RV10-Archive.digest.vol-cw
December 11, 2007 - - - - , 20-
      efficient
      way of dimpling skins. It really works quite well. See attachment.
      > Please add your cost/labor savers to the list.
      > http://forums.matronics.com/viewtopic.php?p=151235#151235
      > http://forums.matronics.com//files/dsc03349_451.jpg
      "http://www.matronics.com/contribution"http://www.matronics.com/contribut
      ion
      "http://www.matronics.com/Navigator?RV10-List"http://www.matronics.com/Na
      vig
      ator?RV10-List
      "http://forums.matronics.com"http://forums.matronics.com
      12/10/2007
      2:51 PM
      12/10/2007
      2:51 PM
Subject: Re: Safety-Trim Group Buy
Date: Dec 11, 2007
Bob and or Stein: Sign me up for the two axis model. Jay Rowe #40301 jfrjr(at)roadrunner.com ----- Original Message ----- From: Bob-tcw To: rv10-list(at)matronics.com Sent: Tuesday, December 11, 2007 5:54 PM Subject: RV10-List: Safety-Trim Group Buy Dear Fellow RV Builders, TCW Technologies and SteinAir are pleased to announce a group buy is now available on our new servo trim controller. Safety-Trim is an electronic trim servo controller that resolves the issues with run-away trim conditions plus it provides 2 speed trim operation as well as greatly simplified switch wiring. For all the detail please follow this direct link: http://www.vansairforce.com/community/showthread.php?t=24478 Thank you, Bob Newman TCW Technologies www.tcwtech.com ------------------------------------------------------------------------- --- 12/10/2007 2:51 PM ________________________________________________________________________________
Date: Dec 12, 2007
Subject: Re: AOA Pro vs AOA Sport
As far as I know the only difference is the display, but then I have the 3500 EFIS so I get the pro display and audio that comes with that system. Drop Rob Hickman an email ot go to the AFS forum to confirm.The wing kit is identical for all three versions. Rick S. 40185 ----- Original Message ----- From: "n277dl" <dljinia(at)yahoo.com> Sent: Tuesday, December 11, 2007 8:12:56 PM (GMT-0500) America/New_York Subject: RV10-List: AOA Pro vs AOA Sport Group: is the only difference in the pro vs sport the display? Doug -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=151766#151766 ________________________________________________________________________________
Subject: Question regarding wing root nut plate
Date: Dec 12, 2007
While trying to finish up some of the odd ball QB items remaining to be done, I ran into a question. I'm doing the top side nut plates which receive the screws when attaching the wing root fairing are attached. The forward nut plates all go through the wing walk doubler and are countersunk. The aft most nut plate #19 hole is dimpled. I do not see mention of the preparation of the rivet holes for this nut plate. Should this nut plate be riveted at the same time as the rest, or is it dealt with later in the plans? If now, are the rivet holes dimpled and the nut plate dimpled as well or is this prepared differently? My apologies if I've missed the step in the plans. I've gone through it a few times already and decided to ask the list for guidance before reading it again and reviewing the future steps. Best Regards, Patrick #40715/N690CT ________________________________________________________________________________
Date: Dec 12, 2007
In response to Tim's post on a runaway trim issue. When I replaced the Ray Allen trims recently I had a runaway elevator trim on my first flight after install. I can attest that a runaway trim is not a fun deal, even if you're from TX :>} It ran away so fast there was no time to disconnect it. What happened was I was on climb out and the minute I hit the up trim the servo went to full stops up. I normally indicate about 2 or 3 on my elev trim indicator on climb out and it went to 22. I had to hold full force pushing the stick forward to keep the plane from trying to go straight up. It took a pretty strong push to hold the stick forward, in fact I told the person in the right seat to put his hand on the stick lightly just in case my arm got too tired. The next issue I was faced with was how the hell am I going to flair this thing on landing. As I slowed the plane for landing the control forces let up somewhat, because of the speed reduction, but I still had to keep forward force on the stick until the last minute and I released a little to land. Luckily that landing method worked. I'm not sure a small woman would have been able to hold the forward force necessary in this situation. Boy I can only imagine what a runaway aileron trim would take to control. We ended up replacing the elev trim servo and have had no more problems. Ray Allen said it wasn't their trim that caused the problem but maybe how we wired it. I'm not positive what caused it but if you were Ray Allen what would you say? I think we wired it the same the second time. Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: Question regarding wing root nut plate
Date: Dec 12, 2007
If you are talking about the upper aft nut plate, I riveted it at the time and dimpled all the holes. Dave Leikam 40496 ----- Original Message ----- From: "Patrick ONeill" <poneill(at)irealms.com> Sent: Wednesday, December 12, 2007 6:06 AM Subject: RV10-List: Question regarding wing root nut plate > > While trying to finish up some of the odd ball QB items remaining to be > done, I ran into a question. > > I'm doing the top side nut plates which receive the screws when attaching > the wing root fairing are attached. The forward nut plates all go through > the wing walk doubler and are countersunk. The aft most nut plate #19 > hole > is dimpled. I do not see mention of the preparation of the rivet holes > for > this nut plate. Should this nut plate be riveted at the same time as the > rest, or is it dealt with later in the plans? If now, are the rivet holes > dimpled and the nut plate dimpled as well or is this prepared differently? > > My apologies if I've missed the step in the plans. I've gone through it a > few times already and decided to ask the list for guidance before reading > it > again and reviewing the future steps. > > Best Regards, > Patrick #40715/N690CT > > > ________________________________________________________________________________
Subject: Safety-Trim Group Buy
Date: Dec 12, 2007
What trim servo did you end up with. Was it a replaced Ray Allen? John J 40328 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Wednesday, December 12, 2007 5:21 AM Subject: Re: RV10-List: Safety-Trim Group Buy In response to Tim's post on a runaway trim issue. When I replaced the Ray Allen trims recently I had a runaway elevator trim on my first flight after install. I can attest that a runaway trim is not a fun deal, even if you're from TX :>} It ran away so fast there was no time to disconnect it. What happened was I was on climb out and the minute I hit the up trim the servo went to full stops up. I normally indicate about 2 or 3 on my elev trim indicator on climb out and it went to 22. I had to hold full force pushing the stick forward to keep the plane from trying to go straight up. It took a pretty strong push to hold the stick forward, in fact I told the person in the right seat to put his hand on the stick lightly just in case my arm got too tired. The next issue I was faced with was how the hell am I going to flair this thing on landing. As I slowed the plane for landing the control forces let up somewhat, because of the speed reduction, but I still had to keep forward force on the stick until the last minute and I released a little to land. Luckily that landing method worked. I'm not sure a small woman would have been able to hold the forward force necessary in this situation. Boy I can only imagine what a runaway aileron trim would take to control. We ended up replacing the elev trim servo and have had no more problems. Ray Allen said it wasn't their trim that caused the problem but maybe how we wired it. I'm not positive what caused it but if you were Ray Allen what would you say? I think we wired it the same the second time. Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: Trying to keep the belly clean - Air/Oil Separator
Date: Dec 12, 2007
I have a new Mattituck 540 and had the same issue. I installed Van's air/oil seperator and have been very happy with the results. I have about 45hrs on the seperator and 95 on the engine so far. I had a wolf seperator on my bonanza for years with good results. I have noticed that the oil does seem to be more dirty with the seperator than without. But since I can run more oil in the engine and I change the oil every 50hrs I do not see a problem with it. -------- MARK SUTHERLAND RV-10 40292 Flying since June 07 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=151870#151870 ________________________________________________________________________________
Date: Dec 12, 2007
Yup. That's the one. Thanks Dave! Best Regards, Patrick #40715/N690CT -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Wednesday, December 12, 2007 5:32 AM Subject: Re: RV10-List: Question regarding wing root nut plate If you are talking about the upper aft nut plate, I riveted it at the time and dimpled all the holes. Dave Leikam 40496 ----- Original Message ----- From: "Patrick ONeill" <poneill(at)irealms.com> Sent: Wednesday, December 12, 2007 6:06 AM Subject: RV10-List: Question regarding wing root nut plate > > While trying to finish up some of the odd ball QB items remaining to be > done, I ran into a question. > > I'm doing the top side nut plates which receive the screws when attaching > the wing root fairing are attached. The forward nut plates all go through > the wing walk doubler and are countersunk. The aft most nut plate #19 > hole > is dimpled. I do not see mention of the preparation of the rivet holes > for > this nut plate. Should this nut plate be riveted at the same time as the > rest, or is it dealt with later in the plans? If now, are the rivet holes > dimpled and the nut plate dimpled as well or is this prepared differently? > > My apologies if I've missed the step in the plans. I've gone through it a > few times already and decided to ask the list for guidance before reading > it > again and reviewing the future steps. > > Best Regards, > Patrick #40715/N690CT > > > ________________________________________________________________________________
Subject: FWF wiring
Date: Dec 12, 2007
Need advice on wire runs in the engine area. Is it okay to run the CHT/EGT wires in the same bundle as the lower plug wires as they run aft? How does one attach that bundle/bundles----with Adel clamps to a rocker cover screw, or something else? Can all the CHT/EGT lines run thru the firewall at the same location? Any and all advice/pictures welcomed. Jay Rowe (about to finish FWF) 40301 ________________________________________________________________________________
Subject: Re: FWF wiring
Date: Dec 12, 2007
Jay, I'm not as far on my -10, However, In our Glastar all CHT and EGT cables are bundled together with the lower spark plug wires and run aft together to the magnetos, then the cht/egt bundle runs with some other wires together thru the firewall. 8 years running with no issues. -Bob Newman TCW Technologies www.tcwtech.com ----- Original Message ----- From: Jay Rowe To: RV10-list(at)matronics.com Sent: Wednesday, December 12, 2007 9:43 PM Subject: RV10-List: FWF wiring Need advice on wire runs in the engine area. Is it okay to run the CHT/EGT wires in the same bundle as the lower plug wires as they run aft? How does one attach that bundle/bundles----with Adel clamps to a rocker cover screw, or something else? Can all the CHT/EGT lines run thru the firewall at the same location? Any and all advice/pictures welcomed. Jay Rowe (about to finish FWF) 40301 ________________________________________________________________________________
Date: Dec 12, 2007
Thanks Bob, I'll follow your lead. Jay ----- Original Message ----- From: Bob-tcw To: rv10-list(at)matronics.com Sent: Wednesday, December 12, 2007 10:11 PM Subject: Re: RV10-List: FWF wiring Jay, I'm not as far on my -10, However, In our Glastar all CHT and EGT cables are bundled together with the lower spark plug wires and run aft together to the magnetos, then the cht/egt bundle runs with some other wires together thru the firewall. 8 years running with no issues. -Bob Newman TCW Technologies www.tcwtech.com ----- Original Message ----- From: Jay Rowe To: RV10-list(at)matronics.com Sent: Wednesday, December 12, 2007 9:43 PM Subject: RV10-List: FWF wiring Need advice on wire runs in the engine area. Is it okay to run the CHT/EGT wires in the same bundle as the lower plug wires as they run aft? How does one attach that bundle/bundles----with Adel clamps to a rocker cover screw, or something else? Can all the CHT/EGT lines run thru the firewall at the same location? Any and all advice/pictures welcomed. Jay Rowe (about to finish FWF) 40301 ------------------------------------------------------------------------- --- 12/12/2007 11:29 AM ________________________________________________________________________________
Subject: NACA Vents
Date: Dec 13, 2007
I'm just finishing up my tailcone with wings coming in January. For those that have use a NACA vent to provide an air inlet for the overhead console, would you recommend installing them at this stage. My assumption is that it would be much easy cutting the holes prior to riveting the tailcone together. My second question is has there been consensus on the best local to place the vents yet? I'm also just starting to start looking at NACA sources. Van's has one for $6.25 and ACS has several, but all are over $30. I was caught off guard by the price differences. There can't be that much difference in quality. Thanks, Bob #40684 ________________________________________________________________________________
Subject: Re: Safety-Trim Group BuySafety-Trim Group Buy
Date: Dec 13, 2007
Yes it was a replacement from Ray Allen. Wayne Edgerton N602WT What trim servo did you end up with. Was it a replaced Ray Allen? John J 40328 ________________________________________________________________________________
Date: Dec 13, 2007
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Re: NACA Vents
Bob: I bought the ones from Vans'. Order them when you need something else. I waited until I had the top on to cut the holes. Made up a template of the NACA hole before I installed the forward vents. Then just traced it on the skin and used a nibbler to remove the majority of the aluminum. File to do the rest. I placed the front of the vent 10 inches behind the rivet line of the bulkhead, centered in between the longerons. No science involved. On accuracy's web site there is a reference to them working well. You can wait until later to install them as the top skin will be off until you are ready. I have more pics if you need them. Fred Williams day job getting in the way of building. Bob Leffler wrote: > > Im just finishing up my tailcone with wings coming in January. > > For those that have use a NACA vent to provide an air inlet for the > overhead console, would you recommend installing them at this stage. > My assumption is that it would be much easy cutting the holes prior to > riveting the tailcone together. > > My second question is has there been consensus on the best local to > place the vents yet? > > Im also just starting to start looking at NACA sources. Vans has one > for $6.25 and ACS has several, but all are over $30. I was caught off > guard by the price differences. There cant be that much difference in > quality. > > Thanks, > > Bob > > #40684 > > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Subject: NACA Vents
Date: Dec 13, 2007
Thanks for the quick response. The picture was very helpful. I'm assuming that the tray attached to the bulkhead is for your ahrs? Out of curiosity, what's installed below the naca vent on the left side? I know the feeling about your day job getting in your way. I took today and tomorrow off to work on the tailcone and I've already received a half dozen calls from the office. Time to unplug the phone in the garage. :^) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Thursday, December 13, 2007 9:38 AM Subject: Re: RV10-List: NACA Vents Bob: I bought the ones from Vans'. Order them when you need something else. I waited until I had the top on to cut the holes. Made up a template of the NACA hole before I installed the forward vents. Then just traced it on the skin and used a nibbler to remove the majority of the aluminum. File to do the rest. I placed the front of the vent 10 inches behind the rivet line of the bulkhead, centered in between the longerons. No science involved. On accuracy's web site there is a reference to them working well. You can wait until later to install them as the top skin will be off until you are ready. I have more pics if you need them. Fred Williams day job getting in the way of building. Bob Leffler wrote: > > I'm just finishing up my tailcone with wings coming in January. > > For those that have use a NACA vent to provide an air inlet for the > overhead console, would you recommend installing them at this stage. > My assumption is that it would be much easy cutting the holes prior to > riveting the tailcone together. > > My second question is has there been consensus on the best local to > place the vents yet? > > I'm also just starting to start looking at NACA sources. Van's has one > for $6.25 and ACS has several, but all are over $30. I was caught off > guard by the price differences. There can't be that much difference in > quality. > > Thanks, > > Bob > > #40684 > > * > > > * > ---------------------------------------------------------------------- > -- > > __________ NOD32 2721 (20071213) Information __________ ________________________________________________________________________________
Date: Dec 13, 2007
Bob: It's the power supply for the strobes. Whelen (sp?) . Vans has a plate that will let you attach it to the stringers. Dr Fred ( in between patients) Did get the brake parts painted this am. ________________________________________________________________________________
Subject: NACA Vents
Date: Dec 13, 2007
Sounds like a re-alignment of priorities...so irresponsible for a grown man . In between teeth, and wishing I was a kid again with a really big expense a ccount. John> From: rv(at)thelefflers.com> To: rv10-list(at)matronics.com> Subject: RE: R V10-List: NACA Vents> Date: Thu, 13 Dec 2007 10:46:24 -0500> > --> RV10-Lis t message posted by: "Bob Leffler" > > Thanks for the q uick response. The picture was very helpful.> > I'm assuming that the tray attached to the bulkhead is for your ahrs?> > Out of curiosity, what's inst alled below the naca vent on the left side?> > I know the feeling about you r day job getting in your way. I took today> and tomorrow off to work on th e tailcone and I've already received a half> dozen calls from the office. T ime to unplug the phone in the garage. :^)> > -----Original Message-----> F rom: owner-rv10-list-server(at)matronics.com> [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Fred Williams,> M.D.> Sent: Thursday, December 1 3, 2007 9:38 AM> To: rv10-list(at)matronics.com> Subject: Re: RV10-List: NACA Vents> > Bob:> > I bought the ones from Vans'. Order them when you need som ething else. I> waited until I had the top on to cut the holes. Made up a t emplate of the> NACA hole before I installed the forward vents. Then just t raced it on the> skin and used a nibbler to remove the majority of the alum inum. > File to do the rest. I placed the front of the vent 10 inches behin d the> rivet line of the bulkhead, centered in between the longerons. No sc ience> involved. On accuracy's web site there is a reference to them workin g well.> You can wait until later to install them as the top skin will be o ff until> you are ready.> > I have more pics if you need them.> > Fred Will iams> > day job getting in the way of building.> > > Bob Leffler wrote:> >> > I'm just finishing up my tailcone with wings coming in January.> >> > Fo r those that have use a NACA vent to provide an air inlet for the > > overh ead console, would you recommend installing them at this stage.> > My assum ption is that it would be much easy cutting the holes prior to > > riveting the tailcone together.> >> > My second question is has there been consensu s on the best local to > > place the vents yet?> >> > I'm also just startin g to start looking at NACA sources. Van's has one > > for $6.25 and ACS has several, but all are over $30. I was caught off > > guard by the price dif ferences. There can't be that much difference in > > quality.> >> > Thanks, > >> > Bob> >> > #40684> >> > *> >> >> > *> > ----------------------------- -----------------------------------------> > --> >> > > > > > > __________ ================> > > ________________________________________________________________________________
Subject: NACA Vents
Date: Dec 13, 2007
Bob, I am on the road so this is the only photo I have available. We placed ours just behind the baggage bulkhead. Again no science, just the shortest distance and it's the same place one of the very first OH console installers placed his with good results. We waited till late in the build to add the vents but well before the canopy was attached. Wait... The canopy still isn't attached. Darn. If you want to see some detail of our OH console visit: http://www.painttheweb.com/rv-10/console.htm Good Luck, Robin ________________________________________________________________________________
Subject: Van's cowl vs James cowl
Date: Dec 13, 2007
I am wondering whether a few builders can comment on the results that they have had with the James' cowl. What I am looking at is the overall quality of the James product vs Van's c owl or compared to other Van's fiberglass products. I am not so interested in the speed improvement debate, but quality and whe ther by using James made more work for the builder because Van's made the F W package for the Van's cowl. Also, I believe if I have energy left at the end of my build that I will be doing a plenum for the engine and I might be interested in molding it for others and the James has those nice intake rings. A nice plenum made of 50/50 carbon/kevlar with high temp resin would look c ool and I could realistically do that...energy remaining. What did van's credit for not taking the cowl with the finishing kit? Thanks, John G. ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Re:Drive
Jim there are two drives of ours on Barnstormers. One is 1000. the other 2600 with the engine, both are from good people The one in Texas was sold by his widow and the guy removed the engine and drive for a Lycoming. The other belonged to a fellow who died of a heart attack and his son is selling it for 1000.00 Go to Barnstormers.com, punch in search then enter RV6 and they come up. Jess **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: NACA Vents
Date: Dec 13, 2007
How much does the overhead console cost bare? When you're all done installing it with vents and eyeball lights how much does that run? -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Thursday, December 13, 2007 4:14 AM Subject: RV10-List: NACA Vents I'm just finishing up my tailcone with wings coming in January. For those that have use a NACA vent to provide an air inlet for the overhead console, would you recommend installing them at this stage. My assumption is that it would be much easy cutting the holes prior to riveting the tailcone together. My second question is has there been consensus on the best local to place the vents yet? I'm also just starting to start looking at NACA sources. Van's has one for $6.25 and ACS has several, but all are over $30. I was caught off guard by the price differences. There can't be that much difference in quality. Thanks, Bob #40684 ________________________________________________________________________________
Date: Dec 13, 2007
I asked Van's about the prices a while back (of their cowl) of course I just deleted it off my spreadsheet cause I decided to stick with the stock cowl. I am pretty sure it was right at $800 for the cowl and spinner parts. The tough sell is the spinner kit. If you are going with the hartzell the larger spinner kit is more than the James Cowl itself. I haven't heard any reports about improved speed, cooling, or what have you. Come to think of it I haven't heard any reports about the James Cowl at all! -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Thursday, December 13, 2007 3:01 PM Subject: RV10-List: Van's cowl vs James cowl I am wondering whether a few builders can comment on the results that they have had with the James' cowl. What I am looking at is the overall quality of the James product vs Van's cowl or compared to other Van's fiberglass products. I am not so interested in the speed improvement debate, but quality and whether by using James made more work for the builder because Van's made the FW package for the Van's cowl. Also, I believe if I have energy left at the end of my build that I will be doing a plenum for the engine and I might be interested in molding it for others and the James has those nice intake rings. A nice plenum made of 50/50 carbon/kevlar with high temp resin would look cool and I could realistically do that...energy remaining. What did van's credit for not taking the cowl with the finishing kit? Thanks, John G. ________________________________________________________________________________
Subject: Re: Van's cowl vs James cowl
Date: Dec 13, 2007
I just received my finish kit estimate yesterday for the same type of setup. I removed the cowl for a credit of $793.34 for the upper and lower halves and the inlets. For the removal of the entire spinner kit the credit was $120.00. Hope this helps. Eric Kallio 40518...Canopy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152050#152050 ________________________________________________________________________________
Subject: NACA Vents
Date: Dec 13, 2007
I don't have all the pricing yet. To me cost is secondary. My wife requires a ton of blowing air in her face when she flies. If installing an overhead vent is what it takes, then that's a mod that will be done regardless of price. I almost had to install air conditioning, but she has since relented on that requirement. There two methods. Several have used a Chevy SUV overhead console or you can get one from Accuracy Avionics. http://www.accuracyavionics.com/v1/fiberglassoptions.html From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Thursday, December 13, 2007 6:24 PM Subject: RE: RV10-List: NACA Vents How much does the overhead console cost bare? When you're all done installing it with vents and eyeball lights how much does that run? -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Thursday, December 13, 2007 4:14 AM Subject: RV10-List: NACA Vents I'm just finishing up my tailcone with wings coming in January. For those that have use a NACA vent to provide an air inlet for the overhead console, would you recommend installing them at this stage. My assumption is that it would be much easy cutting the holes prior to riveting the tailcone together. My second question is has there been consensus on the best local to place the vents yet? I'm also just starting to start looking at NACA sources. Van's has one for $6.25 and ACS has several, but all are over $30. I was caught off guard by the price differences. There can't be that much difference in quality. Thanks, Bob #40684 __________ NOD32 2722 (20071214) Information __________ ________________________________________________________________________________
Subject: Height of Fuse stand
Date: Dec 13, 2007
Group: Roughly, how high off the ground should I make the stand for the QB fuse. Think I read that the bottom of the fuse is ~27 inches from the ground with wheels installed so is that about right height. I'm copying the stand that I've seen attributed to Rick S. I'm 6'5" so don't want it too low to the ground. Knees don't bend quite as well as they used to :) Doug QB fuse and wings here Monday..... -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152063#152063 ________________________________________________________________________________
Subject: Alternative engines
Date: Dec 13, 2007
Here is an interesting read on the alternative engine subject. http://www.prime-mover.org/Engines/GArticles/article2.html Dave Leikam 40496 ________________________________________________________________________________
Date: Dec 13, 2007
Very interesting read ... thanks for posting. Hope you don't mind but I'm going to post a link to the article on a couple of other boards ... g _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Thursday, December 13, 2007 9:25 PM Subject: RV10-List: Alternative engines Here is an interesting read on the alternative engine subject. http://www.prime-mover.org/Engines/GArticles/article2.html Dave Leikam 40496 ________________________________________________________________________________
Date: Dec 13, 2007
Subject: Re: Height of Fuse stand
no no no. You want something low to the ground while you work on it, unless you plan to skip to the gear install first. You're going to be climbing in and out a whole lot and leaning over a bunch before it's up on gear. How tall are you???! I used two pallets fastened together with casters on the bottom, and it was still a little tall. I put a carpet scrap between the pallets and the fuse. BTW, If you plan to skip to the gear install, make sure you've done any soundproofing to the subfloor and floor pans under the gear leg brackets. I and others had to remove them to get the subfloor work done, which in itself involves a lot of bending and leaning, so you want a short stand anyway. Rob Wright #392 buildus interruptus since May, but still here! ----- Original Message ---- From: n277dl <dljinia(at)yahoo.com> Sent: Friday, December 14, 2007 5:15:09 AM Subject: RV10-List: Height of Fuse stand Group: Roughly, how high off the ground should I make the stand for the QB fuse. Think I read that the bottom of the fuse is ~27 inches from the ground with wheels installed so is that about right height. I'm copying the stand that I've seen attributed to Rick S. I'm 6'5" so don't want it too low to the ground. Knees don't bend quite as well as they used to :) Doug QB fuse and wings here Monday..... -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152063#152063 Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 13, 2007
That's a really interesting article. Do you know when it was written? Best Regards, Patrick #40715 / N690CT _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Thursday, December 13, 2007 9:25 PM Subject: RV10-List: Alternative engines Here is an interesting read on the alternative engine subject. http://www.prime-mover.org/Engines/GArticles/article2.html Dave Leikam 40496 ________________________________________________________________________________
Date: Dec 14, 2007
I spent roughly $1500. Came with all the lights and vents. Here's a web site. accuracyavionics Dr Fred. Ben Westfall wrote: > > How much does the overhead console cost bare? When youre all done > installing it with vents and eyeball lights how much does that run? > > -Ben > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler > *Sent:* Thursday, December 13, 2007 4:14 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: NACA Vents > > Im just finishing up my tailcone with wings coming in January. > > For those that have use a NACA vent to provide an air inlet for the > overhead console, would you recommend installing them at this stage. > My assumption is that it would be much easy cutting the holes prior to > riveting the tailcone together. > > My second question is has there been consensus on the best local to > place the vents yet? > > Im also just starting to start looking at NACA sources. Vans has one > for $6.25 and ACS has several, but all are over $30. I was caught off > guard by the price differences. There cant be that much difference in > quality. > > Thanks, > > Bob > > #40684 > > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Dec 14, 2007
drfred(at)suddenlinkmail. wrote: > I spent roughly $1500. Came with all the lights and vents. > I believe that price is with them installing all the vents, lights etc. I got just the overhead with all the parts and it came to $1100 something. I am at work and don't have the exact amount at hand. I think the overhead unit without the lights and vents is just under $700. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152115#152115 ________________________________________________________________________________
Date: Dec 14, 2007
Subject: heavy wing with fairings
Someone locally is flying his RV-10 and noticed the following I thought I would challenge the fliers with: What I noticed is at faster speeds the heavy right wing is more noticeable. Need to figure out what is causing the heavy wing as it relates to the fairings. Any suggestions? Slower speeds not noticeable. Pascal ________________________________________________________________________________
Date: Dec 14, 2007
Subject: Sam James cowl
There was an earlier post asking about rv-10s with the james cowl.Is anybody out there actualy flying a 10 with one.How much is that special hartzel spinner kit? ************************************** See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: Re: heavy wing with fairings
Date: Dec 14, 2007
I had a similar issue and agree with Tim. Make sure he is flying with the ball centered. I is most likely a rudder trim issue which is very common on RVs. Spruce sells some plastic ones you stick on with double sided tape. Get two so you can cut them down for the right amount of trim. -------- MARK SUTHERLAND RV-10 40292 Flying since June 07 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152127#152127 ________________________________________________________________________________
Date: Dec 14, 2007
Look at William Curtis' web site. He has some fuselage stand options posted. <http://wcurtis.nerv10.com/fusestand/index.html> My fuselage stand is just 2 2x4s with plywood on top, covered with carpet that run under the wing spar. I then have a 2x4 running parallel to the fuse on each side with casters (total of 4 casters). I support the tail with a plastic crate with foam on top. Larry Rosen #356 Robert Wright wrote: > no no no. You want something low to the ground while you work on it, > unless you plan to skip to the gear install first. You're going to be > climbing in and out a whole lot and leaning over a bunch before it's > up on gear. How tall are you???! > > I used two pallets fastened together with casters on the bottom, and > it was still a little tall. I put a carpet scrap between the pallets > and the fuse. > > BTW, If you plan to skip to the gear install, make sure you've done > any soundproofing to the subfloor and floor pans under the gear leg > brackets. I and others had to remove them to get the subfloor work > done, which in itself involves a lot of bending and leaning, so you > want a short stand anyway. > > Rob Wright > #392 > buildus interruptus since May, but still here! > > ----- Original Message ---- > From: n277dl <dljinia(at)yahoo.com> > To: rv10-list(at)matronics.com > Sent: Friday, December 14, 2007 5:15:09 AM > Subject: RV10-List: Height of Fuse stand > > > > > Group: > Roughly, how high off the ground should I make the stand for the QB > fuse. Think I read that the bottom of the fuse is ~27 inches from the > ground with wheels installed so is that about right height. I'm > copying the stand that I've seen attributed to Rick S. > > I'm 6'5" so don't want it too low to the ground. Knees don't bend > quite as well as they used to :) > > Doug > QB fuse and wings here Monday..... > > -------- > Doug > RV7A flying ~500hrs > > > Read this topic > > > Find them fast with Yahoo! Search. > * > > > * ________________________________________________________________________________
Date: Dec 14, 2007
Subject: Illuminated Switches
Hi As I plan my panel, I thought it would be nice to use illuminated switches in some applications. I came across some MilSpec switches but I suspect they would be very expensive. Does anyone have a good source for switches that would be appropriate for panel use (other than the typical toggle switches). Cheers Les Kearney #40643 C-GCWZ (Resereved) ________________________________________________________________________________
Subject: Re: Illuminated Switches
Date: Dec 14, 2007
Look at the Honeywell AML available from Stein for $61.50, and probably others. LED lighted, and can be color coded and/or engraved. Pricey, but very nice. Jim Berry 40482 Finishing forever Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152160#152160 ________________________________________________________________________________
Date: Dec 14, 2007
I prefer to work standing up, rather than be kneeling or bent over. My stand was 48" x48" x 24" high, and on casters. The low point of my fuselage on the gear and wheels is 27.5" above the ground. At your height if you made a stand 28-29" high it would simplify attaching the gear and wheels, and might be a more comfortable working height. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152163#152163 ________________________________________________________________________________
Date: Dec 14, 2007
I used the small AML 34's my panel. Downside is there about $50.00 each with engraving. RV10 panel Les Kearney wrote: > > Hi > > > > As I plan my panel, I thought it would be nice to use illuminated > switches in some applications. I came across some MilSpec switches but > I suspect they would be very expensive. > > > > Does anyone have a good source for switches that would be appropriate > for panel use (other than the typical toggle switches). > > > > Cheers > > > > Les Kearney > > #40643 > > C-GCWZ (Resereved) > > * > > > * ________________________________________________________________________________
Subject: AOA in your RV-10?
Date: Dec 14, 2007
Who's using AOA in their RV-10? See: http://www.advanced-flight-systems.com/Products/AOA/aoa.html Blue Mountain has integrated AFS's software into EFIS/one Gen 3, but I don' t have the wing kit installed. Is the "Wing Kit A" that AFS sells worth the $400 or could made easily? Does anyone have good pictures of the hardware included in "Wing Kit A"? ERic-- RV-10, 40014 N104EP ________________________________________________________________________________
Date: Dec 14, 2007
Subject: Re: Alternative engines
Dave Leikam wrote: > > Go ahead and post it where ever you like, I found the article by > chance while Googling around. I have no idea when it was written, but > I assume it is not too old. It references Toyota's interest in > building a small 4 seat GA airplane, and I remember hearing about that > several years ago. I looked at the page info in Firefox (Tools, Page Info menu under Linux), and it says this page was last modified on Nov 4, 1997. No idea if that is really the correct date it was published, though. The author's info is at the bottom of the web page, so I suppose we could contact him and see... It would be interesting to find out about the Toyota research project. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Dec 14, 2007
Doug, I've been through a couple iterations of the fuselage stand and you can see mine and some others here: http://wcurtis.nerv10.com/fusestand/index.html My stand has two heights. Even at 6'5", I don't think you want a stand at full height to work on the fuse. My lower height has the fuse belly 12" off the ground. At this lower height, I still need a step to get in and work on the top. The drawing at the above link is the most update stand that I think works best. I'll add the updated pictures shortly. William http://wcurtis.nerv10.com/ -------- Original Message -------- > > Group: > Roughly, how high off the ground should I make the stand for the QB fuse. Think I read that the bottom of the fuse is ~27 inches from the ground with wheels installed so is that about right height. I'm copying the stand that I've seen attributed to Rick S. > > I'm 6'5" so don't want it too low to the ground. Knees don't bend quite as well as they used to :) > > Doug > QB fuse and wings here Monday..... > > -------- > Doug > RV7A flying ~500hrs > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=152063#152063 > > > > > > > ________________________________________________________________________________
Date: Dec 14, 2007
Thanks for the input folks. This helps a lot. I'll leave it a little flexible, keep it simple and play with a couple heights and see what works for my size. Thanks again. Traveling to Gatlinburg, TN this weekend and will hopefully get re-started early next week. Doug -------- Doug RV7A flying ~500hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152183#152183 ________________________________________________________________________________
Subject: Re: New GPS & WX
Date: Dec 14, 2007
http://www.bushnell.com/gps/ This is a new Busnell GPS that shows graphical weather and XM Radio, all for $16.95/month.? While certainly not a full up aviation GPS nor Aviation Weather, it is a nice little GPS with some neat features, it will show the weather ahead...our main use as pilots.? The addition of XM radio makes it even better. I have a 496, but at nearly $60.00/month for WX and radio it is hardly a bargain.? Has anyone investigated this new device and its capabilities?? TIA Jeff ________________________________________________________________________ ________________________________________________________________________________
Date: Dec 14, 2007
In a message dated 12/14/2007 1:46:17 PM Central Standard Time, deej(at)deej.net writes: It would be interesting to find out about the Toyota research project. Toyota said about 4 years ago the stopped the 4 place/engine to concentrate on their jet...which was on show at the last two KOSH's... **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 14, 2007
Hi Jim It looks like I will be using at AML's. The milspec switches I found were $400+ each and had some very nice switch guards. I would have been tempted to use at least one of them but for my bus master but they couldn't handle the amperage I need. Damn! Cheers Les Kearney #40643 C-GCWZ (reserved) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim berry Sent: December-14-07 11:48 AM Subject: RV10-List: Re: Illuminated Switches Look at the Honeywell AML available from Stein for $61.50, and probably others. LED lighted, and can be color coded and/or engraved. Pricey, but very nice. Jim Berry 40482 Finishing forever Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152160#152160 ________________________________________________________________________________
Date: Dec 14, 2007
Basic fiberglass and access covers $695 Fiberglass, air vents, lights and switches (items un-installed) $1,195 Fiberglass, air vents, lights and switches (items installed) $1,495 Fiberglass, air vents, lights, switches and DVD player (items un-installed) $1,575 Fiberglass, air vents, lights, switches and DVD player (items installed) $1,875 http://www.accuracyavionics.com/v1/fiberglassoptions.html William http://wcurtis.nerv10.com/ -------- Original Message -------- > > > drfred(at)suddenlinkmail. wrote: > > I spent roughly $1500. Came with all the lights and vents. > > > > I believe that price is with them installing all the vents, lights etc. I got just the overhead with all the parts and it came to $1100 something. I am at work and don't have the exact amount at hand. I think the overhead unit without the lights and vents is just under $700. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Fuselage SB > (N410GB reserved) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=152115#152115 ________________________________________________________________________________
Date: Dec 14, 2007
You sure that was Toyota? I haven't seen a Toyota jet at OSH, not that I see everything each year. Toyota had a POC piston aircraft they were flying for a while but I think they abandoned it. http://www.avweb.com/news/atis/181827-1.html Honda on the other hand has had a jet at OSH for the past few years. They have since decided to manufacturer this jet in Greensboro, NC. http://world.honda.com/HondaJet/ William http://wcurtis.nerv10.com/ -------- Original Message -------- > In a message dated 12/14/2007 1:46:17 PM Central Standard Time, > deej(at)deej.net writes: > > It would be interesting to find out about the Toyota research project. > > > Toyota said about 4 years ago the stopped the 4 place/engine to concentrate > on their jet...which was on show at the last two KOSH's... > > > > **************************************See AOL's top rated recipes > (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 14, 2007
Sorry Jesse, it's the Honda jet, although I've read that Toyota also has one under development which is why the dropped their GA program but who knows if anything is accurate you read these days...including my missive... P **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: VP-200 Update
Date: Dec 14, 2007
We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". Those of us who live and fly in the US sure have it good. You have to have permission to spit in the air down here. As an update on the Vertical Power system that some are interested in hearing, we have it up and running and mostly configured. It so far is a fantastic way to handle the electrical system, from initial wiring to setting flaps and wiring trims. With the trim settings, if you have it wired backwards, you can just flip it in the menus and it changed direction. The flaps allow you to set up, down and two intermediate positions if you have an indicator (enter the Ray Allen position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think they have implemented the trim sensitivity option yet, but it will soon be possible to automatically slow down the trims in cruise and speed them back up in slow flight and pattern work. Adding circuits, like we added for pumps from wingtip tanks to the mains, is super easy. Just pick an open pin, run a wire and set it up in the menu. They are right now debugging the reading from the Dynon EMS to help with the automatic mode switching (we are the first ones running on a Dynon with the VP), but the GPS info from the 430 is already on there to do some of the mode switching. Each device can be set up to come on automatically in any mode, including preflight, so you could have it turn on a Garmin 496 during preflight to go ahead and start downloading the weather. Overall, I am so far very impressed with both the functionality, the ease of installation, the great documentation and the quick and thorough tech support in getting things running. I just wish all of the possibilities were already implemented in the software. That will come. For the record, I am not affiliated with Vertical Power, but I am one of their dealers, which I will continue to be as long as they keep up the good work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Dec 14, 2007
That's great to hear Jesse - I'm also going to go with the VP setup, and Marc Ausman actually came to my house last Tuesday (ok...he was already coming to LA, I'm not that special!) and we went over some of the stuff, and he brought me a dummy CU box and display faceplate to use for panel planning (refundable deposit required). Overall, I am incredibly impressed with what he's doing, and he's a really nice knowledgeable fella as well! He actually had some great suggestions for my aircraft that weren't related to his system as well. He's got a RV-7 that he built, so he can kinda relate. Anyway, more to come! cj #40410 www.perfectlygoodairplane.net <http://www.perfectlygoodairplane.net/> -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Friday, December 14, 2007 2:13 PM Subject: RV10-List: VP-200 Update We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". Those of us who live and fly in the US sure have it good. You have to have permission to spit in the air down here. As an update on the Vertical Power system that some are interested in hearing, we have it up and running and mostly configured. It so far is a fantastic way to handle the electrical system, from initial wiring to setting flaps and wiring trims. With the trim settings, if you have it wired backwards, you can just flip it in the menus and it changed direction. The flaps allow you to set up, down and two intermediate positions if you have an indicator (enter the Ray Allen position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think they have implemented the trim sensitivity option yet, but it will soon be possible to automatically slow down the trims in cruise and speed them back up in slow flight and pattern work. Adding circuits, like we added for pumps from wingtip tanks to the mains, is super easy. Just pick an open pin, run a wire and set it up in the menu. They are right now debugging the reading from the Dynon EMS to help with the automatic mode switching (we are the first ones running on a Dynon with the VP), but the GPS info from the 430 is already on there to do some of the mode switching. Each device can be set up to come on automatically in any mode, including preflight, so you could have it turn on a Garmin 496 during preflight to go ahead and start downloading the weather. Overall, I am so far very impressed with both the functionality, the ease of installation, the great documentation and the quick and thorough tech support in getting things running. I just wish all of the possibilities were already implemented in the software. That will come. For the record, I am not affiliated with Vertical Power, but I am one of their dealers, which I will continue to be as long as they keep up the good work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Dec 14, 2007
Subject: Re: VP-200 Update
Any thoughts as to cost of the VP-200 vs conventional breakers and somebody else's engine monitor/analyzer? On Dec 14, 2007 3:12 PM, Jesse Saint wrote: > We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". > Those of us who live and fly in the US sure have it good. You have to have > permission to spit in the air down here. > > As an update on the Vertical Power system that some are interested in > hearing, we have it up and running and mostly configured. It so far is a > fantastic way to handle the electrical system, from initial wiring to > setting flaps and wiring trims. With the trim settings, if you have it > wired backwards, you can just flip it in the menus and it changed direction. > The flaps allow you to set up, down and two intermediate positions if you > have an indicator (enter the Ray Allen position sensor), so if you want up, > 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think > they have implemented the trim sensitivity option yet, but it will soon be > possible to automatically slow down the trims in cruise and speed them back > up in slow flight and pattern work. Adding circuits, like we added for > pumps from wingtip tanks to the mains, is super easy. Just pick an open > pin, run a wire and set it up in the menu. They are right now debugging the > reading from the Dynon EMS to help with the automatic mode switching (we are > the first ones running on a Dynon with the VP), but the GPS info from the > 430 is already on there to do some of the mode switching. Each device can > be set up to come on automatically in any mode, including preflight, so you > could have it turn on a Garmin 496 during preflight to go ahead and start > downloading the weather. > > Overall, I am so far very impressed with both the functionality, the ease of > installation, the great documentation and the quick and thorough tech > support in getting things running. I just wish all of the possibilities > were already implemented in the software. That will come. > > For the record, I am not affiliated with Vertical Power, but I am one of > their dealers, which I will continue to be as long as they keep up the good > work. > > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > ________________________________________________________________________________
Date: Dec 14, 2007
The article appears to be about 10 years old. Cirrus and Thielert have skewed all the basis. The Continental Diesel has been abandoned. The Orenda goes way back with Lancairs. The Zoche Diesel is still a research project and Mooney is long out of this Alternate Engine hunt. It was fun reading. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Friday, December 14, 2007 11:19 AM Subject: Re: RV10-List: Alternative engines Dave Leikam wrote: > > Go ahead and post it where ever you like, I found the article by > chance while Googling around. I have no idea when it was written, but > I assume it is not too old. It references Toyota's interest in > building a small 4 seat GA airplane, and I remember hearing about that > several years ago. I looked at the page info in Firefox (Tools, Page Info menu under Linux), and it says this page was last modified on Nov 4, 1997. No idea if that is really the correct date it was published, though. The author's info is at the bottom of the web page, so I suppose we could contact him and see... It would be interesting to find out about the Toyota research project. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Dec 14, 2007
Hmmm I have a couple of long conversations with Marc Ausman of Vertical Power over the past couple of weeks. I have decided to use their product after seeing it at KOSH and reading the online docs. I like the idea of eliminating the traditional bus / breaker arrangement for something that is a more sophisticated. One of the nice things about their system is that it builds in capabilities that would otherwise require integration of other boxes. Things like trim sensitivity, landing light wig wags, door alarms / annuciators / low voltage warnings / audible alarms / etc. If VP's post sales support is even half of what the pre-sales support is like, they will be a great company to deal with. Cheers Les Kearney #40643 C-GCWZ (reserved) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: December-14-07 3:13 PM Subject: RV10-List: VP-200 Update We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". Those of us who live and fly in the US sure have it good. You have to have permission to spit in the air down here. As an update on the Vertical Power system that some are interested in hearing, we have it up and running and mostly configured. It so far is a fantastic way to handle the electrical system, from initial wiring to setting flaps and wiring trims. With the trim settings, if you have it wired backwards, you can just flip it in the menus and it changed direction. The flaps allow you to set up, down and two intermediate positions if you have an indicator (enter the Ray Allen position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think they have implemented the trim sensitivity option yet, but it will soon be possible to automatically slow down the trims in cruise and speed them back up in slow flight and pattern work. Adding circuits, like we added for pumps from wingtip tanks to the mains, is super easy. Just pick an open pin, run a wire and set it up in the menu. They are right now debugging the reading from the Dynon EMS to help with the automatic mode switching (we are the first ones running on a Dynon with the VP), but the GPS info from the 430 is already on there to do some of the mode switching. Each device can be set up to come on automatically in any mode, including preflight, so you could have it turn on a Garmin 496 during preflight to go ahead and start downloading the weather. Overall, I am so far very impressed with both the functionality, the ease of installation, the great documentation and the quick and thorough tech support in getting things running. I just wish all of the possibilities were already implemented in the software. That will come. For the record, I am not affiliated with Vertical Power, but I am one of their dealers, which I will continue to be as long as they keep up the good work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Dec 14, 2007
HERE ARE SOME ROCKER SWITCHES.......... DP http://www.aerocraftparts.com/Categories.aspx?Category=38940ec0-b260-4e9f-a23c-b80ff8e89c67 -----Original Message----- From: Les Kearney <kearney(at)shaw.ca> Sent: Fri, 14 Dec 2007 4:39 pm Subject: RE: RV10-List: Illuminated Switches Hi Ted ? Those are very nice switches. Much nicer than the usual throw switches. Thanks for the link. ? Cheers ? Les ? PS: Did I see your plane in a recent copy of COPA?. Where are you based? ? ? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted French Sent: December-14-07 2:34 PM Subject: RE: RV10-List: Illuminated Switches ? Les ? See:? http://www.action-electronics.com/pdf/gcsw16.pdf ? Look at the one at the bottom of this page.? The light is independant of the switch. I wired mine so the panel lights bring it on fairly dim, but when switched on, they go full bright. Also available from Stein with white light instead of green. ? See my panel at:? http://www3.telus.net/elfrench/Panel_Feb_26_2007.jpg ? Do Not Archive Ted French C-FXCS RV-10? Flying -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Les Kearney Sent: December 14, 2007 8:34 AM Subject: RV10-List: Illuminated Switches Hi ? As I plan my panel, I thought it would be nice to use illuminated switches in some applications. I came across some MilSpec switches but I suspect they would be very expensive.? ? Does anyone have a good source for switches that would be appropriate for panel use (other than the typical toggle switches). ? Cheers ? Les Kearney #40643 C-GCWZ (Resereved) ? ? href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com ? ? ? http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com ? ________________________________________________________________________ ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Date: Dec 14, 2007
I am planning to use the VP200 in my plane as well. It is more expensive than going with traditional breakers and switches, but there are several upsides. One of which is that the system continues to improve through software updates as previously mentioned. I ordered the VP200 back at Oshkosh thinking I would be further along by now. It really does look cool sitting on my desk. :-) Mike Schipper #40576 - Fuselage - www.rvten.com ________________________________________________________________________________
Date: Dec 14, 2007
Does the VP-200 include the engine monitor? I thought it simply displayed data transmitted by an owner provided engine monitor (JPI, etc.). Best Regards, Patrick #40715 / N690CT -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, December 14, 2007 2:47 PM Subject: Re: RV10-List: VP-200 Update Any thoughts as to cost of the VP-200 vs conventional breakers and somebody else's engine monitor/analyzer? On Dec 14, 2007 3:12 PM, Jesse Saint wrote: > We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". > Those of us who live and fly in the US sure have it good. You have to have > permission to spit in the air down here. > > As an update on the Vertical Power system that some are interested in > hearing, we have it up and running and mostly configured. It so far is a > fantastic way to handle the electrical system, from initial wiring to > setting flaps and wiring trims. With the trim settings, if you have it > wired backwards, you can just flip it in the menus and it changed direction. > The flaps allow you to set up, down and two intermediate positions if you > have an indicator (enter the Ray Allen position sensor), so if you want up, > 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think > they have implemented the trim sensitivity option yet, but it will soon be > possible to automatically slow down the trims in cruise and speed them back > up in slow flight and pattern work. Adding circuits, like we added for > pumps from wingtip tanks to the mains, is super easy. Just pick an open > pin, run a wire and set it up in the menu. They are right now debugging the > reading from the Dynon EMS to help with the automatic mode switching (we are > the first ones running on a Dynon with the VP), but the GPS info from the > 430 is already on there to do some of the mode switching. Each device can > be set up to come on automatically in any mode, including preflight, so you > could have it turn on a Garmin 496 during preflight to go ahead and start > downloading the weather. > > Overall, I am so far very impressed with both the functionality, the ease of > installation, the great documentation and the quick and thorough tech > support in getting things running. I just wish all of the possibilities > were already implemented in the software. That will come. > > For the record, I am not affiliated with Vertical Power, but I am one of > their dealers, which I will continue to be as long as they keep up the good > work. > > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > ________________________________________________________________________________
Date: Dec 14, 2007
Is there any sense of how much weight you add with the VP-200?.. and would it replace the function of the Safety-Trim device? Jeff Carpenter 40304 On Dec 14, 2007, at 3:22 PM, Michael Schipper wrote: > > > I am planning to use the VP200 in my plane as well. It is more > expensive than going with traditional breakers and switches, but > there are several upsides. One of which is that the system > continues to improve through software updates as previously mentioned. > > I ordered the VP200 back at Oshkosh thinking I would be further > along by now. It really does look cool sitting on my desk. :-) > > Mike Schipper > #40576 - Fuselage - www.rvten.com > > ________________________________________________________________________________
Date: Dec 14, 2007
Before I had many hours in the soup IFR, I was in favor of as much automaiton in light aircraft as possible. Now I've kind of taken a more conservative approach and in addition to the cost of the VP-200, I would only fear the WOPR/Skynet affect if this box that is hooked into and in control of (almost) everything should "lose it mind" and go stupid (or smart:-). But that's just me, YMMV. William http://wcurtis.nerv10.com/ -------- Original Message -------- > We are ready to fly, just awaiting the permission from the Ecuadorian > "FAA". Those of us who live and fly in the US sure have it good. You > have to have permission to spit in the air down here. > > As an update on the Vertical Power system that some are interested in > hearing, we have it up and running and mostly configured. It so far > is a fantastic way to handle the electrical system, from initial > wiring to setting flaps and wiring trims. With the trim settings, if > you have it wired backwards, you can just flip it in the menus and it > changed direction. The flaps allow you to set up, down and two > intermediate positions if you have an indicator (enter the Ray Allen > position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 > and 30, that's no problem. I don't think they have implemented the > trim sensitivity option yet, but it will soon be possible to > automatically slow down the trims in cruise and speed them back up in > slow flight and pattern work. Adding circuits, like we added for > pumps from wingtip tanks to the mains, is super easy. Just pick an > open pin, run a wire and set it up in the menu. They are right now > debugging the reading from the Dynon EMS to help with the automatic > mode switching (we are the first ones running on a Dynon with the VP), > but the GPS info from the 430 is already on there to do some of the > mode switching. Each device can be set up to come on automatically in > any mode, including preflight, so you could have it turn on a Garmin > 496 during preflight to go ahead and start downloading the weather. > > Overall, I am so far very impressed with both the functionality, the > ease of installation, the great documentation and the quick and > thorough tech support in getting things running. I just wish all of > the possibilities were already implemented in the software. That will > come. > > For the record, I am not affiliated with Vertical Power, but I am one > of their dealers, which I will continue to be as long as they keep up > the good work. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 ________________________________________________________________________________
Date: Dec 14, 2007
As far as that goes, you can build in a safety net for critical stuff in the event of the VP going boom. Really easy to do, and there are diagrams on the VP site showing different ways to go about it. when it's working, which should be the norm, the automation will be VERY nice to have. Also, the emergency handling is pretty slick too! cj -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Friday, December 14, 2007 4:19 PM Subject: re: RV10-List: VP-200 Update Before I had many hours in the soup IFR, I was in favor of as much automaiton in light aircraft as possible. Now I've kind of taken a more conservative approach and in addition to the cost of the VP-200, I would only fear the WOPR/Skynet affect if this box that is hooked into and in control of (almost) everything should "lose it mind" and go stupid (or smart:-). But that's just me, YMMV. William http://wcurtis.nerv10.com/ -------- Original Message -------- > We are ready to fly, just awaiting the permission from the Ecuadorian > "FAA". Those of us who live and fly in the US sure have it good. You > have to have permission to spit in the air down here. > > As an update on the Vertical Power system that some are interested in > hearing, we have it up and running and mostly configured. It so far > is a fantastic way to handle the electrical system, from initial > wiring to setting flaps and wiring trims. With the trim settings, if > you have it wired backwards, you can just flip it in the menus and it > changed direction. The flaps allow you to set up, down and two > intermediate positions if you have an indicator (enter the Ray Allen > position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 > and 30, that's no problem. I don't think they have implemented the > trim sensitivity option yet, but it will soon be possible to > automatically slow down the trims in cruise and speed them back up in > slow flight and pattern work. Adding circuits, like we added for > pumps from wingtip tanks to the mains, is super easy. Just pick an > open pin, run a wire and set it up in the menu. They are right now > debugging the reading from the Dynon EMS to help with the automatic > mode switching (we are the first ones running on a Dynon with the VP), > but the GPS info from the 430 is already on there to do some of the > mode switching. Each device can be set up to come on automatically in > any mode, including preflight, so you could have it turn on a Garmin > 496 during preflight to go ahead and start downloading the weather. > > Overall, I am so far very impressed with both the functionality, the > ease of installation, the great documentation and the quick and > thorough tech support in getting things running. I just wish all of > the possibilities were already implemented in the software. That will > come. > > For the record, I am not affiliated with Vertical Power, but I am one > of their dealers, which I will continue to be as long as they keep up > the good work. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 ________________________________________________________________________________
Date: Dec 14, 2007
William I spoke to Marc at VP yesterday on this very point. There are failsafes built in. For example, if he box had a major brain fart (notice the high tech terminology), I can still drive my EFIS off the main bus wth the simple throw of an external switch. In all seriousness, VP has given thought to failure modes. Given that the system detects and handles device faults, can automatically implement load shedding if an aternor fails, I suspect this is a lower risk solution. Personally, I like the idea of a solid state electrical system rather than th rats nest of wiring / breakers etc hat I have seen in more traditional a/c. Cheers Les Kearney #40643 ----- Original Message ----- From: William Curtis <wcurtis(at)nerv10.com> Date: Friday, December 14, 2007 5:21 pm Subject: re: RV10-List: VP-200 Update > > Before I had many hours in the soup IFR, I was in favor of as > much automaiton in light aircraft as possible. Now I've > kind of taken a more conservative approach and in addition to > the cost of the VP-200, I would only fear the WOPR/Skynet affect > if this box that is hooked into and in control of (almost) > everything should "lose it mind" and go stupid (or smart:- > ). But that's just me, YMMV. > > William > http://wcurtis.nerv10.com/ > > > -------- Original Message -------- > > We are ready to fly, just awaiting the permission from the > Ecuadorian > > "FAA". Those of us who live and fly in the US sure have > it good. You > > have to have permission to spit in the air down here. > > > > As an update on the Vertical Power system that some are > interested in > > hearing, we have it up and running and mostly > configured. It so far > > is a fantastic way to handle the electrical system, from > initial > > wiring to setting flaps and wiring trims. With the trim > settings, if > > you have it wired backwards, you can just flip it in the menus > and it > > changed direction. The flaps allow you to set up, down > and two > > intermediate positions if you have an indicator (enter the Ray > Allen > > position sensor), so if you want up, 0, 10 and 30 instead of > up, 0, 15 > > and 30, that's no problem. I don't think they have > implemented the > > trim sensitivity option yet, but it will soon be possible > to > > automatically slow down the trims in cruise and speed them > back up in > > slow flight and pattern work. Adding circuits, like we > added for > > pumps from wingtip tanks to the mains, is super easy. > Just pick an > > open pin, run a wire and set it up in the menu. They are > right now > > debugging the reading from the Dynon EMS to help with the > automatic > > mode switching (we are the first ones running on a Dynon with > the VP), > > but the GPS info from the 430 is already on there to do some > of the > > mode switching. Each device can be set up to come on > automatically in > > any mode, including preflight, so you could have it turn on a > Garmin > > 496 during preflight to go ahead and start downloading the weather. > > > > Overall, I am so far very impressed with both the > functionality, the > > ease of installation, the great documentation and the quick > and > > thorough tech support in getting things running. I just > wish all of > > the possibilities were already implemented in the > software. That will > > come. > > > > For the record, I am not affiliated with Vertical Power, but I > am one > > of their dealers, which I will continue to be as long as they > keep up > > the good work. > > > > Jesse Saint > > Saint Aviation, Inc. > > jesse(at)saintaviation.com > > Cell: 352-427-0285 > > Fax: 815-377-3694 > > > > > > Lists This Month -- > (And Get Some AWESOME FREE Gifts!) > Click on > _- > = -Matt Dralle, List Admin. > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > > > > ________________________________________________________________________________
Date: Dec 14, 2007
Les, Are you going with the 100 or 200? I'm still struggling with the price/value of the unit. Having met Marc and team at Michael Sausen's house before OSH and listening to him explain the system, it is certainly a great product. I think I would want to go with the 200, but am having difficulties justifying the expense to myself, let alone my wife. Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Friday, December 14, 2007 5:50 PM Subject: RE: RV10-List: VP-200 Update Hmmm I have a couple of long conversations with Marc Ausman of Vertical Power over the past couple of weeks. I have decided to use their product after seeing it at KOSH and reading the online docs. I like the idea of eliminating the traditional bus / breaker arrangement for something that is a more sophisticated. One of the nice things about their system is that it builds in capabilities that would otherwise require integration of other boxes. Things like trim sensitivity, landing light wig wags, door alarms / annuciators / low voltage warnings / audible alarms / etc. If VP's post sales support is even half of what the pre-sales support is like, they will be a great company to deal with. Cheers Les Kearney #40643 C-GCWZ (reserved) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: December-14-07 3:13 PM Subject: RV10-List: VP-200 Update We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". Those of us who live and fly in the US sure have it good. You have to have permission to spit in the air down here. As an update on the Vertical Power system that some are interested in hearing, we have it up and running and mostly configured. It so far is a fantastic way to handle the electrical system, from initial wiring to setting flaps and wiring trims. With the trim settings, if you have it wired backwards, you can just flip it in the menus and it changed direction. The flaps allow you to set up, down and two intermediate positions if you have an indicator (enter the Ray Allen position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think they have implemented the trim sensitivity option yet, but it will soon be possible to automatically slow down the trims in cruise and speed them back up in slow flight and pattern work. Adding circuits, like we added for pumps from wingtip tanks to the mains, is super easy. Just pick an open pin, run a wire and set it up in the menu. They are right now debugging the reading from the Dynon EMS to help with the automatic mode switching (we are the first ones running on a Dynon with the VP), but the GPS info from the 430 is already on there to do some of the mode switching. Each device can be set up to come on automatically in any mode, including preflight, so you could have it turn on a Garmin 496 during preflight to go ahead and start downloading the weather. Overall, I am so far very impressed with both the functionality, the ease of installation, the great documentation and the quick and thorough tech support in getting things running. I just wish all of the possibilities were already implemented in the software. That will come. For the record, I am not affiliated with Vertical Power, but I am one of their dealers, which I will continue to be as long as they keep up the good work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com __________ NOD32 2724 (20071214) Information __________ ________________________________________________________________________________
Date: Dec 14, 2007
I agree. After 4000+ and about 10% of that actual IMC without a working autopilot and a career in information technology, I don't trust someone else or something else flying the aircraft for me. Hence my 10 has every appliance on its own breaker (eithor pull or toggle), two batteries and three ways to get to the batteries. If you use the automation just make sure that you know what it does for you and how to disconnect it and hand fly from raw data. Hence it follows if one can't fly an ILS in actual IMC to minimums, then the automation should not be doing it for you. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Friday, December 14, 2007 5:19 PM Subject: re: RV10-List: VP-200 Update Before I had many hours in the soup IFR, I was in favor of as much automaiton in light aircraft as possible. Now I've kind of taken a more conservative approach and in addition to the cost of the VP-200, I would only fear the WOPR/Skynet affect if this box that is hooked into and in control of (almost) everything should "lose it mind" and go stupid (or smart:-). But that's just me, YMMV. William http://wcurtis.nerv10.com/ -------- Original Message -------- > We are ready to fly, just awaiting the permission from the Ecuadorian > "FAA". Those of us who live and fly in the US sure have it good. You > have to have permission to spit in the air down here. > > As an update on the Vertical Power system that some are interested in > hearing, we have it up and running and mostly configured. It so far > is a fantastic way to handle the electrical system, from initial > wiring to setting flaps and wiring trims. With the trim settings, if > you have it wired backwards, you can just flip it in the menus and it > changed direction. The flaps allow you to set up, down and two > intermediate positions if you have an indicator (enter the Ray Allen > position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 > and 30, that's no problem. I don't think they have implemented the > trim sensitivity option yet, but it will soon be possible to > automatically slow down the trims in cruise and speed them back up in > slow flight and pattern work. Adding circuits, like we added for > pumps from wingtip tanks to the mains, is super easy. Just pick an > open pin, run a wire and set it up in the menu. They are right now > debugging the reading from the Dynon EMS to help with the automatic > mode switching (we are the first ones running on a Dynon with the VP), > but the GPS info from the 430 is already on there to do some of the > mode switching. Each device can be set up to come on automatically in > any mode, including preflight, so you could have it turn on a Garmin > 496 during preflight to go ahead and start downloading the weather. > > Overall, I am so far very impressed with both the functionality, the > ease of installation, the great documentation and the quick and > thorough tech support in getting things running. I just wish all of > the possibilities were already implemented in the software. That will > come. > > For the record, I am not affiliated with Vertical Power, but I am one > of their dealers, which I will continue to be as long as they keep up > the good work. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 ________________________________________________________________________________
Date: Dec 14, 2007
Marc does have a document that you can use to calculate the differences. http://www.verticalpower.com/docs/Pricing_Analysis.pdf I would be interested in seeing if somebody has taken the time to complete the worksheet to see where it came out. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, December 14, 2007 5:47 PM Subject: Re: RV10-List: VP-200 Update Any thoughts as to cost of the VP-200 vs conventional breakers and somebody else's engine monitor/analyzer? ________________________________________________________________________________
Date: Dec 14, 2007
Hi Jeff, The combined weight of the control unit, the display unit, and the remote switch unit is around 5 pounds. I really don't know how that would compare to a couple dozen breakers, switches, and wires. Yes, it has runaway trim protection built in, along with many other safety features. There is no built-in engine monitor, but it will take the output from any GRT-compatible EIS and display the engine data. Mike Schipper #40576 - Fuselage - www.rvten.com On Dec 14, 2007, at 5:45 PM, Jeff Carpenter wrote: > > > > Is there any sense of how much weight you add with the VP-200?.. and > would it replace the function of the Safety-Trim device? > > Jeff Carpenter > 40304 > > > On Dec 14, 2007, at 3:22 PM, Michael Schipper wrote: > >> > >> >> I am planning to use the VP200 in my plane as well. It is more >> expensive than going with traditional breakers and switches, but >> there are several upsides. One of which is that the system >> continues to improve through software updates as previously >> mentioned. >> >> I ordered the VP200 back at Oshkosh thinking I would be further >> along by now. It really does look cool sitting on my desk. :-) >> >> Mike Schipper >> #40576 - Fuselage - www.rvten.com >> ________________________________________________________________________________
Date: Dec 14, 2007
I have done the worksheet and I found that either unit saved me about $1,750 in parts (flap positioning system, trim relays, switches, breakers, etc.). As Stein told me when I talked to him about it, it really comes into play a lot when you start calculating the amount of time it saves. I think that someone who has never wired a plane can handle doing it with this a LOT easier than the traditional way. When it comes time to add something, which you will very possibly do even before you get the plane flying, you can just add that to the spreadsheet and run a wire from a pin on J3-J6 and set it up in the menus. It also gives you a lot easier point to start to build the wiring harness outside the plane as one piece and just slide it in (minus some of the big wires, of course). I have now wired 3 airframes with this and am very happy with how easy it is to plan- harness-install. After next weekend anybody who wants to come by X35 for a ground demo, I would be happy to do it. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Dec 14, 2007, at 8:00 PM, Bob Leffler wrote: > > Marc does have a document that you can use to calculate the > differences. > http://www.verticalpower.com/docs/Pricing_Analysis.pdf > > I would be interested in seeing if somebody has taken the time to > complete > the worksheet to see where it came out. > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly > McMullen > Sent: Friday, December 14, 2007 5:47 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: VP-200 Update > > > Any thoughts as to cost of the VP-200 vs conventional breakers and > somebody else's engine monitor/analyzer? > > ________________________________________________________________________________
Date: Dec 14, 2007
OK, is this the "saving" by spending or are you saying that if you had not installed the VP-200 you would have installed $8,245 ($6,495+$1,750) worth of wiring, breakers and devices? This, I find hard to believe. And there is the tell; this product is a GREAT deal for a reseller. It allows them to add another high value item to the customer cost that saves THEM the reseller time in wiring. Don't get me wrong, I think this would also be great for those that have never or had little or no experience wiring an aircraft also. But you would have had to have slept through economics class for the VP-200 to save the end user money over a conventional design. The ket fob and automation features are compelling however for a VFR aircraft. William http://wcurtis.nerv10.com/ -------- Original Message -------- > > I have done the worksheet and I found that either unit saved me about > $1,750 in parts (flap positioning system, trim relays, switches, > breakers, etc.). As Stein told me when I talked to him about it, it > really comes into play a lot when you start calculating the amount of > time it saves. I think that someone who has never wired a plane can > handle doing it with this a LOT easier than the traditional way. When > it comes time to add something, which you will very possibly do even > before you get the plane flying, you can just add that to the > spreadsheet and run a wire from a pin on J3-J6 and set it up in the > menus. It also gives you a lot easier point to start to build the > wiring harness outside the plane as one piece and just slide it in > (minus some of the big wires, of course). I have now wired 3 > airframes with this and am very happy with how easy it is to plan- > harness-install. After next weekend anybody who wants to come by X35 > for a ground demo, I would be happy to do it. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > On Dec 14, 2007, at 8:00 PM, Bob Leffler wrote: > > > > > Marc does have a document that you can use to calculate the > > differences. > > http://www.verticalpower.com/docs/Pricing_Analysis.pdf > > > > I would be interested in seeing if somebody has taken the time to > > complete > > the worksheet to see where it came out. > > > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly > > McMullen > > Sent: Friday, December 14, 2007 5:47 PM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: VP-200 Update > > > > > > Any thoughts as to cost of the VP-200 vs conventional breakers and > > somebody else's engine monitor/analyzer? > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 14, 2007
Subject: Fw: fuel prices along chart
Here is a neat link someone posted on the SoCal VAF yahoo list that may come in handy when looking for a cheaper $100 burger location. http://www.seattleavionics.com/FuelPrices.shtml#FuelPrices Pascal ________________________________________________________________________________
Date: Dec 14, 2007
That is not a savings of $1,750 beyond the cost of the unit, but rather towards the cost of the unit, according to my calculations. As I mentioned, "it really comes into play a lot when you start calculating the amount of time it saves" on wiring. For those who want to take the time as in many other aspects of the plane, then it would only be a benefit if they would otherwise pay someone to wire their plane because they don't feel they are up to the task of wiring for whatever reason. Yes, it can be a great deal for a reseller/ installer because of the time savings, but I am actually making the point that would hurt a reseller, that it makes the wiring easy enough that more people can do it that would otherwise not want to mess with the wiring, and I know there are a lot of people like that (how many on the list have done or plan to do all of their wiring except the standard wiring harnesses for things like radios and other instruments?). For the completely budget conscious person who is comfortable doing the wiring, then this is not the way to go. For them just going with a couple of fuse blocks and half a dozen cheap switches is the cheapest way to go. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Dec 14, 2007, at 9:57 PM, William Curtis wrote: > > OK, is this the "saving" by spending or are you saying that if you > had not installed the VP-200 you would have installed $8,245 ($6,495+ > $1,750) worth of wiring, breakers and devices? This, I find hard to > believe. And there is the tell; this product is a GREAT deal for a > reseller. It allows them to add another high value item to the > customer cost that saves THEM the reseller time in wiring. Don't > get me wrong, I think this would also be great for those that have > never or had little or no experience wiring an aircraft also. But > you would have had to have slept through economics class for the > VP-200 to save the end user money over a conventional design. The > ket fob and automation features are compelling however for a VFR > aircraft. > > William > http://wcurtis.nerv10.com/ > > -------- Original Message -------- >> >> >> I have done the worksheet and I found that either unit saved me about >> $1,750 in parts (flap positioning system, trim relays, switches, >> breakers, etc.). As Stein told me when I talked to him about it, it >> really comes into play a lot when you start calculating the amount of >> time it saves. I think that someone who has never wired a plane can >> handle doing it with this a LOT easier than the traditional way. >> When >> it comes time to add something, which you will very possibly do even >> before you get the plane flying, you can just add that to the >> spreadsheet and run a wire from a pin on J3-J6 and set it up in the >> menus. It also gives you a lot easier point to start to build the >> wiring harness outside the plane as one piece and just slide it in >> (minus some of the big wires, of course). I have now wired 3 >> airframes with this and am very happy with how easy it is to plan- >> harness-install. After next weekend anybody who wants to come by X35 >> for a ground demo, I would be happy to do it. >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> Cell: 352-427-0285 >> Fax: 815-377-3694 >> >> On Dec 14, 2007, at 8:00 PM, Bob Leffler wrote: >> >>> >>> Marc does have a document that you can use to calculate the >>> differences. >>> http://www.verticalpower.com/docs/Pricing_Analysis.pdf >>> >>> I would be interested in seeing if somebody has taken the time to >>> complete >>> the worksheet to see where it came out. >>> >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly >>> McMullen >>> Sent: Friday, December 14, 2007 5:47 PM >>> To: rv10-list(at)matronics.com >>> Subject: Re: RV10-List: VP-200 Update >>> >>> >>> >>> Any thoughts as to cost of the VP-200 vs conventional breakers and >>> somebody else's engine monitor/analyzer? >>> >>> >>> >>> >>> >> >> > > ________________________________________________________________________________
Date: Dec 14, 2007
Bob I am going with the VP200. I am also using an Approach Systems faststack (see http://www.approachfaststack.com/index.html) to do the wiring interconnects between the various boxes. Between these two systems, I expect my wiring chores to be manageable. My reason for using the VP20 was I wanted to make the power side of the wiring as simple as possible I saw the unit at KOSH and was very impressed. I was also impressed that people such as Stein spoke highly of the product. Stein has a great rep within the -10 community so I give a lot of weight to his recommendation. There are a lot of things that are built into the box such as being able to identify and isolate electrical problems very quickly. The box also handles failures such as load shedding based on either or IFR or VFR rules if there is an alternator failure. It will turn the boost pump on if the main fuel pump fails. It will wig wag lights. If will control trim tab speed based on the mode of flight. It will allow the trim controls on the co-pilots stick to be disabled at the push of a button. It will provide audible warnings for various error conditions such as a door being ajar. Many of not all of these conditions can be duplicated using other products. This would require however, the integration of different products which may be complicated. I want to do my own wiring and as I readily admit I am a rank amateur at this, I want it to be as simple and fool/idiot proof as possible. I also think that the panel will be safer and easier to troubleshoot. In fact, in most cases I expect that the VP200 will zero in on the problem for me. Unlike most -10 builders, I am going the "alterative engine" route and am installing an Eggenfellner E6TI engine. This means my electrical system needs to be bullet proof because no electrical system means the fan upfront stops and I start to sweat. I believe that the VP200 will provide the level of reliability I want. They have a wiring scheme specific to the Egg engine which has been "blessed" by Jan Eggenfellner. As for convincing your wife, I suggest you use my technique - keep in mind that both my wife and I are accountants (she being far better than me). Anyway, I just say it is needed "for safety reasons". She then makes some derogatory remark about my "plane math" and walks away. As far as costs are concerned, I keep all my receipts in a box. When the C-GCWZ first flies, I plan to burn the box and forget the cost. Cheers Les #40643 PS: Seriously though. Download the user manual / install manuals for the VP200 and have a good read. Understand what the VP200 really can do and I think you will be pleasantly surprised. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: December-14-07 5:51 PM Subject: RE: RV10-List: VP-200 Update Les, Are you going with the 100 or 200? I'm still struggling with the price/value of the unit. Having met Marc and team at Michael Sausen's house before OSH and listening to him explain the system, it is certainly a great product. I think I would want to go with the 200, but am having difficulties justifying the expense to myself, let alone my wife. Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Friday, December 14, 2007 5:50 PM Subject: RE: RV10-List: VP-200 Update Hmmm I have a couple of long conversations with Marc Ausman of Vertical Power over the past couple of weeks. I have decided to use their product after seeing it at KOSH and reading the online docs. I like the idea of eliminating the traditional bus / breaker arrangement for something that is a more sophisticated. One of the nice things about their system is that it builds in capabilities that would otherwise require integration of other boxes. Things like trim sensitivity, landing light wig wags, door alarms / annuciators / low voltage warnings / audible alarms / etc. If VP's post sales support is even half of what the pre-sales support is like, they will be a great company to deal with. Cheers Les Kearney #40643 C-GCWZ (reserved) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: December-14-07 3:13 PM Subject: RV10-List: VP-200 Update We are ready to fly, just awaiting the permission from the Ecuadorian "FAA". Those of us who live and fly in the US sure have it good. You have to have permission to spit in the air down here. As an update on the Vertical Power system that some are interested in hearing, we have it up and running and mostly configured. It so far is a fantastic way to handle the electrical system, from initial wiring to setting flaps and wiring trims. With the trim settings, if you have it wired backwards, you can just flip it in the menus and it changed direction. The flaps allow you to set up, down and two intermediate positions if you have an indicator (enter the Ray Allen position sensor), so if you want up, 0, 10 and 30 instead of up, 0, 15 and 30, that's no problem. I don't think they have implemented the trim sensitivity option yet, but it will soon be possible to automatically slow down the trims in cruise and speed them back up in slow flight and pattern work. Adding circuits, like we added for pumps from wingtip tanks to the mains, is super easy. Just pick an open pin, run a wire and set it up in the menu. They are right now debugging the reading from the Dynon EMS to help with the automatic mode switching (we are the first ones running on a Dynon with the VP), but the GPS info from the 430 is already on there to do some of the mode switching. Each device can be set up to come on automatically in any mode, including preflight, so you could have it turn on a Garmin 496 during preflight to go ahead and start downloading the weather. Overall, I am so far very impressed with both the functionality, the ease of installation, the great documentation and the quick and thorough tech support in getting things running. I just wish all of the possibilities were already implemented in the software. That will come. For the record, I am not affiliated with Vertical Power, but I am one of their dealers, which I will continue to be as long as they keep up the good work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com __________ NOD32 2724 (20071214) Information __________ ________________________________________________________________________________
Subject: Composite School - helpful advice please (Doors/Cabin top)
Date: Dec 14, 2007
I am presently fitting my doors. I have the latch pins and gas struts installed and cannot get the doors to fit perfectly. The doors fit nice and tight at the top (with some shims) and at the bottom with the latching pins. (Rivithead set is very slick) But the middle of the door is unsatisfactory Essentially the door bows outward in the middle more than the cabin top by about 1/16-1/8 inch. It seems evident that the solution is to build up the cabin top at the front windshield flange and at the area between the door and the rear window. The best advice that I have received so far is from Gus at Van's who suggested that I saturate foam with epoxy and shape it to the area and then cover it with a thin coat of fabric saturated with epoxy. I was also warned not to use ANY polyester/bondo products on the cabin top. Any advice here will be appreciated -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152296#152296 ________________________________________________________________________________
Subject: Re: heavy wing with fairings
Date: Dec 15, 2007
I had the same situation on mine and in my case I determined that it was just in need of right rudder trim. I installed a 7" long static rudder trim piece and the problem went away. So once figured out it was a simple fix. Wayne Edgerton N602WT Someone locally is flying his RV-10 and noticed the following I thought I would challenge the fliers with: What I noticed is at faster speeds the heavy right wing is more noticeable. Need to figure out what is causing the heavy wing as it relates to the fairings. Any suggestions? Slower speeds not noticeable. Pascal ________________________________________________________________________________
Subject: Re: AOA in your RV-10?
Date: Dec 15, 2007
I've got an AOA Pro in my (not quite flying yet) panel. Alex DeDominicis also has an AOA Pro in his RV-10 that he uses for transition training. I just flew with him last week and it was great! The wing kit consists of a pair of UMHW "pressure taps" and the associated tubing. There isn't really anything special about the taps - they just give you a way to connect the tubing to the small hole in the upper & lower holes that you drill in the wing. Upper port also has a fitting for draining any water that might collect. The tubing is colored 1/8" Tygon. Kit also includes install instructions, labels for the ports and some other misc. stuff - not sure if it also includes the switch for flap position or not. There's probably some cost saving potential but in the end you'd spend a fair amount of time trying to replicate what AFS sells and wouldn't end up with the same quality. I personally would consider fabricating my own wing kit any more than I'd fab my own heated pitot tube. Bob #40105 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152317#152317 ________________________________________________________________________________
Date: Dec 15, 2007
Typo - I would NOT fab the AOA wing kit any more than I'd considering fab of a heated pitot tube instead of buying one. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152318#152318 ________________________________________________________________________________
Date: Dec 15, 2007
Eric, I have installed two AOAs in my RV-10 still under construction. I looked at all the options out there and decided on the Dynon heated pitot with AoA. Listed at $450 but it'll be $600 by the time you buy the Gretz mount and other stuff (it's still an excellent pitot tube). Obviously that means there will be a Dynon somewhere on the panel. The other AOA I purchased is called a Lift Reserve Indicator made by InAir Instruments. It is purely mechanical and used a round dial gauge that I plan on mounting on my glareshield. I think I paid $400 for it at Oshkosh. You probably wonder why two - simple, I was a Navy jet jock many years ago and learned to trust it above everything else. The Dynon, InAir, and the AFS use the same principle of differential air pressure. The Dynon and InAir are under the wing and protected from rain while parked. The AFS uses a hole on top of the wing which requires a drain port to check during preflight. I've seen a few airplanes out there with a Vane on the wingtip that would do the job as well, but I was worried about its susceptibility to damage by people passing by who couldn't resist turn it. You can build your own, as well. Here is a site where someone did: http://www.ch601.org/resources/aoa/aoa.htm The principle is real simple: two air ports at different angles to the airstream. If more air is coming through the upper one, you're going fast. You could actually just hook them up to red and green balloons in the cockpit. When the red one gets bigger than the green, you should drop the nose. Calibrating something like that would be funny to watch but you get the drift. One additional point; the Dynon heated tube gives me IFR capability and the Dynon EFIS will give me the required aural stall warning. I didn't install the Vans Stall Warning device because of that. Hope this helps John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152344#152344 ________________________________________________________________________________
Date: Dec 15, 2007
If you can trim the edge of the door any more so it fits a little below grade, that might reduce the 1/8" high to more like 1/16". In other words, split the difference so the thickest filler is only 1/16, some where the door is low and some where the top is low. That should be pretty managable. We ended up putting about that much flox putty around the opening to bring the level up a bit. We used flox because I was concerned that filler wouldn't hold up in such a high traffic area. The best filler for other areas that we've used is Superfil. ACS P/N 09-28250. It's epoxy and it takes a long time to cure (12 hours!) but it works and lasts great. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com N921AC 50 hrs, currently at the paint shop -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Friday, December 14, 2007 10:50 PM Subject: RV10-List: Composite School - helpful advice please (Doors/Cabin top) I am presently fitting my doors. I have the latch pins and gas struts installed and cannot get the doors to fit perfectly. The doors fit nice and tight at the top (with some shims) and at the bottom with the latching pins. (Rivithead set is very slick) But the middle of the door is unsatisfactory Essentially the door bows outward in the middle more than the cabin top by about 1/16-1/8 inch. It seems evident that the solution is to build up the cabin top at the front windshield flange and at the area between the door and the rear window. The best advice that I have received so far is from Gus at Van's who suggested that I saturate foam with epoxy and shape it to the area and then cover it with a thin coat of fabric saturated with epoxy. I was also warned not to use ANY polyester/bondo products on the cabin top. Any advice here will be appreciated -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152296#152296 ________________________________________________________________________________
Subject: Re: NACA Vents
Date: Dec 15, 2007
On Dec 14, 2007, at 7:10 AM, Fred Williams, M.D. wrote: > > I spent roughly $1500. Came with all the lights and vents. Here's a > web site. > accuracy avionics We bought the whole kit, too. It would have been much cheaper without the lights, eyeball vents, and switches, but probably no net savings once you bought all that stuff. OTOH, you could pick the lights and switches you wanted. We think we like the lights, but "we shall see" when it comes time to fly at night. The vents are particularly nice. Nonetheless we would consider the bare plenum "next time". Tony at Accuracy may be rethinking the switches, I think. Because we're mounting an antenna in the "DVD" area, we've cut in a couple more access hatches. We also "customized" the area in the front center to accept grommets for antennae. Turns out we're using those grommets for other wires because we didn't want to cut into the structural shell above the pilots' heads for GPS antennae. Also, in order to fit our particular airplane, the plenum needed to be completely cut away and re-fitted in the area of the "joggle" between the thicker and thinner parts of the shell, and at the aft end we needed to cut off the flange. We made a "plate" to extend the bulkhead and serve as a doubler for the SCAT tube fittings at the back of the baggage compartment. This allowed the corrugated panel to be cut away to fit around the plenum, and still be removable and replaceable. Photos available offline by email. Installing NACA vents with the tail cone, but not the cabin top, in position was pretty easy. Nobody seems to know an ideal position, so we just copied what others have used with apparent success. We mounted them right behind the baggage area, and roughly midway between the longeron and stiffener. Marlys and John 40458 > ________________________________________________________________________________
Date: Dec 15, 2007
Hey John, The InAir (and Dynon) is a great deal cheaper than the AFS. Does the AFS AOA have any benefits over InAir? regards, cjay johngoodman wrote: > Eric, > I have installed two AOAs in my RV-10 still under construction. I looked at all the options out there and decided on the Dynon heated pitot with AoA. Listed at $450 but it'll be $600 by the time you buy the Gretz mount and other stuff (it's still an excellent pitot tube). Obviously that means there will be a Dynon somewhere on the panel. > The other AOA I purchased is called a Lift Reserve Indicator made by InAir Instruments. It is purely mechanical and used a round dial gauge that I plan on mounting on my glareshield. I think I paid $400 for it at Oshkosh. > > You probably wonder why two - simple, I was a Navy jet jock many years ago and learned to trust it above everything else. The Dynon, InAir, and the AFS use the same principle of differential air pressure. The Dynon and InAir are under the wing and protected from rain while parked. The AFS uses a hole on top of the wing which requires a drain port to check during preflight. > I've seen a few airplanes out there with a Vane on the wingtip that would do the job as well, but I was worried about its susceptibility to damage by people passing by who couldn't resist turn it. > > You can build your own, as well. Here is a site where someone did: http://www.ch601.org/resources/aoa/aoa.htm The principle is real simple: two air ports at different angles to the airstream. If more air is coming through the upper one, you're going fast. You could actually just hook them up to red and green balloons in the cockpit. When the red one gets bigger than the green, you should drop the nose. Calibrating something like that would be funny to watch but you get the drift. > > One additional point; the Dynon heated tube gives me IFR capability and the Dynon EFIS will give me the required aural stall warning. I didn't install the Vans Stall Warning device because of that. > > Hope this helps > > John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152444#152444 ________________________________________________________________________________
Date: Dec 15, 2007
There is absolutely nothing wrong with the AFS system from my point of view. I just prefer to have the probes under the wing. The hole on top is a water collection problem, that's all (easy to put a cover on pitot tubes and LRI probes). Cost is also a factor. However, I will say that I find most of the cockpit displays too colorful and complex for my tastes. Too much interpretation of what the little colored chevrons mean. That's why I like an analog dial - just like the Navy. The red/amber/green colors originate from the chevron light indicator that was in the carrier jets (only used for landings). The pilot only saw (from top to bottom) an inverted red chevron, an amber circle, or a green chevron (slow changes would show two lights). What the Navy pilot was seeing was the same thing as the lights on the nose wheel that the LSO (Landing Signal Officer) saw. In a simple example, he could tell if you were pulling up the nose without power because the lights would start blinking from amber to amber/red, or red. Since you asked, I read through the calibration process of the AFS product and found it a little complex. Calibration is still required for any of them, but I liked the InAir the best. Since I didn't want to cut into my QB wings to put in Van's stall warning, the Dynon system seemed to fill all the squares - a heated pitot, and an aural stall warning that was based on a system I knew and trusted. I still wanted a genuine analog dial, so I also chose InAir and put it on the other wing. The advantage of an analog dial is that I will be able to calibrate Maneuvering, L over D max, Best Glide, Best Range, etc., and put marks on the dial face. To give an example, the guy who always won in ACM (air combat maneuvering - dogfighting) always kept the high g turn right on L over D Max. Since the gauge was on the upper left of the panel, a savvy Air Force guy could force you into right turns and take the advantage away, I'm sad to say.... John cjay wrote: > Hey John, > > The InAir (and Dynon) is a great deal cheaper than the AFS. Does the AFS AOA have any benefits over InAir? > > regards, > > cjay > -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152452#152452 ________________________________________________________________________________
Subject: oil canning.
Date: Dec 15, 2007
I remember reading a post a few weeks ago about this but I don't recal the location of the problem I closed up the bottom of one wing today and I am quite surprised to find s o much oil canning on the skins just aft of the main spar. I used clecos in every hole and I followed the directions, starting from the location indic ated and moving forward and inward and outward at the same time. Aside from a few blemishes, I thought I had done a fairly good job, but compared to w hat the rest of the quickbuild wing looks like, I would say I am missing so me thing. I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin. Any body want to admit to having a similar finding. Thanks JOhn G. 409 ________________________________________________________________________________
Date: Dec 16, 2007
Hey John, Previous post was probably from me. I had oil canning in the VS and rudder . Tore down and rebuilt the VS - it is now much better. Oil canning in th e rudder was due to not enough bend applied to the leading edge which place s too much stress on the skins behind the spar. Removed the LP4-3s and ref ormed by hand and re-rivetted. Only a small oil can in one panel now. Thi s is a lesson for those about to build their rudder - once initially formed , the bend is quite easy to finish by hand forming. Do not try and pull th e skins together with clecoes and then rivet. Oil canning will result. I rivetted my bottom wing skins solo. One panel oil cans aft of the main s par (midway between the outboard inspection holes). The rest are tight as a drum. I noticed the skins tighten a fair bit as I neared the end of the r ivetting sequence per plans. cheers Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of John Gonzalez Sent: Sun 16/12/2007 16:06 Subject: RV10-List: oil canning. I remember reading a post a few weeks ago about this but I don't recal the location of the problem I closed up the bottom of one wing today and I am quite surprised to find s o much oil canning on the skins just aft of the main spar. I used clecos in every hole and I followed the directions, starting from the location indic ated and moving forward and inward and outward at the same time. Aside from a few blemishes, I thought I had done a fairly good job, but compared to w hat the rest of the quickbuild wing looks like, I would say I am missing so me thing. I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin. Any body want to admit to having a similar finding. Thanks JOhn G. 409 "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Subject: collision avoidance
Date: Dec 16, 2007
After two near misses in or above the CHD class D within the last three months, I would like to hear from anyone who uses the Zaon MRX or XRX. I currently have the MRX and it provides distance and relative altitude separation. Bearing it lacks. The XRX is supposed to provide all. On both misses, I believe the MRX got my attention (although I don't specifically recall) and I spotted traffic between 11:45 and 12:15 at 1/4 mile and eithor <100 above and >100<200 below me. In one instance I jammed the stick forward and lifted the tool box in the rear from the floor. On both occasions I was monitoring CHD tower and no advisories were issued. From what I could tell both of the other aircraft were missed approachs or departures from CHD. When traveling through or above CHD class D, I advise "don't expect anything from CHD tower" and reduce to maneuvering speed. Incidentially I am currently flying the Glastar but will put some PCAS in my 10 when it flies in 1st quarter. Ryan TCAD is out (too expensive); Garmin 330 is out (have G327 and mode S is becoming obsolete). ________________________________________________________________________________
Subject: Statistical Sample
Date: Dec 16, 2007
It looks from the attached information (which Tim began) that the total fleet hours are now at 21,000. If you are willing to update the info or add your flying RV-10 to the mix, then send me the data and I will add it. John Cox #40 <> 600 ________________________________________________________________________________
Subject: Aeroduct vs. Scat Tubing
Date: Dec 16, 2007
I have been thinking a lot about the oil cooling temp issues for the -10. Some have chosen to upgraded the oil cooler. I have an interest in controlling the oil temps by improving the air flow to the box and them adding a gate in the oil cooler housing that will allow me to restrict the air flow to the oil cooler in cold weather. (photo attached) I am considering swapping out the standard Scat Tubing for Silicone lined high temp Aeroduct hose. I have purchased this hose for my OH Console to replace the hearting scat tubes. It's nice stuff! My thinking is that this duct is much smoother and significantly less corrugated that scat tubing which SHOULD improve airflow to the oil cooler. The down side is that this ducting is only sold in 12 foot lengths at $150 / 12 feet. I probably need 2 feet. My other concept is to take two 3" tubes from the baffling (one on each side of the engine, I prefer this symmetry) and have both of these 3" tubes feed the oil cooler box. I don't know if I will have room to run a 3" duct from the right side on the engine to the oil cooler mounted in the typical location. To further complicate things I will be using the James Cowl & Plenum. I would appreciate any observations on using the smooth Silicone lined Aeroduct hose vs. Scat Tube and or comments on two 3" tubes/duct vs. the one larger tube/duct. Thanks, Robin Thinking of an RV-8A...Mental illness runs in my family. http://www.hrpworld.com/index.cfm?form_prod_id=3171&action=product&fo rm_ cat_id=59,7 ________________________________________________________________________________
Subject: Re: collision avoidance
Date: Dec 16, 2007
I have the XRX that I used in my 182 till I sold it last year to build the new RV10. So far I am impressed with the unit and probably more important - the company. The unit is not an excuse for heads down VFR flying. View it as a tool in your tool box of avionics I find that the delay is significant on the unit, but being aware of that gives you a lot of what you need to know anyway. The Xaon people are very nice. My unit is going back to them this week for a FREE software/firmware upgrade so that it will link to my GPS496 unit and display on the display of the GPS496. Can you get a better deal than that for TCAS for less than $2K. Jason (the president of Xaon) is aways at OSH and is very approachable. Last year he told me that he would trade my XRX in at full value when they come out with their hard wired installation. He might even do the same on an MRX to XRX upgrade. -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152541#152541 ________________________________________________________________________________
Date: Dec 16, 2007
Robin, that's a most interesting landing gear leg and brake assembly (shown). You will find many advantages to the course you are pursuing. LoPresti would be please with your acknowledgement on air flow control. Let me know how much you have left, I would be interested, Too. I am looking at an improved flow path over the stock configuration. John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, December 16, 2007 11:14 AM Subject: RV10-List: Aeroduct vs. Scat Tubing I have been thinking a lot about the oil cooling temp issues for the -10. Some have chosen to upgraded the oil cooler. I have an interest in controlling the oil temps by improving the air flow to the box and them adding a gate in the oil cooler housing that will allow me to restrict the air flow to the oil cooler in cold weather. (photo attached) I am considering swapping out the standard Scat Tubing for Silicone lined high temp Aeroduct hose. I have purchased this hose for my OH Console to replace the hearting scat tubes. It's nice stuff! My thinking is that this duct is much smoother and significantly less corrugated that scat tubing which SHOULD improve airflow to the oil cooler. The down side is that this ducting is only sold in 12 foot lengths at $150 / 12 feet. I probably need 2 feet. My other concept is to take two 3" tubes from the baffling (one on each side of the engine, I prefer this symmetry) and have both of these 3" tubes feed the oil cooler box. I don't know if I will have room to run a 3" duct from the right side on the engine to the oil cooler mounted in the typical location. To further complicate things I will be using the James Cowl & Plenum. I would appreciate any observations on using the smooth Silicone lined Aeroduct hose vs. Scat Tube and or comments on two 3" tubes/duct vs. the one larger tube/duct. Thanks, Robin Thinking of an RV-8A...Mental illness runs in my family. http://www.hrpworld.com/index.cfm?form_prod_id=3171&action=product&fo rm_ cat_id=59,7 ________________________________________________________________________________
Subject: The Greenies are Coming
Date: Dec 16, 2007
Nothing fall through the cracks. We let it happen through our own apathy or failure to clearly communicate our desires. It is a two way street. One of the authors of our latest fiasco was even a major radio talk show host and aviator. Oh the blasphemy. Oregon is now acknowledging that in an effort to please our Left leaning Governor, Senators and Representatives we would try to keep Oregon as the farthest left of logical states on the Western Seaboard (and that's no easy task with California so progressive). Everyone is now willing to admit the language was poorly written, incompetently researched and hastily passed. The lessons for all pilots (Everywhere) is to keep abreast of legislative trends. This same one is coming to a state near you, sooner that you're ready for it. Montana took a pre-emptive effort to protect the supply of Non Ethanol AVGAS throughout their distribution system. Oregon is trying to correct the widespread damage by leaving a provision for a new distribution and new sale of 91 octane Non Adulterated MOGAS for use in aircraft using an EAA or Peterson sponsored STC. The difficulty is that MOGAS does not stay as a "fresh consumable" as long as AVGAS. It lacks stabilizers. The supply of this product is not likely to gain market viability. The new loophole would permit FBO's to buy another fuel tank, pay another licensing fee, track another fuel source for sale and then try to find a distributor to bring very small boutique quantities of this new 91 Octane MOGAS to airports around our state on a frequent basis. Try to imagine the Supply and Demand model for very small quantity distribution (less than 5,000 gals) to your favorite airport. On a second front, they are redefining the descriptor for AVGAS to protect its cleanliness and not further disrupt our state based <> aircraft and aviation industries. We are still trying to jumpstart the Ethanol Industry before Iowa, Nebraska and the Great Heartland takes away all our business with our middle eastern brethren. Attached you may read the latest developments to try and stem the damage that has now been done. Before making cross country flights, research the grade and availability of your favorite fuel. Not just its price. Stay aware of your local legislative issues. John Cox #40600 Legislative Affairs for the Oregon Pilots Association ________________________________________________________________________________
Date: Dec 16, 2007
Subject: Re: Aeroduct vs. Scat Tubing
Kind of a side note as we're talking about cooling and air flow. I took my cowling off last week and noticed that the aluminum shielding I had applied to the bottom cowling had been peeled up just underneath the oil cooler. Now I can't say for sure, but this seems to indicate that the air is flowing forwa rd in this location; probably not the most efficient flow pattern. Possibly additional louvers in this location may help. I have the stock oil cooler with a stock installation. You might notice I'v e added a few extra louvers on the bottom cowl. I've also added a "dryer vent " exhaust on the exit side of the oil cooler (see photo). My hope is this would help the air exiting the oil cooler to more smoothly mix with the exi ting air. I have no hard data to back up whether these were actual improvements in air flow; however I'll say that my oil temp and CHTs have become lower and more manageable with the changes. -Jim 40134 - Flying In a message dated 12/16/2007 2:27:23 P.M. Eastern Standard Time, robin1(at)mrmoisture.com writes: I have been thinking a lot about the oil cooling temp issues for the -10. Some have chosen to upgraded the oil cooler. I have an interest in control ling the oil temps by improving the air flow to the box and them adding a gate i n the oil cooler housing that will allow me to restrict the air flow to the oil cooler in cold weather. (photo attached) I am considering swapping out the standard Scat Tubing for Silicone lined high temp Aeroduct hose. I have purchased this hose for my OH Console to replace the hearting scat tubes. It=99s nice stuff! My thinking is th at this duct is much smoother and significantly less corrugated that scat tubing which SHOU LD improve airflow to the oil cooler. The down side is that this ducting is only sold in 12 foot lengths at $150 / 12 feet. I probably need 2 feet. My other concept is to take two 3=9D tubes from the baffling (one on each side of the engine, I prefer this symmetry) and have both of these 3=9D tu bes feed the oil cooler box. I don=99t know if I will have room to run a 3 =9D duct from the right side on the engine to the oil cooler mounted in the typical location. To further complicate things I will be using the James Cowl & Plenum. I would appreciate any observations on using the smooth Silicone lined Aeroduct hose vs. Scat Tube and or comments on two 3=9D tubes/duct vs . the one larger tube/duct. Thanks, Robin Thinking of an RV-8AMental illness runs in my family. Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: wing tip
Date: Dec 16, 2007
I'm about to fit the wingtips to the wing, and I need to determine the neutral aileron position to align and trim the length of the trailing edge of the tip with the aileron. Does the neutral position that is set with the rigging of the wing bellcrank give a true neutral, or does the aileron need to be set to trail with the flap for a accurate neutral position? On the RV8, I had to wait until the wing was mounted to the fuselage, install the flaps and rig to full up, then adjust the aileron trail to the flap trail to get a true neutral. Am I better off waiting until this scenario on the 10 as well? Chris Hukill (what, more fiberglass!) ________________________________________________________________________________
Subject: Re: wing tip
Date: Dec 16, 2007
On my 6A, I had an airfoil template that I used for the ailerons, flaps and tip - even prior to inatallation of the wing to the fuse - and it hasn't needed to be changed since I installed the wing. I was planning to do the same again...... ----- Original Message ----- From: Chris Hukill To: rv10-list(at)matronics.com Sent: Sunday, December 16, 2007 8:06 PM Subject: RV10-List: wing tip I'm about to fit the wingtips to the wing, and I need to determine the neutral aileron position to align and trim the length of the trailing edge of the tip with the aileron. Does the neutral position that is set with the rigging of the wing bellcrank give a true neutral, or does the aileron need to be set to trail with the flap for a accurate neutral position? On the RV8, I had to wait until the wing was mounted to the fuselage, install the flaps and rig to full up, then adjust the aileron trail to the flap trail to get a true neutral. Am I better off waiting until this scenario on the 10 as well? Chris Hukill (what, more fiberglass!) ________________________________________________________________________________
Date: Dec 16, 2007
High pressure and cooler air from the upper plenum escapes through the oil heat exchanger and collides with the downflow past the cooling fins on the port side. It is a great example of the burble generated from the collision of air masses. It may also indicate an adhesion problem between the film and the lower cowl finish coating. John Cox 40600 - dreaming ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com Sent: Sunday, December 16, 2007 4:49 PM Subject: Re: RV10-List: Aeroduct vs. Scat Tubing Kind of a side note as we're talking about cooling and air flow. I took my cowling off last week and noticed that the aluminum shielding I had applied to the bottom cowling had been peeled up just underneath the oil cooler. Now I can't say for sure, but this seems to indicate that the air is flowing forward in this location; probably not the most efficient flow pattern. Possibly additional louvers in this location may help. I have the stock oil cooler with a stock installation. You might notice I've added a few extra louvers on the bottom cowl. I've also added a "dryer vent" exhaust on the exit side of the oil cooler (see photo). My hope is this would help the air exiting the oil cooler to more smoothly mix with the exiting air. I have no hard data to back up whether these were actual improvements in air flow; however I'll say that my oil temp and CHTs have become lower and more manageable with the changes. -Jim 40134 - Flying In a message dated 12/16/2007 2:27:23 P.M. Eastern Standard Time, robin1(at)mrmoisture.com writes: I ha ve been thinking a lot about the oil cooling temp issues for the -10. Some have chosen to upgraded the oil cooler. I have an interest in controlling the oil temps by improving the air flow to the box and them adding a gate in the oil cooler housing that will allow me to restrict the air flow to the oil cooler in cold weather. (photo attached) I am considering swapping out the standard Scat Tubing for Silicone lined high temp Aeroduct hose. I have purchased this hose for my OH Console to replace the hearting scat tubes. It's nice stuff! My thinking is that this duct is much smoother and significantly less corrugated that scat tubing which SHOULD improve airflow to the oil cooler. The down side is that this ducting is only sold in 12 foot lengths at $150 / 12 feet. I probably need 2 feet. My other concept is to take two 3" tubes from the baffling (one on each side of the engine, I prefer this symmetry) and have both of these 3" tubes feed the oil cooler box. I don't know if I will have room to run a 3" duct from the right side on the engine to the oil cooler mounted in the typical location. To further complicate things I will be using the James Cowl & Plenum. I would appreciate any observations on using the smooth Silicone lined Aeroduct hose vs. Scat Tube and or comments on two 3" tubes/duct vs. the one larger tube/duct. Thanks, Robin Thinking of an RV-8A...Mental illness runs in my family. Jim "Scooter" McGrew http://www.mit.edu/~jsmcgrew ________________________________ See AOL's top rated recipes <http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004> and easy ways to stay in shape <http://body.aol.com/fitness/winter-exercise?NCID=aoltop00030000000003> for winter. ________________________________________________________________________________
Date: Dec 16, 2007
Chris, Other's will have to chime in, especially those flying. When I did my wing tips I used the "neutral jig" which sets the aileron neutral position, checked and aligned the flaps to the ailerons and then set my wing tip trailing edges to the ailerons. I believe I had the "old version" of wing tips as they were about 3/4" longer than the aileron, but none the less, I had to cut the upper and lower wing tip surface at the trailing edge to pull the wing tip into alignment with the aileron. I used a long straight edge to align the wing tip to the aileron and used it as a clamping jig while the resin dried. I remeber cutting about 3" forward from the trailing edge to give the upper and lower tip skin some compliance so I could easily align it with the aileron. When I was done it came out swell. Here's a picture when it was all done. -Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Subject: Re: oil canning.
Date: Dec 16, 2007
JOhn, You got my attention. I'll be closing up my QB wings in a week or two and I've noticed a little "slop" in the open ribs, especially in the middle, when I tried to precut the pitot mount hole. I'm guessing about two bays outside the last inspection port, right? John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152605#152605 ________________________________________________________________________________
Date: Dec 16, 2007
I would get it all in the wing rack and get the flaps installed so they're all the way retracted, and then align the ailerons to them and then mount the wingtip so it aligns with the flaps and ailerons. That way when you're in cruise it's all lined up nicely. If you just did it rough now, chances are it won't be aligned well later and you may end up with the famous "droopy aileron" syndrome have to deal with that later. Tim Olson - RV-10 N104CD - Flying Chris Hukill wrote: > I'm about to fit the wingtips to the wing, and I need to determine the > neutral aileron position to align and trim the length of the trailing > edge of the tip with the aileron. Does the neutral position that is set > with the rigging of the wing bellcrank give a true neutral, or does the > aileron need to be set to trail with the flap for a accurate neutral > position? On the RV8, I had to wait until the wing was mounted to the > fuselage, install the flaps and rig to full up, then adjust the aileron > trail to the flap trail to get a true neutral. Am I better off waiting > until this scenario on the 10 as well? > > Chris Hukill > (what, more fiberglass!) > > ________________________________________________________________________________
Subject: wingtip
Date: Dec 16, 2007
Here's one more wingtip picture from the alignment process. -Bob Newman ________________________________________________________________________________
Subject: wingtip
Date: Dec 16, 2007
Chris, I found one more picture. This was with the straight edge clamped to the trailing edge of the aileron and wingtip as the resin hardened. -Bob Newman ________________________________________________________________________________
Date: Dec 16, 2007
Thanks Ron, I had completed last night the rivetting of the bottom wing skin completing step 11, section 20-5. As I stated, I noted the large amount of oil cannin g in the squares aft of the main spar and I stopped. This morning I removed the rivets that are forward of the J stiffner, all the way to the spar and the skin released with no seen tweeks. What I am having trouble understanding is that eventhough the rib flanges h ave been crimped, the ribs seem to be loaded with pressure and they need to be pulled into alignment with the skin holes. These pr loads seem to be wh at is causing the oil canning. Studing the ribs without the skin indicates that the pulling force each rib exerts is in the opposite direction from the direction the flange is facin g. Where the plans have us start is the centerpoint where both rib's pullin g forces are coming together, directed toward one another(which means loose skin). Perhaps if I would have proceeded the skin may have gotten tighter toward the completion of step 12, as you suggested, but I was reluctant to proceed. Step 11 really doesn't spell out the order too well in how to rivet the ski n to the underlying structure. It says nothing about how to proceed forward of the J stiffner. I presume the entire J stiffner needs to be rivetted pr ior to moving forward toward the main spar, no clecos forward of the J stif fner, this allows us to get our hand up under the skin to access the J stif fner. After it is rivetted, I presume we need to cleco the remaining struct ure closed and access the interior from the access holes. Sorry for the long post just don't want to have to drill these rivets out a gain. I seems so strange building structures which have these preloads on them an d then asking another preloaded member to cancel the other out. I seem to n ever get over this and how we are using controlled collisions to build stru cture. Next plane will be fiberglass. Thanks for any suggestions other than quiting, JOhn G. ________________________________________________________________________________
Date: Dec 16, 2007
When you are joining adjacent skins you should trim the edge so that there is about a .020 gap when clecoed in place; this will allow the riveted skin to expand to fill the gap. If the skins fit tightly before riveting there will be excess metal to oil can. You can also see the ridge where the skins join. Addtionally you can cleco the skin every other hole and lock the skin in place before making a second pass and finishing the job. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, December 16, 2007 6:48 PM Subject: RV10-List: Re: oil canning. --> JOhn, You got my attention. I'll be closing up my QB wings in a week or two and I've noticed a little "slop" in the open ribs, especially in the middle, when I tried to precut the pitot mount hole. I'm guessing about two bays outside the last inspection port, right? John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152605#152605 ________________________________________________________________________________
Date: Dec 17, 2007
Bob, That is one sweet workshop! Jim C (40192) =========================================================== From: "Bob-tcw" <rnewman(at)tcwtech.com> Date: 2007/12/16 Sun PM 08:37:53 EST Subject: Re: RV10-List: wing tip Chris, Other's will have to chime in, especially those flying. When I did my wing tips I used the "neutral jig" which sets the aileron neutral position, checked and aligned the flaps to the ailerons and then set my wing tip trailing edges to the ailerons. I believe I had the "old version" of wing tips as they were about 3/4" longer than the aileron, but none the less, I had to cut the upper and lower wing tip surface at the trailing edge to pull the wing tip into alignment with the aileron. I used a long straight edge to align the wing tip to the aileron and used it as a clamping jig while the resin dried. I remeber cutting about 3" forward from the trailing edge to give the upper and lower tip skin some compliance so I could easily align it with the aileron. When I was done it came out swell. Here's a picture when it was all done. -Bob Newman TCW Technologies www.tcwtech.com =========================================================== ________________________________________________________________________________
Date: Dec 17, 2007
In a message dated 12/16/2007 1:30:04 PM Central Standard Time, pitts_pilot(at)bellsouth.net writes: Playing Devils Advocate here ...... you were outside of their controlled airspace. Class D is advisory for traffic not control as in Class Alpha or Bravo.... P **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 17, 2007
Subject: Re: prop
Tip damage sounds a lot like prop strike. I wouldn't touch it. -Jim Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew In a message dated 12/17/2007 9:08:23 A.M. Eastern Standard Time, pitts_pilot(at)bellsouth.net writes: --> RV10-List message posted by: linn Walters It's time to plead ignorance here! I have a good friend trying to unload a CS prop ..... rarther cheaply. Has minor tip damage :-( I don't know if it'll be any good on an IO-540 or not. It's a Hartzell HC 624K-4CF Case # (hub?) 2960 and blades #s FC 7666A2 He just called and eht email was up so I decided to query and then google Hartzell. TIA Linn do not archive _ (http://www.mit.edu/~jsmcgrew) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: wing tip
Date: Dec 17, 2007
I just got off the phone to Vans, and was told that the rig on the 10 is to put the flaps all the way up against the hard stops at the rear spar, which is the reflex position, then rig the aileron to trail with the flaps, then the tip to the aileron. The bellcrank jig is used only to center the bellcrank, not to rig the aileron. Thanks to all. Chris Hukill ________________________________________________________________________________
Subject: Christmas
Date: Dec 17, 2007
This was hijacked from Van's Airforce Gary 40274 The Twelve Days of an RV Builders Christmas Its late. Youre behind. Your spouse is standing there tapping his or her foot because you havent provided a Christmas list yet. You havent even started a list because you have been busy working on your RV. (You also havent started your Christmas shopping because your RV consumes your life but we cant help you out of that sort of trouble!) You need help. You need a list, and you need it now! We are here to help! We offer here an amended version of that old holiday classic saluting the Twelve Days of Christmas. Not having much use for calling birds or maids a milking, and being more than a little concerned about the effects on weight and balance of ten Lords a leaping (do they affect gross weight while in midleap?), we felt that a more appropriate shopping list needed to be developed especially with the builder in mind. Maybe by leaving this ditty around the house, a few last minute presents might be generated. In an effort to be concise in communications, we will forego the multitude of verses leading to the final approach fixso here is the twelfth day! On the twelfth day of Christmas, my true love sent to me Twelve silver clecos leven truss head screws Ten rolls of duct tape Nine Scotchbright pads Eight cans of primer Seven nylon tie-wraps Six hi-temp lock nuts Five bucking bars Four dimple dies Three rivet sets Two quickbuild wings And a slow-build fuselage Happy Holidays from Paul and Louise! __________________ Paul F. Dye RV-8 - N188PD - "Valkyrie" - 630+ Hours! TMX-0360 (180 HP), Hartzell Blended Airfoil, GRT EFIS panel VAF #35 EAA Tech Counselor/Flight Advisor Nassau Bay, TX
Gary
40274
Talkinghttp://www.vansairforce.com/community/images/icons/icon10.gif" border=0> The Twelve Days of an RV Builders Christmas
In an effort to be co ncise in communications, we will forego the multitude of verses leading to the final approach fixso here is the twelfth day!
Five bucking bars
Four dimple dies
Three rivet sets
__________________
Paul F. Dye
VAF #35
Nassau Bay, TX
Date: Dec 17, 2007
Subject: VP-200 Update
They are a start up. History shows that you.... a) shouldn't be excited to be first to deploy and b) don't put down a large deposit. :-) Cheers, Jay Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Dec 18, 2007
Subject: Re: Statistical Sample
John, Just back from Stein putting in the SL30.............turned 125 hours. Got pics of Dynon LOP with all 6 cylinders on our O 540 at several power settings going to MSP and back cruising at 10000 ft. Dean _____________________________________________________________ We support your cause! Click now for great support hosiery! http://thirdpartyoffers.juno.com/TGL2111/fc/Ioyw6iifpk7t9LyZHBVVAuVAbNJ1 tijSXv2BPMkSCpEzXItjrLkfec/ ________________________________________________________________________________
Date: Dec 17, 2007
DEAN, WOULD LOVE TO SEE YOUR PICS AND PERFORMANCE FIGURES IF U DON'T MIND SHARING. THANKS, DOUG PRESTON N372RV -----Original Message----- From: ddddsp1(at)juno.com <ddddsp1(at)juno.com> Sent: Mon, 17 Dec 2007 6:31 pm Subject: Re: RV10-List: Statistical Sample John, Just back from Stein putting in the SL30.............turned 125 hours.? Got pics of Dynon LOP with all 6 cylinders on our O 540 at several power settings going to MSP and back cruising at 10000 ft. ? Dean _____________________________________________________________ We support your cause! Click now for great support hosiery! ________________________________________________________________________ ________________________________________________________________________________
Date: Dec 17, 2007
And on one of the occasions he said he was above the class D...hence in class E. On Dec 17, 2007 6:54 AM, wrote: > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > pitts_pilot(at)bellsouth.net writes: > Playing Devils Advocate here ...... you were outside of their controlled > airspace. > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > P > > > ________________________________ > See AOL's top rated recipes and easy ways to stay in shape for winter. > > ________________________________________________________________________________
Date: Dec 17, 2007
This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Dec 17, 2007
Just a couple of comments on this. Most people I have talked to have rarely, if ever, actually had any water in their AFS AOA. It also comes preloaded with an RV-10 profile so while it does need to be calibrated to your specific aircraft, it's at least useable out of the box. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, December 15, 2007 7:46 PM Subject: RV10-List: Re: AOA in your RV-10? There is absolutely nothing wrong with the AFS system from my point of view. I just prefer to have the probes under the wing. The hole on top is a water collection problem, that's all (easy to put a cover on pitot tubes and LRI probes). Cost is also a factor. However, I will say that I find most of the cockpit displays too colorful and complex for my tastes. Too much interpretation of what the little colored chevrons mean. That's why I like an analog dial - just like the Navy. The red/amber/green colors originate from the chevron light indicator that was in the carrier jets (only used for landings). The pilot only saw (from top to bottom) an inverted red chevron, an amber circle, or a green chevron (slow changes would show two lights). What the Navy pilot was seeing was the same thing as the lights on the nose wheel that the LSO (Landing Signal Officer) saw. In a simple example, he could tell if you were pulling up the nose without power because the lights would start blinki! ng from amber to amber/red, or red. Since you asked, I read through the calibration process of the AFS product and found it a little complex. Calibration is still required for any of them, but I liked the InAir the best. Since I didn't want to cut into my QB wings to put in Van's stall warning, the Dynon system seemed to fill all the squares - a heated pitot, and an aural stall warning that was based on a system I knew and trusted. I still wanted a genuine analog dial, so I also chose InAir and put it on the other wing. The advantage of an analog dial is that I will be able to calibrate Maneuvering, L over D max, Best Glide, Best Range, etc., and put marks on the dial face. To give an example, the guy who always won in ACM (air combat maneuvering - dogfighting) always kept the high g turn right on L over D Max. Since the gauge was on the upper left of the panel, a savvy Air Force guy could force you into right turns and take the advantage away, I'm sad to say.... John cjay wrote: > Hey John, > > The InAir (and Dynon) is a great deal cheaper than the AFS. Does the AFS AOA have any benefits over InAir? > > regards, > > cjay > -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152452#152452 ________________________________________________________________________________
Subject: dreaded oil canning lessened
Date: Dec 17, 2007
Tonight I re rivetted the bottom skin all the way to but not including the last the ribs. I never had a problem aft of the J channel, the skin was tig ht. I did as suggested and removed about 1/32" to 1/16" off the edge where the seem is joining the LE skin. This time I hop scotched each rivet, jumping f rom rib to rib, one horizontal row at a time. I basically numberred each ve rtical row of holes with the order I would rivet them in, doing my best to cancel each rib's spring loaded force out. Because of the access panels and our ability to get inside the wing, rib flanges are turned out board or in board in pairs. I never rivetted a pair together. It seemed to have helped but I am hoping that after I rivet the remaining t hree out board ribs it will be even tighter as Ron suggested his did. One thing for certain, I wish I was as proficient at rivetting on the rear spar area, where I started as I am now. Got a few blemishes up in those are as. The small square faced bucking bar worked best with some heave plumbers tap e wrapped a lot of times, overhanging the the square face by about1/8". Thi s helps soften the blows form any miss alignment hits, no internal dammage and it also helps sensory issue of finding your rivet and the center of the bucking bar face. Lastly, you can push the face of the bucking bar flat ag ains the face of the interior skin and your rivet is less likey to come com pletely out. This make keeping the face of the BB parallel to the inside sk in easier. Tonight I learned how to push the rivet back and forth between t he bucking bar face and the flush set on the gun and get a real good feel f or the pressure needed and the center of the bar face by how it rocks on th e rivet. Interesting little tid bit of info. The plumbers tape is the real trick JOhn G ________________________________________________________________________________
Subject: OAT probe location
Date: Dec 17, 2007
Has anyone installed their OAT probe on a wing? If so, where and how? I want to make this decision before I close my wings. Dave Leikam 40496 N89DA reserved ________________________________________________________________________________
Date: Dec 18, 2007
Hi Dave, I mounted mine in a rubber grommet in the right wing centre inspection plat e. cheers, Ron 187 Moving to the hangar !! -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of Dave Leikam Sent: Tue 18/12/2007 16:14 Subject: RV10-List: OAT probe location Has anyone installed their OAT probe on a wing? If so, where and how? I w ant to make this decision before I close my wings. Dave Leikam 40496 N89DA reserved "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Dec 17, 2007
Note: The Reserve Lift Indicator is calibrated by flying, stalling, landing and adjusting the probe--flying, stalling, landing and adjusting - flying, stalling........ However, once installed it has worked as advertised. My problem is and has been the indicator needle. I cannot see it in the last twenty feet during landing. My peripheral vision doesn't pick up the indicator needle( mount ed on the Glare Shield) when I need it. This may be my problem as I am a l ow time pilot with a high pilot load during landing.I intend to install the AOA Sport next, I intend to mount the LED display on the Glare Shield and monitor the color change with peripheral vision. > From: rvbuilder(at)sausen.net> To: rv10-list(at)matronics.com> Date: Mon, 17 De sen.net>> > Just a couple of comments on this. Most people I have talked to have rarely, if ever, actually had any water in their AFS AOA. It also com es preloaded with an RV-10 profile so while it does need to be calibrated t o your specific aircraft, it's at least useable out of the box.> > Michael> > -----Original Message-----> From: owner-rv10-list-server(at)matronics.com [ mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman> Sent : Saturday, December 15, 2007 7:46 PM> To: rv10-list(at)matronics.com> Subject hngoodman" > > There is absolutely nothing wrong with the AFS system from my point of view. I just prefer to have the probe s under the wing. The hole on top is a water collection problem, that's all (easy to put a cover on pitot tubes and LRI probes). Cost is also a factor . However, I will say that I find most of the cockpit displays too colorful and complex for my tastes. Too much interpretation of what the little colo red chevrons mean. That's why I like an analog dial - just like the Navy. T he red/amber/green colors originate from the chevron light indicator that w as in the carrier jets (only used for landings). The pilot only saw (from t op to bottom) an inverted red chevron, an amber circle, or a green chevron (slow changes would show two lights). What the Navy pilot was seeing was th e same thing as the lights on the nose wheel that the LSO (Landing Signal O fficer) saw. In a simple example, he could tell if you were pulling up the nose without power because the lights would start blinki!> ng from amber to amber/red, or red.> > Since you asked, I read through the calibration proc ess of the AFS product and found it a little complex. Calibration is still required for any of them, but I liked the InAir the best. Since I didn't wa nt to cut into my QB wings to put in Van's stall warning, the Dynon system seemed to fill all the squares - a heated pitot, and an aural stall warning that was based on a system I knew and trusted. I still wanted a genuine an alog dial, so I also chose InAir and put it on the other wing. The advantag e of an analog dial is that I will be able to calibrate Maneuvering, L over D max, Best Glide, Best Range, etc., and put marks on the dial face. To gi ve an example, the guy who always won in ACM (air combat maneuvering - dogf ighting) always kept the high g turn right on L over D Max. Since the gauge was on the upper left of the panel, a savvy Air Force guy could force you into right turns and take the advantage away, I'm sad to say....> John> > > > cjay wrote:> > Hey John,> >> > The InAir (and Dynon) is a great deal che aper than the AFS. Does the AFS AOA have any benefits over InAir?> >> > reg ards,> >> > cjay> >> > > --------> #40572 QB Wings, QB Fuse arrived> N711JG reserved> > > > > Read this topic online here:> > http://forums.matronics. ========================> _ ====================> > > ________________________________________________________________________________
Subject: Re: OAT probe location
Date: Dec 18, 2007
I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing. David Maib 40559 On Dec 17, 2007, at 11:44 PM, Dave Leikam wrote: Has anyone installed their OAT probe on a wing? If so, where and how? I want to make this decision before I close my wings. Dave Leikam 40496 N89DA reserved ________________________________________________________________________________
Date: Dec 18, 2007
I don't know of the plumbers tape but I have found that the following tape is excellent for holding rivets in place, holding small pieces of baffling material to the bucking bars and general composite work. It does not leave a residue and does not stick to fiberglass resin/epoxy. http://www.uline.com/Browse_Listing_6090.asp?pricode=wi830 <http://www.uline.com/Browse_Listing_6090.asp?pricode=wi830&wcw=google> &wcw=google _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Monday, December 17, 2007 10:12 PM Subject: RV10-List: dreaded oil canning lessened Tonight I re rivetted the bottom skin all the way to but not including the last the ribs. I never had a problem aft of the J channel, the skin was tight. I did as suggested and removed about 1/32" to 1/16" off the edge where the seem is joining the LE skin. This time I hop scotched each rivet, jumping from rib to rib, one horizontal row at a time. I basically numberred each vertical row of holes with the order I would rivet them in, doing my best to cancel each rib's spring loaded force out. Because of the access panels and our ability to get inside the wing, rib flanges are turned out board or in board in pairs. I never rivetted a pair together. It seemed to have helped but I am hoping that after I rivet the remaining three out board ribs it will be even tighter as Ron suggested his did. One thing for certain, I wish I was as proficient at rivetting on the rear spar area, where I started as I am now. Got a few blemishes up in those areas. The small square faced bucking bar worked best with some heave plumbers tape wrapped a lot of times, overhanging the the square face by about1/8". This helps soften the blows form any miss alignment hits, no internal dammage and it also helps sensory issue of finding your rivet and the center of the bucking bar face. Lastly, you can push the face of the bucking bar flat agains the face of the interior skin and your rivet is less likey to come completely out. This make keeping the face of the BB parallel to the inside skin easier. Tonight I learned how to push the rivet back and forth between the bucking bar face and the flush set on the gun and get a real good feel for the pressure needed and the center of the bar face by how it rocks on the rivet. Interesting little tid bit of info. The plumbers tape is the real trick JOhn G ________________________________________________________________________________
Subject: Re: VP-200 Update
Date: Dec 18, 2007
> They are a start up. History shows that you.... a) shouldn't be excited to be first to deploy and b) don't put down a large deposit. > > Cheers, > Jay > All true. New products and companies, particularly those involved in aviation, should always be viewed with caution -- Caveat Emptor. However, in the case of Vertical Power, they only bill when ready to ship and they are shipping products -- this isn't vaporware. I know because I have a VP-200 and a wiring harness sitting in my workshop. Marc and crew have also been very responsive to questions and requests for support. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152868#152868 ________________________________________________________________________________
Subject: bottom wing skin
Date: Dec 18, 2007
After reading this thread about oil canning of the OB bottom skins, I took a good look at mine, that are clecoed on, but not yet dimpled. I see considerable oil canning, and the forward edge of the skin is tight against the forward skin and actually overlapping it slightly in some areas. I obviously need to trim some off the aft skin, but short of blazing away with a file, I wonder if anyone knows a way to remove this material and leave a smooth, strait edge. I have not put a preload bend in the skin as you would with an overlapping skin, but I wonder if that would shrink it as well? The plans don't instruct you to put the preload bend even on the inboard edge where it overlaps the IB skin, but I assume that's just an oversight? Any suggestions? Chris Hukill ________________________________________________________________________________
Date: Dec 18, 2007
Subject: Re: bottom wing skin
I passed a file over then polished the leading edge and tank skins=C2-par t of the skins until they fit against the wing skins. I also put the preloa d bend on the skind to allow it to lay as flat as possible after they were riveted.. My wings are in B-21 Chris if you want to take a look someday. Rick Sked 49185 ----- Original Message ----- From: "Chris Hukill" <cjhukill(at)cox.net> Sent: Tuesday, December 18, 2007 8:12:06 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: bottom wing skin After reading this thread about oil canning of the OB bottom skins, I took a good look at mine, that are clecoed on, but not yet dimpled. I see consid erable oil canning, and the forward edge of the skin is tight against the f orward skin and actually overlapping it slightly in some areas. I obviously need to trim some off the aft skin, but short of blazing away with a file, I wonder if anyone knows a way to remove this material and leave a smooth, strait=C2-edge. I have not put a preload bend in the skin as you would with an overlapping skin, but I wonder if that would shrink it as well? The plans don't instruc t you to put the preload bend even on the inboard edge where it overlaps th e IB skin, but I assume that's just an oversight? Any suggestions? ============== ==== ======================= ________________________________________________________________________________
Date: Dec 18, 2007
I installed mine on the wing 18" outside the tip of the propeller in an inspection plate. Drilled a small hole and sealed with Proseal, added a connector for servicing. No issues. Bill DeRouchey N939SB, flying David Maib wrote: I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing. David Maib 40559 On Dec 17, 2007, at 11:44 PM, Dave Leikam wrote: Has anyone installed their OAT probe on a wing? If so, where and how? I want to make this decision before I close my wings. Dave Leikam 40496 N89DA reserved http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 18, 2007
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Chris; Have you considered a "v" notched deburring tool? Should trim off a couple thousandths each pass. A good fine file is probably the best . Also, if you take a sharpie and put and run it and your finger down the edge before you trim, it gives you a line to thin down to see how much you took off. I'd just recommend going slow with the a file and then rounding the edges with the v tool. Dr Fred. Chris Hukill wrote: > After reading this thread about oil canning of the OB bottom skins, I > took a good look at mine, that are clecoed on, but not yet dimpled. I > see considerable oil canning, and the forward edge of the skin is > tight against the forward skin and actually overlapping it slightly in > some areas. I obviously need to trim some off the aft skin, but short > of blazing away with a file, I wonder if anyone knows a way to remove > this material and leave a smooth, strait edge. > I have not put a preload bend in the skin as you would with an > overlapping skin, but I wonder if that would shrink it as well? The > plans don't instruct you to put the preload bend even on the inboard > edge where it overlaps the IB skin, but I assume that's just an > oversight? Any suggestions? > Chris Hukill > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Dec 18, 2007
Take a long coarse file and run it lengthwise along the edge of the skin. Finish with the file held at a 45 degree angle along the inside and outside edges to debur. Jeff Carpenter 40304 On Dec 18, 2007, at 8:12 AM, Chris Hukill wrote: > After reading this thread about oil canning of the OB bottom skins, > I took a good look at mine, that are clecoed on, but not yet > dimpled. I see considerable oil canning, and the forward edge of > the skin is tight against the forward skin and actually overlapping > it slightly in some areas. I obviously need to trim some off the > aft skin, but short of blazing away with a file, I wonder if anyone > knows a way to remove this material and leave a smooth, strait edge. > I have not put a preload bend in the skin as you would with an > overlapping skin, but I wonder if that would shrink it as well? The > plans don't instruct you to put the preload bend even on the > inboard edge where it overlaps the IB skin, but I assume that's > just an oversight? Any suggestions? > Chris Hukill > > ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Date: Dec 18, 2007
On my RV-9A I installed the OAT probe in the left inboard access panel. It works great and it is removable for inspections and whatever. There are a few pictures here: http://www.my9a.com/finish15.asp#090905 Regards, Mike Schipper RV-10 #40576 - Fuse - www.rvten.com 0559 On Dec 17, 2007, at 11:44 PM, Dave Leikam wrote: Has anyone installed their OAT probe on a wing? If so, where and how? I want to make this decision before I close my wings. Dave Leikam 40496 N89DA reserved ________________________________________________________________________________
Date: Dec 18, 2007
As per taking material off the edge that joins to the LE skin, place a stra ight edge about 1/16" above the edge and mark it with a sharpie. I used a V ixen file and trimmed about 1/32" off. Rivetting across in horizontal rows and moving forward as I discussd in the previous post brought the edge tig ht with no gap. There is a point where you can take too much material off, remember the dim pled holes on the skin still have to line up with the countersunk holes in the spar cap. I noticed that my skin holes were slightly forward of the the se countersunk holes in the spar cap...so you can go to far and you won't g ain anything, only a gap in between the skins. I did not pre bend the skin at the inboard overlap. It layed absolutely fla t with the inboard skin when rivetted. I don't see how this would take up a ny slack. All the dimples still need to basically line up. In my mind it seems that only couteracting these loaded ribs in rivetting o rder and thinking about how an offset dimple reacts to its dimpled breather en, is the only way to tighten the skin. The above vixen file does absolute ly help to a limited extent. John G. From: cjhukill(at)cox.netTo: rv10-list(at)matronics.comSubject: RV10-List: bottom wing skinDate: Tue, 18 Dec 2007 08:12:06 -0800 After reading this thread about oil canning of the OB bottom skins, I took a good look at mine, that are clecoed on, but not yet dimpled. I see consid erable oil canning, and the forward edge of the skin is tight against the f orward skin and actually overlapping it slightly in some areas. I obviously need to trim some off the aft skin, but short of blazing away with a file, I wonder if anyone knows a way to remove this material and leave a smooth, strait edge. I have not put a preload bend in the skin as you would with an overlapping skin, but I wonder if that would shrink it as well? The plans don't instruc t you to put the preload bend even on the inboard edge where it overlaps th e IB skin, but I assume that's just an oversight? Any suggestions? Chris Hukill ________________________________________________________________________________
Date: Dec 18, 2007
Yes, remeber to de bur the inner and outer edge with your preferred method. John G From: cjhukill(at)cox.netTo: rv10-list(at)matronics.comSubject: RV10-List: bottom wing skinDate: Tue, 18 Dec 2007 08:12:06 -0800 After reading this thread about oil canning of the OB bottom skins, I took a good look at mine, that are clecoed on, but not yet dimpled. I see consid erable oil canning, and the forward edge of the skin is tight against the f orward skin and actually overlapping it slightly in some areas. I obviously need to trim some off the aft skin, but short of blazing away with a file, I wonder if anyone knows a way to remove this material and leave a smooth, strait edge. I have not put a preload bend in the skin as you would with an overlapping skin, but I wonder if that would shrink it as well? The plans don't instruc t you to put the preload bend even on the inboard edge where it overlaps th e IB skin, but I assume that's just an oversight? Any suggestions? Chris Hukill ________________________________________________________________________________
Date: Dec 18, 2007
use a sanding block or compositie sanding block _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Tuesday, December 18, 2007 9:12 AM Subject: RV10-List: bottom wing skin After reading this thread about oil canning of the OB bottom skins, I took a good look at mine, that are clecoed on, but not yet dimpled. I see considerable oil canning, and the forward edge of the skin is tight against the forward skin and actually overlapping it slightly in some areas. I obviously need to trim some off the aft skin, but short of blazing away with a file, I wonder if anyone knows a way to remove this material and leave a smooth, strait edge. I have not put a preload bend in the skin as you would with an overlapping skin, but I wonder if that would shrink it as well? The plans don't instruct you to put the preload bend even on the inboard edge where it overlaps the IB skin, but I assume that's just an oversight? Any suggestions? Chris Hukill ________________________________________________________________________________
Subject: Strobe and Antenna Wire in Same Conduit
Date: Dec 18, 2007
Has anyone run their Strobe wire and Antenna wire in the same conduit? Results? Chuck ________________________________________________________________________________
Subject: Cooling tube on lightspeed ignition box?
Date: Dec 18, 2007
Hey all - I was monkeying around with the install of my LSE ignition box and in the instructions it says: On 6-cylinder systems, cooling air should be supplied to the box via the cooling port on the 15-pin connector side of the ignition module. For 6-cyl. systems that do not have a cooling port, contact LSE for this modification. Cooling is not required for 4-cyl. systems. I'm wondering how others routed cooling air into this small (3/8" ish) tube on the side of the unit? any suggestions? Thanks! cj www.perfectlygoodairplane.net <http://www.perfectlygoodairplane.net/> ________________________________________________________________________________
Date: Dec 18, 2007
Chris Hukill wrote: > snippety snip... I obviously need to trim some off the aft skin, but > short of blazing away with a file, I wonder if anyone knows a way to > remove this material and leave a smooth, strait edge.... A word in general about filing skin edges. I know that I didn't have a clue as to how to easily and quickly file down a skin edge using a file, particularly a Vixen file (whatever that is). Perhaps everyone else knows what they are talking about but I think a lot is taken for granted here. I still am not sure I understand how to properly use a file on a skin edge but someone took the time to explain via email and the technique I ended up using really works easily and quickly so I assume it may be close to the accepted and proper technique. I place the sheet on a table with the edge overhanging slightly and use a clamp or two or hold in place. Using a Vixen file from one of the tool houses, I lay the face of the file on the skin edge. I hold the file with one hand on the handle and one hand holding the tip. the length of the file is laid along the skin edge but at a slight angle (15 degrees maybe) so that my hands don't contact the sheet. Then a single, smooth stroke from one end to the other. If everything is held steady, a nice clean cut is made with a significant amount of aluminum removed. 1,2,or 3 strokes is enough to smooth most edges. Removal of 1/32" may only take 3 or 4 strokes (a wild ass guesstimate since I haven't measured before - John's technique for measuring sounds correct to me). Very little dressing is required afterwards to completely deburr the edge. An edge trimmer will work, or scotchbrite or abrasive paper for final dressing. My guess is that just about everyone commenting here knows how to do this but I know I didn't have a clue until someone clued me in. If someone wants a photo, send me an email. Bill "lifetime modeler, woodworker, wing profiler and tinkerer that is still learning to use basic hand tools while thinking about doing the QB skins" Watson Durham NC 40605 ________________________________________________________________________________
Subject: Favorite greasy belly cleaner ?
Date: Dec 18, 2007
(Its a little off topic since it relates to my RV-9) Do you guys have a favorite cleaner for the "greasy belly" ? I've heard of the Stoddard cleaner which is supposed to be pretty evil stuff. Simple Green apparently has issues if used on bare aluminum. There's such a range of products on Spruce that I don't know where to start ... Gerry http://www.n747wg.com (Haven't opened the box yet.) ________________________________________________________________________________
Date: Dec 18, 2007
The ADS-B transmitters were turned on in Salem, Oregon last Monday and are working in several eastern seaboard states from Florida through Washington, DC. Someone needs to break the stranglehold on Oregon based Garmin so that "Supply and Demand" makes this a more common of a collision avoidance system than $7K. The EFIS solution is being solved one RV-10 at a time. Till then, some are using ZAON patched to their GPS screen. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay Sent: Monday, December 17, 2007 8:29 PM Subject: RV10-List: Re: collision avoidance This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
Subject: Collision avoidance
Date: Dec 18, 2007
Speaking of the Zaon to the 496..... Anyone tried this yet? Is the resultant inset readable? I am seriously considering doing this, but only if I don't have to spend too much heads down time trying to read a tiny inset screen. Any experiences? John J 40328 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, December 18, 2007 2:44 PM Subject: RE: RV10-List: Re: collision avoidance The ADS-B transmitters were turned on in Salem, Oregon last Monday and are working in several eastern seaboard states from Florida through Washington, DC. Someone needs to break the stranglehold on Oregon based Garmin so that "Supply and Demand" makes this a more common of a collision avoidance system than $7K. The EFIS solution is being solved one RV-10 at a time. Till then, some are using ZAON patched to their GPS screen. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay Sent: Monday, December 17, 2007 8:29 PM Subject: RV10-List: Re: collision avoidance This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
Subject: Re: collision avoidance
Date: Dec 18, 2007
The methodology from the FED and the FAA is to transfer the infrastructure cost from an aging, (expensive to maintain) radar based IFR ATC system to one where the main cost is the components that are funded by the direct user in the aircraft in the ATC system. RSVM and Mode S were two such maneuvers. Awaiting Sen Lott's replacement to give direction to FAA funding after the first of the new year. Then 12 months before everything goes Topsy with the new 1600 Pennsylvania Avenue habitant. Would love to see a $3K box as an alternative to the GDL-90. You all built rack mounts for those, Right? John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, December 18, 2007 2:44 PM Subject: RE: RV10-List: Re: collision avoidance The ADS-B transmitters were turned on in Salem, Oregon last Monday and are working in several eastern seaboard states from Florida through Washington, DC. Someone needs to break the stranglehold on Oregon based Garmin so that "Supply and Demand" makes this a more common of a collision avoidance system than $7K. The EFIS solution is being solved one RV-10 at a time. Till then, some are using ZAON patched to their GPS screen. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay Sent: Monday, December 17, 2007 8:29 PM Subject: RV10-List: Re: collision avoidance This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
Date: Dec 18, 2007
Query Bruce Radke on his Zaon. John C -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Tuesday, December 18, 2007 2:53 PM Subject: RV10-List: Collision avoidance Speaking of the Zaon to the 496..... Anyone tried this yet? Is the resultant inset readable? I am seriously considering doing this, but only if I don't have to spend too much heads down time trying to read a tiny inset screen. Any experiences? John J 40328 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, December 18, 2007 2:44 PM Subject: RE: RV10-List: Re: collision avoidance The ADS-B transmitters were turned on in Salem, Oregon last Monday and are working in several eastern seaboard states from Florida through Washington, DC. Someone needs to break the stranglehold on Oregon based Garmin so that "Supply and Demand" makes this a more common of a collision avoidance system than $7K. The EFIS solution is being solved one RV-10 at a time. Till then, some are using ZAON patched to their GPS screen. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay Sent: Monday, December 17, 2007 8:29 PM Subject: RV10-List: Re: collision avoidance This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
Date: Dec 18, 2007
I bought the XRX; it arrives tomorrow. I did learn that , for me, it will be a standalone unit. To use and see on the GRT screen a serial port IN/OUT is required. It must be operating at 56KB. On my Sport EFISs, I don't have one to spare. I will advise the group after a couple of weeks of flying. The MRX and XRX will sit together on the glare shield of the Glastar. Only the XRX will sit atop the 10 panel. If they ever provide traffic to the Cheltons I may have traffic on them. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Tuesday, December 18, 2007 3:53 PM Subject: RV10-List: Collision avoidance Speaking of the Zaon to the 496..... Anyone tried this yet? Is the resultant inset readable? I am seriously considering doing this, but only if I don't have to spend too much heads down time trying to read a tiny inset screen. Any experiences? John J 40328 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, December 18, 2007 2:44 PM Subject: RE: RV10-List: Re: collision avoidance The ADS-B transmitters were turned on in Salem, Oregon last Monday and are working in several eastern seaboard states from Florida through Washington, DC. Someone needs to break the stranglehold on Oregon based Garmin so that "Supply and Demand" makes this a more common of a collision avoidance system than $7K. The EFIS solution is being solved one RV-10 at a time. Till then, some are using ZAON patched to their GPS screen. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay Sent: Monday, December 17, 2007 8:29 PM Subject: RV10-List: Re: collision avoidance This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
Date: Dec 18, 2007
will solve the rack mount when the need arises. My 30 years in the computer business (prior to retirement) always showed that a smaller, less expensive , more capable solution was due out next year. And it was (except when involving the Feds or FAA). But waiting for that meant I go without now. Perhaps the XRX only solves 90% of the possible traffic problem (transponder equipped and operating), my eyeballs and ATC radar (operating IFR) will have to do the remainder. After that we depend on the probability of two aircraft not operating in the same ocean of air at the same location and same time. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, December 18, 2007 4:05 PM Subject: RE: RV10-List: Re: collision avoidance The methodology from the FED and the FAA is to transfer the infrastructure cost from an aging, (expensive to maintain) radar based IFR ATC system to one where the main cost is the components that are funded by the direct user in the aircraft in the ATC system. RSVM and Mode S were two such maneuvers. Awaiting Sen Lott's replacement to give direction to FAA funding after the first of the new year. Then 12 months before everything goes Topsy with the new 1600 Pennsylvania Avenue habitant. Would love to see a $3K box as an alternative to the GDL-90. You all built rack mounts for those, Right? John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Tuesday, December 18, 2007 2:44 PM Subject: RE: RV10-List: Re: collision avoidance The ADS-B transmitters were turned on in Salem, Oregon last Monday and are working in several eastern seaboard states from Florida through Washington, DC. Someone needs to break the stranglehold on Oregon based Garmin so that "Supply and Demand" makes this a more common of a collision avoidance system than $7K. The EFIS solution is being solved one RV-10 at a time. Till then, some are using ZAON patched to their GPS screen. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay Sent: Monday, December 17, 2007 8:29 PM Subject: RV10-List: Re: collision avoidance This is a scenario where you would be hard pressed to beat ADS-B for traffic awareness. You are outside of radar control or controllers are too busy to notice; ADS-B would give you a clear picture of traffic (altitude, bearing, and direction) without ATC help. Unfortunately, most people don't understand it, and no one is using it yet. Not cheap enough yet either, the GDL-90 is about $7K and you need an EFIS/MFD that displays it. Also, ground station coverage is only on the east coast right now. cjay apilot2(at)gmail.com wrote: > And on one of the occasions he said he was above the class D...hence in class E. > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > pitts_pilot(at)bellsouth.net writes: > > Playing Devils Advocate here ...... you were outside of their controlled > > airspace. > > > > > > Class D is advisory for traffic not control as in Class Alpha or Bravo.... > > > > P > > > > > > ________________________________ > > See AOL's top rated recipes and easy ways to stay in shape for winter. > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=152823#152823 ________________________________________________________________________________
Subject: Re: Solvents. Was:Favorite greasy belly cleaner ?
Date: Dec 18, 2007
> Do you guys have a favorite cleaner for the "greasy belly" ? I've > heard of > the Stoddard cleaner which is supposed to be pretty evil stuff... Generally, organic solvents are to be treated with considerable respect. i.e. Don't breathe them. Don't get them on your skin. Some are _relatively_ innocuous, like ethanol. Some are downright dangerous, like benzene, acetonitrile, and a whole long list of others. However, _as_organic_solvents_go_, Stoddard solvent does not strike me as too bad. It's a lot like naphtha paint thinner, but it evaporates and flashes (catches fire) at a higher temperature and hence is much safer to use inside buildings. Chemically, it's a mixture of relatively non-reactive hydrocarbons. Ten to twenty percent of those hydrocarbons are aromatic (related to benzene and toluene, etc.), though, and that might reasonably cause some worry, especially about increasing the likelihood of contracting cancer. A quick and superficial Google search shows up several sites that appear to say there's no evidence for increased cancer risk due to Stoddard solvent exposure. Maybe. caveat emptor. Because of fire danger, it's a whole lot safer than using gasoline; similar to kerosene, I'd say. On the whole, it's good stuff, used properly. If we use solvents, (and, practically speaking, we must) we need each to set our own standards for exposure limits. There are OSHA limits that are useful in assessing comparative toxicity, but who can measure 1 ppm of something in the shop air? Not me! Flammability is pretty well known for most solvents. Your insurance company probably won't approve of most of them for fire reasons. As a used-to-be chemist, and a cancer survivor (probably caused by solvents, so they thought at the time) here are some personal standards. YMMV. It's worth your effort to establish your own. I'm not suggesting these are even acceptable. Disclaim, disclaim. I have no connection to anybody selling solvents except to occasionally buy some at the hardware store. 1. Use gloves every time you handle solvents, except maybe a quick alcohol wipe. That's triple true for epoxy work. I prefer nitrile gloves because they slow down most solvents better than other kinds of gloves that let you retain some finger sensitivity and dexterity. I think latex is next to useless against the solvents we use. 2. Don't use acetone, MEK, oil and grease remover or lacquer thinner indoors if you can help it. If you must spray paint indoors, open the garage doors. Outdoors, keep your snoot away from the vapors and your skin away from the liquids. 3. _Do not_use gasoline as a solvent indoors, and only very reluctantly outdoors. Get some Stoddard solvent if you're tempted to use gasoline. Acetone is a serious fire hazard to, as are many organic solvents. 4. A well-fitted (yes, fitted) respirator with a fresh activated carbon cartridge is very good at cutting solvent exposure, but completely impractical for me because of the difficulty of knowing the cartridge is effective. I have a supplied-air respirator which is much more practical and probably more effective, used correctly. I seldom use either. 5. Wipe up spills immediately, and put solvent-wetted paper towels where you don't breathe the vapors - outside mostly, sometimes in a closed container. Others have posted about Simple Green- the danger in the ordinary kind is that it contains a chemical base, and will thus expose aluminum to attack by dissolving its protective oxide layer. Even painted aluminum will have cracks in the paint, and liquids will pretty much all wick into cracks and crevices to do their nasty deeds and will be reluctant to come back out. The reformulated stuff is allegedly free of the problem. On Dec 18, 2007, at 3:35 PM, Gerry Filby wrote: > > (Its a little off topic since it relates to my RV-9) > > Do you guys have a favorite cleaner for the "greasy belly" ? I've > heard of > the Stoddard cleaner which is supposed to be pretty evil stuff. > Simple > Green apparently has issues if used on bare aluminum. There's such > a range > of products on Spruce that I don't know where to start ... > > Gerry > http://www.n747wg.com > (Haven't opened the box yet.) > > ________________________________________________________________________________
Date: Dec 18, 2007
Wow! You are at the Empacone and you have alredy purchased a VP-200. I wish I had such confidence in ANY piece of avionics. I'm at the Fuselage/Finish/Firewall Forward AND panel wiring and I know that I'm gonna install a GNS-430W but I still haven't ordered it yet. I guess you plan to build really fast. William http://wcurtis.nerv10.com/ -------- Original Message -------- > All true. New products and companies, particularly those involved in aviation, should always be viewed with caution -- Caveat Emptor. However, in the case of Vertical Power, they only bill when ready to ship and they are shipping products -- this isn't vaporware. I know because I have a VP-200 and a wiring harness sitting in my workshop. Marc and crew have also been very responsive to questions and requests for support. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone ________________________________________________________________________________
Subject: Re: Cooling tube on lightspeed ignition box?
Date: Dec 18, 2007
CJ, I bought a 3 port blower fan from Stein. I will use the other ports for the Avionics LRU's and one for the Lightspeed. Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153020#153020 ________________________________________________________________________________
Date: Dec 18, 2007
Since there is nothing proprietary about ADS-B, how does "Oregon based Garmin" have a "stranglehold?" William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > The ADS-B transmitters were turned on in Salem, Oregon last Monday and > are working in several eastern seaboard states from Florida through > Washington, DC. > > Someone needs to break the stranglehold on Oregon based Garmin so that > "Supply and Demand" makes this a more common of a collision avoidance > system than $7K. The EFIS solution is being solved one RV-10 at a time. > Till then, some are using ZAON patched to their GPS screen. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay > Sent: Monday, December 17, 2007 8:29 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: collision avoidance > > > This is a scenario where you would be hard pressed to beat ADS-B for > traffic awareness. You are outside of radar control or controllers are > too busy to notice; ADS-B would give you a clear picture of traffic > (altitude, bearing, and direction) without ATC help. > > Unfortunately, most people don't understand it, and no one is using it > yet. Not cheap enough yet either, the GDL-90 is about $7K and you need > an EFIS/MFD that displays it. > > Also, ground station coverage is only on the east coast right now. > > cjay > > > apilot2(at)gmail.com wrote: > > And on one of the occasions he said he was above the class D...hence > in class E. > > > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > > pitts_pilot(at)bellsouth.net writes: > > > Playing Devils Advocate here ...... you were outside of their > controlled > > > airspace. > > > > > > > > > Class D is advisory for traffic not control as in Class Alpha or > Bravo.... > > > > > > P > > > > > > > > > ________________________________ > > > See AOL's top rated recipes and easy ways to stay in shape for > winter. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=152823#152823 > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Favorite greasy belly cleaner ?
Date: Dec 18, 2007
What about good old Windex or 409? I do not know if either of these would hurt AL however. They are both good, mild grease cutters. Dave Leikam 40496 ----- Original Message ----- From: "Gerry Filby" <gerf(at)gerf.com> Sent: Tuesday, December 18, 2007 4:35 PM Subject: RV10-List: Favorite greasy belly cleaner ? > > (Its a little off topic since it relates to my RV-9) > > Do you guys have a favorite cleaner for the "greasy belly" ? I've heard > of > the Stoddard cleaner which is supposed to be pretty evil stuff. Simple > Green apparently has issues if used on bare aluminum. There's such a > range > of products on Spruce that I don't know where to start ... > > Gerry > http://www.n747wg.com > (Haven't opened the box yet.) > > > ________________________________________________________________________________
Date: Dec 18, 2007
Windex contains ammonia, which is bad for aircraft and plexi. IIRC 409 also is corrosive. On Dec 18, 2007 8:53 PM, Dave Leikam wrote: > > What about good old Windex or 409? I do not know if either of these would > hurt AL however. They are both good, mild grease cutters. > > Dave Leikam > 40496 > > ----- Original Message ----- > From: "Gerry Filby" <gerf(at)gerf.com> > To: > > Sent: Tuesday, December 18, 2007 4:35 PM > Subject: RV10-List: Favorite greasy belly cleaner ? > > > > > > (Its a little off topic since it relates to my RV-9) > > > > Do you guys have a favorite cleaner for the "greasy belly" ? I've heard > > of > > the Stoddard cleaner which is supposed to be pretty evil stuff. Simple > > Green apparently has issues if used on bare aluminum. There's such a > > range > > of products on Spruce that I don't know where to start ... > > > > Gerry > > http://www.n747wg.com > > (Haven't opened the box yet.) > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Joe Zac suggested WD-40 sometime back. Works great. Anh N591VU-115hrs In the middile of Condition Inspection ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Tuesday, December 18, 2007 11:23 PM Subject: Re: RV10-List: Favorite greasy belly cleaner ? > > > Windex contains ammonia, which is bad for aircraft and plexi. IIRC 409 > also is corrosive. > > On Dec 18, 2007 8:53 PM, Dave Leikam wrote: >> >> What about good old Windex or 409? I do not know if either of these >> would >> hurt AL however. They are both good, mild grease cutters. >> >> Dave Leikam >> 40496 >> >> ----- Original Message ----- >> From: "Gerry Filby" <gerf(at)gerf.com> >> To: >> >> Sent: Tuesday, December 18, 2007 4:35 PM >> Subject: RV10-List: Favorite greasy belly cleaner ? >> >> >> > >> > (Its a little off topic since it relates to my RV-9) >> > >> > Do you guys have a favorite cleaner for the "greasy belly" ? I've >> > heard >> > of >> > the Stoddard cleaner which is supposed to be pretty evil stuff. Simple >> > Green apparently has issues if used on bare aluminum. There's such a >> > range >> > of products on Spruce that I don't know where to start ... >> > >> > Gerry >> > http://www.n747wg.com >> > (Haven't opened the box yet.) >> > >> > >> > >> > >> > >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 19, 2007
Use Goop. The hand cleaner they sell at WallMart. The white color can. Have used it on my 6 for 10+ years without any ill effects. I figure if it is good enough for your hands, it is good enough for aluminum. Rob. On Dec 18, 2007, at 5:35 PM, Gerry Filby wrote: > > (Its a little off topic since it relates to my RV-9) > > Do you guys have a favorite cleaner for the "greasy belly" ? I've > heard of > the Stoddard cleaner which is supposed to be pretty evil stuff. > Simple > Green apparently has issues if used on bare aluminum. There's such > a range > of products on Spruce that I don't know where to start ... > > Gerry > http://www.n747wg.com > (Haven't opened the box yet.) > > ________________________________________________________________________________
Date: Dec 19, 2007
Well, yes and no. I'm not usually one for bleeding edge technology, but I'm confident in this product. Call me crazy. I was actually on a really good build pace, but had a little detour through Iraq that basically shut me down for a year. Anyway, I had the extra cash available so I went ahead and made the purchase as a welcome home present to myself. Now for the rest of my avionics, I'm like you, I won't commit until I'm actually getting close to being ready to work on the panel. I seem to change my mind daily as to what I'd like to have and what my budget can support. [Wink] Seriously, I have settled on a baseline panel (see attachment) and now I'm just evaluating the new products that come out to see if they warrant supplanting what I've already chosen. Cheers! -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153067#153067 Attachments: http://forums.matronics.com//files/grt_panel_18_dec_07_550.doc ________________________________________________________________________________
Date: Dec 19, 2007
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Chris, I made an adapter to reduce the standard 5/8" cooling tube down to 3/8 out of some sort of poly tubing that I found at a home improvement store. Seemed to work pretty well. Bob _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Tuesday, December 18, 2007 2:47 PM Subject: RV10-List: Cooling tube on lightspeed ignition box? Hey all - I was monkeying around with the install of my LSE ignition box and in the instructions it says: On 6-cylinder systems, cooling air should be supplied to the box via the cooling port on the 15-pin connector side of the ignition module. For 6-cyl. systems that do not have a cooling port, contact LSE for this modification. Cooling is not required for 4-cyl. systems. I'm wondering how others routed cooling air into this small (3/8" ish) tube on the side of the unit? any suggestions? Thanks! cj www.perfectlygoodairplane.net <http://www.perfectlygoodairplane.net/> ________________________________________________________________________________
Date: Dec 19, 2007
Todd Welcome back from Iraq. Your service is appreciated! As far as panels go, yours is a near clone of what I have in mind. Dual GRT / VP200 / Trutrak AP / PS Egineering / Garmin everything else. How are you planning to mount the two boxes over the tunnel? I have contemplated getting one of the fiberglass consoles but a also considering building something as well. What software are you using to layout your panel? If you are doing your own wiring, check out the FastStack from http://www.approachfaststack.com/. Cheers Les Kearney #40643 C-GCWZ (reserved) ----- Original Message ----- From: tsts4 <tsts4(at)verizon.net> Date: Wednesday, December 19, 2007 5:51 am Subject: RV10-List: Re: VP-200 Update > > Well, yes and no. I'm not usually one for bleeding edge > technology, but I'm confident in this product. Call me > crazy. I was actually on a really good build pace, but had > a little detour through Iraq that basically shut me down for a > year. Anyway, I had the extra cash available so I went > ahead and made the purchase as a welcome home present to > myself. Now for the rest of my avionics, I'm like you, I > won't commit until I'm actually getting close to being ready to > work on the panel. I seem to change my mind daily as to what I'd > like to have and what my budget can support. > [Wink] Seriously, I have settled on a baseline panel (see > attachment) and now I'm just evaluating the new products that > come out to see if they warrant supplanting what I've already chosen. > > Cheers! > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=153067#153067 > > > > > Attachments: > > http://forums.matronics.com//files/grt_panel_18_dec_07_550.doc > > > > > Lists This Month -- > (And Get Some AWESOME FREE Gifts!) > Click on > _- > = -Matt Dralle, List Admin. > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > > > > ________________________________________________________________________________
Subject: Console above tunnel
Date: Dec 19, 2007
Here's what I have done for the console above the tunnel ERic-- RV-10, 40014 N104EP How are you planning to mount the two boxes over the tunnel? I have contemp lated getting one of the fiberglass consoles but a also considering buildin g something as well. /9j/4AAQSkZJRgABAAEAtAC0AAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/APK8UAOTrQBMKQDDw1AC44zQAina2aALIPFIZXmffTQEdMQUALQAYoAUCkAo HPSgAzjgCgBRk0ADjAoAQfSgC7ZDKsDUSNImjH/q1rI0I74ZtiR2INNbhL4TOI+etTEcBTYhcUgD FAxcUAGKADFABigAxQAmKAFxQAYoEJigYGgAoAMUCCgYUAJTEQspOfagBEUk8cU2CJQu3ikhsnt1 3OoqJOxcS0Y6y5jWwgiBbB6VSZLQtqZPtJQ8qOOacthRWpWvQPtL445qobET3IB6VRIUCDFMAoAS gAoATFAB5g6DrStcdxgyXO78KdrCuOxTAMUAFABigBMUAGKAJAMUgGMMOp/CgBzDimBAeOTQAhBb rwPSgCawi3z8DgClIcUWy6eb5WRn1qUi2+hDIclmHRaCSnVkCqMmgDRsE4ZvwrKTNYI0tuABWJuc vXYcYo60ASA0AI1ACK2BQAEj0zQBLE2eCMUgBogFJFCAgxTAXFAC9KAFz6CgBKQDqAHBRQA4UhiO MimgGJwRQIu2pw5qJGkS2LlIhtOfwrO1y27DZbqOSJk5yRTSsxOV1YpsMEVoZiimIWkOwuKADFAB QAYoAMUAGKACgBMUALQAlMAoAKACgAoAKAEoEGKBjEQqTyMUAh2KEJk9udrA47VnI1gXCM1kbBH/ AKzpVWIG2u4XT5oexSsVLwHz3Pqa0htYxnuMhXMi1WxI0/eNAmJTEJQAGgAHPSgdhwjJ68Urj5RR An41PMVYRoOcg0+YXKIYiFzkGnzC5RgBJwOtMVhXjZACRjNFwsNoEFMBVHNIB+R60ARuRlfrQA4k EGmBCo3NnsOlAA3U0ITLulrhJHPAqJvoaQ7jIo4p52IzxzSfuoFqxbkBIiAMc4FC3HLYpYPpWhlq PQYoY7GrZptjT35rnkzeKLtQaHKkYrsOMUUAPBoADQA3FABigBwbFACmRsdaQDM0AFMBaAFAoAXO O1IAoAcDxn0oGPFIAI4poBqD5qALEI+epkVAmkUFc4rNOxckQL1rXoZDnHINSWPCj0piLNvbpKGy SMdMVLYy3b2MH/LZyPpUObKSRdOlWkkfyDHowOaj2j6l8i6FGfSJo8mPDr7datVCXApNEUOGUqfQ 1pciw3aPSgA2j0oANg9KBCFR6UAJtHpQAbRTATaKAEKigLBtoANooACoAoAh81ewNFhXJU2uMigY pQUANK0CZPaAFvwrORpEt9ayNivdZUAgkc9q0hqZTViKAkSfeP51UkKDHXQ3MKcRSFtYstnuKGwS I5YQsm0HFCYWHfZ1zjJ+tPmFykXlHNHMHKKIlHWlcfKOwB0FIewUhiUxBQAZpDEwKdxAwyuD0oTB kRi9DVXIsNKMO1O4uUXaQuadxWGEe1ADT98YFMBHJAwOM0AKi4FAIa/SgGWbW6SOHyypJOc1Eo6l Rehc023hZWlBb0IxWc3bQumuo/yY25aPOD3ouUkO8mJRxGuPpQmJpGWFzJgdzWl9DPqbEC4+gGKx lubRJqgs5Uiu04xMGgB68CgALUANzQAvWgBQKADHNAC4AoAO1AABg0AKR0pAKRQAUAKBnIFAyRVw BnikAvAHTP1oAjH36YizDww+tTIuJbkHy1n1NXsUyPmP1rVGTHMDt5qQHBgO9FhFywYEuB7VMii7 ioGKm+M5Rip9qLXEnYsR3zrxIob3HWocC1Msb7a6G1gpPowwalXRd7lW40ZG5hcqfQ9K0VR9SeVG bPZy25+dOPUdK05osnksV8j1FUTqISPUUagQvOoPyjNMVxv2g/3f1o5RcweeP7potYOYa1x6LQK4 iznPzDimMnUjGaQwYjafpQBSqiNyxbYCH61LKSHSybADjNCC9iMTZ4p2C5dsx8x+lZVDaBbrE0K1 4eFFa0zOpoQQjLcdauSREGXBYyS4Y/KPes+flNOW5atrLyTkHJqJTuVGFiU6fHI5eQEn0zU87WxX KhH02FhnLKfrTjNk8iK76W38L/nWnOhcpGdMuAcBQR65o5kJwIp7OaD7y5HqOaFJA42K5GKpWJ1E oASmISgBrFV6miwr2I2m/uiqURcwwytnrT5RcwonPcUcocw8SqeuRU8rQ+ZDhtc4FGq3GkmSR2Lu 24DaPepdRdB+zRZj0yMNukJY+nQVDqlKnYtCCMALsXH0rPmk+pdoroVpY7RjtIUH24rRSkkS4xZE dNizlSwp+0ZPIiWGF4IiqPyTmhyTGotEVwJtjBQxz3BqotEyTKOyQfeDfjWl4kWJrRN0wz0HNKVh q5rQjCZ9awbN0iSkM5ZRwQRzXYcY3JoATNACgE0AKB70ALgdqADJoAWgBaAFxQAYpAKOSMUaAOKY HOBQAcDtmgCRclc5wM9BSKSEAIpXAXFMCPHzCmKxYj61LKWhdYfKay6mvQoy8SYrRGT0JGcFMd6L DuRYpiLumcTsPVamQzUxWQDlFAAVpgJsoAekssf3WOPQ80rJj5mizHdoeJVx7jkVFrGikhs2mWl0 NyqAf7y01NodkzKu9CnjBMJEg9OhrVVE9zNw7GTLC8TbXQoR2IrVO+xk4tEeDTEG00DsJtwMmkO1 hhpiHxntSY0PB+YD3pDLsdsGP3OfpUORokiC5jEczKowB2pp3IasJb7fMG8fL9Kb0BIsXCwLGQgU P7CkmNi6ec7vaomVDctkgdeKzNRrWMt2V2/Kg6sapSUSZR5i3bWkFoRsBkk7ms5TuxqNi3teQ5Py j0FQ2UiRYwvQVJQEGmA4x5AHH5U07CsIIwARgfWndBYYNocZDflVaCuPKgVjd3KIpII3zmNSfpVp slpHP3oWO4dV+VQeBXTDVGUtCo0yjpzVqJDZG0rHpxVJJE3GHNVoSJR6AwxRtuCJ4bOab7iHHqeK hzSKUGy7DpIHMr/gtZyrGkaReitYoR8iAe9YubZqopEmKkdhCOKEMqzJdDmN0I9CuK0jyGUlLoVm uLqI/vIAR7VpyR6Mnmkt0MN7DIf3kbKfrT5H0DnXUnW5hKgJJt+tRyNPYfOh8ZPJMiv9BSa8hpru OchR90n6ChIegkeDnCbfqMUN2BImViBjipKHg0XA5veDXYcYw9eaYCJt3gNwO9ACvjcQpyKAExQA YoAUjigBcdKAFApAOC/hQMs21jNcNiKMt7ngUm0txqNxlzaz2z7JUK+noaE0xWsQ4pgKBmkBpWGk X16D9lt5HUdSBx+dTKSRai2WW0G+SJnEPmKoy3lndt+v5VCqRZTgygbZxy2EX1Y1V10J5WtyvKFR xtbd74q0SyRCCOKGCLoOUH0rF7my2KlwuHH0rSJEhmOKZIcigCzpx23Ke/FKQza24rEBQKAFxQAu KQxdtABsoFYFVkbKkqfUUbhqi1FcTdCgf36UuU0Uh7QSXPEkEZHoVzTTa2CzZX/4RVZWJG+MHtkY FV7QXKZ+uaEul2ySiQvubbgiqU+YTjYwGBY8CtNjO1xpjf0p3DksKgxRcEPAO4dqQyzDdSZWOP75 OMmpcdCkxl8CLls0R2FIt2SL5ILED61LZUULM0Y4TB+gpJjaFsLKaRSY+FJ5JpSY46GlFp20gkZI 7sazZZZ8hjwX4qeVjuSJbhOmD70nEpMdtI6iptYBaQBgUALQMQ0ABouFitLMOQvJpqIhYcgkt1I4 q0hM5nVijXrmPpx+ddVNaHNN6lPFaEAqliFUEk9MUnZAi3FplxJyVCD3rN1Io0VO5ci0dF/1jlvY cVm63YtUy3FZQRfdjGfU81k6knuaKEUTYxUlCYoASgBPpTAKAGkU9A1GkUCIXt4pPvIDVqclsS4x e5Wk02I/cJWrVWXUh010K7adKh/duD+lX7SPUj2bWwzbdw/3sfnT91ktSQovpkPzAH6ij2aYc7Rc tblpiAYiB69qynFI1jJsu7c1kanK5xXecRJkYyaAGE/NkcUALQAtAAKQChfegDR0mGKYSo67uM1E tC4okuNJcZMDbh/dPBpRnYbiSaLbbbtluICcLkBh0pyYoqx0sYQjC4X2rnZsgkgV1KyKGU9iKLhY zLrQIZMtAxjPp1FWqhPJYoS6bcWrJsjwcctjI/OrUk9xWa2LOmS6lMht4LiUox5UMcE1MoRKTkaG lWGrQ3DG2jlWVW5AzScVJaO40mdBJpK3VqraxphV8czREKx9yOlYc7g7Ipxuef6zawWt08dtOJUD ED1FdcJNowkrFK34JrQzRoQjMYrFm6Q2RQWFCBgFXoFFK4WHbFx90UXKsOiULKhAxzRcmxr45pEj gtAhdtIBQhPABNA0Tx2Ur/w7R70WHylqLTCSM5P0FLYfKXodI4yUC/Wlcq1i0lhEn3vmxRcLkwjR PuqBQAEUhGN4qh8zSHIGSjA/rVR0A4YxN6j8K1uFgEQHUk0XBoDEvpRcmw0xYwR60+YLFtDDGwcI C/0qJMqOhDNiSQuRyaaYmJ0GBwKYhM4pAze0h2NoOehI6VDRVy9v5wQDSsFx25fcUWAUbT0YUWAc FIosMCM9RU2Q+YTYPQ0nBdB8wbB2P51PIPmGSDYuWIxUuJSZFcodiFc/NVcthX1KhZYzheW9fSnY B8DbY5JG7KTVR3Jloco7bmJ9TmupLQ5nuJGFLgO21fUDNNuwGpaw2Yw0UwMg6EnH6VhJyNYqJeDT L1QOPVayaRpzMcs6Hg5U+jcVPK+jKTZICCOKnUYlMBpoASmAUAJQAhpiGmgBtAhCKAskMZlUZJA+ tVZktjFkDn5AW9+gp2sFxWhSQDeoNClYdiaNQowBgVMncaRJUlI5KvQOEcvIoATBzQA7HrQAoxSA KAFFAGhozbboj+8DUyKizeUViaEkfHFAyUUgJo5GHXke9IdydGR/Y0mguP8AL9QCKVih+nBdOuxc wRqG7jsaUrsa0G6h4h163mkmtEiEbc4jX+felGmu5DZyWp61qeosftl1K3+xnCj8BXRGlFbEOTMp hzWuiIZZtItwLHp2qW7Dirl2JAq4zWLZstCuzMGIEbHn0rSxDdhQ7/8APNvyosu4rsXc3/PNvyos h3ZNa7nnRTGw59KTjYV2bcVvI/3UNQBbj09z97Ao2HylmHSmbohP1pXKSL8Ok7cbyE+lSPQtx2cE X8O4+9AXJR8owoC/QUWFcQgmgBCKAExTAQikBj6/5720kMSFkZCW46YGaaQHECRcjrzWlg5hd6+l KwXGlvQYp2Bsb160yQNADSaAEpgFAja0Nh9nKkj7xqGUaeBU3AMY6UwDAoAcMjoSKAvYXc47g/UU WQXFEo7r+VK1h3uKHQ98fWgCN1WSRRnipeo0Vr6YsVQAqoH50rFGbcXCQLljz2HerjG4nKxlTX00 hIDlUIxtB6it4xsYSlcq4xVEiUwA0APjnmi/1crL+NS4Re6HzMsx6rcLw4WQe4qHSj0KU2iePVYD 9+N4z6qah0mi1URbivYZPuTL9G4NZuDLU0T7zj7ufcHNTysrmQnmKe4pWHdC5p2GJSsAlMVxrEL1 oAqzXuzhIpHP0wK0UE+pDk10IQby4PAEK+uKu0YkayJo7JEOXJkb1aoc7lKNiwFx0qGWkKBQDHKK Q0h3SkF7HK7V7NXoHEIBg0APxSATFAABQAuKAFAoAt6cdl3GffFKWxUTpAMVh1NR60gJQKAHqKAH rQBPG7L06UWFcnV1bhvlNKxVx/l4GRyKmzQyrdabbXY/fRAn+8OCKpSa2Cxg33hiVctaOHH91uDW qqLqZuBQjt5bdTHKjIwPRhTkwih4BPSoLJo0LcAGkUrFyHTbiQZCbR6txSFoaFvoobHmOW9lFCDQ 1bTR1QjZCB7tSuGhpJp6qPmb8BQBOkESfdQfWkK4/n6CgBCKBBigBMUDExQAmKADFAEckYkADZ6g /lQAksYdGU9CMUgPM5VKyOp6qSK1SERmmAmMUAGKBBQAbaADbQMTbTAjZgvQnPtTUUyWx8d7cRfc lYfU5p8iJuWo9buU+8Ff6jFS6Ycxbi16M48yJh9OaXI+hXMXItWtJOkoU+4xSs0Fy0kscg+R1b6G pGPxQAYxTAj3ETIFOKhloytbvVtrho05cAfhWkYXJbsYDyM7FmbJNapKJi22NNUAUAJigBCKACgA xQAYo1DQQqKPUPQVHki5jdl+hpWTC7RYTUbhOGKyD0YVLpopTZMmqJ/HEye6Gp9l2K9oWY76B+lw V/3lrN02UplmNRJyJt49ARWbVi07jGW5Rv3aRFfckGqTVtQadyZQ20bgA3fFS2ilcSRljxvZV+po SbBtIQEMMg5FK1gvcMUwF6UncCrcahFBkA7m9BWkabZEqljKuL6afgnavoK3jTSMZTuVtgA5qyBR xQA8DNAxTGc5zgUCFCD1oAdHHlgDwKRRJPCIZCgOcdaSYBGMMpHY0AdOvIB9RWDNESKKBki0ASKK AHqOaBEiigB6igCVGK9DSGTq6t94Y9xQNFHVNSi08ogR5ZHHyqBgfnSULicrGe0Goanj7QEhjzlV HarsojvcuWvh+IY3BpD9MCi6Hsa1to20YVFjH05qWwL8WmxJ94ljSEWViSMYRAKAHEGgAxQIMUAJ igYYoEIRQBFG0rSyrJHsRSAjA/eGOvtQMfigAAoADigAWNm6ClcLDxbZ6n8qnmsVynA+LrBbDVf3 a7ElXfgeuea1g7olqxhkVZIlACUAFMApANd9vbNNILkTOT349KuxDY2mISgQUAFABigAVmU5Viv0 OKALMWo3cX3ZmI9DzU8g07FyLX50/wBZGj/TipcB8xDeavLOcx5i9weaFTsPmM+R3lcvI5dj1JOT WiIuMpgBoAMUAFABSATFACYxTAWgAoGNZsUCGhqAFxmgBpWmADcp+UkfSluLYnjvrmLpKT/vc1Lg mUps0INQcxK8qrz1I4rJ0UWqjF/tO3Y4dT9SM0vZNbFe0XUWbU4I0/d/MewAxSVNt6jdRJaGZPfT zNncUHYLxW6gkZOdxr3c7psaRiKfKhcxDTJHAc4FAABnk0ALt9KBjlXGKAJG44xSAQDBoGh/IHYU hjPMUdOaaFcFZ2OAcU7COnsjutYieTtrCWhqiyBUjJFFAEiigCRRQIkFADwKAHgUAPAoAVokkGHV WHoRmmnYAt9LhklAhd7ds5Bjbj8ulNW6gdBGAFGAB9BUMdx9IAxQAYoAKADFABigBDQMMcUCExQA HigBApPQUh2DyyASePpSuUkV7O5SeaaLYySRHBDUXCxoKKllIcRSGcl8QYS1taXGOVcxk/UZ/pWl J9CZHEVsZCcCgBCfSgAoGFMAOB1o1FoROUPQZqrMltEePSmSJjFMQUAFABQAUAFACYoAMUAJQAUA IRigAxQAUwDFIBMYoAKYCYoAQmgCNz81AhVGRTAUjYeaQB9KAD60AJxQMU5xjPHpQA3GKdybCUDs LigAxSAMUAGPSjQBwA6k0DHZA6UAJmgCWRlGMcnGeKiwDC59lqrASJCWXcc7fU0r2HYd5IXkj86L hawoX5vamTc19MmIjMf93kVnNGkWaKSDvxWZZMhB70ASrQBItAh60ASCgB4FADwKAHgUAT27bJVb 0NMDWZ0iVmchVHOTUsY6KRJkDxsGU9CKQD8UAGKADFAEK2yrdSXAZ9zqFIJ4GPQfjQBKRQAhFAxQ CRwCaQDhGe5x9KLjsKIwDSuOw7bQNBtFIZEkMcTMURVLHLEDrTuImQVLGOIpDOd8Vq1zo12pQr5R Dg+uDWkCJHnnatiBpFABimIQkDqaVh3GlifurVJEcwySNwAWqkSyPBFABigApiDFACEUAJQAUALQ AUAHSgBKAExQAUABFACdKYCZoAWgBM0ALQA00ARuufrQAsEjwvuCg8d6LCJridHj/wBXh/WkkNsq h8dKYiQTeq0DF8xD6igBp29jQAg56UCHwwSTyBI1Jb0obsNK5JNazQHEkbL9RSTuO1iHFMkMUAWt OmiguN0y5XHBx0rOpFtaFwaTKwBrQgNv1oGhwQCkA7AHakMcsat16CgC4v3QB0qSkEifKcdKENka KaszLEDmKQNnjvUspGupyAR3rFou49TimMmWRh3pATpL6igCZWBoAlWgRItAD1FADxQA9eooA1QH mt/3b+WzJjdjOKBkUFg9tpzW1vOUkOcSbehPtSAuqpCgE5IHJ9aQC4oAdigBv05oAUIfXFADxGPS kUP21IwxQAmKAFApFARQIYwxTAVTigB3akMqajCLmyuIP+ekbL+lOOgM8kJAHPBHauhIybE3oO+f pT5SeYjaTPQYqlElsYaYg+hoAKAExTATFABigQUAFACYoAMc0AJQAUAFABQAdKAA0ANYhepoAaHB oACKYBQAUAGKADFADSKAExQAEUAG0DtQAED0oAaVHpQITaKAGBih4pgaujXi23mM6gtxtHT9aiSH HRnQLeW8tsJZdoXuD2rOxqmZl3DpkjfI4Qnug4ou0FkzLv7QWrqFkVwwyCK0i29yJRSJ7B7JAPMz v9WHFZz5uhUGkUcVqZi4oAXOKQCZpjJo87Qe1ICzEcLUlIUdaNh7iKuDiqIHgUgNCzfMe09VqJFI tqagsetAEi0ASKaAJUYjvQImSUigCdJFPtQBMuKAHgUAadi2Ycf3TSYFukMOvQUAOCE+1A0PWMfU +9K47FK1mna+nhkAMaAFWC4APpTsIugUhigUALipGGD2oAMUAKBzSGLikOxHJhFLMcAdTVITIre4 iuCwibO3rS5kx2JTxTswGNQJnkmsW32bVryHoFlOPoeRXXHYwZS4FMkM+lACYpgJ0oAAaACgBMUA GKADFAgxQAlAwoAMUABFAhKACgBKAA8UAVmYsaYhQOKAHoe1ACnAoGJuAoAUMKAFyPWkAdqAInbB poB6nIoAXFACYoAQrQA0igQ3aKYCjigCRZXA2Bjg9qTQ0ydEyBgnNZs2S0IZlYN82cdqpGclqR1S ZOw+kAUAHegBcUASwsVPPSkxosqw3hQOo61JVyZUzUlDRsV8NkGrJLEf2fHzMc+1ADxc28TDZ9M1 LQ72LqkY46VmUSLQBIpoAkU0ASCgQ9aAJBQBIpI6HFAEqSsPegC0l7LDC32eDzZTgKm7GeaLAbkS OqgTKFkx8wByM0mUiXHFIBQKAFHBqRgeetOwhAKBi0AL0qQFoGNLBepA+tADhQMdikMa6KyEN0pX AxL/AMQ6RpKeWswlkH/LOL5j+J6CmoyfQTlYp6J4n/tbUGg8lYk2kpzkk1r7Nx1bIU7m+az6lHnf ja38nXTJj5Zow34jg/yFdNN6GckYBT2qzMaVxQAw+9MAOKAEoEFAwoAKAEoEFAwoAKADFABigQUA JigBMUAIRkUAVSNrEGmItWsJmbCgkAc4pDEnt3jbJRgvqRQBErLn0piJVEZ/jAoGO8lSOGU/jQBG 0OOn6GgCM8HFACFT1NGwrFq2sbmSIvHC7IO4FK+pXKRsjIcMpB9xTB6CdqBBQA0igBhFAhKAAZDD FNgiyoPQ5rNmqFYso4GR3U0kEkRSxjAZOUP6VZAmKBBQAtABQMUUAWFOBG2ehxSAvqMcfjWZqU7y RN6hW5HWqiZyGRnJ61QCScNTQGtpk/mQ7CfmT+VYyRSL4qSmSLQA9aAJVoEPWgCRaAHigCRaAHqc HIoQHR6bdC8twrf62MY+opvUCyKjYoWkMBQIWmAUgCgBtAx6jikxoqX+n/bNu5yoByMc0Jx6hYW8 v7TTot13cJEB/fbk/h1NG4bHL6l4/gjymnW5lb/npJ8q/l1qlSvuTz2OX1HXNU1NWa5uJBDnGxPl X8q1UEjNyuURbyiETqp2EkZFVezEWdMvPsV5DOmd0bgn6U2CPVI5FmiSRDlHAYH2Nc0lqbX0OV8e W+Y7SfH3WKH8f/1VcQOPxWl7E2EK/jT5ieUjZfbFUmJojZOuKexIzpQK4YoAMUAFABQMKADFABig AoAMUCDFAwAoAQigQ0imIjePd7GgAgaSBiY3Iz196AJri6lmh8s49z60h3KQjf6VRI4RH1pDDyz/ AHqADaw6NQAjblwWoAeJ1242c+1DGd5pt5aLbQRKyKzLnaDWTRaZZns7W5U+ZGje5FFxmNc+H7WR v3DMhP4inzhy3Oe1C0ayuWhZgSvpVrYhqxVpiGkUCEoAQj0oAt222SNvm2yKMgE9RWcjSA8KcDg4 P61JqldEbR+WeOVPUVSZnKJDVmYooAKAAUDFHWgCZeY2XuOaQyRpZpI1A4GMZHekkO5CIHHO04p7 E2dyRRtIzSuU4tA46UCZLaO0Myv26H6UMcdDdU5xisepZIDSAkU0ASqaAJFoEPFAD1pgSLQA8UAT 2k7W0yyKcYPNCdgOljlSaNZU+63X2NJgR23nbn84Ac8YpFE9AC0gGTFhGSmN3bNAENibgxH7SBuz xxjIosMs7cnoaFqGxjar4n0/TMozmaUfwRjP69KfK2K9jj9V8b6jdZS122sZ/u8sfxNWqS6kuZzc s0s8hkmkaRz1ZjkmteVIi7JbCEXF0kbdDnOKHohD7+1ks28stmNuRUxakM1tLlhaxEYI3ICWU1Er 3AxFwW54HJrRbAeheDL77TpXkMcvbnaP909KzmjSJL4stzLoVwc7mjIkHtgjP6ZqIjscARWgxuMU AKBkUXARkUdOtFxWTIniPp+VWpEOJHs/CquRYTbimIQ4oGJigA6UAGKADFAAaAACgQc0DAUABxQI aeKAEoAQgUAJtFACFaAG7aYg20AIVoAayZGKABU20BYmSZ0XapA5zkdRSsM07PWLsusTOGDHGe9S 1YaZ1Ea7YQ3cCsnqaxON1eYz38sh7mto7GctylVEjTQITFACGgBMEHijQFob9lqNte26214oR1GE ccVlKNtTWE7aEN3Yy25z95D0YdKhM20Zk4xW5yh0oAWgBaACgZLDIN2D34oABIUGMCkBKspZcFRi kyk7AAOO9I0cmLnNBAooA09Pm3R7D1X+VRJFF5agCVaAJFoAkU0CJFoAetMCQUASCgBwoA0dJu/J fy3PyNSA3F44/wAmkMWgYUgK13qdnYJuurhI/YnJ/Ki1wOcvvGqFjHp1uXbpvf8AwqlATkaPh2HU 9cPm3s2y1IwVjxncP8a6IQSM2yDxb4Mt7TRmuLLeWhO5geeCf/1VTSQkzz20iD3kaMMrnkVEmMdq tmlrIpQna/b0qYu4iGG4FtciSAEAdmqmrgWNSuxeNEVBGF5HoamMbIY2O3klkJtY3Vfr0/GqVgNC w0G5upCkUTS4PJTp+dPlA7HQ9BOkytI00SSbPmhDZO0nr+dKcNBpmlfQfaLOaLH30K/pXOjU8sUE DHccVYC4x70AIRQA0DmgA5ouApweop6i0IzGD0qlITgRPGVq0yHEbTJAigBKACgQuKAExQAYoATG DQAYoAQjNADSuKAG4oAWgAoASmAYoACKAGkUAGKAExQBY087b2LP96plsCO5UboePSsUbI4W/jMd 3Kp6hjW62MpblcimISgBKAExQAmKBCDj60AaOn6vLafu3HmRHqrVEoFxnYo1RIYoAWgBaAFCk9BQ O1xwgO7JOKVx8pMQM54zUlC4NAC4pDCgQopgTW8hilDD8aQzYRgQCOhrK1hkqmgCUGgCRTQIlWgC QUAPU0APWgB4oAcDg0wN7TLrz4tjH94vT3FIC+KRQYpMDzzxJpYj12UO58uQeYgHoev61opWRDIo Io4RhFApN3JOv8E6h5N2bZzhJRx9a3pvSwmdjdtFNaMpHmRS/IdnPXiqsSeH63aSabqctuw2PC20 EcZx0NTYsqXU0t4Ywy5ZBjjvSUUgH2+mSNhpGWNPVqr0A2tO0VZpRFa273Evqw4H4f40WYzs9I8F 42yanIDjkRL0H9KaVhNnTNDFZWjLaQICBwo4z9aZJl3VpaG/S+lGx1jMZOeoPakxlfplc5K8E1yy VmapnmOqwm21S7hAwFlbH0JyKpLQoqc0DA0CArQA0gigA6UwFyPpSAKBjWRW6imnYlq5G0RA4/Wq UyHAiIxwRtrRakPQTGKACgBaBC0DACgAIpANpiEIoAaVoATFACYoAXbQAYx0oATpQAlMBpoAKQCq /lurDsc03sB3OmTrPbIwPUVizSJieJ9PKuLlBweGxWkWEkc8aoyEoAKBhQAEUAJigBpWgB4FIYoB PSkA9YievFFwsPCKvbNTcqw7+VAxcUALigBaAAe1IYoH4UAOHFAhcc9KYzQsJcr5ZPI6fSokBeU1 AyVTQBIpoAlQ0CJQaAHg0APU0APFADhQMmt5WgkV1OCDQI6O3mWaMSL36j0NICagq5geMLPzNPW7 QZe2OTj+6eD/AI/hQiZI5VHDdKbRBbtJ2gmSRDhkORTg7MZ6DHr2n21hE6nAbnYv8JPWuhyRNjjd ehs9e1R7nPlKE6u20H3Pf8KlSTKtYqR6dYQQSeW7SunJKJk49h0A9zVWEbWheGYbuF7ud3ZVG5Ik Jy3sX6/XGKpWQrnUaRNapYKbW3W3UEqUUY5FFySSS8+uR6VLKsVpdQXkZLMP4V5NAFK623UL297K kMMgbOTl+emAPTmhWW4EEDQ+aEtZZZYkjC73XAyOOKyqNPYuOhxnjGDytY3gcSxhvxHFQtjQwiMU wCgA70DAjIoAYUouIQgigYuKAAUgDHfFADWUNwaadhNEawEE84q+YjkEZCOSPxFNSE4jdg7VZFgI xQAUAApAIRjpTAMUANIoAaRQIQ0AANACigBCKAG4oAaRTAaaAENAG34c1EQy+RIcAn5ahoadjq2R LqEowBVhjFSaJnHaxo8ljIXQFoT0PpWiZDiZWKZIUAJigBaAExQAYoAnESjrzWdy7DsY6cUXDYUC kUFAhdvpQAUAAzQMMUCFFAx2KAACgBQTQBJE5jkDjtSaA142DKCOhrMZMpoAlU0ASKaAJlNAh9AD 1oAkWgBwoGOFAF/TLryJNrH5G4NAjeBBAwcj1pDGSKk8bxsAysCrCkOx5+9g9pPPBK2BAxGQMkqO hwOnGOtapXM2N+1xxLlV+Qf8tJOAfz4/nRygVn1hpXIgQzOeAecD/P4U7DubfhvRhqU4l1O4IjQ4 MKttGT0/rRGyYM6u5+yWNt9nit1W2c7H2DGM8Zra5mLp1s2mQCGOYSKJCxyMYGO35Uh2GXeqWtsv 72eOPvtH+AoAo/2z5/y2kDPnoTxUt2GkPjgu5hmaXyl/ux8VDqWK5R0xt9OhMrRlvoMk1DbZaSLE MyTQJImQrjI4qNRnLeNo1kitLlCGCs0bEe//AOo1SA5TFUAnSgYnegA60gD270AIetADiMigBMcU AN+lADsAUAGKAEwKLgMZRjpVXFy3I2RvqPeqUiHAZjnHSruQ1YXBHagQUwDFADSKAENAhNtACbaA ExigAoAQ0AMIoAbimAYoATocrwR3o3A6fQNZDhYJyA46e9Q1YaZ0ZWOeMqwDAjvUl3Oc1Xw0cmSz /wC+P8KpSFbqc5NbyQOUkRlYdiKu5LRFigQYoAMUAFAFrGKyNQxQIDQAlADhQA7GaBhjFACCgBwA oAULQAbaAFA9qAF7UAa2loJbcjPKmokMsmNk69KkBymgCRTQBKhoAlBoEPU0DHg0APBoAcDQA5Ti gDa0u68xPKY/MOlAjRAAyQME9aQzkPHiS2qw3lugO87GJ52nscdKuLBnGoqzt5l/OxI7etaambNr TBbyxYtSAw6oRg1nKLA0LWTy5CHRiBzx2I6GiKsBq3XiJpIt0UURcn7uc/j6VpzCM/fqupNh52Cn tGMCp5yrXNCz8ORqRJP8ze/JqXMpRNqGCOFQsahRUtjJKkYyREkG11DD0IzTCxXkvraGVYDKoc4G 0c4+vpQDZl+JrRDocwjXb5ZEn68/zNNAcLjH0qigPSgBvekAYJ9qADGKAAigBc4oAaTQAlAABQAd KBgeaADigQhGfamA3Z60XCw3y8fdOKpSIcRpGOox9KtMjlsGPTpVCEZaBWGlaAG4xQAhNAhKACgA xzQA0j0oAYRigBKYCUAIMg5GQR0NAjd0nX3gxHcklegapaGjqra7iuEDKwIPpSsWmF1YW94mJY1b 37ikMwL3wqclrWT/AIC3+NNMLGHc6Xd23+shbHqBkVVyeUqFSO1AgIoEWKzNRe1ACUALigQCgBwo GPAzQAhGOhoAAMUAKKAHcdqAAGkAvFMC3p90LZ23DKt1x2qWrjRtxSJMm5CGFQAjQgHjigBm0r1o AcpxQBIrUASq1AEgNADwaAHigBRQBLFIY3DKcEUCOhtLgXEQcde9ICLV7FdR02e1PV1+U+jDofzo TsM8xXSbmYgSYi5wd3X8AOa6IszZr2OkR2pVxuLj+JzjH4D/ABpuQJGpHpr3g2hGcep4FZNjsatn oUUQBlO4+gqWy7GrHEkQwihR7VIFO6sDcXcU/nMgjIO0d6asBezSGZmoa5Z2TGPeZp/+eUXJ/HsP xosGxiXWq3l6CpIt4T/BGfmP1P8AhSZDZVRQgwvH0oJudKpGo6UysOZYyjfXGDTNUedEFcgjkcGq KDg9aAEwO3FACdKAEoAXIoAay+lAxuKBBQMUUAKCBQAYHpSAXGKAGmgBDxTASgA46UCE8tT0GD7U 72FyiFWHoa0UjNxGHB9jVXIsxhWmAwikAwjFMQlAC0AJnFACGgBppgJQAGgBKBE9rdz2jboXK+3a kM6Cw8TLgLcqUPqORSsNM3rbUILgApICPalYdyz8jjnBpWKuV59JtLjO+FSfYUaj0KUnhK2kBMYk QDvnijULI44DmkApFABigAANADsYNACigB1AD1Ud+tACMoOSvGKAGkYoAAaAFxQA4UAKDikwJ4pX hbdGxU+1KwzUt9VWRUjmAUg5DDpScQNABXGeCPUVFgGNFjpQAzBBxQA9TTAkU0ASqaAHA0APBoAc KBFuwujbyj+6eooA6BWDKGB4PIpAc/PpE/8AaEzRlfLmcuGx09qtSCxcj0yC1QyzZlKjPI/pSbCx bsrmK5gEkSlVBxgjGKkaLBoGIeKAMbUfEljYt5SMbif/AJ5xc4+p6Cny3E2Yd1qWoaj/AK2T7LCf +WUR5P1b/CjYhshjjSFdsahR7d6Vxalq2s57k/uoyR6ngUrDsbNnosUWGnPmN6DpTsUkaIUKAAAA OwpFHnWtwfZtVuohwA+4fQ8/1qxoonigYueaAFOKAGnFACUDDoaAEyPSgQ3HNAw6UAFACg0ABPvQ AE0CG4zQAlABjmgB30oGGTRcBDg9RTuxOwzyyfug1SlYhxElhaJyjjBHpzVqRDiQsh9KokiI5oEJ QAd6AEpgLigBpoASgAoAKADHNAh0cjxNmN2Q+oNAGhba7eQYywce9KwXNW38VAYEsbD3BzSt2Kua tt4sh8soJyqt1U0aodziqgsUUAOoABQA6gBRjHFAC8elADtwUdOaQwDgnpigBSAe1AhhXHSmAmaA H8jpQA7NIYucCgBynjFIZatrqW1xtYMv909KBGvaX0VzwDsf+6ahoCy0YYdKVgIzGQMjpQALxQBI poAkBpgOBoAeKAHA0Aa2lXfHkuf900xGnUgIQGXBwQaBjURIk2oqoo7AYFAGRf8AiS0tpDDbBru4 /uRcgfU00n1FcypzqOp/8fs/kQn/AJYQnH5nrV2SJuPitLa2jKRxKifTrQFhI9Ne5k/0dSE7k8Cl awrGva6NDAA0v7xv0qWWlY0FARQFAAHYUikVrZblZpzO4aMt+7A7CgCwaQHF+M4NmoRzAcSJg/UV SGc/0pjAe9AB19qAACgYmeaAA80AJigBDxQAYoAQCgQfhQAuDQAdqBiDigAxQAhFAhPagYq8sFB5 PrQK5ZiUxspjTe6nJz0I/wA96GK42aNFkCOzKpOcg5H5UxEcypFKyRuJFBwGAxmkUQsMnOKpMTRG 0RxkVakZuBAwKnkYqkQ1YaRTFcDQAUwENACUAJQAUAFABQAUAkaFro91c25mjUbR0BOCaz50nYvk KksDwuVkUqw7HirvfYlqw/vWZoLQAUALnFADgc0AKPagBQKQABjtQA8LQMULk8HNAwCc+1ADCvPF AWFApkhjBpDHUAKDikMcDQA5SPpSA0LPVJbchZP3iD8xQFjXgnhudzQkYJyV9Km1hEhjBFADCpU8 0gFBoAeKYDwaAFBoESIxVgR1FMDesrgXEQz1HBFICeOMRR7E6DpmgZyVzBfalI41K5KxhiPs8Pyr x6+tVsQyeGCG0j2xIsae1VqBPDBNcf6mP5f77cClogsaNvpUaEPMTK/v0FTzFJE17LJb2rPbxB3X GFqb3GihqWuJYqiGMvOVDMm7AT6mmogQaX4lt72fyHAikPAIbIJ9Kbi0FzbNQMQ0wOU8XyGaFNyh fLY47k54qkBy2D2pjExg0mMWgYEYoAQigAHHBoAXigBDxQAnX2oATvQIMUAHegYgPagAz7UAFAAe DQAhoAQKKAHRs0WdjEA9RTFYTPYUgDIxQAcUxhjFACFQeozRclpEDwDqpx7VakQ4kLIw6j8qvmRH K0NqiRKAEI9KADGKAEoAKAFApAbOi6QbgiedSIh0H96sak+iNIROmChVAXgCubfc3tYilhjmBEiK 49xVKTWwrI40jHSukyE6UAHWgBwHegBcigBw45oAUH0pALnBoAdmgY9MHg0hiMSOKAD6UAOCkjpQ Am0dzn6UABIPbA9KAEoAUUALnFICROfYUDJUkMRDQkhh36GgdjSs9W6LcjH+2P60rE2NZGWRQykM p6EVIhGi7igBmCOooGLnimIcDQIeDTAs2lwYJQw6d6QHQRuJEBU8UhmVq1pdNOr2caMZOGLNjafW qTJaJLTSUiw9w3nSeh+6PoKHIdi3b3MM7SRxHmI4IxipHYmHFACEUAef+JUlS4mkkP7uW4cHn0xj 9DW0UQ2c+JBHIDFtGOhq7XJTO98KXep3MTG/R2iI3RysOTWM7IuLN+oLKWrWoutPuIgBlkOPr2pg edkUyhpoAB05oGIfrQAnegB1ACEDtQAn1oATBxmgAxQAYoATFACkZxxxQAmMUAAoAMZ6UAG3A5oA a3oKAG496ACgQg4oAcDQApoACKAGnimAxiAKaTJbVisx5rZGLGUxB0oAMUAJQAUAbWiaOboiecER DouPvf8A1q56lTojWMbnUbAoAAAA7CsdTa1gxQAxl4xikBxXbiuoxG4oAXGKADtQAoFAC5oAVTik A88rmgYKaAHkfN8lIZLGikZY8jtQBEzAN8v50AAJPU5NAxdpoAMcetAhyoT7UADBRwDk0AIPagBQ TmkMeDQA6kMmtp5rU7oWwPTqDRcVjZtNTjuFMb/upSMD0z7Gk0JouwhmjAmXD96QhXhwMrQBF0qh DlNAEimgDT0262EIx4PQ+lAGsORSAKkZHHDHGzMiBWc5YjvTQGHJd37u80c23DHZCVG3APc4zk1a RLZtwSedDHJtK7lBwe1TaxRg+JNCa9V5IVL7sF4wcHI6MPfHaqjIlo53TvCc8k+HjkjH99xgL+Hc 1UpgonfQxJDCkca4VAFA9hWRRTuL8xXkUIiyrvtJzyPekMunigDznU7f7PezxgYUOdv0qiimRTsM aBgmgQe1AxKAHUAA5HFIAHFAADxQMQj8KAD6UAIRzmgA5oAXAHvQA0n0FAA3A560CEA780ANP0pg JigQY/GgBKAAZU0ASZ45FADTigCKRgn1qkiWyBmJPNapGTY081RI2gBKAFoATFAFnTRbfak+2EiL 2H86id7aDW53FvJDJEDAysmONp6VytdzpTViTFJMdhCMUgExxQM4WuowFxQAAUAGMCgAxQAEUAIo xQFiVBxyaQx2wdRzSuOwB8DHAoAXHemAuKAHbcc4qbjFGAfmoAUOB0FADGJPU0ANpiFHFADs5HIp DFU4+lAD/wCVIY4NikAp+b60AXrDU5bbCP8AvI/Q9R9KYmjetrmK5TdE4PqO4pWJJTGr9qBELxMn TkUAIDQBJG+0g0AbthceZGATzQBapDA0hlSWwR5CwYqDyQKpMlosooRAqjAHFIdgIpDE2imIOgoG RMyhuBkjvSYDT83WkBVvbCC9j2ToD6EdRQM5XVPD09pmSAGaL26j8KtMZjEc46GgBo96Ywx7UgFx 7UAA44oAD146UANoGKBxQAuMUADDA5wT6UAMOaAFGe/AoACR2FACY7igQvQcCgBhBNMAx2oAbjFA AB6UAKByDQIRjzQMidwoq0jOUrFdzk5rVIyuN70xBQAuKAExQAcigBO9AwNIRJBPLbPuhdoz7Gk0 nuNNo2bPxJKh23KCQf3hwaylT7FqZuWmp2t2P3cgDf3W4NZODRqpIt49KjYpM4OuoxFHFAC/SgA7 UAAPtQAuKAFUYpDHDg0ASdBkVJQ3YD0FADgh70CHjC9f0oAGfjjigZF160AOFACnpxQAmM0AIRig BBTAcvApMB4x2pDDPOKAHDPXoaAJAc9aAHI7xMHicq3qDii4rGzY6yCQl1hT2kHT8adiWjZRldQy kMp6EVLERskcjFVYbl6gdqAImjaM89KAJ7S4MMgOeKYG7u82EFT154P6UgIdPili87zSdrPlFZtx UfWhjLdIZVuLv7PcQxNGxWU4Dg9D9KALJoAjZwPr6UAMJLdfypAJikAYoAMUDEIoAydT0G3vQXQC KX+8o6/UU0wOUv8ATLiwkxMvy9nHQ07lFPHPHFMBegoAMEDNABgmgBCuPrQMQqc+lIBc44FADec5 pgGfagBNtAC7cUAIT6cUABOKAG5zTEA4HpQAEDHv6UAJwB0oAbnGaaQm7EMj9hWiiYylcgarRIlM QYoAKACgB8cbSyLGgyzHAFJuyHY6OTwmCgMdxh8chl4zWHtdTTk0Mi+0a6shudAyZxuU5rSNRMlw sUChXggg+9Xp0JExigQhoAVSVORxRoGpo2etXdthd/mJ/dbmolC5alYrUihaAFxQAnSkAooAUA0w FqRiYPA7UwLESjv1qWigdghwtJIBhYmqAFbmgQuKBiEUgAcUAO4HUUhgKAArQAAUwF20AKFIpALj B9aAFGM0AOzzgUAOBGeaQD+Mc0wJrS9ns2zE3y90PINMlo3LHUYLubcW8ubGCh6H6GlYm1jUwCME cUgIZLYdU/KgC3plyUbyZTjPQ0AawpAICDzSGRSJF5gkZVLjocc0AIWZvYUDEAA6CgAxQAppDExQ AYoATFABjFADJIUlQpIoZT1BpAc7qfhkHdJYnH/TMn+Rqkxo5yW3kgcpKhRh2NVcY0AfWkAhHpQA zJ70xifnSAdxjpQAhH5UAHGKAEJ9KADmgBO9MBCwoAb9KAFPNMQn0oAaeM0JA3Yhd89K2ijBsiNU QM70wEoAKQC0AGM01qB0HhOw82Zrtx8sfCfWuerLoaQWp1mKwNSMId5JwV7UDIbiyt7gYmhRvqKp NoTSMq68M2smTC7RH06itFVaIcLmTc+G7yHJjCyr/snmtVUTJdOxlzWs0BxLGyH3GKpNdCbNEWKe oiwRWRqAFAhwHNADtvegYqgc9gKAEAPXFIY4AfjQAHNACd+KBhigVhe1AAq0hj+woAUjAoAZ0oAd nNIY7PGaAAHtQAp9aQWHLgUAB5oGKBigA/CgBcZ9qAADHSgVg5FMB4YYpAGOPcU7gadhrU1thJ8y x+v8Q/xp7kuJ0VrdQ3Ue+Bww7+o+tTYklKBuo+lIRetpZCck5UDBphsStIx4UED1NSUIFx7n1NIY vSmAYoAMUAGKADFIYYoASgAoASgAxSsBVvtPgvoysyAns3cU0BzGo+Hri2BeD99H7DkfhTuMx2Qr wRyKY0RmmMQACkAu3v0oAOQPagBpGKAE6jigBMc0AL3NMBNtAAFoEBXFMBh468UAyGSTPArWKsYy lciNaGY00gG0wEoAMYpALt4oAfDE00qRRjLOcAUpOyGkehWFqtlaxwJ0Ucn1Pc1xN3ZutERanfCx iDBd7nhVHeqSuN6FiF/NhSTaV3AHB7UtgTHGmMaRS1ATI5oAa8ayLtdQw9CM002thWRnXWhWU/Ij 8s+qcVaqMXKjka0JAUAO6UAKCfpSGOGPpQAhPagBKAHDigA6UAOzxQMNhPQUgFwB1OfpQA5WC8jr 7igYnIoAQjFIBBwaAHdR6UAHAoAcopDA9MfrQAD3oAf2oACoxzQAYJoAAcGgBc80AOHXmgBfwoAT p0oCxLFI8EgeFyjjoVouLlNux8QDAS8XH/TRRx+IpkOJu28wkUPDIrKehU8UrWJsWre+SR5In4eM 7W9qLDLJXuDkVJQmKADFABQAUAFADWDbG2Y3Y4z0zQgKWmDUgZP7RMJH8Hl02MvYqQDFABQAlABi gDP1DRbW+BJTZJ/fXrRcEzl9R0S6siWK+ZH/AH1H86ZRmFcdRzTGIRigA69aAF2DjmgBCg7cUANK 4Hr70AIOlABj0oAOKYhCcZosBWmkHQVqo2MpSKx4NamQuaAENACUAGBQAnSgA9qAOk8JaflmvZF4 Hyp9e5rmqyvoawR1BIHesVoalGGKR9QkmlA2qNsfP507iLuR0pAIaYCUAFACUAIelA0cAeTwK3Mw 2epphYXAoHYC3oKQCUCFBoAXFAxRQACgBwxnpn60DAs3fpQAg4oAUHHbNIYqtjtQAEUgG+mKAJFB oYxcjFIAHPf86Bi4HpzQAoGBSAUUAH1oAUcdKACgBQfyoAcT+VACigBO9ACnigBc8dKQE1ncSWsm +Byje3Q/hVXJtc6Gx1mGd8XAWKZuN3ZqCXE24ZmTocigktpIkg9DSsO4pUrSGJSAKADFMAxQAUAF ABSATFABigAxQAmKBgVB6jigDI1Hw/bXWXiHlS9eOh/ChDOXvtMubBiJkO3sw5BqrjKRHNAxc4oA DtPfFADGyo4oAQOCcdDTEKR70AMyc8imBHJJngYrSMTKUis4Oa1MyMigQmKAEpAKOKACmA0ikAqj LDPA7mh7Adxp2oaaLeOG3uEUIMAN8p/WuVwle5tFl4SI3Qg1k731NB24Lx0zT0ERhv31Zt6lEma1 EIDQIWgYlABQBwO4V0ECE0AJQIKQwoEAoAcDigYooAUUAFAxeTQAFTmgAApDF7UAAOOKQAFxzQFh QaBjs57ZpAKAD0oGKM56YoAXHNIAoAPrQAZ54oAXIx7+tABkHpQAvbFADs8dKAFz7UAIaADJFIAB IpiJFOetAzU0/VJ7XCn95EP4Sen0NCJaOis72G7XMT/N3U8EVRDVjQiuCvDcilYLlgBXGUP4VNgu NIxSGGKAFpgJigAxQAYpAGKACgAxQAmKBhQAhFAhrxrIpV1DKeoIoHcwdS8NRS5e1Plv12nof8Ka Hc5m8srizk2TRsp7ehpjIAOKBi47daBEbRjORTAXBAoAQgY5OaAIHhDHK8GrUrESiQuhX7wrVO5k 4tEbDHNMQ3vTATFAhaQCYoAKYBQAZ4oGWbXULm0/1MpVf7vUVm4Jj5maCeIpGAFzbxS45BHykVMq SexSmX7fxDaswLh4/qM1zuhJMtVEasGpWdwB5VzGT6bsH8qbgx8yLAqbNDQtMYUABoA8/wAV0EC4 oEGKAEpDExQIcAKADFAw6dKAHdaADpQMWgBQSKBgPpSAXpQAq0gFoGIT7UAKp4pALQMcDgeooAXg 9P1pAJz+NMAoAXNACjpSAFWgBxGDzQAAUAL7UgGmgBccUAL04NAx3agB6kgD0oETxyNGwdGKsOjA 8incVjbsNdxhLvnsJF/qKZLib0MoZQ8bAg9CDTI2LSXCkhJMAnp70rBcjtrhbpp/KRtkTlN56MR1 xSaKJsUgCgAoAKQBQAYoAKACgBMUAGKACgBMUART28VxGUmjV1PYigdzndQ8M4Beybj/AJ5t/Q0x 3OemhkgkMcqMjDsRTQERHpTGJ3oARlHagAC45I4pMBGUdKpMNCCW2U8p8p/SrUjNxKsiMn3hj37V opXM3Gw3GKdiRKAEoAUCmAetADTQAYz0oACMUAITQAA0mGpNDe3NvgxTyJ9GpcqHdmhB4kvo/vsk o/2l5/SodNMpTaNC38UoeJ4GHuhzUOl2LVQ0IdcsZf8AltsPo4xUOnIpTRyWMfStRBQIKAFpDEoA MUAFAC49qAFoAM0DFHT2oAOlAwBpAO7UgAUAL3oAM/jQMXrQAAUgFNAAAaBjs+tAARxxzQAoFIBw wPpQAv6UAH0oAAMUAOJ5waAG4oAXOKQC45oAdgr3pjDpSEKGxQA9W5GTigC/Z38tm2YW4PVT0NO4 nE3oNRtNQ8lpP3VxCSVycZB6/hVIzcbEuk3f2XR1uWP7oyMScdMuaLCNqN0mHBwamwXAqRSGJQMT POKAFpAGKADFABQAlABQAUAJigAxQAEUDKt5YwXibJ4w3oe4pgc1qHhuaDL2pMqf3e4/xppjMN4m ViGBUjqDVANwRSAQrjkdaAAHP3qBiHGOlACFAw6Aj0pp2E1cry2g6x8exq1MhwKjoVO1htNa3uYt WExigBMZpgHSgBDQAUAJk4NADTQAhoAKQBQAmaAF3GgC5isjYTbQAd6AFNIYUAFACYoAMUAKBQAp GKBgM0ALQAUhgc0gFoAUcUAKKBiikAuMc0ALjNABmgYuflwBQAAYwRQA7g9uaQCg+nWgBepx3oAX GKAAdeKAD9aAEJx16UACZPIHy+tAXHkelAwB9uaQg2etAx444Xp70ALt4oAdupCHKwJpgzV0vWGs 4jbuvmW5/h7jNO5LidFaXMVxGHgcFfbtVGdi9FccYf8AOpaAm2ZGUORSsNDcYoGGKQBQAUAGKAEo AKADFABQAlACUAFMYhFIChf6VbXy/vEw/Z14NO4HM6joVzaEsg82Md1HI/CncDJIxTGG0Eds0AN2 0DDb6daAEJ7ZFADZEWQcrmmm0JpMpy27JyvzL6VqpmLhYh6/hWhA00gENMBDQAlACGgBtABmgAoA KQBmgC8ayNhKAADmgApDFoAb0oAX6UALigAHWgYvUUANoAM0AKDikMf9KQCc5oAUZBoAD1oAcOeD SAfigYEjFADMUDF/nQA7J70AGaQDwM0AOGBQAmS1ADugpAJ396ADaDyetMB4BpBYUgAdaQxAxx7U xAKBjwMUABJxgUAJkUAC880APBwKAsWLa4kt5A8LlW9RQhNHQ6frcc2EuMRv03fwn/CqvczcTZil ZOVPFBJaSRZODw1KwDipFIoTFIBMUAGKACmAlACUAFABSASgAoAQ0AJigBCKaAy9R0O2vMso8uX+ 8v8AUUDOY1DSbmxbLpuj/vr0qrgigeKBjc84xQAhHFAxuSOgoACKYivLAG5HDetUpESjoVHUqcMM Gtk7mTVhtMQhoAaaAA8UANPFABmgBKAFoAQ0AaHesTYMYoATHpQAdKBhQAgFIBelABQAtABnBoGB 9QKQCdelAwxQAoOOKAHZpAH0oAU9aAHKMUgFOaBhigBBx16UDHDGPSgAxngUAL06UgFB7igB3WgA xzSAX+VABxnGKBiqQKAFOc0AAXtSAUACgABoAdnHWgBM8cCmAuKQCgY5oAOvfimAo+WgB6uDj86W wGjp+rT2RCk+ZF/dJ6fSqTJcbnTWV9BeJuhfkdVPUUzNqxfjnKjDciiwiaNVYfuzx6VNhgRikMTF AxMUCEpgFAgoASgBKBkfmEy7QBgdaAJKACgBtACUANZQwIIBB6g0DMXUvD0Nxl7f91J6djTA5q9s bizbbNGVHYjoaBlQjFMBpHpQAh9BTAZQMjkjDjmnF2IaKboUO0/nW6Zi0MxQAmKYhDQAlACUAJQA UAFAG9qenNZS5GWiPQ+nsawubFLvTATvQApGaBjcYoAMYpAHNAC4oAB1oGKwHY/nSAQe9AARigYC gBc0AFADx0pAJjnigB44FIYZJNAAB+dAwz2oAUc+woAXFIBevFAC4HbrQAA0AKPegBe3pSAMHFAw AFAD+lACEkUAB9+BSAU460AKPmGelMBcYoAUHikAoGfagA6dBmmA0ZJ54FACkdMUgHqTxnpQBJDK 0cgeJyrL0IPSgGjo9L8QIWWO9AB/vjofr6VaZnKJrWURtFZY5mkjLFkLHOAe1BFrGgkquMNwamwx zJjkciiwxmKQCUwCgQlABQAlAxqLjP1oAWgAoAQ0AJQAhpAIaAuRTRJKpWRAynsRTGYGo+HFYF7R gp/uHpTuBzlzbS20myVGQ+9UBCaBjeR24pABwaYEMsQYdPpVRdhSjoVHjZTyOPatVJMxcWhhGBTJ GY9qAEPFMQlIYEUwEoASgD0m4gSeNo3XIYVzmxyeo2EllKQRmM/daqAqGgYUgA+1ACAUAGOaAFxQ MBSAXFABxigAGKBiGmAgyOtIBcGgBR6A0gHhcDHehjHYwKQCD8qBiCgBR7UAKAaQD0oATIzigAFA C0AKBzQA/HFIAwBQAFefagBT6CgYe5oAGyw9KADAz60AJ7+lAD+1AATxSAN2DQAuQPpQAo564oAV oyCMcelAC/d60AJk+lADkbHagDR07U57E4Rt0XdG/p6U0xONzp7DUYL1P3TYfuh6imZONi/HKycd RQIsApIOODSsMYyletADaACgBMUDDFACUAFACUAIaAEoASgBpoEIaBiGgCC6tYblCk0YYe9MDm9R 8OPGS9md6/3D1ouMwnjeNyrqVI7EVQDdtAyMgg0AMI9s07hoRPCrdMg1SkS43IXhZc8ZAq1JGThY hIqibDSKAEoAaaYBQB6dWBsR3ECXETRyKCpFAHJ6jYPZTFSCYz91vWgCpQAYoKDvQAlAhcYpAGKA DpQMKAEx3oAcBkc0DG4OMUAKBnrSAco70DHD1BoARic0AIOtIY6gAwaQC8ZoAUN2oAcP1oAUDFAB gdqQDhigBcD8KBhkdMUALQAvGKQCHg0AKDkdKYCUgFHHpQAp6ZoGJxigQDNADhj60AA4NADt3GO1 AC8HpQAw8HigYoPvzQA9JCpHpQBJHKUYFCVYcgg4IouJ6m9p3iHGI7zkf89AP5iqTIcDoIpVdQ8b hlPQqc5p2M3oWY588P8AnSGPKAjK80ARng0gCgBKACgAoAQ0DGmgBKAENACUCENAxppgNNACEUgK l7p9veLiVBnsw6ii4I5rUNAntyXhzKnt1FNMZjOpBwcjFVcZGBQAGgBh6c0wGNErLkinclxIHgI5 U59qtSM3AgZSOvFaXItYaRQAlAHp9YGwtMRDdWsd1CY5FyDSsM5K/spLKbY4yp+63rQBWxx70FAR QAEZFIBCScZ7UCAGgB23gc0DGkUAFAC9O1AxTSAQc9RQA4dMUDDt6GkAD3oAUCgYuOM0ABpAIPyo Adx2oAcBigAJ/OgBR7CkA8DpTAUA+tIYFec0ANzigBwPagBOuKQDhTAdgD2pAIaAG96BhnmgQ7OB wKAA4oAUDjJoAXGaABuBjpQA4phQeCCKdguMxikMAMUAB9qAHhsGkBcsNRnsXzE3ynqh6GqTJaTO p07V7e+woPlzf3GPX6etMzaNDzjAjPn5VGT9KYia3uYbuJXRgQwyCO9JiHMhWkMZQMDQISgAoGIa AEoASgBpoASgBDTAbQAhoAaaQCGgDO1DSLe9BLLsk/vLQO5zGoaLcWWWC74/7y/1qrjMxhg0xiHp jFIBucUwGnimIYyhhyKpMlxIZbfYRtIP0qlIhwK7Ag9MVa1Iasen1iai0xC4oAgvLOO7hMcg69D6 UgORvbOSzmMcg4/hPrQUVulAAT+FAxOvIoAKBCjtSGLQAmMUDFxxSAADmgB2OKAFIwMGgYnfikAD igBwI7cmgYuR0oATGDSAOvSgBQvI/lQA4gjrQAmKAFGelIB/SgBcigYm6gAxgfWgABxQAuOaQB0o ACwIFAC8jFABkZzQMU4NAhuPTigB2B0oGL04pAKvHBzTAUjPfNAhDuVcA8elMBgPNAxRntSAd29K AE6npikA5Tjg0ASocc556j2oB2NnTPEUtuQl2PNiPG7GSP8AGrTM5RN2x+zeQDZFfJzkBegpkWsX 47grw3IosIlwrjKmpGRkEUDCgQlACUAJQAlACUxiGgBpoAaaAENADTQAlADSaQDSAR6igZk6hodv c5aMeXJ6joaadhnNX2nT2TfvEO3+8OlPmQFNlAXPU1QERFADTxTATj8KAGOgammS0eid6BCigBaB DhQBWvrKO8hMbj3BHUGkwOQu7WW0nMcg57HsRQUiuRigBQKQwK4+lABzQAvSgBce9IA/SgYoBxQA Y7UAG2kAY2n1oGFABg59KAFFAABSGKAB7mgBc0AKD27UAKBjpQApPpSAT9KAFBGOKBiggn/61ABg 9s0AA4GTQMd2pCE/WgBNvHSgYoIBwaADHp+VABjHSgBVPrQA7ac0AA4J9aBBux0xQAoPPJxQA0na TigBAQetADlOM80DEyCfSgB4zjPB+tAAPcUgFLDHHagAB/CgCxZ3c1nLvhcqe47H6iqTJaOk07W4 brEcuIpfQnhvoaozcbGskhU5BxRYkspMr8NwaVgFdMcjkUDGVIxKYhKBiUAJTAQ0ANNADTQAlACU ANNADSKQCYoAQ0ARSIrgqyhgexpDOa17TLeCMzREof7nY1cRnPYxmrAQ4oENOPSkAhPYCgZ36tuA PrVED6BCigBwoAWgCpqWnx3sO08MPut6UrAcfd20lrMY5AQw/WlcojXigYHigBO1AAp45oAUdaQD gQKBijmgBeBQAbj0pAJ9DQAmaBjxyKADv0oGBNIAwc0AG0igBcUgFz6UwD27UhikY6GgBACKYD1O Pf2pAG89KADHpQMQelAh3SkAvagYw8GgAB5pgODcc0gAc44oAd7igBQAR6GgQw5yOKAFoACKBjcY JoADkUAKG5xQAucZoACc0AJyO1ADs5NADieaQgzinqDNbTdbltcJKTLD6H7y/SqTIcTpbW7huo98 Dhh39R9aozehbjmKdeRSAmBWQfKcGlYYwgr1FIBKYxDQAlACGgBpoASgBtACGgBpoAQ0ANJpAIwI GccUWAq3t1HZwNLKcAdvX2oSuByGpal9tTgncTkj09q0tYaMsk9xQMQn0piAYpAFAzvAh3ZBxn1q iCUDFAhRQAuaAHA0AKKAKepadHewkMMOPusO1JoDkLi3ktpmilXDD9aSKRCetMYfypAA9MUAOANI BygY5oGITjigAHJoAU5pDFxQITGKAFzjFBQv4UALn2pAIScdKADk9xxQA5enNACDknFIB3v3pjD6 0gDp0oAWgAVaAHHIoATvQA7pxSACcgUANZcYIoAYOuaYx2D+FIBw/I0AKM9hQIkCZ78+lACdsNQA jJxQA3oeaBiYxQAuKAG9KAFHTmgBccYFACEdqACgAJxSATJzxTESA4PWhgTwTyW7iSFyjjuKE7Ca Og03X45sR3WIpOgb+E/4VZm4m0rd1NBOxKl2m7y5CN3pRYCYoCMryKQyMjFADaBgaQDTTAQ0AJQA 00ANNADSaAI36UAUVjazeWaS6kMJGdjnhfpRuByWs6nJf3GRkRLwo/rWq0QFDIxyKTGH3h1pDGEF T0piCkMU0Ad6rYNUQODUxDs0gFFMBwoAcKAFFAFLU9OjvoSDhXH3Wx0qWBx1zbyW8rRyLtdexpFD AOKBhQApNIBRQMPWgBdvHWgB2KQAKBi4oAQrSAUcDmgBcA80DDb+FAAQKADikAAYHApgGKAFxzig YuBikA0ZBoAkHPegA56Y4pAH4UAKDk0AJ06UAJjFACdaBi47daAFUkYIHSgB4OOT1/lQIbuxzn8a AHqwfg8UAKeOOg9KBjWGTxQAwnmgBCM0AHagBR+eKAHqSBQAh5oATjvxSGIcUCD6Y+lMAx7UAAYr 3piJAwIpAaGm6vNYkLnzIv7jHp9D2qkyXE31ey1V4bmJytxDxjODj0IqkZNWNGKVo+h4oAsrIko9 GpANZCtSUMNACGmA2kAlMBpNADTQA00gGMQASTgD1otcDjfEOsfa5TbwH9yp5I/iNbJWQGKDjoce 1IEKG9RQMOKAEOR1ORQAmRn0NABhsZoA7zPNUSOzTEOFIB4oAXNACg0AOFADhSYjP1bTEvosrhZV Hyt/SpsNOxyM0LwSNHIpVwcEUrljAD3oGLxQAYoAMc80AL070ALmkMXPpQAtACgjpSAUjnNAB0oG LjNADTQAAUAKOKADigA6dO9AAAaQxe30oAaDznOKAJA+BikAmfSgBecUAANAC8GgBpyDQMM4HPU0 AKDjk8e1AhDk0AAB9aAHAHrQMduBGDQA1gR3yPWgBD+tACDOeaADmgAHBwaAHscCgAXJ7CkA1h64 pgIwHQGgBM8UABBHOaBBzjmmA4cHikFhwP0pgSRSPE4eNijDoQeaLsTSZvafrwOI70bT2kA4/GqW pm4m2rggFTkHoRTsSTx3GOH5FKwEhAYZU0h3IzxQO42kA0mgBpNMCKWZYULvnaoycUJXAZBdwXcQ kt5N6njpgihoDm/EusfetLZuOjsP5VpFWQHN+pPWi4JDc+1Aw7cUAIDxQAmSDkGgBc+3NAB9D+dA Hed6ogUUwHqaQDxQAtACigB4oAXNIB2aAMzWNLW9j3KAsyjg+vsaloEzk5EaJ2SRSrKcEGkXcYDz QMXJFAAelAAAMcUAOxjtSGKuKACgA4B4oAdmgBcikAufXigBOlACDIoGHWgAXigBSD2oAUEYpDEJ oAOPSmAckCkAJ1oAeO9IBMc5oAXP5igAIyRmgYdPvfhTEISD1oAC3HSgAU5HtSGKegoAaeD70AKr 7eD0NAAQDyvPtQAdqAHAdzSAMg0AIaABOST6UAOLA8UwGEZ+7QITgDJ/KgBM55oAUnFAATgUALn0 pgOQ+9ADw1LYC3Y6jPYnEZ3R90bp+HpVJkNHRWWpQXg+Q7XHVD1pkNF1JWQ8GgROsyScNwaLANIY dRx6ilYoaaQDCaAGNQwOf17VEsUa2ttqysPmI/hH+NXCPVgcpy3zMatgJSGBOKAE3ccUANzjtQIT NMA3UgDdQB3meaokXNMBwNAEintQA8CkAtADhQAooAcDigBevakwMnW9KW7jMkQxMo/769qhoE7H Jk4oNLgOB1oAQZoAVc/SgB2SDz0oAXp0NIYooASgBSewoAUcGkA7OKBiE8mgA9hQAe3pQIUZ9KQx w470ANx3oGLx6UAJn04oAQN+BoAdz60AGQKAA96ABaQC84GaAEzmmAoXPNAAB60gAkdKBiE8e9AC d6AAYoAUflQA/g+x/nQAmDikAmR+NAATQAnPY0wDvQAo+XFACY79qAE6CgA7c0CFABH0pgKPagAz 6UAJnHU0CHhgTQA4OVYFSVYdCDjFMLGvY64VxHd8jtIP6imQ4m2kqyKGRgynoQaZBPHcFeDyKAJg UkGVODSGRsCOoqRmRrmqrp8O1MGdx8o9PeqimBxblp3LuSSTkk1o3bQBjLipGICBTAQn2oAaTQAn egQUwG5oAXtmkB3gNUSOFMBaAHCgCVDmhgOFIBaAFFADgaAFBzwKBEGoXcdhbGSQguR8q9yaTGjh WbcxJ6k5qSwwO1IYlACg0AP7YNACA44pDDmgBRg4oAXvQAe1IBaBi8UAA68UAOJANABnH1pDGnjr mgQc+lAACM96LDCgBaAAUAB6cUAGeaAFwMcGgBc5pAJjb3pgAPXmgBRgikAAYFAxo5P0oAXIzQAg PPtQAZ7UAO6GgAViTj8jQAhABx3oAXrQAg9P1oAM7RwKADOV96AEJxQAg9qAADuRQIcCBTAQ4B9f agBN3NADs8daAE5A5oAA3rTEOzQBPaX01o2Ym47qehpktHQWGqQ3nyg7Je6H+lMhonvLo2UPn7WK A87e1Owh02rJFYNcMMgLlfc9qFG7GcLcSyXU7SyNuLHNXdIoTdtFZjI2OetMQ0+1MBpzQA00ALj1 oEJn3pgJ3oAQn0oEd6KoQ6gBaYDxQAoOKAJQcipsA6gAoAcoJ9hQBm6lrkNoDHbYll7nsKQ0jl7q 5lupTJK5Zj60iiHoaQxCRSAUUALQAuaAE5oAUHHegB2e1IoMgUAL0pAA5oAXpQAooAXpQAAZ60DD 2FIQwHnHeqEOHbNSUKOlMBaQDc4oAUcUAL0oANpBHagAHy80hgfemITHPFACjtQMTvSELj0oATBz QMO2KAHKvegAOMUANHHFAC52j1z2oAaOKAHHnoaAFznjpQAh46UAMHoaAFBx9KAJMj0xTENYZ6Dm gBnOeaAAg9qBC52+9MYM4PagBmexpCFBpgG7mgBTxyMgjoaYGtp+usg8m8G+M8bu/wCNMzcSPX72 F4I7e2ZWU8nbVpW1EkYIYjpUlATmgYoBYduKBDDTATdQAnXpQAhJoEJ1pgITxigQmaAO971QhRQI cKYDxQMcozQIcBhhj8aQyT2FICO5uYbOPfO4Hovc0Ajm9T12a6zHFmKL0B5P1pDsZWeeaRQmRSAT NMBRSGKvFACjrQApNIBO1ABigBeh56UDFpAKCcUDFHSgB2MigAHtSAUjFACHIoGLg0CGqMMeKYDs VIw57UADZxQAACgB2BjmgAzx8uKQCcY9xTACcigYHpSAToOKYB0oATn8KAHDp7UALmkAm3rzigAH y980AHU8UABG3r3pgJ060gADvQAmKAFIyKAAcH1FMQhXvQAY7GgBSOfagAyBQAFwBTEMzmgAbBoG NPtQAmcmgQpOOlACHHGaAANigBpIpiIzyfSquxDaAEoEJnFMAbH40ANIwaAEPFMQhOKADgfWgBGH cdKBDc8e9AHds4HHerECBidzH8KQEoOKYEiLn6UATqoA9qBCkDqSABSuMyNS16O3zHa4d/73YUhn N3FzLcyF5nLMe5pDRHmkAmaBhmgBd3NABnFIYZoAUUAOPbFIYoHFAB0NAD1UucAfnQA0EA4NADsf lSGISenagBeaQCg0ALu4oAA3amAuDjg8UgFJ/KgBpOOtMYAZYKMlj0FKwrjs9jSGJjFABnmgBMHN AADxigYueOOaAEJ//VQApxQAnegAxQAo4oAcfUcUgFDdv0oAXaMZHWgBBhTQA1jmmAwcUAKT3xSA O1ACZ9KAHAYpiF5x6UAIMUAITz1oAPpQA05B54pgJnHWgBOO1ACYoEJxQAZ4zQAHoR3pgM3HHWmI TNADT70wEJFAhvHegQUwEJ5oAM8UAIfagQ3tzTAaaADpQICaAO0tfu596sRYpAPSmBYXrTQEg7Um IyPErstsArEA9cGpGcsf60FCUgCkAtAxO9ACGgBB1oAdQMevSkMf2FIAXrQANQAueKAEk+6aAFXp SAWkMclACHrQME60CGyfc/GqJYZOKAJR0qWWhq/db60CLurAR21qUG0tCmSOM1aIZTTtWZoOegBv egYN1oAD2oAB1oAXvQMTuaAEFADh3oAOxpAOT+lACDrQA5OhoEMH3TQAn8AoAaelAxV6UyRBQUL2 oEOpANahAO/goAalMQP1NAxP4aAEWmIQ9aBid6ZIw9aAFTvQAh6/jQAAUxDT1oAYaYCUCG96AEFM QGgA7UAKKAGPQhCdqYDe9AhTQB//2Q= /9j/4AAQSkZJRgABAAEAtAC0AAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/APOKkYYoAbigBFJU5HanuI1beUSx57jrWUlY2WpIRUjGZ+bFAC5oAXcPWiwD S6gdRRYVxpdMckU7BcYZ1X7vNFhc1iM3DdsCnyk8wxpGJ61VrBe40k0CG0wLNrcmIFSMjtUyjcad ixu81SxOAKm1jTcigkjlfaM5FV0IvqVbhNk7j3qo7Ey3I6oQoFAC4xQAtABQAuKQC4oAXFAC4oAU CgBQKADFAChaEBcstMub1sQxEjux4A/Gh2Q0jes/DkMOGuG8xv7o4Ws3UsWol2aSG0jAYrGg6L0r J6lXsZdxqjPkW6cf3mH9KFETkUmZnfe53N6mqtYi48vkUwIj0NNIYsI/cipLQ7gKaQFO4HyiriKR AF9qszsOEbnop/KgY/aVGCMVJQmKBDWWgREeoFMBJlxzTEyAnHWmhEliMXkZ96Uthrctarww4qYF zM0swTKk9a0MyJyx6k00IltuDz92kxonk2MQU6GkMBaBhuJouKxHLDEOFJ3VVwsReQQuSwAouBEo y3PSgB2dh4oEITu6mgCzZXhtCSF3A9s1Mo3RUXYvnXUZWV4TgjHBrP2b6FOZHb39jBMJVicMOmTk flUSp1JaXBSSI7i/gmbe4ZmznHQU4UpR0G5kaagFk3LBCP8AeGa0dJ9WRzEF3c+bMzx/Kp7VUY8o myqck1dxXAAmgQqqT7UDJGkAj8tB1OSfWgCLNACZoAuVIwzQAnU46UASbIx1fP0FK4yWOZIh8gNK 1x3HfbD2FLlDmGNcuTkcU7BcaZnPeiwrjSzHvTsFw5oGL+NAhKAFJpWAM0wDNABQA63YNLt7YpSG jQhGQR2qDUjWBYbhSBgMMCne+hNrO5X1Bdtx9RVx0IkV6ZIoFMBaAFxQAUAKKQC0AKKAFFACgUCH AUDNGw0W7viDHGVj/vtwKNEFjpLDw1a2wDT/AL9/cYX8qzlM0SL11c21jH+8dIwOiD+grO7Y9EYd 3rU02Vtk8tf77dfyo5SXIzWUu2+Vmkb1Y1dhXFx6UAGKQAaAGPwjH2poDPMr44YgVdguSwbmbljU S0KiWVwPvYPpUxKYpwOwq7kixyYyBSYyJ2y3rQAxlxyOlMTI2FMkiPD0gIbhvmAq0IhY56daYiSx /wCPuP60pLQaepoaqPkFRAuZlqRtxWhmRMhJ7UxE6gRx5AznqaQEQk2rhe1FgBpnKDBosAwEk8mm AjNu4OcUxjlX0pADLkng0XCwrWsqjmNh9RRzIfKxhRhxikTZjWUgUwsM5p6BoLg0WQgwaBhj2pAK MDqKBocDH9KChT5fY0gbiRkDtVEDaADpQBbqRiGgA20ALs45oCwYxQAuKAFpDF6UALQAdKBiGgQU AGKADFAC9KAF25HfFADokCNkdadgLUcrL2FTYbkLI5fb22nNLlC5HdL5xUr2HeqSEyuYXHamIbgg 80wFFACigAPSgAyB1pAOyvY0AOAz0oAeqE0AadhoV3d4bb5cf95+PypOVhqJ0en6BZ2mGdfOk9X6 D8KhzKUS7d6hbWS/vnC+ijr+ArO7Y3oYt1rdzcZW2XyI/wC833jVcpPMZpTLb3Jdz/E3NAhcUXCw baADGKQxCKAGkUwIrkhYWPtTQGaXHpWgi1a1nIuI64YoUPbNKI5C78gHsaogTeB3FAxB145oAkAb 0pDGyJtGTwKaEViPmNXuIbJGGXkc+tTsBWMbLVCLFjAftCMT0NJvQaWpc1UfID6VMCpmPWhkOhj3 yAYzQBqf2NdyRABVwecE0kyrCNoV+qkCJMexp3DlK7aFeoMtFx9aLi5QGiXZHEfH+8KOawcoraFc oAWUKPdqadwsOl0aeCBZAytubaApyTRcaiaGm6OsJEtxhn6hewrnnO+iNFGxrN8wweR6VldmmhG0 EWCzogHuKpORNkYutrE8JZEVNnTA61tC99TOWxgAEnAGTWpmWJLRooS8nynstK5ViDpiqJDoKQAi M5wBQ2kVGPNoiwunTMOEbHXOKzdVI6I4So9iGW2ePqKpTUjKdKcN0QnirMgoAMUAWqkYtAxQpPOK QBQIKAFoAOKBhQgDNMAoEITQAoXdSGHSgA5JoGLxnaTzQIWNjG3K8+hpgicvG2GyQfSlYYjTDgAY b60CIjNzzVCASe9ADhJjvQAM4IGaBCAflSGBVugxigBPKJ6sKBkhj3Abm6UXfQAWFM43Emi7A3tL 8L3V4ocoYYj/ABP3+gobsFjobbRbXTwCse9x/G/J/CspTLSFudQtrQfvZBu7KOSai9w2Mq51a7uR thX7PH/e/iP+FNRsS2UliAbccs56sxyaZI7FAxNtIYYoAMUAIRQA0igBpFMCtfHEB+oqogZoXJqy S9bLgCs5GkRL1eFogEgtQHGGGQKp6CRZMMf9wVNyrCqAvQAUgDcaAIp/uU0JlUDk1ZAFCaAGSJim xouWq4KnFZFIsXMW8cjiiLsNrQz5dOXOVyPar5ieUsW9vHBg8A+9Ju4JWLsF0yHhuB71LGW11NwM Z4pajFbUCwwRRqMqNqEoYhY+B0qkiSVHnuoWVhs9DU83Kx2uWIofLQLkn3NTKVwSsSBeamxdwcrE uW6+lOwrmdcTNIfQelWkSVJoFuF8tyQp9KtOwmrka20VuP3SAH170XuFjP1RvlUepqokyM5+taEC xIXYKBknpSk7FRjzysdRoMFratulCvL6t0H0rzcTOUtEfQYPDwpq73OgivYjK5Eg4AH9a4XGaR36 NmfrS2l1FghRL2Za3oSnFmdanGcLHE3MZikZWHIr2Iy5kfL1Yezk0RqeMVRkN6UAW+ewqRjgMdTi gBM46UBcTNFgFzRYABosAUAKKAEJoGITQAuD1xQFh2cDikMOOwoETRwO6lui0m7DSGSBApULiRW+ 9ngimtVcliBtwwzHcOnvTBEayAP8w46GmxkpUn5WHzD7rCpCxI1q0uOgfufWi47DDZTr0XP0NFye WxE0Mq9UYfhTCwIjucKpJ9KAsSpFLjqFHuaBjhEc4aVfwpBYsQWM1xIY7dWmI6lRQM17XwvcuMzI qf7zf4Ur2HY1bXQfsSZhMZlz97b0+malthYsMdWX7t05/I/0qRWK1w+qyKVe4kx7IM/nRZC1KItf KJYqxY9WbqaYBt5pALs9aGFhMUgEIoGJigBMUAIRQA0imA0igCpff6sfWnETKSkKeRWgFy35Gayk aRI7z+GnAUxbIfMachInkl2OF2k+4oSGJK5TGB+dKwDZ9/kZQ4amtADafJUMcnvQgY0IBVECkYFA yJxuOKTGizAMMoqCkXCuRUrQorzHYjN3AqkS9CgCZMljkiqWjIYyZ9inHWraQgjyqAZOfrSsFySN JZXCR7mPoKHZDVzYstL8vDzuWb+7ngVnKRaVjRCAcYrPcY5Y80xkc8ywjC8tTSEzOlkZ2JJqrEkJ oAaOKBkUhyaYjI1Q/vVHtWkURIot1NUSWrAAOW7gcVnU2OvDJN3NBGNc1j01J9AjdgWIJ60NIcJS QplPc0cqDnkihqWCyt3IropHnYyz1KS8A1scIlAFoscen0qRiUAFACCmAtAB0oAcjAHkUrAK77ug AFIBhPNMByj0oGOPtSAaCScCmATbosArgmgRatrpRa7XzkcYqZRuhp2K8k+XY4GD2pxVkDYwgnDK wP06iqFsSKgk+Yk7/THWkxosxg8A9ulSUWUPQt3qRkq0APBpXAUKOeBz1p3AY1nC38GPpRewBHp8 CnJ3H6mjmCx1/hyGKKxISMDLnNJgawjjP8OKmzC4vkJ2JFAXE+zDswoC4htGoGRtaNz8tMRC9iCP mjU/UUBYgbTIT1jx9DigLED6TGfuswoCxA+kN/DIPxFArEL6XOOgB+hosKxA9nOnWNqLBYheN16q R9RRYBhFFgGEUARy2n2gD5tuDRew1G5H/ZIJ4k/Smqg3EBD5EhjznA61LdykiveD5kqoEzFsx8xp sSLZWlcoa0YbqKLiAqMYxxQA1xgUIGMxVEjJDgYoAaq45qWyizEMOtJgi6oqGWUtQ4TA7mrgTIpx L8+PUVU9CERugY89qtai6l6x0yW5IZhsj9T3+lS5WKUTdt7SO3TbEoHqe5rNu5SVibZU2GOCADLc ChICtcXOAVTiqsIouSadgIWoAjagBpNAEL00IyNRb/SsegFaRIkVcknoKokmtXxJg8VM1obUZcsr GhGD2b9K5meqkxVztzx60hq6Qx2OegqkiJNlC6fe+PSt4Kx5teV3YgwMdRVowEx7imBNmkMBQAtA BQAZoAM0AGaAAmgBAaAJBkY5pAGefl5NADJCQwwcehpgLueR8uc8UCEZgBgUANCljRcZPHGRUjSL KgsRkge9IpEqrjBzkjjHrQMdyv8ADle9IRYXkZByKQx4FADgKQxwoAkFAHUeHubD/gZoJNdUNAEg j460gE2FaYCgYosA4E+tFgHZ45FAXDap/hFILgYYz/DQMYbOM0AMNgp6HFAEbac3ZqQEL2EvoGFM CtJpoP37cH8KAK0mlQHrEV+maeoWIDpEY+5Iy/rSY0rEZ0px92QH6ipsO5Tn0m588uqhhjsaphcz 73T7kYJhf/vmqgTLUr2kbI5DKVPuMVUl2Ei0WA6mosyhhkX1osAnmDsCaAEJ3KDjFAiN2CiqJK7t npQA6PqAeaALkY/erUspF1ehrM0Rm6k4UoCa1iZyI7GNp7hVRSfwpzEjbstGSL558O/p2FRfSw7G lsA4HFSxiiPJpDHMFiXLdaYmUbiYueOlMRUamBG1AETUDIjQAxqBETUAY96M3TGtlsQyAUyRdpHI pDTsWYLoKMPwazlC+p3UsQoxsyVbqPy+oBqPZm8cTHlsVZrknO3861jGxx1cQ5aIqk5NWcoqqWwB yfSgBtMCakAZoAM0AFAC0AFADgtABtoAXABHQe7UAOKjZvAL8/QUiiNix4xtHoBimIcvTYRn09jQ Ia67AD3NAxqqT1oEWI46llE6pikMk28UhiqV7jBFMY84A2gDn36Uhk8QPCnilYGWEhduldEMPKRz yxEIkn2dlOCVH41bwzRP1qA4wgDhwT6YqXhn3BYmLdrDcFeoxWEoOO50RkpbHRaJdQ2umtJO4RBJ jJ+gqHoFjVg1XTpk3fa4wOnJpXAtJJDJgxTI4PQqaBlzy+MHrRcRAyYOKYgAoAcBTAmSPIoAd5Qp ANKYpAAHamMUqVNABSAcAD2oARkU9VFGoDGtYW6oKAuRNp0J7YoHcibSh/CxpiIm0uQfdYUDK8mm y/xRq34UagUpdJiOd9ov4LSuwKr6Pb9lZKdxldtEAJ2yn8RRcCvNo8+MKyn8cU7iKFxo9yBzGzfQ 5pklT7HNG3zRsg9xQA5Igrg0rMCxGMSLSaGi4BhTWdjS41NKe8kDv8kY79z9K0TsS0bNtaQ2qbIk C+p7mpbuCVibbSAcsWaAGTSLCMDk1VhXM+V2c80WAhagRC1AyNqAImoAjagCNqAIzQBkXgHnttOR Wq2IZBjHamSLvxxtosO4zIJ6GmFkNI69sUaA12E57c0wEKt/doEL0IIBBHekAjHeeeD60AOz6UAH 40AKKAFxQAbgKAASEHhRQAGRyMZwPagBu5vU0AJ1pgSRNt+U/dPWkMmbEfTlD60gGSAAgxtuHrjG KYWsSlTjDfMGAYH0NIYJGfSkCJ1TAFIY9QaQx4FADlU54xjHOaBjDHjp0ouCRatFXG5z0OK6aSit ZHNWk2rIvKzN/qwG9ecV2LExWiOD6rK95FiPnqMH0NdEJqZjOm6fUbJHtOR0NDikxKd+o3aGGG6e 1Y1aSmtDenWcHqSrtMQiwTGG3dcHNcv1XQ6vrWpdawspYhMu0uv8DMFz7GuGS5ZWOuMuZEnhW4Ns JIpwVjzlSf1FDKOttr22uEKJMjOv8IPP5VFwJb5rS1shcT3CRk9ia06CMmLXtNd/LWcZPQlTipuB bnuYraAzSMAmOPf6UWAqQeJLVZFjuAYiwyMnI/MUmgNiK5hnUNFIrA9OaV7ASBcrnHFUBGUwaADF ABtxSAcBgUwHKdoxQAhFIBQKAFxQAtMYYFACbR6UgGtBG3VR+VO4ELafCxPyCgCF9JiP3SRQBC+k MM7H/OgLlWXSpumAaNR3Kk2k5+/bA++KLsChLosGf9UyH1BIp3AgOkbDmK4kUjpnBpXQWZYU6hH/ AMtLeYejx4/lRoKzH/a51P72xDD1hl/oaA2J7O7tLqcwIzpcKu4wyrg49uxpWHcW4uAAVT86dhFG TPU0AQtQBE1ICJhQMjagCJqAI2oAjYUARkU0Bjzr++bII5rRPQhieSPL3bselHMO2hEvBpiWhOm0 sp4HPOag0spEhgjOeR17VN2jVU4pakbWsY74p8zE6Ue5DIiqRgmrTMZx5SM/e4JqjMVUMjAA8mk3 YaQ3H4UxCZUd80wEMnoKAG7ietAC5oAM0ALmgAoAeopAGQKAJIpGGQOQeoPQ0MaLEa7GymMHqpqS iZY9oD7SuOgpFWEU98YpAOzQIcKBjmG3b3J5I9KQbDurbvwx6UALigdidx5dqihMM5J3e3pWnQze 462keORGTkjqKIgzoRZSzlZEj4dd4AH5/wBa7qU0jirQbIrq3eBVEi7c8gniu3mutDz+TlZUJAOB z9KQ3uUNTvjbqIojhz95vT6Vx1qrjojso0lJ3MaRi7ZLZPua4td2d1kti2m+C1JkmcbsFEDdfWoK Io53jcPG7KwPBBwRVWuTcvXGq3F+Q91MXZRgZ/z1pWsVcjF03miRBtIwRRy3C502lahJqTCO9Jk2 8rnoB7Cp5bDubJ0mBEaWKHzJAMqrcg0ry6BcseF7Fxcs0qHygcEY4HvWyhZXYrnVQqpikiPBU8Gp aAryhApGMmoYytUgKaQxRTEGKAFpDJI039MfSmId5ZH8NADdvtihAGKAExQAoGKAHKm7pTQDSMUg CgAoAMA9RQA0xI3VR+VAyGSxgfrEPyoAqHSoHzhWXFAHNXNvcfaZN7NBECQqAfMR657U2gIYLWKB y8aYc9XJyx/Gi4iU0ARvSAiNAyJqQEbUDImoAiYUARMKAGMKAGEUAYkr/vW5Yc1stjNiIVxy35ih oAJXsRQhjCQOen0oC4bx6kUWC44SADBYj8KVh8wu5ccODx3osFxu3jPBpiGrwwIFD2ArEk1RIgoA WgAxQAuKAFAoAUCgB2AOtIALUAKqlqYEioAKQ7Eq8VJRL5r7du47fSkVclQxHbyx/wBnFADpfLyB GrKx7NQOxMsQdAvIHUkL/WpKdhTHGuSSQB69TQJIiWQIT5kbYP3RmmkK5IjoBub73VVU00O9jamn s5dHsnWLM0e5JMnvnIq+YxadzMS5aByY9q59qSeoM3oNRn+xQkzNwCMD611UkmzmrNpEbSM6lSc5 HevTSUUeS5NyF+zRiJne5VcAnbg5rGU7dDaMLvc465mMkzPnqeK8yUm2erCKirEWTUlEsX7zEfc9 PrSsMeiMMjBpgS/ZZ1UMyFVPc0gLcVmFdQ8iqD3zmgDofD01laalFvcuM7TgcHNO4zs7W+VIVVIU ymV3EZJxxWblbYpIz18Sm31KQcCNiUIwBkjHP86pNvclm5bXIdmO7kgGpYxz96kZGODSAybzxFZ2 8jookldTghBxn6mockjphhqk+hFD4jiaFpJYTFjoN4OaXOglhakehBH4wtzJh7aQJ/eUg/pQ5WK+ qysajazbGxe5hcOQMBOhz2GKcZXMJU5R6HPHWNWjRlEieYWByew9MdKtJMjUuW+u6jG0KzmHMnYD BHOOfSnyCOvs0LKjudwb9KpILk09uQxKjijlFcrmMhc1IxlIBwYjpxQAlACYoAMUAGKADFABigBj Z7UAc3rp3XrD04psDOApDENAiJ+tAEbUDI2pARNQMhagCJqAI2oAjY4oAhd/ShAV2hjbsM1oSRNb rj7g/Ci4mVZEQHABFWIrSkLwDQIZvwKYEwVsZBpAIdw+9QAMCvJUCkMQE9jimIr0wFoAXFACgUAK BQA4LQApIFIBpNACqtAEi57UDJFHtUjJVhkYfKpP0pDAwuvVWH4U7hYQKR3oHYcMg8HmkBIHkC4D MPoaAY6N2jzg4/ClYdxQMnJ5PqaBDwKBluzuFgLK8SyRuMFScfj9apJt6CbsOeJDL+7SQj/ardYa TZzyxEI7lyMsQoYbVXgCvQpUOU82tX5tETjc2doNa1J6WMoQ6im3lmgm2j7qE9fauSrUUYnVSpuU jkZYnRUZlIVxkH1rhPQ2I+nWgY9DhhjigC3PcM0xy5xnIHpQA2W5ckjuOKTAlVHEYkd8A80AT6Yr yXcaKeWYc0AjtTqcNvFtjkRsZy+4YH+NZMsq2VmuqXiTLk28ZxnH32qkI7CCAQoqr+JoYyY9KQbH O+Itaa2Y2lqcSkfO/wDd9h71hNnoYTDKb9pPY5fawP3G/Ks+Rs9ZVqUdEPVQeo/MUnFo2jKEtg8t UHCc+1NMzqU7ajPPaN/lG0inexi6SluXrK9mhkDxkkd1PQ1SbOaph420OibRRc2wvc4DfMA3UHPS uuDsjx5q0rHVac9vJaRxwuD8tUZlosfJJzggYNIZmt1NZMoZSAWgAoAKACgAoAKACgBrdvrTA5XV G3Xsp96GBUpDGNQIjbrQBEwoGRtSAiagZE1AETUAQSSAUxFdmyaAK7TqJvKPWqsBIFz0oEI6gKfm 5oEUH5JrQRTnj2kYBwaaEQgc4INAFwKQoqQFnjMe3d36UDFKfu8N160DI9oSI+poEVgKoQYxQAtA CgUAOAA60ABakAmKYDlSkxokC0gHgY6UhjgRQMlguHhbKH8KloC3Lf8Amw7Qm1j1pctiisuMciqE OCemKBC7cdaQxQKAHBfamMeFxSEPAou1sFiaKV4+nI9DW9LEOBhVw0Zlu38+5OIo8erHpXQ8a7HO sA09TWg0pSAZ5pHb0DYH6VxSxEmzrjQgloacNvHBHsRQFPX3rJycjRQijz/WLV7K8kt3ztU/Ifbt W0WRJGeRiqEPjHNADlBeUYGcmgRoizjDHcCxP4VLY7DjayybQSu3tzgClcpRNjStFnuNiwKwU/6y bbgAeg9aYjq5PD+nSxohgCFAAGUYJ+tTcZqWVnDaxqkajCjA9qLgWs0gI5pBHG8jHCopJpDWhwMt zumkk27pXYkse1UomjrSkrDoJ3EgEih1PXjmqtcy55RNaXTg8UUkaHY4yrUnTO2liWiB9NeInf8A KAM88cVyuFmexCvzxKc9vbeVuZ2afOG44NGliLzvqMhuHhjMcWFB745/OpT7Ezgm7m7p007aUgDn iXv3Gc1vE8nEpc+geHLq6fUZBET5aE/NjtmtnojlOtJdcBmLE8kms7jGGkAmKAFoAKACgDL17WYt Htt7rvkbhUzjNOwjiZ/F+qySbllSJf7qoMfrSsUdB4b8Vi+lW1vgqTtwjjgMfT2NTsDN+e/trdwk koVj2q0STB1dNyMGHXINCA5S7O64c+9AyuaQDDQBG1AyM0ARtSAhegCvI4FAyrLIT7UwKzsaYhhb AyaLCKV2pP7wcMp61SFcsxzb4gaLCAU0Ax4x1HWmIiK47UANMa9cUANdT2FAxk0Eske9VYhe9NAO t1cgr5Llj7cUMB0sDoPmH5VIzOFWSKKAHAZoAXpQAnJoAULSAeBSHYcKAHgUAKBSGLgUAKAKAHri kUOFAhwz24oAkTJ6jNIoeABQAoIpAOFAEsUTyMFRck+lAzastG6Ncc/7IpOQWNdLYRqAgwB2FRqC JVG2mMeoYnilqIqapoS6vaSDhbiM5Rv6VcXYmSPPrmCW0laKeMq4OCDWyZnaxErAnGDzTA2dN03a POnZUHZT1/KolNFJGjZWEmpXIitkO3PLnoBU6lWsdjfKujaJ+4jRnQBVLLnk96FqS2VvDl7c3Mss U53qqht3oT2qmrCOiUYGTUjFAHcCgBfLHUEikBU1WJ3sJkU53AA/TIqo6sHock+mTB3AQ5B59q3c dDNS1F09beKRvtLHIP3V/wAamOhUmzoIdXiNhNbwps2EMnc+9EmOG5hXt60snzMSQK46rPfwcdCh 80hIXk5rKKudda0epNFbgMolkVN3TNaxhY86vXSWhom6jgg8i0k82UjCseFX/E1olY8mUuZnS+HN OSwsFB5c/Mzf3mpvUmxoscknuaBjOlIBRQAtABQAYpged+PJGOrhCTtCCtH8II5kmsygVyjBlJDA 5B9KLAdcRczeXLOpLTRh1JOOSOtWrWIZ0ukiVdPZ5htOMDjFSIw5jmRj70iiI0gIzQBG1AyNqAIJ HAFICrLKe1MRVY9zQBDIaYELGmBDMRtwe9AyB5CY9g6GhaBYdbjy02802xWJwy49KQWEJHamKwwi gBBgUAGCe1MVizbXHkfeAdf7p6UAbekafFcQGZ3UOxzszTQFbV9PEIzswh/KmM44CmSOC0ABPpSA TFADwtADgtIY4LQA4UALmgBRSGKKAFoGTJgrhlOOxqRimMrz29aBjlUCgB4yeB+lK9g3HiJ+u0ge 9TzjcbFZruNTgZY+grRK5F7F+3RFhE12wiQ9ADkmoZSF/t/7N8tpAir6vyTT5GxOZLb+K7lT+9hj ce3FHsmLmNW28WWjACaOSM+o5FJwZXMalvrOnXOAl1Hn0b5TU2a3He5eR1blCCPY0gL1iP3bn1b+ lWiZFTVtDtdTXMg2SdnA5qiTDTwVKsuUli2jvg5obKWhs2Phe1hGbgmZvToKmyHc2YLeK3QJDGsa jsoxVXZNx8kKTxtHIoZG4INGwhttZwWaFYIwgJycdzTvcRLSAcKAJB0pFDXAIK+tCdhM5zxFfTSu wIKY4dQOAfX8a3TuibHNlgO/JpDLNlP5PmPIcDB6+vas5vQ2pU7sqeZvZnPAPSuSbufSYenyxNWx P2aANtw7DJb0q43Rw4mpzOxe0KOXUdUN5ICYYFKRn1J61qmzy6suh0pggZgzRJuHcqKq7MLE6n5c DpSGLQAh6UAAFIBaAFoAKGBxnj/TpZBFeRR7kQbXIHIrWKugRwxzUW1GXdJ06bUryO3hUkseT/dH cmk0NHrUVvHFDHEFBWNQoyPQUEsjvTttpPpikhHJydTQMjNADD0pgROQKQFSWUDgUAVZHJoAgY0A RMfSgCBjTAjamBVkbc+B0oGKFHFADuKAFHtSAKBgaYrBgUrhYXtTuFhO9ArEqTvH9wkfSncVh8l5 PMu2SRivueKLhYzBbRSf6iYZ/uPwau4iCeCaI/vI2X3xx+dFxEYWmA8CkA4CkMXFAFm3s3nQspUA HHNZTq8krFKJDtwSK0TvqKwoU+lAxwQk8c0gLUVhIRvlIhT1c4ouBJ5lpB/q4zMw/ifgflRcCOa4 knxuwAOgAwBSGMVjjHQUDFHFILj1JXlcg0WC4pYnqc/WiwN3KzwxmXdyD7VaZJXkLK5BzwaZFxhN O4Dk3Ci47CseaBAGIosBPDeTwnMcrof9liKXKO56PpF7Lb+E4rtyZJiCQWPU7iBWckO5Y8Pahc38 Tm5VcrjDL7jpRYdjbQUASAUgHYBFAgHFMBDTELTAUVIyUUhiEc0xGXrOltex7oH8ucDAPZh6GmmB xk8l1YzeVcWyJIp4JHB/xpSkzro0ac3qyoWLnLnPOcdq525M9inSo09SzaiM/vJXURqenrRGI8Ri YxjaJradavrtxtRnjs0++wGN59K2UTw6lS52VpbxWsKwwoERRgAVZhe5NikITaPSgYuz0JFACFSO +aBCEnuDQMAw9cfWgBwoAWgBHUMpVgCD1BFF7AYdz4S0q4lMnlNGT1EbYFXzaAaWnaZaabHstIRH nq3c/U1AFukBR1NttpJ7mmBzLUARNQBBLIFoAqySZBoAqtSAjYUAQt3oAiemgIG6UDIpDhSaYFZV NAD8UgHdKBiUAAoAXNABQAUALQAUABAIwRQBj8k1sZFiG5niGEkOPQ8ikMmFyjf623jY+q/KaQDg bNuscqH2bNAEiQWrn5ZJR9UpXHYPsfzfKxZfXGKLhYtwp5MezGec1hOHM7midivHZhmJeTb9BmtU 7KxFiXy7SE8rJIff5RTuMPtjKMQRpEPUDJ/M0gIHZpDl2LH3oAZimAfSkA4UAOFAC5NACc0ARspz mgCNo93JqrisAgUUNhYkEWKVxiGP2ouKwwxD0xTuFhvk89aaYrHrGi2kUnh+zt5kDIYVyD+dRIZf trG2sU8u1TYpOT9aQFhRgUAPFIBwoAXFAhuOaYgxTAeoxSGPpDDFACHimIhubSC7j2XESyL6EU7g nbYyJPCGmu24GZB6B+KNC+eXcdH4R0xJVfbIyj+Bm4NLQTkzdjiSFAkaKiDoFGBQSx4HHFAC4oAU CkMUCmBS1m8NhYmZcb2YKuRkD3/SmlcEUdD1Ke7mkhnAJUZ3Af4UNWHY2cUhBsHpQAbCOjGgQn7w dNrfpRYYm8j7yMPwz/KlYBRKh4DDPpTEOpDMvWH/ANEHuc00BzshCjJoApTT9loAqyE5pARseKYE ZoAjfgUgIG4oAiegCFutMZVuJAGEYIzTSAFGBxQAdDQAvSgYlIBaADpQAyRwo5ppCbsRi4A6g0+U XMOFwh74osFx4kU9GFKw0x+aQzKC1qZEiqfSgLF6z0y5uiAkeM9zxUlKJbXSPKcrN94flS5irFhb eFBjr9BU3HYcsAJwAQPSgRYjsiTk8UhkVzZMoJU59qYGVcDDD8qYiLPpQAc0AGKAACgBw4oAXFAC gUgF4oAQ4oAbjNMBwSkMeVoCw0rimAm0ntQFgCDIFMR6zYJ5dlAvpGo/SpZJZFCAeBQMcKQDhQAt ABTJFpgKKQxwpDFoACKYhoBBoAcBQA4UDFoEHSgBwJoGPB9hQApNAFW/s4r+3MM2duQQR1Bppgit pWj2+lh/JLFnOSzUMdzQAxSELQAUCCgBTQMaVB6gH60xEUihTwjD/aXtRYDmLzUpprYCeLym8xxG pGCYwflJHvQBjyyFuSaQyDpQBGetIBh5PFMBmMGgCGQ9aAIHoAic8UAQsQoLHoBmmBmqou5/3akO e2etVewJDWDxsVbcrDqDTsJ6C+a4/iosK4qzsOuDS5R8w4XA7rQ4hzDxcJ3yKnlHcSScAYXk01EL lYkseTVkiYoAMUCACgBwd16MaVh3Nez0l7gZmi2H1HGajYrlNOKwtLVRkLu9uf1pXKsSNdgcRKF9 xQBW2M5JOTQBPFbevFAFlI1XoKBkgHakAbC3GKAMfW7Fo0E0eNucMMdKaJMjpVAFABmgAzQAopAK DQAtIBwFACigYuPTigBwGKACgYtABQA+GLfKi+pAoQj1WMbUUegxQQSLQBIKQxRQA76UCM+HV4Jb 97MLIsikgFhwSKAsaNMQUDHCgBRSGOAoAUUAFACigAoAWmIKAFFAx4pALQAlMAFABQAUAFABQA6g AoEQXMixxnPTqfpTA4m/uDc3Dyt3PFICk9AyJz2FIBmOPegBrDFMBjnigCu/WgCF6QEDHmmMpahJ si2jq1VFEsooNoGDgirJuW2aa7t8uN7RdXPXHv60tirXKuKYrWE6UCEJpgHakCFbG7ikNgBTEJ0o AKACgAoA6uS7eQ4BrE1GBGY5PP1piLEcJxjFAydIdvagCTgUDAAk8DNAE8dvIT90igRYEARcHk07 BcrXUS+S3mf6sD5s0hHFNwxGMYNUAUAGMUAAFADsUgFAoAXbSAcFoGOxigBRQMO9AhaBgKAFFAFv TE36jap6yqP1FCEelTSrBC8rnCopZvoKCDjrXxzdFmeTTd8AbGYyciq5BXNmx8a6Rc4Ekr2z+kq8 fmKlxsO5vWt3b3a7raaOUf7DA0rDJ+DQIzbTSEtrszeaz4JKqe2aSVhtmkKokU0AKtAx4FIY4UAF AC4oAXFABigAxTELQMUUAKKQC0AFMAoAKAFoAKACgBaAEYgDnigRgeIb3ZF5anDP+gpgcyT8tICF zigZGOaADFIBrCmBXlI7UAQNQBBIcZoAgJoGZd0/m3B9F4FaohjOlMRPZztbzhhgg8Mp6MO4qWhx C+iWC6kRPu5yPoeaY5KxWNBIUwHwQPPIEjGWNS2OKuyTbbguNzswHBHAzQOXYg5FMkOtABigAoAQ 0AdLaFZMYGAayNTSjh5xQBYEZUcLQA9IHk5yFHvTAnjtUA+YEn1NNIRYSMKflAH4UWASSaGIZllR fqaAM641y1TIhDTMPTgUxGTf381xGTIQi/3R0FSBhu29y3rTAAKQxaAAUAOB5oAWkMUcUAKDigAz QAvSgB340DCgBR7UASRRvKwVASaBXsa+gQxDV7ZCfMkDZOOi4Gaols6Lxjd/Y9BmwcNKRGPx/wDr A0kiThrL+07OAPalvKf5tq8g/UVqIg1C/e7jjEsEKSL1dFwW+tICtGs8SiaLzI1zw6kgUWC5r2Pi zWbPAF2ZlH8Mw3fr1pOIXN+y+IfRb6xx/txN/Q/40uUZv2PizR73AW7WJj/DKNv69KnlsBsxSJMu 6N1dfVTkUgJQMUDFoGLQIxdUv7mO+MVtIiiNQSGH3vakUjbjJKqWGDjkUAPoEFABTAKAAUAOpALQ AtMAoAKACgAoEB4oAUUDK17IsaZY8Dk0AcXqNwbi4Zye9MCkTxSAiY5NAAKAF6CgCGQ4oArPQBE7 UAVJGyaAILiTy4mbvjiqQMzEGBk96sgWgAoYFi/TZMCpJR1DKT3GKEVIhiieZwkaFmPpSFYmnjt7 dgoJncfeIOFB9B60FbDVujHE0cSCMuMO3cj0+lNCuQUEiYoAKADOKAEoAKAOnsLV4WKyHj2qLmpt QREj0HqaQF6KKMD19zTAZdXlvax7pGx6Ad6LiMqfxDxiCH8Wp7kmfNqt3PndMQPReKAKTzc5Zifq aYB5+B8q496kZHIxdGye1AFQc0DHYxSAM+lAC0DFFIBaAFBoAd1oAOlAC5NAAKBpDgKALKQBVDzN sTsO5otYnmEe4LKUiHlx+3U/Wi4Gr4QUNrKccKjH9P8A69MGSfEW7zLa2gPCgyMP5U4kHIRTywn9 27L+NaCGuxcjjtgUATCa5iiMO9ljPBQ9KBDMYFAyzLCI7VZMDceBmgCrkE8r+VICza3lxaNm1uZY j22MRRa4XN6y8b6xa4Ezx3K/7a4P5ipcAub9l8QbN8C9tpYD/eX5lqXFodzobHXtMvsC3vIix6Kx wf1qdRlx7WCaRZXiVnHRsUXGixSGKKYBQIKYAKQDhQAUbAFADhQAUALQAUwCgDl9fvLg6q8SytDB CgI64YkdeP8APFaW0EaugXE0+mrJcHJycH1Has7DKGv3uF8tTyetMDmmNICFz6UAMpAKBQAOQBTA quwoAgY0gK8rUwK7GgZRvmy6xjtya0RLIcUyROlACGgNehdEI82NbiT9zGgYnuQecCpNGl1K8s5M jGIeUh4Cqe1UTKXREVBIUAIaACgBKACgBMUAGKAO9EO1ORzWdjUrXV9NaZKxiRV6nPSgkoya9cON qbUHsOaqwrlX7W7MxZmYkYOaEgK5lJzgAVaRNwj3ykgZOOcCpbGhF5HNIpIepGKRTAjj2oJKanB9 qBj6QxRgUCFpDDpQAooAM0AL1oAcM0AL16UDJYYXkbagzQguT7o7bhMSS/3j0FMncrvIztuc7mNI dhAD3NAWOj8FJnUZG/ux/wBRTEzn/Et6bvXrmYYZUfao9hxVpWMypLdx3BQ+QkTrksUGN3pVAOu5 Q0Fm6yZkUbSOhXB4oAaZrnUZ0jAMkhP+T+lAgaDy5mjEgkAOMjoaBj9RcDy0HRR/n+VAFINjpSAX IxQAAkdCRQA8SH2NPUQodD1GDQM0bHWNQsSPsl7KgH8JbI/Kk0gOgsvH2ow4F3BFcL/eX5WqOQq5 0Fj480qfC3BktmP99cgfiKXI0CZ0FpqNnegG2uYpR/ssM/lUjLNACigBRQBz+uXR+1+XHcSQugBA x8p/KiTGlc3LYuYIzJ9/aM/WhbCZNQAUAFAC0wCgCtdWFvdEGaPcemc4ouxDbmSO1tyqgKqjoP0o QHGXs5nnZie9MZTdqQERNADaQDl6UARSNTArSHJxQBE5wKAKsh5oAhZgoJPQc1SAzcl2Zz1Y5q0S xaBDaAENAXtsOd3kxuOcDAoQ27iYpiENIAoASgAoASgAoAKACgD0SRvTrUlmfeBY4XMnVxgCkwOc IwzAdAaoQL1piH7RnpSuOwAY6HFJgB96AEZlHekURvLuGAMCgREF5oGPHFIYUAKeBSAKAFoAAKAH CgBwoGWIbf5d8p2J+p+lFhNiy3AK+XEPLj9B1NMRX5+gpFWHD8qAHZA7UDN/w1OLOw1W8PHlRAL9 ecfrimRI5KGGW6eUoASql2yccVoZkJGDQAh65oAkgnltpN8LbWIxmmIns8FwWIAHrQMjvS3nPkY5 /SgCsKQDgaAEzQAvSmAUALmgB6OV6HFAEiynoQDQBIkgVgyM8bDuposgNiw8S6vZ4EN80qj+CU7v 50mh3OgsfiFKmFvrEN6vE2P0qOR9AudDYeMNHvMD7SIXP8MoxUuMh3Ndfs11tkXypsfdcYbFIdyc Ci4C0AFAC0AFMBDuPTigBN2E3HtQBzmvXZ5iVvc4piOec8UhkDGgCM0AA60AKxwPSgCvIetAEB60 AQSmgCs3WgCrevhAg6sefpVxEyrjAqiRKADFABigAxigBKAA0AJQAhoAKACgAoABQAYoA7a61OCE lY/3j+3SpLMHUbySQM+7LdvahCKEcuBhqYiVXXPBoGOMoFIBhmPagY0l26mkMAhoAdtAoGBHNIAH WkAd6AFFACEUALjigBR6UAPjRncKgyTRYL2LeyK05kxJJ2XsPrTFcglmeZsk5/kKAGqoBpMoceKQ CDmgAAoGbtlp11e+F76OzXdK8o+X+8AOn61SdjORykyXVhI8c0csDEYZWBGRWiaIIvMzzRoBLI8T hdi7cKAfc9zTALe3e4dljxlVLHPAwKAGFfWgAySAucgcAHmgQmz2/KkMNh7EH9KAGkEdRigApgLm gAFAC5oAUHBoAeGoAmgwNz5+6OPx4oESkSpgOhXIyAeOKAHAK33xgZ5z2oA0LeOWKVTpt8ytk4AY jtRZMZqWfi3WrKZYp5Y7heOHHP5ip5EO51Vh4timdEuYGjLHG5TkCs2rFHSDpQAtIAoAKAKd/OII mPpz+NMDjbuYyylietAFNzxQBETQA2gBVGOaAI3PpQBC54xQBC5xSAqytTAgNMDPmbfKx7dBWiJG UCACgBcYoAOlACUAFACUAJQAlABQAlABQAUAKKAL7TMeBhRQlcdxrAlDTasJMrDNSUOANSA8KT16 UDJAoHSkMXFAwxQAUgDigBvfigBaAFAoADTAUHmkBYhtjIN7nZGP4jTSFcdJdLEpjtV2ju3c02xb lXljk1I7DulAxwJ/CkUOoEHAoAM0AWtQu5ItMsrSJ2TezSvtOMnOB/I1rTjzS5TOo7FNX1CYiGK5 llU/wO+R0960r040o8zZjCfO7Iz7y1uYJSJoijdcYxWVOUZxvFmrTjuVw7KeasRLHOy52sRuGDju KAHeZn60AW3ktzbQqi/vBneSMZzjAoAZbwyXEyQwqWkc4UDvQAMhQ7Wx1xQAm0D2oAYY8jgD8KAG lCPb60ANCkduKAFzQAAUAO7UATpxBjOCx/z/AFoEaFtq9xDGY5UWWM9dwyfrn1oAg3RvIgmyI2Yl sCgC++n2jQPNbXq/KpOxuG4HajQZWtVLSqDzgZP+fzpMSOj0K3NzqdvFjI35P0HNSyj0kDAAqBiU DFpANZtoJ/KnYDmteu8t5Snp1oA56Q80ARNQAxqAG0gJMbVpgQOeaAIGOelAEErbRSApuSTVATW9 o06kdN3AzSvYLEWpaFLYQCXzFdf4u2P8a0i7iaMvFUSGKQBigAxQAmKAENACUAFAAaAEoASgAoAK ACgC3tyvXkVaJehJEjsCFBOOahuxaVyv0Y4qNyth60DHgUgFoAUEfhSGIeKAEzQAp6UAJ0FACigA xmgY5Yy7BVBJp2FexaCQ2gzMQ8nZB0H1pktlee4kuG5OFHQDoKQWI1H4UikOx2FAxQOaAHDn2pDH dqAE6dTxQK9iN5f7tWokORBLMZn3HI8tMDn0/wDrmtI+67kPUksdQa2lLPGJQVKkZx1qMRzVopN7 BTUabOo0LXNMJmW5xCX2ovmDcNoOTzjuSaijS9mmr9SqkuZnNasLee/up7cJHAZTsUYAxnjArYko GDPK4P8Au0gGeWw6c0wEDMnUEUASxzlWDKxVh0IOCKBEgkz1NAE6GFriMMdsWRkn9aAHXAiE7+T9 zcdv0oGNjhlmDtGhZYxuYgdBQAzYCeRg0AN8sdiPoaAGlCOoP4UAJjPAOPrxQBoaasRuwspj2Kh/ 1nT8PzoEaGq2NvbQxPHE6PJ0IbKnpnigDLIMhYKm5V68dKYCIvzY+ZfbtSA0bAZ3P74pMDs/BFtu uprgjhF2j6mpZR2ZqRjaQC5xQMp39wIYmcnGBgfWgDjbmUySMxPWgCm55oAYaAGGkAq8dqABzx1p gV3OKAK8jUAVZXzxTAdbweYcnhaTAsXDmG3dkO0qOCO1KOo2YUks053TSu5/2jmtkrEXGY5oEJQA hoATNACZoASgBaAEoAQ0ALigBMYoAMUAFAB0oAndsgZwMelU2SkOSZ40ZVOA3WoZaGgZpFDwMVIx 3SgBMg0AL+NIAwSPegA+tAxcelABQAtAE8Fs8uWJCoOrHpTBsdLdpApjtV+rnqaZF7lPknLcmkUP FIoUCgBQKAHAUgHAUDEdwn1pqNyXKxXdix56VpYzbI1XzZ1jMixg/wATnAFNCEuo445NsEhlTH3t u3n2FMCBQQT7c0CFGTzzQBakAFsoBQnPI2/MPx9KALOn2NvcxEveRwy5wEcHkeuaAIDGxViq7gp5 P6UDISiEen60AMa3DcqAfoaBEflOp4P4GgYZK/eytAEiMewDfSgRNBeyQpLHG+1JRtcEdRQAbupN AE6CA2oJyZi/Y8BcUALbWstznyVLYpMCJ48EhhyOue1MAwhGDjigByjBB3McdAT0oAlt55bUvsCs jdVI6/5zQA+4umupmmdFQ4+6owM0AXbVdkKikM9I8I23kaQjEYaUlz/T+VZjNkmgYmaTAR22rkde 1AHM69d7nEKnhetMDCY0gIjzQMaaAG45oAU8CgCKQ0AV5WxQBUkegBsMRlf2pMC/hUX0AFFgMW/u zO+xOIx+taxRLKhNMQ0mgBCaACgBKACgBKBgKBBjFACYoATNAC0AFABQAAZoAf16DFSUkORTQ2NE irjtSuULSEHFACEDNAC49OBSAcvFAxaAEPFAAATTAuw2yQp510dq9QndqdhXK11dvckKAEiHRRQI gC46Uhj1WkMeBjtQMWgBwFADugpIHoRvLgYX86tRIciAknr1qrEMKYEUiFiNoyaAElhMcaO3R+mC DTAgB2555NAEkWS4BwPegRPPPtkAVYwAOShyG96AEDA9VKn2oAsQTzW8m6CTaR1GaAGXs8lw2+RV 3HjKrigZZgtbSeNdt0scmPmVwefxoEVgPnVScqTznnigZLc28KtiB2de2RigCq9urcDaT7daBDGS RTjO7HZ6AG7gv3lZPdeRQA9efuFX9uhoAu2Opz2BYR/KWGMEUDTIXlLszMcsTk0AyxB9k/s+XzCT dFwEHYDuaBEGdoJHrxQBO1vPHBHOyYjkyFOeuKAGp87IOxOaBmvaxtLNHEgyzsFH41IHq9tEsECR rwqKFH4VDGONIYDigClqNyIYmfPTgfWnYDjriUySMxPJNAEDHFIBjUDG9qAEPH1oAaxwKQEEj4FM CnK+TQBEiGVsdhRsBet1GHwMKnGfWkwMvUr3zCYYj8g+8R3rSMdCWzP6fSrENbikA3NABQAlABQA AUALjFACUAFABQAhFABQAlAF6x0ue8IwpVPU0mx2OksNHgtgDt3N/eNQUkcvgAcCmMM0gFoGJjPS gQdKADpSAXNAw6UAGTQA+NWdgqgsT2FFgZdHlWIBfEk393stMncpzSvcSb5Dn2ouNDQB6YpDFwKA HD2oGLg0AKBjrSYwZlUc/lTSJbIWkLewq1EhyGZqiRKAFoAltIlnu4Y2zhnCnH1oA6vUfA+5SbK4 Bx/BMP8A2Yf4VnzDZzF9oV7YP/pVvIkeeXA3L+Yq1IQhhghgM1swMiep6++KoCi7CWUucKx6jGBQ IuzXcl0qrKq4U53Adf8AOKAFjitJ4wftJilA5DKSCfrQBAPMDBUyxPYDNACbkbquD6rQBoaNd2th fxz3cAuoVyDG3Q8f40FJ2G6pew32pS3NtbLbREAiJOgIFCBkU0dlIgeGRkbbyjjPOOxoJIY1kMix IC7McBOuaABsAlZEZWHB46fhQAw20cn3dp+nBoAb5UsfCvkf3XGRQA0sB/rIivuh/pQA9FD/AOrk Rj6Hg/rQA5w8eFkjZD6EUATNeTSwxwtJujjyFX0pgT2ab5i3ZRipGdT4RtPtGrxtjKxAuf6VDGj0 NyEQk9FGTSsBzcPifzLhAbdlikcIrZ9elU0M6Bn2pn14FQBy+u3m9/KU/KtMRiFqBkeeaQDutAwb AFAERbGaQEUjcUAVJXzTAgALttWgC2kYjXApAUNQ1DERtoDgZ+dvX2q4xtqyWZdaCGk0AIaQBQAU AFABQAooADQAh4oAKAG0AJmgAGScDmgDd0nRt+JbgfRalspI6OONYlAAAxSKsJJMF70AcSPegApA LmgAFAB0pAH6UAFAwoAlghed9qDP9KYi1JNHZKY7chpT95/T6Uydyjyzbick0i0rEgIpAKQDQMMU AJQAoz24osFxry7eByaaRLZEWzya0RDEzQIM0AGaACgC7o67tVtB/wBNV/nQxo9VPArIbADj1FAG NrGi6M0bT3Ua25PHmRnac/QdfyouBzt34KlkjE+nXEdxGwyob5WI+vSrUhHPXmm3mnti4hkhP+0O D+PSncRftdOs72DEczi4Rdz/AC8H6fyqrAVxY3VtJ5kOGIHYZx+FAht1evOoWeGNWByWVME/WgBl v+7USSQmRGBx9c/5FIBtvHKc+VGXf+7jt3/pTAZlCcOhU9OKAHorIwkgkw46EHBFAE1zqFzLGy3I V9xGW2jJx2yKYDdPtoLqVlnuVth1VmGQTQA65t5LV1QTJKCu75TkYz3pAQq6suWX/vmgAa3jkHGD 7dDTAvLpF2EH2G5S4Tr5een/AAE0AU50aFyt5ZtE/qnH6Hj8sUAT2LLu2QzJkn7soKn8+R+tIZ6X 4Q0x7G0M8xXzJwDhTnA7c1m2M6B8OpUjIIwRSA52HwyIryN/PJijfeq96fMBo6nciCFjn2FIDjp5 DI5Ynk0AQE0AIBk0DRJ+lIZFIeaAIHagCGV8CgCscs2B1oAsQxhBx1pDKOpX2wGGI/N/ER2q4xJb MrpVkiHrQA2gAxQAUAFABQAtAC4xQAlADTQAUAJQAmKANzQ9NDETSD6CobKSOkUBF4pFFe4uRGOt VYDBvtXwSsfJppE3MpJOxpWC5IOelJoYuMUhhSADQAUAFAE9vbNPkn5EHVz0FNAx812qoYbUbU7t 3amIrBcHmpKSsOHHagA6UDFBIoC48GkCByFGSadguV3lJ4HStEjNsbmmSJmgBd1ACUALigBRQBp+ G0363Zr/ANNAf60PYaOr8UajdW17HFFcfZ4xEZM/3jzx+n61lHuM3dPlaazhlf77IGP1xQBX1qym u4omtthkibIV+hBoAtaXbNaWMULkFlHOBxQBaeNJFKuoZT1DDIoAxL/wjpl3lo42tZD/ABQnA/Lp TuxWMS78MavZgm1lS9jHRW4Yf5+tUpCsc5qjXazBbmCS3YDBVx1P1NVcLECXcywmEs3lHqBxTAI5 5Y3WS3ba46/jTERyyOZZHkXDtz070gJbK1imjYPcrDKuNoYfe9eaAGl5ImYbg6qSM9jQMUtE/wB5 Cp9VpiE8k4JikDe1AFqwlhsiwubUTIQBk9R9KQEMzxSTO8cflx5yqZzgUAO3MgTBIZQOR+dAFu31 G5DKpYS5G0CQbsD8aLgX4AiRKWRfmy3I9akZ6VpMBttMtom+8qDPsfSoYyzSGMkfaueh7UxHKa1d +dNsX7q0AZDCgBhIFACqMnihjQ5jxSGV5Dz7UAV3PagCB8s20UASpHsXnrSuMp6heiNTFEfnPU+l XGJLZjjg81oSxDzSATmgApgFIAoASgBRQAtABQAUAIaAEoAQigCewtzPcKuOO9J6DsdlbRCKMAcY FQUhLmUIpPpTQzl9Tv2kcoh47mrsS2ZtBImaLAOVytKw7kyyAjnilYq4+oGG2gBQKALEFuoXzJjt jH60xXG3Fy04CINkQ6KKYESrgccUihwApDFIoATp0oAGIFCQNkRl9KtRIchhYk5JqrEiUCCgAoAW gBRQAvegAFAG74OTfr1uf7oZv/HTSew0eg3Fpb3JXz4UkK/d3DOKyQyRVxwOMdqYDxxQA4UAOFAC 0AOxQBHNbw3CFJ4kkQ9nUEUAYGo+C9NuAWgLWjdfkOV/I01ITRzVz4S1G1JltfLvIh3hbn8qvmFY w7kSxTbZImiccFWXB/HNFxCrbrJDvwQxOBt6dh/WqV+gNpbjGtnjOGyB6MMZ/pTcZCUol2G+hWBL e8s1dU6Mvyt+ffrQMottGCuRz37UAW5bW9toxI8TGMgHceQM+9AECNHIwDRlWPcdDSACdzE+vNAE tspaQe3/AOqkB0mj2X27UrWI/cDgsPYc1LGekDgVJQ3vSAzNYuxDA2Op4FAjkpJCWJ9aoCCRqQEY 5NAEo4AoY0MkcAUhldnJFAEJyTgUgJI4wpPdu9AFPUbwQjy4zmQ/pVRiJuxj47nk1oSNOaAGkUAF MA6UAHakAmKAExQAo+lABQAA0AFACUAFACUwNrw/ECxbFZtlI6aNclV9aEUjF12cwxMB16VSQPQ5 c8nNUZiUgEoAKAFBoAkSQrSaHcmjcMcd/SpsUmXVWO3UPOMn+FP8aVhtlaaZ7l9zngdAOgpiSEAA pFC5pAKOaB3FOBQDI2lA6cmmokuViBmLdTWljMKACgBaAAdaAFoABQAvTigBRQAtAHSeBEzq7t/d iP8AMVMtho6/X746do91cKcOiEIf9o8Cs0Nnmi6vfpKJWnkLkfeLHOPrWthG/pvjW7jKpcok6+p+ Vvz6UNAdPYeJNNvGVPO8mU/8s5fl/I9DU8oGypBAIPBqbDHCgBwoAcKAKGuRSzabIsIJOQSq9WAP IoAoeGIGie5ZYZIYGI2q55z3oA2Luytr1Nl1BHMv+2uaAOdvvA1nIS9hNJavnIX7y5/GqU3ETimY t5oetWGfNgW9gHdOT+XWto1jJ0UzJup7WSSBUiNu0cW10deC2Tzj8f0pN3LSsUW8re2FwCTgj0pA Sn7SUKJMZEYcgN2+lAEa8ZOMYGOnc0AAI6d6BlqzXnPvn/P5mkwO58E226aa4PRF2D6moGdax4qQ IZX2qecZoA5LVrvz5yAflXgUwMxj3oAibrigAHA5oAC+BxQMryvk47UgIySTgDmgZPHF5YyetSMr X92lrDhQPPcVcUSzBJLEsxyx5JrUkSgBCKAEI7UgE6UAJQAhoAKAFGKACgAoASgBDQAZoATNACUw Oj8OAbF+tQxo6EDYwPoaRRheLoDE2OxORVpAzl8UXIDFADaACgBaAHxI0rhUUkmkCLuY9PGBiS4/ RaYyqZGdizncTRYE7EiyLiosXcdkVNrDHdOtACNIEFVYTZA0jOcdB6VSRDYymIWgBaACgAoAXpQA CgBaAHCgBeKACgDqvAK/6dct6Rgfr/8AWqZbDSNH4gzeXoqR95JQPyBNRHcbPOyx65rYgcHH0NAx 4kIGDyPQ9KQF/T9av9Px9kupI1/uE7k/I0aBc6bT/HxGE1G04/56wHj8qnluO51Gm65p2pAfZbuN m/uE4YfgalqwXNIGpGLQA4UwFpALTAKAKl9pdlqC7bu2il9yvI/GncDmr/wFbvl7C5aE/wByQbl/ PqKfMJo5u/8ADWq6flntWkQf8tIfmH+NNSuKxl5PQk8dj2qwIViYTlsDGc5/pQBrW64GAOgx/n8c 0mB6L4Rtfs2jRlvvSkuf6foKzGbJoGY+sXghgOD8zdPpQI5V2zk55oAgZvTrQAhPFADWb5aAImfa vvQMgyWb1JpAWoY9gyeppMYy+u1tItxwXP3V9acVcGc7I7SSF5CSxPWtbEsZmmISgANACZ5oAQmg BDQAUgEoAKAA0AHSgBCaAEoAKAENACUwN3w7LhcZ5BqHuNHUg+YoNKxSK2t2v27SyQMyxcH3HarQ M4R1Kkg8EUyBlACUgFAoAlt7Z532r+J7CgLFqWeO1QxWvLn70n+FAyj16nnvQIUGgApiHBjUlXF8 w+tFguN96dguFAgoAXpQAUALjigBcUAGKAFFABQAv0oAKADOKAOw+H4zJeN7L/WpkUjotb0i31m1 ENwWUqcoy9QazWg7HC6n4Q1GzYmFPtMXYx/e/EVopEWMExtG5V1KsOoIwRVXAQD8KAJWhkRFdlwr dDmgBASBxTsABhkHlWHQjiiwG1pvifVtPwsdz58Q/wCWc3P69aGkFzqdO8e2cuEv4JLV/wC8PmX/ ABFRyhc6azvra+j8y1njmX1Rs4qXEZZBpDHA0ALQAUALQBn6vqD2KxiKLe7nAJ6U9hFYafYa5AWv bFBMp2tjhgfqKVwMe98BqWJsbsoP7koz+tVzBYkg8GSIAGukGOpAJzRcLHXQxrDBHCnCooUfQUhi TyBEP6/SgDjtXuzPcNg/KOBQIzXbFAEYPOTQAjPg4FAEbPzzQBWkfLYHNAyxBFs+ZutIB9zcpbRF 3/AepoirjOenme4lMkhyT0HpW1rEXIzQAykAnSmAFiKAEoAKAE6UAJSAKACgBDQAmaACgAoAKAEo AaaaAvaRP5NyATgNUsDsbWTKikUi2rbG3AZHQj1FGwzlvEek/Z5PtMAzBJz/ALp9DV3JaMAigQyk BZtbUy/Ox2Rr1Y0APubxdnkW42x9z3akBUpgFABQAZoAdQAUAFABmgBc4FABQAuaAFBoAM0ALmgB M4oAKAFzQAuaACgDtvh+uIbtv9pR/OomWjrqzGAFMkq3umWeoJtu7dJO2SOR+PWmBzOo+BImy2n3 DIf+ecvI/A1SlYRy+o6HqWncXNu4QdGX5l/MVSkIzuRVALntQAo9jigB2445GRQA+GRoZBJBI8Mg 6MhwaBHQ6d401WzwsxS8j9H4b86lxRR1OmeN9Lu8JcF7SU9pB8v5ipcLbAjooZo54xJDIsiHoynI qWmhkoNFxC0DK99aC8iVPMaMqwZWXqDQA3TrGPT4DHGSxLbmY9SaBFoGgBc0AL2oGY+tXnlQHB5b gfSmI5R3y2aAIGOTQA3dnpQA1mCjpQBAzEUwJbe3x879fSkMfPMkEZdzgCiwGDc3D3Eu9zgD7o9K 0RJDmmA3NAAT+FADetACHjpQAnNIAoAKAAigBvQ0AL0oATFABjFACUAJQAtACUANNAAGKsGHUUAd Xo16JolyfmHWkBuRtkUikOZFaNo5F3xOMMv9aNhnH63o72Uhkjy0DdD6fWr3JaKFtart864O2Ifr UiI7q7afCINkS9FFMCCgAoAKAFoABQAtAC55oACaADtQAUAFAC0AAoAWgAoAKAF4A70AL9KAEoAc KAO78BLjTZ29Zf6ComWjqM1mA4UwMLxP5iG2kR59vOVjB69uaYGxaF2tYjICHKgsD1BxQIlxng8j 0pBYyNR8LaXf5byBBIf44fl/TpTuxWOV1LwNfW2Ws3W5QcgAbW/KrUgsc3Pbz2shjnieNx1Vlwaq 4hgPpTAdxigAB98UWQC7j3GR+dGwFqxv57GQPaXEsDf9M3Iz9RQB1GmeObuLCXkcVyv94Hy2/wAD UuI7nTWfirTLgqrytbue0owPz6VPKwNpHWRQyMGU9CpyDU2GOBoERXU0dtC08zhI0GWJ7UJAU9N1 q01KV44GO9RnawwSPWm1YC7cPsTrjPX6UkM4/V7vz7g4PyjpTEZjNzQBG7DoKAGF9ooAiZiTQBPD DyGf8BQBNK6xoXchVHU0JXA568u2upc9Ix91a0SsK5WOKYCUAIaAEoAMUAIeKAEpAJQACmAUAGcU gEyKABQXYAdTQA+eCS2lMcq7WHbIP8qAI80AFABQAlACGgBCKYE9jdtazBh93uKAOxsLtZkBUikM 0kYEUDuJNGskZUgFT1U9DU7DPObm5e5fLcKOijtVEEVMBaQBQAUALQAUAFAC0ABoAXpQAUALQAUA FAC0AFAB0NABQAooAUUAKDQB3/ghcaMT6ysf0FZyLR0QNQASSLFGzuQqqMknsKAM2LxLpc0nl+cV PYspANVysRrRusiBo2DKe6nNK1hjhQA/HpQIKAILuztr1PLuoY5V9GGaNQsczqXgS1mBaxlMDdlf 5l/PqKd2gscpqfhzUtMyZbdmjH8afMv51akIyjx14qxACRQAucnkUAPAoAejSJ91jQBo6Zq91aSr 5MrRnOMocfp0pWA7bwr4iutVuzbzqjL5W8SAYPXv2qZKwzc1i0a/02e3QgSMPl3dMg5FSnYGYnh7 Sb631Bbi7WONY4jGAMZb8qG7jL2tXvlwtg8v0+lCEcpI+TQBAzc0ARE5PFADTyaALNtb/wAbj6Ck BIADM0kjFY4lz7Z5poDC1G+N1JtTiFeg9fetErCKRx1piGZoGKTQAlACUAGTQAmaQCZoAUUAAGWC jvxRcAuI3hOM5A6j0pXAi3ZpgFADcnNADgc0AL1oAWgBM+lABQA05oAKAEpgXdNv2tJACTsP6UgO vsrxZkBDZoAvq4IosNHmdAgoAKAEBBoAdQAUALQAUAKKACgAoAKAFoAWgAoAUUAGKACgA+lACigB ccUAKtPqB3nh24Ww8L/aGUsELNgd+cVlLcpF/RdXOo+YrwmJ0wcdiD3pNDJddBlsfsynDXDiP8Op /QGiIEd7o1nOuDGB24q7EmUNIvtNZpNOunx/c7UDJLbxbLbymDULcM68Fo+tFgOtU5ArO1hjxSA5 jUYpU18siTuzMhiYHAA4yPp1qgOnFIBRQIytS8NaZqWTLbiOQ/xxfKaE2gscpqXgG6hy9hMs69kb 5W/wP6VamJo5m7sLuwfZdW7xN/tLiqUhWIAeeaqwhc80DHR5Lsq/3aQHpXgOyENhLckfNI2xfoP/ AK5/Ss2yjqMVIyC7k2xkZ4xk/SmhHG6pdefOx7DpTEZrtQBEx7UAN7cUAWbe2zhm/KkMsOcL6Ciw GBqd/wCexhib92DyR/EauKsSZ/SrENJoATNACE0AGaAEoGGfWgBCaQBQAfSmAK21gcdKQF2VxcZZ VGSOg6Y9KjZjKXkHcQuSB0+lXzCsRkAMR6U9wHxLE27zXK8fLhc5NIBnyg0AP8yEQgbH83P3t3GP pimA2NkIJbikA8tEOhz+FMBQYjxkUbAIVTsaQDCnoaYgWMv0Iz7nFJuwx4tZjyFB/wCBClzBYtWc t1ZMDsYx0XCx02naik6jB57imM4cUCDNAEZchhmgBDwxIzimBKhyKQDqAFFABQAZoAWgAoAOKYC9 KQBn0oAWgBaACgAoAXFABQAtADhTA9D0C1Sfw5DBIDskU5wfU1lJ6lFrStHh0xnZHeRnAG5vQdqm 4xt83/E4szKwjgiVm3McBmPAH86qIF9znkc1oIYSFUs3AA5pCOG0tP7S1+MkZV5S5+g5/pSegj0g Hmsyh2cCkMyL3xLp1nI0ZkaV1PIiXdj8elVYQtl4o0y8kEazGJ26LKu3NPkGjZU5qBjgtAC4xQxE Uwt5swzCOTP/ACzfB/Q0AYWpeCtMu8tAGtXPePlfyNNSYrHL6h4H1O2JNvsuU7bDg/katTE0ZEOl XyXXlvZ3AfOSPLPQU+ZCses6NbGz0u2hYYZUG4e55NZtllxmCqSegpIDC169MMJQHDv19qoRyjtk 5piIWNAEecnigC3a2+7DuOOwoAtOSF+XGaQGHq+oZzbwt/vMP5VokIyRwDxVCGk0AJn1oAQ0AJn0 oASgYcd6ADNACUAKPakAZAoAaWFNATWwl2lkB2juKiZpGDkro1YdQsBJhbFslAuPMx83c9P0oS0J ujK1OeOW7Z44vKXoEznFWhXKe/FAhpce9ABvoAmihBUFuCenFICVLZN+PvH0XmpbGot9CVoJG4W3 IX1I5ouWqUmRtaSjP7s/XNO6H7KXYia3lU8KQKd0TyS7Ddjr1Q/hRoTZoAxXuR9aLIC0sV0VRhuC noT0qbocU5aIEuXil2vujbs1MJRcdykKZIUARHg0wEySfWgCaMYFADqQC0AFAC0AFABTAKAFpAOx zQAlAC0AFABQAooAKAHCgBwpoD03RE8vSrVfSMfyrF7ll8VIA6pIhV1DKeoYZFCApHT/ACmzZzNB /sH5kP4Hp+FVcRS1ea9TTZ0NsS7KQHiORz39RVqQjP8ABFkwu5bl0KqibVyMck//AFqHJAdkOtZl IwfGGqmxsxCjlGlB3EdQvoPrTihM4WO/L5VR5ajoAoq+VBclt5IJmMdwgOeA68YPak0FzrvCeqzJ O2lXrksgzEx6kelEldaAjrQeazKHUAc3d2Uqau5gglYs4dJGPA9abYjpKQBQADrRZAO6UAQ3MgRC ScBRuP8AShAcTqd0bi5ZieO1WhFBmoEQucnigC1aW2fmYcfzpAXTwMCgDI1jUfJBghP7w9T/AHat IDBx35qxATQIbntQAhNACE0ANoGFABQAUAKoyfbvQA6IKzkHJRckmlcdgeVAwCknHQgYpDshgkwc /MPxp2FZFu11Bod+5AdwwB6VMlc6aGI9j0uQSyRM+9Iyh9jQk0TVqU5u6VmVpQXcsO/rVHOR+W3q KYDlhLcDJNADhGsYzuU0AOLliB/CBj60AtC3BfvbgLGFUewqHG5tGs4kv9sT55FLkNFiX2Hf2y38 UYP4CjkKWKfYcNYj/igFL2ZX1pdUNOpQN/yyx+FNQF9Zj2GSXlsRzHn8KHFjjWpXu0It5GpGwlfY 9KnkZSq073SJJZ4J4WYgb1FCTNak4TjoZWa1PKEoATAPWgBQoHQUAOoAKAFoAKADoaAFoABQAtAB QAtAC0AJ0oAX9KAAUAKKAHCgAzQA5aYI9StB5VpEp6KgH6Vg9yyyjBgCO9IB+OKYCe1ACimBItSA 4UDOB+IbN9viGflCZrSJLOWtlOcngCtCSxuUMgbIBPNAHQXVykM2h3sTfvMBZPfDEfyFJjR6MK52 WOBoAM0ALmgYooEHFACMdoJPQc0AYGvXhii8kH535aqQjl5WqkIgJpiLNpbFzuYfLUsC8eBgcUAZ uq6gLWPYmDKw4Hp71aQHOEkkknJPJJqxCZwOKBDc85NADaAENACGgYUAJ7CgAoBk0MG/azMFUnHu alsaVxZY1jX52AXsg6n60kPYhaQsmwAKmc4FUK40CmIXpQAp6UgG9KYDTQAYAoAePlwTx6UiraET fO5Y/dzwKCR3amAdqACgBKAA0AJQAlABmgCORiOBQO7JOlIQUALQAUAFAC0ALQAUAFAC0AFAC0AL 0oAKACgBaACgAoAWgBaADvQBJEPnX60Aj1SJkeMY+6R0rF7lkq4UYHApASDpQgONubm6TXZP9Ik8 xZgqRAHBUn/CrQHZL0qWA8cUgFFAHnvj+4MurJDtIESDn1zWkCWYSR7YlHTPJrTYRHhpZVVBnJpN gbltA13qmn2KDIjZS30Byf61MmNHpynisSx2aACgBQeaBi5oELQBBdzCJCzHCqMn+lUBxWoXJuJ3 cnqaYjOkOaBE1lamU7nGFpiNI4UADjFIChqV+lnDuPLnhV9apIDmJJWlkaSQ7mbkmtBDM+2KBCE0 AMJ5oAM0AHegYh6CgAoASgB8Sbz0J+lTJ2HFXZPJIlu/ADSY49FpRRbaSsiqSWYs3JqzMMUgCmAZ oAM+9ACGgA4oAmtoRKzFjtVRk1LHHUgmcSyYRdqjp9KaQ2+gn6UyRe1ACUAFACUAJQAGgAoAKAI5 EJ6DmgB1IBaAFoEFAxaACgAoAWgAFAC4oAKAF96AFoAMUALjFABQAtAC8UAAGKAFxQA5VJIA5Pag Dr/DegeWFurtcv1VD296ylK+xaR1AQemKzuUOwfrTFYcGp3CwhijMnmFFL/3sc0tQJRTELQAooGY HjOC2OkyTyRK064WNu4JNNEtHE6dBLezGHyZZjjOIxyBWrJNi10m8jbbZ6ZKH6eZPgBfeouUkdP4 c0FdLDzTOJbuQfM46D2FS2NI3qkoKAFBoAM0CFBoAR3CKWPQDNAGB4gvCkYhH325b2qhHMu3NAEl patO248IKALt5L9lt/3aZfIVV9ycUxEFzMbG133TZbnHvzx+mKpK4jlbqd7qYyynk9B6CrSERZ6U xCHGeKAG0ANPTigBOh4oGFAC9qAENACqCzgAcmgC98lvaCTOWOVXA/WoSuzTZFDkkk85q9tDMXFA AeuaQBximAlACd6AE5oAUAkgDqeKQIsOwgTyweSPmP8ASkXsiqBj3pkeYuKYBSASgAoASmAUAJQA maQF6NRsGAOlACnp0H5UAZ+aACgBRQACgB2aACgBaACgBaAFoAKAFoAKAFH5UAFAAKAHCgAxQAuO KAHBT2GaAOt8N6Bs23V2vzdUQ9vespTvoi0jqVGKzGPoAUUALgUAG30NNAKDjrTAfmgBc0AV7+yh v7ZoLhNyHnjqD60CKmjaNDpKyCNi5kPLMOcdhVXEaqjFSNEg4pDDNIYuaYC5oAjuriO1t3nmbbGg yTQgKGl67b6jO8KKySKMgN3HrVONhFy6lCDJ+6nzH+gpCOLv7k3E7OT1PFUAy0tWuHyeEHepYGsF WNAqjAFMCpePFHE0k5wi800JnK6jfPfTmR+EHCr6CtUrElPrzTEJnFACUDAn0oAbQIKBht5oACtA Bj1oAQk5AHGTikxrcsXbjKxDooFCHIrjigkXIoAXjFMBv1oAOPWkAjCmAqqWYKvU8ClcNy15cdr9 9w0xOAMcL7mla5aXLqVGO45PX3qiW7iY5oEGKQCUAGcUAHFACUwENACUAFIC0lzEFAJOfpQA7zU7 KTTEURSGLQAuaACgBaACgBaAFFAC0ALQAUALjmgBaACgAxQAoFACgZoAdigBwFAI6rw7oOCt1dLz 1VD/ADrKUr6ItKx1SgAcVAxwoAdQAtACg0ALQAtAwxjpQIAcdaYDgaAFFMQ8cUhjLq4S1t5JpDhE G40krgZ2m62l7cGBomjbGVyc5FU0BrA1Ixc0AV9UtPt+nzWwbaXHB9CDkfyoWgjE0jSb21vknuSi RxIUAQ53ZNU5X0Ak8Q3vlReSD87ctRYRg2ls1w/PCjqaANhEWJAqjAFIBkjhFLMcAckmmg2OT1XU DezYUkQqeB6+9apWJZnNg+1USNPFAxpoAOlAB9DQAlAC4oAD0oADQAhoAT7pDEZxSY1o7lm7QAJI rZVhnB7UIcu5WHSmSGKAE6UAB5oAVUZuFVj6YGaQEotWAzKREv8AtdfyouUoj0nigz5HX++eST7U rD0RWYliSe/P1qiLsSgAoAKQCUAJQAGgBuKYBQAnegBCaQDTTAngbcMHqKAIRSAKAFoAWgABoAXN AC9qAF9qAHCgAoAUUAKKADNAC0AKBQAtACgUAPx2oA6fw7oWdt1dL/uKf51lOV9i0jq1GBioKHUh C0wFFADqACgB1AAKAHUAFABj04oABkUCHKeaBjLqFbq2khY4DDr6elC0AytO0aeC7imuJwwiUqir nHPU07gbY4pDHUCFzQBWuphGrMxwqDJ+vamkByTh9Ru2kP3c02I0o0WJAqjAFIBGbFOwHMa3qf2h jBCf3Snkj+I/4VrGNibmPuz0qhDWoAaaAEFABQAuMUAJjH1pAGcUAGaACgBM4oAQjIoAmhn8v5WA ZDwVpWKVluT/AGaGb5lnEfs4oHyX+EX7DGy4W6jyP73AouHs5eQx7NIuZLpAP9lc0XYuTuMxZJyT JIPc4Bo1Y+WIjajIBttoxCvQY7UBe2xWd5JDmSQsadiW2IMDpxTEKKADPFIA4oAO1ACdKACgBpoA Q0wDNACUAJikAlMAVtrAigBBSAWgBaACgBRQAUAKKAHCgBaAFFAC0ALQAY5oAWgBwoAUCgBwWgDp fD2hlitzdLx1VCP1NZykXFHVoAowOKyKHigQ4UAKKYCigBaAFoABQAtAC0ALQAtACigBSOKAEXcP ekMcGFMQuaAFzQAjPtUn0oAw9XledhaofeRqoRFGiwoFQYAoAC1LcDn9d1X71tbt7Ow/lWsY2E2c +egqiRp7UAITQAvagA6HigAoAQ0AB6UAIOOtAAfbigBOlMBKAFx6UgAjBxTCw0g9elACMoPc/nRY AAwMZOPrQADjpQAmaADrQAdu9ABSASmAUAHNIAFAB2oASmAlIBM0wCgBKQAaYDTQAUgFoAKAFoAW gBRQAUAOBxgj9aACgBaAHCgBRQAoFACgUAOFACgUAdJ4f0XzCtzcr8vVVPespS7FpHVooUYFZlDx QA4UCHCgBRTAWgBaACgBRQAtAC0ALQAUAKKAHCgBaBiMoPWgQhyo459qAGJOhO0/K3oeKAIbmUhx gkJHy3ufSqE2ZhI3FvU5oEMJoGY2tap5CmCE/vT1P93/AOvWkY2E2c4frVEkZ60AA6e9AAee1ACE Y7UAFAC9BQAnvQAh5oAQigBKACmAnQUALSAKYCUAFACUAJxQAEGgBKADNABmkAlMANACdKQBQAhN ABTADSASgApgJSASgBKYCCkAooAUUALQAvHGPxoAKAFoAWgBwoABQA4e9ACigBwoAUUAPAoA6DQd GMpFxcLhOqr61nKRaR1aAKMAYFZFEgoAUUAOFAhaAHCgBaYC0AKKAFHFAC0wDNAC0gFoAWgAzQAu aBhmkAuaAGuqEfMAcetNCMfUrtUBjiwPXFWSyuGyAfagaMzWNTFmnlxkGZun+z71SQmzl2YsxJJJ JySe9WSITQA2gBDQAoJAoAKAEI4FABmgBucGgBc+goAQ89aAEz60AHegAHSgBtAC5oAKADNACUAJ 0OcUABNABQAlABQAgoAKACgBtACUAFABQAlAADigAoAQ0AJigAoAKAHUAFAAKAFoAUUALQAtAC0A OoAUUAOFADwM0gN3Q9HMzCe4XEY6Ke9RKRUUdXGoVQAMAVkWSA0AOBoAcDQIcDQA7NAADTAdQAoo AWgBaAFoAKAFzQAuaADNABmgB2aADNABmgDL1jUltYSM4PSriiWzFmYpHvlOONxJqkIr3GrRw2SP Gd0jj5V9PrQo6gc5LI0jl3JZmPJNaCGH2pAJQAlACsRgAUANzQAvbFACHPpQAmDmgBMUAH0oAQ8U AFAB2oAO1ACUAJQAUAFACcUAFACZoAM9qAE6GgA6UAAoAO9ACUAFMBtABSASmAdqAEoAKAEoAM0A FIBaACgAoAcKACgBaAFoAWgBRQA4UAOHWgByj0FAG5omkGciaYfux0HrWcpFJHVRqEUADAHSsy/Q kFIBwNADwaAHA0CFzQAoNADgaYCg0AKDQAuaAFzQAoOKAFzQAZoAdQAUAGaAFzQAlAFa9u1gjPrV JCbOckIuLpHl5VTu/Gq9CWZGtah9okMcZ/djr71aVhGSSfwqgE9aQCdqAAnFABmgBMUAGKAEJoAD +dABmgAyKAE4FACZoAM0AJ9KAEFABQAmaADqKAFzQAlACZoAM0wEpAAoAKACgBOlABQAlMBOlACd 6ACgANACUAJQAUAJQAUgHAUAFABQAtACigBRQAooAXFADhQA4UAOANAGto+mtPOrTRv5Y56cGs5S KSOujUIoVRgCsyyQUAOFIBwpgOFAC5pALmgBwNACg0AKDQA4GgQoNMBc0ALmgBc0AGaAFBoAXNAC 5oAAaAIbi4WGMkmmkI567uGmcsTx2FWSZGpXmxTFGeT94+ntVJAYzHNUIafpQAmQDQAmaADtQAgN AC9qADOKAE+lABz1oAQ0AJ1NACUAGcUAFACUAGaADigAoAQ0AFACUAIaYBQAlIAoAM5oAKACgBKA DPFADTTAKACkAlABQAY70AJTAQ0AApALQAUALQAtAC0AKKAFoAdQAoFADwPSgDd0fSDKVmuBhOyn vWcpFxR0yKEUBeBWZQ8UAOFADhQA6gBRQAtADgaAFzQBy+uXd39uaPdJHGvCheM+9aRaJdzb0P7Q LEfai24n5d3XFRJjRo5qRig0ALmmAoNACg0CDPpQAoJPbFAC0DDNADZJRGpJNOwjBvrszPgH5RVo kyb+7ECYX756e3vTSJMNmJYk8k1YDPWgBueaAAmgBO1ACUAFAC5AoASgAoASgBDz7UAJjBoAQ0AF ABQAhoAUYwc0AIDxzQAUAFACZ/CgA7UAJQAhoAO1ABTASgBc0AFACUAIeKAEoASgAoAKACkAmcUw EoADQACgBaQBQAtAC0ALxQAtADhQAooAeq5OBQBv6PpGds1wvHULWcpdi0jo1AUACsyvQeKAHA0A KDQA4GgBwNACg0ALmgBQaAFzQAYB6ikFhwNAC5oAXNAC5pgKDQAuaAsKDQAuaBBmkMGcKMmna4jF 1G9LsUU8Va0JMm5uFgjLN17D1qkgMKaVpXLOck1diSMnIoAbmgBKAE6UAJmgBDQAUABNACZoAXPH pQAh+tACBsdKAEzQAd6AA8UAIDQAdqAEoAAcUAFABQAlABQAgoAM0AFACUAFMAzQAmaAFoASgBMU AJQAUAJQAUgEpgFABQAUAFAC0gF70ALQAtACjrQA4UAOFAF/SQDeICARnvUspHYJ0rE0JBQA8UAK KBDhQAooAcKACgY4UCFoAcKQxRQAUAHegBaAHUAKKYC0hBQAtABQBWviREcGrQjAf7xpkmRqhPng Z421cRGe1UITtQA3tQAp6UAMPWgAoADQA00AFAAaAA9KAG0AFAB3NACr0oAG60wGmkACgANACelA CjpQAnegA70AJQACgBT0oAbQAUAJQAHrTAQdaAFpAJQAUwCgBKQAaAG0AFMAoAKAP//Z /9j/4AAQSkZJRgABAAEAtAC0AAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/AOa1NcXSsP8AlogNQUVUiJcY79abGWXV1KhQCO9ZaCsOnAWAsThuooSAiguM 8NwacogTNjHFZtAMRtxJximxELjac5HNMZGkp+0bOhAyDVMDVjKzx89e9Z7F2Mu6sgkhAOM9K0Ur ktFRleI8/mK0uTYljnHRh+NKw7k/yuOxFIaIntFPKEqadwsRGOWI5xx6inuTaw+O6/vDP0pco+Ys JIr9CKWwx3egQqqScAUMofNbSRY3LjIyKQiIgCgCKTAINACMcKT7UxFUj92B3Y1YiwyAAdiBUDFg lMEmex60SVxF/Ct+8H51i1YoqzIHUunPrWsWSMiBx6YqmMZcthMDqeKEgY2xTLs+OnAokxIew8uU j8RRuMtpyOKloZNHbSuQQhwO9SBZxSAt2l2Y8I/3Ox9KhxKUjRBBGQeDU2LILiEsC0WFkHQ1SEQ2 10Jz5FwojnFXsSU76eezl2zQKyHow71VuqFexALqwn4kjMZPfFL3kAj6ckq7rWUMPQ0+YLFRoXiY q6lT707iFApiJUTFAizEMUDLllIDN5Z6sKmQ0NjTy5JFP8LHFSNiEbgRnFBI3ySFPAIPcCkUCnb9 04AHQ0DHrMDw3BoEObGMg0xEEjc8c1SQmZ2oxtuV9pA6VTNqbJNOlBi2t1FCIqKzLqYlXcvSnJEX Dc6dOlRYY9bhTgNwamwyYHIqbAT2y/PTGWGpAMoAB96gBhoAgvU8yEjngg1UdxMzk3KeM/lWjSYl oXYVkfjYfyrNqxSJhbSH+H86AJIbYo4YkcUgLGKAEIoATFACGgDL1SK3s7+OG7zJ5aEZiOcn61vc zuVvNtesdvIB7tS5l1GKTCQcQyDH+1UpxAgkNvKNrO6duapCKl7bG2jEgdWjJxuBqhXEtJd5AD5F RJDLqrWQFSQfvDVAQyrtvI2HRlqtwLcUphYHsahopF2aITxZH4VN7FGb5bFiuMkdq1TEV5LdTyny mqRNiIO8J54/lVbiLMdwG46GpaGiXOaSHcU2aOu+QbfTHU0XDQqSW0iN8nzAfnVXRI1Z3Q4b8jSs Fy/DcxbAFbDnrnrUtDuK948gEWWdVORxnFJ2RQXDwSIhg3dPm3ev1piKjgZGfWmDGSsPLIH0pokh HMiD0qmBYboakZGTxTET2lxsOxvunp7VElcB8ytG+4L8h9DQA5wxxt6GncZCbG5ncbIXwB1xgU00 hGjaaRJHEBIyoe/NS3cpIi1K2ihjDJKGcHke1OLEx9hexwQ7fKDP60pIZK2oTSuBwq56VNgJqQgA oAtW1wYflblP5UNFJmgjBlBU5B71BaZXvbJblcg7ZB91h2ppiZFDdCWM2Goxru/hcjr9KtMkxNQs Gs5SD8yH7rVdxFeNnjcNGxUj0pWEalteJcL5V2oz2alawxlzZmEhl+ZD0IppiZAcl1VePWqsIsjh aAHW24XatgnFKQ0aM9vKJXkWNihTJOOmKgZUQH0NOwiVQ4OAtFgCS1aVgSduP7tOw7jhZgdeaVgH i2QDGKLACQop6CrsK5BqsaPZOARuXkUFw0Zh2ynzcICcilHcuorq5opHPHHhI/wq2YDracTDBGCO CKmw7iy2iytu5FKw7j0jMOArGpaA0bUdTUDJsE9OaLDFEbn+E0AKIH74FAC/ZvVvyFACi3QdRn60 xCiGNeiKPwouwFxigBpFAARSAjQP82714+lADjQAhFADSozn2oA5zVVzqUcXaOICtWSM2vvXBG3v WYD5WKqEHU9aSsBTuWAwufc1rFCMy4kfdhvudhViJLFWEnmIcKnJzQ0Bo2uoJOzBvkYngVnKNhjp uGx+NSBGV37exU5FFwJHH7tj6UIZYsLjGEboelS0UmWmgXzN464oQFC/tzEPMjHynr7GtExFBnG0 7hxV2JI44ZJW/cxuw+lPYLGraaVeuBlAo/26hyQ7F2WOX/UTMoMY+QAfe9qWg2jLnRVkAYsT1wrU WFsMgRJpNkmWBGVY9arYCvNAY3wpyPQ0011FYbDcyRN+7coaUophexJDKBuDHBNHKO49ucfWpGV5 BwB3zVokIlJmOOwpsC8trLIuFjYn6VIx66PdP1CoP9o0riJhpEUYHn3Kj/dochkon0+L5AzSkfjU hsP/ALQjQfubbHu3FJBco3GtXRYom1MHHAzVKKC4GaWRRvkY+tFkO4wgEYxRsBXUmN8HtVbklqNh vXnvUjNIdKQDhSAdQA+CdoG45XuKloq9jTidZU3IcilYq5HdWqXKbWGCOjDqKYMrKhlQ2l4Mn+Fh 3q0SZraPdCYpHCzr2IFXcmxcg8O3rDlFQf7TUXFY1LbRJo4vLmlRlPbniouUOTw7ArBjIx9aOYRY t9PshK0axBmUZO7mjmHYvpDGg+RFX6Cle4EV6wjtJmIyFQnH4UJAYNtPHNHvwF9s1omIc0sS9CT9 BQAqzZHyoT9eKLgIzyH+ELUgJtc9W/KgLB5GepNAWGyW6lCMdRikMx7GxuVu0YQuVBwTjtTRvOV4 2OiS0kIH7sj60+c5rFddDYXDyB1UMc4o5x2Laaag6uT9KnmGh4sIB1Un6mpuBKsMafdRRQMdjFAC YoATFACYxQAGgBpoAQ0ANNADCwHekAxp416sKAIHv4R0bP0pgIl00v8Aq0P40AKfOPUhaAOalvEk 1K4djwzYU+wq5IgtoQBu9Ky1GRO4RWkY81aQigdzsT1JrayQh8emzzDiI4PrU3Q0i2mhybAjSrGv U460udDsP/siyi5lnOfrilzyGS50yEANKDj1bNTq9xbDft2mBsKQT7A07Bccbm1YYER59qNhEb3V sEJWIjHtQMs6dcC6g3cgjqKm1irlohcEEAihCIJPJiK/6MHBOOFziquBrwFGUIFCkdMCoZSY8gji kMhubfzgCDtkXlW9KadhGRm3W423cJWccZHQ9q021JZYSytAQREwI6Ypcw7DZNPsHOX3g0cwrER0 7Ts/M5/GjmCxVudItSpNtcjcOzGqUxWMlg9vIFkAOD68Gq3Fsa1jLp8xCvEqP/tcios0NGslooXM QiGfSldDGPaXp4SSFRSugsVZdJv5PvXa49jimmgsQnw7KTlpkJ9zmnzIVhw8POh3CdAR6Cm5ILFg 6cnlbmmUjrwKz0CxCdAt925rsdc1fMFiX+yrYDH2qncBf7JtMc3n6ildIZS1PToIIfMgn8xgeRkd KcZXJGaVaQzqxeYpIhyFxwabQF8KQeBU2GTx2k8mNkTt9BSsBai0e8f/AJZbf944oAtR+H5SB5kq r9OaQFu20WKBs+a59QOBQMuLZwr/AAZ+poHckWJF+6ig/SgQp4FAiOJn2FpQq/T0o2AiW+tXl8tZ 42f0DUrjJs5bA6YoAVEVCzKAGbqfWgBTQBV1EZsLgf8ATNv5UwMTTbdPs6kgZqkMuG2J+6hP4U7i HCzkI4TH1NDYDhpxONzAVFwJFsEHVifpT5gHi0iH8JP1NK4DxEi/dQA/SgBaQCUDCgQhoAQ0ANoA Q0AIaAGFgOp4oGMeZF6sKAK8mo28f3pF/OgCpLrduv3SW+goArNrUj8QwM1ADfP1Gb7sYQe9ADHg u8gySkj0FNASRQRsMnJPvS5Srk6wovRRQItwKFTPQUxFLVLwW0DSfgB60JXA5B4ngkMUq4Yc1sjP Yt24nfAXcfaloXY100/ci+cwVR1FRdBYR72wsvljAkf2GaWrAqzaxcy8QqkY9+tUok3KbzXMh/ez vj0HAquVBcjvLFseZEzN6gnNSnYCju/hda00EKIsn5DzSA07Dz3G1o2OOhxWckMtyWc7IdijPvSS An0oEK+Rgg4NEkNF+pGOTg5FAyVWIOQeaBF6GQTLg/fFIoUrjgikMqahYpeRYPyyD7relUnYVjnp ri8tHMDuylf1rRJMhuxXe7nb70r4+tHKFxzXHmQBGXJXo2effPrRygRxyGJ8gAg8EetFgFuYEKb4 +UP5inbsBRdWjcheQO1VuSSxXUm3AkdcehxS5UFyUXE2OJ5P++qXIiripcXBP/HxKP8AgVHKFx00 s6gYuJT/AMCpcvkIYHlYczyj/gRp8vkAzZNuGHZwO26nZdirF37NLewwyLG7TK2xwAfmHY/0oaRJ dXw1fTqvlwMvruOBUKwy3B4Kunx5s0cY+pNO8QsaFv4Ktk/11w7+yjFHMgsaVv4c022IIhLEd2Ym k2OxdMNtbY2wovphc0tQJ8YHT8KkBaBiHj0ouBnS67psU3lPdIH6H0H40aiGz69psBw12hPovzfy phsUv7dN8xTT8BV6vIP5CpGiZb29jXGIpT/eOVxQOxnavd6hJblTtVD94RikPlKtppMkiiR38s9R VKINo6y2yYU3HJwATQQS0AFMBjqGUggEHsaAGLGijCooHsKAHUgEoAMUANNACUAJQAlMYlIQhOKV wGF1HcUXGQSXcMf3nUfjQIqS6xap/wAtAfpQMqya8g+4jGi4WKzaxcSf6uPH60BYhMmpz/3lH0xQ OwDTrqQ/vZz+eaAJE0iJfvuzfpQIsR2NvH0iX8aAJ1QL90AfSgBcUABAIwaAK7wlG3LxVAEcyvkA 8jqKQ7lpjiNVHegDC8To3lx7fug81URMhg0d7iTzJmwv60+YSiW5bq2sV8uBN8g7CpNYxctEYuo3 F3cffchT/CtVGwqlGUNTPV3iOMYrTQwuSrcDjIx9KALUTGTAQ7j6UAaNvp9y2CT5Y96iTiVYll0+ yj+a5cE/XFJS7A1YhN9p9txDEGI9Fp2kxXIJdfccRQgfU01ERFFrM0hKyNsz0IFDQzT0VCI5WZtx Zs5qWxxNHaagocBQIdQMcjFCCDigRoQuJ0HZ6RQbSKQynqWnR30W1vlkH3WHaqTsJq5yNxDJaztD Ou1x+Rra9zOw0UALjikMt6fbzyuTEgZAPm3cLj3NO9hqNyOSyje5kKTIqDqW6D/GhMbhYJItOWHb EZppP7+Ao/Ki7HHlW461ghChvstzM390Hav59aNSdGyKUItyRPA8Cf3VOT+tFmOUovQ1NF0211a+ ECmWNQhYkkEnFTdoNDp4vDGlW+0OrOe29uv5Uc7FZGlDpNjB/q7SJf8AgOalthcde3MGnWrTSAIg 44HrRcLGO/imED5IXc/XAqGVYhtNfubvUIolRURmAIz2p6BY6VmCqWJAA5yaBGRN4k02OXy2mY8/ eCkijXoILnxFpEOPMulYjoFBJp2YGNqnjFmYR6ahyeruP5CnyiIE8Ra0kXzRxuezFef0pcoFWfUN ZvVKy3HloeoXA/lTskBHBZRRr8wDN3JpXYEi2sKkkRrn6UagTxsYmBT5SKkLmzZNJdxkohyOD6UW Hcnks5QmWXj0zRYq4ltbytIoIPl+pqkS0X7U5h+hP86QENpcTTXc6NGFijOAe596YFs8UANbp360 AVYUuxfzvLIv2XAESgc++aALRpANJA6n2oAKBjSQKBEbTIvVgKQFWfVLaEfPKg/Gi4GdceKLGHgP uP8AsjNO1wKcvioFd0URI7E8UWAzpvEl5IcIFX9apRAqNd6rcn78hB9BinyoRPb6bcykm4fH1OaT shmxDo0EaDczMT+FQMspYW6YxEPxpDJ0jROgC0AOZRxg54oAjK0AMIpiEoAKACmAUgAgEYNAFZrQ K+5R1PWruBZbh19hUjIb6EOm4qGHcGmh2MW71KS8cxWvyQjq/wDhQkZtlEARsdnI7k96pxOijV5X YkIEi+tRseg0pogMGSVIz6cda1TPNq0XE0LbQBIvmTDy1/WhzMUu5PJd2GmDy4FDSe3JqNx7FG6v dRuUzGBGh7DrTtFCbMmQXCtmVWJ9W5q1boSJ5/ZlFUAu6NuuRQABFPRgaAOk8P8Ay2jZ/vf0rKZS NPdUFADQIdQAtAD42KMCKANCJxOvH3hSKDGKQylqmmRahDtbiQfdf0qouwmrnJ3Flc2ZInjIUHG4 dK2TuZ2sTPbollE6/PJMTjB4UA+lI1SSNi2tL1LURW6LEpO4s3JJ/HpSuNseNJvJ2BuJVbb0zzmp sHPpYsGyuII+LmG3UdkUKDTeootoqxxmyzLNc71PIwcFvoCKLWHfm3LEskOoQqEgE2eNjLhs/wCF O4uRFfTfDeofa2eNzap3ZTjj0FNslqx10+mw3MtvJKz5gORg43fWouIunk0mBkeKFB0abI6FT+tI aMKy0yCS2VmBYn3rQTZctrOK2kDRrtIPBptCuUtWN9cXGxTKyemeKzcS4szTYDf+/wDvDjApbA2Q 3eko6l4Rhx29atMzaKtlItu/7xPrxytU02I3beM3QzApf/dGazsyiz/Y94VLeTj2zzTAS10q5nkC mNkUHksMYpWA24tEtI+qlz7mi4xs2h2skm4bkH91elFwLtvDFBEEhGFHpQBJQAhpDIbcfuvxoESL nHPFAEUsSyOjMfuHIFO9gHF1HfFK4EMlxCn33GAc8mi4FK41uwhbc06Zxjg0AZsviq0jGIg7/hSs BQn8WytxFCB7k1VgKMuvX85IV8eyimoiKsp1KXLSmYr75quWwiNdOupTkqR/vGgBl1p5t2QSNkkZ 4oNacbmnp1jBJaozqT7VIpqzNBLaGP7kaj8KCCYL2pAKi/Nj3pDNDpge1IYxuQQCR70WAgdTjnJo sBGSwPBx9KkB63BHDCmMlDK44NMQFKAG4oAMUAFAB3oAUdaaASdcYamwHKQy4NIZy8gWFAqADNVE i5CeTjFXYQ6GJ3kCxjJPalJHTRquO5tRwwafF51xgsPWoCdRz2MnUtVuLxtsf7mE+nU1UUZyhJIz 1VU6DJ9TWisZGjasxh+Vcn0rGaAsToPKORUp2BmXPChP3QMgVomBB9kQpnkHNaXERNaMOVamB0Og IyWPzcEuaymUjSFQUKKBDxQA4CmA4CgCSNijArxRYDQjYTLkfe7ipsVcTFIZBe2v2m1kiyAWUgE1 SdgOXfRdRLRiON3KDaFRThfxra6M9TpdOtNZWAJPEhPRS7YP41LsNaF220i8OWuroZ7Kg4H+NK43 vcmbw/bSuHuZJZmHQFsAfgKSdh8xaj0yzjO4W6FvVhk/rRcVyysaJ91VX6CkK7HYpAFABTAx/Fjb NBuW9Nv/AKEKOobGJpGpQNaqhcK69Q3FaWsSy8twryBFO5mPAHemItm2uthYR446Z5pXRVjMg0q6 uJfmjKAnktWbGbcOj2kYGY959WNAFS+8MWN3MJQGiYdQnQ1Sm0FjStLOGyiEcCBQOp7n61Luxk1I AxTAKBCEZBFADI4xGgUdBQAFgvekBFJcxp1YD8aAK326CLO0k5OeKAIm1Jif3cZP1oAw9Z1rU7Pk WwWI9HPIqlERl3OpX8mnm4aVlOONvFJLUp7GB9puZ3+eWR/qauxBZhtJ5CMRt+NIZbj0mVvvsFpA WYtJiH32LUwL1naxQTJsQA9KpMRc1IYiB9CDVPYRXrIoydZ4li+hpm1Iu6T/AMeafU/zqSJ7l5Rk 0MgXo1FgHRjMo+tIZcbg0hjZHCADuatICNhkcHI9utDQhhAJ45qQI2TNIdxm0g8daVgJFnZeG5oA mSRH9j70xjitAhCuKAExQAo+8KaAkIBGDTYFYgxn2pDOXd97lvyrVIzHRxtIwVBknpTvYLGwoh0q 182XG/H459Khu5WxiT3Et5L50v3R91fSjlNaMlF6jiqyLUp2PQajOJXKlTg1rFnnVaXI7l7TowGL 5OelZzMS1cAlCM1CBlFreV9uxGPGOB71ogJIdLunUjZt571YFmPQpW+84H0piL8NmbSERg5xzUSK Q8CsxjgpoAkVaAHqhPAGaoCzHYXD8rE2PfigC1FpE7D59qfU5oAsQaQ8bZMwx7CkBc+wwn7wJ/Gk O5KlvEn3UAoFck6U9ACkAAZ4707AJM6W8ZkmZUQdSxwKLARw3VvccQTRyH0VgaAJaQCUAUNWuri1 iRrW3M7lgNo7CmgL+CAM9aGBjeLxnw7ef7o/mKa3A87tbz7FLsljWVHAyDWjJOl0L7Jc39rJbMoZ Dyp4b/69QykdsRxwcVDAqR3EhvWhKfKqj5sVTWgIt4qQENAxCRQA0uB3oEQvdxIeXFAED6nEPu5b 6CgCFtRkf7kR/GiwCb72XoNo9hQMX7DcSffkP50AOXSlH3mzQBOlhAn8OaAuSCONBhVA/CgLmX4k 2DR7kPkrgfhyKaFc5jUQqaRBEo+ViopoVxltBGmNqAfhVCLqikMXGKQCCgB8Y/ex/WqQizqi/wCj E+gq+gioKzRRk6xzcRr/ALP9aDelsXtKGLJPxpGU9y+o4pNCIZ5MHANUtBFi0HzrnP41LGWieTUj I5Sqjc2AB3NVcRGFD/NG2PcU7gIZCOJBn3oAUbXHynPsetFgGkf/AKqQCFR/+ukMYUx04pAOWV0/ +vSAnSZW68GgCTaO1MBjZXkLn2ppgN+0AfeRx+FVcB3nxEYJH40rgcioPatTM3dPtktLc3E2AcZ5 7VDK2MW7ml1C4MhB8sH5VqoxEyWK0lc48pyPpTDYsQ6Pcsc7Nq+9Jo6adblLf9hEj52/IUkiqmIu i1b6RHCOMn61VjkLa2Ma/wAINCQXJUtwO1FhXJFgA7VVgHNCNgK9Qeg70tAI7jTprgqY42yO54qZ WZSHw6Lcn7+1fqazGXYtDiA/eSMx/wBkYouBZj0u1T/lnu/3jmi4FpIkjACIqj2FIB4FMAxQAUgC mAUABGaACgBR1oAx9V17ToZLi11G3ZzGB5fcNx6fjXTTsQzmNCtp7S7t79TG0PVir9AeCD7ioml0 Gmd1DNHNGskTq6N0ZTkGsbFDZ50g27s/McDAoSAkHFACmkBl+JImm0S7jRdzMnAH1qkgZ5/B4ev5 2JaEjd7Zq7k2NzQfDFzZ38NxKzKqHOMYpSlcaOzdwBw2KzuMha5gjJJZQTRcCFtSjH3AW+goAia/ lf8A1cX507AN/wBMl/2R7ClYAGnzSf6yQ/nQBKmlIPvGi47E6WUCfwg0ASBI06KPyoAUn2p2EGSR RYBMZ6nFAB7AUgFKEDJGBTAw/FX/ACBJwO5Uf+PCmBzGpHc1nCO3NCEyeNMCqYiZRxUjFNACCgBy HEifWqQi5qIzZt9KoClEMqD7Vm9xmNqjbr0f7KimdFLSJqacmLSIe1SzB7liaQRRkntQkIhiRkUS yDc7cqlUBeteXyeuKhjJT1oAhuYDOm0MV9xTAdaQLbxCMEkAdTSAV0oQETxY5HBqriBX7OM+/emM eQCMj5h+tS0A3HpyKAEK/h7GkA0p+FIaBXdO/FKwE6Tg/eGKQyYAEZFVcBpQelAGdDoyQyqWYtjn FatkGibRbobXGYl7etJIZNHp8KABI1H4VWoFhbdFHQUWYXHCPHbFOwhpVc9R9BTWhNiVLZ36Rsfw xSuOxMljIeu1fxzScwsSLpwz80h/AYpc47EyWUK4+TcfUmpcgsTLGq8KoA9hSAdigYuKADkUAFAB igBaACgApAFMAoASgAoAKAMTXvDyatMkwlEThdrfLnd6VUXYViCx8OTWVpJHFd/OWDIdvA+tNyGa Oi6c+m2hikk3kuWJ7DNS3cC8yo2NwBx0zSARpFHekBFJeRJ1cUAV31GP+EFvoKYERvZW4jiwPekM ALyTvtHsKLCAafM/+skP50DJU0yIfeJNAE62cKfw0CJQqL0UUAG70FAwGTQAbeetAhGXFADaYCGg QqD5qBllEUgnt3pgUL2f7NDJMnCqCSO+KLXFsc++vXFzK8dvCwZASd5x07fWk1Ya12KN1qdxf6bK s6Kqh0OR9adrAZkjebqS+kaU1YTNBR8tJhbQcOKAT7iE0JBcARQAmf3i+xqkI0rsZtGHtVAZyHES /Ss+ozn7tjJdyEd2xTOmOkTbFwsEaonLAYpNXOYcqdHlyVXt/eaq2QEw3bizfeP6VLAt2v8AEakZ JQAUAKBwaQDDQAhFMZG6A00xWIwSp9D61QDweeeD6ikA7tyB9aVgDb6UgG4x7UDExjtj6UNDuOVi vQ1FrDJBOP4h+NAFoxO5JRSSfQVs2QXorWQIFWM4Hc8U0xWJ1s5T1KL+tHOFh62XPzyMR7cVPMwJ Fs4B1Td9eaLsZMkaRj5FC/QUrgKVyRzigB1IAoAKACmAtABQAUAFABQAUAFACZoArhrg3ZGB5GPT mmBYxSAM0gE3AUANaVR3FAEMl5EvVxQBA2pJ/CrMfYUARte3EnCRn8adgE2XsvfaPakA4adI/wDr JCfxoAlTTYlxu5p3AnS1hToopASBVHRaYAT7YosAmT60AJQAUhgKYh8UfmPt4FADplWNM5IIOMet AFC61e3sQfOdIcdm6/lRZgUrbxDbXlyIwT8xwrEYDUWYGpQA3vQA9OKAHvOEg25xnqaAMy+1WyWT 7HcRtIJVwoU4289a2g1ElrmM/UzDptsGs2EkknA3cMD6mpa52Pm5Ec8xmZWDuTu6iu5YZOJwPEvm IYImSWSQkZY/lRHCpBPEsnzID8rHPoelN4dPQI12hwlfHIANYVMNJbGscTCWjEZmPeuGXNF2Ola7 DKi7ZQ6KQmUoegwc1rERuSc2p+laiMqM5hX6VlK62KSKd5bxRR7lQb2NcdOpKU7G8tIklvbFQryn B9PSu9HOXk+chiMKPuj+tTJ9BodjmkIs24wjGpKJKYBQAD7v40hDT1oAQ0wExQAxlBFNMCPlOD0p 7gOU4Hy8j0pAOU5+7wfQ0WAcPTFIBCnpxQFhpXHt707AMKn6/SlYd7HZhQvAAH0piFoAKAFoAKAF oAKACgApAFACUwHUAFABQAUAJSAM0wDIFADGkRepApXArTalbQj55kX6mgCjJ4jtAcRFpT6IM0AQ Prlw/wDqrcqPV2xRYCtLf3kinMwQn+6vT86qwibRkuLwvFdlhJGAd2TtceooegzYTTYU681NwJ1t 4U6IKAH/ACjooFAC7qYAMY5oEABY8CnYBwTHWkMdsoAYwHTNICM8UwCgBKACkMliGTTAivpUXhjh VGTTjuSZ2paXDrcpmtZRNAoHmL0JxW8rWEtNDnL69toXWGCPckROD0x9K5G+VnfTwzlE0o/E0C2o aVHMvTavejmI+rSvYjTxQrE5tT7fP/8AWo5hvCs0NN1u2vCEP7mU8bG7/Q0JmU6Eoq5pqoY7G6Gr ML9DmNe09Ibnz8lWYgD0B/wp9AM3Vi5uopOSmMCujD2vqY1l7pCsm7jvXq6Hk631HLEHPy5DHsKe jKWo9o3RcYyaTlGIuVt2IZ4Z4CPOHl5GQGXqK5Xilex1LCaXIvNUdeBnFc+JcKkbo2oRnB2Y7Ned ujsYsP8Ar2/3a0gI3hzaj6VuSYCzF5kgXgA8+9YVvdjcuC1LMnzXUYxnaCcVx4Za3NqpI675gnYc mu97HOWOgqChuabEWoRiL8aRQ+gQUAKfuigBlACGgBKBiUAIRmgRGVK9PyqrgAIbg8GiwD92OGGR 69xQA4ZAz1HrSGOyKAI2AzxxQhHYHrQAtABQAmPegBRQAtABQAUAFIBOtNCK8EEkc7u0hIbtmm2M s0gDcKAGtKo6kUAV5tQt4fvyKo9zQBm3HiewhyBLuPovNIDNn8YqTiCBmPvxQBUfXNVuTiMJED3N FgG+TeT83N65z2TimA+PT7dDkpvb1Y5oAsqgUYUAD0FADj0oAZ2piN7ST/oq+oNDGX6QBQAUCCgY /A2ZzQBYs5RETlQQ3UVSYiO8kRHzGpwTwKN3YDnNW1u6tg6xRAupxgnH40cjQynY63dw3CfbQpgl G4Mv8NTYaR028MAynIPQigQZoAM0AIKAHgnHHFAGR4ht7iWzdoG4P3h3prR3AxYLma10dzG5VtoA x1Azg0m2a0UnPUxmlDqRIuW7MOtYN6ntJfykYBB4zQy+thzAgcA1Opo+WK1GjzVwyhuDkEdqtRZh KrSeh2Xh7V/7QhKTcTx9cfxD1q1c8jEUlF3Wpfu4kulKSRb1PB3cVotDmK66ZbrHs8iIJ6YzQm1s FrmFrWlx2e2SAnDnoe1ehh6nM9TixFNRWhmwSFXPOGHSu9WbPOloadvfI6lbkBlU8tjkCuKvo7Hf h0mjM1acXcpaN2Ma8IjdVGelcLSZ3RbKMqkWc2V+6QQfQ1PKNsktm3RKaxluBYg/1/8AwE04gbsH NsPpXQIw4oQLx3PUHgVw4meljanHqWQQu+UcuTsSnho2QqjuLBzuc9zXTIzJ26VNhiAYFDAuRjES 0gFoADQApx0oAZQAlACUAFAxKADFAhrJmmFhuSv3ulMLCqSvKH60APDBuPut6djSAQ8HB4NMDryc e1IAzQAA5oAWgAoAWgBKAAkCgBpkUdSKQEE19bwjLyKoHqaYGbceKNOhJH2hWPovNFgMu68bQoD5 ELv9eKLAYkvji9nm8uONIweM9TVctiUyOTUtQuus0hHtxUlEYtZpDmRz+JzSAmjso165Y07gWkjR BhVApXAkFAE8UuOD0oAtKQRxTAdQAjdKBDKoEbmjn9wR6GpGW/tUImEPmp5v93PNAGfq3iLT9KbZ czZk6+WgyaaVxDtI1+w1bK20vzj+Bhg0rWA1aBhQBNHQBkeINRayRXix5u4Bc/nTjuJktsttqY+0 zbUum6Mfuk9PwrVyT0ElY5/xDdnTyFZAXYcZHb1qOW5VzmofEl7AxCOcYwoBwFocBXOu8PeIk1CE pcsscyDkngMKhqwzbimil/1ciN/ukGgCWgAHFAC5AyOoPBFCAwpdG/fP5cyrC/JQrnn2qg80YWua YLCWMRtkPnGeKylE9TC1ebcowTGFgfQ9D0rK9j0Yq6udDo9rbX7I4IhcZZmP3QBXTCKaPJxNaabR lazIVuW8pBGucDA6+9W42ODmvqO8PzrDqMTH5WbKNjoQf/r1LRXO5I7UUiBTigDK8QIn9lzSOD+6 G8YrSnPlInHmRyUc8UozG4b27ivQo1+Z2OCtQ5VccjlXYE/I/B9quvS5tScPV5dCmLeVixjXKryT 6V5clys9RO6uN1XVv9ATT49rYbe8nc8cD8KaEN0wsYRu6dqxktRl1WEcqsTxg0ogb1id1qh9RW60 E9DLKSPdSoi4GfvHpXHVoOUrm0Z2Q3oCQcgcL/jXRGPKrGUncsINqADtQA4nJoAf6VI0W+iKKACg A70ADdaAG0AJQAlAAaAEoGKKACgBCKaAjKY5XimIbnswp2Ak35XawyPXuKmwHU3lv9pjCbsc5+tV FgySJPLjVMk7RjJpMQ/IpDGmRR1IpCIpLuKMZZwB7mgDPufEVhb/AHrhM+gOaYzKufG1qmfKR3P5 U7CMq48Z3Un+piVB6k5osBmz69qNx964ZR6LxRYDPkllmJ8yR3z6kmmhEVraSPdpGOA5wGNWtRHU ReGF8vdLPn2ApqI7nLXVp9l1ORVPEb5GadrknRoQVBHQjNYNWZoPFIBwoAcKAHCgB4oAkjcr9KAL SOGFMBzdKAGY5psSNXSidjgeopDMC8sr+zaa8kXHk5l8zPXHQf59asRw0sk15cNJIxeRzlmPerWi JNjw/BJa6payI53+YPlHfmk9hnq9ZFCZoAkB4xQBja/p7XCLLHkun8PY/wCcVS0EZf2sW9lLtB+T LYPpStdgc1dax9sl/wBMBkGcdeR9K1SJM2SIoxdfmTs1AELuyP5gbjuDRYCe11me2kDQnaR3zUuJ SZ2GleMo5LkWt8uwk4WboD9R2qeUZ1i8gHcCCOoqQAqPrTEOCgDgYpDMrxBpY1G0G3iWM7l/qKLG lKo6bujip4JLdisnXpmsZKx7dCrzomtrhxbOiEg4wcelbU3Y83FwkmyNZmZlVzuUHoa1epwLY27T TrcyWbwyZkd9zR45RR3NVJ6AlY6msShM0AZniXP9hXmP+eZoQHnVrZSyw+dG2GHNVdxZLjzaMma4 uYMiVd3HFdMcW0rHNLCRb0K0lzLKOTtB6gVnUq85rCkoEMVrLNPtCnr1xWVzU344BAioOo61lJgR XY/dDtg0Q3BnQaU+bGP/AHa6CStcMBviThnbLH0FSxkJALqvpzSYEw6VICoMmgaJAPmqRls8UANo AVfvCgAY/wA6QDTTGJQAlABQAUAFAC0AJQAjGmIbimAm3HQ0wN651uzg+/Og/GosDZlXXjKyiyEL OfYVVhXMqfxpLJkQw492NOwXM6fxHqE3/LXYP9kUWFczpbueYnzJXb6mnYCs6kg4zmmA6C2mlO1U P40xGpa6DPKgZiq0noMtS6GlugLOWqGMjFrFH0WkA6MAOpwODmqQHVQfPAD7VsScP4iiEeqyHpuA NOOiJLWmyeZaJnqvBrCe5oi2KgY4UAPFADgKLgOFIBRQA9WKnIpgWElD4B60wHgc0xGjpJxI34Uh mndwJdWstvJ9yVSpx6GhCseaS+GdQsLhka3aRc/K6DIIrXoKx1XhPQ3td11ewgSEDywTyvqTScrK wzp6zGJigBd2KAELg0CMrVdKSe1umgj2zSIQTnr+FUtAPNbi3eKbDKVKnkGquKxGs+x2AJA9PWqE RsFn3OSFC8kf4UAViwz8oxTAcHLHJOSPWhIdz0vwRfyXek+VKSWhwAT/AHe1Yvco6ICgQtIYhoAx da0Nb7dLCQsp6g9G/wADSaub0qzpnNroOqxMHS3IPThh/jSUH3OueKjNaovW/h29mVfNS3gIOcjJ b/CrWhwScb6HQ6fpsVgjbSXlf70jdTRchlmkBDfXS2ds87AkIOg6mmBkahfLqHh2/YRtGyKVZW9a a0Yjl9K+W1x6jFTJ2AsOqbfnAwPWstWD8itEtq75jUE/Q4qtUMsgbenH0qbsBKAIbld0e0dyKqG4 mbumALBsHReK6ESVZxtupe3Sk0MZEMgt/e5/CkwJBUgSIMc0DHxj94v1qRlputADaAFTrSAQ0AIa YDaBhQIKACgYUwFoEFADG607AJQA8DikwOHwxPOasmw0Rs7cCmImS3YDpQMf5OBnNAD4YFDfMCaY F6ONFGAgBpAPRcuCSM46jvQI1rDPk4z0NJgSXYDR4Y4HrUFGU/tQBGBTQHT6c261X6VqiTk/GSGK 7hlXqQVpoRV0USCJyykIT8pPc1E0UjUFZFD1FAEijFIBwFAADigBQaAFBpgB45FAFi3m5w/50xGr pvEpx6UDNqkAdKNRBg9gTTGAVvYUAOCDuaACQKis3YDNAGRputpe3Sw+UU352H1x/wDqqrCNipsB k6n4estSk8yQMkh6svenewHAa1aQwRzZUpPG+0jHB5rRMkwSx2YqgGCgB8Y+ahAekeAIsafJIQRn C/lk/wBayluWdRwKkAoAQmgBKACgLCAUBoFADWoAgubdLqF4ZRlHGCKa0Ay7/T4dO0C9jgz8y5Ys ck9KHuBy1iMQCspPUBZI/PuIom+5gs3v7U4iLkqqIiMAADirYFftWTGFADSCcAdcinHcDY0/jePQ 10ogq3q5umXuwGfpSkMUCpAUDmkBIOKQySAZlWkxoskc0hjSKAEDAZGeaBBnNIBpqgEoGFAgoAKB hTEAoACcUANpgKBQAtIaOSdVHAGKskfGncUCJCMUAMK5wKAJkXHemBOg9KYEojGMjrUSEXdPJ2sB 2agZYuwTbmpAyjQMjxQgOg0Z8wY9K2iIzPFdqJ44vUNxQ9BGBZiRbgNI21VG35j+grOUhmsoqLlE qikA4UAOoAKAFoABQMU9KBCr1pgWre6mgR/J2mTaQm7pnHFCA6HSvtjWUT6gqLO3LBDwB2qrAXxi puA6gBDTASgBGAIII4NAFCz0i1tLjz41O7nGe2aq4F+pAKAOd8T6B/aMEktuo84jkevvVRYmeYzQ PBK0cqlHU4II6VqTsR7ecUAa2kaXcXsywRR/f6kjoPX2qW7DSPUdNsk0+zjt4hwg5PqfWsupRaNA CUAGKAENACUALxSAKAGGmAh6UAZ2vA/2PdA8/JQBxtl/qBWcgLC4Vw3cDFJOwCyPu4xgVbloBBM7 AqkYzI3TPb3qYq4D/IkjTc0m/wBRjFW4iGOSqlh1HIqI6MZp6SCqspOT1J+tdMSQuhi8/wCA0pAN FQAq9aBklICW2Hz5pFInqQA0AIAMdOaAGmmA00IQlMYlAgpgLQAUAFAhrUwEoGSAcUgDpQBzDIAM Ac1dxDgNoxQIQ9KBiKuTQIlVRmmBMnHSmBZQfLUyET2HEjj6VCGWpjmMjHFMDJcgMdoIGeKQXGCg Zq6FJyy1rERNr6A2hfptIOaJAjkZ4pbwGRTtVD8i+vvWaVhmrC25FbGMiokMmU0rgPoAKYC0AKKA FAoAXtQAgpgSDijYDq9HuRc2Kg8unFO4FwCkAvSgApgFACY4oAQUAFABQAdBQBj6z4csdYO+ZCk3 /PROD+PrVJ2AyrfwNaQSBjcysPQACnzCsdDY2FtYReXbRBB3PUn6mpeoyzSAKADOKAEoASgBsreX Ez46DNJuw1qQ2NwbiNiwUFTj5WzQtQasWDTENNIBKAKGu/8AIJuv+uZqkBwNissybvOKKOgUUWEa ABGQeorJqwwqQCFf9J3f7OBWkREs7DaV7mqbArMMqR2rJbjNXTlwu7ua6o7EDb0Yul91NKQxgFQA ooGPBpAWLbuaQ0S1IwoAQjgUANpgNNMQ2gYUCCgApgLQAhNMQ2gBVHNAx/SkAUAc6FNUIQigBnSg BU4FMRMg9aAJlAzVCLMa8UgHW/yTt9KyTsyi08ilCM80+YDNMRL4bjntQ2Owv2ZlHByannEWNIYx 3ZQ8HHNbRdxE2rBr6Z4BkQxLlv8Aab/639aTYIx4hhcAcAUmMsIjeUGI4J4pSQCqcVAyQUgFzQAo qgHCkAvSgBRQA2mIkHSkM0tDu/s12FJ+V+KYHT9yKAEJoAKYBQAtIBtMAoAKAEPFACZoAQfSgB2K AKlzqEFvOsLltzegzj60AWaAENACdKAAUADhSpDY2ng5pbglYzzd6XpaFfPhiHUgNzTsBmXfjTTo ciLfMfbgU1ELmZJ42uZDi3sV9ixNPkFc0/C2vS6u1xHcIiSR4I2dCKTjYE7mjrYzpV1/1zNCGcLo 4HlfN0FDEXDyxPrWUhiVIB06UbAFO4DSODQgNTTW/d4711R2RAXw/wBIj+holsMjFZgLQAdqGMtW 33CagaJDwKQyOOZJWKowJHWgCRyOaAGdqYDaYgoASgAoAWgAoAYaoBKBEi8UhjqACgDnc0xBimAw jmgB6xseimi4EyQP3GKXOKxOkOO9TzhYmX5anmuMbuXOB1qbASKQq7m5J4UetVsUIAQSW6n9KhiB SxJyBjtTYiqk7Q6mz9QE6VcZAbtojmx3ygCSTLEemegrojGwjncbJJFP8JIrN7jLRYrLHACQEiGf qeab2EgZR3GD61mMAMUhhimA5aQDxQAtMApAJjFNASL0pAKCVII6igDrNPuRc2qP3HBpgc94hvr6 31QJBJKoAHlqq8Me9WkB1UeTGhYYYgZHoakB1ABSGJimIaxCDLEAepp3AFIYZBBHqKQAeaAG96AH AUALQBRutOFxOsnmugGNyj+LFLYC1I6INzsqj1JxTAzLvX9Ntc+ZdIT6LyaeojGu/HNpHkW8DyH1 bgU1FiuZF1411CXPkIkI7YGTVcoXMe51fUbvPnXUjewNOyQXKmC4JbcT7mmIdHaTyruSM7eue1MC WACRT5tz5aqOAeaANfwdcJb6/wCXE5aOVCoJGM9/6VE9ho7bWMf2Xddv3bfyrNFHD2GPJ4x1qJCL NQMazBeWIA96YDY5FmYiM7sdTTUbgKIrmQ4jQKM9TVqmIlj0udyPMlOM9AMVajYDStrb7OcirRIy +IMsR9z/ACpS2GRioAWgYjHigC3bcQ1LGh55BFSMhtrRLeRnTcS3qaYEzUgENMBpoASmISgYUCCg BCaYhpqgFUUgH0hiigBaAOdj+bgdafS4i2kCgZbk1LkBIEVeigVDbAWkMM4poRHPcx265kOPQChK 4iGO/Ln/AFMgX1xVcg0WkVFXzW6dvc+lNIBybid743Ht6D0qJO+gD6gA6CmBmTtm+QqcKGCt798V pT3DY66L54Bj0rpJObuICdSaIDG9wPzrOw7kfneZezyjoZCB9BwKGCLbAMKkZGOKkY4UAKKQDhQA 6mAUgGnrTQD16UgHUAamg3PlzGJj8r0wOg2gnkAkUAOFMBaAENIAoAo6vayXdoUjCsQc7WOAaLAO 0u3ktrNY5QoYEnAOQPamBboAilnghGZZUQf7RxQBmXfijSrUHNyHI7IM00gMW68exLkWtsW9C5p8 jFcxrrxhqtzkRssS+iCq5RXM2SXUL1v3ksj59TRdILME0uRvvHmpdQrkZINNRepqfaFctga2ij46 4o5mFkRsB0AFUmxNIq8+YV61aIYRQ3VwCkW4qOOuAKoRH9nbzRESoYNt68UAW7Fv7N1S1k8xW2uC dvbmplsNHpGt/wDIIvMdPKb+VZrco4HTfPdCtvFv9ycAUnG7A0U028l/1kojHog/rTUSSzDocCnd Jl29WOarlQF6O2hiGFUDFVYBJbu2gHzuo/GkBWOrIzBYkZsnAOMCmBELi5uMlWSNckccmpbsAqwY YMzs7D1NK4EgpALQMa/agC5CMRLUsaH1Ixy9CaQDT9MUwENMBpoATFMQlABQAUwGmnYQgoAeOKQC 0DFoAKAOctXCXbRN1A4qE/dHNWNAYPUUkIWi4gpAFAFAJ5147PyEOAK3ghGhDGTz0ApSmkNIcw3T EkYVRhR6VnKV9gtYdWewAKYA3TFIDOuIxEqFTn94ST6mtIbg0dXprB7dDnqBXUiTL1BPK1QzDgJG z5+g/wDr1LQGPZjCoD3NQyjU28VFwInHNADQaBjhSAcKAH9qYCUgEPWmgHLSAfQA6NzG4YdQaaA6 2znE8CSDuMH60AT0AGaACgCCe8trYHz544/95gKAMe78X6Zb5CyNMw7IKpQYr2Ma78dS7T9ms9qn ozmq5LBzGLdeKdVujj7QYwf4Y+KagTcyZrmaZj5ssjn/AGiauyC42GMydAOOp9KltIaLcNqg5c5+ lQ5spIuRJDGV2oCQep71m5NlpInEqqMKBzzwOlQ7j0GvLtbDZHt3osO5A8q4J3d+lUkJsgeUE/0q 0iSB5AByfwq0iWVy480HOKtED0uXgZjDjkY5FAEMsjzOzu2WJyaAAKVAbaQCeD60Ad1puo3GpeHr 8TYJjiIBx14P+FZ9SjK8LSLDaStMwUEgjJxTuBfm1u2Q7YyZG7BBmncRGL+6ncKsPlKe7nn8qLjI hHLcgvJPJsJ4UHHFRzAPS1hjbIjGfU8mi4D3A4z2OacREFk+GK9m5FOSAu4qQExQAUAMbqKBl9fl RR7VDGANIY7OFx60ANzQAUwEIoAbTEFACUAIaaBjaYhVFADqQxaACgBaAOY1HEN9DOn3WqIGtRGk pB5FJ7mI6kAUAFACw2oEhc8A9RV81iuUtdsDisxkgtvMiLj7woEzKuLthIIbdPMlP5CqULki/wCm w/NN5RXuB1quSwE7SApuHU9PrWfLqBVng8qxVCdxTqfXmrS1A39CffaoPTiulElPxC+xbgj7xVYx +Jz/AEoYGVEdhU9hWbGakbB1BHQ1BQyWPPIpAQdDQA4UAOFAEi0wAikA09aaAVKQD6AFApoDZ0K4 2sYWPDdPrTA3ByPekAtACkfKaYHmviBGi1e5RiT82QT6Hn+tWiTLsrh4HaOKCOWVm+UsuSK0EJqM l84QXjAKD8qjHH4UCK0Ur28geIgP06ZoAjnEpcvKDubnJHWgY+yOXKlgoPc1MkNFjeQSDis7FDxL tGDSsO4GcFsLn2A5o5QuMknIPIwfeqURcxXNwCG5Oe2B1quUVyIyse+KpIVwVXkYKuWJ4AoEPgt2 mD7APkGTQBHkA80wFuXhMg+zhlXaMg+uOf1oAkhF3eRpBBFJKqsWARScE1N7Ad9o1rcWnheSK5i8 uXY5298Y4zWba5izjtOjWfyFddwO7Ip9STUe1QDGwexHGKQEsCyJbyGSTcyjgn3oGWkAEaheQBji lYYwlQcFgD7mqsSJL9xvof5U0gK0q+SysvAPT601sBdikEkYYVAxTQAmRnGRn0oATq4FK4F3GTx0 AqShSyKeT+VIBFkDH0xQgBfmpgFABQAhoEJQAhpgNNNAIKYDwMUgCgBaAFoAKAOb1BRNp+9f4Dj6 d6zStI2equT2Evm26H2py3MC0KVmA8RHbvchF9TVqL6gVp7+OJhHbjJPBkYdPoKqyQiaN2jQcmTv nvWLLTJDdRqoJP0Heiwx3nzSx7P9Wh6gdTSYmRaRAsbTNgBy5H4VtERJqS4ZT7UCIokOxex6/SpA W5XdasP9moT1AueHJcxkeldUSSPUUF5eCLOA0pP4KAP8abQDLnS/J+65Jz3qWguV4JDEdp6Dgis2 ii8MMMjkVIyGSPuKQEVMBRQBIppgO7UgEamgBOtFhEqrmgZJtxTAdDIYpVcdjmgDqreUSxq46MM0 gJaYCimBwvjaDy9QjmA/1iYP1BqkSclcFo5SyEqeuRWgiIiQ5kIcgfxHtQIs+Sr2YuIWPmREeYrH 9R7UARrdFrlJLlmbBBP4UAReZ++Z+gYnPFA1oPeVDjZu6c1PKVcYXOc/zp2JGs7AA5I+nFFgExk9 eaYDp4hCygOHDKGyO3tQIUyQi2ZPL/e7gQ+eg9KBkImMbBlOCOR7UAME7KTtJGetIBuWPSmBJBb+ a+JJPLXHXGaAL6XSW6qiXFxJj+EMVWlYDtvDN6154dl8xizxb0OTk4xkfzrFpcxRyulKReHBGxQS PxqmI28ZHShANYhYZcoWzgYHemMrtGf+XjIUdI04H/16m4ya3jt5I8rEAOnK80riFkhWNWMSkMR2 qkIQlS3l/NM39zGcfjR0AnWIxgltkQPOCamKaepViqrC5kkUXKJCOAQOWq7gL/ZcBXMWGI/iVuRT ETQAoqgkkrwc1DAshgxOTgmpaGhCpFTYYhoAVJCn09KLgSrIrexpgOxxQAUCEoARqYDDVAKBSAWk AtMAoAUUDCgDDMBjFzB96NgHQ+oxUX6mtraEGlmC2g2zzgHPCKMmrsmrsyasy0+oKB/o8LK396RC aly5dhFQtPc/M8u4Hvmq5+4D4rcLz39TVKzWhJdgGEANYyGSGJGYMVG4d6i4yQUAC/IxZeM9aalY AuG8zBYdKpyEIvIIHBxn9aaAYRmP8KlbgN0KQRSODxgH9K6IklqBczO/9xFP4t81aCE1jUFDKkB3 Nn5gKlsaRn3EgLQyA/6xf1HWpaGT28/l4zytZ2GWEQKzEHKscigY2SPHIpARdDQA5TQA8GmAp6UI QKOaYEoO2kMQvQAZoA3NCud0ZiY8jkUAbFACrTA5rxxb77COYDmOTn6H/Iq4ks4C5H3T+FaCImuJ 2iERkIjAxtHSgRH0FACY5GRQMkihaVJGUgbF3EH0oAYCMjPSgBZ2i80+TnZgdfXHNACPdEweScbd 27pznGKAIXm3Y74GKBDfnPbFAxfKY9SaAFEKjqR/OgCWC3adwkMTSN6AUALNG8DlHAUjGQKAJZ47 dIozHK0kh5cYwF9qQFZvvGgDqvA9xiO/tifvR7wPzB/nUSWpSMu1maFUZEXIOD70AatpMzMRIWHP QjIH40hFqPe1xIpUCPG1fqOSaYyYorr82KgZWaJ4m+TkUCZOUCrvkyFxzjrWlhDGMgULHi2iPYcu 1A7mdqqxxRKEV2kc4DMeaQ0JaX3lxpAkaIAMFm6fWr2RG7HPdoj73mAx028E/hU3KtY0IZRKA2Pm xkH1qGtQIXvFW4WHaSzenanyhcsxTd1IYd6VguSja4yvX0qWhoaVI60rDExSAeshXg8igCVWDf4U xCkUAMPWqATFADsUgFxQMSgApiCgYtIDGs5VdOWyVyM+x/8Ar1knY6CmQIZ1lxwW2N/SqjqZTRod uKWxmV2tRyUJXPoa0UkIfHFKo5YNWctNgRYjIx0wRUc1xlNrie7lZLUhEU4LmtowETpHcQY3TeYP QinKAi0DkZrFqwxGoGROxV1IyMA1pHqIlx8uKnqBRt2MdzIo6sSo/Gt4MRu2cYeG5ZR96UqPoOK1 sIzpdMudm+KZFUfN93nP1rNxHzWMS4MqRxjOTG5J/GqSAv20okjBFQ0BdhfHB6VAyzjIpDIZI8ci gCLoaAJFyaAHYwKoQDg0AOJpDEoAWgCxYzmC4Vx070AdXE4dAR35pgDSojBWYBj0GaLAUtft/tOl XMYHOzI/Dn+lNCPNZrVmtHmyAF6D1rQkp2/2fewuN23acbfXtVAQbsCgAlnL7dx+6MCgCIynsT+F ACZc9BxQAoidupoAcIV7mgCza20cr7TuHoAM59qAEeLZN5R/dndtJI+7QA2eONDhZfMPqBxQIkhu DHEqJBGHH/LRhzQBChaMkiQqSMfLQA0gdQpY+poAnjt3ktzMHjRBnqeSfQUDK7DhT1pMDU8K3Hka ugPCyK0Z/Ef44qWNEMgaXTYnQnPmeWQKlblW0NrT7yGOyUlgZAOQepxUzdtQjEprdv8AagiyeXlt 7HPT/wDXWdNOb5inojXS4GRh1dDzkHkfhWzRmThkUGRzhF700rDtcrT3XmRu6HDqBgA/d5oT0G1q UhfNGzbipJ7AZaluIz570XNxmXO1Bxk45/CnsV0I5Ybi4UyEeVF2A6mi4mRwwbGDkDns3NS5vZCs dRajj6LSTYXMbVYnj1ITIr7Su75exrQLkkFw7YeP/XYyR0Eg/wAadrgacE6yxrIp4Pes2rAWkkBG G/OlYY4p3ByKVgG4qRidKBDllI68imA8MGHFUA4CkMWgAxQAhFABigBKAFoA5iwnChc4xjBFZyRr FkzqG8+Fjgn5lP8AI1OxT1RPZSeZAM/eHBqmYPRk+KQhw4pADoGB9fapa7ANsY1hiMa9Rz9a6YS5 lclkoGWZj24FU9gQKMKBXOxkcsqRj52C/U0kgEVllQsjggYGR65q0rAPRCCTuJz2Pale4Fa2QHVk zwAQ5/Dn+la0xHQaMP8AiXIccsCx/E1uIxLwvHdTAMw5zjNZyuNFGYbsk/jQmBBbP5EmP4D1psVz WiORWZZZjbAwelKwEmKQELxfNkUAPACiqAazUAMzzQIdSGOFAC0AAoA6HR7nfBtJ5Xj8KAKusafd z3qS24yCAM7sbeapMDc25t1R8EhcGgR5ReXhtWntvL8xAxAPb61oSZA8xz8qn2qrOwrq9i/aaBqF 3PHEIyhkzjdx2zWcakW7IpxaH6loMumzxRTMrmRA6lTxitWrElJUQEAA0hlqayntog8sXlhumev5 UAEsECRn/SRI/ZVU0AMtphCDmBZDngv0FAFzTNTksNUjvtkcjo27yyODQNMg1e+fUNSuLqWMI8rF ioGADTuIglgmiiWVkCo/Q0gGQGEu32guVA42d6AGEZkzGhChsjPXFArlu7ku5h/pBKjG9VC4H1oA qKOMbSfTJoHYvWui6hfEeTayFT3xtH5mlcdje0zwdcwSpPczJHsO7avJ496lyBIxrVVbTJFIPE6n ipe5a2Lf2QwzhVTZG6gsDySBjOPepklLcSLsFkjKzCbduYndgU7cvwku42SxPPEbjvxgg/Wq3DYi vWU+XbvlFBwQTgZ9zSZpCLexOYI7W3Jdl2HGcDjqKSJk9Shf3gkQ/Zodo6B2GCfoKEw3KkFmVIkk TCr3PUmk02DfQ0re385xuYk9W56D0p7BsT3dgpw8QAI6ihCLUHCOfagZVvCUkHICqo596bYGadm5 ijdTkBT91vUUoysKxNBdPFJuNuwJH7xVIPPqBVt3FYtpqUJYA7kJ7OMVEtARajuo84WRc+malO5R ZDK454NOwCMpFIY3FIQYPai4yVJMcMMe9AEvXpzQAmPSgAoATFMAxQAhoA49kltpDG6Mr54GKLpo cWXZMgRykdPlb6Vl1Nh0TGK654WQZ/HvVWuZSRfFSQLmgBymlYBjnZIr9B0NJPldgsSgYFW5CI55 BDE7n+EZqUrgVYdOE8BuLkl3YZVfSt7ICGRvsvkRIu0l9xH6f1oewGlWIERAR55f7sD4/Hj+tbUx G7pR/wBEjHT5cVuIx9aXZeE/3lrOQFDg8GkMpvEzSMsXz+wppjsWtMnZw0bjDIcGk0JGovIqSh8b Y4NICTGaAIpVI5FAERoAaKAJRQAooAWgBaALem3HkXAz908GgDp0bKjFMCRgrIynuMUxHmWoIqvP CVAMbFTx6GtFsSZQkEaDg56fjXW5wdLl6mCg1K5efxBNHKsluixSBt+c5Oef8TXmU6HJK7Otz0sU 7rUri/uFkupDIV+VRgYA+ldbepnqQTIu8sGwDznpSAVpTM+Xd3Y9zQIfBbTTJvjVVTuxOAKAI0VP P2zSYXnLLzQA+Y24KC2WQ46s3egY248ngo7O38RNADFUOvzMcDoPSgCeysrq4kHkW0kg/wBlP60m 7Ab1n4X1KRRuENuM9W+Zv0p+07E8rNaLwlBhWvbma42DGM7QBUObLSsW9Ih0ku6WVsiunUlOSPXN Rdjsa4AHFK4xJB+6f/dNCA81tG2afMwXcfOUY9TVSK6GncSMlrDNLhXjYE/Q8GjqZ9BvmSpObeBc K/zpj0PUfnTY0XEVYdu44Ccsf7xoQbmeZre9kVGDvHyfNAxgn0qXKxUZOOxINOdNqm4MkZIAGO1O 10Ju+5HeIHvoLaIAKh3MR60rAXHVXQYXKDiNfU+tAJXGCB7XlTkHk+9IbJTOvlksdhx0NBJW8yWe LFsxVSeXH9KQECwoJ83MYkA65/nVWAtz2EEkO62RVOOw60rWGZksjWzRXaDH8Mi/zrRWsC1NhNk0 ayKAUI4zVWuQ9BJLOCYZKDI9qylGw7kG2eyyRmWHuO60khl62ullQFTkGp6gThQ33fypsYm3FSMC KAEBK9KYEqSA9eKAHUAGCKYCYoAQigBZEVs5AJ7VjcsxJoxu2MMiRKb01LWxRYM0B4w8Zyfw61Se vqTJaWL0cqi28wnIAzSfxGJXhhnvj5jyGOLsBWyjYTLkdr9nGVldh3DHNKUQHzDML+wyK5pblokQ 5RT6jNUIZcR+bC6eoxQhDkbNioKhHAxjNbN6AUBH5+oMW+5EAB9aV7IC8KzAjuP+Pa5xgMdiAk46 kk/yransI2tOfKA+1brYRn+IU+aN/ciokCMocioKEdLlwAr4ABxjjr1pXsV0KJMtpdiVwQCefcVW 5Fjet5FkRWU5U1Nhk+KQyRGxwaAIlLF5EfnB447UAMdNv0pAR96YEi0AOFAC0ALQAo4IoA6TSrjz oACeV4NMDRXB60AcJ4ntxDqs5Ax5gDfWtUSc28BaGVxtARs4z600Iz3+8T3piHxAFc9KBk126SzA QrtjVQoHfgdT9aBCx3Ekdv5ICBT1OOT/AJxRYY+0hinZ/NmMcajd0z3oCxcFrarLsgV7k9tgJouF i6PDupX4ULai2jBzmRgP0FS5BY1LPwNGuDdXJb/ZjGP1NTzDsbNp4d020wY7ZWYfxP8AMf1qXIDT VVRQqgADsKQwoGNZQwIPemBTsNOjsndld3LcDd2HpSAtSg7CV6gcCgDn9Amv5bm4W5MpjCEtvGMN 7e1U9wOVtmVLTk5DTflilJGiehbmUzhRPKqgtg+tNENWLN5PFbwpLGjN5RCrjgc/5NUQStG0lqZW 4crgJ6Z4ArOcHJ6DJbW2jtowqjJxyTSasMJ5RCwk6BeT+ANWhIp2MqSGRp4z5j5csvGB0xQVI0UR AwYEjjABHQUhdBtzcJBGWdhjoAB1NAGb9mM+Z5lJjPKp0H40ATQXDKSjLgjoF6YosIsLFHcxMc4Y Hj2pLQCpuks5cHp6etW1dAReWJmkKcoSSQfcf44pJ2AZp8/kP5JJ2HkL7dx+FUmN7GsD0IOc9/Wq epA/rWb0KKVxbvC3nW/1ZPX6UnqBZgnDoGGRUoCysgYfMKGihxTuORU2GJigBCtAChivuPSmIkDB vrQMXHNACEUANDh0Dr0IyKxKMHVJjA9tIegYg/nV2uik7NDZQEn3D7koz+I/+tWcH7r7mj3IYlJi mt/T7v0rZb3OaSsakKERoo4AFasiwSDHGetQ2AScW8p9FrCW5aHwjEaD2FNEivxQBE7iJC5GQvOP Wq6AR2qEJuYYZzuPtR0AkYuo+UZ5pqwEGpFRp4yeZJuR7KB/jWsdhGnoUu6FR/dGK1QibXUza7v7 pBpSBaGCKzKJk6CpBDpoUnjKMOvf0oWg2ULOZrG4NvN9wn5T6Ve5Jsq9QUO3UAPRs8GgBWGRSsBW dMGmAq0gHZoAUUAKKYDhQBf0qfypwpPDcUAdIhzTA5TxxEwltZ1XhgUb+Y/rVxJZxki5kZR/EMce tWIqSREOQykMOxqrCJrOIF8OCRj7oGc0hmnH4evb1wbazljQ9Wk+UfrSvYLGvaeBpWwbq5VB6RjJ /Op5h2Nq08KaZbYLRGZvWQ5/SpuOxrwW8UChYY0jUdlXFK7Az9fgnntVWBXdd2XVDgkdv1pDLenR vFYwpJu3hfm3HJpsCxSAQ0AJQBHNPFboXmkWNR3Y4pgZF14o0+AHy2aY+wwPzNPlEZ0fjeASkSwf JnjYckfWjlC51KMrwh0OVYZBqeozy92YQoiuVzI3Q+9aCbLcU4iBwRL5XBK8nHYj3FIVy5Das7BZ 5BJHH2PXce5pJjaL7A+UoI5LjP509kImrMZl6w4WMA8Ann6ZFadAQ7S4zJGXYYTPHqf8mpZRpcAE ngUriM8bNSuPlz5URwT6mkBohQFwOnpQgKslqQ++P8qpiIZI3SQGMlZP50XAUSJcAwzDbIP88Uai KjRyWs/HcHHoaBlW5UP+8TiSNsnH5g0P3WOOpestSim2wv8AIx6H3rWIpRsXlJVsHilJCTJCKzGV CxS+EZHySLx9RU21GWBlOnIpiJI5SOh/Ciw7kyur+xqbDuKRjrSGJigY3GKBDlfHBoAeeelAGfpE 3nadCc/dG0/hUSVikZHiMf6Gh9JG/nWkN7ik9LjbN/tOnD/npHzWVRclXyNIO8biuwSaKZen3T/S qiTNGkrHAweKdzEO9SwEuHPkrCOsjDP0FStWUSksANoqtiRssqJy7qoHqaErgUZ7yKQ/ujvWMbm2 /oKpxYBFPfXBxb2bKOxfir9n3Atx6Rfz4M9x5Y/uoKtQQie209Zngt3BdIi7ZPfnH9KuwjZt7WO3 +6oA9KaQEOqgPayKPSlIDml6VmUSoeKlgSg8CgZDfWouYuPvjoaaYiLTZ3I8mU/OtDA0lOaQx1IB 6vkY70wAjNAEZUqfakAUDFFAhRTAcKAHISCCOMUAdPp1x50Cnv0oAi1vThqloIQ+xlbcpxVp2Ezm E8GTu4Z7pI8dgCTVcwrGhH4T061RpbppJtoydxwP0pcw7F/RjYPvW0sxbsmMhowDg9DS1A1cUhiU AFACUAGBSAQ4FAFG91ewsQftF1GhH8Ocn8qfLcRhXnje1TIs4JJj/eb5VqlALmJeeLtRnyFlWBT2 iHP5mqsK5jTX00zbnkZ2P8TnJp2C5XZy3LsTTsIaSNpAH40WA9S8NzGbQrNicny9p/DisXuWcHPb hoTIXG2NjlR1JzTuD0HWgEB3yAg4Bznjb0NNC6GrbuLiLzYWHmDhvRvrU9SrlmOVmCpIhRgwOD3F UxWLXWsxGVqQElxDDjJZuB61p0GaUSiJFQdqgCrqMjybbWA4kk6n+6KGBZtYEtYFijGFX9fegCCa 9keYwWaK7AfM5PyrQMaLe/5P2pAx7bOKAEkkuI+LmFWQDl4+34UCIpIg6rKhDqeQwoEDzBkCy8kE EGhrQLmfq0RgkjlTO1htOPSri+ZC2KwhDx71PIPbqKm9i9zY026adRDKwMqj5W/vD/GtE7ktWL8b ZGDwaUkJFa5wL229RuNZjLVACFM+xpgICVPP50WAsRy4GG5FKw7k20EZWoZSGEUDE24oAASDQBz+ iW6SJMgd0dWyCrY4okxDNdUjT1UksQ5GfWiLHLYraGWj2hhhXHf0qa1paDpOxZnjIEkPPHK/zFTG Vnc0ktLE1pOrW6lmAwMHJq2tbHPsPS7hZiFfdtGTjtUyXKBVW4u7m4321sWGMKW4ArSFJCLa6Vqt 0P3twIR6IKtQSEXLTwpESGmMkzf7Rq7JAWLazt4NU+yJEsYWPeffn/8AXUJahc1ljij961Yhst9B brksiY9aAMD+1Usp0ZwzM8WQAM9ST/Whghkmt3Uv+rjWMercmp5hlV5p5j+9mdvYHAqXIBABUjJE 60mBIDxQMeKAIbq3JxLFgSrz9aBEttOs8YdeD0I9DQBPmgYfSmBIhzSAkKgjFAELLtNIBKBi0CFF ADhTA09HuNkvlk8N0oA3eo9qYB3oYDZolmiaNxlWGDQgK+n2CWCyKkkj7yCS5yeOlU2BaxUgJQAy aWOFC0rqijuxxQIxL3xZpVplROZnH8MQz+vSqUQuYV545uHyLO1SMf3pTk/lTURXMO+1zUb3InvH 2n+FPlH6VdguZ24ZyBz6mgQhY9zQA0mmAmaBFi1sLm8bbbwSSH/ZFK47G/YeCr2fBu3S3T0+81S5 2HY7XTbCPTbGO1iZmVAeW6ms73KR5xEFlvGjbJBkOR+NVLQTNJ1hOnKso+8cD1/CjpcV7FXT47uB GIGxc43OKGPc0UnmZ0SUKdrZ3r29vxpoNjSDZGBUW1AzcedqNtJjGA1U9ilsaZAHJqRFKwjL3Et0 f4jhanqAXty0k32O34dh87f3RVFItWlrHaQiOMcdz3JoJZKaAA/pQIoXMf2TdPDtVSfnRuh+nvTG Upbu3kK+WGBPXI6UWEJ8tzGbaRs55RvQ0LQDNlRrNwR9zOCPQ9xVMdyTeUIZeO4I9fWhaAnc1LPU BMqiUbZOhPY1e4mrE8i+ZexEH7q1jNWYFugB2OKBjSKYhoBU8flQBKkmDwcGpaGidZFYYbg+tKxQ pQj3FIZGwoA5zRJdt9tzxIn6iiQIm1vmzx/01NTexfQrxMq2u5V+6u1T2z6VhZ+0sLbUsOd8ccpy DjawqkrPlZs9dSG0sIZ7yRZc7fvAZrpg1ynNNWkasWnxbvIhQKD9846D/GnGN9WRexsxQRQqFUAA dMVrZCuPe4ihGSyr9TT2EULnxHawIVEu8gcKnNJsDn49buprySaODexGFzxtFQlZjFkn1O5z5lwI V9EFU2BF9jRUd5WklcDgsaQE84T+01Q/dWJU+nyimwQMuxsZrMYgoAcKAHr1oGPWkA9aAJVpMCnO ps5/PQfu24dfT3qtxFtWDKCpyppbAOpjHA4pATIwYe9ACuBxnvSAiK7aAEoGKKBDhQA+NijhhwRT A6a0mE0IYelMDnrOa/bXAGM4/enep+4Eq3ZIR1JqBlK61axtATNdRgj+EHJ/IU0gMS88aWkeRbwv IfVztH+NPlFcwb7xjqM+RE6W6/8ATNcn8zVqIrmDc3c1y26eaSVvV2JqrIRCWP0oAaTmkAlMBVVm OACaANGz0LUbzBhtZCp/iIwPzNJuwG5Z+BZnw13crGP7qDJqeYaRtW/hvR9NUSTIHx/FMc/pUtjs bkKRrGBCqKmONgwKm47D8UhgRxQhHl0Moiu5H4Uh2znvWqXclsv2iBkWSRtxA+UdlqZBY0EAljkg bo68fWmhooIWtonV+dxBDehB6U0EmXbuUwQNKGxtGP8AChoSIrRg32V854OT+FSyloiTVJm2pbQ/ 62Y4GOw7moAskpZWf+zGtNAiHS4dsJncfvZjvY/yoAvY4pAIaYhM0AY2tTl5RbsMIBuz61cUK5QX GBjpViJbdC8qIvBzwazegx+oQGQGRgQVP7xR/OmgK1sm6Pap3YHSh6agOA2ZIGQeq0/Mq5YsLsG8 +aTnbtGazacmBuIdw4ptCHCkMDQIbimAhFAAGK9enrSGTRy46cipaGmSjbIOOD6Uijjrdvs97GRw Ekx+BqmtBIv6uSbEnv5prPyL6ELQk6SCrcR4Y+5NKlD3nJkSehaiYSxAf31z+Iqaq5Xc1pO+hFJK YGSYHbj5Wqqb15QqbXLCa4sSbLaJ5GPJY9zXVtocxDNf6nP0Kwr+tK4FSSzdmElzcSSAdRntRzWC xGVFmmyFF81z8o9BUJ3HYt2zfZ0A5ZjyeOtUItsQ4BC/X2pAQyrhMDvTQEMv73Vrs5AWM/pTYFiY rIokTJHQ1AyIUAOHXHegCQcUDHr1pAOFAEimgBWUOhVhkGkgKULG0m8l/wDVN9w+ntV7iLwqQFFA DlODxTAkkXzEVlxuU55pFEm3cKBELKVNIYlACigQ4UAauj3G1jGT9KYG2AOoFMDI8VxPJo0jRsym Nlc7TjIzg/zpxBnmlzM5YgswGfWtSLlctTAbQA6PaGBcEr3AoAkitpbmXbbxO5J4CjNK9gNqz8Ha lcYLosC+sh5/IUnIdjds/A9pHg3Uzyn0X5RU8wJG7aaPYWQHkWsan1IyfzNS2x2LmPwpahYULQNF PU7KS8iVInVSDk7hkHigZYtoRb28cQOdihc0hEtADTTQHllwvl3cikAKZNwz3GatEtGglxEkx28I 3QdRmm2UkTxzhrhWiOFTkg9/pUplNaC3qj7QkeNyuwbHt3o2M2E8Z2SWrnIdcxsf5Voncq2hUsmb 7My9Ghkzj1HOahoCWxkeSSW55JIwmewrMENvb15Y47addjMw3N2IqkUkjYjmYqNkfGP7wqRaD90x 6Io/4FQA1vP9Ix+JoAr3F59nGZHiHtk5qkgsZ9zOdRQKlpI3o4HH61WwmkUYwYmMcgKlTyPSruRo Sq2xw6N93kcdamSuUai3MUsi/MNzjayn9KlAZuoWrWM4urfhU5dPaq30EEzJKqNCf9Z6dvWs78rG RPajbhRtIrRWeo7l7Tb8xnybk4I+6xpvUGbCkEZFZNCQuKQxMUwFxQAYFADCpHI4oAcr888GkM5d 084lwQnTIbjBFIEX751m0p2XB+ZWz6HHNJqxp0K8dx/oYjYhFIwe5ahOS2MmJDK6qsigJHG3Tuam UHYuEveLd7GHgkC9GG5axg7TN5q6INKO6PaeMV2N63OO2pM9wEkMeRkdT6VHMyrFaW4MT/KxlyRu LdFpWcg2JLONZGadjucn8qtKwi1imIUZ6jigYEgsikYy6/zpxEU7dRJdXTkZDPz+dMC3GqK/lKCA wwfrUsZFt2nB7UgFAoAcKAJFpAOHWgY4UAOzQAyaJZoyrfh7U0IitpmRvIm++Oh9abAtCpAetAx6 nByKQE6EHkUwFZAw5oAruu04pANFADgaYEsEhjkVh2oA6e1lEsSkelAC3MQnt5YmGQ6laaBnkN9G yTshUgg4INbIiw600q9vGAt7aR/fHH50r2Cxv2Pga7kw13KkI/uj5j/hS5x2N+y8I6ZaYLRtO47y Hj8hUuVxpG1DDHAmyGNY19FGBSuBJigZm61DNNHGscUkq5O4I+09OKAJ3uYdOsY2vJtgVQGLHknH 60WAzo/FFnIx8uK4ZB1cLx/jSY0atpeQXkQkt5A69/UfUUgJ6AExQISgYHB4oQjiYbWO/tHIx50E zflnpWgtyvcxJOGSJV3Dq2Pu1K3KtZEBtQ1sJY2IYDkE02rMSZMLhI7USyOplUgYPce1DDqWJgl3 ZqyN9whgfahaDRkQ3XlCbeM7kGPc5P8AjTlsDLcYukgVrR4ZU9MYNTyhcqiaWa4c3NsSFG0hRnBp 2G9jQsL2GJTHGjqq9V2nIpWYrFlNUh+65IYf7JFFh2RDc6j58ot7Vhk/eY8YpbBZIsw6fFHhmHmP 6np+FFyWWcgdeKdiTH1mL95HLGuT/EQKtBYy/tK+aqfdJOMnoKYG3JYwrCGyXTHUdR7is2+VlkBe RIFlmZZYSNpbuPY1XS4ipbwOimdEAgDcqOq+9S1cC98k+A5Abs47/WpTtoIguLXja4+hrZMBLS7m sm2Pl4+2aUhpG1BOky5RgfasrhYlxQAYoAXFACUANZQRQBy6y7UZZlLOoxgfxD1qWubYFoXRJ5uk 3J4wCDxxij1NFsYsCGSYLGeW71qnYyZoTobWB4n53YwfWlq3cWxfQ5tlB6p/KuOceWVzsg7xsZfn G1nkiT7xPH0rpWsTmkrMRImc7pCY4geSerVXMiS/Dahx5hXagHyr/U0+giHSlAbHIYrkilFjNErj kUxACD7GgYEfvYv98H+v9KcRFLSnyJi3QueRQwL4UrllOOODSGMnX7smMZ6+xpARigAwdwOen60A SLSAkFAxaAFzQAooEMuIRKvow6GmgGQSsD5cvDdAfWmBbWpGPFIBykqcimBOrBhxQAroHFICq6FD zQAgoAcppgbGkXGPkJ6dKANfNAEBtLZn3m3iLddxQZp3AlChRgAAe1FwsY0l/cHWltkZVTcAUZeo 9c07AbJFIBMgcnge9ADY5Y5c+W6PjrtYHFFgHnpSA861y7l1S6ubpiTa27eXGvbP/wBetFoJmALm UZYSMD0Cg8VbQrl2w1u80+VTbSEseGB53e1KwJnqFpK01rFJIhjd1BKHsax6lktACGgDnrCC9Gt7 pBMq7mLseVK9hVaCObsLxrDUrgscxvOVIH1NXuhbGhqcMca+fEjkOesXGKhA7mWrzBHt0O/LHPYg VciVuRzwrdPZxRnbKQECnj6UkUx1vPJp108Mill+660MpbDdKty0skjEHaCig/ShCuWBO1qkpVPl XBKHjGfT8aTuNWJ9PKLD98h3O45OOam7Q2mSXcW9fM+66DKv3FPmYhv2ndbq2xDI4AAx3qriQqRW 0EW14g7HqcZJNLmQNE8Cgqy27unoDk4/A0JpiJog6nEu1vcDFU4sRNlfaps0BzWr2atHJLEuDFKy t9DyP51SfcGi7pF2y2QRkLv0CVE7DQ6OzImT7WMo5JCfwg/SoTY7E64tbkRscKen+0K0EQXUQtH3 f8uzngj+A/4UmrgSo2Btcbl7f/WqVoMbJbLIh2/MvcdxWqJuU1Elo2VJ2+o7Umky1LQ1bW+VwBJw fWs9h2LgI7dKBbDqBCUAIaBnNXdp5brMWLAcNmnsSXQqGxuVUAAqvSoe5pHYybVXtZm2JvUdsc1p 0M+ppQ3dvcYWQbW9HFRdxHYnDIJxH03jb0/Ksqr5ka0tGZl0pjukcYGeD74qqWqFUVmaMVsj4klw x9Owq04mZNNKkMZZiABVOzWgilp/zzliMHb09OaErIDQ20xEbKNwBzz6UARF2Ei56KrH/wAdNVER BpCf6MW9WNJjLvzqVVVDAnpSGSu8b2rBQdwOTmkBSzQA4UAPBpAPHSgY6gAoAcKAHGgCOSJZFwRz 2piGxytEdkvTs3+NAFtTxxSGOoAcjFTxQBYU5GRQAjoGFAFVlKnBpAAoAsWshjkUjtTA6SBxJGCK AJMUAFAENy6QRSTlNxjUtwOaaGc6viC/1FiunWyIoOC7nOK05Sbh/ZV5eNnUL53B/gTgCnYCa1s4 9K1a2EGVinRkbJz8w5FKSA3nyUYDris1uM81iuNujXVkyjzUuN5z6YI/rW3Ukw8H5m7jt6UxFzw/ btc6tbIBn5wfwzUydkB61WJYUDDFACdKBHlV+0iancpGM7Z3YZ7EMa3j8JMtzQ0rUTFiCdt6N15y QazGS3NlLDIz28iiKXkkjJFJisUr+2ukMU28MY/QdKEMgvJnubs3DEBnGWGep702NOxo2oR4VdSE lQ9ex+tCG0UJ5xIxQzNHtH8Zzk+1NMaSC0DTAgyOSecqf6UnJC5pIfG7RyslwskiDtu/oKaswunu WFukmuQ6JIUjGAoXoaloLWLyzeYpKwPn0YYzUWsAJNPuH+jYI/2qcRCteXG7b9jb6lhV3YiC8uJ4 sFpERDznGcUuZglczo5HnaUIZpixyduAPrVW7j2L9jbX0aIqNFGSDuJGTSfKKxYl069kAzfEkHP3 aW5SaM+7N62I5irMjcEcH2NNSsNxRo2l2hXyLlQp6Mjdvf6Un3Fyj2s/s/3MtB2HdPp7UmTazG+W 6MHjbBHp0NJSsBK8KToSq4P8QrRMDOMT2rkNzH2PpQ9Sky1b3DRjg7l9KzaHY0IpklGVP4GgViWg BCKAM8opUqRkHtTJK8UBgt7xCdy7QVz1AzUs0jsyvZ4N22KsjqXbi1gZS8igYGSRxUgZQY+bujZy MjYpPQVDV0youzJ9UjDqHxkHDCs6Ls7GtTVXI4LKZ1DxuAPTcRXQ7HOTm1n3BjHEXHQk9KSVgLdv biIFjy7csaYEwFAhCmaAKF4xSZlA48o/hnirQBpQaO1TbyvOQaljNEBXXjrSAiSMRpKCTkj9M0AV wKAFxQAooAkBpDHZoAUUAOFADjQACgBzIrrhhmhAVx5lqe7R/qKYi3GWkUskbsg6kCkMkC8ZHIoA cjFT7UAWFII4oAZJGGFICsylDg0AKpwaYG5pc2QFzxQM0jQIKBjHUOrIejAg00I43w6Ta6tdWjcH JA+oNbLVEnT8LySAPWgDP1KZLjyBaN5s8UquAgz35yfpUtjNo1AzyvVPNu9XujbROGlkOI1HOK1R DHW+mOyhFEglP3l8o5BqHIaR2Hhjw+NOBnlX98w4B6ipbuVY6B3CKWY4C8k0gK9hqNtflxbybinU EYpMC2aBjTQB5jqKKurX6ScIZmPHXqa1T0JcbkSP+7ZIUYKB8x29ajqVokaNg9zBFgRuY8cq5HP0 pi3HyQrcAvbTPE38SA0rjuc/LZ3UO5GiJBOMrzVCNC3LRo3nAopGOaS3L6F2WxW5iD4EoHUqPmHv 70pRZC0M5reWP5rIkp3B6jFNQug5iN9RdhiWNXwOvOQaIxsx7k+lvPEjSRsjg/eQnke9U2I0VvmK hv3JB/6aYqOUdh4vW/547v8AdcGlsFiGe9uS6iK3Kr1O7n9BVRl3JaKGq3S3BOCQI+ikYyatLQEX bGYLFbwxrh8fMfb1rPqDNCA4mDHPzcn2qOR3uO+hdZwi7mIAHc1dugjImc6hdo0R2RRZO8D73/1q GrFJjLtEu0XzgFlXjeOtTfQFuWNMvdi+RcNnB2hjRcpovvFs+Yfd9R2pNXJtYjAO7chww7CknbQB xVZ1xt5HUVsmSUJLJoiWtzx3Q9Kuw7kSTYcBsxyD1rNxGaNvdZwsnB9R3qGgLQPFICh0qiSObmG6 /wCuf9almkdjK0t/KufLlOD2J71ZHUvarKfJ2qeCRn2GazWoFOzb95JJ/DyR9AKtb2ET5D6eqty6 f/rrnty1DoWsLEmly5QrjkV02Oc0AKQDttACbaAExQBlag3+kS+0YH05qkhFrTo8WcfbIzSYyxsI 5HBpAJcSOAqpDuLDBbPAoAgcDcQvagBBQA4CgBw4pALQMUUAPWgBxoABxQBIvSkAuM8U0Bd025WB BC/3fWgC1PaKyl4e/YUAZxGDigB0bbT7UAFx8rxSBmwTt2gfqaAJHjDj3oArMpRsGgC3p83lygE8 UAdB5gEe8nAA5oAztO1u31C5aCNXVsFl3DG4eoqmrAaeKQGDcaBI2rtfQ3Ii3HJG3JBqlIReTS4T g3DyXBH/AD0bj8ulJyAuxxJGu2NVQeijApXGOIpAyutjbpcNcJCizN1cDk07hYm2jOaQC4pDI7iE TQvGTgMpGRTAzdF0ZtNlkkkm8xioRcDGBTYjVJxUjIXuFBwoLH2FMDh7i2mbXrl1gU7n3EN6e1Vu GiDVbN9oKxOkh+UYHUVcVqZyIoJZoVwwLgdj1odh6lWRspKiExuRuRj29qVkVfQonULtWRM7uxYi nbS4otsvWlvNdXSvISYV/hPQmkMsSXP9nuyANgN8u0Z98UwZdKpcIryAwSkZDj+tK76EmZqthKFG YAxBz5sY7e4qkxogt7eFWKyHy9wAWRT0PvSkh3QrwS2k2WKjI+VxjB+opdB2BpCFLsVhmHI2DGak EmOiv5mUkNiQnGW4H51nKm73RWiIvszSSmRm84k5O1eKvUhl23tJYczoPKH+2e3pirSEkxrXriVv McL7RDNUmDRKkU1+wDkpH/ttkn8KiUgRsW9ukEe1B9T61O4yKewRwdhwaQIzrNY1mmSbLIXwsnY4 4qrDdzVMrWqgeWWj9VOcUrAiOQgr51sd690B5H0o5bgLFOky5VsHpn39D6VOqAlJ3cN8r+vrWikS yC4tVlGHUZHtVrUEyk8EkRwjYPYN0P0NKxVxY72WBtsqMv8AKpcQLB61JA1x+5uj6Rj+dSzWOxko guJHDLgn+In7tOxBGNRWES28pEqkEBwOtPlsK5JayoIhAeGKBcd+aEBf8vamQufMBGP8+1ZVFrc2 pvWxDp7CKdlbjmtU7mUlY11wRkUgFoAMUCE20ASy2ts2l3ErRq0qr17itNhFO0GLaMf7IqRk2KQC kgYHrQBBLF8wboe9AEJABO05FAAKQDhQA6gBR0oGKvWgB5oAKAHpQA8UALQBZtrt4Dj7y+npQBLc oky+dF+IoAqigB8bbeO1AEwoASSIOPegCrzE49qQG9Zut1alG5VwVNUBFpuiwadMZUd3bbtXcfuj 2p3A06kBKAKdzqtna3KwTSbZGx24H1p2AvUgENACUAFAxCcUAM38cDNADdzH2pANx65P1pBYCKAM 3VNP+0pvjJSZRwynBpp2BmDtuRdD944EY6tzzWremhKI3knWUq4WUkbuOtYV5xSNlZlVvIuF23GY pD/d7A1nQbDkWyEvoUiTMToYm2gc8jA6Yrr3Rm4uD1LMMRNoY432sRjcKWxO5Vt7Z7dJNzGR0bOT 9KctVoOJNLtuFEk77IAMhO5HqaSdtA2ZFBqRjzIJMQk4VSMjAquUCOWeK+KmWJYUPG8DlqT0H0Jb jR0aPdDe5wM7XGPyqkwTMqSAIEIk+bGfm7U9SWWtLeLc/nDdIfu5GaTZXK9y200dqG25GTnYnJH+ FRYL2H/ZnugGlbCHnGcnFDYOTLEVtFCoWNAopIkGtdrboW2H07UXAkS8MB2zAgevY0hkt7eLFaM6 n524UepNCQ0Lb2KiwWCT72Mk+9JsLjIHCf6Ncc46GhuwD5bDY/nWrbH7r2aiMgK++IyESJ5M/vwG qmrhsPjuV3mGU7W7K3H5etTawFgPtGD8y/ypp2ExZY0ljOfmU/mK0TuK5B5XybW+dR0z1oaBMrrI DGHHftWVxjDJutbxuwUDjtzSLWxgQk3s7RoGCZ9eta7GT3LV1ZwRosYlVpWOMA5xUtu2oylPKon3 7GRkOFPr9aIrQTNuLUIrizUjiRCMrUTRpB2EXCXSt2YVNN6WKqI1kAAGPSrMh9AwoAKYh2pSeTpb Rrj96uTVAQQrtiQegFSA/FACigAK5+tAFZ4sP8vQ0AR4wcUgFFADhQAooGOFAC0ALQA5aAH0gFFA DhTAcjMhJQ4Pv0/GgBsU6ySMm0o69VP8x6igCaRUVVKnk9aAFjfbwelAE4xQAyWMOKAJdLlMUpib jPSgDdByM0AFAC0AYWpaA97fNMJ8RybQ6kZPHpVc1gNwkDAFTcBCQKBjC/oM0gGkk+1AxKAFpAJQ AhoAKAENAGfe2gyZFGQfvD1qovXUlowra0ME8zvJvLngn0rz8e7S5Ua01oZN1cSC/mMaKUbgsewF dOGjaBL0Y+IPBbbiiyxyHlGH6j0rrg+jFJuRYa2a2CyWMokRuREx/kap2M7WGQLLMQ7K6IuS2Rjc 3epKWhWu7sxW5t9hPJBJ6YpJXYPTUyXt59oYKRGD68ZrRuyFe5uWk0KkeeoLgY3+lSh2GX8q3OI4 A5brkjAHvTtYNinZ28c7hZJdoUZJptlNWVx0lu8fzgE2xPBAwfr7Vi3yslNmhpTxukkYwwU9SOSD 61W+omTwSIkjQJkbADj2pgWgOKhsCKa4ih/1kiqfrRYoYLq2kT/WIR7miwkmU3hk3rNCm9FPyRk/ rTKNG3vwIyZAVcdU7ipZNyS6AaNbiPll5I9RQMlhkzGHi+ZD29KhqzAdIkV0mHUMPfqKpSC5RuNN Ozav7yPsrdR9DVqQFaK8azbyrncU7Mw5H19abVxWNCN1IDxMrKfTkGpSsApz1GSDxjuK05hWMCS7 jiJUthSc4B5rnjcZbSZH0m7kRCgAUKGFW90WtjH0y1aViWbGSepwKpyWxmlqW7uBbZ/lI4iLcDFS 3cCmP37cr8ijA/GtI2SEPtIlV9rgjrtb+lDGnY1Lj5YI5D/AcVyx0kb1Fpc07ZvMhVvat2YkoHFI BcUAKBTAi1dT5EAyMEAYqhEgXgVIBigAxQAtAEUkeSSBQBVMZV9uCc9KAA8A0gFWgB9AxRQAtACi gBw4oAfSAUUALTAUUAKANwbAyO9ADzzQAUASRvt4PSgCbNADSvzBgcMDkGgDYs5xKoXocZoAn24f dn8KAFLYoGIX9KQDMk98UBYTAoAKACgYlAB2oAKQhDQMKYhKQxCMigDE1ezeJHlg4zyeKiVOM/i3 GnZGA9mghIEsaueuTmtYqySJbJ5CJIjHEpc44OMAVaWpDKzWLyhZUl2P6AcA1Wg0W9PuZcyW90Vk VTjd3o0HYzZbc3N3LPCyiGJv4ufx+lDdtina2o6CzM6uTIHBJwqkD8cVk6mtgVie1WKOINcQuHXq xUkfWqSZLepVa5S4lKhwgfqx4wvpWj00GtNWMna2lA2yxxrEML/tH/CpQm7kv9tW7QBGjZ2PBVRx Q43EmZ8M7RymeMlADynqKdrBa5saXKtzPLOOOANvpUyGyS5umlmNra8P/E/92p21BaET2VtbIXnJ kPv3oHcSHT1mbzJE8tP4Yx/WkVzFn7EYx+4laP2JyKExXK7yOJFS6Xyz/DIvShho9ixFO0J2z4Kt 0kHQ/WhEi2Uv2W4eAn5D8yGmBoFQ+GTg+oqGgBZmXiRSAP4qNhiywxXK7XjEgPtTUh2IbLQ0t5S6 O6qf4M8UNhY1I7dIxwoqbjOCiWJCTEu8+vU1WvUg0pNw0K4bH3mAwPxo0voabIy4HV0UNlT26/0o cbszT1FuDtzH85ZlwCx4xmhaAXYYQtsqkck9aFK7CwWlv9ptZvXll/CrbEWSPMt3Uj70YP8ASuba R0vWI/RZjzC3OBxW5zmoaAHYoATtTAj1bd51qn8Py96bAlqQDFMQUAFABigCGRTnuPQjtQBVwQSD 1FIBRQA4UAKKBik4FABG25AcYz2oAk7UAOFIBwoAWmAooAcKAFFAC0ALQBJG+OD0oAloAt2TqrYz huxoAv5buePYUhhwKBhmgApABpgJQAlABQAUAFIQlMBKACkMM80ANdQ6kEZBoEYN5YJayZSMbGPB x0q7iIOc4xxSbCxCq7JmTs3zD+tUIrXzJArvtIZlI3D196qOo0Q6KfIBVuQ4B9etPZjlsXbm3hi/ eAKgHBHTFRKLuSjNul/dhoN8cROCcn5voKtB1KU2lOZFQfM2NzAHGBQpXGy0dD+zMUu7WWFgoKhm 65qiCpcBYsCJEUqeoHzUJFWsSR2ojYNcq+4j5cdM1E2NEa+faSi5iIA6Mv8AjUp3C7LcOoxW1plE Hmtklj0Jo3dh3Lunst1EtyxLue7DGPoKT0FculgoySAPekBE13CucuvHvRYCCW5SdCgjZx7LQBDb TNEfIulKo33SaC+hM9uyuvlncAcgdxRexFjSt7aY4IG360rjsXUtAf8AWMTUjSLCRqg4GKBi9KYF W4v4LfIZ8t6LyaLBc5CKMBiVABHFZ87SJaLl4RHpI28K8xP1wP8A69aLoy3sUNOaKIkzplDwGxkC tGZhceVLqCmIAIqHp0NYJycXcCVCkmBG3SMk46A1ajbUDQ0pRHbgd+mTRzXHYrjAmUdeCuPxNZy3 N1sJpSeXeSZPJOPpWy2MHubeKBBQAEcU0A7VogLmz4w2OfwFNgJipABQAYoAXFAhDTAQjjGKAIWT vgFhQBVHWgB4pALQMdQACgBwoActIB4oAKAHCgBaYDhQAtAAKAHCgCRGxwelADo8k/LkHPFAGpZX PmrscYcdjRYZYIxSGJQAUAFABQIKACgAoASgBKACgBMUAGBQAUDI5olljKsMg0CMG6ga2kKN07Gg CpMcKJB1Q5/DvVJiG3sQnt2X1HFNPULGPpsszTbFKq20DPpir8x30NaO1DHzJyZXH97pj6UcxI27 dTcRR7AEjO4nPtxRfQLDrTaNsso2iRgWOM4Gf6CkhWGeIdUFzfym3cOM7VbsFFaJlJGfZ2uG3SDc zetASZZ2kAxqrjLd+Vxj0qWrkFW506eaKZ4WOEHzgDj2qJPlZdzK8pnkwnykAEhuhpcwrGlp80sb FWXyQvJ5yuKmw0i3DtvZSXmIX+FR3p3DYvR2kEXRFye55NICwkTOcKtAWLA0sSgedggc4pXKSLSW 8Nso4VR0zUjJxjHGKAEd1RdzMFHqTinYLGXea/bW+RGfNb/Z6U+UDJk1DUNSbbHmKM+nFPYQ77FN bRl5pQwPUCjckV4htD44bg47HtWMLPRlMg1Un+zrRATxvf8AUCtLW0Kb0IrZsW+FR8EYJC1nNSex KsVvKCzO6oQqJjGOpNUua1hBBvlkWOIFR0Oa0SsI31jWOIKPlCilJdguZbuN6sAD8/X8aztrY3js OjPl6gfc1cXdGc1Zm11HFUQEan+I5NADbmTyYJJB/CM00BWXUm1G6jZ0CeWuOD1okBd7VIBimAoo AWgQhGKYCMPzFACOu5e4NAFdowH3nIHegCLjqOlIBRQMdQAUAOFADloAdSAWgBwoAWmAooAUUALQ AooAeKAJI22sD6UASNM3nh1OABgUAaltMJk96QyTpQMSgAoAWgQlABQAUAFACHigBAykZUgj2oAK ACgAoGJQIgurdbiIqw+hoAwJoWhdo3Ht9aFoKxBG22Nlb/ln/KqsBiW6bGEqjYxck/Q9KuLBo245 lDhCQCeR70WEipdAyRZX+Obbn0HT+VCHIi1DUhEfJtxluhI7U0rAislvJAvmtGWJOcHtVNobLu/y 495UKxHAJouQ0yP7Ym4jcW+gphYhK32WeEskb/eBb7w+lRKzCG5Baae1xAzZCkcqTxmspOzSLe4W drNexvtYfKcbG5zTkkmDNbT9AlAVm/c+qhsg1mCRtw6bEm0t8zL0J7UFFxI1QcAUAL0pgQTTwodj kFj0XqaaQmYmpeIHgnNvbwHeB1NUo9RXKHl31/8ANcyFQex/wpPQLlmDToYsHbub1NK4FkKFHAoA rahK3lFM9BTQmNicPAVJ7fyrNKzKWpW1l/L8iLHKwgfnzWnUciK1dljUFyo9BSkIs26rcuoRiw3Z Y/TpUpCNF/KjG9tqgDqatCKUjyX3yQZSL+Jz3+lAFOeNYCUXOFas38RtH4US3GEvkIOQcc0UnoKp ubSHKg1oZDs7RQBS1adFs3TPzvwF700IraVGFnnQ9V4okhmsg4qUA7FMAxQAYoAR1Y7drbcHnjrQ IUigBCKYEcqBtvUDPamBB5Xz/KflalYCPocUhjhQA6gAFADhQA4GgB1IBaAFpgKKAHCgBRQAUAPW gB4oAUGgCaGQxMGFIDWikWZAR1oGGMGgYtABQIKACgBKACgDN16UpYlFYqXYLxSbsVFXKuhrtu5w hbywoG0nODUp3HJG12qyAoAKACgBKAKl/arNHno46GgDmL8H7QkK5DP8r/SqGht7CFUMq8KNpHt2 ouK5GoSZArjJXoehqw2KeoGZIxDESQG3biefX/GnEGyXTLLEazAqWYZBPOKUn0BPQveSWzvdm/DA pXC4xbSHdnywfc0cxJKIkAxtA/Ci4iZbaSZSqKeRjPap5ikrFqz0YRQLHK24AYIFS3fUZoQWsMC4 jRVA9BU3uMlxTAazqgyxCj1NFgKFxq8CNsjzI3t0qlEVzPub+8k5TaozwoqlEVyOFkM8DEFXJ+cV VhXK97tTX024+ZMH60ug+hdHQVAD6QxrsEUk9qAMq5fcGJ7mmIIoCI4N2MsxHB9cVL3KRFrGZtSc J90HaPw4obsN6laYNHGFB+dsjA7D1ppX1J2NSxUWdoDgl26KOtFxEi2r3DB7g59EHQUn5AXURUGA MCmkBkajw0v1z/Kp+0ar4CPUG2SRPjjaDUUuo6u6NizmE0CsFZR/tDFbsxuT0gMPUY1k1CJYmJkY hMnnBqkhDLbzP7VGXJfcQzetDQ7nRYxUgLQAYoAMUAL0oAWgBCtMCG5jeSB0jba5GAfSgQyC2EcK x84A6k0wImj2sVP4GkAgGDyPrSAU4zx0oGFACigBwNADhSAUUAKKAHCmAtAC0AANAEgoAWgBaAHq e1AFi3nML5HT0oGaikSLuWkAUDCgAoEFABQAh4FMCre2K3yorMUKHIIqZDQlhYLZK/zl3c5LEYqU rDuWjVkhQA3FAC0AJQAYoAztQ05JsSRqA6nPHegRkSpkFSPYimIy3DW02w9P4D/SrTK3EuyphSbk bSQfX0qkIsaXlLRI34ZcgioloIvKpY4UEn2qbhYni0+Rzk/Jn86LjsXYrGGIZbk+rUrthYsqoXgC kMUUDILi9gtx+8kGf7o5NCiF7GbPq7tkQIFH95uT+VO1hXKrO0vMzlyfXtQmSVsrHIzkcLWiQjTt WjmhY/KT/CBTAx7l2Sc9VKmmBWuHK39vMcnkg4GaljRoGUtjyzx6c0hhvk5yxHsBmhARSSPs2se9 JiK0oJXAHekBfgCiaIEcJlvyFS9zWJkyyZnVzx1cmhq6JGxy77jG0PK3O3+QoSajYk2reJkGZCC5 6+1OwFkH2osAhz2pagZV+CZJc46UvtXNY/DYhvzmC3Yf3RUUt2i562ZpaZP5tuMnJXg1u1YxaLPm DJ/KkSZxtwusRySkiNnB44/WrixDrBCLwsuCDyfapbGbFIAFADQH8w5K7MceuaAH9qAFFAC0AGKA AigQ3HNAEboSc8ZHSmBWIyTkYIpWAQUDCgBaAFoAQP8APtwQcZHvSAkFADqAFFADhQAUwAUwJFpA LQA4UAKKAHqaALdpcGJsHpQBpcMu4UhjaBhQIKACgApgIOKQBTAKQCUAFACUAFACUAGKQGfqFl5g MkY+YdR61SAxZ7dJYysg/wARTuIgTS7i5iEXIQcb270+awWNW00iOH7xLE9fSobuM0FjjgTOAqjv SGSDBGV5FMCKcRGNhNjZ3yaBFF9UghURwKZMcD0/OgChPfXE+Qz7F/upx+tPQm5WwBSuAAUALQBX nBA68GrTEIuIkDAkODwQasCFmJySck8k0AEkmx7d89GxSZSNkDgcVncLAx2KSegp3AzJG3MTSuIZ QA6OZ1tLud8j+BQe2aGjSJnblYSSMeAKTJMlbh0ufORjuDZrdR0IudbZ3ourdZE+90I9KxkrFFoT YHNSAplXGaAM+/5mPPVM1L3NY7Fe7GbKBvappu0mOeyLGl4SR19RkV0MxuX1kw+GQj3qAIdScNAp HPzf0NNMGWLAKltGMAErzQwLK9MUAPBoAaiiKLBJIHc8mgBwOVBHQ0ABIzigBaAAGgB1AhKAEPTp TArSAEqSNrdxQBE2CSVpDEoAWgAoAABuzjn1oAeDQA4UAOpAKKBhTEApgPWkA+gBQaAFFADhQBID xQBds7nYdrHikMvEdxQA2gAoAKYBQAlABQAUgENABQAhoAKADFACUAGM0AU5rVFk8wL160ASIAAM dKAHcUgEPsMimgG4PpikBjatauJPNJZ0Pqfu1QmUKRI00AFAC0AFAyOcqqjd0NUhFR27ZzWoDCaQ DJF3pjOMdKQzXs5G2hXbJ6g1DQxLyXJ2DoKQMqxo8rBUUsfanYRNNYywx73GPaiwFXVW22SRjgt+ 8b+lStTV6GdLFjTiy9WOKozZjlWU4IINb9CLGpp0N5BJGyQy7SeeOCKlpMaOlEXHXHtWDRQ0xsPe kBTucmbGMYWk+hrT6kMpzp6exqFpUY5fCXdOVMb8c4xmtupjbQvFQfp6UAZ+pvxEmMdTj9KcRGhC gESD0XFIZKDgDAoAeDQA4GgBeKADFACgcUAGKAF5oAbJIkMbO5AVepoAUEMgYdDQAjxK457UxFea LYQy9O9ICJ12tjpQMSkAUwCgBwoAcDQA4UALSAUmmAgpgSLSAdQACgB1ADhQA5TigCVaAL9pcfwO aBlojFKwDaACgApgJQAUAFIAoASgAoAKAEoAKAEoACM0DK8imI5UZU9R6UAQTu6DcPmX0FCEy1bS pNEMUwIriaK3z5jhRU7AUJtUtjlNpfI6UXsMyJMbyQMA9BRzXJG0yRKBhQAoFICC8IO1elaREUt2 TVgKaQAnzBhQCLcDORGQPu0NjJPs8txvOdh7E+tJIDd0qNYrdUIUvjlgOpqrAS3MQdSCOtIZxmpy +ddYXOwnaB7Cso6IuZJJDmyiIIwnJFFyBIrKKW4WVgGwgx9auDYmjZgb92B6HFaCFKlZST0as5Ia FYD0qRlG+wJcD+5WUt0a0+pRUE6XgnOCaT+Mr7Bb01XeLAOBWrMehebIiYdBjHWgRkX4bz41Of8A JqogbaNkbcEAd6QEZlKXCphm3/kKALQoAcDSAdmmA6gAoAWgAzQAFQwwwBHpQAoGBjtQAdDTAhuJ RGuNjsT0CjNAivIjKRuHB/SkMYRg0AFABQACgBwoAcDQA4GgAPSgAFMCQUgFoAd2oAUUAOHBoAcD zQA9TigC4kKyQl9+0rzQAwtc3UsEcUwijHzSEdT6AUwNIjFSMSgAoAKACmAmKQBQAUAFACYoAKAC gAoGJQAhGaAK0ieX2+Q/pQBUbdaSb1/1Z6j0pollS+PmPuzkHpUTAosoBzgZrNMoYrM4IdNmPfrT FYYeGIzyK1WxIZoAQUAOHWkBRvnxIeegrSKEZ8EjMx9K0As7uKkBYOWIoA2I2YW6/Z4cgDlqEMmd ZPsx8nAk7Zq0IsWkjRld/B7/AFosBpuA8YYVJRwUSiS4LZ+VB1rGWiHe5qQRo9qFIGCOaFsJmdp8 qJeSQq5Kg4ANaLQVzYtzhip6GqETzJkAjqvNJoaEByB6VmMz7/8A1pPon+NZy6GsOpUhObGQe9KW kxp+4aWkgfZhxWpiWnAVTk4A5zQ0Bg3d7BNdLIHOxCAWxx1q1F2EbULpMolifcCOCKzaGTLwORg0 APVsigBc4NAD1NMBQaAH0AGKACgBaAFoABQAcUANkQMuMUCKUq4YLjaQKAGUDFoASgBc0AOBoAUU ALmgAHWgCQUAOFAC0AKKAFFADgaAH9KAJUf5SD0NAD41YbnQEkdKANK3mEyDsR2pDHkYoASgAoAK YBSASgBaBiUAFABQAYoASgAoAQ0ANIBGDQBVlj2ZUjKH9KAsZ08Xknaf9Weh9Kb1QjNvbiO1Hz8s eijqay5dRXKLPdT9cQJ7ctVqIXHRQLDkjJJ6knJNMRJQAvSgBwOBSAz7+MqpbPBrWIFWGLYmSOtU IcDzikBLbDEwHrQM6XTMeSEI6daaAmngMZ3pyp6imBD1piLlpLlfLY0hnJ6bZr5BY5yaxk7jIry/ NhDtXDMSRj0pwVxMwYp2SYSc7s5raxJ0Nzqyw26SRjczDgelKwyjb6vcT3SLLLtjJ5oegJnULjaN vTtWDKMy/kw8v0xUfaNY/CV7fP2OT6Up/Eio/CaGjHNr+NamA7VbgW9jM7HnaQPcmqSEcUEk8oyY by92M9s1r0Edj4fIfS49vUEg1lJFI0tuRzUAJGNpINAyTFACcikAo9qAJFamAozTEKeKQAKAB1DK VPQ+lMAVdoAyeOOTQBJjigBCOOOtAEFwgbA/i7UwKxQ7QeM+lIBlABQAUALQAx5CjoMZVjjPpTAl FIBy0APFADhQACgBwoAWgBwoAeKAHIecUAW7abym5HBoARJmSYv0yelAzSRhKm4UAJQMKBBQAlAC 0AFAwpAJQAUAFABQAUAJigAxQMYyhgQelAGNqVtMsyHexgJwQO1MlmPOsQlzL8siZXPUUMkri4je Ty49zYHJ7UgH5oAM0AGaQATximgK+oncqItaoRFj5AKYFyxsoHizMCWY8EHpSuFh0lg9vIrr86Aj kdRT6AatsNjCmgLyyD7p6GhjKs8JhYsv3D+lCBjFbuKAKCRhIwo7VikMyNZsTdOvlY8wetOOjE9T JfSb2PrA34c1siSSx0ya6dkb5No5zUt2Gkab/wBl2cS27xlpxjcR2patDsbkZUxrs+7jis2UY98S RK3qcf5/Ks1rK5rtGwKNluwx1QUpfEgj8Jc0f/j2P1rUyMjxGl3JKBgtAORgdK0iZmPH5qqUwdp6 jFWwN3wy1ykhj2HyTySRUSKR0bsQPlGeazKDgEc8mkAqtkkelADzjFIAHFACchxgDHrQBIDTCw4G gLCGgLCigB1ADgcUxB70ANbkjGPxoAguIv4l696AKpGRn86AEoASgBc0AFMBwNIBymgB4NAxwNAC 5oAUGgBc0AOBoAUGgCXy3BAxk9RigRLtP0NIYoGaALFtMYmx2NMC91AIoGJmgBrAnpxQIUcCgAoA M0DFzSAKAEoAWgYlABQAUAGKAExQA10DKQaAOS8RadLbZlhBZGP5GhEtGdbQ+RHjqx5Y+9NkkuaQ CZoAM4oAQHLAU0gK1x80/wBK2QhCcLgUgL1ldkwmBIeVOQe/+c1NmVdWNNHwoLHnvWiRJIQV2uo5 J5HakMsK2/7wwfakBL1GxulMCnNGYWz/AAfypgUDWKGQgDe/4VjPdDRaX/VirWwMq2Y5mPfdWkti UYOqAf2lccen8qqOwdTf07/jwi+lZsozLv7o/wB6ojuay2LE3ER/65j+VTL4kOPwljRv+PX8a1Zi 9i41NEjBGmfur+VUBOgAOBxSGMyd0vPSpGSQcx80gY//ABoARulIY8dKACgBe9ADhTADQAq0CHrQ AfxUwHCgQnegBDQBTAG56AITQMSgQUAAoAXvSActMCQUhiigB1MAFADqADtQA5PvCgDat1AjBAGa QEFzxO1DAg70AOoA0bT/AFVMY40AFAB2oASgBaAEpAOoGFACUAJQACkAUAFAAaAGmgCG8ANu+QDx TA42T7xpszGVIxpoEIaYDo/vj6VSEVz/AK1vrWvQQ1utAyxp3/HytAGqnLc80xl1OlICdelIY+Tt 9KYiObmA59KYH//Z /9j/4AAQSkZJRgABAAEAtAC0AAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/ANA9a4zcY2c0AVMZlJ96ENjbtd0TAelUSJps+63EfG9OMGkBe7UAZNqZE1aZ ZzyV+Q46irewloZfjSLKW8noSKKbJkhnhRWEU3pn9ac9y4mvqfMSMO/BqAK+mpvuFHvVICfxN96M DutNgiG2BaxTPJwKy2ZZP5MMzxxyRqRjHNLZgxW0iMcwSvGfancRGYdRt/8AVyLKPQ9aAAatcQHF xbsPcCgRag1u3kwC20+4xRYC9FdRSfdZaBE6sD0IoAdmgBRTAWiwBnBHvRYY8UCF6UAApALTAWgB RQAtABnFACigBGjWT7yhvqKEBC9hEemV+lVzBYgl058Hy2Un0PFVzCsVxBdRuP8ARifcEEUNjNYi X7HI23MqqSFHeoAS3kaSFGdSrEZIPakMivhZ7FF6ItrHA3gU02Ioz+GNKulz5OzPdDT52gsUo/BN nDLvVi4HRXqnUbEkkXzp8sS4WP5R/drKxpco3TTRkqsbD/aZeKLCcrFPYSxZiSx7mk1Yh6i4xUgJ igYmKYCGkAxqAGnpTAzNXzuhAHrWsESxttazvjbE5/CrYy7HpF02CUC/U0gLC6LLxvkUUrgPGjKO swoAa+lxp0lyfak2NEyIkCBVFZtjBiFGWqbAVJZN2fSnYVzMvZ85jX8TW0I3JEsbbP7wjAHSipK2 iGkTNDAX3HblTnPSo96wi/Dcyx4KnI9DS1GWxexyDbMmPei4zM1xYhbK0bZy3QVcI6ibMbypzHuV W8v1ArZkDVBFAxpn2HHU96QiWKbfjA69qRRKWI7UWATzDjjvTSFcifjimImjXavuaQx6g0ho79ut YFjW7UCKpG2Q0FDmUEEVZBnTwvBL5seeeoFFgJI798c4NSMqX8ss00U0PyvH+RqlorCsR6or6nap E6eWwYHcDmhaDLmnWiWdsFQYFEtQH3q5sCcdKQEOjLtuC5+7Gm4mrSEJrStIbcnktHx+JokCIY5E gjdJByh28Vm1qVdlnS41nZpW3Eqfl9KHoBphcUgA0AIQDwRmgCtNp9tMPmiXPqBigdym+ihSTbzv Gewp3EQbdXtT8rCZR+dG4rFiHWriPi5t2XFJ6DsXIdetWO1nCn0bimtUJ6GhFeQyjKup/GgROGU4 wRxQMeKAFoAUUCFpgLQAooAWgdxaAAUADMqKWYhQO5OKBXG29zBcMywyo5XqFYHFDGTYoQBigBaA G45oAwvE8K3TWkD5AZicj2FF7IEiGK3MCbIJpohj+FzWd2y9DT0QkCSIytJtIzuOcVSuS7GrVEiY DZyM/WgZA9naz5zEme+BigCtLokDfcZk/WlYClNoUy/6t1b9KLAUptNuos7oWx7DNKwFR42U8gj6 0rAMIxRYBpoAhe9t7KQNOm84+UYzVxuSyOXxO+wmC2wucZJq7MVyt/bl7O2N6oPaiw7g11ct96d/ wNFhoktLea6fmWTYOS26k3YLGwkYjQIvasWx2GNiPJNIZVlkLnJPFAFC6ucZVDz6+lbQj3IZVt4D cSf7I6mrk1FaCSNNhsj2rxxWF7u5T0KNmZ4btWlhLR5+tb8ysRqdGj28i8xY/CouigNvayAgHBPH WlYdzm9WsUsZFRJmkDc4PatoO6JaNLSPPitgrW++I8gg5/SokO5PPpltdDIXyn9hikpWHYxL3Qri 3JKjzE9Vq+YVjR0LTxJaFZU4J6kVLkCRqNpFmYwoQgj+IHms+ctIrf8ACOqzYic/iKpVLCcTM1TR LiykDECVcZJQdPrWilcXLYoBjnB6Z4xTEalrBG0LkyBZAPlQDJapbA7BqxLGnpQIimXgMKBjAaYh SoYVQitJaRsemD7UhkRsMdHagZJHaKhyevvQIklYBdoFAD5Ys2jIfSmgKOTa6SxIw9w2F+lWIkmi MmoQRn7sUYJqJDRnXQzLKOmZTWEpe8bwimjY04AWcYAAwMcVoZS3LPQUhCGmAmKACkAuKAFVcmga HtErxsCAR70CMbUtLhkZWSMZ7gVnVqOCHFXMu5sjbqWh82Jl9DxWNOvctxH21zq6p5kWZYwM8iu6 OqMnoWV8US2oX7XAy544o5BGjaeKbCbAMuw+jDFJxsJM1Yb2CYZSRSPY0bDLCup6GkMeKBCj8qoB FzjnrSAeKAKl5qEVpNHCyu0kmSAozwOppqNxFPV4pNTtlt1dIFLAsXYVcEJmHoJtbSSSb7ZidZCm xFJ3DOB7YrSUVYEzulf5QcYJFc/UY2goGwBk0AAoAw/EEixXVmznAG6lbQEzOknkm4GY09B1NSlZ A5ElrezafG32eJHz1UnFO5Is3iXUCVWGxVD3LHIpjNTS9bW4XbeKtvKPU/K30o2GayFWyykEH0p3 AcrBs4IOPekAuKYC0ARyQRSj95GrfUUAVJtGs5OiFD/smgCjN4cB/wBVNj2YUAYOreFr95FeNBIq j+FquLJaMO50i4twRJBIp75BrXcVir5TR8YNKwE1u7BiuCdwxxyRUNFRNuC7Fugj8kOnG14v6ism rmu5aEybNy59wRg1NrEdSpNL1ZzgClYTMu5vC2VT5V9fWtoU+pDZDb273Deidz61UppKwWNaKJYl CqMAVzttlpDxCznpxQIsJBGmDnJqtAJC+BgDFOwXK8j5OSORTsBgXsvnXTN0UHArWOiJZaXXvsca xxnzCB07CpUbsG7Fyz137YwQ27Fj/d5puNgTubUUbY+Y4HpWTZoiYJjgDFQUWYbUkbn+VaAuSl1j XbGMe9UIp3cbT28sa/edSBVLQRjweGyGBmcADsvJqnMVjVhsoLcfu0APqetS3cLF49KkYgHFMQwe 9MZDLGV5XkUgIw+KEKwu8UwF80UAMeUdqQxYYizbm49KYFkgbSKokzbjbd6nDAv+pgAH496YItQq HkmmXo7fL9B0rOTKMK9bEo95WrB6zOiOiNjSyTaDPZj/ADrSOxjLct0yRBg0wFxSAUJQMcQqDJIF AiF7pE+7yaAIjeOeFA+mKBiNKWU7wBTSuJld0DhEzlSRkVTgiUy7Eix25RBgAUkkhtmfdxRyookR WGf4h7VWxJzc1hBKskqjaCcJirUiSGG0nLobOVh1I5xwO9NAy4mo6xYnD7nUf3hmk4hcvw+MHiIW 4h/FTU8vYq5r2niuxnwGlCH0YYpWaC5rwahbzDKSKR7GldjLKyK3QilcCrf6bDfPG7sytH0ZapSA ZPo1vNavCS43D727mmpCMnTvC8tvcpJLMhRWztA64qnLQEdVmsxgSF6nFCASaNZreSI5G8YyO1AD YYzHGqE52jFAzA8UDN7Yj/ep9BFTGKyAMcUWAQigCOWNZEKsMg00wKn2Jo8/Z7iWLPGA3FVzAFlb XFjKJobllkH5H60OVwNdfF01u227s84/ijPB/CiwC3Pje3QL5FvI577jtxT5QNbR9ftNUj+VvKkH VHPP4etAGqpB6HIpALkUwFzgE4zigBFIkXlfwNOwFO60ewuR+8tkye4GDTUmgMu48I2wBa1keOQH I5p8wFOTw3dh/NLK7gHleC31obuVdW1Kfk6zZKVmtjcJ/dYbgPpRyxKjOO1jJu45ri4KzKlucZAb IFOMUgnytaDk0Z0USyPHIn+wwIpSkQqcuhchtycADAFc+rYWa3LAiRBlu1UgKs0/zfKeKollV2di SGI/GmMmSZlT5myanW4ytcagCjRxtljxkdq0iiWYdzksIx361srIhmpp3hyW5IebMcf6moc7FRjc 6ezsYLKPZCgX1Pc1g5NmtrFuJPNbC80tQ0LscUcIyfmagBJJC5qrCIyKAEAwaAFY0ARtSAmHWgBT xTEQt9400AquV9MUANljik5UFD6UWHcrtbsOjCiwrjfs7d2AosK49IkTqcmiwXJQ6jjcPzpgDyos bOWG0dT6UWApxrsR5FGJJzhPYetPYC6qCOMKOAorIZzd0PMlXHYFvzNZR35jo20NnRwTaf8AAjWq 2Mpbl0qaCRQqovJAoAje5jTgc0gK73btwgx9KBkG8uTluadhXHrGSen500rCbJVhAzk0AIFA6Cqu IAihshQDRe4FiLlGHtS0QzK1JHe3KocEkCmTYw9WkWCIxIR+7GOP7x6/pWiRJe0aArbiQjG5QFB9 KGMuuOKBFS7s4JR88Sn3xUp2G0Zk+jRHmNintVcxJatdHuTAGt58MOMA4ppJ6lDG1DVtMcLK7Fe2 7mpaQy7a+MZEwJ4c+6mlyjN/T/EVteYC7g3oRSsBqRXcbdGFICcOp6GkArKJFxTuA4cUAGKAOc8T f8hCyHs1PZAVKyA3NFt45LRjIitlu4qkA2+0lW+a3G0/3e1NgVYNFuJM78R46Z70rAMn0e5hRmwr KvJ2miwGceO1KwDWGRgjijUCE2kLNkxLn6U7gJNaRSJjaFPYjtSuMrodUs/+Pa8kC+m4/wAqrmQi OC51eO485Z5g4Ocl+DVXQHV6f4styqx36tBN0JxlTUgaUuvabBb+b9pRl/uqcn8qeoDNP8Raffyi KKQrIeiuMZo1A1iwGPc4oAcF3Agde1OwGbpU91PHJ9rh8p1cqB6j1oasFy3LbQzDEsSP9VpJsDLv vD1hJE7rGYmAJyhIp3KUmupzNtcwA7D5+BxuADj/ABptIEm3qQ3cq+YVSYSD8sfhUNMtwsVHBJoS Zi7CBegrRQbFdDb1QtuVLfMegrTlsK5VstOnujthUgd27Ck2khpM6i10qGIRPIiPMihd+KxlJmiQ /Ur6LT4N7/ePCr60opyHflOQ1DWbm6P+tZF/uqcCt4wSMnK5nrdzxtlJpFPqGIquVE3ZvaF4mmWZ YL5zIjcB26is5QKUjs1IIBFY9TQWmAlACGgCNjQBYHWkAjnmqJI2GehxSGRmNv7+PwoATyz/AM9G ouAeQP77/nRcBRbJ33H8TRcBlxFDFEWKdB60XEzCKkSFiTnsKaA2ja7YIrUkBEHmynNaJWEiS3Uz P57LgEYQei1lKV9CrD7nMdvI3opqWUc7Jx55/uKq1nHY2e5raZcxx2S92yePxrRbGUtyWS8duFGK CSBmY/fbH1NCQNiYPZSfrxVqJPMPEZx8xwPQcUbCuPSMfwrQOw/bjr+lFwJUwMACkMiYYJoASgRL B1I9qBmdqReOCRkHzAZFUmJnP2Fob29VHy0cfzyH1NU2Fjoyu3gDAHSlclkTiqEMcZWoKKzUyDQ0 huGWqjsUV9XQHy2I4DYoewIznsYJG5QDPpWalYZ3FnYWkFrHEkQUBeo70NsoWTTIm5RsUrvqFiJr K4i5jYmi4WGCe5h4dc1QiZNRH8YK0gLMd1G44YUAUtTsDfPHIjjdHnCnpzTAzJbK4i+/EfqORU2A 2tEUrZ8jHzGgZaunEKFxjd0qkIliO+NWIwSM4pMB+O1AzOm0a3lmMmWXJyQvSgRI+lWbLjygPcGg DL1HRjAm+DcwzyuORSsMowafczkhIm4654pcoDJtOuYfvwt+VHKBUIxU2YFe5EJH704x6dauKYXM 258lZCIWYp6sMVsoPqRzFbzMMCuQwOQR2qrJCbPT/Dl1JfaVBLPkSjhs9z61i9yka3SluMTFABQB Ddnbayn0Q/yoA81tZp1LBJpIxnorYpyY07CgSfaxPJIZSOzAHNXFNhKqy011GsbF7CIjrlCVP+FU 4tDi4Pcz4BLdyM9ujlV/h9KLtCko9DVs9DLsJbw5P9wVEqnQlRNqOJY0CooUDsKyuyyeKBpDwOKB nA+Kroy6nKgbKRnaPwrogrIykzDLVoQNJpACnDDHWhhsei+H783lkhfAcDBrmlubR2NbFIYh4oAa TQAxqALA60gGP1piG0CCgYUAKKBC96BlHUpQq89F6D1NAFfS7XzZjI+NsfzHPc1pFCZabF1OUB+Q HdI3qfSlNiii21xFGMA59hWTZdijfXRkj8sDAYgVMnZFxV2YJPyySZ4eQ/lRFaWKZqWSf6OhCk5G eeBWijYxlIseW2OW2j24qrE3FRAPujNFwJQh7nH0pXGOVAKQ7EgpDGP1oQiWIAUmMhkHzGn0EYeq a8LG78hIvM2gFjnGK0jBtEuRr6Zdx3kKTRH5WH5VMlYaGX0ZeGVRjODjNCGyGwtVtYdoO5jyzepo YIlkHNNEshcVSEMYcVLArOuDQIs6W22cj1FVECXWI/8AR3Pp81VYDPXqDWHUs7WI5iT6CqAeCRQA 9WI6UAKSG+8KBjGt4XH3cfSgCB9MQjKNSuFiE2tzD9xiRTEKLm4j4ePP6UBsSx6gnRgV+oosFyxH PEwGCDznrSuBOGHrQA4EUxi0AFABQAtABikBh6n4dF1Jvgm8jPUY4q0IdD4WsVgEcoaR+75wafO0 Kxl6n4MjVDJbTPweVYZ4qudsLEVhpVlasCEEkg7t/hV3Ieh1WmAiEgjHPSspFIuVBQUAFAFXU2Ca fcMegQ00rsDzq2We5YRpDuZR/D1Yf41pazL0cRIwqOxu5fJVT/qwuXPsB/Wr2M+W3U0FiuNSQJHC trb+pGWP41nJmsZxS0Rq2ljDariNAGxy2OTWbkTuy0qE9BUgWYrUKN0nHtQMkeQBdqjApok8s8QQ tDqUwYc7ia6YvQzkjK70yQpgOjQsRgewpN2BI7bwxGYxt7ACuWW5ulZHSUgGE0wGmgBCKQywpAoE NPWgQ0rmgYhGKYrBigB4U0ANk+Qe9AjInb7TcYH3VOB7mmgLE8hs4BBEP3jjJPpWjdhblW3V40wT tB5OTWTVy72JwR2Bb9BSUCXIq3khRGZgAEUtgevQVFRdDWl3MryyI4Ih95hz9TWj3FfQ6WKIoiqM KAMcU7mdh4jUe596QC0DCkAooGKKAArzmlcBd6xrvZgqjuTS1GkY2oa3EkjJar5z+o6CtYwuS3Y5 zUYLqQNdzIW3HBKiumMklYxaZueDllS3cyBgrP8AIDWFR3LjobVwOXFZotEKH5QfanYQrcimhETC ncRFjrSaBEEw5oQMWybbcrVREat+nmWzD1U1qBhw8oh9q5nuUjqU1K2iaGCSQCRlGBVWC5fBoAcD xQMWgBQKAHjikA8E0WHcGVW+8oNICJ7OF+2DQBWk0wdUbmgLERguoT8rEj86YgW7nj++maAJo9RT o4K/WgC1HdRv0YH8aAJQy9jSGOBoAKYCPuC5FOwhw6DNADuKQFf7FbeZ5nkpv65xTuAtsD5k3pup CsN1G+j0+2M8wOwddozTSuMkt50uYUliOUcZB9qQEtADJ4lmhaJxlXGDQBiXPhsC1aGzl8recsT1 PtmtOcaaSKkHhuSIq90zXLpwu45ApOVxKK3LflFOCuMVmUSw2zSH0HrQMshY4B8vLetAmyJ3LGgQ w0COa8V6P9rT7REP3gGD71pCVhNHDTW8kTYZSK1uiLMasRyCykj6UcyCzNO2s2LJKylEzwuKiUrl RR2mjWwhtw3c1h1NbmhimIQigBpoAQ0gJe9AC0hCgUDAqAMmmBE08ad8+woERPeMeFGKAK9xM+za CS78AegqkhERKWEHzDM56D096u1hBAkzjzJWwzdPUCk9Q2JFiUHux/OgCURsewX60rhYx9TYMxjz ne4X8B1rB6yN4q0Rtgn2nUd+Plj5/wAK0RMtEbwpma2CgYlABQACkAhYKCWOAKGBkX3iCGEmO1Hn SDv/AAiqjTuNyUdzG8y61SbDF5m/uLwq/WteVRI5m9jas9HW3AM+Gb+6PuiocgSNLaMY7VF2McgA YYGKAFnHzmgaKqcKKZI7NADSKYETDBpiIphxSQ2QxnbIp96aJN2T57f8K1A5+FduV/usR+tZTWpS NXVdMlkgingCZ2DeSORjvTiwZDHNNKVneV95AIAYgD8KhvURv6bdG4h+b768H3oQy4KYxwoAetIB xyPpQA9VyucUANIoGA4oELuNFguIURvvKKLDuQvZRP0GKQFaTTD1Q0XCxEYbmH7rNj86dxWFW9mj 4dM/SiwFiPUozw2V+oosBajuEf7rA0ASBge9ADwKACgCK243H1Of1oALmCO7geCXlDwQKadhMW3g S2hSKIbUQYApASfSgYHIOKADjPagBaAEaNWGCoNAXI2gUjAJX6UWGmQPZv8AwsD9adgIHt5E6oce 3NAERGDQAxlDDBGRSAx7zQo5WLRHaT2NGo7opDw9NnkpildjuiZtO8iMJOQ0ZOCR2pxJZZnll0/b GFV48ZV/UetaclxXJrW9juBhT82MkVm1YaLFIYhFADSKQE5AB5pARvPGnfJ9qAsQPeH+FcfWmOxG ZHcfMePfgUkgI8L2yx9qrlJbFjYhuVAA9OSarlFcJpFtQZnwZD0HpVWsIrW0El1KbiboTlQf51LY y9sGeSTQIlUADgYqRjJ5BFEznoBSezGjmLqUm5yedg/U1EUb9Da0e28m23sMPJ8xqzGTuX6BCUAF GwCUXAz9Q1a2sVO5g8nZFNVGEnsLmsYMk9/rTYVHEXZRwv4mtUox2J5rl+z8ORrhrlt3+wvApSqM FE3La2jhTZEioo7AVk5XLSJJh0x6VIFeWaOBd0rqi+rHFUBJE6yAMjBlPQg07WEPnHzD6UhlVPu4 9DQDCmISgRE9UiSCQ0ARHigZuQHfbj6VqhGE42Xcy/7Waie4I7KJA9qqN0KAH8qhaFnOSx+RK8e7 dtYjP40mSX9EJ8+QdtvP50kM0X1KzSTy2uIw/pnpVXGWVdSu4EEetIDBu7zUZL1ltn8qEHGSuePW mBFpOt3dxe/Zrr5Tjhh0JpuNtgTOtt5PMTnqOtIGTiAsN3AHqaaQiKZFT7pzQBGDipGIfrQACgB4 zQAv1FAxGijcYKikBXk0+JunFGwFd9MZeUancLEZS6h6Fj9eaBDkvpo+HTP0oAsJqUbH5sqfegRP DLHlirD5uaBkwZaAFzQAxIyjsc8HtVdBDyMkHNSMrra7LszqfvfeoAtUAFABTEFIYtADGiR/vKD9 RQBA9jG3Kkr9KAK8lhID8pVh+VAED28qdY2x+dAGLrpcRIq9CeauCE2S6JbS6vatayhSYjujfPOP StrE3EuLNbCTLAo4O1T2bnmomi0yeNgy5Fc5Q48UARPKo4oAid5JOSTikUMwo7lvpVJE3FAf+EBf 1NHKK4ojA++Sx96onUJGKDCryegoAZLMtoDuO6XH/fNVsBXtYGvJPOmz5Y6A96hsZp4wOOBSGM7U xDx0pAZmr3IXEfZRvb+lSzSKMrSLX7ZOGbPlqdz+5p2shyZ04GOlBmFACGgDP1DWLWxyHbc/9xeT Vxi2JuxhT6nqGqSeTZjy0P8Ad/qa0tFEu7NLTtBggAe5xPMeST0FS5voNI10jCgBQAPQVk2VZEqq BRcaFAqRhMPlWhCZyfjAPm3YkiIZzj1reFjOQ3whdsJWtiWKldwz2p1FoCOsnHT6ViWVAMMw9zTB i4piENNCInqiSu9ICJqQzX05t1uBWyYjE1W6hs79jK2MqOB1pSVw2LcvjWFUCW0JJAxlzj9KjlHc oReIlu7wC5typc4LRcn8u9DiC1NjU9QtrDTGSynVp5eCc8gf0qUrhscZJcSqWKM3PBweta8oXOh8 O6lPPC0cju/l8lf9nvUyh2GmdXZ2Us43KDsPOTxgVPKO4+ey022Ky3EhBB58o9/f8a0h5kyZZs7m NwkkThlcdO9TJajRd8zcMAnFQA1qBje1IAoAUUASqu4fKRRcBCCvWgYdRxQITkUAKCaLALkdxRYY 1oI36qKQFaTTo2+7xQBXfTnQ5Q/lTCxGftUPckD1FAhy6g6f6xD+FMCZNUhY7WbaffikhFuOeNgM MDTsA8cjAc9c8UDHFtuOCcnt2pAOoEFMBaQBQAUAFMBaAExQBXvbKK8hMcij2YdQaadhmZZaRcWV 0JI2RlBzySKvnJaLmsWL37RyEqXH3h0H4U3NNAtDCisry2MhliPzHII5FZWLuRStITg8e1FgIORS GWjGP4jk+9IQ4L2VcD3ouFhwj9T+AouA4Jj7o5oSBlK6ukhDbSDJ0J9PpWmxNyta2rXLebMCE6gH vU7gasYwMDgVIxW6UhsaRVCI5pRBCzseAPzqWNHOXJlu2WNfvzN+lStTV6I6CytUtIFjQdOp9TVm bZYpCGSOsaFnYKo6k0wvY5fV9fedjBY5C9C46/hW8KdzNsh03RZblhJNkL796U5W+AIxZ09tax26 BI1CisLlk4GKBjqBhSAcvXigYS/c+hpIRSu7SK8gMMy5Q/pWidiWitpmj2+nOzxFmZuMsegpylcS RqS/dU1BRWA+ZvrQApFADGGBVIkheqJZARzSAjcYpFFq2uhbWM0rY/dqTWiJOFurlrmd5X5LHJzW oiHBByKBFhZJIwHUlD2I7Uco0xFd2YjJJPPNK1guWRAEQNPKq56KDk0AaWgasumajFJHGGU/I4bu DwaL2A6VNUuy3kQxmVF4XJ6CsmzQTVJjJb+W5AJI3H0pRugNXw/b7YYh0x8xp3A2AME1ICE0gI/N Tdt3Ln0zQMkBoApavdyWtmxgAMp4XPQe9CAwrjXr+yt4ZJ7aNi2d2GP5+1Uo3Yjd0G8m1W380Dyw DgoeaHER0CQK8HyjBpqIXGS2eyHzGYD2quSwJlQkDpWXUoSgBwYr0OKYCjJoAMkUhCMcjGBSsBUu 4Hkt28iNPOI43HgU1oFzJg0eGBi8+Zpjydx4B9hVXEWTAmQVypHdTigQoFzEMxyhh6OP6iiw0OXU Zof9dA2P7y/NSHYmi1S2lcHeA44wTj9KAuXI5Y2JYNyfekFyUMD0oEOFABQAUwFoAKACgBKADFCA MUARS20M3+sjVvwouMpT6LbuDs3IfbkUXAytoB4FZ3KCmA7aFG5jtHvVRiK9ihqF3sGyPIB9epqr kla1tDKfNmHy9QvrSYzSUcUgHDrQIG64pDGnvTuD1MTUbr7RMsKH5AeaykzaEbEmjQiS4kuP4V+V KcUKTNnNUzMztR1i2sVIZt79lWqUWxN2OZur+91qYQxBgmfuJ/Wt4wUdSL8xt6ToUdqA8wDyemOB USq30KSNoKFHFYlC0DCkAlACimA4daQwcfuzSEQCqQhwpgPf/VikBX/5aN9KAFoAa/SmhMrvVogh brQAx+RipGUdVdl0udV/iKg/nWsSWcmetaiJICBIu77ueaSA2JmtVtHhRdzg5VyKpiM3cSeFqChy W0zgsQQPU0XCxLaWxMy5OFByTSbsOx6TptkJbNHcMocZCg4IFZdShz6FayMpcy/L0BamBp2sSQqQ owKTD0MTWPEZtLl7e3jVmXq5PGazlI76GDdZczMWTXLyXOZXGfQ4rJzZ3LL4rUqTTEYfzGLnk+1L mubRoRjoX7LxFd28RjJD/wB0vyRVKdjCpgovUgm1O7mk3tM2fT0pOdxwwULWOj0S2Ou2zLIFJQYY muimrnl4ikqUtDd0eCw05fJ+1AzZ2YJ49hXUlochrjEMuHIVXGay2Ap3bguwRsr2qJMpFTNQUAoA cKBEkZB4oAc6kDkcUCIyoPSmAiDDH6UAZ8v3jQMYKYhw6UhoSkMilgilH7yNW+ooEVmsNhzbzyRH 0zkfkaYwE+pW39ydR6HBosKxLHr4jOLmKSE/7Q4pWCxoW+q204GyVT+NAi2syt0NADwwPegB1ABT AKACgAoGFABSA5kKW+ncntUqJQ37RFEC+cqP4j0P0rVJIlsy7vUHnbA4XsPWpb7APtbRmIkn5bsD UjL+3ii4CUCCmAZ5JpD6GXqd+I1McZ57kdvapbLjG6uZSq6Kf+esp2gegqLGlzeie3060VHkVQg5 +taehi9zA1bxDK6lLUGNDxvPU/StYU77mcpFGx0q51FgwBSM9ZH6mtG1HYlJnWadp0NhFsiXB7se prBybNErFwcCpGFABQMKQBQAdKAFHWgB5Hyke1ICtVCHCmA8/wCq+hpAV+kn4UAOoAa3SmJlZxVo khcYoEMpDI5bf7TFJB3dePr1FXEGjj7pCk7grtIOCPStSCIUwJ0L7x6UhFob32oowB0wKRSPRbfw 3ZSafHHNGfMKgs2eQaxvqXYzdX8MQWdiZLfzHfcBz0Aqk7hY0/C3nmwYyltm/wDd7hzikwRujGPa puMqapcLZ2ckg4kIIQDu1A1ozgRAJG+eTMjE5/8A11Lgd31xpWirFm40qS12/OrZ7A5xUONzqo4n uR/Z3YHCk4HPFZ8tj0VOMlcZ5IRcsCD24pWFcFmSIYCDd6mmybamjoV/Il0yhyFZcHHStINo87Hp WuOnea71NRC5B3jH+NdCk0jyGjtbdZDFvldnbGATUXuNIkzhTS9Q9BmRQMB1o0FqQahex2Fq00vQ dFHUn0oHY5uLxTKhR762aKOQnYV9varcOxJ0Njq8V1GDA/mZ7d6nlYF+EhvmIIHcUAxzpt+YHgg0 MEZkn3qEMZTJAUihaQxDQA2kAhoAY6qwwwBHoaAKE+nWr5ITy29UOKdwKpivbY5tbssP7r0CsSJr 1/a8XNuWHqtAWL9r4ptJMByUPowoCxrQajBMMpIp+hpgWVlU9DQIeCKAFoGFABQBx95NsCtOQT1E S9PxqthmXLLJcy9Mk9FHQVLkFi/aWYi+d+ZP5UmBdCgVIAaAGGmISmBR1G9EK+XGRvPU+lQ3YqMb sy7aISZnc8A/ID3Pcmlc068qKYvtly0yAHZ8ql+gpqBEphEZtQlYYaQv/wAtGHAPtWyhYy3Nax0C CFhJcHz5vVug/Chz6IOU2VUKMDgVk2yxelABQAlABQMSkAtABQApoAeo4PvSApzv5MTuBnaCcU0h HLWPiW4a8UTlWidsEYxt/Gt+TQzudgh3QZHIrE0RAf8AWL9DQMdSEIaYMruME1oiCBqAGD71DAeg 2yofektxlXxDoX2thcWy/vm4I/vVsnYVjk7i3ltpDHKhVgcEelNakvQv6Ppkt5JlY3b/AGVGSaTd hpXOy0bwx5Vwk92AoTkR5ySfesmy7HVdKkBcUAIFA7UwFFJ6Ac/4s80+SEB2gHJq4q4m7HNRQkyj Py/XiqsK51kM9k2nxzSnzbiM7G9x2quVWKhJmLqWpGR2EIEaNwVWuSoz38JHmj7xjzS5bjNZnS0o 7FjTNNk1KQiPkJ94k4ArSMbnFicR7LY6a20H7LCRC8bSHruBxWqSR5NStOo9dibS9LngnaW5MZcn grQzE3Z5Y4YhuYIijkk0RjfRA3y7mPe+ILeNdsAMrfkK64YOctWc08VGOxjtrl5vL71A7Lt6V0rD RtYw+sPcmsfEMyNi6UOnqODWdTBprQcMW09SK+1ZrmcsFGwcKp7Uo4R9S5YuO6LVrFbatb+XIg3K MbTzXNVpTpPQ6KVZVEaejafbafBN9ouVSSNSqJwDjr+NaR1Q3oVryW7juIfKXMUnyg54Occ1LhqN bGtZtIYGEhJK5GTWEtC0VZOtSgGVRILSGLSKENADTxQAxnApAQPL6UAQliaAGGgBpoArz2kEo+eN c+tAFF9L2HdbzNGfrTAVLzVrI/K/mKPXmmBdt/F0kZAuYSPUigDXtPE1lPgeaFPo3FIRqxXsMoyj qfoaAJw4PQ0AefJFLcynnOerGkM07W1SBflGW7mgCyBigAqRiUwGOQvJ4ouiSldXqxqQh3P/ACpc yHGNznL66bftHzE9STxQo31NJPl0RMwmFosS/NczcKB/CtTCPNIb91F3T/DyRhXvG81/7v8ACK6X IwsbccKooCqFA6ACs27jSJAMUhhSAKAEoAKAEoAKACkMUUALQA9eOaQyvIoJZSMg8U0JnJXnhu4W 6ItwhhZsg9CtdCnoZtHXWsfl2yxk5KqBmsWWRNwy/WkA7tQAhoAgk61SJZA9UIZ3pMSHnsfSktyz bsQJDHn1zWr2JRU1Xw21/q63fmIIjt3qy5PHpUqQzdt7aK3QJDEka+ijFQ3qMmAoGKaAFFAgoAWg ZX1DIs5gqK5K457e9XF2ZLVzgJ5S8xJOSDirbFaxZtZfJgZnOAeR71DdkaU4c8tCkZN7EjueK5ZO 59HQg4RGNEAfnfHsKcUROq4o7bwxpxsbItIMSTENg9QOwrZHh4ip7SRtBARTtcxe4bPTND3BaI47 Wr+W4u5FZj5cZKqo9q9rDU4U4XfU8fEznUnZdCgrOefLYfjWyxEdkYyw8rXJlXcOn44rXSaMU3Bk Lvg4UdO5qVGxpe4wnAznPrQIfbXc8TnyHZWYbeKxxEU4G2Gm+exHfteQzqtw7PIVDZzzXj3toeyd n4eYzWEPnwHK9S3SobA13ZSG2gAY6VLKRnSUgZHVCEXrSAcaRRG7haQEDyk9KAIWJJ5oAaaAENAD TQAymA00ANNADDQBFLDHIMMgP4UAUpdMiblCUNMZXNveWpzBK3/ATQImh8R6jasEf5yOzcU1G5L0 N+OJYxtQYFZlEnSgYmaQEUlxHHwWGfQUnJICpc6gIULHCD1c4qG29hmOdTN7MUiZnA6noBRyMcdS G/uRFGFTJdugA5q4QUmXJqKIbSwlRhNdAIgG4qTyfrWtSSiuWJjBOT5mbej2rSO15MMM/CD0FRFc q0Kk7s1wAKCQoAKACmAlIBcUAJQAlABQAUhi0AKBQMcOKVgIWOXJFMTEPWmIlj6GgCtJxj60APoA aelAELDjNUiWQMKokYRikAo5FK1ija0c7tvsK0ewkbIrMoWgYooADQAUCFpgKKAA8jFIDEv/AA7H M7Pby+TuOSpUMM/0qkwMK+8P6oJPuidOxQgcfSpcWzvo16cFsOtvDGoSrl/Lh9nbn9KlQsaTx/RI 2tO8LWtvte5JnkHODwo/CqSscc68pG8BgUzAcKNgRBfOY7KdkOGCEiqho7iaurHn9y5SQgEM3Usa 1lOT2IjTUS9o0hkkMDqCJBtBx096UW7jaRsS6bFZKTduA6nBjXqa9ClUex59aklqYt/5Ry8S7eTx mu5Jo4OZdCgWzxQ9gV7mnpumyri5KOyryMLmvKr17qyPVo0FH3jUtNJ/tG+WacERoMc9T9a4DsOm VQqhFACj0oAaRgSfhUjKMlNAyKmIaXCnk0hkUkx7UhkLEnrQAlADTQAhoAaaAGmmA00ANNADDQA0 0AMNADCaQEbNimhMyrlxJcTf9MwBWqViTp2ukzhAWP8AsiuXnuajGllIyFWMermjXoBQudRtYjiS 5aV/7kfNNQkyWyjPqFyV/cwpap/ek+9+VaKihOVjHYNd3AQM87k8s3QfhW/s4wVyE3JmnGggRYLc bmJwSP4j/hXM5c7sjptyo1bayhso/MdQ82PvHrn0FPZXRk/ediq6m9vRADlUO6Vh3PpUxV9WXJ8u huqAqgAYA7VRAtIApgJQAtACYoAKQCUAFABQAUhi0AOFAxwGaQEcwAYfSgTGCqESR9aAK0vAPsaA H0ANbpQAwj5apCK7CqRBGRQAJ6VLKRtaDzv9qq4I2fpUlC0ALQAvagBB7GmIWgAoABQAue1ACYoF YVRigLDqBi0AKKAI7mPzreWMdWUj9KEBxuqaSLKQPM4AlXeoHJ/+tW1ibmel48ClYjtHqOpqb2At 3F48zDcxLEAHmu/Dq8jhxLtEgunxExr1JbHkx3ILK3e7uY4R8u84ya5K0+WNztoxTkejx26JEiY+ 6AoPevEd73PYSsh3lsn3HP0bmgA3OByv5GgCNZkIlTeN45255x64qRopyyKueeaAKryk9OKYiPJJ 5pDQGkMbQAGgBpoAaaYCE0AMNADTQA00ANNADTQAw0ARMcUCIm4BY8Ac0xGBYzecbtz/ABMa2J6m +1zqEg4WK1T1Y1y8ppcpTtCAWuJ5rsjsDha2jBmbnYzW1fYSttbpGP8AZ/xro9lGO5LkPFnf3qb5 f3MZ9Rgn8O9TKpGK0GoOTLVvbpaRNGhJP/LWQf8AoIrjnUc2dUYcqNfS7Lyx58ow56D+6KqxnJjN TuCigpy7HbEo/U1D958pSXKWNNtPskAU8yNy59TWlraGbd2Xh0pALQMKACgApAITQAlABQAUDCkA UALQMcKQAO/1oASYdKQhiiqAcn3qYFeb+KmIcOlIBr1SExO1ICBxgmqQmRsKZI3pSA3NAX93I3q1 ItCy+I9Mgu3tZbkJKhwcjgH60WYXNC3vLa4UGGeNwfRhQ00FywKQ7DZtwhkKLubacDOMmqiIx/DN vdQJO1ysiKzDarnPPOTQI280DEFAC0ALigA5pAKKYC0AAoAUUAOAoAwPEenSyRmWMF4xywHVfUir TvoTscq9ukbApIZPbbjFbQoTm9DOdaEEPUfPu/IV69Gh7NXZ49ev7R2RYgtDdyhVRmb+6o/ziscR iYw2NsNhpSV2dJo2hC0lFxOB5g+6g52++fWvLqVnUPThSjDY3RWRoFADXXcuMke4OKAMu8soobpr oM5ndAnJ6CkBWPSkAw0AApDQhoGJQAhoAaaAGmmA00ANNADTQA00AMJoAaaQDG4piGGgClq832fT pmBwSu0fjTjuD0RgaKRmWP2BraRmaJuZ5X22Vrub+8+XP+FHuoFclj0K8u2DX0+0f3c5P+FDqdh8 hqwadZacm9YwWH8Tck1jKbe5SiVbieS4chDjHBPZRWMnfY3ikiXT7RZCrkfuV+6D/EfWrRMpF68n WJCpbaAMsfQUpMUFcp6fC9zN9tnHbbEvoKcFyoU2anSqIsOWgodSAKAEzQAUgEoAKACgAoAKQwoA WkAooGOXrQISb7n40gIxVAKvBFNCIJ+GYUxCKcqPpTEBoABSY0QydapCZERTJEoA3NPkW00mSd+F UMx/Cp62LR5yl0PMlmurUTJMxYk8Y+hrpRncZcTwwlHsHmjJ5ZWP3fpRYLmjp/i7UbPCs/moOzc1 DhcakdNp/jiynwtyjRN6jkVDg0Vc6K1v7W7XMEyPnsDzU6jLNAABQA4CgBaAII7u3lmaFJVaRfvK DyKQE1MBRQAooAKAHUAFG2wepk3/AIetbty6loHPUp0P4VtCvOOxjKjCW5XPha38wYuJfLHVeMn8 a0liqklYlYemtkbFpaQ2UQjt0CL+prmb5ndm60VkWBQJIKBi0BYQkYJPQUmBk3UpklJ7UhlZqBDD QAZoGGaQDaBiUAIaYDSaAGE0AMJoAaTigBpNADDSAazYoAj3c0wFFJhYwfFM+EhgB+8SxrSCJlsY 1jP5F2pPQ8GtpK5mj0VUVRhFCj0AxXKbaiSusKbmOPalew0mZM07XLkg7YxwWHb2HvUtXNFZBaW3 2p9oG2FPvEd/amkTJ2NWR1gj4GAOABTehC1Mna2oXXk/8skO6Rh3PpUrU0fuo2woRQAMADAqzNja okUHmkMdUjCmAUAFIBKACgAoAKACkAUDFpAKKBjhQIHA8sikNkQpoQDrTQiG4HzmrERxn5BTsIdS AVaGNEcnWmhMiYUxDcUCJPE139j8LxxA4efC/h1P9KcV7w2ziIL+e3TywQY/7rDIrYggd975A4oA luJ1m24gWMgYO3vQAyKMuSPSmA+G5kgf9zMykH1pOw7m7p/jHULTCyt5qDs3NQ4DUrHUad41sbnC zgwt+YrNwaL5joLa8t7pd0EySD2PNTsBOOKAMfTtKmg1GW5mKc527epye9U2Br9KQC0AKKAFxQAU AFADqACmIMUAC0ALnFACnpxSGVbuTyogmcnuaQGYTQMjY80EjDQA3pQAZoAM0DCgY0mgBhNADCaA GE0ANJoAYTQAxmxQIjLZ69KAE4NA0FIZy2uN59+SG4T5a3hoiJIoGFlcHHHrVXJ5bHpM8ywoSfyr lZra5ku73jsxO2FerD+QqTRaAkRun8mIbI16kfwj/GpXvA3ymqiLDGsaAKorVIyeplahdM7iOLlm O1B/Ws27s1iuVGjp9otpbqg5bqx9TVmb1LJ6U0IZTJDPNADh0qSgoAKACgAoASgAoAWgYUgFoAMU gFFAxc0CF9qAIRTAWmIjuR8w+lUiWQRfc/GmA/FAgHWkMY45poRGRTAAKAMXxvd772C1X7tvGMj3 P+RWkFoJsw5Z4ZQuIVjYZzjoaskfPKsFyjosbhoxkY45FAEXlyXCvMqBYwevQfhQA9AI4HbvQBRJ yaAFDkd6YDxJ6j8qALNtez27BoJmU/Wk43C9joNP8a39thZ8TIP73+c1m6ZSkdPp3jPT7vCy7oX/ ADFQ42KubsFzDcruglSQf7JzS2GTUxWFFIBwoAgvLqKzhMs7bUHFFhjraeO5hWWFgyNyDQImFABQ AtAwAoEcVqF1dtrcq+dMkqzKsKKPlK55/StV8IHZg7UBbsOaxGZdzIZHJpDIDQBGxpkjKYAaQxhp iEzQAZpDEJoAY1AxhoAaaAGmgRE7UWAjNMBp5OKAEJxSGRTTiCJ5D/CM01HmFflOamRL1GkiyH6k Vony6DtzIqwSGJyr5K9waprS5CdnY7MlrxjI7bYR1b19hXGjo2Bg1w4ghGxF/JR/jRuGxpwxJbxB EHH86tKxk2U9RulhjK5xkc/4UpPsVFEej2rMxu5h8zfcHoKErDkzWPFMgSmAw8UxMSgQ5TxSKFpA FABQAUAFABQAUDFpAFIApgGaLBcKBDh1FAEZ4Y0DDtTER3PRfpVIkgj4yPemBJQAmKQCHqaYDCKY gXCkFug5P0oA4y5ZtU1K5m3Abiz5bjgVtFWRBRZcUwG4oAm+0StCkBIEanIFAEt0u22XbyM8mgDP 70AFMBaAE5oEOWRh3oAkWRT1GPpQBbtb65t3DQTMCPek0h3Oi07xve25C3KiVfUjms3EdzqNO8Xa dd4DuYmPryKhxsUmbsM8U67oXVx6qc0iitq9pPe2wjgkCENk7uhpp2EP020+xWiQ5BK9SBgZpAW6 ACgBaBhnFADDEhcOUUuOhxzRfQCC9l2jYDUgZxoGMY0ARE0yRvegYppANNMBhFNAxCaBDc4pDGk0 AMJoAaWoC5GxzTAbikFhjGgBvSgBjGgDL1yYLaFf7xxWkSZHP20zQShh071pKN0KMrMt38IZFnj6 Hrioi9bM0lHS51JMl7II4hsjHp0WuX4tjZ+7uadvAlvGEQfU+tWtDJsju7lYIyxIz2FMS1MizhfU rnexPkIcnP8AEalI0bsdCoCgAcAdqZmBoASmA1utNCY2gQ5aQx1IYUAFABQAUAFIBaBhQAmaACgA 6UCAUAOAO0n0oAZLkNx3oAaW4pgNn/1amqRJDH1amA+kAUAJjmgBpHNMBsqwmGQXEnlRFSGf0GKA OIvbOO3Ym2vIrhPbKt+RrdbGZTV8EE0wJJZRI5YADcScDtQA+WDyo42LAl13YHagCPnBGcg0ARlA enFACGMjpzQAwjHtTEFABQAUAKpxQBIsjZ9frQMlbAc44x6UtAL1hqN9byD7LK+4c4BpNIdzo7Dx zd25CXsIkxwSRg1DgUpHTaf4q068AzJ5THs3T86hxsM2o5ElUNG6up7qcikA+gYUANKg59aABm2q WPYUgMuZ9zGgCEmkMjY4FMCMmmSIKQ0FAxKAENAhhoAYRQAxhQAw0AIRQA0jFAWGMcUARmgBhoGR vnoKYjB1198qop+4ORW0UQzJA5qyTR06QMrW8n3T0rKSsawd9DuoYEt0CIMCsC2JPMsSFm4Apk2M GQyand+WnA7nsBQXsb9tAltCscYwo/WkQS0AFACUAIw4poGMpiFHFIB4pDCkAtAwoAKACgAoAKAE piCgBQKAHYHFIBnmoM5oAj84EncMemKAD5WHynNAA/MA9jVIRAnDmmIfQAUAFACEc00DMTxRc+Va JEOrtyPYVcF7xMnpoYlnZxXkyxe2Tt6nA5rqxMoU6d47mNJSlMsyeFbuUSPZ4ljXH3vlbJ5xiuSj V50b1I8hgkMhIPbrWxAok7GgCzDcqkEkewEuR83pigAt4jcTiMMq7u7HAFADSoFADSoPWgCMxigB uw0wEoEAoAkh/wBYD6c0AaNvdWxi8u4g+YDAdTj86QxLa2NzKVikWNlHAJxmgB92l1bjyLgAd+Rz +f4UAJF8oFJ7jO88AxSeRcSlj5ZIUA1nMpHWkYFZlCUwCgCpeygfIO1IDPY0hjCaAI3PFMQwmmIQ dKGMKQwoAQ0AMNADTQAw0ANNAhpoGRscUgIic80wGMaQDSaYgSIvzVIRSu9IjuGZlO2T19atOxJz s8BhlKsMYODWnQQiExSD26UPYFoz0WeVYkLOcAVyG25g3M8t/cCGEZ+nQCgpaGxY2aWcIReWP3m9 aZLZapCEoAKACgAIpgRmgQCmA8VIx1IAoGFABQAUxXENAC4wM9qQgAFMBGZQMEigZG1xjhRSAheV j1NFgIy/pQgEG9zwKoCZIdvLtz6CgQ4thCvUZpiGdGX1xQA+gBKACgCpe3i2q4275CCVT1wMmqir ivY5HVdSa/nSTZsCrgLnNbJWIuUEZkberFWB6g0OKa1Hdp3Rsaf4mv7GF4lZZFfJy4yQSMZzRGKj sDbe5lTYBUbQSRyc5zTEMMWR/jQAwoV6ZFACZZRz0oAkSUdetAFiOaIWxjKfvC2d3oPSgAtrdrqY RR4BwTycdKAIiuOtADSgoAaUx0piJrJVEy+YVCk856YoGaWo2drDHG8W4M4zwwK0gMzY4AfBAPQ0 ATKzOwDknHrQBZQZwBS8xnqnhq0+xaPbxkYYrub6nmsXqy0adIYlADWbYhY/hSAypnLMaBkLUgGm gCN6YhhpiAdKQwoGFADTQAwmgBpoAYaAGk0AMJ4oAhY5NAhhNIY00wJY4CxG7pTEWCAowOMUxEWO tAWOc12IJcOR3w1awd0SzLA3R57iqJOmubibULjyYRn3HQCuQ6bWNawsY7OLaoy5+83rQTctUAFA goAKACgANADCKYhKYh6mpZQ6kAuKBgeKACgQY4PPamAnbnigBjyqox1oAiaZj04FAERNAxCTjigQ LGzUxEqwqv3jk0AO3Y4AAFMCOSZEHJyfamIWI+ajN93HSkAxRhx9KAJaACgBKAMfxBYyzRpcQvtM QORnHFXF2FI5Nz0GegxWxBHkd6AHxAF1AYD3NAD2f9+HBXcp7Dg4oAs3V79raMzRom0/MY1wWFAD LiKFAHhmDqT9wjBWgCsYjtBKkBuQfWgBhhPQDJ9utADNpHT8qAFWRkPUg+ooAcHzQBYklSRUCoF2 qB7k+tAEl3Zm2SNmZWD9MGkhtFbH5UxAMgdaALMV9NHAYMKUIxyoyKYCR8sWpAauhWhvdTt4cfKz jd9O9S9EUj1lAFUAcAViUITigAoAqX0vOwdBSKKBNAhhpDGk0ARsaYhhpiF7UhiUDEPFACE0AMNA DTxQBGxoAaxxQBExoERk4oGNALHCigC3FbhBluTQBIOOaYiF3wff0qhDeaXQaMTxAMOhx1UitIbE SMWAZYr2NWSd5Z2cVnHsjH1J6muQ3LFABQIKACgAoAKQBimA1hTQhKYDgKTAcKQx1IAGO9ADSwUf NTAiaf8AuigCJnZupoAZnFADST2oAekTN14pgyUIqe5oEBcDuBTAYXzwo3H26UCBY2cjcePQUxET xBWIx3oAsW4wjj2pMaIR98UwJaQBQAUAR3EIngeJiQGGOKFoDOevvDF+luXhQTRZyNnUfh1rZTJa Oea1lE3lspD5wQeKtakk/lfZT87EFhwR/XNMBlosBci5LID0K9jmkA+O1kmL+Qu/b27mgCJ1Kkqy lSOMEdKYieG9nii8oFXjxjDAHFAy/ommPfRXdxHcwwfZot2JDgsPQVLdikjNEMk6ySJHuC8nHYUy WVyg56r9aAGGLAyPzFACfMvvQA7ziQAxJx0zQBZt7sRQTRbFPmADceo5oASICWVUyFDEDJ7UAPuo UgndEfzFViAw7+9MB6IQBmkM7L4f2e+5mumHEYCr9TWc2Uju+lZjGmmAyRxGhb8qkZlyPuYmkMjJ oAYTQA00CImpoTEpgLSGITQMaTQAhoAZQAxjQAwmgCNjQBGeKBCJG0h9BSGXIYljHA5oAc3AxTAh kkwNq9fWqRJCBzQIfjmkUjF8RcRxt6Ma1gSzFtuSR6GrJPQq5DYKACgQUDCgAoAUUALikA0imITF MQoFADhxSAaXVByaBkTzMfu8CkBETnqaYDd1FgE5PSmgJUhOMscUAPAVOg5pk3EZ8DJOKAGby33F z7npTABHk5c7jQIkCgcDikwHoKQyOdcNmi4DoOp+lAyA8P8AjVCJKQBQAoXNAAxVOpoGbNl/x6xn 2zQBFfaXZ364uYFc/wB7GCPxqk2ibHNap4KLp/odwWUdI5O30NaKYuU5W+0i905itxA6D1I4P41d 0yRtjZzXO4xMEZemWwT9KAGyJLFcKbuNnAPzZPX8aYguFtfla2aTvuV+340DITxGWDkMTgr7UguK jtHgpIUb24pgIzszbpMtlst7ikBPcizYF7VpEJP+rbsPrQBB5EjR+b5TGPON4HFMCIxgjgg/WgBh Qr6igBTvT7ykfUUgJYXDOoY0AackivtVccUhnpXhGz+yaNFkYaT5z+P/ANbFYyZSIPE2qXFlKkcD rGNu4sR19qqK0GaumzPcWUMr43ugJxUMCO9lydo6CpGUjQMaTQAw0ANNAiOqQmAoADSKEoAaTSAa TQAxjxTAYxoAjY0CGGgY+OAty3SgCZgI0OB0FIBLYFYTI7khjkZ7CmAyVix9BTER9KYgAoAXPWga MnxAh+xK/TLcCtIksw7UfM1WSegnrXIbCUALQIKQwxQAuKAFAoAMe1ABimIb056UxEbSqnA5NAET SM3tSGMzQAZoAApbgU7ASLCByxp2EPGF+6KLCGtIF+8cU7AM3O33RtHqaBCrEM5b5j6mgZJikAYp ALQA4cUANmGUBpDEh++KaAgfhyPeqESgUgFJCjJNAFeS67JyaAQxYWkbdIePSgZqanqDaVZ26xRe ZI/ygE4HA5qkBd066+22cVxt271zj0oYjN8RC6M1usAmKHp5Zxhs96Nxmz5ayRBJVDAjkMM0XaE0 Y974Vsbh/NtgbWYHIaPoD9KpSFYwb/QtTsyzGJbyPqWjHJ/CtFK4mjl77AlIWEp6ggg0yRJZkl2f u1QjrjvQATzpNDEnkqjpwXH8Q96YBa28ty7rBg7R0JxmgCNxtZhIu1l4PtSETQXdzbIUgmYIedvb 8qYyOEI88azN5aZ+ZsZwKAJbqGOGby4ZlmXAO4DFAD11DKqlxCk6AYG7gj8aQDPs9rPhoPMjbPIP b8aAL+mWv+mwq+JlZwMEYJpS0KPXI0EahVGABwKwZRBeWVte7ftEKybemaaYD3KwQ4UAcYAFTcaR mSNkmkMjNADaAGGgBppiGU0JgKAEJpFDSaAGk4pCGk0DGMaYEbGgQ0AmgZNHCBy3WgCYUgGMQPc+ lAEbZYjJzimBGxqiRvegBRxmgCCedYlAJ+ZjgD1poHoUfE0y+WsS/wAJxWiJMS253DvVCO/rkNwo EGKAFC0gFxQwFAJNIBQKBgSF5zQIiaYD7opgQOSepoAjNMQmeKAHLGzdBTESLEq/eOaYD92OAMUC I3kCnGcn0HJoAb+8f/YH5mmIcsYU5xk+poAfikMWkAUAFAwoAAaAHMNykUgIozhxQBHKR5pAI69a tIkbJcqi/Lz24oAiVJZ+W+VaQyzFCsY4HPrQMeoy4HqcUAat/ptvqEKx3KkhDkEHBBpp2Ant4Et4 ViiXaiDAApBYlxTAKAFFAhaAKd9pNnqAxc26Of72MEfjTvYLHMan4EBy9hNz/ck/xFWpEuJy+o6X e6eNlzbMmP4ux/EcVfNcRTijLAsMqw4GPWqSJuIVZWw4J5yQe9NpoE0yxdNaSgPbI8MhPKE5UfQ1 IyJIZnjaRY2eMHGQOlMCNSpPHBoERnqTSGXrMbUHvzSYHT+DbM3OrrIR8kA3fj2qJvQtHonasyhn ekBQvJd7YHQUDKhpANNADCaAEJoENamhDKYhB0pFIQ0hjTQA0mgBjGgCMmmALGWNICdUCigB1MBj MSfl/OgBuNtADCcDNMRHVCADmkBBdXCW8ZZjyegppAc/LNPJcrKx5BygFaaISWtivcyu5IlbJJyf Y0JlShyKwtuMTc8cVRmd7jmuM3FxQIUCgBwGTigAFAAWC9TSCxC03ZeKBkZYnrQA0miwCE9h1piF SFmGSMVSEx4jVPc0xCluPSgREZRnC5ZvQUAGx3+8do9FphceqKgwoxSAdigBaAEpDCgQUAFAwoAB QA8EDFICrIqyo4wcHI5oQFCG3dRtjPX8a3urE2LsFqqDLcnr7Vlcdix04xQMB1oAkt1zcRjHekBH 4w1WbTrOJLV9s8zYBHXA61cFcls5GHxNqEcu97h93TnkH8Ola8ornSaf4ySQD7bDgf8APSLkfiOo qHEq50dne216m+1nSVf9k9PwqLWGWaAFFAhaBmN4mkmS2j8t5I42Yh2j69OKaAuaWsk2mQi7G9iv zBx1+tFxWM7UfCOn3RLwA20nUGPpn6VSm0JxTMC78OahZOHkgW+gU5JT72PpW3tboy9nZnM3aqju PLZDvJ2sMECkUNt7iaFdsEzID1XPWgCFhtXGMGmFhqjcQo7nFIC9FweOnakB6J4HtPJ0x7hhhpm4 +g/yaykWjo2OKkohuZPLj46mkBmOcmkMYaAGk0AMNACUCGMaYhtMBCeKQxuaQxpNADCaAGk0AOSL PLUATYxQA1mAoAaQT14HpTAQ0wGse1AEbU7EjTTegDJpUgiLSMFFJagc3c3X2maSTPyrjCmtUhPQ mMsEkeUHlkDp1ycdqyadzemkouTMlwRnJ5Jya2itDCcnJ3LcBDMnYhaZB3v0rjOgci5PJwPWgQAf hQAjOq0h2IWlJHHFAWGE+poENLUxiDLcAE0WESrbk8scCnYCQKiD5Rk0CEZuOTgUwIDJk4jUt79q ZInls3+sbPsOBQIkVQvAGBQMdigLBQAUAFABSASgAoGFAChc0AIzqg5IFICGSYk7VX8aABYifvHF FhkiIq8AAVRKH8UDExQAmeaALFjzcr7CjZAcz8QZt2pW8Q48uPP5n/61a09iGcpux1rQkVWKnKMR QInhu5IZA6O8cg/jQ4NJpFHRad4zv7bC3Srdxjv91xUOA+Y6jTPFGm6jhVm8mQ/8s5flP+FTy2Hc 2lOfpSKFIBHIqbgL0pgLQAUAUr7SrLUFIurdHP8Aexgj8aalYmxy+p+Aw2XsJgP9iT/GtFMXKcrf 6Lfac2LiB0GeDjg/Q9Kq9yWipEuMsQAVH50xFu1QsyqBkk4xUso9c0+2FnZQW4/5ZoB+NZM0LGOe egpCM66l3ufSpKKxoAaTQA00AMNACE0CGMaoQzNACE0hjc0hjWNMBqqWPFAEqxiMZNABExfdlSNp 496LADNzgcmkAgGPc0AFMBDQBGetMQw8VSEUr7UYbNfmIZ+yimkIxG+2avLkZWMdzwBT0QXLo0SN Itqud5xljRzBa7KqwI1zHCnCAlj9B/8AXqVub1HZKCKFywe5kI6ckVsjm20JbZSGibkZ44oEj0Do MniuI6BhlC9KAImlZj6UARlsUAN3E9KYhVjZ+1AEy24X75pgSAhRhRigQ13AGWOBQBF5pb/Vr+Jq hCeXk5clj6dqAHgYoELQAUAFABQMKQBQAlABQAoFAASqDmkBXkuOycmgBqwM/wAznFAE6KqdBTAe KYCbRQAEYoAAKAALQBb05f8ASPwoATWtBs9XXdMpSYDCyL1H+NNOwmji9S8HahabmhUXEQ7p1H4V spXJsYMsTxsVdCrDqCKokNo8rfvHXG3vRYBqnHQ4NAC788OPxoA1NM17UdNIFtclox/yzk5FJoad jq9N8c20uE1CFrd/76/Mv+NZuBXMdRaXlveR+ZbTJKnqpzUcthk4oGHegAoADwOBQBi6fqr3141t cQII3zt79OoNUIdc+FtKuGLG32Mf7hx+lCkLlILTwfaWt6k6ySFUbcEOKcpXQ7HSDrUAQ3Unlxkd zUjMwnmgY0mgBhNADSaAGk0ANJoERk1QhucUhjSaBiE0CHJEWOT0oAmVQo4pDGyAFSDwKAEz+7VF J2gYyepoAQAAYFACUwEoAaeKBEbHAp2EYuqaq6ExWoy2cE/4VokIr2GjvK/nXpPrtz1+tJy6Abao sahUUKB0AqQI5TtRz6A0y47mNZttS6nP8KhR+VAVH7xlxJ5sj89q2MS8wEZhHvg0FHXs7N1NcRuM J96YhpJziiwEiQs/bAoFcmWFE68mmA7djhRigBjyqn3iB7UCITK7/cG0erf4U7E3BYxnLZY+9MZI BikAtMQUAFIAoAKACgYUAJQAooAU4XrSAgkuAOF5oAiCSTHnIFOwFmOFU7c0APxmmAbRQAYxQA0k 0AGaAFHWgAJoAu6WvzufagDRx7UDDFPYRnXVrpmqu8EywyyJ1x95fxppsTOb1PwL1fT5v+2cn+NW pktHK3+l3mnvsuYHjPYkcH8atO5JU5FOwAMfSgB4dhx1FAya2upLaQSW00kEg7o2KVgudNpnjW9g wt7Gt1H/AHl4Yf41LgNM6vTPEem6jhYpxHJ/zzk+U1m42Kua+eKQxaAKltplra3DTxR4kbvnp9KL iLfSkMXvQMXp14oAzrqTfIaQFcmgCMmgBpNADSaAGk0ANY0CIyaoQwmkMACTgUATRxdzSGScDpQA 1mAFADME8n8qAA0ARTTJCN0jBRnHNNIRJjigBppDIbiVIYyzsFHvVIVzIkmn1FikGY4e7+tUtCWW rewgt8bUBYfxHk0NgWOlIYg60AMdd2QehouC0ZgX8b2UUkIXKStnd6VUVqXNplSwGWfBOOtaswJZ id4PTaRQUddyTgVxmxKluzcngUxEyxonuaQClqYiJ5lQ4zlvQcmnYCJnkfp8g/WiwgWIA5xk+ppi JAlFwsSAAVIxDTASmIKACkAUAFABQMTk0ALjHWgBkkyoPekBXLPMcL0pgTR24Xk8mgCbtTABQAHN AAKACgAoASgBKAAHJxQI0tMHyuffFAy9SGKOKAMmx0ya31Oa5kaPY2doUc81dxGpipuAkkMcyFJU V0PUMMindisc7qngqxusvaE20h7Dlfyq1MnlOP1PwzqOm5aSLfEP44+RWilcVrGSQVOOlMQmcds0 AKDz8pINAEqzMD8w3UaAbWl+JrywwiXD7B/yzk+df8RUuJVzqtN8ZQy4W7iKH+/HyPy61DiUmdHa 3dvdpvt5VkHseRWbQyDWb3+ztPe4VA7jAUE4GTTirgVtA1Ka/il+0IqyRtglTkHvTkrCTNG5kEcZ 9TUlGYx5pAMJoAaaAGE0AJQA0mgCNjTEMJpiBULH2pDLEcYUe9AD+lSMjZucDrTAQLjk8mgANADT QBUubX7RNCzEbY2zg96aYMtMaGwKV7fx2owfmc9FFNIRSW1mvHEt2SE7Rj+tUIvKiooVAFA6AUgC gQg5NAw7mkAztTAwvEEuZI4/QZrSAmRWCiO3dj1qnuSMuxiAFgeTnPpTQHcjanCiuM3At6mqsSQP cLnCAufbpRYL2Iz5kn322j0WnYV7jkjAGAMCgViQKB1pDHCkMWgAoAQ0CEpiCgAoGFABQAAetIBr yKg5OKAIGlMmQuR6YoAdHbZ5k/KmBYVQowoxQAvQ0wE4oAMUAFAB0NACkUAJigANADQRQAySVU6k UAamkNvtS3TLGhjLwNIDI1K5vpLpoLCRE8pAzFlzknoKuKJKkXiC7s3CananH/PSIfzFNxHc2rPU LS+GbaZXPp0I/CpcbBctikAoGeB1oQGfZ6pHd3ctsI3Vkzyw4bBwaq1gK2p+GdO1EEtF5Up/jj4/ Smp2JaOR1XwVfWoL2uLmMf3eGH4VamTynNywyQuUlRkYdQwwRViGAkUwuOzxyKQEkLbHyo6A0AdV 4MgkuNaikBYLCCzHPXsB+tRMtHe3ltFeW7wTLujfrzWKdiiHTtOt9MhMVupCk7mJOSabdwRDcy73 NSMrk0AMJoAaTQAwmgBCaAGMaYDPpQSSLF3NAEyqAOKQxSQBQMiJLdOB60AAAHSgANADTQAlADSw UEkgAUWAzLi/kncwWQ3N3b0q7WEyS0sEgPmyHfMerHt9KVwJzTENNAhpoGC9KQDT0NADT0poDl9S l869kI9dorZaIhl6OIraogGCxzSH0KmoMpZo1P3F6dOapCOwe6zxEpPueBXKkaNjNrSf6xifboKq wrkqJgcDFK4WHhMUrlaDulIAoAWgAoAM0AJ3piEoEFABQMAKAAsFGaAK8k5PC0gESBnOXJoAsoio MAAUwHUwDBoADSATByOmKYC0AFACEUIAJoACwA60AQyTqOnNAELOzHrgUAR7OTQBo3KTL4cYW4fe f+efXGef0poCTw19oXTj9pMmNx2+Z1202kIlsJPPgkuNuPNkYj3AOB+grRaIQrqH+VgCPQ0wOO1s rDq5jtB5ZXAOzg5p6CuegWMbxWcKSMXdUG5j1JrB7losUgM6y0qGzupJ1kdmfPDHpk809wNCkFgx TAq32l2eoJturdJPRscj6GmpMVjltS8Bocvp8+0/885P8atTE4nKahot9p7kXNu6j+8BlT+NWmiL FaAYY5FUB6R4GtRFpr3GMGVsD6D/AOvmsJMtHSZwKgsgu5PLj2/xHrSAzWNAEZNADCaAGk0AJQA0 0AIFLHimiSZIwtAEczn7iMA5Hyg9z6U7ATvhO/4UmNEZBPJ/AUhiUABoAbQAh6UAQXNzHbR7pGx6 DuaEBm7bjUmySYbft6mqvYRoQwR28YSNQo/nSGK5wKaEyM0xDTQIQ0AJnApDGmhAR3Egihdz/CCa aWoHK2q+bcqPUkmtuhDNiaTYRgcIKEMxCTLM5HJ5NMR3SpXMWSBQKVx2HikMdQAhpgFABmkAUAFA CGmIKBBigYEhaAIZLgDheaAI1SSU+gpAWI4VQZxk0wH0AJimAoFAhaACgYZoAM0ANLfhQBHLcRxk Bm69KV7AQXFxJsPkBd3Yt0piGB3ZR5h+bvincYYpALigBRQB0lku21iH+zSAlKggg9D1FMDObT57 cf6FMDGOkMo4A9j1FaKYrED3ywZF3G8DAZ+YfKfoaaYmctosTan4gjd+QZDK3061T2JR6N0rBmhj +I9bj0m2ADDz3Hyj096cY3C5w82oyXWZWuJjIT94SHj8KtKxPMbPh3xFcW08dvfymW3kO1ZD1U+5 9KJRGmdyKyGKBz6U0BiaZqE8+pywvIjxjOAo6YNW0BssgZSrAEHsRU6hYoyaFpkknmNZQ7j3AxTu xWLsEMVtCsMCBI14CjtU7jJOB8x6DmgDMuZPMcntSGVzQAwmkAwmgBpNMBKAJY4SeTwKBEgUL0po QhNAEYOH+UZb19KYxwGOep9akYhoAaaAEzQAh4FAGfeagIz5UA8yU8ACqSsBFb6ezv516d79QvYU MDQxjpSAQ0ARMeaaENpiGnigQ09KAEOaQxD92gDL1ycRWuwHlz+lXFCZmaMu+dmI6CtGSS6jLkSc 0IZnQOY3JyRlSKYj0Ada5TUdSAcKAFoGNPWmSJQAtABQAUAFABwKAI5JgvAoAhy8pwOlICaO3A5b k00BMOKYB2oATHFAC9KACgBKAEyBQAjPtGfSmBE064yvNICF5Xc4HAoAj8lT2qQH4pgGKAFoAKAF HJApjOnjG1FXpgUAOxQAtACMiupVlDKeoIyKZJXtdNtLSYzQQJHIwwSBTuFi3UjPK/F9091rtwCc hG2AegFbwViGUIwQoUnHFN7kmxpFqL3T77fkCKLzFI7EED+tJxuykegaJO1zpVrM3LNGM1jJWLL9 IYxIYo2ZkjVWbqQOtAiTFAwxQIQjAoAgvJPLjEYPPekMzSaAGE0gGE0wGE0AKqljwKALEcIXk0AS HAFAiGTIYcgKOtMCMkt04HrQIVBihjQ40hjc0ANNADJJEiQs7BQPWhIDLluZ75jFajbH/E9Vawi1 aWUdqvy/M56sepqWx2LBoAaaAGMcCqQiM0xDaGCEbrQA00hjSeKBDZHCKSSAB1otcDldVujdXOQf kHC1tFWJZb0mMpCZAOCcZpiRTuXLrKcnrtpgQREb35PCmgD0DDJ1BIrjN7D1YHpTEOFAhaAGnrQI Q0wCgBwFIAIAouFhjyBe9MCAyl2wAce1CAfHb5OX/KiwE6qFHAxTAdQAlABQAUABoAbQA1pFXqaA IJJj/APxoArxR7A2GY7iScnNAEgFIBcUALQIjCESFt5IIxt7CmMkApAFABmgB9uA1xGD/eFMDpGT eAM45zQBIBSGZniLUJtOtEe3UNI77RntwT/SqiriuS6JeyX+nxzyqFckg7ehxQ9AL9SBDdPJHbSv Cm+VUJRfU1QHkbJLJdSSXAYSEktuHOa3WxmxkrY4B5NMRpafJLZ6bcHLDzx5YHqM5/nik3qNHpWj W5tNMtYGGGSMAj3rCTuzRF2kMMUALSAWgBGYKCx6LQBkzyeY5Y0AQk0ARsaQDCaYEkcJf6UAWljC DigBTQBG7ACgRCwLct+VMBKYgHWkxoU0hjTQBUvL6K1Xk7n7KKdgKUdtNfMJbrKR9o6G7CsaSRrG oVFCqOgFIYGgBDQA00ARuaoQymIQdTSAaetADS6r1IH1oGULvVIIARu3sOwqlG4noYt7qclyCB8q +grRKxNygELsAD7VTEdNc+VYaUqhT8y4JHUsOv4YqUNHPlv9H4J5Oc1RJHCvyyHGflNAHppUHg1w nSQtAB0/SqEM+ZfvDI9RQFhwYEcGgkQ00JiYpgOAxSGBcKOuKAK8kxPC0gESFmOW4FUInSNUHAp2 EPoAWgBKACgAoGNLKo5IFAEMlwBwvJoAhaR29qAEApALigBcUwAYHSgAzQAUAJSAcKAA0AIB6UAa FnYEkSS8AcgUDsaqZXGDn60BYkVvXii4EV5ZwX0PlXMYkTOcH1pp2Cw+3gjtolihUIijAAo3Alo2 EApAeYeIpJrzxDPsQ5DbFQDrjiuiOxDLf/CP3MbKz6ZOznnAYEfnUcw0je0jw/PJcRXWpokaw/6q Bcce5qXIdjqakoWgAFAC0gBjgZoAq30uxBH3PWgDNJpAMJoAZgk4FMCxDb45agCxwOKAENAETvzh eT/KgBmPU5NACGmBGaZIUmNAzBRliAB60hmZPfyTuYbJdzd37CmIktdOSEiSU+ZKedx7fShsZbNI BKAENADTQA1jgUxERNMQ2mAjHaM4pDKF3fJCDnINXYRi3V7JIOAevWqSEVBC8p+Y/nRewrXHhI1+ TOSOKGUogrxiYDDHB7d6CdmPvftU8gWRGX+6p7CnEGSTaa6wRkAcKScHrVCK6p5UMyTRNvKjHOMc 5oEdjaazHIQs3yn1rk5Ta5qoyuMqQR7UrFClQetFwuRPb914PtQIibcn3x+IoQMNwAyKYiF5+woA YqPJ1oAnjiWP3NOwiQHmmIWgAoADQMTIoEMkmVOp5oAgadj0GBQMjIJPJzQAYxQAuKAFoASkAtAh BQMKACgYmDQId0oAeiNIwVQST2pAalnYLFhpBlvT0oKLwFAC0ALQAvI6UAKG9eKYh9AhwFAFZtPt nu1u2hUzqMB8U7hYs0ALQMKVwFFACigDnrnxIYtV+zJBuhWQRM+eQfpWihpcRvkj7x6LzWYzJuJT JISaAICaAFSNpDwKALUUKxj1NABIzD5UxuPrTSFcZEztCryLsYjkelKwDWYtwvA9aBiYA6UABoAa aAGHA71RJWnufJYAxtzyCeM0WuBREV1qTZmJhg7KOpodkM0YII7eMJEoUD86kY4mkAhoAQ0wENAD TQBG57U0IjNUIeJIrd0EsLyluflOMUwLypp18m2KVoZP7jDBoSAwdV0aa0DO0e4HoRzj607AZMNl lhvyKG7CG321CsMQ25/OhFdColq8s3lwIWJOM1SJXc3PDWlgXDSqoklUEYPRfehgXmtibudpUUso wBjj3pSfIrjtqUEnhuQtrIjR/Nw/p6VnCrzMU1Yt6npjRWOJTvw4BYccc4P610ohGIzfOqADLHAz 0rlRokaFhdSQlhG/TtnIp2G7o2LXU0fCyjYfXtUtDTRoqwYAg5BqShSoI6UCK89oGHy8GgCusAjb 94Pp6UwsT8AcdKYhpqiQoAM0AG8DqcUARPcKBheaQyFpHbvgUANxQIMEdKBiigBTQAlAC0AJSAbk DJ9etIA3Ci4xQKYC0AKT2oETW1tJM2FH1PpQFjYtrVIFwBk9zSKLAFABQAtAC0ALQAUAAyOlADw/ rRcQ8HigBaYEN5OLW1lnIJEaliB9KFqIxND1m6vbsw3KxgMm9Nh6DOMGrkkgOgFQMcKAMebw9aSa l9ty4bdvKA8E1XNpYmxd1Cby4wgPJ61BRl5JNMCaK3LctwKALSqEGAKBCE8UDIJ0VsFiRjpg4zQg EkYyHLdPSgBOlACGgAoANrH7q5NAEyWaIQ8p3MPyFMRT1ZkuYvKjAZ1OQf7tNOwiKCPyYVQnOO9S xoeTSGIaAG0AIaYCGgBpNAETHmqEMNMRdvoR9mt5lHsT9R/9amMz5FDYyOlIRYt9RmtUMb5mibr/ AHsf1ppgQz28V9ltPIzjLL3+lOwjnZIjFqojmBB6c07A3oXkI0+wllC5eSQgD2qoK5Kub3hdDFpf nyDBfJz7Coe5b0HwKJJ3f7wK7jj3qnFSVmLqc9egNev5Y3bQMj2rlnT9mrou6ZsmU3Gj7GbJQhWJ 7gNXTTd0ZtWZy8kYcbWrFFPQltAI3CjgHimhC3pm3RpEdu49aZUS7YvqFn9yQSr/AHDSdijbtNSi mby5AYpf7jcVNgLwoAYxRm2ZG70pWAheAg/Idvt2poLERJU4YYNUTYY0qqOtMRC05P3RigRHuJ6n NACDigYmZPM/h2Y/GkA8DFAx1AB0oAQ+lAC0ANOBzSAYzZ6UhkZbkqwNTcLEiK2PlUD60rvoA8Kw 5LZp3YCM+OgqgLtjZyT4ZxtT+dAjZiiWNAqjAoKH4oAWgAoAKAFoAWgAFAC0AFIBRx0piFDHvQAr BZFZGAZSMEHvQtBFLT9Hs9OdntoyrNxknPHpVt3AvipGOFADSwXLHgLzQBkTM1xMSOlAE0NuEwT1 oAm6UANoAikkAOByaAIu+ScmgBCcUALQAhoAnht93zPwv86AHyXUUA2py3oKAKM88kxwx2r6CmIi ACjAGBTELUlISgBKAEpAIaYDScHFADGPpTSERmqENNAGrCBcaPInVo+R+HNMLGOeelIB8xhswomV pZn6RJ/WqsItJFHBCJ5LUxSdhFlm/GgCC5t7fW496ZS4jxhmGGH1FNMGUNcgK2drDt+csen1qouy LhY2r0jTtESMcEJj9KnqJ6lTw7dr9hEb/wCuAOPUjrVX1M+pj31tOl5Nc24LIcsCOxz0NOrFSVgT adzK/tW8MDxheJH+mTSjBJDbdyx3rnsUKpwwIPQ00Jl1kVmVj/C2abHE3YY0RRtH41JQk9tFOuJF B9D3FAFdWu7D7hNxCP4SfmFAGhbXcM4DL8rHswwaLBcsYBqRiNGrDBGaYFSewzzHx7UkxNFJ42jO GBFWmTYbTAAKADvQAvegBQaQC5oGFADSfSkAzBzzSGGMcCgCtqDTrEPswBmzwD3FOMUK4mmPeOpN 2gXHQY5qmkthXL+0sQAOT2qSjRsdMAxJOMnsvpSA1AAOgxQA6gYtABQAUAFAC0AFAC0AFABQAtAC 0AJt5yOD7UAKGI4I/GgQ4MD0oAHcIpY9BVAQXWXRY1OFPJNIBiRrGMAUALQA08UAQPLnhPzoAYBi gBOlABGRuIYZ44oAVuKAIGvYIJApPmSnpGvJp2AkaaSRfnOz/ZB6UgI8ADgYoAaeKYhpoAWkNDTS AKAEoAQ0wIm600IaaYhppgNoA0NGmCztE33XFMCK1tdl+8bDiIk/4f0pgM/tCGKG6uYogTH8u89X f0+goEZKC4bMr3UyyNydrYAoAvWd4wmVbpg3ZZ8YZfr6ikM1LuwW4uIGYfdbdTuHoZfi24yFgU8n C/n1phsZD3JsXjkTqnOD9MVMZajUNLmrNfqBApcB5wD5YAJ59+1atEHPalcR3d5JHEABEuAV6H1N FhX1sSSQ5U7Tg1gURRs4RImiC7c5YdWoKbRoROCqnsRQSa2ny7oME8pwaksneZVHXNAEDTsxG3ih AVrlCDy/lnrmtEiLhba6kJVG3yAcFsVLgykzatryG4XMbg+1S1YpalipAbJEsgwwBoAoz6eRkxn8 KaYmimylDhhg1VxWG0xCE9hQA1w3ylTgg9KAJM0AJu9elSxgHBHy9KBid+KQiRRigBAqlt2Bn1oS AlhiaRwqDJNMLGvZ2KwDLfM/qe1IZbAoAXFAxcUAGKAFxQAmKAFoAKAFxQAUAFAAKAFoAWgAFAAe KAGNHvwQSrDuKBDxEdo81wcc9MUwIFYHODxnFAgNAxrsFGTxQBXdi/XgenrQAlAhKBiGgAHFADZF 3oVJIyMcHFAEEFrDbKVhjCZ6nufqaAJaAENAEbdaYhtADu1IYlIBDQA00wGsaAIzVEjTQA00wENA BHIY5FdeqnNAHRQCKb/SAPnkTB/CqA5e98uKyjiLKB9pctz6UWEVJL62jHzTIPxpWC5VfVrfogkk P+ytNRYXOq8P37Xth5kkbR+VlRv6mi1hpnE65qVxcamzKCiKx2tt7etaNaCWrKyQS3t0sUs0hyQM 1MEtzWzUWzYt7CDTATlpJXXGW6qD/jT32OZ3tczoUCzx7QMMSp/GmtVoXUXK0y6DXOMXjoaAJEwq gKMCmBPbyFJRg8PwaRSZd5pDJIVy4FCEVdUYGcL2UVtFEEcFi0q5wACaG7DQksBtfmRyrg8YNRuV saNhqsmwCddw/vCpcQUjWilSVQyMCPapKJBSAilgSQYK5oAz7jT3X5o+R6VSYrFQqVJBGDTExBx1 NAhGb34oAZkEe1IY5R2UYFAEiqF6UWAdnHWgCxa2rzn5Rhe5oA2be3SBcKPxoGS0gFoAUUDFoAKA KQ1W0MyxCXLFtgIHGaALooAWgQUDCgAoEFABQAtAwoAWgBQpNAhzMsK5NMCk05mY4PAppCEi4LD3 zQCCSQLwOW9KQyE5JyxyaAA0wG0gA0AJQAlACUANNAAaAGmkBG3WqEJQAopDQGkA00ANJpgMNMQw 0xDTQAhpgNNADepxQIt6lpsU2o2kM00yo8eCEfABAq07IDM1HwzDDHcmJWJjYFC5zlSO9NSYWM1d LZf40H+6gqeZgOGnKxw0sjewOKTY7HVJANP0FIoxguMD1yaaDYydX0tJ5kYyCKNUAPGSfpVxJemp SWS1tdTiXG2OJCPmHJJ7020mWrysV79nntmud2AsgbjuM9KlqzIm1J2XQoF9rFh0B3D8KulsPEfZ LoNcwDs0CHqeKAHqeOPwpjRpxHeisO4qSyzbgbs00JmVcuHuGZuV3VqQTSakyBltrcBMd+5otcDN 82aR2kmOSew7UKI7l61bEIyeakRYDvGwaNip9qVh3saNtqYICzjaf7w6VLiUpGirBlBUgjtipKGy zRxbfMYAk4A9aAGzWscw+Yc+tAjNudPkj5T5hTCxSKEE5pCGZAOTn6UwJVzt9KYhwUsRgnPpQxml Z6ezYeYYH92kBpxxrGoVRgUhj6YC4oAWgAoAKAEJosByDr5XmBQAYpt2ccjmsOZpmqSaOugfzYUc dGANbdDNolxQISgAoAKAAUALQAUAFAD0jJ68CgAllWIYHWnYChO7SA460xD1CohbaFZscDtQIhO/ eSDtBoGIBikMKAENAhKBiZoASgBM0AIaAEoAQ0ANoAY1MQ2mAo6VIxDQAhNADCaAGmqEMNACUCGm gBpoAdCMzIP9ofzpiL/iMNHqcDDgiPI/Sq6AWoJheopyMMpR19D2NCAxr02lnO0U8FwNvRoxkEUM Ylhf2st0kFrZSkscGSXsKQG7qCbnjjH3Y1LH+lUhM5TxTfSwSxJbzbML82096ta6Ca0OdWczXG5s s545pqNtylPkjY1bxgmmtGvAd1C/h3qE7szS0bM4HcrA9jn+hq72lZF1VeCZeFcwEgRiu4KSB1NO whAcGkA8NihjRo2LgqV9ORSZaJpJhGjeuKqKJkZYGetakE0RAJWmBAyHfipbsBbjXYoqBj80AKDT AmguJLc5jbA7qelJoaZqW1/DNhZAEftnpUONik7l4VIxCVzt70xle4so5geMH1oEzNmsnhOcZHqK YrDYoWlbagyadwsa9pYJD8zfM/8AKkNIuAUALQAUAFAC0AFABQAuKAKMmi280sjlnAkOWWs3HUtM uogijWNBhVGAKskdQIWgBKACgAx6UALigBQKAJEQDlqdgIprjA2pRYCq2ScnmmIbnHSkAhPrTGJS AQ0AJQAhoAaaBCUDEoASgBKAEoASgBDQAxqYhhpgL2qQQhNAxpNADTTEQzTLFt3nG44FMBxNAhpo AaaAGmgBY22yofQigDR8SvvubZ/+mRFW9gMuyupbW78wZ8sYG31FJAaurxpd2y3EWNyjP1X1qriK nh1RLfuQPljHX1NJxsgual3NtS9lH8C7RTKS1seeXG64meSQ57k1tK0ELfYjtVEW526k8AduKmT9 0ziueVi0DC4Mn2mTKDMasmBUU7JlTVtCqzjarjHzZziiek7mkVz0mjRtoWmlCKOTWaRB1un2aQQh cDpzV2EU7/SIpSzwfI3p2NHKBhSxPA5WRSpFZtWAltJCkynt0NJlonu3+U47mriiWVgcCrJHBsNQ BONphyqdepNKQD+wrIYVQCg0ALmgCa2ge4favTuewobsCRtxRG3VUTcw7kmo3NCYYJ5GDSAdQAw/ Pwoz70ASRQrEPlAB70wJKAFoAKAFoAKACgAxQAooAWkMUHFACUCCgBaACgAoAKBjlUk0AP8AljXJ NAivLMWOB0qgIDQA1m9KBDRxQAUDCkA2gAzQAwmgBKAEoAKAEoAQ0AJQAlADaAGNTENNMQlSMQmg Y0mmIQ0ARSRqzKx6qcimIWgBtACGgBpoAaaAL+oN9psLeYdYztb2zVAZu3ueBUgaGlyhw1u/Cn7p 9DVRYi7oGnGxludxyCePpVSdxoztauvK0pwD80rk/hmqW5VzlZRthWNcAtgmk9WKNr26IjWBzKkb Ak46D60qkktx07ps1GsJFjXEbEAdDxiudYikuonBtjo9PIQKYkBbgEkfKfWl9apSfxAoNaGvoun+ Um9x85/SuhIRrsdo2jrVklO9vYrGHzZjhc4pgV72CO/sxIvBxlTjnFSxmXJYvColibzI8ZOO1Z2A huCQqgHirQmRBsimIJDgfWgDQsV32xB60MBF5QVkygNMQmaSAVQTUynYaRNBdCCTajDf6ZrO5drG haam7HE0YXnqpp8wGyPL8oMSCCOKsZCqM5OchOw70MRMoAGAKQC0wCgBaACgBaACkAtABQACgBaA CgAoABQAtABQAtADkTdz0oAc8ixDjrQBUdy556UwIycUwGEk/SgAoASgAoAQ0gEoAaTigBpNACUA JQAUAIaAEoASgBKAGmgBjGmIbQAUANJoAYaAEpgIaQCEUAIaBDTQA2mAhFAE1vOIQyS8xPww/rQm AksSKY8NlG6OOlOwDZ455IxHZAh8j5ulEdwZ0NkzrbSGVlZwuCRVPcEcVq12J1Ea/wDLMc59f8iq WoSRAlruEcmTk8/SmiI3Ssx7w7FDqdrj+IdTWU4pra5cZvqasAX7MwllaTeM9M4ryZ4epzXjGxup KxTuY4wqv5kuR7VrGjUS2FzI6tQIlr1TEj3BifWnYkintorlQsyB1Bzg0ALJtjjwB9FFJjMe7ilg RiGwrfw+lTe4zKkLFsDoBVEgvSgAY549KBFzT5RuKnvzQwJQcOw96yZQ1qBAoBb+lRKVikPJIICp x6k1l6jHJEu8sFGT1NAy7bW7SHCj6mmkBsW9v5SAE7sVoBNimMCBSECqQeuRTAdQAUAKKAFAxSAK ACgAoAWgAoAKAFxQAUAGKAFAoGSJHjk0CGyzBeFpgVWYk80wGE4oAb3pAJQAUAJQAlACZoAQ0AMJ oATNACZxQAUAIaAEoAQ0AIaAENADSaAGnrTENoAaaAENADKACgBM0AITQAhoENoATvQA9EyeTSAi eWKFl+0OEDdCe9VYBt7DMVD6dLsfqQDwffFCdtwsAiv2tmE14wODwgAoTVx2NDw9Kf7BLNnPOc96 vcFucbMxaQnnBfGaT03dhyN62VokgikhXHA3Y9q8ipUd3yyNeVCXfmoHCwIEHQ0Um207sc0loSwO qoAeOK9iGiscrWpBfSRmM/OBketU9hpHSu25vagCIo28lcAEcnvTEOJwAq8mkOw5I8HLHLfyqdxm dq3KBR0HNFrCOc+Y5POKoRIo4oAYwIegTH2z7JQelNjLhOJD7isZDFJqREUih8HkEdCOtVZDHQyy IwV/mX+8OtZuI0zcsrFpQGYbV/nUqNijXiiWJQqjFWgHUAFMBaACgBcUDFxSAXFABQAlAhaYBQAY oAMUAFAxaQBQBHc3EdrGHlYKuQMmgCzGU8sOGBBGQadhEMk+44XpQBCaYDCaAGnigAzSASgAoAaa AEoASgBrUANNACdqAEoAKACgBKAG0AIaAENADelADSaYhtAAaAGmgBKAGmgBKAExQA2gAPpQA7bt xxyaQE0UHdqAG3VvDMF85VKqcjNF7AVH1O3ibZAjSsOMIOPzoDYkjuLiQ4+zFWP3UYjJ+vpVJCub BhEVjLEoAOzoPXFUgOKewSOBJVJLs3T1pN2LhFtm5Ep2KCTnHrSVKPYltkdwAiE+gpqlFbCu2Y7L FKFMjusp578+woWrEyCS081gC5Vc5zjOK1TsSd5SKGFixwn50APVdo46+tKwDs4BpgZt4jzbwi5P QUMSIBpUSRKZJCMDL4oYypcxWxjLW+4FTznvSuFio65GaZLINwWQA+tMC+/BX8qykhiGoGOiieZw sakk9hTCxu2GjrGA83LenpSuUka6qFGAMCkUBoAQHNMBcUAGKAFApAKBQAuKACgBaAExQAYoAWgA pgFIAxQAtADlQk0wCZI2iZJACGGMUCZS/wBVCIkyFXgUCLLRxxR/J1NMCBjn6UAMJoGN70ALQAhp AIaAENACUAJQA00ANNACGgBKAA0AIaAEzQAhoAaTQA2mA1jgcnihCIoZknTfG25exFAElACGgBpo ASgBKAEoAaeO+KEAYzQAhByAtADnuIo5EillCzNwoNPlAjm1ICYwWyGeXocHCg/WpAjS2uZJN97K NvaNOn4mok4x3Y1ctLHFH/qUUe+OlWmraaidy3aqkKtPJwqDOT3qlfqPQTSZnnaZpT/rDuA9BViM G8RUn+zH5WSbHHXB6VLRrB2VxXS8hb/Wgxn+LbyKOaxDs9iNt8hkU3DOgX76rwDTTE10HAQWkaMG Jlxxk5JqJSS2FysqyyNIzMmFXOSax9o5MvlVjrAWl5+6v867DIsRQlh8o4FMBkxxwv50hlXDCQbi dueRSQDzNHu25xVXFYrajvNviPJ55x6UmrjRz1/eI37tVeORcDA6GoSYNoI5cgVpYgjlHz57UwL+ 7fAjemKzkhlqzsJbthtGF7sazehSR0VnZRWqYQc9zUlpFoUDFoEFACY5pgLQAUAKBSCwtAWCgLBQ AtAB9KAAUAFABTAWkAUAPRM9aACWQIMCmBDGjy/OcBe1AiNxtemAjMe9ADCaAGmgQnSgYmaQBmgB tABQAmaAEPSgBnc0AJQAlABQAhNADaAEJoATNADWNMBKAI5VEkbIejAg0IQ2GJYYkjToowKAsSUA JQA00hiGmIKAsNpARywhyCc8U0wJowCpUL9KAGyExAJHwxIGcZo2AoazFDNcRxrCJLlh1z90etK7 YGha2kNoo2qAx79zTswEnyflDNGSchuo/GvPxFOfNfoaxkiL7RJArecm4D+JRUx54aop2Y6W5+37 IIuIl5f3PpXdTqOS1MmrFqA+TcIw4HStkSVNftgt9b3K8ByAxqkUtFYZeOYrc4I3N8oJ96jqLYzL idbGMpbuDuGCv9acuxaZXsYvNRZH3NKTxxwPaolHQbbuX54jFBHEY1BJzuBrNKMUFmzpE+6K6zEn gJCnmmJCSffP1qRlZ6BlS4A20AOQ/uhVEnL6jzfTE+tIQyKqAkk7UCL1jzEAeeaiRaOwtQFhUAAD HasWWTikMKACgBaACgQlADhQMWgAoAKQAKYC0AFABQAtABQAlMB6daQEj8IaAKb96Yia1P8AolMC F/vGgQxqQyOmAjUEjaBgelIYUAJQAlACUAIelIBgoAKYgNIYhoAYaYhKAEoAQ0AMP3qACgBDTEFA wNADTQISkBBAT5kv1H8qYyWkAncUADUATLwq44pgS9hSAoQf8hO7PcKoB9KroIsAnzE9wc0wGXnC VLGiKMncvuOahlCaWoETYAHzH+dNCLh6GqER+If+QTnuMYNaw3Ezm7l2Z03MT8w6mpe5SI70ANgD t/Soe4xulkmMAnjFPoORuyqGcBgD8o61Mgif/9k /9j/4AAQSkZJRgABAAEAtAC0AAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/APPY4Aox1qCh4QDjbUgKIw3TjFMC0NO86AyRp064YZGPbrRcqxWktRFG5xk9 s1VybWKe3JwKexI5hmPBqRka1Qh1ADSvNAEpdUTJGTStcYguDnCpRYLitNIONoHtQkFyWCTzAcjk VLVhomUE9BSGKaAHmJjF5gBKjgn0NMLEtgiSXSRyNtST5GPoDQkBQu7Q2ty8TfwnFWrkmvqUJutC sbhUG6MmE7Rye4z+f6UW7gM0CxuftLL5EgjkUqx28DIoaGXdK0lrOd5L3y0/uhmFS2VHQ3GvbSzC 77hSGGRt5/kKkHIhbXbYIzJ26AjG76UxcxCfE0eMC0LEdy4FOzFzCDxS/aziA9SxNHKw5iFvE92c 7YbdR/uk/wBaOUOYrnxDesT/AKkf8A/+vS5bDUmXpZ9SSEuZdpAz/qxgVKWpbTSuZD6teN96Ue42 D/Cr5DJyK0l5NIoDlSB22L/hVcoXEjuZYwwRgoYYOEHI/KiwXLWmRGeVzlV8sBuFUd/pUSlymlOK YmqRNBcLuZGMi784U/0qkyZaMgaaR1UMQQo4BReP0pkDRPIkbIpUK3UbF5/SgLj7O4eOberLG6qS rBFHP5UBcjMz7t3yZ6/cX/CiwXJJr+5nffLIHbAGSi9AMDtS5QuBv7kxCIyDy1JYLtXAPHPT2o5R 3Gre3CBgjhQww2FHI/KiwXES7njcPHJtccgqoGP0osIRrqYksZDk85wKdguDXty/LTuSBgZ9KXKA jX1yyKhnk2g5AzwKLAJ9ruQMCeQA+jU+VAM+1XAORPJn/eNHKgE+1T/895P++zSsAn2qcHPnSf8A fRo5QLB1C4J+8B+dHKAh1C5/56GlygA1S7XpKRRygB1S7bgv/OjlAY+p3AGC2fxNHKMnE8xQOwB4 Bxn16Ur6l8rtchlugW5iUEcdj/SqIuyMSoesaf8AfIoC45DbNIokSNUJ+Y7TwPwoYy5bi3hkZIfL WNjlWcsM/wCFZvU0StqaEdusmMPEw9UlB/SlyiuLNaGNiAkhQHhwmQaXKh3KrBc43DPoeP51PKik ytNE/wB0DILA8Ux3GXK8p2IoW4dDGnOZWPvW6Rg9xlMQZAFABuAFACgjHFIBpb0pgD/doER9qYC9 FpAPUcUAXLOMNG5NZy3KQ8SD0NMLj43G4ZU49qVih8h2nIyFNAPQPNwo2Eg4wcHrRYVyK4b93ndk ntTQMpo2DmtGQPdvlzUoZACV6U7CHA0gFJ4pgCYY4J9qNhouW1vgDaPm/lUNlWG3cXzBhwehppiZ LDb7IPM298H2NDGTW67pBj1qUFjQvtJMcyrbbpVcBlKr1zQkMs2VjLFaT294VgjcAqZCB8w6f1pi K8VnYwOplunkI7RJj9TTWgjSlvtMlme5ksRI7dpHySfwGKpNoQv9rosYjgjSMDoERVAP5H+dF2w2 M66vri4kO+RmGOjOSP54oaEUy7HknH0FFgGkc55pgAAO4sW9AAOKAGEYp6iFyQaQxSPwoAYRgnji hhqXJNTkeIIwyQMZ3H+VZ8mu5p7TSxRJBrQzEGKAFHOBSAmjMsDBlypI7jqKTVyotxGuWdtzAZ9h imotClIQgjtTEGxipYKdo6nHAoejCwzGCMUANAZmwBQInezcKcHMgOCoHTjPX/PUU7DJJtPaCeaG R8NGwXOMgmiwrkN1aT2jATRshYZX0P0oaC5GF+XOeakdi6bFRACGLOR2PsD/AFFZqWprKCSM81oY gkbSOqoMkmgZMscQlWJmZmLYITjHrTEOt7L7XDJJbsVEYy2/oPQZ9adrgU2DAlSCrjqPSpGBpgOo ADSAaeKADPpzQAFQR0oAN7Bdo4FFiuZjQKCLigUxiFSSSKTGnYne5ZlA/iGPpxUKOpo56WI8nOSc n1qjMliuZov9XLIh/wBliKLIRZTV7oDEjJMPSVQaXKVdk8Oq24DB7Xyi6lS8Rzj6A1PK0PmFVUmx 9nu0kP8Acm+U/rRYdypc6a6kmaxlXP8AEgOP61SYmQz6QY40cS7fMGQrjBFHMKxXk02VYgQDIf8A Y5p3CxQdWT5SMY9aYmLk/gKBDQTnkUxgTkEUCEP3aAFHOBSAmy20DPFAFyxIEezuOTWci0Mj+Vhm mxIuKwU0i9h01350JjYZx09qSQmyBYd7qgIXIzk8CquKxBKvGMZz0poRUGfxqyCQRSnBEbEVNyrA LSf/AJ5mjmCwjQSp96Mj8KdwsJ5bbc9KBCQglwOnekxo1YeoI5qGUi3JYsxUKu8ONykdx/Si1h2L +kWRt3k+1IpidSpUnv2P4Va0ExB9ks5CsUSykcbmOR+VJE3HXGr3MkaohCInQLx/KnYRnF3d8sef WqsAn160AXLOxe7JWLGaWxcY3IruBrZ9rjacZBHShO4pR5SEYUqSaZI1sZ46UAOUg0ANYnPTpQBa s4omtrqRk82ZEBjjzjccgH8hzTTAhuokjnUABQVDMoOdp9KVwJruKPfdBECwx48mTP8ArP8APX2o uBXUf6KTGqtPvHDf3ec/0pANmRBd7YjlN3H5UwJri0MVukm4HeOnpQBDZQ+c4TOMnH6UgEuIvKnK HsSKANLSlhN1GdSWRoWUhSO/pj2zQnYbL+kmwS4mTUonC+WcCFASp7Vak0JlO4WOS2haOLbhTuYk cnPFTdtgZZilMcrKDsU/NjoOaT3GQrTJJoWSJC5K5J27SOcdyPegBIlVpVEEkuwcuTxigC5rzY1a 4YOzW7y5+U9fpQBYln/tPRGUlibM/Ju6kY4/kR+VUZy0Zhj9Kk0HmaQoE3cD061PKW5XIiKoknhg eSMrGU3vkfM2CAKAG/blUpIyAzICvyjAx6+55ouBZ1SaGK1gsLbqxEs+Pm+YjgZ9gaLgVrtVZY5V bcxJRiFxnHQ/lTsIrEUhjttAClTSAqSElyDxigBFOCCKYE0pwh+bbxQBbtrSN7EyfaE3bS2GP3QO 34/4UrjKwjjaeENcKofrjPyfXiqbEkT3kMUUqhZkCuMnAOEHr0qUwYmlRRSrL5lwIz0APp3NEnYa I7aB7mdYYRudzhfejoInvNPuLIos6bd/C+9OwFaRWjYq3DDqKQBAw8wCQfLUyvbQuO4+ZkyNvBwP z70K4Mj3UyByXMsfCSOo9AeKLDLC3Uk6CJznGSD3/OoLSBGZJAAWBAyDRYbViV1WX/XRrJ7ng/nT vYkiaxhYfuhz/dJxRcCtIltE22SKRWHrRqGgeZZ+jfitHvBoNH2LOQxz9KNRaCj7IOjj6kUaj0AR 25PEoo1DQkht/Ll3A9aljRCAB3qySTIPakMRnA4GBQAmDjlqAI2bn1p2EJcqqzAgYGAeKaYrE/29 h91B+NTylXGG8nboQPoKOVILjTJM/VmP40WQD4bYygjJDduaLhyklhpkryMXQqo/iPA/+vV3Jsbd vp0NugkmYKByS3A/LrU2HzWFub2LbEtsXwjbueFb8KpIlu5qWURvrJppZUUKCSGwBx2A/wA9al6G ySRkTxxrOQg2jAOPSqjsROKTuMKZBqjMhYbO1Ax7W5EHnqQyAgNjsaANDw7q/wDZl2Jdo45GRn16 /nUtsuLRHrV8l9dtIoAyS3AwMn0HpxUxT6jm09jOGM88VZkOZccigBq4HWgY5jxQBLp9qlzM4kfy 0RGkZsZ4AycCmgImiTZFLEWMcgO0sMHjrQBNNaxpK8MbM8kcQlZgPl5AOB+dICxbWEEtg9xLMEaN gAg6tTArX1r9kvEj6EHnP0oAuXwzplufqOTULcbKOlD/AEhP94fypvYEGojF4/8AvGhbCId8jnAY naMDnoKLALiX1P507AJtkHX+dFgGfMCQc9PWlYBMc09gaL6w4sLWeEqkhd0diOB0IyayT98belim 8bSXD+ZPFkYyc8HitWtSSLyMhAsiszHGM9KAubOnyTw2t5HOcIIeCMY4B4zQZy1MPHAoNWLjFIBO lAErRxPFG00vlpyOFyc5/wDr0wKSxu3KqSOgwKdgJrRns7uN3UKT/fB4B70WBl29dWgiAYHLFgMY 4Axn9KAKB5apAfjFACqxRgwOCOQaAK8ke9iw4NMASHn5sUAPdAw56UgGJAF7kj0oAHhVjk5BoAUR KBxQAwQIDnmgCRSUIZCVI6EHBFABJJJJjzJGfHTcxNADMUAGKADGKBjDTEIaABSUYMpwaVhp2HGQ 5znB9qLA5FiG8xxIPxFJoLl1SGUFSCPaosUO2q67JFDr6HtSuBQudM6tbkn/AGT1/wDr1aYmjNZC hKsMEdqolobmgBUwXX0zQBoNeKpKjnjgis+XUtSKgarJJUy3tSYxTtBzj60gCQk4PQe1NCI6YEzb ZQpA5Awal6FIFiPZaVyrD1halcfKW4NOeUbiQsY6s3AqkgsjTt7KK3TecIo58yT+g/xoaI5iK51N FJFshLd5JOSfoO1URcz5ZnlbLsWPqaoQsZ9aYMtxTSRKVRyqnn2pNFXYvIbJJJPUnqaa0RLu2SBu BQAhA5BFAFm0MYDxMMJKNuT2PrSGUJ4jE7LyMGgCMZNACqPagRICMdeaAG7RQA3BB5oGPjLxMGQ7 WHcUANklkkxvOdowoAwAPpSAUSuE2F22njGe1AFiG4KJt6D2oAhnkDyIwycHvTAmluTJaxwlANpz n1pWGVrKQwvuABwQcGmIddv5s3mEAFj0FJKwEUZVXJJA5piNManAAB5ER/GpsyrjZtSieFkEMSlh jI7UWAzjtMhIOeKoQEcigC3pt1DGJLS7z9mmxkj+Bh0P09aynH7SAW+03yEVVjDAAFp0bcpz6VpB 8yuJtIWDTmErx+WrrnaZHBUIashzS2I724igtRZ2zZHWZweGPtU3FFNu5QxQahigBCKAHRzbFZWU GPP4g+tAGlYszXAmWJQjkqPKO1l+vNMCuQkfmm7KKsg/1acvkHI+lFxFGedpJGkfgngAfwj0pMY0 daLAPPSgBMFjgAn2FJgBAycHIoATvTAUCkAlAABmgBKAExQAjYPSgBnegByjmgBCfSgBtADTTAQj FIBCaaAbjIoAGK5GKAHwztC3DcelS0Ui8bjCBgwzjOPxqLFuyRagYyIGIxQ0SE9rFcjEi4bswHNN OwjFvbCS2PIyp6MOhq0KxBblY5VLHgdaGgQ99pldkORSQDkQdz+AoAk34HHApDI2kzwOFpiAk/hQ AhPPWmA+1bE2PXipkOJpQQvM+yNSx9AKhRNeY1rLTdx4AkcHn+4v49/wquWxLmSzTRQOVjxPOOM9 FX/PtTuQryMq8adpD9oPzdRg8Y9qpailGxVpiFxigQq8EUwLEZ4wcUATK2R0oAUkjvQA0yqo+Ygf WkAjXMePvD8KAGCQEbjkg98UWGG7HIU/TaaLAG4kH5G/75NOwgG7/nnJ/wB80coDwHzjyZPyo5Qu IY5G/wCWL/p/jRyhccIZ+0Jx7kU+RhzCGCckZjCj/epOLW4XEa3mDFQEOO+aQw8ibHRB+JoAGt5S MHZ+ZoAZ9lf1T9aAD7I395PyoAPsrDkOv/fNAB9nfu4/75oEO+z/ALvO8bs+goGN8kj/AJaH8hQA 0qY+Scr6+lAC4OGOCQoycUAJJGolJBzjoaAFSSSHIikeMH+6cCjyRLimLNPNNnzZpJM9QzUrC5Ik JUYxjimUtA7UDENACUAMYAtjoaAEYovFFgGhlzxwaAFwMjNIB47Y9aT0Kik2aFzp4iiUKwdyOx/z 61EZXdjWVNRVzPxWpgAGKQAOtAASB3oAaSPWgA3KO9ADSw9RQMQtjuKBDd4HcUAIWX+8KAE8xR/E KAG+Yv8AeFADt6noRQA0svrQMCRQIVY2cZRCR7CgBroyjkYpgRYoAQ0BccjshBUkY5FKwGzY3SXC 7Tw46j1qGhplwLSGDIGUqyhlPUGgDH1DSTFmWDJTqR3WrUgaKDYByoIz607AtBgLD6UEijnjcB9a AAMBxyaAJCy4HqKQxvFNIRc0/T2nbzJG8uFTy5/kPU0wOqtokWE7/wBxbAcgnDOPVj/SpbKuZ2oa pvZo7MGKEjBIPLD+g9qEiGVbG8+yyBmTcucnHWnYtTsLfXQu5fMVSoyTz15pRhyhOdyBVB61RAba ADFAEkbbaAJQ2DQA522oW9BTAcAlvGXlIz3NK9gIf7UtR/Ef++aLgH9rwABcsQDkcUXKHHXYB0Rz xjmtfaaGThZjTr0eSREee3FSqjQ3C43+3wPuxN+dV7Vi9mhp8QNnIh5HQ7qXtWPkQw69JjAhGB70 vaMORCHXpz0jQe2aXtGHIhja1O3VEpOTluNRS2GHV7j0T8qkoadVufVR/wABoAadTuj/ABD/AL5o AQ6hdH/lp+lADTfXJ/5aNRYBPtdwf+WrfnRYBpuZ/wDno/50AS2lxL9pjBdiCcHJpgarlnl8tDtw Mk0ALLHsjyWzn160CGduKBkbK2Rt7kAc0AJNlMhg27p1wB/n+lNCJHEZuGRYvl6Axkn1/wAR+QoC wXEPlHCuJEP8Q7H0/wA+lDQJkWMCkMbHGsjEOxHIAxUtmc5co2MfLimi07q4CLzJVXdtBOMnoKYF wxRW880AZWZeAyjI545z9azqNpqxpCKkSyW8N0r+SC8SKC0hGCCe365/CtU7rUzktbIydpjlMTn7 p9aloCaIZkUUxk0ruVCl2wO2anlsU5XViLGBTJAGIFvN+6F+p/CmAl5AFtY5FgKK+CrYI9cjPemA yyigZgJ42ZcZyO2Kh3AdcW1rLeJDbDCgZZs5zSTaGSGzgH8ApczERN5UUwiSLDZwSR0p2YGhdNpZ 8pLe3kwigTPJ97IPJGDincBI57NJy8mnx7JFIUDOB7iquSIxsJVdEtlRwCWJU4X9adwKdnbxSTNG 0SkKpO4Drms5NoomlS1hZYzCpY9ABUJtgOEFq6FhGgOPyo1QxkawFSGjwP8Ad5oN41LRsWprCOCN JPK3owzuBH+FWjB7jYZIo2zH50R9VYUmIi1m6M0KKXDnP3tm1vxqkwMccUwENACCmA5GZHDIcMKG rgbtldLcRAnhh1FZtWKRZVlJ4IpDJMZFAGXqOl5zJAOe6j+lUmJowN7YxVkhk9KAAE0ASLkikCNK ysVCrNcA7TyqDq3+A96LlWN2GIRp9oudqBR8qY4Uew9akVzOvr6S7bGSsQPyrn9T71SRJVxTABg0 AAYZ2qMnsBTSb2C6Li6ffHj7K6/7wx/OtVRbM3UUdx0mn3kSBpbdwp6EDP8AKh0ZIFUTIzEwQOV+ QnAbtn0+tZyjylp3QyJ42JBBqSiQHk4FAhJDmJx0JBoANU+awJHsaAMSMBuDSAkWFT1zQBbhs4WV s5z9aXoUlcie3jB4B/OmK5H5SelAhPLT0oAAqjsKYCED0FABgUAKAPSgYcY96AEPWgQlACUgCmA0 0DFtT/pEf+8KANuaNiSyNtJGD70AMS3bBZmXgHjNAiXb8oNAx1tbm5MyglSsZIOOM+lNIVx9v5Z2 xXyFoolOxo+gzz2p2sFxLie1tcNp5YS55bsAMHoff+VK4hLaF5YZjMwVWG8bjycnGQPr9KdhlQcq M9e9SMiZG3EqcUhNXHIpVcd6Y7EkLtHHMRCkisCpLD7vuKTYWEijRhtDnOAxxWMm76nRGKtoNDJu yC7Kwy6px+dUrsznZDb0N9ojyDuKg8g1qjIWFcyjFA0SyDmkBERQBGIXnuUiiUs7cAD60Aal0ptj aWdwxltoSdyn7oc9cfTj9al+QBqEUdjbvLCQhYEAYznI7VMZO+oFLT7Vhs+Vg787sHgUSYzTOnRF cSbic5yDjFRdgZ11p0ySvOJAQDnJJJrVTEKNNugJMSoC/X370udBYDpt03l5mB2dOT8v0o9ogsH9 m3W6Q+evzjB6801PsFi1ptg0afLl36Eg5AqXdgNvNJnacyrsAIxh2xiqjotQK8Zi039zI+585Zk5 AqZJvYaJ2aOZBJGwYd8VFmDH2d55BMUo3wN1X096tOwmF7aiBwyHdE/KtVNAZmofdUUogUiK0ATF IAI4pgIKABWKsD29KQ0zWsreeQiRRtU5IbNQx3NlEIAz1pMY7bSGcLzWxmLg0AKAelAGnZ2qwIs0 67mPKIe/ufapbKsbemiJpXlu22uq7sEdR7f4UgKV/em7lwvyxr91c9P/AK9UkSyqBTEOC5FAEe1j KsceSzHAAqox5glKx1+k6GtgEkkAaU4bfn+Vd8YxjE4pyk3obMkjzSB5eTwpIHJx0pOTjFsEuaST KdzexWzqZXRvLzhMZJrL6xZXNpYeV7IoyR2WqWx8nKXROScYx6cd6d41FdENTpNX6nOyRG3meJ1C uDziuR2vZHbOnKm7MQD0pECspwc0AOuQDpzBWLDZ6UAYMZw1ICwpoAuW5ODii9hp2IZOpzQK1yKg BKAEoASgBKAAUAFABQAlACUAFMBDQAW/E8f+8KBm+enagBrAFT9KYhwHyY9qQyzpOq3GltcmFj86 ZC4yC3OM809eghZta1G4CG+nl+xzAgonAYDjH50aoDPeJbucLZRsMgZUnvnHr7imtQLFpJLbQzea TsUbdpAPQngcHv8ASjYCmoIUA+lSMMc0AHWgB9mITPsuQzJywVTgtx0osApgkgSIjyx5zHardVx6 1M43LhLlHWylP36yNFJuYPxhdvsfrTjorEy1dyoZBNM8uOO3GP5UyR0HEo/GkMnbmgCM0AW9K3/a ZDEq+Yqja5PKc9vWonKwGusKKEygcIdwDc81mmMo3EY17WNluoWGAZZc/ebvittGhFmVxAxjkO1h 2xWbpyHcRZFfoalxa3Dcr3m+SCRIF3Hbyx6CiKuacmgTTGzhje6XYHHBXnNU6buQ1YtosGxXaYEE ZATk0cqW5INMigiOJR7vyafMlsMp28P2VXEbuAxyealyYDiM/Wpu+oWK9xIIwBs3Z7VpFN7CKtrb MZ2kiASHHzAn+VEtBkksQRiPSpWoFixmDIbaU/I33T/dNNPoIy9UUxyhD1FaJAUcVQAAc8UgHQqG BLiTrxtApgPnt2WFZUSRUJxl8c0ARMjIcMMHrSA1tDudrGBj15WoloBtipKHbaCkcXsiHcVepOgB Y/ajUNDStLWOKMTSKGJ+4hHX3PtS1GX7K3NzOZJT8o5JNMRLc3sM0xzhYoxhAOC1KxUZWZmXGx7g ugA4xwOtOKsKo7sakiBtpIBqyCcjA6UAWPDMBudSeTaW8teABXXh0c9Y6DUdRgsiIv3m7APle/r7 VVWso7GVOjz9StDfSXIGZEjV8gIpO4fU1ySq8+52xoqG4TW0Gw7mSIqvAzuLn39KzbRqm+hWtJIb VzK7/NjCgdqnnUY2RvRgnU/e7Ipazc/aUhlWNEEfGVHJB9T9aIt21JxUvaVHIrx4bHYVozlHnkYz mkIco3WDL/ssP50wOdT71AFlBQBctGwxqJCZBMfmNCBERqhiUAJQAUAJQAUAJQAooAQ0AFACUwEN AD5BiOAgYyOfzNAGrCj3F6LWCOLcckFzgdKaAsS2zQB8lCASuU+6T7UAGMqOO1Kw9CLJSQOmMqc8 9D7H1FMQk8iT5aSRo2GTtbkd+n5frQBLJ9nS6d/tIc5yPL4yeeOPoPz9qVwG3l09wd23ao5xjqfX /Pei4EIoGFhFFdaoI5LnyFXlXI4zjpT0ES31m1ldlPl8uUeYgQ5ABPSjQZVdSXGOMcgikBILidFA KpJjoT17f4fqaQEUzzXGBIcKOw/z6UwGiPGAOBQBLHhGBP6Um7Ds2WDExjD7Tg9KnmL5GlqRAVZl saWgQeZNO24LgKP51jOxpFJlnWpDaQBI33Tynaigc/Wpiga6EunaYljbhfMxIeWPvQ5N6DSQ+609 b2ZJJbl2ZBwMjp71XtGtA5UTGO0DhlSHj+HPFLnbBKI9riMLhJIox/s4o52h2iVJzbzD99OsnpuY HFK7Ye6Rf6KowJkHoNwpWFeIm+0HWdP++xTsLQY01mP+W6f990aheIw3NkP+Wyf99UWY/dGNPp7M N0iN+NNcyF7g9FjZikKgR9TSlHqNWew2+jRYQwX5s4oi+gSVkZ2MGqIK2qzedMhIwwUBj6mtIsRS xVWAcrMmShIJGOKQCQyPEw3BmUfwhsUAK0rupQ7imflUsSFoAbigBYnMUiuvVTmhgdbbOJ4EkXow BrNlInC8UijkRar/AHafMLlLltZxxKJpUBH8K/3j/hT5mNqxMA00gzyxo1JuWbtxbw/Z0PJHzn+l MTZlkZNWSKBxgUB1HQxKrMxUNn17UDLBHy0CJ/CcvlX0secFl47V2YdpnPXTNDV7Kea8FyuHG0Ah z6VnXoqWxWHr8m6Kn25oU8tUhXgg7Bz+dcTg1uz0VWUtkMS7dAcbeQOSAalxuEasokNxcPKMOcgd sAUoxsKUuZ6jbkYsGz1xWl9SHotSGH/VqPatOhj1JRxQBJbcwOv+0RQI5wDbJj0NAE4oAtWv3qhg xk33zTQlqQmmMKAEoASgANACUAFAAKACgBKACgAxwaYATvjjUjbt4B9eaANRkhdtzBS3f5jQBOGJ j2hjt/u5PFFgLEalkiVTjdgE+lTJ2Lik2F3BFESsbEsoB6dj/KpjIucEtiqEJ7VoYjhHg8YFAwK4 7igBjADuMUAQvbq7bs4I7qaLAPCBOhJJ6knmiwD1hduQjEeoBp2AURNzgHpjpSADA5bJBz+VACG3 I6lR/wACFADI41d8N0x2pMabRdkuiAo2B8YyG6HAwKhR1NZVLqxVxk+lWZEX7wTSCJmXgdKtU1JX M5tp2RattOnuHMksm1UwNzdSSM8e1SoroXqtCO7guYGYbiwXAyPfpUtInUT7ZK0Plwq8YAxK2Mkn 39qjkaKb0GfZ325Dk96nninYXs5PUsQ6RdyQ7/JmLY4AQ8iuiMYNXM2pIzroPBMY2ypXgj0NJxQ0 iNFMjgepqLCJmmiCeSsILZPzAcmnY06EW5RDkDv3qrIi2pXeQlxzxRoXYmhkIkUxgbhzzzQFkdBY Xv2w58uOMogT5Bjd7n3rOctCobk94MxFf4uuKzRpLYyyCDTMzPvDmY1rHYRB2qgG5OQFxnOMUgFK SeYyYG5QSRn0oARQxVnyNoODzQA5QSisSPm9D0oARxigDR0vU3t1EAUMueMnGKzki4o1bbVFZwsg 256GpsU9CpBEGy78Rr19/aki5BI5d9x47AdgKu1jK5btoxbWrXb/AEUHuaYnoZszFiSTkk5J9aux IiR7uAOaYFn7DMke8xNt9cUAM27eQcigBSaTAqCV7G8W4i6g55qoycRNJlzUNUuNQI8yXcmMhegH 0FK7fUpadCg0xjIBFLl8yuYuX8M9lHE0m0iQZXac8Glyi5ivGTJjcSCe1NRDmH3Lu0KQY+YHJ+na kkDehYVAigdxVEIUAc5oGLanBkHvn9KAOfmG24cejGgQ8UAWLY4cVDFJXQTn5zTiKOiIDTKCgAoA SgANACUAFAAKACgAoAQ0AL2oAJP+PaE+5/nTA17dke8EU9z9ni2g7tufSmnYC1dRQI5NtN58fGJM EE8elDARCViTHoKW41oyN3kZ9nmYEmA2B1FKxTkONsBEJPtUa+zE5z6dKogjhE0jCMSBepyeOlIZ WkuH3FSWYj0osB1PgK3t9RnuoLtAyogdA2ASc+ppXsB1v9l6REpxFtx6MBRzDJY7DTSVaOMk9sMD RzAZmu+INI0iGSFT9ouGBUwB+B/vHtSuwPMWlLMT8gz23dKYiSCNpW2nap7ZOAfxpgTxwgRKzKrB yNv70DH1FACQZ8xgeKAuSuKQxg60ARASGeUxKWYAdB933quaysS11LcF21rGpxuRuAjdiOKz2FzX Ib77QLktdRNG3GF6YFMVxViZ7Vp0hkMQOCd3GcUldjv2EsluHk2QgMqKWIbA4/GpdONx+0lsXbW+ vncwxzbdik4YAAY7f/Wq48q0JfMUp55hK8hYhifmxxmqIbKigI3mZzk8VJSAR3EaMzRfJKODx60z REE25UCFdp96BWIsPt2gUASxI0ZB4HrihiTOg020jT7jllG1wB0BI/pWUmawiW5+wNTfQcjMkHJ9 jQiDJuTmZq2WwiKqAQoDyaQBsGaAFCDHSgBQuO1ACMKALeilRfKjqCr/AC4pS0QJnTJY28Z3LEoP rUFblG5CeWFj4CdB/j71CNWV4V8yRUP41aM2kOvwqS+VETsXkgnjd3x/KriQ2mUieaYGx4dVGuiG UE44yaY0dS6KEIKjGO9IDjr8RpdSCI5GegGMVMWIr9KsCKYAod3SgB9jZNchkjZVAGSGbAx+NOwr jp7O2jXCO5cHBGeKAIQkbNhg5I9WNAFpVsI4QGAEpB6AnB7UMBbFY3EpuAxCglTvC4/PqfaiwyFW 3A/WkIUcdelAD7f/AFsn0BoAw75dt5KP9qhAIOlICaH74oBizfeoAiNAAaAEoAXFACYoAMUAGKAD FABigAxQAUAFACHd5Kg42ZOKYzVUkqpCE8DkqKAHBucEYP4UAWU5iT6UARyDFymOKAK2mjeA7yr8 rEbXPDCgQ+GVVkbeuFyPyzQBRvDwSMgFqBlZXdTlWIPqDQA4yyHq7fnQAC4mThZXX6MRQAzd68n3 oAQHmgDUiCFI/NDbO5Xr+tADlW3Ay6yFOcbSAfx7UCHW2POfGSuOMnoKQyVzzQAg6UAMjD5nMTFW J7HHQVlKXvlpe4wlRjbW4HJOTkVUdTGSJPKcxL5z5YISCTkZ5qL2kate6QxQyKfmbC4+7nrx6Vc9 NTOnsOuLYkjY4VMcMeBxVRs1dk9S3ZxqlunzBsjLH3riruz0OyjsQX+0DAAyfwrTDyM66KKsqj7j YJx94Hn6V0mFkDF2jwCSuOATjFMeiFi2MQHzgcjNRM6cO4X94ka3Lvu6ZrNTsOvHmlZbD3T5Qo4+ tClzO5m48sbGrpgaOPZtIHJbIxt9KqQoKyJLieLK4cGosOTKcy/O1NEGJNzIx962WwiKmAuSMDaa ADccHCnjvQAb2ChihA7cdaAHFnV9pQhvTHNADNxOeOB19qAJbZzFPFIP4WBpPYDuVGVBArJGiOfd WA+tPYLjrEFZN2M5OBTYRtfUZqUKxhZInySfmGc9e9KLd7Gk4xtoUs/NWpzksUjxMHRirDuKANCT W7uSMJvC+pA5oaAoEncWJyTzmmITNAC8Hg0DHhV29OKQDWBxhXYD0zTQiPy9xwZW/OgCfyo4kG3G f1psCSC5mhDLE+1W5IwDz+NFxkaqFGBSEJjPFADoRtuPqv8AWgDI1Ubb1/fBoAhXpSAljOGFAD5f vUARGgAoAKAFFACUAFABQAUAFACZoAQmgBM4PNMB7D/RF9nP9KBmhBtE8LzQPNDsGVU4zx6/WgRe meAxBYYzHjs3U8nmmARErEn0pDGXHFwlAFKyg3BTIRsVzlCcE0CJ02eaQwGDgD2GaAKN3jDY/vUD Ki80AAGThaAEYYODQA00AKnWgDZthJhPLAyF5yAR1PrQAsZuBP8AuxiQ5zwOfX2oEJbKVlkyMEcH nvSGTyRssYfHBPWgBg6UARJk/aABnr+HFZyjeVx89o2BJWPlIpC7RjnvRHQyk7jHlk2hXYN1Oc9c 0nHW5XNpYHkcMjF84U8H8qt6ihoO3iSHaxfqOFOKFoT1HQzMiYjcKPRu1ROEZGkKjjoNed3w0ixs R79acIKIpVHIas+w4aJTnpjmr2FoxjGcHcoUDsMUBohYt0koJXFJ6i929y3kZ6jrXLJO51xmrbkM u4yqUGQF5rWlGxlUld6G1YFv7PeWZvmYkkn8qJXTKjtc5ids3ZySE3YznpzWsVoQ2jonswFPkzbl 5wcdeKhbjOclB3GtSSMCgBYy8T7kYhsYoAFDCMoGO1jkj1oAQqSqqzEhenPSgBSCW3FiW9c0AIEA +tACjj8KGB3do262ib1QH9Kw2NEYsxLfXpVIQt4xt7aKNCVZhuYj0/z/ACq47kszZHLADdkCqtZg 22QtKB8qjLegpoknktL1IFlZAiE49807APWzm+ziXzVBIJCkdcUMBkZZh9w8dTSAQMfMKlcYoAk6 AnFAERugF5HPpQgJIrWSbaZn8tWIwo+8Qe4qtgLJsI4PllicNtzktwQTgH25oEOntktZBG+3cVGA TuGeh57c5o3AqzxywqDt+RjhX7Nik1YZJGSUG7k+1ICQMqj3oAjV83KHpwRTAzNZGLoH1WpGVU+6 KBEi8GgB8h6UARk0AGaADNABQAlABQAUAHagBRQA00AJTADzQA7biHcGON2MUAaKyhIowWC5UYHJ oAlUkrkZK+uKdgLUQzCv0pDGSjN1CPU4oAbN8ykRhQi/xnvQIPMhkULLEFI7oev50AZl2RlgPu7u M+mKBlXpQADOOKAG4NABtPpQA+KJi6jGMnqaANmNjabkcYZY+meD3oAiZfMIA5dhklqBEscMlvIV lQpkZGR1+lAxxB6dqQC+1ABAtmUfzmffvPAHFQ2ZyJv+Jev3VkPGDx3/AM4pEDd1jgEQSfjQAhmt OT9nc8dzQFrEhu7IbcWLHCYOX6t6/wD1qCkQm5iAIFqPrmgkRrtSMC2QfU0WYxn2w9oIqLAP+2uA dsMXPquaYyAXtxwFiTH+7TK5Li/arsjiMfglFkV7NrYmtLuJi6XkjBTjO0AEDvQiUnc14PKTT1E0 bGPHGDjP1FZTvc3irLU5zVJLSRybaNl/vHtWlNO2oNx5dNzXsIZF0cTmVlCxnao9KS3LdRWtYwCM 1qYDMUgEBG7BzmgADDBPPFACE9MA0ALu9qAFBzzg4zigBDkdqANuz1K8gtwrqNgACFl6isnE1iib AEi7gce1NEsj1GUT3LFD8igKKtEMzLrCEbfvGqEXYrCJbVZTLh+pGM/5+lMBxnkkhYo+1EwMM3J4 xSYDruVyIJkAjV0wQDnJHGamKswHWd8sf7t44yh6grwfrViK8sVwg8yWNgvTdikMTPBOeBQBHYgP K9y+NsfIBXIJ7A046AWLqSJ1ieJn8znIJ+79KAHQTM/mPKxbewVifQ5z/SgCurGKXOAWQ9CMigDQ 857+VmMGI9v7zYOR3z7GjoNK7sVfKe3maB+qjIPqKiM1LQ2rUJUXaXUUj1qjEYQBJGR/ex+lAFHW x+8ib2IoEUkPyikA4daAJJOgpIbGGmISgAoASgAoAKACgBaADtQA2gAoAUUAOBBtiuRkPnH4Uxml YtJDNa3MRiLRr0kOR+VAF+7vZbw5n2E448voOaYiOM4hFIYkgPmRyDkL1x2oAphtmFYjAbP1ouha ly+No8sf2QELtyx9ye9O6GQGO3cqu1hnG89eaQDJIYUYhE3LnglcZ/CgB0620ePJDNxzvUDn2oAQ taiEYQiXuSRt/DvQA2OWAI25BvzwwYcfh3oAWK5iXd5kYk9PnK4/KgVyJ5QS2OmeBTsFyNZGRspu yOhx0o5RXLyXMl04ac/OFwMjH4+9JjTRJjFIYhHTBzmmBf0+10s2xa6vUSRmJK+YBj8KwlKVy/Zx LXkaGAT9qLBeThicflU3kJ04IiMvh5RjzWP4NT94fs4DTd6AOiu/0Umj3g5aY06noanIt3P/AAD/ AOvTtIF7NDTrGjgfLZOfT5B/jS5ZB7nYmi1G2f8A1ekOB1y6qo/Wlysfujxfg/6vSQR67lA/lVcu gXQv22c/d06NfrIP8KFEOYzp9fmhcq9iiEerf/WquQXOFvr0s8oTyUQk4HU0ezsHOOtPDsV1esZZ 2IZyTtGMc05OxK1Z0zabE6bHZivpUFX6EP8Awj2nMuDbjPrmmpisZurWv2TTpRE5CAbdtVHUGcoR g1ZIm3igBoRtpG7qc9KAAxnaq7uBQA/YTJvLncOhFADNm3OCeetACxrjAHTPAosBvRaDgqXJkBxw pwahyGbcSW4iSJo8KgwAwzUXLRnW4AuA393mqQmZjks7E9Sc1oiCmqedfohOMkDJ7VQi5exfZYxH vDAnJI/zxQBBGpYfKpP0WgDTfT7iTS4SsZLI7Hb3x64+optAUpNNmiUySRlAOTk1Ow1rbzLU5ljt AijzFYFTkdKSlc3r0HStruZZYm2fPUcUznLdkoisFeVH8p252tjP+NNgRhFllfyhtjHPzdh70ASO rGI+UhWFTksep96AHlGcYmTJxnenJH1Hf+dACW32i3ufLt8M7DjAznuODRa6sA+8cB7Nix84Ao67 cYA6fWpUEjerXlVS5ug5gMBhTMSGVcKG9GB/WgClrQ+SNvc0CM6PpQA8daQEsn3RSGRGmISgApgF ABSAKADtQAtACUAJTAKAAUARn7xoGbdv/wAe8f8AuigB/Occ0CJYgXjCgEt6UDEljkw0JJTLKrc9 OaaV2JuxCbe2RmV7mbKsRgDP41tyJGXO2VyQOzH6uanlRVxmV/uD8WNFkFwJUHhE/WiyC4bh/dT8 qLILhvP+z/3yKLIBPMb+9RoA0uT1c0aAN3e5/OjQCRRJGPMUMMd/Si6Cw+NZJju3fN1Oe9ZTLglf U1pFRIgq4HA5PU8ZJz9e1Yq9zpk4qOhWHzMOeK1RzlK0QO8hKgneadkBs6bCxlkiEOImQjf2z2qX oHoULy3K7wWxgZ+UU2rFc0maOm2tpfQ4nTEq4GwkKeg/rRcWpak0axDKGjMQHZgRn8c0m2BFcR2d svl20JjkHU5PI9jT1FdkYuZlKCJiWJ2lG5U/4UMC+oDjhdrj+HsfpUDsIBilsFgeGOQYdFb6incL FObSovPhlgUIVcbgOhGapMRqaEmZXk7HLfnUT3GjZqShTwpPtSA5zxM23TiB/EwrSGomcht71ZIF gOKAEL8CgADgUAKsi9O9ADWcdqAJbVfMniA7sKTA7qKJVOVUAt1rNlIf5DbySQVxwMf1ouVYxkHE jDsp/lTQmZR4zzVkFKQmK6VwSOetUI0Z7aZrRZpFOM5ViRz/AFpgVxPMBgTSAem80AW47yd9OuIj Kx24YZPOM4I/WhgRJFE6BnulUn+Egkik0G2xas757JPMdTIG4HAHp/hRy2NJ1JT+IzIlMsc3+0xo Mx+nEPG8Dgk9QuMnI7D/AOtVATSyqsz/AGePapGCpGcc1IDYWaSSRnJI2NuJ7cf44pgJOp+SVful VGR2IA4/SgB0ZuVxdIzjB2+ZnkfjQgC8Ja7ggyT5Qy2W3AH29qAJCxpARzsfJP50AVdW+a1BHZqA MpKAJBQBK/3RSAiNABTAKACgAzQAUgEoAWgBKACmAlACrigBrrhs9jQM1I5dtvGAcfLkn0FADlaR AJMOqk9S1Ai1BIQodSQeTkUAR3LusJcHI3Atnr1zQnZiautB0kcChZZMt5mSMN0+tbc8SFF2KpRZ 5EWBGLP0UGk5oaiNmtpIApliZA2SCx64qLlWJf7OnWaGFljVphlCZBjHue1FwsMW0YrOS0K+T1Bb lv8Ad9aLhYGtdkEUvmRP5mcop+ZPrRcLDFjVhLmRUKY2rj730ouOwgjj/dZlPzffwv3Of14pXCxI sVqJplaaQoB+6YLjce2fQUXCxC0hjPyk9MZBpXGiWxx5jAE4xxSAuHHcD8qB3G8CmIraayvJ5ZON z46e9IDUt73zNSijUFY0bCr2pMLEGpSN50qOmBGxUcdeaUtWb0kuS5Nb6nDHgGFvfGDTsYXuWv7Z tQQFMsS45+XIpNAUmuoDKyxyBgT8uAR/OqTsBbtY0SRi7LlgNh6ZFTJgXM4GR25BFJDI5mkljWeJ sAcSJjofWqsIdDMrcHg0mhkx+6fpUp6iLuixCKJwOmcClLcpFq4geWSNklKBTkgd6TGSyHETUgOX 8VSKLaJAwyWzjPtWlMlnLnpxViG8qOBQAwg7MAYPc+tADv4wQg2j+GgAUMAw45xz3H0oANp2BM8D 070AXdNUtfQ4wTuH6UpbAjt4pRj51I+lYs0ROpRh8rA0hmDHwrqcAEHJPQCnqWlEyL2FY7geWT1I POefatIN9SKkUtivPGJFyOoqzIW1uXO1Gc5Tgc8VSEW7uxERQhlUuu/ZnoKLBqJBa5VhI5jOD0br jtWU5SWx00o0/tCfZCqvKc+Uh/8A1ZrXYxqKPNoOvNRjNisCQ4kJ6nnA9j19KG7kEVrGI4QvfvSA ikQx3Akj69SKEBqRTW7KrReWlw4w6kYUDvz61QFe1jaNZBMuwbPMDYzgjgfrSAfbmSbzo7mMsXGF O0Da/UZ9qdgIYrmLTtrnE0nXy88D1B9aTArWxAdmf/WOc49KALWQaQDJD8pAoArakRLZ7/YGgDJi Gfb60AShAOsij8aAHsY9oHmj8BRYCMmIfxn8qAE3R9ixoATevZT+dACF/RaAE3+woANxoATJ9aAD JoAOaAFCk9AaAHCKQ9Eb8qAHLbTHpE35UASJazE4MfFAFwwgRhc5IXFADr2USRRogJPUimBLCNsC g9aQCSjzI2TOAwoAbcZaJIWWNdvU5OTRZAnoRCPkYdcr6U7BoOER/v8A6Uht6i+QD1ZiKADyFHc0 WYhfIX3/ADoswDyEH8NFmPUQxIP4RRsKwm1B2WmvMLC7BjO0Y9cUtAHwgLuwMUDHE8UAKKQEtrYx IqyeZGDncMt0pDLnl2kcqzLJEr5yR1pMQt5La3Fw7GRfLySMA5J96pFN6EYbTlXDRxt77DQSREaX 1ZH/AOAgj+tAEOzTlkDoLj5TnHFIB1xPaTlC0MrbBgfMBTsBGlxHEf3SyAehkNAEkeoyxSM6Y2su 0o3INADDfSn0H4UAH9pXG3aJOPpSsADVb1VIW4kUf7JxRYCJtQu263Mx/wCBmnYCF7mcjmaQ/VjR YCFmZupJPvQAwZoAeF4oANtFwHAJ8oyR68dKAQ6QQgrs3sP4s8UAyH6UAavhiNW1mLfjChjz9Kzm ykd2YlaJ9u0HHBx0qIsexT+zlUGTlu5ptDuYc8blCqkjPYUJiaKU9oY03SOo/wA9K0TEyoEckDgb jgZNUtSStcwSRybHBVwaa0EBklRQSVb9CKAJZNSL28cJQgITyD1zRdhZdSNbyfy3iiyEf7wPegLK 9wig5LOfn9fSgCymUXGc0AR5wzHOKAHQspkEjxqy916ZFAD5riQsTGZFB6gsDTAbc3N1dEF2C4UL xxnHQ/WkBEkIQ7m+ZqAJlCbt235vWgB4ORQA3vTAheMy2ZQdSMUgM77HcdBG1ADhp1wf4APqwoGO Gmz9yg/4FQA4aXJ3kT9aAHDTPWX8hQA8aWg6yt+AoAf/AGZAOrPQIX7Dar1DH6tQA5bS03AbB9dx oAUQQD/lkv5GgBRHEPuxD/vmgB4XjiP9BQMUB88Lj8aBAEkY+n40AHluOu2gYqo4IbI46cUCEMRb JLfpQACEepNAxXFAEQxigBwVp8uwLt3JPtWE5NM9PC0YThdoGiKToMbd+B696dOZljaMadrdTcXQ YRKEe5bcewWk6yPL9oQrpCHVLi18xtkaKwPfmq9pZXK5tLk40W3a3nkSSXMaFvm47VmqzbsT7TWx DaWVqdPt55ImkeRQSd+BmqlNp2CUraIW7s7dbvTdkIRZXIZeuaUZtq4KUmaq6egmAWyj25xuOOlZ c07k3dzP0yELLqeyNdyzkLkZx1rWTlylNuxLqjg6DIr7Vk3LwMA9fQUoN3FC9zm1Gc10m4EYoATJ +lAEgo0GDdKNBDaAENIBO1ADcDtQAm2mAYoAKQCGmgEoAQj0pAJigBNuTQA+HzIpVeNSWXkfLmi4 Ci0uZCSIJCSc8IaLoCRdMvT0tpf++cUroLEiaPdnl4iq9+RnH51LNI2F8tBIPKRcg4Cv3+tJXHKx ck0i7lYSMbeMAYwucVdzOxEuh5PNzH+Csf6UuYdi1FoTRDzFfzGXoNuP51L1LjZF7SkvoWMEiE27 /eDdveoasN2ZtqMKFxwOKQkjCuJUgGcZPYetERsoeWZnZ5WCkAkD09q1SsZ3Ir2N2tw+3ATAyBTT JKDFnYF2LEDAz2FWITjpQA4oo6AflQAYAHpQAooAWgAxn6UAHA9qLATQWs8xGyFgpGQzfKD+Jp2A Lm1ltlDSoVBOAcgg/lQBD1NIBQMUAOzTAO9ACEEH5PyoABuPUCkA4KcHJHPtQMNh/vfpQAbD/eNA hNvu350AGwe/50AAjH92mBJ5YHYflSAUDHbFADsZ4xQA3AB680DHdBQA3vQITOKBid6AHg4AFAi5 fWcMFnDNBOJy3Em0YEZzwPxq3sMpJyKgBrqeaAIQACOOlAFmzQOjHOOa5Kz1PcwCvSG3Uey5j2nk Ln8jVUdUc+Y7xNCXWgZsrbp5nH3nJ/Sq9l3PG9kRDVp1vZLrZFvkUKQQccfjVqmmi+SyFbWLkpIi Rwxo4IIVeuaSpJakqC3K8N9cwQJDHJtRBgfKKp00xuKYyW7uZWRpJ3LIcqc9D7U1CMdBpDVmvLmc RiaVj7yGpfLA0jBSGTwyQyEOcseSc9apNSCUOUiCU+VIhJEicA0xk1nam4DF3wBwBxzWUpWN4wTQ SlxELeOMMgbfuC8nitE9DGSSY1La4b7sEp+iGldAPNhdkf8AHvIPquKLoA+wXA+8ir/vSKP60XQW GvaMo+ea2X6zLRcLEflwjhr22B9mJ/kKLgNP2RTg3sefZGP9KAFT7Gx4unb/AHYj/jRdgIz2Ktgv csfaMD+tF2Aqvan7tteP+IH9KVwJokVz8ulzH3eUj+lAFo2NyjAHS4Fz0LSk/wBaTA0I9DucDNvZ IfoTU3GTLolx/etE+kANK4xjaVco5H2wD/chUU7gH2CX+K+uT9Dii4C/2eh+/NcP9ZTRoIjWySOQ Lyw7EnNOxRMyIh3YAIrRIi41XBO5YgR6kU7CbLkEobgjaaQ0SOSOqgiiwEcFxHISqqVIqWhlkAio KHA0howFtywd2YbsZ5/kKEhMPKL7cgcDHAxV7E2Eu0H9n3Kd9gb8mFAjnsN3UgetaEiMSBlRmkxi 5PemAuRigQLwKAHmgABFADBNHHcxmQZQHJXbnPtjNNAdBYR/bbczXjRRiQ5Vnydo9FH9abANS0a3 2ZS4idACUljJwGxkAjtUDMCGQvHk9RwaYD80AKOtMTNOPS99o0vnosgIHlkHr9alysUo3M9gVOGG DTQrWDNABQFhcFRRa4BnFACg+1ABxQAZIoQg3AEbj1pXsUo3HluMdqNxPQaTjpTATNAC80agKOlG wyc6fcC3EzBcMNwGecVmp6mrpWVxtolvv/0sTbMf8s8Zz+NaXMbWC5SHzf8ARt4j7eZ1/SgVhITM iyImSsg2sB3FK5ViSKwuX+5byn6IaLgXotKjjtl+0xyi6c8JyDj2Hr3rFyfMdUVHlM0adcu2Y7eV lzwQh5FbX7nK0r6D00bUwxEUbKhPcgUnGLNoVa0PgZMnh3UmfcygnGBlxxSjZETnKpuXLXQby0Z5 pLfzMgDCAk47444qJ67FU5cu46Pw3eahIzhGhUAfejPNVF2Jk7ltPBVx3lb/AL4H+NPmI5SVPA8h +9K36CjnDlJk8DIPvyN/31/9ajnHYnHgqBUPlvsk7MST+lTJ3KjoSW/hFRMXvGgmGMD5Dyc9aL6A 9S/H4csYxxDEP+2S0rk2MzxVp8Vjo01xb7UljxtPlr3IHpTTBowIdKvJ9OW5ubxCGGcBAMZpuJSl YyrOG+t9UFtcTyBM4Yq2M+lNrQi+pc1XSGht4tl5KzSsQdxOBimo6BcH0mN7nTzvY7o8vz1INTbQ LlV9NjluJZA21N5AHsDVAKukQSINxbnnGahuwEy6FZhlHlknv8xoTEDaVZiZsQKRnvTuBr6LaQQi VkhRR7CriDK0aIxZ9i5Yk5x71MhokCgdBioAUjIxTAlgJbyYXO9lbhj6elJjNmkA3emeXUfjQMqz YLMVOeaAIG4oAZTEI2MU47gNsrVtR1ZbQDKIhlk9wMYH5mtepLNC70i4jyUiZgPQVrYi5BbafcSq WETLj1FRYpMmuPL+zQyLwzDDD36VNirlWJRuyAKiQ0WlOayKQ8KPSgZlOoZidoA9BQgE28gKMk8D FUncViW70RktLi4eUlhC37sDgcU72JaOOYnGMnFakDRlenFAxMUATWsQluIo2OAzAUxG3KLCewuI obfy5Yukh46UrlONkYKEMKCUKRQOwturNOYhMsKzLsZmGR9PamhbHS2emNqHlMQz+TF5UqRkEowz z9OQc0plIzxbtY2ssd4wh84hE3Hk/N1+gpCM2ZYUnkFsMRZ45Jz70xCxxySA+VE0hHXA6UnJR3Lj By2GA5xwR7U4u5L0LovD5Z/dpywJyTknHX6cVDWpaehXOWyT161ZDG45oAUZBoew0tTbfTrVbAsu 8uoG+TPAJ6fhWF3c6GotGSsMjj5UY/QVtc5iQWNw3SGT/vk0XQDhYzr96Pb/ALxA/nRdAI1sVHzS wL9Zl/xp3CxasLq0sWJee3d24G188fUVjNN7G9OSW5TnuLGWZ2a8SPBwQEY59+BTi2iJtPYj+06a p/4+pW/3Yf8AE1dzMX7fpg/5+m+iqv8AU0NvoAjanp6DK2ty/wBZQP6UagWYLy3dFkXTuvTzJSf5 YqdSkySW8upQVWFcHkANwKm1i3JvQuLe3GArLbBRxhYRj9c07kHWaDpy3Fgk8zKGc5GyNVwPyouB rLp0Kj78v4NilcY42EA/vn6uaVxEcmkWUpDPBlh0bJBp3HfQmisraJFRIECqMAYod2JIkEUY6RqP wpBYdgDoB+VA/QBQAUAhyqWBx0oAjLLv2hwW9KAA9KQWYUwsxelMCGe+hhRy7BQvVm4A/GkBzHjG /trvw/cRwSh23JkYI6kVUWD0Keq/ufDvljjKqv8AKtCLMz7Mfbkt5icywtsc+o7Gp1HoP1ZgZYI8 /d3H+X+NNPQQ+P5fs0p+7HC7H9KnyGZkJIt0+bJbk+xNO4FyNDuABNRMCdMCQseiimloBCBnn1pi NCz/AHdjM5461cdgKMIwij2rN7jRIKQC0xk9iu66X/ZGaTA1CeM0JAVZUWVCyD5hQ1YCnuaNuOnp UjJFdZB6GmAFcUCIZDiritQGQ3JsNVivAcRyoYnPp/kgVoSzUurqaRGO8gexquYOUqw3Mtup2ynH 1pXDlKbzF3RAehyahspIuQDioYFlBUlD6QzLlcIpJ4FAF/R7eN8zsyu/QKDnbVWsJmjebBayiQhU KkEn6VLA80nt5YArMAVPGQc1qp3BwsRkZ9qtozALjvmlYByoWZQDg56+lAWuT3kTW8vlRzrIpAJZ DwTSQO4WVuskmJN2OwA5JokXBRe5Je2kccg+zbmU5BHXBFZwkaVVFbFUwMMhto/3mAra5hr1GxKY JC8d6sTeqTAH9DRzBYJBEz75rtZG9XYt/SlcLAJbUH/j4H4IaLvoBYgvfJRjAQyKPm3jBP0rOS5t zWNRx2Kp1K2ZmYxTMxOeCB/jVR0Ik7iDVYwTiyfjk7pf/rVTViBDqr5+WxjGPUsf601G47iHU7no LWFf+AZ/maVgNDSDfX07x7reMqu7iJf8KTQDtTg1SC6+zi9I3x+bhflBxyOKVrDuylGdSuYwftsu D3MppNpBY09E0c3Ucz3N3IxRgAA2Qfzp2TEzL1KwVLmVlZsqfu+1OyASLT45EVhIcGiwDm06FR1b 8aAFTTohyxZs9qAJ/sUK4AjFMZLBbRZx5S9fSgDTs7JBcjMa4+lKQEmrwBGjZQADleB6f/rqQKcX FIZMRxkUgO20G8httEgaeQIMkDP1osMsX3iTSdPnEF1exxynB28nH1x0pWA0opEmjWSJw6MMqynI Io2AeOKQDZ7iG2QGVgpbpnr+ArSKuJmBeeIrm1ugs1vGkORnccNihoEbcM8VxGJIZFkQ9CpzUDJK ACkBX1K7WwtvOkBMYxkDqcnFXFJC1aOO1S7FtcpcJK8ty3JXONmegFKco20Oqhh3UV2LZeLL6Jl+ 0oksWOeMNWHOd0su03Op0zVrXUlzBJ8w6o3DD8KtSuefVoTpbl24YiI7CAwBIPvV3MF3OY1C9tL2 W4SeMeXbscdcSHtx9TW8UpS5SJPkjzHN3BabdEAArkZHY46V6EcNBHnSxUnsOujPNb/Z5rklQQQC OlN4emKOJqIi0lWivWgYgrIhyBXn16cqcvI76VSNSN+oups320opAUbWJP0xis7Fli+lWLRVwfmk UIPxNJLUZnWSZIqrAaMAO/PQDmsnuA7IETcjLHFUA0Y7EUAXJPk0k+rcfnWkdhFRetZjHikAjsqK WY4ApoZa0hvNLSgYGOKlgaEpVY2Z+gGTTTApjEsXnxgqD+dO99AIzh+G4NDQELxkHjipsMVJivD9 KVgIb1mypjOB644rRMkFKuhVsMp6iqAMSwxlIWJjP8JPT86EtR3IGFw5wQEHuabJJYoxH3y3c0Ws M0IhhazZSLCdKkY7tSGYsE2ZVlZcqDkKe9MB8d7cwS4ibamc7QBzVIlsn1C8uL61aFY1UMAc596O UVzGktJpQVdPlJA46mmo2Kc7ix6VGjfv2QD+6uSasgdJaW4GI4QPc80ARFI04wo/CkA0RqrKy8YO eO9ICO2hZryR1mkR0wVweBkVLdgKd9pssMfm3E+92fCgfmf6fnVCZVezjSNJmw27+Ci5diyLKEWC XAjAPn7D9MCiwjV0jTreS3O+KFirlfnBzwfrWliLmimmWFrvkMECIOckZx+dMDm9Wka6kfyY1ht8 4XIxu96zY0Z9vCsQWQncy5IA6UAXLBYI/NF3jGBgnP5cVFdSUVylU9y3PFF/Z7SbVBwDnHJpYZS5 ryeoquiMreAAR9BWzdiUbfhqNorttwyXQ81Kdxmjr6hdasG7PGyfpQCOdSfyrYp0wSCfxrJq5a0N 3w6Gjgm3cF8HHpWiVkQzP12PydXmYfdyFx6cU0IqQ5iuNmflbpTGW/K3H6Uhjo0yT0+WgB5xyTRY RYs1xhlwD3zTA07KVTKR0yeOKlgS6tDvsnccmOQH8CMUdBmMgxUDJV6UAdf4etIL3Ro0uE3BHOOc d6dxnGQ+HmXULk6hEXmMpCqc4Izwaq+hNj0Pw/ZtYaXFbsuzaSQn90E9KzY0aNAzC8Uo8ccd4hYr ECCPQ9j+dVFiZwniDWLm/eJM/vAPmVeCR2JrQRW0XxJe6NLiNleInLpng1LiCZ6louqQaxYJd2xO 1uGU9VPcGs2UXqQFXUrVL+2MEjEDjkdsHNUgZxus2E1lcPIVG0YIIOf89Kxnoetg5R+FjlW0msg+ FSdhkZHB/wDr1vTgrXOfFVqiqOKeiDRUaLWLRhGVcsVOBjKkGlKnYwWIco2Z3HPoalIw6GTqmlfa xmEpFu++CMg+/wBa0py5ZEzjzRscpbs9pJLvHK8YI7V7MHzQueLNOFRRG6pNDKyR2wMTjGR6n2Ne ZUqNs9eFOyKgka21CFXXbIYSSD9eKUpcy1BQ5XoNuoTPqE+WwvH8qwlLlRZauYkk8mJhlI0BAPrU Sk0rlDNkcKlgAoA5NZ88mA1ZUk+5u/EEZp6gLxSuAwkiRApxk8/SrhuI1L4bLOBPUiulbElUVmMS SVYxz17ChARrA853T8J2WmM19LQLC20YGcCs+oy4RTERT8JjtmgZSkTPTg00IjD4O1vzp2AGjDCk AxQ0bZU8elSyidRDN99Fz9KVxg9mg+6WX6GqUhNEDQOOjA/UVakTYjFq3nByDn2PFNyAvoMACoGS rxUjHUDMQ8e1NCCL5utUiWaEMY2IRz8v9apAVNTlYBFj4HcjvQKwltB36+4qrASXDxxfIFy/p6UW EU2jM2cqvPtRYCu9q8B3KDszgj0pNDJdNjQ3j7gSzIMfXP8A9ela4FPxGwF2sSHhBz/vGhsEZztu g8v0x+PB/wDr1JoW4yG0G7XvHKjj9BWj2M5bkFlqt1A8kMUu0MS33R1ouFixLJLOwaWR5COm49KT egrFK9lWZkhi+bkZP9BWfmUV1j8sqN2AGCj3wef1pxd0IWclgPmU5wOvvXRGScbMhprYllupZLby PLCICMHNYRoxpy547jvcZbIHkJBI2fdpzGjZ0OXdfgEFXAIKnv71MdBsva9J51zp00OWaJvnA6jp VPQSOfjtmlvZzj90jlgMdfSkM3tNaJUm2rI2FUOHOMknt7UK9xsrarAyXDxTD5yoyc5NVawjLdSY 9h/1icg0yS/aET2ysOD/ABY9aQyZYxGoosMaE3vj05o1EW4I8dP1oAtW67LhO+TUsDVeLzbS7THJ GcfhVLRAc4ikjmsWyiRVxU3A67wpcRi2NsGPmZL4wenHfpVbjN/bk5wOO9MBQpoAXBoAqOYL6O4t 9wf5SrLTsI8a1VJINRvY2BDrIVP0BrVEsz1zuGOtNAek/DKJ0tbwnPlsykfXn/61Yvcs7YAUgEIG aYGbrGkQ6nHhnaOQDAZf5EUmkzajXdGSaOTfRdRtXMLWjzLnCPGRilFuJ04h06z507M6XRrC5jWO S92q0YIjQHJXPUk1blc4Wknoa56VIhKGC0OW8ZKlqLd4oS807lSq9xjJrroV3B67HNXo8693c4+4 1GJZAphPm4xhhjGKutKEnzRRNGNSK5ZMn0gSX13LdzsWKrtBNcu50l11P2ubHfb/ACrGeskMdKQJ X9BgfpUzvfQaIZV8zb3AOcetKLsxMXJCYY98mm3cZEkySEhCTj2OKmwDohuukHtVwWomamo/fhT0 BNdLdkSik7bRx17CoWwx8UG075OX7D0pMCRs81IGjYLttl9+aCixQIguD0H40DK5oAidA3WmIapK HDdKYEu0NUvQoYyFaQxUnZRg8iiwrkikNytMQYxQA5VNFwsSikMKBmM4yKYgXCkU0yS7bzARDPHU VQFWRMwQnuODTQFm2ZE5bhRjp71ZItzDZuf3MkgYnjK5oA1bHQfMUNvX6EYpsCa60IglQA2Rzjmp YHJWyi11XD/8sy6n8Af8KSGY2sOxmErAgMxOf8/WoBEVjClw53sVA6YHem0VcnjUpa6jGcgFFI98 EVS2Je5Us1G+Q45wCDUt2GhbyUx4xkZH50dBCwxDPloDnGWY8fWplohktui5POR0UY/WqitBFbYP NeMqPv7ufTp/Wk3oCHXoEYjj6FQfypwlcHoTWMeIA2Pvc1bEaFlGVuopgCAG5asuoxNUmktZ5Gic grKOfYjp+lVa7BDYkIurhQc5II/EUbAXY1MdncnuAp/I1VwZb1iESX5Y90FKT1Az5NN8xldHCdjk ZzUc9gsOtNNNtI7ebuVv4dvSk6vYLFn7OrH73T2pe0YwW2jjBJJ+tL2rCxZSFRU+1YEiqocccjkU c7A0NPlE8UrgcZxz7cV0w1iSznxglsdASKwZSF6Uhm/4QuhHfNAT8sq/qKqIHYYxVAFACN0oAhih jiZmRArN1I70xHMeK/B66tMbyydYbojDhh8r/wD16akFjB0/wDqXnD7Q0MSdyDuyKbkFjvtM0+HT LRLa3Hyr1Pdj61n1GW6YCGgBMUhrToHSkL1QYpgHSkwK17NLBbSSRR+Y6jIX1poDm9ane61HRhIh R9kkrL6dBVxSE20cprbB9Vu3AB2qEHHuP/r1UtBFqwDQWcwA5Zwg/H/62azi9ALcMglvZ0wQY2x9 aXmMo3CGa5cvygPA7VSaYEsS7IwMYA6VhLyBAwDAA8rnJ96UdBsc5BXA4q5STRKQ6xXdej2x/jTp 7gy5ft/pR/2VxW7EiKBNx3sPpUMY9jk0gGt92gDXgXZCi+1IofQBWnOXP5UAQGgBtMQmM8UtgAAo fanuUSBgwqbARsvORTEIAVORxSBFhJAcBuD60hku30pgJjFABQMyTQBE3r6UITAuTEwB561bJHxM WsXGclDmqQCCXMRA9jVCHwT7GBHWgDXt9UkVQNxoAuw6oUJYt90bmPoKAOKnl8+aWQnBZt5/E8/o TUgS+JLNV06xK46/MR781D0YGdp8QSZFUcZqmCHXTuJ7iIAbFQgn6jihbAyCwXY6kjhhtP4j/wCt QwLq6aZpFlbbhR8oPrUOVhk39mAqFaTjOTgY3fWs73AVdNjVQu5zg5B70/aMQq6dbqTkMxJycmlz MY/+zbQhd0IbaMDJJpKbQEyW0KKFWNQB7U2wM+/f7FNAE3BWcZ79/enBXYmSeI4tgeTHDBfzBx/U VtswI7YD7Y555jUj+VAy9t3QTx/34zihAyfU8sYJR/FADTkJDYwCqkjpXMyh9TsAx1zwOB396uGo BEu1xjOO4qppIRaWsQJKaAsaJ/x6Sf7zfzNddP4SWc/DndKPSRh+tZyQ0SYqRk9hKba6jmXIKMDQ nYZ6Bc3nlQxyqjSCTGNvvWlrgWewxSegCUANxQIXFABSGFACGmAlIAzQMSkA2KVJQTGwYA44oAca AGn2oA5TVn8zxQxP/LC1A/EkmtI6Es5SzjiuTMZM7xh856jJrOU9SktC7ZvHMtsqvuCsZG9cDpQm LlIbGZm1CYqwK/fOPpmk9xllV4HFZSlroIjaLzrqKN2wnXb6/WqhqJkjIqu2xQq54Aonq7IaGHBq LagWdJXddMff+lb0xMW8bfeyKPXFbMklHC4HQVmUNxzQAAbmVfU0MDY7VICUDKkn3iaYEZoEMpgK OooGP4NSMYy4PX8atCFGQQG49/WhoCQqCKgZGVIoAekjJ05HpSGWEZXHHWmArLigDDRt0an2oAaw oEyJulNEklkBmVP7yVSAqhipqxDt5RuSRnn1ouBMt0F/ix79aLisRPfvckW1uCwY8gd/qfSi9xlc 2ckt0LQuA0gUHH8JIyf0pdQRs6/aCHQ0jXJWDaAT7cVm9WBhWkscLM0hYDGOPSrew0QySL52wD78 ZPtjNTF6FND4MLb7zwEZCf1H9aroQbFsQ0C46Vg1qMkpBYq6izpaOYwSeny9cUtwMqOCVFEsMZWY Hj5zz9a1tZAby9BWXUB1AFDVLRbkxsQSYssAO9XB6iZc8RRl9IaQDOFBrd7iMyxw06nnmIfz/wDr 0mUXg4iuLck8M+wj6g0ITLNyY2FlHuBwvlsAemMCiQIijYKi547VzdShXL7CUwCOma1UBBbSmaLc y7WBwRWb91jJkYbSV6Um7hYhhR3bfJI4J5ABwBXRGCsTcugn8Mda52rMaLmhDNpL/vN/M11U9iWc /ApF1cRkYy7EfnSY0S45rNjDO01DGdx4auRc6WgJy0J2n6dq1WwGrQAUARzF1iYxjLAcCkxoWMko CwwccihALiiwCM6J951H1NFmIpTXVqlykr3sKKowVMg/PrRZhcil8QaTF97ULcY9Hz/KnysLlSTx doif8vm7/dRj/SnysVytJ440lM7fPf6R4/nRyMLlJPG+n2yFYLK4wTnDMB/Wj2bDmGy+PcLlLFAM Zw0wz+QFPkDmOrsrgXlnDcqNolQOB6ZFZlHIX8v/ABOdal7Roqfktax2Ie5ylu0qTTmHBYRhcHvW ErXNUWNOJgsppiMMSsK/U9aa2uIvW8CRmaRFwWAB/OpTvcGNjMs5LByijoAP51UYqxFyfnAzWL0e gyKWPzXVW/1fUj19quO+oMdsROI1Cj0ApzaBF/Ro8F3x61tTRLK6nfdSv71UmIfNIIoyx59AO9QU OWgCWBd1zGPQ5pMDUxSHYYxwpoAptTAYaAEpiAdaBjxSGMPWmIco4wRlfSgBQSnfcvr6UDJBgjil YBpT060gG8qfSnYCaOfIw3T1qRmJFxuX+6aYDzxQJkTYpkhAdk6EeuKaAq3AZJ3B+UKScnoasQiR yTKSi/KP424FJsB8FmtwF81j9BxmlcZ0kFrbWlqHijRExk8f1oTBnL6ZfRLrX2i7kEaks2W9T0rV L3bkJnTaiUvNJnMTB0aM4K8g1hLQs4xOYwfaq3QluSmP545DwApH4f5zWWzsbtaElum+zuwBnERb 8jmtlsYMv2MgeH5elYSGE1y6y+XEoJAySegpxjcBLe5MsjxSLgr09xSlGwE4RQchQDU8zAytavJo pVhiJQbdxYd60pq4myPQr64luJIJWaRQu4E9qqcVEDZcHcMddrfyqIPUB7XQu4hY7CQYSC/vitnL UDJ04bL0QsCGSLGPyoTuVYsXSR/2jE0hwqqG5PcGo2CwCSNtTdo2BGQxx9aE7isXUGMj0J/nWLGP A4xVKdgIrmb7LAzqm4jsKLc0hFCw1rz7wW8kQXd91gaqVOwXNtFGelZ8zWgWJCMCpAteHzi3mH+0 3/oRrspbEsp6i8JdEQqZQDnHUUpPQaKDHmsxkcqkkYpNAdH4PuDFdvAx4lX9RTiM66qAzvEF5NYa a89uF8wEAbhkCmkBw/8AwlOpSW3mG5uRxyY4UCKfrWvKTczpNf1R93m6ncLgZHzYyfTiiyFcpyal ezbd93cHPUNKx/rRoBWe4Yn53ZvqTQBC0vPagCMzN24o1EJ5jepoGLHJuOCOaaYGiscksqiOFJWa NThx0HSgCJGmEUioqFBy5Krn8zz2pAeoeE5PN8O2Jz0Tb+RxWD3NDlbyQMmuTD+OdlH54rRbEvcx LAZlnb/aArmnualjUf3cllAOMv5jfWqXwkLc0EGIAR3bNQthsQYUdhQm0iSNpox1kUfjStJhcb5y H7u5v91SaagwuKolf7sEp/4Din7Nga1hG8FkxkXaRmumCsSyjbjlj6mlIEI/7y5VP4YxuP17VIyw BQBYsFzcE+gqWM0aQyC4HyjBIpiKrcUARmmAlMQq0DHE4FJDGjrTESdqkA5HI6/zqrgGzHzR/itM ByuG4PBpNDHEZ60rAMKbenSiwzIPyXDL6jNJCQrUAMZTmmIAtMCaO0jkIklXee245AouIbqTFYRE vV/5UgK1rIUkXPrTGbdzJnSXUEA7SPpTfwiZx9rp13qEjyWaI6xnBDHFXeyQrHW6JpstjprwzlS7 ksVXouR0rOb0GcsE2Fk7qxH60J6E9SdgXtlA7KD+TEGs38R0t+6WdDi837QvYwn9a3Wxzsj0dj5O DwRwaxkBckgDNuBwamMuUYscIQ7zy2KUp3GVX1ICQBIiyHjcD3pJAWZIYbuMeYgZf5U0+UVh1vax W4xFGFz1xRKVxj3GHj/3sfnxRF6iZRiu/sjtIBuyqj9at7lFe1uPO1kyBdoKEVURMm1KLzpUTuyM B9RzSmUitYL85fBUnK8/TNKLEzaXq2B3rKW5Iu8BtoBLegFNQbHccVVx8y5HTBFNNxAp2Oj29nOZ k3M2Tt3fw05VHLQErElnqiXl5JbwAZT+8cbvpTVJtXFc0WBzlsgjtWbVhljQCDHMB/eb+ZrqprQh mFcu0N5MACQrt+NJodyUc89iM1Fhj9uRSsMs6fI8F1FKoPyMDTSsB6Arh1Dr0YZFUBm+JU36Lce2 D+opiZ5IVHzgvtK9FwTu/wA4rVEkxICo0fD7SH3LkfUUAQbFXYQrKAAGzySecmgCGSPLnbkjtQAz yye9IAMXJx0pgHktjPQE4zigB8Ns8joqAlpDhcDrSAss0zPFCzBWjHlg52457mqEQqFfJYquASM9 z6Uhne+B76f+z4bfycwIz5k9DyayktSznkm36LM/eW5J/Ns0bXEipp5AQliBuk61jJXkzXoF9MJd VQqRtUkD8BVW0JsWdKvEuJhFdsiwKCSc4oS1E0ajXWgQjJkibHcDdW3KiAXWtKUZgiZ/9yOlZAO/ tuNoTLFaOUHckCndAP8A7SuMcQxp9Wz/AEov2AqTapM7GHdFgqc7f5UnJ3HYWF1CtyOOTQxC2YPl GRvvSHcf6fpipGWB0oAtaaOZG98VLYy6WAxkgUhkFyegoQFVjTEMNMBDTEKnWhggY80DFQYFJjH0 gCmAvfIODQABQ5x0aqAUMUOG6UAScY4qHoMyNRj8m99s4pISG96YAwzzTAWNNzgDvQIv7AAB6UgM qZvOmZx06D6U0FiJl2nNAFzUZCmmNg4DRE5/3mH+Bq3qrCuSeDogumySDq8hyPTFOfRAb5HFZDOI 1CPytSuUx/HkfjVRJZFIxW1UA4yWU/mDUNamq2sanhYq73foMIK3S90xZSsf3d9dQ9Nkh/nWMika OQFyeAKx3GNSaOTKq6sfY0WsCKzaeNrBHK56YqrgWbeJbWFYx0H60kuYCNdQh+1G2bKP2z0NU6bF cnm4UH0IP61CeozNuIMyGMdSrAfnWk+44kVjA8F5D5o+Zt1VBjkaF0Nt1at/tkfpRPYUQvsAxHGA Cc/lWUHqOSJ4/wCYH8qUtySWIBM+pOa2jNJCsOJyc1nOVxoUCsxmYuhRR3y3UM0kbK27AFbKq7WJ aNcnk56nms3qwsWNC8sPOEznJ3ZHf2rqp7CZg36n+0LjGMFj1OB1pN2BIbpspdJInxujYrwc8Umh o0o4lSLcWGfShASLdCNCoA5obA6vQ7zztKVm5MWQaQyS9lW+0W6ZAcFGGCPQVQmeTT7FuJwd2AW2 7fXPGfatVtoQQrl2KIGdyOAvY0NWsFx8sMsKt5sDrkjDMCMU7DIycArs5LBs45FIBMswCbQMEnPA P50AP2ygOmQFJGcHIJFAB5chQAucA5C4OAaAGiJwQ2/aR3x0/WgBGizy0pJ9cgf40AWbWK1iZJJD 53qjgkfpilYD0fSZYI/DBnt4UgQxO5VBgZAPP6Vl9os8/gZxpCKEJHmbifT/ADmk92CKsgaO3jVg oGckk4xUrVlvQfbx/uxcSRuE2tywwp7UNCuR3MYgtJMIyFwuFPpnNO2qJuVYvmBDYCN1J7Gteo2T QSKlwvklhEvPzVEo2FY21ljliQRMpV2AOPz/AKUgsW550jIUZeQ9EXk00xEcFsqKzPDGjNzhefzp 6thca1t56MnPON3OOO9U2KxdVSgA6gCk0gJARjIqEMu6auLfPqahjJZrdJmRnzlDkYNAyGc5c00D IGpiG0wEoEKOBTGIOTQIkFIoWkAUwFFAC4zQAobs/wCBpgJgxnK9PSgCv4ji2Tlh6A1AFJecGmMk xxSAsWsWMt+VUSN1CXybc4OGb5RSAzEdVA54FUIkIWReKQyLXpCunwQKPmdRnH1OP51p2IaNrSkT SNC8yUHail2x1qZPUor6f4mW6uo4ZLYxLKcI27PPbNHKFyh4hi2aqWHR0B/KojuBntCWKKOvXHp/ n+lEnYpK5c8HMVedSfvnNbr4TNi3ERg8QXDYwkgBH1xWMloNEl3bm6jEW/YpPJH+fWs4PUplG3t7 iG5COv3T1HQirm0CNcViAjruAwcYNVF2EU7jTRPdwz7tuz73vjpWrmgsW7gfum+lY9R2K11gXUTA g5J49MirnsOAkg/0q2b0Yj9KmmxyJtQGFhb0kFaz2JQl7uAiKEhg4wR1rGmtS5bE6pLghY3fgDIH fFU43IuSpFct0tn/ABIFHs2FyZbG+bpEi/VqapMLkqaVek/eiX8Car2Yrkh0S7Yf8far9EpqmDZL HoLf8tL5z+AH8hVezFcs29hBYqdkgP1NWlYTOQ1MZ1C4HBG/ioZSKtqxtr/n7so/UUgRrSkOy7Tx ikA6NQOtSM3/AAtOEupLc9JFyPrVIDoL4bNOuAmFwh7U1vqD8jza2f7PPKjsoSUFXYouemMdK6J2 hTbhuZKT5tR7waVHb77aaf7bv6gkDH/6qxpOXJee5ctzPlj8yUrKyr1O6Uk1qSR+UoDbSikdFEZO aLDHKo2fN5gk9AoCj8aAL2qRWiQW7Qyh3YZkXG3HPTNXbQDK+USbwEKg8qWJB+tZgCE+eDGiFzwE EW4dPQ0ACCZLnCBlmOeNoXHc9elAEL/KvPGCQcnNAHb2FznwHdH+6jp+f/66yfxFmDpukme2QzEh VHyFT/Sob1YFqPSoFuCZVWVz/Ey0ubUNS66qqbdo2jtimKxkahGzBpQMYU+nNapaXEVJ9Khu7JLi 0QpIVzs9aqLuDZkQN5O5eAcY5FOVmzRCQNJFN5kJ+73osmI6PTLiAx5UBXP38nkmsZRsxNGkoB5H SnEkY+IrnI+63FVIESZxIB65/pWT3sUDjaDtqopJCNS1Gy3Qe1ZlEhIAJPagCmxzTQETUxDaACmh CGmMcgpAOpDCgBaYC0AKKAFoAMlRxyPSgCXxHFujVse1SwMK2OY19uKYyyqkkAd6EBeVdq4oYkYu py+ddbAflj4/HvQhMiEG4YzVCJ4IdhAz1otcCK8j+0awsSgbURBz0JPP9a0tZErc6kRpPA0EqhkY bSO2Kxe5bM6y8M2FjdLcRiRmU5QM3C1fMIq+JYx58D5wQDn6VmnqDMeEhpBL0IfGPT5Tx/KpqGsN A8NP5d0PQkiumGxia2tOkNzCzIMu20NnpxWc0NFdriFesqAf7wrDlYwF1COkgP05o5WAhukHIWVv 92MmnyNhckhlklbC204HqyYFP2YrlkQXBHywt+NP2YXFisL6XIktwoPZSSar2YXKup2kkEcMrLgL IIz9cUTXujW5DOdrRN0w4rKGjLYt6zPCQOQGB/Wt5kLcl3ywvBPIiNEJAwVTk4DdxWMLcxUtjUt9 T8sOY7csGYtzgY9q3RA86tccbYYVz0y//wBaqvYRH/a10xQBoRvOBhSaXMwJRLevkNc7f91BU87H YWTzFjJe7lJxnhgP6UKbBo5a8+3yzTFL2cQpgffPBxnFWpCtc1LW2ibSYnc+bICQ7sSahsdrGfLC UuNvRR0FILDbtMxo4HzRncKEBdiYMgZeR1BoGTZwaQInsrhra8hmB+61JDO+cq1vIeNrIT+laJEs 8t1ZdvmKoORI4I9RmtSDNsxmNUWM+duyWGc49KBlyfPnDqUzyEbB6e9MQQ20lwzhI1cgDG6Xbj/G gBDamGNvM+zZ9WYlh9OaVxiSu1wsYVZGZBjIGfyp8yCw7+zr6aQOkF07E5yIyOfyqboLMux+Hb+e Tc9ldNlsksyr/M0+ZC1H/wDCHam7DEMEY/6aS5P6VLkOxMngW8kwJbi3Re4UE/4VPOVYu6xpp0Hw ddW6zeaZJUwcYxyOP0qb3GjPsLiWO1jGcnHcdKgocZHaUNuIbuam2oh00TPGdhYtjoT1qkBXeP8A 0NgByv3h1x71vHYzZRsL2RZnhmA3oQcdvfH4H9KS3DoJqENrHfndEOV3/Kev4d6popNmY1lukP2K VZB1CbsMPbFPZDT1LtihtWZrqFicYOR0Htis5FM0kn8lfMiPmQY5AOSKSbIHGRLqPzIH3r7dRTT1 FYktmMkwJ7CspL3rjLD+lV0AvpcKFG0ZxU2KQ15yRggAe1IYw8jPrTQhhFMQwimAlABjJoAeOKQx aACgBaYBQAooAcKAFoAv6ugktH9hmkwObiUJJIgIYBuCKBly2jyd3FC0AfdTCCB39Bx70twMFQd3 zcknJPvV2ILMZoAc0mFIU/MxCKfcn/CnAGNTm7klXqZDj6DgUSYJHR2xbykZsZI5x0rNlImnuI4I HlkOFUc0xHH6rcPNIzvw7Hkf3R2H9aQIp2522rN/tsc/RamT6Gy2E0c+W0L/AO3XQtDnOru7ayu1 U3ZQheQGNU0BXWDRLfp9mB+oqUkBN9v02IfKAf8AcQn+lOyAP7Wtx/q7SdvpHj+dGgFe+8RGyjDt p0209+OKLoRmt44nP+o0/wDNv/rUwGyeKtV8sOYY41PTqaLgOuLm4ubIST3EKrkOUPBY57CspPSx S3GXrQi3QImJP7w5LZPGaxjqzSRIIp5Y+qjI7mt3YzI5RfDaI1BkBzuUfKPrWSik7lcxchF5IIop nYRplyNo+Zjx/KtE7El1bbI6Hjp7U+YRPFaEjB4HoKVwsWI7GOPpnH1NTcY6S3jVDtUA0wMDWbZ/ sMhiG0ghyRxkjvQODsZegTuHmhLg5w4UnIHbNNoubT2NK9Q+VHIEIAJGe596RBVU73welSBLafun aA9vmT6VQFo+tSAoFLYZ22hXP2nTEyclQUNaJgzJl8JGaaZ5bwhXbICxjP60+YmwkPhexhuREbu5 MhGeMAfyouFi2vhTSwcvHI57lpDz+VK7HYnj8O6VH0sYj/vDP86LhYtR6fZwj91aW6+mIwKLhYSx E/lsblFVtxwAMYFLQCz06UAGKAK19a/aolQuYwGznFGoD3mRY3KESFFztByTSsM5Pxdem90K2zE0 RkuMbT7A/wCNPoBmgmOEBRkqOnrUoBhZzIpAIBHPtQwJ45ihAIJFCAtcMuR3qouwmjCuofL1INg4 Ufqe1aXvsTsS6jZJeRod4jkRcbycAVaYXZBoFpBFcTSSTRSSDG056dc1nJ3KSNWdopDiNN7ew4NQ m0MoyWLQMZ1AhP8AEobAP55o5mPQzzI1pK8oi2bucq/B/TFF7hoiS11K4ZS8EAJPdnH8qVtdRNo0 dLluLi4InZSARgBcYpN62Al/tGJL1ouVGSFY9GI6ira0JRoAh1yv4is2ihASp4oAdkMOOtNMLDSK oQmKAACkAtIYtMAoAKYC0ALQAooAWgDXuF3wuvqKGByiDbPtPB6fjSGjST5V2ikMzdTmzIsQ6Lyf r2oRLM8NzVkjTcHdsj69z2FTJ2GTR5+3woTxboZnz644/pWkdgZLZk/IfRc/nzUPcDobRwbYliFC /pUlGPf3puWDD/Uof3an+I/3jQSirc2xXS5LhxyxAXPcnvSZVjMkPl6b7sP5n/61Jas0ekRYoytq oHBC1tc5zPghklIOGOcjLHOTV3Ea63UVhKkaxKx24zjvUNjLunSTXJaSXhQflFMDS/nQArIkilXU MGGCDQIpvZRQSJsUAHt2FQ2Ow650+CaMo6g5/SqAwptOubVkOd8Uedpxnr61JtSjF7k1rmWWBip+ aTGPzppEzRvLEQeQB9TSZmSBY1IzIgz70gJlaHH3x+AoGPE8KDA3n8OtAx4uVH+rj5PqaAsSG6z0 jX8TQBG9y5OBtH4UBYz7gvtdCQQ/BGOooEZ1jpUFpK00W4lhjB7CquFi1IgaGUZ44IBOf89qGMrI FHYVADblTtEiD54+R7juKaAnjdZFUqeCMigB+MUhm/4UuNs0luTw43D600Bu21xJI8wli8tEPDE9 eaqwglurKGQvJPAj4wSXAOKOVgVJvEWkwnD38OfZs/yp8gXKUvjPR0ziaRyP7sZpqAXKU3j/AE9O Ira5c+4A/rT9mhXKcvxCOP3Onkf77/4U+RBcozePdSb/AFcFvGPxNCikK5nz+MdYmzm72D0jUCnZ Bcz7jVr65B827nYHsXNMLml4LvpbfX7ZNxKTZjYH8/51E9UNM6Px24NxpsA/vM+PyrPZFGdUgIFA 6cUANkdYxlmCihARjUFUZTkd+1JlJEc07XHfPcKvH6//AFqaZSiik9s8zdAuemOSaOYLIRrKO0AI kIuCflC/1p3JZuxSTGICNFjwOXK4/SjmRA1oEBDSkyOT8oPVv8BSvcLDzp6zDfPhnH3V/hX8KpOw FVYjDL5Xl7kYnOcDb9KBWLOnQGGdhnIGSKT3CxS1O2SQzx+WUDHcrE8bv6Zq29B2sN0i7lXEUxyc fK3r7GpsM2FIccde9SAYx0pDEz61RIYoAUCgYYoASgAoAWmAtAgoGOFABmkM2Sc5FMRyuoL5OpBh wPMH60gRdZxHGXY8AZNDGYjsWLO3Vjk0IRU3GVyqHCDgt6/SqvbURNCEEyRjhV+ZvoOTWa96Qwh3 fYru5b79wwQfTOa2YmSwOUJPbAFZsZM1006mMErB/F6sfT6UCLFnZNeShn4jXr/hUoY/xQwS0ggU Y+bOPpSZUTAu1y8UI9s/5/OnFa3HN6E1wwhhOBkkYH1qzJk7QCO0iBbCqNxGaYEMEUV2DO2S2SAc 8U2Iu2MyoGQYAzxTuBae6WJS5Vz9KQEbagvBijyTxyaNh2HybnQsX+fstYO9xoVZpgTlwRjpitk9 BMZLNJsYlzgDJxQIwLC8aW4t0Iwd5Oe/f/Gg2cdDoSFTk8k/zoMkSRnC8ikMBGA5YZH0qQHhcHqa AHhsUwHZJyOQcdaAGQiZDhhkfWhALKpbnHSmIhxjkUALty2OAGGM4/IUAUgME1Ix46U0BBB+4mMX 8J+ZP6imBeK5XNSxk+nXBtb2GXsrc/ShDOo8Sr5uhXJUnGzdx6f/AKq0TEeTchQgO7A5J71rYhsQ lhgEjFMQqqCpJcDHQetSAhRT3Y0XCw+OyllP7q2lf6KTRdBYtx6Dqkv+r06b8Vx/OlzIdi3F4Q1u T/l0SMf7cij+tLmCxbi8A6i+POuLeP6Emk6jHym1ovgmLTryK7lu3lliOVVVwv41Dk2NIz/G8rN4 htY1XcEgzjPqT/hTktA2Mr+0WtwTcQyKn94LnFZRTG2Tw38E6BomYg/7B/wrSzFcq6h5J/fPvZgP lXoKNQuQwWrzYk2qdvRQ2AKTKTHpJO52LFjB7dB/SkXzGhaQSSg7jtJ6nOWP4/8A1qm5PMXY7aG2 yQAXPU9/zoEAdpTiIBsd/wCEf40xE8MIjyclnPVj1NMCXFAEFzCHTPOR6UAQWM4ErK33iODQIGbG 6G45R+jHtVsDGTfbtMv3jA3I749R+f8AOmnrYDWt5RJGsiHIYZGKHGwi2jb/AGNZspClM8UhgPl4 NMVg296BgaAExTEJQAUALQAtMBaBBQM2M80AYPiGIgq4Hb9akCnfz7oo41/j+ZvpTYzLuHMj+UvH diOwoEAIjAC8AD8hWU5XskCQ22PmQXE3/PQiJfp1NbxXKhFq+ISO2gHAA3n8aGIgyZRtHEYPPvUj LNvCZ5UUfLGDzikM6iGNYIwijCigDntfcS6lFGfuovP86i5cF1MuEebdPIR9K0WxEncddI09zBCm Rk5P0FVEk0bpMqAV3L0OBS6gQsVSPagAA4AFVuIz5HZN4Vtp7GnYCvJDcMfmlOfZjT0An0a0l+1v JLykfTnvRJoDZfdvGDWQxJ5Tb27SFS5UdB1NMCIT/a7BpYhhmU4HoaBGXokLteBmj2iNTk7cc1TL u7WN5Yj5hkY54wB6VIiRRx0oAeq0gHgUAKAKAAcGgCRc59qdwAjrQIrzZjBcKSB1A70APiCqyswJ jzmgCnOoEzgDoTUjGiiwEdzGWjDJw6Hcv+FMCzZSiWMY79qGgHsu1qko6/THXUNI8qXkFDG49sYq hGGPAFiHLfap8HsABVczFYkXwlo1tPHFIs8rv0y3H44ouxWNKLw1pEONthE3+8N386ltjsXYtPs4 B+6tIE/3YwKLsLEc10LSV2nCQ2qL99uOfb/Cna4NWK9vr+n3EuwSMno0iFR+Zp8tgRqYyODj3qR2 IbSA28ZVpDISScmgCahgea+LUe68U3PloZDHGiY3EDpnt9aJu2gGfJFi2fdbSocY65yfxrJOSBil xFCigyAKu0qpIoc2CIVlkIG2TaRyd3ORTU2FiRAUl82Zflf7gAwDT5rjNaByY1MdqygjgHAoTAcF nz/BGPbk0xBGSJQtwrSjP3gePxH/AOumBpqAAABge1IB3SmAUABFAFeSDbMJUxnuKYiGchx5b9P4 WPamnYGZGGh1By3LFBgeuOD+lKW90BYsW+zTmDP7l/miJ7f7Nap3QmaIyvIqHGwInjcOOeD/ADqG ihSM0hiA7eD0ouApAwCKYCUCG0wCgAoAWmAooAKANfoaEBn63HvtdwHSpYHL+YfmZjyvH4CmDIYu I/Mbq3JokxFe8kKpsH3m5b6elTCN2Ddi4gWGG0ibgBTI/wBT/wDWrd6AguXE87SdE7D0HasxCwDz CMDagqWUaUGFIVRjNJAbdvL5sI5GQMGmwexy98++9uZM99o/lWa3NVpEklt1t5VVehUfnWpj1HWq AyGTHI4BovYC0aAI5IFkHHBp3AzriAo/zLxVJkkMisvOCBnA96YGnaReRbAEYY/M2PWobKJIstzm kA8r260wBY1RdqqAPQCgVhdn1H0pDJRkDt+NMBTyBQAgNIBwoAcKAFCjOaAJVoAUjFMQ1lzQAz/V g5BKjnCjJz7UmBRlIaRiARk55oGNFADsUALZ2UrySyQ42jkr7+1NgWpEyvuKgo1/C8+2SSEnhhkV SEzo6AKeqz/Y7OS7SJXkiHGfc4poT0Md9Zvy4TEEZPojN/WpckZOqkaWj3VxN56XTKzIw2sq4yCM 9Pzp3uaRlc57xzqAheSJg25IVMRHQMzHJ/IY/GtYIJM4GK5nSQFWJbOMHv8AWraJTPX9AeRtKiEx JdCycnsCQKwZoaFICtc3sNtJHHKTuk6YGaEBxM5Mmv6lIP8Anrt/LilPcCfaPSkkBG8Eb/eUUnFA QmxhI2gHHocH+dHKhixWUEbBgg3DoaSQixjHSrATFADNoUlj360ATRSkcMcrQBYBBHrQAoFAC0AI aaEVbm3Eikgc0wM7U13Qecg/ew849RS3ArTAXUOVypzuU+h7U4uw0zQ0+4aeHbJxMo+b3960epLR YwR0rOwIljk3cE8+tKxRIVPSoGMBI47VQCk8ZFACUwENABQIKYCigApAbB60AQXsYktnHtQBxN58 nmL/AHsfzxTQCsQM5+6gyaz3YJWM0MJrjL5Ck5P+fpW8VZEt3NKWTz53mK7YwBx6AdBSYIarGVRk YUnp7VIy1GMYA6CpGWYuoHXNAGgP3Ns7MR8oOT60nsO12YcEZlmRT3befwogtC5voTTZaYy/w5Kj 8qoyRPaKRED/AHjmgCcjmgBelAxGVWG1hT2EVvsgEqnqg5waExJBeRGQxkFgUOcA8H60IZYiKqoV duaEA49fSkA4N0z0oAQCmA7YHUqeQevFADxEIolQdhigBuKQCjigBw5HFADgKAHrQBIOlABjPHeg BpXtigCjdxhH4HXmgCECkA7FAE9ncNbTBx07imBbvNpctGflkG5f60hiafJ9l1CJ+ilsGhDOokvC l7FbiJmDj746CqELqdu13p88CEBnXCk+tITVzGGjXcm0yJahl7sS3+FQ49TF0jT02wktHmkllV2l xkKuAMfjVo0irFTxHoY1ZFdNvnKpUq3AdfQnt7GmnYpnF6P4ekl8QyWh/cyW3ztuO4j3Hr1q5S0E kekW8KWsCQxjCIMDNZ7lEvagZG8UbsrOisUOVJHSgDgbI+ZNdyj+OZj+tJ7iLfagBoGaQCFAH3Dr QAtMBc8UAGKBCEZ60DAigASQxf7vpQhD1vImkKA+gB7EntRYCwDQMWgBpGDTEVLuAEFl9ORQBjWy lTLAfvx84/vLQBEzyWlws0fzKDkD1HcVonoM3onWSNZEOVYZFQ9BCkYORRuBNHKGGD+dTYoVlpDG Z2mgQp+bkUwEoAKYBQIM0AGaANnvQA1xlSPagDjNZh23QA4G7/69IDPvHIURKeW5NCjcVxlrEMZJ wg7+ta3EkaV6/l2cVqoAaQh2A7DsP60hkUQx246CpAspUjLlomWyQOO9ACarPtjEK9W5P0rNvoaQ XUr2K7YXmPGRgVrHRES3JXixpqNjnduP40CJYlwBjsKBEnagBMUALigCOWQRAEjrQNjYyX+bBAPr TEMuVuEbdbxRM2MbmODQrASW/nGIGfbv77elAEvQcCkA4dKYD1AyM0ASsMrQBHikAYoAcBQA4LQA 4DFADwKQD8U7gIRQBXu4yyZXr0oEUQMUhi0AFMCeF+FDcqDmkMmIDLleo5FAzrdOm+0WcUnfbz9a YixQwKst4Y72O3ETEPj5vSmgLZ4pANouFiJLaBJ3uEhRZnGGkCjcR6E0gG3kLXNtJCrmMuMbh1FN ANsLY2dokLSeYV/iP1oGPnuI4onZnHyqT1oA4TTE8u3IHJ3nP50m9RFiUlV4pAOXlRQAbaYCFRQA oFAC4oEIRQMQ0AQ3cTS28kanaWUgH0NNaAULDTrm1+ZrtmJIJXGR+tNtCsbUMhdfmG0jtUjJc0CE PXFMAFAGVqdq0ciXUI+ZDyPUdxQBWdFdN0Y3Kfm204sFoR2F2bWcwOCIXOVPYVpa4M2j0rO1gQ3H cdaQySOT+FulIY5lxQMZnBoEO4PTigBKACmAlAhCaANzaaBiONuD+FAjndXt0a5y4yuNx/CkBzSx NcXLL2Bwx9a0ihGqsEUA3uB5cXb+83pSYFIu00zTP95jSAmT0FICzGvtSA0IiIoPMfoBk0mUY00j TvJKenOKixqtEWiSlhEg6t2rXoYvc0548WjIP4R/KkIgj+4KYDsUAHSgYUCIpgGG096AHxL69qYE p6UgG0AHQ0AO75oAVMFhQBZx8vSgCMjFABwKAFAoAcKAHEUgFTlRQA8YFIBTVAxrLkEYoEZcieW5 X0oGN70ALQA+OkMnibBx60DN/QJdsbxt93ORQI1g6qMCgYnmDOcc0XCweafSlcBDIfagdhu8+tAD Tk9zQAmKQDXUMpBHXigDkxbmzubiEn+MsPoaYhzDIxQ0IAMCmAAg5x2oAMUAJ0OKBBQAc0wE79DS GIetACEUARy+YNvlgZz1PagCe2lcoFlxvA5I6GmIk2Zl356DAHpQA88UAIwDKVboaAMWVDZXYjP3 HOUPoe4/Gk/IBZ4FdCyj5T1HpVxl0AdYXigmCR87e/pTaKtY0OlQIaw/OkA6KQrw3SgY9lyMg8UD GcigQ4EN9aAENMBDQAhNAGr5zetSMilmIHOTzwKEIytWlz8vc0xGdaQKJJJpCERR19z/AFrRaAVr yc3DhVG1Bwq+gqGwECbVFAMkjHNAi7bqxZccc8mkMj1W5ywt4z8q8tj17CpZcUUT8sLD3259+9CW pTehogj7VAhHCAHFWZGnKN0LbWGPWpAqQElCT0ycVQiWgYhFAhrnaM0ARAq0gJOD2FAEu4AgE4J6 e9ADx0oAQrznJoAMjFAApPPGMGgBRIqkAnmgC0jAr1oARh6UAN3YHK5pAOVs0wHYoAetIBVXFADw KADtzQA1GV1DIQVPQimBUvowG3Y696AKlACigBU4NAyWpGaGnTmOVWzwv3vxoA6IGgAoGGaACgBK ACgApAIaAMbXYNrR3Kjp8r/Q9P1poRn4oEIRTAOlAC0AGKAG9KBBQAnNAxCOetABigBCOKAGGmBL HMA21jjPSgCfNAhp4+lAEN7apeQNG3B6qR1B9aBmZBJKgKyL+8Thx2PvUXGRX9mCFuoMgr94CtYu 4FnT7zzP3UnDDkGhoRe71AxrCmII5ChwaBkxAYZXpSGR9KBDgc8HrQA08UANJoAv55pFDJOWB7LQ SYt5JvnPoKYFO8uB+6UDG1cEevPWmIihQk7j1NILEr9RTBixj5gKBFwym2hdyDnoqn1qWUkZyKZH x1Zj+ZoWpo9Ca6jVJoIV6AjNPqR0JI3Jmdx9KOpCNCEERBT1PNDGKqBVAHQUxDulACUANkJ2kLjP amBHHCAAxA3UgJQozQA+gAxQAnTrikA5eaYDTDHIwLICR0J7UgLEcS+9ABKGjHAzSAZG+6gCQCmA 7FMB6YHApAOFADhQA7AIwelACJGsaBY1CqOgApgRXKZjJxkjmgDNIxmgBOlIBR1oGSDpRYZICQOD ikB0unz+faqe44NAFmkMKYC0AJSAKbVgEpAFAEN1Cs8DxN0YYpiObj3LlH++h2n8KBDqYBQIg3bm O3dxzg0hkq8jNACnimAmaAENACdKACgBMYoAaRQA0rTAdFJ5fB6fyoEWAQeQcigBR19qGMrX0BZf NjA8xRznoR6VAynBKrrwMqeGU9Qe4NCugKzW2yQrE20j5oz/AErVO4Fu0vRJ+7mGyVeDmm0ItNUA RsKABJGQ/wCeaBk2Vddy9e4pARlsd6AHKxPBBNACbGPbFIZdzigZWMn7l5D3JxTJMZzuYk9zQBUl j3TBj0xQgLCjApAIetMQ6IHdwORQBDcSmVwAeF4H+NSy0i7psAVfOIx2X/GqSsKTKrtvu2f+6CaE D0JIBlUHdjQSaa8H6UAOApiFoAQigCMglhimBIBSAOlADgKAEJwcd6QCj0oAeuADTAVcUASpwaAF fpQBHgA8CkA5enNADx0pgOXA6UAOFAC9qQDhQA4UAIQOnamBmXKFHPoDihgQHikAUwJFNAyQHikB p6LPslMZOA3SkM3KQwpgFABQhGTa380uryQbl8kFgBj0H+NS5e9YqxrVQhKAEoAwtWh8i9WQDCTD B+ooEVsUyRDQAbR6c0hjQMUAFACE4BoAbk0AL24oAFJ6EdKYC4oAaRQIaRTAY3TGcGgBInljk52l MfjQBciYMMilcY7jPtSKMu+tWhlM8C5B++n94e3v6UCIJI3nhDQglh8yHFNSsFiR7Oe5hSQRGOde Rn19KtSCxagtbhfvbQpHIz0qGxE/2Vu7flQMQ2ygckmi4CCNST8hBHfsaAHLsIIGPpQAoOMDvQAp DL1pDQXTlYWx6YpDKd43l2yIPSqJM76UIB2oxeRMoHQAUhEYNMYmO9IQkrGJBtOCaBxRHawmaUIO M/oKEW3oa9wyw25xwMYFUzNGSmfKZz1kb9KEORetVzL7KKQi6OBTAWgBaBCE0AIoxQA4UALigBfp QAY7dqQC0AL0oAUAUDHr1oAfmgBMUwFxQIcowKQwwO1ACr0oAeKBDsUAOWgANAFS9jzhh+NNiKBp DEpgOU0ASjpSGSwSGORWHUHNIZ1ELiWJXHcUAPoGFACUARR2sEcxlSIK5zkj361HLqFyWrASgAoA p6tb/aLNlUHevzKR2NAjDRt6AjimIXmgApAN7kYx70ANy3mFccY65oGI2aAGnOMc0AOT05/GgB2M UxBQAGgLDdpPQE/QUXCw0Wc7zA+VlMZGexouFiddPlP3sClcdiaKwKf8tPyFK47Eotl7lj+NOwA0 KKvCAntmiwDWmgjHzuiH0yKLAV5NRtV6Sbv90GnYTZWfVkH3I2P1OKNBFWTVpj9xEX680XAge+uH /wCWhH04ouFyFi7pvd2Izjk00K46CX7FP1yrdcU3EEzZV1kQEHIPINSWSA7xg/eFICG8OdiDueaQ FG/fdIF7CqEV4BuuYl9Wz+XNUgLetR5UN7VAjNU/KKBkh4WgZVnYySAdFHWki1oa+nW/lRb2GGf9 BVmciDU5C7rCnU8fjUt3dh2srkMiBJkjX7qCmSW7NMIz92NMC3QIKBi0ANbk8UCFXjg0ALigBwFA C0AFIAxQAooGLxQAo6UAOB5pAOz+lUAo+tAh44pDE7kCkAdKBjlPNAiSmAoNADhQIimXfEy98UwM pxtYikA2mAq9aAJaQxVPNIZu6XcCOErKdq9VJoA080AFAwoAKQhKYwoASgBKBHP3sH2W8dRwknzL 7eopiIulAAaAGmkMbj05oAVYpn6Rt+VILEsdjcHqmPqaAsTDTpD95lFO47Ei6cB95yfoKAHixiXr k/U0agPEES9EUUagMaaKEMZZIkUHg5p2AqTa7p8PW4VvZeafKBUfxLCeILaeX0+XAoshXK7+ILjJ zatEOxKk0aCuNGp3FwMrMQPQLjFK4XIZZWb78jH6saVxakDyogJNACBsgH1oYCE0gGE0AITgUATK MW65781aEQMgDDjI70NsCxaXnkKUcFk7AdqRVyQ6wDIFWMg9iTTC5oSHdKW7IMfjUlGXITJKcdSa Yh9ip+3Pn/lmuPxJ/wDrVaRJoXy+Zbn2qGhmJGMMy/3TigYs0mAQOuPyqSkLp1v503zfdHJ/pTBu xsTyLDGW/Kk3YS1ZnWa+ZM9ww+VM4+tC7lS00Ii2XkfGe1UZmjCu2NB0wKYE1MQtIYDFAhhBLYxx 60APxQA5RxQAtAB0pAFACigAyAcd6BgRmgBFQjvSAkWgB6jvTAXFMQ5RSACOaBi0gDFAD1PGKYCi kA8GqAO9AjNu4tkjEdzwKQFWmAqHNAIl7Uhir1pDNGwncMmOVjPPsKYjfHIzSGhaBhQAUAJQAUAJ QAUAUtUtvtFvxw6HcDQIqLppIBMg/AUBYlTTYu5Y/WkMk+yQxjIjDUASbY4xnCr+lFgIGvYY2bfN HjsB1p2C5E2q2w4Uu/0X/GnYVyvJrGGAS3Yg92YcUCuQvq07fdWNfwJouFyCe8umUYmILH+EAU0x XIvJuB88kzSRn7wLZxVq4DHSF9KVXwSZhwe/NJoByW8Mf3I1H4VFhjyoosgGkYoApXj8hVPJ6mjY RVXfli5Xk8BRxSbAR0V8ZXOKWwD+iigBhNACUAHXAoAmaTkKO3FWIY+epHXpQMrueKTAiEhBwnHv TA6K8YRxsBxmkUzK3FSCDyDmgCxpbeYss2QWkcnrzWiJNAnfEy1LBGExEUjnpUFEH3ycg59PU0Gh tWMIghAP3jyx96ZG5Vv5mmlWGPnP+c1D1KSsWXUW9oFXjtVPYllO3BZkH945NMk0165poBwNAhaB iE0CBetAD6Bi9KGAUgA9KAFBoAUUCFGKBi4oAWkAAc0DHjigBaYh2aAF4PWgAFIBQKAF6UAKKAHg 0wFpiK94gZQfTr9KAMo8HFACr1pMESZpDFBouMtQs8asBkbh+lFwOgsJfNtkPccGgCz2oGJQAUAF ACUAFABQAhoArKNjGMgccr9KAG3DmNNw6DkimJiwyxvbrLuABGck4oBFS/MFxbsoljJHI+YdaQMx aCRDQA2gApAMkzt46jpVR3EV47yeKyaNmDKxwMk5FbICs0wihMjk7UYE4pMDWhlSaNZIzlW9sVmU PNICKZwi570wM24faQxBIGScUhESP5gJx3496mwDZI3cjB2rTsBL0FIBpNADSaAAHb83pzTW4Eds XZmkfv0HpWkmkSSk8YycVJRWmbFAEI4BPrSA3dQkyQBQUZtzJ5cLt3xxTQmVNP8AM3pglV7mtSUd JbOSBu6moY0ZOpLsuOBnnpWZaH2EO595HC/zoG2Wry5EMZUH5jSBIZYQFcyyD5m6ewprQGLqT8BB 9KCWxLNfnLdlGBTEXV6UwHCgBSeKAGA5agRItADqBhQwEB5qbgOOccHFAEUcq/aDHn58ZxQBYFMQ CgY4UAFACikMUcUCFoAUUwEYbuDQA4UgJB0oAXigAoAAefWgCVEduiN+VO4WHm1lkUgpgEdzRcLF UaFIxBeVR9BU3HYnTQoh96Rj9KAsSnTbSEAsjNzjuaLCLkNnbpwsKD8KYyPUIgLYMABsP6UWAh0y YeYY89eaANOgYUAFACYoAKACgAoAQ0AQ3C4AcdV6/SgBhKsduRyOnrTEYdwDCz25+4DuX6VMthdS my7W3Kqk9CSccVndjGh1LFVYEjsD0q0yWOqgG0AGaQBimIyZmzKR05rZbAMJJAH8O4Ej1pMDeXAA AGAKzKGTOyrlFBPoTjimBUmkLn2qWxEDKGPIzikIMY6UANPSmMY1IBtACGgBC2FPvTQAhVVGc4z2 oeoAzYz6VQFJ5N78UARyOei/QU0K5ryyF2yakspXp3bI/wC8c00SxNOwhA96u4jbRsMKSAraqmcM vB9ahlIUSra2/BBJ6Ui0Q2kTTv50vK54z396SBs0lpiMy5ffcfTmhElu0GIgfU5qgLINADgaADOB zQIQdODQA8UAOzxQAhPFJjGA4BNSgJU6U0gF2LnPeiwDZiQFI7EUxD1Ybio7cmmwHg1IxRTABnd1 49KQC5oAUe1AD1jc9FNAD/ssrjGMfjQOxMljJgZYUgJksR/E5/CgCVbOIdcn6miwWJFt4l6IKEA/ 5EHZRTsBHLcRrtxPGuDz3yKdguMfU7VDy5/BTRYLlhT83APTJ9KVgI57gwsAVGD3NCQMWW6hgXdJ KqACmIqyXsc8kYhmYYznjAIxTTQmZ9zJ+9uELErsBwT3yKt7Eoq2dx5F0kgPAPP0qLFnWowKgjoa kodQAZoAKAEoAKACgBKAEYcUAc3rep3em3CwxrEImGUYqSfpVol6FD7XczxefdZGGAQ7cZBznH6U mIr+XblgHkErn+8Sc/hUWAnREjGEUKPQDFFgHbqYCFqAGg0gCRtqMfQU0BhiXfO49O9bdBEm75W9 aXQZuhgFGSOlZoZBcTDbtU0XEVDIB1OKQBuyM0AIWoAaxoAjJpANzigAoAY/B54FUkDFJ+UEdKmw Ir3Em1cetUgK44XPc0xDU5JbHA4FUkI1mOSTUGhRL775h2RatEMdZH+Y/nTA20HSkAt6m6AVLKRl 20D3MuZM7F4+tSWawAUAAYApkg7bI2akwMkNudj74FUhGnH8qgDsKAJQaYDs0gGbgWwD0oEPB4oA cDQA4UDFPSkwG4wOKQD1PNUA8KT0B/KkA4QSNwENACw2UwXG0DmlcCwtjIepApodiVbDnlqQWJVs ox1yaAsSraxD+EU7MB+yNewFFmBFNNEuMTxxkHJ6HIp8oXIpdVtYjgtyewFOwrh/aWR8sTfjgUkg 5hpv5m+6qL9TmnYVyKW5umHyzhD7JQK41pZW+9LIf+BY/lQFxvynqM/XmgABAPAAoAbJgqQemKYg Oo3BtsKxyBgbeDWPPYtFa6mmMBbe5bGeTmkp6jYQzfaIg5Oc0SbuJBEdj7NzMw+bkf1ouDGy3AY3 Ax82Ac/Xt+lbp6ElVDzUjR1ekXPnWsYzyvympKNCgAoGFABQAUAFACUAFAGT4gsReWRIHzxHcP6i miWjjxKXYuSdq8KKGIlsUyWmbvwv0qQLeaAELUAJupAJuoAbKwKEHpiqjuBjIgUM47mtRDozkN7D NJgaJkyBWYxhOaAGNgnkZoAXdxQA3dQAhPFAEZPNACE4osAzeSQF607ATooZMNgmnawysx8vMfRe oHanYRUkbzH9qQDHO44FNIRSuLo+aEiOAK1SFc6FmwCawNDPj4maT+9kVaIJrRlUHJxgimM3Ip7d yFSUFvSiwWJZhugYVLAo2RwGHvmkUWs80gIb2TZEB+NICnbJ86D05NNCNBfWmIeDTAXNACRxkMxV Tljk+9AEoR/7poAlSCQ9gKQEq2r45OKAHraH+JuKBkyWsY6jP1oAnWKNeiikBJtReSAPrRYZGbmF JM+egUD7oxRYLgdRt1/iJ+imnyiuQzazDCMlWA/2iBRYdyhL4kkY4trbePUk4oukIjfUdYl+6sMQ p3QXI2/tWb/WX5UeiDFK/YQR2sqHc9y8nqH5ouwLN3GYUi3cCRSP5VYiK7gEbRHHHAHHWlcLF0Nx SAN2KADdxSAaWoAN1ABuoAazcGi4FTzBHGwfdg/3Rk1k1cobJdosaqY5MEcZxS5WFxliJF8yJAp2 n+I9ARmqauK5pJaORlpyP91QKpRFcpPGkcc2CSxYA5/GtEhDBgAcVLRSNvRbiNJY414Z1O76jpSK N3NIBaBhQAUAFACUAFACUAIwBGKAOH1qxNtfmFBiOQ7lPoO9DJaFUBVCrwAOKQgLYoAYWoATdSAN 1AENy+2NvpWkNxFMY2BT0qwGbo4GkVuBzg+o7U3sBaVvkH0rFrUYbqAEJpANLUwG5oARnxTAjMlF hEZamIVTty3p0pjJYZSz8jGaYyvf3MCfK0nzj+6M1XKIr2/lXGRFKd391hg0nEQ9Y0jySefU00rD Im+zK+cKT9MmncDSvcJa7weWOMVkWVduLceoqkSxkY+RvwFAGjZ2hZlkbjHSmBrZwuCahgUUjdZ8 hTswRQUWQr/3TRYQyaye4PLbRRYCSGxCNncc4oEWVtV7k0ASC2jHamA6NAM5XFADyVQfwj60WAat zEijdKhPtTsAhv4R93c30WiwXGjUQQCsTf8AAjiiwXGtqEvZEH1yaLBcYb+TJBmVPoMUARm73dZ5 G+hqboQw3EQ5Kkn1Y0XGh0dx5j4ChVx0FK4EVxNM8wggO0kZZj2FAD4tOiVt0pMr+rGk7jLiKFGF AA9qEArUwE6U2AoNAh+rL5mn2rDqDj9P/rVaAqwyyTBDIBiMbRjv70mxE+7ipAN1ACbqADdQAm6g BQ1IALcGgCsTmpGVZP3bZKKc8jNMCKykkaRpQxDMeSKYjasZmNs7ySBsyEDnmrERXsbQx4cKCzA5 Vs560wKmeBUspFi0kMcyODypzUjOwicSRq46EZpFD80AFACUAGaACgBM0AFADSaAMvXbXz7XzEGX j5HuO4pAzmg3FBAhNIBpNACFqAEzQBBcngD1NaxEQPwaoEVXXz5wg6Dk0m7IC+OBishiZpgJmkA0 mmAhDdgaaAaUJ6lR+NOwhrIqHDMc+gFOwChB/dP4mmoiBxEANxAHtTsMgupRGNkXBI5NUkBjTqSS RVCJtGieTUoQmeDk/SkwNK+iVZ3CqCQckGpGVQpHbFAi5eNlkjz71CLGzNtXaPSmSySzQMFz/EwF A0b8cajsKQ7EgIHagBGkVepA+posAw3kA/5aL+BzRYQC+iyAN31xRawDvtkIOc80rgNa/Xadh59x QmA06iducfWhsCCXUXYEKOCDyKLgImNozyferJJN2KAANg0AO3UgELUAVbkM0o2ttOM1NxoIxsQL 6VAxzAOuGGRSGPhIjdABgEmmgZa4Dh8c4wfpVCLINBQ4GkApPFMQ3FMQucCgBl7P/wAS5V7qw/rV gNXhQBUAODUgELYoATdQAu6mAE0gEzSAC3BoAhDDPNICheNtL/pVIQ+wZYos9W7U0BopbLGMgnP1 4piK8hPkgFQPm6jvx1poCKORZIg6nihoaJom5HOKgo6jRJ/MtdhPKcUFGhSAWgBKACgAzQAmaAEz QMQmgBrcgigDj9RtzaXbx4+Q/Mn0pEMqE4oAaW5oEJmkAo/WgCK5QrMkZ6gZNbJWQitcNsUmmAtn bOqb2U7m5yayk2xk5Tb95lX8aEgGExj+In6CkA3zVHRPzNADGuGHTC/QVQEW55D1JPpmgQGIY+cn 6CrSAJbhQc5yemc/1qhEfms3cAe1JyGIACw55qbgLcwFmkck4blSBxn0rVMRVSwublgkMTHPcjAp isdFpmkx6dEed8zfeb+lSNIZcWQM7SetN7DtqRCFCuJEBx3NQOxls++5Y9h0oSBjJWyaYElvcNE0 QXGc55pWEX2vpz/GB9BSC5E10x4aZs+maA1HAAAN1zxzTQh64X7oA+lFwH7uKT2BEWMMF3NknNZF okY4U0IRIvK4oYEZOInBIJA7dqAJo3+VfpWpJJuoAN1AAGpALuoAinYLh8ZxRYa0I0lDgkcDOBUW HceWODt69qLAOi81iC67cMCOe1NWQMt7qAJoXAO38qBkwNIYFqYrBmmIhdySeeKVwIZ2zbyD0Oat agPjkyin2qGA7fSuAm6kAu6mAoagAzQAm6kAE8GgCEYBzRcDPuPnZsHvTuBPbpmVB6c0JhY0i/yn NWIpM2VCkn75/pQhGGrvHMgEjLg4NaPYaRrSTBYJFdtrFCoPrnj+tQkGxueGbviLJ+8NrfUVLLR0 +akYZoAM0AJmgBrNgUDsMUuWyeB6UAPzQAmaAEzQBk+ILTz7XzUHzxc/Ud6AZzIyw+UE0iBfKfuM fU4pAAjGeXH4c0BYnVVgjMgyzj7qkVUdwsZkcu+Qs5y561t0JK8n72fb/CvWpkwJn38fMR9DWaY7 CM7SOzyY3e3em3cBpcCkkBCZ0Z9oYZ9KpxsIkClhycKKEhg0qxjCjn261SSQiFmLdTgegoAoyRTz SkbQqdielVdJCLccexAoyQKz6hYlRCBkKR9RQyizYSMJwM8AHIqogbEE7BeQMGrCw5pj6CkMiklG 3LcCgCsdsnbimBgQ9T9aSJY2TqfrQMRf9cv+7QIsQdaQCqB5vSkBbP8AqT9aYhV6UAOpPYaBetZd ChZPuGhASJ0FDAZIMRP9DQIdH9xa0JJBQMWgSFFIBaYyOXoPrQIcigdhUjHjrQNEi9aQC0APXgj6 0DLY60DE71QA/wB00CK/aoAhuD8klaREEH+qWoe4yYUhB2oABQAvegBR0oGB7UCBqAITSApDo/1F MCe0/wBa3+7QBZBPr61YiGbpHTAxT/r0/wA9606DRqTAGE5APA61ImWtBOC2OMSVEikduPuj6VJY vagBKACgBv8AFQMWgBKAEoAKBEcvMbUAcl0LAcDnipI6kGAZlyM0mMtMAOgxSASL/j5i+p/lVQ3B mDLxeS44+Y10kCW/RvrWMhknapGI3SqQitdcW74qkIoWn/Hwn1q5bCNeTjH0pIorxfdakACpEWbd QSMgUMSLqquPuj8qCgbpQCKtsAJZMDHFUgNNfuirGKaQEcg5FAEU3GKYj//Z ________________________________________________________________________________
Subject: Re: collision avoidance
Date: Dec 19, 2007
Lack of viable competition creates a stranglehold for most competitors and hence the customer. More suppliers, constant demand - better pricing. The GDL-90 is made in Salem, Oregon. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Tuesday, December 18, 2007 7:51 PM Subject: RE: RV10-List: Re: collision avoidance Since there is nothing proprietary about ADS-B, how does "Oregon based Garmin" have a "stranglehold?" William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > The ADS-B transmitters were turned on in Salem, Oregon last Monday and > are working in several eastern seaboard states from Florida through > Washington, DC. > > Someone needs to break the stranglehold on Oregon based Garmin so that > "Supply and Demand" makes this a more common of a collision avoidance > system than $7K. The EFIS solution is being solved one RV-10 at a time. > Till then, some are using ZAON patched to their GPS screen. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay > Sent: Monday, December 17, 2007 8:29 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: collision avoidance > > > This is a scenario where you would be hard pressed to beat ADS-B for > traffic awareness. You are outside of radar control or controllers are > too busy to notice; ADS-B would give you a clear picture of traffic > (altitude, bearing, and direction) without ATC help. > > Unfortunately, most people don't understand it, and no one is using it > yet. Not cheap enough yet either, the GDL-90 is about $7K and you need > an EFIS/MFD that displays it. > > Also, ground station coverage is only on the east coast right now. > > cjay > > > apilot2(at)gmail.com wrote: > > And on one of the occasions he said he was above the class D...hence > in class E. > > > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > > pitts_pilot(at)bellsouth.net writes: > > > Playing Devils Advocate here ...... you were outside of their > controlled > > > airspace. > > > > > > > > > Class D is advisory for traffic not control as in Class Alpha or > Bravo.... > > > > > > P > > > > > > > > > ________________________________ > > > See AOL's top rated recipes and easy ways to stay in shape for > winter. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=152823#152823 > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Subject: RE: Console above tunnel
Hi Eric You tunnel mod looks brilliant! Thanks for the pxi and the ideas. One of the small complaints I heard at KOSH about consoles was that they could restrict travel of the stick because your leg gets in the way (the console doesn't allow your leg to move out of the way). Have you sat in your plane to check range of movement of the stick? Cheers Les Kearney #40643 C-GCWZ (reserved) _____ From: Eric Parlow [mailto:ericparlow(at)hotmail.com] Sent: December-19-07 9:14 AM Cc: kearney(at)shaw.ca Subject: Console above tunnel Here's what I have done for the console above the tunnel ERic-- RV-10, 40014 N104EP _____ How are you planning to mount the two boxes over the tunnel? I have contemplated getting one of the fiberglass consoles but a also considering building something as well. ________________________________________________________________________________
Date: Dec 19, 2007
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Re: Cooling tube on lightspeed ignition box?
zackrv8 wrote: Zack: I'm getting ready to start assembly of the panel and associated boxes. Any chance you could take a pic of your installation? Trying to get placement of items solidified in my mind. Thanks Fred 40515. On the gear, starting wheel pants. > > CJ, > > I bought a 3 port blower fan from Stein. I will use the other ports for the Avionics LRU's and one for the Lightspeed. > > Zack > > -------- > RV8 #80125 > RV10 # 40512 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=153020#153020 > > > ________________________________________________________________________________
Date: Dec 19, 2007
Subject: RV10 Winter Flying
Just posted on VAF data from recent flight to SteinAir for those request ing. Pics show Dynon Lean Mode and all cylinders LOP on O-540. DEAN _____________________________________________________________ It's never been easier to trace your ancestry. Click now to research you r family tree! http://thirdpartyoffers.juno.com/TGL2111/fc/Ioyw6iiefptplyF7HMgzSH33IjhQ j4mNulDrZhTJZK8jHCMYsisLcY/ ________________________________________________________________________________
Subject: Re: VP-200 Update
Date: Dec 19, 2007
Les, I'm going to go with a center console from Accuracy Avionics. I'm also going with their overhead console as well, with NACA vents in the rear to feed the air vents. A far as panel layouts, I've been using ePanel Builder online and Accuracy's 3D panel wizard. Right now these suffice for the rough order of magnitude that I'm dealing with at this stage. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153115#153115 ________________________________________________________________________________
Subject: Re: Favorite greasy belly cleaner ?
Date: Dec 19, 2007
Good old WD-40 Sent from my iPhone On Dec 18, 2007, at 5:35 PM, "Gerry Filby" wrote: > > (Its a little off topic since it relates to my RV-9) > > Do you guys have a favorite cleaner for the "greasy belly" ? I've > heard of > the Stoddard cleaner which is supposed to be pretty evil stuff. > Simple > Green apparently has issues if used on bare aluminum. There's such > a range > of products on Spruce that I don't know where to start ... > > Gerry > http://www.n747wg.com > (Haven't opened the box yet.) > > ________________________________________________________________________________
Date: Dec 19, 2007
Hi Todd
December 11, 2007 - - - - , 20-
RV10-Archive.digest.vol-cw
