RV10-Archive.digest.vol-cl
July 06, 2007 - August 02, 2007
use them for final trimming without screwing up the part.
Thanks!
-Jim 40384
Subject: | Re: Final Trimming of the Wingtip Lenses |
Bench sander first followed by file.
Dave Lammers
finishing
James Hein wrote:
> Hey all,
> I'm tryting to do the final trimming of the wingtip lenses to fit
> into the wingtips, and I want to know:
> What tools did you use to do it? File? Sanding? Razor blade? Other?
> For rough trimming, I just used the tin snips, but it would be
> difficult to use them for final trimming without screwing up the part.
> Thanks!
> -Jim 40384
> Text inserted by Panda Platinum 2005 Internet Security:
> This message has NOT been classified as spam. If it is unsolicited
> mail (spam), click on the following link to reclassify it:
> http://127.0.0.1:6083/Panda?ID=pav_49238&SPAM=true
From: | "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> |
James:
I used a belt sander also. Just take your time with it. Go slow.
Fred Williams
40515
From: | "Michael Wellenzohn" <rv-10(at)wellenzohn.net> |
I used a vixen file for the final work.
Michael
#40511
RV-10 builder (wings)
#511
http://forums.matronics.com/viewtopic.php?p=122607#122607
Subject: | Tail cone question |
On page 10-4, I just trimmed the F1010A angle support to fit the F1010
bulkhead. It does not fit between the tabs at the top of the F1010 bulkhead
when positioned 1/8 above as in the figure? It is way off, i keep measuring,
all dimensions appear corrrect. Has anyone else noticed this? I plan to
just trim more (about 0.25" off the angled portion until it seats passively.
The other option would be to fasten it to the aft side with NO
tirmming? Will that mess other things up? Thanks for any input. - Steve
RV-10 #40499
Stephen G. Blank, DDS
184 NW Central Park Plaza
Port St. Lucie, FL 34986
772-475-5556 >>> Cell
From: | "Bob Leffler" <rvmail(at)thelefflers.com> |
Please keep us informed as to what you find.
I'm a little behind you in construction. I probably won't get to this until
mid August based on vacation schedule and the abundance of "honey do" items.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Stephen Blank
Sent: Saturday, July 07, 2007 2:02 PM
Subject: RV10-List: Tail cone question
The other option would be to fasten it to the aft side with NO tirmming?
RV-10 #40499
__________ NOD32 2383 (20070706) Information __________
From: | "Albert Gardner" <ibspud(at)roadrunner.com> |
My Dynon 180 always shows -45F or -46F degrees AOT. I ordered another OAT
probe but it reads the same. This is the OAT probe with the black band that
connects into the remote compass box. Can't find anything wrong with the
wiring and the probe is configured as choice 2 in the setup menu just like
Dynon says.
Anyone else been down this road?
Albert Gardner
Yuma, AZ
Subject: | Re: Tail cone question |
Stephen,
I'll start out by saying I think I built the F-1010A wrong the first time as
I ground the angle the wrong way. The area that is removed includes a
triangular section of one of the sides of the angle, as well as all of the
other side of the angle.
See if this makes sense, when F-1010A is oriented correctly, the horizontal
piece of the angle will measure 10-3/4" at the forward edge reducing down to
10-7/16 (10-3/4 minus 5/32 minus another 5/32) at the aft edge. The aft
edge is also where the vertical piece of the angle is joined with the
horizontal piece. The vertical piece of the angle (and the part that gets
matched drilled with F-1010) will measure 10-7/16 x 1" in a straight 90*
rectangle.
You will definitely want to make this part correct as all four of four bolts
that hold the forward part of the horizontal stabilizer to the fuselage go
through F-1010A. Too small will likely lead into edge distance problems
down the road.
Take a peek at page 10-10 figure 3 so see how the angle is required to fit
in between the fuselage stringers (F1032L/R) and that F-1010B then sits on
top of F1010A so that later down the road six bolts will hold all of this
together and keep the horizontal stabilizer firmly attached.
I hope this helps.
-Jim
40603
> passively. The other option would be to fasten it to the aft side with NO
> RV-10 #40499
o=\o
Stephen,
In step 1 on page 10-4 it calls for an angle to be cut in each end of F1010
A. Double check the top drawing on step one; this may be the cause. As far
as mounting it on the aft side, look forward to page 10-10 and you can see
how it fits the tailcone.
Vern Smith (#324 fuselage)
Date: Sat, 7 Jul 2007 14:01:56 -0400From: sblankdds(at)gmail.comTo: rv10-list@
matronics.comSubject: RV10-List: Tail cone question
On page 10-4, I just trimmed the F1010A angle support to fit the F1010 bul
khead. It does not fit between the tabs at the top of the F1010 bulkhead wh
all dimensions appear corrrect. Has anyone else noticed this? I plan to ju
The other option would be to fasten it to the aft side with NO tirmming? W
RV-10 #40499
--Stephen G. Blank, DDS184 NW Central Park PlazaPort St. Lucie, FL 3498677
2-475-5556 >>> Cell
PC Magazine=92s 2007 editors=92 choice for best web mail=97award-winning Wi
ndows Live Hotmail.
ration_HMWL_mini_pcmag_0707
From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
Subject: | Re: Dynon OAT Probe |
Albert,
I believe you may have it wired wrong. Look at how you wired the resis
tor in line............Read the wiring instructions closely.........call
Eric at Dynon...........he will walk you through it.
DEAN
Click here to find singles for dating, romance and fun
http://track.juno.com/s/lc?u=http://tagline.untd.us/fc/Ioyw6iif6J0ZaI9
GMzulnSwhBxsPqRSBmGruyETgHSpjp4mzV3F9gw/
Albert,
red the resistor in line............Read the wiring instructions closely
.........call Eric at Dynon...........he will walk you through it.
DEAN
http://tagline.untd.us/fc/Ioyw6iif6J0ZaI9GMzulnSwhBxsPqRSBmGruy
ETgHSpjp4mzV3F9gw/">Click here to find singles for dating, romance and f
un
