RV10-Archive.digest.vol-dc
February 22, 2008 - March 04, 2008
      >> errors".
      >> Nine employees of the Arab airline were in the aircraft, but "no
      >> employees"
      >> from Airbus were present.
      >> The Arab's taxied out to the run-up area.
      >> Then they took all four engines to takeoff power with virtually an
      >> empty
      >> aircraft. (They obvious didn't read the run-up manuals.)
      >> No chocks were set, (not that it would have mattered at that power
      >> setting).
      >> "Brakes will not hold it back at full power anyway".
      >> As it turns out the takeoff warning horn was blaring away in the
      >> cockpit
      >> because they had all FOUR engines at full power.
      >> The aircraft computers thought they were trying to takeoff but it
      >> had not
      >> been configured properly (flaps/slats, etc, etc).
      >> Then one of these brain surgeons decided to pull the "Ground Sense"
      >> circuit breaker to quiet the alarms.
      >> This fools the aircraft into thinking it is in the air."A big, big
      >> mistake"!
      >> As soon as they did that, the computers automaticlly "released" all
      >> the
      >> brakes. ("this is a Safety feature so that pilots don't land with
      >> the brakes
      >> on".)There was No time to stop and no one smart enough thought to
      >> reduce the
      >> max power setting.....
      >> So the rest is as you see it below.
      >> No one is talking, so who knows if there were survivors.
Subject: Rudder Trim - Spring Bias
Date: Feb 22, 2008
I have 'developed' a spring bias rudder trim system for the RV-10. After sharing this idea with Deems he encouraged me to do the same with the rest of the group. So here goes, but before I get into any details let me preface this whole conversation with a few thoughts. This is all in theory, I have absolutely no actual flight testing to back up any of the 'claims', or assumptions. Just good old common sense and a tiny bit of engineering. Our airplane is not in the air yet, I had hoped to get in the air, prove out the system, then share with the world. To prevent anyone else for possibly needlessly cutting into their rudder to add a trim tab, I have decided to bear the scrutiny of an unproven, theoretical system. Please be gentle... I will attempt to verbalize the system. I used two torsion springs, one mounted / wrapped around, each rudder bar (the bar that connects the rudder pedals). One of the springs is fixed on both ends providing a torsional force on the rudder bar. The other springs free end is hooked to a servo motor that allows approximately 30 degrees deflection. The theory is that the two springs will seek equilibrium (OK, that's not much theory, that's more fact), here is where the testing needs to happen. If I deflect the one springs free arm 30 degrees, will it create enough force to put the airplane in trim. The springs apply about an 8 pound force to the rudder cables (pre-load if you will), assuming they will want to maintain in equilibrium a 30 degree deflection should be more than enough to trim the airplane. The servo will act as sort of a fine tuning mechanism, the course adjustment will be accomplished by winding more or less tension in one spring or the other during flight testing. I like a few things about this method. 1) It can be installed to any flying airplane with no modifications required other than wiring. 2) There is a chance that this system could be made manual and eliminate the RAC servo if desired. 3) This system provides tension to both rudder cables, no more 'flopping rudder'. 4) Keeps the rudder 'clean'. 5) Doesn't add much extra rudder input force. I sent pictures of this system to Deems, I will 'attempt' to post some pictures to this forum if there is interest. Comments welcome, I apologize for the extremely long post, but I have added Deems questions below, I figured if he asked, many more will have the same questions.... 1. How did you determine which spring type/size/strength to use? OK, you busted me!! I didn't do the math, I feel extremely guilty about this, as an engineer, I should probably go back and figure the forces here. Here is what I did; since I grew up in the business of garage doors (my Dad owned his own company doing this), I went to Fleet Farm (one of our local supply houses, similar to most lumbar yards) and found a garage door spring that had an ID that would slide over the rudder bar with room to spare, and would fit between the two rudder bars (I will measure this for you). I then cut lengths of the spring until I got what I 'thought' was a reasonable amount of force with two turns of pre-load, and bent some custom ends on them. With torsion springs you have two options to increase the reaction force. You can add turns of pre-load, or you can shorten the spring with the same number of turns. I just went until I reached what I 'felt' was a happy medium. Remember that as you wind a torsion spring more and more the inside diameter decreases, until it eventually binds on the shaft (rudder bar). What mostly drove me not to do the math, was I had absolutely no idea what sort of corrective rudder pressure was required to put the ball in the middle. My plan all along has been to get it in the air and do some experimenting, I installed the system so that modification of the spring force should be simple. I just need to start dating a contortionist :) 2. I assume that you can 'adjust the torsional load somewhat by moving the collar/s, Is that true? Correct, I started out with each spring wound an equal amount. If I find that I need additional trim to one side or the other I will wind one of the springs to compensate. The servo will just provide the 'fine tuning'. 3. One of the pictures shows the center support brace minus the delrin bushings, I'm assuming that leaving those out is not a requirement of your approach and was just the result of taking the picture before they were installed? Correct, in fact there isn't a single modification to the airframe, if I remove the system no one could ever tell it was installed. I built the mount so that it could be used in either the forward or aft rudder mounting positions, my pedals are mounted in the aft position. But I drilled and prepped the airframe to mount the rudder pedals in either position. 4. What about the mount for the RAC servo, do you have a picture of it before the servo is mounted. See attached.... The angle was determined by something, I just don't recall what anymore. I know it has to be at an angle to work though. I can measure if you decide to attempt this. 5. Also it' looks like you used a small section of SS cable to connect the servo arm to the spring coil, correct? Picture? Correct, see attached. One end is run through the servo arm, the other gets hooked by the spring. The spring on the pilot side is hooked over the opposite rudder bar. I gave some thought to your desire to have a manually operated system, I think this system could be done manually with very little pain. You may be able to add a knob that would come out of the sub panel, really anywhere along its length. What would have to happen is a bracket would need to be made that slid over the rudder bar with a nut in it. Then a threaded shaft running from the rudder bar to the sub panel would be used to adjust the free arm of the spring. It may be best if the spring were pushed by the shaft instead of pulled, as this would make the mechanism a bit simpler. I could do a drawing of what I am thinking if you are not following. While it was not my intention to begin producing kits, if there is enough interest, I could be persuaded to fabricate a few. Thanks, Jason Jason Kreidler - 40617 Finishing (4 Partner Build) ________________________________________________________________________________
Subject: Amendment and Revision to Kit Building Rules - Where's
the Leadership?
Date: Feb 22, 2008
Deems, you have hit it on the head. Randy Hansen is our (everyone's EAA Government Relations Rep). He wrote this glowing passage after Oregon killed an exclusion for one grade of gasoline to be available for aircraft operators of STCed MOGAS engines and LSAs with Rotax (which require a restriction on 100LL). "When we sent our first EAA member e-Alert/Notice to Oregon members, Dan Clem and the Department of Ag were very strongly opposed to asking the state legislature to amend the new ethanol mandating bill. They said that because this was only a special secession and that all special secession bills had already been identified, that any modifications would not be looked at or accepted. In actual practice, the OPA and EAA members were able to bring their concerns before their individual legislators and get the bill listing several exemptions, including aviation, introduced and acted on. Hopefully, this afternoon the bill will be finalized and passed. While the "exclude all premium gasoline from ethanol-blending" point of view has not, so far, carried the day - it has been an overwhelming success to get this far into the special Oregon legislature secession with a bill that state advisors said should not have happened. So, EAA must offer our congrats to the entire team for this huge effort and success." The role of the Director of Aviation, Dan Clem, has now been brought into question on Ethanol at the Pump. Nothing about HB2210 which is law or the SB1079 Amendment A6 which was supposed to correct it during the Emergency Session this week, can be called a success. When pilots, who had waited hours for the Railroad Lobbyists to finish talking, our legislators walked out of the hearing on them. The result is that Oregon is the first state in the union to mandate that all consumers buy adulterated fuel at the pump with a minimum of 10% ethanol. Greenies want all states to mandate Ethanol. Several states provided fuel exemptions. Oregon is not one of them. The First Responders who use gasoline emergency generators, the boat and auto aficionados and of course aviators be damned. Everything was tried, nothing persuaded our legislators. The EAA did nothing but offer congrats to some entire team which did not represent our interests. Now all of you flying from other states had better check fuel supply first. Don't get me wrong, I love the EAA for what it presents, but legislative and government relations are a travesty. The ARC is not much different. The EAA needs to focus primarily on Experimental Certificated Aircraft.... Period. John Cox #600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, February 22, 2008 7:22 AM Subject: Re: RV10-List: Amendment and Revision to Kit Building Rules - Where's the Leadership? It's too bad the ARC couldn't agree on proposed rule changes, (for 'economic' reasons) so now we're left with the FAA drafting the changes. Its fairly obvious that based on the varied interests of the representative parties, that ANY changes that were considered were going to result in a financial hit to at least one of the represented segments. In this business world this is what happens when there is a Leadership void. Which is what I see happening here. What I find personally extremely disappointing is that the EAA, who at one time was the best representative for 'us' (homebuilders) seems to have become a victim of the 'special interests' and has followed vs. lead on this one. My letter is on it's way. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ > * > * ________________________________________________________________________________
Subject: Re: WRECKED A340-600 at TULOUSE FRANCE 11-07
Date: Feb 22, 2008
msausen wrote: > "Would it have been as comic had the aircraft been painted with British Airway colors?" > > Hell yes! -- Its Friday so I guess we have to be politically correct. Ya-all have a good day! -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165583#165583 ________________________________________________________________________________
Date: Feb 22, 2008
> William I agree with you but can you tell me what Dr Suess has to do with RV's? That's in jest --right? I can't tell? William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess ________________________________________________________________________________
Subject: Mod1 Overhead Console
Date: Feb 22, 2008
Yet another overhead. Pretty nice and small too. The Mod1 Overhead Console is mounted to top of cabin or top wing skin with four stainless steel screws into the four standoffs or posts on Console. The lights are the same ones that come standard w/ Accuracy Overhead. I think I've seen them on Stein's website too. http://www.cockpitlights.com/console.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165588#165588 ________________________________________________________________________________
Date: Feb 22, 2008
Subject: Re: Rudder Trim - Spring Bias
When do we get to see some pictures? -----Original Message----- >From: jason.kreidler(at)regalbeloit.com >Sent: Feb 22, 2008 12:55 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Rudder Trim - Spring Bias > >I have 'developed' a spring bias rudder trim system for the RV-10. After >sharing this idea with Deems he encouraged me to do the same with the rest >of the group. So here goes, but before I get into any details let me >preface this whole conversation with a few thoughts. This is all in >theory, I have absolutely no actual flight testing to back up any of the >'claims', or assumptions. Just good old common sense and a tiny bit of >engineering. Our airplane is not in the air yet, I had hoped to get in >the air, prove out the system, then share with the world. To prevent >anyone else for possibly needlessly cutting into their rudder to add a >trim tab, I have decided to bear the scrutiny of an unproven, theoretical >system. Please be gentle... > >I will attempt to verbalize the system. I used two torsion springs, one >mounted / wrapped around, each rudder bar (the bar that connects the >rudder pedals). One of the springs is fixed on both ends providing a >torsional force on the rudder bar. The other springs free end is hooked >to a servo motor that allows approximately 30 degrees deflection. The >theory is that the two springs will seek equilibrium (OK, that's not much >theory, that's more fact), here is where the testing needs to happen. If >I deflect the one springs free arm 30 degrees, will it create enough force >to put the airplane in trim. The springs apply about an 8 pound force to >the rudder cables (pre-load if you will), assuming they will want to >maintain in equilibrium a 30 degree deflection should be more than enough >to trim the airplane. The servo will act as sort of a fine tuning >mechanism, the course adjustment will be accomplished by winding more or >less tension in one spring or the other during flight testing. > >I like a few things about this method. >1) It can be installed to any flying airplane with no modifications >required other than wiring. >2) There is a chance that this system could be made manual and eliminate >the RAC servo if desired. >3) This system provides tension to both rudder cables, no more 'flopping >rudder'. >4) Keeps the rudder 'clean'. >5) Doesn't add much extra rudder input force. > >I sent pictures of this system to Deems, I will 'attempt' to post some >pictures to this forum if there is interest. Comments welcome, I >apologize for the extremely long post, but I have added Deems questions >below, I figured if he asked, many more will have the same questions.... > > >1. How did you determine which spring type/size/strength to use? >OK, you busted me!! I didn't do the math, I feel extremely guilty about >this, as an engineer, I should probably go back and figure the forces >here. Here is what I did; since I grew up in the business of garage doors >(my Dad owned his own company doing this), I went to Fleet Farm (one of >our local supply houses, similar to most lumbar yards) and found a garage >door spring that had an ID that would slide over the rudder bar with room >to spare, and would fit between the two rudder bars (I will measure this >for you). I then cut lengths of the spring until I got what I 'thought' >was a reasonable amount of force with two turns of pre-load, and bent some >custom ends on them. With torsion springs you have two options to >increase the reaction force. You can add turns of pre-load, or you can >shorten the spring with the same number of turns. I just went until I >reached what I 'felt' was a happy medium. Remember that as you wind a >torsion spring more and more the inside diameter decreases, until it >eventually binds on the shaft (rudder bar). What mostly drove me not to >do the math, was I had absolutely no idea what sort of corrective rudder >pressure was required to put the ball in the middle. My plan all along >has been to get it in the air and do some experimenting, I installed the >system so that modification of the spring force should be simple. I just >need to start dating a contortionist :) > >2. I assume that you can 'adjust the torsional load somewhat by moving >the collar/s, Is that true? >Correct, I started out with each spring wound an equal amount. If I find >that I need additional trim to one side or the other I will wind one of >the springs to compensate. The servo will just provide the 'fine tuning'. > >3. One of the pictures shows the center support brace minus the delrin >bushings, I'm assuming that leaving those out is not a requirement of >your approach and was just the result of taking the picture before they >were installed? >Correct, in fact there isn't a single modification to the airframe, if I >remove the system no one could ever tell it was installed. I built the >mount so that it could be used in either the forward or aft rudder >mounting positions, my pedals are mounted in the aft position. But I >drilled and prepped the airframe to mount the rudder pedals in either >position. > >4. What about the mount for the RAC servo, do you have a picture of it >before the servo is mounted. >See attached.... The angle was determined by something, I just don't >recall what anymore. I know it has to be at an angle to work though. I >can measure if you decide to attempt this. > >5. Also it' looks like you used a small section of SS cable to connect >the servo arm to the spring coil, correct? Picture? >Correct, see attached. One end is run through the servo arm, the other >gets hooked by the spring. The spring on the pilot side is hooked over >the opposite rudder bar. > >I gave some thought to your desire to have a manually operated system, I >think this system could be done manually with very little pain. You may >be able to add a knob that would come out of the sub panel, really >anywhere along its length. What would have to happen is a bracket would >need to be made that slid over the rudder bar with a nut in it. Then a >threaded shaft running from the rudder bar to the sub panel would be used >to adjust the free arm of the spring. It may be best if the spring were >pushed by the shaft instead of pulled, as this would make the mechanism a >bit simpler. I could do a drawing of what I am thinking if you are not >following. > >While it was not my intention to begin producing kits, if there is enough >interest, I could be persuaded to fabricate a few. > >Thanks, Jason > >Jason Kreidler - 40617 Finishing >(4 Partner Build) ________________________________________________________________________________
Date: Feb 22, 2008
In a message dated 2/22/2008 12:08:17 PM Central Standard Time, wcurtis(at)nerv10.com writes: That's in jest --right? I can't tell? I was hoping to lighten the moment and work off of the comment... P 8-] **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Feb 22, 2008
Jason, its sounds like a very elegant solution i can't wait to see some pics. [Steven DiNieri] rom: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com Sent: Friday, February 22, 2008 12:55 PM Subject: RV10-List: Rudder Trim - Spring Bias I have 'developed' a spring bias rudder trim system for the RV-10. After sharing this idea with Deems he encouraged me to do the same with the rest of the group. So here goes, but before I get into any details let me preface this whole conversation with a few thoughts. This is all in theory, I have absolutely no actual flight testing to back up any of the 'claims', or assumptions. Just good old common sense and a tiny bit of engineering. Our airplane is not in the air yet, I had hoped to get in the air, prove out the system, then share with the world. To prevent anyone else for possibly needlessly cutting into their rudder to add a trim tab, I have decided to bear the scrutiny of an unproven, theoretical system. Please be gentle... I will attempt to verbalize the system. I used two torsion springs, one mounted / wrapped around, each rudder bar (the bar that connects the rudder pedals). One of the springs is fixed on both ends providing a torsional force on the rudder bar. The other springs free end is hooked to a servo motor that allows approximately 30 degrees deflection. The theory is that the two springs will seek equilibrium (OK, that's not much theory, that's more fact), here is where the testing needs to happen. If I deflect the one springs free arm 30 degrees, will it create enough force to put the airplane in trim. The springs apply about an 8 pound force to the rudder cables (pre-load if you will), assuming they will want to maintain in equilibrium a 30 degree deflection should be more than enough to trim the airplane. The servo will act as sort of a fine tuning mechanism, the course adjustment will be accomplished by winding more or less tension in one spring or the other during flight testing. I like a few things about this method. 1) It can be installed to any flying airplane with no modifications required other than wiring. 2) There is a chance that this system could be made manual and eliminate the RAC servo if desired. 3) This system provides tension to both rudder cables, no more 'flopping rudder'. 4) Keeps the rudder 'clean'. 5) Doesn't add much extra rudder input force. I sent pictures of this system to Deems, I will 'attempt' to post some pictures to this forum if there is interest. Comments welcome, I apologize for the extremely long post, but I have added Deems questions below, I figured if he asked, many more will have the same questions.... 1. How did you determine which spring type/size/strength to use? OK, you busted me!! I didn't do the math, I feel extremely guilty about this, as an engineer, I should probably go back and figure the forces here. Here is what I did; since I grew up in the business of garage doors (my Dad owned his own company doing this), I went to Fleet Farm (one of our local supply houses, similar to most lumbar yards) and found a garage door spring that had an ID that would slide over the rudder bar with room to spare, and would fit between the two rudder bars (I will measure this for you). I then cut lengths of the spring until I got what I 'thought' was a reasonable amount of force with two turns of pre-load, and bent some custom ends on them. With torsion springs you have two options to increase the reaction force. You can add turns of pre-load, or you can shorten the spring with the same number of turns. I just went until I reached what I 'felt' was a happy medium. Remember that as you wind a torsion spring more and more the inside diameter decreases, until it eventually binds on the shaft (rudder bar). What mostly drove me not to do the math, was I had absolutely no idea what sort of corrective rudder pressure was required to put the ball in the middle. My plan all along has been to get it in the air and do some experimenting, I installed the system so that modification of the spring force should be simple. I just need to start dating a contortionist :) 2. I assume that you can 'adjust the torsional load somewhat by moving the collar/s, Is that true? Correct, I started out with each spring wound an equal amount. If I find that I need additional trim to one side or the other I will wind one of the springs to compensate. The servo will just provide the 'fine tuning'. 3. One of the pictures shows the center support brace minus the delrin bushings, I'm assuming that leaving those out is not a requirement of your approach and was just the result of taking the picture before they were installed? Correct, in fact there isn't a single modification to the airframe, if I remove the system no one could ever tell it was installed. I built the mount so that it could be used in either the forward or aft rudder mounting positions, my pedals are mounted in the aft position. But I drilled and prepped the airframe to mount the rudder pedals in either position. 4. What about the mount for the RAC servo, do you have a picture of it before the servo is mounted. See attached.... The angle was determined by something, I just don't recall what anymore. I know it has to be at an angle to work though. I can measure if you decide to attempt this. 5. Also it' looks like you used a small section of SS cable to connect the servo arm to the spring coil, correct? Picture? Correct, see attached. One end is run through the servo arm, the other gets hooked by the spring. The spring on the pilot side is hooked over the opposite rudder bar. I gave some thought to your desire to have a manually operated system, I think this system could be done manually with very little pain. You may be able to add a knob that would come out of the sub panel, really anywhere along its length. What would have to happen is a bracket would need to be made that slid over the rudder bar with a nut in it. Then a threaded shaft running from the rudder bar to the sub panel would be used to adjust the free arm of the spring. It may be best if the spring were pushed by the shaft instead of pulled, as this would make the mechanism a bit simpler. I could do a drawing of what I am thinking if you are not following. While it was not my intention to begin producing kits, if there is enough interest, I could be persuaded to fabricate a few. Thanks, Jason Jason Kreidler - 40617 Finishing (4 Partner Build) ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Feb 22, 2008
Enclosed are a few photographs.... Thanks, Jason Jason Kreidler - 40617 Finishing (4 Partner Build) -------- RV-10 Quick Build 4 Partner Build - Finishing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165593#165593 Attachments: http://forums.matronics.com//files/copilotside_947.jpg http://forums.matronics.com//files/overview_610.jpg http://forums.matronics.com//files/pilotside_821.jpg http://forums.matronics.com//files/servomtg1_720.jpg ________________________________________________________________________________
Date: Feb 22, 2008
From: Carlos Hernandez <carlosh(at)structuralaz.com>
First I must admit I'm building a 7A. Second - you guys are an awesome resource for ideas! Do any of you repeat offenders know if the rudder tubes are the same size in the 10 and 7? I like this idea very much and, with your permission Jason, I'd like to use it if it works. Carlos in Arizona (Watching this development with great interest.) jkreidler wrote: > > Enclosed are a few photographs.... > > Thanks, Jason > > Jason Kreidler - 40617 Finishing > (4 Partner Build) > > -------- > RV-10 Quick Build > 4 Partner Build - Finishing > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=165593#165593 > > > Attachments: > > http://forums.matronics.com//files/copilotside_947.jpg > http://forums.matronics.com//files/overview_610.jpg > http://forums.matronics.com//files/pilotside_821.jpg > http://forums.matronics.com//files/servomtg1_720.jpg > > > -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Subject: Airbus response
Date: Feb 22, 2008
It seems that the first response on the PC crowd in this country is to play the racism card. I assure you that the ethnicity of those on board was the least of my concerns. The real concern was the stupidity of the airmen. However let's address the race issue. I spent 16 years living and working in the Middle East so I know better than most the strengths and weaknesses of the culture. I have visited in their villages , attended their weddings and speak, read and write limited Arabic. I assure you that there are more incompetents in technical positions in the East than in the West; this is in part due to their culture and religion. As an example I was hiring a data processing analyst for my group; I was sent two Arabs by my Arab boss ( a stand in vacation replacement) for the interview. Both had been schooled in the USA. Both had BS degrees in computer science and one had a MS in computer science. One had a BS in computer science from Eastern Michigan University where his transcript showed barely passing grades. The other had a BS and MS from Florida State University and had a GPA A-. Needless to say I chose the good grade fellow. My stand in boss then told me to hire the low grade fellow; It so happened that that fellow was of the same tribe as my stand in boss and brother of the Manager of computer operations. I did as instructed and when my real boss (another Arab, same tribe) returned I recounted the situation. Shortly thereafter my first choice was sent to my group and the low graded fellow was put somewhere else. In another case the head of the Aviation department is a well qualified Arab who has qualified as a B737 and G IV captain at Flight Safety where ratings are not handed out by tribal decree. ________________________________________________________________________________
Date: Feb 22, 2008
Jason; you mentioned "While it was not my intention to begin producing kits, if there is enough interest, I could be persuaded to fabricate a few. " I may be interested after hearing how well it works and you feel that the "engineering" is complete. Thanks! Pascal ----- Original Message ----- From: jason.kreidler(at)regalbeloit.com To: rv10-list(at)matronics.com Sent: Friday, February 22, 2008 9:55 AM Subject: RV10-List: Rudder Trim - Spring Bias I have 'developed' a spring bias rudder trim system for the RV-10. After sharing this idea with Deems he encouraged me to do the same with the rest of the group. So here goes, but before I get into any details let me preface this whole conversation with a few thoughts. This is all in theory, I have absolutely no actual flight testing to back up any of the 'claims', or assumptions. Just good old common sense and a tiny bit of engineering. Our airplane is not in the air yet, I had hoped to get in the air, prove out the system, then share with the world. To prevent anyone else for possibly needlessly cutting into their rudder to add a trim tab, I have decided to bear the scrutiny of an unproven, theoretical system. Please be gentle... I will attempt to verbalize the system. I used two torsion springs, one mounted / wrapped around, each rudder bar (the bar that connects the rudder pedals). One of the springs is fixed on both ends providing a torsional force on the rudder bar. The other springs free end is hooked to a servo motor that allows approximately 30 degrees deflection. The theory is that the two springs will seek equilibrium (OK, that's not much theory, that's more fact), here is where the testing needs to happen. If I deflect the one springs free arm 30 degrees, will it create enough force to put the airplane in trim. The springs apply about an 8 pound force to the rudder cables (pre-load if you will), assuming they will want to maintain in equilibrium a 30 degree deflection should be more than enough to trim the airplane. The servo will act as sort of a fine tuning mechanism, the course adjustment will be accomplished by winding more or less tension in one spring or the other during flight testing. I like a few things about this method. 1) It can be installed to any flying airplane with no modifications required other than wiring. 2) There is a chance that this system could be made manual and eliminate the RAC servo if desired. 3) This system provides tension to both rudder cables, no more 'flopping rudder'. 4) Keeps the rudder 'clean'. 5) Doesn't add much extra rudder input force. I sent pictures of this system to Deems, I will 'attempt' to post some pictures to this forum if there is interest. Comments welcome, I apologize for the extremely long post, but I have added Deems questions below, I figured if he asked, many more will have the same questions.... 1. How did you determine which spring type/size/strength to use? OK, you busted me!! I didn't do the math, I feel extremely guilty about this, as an engineer, I should probably go back and figure the forces here. Here is what I did; since I grew up in the business of garage doors (my Dad owned his own company doing this), I went to Fleet Farm (one of our local supply houses, similar to most lumbar yards) and found a garage door spring that had an ID that would slide over the rudder bar with room to spare, and would fit between the two rudder bars (I will measure this for you). I then cut lengths of the spring until I got what I 'thought' was a reasonable amount of force with two turns of pre-load, and bent some custom ends on them. With torsion springs you have two options to increase the reaction force. You can add turns of pre-load, or you can shorten the spring with the same number of turns. I just went until I reached what I 'felt' was a happy medium. Remember that as you wind a torsion spring more and more the inside diameter decreases, until it eventually binds on the shaft (rudder bar). What mostly drove me not to do the math, was I had absolutely no idea what sort of corrective rudder pressure was required to put the ball in the middle. My plan all along has been to get it in the air and do some experimenting, I installed the system so that modification of the spring force should be simple. I just need to start dating a contortionist :) 2. I assume that you can 'adjust the torsional load somewhat by moving the collar/s, Is that true? Correct, I started out with each spring wound an equal amount. If I find that I need additional trim to one side or the other I will wind one of the springs to compensate. The servo will just provide the 'fine tuning'. 3. One of the pictures shows the center support brace minus the delrin bushings, I'm assuming that leaving those out is not a requirement of your approach and was just the result of taking the picture before they were installed? Correct, in fact there isn't a single modification to the airframe, if I remove the system no one could ever tell it was installed. I built the mount so that it could be used in either the forward or aft rudder mounting positions, my pedals are mounted in the aft position. But I drilled and prepped the airframe to mount the rudder pedals in either position. 4. What about the mount for the RAC servo, do you have a picture of it before the servo is mounted. See attached.... The angle was determined by something, I just don't recall what anymore. I know it has to be at an angle to work though. I can measure if you decide to attempt this. 5. Also it' looks like you used a small section of SS cable to connect the servo arm to the spring coil, correct? Picture? Correct, see attached. One end is run through the servo arm, the other gets hooked by the spring. The spring on the pilot side is hooked over the opposite rudder bar. I gave some thought to your desire to have a manually operated system, I think this system could be done manually with very little pain. You may be able to add a knob that would come out of the sub panel, really anywhere along its length. What would have to happen is a bracket would need to be made that slid over the rudder bar with a nut in it. Then a threaded shaft running from the rudder bar to the sub panel would be used to adjust the free arm of the spring. It may be best if the spring were pushed by the shaft instead of pulled, as this would make the mechanism a bit simpler. I could do a drawing of what I am thinking if you are not following. While it was not my intention to begin producing kits, if there is enough interest, I could be persuaded to fabricate a few. Thanks, Jason Jason Kreidler - 40617 Finishing (4 Partner Build) ________________________________________________________________________________
Date: Feb 22, 2008
Very Cool!!! Like the torsion springs in a garage door....good thinking. Bu t alas...I ain't crawling under that panel one more time. Rick S. 40185 ----- Original Message ----- From: "jason kreidler" <jason.kreidler(at)regalbeloit.com> Sent: Friday, February 22, 2008 9:55:17 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Rudder Trim - Spring Bias I have 'developed' a spring bias rudder trim system for the RV-10. =C2-Af ter sharing this idea with Deems he encouraged me to do the same with the r est of the group. =C2-So here goes, but before I get into any details let me preface this whole conversation with a few thoughts. =C2-This is all in theory, I have absolutely no actual flight testing to back up any of the 'claims', or assumptions. =C2-Just good old common sense and a tiny bit of engineering. =C2-Our airplane is not in the air yet, I had hoped to ge t in the air, prove out the system, then share with the world. =C2-To pre vent anyone else for possibly needlessly cutting into their rudder to add a trim tab, I have decided to bear the scrutiny of an unproven, theoretical system. =C2-Please be gentle... I will attempt to verbalize the system. =C2-I used two torsion springs, o ne mounted / wrapped around, each rudder bar (the bar that connects the rud der pedals). =C2-One of the springs is fixed on both ends providing a tor sional force on the rudder bar. =C2-The other springs free end is hooked to a servo motor that allows approximately 30 degrees deflection. =C2-The theory is that the two springs will seek equilibrium (OK, that's not much theory, that's more fact), here is where the testing needs to happen. =C2 -If I deflect the one springs free arm 30 degrees, will it create enough force to put the airplane in trim. =C2-The springs apply about an 8 pound force to the rudder cables (pre-load if you will), assuming they will want to maintain in equilibrium a 30 degree deflection should be more than enou gh to trim the airplane. =C2-The servo will act as sort of a fine tuning mechanism, the course adjustment will be accomplished by winding more or le ss tension in one spring or the other during flight testing. I like a few things about this method. 1) It can be installed to any flying airplane with no modifications require d other than wiring. 2) There is a chance that this system could be made manual and eliminate th e RAC servo if desired. 3) This system provides tension to both rudder cables, no more 'flopping ru dder'. 4) Keeps the rudder 'clean'. 5) Doesn't add much extra rudder input force. I sent pictures of this system to Deems, I will 'attempt' to post some pict ures to this forum if there is interest. =C2-Comments welcome, I apologiz e for the extremely long post, but I have added Deems questions below, I fi gured if he asked, many more will have the same questions.... 1. How did you determine which spring type/size/strength to use? OK, you busted me!! =C2-I didn't do the math, I feel extremely guilty abo ut this, as an engineer, I should probably go back and figure the forces he re. =C2-Here is what I did; since I grew up in the business of garage doo rs (my Dad owned his own company doing this), I went to Fleet Farm (one of our local supply houses, similar to most lumbar yards) and found a garage d oor spring that had an ID that would slide over the rudder bar with room to spare, and would fit between the two rudder bars (I will measure this for you). =C2-I then cut lengths of the spring until I got what I 'thought' w as a reasonable amount of force with two turns of pre-load, and bent some c ustom ends on them. =C2-With torsion springs you have two options to incr ease the reaction force. =C2-You can add turns of pre-load, or you can sh orten the spring with the same number of turns. =C2-I just went until I r eached what I 'felt' was a happy medium. =C2-Remember that as you wind a torsion spring more and more the inside diameter decreases, until it eventu ally binds on the shaft (rudder bar). =C2-What mostly drove me not to do the math, was I had absolutely no idea what sort of corrective rudder press ure was required to put the ball in the middle. =C2-My plan all along has been to get it in the air and do some experimenting, I installed the syste m so that modification of the spring force should be simple. =C2-I just n eed to start dating a contortionist :) 2. I assume that you can 'adjust the torsional load somewhat by moving the collar/s, Is that true? Correct, I started out with each spring wound an equal amount. =C2-If I f ind that I need additional trim to one side or the other I will wind one of the springs to compensate. =C2-The servo will just provide the 'fine tun ing'. 3. One of the pictures shows the center support brace minus the delrin bushings, I'm assuming that leaving those out is not a requirement of your approach and was just the result of taking the picture before they were installed? Correct, in fact there isn't a single modification to the airframe, if I re move the system no one could ever tell it was installed. =C2-I built the mount so that it could be used in either the forward or aft rudder mounting positions, my pedals are mounted in the aft position. =C2-But I drilled and prepped the airframe to mount the rudder pedals in either position. 4. What about the mount for the RAC servo, do you have a picture of it before the servo is mounted. See attached.... =C2-The angle was determined by something, I just don't recall what anymore. =C2-I know it has to be at an angle to work though. =C2-I can measure if you decide to attempt this. 5. Also it' looks like you used a small section of SS cable to connect the servo arm to the spring coil, correct? Picture? Correct, see attached. =C2-One end is run through the servo arm, the othe r gets hooked by the spring. =C2-The spring on the pilot side is hooked o ver the opposite rudder bar. I gave some thought to your desire to have a manually operated system, I th ink this system could be done manually with very little pain. =C2-You may be able to add a knob that would come out of the sub panel, really anywher e along its length. =C2-What would have to happen is a bracket would need to be made that slid over the rudder bar with a nut in it. =C2-Then a th readed shaft running from the rudder bar to the sub panel would be used to adjust the free arm of the spring. =C2-It may be best if the spring were pushed by the shaft instead of pulled, as this would make the mechanism a b it simpler. =C2-I could do a drawing of what I am thinking if you are not following. While it was not my intention to begin producing kits, if there is enough i nterest, I could be persuaded to fabricate a few. Thanks, Jason Jason Kreidler - 40617 Finishing (4 Partner Build) ==== ======================= === ________________________________________________________________________________
the Leadership?
Date: Feb 22, 2008
Deems, The ARC did agree on a few things. We agreed that flagrant pro building exists and that it should not, and we agreed on several fixes to the current system. Where we disagreed most significantly was in how to define the major portion. No one thought we should count hours or dollars. No one wanted a rivet (epoxy/thread/grain) count. I believe the rule was poorly written and has somehow managed to serve us anyway. A lot of credit for the success of the current situation is, I believe, that initially there was not any real financial incentive to pro building. Back in the day you could buy a nice plane for less effort than you or a pro could build one. When that equation started to change, pro building became worthwhile and there wasn't anyone enforcing the fact that it was not within the rules. It was a cottage industry. Now that there is real money involved (several hundred million dollars by my accounting--very little mine >:-(), you are correct in that the parties at the table mainly had their interests in mind. Everyone wants it to work for himself after it all shakes out. You are also correct in that the committee was pretty well balanced in terms of personalities so that no one party emerged as the leader for the rest of us to rally around. I don't think that was intentional when the committee members were selected. I think the FAA wanted a broad and representative sample of the industry and that's what they got. Earl Lawrence from EAA was helpful and did stand up for its membership and the industry as well as he could, especially considering that a workable definition of "major portion" is such a slippery critter. I think there is an elegant solution that has not yet surfaced. I hope that with more input from more people it will show itself. I don't really think that amateur building is in much danger. Violaters will probaly not be tolerated much longer, but those who've gotten away with it so far, I think, are pretty safe. FAA lawyers made it pretty clear that pursuing what's already happened under current conditions would be difficult to impossible. Write those letters! Thanks for listening, Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, February 22, 2008 7:22 AM Subject: Re: RV10-List: Amendment and Revision to Kit Building Rules - Where's the Leadership? It's too bad the ARC couldn't agree on proposed rule changes, (for 'economic' reasons) so now we're left with the FAA drafting the changes. Its fairly obvious that based on the varied interests of the representative parties, that ANY changes that were considered were going to result in a financial hit to at least one of the represented segments. In this business world this is what happens when there is a Leadership void. Which is what I see happening here. What I find personally extremely disappointing is that the EAA, who at one time was the best representative for 'us' (homebuilders) seems to have become a victim of the 'special interests' and has followed vs. lead on this one. My letter is on it's way. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ > * > * ________________________________________________________________________________
Subject: OSH RV-10 Operatonr seminar was: Establishing gross weight
Date: Feb 22, 2008
Purging important old posts and converting some to PDFs for research. We should contact AirVenture about a meeting tent to discuss RV-10 Operating Issues like the Lancair boys. We have plenty flying now and could pack a tent. What say you? We could segway right into Pilot Proficiency. EAA asked if I wanted to be a Featured Speaker. I can at least find out how to reserve a tent. JC -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, May 18, 2007 5:42 AM Subject: RV10-List: OSH RV-10 Operatonr seminar was: Establishing gross weight Let's do it! How can we make this happen? I'm willing to assist, with the caveat, that I am NOT qualified to provide the content but willing to help assist in the organization, administration and delivery. Perhaps this could be a step towards a Pilot Proficiency program? Deems Davis # 406 Finishing - ( A Misnomer ! ) http://deemsrv10.com/ John W. Cox wrote: > OSH > > Anybody want to talk about an RV-10 Operator's Seminar at OSH like > Lancair does? So we can hammer out these issues. > > John Cox > > * > * ________________________________________________________________________________
Date: Feb 23, 2008
Jason, I love it! Simple, clean, and easy to install or remove. You've sold me on it. If you decide to make a few, sign me up. John jkreidler wrote: > Enclosed are a few photographs.... > > Thanks, Jason > > Jason Kreidler - 40617 Finishing > (4 Partner Build) -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165729#165729 ________________________________________________________________________________
Subject: Re: OSH RV-10 Operatonr seminar was: Establishing gross weight
Date: Feb 23, 2008
Excellent idea. Go for it. By the way, anybody going to Sun 'n fun? I plan on arriving day one and staying until I'm bored. I'm driving down so there will be at least one RV-10 builder there with a car (actually a six seat Chevy 4wd pickup). John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165734#165734 ________________________________________________________________________________
Date: Feb 23, 2008
Subject: Re: OSH RV-10 Operatons seminar
I think this is a great idea, and the time should be right, there are enough flying RV-10's to where there's some really valuable information/data that could be assembled and disseminated at such an event. In fact I could see the possibility for several sessions, each with a different focus. I don't know what the availability of the tents might be, but there' always the possibility of 'carry-over' sessions occurring @ RV-10 HQ in the evening. Some thoughts about possible topics: 1st flight: Preparation for Sharing of Stage ! test plans/scripts Here's what I learned during Stage 1 Maintenance issues - What to look for and to keep your eyes open to. Performance data - Let's publish a standard/simple performance recording procedure and ask as many -10's as possible to fly it and report. Insuring your RV-10 How do you fly your -10? ROP/LOP TO/Landing CG issues (nose heavy?) Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ John W. Cox wrote: > > Purging important old posts and converting some to PDFs for research. > > We should contact AirVenture about a meeting tent to discuss RV-10 > Operating Issues like the Lancair boys. We have plenty flying now and > could pack a tent. > > What say you? We could segway right into Pilot Proficiency. > > EAA asked if I wanted to be a Featured Speaker. I can at least find out > how to reserve a tent. > > JC > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Friday, May 18, 2007 5:42 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: OSH RV-10 Operatonr seminar was: Establishing gross > weight > > > Let's do it! > > How can we make this happen? > > I'm willing to assist, with the caveat, that I am NOT qualified to > provide the content but willing to help assist in the organization, > administration and delivery. > > Perhaps this could be a step towards a Pilot Proficiency program? > > Deems Davis # 406 > Finishing - ( A Misnomer ! ) > http://deemsrv10.com/ > > John W. Cox wrote: > >> OSH >> >> Anybody want to talk about an RV-10 Operator's Seminar at OSH like >> Lancair does? So we can hammer out these issues. >> >> John Cox >> >> * >> * >> > > > ________________________________________________________________________________
Date: Feb 23, 2008
Somehow I seem to not have the pictures, where can I see them. Bob K -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, February 23, 2008 7:36 AM Subject: RV10-List: Re: Rudder Trim - Spring Bias Jason, I love it! Simple, clean, and easy to install or remove. You've sold me on it. If you decide to make a few, sign me up. John jkreidler wrote: > Enclosed are a few photographs.... > > Thanks, Jason > > Jason Kreidler - 40617 Finishing > (4 Partner Build) -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165729#165729 ________________________________________________________________________________
Date: Feb 23, 2008
Subject: Re: Amendment and Revision to Kit Building Rules - Where's
the Leadership? Thanks for the insight Dave, and Thanks also for volunteering to spend your time on this issue. I'm just another 'special interest' that doesn't' want the abuses of a few to end up limiting or restricting the abilities of the critical amateur mass. Having already written and sent my letter, I'll calm back down and now wait for the NPRM and hope that the right things happen. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Dave Saylor wrote: > > Deems, > > The ARC did agree on a few things. We agreed that flagrant pro building > exists and that it should not, and we agreed on several fixes to the current > system. > > Where we disagreed most significantly was in how to define the major > portion. No one thought we should count hours or dollars. No one wanted a > rivet (epoxy/thread/grain) count. I believe the rule was poorly written and > has somehow managed to serve us anyway. A lot of credit for the success of > the current situation is, I believe, that initially there was not any real > financial incentive to pro building. Back in the day you could buy a nice > plane for less effort than you or a pro could build one. When that equation > started to change, pro building became worthwhile and there wasn't anyone > enforcing the fact that it was not within the rules. It was a cottage > industry. > > Now that there is real money involved (several hundred million dollars by my > accounting--very little mine >:-(), you are correct in that the parties at > the table mainly had their interests in mind. Everyone wants it to work for > himself after it all shakes out. You are also correct in that the committee > was pretty well balanced in terms of personalities so that no one party > emerged as the leader for the rest of us to rally around. I don't think > that was intentional when the committee members were selected. I think the > FAA wanted a broad and representative sample of the industry and that's what > they got. Earl Lawrence from EAA was helpful and did stand up for its > membership and the industry as well as he could, especially considering that > a workable definition of "major portion" is such a slippery critter. > > I think there is an elegant solution that has not yet surfaced. I hope that > with more input from more people it will show itself. I don't really think > that amateur building is in much danger. Violaters will probaly not be > tolerated much longer, but those who've gotten away with it so far, I think, > are pretty safe. FAA lawyers made it pretty clear that pursuing what's > already happened under current conditions would be difficult to impossible. > > Write those letters! > > Thanks for listening, > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA > 831-722-9141 > 831-750-0284 CL > www.AirCraftersLLC.com > > > > ________________________________________________________________________________
Subject: OSH RV-10 Operatons seminar
Date: Feb 23, 2008
When I inquired last year the forum pavilions were available in the evening, but that was about 6 weeks before Airventure. We may be early enough to find a location during the day. While clearly not an expert yet on most RV-10 topics, I would be willing to assist with organizing or with any other tasks that need to be done. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Saturday, February 23, 2008 10:50 AM Subject: Re: RV10-List: OSH RV-10 Operatons seminar I think this is a great idea, and the time should be right, there are enough flying RV-10's to where there's some really valuable information/data that could be assembled and disseminated at such an event. In fact I could see the possibility for several sessions, each with a different focus. I don't know what the availability of the tents might be, but there' always the possibility of 'carry-over' sessions occurring @ RV-10 HQ in the evening. Some thoughts about possible topics: 1st flight: Preparation for Sharing of Stage ! test plans/scripts Here's what I learned during Stage 1 Maintenance issues - What to look for and to keep your eyes open to. Performance data - Let's publish a standard/simple performance recording procedure and ask as many -10's as possible to fly it and report. Insuring your RV-10 How do you fly your -10? ROP/LOP TO/Landing CG issues (nose heavy?) Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ John W. Cox wrote: > > Purging important old posts and converting some to PDFs for research. > > We should contact AirVenture about a meeting tent to discuss RV-10 > Operating Issues like the Lancair boys. We have plenty flying now and > could pack a tent. > > What say you? We could segway right into Pilot Proficiency. > > EAA asked if I wanted to be a Featured Speaker. I can at least find out > how to reserve a tent. > > JC > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Friday, May 18, 2007 5:42 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: OSH RV-10 Operatonr seminar was: Establishing gross > weight > > > Let's do it! > > How can we make this happen? > > I'm willing to assist, with the caveat, that I am NOT qualified to > provide the content but willing to help assist in the organization, > administration and delivery. > > Perhaps this could be a step towards a Pilot Proficiency program? > > Deems Davis # 406 > Finishing - ( A Misnomer ! ) > http://deemsrv10.com/ > > John W. Cox wrote: > >> OSH >> >> Anybody want to talk about an RV-10 Operator's Seminar at OSH like >> Lancair does? So we can hammer out these issues. >> >> John Cox >> >> * >> * >> > > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 2897 (20080222) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 2897 (20080222) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Feb 23, 2008
The worst time for a reserved discussion area was after 3:00PM and when the late Jimmy Franklin would fly his Jet Assisted WACO or a Harrier Demo performed during the airshow. Seems like a successful time slot just before the Airshow and later in the week (WED/THU/FRI) might hold the greatest potential for attendance. When the airshow ends, the whole culture and traffic considerations at Air Venture Change abruptly. In the evening we might need to add other considerations like hunger or Thunderstorm avoidance on the airport grounds. Construction Mods, Calculations of amended GW, Phase One Compliance, Transition Training, EFIS setup and testing, flight performance numbers and first person stories might hold a crowd even during the noise. It is best to request an area even before Sun N Fun kick into gear. I say we forward our ideas to Deems for validation and screening. Then we can outreach for the best panel speakers from the RV-10 family. Tim can you contact OSH or Mike are you listening? John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Saturday, February 23, 2008 9:40 AM Subject: RE: RV10-List: OSH RV-10 Operatons seminar When I inquired last year the forum pavilions were available in the evening, but that was about 6 weeks before Airventure. We may be early enough to find a location during the day. While clearly not an expert yet on most RV-10 topics, I would be willing to assist with organizing or with any other tasks that need to be done. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Saturday, February 23, 2008 10:50 AM Subject: Re: RV10-List: OSH RV-10 Operatons seminar I think this is a great idea, and the time should be right, there are enough flying RV-10's to where there's some really valuable information/data that could be assembled and disseminated at such an event. In fact I could see the possibility for several sessions, each with a different focus. I don't know what the availability of the tents might be, but there' always the possibility of 'carry-over' sessions occurring @ RV-10 HQ in the evening. Some thoughts about possible topics: 1st flight: Preparation for Sharing of Stage ! test plans/scripts Here's what I learned during Stage 1 Maintenance issues - What to look for and to keep your eyes open to. Performance data - Let's publish a standard/simple performance recording procedure and ask as many -10's as possible to fly it and report. Insuring your RV-10 How do you fly your -10? ROP/LOP TO/Landing CG issues (nose heavy?) Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ ________________________________________________________________________________
Date: Feb 23, 2008
I have not talked with Bob Condry yet, but I will be at OSH early again this year and will help stake out a HQ up close. Bob, do we want to do the reservations like we did last year or modify? Gary 40274 -------------- Original message -------------- From: Deems Davis <deemsdavis(at)cox.net> > > I think this is a great idea, and the time should be right, there are > enough flying RV-10's to where there's some really valuable > information/data that could be assembled and disseminated at such an > event. In fact I could see the possibility for several sessions, each > with a different focus. I don't know what the availability of the tents > might be, but there' always the possibility of 'carry-over' sessions > occurring @ RV-10 HQ in the evening. Some thoughts about possible topics: > > 1st flight: > Preparation for > Sharing of Stage ! test plans/scripts > Here's what I learned during Stage 1 > Maintenance issues - What to look for and to keep your eyes open to. > Performance data - Let's publish a standard/simple performance recording > procedure and ask as many -10's as possible to fly it and report. > Insuring your RV-10 > How do you fly your -10? > ROP/LOP > TO/Landing > CG issues (nose heavy?) > > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > > John W. Cox wrote: > > > > Purging important old posts and converting some to PDFs for research. > > > > We should contact AirVenture about a meeting tent to discuss RV-10 > > Operating Issues like the Lancair boys. We have plenty flying now and > > could pack a tent. > > > > What say you? We could segway right into Pilot Proficiency. > > > > EAA asked if I wanted to be a Featured Speaker. I can at least find out > > how to reserve a tent. > > > > JC > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > > Sent: Friday, May 18, 2007 5:42 AM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: OSH RV-10 Operatonr seminar was: Establishing gross > > weight > > > > > > Let's do it! > > > > How can we make this happen? > > > > I'm willing to assist, with the caveat, that I am NOT qualified to > > provide the content but willing to help assist in the organization, > > administration and delivery. > > > > Perhaps this could be a step towards a Pilot Proficiency program? > > > > Deems Davis # 406 > > Finishing - ( A Misnomer ! ) > > http://deemsrv10.com/ > > > > John W. Cox wrote: > > > >> OSH > >> > >> Anybody want to talk about an RV-10 Operator's Seminar at OSH like > >> Lancair does? So we can hammer out these issues. > >> > >> John Cox > >> > >> * > >> * > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Gary
40274
> --> RV10-List message posted by: Deems Davis
> 1st flight:
> Preparation for
> Insuring your RV-10
> ROP/LOP
> TO/Landing
> Deems Davis # 406
> John W. Cox wrote:
> > --> RV10-List message posted by: "John W. Cox"
> > could pack a tent.
> > What say you? We could segway right into Pilot P rofici ency. <BR>> > <BR>> > EAA asked if I wanted to be a Featured Speaker. I can at least find out <BR>> > how to reserve a tent. <BR>> > <BR>> > JC <BR>> > <BR>> > -----Original Message----- <BR>> > From: owner-rv10-list-server(at)matronics.com <BR>> > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis <BR>> > Sent: Friday, May 18, 2007 5:42 AM <BR>> > To: rv10-list(at)matronics.com <BR>> > Subject: RV10-List: OSH RV-10 Operatonr seminar was: Establishing gross <BR>> > weight <BR>> > <BR>> > --> RV10-List message posted by: Deems Davis <DEEMSDAVIS(at)COX.NET><BR>> > <BR>> > Let's do it! <BR>> > <BR>> > How can we make this happen? <BR>> > <BR>> > I'm willing to assist, with the caveat, that I am NOT qualified to <BR>> > provide the content but willing to help assist in the organization, <BR>> > administration and delivery. <BR>> ; > lities
Date: Feb 23, 2008
Gary, I will also be there again early but haven't really done any planning yet. I thought last year worked OK, but if somebody had ideas for improvements I'm all ears. BTW, last year folks were very generous with their contributions during our various "food nights" and we overachieved a bit... I plan to use the excess collected to partially offset cost for an extra site to give us more room for gathering and socializing for the group. We can plan more when it gets a little closer. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165837#165837 ________________________________________________________________________________
Date: Feb 23, 2008
All, thanks for the encouraging comments both on-line and off. I really didn't expect this sort of interest. With that being said, I would really like to find a willing participant to test this on a flying RV-10. We are several months away from our fist flight, I don't think everyone has that sort of time available. If anyone would be interested in helping out with this sort of testing please let me know. I am really surprised at the number of people who expressed interest in installing a kit (once the system is working). I have decided to create a kit of parts once the concept is reality. As far as using this kit on an RV-7, I have a friend building a 7 not far from where I live, I will stop by his house and measure it all up and see if it will work. If you are still unable to view the pictures please send me an e-mail, I would be happy to e-mail copies. Thanks again everyone!! Jason - 40617 Finishing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165844#165844 ________________________________________________________________________________
Subject: Re: Request of those flying (was Rudder Trim - Spring Bias)
Date: Feb 23, 2008
"Also, if you need 30 degrees of pedal movement to hold the airplane in trim, I suspect you have something else very wrong going on so that should be plenty." Just to clarify, I am not suggesting that a thirty degree deflection of the free leg of the spring will produce thirty degrees of pedal movement. The thirty degree deflection is the amount of bias available to produce a much smaller movement of the actual rudder. Because the first spring is counteracting the second spring, the difference in the induced tension between the two is your ability to trim. Thanks, Jason Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165847#165847 ________________________________________________________________________________
Subject: N410BL Flies!
Date: Feb 23, 2008
Well, at least the empennage... :^) With the assistance of the family, we hoisted the empennage using a couple bicycle hoists. Now my wife can get her car back into the garage. Unfortunately, it's a couple days too late. We've had freezing rain here the last couple of days. Bob #40684 mykitlog.com/rleffler ________________________________________________________________________________
Date: Feb 24, 2008
I looked at the calendar and we will probably arrive at OSH on the 21 on Monday again and we can stake out the sites on Tues the 22. If you want to be the treasurer again, I would be greatful. Gary -------------- Original message -------------- From: "bcondrey" <bob.condrey(at)baesystems.com> > > Gary, > > I will also be there again early but haven't really done any planning yet. I > thought last year worked OK, but if somebody had ideas for improvements I'm all > ears. > > BTW, last year folks were very generous with their contributions during our > various "food nights" and we overachieved a bit... I plan to use the excess > collected to partially offset cost for an extra site to give us more room for > gathering and socializing for the group. > > We can plan more when it gets a little closer. > > Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=165837#165837 > > > > > > > > > >
Gary
> --> RV10-List message posted by: "bcondrey"
> Gary,
> ears.
> Bob
Subject: Rudder Peddle Position
Date: Feb 23, 2008
Ok all you flyers and near flyers, did you position your rudder peddles in the forward or aft set of bolt holes? Thanks to the excellent plans, it you blink you miss completely the fact that there are 2 sets of bolt holes that can be used to set the for and aft positioning of the rudder peddles. Section 38 page 4 shows the 6 holes in the F-1013 longeron and shows the F-1039B bracket being installed into the forward set of holes but doesnt mention the aft set of holes and why you may or may not want to use either. You then blindly proceed on and drill the F-1039D bracket for the center support blocks based on the set of holes you used for the side blocks. It is not until 38-10 where the secret is revealed when in step one you make the Rudder Cable Links, either the Aft or Fwd based on the holes used previously. Well I drilled the F-1039D bracket for both settings so I can go either way at any time with out having to do any drilling in the future. Here is my question, which location did you install your peddles, how tall are you and do you feel that you were correct in the location you used? I know that we have a fair amount of latitude due to the ability of move our seats forward and aft. I can see tall pilots wanting the forward position, but at some point smaller pilots would prefer the aft settings. The seat can only be moved forward just so far before the stick starts getting in the way. It would be nice if we could come up with some type of rule of thumb that would say any one shorter then 5'8", then install in the Aft set. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165870#165870 ________________________________________________________________________________
Subject: Static ports
Date: Feb 23, 2008
Has anyone purchased the static ports offered by Vans? Are they aluminum? Flush mount? Quality? And by the way, my wife and I will be at SnF Wed. through Sun. and would love to get together with other builders. -------- Tom Ganster 40778 Tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165871#165871 ________________________________________________________________________________
Subject: RVator
Date: Feb 23, 2008
I have not seen the first installment of the electronic form of rvator yet. Does anyone know when the first issue of the year usually comes out and how to access it? -------- Tom Ganster 40778 Tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165873#165873 ________________________________________________________________________________
Date: Feb 23, 2008
Subject: Re: RVator
Late Feb 08,,, last Van's said..Yeah I know it's already the 23rd...gives thme a few more days... I still like opening the mailbox and finding the RVator...makes a long day seem better.. ----- Original Message ----- From: "tganster" <tganster(at)mwwb.net> Sent: Saturday, February 23, 2008 6:42:35 PM (GMT-0800) America/Los_Angeles Subject: RV10-List: RVator I have not seen the first installment of the electronic form of rvator yet. Does anyone know when the first issue of the year usually comes out and how to access it? -------- Tom Ganster 40778 Tailcone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165873#165873 ________________________________________________________________________________
Date: Feb 23, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Sounds like a plan! Bob _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of speckter(at)comcast.net Sent: Saturday, February 23, 2008 7:01 PM Subject: Re: RV10-List: Re: OSH RV-10 Operatons seminar I looked at the calendar and we will probably arrive at OSH on the 21 on Monday again and we can stake out the sites on Tues the 22. If you want to be the treasurer again, I would be greatful. Gary -------------- Original message -------------- From: "bcondrey" <bob.condrey(at)baesystems.com> > > Gary, > > I will also be there again early but haven't really done any planning yet. I > thought last year worked OK, but if somebody had ideas for improvements I'm all > ears. > > BTW, last year folks were very generous with their contributions during our > various "food nights" and we overachieved a bit... I plan to use the excess > collected to partially offset cost for an extra site to give us more room for > gathering and socializing for the group. > > We can plan more when it gets a little closer. > > Bob > > > > > Read this topic online here: > > --> ________________________________________________________________________________
Subject: Re: Rudder Peddle Position
Date: Feb 24, 2008
Always and I don't care how tall you are, mount your rudder pedals as close to the seats as possible for the following reasons: 1. It will allow you to sit further back, helping CG a little. 2. Gives you more stick to belly clearance at full up elevator. 3. Allows you to skip the extensions you have to make between the peddles and cables, which makes the bottom of the peddle a few degrees closer to you helping in not applying the brake until you want to. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165921#165921 ________________________________________________________________________________
Date: Feb 24, 2008
I coordinated a forum on alternative fuels last year and just received forms to propose a seminar this year. They are roughly 90 minutes long and I was able to get the day I wanted last time. That time length is ideal for 3 speakers and discussion -- so in addition to 'tentside chats' in the campground -- are there three of you who'd like to put together materials/powerpoints for relevant topics discussed earlier on the thread? If so I can get the slot in-process. I'd need your names and topics and could proceed. -------- RV-10 Builder #40546 Tail mostly done, wings complete, starting SB fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165937#165937 ________________________________________________________________________________
Subject: Lack of Install Instructions TruTrak
Date: Feb 25, 2008
Here is a supplement to AirMike's invaluable post below. "The brass screw is a shear pin - do not try and remove it!" It shears easily - don't ask how I know ;-(. According to SteinAir, I am not the first person to have done this! Tim O, maybe a useful inclusion in the RV University? The drive wheel should be carefully levered off with the brass screw in position. Trutrak makes a great product, but their documentation is disgraceful. Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Monday, 26 November 2007 12:28 PM Subject: RV10-List: Re: Lack of Install Instructions TruTrak Pitch Servo Installation RV10 As supplied with torque enhancement rail 1. Confirm that a .20 hole has been drilled in the proper position on the bellcrank per the plans for the RV10. Placement and sizing of this hole is of the utmost importance. 2. If it came with your kit, remove (discard or use for another function) the pitch servo bracket supplied by Vans Aircraft. Use only the pitch servo bracket supplied with the autopilot servo by TruTrak. 3. Place the servo unit on a stable surface and remove the stainless steel screw and nylon washer holding the drive wheel and torque rail to the drive shaft. Carefully set the screw and nylon washer aside. Note the small brass screw on the drive wheel so that you can reposition it in the same position as it is when removed. Carefully pry or lift the drive wheel and torque rail off of the drive shaft. 4. Take the drive wheel rail and torque rail. On the forward edge take the eyebolt and screw the Rod end bearing #MM-3-300 into the torque rail approximately half way, using the supplied standard nut as a locking device. Tighten the nut against the aluminum torque rail. 5. Attach the servo bracket to the airframe per the photo supplied by TruTrak. Please note that bracket is attached to the inside right line of bolts adjacent to the bellcrank. Secure the (3) AN3 bolts and the (1) single AN515-8R8 screw and torque to the proper value. Mark the torqued bolts with security paint or colored nail polish. 6. Position the servo motor on the outside of the bracket in such a way as the drive wheel protrudes thru the bracket and the four bolt holes on the bracket line up with the four bolt holes on the servo motor. When you look at the servo unit, the electric motor will be aft and the Connector plug part of the servo will be forward with the connector plug facing outward (away from the bellcrank) 7. Attach the servo motor to the bracket using the four supplied AN3 bolts and the rough washers. Secure the AN3 bolts and torque to the proper value. Mark the torqued bolts with security paint or colored nail polish. Safety wire the four bolts at your option. 8. Reposition the drive wheel in the same position as it is when removed. Reattach the stainless steel screw and nylon washer to the drive shaft (now with the attached eyebolt). 9. Secure the rod end to the bellcrank as follows: Insert supplied AN3 bolt through the bellcrank from the pilot side insert aluminum spacer insert rod end bearing insert large cadmium plated washer and secure these pieces with 10-32 lock nut. Torque to the proper value and mark the torqued bolts as before. 10. Check that , when moved, the toque rail clears the two retaining bolts on the upper side of the servo motor. 11. This is a good time to be sure that you have made provision to install/secure the static lines and install any needed security fittings for the wire/s that operate the pitch servo unit. -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=148485#148485 "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Feb 25, 2008
Just checked Tim's site http://www.myrv10.com/N104CD/upgrades/20060816/index.html - there is a clear warning not to try and remove the screw - doh!!! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron Sent: Monday, 25 February 2008 8:44 AM Subject: RV10-List: Lack of Install Instructions TruTrak --> Here is a supplement to AirMike's invaluable post below. "The brass screw is a shear pin - do not try and remove it!" It shears easily - don't ask how I know ;-(. According to SteinAir, I am not the first person to have done this! Tim O, maybe a useful inclusion in the RV University? The drive wheel should be carefully levered off with the brass screw in position. Trutrak makes a great product, but their documentation is disgraceful. Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Monday, 26 November 2007 12:28 PM Subject: RV10-List: Re: Lack of Install Instructions TruTrak Pitch Servo Installation RV10 As supplied with torque enhancement rail 1. Confirm that a .20 hole has been drilled in the proper position on the bellcrank per the plans for the RV10. Placement and sizing of this hole is of the utmost importance. 2. If it came with your kit, remove (discard or use for another function) the pitch servo bracket supplied by Vans Aircraft. Use only the pitch servo bracket supplied with the autopilot servo by TruTrak. 3. Place the servo unit on a stable surface and remove the stainless steel screw and nylon washer holding the drive wheel and torque rail to the drive shaft. Carefully set the screw and nylon washer aside. Note the small brass screw on the drive wheel so that you can reposition it in the same position as it is when removed. Carefully pry or lift the drive wheel and torque rail off of the drive shaft. 4. Take the drive wheel rail and torque rail. On the forward edge take the eyebolt and screw the Rod end bearing #MM-3-300 into the torque rail approximately half way, using the supplied standard nut as a locking device. Tighten the nut against the aluminum torque rail. 5. Attach the servo bracket to the airframe per the photo supplied by TruTrak. Please note that bracket is attached to the inside right line of bolts adjacent to the bellcrank. Secure the (3) AN3 bolts and the (1) single AN515-8R8 screw and torque to the proper value. Mark the torqued bolts with security paint or colored nail polish. 6. Position the servo motor on the outside of the bracket in such a way as the drive wheel protrudes thru the bracket and the four bolt holes on the bracket line up with the four bolt holes on the servo motor. When you look at the servo unit, the electric motor will be aft and the Connector plug part of the servo will be forward with the connector plug facing outward (away from the bellcrank) 7. Attach the servo motor to the bracket using the four supplied AN3 bolts and the rough washers. Secure the AN3 bolts and torque to the proper value. Mark the torqued bolts with security paint or colored nail polish. Safety wire the four bolts at your option. 8. Reposition the drive wheel in the same position as it is when removed. Reattach the stainless steel screw and nylon washer to the drive shaft (now with the attached eyebolt). 9. Secure the rod end to the bellcrank as follows: Insert supplied AN3 bolt through the bellcrank from the pilot side insert aluminum spacer insert rod end bearing insert large cadmium plated washer and secure these pieces with 10-32 lock nut. Torque to the proper value and mark the torqued bolts as before. 10. Check that , when moved, the toque rail clears the two retaining bolts on the upper side of the servo motor. 11. This is a good time to be sure that you have made provision to install/secure the static lines and install any needed security fittings for the wire/s that operate the pitch servo unit. -------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=148485#148485 "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Subject: Trimming wing tips
Date: Feb 24, 2008
Looking at the plans, it seems that a lot of material needs to be removed on the wing tips. I think I've got it marked up right but I'd like a quick confidence builder that I'm not overcutting. John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166000#166000 ________________________________________________________________________________
Date: Feb 24, 2008
Subject: Things to order from Vans and others
Hi I have been wandering through the Van's website looking for bits and bobs to order along with a replacement for a piece of aluminium I turned into scrap today. I noticed that there is an aileron trim kit and was wondering how necessary it is on the -10. Any comments? I seem to remember reading that the aileron trim was not as necessary on the -10 as rudder trim. I also saw *somewhere* some barrel connectors used to connect wires between the wings & the fuse. Does anyone have a part number for these connectors? Inquiring minds need to know Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Subject: Re: Trimming the cowling
Date: Feb 24, 2008
Hey Jim, Just a follow up to tell you how much I appreciate your tape method. Today I used it to mark the doors to fit the cabin. I made the first cut a hair outside the line just in case I didn't get it quite right, but after sanding some, I went right to the line and it's about perfect! How easy is that! Thanks again. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166027#166027 ________________________________________________________________________________
Subject: Door pin alignment
Date: Feb 24, 2008
OK, we're about ready to start final fitting the doors and I'm reading ahead about tapping the rod and making a center pin to thread into it ... just to mark the center for where it hits the jamb? Seems like a lot of trouble to go to just to mark a center. Has anybody stuck a sharpie in there or anything? I didn't see anything on Tim's site about it -- just thought I'd ask. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166035#166035 ________________________________________________________________________________
Subject: Re: Things to order from Vans and others
Date: Feb 24, 2008
On the connectors, CPC Series 1 or 2 from www.mouser.com. Stein's molex pin crimp tool is great for the series 1 and the D-sub crimper for series 2 (the Series 2 machined closed barrel pins are the same as the D-sub pins, but are only good up to 20 gauge wire, I think). Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Feb 24, 2008, at 7:40 PM, Les Kearney wrote: > Hi > > I have been wandering through the Van=92s website looking for bits and > bobs to order along with a replacement for a piece of aluminium I > turned into scrap today. > > I noticed that there is an aileron trim kit and was wondering how > necessary it is on the -10. Any comments? I seem to remember reading > that the aileron trim was not as necessary on the -10 as rudder trim. > > I also saw *somewhere* some barrel connectors used to connect wires > between the wings & the fuse. Does anyone have a part number for > these connectors? > > Inquiring minds need to know > > Les Kearney > #40643 > C-GCWZ (reserved) > > ________________________________________________________________________________
Date: Feb 24, 2008
YEPP, ALOT OF TRIMMING IS NEEDED. ALSO, ONCE YOU HAVE THE TIPS IN PLACE WIT H THE NUTPLATES, BUT BEFORE YOU PUT IN THE TE. RIB, MARK THE AILERON TE ONT O THE WING TIP WITH A STRAIGHT EDGE. I THINK IT WAS MY LEFT WINGTIP, IT WAS ABOUT 1.25 INCHES TOO LONG. AMAZING QUALITY!!!> Subject: RV10-List: Trimmi ng wing tips> From: johngoodman(at)earthlink.net> Date: Sun, 24 Feb 2008 14:48 "johngoodman" > > Looking at the plans, it seems that a lot of material needs to be removed on the wing tips. I think I've got it marked up right but I'd like a quick confidence builder that I'm not overcutting.> John> > --------> #40572 QB Fuselage, wings finished> N711JG reserved> > > > > Read this topic online here:> > http://forums.matronics. ========================> _ ===============> > > ________________________________________________________________________________
Date: Feb 24, 2008
Subject: Crimpers
Hi Again I have been looking at electrical tools at the local electronics shop with a view to acquiring the tools required to do my electrical system. Not that I know much about these things, but the Paladin Tools seemed well made. I was thinking of getting their Crimpall handles with dies for insulated terminals, open barrel and D-sub pins. Has anyone had experience with this brand of tools? Advice gratefully appreciated. Inquiring minds need to know Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Subject: Windshield scratches
Date: Feb 24, 2008
Help! Scratches on windshield............. Wanted to clean off the bugs and, using a nylon encased sponge, just about put as many scratches on the windshield that I could do. Any advice appreciated. I've looked up some products on ACS, but wondered if anyone had had such a problem and found a solution that they could recommend....PLEASE! Ugh. John J (on the GlaStar, not the unfinished -10) ________________________________________________________________________________
Subject: Crimpers
Date: Feb 24, 2008
Les - I have a set of Paladin Crimpall handles and dies for PIDG terminals. I'm VERY happy with it. My D-sub crimper is also a Paladin, Model number PA1440. Pretty satisfied with it, too. Shop around. I think I paid about $80 total for both, new, including shipping. neal RV-7 N8ZG Baffled by Baffles _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Sunday, February 24, 2008 9:30 PM Subject: RV10-List: Crimpers Hi Again I have been looking at electrical tools at the local electronics shop with a view to acquiring the tools required to do my electrical system. Not that I know much about these things, but the Paladin Tools seemed well made. I was thinking of getting their Crimpall handles with dies for insulated terminals, open barrel and D-sub pins. Has anyone had experience with this brand of tools? Advice gratefully appreciated. Inquiring minds need to know Les Kearney #40643 C-GCWZ (reserved) href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Feb 24, 2008
I am not happy with the stock door/locking pin setup. They have several problems that the aftermarket guys have solved. One of them is lack of a door key lock. If I were doing it again I would spring for one of the better door handles or at least the machined latching pins with the magnet built in the pins. Check some the web sites of RV-10 builder and/or the list archives for post concerning door handles. I wish I had spent some money and did mine differently. Also, although my door had a really nice fit, after I put the 'P' seal on the door edge I had to do a lot of sanding to make my door close and the fit isn't quite as nice. The location of the mechanism inside the door is very far forward but it makes it a stretch to stand in back of the wing and lean forward to unlatch and open the door. In spite of this I love this plane. Albert Gardner N991RV Yuma, AZ -----Original Message----- OK, we're about ready to start final fitting the doors and I'm reading ahead about tapping the rod and making a center pin to thread into it ... just to mark the center for where it hits the jamb? Seems like a lot of trouble to go to just to mark a center. Has anybody stuck a sharpie in there or anything? I didn't see anything on Tim's site about it -- just thought I'd ask. Later, - Lew ________________________________________________________________________________
Date: Feb 24, 2008
Subject: Re: Windshield scratches
Get a Micro Mesh kit. Follow the instructions and use copious amounts of water .... adding a little dish soap won't hurt either. Take your time. You'll get some sore arm muscles in trade for a clear view. Linn John Jessen wrote: > Help! Scratches on windshield............. > > Wanted to clean off the bugs and, using a nylon encased sponge, just > about put as many scratches on the windshield that I could do. Any > advice appreciated. I've looked up some products on ACS, but wondered > if anyone had had such a problem and found a solution that they could > recommend....PLEASE! Ugh. > > John J > (on the GlaStar, not the unfinished -10) > > ________________________________________________________________________________
Date: Feb 24, 2008
Rudder trim is far more of a "nice but not really necessary" option than aileron trim. The trim kit is very easy to install at any point or even after the plane is finished. Put the 5 wire cable in place during construction and plan ahead for space of the IP for a switch and indicator and you would be ready to add trim later. The kit is about $350 ordered as an option. Rudder trim at cruise can be a simple tab or wedge on the rudder as required but many of us would like to have adjustable rudder trim. Albert Gardner N991RV Yuma, AZ -----Original Message----- Hi I have been wandering through the Van's website looking for bits and bobs to order along with a replacement for a piece of aluminium I turned into scrap today. I noticed that there is an aileron trim kit and was wondering how necessary it is on the -10. Any comments? I seem to remember reading that the aileron trim was not as necessary on the -10 as rudder trim. I also saw *somewhere* some barrel connectors used to connect wires between the wings & the fuse. Does anyone have a part number for these connectors? Inquiring minds need to know Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Date: Feb 24, 2008
John Every year there is a chap at KOSH who flogs a 3M scratch repair kit similar to: http://www.skygeek.com/window-tools.html I have watched while a window is scratch and the all the scratches are polished out. I tried this on my PA218 a few years back and ended up just replacing the window. If you try one of these products, get someone who knows what they are doing to do it for you. My impression is that these products can be very effective in the right hands. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: February-24-08 8:47 PM Subject: RV10-List: Windshield scratches Help! Scratches on windshield............. Wanted to clean off the bugs and, using a nylon encased sponge, just about put as many scratches on the windshield that I could do. Any advice appreciated. I've looked up some products on ACS, but wondered if anyone had had such a problem and found a solution that they could recommend....PLEASE! Ugh. John J (on the GlaStar, not the unfinished -10) ________________________________________________________________________________
Date: Feb 24, 2008
I believe you have two choices. The first one is messy - ruins the paint job: replace the windscreen. The second one isn't as bad but probably takes just as much time: buff out the scratches with progressively finer abrasive material. The stuff you need comes in a kit with instructions. You start out coarse(400 grit?) and graduate up to 1800 or 2000 (crocus cloth?) with water. I've never done it but I hear it works. Mask off anything you don't want to scratch while you are removing scratches. Paul Hahn #40203 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166062#166062 ________________________________________________________________________________
Date: Feb 24, 2008
I've used this kit before, on a couple different planes, and it worked miracles. http://www.aircraftspruce.com/catalog/cspages/scratchoff.php It's called "Scratch Off". I used it on all of my windows when I got done, to get rid of any scratches I caused during construction. Tim Olson - RV-10 N104CD - Flying John Jessen wrote: > Help! Scratches on windshield............. > > Wanted to clean off the bugs and, using a nylon encased sponge, just > about put as many scratches on the windshield that I could do. Any > advice appreciated. I've looked up some products on ACS, but wondered > if anyone had had such a problem and found a solution that they could > recommend....PLEASE! Ugh. > > John J > (on the GlaStar, not the unfinished -10) > ________________________________________________________________________________
Date: Feb 25, 2008
John, This happened to an RV6 in our hangar. It was repaired by a chap who does motor cycle plastic repairs and after he finished you could not tell it had been done. The process was complex with many stages and he was clearly masterful at it. Having seen it done, I wouldn=92t try it myself. Good luck, John Cleary _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Monday, 25 February 2008 2:47 PM Subject: RV10-List: Windshield scratches Help! Scratches on windshield............. Wanted to clean off the bugs and, using a nylon encased sponge, just about put as many scratches on the windshield that I could do. Any advice appreciated. I've looked up some products on ACS, but wondered if anyone had had such a problem and found a solution that they could recommend....PLEASE! Ugh. John J (on the GlaStar, not the unfinished -10) "http://www.matronics.com/Navigator?RV10-List"http://www.matronics.com/Na vig ator?RV10-List "http://forums.matronics.com"http://forums.matronics.com "http://www.matronics.com/contribution"http://www.matronics.com/contribut ion 24/02/2008 12:19 PM 24/02/2008 12:19 PM ________________________________________________________________________________
Subject: Re: Crimpers
Date: Feb 25, 2008
Les, I've had good luck with that brand of tools. Here's a doc with some good info about different crimp tools and how to use them: http://www.verticalpower.com/docs/Connector_Service_Manual.pdf Marc -------- Marc Ausman http://www.verticalpower.com RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166102#166102 ________________________________________________________________________________
Date: Feb 25, 2008
Thanks to everyone for your posts on windshield scratches. I will order the Micromesh and have at it. I'll take pictures of the tools that made the scratches, the actual scratches, the tools assembled to get rid of them, and document the process. If I'm successful, I'll post everything on my site and send it on to Tim so it can be placed in a convenient location for future reference. Knowing Tim, there's probably something on the topic on his site already. If I have to replace the windshield, I'll take pictures of Hell's canyon just before the leap. You know, I just never thought that the windshield I'm zooming through the air behind (well, relative zooming) would be this soft. Another lesson... John J 40328 ________________________________________________________________________________
Date: Feb 25, 2008
Subject: ARC follow-up
Following my reading of the ARC final report published by the FAA. I sent off an e-mail to several addresses within the EAA, similar to the one I posted on this forum. My objective was to voice my disappointment with how I perceived I had been represented in this effort. I'm happy to report that today, I've been in receipt of several encouraging e-mails from Earl Lawrence the EAA's regulatory affairs officer. Earl was the EAA rep on the committee and along with Van one of the co-chairs . Through this dialog he has shared considerable additional information and insight from the proceedings and most importantly has indicated a pending EAA communications program/campaign which will address (but not be limited to) the following 3 questions: 1. What the EAA proposed to the FAA as a co chair of the ARC ? 2. What is the EAA's position wrt Commercial Builders and the impact they are having on our sport/hobby? 3. What the EAA recommends Amateur Builders do to continue to support and lobby for our existing rights to continue to build, fly, and maintain our aircraft ? I'm encouraged that the EAA does in fact plan an active role in this effort. And that they will involve the membership in the same. Through this brief process, I've also learned / formed some additional opinions that have given me cause to _increase_ my concern that the FAA _might_ act in a way that could limit or restrict our existing capabilities. (Yes, that means RV-10 builders) And as a result I'm reminded that keeping silent and hoping for a favorable outcome is not the best course. I simply care _too_ much about what I'm doing. As this issues moves forward I would encourage each of you to find a way to voice or record you desires. My experience in having the EAA hear my voice was encouraging and rewarding. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ ________________________________________________________________________________
Date: Feb 25, 2008
Your point is well taken. Care and protection of the windscreen leads to years of trouble free enjoyment with continued clarity. Bugs, ballpoint pens, clipboards, headsets and other sundry items leave a lasting and less than enjoyable impression. There have been a few novel headset hangers in some of the pictures that have drifted from this list over the months. The Repairman's cap needs to be on while we are wearing the Builder cap. It can substantially reduce the post production repairs list. John ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Ritter Sent: Monday, February 25, 2008 10:30 AM Subject: RE: RV10-List: Windshield scratches I had a scratch on my RV-10 windscreen on the inside about 4 inches long in a curved portion of the window (slap anyone who tries to put their headsets on the glareshield) that was really difficult to get to. Wish I had left it to the experts. At the end of the day I got rid of the scratch OK but ended up with a distortion I couldn't live with - not one of my better monemts. Ended up replacing the windscreen - you can imagine how much fun that was. Had the plane been painted I would have really been up a creek. Mark RV-10/N410MR ________________________________________________________________________________
Date: Feb 25, 2008
Subject: Fitting the cowl tips and the 1/4 turn fastner
Fitting the cowl.. some of this is cart before horse but I tried to keep it in some semblance of order I hope to help others who have not come this far...I have spent the last three weeks getting the cowl to fit properly...maybe I'm being to anal but this is a very cosmetic piece so I hope to help everyone achieve the same fit, maybe you already have. First off I am using mil spec 1/4 turn fasteners on the cowl sides, and along the top cowl firewall side. They are spaced at 4 inches around the firewall, 3.5" at the top to bottom cowl seam. I used hinges along the firewall the firewall for the cowl sides, only because I had already mounted the hinges prior to bolting on the engine mount. TIP #1 if you are mounting ether hinges or flanges for 1/4 turn fasteners, do so prior to mounting the engine mount...not enough readily accessible space to buck the rivet prior to installing the mount. OK....I can not emphasis this point. You need to get the forward part of the cowl fitted first...the inlets, the spinner diameter all that stuff you need to get right first. You may need to trim the top cowl to allow getting the nose ring to fit and the bottom to slide up over the top. The bottom cowl over laps the top cowl on the sides. Sand and make a very straight line on the bottom cowl now....it will be the guide for marking and cutting the top cowl when that time comes and the material seemed thin on the very edge, you will need to straight, blunt edge. Fit your top cowl as best as you can before even bringing the bottom cowl, left right, up down get the top as close to perfect before going any further, including the spinner gap. Get two sanding bars/blocks. I used a 12" and a 30" The 30 was fitted with 80 grit paper and the 12 has a coarse Carborundum metal backed abrasive plate. The edges sand very easily...too easily if you get aggressive. Once you mount the cowl bottom to the top on the aircraft you will notice that the back over hangs the firewall quite a bit. Trim the bottom to allow it to fit flush with the bottom. Beware of the flange interfering with the flush fit. I had to cut a portion of my bottom mounting flange back about 3/8, just make sure it does not hit the honeycomb. The masking tape method previously posted worked well for cutting the initial line on the top, bottom and sides. I still did not end up with a perfect flat nose ring once the cowl was fitted. To fix that I shorted the cowl about 3/16 to allow me to build up the nose ring with micro/epoxy. Then sand it for a perfect gap. Me engine has been mounted for 6 months so I don't fear sag to much at this point. OK...1/4 turn fasteners. I recommend using .063 for the flanges. Make sure they are at least 1-5/8 wide...Once you scallop the flange, it bends fairly easily into position. The reason I don't recommend anything lighter is the holes that must be made to mount the receptacle. The receptacles are mounted with -4 rivets, which just barely make edge distance from the middle receptacle hole...that hole is 11/16. The distance for the edge of that hole is very close to the edge of the flange, so don't go with too thin of a flange. I had all my flanges clecoed in place for fitting the cowl. Once the cowl was fit very tightly to the firewall I drilled all the fastener locations with a #40 and clecoed, checking fit after each hole. Did the bottom first, using #8 screws there but drilled and clecoed non the less. Then did the top cowl, firewall side then taped and strapped the two halves to mark the side cuts. Marked the top cowl using the bottom as a guide and cut near the line then sanded to the line with the long sanding block. Made up the side flanges with 1" -3 rivet spacing, matched drilled them to the bottom cowl, clecoed and reinstalled the cowl...side seam was perfect but tight, that's a good thing. Now I drilled the top cowl/side flanges while the assembly was secured to the aircraft with tape, straps and the neighbors small kid who worked underneath :). The trick is to get that whole shebang drilled and clecoed to the flanges. OK...tip coming! remove your flanges (mark them) then go over to your trusty drill press because your gonna drill a boat load of holes. Open the #40's to #30 and use the drill jig provided by Milspec to drill the rivet holes for the receptacles. Then open the center receptacle holes with a unibit to 11/16" that's a big hole and lot of chips. Then countersink the rivet holes for a flush -4. TIP!!! prime and install the receptacles now, don't wait till the strips are riveted to the aircraft. Once the receptacles are on, run them in on a best guess depth, use one of the fasteners to get close, all of mine were to shallow. Do this before mounting the strip...just by attaching to the cowl while it's on the bench. Then rivet the flanges to the aircraft, mount your cowl and see how it all fits..you will have to adjust (read bend down) each scallop to allow the outer edge of the cowl to fit flush...actually do it as soon as you do your first fitting of the flanges and cowl.Then final adjust your depths. I used the snap ring tool and the pliers from Milspec...right tool, right job...they worked perfect. Don't skimp on the clecos...use them in every hole. Final fitting...now that everything is installed with the fasteners, I removed the cowls and using masking tape as a guide (OK, anal here 3/64" material showing to be trimmed off, maybe a little more) I removed the small amount of material from all the edges to allow for that small line that will be occupied by paint. By waiting to do the final trimming now, you just push each part to the firewall snug each and every time during the fitting process. Would I use them again? Yup...Cons..they ain't cheap, took me about 60 hours to totally fit the cowl and install the fasteners, not including the oil door, louvers etc.. Once finished I am going to remove the metal grommets in prep for paint. Put your power tools up high and ignore them while doing this, the one exception is the Dremel, I used it to cut all of my cowl exclusively with there quick change made for plastic cut off wheels. Easy to control and very straight smooth cut. I hope I helped all of you thinking about this method. Thanks to pics of Vic Syaracuse, Randy's RV-3 works and a close examination of Wayne Edgerton's for helping me through this whole thing. Now on to the wheel pants & fairings...they are easy right? Rick Sked 40185 ________________________________________________________________________________
Subject: Elevator Stops
Date: Feb 25, 2008
I am rigging the elevator and cannot get enough movement to go from stop to stop. It is hitting on the front ball joint shank in one direction and the lower ball joint under the battery. I do have the minimum movement in each direction but I don't like that the movement is limited by the control mechanism instead of the stops. Any one else have this problem? Better yet anyone have a solution? Gary 40274 ________________________________________________________________________________
Subject: Fuel Tank Leak
Date: Feb 25, 2008
After 190 hours a leak developed around the fuel line fitting with the stra iner that goes into the right tank. It appears the fuel is leaking around the flange inside the tank and coming out around the opening for the fittin g. They are QB wings so I can't take credit for not properly prosealing th e flange to the fuel tank rib. With no access to the inside of the tank I' m trying to come up with a fix short of removing the tank. First two attem pts to come up with a fix failed. The third attempt appears to be working knock on wood. I'm getting really good at taking the wing root fairing on and off. The thought of messing up my paint job removing the tank screws is not plea sant. TIP - Those in the process of building the tank don't spare the proseal aro und the flange that is riveted to the rib. Mark RV-10/N410MR
_________________________________________________________________ Helping your favorite cause is as easy as instant messaging.-You IM, we g ive. ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: Unusual paint ridge around windows
Date: Feb 25, 2008
I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 9:35 PM ________________________________________________________________________________
Subject: Re: Fuel Tank Leak
Date: Feb 25, 2008
You did not say how you fixed it on the third try. I have a leak on my QB tank and Van has sent me a new tank but the thought of replacing and repainting the tank has stopped me short. My leak (the third discovered on this tank) is at the outboard panel. Any suggestion short of opening an access hole? Rob. On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: > > After 190 hours a leak developed around the fuel line fitting with > the strainer that goes into the right tank. It appears the fuel is > leaking around the flange inside the tank and coming out around the > opening for the fitting. They are QB wings so I can't take credit > for not properly prosealing the flange to the fuel tank rib. With > no access to the inside of the tank I'm trying to come up with a fix > short of removing the tank. First two attempts to come up with a > fix failed. The third attempt appears to be working knock on wood. > I'm getting really good at taking the wing root fairing on and off. > > The thought of messing up my paint job removing the tank screws is > not pleasant. > > TIP - Those in the process of building the tank don't spare the > proseal around the flange that is riveted to the rib. > > Mark > RV-10/N410MR > > >
> > > Helping your favorite cause is as easy as instant messaging. You IM, > we givein' target='_new'>Learn more. > > ________________________________________________________________________________
Subject: Re: Elevator Stops
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Feb 25, 2008
Gary, we also had a problem with the elevator rigging. It has been quite a while, so I will attempt to recall as best as I can. Our problem was the elevator horn would not bump against the aft stop. The bottom of the elevator horn seemed as if it could be 'forced' past the stop and become jammed. We ended up building up the stop with an extra bar of .125 aluminum and a piece of 1x1 angle. When we asked Vans, they had never seen this problem before, we double checked everything, and they gave the thumbs up to the fix. To tell if you are having the same problem as we had, take a look at the elevator horn when the elevator is in the full nose up deflection. If it seems as if the elevator horn could go past the stop let me know and I will send you pictures of our fix off line. Thanks, Jason #40617 - Finishing speckter(at)comcast.net wrote: > I am rigging the elevator and cannot get enough movement to go from stop to > stop. It is hitting on the front ball joint shank in one direction and the > lower ball joint under the battery. I do have the minimum movement in each > direction but I don't like that the movement is limited by the control > mechanism instead of the stops. > > Any one else have this problem? Better yet anyone have a solution? > > Gary > 40274 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166197#166197 ________________________________________________________________________________
Date: Feb 25, 2008
I'm lucky in a way in that I can see the leak by removing the wing root fai ring. I put two flat washers over the strainer and on to the fitting. I pu t a liberal amount of proseal around the washers which I hoped would push t he proseal into the opening around the hole in the fuel tank rib when I tig hten the fitting. The washers also might help in tightening up the flange in the tank against the rib. If it starts leaking again I'm going to try t hinning out some proseal with MEK and suck it into the hole using a suction pump on the fuel vent. After that I'm out of ideas and will have to remove the tank to cut an acce ss hole so I can get to the flange. A paint cutter (The Yard Store) works fairly well around the screws to keep the damage to the paint at a minimum. A friend with a fuel tank leak used the cutter around the screws of his p ainted RV-7 and it looks OK - not great but OK. Mark RV-10/N410MR
From: flysrv10(at)gmail.comTo: rv10-list(at)matronics.comSubject: Re: RV10-List: Fuel Tank LeakDate: Mon, 25 Feb 2008 17:32:14 -0500You did not say how you fixed it on the third try. I have a leak on my QB tank and Van has sent me a new tank but the thought of replacing and repainting the tank has stoppe d me short. My leak (the third discovered on this tank) is at the outboard panel. Any suggestion short of opening an access hole? Rob. On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: After 190 hours a leak developed around the fuel line fitting with the stra iner that goes into the right tank. It appears the fuel is leaking around the flange inside the tank and coming out around the opening for the fittin g. They are QB wings so I can't take credit for not properly prosealing th e flange to the fuel tank rib. With no access to the inside of the tank I' m trying to come up with a fix short of removing the tank. First two attem pts to come up with a fix failed. The third attempt appears to be working knock on wood. I'm getting really good at taking the wing root fairing on and off. The thought of messing up my paint job removing the tank screws is not pleasant. TIP - Those in the process of building the tank don't spare the proseal around the flange that is riveted to the rib. MarkRV-10/N410M R
Helping your favorite cause is as easy as instant messaging. You IM, we giv ein' target='_new'>Learn more.http://www.matronics.com/Navigator?RV10-Lis t href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution _________________________________________________________________ Need to know the score, the latest news, or you need your Hotmail=AE-get yo ur "fix". http://www.msnmobilefix.com/Default.aspx ________________________________________________________________________________
Date: Feb 25, 2008
they sent you a new tank?? wow, I thought they were handing out 4 inch "access panels". Never understood the logic of repairing a pinhole sized leak with a 4 inch access panel. ----- Original Message ----- From: Rob Kermanj To: rv10-list(at)matronics.com Sent: Monday, February 25, 2008 2:32 PM Subject: Re: RV10-List: Fuel Tank Leak You did not say how you fixed it on the third try. I have a leak on my QB tank and Van has sent me a new tank but the thought of replacing and repainting the tank has stopped me short. My leak (the third discovered on this tank) is at the outboard panel. Any suggestion short of opening an access hole? Rob. On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: After 190 hours a leak developed around the fuel line fitting with the strainer that goes into the right tank. It appears the fuel is leaking around the flange inside the tank and coming out around the opening for the fitting. They are QB wings so I can't take credit for not properly prosealing the flange to the fuel tank rib. With no access to the inside of the tank I'm trying to come up with a fix short of removing the tank. First two attempts to come up with a fix failed. The third attempt appears to be working knock on wood. I'm getting really good at taking the wing root fairing on and off. The thought of messing up my paint job removing the tank screws is not pleasant. TIP - Those in the process of building the tank don't spare the proseal around the flange that is riveted to the rib. Mark RV-10/N410MR
------------------------------------------------------------------------- --- Helping your favorite cause is as easy as instant messaging. You IM, we givein' target='_new'>Learn more. http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Date: Feb 25, 2008
Subject: Re: BA Prop
Well you know some guys....two things to hand prop aren't enough. ;-p On Mon, Feb 25, 2008 at 4:19 PM, John W. Cox wrote: > > > Viagra, for prop envy. Last longer around sexy aircraft. I have heard it > all. > > > John C. ________________________________________________________________________________
Date: Feb 25, 2008
Consider that likely the replacement tank was built by Van's staff rather than in the Philippines. Might just be a bit better construction. On Mon, Feb 25, 2008 at 3:32 PM, Rob Kermanj wrote: > You did not say how you fixed it on the third try. I have a leak on my QB > tank and Van has sent me a new tank but the thought of replacing and > repainting the tank has stopped me short. My leak (the third discovered on > this tank) is at the outboard panel. Any suggestion short of opening an > access hole? > > Rob. > ________________________________________________________________________________
Subject: safety-trim mounting locations
Date: Feb 25, 2008
Where are/have people been mounting the safety trim controller unit? What factors influenced your decision? THX -Ben ________________________________________________________________________________
Subject: Re: safety-trim mounting locations
Date: Feb 25, 2008
Ben, I certainly want others to chime in, but some of our customers have mounted the Safety-Trim controller to the wing spar under the front seats, This certainly is a very short run of wire to the trim switch wiring coming from the control sticks. We are mounting it in the rear of the our RV-10 on an equipement tray behind the baggage area. We have photo's of this on our web site. In our Glastar I mounted it up under the instrument panel near the previously existing wiring. Thanks, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Date: Feb 25, 2008
Thanks for the info. Rob. On Feb 25, 2008, at 6:54 PM, Mark Ritter wrote: > I'm lucky in a way in that I can see the leak by removing the wing > root fairing. I put two flat washers over the strainer and on to the > fitting. I put a liberal amount of proseal around the washers which > I hoped would push the proseal into the opening around the hole in > the fuel tank rib when I tighten the fitting. The washers also > might help in tightening up the flange in the tank against the rib. > If it starts leaking again I'm going to try thinning out some > proseal with MEK and suck it into the hole using a suction pump on > the fuel vent. > > After that I'm out of ideas and will have to remove the tank to cut > an access hole so I can get to the flange. A paint cutter (The Yard > Store) works fairly well around the screws to keep the damage to the > paint at a minimum. A friend with a fuel tank leak used the cutter > around the screws of his painted RV-7 and it looks OK - not great > but OK. > > Mark > RV-10/N410MR > > >
> > > From: flysrv10(at)gmail.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Fuel Tank Leak > Date: Mon, 25 Feb 2008 17:32:14 -0500 > > You did not say how you fixed it on the third try. I have a leak on > my QB tank and Van has sent me a new tank but the thought of > replacing and repainting the tank has stopped me short. My leak > (the third discovered on this tank) is at the outboard panel. Any > suggestion short of opening an access hole? > > Rob. > > On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: > > > After 190 hours a leak developed around the fuel line fitting with > the strainer that goes into the right tank. It appears the fuel is > leaking around the flange inside the tank and coming out around the > opening for the fitting. They are QB wings so I can't take credit > for not properly prosealing the flange to the fuel tank rib. With > no access to the inside of the tank I'm trying to come up with a fix > short of removing the tank. First two attempts to come up with a > fix failed. The third attempt appears to be working knock on wood. > I'm getting really good at taking the wing root fairing on and off. > > The thought of messing up my paint job removing the tank screws is > not pleasant. > > TIP - Those in the process of building the tank don't spare the > proseal around the flange that is riveted to the rib. > > Mark > RV-10/N410MR > > >
> > > Helping your favorite cause is as easy as instant messaging. You IM, > we givein' target='_new'>Learn more. > http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution > > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > Need to know the score, the latest news, or you need your Hotmail=AE- > get your "fix". Check it out. > > ________________________________________________________________________________
Date: Feb 25, 2008
Yes they did. However, my first leaks began on two rivets, then at the fuel pick up area, and then at the outboard baffle. I had no difficulty asking for a new tank. Rob. On Feb 25, 2008, at 7:00 PM, Pascal wrote: > they sent you a new tank?? wow, I thought they were handing out 4 > inch "access panels". > > Never understood the logic of repairing a pinhole sized leak with a > 4 inch access panel. > > > ----- Original Message ----- > From: Rob Kermanj > To: rv10-list(at)matronics.com > Sent: Monday, February 25, 2008 2:32 PM > Subject: Re: RV10-List: Fuel Tank Leak > > You did not say how you fixed it on the third try. I have a leak on > my QB tank and Van has sent me a new tank but the thought of > replacing and repainting the tank has stopped me short. My leak > (the third discovered on this tank) is at the outboard panel. Any > suggestion short of opening an access hole? > > Rob. > > On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: > >> >> After 190 hours a leak developed around the fuel line fitting with >> the strainer that goes into the right tank. It appears the fuel is >> leaking around the flange inside the tank and coming out around the >> opening for the fitting. They are QB wings so I can't take credit >> for not properly prosealing the flange to the fuel tank rib. With >> no access to the inside of the tank I'm trying to come up with a >> fix short of removing the tank. First two attempts to come up with >> a fix failed. The third attempt appears to be working knock on >> wood. I'm getting really good at taking the wing root fairing on >> and off. >> >> The thought of messing up my paint job removing the tank screws is >> not pleasant. >> >> TIP - Those in the process of building the tank don't spare the >> proseal around the flange that is riveted to the rib. >> >> Mark >> RV-10/N410MR >> >> >>
>> >> >> Helping your favorite cause is as easy as instant messaging. You >> IM, we givein' target='_new'>Learn more. >> http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Date: Feb 25, 2008
Scott told me that it will be built here with the knowledge that it is going to replace a tank for an unhappy customer. I am also very pleased that we deal with such a great company that backs up their product without question. They certainly make up for that rare deficiencies that come up. Rob. On Feb 25, 2008, at 7:14 PM, Kelly McMullen wrote: > > Consider that likely the replacement tank was built by Van's staff > rather than in the Philippines. Might just be a bit better > construction. > > On Mon, Feb 25, 2008 at 3:32 PM, Rob Kermanj > wrote: >> You did not say how you fixed it on the third try. I have a leak >> on my QB >> tank and Van has sent me a new tank but the thought of replacing and >> repainting the tank has stopped me short. My leak (the third >> discovered on >> this tank) is at the outboard panel. Any suggestion short of >> opening an >> access hole? >> >> Rob. >> > > ________________________________________________________________________________
Date: Feb 26, 2008
Rick fantastic write up. Valuable stuff indeed! Any photos? John 40315 (cowls) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Tuesday, 26 February 2008 7:00 AM Subject: RV10-List: Fitting the cowl tips and the 1/4 turn fastner Fitting the cowl........................ ________________________________________________________________________________
Date: Feb 25, 2008
That makes sense,Always nice to hear how Van's stands by their product when there is an obvious problem. Thanks for explaining! Pascal ----- Original Message ----- From: Rob Kermanj To: rv10-list(at)matronics.com Sent: Monday, February 25, 2008 7:04 PM Subject: Re: RV10-List: Fuel Tank Leak Yes they did. However, my first leaks began on two rivets, then at the fuel pick up area, and then at the outboard baffle. I had no difficulty asking for a new tank. Rob. On Feb 25, 2008, at 7:00 PM, Pascal wrote: they sent you a new tank?? wow, I thought they were handing out 4 inch "access panels". Never understood the logic of repairing a pinhole sized leak with a 4 inch access panel. ----- Original Message ----- From: Rob Kermanj To: rv10-list(at)matronics.com Sent: Monday, February 25, 2008 2:32 PM Subject: Re: RV10-List: Fuel Tank Leak You did not say how you fixed it on the third try. I have a leak on my QB tank and Van has sent me a new tank but the thought of replacing and repainting the tank has stopped me short. My leak (the third discovered on this tank) is at the outboard panel. Any suggestion short of opening an access hole? Rob. On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: After 190 hours a leak developed around the fuel line fitting with the strainer that goes into the right tank. It appears the fuel is leaking around the flange inside the tank and coming out around the opening for the fitting. They are QB wings so I can't take credit for not properly prosealing the flange to the fuel tank rib. With no access to the inside of the tank I'm trying to come up with a fix short of removing the tank. First two attempts to come up with a fix failed. The third attempt appears to be working knock on wood. I'm getting really good at taking the wing root fairing on and off. The thought of messing up my paint job removing the tank screws is not pleasant. TIP - Those in the process of building the tank don't spare the proseal around the flange that is riveted to the rib. Mark RV-10/N410MR
------------------------------------------------------------------------ Helping your favorite cause is as easy as instant messaging. You IM, we givein' target='_new'>Learn more. http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Date: Feb 25, 2008
I have looked at your install in the 10 on your site. The equipment tray is a great idea and looks nice. I am concerned about the wiring for that location. I am quickly finding out the reality that the conduit that goes under the floors up to the front is prime real estate. There are quite a few less wires running through the conduit to the tail if you mount it up front. This might necessitate that I install it in the front half of the plane. -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob-tcw Sent: Monday, February 25, 2008 6:56 PM Subject: Re: RV10-List: safety-trim mounting locations Ben, I certainly want others to chime in, but some of our customers have mounted the Safety-Trim controller to the wing spar under the front seats, This certainly is a very short run of wire to the trim switch wiring coming from the control sticks. We are mounting it in the rear of the our RV-10 on an equipement tray behind the baggage area. We have photo's of this on our web site. In our Glastar I mounted it up under the instrument panel near the previously existing wiring. Thanks, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Date: Feb 26, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Leaking QB Tanks? Y'all are making me happier and happier with my economics-driven decision to go the slo-build route. Jack Phillips #610, Raleigh NC Still waiting for my Slo-Build Wing Kit to Arrive _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Sent: Monday, February 25, 2008 5:32 PM Subject: Re: RV10-List: Fuel Tank Leak You did not say how you fixed it on the third try. I have a leak on my QB tank and Van has sent me a new tank but the thought of replacing and repainting the tank has stopped me short. My leak (the third discovered on this tank) is at the outboard panel. Any suggestion short of opening an access hole? Rob. On Feb 25, 2008, at 5:08 PM, Mark Ritter wrote: After 190 hours a leak developed around the fuel line fitting with the strainer that goes into the right tank. It appears the fuel is leaking around the flange inside the tank and coming out around the opening for the fitting. They are QB wings so I can't take credit for not properly prosealing the flange to the fuel tank rib. With no access to the inside of the tank I'm trying to come up with a fix short of removing the tank. First two attempts to come up with a fix failed. The third attempt appears to be working knock on wood. I'm getting really good at taking the wing root fairing on and off. The thought of messing up my paint job removing the tank screws is not pleasant. TIP - Those in the process of building the tank don't spare the proseal around the flange that is riveted to the rib. Mark RV-10/N410MR
_____ Helping your favorite cause is as easy as instant messaging. You IM, we givein' target='_new'>Learn more. _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Feb 26, 2008
I had my trim relays mounted under the panel lip edge....no big reason, as they could have been under the seats I guess. So for me it was easy splicing to just put it in under the radio stack. For some of these lightweight plastic boxes, I've found the hard plastic high strength velcro to be great...just slap on a slab and stick it in place. It isn't as solid until you get it on there for a day or two, but once the stickyback tightens up, that thing isn't going anywhere....and it's easy to yank off again. Did the same with my GRT Manifold pressure sensor, and my CO monitor. Just the lightweight or plastic things....and nothing that can drop and short out. Tim Ben Westfall wrote: > I have looked at your install in the 10 on your site. The equipment > tray is a great idea and looks nice. I am concerned about the wiring > for that location. I am quickly finding out the reality that the > conduit that goes under the floors up to the front is prime real estate. > There are quite a few less wires running through the conduit to the > tail if you mount it up front. This might necessitate that I install it > in the front half of the plane. > > > > -Ben > ________________________________________________________________________________
Date: Feb 26, 2008
John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM ________________________________________________________________________________
Date: Feb 26, 2008
Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM "http://www.matronics.com/Navigator?RV10-List"http://www.matronics.com/Navig ator?RV10-List "http://www.matronics.com/contribution"http://www.matronics.com/contribution 9:35 PM 9:35 PM ________________________________________________________________________________
Subject: Urethane pourable expanding foam in doors?
Date: Feb 26, 2008
Hey all - I know someone around here has thought about filling the doors with an expanding foam to give them some density and make 'em be less flimsy. Anyone care to speculate if you'd split your door in two by doing this? I was thinking something like this: http://jgreer.com/Foam%20Page.htm I called and spoke with John Greer there and tried to explain myself. "uh, so, I'm building an airplane, and I was thinking..." you know how those conversations go. I asked if he thought I'd blow up the door by filling it with that stuff, and he said he didn't think so. After thinking about it a bit, I think I agree. My reasoning: on his website (and others with similar products) there's a picture of a paper cup with some foam that has been poured and expanded in it. the foam expands over the top, and creates a muffin-top type situation. the paper cup retains it's shape, and doesn't split. So, think I, as long as you have open space for the foam to expand, it's not going to split the door. Now, this is all my hair-brained theory. The leap to filling my already-fitting and built doors with something that could destroy them gives me pause. The upside to doing this is that it seems like it'll make the doors feel much less flimsy, not add too much weight, insulate a bit, cut down on noise, etc. Downsides? possibly having to build new doors. hmmm. I think I'm going to get some of this foam and do some testing. While I'm on this voyage of discovery, anyone want to give their opinion? A search of the archives only had one entry on the subject, and it had not much detail. cj #40410 finishing/FF/various science projects www.perfectlygoodairplane.net ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: Urethane pourable expanding foam in doors?
The paper cup is a different story as it can easely expand, if you have a small and narrow channel the story might come out different! I would be very carefull with that approach, for a short open space ok, for a long (>3" and narrow (1" or less)) I would leave my fingers off, and then there is the weight of UR foam. as usuasl just my 5cents Werner Chris Johnston wrote: > Hey all - > > I know someone around here has thought about filling the doors with an expanding foam to give them some density and make 'em be less flimsy. Anyone care to speculate if you'd split your door in two by doing this? I was thinking something like this: > > http://jgreer.com/Foam%20Page.htm > > I called and spoke with John Greer there and tried to explain myself. "uh, so, I'm building an airplane, and I was thinking..." you know how those conversations go. I asked if he thought I'd blow up the door by filling it with that stuff, and he said he didn't think so. After thinking about it a bit, I think I agree. My reasoning: on his website (and others with similar products) there's a picture of a paper cup with some foam that has been poured and expanded in it. the foam expands over the top, and creates a muffin-top type situation. the paper cup retains it's shape, and doesn't split. So, think I, as long as you have open space for the foam to expand, it's not going to split the door. > > Now, this is all my hair-brained theory. The leap to filling my already-fitting and built doors with something that could destroy them gives me pause. The upside to doing this is that it seems like it'll make the doors feel much less flimsy, not add too much weight, insulate a bit, cut down on noise, etc. Downsides? possibly having to build new doors. hmmm. I think I'm going to get some of this foam and do some testing. While I'm on this voyage of discovery, anyone want to give their opinion? A search of the archives only had one entry on the subject, and it had not much detail. > > cj > #40410 > finishing/FF/various science projects > www.perfectlygoodairplane.net > > ________________________________________________________________________________
Date: Feb 26, 2008
There are people who have put fabric on their doors who already can't get the lift cylinders to stay up well. It would only get worse over time. Mine work good, but I would never bother filling them with foam. If you want me to be blunt, I could just say "Hey cj, that's a dumb idea." But instead, I'll just say......is it really worth the possible downsides? :) I think you'll find that just having fabric on the inside of the plane will deaden echo'd sounds, and make it pretty quiet. And, warmth wise you really have no concerns. The heat output in the -10 is incredible. I fly in 10F weather with no jacket in the plane because you can easily warm it comfortable with 1/2 heat. I can't even use full heat. Anyway, you got my .02. No offense, just havin' fun. Tim Chris Johnston wrote: > Hey all - > > I know someone around here has thought about filling the doors with > an expanding foam to give them some density and make 'em be less > flimsy. Anyone care to speculate if you'd split your door in two by > doing this? I was thinking something like this: > > http://jgreer.com/Foam%20Page.htm > > I called and spoke with John Greer there and tried to explain myself. > "uh, so, I'm building an airplane, and I was thinking..." you know > how those conversations go. I asked if he thought I'd blow up the > door by filling it with that stuff, and he said he didn't think so. > After thinking about it a bit, I think I agree. My reasoning: on > his website (and others with similar products) there's a picture of a > paper cup with some foam that has been poured and expanded in it. > the foam expands over the top, and creates a muffin-top type > situation. the paper cup retains it's shape, and doesn't split. So, > think I, as long as you have open space for the foam to expand, it's > not going to split the door. > > Now, this is all my hair-brained theory. The leap to filling my > already-fitting and built doors with something that could destroy > them gives me pause. The upside to doing this is that it seems like > it'll make the doors feel much less flimsy, not add too much weight, > insulate a bit, cut down on noise, etc. Downsides? possibly having > to build new doors. hmmm. I think I'm going to get some of this > foam and do some testing. While I'm on this voyage of discovery, > anyone want to give their opinion? A search of the archives only had > one entry on the subject, and it had not much detail. > > cj #40410 finishing/FF/various science projects > www.perfectlygoodairplane.net > ________________________________________________________________________________
Date: Feb 27, 2008
Hey CJ, Have you installed the windows in the doors yet? I thought the doors were flimsy too, until I installed the windows. Seem plenty rigid to me now. With real issues surrounding door fit, the door latch and the installation of a locking mechanism, rigidity of the door has not been a concern for me. YMMV tho' Cheers, Ron 187 still trying to finish -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston Sent: Wednesday, 27 February 2008 7:38 AM Subject: RV10-List: Urethane pourable expanding foam in doors? Hey all - I know someone around here has thought about filling the doors with an expanding foam to give them some density and make 'em be less flimsy. Anyone care to speculate if you'd split your door in two by doing this? I was thinking something like this: http://jgreer.com/Foam%20Page.htm I called and spoke with John Greer there and tried to explain myself. "uh, so, I'm building an airplane, and I was thinking..." you know how those conversations go. I asked if he thought I'd blow up the door by filling it with that stuff, and he said he didn't think so. After thinking about it a bit, I think I agree. My reasoning: on his website (and others with similar products) there's a picture of a paper cup with some foam that has been poured and expanded in it. the foam expands over the top, and creates a muffin-top type situation. the paper cup retains it's shape, and doesn't split. So, think I, as long as you have open space for the foam to expand, it's not going to split the door. Now, this is all my hair-brained theory. The leap to filling my already-fitting and built doors with something that could destroy them gives me pause. The upside to doing this is that it seems like it'll make the doors feel much less flimsy, not add too much weight, insulate a bit, cut down on noise, etc. Downsides? possibly having to build new doors. hmmm. I think I'm going to get some of this foam and do some testing. While I'm on this voyage of discovery, anyone want to give their opinion? A search of the archives only had one entry on the subject, and it had not much detail. cj #40410 finishing/FF/various science projects www.perfectlygoodairplane.net "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: OSH RV-10 Operatons seminar
I would definitely pay for a few extra days and split your gas Tim to fly over there and stake it out. The spots last year were great and it really made it fun to be so close to the front and not have to walk up and down the busy road. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: Tim Olson <Tim(at)MyRV10.com> Sent: Sunday, February 24, 2008 6:38:12 AM Subject: Re: RV10-List: Re: OSH RV-10 Operatons seminar --> RV10-List message posted by: Tim Olson I think this year we were also contemplating having me and/or Michael go over there a little earlier so we could get contiguous spaces. I think it was a bit scattered last year and a few of the people who were out there further thought it would be worthwhile to get sites earlier and pay a couple extra days, to get them closer. I'll touch base with Scott, but it may be that if others are unwilling to pick up a couple more days to be closer to the group, that I'll still get over there either on, or before that weekend before, so I can grab a couple of them for us. I definitely think we need to, as a group, like you mentioned....get a single additional site just for hanging out. It got a bit tight at times trying to cram all the chairs into the end of a site. It'll be sweet if we can have better group space this year. Personally, considering how close the sites are to the show, I think if we grab some all contiguous, we should skip getting an EAA tent or whatever, and just do it all at the campsite. Tim Olson - RV-10 N104CD - Flying do not archive Condrey, Bob (US SSA) wrote: > Sounds like a plan! > > > > Bob > > > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of > *speckter(at)comcast.net > *Sent:* Saturday, February 23, 2008 7:01 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Re: OSH RV-10 Operatons seminar > > > > I looked at the calendar and we will probably arrive at OSH on the 21 on > Monday again and we can stake out the sites on Tues the 22. If you want > to be the treasurer again, I would be greatful. > > > > Gary > > > > -------------- Original message -------------- > From: "bcondrey" > > > --> RV10-List message posted by: "bcondrey" > > > > Gary, > > > > I will also be there again early but haven't really done any > planning yet. I > > thought last year worked OK, but if somebody had ideas for > improvements I'm all > > ears. > > > > BTW, last year folks were very generous with their contributions > during our > > various "food nights" and we overachieved a bit... I plan to use > the excess > > collected to partially offset cost for an extra site to give us > more room for > > gathering and socializing for the group. > > > > We can plan more when it gets a little closer. > > > > Bob > > > > > > > > > > Read this topic online here: > > *> --> * > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > > > * - The RV10-List Email Forum - Use the Matronics List Features Navigator to browse the many List utilities such as List Un/Subscription, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much much more: --> http://www.matronics.com/Navigator?RV10-List - MATRONICS WEB FORUMS - Same great content also available via the Web Forums! --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 26, 2008
Absolutely do not do this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! You will find out several things. As has been said, with so little space fo r the foam to expand into, it can easily seal itself off, leaving no place for the expansion to go and it will warp and bow out your doors. If you cou ld have each part half still in their mold halves and then fill it and clos e the mold, it would be a different story. "Do Not Seek The Treasure!!!!" Oh Brother Where Art Thou JOhn G.> Subject: RV10-List: Urethane pourable expanding foam in doors?> Da -list(at)matronics.com> > Hey all - > > I know someone around here has thought about filling the doors with an expanding foam to give them some density a nd make 'em be less flimsy. Anyone care to speculate if you'd split your do or in two by doing this? I was thinking something like this:> > http://jgre er.com/Foam%20Page.htm> > I called and spoke with John Greer there and trie d to explain myself. "uh, so, I'm building an airplane, and I was thinking. .." you know how those conversations go. I asked if he thought I'd blow up the door by filling it with that stuff, and he said he didn't think so. Aft er thinking about it a bit, I think I agree. My reasoning: on his website ( and others with similar products) there's a picture of a paper cup with som e foam that has been poured and expanded in it. the foam expands over the t op, and creates a muffin-top type situation. the paper cup retains it's sha pe, and doesn't split. So, think I, as long as you have open space for the foam to expand, it's not going to split the door. > > Now, this is all my h air-brained theory. The leap to filling my already-fitting and built doors with something that could destroy them gives me pause. The upside to doing this is that it seems like it'll make the doors feel much less flimsy, not add too much weight, insulate a bit, cut down on noise, etc. Downsides? pos sibly having to build new doors. hmmm. I think I'm going to get some of thi s foam and do some testing. While I'm on this voyage of discovery, anyone w ant to give their opinion? A search of the archives only had one entry on t he subject, and it had not much detail.> > cj> #40410> finishing/FF/various science projects> www.perfectlygoodairplane.net> ________________________________________________________________________________
Date: Feb 26, 2008
Been there, done that .... but not on parts like these doors. If you decide to go down this path .... and I think it's a good idea .... there are a few things you can control, and a few that you can't. You really should make some weep holes along the cavity ..... a place for the pressure to go. Plug these with a tapered plug that's snug, not tight. At any signs of swelling, pull the plugs. The pressure can get fairly high per sq. in., but having a close space makes the foam denser, and therefore stronger. If there's a seam that didn't get sufficient epoxy, it may part. To do a good job, you need to get the liquid foam to coat the whole cavity before it flashes off. The cooler you keep it, the longer your working time. once it starts to kick, it generates it's own heat and it'll run away pretty quickly. You need to have some way to get the liquid mix into the cavity ..... you may be able to take a baggie, cut a corner off, and tape a tube in the hole. Fill the baggie with the mix, and squeeze it like a bakers icing bag into the cavity. I had a machine that mixed the two parts and I could spray it into a cavity. Having gone all through this, if there's a boat manufacturer near you, they have the machine to spray foam into flotation places and can give you some pointers. Linn Chris Johnston wrote: >Hey all - > >I know someone around here has thought about filling the doors with an expanding foam to give them some density and make 'em be less flimsy. Anyone care to speculate if you'd split your door in two by doing this? I was thinking something like this: > >http://jgreer.com/Foam%20Page.htm > >I called and spoke with John Greer there and tried to explain myself. "uh, so, I'm building an airplane, and I was thinking..." you know how those conversations go. I asked if he thought I'd blow up the door by filling it with that stuff, and he said he didn't think so. After thinking about it a bit, I think I agree. My reasoning: on his website (and others with similar products) there's a picture of a paper cup with some foam that has been poured and expanded in it. the foam expands over the top, and creates a muffin-top type situation. the paper cup retains it's shape, and doesn't split. So, think I, as long as you have open space for the foam to expand, it's not going to split the door. > >Now, this is all my hair-brained theory. The leap to filling my already-fitting and built doors with something that could destroy them gives me pause. The upside to doing this is that it seems like it'll make the doors feel much less flimsy, not add too much weight, insulate a bit, cut down on noise, etc. Downsides? possibly having to build new doors. hmmm. I think I'm going to get some of this foam and do some testing. While I'm on this voyage of discovery, anyone want to give their opinion? A search of the archives only had one entry on the subject, and it had not much detail. > >cj >#40410 >finishing/FF/various science projects >www.perfectlygoodairplane.net > > > ________________________________________________________________________________
Subject: BA Prop Part II - Paint
Date: Feb 26, 2008
Seeing that my last question about a BA prop ended in a discussion about male performance related issues I am hesitant to ask a follow up but here it goes... I always lusted after the custom painted composite props and assumed that I could not paint my BA prop till I saw an RV-10 for sale on Barnstormers with a painted prop. I am beginning to feel my life can now be complete. Any comments on the practicality of painting this prop full length or just a modified paint scheme on the tip (extended)? Robin ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: BA Prop Part II - Paint
You can definitely paint the BA prop!! Hartzell will do it for you. Kirk Quoting Robin Marks : > Seeing that my last question about a BA prop ended in a discussion about > male performance related issues I am hesitant to ask a follow up but > here it goes... > > I always lusted after the custom painted composite props and assumed > that I could not paint my BA prop till I saw an RV-10 for sale on > Barnstormers with a painted prop. I am beginning to feel my life can now > be complete. > > Any comments on the practicality of painting this prop full length or > just a modified paint scheme on the tip (extended)? > > > Robin > > ________________________________________________________________________________
Subject: Re: Unusual paint ridge around windows
Date: Feb 26, 2008
John, After you painted the door with Imron, did you bake the paint to help it dry or did you let it air dry? Zack -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166516#166516 ________________________________________________________________________________
Date: Feb 26, 2008
John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...quite a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did something similar around the windsheild of mine, but the overlay went on many months after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Tuesday, February 26, 2008 12:34 PM Subject: RE: RV10-List: Unusual paint ridge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 2/23/2008 9:35 PM ________________________________________________________________________________
Date: Feb 27, 2008
I don't know what caused the ridge, but when I got a crack around one of the windows on a plane I built 20 years ago that followed the contour of the window like your's does, I took some pinstripe tape from an auto store and overlaid it on the crack/ridge in your case/. It hid the crack and I didn't have to repaint. You might try that and see what you think. Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Wednesday, February 27, 2008 1:25 AM Subject: RE: RV10-List: Unusual paint ridge around windows John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...quite a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did something similar around the windsheild of mine, but the overlay went on many months after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Tuesday, February 26, 2008 12:34 PM Subject: RE: RV10-List: Unusual paint ridge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Feb 27, 2008
CJ, What happens to Urethane when it burns...what types of gasing off are you going to get as the foam expands and continues to gas-off. Some applications of expandables can cause irritation to lungs and soft tissues both immediately and long term migration. P **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Feb 27, 2008
When you guys say you are overlaying glass over the seam, what are you usin g, what weight of weave, how many laminations? What I am wondering is once you have done this, are you building up the rest of the cabin top to match the contour which this overlay has created, or are you sanding the overlay down so much that it really is much thinner than it was when in full form? John G. 409 From: Dave(at)AirCraftersLLC.comTo: rv10-list(at)matronics.comSubject: RE: RV10-L ist: Unusual paint ridge around windowsDate: Tue, 26 Feb 2008 22:24:54 -080 0 John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...qui te a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did some thing similar around the windsheild of mine, but the overlay went on many m onths after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John TestementSent: Tuesday, February 26, 2008 1 2:34 PMTo: rv10-list(at)matronics.comSubject: RE: RV10-List: Unusual paint rid ge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. I ts as though the Weld On expanded when painted over. I used West System ep oxy. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Dave SaylorSent: Tuesday, February 26, 2008 1:26 PMTo: rv10-list(at)matronics.comSubject: RE: RV10-List: Unusual paint ridge a round windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin d id you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John TestementSent: Monday, February 25, 2008 2: 36 PMTo: rv10-list(at)matronics.comSubject: RV10-List: Unusual paint ridge aro und windows I have had an unusual situation with the door windows when painting and wan t to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberg lass joint - it is about 1/4 wide and 1/16 high. The area was level and smo oth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final c olor and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testementjwt(at)roadmapscoaching.com40321 Richmond, VAPainting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "Jon Reining" <jonathan.w.reining(at)wellsfargo.com>
Date: Feb 27, 2008
I just foamed the walls of my house for insulation and went through a pretty extensive search. There's a big difference between the open and closed cell foam. Its looks like you're looking at closed cell foam. The open cell foam tends to weigh less, but also have a pretty huge expansion factor when its applied. So I'd definitely stay away from that. The closed cell foam doesn't expand as much, is denser (and weighs more) but also adds quite a bit of structural strength. I ended up going with closed cell foam that is made primarily from soy beans and had an R value of like 7.5 per inch of foam. As an insulator on a house its awesome. So, to apply all this to airplane building... I don't think its entirely crazy, but I'd be especially careful. Perhaps glass up a simulated door cavity and try it out and see how you like it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166588#166588 ________________________________________________________________________________
Date: Feb 27, 2008
Just one thought on the foam. You also have to be concerned about water absorption and UV and heat affects. Rene' Felker N423CF 40322 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jon Reining Sent: Wednesday, February 27, 2008 10:26 AM Subject: RV10-List: Re: Urethane pourable expanding foam in doors? I just foamed the walls of my house for insulation and went through a pretty extensive search. There's a big difference between the open and closed cell foam. Its looks like you're looking at closed cell foam. The open cell foam tends to weigh less, but also have a pretty huge expansion factor when its applied. So I'd definitely stay away from that. The closed cell foam doesn't expand as much, is denser (and weighs more) but also adds quite a bit of structural strength. I ended up going with closed cell foam that is made primarily from soy beans and had an R value of like 7.5 per inch of foam. As an insulator on a house its awesome. So, to apply all this to airplane building... I don't think its entirely crazy, but I'd be especially careful. Perhaps glass up a simulated door cavity and try it out and see how you like it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166588#166588 ________________________________________________________________________________
Subject: Unusual paint ridge around windows
Date: Feb 27, 2008
I usually use one layer of about 8 oz and one layer of 4 oz on top of that. I make it wide enough to cover the joint between the plex and the frame and to extend up on the plex about 1" and back on the frame at least 2". Yes you work to make a smooth transition between the glass and the frame with micro and epoxy. If you want more detailed instructions e-mail me off line. Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Wednesday, February 27, 2008 10:16 AM Subject: RE: RV10-List: Unusual paint ridge around windows When you guys say you are overlaying glass over the seam, what are you using, what weight of weave, how many laminations? What I am wondering is once you have done this, are you building up the rest of the cabin top to match the contour which this overlay has created, or are you sanding the overlay down so much that it really is much thinner than it was when in full form? John G. 409 _____ From: Dave(at)AirCraftersLLC.com Subject: RE: RV10-List: Unusual paint ridge around windows Date: Tue, 26 Feb 2008 22:24:54 -0800 John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...quite a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did something similar around the windsheild of mine, but the overlay went on many months after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Tuesday, February 26, 2008 12:34 PM Subject: RE: RV10-List: Unusual paint ridge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ONT> size=2>Version: 7.5.516 / 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 27, 2008
GRENADE ! (sorry - couldn't help it) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Wednesday, February 27, 2008 1:56 PM Subject: RE: RV10-List: Unusual paint ridge around windows I usually use one layer of about 8 oz and one layer of 4 oz on top of that. I make it wide enough to cover the joint between the plex and the frame and to extend up on the plex about 1" and back on the frame at least 2". Yes you work to make a smooth transition between the glass and the frame with micro and epoxy. If you want more detailed instructions e-mail me off line. Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Wednesday, February 27, 2008 10:16 AM Subject: RE: RV10-List: Unusual paint ridge around windows When you guys say you are overlaying glass over the seam, what are you using, what weight of weave, how many laminations? What I am wondering is once you have done this, are you building up the rest of the cabin top to match the contour which this overlay has created, or are you sanding the overlay down so much that it really is much thinner than it was when in full form? John G. 409 _____ From: Dave(at)AirCraftersLLC.com Subject: RE: RV10-List: Unusual paint ridge around windows Date: Tue, 26 Feb 2008 22:24:54 -0800 John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...quite a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did something similar around the windsheild of mine, but the overlay went on many months after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Tuesday, February 26, 2008 12:34 PM Subject: RE: RV10-List: Unusual paint ridge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ONT> size=2>Version: 7.5.516 / 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution http://www.matronics.com/contribution ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Feb 27, 2008
I have just been using one layer of the lightest weight glass I can find (I think 1oz). I have to be careful not to sand through it. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Wednesday, February 27, 2008 10:16 AM Subject: RE: RV10-List: Unusual paint ridge around windows When you guys say you are overlaying glass over the seam, what are you using, what weight of weave, how many laminations? What I am wondering is once you have done this, are you building up the rest of the cabin top to match the contour which this overlay has created, or are you sanding the overlay down so much that it really is much thinner than it was when in full form? John G. 409 _____ From: Dave(at)AirCraftersLLC.com Subject: RE: RV10-List: Unusual paint ridge around windows Date: Tue, 26 Feb 2008 22:24:54 -0800 John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...quite a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did something similar around the windsheild of mine, but the overlay went on many months after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Tuesday, February 26, 2008 12:34 PM Subject: RE: RV10-List: Unusual paint ridge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ONT> size=2>Version: 7.5.516 / 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution "http://www.matronics.com/Navigator?RV10-List"http://www.matronics.com/Navig ator?RV10-List "http://www.matronics.com/contribution"http://www.matronics.com/contribution 8:35 AM 8:35 AM ________________________________________________________________________________
Date: Feb 27, 2008
That's pretty light material. Next time (??) try something like 7781 which is about 8 oz as Gary suggested. Two layers of that should work fine and tolerate some pretty significant body work. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Wednesday, February 27, 2008 12:48 PM Subject: RE: RV10-List: Unusual paint ridge around windows I have just been using one layer of the lightest weight glass I can find (I think 1oz). I have to be careful not to sand through it. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Wednesday, February 27, 2008 10:16 AM Subject: RE: RV10-List: Unusual paint ridge around windows When you guys say you are overlaying glass over the seam, what are you using, what weight of weave, how many laminations? What I am wondering is once you have done this, are you building up the rest of the cabin top to match the contour which this overlay has created, or are you sanding the overlay down so much that it really is much thinner than it was when in full form? John G. 409 _____ From: Dave(at)AirCraftersLLC.com Subject: RE: RV10-List: Unusual paint ridge around windows Date: Tue, 26 Feb 2008 22:24:54 -0800 John, I think you're right, there must have been a reaction. Let's see, Weld-On, base resin, plexiglass, West System, Smooth Prime, primer, and Imron...quite a few volatile chemicals all in close proximity. I would have thought the overlay would have taken care of that. I did something similar around the windsheild of mine, but the overlay went on many months after the bond was cured. Maybe that made a difference--allowing the bond to cure fully. Also, I used Hysol instead of WeldOn, just because we use it alot, not because of any other characteristics. Wish I had something better to tell you. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Tuesday, February 26, 2008 12:34 PM Subject: RE: RV10-List: Unusual paint ridge around windows Dave, The ridge is just over the Weld On seam between the plexi and fiberglass. Its as though the Weld On expanded when painted over. I used West System epoxy. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Tuesday, February 26, 2008 1:26 PM Subject: RE: RV10-List: Unusual paint ridge around windows John, The ridge looks like it's at the edge of the fiberglass. Is that right, or is the edge of the fiberglass further from the plex? What type of resin did you use to overlay the seam? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Monday, February 25, 2008 2:36 PM Subject: RV10-List: Unusual paint ridge around windows I have had an unusual situation with the door windows when painting and want to see if anyone else has seen a similar problem. After painting the doors a small ridge developed above the Plexiglas-fiberglass joint - it is about 1/4 wide and 1/16 high. The area was level and smooth after priming. I used the Weld On 10 and put a thin layer of fiberglass over the seam. I then primed with UV SmoothPrime and primed over that with the Dupont high build primer. All looked good until we painted the final color and clear coat (Imron). It seems like some kind of chemical reaction. Anyone else seen this? Any ideas? Suggestions on how to best fix and avoid this on the other windows? I have attached a few photos - a little hard to see the ridge. Thanks for you input. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting in sections and LOTS of little stuff 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ONT> size=2>Version: 7.5.516 / 2/23/2008 9:35 PM href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 2/27/2008 8:35 AM ________________________________________________________________________________
Date: Feb 27, 2008
Thanks for all the input everyone. Sometimes I get nutty ideas while I'm sitting here at work, and I need people to tell me they're nutty. Sheesh. It's not like I don't have other building tasks to work on :) I'll just build on, and forgo the foam-core-door idea. cj ________________________________________________________________________________
Subject: eggenfellner engine ordered-concerns about sole supplier
Date: Feb 28, 2008
I posted this over on VAF forums but thought I'd put it here since the readership is slightly different. I've ordered a 3.6L turbo for my rv-10. The one thing I'm having trouble with is the idea of sole supplier or possible orphan status of the engine/psru/turbo etc. I really like Jan's subaru concept and definitely not looking to bash in any way. If he should suddenly go out of business or no longer be available to provide psru's, what are the alternatives for those that have puchased this package? I understand with a lycoming/clone that there are several alternative suppliers, any thoughts or comments? Thanks, Tom Hanaway Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166747#166747 ________________________________________________________________________________
Subject: Re: eggenfellner engine ordered-concerns about sole supplier
Date: Feb 28, 2008
I fully understand your anxiety. Not bashing Jan or his company in any way, this is one of the reasons I decided not to pursue an Egg for my RV-10. This, along with education I received in assisting Dan, it became very apparent that experimenting with alternative engines required more skill and experience than I have. I chose to go a more conservative approach to go with an engine that I can get assistance from the local FBO if needed. I haven't made my final decision on vendor and probably won't until around Airventure time. The good news is that there are plenty to choose from offering very similiar products. > > From: "tomhanaway" <tomhanaway(at)comcast.net> > Date: 2008/02/28 Thu AM 11:29:48 EST > To: rv10-list(at)matronics.com > Subject: RV10-List: eggenfellner engine ordered-concerns about sole supplier > > > I posted this over on VAF forums but thought I'd put it here since the readership is slightly different. > > I've ordered a 3.6L turbo for my rv-10. The one thing I'm having trouble with is the idea of sole supplier or possible orphan status of the engine/psru/turbo etc. > > I really like Jan's subaru concept and definitely not looking to bash in any way. > > If he should suddenly go out of business or no longer be available to provide psru's, what are the alternatives for those that have puchased this package? > > I understand with a lycoming/clone that there are several alternative suppliers, any thoughts or comments? > > Thanks, > Tom Hanaway > ________________________________________________________________________________
Date: Feb 28, 2008
In a message dated 2/28/2008 10:35:54 AM Central Standard Time, tomhanaway(at)comcast.net writes: I understand with a lycoming/clone that there are several alternative suppliers, any thoughts or comments? Thanks, Tom Hanaway you put down your money and you take your chances...after all it's experimental...so you are the builder and can make any part for your aircraft... P **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Subject: engine question
Date: Feb 28, 2008
Hey all, I have been lurking on the list for a month or so, I'm interested in building a 10, and obviously have many questions. I live in FL and plan on being at Sun N' Fun to ask most of them, but the engine thread compels me to ask, with the threat of avgas disappearing sometime in the future, is anybody considering a diesel engine? Do they make a 260 hp diesel or comparable yet? I have heard a few are out there, French manufacture I believe, but know next to nothing of these Thanks in advance! Damon ps. Hey Chris, I got the Apple TV and I am very happy! Thanks for all your help! Enjoyed your website as well, nice job! ________________________________________________________________________________
Date: Feb 28, 2008
I really think one of the only concerns one would have with an experimental engine would be if you have an engine problem away from your base, it may be hard for a while to find an A&P that would want to work on it and sign your log if you were not capable of doing the work or didn't have tools, etc. **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Feb 28, 2008
Subject: Re: engine question
Those French you mention (SMAengines) wont do anything unless Van's agrees to be a distributor, aka they are not interested in selling to individuals. I know there was a few others but as far as I know none really as in production for the experimental market. I figure there are way too many engines out there for there to be a short term issue on fuel use. Welcome aboard! Make sure you find Jesse when you're at SnF, he'll be a great asset if you do. Pascal ----- Original Message ----- From: "Damon Wack" <dwack(at)flbb.net> Sent: Thursday, February 28, 2008 12:17 PM Subject: RV10-List: engine question > > Hey all, I have been lurking on the list for a month or so, I'm interested > in building a 10, and obviously have many questions. I live in FL and > plan on being at Sun N' Fun to ask most of them, but the engine thread > compels me to ask, with the threat of avgas disappearing sometime in the > future, is anybody considering a diesel engine? Do they make a 260 hp > diesel or comparable yet? I have heard a few are out there, French > manufacture I believe, but know next to nothing of these > > Thanks in advance! > > Damon > > ps. Hey Chris, I got the Apple TV and I am very happy! Thanks for all > your help! Enjoyed your website as well, nice job! > > > ________________________________________________________________________________
Date: Feb 28, 2008
If you wanted to hedge your bets, you can control the compression and either go with 235 or 250hp engine, with plenty of margin for 96 UL fuel. Heck, 260 should have no trouble with it. Only the 300 hp versions of the engine and turbo engines really need 100 octane. Avgas won't disappear, but it may lose lead and octane. On Thu, Feb 28, 2008 at 1:17 PM, Damon Wack wrote: > > Hey all, I have been lurking on the list for a month or so, I'm > interested in building a 10, and obviously have many questions. I live > in FL and plan on being at Sun N' Fun to ask most of them, but the > engine thread compels me to ask, with the threat of avgas disappearing > sometime in the future, is anybody considering a diesel engine? Do > they make a 260 hp diesel or comparable yet? I have heard a few are > out there, French manufacture I believe, but know next to nothing of > these > > Thanks in advance! > > Damon > > ps. Hey Chris, I got the Apple TV and I am very happy! Thanks for all > your help! Enjoyed your website as well, nice job! > > ________________________________________________________________________________
Subject: Handy HF Stapler (off topic)
Date: Feb 28, 2008
Just thought I'd put in a plug for the pneumatic Harbor Freight "1/2 inch Crown Stapler", number 46365. I bought one for $30 to attach Tyvek to the exterior of the sheathing around the carport I'm converting to a garage (RV-10 workshop.) It works like a champ. It does not have any safety, so it doesn't matter whether the tool is against anything - if you pull the trigger it fires a staple. So you have to be a little careful. But it has been firing 1/2 inch long staples into 1/2 inch thick OSB and fir 2x4's with no problem. To top it off, I discovered when I unloaded a bag of HF pneumatic couplers I purchased yesterday, they had included a little book of retail store coupons, with one for this tool discounted to $10 (valid 3/12 to 3/30). I'm happy to have found it for $30, but some of you may wish to take advantage of this deal. I do not work for HF, nor own any of their stock - just thought I'd pass on what appears to be a bargain. -------- Bill (and Jon) Reining 40514 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166875#166875 ________________________________________________________________________________
Date: Feb 29, 2008
Subject: Rivethead Door Guide and Pin set
I am looking for real world feedback on the door guide and pin set. Nice video but hear it doesn't fit as well once the rubber seal is installed around doors. Thanks! Pascal ________________________________________________________________________________
Subject: Final assembly
Date: Feb 29, 2008
I finally have the wings and tail on. Gary 40274 ________________________________________________________________________________
Date: Mar 01, 2008
So you and Brenda will each be bringing a RV to OSH this year? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Friday, February 29, 2008 8:06 PM Subject: RV10-List: Final assembly I finally have the wings and tail on. Gary 40274 ________________________________________________________________________________
Date: Mar 01, 2008
We don't know yet about that. I will definitely be bringing the Dolphin. Not sure yet about the RV10. Gary _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Saturday, March 01, 2008 9:15 AM Subject: RE: RV10-List: Final assembly So you and Brenda will each be bringing a RV to OSH this year? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Friday, February 29, 2008 8:06 PM Subject: RV10-List: Final assembly I finally have the wings and tail on. Gary 40274 __________ Information from ESET NOD32 Antivirus, version of virus signature database 2913 (20080301) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Mar 01, 2008
Subject: Engine Iso Mounts
Tried an engine hanging today. My boss mounts each have a roll pin in the hole that each iso mount fits over to ensure correct orientation when installing. However, my iso mounts from Van's do not have the corresponding hole for the pin to sit in. Which is right, the boss mount or the iso mount? I notice that the plans (FFWD page 4 or 5?) show the hole as empty, but we know that the pictures are not always accurate. Rob Wright #392 Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Subject: counter sinking canopy holes
Date: Mar 01, 2008
Just now installing the seat belts and I need to countersink the canopy for the large screws that hold the shoulder harness in place. I don't have, nor can I find, a large enough countersink cutter to do the job. Any suggestions? Jay Rowe ________________________________________________________________________________
Date: Mar 01, 2008
Subject: Re: Rivethead Door Guide and Pin set
certainly there must be someone who has the Rivethead aero door guide installed.. Thoughts? Thanks! Pascal ----- Original Message ----- From: Pascal To: rv10-list(at)matronics.com Sent: Friday, February 29, 2008 12:48 PM Subject: RV10-List: Rivethead Door Guide and Pin set I am looking for real world feedback on the door guide and pin set. Nice video but hear it doesn't fit as well once the rubber seal is installed around doors. Thanks! Pascal ________________________________________________________________________________
Date: Mar 02, 2008
Pascal, ours work great but the engine was just hung and the front windscreen has not been installed. Same with the prop, spinner, cowl. Not really real world feedback but the best I can do. Robin http://www.painttheweb.com/rv-10/Doors.htm ________________________________________________________________________________
Subject: Re: Engine Iso Mounts
Date: Mar 02, 2008
Take a punch and drive the pin out. Not needed on the RV-10. Jim C (N40192) =========================================================== From: Robert Wright <flywrights(at)yahoo.com> Date: 2008/03/01 Sat PM 07:12:24 EST Subject: RV10-List: Engine Iso Mounts Tried an engine hanging today. My boss mounts each have a roll pin in the hole that each iso mount fits over to ensure correct orientation when installing. However, my iso mounts from Van's do not have the corresponding hole for the pin to sit in. Which is right, the boss mount or the iso mount? I notice that the plans (FFWD page 4 or 5?) show the hole as empty, but we know that the pictures are not always accurate. Rob Wright #392 Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs =========================================================== ________________________________________________________________________________
Subject: Re: counter sinking canopy holes
Date: Mar 02, 2008
Hey John, Tool sharing?!!! What an awesome offer! Please put us on the list. Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167228#167228 ________________________________________________________________________________
Date: Mar 02, 2008
Hey Robin, Thanks for the door pictures. We just installed the hinges yesterday. Even trying to pay attention to the unique orientation, I still managed to get one set on reversed fore and aft! Here's a couple of questions: 1) It looks on one picture that you have weather stripping installed? Still fit? I had thought of temporarily attaching the weather strip with something less sticky than "Gorilla Snot" to get the fit right before final installing. Weather strip goes on after painting? 2) Did you just drill and tap the canopy hinge to attach the covers? I had thought of using the scrap fiberglass from the window cutouts instead of metal. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167231#167231 ________________________________________________________________________________
Subject: fuel pressure
Date: Mar 02, 2008
Just finished the testing of the fuel sensors , EIS 6000 calibration and the test of the boost pump. The display show only 1.2 psi but the Chelton shows 12 PSI. What PSI are we supposed to see for the Van's injection boost pump? BTW I suggest pouring some mineral spirits or Av gas through the tanks and draining through the sump before connecting to your fuel lines and boost pump. It took four flushes of the right QB tank and two flushes of the left tank before there were no contaminants showing. Otherwise the proseal fragments and other debris just collects on the screens and fuel filter. It requires two -8D caps to seal the ends of the tanks. Also when bending the wire for the floats be sure to get the piece that penetrates the float bent at a right angle. If the angle is slightly acute it can bind and cause the float to stick at empty. ________________________________________________________________________________
Date: Mar 02, 2008
Here's a little before and after I did just now while waiting for the wife to get more beautiful. I'm thinking that for sorta a lock, instead of leaving the "button" sticking out on the outside to push in to release it, I might shave it off so that it's recessed, weld a cap on it, and then you can insert any key, etc. in it to depress it. Not much, but somewhat of a deterrent -- and more aerodynamic, weather tight. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167247#167247 Attachments: http://forums.matronics.com//files/handle_984.jpg ________________________________________________________________________________
Subject: trash in the tanks
Date: Mar 02, 2008
obviously an orange bucket with three gallons of AV gas and the residue at the bottom. IIRC this was the second flush of the right QB tank. ________________________________________________________________________________
Subject: trash in the tanks correction
Date: Mar 02, 2008
-----Original Message----- From: David McNeill [mailto:dlm46007(at)cox.net] Sent: Sunday, March 02, 2008 10:11 AM Subject: trash in the tanks obviously an orange bucket with one gallon of mineral spirit and the residue at the bottom. IIRC this was the second flush of the right QB tank. AV gas works but the blue dye makes spotting the debris more difficult unless in direct sunlight. ________________________________________________________________________________
Date: Mar 02, 2008
Thanks Robin, not hearing any complaints it actually great feedback. Thanks! Pascal To be clear I know RH Aero takes months so since I am months away I know I should order them now if I want them by Christmas ;-) ----- Original Message ----- From: Robin Marks To: rv10-list(at)matronics.com Sent: Saturday, March 01, 2008 9:44 PM Subject: RE: RV10-List: Rivethead Door Guide and Pin set Pascal, ours work great but the engine was just hung and the front windscreen has not been installed. Same with the prop, spinner, cowl. Not really real world feedback but the best I can do. Robin http://www.painttheweb.com/rv-10/Doors.htm ________________________________________________________________________________
Date: Mar 02, 2008
Lew, I suggested that it be passed on from builder to builder. I think Jay is passing it to "Barry in FL. " I suggest contacting either of them, because I don't know where it's going once past Deems and Jay. Best John 40458 On Mar 2, 2008, at 6:59 AM, Lew Gallagher wrote: > > Hey John, > > Tool sharing?!!! What an awesome offer! Please put us on the list. > > Thanks, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Landing gear installed, we're mobile! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167228#167228 > > ________________________________________________________________________________
Date: Mar 03, 2008
From: "Patrick Pulis" <patrick.pulis(at)seagas.com.au>
Date: Mar 02, 2008
Subject: Jacking up the -10
Hey all, I'm trying to figure out the best way to jack up my 99% completed -10 so that I can complete the fitting of the main gear fairings. Suggestions? I've got a harbor freight nearby... Thanks, Brian 40308 Main gear fairings then inspection! ________________________________________________________________________________
Date: Mar 03, 2008
Forwarded second attempt from Patrick: Hi there John, could you please indicate the part number for the countersink available from Avery as I would like to obtain one to be sent downunder. Regarding harnesses, I have just purchased a set colour matched to my seats from Hookers, they are great, albiet a little pricey, but well worth the money. Regards Patrick Pulis #40299 VH-XPP Adelaide, South Australia "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
From: "Rick Barnes" <rickbarnes(at)highlanddental.com>
Date: Mar 03, 2008
Mike Howe and I just installed the after market Rivethead door pin guide set. We didn't receive any info on the installation from Rivethead. We used the plastic ones supplied by Van's to mark the holes in the frame. The new guides didn't line up exactly with Van's. We had to do some drilling/sanding of the guide to get the pins to fit. Once modified they seem to hold the door very tight. We don't know how the weather stripping will affect the fit. We're miles away from that part of the finishing. I hope this helped some. Rick _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Sunday, March 02, 2008 11:22 AM Subject: Re: RV10-List: Rivethead Door Guide and Pin set Thanks Robin, not hearing any complaints it actually great feedback. Thanks! Pascal To be clear I know RH Aero takes months so since I am months away I know I should order them now if I want them by Christmas ;-) ----- Original Message ----- From: Robin Marks <mailto:robin1(at)mrmoisture.com> Sent: Saturday, March 01, 2008 9:44 PM Subject: RE: RV10-List: Rivethead Door Guide and Pin set Pascal, ours work great but the engine was just hung and the front windscreen has not been installed. Same with the prop, spinner, cowl. Not really real world feedback but the best I can do. Robin http://www.painttheweb.com/rv-10/Doors.htm href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Lower Cowl Mounts
Date: Mar 03, 2008
Looking through some of the old postings, I found some discussion on replac ing the lower cowl mounts with nutplates and screws. Are these modified mou nts still holding up well during flight? Also were #10 countersunk screws a nd nut plates used? And finally what was the mounting plate made from? Thanks, Vern Smith (#324) _________________________________________________________________ Helping your favorite cause is as easy as instant messaging.-You IM, we g ive. ________________________________________________________________________________
Date: Mar 03, 2008
Lew, The only weather stripping we have is on our inner console, we used Door Seals for the doors and it took some significant modifications to the door frame to properly install the door seals. The end result is fantastic but I am sure there are better door seal choices available. Yes we drilled & tapped the hinge for 6-32 screws. There is no reason that fiberglass will not work but we chose aluminum because we could bend the edges down slightly so they will lay in the recess tightly and not flex up. Plus we plan to probably powder coat to match other items we will be powder coating. One of the mods you did not mention is the fiberglass inner door gap cover that allows the door seal to make complete contact. We believe this will make for a quieter & less drafty cockpit. http://www.painttheweb.com/rv-10/doors.htm Good luck, Robin >>>Hey Robin, Thanks for the door pictures. We just installed the hinges yesterday. Even trying to pay attention to the unique orientation, I still managed to get one set on reversed fore and aft! Here's a couple of questions: 1) It looks on one picture that you have weather stripping installed? Still fit? I had thought of temporarily attaching the weather strip with something less sticky than "Gorilla Snot" to get the fit right before final installing. Weather strip goes on after painting? 2) Did you just drill and tap the canopy hinge to attach the covers? I had thought of using the scrap fiberglass from the window cutouts instead of metal. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167231#167231 ________________________________________________________________________________
Date: Mar 03, 2008
Subject: Re: Lower Cowl Mounts
Not countersunk screws....round head screws. Yes, they're holding up great for people, and there are some now that I know personally (I'll let them speak up if they wish) who didn't install them until after they had issues with the hinges. But, there really are no problems with nutplates and screws...it's really secure. Tim Olson - RV-10 N104CD - Flying Vernon Smith wrote: > Looking through some of the old postings, I found some discussion on > replacing the lower cowl mounts with nutplates and screws. Are these > modified mounts still holding up well during flight? Also were #10 > countersunk screws and nut plates used? And finally what was the > mounting plate made from? > Thanks, > > Vern Smith (#324) > ________________________________________________________________________________
Date: Mar 03, 2008
I made mine out of .063 aluminum, I think I used #8, three per side. Rick Sked 40185 ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Monday, March 3, 2008 8:33:55 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Lower Cowl Mounts Not countersunk screws....round head screws. Yes, they're holding up great for people, and there are some now that I know personally (I'll let them speak up if they wish) who didn't install them until after they had issues with the hinges. But, there really are no problems with nutplates and screws...it's really secure. Tim Olson - RV-10 N104CD - Flying Vernon Smith wrote: > Looking through some of the old postings, I found some discussion on > replacing the lower cowl mounts with nutplates and screws. Are these > modified mounts still holding up well during flight? Also were #10 > countersunk screws and nut plates used? And finally what was the > mounting plate made from? > Thanks, > > Vern Smith (#324) > ________________________________________________________________________________
Subject: engine question (aerodiesel)
Date: Mar 03, 2008
For info on aerodiesel engines see: www.dieselair.com ERic-- RV-10, 40014 N104EP > To: rv10-list(at)matronics.com> From: dwack(at)flbb.net> Subject: RV10-List: en gine question> Date: Thu, 28 Feb 2008 15:17:55 -0500> > is anybody consider ing a diesel engine? ________________________________________________________________________________
Date: Mar 03, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Doors
Robin; Great pics and write up on the finer points of the doors. What door seal material are you using? Fred Williams 40515 ________________________________________________________________________________
Subject: Re: Jacking up the -10
Date: Mar 03, 2008
To all, Has anyone developed a good method to jack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants before mounting the wings. Jim Berry 40482 N15JB(reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167445#167445 ________________________________________________________________________________
Date: Mar 03, 2008
One of the problems i found was the way they mounted from the backside which made it difficult to mount and adjust. i made a similar part but made it screw in from the front. i fabbed a backplate with platenuts and ovaled out the holes in the doorframe to allow future adjustments. steve dinieri _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Sunday, March 02, 2008 1:22 PM Subject: Re: RV10-List: Rivethead Door Guide and Pin set Thanks Robin, not hearing any complaints it actually great feedback. Thanks! Pascal To be clear I know RH Aero takes months so since I am months away I know I should order them now if I want them by Christmas ;-) ----- Original Message ----- From: Robin <mailto:robin1(at)mrmoisture.com> Marks Sent: Saturday, March 01, 2008 9:44 PM Subject: RE: RV10-List: Rivethead Door Guide and Pin set Pascal, ours work great but the engine was just hung and the front windscreen has not been installed. Same with the prop, spinner, cowl. Not really real world feedback but the best I can do. Robin http://www.painttheweb.com/rv-10/Doors.htm href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 03, 2008
With or without the engine? If without, then using a jack/stand on the engine mount and one on the tail tie down base and then something to stable it works. With the engine, then you could possible use an engine hoist to hold up the front and a jack/stand on the tail, also with something to stabilize it. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Mar 3, 2008, at 3:20 PM, jim berry wrote: > > To all, > > Has anyone developed a good method to jack and support the completed > fuselage before the wings are attached. I want to raise the fuselage > off the wheels and fit the wheel pants before mounting the wings. > > Jim Berry > 40482 > N15JB(reserved) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167445#167445 > > ________________________________________________________________________________
Date: Mar 03, 2008
I went down to harbor freight, and they were having a sale on lift tables. I bought one, modified it a bit, and it worked like a charm. See here: http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Landing_Gear. html it was just the ticket for doing the wheelpants and gear leg fairings. I used a heavy duty saw horse under the tail, and adjusted the height so that the aircraft was level. cj www.perfectlygoodairplane.net -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim berry Sent: Monday, March 03, 2008 12:20 PM Subject: RV10-List: Re: Jacking up the -10 To all, Has anyone developed a good method to jack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants before mounting the wings. Jim Berry 40482 N15JB(reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167445#167445 ________________________________________________________________________________
Subject: baggage floor access plate for step
Date: Mar 03, 2008
I am pondering adding an access hole/plate on the baggage floor that would allow one to get at the step attach hardware. Has anyone done this? What are some thoughts on it? Pictures? -Ben ________________________________________________________________________________
Date: Mar 03, 2008
Jim,=0A Here is how I do it...=0A=0A ----- Original Message ----- =0A From: jim berry<mailto:jimberry(at)qwest.net> =0A To: r v10-list(at)matronics.com =0A Sent: M onday, March 03, 2008 12:20 PM=0A Subject: RV10-List: Re: Jacking rry" >=0A=0A To a ll,=0A=0A Has anyone developed a good method to jack and suppor t the completed fuselage before the wings are attached. I want to rais e the fuselage off the wheels and fit the wheel pants before mounting the wings.=0A=0A Jim Berry=0A 40482=0A N15JB(reserved) =0A=0A=0A=0A=0A Read this topic online here:=0A =0A http://forums.matronics.com/viewtopic.php?p=167445#167445 //forums.matronics.com/viewtopic.php?p=167445#167445>=0A=0A ======================= ======================= vigator?RV10-List<http://www.matronics.com/Navigator?RV10-List>=0A ======================= ======================= ======================= http://www.matronics.com/contribution ======================= ====================0A=0A =0A=0A ________________________________________________________________________________
Date: Mar 03, 2008
Jesse, The engine and prop are on. I thought about using my engine hoist to lift the fuselage, but am reluctant to hang all the weight from the engine mount or the engine lifting ring. cj, The link to your landing gear does not work, and I could not find the table you mentioned searching manually. Jim Berry 40482 N16JB(reserved) Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=167459#167459 ________________________________________________________________________________
Date: Mar 03, 2008
Ben, I'd show you a picture of the hole through the baggage floor, but it got covered up by the side panel. Doh. Next time I'll put a nutplate on the top of the step socket and put the bolt in from the bottom, through the belly. This is by no means overkill. We've replaced a few RV steps for one reason or another. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Monday, March 03, 2008 1:23 PM Subject: RV10-List: baggage floor access plate for step I am pondering adding an access hole/plate on the baggage floor that would allow one to get at the step attach hardware. Has anyone done this? What are some thoughts on it? Pictures? -Ben ________________________________________________________________________________
Date: Mar 03, 2008
Thats a great but TINY picture...can you descibe what the jack is pushing o n and how it's attached to the gear. Rick Sked 40185 ----- Original Message ----- From: "Roger Standley" <taildragon(at)msn.com> Sent: Monday, March 3, 2008 1:36:02 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Re: Jacking up the -10 Jim, =C2-Here is how I do it... ----- Original Message ----- From: jim berry Sent: Monday, March 03, 2008 12:20 PM Subject: RV10-List: Re: Jacking up the -10 To all, Has anyone developed a good method to jack and support the completed fusela ge before the wings are attached. I want to raise the fuselage off the whee ls and fit the wheel pants before mounting the wings. Jim Berry 40482 N15JB(reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p========== ============itle=http://www.matronics.com/Navigat or?RV10-List href="http://www.matronics.com/Navigator?RV10-List">http://w ww.matronics.com/N=================== ==<;=C2- --> ________________________________________________________________________________
Date: Mar 03, 2008
Her is how I do it...=0A=0A=0A=0A=0A ----- Original Me ssage ----- =0A From: jim berry<mailto:jimberry(at)qwest.net> =0A To: rv10-list(at)matronics.com =0A S ent: Monday, March 03, 2008 12:20 PM=0A Subject: RV10-List: Re: Ja jim berry" >=0A=0A To all,=0A=0A Has anyone developed a good method to jack and support the completed fuselage before the wings are attached. I want t o raise the fuselage off the wheels and fit the wheel pants before mou nting the wings.=0A=0A Jim Berry=0A 40482=0A N15JB(rese rved)=0A=0A=0A=0A=0A Read this topic online here: =0A=0A http://forums.matronics.com/viewtopic.php?p=167445#167445 <http://forums.matronics.com/viewtopic.php?p=167445#167445>=0A ======================= ======================= com/Navigator?RV10-List<http://www.matronics.com/Navigator?RV10-List> ======================= ======================= ======================= = --> http://www.matronics.com/contribution ======================= ======================= =0A=0A=0A=0A ________________________________________________________________________________
Date: Mar 03, 2008
when you install the wheel pants you might want to jack the fuse itself and leave the gear legs in an "in-flight position" or relaxed position to ensure alignment with the airflow. i had one already installed when i started to think about it. when i jacked the plane and refit the wheel pant there was a difference. it wasn't major, but probably enough to affect trim flight.... steve dinieri _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roger Standley Sent: Monday, March 03, 2008 4:55 PM Subject: Re: RV10-List: Re: Jacking up the -10 Her is how I do it... ----- Original Message ----- From: jim <mailto:jimberry(at)qwest.net> berry Sent: Monday, March 03, 2008 12:20 PM Subject: RV10-List: Re: Jacking up the -10 To all, Has anyone developed a good method to jack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants before mounting the wings. Jim Berry 40482 N15JB(reserved) Read this topic online here:
http://forums.matronics.com/viewt========================================== ===nbsp; <http://forums.matronics.com/viewtopic.php?p=167445#167445> - The RV10-List Email Forum -http://www.==============================================p; - MATRONICS WEB FORUMS href="http://forums.matronics.com">http://forums.matronics.================ ======nbsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/contri but======================================== ________________________________________________________________________________
Date: Mar 03, 2008
Hi Rick,=0A=0AYes, I welded a bolt at about a 45 degree angle to a cut piece of galvanized pipe, and covered it with epoxy and micro-b alloons. Wrapped the inside of the pipe with a strip of inter-tube to prevent scratching and to add friction. The bolt fits in a hole drille d in the top of the scissor jack (from Kragens). Using an electric dri ll with a "tee" makes for easy jacking.=0A=0ARoger=0A ----- Original Message ----- =0A From: Rick Sked<mailto:ricksked@embarq mail.com> =0A To: rv10-list(at)matronics.com =0A Sent: Monday, March 03, 2008 1:49 PM=0A Subject: R e: RV10-List: Re: Jacking up the -10=0A=0A=0A Thats a great but TINY picture...can you descibe what the jack is pushing on and how it's attached to the gear.=0A=0A Rick Sked=0A=0A 40185 =0A ----- Original Message -----=0A From: "Roger Standley" <ta ildragon(at)msn.com>=0A To: rv10-list@matr onics.com=0A Sent: Monday, March 3 , 2008 1:36:02 PM (GMT-0800) America/Los_Angeles=0A Subject: Re: R V10-List: Re: Jacking up the -10=0A=0A=0A=0A Jim,=0A Here is how I do it...=0A=0A ----- Original Message ----- =0A From: jim berry<mailto:jimberry(at)qwest.net> =0A To: rv1 0-list(at)matronics.com =0A Sent: M onday, March 03, 2008 12:20 PM=0A Subject: RV10-List: Re: Jackin m berry" >=0A=0A To all,=0A=0A Has anyone developed a good method to jack an d support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants before m ounting the wings.=0A=0A Jim Berry=0A 40482=0A N1 5JB(reserved)=0A=0A=0A=0A=0A Read this topic online here:=0A=0A http://forums.matronics.com/viewtopic.php?p== ====================itle=htt p://www.matronics.com/Navigator?RV10-List href="http://www.matronics com/Navigator?RV10-List">http://www.matronics.com/N====== ======================= =================<; --> <http://for ums.matronics.com/viewtopicphp?p=167445#167445>=0A=0A=0A =0A <http://md01.embarq.synacor.com/zimbra/======== ======================= ======================= /www.matronics.com/Navigator?RV10-List<http://www.matronics.com/Naviga ======================= ======================0A_ ======================= ======================= http://www.matronics.com/contribution ======================= ====================0A=0A ________________________________________________________________________________
Date: Mar 03, 2008
Oops. The link wrapped to the next page. Try this www.perfectlygoodairplane.net/Perfectlygoodairplane/Landing_Gear.html if it wrapped to the next line again, just make sure the .html is on there or go to the finishing section, and select "landing gear" cj -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim berry Sent: Monday, March 03, 2008 1:39 PM Subject: RV10-List: Re: Jacking up the -10 Jesse, The engine and prop are on. I thought about using my engine hoist to lift the fuselage, but am reluctant to hang all the weight from the engine mount or the engine lifting ring. cj, The link to your landing gear does not work, and I could not find the table you mentioned searching manually. Jim Berry 40482 N16JB(reserved) Read this topic online here:
Date: Mar 03, 2008
Rick, here is another pic of the "gear grabber. After cutting the pipe , open it up to allow it to slide over the gear near the wheel but tig hten against the gear leg as it is raised toward the fuselage.=0A =0A=0A=0A ----- Original Message ----- =0A From: Roger S tandley =0A To: rv10-list(at)matronics.com =0A Sent: Monday, March 03, 2008 2:15 PM=0A Subject: Re: RV10-List: Re: Jacking up the -10=0A =0A=0A =EF=BB =0A Hi Rick,=0A=0A Yes, I welded a bol t at about a 45 degree angle to a cut piece of galvanized pipe, and co vered it with epoxy and micro-balloons. Wrapped the inside of the pipe with a strip of inter-tube to prevent scratching and to add friction. The bolt fits in a hole drilled in the top of the scissor jack (from Kragens). Using an electric drill with a "tee" makes for easy jacking =0A=0A Roger=0A ----- Original Message ----- =0A F rom: Rick Sked =0A To: rv10-list (at)matronics.com =0A Sent: Monday, March 03, 2008 1:49 PM=0A Subject: Re: RV10-List: Re: Jacking u p the -10=0A=0A=0A Thats a great but TINY picture...can yo u descibe what the jack is pushing on and how it's attached to the gea r.=0A=0A Rick Sked=0A=0A 40185=0A ----- Origin al Message -----=0A From: "Roger Standley" <taildragon(at)msn.com<m ailto:taildragon(at)msn.com>>=0A To: rv10-list(at)matronics.com=0A Sent: Monday, March 3, 2008 1:36:02 PM (GMT-0800) America/Los_Angeles=0A Subject: Re: RV10-List: Re : Jacking up the -10=0A=0A=0A=0A Jim,=0A Here is how I do it...=0A=0A ----- Original Message ----- =0A From: jim berry<mailto:jimberry(at)qwest.net> =0A To: rv10-li st(at)matronics.com =0A Sent: Mon day, March 03, 2008 12:20 PM=0A Subject: RV10-List: Re: Jackin jim berry" >=0A=0A To all,=0A=0A Has anyone developed a good method to j ack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants be fore mounting the wings.=0A=0A Jim Berry=0A 40482 =0A N15JB(reserved)=0A=0A=0A=0A=0A Read th is topic online here:=0A=0A http://forums.matronics.com/vie wtopic.php?p=================== ===itle=http://www.matronics.com/Navigator?RV10-List href="h ttp://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/ N======================= =======================< ; --> <http://forums.matronics.com/viewtopicphp?p=167445#167445> =0A=0A=0A=0A <http://md01.embarq.synacor.com/zimbra/== ===================p; > ======================= ======================0A_ ======================= ======================= = --> http://forums.matronics.com> ======================= ======================= ======================= =====0A=0A ________________________________________________________________________________
Subject: Traveling counter sink
Date: Mar 03, 2008
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Y'all should include a traveling signature sheet with that traveling shared counter sink tool for the cabin roof. Each person can sign the sheet and stick a photo of them and/or their fuselage in the envelope before sending it on to the next person. By Oshkosh 2009, it might be an interesting collection of names and places! TDT 40025 Wheel Fairings done! Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Mar 03, 2008
Subject: Re: baggage floor access plate for step
I used the parts for the stall warning horn access panel. I had to drill the bolt hole in the steps from the side, however, to be able to get the bolt in because of how I oriented the access panel. If you rotate it to the right about 30 degrees or so, I believe you can still put the bolt in per the plans. PJ Seipel RV-10 #40032 Ben Westfall wrote: > > I am pondering adding an access hole/plate on the baggage floor that > would allow one to get at the step attach hardware. Has anyone done > this? What are some thoughts on it? Pictures? > > > > -Ben > > > > * > > > * ________________________________________________________________________________
Date: Mar 03, 2008
Sorry, forgot the picture. PJ Seipel PJ Seipel wrote: > I used the parts for the stall warning horn access panel. I had to > drill the bolt hole in the steps from the side, however, to be able to > get the bolt in because of how I oriented the access panel. If you > rotate it to the right about 30 degrees or so, I believe you can still > put the bolt in per the plans. > > PJ Seipel > RV-10 #40032 > > > Ben Westfall wrote: >> >> I am pondering adding an access hole/plate on the baggage floor that >> would allow one to get at the step attach hardware. Has anyone done >> this? What are some thoughts on it? Pictures? >> >> >> >> -Ben >> >> >> >> * >> >> >> * > ________________________________________________________________________________
Date: Mar 03, 2008
Hi Steve,=0A=0AYou are right. When we did the wheel pants, we le t the gear "sag", but it didn't sag much. We braced from the spar carr y-thru and fitted the wheel pants.=0A=0A=0A ----- Original M essage ----- =0A From: Steven DiNieri<mailto:capsteve(at)adelphia.net > =0A To: rv10-list(at)matronics.com =0A Sent: Monday, March 03, 2008 2:11 PM=0A Subject: RE: RV10- List: Re: Jacking up the -10=0A=0A=0A when you install the w heel pants you might want to jack the fuse itself and leave the gear l egs in an "in-flight position" or relaxed position to ensure alignment with the airflow. i had one already installed when i started to think about it. when i jacked the plane and refit the wheel pant there was a difference. it wasn't major, but probably enough to affect trim flig ht.... =0A steve dinieri=0A=0A=0A=0A------------------ ----------------------------------------------------------=0A Fr om: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-serve r(at)matronics.com] On Behalf Of Roger Standley=0A Sent: Monday, Ma rch 03, 2008 4:55 PM=0A To: rv10-list(at)matronics.com=0A Sub ject: Re: RV10-List: Re: Jacking up the -10=0A=0A=0A Her i s how I do it...=0A=0A=0A=0A=0A ----- Original Mes sage ----- =0A From: jim berry<mailto:jimberry(at)qwest.net> =0A To: rv10-list(at)matronics.com =0A Sent: Monday, March 03, 2008 12:20 PM=0A Subject: RV10-List: Re: Jacking up the -10=0A=0A=0A --> RV10-List message posted by: "jim berry" >=0A=0A To all,=0A=0A Has anyone develop ed a good method to jack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and f it the wheel pants before mounting the wings.=0A=0A Jim Ber ry=0A 40482=0A N15JB(reserved)=0A=0A=0A=0A =0A Read this topic online here:=0A=0A
http://forum s.matronics.com/viewt================ =====nbsp; - The RV10-List Email Forum -http://www.= ====================p; - MATRONICS WEB FORUMS href="http://forums.matronics.com">http://foru ms.matronics.=================== ====nbsp; title=http://www matronics.com/contribution href="http://www.matronics.com/contribut ion">http://www.matronics.com/contribut========== ======================= =========0A=0A=0A=0A=0A<http://forums.m atronics.com/viewtopic.php?p=167445#167445> ________________________________________________________________________________
Date: Mar 03, 2008
Actually, I think that's the Per-plans way...you're supposed to let the gear hang and align the fairings while they're in the in-flight hanging position. Tim Steven DiNieri wrote: > when you install the wheel pants you might want to jack the fuse itself > and leave the gear legs in an "in-flight position" or relaxed position > to ensure alignment with the airflow. i had one already installed when i > started to think about it. when i jacked the plane and refit the wheel > pant there was a difference. it wasn't major, but probably enough to > affect trim flight.... > steve dinieri > ________________________________________________________________________________
Date: Mar 03, 2008
seipel(at)seznam.cz wrote: > I used the parts for the stall warning horn access panel.PJ Seipel > RV-10 #40032 I did a similar thing but probably would do it differently next time (there had better never be a next time) [Laughing] I mounted my covers close enough that you can pull the bolt straight out or put it in. After I did all of this, I realized that the side panels will cover half of the plates. So the side panels will not be riveted in place until the very end. If I have to ever remove/replace the steps, it will be about a half dozen pop rivets that will have to be drilled out and then the places will be able to be unscrewed giving access to the step mounting bolts. I have some early pictures at http://www.wingscc.com/N410GB/30-StepInstal/30-StepInstallation.html I am so far behind at keeping my pictures up to date and I don't have any of the later ones on the web yet. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167492#167492 ________________________________________________________________________________
Date: Mar 03, 2008
Can someone point me to some photos. This is a modification I would like to make. I've already lost 2 eyelets. Scott Schmidt scottmschmidt(at)yahoo.com On Mar 3, 2008, at 12:30 PM, Rick Sked wrote: I made mine out of .063 aluminum, I think I used #8, three per side. Rick Sked 40185 ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Monday, March 3, 2008 8:33:55 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Lower Cowl Mounts Not countersunk screws....round head screws. Yes, they're holding up great for people, and there are some now that I know personally (I'll let them speak up if they wish) who didn't install them until after they had issues with the hinges. But, there really are no problems with nutplates and screws...it's really secure. Tim Olson - RV-10 N104CD - Flying Vernon Smith wrote: Looking through some of the old postings, I found some discussion on replacing the lower cowl mounts with nutplates and screws. Are these modified mounts still holding up well during flight? Also were #10 countersunk screws and nut plates used? And finally what was the mounting plate made from? Thanks, Vern Smith (#324) ________________________________________________________________________________
Date: Mar 03, 2008
Two or three pallets with the top one covered with a carpet scrap. Then use various shims to ensure level across the fuselage. That ws my method and it seemed fine, especially after dropping many plumb lines and square lines on the floor to cross-check in-plane. Rob Wright #392 looking at a LOT of sanding when I do the body prep for the door-canopy prep. Just didn't seem to cure flush even after many many clamps held it correctly. But I DID hang then engine today! ----- Original Message ---- From: jim berry <jimberry(at)qwest.net> Sent: Monday, March 3, 2008 3:20:21 PM Subject: RV10-List: Re: Jacking up the -10 To all, Has anyone developed a good method to jack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants before mounting the wings. Jim Berry 40482 N15JB(reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167445#167445 Looking for last minute shopping deals? ________________________________________________________________________________
Date: Mar 03, 2008
Hi Scott, This will show you some photos. Here's a page with some photos towards the bottom: http://www.myrv10.com/N104CD/finishing/20050911/index.html Here are a couple other ones for you too: http://www.myrv10.com/N104CD/finishing/20050918/index.html http://www.myrv10.com/N104CD/finishing/20050911/RV200509110038.html http://www.myrv10.com/N104CD/finishing/20050918/RV200509120004.html I used some heavier stock when I did mine, and I put a plate on the fuselage side, and then another plate on the cowl side that is "permanent" to give the cowl more backing. Not sure the thickness anymore, but maybe .063 like Rick said. It seems it was about the same as the thickness of the panel material. Tim Olson - RV-10 N104CD - Flying Scott Schmidt wrote: > > Can someone point me to some photos. This is a modification I would like to make. I've already lost 2 eyelets. > > Scott Schmidt > scottmschmidt(at)yahoo.com > > On Mar 3, 2008, at 12:30 PM, Rick Sked wrote: > > > I made mine out of .063 aluminum, I think I used #8, three per side. > > Rick Sked > 40185 ________________________________________________________________________________
Date: Mar 03, 2008
Very cool, I was looking for a way to jack mine easily from the gear, I hav e mine on Harbor Freight dollys and I can see using them once flying to get the most from our hangar space=C2-(Bob Kauffman and I) we have 3500 SF a nd rent out what we don't need. The dollys allow us to move the aircraft ea sily into the corners...we inconvience ourselves but not our tenants...look s like an aerolift may be on the way. Hangar space at North Las Vegas is sp arce...we are lucky to own the facility we have. Once the fly off is done a nd the fairings are on for good I'll have to jack from the wing tie down to put it on the dollys...small price to pay for "free" hangar space. Rick Sked 40185 ----- Original Message ----- From: "Roger Standley" <taildragon(at)msn.com> Sent: Monday, March 3, 2008 2:15:26 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Re: Jacking up the -10 =EF=BB Hi Rick, Yes, I welded a bolt at about a 45 degree angle to a cut piece of galvanize d pipe, and covered it with epoxy and micro-balloons. Wrapped the inside of the pipe with a strip of inter-tube to prevent scratching and to add frict ion. The bolt fits in a hole drilled in the top of the scissor jack (from K ragens). Using an electric drill with a "tee"=C2- makes for easy jacking. Roger ----- Original Message ----- From: Rick Sked Sent: Monday, March 03, 2008 1:49 PM Subject: Re: RV10-List: Re: Jacking up the -10 Thats a great but TINY picture...can you descibe what the jack is pushing o n and how it's attached to the gear. Rick Sked 40185 ----- Original Message ----- From: "Roger Standley" < taildragon(at)msn.com > Sent: Monday, March 3, 2008 1:36:02 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Re: Jacking up the -10 Jim, =C2-Here is how I do it... ----- Original Message ----- From: jim berry Sent: Monday, March 03, 2008 12:20 PM Subject: RV10-List: Re: Jacking up the -10 To all, Has anyone developed a good method to jack and support the completed fusela ge before the wings are attached. I want to raise the fuselage off the whee ls and fit the wheel pants before mounting the wings. Jim Berry 40482 N15JB(reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p========== ============itle=http://www.matronics.com/Navigat or?RV10-List href="http://www.matronics.com/Navigator?RV10-List">http://w ww.matronics.com/N=================== ==<;=C2- --> http://w====================== ====================f="http://www .matronics.com/contribution">http://www.matronics.com/c====== ======================== ==== ======================= == ________________________________________________________________________________
Date: Mar 03, 2008
Ben, I think it's an excellent idea especially when working around the plane during construction. Think of it as Shin Insurance because you will whack yourself and it can hurt. Then you will hit your already tender shin in the exact same place and it will hurt even more. We powder coated our steps a smoke chrome and I wanted it to be removable in case the PC didn't hold up. Additionally mine are removal for the Reno Air Races. Watch out Bearcat! Robin Photos Attached ________________________________________________________________________________
Date: Mar 03, 2008
Scott here's a link to 2 photos (click next to see the 2nd) http://deemsrv10.com/album/Sec%2047%20Spinner%20and%20Cowling/slides/DSC04175.html I've since trimmed the inside portion of the 'flange' so that it doesn't stick out and interfere with the air exiting the lower cowl. (A John Cox suggestion) Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Scott Schmidt wrote: > > Can someone point me to some photos. This is a modification I would like to make. I've already lost 2 eyelets. > > Scott Schmidt > scottmschmidt(at)yahoo.com > > On Mar 3, 2008, at 12:30 PM, Rick Sked wrote: > > > I made mine out of .063 aluminum, I think I used #8, three per side. > > Rick Sked > 40185 > ----- Original Message ----- > From: "Tim Olson" <Tim(at)MyRV10.com> > To: rv10-list(at)matronics.com > Sent: Monday, March 3, 2008 8:33:55 AM (GMT-0800) America/Los_Angeles > Subject: Re: RV10-List: Lower Cowl Mounts > > > Not countersunk screws....round head screws. Yes, > they're holding up great for people, and there are > some now that I know personally (I'll let them speak up > if they wish) who didn't install them until after they > had issues with the hinges. But, there really are > no problems with nutplates and screws...it's really > secure. > > > Tim Olson - RV-10 N104CD - Flying > > > Vernon Smith wrote: > Looking through some of the old postings, I found some discussion on > replacing the lower cowl mounts with nutplates and screws. Are these > modified mounts still holding up well during flight? Also were #10 > countersunk screws and nut plates used? And finally what was the > mounting plate made from? > Thanks, > > Vern Smith (#324) > > > ________________________________________________________________________________
Date: Mar 03, 2008
That looks pretty good but how are you going to get the bolt out? Is there room if you move the access panel all the way next to the wall panel to lift the bolt up? -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Monday, March 03, 2008 4:27 PM Subject: RE: RV10-List: baggage floor access plate for step Ben, I think it's an excellent idea especially when working around the plane during construction. Think of it as Shin Insurance because you will whack yourself and it can hurt. Then you will hit your already tender shin in the exact same place and it will hurt even more. We powder coated our steps a smoke chrome and I wanted it to be removable in case the PC didn't hold up. Additionally mine are removal for the Reno Air Races. Watch out Bearcat! Robin Photos Attached ________________________________________________________________________________
Date: Mar 03, 2008
Hey John, Jay, Barry, etc. Nick has contacted me about who's next! Let's use this thread to determine where it's going and to get it back to John eventually. If it's: 1) Jay, 2) Barry, 3) Lew 4) Nick use this to get contact info and send it to the next in line. And others can add their name and number to the list here. Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167550#167550 ________________________________________________________________________________
Date: Mar 03, 2008
hi deems, did you use a shim under the plate to space out for the thickness of the cowl?? Steven dinieri > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Monday, March 03, 2008 7:46 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Lower Cowl Mounts > > > Scott here's a link to 2 photos (click next to see the 2nd) > http://deemsrv10.com/album/Sec%2047%20Spinner%20and%20Cowling/ slides/DSC04175.html > I've since trimmed the inside portion of the 'flange' so that > it doesn't stick out and interfere with the air exiting the > lower cowl. (A John Cox > suggestion) > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > Scott Schmidt wrote: > > --> > > > > Can someone point me to some photos. This is a modification > I would like to make. I've already lost 2 eyelets. > > > > Scott Schmidt > > scottmschmidt(at)yahoo.com > > > > On Mar 3, 2008, at 12:30 PM, Rick Sked > wrote: > > > > > > I made mine out of .063 aluminum, I think I used #8, three per side. > > > > Rick Sked > > 40185 > > ----- Original Message ----- > > From: "Tim Olson" <Tim(at)MyRV10.com> > > To: rv10-list(at)matronics.com > > Sent: Monday, March 3, 2008 8:33:55 AM (GMT-0800) > America/Los_Angeles > > Subject: Re: RV10-List: Lower Cowl Mounts > > > > > > Not countersunk screws....round head screws. Yes, they're > holding up > > great for people, and there are some now that I know > personally (I'll > > let them speak up if they wish) who didn't install them until after > > they had issues with the hinges. But, there really are no problems > > with nutplates and screws...it's really secure. > > > > > > Tim Olson - RV-10 N104CD - Flying > > > > > > > > Vernon Smith wrote: > > Looking through some of the old postings, I found some > discussion on > > replacing the lower cowl mounts with nutplates and screws. > Are these > > modified mounts still holding up well during flight? Also were #10 > > countersunk screws and nut plates used? And finally what was the > > mounting plate made from? > > Thanks, > > > > Vern Smith (#324) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Photoshare, and much much more: > > > ________________________________________________________________________________
Date: Mar 03, 2008
Hey Robin, Thanks for the reply. By "weather strip" I meant the door seal provided by Vans ... did you final install before you're going to paint? Did you shave off door/canopy fiberglass to make the door seal fit right? I do like the cover plates you added so the door seal will continue uninterrupted at the top of the doors -- doesn't that make for some creative nut installation? I've looked more closely at the canopy hinges on ours, and it appears that the hinges are barely flush with the canopy top (maybe even stick up a bit) -- so that it doesn't look possible to recess and fit a plate on top of it. Maybe it's just our canopy (pink), or did you build it up around the hinges? Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Landing gear installed, we're mobile! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167556#167556 ________________________________________________________________________________
Date: Mar 03, 2008
Just a thought but Cessna on occasion drilled a bolt insertion hole directly over the bolt and had an circular access panel below or adjacent to the bolt for hand access to tighten or loosen the bolt. the bolt insertion hole was covered with a chrome cap. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Monday, March 03, 2008 6:28 PM Subject: RE: RV10-List: baggage floor access plate for step That looks pretty good but how are you going to get the bolt out? Is there room if you move the access panel all the way next to the wall panel to lift the bolt up? -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Monday, March 03, 2008 4:27 PM Subject: RE: RV10-List: baggage floor access plate for step Ben, I think it's an excellent idea especially when working around the plane during construction. Think of it as Shin Insurance because you will whack yourself and it can hurt. Then you will hit your already tender shin in the exact same place and it will hurt even more. We powder coated our steps a smoke chrome and I wanted it to be removable in case the PC didn't hold up. Additionally mine are removal for the Reno Air Races. Watch out Bearcat! Robin Photos Attached ________________________________________________________________________________
Date: Mar 03, 2008
I didn't use a shim. In my case I didn't need one. I have a Will James cowl, I believe the construction is different from the Van's cowl and most likely the dimensions also. btw, I'm using countersunk screws with ss countersunk washers. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Steven DiNieri wrote: > > hi deems, > did you use a shim under the plate to space out for the thickness of the > cowl?? > Steven dinieri > > >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis >> Sent: Monday, March 03, 2008 7:46 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Lower Cowl Mounts >> >> >> Scott here's a link to 2 photos (click next to see the 2nd) >> http://deemsrv10.com/album/Sec%2047%20Spinner%20and%20Cowling/ >> > slides/DSC04175.html > >> I've since trimmed the inside portion of the 'flange' so that >> it doesn't stick out and interfere with the air exiting the >> lower cowl. (A John Cox >> suggestion) >> >> Deems Davis # 406 >> 'Its all done....Its just not put together' >> http://deemsrv10.com/ >> >> Scott Schmidt wrote: >> >>> --> >>> >>> Can someone point me to some photos. This is a modification >>> >> I would like to make. I've already lost 2 eyelets. >> >>> Scott Schmidt >>> scottmschmidt(at)yahoo.com >>> >>> On Mar 3, 2008, at 12:30 PM, Rick Sked >>> >> wrote: >> >>> >>> I made mine out of .063 aluminum, I think I used #8, three per side. >>> >>> Rick Sked >>> 40185 >>> ----- Original Message ----- >>> From: "Tim Olson" <Tim(at)MyRV10.com> >>> To: rv10-list(at)matronics.com >>> Sent: Monday, March 3, 2008 8:33:55 AM (GMT-0800) >>> >> America/Los_Angeles >> >>> Subject: Re: RV10-List: Lower Cowl Mounts >>> >>> >>> Not countersunk screws....round head screws. Yes, they're >>> >> holding up >> >>> great for people, and there are some now that I know >>> >> personally (I'll >> >>> let them speak up if they wish) who didn't install them until after >>> they had issues with the hinges. But, there really are no problems >>> with nutplates and screws...it's really secure. >>> >>> >>> Tim Olson - RV-10 N104CD - Flying >>> >>> >>> >>> Vernon Smith wrote: >>> Looking through some of the old postings, I found some >>> >> discussion on >> >>> replacing the lower cowl mounts with nutplates and screws. >>> >> Are these >> >>> modified mounts still holding up well during flight? Also were #10 >>> countersunk screws and nut plates used? And finally what was the >>> mounting plate made from? >>> Thanks, >>> >>> Vern Smith (#324) >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> Photoshare, and much much more: >> >> >> >> > > > ________________________________________________________________________________
Subject: lessons learned installing plexiglas with Weld-on 10
Date: Mar 03, 2008
We just finished building our windscreen faring so now its on to bigger and better things like "trimming out" the final finish of the doors, windows and windscreen. The gluing of the door windows was easy. The first one we did on the bench per the directions except we applied freshly mixed glue to both the plexi and the fiberglass ledge. A few days later we installed the door to the cabin and then: AHH!! We found 3 small cracks on the edge where one of the clamps held the plexi tight against the fiberglass ledge. We stop drilled the cracks and changed technique for the second door/window installation. The door was installed on the cabin complete with hinges and latches and trimmed to give a good flush fit. We used four nylon straps around the entire fuselage and cabin with wooden blocks to apply pressure at the window edges. This pressure was left in place for about 22 hours and the results were great with NO cracks. We then did both rear cabin windows together using the four strap method of holding them in place and when we removed the straps and blocks we were saddened by the discovery of dozens of small "feathery" cracks at the pressure points. We thought of starting over with the rear windows but e-mailed Van's and when Scott said that other builders reported these cracks (Van's RV-10 with 1100 hours has them) but there have been ZERO failures, we decided to stress the cracks to see if we could get them to "run" into the center of the window. We applied heat to get the temperature of the window bond up to where the Summer Colorado sun might cause it to rise. Then we applied an ice pack to get the temperature down to where the lower flight levels might cause it to fall. An amazing result - the cracks disappeared. I don't mean that they went away - I mean they were VERY difficult (in some cases, impossible) to see. We did the windscreen with a combination of clamps on the sides and a strap around the cabin to give us holding pressure across the top. We got several small cracks at the pres! sure poi nts of the clamps - none at the strap. Our final conclusion is that the cracks are caused by high clamping pressure over time and the best way to avoid them when using Weld-on 10 is to remove your clamps (or straps) after just a few hours, maybe three of four, and keep the pressure down to no more than is needed to keep the plexi flush with the cabin. We heated all our weld-on 10 bonds to stress relieve them. Paul Hahn #40203 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167577#167577 ________________________________________________________________________________
Date: Mar 04, 2008
Subject: Re: Sun N Fun
Well the cuts on my hand will be healed by then...from cutting out my old t rim system and instaling yours..BTW...it works great and is VERY easy to in stall...from the git go...not really bad after I had my own installed...rea lly neat product.. Rick Sked 40185 ----- Original Message ----- From: "Bob-tcw" <rnewman(at)tcwtech.com> Sent: Monday, March 3, 2008 6:24:16 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Sun N Fun =EF=BB I'll be at Sun-n-Fun all week.=C2-=C2- TCW Technologies has an outdoor booth at spot N-96 this year.=C2- We'll have a Safety-Trim Tent set up wi th demo units and with just a little bit of luck a new product announcement !=C2- I look forward to meeting=C2- the many builders who have become Safety-Tr im customers. Best regards, Bob Newman RV-10 40176 TCW Technologies www.tcwtech.com ----- Original Message ----- From: Rick Sked Sent: Monday, March 03, 2008 7:29 PM Subject: RV10-List: Sun N Fun What's the head count for Sun N Fun? I'll be there noon on the 8th, leaving Early Friday the 11th. Via commercial airlines. I'm staying at the Marriot Village in Orlando, about a 45 minute drive but nice if you have family (I don't) that can play at the parks while you go to the show. I really liked it last year...pretty laid back and well...fun. =C2- Rick Sked 40185 do not archive href="http://www.matronics.com/Navigator?RV10-List">http://ww w.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">ht tp://forums.matronics.com href="http://www.matronics.com/contribution">ht ================== ==== ======================= == ________________________________________________________________________________
Date: Mar 04, 2008
I didn't need a shim on the bottom, only the sides. Where you have to make up for the curve of the fuselage sides. Rick Sked 40185 ----- Original Message ----- From: "Steven DiNieri" <capsteve(at)adelphia.net> Sent: Monday, March 3, 2008 7:30:05 PM (GMT-0800) America/Los_Angeles Subject: RE: RV10-List: Lower Cowl Mounts hi deems, did you use a shim under the plate to space out for the thickness of the cowl?? Steven dinieri > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Monday, March 03, 2008 7:46 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Lower Cowl Mounts > > > Scott here's a link to 2 photos (click next to see the 2nd) > http://deemsrv10.com/album/Sec%2047%20Spinner%20and%20Cowling/ slides/DSC04175.html > I've since trimmed the inside portion of the 'flange' so that > it doesn't stick out and interfere with the air exiting the > lower cowl. (A John Cox > suggestion) > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > Scott Schmidt wrote: > > --> > > > > Can someone point me to some photos. This is a modification > I would like to make. I've already lost 2 eyelets. > > > > Scott Schmidt > > scottmschmidt(at)yahoo.com > > > > On Mar 3, 2008, at 12:30 PM, Rick Sked > wrote: > > > > > > I made mine out of .063 aluminum, I think I used #8, three per side. > > > > Rick Sked > > 40185 > > ----- Original Message ----- > > From: "Tim Olson" <Tim(at)MyRV10.com> > > To: rv10-list(at)matronics.com > > Sent: Monday, March 3, 2008 8:33:55 AM (GMT-0800) > America/Los_Angeles > > Subject: Re: RV10-List: Lower Cowl Mounts > > > > > > Not countersunk screws....round head screws. Yes, they're > holding up > > great for people, and there are some now that I know > personally (I'll > > let them speak up if they wish) who didn't install them until after > > they had issues with the hinges. But, there really are no problems > > with nutplates and screws...it's really secure. > > > > > > Tim Olson - RV-10 N104CD - Flying > > > > > > > > Vernon Smith wrote: > > Looking through some of the old postings, I found some > discussion on > > replacing the lower cowl mounts with nutplates and screws. > Are these > > modified mounts still holding up well during flight? Also were #10 > > countersunk screws and nut plates used? And finally what was the > > mounting plate made from? > > Thanks, > > > > Vern Smith (#324) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Photoshare, and much much more: > > > ________________________________________________________________________________
Date: Mar 04, 2008
Bingo! Ben. Lew, sorry I am on the road and have too many moving parts these days to reply quickly. There is a =BD" hole drilled directly above the bolt (no pictured). That hole is normally plugged with a plastic panel plug and then the entire area covered with carpet. Regarding the door seal we used a seal sold by McMaster Carr not the vans seal. Sorry I don't have the style number. (Photo attached) Regarding the nut installation for the door, it's not that difficult to remove and I hope the doors will not have to be taken off many more times. At least not till the first flight J We cleaned up under the hinge a bit but ours do sit pretty flush. The metal is bent a bit down into the recess we made for the cover. There are a number of different ways to do this including living with a small bump at each hinge point. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Monday, March 03, 2008 7:50 PM Subject: RE: RV10-List: baggage floor access plate for step Just a thought but Cessna on occasion drilled a bolt insertion hole directly over the bolt and had an circular access panel below or adjacent to the bolt for hand access to tighten or loosen the bolt. the bolt insertion hole was covered with a chrome cap. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Monday, March 03, 2008 6:28 PM Subject: RE: RV10-List: baggage floor access plate for step That looks pretty good but how are you going to get the bolt out? Is there room if you move the access panel all the way next to the wall panel to lift the bolt up? -Ben ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Monday, March 03, 2008 4:27 PM Subject: RE: RV10-List: baggage floor access plate for step Ben, I think it's an excellent idea especially when working around the plane during construction. Think of it as Shin Insurance because you will whack yourself and it can hurt. Then you will hit your already tender shin in the exact same place and it will hurt even more. We powder coated our steps a smoke chrome and I wanted it to be removable in case the PC didn't hold up. Additionally mine are removal for the Reno Air Races. Watch out Bearcat! Robin Photos Attached href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Mar 04, 2008
I purchased 2 extra of the stall warning access panels rom Vans. I installed these in the floor inboard of the step bolts for hand access. I drilled a hole in the lower skin large enough to just clear the bolt head and stuck in a hole plug. It works great, but I like the idea of redrilling the hole horizontal and not having the hole in the bottom skin... -Mike Kraus RV-4 Flying RV-10 FWF and wiring -----Original Message----- From: "Robin Marks" <robin1(at)mrmoisture.com> Sent: 03/04/08 2:41 AM Subject: RE: RV10-List: baggage floor access plate for step Bingo! Ben. Lew, sorry I am on the road and have too many moving parts these days to reply quickly. There is a " hole drilled directly above the bolt (no pictured). That hole is normally plugged with a plastic panel plug and then the entire area covered with carpet. Regarding the door seal we used a seal sold by McMaster Carr not the ________________________________________________________________________________
Subject: Re: counter sinking canopy holes
From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
Date: Mar 04, 2008
Please add me to the list for the counter sink. Eric Gohr 40271 - finishing, Fiberglass wonderland. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167625#167625 ________________________________________________________________________________
Date: Mar 04, 2008
You mention Colorado. How warm was the shop while instailing these windows? John G. 409> Subject: RV10-List: lessons learned installing plexiglas with Weld-on 10> From: eagerlee(at)comcast.net> Date: Mon, 3 Mar 2008 21:08:35 -080 e" > > We just finished building our windscreen farin g so now its on to bigger and better things like "trimming out" the final f inish of the doors, windows and windscreen. The gluing of the door windows was easy. The first one we did on the bench per the directions except we ap plied freshly mixed glue to both the plexi and the fiberglass ledge. A few days later we installed the door to the cabin and then: AHH!! We found 3 sm all cracks on the edge where one of the clamps held the plexi tight against the fiberglass ledge. We stop drilled the cracks and changed technique for the second door/window installation. The door was installed on the cabin c omplete with hinges and latches and trimmed to give a good flush fit. We us ed four nylon straps around the entire fuselage and cabin with wooden block s to apply pressure at the window edges. This pressure was left in place fo r about 22 hours and the results were great with NO cracks. We then did bot h rear cabin windows together using !> the four strap method of holding the m in place and when we removed the straps and blocks we were saddened by th e discovery of dozens of small "feathery" cracks at the pressure points. We thought of starting over with the rear windows but e-mailed Van's and when Scott said that other builders reported these cracks (Van's RV-10 with 110 0 hours has them) but there have been ZERO failures, we decided to stress t he cracks to see if we could get them to "run" into the center of the windo w. We applied heat to get the temperature of the window bond up to where th e Summer Colorado sun might cause it to rise. Then we applied an ice pack t o get the temperature down to where the lower flight levels might cause it to fall. An amazing result - the cracks disappeared. I don't mean that they went away - I mean they were VERY difficult (in some cases, impossible) to see. We did the windscreen with a combination of clamps on the sides and a strap around the cabin to give us holding pre!> ssure across the top. We g ot several small cracks at the pres!> sure poi> > nts of the clamps - none at the strap. Our final conclusion is that the cracks are caused by high cl amping pressure over time and the best way to avoid them when using Weld-on 10 is to remove your clamps (or straps) after just a few hours, maybe thre e of four, and keep the pressure down to no more than is needed to keep the plexi flush with the cabin. We heated all our weld-on 10 bonds to stress r elieve them.> > Paul Hahn> #40203> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.php?p=167577#167577> > > > > > > > ========================> > > ________________________________________________________________________________
Date: Mar 04, 2008
whoever has it. can you tell what size the countersink is? I looked at Avery's site but couldn't find any information on it. Thanks! Pascal ----- Original Message ----- From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu> Sent: Tuesday, March 04, 2008 6:50 AM Subject: RV10-List: Re: counter sinking canopy holes > > > Please add me to the list for the counter sink. > > Eric Gohr > 40271 - finishing, Fiberglass wonderland. > > -------- > eric gohr > EGOHR86(at)alumni.carnegiemellon.edu > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167625#167625 > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Mar 04, 2008
Here is what I did. http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&c ategory=613&log=14961&row=36 It's a push to release pin. Got it from McMaster/Carr or Grainger or someo ne. Also using one on my passenger side stick. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of David McNeill Sent: Monday, March 03, 2008 9:50 PM Subject: RE: RV10-List: baggage floor access plate for step Just a thought but Cessna on occasion drilled a bolt insertion hole directl y over the bolt and had an circular access panel below or adjacent to the b olt for hand access to tighten or loosen the bolt. the bolt insertion hole was covered with a chrome cap. ________________________________________________________________________________
From: "John Hilger" <ninepapa(at)bendbroadband.com>
Date: Mar 04, 2008
Pascal I bought mine from The Yard Store. P/N 13326 Countersink #12 x 5/8 x 100 deg John ----- Original Message ----- From: "Pascal" <rv10builder(at)verizon.net> Sent: Tuesday, March 04, 2008 7:42 AM Subject: Re: RV10-List: Re: counter sinking canopy holes > > whoever has it. can you tell what size the countersink is? > I looked at Avery's site but couldn't find any information on it. > Thanks! > Pascal > ----- Original Message ----- > From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu> > To: > Sent: Tuesday, March 04, 2008 6:50 AM > Subject: RV10-List: Re: counter sinking canopy holes > > > > > > > > Please add me to the list for the counter sink. > > > > Eric Gohr > > 40271 - finishing, Fiberglass wonderland. > > > > -------- > > eric gohr > > EGOHR86(at)alumni.carnegiemellon.edu > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=167625#167625 > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Landing gear lift
Date: Mar 04, 2008
We lifted the plane with engine on (no wings), by using an auto jack and 2-foot piece of 4x4 to lift up one side, then placing a long 4x4 between two tall sawhorses, under the wing spar stub. Then lift the other side likewise. Pull down on the tail tiedown ring to tweak fore-aft leveling as needed. TDT 40025 Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Subject: Lower Cowl Mounts
Date: Mar 04, 2008
Deems, I did a quick look through all you cowl photos and looks like you did a fin e job. I will also using a James cowl, but going with the vertical inductio n model of cowl. Was your cowl that cowl, than you had to modify that area. In your photos the intake was originally oblong and then you did a mod to a round intake. Wil informed me that there is currently only one vertical induction cowl op erating and was kind enough to inform me he wished he had more of a tract r ecord before selling me one. He said that the one currently flying is cooli ng fine. John G.> Date: Mon, 3 Mar 2008 17:46:17 -0700> From: deemsdavis(at)cox.net> To : rv10-list(at)matronics.com> Subject: Re: RV10-List: Lower Cowl Mounts> > --> RV10-List message posted by: Deems Davis > > Scott her e's a link to 2 photos (click next to see the 2nd)> http://deemsrv10.com/al bum/Sec%2047%20Spinner%20and%20Cowling/slides/DSC04175.html> I've since tri mmed the inside portion of the 'flange' so that it doesn't > stick out and interfere with the air exiting the lower cowl. (A John Cox > suggestion)> > Deems Davis # 406> 'Its all done....Its just not put together'> http://dee tt Schmidt > >> > Can someone point me to some pho tos. This is a modification I would like to make. I've already lost 2 eyele ts. > >> > Scott Schmidt> > scottmschmidt(at)yahoo.com> >> > On Mar 3, 2008, a t 12:30 PM, Rick Sked wrote:> >> > --> RV10-List message posted by: Rick Sked > >> > I made mine ou t of .063 aluminum, I think I used #8, three per side.> >> > Rick Sked> > 4 0185> > ----- Original Message -----> > From: "Tim Olson" <Tim(at)MyRV10.com>> > To: rv10-list(at)matronics.com> > Sent: Monday, March 3, 2008 8:33:55 AM (G MT-0800) America/Los_Angeles> > Subject: Re: RV10-List: Lower Cowl Mounts> countersunk screws....round head screws. Yes,> > they're holding up great f or people, and there are> > some now that I know personally (I'll let them speak up> > if they wish) who didn't install them until after they> > had i ssues with the hinges. But, there really are> > no problems with nutplates and screws...it's really> > secure.> >> >> > Tim Olson - RV-10 N104CD - Fly ing> >> >> >> > Vernon Smith wrote:> > Looking through some of the old post ings, I found some discussion on > > replacing the lower cowl mounts with n utplates and screws. Are these > > modified mounts still holding up well du ring flight? Also were #10 > > countersunk screws and nut plates used? And finally what was the > > mounting plate made from?> > Thanks,> >> > Vern Sm ======================> > > ________________________________________________________________________________
Date: Mar 04, 2008
Subject: Re: Lower Cowl Mounts
My cowl is NOT vertical induction, it was originally made for the BPE forward facing fuel servo and Cold Air sump. The oblong induction ring is the characteristic 'signature' for that cowl. When I was ready to install a filtered air system, there were none available that could be easily adapted to that Oval induction ring. I spoke with and followed another -10 BPE cold air builder as he customized a filtered air system using a K&N filter, Will, had offered to work with me in designing and building a filtered air intake for the BPE set up, (that he would subsequently offer to other builders) if I could provide him a 'model' (made from expandable foam) of the bottom of the cowl and the servo/cold air sump. I was ready to follow one of these approaches, when I happened on the information regarding the Rod Bowers design. I was Very impressed with the design and the '3 in one' capabilities of RAM/filtered/Alternate air sources, and after speaking w/ Rod, I concluded that while hacking up my cowl in order to replace the oval induction ring w/ the circular ring sounded alarming, it really turned out to be less work for me than either of the other 2 approaches, plus I picked up the benefit of the RAM air mp increase. I'm really happy with the results so far, although I'm obviously not flying and haven't validated any performance. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ IIRC the vertical induction cowl that is flying on an RV-10 is in Canada, there were some initial issues with heat and cooling, Will designed a modification wihc inclluded a larger exit area (around the exhaust stacks) and that appears to have solved that problem. my understanding is that he subsequently modified his mold to include the larger exit area. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ > * > * ________________________________________________________________________________
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Mar 04, 2008
Guys, did anyone use camlocks for the bottom cowling mounts? Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167708#167708 ________________________________________________________________________________
Date: Mar 04, 2008
I used camlocks around the fuse and piano hinge along the sides (vertical). They work great. Some folks don't like the looks of camlocks but I'm hap py with them. Mark RV-10/N410MR
> Subject: RV10-List: Re: Lower Cowl Mounts> From: rv-10(at)wellenzohn.net> Da -List message posted by: "Michael Wellenzohn" > > Guy s,> > did anyone use camlocks for the bottom cowling mounts?> > Michael> > --------> RV-10 builder (engine, prop, finishing)> #511> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.php?p=167708# =====> > > _________________________________________________________________ Connect and share in new ways with Windows Live. http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_0120 08 ________________________________________________________________________________
Date: Mar 04, 2008
Michael: I used the camlocks thru out (firewall to cowling and top to bottom cowling). Came as a kit (pricey) and fairly straight forward to install. Takes me about 3 minutes by myself to get the top cowling off and on, and a little longer for the bottom since you have to do some nudging to get the various baffles in proper place. The down side to the camlocks, in addition to the cost, is that they are not as cosmetically pleasing as the clean look you get with the hinges. Jay Rowe ----- Original Message ----- From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net> To: Sent: Tuesday, March 04, 2008 3:58 PM Subject: RV10-List: Re: Lower Cowl Mounts > > Guys, > > did anyone use camlocks for the bottom cowling mounts? > > Michael > > -------- > RV-10 builder (engine, prop, finishing) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167708#167708 > > > > > > > > > > > > > -- 3/4/2008 8:35 AM > > ________________________________________________________________________________
Date: Mar 04, 2008
> Guys, > did anyone use camlocks for the bottom cowling mounts? > Michael I am. Two per side on a 0.63 base. Four of each of the below: 244-16 Floting Receptacle 2.89 4002-4 Camloc Stud 2.45 4002-O Camloc Grommet 1.53 R4G Snap Rings 0.20 I used these on the horizontal sides of my Cardinal to replace the SouthCo fasteners and I like them a lot. Not enough however to use them in place of the hinges on the 10 except on the cowl bottom. The above prices are from Spruce, however if you go to OSH or Sun-N-Fun you can get them at the Aeromart for less. If you want to pay even more you can get the adjustable receptacle version but since the -4 stud will fit the thickness range of our cowling, I don't see any reason to use them. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess ________________________________________________________________________________
Date: Mar 04, 2008
Vic used camlocs all the way around. You can see photos here: <http://lrosen.nerv10.com/Construct/SunNFun_2006/Vic%20RV10/CamLocs/index.html> Larry Rosen William Curtis wrote: > > >> Guys, >> did anyone use camlocks for the bottom cowling mounts? >> Michael >> > > I am. Two per side on a 0.63 base. Four of each of the below: > > 244-16 Floting Receptacle 2.89 > 4002-4 Camloc Stud 2.45 > 4002-O Camloc Grommet 1.53 > R4G Snap Rings 0.20 > > I used these on the horizontal sides of my Cardinal to replace the SouthCo fasteners and I like them a lot. Not enough however to use them in place of the hinges on the 10 except on the cowl bottom. > > The above prices are from Spruce, however if you go to OSH or Sun-N-Fun you can get them at the Aeromart for less. If you want to pay even more you can get the adjustable receptacle version but since the -4 stud will fit the thickness range of our cowling, I don't see any reason to use them. > > William > http://wcurtis.nerv10.com/ > "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." > -- Dr. Suess
February 22, 2008 - March 04, 2008
RV10-Archive.digest.vol-dc
