RV10-Archive.digest.vol-dh
April 15, 2008 - May 03, 2008
      	I'm looking at that for my panel.  I spent a lot of time looking
      at it at Sun-N-Fun.  Tell me why you think it's a good or bad
      purchase!!!
      	Linn
      	http://www.matronic           -
      MATRONICS available via the Web
      href="http://forums.matronics.com">http://forums.matronics.com===
      =========http://www.matronics.com/c
      href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic
      s
Subject: AFS Systems .... and others
Date: Apr 15, 2008
This is a great resource to share with the other builders. Knowing how many wires to run in anticipation of future adaption of emerging technology. Maybe Stein could make a future edition of Kitplanes Magazine on aircraft wiring tips, techniques and wiring run planning. Tim has done a lot with his loads and diagrams. Thanks for the wake up call. John Aurora, OR From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Tuesday, April 15, 2008 7:05 AM Subject: RE: RV10-List: AFS Systems .... and others When we build our panels and select the instruments/vendors that are available we are hoping that these products/companies well survive. None-the-less we are well aware that there will be many changes in the market in just a short time. In my RV-9A I installed a Navaid autopilot, changed to a Trio, was in the planning stage of removing the electric gyros and other round gages looking at EFIS/EMS displays. Now in the RV-10 I have Dynon EFIS/EMS and TruTrak but I'm looking at the Dynon autopilot and I know Trio has a new one to present at Oshkosh. My point is because we can make major panel changes some of us will-and maybe more than once. My advice is to make it as easy as possible to remove and alter the panel, add more wires, etc. I added rudder trim after completion but had already run a 5 wire cable into the tail cone and put the indicator on the panel 'just in case' so it was pretty easy to do. But what if it had required 6 wires instead of 5 I had run? Make it as easy as possible to incorporate change. Albert Gardner Yuma, AZ href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Automatic temp controller for air conditioning
Date: Apr 15, 2008
We recently announced at Sun n Fun a set and forget temperature controller for air conditioning systems. In a nutshell, you set the desired temp and it controls the fans and compressor to regulate the cabin temperature. It automatically turns on after engine start, and turns off during takeoff and after engine shutdown. If there is a fault with the air conditioning system, it tells you exactly where the fault is and what kind of fault occurred. You can find more information here: http://www.verticalpower.com/climate_control.html The system is just beginning beta testing now and expected to begin shipping in Q3 08. Marc -------- Marc Ausman http://www.verticalpower.com RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177002#177002 ________________________________________________________________________________
Date: Apr 15, 2008
Subject: flight planning
Curtis, Curtis, Extreme version 2 turbo on bottom 16500 Redundancy 2200 Engine mount (if it works on Buds) 1000 New zero time Block 3000 USD Intercooler 1500 Modification to your mount 500 Total above 24700 Plus extras Muffler, muffler support, muffler wrap 650 Wiring harness heat wrap, water line heat wrap, roll of exaust wrap 120 New total: 25470-5000 deposit 20470. I do not take person checks or money orders. The best thing is cash. You will also need to sign a hold harmless agreement prior to release of the engine. One more thing, i do not rip into engines any longer due to liability, so you have stock new pistons. Jason William Curtis wrote: Not sure how they can call themselves a GA planning site when you can't overlay your route on an actual aviation map (sectional, TAC, etc). Did I miss how to do this? The only options for the route maps are Street Map, Satellite, Hybrid and Terrain. I much prefer http://skyvector.com/ It will overlay your planned route on the actual current Sectional, TAC or IFR charts. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess -------- Original Message -------- > > A great flight planning web site that I think you will appreciate. > > http://www.navmonster.com/ > > > Rob Kermanj ________________________________________________________________________________
Subject: Andair problems
Date: Apr 15, 2008
Bruce: Can't agree more. They make very nice products and have the worlds crappie st service. I purchased two fuel caps for my RV-8 at Sun N Fun last year. They promised to ship them within 4 days. I never got them. Lots of emai ls, calls etc. Finally, I threatened to report them to my credit card comp any and they promised to send the caps right away and give me a 10% discoun t for my trouble. Still never got my gas caps. Only good news is to the b est of my knowledge them never charged my credit card either. They are embarrassingly bad at customer service. bruce From: snyderbd888(at)sbcglobal.netTo: rv10-list(at)matronics.comSubject: RV10-Lis t: Andair problemsDate: Mon, 14 Apr 2008 22:35:54 -0400 I=92ve had an ongoing problem with Andair and I thought that I=92d give eve ryone that was thinking about buying one of their products some insight int o their lack of responsiveness and customer service. I purchased a fuel va lve for my RV-10 before the valve extensions were available. At Oshkosh 20 07 I personally handed them the fuel valve I purchased to be exchanged for one with a six inch extension. The receipt noted the serial number of the fuel valve that I gave them along with a quote for the price of a valve wit h the extension. I=92ve been emailing every 2-3 weeks and I=92ve called th em a couple of times but here I am almost 9 months later with no fuel valve despite several promised shipping dates. I thought I was dealing with a r eputable company but my experience so far has been otherwise. Bruce Snyder 40353 _________________________________________________________________ Going green? See the top 12 foods to eat organic. http://green.msn.com/galleries/photos/photos.aspx?gid=164&ocid=T003MSN5 1N1653A ________________________________________________________________________________
Subject: wing rotisserie & paint booth
Date: Apr 15, 2008
Does anyone have pictures or plans for making a wing rotisserie? I want to be able to rotate the wings while they are being painted. Also, any suggestions for the size and plans for a homemade paint booth would be appreciated. Sheldon Olesen #40080 8 pieces ready to paint--all small ________________________________________________________________________________
Subject: Re: Andair problems
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Apr 15, 2008
Sorry to hear that. I personally had good experience with exchanging the fuel valve with the extension version. Hope they improve their service. Michael www.wellenzohn.net (FWF) -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177030#177030 ________________________________________________________________________________
Date: Apr 15, 2008
Sheldon, Sent you information off line. Bobby 4116 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sheldon Olesen Sent: Tuesday, April 15, 2008 2:07 PM Subject: RV10-List: wing rotisserie & paint booth Does anyone have pictures or plans for making a wing rotisserie? I want to be able to rotate the wings while they are being painted. Also, any suggestions for the size and plans for a homemade paint booth would be appreciated. Sheldon Olesen #40080 8 pieces ready to paint--all small ________________________________________________________________________________
Date: Apr 15, 2008
Bobby, Could you send the information to me to at rambud(at)windstream.net Thanks Bud -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes Sent: Tuesday, April 15, 2008 5:47 PM Subject: RE: RV10-List: wing rotisserie & paint booth Sheldon, Sent you information off line. Bobby 4116 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sheldon Olesen Sent: Tuesday, April 15, 2008 2:07 PM Subject: RV10-List: wing rotisserie & paint booth Does anyone have pictures or plans for making a wing rotisserie? I want to be able to rotate the wings while they are being painted. Also, any suggestions for the size and plans for a homemade paint booth would be appreciated. Sheldon Olesen #40080 8 pieces ready to paint--all small ________________________________________________________________________________
Date: Apr 15, 2008
Subject: Re: wing rotisserie & paint booth
I would appreciate the information too. I'm trying to decide whether to commit to paint or not. And it's time to paint some interior stuff. Thanks Bill "Living with Fiberglass" Watson 40605 Durham NC Bobby J. Hughes wrote: > > Sheldon, > > Sent you information off line. > > Bobby > 4116 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sheldon > Olesen > Sent: Tuesday, April 15, 2008 2:07 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: wing rotisserie & paint booth > > > Does anyone have pictures or plans for making a wing rotisserie? I > want to be able to rotate the wings while they are being painted. > Also, any suggestions for the size and plans for a homemade paint booth > would be appreciated. > > > Sheldon Olesen > #40080 8 pieces ready to paint--all small > > > ________________________________________________________________________________
Subject: doors again
Date: Apr 15, 2008
For those who are not using the metal blocks in place of the delrin blockin the door frame: There appears to be enough variability in door construction that the standard c-1012 and c-1011 are not always long enough to penetrate the complete door frame (i.e. delrin, glass and aluminum). For my money I like to see .25" of complete tube in the door jamb. Because of the length of the tube or the bevel, the supplied pins are short by .25-.375. I am making the suggestion to Vans to lengthen these by that amount and allow the builder to shorten to fit as opposed to my personal solution to buy material and machine as required. ________________________________________________________________________________
Subject: Re: Recommendations for front air vents
Date: Apr 15, 2008
Stein sells tem for just under $100. They are very nice and I found a great way to install them with no hardware or Proseal. Thane ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Monday, April 14, 2008 5:06 PM Subject: RV10-List: Recommendations for front air vents > > > Any recommendations for the front air vents? > Vans wants $145 for the aluminum ones > > Aircraft Spruce has several varieties in the $175 price range. > Is this is the part of the building where you say to the dealer? > > ........ hit me . :-) > > > Lew: good job on the wheel pants. Thanks for the reference, but I just > added the pics. Our late friend, Mark Ritter showed me how to do it when > I looked at his plane a couple of months ago. And I will be "displeased" > if you get flying before I do. > > > Fred Williams > 40515. > > > ________________________________________________________________________________
Subject: Recommendations for front air vents
Date: Apr 15, 2008
OK, so tell us the secret.......... Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Tuesday, April 15, 2008 4:51 PM Subject: Re: RV10-List: Recommendations for front air vents Stein sells tem for just under $100. They are very nice and I found a great way to install them with no hardware or Proseal. Thane ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Monday, April 14, 2008 5:06 PM Subject: RV10-List: Recommendations for front air vents > > > Any recommendations for the front air vents? > Vans wants $145 for the aluminum ones > > Aircraft Spruce has several varieties in the $175 price range. > Is this is the part of the building where you say to the dealer? > > ........ hit me . :-) > > > Lew: good job on the wheel pants. Thanks for the reference, but I just > added the pics. Our late friend, Mark Ritter showed me how to do it when > I looked at his plane a couple of months ago. And I will be "displeased" > if you get flying before I do. > > > Fred Williams > 40515. > > > ________________________________________________________________________________
Date: Apr 16, 2008
Thane - don't be coy. I am about to instal Steins vents and was thinking of E6000 to attach them to the NACA ducts. What was your method? Contact me off list if this is a secret . Cheers, Ron 187, almost there. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Wednesday, 16 April 2008 8:21 AM Subject: Re: RV10-List: Recommendations for front air vents Stein sells tem for just under $100. They are very nice and I found a great way to install them with no hardware or Proseal. Thane ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Monday, April 14, 2008 5:06 PM Subject: RV10-List: Recommendations for front air vents > > > Any recommendations for the front air vents? > Vans wants $145 for the aluminum ones > > Aircraft Spruce has several varieties in the $175 price range. > Is this is the part of the building where you say to the dealer? > > ........ hit me . :-) > > > Lew: good job on the wheel pants. Thanks for the reference, but I > just added the pics. Our late friend, Mark Ritter showed me how to do > it when I looked at his plane a couple of months ago. And I will be "displeased" > if you get flying before I do. > > > Fred Williams > 40515. > > > "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Apr 15, 2008
I'm within one to two hours from seeing how all this comes together and I a m surprised that the pins do not penetrate all three structures. Still have n't gotten to the part about how far the threaded bolts stick out of the pi ns, and why did I have to make a run to the hardware store for these bolts? ?? From: dlm46007(at)cox.netTo: rv10-list(at)matronics.comSubject: RV10-List: doors againDate: Tue, 15 Apr 2008 15:32:38 -0700 For those who are not using the metal blocks in place of the delrin blockin the door frame: There appears to be enough variability in door constructio n that the standard c-1012 and c-1011 are not always long enough to penetra te the complete door frame (i.e. delrin, glass and aluminum). For my money I like to see .25" of complete tube in the door jamb. Because of the length of the tube or the bevel, the supplied pins are short by .25-.375. I am ma king the suggestion to Vans to lengthen these by that amount and allow the builder to shorten to fit as opposed to my personal solution to buy materia l and machine as required. ________________________________________________________________________________
Date: Apr 15, 2008
The pins may not penetrate all three materials. My left rear pin engaged by the .25" minimum but the other three did not; the bevel in the right rear ran right to the edge of the aluminum; not sufficient for me. The only thing I can figure is that location of the handle can effect these lengths. The instructions requiring centering the handle in the box but of course the box location is determined by where the inner shell is glued to the outer shell. The appropriate holes on the shell halves were faint and flat so there is some variability there. By Friday the doors shoudl be ready to go back on. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Tuesday, April 15, 2008 4:17 PM Subject: RE: RV10-List: doors again I'm within one to two hours from seeing how all this comes together and I am surprised that the pins do not penetrate all three structures. Still haven't gotten to the part about how far the threaded bolts stick out of the pins, and why did I have to make a run to the hardware store for these bolts??? _____ From: dlm46007(at)cox.net Subject: RV10-List: doors again Date: Tue, 15 Apr 2008 15:32:38 -0700 For those who are not using the metal blocks in place of the delrin blockin the door frame: There appears to be enough variability in door construction that the standard c-1012 and c-1011 are not always long enough to penetrate the complete door frame (i.e. delrin, glass and aluminum). For my money I like to see .25" of complete tube in the door jamb. Because of the length of the tube or the bevel, the supplied pins are short by .25-.375. I am making the suggestion to Vans to lengthen these by that amount and allow the builder to shorten to fit as opposed to my personal solution to buy material and machine as required. get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: doors again
Date: Apr 15, 2008
Again, I did not thread the rods, just stuck a pencil in the hole with a bit of masking tape to make it firm and centered, and marked away -- it came out perfect. Using someone else's idea, I carved out the BACKSIDE of where the toothed bar retracts, and also a bit of the teflon (where the retaining pin on the toothed bar and the split end of the rod bumps in full open position) so that the pins can retract to the maximum -- which allows you to set the rod at maximum penetration in closed position (make sure they're set on the absolute last possible tooth). In open position, the inside handle is at about 130 degrees instead of 90. I get full penetration through all three structures. No threads. The taper pulls the door in snug with no help at all, no movement at all once it's shut. This weekend we'll temporarily install the provided weather strip with double sided carpet tape to see if we can accomplish the same fit. I can probably post pictures later if there's interest. This is not the right thread, but I gotta tell ya, I very much appreciate the info on the crashes, and it's VERY sobering if not downright discouraging. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177090#177090 ________________________________________________________________________________
Date: Apr 15, 2008
Subject: 64TX is a real airplane
64TX broke the bounds of earth on Saturday morning April 12 in celebration of my 65th bday. Flew well a little heavier on the controls than my 6A but still easy to fly. Now comes the fun. It was kit number 40378 and still needs interior and paint. ________________________________________________________________________________
Date: Apr 15, 2008
Congrats, Bill! I envy you! ________________________________ From: Bill Hicks [mailto:bilhicks(at)swbell.net] Sent: Tuesday, April 15, 2008 7:29 PM Subject: RV10-List: 64TX is a real airplane 64TX broke the bounds of earth on Saturday morning April 12 in celebration of my 65th bday. Flew well a little heavier on the controls than my 6A but still easy to fly. Now comes the fun. It was kit number 40378 and still needs interior and paint. ________________________________________________________________________________
Date: Apr 15, 2008
Bobby, I'm giving some thought to painting also. Could you email me the info also. Thanks, Tom Hanaway tomhanaway(at)comcast.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177114#177114 ________________________________________________________________________________
Subject: dimple or countersink around baggage door
Date: Apr 15, 2008
The plans call for you to countersink the aft six holes in the fuselage skin, where it mates to the forward six holes in the tailcone skin, F-1023 baggage floor angle, and F10100-A shim (page 32-4 figure 3). The QB fuselage has the forward holes dimpled in those pieces. The floor angle and shim was just temporarily attached with pop rivets. Why would I not dimple those remaining holes also? The .032 skin is the minimum for countersink, and I don't see an access issue. Is this a mistake in the plans, or is there a reason to countersink, not dimple. The same for the rivets above the baggage door, and on the right side, that go thru the skin into the longerons. All the holes that were filled with rivets have been dimpled, but the plans call for the remaining ones to be countersunk. Vans says to just build it. Anyone with an input? Chris Hukill dazed and confused ________________________________________________________________________________
Subject: Re: dimple or countersink around baggage door
Date: Apr 15, 2008
I just went out and looked at my fuse as I just did that step a few weeks ago. I countersunk the 6 holes as the plans said. There is plenty of material behind the skin with the shim and angle, no worries. I agree with Vans on this one, just build it. Dave Leikam 40496 ----- Original Message ----- From: Chris Hukill To: rv10-list(at)matronics.com Sent: Tuesday, April 15, 2008 10:30 PM Subject: RV10-List: dimple or countersink around baggage door The plans call for you to countersink the aft six holes in the fuselage skin, where it mates to the forward six holes in the tailcone skin, F-1023 baggage floor angle, and F10100-A shim (page 32-4 figure 3). The QB fuselage has the forward holes dimpled in those pieces. The floor angle and shim was just temporarily attached with pop rivets. Why would I not dimple those remaining holes also? The .032 skin is the minimum for countersink, and I don't see an access issue. Is this a mistake in the plans, or is there a reason to countersink, not dimple. The same for the rivets above the baggage door, and on the right side, that go thru the skin into the longerons. All the holes that were filled with rivets have been dimpled, but the plans call for the remaining ones to be countersunk. Vans says to just build it. Anyone with an input? Chris Hukill dazed and confused ________________________________________________________________________________
Date: Apr 15, 2008
NO one ever answerred my question to this email below I sent a week or so a go. Thanks! This could be the source of the problem right here, as long as the pins are long enough to just be emerging from the door while the handle is in the 1 30 degree position: Important question not adressed in the building instructions. When placing the latch mechanism inside the latch pocket, is it necessary to cut access holes for the geared arms that interface with the rod pin and the gear so that not only is there a cut in the pocket for the pin, but also the back h alf of the gear arm. Basically, when the door is open does the handle go up to the 90 degree position or does it go all the way to the 180 degree posi tion. If the pin was just emerging from the door side while the handle was in the 180 degree position(Facing aft), just think how far the pin will tr avel when the handle is placed in the closed position. The manual does not state the number of cuts in the latch pockets??????I haven't fitted the en tire mechanism yet, but real close so I am not certain of how it is suposse d to be.. JG > Subject: RV10-List: Re: doors again> From: lewgall(at)charter.net> Date: Tue message posted by: "Lew Gallagher" > > Again, I did no t thread the rods, just stuck a pencil in the hole with a bit of masking ta pe to make it firm and centered, and marked away -- it came out perfect.> > Using someone else's idea, I carved out the BACKSIDE of where the toothed bar retracts, and also a bit of the teflon (where the retaining pin on the toothed bar and the split end of the rod bumps in full open position) so th at the pins can retract to the maximum -- which allows you to set the rod a t maximum penetration in closed position (make sure they're set on the abso lute last possible tooth). In open position, the inside handle is at about 130 degrees instead of 90.> > I get full penetration through all three stru ctures. No threads. The taper pulls the door in snug with no help at all, n o movement at all once it's shut. This weekend we'll temporarily install th e provided weather strip with double sided carpet tape to see if we can acc omplish the same fit. I can probably post pictures later if there's interes t.> > This is not the right thread, but I gotta tell ya, I very much apprec iate the info on the crashes, and it's VERY sobering if not downright disco uraging.> > Later, - Lew> > --------> non-pilot> crazy about building> NOW OFICIALLY BUILDER #40549> doors almost finished, pants on, WHEW!> > > > > R ead this topic online here:> > http://forums.matronics.com/viewtopic.php?p =========> > > ________________________________________________________________________________
Date: Apr 16, 2008
Hey John, The plans are silent on this, but attached is a photo of 410RV. If you do not cut the hole in the back of the pocket, there is no way to achieve required full pin travel. cheers, Ron - almost there ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Wednesday, 16 April 2008 2:31 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Re: doors again NO one ever answerred my question to this email below I sent a week or so ago. Thanks! This could be the source of the problem right here, as long as the pins are long enough to just be emerging from the door while the handle is in the 130 degree position: Important question not adressed in the building instructions. When placing the latch mechanism inside the latch pocket, is it necessary to cut access holes for the geared arms that interface with the rod pin and the gear so that not only is there a cut in the pocket for the pin, but also the back half of the gear arm. Basically, when the door is open does the handle go up to the 90 degree position or does it go all the way to the 180 degree position. If the pin was just emerging from the door side while the handle was in the 180 degree position(Facing aft), just think how far the pin will travel when the handle is placed in the closed position. The manual does not state the number of cuts in the latch pockets??????I haven't fitted the entire mechanism yet, but real close so I am not certain of how it is supossed to be.. JG > Subject: RV10-List: Re: doors again > From: lewgall(at)charter.net > Date: Tue, 15 Apr 2008 17:03:13 -0700 > To: rv10-list(at)matronics.com > > > Again, I did not thread the rods, just stuck a pencil in the hole with a bit of masking tape to make it firm and centered, and marked away -- it came out perfect. > > Using someone else's idea, I carved out the BACKSIDE of where the toothed bar retracts, and also a bit of the teflon (where the retaining pin on the toothed bar and the split end of the rod bumps in full open position) so that the pins can retract to the maximum -- which allows you to set the rod at maximum penetration in closed position (make sure they're set on the absolute last possible tooth). In open position, the inside handle is at about 130 degrees instead of 90. > > I get full penetration through all three structures. No threads. The taper pulls the door in snug with no help at all, no movement at all once it's shut. This weekend we'll temporarily install the provided weather strip with double sided carpet tape to see if we can accomplish the same fit. I can probably post pictures later if there's interest. > > This is not the right thread, but I gotta tell ya, I very much appreciate the info on the crashes, and it's VERY sobering if not downright discouraging. > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > doors almost finished, pants on, WHEW! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=177090#177090 > > > > > > > &g=============== > > > "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Apr 16, 2008
The $18 plastic ones from Vans (approximate price) work fine if you add a little RTV to seal the leak in the "closed" position. I believe the process is discussed in 21 Years of the RVator. It's also discussed in the RV-list archives. I used it in my -6A, works well. I'm doing the same thing for my RV-10. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction Fred Williams, M.D. wrote: > > > Any recommendations for the front air vents? > Vans wants $145 for the aluminum ones > > Aircraft Spruce has several varieties in the $175 price range. > Is this is the part of the building where you say to the dealer? > > ........ hit me . :-) > > > Lew: good job on the wheel pants. Thanks for the reference, but I > just added the pics. Our late friend, Mark Ritter showed me how to do > it when I looked at his plane a couple of months ago. And I will be > "displeased" if you get flying before I do. > > > Fred Williams > 40515. > > ________________________________________________________________________________
Date: Apr 16, 2008
Hey John (JG), That's the one! It was YOUR post that gave me the idea to play with the holes on the backside -- I just now got there, and it works. Try it, you'll like it! Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177164#177164 ________________________________________________________________________________
Subject: Re: AFS Systems .... and others
Date: Apr 16, 2008
John, In response to your question. The Odyssey looks very good. MGL has earlier products so they are not exactly new to the game. I agree that some manufacturers will drop out in time and who knows which ones. The one thing I like about them is willingness to incorporate 3rd party devices. They are fine with Trio or TruTrak, and probably can work with any other manufacturer that uses ARINC 429. They can make the Dynon Pitot/AOA work, the AFS holes, and can even accomodate home-made AoA systems. I'll keep an eye on them. Just like Oshkosh, I found Sun 'n fun overwhelming in the avionics areas. Too many things to absorb. The one thing I have gotten out of it however, is the high prices and arrogance of the Garmin folks. John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177184#177184 ________________________________________________________________________________
Date: Apr 16, 2008
In a message dated 4/16/2008 9:18:34 AM Central Daylight Time, johngoodman(at)earthlink.net writes: is the high prices and arrogance of the Garmin folks Anyone else get the feeling that now since garmin has gone from aviation background to the general public in car devices...they really don't need aviation anymore or certainly have an attitude like this? We're sort of their test market and highest profit margin per product area, but lowest market unit area... P **************It's Tax Time! Get tips, forms and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolcmp00300000002850) ________________________________________________________________________________
Date: Apr 16, 2008
Thanks Ron, I cut the holes anyway, but was skiing last weekend so I haven't finished t he pin install. If I don't get enough length with the Van's pins and bolt a ssembly, I'll make up my own from new tube stock. JOhn Subject: RE: RV10-List: Re: doors againDate: Wed, 16 Apr 2008 14:50:25 +093 0From: ron.mcgann(at)baesystems.comTo: rv10-list(at)matronics.com Hey John, The plans are silent on this, but attached is a photo of 410RV. If you do not cut the hole in the back of the pocket, there is no way to achieve requ ired full pin travel. cheers, Ron - almost there From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John GonzalezSent: Wednesday, 16 April 2008 2:31 PMTo: rv10-list(at)matronics.comSubject: RE: RV10-List: Re: doors again NO one ever answerred my question to this email below I sent a week or so a go. Thanks! This could be the source of the problem right here, as long a s the pins are long enough to just be emerging from the door while the hand le is in the 130 degree position: Important question not adressed in the bu ilding instructions. When placing the latch mechanism inside the latch poc ket, is it necessary to cut access holes for the geared arms that interface with the rod pin and the gear so that not only is there a cut in the pocke t for the pin, but also the back half of the gear arm. Basically, when the door is open does the handle go up to the 90 degree position or does it go all the way to the 180 degree position. If the pin was just emerging from the door side while the handle was in the 180 degree position(Facing aft), just think how far the pin will travel when the handle is placed in the clo sed position. The manual does not state the number of cuts in the latch po ckets??????I haven't fitted the entire mechanism yet, but real close so I a m not certain of how it is supossed to be.. JG > Subject: RV10-List: Re: do ors again> From: lewgall(at)charter.net> Date: Tue, 15 Apr 2008 17:03:13 -0700 agher" > > Again, I did not thread the rods, just stuc k a pencil in the hole with a bit of masking tape to make it firm and cente red, and marked away -- it came out perfect.> > Using someone else's idea, I carved out the BACKSIDE of where the toothed bar retracts, and also a bit of the teflon (where the retaining pin on the toothed bar and the split en d of the rod bumps in full open position) so that the pins can retract to t he maximum -- which allows you to set the rod at maximum penetration in clo sed position (make sure they're set on the absolute last possible tooth). I n open position, the inside handle is at about 130 degrees instead of 90.> > I get full penetration through all three structures. No threads. The tape r pulls the door in snug with no help at all, no movement at all once it's shut. This weekend we'll temporarily install the provided weather strip wit h double sided carpet tape to see if we can accomplish the same fit. I can probably post pictures later if there's interest.> > This is not the right thread, but I gotta tell ya, I very much appreciate the info on the crashes , and it's VERY sobering if not downright discouraging.> > Later, - Lew> > --------> non-pilot> crazy about building> NOW OFICIALLY BUILDER #40549> do ors almost finished, pants on, WHEW!> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.php?p=177090#177090> > > > > > > &g================> > > p://www.matronics.com/Navigator?RV10-List ics.com .matronics.com/contribution "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Apr 16, 2008
with the G1000 and G900 I think the Garmin folks are more "we're better than thou" than thinking we are their test bed. Some company reps get that way, figure they don't need anyone when they are selling products based on the name alone. Arrogance is from thinking they dont need us as much as they think we need them.. Sadly I need a 430w to go with my AFS system.. until there is a good replacement I really dont have much of a choice.. happens when a company buys their competition (Apollo/UPS) Pascal ----- Original Message ----- From: GRANSCOTT(at)aol.com To: rv10-list(at)matronics.com Sent: Wednesday, April 16, 2008 7:26 AM Subject: Re: RV10-List: Re: AFS Systems .... and others In a message dated 4/16/2008 9:18:34 AM Central Daylight Time, johngoodman(at)earthlink.net writes: is the high prices and arrogance of the Garmin folks Anyone else get the feeling that now since garmin has gone from aviation background to the general public in car devices...they really don't need aviation anymore or certainly have an attitude like this? We're sort of their test market and highest profit margin per product area, but lowest market unit area... P ------------------------------------------------------------------------- ----- It's Tax Time! Get tips, forms and advice on AOL Money & Finance. ________________________________________________________________________________
Date: Apr 16, 2008
Pascal's hit the nail on the head! UPSAT had a great line of products that kept Garmin on their toes and reasonable. Garmin's taken some of the good things and discarded some of the good things. If there were only some competition.... -----Original Message----- >From: Pascal <rv10builder(at)verizon.net> >Sent: Apr 16, 2008 11:13 AM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Re: AFS Systems .... and others > >with the G1000 and G900 I think the Garmin folks are more "we're better than thou" than thinking we are their test bed. Some company reps get that way, figure they don't need anyone when they are selling products based on the name alone. >Arrogance is from thinking they dont need us as much as they think we need them.. Sadly I need a 430w to go with my AFS system.. until there is a good replacement I really dont have much of a choice.. happens when a company buys their competition (Apollo/UPS) > >Pascal > ----- Original Message ----- > From: GRANSCOTT(at)aol.com > To: rv10-list(at)matronics.com > Sent: Wednesday, April 16, 2008 7:26 AM > Subject: Re: RV10-List: Re: AFS Systems .... and others > > > In a message dated 4/16/2008 9:18:34 AM Central Daylight Time, johngoodman(at)earthlink.net writes: > is the high prices and arrogance of the Garmin folks > Anyone else get the feeling that now since garmin has gone from aviation background to the general public in car devices...they really don't need aviation anymore or certainly have an attitude like this? We're sort of their test market and highest profit margin per product area, but lowest market unit area... > > P > > >------------------------------------------------------------------------------ > It's Tax Time! Get tips, forms and advice on AOL Money & Finance. > > ________________________________________________________________________________
Date: Apr 16, 2008
I wonder what the price will be for this Honeywell unit. The one sitting beside the AFS display. Garmin needs competition so I hope this product will be competitively priced. https://commerce.honeywell.com/webapp/wcs/stores/servlet/CategoryDisplay ?storeId=10101&catalogId=10052&langId=-1&cursel=item1&identifier= Apex%20 Edge%20Series Bobby 40116 ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Wednesday, April 16, 2008 9:14 AM Subject: Re: RV10-List: Re: AFS Systems .... and others with the G1000 and G900 I think the Garmin folks are more "we're better than thou" than thinking we are their test bed. Some company reps get that way, figure they don't need anyone when they are selling products based on the name alone. Arrogance is from thinking they dont need us as much as they think we need them.. Sadly I need a 430w to go with my AFS system.. until there is a good replacement I really dont have much of a choice.. happens when a company buys their competition (Apollo/UPS) Pascal ----- Original Message ----- From: GRANSCOTT(at)aol.com To: rv10-list(at)matronics.com Sent: Wednesday, April 16, 2008 7:26 AM Subject: Re: RV10-List: Re: AFS Systems .... and others In a message dated 4/16/2008 9:18:34 AM Central Daylight Time, johngoodman(at)earthlink.net writes: is the high prices and arrogance of the Garmin folks Anyone else get the feeling that now since garmin has gone from aviation background to the general public in car devices...they really don't need aviation anymore or certainly have an attitude like this? We're sort of their test market and highest profit margin per product area, but lowest market unit area... P ________________________________ It's Tax Time! Get tips, forms and advice on AOL Money & Finance <http://money.aol.com/tax?NCID=aolcmp00300000002850> . href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 16, 2008
Garmin does have competition in the form of Chelton, OP and others. Plus I absolutely consider the lower priced EFIS units competition to Garmin as I strongly considered them before going with the G900X. I agree that Garmin is A LOT like MS and they both seem to be full of themselves however they both make excellent products that tend to be pretty well sorted out when they hit the market place. A thing that is really difficult to do in the aggressive world of software development which at this point is exactly, they both are... software vendors. While I can find fault with MS, I have also been able to pay for my -10 and the balance of my family's lifestyle almost exclusively using MS software. I can get annoyed with MS but I am also thankful that they are a stable, consistent global company. They may screw you on some product pricing but they don't Bear Stearns screw you. The same goes for Garmin from my point of view. On my G900X purchase I looked at Dynon, GRT, AFS on the low end and Chelton / OP on the high end specifically and I know I would have been very happy with any of these fine devices but I would have still had to get a transponder, dual radios, audio panel etc (OP excluded) ... and when I penciled it out the difference was not that great. In some cases there was no price difference at all. PLEASE cut me some slack here because in this scenario I consider $15K "not that great." Then adding the potential costs to integrate all these different pieces of equipment from different vendors and learning the nuances of each piece of equipment made the purchase price difference (to me) become almost a push. The thought of a single fully integrated stable system did have its appeal to me and was probably the overriding factor in my choice. Add the fact that I many want to move up in aircraft class at some point and that there is a very strong possibility that there will be a G900/1000 driving that ship and all of a sudden Garmin made the most sense for my purchase. Yes we can bitch about Garmin for many reasons. I plan to be one of the loudest complainers starting in the next few months as we give life to this horse tail size gaggle of wires but for now I am fat, dumb & happy as the unit is paid for, delivered and looks exactly how I sketched it out 10 months ago . Robin WARNING, this aircraft is amateur built... ________________________________________________________________________________
Date: Apr 16, 2008
________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Robin Marks Sent: Wed 4/16/2008 10:04 AM Subject: RE: RV10-List: Re: AFS Systems .... and others Garmin does have competition in the form of Chelton, OP and others. Plus I absolutely consider the lower priced EFIS units competition to Garmin as I strongly considered them before going with the G900X. I agree that Garmin is A LOT like MS and they both seem to be full of themselves however they both make excellent products that tend to be pretty well sorted out when they hit the market place. A thing that is really difficult to do in the aggressive world of software development which at this point is exactly, they both are... software vendors. While I can find fault with MS, I have also been able to pay for my -10 and the balance of my family's lifestyle almost exclusively using MS software. I can get annoyed with MS but I am also thankful that they are a stable, consistent global company. They may screw you on some product pricing but they don't Bear Stearns screw you. The same goes for Garmin from my point of view. On my G900X purchase I looked at Dynon, GRT, AFS on the low end and Chelton / OP on the high end specifically and I know I would have been very happy with any of these fine devices but I would have still had to get a transponder, dual radios, audio panel etc (OP excluded) ... and when I penciled it out the difference was not that great. In some cases there was no price difference at all. PLEASE cut me some slack here because in this scenario I consider $15K "not that great." Then adding the potential costs to integrate all these different pieces of equipment from different vendors and learning the nuances of each piece of equipment made the purchase price difference (to me) become almost a push. The thought of a single fully integrated stable system did have its appeal to me and was probably the overriding factor in my choice. Add the fact that I many want to move up in aircraft class at some point and that there is a very strong possibility that there will be a G900/1000 driving that ship and all of a sudden Garmin made the most sense for my purchase. Yes we can bitch about Garmin for many reasons. I plan to be one of the loudest complainers starting in the next few months as we give life to this horse tail size gaggle of wires but for now I am fat, dumb & happy as the unit is paid for, delivered and looks exactly how I sketched it out 10 months ago . Robin WARNING, this aircraft is amateur built... ________________________________________________________________________________
Date: Apr 16, 2008
Robin, your killing us here. "Warning, this aircraft panel was built by" one of the finest avionics shops in the country. You have what many of us can just dream about. As configured, what did it run (in US dollars) to get to this level of coverage. My question is still out there (Remotely mounted avionics). Stein gave me a price for my creation and I could by a 1970 Cessna or Piper for that chunk. The market needs a challenger to Garmin on the ability to remotely locate and control "current technology" avionics. Each of the competitors you mention love to have panel mounted bricks like the ole Motorola, first generation cellphone, that extend 11 inches towards the firewall and then add real weight forward of the CG point. Do you have any pictures of your remotely mounted dual GPS/Nav/Comm/ILS units? I would love it if AFS/Chelton/Grand Rapids/Dynon/OP/L3/Avidyne and all of Jesse's forgottens would control the remote Garmin stacks - off the high value real estate like your picture shows. Technically advanced certified aircraft are all the same layout and supplier - Garmin 1000. We need some choices here. It is like the days of being a logger in the Pacific NW circa 1850 or a pipeline worker in Alaska 1970. Ecks, does anyone shave their legs up here - oh there are few of them. The price Please.... John C. ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Robin Marks Sent: Wed 4/16/2008 10:04 AM Subject: RE: RV10-List: Re: AFS Systems .... and others Garmin does have competition in the form of Chelton, OP and others. Plus I absolutely consider the lower priced EFIS units competition to Garmin as I strongly considered them before going with the G900X. I agree that Garmin is A LOT like MS and they both seem to be full of themselves however they both make excellent products that tend to be pretty well sorted out when they hit the market place. A thing that is really difficult to do in the aggressive world of software development which at this point is exactly, they both are... software vendors. While I can find fault with MS, I have also been able to pay for my -10 and the balance of my family's lifestyle almost exclusively using MS software. I can get annoyed with MS but I am also thankful that they are a stable, consistent global company. They may screw you on some product pricing but they don't Bear Stearns screw you. The same goes for Garmin from my point of view. On my G900X purchase I looked at Dynon, GRT, AFS on the low end and Chelton / OP on the high end specifically and I know I would have been very happy with any of these fine devices but I would have still had to get a transponder, dual radios, audio panel etc (OP excluded) ... and when I penciled it out the difference was not that great. In some cases there was no price difference at all. PLEASE cut me some slack here because in this scenario I consider $15K "not that great." Then adding the potential costs to integrate all these different pieces of equipment from different vendors and learning the nuances of each piece of equipment made the purchase price difference (to me) become almost a push. The thought of a single fully integrated stable system did have its appeal to me and was probably the overriding factor in my choice. Add the fact that I many want to move up in aircraft class at some point and that there is a very strong possibility that there will be a G900/1000 driving that ship and all of a sudden Garmin made the most sense for my purchase. Yes we can bitch about Garmin for many reasons. I plan to be one of the loudest complainers starting in the next few months as we give life to this horse tail size gaggle of wires but for now I am fat, dumb & happy as the unit is paid for, delivered and looks exactly how I sketched it out 10 months ago . Robin WARNING, this aircraft is amateur built... ________________________________________________________________________________
Date: Apr 16, 2008
I think Garmin is more reminiscent King in the 70s when Gar Min germinated. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Wednesday, April 16, 2008 8:14 AM Subject: Re: RV10-List: Re: AFS Systems .... and others with the G1000 and G900 I think the Garmin folks are more "we're better than thou" than thinking we are their test bed. Some company reps get that way, figure they don't need anyone when they are selling products based on the name alone. Arrogance is from thinking they dont need us as much as they think we need them.. Sadly I need a 430w to go with my AFS system.. until there is a good replacement I really dont have much of a choice.. happens when a company buys their competition (Apollo/UPS) Pascal ----- Original Message ----- From: GRANSCOTT(at)aol.com Sent: Wednesday, April 16, 2008 7:26 AM Subject: Re: RV10-List: Re: AFS Systems .... and others In a message dated 4/16/2008 9:18:34 AM Central Daylight Time, johngoodman(at)earthlink.net writes: is the high prices and arrogance of the Garmin folks Anyone else get the feeling that now since garmin has gone from aviation background to the general public in car devices...they really don't need aviation anymore or certainly have an attitude like this? We're sort of their test market and highest profit margin per product area, but lowest market unit area... P _____ It's Tax Time! Get tips, forms and advice on AOL <http://money.aol.com/tax?NCID=aolcmp00300000002850> Money & Finance. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 16, 2008
It'll list for around 17,000 That GPS/Nav/Com will list for about 14,000 bhughes(at)qnsi.net wrote: > I wonder what the price will be for this Honeywell unit. The one sitting beside the AFS display. Garmin needs competition so I hope this product will be competitively priced. > > https://commerce.honeywell.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10101&catalogId=10052&langId=-1&cursel=item1&identifier=Apex%20Edge%20Series (https://commerce.honeywell.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10101&catalogId=10052&langId=-1&cursel=item1&identifier=Apex%20Edge%20Series) > > Bobby > 40116 > -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177278#177278 ________________________________________________________________________________
Subject: door seals
Date: Apr 16, 2008
Just a heads up. My original door seals were light gray. Because one did not stick properly I ordered a new seal; had to purchase the 25 feet. OK. The new seals are light brown. Surprise. ________________________________________________________________________________
Date: Apr 16, 2008
Subject: Re: door seals
>From Vans or ? I thought some were using seals from aircraftdoorseals.com On Wed, Apr 16, 2008 at 6:32 PM, David McNeill wrote: > Just a heads up. My original door seals were light gray. Because one did > not stick properly I ordered a new seal; had to purchase the 25 feet. OK. > The new seals are light brown. Surprise. > > * > > * > > ________________________________________________________________________________
Date: Apr 16, 2008
Subject: door seals
Subject: door seals
Date: Apr 16, 2008
vans _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, April 16, 2008 7:00 PM Subject: RV10-List: door seals >From Vans or ? I thought some were using seals from aircraftdoorseals.com On Wed, Apr 16, 2008 at 6:32 PM, David McNeill wrote: Just a heads up. My original door seals were light gray. Because one did not stick properly I ordered a new seal; had to purchase the 25 feet. OK. The new seals are light brown. Surprise. ________________________________________________________________________________
Date: Apr 16, 2008
David, Other than color are there other characteristics that are different? Dimensions, including thickness? Stiffness? Etc? Thanks, Dave Lammers Finishing--about to fasten door seals David McNeill wrote: > Just a heads up. My original door seals were light gray. Because one > did not stick properly I ordered a new seal; had to purchase the 25 > feet. OK. The new seals are light brown. Surprise. > > ________________________________________________________________________________
Date: Apr 16, 2008
Robin: Fantastic panel. I am wondering how you and the others using extended depth panels are planning on handling the stick interference issue? My panel is less than an inch deeper than stock and getting the Infinity stick grips to clear took shortening upper portion of the stick as much as possible and still mount the grip. Thanks Dick Sipp RV10 N110DV close ________________________________________________________________________________
Subject: door seals
Date: Apr 16, 2008
does not appear too be; be advised that this time we are using the same 3M super silicone sealant clear that is mentioned in the plans. Used a GE product first time, a silicon sealant rated 10 on the 10 scale bonding the seal to glass and one worked and the other did not. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Lammers Sent: Wednesday, April 16, 2008 7:39 PM Subject: Re: RV10-List: door seals David, Other than color are there other characteristics that are different? Dimensions, including thickness? Stiffness? Etc? Thanks, Dave Lammers Finishing--about to fasten door seals David McNeill wrote: Just a heads up. My original door seals were light gray. Because one did not stick properly I ordered a new seal; had to purchase the 25 feet. OK. The new seals are light brown. Surprise. ________________________________________________________________________________
Date: Apr 16, 2008
>My question is still out there (Remotely mounted avionics) Why the fascination with remote mounted avionics? The Garmin G-900 allows installation with the Line Replaceable Units (LRUs) mounted remotely or directly in front of the screens. While remote mounted avionics may be a plus, even mandatory in large aircraft, that requirement is significantly reduced in small aircraft such as the RV-10. Here is a picture of a G-900 in an RV-7 by a Garmin engineer. http://nerv10.com/wcurtis/pictures/images/G900XRV2.jpg Here is a picture of the forward side of the panel with the LRUs installed with the screens. http://nerv10.com/wcurtis/pictures/images/G900XRV1.jpg This is a picture of the G-900 with only the screens installed on the panel. The LRUs are installed in a remote location ala new Cessna 182-206. http://nerv10.com/wcurtis/pictures/images/G900XRV3.jpg William RV10-List(at)matronics.com ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: Torque wing bolts
Date: Apr 17, 2008
Could someone look up the torque for me for those nas bolts that hold the wings on? Cant find my red book regards Chris ________________________________________________________________________________
Date: Apr 16, 2008
Thanks for the review. I captured all of these back in the Garmin tent at OSH '06. It was a proof of concept done in Salem at their Black Ops site where they developed the G1000 options, G600 and G900X. Remotely mounted avionics stacks reduce panel heat, provide tremendous flexibility in W&B issues, improves performance, enhances pilot ergonomics and functional flow during "hard IFR" (a phrase I do not like). Remotely mounted makes panel installation a breeze. It only took some time inside a shiny new KingAir C90, a new Mooney, a Cessna 182XP and the DJet prototype to see clearly where panel design has moved since Jim introduced "ArchAngel" in a Lancair IV, N425HP (Jesse' you tracking this hangar queen?) back in 1983. Dynon pryed open the low end of the Experimental market, Sierra moved the bar to SV, AFS brought us the best in engine monitoring and now the playing field is infilling the holes. The only missed point is that volume should begin to push down the piety of Garmin. If only Apollo(UPS Aviation) in Salem would jump back into this game. Aspen is even breathing life into the concept of Dynon style EFIS screens for retrofit steam gauge guys. And let's all thank Mark and his Vertical Power developments. Let's not forget our own Bill DeRouchey and the great job he has done with his panel. Jim Hergert's N6XE set the standard with his three screen Chelton Sierras and it is so beautiful that Garmin uses his plane in their literature to sell the G900 (He doesn't even own them). His only Garmins are not EFIS they are the Old Panel mounted Rack Avionics of the 1950's. Oh how I love nostalgia. One formula has remained timeless. The percent of final cost in the airframe, the percent in the FWF, the percent in the total Avionics, Abby would love you to factor a percentage for a professional interior - too. As Stein puts it so well, three things lead to higher resale value. Avionics properly laidout, well wired and functional is a big one. Now that RV7 with dual G900's that sets the needle to full deflection. WOW he took that to heart. Oh yeh, if we could only pay what he did. That is where "Supply & Demand" needs to sign in. The one factor missing from Robin's post was the Garmin mandated factory installation cost. Tim got it right - he did it all and shared each step. Randy got Lancair to do his. The rest of us say our prayers each night that pricing will get downright competitive like Dell Computers. John C. ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of William Curtis Sent: Wed 4/16/2008 9:10 PM Subject: RV10-List: Re: AFS Systems .... and others >My question is still out there (Remotely mounted avionics) Why the fascination with remote mounted avionics? The Garmin G-900 allows installation with the Line Replaceable Units (LRUs) mounted remotely or directly in front of the screens. While remote mounted avionics may be a plus, even mandatory in large aircraft, that requirement is significantly reduced in small aircraft such as the RV-10. Here is a picture of a G-900 in an RV-7 by a Garmin engineer. http://nerv10.com/wcurtis/pictures/images/G900XRV2.jpg Here is a picture of the forward side of the panel with the LRUs installed with the screens. http://nerv10.com/wcurtis/pictures/images/G900XRV1.jpg This is a picture of the G-900 with only the screens installed on the panel. The LRUs are installed in a remote location ala new Cessna 182-206. http://nerv10.com/wcurtis/pictures/images/G900XRV3.jpg William RV10-List(at)matronics.com ________________________________________________________________________________
Date: Apr 17, 2008
Subject: Encoder / Transponder question
I'm in the process of connecting up some avionics HW and need some assistance. I have the Ameri-King AK-350 encoder and the Garmin GTX-320A transponder. My question is where do I hook up pin #18 on the Garmin ? Its listed as Altitude D4. The AK-350 doesn't have an altitude D4 pin and I can't find a reference as to what D4 actually is. Is my AK-350 outdated? The AK-350 has a DB-15 pin connector and the Garmin has a DB-25 pin connector Anyone have a schematic laying around that includes the Garmin. My AK-350 is new in the box but about 7 years old. A google search did not provide any worth while results John 40102 ________________________________________________________________________________
Date: Apr 17, 2008
I have not searched for the 320A manual I have for the Glastar but I believe you do not need to hook up that wire. I believe that the encoding is binary and the D4 provides an altitude that you encoder does not support; Your encoder may be limited to 20000 but the Garmin may be able to report 30000 to ATC. Additionally Garmin can supply a pdf of their old tech manual. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hurst Sent: Thursday, April 17, 2008 5:53 AM Subject: RV10-List: Encoder / Transponder question I'm in the process of connecting up some avionics HW and need some assistance. I have the Ameri-King AK-350 encoder and the Garmin GTX-320A transponder. My question is where do I hook up pin #18 on the Garmin ? Its listed as Altitude D4. The AK-350 doesn't have an altitude D4 pin and I can't find a reference as to what D4 actually is. Is my AK-350 outdated? The AK-350 has a DB-15 pin connector and the Garmin has a DB-25 pin connector Anyone have a schematic laying around that includes the Garmin. My AK-350 is new in the box but about 7 years old. A google search did not provide any worth while results John 40102 ________________________________________________________________________________
Date: Apr 17, 2008
In a message dated 4/16/2008 11:05:11 PM Central Daylight Time, wcurtis(at)nerv10.com writes: Why the fascination with remote mounted avionics? CG... **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 17, 2008
IIRC the first nine pins provide 8 bit binary to indicate altitude and one the 320A is capable. Short story you do not need to hook it anywhere.. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Hurst Sent: Thursday, April 17, 2008 5:53 AM Subject: RV10-List: Encoder / Transponder question I'm in the process of connecting up some avionics HW and need some assistance. I have the Ameri-King AK-350 encoder and the Garmin GTX-320A transponder. My question is where do I hook up pin #18 on the Garmin ? Its listed as Altitude D4. The AK-350 doesn't have an altitude D4 pin and I can't find a reference as to what D4 actually is. Is my AK-350 outdated? The AK-350 has a DB-15 pin connector and the Garmin has a DB-25 pin connector Anyone have a schematic laying around that includes the Garmin. My AK-350 is new in the box but about 7 years old. A google search did not provide any worth while results John 40102 ________________________________________________________________________________
Subject: SkyTec Starter Wiring Warning
Date: Apr 17, 2008
Probably everyone knows about this but me, but since I just fried my oil-soaked SkyTec starter on my GlaStar, I was perusing their web pages and found this: http://www.skytecair.com/Wiring_diag.htm Scroll down to the RV-10 wiring warning. If the shoe fits... John Jessen 40328 building GlaStar flying ________________________________________________________________________________
Date: Apr 17, 2008
Subject: First flight
Serial 40065 N110DV was successfully flown for the first time this afternoon. No problems were noted and the airplane flew well. Pictures and more information after the test period is complete and we've been to the paintshop. Dick Sipp RV 10 flying ________________________________________________________________________________
Date: Apr 17, 2008
Great news Dick!!! With all the first flights, we are going to need a couple rows at OSH for parking all the RV-10s! Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rsipp(at)earthlink.net Sent: Thursday, April 17, 2008 3:26 PM Subject: RV10-List: First flight Serial 40065 N110DV was successfully flown for the first time this afternoon. No problems were noted and the airplane flew well. Pictures and more information after the test period is complete and we've been to the paintshop. Dick Sipp RV 10 flying ________________________________________________________________________________
Date: Apr 17, 2008
No secret, I just didn't know if anyone cared to hear. But glad to share. Here goes; Go to lowes or H.D and B-line it for the plumbing department, then look for the rubber fittings to attach PVC, in line, 1 1/2". Get a coupling for 1 1/2" pipe, it will be about 4" long and have two hose clamps on each end. You will need to cut the two ends off with a band saw, or your weapon of choice. Cut just inside of the groove where the clamp sets. You will now have two couplings for each vent. Then you can use a dremal to cut the big flange off the NACA inlets, about 1/4 inch from the seam, or so you have 1 1/2" diameter left. Then with the nut ring still on the eyeball vent insert it into the rubber coupling and place the whole unit over the NACA vent, and tighten the hose clamp. Sound complicated but take around 30 minutes. Let me know if you have questions. I also have a pic of the end product, looks real clean, is easy to remove, and eliminates the ugly white flange, and requires no hardware or glue. Thane 803-396-8865 ----- Original Message ----- From: "McGANN, Ron" <ron.mcgann(at)baesystems.com> Sent: Tuesday, April 15, 2008 7:14 PM Subject: RE: RV10-List: Recommendations for front air vents > > Thane - don't be coy. I am about to instal Steins vents and was > thinking of E6000 to attach them to the NACA ducts. What was your > method? Contact me off list if this is a secret . > > Cheers, > Ron > 187, almost there. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States > Sent: Wednesday, 16 April 2008 8:21 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Recommendations for front air vents > > > Stein sells tem for just under $100. They are very nice and I found a > great way to install them with no hardware or Proseal. > Thane > ----- Original Message ----- > From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> > To: > Sent: Monday, April 14, 2008 5:06 PM > Subject: RV10-List: Recommendations for front air vents > > >> >> >> Any recommendations for the front air vents? >> Vans wants $145 for the aluminum ones >> >> Aircraft Spruce has several varieties in the $175 price range. >> Is this is the part of the building where you say to the dealer? >> >> ........ hit me . :-) >> >> >> Lew: good job on the wheel pants. Thanks for the reference, but I >> just added the pics. Our late friend, Mark Ritter showed me how to do > >> it when I looked at his plane a couple of months ago. And I will be > "displeased" >> if you get flying before I do. >> >> >> >> Fred Williams >> 40515. >> >> >> >> >> >> >> >> >> >> >> > > > "Warning: > The information contained in this email and any attached files is > confidential to BAE Systems Australia. If you are not the intended > recipient, any use, disclosure or copying of this email or any > attachments is expressly prohibited. If you have received this email > in error, please notify us immediately. VIRUS: Every care has been > taken to ensure this email and its attachments are virus free, > however, any loss or damage incurred in using this email is not the > sender's responsibility. It is your responsibility to ensure virus > checks are completed before installing any data sent in this email to > your computer." > > > ________________________________________________________________________________
Subject: Re: SkyTec Starter Wiring Warning
Date: Apr 18, 2008
No I did not know this does anyone know if Vans updated there plans as mine show to remove the jumper which will make it 24 volts!. regards Chris ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Friday, April 18, 2008 1:47 AM Subject: RV10-List: SkyTec Starter Wiring Warning > > Probably everyone knows about this but me, but since I just fried my > oil-soaked SkyTec starter on my GlaStar, I was perusing their web pages > and > found this: > > http://www.skytecair.com/Wiring_diag.htm > > Scroll down to the RV-10 wiring warning. If the shoe fits... > > John Jessen > 40328 building > GlaStar flying > > > ________________________________________________________________________________
Date: Apr 17, 2008
Subject: Re: Recommendations for front air vents
Thane States wrote: snip > Let me know if you have questions. I also have a pic of the end > product, looks real clean, is easy to remove, and eliminates the ugly > white flange, and requires no hardware or glue. So, where's the picture??? Holding out for cash offers??? :-) Linn > > Thane > 803-396-8865 ________________________________________________________________________________
Subject: Oshkosh
Date: Apr 17, 2008
Speaking of Oshkosh, I hope they allow more room for taxi this year, Last year the wingtip spacing was a bit tight. Jim C 40192 =========================================================== From: "Bob Leffler" <rv(at)thelefflers.com> Date: 2008/04/17 Thu PM 03:56:40 EDT Subject: RE: RV10-List: First flight Great news Dick!!! With all the first flights, we are going to need a couple rows at OSH for parking all the RV-10s! Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rsipp(at)earthlink.net Sent: Thursday, April 17, 2008 3:26 PM Subject: RV10-List: First flight Serial 40065 N110DV was successfully flown for the first time this afternoon. No problems were noted and the airplane flew well. Pictures and more information after the test period is complete and we've been to the paintshop. Dick Sipp RV 10 flying =========================================================== ________________________________________________________________________________
Date: Apr 17, 2008
Sorry the wife has camera. I will post some pics tomorrow. Thane ----- Original Message ----- From: "linn Walters" <pitts_pilot(at)bellsouth.net> Sent: Thursday, April 17, 2008 7:12 PM Subject: Re: RV10-List: Recommendations for front air vents > > Thane States wrote: > > > snip > >> Let me know if you have questions. I also have a pic of the end >> product, looks real clean, is easy to remove, and eliminates the ugly >> white flange, and requires no hardware or glue. > > So, where's the picture??? Holding out for cash offers??? :-) > Linn > >> >> Thane >> 803-396-8865 > > > > > > > > ________________________________________________________________________________
Subject: 430W w/ DIIVSGV
Date: Apr 17, 2008
I have asked for this in the past, and may have reported on it at some point, but wanted to share an experience with the group. Earlier today my dad and I flew from 7FL6 to X35 and did the GPS 23 approach into Dunnellon. This approach is a non-WAAS approach, but when activated on the 430W it reads "LNAV+V". When close to the final approach fix "JOLCO", we just hit "mode" to activate GPSS and then "alt" twice to activate GPSV and the TruTrak Digiflight II VSGV did the rest until the flare. Even while dropping the flaps it kept the needles almost centered and quickly got them back to the center. Other than that, it nailed the center of both needles all the way down to the VASI's, one red one white the whole way down. Most of this to encourage those of you who have the 430W or 530W to utilize this feature in your TruTrak vertical steering GPS. I know a lot of other units have been able to do this for a while, but getting it from possibly the most common GPS in GA is a great improvement. The technology advances even in the short time I have been directly involved in aviation are amazing. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Apr 17, 2008
Subject: Re: First flight
Congratulations Dick ! Keep us posted on how your Phase 1 goes and if you find / encounter any gremlins. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ ________________________________________________________________________________
Subject: FW: 12 "cigarette" receptacle
Date: Apr 18, 2008
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Check this out. I didn't really like the bulky cigarette-type power receptacles from Spruce or elsewhere (commonly with a flange on both sides for screw mounting), so I went to the aviation department at West Marine and found this one by Marinco. As you can see, it mounts with a screw-on ring in the back, so you've only got the diameter of the receptacle itself showing in front. There is an optional front flange if you want to use it. It also has a nice-sealing cap, being a marine product . . . I think it was $17.99 at my local West Marine. You landlubbers will have to go on their web site, if interested. TDT 40025 Wings going on soon! From: Dawson-Townsend [mailto:yooper(at)alum.mit.edu] Sent: Friday, April 18, 2008 1:35 AM Subject: P1000230.JPG P1000230.JPG -- ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Apr 18, 2008
Which starter is Van selling with the FWF now? If it's the LS then I believe the original diagram is correct. If it's now the NL then the new diagram is correct. As always you should review the instructions from the manufacturer in addition to Van's. You know they will always fall back on what the manufacturer says. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Thursday, April 17, 2008 5:22 PM Subject: Re: RV10-List: SkyTec Starter Wiring Warning No I did not know this does anyone know if Vans updated there plans as mine show to remove the jumper which will make it 24 volts!. regards Chris ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Friday, April 18, 2008 1:47 AM Subject: RV10-List: SkyTec Starter Wiring Warning > > Probably everyone knows about this but me, but since I just fried my > oil-soaked SkyTec starter on my GlaStar, I was perusing their web pages > and > found this: > > http://www.skytecair.com/Wiring_diag.htm > > Scroll down to the RV-10 wiring warning. If the shoe fits... > > John Jessen > 40328 building > GlaStar flying > > ________________________________________________________________________________
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
Date: Apr 18, 2008
You don't get a Starter in the Van's FWF Kit. Thank You Ray Doerr -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Friday, April 18, 2008 9:21 AM Subject: RE: RV10-List: SkyTec Starter Wiring Warning Which starter is Van selling with the FWF now? If it's the LS then I believe the original diagram is correct. If it's now the NL then the new diagram is correct. As always you should review the instructions from the manufacturer in addition to Van's. You know they will always fall back on what the manufacturer says. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Thursday, April 17, 2008 5:22 PM Subject: Re: RV10-List: SkyTec Starter Wiring Warning No I did not know this does anyone know if Vans updated there plans as mine show to remove the jumper which will make it 24 volts!. regards Chris ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Friday, April 18, 2008 1:47 AM Subject: RV10-List: SkyTec Starter Wiring Warning > > Probably everyone knows about this but me, but since I just fried my > oil-soaked SkyTec starter on my GlaStar, I was perusing their web pages > and > found this: > > http://www.skytecair.com/Wiring_diag.htm > > Scroll down to the RV-10 wiring warning. If the shoe fits... > > John Jessen > 40328 building > GlaStar flying > > ________________________________________________________________________________
Date: Apr 18, 2008
I also didn't care for any aviation 12V receptacle I could source and the best looking one I could find was on one a 2008 Honda (CRV). Most newer Honda's used the same receptacle with a rectangular spring loaded cover plate and a nice 12V embossed on the face plate. I think I paid $20.00 each delivered from an online automotive supply house. Sorry no photos as I am traveling. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Friday, April 18, 2008 6:59 AM Subject: RV10-List: FW: 12 "cigarette" receptacle Check this out. I didn't really like the bulky cigarette-type power receptacles from Spruce or elsewhere (commonly with a flange on both sides for screw mounting), so I went to the aviation department at West Marine and found this one by Marinco. As you can see, it mounts with a screw-on ring in the back, so you've only got the diameter of the receptacle itself showing in front. There is an optional front flange if you want to use it. It also has a nice-sealing cap, being a marine product . . . I think it was $17.99 at my local West Marine. You landlubbers will have to go on their web site, if interested. TDT 40025 Wings going on soon! From: Dawson-Townsend [mailto:yooper(at)alum.mit.edu] Sent: Friday, April 18, 2008 1:35 AM Subject: P1000230.JPG P1000230.JPG -- ________________________________________________________________________________
Subject: Re: Torque wing bolts
Date: Apr 18, 2008
Hi Chris,=0A=0ADid you receive a response? I need those torques, too.=0A=0ARoger=0A ----- Original Message ----- =0A Fro m: Chris and Susie McGough =0A To: rv10- list(at)matronics.com =0A Sent: Wedne sday, April 16, 2008 9:55 PM=0A Subject: RV10-List: Torque wing bo ie McGough" >=0A=0A Could someone look up the torque for me for those nas bolts that hol d the =0A wings on? Cant find my red book=0A=0A regards Ch ======================= ======================= ======================= ======================= ======================= ======================= w.matronics.com/contribution<http://www.matronics.com/contribution> ======================= =================0A=0A=0A =0A ________________________________________________________________________________
Subject: wiring question
Date: Apr 18, 2008
Now deep into the wiring and panel placement but have several questions. 1) Trim wiring. Specifically what type of wire or bundle do I run from the panel to the three trim motors. I have used Stein's "servo" wire to feed the roll and pitch servos but that seems to have too many wires and some of the wires are too big. Do I make my own bundle or is there something available specifically for this chore? 2) The radio stack cooling fan I have has three ports but I can only find two ports on the radio stack. Do I use that other port to cool the Lightspeed console? And is there a preferred position to place that fan? Thanks everyone for the continued help. Jay Rowe 40301 ________________________________________________________________________________
Date: Apr 18, 2008
Subject: Re: wiring question
Jay, Can't help you with the fans but this works well for the trim. http://www.aircraftspruce.com/catalog/elpages/wc2wire.php Rick Sked 40185 ----- Original Message ----- From: "Jay Rowe" <jfrjr(at)roadrunner.com> Sent: Friday, April 18, 2008 8:11:17 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: wiring question Now deep into the wiring and panel placement but have several questions.=C2 -1) Trim wiring. Specifically what type of wire or bundle do I run from t he panel to the three trim motors.=C2- I have used Stein's "servo" wire t o feed the roll and pitch servos but that seems to have too many wires and some of the wires are too big. Do I make my own bundle or is there somethin g available specifically for this chore?=C2-2)=C2- The radio stack cool ing fan I have has three ports but I can only find two ports on the radio s tack.=C2- Do I use that other=C2-port to=C2-cool the=C2-Lightspeed console?=C2- And is there a preferred position to place that fan?=C2- =C2-Thanks everyone for the continued help.=C2- Jay Rowe 40301 Upgrade Your Email - Click here! ________________________________________________________________________________
Subject: Re: FW: 12 "cigarette" receptacle
Date: Apr 18, 2008
Date: Apr 18, 2008
Jay, I am also running the same wiring as Rick. I also got mine from AS. It is one bundle to pull and not worry which wire is which. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177660#177660 ________________________________________________________________________________
Date: Apr 18, 2008
Ok, I've got a dog in this fight since I just ordered an IO-540 from Van's as part of their promotion. The Van's Lycoming engine comes with the LS starter on the crated engine. Since it's part of the OEM contract with Van's, it can't be changed. If you're ordering from an after market builder, you can specify the NL. I then spoke to the tech at Sky-Tech. The LS has a higher current draw than the NL and may not turn over the engine IF you've done a shoddy wiring job. The NL is recommended for that reason. As to kickback, that can happen depending on settings of a magneto. In my case, I plan to go with PMags for both. Skytech advised that they worked specifically with the PMag system guys to ensure that a kickback won't happen. Bottom line-Skytech changed the recommendation from LS to NL based on several engines having slow turnover due to restrictive wiring or low battery power. So I'll stay with the LS unless I do have a problem. If I was starting from scratch on the engine, I'd get the NL. Tom H. Boynton Beach, FL[color=black][/color] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177671#177671 ________________________________________________________________________________
Date: Apr 18, 2008
Jay, Ray Allen sells wire that's perfect for their trim motors. It's very small diameter and the colors match the servos so you don't have to convert anything. If I had an extra cooling port I would consider blowing cool air up into the top of the panel area. It gets pretty hot up there. Also, put a few vent holes in the top of the glare sheild to let the heat out. My Dynon overtemped on a warm day last fall before I installed the cooling fan and vent holes. We put the fan laying flat so it pulls (cooler) air from the cockpit at about the level of the bottom of the panel. I also ran a couple cold air tubes from the fresh air NACA ducts to displace some warm air. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jay Rowe Sent: Friday, April 18, 2008 8:11 AM Subject: RV10-List: wiring question Now deep into the wiring and panel placement but have several questions. 1) Trim wiring. Specifically what type of wire or bundle do I run from the panel to the three trim motors. I have used Stein's "servo" wire to feed the roll and pitch servos but that seems to have too many wires and some of the wires are too big. Do I make my own bundle or is there something available specifically for this chore? 2) The radio stack cooling fan I have has three ports but I can only find two ports on the radio stack. Do I use that other port to cool the Lightspeed console? And is there a preferred position to place that fan? Thanks everyone for the continued help. Jay Rowe 40301 <http://promos.hotbar.com/promos/promodll.dll?RunPromo&El=&SG=&RAND=47419&pa rtner=seekmo> Upgrade Your Email - Click here! ________________________________________________________________________________
Subject: oil cooler
Date: Apr 18, 2008
I'm looking at putting in a Stewart Warner dual flow oil cooler--told model is 8432R. Using Mattituck 10-540. Anyone use it--any problems or problems fitting it?? thanks larry b -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177676#177676 ________________________________________________________________________________
Date: Apr 18, 2008
Subject: Re: oil cooler
I have Van's stock FWF cooler....I know I'm going to be changing it out...I just know it but I'm gonna try it first. This is my choice for replacment and it may another manuf. that Alex is selling but it is a much better oil cooler in many ways. Heres the link: http://www.aviationtechproducts.com/html/engine__parts.html Rick Sked 40185 ----- Original Message ----- From: "lbgjb10" <lbgjb(at)gnt.net> Sent: Friday, April 18, 2008 10:11:47 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: oil cooler I'm looking at putting in a Stewart Warner dual flow oil cooler--told model is 8432R. Using Mattituck 10-540. Anyone use it--any problems or problems fitting it?? thanks larry b -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177676#177676 ________________________________________________________________________________
Date: Apr 18, 2008
P1000230.JPGThey have a nice one at Aerocraft Parts: http://www.aerocraftparts.com/ItemForm.aspx?item=901-0031&Category=51 ea08db-b876-4fd0-8c8b-dc2ba184c151 Paul Grimstad RV10 40450 Portland, Or. ----- Original Message ----- From: Dawson-Townsend,Timothy To: rv10-list(at)matronics.com Sent: Friday, April 18, 2008 6:58 AM Subject: RV10-List: FW: 12 "cigarette" receptacle Check this out. I didn't really like the bulky cigarette-type power receptacles from Spruce or elsewhere (commonly with a flange on both sides for screw mounting), so I went to the aviation department at West Marine and found this one by Marinco. As you can see, it mounts with a screw-on ring in the back, so you've only got the diameter of the receptacle itself showing in front. There is an optional front flange if you want to use it. It also has a nice-sealing cap, being a marine product . . . I think it was $17.99 at my local West Marine. You landlubbers will have to go on their web site, if interested. TDT 40025 Wings going on soon! From: Dawson-Townsend [mailto:yooper(at)alum.mit.edu] Sent: Friday, April 18, 2008 1:35 AM To: Dawson-Townsend,Timothy Subject: P1000230.JPG P1000230.JPG -- ________________________________________________________________________________
Subject: Wiring NL starter help
Date: Apr 19, 2008
Guys I am now stuck. I have the NL starter and also wired the plane as per Vans wiring kit which I now know is wrong for this starter. I contacted Vans and they are not interested in helping as not the starter they supply. Can somone have a look at the skytec diagram and give me an idea what wires to change. Ofcourse if you have not used Vans diagram you will not know the difference. Vans starter relay has 4 terminals and Skytec diagram has 3. Also Skytec has 1 wire going to the starter not 2. http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg Luckily John Jessen pointed this out regards Chris ________________________________________________________________________________
Date: Apr 19, 2008
Thanks Vern You should have got he email to Roger regards Chris ----- Original Message ----- From: Roger Standley To: rv10-list(at)matronics.com Sent: Saturday, April 19, 2008 12:52 AM Subject: Re: RV10-List: Torque wing bolts Hi Chris, Did you receive a response? I need those torques, too. Roger ----- Original Message ----- From: Chris and Susie McGough To: rv10-list(at)matronics.com Sent: Wednesday, April 16, 2008 9:55 PM Subject: RV10-List: Torque wing bolts Could someone look up the torque for me for those nas bolts that hold the wings on? C======================== ======================nbsp; - The RV10-List Email Forum -http://www.===================== p; - MATRONICS WEB FORUMS href="http://forums.matronics.com">http://forums.matronics.==== ===================nbsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribut====================== ================== ________________________________________________________________________________
Subject: SkyTec Starter Wiring Warning diagrams
Date: Apr 19, 2008
Here is the diagrams. The first is Vans which is how I have wired which is incorrect for the NL starter http://www.skytecair.com/images/Van's%20Starter%20Wiring%20RV10%20Lg.jpg This is the corect wiring. http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg Chris ________________________________________________________________________________
Subject: Wiring NL starter problem solved
Date: Apr 19, 2008
Hi Chris You can use the 4 terminal solenoid - just use the 'S' terminal to your switch, leave the 'I' unconnected assuming you have the standard black starter solenoid. If you are still not sure then give me a call on 0412 624 723 and I'll walk you through it. I'm off test flying an Fadec equipped R7A (the old ICY ;-) but will be available during the day. Regards, Jake ----- Original Message ----- From: "Chris and Susie McGough" <VHMUM(at)bigpond.com> Sent: Saturday, April 19, 2008 6:54 AM Subject: RV10-List: Wiring NL starter help > > > Guys I am now stuck. I have the NL starter and also wired the plane as per > Vans wiring kit which I now know is wrong for this starter. I contacted > Vans and they are not interested in helping as not the starter they > supply. > > Can somone have a look at the skytec diagram and give me an idea what > wires to change. Ofcourse if you have not used Vans diagram you will not > know the difference. > > Vans starter relay has 4 terminals and Skytec diagram has 3. Also Skytec > has 1 wire going to the starter not 2. > http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg > > Luckily John Jessen pointed this out > > regards Chris > > > ________________________________________________________________________________
Date: Apr 18, 2008
Subject: Re: Insurance was AFS Systems .... (G900X panel cost / Stick
Clearance) Here is the post John was referencing. It is slightly different than the information we got earlier where IFR GPS, and moving map and autopilot are required for the 10% discount from AIG. Just got my insurance bill for the renewal and SkySmith included the AIG "Technology Advanced Aircraft" discount requirements. The aircraft must have: 1.) IFR certified GPS, 2.) Moving map, 3.) two axis autopilot, plus any two from column B, including: TAWS, TCAS, Weather monitor (Stormscope, datalink, or radar), a fuel totalizer, and RNP capability. The pilot must have: 1.) Minimum Private/Instrument 2.) Current Instrument Proficiency Check, maintained annually 3.) Air Safety Foundation course completed, selected from 1.) single pilot IFR, 2.) Datalink, 3.) Thunderstorms, 4.) IFR GPS, and 5.) Runway Safety. These are available free and on-line and take about 30-40 minutes to complete. Meet these requirements and get a 10% discount from AIG!! John Cox wrote: > ... > On the Lancair site today there was a posting of new equipment > requirements and pilot requirements that trigger a 10% savings for > true Technically Advanced IFR Experimental equipped aircraft. Knowing > those components, choosing wisely, building safely and maintaining > currency of flight is going to have a positive impact and those are > good things. > > John C > > * > * ________________________________________________________________________________
Date: Apr 18, 2008
Here are a few pics of my eyeball vent install as promised. Hope these are OK. Thane ----- Original Message ----- From: "Thane States" <thane2(at)comporium.net> Sent: Thursday, April 17, 2008 9:18 PM Subject: Re: RV10-List: Recommendations for front air vents > > Sorry the wife has camera. I will post some pics tomorrow. > Thane > > > ----- Original Message ----- > From: "linn Walters" <pitts_pilot(at)bellsouth.net> > To: > Sent: Thursday, April 17, 2008 7:12 PM > Subject: Re: RV10-List: Recommendations for front air vents > > >> >> Thane States wrote: >> >> >> snip >> >>> Let me know if you have questions. I also have a pic of the end >>> product, looks real clean, is easy to remove, and eliminates the ugly >>> white flange, and requires no hardware or glue. >> >> So, where's the picture??? Holding out for cash offers??? :-) >> Linn >> >>> >>> Thane >>> 803-396-8865 >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: 12 "cigarette" receptacle
Date: Apr 18, 2008
Funny that a cigarette lighter defines a standard. Sort of like the 4 feet 8.5 inches of a railroad track.... -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177788#177788 ________________________________________________________________________________
Date: Apr 18, 2008
Subject: PIREP: Electric Rudder Trim - Do I really need it?
Over the past month I have been heavily debating whether I should add electric rudder trim or not. Everyone who has it absolutely loves it and I know it would be great but I wanted to see if I could get away with just rudder trim tabs. I like to add stuff like electric trim but wanted to try the KISS principle first. For the first year I had one of the tabs from Avery on and it always needed a little more right rudder. Last year at Oshkosh I saw one RV-10 with two tabs (can't remember who) so I tried it out. I purchased another tab and temporarily mounted it so I now have two full tabs on the lower portion of my rudder. I have flown for 10 hours now with the two tabs and it seems to be working perfect. At 165 knots true the ball is perfectly centered. At 160 it is barely right and at 170 it is barely left. I am so pleased with the results that I am not going to add the electric trim for now. I believe the electric trim is the luxury way to go but I can now fly with both feet flat on the floor. Just thought I'd share my findings with you. Happy Flying! Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Date: Apr 18, 2008
Subject: Re: Wiring NL starter help
I tend to think you have the wrong relay. The starter relay is normally an intermittentduty model, with 3 terminals as shown in the Skytec diagram. Master relays normally have 4 terminals. I note that the pictures in the Spruce catalog are also reversed. :-( Chris and Susie McGough wrote: > > > Guys I am now stuck. I have the NL starter and also wired the plane as > per Vans wiring kit which I now know is wrong for this starter. I > contacted Vans and they are not interested in helping as not the > starter they supply. > > Can somone have a look at the skytec diagram and give me an idea what > wires to change. Ofcourse if you have not used Vans diagram you will > not know the difference. > > Vans starter relay has 4 terminals and Skytec diagram has 3. Also > Skytec has 1 wire going to the starter not 2. > http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg > > Luckily John Jessen pointed this out > > regards Chris > > ________________________________________________________________________________
Clearance)
Date: Apr 19, 2008
I qualified for the TAA requirements with AIG and still found that Global was a little bit cheaper than AIG even with AIG giving me the 10% discount. Wayne Edgerton N602WT From: Larry Rosen <LarryRosen(at)comcast.net> Subject: Re: Insurance was AFS Systems .... (G900X panel cost / Stick Clearance) Here is the post John was referencing. It is slightly different than the information we got earlier where IFR GPS, and moving map and autopilot are required for the 10% discount from AIG. Just got my insurance bill for the renewal and SkySmith included the AIG "Technology Advanced Aircraft" discount requirements. The aircraft must have: 1.) IFR certified GPS, 2.) Moving map, 3.) two axis autopilot, plus any two from column B, including: TAWS, TCAS, Weather monitor (Stormscope, datalink, or radar), a fuel totalizer, and RNP capability. The pilot must have: 1.) Minimum Private/Instrument 2.) Current Instrument Proficiency Check, maintained annually 3.) Air Safety Foundation course completed, selected from 1.) single pilot IFR, 2.) Datalink, 3.) Thunderstorms, 4.) IFR GPS, and 5.) Runway Safety. These are available free and on-line and take about 30-40 minutes to complete. Meet these requirements and get a 10% discount from AIG!! John Cox wrote: ________________________________________________________________________________
Date: Apr 19, 2008
In my experience the master has 3 contacts and the starter has 4. Ground closes the master and power closes the starter. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com www.saintaviation.com 352-427-0285 Kelly McMullen wrote: > > I tend to think you have the wrong relay. The starter relay is normally > an intermittentduty model, with 3 terminals as shown in the Skytec > diagram. Master relays normally have 4 terminals. I note that the > pictures in the Spruce catalog are also reversed. :-( > > Chris and Susie McGough wrote: >> >> >> Guys I am now stuck. I have the NL starter and also wired the plane as >> per Vans wiring kit which I now know is wrong for this starter. I >> contacted Vans and they are not interested in helping as not the >> starter they supply. >> >> Can somone have a look at the skytec diagram and give me an idea what >> wires to change. Ofcourse if you have not used Vans diagram you will >> not know the difference. >> >> Vans starter relay has 4 terminals and Skytec diagram has 3. Also >> Skytec has 1 wire going to the starter not 2. >> http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg >> >> Luckily John Jessen pointed this out >> >> regards Chris >> >> >> >> > > ________________________________________________________________________________
Date: Apr 19, 2008
Got it! Thanks, Guys! Roger=0A ----- Original Message ----- =0A From: Chris and Susie McGough<mailto:VHMUM(at)bigpond.com> =0A To: rv10-list(at)matronics.com =0A Sent: Friday, April 18, 2008 1:56 PM=0A Subject: Re: RV10-List: Torque w ing bolts=0A=0A=0A Thanks Vern You should have got he email to Roger regards Chris=0A ----- Original Message ----- =0A From: Roger Standley<mailto:taildragon(at)msn.com> =0A To: rv10-li st(at)matronics.com =0A Sent: Satur day, April 19, 2008 12:52 AM=0A Subject: Re: RV10-List: Torque w ing bolts=0A=0A=0A Hi Chris,=0A=0A Did you receiv e a response? I need those torques, too.=0A=0A Roger=0A ----- Original Message ----- =0A From: Chris and Susie McGo ugh =0A To: rv10-list(at)matronics.com< mailto:rv10-list(at)matronics.com> =0A Sent: Wednesday, April 16, 2008 9:55 PM=0A Subject: RV10-List: Torque wing bolts=0A Gough" >=0A=0A Could someone look up the torque for me for those nas bolts that hold the =0A wings on? C============= ======================= ==========nbsp; - The RV10-List Email Forum -h ttp://www.==================== =p; - MATRONICS WEB FORUMS href="http://forums.matronics.com ">http://forums.matronics.============== =========nbsp; tit le=http://www.matronics.com/contribution href="http://www.matronic s.com/contribution">http://www.matronics.com/contribut===== ======================= ==============0A=0A=0A=0A=0A =0A=0Ahref="http://www.matronics.com/Navigator?RV10-List">http ://www.matronics.com/Navigator?RV10-List=0Ahref="http://forums.ma tronics.com">http://forums.matronics.com=0Ahref="http://www.matro ======================= ======================= /www.matronics.com/Navigator?RV10-List<http://www.matronics.com/Naviga ======================= ======================0A_ ======================= ======================= http://www.matronics.com/contribution ======================= ====================0A=0A ________________________________________________________________________________
Date: Apr 19, 2008
I too have the 149-NL starter (that came with my TMX-540) and it is wired per Van's Lightweight Starter Circuit with the "I" terminal connected to the smaller stud (jumper removed). It's working just fine... Brian Sutherland Nashville, TN N104BS 13.5 hours in Phase 1 Chris and Susie McGough wrote: > > > Guys I am now stuck. I have the NL starter and also wired the plane as > per Vans wiring kit which I now know is wrong for this starter. I > contacted Vans and they are not interested in helping as not the > starter they supply. > > Can somone have a look at the skytec diagram and give me an idea what > wires to change. Ofcourse if you have not used Vans diagram you will > not know the difference. > > Vans starter relay has 4 terminals and Skytec diagram has 3. Also > Skytec has 1 wire going to the starter not 2. >
http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg > > Luckily John Jessen pointed this out > > regards Chris > > > . > ________________________________________________________________________________
Subject: Matco 511.25 nose wheel ?
Date: Apr 19, 2008
For those that switched to the 511.25 nosewheel did you change to a different tube than what was in the finish kit? Thanks Chris Lucas #40072 ________________________________________________________________________________
Date: Apr 20, 2008
Thanks Brian if it was not for this list I would had a stuffed starter. Enjoy your flying. regards Chris ----- Original Message ----- From: "rv10builder" <rv10builder(at)bellsouth.net> Sent: Sunday, April 20, 2008 5:13 AM Subject: Re: RV10-List: Wiring NL starter help > > I too have the 149-NL starter (that came with my TMX-540) and it is wired > per Van's Lightweight Starter Circuit with the "I" terminal connected to > the smaller stud (jumper removed). It's working just fine... > > Brian Sutherland > Nashville, TN > N104BS > 13.5 hours in Phase 1 > > Chris and Susie McGough wrote: >> >> >> Guys I am now stuck. I have the NL starter and also wired the plane as >> per Vans wiring kit which I now know is wrong for this starter. I >> contacted Vans and they are not interested in helping as not the starter >> they supply. >> >> Can somone have a look at the skytec diagram and give me an idea what >> wires to change. Ofcourse if you have not used Vans diagram you will not >> know the difference. >> >> Vans starter relay has 4 terminals and Skytec diagram has 3. Also Skytec >> has 1 wire going to the starter not 2. >> http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg >> >> Luckily John Jessen pointed this out >> >> regards Chris >> >> >> >> >> >> . >> > > > ________________________________________________________________________________
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Apr 19, 2008
I am not sure if I can add help or more confusion here. But I wrote this question to SkyTec since I wanted to know what to do with my 149 NL Starter which came with my the TMX IO-540. Quote: Michael, Per that page, "All Sky-Tec NL starters must be wired per diagram "B" below as there is no active "S" terminal. The small, "S" terminal on the NL model starter is used to switch the starter from 24V (jumper wire removed) to 12V (jumper wire installed) operation and cannot be used to activate the starter." So yes, assuming you are running this thing on 12V, you will need to install the jumper. It is confusing. - Rich Rich Chiappe Sky-Tec 800-476-7896 richc(at)skytecair.com www.skytecair.com Quoutattion end: I read here to keep the jumper on! Do I miss something? Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177873#177873 ________________________________________________________________________________
Date: Apr 19, 2008
The diagram he is referring to is here: http://www.skytecair.com/images/NL% 2012V%20Installation%20Wiring_1100.jpg=0A=0AAlso attached. My TMX-IO 540 also came with the NL starter and I wired it per this diagram.=0A =0AWilliam=0Ahttp://nerv10.com/wcurtis/ =0A=0A-------- Original Me =0A> =0A> I am not sure if I can add help or m ore confusion here. But I wrote this question to SkyTec since I wanted to k now what to do with my 149 NL Starter which came with my the TMX IO-540. =0A> =0A> Quote:=0A> =0A> =0A> Michael,=0A> =0A> Per that page, "All Sky-Tec NL starters must be wired per diagram "B" below as ther e is no active "S" terminal. The small, "S" terminal on the NL model start er is used to switch the starter from 24V (jumper wire removed) to 12V (jum per wire installed) operation and cannot be used to activate the starter." =0A> =0A> So yes, assuming you are running this thing on 12V, you wil l need to install the jumper.=0A> =0A> It is confusing.=0A> =0A > - Rich=0A> =0A> Rich Chiappe=0A> Sky-Tec=0A> 800-476-7896 =0A> richc(at)skytecair.com=0A> www.skytecair.com=0A> =0A> =0A> Qu outattion end:=0A> =0A> =0A> I read here to keep the jumper on! =0A> =0A> Do I miss=0A> something?=0A> =0A> Michael=0A> =0A> --------=0A> RV-10 builder (engine, prop, finishing)=0A> #511 =0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forums.matronics.com/viewtopic.php?p=177873#177873=0A> ======================== =0A ________________________________________________________________________________
Date: Apr 20, 2008
>From Skytec Sky-Tec repurposed the S-Terminal functionality on NL model starters to serve as a means of switching the starter between 12V and 24V operation. Because of this, ALL NL STARTER INSTALLATIONS MUST BE WIRED ACCORDING TO THE CERTIFIED AIRCRAFT WIRING DIAGRAM BELOW - NO EXCEPTIONS! http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg I noticed on the starter when I put the jumper back it says someting like jumper for 12 volt operation. So if that jumper is used it becomes a 24 volt starter. I must have had a coeliac moment when I first removed it. regards Chris ________________________________________________________________________________
Date: Apr 20, 2008
Woops missed a critical word ..... From Skytec Sky-Tec repurposed the S-Terminal functionality on NL model starters to serve as a means of switching the starter between 12V and 24V operation. Because of this, ALL NL STARTER INSTALLATIONS MUST BE WIRED ACCORDING TO THE CERTIFIED AIRCRAFT WIRING DIAGRAM BELOW - NO EXCEPTIONS! http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg I noticed on the starter when I put the jumper back it says someting like jumper for 12 volt operation. So if that jumper is not used it becomes a 24 volt starter. I must have had a coeliac moment when I first removed it. regards Chris ________________________________________________________________________________
Date: Apr 19, 2008
> I noticed on the starter when I put the jumper back it says someting like > jumper for 12 volt operation. So if that jumper is used it becomes a 24 volt > starter. I must have had a coeliac moment when I first removed it. I think you have it backwards. When the junper is ON, it's a 12 volt starter; when the jumper is OFF it is a 24 volt starter. William http://nerv10.com/wcurtis/ ________________________________________________________________________________
Date: Apr 19, 2008
>I tend to think you have the wrong relay. The starter relay is normally >an intermittentduty model, with 3 terminals as shown in the Skytec >diagram. Master relays normally have 4 terminals. I note that the >pictures in the Spruce catalog are also reversed >I too have the 149-NL starter (that came with my TMX-540) and it is >wired per Van's Lightweight Starter Circuit with the "I" terminal >connected to the smaller stud (jumper removed). It's working just fine This is interesting. My starter relay has FOUR terminals and came with a tag that said "If original has 3 terminals DO NOT use this "I" terminal." William http://nerv10.com/wcurtis/ ________________________________________________________________________________
Date: Apr 20, 2008
Yep I sent another email thanks Chris ----- Original Message ----- From: "William Curtis" <wcurtis(at)nerv10.com> Sent: Sunday, April 20, 2008 7:54 AM Subject: Re: RV10-List: Re: Wiring NL starter help > >> I noticed on the starter when I put the jumper back it says someting like >> jumper for 12 volt operation. So if that jumper is used it becomes a 24 >> volt >> starter. I must have had a coeliac moment when I first removed it. > > I think you have it backwards. When the junper is ON, it's a 12 volt > starter; when the jumper is OFF it is a 24 volt starter. > > William > http://nerv10.com/wcurtis/ > > > ________________________________________________________________________________
Date: Apr 19, 2008
Think you got the wrong guy attached to the quote below William. That was Brian Sutherland that said that, not me. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Saturday, April 19, 2008 5:04 PM Subject: Re: RV10-List: Re: Wiring NL starter help >I tend to think you have the wrong relay. The starter relay is normally >an intermittentduty model, with 3 terminals as shown in the Skytec >diagram. Master relays normally have 4 terminals. I note that the >pictures in the Spruce catalog are also reversed >I too have the 149-NL starter (that came with my TMX-540) and it is >wired per Van's Lightweight Starter Circuit with the "I" terminal >connected to the smaller stud (jumper removed). It's working just fine This is interesting. My starter relay has FOUR terminals and came with a tag that said "If original has 3 terminals DO NOT use this "I" terminal." William http://nerv10.com/wcurtis/ ________________________________________________________________________________
Date: Apr 19, 2008
For now. :) Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10builder Sent: Saturday, April 19, 2008 2:14 PM Subject: Re: RV10-List: Wiring NL starter help I too have the 149-NL starter (that came with my TMX-540) and it is wired per Van's Lightweight Starter Circuit with the "I" terminal connected to the smaller stud (jumper removed). It's working just fine... Brian Sutherland Nashville, TN N104BS 13.5 hours in Phase 1 Chris and Susie McGough wrote: > > > Guys I am now stuck. I have the NL starter and also wired the plane as > per Vans wiring kit which I now know is wrong for this starter. I > contacted Vans and they are not interested in helping as not the > starter they supply. > > Can somone have a look at the skytec diagram and give me an idea what > wires to change. Ofcourse if you have not used Vans diagram you will > not know the difference. > > Vans starter relay has 4 terminals and Skytec diagram has 3. Also > Skytec has 1 wire going to the starter not 2. > http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg > > Luckily John Jessen pointed this out > > regards Chris > > > . > ________________________________________________________________________________
Date: Apr 19, 2008
Alex sells a cooler that he claims has 20% more capacity. I bought it. I live in NV and it is pretty hot in the summer -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177907#177907 ________________________________________________________________________________
From: "Bruce Snyder" <snyderbd888(at)sbcglobal.net>
Date: Apr 19, 2008
Are most of the parts plastic on that power receptacle? Thanks. Bruce 40353 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Friday, April 18, 2008 9:59 AM Subject: RV10-List: FW: 12 "cigarette" receptacle Check this out. I didn't really like the bulky cigarette-type power receptacles from Spruce or elsewhere (commonly with a flange on both sides for screw mounting), so I went to the aviation department at West Marine and found this one by Marinco. As you can see, it mounts with a screw-on ring in the back, so you've only got the diameter of the receptacle itself showing in front. There is an optional front flange if you want to use it. It also has a nice-sealing cap, being a marine product . . . I think it was $17.99 at my local West Marine. You landlubbers will have to go on their web site, if interested. TDT 40025 Wings going on soon! From: Dawson-Townsend [mailto:yooper(at)alum.mit.edu] Sent: Friday, April 18, 2008 1:35 AM Subject: P1000230.JPG P1000230.JPG -- ________________________________________________________________________________
Subject: RV-10 for sale! My loss your gain!
Date: Apr 19, 2008
RV10 kit # 40017 is for sale because of circumstances beyond my control. Th is aircraft is on gear and is in the finishing stage. Engine and prop are i nstalled, canopy, cowl, doors & window fit is beautiful. The engine is a 12 00 hour total time IO 540 engine with a fresh overall. Prop is a new Hartze ll blended airfoil. Purchase for the price of the kits, engine, prop and bu ilding materials. Please contact me off line at crawfordh22(at)hotmail.com Tha nks! Would consider the right RV trade! _________________________________________________________________ Pack up or back up'use SkyDrive to transfer files or keep extra copies. L earn how. http://www.windowslive.com/skydrive/overview.html?ocid=TXT_TAGLM_WL_Refre sh_skydrive_packup_042008 ________________________________________________________________________________
Date: Apr 19, 2008
Subject: Fuel Line Quick Disconnects
Hi As I look at the tunnel in my -10, I am contemplating how I will be able to *easily* access the fuel pumps / filters that after the panel is installed. Keeping in mind John Cox's admonition to think about maintenance access when building, I have wondered about the use of quick disconnects on the fuel lines so the fuel pumps / filters can be easily removed / installed. I can't image how I would be able to connect these things in the future. I see that A/C Spruce sells experimental quick disconnects and that there are several racing sites that have what appear to be even higher quality units. Has anyone used these in their a/c? Are there any reasons why they should not be used? Inquiring minds need to know Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Subject: Temporary door seal install
Date: Apr 19, 2008
Does anyone know a method of temporarily installing the door seal? I've tried carpet tape and it won't stick to the seal material. I wanted to final fit the doors with the seal in place so there wouldn't be any surprises after painting. Sheldon Olesen 40080 ________________________________________________________________________________
Date: Apr 19, 2008
Sorry about that. Getting confused as to who is saying what. William http://nerv10.com/wcurtis/ -------- Original Message -------- > X-Rcpt-To: > > > Think you got the wrong guy attached to the quote below William. That was Brian Sutherland that said that, not me. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis > Sent: Saturday, April 19, 2008 5:04 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Wiring NL starter help > > > >I tend to think you have the wrong relay. The starter relay is normally > >an intermittentduty model, with 3 terminals as shown in the Skytec > >diagram. Master relays normally have 4 terminals. I note that the > >pictures in the Spruce catalog are also reversed > > >I too have the 149-NL starter (that came with my TMX-540) and it is > >wired per Van's Lightweight Starter Circuit with the "I" terminal > >connected to the smaller stud (jumper removed). It's working just fine > > This is interesting. My starter relay has FOUR terminals and came with a tag that said "If original has 3 terminals DO NOT use this "I" terminal." > > William > http://nerv10.com/wcurtis/ ________________________________________________________________________________
Date: Apr 19, 2008
Les, It's really not that bad a job. The hardest part is getting the tunnel cover off. You might consider leaving a few of the screws out towards the front. That and an electric screwdriver will have the filter serviced in a few minutes. The stock design is simple and light. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, April 19, 2008 7:20 PM Subject: RV10-List: Fuel Line Quick Disconnects Hi As I look at the tunnel in my -10, I am contemplating how I will be able to *easily* access the fuel pumps / filters that after the panel is installed. Keeping in mind John Cox's admonition to think about maintenance access when building, I have wondered about the use of quick disconnects on the fuel lines so the fuel pumps / filters can be easily removed / installed. I can't image how I would be able to connect these things in the future. I see that A/C Spruce sells experimental quick disconnects and that there are several racing sites that have what appear to be even higher quality units. Has anyone used these in their a/c? Are there any reasons why they should not be used? Inquiring minds need to know Les Kearney #40643 C-GCWZ (reserved) ________________________________________________________________________________
Subject: Re: RV-10 for sale! My loss your gain!
Date: Apr 19, 2008
Bad email! [Exclamation] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177933#177933 ________________________________________________________________________________
Date: Apr 19, 2008
Subject: Re: Fuel Line Quick Disconnects
Hi Dave My setup is a bit different. I am installing an Eggenfellner E6Ti (3.6l) engine. My fuel pumps and filters are a different from the stock vans equipment. Looking at the tunnel, they will be a pain to service. I am not as flexible as I once was.... Cheers Les ----- Original Message ----- From: Dave Saylor <Dave(at)aircraftersllc.com> Date: Saturday, April 19, 2008 9:25 pm Subject: RE: RV10-List: Fuel Line Quick Disconnects > Les, > > It's really not that bad a job. The hardest part is > getting the tunnel > cover off. You might consider leaving a few of the screws > out towards the > front. That and an electric screwdriver will have the > filter serviced in a > few minutes. The stock design is simple and light. > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA > 831-722-9141 > 831-750-0284 CL > www.AirCraftersLLC.com > > _____ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney > Sent: Saturday, April 19, 2008 7:20 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fuel Line Quick Disconnects > > > > Hi > > > > As I look at the tunnel in my -10, I am contemplating how I will > be able to > *easily* access the fuel pumps / filters that after the panel is > installed.Keeping in mind John Cox's admonition to think about > maintenance access when > building, I have wondered about the use of quick disconnects on > the fuel > lines so the fuel pumps / filters can be easily removed / > installed. I can't > image how I would be able to connect these things in the future. > > > > I see that A/C Spruce sells experimental quick disconnects and > that there > are several racing sites that have what appear to be even higher > qualityunits. > > > > Has anyone used these in their a/c? Are there any reasons why > they should > not be used? > > > > Inquiring minds need to know > > > > Les Kearney > > #40643 > > C-GCWZ (reserved) > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Matco 511.25 nose wheel ?
Date: Apr 19, 2008
Original tube works fine. Bob #40105 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177934#177934 ________________________________________________________________________________
Subject: Doors and the C-1010 Cabin Pin Blocks.
Date: Apr 19, 2008
Wow, atleast 9 hours today again mounting doors, drilling out the cabin fra me openings and the cabin pin blocks and fabricating the pins from the 5/16 -24 bolts. I noticed that my C-1010 cabin pin blocks were slightly wider o ut of the box than they should have been by about 1/16 of an inch. Regardle ss of the fact that I did not trim them down to the correct width, I do not believe that the door edge bevel would fit over the block without reshapin g the door drastically...the block is quite thick, wide and the door flange s are thick, inner and outer door shells. The blocks just happen to be flus h with the outside edge of the fuse, which made me realize that with the bl ocks in this configuration, the pins cannot come in contact with the painte d sides of the fuse. I remember that a lot of folks are complaining of chip ping of the paint in this area. Of course if I opt to not trim the block's width, then I need to pocket out the edge of the door to allow the pin bloc k to fit into the door edge. If I opt to trim the width of the cabin pin block then there will be less t hickness between the pin hole and the out side of the block. My pin absolut ely go thru the entire block, the fiberglass cabin top and into the aluminu m fuselage members, fore and aft. It seems that the pin block are only supp osed to serve as a guide and a method of pulling the door in with the pin h ole having that 3.4 degree angle in it. Of course if the pin block is reduc ed in it's width, the door pin will hit the fuselage paint, provided the do or handles are not in the 135 degree maximum open position. What have people been doing with this? This sections direction are pretty v ague considering this is such a critical area...misshaps and all. John G. ________________________________________________________________________________
Date: Apr 19, 2008
Besides the quality build and great archival photos, Scott Schmidt was one of the first to consider removal for serving of fuel parts - using a side access panel. His solution was simple and a quick look at Deems site shows a similar build which values servicing ease considerations. The eyes of a manufacturer are often from a different perspective than the maintenance technician who follows into perpetuity after the DAR signoff. The later often using the name of the first (frequently and with color)for failing to take into consideration maintenance access during the build. When it is yourself, it often follows with a whap to the forehead and something that sounds like "I could have had a V-8". (vegetable juice that is) The easiest and most glaring item seen in tech inspections is the large number of builders who do not double back safety wire and learn the consequence on penetration of their fingers or arms to service something - down the road. Boeing has been an example of design which values service in the field. John C ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of LES KEARNEY Sent: Sat 4/19/2008 9:17 PM Subject: Re: RE: RV10-List: Fuel Line Quick Disconnects Hi Dave My setup is a bit different. I am installing an Eggenfellner E6Ti (3.6l) engine. My fuel pumps and filters are a different from the stock vans equipment. Looking at the tunnel, they will be a pain to service. I am not as flexible as I once was.... Cheers Les ----- Original Message ----- From: Dave Saylor <Dave(at)aircraftersllc.com> Date: Saturday, April 19, 2008 9:25 pm Subject: RE: RV10-List: Fuel Line Quick Disconnects > Les, > > It's really not that bad a job. The hardest part is > getting the tunnel > cover off. You might consider leaving a few of the screws > out towards the > front. That and an electric screwdriver will have the > filter serviced in a > few minutes. The stock design is simple and light. > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA > 831-722-9141 > 831-750-0284 CL > www.AirCraftersLLC.com > > _____ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney > Sent: Saturday, April 19, 2008 7:20 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fuel Line Quick Disconnects > > > > Hi > > > > As I look at the tunnel in my -10, I am contemplating how I will > be able to > *easily* access the fuel pumps / filters that after the panel is > installed.Keeping in mind John Cox's admonition to think about > maintenance access when > building, I have wondered about the use of quick disconnects on > the fuel > lines so the fuel pumps / filters can be easily removed / > installed. I can't > image how I would be able to connect these things in the future. > > > > I see that A/C Spruce sells experimental quick disconnects and > that there > are several racing sites that have what appear to be even higher > qualityunits. > > > > Has anyone used these in their a/c? Are there any reasons why > they should > not be used? > > > > Inquiring minds need to know > > > > Les Kearney > > #40643 > > C-GCWZ (reserved) > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: PIREP: Electric Rudder Trim - Do I really need it?
Date: Apr 19, 2008
Scott - very nice - I like your KISS approach. Is there any way you could post a picture of placement. Also where did you get the tabs or how did you fabricate and locate them? -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177943#177943 ________________________________________________________________________________
Date: Apr 20, 2008
And I should have probably added the statement: Prior to flying Sunday I'll be pulling the cowl and disconnecting the "I" lead and re-installing the jumper. The reason I haven't had a problem is that 12V is still being supplied to the 12/24V stud via the "I" lead rather than the jumper. I may be wrong but my guess is that Van's diagram for the LS provided a safeguard against a stuck starter relay in that the starter also must see 12V via the S/I leads coming from the starter switch. Obviously this is problem for the NL as a stuck relay would put the starter in 24V mode and likely result in damage. Brian Sutherland Nashville, TN N104BS 13.5 hours in Phase 1 rv10builder wrote: > > I too have the 149-NL starter (that came with my TMX-540) and it is > wired per Van's Lightweight Starter Circuit with the "I" terminal > connected to the smaller stud (jumper removed). It's working just > fine... > > Brian Sutherland > Nashville, TN > N104BS > 13.5 hours in Phase 1 > > Chris and Susie McGough wrote: >> >> >> Guys I am now stuck. I have the NL starter and also wired the plane >> as per Vans wiring kit which I now know is wrong for this starter. I >> contacted Vans and they are not interested in helping as not the >> starter they supply. >> >> Can somone have a look at the skytec diagram and give me an idea what >> wires to change. Ofcourse if you have not used Vans diagram you will >> not know the difference. >> >> Vans starter relay has 4 terminals and Skytec diagram has 3. Also >> Skytec has 1 wire going to the starter not 2. >> http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg >> >> >> Luckily John Jessen pointed this out >> >> regards Chris >> >> >> >> >> >> . >> > > > . > ________________________________________________________________________________
Date: Apr 20, 2008
I'm a little new around here, but I think I missed a joke or something... 2eyedocs wrote: > Bad email! [Exclamation] -------- Scott Keadle 14A, Lake Norman Airpark N426AK RV-10, final assembly N246SK, Giles 202, flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177974#177974 ________________________________________________________________________________
Subject: WIng Question
Date: Apr 20, 2008
I've just finished match drilling the wing skins and am getting ready to start deburring, dimpling, and priming. I'm curious as to how others handled match drilling, deburring, and dimpling the bottom side of the wing ribs and rear spar. While it's easier to do now before riveting the top skin the wing ribs, I suspect it's probably better to wait until the bottom skins are attached for a more perfect fit. My thoughts are that I will probably have to touch up the priming after final match drilling and dimpling. ________________________________________________________________________________
Date: Apr 20, 2008
Subject: Re: WIng Question
I primed everything as I went, aka, all the ribs are primed than I followed through the steps Van's has in each section except I did NOT rivet the bottom skins on.. So I did match drill and dimple all holes and the bottom is ready to be riveted, I moved on to the next section and will rivet the bottom later. As far the primer being removed, after I deburred each hole using a brush did touchup on the bottom ribs, the bottom skins were primed after all dimpling and deburring. Pascal ----- Original Message ----- From: Bob Leffler To: rv10-list(at)matronics.com Sent: Sunday, April 20, 2008 8:04 AM Subject: RV10-List: WIng Question I've just finished match drilling the wing skins and am getting ready to start deburring, dimpling, and priming. I'm curious as to how others handled match drilling, deburring, and dimpling the bottom side of the wing ribs and rear spar. While it's easier to do now before riveting the top skin the wing ribs, I suspect it's probably better to wait until the bottom skins are attached for a more perfect fit. My thoughts are that I will probably have to touch up the priming after final match drilling and dimpling. ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Apr 20, 2008
I used 3M Weatherstrip Adhesive to temporarily glue the seals then used the Brown Aircraft Supply contact cement for the final. This worked with their seal - I have now tried this with Vans original seal. John Testement jwt(at)roadmapscoaching.com 40321 Richmond, VA Painting -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sheldon Olesen Sent: Saturday, April 19, 2008 10:44 PM Subject: RV10-List: Temporary door seal install Does anyone know a method of temporarily installing the door seal? I've tried carpet tape and it won't stick to the seal material. I wanted to final fit the doors with the seal in place so there wouldn't be any surprises after painting. Sheldon Olesen 40080 Checked by AVG. 5:24 PM Checked by AVG. 11:31 AM ________________________________________________________________________________
Subject: Pictures of the door pins after fabricating longer pins.
Date: Apr 20, 2008
To ensure a complete circumference of the pin in the door jamb we lengthened the pins about .25-.40 inch and shortened the bevel length . That is we made the angle steeper. ________________________________________________________________________________
Date: Apr 20, 2008
Subject: Re: Recommendations for front air vents
Thane, I am doing the same thing but what did you use to attach the vents to the inlet? I haven't installed them permanently yet but I was going to just use a 2" pipe clamp. Rick Sked 40185 ----- Original Message ----- From: "Thane States" <thane2(at)comporium.net> Sent: Friday, April 18, 2008 6:38:48 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Recommendations for front air vents Here are a few pics of my eyeball vent install as promised. Hope these are OK. Thane ----- Original Message ----- From: "Thane States" <thane2(at)comporium.net> Sent: Thursday, April 17, 2008 9:18 PM Subject: Re: RV10-List: Recommendations for front air vents > > Sorry the wife has camera. I will post some pics tomorrow. > Thane > > > ----- Original Message ----- > From: "linn Walters" <pitts_pilot(at)bellsouth.net> > To: > Sent: Thursday, April 17, 2008 7:12 PM > Subject: Re: RV10-List: Recommendations for front air vents > > >> >> Thane States wrote: >> >> >> snip >> >>> Let me know if you have questions. I also have a pic of the end >>> product, looks real clean, is easy to remove, and eliminates the ugly >>> white flange, and requires no hardware or glue. >> >> So, where's the picture??? Holding out for cash offers??? :-) >> Linn >> >>> >>> Thane >>> 803-396-8865 >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 20, 2008
Rick, the coupling I used had the hose clamps already on each end, so I just used them. It holds very tight and you can barely see the clamp once it is installed. Good luck, I am very pleased with the final look and function. Thane ----- Original Message ----- From: "Rick Sked" <ricksked(at)embarqmail.com> Sent: Sunday, April 20, 2008 5:47 PM Subject: Re: RV10-List: Recommendations for front air vents > > Thane, > > I am doing the same thing but what did you use to attach the vents to the > inlet? I haven't installed them permanently yet but I was going to just > use a 2" pipe clamp. > > Rick Sked > 40185 > > ----- Original Message ----- > From: "Thane States" <thane2(at)comporium.net> > To: rv10-list(at)matronics.com > Sent: Friday, April 18, 2008 6:38:48 PM (GMT-0800) America/Los_Angeles > Subject: Re: RV10-List: Recommendations for front air vents > > Here are a few pics of my eyeball vent install as promised. Hope these > are > OK. > Thane > ----- Original Message ----- > From: "Thane States" <thane2(at)comporium.net> > To: > Sent: Thursday, April 17, 2008 9:18 PM > Subject: Re: RV10-List: Recommendations for front air vents > > >> >> Sorry the wife has camera. I will post some pics tomorrow. >> Thane >> >> >> ----- Original Message ----- >> From: "linn Walters" <pitts_pilot(at)bellsouth.net> >> To: >> Sent: Thursday, April 17, 2008 7:12 PM >> Subject: Re: RV10-List: Recommendations for front air vents >> >> >>> >>> >>> Thane States wrote: >>> >>> >>> snip >>> >>>> Let me know if you have questions. I also have a pic of the end >>>> product, looks real clean, is easy to remove, and eliminates the ugly >>>> white flange, and requires no hardware or glue. >>> >>> So, where's the picture??? Holding out for cash offers??? :-) >>> Linn >>> >>>> >>>> Thane >>>> 803-396-8865 >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 20, 2008
Here is a shot of the two rudder trim pieces that can be bought at Avery Tools. The bottom one is a little harder to see because the paint matches. I will now send out the top one to be painted. I attach them with silicon rubber. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: AirMike <Mikeabel(at)Pacbell.net> Sent: Sunday, April 20, 2008 12:26:43 AM Subject: RV10-List: Re: PIREP: Electric Rudder Trim - Do I really need it? Scott - very nice - I like your KISS approach. Is there any way you could post a picture of placement. Also where did you get the tabs or how did you fabricate and locate them? -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=177943#177943 ________________________________________________________________________________
Subject: Stick hits panel solution
Date: Apr 21, 2008
U29tZW9uZSByZWNlbnRseSBhc2tlZCBtZSBob3cgSSByZXNvbHZlZCBvdXIgSW5maW5pdHkgZ3Jp cCBtb3VudGVkIHN0aWNrIGhpdHRpbmcgdGhlIGxvd2VyIHBhbmVsLiBNeSBhbnN3ZXIgd2FzIEkg d2lsbCBrbm93IGluIHR3byB3ZWVrcy4gV2VsbCBmb2xrcywgZmluYWxseSBzb21ldGhpbmcgZG9u ZSBhaGVhZCBvZiBzY2hlZHVsZS4uLg0KDQogICAgICAgICAgICBUaGUgZ3JpcHMgZG8gaGl0IHRo ZSBsb3dlciBwYW5lbCBhcyB3ZSBzdXNwZWN0ZWQuIFRoZSBzdGlja3MgbmVlZCB0byB0cmF2ZWwg YWJvdXQgMS84IiBmdXJ0aGVyIHRoYW4gdGhlIHBhbmVsIGFsbG93cy4gQWRkaXRpb25hbGx5IHdl IHdvdWxkIHdhbnQgc29tZSBleHRyYSBjbGVhcmFuY2UgZm9yIGNvbWZvcnQuIEFmdGVyIHNwZW5k aW5nIHNvbWUgdGltZSBhY2Nlc3NpbmcgdGhlIHNpdHVhdGlvbiB3ZSBmaWd1cmVkIHRoZXJlIHdl cmUgYSBjb3VwbGUgb2Ygb3B0aW9ucyBhdCB0aGlzIHBvaW50IGluIHRoZSBidWlsZC4NCg0KICAg ICAgICAgICAgT3B0aW9uIDEgbW9kaWZ5IHRoZSBkb3duIHRyYXZlbCBvbiB0aGUgZWxldmF0b3Ig c3RvcC4gRnJvbSB3aGF0IHdlIG1lYXN1cmVkIG91ciBjdXJyZW50IGRvd24gdHJhdmVsIGlzIDI1 IGRlZ3JlZXMuIFRvIGdldCB0aGUgZnVsbCBzZXQgYmFjayBuZWVkZWQgd2Ugd291bGQgaGF2ZSB0 byB0YWtlIHRoZSB0cmF2ZWwgZG93biB0byB+MTkgZGVncmVlcy4gVGhpcyB3YXMgbGVzcyB0aGFu IDAuNzUgaW5jaGVzIG9mIHRyYXZlbCBvbiB0aGUgSG9yaXpvbnRhbCBTdGFiIGFuZCB3b3VsZCBo YXZlIHNvbHZlZCBhbGwgdGhlIHN0aWNrIGNsZWFyYW5jZSBpc3N1ZXMuIFRoYXQgYmVpbmcgc2Fp ZCBWYW4gc3BlY2lmaWMgYSBtaW5pbXVtIG9mIDIwIGRlZ3JlZXMgYW5kIGFzIHdlIGFyZSBub3Qg cmUtZW5naW5lZXJpbmcgdGhlIGFlcm9uYXV0aWNhbCBwb3J0aW9uIG9mIHRoaXMgYWlyY3JhZnQg dGhhdCBtb2RpZmljYXRpb24gd2FzIGEgbm8gZ28gZXZlbiB0aG91Z2ggSSBob3BlIHRvIG5ldmVy IG5lZWQgZnVsbCBmb3J3YXJkIGRlZmxlY3Rpb24uDQoNCiAgICAgICAgICAgIE9wdGlvbiAyIHR1 cm5zIG91dCB0byBiZSBhIHNpbXBsZSBmaXguIFdlIHB1bGxlZCB0aGUgc3RpY2sgb3V0IG9mIHRo ZSBmdXNlIGFuZCBwbGFjZWQgaXQgaW4gYSBoeWRyYXVsaWMgcHJlc3MgdG8gYmVuZCB0aGUgY3Vy dmVkIHNlY3Rpb24gb2YgdGhlIHN0aWNrLiBUaGVyZSB3YXMgdmVyeSBsaXR0bGUgYmVuZGluZyBy ZXF1aXJlZCB0byBwcm92aWRlIHRoZSBjbGVhcmFuY2VzIG5lZWRlZCBhbmQgbm90aGluZyBhZXJv bmF1dGljYWwgd2FzIG1vZGlmaWVkLiBUaGUgY2hhbmdlIGlzIHVubm90aWNlYWJsZSBmcm9tIHRo ZSBwaWxvdHMvY28tcGlsb3Qgc2VhdGVkIHBvc2l0aW9uLiANCg0KICAgICAgICAgICAgT3B0aW9u IDMgaXMgdG8gcGxhbiBhaGVhZCBsaWtlIERlZW1zIGRpZCBhbmQgbW9kaWZ5IHRoZSBzdGljayBC RUZPUkUgaXQgaXMgcG93ZGVyIGNvYXRlZCwgZ3JpcCBmaXR0ZWQgYW5kIHdpcmVzIHJ1bi4gRm9y dHVuYXRlbHkgb3VyIGFkanVzdG1lbnQgZGlkIG5vdCBwdXQgYSBzaW5nbGUgc2NyYXRjaCBvbiB0 aGUgc3RpY2sgYW5kIHRoZSBlbnRpcmUgY29ycmVjdGlvbiB0b29rIGxlc3MgdGhhbiA5MCBtaW51 dGVzIGluY2x1ZGluZyBtYWtpbmcgdGhlIHdvb2QgamlnIHRvIGJlbmQgdGhlIHN0aWNrcy4gKEFs bCB0aW1lcyBleGNsdWRlIGhlYWQgc2NyYXRjaGluZykNCg0KIA0KDQogDQoNClJvYmluDQoNClJW LTQgICAgICAgICAgICAgICBTb2xkDQoNClJWLTZBICAgICAgICAgICAgNDAwIEhvdXJzDQoNClJW LTEwICAgICAgICAgICAgIFNvb25lciBvciBMYXRlciwgUHJvYmFibHkgTGF0ZXINCg0KIA0KDQog IA0KDQogDQoNCg= ________________________________________________________________________________
Date: Apr 22, 2008
Subject: Re: Stick hits panel solution
I had the same stick interference with my panel from Lancair. The Infinity grips are much taller and cause this problem. I have posted this in the past but thought I would post again. I decided to cut my stick near the top of the curve. I then purchased the exact same steel and wall thickness only it was a larger diameter so it would slide over the stock stick. I can't remember the type of steel, I just called Van's and they knew exactly what it was. Luckily one of the helicopter maintenance companies here at my airport has a certified tig welder and he charged me $40 to weld up both sticks. He did an amazing job. I don't even notice that the stick is slightly angled but now it is clear of everything. I don't think anyone should mess with the controls and limit them even though full down will probably never be used. My fix took a couple hours once I had the right steel tubing. I then had Flighline Interiors make me some real nice leather covers for the sticks. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: Robin Marks <robin1(at)mrmoisture.com> Sent: Monday, April 21, 2008 6:54:10 PM Subject: RV10-List: Stick hits panel solution Someone recently asked me how I resolved our Infinity grip mounted stick hitting the lower panel. My answer was I will know in two weeks. Well folks, finally something done ahead of schedule... The grips do hit the lower panel as we suspected. The sticks need to travel about 1/8" further than the panel allows. Additionally we would want some extra clearance for comfort. After spending some time accessing the situation we figured there were a couple of options at this point in the build. Option 1 modify the down travel on the elevator stop. From what we measured our current down travel is 25 degrees. To get the full set back needed we would have to take the travel down to ~19 degrees. This was less than 0.75 inches of travel on the Horizontal Stab and would have solved all the stick clearance issues. That being said Van specific a minimum of 20 degrees and as we are not re-engineering the aeronautical portion of this aircraft that modification was a no go even though I hope to never need full forward deflection. Option 2 turns out to be a simple fix. We pulled the stick out of the fuse and placed it in a hydraulic press to bend the curved section of the stick. There was very little bending required to provide the clearances needed and nothing aeronautical was modified. The change is unnoticeable from the pilots/co-pilot seated position. Option 3 is to plan ahead like Deems did and modify the stick BEFORE it is powder coated, grip fitted and wires run. Fortunately our adjustment did not put a single scratch on the stick and the entire correction took less than 90 minutes including making the wood jig to bend the sticks. (All times exclude head scratching) Robin RV-4 Sold RV-6A 400 Hours RV-10 Sooner or Later, Probably Later ________________________________________________________________________________
Date: Apr 22, 2008
Based on Scotts recommendation I did the same thing, except I used a smaller OD, thicker wall piece of stock and put it inside the tube and welded it. It is nice to have friends on the field that can weld.... Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Tuesday, April 22, 2008 9:05 AM Subject: Re: RV10-List: Stick hits panel solution I had the same stick interference with my panel from Lancair. The Infinity grips are much taller and cause this problem. I have posted this in the past but thought I would post again. I decided to cut my stick near the top of the curve. I then purchased the exact same steel and wall thickness only it was a larger diameter so it would slide over the stock stick. I can't remember the type of steel, I just called Van's and they knew exactly what it was. Luckily one of the helicopter maintenance companies here at my airport has a certified tig welder and he charged me $40 to weld up both sticks. He did an amazing job. I don't even notice that the stick is slightly angled but now it is clear of everything. I don't think anyone should mess with the controls and limit them even though full down will probably never be used. My fix took a couple hours once I had the right steel tubing. I then had Flighline Interiors make me some real nice leather covers for the sticks. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: Robin Marks <robin1(at)mrmoisture.com> Sent: Monday, April 21, 2008 6:54:10 PM Subject: RV10-List: Stick hits panel solution Someone recently asked me how I resolved our Infinity grip mounted stick hitting the lower panel. My answer was I will know in two weeks. Well folks, finally something done ahead of schedule... The grips do hit the lower panel as we suspected. The sticks need to travel about 1/8" further than the panel allows. Additionally we would want some extra clearance for comfort. After spending some time accessing the situation we figured there were a couple of options at this point in the build. Option 1 modify the down travel on the elevator stop. From what we measured our current down travel is 25 degrees. To get the full set back needed we would have to take the travel down to ~19 degrees. This was less than 0.75 inches of travel on the Horizontal Stab and would have solved all the stick clearance issues. That being said Van specific a minimum of 20 degrees and as we are not re-engineering the aeronautical portion of this aircraft that modification was a no go even though I hope to never need full forward deflection. Option 2 turns out to be a simple fix. We pulled the stick out of the fuse and placed it in a hydraulic press to bend the curved section of the stick. There was very little bending required to provide the clearances needed and nothing aeronautical was modified. The change is unnoticeable from the pilots/co-pilot seated position. Option 3 is to plan ahead like Deems did and modify the stick BEFORE it is powder coated, grip fitted and wires run. Fortunately our adjustment did not put a single scratch on the stick and the entire correction took less than 90 minutes including making the wood jig to bend the sticks. (All times exclude head scratching) Robin RV-4 Sold RV-6A 400 Hours RV-10 Sooner or Later, Probably Later Stick Jig.jpgStick Clearance.jpg ________________________________________________________________________________
Subject: Perhaps a better fitting door when latched.
Date: Apr 22, 2008
In my previous post, I described the point of my build where I was question ing what to do with the plastic door blocks that are screwed to the fuse, t he ones that the pins go through, as mine where flush with the fuse sides. Even though these acted as a door pin stops which would prevent the pins fr om chipping the paint in the event the pins were not completely retracted, when the door is being closed, I opted to trim them back instead of pocketi ng out the door edge. Now they act as door stops and are trimmed back from the fuse edge, the thickness of the door material. After the door was able to go back into its position that I had spend so m any hours fitting, I engaged the pins to full position and noted that both door did not fit the same way as when the pins were not engaged. After much analysing...here is my idea as to why. I spend so much effort and time making sure that that I marked where the pi ns hit the canopy opening, I was very careful to make sure I dilled my hole s for the pins correctly, straight and true. I even went as far as to drill each hole with a small bit and incrementally step up bit sizes and I did i t from the front as well as from the back. I used a straght edge as a guide to remain parallel to the side and in a fore/aft dimension. The problem is that the cabin sill, fiberglass canopy top and the metal fus elage member are almost 1/4 inch thick and one needs to drill that pin hole so that it is perfectly parallel, in all dimensions to the door pin, becau se if the hole isn't true, the back half of the hole will cause the door to ride up on that pin and cause the door to fit differently when the pins ar e engaged. Another way to do this or to fix it is to do the following: Drill the holes as suggested in the manual, if the problem does occur, remo ve the plastic guiding blocks, the ones that remain attached to the cabin s ide, then enlarge the hole slighly with a dremel sanding drum on the offend ing side of the hole( the side of the hole which engages too much) and re-c heck that the pins go into the hole without any interference while the door is jigged and clamped in its perfect position. Fabricate out of 1" X 2.5" X 1/8" aluminum a new hole. Drill to 7/16". Have the door closed in its' perfectly positioned place and close the pins to t heir maximum extension and place the new plate over the pin and glue it ont o the metal channel which makes up the fuselage side. (NOTE: I ALSO FABRICA TED NEW FORWARD PINS TO A LITTLE LONGER, ABOUT 3/16" LONGER AND CUT THE BEV EL LESS STEEP, SO INSTEAD OF 60 DEGREES, I DID 50 DEGREES OF BEVEL,( this s evers to have the entire pin tube held by the hole. Because the bevel is fa cing up and out, the unbevelled portion of the tube was just barely all the way through the aluminum fuse member.) Note#2 there seems to be enough dis tance between the pin while they are in their maximum open position and the plastic guide block on the fuse side to allow the pins to be made longer. Back to the new plate. Once glue is set, re drill the AN3 screw holes that are used to attach the plastic guide block and place longer screws to go al l the thru the plastic block, thru the fiberglass, through the metal fuse s ide and through the new plate. One will most likely need to make new plasti c guide blocks because the position of the hole is in a slightly different positon in relation to the screw holes. The enlarged hole in the fiberglass can be fixed by resin and cotton flox and the pin vasolined and placed in the closed position while curing. This should be done while the new plastic blocks are in place to minimize sanding. If this is done, all of this should be done, first by carefully checking wh ich pin hole is the offending one or whether it is both, by trying all comb inations of one plastic blocks on the other off, etc. Side Note: Remember, there should be four holes placed in the door handle g ear pocket sides to allow the full 135 degrees of handle movement. The mech anism needs to be centerred, and the toothed arms need to be at their maxim um closed positon against the blind rivet when the handle is in its' closed positon. The pins need to extend all the way into the metal fuse member. W ith all this done, I see no way how one could not realize the door is ajar and the pins are absolutely long enough that they cannot pull out. John Gonzalez ________________________________________________________________________________
Date: Apr 22, 2008
Subject: RV-10 Dash Cover
I get a few e-mails every month about my dash cover. It was custom made here in Salt Lake by a local hot rod shop and they did a great job. I sent it out to Abby at Flightline Interiors to be copied. Today I e-mailed her and she informed me that she is selling them but has not had time to update her website. I have attached a couple of photos that I have (not very good ones) of my cover. If you are interested please contact Flightline Interiors. http://www.flightlineinteriors.com/ If anyone has one from Abby please post a picture. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Subject: 210HM
Date: Apr 23, 2008
The preliminary NTSB report is availaable. ________________________________________________________________________________
Subject: 210HM
Date: Apr 23, 2008
If you want to see graphically the track, check www.flightware.com and zoom in on the end of the track by resizing your browser to 200%. ________________________________________________________________________________
Subject: Re: 210HM
Date: Apr 23, 2008
I believe the link to the track is www.flightaware.com and Tim's link is also broken. Guess we have fat fingers today [Laughing] -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178718#178718 ________________________________________________________________________________
Subject: Re: 210HM
Date: Apr 23, 2008
Thanks Tim, I never would have found it ... now I'm not sure I'm glad I did. I still love building, but my curiosity about flying is waning. Hopefully I'm just temporarily discouraged. What a loss. Here's Tim's unbroken link: http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 Here's the address of the flight (you may have to copy and paste it): http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airports=M54+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;height=340;width=400;departuretime=1207580400;arrivaltime=1207585140 Later, -Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178741#178741 ________________________________________________________________________________
Subject: Re: 210HM
Date: Apr 23, 2008
http://www.ntsb.gov/ntsb/brief.asp?ev_id 080422X00528&key=1 -------- Andy Turner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178739#178739 ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: 210HM
Lew; We all miss our fellow builders who have perished in the last year. I would encourage you to read some of Tim's great articles on what he has done for his family in the plane these last couple of years http://www.myrv10.com/N104CD/index.html and remember people die every day; some doing what they enjoy, some while waiting for that day they would do something they wanted to do and some completely unexpectedly taking out the garbage they hated doing.. I too will go one day, I know where I'm going and I'm pretty excited about it, but in the meantime I want to do what I always wanted (build a plane) and if I die on my maiden flight, I'll be really bummed but I did it doing something I was excited about.. the few we have lost this last year perished doing what they loved.. I encourage you to think of all those trips to meet many of us at fly-in's, in Oregon for Van's open house, etc.. there is so much to get excited about with flying.. Pascal -------------------------------------------------- From: "Lew Gallagher" <lewgall(at)charter.net> Sent: Wednesday, April 23, 2008 1:25 PM Subject: RV10-List: Re: 210HM > > Thanks Tim, I never would have found it ... now I'm not sure I'm glad I > did. I still love building, but my curiosity about flying is waning. > Hopefully I'm just temporarily discouraged. What a loss. > > Here's Tim's unbroken link: > > http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 > > Here's the address of the flight (you may have to copy and paste it): > > http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airports=M54+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;height=340;width=400;departuretime=1207580400;arrivaltime=1207585140 > > Later, -Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > doors almost finished, pants on, WHEW! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=178741#178741 > > > ________________________________________________________________________________
Subject: Re: 210HM - Lew
Date: Apr 23, 2008
Lew, I'd like to add to Pascal's encouragement to you. I've been blessed with the opportunity to fly a lot of airplanes, mostly fighters, and find the RV-10 and general aviation flying to be some of the greatest experiences of my life. This tragedy is certainly sad and disheartening, and for me compounded by the loss of two more brethren here at Columbus AFB today, but I wouldn't trade flying for anything in the world. The opportunities the RV-10 has afforded my family are irreplaceable and I wouldn't be able to spend the time with my daughters who are off in college anywhere close to what I can now. The joy of flight, and in particular going places that the RV-10 provide, are absolutely amazing. The losses of friends and fellow aviators is devastating but I pray will not be more than a bump in the road for your progress to personal success but will be lessons learned as to how you train and act as a pilot. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Wednesday, April 23, 2008 3:25 PM Subject: RV10-List: Re: 210HM Thanks Tim, I never would have found it ... now I'm not sure I'm glad I did. I still love building, but my curiosity about flying is waning. Hopefully I'm just temporarily discouraged. What a loss. Here's Tim's unbroken link: http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 Here's the address of the flight (you may have to copy and paste it): http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airports=M5 4+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;heigh t=340;width=400;departuretime=1207580400;arrivaltime=1207585140 Later, -Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178741#178741 ________________________________________________________________________________
Date: Apr 23, 2008
I know the feeling, Lew. Every time we lose someone close to the aviation family, I seem to pull away from aviation too. About the only thing I've found that can get me over it is to put the headset on and go for a flight. It recaptures my imagination and once I've landed the plane, I realize I still know how to fly safely. Staying in the air has been important to my comfort level in flying. If I go more than a couple of weeks without flying, I start getting scared. Accidents or not. It just amazes me that I can leave the planet in Texas, successfully navigate across the US, and actually make that airplane touch down within a pre-determined 50' x 50' square patch of the planet 4 states away. Just the thought of that amazes me and scares me. To get over it, I've just got to get in the air and prove to myself that everything is A-OK. Some days, I feel like I'm exposing myself to more risks that I'm comfortable taking. There have been times that I've described aviation to friends in the same terms as a drug addiction. (Not that I know what that's like.) I'm addicted to it. I've got to have it. I live for the next hit. I'm willing to take risks for it. I'm willing to risk my life for it. It has a tighter grip on me than I have on my own will power. Some days I feel like I can't live with it, while I know I can't live without it. I am a pilot. I know the risks. I'm addicted to flight (just like those addicted to drugs) whether I like it or not. It's part of who I am and I honestly don't think it's possible to put out the fire. Hang in there. Deep down, I'm sure there is still a flame burning. Don't let it go out. Just get in an airplane and go for a flight. After you return to the planet, you'll remember why you fell in love with flight the first time. Phil -----Original Message----- From: Marcus Cooper [mailto:coop85(at)cableone.net] Sent: Wednesday, April 23, 2008 6:42 PM Subject: RE: RV10-List: Re: 210HM - Lew Lew, I'd like to add to Pascal's encouragement to you. I've been blessed with the opportunity to fly a lot of airplanes, mostly fighters, and find the RV-10 and general aviation flying to be some of the greatest experiences of my life. This tragedy is certainly sad and disheartening, and for me compounded by the loss of two more brethren here at Columbus AFB today, but I wouldn't trade flying for anything in the world. The opportunities the RV-10 has afforded my family are irreplaceable and I wouldn't be able to spend the time with my daughters who are off in college anywhere close to what I can now. The joy of flight, and in particular going places that the RV-10 provide, are absolutely amazing. The losses of friends and fellow aviators is devastating but I pray will not be more than a bump in the road for your progress to personal success but will be lessons learned as to how you train and act as a pilot. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Wednesday, April 23, 2008 3:25 PM Subject: RV10-List: Re: 210HM Thanks Tim, I never would have found it ... now I'm not sure I'm glad I did. I still love building, but my curiosity about flying is waning. Hopefully I'm just temporarily discouraged. What a loss. Here's Tim's unbroken link: http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 Here's the address of the flight (you may have to copy and paste it): http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airport s=M5 4+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;h 4+eigh t=340;width=400;departuretime=1207580400;arrivaltime=1207585140 Later, -Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178741#178741 ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: 210HM
In a message dated 4/23/2008 3:30:44 PM Central Daylight Time, lewgall(at)charter.net writes: Later, -Lew Lew...the idea in flying is to learn from others mistakes and have your own set of limits...not always the published figures on plates...IMHO Patrick **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: 210HM
Lew, Pascal, and all, Nothing I have to say is new at all, but I thought I'd share my feelings. To me, all things involve risk, so I don't really view the fact that it has risk as making the activity something I'm averse to. I've never been skydiving (REAL skydiving), but it drives me crazy to hear about people like my own brother in law, who would LOVE to go skydiving, but simply won't because his insurance wouldn't pay if he died. You're put on the earth to LIVE life, and to me, it's all about what you're passionate about...and fulfilling your dreams. There is a LOT you can do, in ANY activity, to increase your odds, but in almost ALL activities there is nothing you can do to guarantee your safety. So, you simply live life to it's fullest, enjoying the things you're passionate about....and you do what you can to minimize your risks. A couple days ago, I wanted to fill in the AOPA survey and the question "What do you think is the most significant deterrent to learning how to fly, besides cost?" I tell you, I was totally stumped. So I asked a co-worker, who's expressed interest, but never taken the plunge. She said "Probably fear, that they won't be able to control the plane, and that they'll hurt or kill themselves or someone else." I was stunned at first. I couldn't believe it. To me, I always had the passion, the dream, and the desire. The thought that I would not be able to do it safely never entered my mind. To me, if other people can fly planes, then because I WANT to fly planes so bad, I can fly planes. After pondering it for a while, I agreed with her and I filled in the survey. I just didn't realize that some people let their fears crush their passion like that, or perhaps their passion wasn't as overwhelming to quench their fears. So assuming that a person indeed has the passion in them to partake in flying, my feeling is that those that TRULY have that passion for excellence will also strive for developing the knowledge and skill required to do the flying they want to do. For me, one thing led to another and I yearned for more. I love the complexity, I love the challenge, I love flying in and out of IMC. I love the clear sky days, and I love the low drizzly days. But I also want to do it right, and be safe. I have a fear in me, developed from reading all of the negative examples that we have...."Aftermath"...."I learned about flying from that", and so on... I put myself in the cockpit when I read those stories, and I wonder... what would be the way to prevent that situation? There are many good people and good pilots who did some pretty not-so-hot things that led to their demise. I'm no better than them, but because they are my teacher, in some respect, I hope to use them as a source of guidance, and let them help me develop self-control. I don't want to have the same fate, so when I fly, I constantly analyze the safety of what I'm doing when I have those critical decisions, and I remind myself what the cost is if I fail. It's very humbling. But, the risk does not kill my desire...because I KNOW....there is no reason for me to meet the same fate....it's ALL IN MY HANDS. That leads me to re-tell a story. I had many good opportunities for instilling respect and fear into myself in actual IMC during my Instrument rating training. I genuinely was NOT ready, 20 hours into my training, to keep myself alive in IMC...and I knew that. But, I kept flying with my pals....all CFI's, in actual IMC and under the hood, to build confidence. Finally the day came...well after obtaining that ticket, for me to go fly in IMC on a perfect day. No reason, just was the perfect 700' overcast day to go test myself with, ... HA! ... that same risk-averse brother in law of mine. I climbed out into the clouds, and as soon as I was in IMC, I thought to myself "Man, did YOU do it now....Now you're stuck...and you can't get out of this with any help from anyone else...it's only YOU who can bring you both down alive and safe." I was genuinely fearful....but reminded myself that I knew what to do...it was only executing those things that I needed to do properly. The airplane was up to it, if only I was too. Obviously, it went just fine, or I'd not be here today. But, still to this day, when I'm entering the clouds, I have similar feelings, because I respect what I'm doing as "highly challenging" and important to do well. In reading the NTSB report, one cannot help to question the pilot(s). It's our nature. "Why didn't they just fly straight and level and get their bearings?" "Why didn't they just hit the ONE button on their Autopilot (assuming a TruTrak) that gives them instant heading and altitude hold?" "Why didn't they ask for vectors and just fly headings and vectors until they got to some better conditions?" They're gone, so it's not dishonoring them to ask....they're now our teachers. What is obvious is that mistakes were made. Now, for those who choose to fly in conditions like they were, it's your job to find out what mistakes, and NOT make them yourself. Remember them, and honor them by bringing your craft and crew home safe, every time. What can you do to help? Well, I for one, just did an early BFR and IPC yesterday. Nothing wrong with doing a AFR instead of a BFR right? (No, there is no such thing as an Annual Flight Review...but hey, it never hurts.) I want to make sure that not only am I legal on paper, but that someone else critiques me too. I don't WANT him to go easy on me. I did some things and he asked if I wanted ATP standards or normal. I chose ATP. I WANT to be tested. As Phil mentioned, you get rusty and more fearful if you don't fly often, so FLY OFTEN. This activity isn't for the occasional pilot...one who goes up for some touch and goes every 4 months. Stick with it... get some time every month, even if it's only an hour. Can you do that? I'm thinking that if you truly have the passion, you'll make it happen. Flying isn't for everyone...but anyone with the passion can make it work for them. The one thing that does concern me greatly is the number of ZERO time pilots that are building RV-10's. My CFII yesterday mentioned, when we discussed the 3 fatal RV-10 accidents, that we're very similar to the Cirrus trends, but we're very similar planes. He said the average Cirrus owner has something like 74 hours (unverified), and we both lamented at how shockingly inadequate (sorry, really, I am) that can be, for flying a plane with such performance. Sure, it flies slow if throttle back, but it's slippery, and it's light, and it demands respect. So, for those out there that are very low or zero time pilots, please, get in that plane with a CFI and put LOTS of time on it if you insist on flying an RV-10 right away. LOTS of time. You will never progress faster by any other means than if you put on a LOT of time over a short time span. If you can fly 200 hours in a year, you're going to retain a lot more skill for many years, than the guy who flies 20-45 hours a year. So look at it as an investment, and just fork over for the avgas and keep that plane in the air for a MINIMUM of 100 hours in the first year. The year I got my instrument ticket I put in 100+ hours, and it was my biggest year of skill growth ever...and it was the most retained, at that. My first year in my RV-10 I put on 200 hours. It's amazing how much comfort that brings you. So, if you truly have the passion, these accidents, and NTSB reports won't stun you and set you back. They'll make you think, and make you strive for more. And you'll still gladly jump in the plane and go for a flight, because you'll know that it CAN happen to you, but only if you don't get out there and develop good skills, and retain them. Anyone can fly a plane and bring it back to earth with everyone alive. You just have to NOT do the things that people do wrong....so learn from the others who paid the price for your lesson...and develop respect for flying and be safe. Tim Olson - RV-10 N104CD - Flying (sorry, I'll try for more brevity on the next few posts to make up for this one.) ;) Pascal wrote: > > Lew; > We all miss our fellow builders who have perished in the last year. I > would encourage you to read some of Tim's great articles on what he has > done for his family in the plane these last couple of years > http://www.myrv10.com/N104CD/index.html and remember people die every > day; some doing what they enjoy, some while waiting for that day they > would do something they wanted to do and some completely unexpectedly > taking out the garbage they hated doing.. I too will go one day, I know > where I'm going and I'm pretty excited about it, but in the meantime I > want to do what I always wanted (build a plane) and if I die on my > maiden flight, I'll be really bummed but I did it doing something I was > excited about.. the few we have lost this last year perished doing what > they loved.. > I encourage you to think of all those trips to meet many of us at > fly-in's, in Oregon for Van's open house, etc.. there is so much to get > excited about with flying.. > Pascal > > -------------------------------------------------- > From: "Lew Gallagher" <lewgall(at)charter.net> > Sent: Wednesday, April 23, 2008 1:25 PM > To: > Subject: RV10-List: Re: 210HM > >> >> Thanks Tim, I never would have found it ... now I'm not sure I'm glad >> I did. I still love building, but my curiosity about flying is >> waning. Hopefully I'm just temporarily discouraged. What a loss. >> >> Here's Tim's unbroken link: >> >> http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 >> >> Here's the address of the flight (you may have to copy and paste it): >> >> http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airports=M54+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;height=340;width=400;departuretime=1207580400;arrivaltime=1207585140 >> >> >> Later, -Lew >> >> -------- >> non-pilot >> crazy about building >> NOW OFICIALLY BUILDER #40549 >> doors almost finished, pants on, WHEW! >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=178741#178741 >> >> ________________________________________________________________________________
Date: Apr 23, 2008
From: "bruce breckenridge" <bbreckenridge(at)gmail.com>
Subject: Re: 210HM
Word for word, a very encouraging and motivating statement of passion guarded by wisdom. Thanks Tim. I am one of those low timers working on my IFR ticket and loving every minute of it, yet nervous of the day when I'm on my own and every move is up to me. Good words. Keep 'em coming! Bruce 40018 On Wed, Apr 23, 2008 at 7:10 PM, Tim Olson wrote: > > Lew, Pascal, and all, > > Nothing I have to say is new at all, but I thought I'd share > my feelings. To me, all things involve risk, so I don't really > view the fact that it has risk as making the activity something > I'm averse to. I've never been skydiving (REAL skydiving), but > it drives me crazy to hear about people like my own brother > in law, who would LOVE to go skydiving, but simply won't because > his insurance wouldn't pay if he died. You're put on the earth > to LIVE life, and to me, it's all about what you're passionate > about...and fulfilling your dreams. There is a LOT you can > do, in ANY activity, to increase your odds, but in almost > ALL activities there is nothing you can do to guarantee your > safety. So, you simply live life to it's fullest, enjoying > the things you're passionate about....and you do what you can > to minimize your risks. > > A couple days ago, I wanted to fill in the AOPA survey and > the question "What do you think is the most significant > deterrent to learning how to fly, besides cost?" I tell you, > I was totally stumped. So I asked a co-worker, who's expressed > interest, but never taken the plunge. She said "Probably > fear, that they won't be able to control the plane, and that > they'll hurt or kill themselves or someone else." I was > stunned at first. I couldn't believe it. To me, I always > had the passion, the dream, and the desire. The thought that > I would not be able to do it safely never entered my mind. > To me, if other people can fly planes, then because I WANT > to fly planes so bad, I can fly planes. After pondering > it for a while, I agreed with her and I filled in the survey. > I just didn't realize that some people let their fears > crush their passion like that, or perhaps their passion > wasn't as overwhelming to quench their fears. > > So assuming that a person indeed has the passion in them > to partake in flying, my feeling is that those that > TRULY have that passion for excellence will also strive > for developing the knowledge and skill required to do > the flying they want to do. For me, one thing led to > another and I yearned for more. I love the complexity, > I love the challenge, I love flying in and out of IMC. > I love the clear sky days, and I love the low drizzly > days. But I also want to do it right, and be safe. I > have a fear in me, developed from reading all of the > negative examples that we have...."Aftermath"...."I learned > about flying from that", and so on... I put myself in > the cockpit when I read those stories, and I wonder... > what would be the way to prevent that situation? There > are many good people and good pilots who did some pretty > not-so-hot things that led to their demise. I'm no better > than them, but because they are my teacher, in some > respect, I hope to use them as a source of guidance, > and let them help me develop self-control. I don't want > to have the same fate, so when I fly, I constantly > analyze the safety of what I'm doing when I have those > critical decisions, and I remind myself what the cost > is if I fail. It's very humbling. But, the risk > does not kill my desire...because I KNOW....there is > no reason for me to meet the same fate....it's ALL IN > MY HANDS. > > That leads me to re-tell a story. I had many good > opportunities for instilling respect and fear into > myself in actual IMC during my Instrument rating > training. I genuinely was NOT ready, 20 hours into > my training, to keep myself alive in IMC...and I knew > that. But, I kept flying with my pals....all CFI's, > in actual IMC and under the hood, to build confidence. > Finally the day came...well after obtaining that ticket, > for me to go fly in IMC on a perfect day. No reason, > just was the perfect 700' overcast day to go test > myself with, ... HA! ... that same risk-averse brother > in law of mine. I climbed out into the clouds, and > as soon as I was in IMC, I thought to myself "Man, > did YOU do it now....Now you're stuck...and you can't > get out of this with any help from anyone else...it's > only YOU who can bring you both down alive and safe." > I was genuinely fearful....but reminded myself that > I knew what to do...it was only executing those things > that I needed to do properly. The airplane was up to > it, if only I was too. Obviously, it went just fine, > or I'd not be here today. But, still to this day, > when I'm entering the clouds, I have similar feelings, > because I respect what I'm doing as "highly challenging" > and important to do well. > > In reading the NTSB report, one cannot help to question > the pilot(s). It's our nature. "Why didn't they just > fly straight and level and get their bearings?" "Why > didn't they just hit the ONE button on their Autopilot > (assuming a TruTrak) that gives them instant heading > and altitude hold?" "Why didn't they ask for vectors > and just fly headings and vectors until they got to > some better conditions?" They're gone, so it's not > dishonoring them to ask....they're now our teachers. > What is obvious is that mistakes were made. Now, for > those who choose to fly in conditions like they were, > it's your job to find out what mistakes, and NOT make > them yourself. Remember them, and honor them by > bringing your craft and crew home safe, every time. > > What can you do to help? Well, I for one, just did > an early BFR and IPC yesterday. Nothing wrong with > doing a AFR instead of a BFR right? (No, there is > no such thing as an Annual Flight Review...but hey, > it never hurts.) I want to make sure that not only > am I legal on paper, but that someone else critiques > me too. I don't WANT him to go easy on me. I did > some things and he asked if I wanted ATP standards > or normal. I chose ATP. I WANT to be tested. > As Phil mentioned, you get rusty and more fearful if > you don't fly often, so FLY OFTEN. This activity > isn't for the occasional pilot...one who goes up for > some touch and goes every 4 months. Stick with it... > get some time every month, even if it's only an hour. > Can you do that? I'm thinking that if you truly have > the passion, you'll make it happen. Flying isn't > for everyone...but anyone with the passion can make > it work for them. > > The one thing that does concern me greatly is the > number of ZERO time pilots that are building RV-10's. > My CFII yesterday mentioned, when we discussed the > 3 fatal RV-10 accidents, that we're very similar to > the Cirrus trends, but we're very similar planes. > He said the average Cirrus owner has something like > 74 hours (unverified), and we both lamented at how > shockingly inadequate (sorry, really, I am) that can > be, for flying a plane with such performance. Sure, it > flies slow if throttle back, but it's slippery, and > it's light, and it demands respect. So, for those > out there that are very low or zero time pilots, please, > get in that plane with a CFI and put LOTS of time on > it if you insist on flying an RV-10 right away. LOTS > of time. You will never progress faster by any other > means than if you put on a LOT of time over a short > time span. If you can fly 200 hours in a year, you're > going to retain a lot more skill for many years, than > the guy who flies 20-45 hours a year. So look at it > as an investment, and just fork over for the avgas > and keep that plane in the air for a MINIMUM of 100 > hours in the first year. The year I got my instrument > ticket I put in 100+ hours, and it was my biggest > year of skill growth ever...and it was the most > retained, at that. My first year in my RV-10 I put > on 200 hours. It's amazing how much comfort that brings > you. > > So, if you truly have the passion, these accidents, and > NTSB reports won't stun you and set you back. They'll > make you think, and make you strive for more. And > you'll still gladly jump in the plane and go for a flight, > because you'll know that it CAN happen to you, but only > if you don't get out there and develop good skills, > and retain them. Anyone can fly a plane and bring it > back to earth with everyone alive. You just have to > NOT do the things that people do wrong....so learn from > the others who paid the price for your lesson...and > develop respect for flying and be safe. > > Tim Olson - RV-10 N104CD - Flying > (sorry, I'll try for more brevity on the next few posts > to make up for this one.) ;) > > > Pascal wrote: > >> >> Lew; >> We all miss our fellow builders who have perished in the last year. I >> would encourage you to read some of Tim's great articles on what he has done >> for his family in the plane these last couple of years >> http://www.myrv10.com/N104CD/index.html and remember people die every >> day; some doing what they enjoy, some while waiting for that day they would >> do something they wanted to do and some completely unexpectedly taking out >> the garbage they hated doing.. I too will go one day, I know where I'm going >> and I'm pretty excited about it, but in the meantime I want to do what I >> always wanted (build a plane) and if I die on my maiden flight, I'll be >> really bummed but I did it doing something I was excited about.. the few we >> have lost this last year perished doing what they loved.. >> I encourage you to think of all those trips to meet many of us at >> fly-in's, in Oregon for Van's open house, etc.. there is so much to get >> excited about with flying.. >> Pascal >> >> -------------------------------------------------- >> From: "Lew Gallagher" <lewgall(at)charter.net> >> Sent: Wednesday, April 23, 2008 1:25 PM >> To: >> Subject: RV10-List: Re: 210HM >> >>> >>> Thanks Tim, I never would have found it ... now I'm not sure I'm glad I >>> did. I still love building, but my curiosity about flying is waning. >>> Hopefully I'm just temporarily discouraged. What a loss. >>> >>> Here's Tim's unbroken link: >>> >>> http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 >>> >>> Here's the address of the flight (you may have to copy and paste it): >>> >>> >>> http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airports=M54+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;height=340;width=400;departuretime=1207580400;arrivaltime=1207585140 >>> >>> Later, -Lew >>> >>> -------- >>> non-pilot >>> crazy about building >>> NOW OFICIALLY BUILDER #40549 >>> doors almost finished, pants on, WHEW! >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=178741#178741 >>> >>> >>> > > ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: 210HM
Tim; I should have said ">> would encourage you to read some of Tim's great articles on what he has done for his family and builders with feedback in the plane these last couple of years" As always you have not let us down with your insight! Thanks! Pascal -------------------------------------------------- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Wednesday, April 23, 2008 7:10 PM Subject: Re: RV10-List: Re: 210HM > > Lew, Pascal, and all, > > Nothing I have to say is new at all, but I thought I'd share > my feelings. To me, all things involve risk, so I don't really > view the fact that it has risk as making the activity something > I'm averse to. I've never been skydiving (REAL skydiving), but > it drives me crazy to hear about people like my own brother > in law, who would LOVE to go skydiving, but simply won't because > his insurance wouldn't pay if he died. You're put on the earth > to LIVE life, and to me, it's all about what you're passionate > about...and fulfilling your dreams. There is a LOT you can > do, in ANY activity, to increase your odds, but in almost > ALL activities there is nothing you can do to guarantee your > safety. So, you simply live life to it's fullest, enjoying > the things you're passionate about....and you do what you can > to minimize your risks. > > A couple days ago, I wanted to fill in the AOPA survey and > the question "What do you think is the most significant > deterrent to learning how to fly, besides cost?" I tell you, > I was totally stumped. So I asked a co-worker, who's expressed > interest, but never taken the plunge. She said "Probably > fear, that they won't be able to control the plane, and that > they'll hurt or kill themselves or someone else." I was > stunned at first. I couldn't believe it. To me, I always > had the passion, the dream, and the desire. The thought that > I would not be able to do it safely never entered my mind. > To me, if other people can fly planes, then because I WANT > to fly planes so bad, I can fly planes. After pondering > it for a while, I agreed with her and I filled in the survey. > I just didn't realize that some people let their fears > crush their passion like that, or perhaps their passion > wasn't as overwhelming to quench their fears. > > So assuming that a person indeed has the passion in them > to partake in flying, my feeling is that those that > TRULY have that passion for excellence will also strive > for developing the knowledge and skill required to do > the flying they want to do. For me, one thing led to > another and I yearned for more. I love the complexity, > I love the challenge, I love flying in and out of IMC. > I love the clear sky days, and I love the low drizzly > days. But I also want to do it right, and be safe. I > have a fear in me, developed from reading all of the > negative examples that we have...."Aftermath"...."I learned > about flying from that", and so on... I put myself in > the cockpit when I read those stories, and I wonder... > what would be the way to prevent that situation? There > are many good people and good pilots who did some pretty > not-so-hot things that led to their demise. I'm no better > than them, but because they are my teacher, in some > respect, I hope to use them as a source of guidance, > and let them help me develop self-control. I don't want > to have the same fate, so when I fly, I constantly > analyze the safety of what I'm doing when I have those > critical decisions, and I remind myself what the cost > is if I fail. It's very humbling. But, the risk > does not kill my desire...because I KNOW....there is > no reason for me to meet the same fate....it's ALL IN > MY HANDS. > > That leads me to re-tell a story. I had many good > opportunities for instilling respect and fear into > myself in actual IMC during my Instrument rating > training. I genuinely was NOT ready, 20 hours into > my training, to keep myself alive in IMC...and I knew > that. But, I kept flying with my pals....all CFI's, > in actual IMC and under the hood, to build confidence. > Finally the day came...well after obtaining that ticket, > for me to go fly in IMC on a perfect day. No reason, > just was the perfect 700' overcast day to go test > myself with, ... HA! ... that same risk-averse brother > in law of mine. I climbed out into the clouds, and > as soon as I was in IMC, I thought to myself "Man, > did YOU do it now....Now you're stuck...and you can't > get out of this with any help from anyone else...it's > only YOU who can bring you both down alive and safe." > I was genuinely fearful....but reminded myself that > I knew what to do...it was only executing those things > that I needed to do properly. The airplane was up to > it, if only I was too. Obviously, it went just fine, > or I'd not be here today. But, still to this day, > when I'm entering the clouds, I have similar feelings, > because I respect what I'm doing as "highly challenging" > and important to do well. > > In reading the NTSB report, one cannot help to question > the pilot(s). It's our nature. "Why didn't they just > fly straight and level and get their bearings?" "Why > didn't they just hit the ONE button on their Autopilot > (assuming a TruTrak) that gives them instant heading > and altitude hold?" "Why didn't they ask for vectors > and just fly headings and vectors until they got to > some better conditions?" They're gone, so it's not > dishonoring them to ask....they're now our teachers. > What is obvious is that mistakes were made. Now, for > those who choose to fly in conditions like they were, > it's your job to find out what mistakes, and NOT make > them yourself. Remember them, and honor them by > bringing your craft and crew home safe, every time. > > What can you do to help? Well, I for one, just did > an early BFR and IPC yesterday. Nothing wrong with > doing a AFR instead of a BFR right? (No, there is > no such thing as an Annual Flight Review...but hey, > it never hurts.) I want to make sure that not only > am I legal on paper, but that someone else critiques > me too. I don't WANT him to go easy on me. I did > some things and he asked if I wanted ATP standards > or normal. I chose ATP. I WANT to be tested. > As Phil mentioned, you get rusty and more fearful if > you don't fly often, so FLY OFTEN. This activity > isn't for the occasional pilot...one who goes up for > some touch and goes every 4 months. Stick with it... > get some time every month, even if it's only an hour. > Can you do that? I'm thinking that if you truly have > the passion, you'll make it happen. Flying isn't > for everyone...but anyone with the passion can make > it work for them. > > The one thing that does concern me greatly is the > number of ZERO time pilots that are building RV-10's. > My CFII yesterday mentioned, when we discussed the > 3 fatal RV-10 accidents, that we're very similar to > the Cirrus trends, but we're very similar planes. > He said the average Cirrus owner has something like > 74 hours (unverified), and we both lamented at how > shockingly inadequate (sorry, really, I am) that can > be, for flying a plane with such performance. Sure, it > flies slow if throttle back, but it's slippery, and > it's light, and it demands respect. So, for those > out there that are very low or zero time pilots, please, > get in that plane with a CFI and put LOTS of time on > it if you insist on flying an RV-10 right away. LOTS > of time. You will never progress faster by any other > means than if you put on a LOT of time over a short > time span. If you can fly 200 hours in a year, you're > going to retain a lot more skill for many years, than > the guy who flies 20-45 hours a year. So look at it > as an investment, and just fork over for the avgas > and keep that plane in the air for a MINIMUM of 100 > hours in the first year. The year I got my instrument > ticket I put in 100+ hours, and it was my biggest > year of skill growth ever...and it was the most > retained, at that. My first year in my RV-10 I put > on 200 hours. It's amazing how much comfort that brings > you. > > So, if you truly have the passion, these accidents, and > NTSB reports won't stun you and set you back. They'll > make you think, and make you strive for more. And > you'll still gladly jump in the plane and go for a flight, > because you'll know that it CAN happen to you, but only > if you don't get out there and develop good skills, > and retain them. Anyone can fly a plane and bring it > back to earth with everyone alive. You just have to > NOT do the things that people do wrong....so learn from > the others who paid the price for your lesson...and > develop respect for flying and be safe. > > Tim Olson - RV-10 N104CD - Flying > (sorry, I'll try for more brevity on the next few posts > to make up for this one.) ;) > > > Pascal wrote: >> >> Lew; >> We all miss our fellow builders who have perished in the last year. I >> would encourage you to read some of Tim's great articles on what he has >> done for his family in the plane these last couple of years >> http://www.myrv10.com/N104CD/index.html and remember people die every >> day; some doing what they enjoy, some while waiting for that day they >> would do something they wanted to do and some completely unexpectedly >> taking out the garbage they hated doing.. I too will go one day, I know >> where I'm going and I'm pretty excited about it, but in the meantime I >> want to do what I always wanted (build a plane) and if I die on my maiden >> flight, I'll be really bummed but I did it doing something I was excited >> about.. the few we have lost this last year perished doing what they >> loved.. >> I encourage you to think of all those trips to meet many of us at >> fly-in's, in Oregon for Van's open house, etc.. there is so much to get >> excited about with flying.. >> Pascal >> >> -------------------------------------------------- >> From: "Lew Gallagher" <lewgall(at)charter.net> >> Sent: Wednesday, April 23, 2008 1:25 PM >> To: >> Subject: RV10-List: Re: 210HM >> >>> >>> Thanks Tim, I never would have found it ... now I'm not sure I'm glad I >>> did. I still love building, but my curiosity about flying is waning. >>> Hopefully I'm just temporarily discouraged. What a loss. >>> >>> Here's Tim's unbroken link: >>> >>> http://www.ntsb.gov:80/ntsb/brief.asp?ev_id 080422X00528&key=1 >>> >>> Here's the address of the flight (you may have to copy and paste it): >>> >>> http://flightaware.com/live/flight_track_bigmap.rvt?ident=N210HM;airports=M54+KEUF;key d4df5c6845e46bcf7468a922905557f369ebd5;keytime=1208981350;height=340;width=400;departuretime=1207580400;arrivaltime=1207585140 >>> >>> Later, -Lew >>> >>> -------- >>> non-pilot >>> crazy about building >>> NOW OFICIALLY BUILDER #40549 >>> doors almost finished, pants on, WHEW! >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=178741#178741 >>> >>> > > > ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: Re: 210HM
Date: Apr 24, 2008
Tim, Thank you so much for taking the time to share the kind of wisdom all of us RVers need to hear (over and over again). I flew a Cessna 172 for years and did my instrument training in the 172. But moving up to a high performance plane - C182 was a whole new experience. IFR is demanding enough at 172 speeds but things happen really fast in a high performance plane - you have to be ready for this. Your advice to fly LOTS of hours before ending up in actual in a high performance RV10 can't be emphasized enough. John Testement jwt(at)roadmapscoaching.com 40321 N311RV Richmond, VA Painting Lew, Pascal, and all, Nothing I have to say is new at all, but I thought I'd share my feelings. To me, all things involve risk, so I don't really view the fact that it has risk as making the activity something I'm averse to. I've never been skydiving (REAL skydiving), but it drives me crazy to hear about people like my own brother in law, who would LOVE to go skydiving, but simply won't because his insurance wouldn't pay if he died. You're put on the earth to LIVE life, and to me, it's all about what you're passionate about...and fulfilling your dreams. There is a LOT you can do, in ANY activity, to increase your odds, but in almost ALL activities there is nothing you can do to guarantee your safety. So, you simply live life to it's fullest, enjoying the things you're passionate about....and you do what you can to minimize your risks. A couple days ago, I wanted to fill in the AOPA survey and the question "What do you think is the most significant deterrent to learning how to fly, besides cost?" I tell you, I was totally stumped. So I asked a co-worker, who's expressed interest, but never taken the plunge. She said "Probably fear, that they won't be able to control the plane, and that they'll hurt or kill themselves or someone else." I was stunned at first. I couldn't believe it. To me, I always had the passion, the dream, and the desire. The thought that I would not be able to do it safely never entered my mind. To me, if other people can fly planes, then because I WANT to fly planes so bad, I can fly planes. After pondering it for a while, I agreed with her and I filled in the survey. I just didn't realize that some people let their fears crush their passion like that, or perhaps their passion wasn't as overwhelming to quench their fears. So assuming that a person indeed has the passion in them to partake in flying, my feeling is that those that TRULY have that passion for excellence will also strive for developing the knowledge and skill required to do the flying they want to do. For me, one thing led to another and I yearned for more. I love the complexity, I love the challenge, I love flying in and out of IMC. I love the clear sky days, and I love the low drizzly days. But I also want to do it right, and be safe. I have a fear in me, developed from reading all of the negative examples that we have...."Aftermath"...."I learned about flying from that", and so on... I put myself in the cockpit when I read those stories, and I wonder... what would be the way to prevent that situation? There are many good people and good pilots who did some pretty not-so-hot things that led to their demise. I'm no better than them, but because they are my teacher, in some respect, I hope to use them as a source of guidance, and let them help me develop self-control. I don't want to have the same fate, so when I fly, I constantly analyze the safety of what I'm doing when I have those critical decisions, and I remind myself what the cost is if I fail. It's very humbling. But, the risk does not kill my desire...because I KNOW....there is no reason for me to meet the same fate....it's ALL IN MY HANDS. That leads me to re-tell a story. I had many good opportunities for instilling respect and fear into myself in actual IMC during my Instrument rating training. I genuinely was NOT ready, 20 hours into my training, to keep myself alive in IMC...and I knew that. But, I kept flying with my pals....all CFI's, in actual IMC and under the hood, to build confidence. Finally the day came...well after obtaining that ticket, for me to go fly in IMC on a perfect day. No reason, just was the perfect 700' overcast day to go test myself with, ... HA! ... that same risk-averse brother in law of mine. I climbed out into the clouds, and as soon as I was in IMC, I thought to myself "Man, did YOU do it now....Now you're stuck...and you can't get out of this with any help from anyone else...it's only YOU who can bring you both down alive and safe." I was genuinely fearful....but reminded myself that I knew what to do...it was only executing those things that I needed to do properly. The airplane was up to it, if only I was too. Obviously, it went just fine, or I'd not be here today. But, still to this day, when I'm entering the clouds, I have similar feelings, because I respect what I'm doing as "highly challenging" and important to do well. In reading the NTSB report, one cannot help to question the pilot(s). It's our nature. "Why didn't they just fly straight and level and get their bearings?" "Why didn't they just hit the ONE button on their Autopilot (assuming a TruTrak) that gives them instant heading and altitude hold?" "Why didn't they ask for vectors and just fly headings and vectors until they got to some better conditions?" They're gone, so it's not dishonoring them to ask....they're now our teachers. What is obvious is that mistakes were made. Now, for those who choose to fly in conditions like they were, it's your job to find out what mistakes, and NOT make them yourself. Remember them, and honor them by bringing your craft and crew home safe, every time. What can you do to help? Well, I for one, just did an early BFR and IPC yesterday. Nothing wrong with doing a AFR instead of a BFR right? (No, there is no such thing as an Annual Flight Review...but hey, it never hurts.) I want to make sure that not only am I legal on paper, but that someone else critiques me too. I don't WANT him to go easy on me. I did some things and he asked if I wanted ATP standards or normal. I chose ATP. I WANT to be tested. As Phil mentioned, you get rusty and more fearful if you don't fly often, so FLY OFTEN. This activity isn't for the occasional pilot...one who goes up for some touch and goes every 4 months. Stick with it... get some time every month, even if it's only an hour. Can you do that? I'm thinking that if you truly have the passion, you'll make it happen. Flying isn't for everyone...but anyone with the passion can make it work for them. The one thing that does concern me greatly is the number of ZERO time pilots that are building RV-10's. My CFII yesterday mentioned, when we discussed the 3 fatal RV-10 accidents, that we're very similar to the Cirrus trends, but we're very similar planes. He said the average Cirrus owner has something like 74 hours (unverified), and we both lamented at how shockingly inadequate (sorry, really, I am) that can be, for flying a plane with such performance. Sure, it flies slow if throttle back, but it's slippery, and it's light, and it demands respect. So, for those out there that are very low or zero time pilots, please, get in that plane with a CFI and put LOTS of time on it if you insist on flying an RV-10 right away. LOTS of time. You will never progress faster by any other means than if you put on a LOT of time over a short time span. If you can fly 200 hours in a year, you're going to retain a lot more skill for many years, than the guy who flies 20-45 hours a year. So look at it as an investment, and just fork over for the avgas and keep that plane in the air for a MINIMUM of 100 hours in the first year. The year I got my instrument ticket I put in 100+ hours, and it was my biggest year of skill growth ever...and it was the most retained, at that. My first year in my RV-10 I put on 200 hours. It's amazing how much comfort that brings you. So, if you truly have the passion, these accidents, and NTSB reports won't stun you and set you back. They'll make you think, and make you strive for more. And you'll still gladly jump in the plane and go for a flight, because you'll know that it CAN happen to you, but only if you don't get out there and develop good skills, and retain them. Anyone can fly a plane and bring it back to earth with everyone alive. You just have to NOT do the things that people do wrong....so learn from the others who paid the price for your lesson...and develop respect for flying and be safe. Tim Olson - RV-10 N104CD - Flying (sorry, I'll try for more brevity on the next few posts to make up for this one.) ;) Checked by AVG. 7:24 AM ________________________________________________________________________________
Date: Apr 24, 2008
Subject: Re: 210HM
In a message dated 4/23/2008 9:16:59 PM Central Daylight Time, Tim(at)MyRV10.com writes: Well, I for one, just did an early BFR and IPC yesterday. Nothing wrong with doing a AFR instead of a BFR right? The new climate in the FAA has gotten away from the term BFR they are now promoting a more professional approach to training as is done with ATP's...the new Wings program is trying to promote the idea that our training should be progressive learning and proficiency. Thus they are trying to instill that we should all be training, learning new or re-inforcing the basics. Not waiting for a check ride very 2 years. A PPL is just the begining ticket to a ride of learning. I don't know if you newer/non-pilot read Bob Miller electronic newsletter or visit AOPA Safety Foundation courses...both of these provide some great information. There are a number of other publications for pilots of all skill levels...whether it's IFR magazines or general aviation reading. Additionally there are a number of schools one can attend...my friend recently attended an aerobatics school so he's now more comfortable with stalls in all configurations and attitudes...something he feared before this training, now his confidence level has risen. The FAA's folks today believe as many instructors have said forever, get good instruction frequently and not rely on a minimal check ride every 24 months. Continue your learning with new skills either through progressive training in the new Wings program or obtaining a new rating or learning a new skill. A little anxiety is probably healthy. If you've been flying for a while, you've probably done some dum pilot tricks or been involved with situations...with good training and a bit of luck you've learned and grown to be a better pilot. Recently a student pilot lost and engine and landed the plane safely..the news asked if he was going to fly again...he said as soon as he could...now he's received some good training..hats off to his CFI and his good attitude. In golf, reading Jack's book, he say's that each spring he would approach his golf teacher, Jack Grout, hand him a club and ask him if he would teach him how to play golf. Not well or better but to teach him golf basics. As Tim said he's taking a progressive approach to his skill set and that's pretty good advise to all pilots, whether an ATP or a person wanting to learn...never stop learning. If you've learned everything there is to know about flying...QUIT...if not please venture on adding to the skills in your flight bag. Patrick **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Subject: n46007
Date: Apr 24, 2008
First flight was at 0600 this morning. Have one hour of recorded data from the GRT Sport system to review, Used the Cheltons for the first time; very easy to hand fly altitude and heading. ________________________________________________________________________________
Date: Apr 24, 2008
Subject: Re: 210HM
Lew, you've gotten some good advice in the last couple days. Let me add a couple items and make a plea. 1. If you want to build the 10 because you love building and feel flying is not your thing, then do it. Build an RV-10. A great bunch of folks are right there with you. You might have someone who knows flying help you decide on the final panel design, but other than that, it's pretty "simple" and fun. You won't be earning very big bucks at the end of the day, when it comes time to sell, but then you are doing it for the love of building, right? 2. If you want to fly, then I'd suggest starting now. I suggest going out to your favorite field and getting that first lesson, and I'd rather see you do it with the attitude that you're out to have fun. It doesn't matter too much which type of airplane, since the one's that you'll have available to you are all trainers. That is, they are designed to be as stable as possible, and not all that fast. I hope what you'll get from the lesson is that it is fun, it is doable, and that you'll want the second lesson. And the third and the forth and so on. 3. Then, assuming you love flying, I hope you'll spend more time, or at least as much time flying than building. I hope you take the advice of many on the list and get in that 100 or 200 hours and build those skills. But, even if it's the 50 hours most casual flyers can afford, in terms of time and coin, that's 50 more hours than you had before. Fifty more hours of experience leading up to the skills needed for the RV-10. 4. Finally, and this is for all those who lack high performance training, don't even think you can handle the RV-10 without high performance training and plenty of high performance time. The RV-10 is a great plane. Good handling. Good slow speed characteristics. Goes fast. But, it can get folks in trouble because things happen very quickly. The difference between flying a 172 and an RV-10 is not night and day. It's all the same stuff, almost. It just happens faster, so you have to know what you need to do before you need to do it. And that takes time and practice. Someone said there was a lot to learn going from a 172 to a 182. Heck, there's a lot to learn going from a 182 to an RV-10! But, you can go from a 172 to an RV-10, just do it with a CFI for many, many hours until both you and s/he feel you're ready. One analogy that I got from someone about moving up to the faster airplanes was what is often said by college athletes going into the pros, it's all the same, just that everything happens faster and the offensive and defensive schemes are more complex. You can learn it and do it, you just need to practice, practice, practice. In some senses I'm trying to make a very strong case for you to get in the air, and do it soon. You have what is good to have (besides the desire to fly), and that is a healthy bit of anxiety about flying. The faster you get in the air with a CFI (one that you feel comfortable with, don't forget you can audition these folks) helping you learn, the faster that anxiety will diminish and you'll find that this is a reasonable activity, one with so many upsides that the risks are worth it, especially if you manage them well. BUT, don't wait too long. Get going. It takes time, and there is a whole bunch of learning (and a whole bunch of fun) to be had before you will be ready for the RV-10, especially ready in a manner that you will find very enjoyable and exhilarating. Finally, you don't have to build an RV-10 to enjoy flying. You don't have to go fast to enjoy flying. You don't have to haul around 4 seats to enjoy flying. The RV-10, in fact, may not be the right first plane for you to build and fly. That is something that you need to think carefully about. It is, after all, a large commitment of time and coin. However, if you have the passion and you're enjoying the heck out of it, then do it! Just go get that license and build your time.... John Jessen 40328 (on hold while I'm enjoying flying my GlaStar, a very much slower plane than the RV-10, but a joy to fly!) ________________________________________________________________________________
Subject: Re: n46007
Date: Apr 24, 2008
Congratulations, David! Is KPRC in your fly-off area? John On Apr 24, 2008, at 8:25 AM, David McNeill wrote: > First flight was at 0600 this morning. Have one hour of recorded > data from the GRT Sport system to review, Used the Cheltons for the > first time; very easy to hand fly altitude and heading. > > ________________________________________________________________________________
Subject: n46007
Date: Apr 24, 2008
NO decided to go south for better emergency fields and cheaper gas. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Ackerman Sent: Thursday, April 24, 2008 9:33 AM Subject: Re: RV10-List: n46007 Congratulations, David! Is KPRC in your fly-off area? John On Apr 24, 2008, at 8:25 AM, David McNeill wrote: First flight was at 0600 this morning. Have one hour of recorded data from the GRT Sport system to review, Used the Cheltons for the first time; very easy to hand fly altitude and heading. ________________________________________________________________________________
Subject: Emailing: P3260023
Date: Apr 24, 2008
My daughter was happy to see me on the ground after the first flight of N46007. ________________________________________________________________________________
Date: Apr 24, 2008
Subject: Re: Emailing: P3260023
So THAT'S where Santa goes during his off-season! Either that, or Kenny Loggins likes to fly. -Jim 40384 David McNeill wrote: > > My daughter was happy to see me on the ground after the first flight of > N46007. > > > > > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Apr 24, 2008
Big Congratulations. Will have to come see your finished product before long, or if CHD is in your test area, feel free to drop over. On Thu, Apr 24, 2008 at 10:25 AM, David McNeill wrote: > > My daughter was happy to see me on the ground after the first flight of > N46007. > > ________________________________________________________________________________
Date: Apr 24, 2008
CHD is in the test area; will advise when I plan a stop there. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, April 24, 2008 12:15 PM Subject: Re: RV10-List: Emailing: P3260023 Big Congratulations. Will have to come see your finished product before long, or if CHD is in your test area, feel free to drop over. On Thu, Apr 24, 2008 at 10:25 AM, David McNeill wrote: > > My daughter was happy to see me on the ground after the first flight > of N46007. > > ________________________________________________________________________________
Subject: IO-540 arrived two months early- best way to move it?
Date: Apr 24, 2008
Got a bit of a surprise when the trucking company called from the front gate. I ordered one of Van's Lycoming IO-540 special deals at Sun and Fun just two weeks ago. Received a notice from Van's that it would arrive in mid-June. WRONG..... It's here today, literally 2 weeks later and I certainly hadn't expected it. Right now the box, as delivered, is sitting in the side yard covered with a tarp. Questions: 1. Could it just be left crated (long term storage already applied) and covered with a waterproof tarp? Eventually it has to be uncrated and moved down the side of my house over gravel. I planned on laying down some 4'x8' plywood to make a pathway. What's the best plan to move it? Buy an engine crane from Harbor Freight or similar? Rent a pallet jack? Take it out of the crate, put it on a dolly and roll it back? Any thoughts, comments or experience appreciated. Tom Hanaway Boynton Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179045#179045 ________________________________________________________________________________
Date: Apr 24, 2008
Buy or borrow an crane from Harbor freight you will need it again to hang the engine . Alternatively buy a Home Depot refer dolly ; holds 1000 pounds, move over plywood strip. Or you could ask 6 big friends to put the box on some thick plastic and slide over gravel. Just don't leave it outside as $35000 could "walk". -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway Sent: Thursday, April 24, 2008 4:02 PM Subject: RV10-List: IO-540 arrived two months early- best way to move it? Got a bit of a surprise when the trucking company called from the front gate. I ordered one of Van's Lycoming IO-540 special deals at Sun and Fun just two weeks ago. Received a notice from Van's that it would arrive in mid-June. WRONG..... It's here today, literally 2 weeks later and I certainly hadn't expected it. Right now the box, as delivered, is sitting in the side yard covered with a tarp. Questions: 1. Could it just be left crated (long term storage already applied) and covered with a waterproof tarp? Eventually it has to be uncrated and moved down the side of my house over gravel. I planned on laying down some 4'x8' plywood to make a pathway. What's the best plan to move it? Buy an engine crane from Harbor Freight or similar? Rent a pallet jack? Take it out of the crate, put it on a dolly and roll it back? Any thoughts, comments or experience appreciated. Tom Hanaway Boynton Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179045#179045 ________________________________________________________________________________
Date: Apr 24, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: I0 540 Arrived too early
Tom; I Left mine in the box and on the pallet. Jack it up enough and put some big casters under the pallet. What I did was attach the casters to a scrap 2x4, then attached the 2x4 under the ends of the pallet. Now you have the engine in it's foam case, still covered and can roll it anywhere you want. By the way, what was that address where you live?? Dr Fred 40515 paneling is fun. By the way to Tim O. Great write up the other day. You have a good way of writing down what a lot of us are not able to express. Keep flying, keep safe and keep pounding the rivets. ________________________________________________________________________________
Subject: Re: IO-540 arrived two months early- best way to move it?
Date: Apr 24, 2008
I would suggest getting an Auto Engine hoist from HF or somewhere else. I got a good deal at PepBoys. Use it to left the engine/pallet up so it can be placed on some type of dolly. Most of the engine hoists that I have seen don't have wheels that you can role very easily on anything but flat concrete. I would hate to have it lifted up and trying to role the hoist with metal wheels and hit a bump and it possibly tip on you. To much $$$ there to mess up. Once you have the palet on some type of dolly with larger wheels you can role it over your less than ideal surfaces to your final destination. As mentioned before, you will need the hoist later when you attach the engine to the mount. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179074#179074 ________________________________________________________________________________
Date: Apr 25, 2008
I moved mine onto a furniture dolly that I bought from HF. Moves around in my garage real well. If I were moving it outside, I would put it on 2 of the HF dollies ($15-19) in the crate. Leave it in the crate as it protects the unit from damage and rust or perforation of the visqueen covering. Use a jack or a couple of strong guys to lift onto the dollies. Boy is there any place to put it inside. I sure would not leave it outside. Heck - I would even buy a shed. Oh yea - watch those toes moving that heavy momma around. Could ruin your day -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179133#179133 ________________________________________________________________________________
Subject: Re: Perhaps a better fitting door when latched.
Date: Apr 25, 2008
Why are you not using the Rivethead door pins? Way better -------- OSH '08 or Bust Q/B Kit - Ready to exit cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179136#179136 ________________________________________________________________________________
From: "Doerr, Ray R [NTK]" <Ray.R.Doerr(at)sprint.com>
Date: Apr 25, 2008
Subject: Rudder Stop Sheared Off
During the process of getting my RV-10 ready for paint (Yes, I know it's been 2 years) I discovered that my Rudder was hitting the aft ski n of the Vertical Stab. After looking at it further, I notice one of my Ru dder Stops that are riveted to the top hinge half of the bottom hinge was m issing. The heads of the three AN470-4 rivets were still in the hinge half . A simply touch and they popped right out. Now I was thinking I was going to have to duplicate another sto p and rivet it on, but the hinge halves are quiet close together. Then it dawned on me that the Rudder stop may have fallen into the rudder bottom. Sure enough, that is where it was. The 3 rivets that hold this to the hing e were sheared off clean. The only thing I can think of is that when I was in Florida, my Tow Bar on the Rudder Pedals had gotten loose and allow the rudder to get slammed to the stop. No other damage found. So I thought about this for a while and thought this could like ly happen again if I don't change anything. So I decided to drill out the rivets to #28 and use #6 steel screws with stopnuts for both rudder stops. Hopefully the steel #6 screws will be much stronger in shear then the AN47 0-4 rivets. Thank You Ray Doerr N519RV (40250) Currently down for Paint ________________________________________________________________________________
Date: Apr 25, 2008
Subject: Re: Rudder Stop Sheared Off
Ray, This has happened to more than one person in the past. The last one was Scott Schmidt. He had some pretty high winds while he was tied down in Vegas that broke his rudder lock, and his rudder flapped and sheared the same rivets. I know I've heard of one or two others, as well. In fact, I think for one person it actually broke the rudder stop aluminum, but I'm not positive about that. So adding screws might not hurt, but you still may have the stop tabs break off. Either way, make sure you have a really good rudder gust lock: http://www.myrv10.com/tips/accessories/control_locks/index.html It may be that plastic won't do it for you, as depending on the design, high winds could snap the plastic tubes. I suppose if I wanted to toughen mine up, I could have glassed over the PVC, or done some work with strong aluminum tubing. Tim Doerr, Ray R [NTK] wrote: > During the process of getting my RV-10 ready for paint (Yes, > I know its been 2 years) I discovered that my Rudder was hitting the > aft skin of the Vertical Stab. After looking at it further, I notice > one of my Rudder Stops that are riveted to the top hinge half of the > bottom hinge was missing. The heads of the three AN470-4 rivets were > still in the hinge half. A simply touch and they popped right out. > > Now I was thinking I was going to have to duplicate another > stop and rivet it on, but the hinge halves are quiet close together. > Then it dawned on me that the Rudder stop may have fallen into the > rudder bottom. Sure enough, that is where it was. The 3 rivets that > hold this to the hinge were sheared off clean. The only thing I can > think of is that when I was in Florida, my Tow Bar on the Rudder Pedals > had gotten loose and allow the rudder to get slammed to the stop. No > other damage found. > > So I thought about this for a while and thought this could > likely happen again if I dont change anything. So I decided to drill > out the rivets to #28 and use #6 steel screws with stopnuts for both > rudder stops. Hopefully the steel #6 screws will be much stronger in > shear then the AN470-4 rivets. > > > > Thank You > *Ray Doerr* > > *N519RV (40250) Currently down for Paint* > > * ________________________________________________________________________________
Date: Apr 25, 2008
Same reason I am not using dual Cheltons, aftermarket, custom made cabin to p and fifteen thousand dollar, custom painted carbon prop and six bottom in finity grips. To each there own. After all, it is a consumer driven society . Van's original design is good enough, but needs modification and the plans in this section are not written very well, nothing I can't seem to use my h ead to figure out. The up grades for me need to stop someplace and I have chosen where they wi ll be used and I am comfortable with what Van's has provided, it just needs modification and correct installation...no door pins should have ever only gone into the plastic blocks and not into the metal fuse members. No fiber glass door should have ever been made so flimsy that it flexs in flight and allows a pin to pull out. Lastly, the lack of any of the above items are not going to prevent my plan e from doing its' mission, the one real important thing that I need to reme mber is that this is still a small plane in a big sky with atmospheric cond ition that sometimes are not condussive to flight. On those days it stays o n the ground. A leason learned in boating thirty to forty miles offshore in a twenty foot boat off the coast of Mexico and of course my cross country soaring. Don't underestimate mother nature. Yes, flying is like an addiction, but unlike an addiction, we don't need to step into our aircrafts at the beginning of our flights with glazed over e yes like zombies drawn to the gruel. That felling need to be reserved for a fter the plane is back on the ground. It's called afterglow and indeed, it can last for days and can even be rememberred years later. This is a post to cover a couple I never weighed in on. Elitist on his soapbox and now off. JG. > Subject: RV10-List: Re: Perhaps a better fitting door when latched.> From : Mikeabel(at)Pacbell.net> Date: Fri, 25 Apr 2008 07:50:57 -0700> To: rv10-lis bell.net>> > Why are you not using the Rivethead door pins? Way better> > - -------> OSH '08 or Bust> Q/B Kit - Ready to exit cabin top/door purgatory> > > > > Read this topic online here:> > http://forums.matronics.com/viewto =============> > > ________________________________________________________________________________
Subject: Thielert Troubles
Date: Apr 25, 2008
I realize this isn't exactly RV-10 specific but I found it interesting nonetheless. I wonder if they'll even have a tent at OSH this year... http://www.aopa.org/aircraft/articles/2008/080424thielert.html -Brian #40497 Iowa City, IA ________________________________________________________________________________
Subject:
Date: Apr 26, 2008
I posted a question to the wrong list yesterday regarding the Geared Drive system being offered with a corvette LS 1 engine by Bud Warren. It was on display at Sun n Fun and seems interesting. Interested in any comments by those with any experience. Look at the product at http://www.geareddrives.com/ Mark ________________________________________________________________________________
Subject: RE: LS1
Date: Apr 26, 2008
Hi Mark, I'm not a big fan of alternative engines, but the LS1 (combined with fuel prices) has opened my eyes. I'm still not sure if I'll put the LS1 in there or not, but I do know I'll at least consider it. Bud and I are members of the same EAA chapter (302). He's a great resource. Like I said, I'm still undecided. But there is a lot to like about the LS1 price, packaging, and options. Phil ________________________________ From: mark vultaggio [mailto:mvultaggio(at)hotmail.com] Sent: Saturday, April 26, 2008 1:25 PM Subject: RV10-List: I posted a question to the wrong list yesterday regarding the Geared Drive system being offered with a corvette LS 1 engine by Bud Warren. It was on display at Sun n Fun and seems interesting. Interested in any comments by those with any experience. Look at the product at http://www.geareddrives.com/ Mark ________________________________________________________________________________
Date: Apr 26, 2008
Thanks to all for the suggestions and humor. I was just taken by surprise as normally I've had a chance to plan for each step. Harbor freight (only 4 miles from my house) had a sale on the hoist of $147 and approx $26 for the load leveler. The engine is now sitting on a four-wheel dolly in the livingroom. VERY understanding wife and a straight shot back to the sliding glass doors of the workshop when it's time to put on:^) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179369#179369 ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Four New Email Lists At Matronics!!
Dear Listers, I have added four new Lists to the Matronics line up today. These include the following categories: Citabria-List Citabria, Decathlon, Scout, and Champ Zenith601-List Zenair Zodiac CH 601 Zenith640-List Zenair Zodiac CH 640 Zenith701801-List Zenair STOL CH 701 and CH 801 All services are enabled and now available including Search, Browse, Digest, Archives, Forums, Chat, etc., etc. etc...: Citabria: http://www.matronics.com/navigator?citabria-list Zenith601: http://www.matronics.com/navigator?zenith601-list Zenith640: http://www.matronics.com/navigator?zenith640-list Zenith701801: http://www.matronics.com/navigator?zenith701801-list To subscribe, go to the Matronics Email List Subscription Form: http://www.matronics.com/subscribe To check the new Lists out on the Matronics Forum go here: http://forums.matronics.com Enjoy the new Lists!! Don't forget me during the Fund Raiser! :-) Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: LS1
Date: Apr 26, 2008
Could this LS1 presentation at Sun-n-Fun be the phoenix of the link. http://www.vansairforce.com/community/showthread.php?p=4937 ________________________________________________________________________________
Subject: geared drive LS 1 engine
Date: Apr 27, 2008
Jesse, Thanks for the comments. I spoke with Bud at length at Sun n Fun and have some of the same sentiments as you. He is obviously a smart man and very experienced. I have known many people who are very confident to the point of cockiness. For some individuals, frustration, repetition and some level of genius often do not make for good salesmanship. My "problem" with the whole project is represented that there are no weak links or problems associated with the combination. I have been around long enough to know that all things in life come with trade offs. I have no problem dealing with potential weaknesses but would like to know what they are up front. When questions were asked they seemed to be partially answered and partially dismissed . I hope it is because the product is truly that good and the number of weak links are few. Time will tell. Several people asked bud about rebuilds, time intervals and costs. At approximately 5700.00 for a new crate engine, I would be inclined to run it for a reasonable time (whatever that proves to be) and then just sell the old engine to some hot rodder and buy a new one and get the piece of mind of another new unit. I wish I was technically competent with regard to aviation engines to know if the combination of the LS 1 engine and his drive unit and clutch eliminate the balance, harmonic, crankshaft loading issues that are present with aircraft. Certainly the money spent on designing and testing the LS 1 engine for automotive use was significant and the motor has proven itself for its original intended use. The package fits nicely in the -10 cowl (with minor mod) and the heating and air conditioning possibilities are nice bonuses. Limiting the power to Vans rec's would be easy enough if there was data available for the proper settings of the throttle. I wonder how "waterproof" the electronics are in the a/c environment and what could be done to add the necessary redundancies to put these up in the air safely. I should have paid more attention in school.... I am a fan of what Bud has done and very much want him to be a success. He is impressive with all of his racing and aviation knowledge and I wish I lived closer to Texas to keep tabs on his program ________________________________________________________________________________
Subject: 27 April...
Date: Apr 27, 2008
Rudy- After visiting the hangar this a.m., decided to first pursue the larger windshield. -The extended layer of DBM will make a "hump" on the inside. -It will be difficult to recreate straight and curved joggle edges. -The mess, both fibreglass goo and bondo dust... -I really, really, really don't want to mess with more gel coat to repair the new edges. At least those are the highlights. Thanks for the suggestion, but will save that as a back-up plan. I did go on an information-gathering field trip this noon. Stopped into a couple open hangars to inquire about the carb heat issue. Without exception, everyone agreed with you that I don't want or need ram air in this situation. So, you saved me from chopping another hole in the baffling. Too bad Young Eagles wasn't today -- awesome weather! Thanks again! -Scott ________________________________________________________________________________
Date: Apr 27, 2008
Subject: Section 40 Question - Flaps
Hi I thought I'd throw a building question into the mix. I have just installed the flap tubes per the plans. My question is how freely should they rotate? They seem a bit stiff and I can hear a bit of a rubbing sound as they move in the nylon blocks. It may also be that the center horn is rubbing a bit on the center tunnel walls. Any comments form those who have gone before? Inquiring minds need to know Les #40643 ________________________________________________________________________________
Date: Apr 27, 2008
Subject: Re: Section 40 Question - Flaps
Les, I had the same thing, I think it mainly has to do with the close tolerance the tube has in the nylon block and the small amount of misalignment that o ccurs across the sets of blocks. Try lossening the bolts and tighten slowly while moving the flap tube alternating from block to block. It does get be tter as you move the tube more and more. Rick Sked 40185 ----- Original Message ----- From: "Les Kearney" <kearney(at)shaw.ca> Sent: Sunday, April 27, 2008 4:38:03 PM (GMT-0800) America/Los_Angeles Subject: RV10-List: Section 40 Question - =C2-Flaps Hi I thought I=99d throw a building question into the mix. I have just installed the flap tubes per the plans. My question is how free ly should they rotate? They seem a bit stiff and I can hear a bit of a rubb ing sound as they move in the nylon blocks. It may also be that the center horn is rubbing a bit on the center tunnel walls. Any comments form those who have gone before? Inquiring minds need to know Les ============ ==== ======================= == ________________________________________________________________________________
Date: Apr 27, 2008
Hey Les, It's been awhile back, but I remember this same problem on our quick build fuse. I hadn't read anything about it, didn't like it, didn't ask anybody, and just enlarged the aluminum so that the flap tubes only touch nylon. Smooth as silk now. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179704#179704 ________________________________________________________________________________
Date: Apr 27, 2008
Mine were very tight also. Since they did move I just kept building. Once I got the flap motor in and they worked, I figured they were ok. Working fine after 30 hours. Rene' N423CF RV10 Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Sunday, April 27, 2008 5:38 PM Subject: RV10-List: Section 40 Question - Flaps Hi I thought I'd throw a building question into the mix. I have just installed the flap tubes per the plans. My question is how freely should they rotate? They seem a bit stiff and I can hear a bit of a rubbing sound as they move in the nylon blocks. It may also be that the center horn is rubbing a bit on the center tunnel walls. Any comments form those who have gone before? Inquiring minds need to know Les #40643 ________________________________________________________________________________
Subject: Re: It's another girl!
Date: Apr 28, 2008
Well, as long as we are on the baby topic - My wife Sharon gave birth April 2 to twin boys, Joshua and Caleb. We couldn't be happier. And, bringing it back to airplanes, the deciding factor in beginning the RV-10 last winter was knowing that in a few years we would be needing an airplane with significant load hauling capability! -------- Andy Turner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179859#179859 ________________________________________________________________________________
Date: Apr 28, 2008
The support gear required for two infants will tax the load carrying capabilities of even the rv-10.Welcome to the world of airplane carseats and tiny headsets! 728DD-27 mos -----Original Message-----????????????????????????????????? Katherine Scarlet Rore--17 mos From: Andy Turner <aturner(at)clarion.edu> Sent: Mon, 28 Apr 2008 11:00 am Subject: RV10-List: Re: It's another girl! Well, as long as we are on the baby topic - My wife Sharon gave birth April 2 to twin boys, Joshua and Caleb. We couldn't be happier. And, bringing it back to airplanes, the deciding factor in beginning the RV-10 last winter was knowing that in a few years we would be needing an airplane with significant load hauling capability! -------- Andy Turner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179859#179859 ________________________________________________________________________________
Date: Apr 28, 2008
Subject: Re: Thielert Troubles
I wonder how this will impact superior engines, since they are a subsidiary of Thielert. http://www.superiorengines.com/ Will be interesting to see what Deltahawk is up to. Perhaps opportunity again for UAV market with Thielert problems? ECI has been quiet about IO-540 plans. For those looking for options, there is UQM technologies and their powerphase 150 motor. http://www.uqm.com/products/specsheet.html. Downside is continuous power restrictions would get you only ~ 110 HP and current state of the art battery (LiON, including M3, etc) would keep you in the air for ~ 10-20 mins. Then it would be really quiet! :) Eric ----- Original Message ---- From: Brian Douglas <bsponcil(at)belinblank.org> Sent: Friday, April 25, 2008 1:04:02 PM Subject: RV10-List: Thielert Troubles I realize this isn't exactly RV-10 specific but I found it interesting nonetheless. I wonder if they'll even have a tent at OSH this year... http://www.aopa.org/aircraft/articles/2008/080424thielert.html -Brian #40497 Iowa City, IA ________________________________________________________________________________
Date: Apr 28, 2008
In a message dated 4/28/2008 2:51:23 PM Central Daylight Time, ericmpmail-rv10(at)yahoo.com writes: I wonder how this will impact superior engines, since they are a subsidiary of Thielert. _http://www.superiorengines.com/_ (http://www.superiorengines.com/) "Superior engines...Inferior financing".... **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 28, 2008
In a message dated 4/28/2008 2:51:23 PM Central Daylight Time, ericmpmail-rv10(at)yahoo.com writes: Will be interesting to see what Deltahawk is up to. Are they still tied up with the DOD on their programs? **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Subject: Re: Spins in a -10?
Date: Apr 28, 2008
Vans also spin tested one of their factory birds, with a spin chute. Write up is on their website under the RV-10 specific information. They too lived to tell the tale. -------- RV-10 #40333 N540XP (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179918#179918 ________________________________________________________________________________
Subject: It's another girl!
Date: Apr 29, 2008
From: "Patrick Pulis" <patrick.pulis(at)seagas.com.au>
Subject: flap speeds
Date: Apr 28, 2008
What flap extension speeds are being used? I see the full flap extension maximum speed is 85 kts. I have flown the 10 like my old C177RG. Approach flaps at 120 kts to begin slowing and further deployment at speeds below 90 kts indicated. Seems to work as an approach flap of 10 degrees begins the slowing process and no excessive forces seem to be experienced. What are others doing? ________________________________________________________________________________
Date: Apr 28, 2008
For a brief period I instructed spins in the Navy. Quite frankly, it's like practicing to bleed. Stall recovery training and avoidance of icing is what you need to know. If you are morbidly curious about what would happen, have you thought about spins in a 747? John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179994#179994 ________________________________________________________________________________
Subject: What is Vans working on now?
Date: Apr 29, 2008
With all the talk of more babies (congratulations Jesse & co), and now that the RV12 is completed, can anyone tell us what Vans design team is working on now? Will the RV14 be a high speed, 2 seat jet, or will it be an extended, 6 seat IO550 RV10+2 = RV14?, or even better from my point of view, a VTOL 6 seat jet?? Or how about underwing baby pods for the RV10??? Neil ________________________________________________________________________________
Subject: Sun visors
Date: Apr 29, 2008
To all those flying with sun visors, is there a brand you are happy or unhappy with? Any recommendations for mounting or a different size? Thanks. Jim Berry 40482 Finished with fiberglass Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180018#180018 ________________________________________________________________________________
Subject: Riveting Question
From: "Jon Reining" <jonathan.w.reining(at)wellsfargo.com>
Date: Apr 29, 2008
I was cruising through channels last night and saw something on the Discovery Channel that showed an airplane manufacturer riveting wings. They used a piece of masking tape over the head of their rivet gun. Why? Is it the "feel"? Does it make it more "non-slip"? Is it standard practice for everybody else in the world? Jon Reining (with dad Bill) 40514 - we'll finish off the wings some day Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180015#180015 ________________________________________________________________________________
Subject: Re: Riveting Question
Date: Apr 29, 2008
Jon It reduces scratching. One piece of tape is good for only a few rivets before it wears through. Jim Berry 40482 Finished with all fiberglass last week ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180017#180017 ________________________________________________________________________________
Subject: Re: What is Vans working on now?
Date: Apr 29, 2008
I'd like to see them finish the RV-11 motorglider. John #40262 ----- Original Message ----- From: Neil & Sarah Colliver To: rv10-list(at)matronics.com Sent: Monday, April 28, 2008 11:52 PM Subject: RV10-List: What is Vans working on now? With all the talk of more babies (congratulations Jesse & co), and now that the RV12 is completed, can anyone tell us what Vans design team is working on now? Will the RV14 be a high speed, 2 seat jet, or will it be an extended, 6 seat IO550 RV10+2 = RV14?, or even better from my point of view, a VTOL 6 seat jet?? Or how about underwing baby pods for the RV10??? Neil -- Checked by AVG. 4/28/2008 1:29 PM ________________________________________________________________________________
Date: Apr 29, 2008
I think it's called retirement. Given the decrease in the flying GA population, it may be called retrenchment. Of course, free market types might figure that there needs to be more innovation at Vans, not less. How about putting more ribs in the forward part of the HS for safety and the ability to withstand bird and the occasional, inevitable door strike. Or, how about a door that actually makes sense from a safety perspective. If a door is designed to be shed in flight when accidentally not closed, then maybe it's an innovation that enables the door to break away freely, soaring up and over the empennage. Perhaps little wings that pop out, creating the necessary, rapid lifting force. Or, if that's too difficult an engineering feat, maybe it's a door that, if not secured properly, actually cannot be ripped off, as the rest of the light airplane world has. Gee, that'd be a piece of OBVIOUS engineering. Sorry, but the more I think about this door thing, the more I cannot believe it actually was allowed to go to market. John Jessen 40328 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Monday, April 28, 2008 8:53 PM Subject: RV10-List: What is Vans working on now? With all the talk of more babies (congratulations Jesse & co), and now that the RV12 is completed, can anyone tell us what Vans design team is working on now? Will the RV14 be a high speed, 2 seat jet, or will it be an extended, 6 seat IO550 RV10+2 = RV14?, or even better from my point of view, a VTOL 6 seat jet?? Or how about underwing baby pods for the RV10??? Neil ________________________________________________________________________________
Date: Apr 29, 2008
Subject: Re: flap speeds
I asked Van's for clarification regarding the 2 degree flap setting. I was told that it does not have a speed limitation on it. I put the flaps to that position as I am entering the pattern or rolling out on final during an approach. As for the first and second real notches of flaps, I slow to below 87 kts before extending the flaps per Van's recommendations. I'm sure that there is a reason for that limitation. -Jim N312JE In a message dated 4/28/2008 11:03:33 P.M. Eastern Daylight Time, dlm46007(at)cox.net writes: What flap extension speeds are being used? I see the full flap extension maximum speed is 85 kts. I have flown the 10 like my old C177RG. Approach flaps at 120 kts to begin slowing and further deployment at speeds below 90 kts indicated. Seems to work as an approach flap of 10 degrees begins the slowing process and no excessive forces seem to be experienced. What are others doing? (http://www.matronics.com/Navigator?RV10-List) (http://www.matronics.com/contribution) **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 29, 2008
Does anyone have a .pdf that Van's supplies with the finishing kit describing the first flight as well as flap speeds? For me, it is 120 knots for the first, then below 90 knots for everything else. Typically it is 85 knots for the second notch, then 80 for the third. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: "JSMcGrew(at)aol.com" <JSMcGrew(at)aol.com> Sent: Tuesday, April 29, 2008 1:58:28 PM Subject: Re: RV10-List: flap speeds I asked Van's for clarification regarding the 2 degree flap setting. I was told that it does not have a speed limitation on it. I put the flaps to that position as I am entering the pattern or rolling out on final during an approach. As for the first and second real notches of flaps, I slow to below 87 kts before extending the flaps per Van's recommendations. I'm sure that there is a reason for that limitation. -Jim N312JE In a message dated 4/28/2008 11:03:33 P.M. Eastern Daylight Time, dlm46007(at)cox.net writes: What flap extension speeds are being used? I see the full flap extension maximum speed is 85 kts. I have flown the 10 like my old C177RG. Approach flaps at 120 kts to begin slowing and further deployment at speeds below 90 kts indicated. Seems to work as an approach flap of 10 degrees begins the slowing process and no excessive forces seem to be experienced. What are others doing? ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List .matronics.com/">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution ________________________________ Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. ________________________________________________________________________________
Date: Apr 29, 2008
Protects the skin a little from banging marks; might also keep it from slipping. Works fine. John J -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jon Reining Sent: Tuesday, April 29, 2008 8:36 AM Subject: RV10-List: Riveting Question --> I was cruising through channels last night and saw something on the Discovery Channel that showed an airplane manufacturer riveting wings. They used a piece of masking tape over the head of their rivet gun. Why? Is it the "feel"? Does it make it more "non-slip"? Is it standard practice for everybody else in the world? Jon Reining (with dad Bill) 40514 - we'll finish off the wings some day Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180015#180015 ________________________________________________________________________________
Date: Apr 29, 2008
Jon; I also used just regular scotch tape. I used it on the factory head side to hold the rivets in instead of rivet tape. Just fold over a edge so you can easily get it back off. Works just as good as the expensive rivet tape. Helps keep the scratches off the aluminum. Also, I used to polish the head of the rivet set on the scotch brite wheel. It also helps to cut down on scratches/poc marks. Fred Williams 40515. 90% finishing rule applies. ________________________________________________________________________________
Date: Apr 29, 2008
It also ends "smilies" on round head rivets. I find clear packaging tape to work best for both standard and flush rivet sets. Masking tape work for standard rivets but needs to be changed out more often. Carl Froehlich RV-8A (400 hrs) RV-10 (wings) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Tuesday, April 29, 2008 5:43 PM Subject: RE: RV10-List: Riveting Question Protects the skin a little from banging marks; might also keep it from slipping. Works fine. John J -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jon Reining Sent: Tuesday, April 29, 2008 8:36 AM Subject: RV10-List: Riveting Question --> I was cruising through channels last night and saw something on the Discovery Channel that showed an airplane manufacturer riveting wings. They used a piece of masking tape over the head of their rivet gun. Why? Is it the "feel"? Does it make it more "non-slip"? Is it standard practice for everybody else in the world? Jon Reining (with dad Bill) 40514 - we'll finish off the wings some day Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180015#180015 ________________________________________________________________________________
Subject: phase 1 testing
Date: Apr 29, 2008
Just a couple of tips for phase 1 testing. Select an area where there are plentiful off airport landing sites just in case; but most important select an area with cheaper fuel. my choices were to go north or south out of Phoenix. I chose south for both landing sites and fuel prices. I find myself refueling each day after 1-2 hours of flying for $100 +. Its also advisable to buy two cases of mineral oil for break-in; I just started using the second case. Also get your DAR to widen your fly off area if possible. driving back and forth across the area to maintain high power during break-in puts you at the boundary edge quickly. Fortunately to this point, the only known discrepancy is the prop governor is set too low; although take off MP is 28, maximum RPM is about 2520 so governor needs an adjustment. One other tip; the angle of the cowl is very steep; therefore what appears to be the view for level flight in the 10 seems like a very nose low attitude. This aircraft does not fly like other aircraft where the climb attitude view is nose slightly above the horizon; this one is decidedly nose low. Once I looked outside and concluded that I must be descending at a good rate but when checking the PFD, the aircraft had descended very little. When landing, look at the opposite end of the runway and look for things to get flat. Also be ready for the acceleration on take off along with the left turning tendency. Its like flooring your muscle car for the 0-60 ride. Much faster and stronger than any certified aircraft I have flown. Just some initial observations. 9 hours and 15 landings ________________________________________________________________________________
Date: Apr 29, 2008
Excellent and valuable information. Thanks Dave and gentle breezes as you land to refuel. John C. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Tuesday, April 29, 2008 5:07 PM Subject: RV10-List: phase 1 testing Just a couple of tips for phase 1 testing. Select an area where there are plentiful off airport landing sites just in case; but most important select an area with cheaper fuel. my choices were to go north or south out of Phoenix. I chose south for both landing sites and fuel prices. I find myself refueling each day after 1-2 hours of flying for $100 +. Its also advisable to buy two cases of mineral oil for break-in; I just started using the second case. Also get your DAR to widen your fly off area if possible. driving back and forth across the area to maintain high power during break-in puts you at the boundary edge quickly. Fortunately to this point, the only known discrepancy is the prop governor is set too low; although take off MP is 28, maximum RPM is about 2520 so governor needs an adjustment. One other tip; the angle of the cowl is very steep; therefore what appears to be the view for level flight in the 10 seems like a very nose low attitude. This aircraft does not fly like other aircraft where the climb attitude view is nose slightly above the horizon; this one is decidedly nose low. Once I looked outside and concluded that I must be descending at a good rate but when checking the PFD, the aircraft had descended very little. When landing, look at the opposite end of the runway and look for things to get flat. Also be ready for the acceleration on take off along with the left turning tendency. Its like flooring your muscle car for the 0-60 ride. Much faster and stronger than any certified aircraft I have flown. Just some initial observations. 9 hours and 15 landings ________________________________________________________________________________
Subject: Re: Sun visors
From: "Jim & Julie Wade" <jwade2163(at)bellsouth.net>
Date: Apr 30, 2008
Love my Rosen's!! Don't know how I flew without them. Had to where a hat all the time. Or use stickon shades. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180222#180222 ________________________________________________________________________________
Date: Apr 30, 2008
ncol(at)xtra.co.nz wrote: > With all the talk of more babies (congratulations Jesse & co), and now > that the RV12 is completed, can anyone tell us what Vans design team > is working on now? > > Will the RV14 be a high speed, 2 seat jet, or will it be an extended, > 6 seat IO550 RV10+2 = RV14?, or even better from my point of view, a > VTOL 6 seat jet?? > > Or how about underwing baby pods for the RV10??? > > > Neil The number that comes after 12 is 13, not 14.... [Wink] -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180256#180256 ________________________________________________________________________________
Date: Apr 30, 2008
What ever happened to the RV5? Where the RV1 and RV2 the original pitts and van's original modification? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180316#180316 ________________________________________________________________________________
Date: Apr 30, 2008
Funny you should ask. I looked at RV-1 about 10 days ago. RV-1 is located at Dunham Field, just NE of Houston and was the prototype RV built by Dick Vangrunsven. Oddly enough it's a fabric airplane with a little aluminum mixed in as well. :) She is not airworthy, but I'm sure the owner has plans to rebuild her sometime in the future. These photos are not mine, but they are Paul Dye's. Next time I'm out there, I can snap a few of my own if you'd like to see more. Phil -----Original Message----- From: Jon Reining [mailto:jonathan.w.reining(at)wellsfargo.com] Sent: Wednesday, April 30, 2008 1:12 PM Subject: RV10-List: Re: What is Vans working on now? --> What ever happened to the RV5? Where the RV1 and RV2 the original pitts and van's original modification? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180316#180316 ________________________________________________________________________________
Subject: Pre-OSH Pool Party
Date: Apr 30, 2008
For those of you planning to fly at odd altitudes to OSH, you might consider stopping by KIOW. A friend of mine owns a hotel adjacent to the airport and he hosts a pre-OSH party every year. Free food, free drink, etc etc. Last year there were quite a few RVs and even a couple of -10s in attendance. Anyway, he asked that I post this to the list: http://www.alexisparkinn.com/iowa_city_pool_party.htm -Brian #40497 Iowa City, IA ________________________________________________________________________________
Date: Apr 30, 2008
Here's a few more notes I found on VAF regarding the airplane. It was ground looped in a stiff crosswind a year or two ago. (Dunham Field is an East/West Runway with a couple of large holes in the trees to funnel the winds. Not a good combination in SE Texas.) Damage was sustained to the main landing gear, cowling, and belly skin. Mixed into that was a prop-strike. Van apparently created an experimental prop from a Sensnich that was cut down and severely re-pitched. Apparently they can't get a prop-shop to touch it, so they're looking for alternatives. So it sounds like they've got some real intentions to make her fly again. Phil -----Original Message----- From: Perry, Phil Sent: Wednesday, April 30, 2008 2:06 PM Subject: RE: RV10-List: Re: What is Vans working on now? Funny you should ask. I looked at RV-1 about 10 days ago. RV-1 is located at Dunham Field, just NE of Houston and was the prototype RV built by Dick Vangrunsven. Oddly enough it's a fabric airplane with a little aluminum mixed in as well. :) She is not airworthy, but I'm sure the owner has plans to rebuild her sometime in the future. These photos are not mine, but they are Paul Dye's. Next time I'm out there, I can snap a few of my own if you'd like to see more. Phil -----Original Message----- From: Jon Reining [mailto:jonathan.w.reining(at)wellsfargo.com] Sent: Wednesday, April 30, 2008 1:12 PM Subject: RV10-List: Re: What is Vans working on now? --> What ever happened to the RV5? Where the RV1 and RV2 the original pitts and van's original modification? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180316#180316 ________________________________________________________________________________
Subject: Re: Pre-OSH Pool Party
Date: Apr 30, 2008
As another Cherokee owner and member of CPA, I can state that Jay has a great aviation themed hotel. He also hosts an event in the North Forty as well. > > From: "Brian Douglas" <bsponcil(at)belinblank.org> > Date: 2008/04/30 Wed PM 02:09:56 EST > To: > Subject: RV10-List: Pre-OSH Pool Party > > For those of you planning to fly at odd altitudes to OSH, you might consider stopping by KIOW. A friend of mine owns a hotel adjacent to the airport and he hosts a pre-OSH party every year. Free food, free drink, etc etc. Last year there were quite a few RVs and even a couple of -10s in attendance. Anyway, he asked that I post this to the list: > > http://www.alexisparkinn.com/iowa_city_pool_party.htm > > > -Brian > > #40497 > Iowa City, IA > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: May 01, 2008
Subject: Autocad format RV-10 line drawings?
Anyone have line drawings of the RV-10 in AutoCAD? My buddy I'm working with on the paint scheme was wondering if he could get some in that format. I already gave him the regular jpg versions that are out there. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Wednesday, April 30, 2008 9:57 AM Subject: RV10-List: Re: What is Vans working on now? ncol(at)xtra.co.nz wrote: > With all the talk of more babies (congratulations Jesse & co), and now > that the RV12 is completed, can anyone tell us what Vans design team > is working on now? > > Will the RV14 be a high speed, 2 seat jet, or will it be an extended, > 6 seat IO550 RV10+2 = RV14?, or even better from my point of view, a > VTOL 6 seat jet?? > > Or how about underwing baby pods for the RV10??? > > > Neil The number that comes after 12 is 13, not 14.... [Wink] -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180256#180256 ________________________________________________________________________________
Subject: Compliments to customer service at Lycoming-Skytech starter
Date: May 01, 2008
Recently some discussion went on about the Skytech starter and IO-540's. I am also aware of some history of Lycoming service issues. I previously wrote: "Ok, I've got a dog in this fight since I just ordered an IO-540 from Van's as part of their promotion. The Van's Lycoming engine comes with the LS starter on the crated engine. Since it's part of the OEM contract with Van's, it can't be changed. If you're ordering from an after market builder, you can specify the NL. I then spoke to the tech at Sky-Tech. The LS has a higher current draw than the NL and may not turn over the engine IF you've done a shoddy wiring job. The NL is recommended for that reason. As to kickback, that can happen depending on settings of a magneto. In my case, I plan to go with PMags for both. Skytech advised that they worked specifically with the PMag system guys to ensure that a kickback won't happen. Bottom line-Skytech changed the recommendation from LS to NL based on several engines having slow turnover due to restrictive wiring or low battery power. So I'll stay with the LS unless I do have a problem. If I was starting from scratch on the engine, I'd get the NL. Subsequently, based on my phone call to Lycoming and Lycoming's follow up discussions with Skytech, Lycoming sent me a new Skytech NL starter at no additional charge, asking only that I return the unused LS starter to them. Thank you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180539#180539 ________________________________________________________________________________
Date: May 01, 2008
Subject: Re: Compliments to customer service at Lycoming-Skytech starter
tomhanaway wrote: > >Recently some discussion went on about the Skytech starter and IO-540's. >I am also aware of some history of Lycoming service issues. > > > SNIP >Subsequently, based on my phone call to Lycoming and Lycoming's follow up discussions with Skytech, Lycoming sent me a new Skytech NL starter at no additional charge, asking only that I return the unused LS starter to them. >Thank you. > Would you share the contact info with Lycoming??? I know Vans has sold a whole lot of engines during their SNF sale ..... mine too ...... and there'll be a whole lot of folks looking to do the trade. Linn > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=180539#180539 > > > > ________________________________________________________________________________
Date: May 01, 2008
On my Vans certified IO540 the first touch of the starter relay only moves it about a half a blade; but the second try spins it like a top. Same problem and same solution for the Glastar as well. I am using Odyssey 680s. Wire 002 crimped and soldered. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway Sent: Thursday, May 01, 2008 12:20 PM Subject: RV10-List: Compliments to customer service at Lycoming-Skytech starter Recently some discussion went on about the Skytech starter and IO-540's. I am also aware of some history of Lycoming service issues. I previously wrote: "Ok, I've got a dog in this fight since I just ordered an IO-540 from Van's as part of their promotion. The Van's Lycoming engine comes with the LS starter on the crated engine. Since it's part of the OEM contract with Van's, it can't be changed. If you're ordering from an after market builder, you can specify the NL. I then spoke to the tech at Sky-Tech. The LS has a higher current draw than the NL and may not turn over the engine IF you've done a shoddy wiring job. The NL is recommended for that reason. As to kickback, that can happen depending on settings of a magneto. In my case, I plan to go with PMags for both. Skytech advised that they worked specifically with the PMag system guys to ensure that a kickback won't happen. Bottom line-Skytech changed the recommendation from LS to NL based on several engines having slow turnover due to restrictive wiring or low battery power. So I'll stay with the LS unless I do have a problem. If I was starting from scratch on the engine, I'd get the NL. Subsequently, based on my phone call to Lycoming and Lycoming's follow up discussions with Skytech, Lycoming sent me a new Skytech NL starter at no additional charge, asking only that I return the unused LS starter to them. Thank you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180539#180539 ________________________________________________________________________________
Subject: Phase 1 update
Date: May 01, 2008
Now at 12.4 hours and 21 landings including some gusting crosswinds. Oil consumption is beginning to stabilize. Of the 13 quarts poured into the engine at this point nine are still showing on the oil stick. considering the oil filter , this is a consumption of 3-4 quarts during this past week of flying. During the last two days of flights, consumption has been about half a quart (over 3.5 flight hours). CHTs with full rich mixture have been 340-360 for cylinders 2,3,4,5. CHT for 6 is 360-390. and cylinder 1 has been as high as 433 for a short period during the climb. It then settled 395-405. Recently the temperatures have not stayed as high as long and I have been able to lean fuel flow so that EGTs are approx 1350F. Full rich EGTs will be approx. 1200+. Considerable right rudder required during takeoff and climb. Some still required at cruise. After phase I , I will place a fixed tab on the rudder to compensate during cruise. At this point , I don't' know whether rudder trim would be worthwhile. I plan to re evaluate after painting and rebalancing of the ailerons. (My Glastar had a distinct desire to turn right as speed increased but after painting and a balancing of the ailerons to the nearest gram the tendency went away). The digiflie II autopilot works fine with Cheltons in the basic GPSS track mode with altitude hold. It does not work with VNAV at all. I am told I need the 2.24 software versus the 2.2 that I have installed. I will get that during paint. On the other hand instrument approaches with the VNAV and HITS are very easy to hand fly. A series of skyway boxes take the pilot through the intermediate fixes and to the missed approach point. If a miss is necessary the boxes lead the way back to the missed approach hold. Next on the agenda is some slow flight and stall to see how slow we can reasonably fly this thing on landings. On Alex's advice I started at 80 kts on final and have worked down to 70-75 on short final. I noticed that today the Chelton indicated just under 60 kts about the time of touchdown. Be advised also that the low wing provides a good ground effect and any excess speed will use lots of runway. If your initial test runway is less than 3000 feet you might want to consider first flight elsewhere; additionally fire rescue, if needed, would be nice. FFZ has 5200 feet paved and onsite fire rescue; thankfully they were not needed. One other thing, the fuel caps as supplied by Van's QB had a little residue on one of them ; also a little nick , at any rate after filling the tank a small venting of fuel occurs after takeoff. It tends to go away at cruise. I have switched sides for the caps to determine whether the problem follows the cap. More later. ________________________________________________________________________________
Subject: engine mounts
Date: May 01, 2008
Anyone use anything different than Vans Engine mounts--ie Lord mounts?? thanks larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180582#180582 ________________________________________________________________________________
Date: May 01, 2008
Scott take a look at my airspeed indicator from vans for the 10. It shows the speeds you are looking for. Randy 40006 http://www.myrv10.com/N610RV/20050328/DSCN4452.html ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Tuesday, April 29, 2008 2:37 PM Subject: [SPAM?] Re: RV10-List: flap speeds Importance: Low Does anyone have a .pdf that Van's supplies with the finishing kit describing the first flight as well as flap speeds? For me, it is 120 knots for the first, then below 90 knots for everything else. Typically it is 85 knots for the second notch, then 80 for the third. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: "JSMcGrew(at)aol.com" <JSMcGrew(at)aol.com> Sent: Tuesday, April 29, 2008 1:58:28 PM Subject: Re: RV10-List: flap speeds I asked Van's for clarification regarding the 2 degree flap setting. I was told that it does not have a speed limitation on it. I put the flaps to that position as I am entering the pattern or rolling out on final during an approach. As for the first and second real notches of flaps, I slow to below 87 kts before extending the flaps per Van's recommendations. I'm sure that there is a reason for that limitation. -Jim N312JE In a message dated 4/28/2008 11:03:33 P.M. Eastern Daylight Time, dlm46007(at)cox.net writes: What flap extension speeds are being used? I see the full flap extension maximum speed is 85 kts. I have flown the 10 like my old C177RG. Approach flaps at 120 kts to begin slowing and further deployment at speeds below 90 kts indicated. Seems to work as an approach flap of 10 degrees begins the slowing process and no excessive forces seem to be experienced. What are others doing? ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m /Navigator?RV10-List .matronics.com/">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution ________________________________ Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos <http://autos.aol.com/used?NCID=aolcmp00300000002851> . ________________________________________________________________________________
Date: May 01, 2008
Subject: Re: Autocad format RV-10 line drawings?
You can get it from Van's web site. <http://www.vansaircraft.com/public/downloads.htm> Larry Rosen RV Builder (Michael Sausen) wrote: > > Anyone have line drawings of the RV-10 in AutoCAD? My buddy I'm working with on the paint scheme was wondering if he could get some in that format. I already gave him the regular jpg versions that are out there. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman > Sent: Wednesday, April 30, 2008 9:57 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: What is Vans working on now? > > > ncol(at)xtra.co.nz wrote: > >> With all the talk of more babies (congratulations Jesse & co), and now >> that the RV12 is completed, can anyone tell us what Vans design team >> is working on now? >> >> Will the RV14 be a high speed, 2 seat jet, or will it be an extended, >> 6 seat IO550 RV10+2 = RV14?, or even better from my point of view, a >> VTOL 6 seat jet?? >> >> Or how about underwing baby pods for the RV10??? >> >> >> Neil >> > > > The number that comes after 12 is 13, not 14.... [Wink] > > -------- > #40572 QB Fuselage, wings finished > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=180256#180256 > > > ________________________________________________________________________________
Subject: Re: Phase 1 update
Date: May 01, 2008
Damon, Ten quarts seems high for an IO540. Dose that include what went to your inverted oil system? Jim Berry 40482 25 years in a Pitts S1S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180619#180619 ________________________________________________________________________________
Date: May 01, 2008
10 Builders, David We are at similar stages of test flying. I have about 8 hours now, also with Cheltons. I am using 6.0B and a Trutrak Digiflight II with GPS lateral and vertical steering. I have seen nearly identical airframe numbers that you and others have reported and really enjoy the low speed handling qualities. We've done multiple stalls in all configs and lots of slow flight. With the cg at about 20% of the range it is difficult to get a stall break with full flaps. The indicated stall airspeeds are within a couple of knots of Van's numbers. For initial test flying at what will probably be forward cgs, 50 flap landings are more comfortable than full flap. The launch on takeoff (1620 lbs bow, no interior or paint, 50 lbs of ballast in bag compartment) is fun too. I had an issue with unreliable winds and track on the Chelton initially. Successful alighnment and swing calibration seems to have cured that and today it nailed an automatic GPS approach. I am finding the same thing as others have mentioned with the oil quantity. It seems to be happy at about 9 qts; we've added one so far. One caution, the temtation during the initial flights particularly with advanced avionics is to spend too much time looking inside the cockpit. I am trying hard to limit the "inside" viewing and verifing the avionics in small easily managed steps rather than getting wrapped up "what's it doing now" problems. I found that dividing the test flights into half aerodynamics or perfomance tests and half avionics tests provides a nice mix. From a perfomance standpoint (other than no aerobatics) this airplane is every bit as much fun to fly as the RV4 was. I am amazed that a cross country cruiser can be this responsive and fun to fly. For everyone slogging through the never ending finishing phase, don't give up you are going to love this airplane. Dick Sipp RV10 110DV flying ________________________________________________________________________________
Date: May 01, 2008
inside and outside time is a problem. I plan to fly off the phase one hours and get my flying partner in the iarplane. I can give him his dual and we can then do some of the inflight checks I would normally do. I have concentrated on high power settings to break in the engone and confirming reliability of systems. My date with the painter is May 25. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Sipp Sent: Thursday, May 01, 2008 7:48 PM Subject: Re: RV10-List: Phase 1 update 10 Builders, David We are at similar stages of test flying. I have about 8 hours now, also with Cheltons. I am using 6.0B and a Trutrak Digiflight II with GPS lateral and vertical steering. I have seen nearly identical airframe numbers that you and others have reported and really enjoy the low speed handling qualities. We've done multiple stalls in all configs and lots of slow flight. With the cg at about 20% of the range it is difficult to get a stall break with full flaps. The indicated stall airspeeds are within a couple of knots of Van's numbers. For initial test flying at what will probably be forward cgs, 50 flap landings are more comfortable than full flap. The launch on takeoff (1620 lbs bow, no interior or paint, 50 lbs of ballast in bag compartment) is fun too. I had an issue with unreliable winds and track on the Chelton initially. Successful alighnment and swing calibration seems to have cured that and today it nailed an automatic GPS approach. I am finding the same thing as others have mentioned with the oil quantity. It seems to be happy at about 9 qts; we've added one so far. One caution, the temtation during the initial flights particularly with advanced avionics is to spend too much time looking inside the cockpit. I am trying hard to limit the "inside" viewing and verifing the avionics in small easily managed steps rather than getting wrapped up "what's it doing now" problems. I found that dividing the test flights into half aerodynamics or perfomance tests and half avionics tests provides a nice mix. >From a perfomance standpoint (other than no aerobatics) this airplane is every bit as much fun to fly as the RV4 was. I am amazed that a cross country cruiser can be this responsive and fun to fly. For everyone slogging through the never ending finishing phase, don't give up you are going to love this airplane. Dick Sipp RV10 110DV flying ________________________________________________________________________________
Date: May 02, 2008
Hey Jim, I don't believe so, the oil seemed to settle in at the ten qt amount, unless I was doing a lot of inverted or negative g stuff, and then it would drop below 10 pretty quickly. Anything more than ten would blow off very quickly. The Pitts had the same horsepower as the RV, the Extra was a 300hp version. I don't know if there are any other differences. Damon On May 1, 2008, at 10:36 PM, jim berry wrote: > > Damon, > > Ten quarts seems high for an IO540. Dose that include what went to > your inverted oil system? > > Jim Berry > 40482 > 25 years in a Pitts S1S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=180619#180619 > > ________________________________________________________________________________
Date: May 02, 2008
scottmschmidt(at)yahoo.co wrote: > Does anyone have a .pdf that Van's supplies with the finishing kit describing the first flight as well as flap speeds? > For me, it is 120 knots for the first, then below 90 knots for everything else. > Typically it is 85 knots for the second notch, then 80 for the third. > > Scott Schmidt > scottmschmidt(at)yahoo.com > --- Have you checked Van's FAQ's 'Airspeed Indicator Markings' page? http://www.vansaircraft.com/pdf/speeds.pdf It lists all the RV's airspeed indicator markings. -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180649#180649 ________________________________________________________________________________
Date: May 02, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Trutrak autopilots
I need a little advice from those who are IFR rated and flying. Unfortunately, my panel shop, Accuracy avionics just went belly up this am. (I wouldn't advise sending them any more checks) I've been stiffed out of an autopilot that I still haven't received yet. Now that I get to pay double for it, I'm reconsidering how may features I need. I planned on a Trutrak digiflight IIVSGV. I would like to know how often one needs the vertical GPS steering feature. Does it help eliminate setting your power and trim for a climb/descent? I have minimal IFR training, but doesn't one set up basically a table with power settings to see what your airplane will do to get say a 500 ft/min descent? Looks like I could save about $400-500 by not getting that feature. Little miffed this am...... Trying to regain composure and just fly the airplane....... Thanks in advance for the replies. Dr Fred 40515 Now in panel assembly hell. ________________________________________________________________________________
Subject: OSH
Date: May 02, 2008
Do we have a pliminary count of RV10s at OSH this year? I have been talking to EAA OSH to determine where they plan to park RVs or whether it is just HBP out west of 18-36. My concern is my visit is always first IFR in on Thursday AM and first IFR out on Sun AM. Getting to the active without flagman or assistance is paramount. I believe Claude and I will tent camp in Scholler with the rest of the 10 crowd. ________________________________________________________________________________
Date: May 02, 2008
Subject: Re: Overhead Console?
The Flightline A/C guy/s http://flightlineac.com/home have one that they sell/include with their air conditioning system. when I spoke to John Strain some time ago he said they would sell the Ohead separate. It's basically a knock-off of the Accuracy. But, beware, They are ALSO located in BEND ! Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chase Snodgrass wrote: > > On 5/2/08, Fred Williams, M.D. wrote: "Accuracy avionics just went > belly up this am. (I wouldn't advise sending them any more checks)" > > Dang! Is there any other source for the overhead console? > > ________________________________________________________________________________
Subject: Overhead Console?
Date: May 02, 2008
As I was (and am) the guy who connected Ed Hayden and John Strain together for the first A/C unit for the RV-10, you can be assured that my cousins Vinny and Guido will visit him if he tries such a sophomoric stunt. Fortunately he has very little time on the shop floor at Lancair (Redmond), where those fumes might permeate. The Oregon Department of Aviation Board is meeting in Bend on May 21st and I will make a point of putting the issue on their agenda for discussion - formally. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, May 02, 2008 9:58 AM Subject: Re: RV10-List: Overhead Console? The Flightline A/C guy/s http://flightlineac.com/home have one that they sell/include with their air conditioning system. when I spoke to John Strain some time ago he said they would sell the Ohead separate. It's basically a knock-off of the Accuracy. But, beware, They are ALSO located in BEND ! Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chase Snodgrass wrote: > > On 5/2/08, Fred Williams, M.D. wrote: "Accuracy avionics just went > belly up this am. (I wouldn't advise sending them any more checks)" > > Dang! Is there any other source for the overhead console? > > ________________________________________________________________________________
Date: May 02, 2008
Fred, Deems, and RV10 gang, John from Flightline AC, Inc here, Yes we are in Bend, but so is Precise Flight, EI, Mountain High, Cessna, Epic, Advanced Aviation, RDD, Fibercrafters, LancAir, Snowline and a whole bunch of others who are very viable companies and who still lead the way in experimental and certified aircraft development. Bend isn't a curse, but there have been some businesses that for various reasons haven't made it. Now to your solution.... We do offer our overhead (completely different than the Advanced Avionics) separately or included in our air conditioning kit. Ours is designed to be integral and bonded into the canopy. We have one more of our prototype unit, and several of our latest design boxed and ready to go. The prototype unit is the same as the one that is now offered by Saint Aviation. We will sell our last one for $395.00. I am not sure what Jesse will be selling theirs for, but it is from the same mold. He has one installed in Steve's newly repainted 10 and it really looked good at SnF with the leather interior. Our latest design is a 2 piece for easier installation and less expensive shipping. It sells for $595.00 or can be included in an ac kit. As far as designed for delivering air throughout the cabin, the Flightline 1 (aka by us as the one offered by Saint Aviation) and the Flightline 2 offered by us are the best in the industry. Neither have DVD or clothes hanger racks in them, but could be added if someone spent a little time on the design and glass work. Thanks for the plug???? Deems, you really ought to visit here before we all end up having to come stay with your because of the hard times that Bend has dealt us. It really is a great place and the aviation community is very strong and active here. John John N. Strain II Flightline AC, Inc P.O. Box 5309 Bend, Or 97708 541-815-8935 Cell 541-330-5466 Office 541-312-4257 Fax john(at)flightlineac.com www.flightlineac.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, May 02, 2008 9:58 AM Subject: Re: RV10-List: Overhead Console? The Flightline A/C guy/s http://flightlineac.com/home have one that they sell/include with their air conditioning system. when I spoke to John Strain some time ago he said they would sell the Ohead separate. It's basically a knock-off of the Accuracy. But, beware, They are ALSO located in BEND ! Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chase Snodgrass wrote: > > On 5/2/08, Fred Williams, M.D. wrote: "Accuracy avionics just went > belly up this am. (I wouldn't advise sending them any more checks)" > > Dang! Is there any other source for the overhead console? > > ________________________________________________________________________________
Subject: It's Official!
Date: May 02, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Just finished up with the DAR and #40105 is now N442PM in every respect! No squawks found during the inspection, just have to put everything back together... First flight will wait until weather conditions locally improve a bit. Bob ________________________________________________________________________________
Date: May 02, 2008
John, I wouldn't copy the Accuracy OH console directly - fit is poor as it was delivered. With some misc cutting/fitting/filling it looks great, but it somebody was making a mold I wouldn't consider them ideal. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180778#180778 ________________________________________________________________________________
Date: May 02, 2008
I know that Tony just rework the console recently. I wonder if anyone has received one of the new ones and if they fit any better. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bcondrey Sent: Friday, May 02, 2008 3:56 PM Subject: RV10-List: Re: Overhead Console? John, I wouldn't copy the Accuracy OH console directly - fit is poor as it was delivered. With some misc cutting/fitting/filling it looks great, but it somebody was making a mold I wouldn't consider them ideal. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180778#180778 ________________________________________________________________________________
Date: May 02, 2008
Great news! Looking forward to seeing you, Susan, and N442PM at OSH. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Friday, May 02, 2008 3:38 PM Subject: RV10-List: It's Official! Just finished up with the DAR and #40105 is now N442PM in every respect! No squawks found during the inspection, just have to put everything back together. First flight will wait until weather conditions locally improve a bit. Bob ________________________________________________________________________________
Subject: Garmin Rapair - Customer Beware
Date: May 02, 2008
Short story: if Garmin replaces a light bulb in your unit, it's $800. I wa s totally unaware but you can find the verbage in their warranty online. I was expecting someone to call first. Long story: Lost the transmitter on my comm radio on the 430 on the way bac k from SNF, reception was fine. Trouble shooting showed transmitter output was a whopping 1.5W and very noisy after the initial 3 second ouput of 37W You can hear something like a relay within the unit kicking in right pri or to going from 37W to 1.5W. Great, the radio is protected. Something si mple is wrong. My 430 has 130hrs on it. 2-year warranty started on purcha se date so that expired about 7 months after first flight. Sent the unit to Garmin through a dealer (can't send it directly to them). Turn around time was quick - confirmed my suspecion that it was a simple f ix. I was impressed. The damage - $875. My eye balls almost jumped out o f their sockets. After researching a bit I realized that I'm not the first unhappy customer. Garmin has a flat repair rate of $800 for the 430, incl uding shipping (thank goodness!! I wonder why my bill was $875?). They gua rantee complete overhaul if they so deem the unit needs it. This includes cosmetics like worn out buttons or anything they see that's not up to par. Quote from the Service Report "Confirmed problem. Repaired the COMM board to correct the discrepancy. Updated software." Garmin's repair records d oes not contain any more details than this. When asked if cosmetic works we re done to my unit, the answer.... no. I would've been surprised if there was any on such a low time unit. Sounds to me that Garmin has a good marketing strategy to keep all units in service at tip top overhauled shape at the expense of the customers. By th e way, the dealer wasn't aware of this flat rate policy. So what's the chance of something majorly wrong with my 430 would happen to get a good $800 deal? Considering the cost of a new unit, a quick statist ical calculation +/- a bunch% error says that you'll never make out ahead w ith this deal. Google what others have to say regarding Garmin's customer support and see for yourself. I don't mind supporting a good product but t his feels like a log going through my rear end. Anh N591VU-flying ________________________________________________________________________________
Date: May 02, 2008
Subject: Re: Trutrak autopilots
What really bothers me is I have my panel from Accuracy, one of their first. I gave out glowing recommendations for their quality and service because that was my experience. I have not heard from Tony or Eric and this came as a complete surprise to me after talking to them at Sun n Fun. If anyone has suffered a loss as a result of my recommendation for Accuracy, please understand that I had a very good experience with them, if I hadn't, those that know me would tell you I usually don't hold any punches when it comes to service, value and other traits we hold close. Rick Sked 40185 ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Friday, May 2, 2008 8:08:29 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Trutrak autopilots I need a little advice from those who are IFR rated and flying. Unfortunately, my panel shop, Accuracy avionics just went belly up this am. (I wouldn't advise sending them any more checks) I've been stiffed out of an autopilot that I still haven't received yet. Now that I get to pay double for it, I'm reconsidering how may features I need. I planned on a Trutrak digiflight IIVSGV. I would like to know how often one needs the vertical GPS steering feature. Does it help eliminate setting your power and trim for a climb/descent? I have minimal IFR training, but doesn't one set up basically a table with power settings to see what your airplane will do to get say a 500 ft/min descent? Looks like I could save about $400-500 by not getting that feature. Little miffed this am...... Trying to regain composure and just fly the airplane....... Thanks in advance for the replies. Dr Fred 40515 Now in panel assembly hell. ________________________________________________________________________________
Date: May 02, 2008
PS- Fred, I know e have chatted about assembling your panel.....If I can help you sort out that panel let me know...I have a pretty complete library of AA's wiring diagrams, manuals etc. Sorry this has happened to you. Rick Sked ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Friday, May 2, 2008 8:08:29 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Trutrak autopilots I need a little advice from those who are IFR rated and flying. Unfortunately, my panel shop, Accuracy avionics just went belly up this am. (I wouldn't advise sending them any more checks) I've been stiffed out of an autopilot that I still haven't received yet. Now that I get to pay double for it, I'm reconsidering how may features I need. I planned on a Trutrak digiflight IIVSGV. I would like to know how often one needs the vertical GPS steering feature. Does it help eliminate setting your power and trim for a climb/descent? I have minimal IFR training, but doesn't one set up basically a table with power settings to see what your airplane will do to get say a 500 ft/min descent? Looks like I could save about $400-500 by not getting that feature. Little miffed this am...... Trying to regain composure and just fly the airplane....... Thanks in advance for the replies. Dr Fred 40515 Now in panel assembly hell. ________________________________________________________________________________
Date: May 02, 2008
Congratulations. Let me know when you fly. I flew mine up to MN. I still have OP stuff to work out with Stein but now I am in his back yard. Gary _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Friday, May 02, 2008 2:38 PM Subject: RV10-List: It's Official! Just finished up with the DAR and #40105 is now N442PM in every respect! No squawks found during the inspection, just have to put everything back together. First flight will wait until weather conditions locally improve a bit. Bob ________________________________________________________________________________
Date: May 02, 2008
Subject: Trutrak
Guys, Thanks for the input. I do have a 430w for the panel and will likely go ahead and get the vertical steering. Just wanted to know how useful it would be. Rick, thanks for the reply, fortunately I do have the complete wiring diagrams and 90% of the parts. I was able to talk to Eric this am and he was just as taken back as I was. He was completely in the dark until today. He has been gracious enough to offer to help also If I have any problems. Tony has been just as helpful up until this last two weeks. I knew something was up when I called to get the autopilot and adi and Tony said he had to wait until a couple orders came in so he could purchase it. Fred ________________________________________________________________________________
Subject: Van's support to international customers
Date: May 03, 2008
Sorry guys, time for a bit of a whinge. Vans credibility has just taken a serious nose dive for this builder. Weldon 10 is not readily available in Australia and Vans will not deliver i t other than sea freight (3 month delay for $12 worth of stuff!!!). The su pplier here insists on providing adhesive that is significantly past its sh elf life (ie more than 2yrs). I have been trying to get some useable Weldo n for the past 3 months without success. Vans did advise that they hoped t o have a solution by end of April. Here is their response to my query on w hat was happening: "Obviously we have no control over IPS or their distributors. We can become certified for shipping Hazmat, but this requires sending staff on an expensive 3 day course. We are making inquiries to see if we can ship the material through a third party rather than becoming Hazmat certified here for this one product. However it is done, minimum cost for shipping any quantity of the adhesive would be about $200. The reason we don't have an alternative is because experts in the field advised us that this is the best adhesive to use. It therefore seems inadvisable for us to research, or to recommend that you use, the "not quite so good" alternatives. Several RV-10s have been finished in Australia, so this is not an insurmountable problem, though I am not sure how they solved the issue. As I said before, we are able to ship the adhesive in with the kits. If you have all your kits we can conceivably ship this in someone else's kit, so if you know of someone near you ordering a kit let us know. As of right now, that is all we can do. Gus" The majority of RV-10s that were completed in Australia have used Weld-on s upplied by Vans BEFORE they discovered it was Hazmat. Their reluctance to r ecommend an alternative windows installation method, when they cannot provi de their specified product is very disappointing. My -10 is virtually fini shed with a planned first flight date of July. Windscreen installation and fairing is the only job left and I have no more kits to freight in. So, for those international builders that may have a problem with getting W eld-On 10 - expect ZERO support from Vans. For me, it's back to the archives to find an alternative (but not Vans appr oved) way of installing the windscreen. Ron -187 (and reeeeally pi$$ed off) "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: May 02, 2008
Subject: Building Sequence - how long can I delay riveting the fiberglass
top on? I'm looking for some advice on building sequence. I finished sections thru 40 and now the fuselage top has been fitted but it seems to be in my best interest to delay riveting it until a number of tasks are done. It would also seems to be best to delay the upper forward fuselage installation until the avionics are well underway. I have the finishing kit inhouse and the 540 is on its way. I'm thinking that I need to focus on the avionics and other cockpit systems so that I can put the tops on. Those of you that have been thru this, what is a good way to proceed? What kind of flexibility do I have? What pitfalls should I avoid? So much to do and so many options. Hey Bob C - Congratulations! Can't wait to hear about the first flight. Bill "with fiberglass dust everywhere" Watson Durham NC ________________________________________________________________________________
Date: May 02, 2008
Subject: Re: Van's support to international customers
Ron, I'm going the Silpruf silicone method, ever consider an alternative to weld-on? The Glasair crews have been using this method and it even looks like the Cirrus uses similar methods. I have the VHS tape showing it's install and I think it's a better way to go IMHO, Easier to get the adhesive as well. Takes 4 to 5 tubes at about $15 US each to complete. Rick Sked 40185 ----- Original Message ----- From: "Ron McGANN" <ron.mcgann(at)baesystems.com> Sent: Friday, May 2, 2008 6:25:11 PM (GMT-0800) America/Los_Angeles Subject: RV10-List: Van's support to international customers Sorry guys, time for a bit of a whinge. Vans credibility has just taken a serious nose dive for this builder. Weldon 10 is not readily available in Australia and Vans will not deliver it other than sea freight (3 month delay for $12 worth of stuff!!!). The supplier here insists on providing adhesive that is significantly past its shelf life (ie more than 2yrs). I have been trying to get some useable Weldon for the past 3 months without success. Vans did advise that they hoped to have a solution by end of April. Here is their response to my query on what was happening: "Obviously we have no control over IPS or their distributors. We can become certified for shipping Hazmat, but this requires sending staff on an expensive 3 day course. We are making inquiries to see if we can ship the material through a third party rather than becoming Hazmat certified here for this one product. However it is done, minimum cost for shipping any quantity of the adhesive would be about $200. The reason we don't have an alternative is because experts in the field advised us that this is the best adhesive to use. It therefore seems inadvisable for us to research, or to recommend that you use, the "not quite so good" alternatives. Several RV-10s have been finished in Australia, so this is not an insurmountable problem, though I am not sure how they solved the issue. As I said before, we are able to ship the adhesive in with the kits. If you have all your kits we can conceivably ship this in someone else's kit, so if you know of someone near you ordering a kit let us know. As of right now, that is all we can do. Gus" The majority of RV-10s that were completed in Australia have used Weld-on supplied by Vans BEFORE they discovered it was Hazmat. Their reluctance to recommend an alternative windows installation method, when they cannot provide their specified product is very disappointing. My -10 is virtually finished with a planned first flight date of July. Windscreen installation and fairing is the only job left and I have no more kits to freight in. So, for those international builders that may have a problem with getting Weld-On 10 - expect ZERO support from Vans. For me, it's back to the archives to find an alternative (but not Vans approved) way of installing the windscreen. Ron -187 (and reeeeally pi$$ed off) "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: May 02, 2008
Subject: Re: Building Sequence - how long can I delay riveting the
fiberglass top on? Bill, I fitted my cabin top and doors way back. Since then I have, put it on the gear, hung the engine & prop, installed all the wiring, the panel, finished the cowl/FWF/baffeling. Basically my -10 is complete without the top on. The top/windows and the pants/faring are all that's left to do shy of hanging the wings and final assembly..(yeah right) I found it so much easier to climb in and out without the cabin top on the fuselage. I'm afraid as soon as the top is on I'll see that bright light at the end of the tunnel and really start to think I'm done. Rick Sked 40185 ----- Original Message ----- From: "MauleDriver" <MauleDriver(at)nc.rr.com> Sent: Friday, May 2, 2008 6:43:24 PM (GMT-0800) America/Los_Angeles Subject: RV10-List: Building Sequence - how long can I delay riveting the fiberglass top on? I'm looking for some advice on building sequence. I finished sections thru 40 and now the fuselage top has been fitted but it seems to be in my best interest to delay riveting it until a number of tasks are done. It would also seems to be best to delay the upper forward fuselage installation until the avionics are well underway. I have the finishing kit inhouse and the 540 is on its way. I'm thinking that I need to focus on the avionics and other cockpit systems so that I can put the tops on. Those of you that have been thru this, what is a good way to proceed? What kind of flexibility do I have? What pitfalls should I avoid? So much to do and so many options. Hey Bob C - Congratulations! Can't wait to hear about the first flight. Bill "with fiberglass dust everywhere" Watson Durham NC ________________________________________________________________________________
Date: May 02, 2008
Even on my limited budget I've been reminded on occasion that-400-500 is a fairly small amount if that's the only differential factor.- I understa nd if you're trying to trim a bunch of new increased prices, but if you lik e the original feature then it's pretty much-a wash.=0ARob=0A#392=0AMakin g a-negative fortune in aviation!=0A=0A=0A----- Original Message ----=0AF rom: "Fred Williams, M.D." =0ATo: RV 10 =0ASent: Friday, May 2, 2008 11:08:29 AM=0ASubject: RV10-L s, M.D." =0A=0AI need a little advice from those who are IFR rated and flying.- =0AUnfortunately, my panel shop, Accuracy avionics just went belly up this =0Aam.- (I wouldn't advise sending them any more checks)- I've been stiffed =0Aout of an autopilot that I still haven't received yet.- Now that I get =0Ato pay double for it, I'm recons idering how may features I need.- I =0Aplanned on a Trutrak digiflight II VSGV.=0A=0AI would like to know how- often one needs the- vertical- G PS steering- =0Afeature.- Does it help eliminate setting your power and trim for a =0Aclimb/descent?- I have minimal IFR training, but doesn't o ne set up =0Abasically a table with power settings to see what your airplan e will do =0Ato get say a 500 ft/min descent?- Looks like I could save ab out $400-500 =0Aby not getting that feature. =0A=0ALittle miffed this am... ...=0ATrying to regain composure and just fly the airplane.......=0A=0AThan ks in advance for the replies. =0A=0A=0ADr Fred=0A40515=0ANow in panel asse - - - - - - - - - - - - - - -Matt Dralle, List ========0A=0A=0A _______________________________________ _____________________________________________=0ABe a better friend, newshou nd, and =0Aknow-it-all with Yahoo! Mobile. Try it now. http://mobile.yaho o.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: May 02, 2008
I hope the official photographer is on standby to assist those of us that are schedule and distance challenged. Whatever happened to the RV-10 calendar effort? Is a 2008 version available? John Cox wrote: > The light is ON for the Pacific > NW RV-10 builder shindig next Saturday. Yeh All should contact John > Jessen if you can fly your Rv-10 into Dietz Airpark for the get > together. > > John > > > Checked by AVG. 02 AM
Date: May 03, 2008
Anh, With my 430, i lost transmit on com1. i went 4 months using the second radio, because i couldn't justify an 800 repair bill. As it happened the deadline for the waas upgrade was looming close. I decided at the last minute to get in on the "deal". To my surprise, Garmin ended up replacing the main board, the faceplate, and the upgrade waas package for the 1500 dollar upgrade fee. i was so expecting an additional fee, i was half expecting an additional bill to follow. It turns out that Garmin actually repaired my unit, effectively overhauling it for no additional charge. Granted, i spent 1500 bucks, i actually feel like i got my moneys worth. (this time) steve _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DejaVu Sent: Friday, May 02, 2008 6:23 PM Subject: RV10-List: Garmin Rapair - Customer Beware Short story: if Garmin replaces a light bulb in your unit, it's $800. I was totally unaware but you can find the verbage in their warranty online. I was expecting someone to call first. Long story: Lost the transmitter on my comm radio on the 430 on the way back from SNF, reception was fine. Trouble shooting showed transmitter output was a whopping 1.5W and very noisy after the initial 3 second ouput of 37W. You can hear something like a relay within the unit kicking in right prior to going from 37W to 1.5W. Great, the radio is protected. Something simple is wrong. My 430 has 130hrs on it. 2-year warranty started on purchase date so that expired about 7 months after first flight. Sent the unit to Garmin through a dealer (can't send it directly to them). Turn around time was quick - confirmed my suspecion that it was a simple fix. I was impressed. The damage - $875. My eye balls almost jumped out of their sockets. After researching a bit I realized that I'm not the first unhappy customer. Garmin has a flat repair rate of $800 for the 430, including shipping (thank goodness!! I wonder why my bill was $875?). They guarantee complete overhaul if they so deem the unit needs it. This includes cosmetics like worn out buttons or anything they see that's not up to par. Quote from the Service Report "Confirmed problem. Repaired the COMM board to correct the discrepancy. Updated software." Garmin's repair records does not contain any more details than this. When asked if cosmetic works were done to my unit, the answer.... no. I would've been surprised if there was any on such a low time unit. Sounds to me that Garmin has a good marketing strategy to keep all units in service at tip top overhauled shape at the expense of the customers. By the way, the dealer wasn't aware of this flat rate policy. So what's the chance of something majorly wrong with my 430 would happen to get a good $800 deal? Considering the cost of a new unit, a quick statistical calculation +/- a bunch% error says that you'll never make out ahead with this deal. Google what others have to say regarding Garmin's customer support and see for yourself. I don't mind supporting a good product but this feels like a log going through my rear end. Anh N591VU-flying ________________________________________________________________________________
Subject: Re: Garmin Rapair - Customer Beware
Date: May 02, 2008
A good example of Garmin getting fat and happy. I'll pray for mine to last a while. On May 2, 2008, at 6:22 PM, DejaVu wrote: > Short story: if Garmin replaces a light bulb in your unit, it's > $800. I was totally unaware but you can find the verbage in their > warranty online. I was expecting someone to call first. > > Long story: Lost the transmitter on my comm radio on the 430 on the > way back from SNF, reception was fine. Trouble shooting showed > transmitter output was a whopping 1.5W and very noisy after the > initial 3 second ouput of 37W. You can hear something like a relay > within the unit kicking in right prior to going from 37W to 1.5W. > Great, the radio is protected. Something simple is wrong. My 430 > has 130hrs on it. 2-year warranty started on purchase date so that > expired about 7 months after first flight. > > Sent the unit to Garmin through a dealer (can't send it directly to > them). Turn around time was quick - confirmed my suspecion that it > was a simple fix. I was impressed. The damage - $875. My eye > balls almost jumped out of their sockets. After researching a bit I > realized that I'm not the first unhappy customer. Garmin has a flat > repair rate of $800 for the 430, including shipping (thank > goodness!! I wonder why my bill was $875?). They guarantee complete > overhaul if they so deem the unit needs it. This includes cosmetics > like worn out buttons or anything they see that's not up to par. > Quote from the Service Report "Confirmed problem. Repaired the COMM > board to correct the discrepancy. Updated software." Garmin's > repair records does not contain any more details than this. When > asked if cosmetic works were done to my unit, the answer.... no. I > would've been surprised if there was any on such a low time unit. > > Sounds to me that Garmin has a good marketing strategy to keep all > units in service at tip top overhauled shape at the expense of the > customers. By the way, the dealer wasn't aware of this flat rate > policy. > > So what's the chance of something majorly wrong with my 430 would > happen to get a good $800 deal? Considering the cost of a new unit, > a quick statistical calculation +/- a bunch% error says that you'll > never make out ahead with this deal. Google what others have to say > regarding Garmin's customer support and see for yourself. I don't > mind supporting a good product but this feels like a log going > through my rear end. > > Anh > N591VU-flying > > ________________________________________________________________________________
Date: May 03, 2008
fiberglass top on? That's what I was hoping to hear. I really wanted to keep going with the composite work - doors, cowl - since all my tools are dulled and dust is everywhere despite aggressive vacuuming. I'm assuming that the top parts all need to be cleco'd together in order to hang the engine for a little structural integrity? Bill Rick Sked wrote: > > Bill, > > I fitted my cabin top and doors way back. Since then I have, put it on the gear, hung the engine & prop, installed all the wiring, the panel, finished the cowl/FWF/baffeling. Basically my -10 is complete without the top on. The top/windows and the pants/faring are all that's left to do shy of hanging the wings and final assembly..(yeah right) I found it so much easier to climb in and out without the cabin top on the fuselage. I'm afraid as soon as the top is on I'll see that bright light at the end of the tunnel and really start to think I'm done. > > Rick Sked > 40185 > ----- Original Message ----- > From: "MauleDriver" <MauleDriver(at)nc.rr.com> > To: "RV10-List Digest Server" > Sent: Friday, May 2, 2008 6:43:24 PM (GMT-0800) America/Los_Angeles > Subject: RV10-List: Building Sequence - how long can I delay riveting the fiberglass top on? > > > I'm looking for some advice on building sequence. I finished sections > thru 40 and now the fuselage top has been fitted but it seems to be in > my best interest to delay riveting it until a number of tasks are done. > It would also seems to be best to delay the upper forward fuselage > installation until the avionics are well underway. I have the finishing > kit inhouse and the 540 is on its way. I'm thinking that I need to > focus on the avionics and other cockpit systems so that I can put the > tops on. > > Those of you that have been thru this, what is a good way to proceed? > What kind of flexibility do I have? What pitfalls should I avoid? > > So much to do and so many options. > > Hey Bob C - Congratulations! Can't wait to hear about the first flight. > > Bill "with fiberglass dust everywhere" Watson > Durham NC > > > ________________________________________________________________________________
Subject: Re: It's Official!
Date: May 03, 2008
Sorry to hear that you're still having problems, I know it has to be frustrating. Maybe being local to Stein will help. First flight will likely be tomorrow or Monday. I really want southerly winds so I can use rwy 12 at MLE because of reasonable terrain in case of engine issues. The other direction has no real good choice if turning back isn't an option. I've waited 4.5 years, a couple of days is nothing! Bob -------------------------- ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Fri May 02 17:25:58 2008 Subject: RE: RV10-List: It's Official! Congratulations. Let me know when you fly. I flew mine up to MN. I still have OP stuff to work out with Stein but now I am in his back yard. Gary _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Friday, May 02, 2008 2:38 PM Subject: RV10-List: It's Official! Just finished up with the DAR and #40105 is now N442PM in every respect! No squawks found during the inspection, just have to put everything back together First flight will wait until weather conditions locally improve a bit. Bob http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 03, 2008
I'm not that far along yet, but I know Dave Saylor at Aircrafters LLC in Watsonville, CA, has advertised an overhead console in Kitplanes. John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180867#180867 ________________________________________________________________________________
top on?
Date: May 03, 2008
April 15, 2008 - May 03, 2008
RV10-Archive.digest.vol-dh
