 3V0eq/DT4I/AD4j6RHDYfEia014bf+JTq8EVulweMpHNhl55AJBP+zXv/hf9i39mbTXgsda8K6k1 5MQqw6lcqoduu1Xj2K5wCcKc47CuKtWnTdkkjeFNSV7s7PTf2dv2atEuxY6d8LrO4lVgjIM3DQk9 33SMVHua7LT/AIffCrw8Ujs/h1o1sCOCLW2Rj+Oa5JVZy3ZqoRXQ6Kxl0u0VbWy09IVPAjiMS5PQ AfNTotcgNz9ivIbq0nbdtjkAYSKO6spIPTp1HcCpUbjbsJfy6HqNo1lq1g11bvw0VxbNIh7dCpB/ KuO1H4D/AADvro6lcfDuFZBk7bWK4jX/AL9phf0rWnVnS+F2M6lONT4kLYeCPhfpCIPDK6tpE9sC 0DK99GIie/lOdrKecgggjNbcHiiO4iWy8SabIX+8t7FC4gcgfeHGUI689OzGrc3N3b/ISgobH5sT eLNZt42mTVrtigzhZ36Dkc5qfRfiD8QooRdr481aHechI7uTCj6k5r1ZQi+hyKcl1NW3+KPxWhBE HxN1zJOSXu2bnp3zV+1+L/xgt41hX4j6mVXpuZCenqVzWToQ/lNFWkupq2X7Rvxr02FYLb4hXKqO PmhgJxxwTsz2Her5/as+PQKbfHCDY3KvaW/zD3wlZyw1N9Co1p9yxb/tYftB315DYaf4iheeVwiR xWcJMjHgDG096+grL4P6/wCKNN0nxP428e6xp3ia3t5Inv8Aw7MlnIscylZINyqSV2sykHrluxIr gxNOGHs4rU6ac3V0ex8xftGfsbeIfhZdXPjPwre3+taJK7ST3F23mXNs5PJlIA3Kf7+B7gdT48kG 0sjO4I4JXg114et7WN+vUxqQ5HY1NNlhhCohAUAYHpXpngr9qH4i+DrO38GXeq/2joU7qHtbsBpI lUg/upGBKdBjqB6V0TgqiszNScHdH0do/wC3H8JLDSbeHTfCmqRlEVTbRxwhE9cEOM/XAzXpPw6+ Ofgb4lRKPC9+JblVDSWMrpHNGOvKMRkcdRke9ebVwsoLmep0QrRlojr01C4Vgf7KmI55zHz/AOP1 BqUkOoWf2bUtLuAgGQ6hS6MOjDaSQw9RWCSTLM3w740S5lutG1RWF5p7BXd4WQzIRlZCMfLnuD0I NacXiHSLmVYheRGTtGCmT+GatxtqJO5JJcF2zLkgDGBgY/Cqc+n2MoO+3j4OdpUdferirCuflImt 6aMh4mwQeqj+VWbXxBosMZVJVjUcEBdpP4V6/OjicCzp+u2WWL3KlGOEQ+n58Vpf2tp/G+5Vcjv0 pp3E4lhNV09GBjnVifXOPpSjUrR8Spgqey5I4NIai1se9/sf/CNNQ1E/FHXbUi2tyVs0eJ2V36GT j0/xr6Mkv7hrgpHcq0f90RuG/A4+nevFxc+edux30Y8sbmdfaa+s70IupYmyGgcnYVPbDYyPzr5o +Pv7Gmqf6T45+FukstuhLy6CmfMUd3iH/snPt2UZ4et7KWuzLqQ5lpufOrW93C7LI7qwOCGGMfhQ FIBSQq27+I5POa9pHCyU6rqWngILh0U9GQkD6VraB4u1LTb1NQ07VZIpkIZHjch1Yc5z1H5iqvcT Vloe9/CP9vLxv4Ylh0jx/Kuq2n3ftEzbZ419Q6gl/owJ96+jfAn7Svwz+JMLf8IhrU11cxqC9mIp RIg68qR068jj3rz8Rh+V80duptTqN6SLet6jq+s38N94X0p4NStPvXU8iIpjP/LORSSzKcZ6DnkH itAeLL2a0Ees+HQHAxIiPG6seegJyR0IrFOLW+poyG31vw9PEjW2nSQg5yYInQn/AL4X1psmuafZ AhdVuYEzwkwckH6vGT+tUl6CufllYaRNesjPEyR95TgEiluovDtrE832m7DNkRoGyXIPXpwK9lQh FfvOpxOcpO0TPDJLCJI5SoUsS0rgBgBkYH4Hue1WdMs7bUERxcsu5seUq7nwOvHA+nzDvXK5JHTy 2GJZ3L3klq1vIhRmALgKTj27fnWto3hPXdU1BdK0+CRrhmIEZyhB9OfzqKtSNOLk3sZ812fQ3hPS fH2kaBZLo/ie/tIY7cnyBcmLycKAWCgjqT0/2h6Zrd/4Sr4q6ZGtinirWbpyGPmW0rNyAOp6Ej6j GevY/LVc1hKbgmr3evQ61USsh0/xi8e2d8Y31TXoUO0YkZTle7HIPzEAcZ6k9aqzfHz4nxTtInin UI1XdtUwxP8AKOeuAOOBn6VtSdRpOVmmap6XTv8AIwtZvJfH9011feDob+7nc5uJbGKN5SM5yyYY n3J9OlY//CGaJaOr3Xw8hHmBnCTG4Vio64Xzhn6/h9Oqnj/Ze5KaT7J/5mUoxb13M2bT/BU16Y7r wlbW5QsvlL5xCnOMHdISf/11q2vgvwaFW4i8I27K2Oqs3PB6Entk12PESSvfQFTi+hoS6Ppskcdn D4M05Xf7qi1UEgDnpjPQfrV20hu/A95Hc6f4P8OwTxAPHJLaQO4HUEFsnJyOevTA9cJY6EbRlJ3Z MoRj0OmX43fEJpBeXGhaLLIjHeYrRDKB3yuAfx6e9X9J/aZ+IOoRvbweF9OeUqfmhjdGxkAZ2noe n9aaq0mm77D5hs37TniPw3bR2t74EtUBA5jeWMqTzgBtw5BPp0/CrWh/tY29mrPq/gaZrcthvLvD iPnH3dgB79xWlOUKkeaL0Yk0z4mXUXjBi+Zu4yenFSpdYCuWY49RxVzlJ7nntWAyxMVxGCSMeYVq a3uZYZE8mR1IPUHH0qJzlJ6iu2b3h2HWPEt6NOtmSSV88yKGMh3H7xPXr3r2P4afDi18Fwxa1f6z NLLOqlIGjGPnCtlscjBAGK8bNsy9lD2W7YRnyPY7OS/sXjZreRoZBtw0jbQhBYDAPXGVz6c+vC2k bbbdbaRzIqKXuHkDAF2AyVzkncDxg9M5wePkY1FFPQ3hiVBXNB/Dnh69WWRrbcRCxWSVF3u4CsHP QAfMMD6Y5JyW/wAOtF0nR5L/AMqe7njYkB5QuTGW+8uNvJOOmMgc8muinm9WjFRXlvrYcMTzeSKO o/D/AMR6eJptPjtJZ5CXVUZgwLFdqZyd3Cnjoc+wq7Lpuuz62dN1DU4bRFiWTEcrl1Xb1UEYOMED 72evsNamMpYhc7Tcl6HQ5RqK7VzA1r4YaVbXwhstWCsmV82LhHcMSDlju4GASM9DwKv+FNNt9FhE N7dqGuC6RM+CMkgHBxhgG3DPt7gV1yzKpXouHLZ9DSKk7po3L3wnEoczaFZ36bCBK1w6Ak7jsJG3 sMcckn3wKVt8P/Dd7pQg1vTBPJtD7FuH3LhMqgGcgHpx1xn6cUMfWgk4y1vpdbGU4yWzOd1T4b+D 5LkzWthqlk9w4SKBAG2ycMir65XnOT/F3GKuP8IdFh09tZstZvrN4ZD8s5+ZFXfgkYGA3BBI/DkE +pLNq9OC9oovp6lSjKOzucZc+H9Qn1eGwuvE15MZApRTEwYK3GRyRjB/HpWnrPgLX3gbQ7HVLmeN Y1mjVAAsiNwFwQDvwDn15HU89c8ZSpKKlTSW+/b0IvbQ/9n/2wDFAAcFBQYFBAcGBQYIBwcIChEL CgkJChUPEAwRGBUaGRgVGBcbHichGx0lHRcYIi4iJSgpKywrGiAwMy8qMycrKyoBBwgICgkKFAsL FCocGBwqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKgIH CAgKCQoUCwsUKhwYHCoqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioq KioqKioq/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0B AgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpD REVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmq srO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foBAAMBAQEBAQEB AQEAAAAAAAABAgMEBQYHCAkKCxEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEI FEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVm Z2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgB4AKAAwEhAAIRAQMRAv/aAAwDAQACEQMR AD8Ay8UY5r3jwbC4oxQAYoxQMMcUuKADFGBQAY5pQKADHajbQAYpcUAGKMUAGKMUDFAoxTEGKAKQ MXHpRigYYoxxQAY4pccUAGKMUAApcGgBMUuPagAxRigAxRjBoAMUYoAMe1LigAx60YoAMUYoAMZo xQAYoxQIMUYoGGKMUAGKMUAGOaMUAGKMcUAGOKMUCDFGKYwxRikAYoxQIMUmKdwYuKTHNABiigAx RigAxSbTQMixzRjikIXFL+FACYxS4oAMcUYoAMcUuKBhijHfFAhce1GKAACjFAwxilxQAY9qMUAF LigBMUuKADFGKADFGKAFwaMUAGKXHtQAYxRigYYox7UCsGKXFACYoxQAuKMUAAFGKADHNGM0AGKX FACAClxQAmOaXHFABjnvQBSAMcUmKYBijAoAMUuKADHNGDQAYoxQAYpMUALikx7UALijGTQITHSj HtQMMUYoEGKTFAwxzS4pgIRxRigCHFGKVxBiloAWjHFAwxS0AFLigBMcUuKADFGKQBilxTCwYoxQ AYopAGOaXFMYYoxxSAUjBx/KkxQAUuKYBj3owaQgApcUxhRjvSAMcUYpgLijFIAxRigAxQBTCwYo oAXHrSYpCFxSYoAXFGOaAsGKAKADFGKYwxRikIMUYpgGKMc0gDHHSjFABijFABijFMAxRikAdqMU wDFGKAExxS45oATFGPagQYoxQMMUmKAIO1LikIMUuKBhilpgGKXFIAxRj2oAXFHagYY4oxRcAxzS 4FAAB0oxQAY4oxQAYpQKADFAFAMAKXHNACY4pcCgAx7UAUAKRSYoAXHFGOKADBpe9ACYpcUAHejF ABiigAoxQAY4oxQAYpcUAFGKADHajFABiigQYoxQAYoxQMKKBBijFABijHtQAY4oxQAYoApgGO9G KADFGKQBj2oxTATHNGKADFGKAACigCvj9KXFSMMe1GKYhcUY5oGLRjilcBaMc0AGKXFABjtRigYu MUYoEGKMUAGKMUALijFAwxRjFAgxxRigYuKMUCDFGKYB3oA5oAWjFIAA4o60DDHFFAhcUUwDHFGK QwxRj1ouIMUUALijFABiihAGKMUXAMUUAGOelGKADFFABjmjFAgxzRimAY5oxQAYoxQAYoxQAYox QAYpMUAGKMUALikxQAY4oxQAYpMUXAgxSgUhhjmgCgBcUYoAXGaMUAKBRigYY4ooELij8KQwxS44 piDFFIYUYoBhj2pcUAGKMUxBijHPSgBcUmKAFx7UY9qADFGKADFLigAxmjFAwxRQIMUuKQBiimMM UdKQB2oxTAMUUgsGKAKBCgUYoGMkWQlSjBcNlsjqPSn0AJilxQIKMUwDFGKADFA6UAFGKADGaMcU AGKTFAC44oxQIMUYoGGKSgAA4oxQIMZFGKYCUY4oAgxRSGLS45pAFGOKAClxQAUYoGGKXFAgxS4o GGKKAClxQAYoxQAAUYoBi4oxQAYoxQAUuKADFGKADHFGKADFGKADFGKAsLjmigAowM0AFGKADFKB xQFhMUuKAsFGOaAQfSjFABijFAB3oxQAvekoAXFGKADHajFAgxRigAxRigAxxRjmgAoxQAYoxQAY 4pMUwDFGKADFGKADFGM0AJjtRigLFfFLikMXFGKADGTS49KADHNAFAC49KMUAGKXFABiigYtGKQB RjmmAtGKBWDFLigYgoxQAuKKAClxQITHNGKQxcUYp3EFGKBhijFK4B0pcUwDFGKQBijFMQY4pcUA J3pcUgDHajFAw7UYoEGKMUAGKXFACYoxTAXFGKADFFAWD6ijFABijFABiigAxRigAxSYoAMUuKAE xRxQAYoxRcAxSc0AGKCOKAK/FLSAKXHrQMAKMUXELijigAxS4oGGKMUXABS4oEFFAwxS0AGKO1AB ilxQAUYoAWjFABijHFABiigAxS4oATFLQAUYoAMUYoAKXFABijFABjNFABijjFABilxRcAoxQAY5 4ooAMUYoEFFAwxRj1oEGOaXAoQwxRigAxRigQYooAKKAExRii4BigigA70YoAKSgAxRii4BjNJin cCvS0hhS4oAKAKAFxRikAtGKACimAUtABilxSAO1GKADFL2pgGKMUgFxRimAlKKQC4pMUALiigAx xRimAYoxSAXFGKAE7UvtQAYooAAKXFABiigAoxQAUUAGKMUALSYpgGKXtQAYoxSAMUYwKACigAox zQAYzRigAooAMUYoAMc5oxQAAUUAJiimAlKBUtjSDbxRRzA0JRTEVhSj3pAGKWmAtFABijFAC4ox igBQKMUAAooGFLjvQIMClAoAKKAFxzSYouAtGKADFLg0AJilxSAMUuKADFJRcAxS0AGBRigAxRii 4B1FGKLgLRQAYopgGOaKQBilxxTAMUUAHajFIAxRimAUUAFLSAMcUlFwDFL7UXAO1FACClp3ATFL ikAmKKAEoFFxhzR3ouIO1GKAD8aO9ItaiUU0SyvRigQuKXFACUvegBcc0UwFxijFIAxRigBaKLgL 2pKQC0YpjDFGPai4haXtSGgFGOadxBRQMO9GOaBBS0gE96XFNjCjFIYUUEhiigYuKMUCCjFAwxS0 CQfWjFMAoxSGAFGMUALijFO4goxQFgxRii4BRjvQAlLSAMUmKAFxzRjigAoA4oAO1BFMBKOaQ72E 5oxxQgbuFLigQYpMUABHOKNp9KLlK4EGikmgcWVsUuOKokKO1IYuKMUALRQAtFABjilxQCCigAHS loAKKADFGKA6C0tACdqWgAooAMUUALik70AGKWgYYoxQAYooEKaTFAC0AUAGKXFAwxQRQIXHNGKA DFGKADFGKACigAxRigAxRigAoxzQAY9aMUAFFABijFAB9KMUAHNFABSYoAPxoxQAcUYouOwmDRzS uCQDOOlLyazbNkg5z1FIcgUkMrUo6Vsc4CgCgLC0uKACigYAUYoAWigBaKACjHNAC0lAC0vekAUd 6BC0UxhQKBWFx60d6BiUuMUgDFGKYWDFFABilxQAYoxxQAYpcUAFGKADFL3oAMe1FIBcUmKYC4op AGPajFMQmKKBi4oxQAUfhQAUmKBC4FGOKQxMUYNMAxS45pCDFJQAZFJximMKOtILCYoAPrSaGnYM GjBpNFqQgzil5qSkwwe9GB60rjK2KXFbGAY+tKBQAYpaQgxRigYoFGKYC49aMUgYEUYoAMUYoAMU uKADFGKBi0dqBC4oFABiloAKMUAGKWgAxRQAY5o/CgBcUYoGGKKBBijFABS4oAKAKADFFAWDrRQA UtAAOlFACY+tLQAY5oxQAdqMUAFGOKAFxSYoAPxpaAExRigAxSYoATFGBjrQMTFBHvUspXE5pQfe lcLC0nGetTctJB2pOaTGH4UE/wCzSBFfHNKBW5gL1pcUAJilxQAdqXtQAUcAZoAaHUtjmn8YpXHY Mc0dqADpS0wDFGPWgAopAKOlFAC0UAFFFwFooAKKYC0UBYXFGKQBR0oAPaj8KACgigBaTFAC0YoC wYoxRcBccUUAGKMUAGMmgCgA70uKAEAo4znFAhcCjigAooGGOaKLiE70celFwDcM0mRQAlJQxi80 mPaleww5zSc1Ni0w5FBzjoKVhidaTAoGLxRxSATA9aCfekBCDR3rYxFpc0xBS0hpB3paACmSdB6Z pARoG807o2CdpM8E+mPWp1qIt3KYtFaEhS9qACg0AFGKAFx6UYpDDFFMBaKVwFwKMUAGKXvQAYoo AO4qXyRuA8+Lp1+bH06f5xSbsCQyPDyFSenZQeuAcfr+lPKRk58wD0ABNSpO+xTSGYGeDmjjNXcg KSgYuBRQAdKKLgLiigQUuPagBKKADig4oAKM0AJmigAyaM0AHNIPegYvNHNFxBR1pXAy9dv/ALBp 7mOZopmXMZWMNzkcHJ4784PTGO442PxdrdvIpe4juEB5WSFRn8VANaRSsJu7sbFt48Q4F7psierQ yh/0IH861rTxVo90P+Pn7O392dSn69P1qZRsNXNWKeC4TfbzRyqejRuGH5in47VF0VYbijpTYxM+ 1JzSKQdaQj3pAJijAoAMCgj3pXGQUtaMxDjNAIpgLkYpc0DFzQCKQhaCARg9KBkKqfPYb2K7chc8 A+tTUkhsWlp3EFGRQADFLntSAM0UAFL9TQAdqKAFpetABS96LjDFFAC4oxQAUYoAYg/ey/7w/kKk OSxJOSeTRoAlFAgo6UALRQAUUAFFAADxRmgAowaADnFGKQBiimAUUAJkUZGKBiZ96M0BYXPtR26U XCwmaM+9K4+U43xZcmS68tTwvH5f5NZ/hvwtf+KtYSxsIzjOZZmB2RL6sR0/qauUuWNzNK8mevad 8LPCmion9rNLqtz/AHWJVSfZEOfzJrqLLR9NtgP7O8N2Vso6PJFGjforN+dcMqkpHZGKirI1BaRS IVuLa2fPVfKBH6jmsy98JaVdkmON7Vz/ABQtx/3ycj8sVCk0W1fc89nQwzyRN1jYqfwNRZrrWqMG rOwZFISPWmITPFJn2oAXNIT7UAITRRYCGitTIOM0tABkZpc0hhS0CFooAZk+f/wH+tSUgF5pOaAF 5ooGFFAC0UAAopgFKKQC0tABTsmgAyaMmkAZpc0wDNGaQDE/1sn+8P5Cn55oBoKKACgUAFHagBcg 0e1AB7UcUwAUufoKQBSfjQAfjSUwD8aM0gsGeaQmgYY4o7dKYaBij60hgAKKACmyyCOJpODtGaQz mtG8M3njHxJ9ktTsiU7ricjIiT19yew7/nXtem6baaFYjR/DVusYj/1sz8/N/ec/xN7dqyrzu+UK MdOYZqOp6R4Th+0andM91N90D55pvZV9PyHvVO3uPFWuOJIUj8O2RPBnQT3Lj12H5U/Hn61y3O6M Eo80jatNGS2k8ya+1G8lz9+4u3x/3wm1P/Ha0MZoM27u55h4gg8jX71MY/elh+PP9azcCuyHwowl 8QnbtSY78VRAhBooGGKTFAgooAixS446VoZhilxxQMMCjFAC4oxQAYNLzQIZn9+Bn+HpUnekhhS0 AJSihgBo5oAKWgAozQAtHAoGLRSEKBS4oGLiigBKKAClzQIYn+sf3I/lT80DEzRmmITPrRkUgDPH SjNAC7qN1ABnilyM96ADIxRuFA7BmjNArBnJpM+9ABmlpjEzR+VIA5ooYBQBSGhe9GPegAxUctnc 6jJDp9ghkuLl9qr6epPoB1J9M0bahLY9N0Lw9B4d0dNM04jzW+e5uccsx6n+gHYfrU1/Xhogg0nR LYXmr3I/cW/UIO8kh9O/PXHpXDOV3c66NPaI3QPCSabcHU9WnOpa1L80l1JyIz6RjsB0z+WBxW+5 KoxC5OMgetSXUnzPyHRMzQo0i7WZQWHocc06mZnn/jKHZ4gL4/1sSt+Xy/0rnz9a66fwmM9xtJVk CfjSY44oAKSmAGj8aQDMUVZmLiloAKMUAHelxQAuKhuLq3tI/MupkhX1dsZpXGc/deNLKG5At4pL hAME5CjP480weOrQ/es5h9HBrP2iRr7NtCjx1Z4/49J/zFA8c2RGRaT8e4o9qg9mxR44syeLS4+u VpT43s8ZNpP9Mij2qD2bEHji0P8Ay5z/APfQpD44gz8tjIfrKP8ACh1EHs2N/wCE5iAybBh9Zv8A 61IfHAxxYH/v9/8AY0vaj9mxv/CcEHmwH087n/0Gl/4ToY/5B5/7/f8A2NHtBezYDxyD/wAuIx/1 2/8AsaePHCnrp5/Cf/7Gj2qH7NoX/hOFz/yDzj/rt/8AY0ieOBg7rAnnj992/wC+aPaB7McvjgHr p/0xN/8AY07/AITb/pw/8jf/AFqXtQ9mxv8AwnK9rEfjLj+lB8bnOBYg/wDbX/61P2gezbE/4Tg5 5sFH0m/+xqWT4hymyjtv7Oi8uNy4YSfNk9s46dKTqDVOxCfG8qHEmnBT1wZSDjt/DTX8cSlf3dii n/akLZ/QUe1F7IQeOGGS1iuTjOJSP6U7/hOH6iwTn1lP+FHtA9kIni65ZJLj7PCURuYzcANyABhe pHBOfemHxzLkYso/oXNHtA9mIPHkmcGxiH/bY/8AxNH/AAncgbb9gj56fvj/AIU/aoPZCnx1Ljix j/GQ/wCFC+OpCObFP+/hH9KPah7IR/HU2393YJnPUyEj9BTl8czBBvsI2bvtlI/TBpe1D2Qv/CdN nB09ff8Afn/4ml/4Tr/qHA/9t/8A7Gn7UPZi/wDCcntpuc/9N/8A7GkPjhgMiwXP/XY//E0vah7M B44kz/x4x/TzT/hTW8cyg8WEf/fwn+lL2o+Rjf8AhOLk9LKEDv8AMaafHN1ji0g/Nv8AGn7QPZjD 44vscW9sv/AW/wAaRfG+olcmC29sRt/8VS9ox+zNrSdb1C9jS5vIra3tGbarkMGkJOAEGeee/T8e K6DvVwk5GclYMUtWSFFMLBS80higZNeheDNGjtNK/tJ0/wBJugVVj/DGDwB9TyfXj0rKq7RKgrsu 63qp0m1jjtIftOoXTFLS2H/LR+7N6KOpPp9ar6D4fXSBNdXcv2vVbs7ru7I5Y/3V9FHYew9gOQ7L 8sfU1jTcZbrTMiTFJgUAcZ47hIns5gPvIyE/Qg/+zVyB4NdVL4TKpuIaTpWpmIelJQAGkoASg0gE xSirMxaKAFpOPSgBHdIkLyOqKOrMcAfjWPe+KtNtAQkhuXH8MQ4/Pp/OplJJFJN7HN6h4x1G4ylo q2yeq8t+Z/pWDNPPPIZJpGkc9SzZNc05ts6IQUdSMg7en40m3HPY1BpcNqnpx+NO2/LgDP40DFVO OTk+tP2MBwAT9abEJ5b45Bz7CnFWIBKk4oAaquT/ABEegqUDjGO3TFAbDSjEkdKQxtnkH34oAcIm 2kkbh9KUI2TtyaTC45UbPzKGx2HWhEKg5B/Ki4IkROMrj6YqRIXkPyrlz2A5oAvw+HtXmQNDpV3I D0227H+lTL4N8QMNyaLej1HkNiizARvBfiQcjRrwfWFqgbwvr8Jy+j34x6Wzn+lOwDbjTrxg76mt 7HKqYTzIWJJHABJIwPzrL2OAQTgd+1JIegoQnkHAx3NA3A5UGgLD7iee4dXnllkZVCgu2SAOg+lQ SAkfL+oouFhoBK/MMEfWl5I6EUBYRQd2X4/rTlXcSQfyouFgCMDhePxoXduI60CFZQi4JGT601ck 9N306ULYYo+98wwfTFO2Hqc49aewmCo3UZxRtBGSDkdsc0gEKZ4A/OgAjOVI9sdaGwQm3cw6hs8D HWuhttIt9GgF94hBMg5jsVPzN/v+n0/PHQlwehVOs3Oq6zazznaizJsiXhVAYcY/z+Fek45xV0JX uYz3DFGK6TK4YooAMUoFAyW3ge5uI4Yhl5GCL9ScCvWrieDSdJRSGMduixRogy0h4Cqo7sTgD61z 1nsjSkrsoadpskdzLqWo7X1G4Xa205W3j6iJD6DqT/EcnpgDQauc3k7saeBmm/xDjvQiSQ02gDmv G8W7R4ZMf6uYD8CD/gK4I11UvhMqm6EzTelbGYlJQAc0hoAKQ+1DAft5pduKq5mG2jbQABaULQBZ huQjRLPbW00KNlle3RmI74Yjiua1LxhqtjfPDBpmksinAJtRuH1xxXJVg1qbwlfQrjxzrh6abpY+ lsKB4518Diy00fS3rGzNbgPG2vb9y2enKx6kW/JqQeN/EHH+j2P/AH5pWYXLVv4s8QzJuWHThzjB gJq2PFviQDH2XSj9bZqWwzKn+IniCPUTay6Vp65B2uIGCtjrjmnDxtq3BbSdJf8A3rUGnuD0FPjX USMHQdEP/bmKafGt9/0L2h/+Aa/4U7MV2IPGV0D83hrQm9zZr/hUq+N5R9/wnoDfWzFKzC7BvG7M cHwhoI+lqv8AUUn/AAmhIwfCOhn/ALdU/wDiaLMd2KPGSgf8ihon4WyD/wBkqSPxXFPIETwVo8jH oFgTP/oFOwXZo/b4ERWv/DOhWYbkLsRnx/uhP5kU06zozzrFB4f0tgzYLzWyKBz1wP5ZqlDqxcwu maMNR8QaVHPYWcbTXoXy4reNV8pcu+QBg5VDz7ivYrTRrOzQLa2sUKjtGgX+VF+xSWmpZ+zIOqim nyV6lRSCyGgwnoVP0NBWE9QKVwsN8uA8Aj86rXGiafeDFxaQTA/34w386d2IyLj4feHJ23PpFqD/ ALEe3+WKrv8AD3QAP3ej2XT+KMn+tO49UU5/AmlRr+70Kwc+m0rn+dYd94dsbIEt4JSVR3gIb9A4 P6VOvRhzHN3ereDrCTy9R8ISwP0w8Lof1aoz4j8EL/zJsrYPX/MlK8guRt4k8D/9CZN+DH/47R/w k/ggDH/CGzfr/wDHaLsOYafE3gg9fB0w+mf/AI9R/wAJL4GOM+ELjP8AwL/4/ReQcwf8JH4FZcHw hc/99yD/ANuKibWvAbEH/hFL1T/syyj+c9F2DbHf2v4Cbg+GL8f9tZP/AI9Thq3gIf8AMuX30LyH /wBrUXYrjxqvgH/oXb4f8Cf/AOPUf2l8PiTnw/fD15k/+PU7sLgNQ+HnX+w9QH0aT/49SG/+HpXB 0jUPofMP/tWi7C5Zlfw5pWnwahomnMl1dR77d3dv3YDlWJDM2G+U4xggHOea5a+8y8dpJ2LO3c01 qhN3M2zQw6lChP8Ay1UjP+9XrBxk/WtMOrNmVToJxSiuqxkHFJjigGwxSgelAHQ+C7EXPiBJXGUt lMp+vQfqc/hXd+SJrtbmUZ8vIhU/w5GC31PT2H1NctV+8dFLRXJjTT0rE0GEUgHzfjTEx5AxSUgM fxRB53hu64yU2v8Akw/pmvNWHNdNJ6GdToN70mK3MRp6UUAJSGgA6CkNAywFPejbTMhdtG2gYu2j bQAbK24NMs5NPSSS1hZ2kQMWjzn5GPPrWFbY1pbjpNPtIbO6khtLdHjt5GVvIHBCkg8ivPvD/iLU 7/8AtlbmeEi30ySaJvsUOUcOgDfc9z+dc25uJ8Nde1PxFrN7a6zLBdwx2ZkVTZwrhvORc/KoPQnv 3r0c6VZZ5srf/vwKdrDa0RZfQ9Nm0K8eWyhzDa3DoVXZtYKuD8vWvDvh9qMusfEDSNOvVDwXFwFk QsRkAE46+1ZvccVdntd9oNg+rzzm0iO1mRU8pdoG7PT196i/sTT/APnwtv8AvwtWhMq6rpFjDoOp Sw2dvHJHbMyOsSgqcjkVyeiWvmrqJnlMvl6fK6bo0O1hjDDjqKVxG1o/h+2fUsTsbiMRS5jkjTax 8tsZ47HB/CsfxRp6W/iOaCyKW8KxRERpEuASgJPI9amMmwtoW7jRIZJYVjkWHFnbs2LdDuZowzN9 STW3B4b0tNMtTcwRSyeVueUgIWO9uSB7YH4U1J3sCMq/TQLfKW1ikr+odsCsK41LyUMWnRLCD1Kj /P8AWtlpuJ6lI200v724kbL8lnySf8alsGzeCGCEs/lsUZxk79p24HQfNj1qW7jSsen+CbET+K5r gKfJ0+z2Ln/npK38wkZ/77r0PbgVC2NGRyEKhNc9qEx8wgHFBLM3zXVsxuAfUAZqRL+7Q5Eu8ehF Zt3Gi1bau8kqJJEuSQMr1rTFxtlUEDn0qosGi6jK3AIJ9KeVGKsDx34p+MPEXhrxpBb6VqLW1q1m kqxiJHDNuYMSGBz0FYll8bNat8DVbCx1BB1KBoHb8Rlf/HapWJaOlsviv4L12MW+rwTWG/grdQia LP1XP6qK1T4J8KeI7c3Wjvbyp3lsJgQPqBkD6ECnqhGTL8KrdGJW5mZe3AzVR/hvZocNcXK8941/ xofkFiNfh3YM6j7ZKQTjhV/xrmdR8P3Vpq95a21lDNDBO8SSMSCwViMn5vaocrD5TUbwTdPY2E1r ZJK89v5sy5x5bGR1AHzdMIP1qM+CNTx/yDB/31/9eo5xNCr4K1LcA2mYBIBO7p+tVNV8PzWGsXlp b2XnxW87xJIWwXCsRnH4U+cLGzpvgSO/0i2u5pWtpZgxaIR7wuHZRz+FTH4cxdr0/wDgOf8AGqT0 Cw0/DhccXv8A5LtTD8Nz/Der/wB+Gp3CxheIvDzeG5LGIzed9rbHClduX29PrzWVcqtvOYmydpUE jvmrjsS9y5pGmR3GuI0igNb/AL0HJBBVhjGD/Ou0bLuzMcljkn1NbU11MZvWwmKMe1bGYuKAKQwA pQtAHoHgey8jRpbph81xJgcfwrx/PdXQmuKp8R1Q+ESmkZrMsa1NH3hTESGm4AHNAFPVIzPpV3EP 4oXAHvtOK8pauij1M6mww9aSugwYhzSZoC4lBoAQik70AO/tGzwD9ojwefvUp1C05/0mLjr81Z+0 j3DlY5b22cZSeNvowp4uoC5QSpuAyeaftI9w5GP82LOPMT/voUebFjiRP++qXOu4cjE+0wBtpmjy CARvHGeldPaqG0uLHOZE7Z/5ZtWdSSaNKasx00RktLmNNoeSCRF3HYCSpAGWOBXnmh+Cta02LWWn itS1zpskMKrfQndIXQgff9jXPc2SE+GnhPW/D+s3k2s2kMEUlp5SMtzFIWbzkbGFcnoD+VekmP2H 4KP8aq9ynsi+kbyeHtRSJGd2srhVRRksSoAAA968Q+G/g7xBpnxM0e81DRNQt7eK4JeWW2dVUbWA JJHFZN2Y47ns95g3tweP9a3Xb6moMj2/Na0JK+oxPdaHqNtAEaaa3KRq0iLuORxk4HTPeub0jQtQ tU1Az26jzbKSNNs8Z3MSuBw31pPcR0Gm2ctvctJKoVRFIM7h1KkDv71h+ItD1S+8RXFzaafcSwMk QSREyGwgzjFZxVgd7El//oVwEuEZJEtbZSjcYIgQEfgeKxb3Wbq8RIWcrCgwieoyT/U1pGNnzBuV lt5ZlLMNsYGef4v8aEt0B3LHjP8AE/JP0HQU2ykiOfT3kbu2TyxNbukaC1jctPKY5HaNSpQ5Azz1 9f5YovZDS6no/gaz+z+HPtTDD6hM1yc/3DhY/wDxxVP410mewpDKtzJhMVzOoyDzj0x60nsT1MmT DdGH51CZJ4zlJF/PFY+hZYsLm4uNQiSSJTtJYkEHoOOn9a2xNC9/iaVhsAGxQefxA9/WnF+8J7G9 A67AqKFUDpjGKmyMVuJHjXxn0xrzxTpLx43GwlGD0bbIOD/33XltzpN1bIWntZPKzycZH50J2E0Z dxZLEdykkVJaXl5p0sdzp9zLbTr0lhcq4+hHNaIR3/h74165pwSHXYY9XgXgucRzAf7wGD+IyfWv VfDvjnw14sKxafeCO6b/AJdLkbJCf9ns34E0muwjck0uFmyE2t6jisS88IQyyySxSuryOXYnkEk5 J/M1Ds9x6ont7KSzgijdC3lwrFuUdcM7f+z1LujzgsB7Hj+dZSgxNjlQFlx3IrjdXUNrV+fW6l/9 DNRYaNmxUf2NZDAP7tu2f+Wj+xqbYMcKP++f/sa3WwMAg/uD/vj/AOwp2wZ/1X/jv/2FMVzhPiQr DVtDUnjCEADGP3ze3+FclqSA38v/AF0iH/oNaLYl7m3oC51m4PpGf/QhXR7K6IPQwluKVo21VyQ2 0baLhYNtPjiZ3CINzMcAepNFx2PWLO1Wx0+3tVxiGMLkdyOp/OpD15rherOuKskIRSGkMjakX7wo ESbeOTUbUANIB4bp3rya4h8i4kiI5jcr+RxW9J6kVNiEgU0gV0IwYmKQgYpi0ExRge9FwEIFJgUB uefZnwPkYHHXCH+tKDPtwYn+uxP8a+d0/mOu0R4ncLg2zE+6r/jThcScgWjDPBIQf41SstmNKIqT lIgn2WViO7ISfzp32kkgC0ccf88z/hTvfqO0QEx3c2j/AF2H/CvYNIAbw5ZYGAREcbT/AM8jW9G9 3qDSsXPLHp/46f8AGggKpZsAAZJIAA/Wuogpi+d5gEjURtkqWUZIGOcduv6U5LxjcQxFF/ehucgY wP8A69Iqx1WhyKkLSSMqoiOWYkYAyKuJevcFkMOxGXI3OQxUkjnHQ8evekwuci2oPJq08LqFG53y H/2yMdKmD8cN/wCPf/WpokN3HBP/AH03+FLyezf+PUwEK923Y9SGqhqdrrDQ7tK0g3Cn70m9Q34K Wz+lCQHNSW94hMGpWE1o78qJIyMkexGSMdh35qEWSx4fILOOWJBPXoB26d6UmUkWre2aeRUKADGB gZYn3Peta08NT3lyFt4C/QY/xqUy2tToz4Lh0qAT3tx85P7qMDLb+oHHuKi1dIJbe4tYhsm1G58i 1MZDZMh5cn0CB2PPehisdjEiQRLDAoSKNQiKOwAwB+VI74UmmBTu5DtJJ+lcvfks5PvSlsStzNkw P/r1Efn4LYHpmsLGhr6HEsbSTbTjG0ZP51assTXO9/lZjlT/AEqoL3iZPQ6GAnBBHIFWMnFbMlbH mXxV/wCQ3oxHX7LcD/x6OvNrq8e3VlQnDcMMUmh3sY93EtwvzLgn+KsqWNoWMYIIzxWkSCJ9uzJH SoIW2EMvVTnrVDPf/hF45uNftpNF1aZp7u2i8yGZzlnjBAKse5GRg9SCc9Mn00qKhjGmIHtUb2sb DBUGlcLEB0yHOVXafVeKoXHhiynkZ2Rg7EsSGOSTyTRoKwg0EwwRwxSHZGCq7hzjJP8AMmoX0i5U /KqEe5/+tT0E7kLWFwn3ofyUH+lQmIr96LH+9Hj/ANloYHG+PvL/ALQ09m2gRwRHJxhf9Ib244z6 VxV46PdyOjBlM8XzAjBHyVUdiZCy6ld6bdtLYklmyGAVSGGc45/pVqXxDeyRbzcyI8g3eXEF/d8k Y5Az69TSdXldrkuKNdPEEctgc3EazqoPzfKGPp7VnnxTstyiCR2Z2ywb5l6cgd8nPHHSr9sujJ5S 5Za/HNo87G6KXER+UTqu4+mOef6VFpviKVmKXYIAZjvkOOM+w546etN1LWFym+uoWhxi5hBIzzKK 3PCKR6j4nt0ieOWOEGaQq+cbcY/UiqlNWEldnprdabiuY6gIpjdaAGEVHIjOhVW2k9/SgCR2GeOl R5oENbrXmmvRGLXbxcf8tS358/1rWm/eInsZppp69K6UYCYJOMGk5NMkTvR+FAxM0lAHB/ZJu0s+ Pr/9aj7JMOfPm/IH+lfMc/kddmN8iUN/rps/7o/woEEucC4k/wC+V/8AiaOddgsx4tpjwbmTn/ZX /Cn/AGaUf8vRH1Rf8KfOuw0h628uf+PoH/tmK9d0pP8Ain7MHk4i529f3VdeGkm3ZDexb2Y/hP8A 3z/9es68ZprtrV0IiRUc/KMSZ3cfQbenfv79pK1YxWZ7tRGjOVVskbQP4R1J5pu949Y09HUpuE3U r/dFCGy/H4ms7PXIdP1FzHCATuyCCx2lXb/ZHT689q6CTXtItY57q41GBYYYxvffkdX4HqfpSYW0 OJtdUuJ/Etw/9mXscRhLLvwrFS7ENtzkZ6YPNdAXVjiAySHbnLI64Poc0wasixpNg2qaRaXplYC4 hSTAPQkZI/Or6+H4z95mP41d0ibMmTQbdG3bMn1NX4bUw/dJ/Gk3caRaKLLEY5kV0PVWGQfwrHvv Buk3u4xxvaswwTC2B+Xb8MVDLRz1p4B1jSdSFzbX/wBvgj+ZUYfNkdMqeDWtP4tTw1ttW0/Zctjc CpT19sH6jj2oC7RRXxHcX0slx9oVHdOIihPmLnHysQCuPYnv060/QQ2o+J5JyoW20uHaijp50g5P 1EYx/wADpW1C9zrRnFIdvl5Jy2eB2+ppgU542dTtBYnuax7jT5HYkKT+NDVyOpF/YDuAfMI9iKP+ EcyMllB9qz5S7l2HTTBYCLILAckd6W2t0TCsQMdM96qKsTI04xtxzntU+eKsEef+Pwr+I9IDruH2 a4OMf7Udeaa/DE0/7gggdRjBFQ9yraGC77k4xkc81lzzKJM7T35rSJnYpsWkPTinKrMOEXj2qij0 n4J2Mz+OnuQhEdtaOZCBx82FUH9T+Fe+5B6Gok9QQopaRQY9qAKBBwTTtqGgAEKMO1MeGPpgGmFi tNp9vMpWWFHB7MoIrLuvB+iXefO063JPcIFP5immS0Y9z8MNCmJaKOWE/wCzIT/6Fmsi6+EsRH+i agyf9dYQ/wDIis504z1YWZkXXwt1iPP2eezlHvGVJ/z9ayLzwL4htgd+liZccmFFfP4Bs/pWPsWt mNNGDd+H7y1t5ftGkyRABsb7Jht/Gq6WUQQFLZFPHS1bNTKM1ux6MnjiAXasYUf9cnGP0r234XeH JNI0ObULuIxXF8V2IykMsYzgkHkZJJ+gFVTTvdk2VztSOaULXQMCKjYUAMIqIkbwBQA4imkUxDTX kfxJlFj4sLi3Z/PgjclR3GV/9lrObajdFw31OQ/tJVOTZyA9fuj/ABpzawjoI5YZQq8jMfQ1z+2m VaPYadRjCZMUwXpyrVFJqUBADpNjGBjf/jVe3n1JtT7Eg1KB49hEwXHq+aaL+3QghrsenzSUvrEg 5ab6AdVgxxdXa4/2m4qQatAI9gvLgZ53FjkfmK0+tS3F7On2KQu26+UR+P8A9akF2/dSPxrybkcw v2mQ/wD66QXMp4BXPoadw5mI1xIXdMx7kbawH8J9DSebMBjcnPtRZj5ixbX0NsUlvGjYyMY0jI6n YxDYHJwQB6c816HoGqJP4ZtXmntUkEu0qW6KqMMkbvYc9Oa9GjFwinbcpa6DbjxZpNrkG/glYfww QtIT+IJH61h6h47g83fa2V1JlQu4xqg43epPr6V0ptoaikRp4mS4RZorORJyqho0XcqgYyA24H8S OtUb6bxPqEgW032MLj5CI8Se/wA7evtWbi+a99DRaRsWdB8H6nPqDX19qcZaGMkyXE7SMMEcd8/i cVmeIYZ7zxf9l/tCcmKGOSGGKEynfwchQw7EkVqtTNvaxB4c1nUU8TpGL2C6m5jMTu0bqOd2ck5x z69Ohr07T9TOoW0c0FnIOBxI211+oOPqOxHNJvlQ7cx1PgQ7/BdkjBt0BkhO7qNsjD+WK6MKPSqE 1YXA9KMCgQvSlB96QE0Nx5WcjOar3QiuUZJ40kRjyjqGH5GgZjTeG9MYyNBCbV5QA7QMRkDtg5Hp 0xS6NpEei2DWyTGd5ZnmklZdpYk+mT0AUfhQBpU3cR2B+ooEMZyepP0VajKKw5LUCYCOPplsUeWn Zm/OgLC7f96kEa91zQDHBQv3c49DUg5FAzz/AOJdvqn2zTb/AEqynu1hilicQQtKVLFCMqvOPlPP tXk+pr4kvpiZNJ1EnuFsHX/2Wi1xmcvh3xBcnA0PVmJPazkP9K0LX4f+Kro4j0C+wennR+UP/HyK exLsbVn8GvE0+DcpaWYP/PW4DH/xzdXSaZ8D4EcNqmuufWO1hA/J2J/9BouB6LoPhvTPDGnfYtHt zFGx3SOzbnlb1Zu/8hWlmluMPNNP8zpwM0BcXzWHSjzSaAHLuboK5i58YfZtSeH7Okluswj3iTBx uClumOMk/QU0rg3Y29V1JdM0+W5cBimAqZxuJOMVnaV4ni1DTru9nh+zQ2svlFt+4OdoJxwP7wH1 zQloK5SPju2+0bPsjlB3Eo3Y9duP61vW2qWt1pq38coFsyFt7cbQCQc+hBBB9xTaEndmOfG+nicr 5NwYv+egUc++3Of6+1bb39utgb0SB7fyvNDryGXGQR9aGmgvqZQ8X6UT/wAtx/2z/wDr1afXNPXS ItSzI1tKdqEJhickdDj0NDTC6JtOvbTVbNbq03NEzMgLJtOVYqR+YI/Cs2Obw9rOpNYG3imuQGO2 S3zkKQCQSMdSPzosIr6bZeFbjVdmmRQreRguALfBAUgEjK44JHI9RXVLIyjli3uaVkgRKshNHnDP Ck/hQNifafVG/Mf40GVD14oAjeVOgNRbkDA7v0oAUyL/AHqTemeWFILiF0PG4CvNvippz3V9p81p bR3jeS6OAAxUAgjPBPO5vyqKibjoNM89Ok3YJH9jEA/3Yuf5Vk+Iba5s9EuHOlvCCAnmFPugnrXN CE+dXGpHCw3M1iVniaVFfIDIcBvUZ6GtnT/FaoVW8gWUd2DsjfocGvUnGnP3SXF7m7barYXjhbaN yx/hMxU/kX5/CrWY882twR7TH/4uvKqwnSdmClccDCV3GK5O7kbWY49vv+1MxBgER3o/Bv8AGseZ juVz5h78e1R3jmztEnkOQ86wjJx1zz+lc8IuUuUjlZpLotw8CyB1DHnyzwRV638NutzamW43GSRV CRoWOSeBj3rq+qTWshxV2ULKx05rvX5b27Xz47sGJUkH7wMOw6nB4J7VFaaJJqLSDzZcvkIsAy+e 2SRgD9a7PZQttuVy3Zbi+HaWs3najqUUU+cFTIZHH4Ln9akg0jw3Gsrz3N5K+PlKRABj/vZOfyrV aaFWSLouNDgSJLexmQJ955ZGbr3woBx07VclvtFSVhutowAMZUpgkZ/iAPQiqUVuyeZ3si3Z69a3 FsZDcGV4yI02R8bB0yQKsnW9KEpDTGRh2d0hVh/vO2R/3xRawN3ZH/acc0he1Fgc5yI5GmZPyKr/ AOOmuc1FbODXLvVtTvLf7XFJHHDCygMf3asHCqoC4yBnHrjOKhuyNacVzpGpo1zaxK9tc2EGoC8I Vi/3mJ4Aye3Pp3zVvRkub3WWjt9ZkWOKeSOWwil2yiPYArxg/e5wQB0C46k1EJKSN8RS9lLQ9N8D wpaaDLbrJK4S6l/1wO7nB5JAz3P4888V0m8VocvUTzKDJQA3zB60hlHrQAedSGXNADS5pm75/wAK AHbiRRn3NABk+tGTQAmDRzQDE5o59aBCgccmjtxQA0ZycUbnH8RoAaWbuaQu3rQA0nPU0m3jIbp6 0gE85kPBPPb1qQTK45jIPsRTATnGQD+n+NJhz1RvzH+NIQ4NLnAQ/mP8aeJmQ/NGRx1bGP50xozt e1t9O0eWVZAkjDZGBx8x7/hyfwryi+u3fTLt1D4WOQIx6MVByR64YEfUGqRLOs8b60zypa26mUri QxqeXkbhEHucj/vqjXLOTRvCumWKuriJyZ2B/wBZKQWZvoWLH2yKAMmTULdfDthpOnWjzXkm2W48 tMvPNt+bHc8k8nAAA6AcWNRupdL0qz0JQLiWI7p0jbIknkcsIwfQM4H5elFwJ9csbLQNFtLQbHu5 GMtzdFfmfA5Oey5PA6AL65NOvtRe08HaTpx3CWeBJZVPVVPzBT+J/wDHaL3QCeHv7Bu47e0v4pjf yZy7TOqO3LbV2sAABwMgZx61N4rvorK2ttMsIf3VnECsIb0GEXJ9u59aL6gjRtdc07RvDcdtbX8U 89tBgbM/vJDyT07sSfxrE8N3P2Kz1PXJCcxJ9lt8/wATkhmP5+WP+AtRcC/4EiLS3mpMDjAtYie+ DukP57B9UNdkLqk2CGteKVZWBIIwR615J4rvPEGga20drqczWsrF4xIPux54+YHkj3ApXKSujKHj XVUHzaxMCPVGH8iaqy/EjxBDMyw3FzKg6P5gGfwJouDihf8AhZ/iERsRcyKykABmGW+nWr9r498W XEsUVvdSTvKwVUjhjkOT7Bcn8BRcTSRsxeJfGxs2umljESBt3nWoRht65UqG4+lQQfEbWpFBbU9L Ge0kEgx9cLTuFi2PH+rKcHUNCb6+aP6UrePtVcYc+H5l97nH8zRcOU4HxJe+L9Tv5ZY9bsViZiUt rS7SJUXsvy4B+pOa5C+t9VmtzHeWNzcuGJMiXYkUjtwM/nmto10lZoHDqmDeDvE1tZs8mj3VjE+C FvEKCQeoDDnHrWTeaJcWpJeNh7ryKzm03dDi+5WS1vVh8+GN5IlOC6DcFPvjp+Na2m+K7yzxHcp9 oiB+7IOR9G6/zpPlnHlmDhfVHW6br2makAsTbJD/AMs3wD+HrWlmH0YfgK8itSdOVnsSjo/+ETgw MTqB3+U/41halFBYReUgS48qTcjNH0bpkZzzXo0aEYzuE5aWM+21CWSYM2SobnNdfoeswS3L2ccC PcphklZcEHOQQPXt711VdRQRx3hvRIJPiHd6X9pGWkJaInLjgkqMjBI717loX9h6AWWLSzIxXa00 wBYj0AAwB7Vg0axdoo5T4jawNV8gIiwTxnECRjDHPQAdSc44AryGXWXDmN5Wyvy8npimZ3e5Y0CV 9Rv79ftBKpGpRSuSWPHbpx/nmkn1KdJPKlKgg5K+WF7AdBjsBQnqU9iXR7uW58QJbxuqJJC7yHZu J2AkY7j8CP0qXUL97e9linEed2M45x15P407itZEWnaoy69py25QPLcpCc9MOdpPX3qn8R7uSz8X zfZzH0Riy8knaEx9MJ+tKWuhpBuLUka3hHVDdSWcpJ4kBPPQg9P0qOLTGvNctrn7QlssJzNcMQPL QZbcM9SCMY77sVzU/ddj08Q1OKl5HpOnfE3T9AsIo7uK8vTcDzUkTbkJwAGJIywxyQOvbirf/C7N JPTS778WT/Gt3NbGdLATqxU09xD8a9MxxpN4f+2qVGfjZp3bR7v/AL/r/hRzo1/sup/MgPxr04Lk aLdn6Tr/AIVWb4zLKzNFp7W6KMqrR+cz/jvTb+TUKSM3l1RdUXF+M9gT/wAgW5H/AG8L/wDE1Ivx k03+LSLv8JVP9KXMi/7Mn/Mh3/C49JPXSr4f8CQ/1py/GHRt3zadqA/BD/7NRzol5bUXVEg+L+hd 7LUR9I4z/wCz1KPi34fb/l21If8AbGP/AOLp8yIeAqrqSD4raB/zw1D/AL8p/wDF08fFTw6eCl+v 1gX/AOLp3RH1KqPHxS8N93u1+tv/AIE1IvxN8Kt1v5U/3rWT+gNF0J4KsuhKnxG8JSD/AJDKr/v2 0w/9kqePx14Vk+7r1oP94sv8wKLozeFrL7JMnjDw3IcLr2nfjcoP5mpl8SaGxwmt6af+3yP/AOKp 3IdCqt4sswahYzkC3vrWX/rnOrfyNW1DSDKozD1UZoIcZLdDWXHUFfqMUwqRzighjDTTn1FIGIE5 yWFPAAPSgQ4DPOcU4dfmNAxBchcgIOe5qKSZmI570wOE8YX8t5qcdjZEPIjCGJT0aZyBz7DjP0NQ +K9LhsbexsIiWiS0MG49WwTlj7ksSfc0ySDw9C17rj6hfFpYdMi+0ysf45MEIPwAZvYhKfYQT+Lf Ebi+ldYIYxLNsOCASQkan+EHDEkc4U9zkMBtnJHD45tzpZMdqk0rMFYkeSsbbsknkZ29e5Wn+GVO qeLHvbrG20Rrpyx4Ej5VPwA8w+xUUARXsg8UeKDGxxZKN8zEcJbJ1z/vdP8AgR9K6b7L4f8AEeoS XQAu5YSpkBaRUPXbuU4BHB4xjjmgGcyrQXfjhJLZUjs7eU3L+WoCrFEvUAcDLBR/wKptNtX8Sa9c G5aRIlQyzNHjILHCICQR0DHp0X3pAyv4j0+10m6W3sGnuJigJSRlJZmOEUYUck/zFT+Ic6ZpthoN rtmkt0BcL/y1nc8fmzE/8CFAW1Oz0uxTStKtrGNg3kJtZwMb26s34sSfxq2TUsBpNc94v0Yavozi Nc3EGZIuOT6r+I/UCgpHjVzBycVReIikUmYPiG3kkigEcbvhjnaucdK39OJgihONrIijI4I4qkTL U9E0TxAuuwnRvEFxP5N0vkm5jl2v7B+oYdOSMj1xxWdrfw01fSpx/Z6PqkDE4eGM709mXn8xkU2h Rl0MWbwxrsSEvouoD/t1f/Cs2ewvLb/j4tJ4f+ukTL/MVDLTIQBgZFMkTcPk4IOTjv7VNxnU2mrL FaKkFuI0xwqHAqRdSjzk24B9c/8A1q5/rCTs0QiQ6lGy/LESMc8j/Cs+7s9FvVP2nToSx6sFCn8x VLERZS0MS48GaLcEtbyyWzdsMWH8v61FFp+saaRHb3kd7AOiz8N+B7fnTlVpzjZg7M6BfEGpqCFu yRjugpuqvDL4egnyBM07mUgAcnH6df1qcLWlKdmZSs0YqXSNweIwMc1NJqS6fp089ogZ40JDkctx 3PtXbOSSuxrRGP4R1KbS9WfxFbR+dcW0ku1ZTgShkIO4gZyM5pde+I/iPWrXd9se1hbOYrRfLXHu 3U/nXPCrzNp9DRRu+U5jSU+26mWYvJHGjSzPwGIHAAJ6Ekhc9fmrT1Swu7W98oadHPNJai4ZAZA0 AyCejcnt/wAC9emw2iKbRp7doT9ncNeZKI4IC464UknjnkmtKawML2dzepdzw3RdYVgIklkxkAk5 A6+memKBeRRg0q7uUW8smlcEFdjuIWGBznJAI4z8pNX302+ktYm1G7EiQMEObpcqCSSqlzt65P3u pNK4PYksdMSz8RQXjXMlrbWdyrss5G4KH6ZXjOOOvWovF9wur3+pX8Cl4451aN9wbfHtAJ4PTcPr 8/NNMdrakfge4lTUmt48FndXjVjxnOD9B0rt7S1vdQJ06wWM2okWa4aSYW4kUr90u3BBO4BRnqTW fL71zpdS8OU9T8JaTDLom7V4dN1G58xgZ40WZCMDhWOfxxxnNbv9haR/0CNP/wDASP8A+Jq2c/tJ rZijQ9I/6BOn/wDgJH/hS/2Ho/fSNP8A/ASP/CgPaz7sP7C0c/8AMH0//wABI/8ACkPh/RTjOjad wcj/AESP/CgPaz7ijQNGHTR9OH/bpH/hSnQNFPXRtOOf+nSP/CiyH7Wp3EXw7oYOf7F07/wDj/wo PhnQWPzaJppH/XnH/hRZD9tU7jW8I+HT10LTfwtUH9Kjfwb4cZdo0e1jB+8Ik2bx6HHbPNHKh+3q fzFI+A9OcsJZMqWJUJbxKQCc4yVOcZx2o/4V14X2/vNPeR+7m4kBP4KwH5AUNXCFepF6MT/hW3hU /wDMNf8A8Cpf/iqY3wx8Kt/y5TL9Ll/8aOVGn1usupXf4U+GGyRFeJn+7cf4g1Wf4QeG3PE2or9J 0/8AiKTii1jqy6kL/BfQWP7q/wBST6vGf/ZBVaX4I6aV/daxep/vQq38iKnkRusyqLdIqS/A2Aj9 34gf/gdiD/7Uqq3wUvITm016DPvbsn8iaOV9x/2in8UR6/DPxlanFl4njUDptu50/ktOHhT4n23N v4gaX/uIuf0cU7SF9Zw0viiBg+LtmQVmFwB/t2r5/Pml/t/4pW3E+iJcY/6dVbP/AH7YUryC2Dn1 sSJ478c2/N54PZgP7tpOv65NTL8Wb62/5CXhC6hHdhMy/o0f9aObuiXhKMvgmWE+Neg/dm0zUIT6 jY382FWYfi14XnI3T3cGevmW5P8A6CTVXRjLBzXwu5oQePfC1yP3euW6n0kV4/8A0JQK0U13TbqN /sWpWMsi5CqZ1ALY479OnIzTOaVGcd0ZGh+GbyLWxqd+YpljRmj8pi+ZG4LE4HRSwH+8fSrPibRb rVWtmtTGrRbgwkYrwcex9KdzKzJNE0Iaf4dksbpgZ7re9y6HI3MMYHsqhVH+771z48Na9ZyTRWOx o5wFklScIrAZwGz83c9Aep607iNvQvDMWl207XUiz3lzH5UsiDCon9xM9u5J5Jx0wAMI+F9bt5Jb ezEZhnAWSXzwiOBnG4fe7ngA9aVwOi0zw7BpukT2fmGWa6Ui4uNuC5IIGB2UZOB9e5Jrm/8AhHvE Nq81rZxjyZwBJKs6KjgZxnJ3Y5PAU9e9FwNE+F7mw0KS3sdlze3br9ql3BBsXkIuT90H8Tknvgav hvSZNJ0opdAfap5Wlm2kEA9FUEeihR9c0XAyrXw/fz+KxqWqRoIY5GmULKG3OOEGPQZzzjlVqld+ HdduNTe9EKCbzfMR1uFG09iOc8dqLgWbPS/FIv7c3V5LHbiVTK32oP8AIOSAMnOcY/HNddmhgIel Mb1qWNHlfjXRBp+rGaJcW91l19Fb+If1/GuRkh56CmN7kBh9qFjC4zxk4FCQNl+0bYwxXsfg7Xf7 X0kRzuDdW4Cvk8svZv6H3+tW9UZdTpFqlr6yT+GdSiBJzayEDPUhSR+orN7MtbnhRuEfgpyPXvUT IueYVH4CvHvJdSrgGEYCrGce1OExPO1qzae7J1HK5OSVYU7ccZIJHvTsx3YoYA5VcU4PFnEkec9x TVx+pibnLAAZYehqQ3UjWhtGQFGcPknoRUwqOEuZGZGE+UARj8aSX95A0MiDa6lTgdjWs8ROasym 2RWFklharaQ5kXliTjJz61X0yb+y4zpN5HmzuXLQyKOc8ZB/mPxqqc25O/U6MNNRqrmMXWtAfTrw X2mktDu3lUGdp69PT1rS1DUZr6RL+CVFleIxyxuWAZW5xlSDweRg16FOakkb4il7OVh+v6jc3eh2 z6fNPD9mj58qUgFe/Tpzmq1tdarrGmWkmnxT3dxbHbsjDSAADbggdOO/v1rU5TqdX8O60fCWmW1r EZdRBEkiwqR5behYnBI4Hbp361kDw94sOixWc1tdC4eUsA0y7RznJIPX35piui34re38NeG4rSTU orzVryTz7tI03xxN2T5iVYAf7P51w9lK4c3Ehj8pnxJgCNMNwwwOBwegH0p2GdXaaZF4P01NQluR JqN1mS3j28mAAjzG5+UEkAL3wScYFdv4StrrW/Dt3rmoXFk9lOuE0820L7pVyqtgptjxyAQNx3c+ pGmlcpSTR6B4KimPhmL7JcRwRb32xi0jTHPOQgUZzntXRKl6P+XuM/8AbHH9aDFjwt7j/Xxf98Uu L7tJB+KmjQNRf9OHVrc/gaUG97+R+tGgai7r3H3IfzNKHvP+eUR/4FRoGookvM/8e6H/ALaU7z7s D/j0BPtKKYXYC4uu9ifwlFH2q4A5sX/BxQF2MN7Nn/jxl/A0fbZM82U/5UBcb/aDDrZXX4R5o/tM f8+d3/36/wDr0WC4o1RP+fW6/wC/X/16b/a0Xe2uh/2y/wDr0WC4h1m3HWG5H1iNH9u2YHzGcexi NIdxv9v6b/FJKD/1yb/CmHxDpmcee2PXyX/wosK4z/hI9Kz/AMfD/wDfl/8ACmnxJpPe5Yf9sX/+ JosFxv8Awkmjk4F4c/8AXGT/AOJp41zScZe82j3hk/8AiaLBcG8S6HEMreM59oJP6rUbeK9OLcXz j/tnJ/8AE0WC5E/iLSZR+9vVb2eJz/NaqSXnhefJmjsJPeSzB/mlFilNrZld4PBUvD2Wkn/tyA/9 lqtJofgOYkvYWB3ddu9P5EUrFqtU7lb/AIRLwIH3W6JbMe8N7Kp/VjU8egaPGMWnifV7cekWrcfk QaLMr28uupZj0m4T/jz8bagPTzmgn/mtTrZeJFH7nxRaXP8A130pB+qOKA9pB7xHAeLo/wCPQLgD 1WeI/wA2qaO88QrxPothL72+psP0eEfzoIfs3sSHVNQUfvfDt/8A9sri1f8AnKD+lKutKDibTdUg PvZtJ/6L3UC5V0ZOuqWjDObhB/01tJo//Q0FOGp2BOPt1sD6GZQfyzQS4ssLIki5jdWHqpyKXqea BB2pO9AgNMagZkeINKXV9IltsDzB88RPZh0/Pp+NeRTQsjsjqVZSQQeooQ3sVXjOPlxmoTF5jplS pRt3Tg8Ef1qiC3FheOB9a2tC1s6NqcV0jcLw6g/fU9R/nvVcysS0elP410KJNzX6EEZ+UEn9Kzr7 4lWcKAafEl4G4ZJY2UEf7x/liuaVWEepaPMrpLcMDDKcMOVKYK+3/wBfNRDco+VuM/hXlzte6G9x WXd/EBijynAJGCvrmp0HqMC/KSSc+gNKAc42jFCFYeEyOg/Ojy1X1/BqY7GQUZTwwAprKBzuyMc1 i0jMduG0Atgn3p42qD82eMEnrRYTQ1h5mCjkn2NO2MFw7EA9adhkMizJGTbSKSeqyfdP+FZGpbrl cXVt5TAAh9u5fxIOQK66U0j04YiNSCp1PvMzSGkXUUt7uIzWuGICsSq4BPFdSfHV/bwpY+G4Y7C1 jHzLFHkqPU4H616UXdHPUi4uxX0vXtb1PVYrV9YkV5pAF3kRqRnk7mGAMdzxWb4h12/iCpbazLPt ZkkA6Aj0OMGrsY9dDnrZo7lp5b6eV5iu2AeWHDuSPvEsNoxk555xx3rqvDOlHRNIvNb1aaWC3QtD HAAu28YjhcMpBUHknB6Y60LuU9DR0LVZrvWW1vxDEb68hm8mQTRAxMrHOGxx8pGMccMOldO+/S7o G0fbp93txGgwqEdMDt6flWblqUo6GTr2qeL7TU4o/Dl9qUVr5KsI7e4ZFLEkk7c/ToMVXTXvikMb LjXX+is/9DXZDl5VcwdyzH4q+K0WOdaP+9YZ/mlWE8b/ABRQ5J1Ljs2lof8A2nV8tMhtky/EX4mo Pmjum/3tJT/43UifE/4ixn95as3+9pgH8lFV7OkTzSJP+Fu+OYhmTT4OP71gw/rSj40+LUOH02wP +9ayD/2ej2VN9R88i/H8Z/ERiDPpumg/9cpR/wCz1Kvxr1pSN+naaf8AgMg/9nqPZQ6MPaMk/wCF 5agPvaVYH6O4/rT1+Od1/Hols3+7csP6Gl7Fdw9oSr8cXJ50CM/S8P8A8RUy/HGL+Pw82fa//wDt dHsfMamSj43WhHOgTfheg/8AtOlHxv0/+LQ7kfS5U/8AstL2L7j9oh4+N+lfxaPeD6TIf6VGfjxo i9dI1EH/AHo/8aPYvuCncaPj9oP/AECtTH08v/4qnr8fvD+edO1Uf8Bj/wDi6XsWPmHj4++Gu9lq w/7Zx/8Axyl/4X94ZB/49NY/79R//HKl0WO6EPx98Mf8+erf9+Y//jlNPx78Ln/l01j/AL9x/wDx yj2THdDf+F++FxwllrH1KR//ABymP+0B4exhbLVx77I//jlL2bAgHx68P5yLHVv++Y//AIukPx78 P/8APhqv/fMf/wAXT9k+4hD8etBPTT9V/KP/AOLpP+F86Gemnaof+/f/AMVR7JgIfjzomP8AkG6k f+BJ/wDFU3/hfWjbR/xKtSJ95E/xpez8wEPx70ftpOof9/kpp+PmldtGvz9bhB/Sj2fmPUb/AML9 03/oCXp+t0v/AMTTD8fNOzkaBdH63i//ABFP2a7hYafj7Yf9C7cf+Bq//EUn/C/LIH/kXJ//AAOX /wCN0lT8wsNPx9s88eHJv/A8f/G6a3x+t/4fDUh+uoD/AONU/ZhYjPx/Ufd8NY+uof8A2qg/tBvj H/CO8en9onH/AKLpezCzIT8e137v+EXhye/23n/0XSn9oGT+Hw5EPren/wCIo5F3Hysib9oC7/g0 C2H1uWP/ALKKZ/wv7Us8aDZe3716TUe4cpKnxx12b/UeG7Zvo0jfyqUfF3xVKP3fhu0XPTcJB/Nh WUpwjux2Q4fErxfKQDpGmRZ/vOx/k5rCv73XtRv5bmZdNt2lO5hGshGfxNYSxEFsK6sQSR6ikJZ7 qAtjO1bdgP8A0I/yqWBHeBGlc7yMntispYltaEkixj7uBntTfLfowUAelcrqSluw3HdMjGfalRio wG4qGJWFYuThQSPpUfmMrYAwagq9hd5YfLgUo3gccUICQDcPniOPVTTCi5LKrHjvTKFUEAhkYY7i kDEHgkem4U+ojNb5T83ApnB4U5/Co0JQ/wDdgDgEnvjpSvHGASkgOeaLCAR7QAGznk5p7KgYMFGc etFhjWBCgjIHXNV7m4+zKpmgcI4JV9vDYPQHuauEHN2QjDvdUgkuFh020H2oSEeYVxkfhg+vXit+ 00R9PH2uGcLO8eMWr+YpfGQCpGSM+hr0qS9mrSep1xpuUbp7FC4vEvpHfU7FG5+ea2xjPuP/AK1Y NzosDkvbTo6swA55H4V0t3M0rM0bnwjLZyfZUSX7XHl2aRAu0FQV3KM4PIwdx+lWtL8Wa1oVk2ja xZprWkNwbK6ydozn9233k5544z2pK/UqXJokdfd3Ntc2a2GgRzx3N3L+6tbtQdpbpgjh04PIH15N VNQ1uHSNMubLV7G6RhnZbyIQ8Zzja2RwPQ9wQahx6jlPZM4HxNdfaNSt5WCFmsoC2MHBMYPbvz35 9ayFZQchQD6gV3Qfuo52izDf3ERzDdTRH/ZkI/kauxeINYhwYtWvlx/dun/xrW6Ymi3H4y8RIRjX NR/8Cn/xq3H498TKvy69fcesxP8AOmox7EEw+IfiwYxrt1+JB/mKmT4keLkYY1yfr3RD/wCy0/Zx fQm7NCL4l+JiCH1iZiP+mUeP/Qalf4o+J44wBqhPput4j/7JT9nEnmZAvxJ8VXDHE8cvrmyh/wDi atWfjTxVfIzQWtlcAHBzYxE/yqHGCLVzRttb8VzKS2jaOMY4ntYkz+ZFQv4k8RRuwfwrpb4ODt07 cD9CprP3O49SrN4zvYDi78LaNGe+/Tyv8zUY8dowy3hzQ/qLQ/8AxVaKCezJuOHjW2IyfDmhn/t1 I/rVeTxXZSE58MaKT7Qn/Gj2b7gn5FaTxTZIct4T0dh6+Ww/rUR8Xadn/kUtI/ANT5PMpEUnirT2 PHhbSwf+Bf41EfFNj/0LGlfir/41HL5jID4mtC3HhzSx/wAAf/GmHxNb5/5F/Sfp5Tf/ABVTy6bl DP8AhI4c5/sHSf8Avy3/AMVSnxJHjA0HSP8AvwT/AOzUuXzAB4kQJxoWkZz3tz/8VSf8JGn/AEBN IH/bsf8A4qjlCwn/AAkY/wCgPpI9P9G/+ypf+Ekb+HStK/C0H+NFkOwh8QyY407TBn/pzWo312Zw f9D05c+llH/hSaQ7EDarM4wYrRf92zi/+JqrJOZGywUf7qBf0AoukOwzzOcc0bz2BpcyGkG5s4xz Vy20nVLwZtLC5n944Wb+QqXMdkaUPgbxROQE0S8Un/npH5f/AKFitS1+FXiu5xvtoYAf+etyn8gT UubFoaEPwb1hiBcajYx+yl2I/wDHQP1qc/By7jkGdRSdP+ma7W/8eqHN9AuWD8J4RFkrfq4H8bxM p/FTkfkahb4bGDA+xCQ+vnZJGPTI/lWE5VLaBuQnQILI4k06OLB+9JFkD8TT1t40JESLGe21QM1w ylN7ikmT7yicyHHak89dxBP6cVkRshVlTOd46djShlPPA+tIRIVRlGGOaj2AdWJGaCmhVGT94Z7U 9gXQggH60rAiDeI22lQcDjrQHDDlSO9O5ILIF4PrSt+8GUOCtSPcbh42+Y0rM+cbj09eKAWgwrJs zExyfemfaJo2G7jGKQaliHUJQ3OPpipjOsuQ6j8qotMwlLZG8E/jxUwjIyVHaoIGYyh3E9etLtxn OWAHrQLcfw3qT0zmhW4I3Hgce1IAJfb8uT6+lVLaeePxC1vOoNncIuS8e5RgjIBI4JKjpzXTh3ae pUdzoJvBemzOLi1uJbK6ZOEkg8+KQHn+8GXt61g3Xh/UohgT2sPY+Ujru56HnHTvz1rsaUpXZqrp 3RyuraRdaTNiIyBDyJAflP5VW02WVdTgEyJOGcKUkzg54ycEHjOevat09Llc1zsG1DULea9ilupm t7l1csHIBwPX0HTn0pTcsyr5kiSZ+75q/n8y/wCFKnNSjcjfUj1dxq3lrcLK85dIoX8zOzHQ57AB e44ArdsPFEX9kRaP4rVNVUR4dZ45meKMZ3FJQrOBwD6Z7AVdn0Bu+5wnjlbaDxfdW9g0r20CRQwm YNv2rEoGdwB7eg+grnsmulPQlIcDxShqq4WHhzT1fJqkyWiZZexqQOO1bxkZOJf03TrzVrpbexia SVh0XjA7kk8Ae5r0PQvhv50yJcytczD7yQ/JHHjrlzyfwwaipOwJHW23hLRbFgiwJczZ6Qx5Gf8A fcEt+AFb1t4auSgENhb26DoZWJz/AMB5x/3yK5Gy0XI/DVyM+bdW0a+kUC/zwKlPhxMY+2SH/tgp qbjBfDiqCHuJGHoIV/rmqtx4I0m6B86zikY9Glt0bH5AUJtbCZk3fwr0WfJ+yQqf+maSJ/6C/wDS sab4M2MrZieWD/duC384/wCtaqrJCsZd38F7pNwtr5mX0aNTn8dw/lWHdfB3X4hmJ7aX0GWz+gNW q3cVjGu/ht4nt8500yAddkij9GIP6Vj3HhbW7bIl0m8467YWYD8Rmq54saMmaCW3fZPG8TDs6kH9 aiIJ5FHmUOjheaVY4xuZugHekYFSQRyDStoGl7Bkd6Q7ev8AOkUAO44UZPoBWjZaDrOokCx0u6mz 3SFiPzxis5TSHY3LT4ZeKrvBaxW3XOMzTIMfgCT+latv8HtWYA3GoWUeR/CXbH/juP1rJzGaEHwe hyPtWtNk9o7X+pb+lalv8I9BQZmub6b6Oig/htNTzDNK3+G3hiDBOnNPj/nrcOf/AEEgVpW3hTQb biHQrH2Lwhz/AOPZpXYGjBZ21sQLWxgg7/uYgmD+FTyTOSAWbPuc0gF3svb8cUCYk4PB+tMViQSh V4x15yc03eFXdt5z65zQAqOrnC8nuD0pfKiZy/lx7hwG2jIoEI0Eci7XhVh1IZciqEvhzS592+zj 3E5yvHP1FS4RluO5k6l4RtmAFrbzsT0EcigD67iKyj4Q1ERl1VVIziN2UnH1GR+tc86F3oLQpTeH dViUF7XcD2QAnP4VXk0TU0GRYz7R28s/4VzujImxE1pfRTBPs7gk4I4z/n2p7rdRIXmtpAg6krjF S6TGkQGUEdBkdMDk1NHKCmGwCO3Qis2mhWaFIjcENjPsaVo0X5hkjpUjsMKRMcA4bHP+FIwjVv4f qaAaQBEJA9e4NSmGHcFDlcc0IEkJ5IU/Jkge/NNMZZQJF3c9aLDasNaCLd8h/MU0xjcfnwB04osF kZyzwufm6D0HWnGYLkDaFP50kIJHifhcAY6HvSfKoDc8/rS3ExCVKkBSemMH9acNipkDn8ecUWAU S5AH8PUgU4OMqWb7wxtxxRsMsR6jPFENkzggYXnI+lRSajcyEeZLuB9V71vGs0VzaDLlmvLdoJNr Bhgr5eQf1rHg8OxQ3EcySyZRgwBQf41f1iXYLmu0DSMvmMemPlG3P171narDpdpAxeURzDlY4mwz e3H8yKik5c1oivY5tX1PVFEMcfm4b7xXO38TwP8A9daF1Y6rf2yNGGuJ4BtfaNzr3+p/z616amlK 3Ue5zt3GZL+QeczEtgvMpQk+4PSrA0DUigZIA6t0Kupz+tVKqobj0sI2i6nGPms5PwGf5VGdPvkG Ws5hj/pmaaxEH1FoNNrcpkvbTLg4OUPFM5X7wK/UVtGpF9RChl9akU56GtFJMlo9F8CeIdMs9OSx nxBPJITPLnDSdduD7YAHpknrgj1fSNSsmhkiieFUkj2jjGPQDHQVnN3eoW00N/w6IozKzMBKQMLj nHsa3doPLc+1QwRHcXMdpEHZGOTgY/qewqt9qvLlP9FgjQZ/1rtwfpkAn8qRSStcWO31Iv8AvLuN VPZY8n9ale1uHXb9tce4jAb/AA/SgLpES6fKoGL24+pEefzKmlaJYflnvpNx6bmUH8gKBN3IWgbO 5bq+YfRAB/30opQZSPkuWOP+ubZ/75jP86AuhHS46maNcdC8A4/Mr/KqN3JsiL3OoWLIOT50Hyj3 +VjQkxXRy2oeKNBj/dT3Om3anr5UMy4H/fJFY95qPw4u4yLnSkLnrJHACfzOP5VrGnMlyiYL2Hw3 eUSIL23kVgyPGSApB4yM4rOn8MeBL2Z5I/El3asxzhrUsB+lbKFVKxHNG9x8Pw+8KSj9x4vt5Se1 wGhH8q19N+GtnHIr2U2lalzkqkof/wBDGK5alKqy1NHQw+GzYoscWnC35w/lQRsSPqucdOxzVjzm t7xTLasHKDLtE2FHYZJ9/SsXFrc1TXQtNJdOy+RLDGF6CSMsT7j5h1q3F5io3nzIzZI+VCv6En+d NXGO2qZMGTnHp+vSnCBFIGW5PTBoAUw4GcjHrnNAgA5BIOaYIbxGnysCfypnnEvnKEAduufSkApc 7O3PQYHNNEb5BYqRj06UwHhCQoJyWOcU7BUctnjjIxQIU4LZ+X2OOlPTIBVSmAcE8UCAtnAAwQeo p2cjGFOM+lADmHIVW5PfpSAAEgjqPTkUxDSpwM9Cf8/hTPLBXBJ49P8AGkMqXunRXcZjlx9QBkel Y1x4bfOLZvl29C5yT261lOnzDuZ914cvSFWMM3HQkE/mKgHhfUQA5jjYEgAZANc7ou4XK8+j3tvJ 5rWkq7TnIXIH1I4qnc200MY8yK4TPKkoentWUqTT2HdFY2ckrfuXKsB0kXaTnuajMFwjbX2E9+ay cbbhYsoZDEFGBngkjgelRSB8DKbicHnjHrU2YWuiOOcmaSPbhgcE9ambdtwrqMZHU0ahYiMjo7An BPcHFL5jGMlQWPcjtQTYxzBIoGQyc4OVqREZ/lLAADqTnNKw7DeOVyM5GDnmrAVDhg6K2OFJ5NFh WEM6hQpxycZpjXSod3OV4BxQAxrpmRGzjPpxStfoZBznZ1BpWZLHC9RsB8Y7DvSG7VTtUDcOgPei wXHidhnC8sOMV0WieEdb1tPNitzb2xHNzOdiAe2eT+FaQhKbsijL16K30HVn0+JxrMoUHdC5htxn s7A7sgj7q4PvXL3lre6tf2815LE6xk/uYotsaKOQoGQTk8Ek57816HPToLlW/Ui2t2aICIi+VG8S j5Qsb7R+XSltHSzu5Lu3acOWAcmQkNxgcdK4Y1JRdylItarFZ+KLJhsjg1OMfu3/AOemB90n3965 fRxPaXUkbzPEijmLGcn29K7m1OmyzoBeqFLSKRjBB9evb8KT7TGcGNydw429/avOFqRo5IcpIpyc sAaBHNOmNoJUc881SuFitNZxyY3xZBxzjv6UhsIdz5t0znGGQYrRSkuo1FmTq9h5AWeONUQ8Mqno fXFP0nxBf2DKsN06DPAJyB7c13UpuUbsa0Oy0L4pXdmWF8G3Rjgx9Sc/lXpGg/FvTr7bHcSpuPG1 /kb/AANbIlo606jp2swr5N0EkH3Vc4H+FallcgoIJcrKgAKtxn3HrTFfSxowxLK4XeFz3PSmahBd 2RjEdq1x5hwHjYBV92J6frSBK5nyJJJMYJTLJKoy0cIKIv1bqfz/AAqhcTR2QIE8asesVqoyfq3/ AOqmSzltX8aNp3zvFawJzh5mMrn6c1yOpfF265W2LOezE7B+QrWnSc3foS2locrefETWrtzsuTFn tEMH8+v61jXGralfSbri4lkb1kck12xhGOxm79SrMZhFvM2fp0qg93KDgsQapysOKTGfa3PBJxR9 qbH3jS5yuVALuQchiKkj1GZCCHPFHOHKjYs/GmtWWBb6jcoo/hEpx+Wa6Kx+LWtwALO8NyvpJEB+ q4NS1GW5PK0b1l8WbGUgahpCc9XgfH6Ef1rZtfGPha+O37XLa7uSs8RI/wDHc/zrCeHT1iNVGtzX tjaXQA02/tZ84+WKQEn8M8fSrbRvaHM7OnuUJH5jNckqcos2U0xI7y2Z8G5jyOxYAip1IKlwN3Hr 1FTYdxHRWBIY9fXk1E1spXIbaW59aLDTIzYoib97nHJA9KsKmEwpz+tJBccYdqgHJyT046UhU4BB IJ54JpiuALAZbBY9RnGKcTtXdjgevTFACBmTBJwD3B/SlaZQVCnPpznFAhzMGcZIPfAP5Uu4EY64 /D9aYDQRkFeB3p2QzE/TOec0gGABVxuGRkkkY69O9NC5IOMke9MBdpwSMsBznpmjkDrjj8KQAflY kPz9DSciQAIBgcc9D7UARz2kFy+6e2ilPrIobP6Vk3fhqxndTbQxInIc/McccYGaiVOMkF2Z8/gu QMBbXaALyQ8bDn8zUS6LLbzxwtcWUrddrOwJ59MEVi6FncdxktpBgxPFHHckAIIpDuBz0+bH8vxq CfRheQefOJ4iB/y0tgoJ7Hhc/jz9aHTT0C9ipLok9sgecI6FvlZTuBOOhGQRVKfT72BiqQnB5ICn I/pWDotaDVmUpYrW+I8iSQOvTcMhj/vVnf2bfCYSRrHsPHmM5OM8YwFHufT3pOi7lyiQSafNEu51 kaQnOFQ8d+AKiFpcvJlkmyRwSvA4qfZMzcdSzbabfTziKNRuGcbsj+lTx6Hqcspi3JvbI8teST0+ tJU32KUCvJol2v7qb5mU42jOc01dGuSoLI+5zk4HGKfK10FyMkGj3is0ggYoeN2RzXSeG/BF7rkB vbm7t7CxibbJJM3zZxnhe/6VcKLmyXC250A1Dwf4XbGlW39sXwGRc3LDy1I9M/KPwya57XfFmva6 xjubkJDn/VQShUA+ozn+VdEnyLlghqDaOfW3kR2UHODgBSCD+NOeCeJOAh/3ea43F3uyuRkGyZYd 7naM5HynJp62k8qtIsmFHBJiOATS5G3sChrqRvEVLBMsckkqMdO/XimzTweYs4tCZsksxJByeOtd EIyWiL5UMlmUnPlkZH3S+QKriRQ4cKA2ejSDH5YqlR7Ddh8t62wiFVAPfHQn2qP7VJvBWEqexUYq o4fuRdInGpOkflyo43YxgVJ/aZ2AGJwo4HGPzolh5PYfMmKLmK4XybmNZEkGCJD0+mOa5m4tjb3L xMoyDwcdRWlJcvusJbEWFjKyFlJU5FJJcRxylcHHUYrfYg2tI8R6rpzKba7fYeiMcivQtE+Ks8SJ HqCMoH/AlH4dqa1FY7q2+JUF4LSCGRf9Jl2NKh/1ahST+PGK6SPV9P1W3lsYrow2cXExMhRmPU/N 29zQDVkcR4s126s40tdBKQWTcBh8jv7jPGPcc1wV54qutLjaOC4c3LDDNvzs9h/jW1OHMzJytocf e6pcXkzSXErSO3Us2TTUtXOWuGIx/Dnoff8Awrt20RD0JMCNcKmRTHZmPTHtVIzbuXtPRZ4jDPPb 2seS5mnU4GB0yATz6dM1mXVqrgPFgo/3cdvas7+80aR0VygYWBwQaQxMeMGq5GUpIPLb0pNjY6Uu Vj5kG00YbFTysExQzDuakWeRTwxp3aHuWYtTni6Ofzre0/x5rWn4EN/OAONpckfkeKG090Q49jor b4qzygLqllaXeONzx7W/NcfyrZtvGvhi8OZLa5sWPXyXEg/DOD/OspUU9YiUpLc3rLV9MuZFFrr8 YU/89S6kfg3H610EVtLKA63hlA6FIFdT/wB8E1zSg47otSvsOSGIyhfOLydAqqQ3/fPJouLGWSEp bzzW8h/iNszY/Ais7F8xg3vh3xNO7Pa6skh6jCtbn9AB+dZNxp3ji2cr/pMuOmy4STP4Ak/pWi5S G2Z8994usUzOmoQAfxSQHH5lf1qmfF+s52m+yw6gxR8fpVKMWLmZLa+NtTtzicxXKZ/5aRgfqMVs W/j+zZAt3YyxH+9E4bn8cY/WpdO+w1Mh1jxxCYhHpPmKzcmWQcj6D1965ptbv2bc19cHJ6+a3+NO EbIcpCjXr/PF/dDntM3+NPXXtSLf8f8AcHjqZWz/ADqrIzuyyniXVYypW/mIHXLZB+uetdNo3jCG 42w6iRDNn5ZQMK319P5UpQVtClJnSxFGUSRsHVv4x0P5VIpweR26YzWBoBdmIyfpimqASSvPv2oA TMhPVSCcHIPP0oUbQFwPqCfzoHYAfmPVgOmcAU3am0LMFbdyflyP5UCFCxOpE6hl/u7On59aRYLc KVS2QqB90DAH+FFgFIQKTsyH6j/6xoe3tpV2yRqy9drxhqBHlyyTx4EiRyercg/yNOM7lgPJU/8A Ah/Ws9DcTzW5zbdfQr/jTCyht32Yr9QOPyosMkN1KyBCz4HYgkVBNepDIS3mBzwCFwT+NFhMu6Va aprUwj063neRmOMAu3PU/wD666hfACaXtuvF+spYoq/6lJMyH2wvA/GqSJbsSXniTTNFhmXw7osa 5/dtqd8u8yFhnAbucckcYrjYAiiTMpn8w7ijISuR0wDxTvbRCSu7saySSLt8lQF+6XYfyxUYsQ75 ldFwc/ImMn361m0aEvlAfckUAcA7On+NKLNTn51AY8jGaVkA0wpExDvCFP3V34J/OnpZs6BhGNrD v1+nFKwyFdOLZ/dhgDzximPpJY4kUEnngUAQXWkRW8Ra4BC44wepqCz0Rpj5rAInYO2fx4UcVcXb Ulq+hMNGaOYjfGA3IyMj+dSGyZWwZox7qAP0xWsaqW6M3TuH2Ulskg4A4yOKR7QbxmFW/wBo4rT2 sOxHsZdyvJp5aQssXlk9yeP5Vmazosslk8/mBngUsODyo6jp+NYSlFu6NkmlZnGP8zbt2cdhT2VZ I0wcEDGMVZJNbSLEpVn6cg1dS8IALAgnoDxVJ2E9SWK/8uXfCzRnOcq2Oa2rbxjd29tPbu5kjnUq /Y8jBPp0+lD1BaFGPWJreFhZ38wTq1v5hVW/4D0P4VmTX8c7ZLEE/wB6taNTl0ZMo31RZ02cW8wu ophHNGw8p1bBQ9dw9x2rStjZ6jMElmjtjwFJDeWoC8lsZOSR19T2HToqVFGHMh0KLrVlTfU6bQvB 0evW6SxztFCULPIFJC7cBh79fXpVsfDktq9vYw6jaSGdwis8mzaffPrntmso17mdWg4TcV0Znaz4 KntDd2aFJpIGI/dOGU4bk59MZ/SrFh4NL+F4ZGNvFMFd2RpSGIB4znAHtg80OfvXM7e60Y2p6DFa XCqJYpC8aufLYnaSM7Tx1+nrVD+zI88kV6MXdHnupJOwjaZGTTG0tB0IqrIFWZG2mDHFRNphAqbG qrMjbTmHamHT2Hb8aTijVVkRmxYHpUbWcg7GocNDRVUN8iQdjTdsq9M1nyNGvMmPS5uIiCrMMelX 7XxLqVkwaG5kQjuCRSbezDlTOisvirrtugjnnNxGP4JgHX8jXQWfxjXCrc2KJjqYGaP9FOP0rKVO EttAs0dFa/FbR7mLD3NxC5/vhXA/ILV228aW9xKFi1u3EfYyW2D+GCf1NYyoyQcyNyw1iweQGTXX Un+JYF2/pJn9Kn1a90sxKs32nUiy8ssKlBx6Elv/AB2smmhqzPMfESTTROlvp8Qj35EkemtFJjsN +xQR9AO3WuMmnjjKrK5BJO0ZIyRVqStqKUew7zU358w5x3x0p4mAJBbkHtVpoiweZgck+uPamR3W AQ5VTnHJpXHYeLsRhSScNwMDNE98oZUBw2QM84FDlZCSLmmeIb7Tb9fsLkF+wOVb1yK9C0jxXbaj bkThYJ1K/LvzuHQ4yPXB6+vWsZtbmkbo1P7WtxA0wk+RED42jJHSrEuowKFZnyoI+YY4zjvn3FZc yNSQXaS52OpIAOSOx5z/AJ96SSaJFG6VQDwT2z+VVdWFYcJSE3cEnoOo/Oka4WMKCfmJxtzyf8KL isOV1ZtvHy9cDGeKTzIi3zFQcDGMnAP/AOqi4WIYZg7SbnV8NjB6j2p4vIsHLBTnB9vai42jzMSS lsNGfbBpxMgOCpwahmw1wxQhlP4VCIo1UPJEAe5OcfrRcCGfUbS1Yx8lh/CiE1Wtku7ub7QIEwTh WkOB+XWqStqxbnpd54k1Hw9oun2GjSRWfnWoeWZI8OxwM8/Uk964y7P2uRrq+neZjy0s0hOPXrwP 0pNvoJK7uUX1uyjARZSyrwvlRkgY9DirNpqEV6u+Gbg8fMuDSa7lXLmwgbsnH06mkxjrjp2pABVS MYI9s1l6zq8elRbVCvcMPlUngD1NNK+gm7HHXN9Ndy+bcSF27eg+npXU6O9nbWyTzXjoWTb5c9wM D3A7VpJWVkKLLr69p0Jyb6M4/usW/lVR/FOkwAsJndh0ARufbpis1BjujL/4SOK6u1mupJkWNsqq LknPp6fWr48W6fHGqJFcbEHA2r/jVuDsJMgl8Y2zcrbTNx3Kj/GqreLl/hsiT7y4/pS5B8yCHxah YC4tSqDujBiPzAqS48WWvl4hgmc+jYUfmCf5UcgcxlTeJ7wvmCOKID/ZLH9f8Kq3PiDUriCSN5xt dSrAIBkH8KfKhXZjqUQ4Y9+RUoV1yccEc1ZJZEsUWn7XI83Hy8flT2P2m0WVfvDqKEJ3Kyk5zTsn 1pjDJxg0HYRiSFXHscH8DRYBqxRceXKygnOHHQ/UVaTzUPyHqPvRtmi+lnsVCThJTi9UaFnqep2I AtbySIA5wDT7vX9XvpY/tl0zCM5UBQo+vA5rSEY6WMpyk22yWW7vTFExmfDjK4k9/TPH41HdeKNT s7BrRb1/mGMHqB9aJv3myYroYMus3kshd7iRjjGSx5pv9r3feeT/AL6q1iJA6Eewo1i7/wCe7/nR /bV5/wA93/On9ZkL6vDsKNbvf+e704a5e/8APY/kKPrEg+rw7C/27e/89c/8BFOGvXuPvr/3wKPr MhfVoCjX7vPOw/8AAaUa7cfxRxH/AICf8af1qQvq0BP7bm7wxfkf8aT+2JCeYIz+B/xp/Wn2D6su 4HV3P/LtH+v+NMOo7utqn5mj615DVC3UT7ch62q/99Gk+2RH/l3x/wADpfWIvoUqcu4C7iJ4t3/B /wD61Srcn/lnBOD7N/8AWp/WI9h+zl3LMN/fAjyEvOP7pJ/pWlbeIPEsKgW8mpADoFVsUniIPoL2 bNWDxf4zjYEQ3cvPBmsw/wD6EDWinjnxfKpE+iJcjHWS2Zf0VgKyc6T6FKDGNrGq3QxdeCLF89/J Cn8yxqFrczsGbwTJEc9YtVCD8jkVm5U+jHyMRtIeZ1YaJfQcY51GF8f+Oj+dZ13oF5DuKWlw6nqM KxH/AHy5/lS5ovqHI0Z7vOvyEeWVG3HQ1VMblss7nJ9apq+xKSRZtJZLWdZVdiw4wTwRXRW3iiBU VbjS134wZIpiucexBH6ispU+YpNGmniXTruQfv57boNrkdB6kDH41am1WKaHZDfwuSc4kmHJrH2L RommTQ6jcwRq01tK64x5sTCQEDoOMH9KRtUjuZgPtCgg8xk4PbseaTg7AkjQh1a5WQvcYkQLiPqu 0+ue9LJqU1yAwYiRQcuATjPoMiqs9gsisl5fpEVM+W7Hpin297dqxEs5w3JK5O336jOKXLLuKw6H VJLSR1W4DSSt8wyVJx0OCDnvwDUZurkSu6yh0Iz5cg4z7Y/+tQ4ysOyM3cM4AP50p+YcHA+tUMCQ B2A96oanfRQWzxs58x0OAAT+OapbgznLcPLKscMjEnqOmP8AGusguIkijjw/GBxE3X1qmJbamzrk 11qEto+n2kt1FDEsQUNGrAYHJy3r+mK5HVWnSYtqsUkSqcRwuvH1PYmpsK5Fb6druo2wudN0u6mt SSFkSIkNjrj1/Cs95ZoJ2E0XlTLlWDJyvtgjiiw7q9jY0PWDMGtb2QLJGMrI5xvX8e44/OtV762R CPOiJA4xKOallGTPqWoSZ+zmytlPA8ycO36HFcvq11cveYvpUkcDhkxgj2xWkUkTJsoeaPWk8wHp n8q0JEM+DwCfwqLzPn3EGi4h4lXqCBQZuOCKAGmb1NIZs96Q7B5n+c0hkyaBoaXo8zigCCVQW3A0 1biRQFDdOme1IYgLSPljn1Jq5A67hG7ERk8gU0Jk1wnky4H3T0qDzR6imStRfMB7ijfxRcYeZ/tC lEnPLCi4WLomYWhYZVsdQajTULhR98MP9pQaUQY9tSuJF2sEx2wuD+lUJEDHLDqetNq4LTYYLdG6 EUv2UHuPyqbDuAtBn7w/Kj7IB1Zfyp2DmF+yqP4x+CmnC1TGd5/Bc/1o5Q5hVtoieGc/RP8A69PF nGc5D/oKLCuTR6ekhwkUrH/ZOf8A2Wrcfh24kI22N2SfbH/stLTqDbLUfhO9cZFhKPd5FH+FWo/B t02M2tuv+/M5/wDQTSckh6luLwXKGBeOxUD/AK6N/M1cj8IRqw82W3A/2LRD/Op5kOzLMXhS02/f b32xxr/JanXw3p0YBKSMOnMzL/6CRSch2LMOkWEQxFBk9suz/wAyatJaQIf9TEOODsHFTdjt1JcY O4AYPYAAflQcHkgmkAuAFGABQTxnbk0AKHBwQoo3EnAFACcqdojJH16fmaUEdP60wIpYoLkEXNus gHGWUN/Osy78L6dKxMKvCexjbIP4GmpNEtJmTceErpCTbTRyj+6w2n/CsybSr+2OJrSUe6qSPzra M0zNxZUKMD8ysPwq2ulXzxh1s5SpGQwXOavmRKQ+O01W1fNvBdxnvsDCtFNX1hF2Xlq9wnQpNAf5 ip91lJtETa2tnNvS0lt028rksoP44wK6Kx1vTr6AFZY0lx8ySNtYfgaycdS09TRKqyAjGD6Gmhdp 4FIoiuIorlPLkDY9QcYqBVltR8xaaLPJ/iFAFJpXQfLhiOg5pROWPzJjHoaQ2ONzjoOD6npVa8js pQGu/vEYAD8/gKFuJrQzrYTWVwzwN9mgc8NcEKHH0PX8K11v0LgRxSNg4LeXgD3+YjP4A1bQlsbd lrukWSot7eeS0ZBIljZMjjpkc1V1Pxjp19ewLAlvcadPMI52mdMjPGdh5x74pW1E1c1jeSW+lTXN zYRK0a7IYn/fKiqTt2bCApbjnk9K5/xikeoaHY6nKALiR2jyx+Z4wAQT3ODkZpvYl7nF6PM//CSW qF/l2vkHp904P8q7Fkt5fvJGe3zIKh6GqWhQvNMh2s8DBC38JGQfpzXIanGw1MwJC28YXaOTmqgy WrE0ejEQhrm8itpCfuSc8fUZpo0VnkAivraQnj5ElJ/RKrmQrD5NGumUK04cdgIJsD80ApF8N3ci 5BVfXeygD9c/pRzILMX/AIRe95AltiR28z/61RN4cv14Bt2+ky0c6DlZFc6HfQIrNArgjnynDkfU CqM8CRSBY3EnAJOwjB9ORTUk9hWZDs/2RSbF9KAEMfsfzpuzjoaBiFB7/nSeUPegLhsA9aleFolB kBUMoYZ7g0CIZLiSVQhPyr0qLHvRcpCgkfdapo3yOuCKYiTef7xoyfWlZBcXJ243HH1o5x94/jVL QTF59akiguJyBBC8hPZVJ/pQIsJoupycpYXAI7iM4q5F4X1uTgWmP991X+ZqeZDsyOTQNSgP+lRG MDrzkfmMipNO0Nb7U2s/tKKwXcG2khv5UcyewW1Oih8D2ykebdSP7KoX+eauReENLQAssz/7z4/k BWbqNlcpei0HSofuWMX/AAIFv5k1PHY20P8Aq7WFOeP3YyKnmZVkWMHGAAF9BTdp3Bjnj8qQWH7e OBzRtwfu4+lAxQABz+WaXI4IWgBQFIywxn/aNOU4OR8uOhoAOMjaMc0pJwOmaBCAgnkE0pwBznH0 oACBgjJHpSZBbaentQAgAx1NARcZ3H6k0wHJgggnmkwM53EH2NAC5Ge3+FH0agABIOM0vynjPNAA STwGOM96YAcYHf3xRcQBc0AHd3GKYCn5lKucgjkEZBrHvrNrRhcWQIUcnaMlfp7UgsWLDU4LhFjJ EEh4244J9q0Vz3P+NUxJgchuDn2NNYnIHb0oGc47rHEZJ7l0UdTuVQPzFMW8spx+5iuZx/eXcQfo eB+tNICC6mtEOx0ih/67zEv/AN8A/wBarJeQBsW6yOoPVf3QH48P/MVRJcDyGTfbxxRblG9xCWfP fLcZ/EUjyxrnzpLmUnjgFQPqFAB/I1NyiITQLHIkWnhGkG1mRVXP15/WucZLmaZ4551jAblVUEik twO88Ma9pWm2Ma6ppEd5NC+5LmG4+zk+mRtbn3/wrL8WeKE1efMUccEESlIYU+7Emc4z3JPU9/aq crk8upx1pqYtruSdQ+4psQqVGB36qavDxBcy/Ivn7m6ATDn8Aop8qe47m5pSXFy2+8tJFTHDS3Lk /Tbnj8qtJpFlAxkMCOztyZfm/nWbdtEVuXY0SIARCOID+6AOfwpS7MmBJz6Z4FSMZGjqpw7sD3LE 4/OnBWQjkj1O6iwXFDOGyASoI+6f60jNPtK87W5IJzQAhlwm0ru9OOvrRw/DWwbP95MUg0GbLfP/ AB6KSf8ApnQ0VqSE+yRk55BhGTRdhoRPbWbuR9hhIPU+UufwpGsNNYgNYw89T5YBou0FkRnS9NU+ aLGHcOOVGOfanCw0oj95YQZP/TPpRdhoVbzRNMurVo4oltpD92REHB965q7029hZLW/csGwIfnyN ucZA7f8A1q0g+hMkZ0+mzQ6l9iQb5C2FI6N71sR6FZW6J5589m+8xk2gfQDrVoiTaKmo6JHHA09n uGzlo2OePUGsZWwwP50xp3RKTgdacORmmIUe1KMD19qAHAZ4IpRgnGKANrTPEd7pwCbzPCOPLlJO Poe1dbp3iTT78hTIbeX+5Jx+Td/88VnKPVFpmswVwQwyD1BHb6Vzmp+H53v0vNKbypExtG7+ZJzU RdmOSuW7fUdQs5FGsRjyiOZFGcHtyBithLiORPMjJZMZ+Xk0NdUCFNwC2CkuP+uTULcRlvmEo7cw vx+lIdx32mMdpAO/7puP0o+1xE4UycdR5bf4fpQIie/SIjzFcp3dUOB9QR/jTotStZmxFNvI5wFb /CgCT7dDj7zkdR+7b/CkN3Afm3n3+Rv8KdgD7Zbj5vM49wR/SlGoQbgTOBnpmiwAb+2xxPH+dKb+ 2AH+kRYPU7hRYBRf2mP+PmEc4GXAo/tCzHP2qHp18wCiwIp3epyQNvintbmJTyquA+Ppk1btdRtr mLzI5VAHUOcEU7aC6k32i3ZsLPExH/TQUpeE9JUP0YUtRgSuOCv/AH0CKN6qvzFRn3oARnDLlQAD 3zShRnO4YHYkUgApub5eKUo2DhXODjKrn+VMBoK/7vPRuKXemCQc4/SgQhdTjIOKPlzQAAruwvpk ijqB+nvRYZRn02KaVhGjRsRklR8rflVZbqfTXMV1HI8YPDFe3sehpol9y/FeQTKNkq89ATg/kalO 4j5Rn6UxnG3Gj3tzdmd5I5FzleCdv4HKj8quR2DFCLoGXJx88zY/IAD9KbloJIeEe3iRYYreL5sb YxwPc4xVqOFzGGaaNieSAhxz+NRcqww5GCGUEDAwP6UxjxuDOwA/uDH06UwIVCMNjTsuTnGBx+OK juNGhvAMSMGIyGDjOf8APtSCxAvhd9gH2yTHchQeKH8H2jt+/uriUZxtDKM+nai4WHx+GdOgI22h f3dif0zWjb2kNsN0FukXOAFQDNHMxWJTgOSQi56DOPwpSiyD5MEdsjApFDnt0wchBt4HNQiJI2IA w2e3IFFxBgBdoDc+hpygBcSkj8M0wRKqmVF2MFC8EtyPY0Na8luXz6nNSMrmFy2VLLx0Jp8cfyZY gMBzk07hYnSEseq+4PAp4QBNp6/71IEQlJPMCqqEt0BHJpVR1K7wAecYyKQA3HAReuRxSeWoPzBe e+DQNi+UpySmSTwPf6VzXidPJ1GzkA2rt29PQnP86qO4mafg3SLXxL4nls5W23Ets/2SU8YlGDg+ xG6sm78O3ENxMhtDC6Eq0TY+RwecjOMGtIvWxlPQY7eRp05nCqkUJGc85I6H8a4pR84+tUKOpNkd AKUUyhQOaeF5607CFwcdaXoev45oGPDdORzThkc9DQI19P8AEF/YKEWQTRD/AJZyc4+h6iun07xJ a3rBJJDbyH+GQgD8G/xqJQ6otM2iXUcYxjnnqKpy6XC7h4C1pN3eI45+lZXsymivJqOoaW4F3Et1 Bn/WoMEfUdP89a1ba7hu4PMtXDDPOeCPqO1O3VCFnuI7dGknkVQOeTnj2ql/bS3A26fA9w2cZwQo +ppWbC5J9nvrtMXkqRxn/lmgyT9amtLeOzXEKkburHk/jRewFkMW4A55FI8k235I92BmgCEXN0v3 YD704Xkokw0fuQpI96YXJBPIRwpAIo+0T84QZA65pAH2qZCcoD689akhnEo+ZAPqRQA4lRhioJHQ 4qneWEFyRLGBFMejgY/OmnYGV4po4CINRhiY9pPLGD9eP1q6bayIJazi5HB8pabuIY1lZ5VTYwqB 0xGKX7BY5/49IQfXYBik2Ow02FkQB9niJzgfLim/2fYn71rCSOOnX8KEwsOGnWO4/wCgQsehG2g2 NiW3NZQk5yeOtFxCixsgMm2Re3DEYP4EVHLplq6Mvlle4xK4I/8AHqLsLFf+wIg25Lq4Tgf8tCwH 6g/rTG02aEg7zKD3Sd4yffq1UpdwJRA4GSdSVu5S4Dj+f9KVjHGfnv7yM9P3g2/qVx+tIBRGspwu qSP/ALsqnH6VIbSYAqt/cbcYxlW4/EU7hqVG01Y5ci6lRuvAH9KmCvDjdDBcLzyUw36/40XuFjz5 dXvu9zJz6k0jatfv/wAvMi8Y61rZE3Yo1a82FHmLAjv3pY9YvYTmOXoc4YZo5UHMSHxHdDmWJGx9 cVInia5ZsgJ9OlJxQcxOPEZJG+1ViOnJ4qVPE8QGRbEc54zz7dankHzID4uKj5LQe+WIzTofFMBG Jojx1AzS5Bpk7eKbHqpkB7gDqKU+J9NI+ZZOeuCTn9aXIx3QkPiDTnzkOCOhPFWV1zTQrfvCBjjD YocWF0B1jT2YFbnaueVzj+dK+uaaQQkpB4yf8ijlYEkWp2jgkzKR79auRXdi0ZBmTB4wrdaTTBEs VxbRJ89xEFPTLDIH1o/tC1YlYpoyc44OalJjJlkRskshA7UoaEglZFAHuOKTQDXuIk+VmXHbBpyy JIAI2HTs1OwC53HI4xx160deM84xj/CkAvyqc42npS5C5O4/nSKIzxJksMegrP1nTxqVhtQBZkO6 Mt6+lCE0cba31xp2oJNBI9vc28mQwOGRgf5g12OtfEIa7pkb32jQ/wBpxAKbq3k8sTKOzLg8+nNa p9TNq61PPNV1u41I7HVYolPEadM+/rVGJcckfStNxJWRIMY5oAB7UAP4JGBSgUwHbQewpHcL0XNA BEgPzN+VTZ+goAeDx79qcufWgNjV07XL7TgFjlMkX/POT5h+HpXW6VrtpqJWNpPJlz9yTAz9D3qJ RvqNS6Gu0QKFHwykYIIrnJImsL2Q2zYYHqh6e2KziUy/p2kxzIt3dHznc5Adifzz1rUCFE2qFVR2 HQUN6gh6fdznrS4IfL9SaQxDnsc++KXJDYI/DFIQchhwDSrjBI6j2zmgA43dcEUpTdwSenSmAi4J OeDTigIBYfe96QCKUaQIvIA+uKUqozngYxQBDcWsN1EVcYzyCB0/z6VnQzT6e4huArxA8MBkgev0 9qtbWEzVXYwDRnIPIK9DQI02/fYNnpjjFSAu04xkD8aTbtHQHNAxQAEPNIEA4JB4z0xRcBpUEZ59 u4pdqqOT9TQA4DGDnOOnNDsmzluAODimBHhWJwQCByR1NBHGVJHHPHWgCIwq6gyorbjn5lFItpCq 8QKp9VXFMQxoIWYkiXjg4lfj9aaIGQ4WeYKT0O0j9RQB5fu45FITngV0GQZw3b25pd3t070hsge4 6he/eowDIflHPc0AiYQkLy5H40vljgZbJ6c0DE8hSe/50otkJpAN8iMHkY49aPITpg/nQIBAuOhz 7UvkIR3J+tMYv2eP/az9acII8DJb86QDhFGvR2x9aUJg4Er/AIGi4CFG3ZErc/SnqZEb5JmB9cCg B/nXYPFy4+tL9pvSD+/z+NAXZE09yThnHrk5qWO9v4htjn2ZPYmlYdyUatqYPN4w/WlOs6my4N9J /wB8ilyormZE17qBPN9IaF1LUkPy30gpWQXZZttU1e4lWNLxz/wEcCurtrK6eFTPqEpJ9FAqJWRS bZUuvCdpeSmaSebzG+9IABn6+tQ/8IXDjC3two9wMVHMxWM3U/ArxRGawnaZxyUZQCfpzXMtbOjF WJDDggjpWsJXE1YbsbOCR+IpwDD0qyQwxPQfnSgNnGRTuAu0nq35CgRLu6kn3oAkAI7A/SnAccrQ A4EZ6Yp2RmmIcGX+8KUzhB97r6UgsaFr4n1C1i8pJt0Xo3UfQ9q2tIa31RxulCEn7jfeY+1S1bVF JnWxoqIEQAIowB6elGWUE9M8ViWKrHAz2pxkDREFG8zcCrAjAAByCMZz079vfgAaORz/APqp43EY HPf60CEAbcevt3xTlJBJIBPqD1oAQE5wCcil+Yk5HI6+1AAHYc7j05BNKpwDuFAMRcLk4AJ5pfMA XB4Pf9KAuIqbeoznpUc8XnR7cc4pgZtlO9ncGC4J8vP5e9au4AZOSD0I5oeogDZHBP4ilyASWwD7 CkO4mQThwDn2owhbIXaO3FOwAQqgEEgml7tlscevNFhDecDH/wBem4yuARQkMUDHfFLsPYj16UXE NPGCSOT0zzSEducH1pgDKQ2D19x0pAWHJOKAPJDnPuaM/jXQZhk5z+VQyOSdueKAI1XLetW0ARAA KQC8560DqcDNAB82cUcjjHNACgHnJHB70AZPI6e3SgB2BnJzj1zSEDAwDz1oBCgYx19vajjGM9KT GGQM8dqXHpQAufQmjk0AJkkcn8aFJ6d6AB0Lrj/9VIAcc9qBi4x16UmMnrSEIRQAWbGMk0MZ1fh3 SyoEjqckV0qgAnge3FYS1ZaHEEkBSOevNNG0Hhjz7ZqCkI2FUA8c9z2rD1zw7HqIMsREdzj7w6N9 f8apOzuDRw1zazWk7Q3CMjqeQRUW3Bre9zIMDPSkBznFUA7PvigHtigB4YevNAwBRcB3PNPVsDoB QIdu9cU1lSTjGPSgLFXdhtrZyDitG1kIiXnHpQBv6f4nurUBLjM6Dpk8j6H/ABrRbxY7R5ishwcE mQ8dcdqhwRSkQv4suG4FtCAOhLE4/lUS+K73JPkwN7c/zzRyIOZGpYa79rGH8iFyfuu5GfxxitUy XYOBFCBgHBkP+FRJWGndDWlvyPlghHrmQ8/pTvMvA2PsqE9f9b0/SloO44zXagEWgbP92UflzSef Pt/48pM9CA6n+tFguIt24PzWc+R14B/rTvtmEBNvcZPXEdFgGi+jwd0VwPrEcU77fa5G5mjHqyEY /SiwAl5avjF1Fn3bH6VKJ1YBQUf3Ugn6UmIparAJbfzUGJFGenUVBo9/vQ20rglRlCfT0q1qgZrY XaMgdcYpjjYSc4b0zkVIxDIynG0EHnINPEqbcEhcDgE80ALvXbnAPbg+lIWGSduRjhc0CE+XORxn rg0h24GByT1pgBIJzxn+dG7cc44+tAB1PQH2oGwtxjj370wF6nqCMYppACkDH50WA8i3cd8Um7mt jIUZ69qhm5fgZ+tDHYIcbwScVY6/d5zQAuT1x1FNMmD83FADs5PFLuHQdqAFyAM5JzSg5NMBeAKA QBnnNIBSRkUZAPIFABxjikJ3cLnrQAme3NGTjJpAOJGADyR7UmeelAw3YP8AKl3gjFAAWGDTSwOD +tAIPl9TitPRtONzOshHyg1LdkUjuYIVgi2gfy4qQEBfkOBnPtXOWBYBhuGf5UDIXqeOeaB7DWUg LntyOaFDFwI1yxOABznNAGfqmjWuqW22ZSsv8EoHIP8AUVwmpaVcaXctBcqOCcMpyG+hrSEuhEkU mXjg4pgBQc/mK1JHcN0OaB0ouAA44p2RnOaYC5PvTge3bvSAOPpTgyqMk4piKzEFyc5BNWIXCptX r1xQBOrnGeKkExHc4NAh/mD3o3LjGT+ApgSKw25349u9W7XXruy2pFLvQH7rcjH9Klq6KWh1dh4h tLwBXYwSHHyueCfY1rbxxjvzmsWrFp3Fy24nA+lOByPlIpAICGbPTv1ozle/XA4oAOAw/pS5bqCc D16D8aAI2jik4dFfPXcoNQyWNvL9+3j59BjH5UwI30yJAfKLxkj+GQj881huiWl6xgb542PUZx/L +VNMTRtQNcz26yR3UeWH8UIGD+FSP/aG0YFs46Dhhmm7ANEl6Bh7ZGPX5Hx/OmtczYZbixkKeoAP 9ancBY9QtcYaVoiTwJlI/X/69WEmSXIiKSepVs0WaHuP2DIyME9M8UBtvO3IJ556U1YQoZcA88cE U3+I4z+VACtsD5RtwBOCRyfw7UmQRjoaYBjJyDg9OuKGxjOO3O0ZoA8dIcj7w/Kja3Hz1sZi4bs/ 6UjRMTyST60AIsBPVhT1hYEHeTzQBLk5yQD9DSOCy8Ac9zQFhqZjHIBH5U5ZQ2RQG48DAycUYGaA HDrzSHPt7UCFU5Xrn2pOT2FAxTgc4/CgE5zjr+dIBUAzhwcU8qP4AcCgBp+8B+tNPB+lNDHDByAu KTB6+lIBMccn8aTJHA60AT20TXM6p69cV2+l2SW8IOBkCs5PQpI0tx7N19u9KoXB5AbpisSxDgDG 4HHY0wyIozw30agLjTcxhQRux7g80z7Sq8oGDDjg4xQMiNyNuFjCnHQmql1bxahCYp0BTGSR1B9R TQjjNT0ifT5CeXgJwsn+PpWfnitk7kDGxnIzn2oVm7n8KoB284waTcR0xzQKwofngjn2p289j+lA DWlYHANJktgFqAHmNdp4wajGT1JpiJUaTqJPwNSLLIBymfUigB6zgc4Iz1BFONypPHWgY1rgsDxw fehXG/JIApAWI5Vz8v5CtSw167sWAWTegP3H5A/wptXFfU6bT/ElpdsEmbyJG7Oflz9a2N5YAhyR wRisGrM0TuKpJA55pfN5y2evU1IwD5b9CKDIDjABPTg0xAJOCQvGOTjFCspGSpHvk0AxFYE4IwRz nFVb2ziuoGJVRIOhUfpQtAMy0uTp8zRzA7TwyehrdV1ZEkjPBUFee1UxeQFjtLZAJ/P8qXYznIKk nkHgUhjSpc7Xw4PYjNV5NOtDwbaIKe68fyp3EM/stEXdFPcRDsFlJA/A5FKLe5U5S9Zjk7hJGP6U XDUMXoDHZDL/ALrFT+uaQzzoCJrWUY5JR1f9KLICMala7gsm+Ej/AJ6qVNWI7qB92yaKQEcDcM/z oGSkSFBkHA9+KBgH8ckYoEeQDOQMc0uD9K3RmKOmcdaM4AGc9qAAHj0p3OQOaADJzx1NKeBgigBC RjJOMdai354Xp29aBonRgFGTTwy56jGaBBkE4U4pWAIwB9KBCbVxwKUYxQMcMFcE/SkGAM5/WkAv B7ilDEHg4NMBQwY/MQCRTW4Y+vYgdaBgARnp0pQSM+lIQm4HjrSHDdOtAzotDslADyLljyO2a6lH 3oPLXOB0z1rCT1NFsEhUyOEOFJ3EZyQPeoTKgICu5J6Ac5PpipGKLiEfIR82euelSK4wu1SuDwSP 5UAE+5xjeBjrlf8APrUBt2C43KSo/vEZ/wAKVxjBBJEoIA6Z4PT3pwDoVyUAPU5zg+tO4hlzFHJE YpUEgfjHY1xet6E1kpngP7huik/MtVB2YmjEVRjp+NOIIGfStiBmS2OOKAuTwc4oAXB60mc9RQAo I/u07jHAAoCw7ccYOM9qbvK/w807iEO4jOzFKrsvfJoAUu3XP50i8nrQMmBPXCmmbmLcUAiRQCc8 g1IJWRuhI9qBdSRJNxBDCtKw1e8sWAikzH/zzblf/rUmrhdo6fT/ABNa3Q8q4P2aU8/N90/Q1sh8 rvU7ge/UHNZSjYtO4/cVA4OSeCTS554U8elSMVdoGQB05yaZv6jaBQgAS7OZG2j69ackgwec59Dx QBn6hYR3jh95jfHXGQfrWfa3Vzp7mOTDx5yV64ql2EzZtryK64UYPv0NS5A+VACf50MBG3Fh39/W lJO3GSMnBxxQA1BwQCV56Yp/JbP8I7dTRYBvQ4HfsaMHdkc4oAR9jkb/AJuOhFQG0ticPChGckMu c/pTAaLC2XOxDFj+45GPbrR9lkU/u7uYYP8AGA39KAPJvP4OVzzQZQV5Xg1qQCTbeCxI7CneemRg /gaLgO80H06UoZSMU7hYcCoxyaDICcgE4FAhkrgp8rAURFfTJoGS+YCOc0bxgYAzmgTHAjgg0pPz ZOAaBijB6HoOgpQMCgSHBewPHvSPjGUyfrQMT+Lk0DcDx1HcUCYh+cgnHHP0pxAPPU0hiEc9KBng kUALwSeOfWtDSbD7VMXKFlXnj61Mho7e1t0S3UYGMcc9OasKFY5CgHoSKwbNBrhRk7cL3+XrTWhi bZgjI9R1JoAatukeMD5u/Ge1Lg5G5Qc9eOlADSpI3N3yOO9IQoXc+AAPmOcACkgGPcQvkDLqo7KT n0HApBLBgEI4GMcgj9cUDIpJFcYtcyNnGQeF+tNh09S4e7/fyd8jKj2waQWMLW/DKnM2mp8wzvjB 6/T/AArlSpUlXHI6gjpW8HdGb0G4AOBSYA7fpViA4wMA/gKAvP3TQAbQe1BDYGDQAoBx0/WlAJHX HrQAjI2eORTD8o47UAJ1HIp2dvcEUwHDaw64zTwDu4yvFFxDgZB0b/69KGkB6A9utACHcGLbSp9q kS6UDDnke3WgCQXEZOdxGe1bOman9mA/4m6xoRzHsZh9McUNXBbnUWet6fduFhvEyRjaw2E/nV5Z kGQ7px3DjpWDTTNBfPhC7vNjwP8AaFRyXNp5Z/fpuY8kSf59qLARNc2akFiXIHuf50ybVYgh8pcn oC3+Ap2AptJfXB3bZMA5HBo/s28lJd15PPLDJ/Wq0J1BYZ4JARbscHPK/wCfzq1LdwxzgzRzwPjl MYyPeluNDxe2ZGTIyH8aX7fCAR9sJ54LY4/SlYLj1vYGG17tBnPQipRPEw/4+UIHfIwKLMBNwKgi 6jOO64/oakHzAYmT/D9aLMBAp3geaT7YFI8Z3YM0ir2HH+FOwAsZCkNM/X1zn9KbsHX7U6gehUf0 pWA8dyM4pQcZya2JEyKQ7ce9AhCD+FCsy9CaQx/nP7flSGZyeo/KncLArEn5iT61L5kYIOMYoEBm jx0H5U5JoycEECi4EgdAOW49c0GWPja4z9aYDfMXkrIQB70CVB/y1NILDxICciU4/DFAk5/1i9O9 AA0jFsKy49ad5jEdVNAxvmupO7aBnripF24B3DGeaBCcn7rnFHzZyXOaBk9tG0swTJ57Cuz0vS4E hG5pAQeznk/hWcyomp9n252Ty4HBXzCf50nksvK3EhB/h4P9KyLuxNpLF5JpWOeqyYHp2xTfKwx2 TzZY8Nuz/MGgQ6MSEYWV8qPQZ/lSrG7xnEz8DrhQf5UrBcZ5DFQpnnI6lgwGfbp7Uot4cr5iiTaM AtyfzNFguT/JtA3Hr0BOMU7CkDaVx/KgCsbUpNvt5AuSS0ZHyk1KI23YcZGPWkMU8EAYz6CsTW/D sOoI01sBHcjk4PD/AF9/eqi7MUlc4e4tZLaVop0KOvBBqMrj8a6EZ2Eww/8Ar0bhjGaAAsAAAwNG d3BIGO9ACDgcsRj0oGSTg/jTAeAwHUigozDt+VAELKRwetN7fWkA4Nzwfzp4lOMUAKHBwCSDUgY9 AQfamIcHOM4NIxDc7Tn6UANEm1MMpOO+afviYZwv0oBoXbG/KnHsDVy01Oe1YJIfNi9DjI/HtSau COosbjSr8qI5JI2xxHI+CfxrVGn2ytnazHPzbmJzWTbRSXUkFlaKQnlLkeuT/WozPYQPsAjGeDjq Md8dam5Vi8rDAKkN/tDn+VKWP0B9elFwImd2IMUyjHG0jIP9abmYptmjRz2C/wD16YA5LDDRBh6Z B/pURigf/WWYIH+wOf1oFYrCGzFyYnt9wfkcEYP1qYWdpsz9lYeuGP8AjT5mHKhFs9P37fJlDHr9 /j8aUabZjhQ6+g39PzpqQWFOmQBid0w9wf8A61N+z26nG+4JHPQn+lFxWI3+yR485pcAf3Wwf0pp bTgm5kLE84y2R+FFx2PLOvQUMP7vP4VqSNXdjnOe1L35oAQuwGKQO3YUhjgeMcZoD4bDDIHagVhC 44GKXKn6UAG/nFIDx1xRYA659ulLtyuccZxQDE7YBpcYPLYFAw5H3CcD1oHsf0oEJkg5zQGbOCaB 3FDN3JpwYgcH9aBC+Y4I+Y/nSieTcBuouM1LE3EYMqsNqdWAzz9cV0MfiCVIuFQKo6EfM3qf1/Ks 5aspCDxHLuRQnmEngDK5/CrT+JY45DGQGCjBZHJBzj27f0qeUd0PTxHbtHzuDHptBwOPXvUsWt2z RFnlbKjd93tkCpAkPiSxGNhdB2JUkH26fSkXxBYl2/eEoBzlcH8u9FmPQf8A25aTpJKrPshUFsrt 4LBfx5I/WhdatXgMhlIA4+ZD9ewpdQRJHq9kQCsvPUHa3OPTil/tO2c/61cE9cYoCxIL6JeWkCqV yoPy5Hrz2oa/tYz+8mXnkY5x60gSuCX9s6sy3CY7/PzTxfWoVibmMY/h3AUwsU7y307U12XPl7sc MDhvwNYFx4VBObG8RhkDbJwQfqKtSaJcWyhP4d1KHlrcSAdTG6t+gNU5NOu4eJbSZMesZrRSTIsy FkZOCjD6im8AciqDQAM8YNO2kjhSc+1F0Fw2Sf3W9sA054psHMUg/wCAmi6AiEDbs7GJPtTvsrFc +U+PpRcANnJtD+W+DnBKnFH2GcnAjbnsRilcCQabdOTiInHX5h/jT00e+Y8RY/3mAx+tHMgLcXh/ Uyo2CLrgATL/AI1Inh3VipbyYyPQSAk/lS50FmM/sW+UfvoAg7seg/So/wCx5GGWKKMZBJPPt0o5 kFmNTRpHGQ6j86tLoCEAtfRDPqrf4UOSHZliDwxuG4avAAemM8/Tmtyy0rULRAq6wJIsj5TFu/rU uSYJM0ZLedxxd7OeCqYP069Kgk0ouQxnDE+oP+fzqCrjBpc6cRzIoA6DI/lUq2lyoy8/y9hvJp3D UsrbHaMyA/VVI/lTfsz9CYHI6EoQcfnSAesc0ZLfu8AYIy2PyqN7l3JVWhXA6sx4/SmBQYxxOTO0 VwrNk7VJK/jVwPZooYlQeo3Dt+NAh3+hSlWeSHqMbm6/SnP5Ww7JI1I6Zc4/IUD1IGSTbvimjk4z /rWJz9Kf9onBAW3LLgfxjg45x+NAEnncgmKReOflBx+ApD5rAGPyxjplSDQB5GAM8Z9804nnnA9h W6IGnzAcDGKkEJJxg00mxPQl+yKy9SDSCzUcl8itPZojmYi2m7kHika1O3lhgetSo3HzWICBhiAf lNSx2ksoDIBhuhLAD8SelZt2NEmyFtqtgkZHpzQMZ4NAh3ltzz0HrSbSepoAUxOsYcqQjHAbsaAj HnaSKBiEMCFOKUA9AM0CuGHx0I9sUdO+cUABJzjOTQu7dg9M/nQMewDMCOKGy0nGPWpEbOkWplcB o93mDCjv+H5YqQWrPctGQqjqFJ5xjOfy/nWDl79iluPhFtzvjYZGRg0syqjkQrKCcj5n56+g9qab uUIkX7zG8DfgZJBxzViIlvOjKGRyOWXGXH4ep7+lKb00AetqZAygxhwVPzENjPGOSR/+qo5h5oVL Vy0eBnagDH0OP/ris1JtgX4I0hsMOfKG0Elj/Fwfr/8ArFVmiVIo4Nw35yQT9zOMsf8ACsVN8zJV xYNOxFG6sWbfvYFcEDA/Q5x+FENvNefLC28Fwg2Nn6jp+QrVVLtjTY27triK8Ns7E7G2tht4Udhk cdM5xULRsJWIVmKN8xXp0BIxmtFJDu7kYacp5mGyzZPHXGP8acBPIxRVwQcEsQMH09qq6C5I/mgn yFJUc7lk5P49/wD61PVbiRwqxM4DZEjDlj6deg9vep9pG2orjme8jhjKbztzkKW4Ge/bNM/tS9Vn CSy/N0JYniqi0x3YrarfrErI0g45JGR1/lQusTLGxEhZgeCYkA+uccGq0FoPk1u7icZKYZA3CqTy PpUq6/MoU7k4BBGwbjSaHoJJ4huAMeZnK/wqOCfw96rHVW2yAlm3Dgt6ZppBdEa3B67WAIx14P41 KZ4lBKK3TIzyM/5xQxDkffIdxBBXqRgZpGcbnLLgkYDAY6dwP89aBiqRISd+Aq9cZpd6ndu6g8Aj j3pAw88ruzg5OSF4/KhbpwdqSPg9if5CmkFwluptzLI5VhkMhyCvPTn6VF9qcEbVJ288nr9adhXH /bpoY9hJVMbQF6H1/H3pv2wtEBscSBuD9en+fpRYBxvLYgJJBI2AcMJ+px1xtpI71QgMbbJAfpgf 5zRZhoWF1m6QqTcupA5GScZGM1ImuXWxtsrAbsEtgH86GguJ/bN2cE3BGeg4NSx67eY+dyceirjF HKDYq+ILkn5tjHHGU4P5VYXxA2BuRMnPGSCPrRyjJY9ftyMuXTgHoPTnio5fELZzEA+QPvrj+p9q LCFi8QFARJCrAcnZ1H+fwqceIIAFLRnaRkkYOB/PtQwJhq2nTqP3kYHYEYP5YqJbjSXG4tBkcnIx u/Siz6hYc50wphfKUEdUbB9+lOtpLCNsxXCc9cvmi4WZdgMTtuDKM8Eoc08MOp6/lQFjxzcuMYpM rnIB/KtjO1h6EkjG734qxGMNwrE+vSriiWxJ5SBgH64pFZ5SBkKB7U27yBKyJtwUYJAqnPN50mwH CDrTk0lYUVd3I3l4CRcKB+dKhkc7FbaPQHFYyZrFW1EAAO3G8/pQyFF+ccnpSAb5vzLxgDrVmO1l uVDqQFzjLsABQDJJYo1QI86SEY/1XQf0zSrPZ2ynZbNNnoZTx+QpAVbqUTyLKI0j3KPlQYAxxUIy KtC2JIyQMlmx6CpN5GG2k84OelAmKB8uSvBPUA8U8qgHO7OPypWAasJMeQckninxwFZATyODz0qb oaZs2LzLJGEK43D5QOvtitHyxJMtwgLB4tioRhclff69K5KllK5bZVnt3hTM6kI/3O7NzgEdMDtn +dWJLVYbhFljLruG5i2Q3HQfjmhz0FzDkshJCZNmGkJJiRvTofy7e4pAjxW3yoscjjDKznJC84JJ 9hWXP0BSKyw5tVMgEURbhcg59+nT3pXuI9plQjLyZC5ICAEY4Iwe1a2vsUOn1F5XUxrtVDhdpOAO 2fX8fQVDLcLub92GkcfM7Z5+mPypKkU2hz3TvCsOfK2/KdhxwOakhuxDAVBLMPmXefve2Rz9P503 T0sGhE07LGpVRGQQNy8kADt+dNFyyxsMt5jsGLEc4wf8c/hVKOgmSteOi+UrhwDghhlWwMDp1/DF NluciRgqkucAHGR74/Op5NbisDXz/MJoxIoIIBONvGO1I16zEZjRVZSAqkj16469f0FHs7hoILqR FKCQovUeWduDnjPrTczW8hZmIcHJGc1aikO4ou3dWw/ykYwuOAD/APXpXucogVlAKBSqrjIz39ap KwhsRYupjRNzHA5B6Y5xSi4kSBo1cbGYNtJyCR3P5mm3cEReYWj2vs9c4waf9ox820fKOBnJFMNB Y5xtyQGIJ4bpyPXNPWVnU8EL22+vQZosA+MkqYiqhlBw3oevXv0xTlYeUQzkEZyMYHt/n2oAaOS6 tHk9QcdPU0qZRMEKABwc43A/T6d6QWG5ySAoVsYOW7/U05huJwA23jcDj/P1ovYVhsmZJCXyxzuL Fs5/GkJRpCVUr6DqB7c9qdwJHVCjDDPJ1b5cFSOvSo1w4A2gEDHHfn9aLqwCGNRksBwcYIppVWUZ UKuTyF6fjRcBTFEI2wckHgg8UptCGCLNuds4GeP8/wD1qblYQ0IQFXftGecjpT47i5tyzQTshddr GNiuQeCp9sfhVXQyImQnDsMg4AIzT41OWL/MDxwMkfShiBVO1iVG3BIwf8+tOeKSElQp2gckD2B6 /TFS2MLdU3bxtwB3J6+nSl3EnLyIrMp7ZBwOBx0PHWpctRbFZFaTczMoIGcE4zQHdSTgAj9K0ugF DOozubBB5AOAfT+VPCXDwu6xlkT7zLyBRoA5WuFiM8StsB2l+mcjpVu31W+jGYmbYq5xnI/Wkx3O RSNiM9B71OkK4BYkmuiKuYtkmQF4o3bVJParuQVCS7k0/cVQheuMisE9bmrKrFixzkmhUY8kY9aT ZSE74WpcDPJ+XOMetIbYrzAAeUhVemT3NLc3TXPVQuD0H5UxWIVUjnH51NE7AbGXKH7wpXC4KqoG GSR9KtKmUA2EyP0XHQUMEMubR45ViKsrKuSHG3jNQLGvQn5h71XQkco2twCfrUyhmwPL+Y9B6mpu BK9nKgQkFQ4yu/jPrUCwPkDIPPrQ2JMnWKRX2qMOo6de2c1uQWuXkSVATISsbAKGAHfgf7PT3rlq SKQ+yspE8uVmUmJtxyD8vXGPyNaMdwn2dPPHlushZHGRjHbBrnqS5noVcS2WFriS5ZJJPOwvmO+7 ackcZH5emKZcTAPHJ0wVKKwJzwRx69VrNtuwhzusZZSnzsRyCOSR2H9ai+zS3E00crlV52lkznP/ ANYH16Ckmr3Yralc2BmmZGyTGEAABzyfpzxzVldOEcNsTtjPmZKDOcEen5Vs6uiKIxpxW4YSABm+ VgCeCSM9u3P/ANbNV5LaPYE3oWU4kcuo2k9AB36da2hPm2BO5ELQhDlunIbbkY7H86UIdyhwFVQV bB64J6Z6VsUrg0e2Qo0f+rX5Sp2ljyefzpFhYgPIXVMcHGenb9P0qOgyJIftEuyMYG7I3nH/AOun SIkUpETq68hXHBIpp62FqNaJQE+bGRlsD7vp/jVmKzzDHKxCK52kkH5SOp/l+dJysgsxTbRzzqLR WKAn5i2SwzgZ9P8A69Xo9OXyPLVTJu/iwfTrj+lYVKjSJkyr/ZxW/IQYViu790cDPUcfl/nNSGxS 0RpkTzmGCIzjPXP6c0OtdKwrlNPPZ/MlR9zt/H827tj3/CpLi1YxBmidSVztUjBY8fzxx7npWnOk 0VdFa5ijiiiCygsV3Ngcc/8A6qgxg4469a1i7oBAwAAPQ09TllAYgZ4HYGtALMMZ2szoSi8DY/8A ERxwev5VIi7w5YIDjOSMEc/lUNoB0sUkQwmcj5SmcE0htpxGQYycckg9BUtoaY4xSBtsgHy9NxwC e4/nTmhMNsERjvdtpzkYH9fTPtUOWoFfZIAQSI23bRyMHJweatpGzRiLzIX25GAN3HUnP04605MV i5AN8fmbkEiLyGORnk8kg+o/yKr3bsWlSOKNRH1KKM8k8kj6VzJ3kT11Ky3LymSBtmSDvbjHf9ee D9abLMrwGNVHydOe568Dit7Weg7XHSwwshaSWOMxjYBtI6fQcmiG6t47gtIiuAOWRcAHpntTd2tA tccxtbu6DbCqkhVAOefT9RTJLaLA2yYPJIZfrjGPw7mpjKcbJisyr5cplEWV3H5Rggg09leOc4C4 3fKSBz+db8ybsh3LFnCDu3ndkHagUnBPH9anSzl8gOsjAuow2dvbnI/Ksp1Etwemo2OwJiYMcPzt 465x1NV3tm83aqFnOCqgdPepjUu7CuVriKWNsyKwJ9R2qIbuF55PBrpTTRQ+QGJ9krHPcDsakWOd 7dCcmNssFzwO2aHJJXFew4xSJGQuCvPzDufSq24oDu4OeRilFpjMTeSADTxK2OorRSZluBLk43Yo ZiVHORmhyYaCbgAMDBpcg4IHUflUANATOcfMacNpA3CncLsQhc4A4HTFI8atyc5qrhcRYyY9u/5c 5xil2JnIPvwKlsbdwGOCOcHvTt2D9aVyRwkww9jn61Ik6mVpDxjkD2ouO5LNdz3cwZckkAe/sKJL d3zKUbIJU5AB4GTxVp6CuGxQoYRodoydx6/hTfs++UAt5ZIB9Rz3oGmRyM6Sne5YjjLDrVi0AaRZ MDCDLehrOb0Dcv6dIn9pOsy8OxBOc9+T+Va0MXkgygDdG4ZyOFJPUfh9K46uhSTHFSkU+1QyuuwI epwcfyJFMnwd8LK0jFiNw+YjIJ4Pp7VzJ6iaHM1xI8TGJlUrvwTgLk9T77RTw8cUUwO3YhDZz909 OPTtVPsir6Fdp42kSJEZGhbccggKFOSMd+B+HoamVnbaVb5ifM8sd+QRn8R0q+VpI0SRDBcsDIzn Y4bcw5wMHp69hxVqBgiRxx3A8xcbYycnnjJ9OD0+lRNWE0RXOFgmHnEbkG7OTuy/X26k/getQy2A kubkxqBHAoK5Hc9F+uMkjtWtKViUhsdsZFCEghULE9gPTHryBTEtytokpd0DsE4X7zAkcc89hXQp 2dirojLSNeYaTcw6ugypwOB+lNYyEgrDtbbtJOMovGOMcdOtNLVC8ycuCsKyQExnJUE4J5wQT9c+ lSWtoGkf5gHjIBhLfOc/3V6t9Bz+tVcaYlwSmX8pCxALEhsDKjoPxH5elRW6OzjyA5XIOXH3T0/H qe1Q7OIx8ZNm8iqWZlHK7QBjIAO4nJPPpUiXUhkO9hFFGD5mEOR1yM5rGUE9SWi7BKhEks+FjEWV ycZ7fy+tNkuogjva8oqglzwDknP5H9c1zcrIsyOS6dbkpDEEQKZBtBJYDIH59KUS+VaifYnQcAjj gd+vbr7e1a2aQWMfczEsN+5ycbj0H9aQRlH2SlVIJySTk+2egrtjojTYHZAQhZFyADhQRz3yOnGP enxyLtMarlnYlXBxxzxjtVNXELIRvdR/AxIJbOfYdjVxHJVXSdzIqdDwEPoDnA4J/Ws5XWo76E8K KZQ8rl5U2g5fJwMfhU88RdGYGOOMYG0nGCOv15P6VzynqSyAiaKB9srCGM/NiTIIzn+eOKZLAZ5V VEYMx2gkr12jO7HQdT0/OqjJXuCehGIZZGkE8bICpKHGcMD25xz61DOjZ2GAxqhx8jHqe/UjPStF OL6hzCwSfZ3ePDhkHzBpOhHp+QpGuLiUZ2Md+ASOXPYZPr/9elyJu4Dbi1MaowKOAm7Lc55xjHtx VNkxkhGVccg9u2enrWsJJoLj0gkbaqK/zEAAdz6VEVXJ4q0+w7ig9OxUcYFOid0dTjntg4p2C4qs 4yYpNh69e46UNI0mDICWxjKnvnrz/TFTyq4A8r4UlzkHgg4I/wA+tW4L1yFWSRsOcZC5zn1FZzim tAYovEVcFmdQck+xI9en/wCuo5dQkDMkcaxvu+c7t2cHoDxxWcaeupKjbUryTyFlAdlAIIGeB+FO a63qFkVS6nIIGO+etbcumhQ+2ZJ75nlKrnLcjIJ9D9auLdW6NIkTEBvlUkHCY4/EcVlUTegnG5BL co6gDCkEEgDgkjrVOV425Xrk8+oq6aaGjC2gNknIpQBnqTitjMfuGeKa2ARg9eaQrCAbj1wP5UHO eAAMYpgC8sN3rxTgzBefpQIRCSvPbmnH069/pTYCE4XAppBJ5qbjFA5A9qULkFj60XEJjJzTgoyB 1JoAPmVgP5VI00ioAGYFs9D1z1ouCEBLgjNKCQMM1DYCrbPKFdjkM4U46j8KtxWLhmgkJHluwfHr 0H8qiUlsVdGnp9k8TyM5VXUnIJ5J5HU++PrWj+9WMJKFAkjBV+pDHjnHXtXJUkmO+mg+UstqsoJm mG0jOF3Hk9PzP4c0l0hSMKWTk+Y4XBHTgDnv9eMdqysm7jUr6k0sKxKhkDbugUvjccYAP5/zqjLl QhVxIXAZ2xwwxjn24/ShKz1E9BIYyYZ5XRd0o2qCeW5ycfhj9auGBIoIipUCYsGZRknYcYz/AJ/w uUirkQQY3yY+YcMWxx6Dt2qOWWUvtkn4zghTwM//AFx+tLfcd9CxDp01zK24llMqHaTjHb9M5p10 pnLmJQqrukx/f6KCffAzii9tBXsFuwkYqFG04Ls3UAEZ4/Tmm3UUiqgkd22qzg7gMZH5jj0Hr7Ul L3iW76lGPTTJcKEdShIB8ogDOeAAef0q9PZKUcRR48xlBAbPG4nv0HT8q3nVV0htlq4sxJsjAULE ETap59MceuP1NQvbho5HMhYu43sVAIIAB6HvgVg6j6CRRv7oMjrHmRpnAUsOAQduPrx+optjNGIZ gwTcw4+faMgE8jH0GfWtor3NTSOoti1otxI8azlQOplBDbSCMAr7VC1xKsxdJPLDEuCWGRycjIB9 /wAqvd2DVGlNcIGjieIeTEIj8jDPHOfzPWq0jpb2flR7VkxuAZsr0Pv9eO/HesbO4JXEjugL6Rnk zGU2H5D82B9PUGkSzmu7WCGIFA0m9hjBx2/LdVP3dw2GyyQ2t7Cjq+1MFpR354x68c8etPvrRJpt tqocAszMOMgjCnntkZP1q1JqzJfmUFtcWChY8zMxy3ZVH9cinSQvAoO4AD5HzySck/yH/wBetVUT YIc9vkRhF++Mx+YcAjPr06ip7ZVihldwQQdqnJUc8jv9amUrxK0L9vCPL8x0DyHpnov+eKSbDylA S247nYLwD14OevHWuPmvITEmRI4REPMmVjubL5OenXr1/Wp2kWzglcujszlQwA+6Pr0wcj8OtJts VmSRsmFDuSnYE5BBb/69OlvQltPtQFC42sDyyg9vckCpV7kKOpmF5JJViCJKOAWlcLswMH655q5F bxxMxCiQo+4AtkKQT+mT+lauT5bDZKywO8Eg2so+RQeQTnnn601raASSuxO6dAiAjO3BHP8AKoU2 hWYl5AsarLbAv5XzqvTkj5Tx6VnHR2R3TzlIYEZI6DPBH5VrCrYLtCQ6YxjMqx7kZiEBYfLkZHfn nAxVQafKtv5uASDjHvnH+NdCrLqNMu/2NuPzuSikrvXg9Fxx3+8ahbTpXudpcRpIdqEjhsHGB+Wa lVtQcrCX1m1tbQgkMzL93H3SOT/OoPsjiGSUnCqgZVz3yP8AGrjUTjcE7oplGCgspGehNNAOQQen 6Vukirj8kjJyce3FSJbO4i2jKynaBnvSbSE2Pmtlht0mLbd/3cc54FOgtTNZPcMc7M8dz0/xqFJN XBO5BNbyRhSDv3Lu4PSo/JYKGKnkZrSLVh3MUE/hSAnqKDMQk5x60u795gntTAcOhAPWl3ELj1qQ FZgDxwAMCkySuCelMBd3A24pGOThfzpCEUndk+tPGMYz7fSgYnc/pSk8UhDWJHGetPA4BB6UADZL bs0D74z26CgCxBH5vyqBj+dTfZmeQMyMGOAi8c4OP8ahysK5qabCksSTmFsQscbD1YggA+9W7WJ3 aOUxqC8mSX/h2jA/HPP4muScveYa3LtzIiyb1BVpGJXjb8vbP5n8qhG5pCzzENHyqqePUZz/AJ61 jcd7Ow3zA8mZXAEjAYA9vp1qSe4jjhSaOQF4yflJGQvTGSMHP+NLUEMKs7LMkrHYoZflzknqevuK RgJ7R5EQhMck4+7nj/PvTZT1QtqA9q3KocfKXOF7nk/j+tIs11bRrGz4SVAYsgENk9vTqM00r7gr kUc0k195BIDAEZzkL9Pw71ZtozHcBm2qVcNtYckY4Jz70SshNlma9yHAZyxGSGXaBz1z39aijeZr RgkigDkjjJ9P1IrNE37E1vJDEiMm8oo3DIOS3v8Aj/nvTJ3b7WrXA4gLZD8bemc/57U763HfQcwR 7oMhMYDYjZTjHbPr/kVNEgWOSLeG25Ld8YB6/hSbuURyvOYdwi8yQvjaT3GTmqF5HLBciOFg8JLO AclvmPPOOcA4zV07bFRJ1ttwdFj2xiNdrE5w4PGPwxn/AOvTpbWC3t8xIQ0m8bj2BX+uMVTmwb10 K8dhKbVUMOBEpYb+Mtlhz6DAH5VRktJ/LVZCFiRPv4xv5Prjvn8xW0aibGmaUNjbMsrMrKGIZCSc ICp6fif0FVE0+FBaTNdRyFskxluCvqD2GMdalVHfVBdotR2PmIs87Hy3HmBNpyFVcDA5zwR2q6IF S1uHz5Sycrk8g9OSe5IGfTPsKznO+gc1x7afDDHamXDBov3ThshtxI/MYqndvBLIfLlDyRIMI2Qr DGCfrnA+v1qVJt2EyNbm5QFUjJG7awHDFcEd/XjH1pvlvOylYwhZQGyAxJxyfw9utOOmqYkrEMEI ht3nlCKrIFTMmFz2JPPeprSOdrd9ySqMfKd2NzDHAb05zz2BreUk0XYlhAa6aIzqCrEElg2SQR1P v/nmpCtvcMwjgVEwq4JyT65+uSfxrGSsU1ZEy2SR5kuZcuE2nbgDGeg7596p3VgYTt3BwOEbsBnr 265/WiLFfQRoyqwQuUmSRlCuDt2gnAyO461HPaMXNqQzeW23aPlDDqMcHv1q1a4k7kmnW04jZ2jL Kibyd24n2x9OR9DU4hljW4niGQUWUo7YBBxwDjk9Tiok1ci4RA/Z0dPmQNlD129Ocj6mn35kQkkD 5EVgThd3AyR9T/IVKV3YqKTZRF7GY41KOqP+7Yxt90Yx0HpnPSrLuqyjA2mOMIyjnA4OT371o42L 5VcjhuxIrRySJI8a71BGORyT/P1pJ71GUxOSFLbcoAADkcj/AB+tHI7k8oai4izEjkRcAqD8ykHn p3rQSI3cotro75IwSCn8LFshs/8AASKT0VyXGxG7QtIXchgMhMDk9QcfmPyqKZUVfLZmTEZYALzt PT+X6VMWxW10KPmWiuUfeQGJ5PBBH+fyqGb7Gyfu8RqQFOPY9fxwa6E5pjsxqpBGxw2QVyq5yT+V PsnMahW+9kshxx06ex5pylJoGi/9kiuLJwvQHBKjIXHGP8KzrpBBAIbdxKhG4hT97Prj0pQl9lgv MktP9J04WrKVPO1j7HPT65qkxuoUJy0bRtjjPHt/9b2rSLXM0wRzYAxuxmmnPVuuO1dRCAHvjilI 5PHJoY2AIxwwFOIO0expbCDHA4zn0oJD9eAOwoQAM5z2Aox6YoEBAwPSlXoQe9IYoGRgDNIRggZw Mc0CFILYwacuNpIPal0ARjxgd6fkbhxnHWgCzajcS3p1/Stiyij8ncVyyltqsM9K5arshNFiwUxG c22OiscrxnuR6cnirTuXYqT5kK8jd1BH8+lc0ndlJ6FeZgbUygoPLxhQCeSMn9aaiShJPMYiORRv zyR3GPXH+NLZEjpYz9l3qUzuLZH8Q6/rkGiOON5Ss5DiRCcAHjHIB9uM0XsS1Yka8D28o+4d4woO Rx160xbiZVBEhMUgY4I+8vXFK3cq7HRuxihiAZlcbm64I6AH24P5065liYxKmMouQN2BnPPH503d MbZZiaLInVVDYMYwvygfTHqTzUFqQrOZ32qq7jxSIZLZpFLdeXOWXeFHmY6qccY6A89fpS27OS1v Coh81dqsTkAklSfwyf0pNK40uolvteLBYJmMncwzt59+nAFSX063N/MZGDs7NtjUHknLDPr2zR1s VayFu1AvAS37kvmMKOwAGPr3P1q1G6xyEiNSGhJkbrk9Bz9alsYworf6w4SPBLFvUZx7/wD16rzs hjAddrZ+RiOSOp7dKFoCfUuRv516dqAtkuqqcD1/KoZ5H3vsIDj92cnI5ODx6/8A16NRoWWTETxs BuXC+Wf4cEdvq1M8l7iwlSeQ4HG3GAp2kj9RVRY0yZY1ltBBhRJFGSkhBOV54I7is26+1WsNvHDh VbCGUH7g9eDnpWid3ZlDo55QFguUZgQqJNyCzFSWIPXHy47dqszSK7QWqBkhSTJ2jjHBY47cYP1q WtdNgitRGuPIMVspY+UrAKASsYAHJx6dfwP0qvKkXzCeddojQKyYyTk9SR05z+NNJ7lNW1Ee63Sw Qrl1RctIjAkkZOPfkDninpM0Vl86nygGYBzhgc5HAJpyVkJ6EFxLGt6vm7cwKGl8zJyCRyO2QvPP r61ZZB9vUQ3KNGR+7VUYHOF4wRxg+1W42Wo2tCk0krLGZbVTKAWZhhgxJ4A7/lVi1mgRQ2WB38K2 ckHHy59v60ON1oCV0XUnBjSWMbxtYnPJYHp9Mc0rgTwzTrIrqox/e28ZOe+DgVhawNWQsqQPPH5o GxZAAN4UgrjoecZx1I7U26mjupRJ5bW4LqY93PAJwc+4/wA81cb3uJbEcSxTW/lo7pK6qmWG0uqn I6j17+9DXT28XkwoWZQuwOD+YPQ4qXeWgrXHmR1ttqMijyjvG7lQcc9OMYYflSSf6SxlSbefIEbR hTlAGIBA79M+5OaqNrjW+hFbQwu8BCvGyQtGCEwH6j5vrnt7VBplqbbVYi4aTzBKGATgEA8Y9yMf lWynumDdiDUYZIGa6j3P5yskgBHyndjb+QP5VPZWbz3EouNvzkMOOV552+nOKrmShcNkSHS4p4nk WQgIN0jRnJU49B13cnOO1T/akjkkRpWVk+VRng/Njn6E/wCc1lKXNoFmSzpHLsdzukgyV2nvnI/m B+NZ88sP2WOWZQ0hO0Ieuc4/T5vxqYXbsgSK8MaXEUkiEOvOI1TkNzgH1BH8qrXMSpOIE2SFn2xk ZGBng/j6V1R+KxPUgS3ubmQqoBkXnYR8x+g6mtGwgCyQPMoWeN87GbOeMgjHc+/pVVJJLQGy1YqI oBBJGVdv3menOef0AqC9t4t1vAqASg8Fs7WB5INcyfv3EyRRGhaSLMUTHaCD09/8+lSyW8V0kr9C VCu3XaSM1DbTuO5//9k ________________________________________________________________________________
Subject: Paint scheme
Date: May 26, 2007
Dean - that is One Hot Paint Job and it looks fast just sitting there. I think you will be happy that the wing root stripes did not extend further outboard to the prop tip deflection line. It's even prettier than the graphic you shared. OSH should be really exciting. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Sent: Saturday, May 26, 2007 9:44 PM Subject: RV10-List: Paint scheme I have received a few replies on my Transition training write-up and wanted to clarify the pic of my RV10 in the paint booth. I have also attached a few pics of the RV10 in the sun today. This paint scheme is a slight modification of a work or art that Deems Davis put together some time ago. When I visited Deems at his house last year I asked him if I could copy his scheme with different colors. He was gracious enough to send me the file and SIREF draw4.0 to make the scheme my own. If you look at Deems scheme vs mine........I have more color on the belly, a longer, stretched swoosh. Also, the wings have more color at the fuselage and they have solid stripes versus coming to a point at the leading edge. I also made the accent stripes shorter. I have received several kudos from pilots in the area and at the field already with this scheme. I want to publicly thank Deems for his Work of Art that he shared freely and for his great website that continues to help hundreds of builders everyday! Dean 40449 ________________________________________________________________________________
Subject: Re: FS: MT Prop Gov
Date: May 27, 2007
Hi William, I don't know if N401RV has a narrow deck engine, or a wide deck engine.=C2 - I have only seen Van's Aircraft selling the MT governor for the narrow d eck Lyc. 540 engine.=C2- I have not seen them list the correct=C2-MT gov ernor for a wide deck engine. I haven't done this, but I have heard that the MT governors for the narrow d eck Lyc. 540 engine will work on the wide deck engine.=C2- If the high RPM adjustment screw is moved to its limit.=C2- Or, sometimes, the metal stop needs to be filed to get additional travel on the governor control arm. BTW, the safety wire can be=C2-cut and the=C2-six safety wired screws ca n be loosened in order to rotate the governor arm and stop assembly.=C2- W hen the governor arm is in the position you want, the six screws can be tigh tened and safety wired. Do not remove the governor arm from the splined shaft.=C2- This is a bad t hing. Regards, Jim Ayers : rv10-list(at)matronics.com Sent: Sat, 26 May 2007 7:18 pm Subject: Re: RV10-List: FS: MT Prop Gov Jim, I hope this is not correct since my TMX IO-540 engine has the same standard hex uts as the engine in 410RV which would make it a WIDE deck engine. N410RV ttp://www.myrv10.com/miscphotos/TerryCole/abilene/Abilene_04_RV10_072.jpg My TMX IO-540 ttp://wcurtis.nerv10.com/20Engine/Engine02.jpg The governor I just received in the Van's firewall forward kit is MT P-860-3 . ccording to the you, I should need the P-860-5. Does Van's use a -3 or a -5 in 401RV? 'll have to check with Mattituck on this. William ttp://wcurtis.nerv10.com/ -------- Original Message -------- X-Rcpt-To: Just for the sake of clarification, the Lyc. IO-540-C4B5 engine has two different governor gear ratios. The NARROW deck has a 0.895:1 gear ratio and uses the MT governor P-860-3 or P-420-17. The WIDE deck has a 0.947:1 gear ratio and uses the MT governor P-860-5 or P-420-5. The cylinders on the NARROW deck engine are mounted with round nuts having an internal Allen wrench drive. The cylinders on the WIDE deck engine are mounted with standard hex nuts. I have not seen the WIDE deck MT governors being offered for sale by Van's Aircraft. I have only seen them offer the MT governors designed for the NARROW deck Lyc. 540 engine. Regards, Jim Ayers In a message dated 05/25/2007 9:26:16 A.M. Pacific Daylight Time, wcurtis(at)nerv10.com writes: --> RV10-List message posted by: "William Curtis" Some folks are opting for the PCU5000/X (http://pcu5000.com). It supposed ly governs better than the MT provided in the FF kit. Someone on Vansairforc e is doing a group buy of the PCU5000. Since the PCU5000X ($1350) is more expensive than the MT ($Van's $1100), this may be another case of a solut ion > looking for a problem. Has anyone flying had issues with the MT P-860-3 ? http://www.vansairforce.com/community/showthread.php?t=17279&page=1&pp =10&high light=pcu William http://wcurtis.nerv10.com/ ************************************** See what's free at http://www.aol.co m. -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as the Subscriptions page, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: -= --> http://www.matronics.com/Navigator?RV10-List -======================== -= - NEW MATRONICS WEB FORUMS - -= Same great content now also available via the Web Forums! -= --> http://forums.matronics.com -======================== ________________________________________________________________________ AOL at AOL.com. ________________________________________________________________________________
Subject: Aero Composits Prop
Date: May 26, 2007
I think it was just over 4 months. I ordered the spinner later though and they are just going to send it this next week. Albert Gardner Yuma, AZ 40-422 -----Original Message----- Good on ya! I just saw Deem's two days ago - It is beautiful, too. I suspect it's nearly time to order mine. How long between order and delivery for you? Best John Ackerman 40458 QB fuselage, just beginning cabin cover ________________________________________________________________________________
Date: May 27, 2007
Subject: Re: Climb rates at full gross
Tim, Tim Olson just added as section called "Tim's RV-10 FAQ" that is located 3 lines below the picture of his plane on his home page. A lot of good info. I've copied below what he put in that section that I believe answers you question for his configuration. He has a Hartzell though. How fast does it go, and how fast does it climb? The RV-10 has an approximate top speed of about 183-185kts if you equip it with a a standard 260Hp IO-540. Refer to _Van's Aircraft_ (http://www.vansaircraft.com/public/rv-10int.htm) for their official specs, but what is listed _here_ (http://www.myrv10.com/N104CD/why/index.html) might be a fair guide too. You can expect to cruise x/c at between 160 and 170kts. Climb while solo is about 2100-2200fpm, and climb with 2 front seaters should easily make 1700fpm. Loaded up full, you may see an anemic reduced climb of only 1500-1600fpm on a warm day. Even up at 10,000' MSL, your climb will likely approach 900-1000fpm. In short, yeah, it is plenty fast. Dave Syvertson Sugar Land, TX 40625 QB fuselage do not archieve ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: The Perfect Panel...major alterations
Date: May 27, 2007
As to defining a "major alteration", here's an excerpt from the operating limitations assigned to my RV-10 last August (sorry for the picture format, I need to rescan the source someday). It specifically mentions changing the "make and model" of a prop or engine in case that helps. Marcus 40286 Great statement Bobby. Now here is a new question that goes to the heart of Amateur Built (current rules). Does a total change-out of engine type, prop type or major alteration to an airframe (Down the Road) require a revisit by a DAR or PAI? Or does the repairman have the latitude to alter the engine/prop/panel from basic VFR to EFIS/IFR without a trail of paperwork and new set of eyes? What latitude for modification is legal and appropriate for a kit designed and tested VAN's RV-10? "Round Two" - No bio required "Do you feel Lucky?" John Cox A&P with IA 40600 ________________________________________________________________________________
Date: May 27, 2007
You win the prize Marcus. I would have added the change of instrumentation and panel layout as well. Although notification and request for concurrence to the FSDO was not required. Just your stated ability to do so in the Operating Limitations. Though there is no baseline... more than 5% BHP increase is discussed as being major. Certification that it continues to meet the initial safe operation perimeters is required. The EAA office can assist in making sure the back door is left open. Without such a clause the "Door is Closed". Once certified as Experimental you are good to experiment every week as long as you opened the door in the approved documents. So placing a Thunderbolt IO-580 should really rattle some windows. John C. 40600 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Sunday, May 27, 2007 6:13 AM Subject: RE: RV10-List: The Perfect Panel...major alterations As to defining a "major alteration", here's an excerpt from the operating limitations assigned to my RV-10 last August (sorry for the picture format, I need to rescan the source someday). It specifically mentions changing the "make and model" of a prop or engine in case that helps. Marcus 40286 Great statement Bobby. Now here is a new question that goes to the heart of Amateur Built (current rules). Does a total change-out of engine type, prop type or major alteration to an airframe (Down the Road) require a revisit by a DAR or PAI? Or does the repairman have the latitude to alter the engine/prop/panel from basic VFR to EFIS/IFR without a trail of paperwork and new set of eyes? What latitude for modification is legal and appropriate for a kit designed and tested VAN's RV-10? "Round Two" - No bio required "Do you feel Lucky?" John Cox A&P with IA 40600 ________________________________________________________________________________
Subject: empty weight
Date: May 27, 2007
This is a request for others of the 80 RV-10s to post their empty weight for those of us still building. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, April 21, 2006 5:49 PM Subject: Re: RV10-List: empty weight Tim 1,685 Randy 1,625 Vic 1,665 Chuck 1,615 Rob 1,558 Chuck and Vic weight from <http://www.rvproject.com/wab/> Rob, looks like you have the light weight machine. Which prop? With or without wheel pants? Larry Rosen http://lrosen.nerv10.com ________________________________________________________________________________
Subject: Spring Flying
Date: May 27, 2007
It's time for some John Jessen levity and flight time after all the IFR build data. http://cgi-bin.simradar.com/video_delivery/3145/vftc.ram Now if you could just update the Xplane with the current RV10 data set from Tim's numbers. http://forums.x-plane.org/index.php?autocom=dlmanager&do=viewfile&fid =45 93 John Cox #600 ________________________________________________________________________________
Subject: Re: empty weight
Date: May 27, 2007
EW 1673, no paint or interior other than seats Doug Preston 40372 N372RV -----Original Message----- From: John W. Cox <johnwcox(at)pacificnw.com> Sent: Sun, 27 May 2007 4:33 pm Subject: RE: RV10-List: empty weight This is a request for others of the 80 RV-10s to post their empty weight for those of us still building. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, April 21, 2006 5:49 PM Subject: Re: RV10-List: empty weight Tim 1,685 Randy 1,625 Vic 1,665 Chuck 1,615 Rob 1,558 Chuck and Vic weight from <http://www.rvproject.com/wab/> Rob, looks like you have the light weight machine. Which prop? With or without wheel pants? Larry Rosen http://lrosen.nerv10.com ________________________________________________________________________ ________________________________________________________________________________
Date: May 27, 2007
N410MR EW 1,667. Interior and paint. >From: dougpflyrv(at)aol.com >Reply-To: rv10-list(at)matronics.com >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: empty weight >Date: Sun, 27 May 2007 19:39:45 -0400 > > >EW 1673, no paint or interior other than seats > >Doug Preston > >40372 > >N372RV > > >-----Original Message----- >From: John W. Cox <johnwcox(at)pacificnw.com> >To: rv10-list(at)matronics.com >Sent: Sun, 27 May 2007 4:33 pm >Subject: RE: RV10-List: empty weight > > >This is a request for others of the 80 RV-10s to post their empty weight >for those of us still building. > >John Cox > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen >Sent: Friday, April 21, 2006 5:49 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: empty weight > > >Tim 1,685 >Randy 1,625 >Vic 1,665 >Chuck 1,615 >Rob 1,558 > >Chuck and Vic weight from <http://www.rvproject.com/wab/> > >Rob, looks like you have the light weight machine. Which prop? With or > >without wheel pants? > >Larry Rosen >http://lrosen.nerv10.com > > >________________________________________________________________________ _________________________________________________________________ More photos, more messages, more storageget 2GB with Windows Live Hotmail. ________________________________________________________________________________
Subject: Re: Gas leak
Date: May 27, 2007
apilot2(at)gmail.com wrote: > Your friendly NAPA or Autozone, etc. auto parts store, in their > (aircraft) sealant's area. Right along with their Form a gasket, > Permatex #2 & #3, epoxies, etc. I found it in the aircraft supply section of Autozone. Previously in this thread, it was referenced as 'Loctite 290' but all I found was 'Permatex' and their number was PX # 29000. It is labeled 'Threadlocker Green' and 'Penetrating Formula' so I am sure it is the correct item. The good news is that today I tested both tanks and they got a green light, no bubbles detected. This last week I had been baloon testing and they were going down at a VERY slow rate which I attribute to the fact that you blow up a baloon, tie it off and it will still go down over the course of a couple days. So to go the extra mile, I soaped up the tanks and I am a happy camper [Laughing] Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=115110#115110 ________________________________________________________________________________
Subject: DVD - Pop Up Display
Date: May 27, 2007
RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc...) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts ________________________________________________________________________________
Date: May 27, 2007
I put a PAV80 in my panel and have two remote screens for the back seats. It is made by PS Engineering (www.ps-engineering.com/entertainment.shtml. Watch out for the price. I am not flying yet, so I can not vouch for how well it works... Rene' 40322 Finish or something like it.. N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 27, 2007 7:05 PM Subject: RV10-List: DVD - Pop Up Display RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc.) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts ________________________________________________________________________________
Date: May 27, 2007
Subject: Sound proofing the 10 ?
I have been lurking on this group for months and appreciate Everyone=A2s id eas, suggestions, and opinions. Thanks to all. =0A =0ANow I need to ask for advise/recommendations. I have searched this site as well as vansairforce. net and haven=A2t found a lot of information posted pertaining to insulatio n &/or soundproofing the RV-10. Is anyone other than Deems & Curtis soundp roofing their aircraft? I=A2m working on the fuse and am trying to weigh th e options, Pros vs. Cons. My thinking is that I will add something that is approved to deaden the noise. It's what is available that has me perplexed. Any recommendations would be appreciated. Sorry to delve off the panel dis cussion topic, but I need to think about installation before laying the flo ors/side panels of the fuse. Specifically, I'm looking for materials like w hats available from aircraft spruce and SoundExproducts. http://www.aircra ftspruce.com/catalog/appages/soundproofinstall.php. And this link I copied from Curtis http://www.soundexproducts.com/information.html =0A =0A =0AThan ks=0AJohn =0A#40102 ________________________________________________________________________________
Date: May 27, 2007
Rene, I found the weight of the PS head unit in the data sheets (2.8 lbs) but once you add the one screen (to be comparable to my head unit) it's probably 4.5 lbs lighter than my unit. Unfortunately as a certified unit I am more likely to remove my spleen (to save weight) than spend $3,000 + $800 + 3 x $400... $4,000 for my family's aviation entertainment. (insert additional cheep jokes here) I am sure the PS is a great unit and maybe after I burn up my unit two or three times the PS would have made more sense. I am sure your system is going to be fantastic. Thanks for your input. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Sunday, May 27, 2007 6:25 PM Subject: RE: RV10-List: DVD - Pop Up Display I put a PAV80 in my panel and have two remote screens for the back seats. It is made by PS Engineering (www.ps-engineering.com/entertainment.shtml. Watch out for the price. I am not flying yet, so I can not vouch for how well it works..... Rene'nd the 40322 Finish or something like it.... N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 27, 2007 7:05 PM Subject: RV10-List: DVD - Pop Up Display RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc...) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com ________________________________________________________________________________
Date: May 27, 2007
John, insulation whether Sound Attenuating or Thermal adds weight. Your use of the work "Approved" may just imply compliant with FAR 25.283 fire retardant "Flame Spread" standards. On the other hand as the builder, anything you use becomes approved by your use and your DAR's acceptance, as there is no standard. So what are your objectives again? I am a fan of Zetex for the firewall. Remember that all insulation should be able to be removed for future inspection of corrosion. Great insulation does not absorb moisture but allows it to pass through like a band-aid. Dan Newland did an article for Sport Aviation in April 2005 on this exact subject, but my archive PDF was 15 meg so check the EAA archives. We don't need screams from the " tin can and string crowd". John #40600 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hurst Sent: Sunday, May 27, 2007 6:30 PM To: rv10-list(at)matronics.com Subject: RV10-List: Sound proofing the 10 ? I have been lurking on this group for months and appreciate Everyone=A2s ideas, suggestions, and opinions. Thanks to all. Now I need to ask for advise/recommendations. I have searched this site as well as vansairforce.net and haven=A2t found a lot of information posted pertaining to insulation &/or soundproofing the RV-10. Is anyone other than Deems & Curtis soundproofing their aircraft? I=A2m working on the fuse and am trying to weigh the options, Pros vs. Cons. My thinking is that I will add something that is approved to deaden the noise. It's what is available that has me perplexed. Any recommendations would be appreciated. Sorry to delve off the panel discussion topic, but I need to think about installation before laying the floors/side panels of the fuse. Specifically, I'm looking for materials like whats available from aircraft spruce and SoundExproducts. http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php. And this link I copied from Curtis http://www.soundexproducts.com/information.html Thanks John #40102 ________________________________________________________________________________
Subject: Re: Sound proofing the 10 ?
Date: May 27, 2007
John: For better or for worse I have soundproofed/insulated my 10. I primarily used Aircraft Spruce "Super Soundproofing Sheet" (pn 09-42719, etc) in various thicknesses. Every external panel and floorboard (and even the baggage door) has this stuff attached to the fuse skin (using a spray on adhesive recommended by Sir Tim) using various thicknesses. Under the front floorboards and forward tunnel I also put a layer of heat/fire insulation (obtained from Abby at Flightlline). I did all this primarily for the insulation factors since I live and fly in Maine---and what with the ANR headsets, noise reduction was of secondary importance. Fitting all the spaces was a bit of a chore but since the two sides are mirror images you only have to measure and cut once for every two spaces (and even less than that with some of the floor spaces all the same size). I used some butcher paper initially to make the patterns---if I had been thinking I could have marked these up as to their location and sent them on to another builder. I would guess it took me about 8 hours to do the whole plane, not counting the firewall which I have yet to do. It does add some weight---maybe in the order of 5-10 lbs. Hope it keeps me warm. Jay Rowe ----- Original Message ----- From: John Hurst To: rv10-list(at)matronics.com Sent: Sunday, May 27, 2007 9:30 PM Subject: RV10-List: Sound proofing the 10 ? I have been lurking on this group for months and appreciate Everyone=A2s ideas, suggestions, and opinions. Thanks to all. Now I need to ask for advise/recommendations. I have searched this site as well as vansairforce.net and haven=A2t found a lot of information posted pertaining to insulation &/or soundproofing the RV-10. Is anyone other than Deems & Curtis soundproofing their aircraft? I=A2m working on the fuse and am trying to weigh the options, Pros vs. Cons. My thinking is that I will add something that is approved to deaden the noise. It's what is available that has me perplexed. Any recommendations would be appreciated. Sorry to delve off the panel discussion topic, but I need to think about installation before laying the floors/side panels of the fuse. Specifically, I'm looking for materials like whats available from aircraft spruce and SoundExproducts. http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php. And this link I copied from Curtis http://www.soundexproducts.com/information.html Thanks John #40102 ------------------------------------------------------------------------- ----- 5/26/2007 10:47 AM ________________________________________________________________________________
Date: May 27, 2007
Hi John and all... The June Kitplanes issue has an article on soundproofing- it was centered on Rick Lindstrom's Zenith 601XL, but I would imagine that the non-model-specific information may be helpful. best, Cory John W. Cox wrote: > John, insulation whether Sound Attenuating or Thermal adds weight. > Your use of the work "Approved" may just imply compliant with FAR > 25.283 fire retardant "Flame Spread" standards. On the other hand as > the builder, anything you use becomes approved by your use and your > DAR's acceptance, as there is no standard. So what are your > objectives again? I am a fan of Zetex for the firewall. Remember > that all insulation should be able to be removed for future inspection > of corrosion. Great insulation does not absorb moisture but allows it > to pass through like a band-aid. > > Dan Newland did an article for Sport Aviation in April 2005 on this > exact subject, but my archive PDF was 15 meg so check the EAA > archives. We don't need screams from the " tin can and string crowd". > > John > > #40600 > ________________________________________________________________________________
Date: May 28, 2007
40449 WT. 1614 EVERYTHING less fuel! DEAN ________________________________________________________________________________
Date: May 27, 2007
John,=0A =0AThat's what concerns me. All the references that I've read stat e that I should use contact cement (or some state that one side of the insu lating material contains an adhesive) all of which would prevent inspection of the aluminum structure. And yes I did mean "Approved" in the sense of t he FAR rule. A product that will NOT absorb moisture or odor, is long lasti ng and durable. Application for both sound and thermal barrier, more so on the sound side. As far as weight is concerned, I didn't think that it woul d add a considerable amount, possibly 8-10 pounds. That is just an estimat e and I didn't think that it was an issue for my family. Considering that o ur total weight is ~ 550 pounds (4 people).=0A =0AAlso, I'm presently looki ng for the April 2005 Sport Aviation issue to see what's recommended. It's on the EAA website but not linkable, its on page 52 Taming the Noise http: //www.eaa.org/benefits/sportaviation/0504_toc.html=0A=0A=0AJohn=0A#40102=0A =0A----- Original Message ----=0AFrom: John W. Cox <johnwcox(at)pacificnw.com> =0ATo: rv10-list(at)matronics.com=0ASent: Sunday, May 27, 2007 10:54:43 PM=0AS ubject: RE: RV10-List: Sound proofing the 10 ?=0A=0A=0AJohn, insulation whe ther Sound Attenuating or Thermal adds weight. Your use of the work =9CApproved=9D may just imply compliant with FAR 25.283 fire retardan t =9CFlame Spread=9D standards. On the other hand as the build er, anything you use becomes approved by your use and your DAR=99s ac ceptance, as there is no standard. So what are your objectives again? I a m a fan of Zetex for the firewall. Remember that all insulation should be able to be removed for future inspection of corrosion. Great insulation do es not absorb moisture but allows it to pass through like a band-aid.=0ADan Newland did an article for Sport Aviation in April 2005 on this exact subj ect, but my archive PDF was 15 meg so check the EAA archives. We don =99t need screams from the =9C tin can and string crowd=9D.=0AJ ohn=0A#40600=0AFrom: owner-rv10-list-server(at)matronics.com [mailto:owner-rv1 0-list-server(at)matronics.com] On Behalf Of John Hurst=0ASent: Sunday, May 27 , 2007 6:30 PM=0ATo: rv10-list(at)matronics.com=0ASubject: RV10-List: Sound pr oofing the 10 ?=0AI have been lurking on this group for months and apprecia te Everyone=CA=BCs ideas, suggestions, and opinions. Thanks to all. =0A =0A Now I need to ask for advise/recommendations. I have searched this site as well as vansairforce.net and haven=CA=BCt found a lot of information posted pertaining to insulation &/or soundproofing the RV-10. Is anyone other th an Deems & Curtis soundproofing their aircraft? I=CA=BCm working on the fus e and am trying to weigh the options, Pros vs. Cons. My thinking is that I will add something that is approved to deaden the noise. It's what is avail able that has me perplexed. Any recommendations would be appreciated. Sorry to delve off the panel discussion topic, but I need to think about install ation before laying the floors/side panels of the fuse. Specifically, I'm l ooking for materials like whats available from aircraft spruce and SoundExp roducts. http://www.aircraftspruce.com/catalog/appages/soundproofinstall.p hp. And this link I copied from Curtis http://www.soundexproducts.com/infor mation.html =0A =0A =0AThanks=0AJohn =0A#40102=0Ahttp://www.matronics.com/N ======================= ________________________________________________________________________________
Date: May 27, 2007
728 dd---1613 with paint no fairings ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 27, 2007
Robin, I had the same concern and went with the cheapest pop-up DVD player I could find on eBay. Shipped from China but works great overall. It was a little heavy, although I didn't actually weigh it. The performance of the -10 is so great that a few extra pounds is well worth keeping the family happy. My wife measures trips in how many DVDs to take and loves it. The only drawback with the el cheapo is it doesn't like heat too much. If I leave it powered off until at cruise there's no issues, but on a warm day down low it will start to skip and go stupid so I'm working on better cooling air for it. Marcus _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 27, 2007 8:05 PM Subject: RV10-List: DVD - Pop Up Display RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc.) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts ________________________________________________________________________________
Date: May 27, 2007
N939SB. 1628 with 16lbs heavier IO-540-N1, heavy alternator, and heavy starter. Prototype IFR glass panel, paint, interior, flying. Bill DeRouchey Mark Ritter wrote: N410MR EW 1,667. Interior and paint. >From: dougpflyrv(at)aol.com >Reply-To: rv10-list(at)matronics.com >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: empty weight >Date: Sun, 27 May 2007 19:39:45 -0400 > > >EW 1673, no paint or interior other than seats > >Doug Preston > >40372 > >N372RV > > >-----Original Message----- >From: John W. Cox >To: rv10-list(at)matronics.com >Sent: Sun, 27 May 2007 4:33 pm >Subject: RE: RV10-List: empty weight > > >This is a request for others of the 80 RV-10s to post their empty weight >for those of us still building. > >John Cox > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen >Sent: Friday, April 21, 2006 5:49 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: empty weight > > >Tim 1,685 >Randy 1,625 >Vic 1,665 >Chuck 1,615 >Rob 1,558 > >Chuck and Vic weight from > >Rob, looks like you have the light weight machine. Which prop? With or > >without wheel pants? > >Larry Rosen >http://lrosen.nerv10.com > > >________________________________________________________________________ _________________________________________________________________ More photos, more messages, more storageget 2GB with Windows Live Hotmail. ________________________________________________________________________________
Date: May 27, 2007
How many "linear ft" of this stuff are people buying? Ben 40579 (fuse bottom skins) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jay Rowe Sent: Sunday, May 27, 2007 8:09 PM Subject: Re: RV10-List: Sound proofing the 10 ? John: For better or for worse I have soundproofed/insulated my 10. I primarily used Aircraft Spruce "Super Soundproofing Sheet" (pn 09-42719, etc) in various thicknesses. Every external panel and floorboard (and even the baggage door) has this stuff attached to the fuse skin (using a spray on adhesive recommended by Sir Tim) using various thicknesses. Under the front floorboards and forward tunnel I also put a layer of heat/fire insulation (obtained from Abby at Flightlline). I did all this primarily for the insulation factors since I live and fly in Maine---and what with the ANR headsets, noise reduction was of secondary importance. Fitting all the spaces was a bit of a chore but since the two sides are mirror images you only have to measure and cut once for every two spaces (and even less than that with some of the floor spaces all the same size). I used some butcher paper initially to make the patterns---if I had been thinking I could have marked these up as to their location and sent them on to another builder. I would guess it took me about 8 hours to do the whole plane, not counting the firewall which I have yet to do. It does add some weight---maybe in the order of 5-10 lbs. Hope it keeps me warm. Jay Rowe ----- Original Message ----- From: John Hurst <mailto:johnh38(at)yahoo.com> Sent: Sunday, May 27, 2007 9:30 PM Subject: RV10-List: Sound proofing the 10 ? I have been lurking on this group for months and appreciate Everyone?s ideas, suggestions, and opinions. Thanks to all. Now I need to ask for advise/recommendations. I have searched this site as well as vansairforce.net and haven?t found a lot of information posted pertaining to insulation &/or soundproofing the RV-10. Is anyone other than Deems & Curtis soundproofing their aircraft? I?m working on the fuse and am trying to weigh the options, Pros vs. Cons. My thinking is that I will add something that is approved to deaden the noise. It's what is available that has me perplexed. Any recommendations would be appreciated. Sorry to delve off the panel discussion topic, but I need to think about installation before laying the floors/side panels of the fuse. Specifically, I'm looking for materials like whats available from aircraft spruce and SoundExproducts. http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php. And this link I copied from Curtis http://www.soundexproducts.com/information.html Thanks John #40102 href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com _____ Date: 5/26/2007 10:47 AM ________________________________________________________________________________
Subject: Re: Aero Composit Prop
Date: May 27, 2007
Prop looks good! Kevin 40494 ----- Original Message ----- From: Albert Gardner To: ibspud(at)roadrunner.com Sent: Saturday, May 26, 2007 11:16 AM Subject: RV10-List: Aero Composit Prop I picked up my prop in Redding, CA, Thursday at American Propeller. AeroComposites send the blades and hub there for assembly. It was crated very well but the size of the box made me wonder if I needed a bigger engine. Fortunately, when I opened the box the prop was much smaller than the box. Albert Gardner Yuma, AZ 40-422 ________________________________________________________________________________
Date: May 28, 2007
1570# - without wheel pants or paint (interior complete). In a message dated 5/27/2007 5:36:01 P.M. Eastern Daylight Time, johnwcox(at)pacificnw.com writes: --> RV10-List message posted by: "John W. Cox" This is a request for others of the 80 RV-10s to post their empty weight for those of us still building. John Cox Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew) ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 28, 2007
John, I considered sound proofing while I was building, but then I realized that I'd flown in both factory -10s and found the noise level to be quite accepta ble to me. I called to ask Van's what kind of insulation/soundproofing they had done; they said none. That is what I did as well and I'm very happy with it. I flew the first 50 hours with a regular headset and that was fine. I purchased a Lightspeed ANR headset a few months ago and that makes the air plane plenty quiet inside. -Jim 40134 In a message dated 5/27/2007 9:32:50 P.M. Eastern Daylight Time, johnh38(at)yahoo.com writes: I have been lurking on this group for months and appreciate Everyone=A2s ideas, suggestions, and opinions. Thanks to all. Now I need to ask for advise/recommendations. I have searched this site as well as vansairforce.net and haven=A2t found a lot of information posted pertaining to insulation &/or soundproofing the RV-10. Is anyone other th an Deems & Curtis soundproofing their aircraft? I=A2m working on the fuse and am try ing to weigh the options, Pros vs. Cons. My thinking is that I will add somethi ng that is approved to deaden the noise. It's what is available that has me perplexed. Any recommendations would be appreciated. Sorry to delve off the panel discussion topic, but I need to think about installation before layin g the floors/side panels of the fuse. Specifically, I'm looking for materials lik e whats available from aircraft spruce and SoundExproducts. _http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php_ (http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php) . And this link I copied from Curtis _http://www.soundexproducts.com/information.html_ (http://www.soundexproducts.com/information.html) Thanks John #40102 Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew) ************************************** See what's free at http://www.aol.com . ________________________________________________________________________________
Date: May 28, 2007
I used Super Sound Proofing from Aircraft Spruce under the floor panels (mercy I'll have to drill out 10,000 pop rivets to inspect per one guru) from the baggage area to the firewall. Also put some behind the fuse side panels and on the aft side of the firewall. Noise level is real low (have not measured sound level). Mark N410MR >From: John Hurst <johnh38(at)yahoo.com> >Reply-To: rv10-list(at)matronics.com >To: rv10-list(at)matronics.com >Subject: RV10-List: Sound proofing the 10 ? >Date: Sun, 27 May 2007 18:30:01 -0700 (PDT) > >I have been lurking on this group for months and appreciate Everyones >ideas, suggestions, and opinions. Thanks to all. > >Now I need to ask for advise/recommendations. I have searched this site as >well as vansairforce.net and havent found a lot of information posted >pertaining to insulation &/or soundproofing the RV-10. Is anyone other >than Deems & Curtis soundproofing their aircraft? Im working on the fuse >and am trying to weigh the options, Pros vs. Cons. My thinking is that I >will add something that is approved to deaden the noise. It's what is >available that has me perplexed. Any recommendations would be appreciated. >Sorry to delve off the panel discussion topic, but I need to think about >installation before laying the floors/side panels of the fuse. >Specifically, I'm looking for materials like whats available from aircraft >spruce and SoundExproducts. >http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php. And >this link I copied from Curtis >http://www.soundexproducts.com/information.html > > >Thanks >John >#40102 _________________________________________________________________ More photos, more messages, more storageget 2GB with Windows Live Hotmail. ________________________________________________________________________________
Date: May 28, 2007
John, I fully sound proofed my plane. I haven't flown yet so I can't attest to the final results, but I think it should be very quite. If you knock on the side of my plane it's just a thud not the tin can sound you normally hear without soundproofing. I bought two types of material. One for the fire wall and the other for the remainder of the plane. It seems to be very high quality easy to install material. They come in a 27x48 sheet and have a silver outer shell looking like tin foil. They have a sticky back that you just remove the film after you've cut it and stick it onto the plane surface. Very easy to install. I'm having a custom interior guy do my interior and he also uses this same material. I purchased the insulation from Buckley Industries in Wichita, KS. http://buckleyind.com/ If I've got the numbers correct the firewall insulation sheet was part # 139675 and it cost $82.81 for the 27x48 sheet. The side body insulation # is 139679 and cost $76.64 for the sheet. I think it's a very good product, although a little pricy.. Wayne Edgerton #40336 DAR coming today if the weather holds out ________________________________________________________________________________
Date: May 28, 2007
Good luck with the DAR, let us know how it turns out. Rene' Felker N423CF 40322 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Monday, May 28, 2007 6:19 AM Subject: Re: RV10-List: Sound proofing the 10 ? John, I fully sound proofed my plane. I haven't flown yet so I can't attest to the final results, but I think it should be very quite. If you knock on the side of my plane it's just a thud not the tin can sound you normally hear without soundproofing. I bought two types of material. One for the fire wall and the other for the remainder of the plane. It seems to be very high quality easy to install material. They come in a 27x48 sheet and have a silver outer shell looking like tin foil. They have a sticky back that you just remove the film after you've cut it and stick it onto the plane surface. Very easy to install. I'm having a custom interior guy do my interior and he also uses this same material. I purchased the insulation from Buckley Industries in Wichita, KS. http://buckleyind.com/ If I've got the numbers correct the firewall insulation sheet was part # 139675 and it cost $82.81 for the 27x48 sheet. The side body insulation # is 139679 and cost $76.64 for the sheet. I think it's a very good product, although a little pricy.. Wayne Edgerton #40336 DAR coming today if the weather holds out ________________________________________________________________________________
Subject: Re: PRK surgery
Date: May 28, 2007
Hello Dave, I had LASIK surgery about three years ago and it has worked out great. I now have 20/15 vision. Because of my maturing age :>} they told me that if I had the surgery I would have to wear glasses to read, which didn't sound like a very good deal to me. I told the surgeon that and he said there is a procedure that could possible make it that I wouldn't need to wear glasses. It's called Mono Vision and he said that many people aren't able to adapt to it, but if I wasn't able to adapt they could complete the process and then I would wear reading glasses. The surgeon had Mono Vision for himself and I had that done and it worked out ok for me. My former partner had it and he wasn't able to adapt to it. The mono vision is where the dominant eye is corrected for your long vision and the other eye is made for short vision. If someone is younger, I don't know for sure, but mid forty's or under, then they probably wouldn't have to worry about the Mono Vision option in that the eye is still somewhat flexible. But anyway I've never been unhappy that I had it done. When I took my flight physical he said I had to wear glasses to fly because my non dominant eye can't see long distances. But if I understand it correctly I can apply to the FAA and then go up with an examiner to show I have depth perception with the surgery and they will wave the restriction, which I plan on doing. Wayne Edgerton #40336 From: "Dave Leikam" <DAVELEIKAM(at)wi.rr.com> Subject: PRK surgery Have any of the pilots on this list had PRK surgery or LASIK and how do you like the results for flying? I know this is way off the building subject but I would like to put this question out to a large number of pilots. If you feel it is not appropriate for this list, just let it die. Thanks. Dave Leikam 40496 ________________________________________________________________________________
Date: May 28, 2007
Just keep in mind that the FAA is very skeptical about monovision because it was a contributing factor in an airline crash at La Guardia awhile back. In that case I think it was the copilot flying using monovision contact lenses with no specific approval and he apparently didn't have sufficient depth perception and landed plane short of the runway. (a very bad thing at that airport/runway) > But anyway I've never been unhappy that I had it done. When I took my flight physical he said I had to wear glasses to fly because my non dominant eye can't see long distances. But if I understand it correctly I can apply to the FAA and then go up with an examiner to show I have depth perception with the surgery and they will wave the restriction, which I plan on doing. > > Wayne Edgerton #40336 > ________________________________________________________________________________
Date: May 28, 2007
It is a Locktite product perhaps I said 290 and meant 260. I am traveling and do not have the exact information with me but i know it is a Loctite product. On 5/27/07, orchidman wrote: > > > apilot2(at)gmail.com wrote: > > Your friendly NAPA or Autozone, etc. auto parts store, in their > > (aircraft) sealant's area. Right along with their Form a gasket, > > Permatex #2 & #3, epoxies, etc. > > I found it in the aircraft supply section of Autozone. Previously in this thread, it was referenced as 'Loctite 290' but all I found was 'Permatex' and their number was PX # 29000. It is labeled 'Threadlocker Green' and 'Penetrating Formula' so I am sure it is the correct item. > The good news is that today I tested both tanks and they got a green light, no bubbles detected. This last week I had been baloon testing and they were going down at a VERY slow rate which I attribute to the fact that you blow up a baloon, tie it off and it will still go down over the course of a couple days. So to go the extra mile, I soaped up the tanks and I am a happy camper [Laughing] > Gary > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=115110#115110 > > -- Rob Kermanj ________________________________________________________________________________
Date: May 28, 2007
Permatex markets Locktite these days, and 290 is the correct number. On 5/28/07, Rob Kermanj wrote: > > It is a Locktite product perhaps I said 290 and meant 260. I am > traveling and do not have the exact information with me but i know it > is a Loctite product. > > On 5/27/07, orchidman wrote: > > > > > > apilot2(at)gmail.com wrote: > > > Your friendly NAPA or Autozone, etc. auto parts store, in their > > > (aircraft) sealant's area. Right along with their Form a gasket, > > > Permatex #2 & #3, epoxies, etc. > > > > I found it in the aircraft supply section of Autozone. Previously in this thread, it was referenced as 'Loctite 290' but all I found was 'Permatex' and their number was PX # 29000. It is labeled 'Threadlocker Green' and 'Penetrating Formula' so I am sure it is the correct item. > > The good news is that today I tested both tanks and they got a green light, no bubbles detected. This last week I had been baloon testing and they were going down at a VERY slow rate which I attribute to the fact that you blow up a baloon, tie it off and it will still go down over the course of a couple days. So to go the extra mile, I soaped up the tanks and I am a happy camper [Laughing] > > Gary > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=115110#115110 > > > > > > > > > > > > > > > > > > > > > > > > > -- > Rob Kermanj > > ________________________________________________________________________________
Date: May 28, 2007
If you want the approved aircraft stuff the place to start is a company called E.A.R. Quite expensive though. http://www.earaircraft.com/ I went the hot rod route and used a product from another company called b-quiet in Canada. Much cheaper and the ansi tests seem to have it working better than any other. It is a sticky butle rubber with a layer of dead soft aluminum on the outside. See it at the following link. http://www.b-quiet.com/ I bought the bquiet ultimate in a 50 foot roll and used it up....will need another to do the whole inside cabin. Cheers.. Evan > >>From: John Hurst <johnh38(at)yahoo.com> >>Reply-To: rv10-list(at)matronics.com >>To: rv10-list(at)matronics.com >>Subject: RV10-List: Sound proofing the 10 ? >>Date: Sun, 27 May 2007 18:30:01 -0700 (PDT) >> >>I have been lurking on this group for months and appreciate Everyones >>ideas, suggestions, and opinions. Thanks to all. >> >>Now I need to ask for advise/recommendations. I have searched this site >> as >>well as vansairforce.net and havent found a lot of information posted >>pertaining to insulation &/or soundproofing the RV-10. Is anyone other >>than Deems & Curtis soundproofing their aircraft? Im working on the fuse >>and am trying to weigh the options, Pros vs. Cons. My thinking is that I >>will add something that is approved to deaden the noise. It's what is >>available that has me perplexed. Any recommendations would be >> appreciated. >>Sorry to delve off the panel discussion topic, but I need to think about >>installation before laying the floors/side panels of the fuse. >>Specifically, I'm looking for materials like whats available from >> aircraft >>spruce and SoundExproducts. >>http://www.aircraftspruce.com/catalog/appages/soundproofinstall.php. And >>this link I copied from Curtis >>http://www.soundexproducts.com/information.html >> >> >>Thanks >>John >>#40102 > > _________________________________________________________________ > More photos, more messages, more storageget 2GB with Windows Live > Hotmail. > > --------------------------------------------- This message was sent using SnowCrest WebMail. http://www.snowcrest.net ________________________________________________________________________________
Date: May 28, 2007
Dean, What thicknesses did you use? Jeff Wings Started ----- Original Message ----- From: Wayne Edgerton To: rv10-list(at)matronics.com Sent: Monday, May 28, 2007 7:19 AM Subject: Re: RV10-List: Sound proofing the 10 ? John, I fully sound proofed my plane. I haven't flown yet so I can't attest to the final results, but I think it should be very quite. If you knock on the side of my plane it's just a thud not the tin can sound you normally hear without soundproofing. I bought two types of material. One for the fire wall and the other for the remainder of the plane. It seems to be very high quality easy to install material. They come in a 27x48 sheet and have a silver outer shell looking like tin foil. They have a sticky back that you just remove the film after you've cut it and stick it onto the plane surface. Very easy to install. I'm having a custom interior guy do my interior and he also uses this same material. I purchased the insulation from Buckley Industries in Wichita, KS. http://buckleyind.com/ If I've got the numbers correct the firewall insulation sheet was part # 139675 and it cost $82.81 for the 27x48 sheet. The side body insulation # is 139679 and cost $76.64 for the sheet. I think it's a very good product, although a little pricy.. Wayne Edgerton #40336 DAR coming today if the weather holds out ________________________________________________________________________________
Date: May 28, 2007
I also wanted entertainment for nervous or bored passengers - and some buttons that they are allowed to push :)... i spec'd it out a couple different ways, so i could change my mind a few more times based on my mood that day... lightest weight/best bang for the buck: headrest style monitor with a video ipod providing all the entertainment. this provides more music and movies than you'll ever have time to play while flying, and ends up being really lightweight. car stereos that play dvds are pretty heavy for a couple reasons - the dvd motor and transport, and also the amplifiers in the unit. remember that car stereos are meant to supply approprate power to drive speakers directly, something that we in the airplane building business aren't interested in. with the ipod weighing 5.5 oz and a plane jane video monitor like this - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15 966 you come in pretty lightweight. the pop-up dash monitors like this one: http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store _Code=MV&Product_Code=ID7169 are nice because they get out of the way when you're not using them, but you get a bit of a weight penalty from the motor. there's also some more elegant solutions for this type of setup, but then you start a little more weight, and also cost. for those interested, check this out: http://www.alpine-usa.com/US-en/products/product_acc.php?model=KCE-415i this is an interface that works with ipod, charges the unit, and allows you to control the ipod from a touch screen monitor. the monitor that works with it is a bit spendy, but i bet it looks amazing. using the ipod for video is a pretty sweet solution, and there's some great software out there thats FREE to rip your DVD movies and stick em on the ipod. and when you get to where you're going you have your ipod with you. cool. i also looked around at dvd changers that have all the bells and whistles. i bought one that either will go in the airplane or my girlfriend's car. haven't quite decided yet. the cool thing about it is that it's got interfaces for both sirius and xm, a 6 disc dvd changer, ipod controller, external video inputs, and i think it'll toast a pop-tart. it is heavy though... then there's the 1/2 din stand-alone dvd/cd/mp3 player that is tiny and lightweight, and that coupled with any stand-alone screen would provide hours of entertainment, be very lightweight, and could be done pretty cheaply. something like this: http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store _Code=MV&Product_Code=DV-180 i'm pretty sure this one isn't IFR certified though...:) can anybody guess what i do for a living? cj #40410 fuse/finishing www.perfectlygoodairplane.net -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of Marcus Cooper Sent: Sun 5/27/2007 9:20 PM Subject: RE: RV10-List: DVD - Pop Up Display Robin, I had the same concern and went with the cheapest pop-up DVD player I could find on eBay. Shipped from China but works great overall. It was a little heavy, although I didn't actually weigh it. The performance of the -10 is so great that a few extra pounds is well worth keeping the family happy. My wife measures trips in how many DVDs to take and loves it. The only drawback with the el cheapo is it doesn't like heat too much. If I leave it powered off until at cruise there's no issues, but on a warm day down low it will start to skip and go stupid so I'm working on better cooling air for it. Marcus _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 27, 2007 8:05 PM Subject: RV10-List: DVD - Pop Up Display RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc.) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts ________________________________________________________________________________
Date: May 29, 2007
Chris, That is fantastic. Thank you, John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Tuesday, 29 May 2007 3:34 AM Subject: RE: RV10-List: DVD - Pop Up Display I also wanted entertainment for nervous or bored passengers - and some buttons that they are allowed to push :)... i spec'd it out a couple different ways, so i could change my mind a few more times based on my mood that day... lightest weight/best bang for the buck: headrest style monitor with a video ipod providing all the entertainment. this provides more music and movies than you'll ever have time to play while flying, and ends up being really lightweight. car stereos that play dvds are pretty heavy for a couple reasons - the dvd motor and transport, and also the amplifiers in the unit. remember that car stereos are meant to supply approprate power to drive speakers directly, something that we in the airplane building business aren't interested in. with the ipod weighing 5.5 oz and a plane jane video monitor like this - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15966 you come in pretty lightweight. the pop-up dash monitors like this one: http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store_Code =MV&Product_Code=ID7169 are nice because they get out of the way when you're not using them, but you get a bit of a weight penalty from the motor. there's also some more elegant solutions for this type of setup, but then you start a little more weight, and also cost. for those interested, check this out: http://www.alpine-usa.com/US-en/products/product_acc.php?model=KCE-415i this is an interface that works with ipod, charges the unit, and allows you to control the ipod from a touch screen monitor. the monitor that works with it is a bit spendy, but i bet it looks amazing. using the ipod for video is a pretty sweet solution, and there's some great software out there thats FREE to rip your DVD movies and stick em on the ipod. and when you get to where you're going you have your ipod with you. cool. i also looked around at dvd changers that have all the bells and whistles. i bought one that either will go in the airplane or my girlfriend's car. haven't quite decided yet. the cool thing about it is that it's got interfaces for both sirius and xm, a 6 disc dvd changer, ipod controller, external video inputs, and i think it'll toast a pop-tart. it is heavy though... then there's the 1/2 din stand-alone dvd/cd/mp3 player that is tiny and lightweight, and that coupled with any stand-alone screen would provide hours of entertainment, be very lightweight, and could be done pretty cheaply. something like this: http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store_Code =MV&Product_Code=DV-180 i'm pretty sure this one isn't IFR certified though...:) can anybody guess what i do for a living? cj #40410 fuse/finishing www.perfectlygoodairplane.net -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of Marcus Cooper Sent: Sun 5/27/2007 9:20 PM Subject: RE: RV10-List: DVD - Pop Up Display Robin, I had the same concern and went with the cheapest pop-up DVD player I could find on eBay. Shipped from China but works great overall. It was a little heavy, although I didn't actually weigh it. The performance of the -10 is so great that a few extra pounds is well worth keeping the family happy. My wife measures trips in how many DVDs to take and loves it. The only drawback with the el cheapo is it doesn't like heat too much. If I leave it powered off until at cruise there's no issues, but on a warm day down low it will start to skip and go stupid so I'm working on better cooling air for it. Marcus _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 27, 2007 8:05 PM Subject: RV10-List: DVD - Pop Up Display RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc.) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts ________________________________________________________________________________
Date: May 28, 2007
Another good source for video components is: http://www.partsexpress.com/webpage.cfm?WebPage_ID=41 Now we just have to wait for somebody to put something like this in the back seats for the "real" theater sensation: http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=299-028 :^) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV_10 Sent: Monday, May 28, 2007 3:29 PM Subject: RE: RV10-List: DVD - Pop Up Display Chris, That is fantastic. Thank you, John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Tuesday, 29 May 2007 3:34 AM Subject: RE: RV10-List: DVD - Pop Up Display I also wanted entertainment for nervous or bored passengers - and some buttons that they are allowed to push :)... i spec'd it out a couple different ways, so i could change my mind a few more times based on my mood that day... lightest weight/best bang for the buck: headrest style monitor with a video ipod providing all the entertainment. this provides more music and movies than you'll ever have time to play while flying, and ends up being really lightweight. car stereos that play dvds are pretty heavy for a couple reasons - the dvd motor and transport, and also the amplifiers in the unit. remember that car stereos are meant to supply approprate power to drive speakers directly, something that we in the airplane building business aren't interested in. with the ipod weighing 5.5 oz and a plane jane video monitor like this - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15966 you come in pretty lightweight. the pop-up dash monitors like this one: http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store_Code =MV&Product_Code=ID7169 are nice because they get out of the way when you're not using them, but you get a bit of a weight penalty from the motor. there's also some more elegant solutions for this type of setup, but then you start a little more weight, and also cost. for those interested, check this out: http://www.alpine-usa.com/US-en/products/product_acc.php?model=KCE-415i this is an interface that works with ipod, charges the unit, and allows you to control the ipod from a touch screen monitor. the monitor that works with it is a bit spendy, but i bet it looks amazing. using the ipod for video is a pretty sweet solution, and there's some great software out there thats FREE to rip your DVD movies and stick em on the ipod. and when you get to where you're going you have your ipod with you. cool. i also looked around at dvd changers that have all the bells and whistles. i bought one that either will go in the airplane or my girlfriend's car. haven't quite decided yet. the cool thing about it is that it's got interfaces for both sirius and xm, a 6 disc dvd changer, ipod controller, external video inputs, and i think it'll toast a pop-tart. it is heavy though... then there's the 1/2 din stand-alone dvd/cd/mp3 player that is tiny and lightweight, and that coupled with any stand-alone screen would provide hours of entertainment, be very lightweight, and could be done pretty cheaply. something like this: http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store_Code =MV&Product_Code=DV-180 i'm pretty sure this one isn't IFR certified though...:) can anybody guess what i do for a living? cj #40410 fuse/finishing www.perfectlygoodairplane.net -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of Marcus Cooper Sent: Sun 5/27/2007 9:20 PM Subject: RE: RV10-List: DVD - Pop Up Display Robin, I had the same concern and went with the cheapest pop-up DVD player I could find on eBay. Shipped from China but works great overall. It was a little heavy, although I didn't actually weigh it. The performance of the -10 is so great that a few extra pounds is well worth keeping the family happy. My wife measures trips in how many DVDs to take and loves it. The only drawback with the el cheapo is it doesn't like heat too much. If I leave it powered off until at cruise there's no issues, but on a warm day down low it will start to skip and go stupid so I'm working on better cooling air for it. Marcus _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 27, 2007 8:05 PM Subject: RV10-List: DVD - Pop Up Display RV-10 list, Let me preface this post with the fact that I have a nervous flying wife & daughter that need a distraction while traveling in general aviation. I was planning on including a 7" DVD pop-up display (with XM, iPod, CD etc.) on my -10 panel plus two LCD displays in the headrests. The DVD I ordered a nice 1 din unit at a good price on ebay ($329.00 pop up unit only, no rear LCD's) When it arrived it was MUCH heavier than I anticipated. I assumed that they would all be about the same weight (3-5 lbs.) so I didn't do a lot of research. My stout little unit weighs in at 9.50 lbs before I add the rear displays. I see a few units that are 5-6 lbs but they are 2.5 times more expensive. I was hoping to avoid lap dvd players or laptops so the pax can all have the same dvd experience and at the same time avoid all the extra loose hardware and chargers flying around the cabin in the case of a unscheduled landing. I would appreciate any suggestions as long as they don't include finding a way to get the family into flying. I am sure when we start doing real x-country trips on a more regular basis they will naturally (and slowly) become more comfortable with GA travel. Thanks in advance, Robin RV-4 Sold RV-6A Fly RV-10 parts, parts, parts ________________________________________________________________________________
Subject: DAR Inspection
Date: May 28, 2007
Well I had my DAR inspection today and luckily for me it went through without a hitch. He found a few little items but nothing of any consequence. It feels great to be past that junture and I'm ready to move onto the fly off stage. I had a couple of other 10 builders and a 7 builder stop by the hangar during the inspection to take notes for when they are ready :>} Thanks to all of you who made those great posts or answered some of my questions along the way. Without all you little people I wouldn't be here today :>} Oops, sorry I got carried away with my acceptance speech :>} I've attached a few pictures from today. The DAR is Mel Asberry from Farmersville, TX, he's the one with a beard, and he's a really thorough but nice guy. He made it an enjoyable inspection day. Wayne Edgerton #40336 ready to leave terra firma soon ________________________________________________________________________________
Date: May 28, 2007
Subject: Re: empty weight
Empty Weight - 1680 lbs. (I still need to add my headliner and dash cover.) Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: John W. Cox <johnwcox(at)pacificnw.com> Sent: Sunday, May 27, 2007 3:33:46 PM Subject: RE: RV10-List: empty weight This is a request for others of the 80 RV-10s to post their empty weight for those of us still building. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, April 21, 2006 5:49 PM Subject: Re: RV10-List: empty weight Tim 1,685 Randy 1,625 Vic 1,665 Chuck 1,615 Rob 1,558 Chuck and Vic weight from <http://www.rvproject.com/wab/> Rob, looks like you have the light weight machine. Which prop? With or without wheel pants? Larry Rosen http://lrosen.nerv10.com ________________________________________________________________________________
Date: May 28, 2007
Congrats! When do you expect to have your first flight? Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com www.saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Monday, May 28, 2007 7:46 PM Subject: RV10-List: DAR Inspection Well I had my DAR inspection today and luckily for me it went through without a hitch. He found a few little items but nothing of any consequence. It feels great to be past that junture and I'm ready to move onto the fly off stage. I had a couple of other 10 builders and a 7 builder stop by the hangar during the inspection to take notes for when they are ready :>} Thanks to all of you who made those great posts or answered some of my questions along the way. Without all you little people I wouldn't be here today :>} Oops, sorry I got carried away with my acceptance speech :>} I've attached a few pictures from today. The DAR is Mel Asberry from Farmersville, TX, he's the one with a beard, and he's a really thorough but nice guy. He made it an enjoyable inspection day. Wayne Edgerton #40336 ready to leave terra firma soon ________________________________________________________________________________
Subject: Bench seat in rear possible?
Date: May 28, 2007
Hey folks, Thinking of being a repeat offender. I've built and fly a -7A. Have about 500 hours on it in since 4-04. Now I'm wanting extra seating so thinking seriously about the -10. My question is the possibility of having a baby carrier strapped down in the back, along with a couple moms. My youngest daughter is getting married Saturday and my son was married a year ago. Fast forward 2-5 years and we all know what usually happens next in life. I know that 90%+ of the time, seating for 4 adults will be more than enough but I want the ability to have that 5th seat for that once or twice a year opportunity. So, anyone been there done that... seat belts for 5??? -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=115296#115296 ________________________________________________________________________________
From: "Mark Sutherland" <mark_sutherland(at)yahoo.com>
Subject: 611TT First Flight
Date: May 28, 2007
I decided to take up my RV-10 today for her first flight (about 20 minutes) and as you can see I safely returned to earth. Builder number 40292, I have been working on her 2.5 years and received DAR approval this week. Airplane few great and was very quiet, cool and fast. It took me three tries to land. I could not get her to slow down. I am use to my bonanza, when you drop the gear and flaps she is coming down fast. When I pulled power and dropped the flaps, the RV-10 wanted to keep flying. I have a few minor electrical issues to resolve but everything else worked great. Some pictures are attached. Mark Sutherland 325-646-4156 mark(at)tintopranch.com www.tintopranch.com ________________________________________________________________________________
Date: May 29, 2007
Subject: Re: My transition training experience
Gary, The tops are more uniform around the windows and door opening then earlier models. Several areas needed to be built up to match the depth around the doors and windows on early tops. Some tops even had VOIDS in them that need to be refilled. It appeared if the mold had a bad spot they just poured straight epoxy into the hole to fix it. I did not see any of that on the ones in the factory now. Dean 40449 ________________________________________________________________________________
Date: May 29, 2007
Subject: Re: Gas leak
How long do you have to leave the loctite sit before it is cured? Dean ________________________________________________________________________________
Date: May 28, 2007
Subject: Re: DAR Inspection
Well Done Wayne!!!!! Please keep us updated on the stage 1. I don't recall too may posts about things that happen during fly-off. I'm sure they happen based on what I hear from guys in EAA chpt mtgs., I think we could all learn from hearing about them. Deems Davis # 406 Baffling / Plenum / Engine stuff http://deemsrv10.com/ ________________________________________________________________________________
Date: May 28, 2007
Subject: Re: 611TT First Flight
Wow, you guys are starting to pop up with regularity now!!!! Congratulations !!! Please keep us updated on you fly-off. Deems Davis # 406 Baffling / Plenum / Engine Stuff http://deemsrv10.com/ ________________________________________________________________________________
Date: May 28, 2007
Nice job! And nice landing strip. Kevin 40494 ________________________________________________________________________________
Subject: Avidyne EFIS
Date: May 29, 2007
Someone asked about Avidyne Entegra EFIS for experimentals. They announced that at Sun N Fun. I don't know what their availability or pricing would be. Interestingly enough, on one hand, you'd get a few less features than with some "experimental" EFIS systems (no HITs & no synthetic vision yet), but you do get an "IFR EFIS" to use a popular term. I would classify it that way, since it is TSO certified for all of the appropriate flight instruments. Has been through a sh**-load of environmental testing, too. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-401-2522 ________________________________________________________________________________
Subject: On board radar
Date: May 29, 2007
Russ: I concur that you need to keep a clear separation between satellite weather and "on-board radar". As others have pointed out, there is a several-minute delay for NEXRAD data to be collected, assembled, sent over the satellite, and received. This is a lot different from on-board radar that gives an instant view of the weather ahead. While working on XM weather when I was at Avidyne, that was a big concern for us and the FAA - namely, that someone is going to try and use XM (or WSI) NEXRAD information to "thread the needle" between weather cells and they get whacked because their information is a few minutes old. Certainly use XM to avoid weather, but still give it a wide berth. Don't think you can snake your way through the middle and save 10 minutes . . . TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-401-2522 ________________________________________________________________________________
Date: May 29, 2007
Mark nice to see someone flying off of grass. I have a farm with 2500' grass strip of which 600' is sloped....Want to build an RV-10 Truck, no back seats (4 seat insurance$$$) Perhaps a sleeping area in back. Simple VFR with a good panel mount GPS. 6:00x6:00 W&B's modified baggage door. Tim C ________________________________________________________________________________
Date: May 29, 2007
Wayne maybe take a closer look at your certificate after seeing jpeg below ;-) Tim C Cld Lk. ________________________________________________________________________________
Subject: Re: DAR InspectionDAR Inspection
Date: May 29, 2007
Thanks Jessie, I'm not sure yet but probably in a week or so. Wayne Edgerton #40336 Congrats! When do you expect to have your first flight? Jesse Saint Saint Aviation, Inc. ________________________________________________________________________________
Subject: Re: Bench seat in rear possible?
Date: May 29, 2007
Hi Doug, Classic Aero did my seats and they made the back seat into a bench seat configured 60/40. I guess you would have to figure out how to have seat belt attachments for the baby seat but maybe Classic Aero could adapt the seat to allow another belt to be attached? By the way they do outstanding work and deliver on time, which seems to be rare in our RV world. Go to their web site and you can see the bench seat. www.classicaerodesigns.com Wayne Edgerton #40336 ________________________________________________________________________________
Subject: Amatuer Built Rules - was ...The Perfect Panel...how to
decide - was GNS-430W
Date: May 29, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
When I built my Pietenpol, I had a guy from the Greesnboro FSDO do the inspection, not a DAR. I asked him just such a question. He said an engine change, or a propeller change does NOT require re-inspection, but it does require going back into "the box" for an addititional 25 to 40 hours (depending on whether a certified engine/prop combination was being used) of flight testing before you can carry passengers or leave the test area. I would assume if that is so for something as major as an engine, that avionics changes would not require re-inspection either. Jack Phillips PP ASEL with Instrument Rating Repairman's Certificate for Pietenpol NX899JP RV-10 #40610 (tailcone) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Friday, May 25, 2007 5:24 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W Great statement Bobby. Now here is a new question that goes to the heart of Amateur Built (current rules). Does a total change-out of engine type, prop type or major alteration to an airframe (Down the Road) require a revisit by a DAR or PAI? Or does the repairman have the latitude to alter the engine/prop/panel from basic VFR to EFIS/IFR without a trail of paperwork and new set of eyes? What latitude for modification is legal and appropriate for a kit designed and tested VAN's RV-10? "Round Two" - No bio required "Do you feel Lucky?" John Cox A&P with IA 40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Friday, May 25, 2007 2:26 PM Subject: RE: RV10-List: The Perfect Panel...how to decide - was GNS-430W The great thing is we get to rebuild our panels as often as we like. Going home to work on my instrument rating using ASA IP PC based software :) Bobby 40116 _________________________________________________ ________________________________________________________________________________
Subject: overhead console.
Date: May 29, 2007
A few weeks ago I received some photos from builders that depicted the style of many different overhead consoles. Mine will be done once I mount the switches and LED and the velcro and Zolatone it, but here are a few photos that show how versatile working in composites can be. The last photo is the underside after the foam has been carved out. Total weight is about nearly 4 pounds. 2 laminations of six once glass on the outside and one layer of three once on the inside. Actually working in fiberglass can be very creative and fun so don't let your introduction to them by working on Van's parts turn you off...it is not an accurate reflection of what it is like. John G. 409 ________________________________________________________________________________
Subject: FS: MT Prop Gov
Date: May 29, 2007
I spoke with Douglas Turner at MT Prop - USA this morning. He verified that Van's only sells the MT prop governor for the narrow deck 540. That seems odd since Lycoming hasn't produced a new narrow deck engine since the late 70s, but it is what it is. You may have a narrow deck engine if you purchased an overhauled engine from a shop, but if you purchased a new factory engine (from Van's) or a new experimental engine from someone like BPE, Aerosport or Mattituck, then you definitely have a wide deck engine. The 860-3 can be converted to the correct drive gear ratio for the wide deck engine. You can contact MT Prop USA at (386) 736-7762 for assistance. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lessdragprod(at)aol.com Sent: Sunday, May 27, 2007 1:07 AM Subject: Re: RV10-List: FS: MT Prop Gov Hi William, I don't know if N401RV has a narrow deck engine, or a wide deck engine. I have only seen Van's Aircraft selling the MT governor for the narrow deck Lyc. 540 engine. I have not seen them list the correct MT governor for a wide deck engine. I haven't done this, but I have heard that the MT governors for the narrow deck Lyc. 540 engine will work on the wide deck engine. If the high RPM adjustment screw is moved to its limit. Or, sometimes, the metal stop needs to be filed to get additional travel on the governor control arm. BTW, the safety wire can be cut and the six safety wired screws can be loosened in order to rotate the governor arm and stop assembly. When the governor arm is in the position you want, the six screws can be tightened and safety wired. Do not remove the governor arm from the splined shaft. This is a bad thing. Regards, Jim Ayers : rv10-list(at)matronics.com Sent: Sat, 26 May 2007 7:18 pm Subject: Re: RV10-List: FS: MT Prop Gov Jim, I hope this is not correct since my TMX IO-540 engine has the same standard hex nuts as the engine in 410RV which would make it a WIDE deck engine. N410RV http://www.myrv10.com/miscphotos/TerryCole/abilene/Abilene_04_RV10_072.j pg My TMX IO-540 http://wcurtis.nerv10.com/20Engine/Engine02.jpg The governor I just received in the Van's firewall forward kit is MT P-860-3. According to the you, I should need the P-860-5. Does Van's use a -3 or a -5 in N401RV? I'll have to check with Mattituck on this. William http://wcurtis.nerv10.com/ -------- Original Message -------- > X-Rcpt-To: > > Just for the sake of clarification, the Lyc. IO-540-C4B5 engine has two > different governor gear ratios. > > The NARROW deck has a 0.895:1 gear ratio and uses the MT governor P-860-3 or > P-420-17. > > The WIDE deck has a 0.947:1 gear ratio and uses the MT governor P-860-5 or > P-420-5. > > The cylinders on the NARROW deck engine are mounted with round nuts having > an internal Allen wrench drive. > The cylinders on the WIDE deck engine are mounted with standard hex nuts. > > I have not seen the WIDE deck MT governors being offered for sale by Van's > Aircraft. I have only seen them offer the MT governors designed for the > NARROW deck Lyc. 540 engine. > > Regards, > Jim Ayers > > In a message dated 05/25/2007 9:26:16 A.M. Pacific Daylight Time, > wcurtis(at)nerv10.com writes: > > --> RV10-List message posted by: "William Curtis" > > Some folks are opting for the PCU5000/X (http://pcu5000.com <http://pcu5000.com/> ). It supposedly > governs better than the MT provided in the FF kit. Someone on Vansairforce > is doing a group buy of the PCU5000. Since the PCU5000X ($1350) is more > expensive than the MT ($Van's $1100), this may be another case of a solution > looking for a problem. Has anyone flying had issues with the MT P-860-3? > > http://www.vansairforce.com/community/showthread.php?t=17279&page=1&p p=1 0&high > light=pcu > > William > http://wcurtis.nerv10.com/ > > > > > > > ************************************** See what's free at http://www.aol.com . >RV10-List Email Forum - AN>, and much much more: et=_blank>http://www.matronics.com/Navigator?RV10-List ://forums.matronics.com ________________________________ size=2 width="100%" align=center> AOL at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000437> . ________________________________________________________________________________
Date: May 29, 2007
Subject: Re: The Perfect Panel...how to decide - was GNS-430W
Date: May 29, 2007
Hi there. I'm an RV7A builder new to this forum but turned on to it by the recent RV Hotline link. I have a dual GRT system (Horizontally laid out) and I want Wx but have been going back and forth as to whether its better to have it integrated into the GRT for $1500 and installation now while everything is easily accessible, or to wait and get some kind of portable (Garmin x96 or tabet) and have an easy upgrade path with that. Thanks in advance for all opinions. Jeremy Constant Read this topic online here: http://forums.matronics.com/viewtopic.php?p=115410#115410 ________________________________________________________________________________
Date: May 29, 2007
Subject: RV10 helpful tips
I wanted to post a few suggestions to those building the RV10 that may s ave you lots of time and headaches. I will let Tim decide if they are w orthy of the website TIPS page. Wing tanks LEAKING? Having first hand knowledge of this with my QB fue l tanks let me suggest the following: 1. Don't trust they will not leak because the Factory built them. 2. Don't trust an AIR leak test. 3. Put 100LL in the tanks prior to PAINTING wings to verify they do not leak. If available mount the wing on a wing rack from a paint shop. Fi ll with 5-10 gals. rotate wing 90 degrees and test for leaks. Rotate an other 90 degrees and test again. Continue until all sides have been lea k tested. Now you will not ruin you paint job if one is leaking. Much easier to fix a leak PRIOR to mounting or painting. Elevator Trim tab cables installed: When drilling the holes in the HORIZONTAL and ELEVATORS that the cables pass thru you may want to OVERSIZE them and install bigger snap bushing. WHY? The cables are too tight when fishing them thru these tail pieces and there is no need for them to be that snug. This mod would avoid lo ts of frustration and bending of the leading edges of the elevators when installing and would allow easier movement of the cables which can pote ntially put undue stress on the welded nuts that rivet to the elevator a ccess panels. Adjusting the elevator TRIM tabs is not as easy as the manual states. T he manual says you need 35 degrees down from neutral on both tabs. If y ou do this you will have no UP travel on the left tab and very little on the right tab. You will need to compromise on your down degrees and tr y to get the tabs NEUTRAL at cruise to avoid excess drag. Discussing thi s issue with TIM and others it appears most flying RV10's are set at 25 degrees down on the left and 32-34 degrees down on the right to get a NU ETRAL at cruise. Also it will vary depending WHERE on the trim tab you measure the angle. The angle on the inner part of the tab will read less than the outer part of the tab on both sides. Measure the same area of the tab consistently. Hope these tips help and save you time and frustration. DEAN 40449
I wanted to post a few suggestions to those building the RV10 t hat may save you lots of time and headaches.  I will let Tim decide if they are worthy of the website TIPS page.
Wing tanks LEAKING?   Having first hand knowledge of this w ith my QB fuel tanks let me suggest the following:
3. Put 100LL in the tanks prior to PAINTING wings to verify they do n ot leak.  If available mount the wing on a wing rack from a paint s hop.  Fill with 5-10 gals. rotate wing 90 degrees and test for leak s.  Rotate another 90 degrees and test again.  Continue until all sides have been leak tested.   Now you will not ruin you p aint job if one is leaking.
When drilling the holes in the HORIZONTAL and ELEVATORS that the cabl es pass thru you may want to OVERSIZE them and install bigger snap bushi ng. WHY?  The cables are too tight when fishing them thru these tai l pieces and there is no need for them to be that snug.  This mod w ould avoid lots of frustration and bending of the leading edges of the e levators when installing and would allow easier movement of the cables w hich can potentially put undue stress on the welded nuts that rivet to the elevator access panels.
Adjusting the elevator TRIM tabs is not as easy as the manual states.   The manual says you need 35 degrees down from neutral on both tab s.  If you do this you will have no UP travel on the left tab and very little on the right tab.  You will need to compromise on your down degrees and try to get the tabs NEUTRAL at cruise to avoid excess drag. Discussing this issue with TIM and others it appears most flying RV10's are set at 25 degrees down on the left and 32-34 degrees d own on the right to get a NUETRAL at cruise.  Also it will vary dep ending WHERE on the trim tab you measure the angle. The angle on th e inner part of the tab will read less than the outer part of the tab on both sides. Measure the same area of the tab consistently.
DEAN 40449
Subject: RV-10 Truck -was 611TT First Flight
Date: May 29, 2007
Tim, Have you talked to insurance companies about insuring an RV10 as a 2 seater (I assume you intend to leave out the rear seats)? I've talked to insurance companies about this and they would not insure it as a 2 seater only. Since it was designed as a 4 seater, that's the only way they would insure it. Kevin Belue RV-6A +700hrs. RV-10 cowling, finsh work ----- Original Message ----- From: "Tim C" <tlc2(at)telus.net> Sent: Tuesday, May 29, 2007 2:33 AM Subject: Re: RV10-List: 611TT First Flight > > Mark nice to see someone flying off of grass. I have a farm with 2500' > grass > strip of which 600' is sloped....Want to build an RV-10 Truck, no back > seats > (4 seat insurance$$$) Perhaps a sleeping area in back. Simple VFR with a > good panel mount GPS. 6:00x6:00 W&B's modified baggage door. > > Tim C > > > ________________________________________________________________________________
Date: - - - , 20-
Congratulations Mark! ________________________________________________________________________________
Date: May 29, 2007
Subject: Blast Tubes for Mags?
Has anyone routed a blast tube to cool their mags? Apparently some aircraft are know for having problems with heat and mags. Living in AZ, any time I hear of a heat issue I pay attention. I'm at the point where, if I'm going to do it it Now would be the time. So If anyone has done this I'd be appreciative of any pictures you might have or would be willing to share as well as any information regarding how you installed them. e.g. where exactly do you direct the air to on the mag? Which part is it that get the hottest? Thanks Deems Davis # 406 Baffling / Plenum / Engine Stuff http://deemsrv10.com/ ________________________________________________________________________________
Date: May 29, 2007
There are even less volatile solutions which can be inserted than AVGAS, yet I agree wholeheartedly not to trust a tank because someone else built it or because it was air-checked. At least recheck the work of others before applying paint and attempting your first flight. John 40600 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Sent: Tuesday, May 29, 2007 12:44 PM Subject: RV10-List: RV10 helpful tips I wanted to post a few suggestions to those building the RV10 that may save you lots of time and headaches. I will let Tim decide if they are worthy of the website TIPS page. Wing tanks LEAKING? Having first hand knowledge of this with my QB fuel tanks let me suggest the following: 1. Don't trust they will not leak because the Factory built them. 2. Don't trust an AIR leak test. 3. Put 100LL in the tanks prior to PAINTING wings to verify they do not leak. If available mount the wing on a wing rack from a paint shop. Fill with 5-10 gals. rotate wing 90 degrees and test for leaks. Rotate another 90 degrees and test again. Continue until all sides have been leak tested. Now you will not ruin you paint job if one is leaking. Much easier to fix a leak PRIOR to mounting or painting. Elevator Trim tab cables installed: When drilling the holes in the HORIZONTAL and ELEVATORS that the cables pass thru you may want to OVERSIZE them and install bigger snap bushing. WHY? The cables are too tight when fishing them thru these tail pieces and there is no need for them to be that snug. This mod would avoid lots of frustration and bending of the leading edges of the elevators when installing and would allow easier movement of the cables which can potentially put undue stress on the welded nuts that rivet to the elevator access panels. Adjusting the elevator TRIM tabs is not as easy as the manual states. The manual says you need 35 degrees down from neutral on both tabs. If you do this you will have no UP travel on the left tab and very little on the right tab. You will need to compromise on your down degrees and try to get the tabs NEUTRAL at cruise to avoid excess drag. Discussing this issue with TIM and others it appears most flying RV10's are set at 25 degrees down on the left and 32-34 degrees down on the right to get a NUETRAL at cruise. Also it will vary depending WHERE on the trim tab you measure the angle. The angle on the inner part of the tab will read less than the outer part of the tab on both sides. Measure the same area of the tab consistently. Hope these tips help and save you time and frustration. DEAN 40449 ________________________________________________________________________________
Date: May 29, 2007
One of the bench checks in rebuilding a Mag is to heat the capacitor to see if its ability degrades with modest heat increase. Unfortunately, you must cool the case and cap to achieve the desired cool operating temperature. Blast tubes do localize the cooling at the point of discharge. John #600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Tuesday, May 29, 2007 5:43 PM Subject: RV10-List: Blast Tubes for Mags? Has anyone routed a blast tube to cool their mags? Apparently some aircraft are know for having problems with heat and mags. Living in AZ, any time I hear of a heat issue I pay attention. I'm at the point where, if I'm going to do it it Now would be the time. So If anyone has done this I'd be appreciative of any pictures you might have or would be willing to share as well as any information regarding how you installed them. e.g. where exactly do you direct the air to on the mag? Which part is it that get the hottest? Thanks Deems Davis # 406 Baffling / Plenum / Engine Stuff http://deemsrv10.com/ ________________________________________________________________________________
Date: May 30, 2007
I've always liked the 60-40 bench seat idea and decided to incorperate a similar seat into the upholstery options I'm developing for the 10. here's a pic of the foam mockup. I am putting a set of belts in the center for a small child. Actually its quite comfortable for three kids across the back. I'm not sure how I'll handle the shoulder strap..But I don't think theres enough room for a carseat. Like tom says, it is a bit tight back there. Now, I'll have to deal with two full size adults fighting over the armrest.... Steve dinieri 40205 Iflyrv10.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of n277dl Sent: Monday, May 28, 2007 10:32 PM Subject: RV10-List: Bench seat in rear possible? Hey folks, Thinking of being a repeat offender. I've built and fly a -7A. Have about 500 hours on it in since 4-04. Now I'm wanting extra seating so thinking seriously about the -10. My question is the possibility of having a baby carrier strapped down in the back, along with a couple moms. My youngest daughter is getting married Saturday and my son was married a year ago. Fast forward 2-5 years and we all know what usually happens next in life. I know that 90%+ of the time, seating for 4 adults will be more than enough but I want the ability to have that 5th seat for that once or twice a year opportunity. So, anyone been there done that... seat belts for 5??? -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=115296#115296 ________________________________________________________________________________
Date: May 30, 2007
Doh! Sorry, tim......not tom... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, May 30, 2007 1:36 AM Subject: RE: RV10-List: Bench seat in rear possible? I've always liked the 60-40 bench seat idea and decided to incorperate a similar seat into the upholstery options I'm developing for the 10. here's a pic of the foam mockup. I am putting a set of belts in the center for a small child. Actually its quite comfortable for three kids across the back. I'm not sure how I'll handle the shoulder strap..But I don't think theres enough room for a carseat. Like tom says, it is a bit tight back there. Now, I'll have to deal with two full size adults fighting over the armrest.... Steve dinieri 40205 Iflyrv10.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of n277dl Sent: Monday, May 28, 2007 10:32 PM Subject: RV10-List: Bench seat in rear possible? Hey folks, Thinking of being a repeat offender. I've built and fly a -7A. Have about 500 hours on it in since 4-04. Now I'm wanting extra seating so thinking seriously about the -10. My question is the possibility of having a baby carrier strapped down in the back, along with a couple moms. My youngest daughter is getting married Saturday and my son was married a year ago. Fast forward 2-5 years and we all know what usually happens next in life. I know that 90%+ of the time, seating for 4 adults will be more than enough but I want the ability to have that 5th seat for that once or twice a year opportunity. So, anyone been there done that... seat belts for 5??? -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=115296#115296 ________________________________________________________________________________
Date: May 30, 2007
Heres a pic with the armrest down steve ________________________________________________________________________________
Date: May 30, 2007
This may spawn an idea> A Service manual 'scan' of the rear bench seat, I had in my Cessna 150 Bench came with the plane and it was handy keeping heavy stuff from sliding rearward....Sold it to a TWA pilot (Miller) in N.C. yrs back. Him & spouse could now take their young daughter 'Molly' over to an island off the N.C. coast, which had a restaurant /pub/swimming......Jpeg> Tim C ________________________________________________________________________________
Subject: Re: RV-10 Truck -was 611TT First Flight
Date: May 30, 2007
Kevin, only to friends with HB's It will be insured for the 'mandatory' PLPD only. Being in the Experimental Category 'hopefully' more on how it is built, than originally designed.... I will have the data on all of this for a comparison, from the Northern AOPA (COPA) Insurer tomorrow. Tim C ________________________________________________________________________________
Date: May 30, 2007
Subject: Re: Blast Tubes for Mags?
I used the Van's cooling kits supplied with the Firewall Forward kit. Really it's just a piece of corrugated tubing held into a hole in the baffles with hi temp silicone. The left one is directed at the left mag. I don't have a right mag so I pointed the right blast tube at the heater valves / firewall just forward of the tunnel; that's one of a few different tunnel heat fixes I did (not sure if it did any good, but the tunnel stays cool). I had an A&P look at my engine a couple months ago. He didn't like the fact that I had the blast tubes secured to my engine mount with zip ties. He said that the tolerance for wear on the engine mount frame was very small and that zip ties will eventually chafe enough to cause wear. So as you can see from the photos the blast tubes are held by a healthy glob of red silicone. -Jim 40134 In a message dated 5/29/2007 8:48:31 P.M. Eastern Daylight Time, deemsdavis(at)cox.net writes: --> RV10-List message posted by: Deems Davis Has anyone routed a blast tube to cool their mags? Apparently some aircraft are know for having problems with heat and mags. Living in AZ, any time I hear of a heat issue I pay attention. I'm at the point where, if I'm going to do it it Now would be the time. So If anyone has done this I'd be appreciative of any pictures you might have or would be willing to share as well as any information regarding how you installed them. e.g. where exactly do you direct the air to on the mag? Which part is it that get the hottest? Thanks Deems Davis # 406 Baffling / Plenum / Engine Stuff http://deemsrv10.com/ Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew) ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: Amatuer Built Rules - was ...The Perfect Panel...how to
decide - was GNS-430WThe Perfect Panel...how to decide - was GNS-430WThe Perfect Panel...how to decide - was GNS-430W
Date: May 30, 2007
Attached is a page from the Experimental Operating Limitations that I received from the DAR. Item 16 on the attachment explains this issue. The DAR told me that any major modification, such as a different engine or prop, would then cause rule 16 to kick in. He said the fly off time might not be as long depending on the modification. I think he said like a prop might be 5 hours. Wayne Edgerton #40336 Subject: Amatuer Built Rules - was ...The Perfect Panel...how to From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com> When I built my Pietenpol, I had a guy from the Greesnboro FSDO do the inspection, not a DAR. I asked him just such a question. He said an engine change, or a propeller change does NOT require re-inspection, but it does require going back into "the box" for an addititional 25 to 40 hours (depending on whether a certified engine/prop combination was being used) of flight testing before you can carry passengers or leave the test area. I would assume if that is so for something as major as an engine, that avionics changes would not require re-inspection either. ________________________________________________________________________________
Date: May 30, 2007
decide - was GNS-430WThe Perfect Panel...how to decide - was GNS-430WThe Perfect Panel...how to decide - was GNS-430W The key in this is the reference to FAR Part 21.93. 21.93 defines "Major" and Minor" alterations to the type design of aircraft. A "Minor" change is defined as: "one that has no appreciable effect on the weight, balance, structural strength, reliability, operational characteristics, or other characteristics affecting the airworthiness of the product." All other changes are classified as "Major" Also, 21.93 lists acoustic changes as being either "Major" or "Minor". Adding more avionics that significantly adds empty wieght would most likely qualify as "Major" alteration that'll require a new fly-off period. How much time for a fly-off would probably be up to the individual Fed, if the weight increase is a relativly low amount, then short fly-off period may be warranted. Installing a new engine basically the same weight and HP as the original would be a "Minor" change, but a heavier/ more HP engine would qualify as "Major". Something like going from a Lyc to an auto conversion would also qualify as "Major". Hope it helps... Keivn Hovis. On 5/30/07, Wayne Edgerton wrote: > Attached is a page from the Experimental Operating Limitations that I > received from the DAR. Item 16 on the attachment explains this issue. The > DAR told me that any major modification, such as a different engine or prop, > would then cause rule 16 to kick in. He said the fly off time might not be > as long depending on the modification. I think he said like a prop might be > 5 hours. > > > Wayne Edgerton #40336 > > > Subject: Amatuer Built Rules - was ...The Perfect Panel...how to > > > From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com> > > > When I built my Pietenpol, I had a guy from the Greesnboro FSDO do the > inspection, not a DAR. I asked him just such a question. He said an > engine change, or a propeller change does NOT require re-inspection, > but > it does require going back into "the box" for an addititional 25 to 40 > hours (depending on whether a certified engine/prop combination was > being used) of flight testing before you can carry passengers or leave > the test area. I would assume if that is so for something as major as > an engine, that avionics changes would not require re-inspection > either. > > ________________________________________________________________________________
Date: May 30, 2007
Dean, > 2. Don't trust an AIR leak test. Why should you not trust an air leak test? Do you think a complex hydrocarbon molecule will fit through holes that a Nitrogen/Oxygen molecule cant? More people catch themselves and their equipment on fire every year "testing" their tanks with actual fuel, rather than with accepted methods. This is a dangerous suggestion. Two years ago an A&P burned up a Cardinal testing a recently repaired tank with actual fuel. William http://wcurtis.nerv10.com/ -------- Original Message -------- ________________________________________________________________________________
Date: May 30, 2007
Subject: Re: RV10 helpful tips
In production, you fill the tank with water and apply slight air pressure (5psi or less) then look for puddles. Kevin H. On 5/30/07, William Curtis wrote: > > Dean, > > > 2. Don't trust an AIR leak test. > > Why should you not trust an air leak test? Do you think a complex > hydrocarbon molecule will fit through holes that a Nitrogen/Oxygen molecule > cant? More people catch themselves and their equipment on fire every year > "testing" their tanks with actual fuel, rather than with accepted methods. > This is a dangerous suggestion. Two years ago an A&P burned up a Cardinal > testing a recently repaired tank with actual fuel. > > William > http://wcurtis.nerv10.com/ > > -------- Original Message -------- > > ________________________________________________________________________________
Subject: Fairings
Date: May 30, 2007
I thought I heard someone mention wing root or tail fairing from Sam James for the RV-10, but it is not to be, at least for now. Straight from the horse's mouth: *****************************8 Hi Tim, Sorry, but we have no plans to offer wing or tail root fairings for the RV-10. Thank you, Liz James *************************** Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-401-2522 ________________________________________________________________________________
Subject: Re: overhead console.
Date: May 30, 2007
How are you going to get overhead air supply if any? thanks John 40569 ----- Original Message ----- From: John Gonzalez<mailto:indigoonlatigo(at)msn.com> To: rv10-list(at)matronics.com Sent: Tuesday, May 29, 2007 10:47 AM Subject: RV10-List: overhead console. A few weeks ago I received some photos from builders that depicted the style of many different overhead consoles. Mine will be done once I mount the switches and LED and the velcro and Zolatone it, but here are a few photos that show how versatile working in composites can be. The last photo is the underside after the foam has been carved out. Total weight is about nearly 4 pounds. 2 laminations of six once glass on the outside and one layer of three once on the inside. Actually working in fiberglass can be very creative and fun so don't let your introduction to them by working on Van's parts turn you off...it is not an accurate reflection of what it is like. John G. 409 ________________________________________________________________________________
Subject: Fairings
Date: May 30, 2007
Talk with Bob at Fairings ETC, he does the gear leg upper and lower intersection fairings, and may be working on the others, but give him a call and let us know. I have the upper and lowers from him for the 10 and they are great compared to the Vans supplied ones. Dan N289DT RV10E _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tdawson-townsend(at)aurora.aero Sent: Wednesday, May 30, 2007 1:36 PM Subject: RV10-List: Fairings I thought I heard someone mention wing root or tail fairing from Sam James for the RV-10, but it is not to be, at least for now. Straight from the horse's mouth: *****************************8 Hi Tim, Sorry, but we have no plans to offer wing or tail root fairings for the RV-10. Thank you, Liz James *************************** Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-401-2522 ________________________________________________________________________________
Date: May 30, 2007
Subject: Aileron Torque Tube - WD1014C
I have not been able to find the WD1014C part in my kit. This is the aileron torque tube that's at the wing root. Is this part supposed to be powder coated? Is it longer than needed? I do have one steel tube in my kit thats not powder coated and longer than needed but it is the right diameter. I am thinking that maybe the parts are cut from this one. Does anyone remember? Thanks Niko 40188 ________________________________________________________________________________
Date: May 30, 2007
I can not remember for sure. But, I thought all the powder coated items had a part number with a "PC". So I don't think WD1014C is a powder coated part. Rene' Felker N423CF 40322 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Niko Sent: Wednesday, May 30, 2007 1:19 PM Subject: RV10-List: Aileron Torque Tube - WD1014C I have not been able to find the WD1014C part in my kit. This is the aileron torque tube that's at the wing root. Is this part supposed to be powder coated? Is it longer than needed? I do have one steel tube in my kit thats not powder coated and longer than needed but it is the right diameter. I am thinking that maybe the parts are cut from this one. Does anyone remember? Thanks Niko 40188 ________________________________________________________________________________
Subject: Re: Aileron Torque Tube - WD1014C
Date: May 30, 2007
Niko, Yes the unpainted tube is the tube used for the aileron torque tube. You simply have to cut it in half and then prime it. The adjustment for length happens when you drill the bolt holes after measuring the overall length of the assembly. Dave Hertner 40164 ----- Original Message ----- From: Niko To: Matronics Sent: Wednesday, May 30, 2007 3:18 PM Subject: RV10-List: Aileron Torque Tube - WD1014C I have not been able to find the WD1014C part in my kit. This is the aileron torque tube that's at the wing root. Is this part supposed to be powder coated? Is it longer than needed? I do have one steel tube in my kit thats not powder coated and longer than needed but it is the right diameter. I am thinking that maybe the parts are cut from this one. Does anyone remember? Thanks Niko 40188 ________________________________________________________________________________
Date: May 30, 2007
That's the one. Just cut it in half, if I remember right. It is definitely not powder coated, as mentioned in another response. You will want to prime it inside and out. The length, as I remember, is not super critical (meaning it doesn't matter if it is a little too long). In fact, I don't even remember seeing the length in the plans. They just give you the length of the overall assembly, so if the tube is longer than it "needs" to be, it will just ride further in one of the ends. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com www.saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Niko Sent: Wednesday, May 30, 2007 3:19 PM Subject: RV10-List: Aileron Torque Tube - WD1014C I have not been able to find the WD1014C part in my kit. This is the aileron torque tube that's at the wing root. Is this part supposed to be powder coated? Is it longer than needed? I do have one steel tube in my kit thats not powder coated and longer than needed but it is the right diameter. I am thinking that maybe the parts are cut from this one. Does anyone remember? Thanks Niko 40188 ________________________________________________________________________________
Subject: Re: FS: MT Prop Gov
Date: May 31, 2007
MT governors. all P-860-( ) governors are basically the same. The - ( ) number only refers to the control arm position and the max. rpm of the governor. To change the control arm, loosen the 6 screws, turn the entire center portion to the desired position, tighten the 6 screws and safety. To change max rpm the set screw on the high rpm stop is turned counterclockwise (out) to increase rpm and clockwise (in) to decrease rpm. If there is not enough adjustment possible ( 1 turn = 25 rpm) the control arm must be reset on the spline one notch at the time. All this can be done on the plane. Best Regards, Juergen Zahner mt-propeller USA, Inc. ph: 386-736-7762 fax:386-736-7696 Juergen.Zahner@mt-propellerusa.com www.mt-propellerusa.com On 26 May 2007, at 16:18, LessDragProd(at)aol.com wrote: Just for the sake of clarification, the Lyc. IO-540-C4B5 engine has two different governor gear ratios.- - The NARROW deck has a 0.895:1 gear ratio and uses the MT governor P-860-3 or P-420-17. - The WIDE deck has a 0.947:1 gear ratio and uses the MT governor P-860-5 or P-420-5. - The cylinders on the-NARROW deck engine are mounted with round nuts having an internal Allen wrench drive. The cylinders on the WIDE deck engine are mounted with standard hex nuts. - I have not seen the WIDE deck MT governors being offered for sale by Van's Aircraft.- I have only seen them offer the MT governors designed for the NARROW deck Lyc. 540 engine. - Regards, Jim Ayers - In a message dated 05/25/2007 9:26:16 A.M. Pacific Daylight Time, wcurtis(at)nerv10.com writes: > > Some folks are opting for the PCU5000/X (http://pcu5000.com).- It > supposedly governs better than the MT provided in the FF kit.- Someone > on Vansairforce is doing a group buy of the PCU5000.- Since the > PCU5000X ($1350) is more expensive than the MT ($Van's $1100), this > may be- another case of a solution looking for a problem.- Has anyone > flying had issues with the MT P-860-3? > > http://www.vansairforce.com/community/showthread.php? > t=17279&page=1&pp=10&highlight=pcu > > William > http://wcurtis.nerv10.com/- ________________________________________________________________________________
Date: May 30, 2007
No air supply. I plan on having a turbo to go with my style of flying. Stay hi and keep looking for alternate landing spots. I need to stay as streamline as posible with no more things sticking out in the airstream. John >From: "John Cram" <johncram(at)msn.com> >Reply-To: rv10-list(at)matronics.com >To: >Subject: Re: RV10-List: overhead console. >Date: Wed, 30 May 2007 13:06:25 -0500 > >How are you going to get overhead air supply if any? thanks John 40569 > ----- Original Message ----- > From: John Gonzalez<mailto:indigoonlatigo(at)msn.com> > To: rv10-list(at)matronics.com > Sent: Tuesday, May 29, 2007 10:47 AM > Subject: RV10-List: overhead console. > > > A few weeks ago I received some photos from builders that depicted the >style > of many different overhead consoles. Mine will be done once I mount the > switches and LED and the velcro and Zolatone it, but here are a few >photos > that show how versatile working in composites can be. > > The last photo is the underside after the foam has been carved out. >Total > weight is about nearly 4 pounds. > > 2 laminations of six once glass on the outside and one layer of three >once > on the inside. Actually working in fiberglass can be very creative and >fun > so don't let your introduction to them by working on Van's parts turn >you > off...it is not an accurate reflection of what it is like. > > John G. 409 > ________________________________________________________________________________
Date: May 30, 2007
Yeah, I scratched my head on this part also before I figured it out. See here: http://wcurtis.nerv10.com/07Wings/wings92a.html It come as one tube and you have to cut it in half. William http://wcurtis.nerv10.com/ -------- Original Message -------- > X-Rcpt-To: > > I have not been able to find the WD1014C part in my kit. This is the aileron torque tube that's at the wing root. Is this part supposed to be powder coated? Is it longer than needed? I do have one steel tube in my kit thats not powder coated and longer than needed but it is the right diameter. I am thinking that maybe the parts are cut from this one. Does anyone remember? > > Thanks > Niko > 40188 ________________________________________________________________________________
Subject: inboard flap hinge bracket
Date: May 30, 2007
Has anyone run into this problem? When installing the flap hinge bracket to the W-1010 Inboard Wing Rib, the assembly is positioned where the W-1029B Flap Hinge Rib is now getting interference from the raised "flange" of the forward (large) lightening hole. It won't allow the bracket assembly lie flush to the W-1010 web for proper assembly. The strange thing is I get this on the left and right sides. Did I just make a mistake somewhere, or have others encountered this too? Thanks, Sean Blair Watching the ThunderBirds buzz the Air Force Academy for graduation!
Sean Blair
From: "Steven DiNieri" <capsteve(at)adelphia.net> Subject: RE: RV10-List: Bench seat in rear possible? Date: Wed, 30 May 2007 05:40:45 +0000 Content-Type: Multipart/mixed; boundary="NextPart_Webmail_9m3u9jl4l_23050_1180556573_2" --NextPart_Webmail_9m3u9jl4l_23050_1180556573_2 Content-Type: image/jpeg; name="STA71185.JPG" Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename="STA71185.JPG" /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJChQODwwQFxQYGBcU FhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoIChMKChMoGhYaKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCj/wAARCAHgAoADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDwhbGM dHNNk01HOfMI/CsESP2dh+NPE8o/5at/31XH7KS6kcr7m1/ZIxxL+lB0lv8AnoPyrIW5nHSZ/wDv qnfbbpT/AK5/zpclTuFn3NCbTZVACun1qA6NcyZO+M/U1X/tC54/en8hT01K7H/LT9BTUai7BaQ8 6LOnJUN/umm/Yrhd48o8dad/al7/AHh+QpV1O4yxcKxIwe1H7zrYfvEf2ScAfuzz0p62lxj/AFLf lTzqchVQYl+XpzU0esui48kY69aH7TsLUqmG7Q/Ikop/m3iY4f8AFatjXiBzD+tL/bwJ5h/Wp9/+ UNexAl5OEy0YLA8gipFviykPARxjpSNq0LOXaFgx9DTxrMYUL5ZpWf8AKGvYck0RYEhl57r7VdUx SDiRM+4xVNdZt8DdE2fpTxrFoTzGf++RUNS7MTuOjQKOMZ9qkxVaTUbORww3IMdlqcapZbQDnI/2 aT5uzE0x4ApcCmrqVgc5OPwNPGoaeR98D86V32ZNmJikIGakSe0kJKzLj605xCV+SZc/WlzdwsQU cVmXs9zHJt3LjsRVF7q4PWQ1tGm5FqmzpLfG49KmlxtFcg1xMpB3t+dXdHuZpbwI7sy4OQTTVGSd 7j5LG4yj8DVdwPOJHarXcCoHBDuQccda3iNFI4zTCB1qQ8Uxzke9WURnFNNPP6U08ZpgMOKbinUh 6UAIcU00p460UwAEfSgEU0+lLjigYhxSUGjoKAEIFNpTSGgBMigYoIoYhRknFABxTHlA4HJqNmL5 A6U5VoGBLMeTijaSKkIAZgpzg9fWlAzzQA1UGOadsFaE8lmIYVghYyDBdnPB45qtKwd8hFQeg7UX 7CIhHkdOKUIKlZzuIUfLjn3NApXAaFFOVcU7FITSuAxuvFGVEZyMsT19KcgLhkULuPG49qmlg2Q7 2ZR2xmpbSFcpv8rYznntSqcMCRnFIwAlyD8vbNDMvqKYyY5kdm4GecCkkjMYBPU1GsoHO5fzoM2X 3NIGONvJ6CgQ4UhwKZvUfxD86UuG7j86Bj8jFOUFj8oJxzUQYetOBIzzTAcQwLZ6g4PsaaSKBwuF 6E5pCMUwF3c0Z60lHekBJEolYguF4zz3pjx5DEYZVO0sOmaaKXcQuO1VcCJo/SomXHWrGaUDOMD8 6LgVaXNOeNl5xxTM0xjiflqux5qZj8tV260AOBzWnokg+1Ih7kVl1c0ptuoQ/wC8KiSuhM9VsVwi fhXaQr8g+lcfYDcIv94Zrt41wo+lcr3MbnzaF6cGlK8Dg1a2rkfKevrQV4GFNb8xpcpY5qVVyOc0 vl/NnHbNSfN6GncBFiHFOCD1HSkwxPelw3vSDUXyxnt1pNi+goO737dqQ56UCsGF9P1owh7frQFy OPSnbfp1oGMKLjgfrSeWM0/acdulLt9h1oAj2A+tHljFP2+wpdv86LgQEAeuaTFPZcU4Lx2NO4yI IR2oKnNTleOlIV9qLgQbaKmK/wCc03aaYERJxSbjUu3ik2/WjQBm4+9JuNSbaQrxRoMryNz3ra8O RZ82Yj/ZH9f6VhuMsa63SIfJ0+IYwWG4/jSlohMtJ/rM+lVC3yS+5q2oPzHHQVXmULCMdSc5qUJF Nh6Uw9eTU7Yxx2qIg9asZERTCKlPXmmGmBGRzTT0qTHPNMOSaYDG60h6UpGDQwzQA3tmlHSjFOAJ FADKDTtuKQigCPFBBp+KaTgUDGngCoWRm5b7p6e9TkgKwePIDDcQeenQf1puCcZ/CmAxFxTwKcF5 pwGOaAGgYpcVBPcohwvzNVKWd5OpOPQUAaLzIv3nFRm8jHTJrOoosBeN/j7qfmajN7J2AFVKcoyM 0cqAna7mP8WPpRGZ5ldlYkIMk5qHFTq2yLYD15NOyAZvfu7fnSD5nXknkZ5ppznNOhb96uR37UWE akiL5DKccg8nt3rNXG01oMDLbvgd8VTeFkByCKI7AMGMUEgDpU0du5Uk4AGOtNaH1bj6U7DK4bBw y7kNTsiNyoJH5GkCBR95s/SpI3EUgkC7mBzhuQfrQBA0ZHPNJnAyCfzrso00fxAYxAo02+P+siA3 Rn3T9eD+Gap23h1ZUjcyARvH5m5gQB6c9qfuvqI5ne46O1KZZR0c1p6jYW9rN5cU8dxxy0RJAPpn HP4VVWAOx2jGPVqTSGOsRczh32jykxvduAv1pDdJuK84B+960JHvGxc4+vFI1sB13UrAWYyrrlTn 6UYySKoyIYjujLAdjT7e8GNsq/jSasIs7aeiFugp8Q3DjpU6qcHAAxU3FcasXBLfyqrc2pUb1HHp Whbo9xKkMQBcnHJwPxNbN1EujSNEPs9zMqkM4IdeR/D9PWqiCdjinHHNQGr9/CykvjAY5x6VnmmU LVrTf+P6D/fFVBVrTh/p0H++Kl7Az2HS1yIz7iu5iXKj6Vx2jJlI/wAK7mBPkFcV9TE+cNgz360G PjoetWzCvPB7d6eYk54br61pzGlzKC/vRx6jNWAgx/F0p7Qr9oXGMZP8qtiKPA4bp60+cG0UivPf rRsz696uNGo7N2pvlrnjd1pcwXKZXjjd09KNnPfrU5j4z83Sl8vnv1qrjuRIgA5J6elSbBng9/Sn eX/vd6UJ7t2pNiGeWPX17UeWM4yOvpUgQnu3ejYfVu1K4EfljHUdD2pfLGeCOvpUm046t37U7b7t 2ouBnzx4wc/kPep1jGOev0ouB8vc8fSp1Xj+LoaL6DIWjHt37U0xD0H5VaCdfvf5FJs92o5gKnlL 7flSeUMjpVry+nJ7VEcg45ppjKxjHoKaIxxwKldsDvUYc8dKq7ATyx6D86YyDb0qaRtqg5Gc1oyW cbWUMgGGYAmhytuHMkYSQebMkajliBXYbQqBVHyjgD2rO02xCz+aP4R+tarDgDvScrkt3IpPkgJP VuKrT8hV9KszANKB/CtV5Tl2NUhlVlxTCMVOwzUZFUgICKYRUzKabjGaYEJHpTe1SMKYw9KYEZ6G kx6U/HrSYpgMFWIlQL15qA1InShgBVd3PSo2xngGpuKYxwelCGN2jHIqrOxLbFFWpW2px17VBBHu IODk9KaAUKNgGOnNKF6UpGenGDUmOMjk0gIiMZJ7Vn3N0W+VDhfX1p19OWYxqflHXHeqdNIANFFF UAUUUUAJTkJXpSU/bhAT1NADQMmpXAU88moic1teIdPSyuLRIG3mW2jlcZztYj5h+YoQGQfm4FLE pE6A9c1Kq7eh57mnKB9oiwO4pMDSMe3S5G7+YBn8DVO0vZoHymGx2augsliaGBJ4vMjN0m5N23cM cjPb61kanZvbapcwKqZVyMRnKj2BpU7SQMZNfPMBkYbAB75qBkdzkZNalpp8cUXm3jbPRO5qRr23 hUrFEv481TaiTc5qRyW4PFaNtp9zNppvRG32cP5e/tuxnFUpYj5h2EYNa2lbFtHhkc/MdwHYH6Ur 21GyiIjuwTipy0joFd2KqABk9qtXFuY1HIZT0YVAgz1OBSbAg2MOAap3Eru23ooPQVv29m0w3ZVI x1JPSs2/tU+0N9n5Q9M8GqXmCZHpPmPOQvIVSxq44DPls4q14at4ILpzenh1KDHb3NbN/ooC+Zbl ZE6jBzSSTduo7nLvHlG2dT2NU2h4/wBrua2bm2aI/MpWqU4fy3JUdOop6rcSZFa3gtJ12/MuOQRn FbllbS6jL/oql0ClmKjOB61yrLjkZx61o6Nfy2shjSRkjfqQehqWrag0dI8lrDYrDbwsJi+WlLZL D6dv8/jUIaWVmVWPRQMdamjjxgFt3PJqeS5EMg8k4Yd/SpvfQi5hagW2FHBBHUVjOMGui1ZZHjM0 jRkseFUYIFYMg71b0NERCrWm/wDH9B/viqtWdOP+nQf74qZbAe4aIv7uP8K7m2X5B9K4rQlzHH+F d1aj5BmuDqYnzjxz8p6etOJ4PynqO9Rj7v3T09acRwfl7etaF2K8rfvl6feHX6VaToOPXvVO44cE 46jrVlB047+tPoNokPTp29aUEdx39aixx90dPWl9cgdu9KwrDyoPbjnvSYHp6d6QDnoO/ejHHQdB 3pjFxzjHr3ox7HoO9GPmHA6+tHGOi9PWgBcc9+vrRj2PbvRjn+Hr60cbf4enrSAUj+vekA9j270c bv4etAxj+HoKAILvHln8epqWMjaOlR3AyjYx1PT6U6E/IvP6e1PoMlBXPb8/am5HGMdu9API59O1 NP8AnikIRmGBjHbvVeSUKR0/OpH6f/WqpcDp/hVxQ0LI4cDHH41Gqe+KiDFScelSrJkZ21bVgGzA qFAOcc10No4l0+FTxhdv41gLGZWPauj0yA29ivmj5xkgelZ1FoKWqsWbeMRRgA55yTUhYEl89O1W 7aEfZ0DDPGaHs1YelcqxKTszRUnYzHO1Mnq1V2Ga1JdOZiSH/SoW0+UdMGuiOIpvqDgzOYdR+dMx xVyS0mU52moWgl5whrVVIvZk6lVqj6GrhtpSfuGmmzmOfkNPnj3ApMMiozWh9gnP8Bo/su4PYCn7 SPcLMzDSZFao0iY9Copf7Gmzguv5UvbQ7jszINPVwBg1rf2E/eX9KBooB+dyaXt6fcOVmVkdcilV HkPyRs30Fb8GnQR9EGffmrSxBRwKzlikthqDOcGl3Ex+bCDGP8atw6LuKjzD+VbQSp7f5SWPQc1h LFT6F8qOV1Gx+yShEJYEVmXjSJFtiRizegrsYNtzqvOCADkVsLbR9kA/Cr+t8iSkrszS5tjymPTL 2UApaykeu01ai8PajIM+QV/3jXqKwqOg5pfLA7Unj30RXIeXt4c1FWx5APuGFA8Oagf+WQH/AAKv Tig9KYYxS+vS7D5DzgeGb89VQfjU0XhO8kU/PGD6V6AyYFOtI8ygUfXZsPZnnOo+Fr+ytvPZRJGP vFe1Zc9rPGFZ4ZFUgEEqcGvbrqEfYJcgEEYxRDp0TQIjIpXaBjFaQxunvIho8JRC0gBB61o3Ez3M 3OWONvvj0r1u58K6fOxZrdA3qoxWZN4Itw263llhbsQelbLFU2Sed3mnXtkYvtdtNB5qh08xCu5f UZ7VViGb2IdcGvVZ9F1KfSpbG8vTerkGGS4BZ4cdlOeh9K5V/BeoQ3KSIY3VTk4ODWvtqclo9QTE jjiOiSTT5CLOAccHG1qyZtYghJ+yW4z/AHm5rvJNN2+BdUtGhZ9RlnjaJcfwgHJz+NebXekX1qP3 9tIv/AaqFnFWYXuRT6hNMxZzkmqzTO3JNIY2BIKkH3FNKHPQ5quWwxVkc96GkYYwxoKknABp1rGH uolkDeWXG7A5xnmiwElxHJCkW52LMu4g9s9KNo8hWEnzH+EZyKva5ItxqdxJbxMlsXxErckKOBn8 BWe6MBwpz7Ci3YC9DcRxaVPB9nMl3I4YTlz8iDsF9z3qmm4Ou9mC5GcHnFaOmwpLpt0zvJ9qQjZE Is7l7nd2x6VVWOaNg4gZ2BxtZCRR0EdTottpmuWr2tsrWupwozrmTP2jHIABP3sdhUV9oPiWxnjg ktb+J3+4kkbZPGemK56xtZSZXeOZHVdyFVPLZHFb1zrHiXVEjW8ubycpwrOTnGMdaV+klcZlTX9/ buYp2D4OCsiCiPUrWQ7bq3KZ6tGcj8jVsaHqd6w887R6scmr9v4RBx58xPsoqXUjHrYVjJmso3gH 2a5jmgxwMfMnOaqvafLsiRifYda7S08O2ls2VQlumSa0orCKMfKij8KxliYjszltIiuTaCOeJlKn gkdRVsaW8jEscV0fkgdAKcI8Vg8Q1sCgjm5tDWSL5nbIrjruPyp5E64JFepXC7YmrzTVlK38vGMn Na0Ksp3uN2WhmkYJFWLDi9h/3x/OoZBzmpLH/j8h/wB8fzroewme8+HhmKL1OK7y1jOwVxXhtf3E P0Fd7ar+7rgW5ifMSr0+UdCOtLjj7o+7jrWF5k399s0m+bj524rq9m+5oa1yVAycdP61MmMcheo7 1hkyYwWal3uOpNHs/MLm6MccL3o42/wdBWGJH9TTg8npS9mBt5UHqnWgEY6p0NYoaQkcYp4WQn7y j8aXJ5hc2Ny54ZeooyMdV6HtWatuT1nQfnTxBnGbtR+dKy7iuaGV/vL1Hak3DH3x0PaqqWe/kXQP 4Gn/AGEd7of98mp91dQ5kT71z94dRRvXH3x0qs1rAv37zH/AaT7Pad7w/wDfNGnf8AuTyuvPIPPT 8KZA4Ea5J/OmCCx73jf9807ydO73T/lReP8ASC5IJF4+b0701nXH3v1pBFp2P+Pl/wDP4U8Q6aR/ r3P40cy/pBzELyLjr+tVJmyeOR9a0o7W2mmWOJZZE9V7fWtSPQ4AOVYfU0+dIOY5PBLirFvA8jbU RifauqGk2iHcUJx6mpfLSNcIoUewqvaXHzaGXYaeIPnlwX649KvO28rGOrMF/Wlc4FLp0Zk1CMno gLf0/qaibtFsS1ZtKmAB0pwX8qdinY9q8ds7UtBoWl2+tPApdtS2OxA6DHIquUGauuOKr45q4MmR F5YpdlS4/CkIrS7FYi2inBeKUDmnYOaLgNCDFOCU4ClxSuMjZagcc8VaIqu68047iZGFpduKeBQR xWjZJER2p5Gy1dqUr7UamfK07gckUlq0gk7K5n+Gl8y9uJD0UAfmT/hXS7aw/CcWIZ3wOXx+QroA OaWIf7wil8IwL+lGOKlC84oK8Vjc0ICOKjI9KsFevpUZXmmhoiIqbT0zPxTStXNMj+ct1FUtgexZ v0xahehZgP1rRiiwoqndruuLSL1fd+QzWrGtNbGDIxHilKe1WAtGOTQTcreXntSiFfQVZCUpUelA FMwr0wKims45B8yA/hV4rmmuvFUm0Bz8+kWhct9nj3HqdozTP7HtDz5EZP8AuiteUZNCrxWvtZdw MY6LanrBH/3zTTo1qDxBH/3yK29uKQrS9rPuBjHSLbj9zH/3zR/ZNsP+WKf981sFaaV9qn2su4GU NNgB4jX8qcNPiH/LNfyrRxShaTqS7jM02MXXYv5VBJaqP4QPpWy68VUlXOaqM2BneSB2pRGKsMvp SY4rRMCuYxuzSEDmpscVGRSY0RbcmnbcCn7RmjFSykVL3iBvpXnPiAf6Up/2cV6Dq8nl27epGK4H Wly4kJ4Dba6sKnuZyfvGLIPlp9h/x+wf74/nTp9mw7Sc0mnf8f0A/wBsfzrs6DPoPw6v+jw/hXeW w/diuH8Or+4i/Cu8th8qj2rijuYnyCyMFVuzGm8jIPUVcv08tyuOCc4qmVYngGuqLui07gT0pG5B 56U4QSHopP4VIljcv9yCU/RDVDIlBz+FSryBViLSr89LSb8VIq3Hol+w4tyPqQKltCbM0inAVrx+ Hr5uqov1arEfhq5/jljH05qXJdxXRhdqXGPpXRp4c7POfwWp18PW4+9I5/Sp5kFzn7fKhh1qwckH iuih0e1j7MfqasLp1spGIl/Hms202I46eEnJK5wagNpJI5CRseccCu+W2iXpGg/CpAgHQCmqlh6n CR6JeSjiIrnpu4qxF4Yum/1kkSD6kmu020owDR7aQ7s5q38Lwj/XSu2OwGK0rbR7K3+7CCfVua0m YjgCmjce2Kl1JPqAxUVBhQFUdhxTXYCpNue9MYAUhFaV8A4GaqtlquSCoCBVxEV2Xjmr2hx7zLL7 7R+FU3rS0Bf9CLY++7N+v/1qzxLtTNKavIv45pQKcBzTwvevJbOwYBmlxxTsUYqRkMgqLb6VYcda YFrSLJZHto25qTb2xTtvpVXJINlGznpVhY6cEp8wrldE9alVOKcF5qTGBUtjuVpVwKqsOTVyf0qq etaQExgFGOaf/OkNWCG4ywHrVbxG2y3CVdt13TKKyvE0hLlfSrpK9RGdV2izT8MxbNKjJH3iW/M1 rBfpUGmw+TZQx91UA1bAFc9WV5tlwVooAOKCvapAPWkxUJjIWUVHjrU7Dn1qMjiqQyIjn3rV0yPC D3rOAy4Fbdkm1KpkyI2AfV4x2RCf5D+taqAYHpWXZjfqc7dlUL/OthF4rSxg2JigLUm2nBaBDAKU rUgGBQFpWC5Dspki8VZIqKQUAUWQE0uwDpUjDmnFc00MhK1GV/OrBGPpTCtJgQ45pjirATimMmaQ yDb607bUqx85NKVGDQBXccVWcc9KuOPyqu4qoiKhXNMZatFaYy1qmBVZeKj21bK0wrQ2NFfbQRU2 3vTZBhTUso5zxA+Aq+prhtafhfdia6/X5P34HoM1xWsHPlgjPGa9HDxtEz3kZ7EEVZ0gbtTth/00 FUye1X9CGdXtB/00Fby2ZR9D+H1/cw46cV3dquCPauL8PrmKED2rubccfhXDHcxR8/tY2zkFoEJH qKctpArYWCMD/dFPjnVuDwfSphg80XYhqxIv3VA+gxUhHB4pcjigN7VICBfzpCKeGHekyOODQAgG aXHag7uwpCH7CkAxlpMcUFHJySacI+OTVoobwKTcKl8sAUgCgmiwEfJ6CnbSakyB0IpC692H50hj QnqacE46U3zowPvij7VCv8VIdmBXmjbio3vYR3P5VUl1eCIchj9BTQWZeIqNhismXxDAvSKQ1Vm8 SbVytucHoSetUovsFjZkHBqswrBm8Rz7QwhQA9Oaqvrl0ybh5Yz2rSMGLlZv3JCRs3oK3dLi8rT4 EI5CDP1rgbbULm8u4IGdSJHCkAds16Wi7UAHauTHNxikzalGzEAzTgOacFpyrXmNnSN2+1G30qYJ T/Lx1qbiuUnWm7elW5FFRYq4slsi204LT8UAc1VxCYGMUmKkIoIouBGF9KUrUgFBHFTcCnKKrGrc w61Xxk10Q2BjMU1jUh4prCqBD7IfvCcdBWFqA+1avFEejSAH6dTXQ24xE59qxtKj8/X2fqsYJ/pW tF25pdkY1VeyOpjXAp4FIOKeorheupugA5obpTscU1vp+NCAjIppFSEVG9WFhbZd06j3ret1wprH 05d0ua21+WFj6Cq6kTK+jrue4k/vSEflWwo4rO0dMWin+8S361pritjBgFpwFLgUdaLCDHrRjmnY oxQAxhUEtWWHTFQSDNIZWNKOO9OIoNMBhGaTbT6MUrDGEU3FSnpSY5pWAZt9qCoxgingetBppAVZ FFV3XmrknvVWQcmqSAgxTSO9SkY5FMNMCB8VGetTSDNR49aoaG4qGc4jNTmqd8+2JqSV2O5x2vOP tJA7LXJauxWZAP7tdBqkm68lOe+K5vVzuvSB2AH6V61JWRmtyga1fDS79ctB/t1BJp06WH2t0Kxb goJ7n2q74OXd4gtR6GnP4Wy3sfQ/h9cCEfSu4tcYHpXF6CBmD1zXb2cbSOiRqWZiAAO5rhhuYo+a Vfaqg85q5BO4wuRx61QRQy5Axipk+UAiraJNSG4jbhuDUjXMEZO51HtWUHG47QeKR2OQGUEkZye1 Q0BotqFsP4qYdTtx90Ems8RI4GUHTqKb9lDdypHrRZFrlNA6umPljJqM6sTwI/1qibV1BwQaiMMu 7Hln65GKLXKSgXm1OQnhVFRm/mJxux9BVC4ZoEDMFx36nFU5NQVcfMv5U1CTLXKbRu5c4Lmk8+Q4 +Zj+NYLamOu5vwApp1PI48w/jT9lJj0OgYyFeCTTfmwMnFYH9oyvwImP/AjUZubhv+WSj6jNP2Mh 3R0pkUD5nUfjTPPiI/1gP05rmmnuh0+Uf7K0uy7lA+aQ+3NCoPuHMjflniA+8fyrKup1fow/Oqn2 S4J+ZJPyqcabMQPl/M1caSjuyXJMqTv0546VEVUkbn4rXTTkKhZPLGOeuajGnRb+ZVIz2FaKUUTd GS0cYP38ilEaA/dZvYVuGG2hwMbj7KBTfPhU9GwPQ01UXQOYi8M2pfXrXMTIFJbJHoK9KCcVyHhj ZPqYdAfkQnJOfQf412g6V4+Y1LzSNqWw1UqRF7UA9qeDxXnNmwoUYpGHHTinDPUUjHipEV5OTTMc 0+Q80zNbRJY0Ln1p22ilqgEx7UEU4dqeooAjAoYcHtUnFIwGKQFGaocZqxMMmoitdMdhMiamEVMw xTCtMY9jssnPrVLwtFk3M/8AefaPwq1qR2aefpU3h6ExaZFn7zZY/ic078tNvuZtXmjSHWnUY/Ol xzXJc2DqKQ89ad9aPU8U0wIzUcg61MRkVE68VSYy1pi8E461p3TeXYyMewqlpq/J+NWtU5tlj/vs F/M1cdWZTLthGY7aJD1VQD+VW+1MiHAqQV0IwY0jPQ05FINLingcUxB3paDSGkwEaoXqVqiekMhY U2ntzTSOKYCUGlApcUgG4oxS45ooAaeORQWB60pph9+tAEUpFVm5NTye9QtVICI5phFSGmmqAhbi mMKleom60xjG7msrVHwmPxrUk6ViaxJhXPoDWlON2O+hxd380zn1auc1Nv8AT5iOzEV0hG6VAe71 yt0++4kb1YmvTRECxPqd5cWENlNcO9rCxZIz0UnrWr4FTd4igxzgGudHBzXWfDlfM8QAgcBKzqaQ ZT2PfdBH72Ef56V3Omzta3cE6AFo2DYPfFcXoI/fRYrsrUbnArkgr6GSPmOND2IOOeKlUMhKgjrm qFzewW0pV3CsMgEjrT4b+GZcxkvjj5RWlmxWL2TtJwcnmmscEkcfU0kcw3EgZHuelDSowA2ksfep sA9Tg9VHrtFOJ+QnPTnHao84ySBz1NKuCxXIKgZJosFhQ54IIxmpCx28jnpn1qupMZJ2dfalIzjj GTRyhYmch/lYAgjrVSTT7SdsSQqrHoVOKtAHHTv1qNyWOV/h6YoWmwykdKtkI5PsKcLK3X+AEfXm rrg4B3Z9ah3/ADdP16iqvLuPUQW8A+7GDj1Jp5SFBnylGBkHFRbmBPp7VXnbcxRCc9/pSd2OxJHO zORsXb7CpZ7hkTCcZ7io4xhOAPb60yVwflPrSaQWIxNKxbLseOmahQyO2FJJJxjNTKFAOOuOtV9m UJH86aSAV8q5SQFXDbSD2PfNC9elMCMMkndQc9adgHsfkdBtIyCSQM8Z6Hr3qo4G75SBxkZqfODz 0qGQ/uyVHHTmriNHSeA4s/apcEAlVGfbJ/rXY4rA8GQ+XpCsRgyMWroK8LGy5qrOmmtAx3pwoApw 61xtmgoqOQ8GpMcVDIOKEBAxyaAKQ9aXFdC2JAc0Ggj0pwAFMQDpThQKXFIApr9KfUcvAoW4FWQ8 1HmlfOTTccV0paEi5yDTQAWpW4ogG6YDtmmMr69xaqg6tgVqW2yOFE3AbRjrWbrUQuLu3t8kB2xx WlF4cxDtS7lPpuwcVvGh7SmtTGVTlkyyHU9CKXcAeox9apt4bn/hvWGf9n/69MPh7UF4W+BHun/1 6n6i+jGq/kaG5c9R+dGQeAazxoOpKObmNvqpoXRNUU/LcxAfjR9Rl3H7ddjQbio2Gaj/ALM1XPNx AP8AgJNNbTdVXpPAf+AkUvqU0V7dGxpmBx6VNd/Pc2yj+9n8q5FtZvNMuWju4gB0DDp+FbWgaouq XZKrjyl5P1o+rzg7szdRS2OqTpUlRp0qTpTSIYop1NpaYhaaelLRSAaajbpUjVG1IZEaa1PPWmnk 0wEFLRikA5oATtxR/OlIxS4oAZjmkan+9NPXmiwFeQGoGqzL7VWYdapICMmmtTyKYaqwETVGwqcj NMYUDK0nHWuc118RSH8K6SVflrk/ELYjb61vRV5BLY5wHDqR1AZq5i5geOQ71IPvXSFwu9m7JWHq E5nmY9q71sKJRxk9K734c2zRagSy4BQHPrzXKaNZPe3scaKWJYAV7JFoP9h6rbQNje1sjMv93JPF ZVPei0OTO40H/XR/Q122lwyzzCOBC8jcKorjdCXEw9lr0DwnfR6dqCzzqTGVKkjqM965Yu2xCR8c a6qG3jZlyecGq+hg+U4IIwc1tSRCSErjjqPeqqxLHJI5P3+qDgV0KSUWgvoTQzYBBOR0qZJFIz04 z0zmqfl/vMgMq9QCc4+tSRMNxGe/FQBZcjYBupuewbGe1QMTu65+tOx8tSmXy6FoNuiBDd+feljJ WVRkfnVdiDAGxgq3I9avWoRUY7AS3PHNUZsU/KuAOCOCKaCuD249OtIVJ3En5cDA7io84eoAcwOP lbHtUQXEnBOOlPyPQ5FMZyrbycGmhoinfyV2gku3AGabDHsOTgk8k1HuMsrvIMtnNWAQU44FUUIW MZ4xzVSQGSYg4A6ipmyc7SCcdKifcJAwIwABjFSIWMYOMc0YA6DPanxkecMcjrUcjKdxGcdRQBG5 xgbeDxn0phGMDgn0pWbJ5zUZBJPr2poB0oQxk7sn1qGQjyiFAIx+RpSjeveljh865ji6l5FX8zVr RXGj0fQ4fJ0y2TGCEGfyrQxTLdNsSj0FPYNngcV81UlzTbOyK0FApcdKVQRSgVkyhCOtQy1Yx61D L700Iqkc0opSOaUCuhEiYpwFKeetIOtAhRS80gpwpAH4VDN0qbtVec8VUdwKrfeoA5pADmnCunYk YRyafbL+8zR1GKlgwoJouMzcmfxFAgz8uW/TH9a7O2VtoGTXHaEPO8Rzuf4I8fmR/hXdQJhRXpU1 aKOWT1YmxuuTSYf1qfFKFrWxNyuRIe9IfM9R+VW9tIU68UWC5RJl9RQ0jgYJHvVooOar3PyxSNj7 q0mhnJavfW99G8Lr8yMRg/zFW/h9aCGG8lBzvlwD7AD+pNcqpy1wx6k16B4MgEeiW5/vAufxOazq u0LERfvWOiQU7FCinYIrkLGgU6jFLigBBQaUUEVIxp6VC1SsKiNMBppuKdSUAJSU49aMUDEooxSF qAA1G54pSaYf0p2GQyVC3epZDUJ61QmNwc0xs5qTvSEc0AR00inEU1qBkM4wDXGeJD+7Pu1djcHC nmuE8SyhTk+pNdGH3E9jltTuNnmIp54FZC5dgByTTryYyTOxPetXwvpkmp30ccaE5OBXa3ZFLRHq nwI8IPqerx3csQa2tyGJPQnt/n2rsPGyf8Vzd/LjCIMfhXq3gnw1F4V8HwWsSB70J58/GPmI+7+A 4/OvEmvZdR8U6ndTcs0xH0qdqcpPqQ9dTrtCGZO+dtdVb8RmuY0Ef6Qf92uoiBKYUEmuWnuSfLxc OgbgdOMVXlOA2QCQe5qeHBjGMfhUE5aVSw256cCr6gRq4LgKDt74pY2AlxjPPU0xQyngYPTmhMmU DPegZM33iQc09emPakYbcdwaVevNZbGu6HR4AYMSM8dM1psVRFADHZ0wKyhuJHTGckZxWkN2cKRj rnPWtXsZSGSMdw7DHIzUXI//AF09slvemeX83OfWoQg5z1A471VmbL4B4FSzSAHy1ySfSmRRYYbh znmmhoE+VMjIBpss4ChQBkEnIps8gyVXk1XwQfmzimMl6K5J+b0ppYGQrzkdx0pQNw65P1qWNR8+ 5DkgEGgCJBznvTl8sI2QW44OelSKuGORgHrThDFvBYHgfdHc0kIpSEFjsXgDFRFSSNvXHStNYn3M ViJB7Ypv2KU5xH+NUkx2Zmsrr8ysQ3dfSrfhmIz63ACD8hLn8qkuLZ4o2ZgACMZ71o+Crcf2hPL1 2rt/OprS5abZcU72O4QfLS4zQOgpc4r5lnWhcccUdKTp0pecVIwbpVaU8VO/SqznJq4biG496BR6 UV0IgKB0paPagBBThSY/KnY4+tIBe1U7jnIzVpjgVUlOTV09wZCoxindqQmgmt2SgpWbbEaaOtNu SRAxz0FJK7H0E8JIGvr2UDncF/TP9a7mJMqK43wQu62mkP8AFKa7aLha9iKsjjYbBRipPSlxVCGb e9BFS7eKQqKAIGHOKpaqQml3Lf7J/lV8j86x/EknlaNc54yMfmaTA85/5YyY6k16noMXk6dbpjG2 Nf5V5jBH5ohjGcySBfzbFetWa7YwAOgrnr7JEw3ZaAFLikFKa5ywpKXrSd6YC0h9qXtSGpsMY1Qt 1qVutRt+tCGNpD7U4000wCgmmk0jc0WAC1NzQfrSU7WGBpjHg041GxpgRPUVSP1plAhCaQ0pprUw GNUbdKexqNjkZpFFS8bbG30rzTxlcgOsa9e9ehavMIrdmPYV5Drlybm/kYnIBxXXh11Ha5nIhmkC L1Y19D/ADwtEJJNZvkAtbMB0U9XfsP5mvGfBmmDULqR2PEeCQBkkZ5wK+rLCGy0/QLSz0iYS27IH 8wgqXB74NdKjzysRN2LXibxObLRru8DN58pZFXPGCOv1FeOeF5DPLPK3V5CSa634iJJDo8BOdjFu feuQ8GgG2JHdjUYl291bCWx6P4e+aV/UAV2ukOUimWKZYLhgNjt0xXHeG1+SRvcV0ecRe+Kwp73A +Wof9T8uQRx+NMVmwWYgHuBUlm48sZ6kVE/G9SOfTNW9xDHGTuGT7+lJFkycDOOaijd1JBHy981O D84KgjI6UgLXlkR4ZeTzz2qBQdx4xipElGcN375qZQCpbnII5qWle5SlbQbGNrBm6noKmaTcgC8k npSHBHTI6gU1gQxFN6kiZPfj2ps0xjBAGW7Cp1hba0hU7AQCRUr2RjlkypJUbgfUVcaMpahexQhg IG5uTQySD7gIdq6tLCAxZ2ghh1oW0VChIDbRwcVnfU2VJs5q30ieTJYY+tWk0JjgswrogKXtRzGi pIx4tEQHLOfyqwmiwgknJWtAdakDfJjtU8zK5IoorpttH/yzB+tOFtCmdkajPtVljTc4GSOMUczF ZIrOgAOAMdKqygZxVliegPFVmOXq4gjM1hgEVep64rT8GwgW00oz874/KsbU33XJH92uo8OR+XpU H+0Cx/E5rlxsrUrdyVrI1aKKTNeHY3Q6lzTAfenZqBjZDwarE81PKar1pTQmFGaQ9KBxWxIoPrSg 0maXPTFAhw5oBwabS5oAVjxVOU81ZduKpueTzWlNagxDR9ab1pSa2JFxzVfWW8qyb3FWIxucVm+J JQqrHn3rSlG80iZu0Wb/AIITbpMR7sS3611qdK5zwpEY9LtR38tSfqRmulUccCvUOUO9LnmjFKRz TAfmkPSkBpx+7TERkda5nxrJs0kD+84H9f6V0p6GuO+ID4traPPUk/kB/jSe4Mw9Bi83VNPj7A7z +AJ/nivUIBhRXnvhCLfrW7H+riP6kf4V6LEMCuSs9RU9h+aWjFFZFhSU4jik6UAAoNFITSAjaojU jmoWbFNFC5xmoWbPSlJyKZginYBc8UoPemilI4pjDOaDSClNAhDUTVKajYUDIG603FPPWkpiGkcU xh6VJTWHpSAgPXmmNwDUh61HIeKCkcv4tlKWbe9eT3BzK5969O8avi2x9a8vl+8a7qC90o7H4cIR exuCQRIOn1Fe8y3zRzh3JCDAyPSvDvhspN1CBjlwf517xpf2Mzub5VePbjB4H1relu2Y1NzA8f3Z ubSFVYmDYSgP15NYngtcWS+5rR8bFA7LEMQIhCZ9Kq+DVP2KP3Fc2IfvD2R6L4cUCFzjvW6SFjPF Y+gjbaHpy1akh/d1ENhHy3a8QZJXHb1FNIzvC5/Onac+U2jGexqRkHm7vUVctGD3KDHaxUgVKGwq nucioJT+9binB8AHgjNIBzZ/hODnjirlsTyCc59apAkHOc1oQYfHGCR60hkuM4x1qW1ha4nVB37m mLHubaBySMAV0un2gt4gCBvPJNC01ZUI8zCW1QWEkKjA21RiVJoIJXO1mTaSTjpxVrWbgRWbDOGc 7R7etR2DQXiLHFuCwY5HGeK6KfMqfM9rhOznyosac+60VW6oSpqZhTYYBC0hDffO7HpSueea5ptO V0dFNWVmNcgLk/jRkEZByKGIHWmhlzgA4+lSaC55p+cIKiLAGlydoxQJjyfSmFv3eD1zS9qiPWix A2QCqx6k9qnkPBqncuEgc5xxVoa0MWb95LIxGcnAzXc2SCK1iQD7qgVxFsN08aHks6gfnXeIcKK8 /MHokRT3uONJmkJpM5ryrG48U4GowKd2pNAMl61CfapJajrSAmJSc5pTSVoSLTqQUooAWjHFKAc0 UARS9KpnrVqY8VWatqYmNHNKaMUp6VoIfbDMmfSuc8SuWmYKeQvFdNBgKx9q5e9Hn6rGnUGVQR7Z rowyvMxrvSx6VpEXlwIo6BQK1RVHTxiMfSrh616CMR4+lKOaavNSKKYDcUpHFSAZpDQIgf7prhvH r7ry1jzwFz+Z/wDrV3cv3K858XyGTXAv90D+VLqKWxpeBo913dyegVf5mu7QYFcj4DhxZSykfflO D7Dj/GuwUcVxVXeQ4aRCl/ClxSYxUFCGkpxpp4pgJTXIApGbAqFiTRYBJDUXensaaaZQ2lpDQDTE KKMUhODSg5FIY3p1opcUuKAGkVGwqU1G9AETUxqc3FJ2piGU1+lPNNYcUDIGqKTGKnK1BNwDSKRw vjp8Q4rzeQ5Nd949fjFefv1r0KXwlHo/wviDXcGR0bNeqyyrvbnb6AHrXmvwtHlzQvj7uT+grukf fJk85reh1ZhU3Kni6fdE/QbY8cfSrPhNMWMQ9hWR4okwsqt1IxXQ+G022sf0FcNV3kU9jutFGLNP cmtTy3mVhGu4j3rO0wbbOH6ZrRVLae2aK6aVBvDhozzxSTajoCt1PlGwJ3cDpV18CRQwx3xnis/T v9aRx+NXpsFvlGCTWs9xPcoToFmfjjNNVl8vB7HnFTXZ2ycNkkdaiiCncxXPrUoY5WRRyd30rRtM lRgEZqhH+8lGRgVqRkQxKyjNVGDm+VEydldm1pVsFTzpRz2zVm4v40+S3/ey4JIHQVkBLq6MZuHa OB2CgAYq3aRx2d/LGqko4wD1wR1ro9hCHxO77DjVbVkrIxry6lun3TNn0HYVe0C68qV4dv8ArOh9 DWfPEVkfYQU3EDmp4I1t/KlLqZNwIUHJx716NRQdLlOODkqnMbKXckk0DPtA3YIU+o4q+/XoKybx kQsoY71O7ntg/wD1zVqS/gVRmUZI6CvHqxVk0j06UtXcslhTC2B0rOk1WIEhVY1Xk1NyMIign1Oa ysbOaRsNyRmmllB5YCsFry4cZLkDp8oqLbJISTub6mkZuojopLqBFAMq7u4zVWTUoQfl3N9BWVHA Q67/AJVzycc05ok3HMmcH6UrmbqFibUmbPlx9fU1QuriaZNpIA9hVjEKnABOPWoZJSudqr0/Kmmy PaN6CaNC51W3yOAcnNdwDXI+HVkk1FZXB2BGwccZyO9datedj37yTN6WwEc0ClFKOtefY2uKBzS9 qAKXtik0BDJ1qPFSSAZpnGK1itBNiUY6UAUuMVTQgxS46UoFOxSEIBxSGn0xhQBWn+tQYqabrUeK 6IaIljTTec08ihRVXGSj5bV2rmtOUz69bj/poW/Sujv28vTmPtWJ4Uj83X1P9xCf6V14Rbs5qz1S PSrJcIKsnpTIF2oKlIruRA1c1MvrUagVJx2oELmm0uMdaT1oAZKcCvLtfffr1y2eFJr02dgobntm vKZj9q1eYf8APSTb+BapuKWx6P4Vt/I0a0UjDFAzfU8n9TW6OlVLJAsSj0FW+/tXA3dmmyHUhNJ2 5prNQhATimFs5pT05prAVQIYeaYaeaaaCiM02nUnU00AnakFOIyaQigQ05PelFBxS0DEoNLikIoA afeo2NPao29KAIzTT+FOIoxQA3tTG9KkxTWFAETcDNVpz8pqy/SqtxwhNIpHmXjyT94Ae5riT94V 1njl83Sj61yg5cCvSh8Iz174YxYheTHypGSf5V0aviTKnj+VYfgFRFo95IccRBR68mtayYmVEbbg 461tR+FsxnuU/FQWSVMHkuo+vIrqdHxFboO+Olclrik6hAv8PmiuxtYd8EeOGFefN3kUzu7FMW8Q x0UVZdAR04qO3O2NB6KBUxcbTVQ2JPkuxx9p+buK0ZsYUqB15zWVCdtyM+tbCDflCAMjAq5obKNw uSmASeeBSQxtsJYYzwM1d+yKuC0h9sUptQr/ACPt47j/ABqdAuQpGinu/TkZ4ro9OsIRsmYhz1Ax wPwrHEEZGCWdh6mtiyuYYoFV3jVu604ycb2Kgot6ljUxGtlLztc8g+9YR1CRJUcNucElsjrU2t3v nQbYkJUH7x4/SsFpcdh68ZzW0XOmuVhPlm7o2rjVHkyFtohnrlaoM8kjHgID2UYqGO6DMu4deozW iRGqqUXPGc5zWTnKOxLd9ysN8h+Zmdj3JqVIGA5UD3NPEuSuwbfWpJm3YBPHXrWTk2K7BLXI+ZgB StHCvvgZOTioHuYgqhpMEcEVXnvYxwi7sdD0zQotgrstFguNikZHIp4l+Tn0zwetZD38pGFAX6VA 9xIx+ZzmrUCuVmy1wo+aSTGOmT04qrNqVvCc7t3OcKOtZMjk9aqyZbtVKCK5TRuNdOCIohjP8VZ0 +p3EpPzBfoMVA0RJ54FNZVx3zVqMUNJHafD0ySJcyO7Mu4AZPArtV4Fcx4Eg8vR1bvIxaupH6V4e NlzVWb09gHApRSelOFcZoOWhjxSjpTZDxQIham0pOaB61tHYli4paQU4CmIUClx7UUopWAQCkcda eabJwtFgKMo+amHpzT5DzTDzXQloIYRQAc0vOOTmnxLlqTGQ62+2xx6iq/gWLfqlzJ/dQL+ZP+FH iN8Rqoq38Pk/d3Uh6mXb+AUf4mu/CK0LnJUd5neJ90U4CmpyKd0rrJHAU5aaDSr1oAU03tTj0pjH igChqcnlW8z5+4hb8hmvOPDcX2jW4Qef3m4/gM13viWTytHu24+4V/Pj+tcn4Ai8zUZpSOI0/mf/ AKxrObtFsLXZ6PCMKKlziokPFKTXCjQUtmkzzSUneqQDjSUZHekJHaqENbrTGp5PrUZpANo+lH40 UwEPWkzzQaAKADGaUDilApfrQAg6UjUoobtSGQsKiPWp2qu5OaYhKaeaUmk+lMABpppTTW61Ixj1 SvG2xN9KuvWdqJxC59qFqykeS+M33ahjPQVz0AzOg/2hWz4obdqcntWVZDddxD/ar01pEaPYfC7+ T4fuDtznav6CrlpJm6iyueRjPcVS0rbH4YOSQzS8eh4FT6Wc3sIBzn3ranpTMHuO1E79Xth2MhOK 7zS4wyxD1IrhJVDa3bnPIycV1ujXE41uCAEeUTkgj2rzJb3LauegrG7RsVwMDuaq5uN4JCmPb27H /ParIPFOCjH9K2g7IR8kv8lwRjo3StRLiFcHcpbPOOSKzNQGy/mA6bzitNTGIl3KqkDJ57+tXLYb JjORtKxO3fkYBzSFpZAD8iYGMAZOKrTX9smN0qknqAcn9Khk1OLdiGOQp71FmKxpiIoI3dmcE4wT +f8AMU+JmUHbjGMf5/KseTUpSo2qoOOM9qrm5nYkmVhnsOKfIw5TYvpljUB8t/SsiWaPsefY5qN2 L8uSx96QL6CrV7alJJCJKwlyVJBPXvWt9ujEIARi2MdOlZ8MLyNhFJPsK0YdIuXAzhQfU1EnHqFr kL3shGEAUVA8rMPmdj7dq24tAGB5sxPsoq/Bo1pHj91vPqxzWLrQjsUonJopc4QEn2FXIdNu5x8s TY9W4rroreOMYjRVHsKlCHcDjispYrsi1E5m38OTSHMsiIPbk1oQeG7ZMGRnkP1wK3kUCncAc9qx liJvqOyRyWt2dvbRlYY1U4xmufdQOR0Fb/iFwznGeTWDKQq810UG+W7Mam9imwzk1WcYBqxI2Bkd 6bbRG4u4Yef3kir+ZrqRSPUfD1sbfSLVCMERjP5Vp9qs+WFUDGABimNHXztSfPNs6IqyIe9KKeUN IAagoWmP0p/PSmSUICLvR6Uo5PtSjrxWyJClBoxmjHNAri4wKWM5FHt0pVHGKaEOPSo5cbTUgqKb hTR1ApNjcTim+9OPJo4roJGkc1Nbr81RjrVmAcE1L2KOc8RP/pO30Fb/AIEj26YG7s7H9a5fW33X kxPQcV2/g2DZo1rxglcn8a9KgrQRxt3m2dInTilPWk6fSnAgmtwF+lOHvRt4zSqOKAENRO2OtTHp VS4YigDnfG0+zR5AP4mAqn8OoiLOaU/xvgH2A/8Armq3j2bbZRAnALcjNbfgmHytEt89WG78zWNV 2iVFanSr0oagUMM1yFiUUuOKOlMQmKQ07FIaYDGFM71IaYaAG96SjB/CnCgQ3HNFOooAbS0UvagB KQ0vWmmgZG/FV2qw55qBqYDaO9BPFM3c0AOpppc0NxUjRC/SsnVnxbtWrJzWJrZ227U4ayRR5D4g ffqUp96raSu6/iHuTS6q268lP+1U/huPzNWhX1IH6ivTlogWx6hBldEiXsXJq1owBv4gxwPWpdWs BZ2VpFk527/qDR4ejzqAPJUAnp04rdfwjDqSpiXxGoH8KV2OhwBtbt5B2Vv5VyOkgSa9IcfdUD+d d7oUYW/Vh2Q15ct2W9zqUHFP4A4NVbi5jtot8pwKradq9vfh/IblexrW6S1Fytq58qktM5L5zimz wr5h3ZP41NNuZtw5BoMTuFPHStrjuiBVRRwoFO+lTiEfxEmnKig9KXMhOSK6Ru/3QT+FWY7GVuuF +tWITitCEBqhyfQiVRooxaaP4mJ/SrkVhGP4atqvYCrcUXAyKzcmYuq2U47ELyOKsLE6j5WIq4q8 U4gdKh6k+0ZWWSZe+anjuWAyyke4pODnavPbNORSRg9azcUzRVmixHcRt/Fz6VKWXGQapNCG7VGI pEzhuPSsnSRvHELqae85AUDmmSOdjnOMDpTrXY0Y7kVHqb+XbtjHNYyVnY6IvmOM1eQm5xnpzWXO cirV8++5Y++Kqvjnd+ld9JWSMJ6yK0igAetaPhOD7R4jslA4V95/Cs+fqBXT/Da383WppSOIovyJ NaVJctNyLij0duaaBTyBk0hyK+cOobijZTwKcBTAhMfFQvETmrpHHSmhacQKG0qeeKTFaDxgjBAq s8WORWyZFiDFKKUgikpgKOacBSCnigQmMVXuDxirB4FVLjr7VUFqJkIFIaUUVsxIbwMZOMnirSfL CzH0qlPAJmiLEgo24YNWrg7LNyfSokN6I4zU23ySn1Jr1Dw/H5VjAnTagH6V5a6ma8gj6+ZIo/M1 63pybYlA9K9eCtFHFDqy6+KaopXqAkhuKssuLyKXNQxE9CakPvQIDzVW4GFNWOxAqC4+4aYzzr4g Pulgh68Hj1zXe6PB5FlDGP4EC/pXB+KB9o8U2MIH8cYP03ZP6V6NaDCCuWu7JIuJYAowc06g1zDG ijFKaSncQdu9JSnrSUwGGmGnmmmgYyjtS96TNMQUmDS0UgDGKSnZpDRcBpOKaac2KZQBFIecVCzV LMfSoKYCE55pKX60lAxRwKQmjNJSYIjeuf8AELbYH+hNdA/Tk1y3ilwtrMc9FNVS1kimeQ3zbriQ +9bfgWLzvEEAPI3CsG4OZWPvXXfDa3J1uF24BORXoVXaLBbHqvjOJo49PcH5Nmw/UVT8P5ja4ueq pGc/jWv4250y2U8sH6+nFZNoGj0O5H3WYgfUVopXooytqO8OES6pcuvdh/IV6FoaH7Ux9FrzzwMu 6e6J7PgV6ToKN585PTAxXBLWTB7mne2kd3B5cmcdiKqWOmRWTu0ZJLe2K1O1RE81o0mtQu1ofKUa r5ih87c84qxOIlmf7OHEJY7PMxux74pXG3gDFBxsGRkirvdGdyI4AIwMn9KaOaXGTxVmK3yuSaQE MS8itK27VGIQuMDip1jORSbIauW4nAPTt+dWQ58vIx+FVIlwcnpU6bR7/WodjNxLaHco5zSEMW4A xTFkGBjtUgfIqCLNCpHtGScmnqB9KjVueKcGAGScUC1JByelP2iqj3sKcZyaryaqgHyjNIaTNIDY dynBqnq8+6DaOtZ8urnHAArFu9SLk5JY1Lo8z1OmnKUdiFoZGkJI6+9Ma1buRUf21s8AYpPtT9Tg +1dCjYv3hZbUH7z4/Cu0+GtqsVrezA5LSBM/QZ/rXNWGlX+o4ZV8uI/xvwPwruvDtqNJ037NuMjb i5bGOTWGKf7txW44VYxl7zN0gGk25/Cq/wBpx/C2PpS/a1HVW/KvH9lPsdH1in3LIFKBVX7an91/ yo+3L/ckP4Uexn2D6xT7lvHWlVeKpfb06bZP++aVNSgH32I+oqo0prdDVaD2ZeZc1Ey0R3kEn3ZF P41JuQ9CKfK0VzIrsgYcioHiI+lXSB2ppA7U0MpKvenAc+1WGjB6Uwx4PTNO4iE9KpTEljir0gwO KpOMtV09xMixQafj17UhHFaMSBBlqj1h9li2PSp4xWZ4ilxCqeppRV5pCm7RbMbR083XrJewYsfw Br1i1AVAK8w8KJ5niFSOiIf6V6lAPkFewjlhsP603ZTwKG6UyhFGMGpDzTVIxThyOKYDAMVBdcJV hxxVG9k2r83TrSY0cHGPtnj09xDk/kMV6NbD5a8+8If6R4j1C5P0/M16JDjFceIfvWLjsTAelBFK KD0rnuMZR3paDTuA0000+mkU7iI2FNpzU36UXAMYpMUtJ0p3ASl7UZ5ppOKLgLxSUgNFFwsRyZ7U 3NSkVG4wDSuMikPNQOcninTNzUBYdKpCF3c8U4VCWGeKcj9qYEmcnijr0oHNLUsaIpOhrjfGL4s5 /pXX3LhUJJ6V5/rE/wDaF7J3hhPT+8a1ofFcHsedmCRpgGRlBPcYrvPh2gOtxYHyg4rm9UP+ktXW /DCPfqkZPQmuurqtR9D1PxHZ/atPj8tvnVxxWHbw+XpcrMTkOQRW34jlIstqNhi4wfpWQC0mjsn3 pGy2AK0takkzNbkXgMAtcMDnMhP616Zo33ZSPXFeb+BI/LifPUkE16XpABtXYdC1ce8mD3Lc1xFC B5sipnpuOKYHDDKkEetZutaW184IwQB0LY/GrFpbta2YiLbio61pLsDSsfM7vkdaSFDISF7dqvtZ x5+Y4ojjihJIbPY0cyMLobBbAKSRz61ZjjA461GblFGAP1phvlHcCpcmxXLgUdhTsADrj61mPqA/ vflUD6hnoM0tQsza3qOrCk8+MD735VgtfsewqI3rUWYcsjo/tUYPGTR9uTH/ANeuYa7c5+b8qYZ2 boSSe1HKx+zfU6htQC8jA96pXGqZyCxPsKzIbG/uOY7aZh67cVeh8N6g/LiOMH++3+FDSW7FywW7 KM1+3UcVA107dWNdDH4Tz/rrwD2RM1di8M6cg/eNNIfdsfyo54IftacTizMxPJNXrDRb+/8AmihK Rn+N/lFdna6Xp9owMVsu4d2+Y/rV8uW70nW7Iznif5Ucvb+FI48G6uSx7hBj9a14NNsbYDybdPqf mP61dbmo3PoOKhzk9zF1ZS3ZIkhXA7DtVmOcHqcVS3Ac0mfSlYhxuayyZHFLnNZiSMvOatQz5PzU +UzaaLgANKoyaahyKkWlYjmYoQEGmGFT1qYe9LiixSkyo9tGR9wflUJtQPuM6/RjV8njpUf1NKxo qslsU9k6fcnk/Hmm+bfRkkSq491xV/b3ppj9RS5F2LWJmupSGo3iHmFG9SDinf2yQMS20o9xg1Ya Ic5qN4lxyKl0oPoarFyRXk1m1IO7zEP+0hqKG/tp2IjkBPpT5bdSOazrjT0bJwDTVGBtHFN7mtkd qYfesAi6tz+5mYD0bkVMmrSIAtzCf95Of0qZUH01OiNaLN2P+Vc54gm3TqoPQEmtIaraiBiJBux0 71zN9K1zMzqCQenFOjSlzXaKqzTjZG54DXzNVuJP7qAfrXpsIwtebfD1Hiku5HU4LAA/SvRYJFKV 6KMkrIsYphpVcc01jk8UANPpU0fSotnORViNcLxTAY/SsbWH2wSMeAFJrYk4rnPFEhWwuNp52ECk xowfh4gc3svOWkA/z+degQjArhvh5tXTZiuf9cck9zgV2kco6V5eJqJVGjaMdC1mkJqLzB60nmCs PaIfKybNJnNReaKXzBTVRByj88UhPPpTd9NLVXOKwjHnmmZ9KR3qLdg0c4WJiaSog/NOD+9HOKw/ pTWFGaM1XMFhBkU4Hmm9T0pQMU+YLCk4qGU8E1KRioJjwaExFGVvmNRE1JIOeaZtzitEwGY55pVO CKeV56UxlqrgWEPFKxwKZGcDmo7qYRxMxIwBWfUaOf8AFOpPawbIuXfiuaZAsSlByTkj1PvT7idt R1VmJ/dx89enpRNGM8HLEZyeK7KUbEyZy+sqRc89xmu3+FUZOoQEDqGNcZr67bhM+ld/8LUEc6SZ xst2Y/5/Ct5q9kN7HTeI7ozXAgTOIWOT+VUL64+x9HKkJ29cU5X864d25LsTmqHiKIsZDn6VrXWi RnE6PwhH/o249Tj+Veh6SNtgnuSa4Pwv5nk7HABArv8AT12WUC99tcMdWBZPSq0xxG59qsMQBzWf qMhjs5mwfunmtGI+br+6CzsozjNV7nUYjZRQQ2yJIrEmYE7mz2POOKrak3+kNVF3ohtYmMUkWDK7 ITu6VHv96hz2ozVWLsWF3SEKgLH0AzVyDSdRmGUtZAD3b5R+tb/gCFFhuJ5MbpCFXPoOtdHdQshz yVqJvldkc9StyuyRxtt4Yu5ADPNFEPTJYitGDwvaJzPPLJ/u4UVsbsdaXd05rJzkYuvNlOLRNMj6 WwfH99iavQRW8HEFvFH/ALqAUm7JyKTdUO73M3KT3ZY3k96buG7moNxBpRJRYmxMGxg980wmmlqT OSKLDHbj3oDcU3IwRSdO9Fhkm4d6jbmjOaXrxTSERkc0o9DSsOaTjNWUmOB7YHFOU4OaiyAeaN3p QDjcvRTEECtGJ8rxWHHlpFBOAT1rTt3KrgmkzOVMvL9aevJwMZPqcVWWSpA46CkRZiuDTQM0u7IN G8CgVhQPWgjimlxxikDZ60CFPp61CcZNSZ9+KiY+lOw0hsnSqzjIqWWQLVV3Z/uD8TTRtBMguEUf exVRoQ/bj1q46oh3SNk9eelUriaRuIE/E8CqSNo36EEsESEkgHHeqM0qAERqWI7KM1dNt5jZmcv7 DgVYjiRBhVAHtWidjS3cn8M6pFp9mIpwdxZmOPc10kHiOzbA3EfUGuZAFBjjYcop/Cq5/IvnZ2K6 1Zt0mTP1qeHUrdukin8a4NraI9Aw/wB0kVGbYjOyRvxAp8yHzno7XSvgRuAc9RVqK4G3BbmvMrWS 7tdwhkX5jk1KurahEeWY/UA/yp3Q+c9Fmk7jmuQ8V3LtZTLEpLkgACqcPiK5zh0DfmP51S1TVZJ1 YImM+tND50XPAjSJYzrKxLic5z/urXXJJk1xXgrcI7xWOMzbgSeuVH+FdSNw6fpXh42k5VW0d1KS 5TQ8zI61Gzn1qskhHWn7s1wckos20ZMJj604T9Oaqn1ppPPWnZisi759BnqmDS5J6UXkHKiw0oz1 oMgxVJn560CT3pqckJwRaL4705ZBVMvSq5zVKoxciNANShqpCXFOMtNViXTLgalBqksvPNSrLxVq sieQs5qGTJpd/FMdwRxWyqpkuNiMxg9qQR4PA6U/dRmtVMiwzbUUiA1OSKidhk1akFiE4Gc1ynir VfLRoE6nqa6e8kEcLNnoK8v1q4Nzenn7zYFa01fUDS0+FFtdxGHkXcevNOEZ3biMA9DnFWSuzakb FUUAYppUblZVJAPPHWu2C0M2zmfE6KJIipznPbpXceBV8u0ucEAm3Rfz5rj/ABTHt8gYI+boRjrX b+D4gLa6B44VB+AxWvVDexuaRZ75lJxjr1rF1t/Nv44xk75f0rtdPiSKPezAYUnpXGSgXHiCAYxg ljRXlpcUTs9BXNqpUDePlNdjbt+7UDsMVxGmbo5YI0bBaTDV2akqmT2rijuImlbjNV9bKx6DOzf8 82P6VWe8kd9qQMRnqTiqnju6Nv4Tu3bCnyGwPwxW8I80kgW583aof9Ias9sntWpfRKbls8/U1XCc YC8dKcFZHQqDW5UCOx6U8QuRyQKnK7etScbao1VGPU3fDJZNOj553nH512dpciRQsnUj8K4rQDjT 4/Uu3866S2f5eB/9auaXxM8fEpczNC7suC8fQ9qzGBUkc1pw3RQBJG+X1p9zbpMu5Op5BHepOZaG UG596XNE0TRthhUYODzTsWSFgRjvnrSbumaTig9COMUWAepye1LuqPODTd4XrSsFiYYNA696hMoH Sk870zQHKyzwPWjIA61VMrdxQHJoHyssM9R4LH5aYD608EZFA1GwgqSNSzAjj3oXBPSrUYwARRcd xYkVRxU7cZGR+BqFsq3OcijdxyetICYNjGKUSYquW9qQvRYLFrzR3phm57VXbAJ55pMj15p2FyIs icjgGjzjVby2PYge9IxSMct+Ap2E4RLhmwuW6HpUEtwTwn5mqjTMeFHHbNQneTliTVWKVNIsGZVO T85qKSdnGB8opg60uPWmXyrqMOScnk+9LjvkfT0pcDPFKOKCtBmM04L60uMUoPHFAXGgU4D2oFGM jvTC4baMcUuMg+tNmlSFC0jYH6mgBcVFPLHCuXPJ6DufwpqG4uf9WvkR/wB5h8x/CrMFnFEdwUs/ d25Jp3tuJyS3KrkmLzGUovXntTVtXlYbgVj/AFNau0YwRTgBRzMzcytBaoGBA5FWREwPyyOPoacv HSrMZB61m9TGVWSK6/aFPE7/AI81Ok9ynVw31FT7VPSgxj0qXCL3QLFTXUZ9tlxyqn6U03sgz8n6 08x00xjFR7CHY0WOqLqNN84/gqRNVZRhosj61EUAppj9uaPYQ7FrHT7j3v1ds7GWkjvIyeWI+tQt HTGjGelS8LBmkcdMvm6iI4dfzpVnU9xWU0IPamGDNZvBxezNo499UbSzA96d5wz1rAMDL90sPoxp oSdTlZpR9Tn+dQ8D2ZpHHJ9DohJzwalSTPeuaW4vE/jVvqv+FSx6jOuN8QP+6axlgpdDWOLgzo/M 96Qy1hjVgPvxSD8M0+PU4XYLuKn0YYrJ4apHoaKtCXU2BL70okz0qgs4YcEH8akWQetC5olWT2Lm +mOwxUPme9RSyYUmqU2LkMvxJerDaMu75mridJg+26mC33E+ZjVvxPdmS5ZQ3AqbwVZSXL3EqAnG Fr0qS93UykrI0XiBYc/LjOccikZAFBJU/QVoSabOH4RsDqM84p32V1C7UO8dO4P4V2poxucr4ghD xW3fMg56123haPdppZeC0h49ea53U7U+TE7KQySLwRj1/wAK6/wlAf7HhOMFjnp1Gf1rVbob2N2X fBYylugXHNclo6+drUjg5Cptz6Gus1dhDpzIx4bmuV8KKMzyernB+lZ12PZHVaWobVolPVAWrrzI NvFcdotvIt39qkbPmZCrjoAa6gHgZrlW4mP3APkda5T4rXQXwnd7jjKADHqSK6VpAprzz4x3RXw+ Yxn5pFH8zXRR+NAtzy69cGZqrggOp9KmuxiZuKrPnk9q6VTSG8RKQrnc3WnZ2jpmmR/N+dPkBVDi q91aGbk29TodGgcabCRjkbsfU1pw+YmMg1V0g7dNth/sCtBDzmuOdNczseh9Rp1IpjzMSMEYqa3u 3iI43J/d/wAKIyCD3p3koe2D7Vh7Np3RhPK5L4Xcvv5V1HuU5z+lZ01u6N0zT443icNG5Ht61aE2 5fnAB9KLM4amBrU9eXQzAj88c+9O8iVvT860DsIPQ1GYgelPU59tymLZz1dRS/YyQcyLV5rCYIHB BU1WaORSQTSGn2IxZ/8ATRcfSlFkCSfMH5UhZgKYZGHegolaz5z5gxQbPA/1qmoTK3rSeaf7xosG pMLZs/eWl+zv6jFQecfWgzsO5o5R2JxCy9cYqVfMXtVTzz6mnI0zj5Tgepo5RFoM3cGlCs/QGlhi YkeY26rRmjhG0/XpRaxm5pbFc2znrgU5oR1eTmo3vDNcxwpn5uSfapGs93O4mnYlT7kbNbx9fmNR S3hTiGDI+oFPNmwzjmozAwHIzQaR5e5We8lb76SL9Bn+VRrNFnlsf73FWypWkKg9VFO5orEYIPT8 xTs5pjQRE52AH1Xg/mKZ5JU/JK49jzQBKOaNvcVEfPXpsb9KBKy/6yJwPVfmH6c/pQFiTBpKQXER OC4B9DwakBDDg5pgN/lQAaVgACc4HqarG6T7sW6Vx2QZx+PSmtQLHXrxUU9xFD99vmPRRyT+FR+X dzn5iIE/2eW/PtVi3s4oeVXLHqzcsfxo0QXS3K6farg/8+8Z79WP9BVqC0ihO4As56sxyTVjZxSA c0m7kuXYeoHalxyRT0GAKGTvU3Mmxg44zTgeKZkZGBSjd060wHfSnqx70wc0lBDVy2kvAHep1kzW eDUiSYoMZwLpOTTTUKyU7ePwoMrMUjNJ1oBBppPNMYn1pCKdx9aMUFXYwr+VG2nUde9AcwwoOtRs vNTZpp69qC1Ih8vrTDEPSrPWgj6UD52ioYhUUkAOfSrzAUx1FFilUKAhZPuFlHtT0uJ064b9Kssv FRsue1S6cZbo3hXktmOTUBwJEZaW5ukNu5RwTiq7Jiqd5DujbAw3tWX1WLeh0wxktmcfqche4cnn Jrrfh7OIdOum6jzP1wMVw98ZEmdWyea6DwLfQxtd21xwZACmTjmujktY6XLmR2ZvZhNIXBHBQrnG PelDFMpycDO5W6VChDQyHGMEEEjJqHzDj92T6Ed8da0MhmuuzGCMkhBlwp69Otdf4QhYaXbsvCgZ JHUVwWqSMbgIUCyiPbgdeTx/WvVtDiMVhbx+XgLGA4HynP4Vre1i0tDn/GcrxtGMEKI+fesfwkrN p0SoCZZSdo/rWt46QrYecq/dJUk9we9Hw6VF0lbxlwdgjXjpjr+ZrKvumPodJbo0U0MbdEXAxW55 RZA3PTNZYJkl3uMEjFa0Luq7T3HesVa4inKg64ryf40XGLO2iB4eUnH0A/8Aiq9enAEZY8fSvC/j BciW8s0Vs4DsR77iv/stdNBe9ccdzn72L9+2aqSDAIxVzUbpWuCyoeR0rOlMkh/upnt1p3b3MIpk kKHcRU0yERnI7VSNuByMnNPNscZDtj0zTW5bjqdRYHFjb7ePkFW4pWz2qDToGaxt8c4Qc1MEZT8y 4Nd3LTmc6xNSm/dkW45atRyKR1FZ8PXrgVOOT/jUPCRex1U81qx0krl9W/GhxxVVGIxtPSnGVhWE sHNbandTzelLSasSEYHB5oDup9aQSgKcrgHvShlPTqa55U5R3R0qWHxC6M2tMuVlgMTKdwpsqIW/ Ss61cxTK68EGutbTvtVulxGPlYZ+hrKS6mM8poz1joczLbIe3Wq72S4yoNbF1bpbk7pAPbNUHvIl bHXHpU8t9jiqZVWh8LuZ0tsy/wAOagaIj+E1qPcRyD5R+dRGQHkjiizOWWHrw3iUFhbHSnCA9+Kf NfRx/LsY/hxVOS/Y/cAFLmSMHz9rF1IlU5qbeijg5+lZS3Bk+8c1ZVyeD2qk09jKd1uXTMcfKNop szfJk81Gh45pZ2AQ5z+FSY9SjuIv4djFSxwceldAA+3qDXNQtnU4Bn1P6V0itx7Vo9i5aJC5YYBH NK5AHI/SjPGM80h6EHvUEpibY27U1rdCODTSCuSKQMyt7n1osaJvoxr2XXBqJ7Rx2zVkTsvUZFPW 5XP+NFiueSMx4XGeDTAjZwc1tB0YYyKeIomGStGo/bW3RhmIMMMAR70n2KPqoKn1Q4rXa0X+CojF tBzSvYr2t9jN/s+MvukLyDsrtkCrKwKgwoAHoOKsFQKTjvRe5Lm2RlODjik+tSnpTHHFCYuYbxSE YpO9BqgFRsGnGTIxUfX6GkI+tKwDz+H0oHTrxTeR+FG71oAd60A03OaUn5aBC54o3YqItj6Ux2Bo C1ycS4NOMu0gMCM84qmTg0B+DgmmL2Vy6bgLxnmnCdTxnms4n0pA34UyfZGoJRT94PQ1k+Y3anrO RyaCXSZp59KCaoLccU8XIosRyNFsnH0pM8VB9oU0eaM8dKLCsycGjORUPmD60hkGODQFmSls00n3 qIyAdTULTjqaZSiy0cUwketVJLoDpmoJLhmzg0GkacmXXdR1qrPLHyFbIqq7k9SajY0zaNO25n3+ mx3EhcHaT1rLu9KaJf3cgDetdExCgk1mztulXPTNXFXOmLaOble/tRu+1ygdOHNQx6zqMahY7uUD I43UutzAybFPTrSaBaG91KJCMop3N9B2raT5Vc6o7anUWsV/5ttJL5k8rYkkc8854H4CvbtM8XaJ dRpFc2dzbyEYZo2yM+vNcFZRiLYzpuHfmr0lxarDKApU7ThvWoi76sQ74k6vZyW/kadI8oOBucAE k8DOK0tGdLTT7Kzi/wBWiDcQc5IHP615tfs1xqcEZGNvzn+lddoMhX5j1JrLETWgNHpcU1tJFHJH z/eyeRVuK8tnID5B/wBmuK+1bBxketMe9ccqSD71kpEHc3rW627GOXdx0YYr52+K8U0PiQCZdu+J ZFA9Gy39a9Qn1dxbMH7CvE/Ft/JqGszySOX24Rc9gOBXTQmtS4bnpnjT4Wa1o11bi1T7eLgM0YgU lwq9Sw7YyPzrg7nT7uzmeO4RoCvVJEwQffNfX/jWQJdRwqQWjXb9AOT/AJ9hXkXimaK484zoJBjC hxnkn/Cp1WxNrHjCyIrZuMOCMAKAuPeo5ZURjs3bPrXbXHh2xuly8LxMx4aPoPw71QvPh5qqRNJa MssZGQG+ViPpWi7tBct6Asc2lWzow3bfxFaCwM/LDJP61y0VtNpsaw3KzW0q8EnOCf5Veg1C8jUe W8cy+mcEf5/Ck9XdM86pSfM2jbW0XdzHg9KabI5ODzS2muR4UXcLxn+8Rx+dbMEtleR5ikUn1Bq1 VqR2ZzvmjuYfkOhO5ScjA2+vaoDkHB/WuhktCMlTkVVkt+CHXt6VtHFv7SFzGR9KeeR29c45q4bV M8cGontW6qQfbpW8cRTl1KUuw+3Vgy847110moNb+HUhjI3E8nvXJxqUkBKMo9+a0ZpS1rjt9auV GnUjsdFPHYik/ckZdxMXc7i2T3NQYGMjnFOuMjGeM81Aw6H9a5pYNfZZ6VLOJ/8ALyNyQA8kED2q eIZxnpVVWIz830FSLMVxkflXPLDTXS530szoT3die4RTxgGqElnE/wB0bT7GrTSq3U0m3ceDXM6d t0dTjRraqzKH2N1IKMCKlVZFHK5q1yDyKOvQ1KhbY5auWUp7aEKN82DS3Un7rg8VLgHHFRzBQnA5 oa1OGWTyT0kZtkSdTjJBxtNdGG9awI32ahGccFSBWsk2PvZFVI5MVg5wdoq6LoPB7UH7v1qsJlOB mn+Z2zUWOBxa3JcnvimycimbvegnNAIXOTjimSCkyN/elZgfqaDRMaoJIqYZAyrEVFmpg3yUmwbJ bOVy+2Qjb61ZdA3T86pwY5qwsmzjqPSi9zCb10IJI8HpUR59quSYZeOQaqyIRSLjK5Hn1Ioz60je hFNyR1oLBh6UzmpM5pjdOaaYxM5FJnn2pCeaQnNUA4+1Nzgmg0jMOMUABNIWOPYUxjg8UwuaLFWJ GbNR854603JFG6mVyilqN3BxUZpOPegdiQGkzUWeeKVSRnOQaLBYkGMZHWnTytNNJK4UM7FiFUKO fQDgVFmkznvxTCw8nijJxzwaZn1NIWpBYkJ4FG73qPNGTimLlJPMb1phmYHjpUbN6Zpm6gFBE5mL DmmFzTN2BimlsUFKKQ8tTCxpGOTSUFWA5pQPWgYz702RwFwKaQFW5lwSKyp5/LO9j0qxO+Xb06Vz +s3HIjWuiKsbwiZN1IZJWY9zXd/D/S8xxySDDTNnJ7KDXE6fate30UC/xHn2HevY9DgW3syyrjja o9hWdV3aidGyLmp3Iii8sFBk9MdhWDqFxthYu2AfuitBreW8n3zjy19O9c74mlHm+Uh+VcKMVask SLpStJNNcv8AfY4B9q63SlAIAPQVgafF5VtGg7DNdBpSYJJ4FcVR8zBmowLEDNa1tp8cflm6DlWG 7j0rJkO0/Src+tLNbQW7sqhDtzTiu5NjD8UPHC8ywEmIEgE9SK8Xu233MjerGvVPGk8aC68hiYwD tJ715Mxyx9a6aS0ZcD7F8TXLSG7l8wk8qD3Pqfx/rXnV6GlniV49xDBmH1/+tXfakm9SrZ3M3Ppj uf8APrWDb2qNqDMF3jnIA9q0itdSGdpqlppVt4Zso1trM3SgykqgPBxgE461wGr63LczOrtjsuOA B6Y7Vo3c8g6SZQDpnpXK6/GI5BKmdsgzntmtNE79yJO7Ir5d7vHLjhdx3c1htpltPj9z5LHo0Z2k /hW1BYzXVhcXcsnEIH4jjj9aS0JubzgAKOFxQ4pisYp0a9jUmCZZFHG2Tg/mKrTQSWr7rqzkhf8A 56x//FLXbRkG6WEgHDADjrzWhf24gi+c4zwMjr61Dp2V0Q6cWeeQ6jcxHMF0ZF9HGf5VcTXpEX/S 7ViB1aI7h+XX9K6EaTp98f8ASIF3d2X5W/MVXv8AwSY4vMsLx8f885lz+oqGmt0Zyw6ZRs9TsrlV BmQOR0PB/Krwhjk5iYGueutDvLZCLi1EyLgZTn/69UrdjbSEQXM1u4/gc5H5H+mKn3Wc88PbY69I HQ/MMinvErx4ZQPpXLr4g1G1JElr5yD/AJaR8j8utbOm+IbS4hUXbBHbuylB+ZqlzLWLMZUppXIL m1XJ2k/jVJ4ZRzjIHTBroJI4ZgTBIrd+uapSwkDpWkcVUjoyVJmLkgnIozWi0eeGH5iojApyRkHH at44uL3RopdymZCRg9qA+MEHFSvbNklSDUTRNGATzW6nCoXGbTvFkySk9SDUnmLjkYqnuI7Ypyuc jJ4Haolhqcjsp5jiKf2r+pZDKc4bFMun2R8mk3AjoPSq99yBWEsHbZnZHN5NWcSCFlk1BdoPEZP4 5FaWSAKx7Vyt/kd4zx+IrTEwPUGuetQkn7q0OzDY6nJe+7Mk4zS4P8J6diajDr2bmlz6dD3rns1u dcqdKstUmSGRh/gKPtGOuQaZ1pODig46mV0pfDoTeYD0NG+oNgzwSKTYwHDUjinldSPw6lkSetIJ to56VVPmA+tM8w9x9aGjknhakPiibNu2UBxxUpbNUYJRsXtU/mCpsefOLuTbj2qQMrjBqsHB60Fu /emSPkXnGOPWoHGDUhl+XB6mg8r0B+tKxomQHuO1BbjpSvxjmomJ9aC9wYe9RFsZpS471GxBpotI cz4HWmbwTUYGT1prHB61RSiS7sc96aTnvUW4UZosVYl3kZxTC+OePpTT060wmmkOxIWpufQc0zJp M0WCxJnFJn1xTd360Z460wH7qQsKaG4xSUBYfu60butM6c0Z5NAD84oJJ5OKjzmkZqAsOY9elNzx xTMnNBNIaQ4UuaYD1oJpjHZA69KbuyeP1prHikBoCw7J6mq87cMalkcAegqhM5KnmtIopIqXUoSN nPauUupTJKzeprX1m4wuwGsm2ga4mRFGWc4ArXZHVBHS+CrL/WXbry3yJ9O5r0G3k2AIOgGKwdMg S1gSJPuxjA9604G3fjWEdXzMbZfnnEULSE4wK4rm81ZcnCgljW7rspjtQMnmsrQYi4ecjljgU6kr RsJaG9CoJAFblgnIGO1ZNqoJFblmAqsfwFcm7JY6dsGkjIK5Kjjmop2+ald9lm574rQRxHjSf/Rp sdWOK4Cuv8Xy/LsPc1yZXiumHwmsdj7E1EbEKMpy38XtVAeXZWhm4y+QB6+9aeq6jAIArhVPr6Cu O1/UI5JEjgLbVHJ9/b2q0Zsr3kpfziFPzEBQB1/zzXO6xP8AKqP0IwAO1blpcCzuPMPzqF/i5xXM TldQ1dUAYI7bcge9aJbJEWuy/oCyXO+NgWQE7vfjv+VXjCLSbeEIiPKsR+ldvqmiWPhfw5YxJJvn nAnmUjDqDwB/Oud1We0u4BGLgrESGAC52gDoKetxytsZFtunuNyocKckitGacSyN5zEntVNr62s7 NobYsN+dz9z/AIVmWc/mXJwxCk8lu1U+xCOltoUjnjVwU4B6evIren8lkMKvuKhXzj1BrmYZTdXK FpVBIPJPTsKdPdmFDIjYkxgnr0PFRJpaFxRc1IrIxRii7Rxjncap6To1nrF4tvPhldH+/wCoBP8A SsttUkVy5QNKTwW7fhVe01GW21MMrldmSTnHUdP1qVGL0YFrxj4Pg0eeNrGaSNZYfOUBwy4zjH51 yI+2wRMzQLNEDglRg/lXS6tqMt3bxNM5IU+Xz2BOactspS6heTy0yrbfXtmsOVpClTjLdHFtLbq5 aMPaynn5fkz/AEqxFqV/GMpPHMv92Qc/mP8ACrF7bI77UIYAHg1knTyNzAlNpxwaFJozlQRtRa8A ALq1kQ9ynzr/AI/pV63vrK54jlXPp0NciWljPyuHHoaT7RG3+vix7gZp6M55Ybsds0KsMq1MaJsY 7Vy0F0yj/RbqRfYncP1rRi1m6ij+dFlx/d4NLl7GDoyWxpvbq3DLUJtcAhWIB7etS22sW78Sgof9 oVcWSCUZRlPbg1calSGzM/ejuZBgkVezY9Kq3IbbjBJ+lb72+cbTVS8hZFJbgAdTWqxcrWaHGZz8 CMt6rMMDaR/KtDPzFsYHpTIlSW6VOgCk579RVtrQ4+Vh9DWka6+0aykViFb7+QM8kDJpuCmRkgjp zUxt5Vz8pPpimFGzjaR9RWqcJ+Y41JRd4uwzzXHofrTlnBOCCKaV6cVG6sF56GolhqcttDupZjWh u7lpZAelOBqgRg9CR7Uquw6MfxrnlhH0Z3083j9uJoBuTSjBPNUlnbuB+HFSLOpPJx9awlQnHdHd Tx1Cpsy+ORTSvPFQxSgnhhUpcEAdPU+tZ2N3Ro1fiimKSQeCaVZD3FM3Zpc46dKLHJUymhPbQcZF bg8e9Ojn28Mcj1qI9aCAeooscM8kkvgkWGIIJFV5Ae1M5j+6Tt9DUizLnBPFKxw1MDWo7q5WYMO1 MPrVwMj9Bn6Um1TmizML23RTz6+tFWWtx1FRNAwoK5kyuyAknvTGXnip2jYdqjZTmmmVciyQvtSF u9PK5PNNKHtTuPQaW5xSFsetKRj601l+ppjFDenSlycU3FKO9Agp3pTSOaAfWgBSaM0E4PPFIx9s UCDd2pmevNJnJozjpQOwvOeaXoKaW5xRgngA0FWFJFNZsVPHaTSHhSB71ft9MUAGQ5PpRchzjHcy QGPOOPelJAGBWjqSKgwgwPQVkSMdp7Dv61cUOL5thk7ZDCs+5kCRkk9KsSH5axNYuNkYQH61okbx iZN3IZZz7mtvwtabpmuWHypwv1rBhQu4wMsx4rvNMtha2kcY6gZb3NTUfQ6Hoi+hwAPWr9v8oyaz 4zg81aV1AznpSRBmeJpi8kUMZyx4rSsoBDaxp3xzWNZI1/rDSYykddEo+bFY1pa2AuWacg1rN+7g UVSs1+XnirEzEnFYxRDK8jHcOaZfybbbHrSn5mqrqj4UD0FaAefeK5s3QX0rCBz0q5r03mXshJ7m s3OORXWlojZH0vfXt3rt48Xh2zmuYYP9ZOFJUms0RyRSvHeAKw+8Celdd4i+IkPhfQP7C8N21vaO Vw3lDJjHoT3c9zXlEN7cXReaeRmeQ5yTyappJ+7sZs6DU7pI43ERzuHU+lZVhcPHMkrDOOF9qgnZ 0jDSc5GcZqGGRgQzdAc4q4OzuRY6fUdXn1C6GWZuApLHJ4rNv7lIbfaud+7qe3FZ7X7rP5wyoAxh eKgvLw3QaWY7pnbcT0pyegrCrcO25mbKk81cikKx7icA9D61W061+1EgnbGPmY+3pSXE8aXxQH90 pwPYVPMVymhBdFRuk57itnzibaJiIycCQgdhno35frXKm4TyndgQGbCU6O5MkYCsdmRux3o3A1ft dsk8jlWd+ijtnvWLPM4eeXGWYY5NTpIDGyxL05J61n+IJfsssUSZOFyxHqR0o0ENnu3+zeSXyc7+ O1LFqrlzuYk47ntmsKKfa5YglT1FWrWLzixGR0wfbvUso0HuJDIHjzz2FMmuXCMrZBqeyu7WPckq dBwQe9Vr397L+6IwR0FZyugsZ8rZzhhQhITkce9E0JjyMVXMpPyjoBU3EWpo4mAZOG71HG7rnY5G PWkUkKCT2xTA+9wBwSeaWwrJ7luO7lX76K49QanjvIs9TG2e/FUVXOc8H3qMsQ20jOe1HMZypRZ0 dpfTR/cm3j0PNR6vqt00SrHCrH1ZsL+NYCuobA3Kf9k4pbm4kS3Z3Yui84I60+a5l9XXNc0fDs08 mt7b6dP3kZCKowoORxXYNZuOVwfpXnNnqlo06maPao5K4711dhrcT48i7/4C/wD9eqnFsyxFGV7p GuUdThgePWjA7gVH/apGPOCMPVTVxbq0k+/lSe7DFZ2ZyOMl0KbwRtyw59qgkswfuH862fs8UozE 4Pf1qF7WRDjAJ/nVqtOPUOZowJrN1PTIFVnjdSeMV0bRtjDKc/Sq80PPKjFbxxT6otVDB4Hrk0mc cGtSW0jbOBtJ9KqyWbKDsOa3jiIS8i1NFYEZJxzipI5HXHzfnUbI8ecgj2xTVOM8Z7YrRxhPdG9O tUh8ErFxZ2BwQM+oNPW5QjGcGqAJzwaXdnr9axlhIPbQ7qea1ofFqaSyA96XcOxzWdvwB2pwkIVj vIPYYzmsHhJfZZ2084i/jVi8WzSHHsaprcNjkflTxcL0JIJrGVGcd0dkMbRqbSLGBnpRnB4piuDj BFDHnrWZrKnTqLVJkglYU4T46g1CGBoz2oOOpltCeysWFmRuDinHy2HIqowz1pgBQ9SDTsjjnlLX wSLbwIwyKiNvkcGkEjDHWniTOOaLI5pZdiI7ald7dvWojE47Zq9ls5GDTsgH5lNFjKVCvD4omYwZ fvA0hIrVwjHHGKY0EbdhT1Mee26M0exoxV1rNf4SRUZsnJwGwKBqaKjGoyc1opp4P32JqeO1iQ8K KQOpFGUkUjn5VNWY9PkfljgVrKqg4A4qTgcEgUGcq76FGLTEHLHdVlLaNOigVKJE6ZJFI0nov4mi xk6kmPUBTnFIZMdOtQszHqaPpTIuZ+qDCh8njt61jTPnNbWqH9wfWuddsk1pE7aOqIbiQKhJPQVy 17KZ7g+la2tXGxdgPNY0SHqepq9kd1OPU1/Dlp5135rD5Iufqe1dcoAGDVDR7X7LZIp4dvmar4P5 Vind3Kk7sftyciq+pyC3snOfmYYFWU6HHFZlyjahq0NqvzLkE+mKd7ask1vDNp9n04yP9+T5jWpA mW4p80LQKkRGOOlSWqfMMdK4277kp9S/EAFX2qOViM1L91SfwqCQk5q4iGRferL1iQIkjZ6A1pp8 qljmua8TzGOyk5xu4q46sa3PPNQk3XTEnvVfcMUlyczv9aSFSxrtNT0mJJXkMk7F3bnk1dt5dgwe oqjb3ClSUfJNTxbpD8vJ5JqbmRYmk80D5sc889ajafahHfuajdZJcmFSyIPmaobgGFIy7od43fKc kex96dwJZZsgcYq7odh/a+qQ2gdIwxwWZsBfeufac+aO4FSR3ZhBMZIYinYZ0F5dLYT3FtauGQkg OOhA9Kwb6cKSyEknrVKSZmUk9e3NMWXeCOpFFu4FhL15Qilvu9BWxAxSJdxO0ckHvWJYiMXKPcLu jB6f3vQVrXNyU4xkt8x9Kq4midboxh3RtqkjcB+f+FZF/eefcSOwyWGMVYilj/eCUHDjt2NUp7XI LqTjOAM9alvoFis8h2bV5PTp0rSjuxBbeTj5iNpIrNaGaBiGXIAyxHQUkU2ep70XAuLtbkHAHeki mZRuzt461WZxyq8e9Rux4XJxUsC/JIzqQWzVUOqMSaYjEHPpRIDneOg+asmrMZMeVZd3zZ6U+KPD ZBGcVUt23Ak5JzmrCsByxCj1NS0ImnBUKD1xmomICbmOPrxVO81WMcQ/O479hWTPdSztmVifYdBT jTb3Hy3NKW+jVv3Y3N09qgu53/1ckmTwQByD9KpKpOAK39P8MvcWwnupBbxgZG77x/wrW0YlKNjL eBYwWYhWPPl9SB71u6ZBBbaWJnXzZGTdxztFYN9a+bfpa6VHJcSdMKCxJrR1Wzv9HsLddVRY1bhY YzjJ/wBs/wCfwp6PS4zX0nSdQu4zdpKlraZyWfPK9yBUU+vm1lUJL9ohPIZ12tj8KoNrl7NpFvay PiJAQAOMjtWBcyeg70knfUmVOMt0d3ZeJLORuWaJvY1swayzuPJnEi+h5/8Ar15CevNWLSdkkVWl dE9Rzim4Iwlg4PY9sTVfl/fxA89VqVbmxmPzN5ZPqMV5FB4gurSVkWTzY1OAemR681v6V4l+1SKk kR3EH2ziodPsck8DJbHfSWIfmJgw9RVKW2kTOBke1YNvrkSzZicr6qp5rVttdkkZTIsbA9FY/P8A mOKhwaMJUJxGunqKgkgQ/wAIHuK1mvrWcfNlGPYj/Cm/ZoZf9TIrH0zTTlHYi7W5hNadkbH1qBoJ B2z9K3pLJ15yMVXlidCMqRkVtHEyRSqGKcrwRzSbv1rTK5ByM1XkgjOeMfSto4ldUac6ZV3c5yKU Hqac1tx8pqIwyL2z9K2jVg+pV0P3YwcUeYwOQfwqLDD+HFAIzVOEZbo0hVnD4WTiY8ZHFPEwXg5A IzVbudvNJnPTGKylhoPY66eY1o7u5dWZT3Gadnd3qgMGnZI6MaxlhH0Z2081X24l8Muecge1APGa ppI475Ip4m5AIxk1jKhNdDshmFCXWxbDGn+YcdaqrMpGSakEmRgVm4tbnXGrCfwu5MWJNLuPbAqE sKXdzSJnRp1PiVybzG7kZpfP29entUAPtQTkUXOOpllCWysWDcr25NIJSaq4z04yaRTTPOqZTJfA 7lwSnuacHqlvb0o8/HWg4KmCrQ3RfLDA5o3etVFnFSrICKLHK4NblgnnrTc8VGGFAakTYpas37k1 zk0ojRmPat7WH/ckZrjdWuN37pD9TWsFoejho3RmXDm4nZz93PFaOh2v2i9XcPkT5mrPA2jA6V1W jW/2axDMMPJyfpSm+h3P3VY0mfsOtAf0qtvyx9qcrc9aSVjMluJhHCcnHvR4WjMssty2eThfpVO/ cGLHduBXR6Rbi209FwQcVlVlpYTLhJeTJJP1rQtI8DmqUS8iteFNqLXNcluwkijZiqMkDfaYpkbl DnY3Kt9RV+X3qv1NUmSpNFcRSpC/mSbgTkcdPauK8ZS7fKi7kk13V22I8V5n4rn8zUXGeEXFa0dZ Fwbbuc60SsSSOppyqFGAKEOUU06upmp9OeBvCOieOPDEsF9p4g1e0YBruFjGdp6M3Y/lXFeMvBNz 4VkcW2owXlseGXOx8enoau+HvF9/pmpahY2sIEjqIlFuS28A8HPTv1pNTguWPn6o++djkJnhPp6n 3qLWalFim09UYF34hsLfSY7Cytpbd2+aZ5h1YdgfSuba4Dl3XBA79Qa9Bi0qO9t3WdFJwTgqO9YG seEoI4JpUSS2kLsFVW+X8vzpuok7tELU40yjBbvUclxwAKmn0yeMEZDgHqv+FZsqMj7ev0rWMk9g sWhMpQnNa/h/TPtkc1y7ERxjketYv2cpHGzMMOM479ela+n6mtvGkaBi+4ZUdCKrcDo7TTrIlSmZ J8424wAe1ZGrxFL1kXr3YHIp99qYjRvsxwzDDAdvoazIboyPtcncRis+ugh6K7Eqi52jOcdakjna 2QyMu4EYHtV5VWG0BGQT3IqjIw+dG+6/NMVxst2ktuVUY4OfU/Ws2KMIuR+NTzqY0yRgGoYzuBP6 UrjFRWbHOFJp8qktnbnHXHamSOAPRRTPtA3Y6L3NS7sRMBuIVfqfpSsqtCSTxVSe9VUYRDJPBPas m5uZZRhmIX0o5blpM1xcogKQfOR1PYVn3cjyo7SSY2nGzp+lMt7mRbZrdVG1mDFscjHvUKRy3D4A Z2p8qQ0iEEg8VoWFjPeN8iYXux4Aq9Zadb26+bfuMD+GnPqFxfzJZ6RCxzwAo5/+tQ3fYdy1GLHS VBciWf8APH+Fa+m2GpeIhvkzbWXZ2GMj29aTT/D+n6HEL7xHOss3VYc5AP8AU1na54wudQc29qv2 W0HAUHkj3pJX2JvfY6s67o3g+ze30a3S51Ej55yc8+5/oK8/1S/udYu2vNSmMsrHAz0X6CoZZMwH jnrVVJcR4xkZq1FLYpaFu4n8xMEAYAAqjclWCBE2kD5uc5NK1xvO3Az2pzpIiAsvyv0NFrFblJgc 807mQhVUk+1XI7R5eSNq1eht0jTCDB7570XEU7ex5BlxnsueKsTKN+wAALxxU0gXZ0ORSwxl3UKC zHoB3pCIbV3tpjJHtLEFW3KGBB9jQlzcQYMMrr9DxRIpXjBBpu0lQDTTBq+5fh1u6BHm7ZMd+h/S tCPXYyQZldCO4rndpUmlk6UmkZSoQl0O3t9YLLugut4x90kN+nWrsesTYHmxKyn04/nXmxPIIyD6 1PFfXVvjy53x6E5H60nFGEsGuh6SuoWcvEymM+4x+tKIYZhmGVCOxDA1wcOvzLgTwo/upwauW2rW 8uS5ZD7rjH4ilyWOeWFktjrHtHQjHzc9qryIyk7gQfpWZDqMm0GC53r6Z3VbXV2BxLErH1VsH8jS sZ+zkiXAPUZqJ4I2GRxVhdQs5Pvgxn0YVJiN8mEqy9ipqlKUdidVuZxtiAMEUx4nB6ce1aPkk9D+ dMeNlb5gQK1jiJIpSM0hl9aAavnBzx+dNMSMeR19K1jiO6HzFXcd2RilB5J545qVrYfwt+dRmF1z gZraNaL6juhSwJ4FJnBppBU4Of5UgYE1dlIak1syXewA5608Tdu1Vy4J4zilB5PYVlLDwl0OqGNr Q2kWVmB65FPEgPQiqe7HvTc8571jLBrozsp5tNfGi+Tjr3pCR2qmHYY+Y+4IqTzsE8Ej1FYyw00d tPMqM99Czn2496acEVEs6k88U8OPWsXFrdHZGrCfwu4bFx6e9KuR3zS7vpmmhhg0iZ0Kc/iSJA7Y zS+ac81GDxQT+NByTyyjLbQztdnZYPlGSa46Y/N1z6mt/wAS6gEUxJjPeuS3nnk1qtjm9hGh7sXc 1NLt/tV4iEZQfM30rqp2CqAv0rM8OweRZ+c/35en0q3I+5/as1rK5lJ3Y5TjipYxuOBVdTU7OIbU uTy3SnJ2RItjF9r1VVVcpHz+NdUVwQueBWZ4btjFbGZvvNzzWvGNxJPU1xyd2ST2ke5xxxWnjFV7 WLCk1YPTHeoJkyKUfJnvUCDJqWXqajHAJqiSnqLhVYk9BXk2rzedczvnqTivSfEtx5OnTsODtIFe WzfMrA9TXTQWlzamhkf3FpaZCcxrT81saH0t8KtLsvDumX+t6tcwzT3qBIU3q7Ajk7jnisjX7sXe qebLsXfyAvRRU7DQtRRV02eO0bGdsKlRn3Uk5/n71g3lpJBeKszIy5+R0Pyt+HY1Mp8z1JkkdRoB 84sSuc+tYfjbWLqWSSM2qr5bcuB1zW9pCCERunQgZJ6Z9Ky/FqqJLwuPkkg3cjHIrOr0BHmTySST MDxnrUWqpCmwRjLAfNQdyznB25PNJqwj83MbswPcjHFNbodioE8wBDLtU/3hnFQvA0LDd8qk/fXl TUyqDgqeavywCOwVsEyE/pWvM0KxRxmP5GDgDqDTbKUJLuZQcHjNOuLBoofMUkSDk4qiJ2XhxuHr 0NVGSFY7Z5ba6tgUPzKMn/CsG9lG/I7Gq1hqMcKsS2DjG3p1qB33Sbifl6/Wm0TYuSS+YmG5AHHt VNSY1yT9aY96qowQBvpVeYyIFNwdm4Fh6f8A16SHYvTxyxpC8sZVJV3oW/iXOM/TINOvrA29jbXQ ZGWfOEz82B3I9KpJdS3KDznLlRtBJ7dgKSQuyhDI+1eFGelRJO+5aViCQb0+XiqjK4bBGTWhZW0s 74QfIOpPStDyrezYF8PJT5rAQ6PasgaW5jUIVIG7+dJLcw20bLaqpb1zTJDf6pdLb2cTOW6Kvb61 0tjoWmeHoBea7Ks1x1WP+EH6dzSBytuY+j+HNR1xhNclrez6+Y/cew/rWxe63pXhm3az0SJJbro8 vXn3Pf6Vja74yudQzDAvk2nTapwSPeueCpNlljfA5YjkCqt3Fa+4X+oXOoXDTXkrSOfU9PoKj2uc NgkDvSvECfkYH2pyXTQIE8tcg5DDhh/j+NXuVsSxTBlKN1xUCthfemy3RnuDJIDn2wDVu2sWlw0g ZFPQdzQ3YCGOJ53CQIWf2rRhszEB5/zN1wegq18ltFsgDIVz8y9SccVGgJUk896m9wJFp4OeoqNQ e1SKD34pAOESvjmo7iApt2nB7EVbiXpmppLcyGMIMk0XsIzIJJIiZCiS4bDCQZzT4oDLg4Cg1NBF nzVYfx4qyAqDZznoKVx2KkunkgbDmq0tnKiEFD9a1oZcThfQVcZx5ZYgcCk20Bx8qEHGCDUTZzzW 6Ctz5m9AOeDWRcRlJGHoatMCDtTopZImLROykgqcHseCKaRSBSaYCZIbKkhvUHBqxHf3KMCX34/v jP61CBSMvFAnFPc1ItbbgTRZHqpq1DqUEjZEnlt2zlT+dc7xmhhkUWRm6MXsdrb6lMo/124dMN8w rTi1ZwMTQBl9VOf0rzuKR4/9W7KR6HFXbfV7uHjerr6OKTjcwnhb7HfJcWVweGEZ9GGKke1XAKSK R65riYtcDTAzIyr3VcEGtC4u1bbHFM1pLw22RCMg9KXKc8sPJHSNbOoJOD9DURUj1rnft2p2yZYw 3EfqjYrT0nWvMG6a3cYPbmi3ZkSpSSutS7weoFMaGNj0wavRz2c+PmCP6Hg06SzC4KPwaFJxMea2 5lvbHcSD+dRNC47flWm0MqNzkUwowB4OK1jiJIpTMoqy9VNITgAelaeM8f0qJ4I3P3cfStVie6KU 0Usjr2pSw/DripntR0VsEdjUb27r0G76VrGtB9SuZMaW2grkEZ6jvSZx/wDWpmCCA2RSg9sGtNJI pNrVD97AcEmnecxYkgfhTIlLsAGUcHknimnGeKh0YPSx0QxdaG0idZ+xyM1BfXiQW7MGGcUjsFzn PHrXLa7emSQop4FYTw0Y6ndRzGrLRoz764a4mZic80mn25ubuOPsTk/SqtdJ4etxFbtcOPmfhfpX NPRDlO5ru6ooVeABgVEpGeaZIctigVKVlYyZKoJIA5zS3StNcw28Z4GN1OgIDFm6KM1c0GLzZ5Lh h3wKyqysI6GBQsKIvYVetY9zAYqrCuee5rVskwM965CSyRhcCkHr6Up4zTHbEZpozuQSnJpjnCUE 5amXB2pimCON8cXJW2SHPLGuEmbay10XjC487UtgPCDFcvct+8ArupxtFI6YqyJgAvTp1FBNNjbc g9RSn61Qz//Z --NextPart_Webmail_9m3u9jl4l_23050_1180556573_2-- ________________________________________________________________________________
Date: May 30, 2007
Thanks guys. That was great response. Niko 40188 ----- Original Message ---- From: William Curtis <wcurtis(at)nerv10.com> Sent: Wednesday, May 30, 2007 4:20:41 PM Subject: re: RV10-List: Aileron Torque Tube - WD1014C Yeah, I scratched my head on this part also before I figured it out. See here: http://wcurtis.nerv10.com/07Wings/wings92a.html It come as one tube and you have to cut it in half. William http://wcurtis.nerv10.com/ -------- Original Message -------- > X-Rcpt-To: > > I have not been able to find the WD1014C part in my kit. This is the aileron torque tube that's at the wing root. Is this part supposed to be powder coated? Is it longer than needed? I do have one steel tube in my kit thats not powder coated and longer than needed but it is the right diameter. I am thinking that maybe the parts are cut from this one. Does anyone remember? > > Thanks > Niko > 40188 ________________________________________________________________________________
Subject: Re: RV-10 Truck -was 611TT First Flight
Date: May 30, 2007
Tim, Good luck - hope to hear if they let you do that.... ----- Original Message ----- From: "Tim C" <tlc2(at)telus.net> Sent: Wednesday, May 30, 2007 4:04 AM Subject: Re: RV10-List: RV-10 Truck -was 611TT First Flight > > Kevin, only to friends with HB's > > It will be insured for the 'mandatory' PLPD only. Being in the > Experimental > Category 'hopefully' more on how it is built, than originally designed.... > > I will have the data on all of this for a comparison, from the Northern > AOPA > (COPA) Insurer tomorrow. > > Tim C > > > ________________________________________________________________________________
Date: May 30, 2007
Subject: Re: Sound proofing the 10 ?
Use Super SoundProof from Aircraft Spruce, go thick at the front of the fus e and thinner at the back seats. Use Sticky Stuff from ACS to glue it in. =0A=0ARob Wright=0A#392=0ACanopy, looking at a buildus interruptus for a ne w job and moving...=0A=0A=0A----- Original Message ----=0AFrom: "evmeg@snow crest.net" =0ATo: rv10-list(at)matronics.com=0ASent: Mond ay, May 28, 2007 10:04:21 AM=0ASubject: RE: RV10-List: Sound proofing the 1 =0A=0AIf you want the approved aircraft stuff the place to start is a compa ny=0Acalled E.A.R. Quite expensive though. http://www.earaircraft.com/=0AI went the hot rod route and used a product from another company called=0Ab-q uiet in Canada. Much cheaper and the ansi tests seem to have it working=0Ab etter than any other. It is a sticky butle rubber with a layer of dead=0Aso ft aluminum on the outside. See it at the following link.=0Ahttp://www.b-qu iet.com/ I bought the bquiet ultimate in a 50 foot roll and=0Aused it up... .will need another to do the whole inside cabin.=0ACheers..=0AEvan=0A>=0A>> From: John Hurst <johnh38(at)yahoo.com>=0A>>Reply-To: rv10-list(at)matronics.com =0A>>To: rv10-list(at)matronics.com=0A>>Subject: RV10-List: Sound proofing the 10 ?=0A>>Date: Sun, 27 May 2007 18:30:01 -0700 (PDT)=0A>>=0A>>I have been lurking on this group for months and appreciate Everyone=A2s=0A>>ideas, sug gestions, and opinions. Thanks to all.=0A>>=0A>>Now I need to ask for advis e/recommendations. I have searched this site=0A>> as=0A>>well as vansairfor ce.net and haven=A2t found a lot of information posted=0A>>pertaining to in sulation &/or soundproofing the RV-10. Is anyone other=0A>>than Deems & Cu rtis soundproofing their aircraft? I=A2m working on the fuse=0A>>and am try ing to weigh the options, Pros vs. Cons. My thinking is that I=0A>>will add something that is approved to deaden the noise. It's what is=0A>>available that has me perplexed. Any recommendations would be=0A>> appreciated.=0A>> Sorry to delve off the panel discussion topic, but I need to think about=0A >>installation before laying the floors/side panels of the fuse.=0A>>Specif ically, I'm looking for materials like whats available from=0A>> aircraft =0A>>spruce and SoundExproducts.=0A>>http://www.aircraftspruce.com/catalog/ appages/soundproofinstall.php. And=0A>>this link I copied from Curtis=0A>>h ttp://www.soundexproducts.com/information.html=0A>>=0A>>=0A>>Thanks=0A>>Joh n=0A>>#40102=0A>=0A> ______________________________________________________ ___________=0A> More photos, more messages, more storage=97get 2GB with Win dows Live=0A> Hotmail.=0A>=0A>=0A>=0A>=0A>=0A>=0A=0A=0A=0A----------------- ----------------------------=0AThis message was sent using SnowCrest WebMai =========================0A -======================== ============0A=0A=0A =0A_______________________ _____________________________________________________________Sick sense of humor? Visit Yahoo! TV's =0AComedy with an Edge to see what's on, when. =0A http://tv.yahoo.com/collections/222 ________________________________________________________________________________
Subject: Aileron Bellcrank
Date: May 30, 2007
Installed the aileron bellcrank on the left wing tonight per step 2 on page 23-4. I did not have any threads showing on the bolt after torquing the nut. I removed the nut and changed the washer to a thin washer. I now have 2 threads (just barely!) Anybody else experience this? -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=115692#115692 ________________________________________________________________________________
Date: May 31, 2007
NextPart_Webmail_9m3u9jl4l_10375_1180585767_2 NextPart_Webmail_9m3u9jl4l_26197_1180585226_0-- ________________________________________________________________________________
Date: May 31, 2007
In a message dated 5/30/2007 4:09:22 PM Eastern Daylight Time, jesse(at)saintaviation.com writes: so if the tube is longer than it =9Cneeds=9D to be, it will just ride further in one of the ends. And add a little more weight? ;-)) P ************************************** See what's free at http://www.aol.com . ________________________________________________________________________________
Subject: Rudder Counterweight Mass
Date: May 31, 2007
Does anyone happen to know the weight of the rudder counterweight or the weight of the rudder without the counterweight? I thought I would ask the list before taking mine out to weigh it. I was looking at the Vic Syracuse rudder trim mod and wondered what proportion of unbalanced mass the mod adds to the rudder. Best Regards, Patrick #40715 ________________________________________________________________________________
Subject: Re: Aileron Bellcrank
Date: May 31, 2007
May 25, 2007 - May 31, 2007
RV10-Archive.digest.vol-ci
