RV10-Archive.digest.vol-cx
- - - , 20- - January 03, 2008
      I have seen their consoles and they look nice. I might go that route as well. On
      the other hand, I like Eric's solution as well.
      Cheers
      Les
      ----- Original Message -----
Date: - - - , 20-
Subject: Re: VP-200 Update
> > Les, > I'm going to go with a center console from Accuracy > Avionics. I'm also going with their overhead console as > well, with NACA vents in the rear to feed the air vents. > > A far as panel layouts, I've been using ePanel Builder online > and Accuracy's 3D panel wizard. Right now these suffice > for the rough order of magnitude that I'm dealing with at this stage. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=153115#153115 > > > > > > > > Lists This Month -- > (And Get Some AWESOME FREE Gifts!) > Click on > _- > = -Matt Dralle, List Admin. > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Subject: Re: collision avoidance
Ah, got it. But I think it is the fault of the competition (Bendix/King, Chelton, L3, Aviddyne, et al). I guess I'm trying to figure out what is preventing the competition from coming out with their own product and giving Garmin a run for their money. I don't see the experimental EFIS makers entering this market because as with Transponders and GPS, ADS-B devices will probably have to be TSO'd, even for experimentals. Garmin used GPS to spearhead their way to avionics dominance, and nothing I see should prevent one of the other vendors from using ADS-B to do the same. I don't see this a the fault of Garmin, I see it as the fault of the so-called competition. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Lack of viable competition creates a stranglehold for most competitors > and hence the customer. More suppliers, constant demand - better > pricing. The GDL-90 is made in Salem, Oregon. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William > Curtis > Sent: Tuesday, December 18, 2007 7:51 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: collision avoidance > > > Since there is nothing proprietary about ADS-B, how does "Oregon based > Garmin" have a "stranglehold?" > > William > http://wcurtis.nerv10.com/ > "Be who you are and say what you feel because those who mind don't > matter and those who matter don't mind." > -- Dr. Suess > > -------- Original Message -------- > > > > > The ADS-B transmitters were turned on in Salem, Oregon last Monday and > > are working in several eastern seaboard states from Florida through > > Washington, DC. > > > > Someone needs to break the stranglehold on Oregon based Garmin so that > > "Supply and Demand" makes this a more common of a collision avoidance > > system than $7K. The EFIS solution is being solved one RV-10 at a > time. > > Till then, some are using ZAON patched to their GPS screen. > > > > John > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay > > Sent: Monday, December 17, 2007 8:29 PM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Re: collision avoidance > > > > > > This is a scenario where you would be hard pressed to beat ADS-B for > > traffic awareness. You are outside of radar control or controllers > are > > too busy to notice; ADS-B would give you a clear picture of traffic > > (altitude, bearing, and direction) without ATC help. > > > > Unfortunately, most people don't understand it, and no one is using it > > yet. Not cheap enough yet either, the GDL-90 is about $7K and you > need > > an EFIS/MFD that displays it. > > > > Also, ground station coverage is only on the east coast right now. > > > > cjay > > > > > > apilot2(at)gmail.com wrote: > > > And on one of the occasions he said he was above the class D...hence > > in class E. > > > > > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > > > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > > > pitts_pilot(at)bellsouth.net writes: > > > > Playing Devils Advocate here ...... you were outside of their > > controlled > > > > airspace. > > > > > > > > > > > > Class D is advisory for traffic not control as in Class Alpha or > > Bravo.... > > > > > > > > P > > > > > > > > > > > > ________________________________ > > > > See AOL's top rated recipes and easy ways to stay in shape for > > winter. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=152823#152823 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Subject: Instrument Panel Dimensions
Hi Over the past couple of weeks I have been playing with panel layouts. What I don't know is what the exact center of vision is offset from the center of the RV10 stock panel. I have a pretty good idea of where it is but was wondering if anyone has an exact measurement. I would hate to have my EFIS off center as it would annoy me to no end every time I flew. Inquiring minds need to know. Cheers & Merry Christmas to all Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Subject: Re: Instrument Panel Dimensions
Date: Dec 19, 2007
I don't have a number but it seemed to me for the GRT if the left edge of the efis aligned with the first screw to the left of the left panel rib that would center up the Horizon one. -Chris #40072 finish/panel/top/interior paint ----- Original Message ----- From: Les Kearney To: rv10-list(at)matronics.com Sent: Wednesday, December 19, 2007 7:50 PM Subject: RV10-List: Instrument Panel Dimensions Hi Over the past couple of weeks I have been playing with panel layouts. What I don't know is what the exact center of vision is offset from the center of the RV10 stock panel. I have a pretty good idea of where it is but was wondering if anyone has an exact measurement. I would hate to have my EFIS off center as it would annoy me to no end every time I flew. Inquiring minds need to know. Cheers & Merry Christmas to all Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Date: Dec 19, 2007
Center of pilot's view is about 1.125" inboard of the left panel rib. Bob #40105 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153185#153185 ________________________________________________________________________________
Date: Dec 19, 2007
Subject: Re: RV10 Winter Flying
Couldn't find it. Where on VAF did you post it? -Jim In a message dated 12/19/2007 2:44:55 P.M. Eastern Standard Time, ddddsp1(at)juno.com writes: Just posted on VAF data from recent flight to SteinAir for those requesting. Pics show Dynon Lean Mode and all cylinders LOP on O-540. DEAN Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 19, 2007
Off center being an annoyance is an interesting idea... but I've been flying behind an asymmetrical, off center steam gauge panel for awhile. Don't even think about it. Not sure an EFIS changes that. Inquiring minds want to know. Symmetry is a beautiful thing - but it occurs to me that it's not as simple as a perfectly centered screen or array of gauges. There's a functional symmetry and a perceived symmetry and not sure what else. The best looking panels seem to have the panels stacked in front of the pilot or split between pilot and copilot. But having to dip my head to see the bottom panel will annoy me to no end when in the clouds. I just spent the day pasting instrument pics to my panel. Very interesting. Bill Watson 40605 Les Kearney wrote: > > Hi > > > > Over the past couple of weeks I have been playing with panel layouts. > What I don't know is what the exact center of vision is offset from > the center of the RV10 stock panel. I have a pretty good idea of where > it is but was wondering if anyone has an exact measurement. > > > > I would hate to have my EFIS off center as it would annoy me to no end > every time I flew. > > > > Inquiring minds need to know... > > > > Cheers & Merry Christmas to all > > > > Les Kearney > > #40643 > > C-GCWZ (reserved) > > > > > > * > > > * ________________________________________________________________________________
Subject: RE: Console above tunnel
Date: Dec 19, 2007
I used the wood grips from Vans and cut my sticks as short as possible. Even so, I was not able to get full forward right stick. At that point I had only the left stick in place. I was using the stock engine control bracket under the instrument panel crossbar. So, I moved the bracket to the right a bit (maybe 1/2"-1") to get full travel. When I put the right stick in, again using Van's wood grips and the shortest possible stick length, I was able to hook the right stick into the space between the mixture and the throttle. Not good. So, I bought the quadrant and will see how it affect stick travel. $$ and work at this point but better than locked controls! Eric, that's a beautiful console but I think you may have some interferance. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Wednesday, December 19, 2007 8:51 AM Subject: RV10-List: RE: Console above tunnel Hi Eric You tunnel mod looks brilliant! Thanks for the pxi and the ideas. One of the small complaints I heard at KOSH about consoles was that they could restrict travel of the stick because your leg gets in the way (the console doesn't allow your leg to move out of the way). Have you sat in your plane to check range of movement of the stick? Cheers Les Kearney #40643 C-GCWZ (reserved) _____ From: Eric Parlow [mailto:ericparlow(at)hotmail.com] Sent: December-19-07 9:14 AM Cc: kearney(at)shaw.ca Subject: Console above tunnel Here's what I have done for the console above the tunnel ERic-- RV-10, 40014 N104EP _____ How are you planning to mount the two boxes over the tunnel? I have contemplated getting one of the fiberglass consoles but a also considering building something as well. ________________________________________________________________________________
Date: Dec 19, 2007
Technically speaking the Garmin products are now made outside the US of A and they are now situated safely, from a corporate environment on a Caribbean Island (away from CONUS). Formerly they were from Olathe, Kansas, represented mid-America value, made a great product, bought (Morrow Electronics - Salem, OR) which had been acquired by UPS (so they could track their trucks and compete with FEDEX)and the rest is our wide range of Christmas GPS choices. Bring on the optional ADS-B suppliers. My money is always quickly converted (what little I have). I will know when Garmin decides to flex their muscle and become predominant in aviation when they drop the price on the twin G-900 and ADS-B for widespread fleet consumption by us little folks. Take a lesson from your handheld GPS products. Merry Christmas, John C -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Wednesday, December 19, 2007 12:48 PM Subject: RE: RV10-List: Re: collision avoidance Ah, got it. But I think it is the fault of the competition (Bendix/King, Chelton, L3, Aviddyne, et al). I guess I'm trying to figure out what is preventing the competition from coming out with their own product and giving Garmin a run for their money. I don't see the experimental EFIS makers entering this market because as with Transponders and GPS, ADS-B devices will probably have to be TSO'd, even for experimentals. Garmin used GPS to spearhead their way to avionics dominance, and nothing I see should prevent one of the other vendors from using ADS-B to do the same. I don't see this a the fault of Garmin, I see it as the fault of the so-called competition. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Lack of viable competition creates a stranglehold for most competitors > and hence the customer. More suppliers, constant demand - better > pricing. The GDL-90 is made in Salem, Oregon. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William > Curtis > Sent: Tuesday, December 18, 2007 7:51 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: collision avoidance > > > Since there is nothing proprietary about ADS-B, how does "Oregon based > Garmin" have a "stranglehold?" > > William > http://wcurtis.nerv10.com/ > "Be who you are and say what you feel because those who mind don't > matter and those who matter don't mind." > -- Dr. Suess > > -------- Original Message -------- > > > > > The ADS-B transmitters were turned on in Salem, Oregon last Monday and > > are working in several eastern seaboard states from Florida through > > Washington, DC. > > > > Someone needs to break the stranglehold on Oregon based Garmin so that > > "Supply and Demand" makes this a more common of a collision avoidance > > system than $7K. The EFIS solution is being solved one RV-10 at a > time. > > Till then, some are using ZAON patched to their GPS screen. > > > > John > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay > > Sent: Monday, December 17, 2007 8:29 PM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Re: collision avoidance > > > > > > This is a scenario where you would be hard pressed to beat ADS-B for > > traffic awareness. You are outside of radar control or controllers > are > > too busy to notice; ADS-B would give you a clear picture of traffic > > (altitude, bearing, and direction) without ATC help. > > > > Unfortunately, most people don't understand it, and no one is using it > > yet. Not cheap enough yet either, the GDL-90 is about $7K and you > need > > an EFIS/MFD that displays it. > > > > Also, ground station coverage is only on the east coast right now. > > > > cjay > > > > > > apilot2(at)gmail.com wrote: > > > And on one of the occasions he said he was above the class D...hence > > in class E. > > > > > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > > > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > > > pitts_pilot(at)bellsouth.net writes: > > > > Playing Devils Advocate here ...... you were outside of their > > controlled > > > > airspace. > > > > > > > > > > > > Class D is advisory for traffic not control as in Class Alpha or > > Bravo.... > > > > > > > > P > > > > > > > > > > > > ________________________________ > > > > See AOL's top rated recipes and easy ways to stay in shape for > > winter. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=152823#152823 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2007
Thanks Bob I was using my handy dandy laser level and estimated it was around there. It is good to know what the "book" answer is so I can plan accordingly. Cheers Les #40643 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bcondrey Sent: December-19-07 8:08 PM Subject: RV10-List: Re: Instrument Panel Dimensions Center of pilot's view is about 1.125" inboard of the left panel rib. Bob #40105 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153185#153185 ________________________________________________________________________________
Subject: Jack Stands
Date: Dec 19, 2007
Being a sort of cheap frugal type I made these stands out of $12 worth of =BE plywood and 2 long rams from Harbor Freight on sale. Seems to work OK. (base is 18" square.) Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Dec 19, 2007
Bill I have been playing with layouts, online, for a couple of weeks. What you select as an EFIS setup seems to drive the placement everything else. With the smaller GRT screens, you could have two independent efis screens side by side with the primary display directly in front and the second to the right displaying a moving map. That drives everything else to the right. The beauty of this is that it would allow the second efis to be used as a backup if the primary screen had a brain fart. With the larger AFS Efis screens, it seems that the only reasonable layout is to have one centered in front of the pilot and one in front of the co-pilot. That would be fine if both seats had pilots. Otherwise, in the event of a failure on the pilot's side, it would seem that using the co-pilots' screen as a backup would be problematic. Decisions, decisions... I just pickup up a copy of the Panel Planner software to help my panel design process. Embedded in the software is an article from Kitplane Magazine from 1999. I found the same article online (unfortunately without the pictures) but it still has a few pearls. I especially took note of the issues around positioning of switches. The following link will get you to the article. http://www.accessmylibrary.com/coms2/summary_0286-9339593_ITM Cheers Les #40643 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: December-19-07 8:19 PM Subject: Re: RV10-List: Instrument Panel Dimensions Off center being an annoyance is an interesting idea... but I've been flying behind an asymmetrical, off center steam gauge panel for awhile. Don't even think about it. Not sure an EFIS changes that. Inquiring minds want to know. Symmetry is a beautiful thing - but it occurs to me that it's not as simple as a perfectly centered screen or array of gauges. There's a functional symmetry and a perceived symmetry and not sure what else. The best looking panels seem to have the panels stacked in front of the pilot or split between pilot and copilot. But having to dip my head to see the bottom panel will annoy me to no end when in the clouds. I just spent the day pasting instrument pics to my panel. Very interesting. Bill Watson 40605 Les Kearney wrote: Hi Over the past couple of weeks I have been playing with panel layouts. What I don't know is what the exact center of vision is offset from the center of the RV10 stock panel. I have a pretty good idea of where it is but was wondering if anyone has an exact measurement. I would hate to have my EFIS off center as it would annoy me to no end every time I flew. Inquiring minds need to know. Cheers & Merry Christmas to all Les Kearney #40643 C-GCWZ (reserved) href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: RV10 Winter Flying
Date: Dec 20, 2007
http://www.vansairforce.com/community/showthread.php?t=24792 Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com Sent: Wednesday, December 19, 2007 7:16 PM Subject: Re: RV10-List: RV10 Winter Flying Couldn't find it. Where on VAF did you post it? -Jim In a message dated 12/19/2007 2:44:55 P.M. Eastern Standard Time, ddddsp1(at)juno.com writes: Just posted on VAF data from recent flight to SteinAir for those requesting. Pics show Dynon Lean Mode and all cylinders LOP on O-540. DEAN Jim "Scooter" McGrew http://www.mit.edu/~jsmcgrew ________________________________ See AOL's top rated recipes <http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004> and easy ways to stay in shape <http://body.aol.com/fitness/winter-exercise?NCID=aoltop00030000000003> for winter. ________________________________________________________________________________
Date: Dec 20, 2007
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Les, I also decided that I wanted the EFIS centered in front of the pilot seat. Like was suggested earlier, I have a second screen just to the right of that and a third centered on the right side front seat. This makes the radio stack a natural fit immediately right of the center panel rib. This sort of layout will likely require that you trim & reinforce the outboard panel rib(s) for clearance of the screen(s). I also started out with Panel Planner and it was helpful. I was however disappointed to find out that the dimensional info isn't quite right for the RV-10 panel. I iterated a couple of times with the folks to try to get it right but in the end used that only as a visual guide and manually measured/cut my panel. They may have updated the panel definition by now - that was last spring. Bob #40105 (getting close...) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Wednesday, December 19, 2007 11:28 PM Subject: RE: RV10-List: Instrument Panel Dimensions Bill I have been playing with layouts, online, for a couple of weeks. What you select as an EFIS setup seems to drive the placement everything else. With the smaller GRT screens, you could have two independent efis screens side by side with the primary display directly in front and the second to the right displaying a moving map. That drives everything else to the right. The beauty of this is that it would allow the second efis to be used as a backup if the primary screen had a brain fart. With the larger AFS Efis screens, it seems that the only reasonable layout is to have one centered in front of the pilot and one in front of the co-pilot. That would be fine if both seats had pilots. Otherwise, in the event of a failure on the pilot's side, it would seem that using the co-pilots' screen as a backup would be problematic. Decisions, decisions..... I just pickup up a copy of the Panel Planner software to help my panel design process. Embedded in the software is an article from Kitplane Magazine from 1999. I found the same article online (unfortunately without the pictures) but it still has a few pearls. I especially took note of the issues around positioning of switches. The following link will get you to the article. http://www.accessmylibrary.com/coms2/summary_0286-9339593_ITM Cheers Les #40643 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: December-19-07 8:19 PM Subject: Re: RV10-List: Instrument Panel Dimensions Off center being an annoyance is an interesting idea... but I've been flying behind an asymmetrical, off center steam gauge panel for awhile. Don't even think about it. Not sure an EFIS changes that. Inquiring minds want to know. Symmetry is a beautiful thing - but it occurs to me that it's not as simple as a perfectly centered screen or array of gauges. There's a functional symmetry and a perceived symmetry and not sure what else. The best looking panels seem to have the panels stacked in front of the pilot or split between pilot and copilot. But having to dip my head to see the bottom panel will annoy me to no end when in the clouds. I just spent the day pasting instrument pics to my panel. Very interesting. Bill Watson 40605 Les Kearney wrote: Hi Over the past couple of weeks I have been playing with panel layouts. What I don't know is what the exact center of vision is offset from the center of the RV10 stock panel. I have a pretty good idea of where it is but was wondering if anyone has an exact measurement. I would hate to have my EFIS off center as it would annoy me to no end every time I flew. Inquiring minds need to know... Cheers & Merry Christmas to all Les Kearney #40643 C-GCWZ (reserved) href="http://www.matronics.com/contribution">http://www.matronics.com/c o ntribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Dec 20, 2007
Dean, Thanks for the post. Can you please explain the EGT readout on your DYNON? Especially the last readout (1,1,2,3,4,8) I was not aware the D-100 displayed EMS data. Is that part of the D-100 or is it just presenting data collected from your D-120? Regardless, VERY cool! We are so lucky to have these avionics choices vs. just a few short years ago. And I am glad I am not flying in a 35 year old Cessna with it's equally old cracked plastic covered panel and 126 kt cruise. Thanks, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com Sent: Wednesday, December 19, 2007 10:41 AM Subject: RV10-List: RV10 Winter Flying Just posted on VAF data from recent flight to SteinAir for those requesting. Pics show Dynon Lean Mode and all cylinders LOP on O-540. DEAN _____________________________________________________________ It's never been easier to trace your ancestry. Click now to research your family tree! <http://thirdpartyoffers.juno.com/TGL2112/fc/Ioyw6iiefptplyF7HMgzSH33Ijh Qj4mNulDrZhTJZK8jHCMYsisLcY/> ________________________________________________________________________________
Subject: Merry Christmas
Date: Dec 20, 2007
Very easy solution. Keep building while your wonderful wife who has loved y ou tremendously and who will continue to love you, shows you her love again by getting her pilot's license. Every pilot needs a good co pilot, I'll le ave the decision of who gets to play which role up to you. Keep pluggin away, great to hear it is not life threatening!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! John G.> Date: Thu, 20 Dec 2007 08:17:49 -0700> From: deemsdavis(at)cox.net> T o: rv10-list(at)matronics.com> Subject: RV10-List: Merry Christmas> > --> RV10 -List message posted by: Deems Davis > > Over the past 2 1/2 years this list has grown to become my aviation > family, and so it's only fitting that I pause and THANK YOU all for the > help and support I'v e received from you and to wish you a MERRY > CHRISTMAS and HAPPY NEW YEAR> > Deems Davis #406> > > warning what follows is off topic.> > PS. Some hav e noticed the the daily updates to my website haven't been > occurring. I'm receiving some off-line e-mail queries about why, so I > thought I'd post here to save some time.> > Last Wed. I experienced what the FAA calls 'a di squalifying event'. The > medical term is Transient Global Amnesia (TGA). I n lay terms I > permanently 'lost' from 9am to 3pm of that day. Judy took m e to the > emergency room where they did their diagnostics. Her description of the > events that transpired during the episode are comical in retrospe ct, but > I assure you there was nothing funny about it at the time. I have a > small recognition of the onset of the episode, and what I recall was > terrifying. Once the episode passed, and memory, and the ability to form > new memory returned, my biggest concern once I learned this was not a > li fe-threatening event was my future wrt to aviation, the RV-10 > community a nd my project. I spent a very sleepless night in the hospital > during whic h I resigned myself to selling the project and retiring from > aviation as I suspected that the FAA would not look favorably on the > experience. Need less to say, having had this dream/ambition for so long > and having postpo ned it during the family/career years, and to be within > weeks of realizin g it, I've been a little bummed these past few days.> > The good news is th at TGA, while largely enigmatic to the medical > community, as to cause, ap pears to be completely benign, with no > residual health effects or implica tions, and the likelihood of > recurrence for me is only marginally greater than the general > population. When I was released Thurs. the 1st thing I did once at home > was to begin my own research courtesy of Google, and the associated > medical & FAA databases. I've read numerous medical papers/st udies > published on the syndrome, learned about as much as a layman can. A nd > despite the initial anxiety that this produced, I'm becoming more and > more convinced of the favorable prognosis.> > After taking a couple of da ys to 'chill out' and smell the roses, I have > begun to wrestle with the p ersonal decision regarding my aviation > related future. I won't bother you with the decision process but, during > my research of FAA Flight Surgeon advisory letters, I've learned that it > may be possible with a special iss uance medical to continue my romance > with aviation, the downside is that the FAA wants to wait 1 year as a > precaution to ensure that the episode i s not masking any other > neurological anomalies. I've confirmed all of thi s the other day during > a consultation with my AME, Dr. Farrod (who is exc lusively dedicated to > aviation medicine). I'll begin collecting the data from the hospital > within a week or two so as to have it ready, when / if special issuance > time comes around. So for now, I'm grounded. As of the w riting of this > note, I'm inclined to continue and somehow find a way to s tretch 1-2 > months of remaining work into 12 and not go crazy each time I read/hear > about one of the expected 100 completion's I expect we'll see n ext year. > So for the time being, the updates may be slower to non-existen t. If > they resume, Their frequency will likely be reduced.> > I debated o n whether to put this note out to the 'list' but I didn't > want to 'disapp ear' and become the next James McClow and the subject of > John Cox whimsic al posts! Please rest assured, that I am physically and > mentally OK, ther e are no restrictions on any of my activities (other > than piloting) and t here is no treatment required or necessary.> > > If I decide to continue pe rhaps I'd use some of next year to help > organize and work on an RV-10 Pil oting and Safety program. The content > of such a program would obviously r equire considerable input from the > community.> > > Deems #406> > 'Now whe ==============> > > ________________________________________________________________________________
Subject: Strobe and Antenna Wire in Same Conduit
Date: Dec 20, 2007
Has anyone run their Strobe wire and Antenna wire in the same wing conduit? Any interference or other problems? My Electronics guru says there should be none since all wires are shielded. Anyone? Chuck ________________________________________________________________________________
Date: Dec 20, 2007
Subject: Re: Strobe and Antenna Wire in Same Conduit
The strobe wire and nav antenna coax are in the same bundle on the way out to the wingtip on my RV-10. If I remember right, I believe I can hear the faintest tick-tick-tick from the strobes when listening to NAV audio. It's hardly noticeable. -Jim N312JE Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew In a message dated 12/20/2007 12:12:01 P.M. Eastern Standard Time, chuck(at)chuckdirect.com writes: Has anyone run their Strobe wire and Antenna wire in the same wing conduit? Any interference or other problems? My Electronics guru says there should be none since all wires are shielded. Anyone? Chuck _ (http://www.mit.edu/~jsmcgrew) **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 20, 2007
>> And what outside aerobatic maneuver would you be trying to accomplish??? :-\ << Landing in a gusty crosswind, recovering from wake turbulence, avoiding a mid-air, dealing with a bird strike...<8-O Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Dec 20, 2007
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Deems; Sorry to hear about your misfortune. I just cant wait to hear about all the neat gizmos and stuff you will be adding to your plane this year. (what was that gross wt limitation again?) To everybody else on the list. Merry xmas and happy new year. Dr Fred. ________________________________________________________________________________
Subject: Favorite greasy belly cleaner ?
Date: Dec 20, 2007
Thanks all for the suggestions ... I happen to have a big can of WD-40 lying around - it seems to work a treat !! g -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Sent: Tuesday, December 18, 2007 9:26 PM Subject: Re: RV10-List: Favorite greasy belly cleaner ? Joe Zac suggested WD-40 sometime back. Works great. Anh N591VU-115hrs In the middile of Condition Inspection ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Tuesday, December 18, 2007 11:23 PM Subject: Re: RV10-List: Favorite greasy belly cleaner ? > > > Windex contains ammonia, which is bad for aircraft and plexi. IIRC 409 > also is corrosive. > > On Dec 18, 2007 8:53 PM, Dave Leikam wrote: >> >> What about good old Windex or 409? I do not know if either of these >> would >> hurt AL however. They are both good, mild grease cutters. >> >> Dave Leikam >> 40496 >> >> ----- Original Message ----- >> From: "Gerry Filby" <gerf(at)gerf.com> >> To: >> >> Sent: Tuesday, December 18, 2007 4:35 PM >> Subject: RV10-List: Favorite greasy belly cleaner ? >> >> >> > >> > (Its a little off topic since it relates to my RV-9) >> > >> > Do you guys have a favorite cleaner for the "greasy belly" ? I've >> > heard >> > of >> > the Stoddard cleaner which is supposed to be pretty evil stuff. Simple >> > Green apparently has issues if used on bare aluminum. There's such a >> > range >> > of products on Spruce that I don't know where to start ... >> > >> > Gerry >> > http://www.n747wg.com >> > (Haven't opened the box yet.) >> > >> > >> > >> > >> > >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Dec 20, 2007
Glad to hear you are OK. I'll whack John Cox if he gets out of line. I am sure there are a ton of volunteers to help with the flyoff time while you are grounded! -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Thursday, December 20, 2007 7:18 AM Subject: RV10-List: Merry Christmas Over the past 2 1/2 years this list has grown to become my aviation family, and so it's only fitting that I pause and THANK YOU all for the help and support I've received from you and to wish you a MERRY CHRISTMAS and HAPPY NEW YEAR Deems Davis #406 warning what follows is off topic. ________________________________________________________________________________
Date: Dec 20, 2007
Whew, I'd like to forget the first wife! Hopefully I will have learned before I get to the second wife:-) William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > If you learn how to start such an episode, let me know. There are a few days of my memory I wouldn't mind deleting from my files (the day I married my second wife, for example...). ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: Headset jacks
Date: Dec 21, 2007
OK dumb question with headset jacks.....Headphone and mic jacks have the same number of terminals but one has a larger hole than the other. So which one is Mic and headphone regards Chris ________________________________________________________________________________
Date: Dec 20, 2007
The smaller one is the mic. The outer is ground, the "tip" is the PTT and the "ring" is mic audio. The larger one is the earphone. The outer is ground, the "tip" is earphone audio left, the "ring" is earphone audio right. Most don't wire the "tip" on the microphone jack, but the benefit of wiring it is that that in a pinch, you can connect a regular hand mic with a PTT into the jack and it will work. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > X-Rcpt-To: > > > > > OK dumb question with headset jacks.....Headphone and mic jacks have the > same number of terminals but one has a larger hole than the other. So which > one is Mic and headphone > > regards Chris > > ________________________________________________________________________________
Subject: Re: Headset jacks
Date: Dec 20, 2007
The bigger one is for the headphones. 1/4" diameter. ----- Original Message ----- From: "Chris and Susie McGough" <VHMUM(at)bigpond.com> Sent: Thursday, December 20, 2007 6:02 PM Subject: RV10-List: Headset jacks > > > > OK dumb question with headset jacks.....Headphone and mic jacks have the > same number of terminals but one has a larger hole than the other. So > which one is Mic and headphone > > regards Chris > > > ________________________________________________________________________________
Date: Dec 20, 2007
The larger is for the Headphones quarter inch if I recall correctly. JP Instruments Amber Wilson FAA STC Administrator JPIAmber(at)yahoo.com 800-945-4574 X204 ----- Original Message ---- From: Chris and Susie McGough <VHMUM(at)bigpond.com> Sent: Thursday, December 20, 2007 3:02:33 PM Subject: RV10-List: Headset jacks OK dumb question with headset jacks.....Headphone and mic jacks have the same number of terminals but one has a larger hole than the other. So which one is Mic and headphone regards Chris Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 20, 2007
No interference with my setup, in fact (oddly enough) the slight background hum decreases when I turn the strobes on! Marcus _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chuck Weyant Sent: Thursday, December 20, 2007 11:10 AM Subject: RV10-List: Strobe and Antenna Wire in Same Conduit Has anyone run their Strobe wire and Antenna wire in the same wing conduit? Any interference or other problems? My Electronics guru says there should be none since all wires are shielded. Anyone? Chuck ________________________________________________________________________________
Date: Dec 20, 2007
I have been flying with an XRX for about 1 1/2 years now. At first it was with the stand alone unit and for the past 6 months with the Garmin interface. I placed my unit on the glare shield and discovered that it was difficult for me to see the screen due to ambient light. I found that a white sheet of paper in front of the screen reflected the light and made the screen readable. So I cut a sheet of plastic to fit under the unit and extend 1-2" in front of the screen. I covered the extension with white label paper and was able to see the screen without a problem. On the stand alone unit you have to look at the screen periodically to see if traffic is displayed. It only warns you when traffic gets within the two warning parameters.. Now with the Garmin interface it is much better. The screen just says Garmin and traffic is displayed on my GPS 396. Traffic is displayed on the map page according to your setup. When traffic gets within the warning parameters you get a pop up window with the warning. Overall, this has been a good investment. I have seen traffic that I would have missed without it. Still, I get warnings where I do not see the traffic. It has not been false echos as this has occurred with ATC advisories and map display and still I never see the traffic. So, this unit is another good resource for collision avoidance. Traffic in the pattern is easier to pick up. JF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153423#153423 ________________________________________________________________________________
Date: Dec 20, 2007
Subject: Re: Merry Christmas forgetting our first wives
Hard to forget my wife... I think of her everyday, I loved her than and I love her now. If it wasn't for her I wouldn't be building the RV-10 today. Ya she's a keeper ;-) Pascal ----- Original Message ----- From: "William Curtis" <wcurtis(at)nerv10.com> Sent: Thursday, December 20, 2007 2:11 PM Subject: RE: RV10-List: Merry Christmas > > Whew, I'd like to forget the first wife! Hopefully I will have learned > before I get to the second wife:-) > > William > http://wcurtis.nerv10.com/ > "Be who you are and say what you feel because those who mind don't matter > and those who matter don't mind." > -- Dr. Suess > > -------- Original Message -------- >> >> If you learn how to start such an episode, let me know. There are a few >> days of my memory I wouldn't mind deleting from my files (the day I >> married my second wife, for example...). > > > ________________________________________________________________________________
Date: Dec 21, 2007
Deems, Wish you and your family the best during the Chrismas Holiday. I hope you continue on and get that RV10 flying. I may be flying to Mesa early next week..........if you feel up to it would you wanna go for a ride a round AZ in 805HL? God Bless, DEAN _____________________________________________________________ Solve paternity questions with expert DNA testing. Click now! http://thirdpartyoffers.juno.com/TGL2111/fc/Ioyw6iifnrtA5aqF3iHI00ksEKVp Dsm3NstrEaZzHtys5xcrHoQYpe/ ________________________________________________________________________________
Date: Dec 20, 2007
Subject: Wiring
Total Novice here..... I'm building an RV-10 with dual Lightspeed ignition. Electronics are as follows; SL40 Radio, GTX327 Transponder, 496 GPS, PS3000 audio panel, and the Advanced Flight Systems 3500 efis. My question are; Has anyone set up the rpm wiring between the Lightspeed and the efis? Prior to finalizing my connections, I wanted to double check my wiring pin numbers for the wires which interconnect between equipment.... ie. 496 to efis, or sl40 to audio panel, etc Any help will be much appreciated Thanks, Don McDonald N14XG --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Dec 20, 2007
I believe Zaon is working on an ADS-B module for their next product which is a built in system. They were showing it in OSH. Don't recall the price though. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Wednesday, December 19, 2007 10:33 AM Subject: RE: RV10-List: Re: collision avoidance Lack of viable competition creates a stranglehold for most competitors and hence the customer. More suppliers, constant demand - better pricing. The GDL-90 is made in Salem, Oregon. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Tuesday, December 18, 2007 7:51 PM Subject: RE: RV10-List: Re: collision avoidance Since there is nothing proprietary about ADS-B, how does "Oregon based Garmin" have a "stranglehold?" William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > The ADS-B transmitters were turned on in Salem, Oregon last Monday and > are working in several eastern seaboard states from Florida through > Washington, DC. > > Someone needs to break the stranglehold on Oregon based Garmin so that > "Supply and Demand" makes this a more common of a collision avoidance > system than $7K. The EFIS solution is being solved one RV-10 at a time. > Till then, some are using ZAON patched to their GPS screen. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay > Sent: Monday, December 17, 2007 8:29 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: collision avoidance > > > This is a scenario where you would be hard pressed to beat ADS-B for > traffic awareness. You are outside of radar control or controllers are > too busy to notice; ADS-B would give you a clear picture of traffic > (altitude, bearing, and direction) without ATC help. > > Unfortunately, most people don't understand it, and no one is using it > yet. Not cheap enough yet either, the GDL-90 is about $7K and you need > an EFIS/MFD that displays it. > > Also, ground station coverage is only on the east coast right now. > > cjay > > > apilot2(at)gmail.com wrote: > > And on one of the occasions he said he was above the class D...hence > in class E. > > > > On Dec 17, 2007 6:54 AM, wrote: > > > > > > > > > > > > > > In a message dated 12/16/2007 1:30:04 PM Central Standard Time, > > > pitts_pilot(at)bellsouth.net writes: > > > Playing Devils Advocate here ...... you were outside of their > controlled > > > airspace. > > > > > > > > > Class D is advisory for traffic not control as in Class Alpha or > Bravo.... > > > > > > P > > > > > > > > > ________________________________ > > > See AOL's top rated recipes and easy ways to stay in shape for > winter. > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=152823#152823 > > ________________________________________________________________________________
Date: Dec 20, 2007
As a fellow traveler who just turned 60, all us geezers fear what has happened to you or worse. Though I do not know you personally, I relish seeing your posts. Please keep up the faith and your progress. I will say a special prayer for a healthy 2008 for you and your family. We all need goals in life, I think that a realistic one for you is to get your a/c in the air and fly a lot of dual in 2008 and plan to go solo on a specific date in early 2009 (maybe 2/1/09). -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153448#153448 ________________________________________________________________________________
Date: Dec 20, 2007
Deems - others have said it better than we can, but nonetheless, hang in there! We enjoyed meeting you at Oshkosh this summer, and continue to enjoy your posts. Keep 'em coming while you polish your -10. Merry Christmas and Happy New Year to All! -------- Bill (and Jon) Reining 40514 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153467#153467 ________________________________________________________________________________
Date: Dec 21, 2007
Maerry Christmas and Happy new Year to all of you. I am from Italy building one of the first or the first RV10 in Italy Claudio Masci (I-BIRO Reserved) -----Messaggio originale----- Da: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Per conto di Bill Reining Inviato: venerd 21 dicembre 2007 8.12 A: rv10-list(at)matronics.com Oggetto: RV10-List: Re: Merry Christmas Deems - others have said it better than we can, but nonetheless, hang in there! We enjoyed meeting you at Oshkosh this summer, and continue to enjoy your posts. Keep 'em coming while you polish your -10. Merry Christmas and Happy New Year to All! -------- Bill (and Jon) Reining 40514 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=153467#153467 ________________________________________________________________________________
Date: Dec 21, 2007
Deems don't worry about stretching 1-2 months out to a year. When I thought I was a month away from being finished with my RV-10 project I found that I still had more than three months of almost full time work to get it to DAR inspection. In addition, you can also use another pilot to do the fly off hours and still be involved with the daily cowl removal and adjustments that are needed. I had another pilot listed on my insurance for the flyoff period and the insurance company didn't charge anything extra. My dream was for the two of use to get the flyoff done sooner so that I could fly to OSH2006. After getting my DAR approval I knew there was no way I was going to fly to OSH2006 unless I falsified my flyoff time so as it turned out I ended up doing all the flyoff time myself over a little more than a month. Even 17 months after the first flight there are still things that I am changing, many of which would have already been done if I had been grounded from flying. During my build, I had three major surgeries over a four month period and it was really hard to take the time off building to get well but man has the flying of N710RV been worth it. Merry Christmas Russ Daves N710RV - #40044 N65RV - RV-6A Sold N742PZ - RV-8 co-builder N____RV - RV-7 just starting ________________________________________________________________________________
Date: Dec 21, 2007
Subject: The Pity Party has been cancelled!
The Pity Party has been canceled: :-D Construction on N519PJ to recommence Jan 2, 2008 Website updates to follow thereafter. Seriously, Once again this 'family' has proved it's value. I CAN"T BEGIN TO TELL ALL OF YOU JUST HOW IMPORTANT YOUR WORDS OF ENCOURAGEMENT AND SUPPORT WERE / ARE TO ME. I've read and reread them all. I'm overwhelmed with the responses received both on and off line, the support, advice, suggestions and sharing of your own stories and experiences were JUST EXACTLY WHAT I NEEDED. And have helped me to get around the corner. I'm so thankful, and a little embarrassed to have bent everyones ear with what in the eternal scheme of things is really a wart. Jack - Sorry can't help, throughout it all Judy was, is and always will be my one and only and my anchor. Tim - No offense taken - currently accepting suggestions for change order # 3982 Bob C. - I'll gladly do your fiberglass work. I guarantee you won't like the price. Ben - Give John C. a whack, just for the heck of it! John C. - Duck if you see Ben coming! Paul G. - No more whining about a bad back, get those Rudder pedals fabbed (I'm putting them back on the list, change order # 3981 !) Ed H. - You win! ...... but my plane will be faster than yours......... Neil - I'm telling Sarah about the blond jokes David - Thanks for the link to the local test pilot Dean - You Becha! - Does a bear poop in the woods! Matt - Sorry about the wasted bandwidth Patrick - My source for transparidium has dried up, but I've got an idea that involves putting sneeze pins on the condoleators. I expect a 5 kt gain! To everyone - My heartfelt THANKS ! Deems #406 ________________________________________________________________________________
Date: Dec 21, 2007
Subject: Yahoo! Auto Response
JPI will be closed to observe Christmas December 22ND and will return on December 27TH. JPI will be closed to observe the New Year Holiday December 29TH and will return on January 2ND. The holiday season offers us a special opportunity to extend our personal thanks to our friends, and our very best wishes for the future. And so it is that we now gather together and wish to you a very Merry Christmas and a Happy New Year. We consider you a good friend and extend our wishes for good health and good cheer. It is people like you who make being in business such a pleasure all year long. Our business is a source of pride to us, and with customers like you, we find going to work each day a rewarding experience. To our friends all over the world, JP Instruments extends to you and your loved ones our best wishes for a Vrolijke Kersttmis Sarbatori Felicite Joyeux Noel Tin Hao Nian Froeliche Weihnachten Felice Natale Kinga Shinnen Glad Julen Ichok Yilara Boas Festas Chrustovjna Wesloych Swiat Glaedelig Jul Veselele Vanoche Felice Pascuas Sretan Bozic Boldog Karacsonyi Unnepeket Merry Christmas and a Happy New Year! ________________________________________________________________________________
Date: Dec 21, 2007
Subject: Re: The Pity Party has been cancelled!
Deems Now that you are accepting change orders, please let me add to your scope growth. The link below is to a very interesting device that I came across yesterday. It is an "air slicer" and can be found at: http://www.periheliondesign.com/moreproducts.htm So what we need is a way to use this so we can mix variable amounts of warm / cold air to get heater air of a specific teperature. In the unlikely event you feel the need to hold a "Pity Party", I suggest you keep in mind the old latin quotation and act accordingly: Quis Dolor Cui Dolium Cheers & Merry Christmas Les Kearney #40643 ----- Original Message ----- From: Deems Davis <deemsdavis(at)cox.net> Date: Friday, December 21, 2007 3:30 pm Subject: RV10-List: The Pity Party has been cancelled! > > > The Pity Party has been canceled: :-D > > Construction on N519PJ to recommence Jan 2, 2008 > > Website updates to follow thereafter. > > > Seriously, > > Once again this 'family' has proved it's value. I CAN"T BEGIN TO > TELL > ALL OF YOU JUST HOW IMPORTANT YOUR WORDS OF ENCOURAGEMENT AND > SUPPORT > WERE / ARE TO ME. I've read and reread them all. I'm overwhelmed > with > the responses received both on and off line, the support, > advice, > suggestions and sharing of your own stories and experiences were > JUST > EXACTLY WHAT I NEEDED. And have helped me to get around the > corner. I'm > so thankful, and a little embarrassed to have bent everyones ear > with > what in the eternal scheme of things is really a wart. > > Jack - Sorry can't help, throughout it all Judy was, is and > always will > be my one and only and my anchor. > Tim - No offense taken - currently accepting suggestions for > change > order # 3982 > Bob C. - I'll gladly do your fiberglass work. I guarantee you > won't like > the price. > Ben - Give John C. a whack, just for the heck of it! > John C. - Duck if you see Ben coming! > Paul G. - No more whining about a bad back, get those Rudder > pedals > fabbed (I'm putting them back on the list, change order # 3981 !) > Ed H. - You win! ...... but my plane will be faster than > yours.........Neil - I'm telling Sarah about the blond jokes > David - Thanks for the link to the local test pilot > Dean - You Becha! - Does a bear poop in the woods! > Matt - Sorry about the wasted bandwidth > Patrick - My source for transparidium has dried up, but > I've got an > idea that involves putting sneeze pins on the condoleators. I > expect a 5 > kt gain! > > To everyone - My heartfelt THANKS ! > > Deems #406 > > > > > > > > > > Lists This Month -- > (And Get Some AWESOME FREE Gifts!) > Click on > _- > = -Matt Dralle, List Admin. > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > > > > ________________________________________________________________________________
Subject: David Hitchcock
Date: Dec 21, 2007
David, Please contact me at your convenience. Thanks, Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Dec 21, 2007
Subject: Tailcone - F1010a Question
I am working on the tail cone... and i am not sure if i cut the F1010A angle aluminum the right way. Or maybe i should say, i know i cut the tapered end short.. Does anyone have picture of the finished part or the part in place??? Thanks - Steve -- Stephen G. Blank, DDS RV-10 #40449 766 SE River Lane Port St. Lucie, FL 34983 772-475-5556 >>> Cell ________________________________________________________________________________
Date: Dec 22, 2007
I went kind of picture happy when doing the tailcone. I took lots of pictures of all those oddball tail pieces from every angle. Here is a close up of F1010A that should help: http://www.noimnotcrazy.com/gallery/details.php?image_id=1823 Best Regards, Patrick #40715 / N690CT _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Stephen Blank Sent: Friday, December 21, 2007 8:42 PM Subject: RV10-List: Tailcone - F1010a Question I am working on the tail cone... and i am not sure if i cut the F1010A angle aluminum the right way. Or maybe i should say, i know i cut the tapered end short.. Does anyone have picture of the finished part or the part in place??? Thanks - Steve -- Stephen G. Blank, DDS RV-10 #40449 766 SE River Lane Port St. Lucie, FL 34983 772-475-5556 >>> Cell ________________________________________________________________________________
Subject: Gretz Pitot Instructions
Date: Dec 22, 2007
I'm about ready to do the Gretz Pitot install and can't find my copy of the instructions. Does anyone happen to have an electronic copy? I could not find one on he Gretz Aero site. I don't need the mounting bracket instructions, those ones I found. I am looking for the one that has the wiring diagrams for the pitot itself. Also, is there any consensus as to which bay is optimal from the standpoint of accuracy, ease of maintenance and tie-down clearance? How have people been going about doing the cutout for the bottom skin? The bracket instructions don't seem to provide any guidance for that step. Best Regards, Patrick #40715/ N690CT ________________________________________________________________________________
Subject: Re: Gretz Pitot Instructions
Date: Dec 22, 2007
On my 6A, I put it on the outboard bay of the access panel. Then I moved my tie-down mount one bay outboard so they wouldn't cross paths. The instructions didn't do anything for me on the cutout either. I used the bracket plate as a template after I match drilled the holes - then opened it up with a grinder bit. The wiring instructions were part of the pitot tube itself - I've got mine at the hangar (will try to remember) - but IIRC it didn't tell you which was + or -. I just made a decision and wired it up - neither pin was grounded. Mine works fine. ----- Original Message ----- From: Patrick ONeill To: rv10-list(at)matronics.com Sent: Saturday, December 22, 2007 7:56 AM Subject: RV10-List: Gretz Pitot Instructions I'm about ready to do the Gretz Pitot install and can't find my copy of the instructions. Does anyone happen to have an electronic copy? I could not find one on he Gretz Aero site. I don't need the mounting bracket instructions, those ones I found. I am looking for the one that has the wiring diagrams for the pitot itself. Also, is there any consensus as to which bay is optimal from the standpoint of accuracy, ease of maintenance and tie-down clearance? How have people been going about doing the cutout for the bottom skin? The bracket instructions don't seem to provide any guidance for that step. Best Regards, Patrick #40715/ N690CT ________________________________________________________________________________
Date: Dec 22, 2007
Patrick, I'll borrow a quote from John Cox for you on this "Make sure you take off your builder hat and put on your repairman/serviceman hat.". Although not technically that difficult to install think about maintaining it after installation. I did not think about install or location when I cut the holes for my bracket which I ended up putting it in the stock Van's pitot location. It worked out ok but I had several technical hurdles to overcome. The copper tube coming out of the pitot tube itself came straight up into the aileron torque tube requiring a healthy bend to maintain clearance while the tube moved fore and aft. The mounting locations for the circuit board in this location are sub optimal for ease of wire installation and maintenance due to the aileron pushrod and bellcrank parts. Think about threading the wires up through the pitot tube hole and guiding them into their install location on the circuit board and then tightening the miniature screws. You also have to secure the aluminum pitot line to the copper line through an inspection hole after installing the bottom wing skins. Pictures of my installation can be found here: http://www.sinkrate.com/rv10/pics.asp?f=wings|pitot I ended up making short length wires and connectors that I could attach to the circuit board prior to closing up the wing. I used a locking 2 wire molex plug for the power wires and dean's plug for the thermistor wires. My thoughts were to make the actual installation of the tube into the finished wing easier. One thing to think about too is what happens to moisture that may accumulate on the wires? The circuit board should be on the top side of the wing so all wire runs coming out of the unprotected holes are not subject to water droplets running down the wires and into their attach points. I am considering encasing the wires in silicone but have not yet done that. If anyone has more questions or thinks I f'd something up please let me know! -Ben Westfall #40579 N109LB (reserved) PDX _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill Sent: Saturday, December 22, 2007 4:56 AM Subject: RV10-List: Gretz Pitot Instructions I'm about ready to do the Gretz Pitot install and can't find my copy of the instructions. Does anyone happen to have an electronic copy? I could not find one on he Gretz Aero site. I don't need the mounting bracket instructions, those ones I found. I am looking for the one that has the wiring diagrams for the pitot itself. Also, is there any consensus as to which bay is optimal from the standpoint of accuracy, ease of maintenance and tie-down clearance? How have people been going about doing the cutout for the bottom skin? The bracket instructions don't seem to provide any guidance for that step. Best Regards, Patrick #40715/ N690CT ________________________________________________________________________________
Subject: XRX PCAS initial impressions
Date: Dec 22, 2007
I have flown a couple of flights with both the MRX and XRX sitting adjacent on the panel. Some observations: Traffic is certainly easier to spot given the relative bearing. In the mountains, overflying Boeings strobed the transponder and provided indications of traffic. I primarily use screen B on the unit; it provides a God's eye view of top three threats and detail info on the top threat. The MRX and XRX have slightly different threat algorithms. Aircraft aft of my aircraft seem to given less weight in the threat analysis software in the XRX. Two caveats: Be sure and calibrate the magnetometer as the screen B display will be unintelligible Also calibration can be done in flight setting the autopilot on a 000 GPS track in smooth air. Wait until they improve the connection cable. I found that the first XRX unit they sent would shut off automatically intermittently. Although not conclusive at this point I believe that the voltage drop on their very small power cable is causing the power problems. They use the same power cable as the MRX which requires 20-25% of the power of the XRX. Although I have not determined the wire size, the pin size for the connector is .7mm (.027 inch). Although the specs say that the XRX will run on any voltage from 10-40 VDC; the reality is that it won't run on a 12VDC battery very reliably. Things go downhill rapidly if the source battery supplies 11-12 VDC to the cigarette lighter adapter. ________________________________________________________________________________
Date: Dec 22, 2007
Subject: oil canning revisited
Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved ************************************** See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 22, 2007
Subject: Re: Cooling tube on lightspeed ignition box?
For those of us with older lightspeeds Klaus wants them returned for internal updates as well as a provision for cooling tubes.I should have put those boxes where they were easier to get to. ************************************** See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Subject: Cooling tube on lightspeed ignition box?
Date: Dec 22, 2007
What's the definition of an "older Lightspeed"? I've had my Plasma 111 goi ng on three years. Thanks Mark RV-10/N410MR 170 hours
From: PILOTDDS(at)aol.comDate: Sat, 22 Dec 2007 18:22:13 -0500Subject: Re: RV1 0-List: Cooling tube on lightspeed ignition box?To: rv10-list(at)matronics.com For those of us with older lightspeeds Klaus wants them returned for intern al updates as well as a provision for cooling tubes.I should have put those boxes where they were easier to get to.*********************************** ***See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID =aoltop00030000000004) _________________________________________________________________ Share life as it happens with the new Windows Live. http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_1220 07 ________________________________________________________________________________
Date: Dec 22, 2007
If it didnt come with a provision for a cooling tube you are effected.Three years is about the timeline, although Klaus was not specific to the date. ************************************** See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 22, 2007
John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: "I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin." I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be able to cleco everything in its final place. There should be a small gap (1/32" at the most) between the leading edge or gas tank skins and the CLECO'd bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bounce from one rib to the next just complete one rib at a time. This helps push any excess out towards the ends. If the skin edges are pressed together tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on each bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn't take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don't know what to tell you. -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, December 22, 2007 3:18 PM Subject: RV10-List: oil canning revisited Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved ________________________________________________________________________________
Date: Dec 22, 2007
Subject: Re: Tailcone - F1010a Question
Patrick, Thanks... Now i know i goofed up. I read the diagram to show the vertical piece as having a notch, and the top piece angeled to match the fues sides..... your viesw make this seem simple and it does not seem critical at the ends, but only where the holes are punched. The ends only need to allow the skins to fit by, is that right???? Boy did i confuse my self on a simple part... - Steve On Dec 22, 2007 7:51 AM, Patrick ONeill wrote: > I went kind of picture happy when doing the tailcone. I took lots of > pictures of all those oddball tail pieces from every angle. > > > Here is a close up of F1010A that should help: > > > http://www.noimnotcrazy.com/gallery/details.php?image_id=1823 > > > Best Regards, > > Patrick #40715 / N690CT > > Stephen G. Blank, DDS #40499 > 184 NW Central Park Plaza > Port St. Lucie, FL 34986 > > 772-475-5556 >>> Cell > 772-878-7347 Office > ________________________________________________________________________________
Subject: Gretz pitot instructions
Date: Dec 22, 2007
I used the mount for a template and drilled and traced for the hole after clecoing it over the skin. Then I used my step drill to enlarge the mount hole. Then trimmed the hole to the line with my dremel. I mounted the thing in the bay just outboard from the aileron inspection cover. The circuit board is mounted to the inspection cover itself. Makes the wire connections easy to get at. Dave Leikam 40496 N89DA reserved ________________________________________________________________________________
Subject: oil canning reveised/revisted.
Date: Dec 22, 2007
Sorry I am not able to hit the reply bottom as something is seriously wrong with my computer. As for the loose skin/oil canning areas, I'll bet it is the square just aft of the main spar, one outboard of the outer most access panel and then the square, aft of the main spar, 2nd inboard of the last outboard access pane l. As for when I started this post, my skins on my first wing(Left one) were n ot tight in several locations just aft of the main spar. I had not complete ly rivetted the entire bottom skin in place and had only completed step 11. I opted to remove the rivets from the main spar all the way aft to the, bu t not including the J channel. Again all my skins were tight aft of the J c hannel. I then re revitted the forward section doing the hopscotch method, never moving forward until all rivets in the horizontal row were completed. I had also trimmed the edge the joins with the LE skin. The results this s econd time were better, but I still have some oil canning in the above two bays, with the bottom skin completely closed up....these correspond to the two bays where the ribs naturally lean into each other, or should I say pul l toward one another. This weekend I completed the right wing up to step 11, I am waiting on my A OA sub kit and can't finish right now. Again see other passed post for what I am doing as per rib order, working down and outward and inward at the sa me time. I will post my result after the wing is closed. So far the right w ing skin is very tight aft of the J channel, but so was the left one. The difference so far on this second wing, I haven't made one ding yet XXXX X crossed fingers. The 8 inch rivet set extension from Avery is a must arou nd those flap brackets and buy another flush set with the rubber and put it on the disk sander and make a flat spot on one side so the set can get up to the rivet which is so close to the flap bracket. Will let you know how second one comes out once completed. JOhn G. ________________________________________________________________________________
Subject: Gretz mount
Date: Dec 23, 2007
I recently installed my Gretz mount and thought I would share an issue with the list. The reinforcement plate that is supplied with the mount , the one with the joggle that goes on top of the spar flange, has a joggle of .045 which is correct for the smaller RVs, but not the 10. The flange on the 10 is .065. I contacted Gretz and he said he was aware of the issue, and possibly the next batch run will be made with the larger joggle (which would be easy to shim for the other RVs). Meanwhile he suggested that I could put the plate in a vise and beat on it to fit. I tried that and ended up with something that I didn't think belonged on my airplane. So the fix was to make a new plate out of .065 material, and flush rivet a strip of material to the leading edge, that would go on top of the flange, and allow the plate to sit perfectly flat against the skin. I installed the mount on the inboard side of the outboard rib of the second bay from the tip of the wing. This allows for access with the tip removed, and is far enough from the tip that there is clean air, and it's clear of the tie down ring. Contact me offline if you need pictures. I installed the new Dynon heated pitot / AOA probe, which is fabricated from nickel and it looks like a real quality unit. I plan on at least one Dynon box, which will give me visual and aural AOA / stall warning. The probe also is temperature controlled for low current draw, and has fault annunciation on a Dynon box, or a stand alone LED if not using a Dynon box. My experience with the Dynon system I have in the RV8 couldn't be better. The system is rock solid, and loaded with features. Chris Hukill shaving bottom wing skins to fit ________________________________________________________________________________
Date: Dec 23, 2007
Ben and Jim, I would really like to get an idea of what is acceptable as far as the oil canning is concerned in these bottom skin bays. I have 2 1/2 that have cann ing. Ben, I removed the material at the edge as you suggested a few days ago, bu t i may have removed as much as 1/32 or almost 1/16 on the rework of the fi rst wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then again oil canning on t he second bay inboard of the outer most access panel. Interestingly, I beli eve I removed as much material as I could have at that seam and the seam cl osed up so tight a hair would not even be able to get in it. The dimpled ho les started to not line up. Maybe every hole should not be clecoed and the riveting should be every other hole when working forward????? Perhaps if ev ery hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap at the LE will be t oo tight or non existent????? Ben, do you remember whether your ribs were spring loaded causing them to b ow in a direction opposite their flange direction. I still think this is my problem as on the second wing I am trying every combination with the cleco es. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a drum. Despite what order I do the forward portion o f the ribs with the clecoes, the skin in the same bays as on the other wing still remain looser than the other bays. The only thing i can attribute th is to is the ribs bowing inward on these two bays. The ribs are bowing towa rd one another and the neighbor next to it is attributing to the mess by bo wing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bott om skin, but the building manual sure makes the whole process seem like a n o brainer, but that is anything but what I am finding. Sorry for carrying on with this issue but it is the most frustrating part o f the build which I have found. I conquered my baggage door and it lines up flush with the fuse skin and that took a lot of carrying on to get it righ t. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, the cleco es did't hold too well. Good Grief Charlie Brown. All I want from Santa is two nice smooth bottom wings skins with no oil can ning in any of the bays. I promise I have been a good boy!!!! John G. From: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RE: RV10-List: o il canning revisitedDate: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worri ed that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin .=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be abl e to cleco everything in its final place. There should be a small gap (1/3 2=94 at the most) between the leading edge or gas tank skins and the CLECO =92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bou nce from one rib to the next just complete one rib at a time. This helps p ush any excess out towards the ends. If the skin edges are pressed togethe r tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on e ach bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of PILOTDDS(at)aol.comSent: Saturday, December 22, 200 7 3:18 PMTo: rv10-list(at)matronics.comSubject: RV10-List: oil canning revisit ed Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved ________________________________________________________________________________
Date: Dec 23, 2007
Subject: Re: oil canning revisited
two questions? -Do you have QB wings or SB wings On my SB the ribs bow as well and as far as the clecoing everything on (as I have not riveted yet) everything looks tight If QB- call Van's and ask what's up.. -Are you using the "Oops rivets" second time around? If not order some since it sounds like you are in need of them. Pascal ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Sunday, December 23, 2007 6:16 PM Subject: RE: RV10-List: oil canning revisited Ben and Jim, I would really like to get an idea of what is acceptable as far as the oil canning is concerned in these bottom skin bays. I have 2 1/2 that have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on the rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then again oil canning on the second bay inboard of the outer most access panel. Interestingly, I believe I removed as much material as I could have at that seam and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not be clecoed and the riveting should be every other hole when working forward????? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap at the LE will be too tight or non existent????? Ben, do you remember whether your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second wing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a drum. Despite what order I do the forward portion of the ribs with the clecoes, the skin in the same bays as on the other wing still remain looser than the other bays. The only thing i can attribute this to is the ribs bowing inward on these two bays. The ribs are bowing toward one another and the neighbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the whole process seem like a no brainer, but that is anything but what I am finding. Sorry for carrying on with this issue but it is the most frustrating part of the build which I have found. I conquered my baggage door and it lines up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, the clecoes did't hold too well. Good Grief Charlie Brown. All I want from Santa is two nice smooth bottom wings skins with no oil canning in any of the bays. I promise I have been a good boy!!!! John G. ------------------------------------------------------------------------- --- From: rv10(at)sinkrate.com To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Date: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin.=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be able to cleco everything in its final place. There should be a small gap (1/32=94 at the most) between the leading edge or gas tank skins and the CLECO=92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bounce from one rib to the next just complete one rib at a time. This helps push any excess out towards the ends. If the skin edges are pressed together tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on each bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, December 22, 2007 3:18 PM To: rv10-list(at)matronics.com Subject: RV10-List: oil canning revisited Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved ________________________________________________________________________________
Date: Dec 24, 2007
I have QB wings and everything on the top side is tight and all the skins o n the bottom side inboard, which they did, are tight. As for Opps rivets, the holes are not that large to use them, just the clec oes don't grip well, the holes are slightly enlarged and with any bowing, t he cleoceos come out with any rivetting. Looks and feel are two different things. Push the bays in in the center and see what happpens? JOhn G. Date: Sun, 23 Dec 2007 18:48:40 -0800From: rv10builder(at)verizon.netSubject: Re: RV10-List: oil canning revisitedTo: rv10-list(at)matronics.com two questions? -Do you have QB wings or SB wings On my SB the ribs bow as well and as far as the clecoing everything on (as I have not riveted yet) everything looks tight If QB- call Van's and ask what's up.. -Are you using the "Oops rivets" second time around? If not order some since it sounds like you are in need of them. Pascal ----- Original Message ----- From: John Gonzalez Sent: Sunday, December 23, 2007 6:16 PM Subject: RE: RV10-List: oil canning revisited Ben and Jim, I would really like to get an idea of what is acceptable as fa r as the oil canning is concerned in these bottom skin bays. I have 2 1/2 t hat have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on th e rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then agai n oil canning on the second bay inboard of the outer most access panel. Int erestingly, I believe I removed as much material as I could have at that se am and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not b e clecoed and the riveting should be every other hole when working forward? ???? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap a t the LE will be too tight or non existent????? Ben, do you remember whethe r your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second w ing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a dru m. Despite what order I do the forward portion of the ribs with the clecoes , the skin in the same bays as on the other wing still remain looser than t he other bays. The only thing i can attribute this to is the ribs bowing in ward on these two bays. The ribs are bowing toward one another and the neig hbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the wh ole process seem like a no brainer, but that is anything but what I am find ing. Sorry for carrying on with this issue but it is the most frustrating p art of the build which I have found. I conquered my baggage door and it lin es up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, t he clecoes did't hold too well. Good Grief Charlie Brown. All I want from S anta is two nice smooth bottom wings skins with no oil canning in any of th e bays. I promise I have been a good boy!!!! John G. From: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RE: RV10-List: o il canning revisitedDate: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worri ed that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin .=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be abl e to cleco everything in its final place. There should be a small gap (1/3 2=94 at the most) between the leading edge or gas tank skins and the CLECO =92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bou nce from one rib to the next just complete one rib at a time. This helps p ush any excess out towards the ends. If the skin edges are pressed togethe r tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on e ach bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of PILOTDDS(at)aol.comSent: Saturday, December 22, 200 7 3:18 PMTo: rv10-list(at)matronics.comSubject: RV10-List: oil canning revisit ed Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 24, 2007
John, Most of my ribs had a small amount of preload to them. I had to move them maybe =BC inch in either direction to get the holes lined up at the J-channel (the one just forward of or just aft). I would bet your combination of ribs and bottom skins had just enough variance that riveting per plans or the way you did it would have caused the same result. I don=92t have any advice that would not be wild ass guesses but here are a couple anyway=85 1) Call Van=92s and talk to them 2) Maybe add some shim material between the ribs and skins??? (ask Van=92s). 3) Figure a way to =93shrink=94 the excess skin. Add a jchannel or some similar support??? (ask Van=92s). 4) How severe is the oil canning? Possibly live with it? I would definitely get some oops rivets and drill the holes that are the worst offenders to #30. -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Sunday, December 23, 2007 6:16 PM Subject: RE: RV10-List: oil canning revisited Ben and Jim, I would really like to get an idea of what is acceptable as far as the oil canning is concerned in these bottom skin bays. I have 2 1/2 that have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on the rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then again oil canning on the second bay inboard of the outer most access panel. Interestingly, I believe I removed as much material as I could have at that seam and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not be clecoed and the riveting should be every other hole when working forward????? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap at the LE will be too tight or non existent????? Ben, do you remember whether your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second wing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a drum. Despite what order I do the forward portion of the ribs with the clecoes, the skin in the same bays as on the other wing still remain looser than the other bays. The only thing i can attribute this to is the ribs bowing inward on these two bays. The ribs are bowing toward one another and the neighbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the whole process seem like a no brainer, but that is anything but what I am finding. Sorry for carrying on with this issue but it is the most frustrating part of the build which I have found. I conquered my baggage door and it lines up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, the clecoes did't hold too well. Good Grief Charlie Brown. All I want from Santa is two nice smooth bottom wings skins with no oil canning in any of the bays. I promise I have been a good boy!!!! John G. _____ From: rv10(at)sinkrate.com Subject: RE: RV10-List: oil canning revisited Date: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin.=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be able to cleco everything in its final place. There should be a small gap (1/32=94 at the most) between the leading edge or gas tank skins and the CLECO=92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bounce from one rib to the next just complete one rib at a time. This helps push any excess out towards the ends. If the skin edges are pressed together tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on each bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, December 22, 2007 3:18 PM Subject: RV10-List: oil canning revisited Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved ________________________________________________________________________________
Date: Dec 24, 2007
Thanks Ben, All great suggestions. Definetly want to stay away from #30 rivets on the s kins..too much force used to pound those. The holes aren't that large!!! Ma ybe need to buy new clecoes or bend them for more gripping force. Live with it is a possible solution, but I am a crazy dentist who is obsces sed...it is likely to wake me up at weird times in the night when I should be sleeping. Thanks guys. JOhn From: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RE: RV10-List: o il canning revisitedDate: Mon, 24 Dec 2007 07:24:44 -0800 John, Most of my ribs had a small amount of preload to them. I had to move them maybe =BC inch in either direction to get the holes lined up at the J-chann el (the one just forward of or just aft). I would bet your combination of ribs and bottom skins had just enough variance that riveting per plans or t he way you did it would have caused the same result. I don=92t have any advice that would not be wild ass guesses but here are a couple anyway=85 1) Call Van=92s and talk to them 2) Maybe add some shim material between the ribs and skins??? (ask Va n=92s). 3) Figure a way to =93shrink=94 the excess skin. Add a jchannel or s ome similar support??? (ask Van=92s). 4) How severe is the oil canning? Possibly live with it? I would definitely get some oops rivets and drill the holes that are the wo rst offenders to #30. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John GonzalezSent: Sunday, December 23, 2007 6:1 6 PMTo: rv10-list(at)matronics.comSubject: RE: RV10-List: oil canning revisite d Ben and Jim, I would really like to get an idea of what is acceptable as fa r as the oil canning is concerned in these bottom skin bays. I have 2 1/2 t hat have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on th e rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then agai n oil canning on the second bay inboard of the outer most access panel. Int erestingly, I believe I removed as much material as I could have at that se am and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not b e clecoed and the riveting should be every other hole when working forward? ???? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap a t the LE will be too tight or non existent????? Ben, do you remember whethe r your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second w ing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a dru m. Despite what order I do the forward portion of the ribs with the clecoes , the skin in the same bays as on the other wing still remain looser than t he other bays. The only thing i can attribute this to is the ribs bowing in ward on these two bays. The ribs are bowing toward one another and the neig hbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the wh ole process seem like a no brainer, but that is anything but what I am find ing. Sorry for carrying on with this issue but it is the most frustrating p art of the build which I have found. I conquered my baggage door and it lin es up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, t he clecoes did't hold too well. Good Grief Charlie Brown. All I want from S anta is two nice smooth bottom wings skins with no oil canning in any of th e bays. I promise I have been a good boy!!!! John G. From: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RE: RV10-List: o il canning revisitedDate: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worri ed that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin .=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be abl e to cleco everything in its final place. There should be a small gap (1/3 2=94 at the most) between the leading edge or gas tank skins and the CLECO =92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bou nce from one rib to the next just complete one rib at a time. This helps p ush any excess out towards the ends. If the skin edges are pressed togethe r tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on e ach bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of PILOTDDS(at)aol.comSent: Saturday, December 22, 200 7 3:18 PMTo: rv10-list(at)matronics.comSubject: RV10-List: oil canning revisit ed Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved http://www.matronics.com /contributionhttp://www.matronics.com/Navigator?RV10-Listhttp://forums.matr onics.com ________________________________________________________________________________
Date: Dec 24, 2007
Being it is QB, it should be assumed they set your wings up correctly, versus something you did. I would call Van's and tell them working with their wing following their instructions you are receiving the oil canning and see what they suggest. Good thing about QB there are a few of the same wings out there and it should be easier to figure out than having a Self Build wing were the builder may have done something unique. You might still want to consider getting Oops rivets, if there are a few in a row, which it sounds like, and there isn't that much tightness using the clecoes you may have some looseness that may, just may, be an issue later, also by drilling the #30 hole you might be able to pull the skin a little. Call Van's. Pascal ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Monday, December 24, 2007 7:18 AM Subject: RE: RV10-List: oil canning revisited I have QB wings and everything on the top side is tight and all the skins on the bottom side inboard, which they did, are tight. As for Opps rivets, the holes are not that large to use them, just the clecoes don't grip well, the holes are slightly enlarged and with any bowing, the cleoceos come out with any rivetting. Looks and feel are two different things. Push the bays in in the center and see what happpens? JOhn G. ------------------------------------------------------------------------- --- Date: Sun, 23 Dec 2007 18:48:40 -0800 From: rv10builder(at)verizon.net Subject: Re: RV10-List: oil canning revisited To: rv10-list(at)matronics.com two questions? -Do you have QB wings or SB wings On my SB the ribs bow as well and as far as the clecoing everything on (as I have not riveted yet) everything looks tight If QB- call Van's and ask what's up.. -Are you using the "Oops rivets" second time around? If not order some since it sounds like you are in need of them. Pascal ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Sunday, December 23, 2007 6:16 PM Subject: RE: RV10-List: oil canning revisited Ben and Jim, I would really like to get an idea of what is acceptable as far as the oil canning is concerned in these bottom skin bays. I have 2 1/2 that have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on the rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then again oil canning on the second bay inboard of the outer most access panel. Interestingly, I believe I removed as much material as I could have at that seam and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not be clecoed and the riveting should be every other hole when working forward????? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap at the LE will be too tight or non existent????? Ben, do you remember whether your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second wing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a drum. Despite what order I do the forward portion of the ribs with the clecoes, the skin in the same bays as on the other wing still remain looser than the other bays. The only thing i can attribute this to is the ribs bowing inward on these two bays. The ribs are bowing toward one another and the neighbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the whole process seem like a no brainer, but that is anything but what I am finding. Sorry for carrying on with this issue but it is the most frustrating part of the build which I have found. I conquered my baggage door and it lines up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, the clecoes did't hold too well. Good Grief Charlie Brown. All I want from Santa is two nice smooth bottom wings skins with no oil canning in any of the bays. I promise I have been a good boy!!!! John G. ------------------------------------------------------------------------ From: rv10(at)sinkrate.com To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Date: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin.=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be able to cleco everything in its final place. There should be a small gap (1/32=94 at the most) between the leading edge or gas tank skins and the CLECO=92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bounce from one rib to the next just complete one rib at a time. This helps push any excess out towards the ends. If the skin edges are pressed together tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on each bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben ------------------------------------------------------------------------ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, December 22, 2007 3:18 PM To: rv10-list(at)matronics.com Subject: RV10-List: oil canning revisited Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronhr ef="http://forums.matronics.com">http://forums.matronics.com blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com ________________________________________________________________________________
From: "John Hilger" <ninepapa(at)bendbroadband.com>
Date: Dec 24, 2007
John One additional question, are your wings laying upside down on the work bench while riveting? Or are they trailing edge up in the wing cradle? Could make a difference in the oil canning. John H. ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Monday, December 24, 2007 7:49 AM Subject: RE: RV10-List: oil canning revisited Thanks Ben, All great suggestions. Definetly want to stay away from #30 rivets on the skins..too much force used to pound those. The holes aren't that large!!! Maybe need to buy new clecoes or bend them for more gripping force. Live with it is a possible solution, but I am a crazy dentist who is obscessed...it is likely to wake me up at weird times in the night when I should be sleeping. Thanks guys. JOhn ------------------------------------------------------------------------- --- From: rv10(at)sinkrate.com To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Date: Mon, 24 Dec 2007 07:24:44 -0800 John, Most of my ribs had a small amount of preload to them. I had to move them maybe =BC inch in either direction to get the holes lined up at the J-channel (the one just forward of or just aft). I would bet your combination of ribs and bottom skins had just enough variance that riveting per plans or the way you did it would have caused the same result. I don=92t have any advice that would not be wild ass guesses but here are a couple anyway=85 1) Call Van=92s and talk to them 2) Maybe add some shim material between the ribs and skins??? (ask Van=92s). 3) Figure a way to =93shrink=94 the excess skin. Add a jchannel or some similar support??? (ask Van=92s). 4) How severe is the oil canning? Possibly live with it? I would definitely get some oops rivets and drill the holes that are the worst offenders to #30. -Ben ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Sunday, December 23, 2007 6:16 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Ben and Jim, I would really like to get an idea of what is acceptable as far as the oil canning is concerned in these bottom skin bays. I have 2 1/2 that have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on the rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then again oil canning on the second bay inboard of the outer most access panel. Interestingly, I believe I removed as much material as I could have at that seam and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not be clecoed and the riveting should be every other hole when working forward????? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap at the LE will be too tight or non existent????? Ben, do you remember whether your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second wing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a drum. Despite what order I do the forward portion of the ribs with the clecoes, the skin in the same bays as on the other wing still remain looser than the other bays. The only thing i can attribute this to is the ribs bowing inward on these two bays. The ribs are bowing toward one another and the neighbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the whole process seem like a no brainer, but that is anything but what I am finding. Sorry for carrying on with this issue but it is the most frustrating part of the build which I have found. I conquered my baggage door and it lines up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, the clecoes did't hold too well. Good Grief Charlie Brown. All I want from Santa is two nice smooth bottom wings skins with no oil canning in any of the bays. I promise I have been a good boy!!!! John G. ------------------------------------------------------------------------- --- From: rv10(at)sinkrate.com To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Date: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin.=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be able to cleco everything in its final place. There should be a small gap (1/32=94 at the most) between the leading edge or gas tank skins and the CLECO=92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bounce from one rib to the next just complete one rib at a time. This helps push any excess out towards the ends. If the skin edges are pressed together tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on each bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, December 22, 2007 3:18 PM To: rv10-list(at)matronics.com Subject: RV10-List: oil canning revisited Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?R V10-Listhttp://forums.matronics.com blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com ________________________________________________________________________________
Date: Dec 24, 2007
Very good question and you are the first to ask, and it would/could make a difference. The wings however, are in a craddle, braced at the main spar at the root an d supported at the leading edge at the end of the wing. I have tried lifting the outside of the wing by lifting at the main spar an d it did not make any difference in the skin. Thought about hanging it from the flap and aileron brackets, but that's get ting too crazy. I call it oil canning because it is loose skin that is in the center of the bay and when you push on it it depresses inward and then flexes back out w hen released. Like a pillow. JOhn From: ninepapa(at)bendbroadband.comTo: rv10-list(at)matronics.comSubject: Re: RV1 0-List: oil canning revisitedDate: Mon, 24 Dec 2007 08:51:06 -0800 John One additional question, are your wings laying upside down on the work benc h while riveting? Or are they trailing edge up in the wing cradle? Could make a difference in the oil canning. John H. ----- Original Message ----- From: John Gonzalez Sent: Monday, December 24, 2007 7:49 AM Subject: RE: RV10-List: oil canning revisited Thanks Ben, All great suggestions. Definetly want to stay away from #30 riv ets on the skins..too much force used to pound those. The holes aren't that large!!! Maybe need to buy new clecoes or bend them for more gripping forc e. Live with it is a possible solution, but I am a crazy dentist who is obs cessed...it is likely to wake me up at weird times in the night when I shou ld be sleeping. Thanks guys. JOhn From: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RE: RV10-List: o il canning revisitedDate: Mon, 24 Dec 2007 07:24:44 -0800 John, Most of my ribs had a small amount of preload to them. I had to move them maybe =BC inch in either direction to get the holes lined up at the J-chann el (the one just forward of or just aft). I would bet your combination of ribs and bottom skins had just enough variance that riveting per plans or t he way you did it would have caused the same result. I don=92t have any advice that would not be wild ass guesses but here are a couple anyway=85 1) Call Van=92s and talk to them 2) Maybe add some shim material between the ribs and skins??? (ask Va n=92s). 3) Figure a way to =93shrink=94 the excess skin. Add a jchannel or s ome similar support??? (ask Van=92s). 4) How severe is the oil canning? Possibly live with it? I would definitely get some oops rivets and drill the holes that are the wo rst offenders to #30. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John GonzalezSent: Sunday, December 23, 2007 6:1 6 PMTo: rv10-list(at)matronics.comSubject: RE: RV10-List: oil canning revisite d Ben and Jim, I would really like to get an idea of what is acceptable as fa r as the oil canning is concerned in these bottom skin bays. I have 2 1/2 t hat have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on th e rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then agai n oil canning on the second bay inboard of the outer most access panel. Int erestingly, I believe I removed as much material as I could have at that se am and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not b e clecoed and the riveting should be every other hole when working forward? ???? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap a t the LE will be too tight or non existent????? Ben, do you remember whethe r your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second w ing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a dru m. Despite what order I do the forward portion of the ribs with the clecoes , the skin in the same bays as on the other wing still remain looser than t he other bays. The only thing i can attribute this to is the ribs bowing in ward on these two bays. The ribs are bowing toward one another and the neig hbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the wh ole process seem like a no brainer, but that is anything but what I am find ing. Sorry for carrying on with this issue but it is the most frustrating p art of the build which I have found. I conquered my baggage door and it lin es up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, t he clecoes did't hold too well. Good Grief Charlie Brown. All I want from S anta is two nice smooth bottom wings skins with no oil canning in any of th e bays. I promise I have been a good boy!!!! John G. From: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RE: RV10-List: o il canning revisitedDate: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worri ed that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin .=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be abl e to cleco everything in its final place. There should be a small gap (1/3 2=94 at the most) between the leading edge or gas tank skins and the CLECO =92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bou nce from one rib to the next just complete one rib at a time. This helps p ush any excess out towards the ends. If the skin edges are pressed togethe r tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on e ach bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of PILOTDDS(at)aol.comSent: Saturday, December 22, 200 7 3:18 PMTo: rv10-list(at)matronics.comSubject: RV10-List: oil canning revisit ed Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved http://www.matronics.com /contributionhttp://www.matronics.com/Navigator?RV10-Listhttp://forums.matr onics.com blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 24, 2007
John If you can, you might try setting the wing on two saw horses, bottom side down like glider people do sometimes. See how it acts when you push on the bottom skin. John H. ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Monday, December 24, 2007 9:26 AM Subject: RE: RV10-List: oil canning revisited Very good question and you are the first to ask, and it would/could make a difference. The wings however, are in a craddle, braced at the main spar at the root and supported at the leading edge at the end of the wing. I have tried lifting the outside of the wing by lifting at the main spar and it did not make any difference in the skin. Thought about hanging it from the flap and aileron brackets, but that's getting too crazy. I call it oil canning because it is loose skin that is in the center of the bay and when you push on it it depresses inward and then flexes back out when released. Like a pillow. JOhn ------------------------------------------------------------------------- --- From: ninepapa(at)bendbroadband.com To: rv10-list(at)matronics.com Subject: Re: RV10-List: oil canning revisited Date: Mon, 24 Dec 2007 08:51:06 -0800 John One additional question, are your wings laying upside down on the work bench while riveting? Or are they trailing edge up in the wing cradle? Could make a difference in the oil canning. John H. ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Monday, December 24, 2007 7:49 AM Subject: RE: RV10-List: oil canning revisited Thanks Ben, All great suggestions. Definetly want to stay away from #30 rivets on the skins..too much force used to pound those. The holes aren't that large!!! Maybe need to buy new clecoes or bend them for more gripping force. Live with it is a possible solution, but I am a crazy dentist who is obscessed...it is likely to wake me up at weird times in the night when I should be sleeping. Thanks guys. JOhn ------------------------------------------------------------------------ From: rv10(at)sinkrate.com To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Date: Mon, 24 Dec 2007 07:24:44 -0800 John, Most of my ribs had a small amount of preload to them. I had to move them maybe =BC inch in either direction to get the holes lined up at the J-channel (the one just forward of or just aft). I would bet your combination of ribs and bottom skins had just enough variance that riveting per plans or the way you did it would have caused the same result. I don=92t have any advice that would not be wild ass guesses but here are a couple anyway=85 1) Call Van=92s and talk to them 2) Maybe add some shim material between the ribs and skins??? (ask Van=92s). 3) Figure a way to =93shrink=94 the excess skin. Add a jchannel or some similar support??? (ask Van=92s). 4) How severe is the oil canning? Possibly live with it? I would definitely get some oops rivets and drill the holes that are the worst offenders to #30. -Ben ------------------------------------------------------------------------ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Sunday, December 23, 2007 6:16 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Ben and Jim, I would really like to get an idea of what is acceptable as far as the oil canning is concerned in these bottom skin bays. I have 2 1/2 that have canning. Ben, I removed the material at the edge as you suggested a few days ago, but i may have removed as much as 1/32 or almost 1/16 on the rework of the first wing. The result was still the oil canning in the bay aft of the spar, just outside of the outer most access panel and then again oil canning on the second bay inboard of the outer most access panel. Interestingly, I believe I removed as much material as I could have at that seam and the seam closed up so tight a hair would not even be able to get in it. The dimpled holes started to not line up. Maybe every hole should not be clecoed and the riveting should be every other hole when working forward????? Perhaps if every hole is clecoed and every hole rivetted in in series it wraps the skin on too tight of a smaller arc and then it means the gap at the LE will be too tight or non existent????? Ben, do you remember whether your ribs were spring loaded causing them to bow in a direction opposite their flange direction. I still think this is my problem as on the second wing I am trying every combination with the clecoes. The aft portion of the ribs have been rivetted (completing step 11)and the bays are tight as a drum. Despite what order I do the forward portion of the ribs with the clecoes, the skin in the same bays as on the other wing still remain looser than the other bays. The only thing i can attribute this to is the ribs bowing inward on these two bays. The ribs are bowing toward one another and the neighbor next to it is attributing to the mess by bowing in the same direction instead of the opposite. There could be something unique to the way my wing is before doing the bottom skin, but the building manual sure makes the whole process seem like a no brainer, but that is anything but what I am finding. Sorry for carrying on with this issue but it is the most frustrating part of the build which I have found. I conquered my baggage door and it lines up flush with the fuse skin and that took a lot of carrying on to get it right. Needless to say, replacing the skin may not correct the problem and now all the rib flange holes have been enlarged from the expanding rivets, I know so because when I re-did the first wing forward of the J channel, the clecoes did't hold too well. Good Grief Charlie Brown. All I want from Santa is two nice smooth bottom wings skins with no oil canning in any of the bays. I promise I have been a good boy!!!! John G. ------------------------------------------------------------------------ From: rv10(at)sinkrate.com To: rv10-list(at)matronics.com Subject: RE: RV10-List: oil canning revisited Date: Sat, 22 Dec 2007 16:59:21 -0800 John, I re-read many of the posts in the thread as well as your first one. Your first post you said this: =93I will say that after I got the J channel rivetted and the aft portions of the ribs completed, I rivetted the skin at the main spar, as I was worried that if I kept working forward I would prevent the skin from laying flat on the spar and it might get hung up on the edge of the forward(L.E.) skin.=94 I think this was your issue. You really want to work your way up one rivet at a time. After completion of the aft half of the ribs you should be able to cleco everything in its final place. There should be a small gap (1/32=94 at the most) between the leading edge or gas tank skins and the CLECO=92d bottom skin. This gap just about completely closes up when you rivet your way up a rib (If you work upward one hole at a time). I would not bounce from one rib to the next just complete one rib at a time. This helps push any excess out towards the ends. If the skin edges are pressed together tightly you did not remove enough material and risk oil canning. Mine went together w/o any oil canning. I spent about 5 to 10 minutes on each bottom skin with a file removing the slightest bit of material from the skin edge (mostly just the machining marks from stamping out the skins). It really didn=92t take that long. Attached is a picture of the gap after riveting between the bottom skin and the gas tank. The space is less than a 64th I would say pretty much all the way down the entire wing. Is it correctable now??? I don=92t know what to tell you. -Ben ------------------------------------------------------------------------ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, December 22, 2007 3:18 PM To: rv10-list(at)matronics.com Subject: RV10-List: oil canning revisited Was anybody succesful at improving or eliminating the bottom wing skin oil canning by simply shaving the edge of the skin and reriveting or do I need to replace the whole skin.I have two panels with unacceptably loose skin.I reread the thread and was unclear about others succeses.Thanks ---Jim 728DD 175hours 711 KT reserved http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?R V10-Listhttp://forums.matronics.com blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronhr ef="http://forums.matronics.com">http://forums.matronics.com blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com ________________________________________________________________________________
Date: Dec 25, 2007
Sorry for the segue, but I couldn't help noticing you mentioned the clecos falling out. I ran into that problem on by tailcone and began to notice a pattern. The ones I got from Avery hold fast in final drilled holes, but the ones I bought at Aircraft Spruce tend to pop out every time I hit the rivet gun. It took a while to find all the culprits but I've isolated them into "loose" and "tight." The loose ones are good for pre-drilled holes while the tight ones I save for final riveting. I appreciate the dialogue on the oil canning since I'll be doing those skins on my QB next week. Currently all wired up and doing the flap & aileron fairings. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154170#154170 ________________________________________________________________________________
Subject: Re: Gretz mount
Date: Dec 25, 2007
Chris, I'm going the same route, except I was foolish enough to put it where Van's probe went. The aileron push tube is a problem there but manageable. Fortunately, I was warned, so I'll pass it on. The Dynon tube's metal - where you screw it to the Gretz mount - is very soft and thin. Drilling is not too bad but tapping the holes for screws must be done very carefully. John [quote=" I installed the new Dynon heated pitot / AOA probe, which is fabricated from nickel and it looks like a real quality unit. I plan on at least one Dynon box, which will give me visual and aural AOA / stall warning. The probe also is temperature controlled for low current draw, and has fault annunciation on a Dynon box, or a stand alone LED if not using a Dynon box. My experience with the Dynon system I have in the RV8 couldn't be better. The system is rock solid, and loaded with features. Chris Hukill shaving bottom wing skins to fit /quote] -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154172#154172 ________________________________________________________________________________
Date: Dec 25, 2007
Thanks, I remember your post from a few weeks ago, but I didn't remember wh ich supplier had the better clecoes. Now I will remember. BTW mine are a mi x aswell. Here is what has developed since Monday. I put in my AOA tubing on the other wing and was able to finish tonight the riveting of Step 11, all the ribs but not the Main spar. Here is what I have learned by this second wing. Wish my rivetting on the first wing was as good as on this one. No dents to this point. NONE! Also a big issue I have learned...It had been a while since I rivetted, my excuss for the first wing. On the first wing I believe I was not equallying out the rivet gun pressure enough with the bucking bar pressure, so ultima tely, some of my rivet lines had a slight depression to them. I BELIEVE tha t this will cause a tighter arc pattern to the skin than is supposed to be and the skin in the middle of the bays wants to pillow out. Today I really got my rivetting down and turned the volume down, the pressu re the same, and after the first few gentle hit of the set, i pulled or pus hed out the bucking bar out so the skin would not collapse in. My rivetting looks really good...almost as good as the QB results or back rivetting. So to this point without the rivets in on the main spar the skin is much ti ghter, but a flex is still in the same bay, but absolutely better than the first wing. Will see what happens when the main spar is rivetted, and when the entire skin is finished. Again, I did remove the material from the edge and the without any skin man ipulation(clecoes are in on the main spar) the rivets don't go into their h oles in the main spar because the skin is more forward than the holes in th e spar. A slight wiggle with the ice pick allows the rivets to go in fine. My rivet pattern was going outboard and inboard with each rivet that I went forward. Meaning all horizontal rows were complete before moving forward t oward the LE skin. This is the way the Jchannel was rivetted. I did not complete one vertical row at a time. I will finish the spar rivetting by starting in the middle of the bay, basi cally the same location I started on the rear spar and move outward and inw ard at the same time. It is amazing that some builders had no issues at all with this. To me it s eems like walking across a mine field. Haven't decided what I will do with the first wing, either nothing, or do a n access panel with slightly offset holes in the re inforcement plate so th e skin dimple get pulled inward toward a center point and if this does not work I will cut large holes in each bay to better access each shop head for better removal of all rivets and redo the skin(Without dents) the second t ime. Oh, guess I'll need to sort some clecoes of buy some more from Avery. Merry Christmas, back to teeth work tomorrow. John G > Subject: RV10-List: Re: oil canning revisited> From: johngoodman@earthlin k.net> Date: Tue, 25 Dec 2007 06:43:45 -0800> To: rv10-list(at)matronics.com> >> > Sorry for the segue, but I couldn't help noticing you mentioned the cl ecos falling out. I ran into that problem on by tailcone and began to notic e a pattern. The ones I got from Avery hold fast in final drilled holes, bu t the ones I bought at Aircraft Spruce tend to pop out every time I hit the rivet gun. It took a while to find all the culprits but I've isolated them into "loose" and "tight." The loose ones are good for pre-drilled holes wh ile the tight ones I save for final riveting.> > I appreciate the dialogue on the oil canning since I'll be doing those skins on my QB next week. Curr ently all wired up and doing the flap & aileron fairings.> > John> > ------ --> #40572 QB Wings, QB Fuse arrived> N711JG reserved> > > > > Read this to pic online here:> > http://forums.matronics.com/viewtopic.php?p=154170#15 ======> > > ________________________________________________________________________________
Subject: Re: oil canning revisited
Date: Dec 26, 2007
Here's a slight divergence from the thread but a chance to reflect on how far the kits have come. When I was building my RV-6 (no prepunch fuselage, other parts only the outer skin was prepunched) the big discussion on preventing oil canning involved heating the skin prior to fitting the skin and drilling to the ribs (which you marked to help get the holes on center). The theory was the heated, and therefore expanded skin would shrink slightly and create a tighter fit. Never tried it myself due to the huge amount of extra effort for a one man shop. No help to your current state John, but sometimes I have to remind myself how much better the QB RV-10 was compared to previous ventures. When I was working on the RV-7 I felt like I was cheating since the kit was so much better, on the -10 I felt like I should be arrested for getting away with so much less work! Unfortunately it's still a lot of work but the rewards are magnificent! I hope everyone had a Merry Christmas and that Santa was good to you, Marcus _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Tuesday, December 25, 2007 11:40 PM Subject: RE: RV10-List: Re: oil canning revisited Thanks, I remember your post from a few weeks ago, but I didn't remember which supplier had the better clecoes. Now I will remember. BTW mine are a mix aswell. Here is what has developed since Monday. I put in my AOA tubing on the other wing and was able to finish tonight the riveting of Step 11, all the ribs but not the Main spar. Here is what I have learned by this second wing. Wish my rivetting on the first wing was as good as on this one. No dents to this point. NONE! Also a big issue I have learned...It had been a while since I rivetted, my excuss for the first wing. On the first wing I believe I was not equallying out the rivet gun pressure enough with the bucking bar pressure, so ultimately, some of my rivet lines had a slight depression to them. I BELIEVE that this will cause a tighter arc pattern to the skin than is supposed to be and the skin in the middle of the bays wants to pillow out. Today I really got my rivetting down and turned the volume down, the pressure the same, and after the first few gentle hit of the set, i pulled or pushed out the bucking bar out so the skin would not collapse in. My rivetting looks really good...almost as good as the QB results or back rivetting. So to this point without the rivets in on the main spar the skin is much tighter, but a flex is still in the same bay, but absolutely better than the first wing. Will see what happens when the main spar is rivetted, and when the entire skin is finished. Again, I did remove the material from the edge and the without any skin manipulation(clecoes are in on the main spar) the rivets don't go into their holes in the main spar because the skin is more forward than the holes in the spar. A slight wiggle with the ice pick allows the rivets to go in fine. My rivet pattern was going outboard and inboard with each rivet that I went forward. Meaning all horizontal rows were complete before moving forward toward the LE skin. This is the way the Jchannel was rivetted. I did not complete one vertical row at a time. I will finish the spar rivetting by starting in the middle of the bay, basically the same location I started on the rear spar and move outward and inward at the same time. It is amazing that some builders had no issues at all with this. To me it seems like walking across a mine field. Haven't decided what I will do with the first wing, either nothing, or do an access panel with slightly offset holes in the re inforcement plate so the skin dimple get pulled inward toward a center point and if this does not work I will cut large holes in each bay to better access each shop head for better removal of all rivets and redo the skin(Without dents) the second time. Oh, guess I'll need to sort some clecoes of buy some more from Avery. Merry Christmas, back to teeth work tomorrow. John G > Subject: RV10-List: Re: oil canning revisited > From: johngoodman(at)earthlink.net > Date: Tue, 25 Dec 2007 06:43:45 -0800 > To: rv10-list(at)matronics.com > > > Sorry for the segue, but I couldn't help noticing you mentioned the clecos falling out. I ran into that problem on by tailcone and began to notice a pattern. The ones I got from Avery hold fast in final drilled holes, but the ones I bought at Aircraft Spruce tend to pop out every time I hit the rivet gun. It took a while to find all the culprits but I've isolated them into "loose" and "tight." The loose ones are good for pre-drilled holes while the tight ones I save for final riveting. > > I appreciate the dialogue on the oil canning since I'll be doing those skins on my QB next week. Currently all wired up and doing the flap & aileron fairings. > > John > > -------- > #40572 QB Wings, QB Fuse arrived > N711JG reserved > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=154170#154170 > > > > >==== > > > ________________________________________________________________________________
Subject: Pitot tube
Date: Dec 26, 2007
John The Dynon heated Pitot/AOA probe that I have must be different than yours, as the new heated ones have about 1/8 inch thickness of nickel steel where the screws go into, and drilling / tapping them was not an issue. The plumbing and wires are in the center where they aren't likely to be hit with the drill going in, although I would certainly watch my depth while drilling, as it states in the instructions. Chris Hukill From: "johngoodman" <johngoodman(at)earthlink.net> Chris, I'm going the same route, except I was foolish enough to put it where Van's probe went. The aileron push tube is a problem there but manageable. Fortunately, I was warned, so I'll pass it on. The Dynon tube's metal - where you screw it to the Gretz mount - is very soft and thin. Drilling is not too bad but tapping the holes for screws must be done very carefully. John [quote=" I installed the new Dynon heated pitot / AOA probe, which is fabricated from nickel and it looks like a real quality unit. I plan on at least one Dynon box, which will give me visual and aural AOA / stall warning. The probe also is temperature controlled for low current draw, and has fault annunciation on a Dynon box, or a stand alone LED if not using a Dynon box. My experience with the Dynon system I have in the RV8 couldn't be better. The system is rock solid, and loaded with features. Chris Hukill shaving bottom wing skins to fit /quote] -------- #40572 QB Wings, QB Fuse arrived N711JG reserved ________________________________________________________________________________
Date: Dec 26, 2007
Subject: RV10 N324RG First Flight
Piloted by myself on December 16, 2007 RV-10 N324RG took flight from Propwash Airport located in Justin, Texas. After almost 4 years, and roughly 2600 building hours and weighing in at 1658 lbs., kit # 40063 took to the air. The powerplant is the TMX IO-540 and propeller is a Hartzell blended airfoil. The equipment list includes a Grand Rapids EFIS, EIS 6000 engine monitor, PMA8000, GNS430, GTX330, SL-30, 496, and Sorcerer autopilot. The RV10 is a sweeeeet ride. You can view the video at: http://www.youtube.com/watch?v=VVwVrg1Mr5k I am a repeat offender (RV8 # 80133) so thanks again to my wife for all the help and support and to Vans for another great design. Thanks also go to Alex DeDoninicis for the checkout, and to my son, Troy Grover (Grov-Air, Inc.) for flying down from Indiana to help prepare for the first flight and for flying the chase plane. Ron Grover ________________________________________________________________________________
Date: Dec 26, 2007
Ron, Congratulations! Great video as well, although you may need to update your username ;) Pretty slick having the family play so much a part of it. Have fun, Marcus 40286 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RONALD GROVER Sent: Wednesday, December 26, 2007 12:03 PM Subject: RV10-List: RV10 N324RG First Flight Piloted by myself on December 16, 2007 RV-10 N324RG took flight from Propwash Airport located in Justin, Texas. After almost 4 years, and roughly 2600 building hours and weighing in at 1658 lbs., kit # 40063 took to the air. The powerplant is the TMX IO-540 and propeller is a Hartzell blended airfoil. The equipment list includes a Grand Rapids EFIS, EIS 6000 engine monitor, PMA8000, GNS430, GTX330, SL-30, 496, and Sorcerer autopilot. The RV10 is a sweeeeet ride. You can view the video at: http://www.youtube.com/watch?v=VVwVrg1Mr5k I am a repeat offender (RV8 # 80133) so thanks again to my wife for all the help and support and to Vans for another great design. Thanks also go to Alex DeDoninicis for the checkout, and to my son, Troy Grover (Grov-Air, Inc.) for flying down from Indiana to help prepare for the first flight and for flying the chase plane. Ron Grover ________________________________________________________________________________
Date: Dec 26, 2007
Congratulations Ron!!!! I was in Dallas a few months ago and had the opportunity to have dinner with Wayne Edgerton, Ron, and his wife. Afterwards, Ron invited us over to his house for a tour of his airplane factory. Ron (and Wayne for that matter) have hangars that most of us would drool over. However, Ron still built his RV-10 in the garage with the hangar ten feet away. Something about wanting a/c during the Texas summers. I was very impressed with Ron's skills as a builder. It was clearly one of the best built RV-10s that I've seen to date. Ron I would like to see some pictures of your interior and panel if possible. So when is Troy going to finish his RV-10? The pictures on his website are quite dated. Bob #40684 - Wings ordered From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RONALD GROVER Sent: Wednesday, December 26, 2007 1:03 PM Subject: RV10-List: RV10 N324RG First Flight Piloted by myself on December 16, 2007 RV-10 N324RG took flight from Propwash Airport located in Justin, Texas. After almost 4 years, and roughly 2600 building hours and weighing in at 1658 lbs., kit # 40063 took to the air. The powerplant is the TMX IO-540 and propeller is a Hartzell blended airfoil. The equipment list includes a Grand Rapids EFIS, EIS 6000 engine monitor, PMA8000, GNS430, GTX330, SL-30, 496, and Sorcerer autopilot. The RV10 is a sweeeeet ride. You can view the video at: http://www.youtube.com/watch?v=VVwVrg1Mr5k I am a repeat offender (RV8 # 80133) so thanks again to my wife for all the help and support and to Vans for another great design. Thanks also go to Alex DeDoninicis for the checkout, and to my son, Troy Grover (Grov-Air, Inc.) for flying down from Indiana to help prepare for the first flight and for flying the chase plane. Ron Grover ________________________________________________________________________________
Date: Dec 26, 2007
I may be suffering from "Oldtimers disease" but can anyone tell me where in the instruction manual Part F-10108 is talked about? Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, December 26, 2007 2:25 PM Subject: RE: RV10-List: RV10 N324RG First Flight Congratulations Ron!!!! I was in Dallas a few months ago and had the opportunity to have dinner with Wayne Edgerton, Ron, and his wife. Afterwards, Ron invited us over to his house for a tour of his airplane factory. Ron (and Wayne for that matter) have hangars that most of us would drool over. However, Ron still built his RV-10 in the garage with the hangar ten feet away. Something about wanting a/c during the Texas summers. I was very impressed with Ron's skills as a builder. It was clearly one of the best built RV-10s that I've seen to date. Ron I would like to see some pictures of your interior and panel if possible. So when is Troy going to finish his RV-10? The pictures on his website are quite dated. Bob #40684 - Wings ordered From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RONALD GROVER Sent: Wednesday, December 26, 2007 1:03 PM Subject: RV10-List: RV10 N324RG First Flight Piloted by myself on December 16, 2007 RV-10 N324RG took flight from Propwash Airport located in Justin, Texas. After almost 4 years, and roughly 2600 building hours and weighing in at 1658 lbs., kit # 40063 took to the air. The powerplant is the TMX IO-540 and propeller is a Hartzell blended airfoil. The equipment list includes a Grand Rapids EFIS, EIS 6000 engine monitor, PMA8000, GNS430, GTX330, SL-30, 496, and Sorcerer autopilot. The RV10 is a sweeeeet ride. You can view the video at: http://www.youtube.com/watch?v=VVwVrg1Mr5k I am a repeat offender (RV8 # 80133) so thanks again to my wife for all the help and support and to Vans for another great design. Thanks also go to Alex DeDoninicis for the checkout, and to my son, Troy Grover (Grov-Air, Inc.) for flying down from Indiana to help prepare for the first flight and for flying the chase plane. Ron Grover ________________________________________________________________________________
Subject: Re: RV10 N324RG First Flight
Date: Dec 26, 2007
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Page 48-1 steps 1-4 and page FF4-2 step 8. I thought you were up in MN and the plane was in GA??? Bob -------------------------- ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Wed Dec 26 12:41:44 2007 Subject: RE: RV10-List: RV10 N324RG First Flight I may be suffering from Oldtimers disease but can anyone tell me where in the instruction manual Part F-10108 is talked about? Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, December 26, 2007 2:25 PM Subject: RE: RV10-List: RV10 N324RG First Flight Congratulations Ron!!!! I was in Dallas a few months ago and had the opportunity to have dinner with Wayne Edgerton, Ron, and his wife. Afterwards, Ron invited us over to his house for a tour of his airplane factory. Ron (and Wayne for that matter) have hangars that most of us would drool over. However, Ron still built his RV-10 in the garage with the hangar ten feet away. Something about wanting a/c during the Texas summers. I was very impressed with Rons skills as a builder. It was clearly one of the best built RV-10s that Ive seen to date. Ron I would like to see some pictures of your interior and panel if possible. So when is Troy going to finish his RV-10? The pictures on his website are quite dated. Bob #40684 Wings ordered From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RONALD GROVER Sent: Wednesday, December 26, 2007 1:03 PM Subject: RV10-List: RV10 N324RG First Flight Piloted by myself on December 16, 2007 RV-10 N324RG took flight from Propwash Airport located in Justin, Texas. After almost 4 years, and roughly 2600 building hours and weighing in at 1658 lbs., kit # 40063 took to the air. The powerplant is the TMX IO-540 and propeller is a Hartzell blended airfoil. The equipment list includes a Grand Rapids EFIS, EIS 6000 engine monitor, PMA8000, GNS430, GTX330, SL-30, 496, and Sorcerer autopilot. The RV10 is a sweeeeet ride. You can view the video at: http://www.youtube.com/watch?v=VVwVrg1Mr5k I am a repeat offender (RV8 # 80133) so thanks again to my wife for all the help and support and to Vans for another great design. Thanks also go to Alex DeDoninicis for the checkout, and to my son, Troy Grover (Grov-Air, Inc.) for flying down from Indiana to help prepare for the first flight and for flying the chase plane. Ron Grover http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: position rear Headset jacks
Date: Dec 27, 2007
Guys just wondering where people are putting there rear headset jacks Chris ________________________________________________________________________________
Date: Dec 26, 2007
bcondrey wrote: > Page 48-1 steps 1-4 and page FF4-2 step 8. > > I thought you were up in MN and the plane was in GA??? > > Bob Bob. Think you meant Page 47-11 steps 1-4 [Shocked] -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154418#154418 ________________________________________________________________________________
Date: Dec 26, 2007
You're right - the page was dog-eared where the number is... Bob -------------------------- ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Wed Dec 26 15:24:54 2007 Subject: RV10-List: Re: RV10 N324RG First Flight bcondrey wrote: > Page 48-1 steps 1-4 and page FF4-2 step 8. > > I thought you were up in MN and the plane was in GA??? > > Bob Bob. Think you meant Page 47-11 steps 1-4 [Shocked] -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154418#154418 ________________________________________________________________________________
Date: Dec 26, 2007
On the arm rest just aft of the rear air vent that are on the fuse side. Th ose arm rests are a little too small to begin with and they are more like a elbow rest. John G.> From: VHMUM(at)bigpond.com> To: rv10-list(at)matronics.com> Subject: RV1 0-List: position rear Headset jacks> Date: Thu, 27 Dec 2007 10:14:45 +1100> d.com>> > Guys just wondering where people are putting there rear headset j ========================> _ =====> > > ________________________________________________________________________________
Date: Dec 26, 2007
I am putting them in a center console.....I know....not much help. Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, December 26, 2007 4:15 PM Subject: RV10-List: position rear Headset jacks Guys just wondering where people are putting there rear headset jacks Chris ________________________________________________________________________________
Subject: Re: position rear Headset jacks
Date: Dec 27, 2007
Thanks I have the flightlines interior and didnt want to cut any holes.....this may be the best way though regards Chris ----- Original Message ----- From: John Gonzalez To: rv10-list(at)matronics.com Sent: Thursday, December 27, 2007 10:34 AM Subject: RE: RV10-List: position rear Headset jacks On the arm rest just aft of the rear air vent that are on the fuse side. Those arm rests are a little too small to begin with and they are more like a elbow rest. John G. > From: VHMUM(at)bigpond.com > To: rv10-list(at)matronics.com > Subject: RV10-List: position rear Headset jacks > Date: Thu, 27 Dec 2007 10:14:45 +1100 > > > Guys just wondering where people are putting there rear headset jacks> > > ________________________________________________________________________________
Date: Dec 27, 2007
Hi Chris, I've attached several photos showing where I've got my headset jacks installed. As you can see from the photos there is the headset jacks, a music hookup, arm to control rear seat air and O2 controller. Wayne Edgerton N602WT From: "Chris and Susie McGough" <VHMUM(at)bigpond.com> Subject: position rear Headset jacks Guys just wondering where people are putting there rear headset jacks Chris ________________________________________________________________________________
Date: Dec 27, 2007
Wayne, This looks like one awesome interior, can you please post more pictures and details of the rest of it? !! Thanks, - Lew ----- Original Message ----- From: Wayne Edgerton To: rv10-list(at)matronics.com Sent: Thursday, December 27, 2007 7:13 AM Subject: Re: RV10-List: position rear Headset jacks Hi Chris, I've attached several photos showing where I've got my headset jacks installed. As you can see from the photos there is the headset jacks, a music hookup, arm to control rear seat air and O2 controller. Wayne Edgerton N602WT From: "Chris and Susie McGough" <VHMUM(at)bigpond.com> Subject: position rear Headset jacks Guys just wondering where people are putting there rear headset jacks Chris ________________________________________________________________________________
Date: Dec 27, 2007
WAYNE, YOUR INTERIOR PHOTOS LOOK GREAT. WHO DID IT? WOULD LOVE TO SEE SOME MORE PICS. THANKS, DOUG PRESTON N372RV BHM -----Original Message----- From: Wayne Edgerton <wayne.e(at)grandecom.net> Sent: Thu, 27 Dec 2007 6:13 am Subject: Re: RV10-List: position rear Headset jacks Hi Chris, ? I've attached several photos showing where I've got my headset jacks installed. As you can see from the photos there is the headset jacks, a music hookup, arm to control rear seat air and O2 controller. ? Wayne Edgerton N602WT ? ? ? ? ? Time: US From: "Chris and Susie McGough" Subject: position rear Headset jacks ????? ????? ????? Guys just wondering where people are putting there rear headset jacks ????? ????? Chris [Image Removed] [Image Removed] [Image Removed] ________________________________________________________________________ ________________________________________________________________________________
Subject: Re: Pitot tube
Date: Dec 27, 2007
Chris, I guess I didn't make it clear. Mine is just like yours. Drilling was a minor issue but tapping must be done very carefully because the metal is so soft. John > The Dynon heated Pitot/AOA probe that I have must be different than yours, as the new heated ones have about 1/8 inch thickness of nickel steel where the screws go into, and drilling / tapping them was not an issue. The plumbing and wires are in the center where they aren't likely to be hit with the drill going in, although I would certainly watch my depth while drilling, as it states in the instructions. > > Chris Hukill > -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154523#154523 ________________________________________________________________________________
Date: Dec 27, 2007
Chris: I put mine on the top of the crossbar behind the seat backs, close to center. Dunno whether that will be the best place for cords to be convenient and out-of-the-way, but it seemed like a good spot to me. Phil #40220 (airframe done, Mazda 20B engine being prepared, wiring to come) > From: "Chris and Susie McGough" <VHMUM(at)bigpond.com> > Subject: RV10-List: position rear Headset jacks > > > Guys just wondering where people are putting there rear headset jacks > > Chris ________________________________________________________________________________
Date: Dec 28, 2007
From: "Patrick Pulis" <patrick.pulis(at)seagas.com.au>
Hi guys, I have the same pitot. Could you please tell me what size drill and tap you used for your pitot in order to enable mounting to the Gretz mount. Many thanks in anticipation. Patrick #40299 VH-XPP Adelaide, South Australia -----Original Message----- From: johngoodman [mailto:johngoodman(at)earthlink.net] Sent: Friday, 28 December 2007 3:51 AM Subject: RV10-List: Re: Pitot tube --> Chris, I guess I didn't make it clear. Mine is just like yours. Drilling was a minor issue but tapping must be done very carefully because the metal is so soft. John > The Dynon heated Pitot/AOA probe that I have must be different than yours, as the new heated ones have about 1/8 inch thickness of nickel steel where the screws go into, and drilling / tapping them was not an issue. The plumbing and wires are in the center where they aren't likely to be hit with the drill going in, although I would certainly watch my depth while drilling, as it states in the instructions. > > Chris Hukill > -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154523#154523 ________________________________________________________________________________
Date: Dec 28, 2007
Subject: Build Time
Date: Dec 27, 2007
I offer this for anyone thinking about building a 10 and wondering how long it might take. I believe in calendar time I am progressing on the fast track. Everything is slow build. I am making very few modifications from the plans. One year ago today, I picked up my Emp kit from FedEx Freight. Since then it has been petal to the metal non-stop work on it, except for sleep and a 40 to 45 hour a week job. The Emp kit took about 224 hours of actual construction (no planning, review etc time is included in any of my figures, only physical work). The wing kit has taken about 341 hours to date. The only thing left is the fiber glass work on the aft part of the wing tip and connecting the wing wiring to the components in the wing tip. All wiring in the wing is complete. The fuselage is complete through section 31 plus 36 and most of 37. Work time on the fuselage to this point is about 204 hours. That comes to about 770 work hours plus probably that much time or more X2, X3 ... in study. These building times fall in line with many other builders here which you can find through many of the links on sites such as Tims. I hope I am more then half way by the calendar but I am not sure. The wiring planning is almost over powering. Just take it one day and one thing at a time. [Shocked] If you are considering building a 10, at this stage of my construction, my best suggestion would be to plan, plan, order, plan, start building, plan and then some more planning. And enjoy it all the way. It is addicting! 8) It will also help if you are able to do most of your construction at home, unless you are lucky enough to have an attached hanger. [Laughing] -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154610#154610 ________________________________________________________________________________
Date: Dec 27, 2007
patrick.pulis(at)seagas.c wrote: > Hi guys, I have the same pitot. Could you please tell me what size > drill and tap you used for your pitot in order to enable mounting to the > Gretz mount. > > Many thanks in anticipation. > > Patrick > #40299 VH-XPP > Adelaide, South Australia > > -- Patrick, I'll have to check my notes but I think I drilled it out to a #6 screw. Got stainless steel ones from Aircraft Spruce. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154635#154635 ________________________________________________________________________________
Date: Dec 27, 2007
Subject: Re: collision avoidance
Does anyone know anything about Aveo Engineering's offerings? I saw this company at Oshkosh this year, and they were displaying a very interesting line of products. I haven't heard much of anything about them. Here's their transponder/com/traffic unit for a mere $1,577: _http://www.aveousa.net/av57inavdi1.html_ (http://www.aveousa.net/av57inavdi1.html) Steve Weinstock 40230 In a message dated 12/19/2007 2:44:05 P.M. Central Standard Time, wcurtis(at)nerv10.com writes: --> RV10-List message posted by: "William Curtis" Ah, got it. But I think it is the fault of the competition (Bendix/King, Chelton, L3, Aviddyne, et al). I guess I'm trying to figure out what is preventing the competition from coming out with their own product and giving Garmin a run for their money. I don't see the experimental EFIS makers entering this market because as with Transponders and GPS, ADS-B devices will probably have to be TSO'd, even for experimentals. Garmin used GPS to spearhead their way to avionics dominance, and nothing I see should prevent one of the other vendors from using ADS-B to do the same. I don't see this a the fault of Garmin, I see it as the fault of the so-called competition. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Lack of viable competition creates a stranglehold for most competitors > and hence the customer. More suppliers, constant demand - better > pricing. The GDL-90 is made in Salem, Oregon. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William > Curtis > Sent: Tuesday, December 18, 2007 7:51 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: collision avoidance > > > Since there is nothing proprietary about ADS-B, how does "Oregon based > Garmin" have a "stranglehold?" > > William (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Dec 27, 2007
Hi Steve I saw their products at KOSH as well. Like yourself I was very interested especially when looking at the *promised* functionality versus cost. I have traded emails with the owners over the past few months but so far everything seems to be in the future. If you contact them and get any additional info, I would be interested. Cheers Les Kearney #40643 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of EFDsteve(at)aol.com Sent: December-27-07 9:28 PM Subject: Re: RV10-List: Re: collision avoidance Does anyone know anything about Aveo Engineering's offerings? I saw this company at Oshkosh this year, and they were displaying a very interesting line of products. I haven't heard much of anything about them. Here's their transponder/com/traffic unit for a mere $1,577: http://www.aveousa.net/av57inavdi1.html Steve Weinstock 40230 ________________________________________________________________________________
Subject: Re: Build Time
Date: Dec 27, 2007
Running at 1116 hrs after start of 1/3/07. Q/B kit Planning and advance ordering is essential. The FG-composite work is far more challenging time-wise than I had anticipated. Working on the doors now. Next step is finishing the wings. I am out sourcing the panel as I want to get in the air having been without a plane for a year. A lot of the work has to do with how good you want your work to be. Little stuff like adding nut plates to the tail cone and installing the tail cone strobe took 3 days!!!! ouch! Winter is rough also as deliveries are always an issue and working on the plexi windows difficult (heat the bathroom to 85 degrees). Epoxy seems to be made for 60-80 degrees and curing the stuff slows to a crawl. Even 2 part paints take forever to cure off. I think that keeping the project in the garage as long as possible is also helpful Finally, I want to thank the RV builders that advised me to keep mods to a minimum. Mods are real time killers. The Vans designs are pretty good. If you can shop agressively at OSH or Sun-n-fun you will probably pay for the trip and have some fun while you are at it. My mod list is short: 1. Inspection port for step bolt - loose steps are a PITA 2. Alex "D"'s high capacity oil cooler - hot in Nevada 3. SS vent boxes for the firewall EPM.AV corp - not too hot 4. Matco parking brake 5. Might change to flex fuel lines 6. Not really a mod, but I put in my rear windows and cabin top upholstery before attaching the cabin top. I think that this is a real time saver and cannot imagine doing these two things upside down. Engine Mattituck TMX-IO540 - good deal at OSH Hartzell 2x from Vans Final advice - buy early - it will only cost more in 4-5 months -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154678#154678 ________________________________________________________________________________
Date: Dec 28, 2007
Really really dumb question by a newbie, how does one see the pictures that are mentioned. Simon Wilson ________________________________________________________________________________
Date: Dec 28, 2007
I, too, have looked at their web site and emailed the company.? So far just vague future promises.? The products look nice and at a reasonable price point.? In my thinking, I'm waiting to see if they (or anyone else) has an offering at SNF, if not, I am going to go with the Zoan XRX. Jeff -----Original Message----- From: Les Kearney <kearney(at)shaw.ca> Sent: Fri, 28 Dec 2007 1:01 am Subject: RE: RV10-List: Re: collision avoidance Hi Steve ? I saw their products at KOSH as well. Like yourself I was very interested especially when looking at the *promised* functionality versus cost. ? I have traded emails with the owners over the past few months but so far everything seems to be in the future. ?If you contact them and get any additional info, I would be interested. ? Cheers ? Les Kearney #40643 ? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of EFDsteve(at)aol.com Sent: December-27-07 9:28 PM Subject: Re: RV10-List: Re: collision avoidance ? Does anyone know anything about Aveo Engineering's offerings?? I saw this company at Oshkosh this year, and they were displaying a very interesting line of products.? I haven't heard much of anything about them. ? Here's their transponder/com/traffic unit for a mere $1,577: ? http://www.aveousa.net/av57inavdi1.html ? Steve Weinstock 40230 ? ? ________________________________________________________________________ ________________________________________________________________________________
Subject: tap drill sizes
Date: Dec 28, 2007
a google search http://en.wikipedia.org/wiki/Drill_and_tap_size_chart ________________________________________________________________________________
Subject: Gretz Pitot Instructions
Date: Dec 28, 2007
I'm finally back to building now that the bulk of the holiday season has passed. Thank you very much Ralph, Dave, Tim and Ben for the info on the Gretz! It was all very helpful! Hopefully this weekend I can put it into practice. Dave and Ben you both have done beautiful work. Great pictures and links! Did any of you have much trouble getting the pitot to fit the mount? The instructions say the pitot may need to be ground to fit. In my case, it looks like a substantial amount of grinding. Best Regards, Patrick #40715 / N690CT _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Saturday, December 22, 2007 6:56 AM Subject: RE: RV10-List: Gretz Pitot Instructions Patrick, I'll borrow a quote from John Cox for you on this "Make sure you take off your builder hat and put on your repairman/serviceman hat.". Although not technically that difficult to install think about maintaining it after installation. I did not think about install or location when I cut the holes for my bracket which I ended up putting it in the stock Van's pitot location. It worked out ok but I had several technical hurdles to overcome. The copper tube coming out of the pitot tube itself came straight up into the aileron torque tube requiring a healthy bend to maintain clearance while the tube moved fore and aft. The mounting locations for the circuit board in this location are sub optimal for ease of wire installation and maintenance due to the aileron pushrod and bellcrank parts. Think about threading the wires up through the pitot tube hole and guiding them into their install location on the circuit board and then tightening the miniature screws. You also have to secure the aluminum pitot line to the copper line through an inspection hole after installing the bottom wing skins. Pictures of my installation can be found here: http://www.sinkrate.com/rv10/pics.asp?f=wings|pitot I ended up making short length wires and connectors that I could attach to the circuit board prior to closing up the wing. I used a locking 2 wire molex plug for the power wires and dean's plug for the thermistor wires. My thoughts were to make the actual installation of the tube into the finished wing easier. One thing to think about too is what happens to moisture that may accumulate on the wires? The circuit board should be on the top side of the wing so all wire runs coming out of the unprotected holes are not subject to water droplets running down the wires and into their attach points. I am considering encasing the wires in silicone but have not yet done that. If anyone has more questions or thinks I f'd something up please let me know! -Ben Westfall #40579 N109LB (reserved) PDX _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill Sent: Saturday, December 22, 2007 4:56 AM Subject: RV10-List: Gretz Pitot Instructions I'm about ready to do the Gretz Pitot install and can't find my copy of the instructions. Does anyone happen to have an electronic copy? I could not find one on he Gretz Aero site. I don't need the mounting bracket instructions, those ones I found. I am looking for the one that has the wiring diagrams for the pitot itself. Also, is there any consensus as to which bay is optimal from the standpoint of accuracy, ease of maintenance and tie-down clearance? How have people been going about doing the cutout for the bottom skin? The bracket instructions don't seem to provide any guidance for that step. Best Regards, Patrick #40715/ N690CT http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: position rear Headset jacksposition rear Headset jacks
Date: Dec 28, 2007
I had several builders request that I post some photos of my interior. Rather than post them on Matronics I sent some to them diretc, because of the number of pictures I sent them and the size limits on Matronics. If anyone else would like to see my interior photos just e-mail me offline and Ill forward them to you. Wayne Edgerton N602WT do nor archive ________________________________________________________________________________
Subject: Dropped the flaps
Date: Dec 28, 2007
Well, I've gone and done it. I was hanging my flaps (all done and polished) on the ceiling using a pulley system when I lost control and they dropped. I had a safety line that almost saved the day, but my right flap has a slightly bent corner (outboard) and a small dimple right in the middle of the top half. I should have asked my wife for help but you know how that goes. Anyway, it looks like I'm going to learn some skills in body repair. A quick look at auto body repair sites suggests that a little heat can sometimes raise a dent. Any suggestions would be appreciated. I don't want to go the filler route since I plan on them being polished. John [Evil or Very Mad] -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=154705#154705 ________________________________________________________________________________
Date: Dec 28, 2007
Yes grind away. It is really soft material so "grind" lightly. I actually used the scotchbrite wheel on my benchtop grinder. Go slow and keep test fitting it to the mount as I imagine "adding back" material is a PIA. The attached photo shows what mine looks like after modifying. I recall most of the removal of material was the aft edge and then thinning it a little starting roughly in the center of the screw holes and going forward. I remember having to remove material a lot farther down from the screw holes than what you would think when looking at the mount holes. You can see the color difference in the photo. Thanks for the cudos. -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill Sent: Friday, December 28, 2007 5:05 AM Subject: RE: RV10-List: Gretz Pitot Instructions I'm finally back to building now that the bulk of the holiday season has passed. Thank you very much Ralph, Dave, Tim and Ben for the info on the Gretz! It was all very helpful! Hopefully this weekend I can put it into practice. Dave and Ben you both have done beautiful work. Great pictures and links! Did any of you have much trouble getting the pitot to fit the mount? The instructions say the pitot may need to be ground to fit. In my case, it looks like a substantial amount of grinding. Best Regards, Patrick #40715 / N690CT _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Saturday, December 22, 2007 6:56 AM Subject: RE: RV10-List: Gretz Pitot Instructions Patrick, I'll borrow a quote from John Cox for you on this "Make sure you take off your builder hat and put on your repairman/serviceman hat.". Although not technically that difficult to install think about maintaining it after installation. I did not think about install or location when I cut the holes for my bracket which I ended up putting it in the stock Van's pitot location. It worked out ok but I had several technical hurdles to overcome. The copper tube coming out of the pitot tube itself came straight up into the aileron torque tube requiring a healthy bend to maintain clearance while the tube moved fore and aft. The mounting locations for the circuit board in this location are sub optimal for ease of wire installation and maintenance due to the aileron pushrod and bellcrank parts. Think about threading the wires up through the pitot tube hole and guiding them into their install location on the circuit board and then tightening the miniature screws. You also have to secure the aluminum pitot line to the copper line through an inspection hole after installing the bottom wing skins. Pictures of my installation can be found here: http://www.sinkrate.com/rv10/pics.asp?f=wings|pitot I ended up making short length wires and connectors that I could attach to the circuit board prior to closing up the wing. I used a locking 2 wire molex plug for the power wires and dean's plug for the thermistor wires. My thoughts were to make the actual installation of the tube into the finished wing easier. One thing to think about too is what happens to moisture that may accumulate on the wires? The circuit board should be on the top side of the wing so all wire runs coming out of the unprotected holes are not subject to water droplets running down the wires and into their attach points. I am considering encasing the wires in silicone but have not yet done that. If anyone has more questions or thinks I f'd something up please let me know! -Ben Westfall #40579 N109LB (reserved) PDX _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill Sent: Saturday, December 22, 2007 4:56 AM Subject: RV10-List: Gretz Pitot Instructions I'm about ready to do the Gretz Pitot install and can't find my copy of the instructions. Does anyone happen to have an electronic copy? I could not find one on he Gretz Aero site. I don't need the mounting bracket instructions, those ones I found. I am looking for the one that has the wiring diagrams for the pitot itself. Also, is there any consensus as to which bay is optimal from the standpoint of accuracy, ease of maintenance and tie-down clearance? How have people been going about doing the cutout for the bottom skin? The bracket instructions don't seem to provide any guidance for that step. Best Regards, Patrick #40715/ N690CT http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Dropped the flaps
Date: Dec 28, 2007
John, I doubt if heat will work on aluminum. You might want to try a suction cup to gently pull it out. Automotive supply houses sell cheap suction pullers that work well on "oil can" type dents, but they are probably too large (5") diameter for a small dent. How about the small 2" suction cups that you hang X-mas decorations on windows with? Just a thought -- I've never tired it. Later, - Lew ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Friday, December 28, 2007 9:35 AM Subject: RV10-List: Dropped the flaps > > Well, I've gone and done it. I was hanging my flaps (all done and > polished) on the ceiling using a pulley system when I lost control and > they dropped. I had a safety line that almost saved the day, but my right > flap has a slightly bent corner (outboard) and a small dimple right in the > middle of the top half. > > I should have asked my wife for help but you know how that goes. Anyway, > it looks like I'm going to learn some skills in body repair. A quick look > at auto body repair sites suggests that a little heat can sometimes raise > a dent. Any suggestions would be appreciated. I don't want to go the > filler route since I plan on them being polished. > > John [Evil or Very Mad] > > -------- > #40572 QB Wings, QB Fuse arrived > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=154705#154705 > > > ________________________________________________________________________________
Date: Dec 28, 2007
Aluminum is different than working with steel body panels. Here is a link t hat is a good source for working and forming aluminum: http://www.tinmantec h.com/index.php. If you do contact Ken directly make sure he knows your wor king with 2024 T3 aluminum. Vern Smith ( #324 doors & top) > Subject: RV10-List: Dropped the flaps> From: johngoodman(at)earthlink.net> D 10-List message posted by: "johngoodman" > > Wel l, I've gone and done it. I was hanging my flaps (all done and polished) on the ceiling using a pulley system when I lost control and they dropped. I had a safety line that almost saved the day, but my right flap has a slight ly bent corner (outboard) and a small dimple right in the middle of the top half.> > I should have asked my wife for help but you know how that goes. Anyway, it looks like I'm going to learn some skills in body repair. A quic k look at auto body repair sites suggests that a little heat can sometimes raise a dent. Any suggestions would be appreciated. I don't want to go the filler route since I plan on them being polished.> > John [Evil or Very Mad ]> > --------> #40572 QB Wings, QB Fuse arrived> N711JG reserved> > > > > R ead this topic online here:> > http://forums.matronics.com/viewtopic.php?p ==========> > > _________________________________________________________________ Get the power of Windows + Web with the new Windows Live. http://www.windowslive.com?ocid=TXT_TAGHM_Wave2_powerofwindows_122007 ________________________________________________________________________________
Date: Dec 28, 2007
Wayne, Where did you get the black trim that you have on the interior door frame to trim off the edge? Larry ________________________________________________________________________________
Subject: Safety-Trim Group Buy
Date: Dec 28, 2007
First I would like to thank all the builders who have signed up for the group buy. We appreciate your business and look forward to serving you. We hope you all have had a safe and enjoyable holiday season. This is the final weekend of the Vansairforce group buy for our Safety-Trim servo controller. Over 140 builders have signed up and will receive the full $100 discount on the 2 axis controller and $50 discount on the single axis controller. If you haven't signed up yet the promotion continues until the Dec 31. Other important notes. We've added a few more applications notes on our web site including details on the wiring harness available for use with Safety-Trim. Lastly, we are now selling an airspeed switch that is field adjustable between 55 and 140 knots and is perfect for triggering the 2 speed function on Safety-Trim. group buy link: http://www.vansairforce.com/community/showthread.php?t=24478 Best regards, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Subject: Oil Canning and Santa's gift
Date: Dec 28, 2007
Hey all. I went ahead and pulled the bottom outboard skin off my first wing with the oil canning in three of the bays. It takes about 4.5 hours to remove all t he rivets. I went ahead and did this after speaking to Ken at Van's who sug gested I don't even entertain the idea of replacing it. Well somethings jus t will keep bugging me so I had to do it. In the attachment is the rivetting pattern of the second wing. It should be pretty clear. My result were great. I revetted it by myself, but I have lo ng arms. I always rivetted each rivet, one at a time in horizontal rows before movin g down and doing the next rivet forward. I really think the key is not only the rivetting pattern but trimming the s kin edge, making sure the gun is not pushing the rib flanges in during sett ing...as this will make the skin be on a smaller arc, taking up less skin, thus and excess when one gets to the intersections of the LE skin and the r ear skin. Hope it helps. JOhn G. 409. JVBERi0xLjQNJeLjz9MNCjQgMCBvYmoNPDwvTGluZWFyaXplZCAxL0wgMTEwMDI1L08gNi9FIDcw MDQxL04gMS9UIDEwOTg5OS9IIFsgNDE2IDEzM10+Pg1lbmRvYmoNICAgICAgICAgICAgICAgICAg DQp4cmVmDQo0IDYNCjAwMDAwMDAwMTYgMDAwMDAgbg0KMDAwMDAwMDU0OSAwMDAwMCBuDQowMDAw MDAwNjA5IDAwMDAwIG4NCjAwMDAwMDA4MjMgMDAwMDAgbg0KMDAwMDAwMDkxOSAwMDAwMCBuDQow MDAwMDAwNDE2IDAwMDAwIG4NCnRyYWlsZXINCjw8L1NpemUgMTAvUHJldiAxMDk4ODkvUm9vdCA1 IDAgUi9JbmZvIDMgMCBSL0lEWzxENTQ2RDBDRkE0OTM1ODRDQjM2M0NGREE5NEE0NzA0Rj48QzJG RDgwRDcwRTYyNDk0Q0I3RENDQUU5MDBENkIzRkY+XT4+DQpzdGFydHhyZWYNCjANCiUlRU9GDQog ICAgICAgICAgICAgICAgDQo5IDAgb2JqDTw8L0xlbmd0aCA1NS9GaWx0ZXIvRmxhdGVEZWNvZGUv SSA2OC9TIDM2Pj5zdHJlYW0NCnjaYmBgYGZgYLzDACT4LRgwAQsDBxKPGYoZGBIYBBmsGRgUtzhA xBlX/wSZAcSHAQIMAJDfBWgNCmVuZHN0cmVhbQ1lbmRvYmoNNSAwIG9iag08PC9NZXRhZGF0YSAy IDAgUi9QYWdlcyAxIDAgUi9UeXBlL0NhdGFsb2c+Pg1lbmRvYmoNNiAwIG9iag08PC9Dcm9wQm94 WzAuMCAwLjAgNTI1LjYgNzg3LjY4XS9QYXJlbnQgMSAwIFIvQ29udGVudHMgNyAwIFIvUm90YXRl IDAvQXJ0Qm94WzAuMCAwLjAgNTI1LjYgNzg3LjY4XS9NZWRpYUJveFswLjAgMC4wIDUyNS42IDc4 Ny42OF0vUmVzb3VyY2VzPDwvWE9iamVjdDw8L0ltMCA4IDAgUj4+L1Byb2NTZXRbL1BERi9JbWFn ZUJdPj4vVHlwZS9QYWdlPj4NZW5kb2JqDTcgMCBvYmoNPDwvTGVuZ3RoIDQ3Pj5zdHJlYW0NCnEK NTI1LjYwMDAwNjEgMCAwIDc4Ny42Nzk5OTI3IDAgMCBjbQovSW0wIERvClEKDQplbmRzdHJlYW0N ZW5kb2JqDTggMCBvYmoNPDwvU3VidHlwZS9JbWFnZS9MZW5ndGggNjg4NzUvSW1hZ2VOYW1lL35w czQuanBnL0ZpbHRlci9DQ0lUVEZheERlY29kZS9OYW1lL35wczQuanBnL0JpdHNQZXJDb21wb25l bnQgMS9Db2xvclNwYWNlL0RldmljZUdyYXkvV2lkdGggMjE5MC9EZWNvZGVQYXJtczw8L0sgLTEv Q29sdW1ucyAyMTkwL0JsYWNrSXMxIGZhbHNlPj4vSGVpZ2h0IDMyODIvVHlwZS9YT2JqZWN0Pj5z dHJlYW0NCiTEOpna2IdDJsBgXKYU2eGVI66VqW2srfhEUZSbBEPhIcNBu34XCdEQeDTff69uhEPf 3BkddAm0Cb3YdQg+nS3v/q2k3/0Rjh/a9u34IP//tmpFw5HXr9tbviIh3y/6bhJ07h/T/IhdN7yL 5SjWP0gn1+0P9LStsqrSyZxbILbbvePzf8NbsssIsxUyBWfr7/XoP4foMmz5MtMIMvBMxannJj7e +GTf6D+Q7f1bBrZnneZEWfltBw8KEH2+TAnCH1ft/DLfyInZ96egy92cad/67+RgEeH/7BwsNoML qbKgps0071Qccsf/ffkMC/+oO8GD8GDCDIMLap6SBktDOt2Egsty3dOH0Cmjvsf/+yZBad0wtJWq S8t79XX/+uvyBcc6PkQf3b9+w5KKC6T6/t+rv//3+5DOM1mf7yTh9AyCLrEjALgwcEDoi10kTjdI uM1DVLvqa7d1dr/7bbMJf7/t+DdgobL/w7retXrv/+I2I90vv//7D2/I0Dcj5swmpQDTH9/X/i0/ 0q//+6r//Yw3qcA8JCN5cNQzRHRKga7UMgh//1kEDPEVb+TdUM0qS9QXu+vv3JD4+oSFIZMArWoP //69a/fXdVv636r9/qQaoog3za/dLfr/63ciAyweNV+kqiI/h0jpl0SoF9kWhMjGHhEQCU2oXsJB WquKSh2I7VVa4S+7fiISxfp6grjS2PJK54BdJYct6xDbOrMWHYXzDtQv/fS/kGSeKS3rerEd+3Qt UHsEO6+Evt4fgtaIYQwGARDQulh+wmtqE5GCUwmCluH6QTzrbdN0CC/HrXeIwVsPahbCHvEf/8nk DXVdAvu/XekmweI0KhB5q9vDIWNSx+bAjutQl+g+iI3t2nIVvhfyEEzo7OjKkD9nAxsYjW/79pAg XqENQjvldJSNvROD5sF84DHLzQT3LesCOvX1jCC+6whv2U3070g9aSD3btBP/keAkvpBc1x17YaT CcPQ+U4OXv1YLv6Bgmo12c626oESScOHt4uaHr6H10VX/l+WzDBIfriPaUw4QIL3D7WGgwXtflzB cuYIIHf04i9Z4Tf2gl4aeGQlEw40opkHfsKtpoEG2EqMzhBghwg6tVEEvbew0rVJ2WMmZDsiEr/Q Ov+tevUb6tQWEHw1esKmYu9/u7DBuwYTbCwYSIOdhB6ct2HBHcLQYUIHotyx/apIuPt+E8jrCFOv T+I/r933+vyY/w1bOIk2rDH/Jj6lj07lu6X/7r/1fmXihhhBbWi4M76lv/QdVNGpb/13SS2/t+LD XJh/77r+v+TdKyRFuY+vdfv9/hteQwe93/1vcVJ5v8Iaf/ce6//YaWGGYCk2G37d/erdG0gm/jst 9QItV4r69v7HlcQiEztbR3TIughRFEXREkToxFVXXxS3HH/39xr1/X/rOygMgGgqAyyoDLKgMgyI DLRDLUEMgM3aK9/pMzx/unX8Mw6q+/+1nYoGQGlXBfB5Tg/+2RxiLdbEIskM42X5Y4QaYWI7aVd+ g1hEDw3HOOQ8FuU6khynNZTqQIhSMcqCKOTshog7kM+EDHIieR8wbJ2EzwRXKcmOaCfFWWOW5FHI O5oPMqZdCUHmUOZyxw1reE71a7100LQ2XZp7/v9haIpvqCLcDIpYf3rqFrs44L2nB4i/X+ojhEtl hxyDjkhyDjlYWBFDlcTgzmsrCZBFcm5Q5nKHPZoKHKcsM+hhzeUgocn5VZCaE3IO5Rcw54ILqyqE eExUqyxyY5eHg1kKOTchmjkUchlDncglsFIPxG2hDdSGxkHeiGfUiadtJbf52TWRrLsjjOscZ+MZ tEeLgbQaaYchsLCGzYy19adV1/yED53UBLAu0asIP2Kv7Tlvv/fgiGg9Tt4Jggfp9rSdM3vvp7uE 9EDYCphDYOQ2vJjkRzOQZRyrBEe+/QexlurOW5Y/39V/p8geFHIMmxBTKPbJKC/yCPkxyN6y4L7v 7/0/3+RJvO8BDNiLthOkX7mgEDcKCDZUiMSJuWO3p2m6/1bbS7fwQN9f9f/731Wu4YX/2l3/9BP9 f+//6d/+o//G76p/35NwWUMjGTETBlIyYZSMmGUjIFEwzWzWyYZMMmIgTKRkCikMmImDKSKe+ahi Lpbf2l3/UMKTcyjCNst6geHHtXpb/r6HTTvtbW1TTTTTtbW01h3/3r2CXHM9794wQjWPafqv7/X6 ffd3f36f3+t+UifiPj2v+K6Taatrv7Xw1//v/1//tf3/xQ/DW1be3qGFTCDMOFQ7fzDv9hL9/r/p /p+qf/ev3tra/esNSxyMeNQu9a3/DBe/2uumqp3end6raeq/D4awYXG9Y4iI7tpfb9iF+WZbytIu Q0OLG0wvLcaDBqDG29e/3/8Q+qSY6r/6+va6/f/MP31vX/5UBf//ZEBwg7y3KSKst7pdv4Zi//K1 fj9O4d9/7r//hDtzv0R2t3u/dr7Hwv/hLM7BCDhImPza/zVO3Vb/7/T9T+aK+vTJ7pfvX///r3hN B//cPLcUJyMBO3f//1/LnKcZe4esNF82KS4dwYIUFu29Jd///+nSD69/q+H9N/Xh///6F7el/r22 2m+bAjvrH/+EUP/0WOH0cgf2mrmHYcGQ7dOTHLHkCuHba///HtZY5Mf7b9/tD/t07f+/3/v+wu7f 2v+rXt8P/6e66/+WdKP2P6zAbHtNWGkFMF7DVljv8Li3hKr4/37X9/x3Sr7FUHMiX4zWD9v/+v9p uP9jd9fdNdvX+l+RAEf/hgo9kULtMQkutqIQ3CYW8fXuva9pLM55EcIIOpY7vahPsL2lJ6+EHf15 VA0P+0Pr+KVUObjPvwg/p95QyMMpGTDKQykZSGUjKQyYiYZqM1smGTBlIykMpDJiKQykZAmUjH7g sVFEY768QRCNxoEVGZxheg1YWYDH5G5FH/2tra6dpp2mmqfad2qf47wQbb6zEaaCBMIReun/+EDh v9PXW79fv9de1zX+0ah5iM7NxnbxS+nCCd//ojz1Stv9r9qqqv/9/99PxBB0nemn/98Eg/EU3SCB N99//dr/9qumtrp+t/73/r3rrFZPCaP8L61v/VU1T09O0007W00001UL875X9dP7CH2iyDldB/+m ///lnSh+KL/iOIw0hyyaAiJuZ3WKLHf7H7Vf1/336Qdf/9b9v/v/b6vaT770v/vFBL20W70uhENU TZVpOcyGl1wwtN+v6X+mI3CxC0nFvSjW/39V7fRWY2r0HVPxtU+lXw7C9wVoKERp3SY9t0GF9+/D Ca+0vXrrqg6/78Myj2EnXfT92iSmR2XNL9fj4YMEjB3CRMexUuDDyQGi8twoNCEQ0oIj2v/2QupW h5l2ZzDkNZyJx4LcqZ+LHOKE4MOQhMpydkWDlJksowSgrzGDwUOTc0FDnJkMccwaz8QvFwbjjk8M 5Q5HZblDk3Io4iH+mdk6t1NYZ/XXviv+yGQGooEWhEWVAZCCEREWhBohkA2qiq0yMy6LhSCBn++/ +t/b/kCDIBp632uqsIRa2qQZEtcMJNEuzbCrf9fDKSH4ryuKOdOYIQcckOU5wo4ZXBEozkdwITPM I5mRNHauP51CF44Laazd/jBhBuzJQm1H/fRMf38yDDBX4UmwEPCBRGru23XydEPRbpd+/9P/BkGF x2DYpMijrc7UGbdkcvhBw9FuWwL+t/3/DIZ5GRnDbVqtfj+92EmF9a//+SeyBeSxt9p+/ZnTD/LM Enhf93//wwbwYNtFjySoYbDSNYY/DCivJuSDI4QtwYjYIF73a1/+G+3+Ewt1+mgb+hYSiE/7//+3 ww269f19NrXBJhV8O/t/8MGswZcbH2bChqiYIF6sMK60CbGgcEG+lIWr/mHDDerf6CBoOnS4YK14 QNtYQ/h//DbD8MN+IQLojHHSLHlOBDFS7LuoYYxdcP/4YMGQYkFdybaHCwyEJh2k/tpvvsgigGU4 aGRXJD9Yd19Q3Ig7fSTsK/UL/2vw2+GCbLl99/2GHDB7pRGw7VKtV4RlC/Dh8Xf1/+XYYYaMxcQQ SRMgqLeaweEMUkVlDrpg7IewgwZd/N4f/0w2IYPQVBvlvVroJ/hIRF/Ww3//w3pMt0D/bs8zwcFW RBhA/yRIIl0x/v/r8yOJggmxD+kKEOHTQTI5hB78irpRGoDJgHD/Qb/3uob0EVwVkkeH/8ND6/X9 t9b/66SYekVxfTPRE9M9Z2HAlxkZG72t7+2HB+//1/EECMgYsQQQdw0HaDwqbFKgyZYgmRxot23N FoaBkIuSkEVDug3+G6/ekGHXar/rSrff/LfiwYOUtv+3f/SDDr/v12WP7X3f6xsG22///4QIyFBW np3p+FYaDBUpWBUEnf95N0tn1LcMGsOqW33/CQbgqqq69FvVnEZbwvLfd96qEHhyuFzmP6//8Qg4 1tNNNf4TCdLhL9iO41CD9C1X+2+vwg5lVE2E360g7pQRCEtdKK+KWyWg9qk7Fetq4ZbqXxWtx8Lp d0EsKq+v/fCeyupjPxtl8vFxTYapgC+lXrUdU1UuMJrptf/452UFDK5SB4FD1ot7VMhCVJCzsj+y GFEWS3rr3Na/92VxQDwLGmv/b6I1jroIrpaI6I5FQhvXx5DDb+4YSar6aah12U4EVWggQiwTPevt cL6aLgGCIOuc1YoKIZ1lnacCEHa7BWFBAzoMvRXf/7w6IVfQPyIRHRHSetP9VS91t1/0THbhhhAi v4LvhCIhh/6qnSu7r37/hvBHgGERVzuFCTIWOT4usviZutCgWQzrpTpE3aZHc1SDdcqZf+m2lv6D hPTv31XLHt///Sb7YYQSiOn1v1/vvr2v8k7w3qDZktGgpczJy4JjDUMpM7LjHVhQvqt/rf9Un1f+ EmntOhsJ3hoiwyupAn/+tpe+Gtv6XCK4Mxqwy1om+4YUUl/t16dL/B+weGEEFoIEQ6eoQZd8seSw NATYoECStQlEUvdeu/8UtJa9a/uqa1/V193LdvT4QTSV8seh/8t4aCRXWyilr//4YPSfBAhVExyx +ry3Ld3FMhI1M8QgoQeFC6sIL/hv2tarf1/bypN7vSK5KkDqh980X/YfjhBFc1kt7Y9949v8iMji pBMINoXW0v/l2GH5uiEgaX9Km3bW/FAhZN1rCCNixYbIQNCW2kP/sMPWHSpa9U+rM4XV+gcWiHiE H+6/9X9a9uKqrimoRtOr/D5bhN3/1/3/dgtBRiMUgxCDjdqWyYQ4zq4QY/aX//rp9rQh1wqYbX6/ H/qktcaWtPDtYMGd1Lfkx5Ufv/xBBdZG9hJM7hM5lBhBYOyyaBDXC+tS3p9N3/QX6Y4iNBhKnYOn EMEv/WWO6msMv9L+6K40CFSDRNMIOvIYZKYcdf///sEFVcGVzWoL0wiphnVPGG3f/pN//QT0XXaa +I3X2VwRB+P/f/xQ6fa7+6Jj3tIp5v7Sr7LsiP+CEXmgHqVykyQGgR6xlwHjFP6t8Qwg/12G3w9/ lOyOiOXewh+r9ftew+vNYZzsE49CLLIrDQVxtCzD+t/f8F0GGKrQVEblp0EtcMQiEDPrt+vx7MYb yuJ4U1s8b+/6m0EHb///9Nugh75Wld7WTdbAh/TyFv0r6/+mGD12xCaLHZHZS2prqEIOQjlPC/t9 f/336O04Mb/uvMH71//9fhmfqn7v0diFZjKOTH//t8E//cILK5bMa7p5ZLFIcUIQik5BE6lv9VPB np//+wku636KmNUFaDZQ5Wrr/7I4GFvhV8k/sQlXyWE1JxoaV3iiIP/1RY+Q1I/CIg4r4b4QWVxM HDCYQajwgrsrialuyOd/0lYRBxyPhQb6X9+EF4aaX0rbH3uP6dEL0kBb6X9rpajIEAiIHg6Vv/Hf 6SmoV/CDXoGdqpEcOdAYOpmaMb4QLojAIKtpzlLIFBBIsdu227UMElsLQMH+mvZh2hoNCM1XFbCs 6AvlZREBjS3f1ahhawunfqvVh2tqcNaxVOkwg9Xv42ExrrzO2/CHrDB14UIG8FtJklMqQEXleJEM 4dhrFCGCVkEHeoMNvkqvw7fX7WVzERENP8IJ3se9drQbfr/DO1QzdJ2SeQfXwu1k+XkREcQUy5e1 QMF1638igneCNAdXUJxQU0Ox5FpJAy9CYLUWZ6ENkPa2mZyoCFUE9Ybvr9Jhh//q9Eb9irt/lzMo KvqI4aLdTDGl9W/C/e316kgNH+nsJbg0RQW+RgTk4tD9Xe3fJgMdfSf33r8HgwUaFpQi5Cgxpl3K 5aDlOKV1kL4QTbDzZhNvhAv/Xv6/7sMKWOTd9MP/IYZwmEDWtLzyUEN+EF/SXvr+vdAwW/tWiMdk Cv0wqaZSj6vTj+RAP3iEECrEUQguklyxw8fykYpwQOumvhBy+ZTgQG3rYNME2+EF+EEh+3r7B5XE //KxX5TgRcbSIo6k3q6fpMsfEXfQX6SIx7SUa+H03fwQct/qxkYcEKsmO/XehvfyIo1ggSCDTI7C BAoTS4MH8RWEGlMO69hMOoTh2t6imR42/C7+qDQwg8J+9/ut7+RYV/feyY5OJIBy80UJoP+/wgqa EKwmvBHgMjr8jERwq/VrNQy7hCq/6i08W0CZtEdffkOX1EJhEWFCCEbwmGOxhBDlu29WK8Qg3ulb r5B3wgTQinb9/QhBpV4bMlJc4Ellj+PFBojHe2q2l/8f8GH20E0irDR/oPLcP6+9oiAzpPxVf7OO UtwRQ/b4Mg4fgjtaDQnIbEetJPLdwYIy/iEDCUJMO2oQbH1JE2CGi3IYu/BvxuSx/+l0qtxsseOg m5DPquRQLxcfM9lD/sH9IIN/7SX4QfT0S4JVbbRktQT+/2hnj8jQJ5kBI8i8kHZ5k6i8LvdiCBNW qBsVhtMmHCDuCLktYf96tD/D+Ij4i/1q1UjgocEuFXenDpgqv0yDSPjbW+H8yKlT/3hBDwQ+yx1p +7RX1RHEYYWTxjs5mQMQtW9+Sg/MhUuygNi+lggW0wkQg7EYsmHmRoGcrrPIWRQCpsYMuyPl9ghY aC0vh/X9/b6st7IZb9E3eC6hhyF3nIloRF1pPXyTh8L1/7FGRn6B73SLH5Tg+VdYYaBeagdPkEu6 2vwvknGRqFtdf4IIPCD+q30tPZB5DTetdl2hkVO0r/9hJ+TsuP9IL/+12tkOP+WO4dru1u03//hg gVrVP/v/cfq9FebDt+HYNtJ2ELYtaX39BhEIoBgl+/2PSLgw7emKSEayGBHqZCwfaKhi2LoJrr9w or/ar/3f6KzemV/DRFB3o1QQbDtfv8Omv8XyN/f/CqgQP/psMOlTdjvr7NAcMML1EdNr/O64uMNC EHe+iEkCoEIahBsNhf/VhsNrTohmXD6Y7xoQxT8aCQLxt1f/w2wx44vh91nYEvUrrEggtyE6w1rv +CNAM7CgpEqKXg6isIOTHLHx2ECMiwOi3czpyoRxBgyVB/j+rYYe/yx3yY6O0hHYwF4VP8JBcsff p22iTv/9thvr8NmS28PQdPva6QLr600wwYK//0w2dqo8MkELwu/sGniLa/hhYYTD74hqawmGQ4gF f/2sPj/uDf/cZXLPRDRIDB18cYMgwOUOCf5E3/pNGuUl//WH5bqq5fl1vTa2DuN2GxEJv6f4ggR2 WgQQw0GoEf/LmYFay3BRkEB2nYormoZ2yugCMyFgRunIMFzugbG/v+kun/+GxsFSKmDl4RYXaeZF QnTssdndQ7vt/hJdf/t8txcH9SGGdnfvyaIPuQgyXW0P+/wQWznKeiOw93+ui3EwXYKNRFSGGfhZ kK4hqEKHL2tUv/wpOCUMRdBA//66BDIO95NJK+jOP0zspRHDsbb81hlfhBU1rV/+0ECy30oIyNYX r/87Qjk/r79iF+9P1+IILLdwIhFZB7KR7X34TCDCkGC7Dr/wv/fFr69h5UgY2x/9b5Me///6/Edw gu4Nb0v/+SG0/fH4L7/8ILkMDopwxUP+rCXSLHcKmfZm6/j//4QXNSIPJpVe+1r2sgUI////4/we juEXCEgH/Yr/7NG2vf/7CXBWDJDfKXCGd6RThsaI2DsbQXSVkQcwwNO/r/7f1oGF0DF/03aCZhxq he2F/+1XFcLCZBhjumRAag06DCiH12/8kwj7QudAztY9giCKZDCkQQJI2cGiL7BghTarhug64IPx 1f9AsMhitvDgnK5YjRS41hqYe/8EH5JxCknsIp8wi+crI180GHdZWARBuw6bK6dBOGrJjw0I78kO /hA/hj4IoaERdoP94Nnc8ImQieDIfXlfg0BUHWHCRhkYD7DXdf/eTDQfw9fDBiIcHT716f/Tvv/6 fw94f+/hkF1hhrKcHYcNLW/+H7HthLyWv4fyEGi7wUH3GSYQggEEEGXhRNyx2s2YqWkCOMPaGkr4 aeIXp+5nDO1INGw/eZw+6Dr3/Xtf7H2VBbWGvT9ba4YN78N8Yfu96rBX+3rljwegwthf/wYfgwe0 ODB7LHCKtjSZHNvxiCJcTuNkeBUtZLscff+w3GD128PXLmClv9CiEGkGC21BobpdBr9fzEG2RXlO L/m0w8WF/7u4UEECB8UMfhS4/yIf+gwwZ2ssEDlx3tBgweW44PlTDO770EDREUA9hGQ2Zo2qIgJF v2K/29PX9N+9f+uEnsjxXfSflIf/8PpxX//8PUOKI3wr2hu2tObOQgnDC/oLSJTaBD1//EUMEDwS LQ8N24ivLt5qBfsL/S6dBNdJGSkeW5yokoL9ZX4t/PJ3lv31JAaOGv2ggg9OEEO4QXu7L7Xgg6eD xhvy3/58DHHvEIIUnCIisgRtQzw/cjBm6g3LsFeCDtWD0THd/eEKcL+tBfCT0v0wn4OOt2lD66+o +v+Er6ukF4WId0EzdDCyQ7hgoMPdv/+Q0af4QVbBVggmFluOGETfBgqgmRCYpAihsUyCDOxsRsiw CWQQv/EK+zCNJkMbSCh6rYrsWlcNXW+GheC/06oRYwvSZN39lOBDXbUmO33aH/3BWuRhwiua2W6D 6dpBSx6gwVYM64SHBAjTcGCKWGhmHCVg/1COzQbDBcIOgnv3hhaXkMCPWKTsRxHDD/0eQQbFOEGw v/oML/T+9bMhJe3/EQQcIqGbaDG72IyCBndVKR3dcEErQZoZMxSOPBg/9hqtPy3Hi4msR7T+EC7u 2CB3f+iO216I+nau6Q2uRR02GQ44WFoJUc3T/UMP+gRQwyhvwg3DrpkawSHVNKyNewa6IoRJvYen Jl4YP99nQZhEfI8vT39CIhpqk+uF/bdre3+qcIRGv2m+yKEPs1K2BbeuF3yx3+rhh/v8J9Ht4Mcr 6slmjgYZoYQMxBIIMOwmDK404aHt0xlSAjOMH/lXfprry3emEQ0Vu7vURQPYrYfX2/+/wh6ft9qn p2wpMeCD6/ojX9vyQCpw7yIDoiuvXDBmRK++3lj87B1S3mRoGcIGarDIthOxgwSDRcwXBg/+HpAg oVXXsNPt2w37YQf5kGr/YQ7i7vttf7bUJUGvSwRVv8lRnCT9twgf46JfrHDCvrhj/mgGw1BEKXCG NLQMMH9NA8mO/9eOTcneEDZX8M9Bo7HDQa0CKhyGfazYff76gq18O+1+3/RJD76fp1OiEckBn1Yf KoeCKeGH1kxvRVf2/H3btuNA0THbH/+E9O9v+ODBg0NkIGx2EgfpDwwuxCjBB0zDto7W0VbX7CT5 kChoZkmsMP/tnZUxYeGEK9Jce6V+8IX/h5XCPxclyeH/zEG7YPH3QXW5mv/Z3Cr9jprJmRiF++VA P/DYciAZBAyZElwsPBhYaaBghZaUae1STDDF/YVjp2/JuQSf/4bYYbpzUC69bVEmiFf8aoP9rOuZ KrOV/4f/60wyDAjwt4QWwkyhCn7tKn+wtTb/v9vhlP/aBIGQ9XULJjvCC0Gg0DIKBGr9a/JriaCo hZC/lj3KkD+/GW/+kEw//bitbvteqV2qU5P3/eU69Mjg//8Ur/kzL1oO9ZDQHhct9DphMrozDLpf r+wnXH1/wQKXDG+qbgtOwb9sa8RCEMIRFoJ796uFngyuv+u+v3C5O/y/LUqDL91leP9lv9/ceuh/ hLCVrXbXQe/elh+oTPUnD/7WI6/hesIltYEIMV6Y9Oyx3kKIpTQuNVBA6ZN8uycW12NSqBOQXr/4 qmvv/bwgYQe///+lvQXkOX5N19BAqvyE/VWHShOWOTH1SS+/8fVXyKrw6fcIIEDCh0y3DQfBhXY4 ae7YMEKClw7j62sM26ilMmOHj0P4SCBhSGgF/D491v8deK/axThTD/r40Ld931tS3ff17/tNGQmj iI+Y7Xf/8ERuesNw8MJoGC5b5oM7diutkVwu8RBCIhkzAj/PXlj/YQTNsNe8scPcRp/+PXaYXXqR Rf6IpP5Me7uT2gYP/t4YK///2h/M4v+Pqsghf6vwiGwNJj7WDB5bjhg1hoeK/SbpId+LBlOTzLmZ ScVyGfV/r9LrHb/tbja1U6f+L/msNF07IN0Lt/1SkEDYvhh/xV0y3KXFhSmgvTT+069cP/3knssw pdv1y5hg7yoM25MdMUDEMhDMT1iIjWyEGQ9YYf69U//38PlvQq3qgmmnUL6TcRyGGftfXa6/+rbh /aggzjpBoWGEIYV9hlWTjmsMcQx7wf1kkjjX3S/0wyySDaciDxG9MWn36/b/X/v/5BpU1ConeWPf WW/8JcKn2vr/9BL/HTW8N7udg02vLH/hLggT80A+MKu14hAjIlmy3NRhJukr0HT92Ma9+oIF0F+3 vrr4QS6/11/+0//hBdL8N9UqpeqfFx6LH163019e4S+vYYNpqEn14QLeRB/780WKYjHj8qLRBxm2 /Rgy4xDCELjuEu5nu/16yGcO3Xrwuwf+2dlQEChXEKvd2tV179xyQBH8GH92GGmdAICIo64Q3+DC YpKNKoJ4Q3yBGuG/98LCfp7vGuNlDlOa4vV8GR1w1/9XTXCMK71KcCHqRR0IiIg2RAOXfxfKsE/o EFLAsIcUGVzU3iNMRBoNFVByzAJgg1yoiO8MPr+KC2U6H7b8RX/rUhhn/+liDJbM6r1nYWi5GPLI nS27RqGL5rDHDIx/4IF5VA2d9sIpGcZ2WBoeHSLHiIQY5Vj4ZXBfpcP09sfySsrqF/msHTw1wmE/ wlhP//kMD3vrdbx6F/EFhEY7kn6NFw2V1kMXiN32kvN7fyY7+tW4TLv9jf5lqX8avv+l+tJv/+/y s5UgcIP/plvXyDPrLH+wRkatAn/wSYZXHTZXMhvkEBi0yMB/ayBXqiF/f/oIHTfXqw4YbB7SXT/q t//H+ITSf/CTZ2Hp28fyd/zI0Tj2FfvFeEDhP/ggRswwZ24Y291KwaQbDJDlLmOmPELev6tNf6Ww wnt7UjwE9Yj+d+iBg+pRv2Sf3IrxHv0FbhA9vDTBP+QZ/oPacIMP2h9FkMhhn69h0pWQzGEwZXBA wRzGh28ED+9IMnKIUegjCML/T99vCCRAi2Ib+RuRFMt+qf1tDqffQi//x9htJBERO2/iwQqKV/2T AiF2ZcJ++iTu3EcmCEIEkGwyIuqIMKwrov2n40cQJrhA/XafhkIOFuglbbEa63/QadcL7/fiO3CR G6sMMri5nByDwra91+/QX2F8H1h6SFwyGccoc7kNIcijknIQcschRyQ5hzjl7ChDOy5jNBY8gV5A /fTsmH6fQf350AjvQTYZA8FrZbfp1ul/3b+//LHDb0/Wmw9Ew/8pwXbC/8t7/ojf0Th/gwZK6GCX saVnZmB4HB2s5SBF7VByGhRPjI5mBW/71ekg/oP07cimQ+63MsBcjmRyLhC4KRcGFBSWg9x36EX/ +q3X/72wTcMzrfyuOiCmdi0FBLuv7//Bd/+/qCNAMEQzpQIQYRCjNHtBXO0vPmfwQZy0z4hrBEEx RA2R2P/sRgguNf/6bcl7aCV3/aaaDI01vwsE7X9f4ILpfr12w6bDBJd0td33d+CChTOUlGHtf/rC 9exXfhtQYZ3EEFBtkLB7V77vvZB1BCkgzGDCEfb+FC6S//65WAXQW6af//7Chp2EHmozx/yZgHtV //CCptUt0H9/VdbYMg4Ls2gn/+MPf4a3xCCScKEFLcPRKGi31hgmEwgwgwgwqBkOBB3YoP/XOy0E NYXBgq4T10tukQeygTegpbuvxaEXHBhuh//WdiwbA+Nf/S9EdnGC98JUDfeQc2I4b5bljuX3v/wS 66f4IEEm4IfYqrbBJvTyqUgRsXkICe9OU5m0VAvXpbggsfW+EFVr7pbrD/g4YcEt/7hoP/XGC+yx +vST7W0lTYSYfvB24QT/6ap/9cF8GIT8QVGtu4tBhJDYIIwbBtfB4ohCURUMIhA2R2F//OyykLs0 +v9PxG20FYYaXhg5KCb4XF9+/pdsP4S+Fd5LvV6268NsKw7f/Lct3//hh/CS4YJKm0HDS76U1oEQ 2PBgx7kMBa5nZHf+O2l0RIvyDh3Gu2GyBEvtt0gnM0XBp2/Bg5FWt/t/Wvv/fo8vu6NPYbQXjw34 bKzjv6+PSWUm0/dfCDfDBuEkRogwxCI1O+duIjO87FWUgROI4ish5Q/8EDCWcfI3ev7bwQTsNwtk NHdg+6Cg5BAX3zwZVr/ffHXTXbIwEW912R9HYasYKDpkEdffW8fD5Vsw/7fJgZMcGi7eHgoMftJz swCFOD/0wunSSOykM8zljtYP/f/sNOD27/8kkRwLpaCQ5EH8mBGHX6SSfv/69b9vWvtfyLZcGwLo FzUBYh4X/+/sPiLuVb/2Gsbex7qdQPDcEEYmD2QcdVQhCD+9L/2D/299tur1VeUAfBKw3DZ/QiKD 5oIOOVIbr/+G/rD5Mf7DX9/0kk4bBiPiI9csPert/eH7D8wBgFMZHE99r+Q0xhxwoXg5Tg67hJKu I9g/8N/+LiP/spxFkGBziYrfD6J+81H0t9cP/M7vf9ZBB/7DJwxTMF2D6BVryQCf/Sr0vBht8Pqt BOFpNs4GfEIEGDPCggnMgaOL8IP0vZHJ8k4P37D9/DJDnHIRwn3+9dIHqCI2ad/p6VePt/8Nx35G xQZz/9XXCT9ZMkqbfp67a+G+RSfsuwwbbH0LhWH6Le8hy8IhJKbI4VkONMrAp3UJyGhRT0F2kQwx t/v6Tbd9L96reSSUExhh4JR+n6Vgl8V/72G79cK9e4umFT0Ct/In/2P18P6w/hQk8ijpocK22kLI rzsUIpwdAgZBcPwQN6QSYRVlnAyuQkC/+70gqxDSrbq1h0oWPvdU0/9D/wguP8cJMN/36k3mtF1/ rhhP17/EEgww0GCFpInEMNkRYI3YVPO0gOXbCkPsZkyDQQo1pt0sfkGK/+0F4v0m2xCq9DKeYcdp 6/pHaX/IUcovv9IJtqkkFhsNhJDwUNtofmz/zsLDBBm1wQ8fsEEGIUNKt5DB0i7hlOQgZY4PBg0Q uP7zLRG4j9lQDm0YyPE6NQpsi+aZgzYGYKeU4I4/XQW63SQdUnOxeWwl0+35EAbQWu1/6TTew3CT ILugt/aUnGWP/1V9/vEIMJhoIGDEIEDEIEEYYYZ2oAiEieZE2kSLRa/wlILYKByBjyHHLHKgqDjn HKc9lQS4w5xhcghLjYVsdlUpftTg/rTTYUOgg0km2n03UV3XHy9D1n2KmXJxEaCQ/XyFCfwgYTdN oIGEEFw/3hoNu19KhHWl/+QXT/sELBlAgeEdjDrysqRYC9QyH2nDYjvr0kl/+QbkfiyFHT4/jLmF +G76f3/yUnRv15DKn+x3sOqqotIOvbv2kVRK+hacNMjrb9YMFGGROI9pPGDUvC3Z0D01BfQpL6xE NycG/vDBNA+EQ0f93Kdf+tV/50Aj+Lv25UgwR5fQds1oV/fdrynB/5Gm0G0sjEY1t/BEKNIRfSSQ TiI57Kcv/tosdtCLXrS/1pZKgz9g1/syLFX52Jl1hVvIxEdF0b/VfC6IpP3UkMpDKRlIZSNBlIZS MpGQKKdmuJhkCiYZMRAmUjJhlIyBRMNisHEWKVc0AuvSSS/ILp/+++Hd3Dh3Dhw7h3DuGQ1dv53W Geqlj+n+va4P63cO4fdw7u7u7tO7sYd19tUst+vql7LoC5AxT3RY7g4ODhwcHBwcHBwcHDhwcGwc ODYcHD87GkR0FxGu8L2glSxHb/1zDh3cw4d3fd3cOHDmHzDu7QdoNPOyYP//69ZKQz7/Vb25Y7md 7zOHM4ct3LHDlu5nDmHDmcOaHM7ljvYfc0Byx3LdzDuW7T1q+v+jIFkl08oDR/SD4YPBh4MHgyOu GDww8MHhh4MHhh4MPDDwweGRakDDwYPBh4YNIMHhg8GDcGDRdjYRGMWyOLyRTfh0tedQY/reHww9 vbw3hh7eGHw9vDeGHbeH29tWHvhh7e3tpO1ZSgzsf+ulVtEMH/rhKHhh7ew8N4b26Ye3tq2t7eGH 3hh7Dww9h70GHsPDDXGDv/6/xvkr86AqORAphhg8w2Dy5lx5hlxc3Bg8wwwdl2YKy7MC0CNAPBFu DwRoGCNANTDMFl2GHgjQDU2y48wy48uww8EewbgjQDzcGDUEaA8wwxCN4dkKq2YcFetpaX/v10k2 +w37fYb02+262H2G9WHqG9MOmGPYfYb02G6v4Yfbeg29OHph+29N0G7D3DC99LVLr/+lsat+GH7f hh+3pt93ph+23t7e2+2H2HVWHpt+GH23qG+4eob91sMMVH9/rzussL/4WHw37+Hvfw371h72/Dfh 8Oofw34bvDe4bi38G/D3g7234a8MGZBsuSlx/+GEklh8F/96ul/6//X96+l6+uuvperXXpMsdfpX r6+vr99r15lfqOl+v34bhdL0vS8JeErf6S2l9LaXV19ekvC9JLr6VV9BLqt1+XFdV7zST6X/Bfkk PIMU8KbhBBYggsQQLEIFiEFQggWGEEFiEFYggWIIjeGCBEnwgQLYIECw0CBYggtoEE0IIFhggQVh oECxCCxBAsQgxSOxf1pOk7kMoRQd2EkvIJkwF7/4eFpYQWuEFpWEsUtKktLFXFLFLFbQWKSpWKWI S0EvhEbtVivqTH9339fZiS9f4bhYS0sIKvBLQWEsILS0sJYSwlhBaWloLCWgtXBBXTrD+WP//960 slK8LyI4+UmZr3SwgWEFhArBAsIFQILCBYIFggWYFwgWECwgWEFQQLBAsECwgsEFggWEFQIEG1Oy YEBELKqv1maw1/6SWh8k74KuhftroLCC0sJaWlhLrS4WgtLCWgsJaWtBBUlpaC0oaqgv4/3+tV+L hN9fT/rCWlhLS0sJaCwlhLC66WgtLS0sILS0tBYSwgmQg/CRJaKWkh3r+lXtJ+E1/2KiFEFEKIKI KIKIKIUiKBBRBRCiFEJCCiCiFEFEFEFEKIIMLkrBIirIZd9OuNsJhYShVktBd3xa8t/1CqFUKFUF wqgqhNQmF1oL+EGqu2qdroR6/Zh/7Xz971VQq64VQqhVVVCppqE11wo62FX+kcvJSsPvhhf/4JhQ TUEwUEwTBQUFBMFBMKChMEwUwEChediQyXJFuWOw4iP+qYS0OZOwuPe/cREWhaERxFoREaaFhXnY EgqB+7B55l0YFLn6XFccVnU/r9COIiPhDCbvhA9CI/VL78nBPFe1DXCBX+n+2lVZBAwGFhA/Xjd8 FJx/+/pL5ntaf/v9BBuHqicP//9w1rwYLUq3DRY72D3iKoH6vSSa9nVkXaXh8EZRe5nBpMbB/7/+ ofFwvfQPW9v31ryXRHyP51I4W61WIXkp+we8HgwwgnDtpMrYFUIRB9dWkkllVgRCyNaRDH7++GFw t5MrVe687SKv1gv+DD+8NrYXrYdLS/jr9wvb9+icA8wZgYIEYIwKiEUaKoBGkiWO1v0kl25D7NO9 /2m/bCXdB6veE+F7dardve6/4Yerwvhx4ev1+6/JSBAYf/CIqf4RUB79+DIdOyVKWOUOdwgQg38K l6RkWmkEtB/f1+wmG+kob4exoRYX9JrX2tel3XgtdO+gkGG0gnv+H4Q/+vaC9/QLesGHiEETYQQh AjsUNF+x2oq5CP9LS8ZFlGwvYRP//oIPnYGRHtyphg7UG/Vf9JdbpcV/0sJNqEIXhN/+9Kl+9/39 hoILCBN4Qet4YLgg1Wk6pYZC7M710voQlpOix+/4YXsK/FJcN7/JME/QUQr9Eo2lJjnhHYxY8Jr/ rJXGBA3hqv/YILYrhA8OoQsEd1hyMDHQ+lXhUyreML/9QX//X49pJeqY57G/+CCqv2qYMIK6/XSf kn8kkyKv4hQn/YpBoNMpHnAytzM6SSWFCDfIcutfC/tU45b37+9d/+D/9a9hU75Y+//6X/5DYRkm CewUHeGO5nLfW/9eklX68hlfr7UP4SJj/71+rvS/u6/642ix3tUzDvd+MjML3+kpxKrEeG/vzODS fH3vVughXJYSvT+kEHTtGoJnUGLy317ex/8cf/+11aW0nvXlj/2Gl+sdU+/7SX+GEnycb/d5J+DD BLbiqDO8fXvFIJaWMvnqD1+vQeG1f6EMER2v9a9fT/3//zDhhIu2DuqQ/+3pf/169dcHpgwwQSbD ejIGF+ur4QYSXvgvfH+/bhdtUVlhWu//FfXC9WhWpnD+q6O1ZUGkRNiAl6/SSr/C/TMV3hg9oJMG 9AgYQYQMEGiLu3/6SpVFaa39r36SDYoJOru//1ruv++urDxQTDCC/kosP/+l1Kr1yI46iPuDB4IE TZW9E+pJwQcMh05KDjfa/4STkrDANaBV/zDDeEm+n5b/dNB+NXpL4TJO6f/3D0E2v///0NamRZqu vsL7+oNxCbRY/9VtQSsjnj9BBpILo6gR01//qP+PtaRMe7D3Oxfr/lzCvsMK6/pU12rSV6IgRfC7 pev6vsffhoEFBVsfTwntt+8UtL2n+H2vEIKF71T1D9ev1S5DOrMP4fIp+qW/TQu8H+vnYsl9dPfv p+4QLXDCYRzBENG63EU+4pBpKFuPwfv8JQ/OxNBMJ4P/dDS7TW/b+0rvO0gJoPD6/15CyHYfITMO 14goNFjvCfZWiGF3pBfB8MH0I36vf0sOd1w//X7fv4UzhpRtV/1pJL/df2EoYaTnYq9Fv1IEGfIg /SpLC8H2vFw37/7r3vpLkpB+TcPj6sMJfqvX/eteQa9+vmGXFJtqKXMji7FJFSBxD9+lXpEYGjww /7phtLDD/x2/JhpL7C/D//bCS2NVXfp9HJLZhwX4Lcg2aXlW/DwXho7DR2VhozgGP0kk0sMQZG3h D/D/8LfiP3/96hPwWsO/vqmG/9/6rTpv/v+DxBAibDBnhRrvwgkE69/C9t/DVJ6+t/r0THryBGvh 9ZneEEG87Fq/6WnX5Y8jGRxOQcZw/fDDcEEG1OwLLhDIFAjHcaCtV1uhXJmM+pY//b65h4QtP/xS 6+sfasP/YeEE66Z2rX3apa39fF2K1wYcQUVpHRG8jhAn/oKku9Rz19/Uw2HT8iwEhFkEBiXT1ql8 RkuXB9f9NvrlzWuDlR1fXu0geiFCeDC/wYcF7TT36B33qkoZhwgg+QIq2g1/++ybkJprzoC/uqX1 C+QbkeP+l+hDKcjBy/BennCMz+jIqtLEZO+wfQf9BK11a6f1rX0rpXhBvh9kII+IQKDvfet/+/VN Kv8H7B/pQ0WO9r2zAfSk/Be9df/4Pwwf4Sv87FX6EO1hV/v6S/5qBfkDD/hBIuA0mN9LjD1fXaVJ V2vJx4P7hBbDSfv2kQzqEI+r6XDXw/D/Fbf35VRtL/VJfFf8qHMOt4JwYMEmztWDsUDhhb3pCqWQ XaPf/WK+FmJsFI7bXcX//yUg7T//vWtMMNBWw91OyVGCf9L1YIf+Evx7DYQJYbCBglO6wcjsWh9K ktx+703/vXhm2Tr/6XuU4aPqucg/+Ft6MuXH+lpZU3+/pP/YQQIGRYChHagEKcM8JkEhfpKlv/3+ vxSbEIJNOjtUDH6WQReyCDr///qHS3Kl1t/j4jv1iPcqzwQIG+mTHK4pVBnZcH/SQSqSwUjogxMf +vhBOp2KG4iE02F6WbdYQwv9r4fV4cJl5Nx9VvfT/siQF8OIJtFj+LTO0hkxkzP6STQWneX64jvM 4dRX3blOCdNkKf66Jj5bmHfntP/3T/y32n+n1/Ut9b/X9cMOCrOzAVFjk3fNHf/SSa+v/zxf/DDr 136/JcTv0l0v//QN+RN/hun0//zusMFI//2sydf/+EUOD+vqYYMHDXV37jS/9JBCkPDjuKxZDOP7 f6dw75blj7Q72v//2O/Q/dft/+8fW5KAyttpaXqK35Bhn/w3Bosd/3TFHYEyXHS+KQWtljhBrD9f 9KHx/0GcdWEK8mF1+9M44WSA0e/3SmdpP/QsE9+OqSWLCMjCwf1+IILBhpOxFEDxChQyhznMP+qS yVQREGFuS2ZyDCcMyvWgttfsyqB7ERD/RkVKvQ07yTLj+lwwluqy3/qg19aTOyVb/8ECwRoDBBGG GGzDgiXAiuW/9JVS3hY/33S0GGGkmwxra//XS9mHKH+CKf8l71S90u0Fj6/1/lUuZ4IK/6IgPxBe G0F2CIUYXMEdvnfjI+R0Xrj/9BJd64jIjmT+wbfXhK+k6wVCIh9e2r6//EP4YP2F0oYb/Qgnb/9O tfGqfykBPYWIQIMGIRHtXDIRaVMU/pCklkpB6SZMeDXDaWOEg6SJjkx2oSdnHCX0v1prcbg3+gg3 0+mCR2Gzxi0v9e4dreoNfggQbXSq0QuxEORgQL+kllSMRz75JhyP/rzD/5buF3aXaS+Hx4KP6CbX /SmH/SaW/X/0D8k6ITFbEfvIPuthUwgXpJBLv6/cL/1ZBjegYWW8Jel1r+R9++t/ySA8V6/peSoE +gRDvg4L2YcE3FFKCtVLHkXAj0l8L+v098WCjaav/b8w0t//8tw9caChhf16pX7BfbX8MHB3sscI rIOd6ARcV+goVpZ3MHLv8i5/bv2qQVv3+ulkqM2o/x/hh3fhoECXwyvKHeZKP/9NB/wwu8Eew5hw aLcUE0SUwTvBCLB46QWvTuTHIsL9fhNvbq9OmQ46Fgg36117iI/BrruHtpPXDO0iEW/O4qql5Y/z z6PgL/BvBgwXOxZpWyDG9SF2TD9BpJCl07ZrDHIQJhTO/1UMNLOzBQ9FvBtW//+79ZDCfW/rQWb2 wpfbCF/g3Yf/VL/3g+kg/2ECCwmDDLctYIEEGGRNiA9VKWKm++klq30Uh8gXo+/4oJ7tUF7/QPLi H71r4jb7qkeQf7C6h+u2THsRlYg1zPr+tJ9+/SD/wgW0EuH0djbI7kUdY/ZGjH2Ekkv6nUGPr/hL pJMNvCaev/CkSDK8VMijWuF4P73/hYcILYMQkdk2ECHDQ/qC3+ml8xRcqBe3H8QWGFYOggg0DEdu KIMMbuknSWdzB1PEU6vH/1g3r/QILW6/yUg5i+DHtefqwgvWP6CIOUfXSXVaeQcYrIrheE2Y26CC TbRY+W5bvD1IhKT/6C1r8eQz6dD+MQtvr/Eb/90kt/kC9MNenUt3FX+Fv/2vxFb4/cJW2v8EyOMM hgF+2kNJbkgNHJAKmtf7F0QPiwYP/VLyUg5KlmoF+v1t/Hah/+v18P/TJFSTb+RgMS7Z2sC/6SSW 46/1TvbX1pkx2r/6+Hwgv93fd8K+mgXX+lypsgfpc1I8i8YzGXRHH8HB0/jJOvzsJEuCdekkgt08 0DHOzMNF3nNhosd52YjigjSv7BArX1/yMBjCX4d6d/qEH9oZ2QBCCj+l110F5CD5cA5oDSTdJjUJ gyKqiuEwvSS8lQ1+F68PsHu2k/hBtd/9HJJ0P6/fDw/t+lrIj9hv/r/LmC79XhGgHhg1ds1jbpEx 3YMIZpgiXBwYLbSShpdVXIaA/9BhvMQYf4SLtv+XjBH2BabF9JethNDwf7++2120FbD66dSj6JgI vpa4oGR8jhOH/8GHphutsIEnbFJbwaByGcx9Kq1JYZHMwoi8oDZ/9ff36/M0r+ma5yU5oL/+4IaD 86gx/9LcLrVv6jrbb2S0Mr1SaSVesH9SQ/DCCC4QQKnEGRYCQJ2mwlDc7LnrukopO+QZ5Vj8L8Qg sUvbEJNBuPd/7pddp8gX/DC618PQrUsd3fXrSWI+PqhwQItybwQLwbwgbWw6eh+jDrclQJqTg//C SeEF+p2TDOGt1W/7S9V0/+gr0q25h+DKWVaqva3/glp/4hLEEOx6jYYo7DBw0Vm3Swkl5Tg7hB/6 665LCe6lVBBAiESesyJ2llTdd++EnC34T4eggYIP0uHXvC79bBSY7hdZ2JJpxmcpwQRAgWD/rSS7 IT5Km/j3W+dmBBURW7/av+gQfhv/X/w4ZmztOLr6Q/+g+nr+HvXCZA+4YINF4TeiM79KgklkpBwg /b+tNw+/siitu+nhBv1qv/3/r3+qj/+r/XpLy3f/86fcPRY75bkx2awIhh0XD76b/FJJ4JKZ//9B /MOHex//8z9D/1Xxf+3/3hPDel7/LHb/2tfdV5C17+v+D1wwek9ry+BF1TDX9it90klyKxgJ68Gv +19vXiKoOO/6siutfXrVO9fX93yx3hh4S3r21uKoNf9JECl1T4r0v1LgNLfMMMPBIuww3kM5bYpu hH/VYrpEs3WHX3ew771DeEFbDq+vIyJ+/uv+net69U7df2312zDhe70neu6pINet63/dqDB+3u+g vEaERG4bDSfqrf7EVDUL15iDD/6C9+dhA7K4jkFO4YS9Ujjr/ca/ug2/f6ww+gmIOQsNF7/df/aW wvf4MPbfEECwwZ4X7sHbraVU12I84Q/df68Lh6/lj/hd6XS/+v/X0Fhva/h719V1vv+3aBBVY4QL DanYszWGCss2eHyVIV0kqpwfv74aS2tL/rfYakShfS/x//iEFXhLdFj//jh/q652ouvhglBAtYgu K+F52gHw1Igv1SGs7GCY+x6rrfOzAIQi1t3h/VVhf+Eh6/CQ9fV+ulnYYY/4QLhdakQE+qEGQQD6 SXncwx+or/2k9Q6ZPAw/pa4L+11+wljOy53bBv+lwS/guD7zsacNpu4bB+qCr/9f+CBy313w+0iF R2p/8H/YXD5h33Uz3q+W731TryUhnYb/G5hwerGE/zIYEsHzwnoJNNa0ynDr/29L/wlLHf//rR2S e4Yf/2/dfyFhoT79f/SS8gghHYP+/Bg8JctyY7hxV3hvyOCdq71jlUhX+Vd4bwl7/8t3sMLEFmQo Kl9JeF/35ib1b1+uvjrBA6ql/BL9QfwwweCBGzDBt+HorZmz5n7QRDgUyJhlpCK15Tg7/t9W9LuI oWC//DQILCD0ggzFkrDwX9P99BdyY8f42nCCwn4Qh4WEv2Zw/de+mK+6EUEoQNKiBBl62/1Yf0lh h8JmHT18FhNJJA9qQfZlP/9v6QWw2El190RgZ4LQfhEEwztYIMNCPeGDvEECwbEJCOr0sE4RDHkJ AaQSBEQuDzvQH/hv0t6OyYOw8NQvpBbfpAw3JWIRoI/c3Bh+uG+4xFxuFhtKkm1hg/rCYYfhAnbX IFUdhg5Vs5ESDLwQJwYapAgQYbhMqIQZF4hLKg3f7fFbaLH1tXX8LbrOaQT/ERH/vwv8M+MjAXa/ 9IkWH1CcJEh3oln+rhJ4LYrEOFGv8IJB4YaSVhBBEI4fCdedit9IL/+zIuf117f6SsP7+g/DSXXX 7d8mV0t21rSCv9fCD3EEFwt87MSU1DSSdawgjN3htJLQRmZwM0N///CC/9Qv99+nTV0ukmre2v09 a719aCrH6SvuqWv32Cv5bh7ggXB96pkGEMqgdrVBQ4WGHWwkvDexQQXX4rh8w70sFO3991xvU7xE IiPH2YMh5iI6KI1JA0Kjb2ggzF6buu9f8JBOmvqQagyGUghlEEMs4iLiIhghFd9Kg/oPguaA7pjd Ex8ibHnYgx9BWq+tYbxQh/kx717D1b/omYO2RmbzaI/SqbORMKgp0RgIY2bDOVB4szmHNBIISHNl lwZzeEU5HQWRXt5KQzyY/76sL29Kuuwk4QiL31oRklaMgo2q77oP6w3j4YPBK4pJkEUiD7Av6WGm g9bTvrTNb/3vgjw9QRUPw3ITY3/rr1ShO3tf9e/02G4UIN33o7CBh30rayDsyE9EF+Qsicn2Qrha /fDuvYMNwiPLBsEKw6KuPQ60awRCwg0wkIYUPIIQ6YS/tr6b2guxBBSGN1r6ScJ/7vgsR/7yrv// hN19+CBrhPJdMJ9B1/b4fsIIKwwfCO04sETMEDMJv0EIIhmkBnYxxFCLapyJC/vw/oJMJhsEguwb TN/rp6chlDq3UNBhf+r8UEIbEJcGHTT91T9hU5B3LcseGEP97Rbg3wQIG6BoiQUEru10EERuRIDb wyDGWwgf7Zrif+4+36viHJIDxca4QVBNvpW1/7g/77D8IJtQcIJEIPfqnkI7DfLmq7/7Xjq4YfEJ tFjzsyCAiH2MLe7RW/ChBUmGGiEe/pHYdF9xVt/1Dawn9ad3aBN9LVteqVIJshrWQKASx2//YfUe nC9Q0F6rk3d7bXrcgeGsVe2/1lyDD4Vacg+0787Tg+kEl3D9j6psgeCqJWph2//ww+EdjAeuTuyD G9BGFWkkPbTb+uHsw4W/+/foIN+nBugS1ru/XXkNKZuMWhq0wu/3vq9nZAZfnZQknK2Fo7oDGqUR EWaBllAZZQGUSAy8EIUQR3QH02D2Gl/Wggu0Gnp7h6CBOklfrW8iPOwwuFQex/3aS7X03UHmc+ww lrkGkchsHKHhpzURHRcVljljk3Pa/ww/Xa/4hArgwiIMDmHedkwz2pUwQvCMhBbSUhhyJ4IQ2ZFz ZY6ac7ECOkuGvuoS7QQb37igqZ2GHLxAq9arZFf/TVBvq8P/0FzOGgTrH/hCwWGqr703/TsNeTH4 /VwQQI4/DDSDDSdng49hdZEBQZDAFSSeWPxtJaOxMzQQGH9eT3v0v2/SxEO7tSDjoFBg/V0u+/ei FozQb/7h/4ofDDQTYXlvDCEQ00EEGGtVG3bf1BhEHwgsgTfqr+/BFuJrzEGGk4JF8MM7VgmdkA52 FghJAfShFIHXMzdDqQPBqUA1jC3/qEP2GGk2gkG2mqndYYgg76wgqe2uyB4aYMMjrfsN+737b9Lh x/QfVa/vpkDwxAbH01f/O9CK40k9MNhWGECW5DD32Q6x0Ek8XbaIXBsnsuQQY8Rmdt/cEHb7SrlZ 3fDTR2IHsMEv7T3ljheDDf/+kE3/S20HD6EQc7JkDBgktUHf0nasGw3qw172EDK5jXYQIFCdBgyL 4I7VgjhyrCkVAjVJkFw3CbWG052BiMb2l/CITH+NIK2w6CT8HCBaq7vf04Yb7H/Kuw3vhL4Yb8l4 n/dAnS3sc7StJvbYb4a78NBNjeECTsGGG9opwwmS0HO0+pUB5CCukmmw2g6fsGw/X9NBO+EFThh6 nYq/VCgQL+mn9W0mww+ij/w0m/VeG8w9v/KcMQ9JX27rSw25VcR/w4TfEFWTIK2viLCpEOWEFwKq QME3dK3TYYPTNYZ/8tw0FZXV7VbwcV4MnsIoQYNUjljbelG2G8lQL3/20seF4YP8pwQWUOcnDB+m k29b96f/NSwYNXK4qEhFTVYMHWdkwdMgkYCWYRHTIYUgfV09ik02Den//De5XAwIcVIOwd/1TRDA 5tCBAX0tK3OxFVOw+mQsf/3Td+gz0//6cWDg+v92tbfLmZQn/jlyMDrBEQcnAaDU0RsFGRMFdPYR AzRC3yDCFZrrUMNtNLYYd2t/7vsPbQQt3QQ8hAKOwzjgnljoPIO4QOOurv+Rptt7v//w6mucktt3 rkYBXdBv/BnwEINNVVf1Sew9EM4j919UrtAwk2ixwaRHbWei4HhvM+zsuwQP6wQgyMBMiYGFSFJt h6SSDcMd/x/QSnr73w3HIKBmQUh0scWVCC99rp/V3Sqm39r/aS1vhy3W95mZgacg1jlDm1CSaUpw x4X/tVd3WikDG79fUQQLQfgwaSCbwYNoQ3UiFIJLljk+exHv9JGDSbcaUwZ4MyGHKo2PvpVfhh6v tkbTTqNBb/rOyZFQh+k6267V//4S+sMNCrwRVsX+EEn66cOLX39qbaXu+19wQL7sMHk/6BgwYfUI iSLAjBhg18QZFHWawcXSVIMO6TSTTbfa52Vsj/13Ww1CDf7f0El2/lOBAjrrreQJFUS2lHbqGC4Q g+IW3e3Sd9hv9BIK770/0oyQBchhlBDNhllAZQRDLhIf5KgQeCBrCpPUEDq36S+FT1sR2ZHDBLow XVBNUQynffXt6lOGfpvC2WP2iqhl9/pXrw3rqhDkoDK9qmZ0agYL/OOmQSAmRTl9ZJ1I4TvV9EKO +r38lIa/M7fpLvyOg3UF166UivERDI9Wdlbaafb6+iRAPH2HqRwPB5Dvb8QQXhINCDDEEjsmHl+X KoK/WEltq0lT3gzpPCQb/+KQ39BX4t0diarYL9INbukPT3hM2ikIwfSfvjRBnn270szgXD4IPcyB 2/VJbfiyFe+mg2vpN77yXEVzwRBsErfggVhDSDaggdqQuO1bLhCIBySiXjV3SRKRt6d7+mP3oREI FIj/wrqlcw9bWDVOktI4lttKqf//TlX+/WHfiF9a6x3F6WqBwyIFOAhhEcDBeI5kcGNVDVrJj3/r oGwfpIlLVO3wTDPAisdyY7aZC70bIxwQQVJKiB4MtbSSFvq3//u/wl/psarqWPaDctzfBghQXur+ 7/ev3g7T6a3+nX/2mH7yaqurkDw2odnYyqvv7/Ww3w0FEEU9v2EwYIJrX2gyD77eSDBEOChaXL0O UHHKg+FebCHOzSbTSSYe7GxX3mdu/9vpK6+/p3/Gl9JHYMPaf6/FP19uNr+/hwwtvxpy33raWv32 6a02vX1UMG4pbMOuuGDImoJNJugnuatiNFuXzCC0mglBgmrDdJXfBgvmBmM4lww9Kx3FYcgjmdTD 7jkncf+6XQ8b9dWtD9DCD9t0r2u2Ihb01Qehf9LqrVvSVt2WOF4iPMMGG2u2PNAYMJWLmcKg6ITd a/IhIhliKpSI5ExtOGkkmyXeVX/psNsJd/DDXiNYSHVR9V63x60Hks0H/w3YLdLhthJZ2kvCCYuv S/thNpK64QvyXfwxCYY+DBiCWEQxW1QKN06ShJhsbrbCeEH8hAnhBNPWb2wkCO+4YWFktRdFE/VL lHapRf//SqH6DYYUJhh1FMJxEaS3VtN6oyAn9cOuZikbFYNLTBsIjxwZ2BmGgZFXCVCSIIO9Btqk m3y5mGyUhT94Qhg0vbS7dpPS1Dbaukqb7TkwE96hBMNd6eq6CZkChPX77+1URBe+4IIMg9PQSYbw ua3YIgwrpSF2XenFmYZRIDKSNgRHndAX8NVQTFdAgmDYSCaCDTRK53WGdPqQI3oI7W6S3QL+xQNY 0HFIVuE9p6ohmFyhsocqD9/XkQfwv8ItwMM+CCJsrNYvb0RzekicEDw2nci8zvzRLlTSyLIK20RR 8IGFpP/1Qb6UzA8NW369p+D7ddFuUiYS1luZ/R2kMp0k+lR1A8GiQuOm/S/Krw+2FxGQhsJOZ1W7 DCuiQKm/QR2JA8w4QcMJtLSEGRfWQsioBPZzXp1W7/4dPruu469BhNYKG+GGE66jzso/9Lh/0rG9 tpOrb4K/YisjTgmnOwIMRGHYR2DiOIDB76oGdc5n8wjCMI0I3k+XRcGmLMzuh7YLCBB+1rVKE+MI bB59d1IHgsw1b0rF0CBeGF2SI7AkRpEDyB5A8mW0Taten3TD0H6VBdypNLfwlx+ykMpGgwg4aDTK Q00GajKQykMpGTDJhlIZSMmGUhoN/gggyK8K9elCSdvahBNqyHEEEkV/w4cNB3dw7h3d3DTh8O7t +pJbjClw/XS77TXfYcL6d3dw7h3Du4cO7h3DuHcNeX4IUTydhPr/0SHIZ7MOfjwU58IEDl2cczlu Yc3vpvrvIIJC+nBwcHBw0DhwcODg4cODg2HDg4aDg4YT2g0awxQc7GBI714UhkAYvboJJvCwf5b5 nDljuZw2Ydy3Dljhyx3M7ljuYcOWO5nDljuZw7RbhzDu5hw5Y7mdw09j/ThP+u71peFg/7e3sPfD D7cN7D2+Hh9vb2HvLd97Dlu8N7DtuZ2ibjUvfql4S9OF676CDD+l4YeeLBg8MHgweGDoMPBg8GDw YOgYPDB4YPBg8MHgweDB0GDwweGHgweGDSdDe1koDBEKVjSsJInBbngriCWV53KIIMDmHOBkH0Yh sUkm9EQbB/BJh4Ye3sNQ+w1YeGHw8N7D2HhvDeGHhvDD28MPbwYdQ8G6dkHeQZtrCdBdVpHayEDd /e4P9Ye3sPb2HhvBvbwb2Ht4b29vb4e3sPbww9vDfYSba31p0n+t/qr4Yf5GCmCLiqYMwPLmGDzB mB5gy4uXIwWXNh5gzA8w2DzDMDzBmAhgwxmDNllyLjzBgweXZgXLkYLMM2VlzMDzDDBuYYYPMGXF zDMBS5udhEGCF3r5JTwSpJEmRLRgwe2kk7ktCEVXIUtLY1b8N9t+G/Yb4b1b8N6sPt99vSDfd6Yb 9h6t+32H1DfhvUNeEwg969hBlDoW1PKlV23VX3IwEX/Cw+37+3q/v237em+of3sPbft+37+/3q3r ft9t9vd9kIaxXkuQjWCarq7ek3g6afH9ev//6//36//6//96fffV/f3/9r69CwQhQ4YUED0FaSrt 2l3g//g9Wkqwl0gvXoJdJeEt0qcJdLhaS3S6CX/hd0t0t0vS6C9LVSxyeUwsV/79XdU2pKQcx1Xw 3QRFjhbdBdJO0ECvraCW0gukt0vXXCXQS9LaCCWkFtJeEulXS6SV03/dO6T0uun3SXaVMhMfgw0C z4tGY8QQSnxaEECUQgWIILEIKz48QiURCJREILEECz4uIQTiCCxBBKIQLEIE4ggWIQLEERuGK9PJ 5UNInz10gwQYJgm21Sbvx+6C0FaWEFcJtXCWlhLrCWEsJddYS0tBOlhLSwk6Cdf6eW5b2Fv+oiLd 9PvkgMfButLCWlhVCC0rS0FhLQWlwsJWgrSwgtLCWgtLStJhr2tPvgwq9L90lI0d4j/bSwQLCBYI FggTggWECwQLBAsECsEFgiVGXHggWCCwQLBBYILBAsECwQLBAqBBNrEd+nndYaP6BpJtuqCDbytf /rSiFFRCQqIWgoqkFFWv6VJRC0FFaCwlhK0ohMhB74XfttdRr0lTfJUGcH/HFVCqElHCjhRCiFFR CqKhRUQoqIVNfYIPQ+66VtvSV9SDP4agoUJgmEwUFCgoUFBQUKChQUKFBQoJhYeINjYTaRKlpGDQ ttTekYI8GXD9/9VVILhVChVChQqhVCqqp1O0ge87Bsjrwnraekn9//+EwoUJqFVNVVVUKqqoVQms aDCQ64f3336t5VP+0WcF87JhnGZwgQbEKQorQS26CTQUNN8lQZyGD/7dSnnFNBsO/CDNNsp/1jb1 S+0q3qYMjFfD1iLZBruEPtV/k2E2ntWFCYy3pktD6XaVb7wv3udiha9TPl8wwfwmQg5oCwZIfI4V 7IJFgvkn2ntf+68PpkcEMgCioI6lUJr3zvRfQcHM77qEn/vIZxFJpEGschlwRHLgochocgYciOfz YdynKdt6QpNO253cCIkiz7h//yY+9fl31pEWRXb1SaatUwn1hzQ1/+vj/f2oQN3rj+hfeHhg9jOy YO8UlFNpO9IIUE24MKFRKRQ28mOTt/mcPbCWo+yx7frfvY6tfVP/bww0nopww69aVhdI46d1ppv6 fqoMHmGGGTaoUxttYaaDTBNtIhhRVQk3pJDa//2+w2kE2GPChWDOEFQtb71W8lRm1/92+7CCuzsT 8dMJhBhLrV+t9NB3a98uRgfhuuGdlwXKtlTYQYSCDsEQQaVcK7pJvQtiK/4Yf99Juqf6C0vdUtyq rkQff/foJFuC71V+vot6Cvpb9Kx93/64hAggwwYhAlVJOFNFZY7gtINJBtMKk3y3bZTxc/q6Wlhu pHYI1A9SY//+C1Fb6//Ef9ILCSusJpf9f3qqr63//4ggWCCTBvEfrvC+o2lTaI3DSSb2//hLQVt/ /HvFELRHKlStJtUrJf4iv6C0r0WPMoOKSqrwhD9dfXQf/cIKIJEx7FYd1apigQO0krp0qDaev9Ku /3aDQ4T69K+szAjr8VCptr2E0LM4XrUZdPSlctbYJ7LHLX0+CYStvna2DiOGkR0D0kkINhhJJOwu VSKe/CGnrVQgaCD+sgwPjX/uD60v+UL6bpLr648lIMQ+5NhT0H52TBGCFYav0klEcenB9bW7wgYZ ThUtP1XX2DB90H64Vvlj/1SWQzjqS69BvrB1LHDTwiE4GEDpf9JUpLkGR2v5czBCDyFf6w3M74IG 1Mk4pfN91/r1pfVbXLd9yT4f/8EDpoQ0/X+ktroEU9pFwU/H36oOaAa4YasYhqX8hYbPiq/qkhQT ikKmo8lIEf+8N1t1jX/9r6qrVb6cV+Ht/hc7SRtbeyTlDhBpqn9arrSa+vwdgwa4aBJwiC45iNBk O8REXGwukoSLyQhKh5LixBCyKvlj8u2H7QSLsNx3lZbnZAOwmGlqlr6SwqCC/TD7DtYpcG9q+oUw dpdVSaWr06C+oYMt1f2w1wgSbZ2JbFfqm9dL6VJKGTsEMF+wbQP3Xhaafv6b19Jf7oNA4X3BFQH+ vw3aO1bQbWp2IKt2vVX0q1674IMMHfCCCawZFhIEdqAzj4fRMeI6SSCcIJJLjDISRZ/hu8Qgh3EJ Kde197/69eW5Y9P/v6W36ZhxvrlSWlWNLX7afJC/SCeECyNNKXMuuEHR3oMLFJEsDGqSS0l/ydv3 04SXCTbe00u4Q+kH0qX//T+var0F+9UrC2sJ3paWvd1T8fEECRGO4gldGeI1LeMKqv6SSSS2I//p LfUfXsjSIUR0/9f//sJU9f/lSDQIpBvVJVpJfXkheCBW2zG0WuKVYTdUXNUFS1woNL/FLtb+r7/6 rpOP++FBEex632QQfva3VV+9ceF7e+dihtUIpfWukq5KwgeF9hLuS/p4TacqhGF/+kulpx8kLqvQ euFFtOHvrVL1Wmn9RQV3D087JghLhjT16dJJKktEshB/db4ffCCcZ2Mf/XVfwnkY7/pK3fM/S5Y5 Y7TLxLgQ3+KnZWLqq/wQf+lvLcN9jdNLdCGnhfkTYoQY2dJGCyJaX9P/JPaf2Hrwcscrk/33/IJs DIN98/pB1//vv/bVK28ZlLfLHuw19AwiGb5BgghlOKjT+//WeJBir5mWCTg20MR0zRKgzbbCC0pM chjYggu44rCDCWwwtr/4fdG5vSdIa/rv+gZBjepFDyDKOsF/WGv/v9Nh4SNzYX/968x4MHCBkNgU QXqyREwzMMtLdrr38scPfsMNQgkGyE2IITZfdq+GmFqEDSOoMKVAMLvoMLWGheF/vDD/w7oL4VRH 7Q9eGDSBg6Sa9awRDPV//t9///OOVtJ8fvBhpBg0sdbXuIX+8MHj0CCwwcJBSCbAzbqV/2mdNEFA ZGOey6zjnuXyMBoNA0IUdAIil1CB/09v2kthvTZ2DRcdWkRYi8R8ji/ENDNAy5DKRBDBK0t0//QI 8B9iEFhsQggbO6wYkQdMYIRH/fw/6ypn/+wmGH4SwbSOxQjWGhMR76gmcZKwRUgINojkR8jhoOoy kNkcJLalu/6ft+gk27dc7qzNtV8ijofiIiq/+6mff+lfwkr52TMJGPo7DDRXrVfVfr/v/Tv+IIt1 UMPMOkLTBmQFNQFkOI+EHJ8T74a0qROElsIOlr6+uRR9OEuEED1/Eaa4i138fVIOuLInryUg/9b+ /QXpxV1RqFKyMWl9f19ESrqL1rx3r+z5cECII4b0IhBggY7+/DSo0JIE6QVMJLhRX+yOeF6RFQHW nnacM7X/394TrcGEuwq/96CthJW+dpAI1TH9e6VOuklGsWv6t4QJxQIjBGtNF/luWO6IZGP/7S9E Pwaq6WP/fS1Bu/3r+7//XtBOv+doX/uKomNJtev/ZwPf//63WqWEy51/4SaBoJ08fvxTut/Lnpaw k0ggtdOD/q8Lvb87SInRf////Xr66p/j/9tdq3MO9CIdrcVLHv//pbqE19Llv/7i1Bq2k9psb+3f 9frqiY6VVWupY+9/fNDX42mo/1a7//XC0lpZVfS/8kPf2/X6YX7j1T6W9apU66f/9ra8MGgi8Gwk 4g0zuEdnmIoR7aqtqFHpLWSkCNV/9j7DVcLQaw6CIO/qkul0lpdYj/tfhFQ67QTZ2lCKg6Nrrxr6 X+67r1i5IO8IMGGlkMmwSMNg0GFQeSAYolpt8JLFKgkkbely3KHIqck6/8Nbth+npW2nqKcJT5L0 v1Xf+Ztpr39/vVhPQV2veKhN9fr69d2nH18HVf6b6XL/CWScp0VbqGv06SSQS9LbNqR6S7/8z0D6 CX+29b/CFginBhV/SOrIuvr/rQi0L9/hhhA+qrknewdJV313Cv/sIHrCVevW/X2wYIg3rYggRb2v QTbgwwgR2rDRfy3jqkid/0gTT0gibpBF6qtLeW7/+G0HhfffB0vWNI7rDR+/uv9bC4aVUu1X/8MM Iiccc4/QQ/9vrDWu5fli1br6+1WqXG0sqb5Y//5cww0CEQ3giTcS1TbtzD2n3eneqq9UqrSoVtBd b6Xx/UMNW//b39E+Jp9NQnouY/futV9LS9f/yQv7dLiv/16p8ySGGH9evVetfr+q+/3wQQbgkv+P 27hBwg/2vSEXSSSetclbCxSXr+gktwoWvtfhOH913vXCS6XSwh//vdBIJ6f/+0ovT9a+rXSYSTna qs0ftNf/PjRJ5D2GP3StbGoWW5Y9woW+1paUUrGgnwhH3+klhPbOgi7X5lWD/tpJfrpLXrewXX9L FN73/aluW9fePX0vSS+Lx7/hAu2zSbBOkk8ML8maherVO/T0tF2llc5LkrE6/hBaen4rdhr7TDXG 1XetrSppeug+/x99v69X0mN7UL+tKo//T/7BUaOTH3BwzVUix3R2kDsRlTAg7IDDFCK7a6SSILjk Gshx6/9BaH9tiu9+v/16ra//9rSfljh9V6a+yx0Qrf166f+Tf/xpW7wYYYarFJtS5m3VEQTPnu3V pJVI7I1jJd6RMeQhf/V32G2kryY+FWycSMjbUJrel9LX//ZrDRVfrv2/S+THkC3aEOmFST/XVVar a//v+EpOP4R4Bhgwgicbe+VYrITYHiGsP3S0kkh3EInqFtxV/9BW7+E27VTEw/ynBi9Ex9L/9dJf 8ZBimz/236/bbDSQSd8ap9OgUm/vr0q9INeD//KH9/4MMMhA0gthkS2KTRO2djAmi36QffSwlSpX Q4ZhwVf/u/v9WQfgv1ZY+RBwqDp/r/2v6INzr9pr/+g/ev0mO+vqT8L11X7/9JK9tLEf/8HeH/YI EEW5WGwGRXCRIXQdgmEGldOI2kn+0ulRBd9G3r3X/79fFBB2xU7LEQOdZMeyKOr/3r1rW9Lf/7M4 bvWuk0HSO1sHW+pY/1/butKvS7/X/qDDfGqwgRbpYwbVdsEq3YUJ9L3XWguknpcV/fYf9YSd/478 R6X9XSC17vW/99tv10E/btfHqvsV6DSaqv6/t5hmBw4dJRC7RY8RDCjKebCQXbroEDoVyL2EsqbD //Vv9auKztKEDBUsdf6VqlSbfhWUOFX69ttoVhb8MX3p3rUL0Gr6woj/H3DDaQTCVqjtICBNmHCd pJbfRD+wko7pZKg5GBov/rekP2mosKmEwn69vrtdBdf3QUQvf5P4SFhD73C6X/gvv4hBBwkdU/1V giF2sbaOhkVPSCaSVWl2GaSm/4SYaSens9v0/003SvSa64Mf+lDSv8Qf731v9LHS2GRD/4IEGKQP WnuiZSrZs710THQVLdcgggQZHfX0EGr0/sKnLcsfvbf9WuQ0r1rF/4pqHy39MZUwY9//rSwToUrX C38qnsEW4GDy3DWozsCCNJ/7eG4ULWKCoJ6wgUzlvr34YWGH+Fa/3+2Ewr+u10C3e+vCLcX9vV9q RYXr/iOlr9df/TxXBh0CTaDGagK4ynDP27fUKkrJSa4ZCF//fvN4YNwkXuTHmsH3bI4092ndektU sMHf/+8JvhLYaUseraXX2N9a7oPw8R/++wweECQbB17oho3ooUjHJxIkBjbb1QSpNppHc1g/9/9+ F7++IwQ673FUl5Pk4GEhw9fXJNf/fp+Uj//NJ6XqwgwvvX30D+gQKmDaQTxTklRs+vsIN6RNwUJW 8JpZKAwXY/+/YQS22kFfYu9/237Spd/+VF++H4pYbFJiv6ZOyblX2/0mF161v5kBKvIYCsPwgWDD WWOirSX4uLe2hDJAZRIAxIZpyGXxBrDIGEOLS2XEpwIH8g3Kcsd+lYeg7RLg//Xuqd3hO/xG79kO 8MPwkW62Fexgvv/ff9Eh/0uSvPP/wfhg04hFuphqcw6OyYPRUwc7JlIjr+5F4MRkeEy5BepBk9iH I4oLCFy5mkU/Jj/w2W4wMQSdr3CwrH6/9evX/X/Bq32y3QGb3HeDOtwte7bVkNNqkl+9f/fGGrmG GDCIaZAIO1TqYZkMBAwv22EHFiPsMMNNBcqbBkWRbrt+mGH0GnzsUJYZWEgQYWvjtJeIZWv3T/t/ v017qoRHsQEzrH3bpLbHS7T/tuu7k2GiYW6phA7IR2foYXhmnYdJhbBV6f9tX1LegZh1QYX9asgg wg4+NXQdvu4aX7/39KW+gbExT1pVb73tXa4VjWStFxJbmf/DDewwgQIty5Q7zsmGOW+THYPtMLD2 2dgoL0IbXBDr/0w+hCVJp/f1hYQhrvekrS3//hy6+FwybZ/xHyx4Uf6tV/hd/9j8EC4dot+dipsi jr9EIEIPsvb20km0FjcdeioB4faXLd9Rb//Xt//5BDuvqQ3FrEL2H/vVx6fu6VNrkVgnH91XheGG oV8MEL0wbRFwytsWHSTaSqEDDMOF+u+vDD0s7GxRfDBkmWt6r/q7XfI7/r21Cudqwx0HD+99N1rJ 3EfsQ0mtgvLkYHDNQhc2DoQytjW923SVtJ6SDfXSOgZjj+3oLbaF/90q19r+qkZmgVfw2ZFq6u8K YSyZXdvVv9f90KC/1F+qBhGSoGAgyQD/DtJLS7I7r+kEv8JbfSfrq7ek3X2v4wv7UK4bSQT9r29f rYj/JjoEsk34ggqBhigrIgIZBMuyYLd3QVBsLuQP/6X+EsHVEY7sRD/bet1936/h+gnbSgg6ZlWD 393Va4cg8jpB/V0FwfhAleYfuFKmGdf27ChJus7mBFfTrv0t/Xk+rgurvRHe2l3+LS5Y74rv/27y nDHu/e/9/QXhg9hOx2610dg3W9sNK0rS5czSKV+noMN4Ja4a/J4S2k1St9da9f+F7//FfTXT+2ur f9fk8BUuCPYOxw1TTBgluooHht10jbbQXIaJCn0woXpw6+3j1OwYhDAi+20q02/v+LBPaYb/wwvz uoMJwf9VXr/2ichWsPkw9c7FDDChgvhg3bYdCltpGZZKRl2yDuF8QX9bvvVpioWwe3qu+n3ZMGPw v0venhRdoiCNmDB++l33rv8L2GggVoHot+dpApGBhhHavI/CbDB7bYQPds7UmEPljsjt/peIS2/9 BYaO64EL3hrd2kwtf3bX6BeguZ3dRoLVUH97feLaa//8ECfBAoSgwerwpIdBA0LwsvG7htEFx2kd IjsjkXRtHTN5DRBo3keJMGI/vNYY+FXX2HrtkUlkEHsVvvrFhCIiGiGWghloft/X0+IXt6vDvgn/ 7br//iP/Ig94LzDMDc1CF5sGQgFRLHLHQeorbtKR4CI1srj6o7spH04+ioX/WvTbdK4bff+GoXbd biIiG2tfH7H1+w9AlYYf/9nHChbvtJXrfkQzffB9gvw/VudjTNQYgiP/DCxR5AiCAVsnThWEk2Mu yqLyWsjoINB1/GvS7rO1Yv1sRghBpLhB3Q+kP4jH+/8JbDaQQVq/wgTt9pV7CrJaV/DD7xCCwYYh AgmLFPhAtu26VtIXwQOZyx/7cqSfQWG18HqFvupeSbVrT3f7f+Enb02jtaULv9Onx///lJCHcIJo HWW5Y8GEdrARgtumGkq2loubu3/Jv0xwgQ8w/3OzEpNLv0vbJUVf8f9rhx+/59Wn7sJv0ntf4/48 OCLckONfU7rAi/bF6dBMMJpf//M8wrot1MHd+NO9btdckwb+3Vf9C5nDhIG1t+i3LH75o20n8nZ8 Muu1r5C1kaD64MMt6g7BAiBgaXEIgbl+T2FXf207SGm0wqXakD/hBgiDAwPXYaDGG/kQDDTR2Mv/ dN9W9NcPV/7TXthpoiY9WYdX6Zj9ff+tf+iYF/Fgg3YLBGgMIjwGVcERpw9wxCUbCDg24olAGOHd nRHowZtKXRHZhBI8i6MIuGDoi4UjimoCCPEMFB1AiNLYolwI+0iJR9abalBw0m09B5BQY+9d4tCI hoREaERYQiwQhoH9YTv7MPQTfC1DaTdpN+E0S4tSfxX3aqv6el3/EGTLggbCj7YSbhoIG0Yd8NhO st4cMw4XvIuSM5BfVIjQXstLE3I4S6c1DSKfXf9JIOg+1dURjxqu8YJ9vcaqENO+uiWP/6WH3VBX LdpPXwQcpwzyfgvxZtSh37VrV97109V8EVCCCDHiCBBElbcMNQ3x7hWEwo8Ra22m0l/YQeusR+g/ 6SX2+1/yFkLH7bWv22MwdL/+5i/QSCbww9wk/uCf+LfVdi1/X3FPM34IEkU68EeAaRebBBPplI0G vtvCCVYbYS7DC/08IhJ9f1TDfbqYm2QzhPV9n22uN4aS7/reiC94hYQbb235qeEk2GuiKO4Vb36X Y1//vBA+CCgmbCahh9gnaBWwb8v52DyLft22EvdLDwiN3749rONO//Qel9BfCDT8xP3VbfxQL/4X SSDud/pfuw+jtVDG2gZCMIGPd76269gv+WPrgpY6Q1vaCC9OwwbCCCrSCDBDIoBjh3tpJdpaDIwH +/yQ6THGQccVWIS+TvtjBd/p+3V6W3WqBf/zwJSq4XQXrbhsKwmGColFf3rS//gv6TeMmPSk3QZE HeCBVwvB1GKhA8uYKvcW0q2wkdx6Lgsdwv/vXtukqr0vt52liv2/r2+u3p9/IWRb9+6/t9YQV/7z D04X7UnxLPR9bdUul9JcP9obBpZSQenQ2IV3Tfe6DKyupDOJWnxFh2FCVt0n70QYX7tZiOa6f3wo /49SqCw1v93v//uN//DdQvd2COPqva39EH3XX+/dL20vfC/jDERC4O8YuFJQ7C7Wdqw2Im7V6Jgi 6/23pK21rYoEC/td/JOmEd1iwv+vqWPd6ce/tukl6fZh8F92uWO/WEIIhhcj9b7XWz3en/29afWv hV+RFYLwwd2gkzsDBRx6+N3iDoX6XvDSWw3Q4jD+4MF7DfpzXBBt3/nZidDbT3/d11tI7KVkrjDD B/yJPoPvBF1V9/p4TMdkcXTCq/29JbeuqDDD/X2CNANt8WoMEQqAbh/XuG+VlAkieSnB3WtttKvC jqoP//VhsOL7QIpxd2u9C3oqgPQf/270t6VbD/p/tv5b7QTeDilM/+EvdL3+q910r/D2qqG2HgxC mcGgQNtjaXy3LHiLXhmHMWXpXbS3DaT1LeawwR38ff2/w2kGHdcdbbfg1TW9vSQMF///71aSbYZH SW2k36v+dk30EDaEP31va///9xBAmLCCUGDSBsEVDwS762GFCDEdttUEce2lxSTTX3dQkHS4dX6Q Sd9f13tVvut8R/7pRTm4N03t6RvbiPer3br9/1+34QINYTBg1bFhpAgSDZCbETusHDsKaDDvtiq9 tLDCDCIgNH/0g17q2663Soaoe3S/rtDf/wgg1+velu1V79ul7rrX9YhFuoHuEF2GGkGG1BHYoinD QIQdot+701sOFqXGGUgqRT7vQP0lWwasOkk1Wn96X/1xH/14pK7pBsUEnyY99Lt8dtL1IG/+wXgg SuVlsGEgbCnZMCGTgiy0TM7hxW20gvXSTNYbP3jqEquGGGEm9aBr+MlP9L9dSY//+9V2xuul/ssd Q9vrbX/r+vggSTsMGE/L8F/pBqCQPdoEUP26XrH/3FdthhXMP2vuMRYPuhp20n6S+78L2G1G77ff ff3+x/08pPhdg2L4YhMZWiD0yDjUk2G6SVwluv301reG1haCvQMPvy6Xv6a/8Phe39tBdhAw9X0G lt1sIf3w8aKh5KIoDQ1phhEkBNhwe3aSe7aWP/t/2jgZvy3sJAlTg/brr/+/eRLryKg2GXd/LHaD glsgfJj+rrS9TssX/5cAykC6DtXJCLgzhBr+4IGwaqnQN7h10sNpBPOw0bZj/+wwmt5HjYqeZgeP v9VYNJSnBf+tdburzuYaP/toN4dKiGnSiCkOVZMfS/1tpSY7h642k/tpf//CKsGi3K53Bx28g0pB 6Lftxy/Yd64cQtuhS/MzX/v6DbUQw+WO68MzkQoT98Uur9cFt9bqm/J4TkU//YYav7DoHURCXUf4 JdKQkYEhekvap1lUoT//TDat6QMHRCGaPBEMSpCuGE+iJsGNRZ3ggWxBpOGGaUdZFAz7//qlfcP4 4IFhJ2U4X0+S4XBBd/qmOv//dafww39LC4ja2+gmkFshx3+n76/v2gQSCh+YMMNt1CIWQyCBGzLi nYQHYoMh9iAQhMUC2rQR2Ldt2FyUGecGF/+KWQ3+rD/CC64d4bzFcLeMzDLJAGCQGWUBlFAZZIDK KAzxfTxX/wglTI55u9/0FoK21aDrDkocL6BFPX9ev3/+CCXcpZae9Naojkk3VHYGZCZxFLYUJwQd giIupEHgiCOWOawmQrmcycjHK4pzDRXImDJdFCKRHykd/wwv/wv0H/hL+lYdIJxTo3/42XW3BBqR yKIiL0/7Bf/CVffq0l3TChhukm0GQUMLX+O/9W9bDUNffiCgj87sMyBoj1JNiCBQZpeMIGGKCo1h nu6Rbv/dhJU22KJuRB+xkYF/9a+DY31hLCBhaw2v1X9hfDYpe9CG+k/30nfYbvXQWhrvjbT/xXt+ tq+1f12CtPphsPXBBP1brL8uWopKvbSDTukGVAeDMoLd/Oya8avsMOIqK6+5h9OVIHdQ1/j3j4TL 5fqZ/036/beE7S17tURpL7rultpPghEP//9w+yYZePRhG0wYeEyILSvjwx7ILgsMJgjs4ZW3W3UP v3//3yIOQK+Detb/T2ikB/1/v+1/v/xHTX3tZ2LpWaI39/pe1x/tPKS5MceHEG0nqsIPEHr20ttW 9mSD/vp+8mOU97Sv87MAvJ8Cb33rbSvTNo+q+/w/eigFBsj0fDZt7feFquXbKW+K3300GLX7+G+6 nY4domDDDSbddSnMVEP78Qr07DKg8gX3+/fp8NhK+/BBlVB3/9v3Ef38scO98IIPDYaXry/BX/tb 3yx8H+/ww33oIEGoMMhNU9zP3aTSBLypOtq+m2C+/4Yb7WghljthkcNj0vxStHejI4OE/utr77// t3YqltsU30xtSeMM7lbTjBL///r7/gjQHb8muiGDBgm7XTScgqDB4IKtVxYe3//9Yb6wqYYYXhe/ CYQfBf1/Efzav9MN3VDhw1eYknRGP/TZCRhX9Xf/G8uPsNhj82zBC6hTUKYbDggbf0zupg8hdmvd LbOxq8pH/f6qFVqw2I0rYe9hKpfe4f0dvL2nwiDBPmE2q7rhdW+Ft+xqt+G/DSft3s4F+OxuGgQI MiYvdpLvV93vb8VSf8ql/fUVY61pvrShf2Egl//5K0RwSSwL+uEE+4QVQdQmRjw16saX9dVhC0CH 7civwQIMFZ8YcGGIIFFQTEU1IoJ3CWwmtP/19BrSw3tEYGNql//9//4SBhaTurXhq/pTFy3Y8m5x yh1/v4hDggWD44OEQX0IIU8YUPFvhCMycgkiv3+C0E1ose0VhG2EGDb/fe7w/37x1dZlBiKg2Ut6 W75LSH+9c5twIO37uQb9e/BA6/+LCpj7o6HX/3pkxfdroa8U19Kt9R/fZG4XztbBzKsi7u/oMLb5 MeRjMH/SrrVO4v0h2/kx2mn+PX6/9f6fpP/pkhkwyYiYZMMmIgUQKJiJiIyKeIFECiYZAomIgUTE QKIFkChzsQGx1eZy3kXQ6Xfrpf3+7u9B2ncO7u7W+7QcPomGVOlvf9A/3/qpY//p3aDuHcO4dp3a dw7h3DuyD/7Ll3f8PrvuPr+GuWO4ODhwcHDQcOHDhoGgcHBw4NBwcOHDCDwyhyO+qf9urIQVpYb2 PX/XXdw5h3cNuDuHDh3D2HcO7h2niwn1v+Iq9f6df/7zO5nDljvYczhy3cw4cz5hw5Y7ljuWO5Y7 lj4aaLcO5hw5h3czv+zWD1t37D+/ZY6iP44SvBg8MHgw8GDww8MGoYdgweDDoMHhg8GDcMG4MHNY OXANww2aAeDB4YOXAPDBhFwPdKkTHoRVAyCAVLbxGRR1/V9h4fYe3YYe3hh7ew8N7D29hrD29vbw 3t4b2Hhhq+v+9Bh9f1X9YeG9h4b29vYbhvDD29h4b2Hhtwbww8N4YPbw3sPDfaT6VdazLQP3b3a/ kuIYmRYm4MHgj2DwR4B4MHgw8GHhg6DB4I0A8GDooLCPAeEVYagisB4RUA8GDww8GDwweDDcGDwY dOxixpMijlbTkxwelt4j/pW1TYem3pt5gw3RhsPMMNqYm8w2/bzDYzDjTb02HhB3hMN5ivMQbzE3 mGG8xMNW7LzFGJ6rO1RF0c69fztAv8IKwxq323pgw+4d4b023TDemGHphvt7dNtU29Qw+29MMPTt bDD02+w3mG3Fh4btdHYHhCLwbzsXdfp/4JQ+H7Df/g9Jtvhh9hv37b1DaYfBhvYN9v2G9Q32DDdM Nrhh9ht1DczsNLYaapO9rhpbeEH/huv9V/4XdL69f///1///+v/V//X998WjsmDFa53O/v/7erhL wlul6X/hJaSvX0vWvS8JbS+EvX0l0l0vCX/r0dkxSOYp+F70t8qlLd/wYMQRFeGgguECC2ggsMII LaBAthBBbQILDCCBbCBBbQRIeHBEh7CCC2ECCcNBAthBLaBBbCCC2EEE4cEFwglhhAgW0E4SxZ3U GdIqDkHV0Hrt5LO0pn/20FiEsUsQgsUFiElEILGsQgsaxBLEILEILGlEJYoFtJK0EFikooLFBYhL EIk8V096/S/CEH7/wbhaCwlpYS0FrglpYQWgtLSwlpWliEFilhJ0sJaWrD65cwWl9fer/+w2gsIF hAsECwgVggsIFhEk6BAsEFhAsECwgSggsECoEFggsEFhAsEFhBYIFggTYU7FDIwKGccI7C8juiVA njW52JrX1/9NhLQWEsJaCwlpWloLC6WEtAtLQXC0sJaWEF1pNrdiyWwhFCCNBbSW2g+Qo4Ijq4/7 roLC6WlpaC1wlroLCThBaWlpa4QTpYQXWEtBNyx7qmmkgul7XkuQ3Rtf/iFEFEFEFEJiFEFEKIKI TEFEJiExBRCiCYgogogogogogmK9E8YTCDQcjKIrv7BPFD+oqoVVCphQqhUlChQoVQqpqg11uvJR rr7yWDEMw6/tQqqFUKqhVTVdVVVVVWdgQStEbtYTwujl3Wg3r+7CgmFBMKFBMFBMKFBQTBMEwTBQ UKCgoINYLtoE3LgzunHSTbDfhBiP+ibDoRhNHRVC2EGmml/99fypP77/JcX9uWcFu9Kn/8ggfXV2 uTiE/0K83uKEe+DI4oIHpVWKoIHQf8mwr3q7lTBDFbFSGcV9b/8k7r8P/09vtP+23+E9+0Gn+GFd x8jm9Jgtv9IP/JOtd1DRdMKmWOpY6QQb1HbW1/5BP4csf2kKbJbJ4QjT6/tq/9PkZsOW4aCvjKcC Bw2kH4X8VYX/3sPY6TJaDkGlT29Xbd4g/5/MIj5jMXe37Wut/1+wof8IhlCiRbg8GGCuDOOCMb4q v623j//29gwk4hsmBXpP9dv//7eYg4SMd8zwzx5Mf+dhHX4//wYOkwwYQJBhkTatVlYdV/p/a/38 xBvV0u0h//XsJHTILF8zRG8mMvHftEUgocjTlwRbKgscuzDk3DLxHzcR8jouyPFwbmAPDR//WHf1 eEg/flOZh9SBtBaXNPzqRw/QYMPcJMOFCRHsTsUEkIbDC1//6D1SCYekkdqwx9NqyGSCoOQyQzRy TlOXxEchBzjkXihzDk+Ls/GMGc457KqPZHYL7/frhoKG2kFdfw1OwvK6oxERZlxzr09f8NBBWIQI GGISZC7EIMERUnhDtmRIC//9xCCwgg+GGRroXevTJO//X9Phhpi7+2v//wQLBAibOtFjzsTGawYI Uy54jt50Aj//hYpbrdPs7JTr5cwX//0FSt+DVoWhX9X/f4gmChsedkwcvUibsFJaGx22nREHJDr+ GF6VdcXLmC1slAZXbaBs1I18e2FRW1//X+6EH/8eEW4qII7XIPCei65MedpHN7XbUGSkC/8KyET3 iMRD0lO6xdXf8IH/8Jp/nY3L+hBu9e6f84GViER2Gn3naQLsVSD1Kke2ZLVf/pQ3DddN+vX2+Tt3 //v+ykJrDw1/0F//Sbg9Gfy7tGSSLuIXtrh6/5ScINyx3a3pB8yL27X5kCh///a3t9R7eEPf7BX/ 46DCBN4MHq/RBykLMJCGWOH7dWF/9hFD3w3q/lOD6YMfu1DS/8MJfw8LthUvX7k3Cj/kgPsMczmH mGYHlOIXbDkNCEGEifyMBPcyBDYV/Cei3DBFDwn6sPQVhg9hDVoLuwgw/9B+31d+H0u8MzhfCJaB fdBj/CD8GDLf9hIN/7r5Dwoh9Qgm7af9fYYpr+lvwjtJig/h/a/78OW70P9wgqg6pA07WG1TyEH9 dEJ3y5gwY2iTt8QgrBhiCBAg02MGGy7LHCvmi/fhBv9u/6CWG9OTHtNiI9/f9J/+Ke9BOHBFD7/X f6/03+l29hBYd5Y7qWPDJqCFNyu3Djr9Pe67fhBcOWPSlj18kmMLb8l6+//QQL+Pqv940zjO9QeF 7GCZer+cf4ML7gtj/e8KEDWQpuV9hXD/6f6W7tf+vX7DttmHUd//9Jv4Wih+8U+krhvxGRB/Vb18 ECLfXkWGuOLXG7CQSJxOwbJMnbRb267vpcV+//Qylj7g+2//W/6vpfrZY6GqvH9/vxhLYLEPqaXe I/X//9/hFvV7Xp6+v/Dj//0oRQ8fh9/WPxX/ay3KsRx4dosft4X/+9b3UPr8Kv11+sty1fLH6/Ff mQlHMjjkpKW+I4thLBg+mMyg3hHakPwhFlRf/9h/q1R2k0Hfr/yT/w3grnZmEaFVro1gn3OpkcJw 21wR4BuCWdkyMREA7Z2oDCDb5czJ3dVJwb8PrCbeEEYbDvQQQacnb/774X2/ww9BWw7uCQacJ//6 4Xg7CWrqglYa3pqr/81DSKd/5h3aX7/XwfJcv/+uv+w390tt+WOyObaJj4U1f+GFe/6WoYNtLaBB bIjhBAt3JcJTbTthfYwwf3kUk4bbCWISw2MI7qX/omPZAgMV7QL/r2HfwsNqL+Ev0/2vvpeYZgbD BBYIFg6xFAgrila8GZRr9em2GKwu/oE+7+EDmoCv/vt1oL0WPqoqmSh+n9f/3DCiC2HXQZDqs7Ap Ai6T8IOGN/v6SYKuPkkjZhwsIRB+sMvf/2kgwTW+dgeGxr/kr9/2QQL4ggRxDBPWCIVJBMLD+EHi H/kMsT4SEd9MNBM7GA+/3/39Lrsp8vLakCEH6Rblj//4QItzL75eUQ0FrpmH/7vX/P2Eof6TfLew oXwwr//D6cQl09+Qw/sGUOha2P/+SAz/Cg4a6uGZbSJj4sXeI/4/CupY/dYW+mQRCwq//UPq+1CI OpP0xa//jLgHpP3VvFJlmi1C6+nt/Hf9KWaN9sodfzwGO9vV+E98m5nlmpAYEf6f4MHlOK4MURpt NV5TjLsKaxf/+XNvQRetPDwv7vT//fsPCUNhhPEf48J99/JD0wbwgSbB3w45hyY7moZO//8P/pry XCvq7vy8f9kFx+/tf9Ivmagx7+PT9c6kD6we4IFhkWFCw9B4LfJuMMqMm3gQr//3mHeK4bDQQX7w v0zDhq///9h4QW2KXtCNqqDhpr/fCr+DB4IFg2rYSIMoikLZEbmhFcmnDC/1/30t+86YXk3bBy57 r+v+weluix90mgyqBnqpGPv+v4X3zEDDiF3W9KmmNBhOaw5kamVGDIgTX8Jr+mGy3L0K2/eqTztY /4doNBuP9D/u1rj4+T66f/cNMEQIkLa9f4e2CLcyPawg6rK0ZhnZYBEMIcuMNkJKrD/ohH/0F4V7 /f18V8Ng5Pv/2v3Soeq7/87QGi+OTHYMOnq77BP+IQKw3+i3cX+tBkcAkC22QeXqykOv0wvwk5Sd 9/LHx+8vwTQoFEOWPvf/CDW+gu//d3+RjkbqsQoLT/9eENrggWgbWn67+INCOEQksD9sJffH9Lu7 XeKf8jAYhVHGF/1xXb/3lXNesJlD0FRGBjrngyvglljg+0W44oRr2CFmAgQahd9d68MNuqfIyc7I B8cECarr/0+3/ssdJkyjb1kxwiOibggZxSBgpxwu+/ingwcGa4FcNDQQhp8IzhTQIyEA4j1119t1 CThTb12FB7UJf/75hhh+kXrTV2tqwkTcHkcUwuvvslZLPXqGG0hBQwwegxEQ92TesNBBjF7/X7+m 7Drh1nYRLHaRkNAQZJ3/3//7r0rOyIwEh3hIK9fVfyHe0laD4Wi3pphOZy3k3CM4wgm7/v/d/hLk 3dJf1a/+lWQL//9X4pXhhigWuqybmf/8IyChVu//9wfggTYSBhhYiql86733wSMsDOECMjhgjAYr 6/1fhBOk+yKP6fXiO+lSy6X//3D+vDzD//3r9EEcva3QWP/d/5oDfBAnq0thQu+169DOzOI5mDBI yVv///hvYrSb9ykAhjSsji1a4wunRcwV/1/2H1pR9BY36in9L3r+1/hHgHwTavhSOL2xCFobwgsa ML/Q7+mG+m6r/aZh0VA8p16ZwzKYOU4Z/4iv23sKN+rDh9pBtBPqPv/fqGHi1WlnZhIMvBBgwlLh f///vTnZUq/RY87UGneTdPkcML39Vf/8JZJwvf7lOCFTBIuTtoXVseGULkpFOvXsIILTdP1wqawg +kHoRD1f/FLh17Gl8ty3/80XNf//wl21MP6VpL7/r6CZc/r/hAuDpL6ogTl7Sf1lpPiqIeQXv/4Q XLHYrHVf/DXbXVzIpB+//7hh04cfbvuvC52thnhf1/iC8MGuO3EU9bFVdBlj4Xf+tQ2FcLIPuu9f 1111zRlH8LdhhLO1sH1dqmv9zI8Yhr4WSFfBFuBFqXMNggjDDBpJsIEQ0G6GRNDMYrhQgZLi/1/r +ww0rYe1BeiUo2v4T7/+Lfq6C7hNHYS9EPszseunf+/f2uvBnSzbAiEMEcLBB7XCRMff/v9fSYfR 2Jam5EH2MYcYafX1yx3/o9v7+4SYdIJPQdp8P2h/SZh/XSCDf7dz4wYYhAjsmBATT0Se8hxhNHH/ 379W35In+g33XpA3hh0+RILFL/17er7u8JOqemyvULwb7wm6/99sIdcN/CBB5h7wpbxb81g7IIRr CD6eK/x/D6wla52LMjvVX/u1u2nh/+r7b4rr//uqmiwZgSGiU4YQxVfr5oB/BBjzsCEaikiqhWQz hkU3AuxUHCBwSI4Oyxwr+8P7vheFF9KxiqYP4sNMKvyHdX4YcdVp0kq0Ggw61EeuGhvwYNxft3Ta BAikgyCBhq1fwwV+b2+tE8YYIHsQgiDSB22FDIRdC+P6YYf9OKaJj0EE05b4wav95haYbc/Gp37l OC+yx8jV0Huwgn/jCfu6d/6dfSrhWEn/PxOffrd2n+t/Crigwk++gwnJjj2kvg0WP2wlvFGTom4w SpfUCIlBEd///tAgurq+OT8FedqQaAX8EC6f/01410ix3sfW9cO/S6yGGf/um+CBNbgwaTsIMOF0 dhCwn6oEQh7CFf/76T1hhrhpBhQ00E5oIhvUQo7YjhQeP/YTW+gv3XDBeIwyBHJT7Ch5kciOZe/2 I14QVrmGYIm1YpfbO1YOnYTeE20ZONkEiCHZQzO/XxWvsMIJBsO9/pw0EGS4n/f/qn9NtK2Hyx3o n/8NBMMb//HagrXw6Bd1vdWQYTdnlwYOIuv/hf63WdmC9/NYY9PDmQj0v9NRXSv0G//rXkvuZTB4 ML/bFrEIEGRZkexWxHdQrXQINg+xX+vCCDDS6bCwof9vtf39IP0sY2Ev93/72CBA6jRM20QYgbr3 NbMgKH/+tose1tBP//KcCP7mk+gvwytztJvX/w/4eDhRCbrMsNhnahyUMyF8GhSdL/52/hq6hR52 thnIJkcHO9BVhYiEzdfr/JmExt6fTQtCDoOTesCEwnYXMk4OyZwXytgxzDgxYX0mg900Idpfj9N8 Ni1naQzDN7tP97ddKYvw12/Qhpi4fXROL08Ff8IhL+GDLdbX+SAzmQSL0MLJ2a1TLthoQRDy0Mkc P8EDfhhoP+k/iq726EJqYOP6CD+3301j9frmVo5WtzOWO/02+YMGDg1cRaEMK/bQztbDQEHhff9f 3d+dpAQjUR9r6juSet7/+18PDRY/TER/6pk31//3+kpoDSjzvUztKDPXsiOFLwu8J3pFviP//SW3 T/f9ME/3/9f/2ggth+0/fgwh/////eIQWDBgoc7FmZKRmNr3BFSR+GEgrEVX9awlm4NhSP3poMk1 jSIZ9pX2NZFH1//SwrDCSDh64LQ/pv7kD/3XhAuw2ER4zAikDSZHYIGTcJX7wmCDCFP9r4QXul52 XB05Me2Ewpx0ukDCMlUGP6XFev6RViV9qgwyrJD/xX7IUdcEm0EEw6QKiMDO7fLd6Y0G3ac1ojgh lN/2N+mEkGGwglXddTPST/HIYZ/+1bTirDGEdja+/+v8V5pgvsJIcECJsoNTsxG5E5mlqI+3qXD8 7M92tr4YXhBB1TCbXXrW60p5kIZti0XMerXpapJ9dx9a4UIOqYfcdCCblvq5DPJAKK1UE1VfCD67 V11qL36H39/OyFwmP5Y/rVJEb6//lbBRkm4J/ScM0TIgEDCjSppBIuGvNBh33S4bVfqIMnLVzm5N LVfr+/18f9fU3PVBr9f/4Xg/iKdoIQ2EwiXx1wQ/X8hNFzDsmxqtZFH5krcmO2EIT6pEY/ivyRL2 Gg9+lb8Qgy711qH/heDBw7UGCBynDHC0INigsEGjI4aIr/7dq4oOvlv+qhbX/w3fnYED//60OzDh HYRfrzDDBzDg0Z3gmayMi4PaGidk4bTCIQzIIzkIj/+w3htWO34/wwmiMB//+sPb/v68RX/3+HwY MEnlzMnBsmTIo4WqoH//9Lhq9aiGmm4pf/ftJYI8NL+wwhjk4JD1+sPxBArCDBhggRs2RNhAYIEi Y5Y8Wkg4cKveQMCnWttBWw0HexciOvwv9vwgvf37pEx7CYX6alR/DfhAulv4vaxFsKFCIo4o1Bj9 ekVRbpQ6QUscsf6loClEdYL8H8JDuEEdjaDDYQSrdtCi0Fmg5BB9NL8eILBhCDYoF/tGQOMOMMKF BBhf+tIP/vmVd5BvqqGXMER187D+rCQddj6Qh4QNzIKxF6GuEHsFhEjYacz4xYJjCDLMSwhJpAr9 YxTa+LIEBstBPL6DIgJ/666MiQMST0LUL/4Jj4KaMEaTrD6d7T80lv/yb5O/arqsblwvDCpFvSb/ 5Jw+dkwzsQx1Hvp/klDOvf2GDtdr/8fDJta/B4+P//BkKCIO1Z4I3BGsJLewizo2NtL/2EHDVxEU 6f+P/zDu79eYYtljqvnaD8GDBEXgcGix2p2TDQiUME2GS8LwTX/w3Qbv/oNphM6imMRDX/4YRPVy 3DSY+njQssxaMwTC/+EeA1DdBhpOdia9B5ZioGgf/phhwvDa4/Jx//9urew1c7SM9G06VST/9/ph hpsOy7DDJtqMw2DQsJx7TkIyzFkzh+mvr/VhhK242tfoP9/cJK/YeFcOQwP+1/+Pwggqb/9xFqI/ /klAx4oLutb6DCoiBfIHfvwlXtJHYZw6SOwhFzJPaOgY9ff4QS3iECO6A3K6qKECQspwcMlipjKc CP/hBZTkRz0gmHrwwRHQwv/+kv6SDDrqIgymbgX+X5PHxBAlt2CBBEQgG6nYqaIrUsKaYL1tfX+E EgQe94Kt//8KFvFIIMNtFj+gQf+/9gl7hBBEwTFfoOQzyFf/xSrpJv1tO/9198JQ352TDD//X19h Agrd6kHkMKZooW5b///nz7Hbr7TMH+GVhHIp//pPdBP9a2RDNquxD/tCtpBvlTGZGWEEw/Oxps/p Uwg0Dvp/x5J3fw0wSbvTEP8f/9+3927hP52DaDTpbuP/Id1w+H4YODQTa6EMpwI5Y+WOW9jKcMfd hcOpJ37Dh0U/lUcw70716d2v7Qa7trfDeqdqt8mP//6r4jzQDasMH4MhZBRcA6t2DSY6l/2KW/LN NUwv/fv4YfDXd6frl+XKpd3lmJUI/8MP78PhuvYYX96+ojQZe9EyC+GHbgxqdQIYeDBrthhhJvsL B5H3YWnDIgJ7QPwR4D/0QaC7ow2/7CRdw4tYizKvGlwn6X02/fkNXT7aX2ErbY9A6sju/YQP7DBv DD7Hww2vYMGgVhhvggYZTNst7d/X8P75UApdP28P99R/luYf9EX//vej4vX8N/g8vgWRAyOJ/X/Q IIq3+EE3YawmQgN7aBBQ80C7BhkWAggQpNInzCF367/xb+l91yYDGNcWpVQztil9exFf/p/DQQV4 9ESC4SwuQsORwgbhf/vr+r8QgTdUKBUCBWbBsycFKgdW18g0txX97wl+loJKsENtYr891f+v0E7C pLXkNPSv52lq8pwz11//CTDFUFEFBF8MgwB2SHIaY53BNot7QtpKWYaQeF/+IWkgq3Iw8GEUBzAy PikxqGv8WF+/q9BQsXxERCCrOxeZclHyzCUMD/Xgm1pgswtIECdzswC4QOG4gn+66br3C+EvCaDQ u/31TrQ7V6BV+tHdS/pWRpwy6SFh6QRCSVfpvLmZensML7FpFdL/0l5KFL5//gzAT/v8IK+EDBeZ Kzaf4YrTJDDIfkTyDDdrJSW/WruI/ruGxUO96S9sjg9eWatA/w19hq4dnQP0noW3/8ME4RMfBtQc MNnwIVhTOP1Mk4pEj/nb/V8K5bhthUhS+KQMiAX/klx/mcOaMzt29dXYTWmGXH6BrTDsGHhhYMGo MMMQSSTnYs9VFv8PCvhhkdYbVvYbIUVhd2EibvLMWW/4eFh8e27eCPDYQSCV4Z5KFy5hJmz/wdEu IXbIjwRoDzDBg1MQYPCYMG2ggQRgwyJsagmYtFvqEEgmdBQv2HoKw3pt6cPhhh67YVK2zsvEcImv rrpxXwYdoK2PDa7vv291C9Di+OQ0MxVCv+GQwUKqD7vhvw3tKDBggrrhXfpIm/+wb3pa+vheglBh Jh6VSx/XW5Ln+029aVdBLVboIMGR0ggw2Eggaplj3d/3+y4eDIvksiECxBAnEECwYR3gNQNigQYV 7vRA31t/w27aWEtLCWk0HUIH6vv1/9qQgzC0FrpOggwnVfxDD9cL/BUGDpYILCBYQJQQR2nBhhyx 4QcRqtqFJAP+ITdpaThJQkxCBlQU5Td6XdApGDVjqv1fxWgmKoRFj5Mfgkh0v9EOqSQDIYaIZsEM 64kE11LHwggSTwh+EE4QiLhfW7PJICphV8JcOv/fZGOnJNm18EQ6Vxa71CIYlUQRmixk7QfutEC7 ncscgpOQmSypS+49spwhHizDJ2nf4XJ8SDRMRAo6MoRGsgaIHkDRGkZFKI0ha490MsxaAj/wXIg5 CzBmiM0iFLtUDQaDQaDCDKRmtlPEwyBSDTIEykZMMmGTETDHYRMG+ssdkc/wuQPBSO7u4dw4cOGg 04d3adpkHbMOmwr+7/reHcO7h3ad3DuHd3Du8WCdIGeMk6/+GR8aDhdhQ4cHBwcODg2DhwcODhwc HDg4MJ46IophGd6/CIZZZamdzDhzD5Y4dyxw5Y7tOHcOYdzDuHMO4d2n7fRvd3/5FQ5Txsz5lxT6 NGYFPInZHE2HhtQw6eWOHTew5bhy3Dmhy3Dlu9hqw5oe3LdzO5bu87MwkG4MGMRX8JK7QMMcGxc4 PDDwYN2DwYPBh4MPDDoMG4MPDB4YeDB4MG4YeGDwYOgweGDwYMInYwSBgyDeEGv/C2r7D28MPbw3 bDoN8PDdh1Ye3ht29vDD29h4b2+6e2whS194QSYbhg9vDD28MNW6DfDwb2HsPbwYfDUN7at4Ye3s NW8MMLqDSVtfOzVnjliAjBhg8www8wZgeYMuPMGYHmGGDy5mBcwYYOy7MC5gwweXYYy5lw5hmB5g 2HgjQDzBlx5hmB5czBZhhh4I0B5uDB5dmB5hmAhhvL5mRhBByY+eRJ0vpWxphvVtVDft6b+G/b0w 3232Hw6t+G9MNuremG/YfhvCsPTDfbD03sNnZj3HqW8fdPoLfb9t+/b9h+/Yb9/b1e3sN9sP39h/ ft9w+2+2/D+94TN65lWpMf+U4IXf//33399X3f/39/D7b7/4ftvw/h337D+94fTfw/aEN8J1LfXo X+12HS6XpK6W6XhL18JbreF6Wl/wk9Jel6/+v/hdpfXq9W/71//sOgiK7aCW0EukvCXCS9LpLpdp BdK6tBLpL13CW0leEukFtBLpBf7r/eX6/uNkHHXwvlQNAsQQWIIFiCCsQgWIQLEIFiCBYggWIILE Ik8QiTxCBYgglEIFiEFiCBJCECxCCxCCxCCcQQLEERjhnymgz4ix44xH/7oFoLSwlhLCThK1wgtL CCwlhLSwloLCuEsJYQWlhLQV/vxtEQzB/Xw66WEuFpaC0tBaWEFpaCdLCToLCWgtLCC6wloLCT/9 O0hfwn7cLBAsIJwQLCBYIJQQLBBYQLCCcECwQWECsIFggsILBAsIFhBJggWEFggsIIMMLd4tFmjq /hV9Yq0EoXCCwlhBaCwloLC6ShKkFoLCC0sJaCwlhAtJ0FHcZUbQ19NLbqFEKIUcQoqKio4hMQoh RxUVoLQUVEKOKUJMiPjWCLMWgz/wiLApEMzhwUFCgoJgoJgoKChMKChQUQohQmFBSMIIINdJwwpM P6u29VChVVVCqFUKFVVCpqmv9N/8Jq6aphVwqhVUKqqFChVChUgvrT2/0wncREWCEMFBBgoKFONA oTChMJgmEwUEwXjplmLLPGl+EdjHRZy0s7MZHi5mFRkDDP7lOD/raTwhGn8t9OvxybUkWO/Tf5Mf 9f/f8frtWv8OmN2iGCM9l3/jBlSVPKqGXBwYJOIpjT3G0P+7WzsmBH7G1/h4S03v2vyKPhklkXAM EEYIwLkGfhgh/BHQWHuwaXe/zuv84+Sh+HhewvxH+PhgxwRoBw/BkghX4YX/7ftttQkHGx//Bhl0 qbDDBtBBINcs0kv/mDYyY3sNg4oIJtMEWcqSZHH/+3H8OvhoUv9/hh9K/LeUhjSf/9y3GD2krXmi 5lXmeRpf916UIgheIQJkR9foQyrIs25ZY//XpIPCT/f0C3r/hhdpJPQX3qRAfBbr/sViECRI4PBA mu4wUyJsIFbFL9rCSXr8daRZhll0vX/QSQbiF7TTwkIuv4MFggthwSeGYcIdgybGYaIbVfrS+r4T BFIWw+g0PzsdxC26RcDxQMyGAheb3NEPxgkg2KWCIYTtDDk3HIQiGeRX9VYSftEFx4UN3/XW+Xlr CX+pbcaTmkCCNps7EiScRREN/DDIrr35o3tJBth+zIGqsNA//CDuGEk4P8y1B4MJ1+tNBvDhbv0m GQQ2MiOHt++H3f/q06Tv/7vRbhw/O1YRhpODpN2v4OQYh27DBgxCI9q1GZJDJM6bivw1d8MMNpXT vTk2JOv3t+29K1msHL0J7f5JAyoZb1Xb4R4Bg2sv7PJIa62WYpgQGC+sHSv6bfMO9wpg0K+2VJU/ kb1kSL/httf9VaasJ/8GD92/TDbFf8Nom5TOEy7/8P//Wv0tlYyMBLJsqRcS7/JYRY4b7f9pJ+wv Yg4XFmHof6YXRtmB+9/CBBdMVot7ewybBRbyxyY7/16bfVV40TZO/9V/CD///+3cER8dcIJPVr9Q cmyUGdMd3//4eMfwSQjBlhBFGVQOQKtO4/996v+gTtMijpL5J3H//oIKW/9aOzAPX7M5Y5TqEHa/ euIQTDviCl7LLTQYJRERp/9J+l6wvDCDKkoCKsE9L9/hJv6K6rEl7xTBBhf/sRWCBPVQiuVmEGcZ G2EDNnnZIynAgEDrUM8iReqSsNdWqaa26+wor+1aCYY49/fh1THRB5FfshLCiCbSM7/a/gkTdnTP ETc7YSfw0O39Nf1rLmq1BPevtQju03VvTTVVnZYDtfLHqnYYT/GW3GwYWDENCIaFVEf1TbCBkCO/ hh8MR6uOQtybJYEBB/yZCbf7C6ljp0/+CIL7HhkHcKaAZXFAPAoFvqm+v6fHsMFevpkOOFN1quE8 NbaX34iLbX5Cu4ZblQL4MGVy4Zzpl86ZEGSIvkeLmcyOQjEGCuN9EdHYNZibCIc3Sh/6eGW4I+2G gXnYmvhBBuDHTBsIislybuQjX3tfCCDRNjQEv1w39IUH+nkcPYQSMkqBAgn/8MPwgk4Uj7X/h41f BBu/foqA8ECoIKn/+EGw8JOl/r+w3pUl9bbC+DDkRfQKGlf//WOvaXpQivyp/sGbC7CBBQgQaQYX 2KxSrphf8IJpNQwXwwWECF0giHaM9rCRbpd0n8MLQXWE/jEKDaST+dodWKydH/hQ+EH/wpnDMkuS +/yzalta/++w7/r64YfUV/fBh///N9tK18kgZSB4QYMHWDBL1h+2OGZwv9+9Yv3Ye0EEuvdB9BL3 52hyN3il3/wYPBAv/99dL+gw8Jf/sEeA8IF7/0w3EL1+6bD9g35TrXDcEpaRYGCDS8f0oTpi399a wtfwwQQQ8md/8Qgum/+kW6zdP/wgUP1/4Sv6X+gr4a/JKBiIKDVivrUzhvX1rbw/+TNvgw8tIKL7 1sPH4ZrKP9vLSLC+Ih/MMGDwiDDQ//233/9W9f6B/RkpfLskO/7fpJ9NN/72lT//vB4ggX3tfqHo J+rX4yT9KstyFaG/KUD4MHggQ4sUvTW8JdP03DDitkV/wg8MHJLjnyIr5CD8wYfCf9EdHqw4Sf9A gbXDY3/Xf//v6+/p8MIIEW5JNa/vEJQ/LSUr/6Cs1bX/9QQUGI//rSv//hBTOHk2M1/tWILDZktP H+/Ww7zILX/Wttdf7DCULCPAPx/tglC0ww3/8cLtuv+16YbH/sL6/+1luWW6WWQIv5NBw0+gQWP8 Yfigv/+v/KxEcIXHB3ggX/CEXDfQXkQq/Ix36X9/wwdRBeP+m+jtLX/7b6/+duCYMHcIfrhBZhhv hf8EFrDx++CIffVBv/4Jf5UX/CBfvf/gtwQLh/+FivB/X8IL/+yF2iCBcscH69h9dN/9h4QXsP2+ TIPEF4YP64YOvB/+wfeYbD/5JQMQXwwwf/WC/D/9ar//vt9BIyC36//pBX/2Q2DrrEJX/xGH4QKv /d6Xf+6wlX/gy3Vrwghr+2g+IX/khw/r/4YN844Irj9loTgbAZv7d60g3T+rD/YSalkA1/cGHdqN 4zbWjbWy9iptpR9pF/MMNv6ul1/9Vhw9BFP0k399/KX9g23FIN7/q3+EzTfd+6/v/4UEH0v21/V/ 9IIPcEEw6gx///rewq+Zw6/r/1qISf3///oEETvggTDhYMGZLNfff/93QTHbaf/X/1vXww/6//pb xBB8uwwd1///rgn7bq/////23X/f/9JAmq3H7//9dBq9da//t6whqkFT9/9dVqxBBX9f98JL6X// 9jW8IL/r/vCvCBP/f/qoekv//2FXFf9f8RkObGoX73qfX7hfr7j+2n/r/yOAbBJe//ySgY3G1/6+ uw99fv14MGW6x1/9e/MQbh///307Tv/7+TQnsGHBte9/9v/v/6/a/Drvrv8N2ggprB31319cUtul +v+uErb3v/+EDwgsGDv/7+iK/CCzE39f/0m9LTDf//8EE3EF2GH+v1+g3Xt//r9BcL0v79/pPBU0 CCMlTfwRx19/p/aSTv//Iuv08FYoK/x87GLx/Cb8EC7/x/4j6/t/7/wgqfq//pxBC2v368rBGI0U OvXr/hCIfXv/v7YNgivxtv//6ujJOk/v/XvDH7+v/jJQDG2/b//uW6X////Yae31//wYODYTff/8 7dHizcG7e/q/+SQMrVuxf7//6YYctwbf9f/9+yve3//9+vYaDv//53wu4IJwYdt///S2ksN4b17h 38JYpYIqH2WUzCAgZ2qBAQM7VAh2ICv0CwgsEGDI5LSDBpqqra8LYS9thNve71+tBe4sPa/34ILC BekGDIJ1v/9KNaCTDr/6XoKE4aQQbH//4QUJRCCDIYZSzVU+/CULCQZA8Fo3Su/6+oJ0EG/32vog YM6ggR2GBBlgHgUU/1/vjCIF5cd7//9cpYsIJiy9CigviwyhDX//vDCIO3NQR2cNOxVhC7W17/at OgiDnKcM7SqzjI3JoP33r+OCJc4UiDKr3r/9/4MEEDDEECIEaemn3k3F0T+fzsX6P52L+fzuvo/n YvtH8jEQOKec9v4cKwRTgm//8Kuvpp63p3qn/f7QVldKUd//Xd9p3//rpp/r+RuDCugaCDbW0Gmn /1KMgUQKWlKMgUTEnplEU8U+m6lETEQKTq7BNPsoiYv71dwmxYQjQ4TCD0HBkZoNEXze3CILjhn0 bjCkflkAzogXCYIMj5fCIgYMjwJoNELgM2FLhnMEEy4yPl4FBEGiCCDkQchljhphEOOcciOcc45W FDljhkdkeKCL/6DDSh2lbTWTccCWGz9gwacm7gyOknEQt/zE2uw5nHTyGc2Vf6Vun91uGiQ5Q5DS cgQOQbRyGQG45DNcgeGhyBIOQPBxyFHIGByGQGbdfphhgkuVU1DBpt3CIFGHNZbpl2X5rJVl2R1m sjoXZoLguzcXhKsuyOovCVC7NBdmsvi7BBlwR+ayM4TNBrLs3l2STmua44TLsty4NhdDYYuayzlw W5cE4NM1kWouyOZd/++4OgeGGv4Vj9fYe3baxSVvD2+HUPW9vDD21u0r2Dw3sPY11sLaTGsPDe6v /dfTvbkxwrKpMnhcPS2Ipvbww8NpRw8Nuw3DYKxG27D3w2FiOHh+HhsFjYYVhq2Fim9vDDSd+VgC +0Elttg3LkYKw6jb4JFww0XmRjwRoB5iDDwRoFAjwi7I4cEaAeCNAeCNAou4ReYNQRoDwRoGYZgO CM6Lsji5iBg8EaAebwxCLtovRRHcGfEMTEIxBhF3B4I0B0bgYhG9yqJenigkvDD9h/DXwkm1bHbe gw3rpsJMjhU2+2GqbSZcLDjtjV+k2lDGnfbdhBtJtJtWw6V0G+GLVh6boN07/hL7Dft5L3d+gpEH b26Yb9h9sEn7qGHqHda6w6hpN02EtbW3phv62rDVhhhBWwuEoaTDfbX2/8IFduVoJ+lZpl5tg0Z3 6ChN6g9t+H1T9Qfftv/tQe28P/dh8N9t1+v4PXfdh/8P2pJNL+EFJPNDd2/QS2CF4b/e9KqC0l4X 2vdN/0v/cLpOv9UuvSX//QX+q1f9f0/nZqR52rvfDDe0lx7D31bbVXVr9Lr+glhLfV+mqCtJ0ru0 1hPS2qv96XSYdL20C0t0E6pbf1xBKMPZDqvEECUni4ZmDBhKOQlZFsQQQMQRFHiCBOIQLFAzwYPA gggsQQJxCBggxCI3iESeIRJ4ggYggZ4QjsQgWIIKjMMAgYQMECBgxCIxwzwYEIivEECxBEbsVuD+ /C0+QaMJEFDl90vXdXYNthdOElSwiMd3I3aCwkqJRTSwlhK0ShpwWEtK5KPJxhPCfhaXVrMO7+vV fERHhLQ7YaXYfRPmgWlhdBBuSzVJaCwryfOFoLQVBJuT7WlhBUron1J0EDahtEuaWgsJWqvMOH/4 Lh9YIFhEFA5QiyHkBIuw24dUg6CwSsIFggQdAg3BNhAsEE2ECDaCDoLBBYIFhAg3CDaCwgWECsEC DaQbQQNoINwg3BNwVggWCBBjSvBh/+EstxsnC0uQdwhw6CTgybKpMOM2kQYcQZHi7wlhb3XCWlQQ V71pYXCurfhLCWEE3Wv9e/hLSffb/9VvmgHEQtnco/YMJbbk4HgrRCdbWIUVFOlfEKIUQn9LQWl1 pXVpOrq6xUVIkUrww/gv+HyFh6sR8rAaIXbrCYpioUFBMVHChIFFMbEFEFEExTFB6ioqKgoIPkqG weGH+/b/CBQtvIWGVDeu66qFW8KE10sL3j/qtQpjYebmH8L/tOk1+U6I5ng226r4VcKoT011VMLY T+001UL0Emw9Nv4VYb23ojXSk3RsDyBgxCBcuZPyepI5aQ2lgmmmChMLDUFBsEGngoJgt3dqmCDC RneECUG9QYf0GEr/0FkYgXw6S3dONY+Ii1Q2PiItVVbiO/X//REccN99Ky6Pho6bXiIiN3+W7drq nfWOHrul9Anh3vsIrmrcQls2FwU5uLEEEkLv6YQiOGDJsEnBkSYLYIEF/qHbtbVhFD1xERFBP7jQ bCuHCCxS/Qat7FRhi7CUIKRB7QathrhurQX4QyOA7rhhFO2YXgjjgqybKQcjGXicKS4UjAuYgwyb IFLsMMNwWCBfrDDbvhhJxoIQvWuZ8zuTHdJhhhBXDddfwtu/ljv1Sa17th71D7eFtt1hK+OGDbda BhttqgV8IK3QYNQweDDv/3WIKuVhHER3lzbv+H3sL5McErDsN7Dww+u/ioX0QyjLhhtvVg2kCKjw k/EJXTe3YRTv1h0guv9K2GxSowwYNBbaCYKaPREBCObFlzMDzDMDwQZgsQRI21DEIE0wv/8PtOxB Auwor/CsPhhumG62HhINrsJf702lWGGot1x6C3T/v29J9xfjbQIIMh0/3CTDSCT3u+/19YQIMbX8 Uv/2wkCXT0rQS3/XSkIPH+EE/uEth1QIqHsHhJ0ugltIKKa/naDwggbCCxBAnDDBIrlYoQYYPBhi ERwz48+LiCCgnf4XQQYa6CFhhKu8NoJ0tBaVf8LhKwSMiVatpILveFhLSbCC/+dwHiCJIDccES3g hMPrDpYQLCBUCCg0/4WE+Eg03SC7qIWEuFLHar9AqYUU0w2FC/qIUVhhx/KUDwgYKCO6wzldKIQl scKFC2DCJ5+gUI754MJ13YVQsOr/BBULCOxrb8k6qqthhL9ohNhz0wQh5h7cYsEOXYMGCCMGGDvV eOv0PbaC268LW/696uH+HpkiIFECiYiBRAogUQLIFECyMyMyB5A0QOIGiB5kYTFff5kTXVfh/d3d p6enaaaD00yYiYiBxMUP1v1zvFD0vsPuHDThw7h3DtOHdw07uHcPr5oe0ghFh1RKmUq+UoPpw4OD g4cHBwcHBwcHBwcODg4ODQcNA3/DB4hIm2owgUGgfww+aMOYdw7hw7tOHDu7h3d3DTYaf7eEEHW2 HfDB/yx3t3M4d3MOHMOHLHdyx3d3cscO4d3Dtfww9IMGrDh/O4D63QYPDDl2HsNF2HLgNQ3gw8MO aw8MOW4OXAOaAc0B7BzQHNAOaAc0A2Zw0W4NFwPzEGHhAowZCqpCbL9huKvb2H3ht4eG9h7eGHbe w8N7Dw3t4fYe+3beGG7a/2G8JMiPbIGof328MPDDww9h4bww8Nqwbt4YeGHhvb29h7Dw2rD28N7e w0v024hVwewfo7OSCLsMHhHgHmIMPCM4PCM4eEeAeYgweDBuDDwweDB4YdBFWDwYahg8GDwYeDBu DDzQqDBqDDUGDQQf/hPy4jLj8Olw8Jt9hh6vpsPTb028xN5hhtTEGHmJvMMN6DYeXbeYYMPMTeYg w83t5iDDzc3m4NubTDzEGMxP+lX77/aSsMe3pvSsPsN6bD7YbpsPThvbemxrFpt9sPTvsMPTvTYe mw9MMPVtUGG32k79pYf64X4pYfDfYYfYb1Dfhvwb7Dfg3phvUOoPhvTDfgw9NvUGHphvw32GHaYY emGHoMNW/iEChp8VFPysAY9V+q/3/a/WtfXfv/d9//D9/t+//v7euvWlLcOOFC+r6uluErpL0vX0 vSfXoJdf6q0vrtL17/r/6/W7v+EFuqSC/gwYgiO4ggsQgsQgtggQJRBAsMIEFtAgsMIIE7QQWGgR IeGgVhAgnaCCdoIF0CC2gQLoILcILYQQWGgk7QIJWEE2F3hBYMGET6CIhIC+Vf2loLSwgsUnSxCC caxCCxSxSxCI3ililiEsUFiEsQQWKWIQVCglFLEJir6RmthhdKF8duFpYJaWlhLrCWkoSwgtLQWl paWl1hLSwlhBaI3/hBDhsLcJBfl+T6i3aBKCBYQLBAs2KmCBYIEoIFggWECwQWCBYIFmxVBEk8EF hBYIFggWCBYQLBBYQJhhLiFlzDBgiLZOwcEwX/99wloLS0FpYS0FrhBaWlpaBOuEtBYS0FpWEnpw gm0+u3hXDYUL//9oLSwlpNBLS1wgtdLSwlHhLhYS0FrhBNJYSVJuuvf+x+v9pRBRCiFEFEFEExBR CiCiCiCiCgogkIKIKIUQUQogogogmRB/BdLdUiGctIZ91f/x9QqhVUKoVUlCaqkqSp2va6CTDqF/ /94ULhVUKmuqYVVVMKmqhMK9PdBBsNBBe/fyEW01BMFChMKChTGATBMKCqCYKChQSBQUENcHgwQM MUisClYF+v30IsKmmE7C2FCYVMFVQmmmqq1vw61X/zok9y0DENFXfeEExoJBffwRDJMchlwTHLss c45McnxnLHJwQ2DkY5Eggg5Xl+aDSrLQddX3mHDwQTIjwSBBf/CIEoFjCDVqQY4hRydCoIo5dlOR W5Zww4r4Vf/kCaK3EvdNaQS/12uDBwXggggveOH8Nt+qX+iIBCBBClxC8oyWiG0YIoiGGC4apfI7 LhoNg2Fw2EcGkjgoI4KC4cwDBHBbDU8xNoO9JL0IjBtFvbI4ybDUYFKlF0SL0GDBmRdSx2nohoLC GfdXZ2h2Lhh9iI/2OGH/f7kY72138P2i7G+/8GGoMMJP+FwYMEnZC4mcdf9h7DC/tVhtbERH/t5i DaT/QSzE2EjG2QqKXfrBGgHphgybHFNmwdYggWmDBggQQYYNBoP96bZXwu3q270F3wu7v9dhsIP8 yA46Egu/S9/7h/JIGV7ZkrRTsF6VMEQTQ8hw66wQXQWHUKHfpfzI1Z0CqntBBWmE2G1CuIW0ggYb SUscO/b9JXeuKWE8pzbdBdYpQxCC3lu/+wQIFoHyWwuEC5dGpODnYKQhLhYIEdqEV0o0sMHYYd/x XT6wl76b/RdapB8EMEL+yJPhBcj73oL31Da8ILhBDd3fztDwQK0Cd2QI2KQQIF/RF2lZh+NxCbRn /++nL7fhhsaw96/7JGQKIFkCyBZAomIgWQKJjYRIyYiBRMRA8mIgWQKIFkCiBb/VfrCUQf90neqC v6707h3ad3Sd3adp2g9OPIXFLq9sQQJ5i8NwSsVtsV2mgcHBwcOHDg4ODhQcHDhw4ODhw4ODa67/ CSjy9DLkCwkRvb2HtaLH3Du0GnDvtO7uHd3Du78R/4ScJBYsJaCbfg2l/u7h3Du4cOHdoO4d3dw4 fktyZdaqCRJyyNIhtN06oHLoEceyCjZbvSuW4OZwcscOYcOW4cscHM4OZw5nDmcOWOHLHBzQDZnD mcHM4czg5Y4OZwczg5oDmcMEHoMzOGaP7UESa/OA2U5qD+YDNd6p9h77Dw3t4N7eGHsPbw3hvb2H t7D26b28N94YccNuHd7FU6cPCOwVeS4ZpHAj7W99h4bVh7D32021fYew+8MPbww9vYeGHhvbww95 d3/9PkIqoWQL7Ww7EO0n4Vh4MHgweDBuGDwwbhkekGDwYPBg8MPDDwYPDDwYPDDwYPBh4MPDB2DB 4YOwYMJOYVhuw37WwnYzS1DzS0F+CUPBFQHgjw6BFO8N4R3eCKgPBHduw3YPBHgPYeGHt7ew8N4b 2HhvYe3sNION3bf3tOzyG2RB8hstUn6ReYegw3pt2gy48xN4TDD0GH02HmIN5iD8N8xB6MN8wbDz DDeYYbzabzew7N4bzew82g3m9ujcGKMPt7/wbZnKyFkCA2KEQZY59qhb/CBQwY0wwfYYPChhqmDD 7DD1DB9gw8JsNUGGD0wY0GDGmDB9gw9MMH2GHhBhg9Bhh0EwwemGHhBhg9MGHYTDSbczvmd/70wv MO2EZWJ/pW++m/hvtvw/b+/t+67r/7fv2H9/Dfv7+/t+/7fvX0HfTkzW2HMjUF6uut/9/3/7Xb9v 3f/d/f3///9//f/3r/7S4a/YbcQhFQYMtxYC6sXsHQLhLaCXhLpLoEF0CXhBbhBdBLoK0m4S6BLa QXQSVwlwgQW0EuglThBLQS2gr1hjwx/vrDaa+w6CIg9pLoJbSC2ggtpLdAugltJboJ2gtK0ErpBb hLpLFBbQWxQWHCWwksQlbSbCXa2vyQ7bS7TCT4bDULFLFBKGksUsQliuKWISxXFEniERvGqEJYri EFrigsJYoLFLQWIRGOxX/+UsKoYMMOswzA0QX4MEi83g2IQLBAsEE4ggsEFhAsIFggVBBYQLBBYQ WCBYQWECwgnCBYIFhBYIKwQTggsIINrgwTQMF9B7DeFq2Ew2Ek4eHrS0tBaWlhdLCCwlpaWF0FhL Swl1hBaVIJUsJOXSiIj8INw3FeG5KA20FsPetBYSwlhBaWEC0rrQWEFoLQWEtBYS0FhLrQVpOEuF EZUyK0Xwg8EaAwwv1DDDcK2+0nBAsIFEFhBOECYhYQKISggohYIKIKwgogrCBKCCwgWCBYQVAgSh AsECDIg8goLkKDH01th168MN71t0hxCqISFVFVFQmIVRC4pioqKiFFMQoprVP8hx7pt+6Sw22HUJ fhdVChVBNaVVCqFVdVCrTX8mG/DDDlcLDRiECCQTDDDBiCBOxsKCgoTBVBVBQTCgoKCgoUFBQUFC YXy8NDk7ND/Qf3cEDwgtXfp4VVC4KmFChXVVUKmqahVfXwrv6uuEnK5UDVrSDsG16qE1UJqFCqra YTtNQqhVVIsd/v7/q9oIJyuKgXNhcIEthhhtbKuot0qLkTYxMff//8UFyCV8IJV3+621///94SzS QVsVIKIbfM+rdbp/X1+vhBGhYKERAMOCRCjhw+1risGDJsnLikopL71hBfoIjPrw7cf3sMK/T1/9 K/QI61vCkh9O7V3DzEG1YbT//4ggYeCSSDTDbCCVQjAPbVVNb0wwwQI2bBgwhDL2Y+0q+qDGbrFX q3e/YfbcJclGII2xvq1q9JBEgpUQgRdXVJ99e3118O/bBhKCDDjWECERYhzpJDZoN9bwYP0mDaqR Vgi7SffTwsIofV2v+35vYe0gg20grv/UFFFC47e7Dpaf6DbxSYYpQbD+DwsMIINT2iI5IcHw1gwr p/2DDwQQOkVIIDIXYj/truNIHuHt///pBsjhWDYf2h9eKvmHd0k2i3pfSWEFHbD9ElYwwwkjsXXv eGHLdxXUX9BBRBPNDmh/uyXNr/f2/9f2ggqZEH77+4cPtIdkV7b7DbBprV/Faf11/IXZAdh1VW/w YPEMhgZCT+EChVxCiF9htsPSWT9/m0274S/CCb+Egvw0/S+39Bt3WkYm/StPCQS+VsHg30r0FRha pgw8ECUECTZCGxXiCRY4MydIZLQoIhdqHww5Fhwb11f1+8EX47/2x4UL94Yb2vvj9fGbq2+FsNF5 qn8mOQQzQR4DDqgn/XcIK4hy4BtILhYMMLwUF/DaasNi1u/9hJN+w6S2sMMJNsKv4fTbpL36xSu8 NjBdZicJG02VplKXr6TDDDoJk5213BAndQcLp6YMGCBBBsGSgNBLA0e7CXvH21XhJw1tpcN74S/r 4rdJ/9LSgyMBFf7Xb+738FsIEmFsNAwS0IJoaeYfw+kmDDVSflPkxzZ/C9BNdoa1ff8w4e0EmG1C hC1Qh/pYpex9OlHfhvFBNild/8koPggTCsGQmAkmCYYSarwweCCJsMIJV/+FpU7VdXu/vpBwRTq/ /paC7DQ7Cda/YekxH1/5F3qIWGGKQhgwk9+YZgeCBP3/6aq1g6/7DcQmRR/TevhIKFaRrmDBLBFP 7u/211fjCw6oMMgvRJ/WG2C+DBJgwS/9pNxS/0kg62KivklAxC20kwav/Sbvd/p+wZBhJY4MtwoD CLf+wggpnDQ2EGF/hbYXbDC9fEJK2oYIML/7DBJ2GW6qCG1UfhBOw5Y5x2I/l7GcMg1K4YMMkNX8 IEoMMmycY5BYzipRp/2HhrD5mlr0nDDSdbVP+nhgth4hJvisxWFbW1v/DwZBcTlzBg8EEYmHwtBg wwRFwnANW1b/w9hLbdBBINvhLtwvrr/3j71XD6/+6PbdHJv/IxweV1pv+lt7BdBJg2oVK9W//DfD VoJbbULfaCCDDahXa//7v90tg9LXaoNiEv7tfW6B/gwWDDEIFoPEECBtbCFMMIV/w3/WHXt0mwSi or36D/CVhv4eEmN/7ogvAeTqsIFQdGdcHEJsMjsEGRwC+P47hBf3zQ4TtC0P5FHv8ff93Uijw4a+ SUDEQkvglY0ugYOuu/pyMeF+vfww1r//ZjQT8Kmv3h3ff6oMJcXr8wwYOW4aFX/7S9Nq/u9uSH1/ k5lcFhBP9/227DQK+v0IxBeRKLcSqT/rUMMEn/+l6fdUvSCwRVhpP/ra+6pNX6S4bYK2o/4L4MdP 8QQWmDDBAjZwdlZjN+/+339BabwXcNf1wvZh2s0V9L//W/ewS6gwfx+CBbQSDBtQoNW//9MPV/Xa SYbSXCOTf+vw3hfiFikGxQUscPt/9/YIrAeCCb4WCBA2oUMP/7wf4Qd4SMTD7wk+EL9fj++GHqne yx3oJtU+6/D6VX0S5sPGyW52YRS0dgaiEdnRkYyZIjSbRY64j+TIJf/6X+SJSBRMSZMUMgWQKTok ZMSZAsgcTGQKyBSab+018IOH+6XDqru7Tu7tB3bScO0GqDtB3DuPKk2vgg5Jw+3EEFgwbSBEr6WD g4ODg0Dhw4OHUHDg4cHBwcODhwdNtBk9pPQew/0nDYhJPW4d2ncO7h3cO4d3cO7v8f3hv1QW3/LH w7h3cO4d3cO4dw7h3DuHaj9EiOGRRnwgsG0kySek3NAc0By3DmgHLcHLcOaAc0BzODmcHM4OW4Oa A5bg5bhy3DmgOaA5oDmgHNAOWOGEM7Lf+6gir/hLftB9Xt8Pb23DDw3t7Dw3t7e+we3sPbww9vYe 3sHQbVfpNumw/wgt779vh4N7D2Ht7D2HusPDDVvYeHht4bww7b2Hhvbw+w5O6f4TaoMMPqK7RY9Y PKgcHgw8MHg3hhqDDwYPDDwZFIgweGHgweDB4MHhh4MHhg6DB4MOwYOwYPBg7Bgwgg7T//f2C2PR bu8JEeYamGXHm9vMMjjzEG83t2Xm8EeHm98wy48xNuCOO6Nwbzih4I8B5jh5jDebw3m5h5ibpvOK 6Y3a//v6S1/eEFDb9vQbD1Daw4emw9NvTYeg29NvsMaZcOsPQYbi29BhvTb02Hq3psOzG3qGHmJo xWP19oJewtp6bmsHhArBjsMPsN+DBuoN6YYdJgw+wYdqDB+DD0w6g6YN6YMOWOwYfYMPTDD4YMO0 wYfYYdJgw9BhvTBhJudgmv96S9hPqt4b/dX8P+tt+Hj/et//Dpvv7f/v7ft1v4f39v29VN//UQgv FXwrew////+v+W6/X//1aW/6/9fS+v//X/0t00Df/ggv/BJkUsYYeyEcIFaCXQS8EFtAltAgtwgv CC3BBdBBbQVpWgS6BBU0EuggtoIK4QILDQILoEFbhLaCC3CbSSyH3V770+RO9oEEb7o4gw8MUERH ugsMIJbVdILYS9JYYQSsNJbSW0ERj8K0gsQlbSC2ElsJLDQSxS2EEFigsQlsJNrr/dYQXp2mnSYY eEG3sFBYhLFBYhJxSxCBOISxSoQgsQkopOKI3iFtLEJYhBYrigtLFLC6CsQiN2Kq/dsLhBdQbSeg Vhvw3g6BWCCwQLBBYQLBBWCCwgWEE4ILCBYQLBAsECwgsEFggWCWCCwQWECsEFhBBsLCZb/2lEL9 Pdv7/B0qQWEtBYS0lQWlaC0FhcEtKqwl1pcLCWlhLSwlH/1tfWHr3SXhe/S0sJaCdKksJYS0nQXC 6sEtBYIJ0FhBaC0FwsILhPpf2Kgr5bh1NAwZF8jLYhAu0FEFEFEFEJCCYgogogogogogogogogoh RCiFEFEKIKIKIIMivbX+1X7Df26pBb9VChQqqqrqFwqhVVVVcf9qC/e1w6CwvHVVTwoVQoVQqguF UKoVQtf+woX4MHhJwdBWECMiS3lpAUFBQUFBQUKFTBQmFBQUKEwTUKFbhhP8MF34YdAr2lSC9p2E 1UKqaqFDphUwqhNQoUJqZ3vXzs1v8w27ovP+lZTry3WwkKhEQ1TQsIfwwQ/H/TBg8ECQbIQUdRBU eDKyrdTQGTZJMY/h5XDv/BLbY/Xhl1tr/KUGi7//a/gr+xww1/lYAxBuK9BLDDahNMLfg8MGCTf+ /w0guHSWP95ibBJ/rDXxCVhsQgVfzQ9NtIw2H+R7qJOD/CCojZqGqNZmy8MH2DYRH1h/QW/4QW3j 19uu3Wq+tg79K3W/8MG+Er3f1gwwiGFwXEFvMPq/owZgthBIGRbCQL/htPrv//28UEGGKX1zFDCD 4Xr//bDUJBwl/0GDDCItA1YLYr/KS7V8IEGwXv+6TdVv/hBe0EsJMfX94IPY9f6C660mQg/7e0Ek mHW7/j2IIKIJpf/QSpvIsvXr6CCr/sPFBb6b/j+k1T/kDBnBBBQ3oMt1JKm+PhArv+3pbfYTte/S T//hBL93V9cUw0/4aUIEk3yxwdui3rngyuEi4Dkhx/B2KV/Yba1GRWJmteE4bQL+MK272/+Gn/W2 F/nYahd1gwYboK8iEpEklX2CwYMEg38J15XGft7pPbeuuYoYUvt97mUW0/Yd4XYcPfvTDaI8cPr+ dR8Hn7LmDDbUEEYYYMlAUqgfKf4PsNld0EEt/+72Hr2G60EndtmRNOPa9D//XT4/9vS2HDhivbtL Dev76bg69K3/U0OXDzoE5oB7QIImwYooF34PT/3S9tpBfrgg/vGnCX+9W38UFew/io7sl14YZG1h BBv+SUMqHd9LggTqDDEIFCgqBBj4YY4IIGP6w9d6wvRxB1QJAv8MPQTIQff7/f0CbtNvCQXT8w29 Ity6/rUk4P7MtU3WCCd0w6LHgiIsESS20QuP4YMOIQtf29u5Fj77FR/S6VQg3+3X/O0Hhv/HWrq9 4KFwn/6qu/hkXv71BRsfBQWgn7oIKHF9fCKj/vwn8WF/1SV9X8JsO93deRXTWRYzAkgRJSf9tBKZ 2t/0wwcNbW8XVrQhoPzj/DBYYNFjnH1/3ZMe/sb//6/VbaQ//3j/4///8JYYYX/XQQUH7qQJ1eQo ZWh1/4QLMQYYJBs7C38dpKWOO3911Su9eK0wwwgRxsH/K2eIQW6/Dq9BJfr1269p3wp4eCTsds7u DdcJAgtjXgvbhK5FwYCD+oQegrVRe+Z+gkt62vSt6u/quksz/mdusaUL/hbWw9dE3/grwQLD+1hg +nCCBBbwvxBAgYMUCmRQQYf0uITjrew6C6SX+nhIOl4W69IlDra/DerpL8Lh6CDr9P+qeE2HqFmG XG0CCLzohoLCGyQVDO8eDwQTHmD0EbYb/pcFtb6hhtBK4d9CP6UhR/+nf17gi6sP/tiglYdd8scO KDH3pb//xbNQlfYdJthkUIjkVNm0XsmLoMHCkUf+20v/ryI0vpf4QuI5OGy8Nwv2FvSV/X3Fe3Vv ha4Wth++PDFL7f9r0IIEDBhhBAocHr4I8Bwcd7aX/CUG/4SbFK/X0ww5na5HRsV0vvS916CDa3D1 +29viNtL8UlB2k3hAgdYd/9hvDBhE7tMV/4baS2F+5Y75CWcc46/9sJOGmF+qttekC5nyx3sPklr dJYYauL1waYKSgG2rxCYjIsBBBAIdLoQQWYYMMECN7DDC+wh7bCRkTXUivTTX9BdtpQ4Y/DC2Gw0 hWmu7/0tW0lb+ODDYrYL6f/CC96fv4I7tpxfZxyfhFTZ4/8ILcJMPS/qGG11i449+l0kW8JhsKv6 DDDBkOuqSB97TWyGizi2ILEEEIMMQgVfsNgy11in5FkTRC8f6Qdf//d6DKMJlGv+gg3/2ggl4MLw 0HDQe+zO8ECbmH3+kre/7uHvY3hdDrqIQXdyx/D7/7JGQLIGiBRAsgWTEQNEDyYohFEQJEDiBZAo gWQLIFkDiYyBp/7ggq5rBpMdhuwfB/QaDQcNBoODQaDh1DQOGg4aDhwdwcHIo/+l1cOu3vyktbhw 7hw7uHdXDuHdw7h3Dp7+EFftr/b463dw7u4dw+7u4cO4acO//EL9HgGTZON5bh8t2vUsdwcGgcOD hw4OHDhwcOYcODmHDg4cNhoOHf+F+m2kY2913/SeaA5odzOHM+Z3NAdyx3M4czhzDuZ3sOZ+3M+Z w0W7Rbhy3aafXr9NhhJNh9pbDC54DH3bfcuA9vYeGH3NAeGHt74b2Ht4Ye3sPb2G7ew5cBoa+Cv8 OECtg8MVsVrhJvDB4MHhh4MNQYPDDwYNQw9g8GHhg8GDUMNQYOwweGDww0gweGHhg8MPDBovL+Fm Sqv+l/2v1Yew8N4Ye24b2HsPDeG9h7D2G4MN4dBvDeDDtvDD2HhvbCT/gn8jr+36DTtfhK6CKd7D wRUB4RTh94YeG3YeG8MPBvb21BvN7eGH3gjwHtqCM7wRUB4I7vD/4Q400CCDB0gQi0P4IIwYYsIM wOy5GCwgww8IMwOy5mB5gwYeYMMNS5gw8uYYPMGDGYYYy5gweXIMG5cwYPQYYPLmDBqXIwPTBg8u RgtMMHhAzA9BmAhc7JWZWyu664hIMNpBEpEKwJ+grdQ37D1DereoYft+G/YdKG+9N7fww+/w39vt 9v7D8P7eoa+Hf/9BOKQQMEHvwsHv8P7+HrfX7b9/9X32/f29W+3XD6v4f39/7eHD6vvYIImxNqEG g86kcPh4Sa6wlv+FvCV/0k+u19eul6rSXpdJPruvhfX1+qVg2Drwf1CddP/YdJ0ErpLwltV0krSX SSul6W4VrrXQXr4S2tcJVSXSXS9ILaT6BgySBP/2EvT/XDDaBER7oLaS2kF0EFtJO4QW0lugtwl0 iMfQRJ7QQTtJO0EFtV4QXVW4S2ElultLuEw1hth/QP4hXM+XhN2ieFu8JPYNigWDCoQQWIILEEsQ gWIQWIIJwYVgwWIQLEJYggsQQLEJYggWIIJz48QgsQQJwYLEIFgyO2IWQdSB/Yfwm/p3rfvoPBaW EFpaCwlpYQWEusJYQWgtVQLS0FpaC0uFhLSbWaHLd/tvqP//1W210rSwlpaWEulSwulpa4QWuEtV QWF0lCWlrfvv3knB7sE12q/4J+3CwQLCBYQLCBYIFggsECwQLBEYyECwQLCBWCBYIFggWCBOCCwg WCCwgnBBYQIMeF1/t6dP3rarr+sVHoKKqohRUQorCUVFRWgoqKiohRCiFoKIJkUfFRC6e341xVMU uoXeqhRUKKqmqiqqmKhQoVU0hCeuFXrDIiTXtU1ThD2OCgmFCgoKCgoKCgpJWCgoKChQTBQUKCac EQqqQuwm+H8gfe9cJZCD66qFChVUKqqoVVVVCVqtQggguuYYYf37Cpqnpq9hNVTsJhPChVCqmqpr YUKF6SC7egww70DTwRaWdd3TW0W62MmwkLUFBevDf38NA+murOwv7hV1997RY/uHUJrat5nHUF72 gQXw0r2QqqQslnCGhmgGKuyDAVI5kfOLtcILfLcOo2G319+gYQiIP+KCOv+3u2GHjkn7DS/94IEm /QMGCuDIIpkHkFzwGNA8zGTaoV9/6V/bDS7vXvNp0m2mv6C/zEGwpdPLdy3/cPQcMJGE2VUUrI/4 IK+8JhhggSBwdVvfw+wYYQIIOGEECC9RX/uEFhh2sbXyx32HOwVILbhQvcL/37uKhf7f4+oVL1C/ 2goeqCIUkBL1gw+EEgww1QQIEF7q/3CCg6QQQQQTyfEo+GD6CQYMUCCS/gmH+NBtpJJBfv74oINp UgusJ38ECBhigkRVkjkZf7y5gyNuFQQIG1BBBBGF33/CTrCS/67b0n5DOWkNG6+vy69BA61Xev4f CtrDv3t2cuIVyx4j1vfrEEyK//5H29Pp/IqGgggZ/9+glC9pr8bv8KK7X/XaSrxFfB3rDYT+t/+I QKE1kLZSm/h91wv+v/BKv7/bqvtf//1fw7/JODv8a5YeTIr11giTdaBpqnDX7vVf/7/3rccOG9LY bZf7JP//3F+IUw77/eDB2KUFDv/8RqFhhouMmOHLcPvt/oNP//YWGGEum9v1mGGG9f+r/dbaXBkc dw1rphh68Gix+2lYS6HCPAYJNkrDQSwNnfw238sd1Hf6+nDCRvDd/X/X2GuxTDBL+wbSTh9dvcJM fQMOnaYr+w2if2yVspbf9JfsM7Mwdf//v6/4oKvsEwrhhNeSd0kdhFDena64IJ/MMwKgZXcUvNiP aD4QJCGDEIESuKXD30F/YbCYSthkXRoiqp68UEDaVmjsovWEv1cJ1bDCwwmZynlw8K2sO4arvCCa 73RFqaBdpphU3QMkHw8IED93cN/EKutUE39JXt8OHyxw9BN+3b+qf2gkkG2GtK6Xp/tnZdaWtv3+ CHxBBIJsGDEIFCPbcI9hvbh+DDGIJkQfbww617tBdtpUn6f33sPrlj3lv/cL0qcNr7+/f4bhfTDX v7zSKCGfYVoIErYfu17XTB6owYYOmvtdhheuED7CS266FXH337f+x7FdrCfFfcsfDW12/7Ddp+1u /0SIDeCQTbdbFMQuSHfV7w48NbCXw0jWE6hPHsiDp+mH3WEphw5n4a3/aQb6St9oGmRYXx1bpbfh 4TTBe4NIG9gldrBoQYQ+/RoPBg0nKkKSUI+rSDDxW6/9r0tsK4IMINfDSNE//9+/aC2wlhBpnZ1+ ScGdiUkeIGHkx0eRhHRP9/YavBBZhlxQSDaaYvvbQeFbtPWStd/+16XYbSMOHp/29V++oa//tAwT 6XthBbclBbuTsmO/WDBsGFluDvg6EEZyGj6f9iKsQXYbgluE7dOH/hs7rv4IwT8Ne7X/66Sg36v7 /9q2lW3ZV2SF4L52XUsf/8L0nev//5gjA0DDDQQM44RePptNxlwD58ToGlfQazjNDccQQIGRfBQ0 krSX/tuG83oXI66dd+l9PqCBDp/q6UfEV/w8OGlEW7a4MPQciP7WOwmZ334SBtaVkO/r0EgbDcKG 7DvbXxwwwrwwsOvXQIN7sJqF/0mGw+Hht8xhh9/BpP//4QXhhU1X+kt6g2/07/3CRe4aV/+k6LHt Cwh/iCCBhhg7MbB7IRbmlSYMNaD4YMEFDDIgqHRyfahOVbiFFZLCK0f9BWG/uw3r7/7cF3LcOlfE dOF9w/6Ttr3t63614br/7/6rhw/4IE2wboKQg+IentAlq3IqqQaecH0RoNH/wdPsGwf9QhebWG7I ov2kt+QxBCDkFx7ZVeHSCu42uHa4Nhg/xQIYS709KhSq+IjYahtpLtIVkx3d7DBv8FjVw0D0CI/h AjtONP68GGKCaYroMHDCeyCKZB91/C/kqiiMO1HCRSkRwN/kDyetB1Loi7afbmcNlv5nd/3zMF8i QrDutIlQHhPRFcgpC3fGmRx9h7ex4bmv+bZURKESukQwuChuKwQIlIHgjD4R2IBcW1ERXBh4YNfS 0v9JOrOOc9IPUUwuoR2nAjmf5cw3tpccf+gldiOk/TIaw5Q5EyCKf53oGz/7h4YYV6r+EkEmHwQK 4UEdqpiG9Ts4aAx52Kv8G8wwYZNkCMMIhVUhdg99JBb0gn2Fx6C9f0u20EbbDCBBLrdb+k3XsFyD 7KV/Wl3aSthQgvyLsaSC4R1aSI1UPFsOovhornAx2wgQXh4XyKsEXYFt3CSqqWEw6dhdYr4oLoLD eoULpQ0lafpWMq1jX/hLqgw3qq/D0FdQlYTCQNvvOxd/hBYggQMMQQQYQ/knDqm8Vae7VPUwX4Sw k2kiGctIZ91/uGlbFIXh3XqgcnBEHvwtBBvTT/gwYsFBpA8MMMJIsf0w8Gjz4hYIIP//YbhsJA8w 7vSvS/frp0WP/+GxYavhhv8dP67CiFHyJGTP/mGGDDDBArsMG4IJJ+W/3VgoVcsPQf/bbIfT4bug r/+uNf//7bbMwX6tsKr+//X///cMQqy5GBWGawoIIvQ2KX/39f/0kDCv3ZCOEEFbD/te1///STC/ djhW21+vDvurX+IIEZKwx77BJdtNMMIeVdM4OZxtq2l/CQMltZ3StX4MEMVw91ewW0vnYutBD7pB hMOoQta7dbFMfxwgXQggQgwYhApDuFweDBhXaa/r6CB0mmuHsMEun/FerahhD3m9tJsNBhfhXYIE HUXlwHoMGGCCNsMGI/gqiFyx/hv20lsliNEVTNFfrq/LdKfsO7brsKg1h/mbluCbrLckBfwYdUEm 3hBbCp1/2PtcxMPqmG6S3t/+F6fpv4IJsUFuv/PPYJrCIg5x39hh58YNhKEcm4RyDf/xrghDf/oI N/b9//IKvyuUJW/0sJP///tMkNBlIyYZMRAmUjJhlI83EZGtkxECiYiBxAsgUQLIFEDyBY4oEH+E EtBMNewvH/u07uH3d9r9w9PTtNffxCCwkx2hV1/4dw4doO7vhw7g7uHcO7WH7vpRC42P9IsfBwcO HBwcHBwfBw4OHBwcHBwcHDg4MjHpWuEChSK9kIOE1/Svljhw4d3d3dw4d33d3DbtP38JU1tVIg6/ fcscPeWO5Y+Zw5Y7mcO5nDe7uHcGnDuHcO0//Sr2haH/TeGDwwdAwdAweGDwYPBg5cEWqGD5rDms HLsHNYOawc1hy4DlwDmgHNAc0A5oBzQDRbjfaiChp4OD/jfDeGHhtYeH2H9N4f2HsOrw3w9vh77d hvh7e2lrXV//6Yew9vYeG9g8Phh4b2H7ab4YfeG9h4b2Dww6YeH29tQ7rsK77/hBGDZFeXZgeYZg dmIMPMGXHmIMPMMuPBGgHZdlx4Izg/BFwKBFuMEaAeCNAPCPAPCM4eEZweDDww8GDzQuU4PlQDSe 1uCmgGi4HX9LY0ww9Nukww32Hww3qw9NvVh6DMF6urpt9t6bemGH7eXYbzDYdmIN5hw8Jt6bFF53 8eyvd//Strf2Hdt6t6t9hvtvsN/f23bq32G1Vh9vphh6d9huk77DerD02re18MNMJf/Xffw+odcP 4b9/Da4fw3+GsHw3pht7D+GH2G/Bh6hvUGH4YfYN9tQ7YYJeGGoSb/766+lTQX19L/99f/11/aXX ///91/3/8P8V4b1f/t0m0l4SvS3CXS9JdBLpfS/6XS9d/pLpL0ulvX0v+uuqzDYeCTfXwYM8KYMQ gsQgsQgThhIFiECwwggthBBYaCCwwQILwwQJhhBQwQQWwggWGCBBbQQW0EFhoILaBBNBoIF0EFtA gugnCSDWSf2GHhAjjYMf9wnCToLCWIS0sUsUsQgsUF4hEcRRJ4hLFJRSxQWKWISxSxXEJY1hoKOZ F01oP34S2SmMSf9BaCVdBKlhLCC0tLX0qSdBa2gtcJaWlhBdYSxRKA1ENXfb13pwd/mjCwQWCBYI LCBYIFggrBAsEFhArwgrBBWCBYIFQILBAsILCBYIFhAsEFhBYIE2o7B9BIWDDUJKQ4UH/tdLCC0s JaWlhLhYS9BaCVdJ0FhcILSwlaWEFhBaupNvtPYSTDFBLw7/1FPWgtBaVpdYS0E3hdKggtBaWgus JcKgloLSwgm1+HiEg2Evf+xwUQohRCiCiCiCiFEFEQUQmIUQUQogogohRBRCiFEFEJkV67M4eECJ sXNKEGWPmcH/eqpqmFVcmOFCrhVwuFXCf6w3pP+6vX6qFVQqqFCqqhQqqFVVUFtd3t4Sb/wQv9tM FCYKCgoUFBQtgoJhQUFBMFBS0gUKFBD1qDDiEyIPtdB/+EItO0wmmF7VU0wqapqFUL/MNg4RXVF9 rr/y3FWVyzhNNNf6h6Gtit79Dk3zy3Wc5gin/YYcE+wshdX9PLdSAx+31u//K08qF6/pd7CGr9gu g7+nYQQUGuI/h73e9qISu/+VC+Gu9aCuW/Oy3/BhBhLg087K2V1deCCmsNKMJ94el8sf3/WGH/Xu 4VzOGl6/hBbYV/8jHBsMngl2GHTGRYF0GvELDBggmxv062l0GGumn7Czc2CX/DB3Fe2r6Jv+tMN0 bmDOyxV8MHaXmGYGTaoUvvMiEEGH8LwwwgSsMJlxLrhtndpemGGEk4P6t+F/V0sP+Ymx1/dKw36T 9D6TDrVv/DDBhuF/ol7h5g9I2w2v0EEGDFAkv/b3X//3rd/iEE2lT/92KvwkW5YTdV/Svd6Tpct/ +ggn8Qgi3KgcMHCCC67aWvCCJsENf/9K14SCDYYoFhhbtV5V2En3/+0EFXcJBhvx2xS/tBP2v/DB PWCBBBg63sMJegcQUiD2K/9P4SREm3WN0jI0EI5Lw/9/4Sa6SQQbuWP4dBCPuF7X/BAnuIJAgYbd bQYr5bhwmsGEP4hV0rceSoI1+w/sf71STvi1a4bvr8Fw2U3Coba2iuob4MHBp3+FeO3uN+b25nDm jXekqq6Vrwmw9vj6wT0k36/YMPDBrb/8hNTS/evb21aX/afv/f+wwl//hoK20/9oEFmGbImxAoYf 76utu/9pLttI3MP8PK6n8P//xCC7bQSt/vQdF1DqGbFdGflutjHwQL20Fav4d380B4IW2t4QP6CK H6V197+8/7qeDK6YwnuEh6SYb11g+Qk0KDwZG3MNXCuEH4QWIIETaoYhAu8k71zH4b2rXT4hatqt dv/XNzdMh06CTp9YQQf/hg+tL0wwdHU7BAjZsGiMh8FhBBtJ/t7d4Iode6XpcOvYWgnmHf8MPbxj 1ct04npW3T4xUb/zBmB7e1tLv9aTrC9f77/uEtdvhbfCrf9sP4a4pIsf0w6CXvT/f3wwceCBLmge zQaBEVMpR//+/S39KPp+7/Kuu/r0lsVhBW1h1g4da3DVfWIILD4QTLdhhboseGQqqQq5q6eDljhy 3/9LqIW2DS37DBhuunTdR/wgtqtxp/Bg2Hr3sNX74IFldQg1CbIuk2K4OQxJaa7M4PDBhJ1/SpQo WSY+vlvkx7DXUMPDYLv4hYu1lOGB396Dwwl7ebg2gmH1hOHGygG61xsbFeDB6YYMII42H3r7rrhZ WU15vb7bSVv8LaeWOv6QQtbhMN+9d9ZZTDRETYaFK8EQqqQ6/BfYYPwlDarv7rkbX4QSBFfRd78K gw2kF/WUOobapW8JIf/EIIMMUC/48M7E3apKqCgunBAsEEDYVa78M7fU17+ix/BQivMDHiF0EH3v /aZRZOHvXvqEn6C0nX8P5cA0zYOp4MBhgwko2QzlpDRJZS2CBWCCkR/uH9Xp/1T376UQv63+G+Hw rUK679BBU/6g/wjQD5uD0RyJQ6BJ2nK/B+IUF/7+1t1B3bbUJGKyWIuKSQKEuFtfe/0ww/Bvh2kE k2GNA0Euv+XXJWD/sHKkIwb7IESLWEkCsMGEEEEVxwxsKGn8fDf9KC74YbYSr0kggWwr/r31uoWQ njbYYSbrVJBYw0W7/5OT3sIECChkPBY86A4Ypg6QIIEEEEQhLmsOo++YNhp7isiD26yMEwww0EEq UL2Hv17brwgSCD6GHDBONIIJX22Ff/g24egQSBZQDQbDgwRG2FCRjLsIIzmDyT6Bhk2qFb///W7G Gn0IuLYPTzcGDSMd/8JY2EF0GCK5rWvsPvTcJKG/dwggrQhQxBgk25Y98rmofg7sMNAocH6oQgum DJYHhxvTQYPv+v/rTTIYFjDgtrJXFLgwfDrW6pb4IFZb2oJxHdbsr4BjluHsIIIGDEIE+7S8Q173 a+3iEE3C6WgvDUKu7/DD6DDXtxBdjXw4P8MPBAgdf+V1NG7JGQ1v3/mIMPCv/hYIXhBlwVCPnW17 h09Jt6CtFj/wWEIiI/5oDRcM7SkK6gw4gmK/ULvvUJ2g91+t+tfrkWDOCF6/VP9vwZDWwgw601tR 3aBBQWv/ZAuObQgisvD4U30yxx++ISvf18hRot4iPW0GRB66V/78cMHpByVwMEPYIFBr+od4b1/+ pnDljv637Dwr0PQQW6TH7huW46y5mB4JEdwyKMniCmaXELBg6/w7H28IKww0774W2Ff90W9rTfQV sPTu/2Gv3kY4PHavr2Dbh27BZgzAybIEMbD/t39d/u7mS2MkGsK90kww/4YdbSSt0gt1dC8e2HCt h/oMPxBBYYMQgUscN5Y4b/WHQWvrDd4QVhuu/b/vCsOq/36VOu69/9IK2oV7zBGB7hAsG1wx4Yxy T8QQQMicF/2H4S3lj//vSB6r+/Fdpe1u6egnX99cFsV4YThhcHggg2ix9/wk9ftA00DC70F//BhJ db5BImWV4Avw4piuviECx/JSDlSB0+W4cKv+EvrVPXDdP/0F76d/TcL7+CC/0GEyvgJ4YP+vpKW5 P/k7Jj5OyY8r0F83hh3ffiF2mn0707pem3Drrwng69d/cIL0wYcGix3/hZXJRPXf/0F/mRClvSY7 9ZXUwXhv+v+F/xww/ryyyEQbiDDg0pnD4oFYoKEC9wQLDDCQf/w8N6Ub+qXsJcMML/9B7er1VUl4 hBbYSv/oinDww3SbaYQaYQS7CCy5BgwQRhhg/7oK8MGoXYQhhCgvQXtwrYd/+8xO2uEWlGXOn190 v/B9ScPsGDUECMEXFQaIq+EDAviC+m//f4b07wlsNht3wvCUNhIL96kdd+HqF8OH9bSQbFKvB8gn p9oL/gyFVCHkZ9gsQggYYQX74e/1sOkmGGH9YSevyMcPTtvoIJwwb1DYbWOggdf4Yd27eIQSg2IQ JuWOxdwQVot9/Dff4QW9Iu+DqRJRCv/8OpCu+9cOtv5ULun/+DB8kPDG+CBcOYfHGZLYaCPacI6p iv7mGG9XfiE7rwoSF6kiIFkCiYiBZAsgWQKJiIF0pA0QPIFECyBogWQPIFECyBX/VNtatt6V64SX rafdpw+06TQadpp3d3b//DDyuLhN24J2KwRCEhCrmt7hwcHDQODQcGg4NODhw0HDhwaBw4OHX/31 t+l9JBa8O7h3d3DuHdw24cO7h3B3/fCX78J/QUKXBQ5FH8w7uHDuHdw7u7h3Du4d3D1/qGEEFomP bBqx/k1smvOINHnq3M4OWOHM4OWOGzOHLcHLHBzOHLcHM4ctw5bg5hw5oBzDhzQDmcHM4OWODmcG i3DmgGEH/xQXu4++wmv9L28MPegw9ur2Ht7ew8MPbww+8N9qw98N7ew9uTHH/S93/xH91fDe+3t7 eGHh9h7ahvbww98N7eGHvsPbw3vYYaT38EC7DXm5UsiwaCWhn/UEoPDB4MHgyMOGDww8MPBg8GHg weGDwwdMPBg8MGoMHgw8GDwYPBg8GHgwdMGEEHr6W4j/frr6UPb28Nu2oYeGHw9h5hN7e3hvYeG+ 9tpvbq9h7DsP/8Jf3//7hIuZHFze3mHDzFeYYbzE3mJvMYbzE3w23MQbzBlwhuYebg3mHbmIMPMT DsxBh5hvZdhh5ivMQbzDYhGG/5Dil+Df//UIEoY0DMFhMwPTBh6YYPCYYPhhh6DDD0GDD4YMPQYY 1DoMMOwmGD4ZgtMMHww2kmGH2DB6YYfDBg9MMHph7b/+QhcPT5ZGTIv+k4fb8N937fv23qG/vtv3 32639hrYf229vVvw3232/h7/1tmZGMJ98sf799r1vv/7+/v4f/38N+++H9+g/vq2v+//h//fb/BP aEdTQHaTf71DBCsMHhaCW0EtpLcJbS9AluEuknoElcLguEr18Eugu0EvXcJbhLoEnpKqC0l+F+uw /j/uPYNpaXaS6S6QW4S6S3S2kukndQ0rSVNBLardBdVuEFwgltJdJbhLpejIavwlt/bpJ//cGxCI sQ0EFikuEFiEsUFYpbCSxCStILEKKJO2EEsUFiEnYSWHCTilililhoJY1YhEY7tf/uyH1WDB2CVt 4RQ/ZCwFg6BYhBYIE4hJQgnBBUCBYhAsEFiCC0SiEFiCCwQKwQJTw7EIEoQLCCwgWIQLBAsEExGG RlH+3Jl+Ybev/0013C0FpaCcJaWgsJaC0FhLQWgtLQWtBJwgsILCWgsJaCf/7Y/YYeEQdw8L2rQ7 1hLQWElhYQWugtLC6CcLpYSwk6C0tLS0FhdLSf/va9hvBEW2GDZFiLDCjtpYQUQohRCwgogsEFgg VhAsECUIFhAsILCCwQKwQLBBYQLBAsIFEFggW/720vD8LuKit1iFUKohVFRUQoqKiohRCiopCoqO IVRT/4e2l0F//K8D46hUwqhQqqqhVVQmFTCqoSIUf/h7aXQS4PhBhBhAiGCzUFCgoKFBMKCYKFBQ oUFCgoUFCgoKEERYGwX4e2EtpBYbDSCYJoJq1UKqhcKFUJpqCqFwoUKqpAsf3tpYpOGGISJbgy18 +01CYVQVVCqoT1TCeqahMILf5GODtkSgWCBYPCJVmmVJmeCD3LdaMmxMQwwwf99itcOmE01TkWbd pvtv+GHtYQXf3cOEH6uC7/hg8GCiFtoselaXCbxh//28MFC2/SenV8pFDh0gr+CO4dhgq2K88nSP IN0+g0W7DdpV8IMwPGC6qgg26T++HgwYMRCv+w9hff+n/3ttV/Du//1f/3sMP/0lHfbQ3Qr+YcHg jwGyY//hL6qOP9Q3phuP+wksrrd/T9dt6dyY/+IQLsk7u2RHCkSAWvQMH4MND/hJtB3rhoQwhbr7 +l/oL4f0Gge18Edw/CQT/gglYUH32g7C+EwYPDCBIERBybh/0vvT/kLa/D4oIILb/EL75Y/9j9d0 oWw/wREgfmsHpMX4YXuuECS/9BP23Sfpr3CCwgm+v0n7a/7C9hJKkw2kvswmRcD8I8A8mBfx8QgT EEDDEIF9Qgm/TDD1I7YdZXv8JUG6/0DddvhAk2xVP0FTr/CCKcr7DD0FsGRJmO5FWbggoINr/Sb+ vr1QPh616/6/0u+uQoW2HsQrblj18HYb+ECCwZFdIJJuDZBwvChsU7+yMSv4pO2IQVdhh8K/v3dX 6Sh6SZnUsdgw97f/B6t+ECwb/bww2QXKYzODJsDta3D/7CC20/4uWO/DDv7Lr30QyeqS//BVDfto PWO8jsPVNviFtosdR0ng/hg4jk9fbQ074XFb3/7f/Ybd91vvsi2sLlJ7dfww00G3wXWwqBhDFaDz BgwbLXG/zeGGlvtfhoeuHq39LQbHfjviML73K42yS/31BkY9brrOxbCIIC4OsJFcGYTOMjZggzj/ b8dve/aC5nD2kru+7/rqn/ep2ZIEF7eGkvu//TtBEnraRSPXxgvBg8QgX13/vaV5EH/eu8L3sJU/ Vf/EILoP8N76hew6QT17VX/BAtXvh8w7xgvMMGDwQIWhFoa/pfbVw1XzspVem3G0N/0ul6mhv+Ez eP7wrPIjo1oi+XzVkd/0IK9U/DBqkGNUQklsgYF/8Iri4HgUfhSQ7/9vS17+glCCXqn7/2HhLrX3 SwX8Ji03rzDMDwUEVDpt/EIJhAiGNlZS4v2diXUff2G9BBBhvmj+gkwiHNgf8F1XfDwksH+V4M4X YSuC+PH/YPoF3/v6CgwRFNgL9/6C3f6+/hBQ0F/qv0qbemP/ipna39pehCCwyJ4L9bgsMGVzWBAq /Ix9dhBYdJr+q27QX92l6C7000v1sNa6UiKIYS9hAsicoivjgwzIFVpfuwZMcF+gXev5uDYtBBfh 4jXH+v6cOvtww2vBbaLHgteoNigvyKO264WxXIx2vfpfqHa9fhWPKT9JfuDDbSwwW1pVp4aCCMlU oX7DDYNcf4T94hK1/tsMJe/VcPS0v5czA2K/4IGFweCBa/9htdr0N3oLr+rtZMf9ct3oLr/uRAY0 DSTx8MHEJpL+6gwXdf0G6Ff1hBEaXa+W6kBj2HX+z4pJmPM4Nhosd6dZcwwbCK5rJf4X7fvv+3V1 /CSfsPSj77D6f/BAq8MNVdE6/foPr8V+GHhK/rrh/+vze3QS/9wgtr/BfoGYLBBGDMCtfQggpY4M V/Cf9h6XD+9Lh/6X9+vt/ScN/5Zb/S6617CBKDBr//pLh//hLb//7QSww3hfxCw3//xCCwbEIK6q Cy5sHX/8IKg2lrf4b//6W/a8Lt/8P7CBNtqwZsLQ9L/v4rb4q/QX+/her+0l/g94TsjeGF4ggv9/ X4YXhL/D+F+wXoL/I3B+NtY5J1hAv9Bv9/Tisli/bf/8Osf6KcG+TG/dQbC/4TDfp6/cL/SbD7v6 5bh1/uwb0oen+GHX//bh9/hu//S9X/dQ4f87C/cIF80Bw0W4urLswLD7/hoL3sOkn9MNw+uOKC6w 3/fvb/wgvwYOykHluqETra9F2Gn/QXebm9J88PTa9h/8JfpsPCRhtqg/wuG3/EL+ww8IErIRuWU/ EIE4MGZKVX4X+H0FfCXwgsw7v/X+v/C/CWoYad/gv2ggsMi2qqXj8IF2//pyuUn7QS2G0gS/6XXr +Fr4oLDiEtfiFurT/1usEFkDfVfCtoIEP/b/SduvfqhCS/9/CS+6rsLQX/w2vC21v6pUv/23EFui x+vi4QRkSl/h+lXH+leEF/77667wvpJ/4PBvZzZ9cQq4hf//P/v/1v+H+mO+1WSdT/5G4O21v8NQ tNgoXfw3vr9tDw03/97fRrnXHvH/gw6b0obp/Bwf/YfHw/qpbu/+YYb9bW7LdTR5HK9uzJL+vhWD sPUHzOMIhlC3Bg5oBp9/bD980PX/vbT6/5/ql4fv1girD2/v7SSB5IegsGHhLa9AwYPDBtf9wgr0 38MPXLdaK/fBFWHX/Fb9j28JPf38Nt/+ECBvV7LmDDwQRhsMN/XhMGGPXwSvS+2HoLYd+0l/ldQr /V6Ve+knaf4S/x/EEDegn9evCD8GCtpL/T+/SC2G1QX0qcIL/BN6TW0uw+pFHfpYhf9MPSYWIQLB hnBQggw/CBYQL/C9IcEsPST8VaC/wm9LhGVS29BfVJf6DGlggjIMGMng+EgYewWCBf+OKCena19R X+nhBA/e6+FC/2wiVB4IIgkA1SkUfCD4wv+0CIbFy6RCH/XT9f/CDhBAgbBa+vf/BhggRFQGIRKo vAwVWqEdevboEw639/JPvvw6oNpPdflupF3D/wbQIIpCK+iScMMNLvIZQtQcP/Ix6rqrv137cw7/ 7DqEG01HfX9Pb/4YYhJhwcJt6TWuDwwf9wYaXDo1Ju+3Hljh4Yf/hoILqEG9cz/w+3/y5mBpTu5b g0odv7H4MHgjQD/rsP/tK/TX9hqrf77DpD4Yefdu/X5iDb23+v0m8GDCRtIHMP7QRHQLluFhlemw er//XzsC6N7aSobd2mEn/TD7//aqrT0ww/238JF22VzX/dvoJf8QQJJ0Hwww0hk3t53RPQIErBjJ P+ksQgjJSf9wl7fvW2+EG/VtlutifSWEEn/0qKDOIwjDdv213d7jS0/3CC0v/YQJQRDNOwwd0CCS w/cG4YbUIIF4hBYQJr94S0HhuqSX9W9vpfS0vfUQv4eKC3DV8Ogw2ggkF4SiEOvhZIjwEYMHggtx 3O0CsINikEF4QKF/qyBC96CofbcN4S2IVfuE44YeEuvYIPpfC/UvaA8MOILHBsbVAuCYRXNS//hu urfCXWZE///vXnZqjGbDEivXpMb/5BRDgF6DDglKsOpqiOKRzI4E9KE8YNf+CGUAQrbVGsNkREQ3 5DKFv/9I8BjbhKsgeCgd1/Df/bYJog4wgeGMiChJDd/mcGwv8MloGDAlSGeHmQIDbIEakCiCi918 k1hsf+yDBFkECDUyFsjgrjIfCIOQwV/+Ht7+DFsgaQo7TxFQPBpRLZwSuPDwYP/DdNEY5hyDPZDR aTpJBJ/ew/9tdOyGYOVURSlWiB4ETfBa6ebmzILv8lANAhSERGQ+wgMMhtBUJHdgun8HhMGGg/+3 6Vk07Shfy3f//2HpIKWOGOlImygzjrb/9fgwaBhBSWxpBhtgkKveDB7QSar3m4N2r4bbSS/Ye0gm rf62w19hthIL+CO7xUf9oMGGGQogIcEW4NhkGDhBN+EwYPBAv/vBkMPq2G0EFLt/30Fr+kgxV23D PxjCQQWwe9t4S3+0CCBheDDDERBBAk71pLCBfrGgwXpMhlyW15blkaz+kor/QJHaA2dKwTDri/cJ V+9AhoMIIEdmYwyJCgvwYUF/wlYhIQ2ISv4Va+0F0HSrwSa38QsECBvLdKZ97hAk/8LCTa98Qr/1 oL+uoevgohOi3/woPfwqjX+FMO/9Qq/6w3/2E7r44YP/i0q/hv/nrcL+3/1fVfMMMH/87DRGkTNN YT/th/9MkRApNMgVZA8mIgeQKIxERkCiBZA8geQPIGiB5M0On5J2of/3DQOHBoNA0HBoNBoGg7QO Gg0GEGgykYQZSMq0oREcVw//0qw+Hd3DuHadw9O7h3DuGnpffX+3tOGndw7h3DuHcOHDu4dw7Xpr vcIL+sz2DZhwcHBwcw4cODhyxw5DnMOGixwcHDmHByFLg4cHBwYQfCDXB4ggv/vM725buZ3eG5nD lvljh7ct6sPuaHLHD3mdzDuZw5h3LdzDtDphczh6X/XVh7ew9hy4D4e3sHhvYew9vDD2Ht2we3sP fDDq8NrQ+3pP9imDc+NQYPPlgw8MHgw8GDww8MHhg8MHgwbhg8MPBg6Bh4MNQweDB4Ydgw8MGidx 8GHhAv6Wr7D29h4b2Ht4b28N4b2Hh8MPbsN7DwfYeG9h4br9h4SMltf6g9huHwR3Dw+GHhvDD28M Pb28N7B7eGHUPDew9vh0G9hhIP4biEE/0EEbMwHLkGDUuQYPBMMHmDBg8uYMHmDBg8wwYPLmDB5c wYeXIwELkYCGDBhqXMMPMEYHl2DB5gzA8uYMHmGGHmDMDzDMDzBgweYYYow3LcLDK8uYYOCh37St 8N+34b079+77fth+3779+3fem/sPu3UMP2/DD7h9tXf+3//V99X9/f/w+v76374dNvw9Yf71D+32 /Yb038Pahpf+3hd/2vS6S9LpL16S6+q3r/Wq/+vr/2lr6r+/r//pJhU39ugrhBbr4QW/6XpbpeEu v1pXS9LoJbr4QW0EvS8JdL0u6b/9JJsJ/TDcIivaV2kFtL0EFtILoJeEuktwgtoK4WkvCXXtILdL 13CXS7oL0FbS1RNrP3CWP7DDBgsGCUQQTiECz4uIILEILPjxCBYMLEIlEQiURBBZ8eZjcQQWZjxC BYhAsQQLEEFiCBYgiNwxUm01qIQUG/+tLQShLQWlhBdYXhYSwlhBdYSVBaWEtLS0FrpNqnugrK5q d/urSwulhLCC0sJaC0tLS0nCXWlhBaCwlpYSoIKkm1C6hKHf+W+FggWECcECwgWCBYQLBAsECwQW CBYIFhBKCBYIFggsILBBYQLBEhEILBAsECbUF8IKZw02H/dYqIUVEKKioqKiFpaUVpaUQtLSwlpR XWEmMLsQsN+v/YTUKuFUKohRChMQohVEKIKKioUVwnC9bD3/xUKChQUFCgoUFCYUFChMKFTBQUFB RCZKJbrYfgsMOm3+1CqFwVVCahQqqFUKFVVTTWEF1girDe//UJqCeFCahNbUJqFVQqpqEGsILhaD be/7RaBiERwQLFUwYYh/7jglv9/6Tgv9v+TdZRXMqoL2gkZLJsP1ivC9pBW37ybUXweSdiEtv+ED TeD7wgqYf+/DB8PQW3+y3KjhpqG+9IMJ/wZbiYYuWOMGQcrw4ghDB/tE7y3DrBvmHD2H+02+1cMP 24Tf4MFDeDBrgw9QYOEGQpso+Rjhq3tpYb9uEGD9bdeGwk7+G9kDwQcgYcgQuLd4MGECDeXIwQJF 2GGTbLy5hg8riwHgs+thpX8MJLDa/bhhv+G4T+HQVtj9t2VykDwN/5dhg0m/4XZblYZX1UGW5QiC v/bq/pXpX/zDyuCS3/Vtd6SDbVftBLDDK4mrPoIM+v+9Qm8QQQZF4jbhfxCBYYYQYQYQMgZJhB// yjq8JOv4QWGH/3f76Sh+qCBvk+J53XtP/69YggSkm4YbcIItzLfp38IEZGfmGYG1/9+8JMNfVBAg bf/6Sft7XvVf0rVXigT0WP6+IXphtqgwmFCYV/wQJu5BC7YQIGxX/cKvcQ0IiNetBNpfCREgP++q rdR/xVr9K21/XCH0oZgX3CDaBSY5Q8+OxQIG/6vHEEEiDder6vx03QTbX/4S/wm1rC6Qb/v9BfqW UA0lSTtQbf687E/CBMnZOPvdLeSdv3/+3hTIImFv/D13T5mkm1/8YhCN/+GEvp9A0g2n/5J0Edi6 /+xRXJpLrf/8WuHQp/9r/7hqRHaeHHuv/uvVvoOijCTepNvuDhErkW4/7S9/w6Td5nZHa906T/2v f+W78X375ndj3+DaO1lX1b7gwy3FWiCdtKP8MHDBJ/w+/XG+HUH2v+3a/7rS4vUG1jwl/hhwwk3+ Dx96zEGDSTsjil4N/mIMOZwwQRggwfq87Sl+roN+HFJsP+2HsOC79yMcP73f4fDhXf6h9v/+GHQv kgtcG+TglBDQ4XDLcrDL+28GHDqF/Bu3sGF+ku4P9f6Wwww9L/D7I5j7hf+G1X9Lm8NsWgv4I0A0 trxCBa8nCZB3oF+IQK0GGDBj/pt+PpftBhYq/rq4Nf1Dv+l/jJxSLdbR5GC8ILt7/3e5OGdJwgVO 7WDeIv4QLaCTX+q7T8Jeou3/pdJSxyY//r/6C3/X4hbSUR/xCBLZIDCxCxfeWP+qEEEv8LtlOPr+ K/hYSCf9BePX7/1oIL/BAt1YJv2trgrCBAiK5Jw/6X473W+MUEth/iFt19ePUF3+FV07W/kboX/4 W2t3/8KHVfr/IHa/bQbdBfgt0iic6Bou8riq0yhkxExEwykiYiBRSMmIgUpriYiBRMRAomIgUTET DJiJiBgxCC/C21TwqS/renw0Hpw07u07u07u4bl9f/feC9/9wdw7uG3doO4dw7h3Du7DEV/7Sg+t dLRY7hw4OHBwcODhwdohAYODg0Dg4OHBwcNv/uldsgvrmcaXvDu4dtw7h2w7u7u7u7hshB//bSlj vH3S/uYdy3DuYcNEx2jO5Y4czu7Zh8w7ljuZ3LHDmdyx3M4csdzDhyx3Vf9sKkDB3S5brQmlc1g1 DB4Yc1h4Ybhg7DDww8MHLgNE4DwYPDB4YPDDwYeGHhg9h0DB4YdBg0P/2ldutYIHq3bew9tWHhum 9h4b29h0w9h4b29h7eGHt4YfeGHtr/+sMPwuurahh4fYbt2w9h4b2Hhh4bcN7ew8MPbww99vbsMP fDa/g1DBggnLsuK2pcYI8MIPIMUvMjhBHcPCPAPBGcHhGcHQI0B6KgPBGgHgjQDsEZw8EZwahg8E W4PCPAeEZw8EaAbmMMHgjwDpFQDwjwHgjQHgjQDwRnIIOSd/vO1hMMEtMN8abaeEriwmG3TYemG8 K32GGoQYb026TbpMN6bGYbGrem3hW+21QbemGHYQYb02Hpt+3phr/w8Yqth8JOHI+8JMOrDVMN9t 9sPhvqw9WHe2qt+HTfvTDfsPTDfhvtulYfhv29MMPVrf8Hh7w7cFsMIEdD0Fg9hv2/Bh3h9WH4b8 P2Dd4Yem+Hwb8N6hvw3q3q3eG9MN6hh9t+H7/7f9p9bfetb6+l/ur/6+rWv//6/+v+7/+tf9f9/k Y4eGQkfCVp9V9tBcJfXr/1XhLf6CXpbW66W6+luluvQS3S6S3S6W8LX/DDKsGBh4MIECbRKAbQQK m8GDoERHhoILYQILDCCBUGECBbQIFhoIFsIECw0EFgwggtoFaCuCC2ECBYYQQWIILDQQLEIKgwgg tggQWIQW0CBJCEwwkF/YYIPxSh4Nil+2MJIQkohLEJJiljSiEsQuKCxCCxCIo8QiN4pYpYgl1iEF pYggsasEFirhEbsV/hsL4SbSbX8G0CeFoLQWEsJaSoLC6WlaWgsJaCwlpYS6wgutBdWl/BGgGCIT wdYQIMMJEN++HQSZgbggsEE4IFhBYQJwQLCBYQLBAqBAsEFoLCBYIFggWCBWCBYILBBYILBAgbC/ 026lx9Jun/t90lhaXWEFrpYSwloLSdLCBa6TrpaWgtLQWErX/YbQVN+gmGF0WP17rQThLQVAlpWE FpcK0tJisJR4S0lCC0sJa4QLW0mQg7/qGwghDD4hAwycJf38cQohRCiCiCiCiFEFEFEFBIQUFIgQ QUQUQUQUQUQogoggwq/6wvqGXDEV6W9QmqqoXVQmqqmqqFUKqv+0l/CDG/fVVUKoVNQqhcKFUKoU Kqquv7QIEEgw9ggwTWwYJWHDBQUEwUEGcCBMEwTCgoKCYKCgoJgmCYKCYJ7/iF3xYVb10W62y30V Ctf0EndBhPv14jd93BBQi7fH3hbUP/8LQf+9Y2tfwlG3+493fWISt5TmnluFsbKuQNFu6/Cz5/rw ykdcmOHTH+tA/h3wyBfDw6v+CUEHfBp8h1Rw3DBhK/wXb9k2elj+6h7DX+un8sdrTGGHd4IzsFI8 3/Sv8GD1y3JQTmgPCYMGCBIMMH95Iev7D0sMOth+8Lvvod/h7CvDvDa/X/0P8EaAaQIIxNy3B+GD 6WH/XZG5EH/hYeFth7fmJvcJBh1C/2xv+G9BK3g/2w3aQTDCX4N5EH/pt8Fw/9MG6EIIHCC/fHf0 l31gl/2Egb/w//dLb6wv/oLr8HTrWGggWGDYSBRBe0CCiCbRY7//+IS2xCSC+kqit/JDh/XoLDeg XiEqfX4YevdBBYbUt1ME9AoTVfww7/sILeYegvBBQv/tt6+l/pV1Xb/BGcG2YDK+ILY+RVjEF//s MPa/64XX/9N22q4W/Cuofr+wbBhkMVcdrHgi3E1DTr/StjVfk276GHLH2/9WGvtZbqQGMZh6V0vw wgQJtL/T7MEkxb/FJhr//UPf+k2Ev/8Gwlr8IIMVZGWnyWFELsEeAZNgxTCb/hBBpJPvoRyrtNtJ Btv9J+Hr/6thJNh/iCBguG6H8HVhuC7/QYLh8scsf9//reEDJDguWP6Y/h+sPrrCEfBg//mHDwwg gQMiOCCCfzN1L3r/hvEJHd4cUF/JT+GHhJv+9IQ9f0H5dmB4JAio/gweCBBtP+v23hJNv9h4S0WP 7/6t6CTh0+Yg3EJvr//hh6CthtLoMGHCYq///XXj9t1/+vcJcOq+npr/Dfw0EEoYNpEm4WQMC3cJ QX/tfFJw2IVP6Vr/w/0Ft1v0EEv9YP8EFg2uuIQUP/3+glf/QUP+9v4Sd+Scqi8JWn3WSgHD4gu0 WO6EXwgoaLd/9h11x/xCljh7H3w9dbVfWG66+DBrsLr1gqDBgk/XMOH47/1sNf/YN/1/CwR4YK/9 WH+/46DDBhAjZhkVcjfbf/v9Q6S3/pL/6++F/+gl5EenV+lsP7+0EF6D/+yOYIJhtQv4pNdqnbXt Uww0Ev4QK+Hp0LlWdCCCBxQXXCXw+WPy3Wh96Qb++gtbffBEHLfhBOv4hfLgH1GZQggfBxCDaLH/ r9vWxT4cK//C+mHhf5oddf4X4MPBBOiOj8MHCY+vC+y5hvCRidIN+3Crvwv+HpJsHCf2HX//1BvC BWwa35hmBv//9//p/sNr///Xb63X7v/++0EC2DYSBVvq8HD/+uISwbFBf7ra//9Ltf+quW4/w/wQ JSTa3+IIFNYNJ/3/X+vpdr94fWCCd//CWGGl9YfsQu0WPbS8ECsI9gwSb/d8Lj9fqk7Ckdt94f/7 DS4q7YaBJsPrJQHXMbThrYrgklDhAu/4Yfj1/Cf//7eu+11urD/+DD/rDC2FsIIEGDBhIF/MNg9/ waxsQobEJd+G3r+yal0E9f8G/Je08egQIG1/e999/039awl8P8t0oH8IJuYf74QILpBqE8t1MC+V biFFffFL4by3/2VyVQn+ul3LHf+va9ffCBPuDD6jS4MWCf64X+GoXkVY3//QS6ht1dAqmdr73iCb pwRbg8EEXnq8MHDT19fqw8ErYf4bu/9f4b6Vh/tw5h/+C/tvQVw/zEGDljhqxf4XfVf/8MMPYdP+ F94S3qv9vbXf/RHSQaCCwyK6RG3Bf4bwYYS//jiltil//DCT/33QWHVv8JUCNDCmE3//BAsG1kMo W4hAsJsGCBAg2D//hd9/S8Ogu1/6oL5nv4S969/D9ijILXa7+ECtwkwb0vv4JLY8P4S6CTbwv39C 9KGQg69KmqDDEJfg+mCUg07iPEFiCCJsINBfvxxaybeuFpP/h/+g+rCCb/yOAffSrwogm0/7b//j XMP/t/d/06/8GDvIN0rT8KK/5vYa9939V/wgw2/etawn/+GH1B92W6lm4jsvq5J/5KF/6+9Fv0Ii PT08f+vzOG9Rr3D6/0EF+GGv/Bwczj/QYSX7Dwr/d9/sQgvw3pOyXH73av/CBd4I0A7IwUvOIh+a AcuAaX/X9b0uD/Yew1/4QX3gw9Arv8N7pP7iC+k3tJMN/gw6CNAMm2gphMP1X+vf/mJh2naQQbf6 /aSpt6/tvUMMIK79yMXfYhAnDIg4QQX8MGH4bQLb/C/S3FBf71pN1//wgsG1H8L6sN6/X4IFh1Ld VMzfcEEFYggQMi8Rr673+u+oQfQhBUk6//iEvqv1oIG//8LZFekg/BArBAg3MP//C/78JaXH/+t9 Al9BRTosf+/YKmvk78QUFFf78f1X+v/D/rrfhVX+D+2l/2CYJr/3k2r6Tfr6/rw/T/78U778jgHW QlB9/Xwd/9v79e1XtFj/+38Nvvel4dX+8GD6Qb6+EgvLHD3/WYbDb79Fv2NLJPw3//TDfcscP+/q 0+GZpY/+GGvhg2+mNqqg8GGIJP/3/Db68JrvDYSb/6X7eoVwaHujDYYSMb/2ggn8uzA3wSI82PNA O0wwwQIINkRc/7CCT/bDvCChsP7967/igmvUNt6S2d/eGH/Vf8ECH97zGif4cLwYPaSYMPC/rW61 3D87mvb3CTD0F/CC/QV6BsPhBBfmG3ikDYpV4gjpeIQT6QMNiCEfhhg8ECBsJe6XhhBP1Ffh9J/9 d2lcUH7/QTfeoJuohPLHQP1QQUQTosf+FfR2TVsb90l//q/+pb+g0EoUf/yB/DFv/2FCYV/++RR3 0h/CYXVfteEw/C+Et+/htPhF2YG25rFI4PxBKt/3X7hvhKSHDIqi39cKH17e6K5QvUG70nYePV3+ rekH/xUFbY8KDRY7utw26/f76thXT1fttf9BNN1WMscP7rSB2la4hBOGDEIkbBSwbWO979+EttfD DCX+Hav6CcG1+Gr15G4MNwmG56wQLDr5cy4ybBil2/3DdrHeu/+2Etg/7bpPcQu5n5J/YbhJt/UG Db34JhN+W+LQeroLv7mGw216qo8rmqHumlvr6pt3XtC+PD9JhtV+8GG9OlBNZNjq4eIQRNqiEIFf re0ux8Wpbh2Em0v/t71X96CDf+3BBNhX2taBh4IEG1+00l+o/bD95h9fFJuv7w2xC/v4IExT/5cw waCLcbUf+0n/+24Q/+kqdeqw3TX+IJ7r/2FXXp/JsZf+lX34TV6f3QST/8KozUvfEIKDv/T8O/0t evLblv/oIKHLHf/qDTzLRJ2EFM4OmO/1a41oJtv//Dlj/ilb7r4MJFuDSv4LBhgk9/96j6phgk/8 Ip1sNX6zcG0n+ojhgwr46YYMEEYJg/sPBHhhf90u66em2W6wggi7b7TeF99h6YMGIQVshDYr7SsN qvw/eFbfVBJhulV7/Sr7dJuoXWScPaCTD4TlW8GCBhiEv7D9BQ8Jd6Qdf7e6QNsKEt6T9+wYPBgg wxCTweCBBuYf/bwkH07iFr/o3MPQQdXv/r4TBhxCuWPSmsOCiv/huuvth01/v6b99thf33WEx60i oB7Xf3CCarfCbap/8ahevYbh31XBAha/sMODX/hf/buZ3/0E1/pe//BAh/oEFNYNY/xX2GEEFsP/ wvoa2wk9+F+CBWDBgk3+F+uYmwkYm69fYQWmw0Et/gizkn8QuwcIJNh/0/hen9//66rqv5Nvd+wW 0CCDBh0C79p/W1QbFL/D/axCQbW68NFj/HCCBtL/dX+EE31+WOGv/TzD/weGHTHxBa/7ww18k+or /D2wr6cL/w8EaAYIIxt8G01/h6bDCSbD4cL/yMd6YbStv//0DDfdBXD4NP/3DV1Ik/yuSrlu4af/ DfWEQrcbdUPhh//wRbg8QRICBmtBkRwggXhhwczv/q3hIIPcUF4bljh7/9WHpBEHhiDf5tMPDfH3 7D4IJEdQMHXwgYYeGDBJ+u18KEH1f29tf/hLCCSDd/4fDDCTffDQQTFIJhtzPT8JZcwYYIIw2H/F BQldj66SK/ouvbQS3/SpI1GG/vYSQ/dpW3/BAjvwzwSQQdtdYggh1+v+FCBjV3/hBbVW9f0EE0re u+toJBt0F+ISIY4MLLhttfQIFiEEDBiEvwgiEqD/sfiiuMThBNpfpEZd/t/QIEPQf/BBIMNWw278 EOCBBuYf+EgTffrtRTr/9+/6qF+vwgTnYi7bb2yNVRW/pBaeG9y3SJ+4X/972PTVJaav+CRImGw9 u0+7JETETFCa//b2drVt/+qDh61/XsNq79/wfcO87K/9hBQ3YODzRBha+nDg4O08V8Pfe+DXXdFj 7h3D/9w9thw6hpcsd673Ld3czvfwamYcjouWw5Y4fISFnfmlHpQ5cA8MNE4DmcGrH/lxLhmuGHhh 2GK73rfDew9h7a61h4rb7e1t12CUPYe24b2HW95G4PaySokAuGHgwbgwthgr4JAjuHgjQHhHgHQI 9g8GDBJ1+3kgC+S0G1vMbeDWwyoSvpBMMH3dBNvTtTEGwUjzf9tSnHkaA49NhthkQ9xCRHd4S2NQ w+27TDbq2grYf8GDhB8uyOB4OXBOGDDYZIBfBgwQKwyIbFeCsHsN+G/b4YbCBJsN/gjuGCOPNYSI ivcFBduFd/r1//+l6/TDoeiB4Ycp1/MOwS4a/3rr69f7//Chg8FkGQTBPQSV0QIIUG3ULBkWARgQ u2ECBWGECBUGgQLYQSDBtIE/7e+QynMpJWkFh2QSqCOODYdILbGFiuKCxSxSYYaSX/3UguaEGNkk Qk4gzhJWw1wwxSw8LCCpcJaQbFJ/tBJEh5EBQiVm3ZD7W4QVikYA8GoGwkyHGNBYQWCBYIJQgQNr /dBbRQjAEYwWEuMP3a6WEtBOEvX4pKKF8nIegm9/6wlwsLoINq/wQQaaSGIJsjWEQPBu+0WPJstM IhruQZlwIQnmHr8IIlKhsIJVaIHiBE3XkgDwVK1/6Q4MjL2E2yEHJQXuwo/TOwtEyRGlkYor/EEG DEJUw4QiCBP6ZriYiYgmTDQYWTHpkwyYiBRMRAomIgUTETETD3/TpQTDQR3qDHuq36rcJO/Tu7VU 9r/CtKrCQQJrVk+JVkyZMmSzarf46p369//+EGRBpCGQQhHc0XDFftJ3hFD7VNNU0008Jqmqap2r /6ZDqAgxSEJ/kDwZNd33/59d9r2qbVfggwYSqCa/9e7TtNMb0+9ext/hiEW5AGJNcDuwkWO0WO5n aLHaLHzO0THot8sfaLeix2i3ot2i3pyx2ix3M7NAYX7QYIVV0vb3X216uvdEx9ddf1zO6f/C/wYQ MEQpGQKsKGQahyKchxyJBTnHIcckIvX9N/v/dXV9q33V9q/pNq//O0AXERybBQOGSsnNBop2GCKc w6TDCTYStJsJNpWk2FsLaThW0nCthJwraTYJXTaVydP8GQXaALpNpWCTasMLYWGrDC2lYWGFhqww k2FYaVrDSbWGthK1YYXCsOF/zyOw0YybGa6qyOgthYYShhJhpYJQ1hhbCthWKY2DCVhJhhKwWGEr CTDWGFwrDSv/0EGIjyYNFzDEQi5lxQQIwRHEBBFzDBggjBsGCRcy4oIIwZcU4KYMuKcELmXFOBCO YZEsEYbCLkRw5c2DBIjkXGeELmwYIIwZgYIIw2ROCMGXFBBGGyJwRcwwZwIXYZH4IwbIvIuwxZh7 +/6thW2uGGEFYYaVhhhBYYaC20rDDQWw0Ct1Ta2tsILYNBWGGElhwlDYS2GgkwbCVsNBJsNcNhAk 2l+vkiIGiBRA8gWQOJiIFECRA4p4jM0ynyB5AsgeRpEDRA8gUQPIF+vWGHC2K3hcQldUwxXHYddt Arb7sN1vStoLDpW2gsHS7QWGKw2grYrD/304NA4NBoHDhwwgcNBoOkDQaBoMINA0HDhoP66+t+/D 7tVW1TsLf0trYhbpP1vW/6WHrZIcJt6wyQ6///w7h3cO7u7G4dw4d3adkH+33pQ8IiDukFdBEV3h bdEV3oiu8LDpJtp/pEUcHq30w8K20kw9W2glDwlDpK6CUP/WvcPvh3cNh3dmaNq7u7uHDuGg/eob STdQgw3SYdIJt0E20kw6oNugmG4QTD02raCCbdJhtBJtpKHpB3CTdJBtpBBugrDpJtoK/30WPg4O YcHBw4ODhwcOGgYjBw4OHDg4cODhp+wxBEoBiECBgwQQMMQQIGGIQIkEeGDIuEaAYIkQGeGDDOCg wYQYhBiECKBnhQYYhAgYMQRGgGIIEDBiESQRfBAwYggQMGIIjQDBAgYMQRG8f/tzQ5Y7w3M4ct3M O7mcNEx3M4bM4cmOHLHcscOZ3LHDljhzO5Y7mHDuGh90HCCDwnQQbSegeg6TdB6DojhhEcUnhBtB PQdBOkHQQfbQQeg6Cv/pfaTD4e3w1blu96b21bab29vb29vb2Hh5bhzRXem6DpBvdBBuE6QenoN0 8IPCbhNpBtIHhBug3CDaQdBB8OgQev/FPgw8GDwbwweDDwYPDB4MG4YPBg8MGoYPBh4YPBh4MHgw 8GDwweDB0GHhgwid88gwwkHhNoEG4IPCbSDcJtBBtBBtAg6CDpA6CDaCDwrSDoJtIOgm0EG4JtIM NBRT/h7Ddvh2Hww3YeG+Gob4e3hvYPb2Ht0w+Hhvh2G9hq+MU9N/2rr1pN/39dPXTaXXX3Trpe61 Sh4bUEd3hvg8EVDw3sPBt2HhvDD28N8pw8N7DtvDe3hvh4N0+1f06v3V7fr/3Xx3v3trda+3+/dB GDLiZgwweEwYPMGYHlzLi4QMwWXIuLlzMDzDDB5gzA8wwxmGDGYMuLlzBh4Jhh5gwweXMwPLmYHm GDB5czBZgzA8uzA8wbEIw3w1GxxTFMVGxTFOkxTHG1qxTGxTGxWk9OkQb+lsdt+323qG/Yfvqw9N vVvUOm6hvu9NvtvtvVh6bfsP29Nh3h7frr9rqK92mKqunjjijX31VMPt6b+G/f2/b7D+67a3/v7f v7ft1h/b1b9vw9W1d9NbT+9bTVfvT9PhP/tP7v+u//79f77++/+/X79Vf917+///7tNNU01TtNU1 tbT1tU0nvd8LSC6X0vX0l0t16S8JPS6/6W4Xwl/69JbpeEv+lr7a+nrf3dppqt2np06XsPX90F1V OgukFtJeEFtLugtpWlaCV0l0l1XSW4QW17hLqlaX7612n6chFW9df7Vb9Ib9hgiPGIIFiCCxBAsQ gsQQWIILEIFiECzMeIIjeIIjhnhKEECxQWIIFiCCz4uIIFiECxBAnEECxBEnYheyRFIZSMpGUhlJ CEyYZSMpGKZPFIZSMmIgTJiJiJhlIyYyBMUTt/eqS0sJYSdLCWEsJdKgsJLCdcLrhBcLS0sLhK1b /h3cPhw04cPh3Dh2nd2g+Fr7rCCUJaWkqC4WloLCWk8JpJQgtArCC0sLhBaWgtBUEE2ut3D4d3d6 acO4d3Dhw7hq1+THoLBBYQLBAsECwQTggWECwQWCBYIFggShAsILCBYQWECwgWCBYILBAsIFhBWF 7QcHDg4NA4cHDg1YOHBoODg4dw4OGEjEHb/fpMQtK0FoJQuEtLScLhLCWgsJaCwlhBfhBaUVYQQb 9Fj7u4d3Du7lv77mHDu0WOHdw0k7r7pRVRCitKIUVEKKiFFMQoqKiohRUQoqKhRTIg/25Y4csdyx 3Ldyx3LHct3LHcOWOH2ixw5buWOGzO9uWO5nDduWOHNDmd0t/2KgoKFBMQoUFBQUFBQmCYKFCgoU FBQoQYXpN4MPBg8MHsPBh4MHQYPBhy4DoMNLwweGDcGHgweGHQMHhh4MHhvYPDD319dde1VVVVVQ mmoT1UKvS9h74bw3sPb29g6YeGGrDw3tqw+8N7eGGt4YeG9h/T/qoVQqhMKoVVCqE1ChVBVCprcK we3hh7ew8N7eG8PYfsLe3hh7eDD4eGH7hvb28Nt//cREWVsyBMFCYIWEMEIYQiwhHSBIjtg8EW4e CPYNIwzBZcy43MMwWCNAPNsjiuYgweXZgsETHEECPAwRoB5hmB4I0BqYgweCNYebgweCNANTEGDo EaAeCPAPBGgWKX/LOpvCVt6w6CDbdWH4bVb02HqDapt6sP3TdNh6bemw9Bv2w9N/YemG7VvQYYeF bX+0RGUtlLiZRS47+KXkyyZRS4mX2lbHYb9h9hurvww/D3bfhh9t6bSb4f29W/Yer6hh6Yb7b02H 2/t31xQcNBhMJhMINBoOGg/gsPt+Hvfw/vq37dW/v64e38N+/hvsN+34fw3WH8MPsMmODCXfv/9P u/vXq9V19fXdL1uv/prWl9f/r0v/X19ev1j+q////3rr4QT0l0l6X/SC9Ldd6aX/S3+gl0u6W69J dfhLpJkQd/dqv9pp6/BkQcECIsWEECoMIJUGggthAgtoILaBAqaCCw0CC2ggWwgiCQgrQIFsIEC2 ECBYaBBbQIFtBAugQLaCCw4IFsIIFhoIJhf+un2uuq9xhYhbFBWISxrEJYhcQliEsGsQmIRFeK4p YhLFBYqogliliEFiEsUsUnr6hqE0wgwmnemq8OloLCWlheFoLS4SwtEWMLCCwlpOulpKEtdLSsII Nf3LPqh8G0FggsILBBWECwQWEFggsEFglggg2gsEFhAsECUECwQLCCcILCBWCBYILBBD/sm6rnZT /3gin1paCwlhLStLXSWm60rC66SpOkqWEusElq/yBKNyxxwy4ORwNyPog0DkG7mcococQZHyOGqh DI4dENg5xxDI+R0cDMMUgeGtAjTPZHsJkfTCxmZWoUIh9HWFJ0Yv8RyBLAuvq/tfa/lkA0VwaLKW ESImMgcTGQLIFExkCiYZSMgyJ4mGTGQOJiIFkCiYiBRMRMXxGibGrFhFdKQ/fEfhqviP////5Nyh dfuP+vy09Pv9R7//8tutfh9b7lkLotM0zRfEQXqWdURZgsP4r3rqi2Yf6+0ar4r8toa6/18R+W0K r4/+/LbSJeCBX+H/+gn5ATBpen/+L9f///ltCyfmSxJ/3/Q/KaU//6GrTxHloQoQQ+P/8ptLUctN 4s42sIZNTI+YiPkPINmiLXGLIGYYHMOQQcgtDkTCnJDlzNUdprZTMW5AzKyGQGaOQ45BVggfOU5E occ7kO5KDjkhzuVBVRHB3LHOGfynJcTVnDPMpoEuQWwb7LSB4ZxogoyEQWwJBybngociwQYg45Q5 EZTXLQnDJDXEREI1CGSGmOQjkMwctzOQg5oLckQeyMcrCrKklqWgXDJjsbA0BTI4NZsyPl4njmUd mM3mFLOpouIQgH52lgtikDiERG2XDJBSMMjkYRF1LTVTNYZAbRkLgaBoI4NpHFI4apHZcKXReLs2 ZhFHLUSwPDTK/gtgTmAWw1SOELswReLxdF0Z8tVVEOIrqgZIaDsXj7PAZhqEcZHRHDl49l2XzCI+ R0fRfNFLaGBkZXrA1BsLaFQPBoK5WBqGkW0C5Akey+UCFunBbBTJwyAYKbJgeCuRMDwLkfOxsDwb Cm0sGwtxMDxSAoVhqEBXQN///////+ACACANCmVuZHN0cmVhbQ1lbmRvYmoNMSAwIG9iag08PC9D b3VudCAxL1R5cGUvUGFnZXMvS2lkc1s2IDAgUl0+Pg1lbmRvYmoNMiAwIG9iag08PC9TdWJ0eXBl L1hNTC9MZW5ndGggMzk1MjQvVHlwZS9NZXRhZGF0YT4+c3RyZWFtDQo8P3hwYWNrZXQgYmVnaW49 Iu+7vyIgaWQ9Ilc1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCI/Pgo8eDp4bXBtZXRhIHhtbG5zOng9 ImFkb2JlOm5zOm1ldGEvIiB4OnhtcHRrPSJBZG9iZSBYTVAgQ29yZSA0LjEtYzAzNiA0Ni4yNzY3 MjAsIE1vbiBGZWIgMTkgMjAwNyAyMjo0MDowOCAgICAgICAgIj4KICAgPHJkZjpSREYgeG1sbnM6 cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4KICAgICAg PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6ZGM9Imh0dHA6 Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIj4KICAgICAgICAgPGRjOmZvcm1hdD5hcHBsaWNh dGlvbi9wZGY8L2RjOmZvcm1hdD4KICAgICAgPC9yZGY6RGVzY3JpcHRpb24+CiAgICAgIDxyZGY6 RGVzY3JpcHRpb24gcmRmOmFib3V0PSIiCiAgICAgICAgICAgIHhtbG5zOnhhcD0iaHR0cDovL25z LmFkb2JlLmNvbS94YXAvMS4wLyIKICAgICAgICAgICAgeG1sbnM6eGFwR0ltZz0iaHR0cDovL25z LmFkb2JlLmNvbS94YXAvMS4wL2cvaW1nLyI+CiAgICAgICAgIDx4YXA6Q3JlYXRvclRvb2w+IEFk b2JlIFBob3Rvc2hvcCBDUzMgV2luZG93czwveGFwOkNyZWF0b3JUb29sPgogICAgICAgICA8eGFw OkNyZWF0ZURhdGU+MjAwNy0xMi0yOFQxOTo0NDo0My0wODowMDwveGFwOkNyZWF0ZURhdGU+CiAg ICAgICAgIDx4YXA6TW9kaWZ5RGF0ZT4yMDA3LTEyLTI4VDE5OjQ3OjMyLTA4OjAwPC94YXA6TW9k aWZ5RGF0ZT4KICAgICAgICAgPHhhcDpNZXRhZGF0YURhdGU+MjAwNy0xMi0yOFQxOTo0NzozMi0w ODowMDwveGFwOk1ldGFkYXRhRGF0ZT4KICAgICAgICAgPHhhcDpUaHVtYm5haWxzPgogICAgICAg ICAgICA8cmRmOkFsdD4KICAgICAgICAgICAgICAgPHJkZjpsaSByZGY6cGFyc2VUeXBlPSJSZXNv dXJjZSI+CiAgICAgICAgICAgICAgICAgIDx4YXBHSW1nOmZvcm1hdD5KUEVHPC94YXBHSW1nOmZv cm1hdD4KICAgICAgICAgICAgICAgICAgPHhhcEdJbWc6aGVpZ2h0PjI1NjwveGFwR0ltZzpoZWln aHQ+CiAgICAgICAgICAgICAgICAgIDx4YXBHSW1nOndpZHRoPjE3MTwveGFwR0ltZzp3aWR0aD4K ICAgICAgICAgICAgICAgICAgPHhhcEdJbWc6aW1hZ2U+LzlqLzRBQVFTa1pKUmdBQkFnQUFTQUJJ QUFELzdRQU1RV1J2WW1WZlEwMEFBZi91QUE1QlpHOWlaUUJrZ0FBQUFBSC8yd0NFQUF3SSYjeEE7 Q0FnSkNBd0pDUXdSQ3dvTEVSVVBEQXdQRlJnVEV4VVRFeGdSREF3TURBd01FUXdNREF3TURBd01E QXdNREF3TURBd01EQXdNREF3TSYjeEE7REF3TURBd0JEUXNMRFE0TkVBNE9FQlFPRGc0VUZBNE9E ZzRVRVF3TURBd01FUkVNREF3TURBd1JEQXdNREF3TURBd01EQXdNREF3TSYjeEE7REF3TURBd01E QXdNREF3TURQL0FBQkVJQVFBQXF3TUJJZ0FDRVFFREVRSC8zUUFFQUF2L3hBRS9BQUFCQlFFQkFR RUJBUUFBQUFBQSYjeEE7QUFBREFBRUNCQVVHQndnSkNnc0JBQUVGQVFFQkFRRUJBQUFBQUFBQUFB RUFBZ01FQlFZSENBa0tDeEFBQVFRQkF3SUVBZ1VIQmdnRiYjeEE7QXd3ekFRQUNFUU1FSVJJeEJV RlJZUk1pY1lFeUJoU1JvYkZDSXlRVlVzRmlNelJ5Z3RGREJ5V1NVL0RoOFdOek5SYWlzb01tUkpO VSYjeEE7WkVYQ28zUTJGOUpWNG1YeXM0VEQwM1hqODBZbmxLU0Z0SlhFMU9UMHBiWEYxZVgxVm1a MmhwYW10c2JXNXZZM1IxZG5kNGVYcDdmSCYjeEE7MStmM0VRQUNBZ0VDQkFRREJBVUdCd2NHQlRV QkFBSVJBeUV4RWdSQlVXRnhJaE1GTW9HUkZLR3hRaVBCVXRId015Umk0WEtDa2tOVCYjeEE7RldO ek5QRWxCaGFpc29NSEpqWEMwa1NUVktNWFpFVlZOblJsNHZLemhNUFRkZVB6UnBTa2hiU1Z4TlRr OUtXMXhkWGw5VlptZG9hVyYjeEE7cHJiRzF1YjJKemRIVjJkM2g1ZW50OGYvMmdBTUF3RUFBaEVE RVFBL0FPMmZaWFg5YUs2cW1NWUN5bWx4YTQxdUhwMWRSdXFwZlJaayYjeEE7NHJMc1o3TWpmaFdZ bUoxR3Yxc1hxVE1uMHJNS20vRHVkYisxMjAvWk1hcDFucU45Vit5eTZoNWJWYmpHMmlqSXhqanNx eUw4ZDkvMiYjeEE7ZjFzL0YvVGVuL1BZbjJ6N1BYeXVvM0RyK0ZoQzZ2MFRrUGFRR1d5WGZaYkx2 c2pyOGE5OUxjdXIrbU9vNmxqVTBaR0hrMFc0ZjYxZyYjeEE7K29wNVUxNTFmcjFOb3hiYzFwKzBN c3N4bk9zRk5MTVQxZnNadFpuc3Z2YjlpL3lsYjArbjJZdUo5bXkvMVg3U2xOZG1OOVo2T2pQdyYj eEE7OGdWNXVRMzF5L0lveVgwWFhnSDE4WnRmclVYTXc3YzkrN0Z5RzA1ZFZYVEsvd0JMMDIrdjlC VmpiQXR6WEZ4Ymp0WTBPYTF2cVdRNCYjeEE7Z1dQcnZzMjFNdlkxbjJkck1uRi9TNzcvQUZQUXlQ c0tWMU9GVmhYMTJVTmRpdWJZNitodGZxQjRzMzI1UDZ0VXg3cjMzdWZaNmxmcCYjeEE7MlB2Zllz K3JxM1JNU3d1ZmZUUlVLWFZETXZlNFBjTUs4NEdUWGxaT1V3ZXpGeThtcXVtMjdMdGZrM1pWK3ov UzNKVGFPUjFkMksxOSYjeEE7ZUhTTW5hN2ZUZGtGclE5cjJNSHAzVTQrVHZ4N2F2V3VydWRWVmQv UjJXNHRUN3J2c3VmazRIWGN6cTlkdHRlTlRnMFhWV1ZXTnlMbiYjeEE7MnhTY2ozZlpqajAwMVB5 cWNuMHJQc3VUUS84QXdlWmtkVndQOG5XVzgvQWR0cyt6WW1OWlVjYkxhNnQxVFh2ZGJlNnE3MG0x dmZqVSYjeEE7V1krWTl0NzgrdTdJeC90TjMyZjlOL09XclFGTlF0ZGNHTkZyMnRZK3dBYmkxaGU2 dGpuL0FFbk1yZGJicy80eXhKVGxVVmRZYUtjdSYjeEE7NXQxanFtbHpxRGZWNnJtbXQ3RGoyVVZZ MUhUMzVEN2FNTEkzL2FtZWpsNU9iVmo1L3dDenFmUnpyVExldEdvRitMak50MmtsZ3liQyYjeEE7 M2RGMjF2cWZZbXUyYm00ZnY5TC9BQStUK2ovVmF2dGx1NDJpcDVwYTE5b2FUV3g3aXhwZEhzYSt4 ckxYVnNjNzgvMHJQK0xXZWVnWSYjeEE7bnBOclk1ekRXNXhwZnNwZDZUWVo2R1BpMTNVVzBZdVBo dng4Sy9IcXg2YS8xakF4cjhqMTdmdEgyaEtTdDZoYTNxYk9uNUZUV092cCYjeEE7dXZwZlc4dkJi UmJYUzhXaDFkUHB2ZFZsNGRyTm5xKy83VFYvMm5xdXlzV3pMK3NkMlZqVVl0cm1aTExxN2MvRzlq bURIKzJXMFgraiYjeEE7a1hZZUxkcyt5aXhqR1pHTmlmYnFhYU1ucE9kbFB3dW8vYjlyRTZQMC9F eVB0akttdXpUU0tMTW90YTE3Mjc3TW13dUZMYXFXUHlNcSYjeEE7KzNKeWZScXE5ZTc2ZjgzVXVZ cWJGOUJvc3gyUE5lRTRZVEs5OURNZC9VOStQZFIxTzIyekJ2cWZqZXBYMGZHc1o5cnE5UDF1ajR2 UyYjeEE7dld2d0VsTzdabjVXSjFUcUYrVzY1dlJzUEc5WTNPWXdWdHNhUFV5cXhEUm1Yc3F4cTZi OGV5aGwxUHJaSFVhTHIzMjA0Mk5pNS9UciYjeEE7dnJDL3EyTlJtT3VmUmpPciswMlhWUG8zUHN3 bWwzcHN3S3I4RElZekxxdnNzdXQ2cDlseDhqSXZ3L3N0dDFYUnN0YUJlUjlaTXNWbCYjeEE7dDJV enAxSnhhSGl3TlpOdVg2dS9LRk50R016T2V6RVorajlUSXUrdytwOW1mOWtyV1AwU3ZHemNySGRo ajFzTDlReW5VaXloaHJaOSYjeEE7aXUreVdkUndNWU1xOVgxV1liNnFLOFJteTM3RGw0L1ViOFRD cDZmMHBLZXdTU1VIM1ZWdXJaWTlySFhPMlZOY1FDNXdhNjNaV0Q5TiYjeEE7L3BWMldmMUswbE0w bENtNnErcGwxTDIyMVd0RDY3R0VPYTVyaHVZOWoyKzF6SE5VMGxOZkF5TGNqRmJaY0tXMjduc3Ni ajJtK3RycSYjeEE7M3VxZXh0N3FzWnpuc2N6YmIraHI5SzdmVXJDNS9vOWxqT3FHaW0zZGp2czZu WmtzSVl3RzV1VGlpajdOV3g5bStxaW02NnZJdHcvMCYjeEE7ZjJ6MWYycDZQVjdiNmwwQ1NtajF4 N2EraTlRc2ZhNmhyTWE1enJtUGRXNWdGYnliV1hWVjVGdFQ2L3ArcFhqM3ZyLzBOdjBGbTRMdSYj eEE7czI5YVAybCtRL0Ryc3NzRkQyQ28wK3ZSalB4YTdycWE2TVBxRldIWXpxdU85bUxrOVM5TzNK d0xNajFiYWZ0T0xwZGNaa1dkRjZoWCYjeEE7aTJPcHlYNDF6YWJXYnk1cnpXOFYyTSt6TnN5TjdI LzZDdXk3L1JlOVkrQ2EzOVhyQnF4S2FmdGR0OURXVlB4N24zMlkzcm5MdjJ2YyYjeEE7MXZVUHNX ZjlsdTZaMUNpbk55SzZjbnJEUDBWWDJTcEtSZFR6eFJnWDQvMml2SkdMa1pXVGRkbU51WUtycW5a UFd1bTQvcGgxZDF0VyYjeEE7SjlscXNmOEFaSFpXUit6cU1XMnJwMzJEcU5lWGphdjJDNzdUdC9X UFIrMy9BR2pkNjF2MFBROVQ2ZjdRM2ZaUHR2NlA3TDZIMlgvQSYjeEE7L3NuMHY4cExLNnpsOUlw Nm5sWXh1eU1MSXMyaTU3SFpOSnN1emFUaTFXWVRxRGRUazVlUDA3cE9SOWtwL1orUlhiMUg3TFJp MzBaMyYjeEE7MmhhSDJ2cEgyMzFmV3JuMVAybHYzWW0zN1A4QVpmc3Y3VDNUOXAvWiszOVgrMi8w djEvMFhxZnNsSlQvQVAvUTdxN0p2ZDlaYXNkKyYjeEE7UjZkVlhwbXZGYllJZUxhczUzcjNWdXJ3 N1BWOVREdXJycHF6T3JWZWxUOW9zNmRpMmZyMk1XNFgyZFFaWmhHeDMyZkwyWmxMcmg2UiYjeEE7 RDhlc200dFpjKzJqMEtuczlERDlIMHI4bTMxN2NIOVlvNjFpUnZsbjFtb0p0YUczMHRiNlRxN0tp WFZETWMwMTlSckgyZlBmc3V0LyYjeEE7eU5rL3pMUDhxMGVuNkg2WlpmcURQeDdiUzdJcnE2aVBU Qng3NW9hL0RmamdVUHhXT1plejE3M1B0emN2OVNvWms1R1A2bjJqR3FTVSYjeEE7NkhVYktxdW41 TnQyNzBtVTJPczJXQ2wyME5jWDdNaDFtTzNIZnQvdy93Qm9vOUwrYzlhcGNsMWNNcHA2aGRrVjJV NHo2OGpIcHRleCYjeEE7dEpZKy9Kc2NQV3J5VzR2U0xNU3pJeGJzcDkxblZNTDlyNGQrQmhkWnc4 L0l2d2JyOWVqcldiMUhIemNkdlRMdlhvdU9GYTFsM3BOYSYjeEE7OHNteXc1Vm4yVExxeDJicTdx OHZEeDc3bjRXVmhaZUxYOXErMDRlRllxNkhHQm40Tnh4MzFkUnlMckx0bEhvN3FjaDM2ZW0vN05k VyYjeEE7NjdMK3piOGI5b2JxclA1bTYycTJ5dC9ySlRQcTc4S3h3NmErMW96cy9HeWE4VEhzZnRa YUEydjEydVpaWGxZbGoyYnF2NTdFeW5zcCYjeEE7KzBiTWUyajdWV3ROYzU5WWVxdWE3TnhXaHh4 OGZDdSsyQzFqZlEvU3RGcmJyTFBRNmprdFpSaFkyZjZUL3dCbFpQUzh6SS9VYkwvdCYjeEE7bFgy VlhldlplYlF4bGVFTFBWZlhjOXJxMjJFU3h2MExIMWRPNnRYWCtqc3R5YU43UFZ2ek1iR3hhcWNx dS9JclNVNnlTcVcyMlhiYyYjeEE7WitMa05xeVBXcnN1WTlqUFRhM2N4bGpyS3NobVN6N1UzM1ly OFRmZlYvaC9zbGlyc3hmckN4dGpQMmhqV0FOMjBQc3hIbDRJYzM5SiYjeEE7bEduTm9wdmU2bjFO L3dCbm93bWV0K2xaNmRYNnVrcDAxem5YTFJYMVJ3OUpyclBSeExLUzBWNzdmVHphL1Z4bk42aGZp WU9RL2MvSCYjeEE7WmdXczlUSTZaZGtaRm42dmZuWU5XZG9ZK2ZtMTlYYjByTlkydzI0MzJtakxx YnNZNDFHckh6cUgwdnV2dVk5bDE5R1JTLzZIbzVQbyYjeEE7Znp1SjYyVG4vV1IrRXpOcWJkVzZ5 L0liajQ0cnMxb3R4N2M3QnhjNWtNZDZ0YjZ2dEZIMmlyOURqZFFyeWFLc3VycVZPTjZXSWxOdSYj eEE7N09jejZ5UHhxbnVzZFgwNDVEOEpqMjdyRDZ1ekhleXZKZlRWUzl1eklxOVdoMnkvMS84QUtk dUo5bTZiOXB4K2pQOEF0ZG5RN1F5diYjeEE7UE9GOW5wKzAwMGVsVGppM3B0MlJlN0cyZWhjMzdU Nm1GNm5yWTlIVHZzK1YwL0dveEdaK1BkWXQwNUYzL09SdU1NcHZvSENkWWNJTyYjeEE7cUx0L3Fz WTNLZFhETTZ0bTM5RXg3SFpHTGQrazlUN0hkajFmYjhYRmJWaDlld2NESWUzS3ljZDJQak5pa1k0 cjI0T2E3R3pjYjBjZiYjeEE7R3ErejIrbDFuSC9aL3I5U3g4ZDkvcVkrUmhQcHN3MGxQV3JKNi9Z K285T2VNcXpEcWRsaXEyeXBybkVtK25Kd3Nac01xeUtQNmRrWSYjeEE7bGpQdHJQc2Zxc3I5VDlK NlZiMTBMcTkvVkRsdXNyclpWajJWMXNkVzhXQnhkVFRsT2RWYldYMTVPSlpYa1U1R0ptZnExdDFW L3BYNCYjeEE7R05aajc4aTNsWk9GWjAxMXp4WGw0bVJXQXhtNnNzdkYwVjAwVnV2ZXpHdCsyT3Na VFQ2bG5wWGVxa3BoME4rUlowWHA5bVZXNm5KZiYjeEE7alV1dXFmdkxtdk5iRFpXLzdTNnpJM3Nm L3A3TEx2OEFTKzlYbFhiMUhwN210ZTNKcGMxN2FudGNMR2tGdVE3MHNON1R1K2hsVy9vOCYjeEE7 Yi9Udi9ta21kUjZlKzBVc3lhWFdseFlLeFkwdUxnYm11WnMzYnQrN0R6UC9BR0Z5ZjlCYWtweCtq czM5WnZ6SzIrcFJrK3ZkWGxGdiYjeEE7dWZ2R0N4bXk2dWkzRXR4SFltUGlQd3I4VHFPUDlvby9R NW5UOGpxT0JsNWRYUUt2algxV1czc2JjNTlnZHVOTmdESFZ0bDJNM2JYcyYjeEE7cXUrejNYWXVS WlRmYjZuci9wZlF1K3ora3BVWmVMa1I5bnVydTNWc3VIcHVEcHJ0M2VoZDdUL05YZW5aNlZuMExO aVNuRnlzWEp5TyYjeEE7Z2ZXREJlMnhtUmI5c3JhOTV2dXJjTHF6WmkyWXJYbkt5UFNiajNVVlhV WWRQcGZicXN1ckR4a0ZyR0RyK0MvN1Q2YjhySXR5TWZIeSYjeEE7Nm10dHR4bTR1NTFlUGJleTdQ YmJoWi9VYjdhc2U2M0F1eDhiSzZuamZaZnNWRmExZzNwWFVjVzNIZXl2MHVyVjJ1ZXhyMmJzaW1H WSYjeEE7anN0dG1MWTUxdFZ1TTdGMlh0czlTdWkzRjMraloraldmVGZXenJuMmR0K1ExamMrMnNz ZVh2cmZhL0Rwei9RM3Z5cmJXN2FyYjhqRyYjeEE7YjZWWFNxbVZaRkgySDdiK3o4MUpUWTZqMG5w R0ZWazlZeDhHbXZOb2JabE90cWVNTjFyMkIyUWE4ek5xTk8vSHV0YitzZmJIV1l2KyYjeEE7RnlL LzBhNWYvbkZpL2FmVzlmSSswZnoyejFPazgraDlsL2FYOHorMFB0ZjdQL1QvQUduMGYyUC9BTjN2 K2JQNit1MTZyZlpqOU55YiYjeEE7Nnp0TlZaYzUrOWxaYXdhMjIxMlpUWDRyYmFxdDlsUDJyOVY5 WCtrMlUwNzdWNXI5bVovb3NpZnNIMlg3WjltelBUOUgvd0NkL3dCTCYjeEE7N2Q5aSsxN2Y4aGZz cjFmVSszZnJ2N2QvYi82a2twLy8wZTl0ZHUrc3pHN25QTlZOTVZzdHltaGd0SFVkMTJSalZiK2wz TWY5bHJxbyYjeEE7ZmtlbS9mNm0rLzFmMmRUZERxVlF5TG00OWxlK3ArZXhyNjNYWFZ2ZVBzMjV0 MkQ2ajhTcjFjTzNabWVuaTJYMVUvWXNuUHh2OHRWZiYjeEE7b1ZaNjF2MW9ZNFk5bnBVVnNheksy MmhvOW1VL05xM3V1cHh2UzNYZEoraFJrL2E3L3dEQjNXZEwrMGRIaGsyWW43YXJ3eFk2akxkbSYj eEE7MVpPcktaZUhZbVF4bm9XZlpjcmN5K3JwMlhqV3Z2dHhNOWpLc2owOHV2Ryt3NCtTbE9nN28z VG51YzYydDE1ZTYxenZXc3N0QmJlMyYjeEE7MDhuSDIzUHNiOWl0YTFuNmgvUXQ5ZFZ2MmYxYXEx R3JvUFRLM3N0RExIM1YrbnN2dHV1dHRIb3V2dHAvV0w3Ykx2OEF0YmxWdi9TZiYjeEE7cGNhK3pF dTM0djZGYUNTU25KeStqWVZXQmNhblpETFdZN3F4a0MzS3R1TFd1T1ZYNmo4ZklaMUhOOUc3ZDZO WDJqMS9UdHZ4Y1gwcSYjeEE7OHEzZVlkQTZTQlcxdEcxdFd6WTFyM2dBVlhOejhXdmExKzMwc1RK WitwMC96V0pWNnVOamVsalhXMG92Vm5NWjByTWRZMnR6RzQ5cCYjeEE7YzI0TmRXUUdPM051WmZi alV2cS8wamJzbkhxMmZ6bDlYODRyYVNuUGQwSHBob2JqMXNzb1kyQTA0OTExRHd4cHRkVmordmky MDNmWiYjeEE7S1B0TjMyZkQ5VDdMai80Q212MktSNlJpRU5Cc3lmWTF6UkdYa2pSMWJNVjI3OVA3 MytsWHVaWS8zMTVIcVpsZjYzYmJlcnlTU25CcSYjeEE7eGNmRyt0bExXV09jNDlPc0RXM095N1hn TXN4S251b3Z5THJ1bk9ZLzA2UHRqTmpNL3dCYjBNaTJ5LzdVbzlmc2VNK3FsOTFsTk45ZCYjeEE7 TmV0cnFtRXZ6TVBIdCt6dTZkazA5UysxN0xtVmVyWmpXNGRmcTR2NjNoMVc1OVdhc0xxRE0vci9B RS9NcnFzcng4N3BEc25IZlp0ZCYjeEE7dURyTWF5eXJidmMvRHR4bVhZM3EraCtpNmg5cC9UVy81 THhsRHI1YmJtdnhYNUxxNjdHNERiYUhCenFIc3N6bVUzVlgrbWNqWS9McSYjeEE7MzRWZGI4ZkVw emE3OGo3UmRuMFkxbjdKU25RSnVIMWthSDdUUTdDZDZBY3lyYzE3YldmYXZSdjlmN2Rzc2EvRCsw MC9ZZnN2NkxFLyYjeEE7V3E3djBObFEyVlg5ZTlNN3JMTVhOWitpYllMeFZ1d2I5dWJaVlhaWGIw cG1UNmx1SDZlVDYrUGErbjFxTVN1L1ArMksyKzJrZldTbSYjeEE7b0J2cnZ3clhFdmJhWGJHMjQ3 Vy9aYlkrd3NadXMveWhXeC8ycXovSnZxZm9hcWxuNXJIZjg1S0w4bXltdHVQazQ3cWlOc21tekc2 bCYjeEE7aDQ5ZDcyTmRrTXlMT3BaV1N5cjdVNnJwOWpQczlPRC9BSlJ0eXFiVXBYMWR3Y2lxNi9K ekdPeW5YWk8rbTE3SHRld2VsWTZyT3ZibSYjeEE7c3d2VHlMc1RJcXdzaG1Iald2eDd2VXdmV3I2 ZFJUMDNvM1FYVk51cWZVOHVEYkdscml4em1PaHcyblpiVVdXMXYvNFN0KzlpeXNjZSYjeEE7cjFG MWYyWjFiTUxKSmlvNHI2QSt5dkt2Zms4TjZoUmtaRldiVDl0L1IxWGZhTDZmUTlmQnR6c3JKMkVs SWNUMVBzdFBxK3A2dnB0MyYjeEE7K3RzOVRkQTNldDlsL1Z2VjNmem4yZjhBUWIvNXI5R2xkZnNl eW1zMXV5SCs1dFQzN0NhMnVyWmsyc2h0ajMrZ3k1djVtejFmUnFzcyYjeEE7cDlYMUVzYXYwcXkz MHE2SnNzZHNxTXRPOTc3UFZQc3EvUzM3dlh2OXY4L1paK2t1L25uckZzOWFodHd0cnZaYk5sVnRR OWpxM0V2eCYjeEE7OXZ2dDMvb1hWL3BXdjJYZnp2NkwrYlNVenBwcW9xWlRTeHRWVlRReXV0Z0RX dGEwYldNWXh2dGF4clZTem4vYWJ4MDRzc3JCOU96NyYjeEE7UWFQVlp1SXliS1BzOXIvVXg2TXZD eU1Pbks5WEtvdG9yL1ZhdjU3THBWckx5V1ltTGRsV0NXVVZ1dGNOelc2TUJlNzlKZStxbG4wZiYj eEE7cDNXMVZmNlN4Q3djYTZqZWJ6dnRkQUwyMld1WS9tNnl4dU5rUHRiaC9yTitReGxOZHQvNnF6 RnI5ZjA2cXFNZEtWazRsSXc2c2FxbSYjeEE7S2FiTWYwNmFtMVF4dFZsVDY5dGVRUFJaVlI2ZTc5 SCtucXFaK3BmclhvTEt3WFBkMS9KQmJZeGxXWGMyOTFJZDZWdDdzWEF0d3JzciYjeEE7OUs5OUhv ZE5mWmllbTVuN1B5Y21uN1grcTV2MkRIVzFrdDNWZ2JMTFAwbFoyMVAyTzBldzd5NzFLZjBWZjg1 Zlh2OEEwMUhxVStsZiYjeEE7djlDekZEV1c5ZnBma3VyKzA0MlhleWgwdGNITWZpMDI3YXZXcXpi Y0hMcnFkVXo3Qmo1blRmdDFWT1oxZjByTWY5WFNVN0hVR1d2dyYjeEE7cm0xQnpuRnVyR0V0ZTV2 K0Zxb3NiZGgramtXMWI2OGZJKzAxZlo3dlR1L3dhOGMveWQvM1Evb0gvZDc3ZjZIL0FNaXYvaDUv ekhYcyYjeEE7ZlVXV3Y2ZmtzcERqYTZtd1ZoaEljWEZydG14emJzTjIvZC8zY3hmL0FBelIvT3J6 Zjl2L0FGUjlQZDZPWHM5UDlvN3ZUYnUvWisvWiYjeEE7K3dmdFgyejdEK3ovQUYvMFg3Ty81TjlE L0pIMmIvbkdrcC8vMHZWVno4TXN1eHVvUHJzWS9MeThkOWQrQXh1VFM0ZlpvOWV5MXpjciYjeEE7 OVV1OVM3QXM2eFZpZE16UHMvMldpejBzS243UXVnWEpXdHkrbllUYWJMYWNxLzdianRGWDJqRzlT eTZqQm90eHNQTnlzL0ZiOXJ6YyYjeEE7enFPSlQ2ZHphcWVvZWprWW1aVlpqMDBlaFdsUFZWWFZY Tkw2bnRzYUhPWVhOSWNOekhHcTFrdC9QcnRZK3V6OXg2bXNIR3hhdW4yMyYjeEE7MDA0ZlViWFpE dlhrM0I4L1ppNFZqN1UvTDNPZmU2akgvcDEvMmpLeDh6R3hMdjhBSjJCa1kzU3JkT2RsVjRySFVk T3lic2R0SU5BYyYjeEE7OW4yaDIxL283YjJkUXVwZXg5dEJyeTYzNUdSOW8vcEZlZFhpNWxkZE9T bEs2NnpGYmlQeWJnNzFhYWJ4ajJBdkRhM0dteHo3M1BaZCYjeEE7aDA0ejIwMTJWc3pic3ZCOUwx Yk1lclB4dnRmNlM3azVOZU13UHNGamdkMmxWYjdUN1d2dWQ3TWRsci9vVk8yZjZTMzA2Sy8wMXRW YSYjeEE7NS82d1VaTmwxblVXMVplTU1URXZhYm1XVU1ZZjByV1Q2aitvWWpxS3Zzekw4bko5Mko2 K0xaajNmYmNYcTNUT24vWkxlVmozWjc2WCYjeEE7WDRHUmlaYk5qM1ptTTdHY1d2WTY3RnJZekl1 ZDlwZlZRM0t2NmhYK3ExZXRoK3BqWkZQNjFtZEl2U25ZZmRWVzZ0bGoyc2RjN1pVMSYjeEE7eEFM bkJycmRsWVAwMytsWFpaL1VyVTFpUHFxYlJRK3o2dmVyZGplaUs2cVJpT0Zab09RM0hkaTJaTjJK K2l3L2RaaXUyWTl0ZFdmWCYjeEE7NmRGVnYyeW5HdDM5VXlhS1RjN3BtVzVyYTMyUGJYNkQzalpV M0k5UDBxOHAxbHR0dGpuWWRUS0cyL3JWWC9jYjBjbTFLYy9HTDJmVyYjeEE7ckZ4bldWNzZla0gx OFl2ZGRZd202bGxWbGVWbHU5YkpxdDlMSnJ1dXF4NnJiSDQ5Rm5WUFUzOU5aUkRyemNWL1ZHVlB5 THE4bTZuSCYjeEE7WlhWVTkrS2ZST2JqVjVsbGZVM2ZvbVAvQUVtTlZiaFlObUxtWmJQME4zMmg5 blRQc05nWkhyL1dySEQ2N0svVHhNeHVPOHRobGpCZCYjeEE7MCt2SkwvVjlISXB0cHlLZjBmNnZk aTVlTGRWbFVaditCVlRyMWZyZFN0cE5WZ2MrdnB6YThtdzdhUlcvUDI1OVdKa1BZeXZFNmg2ZiYj eEE7MmF6OURsL2JzaXo5bnZ3cS90T0ZUYWtwMEhGNy9yVldLckxDeW5BcysyVmIzZW1EYmRWK3py UHM3bmVqNnIvczNWRyt0Vlg2dXhuNiYjeEE7Zi90T3FWemJYOWR0RmxiV3RyemNXekRkWE5MM09k ajIxWlYwNWVNekc2bGtmWnZXb3ltMFoyVDZYU2EvMEZlSjFIQ3IrMTZBdGNQciYjeEE7STZvQnJH bkNhNGt0YTExcEZyMnQyMncrM0taaDd2Zld4K096QSszVitwOXMvYVZYMkhNc3F3NnZySXg3c2Ji bFg5VFk1dVF4bGxlOCYjeEE7RHBtVlhVYjc4aXAxT1o2WHA1bFhvWUYzcFkvcVUyVy9ySDJtdTlL YmZUUjArN3FlYjlrcjlhN0h5LzFwMXpNaXMxUE5ObjZTbCtZMiYjeEE7Mm5MeTNldDZYcll2MmY4 QXlQa1llUDhBMFhHd3E3OVBOeW5ZOVE5SmpiY20xM3A0OUxudHIzdklMdHU5L3dDWlhVeXpJdjhB U3J1dSYjeEE7K3owM1BweDczL29sbWRQeFBUNnYxQnhkWGRrSExaYzkvd0RNWE54blkzcDRyYi9z K1BRM3FkVldTY3FqRSswT3ZwOVAvdFg5dXdQUiYjeEE7V1YxalB5YzdxV00vcDllUlpiaTU3YXNZ R3E5Mkc5bFhxVVoxMStaaDBidW5XL2JXM2RQOVd6N1granhmNlA4QXNYcTNVZnRDVXp3LyYjeEE7 ckxsanFtWGdaOU4yTTEyYmp2cHpHTXVGZjJiS0RHZExxZFRtTXlicWNqS3VvZGc1MzZyZ1lPUGQ5 cS9XcU9vK245bzZKbVZsUDIxaiYjeEE7Ry9UTjJqSUpjVzBzZCtnZGF5cSt5dGx1VitpdnNmajJW WXZvVzJZOW1Qa1c0ZHE0M3FPWDladW9ZbGRiTWpKeEs2M01ydnk2YU0xbCYjeEE7L3dDa3B5Nm5P WmhONkxXN0lleDF6SFgzTXVweDdiTUxHdHg2dWhaR1hWNkd2ZzlZdWYwME56UFRlKzMyWk5HTGRi NjgyZmFyTXZKdyYjeEE7QmE5dlUvWStxNnRuUzNVWVhVZW5mczdxZE9KOXIreVl0TmlVbXllbzVY VTh6SXdlblUrbGRSaVdYWWViZlNTS3N1eXVzWXh0ZlkxMyYjeEE7MkMxbE9iL1E3Nkg5UXVxKzBl dGpZdUw5bi9hbGdkVHpjRzdHNmJiMHZKdU5sSk5XUmpQKzAxQTFWQ3g5R1ZtNWpzVzZ2SWZjMTFG RiYjeEE7dVczWmwvb2J2dEhxMlpOV0tIb09MaVd1YmtaTk56dXE0aldzdHR2cHlhZ0R0ZFJXMmwy ZGRtMDVENktXMjFmYU1YT3pXYjhuT3lLciYjeEE7L3dES3VSOXAwK3BZbCtWUTBZdHRlUGwxV010 eDhpMm9YaGhCMjIvb25PcWQrbnhuWDRyMzEzVlcrbGtXZW5Za3ByMmRScXlHVk1zeCYjeEE7SFRh NnEybXJKYUE1elJrTXIrME14YXhrNWRiOFBkalpuNnhpMGZadlh4UHRWdUhiOXAreVo5VDhpbjZ3 dHBOYnFxM1p0NHJ2dDMyTyYjeEE7c3FkaDQyWFpqMFhaem50cHg3TTV6clBSNmRkWC93QW1lblYw K3lpdnFXWGg2cHg4MjdDeEhaTGFUMUNsMU5scjY5R05lTnJNMTJLNyYjeEE7SXF5WHRZK2grVlN6 MmV0WlRiNlAyakc5VDdSWGowZ0g2d1I2ZTQzOVR0eW1Pc1pkVzVqYU9uMDlMdGZXeDdhZlUzM1Ay c3kvVHlPayYjeEE7K2haL1MvdDkyRFU5S2VneThmN1ZpM1kzcVdVZXZXNnYxcVhiTEdid1dlcFRa cnN0Wk82dC93QytzcjlrWVhxZlpvczlEOXAvYlBTMiYjeEE7NVczMWRuN1EvbmZYOUQwdnQzNjV2 MmZzcjEvMVA3TCswZjB5MjFrK2ovbEhmNlgvQUd2Mzd2VC9BTzZQcGVyNm4ySC9BS3o2L3dCcSYj eEE7L3dDNjM3VC9BTzhaSlQvLzAvVlZnNWx1Y09zTVpXTHFzRVpPTVgzTmJrUGM2MTFXUzNJb3JZ MFg0N2NMWTNwZnJXMlVWOU9xOWZPdCYjeEE7KzBWOVdyOVhIdDlSdnltZEh5YittM095c210MWhx ZTBNc2g3TFhic2UydWxtNnpIeG5OZGpaTldQVy9xWDJlcTJ2SDlYcWV4WjlCdCYjeEE7dXlLYk0x dU5nOVFQVlNXME5jY3YzTXhIMU9iNnVLenB2bzVHVDB0bHVSUS9xUDJ2MGNlMm45SC9BRWJGeFVw Nk5KSkpKVGlmV0hxaiYjeEE7TWNqRDliMEgyWStSYlBxTnBMZ3ltNXpkaHlMTUgxcXF0ajdjbCtE MVBFek1HMzdEWmRaUmhaTnVUVnRyRStzbEVzYm5QRmJLZW40KyYjeEE7VGt2eUhza3NkVzFsbEd5 ME91OVBaY3htWitrNlQxYWoxY0ttNzBHWldOaDc5dEpTa0hLdXNvb2RiVlJabFBiRVVWRmdlNlNH KzA1TiYjeEE7bVBUN2ZwKys1R1NTVTh2MGh4SFd1blk1eDNZNHhzTE9ZMGJMSzYzdGRaMGZKcnN4 YWN2OVBqNCt6STlMN0UvL0FKT3VxdTZiWCtpeCYjeEE7UFVSZnJKbDA0V2JWazM3aGpWdHgvdEw3 RGFLR2JzN0JaajNicjY3dWlzZlR1eWJjaDcyL3RUMDJVZlpyOFpuNnhVTHBlR01QNnpZMiYjeEE7 S0xLYWE2TUxPTkhUMk5ycWMydTNOcXNaY3pGdzZuVTFZL28xMFZldmRtK3RtZnpuMkxIeUs4OVdP dFdXUDZvN0d3M1pIMndZamJmVCYjeEE7eDdtYnl3Wk5PMStQaDVIVWNTbHR0ZTIvZms1WFQ3Y1cz K1l1dnlLbVc5THpFcDBIRzhkZnJEYk5tTzdFczlTcHp3ZlVlMnlyMGJNZiYjeEE7SDNPZTM3SXl5 OXVaZDZkUHFmYnNEK2srbitxWm5VZHpmckRoVmlsMUxuNXRWdFZ3YTAwUEp3K28xMzJXYmFxcnJj MzdMalc0YjZ2dCYjeEE7TmpNYXY5a1puL2NqQnQwRGw0Ny9BS3lOd2p0KzAwNFRybXdXYnRsMXJL MzdtMlZqSTJiOFd2WjlsdnNwL25QMmhWUy85bSt2bVhXVyYjeEE7Vi9XRDBhMlZ0cXllcDFUZUdN ZFkyeHZUN3JyOWxqc3JNZFhiWmpZZUxpV2IrbjlPZjloeWJmcy9yV1pIMjFKU25pOWorb211djdQ YyYjeEE7M1B4MlladFlLMlUxWkRxOFhJeThOOTdmMmJiMUM5K1oxWExiWlEvS3lidnRlTmlkUVo2 ditUV1h1Zy90QVk3Y2Q5dU0rckVjMnF6NyYjeEE7UFc1ckd1YXh6Y25BeE5LYWZzK0JsZW5WalpU UFcvUTEyOU55NlB0K0xkbVdCcDZaajVEK28wMmRQYmpVWnVUWlJsQ2l0bExyNkhZNyYjeEE7dDF2 VWI5SDVETDhqSXZzcHY2ZmQ5b1o2Mk5YZjZOek9wMDFUK3I1c3huMjlQeWJxN2Nwc3Z1TFdzcU5s d2M3N1ZrREZxek16N1A2OSYjeEE7TnZUczYrcXVqRnI5WHFIMnYra1o5dVBpcFRsZldINjE5WjZW MG5DemhWWFJkbStxNWxlUlNBeHU5N1AyYmk1bDJUMURwdjJMTDlHKyYjeEE7djdidCsyYlBTenNq Wjlsd3JFdW4vVjdKZTl1ZFhsNDl1Ym01RjJjL0tzeHI3YWJtQjFYMkJ6dnMvVm40VDZzVnV5M285 ZVRkYjZPUCYjeEE7NlZ1TGo0MlhqNXR5cFlQUzJqNjkzWVZOclJYanRHUlk2bXQyTHROVHNWK0hq VWJjZTdIeUg5TzZhN0U2WGs3Y3ZHWit5K3Nmb01lciYjeEE7SXQ2blpuZFZuOUxBeDJQNmZ1eDdj UnJmczlkTGEzaHJhMlhVQ3JEeDh2Ymg0dVI2R1ZiWFJrTTlEMy9aL3RuMmpBcXN4TEVwMEtSYSYj eEE7S21DNXpYMmhvRmoyTkxHbDBlOXpLM1B0ZFd4enZ6UFZzLzR4VitwOVY2YjBuRmRtZFN5YThY SGJQdnNNU1FIV2VuVzM2ZHRybU1mcyYjeEE7cHEvUzJKZExaZXpBcSswWk5tWTkyNTR2dXFGRmhZ OXpyS0dYWTdXVWVuYlRTK3VtejlCVDc2LzVtcitiVU1icVZPVDFDL0dwZTZ4dCYjeEE7VFlrVVdp c1BZNTFlUTM5b2tmWWIzdGM2dXI3TlM3MXNlNm5KOVg5ekhTbU5YVGE4V3QxbXl5M0p5TEtYNVRx TEgxaDlnZTF6c2paZCYjeEE7a25aVXlmMGxYcld2L1oxRlhUdjFuSHg4YkZXVGhQcGIxeTF0Vk5t TkhVNzJQYVBTb3IzdXc2TWgzcVZZdWJWKzByYzMrbjA1T1JoNSYjeEE7K1ZTejE2cmNmRDlMN1RY MEdUNm5wajB2VTNlcFhQcGJOMjNlejFKKzBmby9TOVBkNi84QWgvUTlUN0wrcytrc2VyN2F6NnlQ YSs2NSYjeEE7MVZ0MXo2Nm11aGphbTQzVHE0c3J5cmF2VXgyNWUrejFPbTRtWjZlVmYra3pjUDFP b1kyVWxPOHNuOVQvQUdqL0FNTDl2LzdxL3dBNyYjeEE7OWgvOWkvNkovd0MxVC8yaXJXV2Z1ZDl0 ajA3SSsxeHU5VEkyeDlsM2VwczlMN042Vzc5RjZQcWZzNzEvMWoxLzJ0K3FwS2YvMVBSOCYjeEE7 anAvVHVxWVdWaTVkTHI4WExjNXQ5Ti9xQUVzaWo5RXk3YTZobTZqMWFMTWIwMmIvQU5kby9uZlhX RmZiZ1llTlhTNXYydkt4ZXAyTSYjeEE7cHhzNjV6aS9MRkYyVDB2SHB5dXBPNnQ2VnQ5THNLeWky dkx3djB0dS93RFY4ajF1bFc2dldlcVVkSzZWMUxQb3VyT1JUcHR1c0xxMiYjeEE7NUwyVlZZZEYy NnhyTU9xMTltSjZudnhxV012KzEyK242dHVRbzlVeDZiSzZzRitLNW1Ea1pObEdVeGpiWXRabFVa SHJXdEhUQzdZeSYjeEE7ekx5djFpL3FQbzBzZjYrVC9QOEEyUElTVWxvNnpiZGl1dWJnWkw3Tnov UXBERFc2eXRqMlYrci9BSlErd054bjdidjZQbS9aYm4rbCYjeEE7ay9aUHRtUFhYazNhYW9ucEdJ UTBHeko5alhORVplU05IVnN4WGJ2MC92ZjZWZTVsai9mWGtlcG1WL3JkdHQ2VlBSOEdnczlIMXFt ViYjeEE7TkRLNm1YM05xYTF0bjJwakdZN2JmUWF4ci8wZjgzL1JQMUQrZy9xNlNuTjY3MDZ1bXpP NnNic2lobjJESU4xMWR6Nm0xdXJac3FmNiYjeEE7bERyYlc3YXJjaTJxdjluZFJveDcyZmJjV3JG emJNajlwNkdYbWRTeGMxbTNGKzA0Rm5vczlTb3piVzk5anFMbjJWLzRTcjlOaDIreiYjeEE7K1p4 cWVwWkY5MzZMRng4blA2elZoZE13eFhYZm4xNUdSWDlseG50c3lza0Y3N0dtcXE2eTI3N1BSYmxa RnpNV3ZMeWN2Qnl2U3M5SCYjeEE7RjZsaWVsNnRHbFQwakVwTEN5ekpQcHREVzc4dkpmbzJ6N1VO L3EzdjlSL3ErMzFMUGUvSC9VLzZKK2dTVXhaWjF4MU9JNzBjZHJ6WiYjeEE7WDlzYlk1ekhlaWF2 MWg5YktmdGRkT1hWbU85bU45cHpNZDlGWDlPL1MrcFZZNmhoVmRRd3JzTzR1YlhjM2E0dGlmOEFO ZUgxV00vMCYjeEE7bEY5ZHVQZXo5RGswM1VXV1ZLdit3OEwwL1M5VEwyK242VS9iY3JkdDMvYUo5 VDdUNm5xK3AvaDkzcitoK3ErcDltL1JLWDdKcExybiYjeEE7UHZ5WGk1em5CdjJpMW9ZSE50WTZ1 bjBySzNOWnV5YjdXZm4xUDlEMHZUcXdlblY0aVU0dlNMWFArc0dKY3dOOURLd3N4eE8xdGNYViYj eEE7Wk9IVmxlbGhnV1B3R1haRmwyWGtWM1pWdlVMc2pJOURxMnk3cHVOVlRZK3N6WXRydHlNZkh5 Y050YkszMFgwZXVMRzI1ZUMzSzFkWCYjeEE7N0xhS2EydndjS3U2Mi9xdVpaK2l3N2JlbjFlcXFu VWo2NFVOcmJZNE93TXNoMXd5UTVoYmwwZXMybCtWYjlqZlZmWlo5R25HOVdxaiYjeEE7SHcvVHYr d1c0ZGFYWDYzMVpOOTRwc2RWazRqS0xuVTFPekM4TnZZMWxXVDAzN00rdTNFcHJ6c2oxL1F6Nk16 Snc3ODcwc2V5ekdveSYjeEE7Y1JLZEQ3Uy85djhBMlY0OW4yVDFhQ0hPYnI2bXpMOVN0ejIwNUgv YVAwWDAxWFc0ZjZmN1RaamZic1Q3WG1aTG5EcjFiSE9kTnZVYSYjeEE7bVZXMVd0c2F3TXdjakpm ajJZMlo5c2JoNUQyMTNmYVBzRkhUbjNZV2ZoMi9hN0xmdEswM0c4ZGZyRGJObU83RXM5U3B6d2ZV ZTJ5ciYjeEE7MGJNZkgzT2UzN0l5eTl1WmQ2ZFBxZmJzRCtrK24rcVptVFRWWDlaY2V3c3VJdnph OWppQlZXTDI0SFVXMkZ2L0FITVo5a2JVMTl2byYjeEE7MTJlcyt1cjlwNVZXRit6c0JLYkhUMjRE T3JaWXJaWHVma05zcXN4SHVjQ0N6SnF0cnoyVTJQOEFSOVBQbzZ1L1pmVlYwNzdaZDZsZiYjeEE7 cWRaZmxLZjFod0xUajJkVHdMMjRYVXNhbXdNeUxMVFRSdDJXc0R1by9vOGlySXg4SDE3TTJobDlQ NlBJWi9PVTEzNUNMalkyYS9PdiYjeEE7dHlLMnRyWmsrdFM2MS9yNmVpN0Uvd0FudDIwL3M5bnBl aSt6ZjZyL0FMUmYxWEg5TDBMS00yK3hkaVg1SG9DNjJ0ektzZzNXMStrQyYjeEE7MnhqZlVkaVZm cFhXK2xialhmWk1uN1RYL2g4VDJWMCtyK2pTbWwwUHBPUGkxVnVmZ3VvdkxXWk0zUFprT3F0dEY3 c2pGcnppWFptUSYjeEE7K2kvSnpiYkw4ai95eXY4QXM5M28yZWhSZHljWmxlQUtjYkhyY3pHOU4x T01LMmxzVU9aYlhUajFQc3hxYXJmMFczRHNkYlhWalgraiYjeEE7ZC9na1VmYW4wVmsrblRrSFli VzYyc0dyVGtWMXUvVm52OW5xVjAzT1l6L1RlaC9nRlh5UDJoOWl5bTJWTnlIRnpoVXpIc2RROTlE byYjeEE7K2hZU1BzK2JYVTZ5dXI5WlpYZGRWVmQ5cHdQWC9VMHBwWDlQK3lQdHlPbTlOeE1mcWVk NjFaeTZ2Wlp1YzcxYTdMc3BuVDh2YjZ0TiYjeEE7ZG1WYS9McWZSOXZyeDhUOWI5ZjFscTRtVlJt NHRPWmpPOVRIeWEyMjB2Z2pjeDRGbGJ0cncxN2R6SGZuS1lOdnF1QmEwVkJyU3g0YyYjeEE7UzR1 SmY2alhWN05yV05iNld4L3EvcFAwbjZPdjAvMHRTaW5xREcyc1l6R3hXdnBENjIxaDFnYmwyT3Z0 elgyajlVKzBZL3F2b3NaLyYjeEE7Ujc4aC93QnA5WDB0NlNrMmRaVlhTMTF1N2FicVdqYllLanVk Yld5cjlJNnlqY3oxWE05U2pmOEFyTFAxZjBjajFmczl1SjA0MFA2MSYjeEE7a1U0emNZMXM2amZr dGRRN0dCR3pFeHNYTTlXdXBsdVUvTi9hR2RaNjcvMEdReG45SnkvUXN4c1BPM2ZUdmRYdGZkdGY2 bTRQcWFHKyYjeEE7d1A4QVVaU1czZmFQcFUvcTk5bjUvd0NrdG8remZvL1N4Mk1jL3dDc0pjYW1z OVBKdGNHMk1idXNZY1BEWTdxT04ra3cvWlJhL3dEWiYjeEE7MXVVL0g2dmxmcC9zbGQrSmlYVzEw cFR2S3A5bS9XZlUreTQvOUk5WDFwL1NmekgyZjdWL00vMHYvdEQvQUR2OUIvN1Uvd0RhTlcxayYj eEE7K2ovbEhmNlgvYS9mdTlQL0FMbytsNnZxZllmK3MrdjlxLzdyZnRQL0FMeGtsUDhBLzlYdi9y QTE1NlBuc3luVm5BdHJzYmwyUzZwOSYjeEE7T0dhaTNMdXIyVlozMnJMcS9TMjAxK2pqMXY4QTV2 OEF3WDZlcmx1TCt1K242OW5yVlpHSSt2SGNhUTRWdXJ6R09zd3Z0RGI2YktydCYjeEE7bVo5cVpV M0M2MTZHTjFHejdYZmkvczdFV2xreWNmTkdQVmRmWTV3RnRYcVdVdWRMS20yZlliN0N4bGIvQUxQ L0FEUDJhMmpIKzIveiYjeEE7bVRqWC9hY2l1bG1ZV016S3N6ck1MSGJiYmw0MVRzelpSWGM2b0hG ZFQrbXlQdEgydjlmcnBwMldmWWNuMDJmcUZmMnpHd3JNdEtkdCYjeEE7SlFaZFZZNnhsYjJ2ZFM3 WmExcEJMWEZyYmRsZ0gwSCtsWlhaL1VzVTBsT2YxNmhtVjBySXhiS3ZVWmRXOEY1cGJsTnFMV1B1 cXlYNCYjeEE7Tm03N1o2VjFkZnA0OVZWOXRsL3Bmb3Y4SlhkcHRiZFV5MWdjRzJORG1oN1hNZERo dUcrcTBNdHJmL3dkak43RlM2L1JUYjBmTU5vciYjeEE7bXJIdWRYWmF5cXdWdU5WdFJ0MlpycXNY K2F0c1kvN1JiVlErcDlsZDlub3ZzV2drcFNTU1NTbm42cW5zK3R1TTZ5dXlwLzJUcURSdSYjeEE7 dWRjeDdQdEhUc2l1Nmx0ai93QkR1KzB1WlpYNlZQcGVuOWxyOWJDeGNLMUIrc2ZxVWRTWmtWK21I UHJ4YTJNdDJIMWJCbjRneG1NciYjeEE7OTFucFZXWkd6THpyNk1oL1N2dGVMazlIL1diYzZxKzlr UGNmcmZnVm10d2EzcDJZNFduYnRjWFhkTkRxMis3MWQ5ZXozNzY5bjZXdiYjeEE7MC9VL1Mrblgr czJQbFhXMTErcHZ3N2EyQTRqM0dsbjJsbVhndXdybWRRbyt6M1lsdjZTeG45TzliK1p0d3VtZFF0 cHV4N1VwdXZ0YyYjeEE7L3dDc2xOUURXdHB3clhFdmEzZFliYmNkcmZzdHNlcTVtTDlsL3dBb1Zz ZXhuNjMwMzFQVi9SZWpuNUZGcnVyR2wxTGFSYjFXbkphOSYjeEE7eFBwM1Zzd3RMYks3WDdNdkly dndMSzZjWEZkVmRoWFkyRDFlM0c5S2o5YjZBMU5OcmJTWGJtTmMwQU9jR3c0c2M3ZFZQcFBmK2o5 bCYjeEE7ajJiNi93Qko2ZjhBTzJybjg2dG4vT0N0bnQweWNYSnVGRmVRNjNhK25PdzhkMXZvVjNV MHYrMVk3VzM5UjlYRjlicDMrVGVvL3FsTiYjeEE7UDI5S2VqU1NTU1VwWi9XN21NdzJWUFo2ak12 SW94bnNPM1k1bHRqSzcyWHV2cnV4L1NzeC9WcjlPMytsZjBMR3MrMjVPTXRCVk9wWSYjeEE7MStW UTJtZzF0ZDZqSCtwYTBQRERVZnRGRm5vUFk1dC82elZRMTdQVnhMZlM5UzdIeTZNbXFsSlNMb09W Zm1kTVprNUR0MXRsbHhjSSYjeEE7QTJBWFd0Ymp3QXgvNnN3ZlovMWlySHpQMFg2N2k0bVo2K05W VTYzMUorSGtzTzNIc2JSNkYvNlpqZytwanIyWVhVTTJxdy9vWDFVZCYjeEE7T3lzaDJUY3l5cjlt Zm8vdGZyWTNVUDBWdm9HTGZoOUpveEwyK203SDMxc3FrT0RLbXZlM0ZvcnNhZDExVk9ONlZWT1Jk NmVUa1ZmcCYjeEE7OHFtakpzdHBycWRaNloxQy9KT1hndjhBVHUvVmE2N0d0eDNQWUJlNXVia3Mr MTR0ajJXNC9UY25MWmovQUsxZFYrdFpYNmw2djlJUyYjeEE7bmJYTTRySzdmckhkYmp0c3lBM1Bl KzV4YStvWTcyNFZPSGUyNnJLbzlHM2RzNmMvQ3lzYTVtVmZWMURKK3pmcUZHZjl0NlpjL1MydiYj eEE7SStzWDJpdG1SYzZqSXRhektEM3Z4MjFuSHB4ODdFWkZtTFJYNmVkaTR2cVVQcjZtejdYNnYy ZjlacjZsK3gwcDZCWi9xVi9iZHZxViYjeEE7N3Z0ZTNiOXFmdTNmWmQvcC9aWTlQMWZUL1MvczMr WTlEL0svOUpXZ3FucDUvd0JwM2IvMFAyamR0M3QvbWZROVBacyt5N3Y2YitrOSYjeEE7TDEvVS93 QU45dTlML0pxU24vL1c3L3JPTmpYZEs2bFEvSHJyT1I3V3V0cm9zYmRlNWxWZUhjS2NteHVQa1cv YVBzMk5SWG5QbzlTLyYjeEE7SHJxL21mUnRXYjlZc3JxR0c5N2VsVnVPVmZrdGVIYlhNbmJqK2xu YkN5bXV2S2ZqNEhwWldKK2orc1dSZmtWNUZWWFNyZjJYK3FhdSYjeEE7YlNNbkI2eGo0ektmWHRi WldmU0ZkejNXT3g2Z3o3WGo1SG9ZN3NqWTZwamNmS3U5RzNGK3plcmV5bTM5RkRyamJEazlITlRO N201NyYjeEE7U1hOZXh0alcraGxDeDlMY2l5dXU3OUh1cnlhOWw5LzJGK1ZkaTFmYWFxcjZVcHhl a1kvMWd4Y29OdXdJeGZUYXpJcXhYTmI2VnVHYiYjeEE7OGlqRzZmZmM3cDkxblN1by9hTWEvQ3Fz eXMvRzZmOEFyZlJyNk1iSDlYN0x1czZoZGpWVTFIcHViNmJYWTlBZVhWWE9BdUFZNjI1MyYjeEE7 MnUvSXNaaFA5bWZlL3dCUi93RDJvciswMGVya0xUU1NVNU9YbjVtVGdYTXgrbjVlKzNIY0duOUhX NXRwY2NaMUd1ZGczZXJUL1A4QSYjeEE7clkrUlZqWFVNOVRDNmo3NkZYNmppVzlaT0prc3F5YUs2 WE5JWSthaTZ1NndWMjNWZWhtWU9iZzV0T05UNm5yMk85YW5BenNyRSt4WiYjeEE7T1JrWk9GVEg2 MzRGK1IwNi9MYmtWME13OGU1NGZZMFBZd2Vqa0MreStpNmpxTk9YVmIrZ29jeXZEcHpLY1g3ZDZP WFo5cXN3N3VnUyYjeEE7VTgreHpLcTZ3L3AzVTZ4aStqYjZWVDJzWlZVMStaNk5UY2ZwbVV6Rnlx c09xdmJkaFlsZVhrNUdMYjAzMTZNMjcrYTBHOVV5WGx6VyYjeEE7OU15NVpJZlBvTkFjS2FzdHJH dXN5bU11OVI5LzJKdG1QNnRIMnltLzFiYTZXZXVydHozVjFQc1pXNjV6R2x6YW1iUTV4QWtWczlW MSYjeEE7ZFc5Ly9DV1ZzVmQzN1ZKdmF6N09BNndqR3NPOGxsZm90MjJYMCszN1JiOXYzL29hNzha bjJQOEF3L3JmVFNuTWRtQ3o2MlliTGEzWSYjeEE7enFzYk5wYTIxMVpMOTltRGJqV1ZpbTI3YXpM cXdjNnpIcnU5TElzWmc1bjZEOVhzUXZyRFVEMUZocm9hY3ArTURUWlMydCtXNzBzdiYjeEE7Q2U1 dFl5dW41dERHWXI3YWJhSDM1bE9QNjkvcTMxNC9vL3RUQjFhc1MxM1V6bjNzYXh6S1hVVjdiRFlD MTFwZlBwMlUxL1ozK2xWaiYjeEE7dnMrejIvcDMyZWpsZmFQMmZnWkNqMUxvMUhVYnFyYmp0Tk5i bTEyTm4xR1BOdUxtVTNWT0xqai9BS0hJd0tiZlR2eGNqMVhzci93UCYjeEE7cjA1S1U2QzUvcUxy cXVyTWEvSWltL0x4TnRRdnRBb0d6SS9Xc2x0Vm1QdHE2cGRRenBPUGdXUC9BR2Q5czlMTC9Xc3JJ eU1OZEFzbiYjeEE7SzZabXY2dFRrNDk5bFdNYkdXNUFiZllETlRMcWZSR0xlek13cmNUS2JjejE2 cUdkTnRxdHArMmZhTW5JOUw3T2xPc2tra2twU1NTeiYjeEE7OHV6WjFucDdCYlkxMWxlUURTQnVy ZXdDbDduMlZzZTJ5cTJxeHRYbzVyNnJNV3BsbCtIWjZlVDFEQ1NVNkNTU1NTbExuTU9zWlhYWCYj eEE7NWJlbnRaWlJtNU5kMlFQVHVqOVh4cVdaTHZ0WDJYcUhUY2krcW5Ib1pWaVUzNDkrUDZsMW4y akh6TUxxUzZOWmc2TzQ5Yi9hNzdtbSYjeEE7eHJYMU1EYW10ZjZEMjBSaFdYeWZWeDJaZE4rZC9O L2FQV3U5T3ErbkgrMFU1aVU2YXovc0ZuMjMxOWxlMzdYOW8zZXpkdCt5L1l0LyYjeEE7OUU5VDFm VS9SLzBqMS9RLzdYL1p2OGxyUVZUN04rcytwOWx4L3dDa2VyNjAvcFA1ajdQOXEvbWY2WC8yaC9u ZjZELzJwLzdScEtmLyYjeEE7MSs5enN1bXZCNjA0WmxOVDYzR28yWkZsdEZWTnI4Zkg5Q3U3SjlZ T3FZOTExRnZxOVA4QXMzOUkvUi9yM3JYV3I2d21uMXVqdHMzQyYjeEE7eDNVYS9RYzFsdGhEeFZr dmQvUkw4VjliSDBOdXFzdXQrMVl0YkxQMXZGK3orcFpWWXZlUHMzVk5uNlZ6TjAxMVgzT2ZQb1ZP OVA4QSYjeEE7Vm1XWlBUN1hOUHNwd0s3cmY1dk5wL1djcFYvckM0VjNkSHU5UnRicStvMWhvZDZj TzlXckp3MzEvckdUaGUvMHNpejAvcy8yckkzLyYjeEE7QUVNTEpTVTdDU3o2T3Q0dDJiOWgyV050 ZHY4QVRkQWV4L3AyWkdQZnN0eDNYTWI5bmZpL3JQcStuOW0rMllPUGtlbm1aUDJaWGFiVyYjeEE7 M1ZNdFlIQnRqUTVvZTF6SFE0Ymh2cXRETGEzL0FQQjJNM3NTVTB1dGRSWmc0eldsL28yNVhxMVVY bHpXTXJleWpJemZXdnV1WmZYVCYjeEE7VXl2RXMvU3V4c3JaL3dCeDdLMWRwcHFvcVpUU3h0VlZU UXl1dGdEV3RhMGJXTVl4dnRheHJWWDZzNTdPbFpqcTIyT2UzSHRMVzBoeiYjeEE7ckNReDIxdExL TGNhNTl2K2piVGs0OXUvK2J2cS9uRUxJNjNpMVBvWlN5ek1PWGp2eWNZNHdGZ3NZeDJOUzBNZnVE UDB6OCtqMDduZiYjeEE7cXJLdlV2eU1paW12MUVsTnJMY3htTGMreS83S3h0Ymk3SmxvOUlBSGRm dXZhK2x2cGZ6bjZabnBmNlJHVkYrWlZuZE1yc3dNdHVPNyYjeEE7cVZQK1Q4bHpRVHVzcWRmUmJY ajM3UFdmWFUzN1I5bmYrWlYra1N0eU9yN3NodVBoMHVGYnR0RHJzZzFpMGJjZC9xZm9jZktkU3pk YiYjeEE7bVZlLzM3OFNyL0JaWHFZNlUza2xSL2FUcStvVllHVlE2cDJRMngxR1FITmRRNDF1TzNH M3U5Tzc3YS9GL1cvUSt6N1BUWmsramZmOSYjeEE7bHRzVjVKU2tra2tsTUxudXJxZll5dDF6bU5M bTFNMmh6aUJJclo2cnE2dDcvd0RoTEsyS0RjbXQyeUJaK2tzZlUyYTNqM005VGNYeSYjeEE7ejlI VitoZjZkOW42Qzc5RjZOai9BRjZQVXplcWZXYkg2WmJqTnZ4TWwxR1ZkOW5aa3Rhd05Gb04wMCto ZGJWbld2MjQxbGxIMmZFdiYjeEE7KzJmb2ZzUDJtNittcEJaOWJjZXlxNjJyQXpiUlJUVmtiYXEy V3VleThaRGFYNDlkRjFqNzJmYU1PekY5V3I5RForaXpLYmJPbC9yNiYjeEE7U25ZKzAxK242c1di ZlU5S1BUZnUzYi9zOCtuczlUMHZVL3crMzBQUS9XdlUremZwVlhzdWI5b2JtZWk1MVZGT1MxOXZv T05yU3g5SSYjeEE7TlZPdjJ0ekwvUXNleXZIdzhobWI2TkZyTHY2UDlycGRPNnZZenByRy9zbkxx T0x0eG5VTW9aU0JZM2ZWc3hzZjdUYXo3SnZxbzlLKyYjeEE7bSsvQnFxeTZQMXowY2ZxRjJIWDZm OVpTeWtOeU1ETkRyY25KRlpkVFkwbXNXNUY3WDExZFFlekx1ZlhnTnB5dnNtTlhaYzlsbnBkTSYj eEE7eExQc09aallLVTdaeTNBdGFjZTcxSHVjQXdCcDlqYkdVT3ZkZHY4QXM3R2JMUHRUS24zZmFy TWYxUFR4L1hxdG9VcjhqMEpjNnV4MSYjeEE7VGEzMlBzcmJ2alp0L1Iralh1eWJiYld1ZDZUS0tM ZjVyL1NlajZ1TGkvV0c0UHpiYnVrNTdjZHRqTEs3Mk10dEZsYjNWNFZiNjhMSSYjeEE7YlJuNDl0 ZnAyWFplRFRnN0thcWJNejlQOXNvc3lwTTY3bE02aGQ5cDZMMUhIcjlHb2kwN0wybjNaRHJHdG93 c2pLcFkrbWxqNzN2cSYjeEE7L1dNajlIaStuOW8vWk9QbXBUdGkxcHRkVUE3Y3hyWEVscmcySEY3 VzdiWTlKNy8wZnZyWS9mWCtqOVQrZHFVMXpqZnJKbWpxT1U1MyYjeEE7VGVvdXc2Nld0YlVNYjNO dnFyeXN6SzJ2SmEzSlprdGJUZ1kxbUxkbFkvMjNIL3dWT1hoNU9kcTRYVjhYTnhUbFZNdWJXMjcw SWRVLyYjeEE7ZHUzaW1kald1ZHMzTy9UL0FQY0w5TlRuL1pjakZ6S2NkS2J5ei9zamZ0dnEralpQ MnYxdCszSDJ6OWwreSt0dWo3VDZXMzlYOVQvbCYjeEE7SDEvMFgvSkt1aTFwdGRVQTdjeHJYRWxy ZzJIRjdXN2JZOUo3L3dCSDc2MlAzMS9vL1UvbmFsUyt5TisyK3I2TmsvYS9XMzdjZmJQMiYjeEE7 WDdMNjI2UHRQcGJmMWYxUCtVZlgvUmY4a3BLZi85RDBXNnZKdXA2alZqRGJhNndOYjZsbDdXdkJx bzNpdTVvcWZoYjJiNldYOU8rMCYjeEE7VlkxLzY1K2x6UHRXS3N6Nnp0NmcxdlR5N0piVUg5Um9y WmRWanVMcXZWZGtVaHo3L1V5UHM3L1N2eHNlbTcwUHM5K2Irclo5WDdMNiYjeEE7bmtZK1BkeWFh SDQzVjZNaXVzMVpsbm9sbHJqUXkwM1VZMkpYVTdKWmoxV2ZwN0hOeHZXcmYxQzMvQlZYK3BYOWd4 WS9XRXRGM1J3NyYjeEE7SnB4UTdxTlkzWEIwdlBwWkxtNDJQWldhM1ZaRjdoNmJmMDFUTFdlcGpX L2Fxci9zR1dsTmZGd0srcTR6YzNwWFdNZzlNekt5SzNNcyYjeEE7ZSt3VnZvT0RZeW0rK3gzbzIx M1VZZVl5eTZqN2RpNTlPZjZsditVTWlxc0p3dnJKazBnMVBzd2NpMzBiQTYxNU5iWFZaTk9UbDE1 VyYjeEE7TFhtWnovMHpQdGYyTm1CMUQwTHNESi9aZlVQUSt3NFZ5Mk9qMDRWZlQ2cmNOcmhYbE5i a0YxbHZyMk9MMnQydnV6UFZ5dnRUMjFlbiYjeEE7VTIzN1RlejBhNjY2YmZRcnFWNUpUem5WY0d4 emNySGYxaDJQWmJUWUthYVRlYjZ6WTdOeldYNDFWR1g5cnlNajlYbzlLcjlLejdQMCYjeEE7ck94 Y0hIeDhmTXZwb3QwOUw2czl0RDh6TWFITWRYZFpSU2J3d1hCekxzbjA3L3RWV1JmajJ2c3phMlky VjZtR3luOW5mcVg2amQ5dSYjeEE7cWRiNkwweDJWazUyV3gxdnFZMlErNjJ3VlBEYXEyWXdaaE4v YUZGblRHWTdjaWx2VTZmdHVUVDZPZlhiZCtreEwrb3JvS1JhS21DNSYjeEE7elgyaG9GajJOTEds MGU5ekszUHRkV3h6dnpQVnMvNHhKVGhaZlNPcTQrSzJ2RHk4aDg0L28yc3JMN0hPZTBaR1M2NzF1 bzlRKzBVKyYjeEE7dGtlbGkxZWhsL2FxcUx2UnN6UDZEMUhveWZWbXR4Y3ZxZlVzbXpEdy93Qkps WDQxZ3NGdERHRDdQYTJ1M3BuVUxXZWwrektuMk1xcSYjeEE7OWIvS2x2N1Y5bHZwNE5YUUlPVmpN eXFIVXZPM2RCWS9hMXhZOXBGbE45YmIyVzFlclJhMWwxUHFWdjhBMHJFbFBLOU9zKzFkZHB6TyYj eEE7bjlWc3U5YXg5ZDNxVlM5ek1hdWpHemVtOVN3ZHVKa1lGdEdSWCswTUxOYlhUaTQyVjFQTG90 eEsvdCtOKzB1cXhtNVRXRVpWbGRyLyYjeEE7QUd3NnFzMWo2TEJaN1gyNUgwcnZWc1o3L1pVK3Vu OUo2WHIyODcwL0ViaGRVNkRYaitzM2ZoWlc2aXdPc2JWUkhUdHRMYk1xekF5TSYjeEE7Wm1JK3JC eGFXZnM2M0l2L0FFdHViUlZsMlpPV3VpYmsxdlpROEN5TW1QVEJyZUNKYTY3OU94ekEvRzlqUCsx UHBmcGYwSDg4L3dCTiYjeEE7SlNaSkpWNytvOVB4N1cwNUdUVFRiWTVqR1YyV05hNXpyUzl1T3hy SE8zT2ZlNmk3MGY4QVMramJzL20wbE9UZmRUaDlVeEd2cGE3MCYjeEE7M1pybkhHb3RaYzB2RE00 MnNwcUx2dG1FK3F6MHVvV1YvYVdaUFhMT20vb2E4djhBUjQ5NTNWL1RMVzNZV1hXVEJmRlhxaHJU VGJsNyYjeEE7M094SFpESDdINDltRTZ1bjFiL3Rub2ZvdlJ5OFMrK3ZrUTNySFRxY2w3WFcrdGsy WWpyTHF3WFYrbCtrWTNETlRIV1pGTHNqMGFmcyYjeEE7MWZyVTRGRnR1UjFUOWF5TUxPMHZ0TmZx ZWxGbTcxUFNuMDM3ZDJ6N1JQcWJQVDlMMC84QUQ3dlE5ZjhBVmZVKzAvb2tsTmY5cHViViYjeEE7 YTkrRmt0dHFiVzRVYkd1YzgyZ2JLNnJLYkxNWGV5N2ZSa2I4aGpNYjAvdE9SNmVCNk9YYmxmV0xx Z3BHSGtPeHJtUHc4MXhidTlOaiYjeEE7bnVaWFkwWStGNnQzNjVrZFR4TDdLOEtyRng4NzFmMG1I Yit5ODc5YzZmMERMV3ZkWTFvY0RVN2E3YzF6UVNXdHMvUnVlR3R0WnRzLyYjeEE7bkt2WnYvUmZ6 dGRpeXV0VzJXRHA5bEl5VzExWnBkZWFtM2lHWTllVlpiNitQamhtUmxZOXo2UFJ4Ni81bkl5TGNP Nzllby9WTXRLYiYjeEE7dG1kWXpLR01NUElmdWt0dWFHZW50YWNaam5tdzJ0MmYwdDd2VHMvVDJz d3MzMGFyUDBIMmdWZldhM1NiTVhMcVo2WXRhNTJPOTI1cCYjeEE7KzB1YUF5Z1hXc3Q5TEM5WDBM cTZyMmZhc0xIc3IrMjVIMlZXblpOYmQ4aXo5SFl5cDBWdlB1ZjZlMHNobjZTcjlNejFMNi8wRlA2 WCYjeEE7MXJHZWhmNmN4YTAydXFBZHVZMXJpUzF3YkRpOXJkdHNlazkvNlAzMXNmdnIvUitwL08x SkthbDNWRzFOdmNNWEp0RkZObHpkbFRpYiYjeEE7RFM1OWR1UFExMjEzMmpjMW4yZHRucE16V1hW MjRWbVJWNi9vNFdIVGZqOUY2blRqUHJweWYybTV0ZHdqR3ZmYSsrZ2ZhT291ZFo2WCYjeEE7MnZM dGY2MVQyVjI0MlIwKzdCOUhvdVJqMi9zV3pwYThtdTMwdG9zSHIxbTFtNnQ3SWFObWx2cU1iNkZ2 NlZ2NkMvMDcvd0NjL1IvbyYjeEE7YnRuTzlQd0hYOUg2bjA1aHVKWjFHeGxSZTFvc1pGdFZ0Tnoy MlpsbHV4bnN5L3RqTGVtOVV6YWY4cTQvK1ZNcXZxT1NsUFFNQi9hRiYjeEE7eDNPSU5OUTJGdGdh SWRrZTV0am4vWkhQZCtleWlyN1JYK2orMVdXVldZZnBVZjFQOW8vOEw5di9BTzZ2ODc5aC93RFl2 K2lmKzFULyYjeEE7QU5vcXZNYTM5b1hPRFdoeHBxQmNLbk5jUUhaRzFyc3orYXZZM2Q3TVpudnhm MGx0bjlNcVVQMW43VC8ybzlQN1Ivd0hwK242SC9zUiYjeEE7OWsrMGYraDMyNy96V3BLZi85SDBV WTNyTjZyVHNyL1diQzM5TlZ2cmR1eDhlcWJxdlN3L3RkWCtEcy9XY3JlejlCOXRxL29tSFgrcyYj eEE7elJkajRtSTdJYml0eThsdFhxdWZXd2J3eTI3RmJ0dTIzM1BmbVU0L3AxOU92dytwTWY4QXJH Sm1ZL29iMW9ZekhOdXkzT3FiV0xMZyYjeEE7NXIyc2EwMkQwcUdlclk1bGxycm43bWVqNmxyTWQr eW4wZlI5S3F2SXZxZGJmWXgzVG5OcnV0ck9iVTIxdEhyaDRhNXRqR1dPK3h1ciYjeEE7WjlucXZk VGJsL2IvQU5TK3krdC9PWkgyYXRKU0w2czRIVWNMSHkvMmc5MWx1Umt1dURySFZ2dElMS3EzK3Jm ajA0ckxtZXZWZDlpLyYjeEE7UXNmWDA3N0ZSNldONlAyVEgyRlJxeExlbmRPT1AwMWpiM1Z1Y2FL YjdEVXhyWDJHejdPMjJtbS8wY2ZGcWY2T0pVekgvUjAxVTBmOCYjeEE7SWhZdWIxZXpxRmpMOE5v d0h1ZFhqM1ZPSmMwMU91Ylpibk15MjRWckdaTzJqN0l6Q296V2Z6dHYybjdOWlJha3BGOVpLbTFZ bG5WZyYjeEE7WE1kZzQyVjZ0akhPRGhRK2wxdHpXVjFtcDlyL0FMUmpZZG42TE02ZGtmb2YwWFVL ZjBsT1JzTE02dXkyN3BMaGRRNTlycWJQVXJwYyYjeEE7YksydU5GelhpeGpxYkhaMlB1ZDZOZFg3 THp2VXVzb3UvWm5zL1IzY1IyN0ZwZHZzc210cDlTNW5wMk9rRDMzVStuUjZWcnY4Slg2RiYjeEE7 T3gvK0NyU1VtU1daaFc5VWYxVEtia3NjekZyYzhVbGp3NnM2WSt6ZTIzRXc3OSt6OUxWOW15T29Z L3JYZFFveU1uOVh4S2xwcEtlWCYjeEE7eitrMVVadlRlbll6SFcvWXVuZFJmMC9qMWEzTit4NFdO VlRmWGJnWGJLc1hOc3htZnIyUDZ2NkMvSnl2dGROZWJYWXB6THJzUDZ0WiYjeEE7TkJ5RGpYZW5i ZlkxdHI5ekxNV3lxbXJLWXl6UHlHNzhqSnB5ZlZ5N3JzV243SzkrVjFEN1I5bSswUzZ6VTdJNjNo VWlsdGxqY2JMZiYjeEE7ak9iWTJ0KzR0WlJmNm1SOWtzeThISGI2Mk5YOXI2WG5zemZXeVA2RmtZ OU50dEpzakRPTmQwVnJMTHJYWUxpeTNJZTJ5MjIyZzFIQyYjeEE7Y3kvSW9xZTF6N3M2N3ArWGtl djZWYi9zdG1iL0FOb2YwU1U3QzV6NjBaRGErbzlKcmU1MjExekhiV2Judzc3WDA2bXUyM0dmYlRn MyYjeEE7WSs3STlEMUxXWkdiaFpHVGk1M1RxZjFmSXNyNk5ZbldxUFU2eDB1d2l0d3IzN1ladnZZ NDI0WDZ4VDZUcXN4bUo2YmJjSE5zb3Q5QiYjeEE7bjIvRy9hT05rWUgyajAwcG5kWlpqZFF3MnNv ZFRYNjFvdkdONjdxeU1sMXJxSDJWVTRWbUxhKys2cjdWbTMyWFlqK21YZjhBYXkyaiYjeEE7TS9Y YkR1czF0TFp4Y3ZZNkhCNHgza2VtNm0zTEZ6cTJqMW0vMGV6RWRqT3ErM016UFFxK3kvck9OWmJV WWFHOVd4MldXYkxiTWpLZiYjeEE7aG05NTlWMWJXTVptWWxGZHpzVEw5SitXNTJaWFg2ZlZjRDdO aTFYVnZvci9BR1Y5azIwbE9lN3JOZFc4Wk9MbDBQcnJaYVdqSGZmTCYjeEE7WCttMkdQNmVNeXA5 dGR0dnBXVU5zOWY5RGJrZW45aTJaVDgvcjJWNi93QmpZTUxJdHV4czlyeFVhTjgrajlHMnJJZmg5 UndxL1diZiYjeEE7VTdIdmZsZE0vd0FJeXpxZlQ3Y2JOcnE2QlpQMWhkV3l2QXRlL3dCTjdNL0dG VGl4N203ckgvWjNNZmJqVjJXNC9xVlhXMTEyZXBqMCYjeEE7VzMrbGlabHYyTEp5TWJJU213L3Ex TGFqZjZHU2FHdERudkdQYVhBdUZMcTYvc25wL2JyWHZiay80REZ0WlI2R1RYbGVoZFQ2YW4rMCYj eEE7YS9XOUkwNUFhZEcyK2k4c0xoYjlrZXoydE5qTmxocnM5UzJ1dWkzRnMrMTQ5dDJOVGxXMFcw a2xPZlgxZmZKZGhaZGJhNnhaYzUxWCYjeEE7MFA2U0xLdzFqbjJaVnRWbUg2ZXpCWmxlcjlxd3Jz YjE4YS8xMWlkQTZsall2U09wWnd5ZjFZOVh2MjdxcjdMbWV0a3NZL0R1NmMxOSYjeEE7bVJqNWRt UmRaWGpWVlYxL283c1hPeU1MN1JkbFVycTF5OXVUWWVpZGMzV05yT0xtMmpLYzlsK1d3WTRkVmtY TnZ3dXF1eHYxZDNTNyYjeEE7UDFqRzZmYy9HOUgxTCtsZnBicThkSlQwVGJKeXJLdlZyZHNycmQ2 QUg2UnU0MnQ5V3c3L0FPYXU5UFpUK2haNzZMLzBsdjhBZ2F1NyYjeEE7RisyeDZlSjZ2MnVOM3FE MWZVK3k3dlUyZWx1L2FIMmI5RjZQcWIvMlYrc2V2NmY2cWkxMldIcXVSVWJkMVRNZWh6YUlaN1hP ZmxOZiYjeEE7YkxYL0FHbjlNMnV0bjZXbGxINkQ5WHN0cysxZWl0LzZ6SHJaSDlJMjdQUy9SL3pH L3dCSDFmUS9vbi9hajdUNjM5Ty9VL3RYL2FGSiYjeEE7VC8vUzlOeG1PYmRsdWRVMnNXWEJ6WHRZ MXBzSHBVTTlXeHpMTFhYUDNNOUgxTFdZNzlsUG8rajZWVmVSZm1mV25DYm4wNE9LNXRkbSYjeEE7 L0xiRmR0T1BrTWNSVmtIMzA5UXNwL1JWL3dBOWsvWWY4by9aYXI2OGIwOTc3NmREQ2F3Wk9lV3Vy SmRrTkx3d3RMZ2ZReG03YnhYViYjeEE7VTlsdXhyWGJiN01tMzBQUi9UK2o2T05qMHZyRTlyWGRL YTYybXMyZFJwYTFtUTl6YXJEdHRmNlcxbGRyYnNqYXoxc0N1MStPejlvMCYjeEE7NGwzcmVyVlhq M3BTdWs5SjZMZjA5bVN5akd5cXMxdnExM0RHcnEzWTcyMjE0RkRxdGc5bUwwdkovWjdQVS83VCtw L3BiSzFZUFFPaiYjeEE7T0ZqYmNTdTlsdS9mWGVEY3o5TGM3UHYyMVgrcFd6MXN4L3IyN0crLzBz Yi9BTGk0M3BXTUUxR2x4cWJTeHZyWEFpaHdjemNMYlBWYyYjeEE7NXpXVi9yRDdkNzh0bitEeXZX cjlTMytkVmhKVHpuMWt3dWkwdHFzeU9tTkxibk9xdTZqVFZYdnhtV3VmWmRmWllhN1AxZDF1UmZr WiYjeEE7MzJ2L0FDYlppL3REN2Y2M3Jzd2VvVzhmQTZGZ1lXTGZtNG1GZ1d0cGEwbDFWTkFZYTU2 bmJWWHRmZXlwbEY5TnVmNmRlVmV5bDlQMiYjeEE7bjFyUFQ5ZFErdGVVTWJwenJMNjkySDZkNHZ0 QnVkc0pwdFpXNjNHeHNMcWROK0o3clB0RHMrbjdIamZvNy9ReWJmU3FXZ3pwZUEzYSYjeEE7WDFl dTZ2YnNma09kZTl1ejBDM1pabE91c1ora3dzVzkyMTN2eXFmdGIvMW45S2twcnM2SjlYcjIyV1VZ ZU5MMi9aM1g0N0dNZUJRNSYjeEE7dFRLV1pPUHN1cWZoWFl0WHBlblp2eExzV3IwL1R0b1N5ZWs5 SXg4ZXgxWFRjWjlqMnNxYlg2STJ2T3gyQmpWM09wb3ZlekhaUmUvRiYjeEE7ZmI2TmpNWENzdjhB KzAvcUxRcXBxcGFXVk1iVzB1Yzh0YUEwYm51TnRyNGIrZlphOTlsbjc3MU5KVHgrTGtidW9ZK2JT NnZCdHF4OCYjeEE7czV3dVp0WlU2L0g2WjFMSXljckN5YzNGdHdQVHluWTc4cWpCL2FkSDZlejdY bVkrWmxXNUM2SnVhVzE5TzlXNXJiTXh3WkRxTEt6WSYjeEE7NzBMc2x6SzZiSCtyZ1A4QTBMci9B TmI5WDAyVmZaZjUrejFGbFc0b051RHR4MjUyRlMzcUdLY2VnVnVyMlNXVVlKZlhYalV0WTJuRyYj eEE7K3cvcy9MWlYwMzF2NmJuV2RRd09uL2JGaXRMK2wvVlhJM3R0YlM2aDduNDlObXgzcVlXVGlN ZlRUajQ3ZnN1UDZ1Vlcvd0RXS2NQSCYjeEE7eDZmcCtqL05KS2VqV1QxMjZpdC9UMldXVjF2T1hV NXBjMHZlMGJtNDIrbjBzakZ5S3ZWeU1yR3dMTWl2N1ZWK3Zlam1ZdG1GZmtMVyYjeEE7V1A4QVdL MjJzOU9MS21sZ3phQy9Kc0JMYXQxak1ZTmErbStuTHF5TXI3VDlucGZWUmw0Ny93QkxqZFJycndj aTYxSlNWN1hmdGlrViYjeEE7TWJTMHV0dHZhYm0xT3VMYXNlbG1hM0dvcnR0ejJVZW96Q2Y5cnlN Vm1QOEFvN2ZReU5uVDdLOU5ZK1haVlQxakVmVmozT05sMWxWcCYjeEE7cWNLR3V2ZlZSdHZ2YmRs NFZmVW1WWUZWbjgxaDlVc3IremZvZnMxdUcrcXkwM3FHV1hOYWVtNUxRNTFUUzR1eG9Bc2J2dHNk dHkzTyYjeEE7MllidjBXVHQ5Ky8raC9hcXYwaVNtOHN6cm5xYmNIMHJtMVdmYmFJWTUxNE5yZDM2 YW1zWU50VDdIdG85WEkyWkZlVGhiS04rYlI5biYjeEE7OVRJeHlqcUdXUTRucHVTTnJXdUFMc2Iz RjFiNzNWdC9XL3AxMnMreHYzK3o3UmJYNmZxWW5xNVZlZjEyM05OV0s2ekhiVzJucU5iUyYjeEE7 WFdUVzhRLzltV2UxbHZzeU9vMmRQeEwvQUZzRzkrRGRaZGxZMzlFeE9xcEtkNVFmVTE3cTNPTGdh bmJtN1hPYUNTMTFmNlJyQzF0ciYjeEE7TnRuODNiN04vd0NsL25hNjFVZjFETGJVYkIwM0plNE5E dlNEc2JjU1JTZlQ5MlcycmUzMTdmOEFDYlAxUEovN3AvYWxkblp6Uzl0UCYjeEE7VHJyQ3hwZUhP ZlMxcjl0bnBPcXFQcldQKzBXME4rMVkzcTEwNC84QU5WWldWaDIrcjZLVTNsZzlGdzJaR0wxWEdz TG1ZOW5VY2dzTyYjeEE7UGJrVk8rbTIyM2JrTXliZlRlN0w5ZjFmMmZrMTQvMDZyOGJFelB0MkZU b1daMmN5MkIwNjZ5b3RzTFhzZlR1RHF6WkRiSzdicW10WiYjeEE7bHRaVDlpZlhiYi9QZnIxZlQv U1dmOVVzMnJOcTZuWTBPYmN6cU45ZVN4MGUyeG9yaW4xSnNmYStpZzBVWHVkZGRTeklydW82Zlor eSYjeEE7cWNCSlR2TFAyNHYyMmZVeFBWKzF6dDlNZXI2bjJYYjZlLzFkMzdRK3pmcGZXOVBmK3l2 MWYwUFQvV2xvS3Arcy9hZisxSHAvYVA4QSYjeEE7Z1BUOVAwUC9BR0kreWZhUC9RNzdkLzVyVWxQ LzAvVGNOOXRnc3VjWGVsYzV0bU8xNExYTnJOZFh0ZlMrbkh1eDMrdDZ2NkcvMTd2KyYjeEE7RnIv b3VObWZXbDFicWNIRHN5TE1YN2ZsdHhtM1ZYdnhuaHo2c2h6U3pKb3NaK2w5bTdHcHVweTZNcks5 REZzeC93QlA5cXhydlRYMSYjeEE7V3Z6TWlrdGZWa1hNc3J0WUJ0c2FjZkcyV3N0YlRRMjlqbS80 WDFzNzl6N1Y3UHNlSlgrc1FmNkdJOW1SWml2WmwwN0xXN25WYjNrNCYjeEE7OUZlZFJSZmg1R1Jp VzVGMVZYbzFYZjBuN05aay9xVmVTa3BGOVZjSFB3c1hMR2RtVjlRdHR5N0hqS1lXbHo5b3J4N2ZY OU9xaHJMVyYjeEE7Wk5GN1BzMzZmN0JSNlBUL0FMUmJYaUxiV1RrM2RZdy9TR05pMTNzZGtQTmxa dXRzc2ZXNzdYZTl0VmxsSXB4cmZaaVB4MjVkOWVCdiYjeEE7c3M2WjYrTitxWkZ0aC9VTXRyYlhO NmJrMkd0ejJzYTEyTk5nYTZ0amJLdCtXeHV5NXRyN2EvVzlGK3pIdTliMHJmczlkNlV4NjVaayYj eEE7MWRPdHR4N2JNZDlkZHpqZXdVRnRjVTNPWmJlTTk5TlhwVjIrbS84QW5xdjAvbyt2WXpDKzFL MWlVZlo4V25IaXR2bzF0cmlsbnBWaiYjeEE7YUEzOURSdXM5R3IvQUVkWHFQOEFUWXFYVUtxY3ZF TGNrdFpuNGRKeUF5bDF0cnFYMjA1R0o2MWRlR2NUT3lHYlg1ZFZIcCtoZGY4QSYjeEE7OXAvU3lm NXFlTmZaajRXUFhUaFdXc1pqMWxub1ZzeG1memRqdlNxdzh1K3E3RTIralhUOW51L21QdFdQWDZu NkxMdHhrcDBFbG1XNSYjeEE7SFZqbkRIcU5MUGExNXFkVGU1bnBqSUZkdHY3VGI2ZUw5b2YwL2Y2 ZlR2Ujlhdks5L3IyNGlMaVpYVkxiV0RLd1c0OVZqYkg3eGNMSCYjeEE7TTJtbjdQVmtWaGpHL2FM bTI1UHEvWjdjbkhvK3kvMHEvd0JkSlRqNURjSzdyblRUUzMwcmN2OEFhR0xmay9hSy9YZlZXNS9x NFZiaCYjeEE7ay9hL1MrMS9yZE5tRSt6SjZSOW0reWVoZzE1R1I2RzNtWWI4bS9GdWE2c2ZaTERh emV4emlIa2ZaM09ZNnU2bHY5Q3V6YVAwbGQzNiYjeEE7VytuSS93QzAzcFhabGpNM0c2MzAxbnFO eDZMTHMyYThmMjFYc3NiOXJiOXBvdGJzYm10djlTMzFzZkt0eXJ2UnlNaG1MOWx6T28vcyYjeEE7 cmVTVXBabldhc2l5N3BacE54clptdGRrVjBPZXd1WUtzZ045VjlSclo5bnF2ZFRrMzE1TnZvM01v OUQ5WXlMS01USTAxbWRjWTNiZyYjeEE7M3VzYlFjZk5vYzI5MjV4YWJYZll2VHJwWTE3Ylg1cmNy OW5mcGRqTVptWjl0L25jV3RKU0kzVk0rc0ZWTmoydHN1ZGU2cDd5R1BPeSYjeEE7bkMzNEdQWG1l cmJrNDl2OVB2dTZUOW14NmJzR3V2Si9UL2FmVzJGa3VkZS9xOWUyK3dzcnlMR1BGUkZ0WVljYXF6 N0ZtVjF0cSt4VyYjeEE7dnUyNTJQZmV6SzlsZm8vYmFQMnBUaExXU1VwWm5YS2JYdHdiYW1PZjZH YlE5K3dGencxenZzN250RE50dXh2ci9yR3pJeHRtTDY5bSYjeEE7UjlzeFB0SFRNN1RXVDlZbll6 YU1SMlEydjJaZE5yTHJSUTRWQ2tuS3lNajlmdG9helpoVVpXKy9HOVRNeHF2VXlhS3YwS1NuV1Zm TCYjeEE7dHlHT3gyWTRiTjF3Ylk5elh2RFdCcjdyTktSdGEreHRYbzEyWDIwVTF2dDMvcDdmU3c4 cXdxUFVBRGw5TkpjMXNaTGlBNXRiaTc5VyYjeEE7eS9iVzY5N0xhMy9uNzhQMWNqWitqOVA3Slps VzFwVE9yQnNxZldXNW1RV01zdXNmVzhzZUxQV2MrMXRkajdLblhOcXhQVTJZak1lMiYjeEE7blpW NmRkdnJJdVBpMFkzcWVpM2FiN0hXMnVKTG5PZTc4NTczbHozYldOWlZYL29hSzZzZXI5RFZYV2pK SktVcW4yTDlaOWJiai8waiYjeEE7MTU5SDlKL01mWTkzcmVwL1MvelB0V3orZy9xUG8vOEFhaFcx VTlDNzdUdjJlejdSNmsvYUxmb2VoNk8vME52cGZ6djZQN0QvQUVYLyYjeEE7QUwwdjZiK2pTVS8v MVBSZWpzc2EzSU5yYkcydnNyYzgzTlkyeHp2cytLeHpybll0R1BqVzI3bTdMSDQ5dWJSdi9SMVpY cDEvWXNTdiYjeEE7OVpNUTVkZURWRFMwNU1GenFMTHl4enFNbXJHdnJPSzMxOFIrUG1XWTkzMjFt VDAvMEdWLzAraFMrcmpLVzRiamp0MjB2OUYxUjIxTiYjeEE7M00reTRqR08zWU5HUGhXKzF1emZo MjV1TC9nOGZLOUt2N0ZpUitzdVBqNUZXQlhrdGNham0wZ3Vac2E1cm5COWRUMlgzMVcvWm4rcSYj eEE7OWpQWG95T241djhBNVg1bjIvN05pWmFVbHh1bGRMdWJYYWNDbWgyTmM4VXRZd3NINkZ6Y2Fo eGE2ckczczlMQ3c3YTJPcnN4MlB4YyYjeEE7SzdGc3UreVlXVXB2NkIwYXl0MVQ4U3R6WDJPdGVY QWx6blBmZmtXQjFoL1NPcXNzemMzZlJ1OUQwTXZLeGZUK3paRnRTaDBMbzQ2VCYjeEE7aXVvRDNP RzV3cloramJXeXNQc2RWNldQaFkzVDhTcDlucWV2a2JNWDF2V3Q5S3pKeWFxTWRhYVNubC9yWXpG cWF6SGZWalU0ZG1ObiYjeEE7V1czV013enN0YzZoOURuMDlVc29xdHg3K29YVjMzYlA1enFqT21m YThpbW15MzFOV242dTlGR0t5aTdwMkU4aWtVMkJtTld5c3QzLyYjeEE7QUdsOWJLWGVyNmVPN0wv V2ZROVN6OU4ray9uZjBpbjE4QTlHeXdhL1dKck95b3N1dFk5OC9vYThqSHdHMlpWK0krM1kzTXBy cmY2dSYjeEE7TDYzcmZvZlVWckVGQXhhUmpWK2pqaXR2bzFiRFZzWkE5T3Y3Tzl0YjZOalBiNkxx MmVra3ByMDlFNlJTV09aaDA3cW1obFQzTURuTSYjeEE7WTJ6N1hUUlZaWnVmWGo0K1FHVzQyT3o5 RGkrblY5bnJyOUt0Q3pPbWRDeHNTekp0NmZqT3J4S2JIUWE2V3d6MFc0OTFiWDMrbFJVeSYjeEE7 ekRvcnhYK3JiVlQ5bnJycXUvUVZyVFNTVThsMDNKclBXK25mWjhTbnBWbDlPek54NlRRNDdxVzVl TDlodnR4YjNVWHN4MzRYNm0vMCYjeEE7YTgzR1poMzBZdE51UGIxejlqOWF1ZmMxdzY1MHl5cG5w dnRzelc1RzUrUVh2cXFkYjZKTzZ5amZVeTYvZlI5c3djbnBlSjlwOUxwKyYjeEE7YlI2dlQvMmow Q1NsTE02eXgxdHVBeHRWem5NeVdXc3NxWTF6V2xoMjJNdmY2bEYyT3grTGJrdjlhdXhqUDBQMlM3 N1Y5cS9aWFV0TiYjeEE7Wm5XYXpiYmdiZHhkUmtzdkxSWFlaYUQ5a2NQdFdQWGE3RmV4MmF5Ly91 MWowNU9Ma2Y1T3N6N3FVcGhrWSszcStIa1dWNDUzWkZqSyYjeEE7WDIvcGJodnhwM1lkbVJkUit6 djZKYXpJeGNHak8rMDEvclA2SDFNeTJtOVQxSHA5NFlhY21tMFd1REt5eXhydHpuVi9iR01adGQ3 biYjeEE7dXhQMXIvd3Yrbi9tbG4xVmgzVnJTN2E5amMwdkRtVjFsekxmc1ZGVEs3VFRYa3ZheDlE OGl6N2JsM2RQeS82TGcxK3ZnNUZQcldtOSYjeEE7RDZLMXpYdDZmak5jeDFUMnVGTllJZGp0OUxE ZTA3UHA0dFg2UEcvMERQNXBKU1lkUjZlYW5YREpwTlRLVzVMN0JZM2FLSGg3cThseiYjeEE7OTIx dVBZMnEzWmQvTi9vN0ZuOWQ2bjA2ckNGdG1RNFZWdXNkZFpqdXNjNWxWTzdHNmphK3JBdXB5M3N4 L1UreXZzcDlmOW01dDJObSYjeEE7WFUvcXZxVlhYZEo2VTlqYTNZZU81amF4UzFwcVlRSzJ0dG9a UzF1MythWlRrNU5MYS9vZWxrWDEvd0NGc1dmMWJwZlM2ZnM5ek1ISCYjeEE7bXpMaTkvbzR4YVJt ZnFtYTdJKzFQeG4vQUs2eDdLYkhZdG4yeSsvN04rZ3phZlZ4TGtwMVhaZUszZnV1ckhwMk1wc2x3 RzJ5ejAvUiYjeEE7cGZyN2JiZlhvOU92NmIvV3EvMGlGbVB4WHpVL0wrelhWN1MxekxBMTdIWkhx WWVLOTFUOTFWdnEydWV6RnJ5cWJxTGNxdjhBbXJMYSYjeEE7a21kSjZWWHQyWWVPM1p0MmJhbURi czlEMDlzTjl2cC9Zc0xaL3dDRk1YL3VQVXB0NmQwOXJXc2JqVXRheHRUR3RGYlFBM0hkNnVHeCYj eEE7bzIvUXhiZjBtTi9vSC96U1Ntdmt0NmxROFpicy9IcHhLdHpzcHQxUHNGTEhQczMxWGZhYVhZ MXYyWjNwNU9Sa095c2Y5RFhmVmk0diYjeEE7NmFxMkhST3A1R2VNMnJLcmF5L3AyU2NTeDdBOXJi UzJ1bS83UXluSVl5MmhsdjJqK2EzNUxQOEFRNWVWVHN2ZmJ4K25kUHhuTmZqWSYjeEE7MU5MbXQy TmRYVzFoRGR0Vld4cFkwZXowc1hGci9xWTJQL29hMW1mVmgxSmIxRVk3NjM0emNzREdiV3lwb2JU OW54RGpNM1lkZGVQZCYjeEE7VjluOU96Q3MzMzJmczUrSFRmYjlvcXRvcFNuYlNTU1NVLy9WOUY2 TGErM0dkWTkvcXVkNlJONHNkYXkwbWpIY2I2TEhVWW1ONlQzTyYjeEE7L3dDOCtuN0haL1AvQUtI SnR5Y2VrUDFnb2JrTXdhQ054dHkyTjJiTWV3T3JMYlJtMVdWOVFjemRWYmdmYTY3dnNYNjk2WDgz WGRUOSYjeEE7b3FTK3IrUlRrMVpOdFZucWwxbExyTEQ2UmVYT3hNS3dPdmZoVTA0dGxyNm4xdjM0 OTJiUi9vTXIwZlR4TVdQMWwreVBxd01mTXFiYiYjeEE7Vms1dE5KSnNwckxkd2ZveHVZV3R5V1pM Vy9ZY3ZEcC9XTW5BeTh1dXYxZjVwSlRkNmMrYTdxM08zVzFaRnpiR2wyNXpkejNYMHRmKyYjeEE7 bnkzTTNZMTFGdGJQVVorZ3NxL1ZjT3Y5VXB0cWpsZFl3c2JLK3lQTG5YaHJYdnJZTnpneHpNcTZ0 eksvNTNKZlorenNwdjJmRFprNSYjeEE7WC9BZWorbFMvYm5SZDFMUDJoamJzbHpXWTdmV3JteHpt MVdzWlNOLzZWNzZzbkhzWnMvTXlLUDlMV2twci9XazRIN0F6bWRRcTlmRyYjeEE7ZGoydWV3MU90 YitqcnN5dHoyMXZvMmJQUTNWdmRsWW42ZjBtVlpWT1ErbGFHSlkrekZwc3NPNTc2MnVjNzAzVXlT QVhIN05lWFhZLyYjeEE7L0VYTzlXcitic1F1cVYwSEN1dHVGZjZDdXl4bGx0aG9GWjlPeXQxdjIy c090d3YwVmxqSDVkUDZXbXA5aXBZdlhjS3JPeCtoUERobSYjeEE7aG9xSU5ucU5ENnFhOHJJcmJr NWJxc3JNZlJUZmh1ZmI2UHJYL2JLN3Y4QjFIN0VsT3drb0c2b1d0cEwyaTE3WFBaV1NOeGF3c2JZ OSYjeEE7clBwT1pXNjJyZjhBOFpXcHBLZVhabE5zNnYwSzJrTnBydXU2bFhhd1VPckF0QmZaZGl2 eU1leTFuMjJ1K2k3MTJXUHQ2ZDFSK1BtZCYjeEE7UnIvV01icHk2aFkrYzlqUHJIMDRpNXMyTmZU WlFjaklhNE9jeTYvRXNiZ1VGK0JjeDllTDFMZlptMVZmek5mb1pIcTQzb0xZU1VwWiYjeEE7L1Y4 Vy9JK3hPeFcvckdQbDFXc3RKQWJXd2JtWnJudGNmZjYrQlpsNFZlMnUzOVBsVldmb2RuMnJIMEVr bE9UVzZ1M3E3M1BmOXBkaiYjeEE7WkQ2YTNOWTlqOFp6OGJGdit4UGRWWDZlUmlaRmUvTnR1eXJ2 USsxZlljZjA3Y21ySDlEV1dQazVJYjFLaGw3bXd6Tm1yMVhWczJWbiYjeEE7RmJqK3BRTW5IcXN0 WTdQenFNVDlTdnZ1KzBaM3AvYmZTOWZwbGVsalplTGxzTm1MZFhld2JaZFU0UEh1YXkrdjNNTHZw MDIxWE0vNCYjeEE7SzJ1eEpTWlovVzNQcnhxTHE3L3M3MlplS0E4bDIxd3R2cXhiYUhzcmJaNm4y aW0reWl2MWEvU3J2c3F5UDBIby9hYWRCWm5YQTdiZyYjeEE7dTJ0ZlczTm85VGVHbGdCZDZkYm5O dHk4Qm05dDc2ZnMvd0RUbjE1WG9XMGRQdnlHVStrbE9ta2tra3BTeC9xOWEyeTdyQUFjMTFmVSYj eEE7Ykd2YTVyZ1FmU3huRDlMY0dYNUxIc2N5eXV5eG15bGovc1dGNjNUc1hEdnQyRmlmVm5ZYk9z dVpWajFBOVR1azQ1Yjd5R1VNZmJrMSYjeEE7MDVHWXlyTDN0L1RmMGEyMytrMzRlUGRmWWtwMjBr a2tsUDhBLzliMExvV1JpNUZGcnNhMTF0WWRWN0h2ZmE2dmRqWXR0ZFQ4bDkrWiYjeEE7VGt2ZFRa WGY5b3hMZnM5dnJmNGJJKzBaTjgrdDRtWmxZckJpMittYWJCYytzVlYzUHNEQTUxZFdQOXJkWGow WmJNajBNbkR5YmYwViYjeEE7T1ZqMCt0WFpUNmlMaFY1VFdWYmpzeHhXQTNIdEJmZXoyMGhqTWpN KzA1TEw3YTN0eWZYcy9TZXQ2dFg2WDlCWmRsemF6cUcxb2RkUyYjeEE7WEJ0UWNSVTRBdWE3OWNj MXYyaDIxbDlYc3htZjlwWC9BS1Myek0vbWtsT1RmMFBLeWVwWTFtVGE3THF4blBiWSs0TWEyekV5 TVYySiYjeEE7bDlQc3B4OXRXWSt6cUdOaTlSdiswNGxOSDZYMDhiK1o5SldCai9XQWdzc3lhOXJy TGlMS2kxbGpXUHV1Ymp0L1M0MlRUZDZIVHI2YiYjeEE7V045R2o5ZjZmWFhmZmw0MmJmNk43SVox QnpuSEd1cHJidGhvc3FkWVE3YmI3bk9aa1VibWVxN0Zmcy9jcHlLL1UvV2E3Y1V0d3ROVCYjeEE7 eFM1ckxTMGl0NzJsN1E2UFk1OWJYMU9zWTEzNW5xMS84WWtwekhZWFhYL2FLL3QvcGIvWCt6NURX MXUyYnZVT0h2dzM0M3Y5RDdWcyYjeEE7dC9YdjB2N0t3YmYrMTJmU3FyK2lkV3V4bmZhNzY4ck1v M093Nzc5ajI3MjMzMllXUjluK3lmWnNIcUdMZ3ZycHI2aGkwV2ZwOGkzNyYjeEE7Vmc1dFdIaTEy N0QyZFFOcExMcVcxYmdRdzFPTHRzMDdtK3A5b2EzZnRibWUvd0JML0Q0MzZQOEFWYmZ0aFdDME9z TmptdWFYVFVHdCYjeEE7TFMxdTF2dHNjWHY5Ui9xK28vZitpOW42UDAvMGZxMkpUai9zQ3htVjYy T01TajA2L3dCU3NyeG1OZGoyTVBwTTJNSWUrNnJMNmEzRiYjeEE7NmRuYk1yRWY2R0IrcWVoOXAv VWl1cDY2NWpiYWIvU3lLckE2ekh2RmRsRnpkdHR0bVBSazQ5ZEdWVFY2dVZYalY1bDFIcnMvWjFW diYjeEE7MkM3MWIvdHR0bGZWUnQzNUdPNk51L2JROFRIb2VwdG5LZnMzN00zWjlQMC90R0wvQUR2 MlMzN2FtMTlWMk9Ec2pITC9BRXlHdUZEdyYjeEE7Qlp0cURMSE4rMU8zVk51YmsyT3AzNy9TdG9w OWRuMmV5L0pTbW8zcDNVLzJoUlpmbGZhc1hIc0ZsVzhVdGVKeDNZbG5xTmJodTNXdCYjeEE7dWI2 N0xjWEp3ZjhBbExMcGYrcjR0TkdUckpLdUdkUWwwM1VrRnpTeUtuQ0dpeDdyR3UvV1BjOTJKNlZE SC80UEk5VEs5T3lxejdIVSYjeEE7bE5oSlZDM3FyZlNJc3g3WTlJWHROYjY5MzAyNWRsVC9BRmNq MHZwVlc0OUw2N3Y1bXpIc3YvV3Z0V0pZQXQ5VnhMbW1vdGFHTURTSCYjeEE7QndML0FGSE9zMzdY TWMzMHRqUFMvUi9wUDBsbnFmb2twd3VyZlY3N2JtNCtVNm1mU3ovWGRaUlo2T1I2Tm1MK3pyZlR5 Y2R1RmtWNyYjeEE7Y2owTHNpdjdaZFpkaVl2ODdiK3JkT3J6T2tmVlRxZlJzVEZ2cXFhN09wZFJY bjEwNWR2NnppNDFNVnNyZlpUaXQrMGZiZ3k2aW5MLyYjeEE7QU8wLytTLzJuVDBtejdKVDJGb3RM UUtuTlk3YzBrdWFYRGFIRDFXN1d2cjk3NnQ3SzMvNE4vNlQwN2Y1cEN5QjFEYzRZenFRMTdkciYj eEE7VFkxeE5idHR2Nlp6V1A4QTFwbnEvWldmWnYxUDJmYUxQdGY4M1VrcDU5blN1c25FdXd2dERm dHZvMUVqOW9aVG5SWFRrWStJN0tleSYjeEE7dWkvWmtabVBUa1pHVDAxblNINXY2elZiNnYyS3o5 cDErcDlFK3NXVXdYNHRmcHZma1haREtiODIreDlKdWJqMDBiWFVPeHZzdFROdSYjeEE7VjlzcHdj LzFjTDFidjJabVoyRmZrOUh6K2xxczZxZDNyWStPeVBSMmJMM3ZuZHQrMjd0MkxWdCt6Ky83TC8z TC93QUw5aVZ0SlR6TiYjeEE7blJldkJsdGxGc1hISXhNakhZN1B5aXhqTVp1RlhiZ3ZjNnAvclZa ZTNxMzJpK3luOVA2bUxmazBYVy8wT1k2UjF5cDd2U0xYc3FhMyYjeEE7N01mdCtZMXg5UE5mbU1x eXZ0TE9vMTJNdndQczllUmtlbjlvL3BPQlgrbzNWZlp0M0pkbE5ZRGkxMTJ2OTB0dHNOWStpODEr NWxXUiYjeEE7OUs3MHEzK3oyVlBzdS9TZWw2Rm9tMmRWM3VEc2ZIRFBVSWE0WHZKTmU2b01zYzM3 SzNiYTZsMlRZNm5mczlXcWluMTMvYUxMOFpLYyYjeEE7U3JwUFZYTXBwYlpsNDdEdkpOMTc4Z3Ri YTNxdnAwNWVRelB4N24vWmZ0ZUQvUldldlhiVGlWVjlUei9SKzM5UDArZzlPeU1ISHUrMSYjeEE7 YmZYeWJqYThOc2ZlUUF5ckdwWlpsM3RwZmt2WlJqMU05YjdQUS9aL1NQdFdWNitmbGxGdldvZE9M akFoclN5TW13eTQxdmRZMTM2bCYjeEE7N1dOeS9Tb1kvd0R3bVA2bVY2ZGR0ZjJPMmRWblZUdTli SHgyUjZPelplOTg3dHYyM2R1eGF0djJmMy9aZis1ZitGK3hKS2JhU0R1eSYjeEE7dlVqMDYvUzlT TjNxSGQ2ZXpkNm16MHR2cS9hZjBYbytwczlEOVk5ZjFQMVZMZGxlblBwMStyNmtiZlVPMzA5KzMx Ti9wYnZWK3pmcCYjeEE7ZlI5UFo2LzZ2Ni9wL3JTU24vL1o8L3hhcEdJbWc6aW1hZ2U+CiAgICAg ICAgICAgICAgIDwvcmRmOmxpPgogICAgICAgICAgICA8L3JkZjpBbHQ+CiAgICAgICAgIDwveGFw OlRodW1ibmFpbHM+CiAgICAgIDwvcmRmOkRlc2NyaXB0aW9uPgogICAgICA8cmRmOkRlc2NyaXB0 aW9uIHJkZjphYm91dD0iIgogICAgICAgICAgICB4bWxuczp4YXBNTT0iaHR0cDovL25zLmFkb2Jl LmNvbS94YXAvMS4wL21tLyI+CiAgICAgICAgIDx4YXBNTTpEb2N1bWVudElEPnV1aWQ6Rjg3NzBC NjRDMEI1REMxMUI4ODhDQTc0NDE0QUU0Rjc8L3hhcE1NOkRvY3VtZW50SUQ+CiAgICAgICAgIDx4 YXBNTTpJbnN0YW5jZUlEPnV1aWQ6NWE5NzVlOTctZWFhNi00YWU3LWFmMmQtY2NhMTQ1OTgwOWM3 PC94YXBNTTpJbnN0YW5jZUlEPgogICAgICA8L3JkZjpEZXNjcmlwdGlvbj4KICAgICAgPHJkZjpE ZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6dGlmZj0iaHR0cDovL25z LmFkb2JlLmNvbS90aWZmLzEuMC8iPgogICAgICAgICA8dGlmZjpPcmllbnRhdGlvbj4xPC90aWZm Ok9yaWVudGF0aW9uPgogICAgICAgICA8dGlmZjpYUmVzb2x1dGlvbj4zMDAwMDAwLzEwMDAwPC90 aWZmOlhSZXNvbHV0aW9uPgogICAgICAgICA8dGlmZjpZUmVzb2x1dGlvbj4zMDAwMDAwLzEwMDAw PC90aWZmOllSZXNvbHV0aW9uPgogICAgICAgICA8dGlmZjpSZXNvbHV0aW9uVW5pdD4yPC90aWZm OlJlc29sdXRpb25Vbml0PgogICAgICAgICA8dGlmZjpOYXRpdmVEaWdlc3Q+MjU2LDI1NywyNTgs MjU5LDI2MiwyNzQsMjc3LDI4NCw1MzAsNTMxLDI4MiwyODMsMjk2LDMwMSwzMTgsMzE5LDUyOSw1 MzIsMzA2LDI3MCwyNzEsMjcyLDMwNSwzMTUsMzM0MzI7OUY4RUQ4QjEwQzk4QTE5NUY4OTE1NDAy REIxODYyODg8L3RpZmY6TmF0aXZlRGlnZXN0PgogICAgICA8L3JkZjpEZXNjcmlwdGlvbj4KICAg ICAgPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIKICAgICAgICAgICAgeG1sbnM6ZXhpZj0i aHR0cDovL25zLmFkb2JlLmNvbS9leGlmLzEuMC8iPgogICAgICAgICA8ZXhpZjpQaXhlbFhEaW1l bnNpb24+MjE5MDwvZXhpZjpQaXhlbFhEaW1lbnNpb24+CiAgICAgICAgIDxleGlmOlBpeGVsWURp bWVuc2lvbj4zMjgyPC9leGlmOlBpeGVsWURpbWVuc2lvbj4KICAgICAgICAgPGV4aWY6Q29sb3JT cGFjZT4tMTwvZXhpZjpDb2xvclNwYWNlPgogICAgICAgICA8ZXhpZjpOYXRpdmVEaWdlc3Q+MzY4 NjQsNDA5NjAsNDA5NjEsMzcxMjEsMzcxMjIsNDA5NjIsNDA5NjMsMzc1MTAsNDA5NjQsMzY4Njcs MzY4NjgsMzM0MzQsMzM0MzcsMzQ4NTAsMzQ4NTIsMzQ4NTUsMzQ4NTYsMzczNzcsMzczNzgsMzcz NzksMzczODAsMzczODEsMzczODIsMzczODMsMzczODQsMzczODUsMzczODYsMzczOTYsNDE0ODMs NDE0ODQsNDE0ODYsNDE0ODcsNDE0ODgsNDE0OTIsNDE0OTMsNDE0OTUsNDE3MjgsNDE3MjksNDE3 MzAsNDE5ODUsNDE5ODYsNDE5ODcsNDE5ODgsNDE5ODksNDE5OTAsNDE5OTEsNDE5OTIsNDE5OTMs NDE5OTQsNDE5OTUsNDE5OTYsNDIwMTYsMCwyLDQsNSw2LDcsOCw5LDEwLDExLDEyLDEzLDE0LDE1 LDE2LDE3LDE4LDIwLDIyLDIzLDI0LDI1LDI2LDI3LDI4LDMwO0M3RDVEQUNFRUI5NDMzMkQyQTIz MEVBQjAzMTVBNTk1PC9leGlmOk5hdGl2ZURpZ2VzdD4KICAgICAgPC9yZGY6RGVzY3JpcHRpb24+ CiAgICAgIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSIiCiAgICAgICAgICAgIHhtbG5zOnBo b3Rvc2hvcD0iaHR0cDovL25zLmFkb2JlLmNvbS9waG90b3Nob3AvMS4wLyI+CiAgICAgICAgIDxw aG90b3Nob3A6SGlzdG9yeS8+CiAgICAgICAgIDxwaG90b3Nob3A6Q29sb3JNb2RlPjA8L3Bob3Rv c2hvcDpDb2xvck1vZGU+CiAgICAgIDwvcmRmOkRlc2NyaXB0aW9uPgogICAgICA8cmRmOkRlc2Ny aXB0aW9uIHJkZjphYm91dD0iIgogICAgICAgICAgICB4bWxuczpwZGY9Imh0dHA6Ly9ucy5hZG9i ZS5jb20vcGRmLzEuMy8iPgogICAgICAgICA8cGRmOlByb2R1Y2VyPkFkb2JlIFBob3Rvc2hvcCBm b3IgV2luZG93cyAtLSBJbWFnZSBDb252ZXJzaW9uIFBsdWctaW48L3BkZjpQcm9kdWNlcj4KICAg ICAgPC9yZGY6RGVzY3JpcHRpb24+CiAgIDwvcmRmOlJERj4KPC94OnhtcG1ldGE+CiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAog ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAKPD94cGFja2V0IGVu ZD0idyI/Pg0KZW5kc3RyZWFtDWVuZG9iag0zIDAgb2JqDTw8L0NyZWF0aW9uRGF0ZShEOjIwMDcx MjI4MTk0NDQzLTA4JzAwJykvQ3JlYXRvciggQWRvYmUgUGhvdG9zaG9wIENTMyBXaW5kb3dzKS9Q cm9kdWNlcihBZG9iZSBQaG90b3Nob3AgZm9yIFdpbmRvd3MgLS0gSW1hZ2UgQ29udmVyc2lvbiBQ bHVnLWluKS9Nb2REYXRlKEQ6MjAwNzEyMjgxOTQ3MzItMDgnMDAnKT4+DWVuZG9iag14cmVmDQow IDQNCjAwMDAwMDAwMDAgNjU1MzUgZg0KMDAwMDA3MDA0MSAwMDAwMCBuDQowMDAwMDcwMDkyIDAw MDAwIG4NCjAwMDAxMDk2OTQgMDAwMDAgbg0KdHJhaWxlcg0KPDwvU2l6ZSA0Pj4NCnN0YXJ0eHJl Zg0KMTE2DQolJUVPRg0K ________________________________________________________________________________
Subject: Re: Gretz Pitot Instructions
Date: Dec 28, 2007
I had to grind a bit off the pitot where it slides into the mount. I used the scotchbrite wheel and took a small amount off at a time until it fit snug. Pretty straight forward. Dave Leikam 40496 Starting to rivet bottom wing skins ;- o N89DA Reserved ----- Original Message ----- From: Patrick ONeill To: rv10-list(at)matronics.com Sent: Friday, December 28, 2007 7:04 AM Subject: RE: RV10-List: Gretz Pitot Instructions I'm finally back to building now that the bulk of the holiday season has passed. Thank you very much Ralph, Dave, Tim and Ben for the info on the Gretz! It was all very helpful! Hopefully this weekend I can put it into practice. Dave and Ben you both have done beautiful work. Great pictures and links! Did any of you have much trouble getting the pitot to fit the mount? The instructions say the pitot may need to be ground to fit. In my case, it looks like a substantial amount of grinding. Best Regards, Patrick #40715 / N690CT ------------------------------------------------------------------------- ----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Saturday, December 22, 2007 6:56 AM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Gretz Pitot Instructions Patrick, I'll borrow a quote from John Cox for you on this "Make sure you take off your builder hat and put on your repairman/serviceman hat.". Although not technically that difficult to install think about maintaining it after installation. I did not think about install or location when I cut the holes for my bracket which I ended up putting it in the stock Van's pitot location. It worked out ok but I had several technical hurdles to overcome. The copper tube coming out of the pitot tube itself came straight up into the aileron torque tube requiring a healthy bend to maintain clearance while the tube moved fore and aft. The mounting locations for the circuit board in this location are sub optimal for ease of wire installation and maintenance due to the aileron pushrod and bellcrank parts. Think about threading the wires up through the pitot tube hole and guiding them into their install location on the circuit board and then tightening the miniature screws. You also have to secure the aluminum pitot line to the copper line through an inspection hole after installing the bottom wing skins. Pictures of my installation can be found here: http://www.sinkrate.com/rv10/pics.asp?f=wings|pitot I ended up making short length wires and connectors that I could attach to the circuit board prior to closing up the wing. I used a locking 2 wire molex plug for the power wires and dean's plug for the thermistor wires. My thoughts were to make the actual installation of the tube into the finished wing easier. One thing to think about too is what happens to moisture that may accumulate on the wires? The circuit board should be on the top side of the wing so all wire runs coming out of the unprotected holes are not subject to water droplets running down the wires and into their attach points. I am considering encasing the wires in silicone but have not yet done that. If anyone has more questions or thinks I f'd something up please let me know! -Ben Westfall #40579 N109LB (reserved) PDX ------------------------------------------------------------------------- ----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick ONeill Sent: Saturday, December 22, 2007 4:56 AM To: rv10-list(at)matronics.com Subject: RV10-List: Gretz Pitot Instructions I'm about ready to do the Gretz Pitot install and can't find my copy of the instructions. Does anyone happen to have an electronic copy? I could not find one on he Gretz Aero site. I don't need the mounting bracket instructions, those ones I found. I am looking for the one that has the wiring diagrams for the pitot itself. Also, is there any consensus as to which bay is optimal from the standpoint of accuracy, ease of maintenance and tie-down clearance? How have people been going about doing the cutout for the bottom skin? The bracket instructions don't seem to provide any guidance for that step. Best Regards, Patrick #40715/ N690CT http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?R V10-Listhttp://forums.matronics.com ________________________________________________________________________________
Subject: Oil Canning and Santa's gift
Date: Dec 28, 2007
OOps, the second #14 should be a #15, and the #15 should be a #16 and so on . I duplicated the #14 twice. Sorry, JOhn G. From: indigoonlatigo(at)msn.comTo: rv10-list(at)matronics.comSubject: RV10-List: Oil Canning and Santa's giftDate: Fri, 28 Dec 2007 20:01:09 -0800 Hey all. I went ahead and pulled the bottom outboard skin off my first wing with the oil canning in three of the bays. It takes about 4.5 hours to rem ove all the rivets. I went ahead and did this after speaking to Ken at Van' s who suggested I don't even entertain the idea of replacing it. Well somet hings just will keep bugging me so I had to do it. In the attachment is the rivetting pattern of the second wing. It should be pretty clear. My result were great. I revetted it by myself, but I have long arms. I always rivet ted each rivet, one at a time in horizontal rows before moving down and doi ng the next rivet forward. I really think the key is not only the rivetting pattern but trimming the skin edge, making sure the gun is not pushing the rib flanges in during setting...as this will make the skin be on a smaller arc, taking up less skin, thus and excess when one gets to the intersectio ns of the LE skin and the rear skin. Hope it helps. JOhn G. 409. ________________________________________________________________________________
Subject: XRX CAS system
Date: Dec 29, 2007
I just returned both XRXs that I was sent. The first system had a power issue such that it rebooted itself about o dozen times over about 6 hours of usage. These occurred using four different power sources, two alternator sources which should have been 13VDC+ , two batteries, and two different power cords. I called the factory and they indicated that the unit should be returned for warranty service. The replacement unit was immediately sent from Marv Golden and it reset once on battery power and once on the alternator. I came to the conclusion that the problem was probably a voltage drop on the very small wire size used in the power cord; it is the same cord as supplied for the MRX which uses about 20% of the XRX power. I believe the reset problem can be fixed by Zaon using a properly sized power plug. Some observations during use (5 flights) Traffic was definitely easier to spot given the suggested bearing to the traffic. Identification of traffic below where the transponder antenna was shielded by the target airframe, made traffic alerted late or not at all. The second XRX also had the problem of identifying my aircraft transponder as target traffic and display 0.0 NM 0 FT with the ALERT. This can be fixed by the factory as it was on my MRX several years ago. My transponder antenna was clean at the time. The compass should definitabely be calibrated. Calibration can take place in smooth air using the autopilot on GPS track of 000. It gives the "God's eye view" proper orientation. LCD display is more difficult to see (than MRX LED) with sunglasses and in bright light traffic distances differ between the MRX and XRX; visually the XRX seem to be a little more accurate. The MRX seemed to show slightly larger distances. Although the XRX will display on a GRT and other EFIS, I did not try because I did not have the extra serial port required. Note however the display is either not both. The traffic displayed on the EFIS is not duplicated on the XRX; the XRX display shows a standard message identifying the EFIS. In summary the XRX is an improvement on the MRX, just not a three times the price improvement. I will continue to use the MRX to "wake me up" and keep my eyes outside. Hope this helps some in their decision making. Now if they ever come up with an economical GDL solution!!! ________________________________________________________________________________
Subject: Re: position rear Headset jacks
Date: Dec 29, 2007
Hi Larry, The interior person I used supplied it. He does custom cars also and I think it's just the trim they use on the trunk and doors etc. Wayne ________________________________________________________________________________
Date: Dec 29, 2007
Subject: Safety-Trim Group Buy
Sorry, I was offline for a while, I would like to sign up for the 2 axis (2 preset speeds) Safety trim controller, is it still possible? I'm also trying to get in touch with Steinair for a while, I need a fey of their USB panel mount extension cables as well as a few minor things, tried it more than a year ago but no response. We met at Oshkosh 2007 in the RV10 headquarters and Stein introduced me to Paul Story so I mailed him but no response as well, maybe my mail is lost in spam.. Is there a way that someone helps me to get in touch? Henkjan van der Zouw RV10 #40355 finishing Ps I'm receiving mail at henkjan(at)zme.nl zme(at)zme.nl and info(at)zme.nl -----Oorspronkelijk bericht----- Van: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Namens Bob-tcw Verzonden: zaterdag 29 december 2007 0:29 Aan: rv10-list(at)matronics.com Onderwerp: RV10-List: Safety-Trim Group Buy First I would like to thank all the builders who have signed up for the group buy. We appreciate your business and look forward to serving you. We hope you all have had a safe and enjoyable holiday season. This is the final weekend of the Vansairforce group buy for our Safety-Trim servo controller. Over 140 builders have signed up and will receive the full $100 discount on the 2 axis controller and $50 discount on the single axis controller. If you haven't signed up yet the promotion continues until the Dec 31. Other important notes. We've added a few more applications notes on our web site including details on the wiring harness available for use with Safety-Trim. Lastly, we are now selling an airspeed switch that is field adjustable between 55 and 140 knots and is perfect for triggering the 2 speed function on Safety-Trim. group buy link: http://www.vansairforce.com/community/showthread.php?t=24478 Best regards, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Date: Dec 29, 2007
Maybe Rick Gray can answer that one too if he is monitoring the list...he had some nice trim as well.... Rick S. 40185 ----- Original Message ----- From: "Larry Rosen" <LarryRosen(at)comcast.net> Sent: Friday, December 28, 2007 2:08:05 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: position rear Headset jacks Wayne, Where did you get the black trim that you have on the interior door frame to trim off the edge? Larry ________________________________________________________________________________
Subject: position rear Headset jacksposition rear Headset jacks
Date: Dec 29, 2007
Wayne, I would like to see your photos as I am just now getting ready to install the interior. Thanks, James Stribling 40140 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Friday, December 28, 2007 9:17 AM Subject: Re: RV10-List: position rear Headset jacksposition rear Headset jacks I had several builders request that I post some photos of my interior. Rather than post them on Matronics I sent some to them diretc, because of the number of pictures I sent them and the size limits on Matronics. If anyone else would like to see my interior photos just e-mail me offline and Ill forward them to you. Wayne Edgerton N602WT do nor archive ________________________________________________________________________________
Date: Dec 29, 2007
Henk, I tried to copy you on an e-mail I sent to Stein, but Outlook doesn't recognize the .nl in your e-mail address. Do you have a .com address? Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Henkjan van der Zouw Sent: Saturday, December 29, 2007 9:41 AM Subject: RE: RV10-List: Safety-Trim Group Buy Sorry, I was offline for a while, I would like to sign up for the 2 axis (2 preset speeds) Safety trim controller, is it still possible? I'm also trying to get in touch with Steinair for a while, I need a fey of their USB panel mount extension cables as well as a few minor things, tried it more than a year ago but no response. We met at Oshkosh 2007 in the RV10 headquarters and Stein introduced me to Paul Story so I mailed him but no response as well, maybe my mail is lost in spam.. Is there a way that someone helps me to get in touch? Henkjan van der Zouw RV10 #40355 finishing Ps I'm receiving mail at henkjan(at)zme.nl zme(at)zme.nl and info(at)zme.nl -----Oorspronkelijk bericht----- Van: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Namens Bob-tcw Verzonden: zaterdag 29 december 2007 0:29 Aan: rv10-list(at)matronics.com Onderwerp: RV10-List: Safety-Trim Group Buy First I would like to thank all the builders who have signed up for the group buy. We appreciate your business and look forward to serving you. We hope you all have had a safe and enjoyable holiday season. This is the final weekend of the Vansairforce group buy for our Safety-Trim servo controller. Over 140 builders have signed up and will receive the full $100 discount on the 2 axis controller and $50 discount on the single axis controller. If you haven't signed up yet the promotion continues until the Dec 31. Other important notes. We've added a few more applications notes on our web site including details on the wiring harness available for use with Safety-Trim. Lastly, we are now selling an airspeed switch that is field adjustable between 55 and 140 knots and is perfect for triggering the 2 speed function on Safety-Trim. group buy link: http://www.vansairforce.com/community/showthread.php?t=24478 Best regards, Bob Newman TCW Technologies www.tcwtech.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com ________________________________________________________________________________
Subject: pitot mount
Date: Dec 29, 2007
I too had to remove material for the tube to fit into the mount, but I removed material from the inside of the mount instead of the tube. It didn't take much, but a small sanding drum on the Dremmel tool did the job. I figured the mount is fairly thick steel, and the tube is expensive, and not steel, so logic told me to grind the mount a little, and then paint on a little zinc chromate. Chris Hukill ________________________________________________________________________________
Subject: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938
Date: Dec 30, 2007
Another milestone this morning. The trip to the airport was about 2 miles at 0600 on city streets. All the other parts are ready at the hangaar. Hopefully March. Your message is ready to be sent with the following file or link attachments: IMG_0927 IMG_0932 IMG_0935 IMG_0938 ________________________________________________________________________________
Date: Dec 30, 2007
I take it is a relatively short trip to the airport. Now the fun begins, the system checkouts. Good luck. Gary 40274 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Sunday, December 30, 2007 12:44 PM Subject: RV10-List: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938 Another milestone this morning. The trip to the airport was about 2 miles at 0600 on city streets. All the other parts are ready at the hangaar. Hopefully March. Your message is ready to be sent with the following file or link attachments: IMG_0927 IMG_0932 IMG_0935 IMG_0938 ________________________________________________________________________________
Date: Dec 30, 2007
Nice tow bar. Where did you get it? Carl Froehlich RV-8A (375 hrs) RV-10 (wings) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Sunday, December 30, 2007 12:44 PM Subject: RV10-List: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938 Another milestone this morning. The trip to the airport was about 2 miles at 0600 on city streets. All the other parts are ready at the hangaar. Hopefully March. Your message is ready to be sent with the following file or link attachments: IMG_0927 IMG_0932 IMG_0935 IMG_0938 ________________________________________________________________________________
Date: Dec 30, 2007
made it. threaded rod from McMaster Carr that was machined to catch the cap screws. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Sunday, December 30, 2007 11:25 AM Subject: RE: RV10-List: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938 --> Nice tow bar. Where did you get it? Carl Froehlich RV-8A (375 hrs) RV-10 (wings) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Sunday, December 30, 2007 12:44 PM Subject: RV10-List: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938 Another milestone this morning. The trip to the airport was about 2 miles at 0600 on city streets. All the other parts are ready at the hangaar. Hopefully March. Your message is ready to be sent with the following file or link attachments: IMG_0927 IMG_0932 IMG_0935 IMG_0938 ________________________________________________________________________________
Date: Dec 30, 2007
Subject: Static line and ADAHRS connection - where do you make it?
I'm putting the static line in from the rear ports forward to the panel. Do I need a 3 way fitting or something back in the battery area to feed the ADAHRS box for a Chelton or other EFIS? Just looking for a quick yes or no before I close up the RH baggage wall and the static line. ________________________________________________________________________________
Subject: Wayne's interior
Date: Dec 30, 2007
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Wayne: Why don't you send some of your interior photos to Tim Olson and we can have him post them on his site for all to enjoy . . . TDT 40025 Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Dec 30, 2007
Subject: Re: Static line and ADAHRS connection - where do you make
it? The Cheltons have a MSU and a GADAHRS in addition to the screens. The MSU only gets wires. The GADAHRS gets wires and Pitot and Static connections. Tim has both units mounted in the rear. I am only mounting the MSU in the back, the GADAHRS will be behind the panel. Larry MauleDriver wrote: > > I'm putting the static line in from the rear ports forward to the > panel. Do I need a 3 way fitting or something back in the battery > area to feed the ADAHRS box for a Chelton or other EFIS? > Just looking for a quick yes or no before I close up the RH baggage > wall and the static line. > > ________________________________________________________________________________
Subject: Need wiring diagram for aileron trim
Date: Dec 30, 2007
Hate to bug everybody but I installed the electric aileron trim and suddenly realized I don't have a wiring diagram. Anybody have one or at least know which wire is which? It's the standard Ray Allen trim servo from Vans. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155105#155105 ________________________________________________________________________________
Date: Dec 30, 2007
What are you hooking it up to? Ray Allen indicator, GRT EFIS, etc. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, December 30, 2007 8:41 PM Subject: RV10-List: Need wiring diagram for aileron trim Hate to bug everybody but I installed the electric aileron trim and suddenly realized I don't have a wiring diagram. Anybody have one or at least know which wire is which? It's the standard Ray Allen trim servo from Vans. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155105#155105 ________________________________________________________________________________
Date: Dec 30, 2007
Here is a link to the Ray Allen page with their wiring diagrams. http://www.rayallencompany.com/RACinfo/downloadpg.html Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, December 30, 2007 8:41 PM Subject: RV10-List: Need wiring diagram for aileron trim Hate to bug everybody but I installed the electric aileron trim and suddenly realized I don't have a wiring diagram. Anybody have one or at least know which wire is which? It's the standard Ray Allen trim servo from Vans. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155105#155105 ________________________________________________________________________________
Subject: Re: qb kit-front floor panels removal and gear mount
Date: Dec 31, 2007
Started the task of removing the gear weldments yesterday and found the first one to be as much "fun" as anticipated. Thinking ahead to the reinstall process, I am curious about the procedure to get bolts back in. They were so tight coming out, that I can't imagine they will go in easily. How does one apply the force necessary to install those bolts? John Ackerman, you mentioned grinding down the old bolts and using them as guide pins. Could you elaborate? Any pics? -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155133#155133 ________________________________________________________________________________
Date: Dec 31, 2007
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
David; You can put some LP 3 on the bolts to help them slide in. Just clean off the threads before you put the washer and nut on. Fred 40515. Fun with fiberglass... Wheel pants almost done. Had the pleasure of meeting Mark Ritter and seeing his 10 this weekend at the cafe in Brenham, Texas. dmaib(at)mac.com wrote: > > Started the task of removing the gear weldments yesterday and found the first one to be as much "fun" as anticipated. Thinking ahead to the reinstall process, I am curious about the procedure to get bolts back in. They were so tight coming out, that I can't imagine they will go in easily. How does one apply the force necessary to install those bolts? John Ackerman, you mentioned grinding down the old bolts and using them as guide pins. Could you elaborate? Any pics? > > -------- > David Maib > RV-10 #40559 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155133#155133 > > > ________________________________________________________________________________
Subject: Re: Need wiring diagram for aileron trim
Date: Dec 31, 2007
Rene', Thanks, that's what I needed. I wanted to know if the white wires needed to be bigger but the 1 amp c/b gave me the answer. I was also curious if the colored wires might have needed to be bigger, as well. I was getting ready to order larger wire for the pitot heat and I didn't want to be short. Thanks again. John rene(at)felker.com wrote: > Here is a link to the Ray Allen page with their wiring diagrams. > > http://www.rayallencompany.com/RACinfo/downloadpg.html > > Rene' > 801-721-6080 > > > -- -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155183#155183 ________________________________________________________________________________
Subject: Re: Sarasota info
Date: Dec 31, 2007
General Information: Cockpit Cafe 400 East Airport Ave, Venice, FL 34285 Phone: 941-484-5428 Email: cockpitcafe(at)yahoo.com Airport: Venice Municipal Airport (VNC) Website Comments: The Cockpit Caf=C3=A9 was voted by the Sarasota Herald-Tribune Reader =99s Choice for the BEST CUBAN SANDWICH! The Cockpit Caf=C3=A9, located at t he Venice Airport (VNC) is owned and operated by European trained chef, Jard a Hornacek and his wife Kirsten. Ingredients are prepared fresh daily and fe ature a variety of homemade soups, the "98% Cuban Sandwich", the ever-popula r =9CCzechwiches=9D and breakfasts served your way. Try the bana na-walnut stuffed pancakes and you=99ll feel like you=99re in fi rst class, while only paying coach prices. The Cockpit Caf=C3=A9 also holds the distinction of winning the =9CHundred Dollar Hamburger=9D pi lots choice award. While enjoying your meal, you can look out the window and see the bald eagles that make their home in the navigation tower as well as watch the planes take off and land. The caf=C3=A9 serves breakfast and lunc h from 7am-2pm. Open 7 days a week. Here is some info, I believe someone was asking about Sarasota a short time ago. Jeff ________________________________________________________________________ aol.com ________________________________________________________________________________
Subject: Happy New Year and thanks for a great 2007!
Date: Jan 01, 2008
With the passing of the old year and the start of the new, I just wanted to thank everyone on the list for helping 2007 be a wonderful year! As 2008 begins with a large part of an RV-10 in my garage (the first such year for myself) I think back to the many things I had to go through to get here. Without this list, it would have been a much harder journey and I'm sure nowhere near enjoyable as it has been. My thanks go out to all of you. Here's wishing for a great 2008 to all the RV-10 builders and enjoyable and safe first flights for all the RV-10's that will be flying before the New Year graces us again! Best Regards, Patrick #40715 / N690CT ________________________________________________________________________________
Date: Jan 01, 2008
Here's what I did: Hacksawed off the bolt heads to make pins out of the bolts. Filed cut end more-or-less flat -just a few strokes were needed. You can chuck the pin in a drill press to do this, but it's not really necessary. Ground off the threads, holding the pin in a drill, and rotating opposite to the wheel. Made the (previously) threaded end into a bullet-like shape. Not quite as blunt as a pistol bullet ' say a .45 ACP round nose ' but not sharp like a high velocity bullet,either. This is not terribly critical, but the idea is for the pin to work its way into two slightly misaligned holes, drawing them in alignment with a lot of motion (small mechanical advantage) at first, and a small amount of motion (large force) as the pin gets in farther. Eyeballing the shape gave a product that was good enough to work very well. Polished on a fine Scotchbrite wheel. Covered the pins with grease, wiping off excess. I used Lubriplate, but I doubt it matters. Placed weldment in position. Pushed all the pins into the holes, pushing the pins in a little at a time, going from pin to pin, tapping as required. Hardly any tapping was needed on mine. YMMV. Used the new bolts to push pins on through, tapping as required - again not much. This whole process did not take very long. You only need one set of pins ' probably not even a full set because the first bolt is put in while the parts are free to move. I was worried about clearing the rear spar structure as the pins were pushed on through, but they all fell out the other side without hitting anything. You may want to check pin lengths before inserting them and shorten if/as required. As I recall, I had to use a swivel socket to get on the nuts, and a long extension for reach. Like you, I had a very hard time removing the bolts. I recall it was difficult getting past the floor skin, as well. Bolting the weldment back was a piece of cake. The pins moved it into alignment and kept that alignment while the bolts displaced them. I'm quite sure the bolt threads did not damage the holes and vice versa. Hope this is useful. Happy new year! John and Marlys 40458 On Dec 31, 2007, at 4:10 AM, dmaib(at)mac.com wrote: > > Started the task of removing the gear weldments yesterday and > found the first one to be as much "fun" as anticipated. Thinking > ahead to the reinstall process, I am curious about the procedure to > get bolts back in. They were so tight coming out, that I can't > imagine they will go in easily. How does one apply the force > necessary to install those bolts? John Ackerman, you mentioned > grinding down the old bolts and using them as guide pins. Could you > elaborate? Any pics? > David Maib > RV-10 #40559 > ________________________________________________________________________________
Date: Jan 01, 2008
Subject: Fwd: [gns480-users] Software, Version 2.2
Well.........there goes my avionics selections......... ---------- Forwarded message ---------- From: Donald Kaye <donkaye(at)earthlink.net> Date: Jan 1, 2008 12:51 PM Subject: Re: [gns480-users] Software, Version 2.2 Originally I thought it might be a hoax, but with Keith Thomassen responding, I fear it might be true that the Garmin 480, one of the best GPSs I have flown, is being discontinued. > From: Keith Thomassen <thomassen(at)avionicswest.com> > > Date: Tue, 1 Jan 2008 09:59:31 > To:gns480-users(at)yahoogroups.com > Subject: Re: [gns480-users] Software, Version 2.2 > > > John; After seeing the post on the discontinuation of the 480, I'm > not sure if there will be a software update. In any event, I don't > know what else was planned. I'm totally shocked, sad, and > disappointed with Garmin. > > Keith > ---- Donald Kaye | Master CFI, MEI mailto:donkaye(at)earthlink.net | N9148W M20M ________________________________________________________________________________
Subject: Paint scheme program for RV-10
Date: Jan 01, 2008
By request of myself and a few others, armed with the schematic diagrams of the RV-10 from the DXF file posted elsewhere, William Busto has added the RV-10 to his aircraft paint simulation programs. According to his message to me today: The new MACD RV-10 Version 2.2 color scheme program is now ready for download. Version 2.2 adds the ability to design your own custom graphics for the wheel pants. The RV-10s cabin interior color, including the seat colors, can be customized to your taste. Another new feature is that you can open the cabin door. This makes it easy to coordinate the interior colors. You can download the new program from Client Downloads, if you wish, as a free upgrade for previous customers. New customers will need to purchase the program. The software trial and download and RV-10 design base are available at: http://www.airplanecolor.com -------- RV-10 Builder #40546 Tail mostly done, wings complete, starting SB fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155462#155462 ________________________________________________________________________________
Date: Jan 01, 2008
What a great News Years Day gift. Thank you and thank William as well. John Cox #40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddnebert Sent: Tuesday, January 01, 2008 7:18 PM Subject: RV10-List: Paint scheme program for RV-10 By request of myself and a few others, armed with the schematic diagrams of the RV-10 from the DXF file posted elsewhere, William Busto has added the RV-10 to his aircraft paint simulation programs. According to his message to me today: The new MACD RV-10 Version 2.2 color scheme program is now ready for download. Version 2.2 adds the ability to design your own custom graphics for the wheel pants. The RV-10s cabin interior color, including the seat colors, can be customized to your taste. Another new feature is that you can open the cabin door. This makes it easy to coordinate the interior colors. You can download the new program from Client Downloads, if you wish, as a free upgrade for previous customers. New customers will need to purchase the program. The software trial and download and RV-10 design base are available at: http://www.airplanecolor.com -------- RV-10 Builder #40546 Tail mostly done, wings complete, starting SB fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155462#155462 ________________________________________________________________________________
Date: Jan 01, 2008
Am I stupid or am I missing something I know that it would be a good idea to check the QB work and have a placement for my MB and transponder antennas, but why take up the floorboards. I think that they are already primed. Carpet with some foam backing will provide front insulation..... splain me -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155468#155468 ________________________________________________________________________________
Subject: Re: Paint scheme program for RV-10
Date: Jan 01, 2008
How much $ and does it run on a PC or Mac only?? -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155469#155469 ________________________________________________________________________________
Date: Jan 01, 2008
after 15 day trail looks like $14.95 Version 2.2 - System Requirements a.. Pentium 400 Mhz PC, 128 MB memory, mouse, joystick, 17 inch monitor or better. a.. Windows XP/2000/Me/98/95 with DirectX 8.0 or higher. a.. Windows VISTA is not compatible with MACD Version 2 Due to changes in the new operating system by Microsoft, MACD will not install properly on Windows Vista. A fix for this problem may be available soon. a.. A DirectX 8.0 compatible Graphics Adapter with 3D hardware acceleration. Any PC, built from the year 2001 until now, should already have 3D hardware acceleration built in. If not, MACD V 2.2 will display a message for you. The free trial program will also inform you. You can download the free trial here. a.. Windows XP users already have DirectX 8.0 or higher installed in their systems so an upgrade is not required. a.. Users of Windows 95/98/Me/2000 will need to upgrade to DirectX 8 or 9, if you haven't done so already. DirectX is a free download from the Microsoft DirectX website. a.. Please download the free trial program if you're not sure that your system meets the requirements. It will display a message for you if it doesn't. ----- Original Message ----- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Tuesday, January 01, 2008 8:03 PM Subject: RV10-List: Re: Paint scheme program for RV-10 > > How much $ and does it run on a PC or Mac only?? > > -------- > OSH '08 or Bust > Q/B Kit - Doors/windows/fiberglass stuff > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155469#155469 > > > ________________________________________________________________________________
Date: Jan 02, 2008
AirMike wrote: > Am I stupid or am I missing something > > I know that it would be a good idea to check the QB work and have a placement for my MB and transponder antennas, but why take up the floorboards. I think that they are already primed. Carpet with some foam backing will provide front insulation..... splain me AirMike, I've wondered the same thing myself. If inspection is the only purpose, then why not cut an inspection port? Make it large enough to get your hand in and you have access to install antennas. To close the port up, get one of those plastic round caps the post office uses for tube mailers. If strength is degraded, then screw a top plate on it. To me it's like the QB wings: the bottom skin was put on by the QB folks so that you can't easily rivet the flap fairings. Big deal, that's what CherryMax rivets are for. Just my opinion, John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155532#155532 ________________________________________________________________________________
Subject: Garmin 480
Date: Jan 02, 2008
I'm surprised the 480 lasted this long. I always thought that the government should have examined the Garmin purchase of UPSAT for anti-competitive effects. L-3 (Goodrich) really blew it and should have bought UPSAT. They would have inherited some nice revenue streams and some nice radios right off the bat. TDT 40025 Main wheelpants done! Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) "Non plaudite. Modo pecuniam jacite." ________________________________________________________________________________
Date: Jan 02, 2008
Subject: Re: Garmin 480
Not lasting is one thing, not supporting it is another. Software upgrades I 'm not so concerned about as long as mine remains functional, databases upg rades from Jepp=C2-I am concerned about. Rick S. 40185 ----- Original Message ----- From: "Timothy Dawson-Townsend" <tdawson-townsend(at)aurora.aero> Sent: Wednesday, January 2, 2008 7:48:40 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Garmin 480 I=99m surprised the 480 lasted this long. I always thought that the government should have examined the Garmin purcha se of UPSAT for anti-competitive effects.=C2- L-3 (Goodrich) really blew it and should have bought UPSAT.=C2- They woul d have inherited some nice revenue streams and some nice radios right off t he bat. TDT 40025 Main wheelpants done! Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) "Non plaudite. Modo pecuniam jacite." ==== ======================= ________________________________________________________________________________
Subject: Garmin 480
Date: Jan 02, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I'm sure there are plenty of us in that boat. All we can do is look to other products (like the GX-50 & GX-60) which still get Jepp DB support even though they were abandoned when the acquisition of UPSAT by Garmin was completed. Bob #40105 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Wednesday, January 02, 2008 10:22 AM Subject: Re: RV10-List: Garmin 480 Not lasting is one thing, not supporting it is another. Software upgrades I'm not so concerned about as long as mine remains functional, databases upgrades from Jepp I am concerned about. Rick S. 40185 ----- Original Message ----- From: "Timothy Dawson-Townsend" <tdawson-townsend(at)aurora.aero> Sent: Wednesday, January 2, 2008 7:48:40 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Garmin 480 I'm surprised the 480 lasted this long. I always thought that the government should have examined the Garmin purchase of UPSAT for anti-competitive effects. L-3 (Goodrich) really blew it and should have bought UPSAT. They would have inherited some nice revenue streams and some nice radios right off the bat. TDT 40025 Main wheelpants done! Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) "Non plaudite. Modo pecuniam jacite." blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 02, 2008
Subject: Garmin 480
It's probably safe to say that as long as the demand is there, Jepp will co ntinue updates. One of the few advantages to having a outside supplier for the updated database. Happy New Year everyone! Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Wednesday, January 02, 2008 10:36 AM Subject: RE: RV10-List: Garmin 480 I'm sure there are plenty of us in that boat. All we can do is look to oth er products (like the GX-50 & GX-60) which still get Jepp DB support even t hough they were abandoned when the acquisition of UPSAT by Garmin was compl eted. Bob #40105 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Rick Sked Sent: Wednesday, January 02, 2008 10:22 AM Subject: Re: RV10-List: Garmin 480 Not lasting is one thing, not supporting it is another. Software upgrades I 'm not so concerned about as long as mine remains functional, databases upg rades from Jepp I am concerned about. Rick S. 40185 ----- Original Message ----- From: "Timothy Dawson-Townsend" <tdawson-townsend(at)aurora.aero> Sent: Wednesday, January 2, 2008 7:48:40 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Garmin 480 I'm surprised the 480 lasted this long. I always thought that the government should have examined the Garmin purcha se of UPSAT for anti-competitive effects. L-3 (Goodrich) really blew it and should have bought UPSAT. They would hav e inherited some nice revenue streams and some nice radios right off the ba t. TDT 40025 Main wheelpants done! Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) "Non plaudite. Modo pecuniam jacite." blank>http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com ________________________________________________________________________________
Date: Jan 02, 2008
In a message dated 1/2/2008 12:56:02 PM Central Standard Time, bob.condrey(at)baesystems.com writes: All we can do is look to other products (like the GX-50 & GX-60) which still get Jepp DB support even though they were abandoned when the acquisition of UPSAT by Garmin was completed. Or the 300xl from Garmin that Jepp still sells updates to... P (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Jan 02, 2008
OK, I went and pulled the bedsheets off of my QB Fuselage and took a good look. A total of 12 pull rivets holding down each of the aft passenger floorboards. I can see where it would be tricky to pull it because of all the AN470 rivet heads, etc. I'll go through the plans tomorrow and figure out what's underneath. There must be something I'm missing because I don't see why it's such a problem. I'll get back tomorrow. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155616#155616 ________________________________________________________________________________
Subject: tailcone wiring
Date: Jan 02, 2008
I am getting ready to attach the tailcone to the fuselage but I figure it would be better / easier to run all the wires for the items in the tail while I can still crawl into it before it's attached. I was thinking about running conduit through the bulkheads down one side and pre running wires within it (or at least string). Items for wiring Nav Antenna Tail Nav light Tail Strobe light Pitch Trim Servo wiring ELT Does anyone have any pictures of how they routed their wiring? -Ben Westfall #40579 ________________________________________________________________________________
Subject: Weight after paint
Date: Jan 02, 2008
921AC is out of the paint shop (a couple weeks ago, actually). I like the way it turned out. It's not a show winner but the overall quality is good and the weight is less than expected. We'll have some better pictures up soon. I decided to polish the wings instead of painting, mostly to save weight. I had another polished plane and it held up pretty well. The white paint is Jet Glow single stage. The yellow and gray are color/clear coat. I weighed the plane right before and after. With an average amount of body work and filling, the empty weight went from 1588 to 1598. I think painting the wings would have added another 10 lbs at least. This was a lot less than I expected. I've weighed a few others before and after, and I was expecting more like 20-25 lbs. I set a goal of 1600 for the empty weight, so after the interior goes in later this month, I'm now hoping it won't be much more than 1625. Close enough. Happy New Year! Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Jan 03, 2008
Subject: Re: tailcone wiring
I waited until after I attached the tailcone and found that I didn't need to crawl into the tailcone at all (yet). With the fuselage at the right height, everything is very accessible for my 6' bod and reach. Because all of the tailcone wiring runs forward, my thinking is that it's all easier to do with the fuselage joined. Then you have a good long session of wiring the battery compartment, tailcone, and other stuff. My approach was to copy the routing used in Van's wiring kit (I didn't buy the kit). That is to run the wire down one of the J-stiffeners. Here's where thorough deburring pays off because you don't won't the wire to contact any burrs. For insurance, I put a 1 inch length of shrink tubing where it passes each bulkhead and then added a small length (3/8" perhaps) of edge grommet to each bulkhead. The grommet work really well without adhesive. It's all tied down with tie wraps. Very neat and easy. Giving the whole bundle a twist keeps everything especially neat. Which is not to say my installation is particularly neat... but I'll do better next time. I ran wire for the nav light, strobe, pitch trim, and rudder trim (just in case I do the rudder trim later). I holding off on the ELT hoping there will be an experimentally priced solution with the latest tech standard (900mhz or whatever). I'm going with wing tip Nav antenna. Generally, I'm avoiding conduit for all the initial wiring and only putting empty conduit in for any and all the stuff I'm bound to figure out later. Just a choice. Attached is a pic but I'm not sure it will post. I can send directly. Bill "done flying for a while and ready to build again" Watson Ben Westfall wrote: > > I am getting ready to attach the tailcone to the fuselage but I figure > it would be better / easier to run all the wires for the items in the > tail while I can still crawl into it before it's attached. I was > thinking about running conduit through the bulkheads down one side and > pre running wires within it (or at least string). > > > > Items for wiring > > > > Nav Antenna > > Tail Nav light > > Tail Strobe light > > Pitch Trim Servo wiring > > ELT > > > > Does anyone have any pictures of how they routed their wiring? > > > > -Ben Westfall > > #40579 > > > ________________________________________________________________________________
Date: Jan 03, 2008
I've been following this thread and when I was in Aircraft Spruce yesterday (I live 4 miles away), I asked them if they had a Garmin 480 in stock. I kept getting the yes/no/maybe while he went through his computer, but it turns out the Garmin 480 has been discontinued and is out of stock. However, the counter guy said that they have a whole bunch of NEW Garmin Longstar (?) 480s ordered but they haven't arrived. Price will be $250. Apparently the replacement has a new name - Longstar (I think that's the name he said). John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155732#155732 ________________________________________________________________________________
Date: Jan 03, 2008
"$250." ???? Rick S. 40185 ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Thursday, January 3, 2008 7:18:15 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Re: Garmin 480 I've been following this thread and when I was in Aircraft Spruce yesterday (I live 4 miles away), I asked them if they had a Garmin 480 in stock. I kept getting the yes/no/maybe while he went through his computer, but it turns out the Garmin 480 has been discontinued and is out of stock. However, the counter guy said that they have a whole bunch of NEW Garmin Longstar (?) 480s ordered but they haven't arrived. Price will be $250. Apparently the replacement has a new name - Longstar (I think that's the name he said). John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155732#155732 ________________________________________________________________________________
Subject: Re: Weight after paint
Date: Jan 03, 2008
Very nice looking Dave. When I first looked, I thought the lower part of the fuse was polished as well. Did you consider doing that? It looks to me like this is the airplane that has the left aft upper cowling hinged. How has that worked for you and do you have any drawings, plans, tips, etc. that you can share. I am interested in that mod. Regards, -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155746#155746 ________________________________________________________________________________
Date: Jan 03, 2008
ricksked(at)embarqmail.co wrote: > "$250." ???? > Rick S. > 40185 > --- My guess is that it's only the chip. For those guys who already have one, it looks like the update chips will keep on coming. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155831#155831 ________________________________________________________________________________
Date: Jan 03, 2008
Spent an hour today pouring over the plans and identifying the issues. Pulling any of the floorboards (front or back) pretty much defeats the purpose of "Quick Build" in my opinion. The front ones do have limited access as far as fishing out surprises, but I don't see any other need to get in there (please tell me if I'm wrong). The rear floorboards are very thin in depth, but an errant cleco could be in there. I suspect a strong magnet would answer that question. As far as antenna placement, the baggage floor seems a far easier place for access. I hope that nobody thinks I'm being forward or pushy, but I'm at a loss for a good reason to spend hours undoing what I just paid to have done. Humbly and ready to take some shots, John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved
- - - , 20- - January 03, 2008
RV10-Archive.digest.vol-cx
