RV10-Archive.digest.vol-dk
June 05, 2008 - June 23, 2008
      this forum is a great resource for all those perplexing steps.
      Make sure you pay attention in the empennage because the instructions get
      less detailed in the wings and even more so in the fusellage. THAN you'll be
      worrying about steps you come across that the plans dont even mention.
      It will be a great experience, enjoy the journey of building it has been  a
      real blessing for me so far and I trust it will be equally satisfying for
      you.
      Pascal
Sent: Thursday, June 05, 2008 7:32 PM
Subject: Almost a Builder
> > Tail Kit order was faxed to Vans today, so I suppose I'll have a > builder number shortly and start worrying about picking up the kit and > inventorying it. Looking forward to it. > > > ________________________________________________________________________________
Date: Jun 05, 2008
Subject: Re: Almost a Builder
Thanks. Turnabout is fair play. Some of them already know about it. Heck, John Galban was Doug Peterson's "rivet boy" while Doug was building his -10. Tool kit from Isham is due in Sat or Mon. LES KEARNEY wrote: > Kelly > > Welcome to the dark side. I guess I'll have to rat you out to the > Piper list... > > Cheers > > Les > > ----- Original Message ----- > From: Kelly McMullen <apilot2(at)gmail.com> > Date: Thursday, June 5, 2008 8:46 pm > Subject: RV10-List: Almost a Builder > To: rv10-list(at)matronics.com > > > > > Tail Kit order was faxed to Vans today, so I suppose I'll have a > > builder number shortly and start worrying about picking up the > > kit and > > inventorying it. Looking forward to it. > > ________________________________________________________________________________
Subject: wire tying inside conduit?
Date: Jun 05, 2008
Here's a funny question that I've been asking myself this afternoon... when you run wires inside a conduit (under the rear floors, etc) do you need to tie them up together before you run them through? you know, with zip ties or wire lacing tape? Seems like overkill, but i can't help but think about wires flopping around in there. what say you all? cj ________________________________________________________________________________
Date: Jun 06, 2008
Subject: Re: wire tying inside conduit?
Chris Johnston wrote: > Here's a funny question that I've been asking myself this afternoon... when you run wires inside a conduit (under the rear floors, etc) do you need to tie them up together before you run them through? you know, with zip ties or wire lacing tape? Seems like overkill, but i can't help but think about wires flopping around in there. what say you all? > No ties within the conduit. They won't really flop around ..... and if they do, you've got more important things to worry about ;-) . Lacing up bundles of wires serves to make a neater installation instead of looking like someone tossed spaghetti behind the panel :-P . It also serves to keep the wires from moving around and creating fatigue cracks in the wires where the crimped lugs or soldered connections are. Being contained inside a conduit is best looked at like a loose-tied bundle. > cj > ________________________________________________________________________________
Date: Jun 05, 2008
CJ, I would definitely NOT tie the wires within the conduit. Having just gone through the exercise of running additional wires in an already 'full' conduit, the ties would make installing the new wires difficult to impossible. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chris Johnston wrote: > Here's a funny question that I've been asking myself this afternoon... when you run wires inside a conduit (under the rear floors, etc) do you need to tie them up together before you run them through? you know, with zip ties or wire lacing tape? Seems like overkill, but i can't help but think about wires flopping around in there. what say you all? > > cj > ________________________________________________________________________________
Date: Jun 05, 2008
Subject: Re: Exhaust fitting problem
Is it a Vetterman system? I've been to his shop numerous times and he welds each system mounted directly to the engine model system is to be mounted on. I'm not sure what the problem might be, It's been too long since we mounted ours, but I'd be shocked if the system doesn't fit. If you don't get it figured out let me know and I can contact Larry for a solution. --- On Tue, 6/3/08, McGANN, Ron wrote: > From: McGANN, Ron <ron.mcgann(at)baesystems.com> > Subject: RV10-List: Exhaust fitting problem > To: rv10-list(at)matronics.com > Date: Tuesday, June 3, 2008, 11:54 PM > G'day all, > > After 4.25 years of building and having everything fit > beautifully, I > finally get to the very last set of plans (FF-6 Exhaust > installation). > Install the right side first, still amazed at how > everything 'just > fits'. Finished the routing of the alternator and > starter wires and > pulled out the last piece of the kit that was left - the > left hand > exhaust manifold. > > There is no way that this puppy will fit. The riser for #2 > cylinder > seems to have been welded incorrectly and there is nowhere > near enough > adjustment to have the stack fit the exhaust ports. > > Has anyone else experienced this or am I SOL, right at the > finish line?? > > Thanks in advance for any responses - no 'cheers' > today ;-< > > Ron > 187 hobbled at the end > > "Warning: > The information contained in this email and any attached > files is > confidential to BAE Systems Australia. If you are not the > intended > recipient, any use, disclosure or copying of this email or > any > attachments is expressly prohibited. If you have received > this email > in error, please notify us immediately. VIRUS: Every care > has been > taken to ensure this email and its attachments are virus > free, > however, any loss or damage incurred in using this email is > not the > sender's responsibility. It is your responsibility to > ensure virus > checks are completed before installing any data sent in > this email to > your computer." ________________________________________________________________________________
Date: Jun 05, 2008
Good news Kelly, Welcome aboard. You will love building the RV10. Are you planning to will call your order? Paul Grimstad RV10 450 Portland, Or. ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Thursday, June 05, 2008 7:32 PM Subject: RV10-List: Almost a Builder > > Tail Kit order was faxed to Vans today, so I suppose I'll have a > builder number shortly and start worrying about picking up the kit and > inventorying it. Looking forward to it. > > > > ________________________________________________________________________________
Date: Jun 06, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Ah, Kelly - your life will never be the same. Jack Phillips #40610 Wings (slow build) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 05, 2008 10:32 PM Subject: RV10-List: Almost a Builder Tail Kit order was faxed to Vans today, so I suppose I'll have a builder number shortly and start worrying about picking up the kit and inventorying it. Looking forward to it. How can the best minds in healthcare help you reduce HAIs? Find out September 8th. The Chasing Zero Summit on Hospital-Acquired Infections September 8 - 10, 2008 in Washington, D.C. To learn more or register, visit www.chasingzero.com/HAI Hosted by Cardinal Health ________________________________________________________________________________
Date: Jun 06, 2008
Subject: Cylinder pre oil sequence
Anyone off the top of their head know the pre oil sequence for the 540? you know..bring #? to TDC, oil #?? then which cylinder is next, and so on...Rhonda....Rhonda.... :) Rick Sked 40185 ________________________________________________________________________________
Date: Jun 06, 2008
Hi Rick: Here are the instructions that we recommend with our engines. Either method is fine. 1. Using an external source of mineral oil and pressure, pump oil through the engine using the oil pressure fitting as the inlet source. Install a temporary gage at the right hand forward galley plug and pump oil until the temporary gage reads a stable pressure between 40-100 psi. Remove the temporary gage, install galley plug and connect engine oil pressure cockpit gage. Remove one upper sparkplug from each cylinder and, using the engine starter, motor the engine until the cockpit gage reads stable. Install sparkplugs and torque to 400-425 in/lbs. Install leads. Engine is ready to start for LIMITED ground run. 2. If no external source is available, remove upper sparkplugs and rotate engine through using the propeller until some indication on the cockpit gage appears. Using the engine starter, motor the engine until the gage reads 40-100 psi, stable. Observe starter limitations. Install sparkplugs as above. Best, Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Friday, June 06, 2008 11:29 AM Subject: RV10-List: Cylinder pre oil sequence Anyone off the top of their head know the pre oil sequence for the 540? you know..bring #? to TDC, oil #?? then which cylinder is next, and so on...Rhonda....Rhonda.... :) Rick Sked 40185 ________________________________________________________________________________
Date: Jun 06, 2008
Subject: Re: Cylinder pre oil sequence
#2 is what Aerosport recommends and what I did. Took about 6-8 seconds to see an indication. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: Rhonda Bewley <Rhonda(at)bpaengines.com> Sent: Friday, June 6, 2008 11:10:14 AM Subject: RE: RV10-List: Cylinder pre oil sequence Hi Rick: Here are the instructions that we recommend with our engines. Either method is fine. 1. Using an external source of mineral oil and pressure, pump oil through the engine using the oil pressure fitting as the inlet source. Install a temporary gage at the right hand forward galley plug and pump oil until the temporary gage reads a stable pressure between 40-100 psi. Remove the temporary gage, install galley plug and connect engine oil pressure cockpit gage. Remove one upper sparkplug from each cylinder and, using the engine starter, motor the engine until the cockpit gage reads stable. Install sparkplugs and torque to 400-425 in/lbs. Install leads. Engine is ready to start for LIMITED ground run. 2. If no external source is available, remove upper sparkplugs and rotate engine through using the propeller until some indication on the cockpit gage appears. Using the engine starter, motor the engine until the gage reads 40-100 psi, stable. Observe starter limitations. Install sparkplugs as above. Best, Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Friday, June 06, 2008 11:29 AM Subject: RV10-List: Cylinder pre oil sequence Anyone off the top of their head know the pre oil sequence for the 540? you know..bring #? to TDC, oil #?? then which cylinder is next, and so on...Rhonda....Rhonda.... :) Rick Sked 40185 ________________________________________________________________________________
Date: Jun 06, 2008
From: "David J. Fritzsche" <fritzsch(at)eskimo.com>
Subject: Taking The Plunge
I have been following the list for about a year. After deciding what airplane to build, the next major decision was what tools to buy. Tim Olson's and Larry Rosen's web sites (along with several others) plus much appreciated personal communication from both of them proved invaluable. The advice coincided well with the little flurry on tools in March. One suggestion I have not seen since monitoring the list is to cover at least some of the shop floor with rubber matting to lessen fatigue. Costco carries it at a good price. I received my empennage kit in February planning to start building in late spring. I guess I am on schedule as I took the plunge on Wednesday. Unfortunately after cutting and deburring the rear spar caps for the VS, I discovered a significant scratch on the VS rear spar. I hold an A & P certificate obtained at the University of Illinois in 1961, but I have not worked on aircraft since 1965. Thus I sought advice from one of our EAA tech counselors. We both agreed that it should probably be replaced. I contacted Vans and sent them a digital picture. I received an immediate response that the scratch should have been caught in the packing process and that a new spar was on its way. Thus my experience so far is very positive. As others have said, this list is an extremely valuable resource. I look forward to leaning on it and hopefully offering some helpful input an my project goes forward. -- ~~~~~~~~~~~~~~~~~~~~~~~ Dave Fritzsche 40813 empennage Puyallup, WA ~~~~~~~~~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Jun 06, 2008
Welcome aboard. The tool kit I got from Isham a couple of years ago turned out to be a good one. The only waste was some rivet tape that looked it should be used on a 747. Kelly McMullen wrote: > > Thanks. Turnabout is fair play. Some of them already know about it. > Heck, John Galban was Doug Peterson's "rivet boy" while Doug was > building his -10. > Tool kit from Isham is due in Sat or Mon. > > LES KEARNEY wrote: >> Kelly >> >> Welcome to the dark side. I guess I'll have to rat you out to the >> Piper list... >> >> Cheers >> >> Les >> >> ----- Original Message ----- >> From: Kelly McMullen <apilot2(at)gmail.com> >> Date: Thursday, June 5, 2008 8:46 pm >> Subject: RV10-List: Almost a Builder >> To: rv10-list(at)matronics.com >> >> > >> > Tail Kit order was faxed to Vans today, so I suppose I'll have a >> > builder number shortly and start worrying about picking up the >> > kit and >> > inventorying it. Looking forward to it. >> > > > ________________________________________________________________________________
Date: Jun 06, 2008
Subject: Re: Taking The Plunge
Regarding rubber matting - I bought (4) 2' squares and found it to be perfect for covering my active 'foot print' while not getting in the way. I don't think a rubber floor in a shop is a good thing but standing on rubber is a joy. I spent my working career sitting on my butt so I've always focused on sitting comfort. Building is about standing a lot, and this flat footed, weak kneed builder has found a pair of Sketcher sandals to be the best tool in the shop. Personal preference rules but a little experimentation with the shoes and floor surface seems more than worthwhile. Welcome aboard. Bill "working on those pesky doors" Watson Durham David J. Fritzsche wrote: > > > I have been following the list for about a year. After deciding what > airplane to build, the next major decision was what tools to buy. Tim > Olson's and Larry Rosen's web sites (along with several others) plus > much appreciated personal communication from both of them proved > invaluable. The advice coincided well with the little flurry on tools > in March. One suggestion I have not seen since monitoring the list is > to cover at least some of the shop floor with rubber matting to lessen > fatigue. Costco carries it at a good price. > ________________________________________________________________________________
Date: Jun 07, 2008
Subject: Firewall Forward Kit For Sale
Hello All, I would like to offer my firewall forward package up for sale to those of you on the list. I have decided to install Bud Warren's Geared Drives LS1 Firewall Forward package on my '10 so I don't need it. I had moved along the IO-540 path and had purchased the FF kit before Bud put his package on the market so it has been opened and some of the parts placed on the airframe but not installed permanently. I have the throttle quadrant package. - FF-10 IO-540 W/CT10-3 US$6235.00 I will have to do a complete inventory and repackage all of the components for anyone interested. It is for sale at a ~5% discount - US$5900.00 + 1/2 the shipping Those interested can contact me off the list at effectus (at) rogers (dot) com or call 519-933-2055 Dave Hertner ________________________________________________________________________________
Date: Jun 08, 2008
Dave, I'd jump on the kit but I already have a lot of the larger items that are listed. I'd love to get my hands on a packing list for that kit, I'm curious as to what is included, as far as smaller parts and hoses to help me plan ahead. Is there anyway I could get you to email me a copy? Steve dinieri capsteve(at)iflyrv10.com Iflyrv10.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Hertner Sent: Saturday, June 07, 2008 3:16 PM Subject: RV10-List: Firewall Forward Kit For Sale Hello All, I would like to offer my firewall forward package up for sale to those of you on the list. I have decided to install Bud Warren's Geared Drives LS1 Firewall Forward package on my '10 so I don't need it. I had moved along the IO-540 path and had purchased the FF kit before Bud put his package on the market so it has been opened and some of the parts placed on the airframe but not installed permanently. I have the throttle quadrant package. - FF-10 IO-540 W/CT10-3 US$6235.00 I will have to do a complete inventory and repackage all of the components for anyone interested. It is for sale at a ~5% discount - US$5900.00 + 1/2 the shipping Those interested can contact me off the list at effectus (at) rogers (dot) com or call 519-933-2055 Dave Hertner ________________________________________________________________________________
Subject: 2007 Eggenfellner RV-10 Package for sale
Date: Jun 07, 2008
To RVer's especially RV-10 builders who may be thinking about installing an alternative engine in your 10. Available immediately complete Eggenfellner RV-10 E-6T 220 HP FWF package i ncluding 4 Blade Sensenich composite prop with spinner, prop controller, Gr and Rapids EIS, E-cowling, intercooler package, high output alternator. I' ve taken delivery of everything except the prop, prop controller and cowlin g which are due June/July and partially installed on my 10. Recently I hav e decided to install Bud Warren's GearedDrive LS-1 engine instead and now h ave a "spare" on my hands. I'm offering this package at a substantial disc ount so give me a call or send me an email. Contact me at 936-307-6096 or email at gipsowh(at)hotmail.com . Regards, Bill Gipson Conroe, Texas _________________________________________________________________ Search that pays you back! Introducing Live Search cashback. http://search.live.com/cashback/?&pkw=form=MIJAAF/publ=HMTGL/crea=s rchpaysyouback ________________________________________________________________________________
Subject: Baggage door
Date: Jun 08, 2008
I just finished my baggage door and noticed that the panels are a bit soft due to no stiffeners inside. I was thinking of squirting a small amount of great stuff in there to add a bit of support. I would lay the door on a flat surface and put even pressure on the door during curing to keep it flat. They do not oil can. Just a thought, has anyone noticed an issue here? Dave Leikam #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Date: Jun 08, 2008
Subject: Re: Baggage door
I haven't noticed anything bad on the baggage door. I think I did line mine with that black soundproofing foam though. They didn't oilcan either. I'm not sure if I'd go the great-stuff route, but if you're interested in giving it some backing perhaps just a sponge foam block or something glued in. I'm wondering if a natural sponge wouldn't be better than a synthetic one for fire reasons? Of course, closed cell foam would be better for moisture reasons. I don't think you'll have an issue with the door though, so filling it is probably something more to think about for sound or heat than anything else. I'm just not too sure that great stuff would be the right thing. Especially if it expanded and bowed the door at all. All in all though, you're talking about one of the lesser-critical areas, so probably no idea would be too awful. Tim Dave Leikam wrote: > I just finished my baggage door and noticed that the > panels are a bit soft due to no stiffeners inside. I was thinking of > squirting a /small/ amount of great stuff in there to add a bit of > support. I would lay the door on a flat surface and put even pressure > on the door during curing to keep it flat. > They do not oil can. Just a thought, has anyone noticed an issue here? > Dave Leikam > #40496 N89DA (Reserved) > Muskego, WI > > * ________________________________________________________________________________
Date: Jun 08, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Dave; I went out and looked at my door again. I think it's just the lightweight aluminum door. Probably be all right to add some stiffness. I saw a good idea on my friend's 10. On the inside top rail, there is a forming hole about 2-3 inches from the hinge. Before you pop rivet the door inside, put a number 6 platenut there. Then, when the door is attached, run a 18 AWG wire with a ring terminal on each end. One on the door and one on the inside of the crossmember. You now have a simple catch to keep the door (and your keys) from swinging all the way open and damaging your paint job. One of those simple things to do in construction, but hard to do when everything is all riveted in. Dr Fred. In wiring heaven Dave Leikam wrote: > I just finished my baggage door and noticed that the > panels are a bit soft due to no stiffeners inside. I was thinking of > squirting a /small/ amount of great stuff in there to add a bit of > support. I would lay the door on a flat surface and put even pressure > on the door during curing to keep it flat. > They do not oil can. Just a thought, has anyone noticed an issue here? > Dave Leikam > #40496 N89DA (Reserved) > Muskego, WI > * > > > * ________________________________________________________________________________
Subject: garmin 430 tube question
Date: Jun 08, 2008
I am wondering if someone can help with the placement of the tube/tray relative to the front of the panel. I noticed that the bottom front lip of the tray sticks out about 3/32 farther than the top and sides of the tray. All the diagrams of the tubes don't seem to show this. So, does the bottom lip get mounted flush with the panel (aft side /cabin side) or does it stick out to the cabin side of the panel and the sides and top edges are flush? What gives? I just have trays now. Thanks Chris Lucas #40072 ________________________________________________________________________________
Subject: Initial Canopy trimming
Date: Jun 08, 2008
I just want to double check on canopy trimming. With the canopy fitting nicely and flush within the door space, I still have about 3/16" of jog space exposed on both sides of the rear bottom of the canopy over the mid side skin. Lip is cut back to just under 3/4" so it isn't bottoming and preventing canopy from going all the way down. So-- I've already trimmed past the scribe marks in the doorway area. It looks like if I trim (the door area) enough to bring the back lower part of the canopy flush with the jog line, I'll have sanded away almost all of the bottom of the canopy door frame. Does this sound familiar??? Thanks, Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186877#186877 ________________________________________________________________________________
Date: Jun 08, 2008
Subject: Re: Initial Canopy trimming
Tom, Sounds very familiar. Grit your teeth and sand away. Dave Lammers finishing tomhanaway wrote: > >I just want to double check on canopy trimming. >With the canopy fitting nicely and flush within the door space, I still have about 3/16" of jog space exposed on both sides of the rear bottom of the canopy over the mid side skin. Lip is cut back to just under 3/4" so it isn't bottoming and preventing canopy from going all the way down. > >So-- I've already trimmed past the scribe marks in the doorway area. It looks like if I trim (the door area) enough to bring the back lower part of the canopy flush with the jog line, I'll have sanded away almost all of the bottom of the canopy door frame. > >Does this sound familiar??? >Thanks, >Tom > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=186877#186877 > > > > ________________________________________________________________________________
Date: Jun 08, 2008
Tom, I recently did mine and I'll admit it get's pretty thin on the bottom. However, I think the plans show an outside measure of a little over an inch in that area. I'm not looking at the plans so I can't be specific. John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186880#186880 ________________________________________________________________________________
Date: Jun 08, 2008
Yep, that's how it turns out. You'll want to fill that area anyway to smooth it for painting, so just drill and rivet and keep on moving forward if everything else looks good. Tim Olson - RV-10 N104CD - Flying tomhanaway wrote: > > I just want to double check on canopy trimming. > With the canopy fitting nicely and flush within the door space, I still have about 3/16" of jog space exposed on both sides of the rear bottom of the canopy over the mid side skin. Lip is cut back to just under 3/4" so it isn't bottoming and preventing canopy from going all the way down. > > So-- I've already trimmed past the scribe marks in the doorway area. It looks like if I trim (the door area) enough to bring the back lower part of the canopy flush with the jog line, I'll have sanded away almost all of the bottom of the canopy door frame. > > Does this sound familiar??? > Thanks, > Tom > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=186877#186877 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: garmin 430 tube question
Date: Jun 08, 2008
toaster73(at)embarqmail.c wrote: > I am wondering if someone can help with the placement of the tube/tray relative to the front of the panel. I noticed that the bottom front lip of the tray sticks out about 3/32 farther than the top and sides of the tray. All the diagrams of the tubes don't seem to show this. So, does the bottom lip get mounted flush with the panel (aft side /cabin side) or does it stick out to the cabin side of the panel and the sides and top edges are flush? What gives? I just have trays now. > Thanks > Chris Lucas > #40072 > Chris, Sounds like you have the tray only at this time and not the actual unit. The bottom lip needs to be flush with the front of the panel. If you were cutting out a hole only for this single instrument, you would cut the hole the dimensions of the inside of the tray plus for the height, add the thickness of the bottom lip. So the sides would be even with the inside of the tray, the top even with the top inside of the tray and for the bottom, the lip would be sticking through even with the front of the instrument panel and resting on the bottom of the hole. Now this would be a perfect world, so you would have to add some to the width and height to allow for clearances. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186888#186888 ________________________________________________________________________________
Date: Jun 08, 2008
Yep, I only have the trays now. I see what your saying. I have this as part of a stack. The GTX327 is this way too I think. But, the sl30 and gma340 do not have the lip. thanks -Chris ----- Original Message ----- From: "orchidman" <gary(at)wingscc.com> Sent: Sunday, June 08, 2008 7:45 PM Subject: RV10-List: Re: garmin 430 tube question > > > toaster73(at)embarqmail.c wrote: >> I am wondering if someone can help with the placement of the tube/tray >> relative to the front of the panel. I noticed that the bottom front lip >> of the tray sticks out about 3/32 farther than the top and sides of the >> tray. All the diagrams of the tubes don't seem to show this. So, does >> the bottom lip get mounted flush with the panel (aft side /cabin side) >> or does it stick out to the cabin side of the panel and the sides and >> top edges are flush? What gives? I just have trays now. >> Thanks >> Chris Lucas >> #40072 >> > > Chris, > Sounds like you have the tray only at this time and not the actual unit. > The bottom lip needs to be flush with the front of the panel. > If you were cutting out a hole only for this single instrument, you would > cut the hole the dimensions of the inside of the tray plus for the height, > add the thickness of the bottom lip. > So the sides would be even with the inside of the tray, the top even with > the top inside of the tray and for the bottom, the lip would be sticking > through even with the front of the instrument panel and resting on the > bottom of the hole. Now this would be a perfect world, so you would have > to add some to the width and height to allow for clearances. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Instrument Panel, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=186888#186888 > > > ________________________________________________________________________________
Date: Jun 08, 2008
Welcome to fiberglass purgatory. Almost all escape - some day. Those of us who have escaped, occasionally hear the midnight screaming of those who are still there. Trim - Fit - check - remove........... [Rolling Eyes] [Rolling Eyes] -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186893#186893 ________________________________________________________________________________
Date: Jun 08, 2008
I do not know about using great stuff. It may be corrosive to the aluminum in the initial set stage. Also, I have noticed in the construction that I have done, that it seems to expand (from within) even after it is quite firm. I would worry about it bowing out unless it was held in a VERY secure press situation till it was fully set (24 hrs). Still corrosion and water capture would be my big concerns -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186896#186896 ________________________________________________________________________________
Date: Jun 08, 2008
Secure them at the ends with a cushion clamp or a bit of RTV after you put a bit of tension on the wires. The kinks and bends in the conduit will keep the wires from jumping around with a bit of tension on the ends. Like deems said don't look for trouble. Also if you are concerned, always add an extra #18-22 wire to provide for any future add-ons. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=186897#186897 ________________________________________________________________________________
Subject:
Date: Jun 09, 2008
"Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Subject: Exhaust Probe location
Date: Jun 09, 2008
G'day all, GRTs web site has been off the air for a few days. Anyone know how far the EGT probes need to be positioned from the exhaust ports? cheers, Ron 187 almost done "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jun 08, 2008
Subject: Re: Exhaust Probe location
I believe most analyzer vendors have a recommendation. EI suggests 1.5 inches below flange. All of my IO-360 stacks happened to have a witness hole at that distance that was easy to drill for the probes. Seems to work fine. Probes may live longer further down the stack. Main critical item is that all probes are at same distance. On Sun, Jun 8, 2008 at 7:41 PM, McGANN, Ron wrote: > G'day all, > > GRTs web site has been off the air for a few days. Anyone know how far the > EGT probes need to be positioned from the exhaust ports? > > cheers, > Ron > 187 almost done > > "Warning: > The information contained in this email and any attached files is > confidential to BAE Systems Australia. If you are not the intended > recipient, any use, disclosure or copying of this email or any > attachments is expressly prohibited. If you have received this email > in error, please notify us immediately. VIRUS: Every care has been > taken to ensure this email and its attachments are virus free, > however, any loss or damage incurred in using this email is not the > sender's responsibility. It is your responsibility to ensure virus > checks are completed before installing any data sent in this email to > your computer." > > ________________________________________________________________________________
Subject: Van's RV-10 Whelan Lights For Sale
Date: Jun 09, 2008
After several months off building due to time constraints, I'm back at it and taking care of a few things I've been meaning to do for a while. This is one of them. When I ordered my QB fuse+wings, I also ordered the Van's Whelan lighting kit (incandescent). I've since decided to go LED and I'm selling the Van's lights. I ordered them last summer and the return window for Van's has elapsed. I was going to try my luck on eBay but figured I'd offer them here first in case anyone was looking for a set. I'd rather save someone on the list some money then pay eBay the commission. I purchased the Van's RV-10 lighting kit (wing tip nav+strobes, tail nav+strobe, power supply and wiring.) I'm selling the lights and power supply. I've already used some of the strobe wiring so that is not included I know LED's are the trend, but should anyone be interested in a set of incandescent Whelan's, feel free to contact me off list. If no one is interested, they probably go on eBay later in the week. Best Regards, Patrick #40715 ________________________________________________________________________________
Date: Jun 09, 2008
Yes it is. I ended up with some thin spots. FWIW, I used a variety of power tools to remove the material around the door sill. Once I got to the point of getting the whole thing to settle down close to the jog line, I finally found the Van's recommended 5' sanding block to be an effective tool. Bill "continuing to worry the doors into compliance" Watson Durham NC > > I just want to double check on canopy trimming. > With the canopy fitting nicely and flush within the door space, I still have about 3/16" of jog space exposed on both sides of the rear bottom of the canopy over the mid side skin. Lip is cut back to just under 3/4" so it isn't bottoming and preventing canopy from going all the way down. > > So-- I've already trimmed past the scribe marks in the doorway area. It looks like if I trim (the door area) enough to bring the back lower part of the canopy flush with the jog line, I'll have sanded away almost all of the bottom of the canopy door frame. > > Does this sound familiar??? > Thanks, > Tom > > ________________________________________________________________________________
Date: Jun 09, 2008
The Garmin G900 install manual (using Alcor probes) recommends: A) 2-4 inches from flange, B) Not on any curved portion, and C) All at the same distance from flange. I just finished this and it is a challenge to satisfy all the requirements on the supplied exhaust system. There are a couple more self imposed requirements you might think about: A) Tightening screw accessible during its full range of adjustment (it moves as the clamp tightens), and B) tightening screw assembly away from spark plug access area for ease of plug maintenance. Dave Lammers just finished exhaust install McGANN, Ron wrote: > G'day all, > > GRTs web site has been off the air for a few days. Anyone know how > far the EGT probes need to be positioned from the exhaust ports? > > cheers, > Ron > 187 almost done > >"Warning: >The information contained in this email and any attached files is >confidential to BAE Systems Australia. If you are not the intended >recipient, any use, disclosure or copying of this email or any >attachments is expressly prohibited. If you have received this email >in error, please notify us immediately. VIRUS: Every care has been >taken to ensure this email and its attachments are virus free, >however, any loss or damage incurred in using this email is not the >sender's responsibility. It is your responsibility to ensure virus >checks are completed before installing any data sent in this email to >your computer." > > > > ________________________________________________________________________________
Date: Jun 09, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Ron, I haven't had any issues with their website, if you want a copy of the manual emailed to you let me know. Here's the excerpt from the GRT EIS manual on EGT probe installation. Bob 5.2.9 Exhaust Gas Temperature Probe Installation Start by drilling an 1/8-inch diameter holes at the appropriate position in the exhaust manifold as indicated by the engine manufacturer. If the manufacturer provides no guidance on the location of the EGT probes, we recommend the following: 1. Position the probe 2-8 inches from the cylinder. 2. Although not critical, it is preferable to position all probes the same distance from the cylinder. 3. If possible, position the probes so that they are mounted on a straight (not curving) portion of the exhaust manifold. The hose clamps fit slightly better on straight portions of the manifold. 4. Position the hole around the manifold so that the probe does not interfere with the cowl, and takes into consideration practical needs related to maintenance (does not interfere with the access to the oil filter, etc.), inspections, or probe mounting. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGann, Ron (AUS BAeA) Sent: Sunday, June 08, 2008 9:41 PM Subject: RV10-List: Exhaust Probe location G'day all, GRTs web site has been off the air for a few days. Anyone know how far the EGT probes need to be positioned from the exhaust ports? cheers, Ron 187 almost done "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jun 09, 2008
When I was trimming my canopy I borrowed a Fein power tool from a friend. This is one of those that the blade, although semi-circular in shape, vibrates rather than rotates. Didn't throw off chips and dust and made it very easy to cut the fiberglass. Beat the cut-off tool in every way. Worked very well on the windows also. Albert Gardner N991RV Yuma, AZ (I hope he has forgotten who he lent it to by now) ________________________________________________________________________________
Subject: Service Bulletin 08-6-1
Date: Jun 09, 2008
Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp ________________________________________________________________________________
Date: Jun 09, 2008
Hey Tom, Just to second the others -- I stopped when the door sill started to look thin, and left the gap that Tim says will be filled at final fit before painting. Here are some pictures I took today so you can compare. At one point I noticed that the edge along the longerons needed to be shaved to allow the cabin back to settle as I shaved the door sill -- it's a bit fuzzy (too lazy to climb inside to take the pic) but see "interior cabin gap". Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187051#187051 Attachments: http://forums.matronics.com//files/interior_cabin_gap_509.jpg http://forums.matronics.com//files/exterior_cabin_gap_176.jpg http://forums.matronics.com//files/door_sill_981.jpg http://forums.matronics.com//files/door_sill_2_193.jpg ________________________________________________________________________________
Subject: Re: Service Bulletin 08-6-1
Date: Jun 09, 2008
http://www.vansaircraft.com/pdf/sb08-6-1.pdf This might be the only time I wish I was a bit slower in building a component - Just got this one finished a couple of months ago, now i get to drill all those nice rivets back out. -Andy -------- Andy Turner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187054#187054 ________________________________________________________________________________
Date: Jun 09, 2008
Dick, Can you get it done before you get paint? Hopefully they haven't started yet. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rsipp Sent: Monday, June 09, 2008 8:35 PM Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp ________________________________________________________________________________
Date: Jun 09, 2008
I think I am going to be sick at the thought of taking the elevator/ pitch trim apart again! :-( But! Better now than when I am flying. David Maib 40559 On Jun 9, 2008, at 7:34 PM, rsipp wrote: Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp ________________________________________________________________________________
Date: Jun 09, 2008
Thanks to all. Got it to where I feel pretty good about the fit all around. One nice thing is that all the fiberglass dust made the other scribe lines really easy to see. I feel like I just pledged a fraternity and went through hazing by fiberglass. Nice to feel all the community sharing of experiences. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187057#187057 ________________________________________________________________________________
Subject: Doors/Plexi revisited ... again
Date: Jun 09, 2008
Hey guys, I thought I'd add this, nothing really new. I went ahead and sanded out a 1" shallow with the die grinder, overlapping the plexi and the fiberglass, so that when I laid a 1" strip of cloth and glassed it in, it would be flush. Then came back over it with microbead/glass filler to make it really smooth and ready to prime. By the way, I used the recommended Weld-on to glue in the windows, but it seems to me others are putting too much pressure with clamps and that may be causing the cracks when released. This is not a wood/glue bond where pressure is critical, it just needs to "float" in place with enough pressure to get any bubbles out. The resulting joint is extremely tough with the layer of glass on the joint -- I don't anticipate any cracking or problem with the joint expanding the paint. One more observation: Others have commented about the paint peeling off the windshield in rain at 200 MPH. I noticed that where I had ground out the plexi to receive the fiberglass, it bonds perfectly. But if it spilled over onto un-sanded plexi, the fiberglass would easily peel off back to where it was sanded. I imagine the primer and paint will do the same on unsanded plexi, so I have left a small margin so that I can sand the plexi up to where the paint line stops. The Weld-on actually melts into the un-sanded plexi. I've added the "scabs" over the door hinges for the weather seal, but didn't take a picture of it after I also covered it with cloth/glass and skimmed it. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187058#187058 Attachments: http://forums.matronics.com//files/sanded_medium_209.jpg http://forums.matronics.com//files/skimmed1_medium_873.jpg http://forums.matronics.com//files/hinge_scab_2_103.jpg http://forums.matronics.com//files/hinge_scab_2_medium_156.jpg http://forums.matronics.com//files/glassed_medium_206.jpg ________________________________________________________________________________
Date: Jun 09, 2008
Bob: I hope so, the airplane is in the paint shop now and was not due for finish painting until next week. I asked them to "go slow" until I can get the parts and get over there to install. The pre-paint disassemble has already been done so that will help a little. I think the mod could be done after painting but it would be more difficult and nerve racking. We may have caught this one in the nick of time. Regards Dick sipp ----- Original Message ----- From: Bob Leffler To: rv10-list(at)matronics.com Sent: Monday, June 09, 2008 9:33 PM Subject: RE: RV10-List: Service Bulletin 08-6-1 Dick, Can you get it done before you get paint? Hopefully they haven't started yet. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rsipp Sent: Monday, June 09, 2008 8:35 PM To: rv10-list(at)matronics.com Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 09, 2008
As people complete this SB, it will be interesting to see how many others see some cracks. That will take some time to fix. I swear that even after getting the plane flying I work on it 1 hour for every hour that I fly it. (not really but sometimes it feels like that) Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: rsipp <rsipp(at)earthlink.net> Sent: Monday, June 9, 2008 6:34:49 PM Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp ________________________________________________________________________________
Subject: nostalgic airport link
Date: Jun 09, 2008
hey guys, i found this link pretty interesting, shows some airport history... steve dinieri iflyrv10.com <http://www.airfields-freeman.com/> http://www.airfields-freeman.com/ ________________________________________________________________________________
Date: Jun 10, 2008
G'day all, Removing AN470 rivets is greatly simplified with Avery's Rivet removal tool (Part #40053). But removing the rivet shank without mangling the longerons is going to be a right PITA. Anyone have any suggestions or useful techniques for removing rivets from thick material? Driving them out has not worked well for me in the past. cheers Ron -187 (who stupidly thought he was nearly finished) ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rsipp Sent: Tuesday, 10 June 2008 10:05 AM To: rv10-list(at)matronics.com Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jun 10, 2008
Yeah but Scott, You fly it ALOT!!!!=C2- jealous...another death in the family to deal wit h today...not super close but close enough.. Rick Sked 40185 ----- Original Message ----- From: "Scott Schmidt" <scottmschmidt(at)yahoo.com> Sent: Monday, June 9, 2008 7:39:35 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Service Bulletin 08-6-1 As people complete this SB, it will be interesting to see how many others s ee some cracks. That will take some time to fix.=C2- I swear that even after getting the plane flying I work on it 1 hour for ev ery hour that I fly it. (not really but sometimes it feels like that) Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: rsipp <rsipp(at)earthlink.net> Sent: Monday, June 9, 2008 6:34:49 PM Subject: RV10-List: Service Bulletin 08-6-1 ==== ==== ======================= == ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Date: Jun 10, 2008
Yep but will give me something to do since the DYNON is still not back from being repaired. Thick material I take the head off give a tap and with pliers give the driven part of the rivet a turn to loosen it. Chris Chris ----- Original Message ----- From: McGANN, Ron To: rv10-list(at)matronics.com Sent: Tuesday, June 10, 2008 1:43 PM Subject: RE: RV10-List: Service Bulletin 08-6-1 G'day all, Removing AN470 rivets is greatly simplified with Avery's Rivet removal tool (Part #40053). But removing the rivet shank without mangling the longerons is going to be a right PITA. Anyone have any suggestions or useful techniques for removing rivets from thick material? Driving them out has not worked well for me in the past. cheers Ron -187 (who stupidly thought he was nearly finished) ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rsipp Sent: Tuesday, 10 June 2008 10:05 AM To: rv10-list(at)matronics.com Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web sight. We have some work to do. Dick Sipp p://www.matronics.com/Navigator?RV10-List ics.com .matronics.com/contribution "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jun 10, 2008
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Not the package I was hoping for from Van's when I got home today! (SB package on my doorstep) TDT Tim Dawson-Townsend 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jun 10, 2008
So, ....... we've got a 'fix . . .' (a.k.a. SB) but it leaves me wondering about what caused the cracks in the 1st place? What is going on that would / is causing a crack/s to appear in that bulkhead at those location? (Root Cause) I'm not an engineer, but most cases of cracks that I've heard of are the result of fatigue due to stress, or vibration, or ........? I recall a past thread that spoke about someone who had witnessed the regular 'twisting' of the horizontal stab. IIRC the suspected cause of the twist was the 'unsynchronized' movement of the trim tabs. Could this be contributing to this situation???? I'd like to hear from the engineers out there. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ > * > * ________________________________________________________________________________
Date: Jun 10, 2008
No science involved but......when the airplane stalls there is a fair amount of tail buffet......vibration......maybe the demonstrator A/C will be the only one that develops these cracks due to the type of flying it does?????? It will be interesting to see if anyone else finds the cracks. I plan on doing my inspection today, will let the list know what I find, if anything. Let's see, I have a new plane that has two mandatory (in my mind) inspection requirements, one for the fuel servo and one for the tail. And I had to disassemble the Vertical Stabilizer already to deal with another SB. I am with Scott, it seems like I will spend as much time working on the plane as I will flying it.......but of course that is not really true in that I have 34 hours on the airframe and may have spent 4 hours working on it (inspections, oil, rigging). I have yet to really finish the airplane and am finding it hard to do it. I am still working on the wheel fairings, at the painter finally, and have a fair amount of interior work to finish up. It is just that when I have free time and the weather is nice.....I fly. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Tuesday, June 10, 2008 3:04 AM Subject: Re: RV10-List: Service Bulletin So, ....... we've got a 'fix . . .' (a.k.a. SB) but it leaves me wondering about what caused the cracks in the 1st place? What is going on that would / is causing a crack/s to appear in that bulkhead at those location? (Root Cause) I'm not an engineer, but most cases of cracks that I've heard of are the result of fatigue due to stress, or vibration, or ........? I recall a past thread that spoke about someone who had witnessed the regular 'twisting' of the horizontal stab. IIRC the suspected cause of the twist was the 'unsynchronized' movement of the trim tabs. Could this be contributing to this situation???? I'd like to hear from the engineers out there. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ > * > * ________________________________________________________________________________
Subject: Re: : RV10-List:
Date: Jun 10, 2008
-----Original Message----- From: "McGANN, Ron" <ron.mcgann(at)baesystems.com> Date: Mon, 09 Jun 2008 12:09:29 To:rv10-list(at)matronics.com Subject: RV10-List: ________________________________________________________________________________
Date: Jun 10, 2008
A good reason for selling my future, beautifully completed RV10 and getting a two place sailplane. Just have to tell the third person in my family tou gh luck you can't go today. My single place sailplane, 500+ hours and no pr oblems. Except for vacuuming and washing, almost maintainence free. One step forward one step back. Think I'll keep working toward completion to make sure this cures the probl em before I tear it down. John G. 409 Date: Mon, 9 Jun 2008 19:39:35 -0700From: scottmschmidt(at)yahoo.comSubject: R e: RV10-List: Service Bulletin 08-6-1To: rv10-list(at)matronics.com As people complete this SB, it will be interesting to see how many others s ee some cracks. That will take some time to fix. I swear that even after g etting the plane flying I work on it 1 hour for every hour that I fly it. ( not really but sometimes it feels like that) Scott Schmidtscottmschmidt(at)yahoo.com ----- Original Message ----From: rsipp <rsipp(at)earthlink.net>To: rv10-list@m atronics.comSent: Monday, June 9, 2008 6:34:49 PMSubject: RV10-List: Servic e Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web ________________________________________________________________________________
Date: Jun 10, 2008
I would really like to see pictures of what Van's found when the decided to issue these types of service bulletins. It would benefit us all on what exactly we should be looking for and where and how severe it was. Ray Doerr I just finished putting the tail back together a few week ago after paint. It never ends. N519RV (40250) 376 hours. ---- Rene Felker wrote: > > > No science involved but......when the airplane stalls there is a fair amount > of tail buffet......vibration......maybe the demonstrator A/C will be the > only one that develops these cracks due to the type of flying it does?????? > It will be interesting to see if anyone else finds the cracks. I plan on > doing my inspection today, will let the list know what I find, if anything. > > Let's see, I have a new plane that has two mandatory (in my mind) inspection > requirements, one for the fuel servo and one for the tail. And I had to > disassemble the Vertical Stabilizer already to deal with another SB. I am > with Scott, it seems like I will spend as much time working on the plane as > I will flying it.......but of course that is not really true in that I have > 34 hours on the airframe and may have spent 4 hours working on it > (inspections, oil, rigging). > > I have yet to really finish the airplane and am finding it hard to do it. I > am still working on the wheel fairings, at the painter finally, and have a > fair amount of interior work to finish up. It is just that when I have free > time and the weather is nice.....I fly. > > Rene' Felker > RV-10 N423CF Flying > 801-721-6080 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Tuesday, June 10, 2008 3:04 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Service Bulletin > > > > So, ....... we've got a 'fix . . .' (a.k.a. SB) but it leaves me > wondering about what caused the cracks in the 1st place? What is going > on that would / is causing a crack/s to appear in that bulkhead at those > location? (Root Cause) I'm not an engineer, but most cases of cracks > that I've heard of are the result of fatigue due to stress, or > vibration, or ........? I recall a past thread that spoke about > someone who had witnessed the regular 'twisting' of the horizontal stab. > IIRC the suspected cause of the twist was the 'unsynchronized' movement > of the trim tabs. Could this be contributing to this situation???? I'd > like to hear from the engineers out there. > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > > > * > > * > > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2008
When I call Van's for questions I am usually told that its fine to have some issues I feel may be a structural concern (aka replacing rivets with a pop rivet, etc). The way I see SB's from Van's are that it's something serious enough that they want it resolved. They admit there is something that IS a structural shortfall/concern and should be improved/replaced. Many have complained of shortfalls on some parts from Van's , but Van's has not always sent out an SB on it (WD-415 was improved to resolve a shortfall but not replaced with parts in the mail, there is the landing gear shimmy, etc) My point is regardless of how bad the crack is.. Van's is sending parts out for everyone to replace as needed. As the builder it's up to us to determine if we want that extra layer of protection, even if the crack never occurs, I'm with do the work now versus stressing about it later- Like insurance I sure hope it's never an issue but I'm glad I did all I could to protect myself if it ever does. Nothing wrong with making it stronger. Deems has a great point about.. why? maybe understanding the trim issue or other as to why this SB is needed might resolve other issues in the future. John Cox, maybe you can get the "rest of the story" for us. Pascal -------------------------------------------------- From: <rdoerr(at)kc.rr.com> Sent: Tuesday, June 10, 2008 8:21 AM Subject: RE: RV10-List: Service Bulletin > > I would really like to see pictures of what Van's found when the decided > to issue these types of service bulletins. It would benefit us all on > what exactly we should be looking for and where and how severe it was. > > Ray Doerr > I just finished putting the tail back together a few week ago after paint. > It never ends. > > > N519RV (40250) 376 hours. > > ---- Rene Felker wrote: >> >> >> No science involved but......when the airplane stalls there is a fair >> amount >> of tail buffet......vibration......maybe the demonstrator A/C will be the >> only one that develops these cracks due to the type of flying it >> does?????? >> It will be interesting to see if anyone else finds the cracks. I plan on >> doing my inspection today, will let the list know what I find, if >> anything. >> >> Let's see, I have a new plane that has two mandatory (in my mind) >> inspection >> requirements, one for the fuel servo and one for the tail. And I had to >> disassemble the Vertical Stabilizer already to deal with another SB. I >> am >> with Scott, it seems like I will spend as much time working on the plane >> as >> I will flying it.......but of course that is not really true in that I >> have >> 34 hours on the airframe and may have spent 4 hours working on it >> (inspections, oil, rigging). >> >> I have yet to really finish the airplane and am finding it hard to do it. >> I >> am still working on the wheel fairings, at the painter finally, and have >> a >> fair amount of interior work to finish up. It is just that when I have >> free >> time and the weather is nice.....I fly. >> >> Rene' Felker >> RV-10 N423CF Flying >> 801-721-6080 >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis >> Sent: Tuesday, June 10, 2008 3:04 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Service Bulletin >> >> >> >> So, ....... we've got a 'fix . . .' (a.k.a. SB) but it leaves me >> wondering about what caused the cracks in the 1st place? What is going >> on that would / is causing a crack/s to appear in that bulkhead at those >> location? (Root Cause) I'm not an engineer, but most cases of cracks >> that I've heard of are the result of fatigue due to stress, or >> vibration, or ........? I recall a past thread that spoke about >> someone who had witnessed the regular 'twisting' of the horizontal stab. >> IIRC the suspected cause of the twist was the 'unsynchronized' movement >> of the trim tabs. Could this be contributing to this situation???? I'd >> like to hear from the engineers out there. >> >> Deems Davis # 406 >> 'Its all done....Its just not put together' >> http://deemsrv10.com/ >> >> >> > * >> > * >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: S.B. and A.D.
Date: Jun 10, 2008
The likes of cirrus ,cessna beech and commander all have S.B. and A.D.s.Cirrus had many in its first 150 aircraft.It is to our and our families advantage that vans provides these services,most kitplanes are not around long enough to issue these bulletines.It is a pain in the ass to comply but that is the reality of airplane ownership.I just reassembled my aircraft after paint. ________________________________________________________________________________
Date: Jun 10, 2008
Good idea. Remember the V tail Bonanza: fixed a few times before it finally had enough rivets and doublers in the tail. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Tuesday, June 10, 2008 8:08 AM Subject: RE: RV10-List: Service Bulletin 08-6-1 A good reason for selling my future, beautifully completed RV10 and getting a two place sailplane. Just have to tell the third person in my family tough luck you can't go today. My single place sailplane, 500+ hours and no problems. Except for vacuuming and washing, almost maintainence free. One step forward one step back. Think I'll keep working toward completion to make sure this cures the problem before I tear it down. John G. 409 _____ Date: Mon, 9 Jun 2008 19:39:35 -0700 From: scottmschmidt(at)yahoo.com Subject: Re: RV10-List: Service Bulletin 08-6-1 As people complete this SB, it will be interesting to see how many others see some cracks. That will take some time to fix. I swear that even after getting the plane flying I work on it 1 hour for every hour that I fly it. (not really but sometimes it feels like that) Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: rsipp <rsipp(at)earthlink.net> Sent: Monday, June 9, 2008 6:34:49 PM Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 10, 2008
Just talked with my buddy at the BAC and we looked at the digital pictures I took of the area this morning. The problem area as determined by Vans is the tab that is riveted to the side of the longeron. He noticed that the tab is not radiused and we may be able to radius it and prevent a crack. Also since we installed the outside fasteners as an interference fit HiLoc there is no possible movement in that area. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Tuesday, June 10, 2008 8:56 AM Subject: Re: RV10-List: Service Bulletin When I call Van's for questions I am usually told that its fine to have some issues I feel may be a structural concern (aka replacing rivets with a pop rivet, etc). The way I see SB's from Van's are that it's something serious enough that they want it resolved. They admit there is something that IS a structural shortfall/concern and should be improved/replaced. Many have complained of shortfalls on some parts from Van's , but Van's has not always sent out an SB on it (WD-415 was improved to resolve a shortfall but not replaced with parts in the mail, there is the landing gear shimmy, etc) My point is regardless of how bad the crack is.. Van's is sending parts out for everyone to replace as needed. As the builder it's up to us to determine if we want that extra layer of protection, even if the crack never occurs, I'm with do the work now versus stressing about it later- Like insurance I sure hope it's never an issue but I'm glad I did all I could to protect myself if it ever does. Nothing wrong with making it stronger. Deems has a great point about.. why? maybe understanding the trim issue or other as to why this SB is needed might resolve other issues in the future. John Cox, maybe you can get the "rest of the story" for us. Pascal -------------------------------------------------- From: <rdoerr(at)kc.rr.com> Sent: Tuesday, June 10, 2008 8:21 AM Subject: RE: RV10-List: Service Bulletin > > I would really like to see pictures of what Van's found when the > decided to issue these types of service bulletins. It would benefit > us all on what exactly we should be looking for and where and how severe it was. > > Ray Doerr > I just finished putting the tail back together a few week ago after paint. > It never ends. > > > N519RV (40250) 376 hours. > > ---- Rene Felker wrote: >> >> >> No science involved but......when the airplane stalls there is a fair >> amount of tail buffet......vibration......maybe the demonstrator A/C >> will be the only one that develops these cracks due to the type of >> flying it does?????? >> It will be interesting to see if anyone else finds the cracks. I >> plan on doing my inspection today, will let the list know what I >> find, if anything. >> >> Let's see, I have a new plane that has two mandatory (in my mind) >> inspection requirements, one for the fuel servo and one for the tail. >> And I had to disassemble the Vertical Stabilizer already to deal with >> another SB. I am with Scott, it seems like I will spend as much time >> working on the plane as I will flying it.......but of course that is >> not really true in that I have >> 34 hours on the airframe and may have spent 4 hours working on it >> (inspections, oil, rigging). >> >> I have yet to really finish the airplane and am finding it hard to do it. >> I >> am still working on the wheel fairings, at the painter finally, and >> have a fair amount of interior work to finish up. It is just that >> when I have free time and the weather is nice.....I fly. >> >> Rene' Felker >> RV-10 N423CF Flying >> 801-721-6080 >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems >> Davis >> Sent: Tuesday, June 10, 2008 3:04 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Service Bulletin >> >> >> >> So, ....... we've got a 'fix . . .' (a.k.a. SB) but it leaves me >> wondering about what caused the cracks in the 1st place? What is >> going on that would / is causing a crack/s to appear in that bulkhead >> at those location? (Root Cause) I'm not an engineer, but most cases >> of cracks that I've heard of are the result of fatigue due to stress, >> or vibration, or ........? I recall a past thread that spoke about >> someone who had witnessed the regular 'twisting' of the horizontal stab. >> IIRC the suspected cause of the twist was the 'unsynchronized' >> movement of the trim tabs. Could this be contributing to this >> situation???? I'd like to hear from the engineers out there. >> >> Deems Davis # 406 >> 'Its all done....Its just not put together' >> http://deemsrv10.com/ >> >> >> > * >> > * >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jun 10, 2008
Just spoke with Vans and the pictures will be going up on their website. The crack was near the tab that steps up to attach to the longeron. He did agree that HiLocs could be installed there probably easier than rivets and that it may be possible to install the doublers without pulling the top up -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rdoerr(at)kc.rr.com Sent: Tuesday, June 10, 2008 8:22 AM Subject: RE: RV10-List: Service Bulletin I would really like to see pictures of what Van's found when the decided to issue these types of service bulletins. It would benefit us all on what exactly we should be looking for and where and how severe it was. Ray Doerr I just finished putting the tail back together a few week ago after paint. It never ends. N519RV (40250) 376 hours. ---- Rene Felker wrote: > > > No science involved but......when the airplane stalls there is a fair > amount of tail buffet......vibration......maybe the demonstrator A/C > will be the only one that develops these cracks due to the type of flying it does?????? > It will be interesting to see if anyone else finds the cracks. I plan > on doing my inspection today, will let the list know what I find, if anything. > > Let's see, I have a new plane that has two mandatory (in my mind) > inspection requirements, one for the fuel servo and one for the tail. > And I had to disassemble the Vertical Stabilizer already to deal with > another SB. I am with Scott, it seems like I will spend as much time > working on the plane as I will flying it.......but of course that is > not really true in that I have > 34 hours on the airframe and may have spent 4 hours working on it > (inspections, oil, rigging). > > I have yet to really finish the airplane and am finding it hard to do > it. I am still working on the wheel fairings, at the painter finally, > and have a fair amount of interior work to finish up. It is just that > when I have free time and the weather is nice.....I fly. > > Rene' Felker > RV-10 N423CF Flying > 801-721-6080 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Tuesday, June 10, 2008 3:04 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Service Bulletin > > > > So, ....... we've got a 'fix . . .' (a.k.a. SB) but it leaves me > wondering about what caused the cracks in the 1st place? What is > going on that would / is causing a crack/s to appear in that bulkhead > at those location? (Root Cause) I'm not an engineer, but most cases of > cracks that I've heard of are the result of fatigue due to stress, or > vibration, or ........? I recall a past thread that spoke about > someone who had witnessed the regular 'twisting' of the horizontal stab. > IIRC the suspected cause of the twist was the 'unsynchronized' > movement of the trim tabs. Could this be contributing to this > situation???? I'd like to hear from the engineers out there. > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > > > * > > * > > > > > > > > ________________________________________________________________________________
Subject: Emailing: IMG_1258
Date: Jun 10, 2008
My discussion with Vans indicated the tab riveted to the longeron just to the left of the red collar is the tab that showed cracks. ________________________________________________________________________________
Date: Jun 10, 2008
The truth is I get alot of enjoyment out of the flying, the work and maintenance. I don't have to work on it as much as I do but I want to make sure I am at the front of the useful life curve on everything. When you change the oil every 25 hours, new brakes every 150 - 200 hours, prop lube every 100 hours, tire rotation about every 150 hours, new plugs in the electronic ignition every 100 - 125 hours, the annual every year and then little things that you want to improve, you put some time into the plane. But in return for all the work I have a totally awesome cross country machine that I can travel with and is completely reliable. When I get ready to go somewhere I don't even think twice about something failing because I know the maintenance has been completed and everything is in proper working order. With a Cirrus or other production plane, you really have no idea if something is wrong because you don't get the feel for when things are 50% worn and need replacing. With a new plane we can probably expect a few issues like this. It is still one of the most fun four place planes out there. Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: John Gonzalez <indigoonlatigo(at)msn.com> Sent: Tuesday, June 10, 2008 9:08:12 AM Subject: RE: RV10-List: Service Bulletin 08-6-1 A good reason for selling my future, beautifully completed RV10 and getting a two place sailplane. Just have to tell the third person in my family tough luck you can't go today. My single place sailplane, 500+ hours and no problems. Except for vacuuming and washing, almost maintainence free. One step forward one step back. Think I'll keep working toward completion to make sure this cures the problem before I tear it down. John G. 409 ________________________________ Date: Mon, 9 Jun 2008 19:39:35 -0700 From: scottmschmidt(at)yahoo.com Subject: Re: RV10-List: Service Bulletin 08-6-1 As people complete this SB, it will be interesting to see how many others see some cracks. That will take some time to fix. I swear that even after getting the plane flying I work on it 1 hour for every hour that I fly it. (not really but sometimes it feels like that) Scott Schmidt scottmschmidt(at)yahoo.com ----- Original Message ---- From: rsipp <rsipp(at)earthlink.net> Sent: Monday, June 9, 2008 6:34:49 PM Subject: RV10-List: Service Bulletin 08-6-1 Just saw a new service bulletin on the RV10 on Van's web get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 10, 2008
UmVnYXJkaW5nIFRpbSdzIGNvbW1lbnQNCg0KIk9uZSBwZXJzb24gc3VnZ2VzdGVkIHVzaW5nIGEg aGktcmVzIGRpZ2l0YWwgY2FtZXJhIChvciBIRCB2aWRlbyBjYW0gZm9yIHRoYXQgbWF0dGVyLi4u SSBqdXN0IGdvdCBvbmUpIHRvIGRvIHRoZSBpbnNwZWN0aW9uLg0KDQpQcm9iYWJseSBhIGdyZWF0 IGlkZWEuIg0KDQogDQoNCkkganVzdCBjYW1lIGFjcm9zcyB0aGlzIGRldmljZSBjYWxsZWQgYSBR dWlja1BvZCAofiQyNS4wMCkgT25lIGNvdWxkIHNldCB0aGUgdGltZXIgZm9yIGEgcGhvdG8gb3Ig anVzdCB2aWRlbyB0aGUgYXJlYToNCg0KIA0KDQogDQoNCiANCg0KIA0KDQo ________________________________________________________________________________
Date: Jun 10, 2008
IF THAT IS INDEED THE PROBLEM, IT SEEMS IN MY OPINION GETTING RID OF THE TA B WOULD BE BETTER THAN TRYING TO USE A DOUBLER. THE TAB CURRENTLY AS IS IS LIKE THE PULL TAB ON A COKE CAN, IT SERVES AS A WAY TO START THE TEAR. JOHN G. 409> From: dlm46007(at)cox.net> To: rv10-list(at)matronics.com> Subject: RV10-List: Emailing: IMG_1258> Date: Tue, 10 Jun 2008 11:51:21 -0700> > > M y discussion with Vans indicated the tab riveted to the longeron just to> t he left of the red collar is the tab that showed cracks. ________________________________________________________________________________
Date: Jun 10, 2008
By using a digital camera to tap a few pictures of the area, I'll bet you can put the camera in the rear inspect cover opening and be able to see this area well instead of removing the emp fairing which has a ton more screws. Thoughts? Ray Doerr ---- Robin Marks wrote: > Regarding Tim's comment > > "One person suggested using a hi-res digital camera (or HD video cam for that matter...I just got one) to do the inspection. > > Probably a great idea." > > > > I just came across this device called a QuickPod (~$25.00) One could set the timer for a photo or just video the area: > > > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2008
we also considered getting rid of the tag but it will take a pencil grinder and some contortions getting a view of the work while grinding. As an alternative we are considering creating a radius so that the sharp corner does not exist and prevent the tear in the first place. If that is not sufficient and we do install the doublers,we will not pull up the top but work through the top holes and probably install doublers that will also hook to the external skin as well. a flange for the part exist but no pilot holes are in it. With just 33 hours TT we have a while to think on this problem. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Tuesday, June 10, 2008 1:07 PM Subject: RE: RV10-List: Emailing: IMG_1258 IF THAT IS INDEED THE PROBLEM, IT SEEMS IN MY OPINION GETTING RID OF THE TAB WOULD BE BETTER THAN TRYING TO USE A DOUBLER. THE TAB CURRENTLY AS IS IS LIKE THE PULL TAB ON A COKE CAN, IT SERVES AS A WAY TO START THE TEAR. JOHN G. 409 > From: dlm46007(at)cox.net > To: rv10-list(at)matronics.com > Subject: RV10-List: Emailing: IMG_1258 > Date: Tue, 10 Jun 2008 11:51:21 -0700 > > > My discussion with Vans indicated the tab riveted to the longeron just to > the left of the red collar is the tab that showed cracks. ________________________________________________________________________________
Subject: Drilling out 1/8" rivets (was Service Bulletin 08-6-1)
Date: Jun 10, 2008
This is what I do: 1. Use #30 bit to drill into the rivet head just enough so that you can pop it off. 2. Use #40 bit to drill into the shank of the rivet. Be careful to drill straight. The objective is to drill out the center of the shank and not touch the adjacent material. 3. Use a vise grip pliers on the manufactured head to pull out the now hollow rivet shank. Carl Froehlich RV-8A (425 hrs) RV-10 (ailerons) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron Sent: Monday, June 09, 2008 11:43 PM Subject: RE: RV10-List: Service Bulletin 08-6-1 G'day all, Removing AN470 rivets is greatly simplified with Avery's Rivet removal tool (Part #40053). But removing the rivet shank without mangling the longerons is going to be a right PITA. Anyone have any suggestions or useful techniques for removing rivets from thick material? Driving them out has not worked well for me in the past. cheers Ron -187 (who stupidly thought he was nearly finished) ________________________________________________________________________________
Subject: SB Info
Date: Jun 10, 2008
I just got this from Ken at Van's. This explains where the damage occurred. He said that it could possibly be because their plane is used a little more harshly than the average because of the transition training, that is no license to just ignore it, which I don't think many were considering anyway. Just FYI. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Subject: SB Info
Date: Jun 10, 2008
It would be great if you guys would add whether you are talking K. Scott or K. Krueger when offering advice from VANS. Maybe they have a Ken in shipping, Ken on cleanup and Ken in accounting. One is their propaganda minister and the other is a certified professional aeronautical engineer. One is fairly verbose and the other fairly quiet and conservative. This reminds me of many newspaper movie reviews that read "Ken G. of the #$% says it is a summer blockbuster hit". JC From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Tuesday, June 10, 2008 4:21 PM Subject: RV10-List: SB Info I just got this from Ken at Van's. This explains where the damage occurred. He said that it could possibly be because their plane is used a little more harshly than the average because of the transition training, that is no license to just ignore it, which I don't think many were considering anyway. Just FYI. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Date: Jun 10, 2008
Did the inspection tonight and all is well after 34 hours. Took about 15 minutes and was easy to get a good look with the fairing off. Rene' N423CF Flying 801-721-6080 ________________________________________________________________________________
Subject: GRT Serial Connections
Date: Jun 11, 2008
We are in the process of wiring our panel and would like to know if there is anyone who has the same combination of avionics we have. We are running into problems with the number of available serial ports to communicate with. We are also uncertain as to what information is communicated via the inter panel communication channels. Is there anyone else with this combination: (3) GRT HS Displays (One display has the ARINC 429, One Display has an internal GPS, The last display is 'plain') GRT XM Weather Garmin GNS430W Garmin SL30 Garmin GTX327 Garmin GMA347 Tru-Trak VSGVII Anyone else already been through this? If so we would really like the opportunity to pick your brain. Thanks, Jason Kreidler 4-Partner Build (Jason Kreidler, Tony Kolar, Kyle Hokel, Wayne Elsner) Sheboygan Falls, WI #40617 Finishing ________________________________________________________________________________
Date: Jun 11, 2008
I talked to another builder last night who had just completed the SB on his newly painted but not-yet-flying RV-10. In fact, he had JUST finished mounting the tail and was finalizing his trim tab settings when he got the SB. Sounds like the time involved is less than 4 hours for disassembly, and a little over 4 hours for re-assembly, and that the riveting itself is very easy. So you can plan on probably being able to tackle it in a 10 hour day or less if everything goes smoothly. I'm not sure exactly when I'll get mine done, but I'm hoping to make it relatively soon, so I'll report back too. Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Subject: Re: GRT Serial Connections
Date: Jun 11, 2008
Jason. I have an almost identical set up with the exception of Garmin 530W and no SL30. Call me later today 772-460-3907, say about 4:00 PM eastern and I can fire up the panel and read you the set up. As an alternative, I think that I can back up my settings and email them to you. You may also contact GRT. They are VERY helpful. Regards Rob. On Jun 11, 2008, at 8:25 AM, jason.kreidler(at)regalbeloit.com wrote: > > We are in the process of wiring our panel and would like to know if > there is anyone who has the same combination of avionics we have. > We are running into problems with the number of available serial > ports to communicate with. We are also uncertain as to what > information is communicated via the inter panel communication > channels. > > Is there anyone else with this combination: > (3) GRT HS Displays (One display has the ARINC 429, One Display has > an internal GPS, The last display is 'plain') > GRT XM Weather > Garmin GNS430W > Garmin SL30 > Garmin GTX327 > Garmin GMA347 > Tru-Trak VSGVII > > Anyone else already been through this? If so we would really like > the opportunity to pick your brain. > > Thanks, Jason Kreidler > 4-Partner Build (Jason Kreidler, Tony Kolar, Kyle Hokel, Wayne Elsner) > Sheboygan Falls, WI > #40617 Finishing > > ________________________________________________________________________________
Date: Jun 11, 2008
Jason, I sent you an email off list - I have almost identical except 480 instead of 430W and a 330 instead of 327. Bob N442PM flying _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com Sent: Wednesday, June 11, 2008 7:25 AM Subject: RV10-List: GRT Serial Connections We are in the process of wiring our panel and would like to know if there is anyone who has the same combination of avionics we have. We are running into problems with the number of available serial ports to communicate with. We are also uncertain as to what information is communicated via the inter panel communication channels. Is there anyone else with this combination: (3) GRT HS Displays (One display has the ARINC 429, One Display has an internal GPS, The last display is 'plain') GRT XM Weather Garmin GNS430W Garmin SL30 Garmin GTX327 Garmin GMA347 Tru-Trak VSGVII Anyone else already been through this? If so we would really like the opportunity to pick your brain. Thanks, Jason Kreidler 4-Partner Build (Jason Kreidler, Tony Kolar, Kyle Hokel, Wayne Elsner) Sheboygan Falls, WI #40617 Finishing ________________________________________________________________________________
Subject: SB Info
Date: Jun 11, 2008
The thing that bothers my mind about this type of repair/doubler is that th e bulkhead is made of relatively thin material. We are then backing it up w ith a doubler that is to structurely reinforce the area, but in the process we are fastening it onto the area with more holes/rivets. If the strain is not entirely transfered to the entire area of the interface between the do ubler and the bulkhead, then the stain will be more so transferred to the f astening locations/rivets and thus can't those holes increase the chance of crack propogation. Why is not a flexible bonding method of fastening the double a possibly bet ter avenue as it would tranfer the strain over a much larger surface area?? ? JOhn G. 409 From: jesse(at)saintaviation.comTo: rv10-list(at)matronics.comSubject: RV10-List: SB InfoDate: Tue, 10 Jun 2008 19:20:51 -0400I just got this from Ken at Va n's. This explains where the damage occurred. He said that it could possi bly be because their plane is used a little more harshly than the average b ecause of the transition training, that is no license to just ignore it, wh ich I don't think many were considering anyway. Just FYI. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Subject: SB
Date: Jun 11, 2008
I spoke with Scott R at Vans and the pictures of the actual crack should be on their site by tomorrow. I don't believe that the diagram as previously reported is correct, as the flat version of the part would actually have two tabs at the outboard top edge. My understanding is that the crack would be in the tab that is riveted to the longeron. ________________________________________________________________________________
Date: Jun 11, 2008
Subject: Re: SB Info
This seems to be where we get to rely on decades worth of aluminum aircraft engineering knowledge. Using known materials and a reliable connector process applied in a specific way, we have a reliable fix. Though it's probably noteworthy that the same approach was taken with the original design that is now showing cracks (but no failures). I'm guessing that a flexible bonding method might be superior - but I have a difficult time thinking of how a reliable bonding process could be defined and followed reliably in my shop. Temperature, surface treatment and all that. I can deburr the parts and drive a dozen rivets to a spec. I'm never 100% sure my last epoxy job is to spec. Bill "still worrying the doors into place" Watson John Gonzalez wrote: > The thing that bothers my mind about this type of repair/doubler is > that the bulkhead is made of relatively thin material. We are then > backing it up with a doubler that is to structurely reinforce the > area, but in the process we are fastening it onto the area with more > holes/rivets. If the strain is not entirely transfered to the entire > area of the interface between the doubler and the bulkhead, then the > stain will be more so transferred to the fastening locations/rivets > and thus can't those holes increase the chance of crack propogation. > > Why is not a flexible bonding method of fastening the double a > possibly better avenue as it would tranfer the strain over a much > larger surface area??? > > JOhn G. 409 > > * > * ________________________________________________________________________________
Date: Jun 11, 2008
The way I have happily gone building the plane is thinking that by deburring the edges and holes and assuring they are rounded spreads the stress over the specific area. With rivets that are properly squeezed (read not excessively, which would stress the hole) I think the doubler would have enough holes spread out to diminish any one area except as a whole and in turn be a stronger solution than before adding it.. P From: John Gonzalez Sent: Wednesday, June 11, 2008 7:58 AM Subject: RE: RV10-List: SB Info The thing that bothers my mind about this type of repair/doubler is that the bulkhead is made of relatively thin material. We are then backing it up with a doubler that is to structurely reinforce the area, but in the process we are fastening it onto the area with more holes/rivets. If the strain is not entirely transfered to the entire area of the interface between the doubler and the bulkhead, then the stain will be more so transferred to the fastening locations/rivets and thus can't those holes increase the chance of crack propogation. Why is not a flexible bonding method of fastening the double a possibly better avenue as it would tranfer the strain over a much larger surface area??? JOhn G. 409 ------------------------------------------------------------------------- ----- From: jesse(at)saintaviation.com To: rv10-list(at)matronics.com Subject: RV10-List: SB Info Date: Tue, 10 Jun 2008 19:20:51 -0400 I just got this from Ken at Van's. This explains where the damage occurred. He said that it could possibly be because their plane is used a little more harshly than the average because of the transition training, that is no license to just ignore it, which I don't think many were considering anyway. Just FYI. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Subject: GRT and 430 waas upgrade-help
Date: Jun 11, 2008
Has anyone with a grt panel had the waas upgrade.If so have you been succesful in getting the glideslope and localizer to display on the grt.I reconfigured the gps to the arnc settings per grand rapids but the gps messages that it is not recieving the arnc.I hesitate to change the wiring to display the waas glideslope info until I can solve the ILS display probem.The garmin indicator displays as normal.Thanks-jim? 728DD ________________________________________________________________________________
Date: Jun 11, 2008
Jason, Your GRT configuration is and will probably continue to be a popular configuration. I still have not decided on which solution I'm going with and will probably not for a while yet even though most of the electrical work is done. Why don't you share with the list what you are trying to accomplish. Those that have sent suggestion off list, might I suggest sharing with the list for those that are considering this same configuration. http://nerv10.com/wcurtis/91Panel/10PanelGRT.jpg http://nerv10.com/wcurtis/91Panel/index.html Remember, for each transmit (Tx) serial line you can have multiple receivers (Rx). Many of your listed devices only require one or the other. Only a few require both Tx and Rx. GNS430; Tx Aviation data to EFIS1/2, GTX327, TT VSGV EFIS; Tx Icarus altitude data to GNS430, GTX327 EFIS; Tx / Rx to - from SL-30 I'll have to look up what the GRT XM Weather requires. William http://nerv10.com/wcurtis/ -------- Original Message -------- > X-Rcpt-To: > > Jason. I have an almost identical set up with the exception of Garmin > 530W and no SL30. Call me later today 772-460-3907, say about 4:00 PM > eastern and I can fire up the panel and read you the set up. As an > alternative, I think that I can back up my settings and email them to > you. You may also contact GRT. They are VERY helpful. > > Regards > Rob. > > On Jun 11, 2008, at 8:25 AM, jason.kreidler(at)regalbeloit.com wrote: > > > > > We are in the process of wiring our panel and would like to know if > > there is anyone who has the same combination of avionics we have. > > We are running into problems with the number of available serial > > ports to communicate with. We are also uncertain as to what > > information is communicated via the inter panel communication > > channels. > > > > Is there anyone else with this combination: > > (3) GRT HS Displays (One display has the ARINC 429, One Display has > > an internal GPS, The last display is 'plain') > > GRT XM Weather > > Garmin GNS430W > > Garmin SL30 > > Garmin GTX327 > > Garmin GMA347 > > Tru-Trak VSGVII > > > > Anyone else already been through this? If so we would really like > > the opportunity to pick your brain. > > > > Thanks, Jason Kreidler > > 4-Partner Build (Jason Kreidler, Tony Kolar, Kyle Hokel, Wayne Elsner) > > Sheboygan Falls, WI > > #40617 Finishing > > > > ________________________________________________________________________________
Date: Jun 11, 2008
Using GRT Wx with the WS/HS versions of the GRT requires high speed serial inputs to each DU (as opposed to using inter-DU communication). When the new HX displays are on the scene they will use USB directly to the Wx receiver (processor box not needed with the HX). Only ports 1 & 2 on the WS/HS support the 115,200 high speed serial rate. For redundancy there are some cases where a single device (like the AHRS/ADC) feeds multiple DUs. I'd be happy to email my connectivity and configuration documents to those interested. My panel config has the following so it's pretty complete starting point: GRT (3 screens) PMA-8000B SL-30 GNS-480 GTX-330 TruTrak Digiflight II-VSGV GRT Weather receiver/processor CO Guardian 353 AOA Pro It is a relatively minor wiring difference between the GNS-480 I'm using and a 430W and doesn't impact the serial port configuration. Bob N442PM -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Wednesday, June 11, 2008 2:47 PM Subject: Re: RV10-List: GRT Serial Connections Jason, Your GRT configuration is and will probably continue to be a popular configuration. I still have not decided on which solution I'm going with and will probably not for a while yet even though most of the electrical work is done. Why don't you share with the list what you are trying to accomplish. Those that have sent suggestion off list, might I suggest sharing with the list for those that are considering this same configuration. http://nerv10.com/wcurtis/91Panel/10PanelGRT.jpg http://nerv10.com/wcurtis/91Panel/index.html Remember, for each transmit (Tx) serial line you can have multiple receivers (Rx). Many of your listed devices only require one or the other. Only a few require both Tx and Rx. GNS430; Tx Aviation data to EFIS1/2, GTX327, TT VSGV EFIS; Tx Icarus altitude data to GNS430, GTX327 EFIS; Tx / Rx to - from SL-30 I'll have to look up what the GRT XM Weather requires. William http://nerv10.com/wcurtis/ ________________________________________________________________________________
Date: Jun 11, 2008
I have pretty much the same set-up. Call Carlos at GRT, he was very helpfull. I e-mailed him my set-up and he sent back a spread sheet with all the different wires and serial requirments. We have powered mine up and so far it all works. Call me if you like. Thane States 704-907-7402 ----- Original Message ----- From: jason.kreidler(at)regalbeloit.com To: rv10-list(at)matronics.com Sent: Wednesday, June 11, 2008 8:25 AM Subject: RV10-List: GRT Serial Connections We are in the process of wiring our panel and would like to know if there is anyone who has the same combination of avionics we have. We are running into problems with the number of available serial ports to communicate with. We are also uncertain as to what information is communicated via the inter panel communication channels. Is there anyone else with this combination: (3) GRT HS Displays (One display has the ARINC 429, One Display has an internal GPS, The last display is 'plain') GRT XM Weather Garmin GNS430W Garmin SL30 Garmin GTX327 Garmin GMA347 Tru-Trak VSGVII Anyone else already been through this? If so we would really like the opportunity to pick your brain. Thanks, Jason Kreidler 4-Partner Build (Jason Kreidler, Tony Kolar, Kyle Hokel, Wayne Elsner) Sheboygan Falls, WI #40617 Finishing ________________________________________________________________________________
Date: Jun 11, 2008
Subject: SB
I've been thinking about doing something to this area for some time. What I had decided to do, but had not done yet, is to put a mirror image angle on the aft side of F-1010 like on the forward side. I would then have two angles with a total of four bolts to the longeron. Not knowing all the details of the fix, they seem to treating a symptom and not the cause. It seems that an additional angle would reduce twist and also strengthen the attachment. I am planning to do this in addition to Van's SB. I would like to hear what others think. In addition, I had already planned to add another angle at the aft portion of where the VS attaches to the tailcone. Dave Syvertson 40625 (fuselage) **************Vote for your city's best dining and nightlife. City's Best 2008. (http://citysbest.aol.com?ncid=aolacg00050000000102) ________________________________________________________________________________
Subject: SB
Date: Jun 11, 2008
I just finished looking at our plane. No cracks after 141 hours. The inspection is easy with the emp fairing off. I'm not going to pull the tail off unless more people find cracks or unless there's a better reason. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Subject: SB
Date: Jun 11, 2008
agreed. The aircraft I would like to hear about are those who flew with a misrigged trim and experienced twisting force on opposite halves of the elevator. 33 hours and obviously not enough time to crack? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Wednesday, June 11, 2008 3:16 PM Subject: RV10-List: SB I just finished looking at our plane. No cracks after 141 hours. The inspection is easy with the emp fairing off. I'm not going to pull the tail off unless more people find cracks or unless there's a better reason. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Subject: SB
Date: Jun 11, 2008
Check the vans site ; the service bulletin now includes pictures of the crack and installation of the doublers. Their original description of a crack in the tab is incorrect. see the pictures ________________________________________________________________________________
Subject: SB
Date: Jun 11, 2008
Curious that the crack appeared on the left side. Seems like that is the same side that a mis rigged trim setup would cause twisting of the elevator halves in flight under some circumstances. ________________________________________________________________________________
Subject: Emailing: sb08-6-1[1]
Date: Jun 11, 2008
This is what I found about an hour ago. Look at the end of the pdf. ________________________________________________________________________________
Date: Jun 11, 2008
A few observations... 1) Is the doubler going to be thick/strong enough to keep that from happening? That's a pretty hefty crack. Seems the crack will just be on the edge of the doubler if things are moving around that much. Antenna doublers are supposed to be secured along 3 sides. I'm wondering if the rib was "forced" into position possibly installed with a bit of a bending load on it? 2) The J-Channel is contacting the bulkhead... Didn't we just discuss this? 3) I won't mention the nice long, uniform scratches in the side skin. 4) Anyone know what the pop rivets in front of the F-1010 are.... data plate? 4) I'm with Dave... must be the Continental :-) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Wednesday, June 11, 2008 7:36 PM Subject: RV10-List: Emailing: sb08-6-1[1] This is what I found about an hour ago. Look at the end of the pdf. ________________________________________________________________________________
Date: Jun 11, 2008
Oops forgot my name on the last one... Ben Westfall #40579 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Wednesday, June 11, 2008 7:36 PM Subject: RV10-List: Emailing: sb08-6-1[1] This is what I found about an hour ago. Look at the end of the pdf. ________________________________________________________________________________
Date: Jun 11, 2008
I doubt it was the engine. I just talked with someone who flew the 220 version for transition training September 2007. He squawked the aircraft for inadequate up trim. I have flown the 540 version for 33 hours and never gotten the trim setting more than 2 bars from neutral. Inadequate up trim suggest to me that a improperly rigged trim system might have the two elevator halves fighting each other and twisting the elevators and stressing the horizontal stab. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Wednesday, June 11, 2008 9:02 PM Subject: RE: RV10-List: Emailing: sb08-6-1[1] Oops forgot my name on the last one... Ben Westfall #40579 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Wednesday, June 11, 2008 7:36 PM Subject: RV10-List: Emailing: sb08-6-1[1] This is what I found about an hour ago. Look at the end of the pdf. ________________________________________________________________________________
Subject: Re: Emailing: sb08-6-1[1]
Date: Jun 12, 2008
After looking closely at the pictures, it appears that the metal is not only cracked, but also "crinkled." If you look at the skin to the left of the crack, it appears to also be deformed which concurs with the failure of the bulkhead. First thought is there was substantial down pressure (compression) on the longeron and on the F1010A angle at this point. Except when rolling, would there ever be uneven force on the HS? And even then I would think the forces would be very little. Would it be possible to detect equal tensional stress on the other side? I agree with the twisted HS theory. Dave Leikam #40496 N89DA (Reserved) Muskego, WI - Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> Sent: Wednesday, June 11, 2008 11:29 PM Subject: RE: RV10-List: Emailing: sb08-6-1[1] > > I doubt it was the engine. I just talked with someone who flew the 220 > version for transition training September 2007. He squawked the aircraft > for > inadequate up trim. I have flown the 540 version for 33 hours and never > gotten the trim setting more than 2 bars from neutral. Inadequate up trim > suggest to me that a improperly rigged trim system might have the two > elevator halves fighting each other and twisting the elevators and > stressing > the horizontal stab. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall > Sent: Wednesday, June 11, 2008 9:02 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Emailing: sb08-6-1[1] > > > Oops forgot my name on the last one... > > Ben Westfall > #40579 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill > Sent: Wednesday, June 11, 2008 7:36 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Emailing: sb08-6-1[1] > > > This is what I found about an hour ago. Look at the end of the pdf. > > > ________________________________________________________________________________
Date: Jun 11, 2008
Dave, i agreeI If folks take the time and go back through the archive and read the original posts (12/06) which witnessed the 'twist' and the follow on discussion regarding the Elevator trim rigging and how following Van's plan instructions, can and will result in a twisted HS. the situation described there is entirely consistent with the results depicted in the picture of the crack. I believe that there is a VERY high likelihood that the root cause of the crack lies in a twisting moment induced by the asynchronous movement of the elevator trim tabs. I was the individ David refers to that flew 220RV late last year, and there was not enough up elevator trim available to take the significant back pressure off the elevator during landings. I believe this is also consistent with the trim rigging and twisting explanation. Here's an excerpt from my post following transition training. **This brings up the next point and that is elevator authority. N220RV had NO balast in the rear when we flew. We initiated our approach with 20 degrees of flaps (second detent), Turning downwind we added full flaps. With full flaps there is NOT enough trim to take the back pressure off of the stick. I found that the back pressure was much more than I found comfortable, and flew some landings with 2 hands! Makes it difficult/impossible to develop a fingertip feel on landings. The other item has been reported by several others and that is when landing it takes the full aft movement of the stick. The topic has been discussed & debated previously, but in my opinion with only 2 people and no baggage/balast there is not enough elevator. Towards the end of 8.1 hours, I was able to get some of the rust scrubbed off, got a little less shy about the rapidly approaching ground, and found a way to 'muscle' a couple of good landings. then Mike says " let me show you something, .... we took another trip around the pattern flew exactly as before only on our base leg after extending full flaps, he had me 'blip' off a degree or two of flap at a time until the back pressure I'd grown unaccustomed to holding was gone..... then flew the rest of the landing !!!!! WOW!!! what a difference !!!!! Mike why did you keep this little secret to the end??????? the plane landed almost identical to full flaps, but the 'feel' was completely different and actually a joy!!!!!** Dave Leikam wrote: > > After looking closely at the pictures, it appears that the metal is > not only cracked, but also "crinkled." If you look at the skin to the > left of the crack, it appears to also be deformed which concurs with > the failure of the bulkhead. First thought is there was substantial > down pressure (compression) on the longeron and on the F1010A angle at > this point. Except when rolling, would there ever be uneven force on > the HS? And even then I would think the forces would be very > little. Would it be possible to detect equal tensional stress on the > other side? > > I agree with the twisted HS theory. > > Dave Leikam > #40496 N89DA (Reserved) > Muskego, WI > > > - Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> > To: > Sent: Wednesday, June 11, 2008 11:29 PM > Subject: RE: RV10-List: Emailing: sb08-6-1[1] > > >> >> I doubt it was the engine. I just talked with someone who flew the 220 >> version for transition training September 2007. He squawked the >> aircraft for >> inadequate up trim. I have flown the 540 version for 33 hours and never >> gotten the trim setting more than 2 bars from neutral. Inadequate up >> trim >> suggest to me that a improperly rigged trim system might have the two >> elevator halves fighting each other and twisting the elevators and >> stressing >> the horizontal stab. >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall >> Sent: Wednesday, June 11, 2008 9:02 PM >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Emailing: sb08-6-1[1] >> >> >> >> Oops forgot my name on the last one... >> >> Ben Westfall >> #40579 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill >> Sent: Wednesday, June 11, 2008 7:36 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Emailing: sb08-6-1[1] >> >> >> >> This is what I found about an hour ago. Look at the end of the pdf. >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Harmonic resonance from the new Eggenfellner Gen 3 drive?
Date: Jun 12, 2008
This might be of interest to some...from the GlaStar list: = = = = = I was reading the Eggenfellner list today and saw that several guys are now reporting harmonic resonance as a result of installing the new Gen 3 drive. It doesn't appear to matter what prop or engine you are using it with since both the 2.5 and 3.0 soobs and the Quinti prop and the MT props are involved. So, guys are saying they are hearing a repeating beat sound about once per second. Would anyone from this group that has installed the Gen 3 and been using it for a while care to comment on this? This sounds a bit concerning. Jan Eggenfellner doesn't deny that this is happening, but says it can be solved with proper prop installation, balancing, keeping things from touching the cowl and so on. So, I'm just wondering if this is just something that only a handful of guys are experiencing or ? ________________________________________________________________________________
Subject: Re: SB
Date: Jun 12, 2008
I and another RV10, both of us flying, on my field performed the SB yesterday and found no cracks. As Dave said it's fairly easy to perform the inspection with the emp fairing off, with a flex mirror and flash light. I have about 125 hours and I think the other 10 has about 60 hours. I plan on waiting on pulling the tail off for now and do like Dave and continue the inspections. Wayne Edgerton N602WT From: "Dave Saylor" <Dave(at)AirCraftersLLC.com> Subject: SB I just finished looking at our plane. No cracks after 141 hours. The inspection is easy with the emp fairing off. I'm not going to pull the tail off unless more people find cracks or unless there's a better reason. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jun 12, 2008
That was the first thing I noticed too. It certainly looks like the cracks were induced from a repeated compression and release of bulkhead in that area. Doublers may only be a band aid for this and I bet we will see more of these as the fleet gain hours. If it really is being partially caused by asymmetric trim tab loading, seems like someone could come up with a mod fairly quickly. I know I'll be looking at the trim servo setup while I have it off. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Thursday, June 12, 2008 12:36 AM Subject: Re: RV10-List: Emailing: sb08-6-1[1] After looking closely at the pictures, it appears that the metal is not only cracked, but also "crinkled." If you look at the skin to the left of the crack, it appears to also be deformed which concurs with the failure of the bulkhead. First thought is there was substantial down pressure (compression) on the longeron and on the F1010A angle at this point. Except when rolling, would there ever be uneven force on the HS? And even then I would think the forces would be very little. Would it be possible to detect equal tensional stress on the other side? I agree with the twisted HS theory. Dave Leikam #40496 N89DA (Reserved) Muskego, WI - Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> Sent: Wednesday, June 11, 2008 11:29 PM Subject: RE: RV10-List: Emailing: sb08-6-1[1] > > I doubt it was the engine. I just talked with someone who flew the 220 > version for transition training September 2007. He squawked the aircraft > for > inadequate up trim. I have flown the 540 version for 33 hours and never > gotten the trim setting more than 2 bars from neutral. Inadequate up trim > suggest to me that a improperly rigged trim system might have the two > elevator halves fighting each other and twisting the elevators and > stressing > the horizontal stab. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall > Sent: Wednesday, June 11, 2008 9:02 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Emailing: sb08-6-1[1] > > > Oops forgot my name on the last one... > > Ben Westfall > #40579 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill > Sent: Wednesday, June 11, 2008 7:36 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Emailing: sb08-6-1[1] > > > This is what I found about an hour ago. Look at the end of the pdf. > > ________________________________________________________________________________
Date: Jun 12, 2008
Hmm, surprised he didn't catch that in his testing phase of the design. ;-) Bet you money there is an "improvement" by this time next year and he denies any issues right up to that point. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John Jessen Sent: Thursday, June 12, 2008 5:28 AM Subject: RV10-List: Harmonic resonance from the new Eggenfellner Gen 3 driv e? This might be of interest to some...from the GlaStar list: = = = = I was reading the Eggenfellner list today and saw that several guys are now reporting harmonic resonance as a result of installing the new Gen 3 drive . It doesn't appear to matter what prop or engine you are using it with sin ce both the 2.5 and 3.0 soobs and the Quinti prop and the MT props are invo lved. So, guys are saying they are hearing a repeating beat sound about once per second. Would anyone from this group that has installed the Gen 3 and been using it for a while care to comment on this? This sounds a bit concerning. Jan Eggenfellner doesn't deny that this is happening, but says it can be so lved with proper prop installation, balancing, keeping things from touching the cowl and so on. So, I'm just wondering if this is just something that only a handful of guy s are experiencing or ? ________________________________________________________________________________
Date: Jun 12, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Interesting. When I flew with Alex D. for my transition training he carried 2 cases of oil in the baggage area in his IO-540 bird. Also, he said that he normally lands with half flaps (he has a flap positioning system) unless there are rear seat passengers. When only front seat occupants there is a very noticeable nose down pitching when going from half to full flaps. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Thursday, June 12, 2008 1:11 AM Subject: Re: RV10-List: Emailing: sb08-6-1[1] Dave, i agreeI If folks take the time and go back through the archive and read the original posts (12/06) which witnessed the 'twist' and the follow on discussion regarding the Elevator trim rigging and how following Van's plan instructions, can and will result in a twisted HS. the situation described there is entirely consistent with the results depicted in the picture of the crack. I believe that there is a VERY high likelihood that the root cause of the crack lies in a twisting moment induced by the asynchronous movement of the elevator trim tabs. I was the individ David refers to that flew 220RV late last year, and there was not enough up elevator trim available to take the significant back pressure off the elevator during landings. I believe this is also consistent with the trim rigging and twisting explanation. Here's an excerpt from my post following transition training. **This brings up the next point and that is elevator authority. N220RV had NO balast in the rear when we flew. We initiated our approach with 20 degrees of flaps (second detent), Turning downwind we added full flaps. With full flaps there is NOT enough trim to take the back pressure off of the stick. I found that the back pressure was much more than I found comfortable, and flew some landings with 2 hands! Makes it difficult/impossible to develop a fingertip feel on landings. The other item has been reported by several others and that is when landing it takes the full aft movement of the stick. The topic has been discussed & debated previously, but in my opinion with only 2 people and no baggage/balast there is not enough elevator. Towards the end of 8.1 hours, I was able to get some of the rust scrubbed off, got a little less shy about the rapidly approaching ground, and found a way to 'muscle' a couple of good landings. then Mike says " let me show you something, .... we took another trip around the pattern flew exactly as before only on our base leg after extending full flaps, he had me 'blip' off a degree or two of flap at a time until the back pressure I'd grown unaccustomed to holding was gone..... then flew the rest of the landing !!!!! WOW!!! what a difference !!!!! Mike why did you keep this little secret to the end??????? the plane landed almost identical to full flaps, but the 'feel' was completely different and actually a joy!!!!!** Dave Leikam wrote: > > After looking closely at the pictures, it appears that the metal is > not only cracked, but also "crinkled." If you look at the skin to the > left of the crack, it appears to also be deformed which concurs with > the failure of the bulkhead. First thought is there was substantial > down pressure (compression) on the longeron and on the F1010A angle at > this point. Except when rolling, would there ever be uneven force on > the HS? And even then I would think the forces would be very > little. Would it be possible to detect equal tensional stress on the > other side? > > I agree with the twisted HS theory. > > Dave Leikam > #40496 N89DA (Reserved) > Muskego, WI > > > - Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> > To: > Sent: Wednesday, June 11, 2008 11:29 PM > Subject: RE: RV10-List: Emailing: sb08-6-1[1] > > >> >> I doubt it was the engine. I just talked with someone who flew the 220 >> version for transition training September 2007. He squawked the >> aircraft for >> inadequate up trim. I have flown the 540 version for 33 hours and never >> gotten the trim setting more than 2 bars from neutral. Inadequate up >> trim >> suggest to me that a improperly rigged trim system might have the two >> elevator halves fighting each other and twisting the elevators and >> stressing >> the horizontal stab. >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall >> Sent: Wednesday, June 11, 2008 9:02 PM >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Emailing: sb08-6-1[1] >> >> >> >> Oops forgot my name on the last one... >> >> Ben Westfall >> #40579 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill >> Sent: Wednesday, June 11, 2008 7:36 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Emailing: sb08-6-1[1] >> >> >> >> This is what I found about an hour ago. Look at the end of the pdf. >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 12, 2008
Subject: GTR serial connections
Gentlemen, I have the three screen Horizon GTR system with the ARINC 429 module on display 1, GPS on display 2, and display three has nothing. GNS 430 SL30 GTX330 Sorcerer Autopilot. My problem is the Grand Rapids EFIS will not send commands to the Sorcerer. The 430 will drive the autopilot but intermittently loses the GPSS suggesting that the serial connection is OK but there is a problem with the ARINC429. Trutrak documentation stated both Serial and ARINC 429 are needed for GPSS and GPSV. In the Grand Rapids documentation they say the ARINC 429 can be connected to as many devices as you wish. A friend suggested that I provide a dedicated ARINC 429 connection between the 430 and the Sorcerer. I think all of the ARINC 429 connections to the 430 have been used. Does anybody have any suggestions?? GTR has been helpful but they don't seem to know what is going on here. Ron Grover ________________________________________________________________________________
Date: Jun 12, 2008
First thing I'd check is to make sure that the GRT ARINC is set to low speed. If it isn't you'll see some very strange behavior on the AP (ask me how I know...). Bob N442PM _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ronald Grover Sent: Thursday, June 12, 2008 9:20 AM Subject: RV10-List: GTR serial connections Gentlemen, I have the three screen Horizon GTR system with the ARINC 429 module on display 1, GPS on display 2, and display three has nothing. GNS 430 SL30 GTX330 Sorcerer Autopilot. My problem is the Grand Rapids EFIS will not send commands to the Sorcerer. The 430 will drive the autopilot but intermittently loses the GPSS suggesting that the serial connection is OK but there is a problem with the ARINC429. Trutrak documentation stated both Serial and ARINC 429 are needed for GPSS and GPSV. In the Grand Rapids documentation they say the ARINC 429 can be connected to as many devices as you wish. A friend suggested that I provide a dedicated ARINC 429 connection between the 430 and the Sorcerer. I think all of the ARINC 429 connections to the 430 have been used. Does anybody have any suggestions?? GTR has been helpful but they don't seem to know what is going on here. Ron Grover ________________________________________________________________________________
Date: Jun 12, 2008
But also think not only of a twisted HS theory but remember the tail fuse s kin is part of this equation, I don't see it so much as compression problem as a shearing problem...the fuse side skin going in a different direction from longeron and the horizontal angle that is going across the top and fas tening to the HS stab. As though the HS is not rolling, but rather yawing a nd cycling with some harmonic. John G. 409> From: daveleikam(at)wi.rr.com> To: rv10-list(at)matronics.com> Subje ct: Re: RV10-List: Emailing: sb08-6-1[1]> Date: Thu, 12 Jun 2008 00:36:05 - m>> > After looking closely at the pictures, it appears that the metal is n ot only > cracked, but also "crinkled." If you look at the skin to the left of the > crack, it appears to also be deformed which concurs with the fail ure of the > bulkhead. First thought is there was substantial down pressure > (compression) on the longeron and on the F1010A angle at this point. > E xcept when rolling, would there ever be uneven force on the HS? And even > then I would think the forces would be very little. Would it be possible to > detect equal tensional stress on the other side?> > I agree with the twi sted HS theory.> > Dave Leikam> #40496 N89DA (Reserved)> Muskego, WI> > > - Original Message ----- > From: "David McNeill" <dlm46007(at)cox.net>> To: <rv 10-list(at)matronics.com>> Sent: Wednesday, June 11, 2008 11:29 PM> Subject: R "David McNeill" > >> > I doubt it was the engine. I just talked with someone who flew the 220> > version for transition training Se ptember 2007. He squawked the aircraft > > for> > inadequate up trim. I hav e flown the 540 version for 33 hours and never> > gotten the trim setting m ore than 2 bars from neutral. Inadequate up trim> > suggest to me that a im properly rigged trim system might have the two> > elevator halves fighting each other and twisting the elevators and > > stressing> > the horizontal s tab.> >> > -----Original Message-----> > From: owner-rv10-list-server@matro nics.com> > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall> > Sent: Wednesday, June 11, 2008 9:02 PM> > To: rv10-list@matroni cs.com> > Subject: RE: RV10-List: Emailing: sb08-6-1[1]> >> > --> RV10-List message posted by: "Ben Westfall" > >> >> > Oops forgot my name on the last one...> >> > Ben Westfall> > #40579> >> > -----Origina l Message-----> > From: owner-rv10-list-server(at)matronics.com> > [mailto:own er-rv10-list-server(at)matronics.com] On Behalf Of David McNeill> > Sent: Wedn esday, June 11, 2008 7:36 PM> > To: rv10-list(at)matronics.com> > Subject: RV1 0-List: Emailing: sb08-6-1[1]> >> >> >> > This is what I found about an hou ========================> _ =====================> > > ________________________________________________________________________________
Subject: SB Pictures
Date: Jun 12, 2008
It light of the j-channel discussion of the last week or so, notice that in the Van SB picture, the j-channel also touches the bulkhead as well. ________________________________________________________________________________
Date: Jun 12, 2008
Is the target empty wt CG what 410RV has or something else? I believe it has well over 1000 hours on it now, as it was over 900 last August when I flew in it. It would seem desirable to start planning towards whatever the goal is from the start of the tail cone on. Wonder if Vans will spec that bulkhead in subsequent kits for the next thickness up. I expect I will have the same as all others when I pickup my empenage kit, allegedly arriving tomorrow. Kelly Builder # yet to come. On Thu, Jun 12, 2008 at 3:34 PM, John Cox wrote: > > Know your aircraft's mission! It is time for Tim James to provide > discussion and pictures on his roll bar, VGs and low slow speed > improvements. While he is at it, he can mention the tail > counter-weights which brought his CG "Dead nuts on". ________________________________________________________________________________
Date: Jun 12, 2008
I talked to Vans yesterday to ask that exact question. There is no plans to change the bulkhead to a thicker product. The doublers are the final fix to it as of yesterday. I received my Emp. Kit today and now have a very full garage. Kelly make lots of room the box is 11 ft long almost 4 ft wide and weights 300 pounds. I am serial number 40864 and anything after 40866 will have the sb kit included in build kit. So the fun begins. John G. Cumins #40864 Inventory starting soon. Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 12, 2008 4:32 PM Subject: Re: RV10-List: Emailing: sb08-6-1[1] Is the target empty wt CG what 410RV has or something else? I believe it has well over 1000 hours on it now, as it was over 900 last August when I flew in it. It would seem desirable to start planning towards whatever the goal is from the start of the tail cone on. Wonder if Vans will spec that bulkhead in subsequent kits for the next thickness up. I expect I will have the same as all others when I pickup my empenage kit, allegedly arriving tomorrow. Kelly Builder # yet to come. On Thu, Jun 12, 2008 at 3:34 PM, John Cox wrote: > > Know your aircraft's mission! It is time for Tim James to provide > discussion and pictures on his roll bar, VGs and low slow speed > improvements. While he is at it, he can mention the tail > counter-weights which brought his CG "Dead nuts on". ________________________________________________________________________________
Subject: Re: SB
Date: Jun 12, 2008
Perhaps it's time to take another look at why the RV-10 even needs two trim tabs.... -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187667#187667 ________________________________________________________________________________
Date: Jun 12, 2008
Kelly, The info on 410RV is just data, not a target. It is puts the empty CGjust forward of the forward CG limit and when you add fuel/pilot you're within the envelope. As discussed many times the plane will have more trim authority during the landing phase if the CG is shifted an inch or two aft by carrying some weight in the baggage compartment. As I understand it, the decision to make the empty CG forward is because the arms for fuel, pilot, passengers and baggage are all aft of the forward CG limit. My (N442PM) empty CG is aft of the factory plane for the following reasons: - I have a pair of PC-680 batteries instead of the standard Concorde in the standard battery location with the second battery contactor colocated. - I have dual LSE Plasma III ignitions which means no mags - I have a B&C 20 amp alternator on the vacuum pad and angled oil filter adapter which adds back a little weight up front. - I've got a pretty full panel which is heavier than the factory planes but close to the CG line. For those wanting to do a little planning, here are the numbers: Fwd CG limit: 107.8375" (15% of chord) Aft CG limit: 116.2375" (30% of chord) Fuel: 108.9" Front seats: 114.582" Rear seats: 151.2586" Baggage: 173.5" Disclaimer: Unless your plane is identical in every way to one of those mentioned, your information WILL be different. I only include it for context of the discussion on the need for trim. Bob N442PM (36.1 hours as of a few minutes ago!) Is the target empty wt CG what 410RV has or something else? I believe it has well over 1000 hours on it now, as it was over 900 last August when I flew in it. It would seem desirable to start planning towards whatever the goal is from the start of the tail cone on. Wonder if Vans will spec that bulkhead in subsequent kits for the next thickness up. I expect I will have the same as all others when I pickup my empenage kit, allegedly arriving tomorrow. Kelly Builder # yet to come. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187689#187689 ________________________________________________________________________________
Date: Jun 12, 2008
The final fix is indeed the doubler approach. When you receive your SB package it will contain a replacement chapter 10 of the construction manual with the doublers in addition to directions on how to retrofit them to a tailcone that is already constructed. Parts consist of the 2 doublers and a bag with a lot of AD4 size rivets... I did the inspection this afternoon and found all was well. Given that I only have 36 hours on the plane and am 11 months away from the annual I'll do the 25 hour inspection routine and let the dust settle before tearing into things. Maybe somebody will come up with an easier way! Bob N442PM 40 hour fly-off should be finished tomorrow! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187694#187694 ________________________________________________________________________________
Subject: Rudder Gust Lock
Date: Jun 12, 2008
When I tie down in the open I secure the rudder with a cord after using the seat belt to hold the stick aft and centered. Works OK but I'm thinking of using a short piece of rubber tube with a hold cut in it for the tail light/strobe to stick thru. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Jun 13, 2008
It seems to me that it may work fine for winds of 10kts or so but in really strong winds it may have problems. The rope around the strobe may slip and the rudder will be free to move and get damaged. Secondly the attach points on the horizontal stab are putting a load on the stab that it was not designed to carry. That is a twisting rocking motion that lasts for as long as the aircraft is parked outside in the wind. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, June 12, 2008 9:58 PM Subject: RV10-List: Rudder Gust Lock When I tie down in the open I secure the rudder with a cord after using the seat belt to hold the stick aft and centered. Works OK but I'm thinking of using a short piece of rubber tube with a hold cut in it for the tail light/strobe to stick thru. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Jun 13, 2008
First you must understand the the GNS-430 has 2 ARINC INPUT ports but only ONE ARINC OUTPUT port. Also ARINC is a buss so dedicating it to one output device is kind of limiting. Ideally the single GNS-430W ARINC OUT should be connected to the EFIS, the TruTrak AND the 330 transponder if you have one. If you make the GNS-430W ARINC OUTPUT dedicated to the TruTrak, you are then limited to using GPSS L and V ONLY with the 430. You should still have basic autopilot using the RS-232 from the EFIS to the TruTrak. For full GPSS from the EFIS, you will need a switch between the GNS-430 ARINC OUT, the EFIS ARINC OUT and the TruTrak ARINC IN. This should allow you to get the full benefit of the Sorcerer with the EFIS. William http://nerv10.com/wcurtis/ -------- Original Message -------- > > Gentlemen, > > > > I have the three screen Horizon GTR system with the ARINC 429 module on > display 1, GPS on display 2, and display three has nothing. > > GNS 430 > > SL30 > > GTX330 > > Sorcerer Autopilot. > > > > My problem is the Grand Rapids EFIS will not send commands to the Sorcerer. > The 430 will drive the autopilot but intermittently loses the GPSS > suggesting that the serial connection is OK but there is a problem with the > ARINC429. Trutrak documentation stated both Serial and ARINC 429 are needed > for GPSS and GPSV. > > > > In the Grand Rapids documentation they say the ARINC 429 can be connected to > as many devices as you wish. A friend suggested that I provide a dedicated > ARINC 429 connection between the 430 and the Sorcerer. I think all of the > ARINC 429 connections to the 430 have been used. > > > > Does anybody have any suggestions?? GTR has been helpful but they don't > seem to know what is going on here. > > > > Ron Grover ________________________________________________________________________________
Date: Jun 13, 2008
Subject: Boone, IA Flyin anyone?
I'm planning to fly up to the RV Flyin in Boone, Iowa tomorrow morning, is anyone else planning on flying in? Ray Doerr N519RV (40250) ________________________________________________________________________________
Subject: cutting holes in the firewall
Date: Jun 13, 2008
I am wondeing what methods people used to cut holes in their firewall. I've seen some pretty bunged up holes and some real clean ones. I'm interested in knowing how to make "clean ones" in case that wasn't clear. I doubt a unibit cuts them very cleanly and I imagine the stainless toasts them quickly. Are there punches that work better and where did people buy them if so? Harbor Freight has a cheap set but I don't know if it works on stainless very well. I need to punch the holes for the battery cable and the throttle/prop/mixture. Ben Westfall #40579 PDX ________________________________________________________________________________
Date: Jun 13, 2008
Actually the type of stainless in our firewalls isn't too bad to drill. I use regular drill bits and step bits in mine without a problem. Only way you are going to get extremely clean holes are with lots of patience, a pu nch tool like used for panels, or a CNC machine. I think you will find the normal methods to be just fine though. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Ben Westfall Sent: Friday, June 13, 2008 3:25 PM Subject: RV10-List: cutting holes in the firewall I am wondeing what methods people used to cut holes in their firewall. I'v e seen some pretty bunged up holes and some real clean ones. I'm intereste d in knowing how to make "clean ones" in case that wasn't clear. I doubt a unibit cuts them very cleanly and I imagine the stainless toasts them quic kly. Are there punches that work better and where did people buy them if s o? Harbor Freight has a cheap set but I don't know if it works on stainles s very well. I need to punch the holes for the battery cable and the throt tle/prop/mixture. Ben Westfall #40579 PDX ________________________________________________________________________________
Date: Jun 13, 2008
Subject: Re: cutting holes in the firewall
Ben, The set from HF works great on the FW SS. I used it on mine. Made two nice holes. Dave Lammers Forever Finishing. Ben Westfall wrote: > I am wondeing what methods people used to cut holes in their firewall. > I've seen some pretty bunged up holes and some real clean ones. I'm > interested in knowing how to make "clean ones" in case that wasn't > clear. I doubt a unibit cuts them very cleanly and I imagine the > stainless toasts them quickly. Are there punches that work better and > where did people buy them if so? Harbor Freight has a cheap set but I > don't know if it works on stainless very well. I need to punch the > holes for the battery cable and the throttle/prop/mixture. > > > > Ben Westfall > > #40579 > > PDX > > > > > > > > ________________________________________________________________________________
Date: Jun 13, 2008
I have greenlee punches and some high quality uni-bits, I found that hands down the uni-bit was the way to go. With the punches, at the very end of pulling the punch through the metal the slug would get bound up between the punch and the die. With the uni-bits I found the secret to success was drilling a little at a time from both sides. This would keep the burr from getting very big, the result was very clean accurate holes. -Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Subject: Re: Doors/Plexi revisited ... again
Date: Jun 13, 2008
In response to off line questions about the die grinder I use, a picture is easier and I'll just post it here in case others are interested. I noticed Harbor Frt. has one for about $30, the quick release disk came from a body shop supply, extra disks came from Grainger. This is an extremely useful tool for rough shaping small areas of fiberglass, aluminum, etc. But it is aggressive with high speed and small area, so practice a bit first. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 doors almost finished, pants on, WHEW! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187818#187818 Attachments: http://forums.matronics.com//files/die_grinder_medium_107.jpg http://forums.matronics.com//files/die_sander_medium_101.jpg http://forums.matronics.com//files/shallow_472.jpg ________________________________________________________________________________
Date: Jun 13, 2008
Ben, I have the Harbor Freight punches (which you are welcome to borrow) and found them inferior on aluminum. At work, we use a hydraulic punch which I might be able to borrow. the unibit and possibly multiple are the best bet for 10 builders. Sharing the size and locations with future builders would allow them to use other techniques before the wall is installed. John Cox #40600 PDX - UAO From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Friday, June 13, 2008 1:25 PM Subject: RV10-List: cutting holes in the firewall I am wondeing what methods people used to cut holes in their firewall. I've seen some pretty bunged up holes and some real clean ones. I'm interested in knowing how to make "clean ones" in case that wasn't clear. I doubt a unibit cuts them very cleanly and I imagine the stainless toasts them quickly. Are there punches that work better and where did people buy them if so? Harbor Freight has a cheap set but I don't know if it works on stainless very well. I need to punch the holes for the battery cable and the throttle/prop/mixture. Ben Westfall #40579 PDX ________________________________________________________________________________
Date: Jun 13, 2008
Subject: door pins
I've bent my pins to align with the door curve per plans, and now I'm tryin g to fit them in the 7/16" holes drill in the door jams.- Each time I lat ch the door, the force of the movement pushes the door out of its happy pla ce and leaves a gap.- Looks like the only solution is to oversize the hol e in the direction that will allow the pin to slide straight in and latch, then make a new plastic piece to hold the pin in place.- =0AI could then patch the enlarged metal hole and redrill-the final hole's location in th e patch.=0AOr should I attempt to unbend the rod, but that seems like it wo uldn't then emerge from the door without binding.=0ARight now it looks like it's only the forward pin on the left door.=0AEverything else was done per plans, which of course in this fiberglass stuff means, "hey, here are some guidelines, now just figure it out until it works!"=0AVery frustrating, so I quit for the night before I get drastic and make a huge hole that I don' t need or want.=0ARob Wright=0A#392=0ADoors...Thought I'd be done with them by tomorrow...=0A=0A=0A ________________________________________________________________________________
Date: Jun 13, 2008
Subject: Officially a Builder
June 10 Vans shipped out tail kit, 5 days after I placed the order. Today I on this lucky day, picked up "The Box" and received letter informing me that I am now Builder # 40866. So the big box is tucked away in the back of the hangar, awaiting inventory. Pretty impressive to receive kit only 8 days after placing the order. Interesting that it was shipped FedEx Freight, rather than ABF. Kelly Builder 40866, Tail...inventory ________________________________________________________________________________
Subject: Re: Officially a Builder
Date: Jun 13, 2008
All my shipments came FedEx Freight. They were initially the least expensive (we receive the Van's discount) than I requested they ship the rest of my kits FedEx since they did a great job each time. Congratulations! Pascal #40720 -------------------------------------------------- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Friday, June 13, 2008 8:40 PM Subject: RV10-List: Officially a Builder > > June 10 Vans shipped out tail kit, 5 days after I placed the order. > Today I on this lucky day, picked up "The Box" and received letter > informing me that I am now Builder # 40866. So the big box is tucked > away in the back of the hangar, awaiting inventory. Pretty impressive > to receive kit only 8 days after placing the order. Interesting that > it was shipped FedEx Freight, rather than ABF. > > Kelly > Builder 40866, Tail...inventory > > > ________________________________________________________________________________
Date: Jun 13, 2008
Welcome! Dave Leikam #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Friday, June 13, 2008 10:40 PM Subject: RV10-List: Officially a Builder > > June 10 Vans shipped out tail kit, 5 days after I placed the order. > Today I on this lucky day, picked up "The Box" and received letter > informing me that I am now Builder # 40866. So the big box is tucked > away in the back of the hangar, awaiting inventory. Pretty impressive > to receive kit only 8 days after placing the order. Interesting that > it was shipped FedEx Freight, rather than ABF. > > Kelly > Builder 40866, Tail...inventory > > > ________________________________________________________________________________
Date: Jun 13, 2008
Congratts Kelly. My kit showed up yesterday. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, June 13, 2008 8:40 PM Subject: RV10-List: Officially a Builder June 10 Vans shipped out tail kit, 5 days after I placed the order. Today I on this lucky day, picked up "The Box" and received letter informing me that I am now Builder # 40866. So the big box is tucked away in the back of the hangar, awaiting inventory. Pretty impressive to receive kit only 8 days after placing the order. Interesting that it was shipped FedEx Freight, rather than ABF. Kelly Builder 40866, Tail...inventory ________________________________________________________________________________
Date: Jun 14, 2008
Subject: Re: door pins
I had that problem originally. Before you do anything drastic, lubricate your door rods with some 3-in-1 oil, especially where they go through the plastic blocks. Also, make sure you haven't over bent them. I found that when I took some, but not all of the bend out of the rods, that they moved much more smoothly. PJ Seipel RV-10 #40032 Robert Wright wrote: > I've bent my pins to align with the door curve per plans, and now I'm > trying to fit them in the 7/16" holes drill in the door jams. Each > time I latch the door, the force of the movement pushes the door out > of its happy place and leaves a gap. Looks like the only solution is > to oversize the hole in the direction that will allow the pin to slide > straight in and latch, then make a new plastic piece to hold the pin > in place. > > I could then patch the enlarged metal hole and redrill the final > hole's location in the patch. > > Or should I attempt to unbend the rod, but that seems like it wouldn't > then emerge from the door without binding. > > Right now it looks like it's only the forward pin on the left door. > > Everything else was done per plans, which of course in this fiberglass > stuff means, "hey, here are some guidelines, now just figure it out > until it works!" > > Very frustrating, so I quit for the night before I get drastic and > make a huge hole that I don't need or want. > > Rob Wright > #392 > Doors...Thought I'd be done with them by tomorrow... > > * > > > * ________________________________________________________________________________
Date: Jun 14, 2008
Date: Jun 14, 2008
I had good luck with FedEx....I think ABF stands for Always Broken with Forklift. Anyone had the nerve to add up all their shipping costs? Jeezz it sucks. Rick Sked 40185 ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Friday, June 13, 2008 11:40:19 PM (GMT-0500) America/New_York Subject: RV10-List: Officially a Builder June 10 Vans shipped out tail kit, 5 days after I placed the order. Today I on this lucky day, picked up "The Box" and received letter informing me that I am now Builder # 40866. So the big box is tucked away in the back of the hangar, awaiting inventory. Pretty impressive to receive kit only 8 days after placing the order. Interesting that it was shipped FedEx Freight, rather than ABF. Kelly Builder 40866, Tail...inventory ________________________________________________________________________________
Date: Jun 14, 2008
Subject: Re: Air body saw cheap
I picked up one last time it was on sale for 14.99. A good deal. Some observations 1) Save your receipt - my saw failed while working on the fiberglass top. Couldn't figure out what broke but it is RIP. Not a big deal at $15 but I couldn't find the receipt for a warranty return. (but I am by no means recommending the HF extended warranty) 2) If you plan to use it on fiberglass - get lot's of blades. Or better yet, see if you can find or fashion a carbide grit blade for it. That would be a fiberglass master tool for many of the canopy cuts. I ended up with a carbide grit blade on a (too big) reciprocating saw and cutting down the width of the saw so it would turn a tighter radius. Worked well... the HF saw would have been perfect with a grit saw blade. 3) Tim has a very steady head and nerves of steel. I did a cutout for my wingtip lights and scared the living crap out of myself. I used a die grinder and a hand file on the other one. Tim Olson wrote: > > Just thought I'd pass this along....since after building a plane > I ended up addicted to Harbor Freight. > > The High-Speed air body saw: 91753-5BPB is on sale now for $14.99. > I found it useful a few times, but especially for the landing > lights in the wingtip...it worked great for that. > ________________________________________________________________________________
Date: Jun 14, 2008
i've found that if i polish the rods with polish/rouge to a nice shine then dab a bit of boelube on them they will slide verry smoothly. i'd avoid anything that may attract dirt later. even a silicone dry lube would be good. on the extreme end i did have one plactic block that was way too tight. i chucked the door rod in my cordless drill and ran the rod in the block till it got warm, let everything cool, and it tested much better. of coarse ymmv.... steven dinieri iflyrv10.com ----- Original Message ----- From: "PJ Seipel" <seipel(at)seznam.cz> Sent: Saturday, June 14, 2008 8:54 AM Subject: Re: RV10-List: door pins > > I had that problem originally. Before you do anything drastic, > lubricate your door rods with some 3-in-1 oil, especially where they go > through the plastic blocks. Also, make sure you haven't over bent > them. I found that when I took some, but not all of the bend out of the > rods, that they moved much more smoothly. > > PJ Seipel > RV-10 #40032 > > Robert Wright wrote: > > I've bent my pins to align with the door curve per plans, and now I'm > > trying to fit them in the 7/16" holes drill in the door jams. Each > > time I latch the door, the force of the movement pushes the door out > > of its happy place and leaves a gap. Looks like the only solution is > > to oversize the hole in the direction that will allow the pin to slide > > straight in and latch, then make a new plastic piece to hold the pin > > in place. > > > > I could then patch the enlarged metal hole and redrill the final > > hole's location in the patch. > > > > Or should I attempt to unbend the rod, but that seems like it wouldn't > > then emerge from the door without binding. > > > > Right now it looks like it's only the forward pin on the left door. > > > > Everything else was done per plans, which of course in this fiberglass > > stuff means, "hey, here are some guidelines, now just figure it out > > until it works!" > > > > Very frustrating, so I quit for the night before I get drastic and > > make a huge hole that I don't need or want. > > > > Rob Wright > > #392 > > Doors...Thought I'd be done with them by tomorrow... > > > > * > > > > > > * > > ________________________________________________________________________________
Date: Jun 14, 2008
I reamed my delrin blocks 1/64" oversize(reamer available from Grainger). That was enough clearance to account for the slight angle the door pins have relative to the blocks, but not so much as to have any slop when the door is locked shut. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187880#187880 ________________________________________________________________________________
Date: Jun 14, 2008
I used my saw for a lot of things, but found the HF blades near worthless. Has anyone found a better quality, ready to use blade that will fit this saw? I would rather build airplanes than saw blades (just in case I become a repeat offender). Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187881#187881 ________________________________________________________________________________
Date: Jun 14, 2008
FWIW, I just finished fitting the doors with the Rivethead pin and block set (similar perhaps to Steve DiNieri's). Though I did a lot of 'heming and 'hawing trying to figure out how to best fit them, it ended up being very easy to get a great fit. The bullet shaped rod end and the matching pin blocks really work nicely to 'rack' then lock the door in place. See the Youtube video: http://youtube.com/watch?v=UMJ5ZLT8OTo I can't easily describe the installation procedure I used but it worked much more easily than I could have imagined. And seemed a lot more straight forward than the Van's design. Only tip I can easily give is that the nylon blocks on the doors need to fit as far back into their recesses on the door as possible. That is, they need to more recessed than just flush with the edge of the recess - another 1/16 to 1/8" seemed critical. Robert Wright wrote: > I've bent my pins to align with the door curve per plans, and now I'm > trying to fit them in the 7/16" holes drill in the door jams. Each > time I latch the door, the force of the movement pushes the door out > of its happy place and leaves a gap. Looks like the only solution is > to oversize the hole in the direction that will allow the pin to slide > straight in and latch, then make a new plastic piece to hold the pin > in place. > > I could then patch the enlarged metal hole and redrill the final > hole's location in the patch. > > Or should I attempt to unbend the rod, but that seems like it wouldn't > then emerge from the door without binding. > > Right now it looks like it's only the forward pin on the left door. > > Everything else was done per plans, which of course in this fiberglass > stuff means, "hey, here are some guidelines, now just figure it out > until it works!" > > Very frustrating, so I quit for the night before I get drastic and > make a huge hole that I don't need or want. > > Rob Wright > #392 > Doors...Thought I'd be done with them by tomorrow... > > * > > > * ________________________________________________________________________________
Subject: Panel extended or work-around of lower panel support flange
Date: Jun 14, 2008
I'd like to get rid of the line of nut plates along the bottom of the panel to make the whole lower flange area of the panel (F-1003B) useable without interference and still have structural rigidity. I understand one alternative might be Stein's extended panel but I'm concerned about conflict with forward movement of control stick. Another might be to have a single piece panel cut with support brackets on the ends and no separate lower flange. It's a really tight fit for two AFS 4500's on the pilots side plus three 2 & 1/4" backup instruments. Has anyone come up with alternatives. Especially those that are actually flying [Laughing] Thanks, Tom Hanaway " I can make it work, I'm just not sure how yet." Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187886#187886 ________________________________________________________________________________
Subject: ENGINE 540 EBAY
Date: Jun 14, 2008
My understanding there is an engine on ebay. supposedly a swinging deal. no core required. expires today. ________________________________________________________________________________
Date: Jun 14, 2008
My door building memory dump (or revisiting bad dreams): Life is good, the birds are singing and the lion sleeps with the lamb until you drill the hole through the aluminum frame. Quickly thereafter dark clouds begin to form. I adjusted my door fit, using various techniques, before starting the rod assembly, after the latch mechanism was installed, and after the seal was installed. It would have been much better, mentally, for me to visualize this process as successive approximations rather than three final trims. Make sure there is always a gap between the door and the return lip of the cabin fiberglass. I trimed this lip many times as I worked the door into place. Letting this lip push against the door at the upper part of the door will cause the door lower lip to move up. If you trim the bottom of the door with the lip interfering near the top - well ... To fine tune my door fit I purchased a block of nylon and machined (chop saw and drill press and dremel grinder) the guides on the door, not the cabin frame. This kept the aluminum hole intact. Keep the screw holes in the same location and move the rod hole around. Make the bends near the middle of the rod and "aim" the rod through the hole to minimize drag. Using sandpaper you can lightly smooth up the last 3" of the rod and it will slip through the hole easier. Light weight grease helps greatly. If you need to repurchase the rods buy 2024-T3 raw stock with thick walls. A die grinder with a thin abrasive wheel easily cuts the end slot and you can decrease the pointy end angle to increase metal through the aluminum frame. The pointy side of the rod is inboard to catch the hole with the tip and pull the door  inward. The sharp edges of the rod end function more like a sword than a velvet finger and chop up the receiving plastic. Sand (or fair) down these outer edges to help the rod slide and not stab. Rod length adjustment starts with making sure the door handle swings 110 degrees or greater. Fully retract the rods. The rod end tip should be exactly flush with the door frame. If its pulled further into the door then the rod end may not pass through the aluminum frame when closed. The greater the circumference of the rod end passing through the aluminum frame the stronger the door. If the rod point is outside the door frame with the door handle fully open then it will decimate the cabin jam. The last check is to assess how much of the rod circumference passes through the aluminum hole with the door closed.  If this measurement is small, say .125" , then only the plastic guide is holding the door and the door is likely to open in flight as the outer edge of the guide weakens when the rod pointy end chops it up. Adding aluminum to this joint is a very good case for purchasing the aluminum guides. No passengers move the handle to close the door - only you. The passengers that abused this and made unsightly gashes in my outer skin were other pilots that already "knew" everything. Good Luck, Bill DeRouchey N939SB, flying   --- On Sat, 6/14/08, PJ Seipel <seipel(at)seznam.cz> wrote: From: PJ Seipel <seipel(at)seznam.cz> Subject: Re: RV10-List: door pins Date: Saturday, June 14, 2008, 5:54 AM --> RV10-List message posted by: PJ Seipel <seipel(at)seznam.cz> I had that problem originally. Before you do anything drastic, lubricate your door rods with some 3-in-1 oil, especially where they go through the plastic blocks. Also, make sure you haven't over bent them. I found that when I took some, but not all of the bend out of the rods, that they moved much more smoothly. PJ Seipel RV-10 #40032 Robert Wright wrote: > I've bent my pins to align with the door curve per plans, and now I'm > trying to fit them in the 7/16" holes drill in the door jams. Each > time I latch the door, the force of the movement pushes the door out > of its happy place and leaves a gap. Looks like the only solution is > to oversize the hole in the direction that will allow the pin to slide > straight in and latch, then make a new plastic piece to hold the pin > in place. > > I could then patch the enlarged metal hole and redrill the final > hole's location in the patch. > > Or should I attempt to unbend the rod, but that seems like it wouldn't > then emerge from the door without binding. > > Right now it looks like it's only the forward pin on the left door. > > Everything else was done per plans, which of course in this fiberglass > stuff means, "hey, here are some guidelines, now just figure it out > until it works!" > > Very frustrating, so I quit for the night before I get drastic and > make a huge hole that I don't need or want. > > Rob Wright > #392 > Doors...Thought I'd be done with them by tomorrow... > > * > > > * Site - ________________________________________________________________________________
Date: Jun 14, 2008
Kelly McMullen wrote: > June 10 Vans shipped out tail kit, 5 days after I placed the order. > Today I on this lucky day, picked up "The Box" and received letter > informing me that I am now Builder # 40866. So the big box is tucked > away in the back of the hangar, awaiting inventory. Pretty impressive > to receive kit only 8 days after placing the order. Interesting that > it was shipped FedEx Freight, rather than ABF. > > Kelly > Builder 40866, Tail...inventory I received all but one shipment by FedEx. The other was by ABF. Yes the ABF box was in the poorest shape of the 3 shipments. But not bad. >From OR to OK Fedex is 3 business days and if it is over a weekend I got it in 2 business days. You can hardly drive it in that amount of time. ABF was 5 business days, no variation. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187898#187898 ________________________________________________________________________________
Subject: SB package arrived today
Date: Jun 14, 2008
Just for reference, the SB package from Vans arrived today in the mail from Vans. I am located in Oklahoma City. Included was a complete new section 10 set of plans. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187899#187899 ________________________________________________________________________________
Subject: Certified O-540 NIB
Date: Jun 14, 2008
If anybody is interested in a Certified O-540 new in Lycoming box, please contact me off list. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Subject: IO540 need an engine?
Date: Jun 14, 2008
http://cgi.ebay.com/ebaymotors/Lycoming-IO-540-D4A5-0-SMOH-by-Ly-Con-FREE-SH IPPING_W0QQcmdZViewItemQQcategoryZ26437QQihZ002QQitemZ120270111673QQrdZ1QQss pagenameZWDVW ________________________________________________________________________________
Date: Jun 14, 2008
I guess I'm the exception. I had great service from ABF. Not so much as a footprint on any of the boxes. Neal George ======================== I received all but one shipment by FedEx. The other was by ABF. Yes the ABF box was in the poorest shape of the 3 shipments. But not bad. >From OR to OK Fedex is 3 business days and if it is over a weekend I got it in 2 business days. You can hardly drive it in that amount of time. ABF was 5 business days, no variation. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187898#187898 ________________________________________________________________________________
Date: Jun 14, 2008
orchidman wrote: > >> > > I received all but one shipment by FedEx. The other was by ABF. Yes the ABF box was in the poorest shape of the 3 shipments. But not bad. > >From OR to OK Fedex is 3 business days and if it is over a weekend I got it in 2 business days. You can hardly drive it in that amount of time. ABF was 5 business days, no variation. > > Fedex got the box late Jun 10, and it was available for pickup 8am Jun 13 in Phoenix. Essentially 2 days on the road. Like you say..you aren't going to drive it in less, unless you have 2 drivers and go non-stop. ________________________________________________________________________________
Date: Jun 14, 2008
Subject: Re: IO540 need an engine?
Good price if you don't mind a narrow deck engine and unknown preservation/storage. Not to mention all the choices about parts used etc. already made for you. Good if you are ready to install, not so good if you are a year or two away from finishing. On Sat, Jun 14, 2008 at 1:59 PM, David McNeill wrote: > http://cgi.ebay.com/ebaymotors/Lycoming-IO-540-D4A5-0-SMOH-by-Ly-Con-FREE-SHIPPING_W0QQcmdZViewItemQQcategoryZ26437QQihZ002QQitemZ120270111673QQrdZ1QQsspagenameZWDVW > > ________________________________________________________________________________
Date: Jun 15, 2008
Subject: EIS 6000 question
Hi Regarding the GRT EIS 6000/4000 could anyone tell me what scale factor and offset limit values you used for your fuel pressure sender? Thanks Kevin Shannon Taxi testing the rocket tomorrow **************Vote for your city's best dining and nightlife. City's Best 2008. (http://citysbest.aol.com?ncid=aolacg00050000000102) ________________________________________________________________________________
Subject: SB 08-6-1 Inspection
Date: Jun 15, 2008
There are quite a few threads on this SB. Why don't we use this thread to keep track of what people find when they do the inspection? Just list A/C time and results and we can track the problem with one search. Blue Skys. Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Subject: Re: EIS 6000 question
Date: Jun 15, 2008
For the stainless steel high pressure fuel sender (what GRT recommends for FI engines), the SF is 63 and OFF is 51. Be aware however that there's a minor calibration procedure to set the zero level. As I recall this involves having zero PSI (open the mixture to guarantee this) and then setting the OFF as appropriate. They want this done with the ambient air temp around 72 degrees F. Bob N442PM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=187976#187976 ________________________________________________________________________________
Date: Jun 15, 2008
That's the one I have....the SF is 63, but it doesn't just list the OFF as 51 on my sheet, it says: Calibrate as follows. Set AuxOff to 0. Be sure no pressure is applied to the sensor. Note the auxiliary display. The sensor is operating properly if the aux display is between 20-30 or 2.0-3.0 for aux displays with a decimal point. If the aux display includes a decimal point, multiply the reading by 20 and subtract 1. Pressure will be displayed as 1/10 of actual. If the aux display does not have a decimal point, multiply the reading by 2 and subtract 1. Pressure will be displayed as actual, in units of PSI. (There is a little more text there that I left out, but it doesn't seem it gives the exact number) I believe my offset was set at 47. So while you may be able to get the SF set, I think you have to calculate the Offset on your individual sensor. The rest is my other post....just without the "do not arkive" thing on the end. ------ Those numbers should be on a sheet that came with the sensor. I'd give you mine, but one of my two sensors (The High pressure one) was not the original cheap one that GRT sells, but their more premium "Stainless Steel High Pressure Sensor", which uses a different SF and OFF. I am not sure if that was oil pressure or fuel pressure for that sensor though. But either way, they have sheets for both sensor types that show the info. For the cheap VDO 80 and 150, this is what it says: Set AuxSF to 182 for 150 psi sender, 91 for 80 psi sender Set AuxOff to 29 for 150 psi sender, 15 for 80 psi sender Set Aux Sensing to normal (+) on Options page If the auxiliary input includes a decimal point, the pressure displayed will be 1/10 of actual. For example, 35 psi will be displayed as 3.5 psi. If you don't have these sheets, I'd get them to send them to you. Tim Olson - RV-10 N104CD - Flying bcondrey wrote: > > > For the stainless steel high pressure fuel sender (what GRT > recommends for FI engines), the SF is 63 and OFF is 51. Be aware > however that there's a minor calibration procedure to set the zero > level. As I recall this involves having zero PSI (open the mixture > to guarantee this) and then setting the OFF as appropriate. They > want this done with the ambient air temp around 72 degrees F. > > Bob N442PM > ________________________________________________________________________________
Date: Jun 15, 2008
Barry your point is dead on. Many do not understand the urgency to inspect (within 5) and to continue to inspect (every 25) until compliance (at the very next Conditional). A misread could have major impact. Share the word! Few are getting to the root of the cause. Hopefully it was due to a unique one of a kind, build situation. What is most important is not allowing this alarming crack to become anything more than a simple patch. Stay safe. Tim could best track those who have completed it and confirm if more than a single aircraft was affected. Sharing of what is being found at Conditionals is of value to every single 10 builder. This group is great at the sharing. John Cox Oregon -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Barry Marz Sent: Sunday, June 15, 2008 6:53 AM Subject: RV10-List: SB 08-6-1 Inspection There are quite a few threads on this SB. Why don't we use this thread to keep track of what people find when they do the inspection? Just list A/C time and results and we can track the problem with one search. Blue Skys. Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Date: Jun 15, 2008
Subject: Re: SB 08-6-1 Inspection
N519RV (40250) Hobbs = 381.3, No cracks founds. Looks like it did on day one! Ray Doerr ---- Barry Marz wrote: > > There are quite a few threads on this SB. Why don't we use this > thread to keep track of what people find when they do the inspection? > Just list A/C time and results and we can track the problem with one > search. Blue Skys. > > Barry Marz > 18735 Baseleg AVE. > FT. Myers, Fl 33917 > 239-567-2271 > blalmarz(at)embarqmail.com > > > > > > ________________________________________________________________________________
Date: Jun 15, 2008
N662G 97 hours TTSN First Flight = November 2007 No cracks or other signs of fatigue found Bruce lane Virginia Beach, VA ---- Barry Marz wrote: > > There are quite a few threads on this SB. Why don't we use this > thread to keep track of what people find when they do the inspection? > Just list A/C time and results and we can track the problem with one > search. Blue Skys. > > Barry Marz > 18735 Baseleg AVE. > FT. Myers, Fl 33917 > 239-567-2271 > blalmarz(at)embarqmail.com > > > > > > ________________________________________________________________________________
Subject: SB
Date: Jun 15, 2008
33 hours no cracks N46007 ________________________________________________________________________________
Date: Jun 15, 2008
I may be missing the point of everyone sending in hours and no structural crack reports and although this may be a great idea let's remember the Van's plane saw this at 500 hours with much of those hours for transition training. I sure would not expect many of us to see anything for a few more hundred hours, and if it's mostly straight and level with little stall and landing (hard at that) practice maybe not until 600-750 or more hours. I mentioned this before, Van's rarely sends parts out to us to strengthen what they consider a weakness in the design, so this must be a serious concern for the engineers at Van's. Is it going to take a plane to have a structural issue for us to heed their SB sooner than later? -------------------------------------------------- From: "Bruce Lane" <bruce_a_lane(at)hotmail.com> Sent: Sunday, June 15, 2008 10:35 AM Subject: RE: RV10-List: SB 08-6-1 Inspection > > N662G > 97 hours TTSN > First Flight = November 2007 > No cracks or other signs of fatigue found > > Bruce lane > Virginia Beach, VA > > > ---- Barry Marz wrote: >> >> There are quite a few threads on this SB. Why don't we use this >> thread to keep track of what people find when they do the inspection? >> Just list A/C time and results and we can track the problem with one >> search. Blue Skys. >> >> Barry Marz >> 18735 Baseleg AVE. >> FT. Myers, Fl 33917 >> 239-567-2271 >> blalmarz(at)embarqmail.com >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jun 15, 2008
N220RV is a structural issue, hence their providing a SB. It had far fewer hours on the airframe, than on N410RV. They are not about to admit the material thickness might be spec'ed too thin or the "heat treatment" post fabrication was incorrect. For those who have not yet installed F1010, there are several things that could be done to reduce the likelihood of a similar crack developing. For those who have finished, 5/25/next Conditional should be the mantra. Some may remember the post months ago about cracks in an initial fabricated piece and the words from the factory to just file it, build it and "forgetaboutit". Don't hear that on this crack...do we? If they want reinspections every 25 hours and the crack propagated this far (since the last Conditional), you know it showed some time ago and got missed. So do the inspection but don't "forgetaboutit". And remember "Didn't find the crack Yet, will keep looking!" John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Sunday, June 15, 2008 1:08 PM Subject: Re: RV10-List: SB 08-6-1 Inspection I may be missing the point of everyone sending in hours and no structural crack reports and although this may be a great idea let's remember the Van's plane saw this at 500 hours with much of those hours for transition training. I sure would not expect many of us to see anything for a few more hundred hours, and if it's mostly straight and level with little stall and landing (hard at that) practice maybe not until 600-750 or more hours. I mentioned this before, Van's rarely sends parts out to us to strengthen what they consider a weakness in the design, so this must be a serious concern for the engineers at Van's. Is it going to take a plane to have a structural issue for us to heed their SB sooner than later? -------------------------------------------------- From: "Bruce Lane" <bruce_a_lane(at)hotmail.com> Sent: Sunday, June 15, 2008 10:35 AM Subject: RE: RV10-List: SB 08-6-1 Inspection > > N662G > 97 hours TTSN > First Flight = November 2007 > No cracks or other signs of fatigue found > > Bruce lane > Virginia Beach, VA > > > ---- Barry Marz wrote: >> >> There are quite a few threads on this SB. Why don't we use this >> thread to keep track of what people find when they do the inspection? >> Just list A/C time and results and we can track the problem with one >> search. Blue Skys. >> >> Barry Marz >> 18735 Baseleg AVE. >> FT. Myers, Fl 33917 >> 239-567-2271 >> blalmarz(at)embarqmail.com >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jun 15, 2008
I don't have the sheet in front of my but Tim's info sounds right. I was simply providing my settings. They may or may not work for you; My initial fuel sender used these numbers and after a couple of hours failed. GRT was great and shipped me another one immediately and coincidently it used the same OFF calibration. Bob N442PM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188007#188007 ________________________________________________________________________________
Subject: pre stall buffet
Date: Jun 15, 2008
As I have worked the approach speeds lower, I believe I am getting pre stall buffeting. During the test period my approaches were at 80 kts and half flaps and 75 kts over the numbers in the flare. I did not notice a vibration in the tail and/or flaps on the left side. Recently I have gone to half flaps and 70 kts on short final and into the flare. I feel a slight vibration in the controls prior to touchdown. Since I have been flying it was imprudent to turn my head to look at the left rear of the aircraft. Anyone else have a similar experience? I plan to get my flying partner to land tthe airplane while I observe the rear of the aircraft. ________________________________________________________________________________
Date: Jun 15, 2008
I wish this had been around when I was looking for an engine! I used to leave in the town over from Ly-Con and they are a great outfit. It would certainly be worth asking about when it was overhauled and who's providing the warranty, but I would jump at this in a heartbeat (and no they don't know me and there's no kickback, unfortunately). I worked with a couple guys from Ly-Con on my Skybolt's IO-540 when I did a top overhaul and learned a lot of good things about them. One final caveat, my experience was in 1998 so things may have changed. Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, June 14, 2008 7:41 PM Subject: Re: RV10-List: IO540 need an engine? Good price if you don't mind a narrow deck engine and unknown preservation/storage. Not to mention all the choices about parts used etc. already made for you. Good if you are ready to install, not so good if you are a year or two away from finishing. On Sat, Jun 14, 2008 at 1:59 PM, David McNeill wrote: > http://cgi.ebay.com/ebaymotors/Lycoming-IO-540-D4A5-0-SMOH-by-Ly-Con-FREE-SHIPPING_W0QQcmdZViewItemQQcategoryZ26437QQihZ002QQitemZ120270111673QQrdZ1QQsspagenameZWDVW > > ________________________________________________________________________________
Date: Jun 15, 2008
Subject: Re: pre stall buffet
What stall speed did you derive in your flight testing with full flaps, at gross? I see Van's claims 57mph. How about straight ahead stall speed coordinated with half flaps? David McNeill wrote: > As I have worked the approach speeds lower, I believe I am getting pre > stall buffeting. During the test period my approaches were at 80 kts > and half flaps and 75 kts over the numbers in the flare. I did not > notice a vibration in the tail and/or flaps on the left side. Recently > I have gone to half flaps and 70 kts on short final and into the > flare. I feel a slight vibration in the controls prior to touchdown. > Since I have been flying it was imprudent to turn my head to look at > the left rear of the aircraft. Anyone else have a similar experience? > I plan to get my flying partner to land tthe airplane while I observe > the rear of the aircraft. > * > > > * ________________________________________________________________________________
Date: Jun 15, 2008
Subject: Lost one of our brothers - NOT aviation related
A fellow RV'er emailed me today to give me some sad news from South Australia. One of our RV-10 builder brothers from West Australia, Indran Chelvanayagam, has unfortunately passed. He had looked forward to meeting many of us again at OSH, which is where I first met him about 3 or 4 seasons ago. He was a very friendly person, and I believe he did some good humanitarian work in other countries for many people. He talked of all of his American RV friends with great fondness. He was also a mentor to some of the other builders in West Australia. His passing was not aviation related. While I have no details, the way it was put to me was "unfortunately Indran was suffering with depression unbeknown to all his friends in our local town". I'm sure he probably did not realize what a loss his fellow builders would feel. -- Tim Olson ________________________________________________________________________________
Date: Jun 15, 2008
Subject: Axle Extension Availability Update
Jessie and Everyone, I followed up on Jessie's request for more information on the RV-10 Axle Extensions that are available through Cleaveland Aircraft Tools. They have been added to the website and can be found under the product number: RVAE10 They can be found under New Items or Aircraft Accessories. Mike Lauritsen asked me to apologize for not having it listed sooner. Dave Hertner ________________________________________________________________________________
Date: Jun 16, 2008
Tim - I did not know. I really don't know what to say. I'm sure most, (if not all) of the -10 community in Australia has had some interaction with Indran. Always positive, always constructive and always willing to help - he will be missed. The Oz -10 community is small and close-nit indeed. A very sad day for us here. Ron South Australia -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, 16 June 2008 1:15 PM Subject: RV10-List: Lost one of our brothers - NOT aviation related A fellow RV'er emailed me today to give me some sad news from South Australia. One of our RV-10 builder brothers from West Australia, Indran Chelvanayagam, has unfortunately passed. He had looked forward to meeting many of us again at OSH, which is where I first met him about 3 or 4 seasons ago. He was a very friendly person, and I believe he did some good humanitarian work in other countries for many people. He talked of all of his American RV friends with great fondness. He was also a mentor to some of the other builders in West Australia. His passing was not aviation related. While I have no details, the way it was put to me was "unfortunately Indran was suffering with depression unbeknown to all his friends in our local town". I'm sure he probably did not realize what a loss his fellow builders would feel. -- Tim Olson "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jun 16, 2008
Sad news. Very sad news. Any way we can jointly send a message to his family? Might help a little. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Indran Chelvanayagam, has unfortunately passed. ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: Re: Lost one of our brothers - NOT aviation related
Date: Jun 16, 2008
What a shock he was a top bloke and we were going to catch up with him in Aug when we fly around AUS . Such a shame. Chris Susie and Darcy VH-ICy ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Monday, June 16, 2008 1:45 PM Subject: RV10-List: Lost one of our brothers - NOT aviation related > > A fellow RV'er emailed me today to give me some sad news from > South Australia. One of our RV-10 builder brothers from West > Australia, Indran Chelvanayagam, has unfortunately passed. He > had looked forward to meeting many of us again at OSH, which > is where I first met him about 3 or 4 seasons ago. He was a > very friendly person, and I believe he did some good humanitarian > work in other countries for many people. He talked of all of > his American RV friends with great fondness. He was also a mentor > to some of the other builders in West Australia. His passing > was not aviation related. While I have no details, the way it > was put to me was "unfortunately Indran was suffering with depression > unbeknown to all his friends in our local town". I'm sure he > probably did not realize what a loss his fellow builders would > feel. > > -- > Tim Olson > > > ________________________________________________________________________________
Date: Jun 15, 2008
Last week we recalibrated our AOA which required stalls clean and dirty. At 2400 lbs, 3000' DA , clean was at 62 KIAS, Dirty was 54KIAS. Approaching at 70 with the flaps down shouldn't be anywhere close to a stall, but Marcus is right, you should do some more testing at altitude. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Sunday, June 15, 2008 3:39 PM Subject: RV10-List: pre stall buffet As I have worked the approach speeds lower, I believe I am getting pre stall buffeting. During the test period my approaches were at 80 kts and half flaps and 75 kts over the numbers in the flare. I did not notice a vibration in the tail and/or flaps on the left side. Recently I have gone to half flaps and 70 kts on short final and into the flare. I feel a slight vibration in the controls prior to touchdown. Since I have been flying it was imprudent to turn my head to look at the left rear of the aircraft. Anyone else have a similar experience? I plan to get my flying partner to land tthe airplane while I observe the rear of the aircraft. ________________________________________________________________________________
Subject: Re: Panel extended or work-around of lower panel support flange
Date: Jun 15, 2008
I am not so sure about the placement of those vents. I think that they might fall more easily under the panel lower flange -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188063#188063 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jun 16, 2008
Well that just sucks. I've lost too many friends in the last couple years in both aviation and my personal life. Indran was a hell of a nice guy and we hung out together a bit when he was in OSH a couple years ago. I just bugged him a little while back about when he was going to make it to OSH again. He will be missed. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, June 15, 2008 10:45 PM Subject: RV10-List: Lost one of our brothers - NOT aviation related A fellow RV'er emailed me today to give me some sad news from South Australia. One of our RV-10 builder brothers from West Australia, Indran Chelvanayagam, has unfortunately passed. He had looked forward to meeting many of us again at OSH, which is where I first met him about 3 or 4 seasons ago. He was a very friendly person, and I believe he did some good humanitarian work in other countries for many people. He talked of all of his American RV friends with great fondness. He was also a mentor to some of the other builders in West Australia. His passing was not aviation related. While I have no details, the way it was put to me was "unfortunately Indran was suffering with depression unbeknown to all his friends in our local town". I'm sure he probably did not realize what a loss his fellow builders would feel. -- Tim Olson ________________________________________________________________________________
From: "James, Peter [SD]" <Peter.James(at)sprint.com>
Date: Jun 16, 2008
Subject: RE: RV10-List Digest: ABF
I had 3 of my shipments sent by ABF (Already Been Forked up). They were in terrible shape! One was upside down, despite big arrows and $ signs all over it. It was covered on both sides with footprints. Another had the entire top sheared off by the forks of the fork truck! I was lucky, my contents were not damaged. Mike Lauritsen's crates had been speared by a fork truck and he had to have entire skins replaced. I sent complaints and numerous pictures to Van's - shortly after, FEDEX Freight became an option. I have used them for everything since... including my engine. I don't have a single complaint. Thanks! Pete 40100 - sometime later this year! ________________________________________________________________________________
Subject: Re: Hartzell prop and IO540D4A5
Date: Jun 16, 2008
Subject: Seminar Question
Date: Jun 16, 2008
We will be holding another seminar towards the end of August. My question to the group is about topics. The composite classes are popular and well attended, but if you'd like to see other topics, please let me know. For example, now that lots of 10s are flying, is there any interest in a weekend class on annual inspections and routine maintenance? It's a straight-forward plane but if you've never timed a magneto or changed brake pads it might be worthwhile. Or electrical systems, more in-depth than Sport-Air provides? Maybe more layout and design, or specific hand-on tasks? Firewall Forward? Doors? Also, if someone on the west coast needs their top trimmed and fit in the next few months, let me know. We need a volunteer to demonstrate for the class. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Jun 16, 2008
Subject: IFR GPS
I posed the question of what's needed for LEGAL IFR operation, and this was the reply I got. He lives in the certified airplane world but ....... The unit must be certified under either TSO-c129 or TSO-c146, be installed in the aircraft, and be approved in that aircraft on a 337 via either STC or field approval (if no STC for that aircraft exists). No TSO, no IFR approval. Since I'm planning on using the Odyssee (http://www.mglavionics.com/html/odyssey.html) glass panel with it's built-in WAAS capableGPS with RAIM ....... there's no TSO. Those of you with glass panels that fly IFR with a built-in GPS ....... did you use a certified GPS as backupor wing it ..... pun intended :-D . Linn so not archive ________________________________________________________________________________
Subject: IFR GPS
Date: Jun 16, 2008
Hi Linn, The info is "part right". It needs technically and legally needs to meet the TSO, but of course there is no requirement for an STC or 337. STC/337 are moot for experimentals. Cheers, Stein >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of linn Walters >Sent: Monday, June 16, 2008 2:33 PM >To: RV-10; RV >Subject: RV10-List: IFR GPS > > >I posed the question of what's needed for LEGAL IFR operation, and this >was the reply I got. He lives in the certified airplane world but ....... > >The unit must be certified under either TSO-c129 or TSO-c146, be >installed in the aircraft, and be approved in that aircraft on a >337 via either >STC or field approval (if no STC for that aircraft exists). No TSO, no IFR >approval. > >Since I'm planning on using the Odyssee >(http://www.mglavionics.com/html/odyssey.html) glass panel with it's >built-in WAAS capableGPS with RAIM ....... there's no TSO. Those of you >with glass panels that fly IFR with a built-in GPS ....... did you use a >certified GPS as backupor wing it ..... pun intended :-D . >Linn >so not archive > > ________________________________________________________________________________
Date: Jun 16, 2008
Strange! I read- Rob (or anyone else who knows) Status on the composite blade testing completed yet? -Performance on climb? -cruise? -smoothness compared to 2 and/or 3 blade props ? -Any general thoughts? Thanks! Pascal -------------------------------------------------- From: "pascal" <pascal(at)rv10builder.net> Sent: Monday, June 16, 2008 10:11 AM Subject: Re: RV10-List: Re: Hartzell prop and IO540D4A5 ________________________________________________________________________________
Date: Jun 16, 2008
Subject: IFR GPS
There are nine FSDO regions and 83 offices within those regions and I venture that each will have a different interpretation of this for experimentals. I think if you intend to go this route however, you should get this in writing from one of those 83 FSDOs . Otherwise, if you are ramp checked after completing an RNAV approach, potentially you could be cited for not having an "approved" GPS navigator. To avoid the ambiguity, most just go with an approved GPS navigator. http://www.atlasaviation.com/FSDO%20Locations/FSDO_Locations.htm If *I* planned to fly IFR in ANY plane, experimental or otherwise, then my primary GPS navigation equipment WILL be TSO'd c129 or C146a certified. But that's just me. YMMV. To me an $8000 TSO C146a GPS/Nav/Com offers peach of mind, that a $500 non certified GPS with RAIM (RAIM not proven to anyone outside the company--such as the FAA) does NOT offer. William http://nerv10.com/wcurtis/ -------- Original Message -------- > > > I posed the question of what's needed for LEGAL IFR operation, and this > was the reply I got. He lives in the certified airplane world but ....... > > The unit must be certified under either TSO-c129 or TSO-c146, be > installed in the aircraft, and be approved in that aircraft on a 337 via either > STC or field approval (if no STC for that aircraft exists). No TSO, no IFR > approval. > > Since I'm planning on using the Odyssee > (http://www.mglavionics.com/html/odyssey.html) glass panel with it's > built-in WAAS capableGPS with RAIM ....... there's no TSO. Those of you > with glass panels that fly IFR with a built-in GPS ....... did you use a > certified GPS as backupor wing it ..... pun intended :-D . > Linn > so not archive ________________________________________________________________________________
Subject: SB
Date: Jun 16, 2008
as an example of why we need for info about the cause of the damage to 220RV. I just received ,today, a new SB for my Glastar. In the SB ; the writer states that all counterweights for the elevator must be inspected visually for cracks in the aluminum where the screws hold the counterweight in place. In addition it says that these counterweights must be inspected every annual. Now the fiberglass tips have never been off my Glastar and the building instructions have them installed with blind rivets. Big change.................... Now the rest of the story. The only airplane to experience a problem was a "two weeks to taxi " build that was being shipped from the factory to the builders address. The elevator was stored/transported by truck vertically without the fiberglass tip in place. Damage occurred...Then somebody decided at the factory to issue an SB to all flying aircraft. what a crock. ________________________________________________________________________________
Subject: Re: IFR GPS
Date: Jun 16, 2008
I am a high time VFR pilot, but wanted my plane to have IFR capability. I put in a Garmin 496 - non IFR GPS as my primary navigation system. For the IFR requirements I was told to put in the following: Garmin SL30 Nav/Com with external antenna (CDI on AFS3500 unit) Audio Panel with Marker Beacon Transponder Timer (on AFS3500 unit) Heated Pitot - Gretz G1000 (if I get it in a reasonable time frame) Full lighting system - for night optionally Backup ADI, Altimeter and A/S -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188227#188227 ________________________________________________________________________________
Date: Jun 16, 2008
Go for the Rivethead pin blocks. They are so good and so smooth that I consider them a MANDATORY option. The standard system is so inferior to the Rivethead system it is crazy to struggle with it. The Rivethead system is not perfectly straightforward but it is pretty slick when it is finished. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188228#188228 ________________________________________________________________________________
Subject: First flight and governor
Date: Jun 17, 2008
Just recieved the Dynon back from Dynon which they replaced with a new one. Did engine start today and due to a few reasons I had to run the engine longer than I would like. I am not getting the 2700 RPM and I do I understand I need to Adjust the governor but my question is can I go flying now and Adjusted it after each flight till its right. I realy do not want to start the engine again till first flight on Sat weather permiting?? regards Chris VH-ICY ________________________________________________________________________________
Date: Jun 17, 2008
Chris what is your max static rpm reading? John 40315 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough Sent: Tuesday, 17 June 2008 3:41 PM Subject: RV10-List: First flight and governor Just recieved the Dynon back from Dynon which they replaced with a new one. Did engine start today and due to a few reasons I had to run the engine longer than I would like. I am not getting the 2700 RPM and I do I understand I need to Adjust the governor but my question is can I go flying now and Adjusted it after each flight till its right. I realy do not want to start the engine again till first flight on Sat weather permiting?? regards Chris VH-ICY ________________________________________________________________________________
Subject: Re: First flight and governor
Date: Jun 17, 2008
About 2500 but will recheck on Sat ----- Original Message ----- From: "John Dunne" <acs(at)acspropeller.com.au> Sent: Tuesday, June 17, 2008 4:12 PM Subject: RE: RV10-List: First flight and governor > > Chris what is your max static rpm reading? > John 40315 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie > McGough > Sent: Tuesday, 17 June 2008 3:41 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: First flight and governor > > > > Just recieved the Dynon back from Dynon which they replaced with a new > one. > Did engine start today and due to a few reasons I had to run the engine > longer than I would like. I am not getting the 2700 RPM and I do I > understand I need to Adjust the governor but my question is can I go > flying > now and Adjusted it after each flight till its right. I realy do not want > to > > start the engine again till first flight on Sat weather permiting?? > > regards Chris VH-ICY > > > ________________________________________________________________________________
Date: Jun 17, 2008
Subject: Re: SB
Rick so how many drilled out and replaced rivets will this bring your total up to? **************Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Date: Jun 17, 2008
AirMike wrote: > Go for the Rivethead pin blocks. They are so good and so smooth that I consider them a MANDATORY option. The standard system is so inferior to the Rivethead system it is crazy to struggle with it. The Rivethead system is not perfectly straightforward but it is pretty slick when it is finished. > I'd have to totally agree given my recent experience installing them. There is little installation guidance but muddling thru worked quite well. A few tips based on my experience: - install the nylon blocks in the door as far back in their recesses as possible. Don't just clear the outer edge of the recess but shape it so it can clear the edge by a 1/8" or so. - Adjust the latch arms so the pins touch but don't necessarily penetrate the door sill (Mine penetrate slightly) - use the Rivethead pins to mark the location of the blocks by just dabbing some ink on the tip, holding the door in place, and operating the latch. Do one block at a time - fabricate a 10-32 threaded pin with a point on it. Screw them into the Rivethead block, use the inked mark to locate the block and use a mallet to mark 1 mounting hole. - With one hole drilled and a screw inserted, put the threaded pin in the other hole, operate the latch, get the door in the flush position you want, tighten the bolt. Them unlatch the door, move it out of the way, and use a mallet to mark the 2nd hole. That gave me just about a perfect fit - for the time being anyway. Very nice pins and blocks. ________________________________________________________________________________
Subject: Boston Area RV-10 Builders?
Date: Jun 17, 2008
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I'm in the Boston area all week and looks like I will have plenty of slack time. If there are any builders in the area up for a visit contact me offline. Bob N442PM (flying) ________________________________________________________________________________
Date: Jun 17, 2008
Forgot that it strips my email address. Contact at bob.condrey (at) baesystems.com. Bob _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Tuesday, June 17, 2008 8:59 AM Subject: RV10-List: Boston Area RV-10 Builders? I'm in the Boston area all week and looks like I will have plenty of slack time. If there are any builders in the area up for a visit contact me offline. Bob N442PM (flying) ________________________________________________________________________________
Date: Jun 17, 2008
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
MauleDriver: Did you have your seal on the door? Dr Fred 40515. MauleDriver wrote: > > AirMike wrote: >> Go for the Rivethead pin blocks. They are so good and so smooth that >> I consider them a MANDATORY option. The standard system is so >> inferior to the Rivethead system it is crazy to struggle with it. The >> Rivethead system is not perfectly straightforward but it is pretty >> slick when it is finished. >> > I'd have to totally agree given my recent experience installing them. > There is little installation guidance but muddling thru worked quite > well. A few tips based on my experience: > - install the nylon blocks in the door as far back in their recesses > as possible. Don't just clear the outer edge of the recess but shape > it so it can clear the edge by a 1/8" or so. > - Adjust the latch arms so the pins touch but don't necessarily > penetrate the door sill (Mine penetrate slightly) > - use the Rivethead pins to mark the location of the blocks by just > dabbing some ink on the tip, holding the door in place, and operating > the latch. Do one block at a time > - fabricate a 10-32 threaded pin with a point on it. Screw them into > the Rivethead block, use the inked mark to locate the block and use a > mallet to mark 1 mounting hole. > - With one hole drilled and a screw inserted, put the threaded pin in > the other hole, operate the latch, get the door in the flush position > you want, tighten the bolt. Them unlatch the door, move it out of the > way, and use a mallet to mark the 2nd hole. > > That gave me just about a perfect fit - for the time being anyway. > Very nice pins and blocks. > > ________________________________________________________________________________
Date: Jun 17, 2008
Subject: Wheel Jack
Does anyone have experience with using a wheel jack for the RV10, good or bad recommendations? Sam #40157 And no cracks! ________________________________________________________________________________
Subject: Wheel Jack
Date: Jun 17, 2008
I use the type that uses a short bottle jack and goes into the hollow axel after you remove the axel nut. Works fine and much better than the type that uses a bracket clamped to the gear leg to provide a place to put a bottle jack. The bracket often slips on the gear leg. However, when possible I use wing jacks. Much safer. Albert Gardner N991RV Yuma, AZ -----Original Message----- Does anyone have experience with using a wheel jack for the RV10, good or bad recommendations? Sam #40157 And no cracks! ________________________________________________________________________________
Date: Jun 17, 2008
Fred Williams, M.D. wrote: > MauleDriver: > > Did you have your seal on the door? > Dr Fred > 40515. Nope. >> >> That gave me just about a perfect fit - for the time being anyway. >> Bill Watson 40605 ________________________________________________________________________________
Subject: window adhesives revisited.
Date: Jun 17, 2008
I jumped the gun a while back and didn't carefully enough look at the instr uctions on the Sikaflex web site. If I hadn't already painted the interior of my canopy I would have added fiberglass to the inside of the window flan ge to thicken it so that I could deepen the flange to allow a greqater bond thickness Also, at initial trimming I would have als left the flange one i nch wide not 3/4" wide. The pros with the use of Sikaflex is the idea of a floating acrylic window which would allow for expansion and contraction. The thermal coefficient of expansion between the frame and the window is huge. Because of this, Sikaf lex requires a 3/16'" thick bond thickness and an expansion gap at the edge of 1/4" to 3/8". Given all these requirements, my existing frame flange wi ll need to be thinned by 1/16" and the window thinned by 1/16" whick would still leave the window proud of the outside contour. Also because the flang e is only 3/4", and because we would need a minimum of 1/4" expansion gap, when the window contracts in the cold it will not have that much bond space . I orderred the Weld on and will most likely do it that way and bond it and cover the gap and the edge of the window and the canopy with fiberglass for a smooth transition as I see on most fiberglass ships. The thing that concerns me is that we are trying to contain/constrict the p lexiglass during expansion and contraction and that just doesn't seem right . I suppose the Glasair guys with 10 year old ships should be able to put m y concerns at ease. Oh well, just the over analysing dentist in me. JOhn G. #409 ________________________________________________________________________________
Subject: Re: window adhesives revisited.
Date: Jun 17, 2008
Even if you use an adhesive that requires less bond thickness, you will have places where the window stands proud of the cabin surface. There will also be places where the door is proud of the top, and other places where the top is proud of the door. You should be very proud. All of this can be accommodated by contouring with micro or other lightweight filler. Jim Berry 40482 Proud to be finished with fiberglass Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188333#188333 ________________________________________________________________________________
Date: Jun 17, 2008
I flew my Glasair III with =BD=94 thick windshield for 15 years with it bonded into the frame with epoxy with no problems of cracking or crazing. With that thick of windshield there is no flexing of the acrylic to take up any differential in expansion either. There are many hundreds of Glasairs out there with the same proven record. You can tell from the above comment how I put my window in the 10. Gary 40274 Flying _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Tuesday, June 17, 2008 11:53 AM Subject: RV10-List: window adhesives revisited. I jumped the gun a while back and didn't carefully enough look at the instructions on the Sikaflex web site. If I hadn't already painted the interior of my canopy I would have added fiberglass to the inside of the window flange to thicken it so that I could deepen the flange to allow a greqater bond thickness Also, at initial trimming I would have als left the flange one inch wide not 3/4" wide. The pros with the use of Sikaflex is the idea of a floating acrylic window which would allow for expansion and contraction. The thermal coefficient of expansion between the frame and the window is huge. Because of this, Sikaflex requires a 3/16'" thick bond thickness and an expansion gap at the edge of 1/4" to 3/8". Given all these requirements, my existing frame flange will need to be thinned by 1/16" and the window thinned by 1/16" whick would still leave the window proud of the outside contour. Also because the flange is only 3/4", and because we would need a minimum of 1/4" expansion gap, when the window contracts in the cold it will not have that much bond space. I orderred the Weld on and will most likely do it that way and bond it and cover the gap and the edge of the window and the canopy with fiberglass for a smooth transition as I see on most fiberglass ships. The thing that concerns me is that we are trying to contain/constrict the plexiglass during expansion and contraction and that just doesn't seem right. I suppose the Glasair guys with 10 year old ships should be able to put my concerns at ease. Oh well, just the over analysing dentist in me. JOhn G. #409 ________________________________________________________________________________
Date: Jun 17, 2008
Subject: Door Armrest?
A couple of flight instructors have sat/ridden in my -10 and have remarked that I should consider installing an armrest on the inside of the door. I've seen the center console solution but has anyone attached them to the door? Brian Sutherland Nashville, TN N104BS 42 hours...no cracks, and headed to Glo-Custom in 2 weeks! ________________________________________________________________________________
Date: Jun 17, 2008
Subject: Re: Door Armrest?
I was also considering something like this by bolding a armrest to the door using fiberglass layups. Ray ---- rv10builder wrote: > > A couple of flight instructors have sat/ridden in my -10 and have > remarked that I should consider installing an armrest on the inside of > the door. I've seen the center console solution but has anyone attached > them to the door? > > Brian Sutherland > Nashville, TN > N104BS > 42 hours...no cracks, and headed to Glo-Custom in 2 weeks! > > > ________________________________________________________________________________
Date: Jun 17, 2008
give 'em a book or something else that takes two hands to do, and then tell them to install armrests in their airplane!- Oh - they're riding in your s!=0A=0ARob=0Acan't wait to take some pax=0A=0A----- Original Message ---- =0AFrom: rv10builder <rv10builder(at)bellsouth.net>=0ATo: "rv10-list@matronics .com" =0ASent: Tuesday, June 17, 2008 9:05:56 PM rv10builder =0A=0AA couple of- flight instruct ors have sat/ridden in my -10 and have =0Aremarked that I should consider i nstalling an armrest on the inside of =0Athe door.- I've seen the center console solution but has anyone attached =0Athem to the door?=0A=0ABrian Su therland=0ANashville, TN=0AN104BS=0A42 hours...no cracks, and headed to Glo -=- - - - - - - - - - - - - - - -Matt Drall ==========0A=0A=0A ________________________________________________________________________________
Date: Jun 17, 2008
Brian, I don't have armrests, just some padding on the lower part of the door. Also, I painted the upper part with texture paint, like truck bedliner. Whatever I did, when it came back from upholstry with the new padding in place, the strut wouldn't hold the door up all the time. It's just heavy eneough now to let it come slamming down if it's cold or in a gentle breeze. I measured the strut force and it's fine--I guess it's just a heavy door now. Both doors are virtually identical, but the left side stays up just fine. So, be careful what you add to the door. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10builder Sent: Tuesday, June 17, 2008 6:06 PM Subject: RV10-List: Door Armrest? A couple of flight instructors have sat/ridden in my -10 and have remarked that I should consider installing an armrest on the inside of the door. I've seen the center console solution but has anyone attached them to the door? Brian Sutherland Nashville, TN N104BS 42 hours...no cracks, and headed to Glo-Custom in 2 weeks! ________________________________________________________________________________
Subject: Archer ELT Antenna
Date: Jun 18, 2008
Has anyone fabricated/installed the Archer ELT Antenna per the attached drawing? It seems easy enough, but the devil's always in the details... Photos? Cheers, Jay For those with email digest: http://www.brinkmeyers.net/docs/ArcherELTAntennaRV10.pdf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188442#188442 Attachments: http://forums.matronics.com//files/archereltantennarv10_186.pdf ________________________________________________________________________________
Date: Jun 18, 2008
I just had an interior guy install arm rests on my plane and what he did, which I thought was a good idea, was to installed a couple of nut plates in the arm rest and then put an aluminum doubler on the part that mates up against the door panel. Then he made another doubler for the opposite side of the door panel and ran the screws through that piece into the arm rests nut plates. Wayne Edgerton N602WT ________________________________________________________________________________
Date: Jun 18, 2008
> On Jun 17, 2008, at 9:52 AM, John Gonzalez wrote: > .... If I hadn't already painted the interior of my canopy I would > have added fiberglass to the inside of the window flange to thicken > it so that I could deepen the flange to allow a greqater bond > thickness Also, at initial trimming I would have als left the flange > one inch wide not 3/4" wide... We went through this and decided not to post 2 months ago, but maybe the following will be of value to somebody. When we considered Sikaflex, I did the differential thermal expansion (actually contraction is critical) calculations in the attached spread sheet, which assumes free movement of the plexi relative to the fiberglass. The results are appended as text below in case the attachment can't be posted. It's clear that even a stretchy Sikaflex glue line cannot accommodate the necessary movement unless it is _very_ thick. For example, the door glue line would have to be uniformly 1/8" thick to accept the contraction of 0.07" (on the diagonal) that would result from cooling to - 35 =B0F from a fabrication temperature of 75 =B0F. In that situation the glue would have to stretch 15%. I think that would be near the limit, and it might break or become un-bonded if it were thinner anywhere. The flange is nowhere near deep enough to give that kind of thickness, and of course the flange depth and plexi thickness are not completely uniform. Sikaflex tech support briefly reviewed the situation with me and agreed. Apparently more than a few tens of percent stretch is not tolerable. My expectation is that the allowable stretch might be less at low temperatures, but I didn't ask them. After talking to Van's engineering about the situation, it finally dawned on me that the RV10 design approach was to hard bond (very little flexibility) the plexi to the fiberglass and let the expansion forces be taken by deformation of the structure. This puts tremendous forces on the adhesive. For that reason, we elected to stay with Van's design and materials. As pointed out in other posts, this is essentially the same approach as epoxying the window in place and making a glass flange around its periphery, a la Glasair, et al. Quite a change from the free-floating windows in Cessna, et al, huh? John Ackerman 40458 Assume: Zero stress at fabrication Plexi and GRP expand and contract as "free bodies" - bond stretches No deformation of acrylic or GRP (as opposed to expansion) Acrylic free to expand and contract in flange "joggle" Perfect fit of window in flange "joggle" Expansion coeff's from: http://www.edl-inc.com/Plastic%20expansion%20rates.htm 3.80E-05 Thermal expansion coefficient, acrylic, per =B0F 2.00E-05 Thermal expansion coefficient, epoxy GRP, per =B0F 1.80E-05 Differential thermal expansion coefficient, per =B0F 145 Max temp, =B0F (Phoenix Summer in sun) -35 Min temp =B0F (North Dakota winter in hangar) 75 Fabrication temp =B0 110 Max temp swing from zero stress state, =B0F 36 Max length of door window (diagonal), inch 0.071 Max length change of door window, inch 0.036 Max bond point movement, inch 27.5 Max length of rear window (diagonal), inch 0.054 Max length change of rear window, inch 0.027 Max bond point movement, inch Elongation ratio is the stretched length of a section of adhesive between the fiberglass and the plexi, divided by its unstretched length. Door Cabin elongation, in 0.071 0.027 Bond thickness, in Elongation Ratio 1/8 1.15 1.02 1/16 1.52 1.09 3/64 1.82 1.16 1/32 2.49 1.33 1/64 4.67 2.01 Bond thickness, in % elongation 1/8 15% 2% 1/16 52% 9% 3/64 82% 16% 1/32 149% 33% 1/64 367% 101% ________________________________________________________________________________
Date: Jun 18, 2008
This was an awesome email. Thank you for truly educating me and making my d ecision an easier one. Anyone want to buy five tubes of Sikaflex, cleaner and primer. Darn, I coul d have filled up my F250 diesel one time with the money I spent on that stu ff or my Prius six or seven times. Oh , need to figure the hazardous waste disposal fee also. John G. From: johnag5b(at)cableone.netTo: rv10-list(at)matronics.comSubject: Re: RV10-Lis t: window adhesives revisited.Date: Wed, 18 Jun 2008 10:13:09 -0700 On Jun 17, 2008, at 9:52 AM, John Gonzalez wrote:.... If I hadn't already p ainted the interior of my canopy I would have added fiberglass to the insid e of the window flange to thicken it so that I could deepen the flange to a llow a greqater bond thickness Also, at initial trimming I would have als l eft the flange one inch wide not 3/4" wide...We went through this and decid ed not to post 2 months ago, but maybe the following will be of value to so mebody. When we considered Sikaflex, I did the differential thermal expansion (actu ally contraction is critical) calculations in the attached spread sheet, wh ich assumes free movement of the plexi relative to the fiberglass. The resu lts are appended as text below in case the attachment can't be posted. ________________________________________________________________________________
Subject: HID replacement lights
Date: Jun 18, 2008
Just spent three hours swapping the halogen landing lights provided by Vans with a set of 50W direct replacement HID lights. The before and after pictures should be on http://www.planelights.com/index.php?id=661 in a few days. Will be able to show the lights at OSH on the 31,1,2. ________________________________________________________________________________
Subject: leg and wheel fairings
Date: Jun 18, 2008
Just fitted the fairings last afternoon. Outside temps were 112F; higher in the hangar. Two questions: the plans call for extra layers of glass on the intersection fairings but do not state where the glass goes. Anybody install the extra glass? if so where did you put it? Also found that the areas where they suggest no screws due to access can be easily handled using a button head screw with an internal hex head. what kind of indicated airspeed increase was experienced with fairings for a given power setting? ________________________________________________________________________________
Date: Jun 18, 2008
Not scientific..but I showed about 14 knots. But again...not scientific. Very happy with the speed increase and I thought the airplane handled a little better. Also, my trim did not change. Now, after I did the test I spent a lot of effort blending in the intersection fairings and they are at the painter right now. My plan is to get them on the plan Friday and do some more testing with the paint on..final config. Based on the first bit of testing, I am hoping for the best. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Wednesday, June 18, 2008 2:45 PM Subject: RV10-List: leg and wheel fairings Just fitted the fairings last afternoon. Outside temps were 112F; higher in the hangar. Two questions: the plans call for extra layers of glass on the intersection fairings but do not state where the glass goes. Anybody install the extra glass? if so where did you put it? Also found that the areas where they suggest no screws due to access can be easily handled using a button head screw with an internal hex head. what kind of indicated airspeed increase was experienced with fairings for a given power setting? ________________________________________________________________________________
Date: Jun 18, 2008
Subject: Re: Archer ELT Antenna
Jay, ELT or MKR BCN? Rick Sked 40185 ----- Original Message ----- From: "jayb" <jaybrinkmeyer(at)yahoo.com> Sent: Wednesday, June 18, 2008 3:38:42 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Archer ELT Antenna Has anyone fabricated/installed the Archer ELT Antenna per the attached drawing? It seems easy enough, but the devil's always in the details... Photos? Cheers, Jay For those with email digest: http://www.brinkmeyers.net/docs/ArcherELTAntennaRV10.pdf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188442#188442 Attachments: http://forums.matronics.com//files/archereltantennarv10_186.pdf ________________________________________________________________________________
Date: Jun 18, 2008
Keep in mind that any ELT will not meet the TSO requirement without its manufacturer antenna. They are all TSO approved with their own specific antenna, and you are required by regulation to have a TSO'd ELT regardless of the type of aircraft, if you don't want to be bound by the limitations of no ELT. Can't say how many FSDO types are that sharp on the subject. Rick Sked wrote: > > Jay, > > ELT or MKR BCN? > > Rick Sked > 40185 > ----- Original Message ----- > From: "jayb" <jaybrinkmeyer(at)yahoo.com> > To: rv10-list(at)matronics.com > Sent: Wednesday, June 18, 2008 3:38:42 AM (GMT-0800) America/Los_Angeles > Subject: RV10-List: Archer ELT Antenna > > > Has anyone fabricated/installed the Archer ELT Antenna per the attached drawing? It seems easy enough, but the devil's always in the details... Photos? > > Cheers, > Jay > > For those with email digest: > http://www.brinkmeyers.net/docs/ArcherELTAntennaRV10.pdf > > ________________________________________________________________________________
Date: Jun 18, 2008
Since I'm going the Silpruf method and it is also a=C2-silicone based pro duct I have to consider those ratio's also but,=C2- I have the video from the Glasair folk on how to install using the Silpruf adhesive and there is a gap left around the window to be filled after paint with Silpruf...this should eliminate the contraction space=C2-problem.=C2- Given the differ ent expansion and contraction rates for the plexi vs. fiberglass, it seems that no matter what you did the only time the glass would not be either und er negative or positive compression would be at the exact temperature that occurred during installation. This would explain the cracks around the wind ows installed with Weldon=C2-since the Weldon creates an ungiving, solid bond between both materials. If you allow for expansion and the material us ed in the expansion/contraction joint is flexible I think this would presen t a better option than the Weldon. Filling the areas around the windows=C2 -with flox/epoxy and covering with glass cloth gives brute strength to th e gap hopefully preventing the cracks. I talked to two Glasair builders wit h 10 plus years on their aircraft with glass installed with Silpruf or simi lar silicone=C2-and they had no problems...This is kinda getting like pri mer wars in a way. If you get a chance to look at a Cirrus up close you wil l see their windows are installed with a defined gap around the plexi to ca bin flange, the gap is filled with a material either like proseal or silico ne...maybe anyone with experience on the Cirrus windows may be able to shed more light on that install. Till then...I'm sticking (literally) to Silpru f install. Rick Sked 40185 ----- Original Message ----- From: "John Ackerman" <johnag5b(at)cableone.net> Sent: Wednesday, June 18, 2008 10:13:09 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: window adhesives revisited. On =C2-Jun 17, 2008, at 9:52 AM, John Gonzalez wrote: .... If I hadn't al ready painted the interior of my canopy I would have added fiberglass to th e inside of the window flange to thicken it so that I could deepen the flan ge to allow a greqater bond thickness Also,=C2-at initial trimming I woul d have als left the flange one inch wide not 3/4" wide... We went through this and decided not to post 2 months ago, but maybe the fo llowing will be of value to somebody. When we considered Sikaflex, I did the differential thermal expansion (actu ally contraction is critical) calculations in the attached spread sheet, wh ich assumes free movement of the plexi relative to the fiberglass. The resu lts are appended as text below in case the attachment can't be posted. ________________________________________________________________________________
Date: Jun 18, 2008
That was kinda my point....that's why I asked if it was the ELT or MB since they all come with their own antenna. Bob Archer is known for his coax makeshift marker beacon ant. which work like a champ, along with the other sheet metal gems for NAV/COM. Rick Sked 40185 MY ELT will be outta date if I don't get this finished soon!! ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> Sent: Wednesday, June 18, 2008 3:27:57 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Archer ELT Antenna Keep in mind that any ELT will not meet the TSO requirement without its manufacturer antenna. They are all TSO approved with their own specific antenna, and you are required by regulation to have a TSO'd ELT regardless of the type of aircraft, if you don't want to be bound by the limitations of no ELT. Can't say how many FSDO types are that sharp on the subject. Rick Sked wrote: > > Jay, > > ELT or MKR BCN? > > Rick Sked > 40185 > ----- Original Message ----- > From: "jayb" <jaybrinkmeyer(at)yahoo.com> > To: rv10-list(at)matronics.com > Sent: Wednesday, June 18, 2008 3:38:42 AM (GMT-0800) America/Los_Angeles > Subject: RV10-List: Archer ELT Antenna > > > Has anyone fabricated/installed the Archer ELT Antenna per the attached drawing? It seems easy enough, but the devil's always in the details... Photos? > > Cheers, > Jay > > For those with email digest: > http://www.brinkmeyers.net/docs/ArcherELTAntennaRV10.pdf > > ________________________________________________________________________________
Subject: Re: leg and wheel fairings
Date: Jun 18, 2008
Two layers of glass over the entire upper and lower intersection fairings. Those parts as received from Van's are only 2 layers thick, and would not survive without the extra layers. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188554#188554 ________________________________________________________________________________
Date: Jun 18, 2008
Finished opening everything up this evening. Not flying yet, so, of course, no issues with the bulkhead. We did manage to easily remove the trim without getting into the tailcone. Did it all from the outside. Should get the doublers installed tomorrow and plan to have it all back together by Saturday. Drilling out 52 (?) rivets was the worst part, so far. I elongated a couple of holes a bit, so might have to install oversize rivets. Would there be any problem installing a bolt or screw and lock nut in an oversize hole? -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188560#188560 ________________________________________________________________________________
Subject: HID lights
Date: Jun 18, 2008
Tested the new HID replacements tonight. The after pictures will be on the http://www.planelights.com/ in a couple of days. The results were extraordinary. I would not consider taxi at night with Vans halogen lights. These lights are 3-4 times brighter and more focused than the standard lights. I will show them if interested at OSH 31,1,2. I will be camping in RV10 headquarters. ________________________________________________________________________________
Date: Jun 19, 2008
Subject: Re: HID lights
Can these HID lights be used with a Wig - Wag system that alternates from left side to right? Thanks Ray ---- David McNeill wrote: > Tested the new HID replacements tonight. The after pictures will be on the > http://www.planelights.com/ in a couple of days. The results were > extraordinary. I would not consider taxi at night with Vans halogen lights. > These lights are 3-4 times brighter and more focused than the standard > lights. I will show them if interested at OSH 31,1,2. I will be camping in > RV10 headquarters. ________________________________________________________________________________
Date: Jun 19, 2008
Is this a discussion about the use of the windshield as a structural component? I've not paid much attention to the windshield debate, but if structural, then Weldon, I would think. John Jessen 40328 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Wednesday, June 18, 2008 3:40 PM Subject: Re: RV10-List: window adhesives revisited. Since I'm going the Silpruf method and it is also a silicone based product I have to consider those ratio's also but, I have the video from the Glasair folk on how to install using the Silpruf adhesive and there is a gap left around the window to be filled after paint with Silpruf...this should eliminate the contraction space problem. Given the different expansion and contraction rates for the plexi vs. fiberglass, it seems that no matter what you did the only time the glass would not be either under negative or positive compression would be at the exact temperature that occurred during installation. This would explain the cracks around the windows installed with Weldon since the Weldon creates an ungiving, solid bond between both materials. If you allow for expansion and the material used in the expansion/contraction joint is flexible I think this would present a better option than the Weldon. Filling the areas around the windows with flox/epoxy and covering with glass cloth gives brute strength to the gap hopefully preventing the cracks. I talked to two Glasair builders with 10 plus years on their aircraft with glass installed with Silpruf or similar silicone and they had no problems...This is kinda getting like primer wars in a way. If you get a chance to look at a Cirrus up close you will see their windows are installed with a defined gap around the plexi to cabin flange, the gap is filled with a material either like proseal or silicone...maybe anyone with experience on the Cirrus windows may be able to shed more light on that install. Till then...I'm sticking (literally) to Silpruf install. Rick Sked 40185 ----- Original Message ----- From: "John Ackerman" <johnag5b(at)cableone.net> Sent: Wednesday, June 18, 2008 10:13:09 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: window adhesives revisited. On Jun 17, 2008, at 9:52 AM, John Gonzalez wrote: .... If I hadn't already painted the interior of my canopy I would have added fiberglass to the inside of the window flange to thicken it so that I could deepen the flange to allow a greqater bond thickness Also, at initial trimming I would have als left the flange one inch wide not 3/4" wide... We went through this and decided not to post 2 months ago, but maybe the following will be of value to somebody. When we considered Sikaflex, I did the differential thermal expansion (actually contraction is critical) calculations in the attached spread sheet, which assumes free movement of the plexi relative to the fiberglass. The results are appended as text below in case the attachment can't be posted. ________________________________________________________________________________
Date: Jun 19, 2008
Any updates? Pascal -------------------------------------------------- From: "pascal" <pascal(at)rv10builder.net> Sent: Monday, June 16, 2008 1:15 PM Subject: Re: RV10-List: Re: Hartzell prop and IO540D4A5 > Rob (or anyone in Oregon who knows) > Status on the composite blade testing completed yet? > -Performance on climb? > -cruise? > -smoothness compared to 2 and/or 3 blade props ? > -Any general thoughts? > > Thanks! > Pascal > > -------------------------------------------------- > From: "pascal" <pascal(at)rv10builder.net> > Sent: Monday, June 16, 2008 10:11 AM > To: > Subject: Re: RV10-List: Re: Hartzell prop and IO540D4A5 > > ________________________________________________________________________________
Date: Jun 19, 2008
Good point, I have not heard the "are the windows structural?" point come u p as far as=C2-I can recall. Rick Sked 40185 ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Thursday, June 19, 2008 8:39:54 AM (GMT-0800) America/Los_Angeles Subject: RE: RV10-List: window adhesives revisited. Is this a discussion about the use of the windshield as a structural compon ent?=C2- I've not paid much attention to the windshield debate, but if st ructural, then Weldon, I would think.=C2- John Jessen =C2-=C2- 40328 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Rick Sked Sent: Wednesday, June 18, 2008 3:40 PM Subject: Re: RV10-List: window adhesives revisited. Since I'm going the Silpruf method and it is also a=C2-silicone based pro duct I have to consider those ratio's also but,=C2- I have the video from the Glasair folk on how to install using the Silpruf adhesive and there is a gap left around the window to be filled after paint with Silpruf...this should eliminate the contraction space=C2-problem.=C2- Given the differ ent expansion and contraction rates for the plexi vs. fiberglass, it seems that no matter what you did the only time the glass would not be either und er negative or positive compression would be at the exact temperature that occurred during installation. This would explain the cracks around the wind ows installed with Weldon=C2-since the Weldon creates an ungiving, solid bond between both materials. If you allow for expansion and the material us ed in the expansion/contraction joint is flexible I think this would presen t a better option than the Weldon. Filling the areas around the windows=C2 -with flox/epoxy and covering with glass cloth gives brute strength to th e gap hopefully preventing the cracks. I talked to two Glasair builders wit h 10 plus years on their aircraft with glass installed with Silpruf or simi lar silicone=C2-and they had no problems...This is kinda getting like pri mer wars in a way. If you get a chance to look at a Cirrus up close you wil l see their windows are installed with a defined gap around the plexi to ca bin flange, the gap is filled with a material either like proseal or silico ne...maybe anyone with experience on the Cirrus windows may be able to shed more light on that install. Till then...I'm sticking (literally) to Silpru f install. Rick Sked 40185 ----- Original Message ----- From: "John Ackerman" <johnag5b(at)cableone.net> Sent: Wednesday, June 18, 2008 10:13:09 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: window adhesives revisited. On =C2-Jun 17, 2008, at 9:52 AM, John Gonzalez wrote: .... If I hadn't al ready painted the interior of my canopy I would have added fiberglass to th e inside of the window flange to thicken it so that I could deepen the flan ge to allow a greqater bond thickness Also,=C2-at initial trimming I woul d have als left the flange one inch wide not 3/4" wide... We went through this and decided not to post 2 months ago, but maybe the fo llowing will be of value to somebody. When we considered Sikaflex, I did the differential thermal expansion (actu ally contraction is critical) calculations in the attached spread sheet, wh ich assumes free movement of the plexi relative to the fiberglass. The resu lts are appended as text below in case the attachment can't be posted. href ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/ Navigator?RV10-List href="http://forums.matronics.com">http://forums.matr onics.com href="http://www.matronics.com/contribution">http://www.matroni ============= ==== ======================= == ________________________________________________________________________________
Subject: HS doublwers and j channels
Date: Jun 19, 2008
Well I am almost finished with my inventory down to the small parts bags. I noticed the doublers and j-channel parts are all curved. I would think they would ne straight. They are used to be doublers for the HS front and rear spars and other spars. Has any one seen this in there kits besides me. All other parts look perfect and all in tact. Box arrived via Fedex Ground. Thanks John 40864 inventory mode hope to start building this weekend ________________________________________________________________________________
Date: Jun 19, 2008
Subject: Re: HS doublwers and j channels
The forming process tends to curve the parts, once you start to match drill them and cleco them they end up being straight...unless they are REALLY cu rved bad. I recall the spar doublers being this way for sure, I just used h and pressure to bring them back to flat. Rick Sked 40185 ----- Original Message ----- From: "John Cumins" <jcumins(at)jcis.net> Sent: Thursday, June 19, 2008 9:42:16 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: HS doublwers and j channels Well I am almost finished with my inventory down to the small parts bags. =C2- I noticed the doublers and j-channel parts are all curved.=C2- I w ould think they would ne straight. They are used to be doublers for the HS front and rear spars and other spars.=C2- Has any one seen this in there kits besides me. All other parts look perfect and all in tact.=C2- Box arrived via Fedex G round. Thanks John 40864 inventory mode hope to start building this weekend ==== ======================= == ________________________________________________________________________________
From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
Date: Jun 19, 2008
This is normal. Some bending of the thick punched parts is unavoidable due to the forces need to cut the thicker stock. Just bend it back over the edge of a bench prior to match drilling. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188619#188619 ________________________________________________________________________________
Date: Jun 19, 2008
Rick and all, I asked Van personally at a gathering of like minded plane nuts a while ago if the windows provided any structural strength. He said "oh a little, not much but a little". I then said "So did you engineers say - We should add a window there for strength". He sorta chuckled and said they did provide some strength but not much. One thing he did say was the windows were installed when they did the drop test but he couldn't remember if they blew out or cracked. I always wondered if anyone has dropped one on its back (hopefully in test). I assumed the results were good but I didn't ask. -Ben #40579 PDX _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Thursday, June 19, 2008 9:15 AM Subject: Re: RV10-List: window adhesives revisited. Good point, I have not heard the "are the windows structural?" point come up as far as I can recall. Rick Sked 40185 ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Thursday, June 19, 2008 8:39:54 AM (GMT-0800) America/Los_Angeles Subject: RE: RV10-List: window adhesives revisited. Is this a discussion about the use of the windshield as a structural component? I've not paid much attention to the windshield debate, but if structural, then Weldon, I would think. John Jessen 40328 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Wednesday, June 18, 2008 3:40 PM Subject: Re: RV10-List: window adhesives revisited. Since I'm going the Silpruf method and it is also a silicone based product I have to consider those ratio's also but, I have the video from the Glasair folk on how to install using the Silpruf adhesive and there is a gap left around the window to be filled after paint with Silpruf...this should eliminate the contraction space problem. Given the different expansion and contraction rates for the plexi vs. fiberglass, it seems that no matter what you did the only time the glass would not be either under negative or positive compression would be at the exact temperature that occurred during installation. This would explain the cracks around the windows installed with Weldon since the Weldon creates an ungiving, solid bond between both materials. If you allow for expansion and the material used in the expansion/contraction joint is flexible I think this would present a better option than the Weldon. Filling the areas around the windows with flox/epoxy and covering with glass cloth gives brute strength to the gap hopefully preventing the cracks. I talked to two Glasair builders with 10 plus years on their aircraft with glass installed with Silpruf or similar silicone and they had no problems...This is kinda getting like primer wars in a way. If you get a chance to look at a Cirrus up close you will see their windows are installed with a defined gap around the plexi to cabin flange, the gap is filled with a material either like proseal or silicone...maybe anyone with experience on the Cirrus windows may be able to shed more light on that install. Till then...I'm sticking (literally) to Silpruf install. Rick Sked 40185 ----- Original Message ----- From: "John Ackerman" <johnag5b(at)cableone.net> Sent: Wednesday, June 18, 2008 10:13:09 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: window adhesives revisited. On Jun 17, 2008, at 9:52 AM, John Gonzalez wrote: .... If I hadn't already painted the interior of my canopy I would have added fiberglass to the inside of the window flange to thicken it so that I could deepen the flange to allow a greqater bond thickness Also, at initial trimming I would have als left the flange one inch wide not 3/4" wide... We went through this and decided not to post 2 months ago, but maybe the following will be of value to somebody. When we considered Sikaflex, I did the differential thermal expansion (actually contraction is critical) calculations in the attached spread sheet, which assumes free movement of the plexi relative to the fiberglass. The results are appended as text below in case the attachment can't be posted. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 19, 2008
you'll be doing a lot of this.. look at the plans under the HS (or respective section) and see what they look like when you install them. Match the part number to the respective section. The only curving I recall is one that required me to do it. Congrats on the new kit! Pascal From: John Cumins Sent: Thursday, June 19, 2008 9:42 AM Subject: RV10-List: HS doublwers and j channels Well I am almost finished with my inventory down to the small parts bags. I noticed the doublers and j-channel parts are all curved. I would think they would ne straight. They are used to be doublers for the HS front and rear spars and other spars. Has any one seen this in there kits besides me. All other parts look perfect and all in tact. Box arrived via Fedex Ground. Thanks John 40864 inventory mode hope to start building this weekend ________________________________________________________________________________
Date: Jun 19, 2008
Normal. Check several of the web sites (jessen-rv10.com is one) to see how to get them straight. In short, for the thick HS doubler, put in a padded vise at several different positions and using hand forces, just push in opposite direction of the curve, working your way along the length of the doubler a little at a time until straight. No need to whack it with anything resembling a club. Not sure about the J-curves. I think those come back into alignment through cleco and riveting. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Thursday, June 19, 2008 9:42 AM Subject: RV10-List: HS doublwers and j channels Well I am almost finished with my inventory down to the small parts bags. I noticed the doublers and j-channel parts are all curved. I would think they would ne straight. They are used to be doublers for the HS front and rear spars and other spars. Has any one seen this in there kits besides me. All other parts look perfect and all in tact. Box arrived via Fedex Ground. Thanks John 40864 inventory mode hope to start building this weekend ________________________________________________________________________________
Date: Jun 19, 2008
Thanks so much everyone. This saved me a phone call and looking stupid. I greatly appreciate all the great info and the sharing of ideas and concepts on this list. John 40864 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Thursday, June 19, 2008 10:12 AM Subject: RE: RV10-List: HS doublwers and j channels Normal. Check several of the web sites (jessen-rv10.com is one) to see how to get them straight. In short, for the thick HS doubler, put in a padded vise at several different positions and using hand forces, just push in opposite direction of the curve, working your way along the length of the doubler a little at a time until straight. No need to whack it with anything resembling a club. Not sure about the J-curves. I think those come back into alignment through cleco and riveting. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Thursday, June 19, 2008 9:42 AM Subject: RV10-List: HS doublwers and j channels Well I am almost finished with my inventory down to the small parts bags. I noticed the doublers and j-channel parts are all curved. I would think they would ne straight. They are used to be doublers for the HS front and rear spars and other spars. Has any one seen this in there kits besides me. All other parts look perfect and all in tact. Box arrived via Fedex Ground. Thanks John 40864 inventory mode hope to start building this weekend href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Re: OSH camping status .... lots of space available
Date: Jun 19, 2008
dlm46007(at)cox.net wrote: > You may be right about the attendance. There seems to be a lot of emphasis > on early purchase of tickets. > > -- That must be why they extended the discount period [Laughing] -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188655#188655 ________________________________________________________________________________
Date: Jun 19, 2008
Subject: Re: HS doublers and j channels
I'm at the same point you are, with same observations. Progress is slow when hangar reaches 110 by 10 am. Kelly 40866 John Cumins wrote: > > Thanks so much everyone. This saved me a phone call and looking stupid. > > > > I greatly appreciate all the great info and the sharing of ideas and > concepts on this list. > > > > > > > > John > > > > 40864 > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *John Jessen > *Sent:* Thursday, June 19, 2008 10:12 AM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: HS doublwers and j channels > > > > Normal. Check several of the web sites (jessen-rv10.com is one) to > see how to get them straight. In short, for the thick HS doubler, put > in a padded vise at several different positions and using hand forces, > just push in opposite direction of the curve, working your way along > the length of the doubler a little at a time until straight. No need > to whack it with anything resembling a club. Not sure about the > J-curves. I think those come back into alignment through cleco and > riveting. > > > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *John > Cumins > *Sent:* Thursday, June 19, 2008 9:42 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: HS doublwers and j channels > > Well I am almost finished with my inventory down to the small > parts bags. I noticed the doublers and j-channel parts are all > curved. I would think they would ne straight. They are used to be > doublers for the HS front and rear spars and other spars. Has any > one seen this in there kits besides me. > > > > All other parts look perfect and all in tact. Box arrived via > Fedex Ground. > > > > Thanks > > > > John > > > > 40864 inventory mode hope to start building this weekend > > > > * * > > * * > > *href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List* > > *href="http://forums.matronics.com">http://forums.matronics.com* > > *href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution* > * * > * > > > * ________________________________________________________________________________
Date: Jun 19, 2008
Subject: Re: SB 08-6-1 Inspection
dmaib(at)mac.com wrote: > > Finished opening everything up this evening. Not flying yet, so, of course, no issues with the bulkhead. > We did manage to easily remove the trim without getting into the tailcone. Did it all from the outside. Should get the doublers installed tomorrow and plan to have it all back together by Saturday. Drilling out 52 (?) rivets was the worst part, so far. I elongated a couple of holes a bit, so might have to install oversize rivets. > Not an answer for a purist, but depending on how bad it's off, a regular rivet will do just fine. Unless, of course you have a lot of oversize rivets on hand ...... ;-) > Would there be any problem installing a bolt or screw and lock nut in an oversize hole? > No problem .....just added weight. Linn > -------- > David Maib > RV-10 #40559 ________________________________________________________________________________
Date: Jun 19, 2008
Subject: Re: Hartzell prop and IO540D4A5
I have been flying the two blade composite for around 6 weeks on my RV-4. Everyone that has flown in the RV-4 comments on how smooth the new prop is. The 12 pound weight reduction on the nose also made the plane fly noticeably better. It is hard to tell if there is any difference in speed. Rob Hickman **************Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Subject: HS doublers and j channels
Date: Jun 19, 2008
Kelly Yes it is, been hot here to but cooling off in the evenings. We are down to inv. the many bags of small parts and needs to build shelf above garage door foe all the flat skins. Have fn and try and stay cool. John G. Cumins _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 19, 2008 12:50 PM Subject: Re: RV10-List: HS doublers and j channels I'm at the same point you are, with same observations. Progress is slow when hangar reaches 110 by 10 am. Kelly 40866 John Cumins wrote: Thanks so much everyone. This saved me a phone call and looking stupid. I greatly appreciate all the great info and the sharing of ideas and concepts on this list. John 40864 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Thursday, June 19, 2008 10:12 AM Subject: RE: RV10-List: HS doublwers and j channels Normal. Check several of the web sites (jessen-rv10.com is one) to see how to get them straight. In short, for the thick HS doubler, put in a padded vise at several different positions and using hand forces, just push in opposite direction of the curve, working your way along the length of the doubler a little at a time until straight. No need to whack it with anything resembling a club. Not sure about the J-curves. I think those come back into alignment through cleco and riveting. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Thursday, June 19, 2008 9:42 AM Subject: RV10-List: HS doublwers and j channels Well I am almost finished with my inventory down to the small parts bags. I noticed the doublers and j-channel parts are all curved. I would think they would ne straight. They are used to be doublers for the HS front and rear spars and other spars. Has any one seen this in there kits besides me. All other parts look perfect and all in tact. Box arrived via Fedex Ground. Thanks John 40864 inventory mode hope to start building this weekend href= "http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navi gator?RV10-List href= "http://forums.matronics.com">http://forums.matronics.com href= "http://www.matronics.com/contribution">http://www.matronics.com/c <http://www.matronics.com/contribution> http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Date: Jun 19, 2008
I am sure I will show my vast knowledge of aluminum fatigue (or lack there of), but it seems if you cover with a plate, you would never see a future crack that may develop underneath. I understand the plate is to strengthen the part to keep it from cracking. Is there a chance of a crack forming with the plate riveted on? Thanks, Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188685#188685 ________________________________________________________________________________
Date: Jun 19, 2008
ricksked(at)embarqmail.co wrote: > Not too bad of a discount, $2 a day times 5 days = enough to get that first bottle of water for free!! > > Rick Sked > --- I didn't spend a whole lot of time reading it but if I read it correctly, EAA is not offering the discount. It is Jeppesen that is paying for the discount. If that is in fact true, I will have to go by and thank them. They already get some of my money and as soon as I get the -10 in the air, they will be getting a bunch more. :? -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188706#188706 ________________________________________________________________________________
Date: Jun 19, 2008
A proper inspection views both sides. In this case the opposite of the doubler will reveal any migration down the road. I am always amazed to see builder's with cracks that do not document their length during a Conditional. At the next Conditional they go 'Yup, still there'. Then we measure it to create a baseline and find it has been slowly migrating over the life of the airframe. Stress relief and tortional transfer into the doubler are important parts of the correction. No one is commenting on the appearance that the CNC relief groove for the flanges (two of them) seem to be larger than offered on the virgin parts. This could have been a manufacturing crack which was treated by the builder (the factory) with deburring and grinding prior to original assemblage. A crack is a crack is a crack. It is not going away. It is coming back to play another day. "Metal has memory". Anyone want to play on a review of the pictures? John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of 2eyedocs Sent: Thursday, June 19, 2008 4:05 PM Subject: RV10-List: Re: SB 08-6-1 Inspection I am sure I will show my vast knowledge of aluminum fatigue (or lack there of), but it seems if you cover with a plate, you would never see a future crack that may develop underneath. I understand the plate is to strengthen the part to keep it from cracking. Is there a chance of a crack forming with the plate riveted on? Thanks, Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188685#188685 ________________________________________________________________________________
Subject: HIDs
Date: Jun 19, 2008
before and after pictures of my 10 are on http://www.planelights.com/index.php?id=661 ________________________________________________________________________________
Date: Jun 20, 2008
You talking about the "Big Taste Grill" truck from Johnsonville Brats? msausen wrote: > Ya, but it's the massive $5 discount on the weekly ticket that gets you a brat. HA > > -- -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=188758#188758 ________________________________________________________________________________
From: "James, Peter [SD]" <Peter.James(at)sprint.com>
Date: Jun 20, 2008
David, Stop it already! Every time I think I am done buying 'goodies' for my plan e, somebody comes up with one of those have to have it items that cost me m ore money! So tell us, what is the heat output of the HID vs. the stock Halogen's? I am concerned about the heat warping the fiberglass wingtip....and I am sure others are concerned and would like to know also. Pete (not sure where I'm at anymore - too many little things left to do!) ________________________________________________________________________________
Subject: HIDs
Date: Jun 20, 2008
That's very impressive. I almost wish I hadn't cut my leading edges for the Duckworks lights! cj -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Thursday, June 19, 2008 10:22 PM Subject: RV10-List: HIDs before and after pictures of my 10 are on http://www.planelights.com/index.php?id=661 ________________________________________________________________________________
Subject: Re: HID replacement lights
Date: Jun 20, 2008
Check out their site for some other questions. I had the same thought and recall they had a Q& A Q:Do they get hot A: Yes, but the heat is directly equivalent to the power being applied. If your original application was designed for a 55w halogen, then going to a 35w or a 50w HID should not generate a significant amount more heat than the original halogen. From: James, Peter [SD] Sent: Friday, June 20, 2008 8:52 AM Subject: re: RV10-List: HID replacement lights David, Stop it already! Every time I think I am done buying 'goodies' for my plane, somebody comes up with one of those have to have it items that cost me more money! So tell us, what is the heat output of the HID vs. the stock Halogen's? I am concerned about the heat warping the fiberglass wingtip..and I am sure others are concerned and would like to know also. Pete (not sure where I'm at anymore - too many little things left to do!) ________________________________________________________________________________
Date: Jun 20, 2008
forgot the link.. has the wig-wag answer as well http://www.planelights.com/index.php?id=684 From: James, Peter [SD] Sent: Friday, June 20, 2008 8:52 AM Subject: re: RV10-List: HID replacement lights David, Stop it already! Every time I think I am done buying 'goodies' for my plane, somebody comes up with one of those have to have it items that cost me more money! So tell us, what is the heat output of the HID vs. the stock Halogen's? I am concerned about the heat warping the fiberglass wingtip..and I am sure others are concerned and would like to know also. Pete (not sure where I'm at anymore - too many little things left to do!) ________________________________________________________________________________
Subject: billet door guide fasteners
Date: Jun 20, 2008
hi all, another lister who bought some of my door guides brought up a good point. he was concerned about the attach screws that I use and their strength, and more importantly the quality ( consistency ). I buy most hardware from mcmaster carr , and after a little searching found a stainless fastener of the same size but mil spec and rated at 80k tensile strength. I'm switching to this screw and am inviting all who bought door guides to drop me an email with your address and I'll send out the new hardware. sorry I don't keep personal info after the sale... Steven DiNieri iflyrv10.com ________________________________________________________________________________
Date: Jun 20, 2008
the replacement HID seems to have less radiated heat to the fiberglass tip. When testing the lights I placed my hand about 1.5" ahead of the tip of the light (lens off) and it became hot; but , for unknown reasons the HID did not heat the strobe glass directly in front of it. going flying tonight so will have more info later. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James, Peter [SD] Sent: Friday, June 20, 2008 8:53 AM Subject: re: RV10-List: HID replacement lights David, Stop it already! Every time I think I am done buying 'goodies' for my plane, somebody comes up with one of those have to have it items that cost me more money! So tell us, what is the heat output of the HID vs. the stock Halogen's? I am concerned about the heat warping the fiberglass wingtip..and I am sure others are concerned and would like to know also. Pete (not sure where I'm at anymore - too many little things left to do!) ________________________________________________________________________________
Date: Jun 20, 2008
Subject: Re: HIDs
Depending on what Duckworks option you have, they may have a solutions already, Their website say's they have a replacement for the 4" lights. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chris Johnston wrote: > > Thats very impressive. I almost wish I hadnt cut my leading edges > for the Duckworks lights! > > cj > > * > > * ________________________________________________________________________________
Subject: HID install
Date: Jun 20, 2008
The total install took three hours from wingtip removal to wingtip installation. the ballast was installed as shown on http://www.planelights.com/index.php?id=685 . The ballast is threaded for 8-32 screws and I used an NAS variety available from Spruce with both Phillips internal and external hex head. I installed the screws from inside the tip rib with a small ratchet available from HF. I used a washer under the head of the screw and on the outside of the rib to provide an offset of the ballast from the tip itself. As the site indicates there is an audible whine for less than 10 seconds while it warms. No RFI was observed but will check again tonight when flying. ________________________________________________________________________________
Date: Jun 20, 2008
Subject: Re: billet door guide fasteners
Hi Steve, Please send the new screws to me at: David Maib 1314 Marquette Ave., #2805 Minneapolis, MN 55403 Thanks! David On Friday, June 20, 2008, at 12:31PM, steve dinieri wrote: > ><> ________________________________________________________________________________
Subject: Hartzell Prop
Date: Jun 21, 2008
Guys, a few have been asking the question about composite props so I thought I'd pass this reply from Hartzell on to the list. John 40315 (final not so fun bits) ------------------------------ "John, Sam Gascho forwarded me your e-mail. I am the account rep for Hartzell Propeller that handles Vans. We should have a composite 3-blade prop on an RV-10 in the next month. The same builder is also testing a 2-blade prop on his RV-4. I am waiting on data from that test. The one comment that he did share was how much smoother the 2-blade composite prop is compared to his 2-blade metal. Are you getting a lot of requests from builders in Australia for a Hartzell composite prop? Vans has not decided if they want to offer our composite prop. I've asked RV builders that call me for a composite prop to e-mail or call Vans asking it the plan to offer the Hartzell composite prop. I should have some test data on the RV-4 soon, and RV-10 data in the next month. Please feel free to check back with me. Regards, Kevin Karam Account Representative Hartzell Propeller, Inc. (P) +1-937-778-5731 (F) +1-937-778-4321 kkaram(at)hartzellprop.com ________________________________________________________________________________
Subject: Re: Hartzell Prop
Date: Jun 20, 2008
Just another reason for builders to call and send e-mails to Van's to offer the prop for RV-10's. If there is enough demand (price being the factor) Van's may very well offer it.. Not sure why the hesitation, it's not like they have a MT on one of there planes and hence only sell what they have tested. From: John Dunne Sent: Friday, June 20, 2008 2:18 PM Subject: RV10-List: Hartzell Prop Guys, a few have been asking the question about composite props so I thought I'd pass this reply from Hartzell on to the list. John 40315 (final not so fun bits) ------------------------------ "John, Sam Gascho forwarded me your e-mail. I am the account rep for Hartzell Propeller that handles Vans. We should have a composite 3-blade prop on an RV-10 in the next month. The same builder is also testing a 2-blade prop on his RV-4. I am waiting on data from that test. The one comment that he did share was how much smoother the 2-blade composite prop is compared to his 2-blade metal. Are you getting a lot of requests from builders in Australia for a Hartzell composite prop? Vans has not decided if they want to offer our composite prop. I've asked RV builders that call me for a composite prop to e-mail or call Vans asking it the plan to offer the Hartzell composite prop. I should have some test data on the RV-4 soon, and RV-10 data in the next month. Please feel free to check back with me. Regards, Kevin Karam Account Representative Hartzell Propeller, Inc. (P) +1-937-778-5731 (F) +1-937-778-4321 kkaram(at)hartzellprop.com ________________________________________________________________________________
Date: Jun 20, 2008
Subject: Re: HID install
Thanks, Dave. Great pictures to boot. I'm half way through the SB, what a pain in the royal butt this is...... In a message dated 6/20/2008 1:21:04 P.M. Central Daylight Time, dlm46007(at)cox.net writes: The total install took three hours from wingtip removal to wingtip installation. the ballast was installed as shown on _http://www.planelights.com/index.php?id=685_ (http://www.planelights.com/index.php?id=685) . The ballast is threaded for 8-32 screws and I used an NAS variety available from Spruce with both Phillips internal and external hex head. I installed the screws from inside the tip rib with a small ratchet available from HF. I used a washer under the head of the screw and on the outside of the rib to provide an offset of the ballast from the tip itself. As the site indicates there is an audible whine for less than 10 seconds while it warms. No RFI was observed but will check again tonight when flying. (http://www.matronics.com/Navigator?RV10-List) (http://www.matronics.com/contribution) **************Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Subject: alternator belt
Date: Jun 20, 2008
What is the alternator belt for the IO540; seems like there was a Gates number? ________________________________________________________________________________
Date: Jun 20, 2008
Subject: Re: alternator belt
David, the belt that came w/ my B&C alternator is marked : 7365 GATES XL 110925 Deems David McNeill wrote: > What is the alternator belt for the IO540; seems like there was a > Gates number? ________________________________________________________________________________
Subject: Carpets from IFLYRV10
Date: Jun 21, 2008
Has anyone used the carpets from IFLYRV10; if so what do you think of them? Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Date: Jun 21, 2008
728DD-No cracks found at 220 hours,will install the doublers at next annual. ************** Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Date: Jun 21, 2008
Subject: Grt efis
Has anyone done much hood time or actual IMC flying with the GRT units.I am a high time CFII and would like to discuss it offline.Pilotdds(at)aol.com-thanks.728DD-220hrs ************** Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Date: Jun 21, 2008
104BK-No cracks found at 2005 hours. Oops, that's build time. Bob K From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of PILOTDDS(at)aol.com Sent: Saturday, June 21, 2008 10:18 AM Subject: Re: RV10-List: Re: SB 08-6-1 Inspection 728DD-No cracks found at 220 hours,will install the doublers at next annual. ************** Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Subject: engines
Date: Jun 21, 2008
I was wondering has anyone considered using an LS1 with PSRU? I am a looking at this as a possible engine source but would like some feedback. I am a first time builder and any info would be appreciated. Thanks. ________________________________________________________________________________
Subject: engines
Date: Jun 21, 2008
Do you mean like? http://www.vestav8.com/ or http://www.geareddrives.com/ There a couple about ready to fly, but I'm not aware of any flying as of yet. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of sean garrison Sent: Saturday, June 21, 2008 2:22 PM Subject: RV10-List: engines I was wondering has anyone considered using an LS1 with PSRU? I am a looking at this as a possible engine source but would like some feedback. I am a first time builder and any info would be appreciated. Thanks. ________________________________________________________________________________
Subject: engines
Date: Jun 21, 2008
The geareddrive is what caught my eye at Sun&Fun. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Saturday, June 21, 2008 3:14 PM Subject: RE: RV10-List: engines Do you mean like? http://www.vestav8.com/ or http://www.geareddrives.com/ There a couple about ready to fly, but I'm not aware of any flying as of yet. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of sean garrison Sent: Saturday, June 21, 2008 2:22 PM Subject: RV10-List: engines I was wondering has anyone considered using an LS1 with PSRU? I am a looking at this as a possible engine source but would like some feedback. I am a first time builder and any info would be appreciated. Thanks. ________________________________________________________________________________
Subject: HIDs
Date: Jun 21, 2008
Deems, You are correct, we recently added 35w and 50w 'Low Cost' replacement HID lights (see our 'Upgrades' page). We have the MR-16 2" HID lights for the Tips in both wattages. We also have GE-H3 style HID lights that are simple, direct replacements for the Halogen bulbs in our lights. These lights work very well, in fact Joe Blank just installed a couple in his old RMD style wing tips using my PAR-36 Reflectors with the Low Cost 35W HID. He reported back that he has now lifted his self-imposed 'ban' on night landings at his home strip, since the 4" HID lights work so well. Remember, if you want a 'long' beam that will light up the runway when you turn final, a 4" light will outperform a 2" light, it's simple math. But if you do have the MR-16 tip lights, the HID is far 'brighter', cooler, uses less power, and doesn't burn out, making the HID version a great upgrade. OH, and we have finally joined the modern world - we just enabled Credit Card processing on our website, on the 'Upgrades' page initially. Don 'The Duck' Wentz Duckworks Aviation .com RV-6 N790DW (flying since 1994) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, June 20, 2008 10:56 AM Subject: Re: RV10-List: HIDs Depending on what Duckworks option you have, they may have a solutions already, Their website say's they have a replacement for the 4" lights. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Chris Johnston wrote: > > That's very impressive. I almost wish I hadn't cut my leading edges > for the Duckworks lights! > > cj > > * > > * ________________________________________________________________________________
Date: Jun 21, 2008
From: "sam(at)fr8dog.net" <sam.marlow(at)adelphia.net>
Subject: Re: Grt efis
I've done some IMC flying with the GRT's. Give me a call on Skype,I'm sam.marlow. ---- PILOTDDS(at)aol.com wrote: ============ Has anyone done much hood time or actual IMC flying with the GRT units.I am a high time CFII and would like to discuss it offline.Pilotdds(at)aol.com-thanks.728DD-220hrs ************** Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. (http://autos.aol.com/used?ncid=aolaut00050000000007) ________________________________________________________________________________
Date: Jun 21, 2008
Subject: Re: SB work
Hey John, glad you got the SB going! I just finished the SB today myself. Had me and 2 ladies to do the work...they did most of it. We got the HS completely off and ready to drill rivets in maybe 2-2.5 hours. Had the doublers in place after lunch, the reassembly went fairly well. I'll do a write-up on it. My reassembly was perhaps longer than some peoples would be, due to some wiring related things that I did in addition. Total time was about 9.25 hours to complete the SB, and another .25 to test fly it. This one will definitely have a write-up, although I didn't take much for photos since there is already a great online photo display of it. http://picasaweb.google.com/rv8erpics/RV10SB0861?authkey=HdMqmAzGxsc I agree, as far as the holes in the HS go, except I removed my HS and Elevators/trim tabs as a unit, so I only had to pull the cables from the trim mechanism. I did all of my rivets with a rivet gun, and it went real quick and easy. I found no cracks in the bulkhead, by the way, at 349 hours. And I've flown it hard enough shaking that tail with that stall series I did video and photos of that I figure if I don't have cracks, not many will. More on that later though. The job goes fastest with at least 2 people. Having 3 there was nice in that I was always able to work nonstop as they helped with the peripheral tasks so I could plug away. Glad to be done! Tim Olson - RV-10 N104CD - Flying GenGrumpy(at)aol.com wrote: > ** > > For what it's worth for you who have not begun the wonderful task of > doing the SB on the rear bulkhead, here's some data for you. > > Started yesterday afternoon, worked all day today. 10.5 hrs so far with > about 2 hrs to go to finish. > > This is with 2 people working dedicated full time, and assisted by 2 > others when it came time to pull the horizontals off with those blasted > trim cables. > > For those still building the horizontals, make the holes for the cables > bigger than the plans say in case you ever have to take the tail off...... > > Riveting the doublers in and re-doing the top plate.......we used hand > squeezers as well as 2 different jaw'd pneumatic squeezers plus rivet > gun and bucking bar to get to all of the required rivets. > > Not a fun job at all. > > No cracks in my bulkhead at 70 hrs prior to installing the doublers. > > Not a fun or easy job. Find some extra hands to help - you'll need them. > > grumpy > N`84JM > ________________________________________________________________________________
Date: Jun 22, 2008
No cracks at 40 hours, installed parts at paint shop just before paint. Whew! Dick Sipp N110DV 40065 ________________________________________________________________________________
From: "Chris and Susie McGough" <VHMUM(at)bigpond.com>
Subject: Dynon RPM
Date: Jun 22, 2008
Anyone got a Dynon thats flying. Having trouble getting the Tacho to read correct . It under reads by 200rpm. We have tried several resistors Chris ________________________________________________________________________________
Date: Jun 22, 2008
I have done some IFR also. email me offline. Rob. On Sat, Jun 21, 2008 at 1:24 PM, wrote: > Has anyone done much hood time or actual IMC flying with the GRT units.I am > a high time CFII and would like to discuss it > offline.Pilotdds(at)aol.com-thanks.728DD-220hrs > > > ************** > Gas prices getting you down? Search AOL Autos for fuel-efficient used cars. > (http://autos.aol.com/used?ncid=aolaut00050000000007) > > -- Rob Kermanj ________________________________________________________________________________
Date: Jun 22, 2008
Subject: Re: Dynon RPM
Chris, make sure you have the Pulses per Rev setting in the Dynon set correctly. Mine is set to 1.5 and that is with dual Slick Mags. If will be different if you have light speed etc. It would also be helpful to have a optical sensor tach like the ones used for Remote Control Airplanes. They work well at around $15 for these tests. Ray ---- Chris and Susie McGough wrote: > > Anyone got a Dynon thats flying. Having trouble getting the Tacho to read > correct . It under reads by 200rpm. We have tried several resistors > > Chris > > > > ________________________________________________________________________________
Date: Jun 22, 2008
I have gotten several Dynon's flying. Never had a problem with that. The only place I have seen an issue is when at high RPM's with a resistor that isn't big enough to dampen the spikes, as long as the "pulses per revolution" is set to 1.5, I think it is. I have never had a problem with bad readings at low RPM's. Where exactly are you seeing the issue? Are you seeing it on both mags or just on one specifically? Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jun 22, 2008, at 4:53 AM, Chris and Susie McGough wrote: > > > > Anyone got a Dynon thats flying. Having trouble getting the Tacho to > read correct . It under reads by 200rpm. We have tried several > resistors > > Chris > > ________________________________________________________________________________
Date: Jun 22, 2008
Jesse I have the 2 sensor wires going to the switch with a resistor on each. Dynon is set to1.5. I have not tried individual mags as do not know how. Chris ----- Original Message ----- From: "Jesse Saint" <jesse(at)saintaviation.com> Sent: Sunday, June 22, 2008 10:38 PM Subject: Re: RV10-List: Dynon RPM > > I have gotten several Dynon's flying. Never had a problem with that. > The only place I have seen an issue is when at high RPM's with a resistor > that isn't big enough to dampen the spikes, as long as the "pulses per > revolution" is set to 1.5, I think it is. I have never had a problem > with bad readings at low RPM's. Where exactly are you seeing the issue? > Are you seeing it on both mags or just on one specifically? > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > On Jun 22, 2008, at 4:53 AM, Chris and Susie McGough wrote: > >> > > >> >> Anyone got a Dynon thats flying. Having trouble getting the Tacho to >> read correct . It under reads by 200rpm. We have tried several resistors >> >> Chris >> >> >> >> > > > ________________________________________________________________________________
Date: Jun 22, 2008
Run it with the switch on left and then on right and see how it compares to an optical tach. You do have dual slicks? Make sure your optical tach is correct also. I haven't seen one with problems, but it is definitely possible. Also, are you reading 200rpm off at a certain reading, or at all rpm's? If the 200 is constant, then I can't imagine what else could be the difference since a wrong setting in the Dynon should give you a difference relative to rpm. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jun 22, 2008, at 8:53 AM, Chris and Susie McGough wrote: > > > > Jesse I have the 2 sensor wires going to the switch with a resistor > on each. Dynon is set to1.5. I have not tried individual mags as do > not know how. > > Chris > > > ----- Original Message ----- From: "Jesse Saint" <jesse(at)saintaviation.com > > > To: > Sent: Sunday, June 22, 2008 10:38 PM > Subject: Re: RV10-List: Dynon RPM > > >> >> >> I have gotten several Dynon's flying. Never had a problem with >> that. The only place I have seen an issue is when at high RPM's >> with a resistor that isn't big enough to dampen the spikes, as >> long as the "pulses per revolution" is set to 1.5, I think it is. >> I have never had a problem with bad readings at low RPM's. Where >> exactly are you seeing the issue? Are you seeing it on both mags >> or just on one specifically? >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> Cell: 352-427-0285 >> Fax: 815-377-3694 >> >> On Jun 22, 2008, at 4:53 AM, Chris and Susie McGough wrote: >> >>> > >>> >>> Anyone got a Dynon thats flying. Having trouble getting the Tacho >>> to read correct . It under reads by 200rpm. We have tried several >>> resistors >>> >>> Chris >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 22, 2008
Lew, I think Van's instructions are referring to getting a good fit between the lower intersection fairing and the wheel pants, and upper fairing to fuselage/wing surface. I did away with sheet metal screws or nutplates by using the method of Vic Syracuse and others. My lower intersection fairings are permanently glassed to the wheel pants, then split in line with the wheel pant split. Once the fairing to wheel pant seam is micro'd and body worked it has a very clean, sexy appearance. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189080#189080 ________________________________________________________________________________
Subject: How to fasten this exhaust nut?
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Jun 22, 2008
Hello There, it looks as if this hole was drilled too close the exhaust pipe. I can not reach it with a ratchet nut or an jaw wrench. Any idea ho tow to go about it in order to achieve the requested torque (140) Thanks Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189140#189140 Attachments: http://forums.matronics.com//files/dsc03143_371.jpg ________________________________________________________________________________
Subject: Re: How to fasten this exhaust nut?
Date: Jun 23, 2008
1/4 inch drive with extention. I had the same and with the thinner socket i was anle to do it Chris ----- Original Message ----- From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net> Sent: Monday, June 23, 2008 7:50 AM Subject: RV10-List: How to fasten this exhaust nut? > > > Hello There, > > it looks as if this hole was drilled too close the exhaust pipe. I can not > reach it with a ratchet nut or an jaw wrench. Any idea ho tow to go about > it in order to achieve the requested torque (140) > > Thanks > Michael > > -------- > RV-10 builder (engine, prop, finishing) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=189140#189140 > > > Attachments: > > http://forums.matronics.com//files/dsc03143_371.jpg > > > ________________________________________________________________________________
Subject: AF 3500 Sensor pack questions
Date: Jun 22, 2008
Guys, for those who are using the sensor pack from AFS where did you place the shunt and the manifold sensor. Pictures appreciated. Best Regards Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189146#189146 ________________________________________________________________________________
Date: Jun 22, 2008
Wow! Challenging picture: Four ideas. 1)A 1/4" drive "thinwall" deep socket on an extension. 2)A Torque Adapter(Snap-On makes them). Or 3)a sacrificial crows foot - modified with your die-grinder and 4)remove the studs and use Hex driven bolts into the head. Automotive racing headers use the Hex ones all the time for such close interference. Note: I have always found value in using S.Steel exhaust nuts as once regular nuts corrode, the removal technique down the road is 3X as challenging for non S.S. This nut and the related internal star washer appear 'standard cadmium' plated. John Cox #600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Wellenzohn Sent: Sunday, June 22, 2008 2:50 PM Subject: RV10-List: How to fasten this exhaust nut? Hello There, it looks as if this hole was drilled too close the exhaust pipe. I can not reach it with a ratchet nut or an jaw wrench. Any idea ho tow to go about it in order to achieve the requested torque (140) Thanks Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189140#189140 Attachments: http://forums.matronics.com//files/dsc03143_371.jpg ________________________________________________________________________________
Date: Jun 22, 2008
1/4" drive "wobble sockets" work great too. I've found them locally at Sears. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189151#189151 ________________________________________________________________________________
Date: Jun 22, 2008
#1 or # 2. Loosen the nut just enough to be able to move the pipe a little. Place socket on each nut to ensure the pipe is centered between the studs. Every Lycoming exhaust port is just like this. On Sun, Jun 22, 2008 at 3:22 PM, John Cox wrote: > > Wow! Challenging picture: > > Four ideas. 1)A 1/4" drive "thinwall" deep socket on an extension. 2)A > Torque Adapter(Snap-On makes them). Or 3)a sacrificial crows foot - > modified with your die-grinder and 4)remove the studs and use Hex driven > bolts into the head. Automotive racing headers use the Hex ones all the > time for such close interference. > > Note: I have always found value in using S.Steel exhaust nuts as once > regular nuts corrode, the removal technique down the road is 3X as > challenging for non S.S. This nut and the related internal star washer > appear 'standard cadmium' plated. > > John Cox > #600 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael > Wellenzohn > Sent: Sunday, June 22, 2008 2:50 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: How to fasten this exhaust nut? > > > > Hello There, > > it looks as if this hole was drilled too close the exhaust pipe. I can > not reach it with a ratchet nut or an jaw wrench. Any idea ho tow to go > about it in order to achieve the requested torque (140) > > Thanks > Michael > > -------- > RV-10 builder (engine, prop, finishing) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=189140#189140 > > > Attachments: > > http://forums.matronics.com//files/dsc03143_371.jpg > > ________________________________________________________________________________
Date: Jun 22, 2008
Forgot to mention...my Mooney calls for an AN-310-3 nut there. Key is to replace those nuts every few hundred hours, as soon as they show any signs of corrosion. On Sun, Jun 22, 2008 at 5:11 PM, Kelly McMullen wrote: > #1 or # 2. Loosen the nut just enough to be able to move the pipe a > little. Place socket on each nut to ensure the pipe is centered > between the studs. > Every Lycoming exhaust port is just like this. > > On Sun, Jun 22, 2008 at 3:22 PM, John Cox wrote: >> >> Wow! Challenging picture: >> >> Four ideas. 1)A 1/4" drive "thinwall" deep socket on an extension. 2)A >> Torque Adapter(Snap-On makes them). Or 3)a sacrificial crows foot - >> modified with your die-grinder and 4)remove the studs and use Hex driven >> bolts into the head. Automotive racing headers use the Hex ones all the >> time for such close interference. >> >> Note: I have always found value in using S.Steel exhaust nuts as once >> regular nuts corrode, the removal technique down the road is 3X as >> challenging for non S.S. This nut and the related internal star washer >> appear 'standard cadmium' plated. >> >> John Cox >> #600 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael >> Wellenzohn >> Sent: Sunday, June 22, 2008 2:50 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: How to fasten this exhaust nut? >> >> >> >> Hello There, >> >> it looks as if this hole was drilled too close the exhaust pipe. I can >> not reach it with a ratchet nut or an jaw wrench. Any idea ho tow to go >> about it in order to achieve the requested torque (140) >> >> Thanks >> Michael >> >> -------- >> RV-10 builder (engine, prop, finishing) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=189140#189140 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/dsc03143_371.jpg >> >> >> >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Subject: Re: Control Stick interference
Date: Jun 22, 2008
This is a very old thread, but it is exactly where I am right now. I did the duty search and found that the range of motion due to the bolts is a minor issue for me, as well. With more people passing through this stage, any comments? I think the bolt interference is a non issue because of the stops on the flight surfaces, right? Or, have other people reversed the bolts? John [quote="armywrights(at)adelphia.n"]All, Ive removed the front covers that fit around the control sticks. The plans say to move the controls throughout their full range of motion to check for interference. What is the actual full range of motion? Of course I can make the ends of the bolts on the control stick bases touch the F1033L control column mounts (P 39-7 and 39-8) as well as make the control pushrod (F1065) touch the curved slot in the sides of the tunnel. I believe that once I attach the control surfaces this extra movement will go away, yet the plans say to check for interference without the surfaces installed (p39-8 Step 3). What other experiences are out there? Did anyone have to hack up the pre-formed slots or other areas once the control surfaces were installed? Rob Wright #392 QB Fuse Control Sticks temp installed looks like an airplane!! > [b] -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189190#189190 ________________________________________________________________________________
Date: Jun 23, 2008
Fortunately, I still haven't joined my tailcone or have cables in the way, but I began the doubler plate work yesterday. I found that drilling out the old #30 rivets was hard to reach as the shop heads were facing forward and the taper of the fuselage made the angle tough (Did go buy an angle drill tool for this). I clecoed the doublers on the forward side of the bulkhead and carefully drilled perpendicular to make the many new #30 holes, then mounted it on the aft side, reamed, and then deburred everything. Having more than one set of hands will be handy to get the last few rivets in.
June 05, 2008 - June 23, 2008
RV10-Archive.digest.vol-dk
