RV10-Archive.digest.vol-dg
April 07, 2008 - April 15, 2008
      I installed mine after the fact, and was able to do it just fine.  I
      took a 7/16" drill and went all the way through the Rivethead blocks, as
      well as the door frame, so my pins go all the way through and can be
      felt out the back side.
      PJ Seipel
      RV-10 #40032
      Rene Felker wrote:
      > I added the pins after I had completed my door.  Worked fine.  I rechecked
      > them this weekend after hearing about the mid air door departure and the
      > adjustment looked fine.  Per design the pins do not go all the way into the
      > frame, they only go to the edge so that when they are extended they do not
      > hit the side of the air frame only the metal block. In normal opening and
      > closing I have not had the back pin go outside the guide, but I do have to
      > "help" the passenger door sometimes to get rear pin the hole, otherwise it
      > will just hit the edge of the block.
      > Rene' Felker
      > RV-10 N423CF Flying
      > 801-721-6080
Subject: Door seperation for those who don't frequent VAF site
Date: Apr 07, 2008
Hi Chris, I'm talking specifically about the need to open the door (in-flight from the inside) in the event you decide a parachute would fly better than a disabled airplane. The guy who built the safety latch (mentioned in the link below) says that he's tried to disengage it during flight, but it wouldn't budge because the doors pull out to the point that the latch is pinned-tight. That's good if you're trying to keep your doors on, but bad if you choose to open them during flight. So that was my reference about being locked in. Now, for the part of avoiding the HS..... Any ideas? Phil ________________________________ From: Chris and Susie McGough [mailto:VHMUM(at)bigpond.com] Sent: Monday, April 07, 2008 5:27 PM Subject: Re: RV10-List: Door seperation for those who don't frequent VAF site Phil not sure what you mean about locked in? There is a small pin -lever on the ouside that can be moved to disingage in case your in an accident etc. regards Chris ----- Original Message ----- From: Perry, Phil <mailto:Phil.Perry(at)netapp.com> To: rv10-list(at)matronics.com Sent: Tuesday, April 08, 2008 5:24 AM Subject: RE: RV10-List: Door seperation for those who don't frequent VAF site I'm not sure if I'm going to be a RV-10 parachute wearer-or-not, but I've wondered about the same thing. Part of what scares me about the Safety-Latch (http://www.vansairforce.com/community/showthread.php?t=26526) is not being able to get out. You're literally locked in. Phil ________________________________ From: John Gonzalez [mailto:indigoonlatigo(at)msn.com] Sent: Monday, April 07, 2008 1:51 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Door seperation for those who don't frequent VAF site While we are in this topic, one additional reason for considering the wearing of parachutes??? Reason why Oregon Aero is constructing a different type of seats to handle my Softie parachutes. Just food for thought. Still have to get out of the plane without the HS getting you...maybe get out on the side the door came off, atleast look back first, maybe the whole thing will be missing. JG > Date: Sun, 6 Apr 2008 19:48:38 -0400 > From: ricksked(at)embarqmail.com > To: rv10-list(at)matronics.com > Subject: RV10-List: Door seperation for those who don't frequent VAF site > > > > Check out this link > > http://ww============= > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Apr 07, 2008
Subject: Another fatal crash....
Anyone know who this is? http://www.wsfa.com/global/story.asp?s=8132249 http://wtvm.com/Global/story.asp?S=8130777 http://www.wztv.com/template/inews_wire/wires.regional.tn/35d58e13-www.fox17.com.shtml ________________________________________________________________________________
Subject: RV-10 Down in Alabama
Date: Apr 07, 2008
Bad new in Alabama. An N210HM went down today killing two on-board. My prayers go out to them and their families. http://wtvm.com/Global/story.asp?S=8130777 http://www.wsfa.com/Global/story.asp?S=8132249&nav=0RdE http://registry.faa.gov/aircraftinquiry/nnumSQL.asp?NNumbertxt=210HM ________________________________________________________________________________
Date: Apr 07, 2008
http://registry.faa.gov/aircraftinquiry/nnumSQL.asp?NNumbertxt=210HM -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Monday, April 07, 2008 8:40 PM Subject: RV10-List: Another fatal crash.... Anyone know who this is? http://www.wsfa.com/global/story.asp?s=8132249 http://wtvm.com/Global/story.asp?S=8130777 http://www.wztv.com/template/inews_wire/wires.regional.tn/35d58e13-www.fox17.com.shtml ________________________________________________________________________________
Date: Apr 07, 2008
Michael, I have four flying RV-10s from Tennessee yet none of these match the description based on ownership as reported by the news. My prayers go out to the families of those affected. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Monday, April 07, 2008 6:40 PM Subject: RV10-List: Another fatal crash.... Anyone know who this is? http://www.wsfa.com/global/story.asp?s=8132249 http://wtvm.com/Global/story.asp?S=8130777 http://www.wztv.com/template/inews_wire/wires.regional.tn/35d58e13-www.f ox17.com.shtml ________________________________________________________________________________
Subject: Re: Another fatal crash....
Date: Apr 07, 2008
The crash was my good friend Ham Cartwright and his hanger mate Bob.. He is from our chapter 863 Lebanon,Tn..I understand that they were in IMC conditions!!!!! It hurts John McMahon (RV6 CS) ----- Original Message ----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Sent: Monday, April 07, 2008 8:57 PM Subject: RE: RV10-List: Another fatal crash.... > > > http://registry.faa.gov/aircraftinquiry/nnumSQL.asp?NNumbertxt=210HM > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder > (Michael Sausen) > Sent: Monday, April 07, 2008 8:40 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Another fatal crash.... > > > > Anyone know who this is? > > http://www.wsfa.com/global/story.asp?s=8132249 > > http://wtvm.com/Global/story.asp?S=8130777 > > http://www.wztv.com/template/inews_wire/wires.regional.tn/35d58e13-www.fox17.com.shtml > > > ________________________________________________________________________________
Date: Apr 07, 2008
Check aircraft registry. N210HM registered to Hermitage TN. H Cartwright jr and M Cottrell. No airman info on Hamilton Cartwright but plenty on M Cottrell of TN -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Monday, April 07, 2008 7:51 PM Subject: RE: RV10-List: Another fatal crash.... Michael, I have four flying RV-10s from Tennessee yet none of these match the description based on ownership as reported by the news. My prayers go out to the families of those affected. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Monday, April 07, 2008 6:40 PM Subject: RV10-List: Another fatal crash.... Anyone know who this is? http://www.wsfa.com/global/story.asp?s=8132249 http://wtvm.com/Global/story.asp?S=8130777 http://www.wztv.com/template/inews_wire/wires.regional.tn/35d58e13-www.f ox17.com.shtml ________________________________________________________________________________
Subject: Re: Door separation/opening is an issue, what's the fix/s ?
Date: Apr 07, 2008
All the extra latching mechanisms seem great but, there is a lot of air pressure outside those doors even on take off roll. Any way to use that pressure to keep the doors closed, even with the hinges on top? Dave Leikam 40496 ----- Original Message ----- From: "Deems Davis" <deemsdavis(at)cox.net> Sent: Monday, April 07, 2008 12:39 PM Subject: RV10-List: Door separation/opening is an issue, what's the fix/s ? > > By my admittedly inaccurate count there are at least 5 incidents of RV-10 > doors opening in/during flight with resulting damage. One could logically > assume that there have been: > 1. More incidents that actually occurred that were not reported or.. > 2. More incidents that occurred that did not result in damage (I.e caught > and aborted take-off) > In any rate, the incident rate per flying RV-10 ( approaching 5% ??) is > high enough to have caused me to seriously consider whether a secondary > positive door locking mechanism should be added. (I've already got the > warning lights). I spent several hours over the weekend thinking about a > solution. one of which John G. mentioned. One of the people that had this > happen to them developed a custom solution posted on VAF. > http://www.vansairforce.com/community/showthread.php?t=26526. > I know that some will/have taken the position that proper build skills, > the use of alternate products (Rivethead etc. ) good / intended use of > practices and checklists when flying will minimize the possibility or > risk, all true, NO ONE who sets out on a flight plans to have a door > open, but one need only look at the photos of the damage to this recent > incident to realize just how serious the consequences of an incident like > this could be. That coupled with the increasing frequency of reported > incidents is making me very uneasy. > I have also come to appreciate the creativity and expertise that is > contained within this community. (witness the recent threads on Rudder > trim alternatives). So I'm VERY interested in what other builder/fliers > are thinking/doing/planning on this subject. > > What you got???? > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > > ________________________________________________________________________________
Date: Apr 07, 2008
? When a door opens in flight, the greater/higher pressure is most alway on the inside of the aircraft. In some high performance aircraft even with forward hinged doors traveling in excess of 200 mph, it is physically impossible to close the door while in flight. (remember Bernoulli?) Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ > ________________________________________________________________________________
Date: Apr 07, 2008
I had a door partially open on a warrior I was flying about a year ago. We landed without incident and properly closed the door. In flight, the door could not be closed or opened more to "slam" it shut. It was kind of stuck ajar. I do understand the greater interior pressure. Just thinking. Dave Leikam ----- Original Message ----- From: "Deems Davis" <deemsdavis(at)cox.net> Sent: Monday, April 07, 2008 11:01 PM Subject: Re: RV10-List: Door separation/opening is an issue, what's the fix/s ? > > When a door opens in flight, the greater/higher pressure is most alway on > the inside of the aircraft. In some high performance aircraft even with > forward hinged doors traveling in excess of 200 mph, it is physically > impossible to close the door while in flight. (remember Bernoulli?) > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > >> > > > ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: Re: Door seperation for those who don't frequent VAF site
Date: Apr 08, 2008
Gotcha Phil thanks. Just shows the pressure on the doors regards chris ----- Original Message ----- From: Perry, Phil To: rv10-list(at)matronics.com Sent: Tuesday, April 08, 2008 9:42 AM Subject: RE: RV10-List: Door seperation for those who don't frequent VAF site Hi Chris, I'm talking specifically about the need to open the door (in-flight from the inside) in the event you decide a parachute would fly better than a disabled airplane. The guy who built the safety latch (mentioned in the link below) says that he's tried to disengage it during flight, but it wouldn't budge because the doors pull out to the point that the latch is pinned-tight. That's good if you're trying to keep your doors on, but bad if you choose to open them during flight. So that was my reference about being locked in. Now, for the part of avoiding the HS..... Any ideas? Phil ------------------------------------------------------------------------- ----- From: Chris and Susie McGough [mailto:VHMUM(at)bigpond.com] Sent: Monday, April 07, 2008 5:27 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Door seperation for those who don't frequent VAF site Phil not sure what you mean about locked in? There is a small pin -lever on the ouside that can be moved to disingage in case your in an accident etc. regards Chris ----- Original Message ----- From: Perry, Phil To: rv10-list(at)matronics.com Sent: Tuesday, April 08, 2008 5:24 AM Subject: RE: RV10-List: Door seperation for those who don't frequent VAF site I'm not sure if I'm going to be a RV-10 parachute wearer-or-not, but I've wondered about the same thing. Part of what scares me about the Safety-Latch (http://www.vansairforce.com/community/showthread.php?t=26526) is not being able to get out. You're literally locked in. Phil ------------------------------------------------------------------------- --- From: John Gonzalez [mailto:indigoonlatigo(at)msn.com] Sent: Monday, April 07, 2008 1:51 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Door seperation for those who don't frequent VAF site While we are in this topic, one additional reason for considering the wearing of parachutes??? Reason why Oregon Aero is constructing a different type of seats to handle my Softie parachutes. Just food for thought. Still have to get out of the plane without the HS getting you...maybe get out on the side the door came off, atleast look back first, maybe the whole thing will be missing. JG > Date: Sun, 6 Apr 2008 19:48:38 -0400 > From: ricksked(at)embarqmail.com > To: rv10-list(at)matronics.com > Subject: RV10-List: Door seperation for those who don't frequent VAF site > > > > Check out this link > > http://ww============= > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 08, 2008
Hamilton Cartwright was my tech counselor. He was as nice as they come...please pray for their families. Brian Sutherland Nashville, TN N104BS Phase 1 11.5 hours RV Builder (Michael Sausen) wrote: > > Anyone know who this is? > > http://www.wsfa.com/global/story.asp?s=8132249 > > http://wtvm.com/Global/story.asp?S=8130777 > > http://www.wztv.com/template/inews_wire/wires.regional.tn/35d58e13-www.fox17.com.shtml > > > > . > > ________________________________________________________________________________
Date: Apr 08, 2008
Subject: Door handles
With all the talk about the doors I've been doing some thinking regarding the factory setup vs the aftermarket handles. I like the flush look and o peration of the handles like Hendricks and others but the lack of a positi ve locking detent really makes me nervous. I also want a way to lock the doors so they can't be opened by any passerb y. The is especially important with the TSA rumblings that all GA aircraft must have locked doors. It's not a law yet but I wouldn't be surprised to see it conceded to stop something bigger. Frankly having the kind of inve stment in these aircraft that we do it's a bit silly to not have the doors locked somehow. I know, if a thief really wants in he will get in. But a thief also isn't going to stop at a plane with locks if a better target is around or if it will take too long or be too noticeable to circumvent them. So to that end someone had posted a while back a way to make a baggage do or lock work with the standard Van's door handles. Anyone still have the l inks to that? Michael ________________________________________________________________________________
Date: Apr 08, 2008
Subject: Re: Door handles and locks
On this topic, Isn't there another option to the locks than needing to buy a whole magneto kit from Van's? I would like to get something local that would allow for expansion. I would also, speaking with another builder last week, like to consider a electric locking system that would work with a VP200 or other remote. Any ideas? Thanks! Pascal ----- Original Message ----- From: RV Builder (Michael Sausen) To: rv10-list(at)matronics.com Sent: Tuesday, April 08, 2008 6:32 AM Subject: RV10-List: Door handles With all the talk about the doors I've been doing some thinking regarding the factory setup vs the aftermarket handles. I like the flush look and operation of the handles like Hendricks and others but the lack of a positive locking detent really makes me nervous. I also want a way to lock the doors so they can't be opened by any passerby. The is especially important with the TSA rumblings that all GA aircraft must have locked doors. It's not a law yet but I wouldn't be surprised to see it conceded to stop something bigger. Frankly having the kind of investment in these aircraft that we do it's a bit silly to not have the doors locked somehow. I know, if a thief really wants in he will get in. But a thief also isn't going to stop at a plane with locks if a better target is around or if it will take too long or be too noticeable to circumvent them. So to that end someone had posted a while back a way to make a baggage door lock work with the standard Van's door handles. Anyone still have the links to that? Michael ________________________________________________________________________________
Subject: Engraving Name Plate
Date: Apr 08, 2008
=0ADidn't I see a message sometime back about a builder who was hap py with the engraving job he had done on a name plate for his RV-10? A nyone remember who did the engraving or have a recommendation? ________________________________________________________________________________
Date: Apr 08, 2008
Another option is a ignition kill switch and an alarm. My alarm can be triggered by mechanical shock or current drain or both. The first mechanical shock gets a voice warning, the second sounds the alarm.For those who have installed the door proximty switch, the other side of that circuit could be used to trigger the alarm. I imagine an alarm on an airport ramp would get attention unlike the mall parking lot. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Tuesday, April 08, 2008 6:33 AM Subject: RV10-List: Door handles With all the talk about the doors I've been doing some thinking regarding the factory setup vs the aftermarket handles. I like the flush look and operation of the handles like Hendricks and others but the lack of a positive locking detent really makes me nervous. I also want a way to lock the doors so they can't be opened by any passerby. The is especially important with the TSA rumblings that all GA aircraft must have locked doors. It's not a law yet but I wouldn't be surprised to see it conceded to stop something bigger. Frankly having the kind of investment in these aircraft that we do it's a bit silly to not have the doors locked somehow. I know, if a thief really wants in he will get in. But a thief also isn't going to stop at a plane with locks if a better target is around or if it will take too long or be too noticeable to circumvent them. So to that end someone had posted a while back a way to make a baggage door lock work with the standard Van's door handles. Anyone still have the links to that? Michael ________________________________________________________________________________
Subject: Re: Engraving Name Plate
Date: Apr 08, 2008
Try www.engravers.net, 860-653-2780. I used them and are very happy with the results. They were also very prompt. On Apr 8, 2008, at 10:47 AM, Roger Standley wrote: > > Didn't I see a message sometime back about a builder who was happy > with the engraving job he had done on a name plate for his RV-10? > Anyone remember who did the engraving or have a recommendation? > > ________________________________________________________________________________
Date: Apr 08, 2008
Subject: door safety latch
As I am getting ready to start work on cabin top projects, I am quite interested in the door ajar issue and mods to reduce the possibilty of an unsafe door. I think a forward safety latch would prevent the "air under the door scenario", and such a latch would be easy to build, and retrofit. The small triangular piece that trims out the top forward corner of the fuselage , aft of the naca vents, just above the door pins, could have a rotating handle, that when turned, would engage another pin, thru the frame, and into the door. The rotating shaft would penetrate the skin, and another handle outside the aircraft would be used by rescue personel to release the pin, in an emergency. This eliminates the "can't intentionally release in flight" concerns of our skydiving buddies. There would be no pressure on this pin, of the still intact door, if the primary door pin is properly engaged. The entire assembly could be removed from inside the aircraft, with a few screws, if necessary. OK fire away. Chris Hukill ________________________________________________________________________________
Date: Apr 08, 2008
Subject: Door handles and locks
The version I had seen was a standard cabinet lock from Lowes Depot (same thing as the baggage door lock) that simply used the lock flag to stop the action of the door cam. Probably not too terribly difficult to figure out but I'm not quite to that yet and wanted to save some time noodling time. As far as electric locks go, I see this as something that could be done r ather easily with a pair of solenoids. I would probably do it in addition to the standard door mechanism although it would be rather cool to have sha ved doors and use a door popper like custom cars, just don't know if I woul d trust them given the results if a door opens. I see something like two a dditional pins on the sides or maybe a single or double pins going through the threshold. You would have to use fail retract solenoids for safety rea sons but it could be just a switch control on the panel or integrated with the VP logic. I know Marc was talking about having user definable events i n the VP down the road so you could have something like airspeed > 30 knots = arm door locks. It could also be controlled by the VP remote. Hmmmmmm Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Pascal Sent: Tuesday, April 08, 2008 9:10 AM Subject: Re: RV10-List: Door handles and locks On this topic, Isn't there another option to the locks than needing to buy a whole magneto kit from Van's? I would like to get something local that wo uld allow for expansion. I would also, speaking with another builder last w eek, like to consider a electric locking system that would work with a VP20 0 or other remote. Any ideas? Thanks! Pascal ----- Original Message ----- From: RV Builder (Michael Sausen)<mailto:rvbuilder(at)sausen.net> Sent: Tuesday, April 08, 2008 6:32 AM Subject: RV10-List: Door handles With all the talk about the doors I've been doing some thinking regarding the factory setup vs the aftermarket handles. I like the flush look and o peration of the handles like Hendricks and others but the lack of a positi ve locking detent really makes me nervous. I also want a way to lock the doors so they can't be opened by any passerb y. The is especially important with the TSA rumblings that all GA aircraft must have locked doors. It's not a law yet but I wouldn't be surprised to see it conceded to stop something bigger. Frankly having the kind of inve stment in these aircraft that we do it's a bit silly to not have the doors locked somehow. I know, if a thief really wants in he will get in. But a thief also isn't going to stop at a plane with locks if a better target is around or if it will take too long or be too noticeable to circumvent them. So to that end someone had posted a while back a way to make a baggage do or lock work with the standard Van's door handles. Anyone still have the l inks to that? Michael href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 08, 2008
Subject: GRT HX
Looks like GRT is getting closer to having the HX ready. Looking pretty da rn good for the price! I think this pretty much negates the last attractiv e item with the BMA stuff and with a much more proven track record in suppo rt. http://www.grtavionics.com/File/SNF%20HX%20RELEASE2(1).pdf ________________________________________________________________________________
Subject: P-Mag!
Date: Apr 08, 2008
I stopped by the E-Mag guys today and they now have a 6-cylinder version on display. They said they have production units and will be doing testing. They hope to be shipping by Oshkosh time and are taking no-deposit waiting list orders via e-mail. I told them they can expect to sell a lot of them. I think they said it will be about $1,275 for the mag without the harness. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Subject: was Door separation now Door Locks / Door Handles
Date: Apr 08, 2008
Deems, I am well aware that many doors that open in flight cannot be closed. On my Bonanza (D-35, with poor 1940 latch design) the door opened on takeoff while I was the PAX. It took all my strength to pull the door in about 2 inches. When I finally relaxed (a bit) the door only opened slightly farther and then just held there. I assume this COULD be different had the Bonanza hinges been on the top of the door instead of the leading edge. Maybe that is why it has a "V" tail. Keeps it save from departing doors. Michael (Sausen): my Hendricks latched came with door locks to minimize petty theft. Speaking of door handles I have not given much thought to an interior handle or handle & arm rest combination. Assuming I don't; go with some sort of pull strap to close the door while seated what are other builders using to pull the door closed and/or use as an arm rest. My current plans are to paint the inside door and not place any material on the inside door. Thanks, Robin ________________________________________________________________________________
Subject: Engine stop tests.
Date: Apr 09, 2008
Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind you have little or no oil pressure, then there is very little time to coursen up the prop to minimise drag. And if you are thinking of saving the engine on your forced landing, then you need to drop the flap and stall for a while to get the engine to stop. So what a fun evening. Just wish I had taken the camera with me. If anyone else has done such tests, it would be great to hear from you. Or if anyone has any other thoughts on such matters. Neil ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks back. Osh may be bigger, but Wanaka surely has the best setting anywhere for an airshow. ________________________________________________________________________________
Date: Apr 08, 2008
Subject: P-Mag!
Anybody know if they have worked out the bugs in their 4cyl models yet. Hi story has been very hit and miss on those. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Jesse Saint Sent: Tuesday, April 08, 2008 12:31 PM Subject: RV10-List: P-Mag! I stopped by the E-Mag guys today and they now have a 6-cylinder version on display. They said they have production units and will be doing testing. They hope to be shipping by Oshkosh time and are taking no-deposit waiting list orders via e-mail. I told them they can expect to sell a lot of them . I think they said it will be about $1,275 for the mag without the harnes s. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Apr 08, 2008
Fabulous detail and invaluable research. We need more of this stuff and less accident reporting. By the way, did you go with the stock James engine cowl? The Warbirds acts as breathtaking as the setting at Wanaka. See you for OSH '08. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 10:48 AM Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind you have little or no oil pressure, then there is very little time to coursen up the prop to minimise drag. And if you are thinking of saving the engine on your forced landing, then you need to drop the flap and stall for a while to get the engine to stop. So what a fun evening. Just wish I had taken the camera with me. If anyone else has done such tests, it would be great to hear from you. Or if anyone has any other thoughts on such matters. Neil ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks back. Osh may be bigger, but Wanaka surely has the best setting anywhere for an airshow. ________________________________________________________________________________
Date: Apr 08, 2008
Subject: Re: GRT HX
In a message dated 4/8/2008 12:49:11 PM Central Daylight Time, robin1(at)mrmoisture.com writes: Talk about a powerful package providing remarkable situational awareness fo r under $10K. Flying behind a panel like this was only a dream 10 years ago and now it=99s cost effective Robin...a note of caution...only for experimentals...certifieds will cost you a few more $$$$ (http://travel.aol.com/travel-guide/united-states?ncid=aoltrv00030000000 016) ________________________________________________________________________________
Subject: Re: Engine stop tests.
Date: Apr 09, 2008
James cowl & plenum. Had to add a slightly bigger oil cooler. Neil On 9/04/2008, at 6:20 AM, John W. Cox wrote: > > > Fabulous detail and invaluable research. We need more of this stuff > and > less accident reporting. By the way, did you go with the stock James > engine cowl? > > The Warbirds acts as breathtaking as the setting at Wanaka. See you > for > OSH '08. > > John > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & > Sarah > Colliver > Sent: Tuesday, April 08, 2008 10:48 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine stop tests. > > Hi > > I would like to report on some tests we did this evening. > > We wanted to know what would happen when the engine stops. In flight! > We have a Barratts IO540, standard compression, with the MT 3 blade > prop, dual mags. > > The object of the exercise was to see just what happens when the fuel > runs out in one tank, and how easy it is to re-start. > > First exercise was to practise some forced landings in case we really > couldn't restart it. So complete with clearance from our local > Airforce base, and with one of their squadron leaders in the right > hand seat, the tower fully briefed on what we were doing, off we set > to 5000ft. > > There was a relatively strong wind of about 35 knots at 2000ft & 25 > gusting 30 on the ground . So we came up a bit short (just a bit) on > the runway. I was reminded then that I need to practice forced > landings from all heights, not just pattern (or circuit) height. > > Then it was back up to 5000ft. > Cool the engine a bit, then ( all in controlled airspace I hasten to > add), we cut mixture to full idle cut off. The engine just kept on > going at about 500 rpm in the glide at about 80 knots or so, so > eventually with full flap, and mushing down at about 55 knots, we > managed to finally get it to stop. It's certainly odd seeing the prop > stopped, and the ground so far below. Yes we do know that it is less > than ideal for the prop to drive the engine, but we wanted to do the > tests. There is no doubt that if the engine stops, the glide rate is > about 200 ft/m better with the prop in full course. > > So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a > flick of the starter and away it went. So no problems there at all. > > The next test was a bit harder, because we wanted to check if we could > start the engine without the starter (just in case of a flat battery / > broken starter etc.) I've had two occasions where the engine started, > but the starter failed in the process. So I was unable to restart. > > With the prop stopped again, we went flaps up, full rich,full fine, > 1/2 inch on the throttle and entered a dive. > > The prop looked as if someone was trying to hand swing it (though at > 4500ft and rapidly decreasing, that was unlikely!) > > After a few seconds it finally passed TDC, then again, and eventually > it did restart after having lost about 2600ft, and at a speed of about > 130-150 knots. > > Very quickly it builds up revs, so pulling back on stick & throttle we > were quickly under control. But it is not something you will get away > with under 3000ft. > > Our final test was to deliberately run out of fuel. With plenty in the > other tank! > So we simply cruised around for a further 15 mins or so, until finally > the engine cooughed & spluttered. There was plenty of time to switch > pump on and change tanks and away she went. So no dramas at all. > > Having completed our tests it was back up to 7000ft t play on the > overcast for a short while. > > So in conclusion, there is nothing to be feared about running a tank > dry. So long as the starter works, or you have sufficient height. > > However, if you have totally run out of fuel, it will happily continue > to turn. So bearing in mind you have little or no oil pressure, then > there is very little time to coursen up the prop to minimise drag. And > if you are thinking of saving the engine on your forced landing, then > you need to drop the flap and stall for a while to get the engine to > stop. > > So what a fun evening. Just wish I had taken the camera with me. > > If anyone else has done such tests, it would be great to hear from > you. Or if anyone has any other thoughts on such matters. > > Neil > > ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks > back. Osh may be bigger, but Wanaka surely has the best setting > anywhere for an airshow. > > ________________________________________________________________________________
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
Date: Apr 08, 2008
During these tests, what did you find the best glide to be with and without the prop being stopped. Thank You Ray Doerr 40250 (N519RV) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 12:48 PM Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind you have little or no oil pressure, then there is very little time to coursen up the prop to minimise drag. And if you are thinking of saving the engine on your forced landing, then you need to drop the flap and stall for a while to get the engine to stop. So what a fun evening. Just wish I had taken the camera with me. If anyone else has done such tests, it would be great to hear from you. Or if anyone has any other thoughts on such matters. Neil ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks back. Osh may be bigger, but Wanaka surely has the best setting anywhere for an airshow. ________________________________________________________________________________
Date: Apr 09, 2008
The best glide with the engine at tickover (minimum throttle) was 75 knots. We must have done over an hour of tests to establish this. Last night we were gliding at about 80 knots. Full fine was about 1000 ft/m, full corse was about 200 ft/m better. Sorry, but we didn't attempt to establish best glide with engine stopped as the focus was on re-starting. Neil On 9/04/2008, at 7:39 AM, Doerr, Ray R [NTK] wrote: > > > > During these tests, what did you find the best glide to be > with and without the prop being stopped. > > Thank You > Ray Doerr > 40250 (N519RV) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Neil & Sarah Colliver > Sent: Tuesday, April 08, 2008 12:48 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine stop tests. > > Hi > > I would like to report on some tests we did this evening. > > We wanted to know what would happen when the engine stops. In flight! > We have a Barratts IO540, standard compression, with the MT 3 blade > prop, dual mags. > > The object of the exercise was to see just what happens when the fuel > runs out in one tank, and how easy it is to re-start. > > First exercise was to practise some forced landings in case we really > couldn't restart it. So complete with clearance from our local > Airforce base, and with one of their squadron leaders in the right > hand seat, the tower fully briefed on what we were doing, off we set > to 5000ft. > > There was a relatively strong wind of about 35 knots at 2000ft & 25 > gusting 30 on the ground . So we came up a bit short (just a bit) on > the runway. I was reminded then that I need to practice forced > landings from all heights, not just pattern (or circuit) height. > > Then it was back up to 5000ft. > Cool the engine a bit, then ( all in controlled airspace I hasten to > add), we cut mixture to full idle cut off. The engine just kept on > going at about 500 rpm in the glide at about 80 knots or so, so > eventually with full flap, and mushing down at about 55 knots, we > managed to finally get it to stop. It's certainly odd seeing the prop > stopped, and the ground so far below. Yes we do know that it is less > than ideal for the prop to drive the engine, but we wanted to do the > tests. There is no doubt that if the engine stops, the glide rate is > about 200 ft/m better with the prop in full course. > > So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a > flick of the starter and away it went. So no problems there at all. > > The next test was a bit harder, because we wanted to check if we could > start the engine without the starter (just in case of a flat battery / > broken starter etc.) I've had two occasions where the engine started, > but the starter failed in the process. So I was unable to restart. > > With the prop stopped again, we went flaps up, full rich,full fine, > 1/2 inch on the throttle and entered a dive. > > The prop looked as if someone was trying to hand swing it (though at > 4500ft and rapidly decreasing, that was unlikely!) > > After a few seconds it finally passed TDC, then again, and eventually > it did restart after having lost about 2600ft, and at a speed of about > 130-150 knots. > > Very quickly it builds up revs, so pulling back on stick & throttle we > were quickly under control. But it is not something you will get away > with under 3000ft. > > Our final test was to deliberately run out of fuel. With plenty in the > other tank! > So we simply cruised around for a further 15 mins or so, until finally > the engine cooughed & spluttered. There was plenty of time to switch > pump on and change tanks and away she went. So no dramas at all. > > Having completed our tests it was back up to 7000ft t play on the > overcast for a short while. > > So in conclusion, there is nothing to be feared about running a tank > dry. So long as the starter works, or you have sufficient height. > > However, if you have totally run out of fuel, it will happily continue > to turn. So bearing in mind you have little or no oil pressure, then > there is very little time to coursen up the prop to minimise drag. And > if you are thinking of saving the engine on your forced landing, then > you need to drop the flap and stall for a while to get the engine to > stop. > > So what a fun evening. Just wish I had taken the camera with me. > > If anyone else has done such tests, it would be great to hear from > you. Or if anyone has any other thoughts on such matters. > > Neil > > ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks > back. Osh may be bigger, but Wanaka surely has the best setting > anywhere for an airshow. > > ________________________________________________________________________________
Subject: AFS Systems
Date: Apr 08, 2008
As both GRT and AFS leap frog each other with features, the question I'm attempting to answer is which platform (Horizon HX or AFS 4500) has the best platform for implementing all the new software enhancements without requiring future hardware updates. Both have processor updates and both have graphic enhancements. However, I'm having difficulties locating any information that allows an objective comparison. If either company is sharing more detailed information and SnF, inquiring minds want to know. All that can be found on their web sites is marketing data sheets. It sure would be nice to get engineering specs. Since that's not likely either, I would be interested in hearing any subjective evaluations of these units by anyone at SnF. Thanks, bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Tuesday, April 08, 2008 1:04 PM Subject: Re: RV10-List: AFS Systems I spent some time with Rob this morning. The screen on the 4500 is very nice. It is glossy, and although I have seen glossy screens give more glare in sunlight, Rob says that in their testing it is easier to see. It is about 1,000 nits, whereas the 3500 is about 500, if I remember correctly. According to Rob, all of the units still do the same stuff, although you get get to some features easier and more quickly on the 4500 because of the joystick and extra knob. However, with the faster processor (which may become available on the 3500 as an upgrade) they will be able to offer more things like the synthetic terrain, etc. They didn't have their approach plates demo working this morning, but it should be this afternoon Rob said. It's pretty sweet how you can cross-feed flight planning stuff between the AFS and a Garmin 430/530 or even a 396/496. They also don't have the weather up and running yet here, but should tomorrow, I think he said. I will be stopping back by. They currently only have Nexrad and one other thing (I think the METARS/TAFS) setup, but are working on the rest. So, in answer to your question, the $1,700 (or $1,500 as stated by Rob this morning) difference is the screen, the processor, the extra knob and the joystick so far. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Apr 08, 2008
This is a perfect question for Stein of SteinAir or Dewey Conroy of Pacific Coast Avionics. They are probably both taking all kinds of orders and will address this after returning. Many inquiring minds want to know exactly these questions. I would like to see an EFIS system which can annunciate remotely mounted and controlled avionics without taking the financial dive with the Garmin G900X national debt decision. I am impressed with Robin's purchase but it is too rich for my blood. Synthetic Vision, HITS, Chartview, SafeTaxi, Terrain, Traffic and Weather with the capability to go IFR. Vertical Autopilot GPS steer with the AFS 4500 is a great start. John ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Tuesday, April 08, 2008 2:30 PM Subject: RE: RV10-List: AFS Systems As both GRT and AFS leap frog each other with features, the question I'm attempting to answer is which platform (Horizon HX or AFS 4500) has the best platform for implementing all the new software enhancements without requiring future hardware updates. Both have processor updates and both have graphic enhancements. However, I'm having difficulties locating any information that allows an objective comparison. If either company is sharing more detailed information and SnF, inquiring minds want to know. All that can be found on their web sites is marketing data sheets. It sure would be nice to get engineering specs. Since that's not likely either, I would be interested in hearing any subjective evaluations of these units by anyone at SnF. Thanks, bob ________________________________________________________________________________
Subject: GRT HX
Date: Apr 08, 2008
SSBoYXZlIHRvIHNheSBJIG1heSBoYXZlIHB1cmNoYXNlZCBteSBsYXN0IGNlcnRpZmllZCBwbGFu ZS4gVGhlc2UgZGF5cyBJIGNhbiBvbmx5IGp1c3RpZnkgdGhlc2Ug4oCcR2FyYWdlIFBsYW5lc+KA nSBmb3IgdmFsdWUgJiBwZXJmb3JtYW5jZS4NCg0KIA0KDQpSb2Jpbg0KDQpEbyBOb3QgQXJjaGl2 ZQ0KDQogDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFp bHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEdS QU5TQ09UVEBhb2wuY29tDQpTZW50OiBUdWVzZGF5LCBBcHJpbCAwOCwgMjAwOCAxMjoyMCBQTQ0K VG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBHUlQg SFgNCg0KIA0KDQpJbiBhIG1lc3NhZ2UgZGF0ZWQgNC84LzIwMDggMTI6NDk6MTEgUE0gQ2VudHJh bCBEYXlsaWdodCBUaW1lLCByb2JpbjFAbXJtb2lzdHVyZS5jb20gd3JpdGVzOg0KDQoJVGFsayBh Ym91dCBhIHBvd2VyZnVsIHBhY2thZ2UgcHJvdmlkaW5nIHJlbWFya2FibGUgc2l0dWF0aW9uYWwg YXdhcmVuZXNzIGZvciB1bmRlciAkMTBLLiBGbHlpbmcgYmVoaW5kIGEgcGFuZWwgbGlrZSB0aGlz IHdhcyBvbmx5IGEgZHJlYW0gMTAgeWVhcnMgYWdvIGFuZCBub3cgaXTigJlzIGNvc3QgZWZmZWN0 aXZlDQoNClJvYmluLi4uYSBub3RlIG9mIGNhdXRpb24uLi5vbmx5IGZvciBleHBlcmltZW50YWxz Li4uY2VydGlmaWVkcyB3aWxsIGNvc3QgeW91IGEgZmV3IG1vcmUgJCQkJA0KDQogDQo ________________________________________________________________________________
Subject: Re: P-Mag!
Date: Apr 08, 2008
Jesse, Can you share any experiences you have had with the PMags? Put any in your planes? Any recent problems that you are aware of? Thanks, Nick -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175573#175573 ________________________________________________________________________________
Subject: NVFR avionics help
Date: Apr 09, 2008
Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris ________________________________________________________________________________
Date: Apr 08, 2008
Neil, Fantastic write up, thanks for all the very valuable information. I had planned to do similar tests down the road but your experience builds a lot of confidence in the mean time. Just to add to your statement that running a tank dry isn't a dramatic event, in the Skybolt (same engine) I was told the best (actually only) way to know the aux tank was dry was to hear the engine start to fade from fuel starvation. I was never impressed with that idea, but there's no fuel gauge for that tank. Worked great every time. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 12:48 PM Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind you have little or no oil pressure, then there is very little time to coursen up the prop to minimise drag. And if you are thinking of saving the engine on your forced landing, then you need to drop the flap and stall for a while to get the engine to stop. So what a fun evening. Just wish I had taken the camera with me. If anyone else has done such tests, it would be great to hear from you. Or if anyone has any other thoughts on such matters. Neil ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks back. Osh may be bigger, but Wanaka surely has the best setting anywhere for an airshow. ________________________________________________________________________________
Date: Apr 08, 2008
Subject: Re: NVFR avionics help
Substitute SL30 for the SL40. Gives you TSO VOR and ILS. Otherwise, for more space, but older technology, you could put used KX155 or Mk12D in panel. The SL30 should fit in same space, maybe same tray as SL40. On Tue, Apr 8, 2008 at 4:20 PM, Chris and Susie McGough wrote: > Guys I have decided to change my 10 to NVFR and was wondering if anyone > had some ideas on an easy way to upgrade. > > My current setup is > > DYNON D180 > Garmin 327 Transponder > SL40 Radio > Garmin 296 GPS > Vertical card compass > Backup ALT and ASI > Intercom > > So my question is what would be the simplest way to upgrade to NVFR . The > Australian regs say you must have a TSO GPS or VOR or ADF. > > Should I just get a new GPS? > > regards Chris > > > * > > * > > ________________________________________________________________________________
Date: Apr 08, 2008
Chris, I have a Garmin 480 and absolutely love it. Since Garmin announced they would no longer produce it you might be able to find them for a better deal before the supply runs out. I'm just speculating but I suspect a number of folks will shy away from them out of support concerns. With the 480 (or 430 or 530) you'd have GPS and VOR available. Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 6:21 PM Subject: RV10-List: NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris ________________________________________________________________________________
Date: Apr 09, 2008
Does the inbuilt CDI capability on the 430 and/or SL-30 meet the VOR indication/OBS requirement, or do you need a separate CDI/OBS (eg GI-106 or MD-200 etc)? cheers, Ron ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Wednesday, 9 April 2008 9:24 AM To: rv10-list(at)matronics.com Subject: RE: RV10-List: NVFR avionics help Chris, I have a Garmin 480 and absolutely love it. Since Garmin announced they would no longer produce it you might be able to find them for a better deal before the supply runs out. I'm just speculating but I suspect a number of folks will shy away from them out of support concerns. With the 480 (or 430 or 530) you'd have GPS and VOR available. Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 6:21 PM To: RVs_in_Aus(at)yahoogroups.com.au Subject: RV10-List: NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Subject: RV Grin
Date: Apr 08, 2008
N204GS flew for the first time today. I have been telling folks that it would be done on Tuesday ever since I started building. The airplane flew perfectly. Gary 40274 ________________________________________________________________________________
Date: Apr 08, 2008
Might want to think about upgrading your SL40 to an SL30 and adding a CDI, such as the GI-102A. Upgrade your 294 to a 496 for terrain, weather. Of course you'll have nav lights, landing light, strobes, plus panel lights and overhead map reading lights. Basically, night VFR should be capable of "light" or "rudimentary" IFR. The problem with NVFR is that you can easily get into an IFR environment (unseen clouds that you enter, loss of a horizon due to pitch black seas or landscape). I love flying at night, but have found that since going from the well lit Northeastern US to the relative darkness of the Northwest US, night flying has a whole new meaning. I wouldn't do it where I am located now without being IFR rated and having an IFR panel. Not unless it was clear skies and city lights. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 4:21 PM Subject: RV10-List: NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris ________________________________________________________________________________
Subject: Re: RV Grin
Date: Apr 09, 2008
FW: RV10-List: Jack StandsGood on you! regards Chris 388 ----- Original Message ----- From: gary To: rv10-list(at)matronics.com Sent: Wednesday, April 09, 2008 10:07 AM Subject: RV10-List: RV Grin N204GS flew for the first time today. I have been telling folks that it would be done on Tuesday ever since I started building. The airplane flew perfectly. Gary 40274 ________________________________________________________________________________
Subject: RE: [RVs_in_Aus] NVFR avionics help
Date: Apr 09, 2008
Hi Chris, You seem to have most of what is required already. Like has already been said I would possibly recommend upgrading to the SL-30 or check out the NARCO NAV 122 (entire VOR fits into a single instrument home). However (and it is a big however), the regulations state that you must have an aid in the aircraft which is usable at your destination. This would mean you can only proceed to a field with VOR or carry fuel to use an alternate that does. Check if you also need a TSO indicator/CDI. I am aware the Dynon can do this but not sure the Australian view of it. You must also fix your position at regular intervals when airborne. It might be difficult to do that legally with only a VOR. ADF is the other option and you do not want to do that. They are heavy, difficult to install and getting decommissioned all over the place. TSO GPS (146) would be the best as you can legally use that to navigate anywhere. However that is expensive, both to purchase and maintenance of the database. This is where some reality comes in I guess. I have done a few NVFR trips in my time. The last time was to and from Cowra several times during the convention. It was extremely dark. I was lucky enough to have an ADF / VOR and TSO GPS all dialled in. None of that was any use at all until I got the airport lights on. There was no way I was going to find the place. On the way home to Sydney on Sunday night I left after dark. Again I was basically flying on instruments the whole way home. I have never been that comfortable flying at night and far prefer day IFR to NVFR. I guess it comes down to how much flying you want to do at night and what your equipment requirements are. Also you will need lights, cabin lights, instrument lights . lights , lights, more weight.. The last thing that no one has mentioned .. At MINIMUM a second handheld com with fresh batteries. If you loose COM1 you are in a world of pain if you cannot get the lights on. I think you will find you need an alternate with someone in attendance or where the lights are always on if you don't have a second com anyway. Richard _____ From: RVs_in_Aus(at)yahoogroups.com.au [mailto:RVs_in_Aus(at)yahoogroups.com.au] On Behalf Of Chris and Susie McGough Sent: Wednesday, 9 April 2008 9:21 AM Cc: rv10-list(at)matronics.com Subject: [RVs_in_Aus] NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris __._,_.___ Messages <http://au.groups.yahoo.com/group/RVs_in_Aus/message/6153;_ylc=X3oDMTM1azJ2d TkyBF9TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRtc2dJZAM2M TUzBHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTIwNzY5Njg2NAR0cGNJZAM2MTUz> in this topic (1) <http://au.groups.yahoo.com/group/RVs_in_Aus/post;_ylc=X3oDMTJxdm8xM2dxBF9TA zk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRtc2dJZAM2MTUzBHNlY wNmdHIEc2xrA3JwbHkEc3RpbWUDMTIwNzY5Njg2NA--?act=reply&messageNum=6153> Reply (via web post) | Start <http://au.groups.yahoo.com/group/RVs_in_Aus/post;_ylc=X3oDMTJmaTNnZHBkBF9TA zk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNud HBjBHN0aW1lAzEyMDc2OTY4NjQ-> a new topic Messages <http://au.groups.yahoo.com/group/RVs_in_Aus/messages;_ylc=X3oDMTJmOTk0bmpnB F9TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsa wNtc2dzBHN0aW1lAzEyMDc2OTY4NjQ-> | Files <http://au.groups.yahoo.com/group/RVs_in_Aus/files;_ylc=X3oDMTJnOTU3ZmJzBF9T Azk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNm aWxlcwRzdGltZQMxMjA3Njk2ODY0> | Photos <http://au.groups.yahoo.com/group/RVs_in_Aus/photos;_ylc=X3oDMTJmdnJqcW84BF9 TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawN waG90BHN0aW1lAzEyMDc2OTY4NjQ-> | Links <http://au.groups.yahoo.com/group/RVs_in_Aus/links;_ylc=X3oDMTJndG4xYTIwBF9T Azk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNs aW5rcwRzdGltZQMxMjA3Njk2ODY0> | Database <http://au.groups.yahoo.com/group/RVs_in_Aus/database;_ylc=X3oDMTJkNTZkZTZvB F9TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsa wNkYgRzdGltZQMxMjA3Njk2ODY0> | Polls <http://au.groups.yahoo.com/group/RVs_in_Aus/polls;_ylc=X3oDMTJnMm5vOG1xBF9T Azk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNw b2xscwRzdGltZQMxMjA3Njk2ODY0> | Members <http://au.groups.yahoo.com/group/RVs_in_Aus/members;_ylc=X3oDMTJmYzRkYzM5BF 9TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsaw NtYnJzBHN0aW1lAzEyMDc2OTY4NjQ-> | Calendar <http://au.groups.yahoo.com/group/RVs_in_Aus/calendar;_ylc=X3oDMTJlazh1Y2U4B F9TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsa wNjYWwEc3RpbWUDMTIwNzY5Njg2NA--> <http://au.groups.yahoo.com/;_ylc=X3oDMTJlMGJnZGNvBF9TAzk3NDkwNDMxBGdycElkAz EyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTIwNzY5Nj g2NA--> Yahoo! Groups Change <http://au.groups.yahoo.com/group/RVs_in_Aus/join;_ylc=X3oDMTJnYnM0dHRhBF9TA zk3NDkwNDMxBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNzd G5ncwRzdGltZQMxMjA3Njk2ODY0> settings via the Web (Yahoo! ID required) Change settings via email: Switch delivery to Daily Digest | Switch format to Traditional Visit <http://au.groups.yahoo.com/group/RVs_in_Aus;_ylc=X3oDMTJlcnA1djdlBF9TAzk3ND kwNDMxBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDZnRyBHNsawNocGYEc3 RpbWUDMTIwNzY5Njg2NA--> Your Group | Yahoo! Groups <http://au.docs.yahoo.com/info/terms/> Terms of Use | Unsubscribe Recent Activity * 1 New <http://au.groups.yahoo.com/group/RVs_in_Aus/members;_ylc=X3oDMTJndjRxdGJzBF 9TAzk3NDkwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDdnRsBHNsaw N2bWJycwRzdGltZQMxMjA3Njk2ODY0> Members Visit <http://au.groups.yahoo.com/group/RVs_in_Aus;_ylc=X3oDMTJmZGZkYWk5BF9TAzk3ND kwNDMzBGdycElkAzEyOTEwMzM4BGdycHNwSWQDMTc0MDc4NjA4MwRzZWMDdnRsBHNsawN2Z2hwBH N0aW1lAzEyMDc2OTY4NjQ-> Your Group Y!7 Toolbar Get <http://us.lrd.yahoo.com/_ylc=X3oDMTJwdXRyNWlyBF9TAzk3NDkwNDMzBF9wAzIEZ3JwSW QDMTI5MTAzMzgEZ3Jwc3BJZAMxNzQwNzg2MDgzBHNlYwNuY21vZARzbGsDdG9vbGJhcgRzdGltZQ ygrps> it Free! easy 1-click access to your groups. Yahoo!7 Groups Start <http://au.groups.yahoo.com/start;_ylc=X3oDMTJwdm9yYzFyBF9TAzk3NDkwNDMzBF9wA zMEZ3JwSWQDMTI5MTAzMzgEZ3Jwc3BJZAMxNzQwNzg2MDgzBHNlYwNuY21vZARzbGsDZ3JvdXBzM gRzdGltZQMxMjA3Njk2ODY0> a group in 3 easy steps. Connect with others. . <http://geo.yahoo.com/serv?s=97490433/grpId=12910338/grpspId=1740786083/msgI d=6153/stime=1207696864/nc1=3975891/nc2=2/nc3=3> __,_._,___ ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Date: Apr 09, 2008
Thanks John I am in Australia and are only doing the NVfR as I am studying commercial Pilot licence and NVFR is helpful. I was thinking I could just swap the radio to SL 30 and plug into Dynon? The 296 has terrain and the weather feature is not available in Australia I have all lights etc it just the avionics Chris ----- Original Message ----- From: John Jessen To: rv10-list(at)matronics.com Sent: Wednesday, April 09, 2008 10:10 AM Subject: RE: RV10-List: NVFR avionics help Might want to think about upgrading your SL40 to an SL30 and adding a CDI, such as the GI-102A. Upgrade your 294 to a 496 for terrain, weather. Of course you'll have nav lights, landing light, strobes, plus panel lights and overhead map reading lights. Basically, night VFR should be capable of "light" or "rudimentary" IFR. The problem with NVFR is that you can easily get into an IFR environment (unseen clouds that you enter, loss of a horizon due to pitch black seas or landscape). I love flying at night, but have found that since going from the well lit Northeastern US to the relative darkness of the Northwest US, night flying has a whole new meaning. I wouldn't do it where I am located now without being IFR rated and having an IFR panel. Not unless it was clear skies and city lights. John ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 4:21 PM To: RVs_in_Aus(at)yahoogroups.com.au Subject: RV10-List: NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 09, 2008
Subject: RV Grin
Date: Apr 08, 2008
What a beautiful day. It is raining cats and dogs out west. Congrats. John ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Tuesday, April 08, 2008 5:07 PM Subject: RV10-List: RV Grin N204GS flew for the first time today. I have been telling folks that it would be done on Tuesday ever since I started building. The airplane flew perfectly. Gary 40274 ________________________________________________________________________________
Date: Apr 08, 2008
You might want the SL30 hooked to both the Dynon and a CDI, incase the Dynon goes away you could switch over. Or, get a battery backup for the Dynon. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 5:27 PM Subject: Re: RV10-List: NVFR avionics help Thanks John I am in Australia and are only doing the NVfR as I am studying commercial Pilot licence and NVFR is helpful. I was thinking I could just swap the radio to SL 30 and plug into Dynon? The 296 has terrain and the weather feature is not available in Australia I have all lights etc it just the avionics Chris ----- Original Message ----- From: John Jessen <mailto:n212pj(at)gmail.com> Sent: Wednesday, April 09, 2008 10:10 AM Subject: RE: RV10-List: NVFR avionics help Might want to think about upgrading your SL40 to an SL30 and adding a CDI, such as the GI-102A. Upgrade your 294 to a 496 for terrain, weather. Of course you'll have nav lights, landing light, strobes, plus panel lights and overhead map reading lights. Basically, night VFR should be capable of "light" or "rudimentary" IFR. The problem with NVFR is that you can easily get into an IFR environment (unseen clouds that you enter, loss of a horizon due to pitch black seas or landscape). I love flying at night, but have found that since going from the well lit Northeastern US to the relative darkness of the Northwest US, night flying has a whole new meaning. I wouldn't do it where I am located now without being IFR rated and having an IFR panel. Not unless it was clear skies and city lights. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 4:21 PM Subject: RV10-List: NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 08, 2008
Hey Neil, et al A quick question from a newbie. If the prop/crank is turning, why no oil pressure? I don't doubt it, I just don't understand it. I have no experience with aircraft engines, just automotive that use mechanical driven oil pumps taken off distributor gear, etc. which don't care if the pistons, wheels, starter, etc. is powering it. I know I can find complete books/manuals, and eventually I will, but it's easier and quicker to ask here. Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175624#175624 ________________________________________________________________________________
Date: Apr 08, 2008
*C O N G R A T U L A T I O N S ! ! ! ! *Deems* * ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Apr 08, 2008
Subject: Re: P-Mag!
I think Jesse only builds RV-10's so I doubt it. They are just now releasing their 6cyl models so I don't think there have been any significant hours built up to give a good idea on their MTBF. If you search various archives of the 4cyl homebuilts you will find a lot's of references from one extreme to the other. Overall they seem to have an excellent idea but have been plagued with lots of gremlins in their design. Many people have had no problems but it seems an equal number of people have had consistent problems. I for one really hope they get all their problems licked and end up with a solid product. Lots of potential there and they seem to e steadily improving. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Tuesday, April 08, 2008 5:22 PM Subject: RV10-List: Re: P-Mag! Jesse, Can you share any experiences you have had with the PMags? Put any in your planes? Any recent problems that you are aware of? Thanks, Nick -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175573#175573 ________________________________________________________________________________
Date: Apr 08, 2008
Subject: Garmin 1000 additions
Looks like Garmin is sleeping on the job either. They've added some very n ice synthetic vis and HITS to the G1000. Probably only a matter of time b efore it trickles down to the G900. http://www.aopa.org/pilot/firstlook/080408garminsvs.html Michael ________________________________________________________________________________
Date: Apr 08, 2008
swap the sl40 for an sl30 you then have a tsoed vor/loc/gs. the utput can be shownon the Dynon _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, April 08, 2008 4:21 PM Subject: RV10-List: NVFR avionics help Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. My current setup is DYNON D180 Garmin 327 Transponder SL40 Radio Garmin 296 GPS Vertical card compass Backup ALT and ASI Intercom So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. Should I just get a new GPS? regards Chris ________________________________________________________________________________
Subject: Air field flow for the 10
Date: Apr 08, 2008
I am in the process of working the intake and exhaust heat flow and am wondering if anyone has done a field flow on the RV-10. It makes sense for air to exhaust into a low pressure area and enter in a high pressure area. Hense the need for the air field flow, if that is what it is called. Thanks in advance Bob K Baby steps along once I hit the finishing part. ________________________________________________________________________________
Date: Apr 08, 2008
Garmin GNC 300 XL (?) comes to mind as a swap for the SL40. It is a great little IFR GPS/Comm with moving map. They are pretty inexpensive as well. David Maib 40559 On Tuesday, April 08, 2008, at 06:31PM, "Chris and Susie McGough" wrote: >Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade. > >My current setup is > >DYNON D180 >Garmin 327 Transponder >SL40 Radio >Garmin 296 GPS >Vertical card compass >Backup ALT and ASI >Intercom > >So my question is what would be the simplest way to upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or ADF. > >Should I just get a new GPS? > >regards Chris > > ________________________________________________________________________________
Date: Apr 08, 2008
Outstanding Gary!! Congratulations. I can't wait to see the airplane in Minnesota now that winter is gone. (almost) David Maib 40559 On Tuesday, April 08, 2008, at 07:19PM, "gary" wrote: > > >N204GS flew for the first time today. I have been telling folks that it >would be done on Tuesday ever since I started building. The airplane flew >perfectly. > > > >Gary > >40274 > > ________________________________________________________________________________
Subject: Re: The King has no Clothes
Date: Apr 08, 2008
I cannot imagine why anyone flying an RV10 does not install the very excellent Rivethead door pins. They are tedious to install and adjust, but they are really sweet and center the closure on the door giving a positive feel when closing your door plus the whole install feels very strong -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175658#175658 ________________________________________________________________________________
Date: Apr 08, 2008
Awesome - love that smile (grin). Plane look beautiful. Verrry exciting. -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175659#175659 ________________________________________________________________________________
Date: Apr 09, 2008
Maybe because you pay and they may or may not turn up. Sorry to be negative but if the hat fits. regards Chris ----- Original Message ----- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Wednesday, April 09, 2008 2:58 PM Subject: RV10-List: Re: The King has no Clothes > > I cannot imagine why anyone flying an RV10 does not install the very > excellent Rivethead door pins. They are tedious to install and adjust, but > they are really sweet and center the closure on the door giving a positive > feel when closing your door plus the whole install feels very strong > > -------- > OSH '08 or Bust > Q/B Kit - Ready to exit cabin top/door purgatory > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175658#175658 > > > ________________________________________________________________________________
Date: Apr 08, 2008
Obviously you are going through the time consuming process of panel planning. After beating around the bush for 2 months, I went with the SL30 as most of the threads here also indicate. I tried for a long time to save the extra two thousand plus dollars on the SL40 (radio only). I finally realized that it was false economy. Yes(Ron) you do need the additional CDI and Glide slope lights. The AFS3500 has (built in) the CDI indicators for guidance but you also need an audio panel for the Marker Beacon lights. Yes that is another $1000. My panel is being finished by the very nice folks at Aerotronics in Billings, MT. While I have not yet received the panel, I am very impressed with the excellent customer interaction and pro-active approach that Aerotronic takes. I got three bids on my panel, but went with them on my intuition and the advice of a member of the EAA advisory panel. I will give another report after I P/U the panel later this month. This is my thinking that this a a serous NVFR panel and will get me out of trouble if caught in IFR conditions. It seem to be a very cost effective setup. Probably could save more with Dynon AFS3500 (1x) Garmin SL30 Nav/Com Garmin 327 Mode "C" Transponder Garmin 340 Audio Garmin 496 Digiflight II VS Trutrak B/U ADI Backup 2.25" UMA Altimeter Backup 2.25" UMA A/S Backup 2.25" Xaon XRX TCAS Beta (talks to 496) PAI Vertical Card compass -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175661#175661 ________________________________________________________________________________
Date: Apr 09, 2008
Mike ....my 10 is just about ready to fly and as per email you can see my current setup and wanted to go from there. thanks anyway regards Chris ----- Original Message ----- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Wednesday, April 09, 2008 3:39 PM Subject: RV10-List: Re: NVFR avionics help > > Obviously you are going through the time consuming process of panel > planning. After beating around the bush for 2 months, I went with the SL30 > as most of the threads here also indicate. I tried for a long time to save > the extra two thousand plus dollars on the SL40 (radio only). I finally > realized that it was false economy. Yes(Ron) you do need the additional > CDI and Glide slope lights. The AFS3500 has (built in) the CDI indicators > for guidance but you also need an audio panel for the Marker Beacon > lights. Yes that is another $1000. My panel is being finished by the very > nice folks at Aerotronics in Billings, MT. While I have not yet received > the panel, I am very impressed with the excellent customer interaction and > pro-active approach that Aerotronic takes. I got three bids on my panel, > but went with them on my intuition and the advice of a member of the EAA > advisory panel. I will give another report after I P/U the panel later > this month. This is my thinking that this a a ! > serous NVFR panel and will get me out of trouble if caught in IFR > conditions. It seem to be a very cost effective setup. Probably could save > more with Dynon > > AFS3500 (1x) > Garmin SL30 Nav/Com > Garmin 327 Mode "C" Transponder > Garmin 340 Audio > Garmin 496 > Digiflight II VS > Trutrak B/U ADI Backup 2.25" > UMA Altimeter Backup 2.25" > UMA A/S Backup 2.25" > Xaon XRX TCAS Beta (talks to 496) > PAI Vertical Card compass > > -------- > OSH '08 or Bust > Q/B Kit - Ready to exit cabin top/door purgatory > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175661#175661 > > > ________________________________________________________________________________
Subject: ATP plug
Date: Apr 09, 2008
Just recieved visors from Aviation Tech Products. Came within 10 days to Australia and answered all questions . Great service. Chris 388 ________________________________________________________________________________
Date: Apr 09, 2008
When I went to install a set in my rv10, I modified them to be much easier to install. After seeing my mods coupled with the shipping delays I was asked to reproduce a similar product by a few builders. I think they are a very good anchor for the door rods to latch into, and should add a margin of strength to the latch mech. I do offer them on my website (available immediately ;) sorry for the commercial announcement, I just want all to know there are options... Steve dinieri Iflyrv10.com > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday, April 09, 2008 12:59 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: The King has no Clothes > > > I cannot imagine why anyone flying an RV10 does not install > the very excellent Rivethead door pins. They are tedious to > install and adjust, but they are really sweet and center the > closure on the door giving a positive feel when closing your > door plus the whole install feels very strong > > -------- > OSH '08 or Bust > Q/B Kit - Ready to exit cabin top/door purgatory > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175658#175658 > > > > > > > > Photoshare, and much much more: > > > ________________________________________________________________________________
Subject: Door handles
Date: Apr 09, 2008
Michael, i have been offering a handle kit similar to the Hendricks, but in a complete kit form, thinner in profile, specifically designed for the rv10. My design allows the latching system to remain in place as vans designed. when i started designing the handles the primary idea was to leave all the door latch mech alone. my handles simply replace the outside handle, just in a different position. they also allow standard lock cylinders for locking (just like the Hendricks) and i am introducing on the website this week a flush stainless lock system for all rv10's. easily installed into even flying aircraft. sorry to toot my own horn, but with all the talk about door and latches and the importance of such systems i just want all to know there are options... Steven dinieri iflyrv10.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Tuesday, April 08, 2008 9:33 AM Subject: RV10-List: Door handles With all the talk about the doors I've been doing some thinking regarding the factory setup vs the aftermarket handles. I like the flush look and operation of the handles like Hendricks and others but the lack of a positive locking detent really makes me nervous. I also want a way to lock the doors so they can't be opened by any passerby. The is especially important with the TSA rumblings that all GA aircraft must have locked doors. It's not a law yet but I wouldn't be surprised to see it conceded to stop something bigger. Frankly having the kind of investment in these aircraft that we do it's a bit silly to not have the doors locked somehow. I know, if a thief really wants in he will get in. But a thief also isn't going to stop at a plane with locks if a better target is around or if it will take too long or be too noticeable to circumvent them. So to that end someone had posted a while back a way to make a baggage door lock work with the standard Van's door handles. Anyone still have the links to that? Michael ________________________________________________________________________________
Date: Apr 09, 2008
Steven, I see that you've added many new products to your site. The elevator trim bracket and the aluminum door guides caught my eye. Are you reselling Rivethead-Aero's product or are you manufacturing these yourself? Thanks, Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, April 09, 2008 4:06 AM Subject: RE: RV10-List: Door handles Michael, i have been offering a handle kit similar to the Hendricks, but in a complete kit form, thinner in profile, specifically designed for the rv10. My design allows the latching system to remain in place as vans designed. when i started designing the handles the primary idea was to leave all the door latch mech alone. my handles simply replace the outside handle, just in a different position. they also allow standard lock cylinders for locking (just like the Hendricks) and i am introducing on the website this week a flush stainless lock system for all rv10's. easily installed into even flying aircraft. sorry to toot my own horn, but with all the talk about door and latches and the importance of such systems i just want all to know there are options... Steven dinieri iflyrv10.com ________________________________________________________________________________
Subject: RV Grin
Date: Apr 09, 2008
Great news Gary! I'm looking forward to seeing you, Brenda, and both your RVs this summer. My wife is definitely coming and is anxious to meet all the RV-10 spouses. Please let us know how your Phase I goes. See ya in 109 days! bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Tuesday, April 08, 2008 8:07 PM Subject: RV10-List: RV Grin N204GS flew for the first time today. I have been telling folks that it would be done on Tuesday ever since I started building. The airplane flew perfectly. Gary 40274 ________________________________________________________________________________
Date: Apr 09, 2008
Hi Chris, You'll need to replace (or add to) the SL-40 with an SL-30 which will give you a TSO'd VOR/LOC/GS. To this you will have to add an MD200 series CDI to maintain the TSO. Why don't you contact Jake (can't find his e-mail address at the moment) to confirm that you don't need anything else avionics wise? Also why noit try the Oz RV Yahoo group site? Looking forward to hearing about the first flight - Spring is in the air! Rodger --- On Wed, 9/4/08, Chris and Susie McGough wrote: > From: Chris and Susie McGough <VHMUM(at)bigpond.com> > Subject: Re: RV10-List: Re: NVFR avionics help > To: rv10-list(at)matronics.com > Date: Wednesday, 9 April, 2008, 8:13 AM > McGough" > > Mike ....my 10 is just about ready to fly and as per email > you can see my > current setup and wanted to go from there. > > thanks anyway regards Chris > > > ----- Original Message ----- > From: "AirMike" <Mikeabel(at)Pacbell.net> > To: > Sent: Wednesday, April 09, 2008 3:39 PM > Subject: RV10-List: Re: NVFR avionics help > > > "AirMike" > > > > Obviously you are going through the time consuming > process of panel > > planning. After beating around the bush for 2 months, > I went with the SL30 > > as most of the threads here also indicate. I tried for > a long time to save > > the extra two thousand plus dollars on the SL40 (radio > only). I finally > > realized that it was false economy. Yes(Ron) you do > need the additional > > CDI and Glide slope lights. The AFS3500 has (built in) > the CDI indicators > > for guidance but you also need an audio panel for the > Marker Beacon > > lights. Yes that is another $1000. My panel is being > finished by the very > > nice folks at Aerotronics in Billings, MT. While I > have not yet received > > the panel, I am very impressed with the excellent > customer interaction and > > pro-active approach that Aerotronic takes. I got three > bids on my panel, > > but went with them on my intuition and the advice of a > member of the EAA > > advisory panel. I will give another report after I P/U > the panel later > > this month. This is my thinking that this a a ! > > serous NVFR panel and will get me out of trouble if > caught in IFR > > conditions. It seem to be a very cost effective setup. > Probably could save > > more with Dynon > > > > AFS3500 (1x) > > Garmin SL30 Nav/Com > > Garmin 327 Mode "C" Transponder > > Garmin 340 Audio > > Garmin 496 > > Digiflight II VS > > Trutrak B/U ADI Backup 2.25" > > UMA Altimeter Backup 2.25" > > UMA A/S Backup 2.25" > > Xaon XRX TCAS Beta (talks to 496) > > PAI Vertical Card compass > > > > -------- > > OSH '08 or Bust > > Q/B Kit - Ready to exit cabin top/door purgatory > > > > > > > > > > Read this topic online here: > > > > > http://forums.matronics.com/viewtopic.php?p=175661#175661 > > > > > > > > > > > > > > > > > > > > > > > > ___________________________________________________________ Yahoo! For Good helps you make a difference http://uk.promotions.yahoo.com/forgood/ ________________________________________________________________________________
Subject: Re: P-Mag!
Date: Apr 09, 2008
I've had them for about 320 hours on my RV-7. Early on I had two failures and a third (which was my fault, you have to be very careful making the ignition wires). So I replaced one with a slick mag. The difference between the slick mag and the p-mag are very obvious when running the engine on only one mag (for testing, run-up etc.). Along the way, Brad and Tom were very helpful. More importantly, though, the last 160 hours or so have been flawless. So I can only deduce that they've worked out the bugs, at least based on my experience. If and when I build an RV-10 I'll put them on for sure. -------- Marc Ausman http://www.verticalpower.com RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175686#175686 ________________________________________________________________________________
Date: Apr 09, 2008
Subject: 2 blade Hartzell- SnF attendees
SnF Attendees; http://www.hartzellprop.com/pressroom/pr_htm/pr_11_09_07.htm Could someone walk over to Hartzell and ask if the 2 blade Carbon blade would be a good option for the RV-10? If so what would be needed to get one? I am thinking although it's for the Diamond DA40 now, Hartzell may provide it for other aircraft as well. Since the three blade is in the Cirrus this blade may very well work for us. Thanks! Pascal ________________________________________________________________________________
Date: Apr 09, 2008
Bob, RV6 pressure plot attached. The pressure areas on our 10's should be very similar if your using the stock cowl. The pressure does change depending on angle of attack. Here is another good site with lots of pressure data. Different airframe but the basic principles apply. http://www.melmoth2.com/ Bobby Hughes 40116 I am in the process of working the intake and exhaust heat flow and am wondering if anyone has done a field flow on the RV-10. It makes sense for air to exhaust into a low pressure area and enter in a high pressure area. Hense the need for the air field flow, if that is what it is called. Thanks in advance Bob K Baby steps along once I hit the finishing part. ________________________________________________________________________________
Date: Apr 09, 2008
KX 155 with a CDI would be pretty inexpensive compared to a TSO'd GPS and may give you good situational and back up... (http://travel.aol.com/travel-guide/united-states?ncid=aoltrv00030000000016) ________________________________________________________________________________
Date: Apr 09, 2008
Gary, your work speaks for itself! Deems gary wrote: > > Unlike Deems I am not a very good documenter of my work, but here are > a few pix. > > > > ________________________________________________________________________________
Date: Apr 09, 2008
Bob, i make all my own parts. They are modified versions I made for myself and decided to offer on the website. Check the site often as I'm adding new stuff all the time. Next up are lightweight fiberglass interior trim panels, and a leather interior handle cover. steven dinieri iflyrv10.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, April 09, 2008 6:34 AM Subject: RE: RV10-List: Door handles Steven, I see that you've added many new products to your site. The elevator trim bracket and the aluminum door guides caught my eye. Are you reselling Rivethead-Aero's product or are you manufacturing these yourself? Thanks, Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, April 09, 2008 4:06 AM Subject: RE: RV10-List: Door handles Michael, i have been offering a handle kit similar to the Hendricks, but in a complete kit form, thinner in profile, specifically designed for the rv10. My design allows the latching system to remain in place as vans designed. when i started designing the handles the primary idea was to leave all the door latch mech alone. my handles simply replace the outside handle, just in a different position. they also allow standard lock cylinders for locking (just like the Hendricks) and i am introducing on the website this week a flush stainless lock system for all rv10's. easily installed into even flying aircraft. sorry to toot my own horn, but with all the talk about door and latches and the importance of such systems i just want all to know there are options... Steven dinieri iflyrv10.com ________________________________________________________________________________
Date: Apr 09, 2008
Subject: Engine stop tests.
Something that I was playing with (experimenting is too strong a word) is when the engine dies (in my case idling) and is still turning - if you pull the prop out the RV10 takes a leap forward. Does the glide range increase with the prop all the way out? Is this in fact the standard emergency procedure with a constant speed prop? It seems that the engine turning would power the oil pump and could turn the blades to full coarse decreasing the drag. Any comments? My previous constant speed prop experience was just sufficient to get my high performance signoff. Bill DeRouchey N939SB, flying "John W. Cox" wrote: Fabulous detail and invaluable research. We need more of this stuff and less accident reporting. By the way, did you go with the stock James engine cowl? The Warbirds acts as breathtaking as the setting at Wanaka. See you for OSH '08. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 10:48 AM Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind you have little or no oil pressure, then there is very little time to coursen up the prop to minimise drag. And if you are thinking of saving the engine on your forced landing, then you need to drop the flap and stall for a while to get the engine to stop. So what a fun evening. Just wish I had taken the camera with me. If anyone else has done such tests, it would be great to hear from you. Or if anyone has any other thoughts on such matters. Neil ps- Take off with Sarah PIC at Warbirds over Wanaka a couple of weeks back. Osh may be bigger, but Wanaka surely has the best setting anywhere for an airshow. ________________________________________________________________________________
Subject: Re: Engine stop tests.
Date: Apr 10, 2008
The glide definitely got better at full coarse, but when it stopped, there was obviously no oil pressure, and so we were unable to change pitch. I have no idea if it's standard proceedure, but it was what I was taught to do. Neil ZK-RVT Not flying - sitting at a computer instead. However, both Sarah & I did our first night flying last night. It was great. Although as virtually no one in NZ is RV 10 rated, we had to revert to C152's - aarrgghh. Although it was a bit like meeting a crusty old family friend. There is no doubt that we are spoiled with Vans. I really did miss the EFIS & GPS though. On 10/04/2008, at 4:09 AM, Bill DeRouchey wrote: > Something that I was playing with (experimenting is too strong a > word) is when the engine dies (in my case idling) and is still > turning - if you pull the prop out the RV10 takes a leap forward. > Does the glide range increase with the prop all the way out? Is this > in fact the standard emergency procedure with a constant speed prop? > > It seems that the engine turning would power the oil pump and could > turn the blades to full coarse decreasing the drag. > > Any comments? My previous constant speed prop experience was just > sufficient to get my high performance signoff. > > Bill DeRouchey > N939SB, flying > ________________________________________________________________________________
Date: Apr 09, 2008
Subject: Re: P-Mag!
Have they released a Lyc 6 cylinder model? I know they have been developing one. Maybe one of you at Sun-N-Fun could fill us in. Thye are in building D space #93. Larry RV Builder (Michael Sausen) wrote: > > I think Jesse only builds RV-10's so I doubt it. They are just now releasing their 6cyl models so I don't think there have been any significant hours built up to give a good idea on their MTBF. If you search various archives of the 4cyl homebuilts you will find a lot's of references from one extreme to the other. Overall they seem to have an excellent idea but have been plagued with lots of gremlins in their design. Many people have had no problems but it seems an equal number of people have had consistent problems. > > I for one really hope they get all their problems licked and end up with a solid product. Lots of potential there and they seem to e steadily improving. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard > Sent: Tuesday, April 08, 2008 5:22 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: P-Mag! > > > Jesse, > > Can you share any experiences you have had with the PMags? Put any in your planes? Any recent problems that you are aware of? > > Thanks, > > Nick > > -------- > Nick Leonard > RV-10 (40015) Finish > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175573#175573 > > > ________________________________________________________________________________
Date: Apr 09, 2008
I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes I cannot imagine why anyone flying an RV10 does not install the very excellent Rivethead door pins. They are tedious to install and adjust, but they are really sweet and center the closure on the door giving a positive feel when closing your door plus the whole install feels very strong -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175658#175658 ________________________________________________________________________________
Subject: Engine Special
Date: Apr 09, 2008
Vans has a nice discount on three (was four, but I just bought one) XIO-540-D4A5 engines just posted on the website. On your marks... get set... go! Jeff Carpenter 40304 ________________________________________________________________________________
Date: Apr 09, 2008
My general comment would be no, I do not have any concerns. The end of the rod was already threaded per plans and all I did was fill them. ( Not exactly since I cut and threaded the rods again to shorten them.) But, they are not real tight. After 25 flight hours and the web traffic from last week, I inspected them and did not see any signs of wear. I rechecked their alignment and put some locktite on the threads. I installed mine per the video and thus they do not extend all the way into the cabin frame, only into the block itself. I am re-thinking that..... Also, when you install the blocks there is very little room between the AL blocks and the nylon blocks in the door. I had to cut down the blocks on the door just to get the door to close. I think this closer tolerance helps to reduce the stress on the rod itself. Rene' Felker RV-10 N423CF Flying 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 3:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes ________________________________________________________________________________
Date: Apr 09, 2008
I am concerned about it. Not sure how to fix it though. PJ Seipel RV-10 #40032 Scott Schmidt wrote: > I have ordered the Rivethead door pins and I'm looking forward to > installing them. > Is anyone concerned about cutting the door rod and having a weak point > where it threads in? > Does anyone have any concerns about the system being less robust than > the standard rods? > > Scott Schmidt > scottmschmidt(at)yahoo.com > > > ----- Original Message ---- > From: AirMike <Mikeabel(at)Pacbell.net> > To: rv10-list(at)matronics.com > Sent: Tuesday, April 8, 2008 10:58:54 PM > Subject: RV10-List: Re: The King has no Clothes > > * > > > * ________________________________________________________________________________
Date: Apr 09, 2008
Scott: You just cut off the pointed end of the rod, and tap it with a 5/16-24 tap, screw the point in, and set it with some lok-tite. Works like a charm. Steve Mills N750SM (reserved) RV-10 40486 Slow-build Eggenfellner E-6TI Naperville, Illinois Finishing kit, engine install _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 4:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes ________________________________________________________________________________
Date: Apr 09, 2008
The one thing about the Rivethead receiver/pins arrangement that I'm not comfortable with is that they are designed so that the machined pins are captured by the receiver itself and do not project through the door frame and the intercostal. IF (Big IF!!!) the fit of the doors is such that there is some room for them to shift fore and aft, AND IF (another BIG IF!!!) the pressure inside the cabin is enough to cause some deformation and 'bowing' of the door itself, there MIGHT be a case for the pins pulling out of the receiver and opening. HOWEVER, if the pins are inserted so that they pass all of the way through the receivers and the doorframes / intercostals, this is a MUCH less likely scenario. I think the down side is that with the longer pins, it raises the risk of the pins being exposed and damaging the paint in that region. I fit mine so they are longer and project through the door and frame, BUT I definitely have the likelihood for paint damage. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Scott Schmidt wrote: > I have ordered the Rivethead door pins and I'm looking forward to > installing them. > Is anyone concerned about cutting the door rod and having a weak point > where it threads in? > Does anyone have any concerns about the system being less robust than > the standard rods? > > Scott Schmidt > scottmschmidt(at)yahoo.com > > * > * ________________________________________________________________________________
Date: Apr 09, 2008
I'm a little naive here since I'm just building wings. Couldn't somebody like Rivethead-Aero or Steven DiNieri make new longer rods? I'm assuming that the short pins they send are screwed into existing rods. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 5:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes ________________________________________________________________________________
Date: Apr 09, 2008
I can make pins as long as needed, but consider the loads on the door pins are in shear. The likelihood that the rods or end pins break would be very low given that the doors (uhmw blocks) are touching the blocks in the door jamb. There is very little space. It would take a lot of force to shear a steel line with a stainless fastener threaded within. More likely would be the door flexing as deems pointed out or the blocks themselves tearing out somehow. Once installed and operating it's quite apparent that the guides and pins door fastener system is much more secure than the factory setup. With the factory setup you can get some fore aft movement out of the door even after its been latched. Your mileage may vary.. Steven dinieri Iflyrv10.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, April 09, 2008 7:04 PM Subject: RE: RV10-List: Re: The King has no Clothes I'm a little naive here since I'm just building wings. Couldn't somebody like Rivethead-Aero or Steven DiNieri make new longer rods? I'm assuming that the short pins they send are screwed into existing rods. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 5:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 09, 2008
My impression is that N416EC was a Saint Aviation, VANS directive, Factory approved "Standard Install". Hence the header "The King has no clothes". All of those followers in the crowd to the "As Written Instructions" might reflect careful on this particular style of installation. Every improvement is worth the pursuit. I have enjoyed the discussion and the enlightenment..... So Thank You all. Four good people and three fine aircraft lost in six months is simply too many. JC ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, April 09, 2008 4:49 PM Subject: RE: RV10-List: Re: The King has no Clothes I can make pins as long as needed, but consider the loads on the door pins are in shear. The likelihood that the rods or end pins break would be very low given that the doors (uhmw blocks) are touching the blocks in the door jamb. There is very little space. It would take a lot of force to shear a steel line with a stainless fastener threaded within. More likely would be the door flexing as deems pointed out or the blocks themselves tearing out somehow. Once installed and operating it's quite apparent that the guides and pins door fastener system is much more secure than the factory setup. With the factory setup you can get some fore aft movement out of the door even after its been latched. Your mileage may vary.... Steven dinieri Iflyrv10.com ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, April 09, 2008 7:04 PM Subject: RE: RV10-List: Re: The King has no Clothes I'm a little naive here since I'm just building wings. Couldn't somebody like Rivethead-Aero or Steven DiNieri make new longer rods? I'm assuming that the short pins they send are screwed into existing rods. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 5:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Engine Special
Date: Apr 09, 2008
where did u find these one the site ----- Original Message ----- From: Jeff Carpenter<mailto:jeff(at)westcottpress.com> To: rv10-list(at)matronics.com Sent: Wednesday, April 09, 2008 6:11 PM Subject: RV10-List: Engine Special > Vans has a nice discount on three (was four, but I just bought one) XIO-540-D4A5 engines just posted on the website. On your marks... get set... go! Jeff Carpenter 40304 http://www.matronics.com/Navigator?RV10-List igator?RV10-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Apr 09, 2008
After the 416EC thing surfaced I called the consulting engineer for my project (actually the neighbor lady with a PhD in ME from Caltech). After discussion she suggested several things. The flexing of the door could be stiffened by additional glass ion the inner side, preferably in the shape of an angle running fore to aft. Secondly she made the point that the fatigue ratio of stainless to aluminum is a factor of 10. If one is concerned about the working cycle of bending and scraping these pins to close the door, a thousand cycles could be of concern. As for me, mine is ready to fly with the standard closure but down the road I will seriously consider the replacement of the pins and the door bulkhead bushings with stainless. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Wednesday, April 09, 2008 3:29 PM Subject: RE: RV10-List: Re: The King has no Clothes My general comment would be no, I do not have any concerns. The end of the rod was already threaded per plans and all I did was fill them. ( Not exactly since I cut and threaded the rods again to shorten them.) But, they are not real tight. After 25 flight hours and the web traffic from last week, I inspected them and did not see any signs of wear. I rechecked their alignment and put some locktite on the threads. I installed mine per the video and thus they do not extend all the way into the cabin frame, only into the block itself. I am re-thinking that..... Also, when you install the blocks there is very little room between the AL blocks and the nylon blocks in the door. I had to cut down the blocks on the door just to get the door to close. I think this closer tolerance helps to reduce the stress on the rod itself. Rene' Felker RV-10 N423CF Flying 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 3:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes
Date: Apr 09, 2008
Are you saying that both doors were not found at each crash site? That certainly is one of my questions for the last two fatals _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Wednesday, April 09, 2008 5:13 PM Subject: RE: RV10-List: Re: The King has no Clothes My impression is that N416EC was a Saint Aviation, VANS directive, Factory approved "Standard Install". Hence the header "The King has no clothes". All of those followers in the crowd to the "As Written Instructions" might reflect careful on this particular style of installation. Every improvement is worth the pursuit. I have enjoyed the discussion and the enlightenment... So Thank You all. Four good people and three fine aircraft lost in six months is simply too many. JC _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, April 09, 2008 4:49 PM Subject: RE: RV10-List: Re: The King has no Clothes I can make pins as long as needed, but consider the loads on the door pins are in shear. The likelihood that the rods or end pins break would be very low given that the doors (uhmw blocks) are touching the blocks in the door jamb. There is very little space. It would take a lot of force to shear a steel line with a stainless fastener threaded within. More likely would be the door flexing as deems pointed out or the blocks themselves tearing out somehow. Once installed and operating it's quite apparent that the guides and pins door fastener system is much more secure than the factory setup. With the factory setup you can get some fore aft movement out of the door even after its been latched. Your mileage may vary.. Steven dinieri Iflyrv10.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, April 09, 2008 7:04 PM Subject: RE: RV10-List: Re: The King has no Clothes I'm a little naive here since I'm just building wings. Couldn't somebody like Rivethead-Aero or Steven DiNieri make new longer rods? I'm assuming that the short pins they send are screwed into existing rods. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, April 09, 2008 5:56 PM Subject: Re: RV10-List: Re: The King has no Clothes I have ordered the Rivethead door pins and I'm looking forward to installing them. Is anyone concerned about cutting the door rod and having a weak point where it threads in? Does anyone have any concerns about the system being less robust than the standard rods? Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Tuesday, April 8, 2008 10:58:54 PM Subject: RV10-List: Re: The King has no Clothes http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 09, 2008
Main page on bottom (scroll down) http://www.vansaircraft.com/images/open/Lyc-snf.jpg ----- Original Message ----- From: John Cram To: rv10-list(at)matronics.com Sent: Wednesday, April 09, 2008 5:56 PM Subject: Re: RV10-List: Engine Special where did u find these one the site ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Wednesday, April 09, 2008 6:11 PM Subject: RV10-List: Engine Special Vans has a nice discount on three (was four, but I just bought one) XIO-540-D4A5 engines just posted on the website. On your marks... get set... go! Jeff nbsp; Navigator Photoshare, and title=http://www.matronics.com/Navigator?RV10-List href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com nbsp; generous bsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c ================ ________________________________________________________________________________
Date: Apr 09, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I installed a set of Steven's on my plane and am really happy with them. I really wanted flush handles and one of the criteria was that they preserve the locking feature of the stock handles. Bob #40105 The big move to the airport this Sunday... _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, April 09, 2008 10:47 AM Subject: RE: RV10-List: Door handles Bob, i make all my own parts. They are modified versions I made for myself and decided to offer on the website. Check the site often as I'm adding new stuff all the time. Next up are lightweight fiberglass interior trim panels, and a leather interior handle cover... steven dinieri iflyrv10.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, April 09, 2008 6:34 AM Subject: RE: RV10-List: Door handles Steven, I see that you've added many new products to your site. The elevator trim bracket and the aluminum door guides caught my eye. Are you reselling Rivethead-Aero's product or are you manufacturing these yourself? Thanks, Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DiNieri Sent: Wednesday, April 09, 2008 4:06 AM Subject: RE: RV10-List: Door handles Michael, i have been offering a handle kit similar to the Hendricks, but in a complete kit form, thinner in profile, specifically designed for the rv10. My design allows the latching system to remain in place as vans designed. when i started designing the handles the primary idea was to leave all the door latch mech alone. my handles simply replace the outside handle, just in a different position. they also allow standard lock cylinders for locking (just like the Hendricks) and i am introducing on the website this week a flush stainless lock system for all rv10's. easily installed into even flying aircraft. sorry to toot my own horn, but with all the talk about door and latches and the importance of such systems i just want all to know there are options... Steven dinieri iflyrv10.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Doors coming off
Date: Apr 10, 2008
Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris ________________________________________________________________________________
Date: Apr 09, 2008
Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris ________________________________________________________________________________
Date: Apr 09, 2008
Bill, This info is based on my understanding of the props, if I'm off base someone please chime in. Doesn't that make you feel confident about what I'm about to write ;) The non-reversing constant speed props (like on the -10) are designed to go flat pitch in the event of a loss of oil pressure. The main concern is if you have to execute a go-around or steep climb you want the high RPM available for performance. I think what you are experiencing is simply increased thrust by going more coarse on the pitch while there's still oil pressure. Once the prop stops I seriously doubt there is a significant difference in drag between flat and coarse pitch. So first, I don't think you can control the pitch as the engine quits and second I don't think it would make a difference. Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey Sent: Wednesday, April 09, 2008 11:10 AM Subject: RE: RV10-List: Engine stop tests. Something that I was playing with (experimenting is too strong a word) is when the engine dies (in my case idling) and is still turning - if you pull the prop out the RV10 takes a leap forward. Does the glide range increase with the prop all the way out? Is this in fact the standard emergency procedure with a constant speed prop? It seems that the engine turning would power the oil pump and could turn the blades to full coarse decreasing the drag. Any comments? My previous constant speed prop experience was just sufficient to get my high performance signoff. Bill DeRouchey N939SB, flying "John W. Cox" wrote: Fabulous detail and invaluable research. We need more of this stuff and less accident reporting. By the way, did you go with the stock James engine cowl? The Warbirds acts as breathtaking as the setting at Wanaka. See you for OSH '08. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 10:48 AM Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind ________________________________________________________________________________
Subject: RV Grin
Date: Apr 09, 2008
Way to go Gary, and congratulations on getting it finished on time! Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Tuesday, April 08, 2008 7:07 PM Subject: RV10-List: RV Grin N204GS flew for the first time today. I have been telling folks that it would be done on Tuesday ever since I started building. The airplane flew perfectly. Gary 40274 ________________________________________________________________________________
Date: Apr 09, 2008
One other idea we had was the placement of a knob on the door inside, back near the pin. this will allow complete control (two hands pulling) of positioning the door for closure. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 09, 2008
The original prototype door on N410RV incurred damage during a x-cnty airshow trip to Colorado. As I remember the canopy and door assemblies off N220RV were removed as a quick fix and integral completed "total unit" as a Second Iteration prototype build and used to repair N410RV. All of the early kits going back to Randy s/n 006 and John Nys s/n 047 were the 220RV Gen II type. I believe 416EC s/n 416 was still this same type. Since then, several improvements (alternations have been included) aftermarket which is the thrill of this group, the open discussion, the talent of the individuals and the desire to pursue excellence in build. Tim did an excellent explanation on the Taper. I am opposed to what I believe is in the plans (that should be nothing new to anyone). The Strike plate idea is a corrective measure for the high likelihood that operators will try to close a door with the aft pin partially extended. My review of the 416EC pictures shows an alignment and strike issue with the Pilot's plate. I believe that other than in Tim's "safety locked" scenario this system might allow an opening or movement at a critical point in time. The Rack systems should not allow continued retraction of an engaged pin during flight. I believe the taper needs to be oriented to the interior never the exterior. I believe the pin needs to be "fully" engaged into the metal door pillar. I believe the UMHD is not adequate for a long term receptacle. The view of 416EC showed significant stress forces on the mounting hardware. I believe a handhold which pulls the door down and closed positively even with a door ajar "in-flight" is a wise design change. Within this body of personal opinion are several quality improvements which need universal illumination. For those with the second generation door & latch (220RV). I would like to see 416EC the last RV-10 to ever suffer latch release and premature door departure in flight. Pilots are human, mistakes happen, the door handle might not always get "safety latched" and remain so. The secondary latch on the leading edge or a boldly relocated hinge set like on Cirrus can sure get the discussion stirred. Let's keep the sharp eyes focused at SNF and less mud on the field. There is lots to learn. Think Safety, Fly Safe. John C. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 09, 2008
Two ways to flatten a coarse pitch to fine pitch in the event of engine failure with a Constant Speed Prop Assembly . Adequate Oil Pressure or Counter weights. With the choice of no weights, the reaction time on the prop control is a important skill set. Low pressure - Lots of Luck. Neil gave a great example of the loss of altitude and significant increase in airframe speed necessary to overcome loss of adequate oil pressure. Loose your oil..... Think fast, move faster. Fly the aircraft safely to a walk away landing. - Bob Hoover. Get some practice with a dead engine in course pitch and again in fine pitch. It will drive home the importance in no short order. Practice, practice, practice with lots of altitude and options. John C ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Wednesday, April 09, 2008 8:31 PM Subject: RE: RV10-List: Engine stop tests. Bill, This info is based on my understanding of the props, if I'm off base someone please chime in. Doesn't that make you feel confident about what I'm about to write ;) The non-reversing constant speed props (like on the -10) are designed to go flat pitch in the event of a loss of oil pressure. The main concern is if you have to execute a go-around or steep climb you want the high RPM available for performance. I think what you are experiencing is simply increased thrust by going more coarse on the pitch while there's still oil pressure. Once the prop stops I seriously doubt there is a significant difference in drag between flat and coarse pitch. So first, I don't think you can control the pitch as the engine quits and second I don't think it would make a difference. Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey Sent: Wednesday, April 09, 2008 11:10 AM Subject: RE: RV10-List: Engine stop tests. Something that I was playing with (experimenting is too strong a word) is when the engine dies (in my case idling) and is still turning - if you pull the prop out the RV10 takes a leap forward. Does the glide range increase with the prop all the way out? Is this in fact the standard emergency procedure with a constant speed prop? It seems that the engine turning would power the oil pump and could turn the blades to full coarse decreasing the drag. Any comments? My previous constant speed prop experience was just sufficient to get my high performance signoff. Bill DeRouchey N939SB, flying "John W. Cox" wrote: Fabulous detail and invaluable research. We need more of this stuff and less accident reporting. By the way, did you go with the stock James engine cowl? The Warbirds acts as breathtaking as the setting at Wanaka. See you for OSH '08. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 10:48 AM To: rv10-list(at)matronics.com Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 09, 2008
I'm starting to think of a simple and inexpensive design. Like our co-builder Mr. Leffler, I'm still a ways away from reaching this point. However I've heard of a few RV-10's with handles that allow the door to be pulled down when you're sitting in the seat. I'm thinking of making this pull down strap out of some higher strength material and actually hooking it inside the cabin to a fixed point. If it's done correctly, the handles will be functional and a open-door scenario could result in only a couple of inches worth of opening. Sure it would be a distraction if you had to fly the plane with a door that was cracked open a few inches, but it sure beats having the door remove your Horizontal Stab and tear up your airplane. It's cheap, simple, fool proof, and practical. Phil ________________________________ From: David McNeill [mailto:dlm46007(at)cox.net] Sent: Wednesday, April 09, 2008 10:40 PM Subject: RE: RV10-List: Doors coming off One other idea we had was the placement of a knob on the door inside, back near the pin. this will allow complete control (two hands pulling) of positioning the door for closure. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 09, 2008
Subject: Re: Doors coming off
410RV was right at 1000 hours last summer. Probably has a couple hundred more by now. On Wed, Apr 9, 2008 at 7:55 PM, Chris and Susie McGough wrote: > Guys are we 100% sure that the doors that have come off were latched > corectly where they go into the fuse frames. > > Are we sure that the door handles were closed properly and in the locked > position? > . > Remember the tunnel heat problem, some have the problem but most do not. > > I would think Vans 10 would have close to 1000 hours on it , why has the > door not come off?? Does someone live close to Vans that can have a look and > maybe do some measuring ? > > I am absolutely not saying there is no problem just need some facts > > I have written to Vans to the engieering department to see what they say > > regards Chris > > * > > * > > ________________________________________________________________________________
Subject: Re: The King has no Clothes
Date: Apr 09, 2008
Folks, here is the Rivethead setup on our plane - Our parts were among the first made, and came sans instructions, so we proceeded to install them using what common sense was available... :-) We cut the aluminum tubing latch pins, which had already been internally threaded for the standard installation, to a length that left the Rivethead bullet ends protruding just 1/16" or so out of the plastic block on the door with the door latch handle in in the fully open (pins retracted) position. In the fully closed position, the bullet ends protrude through the Rivethead aluminum block, through the glass doorframe, and through the heavy aluminum vertical F1005C and F1042 Bulkhead Side Channels by 1/4" or more. "Receiver" is the name Deems uses for the block - I like it! The joint where the bullet end butts up against the aluminum tubing latch pin is completely contained in the "receiver". The joint thus takes almost no loads at all. The aluminum tubing latch pins take all the load in shear over a very short distance - the plastic block in the door tries to move outward and the "receiver" stubbornly refuses to go along. I'm not sure, but I think the threaded end of the bullet fills the interior of the aluminum tube in the area subjected to the shear load. I can 't see an even remotely likely structural failure mode _provided_that_the_ doors_ are_closed _and_ latched_properly. Knock wood! The receiver is held in place by two #10 screws that pass through the side channels and fiberglass door frame and into the receiver; they carry the forces on the block to the airframe structure (Bulkhead Side Channels) Oh yeah - the doors close very easily (provided the little pins attaching the latch pins to the racks don't get hung up) and the latchup seems extremely solid. I can't detect any relative motion at all when I grab the door and shake it. John Ackerman 40458 On Apr 9, 2008, at 3:51 PM, Deems Davis wrote: > > The one thing about the Rivethead receiver/pins arrangement that I'm > not comfortable with is that they are designed so that the machined > pins are captured by the receiver itself and do not project through > the door frame and the intercostal. IF (Big IF!!!) the fit of the > doors is such that there is some room for them to shift fore and > aft, AND IF (another BIG IF!!!) the pressure inside the cabin is > enough to cause some deformation and 'bowing' of the door itself, > there MIGHT be a case for the pins pulling out of the receiver > and opening. > HOWEVER, if the pins are inserted so that they pass all of the way > through the receivers and the doorframes / intercostals, this is a > MUCH less likely scenario. I think the down side is that with the > longer pins, it raises the risk of the pins being exposed and > damaging the paint in that region. I fit mine so they are longer and > project through the door and frame, BUT I definitely have the > likelihood for paint damage. > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > Scott Schmidt wrote: >> I have ordered the Rivethead door pins and I'm looking forward to >> installing them. >> Is anyone concerned about cutting the door rod and having a weak >> point where it threads in? Does anyone have any concerns about the >> system being less robust than the standard rods? >> Scott Schmidt >> scottmschmidt(at)yahoo.com >> >> * >> * > > ________________________________________________________________________________
Date: Apr 10, 2008
Isn't the idea of the taper to the outside, to ensure capture of the block and thereafter apply a leverage to firmly pull the door closed and into alignment? John 40315 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Thursday, 10 April 2008 2:08 PM Subject: RE: RV10-List: Doors coming off The original prototype door on N410RV incurred damage during a x-cnty airshow trip to Colorado. As I remember the canopy and door assemblies off N220RV were removed as a quick fix and integral completed "total unit" as a Second Iteration prototype build and used to repair N410RV. All of the early kits going back to Randy s/n 006 and John Nys s/n 047 were the 220RV Gen II type. I believe 416EC s/n 416 was still this same type. Since then, several improvements (alternations have been included) aftermarket which is the thrill of this group, the open discussion, the talent of the individuals and the desire to pursue excellence in build. Tim did an excellent explanation on the Taper. I am opposed to what I believe is in the plans (that should be nothing new to anyone). The Strike plate idea is a corrective measure for the high likelihood that operators will try to close a door with the aft pin partially extended. My review of the 416EC pictures shows an alignment and strike issue with the Pilot's plate. I believe that other than in Tim's "safety locked" scenario this system might allow an opening or movement at a critical point in time. The Rack systems should not allow continued retraction of an engaged pin during flight. I believe the taper needs to be oriented to the interior never the exterior. I believe the pin needs to be "fully" engaged into the metal door pillar. I believe the UMHD is not adequate for a long term receptacle. The view of 416EC showed significant stress forces on the mounting hardware. I believe a handhold which pulls the door down and closed positively even with a door ajar "in-flight" is a wise design change. Within this body of personal opinion are several quality improvements which need universal illumination. For those with the second generation door & latch (220RV). I would like to see 416EC the last RV-10 to ever suffer latch release and premature door departure in flight. Pilots are human, mistakes happen, the door handle might not always get "safety latched" and remain so. The secondary latch on the leading edge or a boldly relocated hinge set like on Cirrus can sure get the discussion stirred. Let's keep the sharp eyes focused at SNF and less mud on the field. There is lots to learn. Think Safety, Fly Safe. John C. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 10, 2008
I have a pull down strap mounted to the front lower part of the door which hangs down about 18 inches and allows me to pull the door down for closure. I also have a door handle mounted to the rear part of the door that I can grip and pull in the rear of the door with one hand while pushing the door handle closed which I find essential in getting both the front pin and rear pin sealed. Under no circumstances would I ever consider any type of door pin that did not go all the way through the door frame. Essential to me is the ability to manually feel the door pin on the backside of the front and rear door frame to insure the pins are fully seated before I take off. Russ Daves N710RV - 200+ hours ________________________________________________________________________________
Date: Apr 10, 2008
As an addition to the standard setup I am going to use a steel set screw from Mcmaster Carr to thread inside the aluminum tube to cover the area of the tube carrying the shear load. I do agree that rear door handle will greatly assist in pulling in the door so that the pins insert correctly. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves Sent: Thursday, April 10, 2008 4:25 AM Subject: RV10-List: Doors coming off I have a pull down strap mounted to the front lower part of the door which hangs down about 18 inches and allows me to pull the door down for closure. I also have a door handle mounted to the rear part of the door that I can grip and pull in the rear of the door with one hand while pushing the door handle closed which I find essential in getting both the front pin and rear pin sealed. Under no circumstances would I ever consider any type of door pin that did not go all the way through the door frame. Essential to me is the ability to manually feel the door pin on the backside of the front and rear door frame to insure the pins are fully seated before I take off. Russ Daves N710RV - 200+ hours ________________________________________________________________________________
Date: Apr 10, 2008
I'm sure they will say Yes. Check any lockset or latchset for the logic of tapered pins on any door of a residential or commercial building. The only exception I can think of is an armory or bank vault door. I still stand my the logic for the taper to go opposite the plan. Oh yeh, and the pins to be fully retracted before a closure attempt. Just think of a deadbolt doing damage if not retracted. John C ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne Sent: Wednesday, April 09, 2008 11:23 PM Subject: RE: RV10-List: Doors coming off Isn't the idea of the taper to the outside, to ensure capture of the block and thereafter apply a leverage to firmly pull the door closed and into alignment? John 40315 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox Sent: Thursday, 10 April 2008 2:08 PM Subject: RE: RV10-List: Doors coming off The original prototype door on N410RV incurred damage during a x-cnty airshow trip to Colorado. As I remember the canopy and door assemblies off N220RV were removed as a quick fix and integral completed "total unit" as a Second Iteration prototype build and used to repair N410RV. All of the early kits going back to Randy s/n 006 and John Nys s/n 047 were the 220RV Gen II type. I believe 416EC s/n 416 was still this same type. Since then, several improvements (alternations have been included) aftermarket which is the thrill of this group, the open discussion, the talent of the individuals and the desire to pursue excellence in build. Tim did an excellent explanation on the Taper. I am opposed to what I believe is in the plans (that should be nothing new to anyone). The Strike plate idea is a corrective measure for the high likelihood that operators will try to close a door with the aft pin partially extended. My review of the 416EC pictures shows an alignment and strike issue with the Pilot's plate. I believe that other than in Tim's "safety locked" scenario this system might allow an opening or movement at a critical point in time. The Rack systems should not allow continued retraction of an engaged pin during flight. I believe the taper needs to be oriented to the interior never the exterior. I believe the pin needs to be "fully" engaged into the metal door pillar. I believe the UMHD is not adequate for a long term receptacle. The view of 416EC showed significant stress forces on the mounting hardware. I believe a handhold which pulls the door down and closed positively even with a door ajar "in-flight" is a wise design change. Within this body of personal opinion are several quality improvements which need universal illumination. For those with the second generation door & latch (220RV). I would like to see 416EC the last RV-10 to ever suffer latch release and premature door departure in flight. Pilots are human, mistakes happen, the door handle might not always get "safety latched" and remain so. The secondary latch on the leading edge or a boldly relocated hinge set like on Cirrus can sure get the discussion stirred. Let's keep the sharp eyes focused at SNF and less mud on the field. There is lots to learn. Think Safety, Fly Safe. John C. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris http://www.matronics.com/contribution - The RV10-List Email Forum - Thank you for your generous support! --> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 10, 2008
It's interesting that this thread is sticking around so long this time...that's good, it breeds awareness. First, in regards to the problem, those (I've read this a.m.'s posts already) who are saying that the issue is an alignment issue, are correct. The problem is, the door handle is forward on the door, and when you pull in to close it, the front of the door pulls in, but the back doesn't pull in as far. So, then you go to latch it, and the back pin hits the nylon block or the door frame. Thinner door seals might help. I can't say I'm unhappy with the ones that came with the kit though, because they seal very well...never had a plane with such well sealed doors. But, yes, with thinner seals this issue could be helped a bit. One of the big improvements would be to have a pull handle centered on the door, or a secondary pull handle on the aft part of the door. The problem there is that, while I'm a chunky monkey, I'm still under 40, and yet it isn't super easy to twist around with the seat in the way, to pull a handle in. So you're still going to have to take care. In short, this problem exists because of the way you pull the door shut, and requires that you pull it shut nicely before you try to engage the pins. To me, if you still have all of the OTHER components left the same, you're still going to have a hard time regardless of if you use the rivethead pins or the standard, because you NEED to get the alignment good before you try to latch, or the pins hit the block and you get a nasty noise. This is NOT a dig on them, because I see benefits to their system. But, the video that was originally put out, where they dropped the door in place and latched it, is a little misleading, because if you have nice tightly sealed door seals, latching it won't be as easy as pictured. I'd love to fly in a plane with alternative door seals to see how tight they seal, and then perhaps I'd consider them, but I am thus far happy with the standard ones because of the sealing. John A, thanks for your description of the installation. Very much appreciated. I'm still not 100% comfortable with having the threaded area anywhere near the spot that if cracked, would cause the major failure, but at least it gives me a little more comfort. Ideally, to me, those pins would be very long and done before you build the door completely. But, I would have a harder time installing those anyway. John C, I appreciate your discomfort with the taper, but really, I think the pins at least need a bullet nose to aid in centering. The taper is probably overkill, but I don't think an opposite taper would do any more than cause more damage...a bullet tip is probably the ideal. Certainly, without the taper I have now, given the standard install, I would not have had good luck with an opposite taper...I would have even worse paint chip issues. Wayne H, You're right on with the reasons...good job. Now, a couple other topics.... 1) RE: front hinges. Not a bad concept. But, I think it would be much harder to design a robust strong and light door with strong enough hinges, and you'd have to be really careful when the door sags or you could crack it. Better? From a door flying off standpoint, sure, but it definitely would require more care, and a totally overall stronger design, more expense, and all that. So I can see why Van's opted for what they did. 2) Re: Closing Doors. Personally, other than my wife, I try never to ALLOW anyone else to close and latch my doors. On one of my earlier flights, a co-worker reached up, grabbed the door, and SLAM! Slammed it down...thinking it was auto latching like a car door. That sent shivers down my spine, so after that I decided to inconvenience my passengers and insist on me latching it. Also, one of the nice things I did during the build was go real slow in trimming that drip edge on the sides of the door. What this did for me is make the side gap almost NOTHING if the door is closed tightly. So, in my plane, it's ABSOLUTELY visible by a quick glance if you have the door in the proper position to latch, and it's closed tight. If the pin is out of the hole, you'd have a HUGE gap. So yeah, some really sloppy door checks are what caused the door departures. 3) Latching: The latching mechanism itself I'm plenty happy with. If someone wanted to add a secondary latch, fine, not a bad idea for the most part. Ideally I'd rather see a vertical pin in the door bottom as a 3rd latch point, that latches along automatically with the other points. But, as I said before, if you have a positive "click" latching system, and you latch it right, you should be good to go. For what it's worth, once mine is latched, I don't detect any for/aft or other movement. They're just tight. The latching is positive and I have zero worries of a properly latched door being released because of the handle being pulled. Whatever you do, try to use your utmost craftsmanship when you do the door latches. From time to time I see RV-10's where you can tell they didn't take the care on some of the glass-related items. But the doors, try to do a great job at least on the latches. Tim Olson - RV-10 N104CD - Flying John W. Cox wrote: > The original prototype door on N410RV incurred damage during a x-cnty > airshow trip to Colorado. As I remember the canopy and door assemblies > off N220RV were removed as a quick fix and integral completed total > unit as a Second Iteration prototype build and used to repair N410RV. > All of the early kits going back to Randy s/n 006 and John Nys s/n 047 > were the 220RV Gen II type. I believe 416EC s/n 416 was still this > same type. Since then, several improvements (alternations have been > included) aftermarket which is the thrill of this group, the open > discussion, the talent of the individuals and the desire to pursue > excellence in build. > > > > Tim did an excellent explanation on the Taper. I am opposed to what I > believe is in the plans (that should be nothing new to anyone). The > Strike plate idea is a corrective measure for the high likelihood that > operators will try to close a door with the aft pin partially extended. > My review of the 416EC pictures shows an alignment and strike issue > with the Pilots plate. I believe that other than in Tims safety > locked scenario this system might allow an opening or movement at a > critical point in time. The Rack systems should not allow continued > retraction of an engaged pin during flight. I believe the taper needs > to be oriented to the interior never the exterior. I believe the pin > needs to be fully engaged into the metal door pillar. I believe the > UMHD is not adequate for a long term receptacle. The view of 416EC > showed significant stress forces on the mounting hardware. I believe a > handhold which pulls the door down and closed positively even with a > door ajar in-flight is a wise design change. > > > > Within this body of personal opinion are several quality improvements > which need universal illumination. For those with the second > generation door & latch (220RV). I would like to see 416EC the last > RV-10 to ever suffer latch release and premature door departure in flight. > > > > Pilots are human, mistakes happen, the door handle might not always get > safety latched and remain so. The secondary latch on the leading edge > or a boldly relocated hinge set like on Cirrus can sure get the > discussion stirred. > > > > Lets keep the sharp eyes focused at SNF and less mud on the field. > There is lots to learn. Think Safety, Fly Safe. > > ________________________________________________________________________________
Date: Apr 10, 2008
Subject: Door Fixes
I remember my first instructor lecturing me (30+ years ago) about not getti ng rattled if a door opens in flight because it is just noisy and an inconv enience. In over 2500+ hrs in taildraggers to twins, both exp. and certif ied, I have experienced at least half a dozen inflight doors openings. Som e were my fault, some mechanical and one just a passenger waking up from a nap and opening the door in the process of stretching out. The point is that doors open in flight multiple times every day with out in cident. No matter how good the latch is designed, at some point it is like ly that the door will come unlatched in flight. Think about the wear issue when the airframe times get into the multiple thousand hours. While I am partial to retract landing gear, I know the insurance rates show that gear up landings are a given. There are several warning systems around that see m to have no effect on the accident rate and no one has figured out a mecha nical way to eliminate the problem. There are plenty of possible failures that can cause serious damage or worse, a door unlatch should not be one of them. On the 10, this problem is compounded by the fact the door lacks th e stiffness to stay shut if only one pin is not in. The failure of the top latch in Pipers is routine, but is not even worth stopping for. I think we need a help from Vans to come up with a solution that really sol ves the whole problem. If I had not already spent so much time building an d fitting the doors, I might have just attached the pilot side door permane ntly and cut the risk in half. I am truly a Vans fan am looking forward to flying SN 40154. Airplanes are fairly complex and every one of them has s omething that gets changed or improved. RV-10 doors are not as serious as Bonanza V tails (one of my favorites), which ultimately turned out to be a cheap and easy fix. It took a long time and the lives of several people be fore Beech could admit the problem and send out the fix. Sorry for rambling Jim McLaughlin 40154. ________________________________________________________________________________
Date: Apr 10, 2008
The current word is that Vans has sold out the four engines and three more. Lycoming has allowed Vans to keep taking orders at that price... I have no idea how much longer it will last. On Apr 9, 2008, at 7:46 PM, Pascal wrote: > Main page on bottom (scroll down) > http://www.vansaircraft.com/images/open/Lyc-snf.jpg > ----- Original Message ----- > From: John Cram > To: rv10-list(at)matronics.com > Sent: Wednesday, April 09, 2008 5:56 PM > Subject: Re: RV10-List: Engine Special > > where did u find these one the site > ----- Original Message ----- > From: Jeff Carpenter > To: rv10-list(at)matronics.com > Sent: Wednesday, April 09, 2008 6:11 PM > Subject: RV10-List: Engine Special > > > > Vans has a nice discount on three (was four, but I just bought one) > XIO-540-D4A5 engines just posted on the website. > > On your marks... get set... go! > > Jeff nbsp; Navigator Photoshare, and title=http:// > www.matronics.com/Navigator?RV10-List href="http:// > www.matronics.com/Navigator?RV10-List">http:// > www.matronic via the Web title=http:// > forums.matronics.com/ href="http://forums.matronics.com">http:// > forums.matronics.com > > > href="http://www.matronics.com/Navigator?RV10-List">http:// > www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Date: Apr 10, 2008
Subject: Re: Engine stop tests.
I may be mistaken but I beleive that you need 1700+ RPM to get the prop to change pitch, in any direction, regardless of the oil pressure. I understoo d the govenor needed the 1700 rpm to function and=C2-allow the oil pressu re to vary the pitch. Rick Sked 40185 ----- Original Message ----- From: "Marcus Cooper" <coop85(at)cableone.net> Sent: Wednesday, April 9, 2008 8:31:00 PM (GMT-0800) America/Los_Angeles Subject: RE: RV10-List: Engine stop tests. Bill, =C2-=C2-=C2- This info is based on my understanding of the props, if I=99m off base someone please chime in.=C2- Doesn=99t that ma ke you feel confident about what I=99m about to write ;) The non-reversing constant speed props (like on the -10) are designed to go flat pitch in the event of a loss of oil pressure.=C2- The main concern is if you have to execute a go-around or steep climb you want the high RPM available for performance. =C2-=C2- I think what you are experiencing is simply increased thrust by going more coarse on the pitch while there=99s still oil pressure.=C2- Once th e prop stops I seriously doubt there is a significant difference in drag be tween flat and coarse pitch.=C2- =C2-So first, I don=99t think yo u can control the pitch as the engine quits and second I don=99t thin k it would make a difference. Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Bill DeRouchey Sent: Wednesday, April 09, 2008 11:10 AM Subject: RE: RV10-List: Engine stop tests. Something that=C2-I was playing with (experimenting is too strong a word) =C2-is when the engine dies (in my case idling)=C2-and is still turning =C2-- if you pull the prop out the RV10 takes a leap forward. Does the gl ide range increase with the prop all the way out? Is this in fact the stand ard emergency procedure with a constant speed prop? It seems that the engine turning would power the oil pump and could turn th e blades to full coarse decreasing the drag. Any comments? My previous=C2-constant speed prop experience was just suff icient to get my high performance signoff. Bill DeRouchey N939SB, flying "John W. Cox" wrote: Fabulous detail and invaluable research. We need more of this stuff and less accident reporting. By the way, did you go with the stock James engine cowl? The Warbirds acts as breathtaking as the setting at Wanaka. See you for OSH '08. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, April 08, 2008 10:48 AM Subject: RV10-List: Engine stop tests. Hi I would like to report on some tests we did this evening. We wanted to know what would happen when the engine stops. In flight! We have a Barratts IO540, standard compression, with the MT 3 blade prop, dual mags. The object of the exercise was to see just what happens when the fuel runs out in one tank, and how easy it is to re-start. First exercise was to practise some forced landings in case we really couldn't restart it. So complete with clearance from our local Airforce base, and with one of their squadron leaders in the right hand seat, the tower fully briefed on what we were doing, off we set to 5000ft. There was a relatively strong wind of about 35 knots at 2000ft & 25 gusting 30 on the ground . So we came up a bit short (just a bit) on the runway. I was reminded then that I need to practice forced landings from all heights, not just pattern (or circuit) height. Then it was back up to 5000ft. Cool the engine a bit, then ( all in controlled airspace I hasten to add), we cut mixture to full idle cut off. The engine just kept on going at about 500 rpm in the glide at about 80 knots or so, so eventually with full flap, and mushing down at about 55 knots, we managed to finally get it to stop. It's certainly odd seeing the prop stopped, and the ground so far below. Yes we do know that it is less than ideal for the prop to drive the engine, but we wanted to do the tests. There is no doubt that if the engine stops, the glide rate is about 200 ft/m better with the prop in full course. So it was full rich, full fine, and about 1/2 inch. Fuel pump on, a flick of the starter and away it went. So no problems there at all. The next test was a bit harder, because we wanted to check if we could start the engine without the starter (just in case of a flat battery / broken starter etc.) I've had two occasions where the engine started, but the starter failed in the process. So I was unable to restart. With the prop stopped again, we went flaps up, full rich,full fine, 1/2 inch on the throttle and entered a dive. The prop looked as if someone was trying to hand swing it (though at 4500ft and rapidly decreasing, that was unlikely!) After a few seconds it finally passed TDC, then again, and eventually it did restart after having lost about 2600ft, and at a speed of about 130-150 knots. Very quickly it builds up revs, so pulling back on stick & throttle we were quickly under control. But it is not something you will get away with under 3000ft. Our final test was to deliberately run out of fuel. With plenty in the other tank! So we simply cruised around for a further 15 mins or so, until finally the engine cooughed & spluttered. There was plenty of time to switch pump on and change tanks and away she went. So no dramas at all. Having completed our tests it was back up to 7000ft t play on the overcast for a short while. So in conclusion, there is nothing to be feared about running a tank dry. So long as the starter works, or you have sufficient height. However, if you have totally run out of fuel, it will happily continue to turn. So bearing in mind =C2- =C2- http://www.matronics.com/Navigato r?RV10-List http://forums.matronics.com http://www.matronics.com/contributi ============= ==== ======================= == ________________________________________________________________________________
Subject: Re: Engine Special
Date: Apr 10, 2008
I bought one this morning. Van's staff advised that Lycoming was making more available. I emailed my forms to Van's, called in a credit card deposit and got the three blade MT prop as part of the package. Wonderful timing as I arrived at Sun and Fun today fully intending to buy a Mattituck at $39,200 less $600 show special. Van's price included shipping and took another $1000 off for the prop bundle. So today was a great day under the theory that I didn't spend as much as Iwas thinking I'd have to. Now,..... on to avionics with all the saved money. Tom H. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176009#176009 ________________________________________________________________________________
Date: Apr 10, 2008
so what is the difference between the YIO540 on sale and the normal XIO540 on the Van's site? Anyone know? Speaking of MT 3 blade, anyone at SnF have a chance to go over to Hartzell and ask about the two blade carbon blade yet?.. figure with Van's there it may be a great way to get the two companies talking about offering the blade to RV builders. Thx Pascal BTW- Tom- great deal you did out there I would have done the same thing if this was next year (aka Mattituck and instead saved 5K on an engine and prop) ----- Original Message ----- From: "tomhanaway" <tomhanaway(at)comcast.net> Sent: Thursday, April 10, 2008 3:38 PM Subject: RV10-List: Re: Engine Special > > I bought one this morning. Van's staff advised that Lycoming was making > more available. > I emailed my forms to Van's, called in a credit card deposit and got the > three blade MT prop as part of the package. > > Wonderful timing as I arrived at Sun and Fun today fully intending to buy > a Mattituck at $39,200 less $600 show special. > > Van's price included shipping and took another $1000 off for the prop > bundle. > > So today was a great day under the theory that I didn't spend as much as > Iwas thinking I'd have to. > > Now,..... on to avionics with all the saved money. > > Tom H. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=176009#176009 > > > ________________________________________________________________________________
Date: Apr 10, 2008
How about a bungee? LOL Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Thursday, April 10, 2008 12:31 AM Subject: RE: RV10-List: Doors coming off I'm starting to think of a simple and inexpensive design. Like our co-builder Mr. Leffler, I'm still a ways away from reaching this point. However I've heard of a few RV-10's with handles that allow the door to be pulled down when you're sitting in the seat. I'm thinking of making this pull down strap out of some higher strength material and actually hooking it inside the cabin to a fixed point. If it's done correctly, the handles will be functional and a open-door scenario could result in only a couple of inches worth of opening. Sure it would be a distraction if you had to fly the plane with a door that was cracked open a few inches, but it sure beats having the door remove your Horizontal Stab and tear up your airplane. It's cheap, simple, fool proof, and practical. Phil _____ From: David McNeill [mailto:dlm46007(at)cox.net] Sent: Wednesday, April 09, 2008 10:40 PM Subject: RE: RV10-List: Doors coming off One other idea we had was the placement of a knob on the door inside, back near the pin. this will allow complete control (two hands pulling) of positioning the door for closure. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. I don't know the specifics but I think John C might. Hopefully he will chime in. I don't know if the door came off or not but they did have a door related issue. I think it was while going to/from Osh or some other eastern states flyin. Ben Westfall _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corectly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked position? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the door not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 10, 2008
Yes, what is a YIO540? Pascal wrote: > > so what is the difference between the YIO540 on sale and the normal > XIO540 on the Van's site? Anyone know? > > > Speaking of MT 3 blade, anyone at SnF have a chance to go over to > Hartzell and ask about the two blade carbon blade yet?.. figure with > Van's there it may be a great way to get the two companies talking > about offering the blade to RV builders. > Thx > Pascal > > BTW- Tom- great deal you did out there I would have done the same > thing if this was next year (aka Mattituck and instead saved 5K on an > engine and prop) > > ----- Original Message ----- From: "tomhanaway" <tomhanaway(at)comcast.net> > To: > Sent: Thursday, April 10, 2008 3:38 PM > Subject: RV10-List: Re: Engine Special > > >> >> I bought one this morning. Van's staff advised that Lycoming was >> making more available. >> I emailed my forms to Van's, called in a credit card deposit and got >> the three blade MT prop as part of the package. >> >> Wonderful timing as I arrived at Sun and Fun today fully intending to >> buy a Mattituck at $39,200 less $600 show special. >> >> Van's price included shipping and took another $1000 off for the prop >> bundle. >> >> So today was a great day under the theory that I didn't spend as much >> as Iwas thinking I'd have to. >> >> Now,..... on to avionics with all the saved money. >> >> Tom H. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=176009#176009 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Price Reduced: RV-10 Project For Sale
Date: Apr 10, 2008
RV-10 project for sale.REDUCED TO $99,900 FOR QUICK SALE! See add in Barnstormers.com and Trade-A-PlaneIncludes all materials to comp lete a flying plane except engine & prop. Full Garmin WAAS IFR instrument p ackage. GNS430W, SL30, GTX327, GI-106A, PMA800SR, LifeSaver 4300 AI, CO Mon itor, BMA EFISone w/ Autopilot and Powerboard. Rudder tim w/ position displ ay for trims and flaps. ELO Touchscreen monitor w/ switch to display EFIS o r computer to Co-pilot. All Van's kits including FWF. Accuracy Avionics ove rhead console and window trim rings. All systems installed including dual b attery Z-14 FADEC based electrical systems. CAD drawings of all system sche matics. To finish it needs: engine, prop, interior, paint, ~1000 hours labo r. Engine $39,200 (Vans)Prop $6,510 (Vans)Interior $3,182 (Flightline)Paint ~$ 8,000 (?) Total ~$56,892 to finish A flying full IFR RV-10 for $156,792! A few photos attached. ERic--(828) 777-7976Williamsport, PA panel4 (Medium).jpg Transfer 12-25-06 192 (Medium).jpg Transfer 1-30-07 048 (Small).jpg Transfer 2-5-07 033 (Small).jpg Transfer 2-5-07 034 (Small).jpg Transfer 3-27-08 120 (Small).jpg Transfer 3-27-08 121 (Small).jpg Transfer 3-27-08 131 (Small).jpg Transfer 3-27-08 134 (Small).jpg Transfer 3-27-08 138 (Small).jpg Transfer 3-27-08 146 (Small).jpg Transfer 3-27-08 150 (Small).jpg Transfer 3-27-08 170 (Small).jpg Transfer 3-27-08 194 (Small).jpg Transfer 3-27-08 207 (Small).jpg Transfer 3-27-08 213 (Small).jpg Transfer 3-27-08 214 (Small).jpg Transfer 3-27-08 217 (Small).jpg Transfer 3-27-08 221 (Small).jpg Transfer 3-27-08 223 (Small).jpg Transfer 3-27-08 224 (Small).jpg Transfer 3-27-08 226 (Small).jpg Transfer 3-27-08 228 (Small).jpg Transfer 3-27-08 229 (Small).jpg Transfer 3-27-08 230 (Small).jpg Transfer 3-27-08 231 (Small).jpg ________________________________________________________________________________
Date: Apr 10, 2008
LOL...sure Gary....how bout we just slip a prefabricated rope loop between the door handles, installed after the doors are down and ummmm.... :) locke d. Rick Sked ----- Original Message ----- From: "gary" <speckter(at)comcast.net> Sent: Thursday, April 10, 2008 5:01:14 PM (GMT-0800) America/Los_Angeles Subject: RE: RV10-List: Doors coming off How about a bungee?=C2- LOL Gary 40274 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Perry, Phil Sent: Thursday, April 10, 2008 12:31 AM Subject: RE: RV10-List: Doors coming off I'm starting to think of a simple and inexpensive design.=C2- Like our co -builder Mr. Leffler, I'm still a ways away from reaching this point. However I've heard of a few RV-10's with handles that allow the door to be pulled down when you're sitting in the seat.=C2- I'm thinking of making t his pull down strap out of some higher strength material and actually hooki ng it inside the cabin to a fixed point. If it's done correctly, the handles will be functional and a open-door scen ario could result in only a couple of inches worth of opening. Sure it would be a distraction if you had to fly the plane with a door that was cracked open a few inches, but it sure beats having the door remove yo ur Horizontal Stab and tear up your airplane. It's cheap, simple, fool proof, and practical. Phil From: David McNeill [mailto:dlm46007(at)cox.net] Sent: Wednesday, April 09, 2008 10:40 PM Subject: RE: RV10-List: Doors coming off One other idea we had was the placement of a knob on the door inside, back near the pin. this will allow complete control (two hands pulling) of posit ioning the door for closure. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Ben Westfall Sent: Wednesday, April 09, 2008 8:24 PM Subject: RE: RV10-List: Doors coming off Vans did have an issue with a door early on with 410RV. =C2-I don =99t know the specifics but I think John C might. =C2-Hopefully he will c hime in.=C2- I don=99t know if the door came off or not but they di d have a door related issue. =C2-I think it was while going to/from Osh o r some other eastern states flyin. Ben Westfall From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Chris and Susie McGough Sent: Wednesday, April 09, 2008 7:56 PM Subject: RV10-List: Doors coming off Guys are we 100% sure that the doors that have come off were latched corect ly where they go into the fuse frames. Are we sure that the door handles were closed properly and in the locked po sition? . Remember the tunnel heat problem, some have the problem but most do not. I would think Vans 10 would have close to 1000 hours on it , why has the do or not come off?? Does someone live close to Vans that can have a look and maybe do some measuring ? I am absolutely not saying there is no problem just need some facts I have written to Vans to the engieering department to see what they say regards Chris =C2- =C2- http://www.matronics.com/contribution =C2- =C2- =C2- href="http://www.matronics.com/Navigator?RV10-List">http:// www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com"> http://forums.matronics.com href="http://www.matronics.com/contribution"> http://www.matronics.com/c =C2- =C2- href="http://www.matronics.com/N avigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="ht tp://forums.matronics.com">http://forums.matronics.com href="http://www.m atronics.com/contribution">http://www.matronics.com/c =C2- =C2- http:// ======================= ==== ======================= == ________________________________________________________________________________
Subject: Doors coming off
Date: Apr 11, 2008
After reading all the posts on doors coming off I went to the hangar yesterday to recheck mine to be sure they were doing what I thought they were. I have installed the Rivet Head conversion and I read someone saying that bullets don't go past the guide into and past the door frame. On mine they are going through the guide and through the door frame. Ok there. I also heard several post say to reach back and feel that the pin has gone through the door guide. If you have a full interior, like I do, you obviously can't do that because the area is covered. I have the door warning lights installed and I check religiously to be sure the light has gone off after the door is closed. I also will not let passengers close the door. I usually stay outside the plane until the passenger is buckled in and then I close the door. I can and would highly recommend the Rivet Head type of conversion. I think Steven DiNieri also has this type of conversion as well as Rivet Head. Boy the damage done to the latest door off incident surely gives you the incentive to double check that the doors are closed properly before takeoff. Wayne Edgerton N602WT ________________________________________________________________________________
Date: Apr 11, 2008
Wayne, with your beautiful paint job, that extra degree of respect for passenger and aircraft are a smart Checklist item. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Friday, April 11, 2008 5:54 AM Subject: RV10-List: Doors coming off After reading all the posts on doors coming off I went to the hangar yesterday to recheck mine to be sure they were doing what I thought they were. I have installed the Rivet Head conversion and I read someone saying that bullets don't go past the guide into and past the door frame. On mine they are going through the guide and through the door frame. Ok there. I also heard several post say to reach back and feel that the pin has gone through the door guide. If you have a full interior, like I do, you obviously can't do that because the area is covered. I have the door warning lights installed and I check religiously to be sure the light has gone off after the door is closed. I also will not let passengers close the door. I usually stay outside the plane until the passenger is buckled in and then I close the door. I can and would highly recommend the Rivet Head type of conversion. I think Steven DiNieri also has this type of conversion as well as Rivet Head. Boy the damage done to the latest door off incident surely gives you the incentive to double check that the doors are closed properly before takeoff. Wayne Edgerton N602WT ________________________________________________________________________________
Date: Apr 11, 2008
Question? How much does the door bow outward in flight. I am going flying in about 30 minutes and will check mine, but just wondering if any of the other flyers have tried to measure the flex. I have looked at it in flight before and do not remember any noticeable increased gap in the door. The reason I am interested is that I did cut my rods down to have the pins be just long enough to go through the AL blocks. With the tight fit of the doors, I do not think that a racking motion could pull the pin out of the block, outward flex of the door could have some affect. Rene' Felker RV-10 N423CF Flying 801-721-6080 ________________________________________________________________________________
Date: Apr 11, 2008
Being a lurker, I've read this thread with interest. Just to make a general comment, for good structural "retention" of the door, I feel the best set-up is for the door pins to pass completely through the opening frame on the fuselage. Of course, I'm basing this on the pictures I've seen so far. How does the warning light system "sense" full locking with the "blueprint" set-up for the door? Seems to me it would be a simple matter to add a couple micro-switches to the back side of the door frames so they light up (or better turn off a light) when the pins are fully engaged into the frames therefore indicating proper lock. On 4/11/08, Wayne Edgerton wrote: > After reading all the posts on doors coming off I went to the hangar > yesterday to recheck mine to be sure they were doing what I thought they > were. I have installed the Rivet Head conversion and I read someone saying > that bullets don't go past the guide into and past the door frame. On mine > they are going through the guide and through the door frame. Ok there. > > I also heard several post say to reach back and feel that the pin has gone > through the door guide. If you have a full interior, like I do, you > obviously can't do that because the area is covered. I have the door warning > lights installed and I check religiously to be sure the light has gone off > after the door is closed. I also will not let passengers close the door. I > usually stay outside the plane until the passenger is buckled in and then I > close the door. > > I can and would highly recommend the Rivet Head type of conversion. I think > Steven DiNieri also has this type of conversion as well as Rivet Head. > > Boy the damage done to the latest door off incident surely gives you the > incentive to double check that the doors are closed properly before takeoff. > > Wayne Edgerton N602WT > > ________________________________________________________________________________
Subject: Hearing the Bear, Watching the Bear .. wanting to dance rather
than RUN
Date: Apr 11, 2008
EAA video word has snuck out that the FAA has been walking all over the grounds of SNF measuring their latest 51% Revised List against existing kits in Florida. Not one single post by anyone on what that revised list might look like. Other than VAN being cautiously optimistic, Can any posters from SNF give us a teaser on what the new list might sound like before it hits us along the head with all claws extended? I know, I know the grounds are drying out and everyone has money to burn buying new toys. 25% of all GA flying aircraft are said to now be some form of the more than 29,000 (5,647 are VANS) Experimental built aircraft. The Genie is out of the bottle. Other than smoke and mirrors, will anyone shed some tangible light on this curiosity in a form we can get our arms around? Once it is out, in the Federal Register to trigger an NPRM, the fuse on the bomb will be lit. 280,000 attendees at SNF '08 and not a damn whisper. Wow! I understand Joe Bartels with his EVO Lancair prototype, VAN with the RV-12 prototype and Mikael Via of Glastar sat at the picnic table. I hear Hunger can make bad porridge taste better. John Cox #600 ________________________________________________________________________________
Subject: Fuel Filter clogging
Date: Apr 11, 2008
Now that I am flying, I like everyone else flying, am concerned with a clogged filter. It is a big job to get down in the tunnel and disassemble the filter only to find that it is OK. Since filters clog progressively and not all at once, I measured the fuel flow by taking the fuel line off of the injector servo and connecting it to a hose that I drop the other end into the gas tank. I then turn on the boost pump and read the fuel flow. Mine started out at 42 gph and has not changed since I started flying. This gives me peace of mind without all the disassembly. If the flow drops below 40 gph I can then go and clean it. Though I would pass along this time saving tip. Gary 40274 Flying ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Date: Apr 12, 2008
"I also heard several post say to reach back and feel that the pin has gone through the door guide. " Guys this is rediculous we need a fix so that whoever can jump in and fly the plane and believe that the doors will not fly off. I mean would the public tolerate it if a car door fell off? Why should we. We need a fix so that you can get in shut the door "thats it" No checking pins or reaching behind the seat etc etc. Ok so I am not convinced about this flexing yet as we cannot be sure the doors that have come off had the rear pins into the fuse (shut properly). So if this is the problem then Iflyrv10.com door guides will fix the problem as the door pins are guided into place. If we are saying there is flexing and the pins pop out then maybe tempory fix would be what Andre has done in here in AUS. About to do first flight in a few weeks and i do not want to have to think about closing a bloody door or shouls I say a door coming off. Keep thinking guys reggards Chris 388 ________________________________________________________________________________
Date: Apr 12, 2008
The after market door guides seem a good idea and I believed that one of the advantages of these was that you were able to shorten the rods so that if you accidently closed the door with the handle in the open position the pins would not hit the outside of the fuse stuffing the paint. This ofcourse means that with the door closed the pins would go through the after market guide but not the fuse. Just a thought regards Chris ________________________________________________________________________________
Date: Apr 11, 2008
Chris I have to say I agree with you. An unclosed door should not result in an major emergency in an un-pressurised a/c. This problem, if not corrected will be an accident waiting to happen. It is a bit like the Far Side cartoon the had a "Wings Off" button on the arm-rest of an airline passengers seat. The questions is not how to prevent the button being pushed but why it was there in the first pace. I know the risk can be mitigated by checking, with warning lights etc. But somewhere along the way, the failure chain will catch up with someone. Flying my Cherokee, part of the passenger brief is that they should un-latch the door in the event of an emergency so the door does not jam upon landing. I am reluctant to use the Auzzie fix as it may trap you in the a/c in the event of a crash. So rather than "fixes", what would be the "Gold Standard" solution? Inquiring minds need to know .... Les Kearney #40643 ----- Original Message ----- From: Chris and Susie McGough <VHMUM(at)bigpond.com> Date: Friday, April 11, 2008 3:42 pm Subject: Re: RV10-List: Doors coming off > "I also heard several post say to reach back and feel that the > pin has gone through the door guide. " Guys this is > rediculous we need a fix so that whoever can jump in and fly the > plane and believe that the doors will not fly off. I mean would > the public tolerate it if a car door fell off? Why should we. We > need a fix so that you can get in shut the door "thats it" No > checking pins or reaching behind the seat etc etc. > > Ok so I am not convinced about this flexing yet as we cannot be > sure the doors that have come off had the rear pins into the > fuse (shut properly). So if this is the problem then > Iflyrv10.com door guides will fix the problem as the door pins > are guided into place. If we are saying there is flexing and the > pins pop out then maybe tempory fix would be what Andre > has done in here in AUS. > > > About to do first flight in a few weeks and i do not want to > have to think about closing a bloody door or shouls I say a door > coming off. > > Keep thinking guys > > reggards Chris 388 > > > > > ________________________________________________________________________________
Date: Apr 11, 2008
That is the way mine are set up. After all the discussion, I am considering changing that and lengthening the rods and getting the pin to go through the frame. Have not really decided yet. Maybe I will have one of the ME's here give me an opinion about the strength of the AL block with the two bolts. My general feeling is that I am ok since those two bolts have a lot of strength in sheer. Rene' Felker RV-10 N423CF Flying 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Friday, April 11, 2008 3:37 PM Subject: Re: RV10-List: Doors coming off The after market door guides seem a good idea and I believed that one of the advantages of these was that you were able to shorten the rods so that if you accidently closed the door with the handle in the open position the pins would not hit the outside of the fuse stuffing the paint. This ofcourse means that with the door closed the pins would go through the after market guide but not the fuse. Just a thought regards Chris ________________________________________________________________________________
Date: Apr 12, 2008
Chris, I don't know how much can be gleaned from the latest? incident as some of the posts allude to the door coming off on a subsequent flight after the 4g crash/landing. Maybe there wasn't a straight section left on this machine. In any case who would go flying in an aircraft with that much prior damage unless you had a special permit to return it to a maintenance workshop? Maybe the door popped out during the crunching landing. Have a look at the deformation on the glareshield. I'd be interested to see what the damage was/might be where the brace attaches to the cabin cover. I don't think well made RV-10's have a case of the door falling off, I think it's more a case of checking to see if it's properly closed. The same thing you'd do when you jumped in the family car. Maybe the answer is a safety catch, sliding window bolt variety, at the rear attached to the lower door aimed down to the inside of the lower sill? I'm interested in hearing Rene's report on the door in flight flexing because I reckon this would be the most likely scenario to ripping a door off especially if a significant gap opens up towards the airflow. John 40315 ----- Original Message ----- From: Chris and Susie McGough To: rv10-list(at)matronics.com Sent: Saturday, April 12, 2008 7:23 AM Subject: Re: RV10-List: Doors coming off "I also heard several post say to reach back and feel that the pin has gone through the door guide. " Guys this is rediculous we need a fix so that whoever can jump in and fly the plane and believe that the doors will not fly off. I mean would the public tolerate it if a car door fell off? Why should we. We need a fix so that you can get in shut the door "thats it" No checking pins or reaching behind the seat etc etc. Ok so I am not convinced about this flexing yet as we cannot be sure the doors that have come off had the rear pins into the fuse (shut properly). So if this is the problem then Iflyrv10.com door guides will fix the problem as the door pins are guided into place. If we are saying there is flexing and the pins pop out then maybe tempory fix would be what Andre has done in here in AUS. About to do first flight in a few weeks and i do not want to have to think about closing a bloody door or shouls I say a door coming off. Keep thinking guys reggards Chris 388 ________________________________________________________________________________
Date: Apr 11, 2008
I did not get to check the in flight flexing today...will have to fly some other day to do it..darn. My wife is out playing this weekend.hockey..so it might not be able tofly until some time next week. Rene' Felker RV-10 N423CF Flying 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne Sent: Friday, April 11, 2008 4:36 PM Subject: Re: RV10-List: Doors coming off Chris, I don't know how much can be gleaned from the latest? incident as some of the posts allude to the door coming off on a subsequent flight after the 4g crash/landing. Maybe there wasn't a straight section left on this machine. In any case who would go flying in an aircraft with that much prior damage unless you had a special permit to return it to a maintenance workshop? Maybe the door popped out during the crunching landing. Have a look at the deformation on the glareshield. I'd be interested to see what the damage was/might be where the brace attaches to the cabin cover. I don't think well made RV-10's have a case of the door falling off, I think it's more a case of checking to see if it's properly closed. The same thing you'd do when you jumped in the family car. Maybe the answer is a safety catch, sliding window bolt variety, at the rear attached to the lower door aimed down to the inside of the lower sill? I'm interested in hearing Rene's report on the door in flight flexing because I reckon this would be the most likely scenario to ripping a door off especially if a significant gap opens up towards the airflow. John 40315 ----- Original Message ----- From: Chris and Susie <mailto:VHMUM(at)bigpond.com> McGough Sent: Saturday, April 12, 2008 7:23 AM Subject: Re: RV10-List: Doors coming off "I also heard several post say to reach back and feel that the pin has gone through the door guide. " Guys this is rediculous we need a fix so that whoever can jump in and fly the plane and believe that the doors will not fly off. I mean would the public tolerate it if a car door fell off? Why should we. We need a fix so that you can get in shut the door "thats it" No checking pins or reaching behind the seat etc etc. Ok so I am not convinced about this flexing yet as we cannot be sure the doors that have come off had the rear pins into the fuse (shut properly). So if this is the problem then Iflyrv10.com door guides will fix the problem as the door pins are guided into place. If we are saying there is flexing and the pins pop out then maybe tempory fix would be what Andre has done in here in AUS. About to do first flight in a few weeks and i do not want to have to think about closing a bloody door or shouls I say a door coming off. Keep thinking guys reggards Chris 388 href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 11, 2008
The Gold standard solution is found on the SR22; forward hinged door and rear/top/bottom latch pin/pins. That solution would require some major re engineering by Vans which is unlikely. In the short run, install a small handle on the aft part of the door to aid in closing from the inside on the ground. Then check your pins by feel or use the system. Do not shorten the pins so that they do not penetrate the door jambs; this is a recipe for disaster if the beveled tips hit anything where they will be stressed/abraded etc. Eventually they may be just short enough to slip out, given the flex of the door and the flex of the rear pushrod. IIRC it was bent slightly to match the curvature of the door. For 29 years I closed the passenger door on my Cardinal RG; not because it would depart the aircraft but the passenger could damage the door. The handle had a shear pin in it so that when the locking bar was pushed aft, it would shear if the bar was not properly positioned and was striking the door frame. I always locked the door to prevent my passenger from disabling the aircraft and creating a maintenance job for me. IIRC I posted a passenger warning placard in the 10 stating that my aircraft does not conform to certification standards. In my cases it meets or exceeds them but in the case of the doors I don't think it does. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LES KEARNEY Sent: Friday, April 11, 2008 3:11 PM Subject: Re: RV10-List: Doors coming off Chris I have to say I agree with you. An unclosed door should not result in an major emergency in an un-pressurised a/c. This problem, if not corrected will be an accident waiting to happen. It is a bit like the Far Side cartoon the had a "Wings Off" button on the arm-rest of an airline passengers seat. The questions is not how to prevent the button being pushed but why it was there in the first pace. I know the risk can be mitigated by checking, with warning lights etc. But somewhere along the way, the failure chain will catch up with someone. Flying my Cherokee, part of the passenger brief is that they should un-latch the door in the event of an emergency so the door does not jam upon landing. I am reluctant to use the Auzzie fix as it may trap you in the a/c in the event of a crash. So rather than "fixes", what would be the "Gold Standard" solution? Inquiring minds need to know .... Les Kearney #40643 ----- Original Message ----- From: Chris and Susie McGough <VHMUM(at)bigpond.com> Date: Friday, April 11, 2008 3:42 pm Subject: Re: RV10-List: Doors coming off > "I also heard several post say to reach back and feel that the > pin has gone through the door guide. " Guys this is > rediculous we need a fix so that whoever can jump in and fly the > plane and believe that the doors will not fly off. I mean would > the public tolerate it if a car door fell off? Why should we. We > need a fix so that you can get in shut the door "thats it" No > checking pins or reaching behind the seat etc etc. > > Ok so I am not convinced about this flexing yet as we cannot be > sure the doors that have come off had the rear pins into the > fuse (shut properly). So if this is the problem then > Iflyrv10.com door guides will fix the problem as the door pins > are guided into place. If we are saying there is flexing and the > pins pop out then maybe tempory fix would be what Andre > has done in here in AUS. > > > About to do first flight in a few weeks and i do not want to > have to think about closing a bloody door or shouls I say a door > coming off. > > Keep thinking guys > > reggards Chris 388 > > > > > ________________________________________________________________________________
Date: Apr 11, 2008
Van's advises that the YIO-540-D4A5 is identical to the XIO-540-D4A5 engine. Both are the experimental versions. Lycoming is getting more agressive with their marketing and wanted a code letter for themselves. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176287#176287 ________________________________________________________________________________
Subject: Re: Doors coming off
Date: Apr 11, 2008
I'd like to see Jesse S. hop in here when he gets a chance. I understand he's a little busy right now [Wink] I looked at his door at Sun & Fun today. Looks like he added both a small interior handle near the rear of the door and a secondary latch that seals the inside front side of the door. Tom H. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176289#176289 ________________________________________________________________________________
Date: Apr 11, 2008
I looked over the pictures of the door departure and noticed something in the upper hinges. It looked like the area around the hinges had little resin between the two surfaces. Also, the screw heads were flattened to bury them in resin so they would not turn when tightened from below. I would guess this was to create a beautiful look to the top of the door with no screw head showing. However, the shear force is absorbed at the large diameter of the screw head and the mating nut surface. Any grinding of the screw head removes area available for shear and its only shear that is securing the top of the door to the hinges. The deeper the screw head is set into the door the less holding strength is available from the fiberglass. So burying the screw heads cause two problems, and if they are over torqued cracking the fiberglass a third problem arises. Are others using this technique to make their doors beautiful? Look carefully at the rear door guide/protector/fuselage hole - it would appear that the rod never reached far beyond the teflon guide, otherwise the protector would be torn off. Bill DeRouchey N939SB, flying tomhanaway wrote: I'd like to see Jesse S. hop in here when he gets a chance. I understand he's a little busy right now [Wink] I looked at his door at Sun & Fun today. Looks like he added both a small interior handle near the rear of the door and a secondary latch that seals the inside front side of the door. Tom H. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176289#176289 ________________________________________________________________________________
Date: Apr 12, 2008
Worth mentioning is many light twins,for example a c-310 can lose a door if it comes unlatched during flight.This is clearly creating a problem on the rv-10 and we need to come up with a secondary latch system that can be released from the outside if rescue is necesary.I used a canopy latch on the forward bottom of the doors.A seemingly simple solution but does not allow rescuers easy access to the cabin.Do cessna aircraft allow outside door entry if the handles are in the down position as in normal flight? 728DD 175 hours ************** It's Tax Time! Get tips, forms and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolcmp00300000002850) ________________________________________________________________________________
Date: Apr 12, 2008
Typically, a fastened shear joint is designed so the entire shear force is transferred in the shank of the fastener, not in the head, even in a countersunk head. Also, having threads in bearing on the structure is a no-no. Tension loads would be transferred by the fastener head and nut, but typical aircraft design practice is to design for shear loadings at joints whereever possible. That said, I don't think there's anything wrong with the design of the -10 doors. If the latching pins are engaged well, the hinges look robust engough for the air loadings. As is inherent with gull-wing door designs, once a door opens in flight and swings out past the boundary layer, it basically becomes another short, fat wing. At 80+ knots, that results in a rather large increase in the forces acting on the door and would result in failures as seen in this discussion. I'd like to see if there's a history of door failures on certified aircraft with gull-wing doors. KH On 4/11/08, Bill DeRouchey wrote: > I looked over the pictures of the door departure and noticed something in > the upper hinges. > > It looked like the area around the hinges had little resin between the two > surfaces. > > Also, the screw heads were flattened to bury them in resin so they would > not turn when tightened from below. I would guess this was to create a > beautiful look to the top of the door with no screw head showing. However, > the shear force is absorbed at the large diameter of the screw head and the > mating nut surface. Any grinding of the screw head removes area available > for shear and its only shear that is securing the top of the door to the > hinges. The deeper the screw head is set into the door the less holding > strength is available from the fiberglass. So burying the screw heads cause > two problems, and if they are over torqued cracking the fiberglass a third > problem arises. > > Are others using this technique to make their doors beautiful? > > Look carefully at the rear door guide/protector/fuselage hole - it would > appear that the rod never reached far beyond the teflon guide, otherwise the > protector would be torn off. > > > Bill DeRouchey > N939SB, flying > > tomhanaway wrote: > > I'd like to see Jesse S. hop in here when he gets a chance. I understand > he's a little busy right now > [Wink] > > I looked at his door at Sun & Fun today. Looks like he added both a small > interior handle near the rear of the door and a secondary latch that seals > the inside front side of the door. > > Tom H. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=176289#176289 > > ________________________________________________________________________________
Subject: FW: RV-List: RV safety RV_Stats-1.pdf -
Date: Apr 12, 2008
This post is read by a number of readers on this list as well, but for those who do not follow it there, the value is clear in reviewing the attached Ron Wanttaja PDF. Dumb Pilot Errors are the leading cause of RV accidents (significantly). Maintenance is seldom the cause because there are so many experts out there on such popular kits. Builder Errors for RVs are greater than Homebuilts in general and may be a result of many assuming that techniques used by others and factory plans are without fault and the builders blindly move ahead with the moving herd. Try being the first for the Acme 1000 and every step is carefully considered and reviewed. Fuel Exhaustion in RVs is inexcusably high and is significantly higher than other homebuilts. (Tell me Why?) Now, here is where you should each be focusing. These statistics are not yet updated for calendar 2005 and 2006 (the RV-10 began gaining flight hours in 2005). Ron concluded that lower accident rates for RVs is a result of generally higher hours of aeronautical experience and more advanced ratings of RV pilots. If you have ever looked over the field of RVers at EAA functions you could conclude they tend to be much older and therefore less bold. Conclusion, the RV-10 is significantly more complex and challenging than our little brother RV-6, RV-7 or RV8. A statistically large number of RV-10 builders had/have no pilots license (during the build) or significantly lower experience than Ron's premise. Many of the builders are younger than his statistics imply. A high percentage have minimally low IFR time (Tim is an exception here). This is an opportunity in the making for rather dramatic Recurrent and Advanced Training for Pilots from the RV-10 fleet. We have the ability to skew the accident statistics either direction we choose. The choice is truly ours. Do you want to play or move with the herd? The insurance underwriters will move these policy costs to remain profitable businessmen. Three (possibly four) aircraft total losses and four POBs in the last five months. 2008 is going to be a busy year. John C - circa 2008 From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry Springer Sent: Saturday, April 12, 2008 1:05 AM Subject: RV-List: RV safety RV_Stats-1.pdf - Hi all, I am sure that a lot of you have heard of or read some of Ron Wanttaja,'s articles He writes article and gives talks at EAA functions about safety etc.and does statistical studies mostly pertaining to homebuilt aircraft. I have known him for a few years and I wrote to him and ask if he could help with the statistic regarding RV accidents compared to the rest of the homebuilt community and this is what he sent me. Jerry Springer +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > Can can I post this on the RV-List? > There is a discussion going on there about how to make the RV flying > community safer and how to compare RV accidents to the rest of the > homebuilt accident rates. Someone ask how to break the RVs apart from > the rest of the homebuilt accident statistics. I would like to point people > to your article or maybe you could help us out some way with RV accident > statistics. I give talks to the local EAA chapters that go further than the articles. Attached is a page from my presentation where I discuss RV accident causes and compare them to the overall statistics. The data is based on accidents from 1998 through 2004, inclusive. "General Pilot Error" is basically mistakes in the stick-and-rudder skills; "SALA" stands for "Stupidity at Low Altitude," buzzing, flying up box canyons, etc. In my presentations, I use a red star to call attention to interesting results, such as the RV's higher rate in what I call 'cross-country' accidents. The lower rate of pilot error accidents may well be due to the higher general experience level of RV pilots, as shown by the median pilot hours. During the subject period the annual fleet accident rate for all homebuilts was about 0.94% (e.g., almost one out of every 100 homebuilts crashes in a given year) and the RV fleet accident rate was almost identical (0.90%). In contrast, the Glasair rate was 1.11%, The overall rate for all N-numbered aircraft was 0.63%, so homebuilts have a rate about 50% higher than the overall fleet. I'm currently adding 2005 and 2006 data to my database, and will be updating the graphs accordingly. Don't expect them to change too much, but you never know.... Ron ________________________________________________________________________________
Subject: door opening
Date: Apr 12, 2008
Considering that some of the previous door in-flight openings occurred on takeoff (in a climb) and the door missed the airframe, it would seem reasonable that at the onset of a problem, to immediately initiate a climb. It appears that the only incident where the door hit the airframe was during cruise flight. If there are other instances of same I would be interested to hear. ________________________________________________________________________________
Subject: RV safety RV_Stats-1.pdf -
Date: Apr 12, 2008
Given the inital guesses of primary cause of the three fatal 10 crashes (out of 100+ flying) they seem to be spread over three categories. I do agree , however , that time in type and recent experience are prime considerations of insurance companies as well as indicators of probable safe operation. Certainly continuing to fly regularly while building will promote improved accident stats. Another thing that will improve safety is getting real comfortable with all the new electronics and button pushing in day VFR before expanding the envelope. Read the accident reports where the pilot says to the co-pilot, "wonder why its doing that?" then (sound of impact) on the CVR. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Saturday, April 12, 2008 8:55 AM Subject: RV10-List: FW: RV-List: RV safety RV_Stats-1.pdf - This post is read by a number of readers on this list as well, but for those who do not follow it there, the value is clear in reviewing the attached Ron Wanttaja PDF. Dumb Pilot Errors are the leading cause of RV accidents (significantly). Maintenance is seldom the cause because there are so many experts out there on such popular kits. Builder Errors for RVs are greater than Homebuilts in general and may be a result of many assuming that techniques used by others and factory plans are without fault and the builders blindly move ahead with the moving herd. Try being the first for the Acme 1000 and every step is carefully considered and reviewed. Fuel Exhaustion in RVs is inexcusably high and is significantly higher than other homebuilts. (Tell me Why?) Now, here is where you should each be focusing. These statistics are not yet updated for calendar 2005 and 2006 (the RV-10 began gaining flight hours in 2005). Ron concluded that lower accident rates for RVs is a result of generally higher hours of aeronautical experience and more advanced ratings of RV pilots. If you have ever looked over the field of RVers at EAA functions you could conclude they tend to be much older and therefore less bold. Conclusion, the RV-10 is significantly more complex and challenging than our little brother RV-6, RV-7 or RV8. A statistically large number of RV-10 builders had/have no pilots license (during the build) or significantly lower experience than Ron's premise. Many of the builders are younger than his statistics imply. A high percentage have minimally low IFR time (Tim is an exception here). This is an opportunity in the making for rather dramatic Recurrent and Advanced Training for Pilots from the RV-10 fleet. We have the ability to skew the accident statistics either direction we choose. The choice is truly ours. Do you want to play or move with the herd? The insurance underwriters will move these policy costs to remain profitable businessmen. Three (possibly four) aircraft total losses and four POBs in the last five months. 2008 is going to be a busy year. John C - circa 2008 From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry Springer Sent: Saturday, April 12, 2008 1:05 AM Subject: RV-List: RV safety RV_Stats-1.pdf - Hi all, I am sure that a lot of you have heard of or read some of Ron Wanttaja,'s articles He writes article and gives talks at EAA functions about safety etc.and does statistical studies mostly pertaining to homebuilt aircraft. I have known him for a few years and I wrote to him and ask if he could help with the statistic regarding RV accidents compared to the rest of the homebuilt community and this is what he sent me. Jerry Springer +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > Can can I post this on the RV-List? > There is a discussion going on there about how to make the RV flying > community safer and how to compare RV accidents to the rest of the > homebuilt accident rates. Someone ask how to break the RVs apart from > the rest of the homebuilt accident statistics. I would like to point people > to your article or maybe you could help us out some way with RV accident > statistics. I give talks to the local EAA chapters that go further than the articles. Attached is a page from my presentation where I discuss RV accident causes and compare them to the overall statistics. The data is based on accidents from 1998 through 2004, inclusive. "General Pilot Error" is basically mistakes in the stick-and-rudder skills; "SALA" stands for "Stupidity at Low Altitude," buzzing, flying up box canyons, etc. In my presentations, I use a red star to call attention to interesting results, such as the RV's higher rate in what I call 'cross-country' accidents. The lower rate of pilot error accidents may well be due to the higher general experience level of RV pilots, as shown by the median pilot hours. During the subject period the annual fleet accident rate for all homebuilts was about 0.94% (e.g., almost one out of every 100 homebuilts crashes in a given year) and the RV fleet accident rate was almost identical (0.90%). In contrast, the Glasair rate was 1.11%, The overall rate for all N-numbered aircraft was 0.63%, so homebuilts have a rate about 50% higher than the overall fleet. I'm currently adding 2005 and 2006 data to my database, and will be updating the graphs accordingly. Don't expect them to change too much, but you never know.... Ron ________________________________________________________________________________
Subject: FW: Door pins
Date: Apr 12, 2008
-----Original Message----- From: David McNeill [mailto:dlm46007(at)cox.net] Sent: Saturday, April 12, 2008 11:19 AM Subject: Door pins Attached are pictures of two aft pins from Van's. I tapped the tubes with a 5/16" 18 tap. Note the different bevels. We did not modify the bevels. The full tube on picture 39 is at least .16 longer than the picture 36. There are at least three additional turns of the tap to indicate the length difference. Picture 35 is the pin in the closed position of the door with the shorter bevel (sent in another message). (And yes I know I need an aluminum cover over the latch pin.) Your message is ready to be sent with the following file or link attachments: IMG_0039 IMG_0036 IMG_0037 IMG_0038 ________________________________________________________________________________
Subject: Emailing: IMG_0035
Date: Apr 12, 2008
Your message is ready to be sent with the following file or link attachments: IMG_0035 ________________________________________________________________________________
Subject: Re: GRT HX
Date: Apr 13, 2008
I am going with the HX screen in my panel. On the website for GRT they now have a pricing wizard that should answer most of your questions. The dual screen is $11,000, and pricing goes up from there with the options. I haven't seen any screen shots of it yet and couldn't make it to Sun N fun. If anyone has some screen shots send them my way. The capabilities proposed at the price of the system were paramount in my decision to go with the GRT HX. I tried attaching the pdf of my panel, hope I got it right. It is being built by Accuracy Avionics while I am off playing Army for a year. Hopefully it is ready by OshKosh for them to display and some of you will take plenty of pictures for me. Eric Kallio 40518 buildus interruptus...was finishing the canopy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176535#176535 Attachments: http://forums.matronics.com//files/kallio_dual_grt_151.pdf ________________________________________________________________________________
Subject: Wheel pants/lower strut fairing
Date: Apr 13, 2008
If anyone is interested, I thought I'd post some pictures of how the wheel pants fiberglass work is turning out. This is using Fred Williams' model. (THANKS FRED!) You can also see the covering of the hinge rivets on the strut pants. I forgot to take pictures of the initial splitting of the lower fairings. I split them first, then positioned them on the strut fairing with the wheels off the ground, strings pulled to the step, etc. then drilled and clecoed the halves to the wheel pants, then fiberglassed them in position, filled the cleco holes, built up overlapping lips (2" glass cloth/resin) ... and there you go. They sandwich together and hold the strut pants perfectly in position, eliminates the screws on the lower strut fairings. If you are planning on doing this, it's best to split the fairing just forward of the apex of the strut curve -- otherwise you have to spread the front lips to install them on the back half. No Bondo -- you convinced me! Mixing the microbeads in the fiberglass (Western systems) is a bit more trouble, but it smooths OK and no worries about bonding. With primer (2K urethane) they will slick up just fine. The plans for the upper strut fairings look a little dinky to me -- sheet metal screws? Has anyone improved upon this? I guess it's not really critical and since they overlap the fuse and the wing joining panel, they have to be removable. Probably a little weird, but this glass work gives me lots of satisfaction. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176537#176537 Attachments: http://forums.matronics.com//files/pants_1_medium_357.jpg http://forums.matronics.com//files/pants_2_medium_148.jpg http://forums.matronics.com//files/pants_3_medium_199.jpg http://forums.matronics.com//files/pants_4_medium_796.jpg http://forums.matronics.com//files/pants_5_medium_170.jpg http://forums.matronics.com//files/pants_6_medium_133.jpg http://forums.matronics.com//files/pants_7_medium_103.jpg http://forums.matronics.com//files/pants_8_medium_739.jpg http://forums.matronics.com//files/pants_9_medium_192.jpg ________________________________________________________________________________
Subject: Re: Hearing the Bear, Watching the Bear .. wanting to dance
rath
Date: Apr 13, 2008
I haven't heard anything about a "new list" but I was at Van's BBQ Friday night. Dick spoke about the new rules and said that the existing kits are grandfathered in. The only kit in question from Van is the RV-12. My take on that statement is that if you go buy an RV-8 kit tomorrow or next year, you are still under the same rule as all the other RV-8s ever built. Good BBQ, by the way. John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176542#176542 ________________________________________________________________________________
Date: Apr 13, 2008
dance rath Ignore the EAA self promotion. I like how they like to take 100% of the credit. Previously Approved Kits to be 'Grandfathered' FAA responds to EAA advocacy efforts *April 11 2008* Manufacturers and owners of aircraft kits that were previously evaluated and approved by the FAA as eligible to be certificated in the Experimental Amateur-Built Category under the FAAs 51% Rule received welcome news at Sun n Fun Friday. The FAA announced that its will not re-evaluate any previously approved aircraft kits under its new policy on amateur-built certification. Kim Smith, manager of the FAAs Small Airplane Directorate, appeared at the Meet the FAA session Friday afternoon at Lakeland and made the announcement, which essentially grandfathers those kits that appear on the FAAs 51% approved list. The FAA suspended making evaluations earlier this year until it finalizes its new policy revisiting amateur-built certification, which was prompted by concerns over excessive commercial assistance and prefabrication that could cause finished aircraft to fall outside the homebuilt certification regulations. There was no intent to reevaluate previously evaluated kits, Smith explained. An NPRM (notice of proposed rulemaking) will be issued sometime hopefully early next week stating that we will not re-evaluate kits that have already been evaluated. Asked by an EAA staffer if the term, grandfathered would apply, Smith agreed that it would. Several manufacturers exhibiting at Lakeland, who served on the amateur-built aviation rulemaking committee (ARC) welcomed the news, saying they had expected the FAA to heed the ARCs suggestion to not re-evaluate previously approved kits. This is good news, said Joe Bartels, president of Lancair, whose new model Evolution was recently evaluated and approved as eligible for A-B certification. We indeed needed that reassurance, and the FAA has evaluated our new Evolution and found it to meet the requirements. Mikael Via of Glasair Aviation added, Thats what we on the ARC expected, and were glad to see it. Our main concern is what the new policy will be regarding new kits, so well have to wait and see about that. We look forward to learning the end result. Dick Van Grunsven of Vans Aircraft also was not surprised at the announcement. We expected them (approved kits) to be grandfathered, he said. But we dont expect it to be business as usual, either. They (inspectors) may pay closer attention than they used to when inspecting the kits from now on, to make sure they do not exceed what is allowed for commercial assistance. EAA President Tom Poberezny, who is at Lakeland this week, added, We are extremely pleased about the FAA announcement to grandfather kits that have already been approved. Earl Lawrence, EAA vice president of industry and regulatory affairs and co-chair of the ARC, applauded the announcement. This shows that EAA advocacy efforts are working and that the FAA is sensitive to the concerns of current amateur-builders, he said. But EAA members need to continue to be vigilant, and continue to follow this effort. If youre an amateur-builder, we encourage you to write the FAA <http://www.eaa.org/news/2008/public_comment_letter.pdf> to help ensure that they fully understand from the builders perspective how what you are doing is fully within the intent and letter of the regulation. Innovation should not be restricted. At the same meeting Friday, the FAA also released a draft of an NPRM that fixes several long-awaited changed to the sport pilot-slight-sport aircraft regulations. johngoodman wrote: > > I haven't heard anything about a "new list" but I was at Van's BBQ Friday night. Dick spoke about the new rules and said that the existing kits are grandfathered in. The only kit in question from Van is the RV-12. My take on that statement is that if you go buy an RV-8 kit tomorrow or next year, you are still under the same rule as all the other RV-8s ever built. > > Good BBQ, by the way. > John > > -------- > #40572 QB Fuselage, wings finished > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=176542#176542 > > > ________________________________________________________________________________
Date: Apr 13, 2008
Subject: Re: RV safety
> From: "John Cox" <johnwcox(at)pacificnw.com> > > Conclusion, the RV-10 is significantly more > complex and challenging than our little brother RV-6, RV-7 or RV8. I can second John's observation as I continue to fly my RV-7A (more or less one of the last round gauge panel RV's to be built, with first flight in December 2003) and my RV-10 with its GRT dual EFIS coupled to GNS480 and TruTrak with GSVG. The -7A requires more attention to airmanship, especially in slow flight where those short wings will bite you if a stall occurs close to the ground. The -10 is much more forgiving with respect to airspeeds and handling. The -7A does have an approach certified GPS (UPS GX-60) that gives course guidance to a TruTrak with altitude hold, but I have to mind the altitude during IFR approaches just like in the days of hand-flown ILS's. One can either have the GPS fly the approach, or can abandon the approach and go missed; that's about it. So when things don't go according to plan on an approach, there is a real simple mindset of 'ok, let's climb, get out of here, and make some other plan'. The RV-10, on the other hand, has a bunch of different autopilot modes: its own internal course guidance from the TruTrak, GPSS guidance which is coming from the EFIS and might or might not really be GPSS, since the EFIS generates its own course guidance. And the GNS480 has a mind of its own about what it calls discontinuities between enroute and approach configurations. With the latest database update on the GNS480 it suddenly decided that approaches to my home airport in Nashville can only be flown via STARS (Standard Terminal Arrival Routes) and the last time I was in the muck trying to get home it suprised me by asking me to choose a STAR before it would load the approach. Not even knowing what approach fixes where in each STAR, I fiddled for a few minutes then just asked for a vector to final on the ILS from approach control, which they provided. Ended up just hand flying the ILS with traditional needle displays since the fancy WAAS GPS was completely rigid in its sequencing, and not useful at that point. Good thing I have hand flown that approach many many times. So my assessment of the fancy electronics is that they are wonderful when everything is going according to plan, but have way too many subtle failure modes when the game changes and one has to make a new plan while hurtling along IMC at 200 mph. Yes, I will go back to school and figure out how to insert STARS into the flight planning, but remain suspicious of losing positional awareness when a surprise comes my way in an approach environment. My friend Ham Cartwright put his superbly equipped RV-10 into the trees in Alabama last week, and took another friend of mine, Bob Lloyd to the great beyond with him. Ham's RV-10 had nearly identical avionics to mine: Dual GRT EFIS, TruTrak GSVG, though with a Garmin 430W instead of a 480. The sad radar track on flightaware.com of his last flight sure has the signature wandering of an IFR flight that has gotten seriously lost and disoriented. Sure hope he wasn't fiddling with the fancy boxes trying to reprogram them as they hit. Stay safe, friends. -Dan Masys RV-10 N104LD RV-7A N747DL ________________________________________________________________________________
Subject: Windscreen Crazing
Date: Apr 13, 2008
I had a similar issue with crazing that occurred under a tape line that I used to mask off the top of the fiberglass edge at the base of the windscreen. After replacing the windshield, I did a bunch of tests on the old windscreen to see what would make it craze. I was able to get cracks and crazing using the Van's recommended Weld-On when under pressure (not a lot of pressure, but some pressure). I decided to switch on my second install to Sika-Flex. I pooled acetone on the window until it evaporated, no crazing. I then took the Sika-Flex primer and applied it and let it air dry for a few minutes (not fully cured, but dry to the touch). Then when I sprayed it with acetone, it disintegrated the primer and proceeded to craze the windshield in that area... Looks just like your window did. I then took a fresh section, applied the primer and let it dry overnight. I then sprayed it with the acetone and it would not remove the primer and it did not craze the windscreen. I played around with it again and if I sprayed the acetone before the primer was dry, it would craze the window every time. There clearly was some reaction with the Sika-Flex primer and acetone while the primer was not fully cured. This never explained why my RV-10 windscreen crazed, but I have come to the conclusion to not use acetone on my windscreen (even though others have used it for years with 'no issues'). FYI, for removing the windscreen I took a router and set the depth to the window thickness and routed around the edges where it was adhered. It made a big mess, but it sure did a nice job and left a nice surface to glue the new windshield to.... -Mike Kraus RV-4 Flying RV-10 FWF and wiring -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Monday, April 07, 2008 1:04 PM Subject: RV10-List: Windscreen Crazing Yesterday I decided to remove the protective coverings from all my windows. The inside had the factory plastic coating still in place and the outside had been covered with spraylat after installation of the windscreen. I think the spraylat was applied in August 2006. Plane was moved to the hanger via a wrecker in December 2006. We used the lancair method and materials to glue in all of the windows. Hysol mixed with flox. Only the windscreen has any signs of crazing. We glued a lancair ES, Mark Ritters RV10 and mine within a few months of each other. The ES is flying with no problems and Mark's plane did not have any cracks using this method. Acetone was used on the glue seam and frame but none touched any other part of the glass. Any ideas? Bobby J Hughes 40116 ________________________________________________________________________________
dance rath
Date: Apr 13, 2008
Larry & John - All of this smacks of big (Good Ole) boy politic. One manufacturer does not want their volume of kit sales reduced. A second manufacturer had a kit that was not approved when this suspension went into effect and is glad it is going to be grandfathered back before the suspension started. This is before they even had a flying prototype (The EVO was NOT PREVIOUSLY EVALUATED). Another blatantly promotes that they can stay under the definition of 51% and do it all with a novice builder with teams of factory trained professionals in "Two Weeks to Taxi". Where is that representative of the lone guy in his garage who does all of the build themselves (within 51%, that the rule was supposed to protect)? The vast majority of those 29,000+ Experimentals were plans built, kit build or true one of a kind prototypes before the big boys developed "Factory Endorsed Quick Build", "Two weeks to Taxi" or This kit can only be completed at our unique one of a kind "Safety is object ONE" factory. This whole mess began over Rick Schrameck slapping 1250 shp turboprops from mothballed Beech Starships into a composite build fuselage only at their "Safety" factory concept. Sounds like Epic made the Grandfather cut. I am clearly missing how grandfathering Fat Cats shows a great job the EAA is doing for the individual members. Point me in the right direction. The only thing I can conclude is the Professional Build shops who buy kits and build to order, are about to be fed to the Bear. I am still wanting to see the revised Tasks List that was being applied against those kits that they looked at SNF '08. Sounds like it may have gotten harder to meet the new Task List for the little guys. Let's see ... Taxes due April 15th then read the Federal Registry for the facts from SNF. Got it! The fuse is lit on April 15th, 2008. Don't sit on the sideline as this NPRM deadline lapses. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Sunday, April 13, 2008 10:32 AM Subject: Re: RV10-List: Re: Hearing the Bear, Watching the Bear .. wanting to dance rath Ignore the EAA self promotion. I like how they like to take 100% of the credit. Previously Approved Kits to be 'Grandfathered' FAA responds to EAA advocacy efforts *April 11 2008* - Manufacturers and owners of aircraft kits that were previously evaluated and approved by the FAA as eligible to be certificated in the Experimental Amateur-Built Category under the FAA's 51% Rule received welcome news at Sun 'n Fun Friday. The FAA announced that it will not re-evaluate any previously approved aircraft kits under its new policy on amateur-built certification. Kim Smith, manager of the FAA's Small Airplane Directorate, appeared at the "Meet the FAA" session Friday afternoon at Lakeland and made the announcement, which essentially grandfathers those kits that appear on the FAA's 51% approved list. The FAA suspended making evaluations earlier this year until it finalizes its new policy revisiting amateur-built certification, which was prompted by concerns over excessive commercial assistance and prefabrication that could cause finished aircraft to fall outside the homebuilt certification regulations. "There was no intent to reevaluate previously evaluated kits," Smith explained. "An NPRM (notice of proposed rulemaking) will be issued sometime hopefully early next week stating that we will not re-evaluate kits that have already been evaluated." Asked by an EAA staffer if the term, "grandfathered" would apply, Smith agreed that it would. Several manufacturers exhibiting at Lakeland, who served on the amateur-built aviation rulemaking committee (ARC) welcomed the news, saying they had expected the FAA to heed the ARC's suggestion to not re-evaluate previously approved kits. "This is good news," said Joe Bartels, president of Lancair, whose new model Evolution was recently evaluated and approved as eligible for A-B certification. "We indeed needed that reassurance, and the FAA has evaluated our new Evolution and found it to meet the requirements." Mikael Via of Glasair Aviation added, "That's what we on the ARC expected, and we're glad to see it. Our main concern is what the new policy will be regarding new kits, so we'll have to wait and see about that. We look forward to learning the end result." Dick Van Grunsven of Van's Aircraft also was not surprised at the announcement. "We expected them (approved kits) to be grandfathered," he said. "But we don't expect it to be business as usual, either. They (inspectors) may pay closer attention than they used to when inspecting the kits from now on, to make sure they do not exceed what is allowed for commercial assistance." EAA President Tom Poberezny, who is at Lakeland this week, added, "We are extremely pleased about the FAA announcement to grandfather kits that have already been approved." Earl Lawrence, EAA vice president of industry and regulatory affairs and co-chair of the ARC, applauded the announcement. "This shows that EAA advocacy efforts are working and that the FAA is sensitive to the concerns of current amateur-builders," he said. "But EAA members need to continue to be vigilant, and continue to follow this effort. If you're an amateur-builder, we encourage you to write the FAA <http://www.eaa.org/news/2008/public_comment_letter.pdf> to help ensure that they fully understand from the builder's perspective how what you are doing is fully within the intent and letter of the regulation. Innovation should not be restricted." At the same meeting Friday, the FAA also released a draft of an NPRM that fixes several long-awaited changed to the sport pilot-slight-sport aircraft regulations. johngoodman wrote: ________________________________________________________________________________
Subject: Jan's posting of VAF regarding Dan's incident
Date: Apr 13, 2008
Check out: http://www.vansairforce.com/community/showthread.php?t=28964 Jan just posted a note talking Eggenfellner service alert about appropriately crimping battery connections. Although he didn't post the actual NTSB findings, it does imply that the root cause may have been that improperly crimped battery cables may have caused the engine to quit. It would be interesting to read the actual NTSB preliminary report. ________________________________________________________________________________
Subject: oil door
Date: Apr 13, 2008
Just a heads up The 2600-3W as supplied by Van's is one size too small if you do any buildup on the back side of the door to make it flush with the cowl. A Camloc 2600-4W is required. $7.50 each from Spruce. They doubled their catalog price this year. ________________________________________________________________________________
Subject: test
Date: Apr 13, 2008
A test to verify sending capabilities. Howard _________________________________________________________________ Pack up or back up'use SkyDrive to transfer files or keep extra copies. L earn how. hthttp://www.windowslive.com/skydrive/overview.html?ocid=TXT_TAGLM_WL_Ref resh_skydrive_packup_042008 ________________________________________________________________________________
Date: Apr 13, 2008
Ahhh, the threads in the end of the rod. I had asked earlier (and don't remember a response) about if the only reason to thread the end of the rod was to put a center marker in it to mark the sill. If so, seems like overkill when a marker can be put in there to do the same thing (a pencil is the right diameter), whether threads weaken the rod or not. Folks are leaving the bolt in there and grinding it flush with the taper for strength? The AL rod isn't strong enough? OK, but I didn't like the idea of screwing in a bullet tip to extend the rod -- which I envision having to grind off the original taper, then the threaded joint would be very close to a shear point ... ? Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176643#176643 ________________________________________________________________________________
Date: Apr 14, 2008
Hi Dan, I'm not familiar with the GRT system, but with the Chelton's when you are loading an approach into your flight plan it allows you to select VTF vectors to final. Does the GRT possible have that option somewhere inside it? Also I think on the Chelton you can temporarily select OBS or heading bug mode for vectors and then switch back to the approach at the appropriate time. Wayne Edgerton N602WT From: Dan Masys <dmasys(at)cox.net> Subject: Re: RV safety With the latest database update on the GNS480 it suddenly decided that approaches to my home airport in Nashville can only be flown via STARS (Standard Terminal Arrival Routes) and the last time I was in the muck trying to get home it suprised me by asking me to choose a STAR before it would load the approach. Not even knowing what approach fixes where in each STAR, I fiddled for a few minutes then just asked for a vector to final on the ILS from approach control, which they provided. Ended up just hand flying the ILS with traditional needle displays since the fancy WAAS GPS was completely rigid in its sequencing, and not useful at that point. Good thing I have hand flown that approach many many times. So my assessment of the fancy electronics is that they are wonderful when everything is going according to plan, but have way too many subtle failure modes when the game changes and one has to make a new plan while hurtling along IMC at 200 mph. Yes, I will go back to school and figure out how to insert STARS into the flight planning, but remain suspicious of losing positional awareness when a surprise comes my way in an approach environment. ________________________________________________________________________________
Subject: RV safety
Date: Apr 14, 2008
Wayne, I just started to really figure out my GRT system, but what I think is happening is that Dan and me are using the 480 (430 in my case) to enter the flight plan and "execute" the approach. I know on the 430 I just select the approach and then hit vectors to final, set the GRT to heading mod (heading bug) and arm the system for the approach. The only thing I have tested it on has been an ILS and once I get within 2.5 degrees of the localizer course, the system automatically switches to nav mod and tracks the localizer. Pretty cool for a guy who has never really had an autopilot before and never flown a coupled approach. It looks like the way the 480 handles the approaches into Nashiville has changed in the 480? Rene' Felker RV-10 N423CF Flying 801-721-6080 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Monday, April 14, 2008 6:19 AM Subject: Re: RV10-List: RV safety Hi Dan, I'm not familiar with the GRT system, but with the Chelton's when you are loading an approach into your flight plan it allows you to select VTF vectors to final. Does the GRT possible have that option somewhere inside it? Also I think on the Chelton you can temporarily select OBS or heading bug mode for vectors and then switch back to the approach at the appropriate time. Wayne Edgerton N602WT Time: From: Dan Masys Subject: Re: RV safety With the latest database update on the GNS480 it suddenly decided that approaches to my home airport in Nashville can only be flown via STARS (Standard Terminal Arrival Routes) and the last time I was in the muck trying to get home it suprised me by asking me to choose a STAR before it would load the approach. Not even knowing what approach fixes where in each STAR, I fiddled for a few minutes then just asked for a vector to final on the ILS from approach control, which they provided. Ended up just hand flying the ILS with traditional needle displays since the fancy WAAS GPS was completely rigid in its sequencing, and not useful at that point. Good thing I have hand flown that approach many many times. So my assessment of the fancy electronics is that they are wonderful when everything is going according to plan, but have way too many subtle failure modes when the game changes and one has to make a new plan while hurtling along IMC at 200 mph. Yes, I will go back to school and figure out how to insert STARS into the flight planning, but remain suspicious of losing positional awareness when a surprise comes my way in an approach environment. ________________________________________________________________________________
Date: Apr 14, 2008
Mike, Now that SNF is over I am waiting to hear from the windshield folks. How long did it take for the crazing to start \ stop during your various tests? Did it progress over time? Not sure what method I will use this time but I may try the Sika-Flex or use the Hysol and flox method again. Thanks, Bobby 40116 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Kraus Sent: Sunday, April 13, 2008 11:59 AM Subject: RE: RV10-List: Windscreen Crazing I had a similar issue with crazing that occurred under a tape line that I used to mask off the top of the fiberglass edge at the base of the windscreen. After replacing the windshield, I did a bunch of tests on the old windscreen to see what would make it craze. I was able to get cracks and crazing using the Van's recommended Weld-On when under pressure (not a lot of pressure, but some pressure). I decided to switch on my second install to Sika-Flex. I pooled acetone on the window until it evaporated, no crazing. I then took the Sika-Flex primer and applied it and let it air dry for a few minutes (not fully cured, but dry to the touch). Then when I sprayed it with acetone, it disintegrated the primer and proceeded to craze the windshield in that area... Looks just like your window did. I then took a fresh section, applied the primer and let it dry overnight. I then sprayed it with the acetone and it would not remove the primer and it did not craze the windscreen. I played around with it again and if I sprayed the acetone before the primer was dry, it would craze the window every time. There clearly was some reaction with the Sika-Flex primer and acetone while the primer was not fully cured. This never explained why my RV-10 windscreen crazed, but I have come to the conclusion to not use acetone on my windscreen (even though others have used it for years with 'no issues'). FYI, for removing the windscreen I took a router and set the depth to the window thickness and routed around the edges where it was adhered. It made a big mess, but it sure did a nice job and left a nice surface to glue the new windshield to.... -Mike Kraus RV-4 Flying RV-10 FWF and wiring -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Monday, April 07, 2008 1:04 PM To: rv10-list(at)matronics.com Subject: RV10-List: Windscreen Crazing Yesterday I decided to remove the protective coverings from all my windows. The inside had the factory plastic coating still in place and the outside had been covered with spraylat after installation of the windscreen. I think the spraylat was applied in August 2006. Plane was moved to the hanger via a wrecker in December 2006. We used the lancair method and materials to glue in all of the windows. Hysol mixed with flox. Only the windscreen has any signs of crazing. We glued a lancair ES, Mark Ritters RV10 and mine within a few months of each other. The ES is flying with no problems and Mark's plane did not have any cracks using this method. Acetone was used on the glue seam and frame but none touched any other part of the glass. Any ideas? Bobby J Hughes 40116 ________________________________________________________________________________
Date: Apr 14, 2008
Guys and Gals...you may want to read that manual very carefully before launching and trying to learn by flying...you'll spend too much heads down time...most systems have a simulator mode or stand alone software simulators...you might want to find a way to plug in your system on the ground and use the simulator there so that when you get airborn spending fuel you're not waiting time and altitude cranking dials and flipping screens learning...and please consider taking along a safety pilot when out with your big screens practicing...hopefully someone with TAA experience. P **************It's Tax Time! Get tips, forms and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolcmp00300000002850) ________________________________________________________________________________
Subject: RV safety
Date: Apr 14, 2008
It may be about time to remind ourselves of a prime directive . If I can't fly IFR/IMC without the Autopilot, then I can't fly IFR. I agree with RV Safety; learn how to tell the electronics how to do what you want/need, don't depend on a working autopilot to do the job for you. Take a look at www.flightaware.com (IFR plans and some flight following) and stick in an N number of interest. Watch the groundspeed and altitude excursions. Changes of 30-40 knots and 1000+ feet between minutes may indicate a hand flyer who is not current to fly IFR without an autopilot ( or less likely very turbulent air and the PIC has requested the block altitude). _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com Sent: Monday, April 14, 2008 7:05 AM Subject: Re: RV10-List: RV safety Guys and Gals...you may want to read that manual very carefully before launching and trying to learn by flying...you'll spend too much heads down time...most systems have a simulator mode or stand alone software simulators...you might want to find a way to plug in your system on the ground and use the simulator there so that when you get airborn spending fuel you're not waiting time and altitude cranking dials and flipping screens learning...and please consider taking along a safety pilot when out with your big screens practicing...hopefully someone with TAA experience. P _____ It's Tax Time! Get tips, forms and advice on AOL <http://money.aol.com/tax?NCID=aolcmp00300000002850> Money & Finance. ________________________________________________________________________________
Subject: Re: Wheel pants/lower strut fairing
Date: Apr 14, 2008
Hi Lew,=0A=0AThank you for the photos. I've been doing the same mod over the last few days so your post is timely and appreciated. =0AI have also been thinking of the upper fairing and the only thing I 've come up with is using nut plates where accessibility will allow. =0AAre you going to do anything about an access door for putting ai r in the tires? I was thinking of a door like Cessna's, either spring loaded or flush latched, maybe both. Since it would be a "curved" door , the hinge will need some special attention to keep from binding. Any thoughts?=0A=0ARoger=0A#40291=0A ----- Original Message ----- =0A From: Lew Gallagher<mailto:lewgall(at)charter.net> =0A nt: Sunday, April 13, 2008 8:29 AM=0A Subject: RV10-List: Wheel pa nts/lower strut fairing=0A=0A=0A --> RV10-List message poste d by: "Lew Gallagher" >=0A=0A If anyone is interested, I thought I'd post some pictur es of how the wheel pants fiberglass work is turning out. This is usin g Fred Williams' model. (THANKS FRED!) You can also see the covering o f the hinge rivets on the strut pants. =0A=0A I forgot to take pictures of the initial splitting of the lower fairings. I split them first, then positioned them on the strut fairing with the wheels off t he ground, strings pulled to the step, etc. then drilled and clecoed t he halves to the wheel pants, then fiberglassed them in position, fill ed the cleco holes, built up overlapping lips (2" glass cloth/resin) . . and there you go. =0A=0A They sandwich together and hold the strut pants perfectly in position, eliminates the screws on the lower strut fairings. If you are planning on doing this, it's best to split the fairing just forward of the apex of the strut curve -- otherwise you have to spread the front lips to install them on the back half. =0A=0A No Bondo -- you convinced me! Mixing the microbeads in t he fiberglass (Western systems) is a bit more trouble, but it smooths OK and no worries about bonding. With primer (2K urethane) they will s lick up just fine. =0A=0A The plans for the upper strut fairing s look a little dinky to me -- sheet metal screws? Has anyone improved upon this? I guess it's not really critical and since they overlap th e fuse and the wing joining panel, they have to be removable. =0A =0A Probably a little weird, but this glass work gives me lots of satisfaction. =0A=0A Later, - Lew=0A=0A --------=0A non-pilot=0A crazy about building=0A NOW OFICIALLY BUILDER #40 549=0A doors almost finished, pants on, WHEW!=0A=0A=0A =0A=0A Read this topic online here:=0A=0A http://forums.mat ronics.com/viewtopic.php?p=176537#176537<http://forums.matronics.com /viewtopic.php?p=176537#176537>=0A=0A=0A=0A=0A Attac hments: =0A=0A http://forums.matronics.com//files/pants_1_mediu m_357.jpg<http://forums.matronics.com//files/pants_1_medium_357.jpg> =0A http://forums.matronics.com//files/pants_2_medium_148.jpg ://forums.matronics.com//files/pants_2_medium_148.jpg>=0A http://f orums.matronics.com//files/pants_3_medium_199.jpg<http://forums.matron ics.com//files/pants_3_medium_199.jpg>=0A http://forums.matronics. com//files/pants_4_medium_796.jpg<http://forums.matronics.com//files/p ants_4_medium_796.jpg>=0A http://forums.matronics.com//files/pants _5_medium_170.jpg<http://forums.matronics.com//files/pants_5_medium_17 0.jpg>=0A http://forums.matronics.com//files/pants_6_medium_133.jp g<http://forums.matronics.com//files/pants_6_medium_133.jpg>=0A ht tp://forums.matronics.com//files/pants_7_medium_103.jpg<http://forums. matronics.com//files/pants_7_medium_103.jpg>=0A http://forums.matr onics.com//files/pants_8_medium_739.jpg<http://forums.matronics.com//f iles/pants_8_medium_739.jpg>=0A http://forums.matronics.com//files /pants_9_medium_192.jpg<http://forums.matronics.com//files/pants_9_med ======================= ======================= onics.com/Navigator?RV10-List<http://www.matronics.com/Navigator?RV10- ======================= ======================= ======================= ======================= ======================= =0A=0A=0A=0A ________________________________________________________________________________
Date: Apr 14, 2008
I know you're correct on being proficient on hand flying the approaches...but going out and learning new electronics while flying is a bit crazy to me...one spends way too much head down time reading, selecting and looking for buttons/switches/and moving screens about...sort not the time to learn with your head down...makes one run into the ground or another plane a real possibility. It took me a couple of days in class, studying and sitting on the ground to learn the G 1000 and autopilot system plus all the new places for radio and phone on the audio panel presentation...if one were moving at 170kts you'll cover a few miles in a minute while you glance down...it's really hard to believe all the information you can go through quickly and what it takes to find exactly what you want get it displayed and inserted into your flight plan. It's pretty easy to fumble around for a few minutes...if you're going the Garmin approach..you may want to look at their FITS program. P **************It's Tax Time! Get tips, forms and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolcmp00300000002850) ________________________________________________________________________________
From: "James, Peter [SD]" <Peter.James(at)sprint.com>
Date: Apr 14, 2008
Subject: Humbling Experience
Dear -10 Listers, I have debated for several days whether to hit the send button on this e-ma il. I am not sure that it is my place to share this experience. I attende d SNF this year and was pleased to look over all of the -10s that were in a ttendance. It is exciting to know that my plane will sit in the same row w ith these birds in the near future. But that's not the reason for this mes sage..... On the way home from SNF, we stopped in Georgia to look at a ground looped Skybolt that one of my fellow chapter members is considering purchasing. D uring the conversation with the salvage yard, I mentioned that I was buildi ng an RV-10...and that unfortunately, one had gone down last week. The gen t helping us stated that the plane was there.... Right next to where we wer e standing. We wandered over and took a look... I have never been humbled as much as I was at the Vietnam Memorial in Washi ngton, D.C. While standing looking at the downed plane, I had a second mov ing experience -- similar to that at "The Wall". I recognized the structur es. I saw the parts that I am so intimately familiar with. I saw the deva station that the passengers in this aircraft must have endured. I can only hope that they did not suffer. I am told that the field of debris was 600 feet long (2 football fields). The first sign of contact was fiberglass imbedded 4" into tree tops. The l ast item in the field was the engine. In all my days, I have never seen a propeller as curled as this one. I am not familiar with all of the detai ls..... but I can tell you this..... There were structures that had every rivet sheared off. I recognized parts that I thought would be impossible t o destroy...yet here they were in pieces. It was my familiarity with the p arts and pieces that made this moment so significant. I cannot imagine wh at was happening at the time the airframe came to this state of being. I d id not know the pilot or passenger. I wish that I could have met them. I am sure they were fine individuals, as all of the -10 builders seem to be. Why am I writing this, you ask? I am not concerned about insurance or the future of our small community of builders. I am not concerned about bent s heet metal. I am writing this to encourage you, my airplane and aviation f amily, to think twice before entering into an area filled with Thunderstorm s. I have no idea what happened, but I do know that this one stop... this 10 minutes in Georgia... will change the way that I "pilot"...maybe for the rest of my life. I have landed for weather before....and I will again. >From now on...I will be much quicker to make a "NO GO" decision. I encoura ge you to do the same. The boys from Lancair told harrowing tales of their trip down this year...and how they had been at 400' AGL above an interstat e to avoid towers. I was amazed that they survived their complete lack of judgment. We all can suffer from "get-there-'it is" This humbling moment in time, may save my life...and the lives of my passen gers. I am sorry that others lost their lives in order to drive this home for me. Be safe my friends, I hope that I can meet each of you in person one day so on. Pete RV-10 #40100 90% done, 90% to go. ________________________________________________________________________________
Date: Apr 14, 2008
Does anyone know of a simulator for the GRT system? It would be great to practice on the ground, without burning avgas! Thanks Sam Marlow GRANSCOTT(at)aol.com wrote: > Guys and Gals...you may want to read that manual very carefully before > launching and trying to learn by flying...you'll spend too much heads > down time...most systems have a simulator mode or stand alone software > simulators...you might want to find a way to plug in your system on > the ground and use the simulator there so that when you get airborn > spending fuel you're not waiting time and altitude cranking dials and > flipping screens learning...and please consider taking along a safety > pilot when out with your big screens practicing...hopefully someone > with TAA experience. > > P > > > > > ------------------------------------------------------------------------ > It's Tax Time! Get tips, forms and advice on AOL Money & Finance > <http://money.aol.com/tax?NCID=aolcmp00300000002850>. > * > > > * ________________________________________________________________________________
Subject: Tools wanted
Date: Apr 14, 2008
Hello all, I've got an RV-8 quickbuild empennage on the way and am looking for used to ols to buy. This is my first RV, so I don't have any tools to speak of. L et me know if you're willing to part with any of yours. Thanks! Matt _________________________________________________________________ More immediate than e-mail? Get instant access with Windows Live Messenger. http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refr esh_instantaccess_042008 ________________________________________________________________________________
Subject: RV safety
Date: Apr 14, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
There is apparently a way to interface it into MS Flight Simulator called GRTBridge. I haven't done it but there's plenty of discussion on the GRT Yahoo forum: http://groups.yahoo.com/group/GRT_EFIS/ Click on "Messages" and then search for "simulator" and pretty quick. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow Sent: Monday, April 14, 2008 2:48 PM Subject: Re: RV10-List: RV safety Does anyone know of a simulator for the GRT system? It would be great to practice on the ground, without burning avgas! Thanks Sam Marlow GRANSCOTT(at)aol.com wrote: > Guys and Gals...you may want to read that manual very carefully before > launching and trying to learn by flying...you'll spend too much heads > down time...most systems have a simulator mode or stand alone software > simulators...you might want to find a way to plug in your system on > the ground and use the simulator there so that when you get airborn > spending fuel you're not waiting time and altitude cranking dials and > flipping screens learning...and please consider taking along a safety > pilot when out with your big screens practicing...hopefully someone > with TAA experience. > > P > > > > ------------------------------------------------------------------------ > It's Tax Time! Get tips, forms and advice on AOL Money & Finance > <http://money.aol.com/tax?NCID=aolcmp00300000002850>. > * > > > * ________________________________________________________________________________
Date: Apr 14, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Recommendations for front air vents
Any recommendations for the front air vents? Vans wants $145 for the aluminum ones Aircraft Spruce has several varieties in the $175 price range. Is this is the part of the building where you say to the dealer? ........ hit me . :-) Lew: good job on the wheel pants. Thanks for the reference, but I just added the pics. Our late friend, Mark Ritter showed me how to do it when I looked at his plane a couple of months ago. And I will be "displeased" if you get flying before I do. Fred Williams 40515. ________________________________________________________________________________
Subject: Re: Humbling Experience
Date: Apr 14, 2008
Thanks for sharing the details of the HORRIBLE accident. I Know how you feel. I have witnessed another RV crash site and it is a sad and humbling experience. Rob. On Apr 14, 2008, at 11:56 AM, James, Peter [SD] wrote: > Dear -10 Listers, > > I have debated for several days whether to hit the send button on > this e-mail. I am not sure that it is my place to share this > experience. I attended SNF this year and was pleased to look over > all of the -10s that were in attendance. It is exciting to know > that my plane will sit in the same row with these birds in the near > future. But that=92s not the reason for this message=85.. > > On the way home from SNF, we stopped in Georgia to look at a ground > looped Skybolt that one of my fellow chapter members is considering > purchasing. During the conversation with the salvage yard, I > mentioned that I was building an RV-10=85and that unfortunately, one > had gone down last week. The gent helping us stated that the plane > was there=85. Right next to where we were standing. We wandered over > and took a look=85 > > I have never been humbled as much as I was at the Vietnam Memorial > in Washington, D.C. While standing looking at the downed plane, I > had a second moving experience -- similar to that at =93The Wall=94. I > recognized the structures. I saw the parts that I am so intimately > familiar with. I saw the devastation that the passengers in this > aircraft must have endured. I can only hope that they did not suffer. > > I am told that the field of debris was 600 feet long (2 football > fields). The first sign of contact was fiberglass imbedded 4=94 into > tree tops. The last item in the field was the engine. In all my > days, I have never seen a propeller as curled as this one. I am > not familiar with all of the details=85.. but I can tell you this=85.. > There were structures that had every rivet sheared off. I > recognized parts that I thought would be impossible to destroy=85yet > here they were in pieces. It was my familiarity with the parts and > pieces that made this moment so significant. I cannot imagine what > was happening at the time the airframe came to this state of being. > I did not know the pilot or passenger. I wish that I could have met > them. I am sure they were fine individuals, as all of the -10 > builders seem to be. > > Why am I writing this, you ask? I am not concerned about insurance > or the future of our small community of builders. I am not > concerned about bent sheet metal. I am writing this to encourage > you, my airplane and aviation family, to think twice before entering > into an area filled with Thunderstorms. I have no idea what > happened, but I do know that this one stop=85 this 10 minutes in > Georgia=85 will change the way that I =93pilot=94=85maybe for the rest of my > life. I have landed for weather before=85.and I will again. =46rom > now on=85I will be much quicker to make a =93NO GO=94 decision. I > encourage you to do the same. The boys from Lancair told harrowing > tales of their trip down this year=85and how they had been at 400=92 AGL > above an interstate to avoid towers. I was amazed that they > survived their complete lack of judgment. We all can suffer from > =93get-there-=91it is=94 > > This humbling moment in time, may save my life=85and the lives of my > passengers. I am sorry that others lost their lives in order to > drive this home for me. > > Be safe my friends, I hope that I can meet each of you in person one > day soon. > Pete > > RV-10 #40100 > 90% done, 90% to go. > > ________________________________________________________________________________
Date: Apr 14, 2008
Stein has some for $90-100 per copy. I don't recall if I sent out this link before but there are some pictures of Dave Saylor's RV-10 here: http://www.sinkrate.com/rv10/aircrafters-fiberglass-class/ that show some pictures of his completed wheel pants with a similar setup. -Ben 40579. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Monday, April 14, 2008 2:07 PM Subject: RV10-List: Recommendations for front air vents Any recommendations for the front air vents? Vans wants $145 for the aluminum ones Aircraft Spruce has several varieties in the $175 price range. Is this is the part of the building where you say to the dealer? ........ hit me . :-) Lew: good job on the wheel pants. Thanks for the reference, but I just added the pics. Our late friend, Mark Ritter showed me how to do it when I looked at his plane a couple of months ago. And I will be "displeased" if you get flying before I do. Fred Williams 40515. ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Apr 14, 2008
Our illustrious Stein has a popular vent: http://www.steinair.com/eyeballvents.htm Looks like he is out of stock on some though. Stein, any idea when you will have more? Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Monday, April 14, 2008 4:07 PM Subject: RV10-List: Recommendations for front air vents Any recommendations for the front air vents? Vans wants $145 for the aluminum ones Aircraft Spruce has several varieties in the $175 price range. Is this is the part of the building where you say to the dealer? ........ hit me . :-) Lew: good job on the wheel pants. Thanks for the reference, but I just added the pics. Our late friend, Mark Ritter showed me how to do it when I looked at his plane a couple of months ago. And I will be "displeased" if you get flying before I do. Fred Williams 40515. ________________________________________________________________________________
Date: Apr 14, 2008
Subject: Re: Recommendations for front air vents
Check out Stein, He's got the best prices on Vents, and they are TOP quality. http://steinair.com/eyeballvents.htm Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Fred Williams, M.D. wrote: > > > Any recommendations for the front air vents? > Vans wants $145 for the aluminum ones > > Aircraft Spruce has several varieties in the $175 price range. > Is this is the part of the building where you say to the dealer? > > ........ hit me . :-) > > ________________________________________________________________________________
Date: Apr 14, 2008
We should have more of the smaller ones back in stock within a couple weeks. Lockheed called and bought every last one we had on the shelf so the stock situation has been hard to keep up with on those smaller ones! We're trying to keep up, but when someone just buys all of them in one fell swoop it takes us a bit to catch back up. Cheers, Stein >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of RV Builder >(Michael Sausen) >Sent: Monday, April 14, 2008 4:52 PM >To: rv10-list(at)matronics.com >Subject: RE: RV10-List: Recommendations for front air vents > > > > >Our illustrious Stein has a popular vent: > >http://www.steinair.com/eyeballvents.htm > >Looks like he is out of stock on some though. Stein, any idea >when you will have more? > >Michael > >> ________________________________________________________________________________
Date: Apr 14, 2008
Deems, Michael and Ben. Thanks. Will give Stein a day to get over Sun -n Fun and call in am to see when some will be available. He'll probably see this later today. Now I can tell my wife I saved $100 today. Fred Williams > ________________________________________________________________________________
Subject: Pix
Date: Apr 14, 2008
I have been flying lots, but finally got the wheel pants on so took some pix to motivate you "yet to fly" guys. Gary 40274 Flying ________________________________________________________________________________
Date: Apr 14, 2008
Subject: Re: Pix
That's it, just rub it in !!!!!!!!!!! >:o Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ gary wrote: > > I have been flying lots, but finally got the wheel pants on so took > some pix to motivate you yet to fly guys. > > ________________________________________________________________________________
Date: Apr 14, 2008
Fred, I got 4 from a salvage yard not a scratch on them, nice Aluminum for less than $100 after some negotiations. So there are other avenues. -Chris #40072 ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Monday, April 14, 2008 6:56 PM Subject: Re: RV10-List: Recommendations for front air vents > > > Deems, Michael and Ben. > Thanks. > Will give Stein a day to get over Sun -n Fun and call in am to see when > some will be available. He'll probably see this later today. Now I can > tell my wife I saved $100 today. > > Fred Williams > >> > > > ________________________________________________________________________________
Date: Apr 14, 2008
Having done it both ways now, I'd say ABSOLUTELY go with the aluminum ones...the plastic ones suck. Anyone want a hot deal on plastic vents? :) Tim Olson - RV-10 N104CD - Flying Fred Williams, M.D. wrote: > > > Any recommendations for the front air vents? > Vans wants $145 for the aluminum ones > > Aircraft Spruce has several varieties in the $175 price range. > Is this is the part of the building where you say to the dealer? > > ........ hit me . :-) > > > Lew: good job on the wheel pants. Thanks for the reference, but I just > added the pics. Our late friend, Mark Ritter showed me how to do it > when I looked at his plane a couple of months ago. And I will be > "displeased" if you get flying before I do. > > > > Fred Williams > 40515. > ________________________________________________________________________________
From: "John Testement" <john(at)roadmapscoaching.com>
Subject: Cowling hinges
Date: Apr 14, 2008
I am pretty much finished building and am sending the plane to my painter in pieces. I am really having a hard time getting the cowling hinges to go in. I believe some eyelets may have been bent a little out of alignment during paint prep. I would like to hear what others have done to realign the hinges and get hinge pins to go in more easily. John Testement HYPERLINK "mailto:jwt(at)roadmapscoaching.com"jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting Checked by AVG. 1:45 PM ________________________________________________________________________________
Date: Apr 14, 2008
Subject: Re: AFS Systems .... and others
John W. Cox wrote: > This is a perfect question for Stein of SteinAir or Dewey Conroy of > Pacific Coast Avionics. They are probably both taking all kinds of > orders and will address this after returning. Many inquiring minds > want to know exactly these questions. > > > > I would like to see an EFIS system which can annunciate remotely > mounted and controlled avionics without taking the financial dive with > the Garmin G900X national debt decision. I am impressed with Robin's > purchase but it is too rich for my blood. Synthetic Vision, HITS, > Chartview, SafeTaxi, Terrain, Traffic and Weather with the capability > to go IFR. Vertical Autopilot GPS steer with the AFS 4500 is a great > start. > > > > John > > > OK, while we're on the subject of the stuff panels are made of, does anyone have any comments on the Odessey??? http://www.mglavionics.com/html/odyssey.html I'm looking at that for my panel. I spent a lot of time looking at it at Sun-N-Fun. Tell me why you think it's a good or bad purchase!!! Linn ________________________________________________________________________________
Subject: Re: Cowling hinges
Date: Apr 14, 2008
John: An old trick from years gone by: Try beveling a piece of pin stock, chuck it in a battery powered drill motor and move it in and out of the hindge at a low RPM. Dick Sipp RV10 N110DV 40065 ----- Original Message ----- From: John Testement To: rv10-list(at)matronics.com Sent: Monday, April 14, 2008 9:38 PM Subject: RV10-List: Cowling hinges I am pretty much finished building and am sending the plane to my painter in pieces. I am really having a hard time getting the cowling hinges to go in. I believe some eyelets may have been bent a little out of alignment during paint prep. I would like to hear what others have done to realign the hinges and get hinge pins to go in more easily. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting Checked by AVG. 4/13/2008 1:45 PM ________________________________________________________________________________
From: "Bruce Snyder" <snyderbd888(at)sbcglobal.net>
Subject: Andair problems
Date: Apr 14, 2008
I've had an ongoing problem with Andair and I thought that I'd give everyone that was thinking about buying one of their products some insight into their lack of responsiveness and customer service. I purchased a fuel valve for my RV-10 before the valve extensions were available. At Oshkosh 2007 I personally handed them the fuel valve I purchased to be exchanged for one with a six inch extension. The receipt noted the serial number of the fuel valve that I gave them along with a quote for the price of a valve with the extension. I've been emailing every 2-3 weeks and I've called them a couple of times but here I am almost 9 months later with no fuel valve despite several promised shipping dates. I thought I was dealing with a reputable company but my experience so far has been otherwise. Bruce Snyder 40353 ________________________________________________________________________________
Date: Apr 14, 2008
I ordered the one from Spruce, but the $56 is too small for the RV10 vent. I had to return it. They were good on the refund. Tim is correct on the metal ones. I bit the bullet and bought Van's vents for $145 (ouch). They do have a nice mounting flange that married up to the vent perfectly. I am unimpressed by them at that price, but I tried the junks and Wentworth, but could not get any. Stein's look good. It just about kills me to think that I saw a bunch of them at a crash site a few years ago and did not salvage them. They were in perfect condition. Good lesson. -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=176888#176888 ________________________________________________________________________________
Subject: AFS Systems .... and others
Date: Apr 15, 2008
Linn, There has been a lot of discussion on the list of how many different EFIS systems this category can support before the industry consolidates leaving some panels without product innovation or support including replacement parts. I know nothing about Odyssey and their backing (and do not want to disparage them) but It does seem that Dynon & GRT on the (relatively) lower end of the price spectrum continue to develop & improve their already impressive & tested products. When one has spent so much time & effort on your aircraft it would be a shame to be stuck with a white elephant panel. Imagine having placed dual BMA EFIS One's in your plane because of all the reported features. When you eventually do offer your plane for sale the panel MAY eliminate many potential buyers. I look at a lot of RV-6/7/8's with amazing construction & beautiful paint then I see their panel and I think... yeeeeh... never mind. I don't know the ultimate difference in pricing between the Odyssey, Dynon & GRT offerings but they can't be THAT far apart when viewed in your overall -10 budget. I always say an aircraft is the airframe design, engine/prop & avionics. I think we all agree you have made an outstanding airframe selection, any of the approved engines are an excellent choice for the -10, all that is left is your panel. Robin RV-4 Sold RV-6A 400 Hours RV-10 Sooner or Later, Probably Later From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters Sent: Monday, April 14, 2008 6:42 PM Subject: Re: RV10-List: AFS Systems .... and others John W. Cox wrote: This is a perfect question for Stein of SteinAir or Dewey Conroy of Pacific Coast Avionics. They are probably both taking all kinds of orders and will address this after returning. Many inquiring minds want to know exactly these questions. I would like to see an EFIS system which can annunciate remotely mounted and controlled avionics without taking the financial dive with the Garmin G900X national debt decision. I am impressed with Robin's purchase but it is too rich for my blood. Synthetic Vision, HITS, Chartview, SafeTaxi, Terrain, Traffic and Weather with the capability to go IFR. Vertical Autopilot GPS steer with the AFS 4500 is a great start. John OK, while we're on the subject of the stuff panels are made of, does anyone have any comments on the Odessey??? http://www.mglavionics.com/html/odyssey.html I'm looking at that for my panel. I spent a lot of time looking at it at Sun-N-Fun. Tell me why you think it's a good or bad purchase!!! Linn ________________________________________________________________________________
Date: Apr 14, 2008
Robin, You raise an important consideration and one I gave serious weight to myself in choosing an EFIS supplier. Personally though I think Dynon and AFS have the greatest potential for longest term survival. Dynon because of their market share due to being first to market and having the lowest price points. Regarding AFS, you may not be aware that they have an OEM relationship with Bendix/King Honeywell (the KFD 840 Primary Flight Display), and also is the exclusive supplier of EFIS systems for the Glasair TWT Sportsman program. This provides diversification and funding for additional development and support resources that benefit those of us with AFS branded products. As an AFS owner I am more familiar with their situation than GRT, I hear great things from owners of their products also, just didn't know if any of this was widely known. I agree with those who think this market will likely experience some consolidation as it matures, and that those still choosing their avionics should consider this aspect as well. Randy Lervold RV-3B, www.rv3works.com RV-8 www.rv-8.com ----- Original Message ----- From: Robin Marks To: rv10-list(at)matronics.com Sent: Monday, April 14, 2008 9:19 PM Subject: RE: RV10-List: AFS Systems .... and others Linn, There has been a lot of discussion on the list of how many different EFIS systems this category can support before the industry consolidates leaving some panels without product innovation or support including replacement parts. I know nothing about Odyssey and their backing (and do not want to disparage them) but It does seem that Dynon & GRT on the (relatively) lower end of the price spectrum continue to develop & improve their already impressive & tested products. When one has spent so much time & effort on your aircraft it would be a shame to be stuck with a white elephant panel. Imagine having placed dual BMA EFIS One's in your plane because of all the reported features. When you eventually do offer your plane for sale the panel MAY eliminate many potential buyers. I look at a lot of RV-6/7/8's with amazing construction & beautiful paint then I see their panel and I think. yeeeeh. never mind. I don't know the ultimate difference in pricing between the Odyssey, Dynon & GRT offerings but they can't be THAT far apart when viewed in your overall -10 budget. I always say an aircraft is the airframe design, engine/prop & avionics. I think we all agree you have made an outstanding airframe selection, any of the approved engines are an excellent choice for the -10, all that is left is your panel. Robin RV-4 Sold RV-6A 400 Hours RV-10 Sooner or Later, Probably Later From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters Sent: Monday, April 14, 2008 6:42 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: AFS Systems .... and others John W. Cox wrote: This is a perfect question for Stein of SteinAir or Dewey Conroy of Pacific Coast Avionics. They are probably both taking all kinds of orders and will address this after returning. Many inquiring minds want to know exactly these questions. I would like to see an EFIS system which can annunciate remotely mounted and controlled avionics without taking the financial dive with the Garmin G900X national debt decision. I am impressed with Robin's purchase but it is too rich for my blood. Synthetic Vision, HITS, Chartview, SafeTaxi, Terrain, Traffic and Weather with the capability to go IFR. Vertical Autopilot GPS steer with the AFS 4500 is a great start. John OK, while we're on the subject of the stuff panels are made of, does anyone have any comments on the Odessey??? http://www.mglavionics.com/html/odyssey.html I'm looking at that for my panel. I spent a lot of time looking at it at Sun-N-Fun. Tell me why you think it's a good or bad purchase!!! Linn http://www.matronic - MATRONICS available via the Web href="http://forums.matronics.com">http://forums.matronics.com=== ================http://www.matronics.com/ c ________________________________________________________________________________
Subject: Pix
Date: Apr 15, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Any difference in flying qualities with the wheel pants, Gary? Jack Phillips #40610 Wings (Slooooo Build) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Monday, April 14, 2008 8:04 PM Subject: RV10-List: Pix I have been flying lots, but finally got the wheel pants on so took some pix to motivate you "yet to fly" guys. Gary 40274 Flying _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Subject: Pix
Date: Apr 15, 2008
It is about 15K faster at the same power settings. Gary 40274 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: Tuesday, April 15, 2008 8:02 AM Subject: RE: RV10-List: Pix Any difference in flying qualities with the wheel pants, Gary? Jack Phillips #40610 Wings (Slooooo Build) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Monday, April 14, 2008 8:04 PM Subject: RV10-List: Pix I have been flying lots, but finally got the wheel pants on so took some pix to motivate you "yet to fly" guys. Gary 40274 Flying _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Apr 15, 2008
Subject: OT: RRL First Exhibition Race
Should be pretty cool at OSH: http://www.rocketracingleague.com/media/press_releases/2008_4_14_oshkosh.ht ml ________________________________________________________________________________
Date: Apr 15, 2008
Subject: OT: it's all about the rivets
An interesting read for all of us rivet bangers. http://www.nytimes.com/2008/04/15/science/15titanic.html?ex=1208923200&en=4b81a0af77edab6c&ei=5070&emc=eta1 ________________________________________________________________________________
Date: Apr 15, 2008
When we build our panels and select the instruments/vendors that are available we are hoping that these products/companies well survive. None-the-less we are well aware that there will be many changes in the market in just a short time. In my RV-9A I installed a Navaid autopilot, changed to a Trio, was in the planning stage of removing the electric gyros and other round gages looking at EFIS/EMS displays. Now in the RV-10 I have Dynon EFIS/EMS and TruTrak but I'm looking at the Dynon autopilot and I know Trio has a new one to present at Oshkosh. My point is because we can make major panel changes some of us will-and maybe more than once. My advice is to make it as easy as possible to remove and alter the panel, add more wires, etc. I added rudder trim after completion but had already run a 5 wire cable into the tail cone and put the indicator on the panel 'just in case' so it was pretty easy to do. But what if it had required 6 wires instead of 5 I had run? Make it as easy as possible to incorporate change. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Apr 15, 2008
Randy, I forgot to group AFS impressive products in my brief list of solid companies. Like Jessie I apologize if I left a few personal favorites out but that just proves the point, too many to list. Again I feel we are very lucky to have all these options made available to us in just a few short years but it comes at a price. My yet to fly G900X has a fantastic new SVT option so my panel is already outdated and has yet to clear 10' AGL. I read that the SVT upgrade for Diamond Aircraft products will be $10K. They are obviously certified aircraft with "certified" costs but I have yet to get an answer on what my unit will cost for these improved features. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy Lervold Sent: Monday, April 14, 2008 10:19 PM Subject: Re: RV10-List: AFS Systems .... and others Robin, You raise an important consideration and one I gave serious weight to myself in choosing an EFIS supplier. Personally though I think Dynon and AFS have the greatest potential for longest term survival. Dynon because of their market share due to being first to market and having the lowest price points. Regarding AFS, you may not be aware that they have an OEM relationship with Bendix/King Honeywell (the KFD 840 Primary Flight Display), and also is the exclusive supplier of EFIS systems for the Glasair TWT Sportsman program. This provides diversification and funding for additional development and support resources that benefit those of us with AFS branded products. As an AFS owner I am more familiar with their situation than GRT, I hear great things from owners of their products also, just didn't know if any of this was widely known. I agree with those who think this market will likely experience some consolidation as it matures, and that those still choosing their avionics should consider this aspect as well. Randy Lervold RV-3B, www.rv3works.com RV-8 www.rv-8.com ----- Original Message ----- From: Robin Marks <mailto:robin1(at)mrmoisture.com> To: rv10-list(at)matronics.com Sent: Monday, April 14, 2008 9:19 PM Subject: RE: RV10-List: AFS Systems .... and others Linn, There has been a lot of discussion on the list of how many different EFIS systems this category can support before the industry consolidates leaving some panels without product innovation or support including replacement parts. I know nothing about Odyssey and their backing (and do not want to disparage them) but It does seem that Dynon & GRT on the (relatively) lower end of the price spectrum continue to develop & improve their already impressive & tested products. When one has spent so much time & effort on your aircraft it would be a shame to be stuck with a white elephant panel. Imagine having placed dual BMA EFIS One's in your plane because of all the reported features. When you eventually do offer your plane for sale the panel MAY eliminate many potential buyers. I look at a lot of RV-6/7/8's with amazing construction & beautiful paint then I see their panel and I think... yeeeeh... never mind. I don't know the ultimate difference in pricing between the Odyssey, Dynon & GRT offerings but they can't be THAT far apart when viewed in your overall -10 budget. I always say an aircraft is the airframe design, engine/prop & avionics. I think we all agree you have made an outstanding airframe selection, any of the approved engines are an excellent choice for the -10, all that is left is your panel. Robin RV-4 Sold RV-6A 400 Hours RV-10 Sooner or Later, Probably Later From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters Sent: Monday, April 14, 2008 6:42 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: AFS Systems .... and others John W. Cox wrote: This is a perfect question for Stein of SteinAir or Dewey Conroy of Pacific Coast Avionics. They are probably both taking all kinds of orders and will address this after returning. Many inquiring minds want to know exactly these questions. I would like to see an EFIS system which can annunciate remotely mounted and controlled avionics without taking the financial dive with the Garmin G900X national debt decision. I am impressed with Robin's purchase but it is too rich for my blood. Synthetic Vision, HITS, Chartview, SafeTaxi, Terrain, Traffic and Weather with the capability to go IFR. Vertical Autopilot GPS steer with the AFS 4500 is a great start. John OK, while we're on the subject of the stuff panels are made of, does anyone have any comments on the Odessey??? http://www.mglavionics.com/html/odyssey.html
April 07, 2008 - April 15, 2008
RV10-Archive.digest.vol-dg
