RV10-Archive.digest.vol-cy
January 03, 2008 - January 15, 2008
      http://forums.matronics.com/viewtopic.php?p=155834#155834
Subject: Re: qb kit-front floor panels removal and gear mount
Date: Jan 03, 2008
I concur: my QB number for the fuselage was #8 and they did not at that time install the forward weldment support nut plates; I reported this to Van's and indicated that that was the only reason to remove it. I believe that they have since installed the nut plates for the forward support. In my case they also installed the mid fuselage floorboards with stemmed blinds and thus the removal was complicated slightly; it require some finesse to get the floors out. Underneath nothing was found. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Thursday, January 03, 2008 6:40 PM Subject: RV10-List: Re: qb kit-front floor panels removal and gear mount --> Spent an hour today pouring over the plans and identifying the issues. Pulling any of the floorboards (front or back) pretty much defeats the purpose of "Quick Build" in my opinion. The front ones do have limited access as far as fishing out surprises, but I don't see any other need to get in there (please tell me if I'm wrong). The rear floorboards are very thin in depth, but an errant cleco could be in there. I suspect a strong magnet would answer that question. As far as antenna placement, the baggage floor seems a far easier place for access. I hope that nobody thinks I'm being forward or pushy, but I'm at a loss for a good reason to spend hours undoing what I just paid to have done. Humbly and ready to take some shots, John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155834#155834 ________________________________________________________________________________
Date: Jan 03, 2008
John, Your's may be different, but my QB had temporary (soft) rivets holding the floorboards in and didn't take long to remove. I needed to remove those rivets anyway and there weren't that many of them so it made sense to pop them out and have a look. Plus the opportunity to add noise insulation. If your panels are completely riveted in then I can see your hesitancy. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Thursday, January 03, 2008 7:40 PM Subject: RV10-List: Re: qb kit-front floor panels removal and gear mount Spent an hour today pouring over the plans and identifying the issues. Pulling any of the floorboards (front or back) pretty much defeats the purpose of "Quick Build" in my opinion. The front ones do have limited access as far as fishing out surprises, but I don't see any other need to get in there (please tell me if I'm wrong). The rear floorboards are very thin in depth, but an errant cleco could be in there. I suspect a strong magnet would answer that question. As far as antenna placement, the baggage floor seems a far easier place for access. I hope that nobody thinks I'm being forward or pushy, but I'm at a loss for a good reason to spend hours undoing what I just paid to have done. Humbly and ready to take some shots, John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155834#155834 ________________________________________________________________________________
Date: Jan 03, 2008
if you are tearing a QB apart to find a cleco.. just move the fuselage around and see if you hear anything.. I gathered people were doing this for the insulation install and putting conduit in that space, hence the effort to remove the floorboards to get in there. If you don't see any need to do anything under the floor, I'd agree focus your time and effort elsewhere. as far as being forward or pushy..I commend you for not being a blind follower and thinking this out for your individual case. Pascal #720 ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Thursday, January 03, 2008 5:40 PM Subject: RV10-List: Re: qb kit-front floor panels removal and gear mount > > Spent an hour today pouring over the plans and identifying the issues. > Pulling any of the floorboards (front or back) pretty much defeats the > purpose of "Quick Build" in my opinion. The front ones do have limited > access as far as fishing out surprises, but I don't see any other need to > get in there (please tell me if I'm wrong). The rear floorboards are very > thin in depth, but an errant cleco could be in there. I suspect a strong > magnet would answer that question. > As far as antenna placement, the baggage floor seems a far easier place > for access. > > I hope that nobody thinks I'm being forward or pushy, but I'm at a loss > for a good reason to spend hours undoing what I just paid to have done. > > Humbly and ready to take some shots, > John > > -------- > #40572 QB Wings, QB Fuse arrived > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155834#155834 > > > ________________________________________________________________________________
Date: Jan 03, 2008
Subject: Re: tailcone wiring
If you go this route, as I did, it would be much easier to drill and deburr the holes in the J stiffeners now. It is easy enough to run the wire later. I have a wire runs on each side. Get the static port in now, also much easier than later. At least that is how I would do it /next /time. Larry #356 MauleDriver wrote: > I waited until after I attached the tailcone and found that I didn't > need to crawl into the tailcone at all (yet). With the fuselage at the > right height, everything is very accessible for my 6' bod and reach. > Because all of the tailcone wiring runs forward, my thinking is that > it's all easier to do with the fuselage joined. Then you have a good > long session of wiring the battery compartment, tailcone, and other stuff. > > My approach was to copy the routing used in Van's wiring kit (I didn't > buy the kit). That is to run the wire down one of the J-stiffeners. > Here's where thorough deburring pays off because you don't won't the > wire to contact any burrs. For insurance, I put a 1 inch length of > shrink tubing where it passes each bulkhead and then added a small > length (3/8" perhaps) of edge grommet to each bulkhead. The grommet > work really well without adhesive. It's all tied down with tie wraps. > Very neat and easy. Giving the whole bundle a twist keeps everything > especially neat. Which is not to say my installation is particularly > neat... but I'll do better next time. > > I ran wire for the nav light, strobe, pitch trim, and rudder trim > (just in case I do the rudder trim later). I holding off on the ELT > hoping there will be an experimentally priced solution with the latest > tech standard (900mhz or whatever). I'm going with wing tip Nav antenna. > > Generally, I'm avoiding conduit for all the initial wiring and only > putting empty conduit in for any and all the stuff I'm bound to figure > out later. Just a choice. > > Attached is a pic but I'm not sure it will post. I can send directly. > > Bill "done flying for a while and ready to build again" Watson > > Ben Westfall wrote: >> >> I am getting ready to attach the tailcone to the fuselage but I >> figure it would be better / easier to run all the wires for the items >> in the tail while I can still crawl into it before its attached. I >> was thinking about running conduit through the bulkheads down one >> side and pre running wires within it (or at least string). >> >> Items for wiring >> >> Nav Antenna >> >> Tail Nav light >> >> Tail Strobe light >> >> Pitch Trim Servo wiring >> >> ELT >> >> Does anyone have any pictures of how they routed their wiring? >> >> -Ben Westfall >> >> #40579 >> > > > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Jan 03, 2008
John, I could not make up my mind. One day I was going to pull them out, and the next day I wasn't going to. In the end, I decided to dig in and do it. I am about halfway through the process and I must say, I agree with you. I paid good money for the quick build and am now spending lots of precious time taking it apart. I think the problems with tools under the floor and quality control issues have probably been laid to rest since the early days. It is not particularly hard, just time consuming and the value is minimal. Since I am committed, I plan to go ahead and put insulating/sound deadening material in there. I will probably go ahead and put the transponder antenna and perhaps a comm antenna under the front floor as well. But, if I had it to do over again...........................probably not. David Maib 40559 On Jan 3, 2008, at 7:40 PM, johngoodman wrote: Spent an hour today pouring over the plans and identifying the issues. Pulling any of the floorboards (front or back) pretty much defeats the purpose of "Quick Build" in my opinion. The front ones do have limited access as far as fishing out surprises, but I don't see any other need to get in there (please tell me if I'm wrong). The rear floorboards are very thin in depth, but an errant cleco could be in there. I suspect a strong magnet would answer that question. As far as antenna placement, the baggage floor seems a far easier place for access. I hope that nobody thinks I'm being forward or pushy, but I'm at a loss for a good reason to spend hours undoing what I just paid to have done. Humbly and ready to take some shots, John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155834#155834 ________________________________________________________________________________
Date: Jan 03, 2008
Totally agree on both points. Drilling the holes for the ties in the J channel were not much of an hassle after joining the fuse but would be easier and done more accurately before joining. My static ports were done before joining - a good way to go. Larry Rosen wrote: > > If you go this route, as I did, it would be much easier to drill and > deburr the holes in the J stiffeners now. It is easy enough to run the > wire later. I have a wire runs on each side. > > Get the static port in now, also much easier than later. > > At least that is how I would do it /next /time. > > Larry > #356 > > MauleDriver wrote: >> I waited until after I attached the tailcone and found that I didn't >> need to crawl into the tailcone at all (yet). With the fuselage at >> the right height, everything is very accessible for my 6' bod and >> reach. Because all of the tailcone wiring runs forward, my thinking >> is that it's all easier to do with the fuselage joined. Then you have >> a good long session of wiring the battery compartment, tailcone, and >> other stuff. >> >> My approach was to copy the routing used in Van's wiring kit (I >> didn't buy the kit). That is to run the wire down one of the >> J-stiffeners. Here's where thorough deburring pays off because you >> don't won't the wire to contact any burrs. For insurance, I put a 1 >> inch length of shrink tubing where it passes each bulkhead and then >> added a small length (3/8" perhaps) of edge grommet to each bulkhead. >> The grommet work really well without adhesive. It's all tied down >> with tie wraps. Very neat and easy. Giving the whole bundle a twist >> keeps everything especially neat. Which is not to say my installation >> is particularly neat... but I'll do better next time. >> >> I ran wire for the nav light, strobe, pitch trim, and rudder trim >> (just in case I do the rudder trim later). I holding off on the ELT >> hoping there will be an experimentally priced solution with the >> latest tech standard (900mhz or whatever). I'm going with wing tip >> Nav antenna. >> >> Generally, I'm avoiding conduit for all the initial wiring and only >> putting empty conduit in for any and all the stuff I'm bound to >> figure out later. Just a choice. >> >> Attached is a pic but I'm not sure it will post. I can send directly. >> >> Bill "done flying for a while and ready to build again" Watson >> >> Ben Westfall wrote: >>> >>> I am getting ready to attach the tailcone to the fuselage but I >>> figure it would be better / easier to run all the wires for the >>> items in the tail while I can still crawl into it before its >>> attached. I was thinking about running conduit through the bulkheads >>> down one side and pre running wires within it (or at least string). >>> >>> Items for wiring >>> >>> Nav Antenna >>> >>> Tail Nav light >>> >>> Tail Strobe light >>> >>> Pitch Trim Servo wiring >>> >>> ELT >>> >>> Does anyone have any pictures of how they routed their wiring? >>> >>> -Ben Westfall >>> >>> #40579 >>> >> >> >> ------------------------------------------------------------------------ >> > > ________________________________________________________________________________
Subject: tailcone wiring
Date: Jan 03, 2008
I did the wiring and static ports before attachment; it is easier to secure the wiring, deburr the holes and install grommets or snap bushings. Another means to secure the wiring is Adel clamps and click bond fasteners http://www.clickbond.com/index.php. These can be epoxied anywhere and provide a very secure wiring bundle to prevent chafing and repair down the road. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Thursday, January 03, 2008 7:19 PM Subject: Re: RV10-List: tailcone wiring If you go this route, as I did, it would be much easier to drill and deburr the holes in the J stiffeners now. It is easy enough to run the wire later. I have a wire runs on each side. Get the static port in now, also much easier than later. At least that is how I would do it /next /time. Larry #356 MauleDriver wrote: > I waited until after I attached the tailcone and found that I didn't > need to crawl into the tailcone at all (yet). With the fuselage at the > right height, everything is very accessible for my 6' bod and reach. > Because all of the tailcone wiring runs forward, my thinking is that > it's all easier to do with the fuselage joined. Then you have a good > long session of wiring the battery compartment, tailcone, and other stuff. > > My approach was to copy the routing used in Van's wiring kit (I didn't > buy the kit). That is to run the wire down one of the J-stiffeners. > Here's where thorough deburring pays off because you don't won't the > wire to contact any burrs. For insurance, I put a 1 inch length of > shrink tubing where it passes each bulkhead and then added a small > length (3/8" perhaps) of edge grommet to each bulkhead. The grommet > work really well without adhesive. It's all tied down with tie wraps. > Very neat and easy. Giving the whole bundle a twist keeps everything > especially neat. Which is not to say my installation is particularly > neat... but I'll do better next time. > > I ran wire for the nav light, strobe, pitch trim, and rudder trim > (just in case I do the rudder trim later). I holding off on the ELT > hoping there will be an experimentally priced solution with the latest > tech standard (900mhz or whatever). I'm going with wing tip Nav antenna. > > Generally, I'm avoiding conduit for all the initial wiring and only > putting empty conduit in for any and all the stuff I'm bound to figure > out later. Just a choice. > > Attached is a pic but I'm not sure it will post. I can send directly. > > Bill "done flying for a while and ready to build again" Watson > > Ben Westfall wrote: >> >> I am getting ready to attach the tailcone to the fuselage but I >> figure it would be better / easier to run all the wires for the items >> in the tail while I can still crawl into it before it's attached. I >> was thinking about running conduit through the bulkheads down one >> side and pre running wires within it (or at least string). >> >> Items for wiring >> >> Nav Antenna >> >> Tail Nav light >> >> Tail Strobe light >> >> Pitch Trim Servo wiring >> >> ELT >> >> Does anyone have any pictures of how they routed their wiring? >> >> -Ben Westfall >> >> #40579 >> > > > ---------------------------------------------------------------------- > -- > ________________________________________________________________________________
Date: Jan 03, 2008
One other consideration: tie wraps get brittle and break with age. YOu can use adel clamps or make sure the access is easy to replace when necessary. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: Thursday, January 03, 2008 8:21 PM Subject: Re: RV10-List: tailcone wiring Totally agree on both points. Drilling the holes for the ties in the J channel were not much of an hassle after joining the fuse but would be easier and done more accurately before joining. My static ports were done before joining - a good way to go. Larry Rosen wrote: > > If you go this route, as I did, it would be much easier to drill and > deburr the holes in the J stiffeners now. It is easy enough to run the > wire later. I have a wire runs on each side. > > Get the static port in now, also much easier than later. > > At least that is how I would do it /next /time. > > Larry > #356 > > MauleDriver wrote: >> I waited until after I attached the tailcone and found that I didn't >> need to crawl into the tailcone at all (yet). With the fuselage at >> the right height, everything is very accessible for my 6' bod and >> reach. Because all of the tailcone wiring runs forward, my thinking >> is that it's all easier to do with the fuselage joined. Then you have >> a good long session of wiring the battery compartment, tailcone, and >> other stuff. >> >> My approach was to copy the routing used in Van's wiring kit (I >> didn't buy the kit). That is to run the wire down one of the >> J-stiffeners. Here's where thorough deburring pays off because you >> don't won't the wire to contact any burrs. For insurance, I put a 1 >> inch length of shrink tubing where it passes each bulkhead and then >> added a small length (3/8" perhaps) of edge grommet to each bulkhead. >> The grommet work really well without adhesive. It's all tied down >> with tie wraps. Very neat and easy. Giving the whole bundle a twist >> keeps everything especially neat. Which is not to say my installation >> is particularly neat... but I'll do better next time. >> >> I ran wire for the nav light, strobe, pitch trim, and rudder trim >> (just in case I do the rudder trim later). I holding off on the ELT >> hoping there will be an experimentally priced solution with the >> latest tech standard (900mhz or whatever). I'm going with wing tip >> Nav antenna. >> >> Generally, I'm avoiding conduit for all the initial wiring and only >> putting empty conduit in for any and all the stuff I'm bound to >> figure out later. Just a choice. >> >> Attached is a pic but I'm not sure it will post. I can send directly. >> >> Bill "done flying for a while and ready to build again" Watson >> >> Ben Westfall wrote: >>> >>> I am getting ready to attach the tailcone to the fuselage but I >>> figure it would be better / easier to run all the wires for the >>> items in the tail while I can still crawl into it before it's >>> attached. I was thinking about running conduit through the bulkheads >>> down one side and pre running wires within it (or at least string). >>> >>> Items for wiring >>> >>> Nav Antenna >>> >>> Tail Nav light >>> >>> Tail Strobe light >>> >>> Pitch Trim Servo wiring >>> >>> ELT >>> >>> Does anyone have any pictures of how they routed their wiring? >>> >>> -Ben Westfall >>> >>> #40579 >>> >> >> >> --------------------------------------------------------------------- >> --- >> > > ________________________________________________________________________________
Date: Jan 03, 2008
Subject: wiring rear headset jacks
Are any 4 place wiring diagrams available out there? Front seats - need push-to-talk+intercom wiring Rear seats - need intercom only wiring (right?) I'm thinking 3 conductor shielded wire all the way around. Note that Stein has most excellent pricing compared with others. For the rear seats... Have folks run a single cable to each pair of L/R seat jacks (i.e. 2 cables total w/ parallel circuits), one cable per jack (4 cables total) or something different? If wiring for stereo, how's that different (conductor-wise) than mono? Different jacks too? Thanks in advance for non-flammable replies. Regards, Jay - jammin' on overhead and doors Looking for last minute shopping deals? ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: Re: wiring rear headset jacks
Date: Jan 04, 2008
Jay the wiring diagram will come with your intercom. The only difference we have made is we have wired the earth on the jacks all back to the panel . The wiring diagram if stereo will also show you what wire goes where. Very basic. Chris ----- Original Message ----- From: Jay Brinkmeyer To: RV10 Sent: Friday, January 04, 2008 5:16 PM Subject: RV10-List: wiring rear headset jacks Are any 4 place wiring diagrams available out there? Front seats - need push-to-talk+intercom wiring Rear seats - need intercom only wiring (right?) I'm thinking 3 conductor shielded wire all the way around. Note that Stein has most excellent pricing compared with others. For the rear seats... Have folks run a single cable to each pair of L/R seat jacks (i.e. 2 cables total w/ parallel circuits), one cable per jack (4 cables total) or something different? If wiring for stereo, how's that different (conductor-wise) than mono? Different jacks too? Thanks in advance for non-flammable replies. Regards, Jay - jammin' on overhead and doors ------------------------------------------------------------------------- ----- Be a better friend, newshound, and ________________________________________________________________________________
Date: Jan 04, 2008
I have been 'playing' with the old style lacing material and have used it in one inaccessible location in place of a tie wrap. I may do this in a few other locations. The most productive technique seems to be to use tie wraps initially then cut them off and tie off with lacing material. Having said that, I look at the many tie wraps in my '96 Maule and see little degradation. Including those under the cowl (non-heat resistant type). I think I remember reading that in addition to high heat, ultraviolet exposure will rapidly degrade the tie wraps. They sure are handy. David McNeill wrote: > > One other consideration: tie wraps get brittle and break with age. YOu can > use adel clamps or make sure the access is easy to replace when necessary. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver > Sent: Thursday, January 03, 2008 8:21 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: tailcone wiring > > > Totally agree on both points. Drilling the holes for the ties in the J > channel were not much of an hassle after joining the fuse but would be > easier and done more accurately before joining. My static ports were done > before joining - a good way to go. > > Larry Rosen wrote: > >> >> If you go this route, as I did, it would be much easier to drill and >> deburr the holes in the J stiffeners now. It is easy enough to run the >> wire later. I have a wire runs on each side. >> >> Get the static port in now, also much easier than later. >> >> At least that is how I would do it /next /time. >> >> Larry >> #356 >> >> MauleDriver wrote: >> >>> I waited until after I attached the tailcone and found that I didn't >>> need to crawl into the tailcone at all (yet). With the fuselage at >>> the right height, everything is very accessible for my 6' bod and >>> reach. Because all of the tailcone wiring runs forward, my thinking >>> is that it's all easier to do with the fuselage joined. Then you have >>> a good long session of wiring the battery compartment, tailcone, and >>> other stuff. >>> >>> My approach was to copy the routing used in Van's wiring kit (I >>> didn't buy the kit). That is to run the wire down one of the >>> J-stiffeners. Here's where thorough deburring pays off because you >>> don't won't the wire to contact any burrs. For insurance, I put a 1 >>> inch length of shrink tubing where it passes each bulkhead and then >>> added a small length (3/8" perhaps) of edge grommet to each bulkhead. >>> The grommet work really well without adhesive. It's all tied down >>> with tie wraps. Very neat and easy. Giving the whole bundle a twist >>> keeps everything especially neat. Which is not to say my installation >>> is particularly neat... but I'll do better next time. >>> >>> I ran wire for the nav light, strobe, pitch trim, and rudder trim >>> (just in case I do the rudder trim later). I holding off on the ELT >>> hoping there will be an experimentally priced solution with the >>> latest tech standard (900mhz or whatever). I'm going with wing tip >>> Nav antenna. >>> >>> Generally, I'm avoiding conduit for all the initial wiring and only >>> putting empty conduit in for any and all the stuff I'm bound to >>> figure out later. Just a choice. >>> >>> Attached is a pic but I'm not sure it will post. I can send directly. >>> >>> Bill "done flying for a while and ready to build again" Watson >>> >>> Ben Westfall wrote: >>> >>>> I am getting ready to attach the tailcone to the fuselage but I >>>> figure it would be better / easier to run all the wires for the >>>> items in the tail while I can still crawl into it before it's >>>> attached. I was thinking about running conduit through the bulkheads >>>> down one side and pre running wires within it (or at least string). >>>> >>>> Items for wiring >>>> >>>> Nav Antenna >>>> >>>> Tail Nav light >>>> >>>> Tail Strobe light >>>> >>>> Pitch Trim Servo wiring >>>> >>>> ELT >>>> >>>> Does anyone have any pictures of how they routed their wiring? >>>> >>>> -Ben Westfall >>>> >>>> #40579 >>>> >>>> >>> --------------------------------------------------------------------- >>> --- >>> >>> >> >> >> > > > ________________________________________________________________________________
Date: Jan 04, 2008
Almost anything is easy, once you know how it's done... I found the PMA8000B datasheet here: http://www.ps-engineering.com/docs/PMA8000B_IM.pdf Rear headset mics: 2 conductor shielded Rear headset phones: 3 conductor shielded Thanks to those that responded both online and offline. Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155919#155919 ________________________________________________________________________________
Subject: AFtermarket intersection fairings
Date: Jan 04, 2008
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Has anyone used aftermarket intersection fairings for the gear legs? Thoughts? TDT 40025 Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jan 04, 2008
Jay, You would use individual 3 pair shielded wire for the pilot and co-pilot headphones. The rear passengers can share a common 3 pair. For the microphones you will need an individual 2 pair for each place. Consider also adding another 3 pair to the front and rear for audio input. Most audio panels now allow separate front and rear audio inputs. I'll have both front and rear audio inputs with a switch so that front or rear passengers can listen to either front or rear audio source. This all assumes stereo. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Are any 4 place wiring diagrams > available out there? > > Front seats - need push-to-talk+intercom wiring > Rear seats - need intercom only wiring (right?) > > I'm thinking 3 conductor shielded wire all the way around. Note that Stein has most excellent pricing compared with others. > > For the rear seats... Have folks run a single cable to > each pair of L/R seat jacks (i.e. 2 cables total w/ parallel circuits), one cable per jack (4 cables total) or something different? > > If wiring for stereo, how's that different (conductor-wise) than mono? Different jacks too? > > Thanks in advance for non-flammable replies. > > Regards, > Jay > - jammin' on overhead and doors > > > > > Looking for last minute shopping deals? ________________________________________________________________________________
Date: Jan 04, 2008
Very cool stuff. Get 'em here... http://www.theflightshop.com/ClickBond/Click_Bond_Info.php Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155931#155931 ________________________________________________________________________________
Date: Jan 04, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Also for the archives, here's a link to 1/8" stereo jacks that are ground isolated: http://www.mouser.com/search/ProductDetail.aspx?R=161-7300-EX Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb Sent: Friday, January 04, 2008 8:34 AM Subject: RV10-List: Re: wiring rear headset jacks Almost anything is easy, once you know how it's done... I found the PMA8000B datasheet here: http://www.ps-engineering.com/docs/PMA8000B_IM.pdf Rear headset mics: 2 conductor shielded Rear headset phones: 3 conductor shielded Thanks to those that responded both online and offline. Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155919#155919 ________________________________________________________________________________
Subject: Battery box question
Date: Jan 04, 2008
I'm finally finishing up my modified battery tray but on page 10-16 step 8 (figure 3) I think I made a mistake. The figure has you countersink #30 the 4 holes for the F1036B Battery Channels in the F1035 battery/bellcrank mount. I did this but started reading on and on page 10-17 step 6 (figure 3) it shows the 1036's laid over the countersinks I just drilled and using AN470 rivets instead of 426's. I should've looked ahead and realized that these didn't need countersunk but hindsight is 20/20. My question is If I have screwed up how do I fix it or do I need to worry about it??? Thanks, Bill Finally back to work ________________________________________________________________________________
Date: Jan 04, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Re: AFtermarket intersection fairings
Tim; I'm currently working on the leg fairings. I met Mark Ritter this last weekend and looked at his plane. He purchased some after market upper fairings from faringsetc. I went and looked at the site. They were $125 . I just couldn't get myself to spend that 100 + bucks. I did go ahead and bond the lower fairings to the wheel pants and will then split them so they can be taken apart. Should work well. I can get you some pics if you need them. I was some more work, but I think it will look better. Fred 40515 Dawson-Townsend,Timothy wrote: > > Has anyone used aftermarket intersection fairings for the gear legs? > Thoughts? > > > > TDT > > 40025 > > > > Tim Dawson-Townsend > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Jan 04, 2008
I tried to look up fairingsetc.com on the internet, but it says the site is no longer available. Do you have the web site for the fairings? Thanks, Greg... -------- Greg Hale rv8/rv10 www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155968#155968 ________________________________________________________________________________
Date: Jan 04, 2008
This (1/8") is for the audio input jacks right? Standard aircraft earphone jacks are 1/4" and microphone jacks are 7/32" Since I'll be using Bose headsets all around, I'm thinking of NOT installing the standard aircraft mic and earphone jacks. 21st century jacks for an aircraft built in the 21st century. If I ever have to use a regular headphone, I'd just use a 1/4 - 7/32 to Bose adapter. http://www.bose.com/pdf/customer_service/owners/og_headset_x.pdf (Page 18) http://www.aircraftspruce.com/catalog/avpages/bosehdst.php Aircraft Spruce sells the the Bose jacks here is the part number. Aircraft Panel Installation Kit 11-01846 $31.00 William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Also for the archives, here's a link to 1/8" stereo jacks that are > ground isolated: > http://www.mouser.com/search/ProductDetail.aspx?R=161-7300-EX > > Bob > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb > Sent: Friday, January 04, 2008 8:34 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: wiring rear headset jacks > > > Almost anything is easy, once you know how it's done... > > I found the PMA8000B datasheet here: > > http://www.ps-engineering.com/docs/PMA8000B_IM.pdf > > Rear headset mics: 2 conductor shielded > Rear headset phones: 3 conductor shielded > > Thanks to those that responded both online and offline. > > Regards, > Jay > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155919#155919 > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 04, 2008
Right - they are for the audio panel aux inputs. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Friday, January 04, 2008 1:14 PM Subject: RE: RV10-List: Re: wiring rear headset jacks This (1/8") is for the audio input jacks right? Standard aircraft earphone jacks are 1/4" and microphone jacks are 7/32" Since I'll be using Bose headsets all around, I'm thinking of NOT installing the standard aircraft mic and earphone jacks. 21st century jacks for an aircraft built in the 21st century. If I ever have to use a regular headphone, I'd just use a 1/4 - 7/32 to Bose adapter. http://www.bose.com/pdf/customer_service/owners/og_headset_x.pdf (Page 18) http://www.aircraftspruce.com/catalog/avpages/bosehdst.php Aircraft Spruce sells the the Bose jacks here is the part number. Aircraft Panel Installation Kit 11-01846 $31.00 William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Also for the archives, here's a link to 1/8" stereo jacks that are > ground isolated: > http://www.mouser.com/search/ProductDetail.aspx?R=161-7300-EX > > Bob > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb > Sent: Friday, January 04, 2008 8:34 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: wiring rear headset jacks > > > Almost anything is easy, once you know how it's done... > > I found the PMA8000B datasheet here: > > http://www.ps-engineering.com/docs/PMA8000B_IM.pdf > > Rear headset mics: 2 conductor shielded > Rear headset phones: 3 conductor shielded > > Thanks to those that responded both online and offline. > > Regards, > Jay > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155919#155919 > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 04, 2008
http://www.fairings-etc.com/ -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of greghale Sent: Friday, January 04, 2008 12:46 PM Subject: RV10-List: Re: AFtermarket intersection fairings I tried to look up fairingsetc.com on the internet, but it says the site is no longer available. Do you have the web site for the fairings? Thanks, Greg... -------- Greg Hale rv8/rv10 www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155968#155968 ________________________________________________________________________________
Date: Jan 04, 2008
Subject: Re: Battery box question
not making sense to me but if you countersunk a 470 rivet hole just put a 426 in that hole, if you did the opposite, than countersink the hole.. either way the hole should be the same size so whatever you need to make it flush or not can be easily rectified.. as the strength should be the same anyway.. ----- Original Message ----- From: Bill & Tami Britton To: rv10-list(at)matronics.com Sent: Friday, January 04, 2008 8:55 AM Subject: RV10-List: Battery box question I'm finally finishing up my modified battery tray but on page 10-16 step 8 (figure 3) I think I made a mistake. The figure has you countersink #30 the 4 holes for the F1036B Battery Channels in the F1035 battery/bellcrank mount. I did this but started reading on and on page 10-17 step 6 (figure 3) it shows the 1036's laid over the countersinks I just drilled and using AN470 rivets instead of 426's. I should've looked ahead and realized that these didn't need countersunk but hindsight is 20/20. My question is If I have screwed up how do I fix it or do I need to worry about it??? Thanks, Bill Finally back to work ________________________________________________________________________________
Subject: DRDT-2 dimpler
Date: Jan 04, 2008
I just finished this today, plans and head unit from sales(at)experimentalaero.com -- took about 5 hrs. to fabricate, align, weld, paint. The steel came from a local scrap yard and is 1/4 instead of 3/16, so it's about 70 lbs. -- and since it is heftier, I made the throat a little deeper. I'm helping a friend build his RV-10 (wish we had had it for his!), and just got my tail section kit for my own. I added the laser X&Y axis guides ($5 ea. at Harbor Freight) to pinpoint where the die is to help line up the hole. It's VERY sweet! Just thought I'd pass on the laser thought. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156072#156072 Attachments: http://forums.matronics.com//files/drdt2_medium_127.jpg http://forums.matronics.com//files/drdt_medium_233.jpg ________________________________________________________________________________
Date: Jan 04, 2008
Thank you !! Thank you !! What a brilliant idea. When I built my 9 I ended up with little track lines on the skin where I was hunting for the hole and the lower die was contacting the skin. Problem solved. g >Just thought I'd pass on the laser thought. > >Later, - Lew ________________________________________________________________________________
Subject: VP200 CU mounting?
Date: Jan 04, 2008
Hey Jesse - so now that you've done an RV-10 with the VP system, where have you found to be the best place for the CU? inquiring minds want to know! cj ________________________________________________________________________________
Date: Jan 04, 2008
You laser light solution appears to have just resolved my only complaint with the DRDT-2. I guess I'll be heading to Harbor Freight when I get back from the BCS Bowl. Do you really need two lights to make it work effectively? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Friday, January 04, 2008 10:23 PM Subject: RV10-List: DRDT-2 dimpler I just finished this today, plans and head unit from sales(at)experimentalaero.com -- took about 5 hrs. to fabricate, align, weld, paint. The steel came from a local scrap yard and is 1/4 instead of 3/16, so it's about 70 lbs. -- and since it is heftier, I made the throat a little deeper. I'm helping a friend build his RV-10 (wish we had had it for his!), and just got my tail section kit for my own. I added the laser X&Y axis guides ($5 ea. at Harbor Freight) to pinpoint where the die is to help line up the hole. It's VERY sweet! Just thought I'd pass on the laser thought. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156072#156072 Attachments: http://forums.matronics.com//files/drdt2_medium_127.jpg http://forums.matronics.com//files/drdt_medium_233.jpg __________ NOD32 2766 (20080104) Information __________ ________________________________________________________________________________
Subject: battery box
Date: Jan 05, 2008
Subject: Safety-Trim Group Buy
Date: Jan 05, 2008
Now that you guys sold over 100 units, I assume that production has a backlog. Any idea about when shipping will happen? Gary 40274 Pick up from paint shop this weekend. Yippppeeeeee! _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob-tcw Sent: Friday, December 28, 2007 6:29 PM Subject: RV10-List: Safety-Trim Group Buy First I would like to thank all the builders who have signed up for the group buy. We appreciate your business and look forward to serving you. We hope you all have had a safe and enjoyable holiday season. This is the final weekend of the Vansairforce group buy for our Safety-Trim servo controller. Over 140 builders have signed up and will receive the full $100 discount on the 2 axis controller and $50 discount on the single axis controller. If you haven't signed up yet the promotion continues until the Dec 31. Other important notes. We've added a few more applications notes on our web site including details on the wiring harness available for use with Safety-Trim. Lastly, we are now selling an airspeed switch that is field adjustable between 55 and 140 knots and is perfect for triggering the 2 speed function on Safety-Trim. group buy link: http://www.vansairforce.com/community/showthread.php?t=24478 Best regards, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Subject: Re: VP200 CU mounting?
Date: Jan 05, 2008
I have installed one on a tray between the sub-panel and the instrument panel cross-bar all the way over on the right side of the panel. Then you just need to leave the bottom right side of the panel empty, which is easy with some panels I have seen and difficult with others. One is installed on the sub-panel, also on the right side, mounting vertically by modifying the right rib and making some stand- offs to hold it. This allows you to use the whole panel, but you can't have anything very deep on the right side of the panel, aft of the CU. If you could find a good place forward of the sub-panel that you could get to, then that would allow more panel room, but it would have to be mounted hanging from a tray mounted on the ribs, probably. My whole philosophy is ease of access down the road, so I like to keep it aft of the sub-panel. It could also be mounted in the tail, but there are a lot of power wires needing to go to the panel, so it would add a little bit of weight in wiring, although it would clean up your panel area quite a bit by keeping all of the wires for lights and things out in the wings and tail away from your panel area. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jan 4, 2008, at 10:51 PM, Chris Johnston wrote: > Hey Jesse - > > so now that you've done an RV-10 with the VP system, where have you > found to be the best place for the CU? inquiring minds want to know! > > cj > ________________________________________________________________________________
Subject: Re: DRDT-2 dimpler
Date: Jan 05, 2008
To the center of the die is 23". That just happened to be how the material I had to work with turned out -- I truly believe I could have added another 4 or 5 inches with no problem whatsoever. This thing is a monster, but solid as it can be! I was actually looking for a laser pointer with a single dot and I was thinking of activating it with a limit switch on the ram so it would only come on when needed. I couldn't wait and found these laser markers at Harbor Freight (Central Machinery, Laser Marker, item 93242) for $5 apiece. They attach with magnets, stickey pad, or screws and have an on/off switch. Since they form a line instead of a dot, I got two so that they make a cross hair right over the female die on the bottom. I read that some didn't like the male die on the bottom cuz it scratched the surface trying to line it up with the hole -- this way there's no scratch and easy alignment every time. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156125#156125 ________________________________________________________________________________
Date: Jan 05, 2008
So how are you setting it up so it doesn't "reflect" off the aluminum and cause some issues with the eyes? Granted it is reflected but I still have my concerns.. Even HB warns about it on item# 93242-2VGA * LASER PRODUCTS DANGER: LASER LIGHT. AVOID DIRECT EYE EXPOSURE. Max. Output <5 mW. This product complies with 21 CFR 1040.10 and 1040.11 ----- Original Message ----- From: "Bob Leffler" <rv(at)thelefflers.com> Sent: Friday, January 04, 2008 7:56 PM Subject: RE: RV10-List: DRDT-2 dimpler > > You laser light solution appears to have just resolved my only complaint > with the DRDT-2. I guess I'll be heading to Harbor Freight when I get > back > from the BCS Bowl. > > Do you really need two lights to make it work effectively? > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher > Sent: Friday, January 04, 2008 10:23 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: DRDT-2 dimpler > > > I just finished this today, plans and head unit from > sales(at)experimentalaero.com -- took about 5 hrs. to fabricate, align, weld, > paint. The steel came from a local scrap yard and is 1/4 instead of 3/16, > so it's about 70 lbs. -- and since it is heftier, I made the throat a > little > deeper. > > I'm helping a friend build his RV-10 (wish we had had it for his!), and > just > got my tail section kit for my own. > > I added the laser X&Y axis guides ($5 ea. at Harbor Freight) to pinpoint > where the die is to help line up the hole. It's VERY sweet! Just thought > I'd pass on the laser thought. > > Later, - Lew > > -------- > non-pilot > crazy about building > waiting on RV-10 finishing kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=156072#156072 > > > Attachments: > > http://forums.matronics.com//files/drdt2_medium_127.jpg > http://forums.matronics.com//files/drdt_medium_233.jpg > > > __________ NOD32 2766 (20080104) Information __________ > > > ________________________________________________________________________________
Date: Jan 05, 2008
My Craftsman drill press has something similar that puts two laser lines on the hole. The instructions make it pretty clear that it shouldn't be used with reflective metals. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156143#156143 ________________________________________________________________________________
Date: Jan 05, 2008
Subject: Re: Laser safety - Was Re: DRDT-2 dimpler
Try something like this: http://www.lasersafety.com/lasereyewear.html -Jim 40384 johngoodman wrote: > >My Craftsman drill press has something similar that puts two laser lines on the hole. The instructions make it pretty clear that it shouldn't be used with reflective metals. >John > >-------- >#40572 QB Wings, QB Fuse arrived >N711JG reserved > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=156143#156143 > > > > ________________________________________________________________________________
Date: Jan 05, 2008
This sounds neat. But I can't quite figure out how it helps yet. The technique I use is with the male die always on the top, I put the hold in the male die, then press down the handle which moves the sheet and the dies down onto the female die. Putting the male die on the bottom produces scratches. Allowing the sheet to lie on the female die and trying to hit it with the male die will sooner or later result in a new hole. I'm doing the baggage door right now on the DRDT-2 and I just can't figure out how to take advantage of a laser guide line. ...but I think I'll get them anyway and play. Bill Watson ________________________________________________________________________________
Date: Jan 05, 2008
Unfortunately, with the leading edges having the male on top would involve putting the c-frame inside the skins and I fear even if i used something there would be worse scratching of the insides than anything I would do to the outside skins, which BTW is covered with paint eventually; unless I am missing something with the method, than please let me know as I am interested in your method. Pascal ----- Original Message ----- From: "MauleDriver" <MauleDriver(at)nc.rr.com> Sent: Saturday, January 05, 2008 9:14 AM Subject: Re: RV10-List: DRDT-2 dimpler > > This sounds neat. But I can't quite figure out how it helps yet. > The technique I use is with the male die always on the top, I put the hold > in the male die, then press down the handle which moves the sheet and the > dies down onto the female die. > > Putting the male die on the bottom produces scratches. Allowing the sheet > to lie on the female die and trying to hit it with the male die will > sooner or later result in a new hole. > > I'm doing the baggage door right now on the DRDT-2 and I just can't figure > out how to take advantage of a laser guide line. > ...but I think I'll get them anyway and play. > > Bill Watson > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 05, 2008
Most people put the male die on the bottom and use the pin as a center and hold. Yes it may scratch a little but unless you are polishing the aluminum rather than painting, it makes no difference. You'll find that you can get into quite the rhythm with the DRDT and knock out dimple jobs in a hurry using the male on the bottom. Just don't get into the "zone" too much and miss a hole. Ask several of us how we know. :) My 0.02 Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: Saturday, January 05, 2008 11:15 AM Subject: Re: RV10-List: DRDT-2 dimpler This sounds neat. But I can't quite figure out how it helps yet. The technique I use is with the male die always on the top, I put the hold in the male die, then press down the handle which moves the sheet and the dies down onto the female die. Putting the male die on the bottom produces scratches. Allowing the sheet to lie on the female die and trying to hit it with the male die will sooner or later result in a new hole. I'm doing the baggage door right now on the DRDT-2 and I just can't figure out how to take advantage of a laser guide line. ...but I think I'll get them anyway and play. Bill Watson ________________________________________________________________________________
Date: Jan 05, 2008
Well, I'm a QB builder so I missed some of the more challenging dimpling jobs. I should say that I always try to use the male die on the top but I'm sure there are exceptions that I've forgotten about (tail skins?). I'm headed out to Harbor Freight now since I just heard they have their 2 ton crane on sale. Bill Pascal wrote: > > Unfortunately, with the leading edges having the male on top would > involve putting the c-frame inside the skins and I fear even if i used > something there would be worse scratching of the insides than anything > I would do to the outside skins, which BTW is covered with paint > eventually; unless I am missing something with the method, than please > let me know as I am interested in your method. > Pascal > ----- Original Message ----- From: "MauleDriver" <MauleDriver(at)nc.rr.com> > To: > Sent: Saturday, January 05, 2008 9:14 AM > Subject: Re: RV10-List: DRDT-2 dimpler > > >> >> This sounds neat. But I can't quite figure out how it helps yet. >> The technique I use is with the male die always on the top, I put the >> hold in the male die, then press down the handle which moves the >> sheet and the dies down onto the female die. >> >> Putting the male die on the bottom produces scratches. Allowing the >> sheet to lie on the female die and trying to hit it with the male die >> will sooner or later result in a new hole. >> >> I'm doing the baggage door right now on the DRDT-2 and I just can't >> figure out how to take advantage of a laser guide line. >> ...but I think I'll get them anyway and play. >> >> Bill Watson >> >> >> >> > > ________________________________________________________________________________
Date: Jan 05, 2008
Just watch the angles that you have them aimed at and the likelihood of direct eye contact is pretty slim. As someone else said, protective glasses would also work and double as safety glasses. You do wear safety glasses don't you? :D Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, January 05, 2008 9:07 AM Subject: Re: RV10-List: DRDT-2 dimpler So how are you setting it up so it doesn't "reflect" off the aluminum and cause some issues with the eyes? Granted it is reflected but I still have my concerns.. Even HB warns about it on item# 93242-2VGA * LASER PRODUCTS DANGER: LASER LIGHT. AVOID DIRECT EYE EXPOSURE. Max. Output <5 mW. This product complies with 21 CFR 1040.10 and 1040.11 ----- Original Message ----- From: "Bob Leffler" <rv(at)thelefflers.com> Sent: Friday, January 04, 2008 7:56 PM Subject: RE: RV10-List: DRDT-2 dimpler > > You laser light solution appears to have just resolved my only complaint > with the DRDT-2. I guess I'll be heading to Harbor Freight when I get > back > from the BCS Bowl. > > Do you really need two lights to make it work effectively? > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher > Sent: Friday, January 04, 2008 10:23 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: DRDT-2 dimpler > > > I just finished this today, plans and head unit from > sales(at)experimentalaero.com -- took about 5 hrs. to fabricate, align, weld, > paint. The steel came from a local scrap yard and is 1/4 instead of 3/16, > so it's about 70 lbs. -- and since it is heftier, I made the throat a > little > deeper. > > I'm helping a friend build his RV-10 (wish we had had it for his!), and > just > got my tail section kit for my own. > > I added the laser X&Y axis guides ($5 ea. at Harbor Freight) to pinpoint > where the die is to help line up the hole. It's VERY sweet! Just thought > I'd pass on the laser thought. > > Later, - Lew > > -------- > non-pilot > crazy about building > waiting on RV-10 finishing kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=156072#156072 > > > Attachments: > > http://forums.matronics.com//files/drdt2_medium_127.jpg > http://forums.matronics.com//files/drdt_medium_233.jpg > > > __________ NOD32 2766 (20080104) Information __________ > > ________________________________________________________________________________
Subject: Re: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938
Date: Jan 05, 2008
Dave, I'm curious about how you attached the aircraft to your car. Did you use the towbar? Jeff Dalton Wings ----- Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> Sent: Sunday, December 30, 2007 12:43 PM Subject: RV10-List: Emailing: IMG_0927, IMG_0932, IMG_0935, IMG_0938 > Another milestone this morning. The trip to the airport was about 2 miles > at 0600 on city streets. All the other parts are ready at the hangaar. > Hopefully March. > > > Your message is ready to be sent with the following file or link > attachments: > > > IMG_0927 > IMG_0932 > IMG_0935 > IMG_0938 > > > ________________________________________________________________________________
Subject: Engine development and politics
Date: Jan 05, 2008
Michael wrote: "We are the product of a capitalist and litigious society, not a pretty thing but our own fault." I'll give you litigious, but you're not implying that a socialist/Marxist/Maoist society would have better aircraft engine choices are you? Governments have a historically-poor record at picking winners and losers in technological or business issues . . . TDT 40025 Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Subject: Parker Rolo-Flair tool
Date: Jan 05, 2008
Just bought a Parker Rolo-Flair tool and the directions are really poor. The flairing part is not the problem, I can't figure out how to rotate the multi-die wheels. I'm afraid I'll damage it if I start taking it apart. Any hints on how to change the wheel with the dies? John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156245#156245 ________________________________________________________________________________
Date: Jan 05, 2008
Patrick #40715, I meant to comment on your entry earlier about stripping screws on the side panels. I also had that problem until I decided to bite the bullet and buy a cordless impact driver. I'm sure that's what they were put in with -- mass production, quick build, etc. These drivers are wonderful! I borrowed a friend's Ryobi to try it. My other cordless tools are DeWalt, so I ended up getting that one so I could use my existing batteries and charger. I no longer dread opening and closing panels with the off round nut plates. This is NOT a hammer drill. When it reaches a certain torque, it goes into impact mode. Usually it only takes a tap or two in reverse to loosen, then it functions as a regular electric screw driver. Be careful tightening as it can twist the head off if you over torque it. Another time saver was a pneumatic pop riveter -- $20 well spent when it comes to popping the floor panels alone! Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156246#156246 ________________________________________________________________________________
Date: Jan 05, 2008
The wheels rotate with finger pressure (bale open). Try some WD-40 or such to loosen them up. Carl Froehlich RV-8A (375 hrs) RV-10 (wings) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, January 05, 2008 9:25 PM Subject: RV10-List: Parker Rolo-Flair tool Just bought a Parker Rolo-Flair tool and the directions are really poor. The flairing part is not the problem, I can't figure out how to rotate the multi-die wheels. I'm afraid I'll damage it if I start taking it apart. Any hints on how to change the wheel with the dies? John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156245#156245 ________________________________________________________________________________
Subject: Wingtip lens
Date: Jan 05, 2008
We're installing the wingtip marker/strobe and landing light Van's kit, and it calls for just one countersunk screw on top and bottom corners of the lens. In Plexiglas instructions I've read elsewhere, they always say not to countersink but to oversize drill the screw hole and use a washer to allow for expansion/contraction movement. I've seen other wingtip lens on the 6A that have several screws & washers along each edge of the lens. Has something changed? Different lens material? Would it be better to at least add more screws? While I'm on Plexiglas ... the owner of the 6A I was looking at said that some of his friends who do acrobatics, have had the fiberglass bond of the windshield forward edge crack where it bonds to the aluminum. They are adding an aluminum strip riveted to the skin that comes up over the Plexiglas 3/4" or so to add mechanical strength, then glassing over that ... comments? Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156251#156251 ________________________________________________________________________________
Date: Jan 05, 2008
sure do, I have a new pair of welder googles.. problem is I can't see what I'm doing.. ;-) seriously though after having a speck of wood dust, making the table, get in my eyes I have worn protective googles ever since. Thanks for the insight, that is actually what I was looking for.. Pascal ----- Original Message ----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Sent: Saturday, January 05, 2008 10:21 AM Subject: RE: RV10-List: DRDT-2 dimpler > > > Just watch the angles that you have them aimed at and the likelihood of > direct eye contact is pretty slim. As someone else said, protective > glasses would also work and double as safety glasses. You do wear safety > glasses don't you? :D > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal > Sent: Saturday, January 05, 2008 9:07 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: DRDT-2 dimpler > > > So how are you setting it up so it doesn't "reflect" off the aluminum and > cause some issues with the eyes? > Granted it is reflected but I still have my concerns.. > Even HB warns about it on item# 93242-2VGA > * LASER PRODUCTS > DANGER: LASER LIGHT. AVOID DIRECT EYE EXPOSURE. Max. Output <5 mW. > This product complies with 21 CFR 1040.10 and 1040.11 > > > ----- Original Message ----- > From: "Bob Leffler" <rv(at)thelefflers.com> > To: > Sent: Friday, January 04, 2008 7:56 PM > Subject: RE: RV10-List: DRDT-2 dimpler > > >> >> You laser light solution appears to have just resolved my only complaint >> with the DRDT-2. I guess I'll be heading to Harbor Freight when I get >> back >> from the BCS Bowl. >> >> Do you really need two lights to make it work effectively? >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher >> Sent: Friday, January 04, 2008 10:23 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: DRDT-2 dimpler >> >> >> I just finished this today, plans and head unit from >> sales(at)experimentalaero.com -- took about 5 hrs. to fabricate, align, >> weld, >> paint. The steel came from a local scrap yard and is 1/4 instead of >> 3/16, >> so it's about 70 lbs. -- and since it is heftier, I made the throat a >> little >> deeper. >> >> I'm helping a friend build his RV-10 (wish we had had it for his!), and >> just >> got my tail section kit for my own. >> >> I added the laser X&Y axis guides ($5 ea. at Harbor Freight) to pinpoint >> where the die is to help line up the hole. It's VERY sweet! Just >> thought >> I'd pass on the laser thought. >> >> Later, - Lew >> >> -------- >> non-pilot >> crazy about building >> waiting on RV-10 finishing kit >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=156072#156072 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/drdt2_medium_127.jpg >> http://forums.matronics.com//files/drdt_medium_233.jpg >> >> >> >> >> >> >> >> __________ NOD32 2766 (20080104) Information __________ >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 05, 2008
Make sure the two halves are not clamped together with the swing arm and wingnut, they should rotate easily - there's a spring loaded detent that locates each wheel in the correct spot. The swing arm when, in the un-clamped position, has a pointer attached to it that serves as the marker to judge how much tube should be protruding through the dies. Lube up the flaring face with a dash of your favorite light oil - Boelube or cutting oil. Don't over flare - there needs to be sufficient metal thickness for the flare fitting to squeeze without thinning to the point that the tube is weakened. Don't forget to slide the nut and collar on BEFORE you flare ;-) (Ai ya ya how many times have I had to re-do a flare because I forgot the collar.... X-) Hope this isn't TMI - just trying to save you a few curses and wasted lengths of tubing :-) g -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, January 05, 2008 6:25 PM Subject: RV10-List: Parker Rolo-Flair tool --> Just bought a Parker Rolo-Flair tool and the directions are really poor. The flairing part is not the problem, I can't figure out how to rotate the multi-die wheels. I'm afraid I'll damage it if I start taking it apart. Any hints on how to change the wheel with the dies? John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156245#156245 ________________________________________________________________________________
Date: Jan 05, 2008
Subject: Re: Wingtip lens
Lew, The wingtip lens plastic, is labeled as plexi, but it's properties are different from the plexi used for the windows. The wing tip lens/covers are much softer. If you use a microstop countersink you will find that it quickly grabs and digs into the plastic. (ask me how I know) making it difficult to obtain a smooth countersunk hole (at least for me) I bought some stainless steel countersunk washers to use to 'doctor-up' and hide the 'chattered' countersunk holes. I've purchased a replacement lens and am going to remake them, and take more care in countersinking the holes. I have no magic plan other than to go very slow and use very light pressure. I'll also probably use progressive sizes to avoid taking off too much at a time. I used 3 screws per lens, one in the corner and one midway on top and bottom. The differences in the fiberglass tips and the lenses curvature requires additional screws in my case. http://deemsrv10.com/album/Sec%2024%20Wing%20Tips/slides/DSC02085.html http://deemsrv10.com/album/LED%20Nav%20&%20Strobes/slides/DSC02219.html Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Lew Gallagher wrote: > > We're installing the wingtip marker/strobe and landing light Van's kit, and it calls for just one countersunk screw on top and bottom corners of the lens. In Plexiglas instructions I've read elsewhere, they always say not to countersink but to oversize drill the screw hole and use a washer to allow for expansion/contraction movement. > > I've seen other wingtip lens on the 6A that have several screws & washers along each edge of the lens. Has something changed? Different lens material? Would it be better to at least add more screws? > > While I'm on Plexiglas ... the owner of the 6A I was looking at said that some of his friends who do acrobatics, have had the fiberglass bond of the windshield forward edge crack where it bonds to the aluminum. They are adding an aluminum strip riveted to the skin that comes up over the Plexiglas 3/4" or so to add mechanical strength, then glassing over that ... comments? > > Later, - Lew > > -------- > non-pilot > crazy about building > waiting on RV-10 finishing kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=156251#156251 > > > ________________________________________________________________________________
Subject: Re: Parker Rolo-Flair tool
Date: Jan 05, 2008
Thanks for the tips. The wheels on mine definitely won't budge. I've tried using as much force as I can with only my hands and they won't move. If there is a spring there, I can't feel it. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156263#156263 ________________________________________________________________________________
Subject: Emailing: IMG_0956, IMG_0952
Date: Jan 05, 2008
Its always a question whether the wings will match the fuselage when both are QBs from different batches. we used grade 8 3/8s and 9/16s sizes. we also had two long 3/8s of normal variety. We found the normal hardware bolts to be about .369 and .559 respectively. The grade 8s were .373 and .559. The NAS bolts were .373 and .561. Buy the ACE bolts and use a band saw to cut off the threads; then grind and polish the ends with the grinder and scotchbrite wheels. We lubed with LPS2. The actual time to install each wing was about 5 minutes but the time to trim and install the fairings totaled about 4.5 hours. That was after my pre prep of a couple of hours pulling the hardware and tools necessary from the kit trays. Thanks Deems and Paul and Tom for the extra muscle. David and Claude ________________________________________________________________________________
Date: Jan 06, 2008
I have an RV-6 and I frequently turn it greasy side up. Never had the problem of cracks as you described, nor heard of it. There are a lot of factors here: slider or tilt-up, epoxy or vinyl resin, number of layers on the layup, 3.5 G loop or 4.5 G, etc. I don't think the aluminum is necessary, and it would be tough to make this compound curve. You don't plan on doing this (aerobatics) with your 10, do you? If so, install a G-meter, don't exceed some small number (say 2.5), and stick with the plans. -------- Dave RV-6 flying RV-10 QB building Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156296#156296 ________________________________________________________________________________
Date: Jan 06, 2008
I guess there really is more than one way to skin a '10. The folks (Jacob) down in Griffin GA suggested the male die on top approach - mainly so you don't miss a hole (useful) and don't scratch (not important). It works but don't ask. I've certainly built a rhythm around that approach too. In any case , the DRDT certainly beats its predecessor (can you 'bang' hear me 'bang' now?) Bill "with a couple of nervous cats" Watson RV Builder (Michael Sausen) wrote: > > Most people put the male die on the bottom and use the pin as a center and hold. Yes it may scratch a little but unless you are polishing the aluminum rather than painting, it makes no difference. You'll find that you can get into quite the rhythm with the DRDT and knock out dimple jobs in a hurry using the male on the bottom. Just don't get into the "zone" too much and miss a hole. Ask several of us how we know. :) > > My 0.02 > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver > Sent: Saturday, January 05, 2008 11:15 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: DRDT-2 dimpler > > > This sounds neat. But I can't quite figure out how it helps yet. > > The technique I use is with the male die always on the top, I put the > hold in the male die, then press down the handle which moves the sheet > and the dies down onto the female die. > > Putting the male die on the bottom produces scratches. Allowing the > sheet to lie on the female die and trying to hit it with the male die > will sooner or later result in a new hole. > > I'm doing the baggage door right now on the DRDT-2 and I just can't > figure out how to take advantage of a laser guide line. > > ...but I think I'll get them anyway and play. > > Bill Watson > > > ________________________________________________________________________________
Date: Jan 06, 2008
Subject: Re: qb kit-front floor panels removal and gear mount
What brand and model do you use? Didn't even know they existed (Googling now). I use a driver with a T-handle to do this - much slower but it works. Very useful in removing QB tanks. Pic attached. Thanks! Bill Watson 40605 Lew Gallagher wrote: > > Patrick #40715, > > I meant to comment on your entry earlier about stripping screws on the side panels. I also had that problem until I decided to bite the bullet and buy a cordless impact driver. I'm sure that's what they were put in with -- mass production, quick build, etc. These drivers are wonderful! I borrowed a friend's Ryobi to try it. My other cordless tools are DeWalt, so I ended up getting that one so I could use my existing batteries and charger. I no longer dread opening and closing panels with the off round nut plates. This is NOT a hammer drill. When it reaches a certain torque, it goes into impact mode. Usually it only takes a tap or two in reverse to loosen, then it functions as a regular electric screw driver. Be careful tightening as it can twist the head off if you over torque it. > > Another time saver was a pneumatic pop riveter -- $20 well spent when it comes to popping the floor panels alone! > > Later, - Lew > > -------- > non-pilot > crazy about building > waiting on RV-10 finishing kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=156246#156246 > > > ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Date: Jan 06, 2008
I think the Rolo-Flair tools are prone to assembly errors. When I received mine, the wheels were installed backwards, which produced a hard outside edge on the flair. Close examination showed that the bevel was on the wrong side, so I called Avery to see about a replacement. Since it was a Friday and I had some work to do over the weekend, I decided that it was possible to disassemble the tool myself (after all, how complicated can it be...I'm building an airplane!) and reassemble it with the wheels in the correct orientation. After some fiddling with the various parts to get them all back in place, I was able to get the Rolo-Flair put back together correctly, and it has served me well ever since. I did talk to Bob Avery about the issue because I can imagine that I wouldn't be the only one to receive an incorrectly assembled tool. If you decide to disassemble yours, be careful not to drop the ball bearings and springs that will probably pop out when you take the wheels apart. They're hard to find. http://www.my9a.com/wings8.asp#062304 Regards, Mike Schipper #40576 - Fuse - www.rvten.com On Jan 5, 2008, at 10:21 PM, johngoodman wrote: > > > > Thanks for the tips. The wheels on mine definitely won't budge. I've > tried using as much force as I can with only my hands and they won't > move. If there is a spring there, I can't feel it. > John > > -------- > #40572 QB Wings, QB Fuse arrived > N711JG reserved ________________________________________________________________________________
Date: Jan 06, 2008
Bill, Nice tool, but you won't believe how these power drivers will change your life! Here's a quick shot of the Ryobi on Ebay: http://cgi.ebay.com/Ryobi-18-Volt-Impact-Driver-New-P231_W0QQitemZ280189857137QQihZ018QQcategoryZ71297QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Here's the DeWalt like mine: http://cgi.ebay.com/DeWalt-DW056-18V-Cordless-Impact-Driver-NEW_W0QQitemZ280187210049QQihZ018QQcategoryZ42272QQssPageNameZWDVWQQrdZ1QQcmdZViewItem They're both similar (both probably made at same place in China) -- and the techno freaks can tell you about torq specs and blows per minute -- just get one or borrow one, you'll like it! Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156339#156339 ________________________________________________________________________________
Date: Jan 06, 2008
I had the same problem as Michael and had to disassemble and reassemble the rolo flair tool correctly. Mark RV-10/N410MR
> From: mike(at)learningplanet.com> To: rv10-list(at)matronics.com> Subject: Re: RV10-List: Re: Parker Rolo-Flair tool> Date: Sun, 6 Jan 2008 10:03:33 -0600 com>> > I think the Rolo-Flair tools are prone to assembly errors. When I > received mine, the wheels were installed backwards, which produced a > har d outside edge on the flair. Close examination showed that the > bevel was on the wrong side, so I called Avery to see about a > replacement. Since it was a Friday and I had some work to do over the > weekend, I decided that it was possible to disassemble the tool myself > (after all, how complicate d can it be...I'm building an airplane!) and > reassemble it with the wheel s in the correct orientation.> > After some fiddling with the various parts to get them all back in > place, I was able to get the Rolo-Flair put back together correctly, > and it has served me well ever since. I did talk to Bob Avery about > the issue because I can imagine that I wouldn't be the on ly one to > receive an incorrectly assembled tool.> > If you decide to disa ssemble yours, be careful not to drop the ball > bearings and springs that will probably pop out when you take the > wheels apart. They're hard to fin d.> > http://www.my9a.com/wings8.asp#062304> > Regards,> Mike Schipper> #40 576 - Fuse - www.rvten.com> > > On Jan 5, 2008, at 10:21 PM, johngoodman wr link.net > > >> >> > Thanks for the tips. The wheels on mine definitely won 't budge. I've > > tried using as much force as I can with only my hands an d they won't > > move. If there is a spring there, I can't feel it.> > John > >> > --------> > #40572 QB Wings, QB Fuse arrived> > N711JG reserved> > > ========================> > > _________________________________________________________________ Share life as it happens with the new Windows Live. http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_0120 08 ________________________________________________________________________________
Subject: Re: Kitplane's article, Ly-Con's case closed.
Date: Jan 06, 2008
Les, On Jan 6, 2008, at 10:16 AM, LES KEARNEY wrote: > Hi Kelly > > > Compare the production runs of auto engines to a/c engines. Auto > engine production runs can run into the hundreds of thousands in a > single year. Think of the QA/QC and engineering effort that goes > into these engines, the quality of the parts and the tolerances of > the manufacturing process. Hands down, I am of the opinion that > these engines will have a higher inherent reliability than > traditional engines. Keep in mind that my engine will be a factory > new engine (in fact I helped un-crate it on Thursday at the > Eggenfellenr shop). It is not a reman, it is not rebuilt, and it is > not modified Auto engines have been designed and tested to be operated in a different environment than aircraft engines. They are operated a majority of their life at a low percentage of power at low RPMs, not at a high percentage of power at high RPMs. > There are new risks I need to manage but these are reasonable. Will > this engine be more or less risky than a traditional engine I > cant say. But I will mitigate the risk reviewing each system, > identifying risks and doing what I can to mitigate each risk. How are you going to evaluate and mitigate the risks associated with the PRU and prop combo? > Pete Hudes ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jan 06, 2008
Just curious? Why would you want an impact driver for screws? Most DC power drills have a variable setting for screws and are designed to slip at each setting. I set mine on the lightest one, screw until it slips and go on. Never had a screw break or bend the platenut and never had one that would not back out easily. What do you gain with the impact driver ? BTW, my 7 qb came with a polishing bonnet under the baggage floors ;-) No charge ! Just curious ? Bill S 7a 80/80 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Sunday, January 06, 2008 10:42 AM Subject: RV10-List: Re: qb kit-front floor panels removal and gear mount Bill, Nice tool, but you won't believe how these power drivers will change your life! Here's a quick shot of the Ryobi on Ebay: http://cgi.ebay.com/Ryobi-18-Volt-Impact-Driver-New-P231_W0QQitemZ2801898571 37QQihZ018QQcategoryZ71297QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Here's the DeWalt like mine: http://cgi.ebay.com/DeWalt-DW056-18V-Cordless-Impact-Driver-NEW_W0QQitemZ280 187210049QQihZ018QQcategoryZ42272QQssPageNameZWDVWQQrdZ1QQcmdZViewItem They're both similar (both probably made at same place in China) -- and the techno freaks can tell you about torq specs and blows per minute -- just get one or borrow one, you'll like it! Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156339#156339 ________________________________________________________________________________
Date: Jan 06, 2008
Peter As I mntioned in my post to Kelly=2C I am not an engine expert / guru / authority by any stretch=2E Below is an exract from Ross Farnham=27s web site=3A http=3A//www=2Esdsefi=2Ecom/air7=2Ehtml Many lay people often point out that automotive engines are not designed for continuous high output applications and will blow up when installed in an aircraft=2E This view is a result of complete ignorance in my opi nion and is not supported by any credible facts=2E Modern automotive eng ines make use of the latest advances in computer design and modeling to optimize the design of everything from port flow=2C port resonance tunin g=2C combustion chamber characteristics=2C vibrational node analysis and mechanical stresses=2E Machining and metallurgy technology is far super ior to the old days when the air cooled=2C flat engines were developed=2E Technology has indeed progressed on automotive engines in the last 40 y ears=2E Automotive engines are routinely tested during development at full power and maximum rpm for periods of up to 1200 hours on a dynomometer=2E The se engines must be able to withstand whatever stresses a customer might inflict on them such as flat out cruising on the autobahn or endurance r acing=2C without failure=2E Manufacturer=27s limits are conservative to guarantee longevity and reliability=2E The engineering and capital inves tment that goes into a new engine release dwarfs any similar development by any piston aircraft engine manufacturer=2E The testing and validatio n methods FAR exceed those required on piston aircraft engines=2E In Eur ope=2C cars are routinely cruised at speeds (RPMs and load) 50-100=25 hi gher than what we see in North America with no ill effects in life span=2E This is real world=2C long term hard use=2E Just one example of the demonstrated real world reliability on the popul ar Subaru EJ22 engine was the 1989 record set by 3 Legacy=27s at an Ariz ona test track=2E These cars were run flat out for 17 days straight with out failure at an average speed of over 138 mph=2E Similar records have been set by Saab and Chevrolet=2E How many people reading this article t hink that most aircraft engines would survive at 100=25 takeoff power fo r 400 hours=3F Subaru now offers the production 2=2E5L turbo STI rated a t 300 hp=2C With the popularity of showroom stock endurance racing in th e last decade=2C we get to see just how good the design and engineering is on modern cars=2E Thousands of Hondas=2C Toyotas=2C Oldsmobiles=2C Ch evrolets=2C Mitsubishis=2C VWs etc=2E are mercilessly flogged to the rev limiter at full throttle for hundreds of hours between rebuilds=2E A ve ry small fraction of these ever suffer a serious failure=2E Aircraft use does not put this kind of cyclic stress on an engine=2C being a constan t load=2C relatively low rpm situation=2E Most modern car engines outlas t the chassis without ever being removed=2E This performance can be equa ted into lifespans of between 4000 and 8000 hours=2E Even operating at 7 5=25 of maximum power and rpm limits=2C it is reasonable to expect a TBO of at least 1000 hours in aircraft use=2E Cheers Les ----- Original Message ----- From=3A Peter Hudes =3Cphudes=40ix=2Enetcom=2Ecom=3E Date=3A Sunday=2C January 6=2C 2008 12=3A21 pm Subject=3A Re=3A RV10-List=3A Kitplane=27s article=2C Ly-Con=27s case cl osed=2E To=3A rv10-list=40matronics=2Ecom =3E --=3E RV10-List message posted by=3A Peter Hudes =3Cphudes=40ix=2Ene tcom=2Ecom=3E =3E =3E Les=2C =3E =3E On Jan 6=2C 2008=2C at 10=3A16 AM=2C LES KEARNEY wrote=3A =3E =3E =3E Hi Kelly =3E =3E =3E =3E =3E =3E =3E =3E Compare the production runs of auto engines to a/c engines=2E =3E Auto =3E =3E engine production runs can run into the hundreds of thousands =3E in a =3E =3E single year=2E Think of the QA/QC and engineering effort that =3E goes =3E =3E into these engines=2C the quality of the parts and the =3E tolerances of =3E =3E the manufacturing process=2E Hands down=2C I am of the opinion =3E that =3E =3E these engines will have a higher inherent reliability =3E than =3E =3E traditional engines=2E Keep in mind that my engine will be a =3E factory =3E =3E new engine (in fact I helped un-crate it on Thursday at =3E the =3E =3E Eggenfellenr shop)=2E It is not a reman=2C it is not rebuilt=2C and =3E it is =3E =3E not modified =3E =3E =3E Auto engines have been designed and tested to be operated in =3E a =3E different environment than aircraft engines=2E They are operated =3E a =3E majority of their life at a low percentage of power at low RPMs=2C =3E not =3E at a high percentage of power at high RPMs=2E =3E =3E =3E There are new risks I need to manage but these are reasonable=2E =3E Will =3E =3E this engine be more or less risky than a traditional engine ' =3E I =3E =3E can=92t say=2E But I will mitigate the risk reviewing each =3E system=2C =3E =3E identifying risks and doing what I can to mitigate each risk=2E =3E =3E How are you going to evaluate and mitigate the risks associated =3E with =3E the PRU and prop combo=3F =3E =3E =3E =3E Pete Hudes =3E =3E =5F-====================== ======================== ============= =3E =5F-= - The =3E RV10-List Email Forum - =3E =5F-= Use the Matronics List Features Navigator to browse =3E =5F-= the many List utilities such as List Un/Subscription=2C =3E =5F-= Archive Search =26 Download=2C 7-Day Browse=2C Chat=2C FAQ=2C =3E =5F-= Photoshare=2C and much much more=3A =3E =5F-= --=3E http=3A//www=2Ematronics=2Ecom/Navigator=3FRV10-List =3E =5F-====================== ======================== ============= =3E =5F- =3E = - MATRONICS WEB FORUMS - =3E =5F-= Same great content also available via the Web Forums! =3E =5F-= --=3E http=3A//forums=2Ematronics=2Ecom =3E =5F-====================== ======================== ============= =3E =5F- =3E = - List Contribution Web Site - =3E =5F-= Thank you for your generous support! =3E =5F- =3E = -Matt Dralle=2C List Admin=2E =3E =5F-= --=3E http=3A//www=2Ematronics=2Ecom/contribution =3E =5F-====================== ======================== ============= =3E =3E =3E =3E ________________________________________________________________________________
Date: Jan 06, 2008
Peter To answer your questions regarding the prop and PSRU, I will be monitoring the PSRU oil temp and doing oil analysis on a regular basis. There will also be periodic inspections for oil leaks etc. Anything out of the ordinary will be investigated and resolved. This is pretty much what I am doing with my Lyc O-360. Cheers Les ----- Original Message ----- From: Peter Hudes <phudes(at)ix.netcom.com> Date: Sunday, January 6, 2008 12:21 pm Subject: Re: RV10-List: Kitplane's article, Ly-Con's case closed. > > Les, > > How are you going to evaluate and mitigate the risks associated > with > the PRU and prop combo? > > > > Pete Hudes > > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > _- > = - List Contribution Web Site - > _- > = -Matt Dralle, List Admin. > > > > ________________________________________________________________________________
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Jan 06, 2008
Jesse, would it be possible to see some pictures of the mount? Best Regards from Switzerland Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156405#156405 ________________________________________________________________________________
Date: Jan 06, 2008
Hi Les, I'm afraid you are missing the point. Yes, flat air cooled engines were designed before WWII. No, the IO540 was not. The current, dynamically counter balanced engine dates from the late seventies/early 80s. Lets see...oh yeah, that is about when Subaru came out with their H-4 design...which was really a water cooled modification of the VW design, that dates back to, oh yeah, before WWII. So, design vintage is really pretty much the same. We all naturally defend whatever choice we make. You hear a LOT more about Lycoming problems because there are thousands of them out there. All the so called automotive technology, really has changed little since 1970 other than ignition and fuel delivery. I think you will find that cylinder wall machining, piston machining, cam machining etc have changed very little. Most of the improvement was incremental for durability, emission control and fuel economy. Aircraft engines have had similar improvements, you just don't hear much about them, because they don't change the certification. For Lycomings, very few have roller lifters. Very few have cold air induction. Even fewer have electronic ignition. If you think it is better, you can get Superior's investment cast cylinders. You can have an engine shop do custom improvements, like honing the valve guides instead of reaming. You can go with gapless rings to reduce blowby and oil contamination. Etc. Etc. There simply is very little technology difference beyond the electronic engine management unit. Which happens to be one of the biggest failure modes of autos today. You would be astounded how many ECUs get changed out in cars...whether or not they are the real problem. Or you can choose as you have a very proven auto engine, that has very little experience in aircraft, with a PSRU that has even less aviation experience. That is the beauty of experimentals...you have the right to choose. Then you can choose zinc chromate or epoxy primer and Continental gold, Lyc gray or blue, Ultimate black, Mattituck red/gold, or purple for your engine color. ;-) And as Tim said, you get to install radiator, engine management computer and monitor those extra systems. On Jan 6, 2008 11:16 AM, LES KEARNEY wrote: > > > Hi Kelly > > > My apologies if my characterization of the IO540 seemed "not intellectually > honest". Ouch! I was simply trying to press the point that the basic design > of the Lycoming is firmly rooted in the past. There have been improvements > over the years but the fundamental design has not changed. > > > At KOSH this year, one engine supplier spent 20 minutes explaining to me why > their IO540 was better than an out of the box Lycoming IO540. It was all > about improving lubrication and fixing problems that Lycoming could fix > didn't want to fix because of the certification process. My club AME > (Canadian A&P) speaks of his high replacement rate for IO540 jugs. > > > I just don't see the attractiveness of these engines. They are old, > problematic designs. > > ________________________________________________________________________________
Subject: Wonderful Oz-RV Family
Date: Jan 06, 2008
I just wanted to tell you folks that by purchasing the kit you get way more than sheet metal and, composite parts, you actually become part of a wonderful community. I spend my last two month traveling through Australia with my wife. And I took the chance to drop some emails to RV-10 builders there and I hardly remember being so much welcome ever before. I want to thank Pat, Chris and John for your hospitality!!! Take care and keep on building. Michael (Switzerland) www.wellenzohn.net -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156408#156408 ________________________________________________________________________________
Subject: F-1099G-l and -R
Date: Jan 06, 2008
Seems like there ought to be at least one screw in that piece holding it to the fairing skin. My plans don't show one; they are from 4th quarter 2004 ________________________________________________________________________________
Date: Jan 06, 2008
Bill, I had trouble not stripping out the Phillip's heads on the side panels that were on the QB fuse -- they were really tight. I even tried the hammer impact driver on some. The advantage of these cordless impact drivers (don't think impact wrench, like lug nut wrenches) is that they end with the impact when they tighten, start with impact when they loosen. You also have no torque on the wrist like you do with the drill/screw drivers. And there's almost no chance of messing up the head of the screw. Keep what you've got if you're happy with it! Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156453#156453 ________________________________________________________________________________
Date: Jan 06, 2008
After all the suggestions, I started to gently disassemble the tool and suddenly it started rotating correctly. Go figure. Anyway, thanks for all the help and comments. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156462#156462 ________________________________________________________________________________
Subject: Re: Wonderful Oz-RV Family
Date: Jan 07, 2008
I really agree that there is so much international help available for RV10 builders - thankfully. Without the help of many, inc Tim, Deems, Gary, Will, Rhonda, Stein etc, we couldn't have done it. Great service from the whole community, even at silly times of day. Good job too, as there is still only 1 RV10 in NZ. But we do have the best scenery on the planet:-) Come on you Aussie builders - how about a short trip across the ditch? We hope to be with you next month - any suggestions as to places to visit? Neil & Sarah ZK-RVT 56 hours. ________________________________________________________________________________
Date: Jan 07, 2008
I have been reading the engine debate with some interest. There are pros and cons to all types. Just to stir the pot a little more!!!! have a look at this South African development. http://www.adeptairmotive.com/site/default.asp It hasn't even flown yet, but it is running. It has been designed from the ground up as a GA engine. Turbocharged, 320hp at 5500 rpm, 70% 210hp at 2300 rpm, Integrated PSRU, Liquid cooled, Compatible with Avgas OR Mogas, FADEC, 130kg (287lb). Targeted TBO is in excess of 2000 hours. The engine has a fairly oversquare bore/stroke ratio (98mm x 70mm) in order to keep piston speed low, as well as fairly short con rods. Now before anybody has a go at the revs, the average piston speed is actually lower than conventional GA engines because of the oversquare setup. It is a 120 degree V6 of 3.2 litre capacity. Real smooth. Just for those with a little experimentation in their blood. Attached is a picture. Simon Wilson ________________________________________________________________________________
Date: Jan 07, 2008
Neil, From a street rod builder's point of view, flames are so cool! But my buddy who owns the RV-10 we're building says flames are definitely something he does NOT want on his plane! Please send more pictures. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156515#156515 ________________________________________________________________________________
Date: Jan 07, 2008
In a message dated 1/7/2008 3:24:40 AM Central Standard Time, simon(at)sertech.com.au writes: Just to stir the pot a little more!!!! have a look at this South African development. Their strategy is to price this experimental engine...unproven ...at Lycoming and Continental's current prices, because they say it will weight less than current engines. Apparently they do not intend to have it certified. So let me understand...they want what the current certified guys want for engines, they want the experimental builders pay extra for a weight difference and the experimenal operators, take all the risk; plus they are based in a country where you can't take any legal action if this engine poops out and kills you...sounds like a deal to me... **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 07, 2008
In a message dated 1/6/2008 1:48:30 PM Central Standard Time, Kearney(at)shaw.ca writes: Even operating at 75% of maximum power and rpm limits, it is reasonable to expect a TBO of at least 1000 hours in aircraft use. Cheers Les Les, What do you think this belief in 1000 hours is based on? **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 07, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Legs/wheelpants
Lew; Here's the link to the pics for the wheel pants. : http://picasaweb.google.com/drfredparis/Engine As you can see from the pics I still have some sanding to do. Also, I did not want to sound harsh in my email about the top fairings from farings-etc. I'm sure they make a great product. I just decided not to use them. I'll take some more pics when I put them back on. However, it was 75 deg here in Paris yesterday and I decided to roll the plane out side and put the engine on last night. Lets see: do I want to sand or hang the engine??? As for the DRDT dimpler. Looks great, just make sure you get the good spring back dimple dies. It makes all the difference. Couple hints that will help. Both Tim Olsen and Deems Davis have done a great job in documenting pics and mods for most everything. Check there sites out for pics and tips. Regarding the engine cowling: I decided to use the skybolt along the top and sides and use hinges for the lower cowl. There is a link to them on vansairforce.net. They have the kit all set up for what you decide to do. Dr Fred 40515 ________________________________________________________________________________
Date: Jan 07, 2008
Aaahh, Engines! If you want to get real exotic, try these: The StarRotor Corp. Brayton cycle engine http://www.starrotor.com/Engine.htm The Beare Six Cycle engine http://www.sixstroke.com/index.html The infamous Axial Vector Engine Corp. http://www.axialvectorengine.com/index.html The Air Force HTRE-3 nuclear aircraft engine http://members.tripod.com/airfields_freeman/ID/Airfields_ID_N.htm My favorite is electric drag racing. http://www.nedra.com/ These guys are actually breaking track records. They use electric fork lift motors with lots of batteries.......I think I'm going to need a larger battery tray than the one Van sent me....... [Wink] -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156541#156541 ________________________________________________________________________________
Date: Jan 07, 2008
Neil, YES More Pictures Please... Robin ________________________________________________________________________________
Date: Jan 08, 2008
As requested. - more pics of beautiful NZ with a rather bright RV10. At the World Gliding Grand Prix Championships at Omarama, in South Island . Back on our home strip. Just east of Mount Cook Over Mt Ruapehu - our local active volcano A huge whirlpool, north of Kaikoura If you would like larger pics, send PM. On 8 Jan 2008, at 4:44, Robin Marks wrote: > > Neil, YES More Pictures Please... > > Robin > > ________________________________________________________________________________
Subject: Re: Legs/wheelpants
Date: Jan 07, 2008
Hey Fred, Thanks for the pics! I've been devouring Tim's site, but only heard reference to Deems. I immediately googled him and found his site -- and spent the last half hour surfing! Paris, France? This is great ... I just emailed a guy in New Zealand about his paint job. My Step-Mom is from Chauny (between Paris and St. Quentin) and they used to go every other summer until my Dad died in 1999. I toured through in 1969 after being discharged from the Army (drafted in '67 - spent '68-'69 in Vietnam) so I wasn't too happy with the U.S. and Europe was a wonderful place to decompress. Later, - Lew ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Monday, January 07, 2008 9:52 AM Subject: RV10-List: Legs/wheelpants > > > Lew; > > Here's the link to the pics for the wheel pants. : > > http://picasaweb.google.com/drfredparis/Engine > > As you can see from the pics I still have some sanding to do. Also, I did > not want to sound harsh in my email about the top fairings from > farings-etc. I'm sure they make a great product. I just decided not to > use them. I'll take some more pics when I put them back on. However, it > was 75 deg here in Paris yesterday and I decided to roll the plane out > side and put the engine on last night. Lets see: do I want to sand or > hang the engine??? > As for the DRDT dimpler. Looks great, just make sure you get the good > spring back dimple dies. It makes all the difference. > Couple hints that will help. Both Tim Olsen and Deems Davis have done a > great job in documenting pics and mods for most everything. Check there > sites out for pics and tips. > Regarding the engine cowling: I decided to use the skybolt along the top > and sides and use hinges for the lower cowl. There is a link to them on > vansairforce.net. They have the kit all set up for what you decide to do. > Dr Fred > 40515 > > > ________________________________________________________________________________
Date: Jan 07, 2008
Too late - I'm going shopping. I was just sharing what I've been doing so far. This is pure learning experience (not to mention new tool acquisition) Lew Gallagher wrote: > > Bill, > > I had trouble not stripping out the Phillip's heads on the side panels that were on the QB fuse -- they were really tight. I even tried the hammer impact driver on some. The advantage of these cordless impact drivers (don't think impact wrench, like lug nut wrenches) is that they end with the impact when they tighten, start with impact when they loosen. You also have no torque on the wrist like you do with the drill/screw drivers. And there's almost no chance of messing up the head of the screw. > > Keep what you've got if you're happy with it! > > Later, - Lew > > -------- > non-pilot > crazy about building > waiting on RV-10 finishing kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=156453#156453 > > > ________________________________________________________________________________
Date: Jan 07, 2008
Hate to let you down. Paris, Texas. We do have a small Eiffel Tower. Dr Fred. Lew Gallagher wrote: > > Hey Fred, > > Thanks for the pics! I've been devouring Tim's site, but only heard > reference to Deems. I immediately googled him and found his site -- > and spent the last half hour surfing! > > Paris, France? This is great ... I just emailed a guy in New Zealand > about his paint job. My Step-Mom is from Chauny (between Paris and > St. Quentin) and they used to go every other summer until my Dad died > in 1999. I toured through in 1969 after being discharged from the > Army (drafted in '67 - spent '68-'69 in Vietnam) so I wasn't too happy > with the U.S. and Europe was a wonderful place to decompress. > > Later, - Lew > > > ----- Original Message ----- From: "Fred Williams, M.D." > > To: "RV 10" > Sent: Monday, January 07, 2008 9:52 AM > Subject: RV10-List: Legs/wheelpants > > >> >> >> Lew; >> >> Here's the link to the pics for the wheel pants. : >> >> http://picasaweb.google.com/drfredparis/Engine >> >> As you can see from the pics I still have some sanding to do. Also, I >> did not want to sound harsh in my email about the top fairings from >> farings-etc. I'm sure they make a great product. I just decided not >> to use them. I'll take some more pics when I put them back on. >> However, it was 75 deg here in Paris yesterday and I decided to roll >> the plane out side and put the engine on last night. Lets see: do I >> want to sand or hang the engine??? >> As for the DRDT dimpler. Looks great, just make sure you get the >> good spring back dimple dies. It makes all the difference. >> Couple hints that will help. Both Tim Olsen and Deems Davis have >> done a great job in documenting pics and mods for most everything. >> Check there sites out for pics and tips. >> Regarding the engine cowling: I decided to use the skybolt along the >> top and sides and use hinges for the lower cowl. There is a link to >> them on vansairforce.net. They have the kit all set up for what you >> decide to do. >> Dr Fred >> 40515 >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 07, 2008
Heck you are missing the DynaCam, which IS a certified engine, that is always going into production "next" year. Or you could totally ignore Vans and mount up an Orenda engine that also is certified at somewhere around 5-600hp. On Jan 7, 2008 8:52 AM, johngoodman wrote: > > Aaahh, Engines! If you want to get real exotic, try these: > > The StarRotor Corp. Brayton cycle engine > http://www.starrotor.com/Engine.htm > > The Beare Six Cycle engine > http://www.sixstroke.com/index.html > > The infamous Axial Vector Engine Corp. > http://www.axialvectorengine.com/index.html > > The Air Force HTRE-3 nuclear aircraft engine > http://members.tripod.com/airfields_freeman/ID/Airfields_ID_N.htm > > My favorite is electric drag racing. > http://www.nedra.com/ > These guys are actually breaking track records. They use electric fork lift motors with lots of batteries.......I think I'm going to need a larger battery tray than the one Van sent me....... [Wink] > > -------- > #40572 QB Wings, QB Fuse arrived > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=156541#156541 > > ________________________________________________________________________________
Subject: Re: DRDT-2 dimpler
Date: Jan 08, 2008
Who'd a thunk there'd a been so much interest in a couple a laser gismo's! Thanks for the comments. Last evening I was experimenting in less than daylight to see what the deal with reflection is. It appears that there's only one spot a few inches off center on the horizontal axis that would reflect in your eye -- if you made an effort to look at it. That's because of the angle of the mounting. This weekend I'll try a simple hood of tape to narrow the cross hair and eliminate that angle. Now, off to that pesky career that gets in the way of my real job. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156740#156740 ________________________________________________________________________________
Date: Jan 08, 2008
Subject: Fiberglass class in Watsonville with RV10 focus
Well, I just signed up for the 2 day class. I just starting looking at putting the top on and queried Dave Saylor about the class and found out one is scheduled for the end of the month. Given all the belly aching about the fiberglass work, I was getting a bit of indigestion. What better cure than some training! Have any of you attended this? Any tips? Bill "doing misc fuse work and getting ready for fiberglass" Watson 40605 ________________________________________________________________________________
Subject: Re: Fiberglass class in Watsonville with RV10 focus
Date: Jan 08, 2008
I'm also going. Airline tickets purchased, suit case has been pulled out. Maybe a year from now, airline tickets will be a thing of the past. [Laughing] Really looking forward to meeting some more -10 builders in person. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156758#156758 ________________________________________________________________________________
Subject: Kitplane's article, Ly-Con's case closed.
Date: Jan 08, 2008
Oh, gawd help me, but I cannot stop myself. Here goes. I wrote awhile back that I'm going to stick to Ly-Con because I didn't know enough to know what questions to ask. Now, I know that was a somewhat stupid statement, especially because I could find out, given my research background, but the point was, and this verbiage below confirms it, I have no clue when enough testing is enough, or enough failures are too many. I am not an aeronautical or mechanical or anything engineer. The one thing I cannot abide are statements that say almost nothing, but sound like they have expertise. "A very small fraction of these ever suffer a serious failure." Ok then, what's the fraction and how does that compare to the current crop of Ly-Con's. What's a serious failure? What were the outcomes? Did the car quit running? Did the people slam into a concrete wall at 100 mph, because that's what an aviator would essentially do, and whomever else was onboard, and that's why the family scenario keeps coming up. Putting an "experimental" engine into a four place aircraft is fine. As I said before I'm all for moving the bar forward. I don't know what engineering good or bad has gone into the certified Ly-Cons. I do know that the expensive certification process has kept them from easily making these engines more "advanced." The final testing that goes into the auto conversions, however, is left to those who are flying them. It was the same way when the Ly-Cons were first being put out. If the auto conversion folks put their designs through thousands of hours of testing in conditions that simulate what a real plane goes through, then fine. Show the data. Show the process. If they are doing so and I'm naive in what I'm saying, fine, correct me. But so far, the only statements I've seen are the obfuscating statements (crap, really) that I typically put into a report when I don't know the answer. Why is one PSRU better than another? Why did Jan declare that everyone must change to the new one? Stronger? How? Is the prop/PSRU combination the issue? Was there a harmonic issuer? Was the metallurgy on the gears better? Were the gears cracking? When you check your PSRU oil, will it tell you that there's a hairline crack in a gear? How will the engine hold up if you get a coolant leak? Will it stop working or get you to a safe landing? How will you know you have a coolant leak while in flight? I am sure that all those who are becoming Subaru test pilots for free will have asked these and thousands of other questions and gotten very good answers. I haven't ever seen anyone come back with a list of these questions and the answers and posted them, but since I'm not following the postings on these lists, maybe they have. Hope so. Now, this is not to say that every and all Ly-Con's shouldn't be taken to task with the thousands of questions that an auto conversion should be, with each question answered by test results. We should all be wanting to know what's the deal. Why do Ly-Con's develop hairline cracks in their jugs after 500 hours? Etc. We have a very large number of very good engine build specialists out there with good knowledge and experience and the willingness to share information (and Ly-Con will share some test results). I want Les to succeed. I want Jan, even though I have reservations about the person, to succeed. I want the folks from South Africa to build the best darn engine that has come along in a long long time. Just don't rely on non-critical statements. If you deal with a person who won't back up their claims with facts and thorough testing, walk away, which is what I did with Jan. And don't subject anyone else to your test bed. And, one more thing, make sure that when it fails, and it will, they all will, that the manufacturer is the type that will come, take the engine back, go over it with a fine toothed gizmo, do root cause analysis until the cows come home, and help the NTSB determine if the fault was the engine and why, and not just walk away and say it wasn't their fault. You've taken it upon yourself to be their test bed, they might as well admit to that and be part of it contractually. I know they won't, but to me, that is the reality of it and that's why I'll go the route that seems to be working. Ly-Con's with annuals. Annuals because I know the environment and how they are run are going to cause problems, eventually, sometimes sooner than later, and that's why we do annuals, not because the technology is so old or bad that we shouldn't have to need them. We do them because when our engine quits, we cannot pull off to the side of the road, we get to do what race car drivers do, we get to plow into the barrier at speeds that do not usually guarantee happy outcomes in a vehicle built out of aluminum, sans safety cage. Les, I met you once in Oregon and have followed your comments on this list and I've always been impressed with your care and thoroughness and intelligence. Please help us all out as you go through this journey and document as much as possible, especially in terms of the questions that you have asked and the answers given. That baby is going to run smooth as silk when you first fire it up, I'm sure. But I'd be doing an annual's worth on it every 50 hours for the forseeable future, until you and the fleet of similar installations are sure you have a winner. Good luck! John Jessen 40328. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY Sent: Sunday, January 06, 2008 11:42 AM Subject: Re: RV10-List: Kitplane's article, Ly-Con's case closed. Peter As I mntioned in my post to Kelly, I am not an engine expert / guru / authority by any stretch. Below is an exract from Ross Farnham's website: http://www.sdsefi.com/air7.html Many lay people often point out that automotive engines are not designed for continuous high output applications and will blow up when installed in an aircraft. This view is a result of complete ignorance in my opinion and is not supported by any credible facts. Modern automotive engines make use of the latest advances in computer design and modeling to optimize the design of everything from port flow, port resonance tuning, combustion chamber characteristics, vibrational node analysis and mechanical stresses. Machining and metallurgy technology is far superior to the old days when the air cooled, flat engines were developed. Technology has indeed progressed on automotive engines in the last 40 years. Automotive engines are routinely tested during development at full power and maximum rpm for periods of up to 1200 hours on a dynomometer. These engines must be able to withstand whatever stresses a customer might inflict on them such as flat out cruising on the autobahn or endurance racing, without failure. Manufacturer's limits are conservative to guarantee longevity and reliability. The engineering and capital investment that goes into a new engine release dwarfs any similar development by any piston aircraft engine manufacturer. The testing and validation methods FAR exceed those required on piston aircraft engines. In Europe, cars are routinely cruised at speeds (RPMs and load) 50-100% higher than what we see in North America with no ill effects in life span. This is real world, long term hard use. Just one example of the demonstrated real world reliability on the popular Subaru EJ22 engine was the 1989 record set by 3 Legacy's at an Arizona test track. These cars were run flat out for 17 days straight without failure at an average speed of over 138 mph. Similar records have been set by Saab and Chevrolet. How many people reading this article think that most aircraft engines would survive at 100% takeoff power for 400 hours? Subaru now offers the production 2.5L turbo STI rated at 300 hp, With the popularity of showroom stock endurance racing in the last decade, we get to see just how good the design and engineering is on modern cars. Thousands of Hondas, Toyotas, Oldsmobiles, Chevrolets, Mitsubishis, VWs etc. are mercilessly flogged to the rev limiter at full throttle for hundreds of hours between rebuilds. A very small fraction of these ever suffer a serious failure. Aircraft use does not put this kind of cyclic stress on an engine, being a constant load, relatively low rpm situation. Most modern car engines outlast the chassis without ever being removed. This performance can be equated into lifespans of between 4000 and 8000 hours. Even operating at 75% of maximum power and rpm limits, it is reasonable to expect a TBO of at least 1000 hours in aircraft use. Cheers Les ----- Original Message ----- From: Peter Hudes <phudes(at)ix.netcom.com> Date: Sunday, January 6, 2008 12:21 pm Subject: Re: RV10-List: Kitplane's article, Ly-Con's case closed. > > Les, > > On Jan 6, 2008, at 10:16 AM, LES KEARNEY wrote: > > > Hi Kelly > > > > > > > > Compare the production runs of auto engines to a/c engines. > Auto > > engine production runs can run into the hundreds of thousands > in a > > single year. Think of the QA/QC and engineering effort that > goes > > into these engines, the quality of the parts and the > tolerances of > > the manufacturing process. Hands down, I am of the opinion > that > > these engines will have a higher inherent reliability > than > > traditional engines. Keep in mind that my engine will be a > factory > > new engine (in fact I helped un-crate it on Thursday at > the > > Eggenfellenr shop). It is not a reman, it is not rebuilt, and > it is > > not modified > > > Auto engines have been designed and tested to be operated in > a > different environment than aircraft engines. They are operated > a > majority of their life at a low percentage of power at low RPMs, > not > at a high percentage of power at high RPMs. > > > There are new risks I need to manage but these are reasonable. > Will > > this engine be more or less risky than a traditional engine - > I > > can't say. But I will mitigate the risk reviewing each > system, > > identifying risks and doing what I can to mitigate each risk. > > How are you going to evaluate and mitigate the risks associated > with > the PRU and prop combo? > > > > Pete Hudes > > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > _- > = - List Contribution Web Site - > _- > = -Matt Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jan 08, 2008
I attended the class last year... worth every penny. What you learn about how much meat you take off the top will save you a couple of weeks of walking around alone. The best tip I've got is to have lunch at the little Mexican joint on Airport Blvd. Jeff Carpenter 40304 On Jan 8, 2008, at 6:10 AM, MauleDriver wrote: > > Well, I just signed up for the 2 day class. I just starting > looking at putting the top on and queried Dave Saylor about the > class and found out one is scheduled for the end of the month. > Given all the belly aching about the fiberglass work, I was getting > a bit of indigestion. What better cure than some training! > > Have any of you attended this? Any tips? > > Bill "doing misc fuse work and getting ready for fiberglass" Watson > 40605 > > ________________________________________________________________________________
Date: Jan 08, 2008
Great mexican food and competitive fuel prices. -----Original Message----- From: Jeff Carpenter <jeff(at)westcottpress.com> Sent: Tue, 8 Jan 2008 9:23 am Subject: Re: RV10-List: Fiberglass class in Watsonville with RV10 focus ? I attended the class last year... worth every penny. What you learn about how much meat you take off the top will save you a couple of weeks of walking around alone. The best tip I've got is to have lunch at the little Mexican joint on Airport Blvd.? ? Jeff Carpenter? 40304? ? On Jan 8, 2008, at 6:10 AM, MauleDriver wrote:? ? >? > Well, I just signed up for the 2 day class. I just starting > looking at putting the top on and queried Dave Saylor about the > class and found out one is scheduled for the end of the month. > Given all the belly aching about the fiberglass work, I was getting > a bit of indigestion. What better cure than some training!? >? > Have any of you attended this? Any tips?? >? > Bill "doing misc fuse work and getting ready for fiberglass" Watson? > 40605? >? >? >? >? >? ? ? ? ________________________________________________________________________ ________________________________________________________________________________
Date: Jan 08, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Good Bill, you go and attend the class, then I can hire you as a consultant when I'm at that stage on mine. Jack Phillips #40610 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: Tuesday, January 08, 2008 9:11 AM Subject: RV10-List: Fiberglass class in Watsonville with RV10 focus Well, I just signed up for the 2 day class. I just starting looking at putting the top on and queried Dave Saylor about the class and found out one is scheduled for the end of the month. Given all the belly aching about the fiberglass work, I was getting a bit of indigestion. What better cure than some training! Have any of you attended this? Any tips? Bill "doing misc fuse work and getting ready for fiberglass" Watson 40605 _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Jan 08, 2008
Someone pointed out to me that people might have mistaken my use of Ly-Con. I meant the Lycoming / Continental engine makers and not the rebuilders. Sorry if I didn't use this correctly. John _____ From: John Jessen [mailto:N212PJ(at)gmail.com] Sent: Tuesday, January 08, 2008 10:00 AM Subject: RE: RV10-List: Kitplane's article, Ly-Con's case closed. Oh, gawd help me, but I cannot stop myself. Here goes. I wrote awhile back that I'm going to stick to Ly-Con because I didn't know enough to know what questions to ask. Now, I know that was a somewhat stupid statement, especially because I could find out, given my research background, but the point was, and this verbiage below confirms it, I have no clue when enough testing is enough, or enough failures are too many. I am not an aeronautical or mechanical or anything engineer. The one thing I cannot abide are statements that say almost nothing, but sound like they have expertise. "A very small fraction of these ever suffer a serious failure." Ok then, what's the fraction and how does that compare to the current crop of Ly-Con's. What's a serious failure? What were the outcomes? Did the car quit running? Did the people slam into a concrete wall at 100 mph, because that's what an aviator would essentially do, and whomever else was onboard, and that's why the family scenario keeps coming up. Putting an "experimental" engine into a four place aircraft is fine. As I said before I'm all for moving the bar forward. I don't know what engineering good or bad has gone into the certified Ly-Cons. I do know that the expensive certification process has kept them from easily making these engines more "advanced." The final testing that goes into the auto conversions, however, is left to those who are flying them. It was the same way when the Ly-Cons were first being put out. If the auto conversion folks put their designs through thousands of hours of testing in conditions that simulate what a real plane goes through, then fine. Show the data. Show the process. If they are doing so and I'm naive in what I'm saying, fine, correct me. But so far, the only statements I've seen are the obfuscating statements (crap, really) that I typically put into a report when I don't know the answer. Why is one PSRU better than another? Why did Jan declare that everyone must change to the new one? Stronger? How? Is the prop/PSRU combination the issue? Was there a harmonic issuer? Was the metallurgy on the gears better? Were the gears cracking? When you check your PSRU oil, will it tell you that there's a hairline crack in a gear? How will the engine hold up if you get a coolant leak? Will it stop working or get you to a safe landing? How will you know you have a coolant leak while in flight? I am sure that all those who are becoming Subaru test pilots for free will have asked these and thousands of other questions and gotten very good answers. I haven't ever seen anyone come back with a list of these questions and the answers and posted them, but since I'm not following the postings on these lists, maybe they have. Hope so. Now, this is not to say that every and all Ly-Con's shouldn't be taken to task with the thousands of questions that an auto conversion should be, with each question answered by test results. We should all be wanting to know what's the deal. Why do Ly-Con's develop hairline cracks in their jugs after 500 hours? Etc. We have a very large number of very good engine build specialists out there with good knowledge and experience and the willingness to share information (and Ly-Con will share some test results). I want Les to succeed. I want Jan, even though I have reservations about the person, to succeed. I want the folks from South Africa to build the best darn engine that has come along in a long long time. Just don't rely on non-critical statements. If you deal with a person who won't back up their claims with facts and thorough testing, walk away, which is what I did with Jan. And don't subject anyone else to your test bed. And, one more thing, make sure that when it fails, and it will, they all will, that the manufacturer is the type that will come, take the engine back, go over it with a fine toothed gizmo, do root cause analysis until the cows come home, and help the NTSB determine if the fault was the engine and why, and not just walk away and say it wasn't their fault. You've taken it upon yourself to be their test bed, they might as well admit to that and be part of it contractually. I know they won't, but to me, that is the reality of it and that's why I'll go the route that seems to be working. Ly-Con's with annuals. Annuals because I know the environment and how they are run are going to cause problems, eventually, sometimes sooner than later, and that's why we do annuals, not because the technology is so old or bad that we shouldn't have to need them. We do them because when our engine quits, we cannot pull off to the side of the road, we get to do what race car drivers do, we get to plow into the barrier at speeds that do not usually guarantee happy outcomes in a vehicle built out of aluminum, sans safety cage. Les, I met you once in Oregon and have followed your comments on this list and I've always been impressed with your care and thoroughness and intelligence. Please help us all out as you go through this journey and document as much as possible, especially in terms of the questions that you have asked and the answers given. That baby is going to run smooth as silk when you first fire it up, I'm sure. But I'd be doing an annual's worth on it every 50 hours for the forseeable future, until you and the fleet of similar installations are sure you have a winner. Good luck! John Jessen 40328. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY Sent: Sunday, January 06, 2008 11:42 AM Subject: Re: RV10-List: Kitplane's article, Ly-Con's case closed. Peter As I mntioned in my post to Kelly, I am not an engine expert / guru / authority by any stretch. Below is an exract from Ross Farnham's website: http://www.sdsefi.com/air7.html Many lay people often point out that automotive engines are not designed for continuous high output applications and will blow up when installed in an aircraft. This view is a result of complete ignorance in my opinion and is not supported by any credible facts. Modern automotive engines make use of the latest advances in computer design and modeling to optimize the design of everything from port flow, port resonance tuning, combustion chamber characteristics, vibrational node analysis and mechanical stresses. Machining and metallurgy technology is far superior to the old days when the air cooled, flat engines were developed. Technology has indeed progressed on automotive engines in the last 40 years. Automotive engines are routinely tested during development at full power and maximum rpm for periods of up to 1200 hours on a dynomometer. These engines must be able to withstand whatever stresses a customer might inflict on them such as flat out cruising on the autobahn or endurance racing, without failure. Manufacturer's limits are conservative to guarantee longevity and reliability. The engineering and capital investment that goes into a new engine release dwarfs any similar development by any piston aircraft engine manufacturer. The testing and validation methods FAR exceed those required on piston aircraft engines. In Europe, cars are routinely cruised at speeds (RPMs and load) 50-100% higher than what we see in North America with no ill effects in life span. This is real world, long term hard use. Just one example of the demonstrated real world reliability on the popular Subaru EJ22 engine was the 1989 record set by 3 Legacy's at an Arizona test track. These cars were run flat out for 17 days straight without failure at an average speed of over 138 mph. Similar records have been set by Saab and Chevrolet. How many people reading this article think that most aircraft engines would survive at 100% takeoff power for 400 hours? Subaru now offers the production 2.5L turbo STI rated at 300 hp, With the popularity of showroom stock endurance racing in the last decade, we get to see just how good the design and engineering is on modern cars. Thousands of Hondas, Toyotas, Oldsmobiles, Chevrolets, Mitsubishis, VWs etc. are mercilessly flogged to the rev limiter at full throttle for hundreds of hours between rebuilds. A very small fraction of these ever suffer a serious failure. Aircraft use does not put this kind of cyclic stress on an engine, being a constant load, relatively low rpm situation. Most modern car engines outlast the chassis without ever being removed. This performance can be equated into lifespans of between 4000 and 8000 hours. Even operating at 75% of maximum power and rpm limits, it is reasonable to expect a TBO of at least 1000 hours in aircraft use. Cheers Les ----- Original Message ----- From: Peter Hudes <phudes(at)ix.netcom.com> Date: Sunday, January 6, 2008 12:21 pm Subject: Re: RV10-List: Kitplane's article, Ly-Con's case closed. > > Les, > > On Jan 6, 2008, at 10:16 AM, LES KEARNEY wrote: > > > Hi Kelly > > > > > > > > Compare the production runs of auto engines to a/c engines. > Auto > > engine production runs can run into the hundreds of thousands > in a > > single year. Think of the QA/QC and engineering effort that > goes > > into these engines, the quality of the parts and the > tolerances of > > the manufacturing process. Hands down, I am of the opinion > that > > these engines will have a higher inherent reliability > than > > traditional engines. Keep in mind that my engine will be a > factory > > new engine (in fact I helped un-crate it on Thursday at > the > > Eggenfellenr shop). It is not a reman, it is not rebuilt, and > it is > > not modified > > > Auto engines have been designed and tested to be operated in > a > different environment than aircraft engines. They are operated > a > majority of their life at a low percentage of power at low RPMs, > not > at a high percentage of power at high RPMs. > > > There are new risks I need to manage but these are reasonable. > Will > > this engine be more or less risky than a traditional engine - > I > > can't say. But I will mitigate the risk reviewing each > system, > > identifying risks and doing what I can to mitigate each risk. > > How are you going to evaluate and mitigate the risks associated > with > the PRU and prop combo? > > > > Pete Hudes > > RV10-List Email Forum - > _- > = - MATRONICS WEB FORUMS - > _- > = - List Contribution Web Site - > _- > = -Matt Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jan 08, 2008
John, That was one of the most well written statements I've read in a long time on that subject. Keep in mind that statistics give meaning when you can determine probabilities, and overall quantities are an important part of that. With 100 flying Lycomings, if we had 2 fail, we'd have 2% failure rate, right? But, consider that the Subaru or other conversions are currently less than 1% of the installed base of Lycomings (in RV-10's). That means that, down the road a while as an example, you may know 10 people who have Lycoming failures, and perhaps 2 who have had alternative engine failures, you really need to look at the data pool that the numbers come from then. If we have 1000 lycomings, and 10 fail, that's 1%. If we have 1/100th the number of Alternatives, (i.e. 10) and we have 2 fail, then the failure rate is 20%. But, to the public, they'll hear lots more bitching on the newsgroup from the Lycoming crowd....simply because that's where the larger NUMBER of failures is. From the looks of it, even once the alternatives get flying in more quantities, they're going to be less than 5 or 10% of the total RV-10 fleet. So, the failure rates have the possibility to be many times larger for every failure. Also, it's just plain not right to consider the statistical failure rate of AUTO engines in AUTOS as the basis for what the failure rate will be in aircraft. You absolutely need to be operating the engines in the airframe to get anything meaningful to go on. That means that today, we have very very little statistical data on the alternatives, and even in number of hours flown, there are many many times less hours being put on them. So, a single failure or two is very significant. One of the large concerns I have is also that those with the alternatives will tend to be tight-lipped about their failures...which is understandable, but it just means that nobody can determine the actual reliability. Related to the question about PRSU reliability, and why the new one is being *required*..... If they had only 2 or 3 failures, think about what that means as a portion of the total. And then think about what that would mean if you scaled that percentage up to the same overall quantities as the number of lycomings flying. 2 or 3 PRSU failures could mean 2000, or even 10,000 failures in Lycoming quantities. Over time, there will be a trend, but until the same unit gets lots of time on it, we'll never know. That's the other sad thing about the alternatives. For instance, the Subie being sold in 2008 is NOT the same as the ones sold in 2007. So, how are people to determine the long term reliability? Still, it's a builders prerogative to choose their engine, and I'm glad we have the option. The real hope is that the alternatives can build on a design that they find to work well, and put lots of operational time on it so that some day it can become a larger and larger share of the overall market. Given some high reliabilities, I would think that many engines could be great choices, but for today, that choice is for those who are willing to accept a much greater share of uncertainty. I'm also uncertain if my engine, or my engine operational styles are going to cause me any grief down the road, but at least there's a pretty good pool of operational data that we can look at to give a general feel of the outlook. Tim John Jessen wrote: > Oh, gawd help me, but I cannot stop myself. Here goes. > > I wrote awhile back that I'm going to stick to Ly-Con because I didn't > know enough to know what questions to ask. Now, I know that was a > somewhat stupid statement, especially because I could find out, given my > research background, but the point was, and this verbiage below confirms > it, I have no clue when enough testing is enough, or enough failures are > too many. I am not an aeronautical or mechanical or anything engineer. > The one thing I cannot abide are statements that say almost nothing, but > sound like they have expertise. "/A very small fraction of these ever > suffer a serious failure." /Ok then, what's the fraction and how does > that compare to the current crop of Ly-Con's. What's a serious > failure? What were the outcomes? Did the car quit running? Did the > people slam into a concrete wall at 100 mph, because that's what an > aviator would essentially do, and whomever else was onboard, and that's > why the family scenario keeps coming up. > > Putting an "experimental" engine into a four place aircraft is fine. As > I said before I'm all for moving the bar forward. I don't know what > engineering good or bad has gone into the certified Ly-Cons. I do know > that the expensive certification process has kept them from easily > making these engines more "advanced." The final testing that goes into > the auto conversions, however, is left to those who are flying them. It > was the same way when the Ly-Cons were first being put out. If the auto > conversion folks put their designs through thousands of hours of testing > in conditions that simulate what a real plane goes through, then fine. > Show the data. Show the process. If they are doing so and I'm naive in > what I'm saying, fine, correct me. But so far, the only statements I've > seen are the obfuscating statements (crap, really) that I typically put > into a report when I don't know the answer. > > Why is one PSRU better than another? Why did Jan declare that everyone > must change to the new one? Stronger? How? Is the prop/PSRU > combination the issue? Was there a harmonic issuer? Was the metallurgy > on the gears better? Were the gears cracking? When you check your PSRU > oil, will it tell you that there's a hairline crack in a gear? How will > the engine hold up if you get a coolant leak? Will it stop working or > get you to a safe landing? How will you know you have a coolant leak > while in flight? I am sure that all those who are becoming Subaru test > pilots for free will have asked these and thousands of other questions > and gotten very good answers. I haven't ever seen anyone come back with > a list of these questions and the answers and posted them, but since I'm > not following the postings on these lists, maybe they have. Hope so. > Now, this is not to say that every and all Ly-Con's shouldn't be taken > to task with the thousands of questions that an auto conversion should > be, with each question answered by test results. We should all be > wanting to know what's the deal. Why do Ly-Con's develop hairline > cracks in their jugs after 500 hours? Etc. We have a very large number > of very good engine build specialists out there with good knowledge and > experience and the willingness to share information (and Ly-Con will > share some test results). > > I want Les to succeed. I want Jan, even though I have reservations > about the person, to succeed. I want the folks from South Africa to > build the best darn engine that has come along in a long long time. > Just don't rely on non-critical statements. If you deal with a person > who won't back up their claims with facts and thorough testing, walk > away, which is what I did with Jan. And don't subject anyone else to > your test bed. And, one more thing, make sure that when it fails, and > it will, they all will, that the manufacturer is the type that will > come, take the engine back, go over it with a fine toothed gizmo, do > root cause analysis until the cows come home, and help the NTSB > determine if the fault was the engine and why, and not just walk away > and say it wasn't their fault. You've taken it upon yourself to be > their test bed, they might as well admit to that and be part of it > contractually. I know they won't, but to me, that is the reality of it > and that's why I'll go the route that seems to be working. Ly-Con's > with annuals. Annuals because I know the environment and how they are > run are going to cause problems, eventually, sometimes sooner than > later, and that's why we do annuals, not because the technology is so > old or bad that we shouldn't have to need them. We do them because when > our engine quits, we cannot pull off to the side of the road, we get to > do what race car drivers do, we get to plow into the barrier at speeds > that do not usually guarantee happy outcomes in a vehicle built out of > aluminum, sans safety cage. > > Les, I met you once in Oregon and have followed your comments on this > list and I've always been impressed with your care and thoroughness and > intelligence. Please help us all out as you go through this journey and > document as much as possible, especially in terms of the questions that > you have asked and the answers given. That baby is going to run smooth > as silk when you first fire it up, I'm sure. But I'd be doing an > annual's worth on it every 50 hours for the forseeable future, until you > and the fleet of similar installations are sure you have a winner. Good > luck! > > John Jessen > 40328. > > ------------------------------------------------------------------------ > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *LES KEARNEY > *Sent:* Sunday, January 06, 2008 11:42 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Kitplane's article, Ly-Con's case closed. > > Peter > > As I mntioned in my post to Kelly, I am not an engine expert / guru / > authority by any stretch. Below is an exract from Ross Farnham's > website: http://www.sdsefi.com/air7.html > // > /Many lay people often point out that automotive engines are not > designed for continuous high output applications and will blow up when > installed in an aircraft. This view is a result of complete ignorance in > my opinion and is not supported by any credible facts. Modern automotive > engines make use of the latest advances in computer design and modeling > to optimize the design of everything from port flow, port resonance > tuning, combustion chamber characteristics, vibrational node analysis > and mechanical stresses. Machining and metallurgy technology is far > superior to the old days when the air cooled, flat engines were > developed. Technology has indeed progressed on automotive engines in the > last 40 years./ > > /Automotive engines are routinely tested during development at full > power and maximum rpm for periods of up to 1200 hours on a dynomometer. > These engines must be able to withstand whatever stresses a customer > might inflict on them such as flat out cruising on the autobahn or > endurance racing, without failure. Manufacturer's limits are > conservative to guarantee longevity and reliability. The engineering and > capital investment that goes into a new engine release dwarfs any > similar development by any piston aircraft engine manufacturer. The > testing and validation methods FAR exceed those required on piston > aircraft engines. In Europe, cars are routinely cruised at speeds (RPMs > and load) 50-100% higher than what we see in North America with no ill > effects in life span. This is real world, long term hard use./ > > /Just one example of the demonstrated real world reliability on the > popular Subaru EJ22 engine was the 1989 record set by 3 Legacy's at an > Arizona test track. These cars were run flat out for 17 days straight > without failure at an average speed of over 138 mph. Similar records > have been set by Saab and Chevrolet. How many people reading this > article think that most aircraft engines would survive at 100% takeoff > power for 400 hours? Subaru now offers the production 2.5L turbo STI > rated at 300 hp, With the popularity of showroom stock endurance racing > in the last decade, we get to see just how good the design and > engineering is on modern cars. Thousands of Hondas, Toyotas, > Oldsmobiles, Chevrolets, Mitsubishis, VWs etc. are mercilessly flogged > to the rev limiter at full throttle for hundreds of hours between > rebuilds. A very small fraction of these ever suffer a serious failure. > Aircraft use does not put this kind of cyclic stress on an engine, being > a constant load, relatively low rpm situation. Most modern car engines > outlast the chassis without ever being removed. This performance can be > equated into lifespans of between 4000 and 8000 hours. Even operating at > 75% of maximum power and rpm limits, it is reasonable to expect a TBO of > at least 1000 hours in aircraft use./ > > Cheers > > Les > > ----- Original Message ----- > From: Peter Hudes <phudes(at)ix.netcom.com> > Date: Sunday, January 6, 2008 12:21 pm > Subject: Re: RV10-List: Kitplane's article, Ly-Con's case closed. > To: rv10-list(at)matronics.com > > > > > Les, > > > > On Jan 6, 2008, at 10:16 AM, LES KEARNEY wrote: > > > > > Hi Kelly > > > > > > > > > > > > Compare the production runs of auto engines to a/c engines. > > Auto > > > engine production runs can run into the hundreds of thousands > > in a > > > single year. Think of the QA/QC and engineering effort that > > goes > > > into these engines, the quality of the parts and the > > tolerances of > > > the manufacturing process. Hands down, I am of the opinion > > that > > > these engines will have a higher inherent reliability > > than > > > traditional engines. Keep in mind that my engine will be a > > factory > > > new engine (in fact I helped un-crate it on Thursday at > > the > > > Eggenfellenr shop). It is not a reman, it is not rebuilt, and > > it is > > > not modified > > > > > > Auto engines have been designed and tested to be operated in > > a > > different environment than aircraft engines. They are operated > > a > > majority of their life at a low percentage of power at low RPMs, > > not > > at a high percentage of power at high RPMs. > > > > > There are new risks I need to manage but these are reasonable. > > Will > > > this engine be more or less risky than a traditional engine > > I > > > cant say. But I will mitigate the risk reviewing each > > system, > > > identifying risks and doing what I can to mitigate each risk. > > > > How are you going to evaluate and mitigate the risks associated > > with > > the PRU and prop combo? > > > > > > > Pete Hudes > > ________________________________________________________________________________
Date: Jan 08, 2008
I haven't attended before, but will be attending this one. I'm happy to hear some other list members are going. I'm looking forward to putting some more faces to the names. I've done quite a bit of glass work on boats, but all the trimming and finishing for an aircraft has been giving me a bit of pause. Especially with all the good things I hear about it. I'll be fitting the top in a month or two so the class timing was about perfect for me. Best Regards, Patrick #40715 / N690CT -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: Tuesday, January 08, 2008 6:11 AM Subject: RV10-List: Fiberglass class in Watsonville with RV10 focus Well, I just signed up for the 2 day class. I just starting looking at putting the top on and queried Dave Saylor about the class and found out one is scheduled for the end of the month. Given all the belly aching about the fiberglass work, I was getting a bit of indigestion. What better cure than some training! Have any of you attended this? Any tips? Bill "doing misc fuse work and getting ready for fiberglass" Watson 40605 ________________________________________________________________________________
Date: Jan 08, 2008
I'm attending as well and look forward to meeting all of you. I do have to say the best tip I've gotten though would be to farm out the fiberglass!!! Sure wish I wasn't flying in on Southwest Airlines for this one too. -Ben Westfall #40579 PDX -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver Sent: Tuesday, January 08, 2008 6:11 AM Subject: RV10-List: Fiberglass class in Watsonville with RV10 focus Well, I just signed up for the 2 day class. I just starting looking at putting the top on and queried Dave Saylor about the class and found out one is scheduled for the end of the month. Given all the belly aching about the fiberglass work, I was getting a bit of indigestion. What better cure than some training! Have any of you attended this? Any tips? Bill "doing misc fuse work and getting ready for fiberglass" Watson 40605 ________________________________________________________________________________
Date: Jan 08, 2008
That's what I like to hear. I just put the top on for the first time and did a lot of walking around. A little experienced help and guidance will go a long way. I've played with fiberglass a bit over the years but only as a hacker. Adding a little technique and craft will be nice. ...this Mexican food thing is worrying me a bit though Bill Jeff Carpenter wrote: > > I attended the class last year... worth every penny. What you learn > about how much meat you take off the top will save you a couple of > weeks of walking around alone. The best tip I've got is to have lunch > at the little Mexican joint on Airport Blvd. > > Jeff Carpenter > 40304 > > > On Jan 8, 2008, at 6:10 AM, MauleDriver wrote: > >> >> Well, I just signed up for the 2 day class. I just starting looking >> at putting the top on and queried Dave Saylor about the class and >> found out one is scheduled for the end of the month. Given all the >> belly aching about the fiberglass work, I was getting a bit of >> indigestion. What better cure than some training! >> >> Have any of you attended this? Any tips? >> >> Bill "doing misc fuse work and getting ready for fiberglass" Watson >> 40605 >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 08, 2008
Subject: Re: Kitplane's article, Ly-Con's case closed.
John, That was a well-thought post. Keep in mind that statistics give meaning when you can determine probabilities, and overall quantities are an important part of that. With 100 flying Lycomings, if we had 2 fail, we'd have 2% failure rate, right? But, consider that the Subaru or other conversions are currently less than 1% of the installed base of Lycomings (in RV-10's). That means that, down the road a while as an example, you may know 10 people who have Lycoming failures, and perhaps 2 who have had alternative engine failures, you really need to look at the data pool that the numbers come from then. If we have 1000 lycomings, and 10 fail, that's 1%. If we have 1/100th the number of Alternatives, (i.e. 10) and we have 2 fail, then the failure rate is 20%. But, to the public, they'll hear lots more bitching on the newsgroup from the Lycoming crowd....simply because that's where the larger NUMBER of failures is. From the looks of it, even once the alternatives get flying in more quantities, they're going to be less than 5 or 10% of the total RV-10 fleet. So, the failure rates have the possibility to be many times larger for every failure. Also, it's just plain not right to consider the statistical failure rate of AUTO engines in AUTOS as the basis for what the failure rate will be in aircraft. You absolutely need to be operating the engines in the airframe to get anything meaningful to go on. That means that today, we have very very little statistical data on the alternatives, and even in number of hours flown, there are many many times less hours being put on them. So, a single failure or two is very significant. One of the large concerns I have is also that those with the alternatives will tend to be tight-lipped about their failures...which is understandable, but it just means that nobody can determine the actual reliability. Related to the question about PRSU reliability, and why the new one is being *required*..... If they had only 2 or 3 failures, think about what that means as a portion of the total. And then think about what that would mean if you scaled that percentage up to the same overall quantities as the number of lycomings flying. 2 or 3 PRSU failures could mean 2000, or even 10,000 failures in Lycoming quantities. Over time, there will be a trend, but until the same unit gets lots of time on it, we'll never know. That's the other sad thing about the alternatives. For instance, the Subie being sold in 2008 is NOT the same as the ones sold in 2007. So, how are people to determine the long term reliability? Still, it's a builders prerogative to choose their engine, and I'm glad we have the option. The real hope is that the alternatives can build on a design that they find to work well, and put lots of operational time on it so that some day it can become a larger and larger share of the overall market. Given some high reliabilities, I would think that many engines could be great choices, but for today, that choice is for those who are willing to accept a much greater share of uncertainty. I'm also uncertain if my engine, or my engine operational styles are going to cause me any grief down the road, but at least there's a pretty good pool of operational data that we can look at to give a general feel of the outlook. Tim John Jessen wrote: > Oh, gawd help me, but I cannot stop myself. Here goes. > > I wrote awhile back that I'm going to stick to Ly-Con because I didn't > know enough to know what questions to ask. Now, I know that was a > somewhat stupid statement, especially because I could find out, given my > research background, but the point was, and this verbiage below confirms > it, I have no clue when enough testing is enough, or enough failures are > too many. I am not an aeronautical or mechanical or anything engineer. > The one thing I cannot abide are statements that say almost nothing, but > sound like they have expertise. "/A very small fraction of these ever > suffer a serious failure." /Ok then, what's the fraction and how does > that compare to the current crop of Ly-Con's. What's a serious > failure? What were the outcomes? Did the car quit running? Did the > people slam into a concrete wall at 100 mph, because that's what an > aviator would essentially do, and whomever else was onboard, and that's > why the family scenario keeps coming up. > > Putting an "experimental" engine into a four place aircraft is fine. As > I said before I'm all for moving the bar forward. I don't know what > engineering good or bad has gone into the certified Ly-Cons. I do know > that the expensive certification process has kept them from easily > making these engines more "advanced." The final testing that goes into > the auto conversions, however, is left to those who are flying them. It > was the same way when the Ly-Cons were first being put out. If the auto > conversion folks put their designs through thousands of hours of testing > in conditions that simulate what a real plane goes through, then fine. > Show the data. Show the process. If they are doing so and I'm naive in > what I'm saying, fine, correct me. But so far, the only statements I've > seen are the obfuscating statements (crap, really) that I typically put > into a report when I don't know the answer. > > Why is one PSRU better than another? Why did Jan declare that everyone > must change to the new one? Stronger? How? Is the prop/PSRU > combination the issue? Was there a harmonic issuer? Was the metallurgy > on the gears better? Were the gears cracking? When you check your PSRU > oil, will it tell you that there's a hairline crack in a gear? How will > the engine hold up if you get a coolant leak? Will it stop working or > get you to a safe landing? How will you know you have a coolant leak > while in flight? I am sure that all those who are becoming Subaru test > pilots for free will have asked these and thousands of other questions > and gotten very good answers. I haven't ever seen anyone come back with > a list of these questions and the answers and posted them, but since I'm > not following the postings on these lists, maybe they have. Hope so. > Now, this is not to say that every and all Ly-Con's shouldn't be taken > to task with the thousands of questions that an auto conversion should > be, with each question answered by test results. We should all be > wanting to know what's the deal. Why do Ly-Con's develop hairline > cracks in their jugs after 500 hours? Etc. We have a very large number > of very good engine build specialists out there with good knowledge and > experience and the willingness to share information (and Ly-Con will > share some test results). > > I want Les to succeed. I want Jan, even though I have reservations > about the person, to succeed. I want the folks from South Africa to > build the best darn engine that has come along in a long long time. > Just don't rely on non-critical statements. If you deal with a person > who won't back up their claims with facts and thorough testing, walk > away, which is what I did with Jan. And don't subject anyone else to > your test bed. And, one more thing, make sure that when it fails, and > it will, they all will, that the manufacturer is the type that will > come, take the engine back, go over it with a fine toothed gizmo, do > root cause analysis until the cows come home, and help the NTSB > determine if the fault was the engine and why, and not just walk away > and say it wasn't their fault. You've taken it upon yourself to be > their test bed, they might as well admit to that and be part of it > contractually. I know they won't, but to me, that is the reality of it > and that's why I'll go the route that seems to be working. Ly-Con's > with annuals. Annuals because I know the environment and how they are > run are going to cause problems, eventually, sometimes sooner than > later, and that's why we do annuals, not because the technology is so > old or bad that we shouldn't have to need them. We do them because when > our engine quits, we cannot pull off to the side of the road, we get to > do what race car drivers do, we get to plow into the barrier at speeds > that do not usually guarantee happy outcomes in a vehicle built out of > aluminum, sans safety cage. > > Les, I met you once in Oregon and have followed your comments on this > list and I've always been impressed with your care and thoroughness and > intelligence. Please help us all out as you go through this journey and > document as much as possible, especially in terms of the questions that > you have asked and the answers given. That baby is going to run smooth > as silk when you first fire it up, I'm sure. But I'd be doing an > annual's worth on it every 50 hours for the forseeable future, until you > and the fleet of similar installations are sure you have a winner. Good > luck! > > John Jessen > 40328. ________________________________________________________________________________
Date: Jan 08, 2008
I attended last year's class with Jeff and will second his comments. I had just spent 2 weeks gradually trimming my cabin top to fit before leaving for Dave's workshop. They showed us how to do the job in 2-3 hours, plus lots of other good stuff. Well worth your time and money. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156855#156855 ________________________________________________________________________________
Date: Jan 08, 2008
Subject: let's not let this happen to us
On the SoCal VAF I saw this and wanted to bring it to this group as we have many critical players that I would hate to see happen to this group. http://rvnewsletter.blogspot.com/2008/01/darned-shame.html Pascal ________________________________________________________________________________
Date: Jan 09, 2008
Subject: Re: let's not let this happen to us
Pascal, Don't underestimate the respectability of everyone here on all sides of any discussion. There is very little here that happens that drives people into anger. Yeah, everyone has some disappointment when others don't seem to "get it",and that goes for both sides of any argument, but at the same time, we make room for those differences as we're all a part of the same family in general....the RV-10 kit family. I think that's what makes this list work so well is that we celebrate that single big similarity more. Engines, primers, EFIS's, and all the other things are just components in the big scheme of things, but it's the fact that they'll be flying the same kit model that gives a union of similarity. There are many hot button topics, but none that really get me riled up too much. I have done things the way that I did, using all the learned info to make my own conclusions. Everyone else really should do the same. Ingest, digest, and then produce your own outcome. The key is soaking in all the info you can. If we avoid talking about the hot button topics, we don't do anyone any favors. And if both camps of any topic don't participate, then the discussion goes nowhere, and people don't get the positives and negatives or other thinking points. So it's all worth while. I'll leave you with this post I grabbed off the Lancair list that I think was a repost from elsewhere. I found it really humorous. -Tim ---------------------------------------------------------------------- I think I've been spending too much time reading email lists, because I found this to be hysterical... HOW MANY EMAIL LIST MEMBERS DOES IT TAKE TO CHANGE A LIGHT BULB? 1 to change the light bulb and to post that the light bulb has been changed. 14 to share similar experiences of changing light bulbs and how the light bulb could have been changed differently. 7 to caution about the dangers of changing light bulbs. 6 to argue over whether it's "lightbulb" or "light bulb" ... Another 6 to condemn those 6 as stupid. 2 industry professionals to inform the group that the proper term is "lamp". 15 know-it-alls who claim they were in the industry, and that "light bulb" is perfectly correct. 19 to post that this forum is not about light bulbs and to please take this discussion to a light bulb forum. 11 to defend the posting to this forum saying that we all use light bulbs and therefore the posts are relevant to this forum. 36 to debate which method of changing light bulbs is superior, where to buy the best light bulbs, what brand of light bulbs work best for this technique and what brands are faulty. 5 People to post pics of their own light bulbs. 7 to post URL's where one can see examples of different light bulbs. 4 to post that the URL's were posted incorrectly and then post the corrected URL's. 13 to link all posts to date, quote them in their entirety including all headers and signatures, and add "Me too". 5 to post to the group that they will no longer post because they cannot handle the light bulb controversy. 4 to say "didn't we go through this already a short time ago?" 13 to say "do a search on light bulbs before posting questions about light bulbs". 1 to bring politics into the discussion by adding that George W. isn't the brightest bulb. 4 more to get into personal attacks over their political views. 1 moderator to lock the light bulb thread. 1 guy wondering when Can-Am is going to step up to the plate and make lightbulbs as bright as the other manufactures. 3 guys wondering what the 2012 lightbulbs will be like. 1 forum lurker to respond to the original post 6 months from now and start it all over again. Pascal wrote: > On the SoCal VAF I saw this and wanted to bring it to this group as we > have many critical players that I would hate to see happen to this group. > > http://rvnewsletter.blogspot.com/2008/01/darned-shame.html > <http://rvnewsletter.blogspot.com/2008/01/darned-shame.html> > > Pascal > ________________________________________________________________________________
Date: Jan 09, 2008
Hilarious! (see #13) David Maib 40559 On Jan 9, 2008, at 8:14 AM, Tim Olson wrote: Pascal, Don't underestimate the respectability of everyone here on all sides of any discussion. There is very little here that happens that drives people into anger. Yeah, everyone has some disappointment when others don't seem to "get it",and that goes for both sides of any argument, but at the same time, we make room for those differences as we're all a part of the same family in general....the RV-10 kit family. I think that's what makes this list work so well is that we celebrate that single big similarity more. Engines, primers, EFIS's, and all the other things are just components in the big scheme of things, but it's the fact that they'll be flying the same kit model that gives a union of similarity. There are many hot button topics, but none that really get me riled up too much. I have done things the way that I did, using all the learned info to make my own conclusions. Everyone else really should do the same. Ingest, digest, and then produce your own outcome. The key is soaking in all the info you can. If we avoid talking about the hot button topics, we don't do anyone any favors. And if both camps of any topic don't participate, then the discussion goes nowhere, and people don't get the positives and negatives or other thinking points. So it's all worth while. I'll leave you with this post I grabbed off the Lancair list that I think was a repost from elsewhere. I found it really humorous. -Tim ---------------------------------------------------------------------- I think I've been spending too much time reading email lists, because I found this to be hysterical... HOW MANY EMAIL LIST MEMBERS DOES IT TAKE TO CHANGE A LIGHT BULB? 1 to change the light bulb and to post that the light bulb has been changed. 14 to share similar experiences of changing light bulbs and how the light bulb could have been changed differently. 7 to caution about the dangers of changing light bulbs. 6 to argue over whether it's "lightbulb" or "light bulb" ... Another 6 to condemn those 6 as stupid. 2 industry professionals to inform the group that the proper term is "lamp". 15 know-it-alls who claim they were in the industry, and that "light bulb" is perfectly correct. 19 to post that this forum is not about light bulbs and to please take this discussion to a light bulb forum. 11 to defend the posting to this forum saying that we all use light bulbs and therefore the posts are relevant to this forum. 36 to debate which method of changing light bulbs is superior, where to buy the best light bulbs, what brand of light bulbs work best for this technique and what brands are faulty. 5 People to post pics of their own light bulbs. 7 to post URL's where one can see examples of different light bulbs. 4 to post that the URL's were posted incorrectly and then post the corrected URL's. 13 to link all posts to date, quote them in their entirety including all headers and signatures, and add "Me too". 5 to post to the group that they will no longer post because they cannot handle the light bulb controversy. 4 to say "didn't we go through this already a short time ago?" 13 to say "do a search on light bulbs before posting questions about light bulbs". 1 to bring politics into the discussion by adding that George W. isn't the brightest bulb. 4 more to get into personal attacks over their political views. 1 moderator to lock the light bulb thread. 1 guy wondering when Can-Am is going to step up to the plate and make lightbulbs as bright as the other manufactures. 3 guys wondering what the 2012 lightbulbs will be like. 1 forum lurker to respond to the original post 6 months from now and start it all over again. Pascal wrote: > On the SoCal VAF I saw this and wanted to bring it to this group as > we have many critical players that I would hate to see happen to > this group. > http://rvnewsletter.blogspot.com/2008/01/darned-shame.html rvnewsletter.blogspot.com/2008/01/darned-shame.html> > Pascal ________________________________________________________________________________
Subject: Fences
Date: Jan 09, 2008
Makes me proud... >From a post on the Glastar list... At my home airport (FYJ) the anti-terrorist fence ends about 50 feet each side of the road leading in. We were issued codes to get through the $17,000 electric gate. Guests must go through the terminal building ($1.7m) to get in. Terrorists evidently don't have the wits to walk around the end of the fence so they are barred from evil deeds. Before the fence, people interested in flying would often stop by and visit or bring their kids to watch. No more. ________________________________________________________________________________
Date: Jan 09, 2008
From: German Alvarez <german.alvarez(at)playalinda.net>
Subject: Re: Fiberglass class in Watsonville with RV10 focus
Hi, I will be attending the class in Watsonville. I live in San Jose and I will be driving to Watsonville and back both days. If someone is interested in car-pooling send me an e-mail. --ga ________________________________________________________________________________
Date: Jan 09, 2008
Subject: Fences
Yeah, My old airport had something similar. Makes the uninformed feel more secure, while inconveniencing the many. Kinda like waiting in line barefoot at the large airports. The law of unintended consequences. I had a non-pilot interloper comment that security like that (gates & fences) "should be mandated at all small airports" -- I had to help him correct his "frame of reference." William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Makes me proud... > > >From a post on the Glastar list... > > At my home airport (FYJ) the anti-terrorist fence ends about 50 feet each > side of the road leading in. We were issued codes to get through the $17,000 > electric gate. Guests must go through the terminal building ($1.7m) to get > in. Terrorists evidently don't have the wits to walk around the end of the > fence so they are barred from evil deeds. > > Before the fence, people interested in flying would often stop by and visit > or bring their kids to watch. No more. > > > ________________________________________________________________________________
Subject: Fences
Date: Jan 09, 2008
When I was a kid (LONG time ago)one of the major arterial streets in Tulsa ended roughly 100 yds from the main runway at KTUL. One of the great pleasures we had as youngsters was going to Brahms, getting an ice cream and cruisin' to the airport with Dad on Saturday nights to watch take offs and landings. Now we have locked gates, limited access, and the big eye in the sky watching you if your within 1/4 mile of the field. Damn shame -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Wednesday, January 09, 2008 12:23 PM Subject: RV10-List: Fences Makes me proud... >From a post on the Glastar list... At my home airport (FYJ) the anti-terrorist fence ends about 50 feet each side of the road leading in. We were issued codes to get through the $17,000 electric gate. Guests must go through the terminal building ($1.7m) to get in. Terrorists evidently don't have the wits to walk around the end of the fence so they are barred from evil deeds. Before the fence, people interested in flying would often stop by and visit or bring their kids to watch. No more. ________________________________________________________________________________
Subject: Fences
Date: Jan 09, 2008
It is truly a shame at the impact the goofy rules are making on a great way of life. At my last airport the 'strict' security policy included giving all those with legal access a card that was nothing more than a business card with your picture printed on it that my kids could have duplicated in minutes. William, thanks for taking the time to educate the non-pilot on how things could be and used to be. I hope we can somehow encourage lookers and wanna-be's back onto the airfield someday. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Wednesday, January 09, 2008 2:16 PM Subject: re: RV10-List: Fences Yeah, My old airport had something similar. Makes the uninformed feel more secure, while inconveniencing the many. Kinda like waiting in line barefoot at the large airports. The law of unintended consequences. I had a non-pilot interloper comment that security like that (gates & fences) "should be mandated at all small airports" -- I had to help him correct his "frame of reference." William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Makes me proud... > > >From a post on the Glastar list... > > At my home airport (FYJ) the anti-terrorist fence ends about 50 feet each > side of the road leading in. We were issued codes to get through the $17,000 > electric gate. Guests must go through the terminal building ($1.7m) to get > in. Terrorists evidently don't have the wits to walk around the end of the > fence so they are barred from evil deeds. > > Before the fence, people interested in flying would often stop by and visit > or bring their kids to watch. No more. > > > ________________________________________________________________________________
Date: Jan 09, 2008
Subject: Re: Fences
/"I hope we can somehow encourage lookers and wanna-be's back onto the airfield someday." Marcus/ You bet I'm trying! On weekends I press my 3 year old sons face against the glass at the terminal when ever a plane goes by! He's starting to ask me to go to the airport with me to look at airplanes and hepikers! I so hope he is a third gen pilot! Carlos in AZ Marcus Cooper wrote: > > It is truly a shame at the impact the goofy rules are making on a great way > of life. At my last airport the 'strict' security policy included giving > all those with legal access a card that was nothing more than a business > card with your picture printed on it that my kids could have duplicated in > minutes. > > William, thanks for taking the time to educate the non-pilot on how things > could be and used to be. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis > Sent: Wednesday, January 09, 2008 2:16 PM > To: rv10-list(at)matronics.com; rv10-list(at)matronics.com > Subject: re: RV10-List: Fences > > > Yeah, My old airport had something similar. Makes the uninformed feel more > secure, while inconveniencing the many. Kinda like waiting in line barefoot > at the large airports. The law of unintended consequences. > > I had a non-pilot interloper comment that security like that (gates & > fences) "should be mandated at all small airports" -- I had to help him > correct his "frame of reference." > > William > http://wcurtis.nerv10.com/ > "Be who you are and say what you feel because those who mind don't matter > and those who matter don't mind." > -- Dr. Suess > > -------- Original Message -------- > >> >> Makes me proud... >> >> >From a post on the Glastar list... >> >> At my home airport (FYJ) the anti-terrorist fence ends about 50 feet each >> side of the road leading in. We were issued codes to get through the >> > $17,000 > >> electric gate. Guests must go through the terminal building ($1.7m) to get >> in. Terrorists evidently don't have the wits to walk around the end of the >> fence so they are barred from evil deeds. >> >> Before the fence, people interested in flying would often stop by and >> > visit > >> or bring their kids to watch. No more. >> >> >> >> > > > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Jan 09, 2008
Been thinking about this and have signed up. Just finishing up wingtips. Have a QB fuselage out in the garage. Will fly into San Jose around 9 PM fri night and head out to Comfort Inn in Watsonville. Look forward to meeting you all. Tom Hanaway Boynton Beach, FL 561-702-5456 (c) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157125#157125 ________________________________________________________________________________
Subject: Fences
Date: Jan 09, 2008
You did not realize that Bin Laden's secret plan was to kill us with bureaucracy. It's well known outside the US that the Feds overreact on everything by hiring more bureaucrats and making more rules. Wasting billions of dollars. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Wednesday, January 09, 2008 1:16 PM Subject: re: RV10-List: Fences Yeah, My old airport had something similar. Makes the uninformed feel more secure, while inconveniencing the many. Kinda like waiting in line barefoot at the large airports. The law of unintended consequences. I had a non-pilot interloper comment that security like that (gates & fences) "should be mandated at all small airports" -- I had to help him correct his "frame of reference." William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > Makes me proud... > > >From a post on the Glastar list... > > At my home airport (FYJ) the anti-terrorist fence ends about 50 feet > each side of the road leading in. We were issued codes to get through > the $17,000 electric gate. Guests must go through the terminal > building ($1.7m) to get in. Terrorists evidently don't have the wits > to walk around the end of the fence so they are barred from evil deeds. > > Before the fence, people interested in flying would often stop by and > visit or bring their kids to watch. No more. > > > ________________________________________________________________________________
Subject: Fences
Date: Jan 09, 2008
I used to walk on the ramp at the buildings just west of Pennant Aviation; Access to the ramnp at the FSDO was not a problem. FBL. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BPA Sent: Wednesday, January 09, 2008 1:50 PM Subject: RE: RV10-List: Fences When I was a kid (LONG time ago)one of the major arterial streets in Tulsa ended roughly 100 yds from the main runway at KTUL. One of the great pleasures we had as youngsters was going to Brahms, getting an ice cream and cruisin' to the airport with Dad on Saturday nights to watch take offs and landings. Now we have locked gates, limited access, and the big eye in the sky watching you if your within 1/4 mile of the field. Damn shame -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Wednesday, January 09, 2008 12:23 PM Subject: RV10-List: Fences Makes me proud... >From a post on the Glastar list... At my home airport (FYJ) the anti-terrorist fence ends about 50 feet each side of the road leading in. We were issued codes to get through the $17,000 electric gate. Guests must go through the terminal building ($1.7m) to get in. Terrorists evidently don't have the wits to walk around the end of the fence so they are barred from evil deeds. Before the fence, people interested in flying would often stop by and visit or bring their kids to watch. No more. ________________________________________________________________________________
Subject: Stunt Pilot Poem
Date: Jan 09, 2008
My son wrote this for an English assignment the other night in my shop while I was pounding rivets into my bottom left wing. I thought you all might like it. Dave Leikam 40496 ________________________________________________________________________________
Subject: Cutting front baffll CB-1001a
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Jan 10, 2008
Hello, did you guys cut the CB-1001a front baffle in order to fit the prop governor through the cut out hole? Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157200#157200 Attachments: http://forums.matronics.com//files/dsc02785_492.jpg ________________________________________________________________________________
Subject: Re: Cutting front baffll CB-1001a
Date: Jan 10, 2008
Yes, a little. You don't want to remove too much, though, because you don't want to lose your cooling air through that hole. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jan 10, 2008, at 3:21 AM, Michael Wellenzohn wrote: > > > > Hello, > > did you guys cut the CB-1001a front baffle in order to fit the prop > governor through the cut out hole? > > Michael > > -------- > RV-10 builder (fuselage) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=157200#157200 > > > Attachments: > > http://forums.matronics.com//files/dsc02785_492.jpg > > ________________________________________________________________________________
Date: Jan 10, 2008
Yep, try to trim in the shape of the governor, so that the ramp kind of form fits to the governor's needs. Leave enough clearance though to guarantee the lever and bolt won't hang up. Then, once you have the slot there and it's wide enough, glass in the ramp ends so the air can't flow up through that area and under the ramps. You should be able to seal that area pretty well, even with the clearance hole. The sealing of the air ramps is a big key to getting things done right. Tim Michael Wellenzohn wrote: > > Hello, > > did you guys cut the CB-1001a front baffle in order to fit the prop governor through the cut out hole? > > Michael > > -------- > RV-10 builder (fuselage) > #511 > ________________________________________________________________________________
Date: Jan 10, 2008
Subject: Diesel engine lawsuit...from avweb...
Millen Aviation Services of Kent, England, filed a lawsuit on Dec. 17, 2007, against Diamond Aircraft Industries in Wiener Neustadt, Austria, over their Thielert diesel-powered DA40s. "The claim for damages is based on our experience with our two DA40 1.7 TDIs, their extremely poor reliability, highmaintenance costs, waiting time for spare parts and, our firm belief of their premature release to market without sufficient research, development and testing," company partner Mike Millen said in a prepared statement. Diamond did not immediately respond to AVweb's request for comment.... Kind of interesting that Millen cites high maintenance and spare parts as a problem when Thielert and others in the diesel business talk about diesel engines as having less parts and more reliability...sure would be interesting to know the exact details... P **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 10, 2008
Michael, You bet--seems that there is no other way. Dave Lammers finishing Michael Wellenzohn wrote: > >Hello, > >did you guys cut the CB-1001a front baffle in order to fit the prop governor through the cut out hole? > >Michael > >-------- >RV-10 builder (fuselage) >#511 > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=157200#157200 > > >Attachments: > >http://forums.matronics.com//files/dsc02785_492.jpg > > > > ________________________________________________________________________________
Date: Jan 10, 2008
Very nice; thanks for sharing. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Wednesday, January 09, 2008 9:12 PM Subject: RV10-List: Stunt Pilot Poem My son wrote this for an English assignment the other night in my shop while I was pounding rivets into my bottom left wing. I thought you all might like it. Dave Leikam 40496 ________________________________________________________________________________
Date: Jan 10, 2008
Subject: Re: Diesel engine lawsuit...from avweb...
That's all I need to know, to make an informed decision. Back to the Lycon for now! Sam GRANSCOTT(at)aol.com wrote: > /Millen Aviation Services of Kent, England, filed a lawsuit on Dec. > 17, 2007, against Diamond Aircraft Industries in Wiener Neustadt, > Austria, over their Thielert diesel-powered DA40s. "The claim for > damages is based on our experience with our two DA40 1.7 TDIs, their > extremely poor reliability, highmaintenance costs, waiting time for > spare parts and, our firm belief of their premature release to market > without sufficient research, development and testing," company partner > Mike Millen said in a prepared statement. Diamond did not immediately > respond to AVweb's request for comment..../ > > Kind of interesting that Millen cites high maintenance and spare parts > as a problem when Thielert and others in the diesel business talk > about diesel engines as having less parts and more reliability...sure > would be interesting to know the exact details... > > P > > > ------------------------------------------------------------------------ > Start the year off right. Easy ways to stay in shape > <http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489> > in the new year. > * > > > * ________________________________________________________________________________
Subject: Re: Stunt Pilot Poem
Date: Jan 10, 2008
Ahhh...so he's observed your craftsmanship??? ;) ----- Original Message ----- From: Dave Leikam To: RV-10 matronics Sent: Wednesday, January 09, 2008 11:11 PM Subject: RV10-List: Stunt Pilot Poem My son wrote this for an English assignment the other night in my shop while I was pounding rivets into my bottom left wing. I thought you all might like it. Dave Leikam 40496 ________________________________________________________________________________
Subject: Gear Leg Fairing
Date: Jan 10, 2008
I'm working on the gear leg fairing hinge that holds the trailing edge together. The plans indicate that the rivets shouldn't be completely set because it might crack the thin fiberglass material. I suppose that this would leave a small protrusion above the surface. Has anyone used the oops rivets here? They are larger diameter (1/8") but have a smaller head and might not protrude. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jan 10, 2008
I think what they mean is to not flair the shop head as much. The countersunk hole is the same and the rivets should be flush...just don't squeeze them as much. Rene' Felker N423CF 40322 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, January 10, 2008 9:15 AM Subject: RV10-List: Gear Leg Fairing I'm working on the gear leg fairing hinge that holds the trailing edge together. The plans indicate that the rivets shouldn't be completely set because it might crack the thin fiberglass material. I suppose that this would leave a small protrusion above the surface. Has anyone used the oops rivets here? They are larger diameter (1/8") but have a smaller head and might not protrude. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jan 10, 2008
Subject: Re: Gear Leg Fairing
Al, whatever rivets you use, consider adding a strip of fiberglass tape to cover the rivet heads. It will keep them from 'working' later on and messing up your paint job. After you prime and sand w/ some primer/filler (Smoothprime) it will look glass smooth. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Albert Gardner wrote: > *Im working on the gear leg fairing hinge that holds the trailing edge * > *together. The plans indicate that the rivets shouldnt be completely set * > *because it might crack the thin fiberglass material. I suppose that this * > *would leave a small protrusion above the surface. Has anyone used the * > *oops rivets here? They are larger diameter (1/8) but have a smaller * > *head and might not protrude.* > *Albert Gardner* > *Yuma**, **AZ* > * > * ________________________________________________________________________________
Date: Jan 10, 2008
Albert: I have an rv6a I do mnot know if the fairing is very much different, but I used the regular rivets, if I recall were the A3-4? they are small.. JUst set them carefully, with enough preasure to get a smooth surface. I did not have any problem with them. The imprtant thing is to have a good quality set of, rivets set heads? ( I got mine from Avery) Adjust the rivet Squezer so that would not crush the fiber glass. Really it is easier than you think. I would not use pop rivets, they do not have the strengh under the stress and tension, if that is the case... also they will never look as good... Hope this will help you Bertrv6sa donot archive On 1/10/08, Albert Gardner wrote: > > I'm working on the gear leg fairing hinge that holds the trailing edge > together. The plans indicate that the rivets shouldn't be completely set > because it might crack the thin fiberglass material. I suppose that this > would leave a small protrusion above the surface. Has anyone used the > oops rivets here? They are larger diameter (1/8") but have a smaller > head and might not protrude. > Albert Gardner > Yuma, AZ > > > - The RV10-List Email Forum - > to browse > Archive Search & Download, 7-Day Browse, Chat, FAQ, > much more: > http://www.matronics.com/Navigator?RV10-List > - MATRONICS WEB FORUMS - > Forums! > http://forums.matronics.com > - List Contribution Web Site - > -Matt Dralle, List Admin. > http://www.matronics.com/contribution > ________________________________________________________________________________
Date: Jan 10, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Albert; I did the gear fairings last week. I used the 3.5 rivets. Standard. I had read the note in the plans and used just a gentle squeeze with the hand squeezer. Had the countersink enough to have the rivet head flush. Went well. I did not hear any fiberglass cracking or see any problems. Dr Fred. Albert Gardner wrote: > *Im working on the gear leg fairing hinge that holds the trailing edge * > *together. The plans indicate that the rivets shouldnt be completely set * > *because it might crack the thin fiberglass material. I suppose that this * > *would leave a small protrusion above the surface. Has anyone used the * > *oops rivets here? They are larger diameter (1/8) but have a smaller * > *head and might not protrude.* > *Albert Gardner* > *Yuma**, **AZ* > * * > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Jan 10, 2008
Dave, Great poem and a refreshing sign of an inspired future aviator (if not one already) compared to the Fences posts. If he writes another acro poem with a more positive ending (ie on maneuvering, cloud dancing, whatever), please post that as well. It was a very well done and by no means am I indicating anything negative about the poem, I'd just like to inspire more along the same theme. Marcus 40286 - Former Skybolt builder/flyer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Wednesday, January 09, 2008 11:12 PM Subject: RV10-List: Stunt Pilot Poem My son wrote this for an English assignment the other night in my shop while I was pounding rivets into my bottom left wing. I thought you all might like it. Dave Leikam 40496 ________________________________________________________________________________
Date: Jan 10, 2008
Just completing a Conditional on a nine year old RV-6A. By the way, the Lycosaurus is an O-360 modified for IO service and over 900 hours of joyous almost maintenance free operations. Compressions were all 80/80 and one was 79/80. One half of the AD426D-3-3.5 rivets have pulled through the glass on the leg fairings. This is the piano hinge retainer on the trailing edge. Integrity of the glass was compromised by hydro-carbon pollution which was to be anticipated. The discovery was part of the SB pursuit and solution on the Nose Wheel Fork. For the RV-10, you guys are still seven years from discovery that the small countersunk head cannot be retained by just the fiberglass under normal vibration forces. For What Its Worth I recommend an epoxy to metal piano hinge fastening process, backed up by the rivets. Be sure and leave adequate clearance between contact with the lower engine cowl and the fairing. The fairing lost all of its outer epoxy and half the glass to the chafing with the lower cowl. John Cox - #40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Thursday, January 10, 2008 9:27 AM Subject: Re: RV10-List: Gear Leg Fairing Albert; I did the gear fairings last week. I used the 3.5 rivets. Standard. I had read the note in the plans and used just a gentle squeeze with the hand squeezer. Had the countersink enough to have the rivet head flush. Went well. I did not hear any fiberglass cracking or see any problems. Dr Fred. Albert Gardner wrote: > *I'm working on the gear leg fairing hinge that holds the trailing edge * > *together. The plans indicate that the rivets shouldn't be completely set * > *because it might crack the thin fiberglass material. I suppose that this * > *would leave a small protrusion above the surface. Has anyone used the * > *oops rivets here? They are larger diameter (1/8") but have a smaller * > *head and might not protrude.* > *Albert Gardner* > *Yuma**, **AZ* > * * > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Date: Jan 11, 2008
Put a layer of glass between the hinge and the fairing hold with clecos till it cures then put your rivets in and squeeze as much as you like. We did this with our 6 after many other builder with great results Chris ----- Original Message ----- From: Albert Gardner To: rv10-list(at)matronics.com Sent: Friday, January 11, 2008 3:14 AM Subject: RV10-List: Gear Leg Fairing I'm working on the gear leg fairing hinge that holds the trailing edge together. The plans indicate that the rivets shouldn't be completely set because it might crack the thin fiberglass material. I suppose that this would leave a small protrusion above the surface. Has anyone used the oops rivets here? They are larger diameter (1/8") but have a smaller head and might not protrude.Albert GardnerYuma, AZ ________________________________________________________________________________
Date: Jan 10, 2008
I didn't do this on the leg fairings, but I did do it on the cowl hinges and that was to apply Pro-seal between the hinge and the fiberglass and then rivet. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chris and Susie McGough wrote: > Put a layer of glass between the hinge and the fairing hold with > clecos till it cures then put your rivets in and squeeze as much as > you like. > We did this with our 6 after many other builder with great results > Chris > > ----- Original Message ----- > *From:* Albert Gardner > *To:* rv10-list(at)matronics.com > *Sent:* Friday, January 11, 2008 3:14 AM > *Subject:* RV10-List: Gear Leg Fairing > > *Im working on the gear leg fairing hinge that holds the trailing edge * > > *together. The plans indicate that the rivets shouldnt be completely set * > > *because it might crack the thin fiberglass material. I suppose that this * > > *would leave a small protrusion above the surface. Has anyone used the * > > *oops rivets here? They are larger diameter (1/8) but have a smaller * > > *head and might not protrude.* > > *Albert Gardner* > > *Yuma**, **AZ* > > * * > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Subject: GNS430 Mounting Tray
Date: Jan 10, 2008
I was quoted a price of $50 for the tray from Pacific Coast Avionics last month. Vern Smith (#324 Doors) > From: mike(at)learningplanet.com> To: rv10-list(at)matronics.com> Subject: RV10 -List: GNS430 Mounting Tray> Date: Thu, 10 Jan 2008 11:42:28 -0600> > --> R V10-List message posted by: Michael Schipper > > H i Guys,> > Does anyone know where I can find just the mounting kit for a Ga rmin > 430? I am hoping I can find one and install it in anticipation of > someday adding the 430.> > If anyone has an extra, or if you know of a sour ce, it would be > greatly appreciated.> > Regards,> Mike Schipper> #40576 - =============> > > _________________________________________________________________ Make distant family not so distant with Windows Vista=AE + Windows Live=99. http://www.microsoft.com/windows/digitallife/keepintouch.mspx?ocid=TXT_TA GLM_CPC_VideoChat_distantfamily_012008 ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Re: GNS430 Mounting Tray
Date: Jan 10, 2008
Thanks to all who responded to my question. After a call to Pacific Coast Avionics, I have a tray, backplate, and connector kit on order. The tray itself is only $35, but the backplate and connector kit adds another $200 or so. Regards, Mike Schipper #40576 - Fuse - www.rvten.com On Jan 10, 2008, at 4:54 PM, Vernon Smith wrote: > I was quoted a price of $50 for the tray from Pacific Coast > Avionics last month. > > Vern Smith (#324 Doors) > > > > From: mike(at)learningplanet.com > > To: rv10-list(at)matronics.com > > Subject: RV10-List: GNS430 Mounting Tray > > Date: Thu, 10 Jan 2008 11:42:28 -0600 > > > > > > > Hi Guys, > > > > Does anyone know where I can find just the mounting kit for a Garmin > > 430? I am hoping I can find one and install it in anticipation of > > someday adding the 430. > > > > If anyone has an extra, or if you know of a source, it would be > > greatly appreciated. > > > > Regards, > > Mike Schipper > > #40576 - Fuse - www.========== > > > > > > > > > Make distant family not so distant with Windows Vista=AE + Windows > Live=99. Start now! > > ________________________________________________________________________________
From: "Jon Reining" <jonathan.w.reining(at)wellsfargo.com>
Date: Jan 10, 2008
Great class. One of the best parts was meeting other builders and sharing stories. The Mexican food was a bonus. There should now be three completed RV10s on the field - all worth seeing. Hmmm... Perhaps if there's VFR weather it might be time for the $100 burrito run in the Citabria to meet some of you guys during the lunch break. Jon Reining 40514 (along with dad, Bill) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157341#157341 ________________________________________________________________________________
Subject: Plexiglass cleaner
Date: Jan 10, 2008
I know this has been discussed before, but I had left the plastic covering on my windows for protection. I am now ready to remove the plastic, but I know it will leave the sticky glue on the plexiglass. What was the best cleaner to remove the glue. Thanks in advance. Greg Hale www.nwacaptain.com -------- Greg Hale rv8/rv10 www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157343#157343 ________________________________________________________________________________
Date: Jan 10, 2008
I would like to attend as well, but their web site doesn't show the class - is it full? I assume it's the 26 & 27 of January. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157345#157345 ________________________________________________________________________________
Date: Jan 10, 2008
Subject: Re: Plexiglass cleaner
The stuff on the windshield won't leave a residue, but, you can clean it with Kerosene. Tim Olson - RV-10 N104CD - Flying greghale wrote: > > I know this has been discussed before, but I had left the plastic covering on my windows for protection. I am now ready to remove the plastic, but I know it will leave the sticky glue on the plexiglass. What was the best cleaner to remove the glue. > > Thanks in advance. > Greg Hale > www.nwacaptain.com > > -------- > Greg Hale rv8/rv10 > www.nwacaptain.com > > ________________________________________________________________________________
Date: Jan 10, 2008
When I pulled the plastic off the windows were the cleanest they've ever been; I don't remember anything left from the plastic covering. I have had to wash them since then. I use Plexus (from Aircraft Spruce) and a micro-fiber cloth (from the aviation department at Walmart). I seem to remember an extensive thread regarding the different solvents people are using on the plexiglass. I personally have never used anything but water and plexus on the windows. -Jim N312JE Jim "Scooter" McGrew _http://www.mit.edu/~jsmcgrew In a message dated 1/10/2008 8:04:23 P.M. Eastern Standard Time, ghale5224(at)aol.com writes: --> RV10-List message posted by: "greghale" I know this has been discussed before, but I had left the plastic covering on my windows for protection. I am now ready to remove the plastic, but I know it will leave the sticky glue on the plexiglass. What was the best cleaner to remove the glue. Thanks in advance. Greg Hale www.nwacaptain.com -------- Greg Hale rv8/rv10 www.nwacaptain.com _ (http://www.mit.edu/~jsmcgrew) **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 10, 2008
Thanks Tim and Jim. Greg Hale www.nwacaptain.com -------- Greg Hale rv8/rv10 www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157355#157355 ________________________________________________________________________________
Date: Jan 10, 2008
Thanks for the suggestions. It sure looks better with the pants and fairings on. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jan 10, 2008
Great, thank you guys! Did I mention this before...I love this forum. Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157410#157410 ________________________________________________________________________________
Subject: Any suggestion where to by avionics apart from Steinair
Date: Jan 10, 2008
Hi, I am trying to get an off from Steinair since last year September. I wrote 4 emails. I talked to Stein directly and still have no offer. I had such great experience with him when I purchased the AP servos and the harness. I can't understand what happened. Thats my shopping list: - Audio panel PS Engineering PMS9000B - Garmin 430 - Garmin SL30 - Garmin 328 (XPDR for Europe) - Trutrak APRV10 (I purchased the Servos already from you) Backup instruments (2 1/4) Altimeter, Speed Indicator, Trutrak ADI (2 1/4) Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157411#157411 ________________________________________________________________________________
Date: Jan 11, 2008
Here is where Stein sent me to get my radios, etc. http://www.starkavionics.com/ Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Wellenzohn Sent: Friday, January 11, 2008 12:39 AM Subject: RV10-List: Any suggestion where to by avionics apart from Steinair Hi, I am trying to get an off from Steinair since last year September. I wrote 4 emails. I talked to Stein directly and still have no offer. I had such great experience with him when I purchased the AP servos and the harness. I can't understand what happened. Thats my shopping list: - Audio panel PS Engineering PMS9000B - Garmin 430 - Garmin SL30 - Garmin 328 (XPDR for Europe) - Trutrak APRV10 (I purchased the Servos already from you) Backup instruments (2 1/4) Altimeter, Speed Indicator, Trutrak ADI (2 1/4) Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157411#157411 ________________________________________________________________________________
Date: Jan 11, 2008
Subject: Re: Any suggestion where to by avionics apart from Steinair
I have had an excellent experience with Eastern Avionics. I purchased my Bendix-King KT-76 (reconditioned), Garmin SL-30, GPS400, GMA340 and an ICOM handheld from them. The service was excellent and fast; always responsive to emails. The wiring was done correctly and exactly as I specified. They have also made warrantee service on my SL-30 very easy. I have no affiliation with them, I've just been very satisfied with the level of service. The website is: _http://www.avionix.com/_ (http://www.avionix.com/) I've been dealing with Ron: _ronald(at)avionix.com_ (mailto:ronald(at)avionix.com) -Jim N312JE (http://www.mit.edu/~jsmcgrew) In a message dated 1/11/2008 2:42:50 A.M. Eastern Standard Time, rv-10(at)wellenzohn.net writes: --> RV10-List message posted by: "Michael Wellenzohn" Hi, I am trying to get an off from Steinair since last year September. I wrote 4 emails. I talked to Stein directly and still have no offer. I had such great experience with him when I purchased the AP servos and the harness. I can't understand what happened. Thats my shopping list: - Audio panel PS Engineering PMS9000B - Garmin 430 - Garmin SL30 - Garmin 328 (XPDR for Europe) - Trutrak APRV10 (I purchased the Servos already from you) Backup instruments (2 1/4) Altimeter, Speed Indicator, Trutrak ADI (2 1/4) Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157411#157411 **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 11, 2008
I had a great experience with Tony at Accuracy Avionics....Give him a call. Nothing but a good product and experience. Rick S. 40185 ----- Original Message ----- From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net> Sent: Thursday, January 10, 2008 11:38:51 PM (GMT-0800) America/Los_Angeles Subject: RV10-List: Any suggestion where to by avionics apart from Steinair Hi, I am trying to get an off from Steinair since last year September. I wrote 4 emails. I talked to Stein directly and still have no offer. I had such great experience with him when I purchased the AP servos and the harness. I can't understand what happened. Thats my shopping list: - Audio panel PS Engineering PMS9000B - Garmin 430 - Garmin SL30 - Garmin 328 (XPDR for Europe) - Trutrak APRV10 (I purchased the Servos already from you) Backup instruments (2 1/4) Altimeter, Speed Indicator, Trutrak ADI (2 1/4) Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157411#157411 ________________________________________________________________________________
Date: Jan 11, 2008
OK, I've signed up as well. Flying into SJC, renting a car, staying at the Comfort Inn. Looking forward to seeing everyone. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157461#157461 ________________________________________________________________________________
Date: Jan 11, 2008
By my count, we now have 8 builders that have spoken up here that are going. Sounds like its going to be a real party [Laughing] John, when you signed up, did they say how many are now on the list. I was told that the max they could handle was 15 and a min to make the class was 5 which they had when I signed up. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157472#157472 ________________________________________________________________________________
Date: Jan 11, 2008
Thank you all for the advice. Michael -------- RV-10 builder (fuselage) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157479#157479 ________________________________________________________________________________
Date: Jan 11, 2008
As of this morning, we have 8 firm deposits, 4 promises, and a couple more interested. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman Sent: Friday, January 11, 2008 9:23 AM Subject: RV10-List: Re: Fiberglass class in Watsonville with RV10 focus By my count, we now have 8 builders that have spoken up here that are going. Sounds like its going to be a real party [Laughing] John, when you signed up, did they say how many are now on the list. I was told that the max they could handle was 15 and a min to make the class was 5 which they had when I signed up. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157472#157472 ________________________________________________________________________________
Date: Jan 11, 2008
Guy, I just signed up for the class. My travel plans are to come into Oakland at 12:05 pm Friday and my flight leaves at 3:50 pm on Sunday. I have a rental if anyone needs a ride. Dave Syvertson 40625 QB fuselage _dsyvert(at)aol.com_ (mailto:dsyvert(at)aol.com) do not archieve **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 11, 2008
I have Aerotronics in Billings Montana doing my panel VP-200 GMA340 Audio Panel SL30 Garmin 430 GPS GTX327 Dual Chelton EFIS Trutrak Sorcerer Autopilot EIS 6000 engine monitor D-10A (Backup) ELT - 406 CO2 detector AOA - Sport Infinity Grips Gary Wirrel is great - I even have his cell phone. Jason and Issac are putting the panel together and the wiring is so clean. They don't hide the back of their panels like you see from other shops they want you to see how much effort they put into making everything just right. The phone number is 406-259-5006 Pricing was a little less than Stein quoated me. Just like you I had a hard time getting response back from Steinair. Charles Usery RV-10 Finish Kit N719PD Reserved --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Jan 11, 2008
> John, when you signed up, did they say how many are now on the list. I was told that the max they could handle was 15 and a min to make the class was 5 which they had when I signed up. He didn't say but I'm getting the impression there are about 8 to 10 of us. John -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157557#157557 ________________________________________________________________________________
Date: Jan 12, 2008
Hey Tim, Our finishing kit is supposed to be shipped on Mon. and when we're actually at that stage I'm sure I'll understand your comments about sealing in the ramps better. In the meantime, I went back and surfed through your site to see if I could find a picture. The only one I found so far is just after you fitted the cowl and trimmed around the governor. Any chance you have close ups of the sealing? Also, I ran across a reference to your adding toner to the fiberglass on the windshield to aluminum bond. I'll try to retrace to that stage to see what that's about, or maybe that's in the finish kit too. I'll also search your site for "bondo" ... I have many years experience with cars -- (first plane!) is there a reason why folks don't just use a thin skim coat of bondo over these fiberglass joints to smooth them up? It's so easy, there must be SOMETHING wrong with it! Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157613#157613 ________________________________________________________________________________
Date: Jan 12, 2008
poneill(at)irealms.com wrote: > Are you sure Deems? It might be a good opportunity to pick up some ideas > for your antenna pylon attach. But too bad you're so far ahead of us! > -- That's no reason to stay away. I'd buy his lunch just to hear about his overhead console attachment. [Mr. Green] I will be doing that someday. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157644#157644 ________________________________________________________________________________
Subject: Seat Belts
Date: Jan 12, 2008
This should be an easy one.... Do most of you just get your belts from Van's, or is there a better option? -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157654#157654 ________________________________________________________________________________
Date: Jan 12, 2008
Subject: Re: Seat Belts
Might want to consider Hooker... P **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 12, 2008
I'm not sure how the percentages shake out, but I know that there are many Van's belts, many Hooker Harness Belts, and even some inertial reel belts that are going in RV-10's. Hooker has many colors, and I picked those for mine. Tim Olson - RV-10 N104CD - Flying partner14 wrote: > > > This should be an easy one.... Do most of you just get your belts > from Van's, or is there a better option? > > -------- Don A. McDonald 40636 > ________________________________________________________________________________
Subject: Seat Belts
Date: Jan 12, 2008
This is what I used.......I am not flying yet.....but getting close. Rene' 40322 N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of partner14 Sent: Saturday, January 12, 2008 11:54 AM Subject: RV10-List: Seat Belts This should be an easy one.... Do most of you just get your belts from Van's, or is there a better option? -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157654#157654 ________________________________________________________________________________
Subject: Seat Belts
Date: Jan 12, 2008
Forgot to add the link..... http://www.inertialbelts.com/ Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Saturday, January 12, 2008 6:00 PM Subject: RE: RV10-List: Seat Belts This is what I used.......I am not flying yet.....but getting close. Rene' 40322 N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of partner14 Sent: Saturday, January 12, 2008 11:54 AM Subject: RV10-List: Seat Belts This should be an easy one.... Do most of you just get your belts from Van's, or is there a better option? -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157654#157654 ________________________________________________________________________________
Subject: Seat Belts
Date: Jan 12, 2008
Rene. Did you send a picture? Perhaps you could send me a picture offlist. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Saturday, January 12, 2008 6:00 PM Subject: RE: RV10-List: Seat Belts This is what I used.......I am not flying yet.....but getting close. Rene' 40322 N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of partner14 Sent: Saturday, January 12, 2008 11:54 AM Subject: RV10-List: Seat Belts --> This should be an easy one.... Do most of you just get your belts from Van's, or is there a better option? -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157654#157654 ________________________________________________________________________________
Subject: F-1099F-L
Date: Jan 12, 2008
. The top flange is .2 inches high when clecoed in place. This part came with the QB fuselage #8 of March 2005. When we queried Vans, they concur that the bend line for the part was wrong. They are sending a new part. while waiting I borrowed a replacement part from another builder on my field and the part fits properly. after installing the F-1099F-L, the F-1099E-L and F1099H-L looked wrong; we replaced them all, including the F-1099G-L and they now fit properly. If you are fitting the wing fairings and get a fit like we did you may have a bad set of fairing parts. In addition Van's aircraft has a single screw in F-1099G-L and -R even though the plans don't show a need for one there. One other thing, the picture as shown in 44-2 figure ! does not match the view of the part; the second part we received works correctly so we assume the drawing is in error. ________________________________________________________________________________
Subject: Baggage door seal
Date: Jan 13, 2008
I know the question has been asked before, but a search did not produce any answers. What door seal works with the baggage door. I got some from Lowes but it is too thick and McMaster doesn't show any the right size. Suggestions from all you flying guys? Gary 40274 ________________________________________________________________________________
Date: Jan 13, 2008
Subject: Re: Baggage door seal
I ended up using some that I purchased at Home Depot. I initially bought a roll of door seal that was the gray colored foam with a rectangular cross section. I bought the thinnest one available and it just wouldn't work becau se it was to thick. I found a different style that worked perfectly on an adjacent shelf at Hom e Depot: the box is out at the hangar so I can't give you a brand/model name right now, but it is made of extremely soft tan colored foam that squishes flat very well. Also the cross section has 3 ridges (it kind of looks like this: /\/\/\ ), so there isn't as much material to begin with. As far as my passengers can tell (I've never ridden back there) it is sealed perfectly a nd allows for easy opening and closing of the door. -Jim N312JE _ In a message dated 1/13/2008 7:46:09 A.M. Eastern Standard Time, speckter(at)comcast.net writes: I know the question has been asked before, but a search did not produce any answers. What door seal works with the baggage door. I got some from Lowe s but it is too thick and McMaster doesn=99t show any the right size. Suggestions from all you flying guys? Gary 40274 _ (http://www.mit.edu/~jsmcgrew) **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 13, 2008
Check out the seals from Brown Aircraft. They have a good assortment. www.brownaircraft.com JF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157799#157799 ________________________________________________________________________________
Date: Jan 13, 2008
I'll also search your site for "bondo" ... I have many years experience with cars -- (first plane!) is there a reason why folks don't just use a thin skim coat of bondo over these fiberglass joints to smooth them up? It's so easy, there must be SOMETHING wrong with it! weight! using microballoons and epoxy weighs less. Pascal ----- Original Message ----- From: "Lew Gallagher" <lewgall(at)charter.net> Sent: Saturday, January 12, 2008 6:37 AM Subject: RV10-List: Re: Cutting front baffll CB-1001a > > Hey Tim, > > Our finishing kit is supposed to be shipped on Mon. and when we're > actually at that stage I'm sure I'll understand your comments about > sealing in the ramps better. In the meantime, I went back and surfed > through your site to see if I could find a picture. The only one I found > so far is just after you fitted the cowl and trimmed around the governor. > Any chance you have close ups of the sealing? > > Also, I ran across a reference to your adding toner to the fiberglass on > the windshield to aluminum bond. I'll try to retrace to that stage to see > what that's about, or maybe that's in the finish kit too. > > I'll also search your site for "bondo" ... I have many years experience > with cars -- (first plane!) is there a reason why folks don't just use a > thin skim coat of bondo over these fiberglass joints to smooth them up? > It's so easy, there must be SOMETHING wrong with it! > > Later, - Lew > > -------- > non-pilot > crazy about building > waiting on RV-10 finishing kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=157613#157613 > > > ________________________________________________________________________________
Date: Jan 13, 2008
Subject: Flap position indicator
Hello all, I'm currently installing the ACS AF 2500 engine monitor, for the flap position indicator the manual says, "any 5K potentiometer" will give a measurement. Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybody who did this already? If yes I would like some pictures, no pictures found in the archives. Thanks for the help, RV10 40355 Henkjan van der Zouw ZME v.o.f. Rijksstraatweg 28 3545NA Utrecht Netherlands tel. ..31 30 6665443 mob. ..31 653235372 fax. ..31 30 6664659 www.zme.nl ________________________________________________________________________________
Subject: Gear and Nose Leg Fairings TE closure
Date: Jan 13, 2008
There was no response to the subject, but I will close out the issue of fiberglass failure of attachment rivets with an alternate product for consideration. The rivets won out - forcing a repair. The plastic airplane boys have given consideration to John Barrett of Barrett/Garrett Enterprises and their composite hinge attached by Hysol composite adhesive to the composite (fiberglass) fairing. A novel solution to dissimilar products attached by adhesive rather than solely metal rivets. On the RV-10 a few newer design features have been added to reduce the occurrence but the vibration is still working on it. Here is the website and information. No indication of failure should be visible for several years down the road. We are affecting the repair today on a 1999 RV built aircraft. John Barrett, CEO Barrett/Garrett Enterprises, Inc. PO Box 428 Port Hadlock, WA 98339 www.carbinge.com John Barrett [2thman(at)cablespeed.com] He is a Doctor of Dentistry just like John Gonzales for a primary occupation but is a wealth of knowledge on plastic aircraft components and use of automotive engines with PSRUs on the front end for safe aircraft operations. John Cox (with no business affiliation) #40600 ________________________________________________________________________________
Date: Jan 13, 2008
Subject: Re: Flap position indicator
Pictures of my POS-12 switch install are posted to this thread: _http://forums.matronics.com/viewtopic.php?t=31209_ (http://forums.matronics.com/viewtopic.php?t=31209) -Jim N312JE In a message dated 1/13/2008 1:35:36 P.M. Eastern Standard Time, henkjan(at)zme.nl writes: Hello all, I=99m currently installing the ACS AF 2500 engine monitor, for the fl ap position indicator the manual says, =9Cany 5K potentiometer=9D will give a measurement. Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybody who did this already? If yes I would like some pictures, no picture s found in the archives. Thanks for the help, RV10 40355 Henkjan van der Zouw ZME v.o.f. Rijksstraatweg 28 3545NA Utrecht Netherlands tel. ..31 30 6665443 mob. ..31 653235372 fax. ..31 30 6664659 _www.zme.nl_ (http://www.zme.nl/) **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Subject: Re: Dropped the flaps
Date: Jan 13, 2008
Hey John, I liked your idea of getting parts UP out of the way, so today I hung my RV-10 tail feathers with strapping material. I just rolled each end about 5 layers and ran a sheetrock screw through it into a ceiling joist. This will be my tail section, but for now we're working on my friend's RV-10. After I finish the '33 Ford streetrod and get it out of the way, that space becomes a paint booth and I'll paint his section by section. And THEN I'll get back to mine! What did you ever do about your dent? As soft and thin as this aluminum is, I was curious if you tried the suction puller. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157870#157870 Attachments: http://forums.matronics.com//files/hung_medium_299.jpg ________________________________________________________________________________
Subject: Paint Pix
Date: Jan 13, 2008
I have a few Pix of my new paint Job. Enjoy Gary 40274 ________________________________________________________________________________
Subject: Cabin door half alignment
Date: Jan 13, 2008
I was wondering if any one has had a problem with clecoing the cabin door shells together with the 4 alignment holes at each corner of the window cut out. If I cleco the bottom corners the top corners miss by about a 1/4 inch. (see photo) They seem to almost line up fore and aft but are 1/4 inch off up and down. I tried clamping from the bottom of the window cut out moving up thinking that it might be a tight fit and all but that didn't work either. I could cleco the fore and aft door to fuselage alignment holes woth no problem too. I have the pink colored finish kit doors and cowling if that makes a difference. Thanks in advance fro replies to the greatest list in RV world. Chris Lucas 40072 Finish and Panel ________________________________________________________________________________
Subject: Re: Paint Pix
Date: Jan 13, 2008
Hey Gary, Looks like a Bulldawg to me! Outstanding! Did you paint it yourself? Can you share some details? i.e. brand names: self-ecth primer, primer, basecoat clearcoat urethane/acrylic enamel, taped stripes, etc.? Later, - Lew (Greenville, SC) -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157886#157886 ________________________________________________________________________________
Date: Jan 13, 2008
Lew, I haven't tried to remove the dent yet. I left the flaps hanging from the ceiling for now. I'll probably get a good auto body repair guy to come take a look in the next few months - a lot of car sheet metal nowadays is aluminum. My big problem is that I've committed to polishing, so it's sort of obvious. The dent is so small that I'm worried that suction will do more harm than good. I quit flogging myself and I've moved on to building. Currently riveting the last bottom skin on the left wing. It would be easy except that the skin fits over a flap hinge that prohibits easy access. The joys of building.... John Lew Gallagher wrote: > Hey John, > > I liked your idea of getting parts UP out of the way, so today I hung my RV-10 tail feathers with strapping material. I just rolled each end about 5 layers and ran a sheetrock screw through it into a ceiling joist. > > This will be my tail section, but for now we're working on my friend's RV-10. After I finish the '33 Ford streetrod and get it out of the way, that space becomes a paint booth and I'll paint his section by section. And THEN I'll get back to mine! > > What did you ever do about your dent? As soft and thin as this aluminum is, I was curious if you tried the suction puller. > > Later, - Lew -------- #40572 QB Wings, QB Fuse arrived N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157900#157900 ________________________________________________________________________________
Subject: wing tips
Date: Jan 13, 2008
I am ready to dimple the wing skins for the #6 screws that will hold the wi ng tips on. What did people do to place the dimples in the wing skin. It se ems that there is not enough space to allow the dimple die to get at the ho le in the skin without the side of the die hitting up against the web of th e ribs. I even ground down female of my #6 die all the way to the dimple an d it still isn't completely lining up with the hole. So what have others used to place these dimples in the skin??? Thanks, JOhn G. 409 ________________________________________________________________________________
Subject: Re: Wingtip lens
Date: Jan 13, 2008
Thanks Deems and Dave, I've added two countersunk screws/nut plates on each lens (top and bottom toward the leading edge (5" and 4.5" from corner) with no problems, and that seems much tighter. My pilot (I'm the builder) has NO intentions of getting upside down in the RV-10 -- I just wondered if anybody else had heard about the cracks in the 6 windshield/aluminum bond, and thought that now would be the time to consider beefing it up. We may still consider putting a 12' or so strip in the center. Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157930#157930 ________________________________________________________________________________
Date: Jan 14, 2008
Whoops, my mistake, I thought you could see the POS-12 in those posted pictures. Here are some photos of my POS-12 installation. I attached it to t he inside of the tunnel near the flap actuator using blind rivets. I made a connection using model airplane a threaded pushrod with a z-bend at one end an a brass clevis at the other. I had to measure carefully/experiment a bit to s elect the appropriate attachment points and mounting angle to get the right throw and to avoid binding. -Jim N312JE In a message dated 1/13/2008 6:00:18 P.M. Eastern Standard Time, JSMcGrew(at)aol.com writes: Pictures of my POS-12 switch install are posted to this thread: _http://forums.matronics.com/viewtopic.php?t=31209_ (http://forums.matronics.com/viewtopic.php?t=31209) -Jim N312JE In a message dated 1/13/2008 1:35:36 P.M. Eastern Standard Time, henkjan(at)zme.nl writes: Hello all, I=99m currently installing the ACS AF 2500 engine monitor, for the fl ap position indicator the manual says, =9Cany 5K potentiometer=9D will give a measurement. Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybody who did this already? If yes I would like some pictures, no picture s found in the archives. Thanks for the help, RV10 40355 Henkjan van der Zouw ZME v.o.f. Rijksstraatweg 28 3545NA Utrecht Netherlands tel. ..31 30 6665443 mob. ..31 653235372 fax. ..31 30 6664659 _www.zme.nl_ (http://www.zme.nl/) ____________________________________ Start the year off right. _Easy ways to stay in shape_ (http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489) i n the new year. (http://www.matronics.com/Navigator?RV10-List) (http://www.matronics.com/contribution) **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 14, 2008
Thank you!, I had the same idea, now I know I'm on the right track. Thanks again. Henkjan -----Oorspronkelijk bericht----- Van: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Namens JSMcGrew(at)aol.com Verzonden: maandag 14 januari 2008 7:45 Aan: rv10-list(at)matronics.com Onderwerp: Re: RV10-List: Flap position indicator Whoops, my mistake, I thought you could see the POS-12 in those posted pictures. Here are some photos of my POS-12 installation. I attached it to the inside of the tunnel near the flap actuator using blind rivets. I made a connection using model airplane a threaded pushrod with a z-bend at one end an a brass clevis at the other. I had to measure carefully/experiment a bit to select the appropriate attachment points and mounting angle to get the right throw and to avoid binding. -Jim N312JE In a message dated 1/13/2008 6:00:18 P.M. Eastern Standard Time, JSMcGrew(at)aol.com writes: Pictures of my POS-12 switch install are posted to this thread: http://forums.matronics.com/viewtopic.php?t=31209 -Jim N312JE In a message dated 1/13/2008 1:35:36 P.M. Eastern Standard Time, henkjan(at)zme.nl writes: Hello all, I'm currently installing the ACS AF 2500 engine monitor, for the flap position indicator the manual says, "any 5K potentiometer" will give a measurement. Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybody who did this already? If yes I would like some pictures, no pictures found in the archives. Thanks for the help, RV10 40355 Henkjan van der Zouw ZME v.o.f. Rijksstraatweg 28 3545NA Utrecht Netherlands tel. ..31 30 6665443 mob. ..31 653235372 fax. ..31 30 6664659 www.zme.nl <http://www.zme.nl/> _____ Start the year off right. Easy <http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489> ways to stay in shape in the new year. ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List .matronics.com/">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution _____ Start the year off right. Easy <http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489> ways to stay in shape in the new year. ________________________________________________________________________________
Subject: Re: Cabin door half alignment
From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
Date: Jan 14, 2008
I had the same problem 10 days ago. Called vans to confirm the issue and just used the lower 4 holes, 2 in the window frame and 2 for alignment to the fuse. All looks good so far. I just finished the 8 hours of sanding and fitting to get the doors fit in the fuse, but they fit fine now. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157946#157946 ________________________________________________________________________________
Date: Jan 14, 2008
I am planning on putting a little fiberglass retainer clip on the leading e dge of the wing tip which the lense can slip under and then place the two r etainer screws in the corners. Using duct tape as a releasing agent over th e leading edge of the lens will prevent the resin from bonding to the lens. It is removed from the lens once the fabrication is complete. On a seperate issue, I noticed my right wing tip to be more than a quarter of an inch too long in chord length and it needed to be cut flush to the T. E. of the Aileron. The left one was not as bad. John G.> Subject: RV10-List: Re: Wingtip lens> From: lewgall(at)charter.net> D 10-List message posted by: "Lew Gallagher" > > Thanks Deems and Dave,> > I've added two countersunk screws/nut plates on each len s (top and bottom toward the leading edge (5" and 4.5" from corner) with no problems, and that seems much tighter.> > My pilot (I'm the builder) has N O intentions of getting upside down in the RV-10 -- I just wondered if anyb ody else had heard about the cracks in the 6 windshield/aluminum bond, and thought that now would be the time to consider beefing it up. We may still consider putting a 12' or so strip in the center.> > Later, - Lew> > ------ --> non-pilot> crazy about building> waiting on RV-10 finishing kit> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.php =========> > > ________________________________________________________________________________
Date: Jan 14, 2008
Been thinking about your first post on the TE closure. What would you think about using soft rivets and an adhesive such as Hysol to close this out? Vern Smith (#324 cabin doors & top) Subject: RV10-List: Gear and Nose Leg Fairings TE closureDate: Sun, 13 Jan There was no response to the subject, but I will close out the issue of fib erglass failure of attachment rivets with an alternate product for consider ation. The rivets won out ' forcing a repair. The plastic airplane boys have given consideration to John Barrett of Barre tt/Garrett Enterprises and their composite hinge attached by Hysol composit e adhesive to the composite (fiberglass) fairing. A novel solution to diss imilar products attached by adhesive rather than solely metal rivets. On t he RV-10 a few newer design features have been added to reduce the occurren ce but the vibration is still working on it. Here is the website and information. No indication of failure should be vi sible for several years down the road. We are affecting the repair today o n a 1999 RV built aircraft. John Barrett, CEOBarrett/Garrett Enterprises, Inc.PO Box 428Port Hadlock, W A 98339www.carbinge.com John Barrett [2thman(at)cablespeed.com] He is a Doctor of Dentistry just like John Gonzales for a primary occupatio n but is a wealth of knowledge on plastic aircraft components and use of au tomotive engines with PSRUs on the front end for safe aircraft operations. John Cox (with no business affiliation) #40600 _________________________________________________________________ Put your friends on the big screen with Windows Vista=AE + Windows Live=99. http://www.microsoft.com/windows/shop/specialoffers.mspx?ocid=TXT_TAGLM_C PC_MediaCtr_bigscreen_012008 ________________________________________________________________________________
Date: Jan 14, 2008
Try this... http://www.aviationtechproducts.com/html/accessories.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158003#158003 ________________________________________________________________________________
Date: Jan 14, 2008
I had the same issue. Just used the lower holes (they matched). There's a lot of material to cut off after gluing the halves together, so it shouldn't be a big issue if the fit isn't perfect on the top holes. Pretty rough stuff. What's with the pink glass? Mine are all green colored. Allergy related? I haven't had any issues with itching except after sanding wing tip glass w/ embedded fabric. This stuff works pretty well if you don't want to wear gloves all the time 12-15800 INVISIBLE GLOVE HAND PROTECTNT http://www.aircraftspruce.com/pdf/2008Individual/Cat08052.pdf Cheers, Jay Fiberglass interruptous while awaiting a replacement garage heater Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158006#158006 ________________________________________________________________________________
Date: Jan 14, 2008
I will evaluate the change in assemblage between the RV6 and the 10. Then weight mentally the advantage of a dimpled strip of aluminum skin to be placed over the original fairing and then finished with a BID of fiberglass. The vibration down the nose is the culprit and we are looking a building a whole new fairing after 900 hours. Will still use rivets with Hysol and a backup. John ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith Sent: Monday, January 14, 2008 7:44 AM Subject: RE: RV10-List: Gear and Nose Leg Fairings TE closure Been thinking about your first post on the TE closure. What would you think about using soft rivets and an adhesive such as Hysol to close this out? Vern Smith (#324 cabin doors & top) ________________________________ Subject: RV10-List: Gear and Nose Leg Fairings TE closure Date: Sun, 13 Jan 2008 12:32:52 -0800 From: johnwcox(at)pacificnw.com There was no response to the subject, but I will close out the issue of fiberglass failure of attachment rivets with an alternate product for consideration. The rivets won out - forcing a repair. The plastic airplane boys have given consideration to John Barrett of Barrett/Garrett Enterprises and their composite hinge attached by Hysol composite adhesive to the composite (fiberglass) fairing. A novel solution to dissimilar products attached by adhesive rather than solely metal rivets. On the RV-10 a few newer design features have been added to reduce the occurrence but the vibration is still working on it. Here is the website and information. No indication of failure should be visible for several years down the road. We are affecting the repair today on a 1999 RV built aircraft. John Barrett, CEO Barrett/Garrett Enterprises, Inc. PO Box 428 Port Hadlock, WA 98339 www.carbinge.com <http://www.carbinge.com/> John Barrett [2thman(at)cablespeed.com] He is a Doctor of Dentistry just like John Gonzales for a primary occupation but is a wealth of knowledge on plastic aircraft components and use of automotive engines with PSRUs on the front end for safe aircraft operations. John Cox (with no business affiliation) #40600 get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________ Put your friends on the big screen with Windows Vista(r) + Windows Live(tm). Start now! <http://www.microsoft.com/windows/shop/specialoffers.mspx?ocid=TXT_TAGL M _CPC_MediaCtr_bigscreen_012008> ________________________________________________________________________________
Date: Jan 14, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
_____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Henkjan van der Zouw Sent: Monday, January 14, 2008 3:25 AM Subject: RE: RV10-List: Flap position indicator Thank you!, I had the same idea, now I know I'm on the right track. Thanks again. Henkjan -----Oorspronkelijk bericht----- Van: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Namens JSMcGrew(at)aol.com Verzonden: maandag 14 januari 2008 7:45 Aan: rv10-list(at)matronics.com Onderwerp: Re: RV10-List: Flap position indicator Whoops, my mistake, I thought you could see the POS-12 in those posted pictures. Here are some photos of my POS-12 installation. I attached it to the inside of the tunnel near the flap actuator using blind rivets. I made a connection using model airplane a threaded pushrod with a z-bend at one end an a brass clevis at the other. I had to measure carefully/experiment a bit to select the appropriate attachment points and mounting angle to get the right throw and to avoid binding. -Jim N312JE In a message dated 1/13/2008 6:00:18 P.M. Eastern Standard Time, JSMcGrew(at)aol.com writes: Pictures of my POS-12 switch install are posted to this thread: http://forums.matronics.com/viewtopic.php?t=31209 -Jim N312JE In a message dated 1/13/2008 1:35:36 P.M. Eastern Standard Time, henkjan(at)zme.nl writes: Hello all, I'm currently installing the ACS AF 2500 engine monitor, for the flap position indicator the manual says, "any 5K potentiometer" will give a measurement. Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybody who did this already? If yes I would like some pictures, no pictures found in the archives. Thanks for the help, RV10 40355 Henkjan van der Zouw ZME v.o.f. Rijksstraatweg 28 3545NA Utrecht Netherlands tel. ..31 30 6665443 mob. ..31 653235372 fax. ..31 30 6664659 www.zme.nl <http://www.zme.nl/> _____ Start the year off right. Easy ways to stay in shape <http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489> in the new year. ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m /Navigator?RV10-List .matronics.com/">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution _____ Start the year off right. Easy ways to stay in shape <http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489> in the new year. ________________________________________________________________________________
Date: Jan 14, 2008
Here's a couple photos of our Ray Allen Pos 12 flap position sensor. We attached a tab/arm to the flap actuator bar/rod in the tunnel with a cla mp. The sensor is mounted on the tunnel side wall with a small bracket. A small rod with an threaded joint connects the arm/tab to the sensor. Eric RV-10, 40014 N104EP Date: Sun, 13 Jan 2008 19:40:34 +0100From: henkjan(at)zme.nlSubject: RV10-List : Flap position indicatorTo: rv10-list(at)matronics.com Hello all, I=92m currently installing the ACS AF 2500 engine monitor, for the flap pos ition indicator the manual says, =93any 5K potentiometer=94 will give a mea surement. Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybo dy who did this already? If yes I would like some pictures, no pictures fou nd in the archives. Thanks for the help, RV10 40355 Henkjan van der Zouw ZME v.o.f. Rijksstraatweg 28 3545NA Utrecht Netherlands tel. ..31 30 6665443 mob. ..31 653235372 fax. ..31 30 6664659 www.zme.nl /9j/4AAQSkZJRgABAAEASABIAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/AOmGc1xljwTSAXP+cUABJoARCdxoAdJcRwLmQ/TFNIluwRSrPEskZyrDIOKR RWuydwqkSyvmmAtABk0gFzQAUALzQAc0gF5oAKBi80gDJpgLzSAr3HUUgGMTgVSERt0oAiTdt5pg WLXJkFJjNZMgVIwy245Ax2pALzQAvNADZGKgYGeaAHKTigB2TQAEkUANV9wyP5UAOzQA0mgBofnb kZ+lMBSTQA00AMZsdaYhpNACZoAM0AJk0AHfNACHNADST2oAUE0wGcknPSkAuaAAGgBCTmgBMmmA i5AoAXNIBMmgBORQAhpgNOaAGnNIBhNAxppgNNIBKAEOaYgU4NICXmgBaADNABk0xiE4oArTMC3y nNJgIM9T1qQHDNOwDidopoRuY5pjHCkAtACGgBYxyTQA2e2Scgv26UASRxrGgVAAo6AUBcqXX+sq iSHFMQUAKKQwoAWgBaACkAUALigAoAXFAwpAV7j7w+lIBjdBVIQxuhpgRqOBQIsWg/eUmM1R0qRi 0AFAxaAExzQAo4oELigYhHNAC4oAMUAIRQA3aM5xzQAhFACGgCKRA3WmIAKAE6UAIRxQAiKVXGSa AFxgmgAoAjG7ccnjtQA7FADTgdeKAGs5DAKMjvQAtACZBoAR3CLkg0wCgANAB0HNABwRkdKAGnrQ AlADSKAIyOaAGmgBDSASgBDQAgHNAEw6UAFABQAUDK98jPZzIhKsVIBFF7AVbKDyIFUkkgc5pPUC zQgF+6KYETvk9aYjpCKQwFAC0AIaAFi6GgCSgBe1MRQuP9YaZJHTAKAFoAMUDFApAFAC0gFxQAUA GKACgBaAK0/3/wAKkBrCrAjboaBDV6UAWbMfPSYzUA4qRhQAYoGFAC0AIVJHHBoEETFlywwelAD6 BjSwUgHucUAFACGgBpznigAoARh6UwGEUCG4oAMUAJigBDQAGgBDTAQCkAYoAbtznPOe1ACbQO1M BD1oAAoGaAAigBMYoAMUAI3IxQAgAAwOlAAaAGsOKAI1XaMZzQAjUANakBGMjrQAp4oAQ9KAEU+o xigCYdKAFoASgBO1AyCRtxx2pAJSAMhRk1SEQyPk4pgOijzyelIDpD1oGLQAtADTQA+P7tAh9AAe lNAZ83+sNUSMAoAWgAoAWgBcUhhQAtABSAWgAoAKACgCtN/rDUgNfirQiNuVOKAGimBasvv0mNGm KgYtABQAUAB60DFFADV+Vip6HkUAPxigBGUHGexzQAEUAJTAbigBKBCGgBhoASgAoAbigAx6igBK AE9qAEPFAADQAUANxzQAmMUwFxQA3vQAvegAoEIRQAmMUAJQAwmgYhFADCKAGNQA00gDFACYoAOh 4oAkGcUALigCpql0bGyknVN5XGF9aqKApabeXN7H5swCKeiiiWgkXRWYxfrTQEMr5OBTAWKLPJ6U wJxyQvQUhm/jmmAooAKQCN0oAkQfKKBDqAEPSmhGdJ941QhAKAFxQAYoAWgApDFoAWgAxSAUUAFA BQAUAVJR+9NICK7h85VXcV2nPFWhDVTy49uc4oAMUAW7L79SxmmKkYUAFABQMXFACigBkgy656HI oAPLbIw5x7ilYB2OaYC4pgJQA00ANoAG6elAhhpgMTJHNAC0gCgBKAEoATFMANADec9OKAFxQAlA BigBMUAJigBcUwExQIMUAIRigBCKAGFaQDSMUDGkUARMMUAJQAUAGKADFIB4HFAC0AU9XTfp0w/2 c00Mq2GPIUD0pS3BFwDjNJAQyydhTEJEmTk9KAJ8ZBC9AKAGk4FIZ0ZFUAooAKQDWoAmXgCgQtAC Pwp+lNCM09TVCAUALQAuKACgYuKADFIBaADFABQAtIAoAKAKkh/en60kAjdaoRE/SmAgoAuWI+ap YzSqRiYoGGKAFoAKAACgAYHjHrQA6gApgJ0FADaACgBp4oAQ0AMIpiExSAKAEPSgCPyyDw7fjTAf ikA1iR0FMBcUAFABQA3bzmgAxQAmKBBQAUwDFABigBCM0AJigBCKAGMKAIyKQDCKBjCKADFABQAt IBw6UALTAgvF32ky+qH+VNAjL0tx5C5NTLcCxLcogxuoQEcJEjk9qALY+7wOKBibto470AAHc0Ad J3pgKKACkA1qYEo6UhDqAGS/6tvpVIRnd6YhaAFoAUCgAoGLQAUgCgBaQBQAUALQAlAFNuZT9aSA G61YiN+lJAJTAuWHU0mM0agoKACmAUALQAUALQAUAFABQA00AJQAlACGgBpoENNACUAFACGmAUAJ QAUAIRQAUAJQAuKAExTEJt5oAMUALigBDQAYpgIBQAFaAI2WgCMjFICIigY09aQCDrQIXFIYYoAc OlMBTSARl3KV9RiqQFC30mOJApdiPai4FqOzgj6Rgn1PNK4FG+/d3q7RgMtAEwbCY9aQwVfWgB9I Dou9UAoFAAelIBvcUwJ6BC0gI5uImq0JmfQIBQA6gBRQAUAFAxaQBQAUgFoAKACgAoApn/WH60IB G6mqERSHj8aLAFAF2w60mM0BUFC0CCmMKAAUAHSgBaAAUALQAhoAaaAENACUAIaYDDSENNABQAUw CgBKAExQAHigBKADpQAUAFABimIKAExQAhOOtABnigBevtTAcq4pgDCgCF1PY4pARvwKQELdaBjD 7UgGjcGOenagB/SgAoAVaAFxSABQAuKYC9KAKGoQSyyxGIAgdadwCKMo3z8npUjHCgANIDoz1qgA nFAAeRSARfvCgCYUCFoAiueIT9atCZRoEAoAWgBRQAtABQMKQC0AFABQAUgFoAQ9KAKQ/wBZ+NCA GqhEM38OPWmACkBfsRUsZfPAOKkoRCSoJGD6UxDqBhQAwPh8YOPWgCTtQAUANdwikmgBVbcM0ALQ AlADN4LFc80ABoAaaYDWOPakISmAmKADFACUABoAb0IoAU0AISAQPWgBDQAooAKYhaAAe9ABTAQo CD70AJjFACjigCReKYCkZFMCORcUgKzikBEwpAREYpAFAxaAACgBQOaAHUgCgAoAKACgCu5xJj3o GMPDGgBDSA6PvVARlMtkk9MYoAkxgYpACf6ygCamIKAIbviIfWqRJSoAUUALQAooAKAFpDCgAoAK AFoAKQBQAjdKBlNPv0IQjVQiJ+opgAoAv2PSokUXu1IYtABQAUAJjnpQAtAC0AIeeDQAo4oAKAEN ADNoDZxzQAd6AGmmBG6BxhulIQopgFABQBGibARknnPNADqAEoAY4O8EEbe4oAAuDnvQA6mIJCQh 2DLUAAoAUCgB+PlNMCBZMjJyvPekBIrqe4pgShARTArmQeaV7ikBOBmmA7HYUwK0r4baetICNwcU AQvxUgRH0oATFIYo4oAUUCFFAxaAFpAFAAaYBQBWn4koGMb7xqQEoA6M9aoBQKAENIAjHzGgCYUx C0AV7z7iD61S0JKlMBaQAKAFFAC0AFAxaQBQAUAFABSAKAGv900DKkX3/wAKaEIaoRE/UUAFAGhY jipkUXakYUCFoGJQAtABQAZwaADvQAtACUAFACGgBuKAENAhppgJ0oASgAoASgAoAQ0AJtFACYpg GMUCFoAOlACM4UZJoATzfRWx9KYBsVhkjikA5UX+6KYEyHAwOKYDGiUvuxzQA8cUALnFAFeWEO+6 gCOQYGKAK7VIFeRN2OcYNADhSGGKAEbOOODQIeucigY+gApALTAbQAUAV7n7woGRt1qQEoA6XvVA KKAENIAiHJoAlFMQtAFa9PKD2qySrQAtIBRQAtABQAUDCkAtABQAUAFIAoAZKcIaAKsXU/SnEQ1q oCNvvCgAFAGjY9KmQy5UlBQIKBhQACgBaACgA6UAIDkA0ALQAUAIaAEoENNADTQAlMBDQAUAJQAG gBO1ABQAUxCGgAFABigBgQeYSefT2oAloAMUwAcUAOBxTAcTQA3dQA0vzQA1mzQBC596AK7dakCJ sUAAHNIYoFAC4oEKOtAxwoAWkAGmAnagBpOKAILjtQMiY/d+lIBM0gOmPWqAWgBDSAdEODQBJTEL QBUvv9YB6AVZJXoAKAFFIBRQAtAwoAKQBQAtABQAlIAoAjl/1Z+lAFaL+L/dpxBjTVCIX+8KAHD0 oA0bLhKljLYNIYtIBO9AC0AGaBhQAUAHSgBaACgBM0AFAhtACGmA2gBKACgBpHFAABgUAFABQAlA BTEFABQAgOetADUTa7HcTnt6UAPpgLQAtACHigBOc9aAAGmAHFAEbHFAEb8nikBCw5oAiYUgEGRS GO7UAAoABxigCQUAFIANMBpoAaaYENxkKCPWkBX3UgDNAzqT1pgFACGgB8X3aAJAKBBTQFO9/wBe R6cVRJBQAooAUUgCgBaBhQAUgFoAKACgBKQBQBFOcRmgCvF0f6VUQY1qYiJh84+lACigDSsh8lSy i0OKkAoABQAUAFABQAUALmgBaACgBKAEoASmAlADTQAh4oASgBaAEoASgAoASgBaBCUwCgAoAaDl +nApgOzxQAdDQAuOKAA80ANOfpQAA+tMAJoAjagCNjSAhfrQAw0gEpDFoABQAA8igB60AKaACgBD QAxutMCKf7lICr3H0pABoGdX3pgFACHpQA+MYWgB9ABTQildHNw/1qiSKgAFIBaACgBaBhQAUgCg BaAEoAKAEpARXHERoAhiGUfFVEREZELFVYEjriqaEMb7/wCFIY4UAaVn9ypKLGakBaACgAoASgBa AE6UALQAtABQAhOKAEJwOOaAENMBKAEoASgBOlAC0AJQAUCEoAKACgApgNoAKYCYoAUUALnFAC5o AbzmgBDxQAjD+dAA1AEZPFADGoAhJ5IpANoAaaQxRQAvSgBDQBIKAFoAQ0AITQA00wI5R+7NICrS ASgZ1Z60wFoAa3SgCRBhRQIcKAAffFMDPmOZW+tUSNoAWgBaQwoAKAFoAKACgBKQBQAUAJSAhuf9 WaAI4uI3I9RVIGVUtkicsoxTbEKfv/hTuA4daQGlaDEYqGUWKACkAUAFABQAUAFABQAtABQAhxQA lABTAQ0ANoAKAENABQIKACmAlABQAUAIaACgBKYCGgAoAXFAC0AFADTQA3NAAaAGMMCgCLPHFAER ++fpSASgBuaQxRQAUAJQBIvSgAJoAdChnJCHpQDJfscntTAb9jkz2pgI9nKVI4pWArf2dPg8D86V gEOnTjsPzosB0B60xi0gGmgCYcAUCFFACD/WVSAzm+8aZIgoAcBQAUhi0AFABQAUAJQAUgEoAKAE pARXP3PxoAYg/ct/vCqQMjNAiI/fNMBR1oA07b/VipZRNUgFABQAZoAKACgAzQAZoAM0ALQAlABT ASgBDQAlACUAGaACgAoASgQZpgFACUAFACUAFMAoAKACgAoAQDGefegBKAGmgABIIoARqAImGOKA I2HNIBjUAMpDFFABQAuaAHDpQAGgCXSjiWQe1THcHsX3mjSQRs4DnoM9a1JH0AJQMSgBrMFBLHAH enYCyetQUFADT1pATYoELQA08ZPsapCM49TTEKKAFFIYtABQAUAFACUAFACUgCgBKACgCC5Pyj60 gET/AFH1aqQiNqYiL/loaBjh1oA0oOEFSMkz6VIxRQAUAGaADNABk0AFABQAtABmgBKAE6UwDNAC GgBDQAmaAEBoAWmAUAJSEFMAoAMUAFACUAFMAzQAlABmgBc0AIaAEoATFACGgBCaAI2oAiakAxqA G0hgKAENAB2oAep4oAU0AP0w4uXH+zUrcHsXJ7OKeaOVhh06EVqST0AJQMQigCOaJZYmjf7rDBoQ Fw1JQHpQA3+IUgJ6BC0AMkOFb2FUhGd3piFFAC0hi0AFABQAlACGgAzQAmaQBQAUAJQBDcdqQCD/ AFK/7xqkIjagRF/G1UA4dRSA0ofuCoKFZWLKQcAdR60DHigBaQCGmAyMMN24g88UAPpAITimAjFh jZjPvQA/0oAKACgBisSSCMc8GgBaAEoAZIxVcgZ+lABxkGgBe9ABQIajhiwGflOKBjqADFMQ12CY ycZ4FACjpQAtACGgBoYHpzQAUABoAbnBoAXNAC0AMJxTATdQAZoAYWoAYTSAaaAGGgBtIA6UDEoA KAHr0oAbvG0t6EChMB9gcXn4Gktwexrbh61oSIWFMBu6gYm6gBCwoAt96goDQAij5xSAmoELQBFP xG59qpCKFMQooAUUDFpAFACUAJQAlABQAUgEoAKACgCC5/hpAA4hT6mqQiI0CIx95qoBy/eFIDSh +4KgokoGFAC0gCmAlABQAGgBBxQA6gAoAKAE6UAJQAlACGgBKAFoAKBCYoGFAAKYhGAYcjNAAOKA FoAOlAEaoEGFGBQAuKAFoAY8aswbkGgAFADu1ADZI96EA4PtTAZgigBDQA0rnpQAwKVBDHJpAIaA GMeKAIxu3HOMdqAFpDA0AR7iHxjimBMvSkBCW8tiuwurdQKjZjsSxkC5VYnHmEfdPWtLW1JuWttz 6LVXCwYufQfnRcLCEXGOgouAmLn+6PzouAh+0/3R+dFwsbHepKCgBE+/SAmoELQBDdcRGqQihTEA J3Y7UAPFAxc+9IBDQAlACUAFABQAUAFIBKACgCvcnlaQB/yyT8apCIzTERj7x+tADl+8KANOL7gq Ch9AxaQBQAlMAoAKAENABQAtABmgAoAKAEoAQ0ANzQIM0AGaACgAoAM0AJmgAzQAUwEzQAE0AFAB QAlABmgBKAEzTAAaAGmgBjHFACZoAaTQAw0gGGgBpoAKBiUAFADkoArzuUjnYHDCMkVMfiG3oY+h Skazbtn72R+lbVFqZ3O4zU2GJmgBM0AJmgBCaALO4ZqSxdwoASL/AFh+lICegQtAFe8P7v8AGqQm UhTEOWgBaQDaADNABQAUAJQAUAFAwpAFABQBWuPvLSAVv9Wn0qxEZoERL1P1pgSJ94UgNKP7oqCh 2aADNABmgAzQMM0AGaBCZoAUUAJQMXNACE0CDNACE0AJmgApgJQAUAFACUAGaADNABQAZoASgBM0 ALTAM0AJmgBM0AGaAEzQAmcUANJoAaTQA00ANJoAYTSAaTQA3NACZoAM0AGaAFTpQMo6vEWtn2kg 4zxUrSQ+hi6O+3UrX2kxW89jM7fUbh7W2MkcZdgQMCpiMkgkMkKuV2sRyPSjYB9ACGgBM0AXu9QW FAACM8de9FhCXFzDawmWd9qjvQlcTY+CVJ4lkjYMjDII70iivekAYqkSyoKYh4oATNACUAFIAoAK AEzQAZoAKADNAwzQAmaQFa4Pzj6UgHN9xPpViGUCIl70wJE+8KQGgpwoqChRwaAFzQAZoAM0DEzQ AZoAM0ALmgQZoGGaADNAhM0AITQAUAIKeoAaLMBM0WYBRZgGaLAFABQAUAJQAZoASgApgGaAEzQA lABQAmaAEJoAbmgQ0mgY0mgBhNADSaAGE0gGk0AJmgAzQAbqAHoaAGXC74iPapZUTlYW8jVYQeMS itnrFENanomeKlAFMBM0AGaAGnFAF89aksKQiLIRyT3oAo6tFHcwFJpQkJGGJPSmrk2JbC50+ztY oIbqHYigD5xT5JDuJeXULkeVIj59GFPVCK/nhCAR19KQEobI4oAXNACZoAM0AGaQBmgA59KADB9D QAYPoaADDf3TQAuxv7poGJtb+6aAK80MrSDEbEY44qQsTG2nKjETcD0qxWGG1nAyY2AoFYiW2m/u UwsSxWspIO0YPvSKLnlMo5Kj8aVgGkheS6f99UcoDTLGDzIn/fVHKAnnw4/10f8A30KOUBDcwD/l tH/30KOUBDdQAZ86P/voUcoCC6gPHmp+dHKAv2mEf8tU/wC+hRygIbqEdZUH/AhT5RDft1uP+Wyf 99CjlAQ6hbD/AJbx/wDfQo5QGnU7QdbiP/vqjkAQ6paD/lun50+UBv8Aatn/AM90o5AE/ta0H/LZ fyP+FHIgE/tez/57r+R/wp8i7gH9r2X/AD8L+R/wo5F3AP7Ysv8An4X/AL5b/CjkXcBp1mxH/Lwv /fLf4Uci7gJ/bVln/XD/AL5P+FHKu4CjV7RjhJdx9lP+FHKgE/ti2yRuOR/smjkFcG1e2UZJP5Gn yBcYutW7AkByB/s1LiMj/t+15yH/AO+aWgDG8Q24+6j/AJUaAMPiOLtE9GgxP+Ejj/55NRoIB4ij xzC9GgDf+EiXH+pb86NAsJ/wka/88D/31SuMQ+IRniA/99UXAP8AhIM/8sCP+BUXAQ6+O0B/76oE KmteYpIiHy9fmppXAYmuK5O1Bx/tVXKAyXXVj5KDH+9T5AFfWCqqfLHzdBuqGrARHWX7Qj86VxjT rMn/ADyX86VwGnWJf+ea/nRcBP7Yl/55pRcBP7Xm/upRcB39szdkQUrgKNan6FIzTuBXku1kbe1v FuznOKLiLQ126UYyp/OjmsAn/CQXO5QSBk47007gNuPEFxbzeW7YJ9c1oogPXX7ggkHOB15xVcoD YtdupUaQHCpweKhjPQD1qCgxSYCbBikBh+MJBBoznGRnp61UHqZzOGtLrTruVIn05VY8Ahu9aSHF 2Rq6clmL426wiKUDoXNTYL3L15fppxAZEOOm5iaaiK46TXZobSOZYI9r9MZqdhsiHiK4PSOIfgah ysAh8QXXZYh/wGjmHYT+37wdDH/3zRzhYafEN5/fQf8AAaXOFhv9vXp6TAf8BFHMALrV8f8Al4P4 KP8ACjmEWINSvGYZuG/IUXGa8L3Lx581qdy7Gff3l3C2BO4/GlzEtEEOq3RJWS4YDHBJqkxEcWp3 zbgztu/h+erTuwtYin1i/WTYjyZHJ+bpVytEFqTS6tc+XH5dw+7+MEnis3JD5Rn9pXBHzSMfxqOY LDTfSHrz+NPmAabs+n60cwhv2oY5X9aOYBPtK/3KOYBpuF/uU+YBPPXsgpXATzh/dFO4B53+yKLg HnkdhT5hBPOrMhQEYHzAgU1IB8rEReYsnyemK1i00BWguTDKWlUspHAGBiocgGiZsk7s59ahsA81 vWlcA3nPWlcBN/vRcA3n1oGIX96BCb6AE30AJv8AegYm8UAOimMTh16jsapMBkrkytNkjPJUHiqU +gi1cxRpapLGzDeOMmtL2QFSC4MMLxcbW6k8msuYAEgUcHikMQzDtSsIie5Cgk8AU1EQQXYnbbEr OwGcAUcoAl6jybArbqGrDRYD1Aw3igADigBwagBcigAVym7aSu4YPvTTsIjiCQXCMq/KThhVxkA+ 7ZJJPlUbRVTkAjOzhdzEheBntWVwEzSGITSATNABuFMA30WANwzRYQu8CgALigYm8CiwDS4piIpS HU5GT6mmnYAju5FtxEQPQ1q5aAhvm4GBxWLYz17vTKFFJgFIDlPiLL5Wjgepq4/EZT3PNIJt3Tgj 0rZjLlpePbXcVwcuUYHr1paDWhreIdei1N4Xgi2FRzkU2SjNS/PAdfyrJxZRMt4p6E1DgBL9pPYG lygMa5cdAaaigEFy/dTT5UA4Tn+6aXKBPDK2fumk42AvQzlGzjpUlFxNanRMBBiq5WFytc30lw25 lo5WFyDzWHajlYC+acqRwQQaEmmApLNI74OWqpXkPYUbj/DU8gXIZpGiwCMUcrC5GLg+lJoVx3nH 0pWAPNPpTEHmGgBPMI7U7CE8007AHmGiwB5pp2APNNKwC+ZkU7AIJmWNowTsJyRVJ2VgG76mwCZ9 KADefSgBdxosAhc0WATcaLAIWOKLAN3mmA3fQAhc0BcN5oGJvPrQApJNGghuD6U7gGwmkA5UNFxg VouBRkInDqrYFXsSLDEIoTsdxNn7ynAxTYElvH5eTnJPeoYy0N1QMcVYgEU0IXaygE0DDOO9ACg+ 9ACEn1oANx9aAEJPrSEICxPBNGgEyQStjCnmlcCQ2M/p+tK4B/Z8/p+tO4EM1pNH1BouBTLYYgmq sA4ZPrSAcM+9ADufU0AIQfU0AMIPqaAGNkdzTAiZiPWqSAYZD2zRYD2rHNSWOpMApAcV8TH/ANCg T1NXD4jKXxHAW0DKxKlCCP7wrpkkNkpt5M5ygH+9U2QhyW/zAPLGAf8AaFHKO5vQ6JprxozX0YJH TeKhxa2GOGiaVkZv4/8Av4KXLIBRpemIeL5ce0g5o9mBKumabjLXyDn++KXs2Av9maZsJF+mc8fO KPZsLiNpdgGIF6mP98UcjC5KmnWecJeDH+8KpJrYCeLTLd2C/axnGSARRqMtR6dD5KqHVye/c0wG Np0KnBlUH3piF/s6E5zIp9OlACf2bADw64+lIdhwsIgcCRR+VMGPGnxgjEwB7YoEUr7QxdurC7Kk cc0NXBEA8PMqn/SuegyMVk6cirj/AOwsf8vQB+lL2chXF/sUbRi5Ge9Hs5BcQ6MOP9JGfpR7N9Qu INIOcG4Wq9mFw/scAkG5UemRRyCGNpLA/wCuTH8qOQA/scn71wox146UcgCjRuSPtKe2B1p8gXA6 Me1wmPWjkAadGbdxcJj8sUcgAdGcEDz09/ajkYDDo8oHE0Z/GlySAadHmBOJk9uetHJIA/sebjM0 YB75o5JANOjXAYDzY/fnp9aOWQANInX+OPrj71HLIBG0q5/vRnH+1RysBp0a5LY3x8jI+Yc0crAb /Y1zx80fP+2KOWQg/si5x0TGcfeFHLIVhp0i6H8Kf99CjlkMDpN4CQFXj/aFHLIYn9l3gxhVOfRh RyMBDp16Bnyxj/eFHIAf2ZfZ/wBQfzo5ALFvpVyQ4lQo2MijkApy6bqBQgW7c9KOQZiSW81ss8Uq lZFxkfjWulxCWaStKFjDMxHShoRsLo+p8HyWAPPJqOUm5JFpWpb1BhYA96XKXc6GysbeKzjW7jdp AxyUGc1cIKwmV9ctI5LOP+zoJPMV/m3DHGKHFW0GjE/szUTnMLDHWo5QHDSdR7xkfU0uUCWPSLwn DjbRygWU0pk5bc30qXGQD/smz7tuzUvZsBrRXY/1dqox6mmqbAYYtSbomD7VXIAi2+pMMszDn160 +QCP7PqhcYztz1LYo5AJJ7W+Em6Ikrj+IjIpezAovpV40peRUBbnhqOVoCwlleqAoKqv4UuVsC1H Yvgb5M/THNHsxE32OMDG7J/Cj2Yxj2qDoV/SlyARPaZ+6wH5cU+QCtJYSN92UA++KpQAqPp93k/v 4/8AvoU+WwAbK7A2mWIfiKdgPXz1rEsUUmAtIDhfiMDK8EYPRc/zq4Oxk9zi7W38gNk5JqnK4xJ5 Y1OwnmqihDrOOOWVFYAgnmtYLUmTsiG/iSOd1j+6DxTkrMIu6KDA7uRUljmbL5ximA7dQAob2oAU OR0pWA3fCyLPcyeZ/CBilYex19vp1p5gYgeZ655ocECkWn02coog3oB0+XNS0h6nMa4lzBqRimZi QgxkY9aFYNTP86RHznJpgjstBs4bnSkeYjLdSawk2dESbV9NsysQk2qv1xSTkaxSe5npYWipx+eT Tv3LaiQy+G47lQ1vOX7kBiCKtNowfI90MTw9HDnfO+7oQXORUtu5ahT+yZlxpF600htJBIgOAok+ bH0q1qctRWkZl3NeWR2ztKhXjBJp6kFF9TuGI2O4A75qkgLf2u6JP758E/3q05RCi5us48x/zp8o rime6B3NNIPYNRyoCa1lvZWAjM0n0NFkgNddNuseZd3BtYj/AH2GaVk9guRm9tbd/Lt4p7k/3nbG afJb4guW44llXzJbaWBfUz4pOPYA+x2zf6uaX/gM4P8AWp5WAjabwSGvSP8AZIP9aOV9wK0lqiMQ 09/GfVoyR+lK3mMiaynIJh1IH2fKn9aNQuQNY6vj5JGkA/uPmldgFtZ6rLzlkA/ic4ouw0NGLSbn bun1ERr3PYfjVKMx6LYoXcsFrMV/tJpgOuwZqWpLc5qkpp+6RrqlsvV5j9ai7MZRxL1RI2s2yj5R NTvYn2WK6u39ehRn1admzAG8vt6ilzSPYo0JQhzNXI/7VuyQFBJ9Ker6lOpT25fxZfgOpugZrdQP VmxTszKfs+1iV3vY1JaFW9dsoNNRfUx5YdGx1muoXufLt3iQdXdsAfjU3lsi4xh3ZfRrWJhHNqEb P/dj+Yg/hxV8szRci3KE2p26uUWefr/zzrN863N06LW1jROgJe20uWYuwz5h4OacWzlmo30OZOm3 mmX4RlI64dehrVMh6Fr7XqyY+csPQDFNoI1I7NEY12dSUkMm4HnBBFQ9Dqj7OS2JdU1CaO1hlimZ Vk+93qlsYyik9B/h3UVmum+3XLGErgHpz70KN3YhqyOjOlxXTB7S/baP4Qc0ODQJgmnJBgTSSk9s tQog2LK1vEMeW7fjj+Zp8grlG7v44BkW4Knrh84/KlZF0430KUmvWSNgo/pnBxTSRDTi7EX9rNgy RQpPEP7jHcKVkK7JYdRsb8BEkkt5uyscZPt2osilJooXJuohOBMzlD0P3gPXFGwL3mZRv7vODO/5 1NwasON/ORzcOKAFt7yYygNKxB9TUSbA2I5owo3vj8ax94VyVby0XgtmqSkK48ahZ/3SfwqrMLjJ b60J4Q/lTsFyBry3PAUj8KLBcrSTxH7pxTQ7mXcOyzH5jg+9WMZ5jf3j+dAj3fvXOaDgPSgAqQOC 8eyf8TCNfRKpIy6nKmrsD3MiUM0rEg9a2SGjSsxY2wVzdPvxkgJnBqk0upXLdErtpkhJaaUknJO0 Una+4Kn2GbNNPAuHH1SjQfIyOSwtpP8AUXKe27inYmz7GdKjQyNG2Mj0pCsERDHDHFMB+0dAwpWE amh6bNqDssMxj2/eINS7lWOjstAuLO4SUSmQocnJ7VjOcl0Likdf/bl3Ba7vIjO0cAk81Sg2ri5z AvWGvy3d9c+XC9vGFEYbqBzn9a55S5XYtao4OfUJY5WQAcHgiuuOqM7FhPEV/FAIkfCDtihxRonJ Fyxur3xDJ9mkkYhBnjtWc2oDUmy0dek0iL7A8Ql2fdduuKUUpj9pYgufE09wgEeISO6HBq7NEyq3 LNv4n85BDqiecvQTRnbIv9DRuSpMW40WSaQXOnT/AGpCRkg4dPqKLWJd27mqLC4msGj1SLzoVJwx PzpjuD3p2YjB1PRpdyQ6fAZ45FV0lXpTTtuBbj8PTogNxNDbj/betFK+wiVdP0uEfvtR8xv7sSE0 agSK1jGf9F024uW7GTgU7PqBKX1mVcRQxWUXqoAOPrRoIpS21nG5fUNRM0ndYzuP507tgQyazFbr s061WP8A6aPy1JRXURmT3U1w++aRnb3NWlbYCMnjtTEAdk5Riv0OKQxiajfC7EaXdwF9FYmob8ir G55l/aFZL3UzHCRna4DE/QVKbE2uhPZa3HPdBobVRFGMPOy4J/KhtAk2asUkVzGGjnBbO/bPRcfL YydV0aSbMzSSEHod29f0otcLWZzctrJEzLsY47gdai9jRRk/hJljWGFW8ve5OCD2qY6sydGs3qQT s8hCmHGPRcVq3ASoOG5LbafcD94xMMQ5LNUNKWjOinVnT+FliO6dDm2hVmGR5o6moVOKN54iVRWk ipGtxez4dHlfuWPSrlUUVoc8KTm/dRvWemLa4a2s/tU/q33FP9alTb6Dm1T0vdklzpGrXx/0ucIg /wCWanCj8BV8z6I5JVZdEXXso4GTAtY5AMbTIBmlaTJ9+XUQx6lIyIlvZNGSOUIJxQ1oUqb7nRWc ZSNgT8wNSro1UbCywJIcEYNUmBSvdCgvbd0YuhPQq3SmnqCSOE1jR7vSXCt8yE4UqKbLjzdCK5d3 0cLJwyt0pomSdzPtpFQbWyAfSi7WqNISWzNOxv57aRRbyAHtnjNUqncPZNvQ6rSfEqTjyb+Lbt4L gVTs9jOcXB2kaF7YS3MfnabdrzyAygj86nbckoySXEMTpdog4+bK4yKnRlRbvoc/aWQuonO0FQx2 8dqjqaTutSF9Plt7kNErJnoynGK6IpWMGxTYrI7SXqPgckxqOamUUO5cv3WOwtpreUIQ20PIfmKV IX7HMzSq9w+AApOVx2qGrGyfMrDc0zNqzDdgjFJiJkyevNQIsoKNRE8YFAhzgdqYyEjmgCNxQhlO 44YVYxBKQm3C49cc0DPeu9cxYu/Ypx1oRMtjA0S51SbU7oXibbdfu5HOc05cttAitDmPHDbtVb/Z AoiZ9Tmiaob3MqZWWVhz1rZDLtlB9o+9EMgdScZrRT8gbsNkVFY4jCge+anmuNMjZ0HOwflRqaKa XQYk6JIGKZHcetRNOWw3MR/LlMko/dqOi5pJNaGbdyEAE9avYLEix45DU0SzrfBIw05JzyKl+Qzt oz6Ub7i1GSYPB6elO1iTntSgFv57RthZF2Ffao9km7spza2ONaCByxMyDnnKkVuoRSI5pB5FvjAn jJ9dxH9KORFe1kOtt9pP5tvdoh74fGaiVJMftJdicQi83Ge6h3dmZ+ahU0jojVThy21Kd3bpaDAk jlyOCjZFOxzjrKG2khMk9ykbZ4U5zVWQXsXLK7kXUY3tJ2EqkYYHbkenvTfKUpM7z+0rcAPeyJvO TiM84PbHeoXMxbELajpggKvcyW8R+UKylB+YpJa6DInt7Up51olnOhOA8sveqS7iIZG1ULi2tLLH /TMA07REUZ7jXgCGEkY9I0ApppbCMm5N45/fmZv94k07oLFYgjtVXQhO9ACbTnABP0FS2MswaddT kCOBzn1FF10FYu/2PHaDdqNzHEevlKcufwp6gUp9YgtJGTTbVYz3lk5Y/QVD0LirkcEd1qc65hWR nPLsvT3zU8/Q0dOMCbVbn7E4061ASOPkt03t60cq3CD10KttchbhHu988Y4IU4x9KWhcoSfY7C3j guI0W1mNtI6nyZY2IV/YjsfanoZOLMT+2NV02/8AsmprHJggZeMcj1BpKCkS5SSLS6whnaKfTonP XdEv69arkgwhWcluXpNs8YaICFz/ANMwT+tJwithqb7kUOlPKN1zM0rHv7fSo5WWqq25Qk0K3JUD AYnAx3pcrLVVfyk6abZ2UJB+539XP+FJU9dR+291qOhUubuWVljhmECngBeAK30StEyhZfErsp3d uqjyn1J5Gkxldxwah8/c3UoL7BYGhy3cK/6TveIYC+i1PLLuL2lPsEWlR2s6SNc5ZGztpcr6sHKL WiOnsNRt5x5YO0jsetNHM1Zl7HpyKBD1BCZFIZla7Zi/tdi8MDkZqxqUo7HnmqWs8V0YpInVR+VO 4009zPmt2QE7WwO4FK9xvlNLTrcTwDLA9tp7VmzaFa2k9UXJ7aW3tN6hiB6dQKa01Lc4S0lsVbLX 7nTZt8MrFe6kcGtozvoznqUkneJ2Gl61p3iWA2s6hJiOUJ6/Q0NJmUW4sSXTv7OyoYeSOjAfzqEi 5PmObuNeVJWQR7lU4DZ61onYl0yMeIAAf3Yz2yKG0CpsyL67uL6QPM2ccADgAUuZFezkVihIpMnV AoJHPUUIGLtwQaTETxmoEWYjSEWIxQA4kUAQscGmBG5oQyldHGMVZRXoA+gu9cxQHpSYAFA6Uhnm fi1/M1q4HYcVaMUc8zbXKnrWlig4PbNAi1ZnDN9KuIpFCU8NS6jLth4fvb+2M8KDb0GTjNWtAsVb nQ7+1/1lu+B3AzTTAoyIVBDRkHPFA7kOCO1A7j9wzxwPek0NSOq8FvhJj/tUbA2dtC+VNMgazZNM SMLxAx+zvtODimS2cI055AFSapke9uwosVzITcxNFg5+xPGuVyWxSsK7CaNNowwzQIkjjjKDmgCR Yov72KBF2W6RbeFUKq64UsDzSRTE1HUpriyWCTYw3g7gOap2JLNlcfZSVZfMhcYkjPcf400AX1l5 GJrZy1u/KMOMex96YiGK9u4z8lzKoH+2adhXLK61fqOZ949HUH+dFgHjW5z/AKy3tn+seP5Glyhc P7ZI/wCXK1/75P8AjTsFxp1ydf8AVw28f0jz/OjlC5Xn1e+nG17l9vovyj9KeiEU85607hchs133 74h87jhazvZlHRXl9PaWqWtvFiTHzmMfdHpUtlJLqY8Nss0rGaC4JPfqazk2axSJv7PtVbIEyH3T NRztFcqJrd10uN8TtLbHBeIgg/UehpqdxONjoQlvrljHDdMHLD/RrnHP+63of51stDIpaZYTadJJ BdHcyn5SemO2Ki2pDWuhbnl2ACPBJPetI2QNEsVwCQu7oOahvUqzEFwqyPKcnyx8v1NJyBpmFqF/ JPKWEgWMcVHtLbHXTw9lzTKxW0ZPMe4ct6LWDnVbFyxUtCGNRNL8jSY7ZrW8ranQ5RgtTUtrie1d WjbDr0YGtFKyPPqTTehrrqdtdgLfw+W5/wCWqf1p8ye5KGXulXCqJbSXzE6gr1qZeQ7j9J1maKQW 1/lT0DkYzUpsLHUxMpQYOR61oSQ3I2DIGeOlCG3YzLq2S9gBCYc8AHrmhiTONu4yvmqyElQQVrOO jE03sU41mCboLUR4PJ3da0qK5UYTWxs6dqAZPKmiZmI+U9jXn4j2ltGaR8zO1nRGW43WvSTnZnoa vDYjmj73QJeRqWHhhbZI3Jbz1IYOrYINck8xbm2iuS6Oitr6KaZ9PucNJsywPcV6OFqupG7M5LlO L8S6A2n3mYFLW8nKkdvautJFatXRitaMFz+hBFO0TNuRH5LDHI59DScUHMyeK0kkHyzRj2LCptYu 9yNoZFZ9oDbR8xFKLZdSncaBlMsQCOx70cxnySQ5DUmZZiNIRZQ0CHMMCgCFyBTGQO4oKK00ZfGK dwGrb+po5hnvnesChaQC0AeWeIX36rcEdN1UZIoWOnLfSyF7qOHbgfOa0WpaOh0bw7C1whF3HNtB JUDrScWUmi/qOjQ/ZXjSSGKYkbS3HHeiMWiZNMw7Xwo3nqbq4iMIOSEbJarQI62BEijWOMBVA4A7 VokSx0hG3GM0WEYuqtYwRB7m3VwxxwvNGwXMyLR9L1NWaGJ4sDrQN6FW58JbQTDKDjs1ArjNOsrz TJiAo2Hr9ako66GVdhww6VaRLY1pMUybmLrkn7l/pTEcMx2nOKi5rawhegLDck0AKGYUDuw5LA+l IBVDKOuKAFG71NAgbJHXn6UDHbiCu48ZGaANYTxEcSL+dUiWPW8KwyRRzBUccjqKYFQzbDhyCPVT TuJkySoR94Yp3CwvBzgg/Q0m7BYv2Wj3F7A0sCFlU4YgdKn2g+Uit9Nkuiwt/wB4V647U3OwWFfR rsf8sm/KlzoViM6Zcr1iYfhTU0FhGjbS4HnjjZ7l+M44jH+NRdXHYxPPl3Z8xsnvmmOxJHfXURyk 8i/RjQMlGr3wP/Hw5+ppWQ7iyaveSRsjyBlYYIIpcqDmY/RdXl0qQ/KJYHI3xk8H3HofenYR6JZ3 NvrVmpSQNu+5J3B/ut6H+dKwdTltTvV0+7a3vbORZF6MG4I9RSsy7orJqtiT8ouFZuMCocGVzI14 p4Def2aHIkWM5z/eI/8Ar0lBpj51Y51I4o5HRp5AwJBHlniqfqXCtOPwlw2UixCQN8numK5nUjey Zpzub94dZKS25l2jJwParlZnPWfNIuQplNx7mk9EYWLBjG0YpbjK39oXFk/7gsgJ6dj+FbJtbDSL 0WutcIVubeKUr+Bp3QnoaFnqsEQAUtGv91u340uYfQ0LXUoLvhZFYj0NWmNrQdc5VQUAY5GATjNP YlGNrunCdjfJGyeZxJGeoPrWUl1OzDU4zlaRwV6bm1uHheSQYPHPUVtF8yMq9J0pWJNM1FoXEczZ TPBPaplFNGOqOw06WF9kshymep5rjxUZez5aaLi9dTYlureOB5fMXagLHmvBVCpzctjfmVjzaXVZ xqx1CNyJN+4fT0r6ilT9nBROaWrPRA1v4i0IyRjO9c47qw7VoOnLlep5xexzWk5QsSvVTnqKSRpV i4y8iFLqVDkY+hGaepg9S1HexyDa9vHuxwQCP5UN2CnF8wkXkMjGTzVYnhk5GPcURHObvoSPbxmB mS5RtoztZSDSaKVZtWK7RGJgD3ANJkMljqSS1GQBQA2SbaCKAsVmcmmMYBSAXp0pAIaYz3U9ayLF pABOBQDPJtVbdfTH1Y1SMombLEX+6Du9qtOwzr/CMctpa7p96k5watM02H+I7S5uTG8KyOvUtjjN UnYzMOOG6jbDMQPY81ejFcsG6ngxtvGX0DKaGCZVl8SXUchjzvx3xilcLFrTnl8QrKrDYIRuqZ67 FJWJLiT/AIRtULo0izj5dvbH/wCuiDsJq5Cviy3I+aCUflV3RPKxjeI7R/4JF/CndBZjRr1p/eYf hTuHKPGv2w/5bN+INPmQuUgvNTtLmMqZsEj0NJsdrHP3WwOQrB17EVnsWVttMA20AG00AOQYoAkw KAADFABikAYB65oAIHCFg6AgjjI6UgHvtJ42D8KYxpwP7n5UAABc4G2lcC/YwGOOXdF8zABT6c0r gd14LDJpc45GZMH8hT3Bs0dM0m30yaWS3DKZODTsSXJ5xBGXbkLycDNLlQyTedoyFI91FHKgMvWL mN9EuriOKM7UOMpjkUKKA89uH0u+tnaENZ3Q58s8o/09DVgY8kTp1FIBlACgUALikMvaPqVzpdz5 sALRn78Z6MKAO/khsfGGkgqwEyD5XP3oz6GkwOMj0eWy1mG2uxtYSDj1GanXoUrEdzqMUOoyXUYL S+YWzQ1K4K1jQ1m7It7fULZFCXI+Yf3WGMinyp6NExbizMi1S5uyIJHHlgZIHGaweHgnc1ptykXd LmLwszHJBIH0pSST0JnpJmpCP3EfuKTM0TZwRUjK1/LJIFQwqwBJDL15H/1q1UirleCAxksSMntS bIepajxnBOalgtCldyfZpA0AaJ1Odwq4l3uXE1G9uolZyQo6EDr9avmb0JaCDVmnVopJmX3B+U/4 VEuY7KGIjTeqI72yg1BNsnyyDowrNOUGetOFPEx0Oel0e4jlIfAQHG71ro9pdHi1cPOk3c2rbULS wthGyM4UcZbHNJK5h5jp7qHVISiRiMYxgGrVNXuQ5M5i6ga3laNh06e9WxnR+AdXNnqf2OQ/ubg8 ezVN7DI/EdqE1O9tMYKOZYv9084pTXKzrpWq0vZvc5zGKts5eVt2JDtjjIH3z19hUdTT4UR9Ohx9 Kqxi9WDO/ALHHpmiwJal65lEjLjsoFSwYR1JJIXHakBGx3GgBBQMKAG0AGKBnu3esixaQDJjtic+ imgT2PI7xt11Kf8AaNUjNEMM3kT7iOMYq47lI7XSNZs5NIkzGwkix1/iq76lNEc/jJYIjbBQ0ZHK kfyNVKzJsZ1vf6fJdpJMSsZ6j0pJWCxbuxpMu0212ZJQflQpj9apoSObltraW6lZ51RiTlcU+VBs b/hS/sdDinaULcCbAwP4cUpJIpO5Z1rVLDU2g8q2tVSMfdmkK5z6cVUYKRLdjPK6bgbrG1P+5cj+ oo9iu4+YiMWkk4Nh/wB8zof60vY9guNlsNIChms7hAehV1P/ALNS9k0Vci/s/Q26C7U4z90H+Rpe zmguRPpmhY/4+blPrEf8KOWYhkmj6KVPl6i6t6NE3+FHJMCJdG0oqMatHnvlWH9KLMYHQbEjKarb kfXFLUBR4bhbpqlr/wB9j/GjUA/4RYn7l/an/toKLvsFhp8JXRPyTwN9HFF32Cw0+E9RH3fLP0el dhYjfwxqaf8ALLI9jT5mKxWl0a+i+9C3pRdhYadJvh1hai4Cf2Tff88Go5gEbSb4f8u7/lT5gGrp 95G4P2eQc/3aVxnZjTRBEnmOh3KGGDnGeaSA3PDcWLJ1Tq0hx+Qq0Jmq9myfekcGmIjNs3/PRvyo AQQSHhZefcUtgG6zp7NprwKRI0ydFFO4HBy+GbhCS1s2P92o5kMgfS8DYylW9GFF0BPpfhlLuaRZ mEJAyuejGgDTPhCGJcSw9P4lNKzGMPhSxYcAj8aVmBIPDFuIiinAPei7QDtP0GTS7oXFncOjdweQ w9DQrjOgubO11iNHkQR3UPKn+6f8Ksk4S48ISxTmMyc/SlcCU6JMumNZM+f3gdD6etJNlvYwWtHs 3mD/AHlBFOV2a0GlclsJDDGUIPXNRKN2c7dzUXUI1iRcnKjHSp5BWK8mpmRiIweOnNHJYaL0cUzQ RyO33hnHpRyjsPVQOqg/8C/+tT5BDjIqc+Un4v8A/WpcgEE16ApBt4SPdjRyIB1rfvOiwQRIGzwO cL+NDaiOxcTRoIYy7gMWznaeKxdXUtUyg4itjstt+M4Csc4o576M6aU5UndEvmK48uQc4otY9eDj iI2Zz2r2bW7ht+9GPHtXTCV9Dx8Th/ZMqW9xJbOGQ9O1aHFYW5uTdPuf5SOlF2aJJk2kAx6nauCO JF7+9S2NwSR0Xjg+XrVtcDjdGM++Dg1UtYhRfK0c1eoIblwvQ8j8azjsbV7QqX7lbvWiRyvW7CgQ hFICdTk1LBkwPHFIQrHtQAlABSAXFABigAxSA90PWszQWkBBfHbZzn0Q/wAqBS0R4/dSf6RIf9o1 okZov2mnRXdurm8gjLD7rNgihrqWkdnoFhaWmng3EsDocgN2Jx0q4tX1HK5l6nokFzdsym3XjGCw HNXGxDTsVl0P7OA3lqw7MDmtNCNSC70stgjCY9qTGmYMulXSysUU47VCVi0yWBXtkKSoSWOABUvU d0Q6nbyvMnlxkqq4OO1ON4i0M6QPGcMGU1eotCSGOaU5jRm+lS20OyLL292LcloXCggdKOZjIQbh FI8tuh7UXDQrySTZ+bcOAOadwGi4kBzuI/GlcBEmZT149Kd2AolbGMnBOaXMAnmMeueKOYAV2DA4 6Ucy7gDSMWJBPWndAAmkHR2H40XAd9qmXpNIPoxouA4XtyOlxL/32aHsA4ajeDpdTD/gZotsA9dW vl6Xc3/fVFkBINe1FR/x9yfiaNAJYNe1AyKGuGIJHUCkxncQJZzbmeRgvYDB/pSsK5s6QIltwYjl d57AenpVrYTLuC2ecHPrQAbGx1H50ANx5YJbGMUgI9UuyloJLeTa6Lww4xRYCkniC4PDT5HuBS5E O5R1i/W9iVXw0gOFIHSrjBBcsWNxqDLGgSNoUX7zIMmm0kK5Y+2PBb7JpogRzgDNS1cLnL6vezpf NJbJ+6wOgOCe9FtAuVjqV6DkxFQfQkUrIZpaR9p1KN3W48vY20qzc0WAu38GoWlun2be7ZBaQHJH 0ppAPtdTTUoRb3OLa8I+RiMBv8+lNoRWiS6VryO54kiUFDjr15qVoNM5i+ja5klD/fIyTVNOw4ux FaqgGxvv46d6iCexpVjy2NBNPWVcoMik9DOw2PRXNyuxCd3GAKlsC5MWt4wr9VGMU72Aol3kJO7a g9KSdwIIwJJSByBzzQwKuoTfP5UY/Kk1ZXHY67w9oqRW2ZiA7KCc/wAqxi1J2Y2rErWBYyLESEzg ZrColGVkbRegxdJHlIvlKGAwzZzuPrRUmnsgi2iJvDyMwbcUPsalVDaNWUHoc3rVpJDcGCXlF5U+ orspbXOfEVnN6mcLZM9K1uc1xws0Y9BS5mFyaKyWKWJwMEMD+tQ5FJs6bx3bK1razAcrIR+dbr4A i9Uc3PbCQByOdoFc8ZWZ1YrVx9CstopbkVo2cdyytimPuio5mMSWxQRsQo6UKTAyl4NX0Bky9RQI cRg0AJQACkAtAAKAFoA9zrI0FkKxAF2C59TQBT1ZwNNuGB42GhEz2PIbgZYn1NaIkgAw6duabZUX qeheF7FptDSTzWILnCBun4VMYJ7lzukcp4xjFvrMkcbNkKN2TnmrSsZKTsN8K6w9pfi2uHP2ef5e eit2NaLUpao7ySJSCrKKdiDMns49/KimiTPudLWSRdq4Tvzipt2LWgRWJVWBJBJ45zVK4mQT6Usp yxqk2TZFmwsVts7SDnnmpepWxokZTaV4+lNWEQvEnOVUf8BotEWpi6tAjRnCL+VS0ugamR9lhHWM VAXD7Lbn/lmKQ7lq2sbYpnyxUMpM04dOtCgzGtZMonGmWZ/5ZLSHcadIsj/yyWjUBjaLZH/lmBRd hcjOhWX/ADz/AFp3YrkUuhWSozbcYGetWrvS4XI20OyXywQcvxwafLLvsK4HQLEybNxDUveC4weH rQx795Ap3kHMVZdFWNt8G5gp496Odoe5bt5ZY02ncCK0U7oLHX+G5CukCSQ4G9jzWkNUJl6zv7a+ DNbSq4U4OKdhD7jeYSIiofIwWosMcST0IpWAy9Zkli0Sd5NvmKvO3p1oA4lL+YfOwbaeM9qOYQ2X VJnG2I7B3NK47F2PXboWscDTHYgwMcU7gRHVmzyaAD+02PGaAHf2l6mkAn22MNuUbW9QcU7sCe31 iW3x5U8gx2LZpNsDSi8QWk+Bf2qv28xBzQB0ED2+p2RFrMHIG0MfvL7GgDl7+yurLerxkqDncven zWCyaMW5kxKlxEf3idc96XM0aqo5pKRpWmveRHHkL6YIqL8xVSly6ouf8JWqOvlworjncO1CjYx6 EtxLa6yJJkYRTMfunpWcmN6Gbd26wJ5W7B9jWiVkSmVFPlkhAMtxkmgtK5WsbRp9UiDdDIM/nWMn oWlY7s3EMLojnBboK5LPdFi3crRlY48DjJPoKcE3qxXM6HVJPPUhWMLEgN64q5w0BM1JrqOFFaRg obgVjGJTZgeKI1YRS8ZyVrqovoY1TnSADXTYwJIQCwpNAjQWDzHijXqzACsGaI0/GbAafHHnkzAV 229wIbow0A8iuSO504p+8l5FVcb/AMa1exxIux421kyglA8tvpQNHN/xGtlsDJVGRQIfjd9aQDel AAKQBQAoPFACZoA916GsjQx/E2mXGqxRrBJ5ZU8/Sq5kibai6shtPD0iEk7IwuTU7hU2PLHyRkfW tEIiIDoCPrRYL2NfT9fuLSx+zAL8rb0YAcHFLlLctDPnBeNppCC7nnirSsjJspTNujEfACnII61a Y1oaEPiXVIgq/awwH99M1dwLX/CUXzAbxA/4EUXETJ4qlC4e1Q/RqEwHjxLER81u4PsQafMKw8eI bQ9VkX/gNF0FjVs5BdqGt23cZobQ+UvCKZFDMhC5xmpuFhSw78UAVp0Rh2NOwjm9XuIVfyYgoZT8 xFKQjN833qLDsWrW4UAqTUSQ0aMN2oUDd0rFplky3YHepswHfax60WYCfah60WYB9qHrRqAyWdZI 2RjwwxVJtCsRDZtjBYnYcjmq5gsKXQu77iGYYzmlzMBTIpRUDEKvp3o5mhND0nVECA8Cpd2Uiq7k FgATk5FOLshksep3MUBgUExEEEfXrW0amhNiPT76TTwwgQjd1zVe1QWLf/CQ3XdaftUFhf8AhJJx 1Wn7RBYeuvtcgxzxbomHIpSmhFe6u0uI1i8tEiU5CAd6ycxlXZB/cWpuwE8u3/uCldhcQw22PuD8 6d2FxBDbf3f1p3YXA29t6H86V2K4w2tv/tD8afMwuBs4AM7mH40czHcY1tCASHbinzsEzVeV9P0e 1SCRo5XJlJHX2p89jRxsrmzpmtw6lCEnYGUD5uMc1oncgrar4cWUma2AGeSPWlK4GLd6QYrc5JBP UEVnqjRVWlZmQsbYKjHmDp70+Y2glUhZbkKyvHnBYY6imc7g46blsXBaZDuOCorRMiy2J9+XVs4w QalouMuUgs7r7Nribj8qTdfbNRKOhV7nf+UjSLJnDKCAfY1x8/LdFEeob1Qui7gV2sB1x60QkFjK tLVi6BJWZFJIXHTNaSqJqwJGxJEjeXkjcnTIrJS5S7XMbxU4js4wTyX/AKVvR1lcyqq2hy3m11WO exJBLhqmQ0jd0I+fqKsvPlLu/HtWcY3kiuhH4quPMuYIc9GLn8+K637tNl0lzSRmNMFi25rjhFl4 iV5sqrKN1bWOYtpOAOtZtDB7gbDz2oUSjEz8x+tadBE0dICYJkZHWkIRkzwRg0ARspWgBmaBhnFA CZoGe8HrWRYYpWGZHixtuhz++BTijOZ5Y2R0OK1WgDU/dgYAOBjmgCNRtTBHQUwJ5SVtI93WqZHU oOcmmkUBWPaTgVQEGT2NFhhkjv8ArRYAycZyaAHRNiZNxJXPSpkkNHX+FZvLvQpIU4Jb0xxioiin Y7gzwtboqyKSWPAP0rVIzZXkjR1PINNqxJzHiOEJCdjmM+oOKluw0cXOHHz7yeeTmkmVYh8x/wC8 aYCiVx0Y0WAcLmYdJDRZDHLdzf8APQ0uVCJBdTf89DRyoBftU3/PQ0uVAH2qf/noaOVDD7VP/fNH KgD7VN/fNHIgF+1zf3zT5UIPtc/9+lyIA+2T/wB+jkQB9sn/AL5zRyqwB9sn/v0ciAX7bP8A36OS Iw+2z/36OSIB9sm/vUciEJ9rm/vUciAPtk2fvU+RIA+2TetHKgD7ZN/epcqAT7ZN/eo5UAn2qX+9 T5UAfbJv71HIAC8mHejlQCm8nP8AFRypASWjT3l1FbqeZGAqWhxNLxNckag8cTfJABGB+FNQXUqc rqyMYXcyOJEfa46EVViUdj4b8TvIix3XDDjd2NS2gOjurODUYDsYKzDrScb7BvucHqel3VjctGyF hnhh0NS1Ye2xnzia0kzIhIcZ+btVdDSFVxlcXCygPEwUr1U8YpLQ1lCFTWOjHwzEOVIzTbsYqm78 qIL9Cs6zLnDdfrRe6sN05R6Ha+HtTW8slRm/exgAj1964asLO5SZsB+QMVj1KsV7e5MpY+SY0yQG PfFaONlcS3LMsMb224nA2nLd1PNb04pxsyZNp6HA+KNUNzcxwxtlYVwT6nvW9OHKZydzE85/WtSA Ezjo1DWgHY+Fley0ua9nOPMPGf7oFKK1uJs568vHuZpbpzy5O0eg7VpV+HlOrD2jFyKBmkP8VQlY 5r31YzzHH8VAWHCaT+8aVgAzSY+8adgFj6CpYE8dSIsxnFAiUgMvrQBDJHjjNMCB0x7UDImBAPtT SGQece1OwWPoHvXMWLQwMLxm2NEcerf0NOJEjzBqsBpNMBBQBNeDFvEPatGiFuUZQoC7DzjmmV1I 2xtoAiOVyMc0xuNhKAEJ9e1AGjZaXNcRGXACgjBqHIdi8um3MeMEc+9TzW2GWFj1CxntZF4LfMo9 ecYqlNisXL3U9XtNgPlgueOOBntVKbYnFGHqWr3t5EUnVcA5JAp7iSSMoknrQMbQAUAGKAHLQA4G kA4UAFADhtAOQenFACCgBKYBQAUALQAlABQAtACUABOKANjS0sIcjULaSZvRGxihJMCa8bR2fFtZ TKuOd0gzn8qfKkBAqaZ/FBcfg4/woshWJY49E/jivPwK0+X+8FiwkPhs8ONQX6Kp/wDZqOX+8BIt n4XYjNxqC/WEf/FUuXzGX7PSfCMn3tQul/3oiKfJLuVZE8ugeESuU1aRPqhNHJLqFkW7Dwrpun3d vdWuoxyiVTsaT5QvuajkuZs5DxRpE+j3BWaeO4E7GRZYjkNzTcbDRhA4zxn+lCKNPRMFiD0zXPU0 A7GCeSzgikXLR8g+opU58u4GosltqUOwkM2M8dRW3xbAcTqaGS9kszJ5gU/KxOaiSsIynhaCQq4w elJMLdhmChytXcd2SxzN90nK+hFJm0a01sxIJZ7K4863bv2pWTWpHM27s6jT/E8EqhblTE+PTg1z Tou90UpotHXdNTLeev4UvZyehScTD1nxQJlMNkCFIwXIrop02iJSRzBOTk9a6DO4UCLOm2hvbyOA dCcsfQd6luwzp/EN0sFiLSE4XGOO1VFHPK7lY5SR84UfdXiiWp1ylpZEdBmJigAFACnpSAdH0qWB YjNSInQ0CJQ3FADGNMCKSgCFxwapFIpYpjPoQ9a5Sh1AHM+PJRFpK+71UVcznuebeakjEKeR2q7W HYaxwM9qaAiW4TdgnFVYC5fMCkO0gjb2qmQiiw5oKuSrp8ksZkVgFHrVuLsEXqPXTJLliyMo9Qeo qYLmN8SnGQiaSzzCBJo2lP8ACDk03oYXuWE8K6rMP3dtkf7wqHKxRFLZajpbtBPG6Y7Z4pAAuJuA XYfjQwLEbXVzJFH5zYXJXnOO9CuF7E+oLftaq0nmuN3px0pK6DQx7hpCGDoVya0uxaIq7DRqFw2m izAlht5JGGxST0GPWhph1HSW83nbGQhuhGKltpFwjzzsWzp4xxkGsvaM9N4NWImsWHQ1XtDJ4LsM NtKvbNP2iMJYWotkRlSGw3yn3qk7mEoOPxDVOarQlKQ/AApXQWY3ODTAXIoACaBDaNQYtGoBS1AK NQCnqAh5IHvS1GdCmntdy6lMHCLbhm5747VLk7lKOhmLyhb3q9yBaLAXItKuJ41kh2srDP3hxTsw NqKxtZGMb2Lo+zIAI57ZpqDJKF/pwjtY/LgkSbcASeh4p8thmc8ckO0SDbkAj6UgE3EUlcY4zXd/ hWZ5VhX5VA+6BRKdmFh+prjw5Zt3NxKP/HUqt0Iw6joM0tEOJG+tYVAOxY/8S1D/ALX+NQtgMu7L LHvido3A+8pxTi7AjnLVnM7ksd3PPetW7gSWrSPcxLM5ZCwBBocRlyewWG7lQBjGPuk96m1iWwW0 hJAcbF7sBnFUmSmJaoWeRFQFWyFyueTQXcZBblZlDDJBxUtiMi4GJ5B/tH+dapaFIjo1ELQAqoXY KoyTwKLgdRY20Ok2nmSkec/X1+gpKPUmUrGJqV4Z5jk1pexMFrcpfSouzQMUwEwfSkA8Rv8A3T+V GoaAI3PCqc/SnqAqAjg1DAmQUrCJ0osIl7U7AMYUrARMeaYETUyiqyfMaYH0D3rlLFoYdTkPiM3/ ABLolzj5q0pGc9zzq3WEyDDsGPX5a3dgLItxK6xBizOcYC1GnQBtxYx2ziOclG64weauwGjDHo+x QzsMDoQeKhxY9Bkg0necSrt/GhKQFwz6N5DR+agB/wBo8VTcrWElZ3Gf8Sd1w10g47MRUqMlszWd Vz3ES00JdrLdIrY678Gi0+jIskTpFpACldQx7eeRTtMLkhg0yYgvqZdug3T549OtK0gLUen6a2du xvo9HvCuX4LS1hcOkKB1XjLU4toJC3E0LoIWkEXf73ei5KSMu+02xu40Es4BB67gDSu+heiKf/CP aZg4uj1/vij3hAfDmnkkLcsMc9RR7wDx4btF4F26g8gg0e8A6LSIoiNtyZAT/FyaTUrF0p8srltd Nt9uWl5z+VRyM7vrs+w7+yLYk/vDx2pcjH9dl1QPo1qDhZfce9HIL67LsVLrw7aTncZ9hxiqUWjm r1PaPVD4PDlnHCcTE88kjpSakaQrcis0K3h20PSU/lRyyK+sr+UYfDVrgZlIOfSjlkL28f5Rv/CM WhXPn4P0ppSIdSL6CHwrZluLlsY9On1p+93Ico72ID4TjJBW7GMc8c1S5zJtMT/hE0wMXgLfTqPa i0yQHhNN3N2MduKPfAnHhS1AybpuPamlILkTeF7bcFF4VPuBR7yAaPCalgVvE68e9LUdyy/h92ec i9CrKfmHrznmhpgmJH4aCAf6UhHfiq1Fck/4RyMD/j6T8qNQuS2mhwW5kWSWOVXAAyduKabQmWod KtEAy5DBichucelWpsVhZtLtJYmU3Dc8rls4PtRzMLGe/h9Dy14pbpz2qbsYz/hHo+92o/ClqFy9 pWnppsVysNzGzTrs3kfdB64rNwbZaaILzRbafTbe1a7CiGV3344O7aP6Vqk7ElBvCtiM/wDEwAAH cVNmBNaaFY2pyt9uJ7Adf1qXTbA1s2n2XyDcg/NkEY9/el7OyApz2ts6sq3PT1Wp5B2MK9hhsrkQ xMspZMlsYIPNaWsK5ShlzJEAApLAZ9PeqbQrHW/Z7ee3VZrhfMHRhUNXER/2bac4u1xS5QSFj0+1 UqReoMHNCixjW021E5dbxMZzg9aTg2Bmy+GbeSV3GoRjLZxVpNDGN4Wt9x2ahHjtRqAL4YjRlYX8 RAPeizAvpo1rCwdZoVlU9fehIVytcaK0xZm1CNn+vQUak211Kf8AwiwJ/wCP6L1FNJlrQfD4cMDh lu4GzwAelF2hNk/9iyZ3efaD1+ShsAbRJix/0q2Uj0UcUXADo90SNupRdMjbgUXYWQxtFuv+ginz eh60XYyEeHGH/L3ESfep1Ak/4R8r1uY+OvPSlZiJBoWM/wCkx5HPWlZiF/sQ8f6RH+dOwCNoh6/a I+enNAETaGRz9oj/ADp2GR/2Gd3NxGPXnpQBE+hFWP8ApMX51Qz2QsAetcpYuR60AcZ8RIpJ4YI4 VLOT0rSGhm9WcrpHh66+0brhAqY5w1U3cqxs2Wg+XdiRpVBQ5UZqFdAkQa14dvbyUSIyMR0wcVrz NCsU7vwteJaxtDE7TfxjIxS52Oxnt4c1UdbN6ftAIX8P6ovJspfype0QDF0LUmbH2SUe+2qUkFrD ZtJvVYA2s2Bx900uZdynqRvYXIYn7LKo9Nhp8y7kjY7WYSpmGQfMOqmjmXcVjudLVggypz9K00tu Q0dLBGCZCoGFhyePYU1YTTMLW7CK4RHDiOQHBz6dqznFPYaZzWu6ftNvCpBkdsZ6CpVolGPfaXcW V15Eigt1yvIp8yKsXboRNYrEkREoxk460JiZSttLu7uGWWGMlYh83PShysPYqKWQ8E1XMwWhKs0g 70jRVproSC6lB65pWNFiJLdEi3rg8g/nU8rNY4u32R16lx5dvKN4SQZXB96aujKrUjOV0XJ5JbQh ZwyZ55PtUuMtzshXp2sxq32TxIc/Wp941VSm+w/7Wf75/OjmZX7tj1uT/eb/AL6NF2NRiSfaMjJZ j/wI0XKcIqJmq8ksuI3lLegJrZuy3PCl8TJrLzZb6K3Z5sFxuG48etDk7aMVjpPEem21nYJNZ3E+ /I3DzCamKktbknMrLcFd6zTkDuGPFaX8xjPtjj/lvLx/tGn8wJLe7d7iJBLISzgcseeaQHqF3oGn l2JjkBz1EhFaKJk5WZCnh3TWUriZduP+WpquQHKyFHhawcf6y4AJ/wCeh5o5Bc7Hf8IXYMM/aLkY GPv5pcoKbYieBLJ1Urd3S5HQmptYrmY8fDq3Y8X9wPrUuTKTJD8ObfHF/Nn1xS5mVYrTfDUEfutR YHtlf/r0czCxkXHw51OEHbdwsM9NxH9KpNkt2MnxlpUmi6RpVtcMPPZpWZkOc/dwKb0QRdzCfTQL Hzw75x0zWSZRljdn5WJ+lO47D7eRxPHhjncKmWwHWgQPATv2MRxgVz3dxXMAxqNQ4YlT3rS42bkP h+08mG5SVmT+Ieh9KbvYm5btoIlvIliGU5ByO1KN7gylc20LMwDADPak20BlawohWPYMAk5IqoMD M84jufzrUYnnHHU/nSHYQyn1P507gIJGY/eOPrSbE/IVpJFH8QH1PNK40mbmmaQl5ZCZ5ZEcg4Ga E7sRhus0bFTvyCQKpuwCxLO4baHO3k9eKXMh2FR5WkAJf35pOSC1jQ1CDZbxvAWzjBwTTurAkUre 3vJ93lB22jJ56UudBYfDb3Ex4mVT6M+Kd7iJ7WNlYpIdxB9azloBoxxKe361FxFqO2TI+UVPMI0r ayhaM5iU4reAGfc2sYYgKMZqZOwIpyQDoB7VNyirfWs0AAKkMRxVIC0toslhswRKRwfetBpnrpjT aWcZxXKrsrQqW91bTSmONgWA+7mhpoZNc6da3UWJ4g+MnmnEhoxG0TTwSBbpjNOwFeXw7p5ORbj8 KNQGDQNPKbTFj3BNGoCHw7Y/wmVfpIRQA4eH7dfu3F0P+2ppDHpooT7t9eD/ALaGi4Ei6XIp+XUL r6Fs0rjuPGn3AI/0+Y+xAov5APFncA5+1k/VBRfyAT7HOD/r0P1jFGghVhvF6Sxf98U+ZrYCWNr+ Pdtli+YYPy1SqMBr/a3++tu3flanmYWRG0c7HLW1qx9xSbbAQwvglrG1P4UrgUpLpUJV9Pg49BVJ uwFb7ZbIWU2Ma564U81UVdCZXMOlvydMiJ+hFPlfcBn2TSTgHS1/Bv8A61LUZYtdH0OZvmtCh9N1 S20Mtr4T0eQZW2k/BqjnYWL8Gi2UEKxi3bagwM81pGsxcpVvvDFhfy75Y5R9DxSdVsOVFaPwZpaN lY5SR6mp9o+47DJ/B2nvIW8ufP8Askf40/aDXMhi+ELJePLusev+TSc79S1UkiQeELIDrcfjijmX cpVpEum+GLTTpjJCs249zjinzIxauTnR4EuTOsTmRvvMFGafMhcos2mQFGHlykHqNtP2iDlIYdLt 4LaSBIZVjk6jy6OdBymO3gyyYkiW6XP+xR7S2wcoL4KtkKul1OrKcg7OlHtR2OiL6nIgD6qWA9YB /hWixNiXBCp9sQ5+3IT6mGrWKJ9mP+1Xit/x9wn/ALYH/Gn9aD2SJ11S8XGbiDj/AKZMP60/rKD2 ZNBrs0f35YWx/wBM2o9tFhyFpPExB+bycewap50NRLcfia1K/OcH2Bp3QxG8T2gOACfzovHuFjM1 PX5LjC2s4gA6naSTQ5pLQlR1Of1a1j1cxPe3Jk8nJXIPGcZ/lWcqlyuUrDS7IrgS5Hptpc2gWEtt Hs7OQyxuvpymRRzhYoyeG7R5yyXAUsc8L0NS5BYQ6DHE2w32COxU0BYjk8Mgv5i3ig9fumpuOxet dNmhDCO8XDDldpx9apSFYtxW8sSsu6PJGAQpGKtTsDRROisT/rx/3zWbd2LlI5vDyztulm3d8You x2I38LWznJbB9hRzSQAvha1BBJpXkATaBZAfPgY9FNVqBTfTNOj437fwNKzAtTvpk0EcLshCdDtw au2gXZJDLYqmxJOB6U1oIXbaeYkgOSnIytJzCwSRWkkzS8qzddq4zUNjsEVvZRkkJn/gFLUCf9wR jy2I/wByjULDlhiXlIGH0SkFmQXNrb7SJICA3fZTV0FjNg0+xtyf3r/Q03cLGkLG2jhWYyMVPpij lYWHhbZem+lawWJBPGq7VWQD2pqTCxWcwgn91IfrQ7hYryGEkf6MWI5ApJMdkD6igwGtwcdMjpWl gsiN9VXp5CjHtRqKyPVG5Ur61mm0VZGfZ6XBa3Mk6D5360SdwSsae3MJ/E04oGZTdTTJCgBjp3FI BlACg0AOzRcABpXGOzQAZpALmgAzQAUAJSAKAEbhT9KAMplBZiR3prYBYokbJZQfwrSBMhJIkA4U CraEiCRFBGBQMkhQbxxSaQzo7NcRDjtWLSKLGAe1FguPWNPSnYLjvJU9qfKK4otU9KrkC7JBZxn1 p+zDmYq2URPJIo9mHMwaxj6DJ+tP2SC4ySwjXuaTpIVyL7Ig60vZIdw+xJ60/ZIXMMa0jA6mj2aC 5C9ugqXBDuRmJR2qeVDuMaNfSiwDDGo7UWAjZF9BTsguRtGvoKVguNMa+gosAwovoKYhpjX0FFl1 AZ5Kego0AaY19MUWAb5Sj+EUwE8tcYxx6UANaJcgjgg5GKLIBGiD8v8ANn1oAaYgpBXilYLjRFgc Ej3BptAAVv4nY/jiiwAVYEFXI9QSaLAInmKGUnIPucikrgRvG2DtdgfqaoAkEjhDuCsvpnmlqAr+ Y/O8qf8AZ6UwI9shGC6t/vIDRYCF4QfvW8D/AIYo1DQi+yW+c/Y1B9noESqEjHyWw/F6NAHfaHHS 3QfjQFxv2uYfdjUfgKLBcQ3t2AQpVf8AP0p8oXGG6vif9cAPalyjuN3XBOWmJ/CnYVxGgDg7hn60 7KwElvbJnaFwBzxQBYCgVNgGs6J95gB9adgKst5CDw2fpVcoiu1yj8iM/U0tAIml9AKYWGFGkwWA FOw+U9SPWucoKQyUnEJ/3T/OtIEyMonmgQZoAWkAx07igCPpQAZoAXNIYuaAFzSAXNABmgAzQAZo AM0AI5+U/SgDKD5dhjvQtgJoeELHoK0pksqxXYnP3cDPFaMSCT74+lShksHMgpMZ0dqP3Y+lZMos CgQ4cUwHjiqQiQHFWgJA3FWA7dQIa0gAye1MBGfIoAZupAMLYHHNFxkbtmpuIgY1LGRNUjI2oAYe KQDDQBG1ADDQAw0ANNADTQA3FMBDQAlACUAJQAhFMBMUANxigAxQA0igBCKBDSKAEIoAbimAhFAD SKYDSKAGkUCGFaAE2UwF2UgA4UcnFAETzxr0OfpTSGRi7dDlFH40ARNJO/Vjj24pjK0keOSc1VkQ x0VvKw3LEzKehAqW0NIe1nckcQt9MUKSRY37De/wwMPwp8yC9h66dfH70TA0c6FzM9LPWuYoKQDp ji3OPT+taRJkZeeaBC0ALSAWgBrpmgCLGKAAGkAuaADNAxaQBQAZoAM0ALmgBrn5T9KAM0KOTR0A miHyY7GtIbEsiMKR/dGKpiRA/wB/8KBk9sP3gpMaOktxiMVkyiYYpAL2qgHA0xDs1QDlaqTEOyad xCFuKdxjC1FwEzSuA1jQBGxqQI2NIZG1ICNqQDDQAw0ARGgCM53e2KAENADTQA2gBppgIaAEoASg BKACgBKAENACUAIaYDSKBARQA00AJigBpFADSKAGkUwG4piExSuAwyopwOT7UDIpJX7cVSQFY5Y4 YmqsKwnl4609AsPQY4I4pOxSQMjtwo49qi4ETWkiKS3T0ocgR0mjEHTYSABwf51nuBdqrAFACGgD Z71mULSAW5OIBj0/xq0SzMpiFFACikAtABSAayg0AREYoASgBaBi0gCgAoAKACgBrn5DQBQHSn0A mi4QVrDYljZabEVX/wBYaQye1/1gpMaOih/1YrJlEopAOBpgOpiFpgLkCqTAXNACGncQ0mi4CE0X AaTRcdiMmkA0mkBGxpARsaAGHpQAw0ARmgBhNADCaAGmgBuaYDSaAEzQAmaAEzQAUAJQAZoASgBK AEpgJQAhoEJQAhoAaTQA00wGEgc9qQIryXaA4Tk0xkQZ5jycD9KLCAsF+VPzq7JIYcY+Y0XQDdme g/OpuA5Yz3NICaGFfMXiiwiZUxSAp6xMILJyGCuRxRa5SNDws5k0S3c8nkH86SET2v2wXkwnx5Wf kx6VVwL1IAPSgDa71mMXvSGJeHEYH+yKtEszqYgoAWkAtAC0gCgBrLmgCJlxQAlAwzSAWgAoAKAD NADZT+7b6UAUB0pvYCeP7grWGxDGS9abAqt/rDSGWbX/AFgpMaOhg+4KyZRJSAcDVAOzQIM0DFou AZp3CwhNMVhpNFwsNJouAhNADSaAGGgCNjSAjJoAaTQAxqYEZpAMNADTTAYaAGmgBpoAQmgBM0AJ mmAmaQCZoAM0wEzQAZoATNACZoAbmgBM0CEJoAaTQBBNcpFxnJ9KaHYz5rlpDyePSrSE2EKBuc49 aYD2Yt8q9PSlcCRY271NwJFjx2pASCOgBQlICSJcSLQA6QiMVMnYaOb8QJKLja5zlQwx6Gtor3bi bsdD4R40WIejN/OskCNqmMSgBDQBuGsxhQMbfcL+A/lVIlmdQIWgAFAC0ALSAKAFoGNYZoAjZcUA MoAWgApAFABQAyY/u2+lAFEHihgTrwo+lbR2IZG5pgVz/rDQMsWn+tFSxo6GL7grFlEgpgOFADhQ AmcUAGeaACgBCaYCGgBpNMQhNADTQA0nFAEbGgCI0AIaAGNTAjY0AMNADDTAaTQAwmgBpNACZoAT NACUAJmgBM0AFACGgAzQAlAhCaAEJoAaaAY13CjJOBQNK5RuLs8heB61SVx2sUWkOfWqtYTYqpkg jP0obJsWkiJxu6elSBOkYHAFAEqpSGPVQKQxxTKkdM9xSAVUwoHXHegByjDD60ANuFypxUy2Gipd 2A1HY6MolVQpU98d60pz92xMlqXNHCWNn5MjBWDE4qUwL32yD/noKChDeQ/3xQA03kI/ioA6TvUD CkAy/wChq0SzPoEFAC0ALQAUgFFAAKBi0AIRmgCJlx0oAZ0pAFABmgBaAI5/9U1AFAHikMnB+UVu tiGRseaYiD+M/WgZZtP9aKljR0MfCCsWUSCmAooAWgAoATNABmgApgITQAlADDTAaTQAhPFAETGg CM0AIaBEbGmBGaAGGgBpNMBhoAa3FADaAEJoASgBM0AJQAlACUAFACUAGaBCUANoAr3d5DaJulfH oO5p2KjFy2KEl2Z1D9FPQU0tSn7pCCzHpxVbENksduTzjFK4izHEF6CkInVKQx4UCkMcKAHAUgHA UAOxQApHT60ANkO3JqZPQZA8jwiLygu+TJLEZwKI6IC5p0SXKyGUAsD1xSiD0Lv2KH+6KsQfY4h/ CKAF+yxf3RQBtHrUFCjrSAhvz1+tWiWUaACgAoAWgQtABQAUhi0AFIBCKAI2WgBhGKAEoAWgCK4/ 1TUAUe1IomzxW62M2RtTAgX7x+tMC5Z/64VDGjoIhhf1rFlknSgQtMAoAKBiUAFAATQISmAmaAGG gBh4oAaTQBGxpgM70ANJoEMamBGaAGHpTAaaAGk0AMNADTQA00AJnFACZoAM0AJmgBM0ABNACE0A JmgBpYL14FMErmLquvJb5itcSS+vYVS0KjBswMz3cu52ZnPf+grKcr6I3clTWhs6fp80aDcdidkP NOKaOaT5nc047cLyeTVCJgmKAHAYoAWkAtAxRSAcKAHDrQA8UAKe1ADJl3bgPWpY0N2/u1B6qCBR 0DqWdGPMw+lKASNStBCZpAJmgDTPWoGKv3hQMgvjyfrVIllPNABmgAoAWgQUALQMM0gCgAoAKQAa AI2WgBhGKAEzigCK4P7o0AUqSKJGNbozGE0wIEPJ+tMC7Zf64VDGjoE4UVkUPoGKKACgQZoGFACU AJQAhNACE0wGmgBhoAaaAI2piGE0ANNADGNMRExoAaTTAYTQA0mgBpNADTQA0mgBKAEoASgBM0AG aAEzQAhbFPXoFyvPeRQj5mGfQdaTvFXexpClKRh6rd3E4/1ghhPXnms41Yydom0oqCKGm6Y07FiG WPPU96pty0RkqlonR21nHCAEQDHfFUo2Mb31LQUCncB1ACUhhQAUAFADhQA4UAOFIBwoAUnigAf7 5+tIBrdKAJNHOJ5R7CohuORavGulnhEC5jP3j6VqItntQAlAGmetZjHJ94fWgZVvT8x+tUiWVaYB QAtIAoELQMKACkAtABQAUgCgANAxjLQBGVoAgueI6AKR7UIB7HmtkQMNAEMfeqAvWH+uFRIpI6BP uisih9ABQAZoATNABmgAzQAUAJQAhpgNNADDQAxqAImNMQw0ANJxTAYxoERtTAhLP5mMfL60wAmg BpI96AGkFu9F7ARyBoueq96lSTdgsIHDDINU9AAsB1NCTFewwSBuVOfpTasC1AvjrSsMN2elAhrM FGWOB70LUZkajr9vaErF+9k9F6Cq5e4jGXXLu6nVC4jUnHApzk4LQuklfUuEOzFLdTJJ3c9BXG4y qO8mdzqcq0LFpo5LiS7bzH7L2FbRil0OGcm2ayRBAAAABV2S2I1HgYoADQAlABQMKACkAUAOFADh QA4UgFFADj04oAV/vmgBh6UgH6ScXbj/AGaiOjKaNitCRM0wDNAGketZjFQ4YfWgZUvD81UiWVh1 pgLQAUgFoAKAFoAKQBQAUAFIBaBhQAUANK0AVLwYjoAonqKEDHE81v0JGMaBFeM0xmhp/wDrhUSG joU+6KxKFzimA6gBtABQA3cM4zQAoNAC0wGnigBoIJoARqAGmgCNjQBHnPSmIaaYET0ICMnA5piE JoAjJoAaaAGE84zQAFwpKY+ciqsBFIXwFB+vtWfLZlXViKVW24jADetbJ2ZnJXIBbmU5lkLAdh0p 84lEmSJIxhVAFSykhHkVBlmCj3qHLoWoN7Gfc6lGFIt/3knYL0pc6UrDcFHbc5+a7u7+X95uKdkX gZrbmRLi0ri2mg3Uo+cCIH161FyTWs/D9vbsGcl29+lS0+pSk0akaRxnYoAx6U7IHJslpk2E6Uhj WbaCfSgAByAaADOKADtQA0Md+3BxjOaAHUgFoAGJCnaMmgBy9KAHjikA7tQA1cgkHp2oAkfhjQMb QwGKhjfejlT7VPKFyQyzf89WpgMMk3/PZ6Bib5f+ez/nTA689agkdGPnFBRRujzVkkANAC0AFABS AWgAzQAUAGaBhmgBaQBQAtABQAUAVb4fuqQGb/EKEA41v0IGP90/SgCvCu1Rz0pjNLTf9cKiRSOg XoKyGNePzB1I5zxQBJQMQnFAhCaAIjGDIr5II7ZpgSZ5oAWgBpoAYke12bJ57elMBWoAjJpAMamB GiCNAuSfqc0xDSaYEbc0AQyLuGM0CEPAx6UwIyaAGk0ARsFVldjg9BTSAl3rgNj5yMVb2AimGFBF S7dRlbzlzgnB96nfYTK894lvlIV3yHnGeB9apqw4xuZst3dsWPmBEHJOMYFTqzpShTV3qZJmmv7w BHkeIdT0/GjlSVzKVScnaKsa9tFlhHbjao6vj+VZRjd3HZU1fc0YLWKBcIoz6961sjJyctSfpTEJ QAY70AFABQAUAJQAhoAM0gDNABQAuaAHCkA4UAKKAHCgY4H5TQAsn3/wFIBtABQAUCGmgANAHWZ5 qBD4j89BVyjdfeqySCgBaBhQFwzSAM0AGaAFzQAZoGGaAFzSAM0AGaAuLmgAzQBWvj+6pAZYPzim gHmtyCN+FP0oAhjPFAzS0z/WiokUjfHQVkMdmmAmaQCE0ANLUwE3UwAGgQuaQ7gTQA3OKYDSaAGE 0CGE0DI2NO4hhNADGNMLkbNTERlqYDCaAGk0CGnBIJGSOlMYx22gs5xQIpXmpxWxVWJck9FGSKU4 aFxVyVo4b6HrkHuDgisU3F6FNWKa2KWcRQNlsZDnkk03Ud7FRaRlXCGcPbuwEe7czHqT7VcVJbg3 zFyC22RhNnlx9AvdvrSmxXUNi/bxhEyBVRVkZPUmHSmIKAEoAM0WAM0AGaADNACZoAM0AGaQxDQA tABQA4GkA4UAKKAHA0DHdqABzyPoKQCUAFABQAmaBBQB1neoEPi+8foaBlC5+8KskhFAwoAKQBQM KACgBaACgAoAKQC0AFAAKACgCtff6sUgMxf9YKcRseetbEEUn3W+lAEUfQUwNLS/9aKiRaN8dKyG C0wFPWgQh6UgIzTAbQA5aAHdqAEoAQ0xjDSENNAEbUwI2oEMoAY3SqAiagCNqYhlACGmA2gCtqBx bNj0pjW5i6YA/nFgGPqealnT0H6SzDUZlDELs6A8VDMXuXn5nwefrWX2hlfU0UTQ4UcLxxXQiUTI crHnmpe4mTx9K1ZI+kAUAFACUAIaQBQAUAFACUAFAxaQCCgBRSAWgBwoAUUAPFADu1AA/UfQUgGr 1NAC0AFACUABoA//2Q= /9j/4AAQSkZJRgABAAEAtAC0AAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAlgBwgMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/AFEZrnLHhOKBDghoAkVKAHhKBkirigQ9RimBIBQgHCmA4UwHigB4FAE0XAJp MDOv33XD+3yioGZTnLn61ixjSaBjMUAI1AFW7OEpoQ+MYjUUmgL+ncZ+lb00IwvEjjzF4/i61oSZ F+FZIyBg9KaES2sZMXStUIjn+WpYF/R0CZfNYTKRqBxWQC+aBQMVNREbDy+GFVLYpG5pXjMW8Jjn j5B4I70oysNjdS8cLPayxpF8xUgH3pN3Eih4UvpF4zj1HrXRATNCW8kiyM+taMk57UL15Z9uegqQ EsZG3jPrTQHZ6feiOMDpxVCMa+n+16g5lbAVQOBQMtWsNikkZkmYhiB24z607iNJGW3+1CFgyKDg +tDBGRcasHjO1AGrl6mr2Mzk8nrUvUzK1+dtu59qEgMTSW/esvrmuim7NGkFe5o6dlL8A+ua2xXx JhQVkzR1xPMurc4/gxWLWgjAu7PZNjHBqHsIrz6ftXeRxUp2CxM1lF9lVlQBqjn1HY07SPZCq+1Z t6lI1LIZB2jmt6ZDG3q4bOMc4oqLQIszL1cx59KxiUym0mYhVWJICaoBhNJARNVCG80Ad7sI6jiq AXFAhwFIBwGKAHCgB4FADxTAcKYDhQA8UAOFMBwNAEoGEznpzSYWMaZ87mPck1mMo5rNjCkA00AN agCpdnkD3pgTD7ooAv2K4UnHauiGgjnvEELvJuz8oyaG7CMh/mRM9quIjRs2UQ4NaJiKd2QScVL1 Asac2IjWEtBl0MagYpY4NKwFSKQLOwccEd6bKQSsAW2njNJKxTICxqhXNvw9OAwPtWsSWaF5Op3Y PStGSc7POv2kcjJBpBcu2Qywx60DN6OXy4+RxirSEYs+oLFezDsQMVLAb9s8xgEOOe1CQHQadMz2 MxJydhpy2EmZRjbPPFc3K0zVvQtLEgUZYdKCCnqkSG1fDdqEBzFi4juAQau+zNaW5p2smb9ST3rq xOsUyoKzcTZ1AZmtj6LWKehkUruWOIh5FyBUS2EmQ3eoW0lmyrHhsVki7jbUB7ZQRxWT3GiyowMC pYy3YSFJgAcc100jNj7sHbyenH9a1mtBIzrgZQiuVLUsyGyMirsQNzTAa1AxhphYbSEehrdZXYVG Ku4EJYbjikIetIB4oAXNADgaAHA0AOBpgOzQAoNMB6mgB49qYDrj93buf9nH51LGY03CGoY0VayG JQIYaBiGmIpznMqj3oAsGgDQsziE54reAjL1EK6vSb1Ec5MCgHGK1Wwgim2qRVIRFJJuNAGhp+wR nLAVjIZcDxD+OpsMXzYR/FQBVvGjdCUPzUDKySFBtYZosFxGlU9qdgL+hZVjzmtEhMg1C4kiuJBu 43EVbEUWBdw2eaQjsfC9ms+0PQUauuRLZqUUdRVok4XVD++DDg1LAn0JGmmPfBX+dVEDrdOBSzud vYt/OqktBIzHd3GCa5myhM+9ZhYqakcWz/ShDOWgfbMPrWhpS3NizYfaFb6V0N81Jepq9JNm7ePn yT6Cskc5j6w/7k0NCMcTfJis7DTN2w/49lrnkWizuC4zTgrsbNCBU2BsDNdsY2Ri3qJdcsSOn+NE xoz7kbVNc9tS2ZEg5NVYkiNIBpPFIBhoGNoA7jqaLkjhQA9Tg0ASg5oGPCmgY5UPoaYh4iY9BQFi VYH/ALpoCw9beQn7tMLDxZyelAWJFtH70BYljtD3IphYqau3lxKmfvN/KpAx5z8tRIaK1ZgIaAGm gBpPFAilnddAelWBZP3qhbgakAX7MeDXXDYRk3n3XrF7jOXnckkZ6Gto7Esh3YFUIbu5oGIJSpIB pWAkEx9amwCiY+tLlAXzj60WsAecfWgBhcmgDW0Bv3pFWgINXJF7KP8AazTAhi5IoYM7XwtdxWzL 5nGRUDRe8UziVsoDsHfFaoR5/qD5cc1LEbPhFo0mG/jLr+hqloDOksWDafcOOjZNVJ6CRlmuVliG pAp6n/x6v9KEhHKRAvMFUZJrW/KXT0ZsRwS28iPIpAPrWdKsnFo6ZmncTgpH9K1jojl6mVqcuYSM 0CZixv8ANSaEjqLD/j3SuWW5qhbp9oH1rWkKRqadLvgU+ldcdjMsXBVlUqOR1pS1GZF+So2msbAZ clAELdakBG6UhkdAxaAO/W3Xks4p2AcsCE8vigklEEIH3xQBJEIIzk80DLH2m3XpHQFwF7GOkdML i/b8dIwKQXA38nYAUBcT7XKe4FMLh9olP8RpBcTzZD/EaLCuSQM5bknimBS1Vi0yIT91f51LGZkp 7VmxojpANNIBhoAa3SgRSg+a5Y+lVcC0fvCktwNLcRbDHHFdMdhGVPyGrF7jOVuRtmce9bx2JZBu qxCE8UDGEHrUsBwpALmgBQaQBmgAzQBreHyftFUgGa3xfSfWmBUjbaQRQB0+iKbkLtHzD8KVgO01 CLGgSb4hkKMGtUgPJro5mb2NZyA1NFJSNn6YBamhHW6Kvm6RIF5O2qeqFsZ4QlsAc1ztMq4SIU6i oaaAztVbbavz2pxA5ixbbdow9adW/K2io7nUa5Ov2WBhXl4WMud3OlvQw5NQDYUcYFexY5W9SRdM v9RhMkERMfrUuSQWK/8AYl1DtZ1ABq1qFrGxbN5USo3UVi6buWpFbUJwMcGrhDlJbuaOhzB0IzWy JNnAMZ+X05oAxdRyTk/WoloMzZOlRcCu1IBvalYYlIYtAHdlTQIMGgQ9c0APFADgKYDhQA8CgBcU AOApgOxQA4CgCxAvB9zigDKvG33Uje+BUMZQl+/WbGhlIY00CGUARycKaBFazGXkPvTAtKMuMU47 jL9wStqO/FdL0RJlycg4GK5nuNHMakNtww9a6YbEso5wasQjNigYqPxg9KlgPwMZBpAJmmABh3OK VgDr0oAnitJZfurgeppAbGnRizGWPzVSAztUk8y4dvU0wIYgWoA7HQESGEMSc0IDem1YyW0ls3KO u3PpTTA4PVdLMEw8s7t5p2uBdji+x2aBsZkOBjuB1osI19Bu3s1DKNyHqtCEbLLpt7yC0Eh9KvQV ynNoVygaSOYXEf61MoJoLnK+Ii0cRQ8EdRXPy8rKRziNsORwavdWG9CR9RkljCOSQvSpjSUXoUpF zRbK21GbbPN5fpSqT5UEVdnoeh20FlbNDG/mLj72a43NyZrYxtUMQ+5KHO8jb6V1UZdCJ7FAEHqv NdSsZFDU4/3ZYDpQ2gE0KcrLjNShnVQgkEBhyDTAzdQjBVjnv/KpkMx5RxWYFZhSAb2oGgxUjFoA 71SDSAfimIXAoEOAoAcBQAtADlpgPAoAXGKAHojN0FMBwGDg8UwLCny4t3oC1JgYZ5yagZTfljWT GNoAQ0ANNAEM5whpoRDYD5WPvTAtRr+8AzinHcZo3agW4AHNdL2JMmQYzniuWS1Gc1rS7ZwfUVvA lkOn6Re6kGNpA0ir1IrZK4ijcRPDK0UgKupwQe1SA2NWYhVBJoGjUttLmkUZIX60WGNutMuLcbip ZfUUCKBWkBpafbxFdzckVIF/fjheBQA13wKpAZd2csaYDEl2DjrQI2NKa7kwqEhSfWmkB1KeFr2W JZ/tK4wOK1SQh8nhS9u4tsMqb15+Y1bjEDm9RsL6xuVgu0I8sbVwcispwS1Q7mlpuVjwaEIvEiqJ HpezWwLI5A9KTA4rxBqDXt5ISMc44rFmhkqu5sVLYEMymOQiqTGPtSyyZU4ptXFc3rTW7mzjKRnK kYOa53T1KuQWsshuvMZs7jmtYqxLZ0NjZ/bThJVVh2rRysNK5Nd+H5DEw8zt6VPOVynLwD7HqLRk /dOKroS0dbA+VVhVCK94AcjHXipYGLMOahgV2FSMaakBoHNIocBxQB3ScNikBMB0qkItAQbQOd1F hEPQ4oAcBQA9cI2SM0WAWSXd/CBVWAVCCKQD8UAKHdBhTimA1S5fmgCe9bZaSe+FpMDHc4U1DKKZ 6msmMbigQhFADTQBXujiM00IbYjEQ96bAuRL+8FOK1A1ltHuHSMHb710vYRn+ILA6bLEhYMH5BFY TVg3OR1tc7cCqgxM6D4cPIjSoGIGRxXQtAOY8WQmLW7k9mcmkAzR4stuIqQRtNC7AHcR9KBk8N8s EZjdVfjnNJhY5a7XZM2BgE0kDVizp7/KRQIuZoAa3SqApXCFjxTAlsrAuwZxgVLdhnS6fGsagKOl KMmx2PQdPkP9kngEhRW0SRdBuXnklEkXlkHge1UxGD42RftXI60+gjCt+M1CBlirJILo4ibtxSYH EX0bRzNu/i5rF9zQqbyvSluAySQvjNNKwy5p9q0jAngUpMDQkswozmpTHYrwybJB7GrRLNm1uhY3 8Vy5IiP3iBVNaAnY6iXVtL4kS9BDj7tZl3OG1iaFtWMlu2VOOatbEtnR6fJvtlIqriJLk/xY7frS YGJdjErYGBUMCow5qRkbUhiL1pMY8dKVgO5PBpgToQRS2ELt/Ci4hQhFMCReO1AEgFMA2A0XANuK AHqcUAPAoAfGo3CmBFqj/u0UdyWqWMypThTWbGVazGJVAIaQhpoAp3pwuKaES24xEv0oYF224lH1 q4bga0NwIbmJpHCqO9b1HZElPxdPFcTQGNw2PSudu40cdqYyVFa00DNbwnN9lmcjgGthGdrUMd5d SSMf4iRUt2Ay1nFtcrGpG3HNIaNxLmNYQwkHPai4GRf3SBjt70AZ+S0DFufSnYVyTT3xJipA0gaY w2k8CmBNb2gJ3NUtgTyKUGE6VIy5aTRxL+8bFCdmB1OneJrCOweJnIYLge5zWqkSP07xbpcE+JJC u49cD9apyAq+LdRs7y5H2adJcDnac0+bQRz6s27C0Ay6hJGDwRVWJIb2N5I8J1NJvQEjN1DQJbuG IpgOvB96iLuWUP8AhE7nHLCq5REb+GZUPL9Kl6DRZt7IwKF3dKyauUXBpwlQksc4oUQZjNaGOdlJ 6GtNiS/IVez27h0xVp3Ec6WRNy7PmB61DQXJHI2q2RTQzptBl3QbaYGo6kr06HNIZj3qndnFSwKL ioGiJhSAav3qTGiQDikB3bpk0CBMqRQBOpoEOBouA9TRcB4pgLQA6gAxQA8DFMCWIZycdBQwKGon /SNoPCjFQBnznipkMr96koQ0hDaAENAFG9PIHvVIRajGEH0pMC5Z/fHpWkEA7UFDDZ3rWWxKK0Wn yyxYVSSKjkuVcp3OhXUkgOwYrWNOxLJIdPlsMs4ABq3YRkNmcSAcEE1AzFvY9jfMuSO9CC5D57Bc c4phcQ4lPcmgC5Hb7o9rdKluw0TRwRxngVCkU0ToMnA60yAuZPs0eSOaoCPS55JZ8knGaUhl67u0 hUjIJqEgMia6eRuuB6VooiZsaDpx1HcokCbRnpnNO1wZm6lbPY301tIQWjYqSO9U0IgikZHBU4NK xR0OnXDTqNoJYdcGqTJLcc7GQkgjnkEdKq4FkndjHesqj0GjV08DAVq46bamW1oaBgUjpXpoxKd1 ZBlJAo5QOV1BTBOVrGUS0Ftfoo2txUIpFG/CtNvToa0TIZi3LyIdoyBQFyiWy3fNIYBjkUwOk8Oy 4IXNCA6tId0LEY+6TVAYt/GSCB0zUMDLYVmykIIyRUgMEeCeKBkgXikB3TKT2p2EJsPpRYQ9FI4o sBKIz3p2C48R0WC5II6dguPENADxEBQA4RigBwRRSAlRQF49aGtAMS4bfM7epqBlKY9qiTGQ4qbj ENAhDSAaaYyjcczoPeqRJPPJ5SAjpSWoF/TiJMMK2irCuTzFTOBirYjf06BRb5xW0UTco63cLaxH tnpU1HZFI4e/vboqVeUletcyk7l2sQWk0Y68E05NoEizLZQy43bRmnTldiaM6400gkKmR7VsSMh0 8DOVINACndHkEcCoY1oNHzcgipsVcmtiRIKexAy+tzdMU3bSPWqTAijcWcZVfvUPUCjLKWYs5ppA RGUZpsDs/BKszOVBxt/rRDcZj+NGMXiK8B/v5q5JkmRDKrMOeakZp2ztEwdTgjvSEbVvciZT03nr VpgdBZ6W8sKuXwMdKfKmJPUuWlttucA8KK54RXOXJ6GiRXZYxuUry+jteJeKluw0jj9cuI5bndGc jFZSZaRmwxNO+xAM1nctFyTTrhEIZeRTUrCcbmLHF9p1BbaQlQapsk6A+BkyGM52kZ6VPMaqNzld X086bemHduHUGqWquTJWLWmzi1dWPAzQiTsbS6RlBDj5h0Bq7gVr6MHIHHapYGEGBlK+hxWcii0q DFQMiZBk0mUN20gPQjE2ThTWqiZh9nkP8NVyAOFrIe2KOUCQWjkU+URKtowGDT5AHraH1o5AHi1P rRyjHi0HvT5QHC1A7UcoDhbqO1PlQDbgCKEnphSayqaIEc43TNYdBlOX730rOQxlJDEoENNADT0p oZQJzdqO1WmSP1D/AFJoiBf8PYZOTzXREkmupCl0D2BxVMDq7SZBZK3tVohnNeIbrzwYwo/Gs5al o46+t7hzu28YxwayjT1G2ZZkMXBHzA1bjcEy9DemfaGJQrURVmMtW9wfPAcbhWpJdkMePu4pDKYU FmFCAZJZI3bBpiuQL+4mAPQVLGNurve2F/OhIRQlbCk1VgKZy1MBywsTxTA9G8ADbCykZ4NKO4yH xPpsE+p3cjoC2Qc49q3vcg4m5tVjmwvyjNZyQzbsLO3kjXfdbTj+7QnYRoWumK1wn2eVnOc4AHNN IR3cFtJBZKGUghau2hK3ItNhkmaRwp64rKnG0i2y69u4BG3muixmcP4pW4jmw4+TPBrKcTRHNkk8 nNYuJSZq+GxDJqUaSc+1ZVNCkdb4sgtrK3ikibYzHHXrxWadykeVRXJGqpJ1w9dDVkR1PU0nJsIZ FTd8oBxUrVF3scN42j/0qKXGM8VotiWc+zEoBTJJ9OndLpPnIXPrSsB2sieZEpzwRmmgOdmTyLkj 15rOQ0SrLgVnYY3fSsUAfikB655QyeO9dtiBwiHpQJi+VjtQACOgQ7ZQAoSgBwWgBdlADttMBNtA FDWDttmHrgVzzKRzsnArJjKbck1m2MbUjEoAaaBDH4BpiKEPN2T6VYE96u6A0IDQ8OhUgLEZ6Zrp WwitqcjG6yOAW6UhHS6duaxXg9K6IozZh6tFJ5wAXrWckWihLaSlcYx+NTYDndUs2gm3OMA0WGNg sy4DqSRSsBae1MO1uabAkEh9zUMaGxviQ00DLYIIpiM3UBtkBHFICmTQBHJytAFWMYPNUBY+70oA 7zwDznn1ojuNmf431GW01aaNejqD+laMk5TzDMRk/NmoA6PTdNUxK7nNUhHQaUgiuUMY2kdxVIk6 W+v5Ut+T2pMSIdJmeO0DBuWOacFoBLPekZJbmrEYeqIt5gyngHNJlI57UIowpEa9KhlGNGJVk3Qs VcdCKxcLlXJNWvL68ijF1cFyn3RSVOwXM3T9OWa42yOR6Yqm7AjWTW7/AEmZ7PzN8aHC7vSpY3uU tY1KbUiqygDac8d6tBIy344pkjUOHUj1oYzubHMlghJ5xikBl6tCElDg9eKTGUtxxWQxUbikMcG4 pAe0gYJ+tdpAuKBC4oAMUAGKAA0AAoAcKAFxQACk2Bka3JlFT1bNYSZSMSUfLWMhlE1iUNpgJQIa aAIpThTTEU7PmVzVgWbj/VGhCNLRBttSVHGa6VsIxdVkMd0vPc4FIDpNIu2Njjd2rVMhmLrV03nD 5zUMpGW945Xlz+dICnOfN++c/WgZFaTSRzrCh+UmhIC3rUrwmJVPOM02BlfbJQetJoaLVvIX+Y9a Qi7HcBeopgV9RlEighQMUAZ2aQDHOKAK2cNVAPL5XigDvfh6SXPrQtGNmT8SFI13pjMa/wAquRJy 8Bw4+tSM7PTpgbROapEmzpJBnBq0yGX9XnxDjNKQ0OS5WG2RemBTT0Apy3OTkmgRUmmMnyjpQMoa iyw27Y60mNGNa3UaBtwyazuOxUu7hZJOARRcaIopnt5RImMj1qbDQmoXQu7nzygUkAGgdyu77jnp xQhPUrscmqAYaGB1/hyYtabCchecVNwJNSiD2+7+JfmoYzGPSswBOlJjHU7Ae2H7x+tdRItABmgQ maAAmgAzxQAbqAE30AO3igBjPgGpYzFv2LzAHsK5nqxkMtqDH8vJ9KvluMyLiGSFsOpXPSueasMg NZoYhNMBtAEU7YQ00Iq2ByrN71YixIcrSQWNvTCVsvlAA5rqjsI5PXARchs9vyqbiL+iXmICpYD6 1pFkMpa1MGk+VgfpQykZZmwvWpuMjMwHXigCxpcfmXqt2FNCYzXJd98yjovFMZmMD2pDLlsGCUhE 2W9DQAyfJSgCrQA184pAQhMmmApXAoA7v4eH97g+tHUbKHxMH/E4iPrEtaSJOQj+8OagZ1GmyD7M tNEm9pNwiZJNWmSxNWvVcAKe4qZSGkRveA/xVSkBDJeKP4qLiKj6kqnCEGlcoztRuyyn5s57UmwR QR5Yo94xWZRHLI83zMVGPSmBCZOOTQAwvnoaAHD7tICJlINUgGbTmmwN/wANttlKk4z2qAOhmt0k idTxnirsM5mUbGZfQ4rJoB9rC87rHGuWPShRGdJH4XYxqS3OBmr5QPQi/J+takhvoATf70CDfxQA nmUAG+gBPM96AG+Z70XAPNouA5WDKffipmxmRcEPcuR0BrC12UQS3H2aSNZMgHkmtUiWM110lit3 jIIyaxqDiY5rnKGmgBpoGVbxtsRpolkVhkQZ9apgWlGWApR3GzajJjsiOgxXX0JOM1mZRcyoDk45 qGgM23u/KP8A9eqRNgnuNxzTBFN52VjjmlYY03DP96iwI6HwrHu3yHoK0WgmZt6yPdyuT/EahjIN 0fSgAjudhIJ4poBzXo6bqQEZut3G6gAFACkZFAEaL83FAFsWjyxnaOcUxo63wAGhutjqcgjn0pIC p8UG3arAcY/cr/WrEcUGKnNSBt6fP+6ouIsyXEsallyF9qVxFOS/keNiGORWfUpFNr65B5c4rboI YbqVnGXJBoKW46F3+0Abjg1K3CWjLvliSYK3IraKuzOTG3a/Z1wvI9KVRWCDM2SYtx0rNF9SFie1 AD4jQBOKQBigCNh81AGpoxxdIOlSB2rRLtAYYzk5/CrQzldRtjHdGNOS3T8amSA7Lwj4e2Ks0w+Y 8k+lVFWEdosEQUDYOBWgrmaZ+T9aQxDce9K4DPtA9aLiD7QPWi4WE+0+9FwENxRcBPNY9AaVwDdJ 2U0nIdhwErdFNHMFiwuY4stxhSaibGZsPLfjk04ITGS+XfI0Mq4Y9DWgjNXSL6IGLDSRg5U+1ZTj cpaEVxaTW4zLGVHvXO4WKuVjWYxhpgUdQOI6pIlj7QYgWhgWYhmQU47jZuTRstkS3TbnH8q6ehB5 vq7L9ul2HgHGaQGc5OOKoBm5u5p2AaSaAELZ4xQCOv0FfI0aWbp8pNU9hHISSF5GOTyamwxQTjrT AbnnmgBeKQDlIzSA0ba2mnj3RRO6jqQKaQriMhGQQQfekwGx4V/egZb85kHB4pgdL4Kbde7s9Mfz qRlT4mkf2pBj/nkAfzNaXEcVSA3dJtXlg3A/LUS0A15YAtk468VCYHMLkB/rTQyQ2/mRZHUVt0JK RyrAHqKT0KjuW7Zf36GpW5c1pc0oh/pa1tszB7EOrrsdlqqmwoGMetc5o0BFMB8YoAlWpYD+lIBu 3JzTAsWx2yKRxipA7e2mMlmpJycYq4sZSulC3Szxn5hxzWlhHZ6BrUVxbeXwrqMGmtyS4dSUH7wq 7oDLkJBPzVycxpYrPMQcbqXMFiJ52HelzBYbFOxfk8U7hY0Y8ECmFixGq0XFYtIuBwKVyh+fakMe o9KYiG/fbC3uMUmwM2FgCc/3TWsCGSRbdyk1qkI3bWdBGOB+VDQGH4yvEbTZEjAEmR27ZrGUblHL oSUBPWuSSsykIaBmfqPQD3qkSy1CNsSj2pSBE9r/AK5e9VAGbmpMVsPm4/xro6Enl2oMrXkxT7u4 4pICm1UA3IxTAYaAGqMsBQB2lyPsnhlhwNwAqmScT3NIoepoAB1oAcBSAcBQB6n8LGjksJY2VSQe 4qouxJyXjULb+IrlIwFXIOBUsZg7+RSGTwS+WdxVWHuKAOn8ITqt0XEe3joPrQtBlb4hzrNqUW3+ FCD/AN9GqEcg4x0oA6fw0262ZaiQGlMQYHX2rNAcnL8jOMY+arQ2W7U/LW6IZQvkxKSKmQ4smsXU uvPIqEaN6GkzYuo8eta9TO2gmvrtmB/vLVz2M46MwD96uc2HY4piHoMUASCpYCmgAFICaKkB0emX LC1IPYjFXERHc3G3PPJrYRShvpbWYSRuQR2rKTsUkIdRuWJYzPk89anmHY9AnbBPasyilM+KTArF 80gJrfqKoDVg6CmIuRAUAWVFIY8CgCSMc9KAM/VnxtT6mpYMzmfajn0St4GbIFutqKfatSQOt+QP vUm7AijqeqpexFe5xWTlYsrjGOOlcs9S0IeKlAZt+cyoB61aEXlGFA9qQFiwGZ1471pTA1daylnh z8v+c1uyTy2cgyuV+6ScVKAgIqgIyKYBigCSziL3UaAdTTQM6rxVmDSoIum45qnsSjjT1qShy0AH ekwHigBRQB3vwvudl1LFnGaI7iZl+P1x4kmPqoNEtxnNtjNIB6dKoDp/DMp8w/Q9KgpFLxod2pOf emJnO4J4xVCN7wzJtLL7VnIDfNnJJG7xsnAyQTziko3AqyeFhe6Y93byEyLyV9a1jEDn44njJRxg 1Sl0JaILlcGhgiGBWR969u1Rc0SujQScO8bd80yC94gXKQsO61r9kz+0c0fvGsDUetMCRaAHikAV IC0AXrC3MhyelNK4Gq7LBGAvWtuUkjhtJLrPOD2ouNIzpUKSlT1BxWEtyhwjOBxRYZ6DcN8xrMZQ mc9KTAhHJpAXbVasLmnB0oEXYQMUwJ1YCkMkBFAEisMGgDF1N99ywH8IxUgZ90SkEx9gK3gZsxXv MJtPB6VpsKwkEXmHLdK5JzLSJ/KQdBWV2VYXHHFK4xj9KBGXP894gq1oI0e1SBd0o7bhSOueK1pA W/ELg2hD8AL+lbNknl8nDGkgIjVAMNMBDQBpeG4vO1SPPReaqKE2bfjyYb4IV/hWlLUSOOPWhKxQ 5aAAdaTAkHSgA6UAbvhG/Ww1NXdtqnrQtGBJ4vuku9ZaWNtwKjmlJ3YGGaAHx9KoDf8AC7kXPH90 ioe40J4zGb4npkA/pTBnOYIpiLukzmCUkVDQGzcS3EkZliJVSPmx6U4JgbvgzUNsrW0hBR+mapNp gUfFWnJZ3r4GFf5lqmrK4nocvdLin0EtRlsPnx61kzpp6qwOhiuFx0Jq+hhLRmxrQzY27e1ape6Z Pc5l+JDWRqPWkBKtIB1ABUgWbS3MzjjiqSA20RbeLA61qkJkSFZJgrnrScgR0dvbhI1469/pU3Gc vfWzJfOD0PNTbUdyZYhtHHaqsK511y3LVzFmdIxzSAWIc0wNGBcAUxF+EECmhE2SKYCqCp6mkMlD H1oAsxHCDJ96AMR3DSu3qSajqA5Xj8zDAEcda6I7ElTxJawtHGY1AYk8ionKw7GbbrthUe1crdyh 5FIYw0CI5OhoAy4xuvvpV9BGiKSAv6Sv77I61vTQCeKX227b+Bt//VVsk8+ulwVI7ikgKpqgG1QD TQB0XgiAPeu5HQVcSWQ+MJ/N1dwDwvFS9xowG60xi9qQCD71JgSigAoAcDjkcUgHBixyTk0rADda aAcnSqA3PDH/AB+AGoe40WPGabbpfdF/lVAc05ximInsV8yQHpg80rAb9xeKlv5MYGSOaV7AVNNu GtrpSDgqcinuB2niO2Gr6Cl1DzLEM8d/WtYu5LR57ccrzUsFsRQHDA1m9Dakx104LDHUVVyZLUvX tyk2nRKD8y9RVRehk46mDJxIagsctICVTQA+gCe2gaZxgcUkhG5BEttGPWtUIgmm5qm7AirHKfOU jjmueTKOvtp82obP8GPzqojMjUApvCQc4AFaJEkQYY7UCOmujjI964zUpEc0ATQp3pgX7cA1Qi4W CLnFMRJGdwBxigB9IBR1pgT3MnlWsjei0mwMJW4rIoy9QvGhk+U4OK3gyB63cl1GocfdrObKQ4AK MVgUNNADGoEQy8KaAM6z5unNadBGgOlSgN3QEUg/KM46muqmIzPG2BbSEnGAP/rU2JHCXCkwq3pU oZSNUIQ1QDTQB1/g2PyrWSfp1NUthHL6jM1xeSSE8k1IIqHrQMXtTAE+9QBNipAKAHAUAC8GkAp6 00A5OlMDY8OH/Tl+tSxoveMRh4if+eYqgkctJjjFMlC2rOJPkqWUbEUTbAX61ImVJ5DFOD6VSGd1 4M1NZozaSnKuOKuOhLOZ8R6cdP1CaHHy5yv0NXLYlGLHw2KyZrT0Y+VcSD3qTa2oSgbcimnYqrHQ oS8SGmcthydKAJFpAWbW3e6mWKIZZjii1xnoek+C0S03ySsJMZyOlbRiSzD1q0lsZWVxlQcA1TVi EYUkhYnFc8maJDQcHIrMZu2t9m0A/iU1rFCKk0u3LMck8mrEUzdc0hncXY+euUsgVMnpTsBaijwK AuW4lpiLSjjpTEPAxSAWmMVeCKTAr6nP/o5Q/wATVm2FjMB4qRlG9tBMwbuKE7CsPRAi4qW7lCmk Aw0AMagRXnOIzQBQ04ZeRqt7BY0AeKSEdJoaAQFh7ZrsgrEnN+OG/cvuPIYcepoYHKoBJYt69ayG ZhrVCGmmA2gDudOQWfhiSTofL/nWj0QjhWOWJ9azQxnemAtACxjmgCcCpAXFADsUAM6NSAU9aaAc gOOlMDW8PnbqEf8AvUmCNTxsMrbsBj93z+ZpjZyBPFMkls5fJk3YzSaKRoDUWPGwVJXIIlo14+WY IKCWrFqxn/s68QRSbipzmquI6PxVt1LSYr6P/WRcP9DWid0Szh0OJMVDKTJJ+ACKk3bEdvkpFyd4 lGX71UcwqdKBEqcnGKQHpPgPw5tjF1OuHYZGewqorUGdu4H3V4UVqiWcD4+1KEbbOLBfqx9KcnoJ I4tDxXJLe5p0Hqu44FCQi4hEKelbpWEJbWdzqc4jgQtQwR0ieBpSikyHOOamwzSuRmQ1zIsRExVA yxGtIRbjXAqhEoFIBwU0AOCMe1Ax8cZDZPYUmBmasR5qJ6DNZsZS6CpAjY0gRHipGIaAGmgCM0CK l4dsZpgVdNXERPrWj2AvpyR9alAdbpUWy23L1z09TXbHYg4nx5y4+bgP+Z71LA5y0GYiM9RUPQZU vIvJmK9qqLEVjVgLEu6RV9TigDs9bf7L4bSMcFyBj8KpsRw9ShjR1pgI3HSgB0Z+agC0KkBRQA4C gCM/fpAOAyaAHxkrwDVAaWjNm9jPAORSYI1vGeBb2/IOVOPzpgzjiOKAH28ckj7Yxk0mNF0abdg5 2Y/GpKuJMtxCuGYimiWymkrJLuyaoR1mm3oezeNjlHUqRVRYmczL+6nZD/CcUmA+Rg8dSbJ3RGDm OkV0K7gEnmqMQWgRv+EtKOpakmVzGhBPHWhAe0QwrZWiouM4xWi0AyfEGqJpWnSTMRvxhR6mr6Ed TyG8uXurh5pCWZjkk1hORdgjBxWe4y1GmwZPFWkIv6TpFxq0wCqVizycVoI9J0bRbbSLcHaMgdcc mmkBMdctVJXcnHFOwGDJHlz9a4jQciVQE8aUCJ1XFAiVQM0DRMpUUFEoxigQ9VbYxVcnpRbQDnNT kEl9JgYC4WsHuBVJpARmkMQ0gGkUAMNADGpgUNRbELfSnEBLBcW496pgW4ATKoHrRAk7GxRktAec gHHua60I888c/LdoAcqCQPc9zUsRiaa2ZNtRMaGauB53SiAMzjWoizpcYe+hB6bhxVAdB4xnX7Lb Qrx3NDA5FjikAwAnpQAHOaAHJyRQBbWkA4UXAeAccUgIiDvoYFq30+4uCBHGT70Jgbdn4TuXHmSs EX25qkx2NaLw1a2kfn/aHEi84IGDVMViHXdPiuhas7lcZHFSOxWl0W1EWACMjGQKBWM6PSvsdyJF fcmfSpYG3EYph8rA+1Zu4GZrVqNmVFWgOXdSGqgNXR5usbHg1QFO+Qx3bqeuaYiNXGMVJaY1G+Vh QaX0IT1oMnuPiBYhR1PFAj1/wBpC2dqJHX5sAn600gOnupB5mP4UFapCPKvGusnUNRMMbfuouPqe 9TKQWOaHWsGyizEQmCaEB0OhaNJq8inBEA6+9bJEno1nZ2uj2w+VVwKpIRSlvpNQk2W5+TnJpMYL 4cVlBYZJGTRcZWZOTXLYsESgCdVxQIdQA9BQBKqDOe9K5RICAKEIsxOiou7IHUmqvZAchPIZp5JD 1Zia52tQIzSGNJxSAQ0gGmgBhoAY1MDM1Q/JgdyBVRQie2XEC03oBYtV3XCD3pw3BnY25EFogGD8 vHua6yLnmnjJ2e/UfwqOPfnms+oGXpOPPqZjRHqpzcGnAGZ5rQRoaAm6/U46c1QFnxXNvvFTsiih iMELk0holRABQVYjeM0XFYWJcdqBFqFGkbai5PtSA2LLw7d3JGSkYP8AeOf5U0BuReBHaLcb6Me2 w1TQE9t4Igjk3S3ob22D/Gk0Bt2ujWUAH+knA9AKnlAviK0jVlEzlemeP8KrlHcgmt7Rl27pCPrj +lUK5FcWWm3McayrIShyPm/+tSAQ2diFUeTke5P+NMCGSzsAf+PYfr/jQBELSwjfclsgPrik0gKW srE0GViAx3ApWAyzZ20kSuYU3Z67R6UgK11ZwROHhjCH2pgZGuR7WSUD7w5piMz+GkMasm3OaVir iZzQSa/hiz+16kmRlU5oA9u06IW1mi9MDJq0Bg+LNW/s7TJXBxLIdq/U1p0EeTMxZixrnkMB1pAd L4a8PyapKrupEOfzqkgPTIo7XRLLJ2oFH5VsiLnKXF5d+JLzy7fctqp5YfxVLY0jrtNsI9PtlB4I HekhsedXhBxuHFVYRkEZJrjNRyrgUxjsUEiigCRBSYEh6UDAHnFCAkvmWOwmbPKx4/GnIDlB0rBg BNSMbSASgBppgMakBG1AGVqRy6L71pERejGI1HtUvcCeyUtcqB1rSG4M69FC2oX+ILge5xXUQeW+ K33agyg5VBtFZ9RmfpZxNUzBDNS5uDTgDKBq0I2PDS/v2Y9qsCnrMnm38p7ZpAUlFDKRIOlItCGk JoQUyLGroYBuAD61LYHb2hwg7CnFiNBT8vBrQBSeeTTAFAosAyadY+ppXsBWa/I+7ETS5gGi/cHi Hii4wbUZCP8AV8DnrSuAQX6Tttxtb0NFwJ346CqJKd4N8LDHagZgNqENujJIcGpAiW9hulGxufSl caK+uIDYqcdM1otiWc3k1JQYoEKKAO/+HWnbyJWHU5/CiwHpNw/lw49a0ihHlnjrUDdakLZDlYeO O5NEnYRzLRvHjepX0zWDGbfhvQpNSnVnUiIH061SQz1K3Fro1lztXaPpitVoFjlriW68TXuxNyWa n/vqi4+Wx1dna22j2oJCrtH5UJEtmHdeIRfzNFbt8oOM561LkCRSaVtxqeYo3imGOfWucoXpTAKB CgUgHAkUAPDUAPh+aVRjvTiBH4hdUsAAMF3x+ApVBo5usQEqRiUgEoAaaAGGgCN6AMm7+a7QehrV Emj2qGUWdNVjcjbWtMmR1N18tqSPvY2iukk8r8RuHv5Nv3RwKzW4yvpaZYt6UpgitqB/ftREGUjW gjZ0b93A7dOKoDHnffM7Z6mgEIKllj+gpFDTTABQZs1NDP8ApI+tSwNnVdVa0iCIcMelEQKGl6/c x3aBpC6McEGrEd3FIssSOOMjNUgJOADigDIupSZz6CpY0NZ8jjipAjyx70WAeD8pGecUMCskbicM OKLsZuLuZFJ7itLisRyRsyMCvai6FY881u3n/tKSNUY46UroLFezWWG6UFSpz0pbgkbWs82Cj3NX bQTObwKkoaR6UCHJGxkVAOWOBQB7P4MsBaaeuRzgChAaGt3i2trLMxwsaFq1RJ43LOZ70zSHJZ9x rGo7saR1Z0hNWe0aM5jA+b3oiijr4Ut9GsxwFIH5VewJXZhPLca/dBQStsD09am9zblSR1VtDb6P aAnC7R+VaJWOWT1OE8T+JZL+RoYGKwjg4/iqZSGkZugzEXIB71hfUs6ZVGBVgbMMzzAuy7c9qzKJ OpoYDsUhCigBwFAC0gLNkP3ucdBmrSAzvE8uXgi/uqWP41lNjRh1kMKQCUgENADTQAw0ARP3oAyc 79QHtWi2JNM1JRoaLxcZ9SAK1pIlm7qLL9mYqwGflH49a6GyTyrXHDX0pXhc8VC0GJpBwWqKgIpX 3MzVUQZUPWtBGrE3k2DdjimBjjrQCJFpM0Q/tSKGGmSAoIZpaKcXI+oqZAa2r6Lc3yLJaIZGHVRV QERaR4Uv/PWW5i8pVOQCwqm7AjtYokgiVN6/KPWp5h2Hb4xx5nH0pcyCxn3MCmUsJMg+gqXMLDBB H3ZvwwKnnHYXyox2J+ppe0Cw7agHCClzjsKGx0AFLnYWLNqlzduscRA9ycCmpNgWb3R7y1j3yOpU 88GrsxHH6qm25DHr3qG2BXZVMqMQM1UHqAuoJ5lqg966SDmGGGI96kdwxxQBveFdP+3agjlcrH/O gD2G1jW2tljHYc1SQjjPiDqPlWa2yn5pjz9BV3shHH6JpEup3AABEYPLVgWj0q3hg0SyGcKVHHtW sRLVmA0s+u3ZAyLdT/31Wc9djojaKOmtkg0i23NhSB+VXCOhhOTbOL8R+I5NQdoomIhH/j1EprYh I5tmyxrnbNCxp8pjuVIpIDsY5AUXp0FXcVjoMYJAGBUFDgMUALQIBQA4GgABoEXbHaFYsSM8Cqjs Bg6/IH1SUDogCj8qwnuUjNNZlCUhAaAGmgBDQBGaBEUvCn6UAZdr81859DWi2EaRqehRoaMMTAjr nitqJDNDUCTCQeB0H9TWsgPMtVx9rfHTPFTEBdMOC1KaBFS65laqiDKwGXFaCL12+y1C+ooAzgKB pEq1LNEhWIAoBkZ6Zpk3FWgi5o6Rxcj6ipkM7eylMSDaalOwiZZZpDguRn8KzlNsuxt6PaaZKu27 fMp7McVcWBU1eztYp2Fm24Drg5pSQGXgdKy1AMY7Uh2FpAFACU0A8Xgs42kbIAHWtYA0YF94hv7m 8ylw7wDgITwBWpJXvLhpgGkXa1RJANDZCH0NKG4MuPHvhQY/irqIORmGJ5F9GNSA0IWOBnn0oGen +BdJ+zWyyMOQMn600B1sz7IzzVCPMdaEuu+IGjiz5SHaD2AFE9gSO10uxg0axViFUgcZ/nUxVxnP 3VzN4gvjDCSLZT8zetOTvoi4qx0dvDBpFoCdqkDj2pRVtxTd9jifEWvvfzNFCxEQPJz1olLsQkYb NgVhuMYKdhksTbHBqRnTRXS+UnP8IpgdmRyaQxcYoEFAC44pARuPQ4pgKpxQI0LdlSMbhwOSaHoU cpO/mzyOT95iawYyOpASkAGgBDQAw0CGGgZDOcI1AGdpwzNI3uatiNA0kM1tDUb89wK6KZDJtZU+ WyqcDBA/qaqYHmmpH9+3vSQCWBwxoYFac5lb61URDIlzKKoCW/OcL6UAUd4FOw9i9pyRzsRIdoHe ixSlYrXWBKQp+UGiwm7knyCAD+KgkYKQF7Sji5H1FSxnbWpHl1AyVZFVhuBx7ViykJrKLcRwmBHZ wc5HarhsU0aHhTUEs0Nve25GSTl15q0yWVbso1zIYhtTccCspMSGKOMZqShcUgDbQAhU44oAz7iZ lZosjnHB71adgsRzWMO1ZZiqf7S4xWnNcXLYx5SskmAeOgobELED5f0ojuSzZslEsaf71dRBxNyp N1L/ALx/nSYzS8P2DXV6gxlVIJpAevadCLa1RAMEDmqSGZ/iK++y2bBT+8f5VHuaokqeHdMjtoPP kXnqc9zU2uXexm67qE2rXv2C0JCA/vHHYelXflRJu6bYwaRZBiACBwKhLUq5xfifxA97K0ELHywc E+tEmI5+OsGArnJpjEWkA8VLGaKTgIvPakB6Yep+tMYUCCgBCaLANZgKQWI9+WAouFi7dv5VjKf9 jAoloM5kVgMQmkAlIBKAENADTQIYaBla7OIzTWoFTSh8jH1qmIvGpGamkAj5gOQOK6aZDDXHkNux UdFI/wAauYHnN+cyVKAZattY0wIZD87fWmhD7YZkpgJdykbhimgKSpuplJFmFHQHY2M0rl8lys6s rHIouQ4tCoSTTJJRxSAuaaf9IFTIZ29kpZMVA0NuwyRnggismUVLDUxvCz7qNkO5r3NyJF2xEsOx PUUXEQQAsDnrUsRZSOkUPCe1IBdlAAVFAGNqsOJQfUVSGZksbOoUu20ds1VxDba0HmdzQ5BYv2ml yXt0YIuPerp6sl6GqNKuNJkjSchlZuD+FdttDNnCfZTNcyem4/zqGB3ng7SPsy+ZIOfvGgDrXkCK Seg/nVIL2OUljk1TWQ5P7mLhfc9zQwRPruoNDCllZ/65+Bj+EetEdAepY0PS49NtfNm5Y8knqxpN XY9kc34t8QtO7W1u3HRmH8qbdkJHJDrWLZRMvAqWA09aYCrSAfUsY8Hgc0gPWz1NACUwGk0AMd8U gIWekMdbDdOg7ZqooC9rsiDTSAMF3AFTU0A5qsRiYpAJSAMUANNADDQIaaBlLUTiBvpTiIZpq7bc GqYFo1IzW0ZiAeCQP511UyGVvEtz5ds4Xsu3/GnIDzuc7pDQgGK200wGtyTQgJ7ZcKTTEMnEbIc9 aaHYgQCmy0jTsIVfqM1DOuERmpwKvQYpJiqRRlIME1ocLJBSAtaecXC1MgO70z+GoGjYkto7iH51 zxXO3qWZKaXDC5wlO4E8qpGnAAxQMis1JJNSJF1VzxQMsR2560gB4DnigYxoiKAKF9bCZSB1HSqA x3tJQcbaYFyzsivzNSA2vDNv/wATNmx6VvRIkavi+BzCsqrxGCa7I7GbPPfDentd3JcrlQfzNSwP QVUWkARRz39zTSAq3twZIDFESHPyj+poegyrhdMsenz+negQ3RtNLO97d8s3Jz2HpQBl+LvEHlA2 1s2HPBx/CKQHDnLHJ5JrNyGKq8ipGSdqQDcUAKBSAcOtIY4DikB62cZNAxpNMCN3xSAgZs0gGM1A FvSQGnLHPyjPFaQEHiNgPIiHoWNZVXqNGKeKyGNpAJSAKAENAEZoAaaAM7VD+5I9aqIiayXbbrTk BKaSGbWkfKmVPTt710wIZleLJkhs5FPUjaPqetUwOBbrQMZQIRqALUeEgJpiKkvIFNDHQruIFJms EdHp0Cxwg45qGdsIlLVwMGiIVloYhGDWh5r3HqppCLVipEy0pAjt9LP3fwqUM6C35jFcz3LQS26v yODSAzrm3OcZzSGPiiEaYFAFq3jyeaBl9UAFADHwooApzPzxTQFZhQAwpk9KQCbSpoA2PDcf+kFs d66aJEjb1uEzabcIOpjIFdcDNmBoelx6daK2MHt7+9DBE0zg5Y9B0/xpoGZ1n+8naX+BeFqZDSJo rZr28DyD92vIFA7FHxZrsemW/kQEbzwo/rVbIR5xNK80pkdizMckmsZMQ4VJQ4CkAtABQACkA4Um MdSA9YZgCaYyKR/SkBAx560gI2akBEz4pAXtKbhiDgnitYsRX1mUy3xB/gULWE9XcaKBqLjEoAKQ CGgBpoAaelADDxQBl6mclV9SKqIi5bjbAg9qGA800xm5pUWI8ggYH611Q2IZz/jWMR2/LZIIH1J5 NDBHEmkMaaYEsFs9w2FwB6mgRauLR1hwhBx6GmIysnODTGi3ZLl1qWdFNHUxIBbjHpUtnfExdV70 omdfYxwMmtTy2WI4/alcC5ax7ZBnikwOt0rtSSGdDbfdxXNLRlIfI4VakZnF98tAE2MkAUDL9umB 0pDJ2O0UCKc8meKAKxXPNAx8UW49KALJt1C/doArSwgdqANPw8u1ifeuqirESN+cBrdweMjFdK3M zGu/3n7uPgdBTQWMa7Dr+4U53cfhVXFYkt4CSsSDgdcd6zZa0JNb1CHSLJ2JAIHP+FXFWJbPJNT1 B9RvWmkPU8D0FTJgRZGRWTGSqaQx+aQCg0ALQAdOtO1wFRlJxnmpkrDJsVAz0+RwSaYELNSYETvS AryyhFJJxSAptdeZ93pSGb+jQuturcYPOO9a2sSZly++5kb1Y1zFEJpDEoEFAAaAG0ANNAhjdKYz JvzuuI1981URGigxGo9qQC96aWozd07EVvk9AMkeprritCGcr44DAxZPAY59zSYI5I0DGkUAS28U 7cxhsUxDJjJC2MsPWnYRW6tQUi/YD94KlnTTOmDYgH0qGd8UYWp8iiJz1zMiHz1qeay6pVFqAHwO XlHYZoYHW6T/AA/SiIzooOAfrXPUXvFIhvJMDFQMoqcc96ALlr85FA0a0S4WpGRztgEUAUmByaYC qlAFy2iwM0mBO6/LTApTDikBd0QYzXZRIka95JttGNdMdyDIEgSJpD1NMCvBAXzMw+ZuntSYE52W Fu0r4DY49qaA8w8W6s2pTOFY+Uhwo9fepcgscupwRUsCfPNQwJENICUGgY4UrAXrKxkuWGBhacVc DpLTRLbyxuQE+9dCikQZ+uaLEkXm2yBWXrilLlBGCJyBisORFHpzNyayNCF3oAhdwBzSApTzb+O1 SBDGAXAx3px3EdZZ3It7QnoqrgCtZvQDCOSSa5RjaQBQAlACGgBDQA00AMfpQBjzndfIPQVpHYRq 9qkAAywqo7gb1htEA3ZwPmINda2JON8byk3UUWfVz9TSYI5g0hicA0Aadrf28cW194OOoqiGZ9xK JSSG3D360xlUD5qRSNCwHzipZ1UzoM4ixWZ3rYxdTOKpHLXZnQIXfitLnns0YrNm61FyTZ0fSUnJ 3cHIApoZpacNkpUdiRQtxnQK4VTXPU3KRn3L7nrMZFntTAuWB+fFSBsqwCUFEDncaAIyuKQDoky1 Ay+iYFAhJMAUAUpunFAFrSztFdlHYhmncENZnPpXTEzMpFE8vljoKBl/YkSZPCIKVhHDeJtZN7ei xgb5c4cj+VOTshpHM+I9PFoqFehFZFnM96oglU9KlgTR81IydV4osMtWNq1xMFx8veknqSdpZ2KW 0KgAAmtG1SjzMFFs1LdIIE3SMB9a8avmMr2gbxpK12OvpLf7Iz7VZMdq85YmtKe5ryRseeSNZGRi MgEmvaTq2MuVHdu/PFbkEMjgd6AKU027gdKQyAmp2AkthumQDnmqQjduHK2LAjBJwKmbsBnVAAaQ CUAJQA2gBKAENAEb8A07AZMY3agfbFUtEI1KQx0QzIBVR3EdDbhWhAPH8R+lda2JOD8ZOGvYx/Fg sT9egqWCOdoGCg7hgZoWoGgizFMGJNn4GrIZlSAb2Krt5pDQ1RzQaJGlYD5hUs6qSNs/crJnbfQx dTPOKuJxYhkGnLmSmzhOgihGBUAdDoUG2Jmx6mtIAU7LaLlhkDk01uBsTvtUj2rnq7looE8k1kMK ALdodpzmkBeaYkDBoKJoxkZpAIw5pATW685oGW6YiGUigCnIctijrYC3BEY0BH0rtoqyIZbu3K2P y9cV0RM2R6bD5Ue5vvH1pDOf8ZeIFsoPJgb963Cj+tVsJnE6QG+2CSQ7iTkk9zWFTYuCNXxaizQo qYJ29qEUzgpFKOVPY1RFh6UhFiLrUjLUEbSuEUcmkxnaaPpiW9sHYc1qkkrsloknnbO0HpXj4rEc y5UdFONhdRja70p1ViHAzxXmUGo1dTSWxz+nX9zaWhjuA0lseA392vSq0YTmnHcxTtoZh08MSyvw eRXSqjXQVju5ZQua1CxSllLGgCAmkAmakC5pi5mz6VaEzU1A4jjT8aioIo1IxKQBQAlADTQAnSgB DQIim4VqpDMuxG68dvemxGnUjHwqWkAFaR3JN+3jfyeCBn19BXUthHnfioH+02LdWG7HpmpAxaBk tuMyDjPenERfOoOsbxNEq7R6e1USZDyCXJ6H0pDQ1Big0Rp2A+YVLOyka7E7KyZ19DFvjuY1aPPx DF0lMyZokch1FvDwDiouB0Wkx5tJMehramBxWmPO2syK5IUMQKHowOtuBuP4Vz1Ny0QNHgVkMaRt pgSRyBRyKAJ4JNz46CkM04ztSpGMZstRYC3AMKKLASlsUgK0z4poCCL55h+dXFe8BoSvtVUHXGa7 I6IhkqgNDh/WtY7EFLXtWi0yyZmbBxTQzy5pn1S+eeXJYnjNDZLL0Ufl3CKlZTLgyXV3eK8iSXoV rNos5PU1C3T46ZrSOxDIY+lDJLEXWpGa2hTRx3qrIMhjS5uXVjO7GFiOD1FeXisZryo3hT6swb+5 MIPlgM3p61yUoc+rG3Yv6Vci4jAIwx4Yelc9eHJK6KjqWLTSClxNFJGGtpecelEsR7qaeocmo3/h FYRwsjAduaf16oHIU5JCxNe8YERNACUAJSA0dKXkmqQi3ftmYL6CokBWqQENACUAFADWHNABQA2m BDcHCGmBnaWMyO3uabEaRqQJbVS0ox61rBCOhyfspAB5GOOw711dCTy/xBKZdVnY8c8D2xUDMwmk Ba08HzGIA7DkVSAs3HNpPLhfmzgDtk02Iw3+XGKYCKxoHcuQTyREFTn60mrlwrOLNGHVo5BskGxq hxsd0cQpLUryr5shxyDRsctVqRo6dbCMipbOc6CEYUVAHQeHZE3PG44NbU2Bl3tqkGpuFx93NOW4 ErHBGTWFRFIjJy1ZlDJOlADM0hFqzX5gaRRoSPtAFIBsfzMDSGaCcKKACRuKQFSVuKAJLFcuSa2p LUQrT5vCCeK60SyS9keO2Vk6lq0RB5zr+oS6vqaWyEhQ20f40NjN3UNDg0vToZo+SxCjj260JEGd Ag+2RFhkbhxUVFoXEseOreNRbPbKVbbzU390s4S9Dh8uOTRHVEtEUfSqZJOlQMsRkqwYcEHNS1za DR1NneT3Gnh943IOcV4tamo1NUdKloZlyz/ad6n7/I9q6YRVjNs3vD4kkJdwM45x6152LaWhrA6e G4VI/mPNcdLDyqPQtuwn20elej/ZsjP2hy5r1jIQigQm00AGDQBtaXHhASKYiO4O6djWbQyKkIQ0 AFABQAECgBhoAQ0wKt42IiaYmVdJH7ommwL5qALFi2yYcZ9K3psR0DybLdiFB42r/U11W0FY8q12 VZdVuWT7gchfoOKgDONIRr6FZS3W5Yk3NyeuKtILlbVrS505vJmUqD2zQwMuYYAoQDE60AWEHSgB ksRdxtFDHc0dNjbeFbrWchHSW1ttwazAvKMChgT2t4bKXzcZA7VVN2YEd9rEF5dh41xxgn3rWWrA laZWRSpB7VlMpDQ43cGsWhiSMPWgBEG5hSA07eMKtSMbLJk470hlmzGccUhl/NAEMsmKAMW71mCK fyjkt6CtFBsVzbsHX7IZRxxW0I2AopkkyHmtSWWLicPAFbIxmquSzkoWtrbV8uoLY+8RwBVJCuT6 34iXUbdLdY9mx8jntV3JKtvzNEfesqmxcTR8RqJGt1bpgVjJ2iapHM+KdPWBY3TJBFOk7oU1Y5tO K0ZkWI6kZYQUii/p0hjl27iFbg1y14KSuUma1vpyvKS3Y8fQ15s61lZGsY3N61SO2Rigxn0rCnTl WlqU5KJZto2nkHpXvYehGmjCUrmsunrtHJ6V1mZgm0UE8VxGofY19KdhDWs1A6UWAihiSRiACMHv RYDWhTyo+OwoehJnk5JNZFDeKBCGpASmwA0AJigBrcUCENMChqRxA30pgw01NsFDAtml0AsWC5lz xxW9NCNy7t3+yN2IXaPqa6egHk+oqFvpwDkByAagRUNIR0vhCRjKyYHGADWsRFTxg7NejcSaUgOf lOcUhjUHNAE6UATwD56TAtWMoW7X61EgOrT50GDiswHqMUmASJvQqOKFoBy9wJrCYpIOCcg+tbxY E0N4WBCyEZ9abVwI2N2j7g5Zfao5R3LEPmvGz+ccjkqalxC5q6LI5mAJJU1lJWKR1CgbKzGULlsS /jQBpWfCA1JRZZuOKAJrOw+1cykhPT1relTuQ2Tw6ZZW9wdtrEzd2KgmutRSIuVtZdYoWWNAvsKJ WRSMeBxLBtKkH2qExjLiGaSE+SCx5+tUhHAXb3CXTtMrRuezDpVEkcTlpAM5NAjoLL70WfUVM9i4 mnr+C0HPYVhP4TWJn+JIg9hF/u06Owqhw5XY5FbPYxJo+1QNFmOkUTKcEEVLV1YEdHpl0JYRzyOK 8p4VudjVTsbdvEXUE16lKhGCRlKVzXs4xGBxW9iTRD8CmBkeScniuU0DyT6UABgJGKAGpaYbNAD7 v93C3bjFTIkyh0rIoaaBCGgAoASgAxQAMOKAIzQIztVP7vb68VS3BlizXbAKb3AnI4pMCxYr+8yM 8c1vADU1C6eGzY9doJ/Gt3sSeU3D7pnJ6kmpQiIilsB0/g5NrM/v/StoiM7xU3mXx5xilIEYLgsw AFSMekEn/PNvyp2AnWJ/7h/KgC1ZW0kjkAY+tSwGWsUi3vKkAH0qJAdhb8Rj6VmA8tikAnmj1oAh uo4bqMpKAR61SdgOevtNe1JaJt6fqK0jK4FeC7kQ7QT6Yq1qM7vRbXTri0BvbNgxH3xnn8qbiBpw aRpisDbXDRn0as5QuNM0RpL7P3cqP+lZOkx3MnUNNu4W3NCxUdxzWbptAmPtrlI48HrUOL6lE8Fw JplRRxTjFNjN+LCRjnH9K7orlMWYOoas73ojhOAh5PrUueo0hNSmJiJY5OOaJO6KKSSBcMvSoQzR thGY96ng9iatCKWraZbapEUbbv7HuPxqrknKpoNvpsjC8nKnOR2yKdhDBd2sVyrLJ8maU46FJlzX rqPbFJkhTjBxWbheJakQahqNrdWEcayguB0pU42CTucfdALMwBrVmQsNQwLKnFIY/dQM09AdjdBA CQaSWoHoNta7YgTWyQmTRkdO4oegInDcCmAwrya5TQMUAGKAFAGaBFDUziPA7mpkIzO1ZDEpAJQA UAJQAYzQAHgUAMYcVQjM1LllH+0KpIGXbcYiUe1D3AlxSsBasdokGeMnk+1dEBGhf3SRWZMgBGC5 z6Y4FaIRwdnYQSx73QEk5qWI6Xw5odhPOPNtkf2YZq4q4HR6vp9lYQqLa2jhJz9wYrRKwjyXxO27 UXx2NSwWhRsonlmVUUs3oBUN2Vxo7Oy8PzXFqX3BSB0Nc0sTBOxsqbMuW3aN2TuDXRTlzq6MpKwi I4PUg1oSSR7gwHckCk0BsNHJbwp5gxuHFczVhlWSb0pAReb74pgJ549aLAQXUoZCM1SQGTGiuzcU 22hnSaNe3NrHsWQlfQ1HtCrG5HqhIHmxI34VSqBY0bbVLbAHzxH2NaKaFY0Ib+Q/6qdZR/dbrVXu IWUWN7lJovJn7MOKUoJj1KsGnvZXOXIeM9GFZKnZ3C5pXchW3dlGeOMVumIwbdYWOZIisnrk1lbU odejepBFXbQllNojDGrc7TU2HckgZsFV70kO5nail9B+9s5QMc7Wq0iSa1ubXxJphF5GomQEbh2q loI4vWbZbJ/J37sHI+lU9iTRv9asLnQIYCrC5jIHTrTi1YbTRzDyqenFRp0GroaeRnOaGBJbjLY7 1mwLLIy9VZfqMUkMQUwN7wpcRx3wjlA+boTQgPRI2GPatkxWIShS5z2NRIpE4HA5oGJnk/WuYoKY gzQAuaQGVqT5ZV/GpYkUjWbGJSASgBKACgAFAAfrQAxulUIy77m4Qe5q4gzSRcKPpSAdQBb0+Le/ 14rogSybXbTOnSnftG1m/AD/AD+daActZDFun0qGBpxXctogaFyprSImJe65eTxjzJM4HpViOYnR bq5LyqGYmoA1LXT4I1DomxsdRTcboadi295PGGCy4Lda53h6beqNFUZnzOWfcxyx6mtoR5VoQ3ca shB4FPoSOjO+5iUdS4FNagdh4riWLSrWQKAQ2PzqJoZxM90EByaxSAzZb5icKcCrsAz7XJ60WAGu nIwTRawD7Pl6mYzoLUbUFc5Zfj6UagSU7sBVdkOVYg1SmxWNG2vmePEx3AfnWkamoWFPiIW7eSSZ Yzxn0rpTTRLHHxBHGpVXDL6elZt2Gi1Z3ttfAbm2MOlSmNonuoo15VwVNXcmxXkiL2OwnBGKdxWI cCJM5HFFgOV8R6+8TGCE8leT6UwMjSNbTToJFK87Tj3NACadKuqauJZUyOBg1E3oUkbXibSbcxxm GMIcdqzbaiaWuS3uh2h0GJ0jQS46gc9KzpTbY5Rsjh5beS3mMbj6V0tmB0nhvSMuJZl/+tRa4HeQ 2EEkQVolK46EUWsBXn8MadcZzAEJ7pxTSA5bWNBn0a4WaHLwg5Den1pSiB1ejXwurRGzzjBpxYy9 OC8eV+8OlNgiNbhto+XtUXKLJ+8awLEpiAcUgBiQpNBJj3jbpvpWTGV6QCGgBKAEoAKAEoAXigBj Hg0AZUnz3yj0FaLYRr4wKQDTTQF/T3252/QVvElkHii6ZNPlRe42fh1NaMRgWvESjpwKhjLM7fIo HrVoTKU+QhqhGdH/AK8UAbO5tg2ntTAgkUk0AQSqB0pAMC570gJLQH+0LbAJ/eDp9aaGzsvHThNA tz0+Yf1qZAjy6eUuxqbAMRC5460thkhiYYyKLiJFtnI4WlcCxbQNG4JGKmTKRtxMFUZrnGX4GBXI pjJTQA0ikAAlDkGnYDM1e3fBuLfhx94eta059CWjBgu5IZi5JbPXJrdq4jodD1OOR2Unb71m1Ydz oomaT5ckr2xVIDRRQIthJOfWqsSzC8QXLwx+SuQx6e1NvlQI4TUIij7mJYnualSuBSIyKaA2PC64 vQaiZcTrte/1aH2qHrE26j5ZS+hjtj2rKkrMctjmrW2hutVTz3Az0z3rrexzdTvbWwgjRQuMCmhF 2OPaeDxT3AuRICMVSRLG3Fqk0ZjlUMh6giqA5saW+k3LNDlrdz0/u1lIo0YZMihDJQFwOKdhjz1N cpoFAhuaAFf7lDEYs53TMfesWBETQA3NAAaAEoEFAwoASgBj8A0AZcfzX59sCtehJsGoAYapAaFh heSucdq6IiZX8VyKmnupXBwFGfUkVbEc3DAx27mOMVA7k7qFxjn61okJkFycIaYjPhwZh9aANgBg ox0pgNxgEkUAVphmkBEBQBNpTgaxbKem8UIbOo+JLAaLagHHzjj8DSkCPMTUgTWhxMtKQzUmiGV6 VmMuwwjaOKlsQ6WLC9KkaRWkkJwBUDLNpdGMgNytFhmqkgZQRSAdQAhoAawyMHpTvbYDl9Ws/IuC yjCPyPrXTTlchlayla3uFPQZ5q2iUehaMyzQg96EhmxaqGfn8q0SJbMDxUgN4mB/DWVXYqJx2sx4 UHFZxYzIxWq0Ebfhni8XHBzUT2LidX4hyUQmolpE1EOTohUElcVjRd2XI4u7OBkZDK3UV2M5nozp fC/iJ5Nttd5JHR/8aTaWhO53VthkDKciqixtWLCHafatUyScEEUxEckQIIIyD2pNDRk3tubfMkY+ X09KzasUjK/tL3NLUZsngmuY0CmIT6GgBJiAnpxSaEYjHLE1ixjTSEJQAlAAaYhKBhQIKAI5ThD9 KYGdYjN659606CNY1ADDVIDS01Scc9Oa6IgZ3i4O0Mat0BDH3JNWyTLhB4GKgAmI3DtxWqArXf3O tAijbrmagDWYkLxTAQH5TmmBC+cVIFdlOeKAK0Mpi1KBuhDg/rQhs6bx/cGXR7MH+9/SiQI4CswJ 7QZmUe9JjN6WH5UJrMZo28H7sVDYD5YB5ZoGjDALSkAc0mMlKMnUYqUIs2Vz5bbW+7QBqhsjI6Ui haAGmgRS1G38+3YYGRyKuMrCaOZcc4PDLwa607oix2HhS4MlttzytCQHU2hIc+hq9iJFDXrV3ZZQ MqBWVTYuJyOvw4tycdKxjuUcxW5Js+HD/piD3qJ7Fw3Os8QL+5TjtUWsjUbFGw0kj+tc9N+87Fvo c3Np1xJIR9ndlPPAreeIUVZmcoXZoW0kNhGqCBQ59q832knLmKsjo9K1KSMAsuFPauujilJ2MpQN uO8jlGVOD6V6CkZ2J0lGMg5FWmSydJQ3GaYDZowwqSkzLOi2zEtsPPNFguPP3jXIbDsZHFAirHDt uCw3knselAD74FIWPtSkSY3asmMbUgIaACgBDQAUwCgBKAIpziM00IpaWMyO3ua0ewjUPAqQG9/S qQGzZssiKAACT27CumIjG8UygmBOcu+7HoB0oAzo8D8qkRFJy5JrVCKl64CEZxSAoQSFXzTA3dPs rq/BNu0RI6qzc1QEF08lpM0M6KHHpSARGWZcqMe1ADGjz07UDMmc7b1e2Klgbvi+QPpFmM5+c/yp yA5HHNQBe0uLdOpNRIaN64ABQViijStxiMUmA6UfI30poDCtkzdP9aiQGv8AZxKuMVIzMu7R7ds4 IFNMC1YXOcRsaYF+kA00AMk4Un2pgcrqagXJZRgHrXVBks1PCVyY7wxHo1WSeg2x2Lk9BVoiTKV5 fqHeMMGXHK1MtS4nL64oe0cjpXPazGcceprURr+Hf+PxfrUzV0XE7jUbc3UKIDilbmVi+axLZ2IE PltyKmNBQZLqGpDbxxIAFHSirh4ziJTdzL1XT7dn88RjeB0rwq1OpQaj0N00zHs5JfOlLgrEM4Br WCjGS5RNaDLXUyNR8lpNqEdT617aeiMLG9a6kiyMgkDFTg81fNZjcTVinVwGRq1vcytYtRuWGDRY EPA4pjM7ufrXEbjhxQIUcmgRS1FyIyPU1MmIzO1ZDGGkAlMBKLAFABigAoASgCvdnERppCINIXCE +1aMRoN0qQGYyQKqIG3pqYXIPXgV0xEYvioAXcLZyQxA/CmxGep+WoQEP3ifrWqEUL1VYgAn34oA sRaPthEqzf8AAWTHbNPlaA6Tw9bmOyMyIoYgHOetUBzmrRzNO08jKwY8YPT2qQIbPk+lAFsHAIPN AzFuBm/GKkDT8VN/oNqn+2f5CkwOZHWpA1NKH7wVEho2Lj761kijTg+4KTAe/wB0/ShAZFuv+kOc Y5qZAbVsOKkZZkhjlQq4BzUgYF9Ym3k3RHirAmtbtWTDkAj1p2An8+L++KOVgQ3U6eWdrDNUkBi3 dq00ZZeTWsXYlkOlR3KXaPGhBU962TJPQo7xvJBZQAV5FNSFa5z91J5kx8nhs8nNZTkWlYjvUZrN g5ycVkmDRxjKTLtHUnArck6vw7oskWJpMVLY72Osijzj5ulaLbQTdy5Emyml3FYmzgUbDRQ1FtiF u1cWOhzU7GlN6mDuUHMhIQk4A/nXHhaKvdmzTasjn9VRYLptjfKeQa9R7aGfI0itDeSQyb0c5780 mSdJpetuQCGye4qXVUdw5bnUWeqRypkNg+ldEJqS0M2rFwXq461qRcjP3j9a4TpFoEPi70CM7VSN 6rWUmBRVcnmhK4mVruQx/wCrUnnGBWnIK4IxZQSMVk0UOpAFAgpgIeKAENAFPUGxA30poB2ljEAq mBbakA0HmriBt6YAI85+6MD3JroRLOZ8SyAami9VQEfjRIRWRwUJqYgMXBQ1qIpOcTqdwAz64oQF /UJcQxqhK5GDg5Bq2I6HSQsOltuQdBkd/wCdMDEXQrvUd8lrsZM5x5qjH4ZqLXGU2tJrK4MM6bJB zjOaYEh+5n2pDMgjdqKj/aFSBp+MUEcFnjPJfr+FIDlx1pAa+kr82azkM1Jv9YtZIZpwn5BSGSN9 00kBzF9NJDdNsYjmt4xTFcms7+4zguaTigTLrXkxH3zUJIZm3c0rNy5NXyoQzafLzn0p2Acn8PXm qbEaGn2Xnvjk8VCRQ6VBb3JToAaGrCNO0iAw6ruU+1VHUQuo3ISPamRVN2QIzrI/vMsOtc71ZRcu VzCw9qI6AzlrS326hvdTgNxxVOpFISR2dj9puFCxpsQDAzXm1sbyfCbRpl6OGeE/vBx7Vphsd7R2 ZM6djThO+MH0r2E7q5gDHAosCMrVbpFQpkHPFYYjVWN6S1MFWEj8H5RwK5Ye6j1KUEylrFtmLeB0 rWLugqQRgjqa2R51RWY+ORo2yhwaiUEzJSaNmz1E4AkOD6isIxlGV0U3zLUuC+kAGJ66/bsz9mjt j1NYli00A9DgU2Blag+6c+1YsCoJtoNaQRLLWneTJJhgDitnsIi1VUjuFWPAGKwkiirWQBQIAB60 wA0ANNAGfqjYjI9eKcQLViu2AU2ImahgEYy3TpzVwA39OAWIEgYAyfpXSkI5LxIwOpIMc7dzfjUs SKhcJETQhkCXB2cECtCSBEE9wFOcE847UIC3cWJtMOlwGXrt7jNVawG3Z61FFZFGJaQZ25X2q7ks 0rGSOJ45ZSUdxt+VOCccn9aAMHWHf+05FYAgKAuPTHFQyiqdpXn0pDMuJQdTUf7YqRGn444isR/v fzokM5QdagDa0kcis5DNCb/WrWYzUhHyCkMc3SkBy2qf8fTfWt4EhaH5hTkNGiAMVAyjeBs/LWi2 ExxH+jj6UkARJuC4pgdV4btwfmK5GOtCBk1/pCPO0vrQ0JFO0mNpKydUzSTsBV1CZXu8DpjFKbGV Yn2ygehrIdzat7RrjHy8GjkbFcuQaNbRHLQjd/erkr4apb3WaRmjVjiSJAEAC14VWnKLtLc6U01o V57yEny9w3elVBSi04ksfaNhT6V9bhneCucU1qyveXQTPtW17IInHavfF5iVJwOK5G+Z2Nr8qK2m XQUlXbFRONjvw1TmRqXCia3PQgioi7aHW1c5WVPLmZT2NdCPKrKzBRzTaOctRYFQykSAD1qOUZ6c epqhBTAkBwlNiMO8f96596ye4FJztH05rogrEMzbbVvIuWJOATVyFc0HuDcyK4PaueWmhRNWQxOl ACjFACkCgBjcUAZepHJUerCriBo2wxAtDEPakwCMEuAO/WtIAzoLJSbcnbnd1xXTcRwusSs+rucH mkwRWujII8k8elJAyoHIFXcRY00M0/AY8jpTQiWcu92qtuJLdHGKd7gdjLDHbaWJJYo2H8WOePXp +FVYCewMMFl/rMw8n7+cDt+Jp2Ectqef7RuPn3jd94/SoYyuThTSGU7FN+pp/v1Ii/48ypsVP91j +tEhnJDqKgDc0ntWchl6T/j4WsxmpEfkFIY8nikBy+qj/Sj9a2gSxLbhhVSBGgtQUVblSCea0Wwm B5tvwpAWbeLZbZ71b2JOw0KPy7ZenNKIMu3K/IfpVsDnHTMj/WsWUjKuwVnDdqANTR9PW4l8xxx1 pxjqJ6HUwRRou1ABW6SRA5iAMEU+az0CxSuLjylbmvEzGgpe8jppyMSzg8+/ac54OB9BU4WldJBK VjdZvKiOB2r2oLlRzs5nWr14yYxwzVy1XK+hvSjzOxEtsj6HLIygyKOtaUldXCrHldjme30pSQ6M nHY3tM3G0+Y5Fcz3PYp/DdmTqkOy43Doa2gzixMbalMVocBKjYFKwxfNosI9WPU1BYnegQ6U7Yyf ahsRgTnLH61KV2IoXzlYXI6ngV1JEswDGQ43A9abJRv2AAiziuSb1LLdQMKAFGKAA8UAMY0wMm+O bmMe9VEDWiGIl+lACN1qQJLb74+uK1ghM6G3Zhbts442r9T3rpsScNqD+ZqcxA4X5RUyGireZKgA daURMqtFxmtBE2mlROA8gTnucZqogTzus1/GqucZ65oA6PUYhFo6rvzkAckevtTEV7ay82waJr6F UYDaMEEYOfSmBihSjspYNg9R3qRjpPu5FJgS6DYtNdpIP72f1oSAX4iKUuLNSOkZ/nSkBx46isxm 5pfGKzkUXW5uBWYGpF90Uhj+1IDmtVH+kmt4CYy3HzCqaEjRjHNQUVb9GK5Q81aEwT/j3FAGgq/6 PEPU1ViTsNNTbbxfShAW5k3rgDrTAhubGKCydgoLnpRyhc5O8tS7AAd6yasxo6LS4EhtV3ZBI/Kt 4rQhsie4eKXCHn0JpgWhdb4dx4OKpDMbULok7RXl4uSk+U1gXdOhKRDPU8mt8NTSJmyW6uAinHau zYzSOL1O7M9+c9FrKolY6sO7TNewPmaNdL7GoovQvFfEzjy2GIzTkc0HsXre6liTCniudrU9SnJ2 C6uBcRYYYcVURV3eJR6VoecJmgQtAHrZ6msyyLzUEoQvhj0FMTJLs7YWpSEYD5JJogiWQ3EWVVfx NdSJKE0KnjpSYFy0XbHiuOaKJ6kYUhigigQhPNMBhNAGTcnfeoKtCNhOFA9qQxpPNDAktQTKMVrA R0MYWO0bJ4ArcRwtwCL6Yf7VSxIikGXAqogxZYRtqmgEsI1LthFLDoWGR0ppCHSywrcRSbEVlb5g F7fSmBt6jfwNYwPFIsoQqSueRVMB0fiO0eFVmhIcKMkYOT3FDYGCXDuzKNoJyB6VACuPkNAG34VT lT71URGb8SuNQtRnOI/61Exo40D5hWYzc0zgLWchlwZ+0jNZjNaMfKKljHEUgOc1UYuTXRTJZDEe RVsRpRAnGKyZaGahay+V5iHGK3poiTI7ZC9tnuMmpasxpmkg+SAf7VMR2NguYU7YFNCL0UWck00h lIymWeQH7iCqJkY8sISbcOVJ4rNofQ0bItKwVBx0ORWiE0XLm1t0GSoD9RjtTsIx7siJSOg9KzqS 5Y3KSuULaPz5wcfKK8dP2lQ3eiNokRRZ717UI2Rzt6mXcZZW61Eqii+U1jF7nI3vlxzM27BJqb3R V7PQuaFqaxTxjzGVScE7cj8qSVthSlfcd4oS1F95qiPB/uDANaOOhCM+AK+fLHy9q5paHq0NYjbm E7SRRFlVIXiZ5btWp5L0YA80guOzQB65jk1maEa26tOHZAWHemhDdTbbDj1pSEYpbBArSCJYySUM TkY7VuSV0hMj4p2AsNZTouUU1DgguQyQ3ca7ivArN0x3Ira5LyGN+CKxlHlKRdBFZDENMCJ+hosI yk+bUPpirWwjYPAqShpoET2LgTKD9a3piNyTC2uWPbcc1uScMG3zyMepc1DBCEjzBjrVRQMLltqV QinFffZ2ICKwII5qkwEhb7TcZZcj0BxwPrQBo3S2UVvsjimScY++cg+tDAzzkDpSuBZh+570APf7 hp2A6HwuuFSmhGL8ST/xNLcf9M/61Exo49fvCsxm5YfKFrJjLaHNzWbGbMMbFehxUjHvGVGaAOb1 dSbjitqZLIoImJHFa2EbVpCAATS5QuXJY1MDAjjFax0EZ1hD/o0wA6bhU6tgTp92H/eoY0dtZri3 ShAyWaTYmBxWgiiApjlK9SKIrUmRR02CS6jC45DHrUPVjRsNs0+PBA34prQdzKkvZJJCXqmyWZt1 M0hxjNcWMnywsaU0XdOh2JyK5cHSd+ZlzkrWDUXk8lnQZVeterKVloZKOpStpGksWdm615CqOWI8 ju5bRRxl+2Z5uDwa9BKxzMi021nnuAEOFz1qnoSi3q1pJDKfNYNxxzV30BjdMkCnaa5Zo9HDSSVj QlClD0qInXLYwZ12ysB610I8isrMaKDFDqBnrueTWdjQkj70yTP1Z8YWlIDIVh5gramiJDbhVKEg 1sSNt3CD73NMAfXJIiUzkCmIBqbXCY3AZpNDKUS/6SWHrXPURUTRU4rlLBqAIZThDTEZln816596 voI1jUIoTNAh1vjzhnvW9MRuzZa0YdQ3yg1uSziyAsjkDjcahgRgfvs1cBMdcAFckZpsZjzj95wO KQixYXElrL5iYBHFUmBvahqcV9ZMQFWTI4HpmqbEjI3M4Ck9O9QMsRjCj1poBJchKoDqvDS4jT8K EI5n4jH/AInMYznEY/nUSKRysfMgFZgbdv8ALt+lZMotwH/SOKlgbttMwX5ulQ0MfLKGGBSA53Uw ftPFb00Qx1uOOlbWEa1uvyiiwF1k/ckgVcQKGlqWhuQB/e/kaSWohNm2CFv9v+lS0M7GzbNumOmK cRsdP904qmxIzIJn+1GFVJDfpQmJo6C2sltYBtxk00tQMfU0YTZeTcT29Kb0GZlx8uOlZ/DqxEMM sKuA67v6VxygpyuzROxNqE9zZQrIsO6FjgMO31rsilGNkTfULtmexY7lO5OdprK9zaxQsGH2Ejd+ GK8uC/fs6H8JgmxL3Ep34RutepucjNvwvpsIuxnEoXOVYEA/lSloxDfFNjay3LGBzEQceWa06Csc y1rLaMHIyvqKzkjooytIla4G3rWKWp6HPoZ8zhpSRWyPPrasQGmYDgeKQHrfQn61mjQlQ4U0yWY2 qPmU+1QBl78N+FdMCGV5rn5TitCSk13gdadwM6efLE5pXCwtrckPwelFwsbNjlmzWFRlI0Qa5iwP NAiKfAjagZm6YMzufc1oyTVqBiUASWw3ScckcD61vTQjdvAINNYjqqYH1PWtiTioh8vNQMRV+Ynt WkSRxwc1QGXcAbzgc0gLFpGrL0GaYFjyEIxjFAAsaqeBigBcAHigBsxBAFAHYeHEwiDFWhHIfEb/ AJDi/wDXMVlPcpHN2sTPKMDis5OwGyg2sBWZRPaHNxUsDaTpUDFzQBk3ibrut6ZLJI4iDWxJqWqc CkBpJFmM544q0JlHSUAe7UDPJ/kaS3GQyr/oCn0cU2JHU6euLOP6UhjrjCoSe1AzmDrn2HWAQu+P +MU0iTqZfEMFxaBrY5YjGPSr2AwXkkeYsWJLVDYMde2k8Vg12OdoyVokuZGcjGjdpA0jLtB6VxzV mXSfcs6N4ijS5bTb/DQvwjHtXVTasVLc1dVtfJgbagaIr8pWolC2qNYzu7GPpUmICuVH1ry4q1c6 n8JliaJbho2bktgV6i2ONm3p9w2lyKzKVDcrIo5FS0xop65fRXF40ksm1m7lcZqkBm3TRy2x2SK3 tQ9hwepjPyKyO1PQrvwQapGFRADTZgSDOKQj1zufrWaNCXpHTZJz982ZHNZgZsjYLfSuqGxDMqWT 73bmtCSoA0km0VMmM04NJjdcuK5nNl2LC6VAhyFqedhYtRQrH0FS3cViXOKQwzxQBWvGxEaYFPSB lSauQGlioARqALOm7ROC3bmuqmI2NTZGsT2wpY1oxHGLwOBWQDB1OK2iSK3C9OaYGZO37zmkBdsz hMgYNMCznPoKAGHg9aAEUc0ARyH5l+tAHc+HgBGn0q0I4T4hsD4hb0Ea1lPcpFbSIFeDd6VzTeox 74E2BQtRk1jzPSegG2vSoGLSAzLni7FdFMlltE3dK3JNK0QgDigRPcajHZ/JKjYI6gVvTpuWxEpp FXRHSa4uXQ5BPH61nJcrsy07oekPmWTD0YVNgOltF22sQ9qQzH8R6kLWAqp+c8AVSQNnEK6+cHmP BOWoJOg1SBtPsotQsfmQ8yL2Ipgbuhi2vrKO7jXqMkelTYGzWuYUmtJIccMvStEhM8z+3NaNLaTc GJiFJ9KwqQFBWZjySh79XHPIqFobrc9Ksr/ZaRx3cY8kr1HNXGSloxzjbVEM2lRxIZ7ILLC3PXpW FSg1PmRUaulmchp2mz6j4glQDbHE3OBxmtY7GbOh1i7i0+8htpXUpjDA1rayJuZmv6C93ai706Uy xAZ2g5xSsO5xivLHJtOQRxUNDTLwOUrJndB3RCwzkU0TLUYKbOSSsy6sPyjjtSGeqD7x+tQWSTNt iP0oewjnbk5LGs0IzpjgOfauuOxBiuxOaroIt6bbbmyRWM2OxtqNq4Fc5QtIBKACgBDxQBV1BwIG +lMCLSVxDn2FVIC/UoBDTQFqxUM2AOv8q6YCLutBU099uQWAGKtiOTZioAqUhApGRzWqEEvA9KAM mX/WEUgNCz4TpTAsMwFADSaYDVySecUARn/WqPcUIDutBPyIPamI8+8eNnxFN7Kv8qzluNDNBkBi Zc1hNalIW4wJc9KEMm045mNRIDbXpUDHUAZt0MXIxW1MmRfteoxXQSa9qvy5piY4ie53qiRMoH8Q rpppQVzGSuU9CRob25RkVTnoKxnLmZpFWRb0cbllVvu7v60rDNfU7tLCxVicDpmnYaPPL67kv7ky E8fwj0FLYCvd2zJFlhWbdh2NXwvrUXlNpl+QYn4Vmq4yuS0dNoVr/Yrywk7rZ+Yz6e1O1hF9pZZ2 HkqUAJ+bsadwscD4u0ma2vWd+fN+YMPWk9SkcsHMMgLDJB6Vk4lJm7P4mSWxWGKFkcDBO6lGCRbl oHhHWdRt79ILfM0ch+aNuQB61tzrYzseppZwwRNPHCqTOMkDqTQldktnlmr+dLq7tfRMjZ4B9KUx xLmneIf7EuhgZtmOHT+tKL0Gy54o0CDULUatpGGRhllWqa0EmclDkqVIIIrmkjsoyuhjDBqTVrQY g/eAeppnLNG4kPyL9KCbHoiDL/jUIsS+O2A803axJgTdKyW4jPmBKuMV1xJZQGm3DDeEwKblYDSs YvLHPBrnm7jLdZDEpDCkAlMQhoQyhqjYhNWhEumjFuKJAWqkANNAX9OG05/CuqBJa1uUfYm3joP1 qmI5KRQy59KlCGA7e1agI7ArmgDLfBc0gL9qcIKoCwQDSATnGKAEX5W6GmA1fmuEHbIoA77RExGp /wBmqEea+OTnxHcewX+VZSKKejH52AODWMxotTtlznrUoCbST++INKQzeWoGOpDM684uFramTIvW natyDXtgcj0qkDLtqiRSEiQDcOVJrRXfQzvYzrVtmsXAHQ4qGrF9CXTnWGO4LHGGP86aJMDXdakv gtuD+7Q5J9TV3SCImj6TJckSNwvUCsW9SyzrFqoQRjjHespaDONvIXhlOKcZW2Bm74c8W3Fo0dte DzrfIA3dVrdSuRY9RtzHLbq0WNjDIxTEZ+s2MF5bf6SDtXgkdRQVE8x1/RngmlMR8xUPJXuOxqWh tW1M7S9Ku9QuVjtoySTySOBWbdhnqnh/QbLw3ZNcXIXzSNzOaqFNyE2cf4k8aXEuohrGQxxxH5f9 quhtRVjOzZtWN7p/i6yCzqIb9BwfWs3ZlLQ4/wARadPYztFOvfg9jWTVirlrwhrraVMLeclrSTgg 9qqMuhLRc8S6XHaXwntwPJn547GpqI6cO/esZE1mwXcFrk5tT0pU9NCiP3cykjoa1Rw1IWNhdRiC jjtWljn1PQ4idxrA0INSkwgHrUtkmSwyKSArKq+d83TNdMSGdDsgFkSAMhaTBHPpnefSsZIokrMB tAAelIYmaBCMaYzN1VvlC+pFVERbsl2wLSbAsikAnSmgNTTlyFJ7c11QJE8QsDbBB1JyapiOdkhL xMBwcdajYZz9zdXNvIUZ+n61omTYhOozEYJFMCI3Lk54ouBKmpTRrgY/KncB41ebHIWhMCRdXk/u CmncRuR2GoSWguUjjdOuM0hlKxuftF2ilNrA8imgPSdI+WAH/Z/pVCPLPGj7/EV2fQgfoKykMo6S +25HvWUloNF67+Wc+9SkMs6WoZiDUyGbClojhuV9agZI0iL3BoaAoXbBp1IrWmJl60zkVuQbduPl qkDIVtFuLh0kLK+PlINdcJ2WphJNsp2W+01SVZnyeME96wnZvQ1jsZGo38q3VzFG3yMxBxU7DsWN A0SXU5A+PkQ+vWobuNaHZC2W1h8tBjHWlawHP6wMODWdTYaOT1ZMNnFZwGZGMNxxWyEen+BNW+1W H2WRv3kfT3FawdzOR0zbJEYNjB4YVo0JPU5ZtAnfUCFP7kHqe49Kyd9jdyTjY3oYNO0G0zCiqT04 7040+5k5WdjgfFOuXt7ctDMrQxA8L61cpqOiGkcbdx7Z8DPNYuV9StEbejRupRom2svORSi3cLHW rcWviO0axuyoulHyt3NbbkPQ4TVtPn0y7aGUEYPB9aylGxaNmDV/tOkLbzkF4j8pok7qxVLSVzQt 1Sa2B4PFcMlZnu02pRuZt5pyuWK8NVQkZ1KXNsZn2dxxt6VtznJ9XZ6eVJfcGxg1ByFO/ky4HpWb YikxwtAGVc3XlyE5rqgQX7fUTLBtDHpihuwIWPIFYSYx2ayGJQAmaACgBppgZeonMqD/AGqqIjRt hiFPpSGTgUWAULk8VURGxpmFUDHJPFdUUIXUrUzLgnH8IptCMuXT/KjLbhUOIHK67CjSLxzmnEDM +yqecGqsIQ2qe9FgGTW6ovWlYCKKNH/ippAWRaAd6aVhG1ZahOLcwea2PTNW5t6CSZDp0WzU0PTJ qUij0vTf+Pc8gYT+laCPJvFTZ1+8P+3j9BWMhlGwbFytQ9hmjet+94NQthlzSD1I61DGbq/MoyBW YxDGn90UAULpVSdcDFawEy/anJFdBBtW3C4p3Al+2QW8oEw2+hNbQTZEmkcpr94H1EtbvkY6iokr MaehVsLJ7yXGCfU1LGei6DbrZWy4AyOtKKGX7y1+0IZIOSRyKpoRyGtQyRsQ6Mv1FYzKRzGpQvIv yIzH2FZx0KuUrTQb+8kAjgZR6sKsm52nh7w3PpbrNJceW3cVcYslnUHyox5rNuVupHSt0Qw1BJDa t5DbW7EU7WHFnA313eWU0qTF3jkGHBP6is/a62OyVNVIXiMh1CGYLbahEJoz/q5e4FOSUtTlWmhT 1fwxJKBc6dJ56Dny/wCIVny2KKWnC4tnbdbygDg/L0qOaw0irPdSW96JomZHU5HYirUhOJ1TNB4q 0nPC3kQ59avcS0ORa3kSYwH5Xzt54rJ6DTsdJpcE9tCIrgYOOMHrXNUj1PXwtTmjYLoMGyDULQ6m VduecU7k8p6AQuCcVbPFMe8OZjUMRVfkVIGReWkkkuR0reNSxNixZWpiA3VEpXCxeHFQUFAhDQAn 0oAKAGmgDKujuu0H41ohGtEMIo9qgCQDFMoU5AGOtXFEmvpqkoCe3AroRJauHViiqelaCM/UWVYS M44qZAcZrJBmXHTmlECkCcAUwAkbeabAeNN+1R7g+fauWdazLjEzprF7WXB6VrCpcTi0XV/1a81s QgVjGwZaBmpaSJ5iS0kB3WlTrLaM6njbVknlHiJi2tXZPeQ1kykUrY4lX61D2GaVyMAHuahDZpaL 0qJDRtjpUDFpAUL7iVK1gJlyz/hroINiGQRrljgCnYDB17WFkBgiAJ6Z9K1jKxDVzM0+ye9mEakK 2CcmplK5SSRv6HaTWd/JE+CVODjpVR2JZ2FiMxtWT0LQpuJLdiUOKpMGQ3HiCKP5bmAMPWnyxe4t TPuPFelxI2Lbn0xRGnAWpzt94625Wzt1T3NVaERWZlLr95fTAzTHBPQcCsp1Eti4xO08OXYnt2tZ jkEcZopzuZS0ZsWUrK7Wsv3k+6fUVsNGZrmkJdIQBhuqms5x7G9GryM8/uYJbSVoiCAD+Kn2rGMr OzNqlNS95DrXUr0TgRzYkH/jwrS5z7aM3U1GYxh5o13d8dalxTHFnNeIIZDcNcFPlbvily2BspaR qMmmXiSxnjow9RVRlYlnR6/ax3cCaja9xlsU5JMSJLG7+1WcZJ+ePg1lNe6dmFnaRamtTJHkYrlS PV8zP+zuOKLDudvIdqmrZ4hiTtmRjUiIqkBpAosAuMUxBQMSgQUAJQAUANNOwGQ/zXw9hVrYRsrw BUgSrzTGPVPmGe1XERtWJVYlU+ldCRIsiqSG6E81YjK1tjHGMkBc81LVwOR1Dl+OQKErBcqAYpgD KCvAOaTA2dBktmAjuG2gda4asOxrF2K/iE28cpjt2Ei44PvTpRkgkzNi5QZNdy2Mh7AYpgOhdou3 ymkI29H1s6erIwLxMPyrS6Echq8vnalcSjgO5I+lYyKRBbf69frUPYZq3oxis0Nmhov3KmbGjZBr MY7NMDPv/wDWJWkBMswzpDGGc4wK6EiDP1DWHlJjhOB6irWgiHT7H7TKA7heeSafK5bCbsdBpVit nqyRo+7cp/CpcWtyuhqwqV1u7U+uf0FVfXQmxuWA/dmokUgu1+U0hnKa8dqGlNaAcldOTnmsogY8 hO41qgLFi2JB9aiaKOz0ecxyIQcVENGc9ZaXOoMklyqyow8yP8zXbCVzOEtC4k63VtuA+boR6GqW po9DC13SBf25mjTbOnUetY1afVHTQrdJHBXsbJJgqVYd/SsovozSrT05kXdNkF7GyGTZMnPPehto yirotLOZ7Z4iVkA4KnrVrVEtHL3tv5MvyghfeoaA3PDt+AGs5jmNxxmriwY6NTYX7wn7j8ipkty6 bszcsZty7e4rlaPYjJcpYzD/AJFFyedGxdsFjaqZ5RiMck1DAZmpAKYCUwCkIDQAlABQAlADZDhT VAZUPzXx9uKvoI2RUAPWmBKCchc9e9axQjc0+3YxB26HnPtWyTEDg+ew9K0EUNWh8yPG3IqGwOPu AIZ2jcH2OKEwALEeSP0qgGTqgX5Km4FQD5uRik0mK7JRBEwySCaaSQFqG1h29VpjCeBEjO0An2pi K9onmS7SODxipYFzUNJmsYhPgGBj+WaB2Mi6tUnXjhvWkwM+G3eG6UOMc9amWwzQvuorKOxTNDRx +7qJgjXFSkMGYKMsQKLXAy9RuULLsOSK2hBollGWVpsKM+4ro2IL2maS0zhiOKVxm1d6akMSmKJi 4xytdmGcVuYVL2GaYWGqxLJlRg8sMUsRboOle2p0kcUYv7hwwZ8DP5CudGho2JypxUyRSJLgZU0h nG+JyUhcgcik9QOCe8d8/J09KnlArM4LZ9aewFmyBMgxUSGdVYttVT3FY31JnHmibqXTwKsyHj+I V1U52PP1izUtZz5YuYmDxt99R2roTOtaosFj5ylWGxuhqrprUWz0MHxToYkBu7dBn+JQK5KtN7o9 ChVXwyORvbUJGt3YkrInEielZxfRiqQ5XoZVrdSLeh9xBY81q9DmkzQvpYnk8qVcN2NSKLuVY4XS QNDyRyMUIpmtek3NpHPgiWPqKoEb/hS7th/rgN7dCaz5dTZVHax0/lxnkRLg+1Ryj5mZmoPhCKzZ BkZqQEpAFAgNACUAGaADNACZpgJQwI5jhDQIzbD5rtj71b2A2AakBwbFMCeHDt+lawEdBbKyRnHQ CuhEmbf6tb6bJicMfUgU1qIgk8TaX5O7fJn0205RQXKU2u6Y7BmjP121CSHcswazoLLiRynHeOtO RMm49tQ8OEH9+p/7Z0vZhcpSzeHZJP8Aj6VP+2dL2fmFwSfw7G+Dcow9kNNU30C5Or+G5P8Al5Qd +hp+zkFyGeLQD9y8QfnRyMLhb3Hh3TX8yaZpyOQqjihU77sOY53xZ4p/taQQ2kfkWqHIXufrRJKI zJtL8cLJ+dZ3uMul43IKnNJoCK5IkwfSo5B3LFjerbpgjJqXTbC5YfV3I+RQKFTC5UlvJZc7m/Kt ORILjEjZsdaq6Fc2dOskOGNJsDoLVAigAUCJJJbjzligZVJ6E110kkZTZBKk41e1FyFOTjgdaio9 So7Gigjg1WZF43orY/AVmijUs2wGpMaJ3bchpDOR8VjFtIfakM80EmzOD1oAj3ZfipA0tOxv4rOQ zo7Q/LWGxRp2r70aI/hWsWcFaNpE+nXpsH2FfkJ+YVvCZ0U0pRNlyscRdMvbvyfVTW97i+Ezp/FN raAxTHdjofUVSXNowt1RyN7e2l3dObMlAw+6a4qq5XoelSkpxszBmjeCXJHQ8URlzKxy1qTiTXsi zLFIp56Gq2MYos6YWknRVba/Y0ItmvLNKk5huYwpI6jvVNAiK1lMUxQcFDkVBR10WtR+UmTztFIY 3UnzxWEhmdmpATNIAzQAGgBM0CEzQAZoASmAZpMCC5bERpoRR0o5dm+tU9gNUGoAXNMLE9pIVmUY yM10UxHRROywgkEdzW5JzWrESu5lAZD2PasW9R2OWu4I0fEb7lPQVTloFiKbhVFQmFiq5IrTmYrD Ax9aXMwsiCRjnrT5mFi9o9olzNmUnaO1NOXQTQ6/VYrwrGMKO1UpS7hYYhGPm6VXMwsQznrik5XC yKJ+9UNjsJSGXbANLKEyRmk5WAtXFu8LY3ZpKYWEjtbiT7qEinz2DlLsGmXB++NoqHUDlNGDTI0w W+Y1DmyrBfRJGE2gD6URbFYvaePlFboDVgznrTESzPAComJX0Ydq3p3MpJEN9Mn2yyMcgkw3XNKa sOLvoidn3a0p6ZjX+VSBtWo++BSZSFYlaRRzvihc2Un0pAeWbd3ApAKkL7+mKQGlYo0Z+7n6VnIZ u2shC/6s1ixly2kcSglcCrjZGNaF1cs3i4IkHFWjGhOzsyvY6zPaXjxGRXiYdD0qnW9mrs7VT5tS OSxN9JLK1sHibsOo+laxnzq5Eo20OSuYPslwxXcu08ZqZRQ4ycXdGpps0F0ymVQ2OGFcqvBnoaVY lTWLRLa6YwZMLcj2rovdHnzjyysVYpCrBlOCKSdhGudWa4jRbgAsvRqu4Ilf/XJKvIIwagon2P2J xQM6XU2BkwK55DKFSAlIBaACmAlAhKQwoEJnFACGgCtfNiE1UQK2kLhCacgNOoQDhTAs2QAlUkd6 3pks6IyF7cjNdD2Ecxq3ysyjtXLNjRz9xAjFCowcc1CkBQuPv49K1iIquasCMnigCu/WgDW0I4c1 pETG6lxeNQIhUcUxjJeegpCKL8OaRQ3pSAv6UdtwKzqbDRfvpFaTg1nEDS0vHljpSkmNGkOKgYtM CnqHRfrVxEy1YH5RiuhEmxB2pgXI4UlwHUEe9aRm4kNFPUrSK2vbRo12guOn4U5NsIqxNc7U1mDH eMUhGzZY3tUstBKMEigZz/iAbrOQH0oA89042scrCaJpD/Dz0qWA+6UmXOAq9gKlyQ0W7OIABu9Y yYWNeHoKzKJRwaFoTJcysXVxLBitked8MjAkBTUSGAFYYnSB6uHnzI1bUSyyRxxbjnOVBxkVpSna KKnG7JL/AEWxubZ4t3lTg8bz3rqjqYyVjiXjbTbk46qecd6mcLl0qjgzS8xLy1JXByOnpXMm4s7J 01VjdGMQY3wRW61RwSjyuxKDkZFAjXs5GNpkDJWgovLMpUH1FAGzdvulNc7KIakBtIBaQCZpgJmm IM0gEoAAaAEJoAo6m2IT9KqO4MXSxiGnLcC/UgOFAFixy0vA6cCt4CZv7TDDlugrd7EnLas24SMK 5ZblGVbAyRlz2FSIy7n/AFjVrECnIasRETQBE1MDR0RsSGrQh2pH/SiaAIV4oAbJ0oEUpBhqRQ2k Bd0shbgZ6VE9hov3oRnGBWcdgNDToEMYPP51MmyjQ8kcYZh+NK9gDy5AciU/iKYFTUGbYAxH4VUQ ZZ0twyAZ5FbIk3bfjFWI0bcc1SEV9cUh7STssgpsSG6mwOsWpXvH/U0CZrWQxK3NJjiPuePmHakU YOvYNs59RSA8yU7ZmA45qWBo8PEuetY9Rl+BAFHtUMovxYwKQElIY+wnzI8Z7Vqjgqxs7jNStf3q zLt465rOurxsaYSdpWF0gr9tG5ygUcEdqmmvdsejPfQreKJ5IoFkVwctnPeuuLsZSOXuZUu4fMQE OPvCrbMrXK1ldtazDn5T1FYzjdHRSrezZqXUCXEXmxfjWUZOL1OmrSU48yM9SYzg1076o85px0Ot 8GRxXSzwSAHIyKEO5I+mOjsoBwDinYRclbLk1xGgzNACUgCgAzQAhoEGaAEzQAlAATQBm6qf3eKq IFnT1xAKG9QLgpAOFAGlpKoJVJPTmuqmJmxesht8LznitHoiTlrtRIXHY1xz3KKRh8iAihBY5+5P 7xq1iIpSGrEQk0ARsaYFnTpfLfNUhWJ7l/Mm3ZpgCdOlADZB7UCKcww1IoipAWbJsSiplsBoTHJF Qhm1pvEQrKQy67hFyaBkYMr8/dWmBWvo1EWR19aaYEdhJ5be1apknSWcu9RVoRopcLAu9wdo61tG NyWxdUliubSN4nVgGB6+4qnBoSaIdXjMepWRB6of51CBovLP9nmBbp3pvUaLE9zCYyfMXFRYq5ym u6mhgeNBk0bAeesx8wn3qGBftpd5UelZsZt2mGUVkykXBwKkAosIitm2Xj8gCtURVjeOhduZ1kiK AUS1RxU/dkQaLlZZmUBgByDUQVj1IvmMjxYyjYi7hxnmtoikYGnnEoBHB7VciIq5fk06Pc0iqQPS joS1rqSxAwjKjMZ6j0rGUb6nXRrNaPYZeWqyL5kY/AVEZ20ZpUpqavE0/A0xj1XYeMiupdzgtbQ9 Aa0RmJx1OaqwHLMeT9a4DQTNIAoAKACgBDQITNMApMBKEMQ0xGVqbfOo96qIGlacQrUsCwKAHiqG aWkoXbI6ngV000QzVvImWEtzgA4qpbAcwclj9a5HuMrXpxEfpSQzmbg/O1bIkpyGrEQmgCNzxTAd C22mBYVs9aYidWyKoBrk1IFOY/NigaI6QElu22VTSaA0nOSMGsxm5p/EQrOQ0WMb5eegpW0GTYos BU1AYhpxQFS368GtRGtaTGLntTTFY2rS8jc7Xxg+tbqXYlog8QWG21S4sgQVYFgvfmt1PQz5Wi1r BP2jTmPBww/UVn0LJ7rnmkhGZOSFNJjMDUB96kxnKyJ87fWshk9p+7Ocik0CN+wI2cVjJFIvDpUj FoAqHH2pvlJ46jtVILXRYtlLqcmqPPqLlkXdPjWOGZipGehFOx20ZaHMeJ/Me6xhmAAA44rSKsXJ mLCCky8U5BT3sdTbKJIFJ6EYo6BUVpDLNIxO0MuNp4oik0Z3aKtyv2K5aMHKHpWNSHY66Na2jLug QqurxTRng9RVUn0ZdaCtdHpA6Cui5xnFZ5rzyxKQBQAUAFAgoAbQAlAwpgDGkBkXx3XKD3q4iNa3 GI1HtUdRk60wHdqpCNbRgFb6D9a6qZLNTUCTAVBwMfpVS2Ecq33j9a45blIp6gcRH6URGczMcs31 rVElSSrQiI0ARN1pgOSmA53K7cUwJY7oDrTEJLc5HAoArA5bJpDHGkAA4NAF+Ft22oYzo7DHlisZ FFhYgWbkihAOEPOd7fnQBWv4wIick00BVt+OgrURpQnIwaSAmIYfd69quPuiY2PWJVVreQ7TnHNb 20uTc3NSmiulsXikDbc55+lK7Qbkl1dQkYB5qkTYz7l128nikwsc5qk45C1DZSOXmYlzz3qBjoWw 3WkwOh0yTKAVlIpGoDWQxaBlRmC3yZJGR2q0NGjplvJO7Kg47mtEjkrQuzdsdNS3ieRySO4rWMS4 rlRBHPLdTEJbbogcdOta8pTYmoeGtL1JchGtbn1xjJqXAISs7mFLpk+nLJbyjOOUYdDTUe5dSaep lNC9xIrKDnODjtWVrPQyTuV9TgaGQZbdxRJFJq5Y8LyN/a0aZ4qIrW5t7S6sz1VV+UfStrGd0cNX AWBoAKQBQAUAIaAGmgQGgBKYCN0NAzIlO69HtVJWQjajGFFZ9Rkq9KoB4qkI19IZVI46n9K64bEs v37r5Dt6jinMSOY7muORSKOpnEVJDOZl6mtkSVZO9WhEOadgGZ5pgOFADGOTQAoGBQAhFACDigBc 0ALQBftMYFQxnS2P+rFYsotRdWpASUAVtQH7k00BRgHzVqI0IulK4FpJCgPy7vatYpPcGXLOHTtT GyaIpN0weK7oUZWujnclexW1Xw5e6YRJC7PbnkeornnLWxcDOkMu0fezWakWNnllEeDkUNgZrxly etIDCnGJmHvSAIl+YUmBuad8jhe1ZSKRsr0rMYtIClcMVvIsHbk9cVpEex12nxfYtOeUgFiOtdEF YiRPczlNJ3j7zCtNhLVnFWvie7sLhvLwyZ6Gkpq4SRp3HjeWWHZ5K7zxxW3MjPYx57zVbwlzBIyj nB4xWcpJFxi2OtLmRUy9uoP94daw9ornVHCX1ZVuis8pLv19aznPsbxw0EXvDdrGmrRlW5opszrU YwWh6co+UfSuk4uVHA55rzzUKACkAuaQBmgBCaAG5oEGaBiZoCwjnCmmBlRjdfGtOgjaTtWS3GyU UwA9Kpbgza0RVJO4ewrtjsQyXWABwnC4zUzYRMGuNsoz9VOIzTiI5qTvW6QirKcCqEQnpVIBgoAc DQBH/EaAHigBDQAgoAKAFoAtWkhBx2qZDOnsJB5YzxWEii9HgZwakZIOKLhYr3/MBqoisZ8HDVqI 0YakdicEZxkA1aT6CH2CSrfq2AwJ45xXp0KyUbM5Zwd7noKxmSxCzAHjpXPUs3oXG6OevrCGMEhB WfKaGNdQxkYwKTQGReRCNTtAGaQHI3fFw496koltVywqWBsW6kEGs2M11HAqGMcPl5wDSGVLZRc6 zBH6HOK2giWd5qEONOKDsK6LGbMfxPL5egxqg2sMcigcTzgORuz1NZ21KYRRyNKrISCDke1OUrF0 6PtDq4Jbm8VIQdzgfTNYObloj0YUo0ldjhC4jkjyUdfvIRV+ydrmFTE9EZOow+Xbj5ATn7wpWRzy qyb0JPCAY6yhJ4x0rWKRM6jasz1EPwK1M7n/2Q= ________________________________________________________________________________
Subject: Windows Installation
Date: Jan 14, 2008
I have just spent two hours researching info on window installation and cleanup for the "Ten". I've learned that acetone is not the best thing to use (crazing, cracking), mineral spirits leave a "oily" residue, and alcohol hardly touches Weld On. Okay then, what to use for cleanup? I glued in one window yesterday. Not entirely happy with the results. Far from 100 per cent flange adhesion, even with modest weights added per Van's instructions to the window (areas of window and fiberglass flange not mated, some might call them bubbles?) Perhaps this is acceptable? Is everyone using strips of fiberglass over the exterior window/fiberglass joint ? If so, why? To hold the window in place, to make a smoother transition from plexi to fiberglass, both? I'm using the stuff Van's recommended for adhesive, Weld-On, and not much inclined to change to something else unless Van's says so, but this stuff is hard to handle and harder to clean up. I'm not a total rooky at this building stuff, finished one RV9A that turned out really nice, but I'm at my wits end with these windows. Any advice would be appreciated. Chuck ________________________________________________________________________________
Subject: Re: Windows Installation
Date: Jan 14, 2008
Haven't got to your point yet but maybe try this stuff to protect the plexi. http://www.aircraftspruce.com/catalog/cspages/discoat4220plexiglass.php And try this method stolen from Deems Davis website to hold window in place with a clamping action http://www.deemsrv10.com/album/Sec%2045%20Cabin%20Doors%20and%20Transpara ncies/slides/DSC04326.html Also I believe in sticking with weld-on, because my quick research shows that it will react with plexi to form a true bond. Like pvc joint glue. I think somebody tried epoxy and weld on using test pieces and said the epoxy plexi joint broke with much less force than the weld-on plexi joint. Finally I understand the thin strip of glass is used as a kind of "dry-wall type tape". It can prevent the joint between the edge of the fiberglass joggle and the plexi from showing up as a hair line crack 100 hours down the road. The plexi-fiberglass do not expand and contract the same so a nice filled and sanded joint will open up over time. If you lay a piece of glass over it you may not get that hair line crack. Its a looks thing. Headed down the above path soon. -Chris Lucas #40072 ----- Original Message ----- From: Chuck Weyant To: rv10-list(at)matronics.com Sent: Monday, January 14, 2008 6:45 PM Subject: RV10-List: Windows Installation I have just spent two hours researching info on window installation and cleanup for the "Ten". I've learned that acetone is not the best thing to use (crazing, cracking), mineral spirits leave a "oily" residue, and alcohol hardly touches Weld On. Okay then, what to use for cleanup? I glued in one window yesterday. Not entirely happy with the results. Far from 100 per cent flange adhesion, even with modest weights added per Van's instructions to the window (areas of window and fiberglass flange not mated, some might call them bubbles?) Perhaps this is acceptable? Is everyone using strips of fiberglass over the exterior window/fiberglass joint ? If so, why? To hold the window in place, to make a smoother transition from plexi to fiberglass, both? I'm using the stuff Van's recommended for adhesive, Weld-On, and not much inclined to change to something else unless Van's says so, but this stuff is hard to handle and harder to clean up. I'm not a total rooky at this building stuff, finished one RV9A that turned out really nice, but I'm at my wits end with these windows. Any advice would be appreciated. Chuck ________________________________________________________________________________
Date: Jan 14, 2008
Chuck: I have completed the four windows and so far they have come out well (no flight or weather stress). I used epoxy/flox (slow cure) as the adhesive and a strapping system to hold the windows in place while they cured ( I used 4 on each window). The strapping was just simple thin cargo straps wrapped around the plane but using multiple soft blocks (rubber sanding pads) at multiple locations between the straps and windows to ensure a tight fit at all 360 degrees around the window. I had previously doubled taped (electrical) the windows at the edges----one layer corresponding to the inside rim of the window recess fiberglass and the second about 1/8 inch outward from the first. After curing I filled in any remaining gaps between fiberglass and window with a epoxy/flox/filler mix and then sanded that junction smooth. (The electrical tape, if you are careful, can take quite a beating and not be disturbed.). I then put two layers of fiberglass over the junction----the first layer being about 1 inch wide and the 2nd maybe 1 1/2 wide but sanded smooth between layers. The second layer abutted the outside (top) layer of tape. When I was happy with how well the result blended in with the fuselage I then removed the top layer of tape and very carefully feathered in the fiberglass on that side. I will then paint to the edge of the 2nd layer of tape. All the above was not my original idea but a combination of suggestions from various sources (Dave Saylor, David Jones, Deems, and others). Hope this helps. Jay Rowe #40301 (just finishing FWF) ----- Original Message ----- From: Chuck Weyant To: rv10-list(at)matronics.com Sent: Monday, January 14, 2008 6:45 PM Subject: RV10-List: Windows Installation I have just spent two hours researching info on window installation and cleanup for the "Ten". I've learned that acetone is not the best thing to use (crazing, cracking), mineral spirits leave a "oily" residue, and alcohol hardly touches Weld On. Okay then, what to use for cleanup? I glued in one window yesterday. Not entirely happy with the results. Far from 100 per cent flange adhesion, even with modest weights added per Van's instructions to the window (areas of window and fiberglass flange not mated, some might call them bubbles?) Perhaps this is acceptable? Is everyone using strips of fiberglass over the exterior window/fiberglass joint ? If so, why? To hold the window in place, to make a smoother transition from plexi to fiberglass, both? I'm using the stuff Van's recommended for adhesive, Weld-On, and not much inclined to change to something else unless Van's says so, but this stuff is hard to handle and harder to clean up. I'm not a total rooky at this building stuff, finished one RV9A that turned out really nice, but I'm at my wits end with these windows. Any advice would be appreciated. Chuck ------------------------------------------------------------------------- --- 1/13/2008 8:23 PM ________________________________________________________________________________
Date: Jan 15, 2008
Chuck, I completed my windows per Van's instruction and at first they came out really nice. After 275 hrs, some of them are showing the joint between the window and the fiberglass. It is showing as a crack in the paint, something I have seen on other RV10s. If I were to do it again, I would use the Weld-On but add a very thin fiberglass tape to cover the joint. This (I think) will add a lot of strength to the joint and provide some level of tolerance for imperfect window adhesion. I would still not relax and do my best to install the windows as if the tape did not exist. Rob On Jan 14, 2008, at 6:45 PM, Chuck Weyant wrote: > I have just spent two hours researching info on window installation > and cleanup for the "Ten". I've learned that acetone is not the > best thing to use (crazing, cracking), mineral spirits leave a > "oily" residue, and alcohol hardly touches Weld On. Okay then, what > to use for cleanup? > > I glued in one window yesterday. Not entirely happy with the > results. Far from 100 per cent flange adhesion, even with modest > weights added per Van's instructions to the window (areas of window > and fiberglass flange not mated, some might call them bubbles?) > Perhaps this is acceptable? > > Is everyone using strips of fiberglass over the exterior window/ > fiberglass joint ? If so, why? To hold the window in place, to > make a smoother transition from plexi to fiberglass, both? > > I'm using the stuff Van's recommended for adhesive, Weld-On, and not > much inclined to change to something else unless Van's says so, but > this stuff is hard to handle and harder to clean up. > > I'm not a total rooky at this building stuff, finished one RV9A that > turned out really nice, but I'm at my wits end with these windows. > Any advice would be appreciated. > Chuck > > ________________________________________________________________________________
Date: Jan 15, 2008
Hey Chris, I like your sheetrock analogy best. We are also soon approaching this stage and will go with the cloth strip -- perhaps carbon fiber. To further the mud joint analogy, I'll probably use a 90 degree die grinder with a 2" quicklock sanding disk and make a shallow depression in the plexi/fiberglass joint (just as edges of sheetrock are tapered) and then fill that back in flush with the tape and glass. And then (just to mess with the purists) I may feather that with ... Bondo! Later, - Lew -------- non-pilot crazy about building waiting on RV-10 finishing kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158263#158263 ________________________________________________________________________________
Date: Jan 15, 2008
Chuck, To provide another perspective, I used the weld-on on my -10 windows with mixed results. The first three windows came out fine (rear window + 1 door). The 4th developed some minor crazing of the plexi around two of the corners where bonded. The windscreen was a complete disaster, the majority of the bonded edge developed cracks up to 1/2 - 2/3 of the was thru the plexi. I did not use any acetone, laquer thinner, MEK, or any other solvents on the plexi and relatively light clamping pressure. The only common theme is that it was getting progressively colder as I did the windows so that may have something to do with it. One thing I did note when removing the windscreen was that the weld-on was well bonded to the plexi but pealed off the fiberglass relatively easily with a little heat. So, for what it's worth, I won't be using the weld-on for the new windscreen and will either go with one of the 3M products or epoxy + cotton flox. Regarding the fiberglass around the perimeter, it supposedly help prevents the cracking in the paint that has shown up in some of the finished -10s. Strictly cosmetic and relatively easy to add. Good luck, Tom Gesele #40473 ----- Original Message ----- From: Chuck Weyant Date: Monday, January 14, 2008 7:06 pm Subject: RV10-List: Windows Installation > I have just spent two hours researching info on window > installation and cleanup for the "Ten". I've learned that > acetone is not the best thing to use (crazing, cracking), > mineral spirits leave a "oily" residue, and alcohol hardly > touches Weld On. Okay then, what to use for cleanup? > > I glued in one window yesterday. Not entirely happy with the > results. Far from 100 per cent flange adhesion, even with > modest weights added per Van's instructions to the window (areas > of window and fiberglass flange not mated, some might call them > bubbles?) Perhaps this is acceptable? > > Is everyone using strips of fiberglass over the exterior > window/fiberglass joint ? If so, why? To hold the window in > place, to make a smoother transition from plexi to fiberglass, both? > > I'm using the stuff Van's recommended for adhesive, Weld-On, and > not much inclined to change to something else unless Van's says > so, but this stuff is hard to handle and harder to clean up. > > I'm not a total rooky at this building stuff, finished one RV9A > that turned out really nice, but I'm at my wits end with these > windows. Any advice would be appreciated. > Chuck > ________________________________________________________________________________
Date: Jan 15, 2008
Hey, folks We're coming up on the same decision... For those who have chosen to use Sika-flex 295 UV, what do you think of it by now? It seems to me like a natural choice for our windows. Does anybody have information to the contrary? How about experience with 3M 2216? Marlys and John Ackerman 40458 On Jan 14, 2008, at 4:45 PM, Chuck Weyant wrote: > I have just spent two hours researching info on window installation > and cleanup for the "Ten". I've learned that acetone is not the > best thing to use (crazing, cracking), mineral spirits leave a > "oily" residue, and alcohol hardly touches Weld On. Okay then, > what to use for cleanup? > > I glued in one window yesterday. Not entirely happy with the > results. Far from 100 per cent flange adhesion, even with modest > weights added per Van's instructions to the window (areas of window > and fiberglass flange not mated, some might call them bubbles?) > Perhaps this is acceptable? > > Is everyone using strips of fiberglass over the exterior window/ > fiberglass joint ? If so, why? To hold the window in place, to > make a smoother transition from plexi to fiberglass, both? > > I'm using the stuff Van's recommended for adhesive, Weld-On, and > not much inclined to change to something else unless Van's says so, > but this stuff is hard to handle and harder to clean up. > > I'm not a total rooky at this building stuff, finished one RV9A > that turned out really nice, but I'm at my wits end with these > windows. Any advice would be appreciated. > Chuck > > ________________________________________________________________________________
Subject: RV-10 finishing kit-recommended deletions???
Date: Jan 15, 2008
Ordering my finishing kit in the next two weeks. Engine will be a IO-540. Other than cowls ( I'm still undecided about James), what recommendations does the group have as to deletions because other aftermarket items seem to be better than the items furnished by Van's? Or is the finishing kit really pretty good as is? Thanks, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158324#158324 ________________________________________________________________________________
Subject: Re: RV-10 finishing kit-recommended deletions???
Date: Jan 15, 2008
Skip the nose wheel-valve stem clearence to close.James cowl requires different (expensive) spinner.I would be interested in anybodies hands on Rv-10 James cowl experience-Rumor has it there are some bugs.The glass is nicer than vans. -----Original Message----- From: tomhanaway <tomhanaway(at)adelphia.net> Sent: Tue, 15 Jan 2008 9:57 am Subject: RV10-List: RV-10 finishing kit-recommended deletions??? Ordering my finishing kit in the next two weeks. Engine will be a IO-540. Other than cowls ( I'm still undecided about James), what recommendations does the group have as to deletions because other aftermarket items seem to be better than the items furnished by Van's? Or is the finishing kit really pretty good as is? Thanks, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158324#158324 ________________________________________________________________________ ________________________________________________________________________________
Date: Jan 15, 2008
Sorry to hear of your window development. Some did not want to hear my post two + years ago as to what was found with Lancair's and those darned plastic aircraft. VAN is relatively new to big plastic canopies which led to a discussion on ways to reduce this likelihood. Deems gave an excellent alternative method. Jesse who has replaced a windscreen can add first person perspective on both removal, product choice and re-installation. The adhesive agent, the method of mounting and the cleanliness of the work will all contribute to the final outcome. No one wants to do this job twice. A similar job can surface with the improper use of fillers over the countersink head of rivets which secure dissimilar products like aluminum and fiberglass. Research carefully. The disband usually takes two to three annual Winter/Summer cycles to fully cure. Pictures of sunken filler over fasteners (under a $28,000 paint job are available on request). I encourage a fiberglass cover strip. I strongly encourage epoxy and not bondo (polyester filler) on the products. The great thing here is that there are so many ways to do this task. Each of us becomes that manufacturer with the end Serviceability of our efforts the result of our planning and research. My hat is off to Dave Saylor to share his techniques with the RV-10 group by hosting a seminar. When working with composites, talk to a composite specialist. When working with aluminum talk to a Vans builder. John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Sent: Tuesday, January 15, 2008 3:57 AM Subject: Re: RV10-List: Windows Installation Chuck, I completed my windows per Van's instruction and at first they came out really nice. After 275 hrs, some of them are showing the joint between the window and the fiberglass. It is showing as a crack in the paint, something I have seen on other RV10s. If I were to do it again, I would use the Weld-On but add a very thin fiberglass tape to cover the joint. This (I think) will add a lot of strength to the joint and provide some level of tolerance for imperfect window adhesion. I would still not relax and do my best to install the windows as if the tape did not exist. Rob On Jan 14, 2008, at 6:45 PM, Chuck Weyant wrote: I have just spent two hours researching info on window installation and cleanup for the "Ten". I've learned that acetone is not the best thing to use (crazing, cracking), mineral spirits leave a "oily" residue, and alcohol hardly touches Weld On. Okay then, what to use for cleanup? I glued in one window yesterday. Not entirely happy with the results. Far from 100 per cent flange adhesion, even with modest weights added per Van's instructions to the window (areas of window and fiberglass flange not mated, some might call them bubbles?) Perhaps this is acceptable? Is everyone using strips of fiberglass over the exterior window/fiberglass joint ? If so, why? To hold the window in place, to make a smoother transition from plexi to fiberglass, both? I'm using the stuff Van's recommended for adhesive, Weld-On, and not much inclined to change to something else unless Van's says so, but this stuff is hard to handle and harder to clean up. I'm not a total rooky at this building stuff, finished one RV9A that turned out really nice, but I'm at my wits end with these windows. Any advice would be appreciated. Chuck http://forums.matronics.com style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 15, 2008
Hey, thanks guys for all the info. Think I'll stick with the Weld On, do more taping in the prep (to cut down on cleanup), and do the fiberglass strip around the exterior perimeter of the windows. Chuck ----- Original Message ----- From: Jay Rowe To: rv10-list(at)matronics.com Sent: Monday, January 14, 2008 7:44 PM
January 03, 2008 - January 15, 2008
RV10-Archive.digest.vol-cy
