RV10-Archive.digest.vol-dr
September 06, 2008 - September 19, 2008
      >             We performed the tail plate SB this week. We have one
      > observation on a tip that may make the process easier. Forgive me if this
      > was mentioned before & I just didn't see or understand the posting at the
      > time.
      >             The last thing we wanted to do is tear into the nearly fully
      > assembled plane to perform this SB. But seeing that in my mind there was
      no
      > option we started the disassembly. Instead of crawling in the tail and
      > disconnecting the elevator trim cables, then removing the
      > stabilizer/elevator from the airplane, we simply turned the assembly upsi
      de
      > down, left the cables connected.  It took about 4 hours to get to the poi
      nt
      > where we could start installing the stiffeners. Total time start to finis
      h
      > was ~12 hours. We also found a new use for the Port-A-Cool.
      >             At this point we now have a completed plane with an SJ cowl &
      > custom airbox. We have completed the high speed taxi & brake test. Now we
      > are just waiting on insurance coverage and for the plane to paint itself
      =85
      > Robin
Date: Sep 06, 2008
Subject: Re: Shoulder harness bracket
partner14 wrote: > > Ok, the install is finished and it works and looks great. Based on the response I guess I need to run some more. Attached is a pic. > Rick Sked asked about using them as a headset holder.... I have a different bracket design already done and mounted in the plane. Will take a pic and send it out tomorrow. > Don McDonald > #40636 > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 1524#201524 > > > Attachments: > > http://forums.matronics.com//files/img_2629c_119.jpg > > > ________________________________________________________________________________
Subject: GPS Antenna Mounting
Date: Sep 06, 2008
I am to the point of needing to mount or at least drill the holes for the 430W GPS antenna. I want to put it on top of the cabin but it looks like I have 2 options. On the cabin top center line for/aft; One is just behind the aft door posts where the top is rather thin. The second location is centered between the door hinges where the top is very thick. Using the aft location, I don't think I would have any problems with screw length or attaching the coax. If I were to use the location between the door hings, I am concerned about getting the coax connected and to a lesser extent the screws and what I would have the nuts tighten up against. Where are others mounting their antenna and any thoughts? -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2951#202951 ________________________________________________________________________________
Subject: Finish Kit
Date: Sep 06, 2008
I have decided to use an engine other than the IO-540 and am ready to order the finish kit. My selected engine comes with a custom cowling and other components specific to the engine. I don't want to order a finish kit from Van's that comes with parts that I will not use. Does anyone have a shipping list for the finish kit who might also identify the parts I won't need? I would settle for just the finish kit inventory list. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2952#202952 ________________________________________________________________________________
Subject: Re: Finish Kit
Date: Sep 06, 2008
Call Van's on Monday and request they FAX you a copy of a current packing list. That way you be assured of getting an up to date list. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2953#202953 ________________________________________________________________________________
Subject: Finish Kit
Date: Sep 06, 2008
Here is the current up to date list as of 8/15/2008 direct from Van's 1.00 FF-10 IO-540 F.WALL FWD.KIT IO-540 3.00 CT A-740 BLACK PUSH PULL CABLE BLACK 2.00 DUCT CBT-5/8 COOLING BLAST TUBE 2.00 EA 4" DUCT HOSE CLAMP 4" HOSE CLAMP 1.00 EA CV HOSE 7545 BREATHER HOSE -540 6.00 EA GASKET 77611 BLO-PROOF EXHST GASKT 4.00 EA DYNA VI I(O)-540 VIB.ISO. RV-10 ONLY 1.00 EA OIL COOLER 20006A OIL COOLER I(O)-540 1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT 1.00 FAB-360/540 FLTRD A/BOX-360 FI320 1.00 FF-1005 BREATHER TUBE 1.00 IE VMP INSTALL KIT FITTINGS/HOSES 1.00 PROP GOV MT P-860-3 I(O)-540 LYCOMING 1.00 VA-102 FUEL PRES. HOSE 15.5 1.00 VA-133 OIL PRESS. HOSE 27.25 1.00 VA-135 OIL COOLER HOSE 16.5 1.00 VA-168 SENDER MOUNT 1.00 VA-186 OIL COOLER BOX ASSY. 1.00 VA-187 4" FLANGED DUCT 1.00 VA-190 OIL COOLER HOSE 27" 1.00 BAF-10-540 BAFFLE KIT IO-540 1.00 PT-035X1/4X4' LO PRES-BRKE RES.TUBE 1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!! 1.00 VENT SCAT 2X3' RED 2" SCAT 3' LONG 1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT 1.00 VENT SCAT 4X16" 4" DIA. RED SCAT HOSE 1.00 EA DYNA BOLT I(O)-540 MOTOR MOUNT BOLT KIT 1.00 BAG 516 RIVET AN426AD3-3.5 1.00 BAG 517 RIVET AN426AD3-4 1.00 BAG 518 RIVET AN426AD4-4 1.00 BAG 519 RIVET AN426AD4-5 1.00 BAG 520 MISC. AN BOLTS 1.00 BAG 521 MISC. WASHERS 1.00 BAG 522-1 MISC. FITTINGS/CLAMPS 1.00 BAG 523-1 FITTINGS/MISC. 1.00 BAG 524 MISC. CLAMPS 1.00 BAG 525-1 MISC/BEARINGS 1.00 BAG 526-1 CABIN HEAT SHUTTLE HW 1.00 PT-062X1/4X24" HIGH PRESSURE 1.00 CT BLK THROTTLE 47.5 10 (I(O)-540) 1.00 CT BLUE VPROP 72.5 10 (I(O)-540)FWD GOV 1.00 CT RED VMIXTURE 51.5 10 (I(O)-540) 1.00 VA-182-PC KIT THR/MIX BKT IO VERT 1.00 VA-189 FUEL LINE IO-540 25.5 1.00 DOC FF-IO-540 TEXT/DWGS RV-10 F.FWD 1.00 EA EXH 10 I(O)-540 I(O)-540 VETTERMAN 1.00 VA-138 FUEL SUPPLY HOSE 14.0 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jfgilmore Sent: Saturday, September 06, 2008 2:52 PM Subject: RV10-List: Finish Kit I have decided to use an engine other than the IO-540 and am ready to order the finish kit. My selected engine comes with a custom cowling and other components specific to the engine. I don't want to order a finish kit from Van's that comes with parts that I will not use. Does anyone have a shipping list for the finish kit who might also identify the parts I won't need? I would settle for just the finish kit inventory list. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2952#202952 ________________________________________________________________________________
Date: Sep 07, 2008
G'day Gary, I mounted mine on the top cabin centreline aft of the door posts in the thi nner material. Even there, the thickness of the cabin is close to 1/2" and the GPS antenna studs were not long enough. The studs are no where near l ong enough to penetrate the forward (thicker) part of the cabin. I made so me extensions out of steel tube tapped for the antenna studs, and threaded on the outside for the nuts. A bit of work but came out great. Antenna le ad passed through the windshield support brace and through a small cover st rip down the cabin top. I think you can buy an alternate antenna that has a flange mount rather tha n the studs. This (and some rivnuts)is probably a better option if you wan t to mount the antenna to the lid. cheers, Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com on behalf of orchidman Sent: Sun 9/7/2008 7:21 AM Subject: RV10-List: GPS Antenna Mounting I am to the point of needing to mount or at least drill the holes for the 4 30W GPS antenna. I want to put it on top of the cabin but it looks like I have 2 options. On the cabin top center line for/aft; One is just behind the aft door posts where the top is rather thin. The second location is centered between the door hinges where the top is very thick. Using the aft location, I don't think I would have any problems with screw length or attaching the coax. If I were to use the location between the door hings, I am concerned about getting the coax connected and to a lesser extent the screws and what I wou ld have the nuts tighten up against. Where are others mounting their antenna and any thoughts? -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2951#202951 "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Sep 06, 2008
Subject: Finish Kit
You stated the Finish Kit but did you mean the Firewall Forward Kit? Seems you would want the Firewall Forward Kit as listed below. Not too much in the Finish Kit is specific to the engine. Get a current FF or Finish kit contents from Van's William http://nerv10.com/wcurtis/ -------- Original Message -------- > > Here is the current up to date list as of 8/15/2008 direct from Van's > > > 1.00 FF-10 IO-540 F.WALL FWD.KIT IO-540 > 3.00 CT A-740 BLACK PUSH PULL CABLE BLACK > 2.00 DUCT CBT-5/8 COOLING BLAST TUBE > 2.00 EA 4" DUCT HOSE CLAMP 4" HOSE CLAMP > 1.00 EA CV HOSE 7545 BREATHER HOSE -540 > 6.00 EA GASKET 77611 BLO-PROOF EXHST GASKT > 4.00 EA DYNA VI I(O)-540 VIB.ISO. RV-10 ONLY > 1.00 EA OIL COOLER 20006A OIL COOLER I(O)-540 > 1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT > 1.00 FAB-360/540 FLTRD A/BOX-360 FI320 > 1.00 FF-1005 BREATHER TUBE > 1.00 IE VMP INSTALL KIT FITTINGS/HOSES > 1.00 PROP GOV MT P-860-3 I(O)-540 LYCOMING > 1.00 VA-102 FUEL PRES. HOSE 15.5 > 1.00 VA-133 OIL PRESS. HOSE 27.25 > 1.00 VA-135 OIL COOLER HOSE 16.5 > 1.00 VA-168 SENDER MOUNT > 1.00 VA-186 OIL COOLER BOX ASSY. > 1.00 VA-187 4" FLANGED DUCT > 1.00 VA-190 OIL COOLER HOSE 27" > 1.00 BAF-10-540 BAFFLE KIT IO-540 > 1.00 PT-035X1/4X4' LO PRES-BRKE RES.TUBE > 1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!! > 1.00 VENT SCAT 2X3' RED 2" SCAT 3' LONG > 1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT > 1.00 VENT SCAT 4X16" 4" DIA. RED SCAT HOSE > 1.00 EA DYNA BOLT I(O)-540 MOTOR MOUNT BOLT KIT > 1.00 BAG 516 RIVET AN426AD3-3.5 > 1.00 BAG 517 RIVET AN426AD3-4 > 1.00 BAG 518 RIVET AN426AD4-4 > 1.00 BAG 519 RIVET AN426AD4-5 > 1.00 BAG 520 MISC. AN BOLTS > 1.00 BAG 521 MISC. WASHERS > 1.00 BAG 522-1 MISC. FITTINGS/CLAMPS > 1.00 BAG 523-1 FITTINGS/MISC. > 1.00 BAG 524 MISC. CLAMPS > 1.00 BAG 525-1 MISC/BEARINGS > 1.00 BAG 526-1 CABIN HEAT SHUTTLE HW > 1.00 PT-062X1/4X24" HIGH PRESSURE > 1.00 CT BLK THROTTLE 47.5 10 (I(O)-540) > 1.00 CT BLUE VPROP 72.5 10 (I(O)-540)FWD GOV > 1.00 CT RED VMIXTURE 51.5 10 (I(O)-540) > 1.00 VA-182-PC KIT THR/MIX BKT IO VERT > 1.00 VA-189 FUEL LINE IO-540 25.5 > 1.00 DOC FF-IO-540 TEXT/DWGS RV-10 F.FWD > 1.00 EA EXH 10 I(O)-540 I(O)-540 VETTERMAN > 1.00 VA-138 FUEL SUPPLY HOSE 14.0 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jfgilmore > Sent: Saturday, September 06, 2008 2:52 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Finish Kit > > > I have decided to use an engine other than the IO-540 and am ready to order > the finish kit. My selected engine comes with a custom cowling and other > components specific to the engine. I don't want to order a finish kit from > Van's that comes with parts that I will not use. Does anyone have a > shipping list for the finish kit who might also identify the parts I won't > need? I would settle for just the finish kit inventory list. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 2952#202952 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: GPS Antenna Mounting
Date: Sep 06, 2008
For mounting between the doors you can use aluminum tube standoffs. drill the top skin the diameter of the screw and the inner cabin top for a snug fit of the standoff. Hope this helps Joe ----- Original Message ----- From: "orchidman" <gary(at)wingscc.com> Sent: Saturday, September 06, 2008 4:51 PM Subject: RV10-List: GPS Antenna Mounting > > I am to the point of needing to mount or at least drill the holes for the > 430W GPS antenna. I want to put it on top of the cabin but it looks like > I have 2 options. > On the cabin top center line for/aft; One is just behind the aft door > posts where the top is rather thin. The second location is centered > between the door hinges where the top is very thick. > Using the aft location, I don't think I would have any problems with screw > length or attaching the coax. > If I were to use the location between the door hings, I am concerned about > getting the coax connected and to a lesser extent the screws and what I > would have the nuts tighten up against. > > Where are others mounting their antenna and any thoughts? > > -------- > Gary Blankenbiller > RV10 - # 40674 > Instrument Panel, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 2951#202951 > > > ________________________________________________________________________________
Date: Sep 06, 2008
Hi What engine are you using? I am using an Eggenfellner E6TI (3.6l) Cheers Les Kearney #40643 - some assembly required Sent from my iPhone On 6-Sep-08, at 3:51 PM, jfgilmore wrote: > > I have decided to use an engine other than the IO-540 and am ready > to order the finish kit. My selected engine comes with a custom > cowling and other components specific to the engine. I don't want > to order a finish kit from Van's that comes with parts that I will > not use. Does anyone have a shipping list for the finish kit who > might also identify the parts I won't need? I would settle for just > the finish kit inventory list. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 2952#202952 > > ________________________________________________________________________________
Subject: Door seals???????
Date: Sep 06, 2008
Left them completely intact in that area, no razor blade down the middle. Thanks, John ---------------------------------------- > From: jesse(at)saintaviation.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Door seals??????? > Date: Sat, 6 Sep 2008 14:53:48 -0400 > > > The majority of air movement that you get without the seals is around > the door hinges, so at least make sure you have a good seal there. > > do nor archive > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > On Sep 6, 2008, at 11:49 AM, John Gonzalez wrote: > >> >> >> >> I put my doors back on the plane with the stock seals in place, >> (properly placed) and I too found that the seals were way too thick >> to allow the doors to close. >> >> I have done a really nice job of getting the (outside) edges of the >> doors to fit to the cabin opening and also got an excellent fit >> where the inside cabin flange joins up with the inside of the door, >> I built it up to fit so that a business card can't even slide through. >> >> With the doors back on, the first thing I noticed was that the >> bottom seal was way too thick. I used a razor blade and cut the >> seals at the corners and removed the whole bottom piece. Tried it >> back on and it fit better but was still too thick in some areas. I >> next used a razor blade and put a single cut down the middle of the >> entire length of the seal. The seal does not seem to interfere at >> all with the fit, but what is left to be seen/felt is how effective >> the seal is with this approach. Again, I am also releying on the >> solid fit of the door to help with the air and not just this rubber >> seal. >> >> JOhn G. 409 >> >> >> >> > > > > > ________________________________________________________________________________
Date: Sep 06, 2008
pitts_pilot(at)bellsouth. wrote: > I don't know why you'd want to go to all that trouble unless your 430W > is mounted to the cabin top too. I'm nowhere near the point of mounting > anything electronic, so bear with me. Why not mount the GPS antenna > (and any other satellite antenna) on the glareshield???? The signal > attenuation due to the windshield is negligible. You could hide it > under the cowl (I think even under the cabin top) as long as the carbon > fiber isn't above it. Mine will probably go on the glareshield. > Linn > Linn, In the archives there is a rather large number of people experiencing problems mounting on the glare shield or under the cowl. I don't want to risk having a problem and having to 're-do' it. Thanks, Gary -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2985#202985 ________________________________________________________________________________
Date: Sep 06, 2008
mckervey(at)charter.net wrote: > For mounting between the doors you can use aluminum tube standoffs. drill > the top skin the diameter of the screw and the inner cabin top for a snug > fit of the standoff. > > Hope this helps > > Joe > --- I think my next step is to get the coax connector and go from there. Guess I will be making a call to Stein Monday. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 2986#202986 ________________________________________________________________________________
Date: Sep 07, 2008
Thanks Gary.... I guess the direct approach is best! Jim Gilmore, =C2-#40317 RV10 Wings/Empennage complete about to start fuse ________________________________________________________________________________
Date: Sep 07, 2008
Actually, I was referring to the finish kit. =C2-I won't need anything fro m a Van's FF FWD kit, as my engine package comes complete. Jim Gilmore, #41317 RV10 - Wings/Empennage complete =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-- about to start fuse ________________________________________________________________________________
Date: Sep 07, 2008
I'm using a Vesta Inc. engine/prop package. =C2-I will probably start or a t least contribute to a storm of dialogue on the topic, but I like the idea of a non-air-cooled engine and parts that are readily available at local aut o parts stores at non-aviation part prices. =C2-Also, not giving up anythi ng to power and relying on a company that produces millions of engines rathe r than thousands is very appealing. Jim Gilmore, #40317 RV10 - Wings/empennage complete =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-- about to start fuse ________________________________________________________________________________
Date: Sep 07, 2008
Any problem mounting the GPS antennas on the top of the tailcone? Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: "orchidman" <gary(at)wingscc.com> Sent: Saturday, September 06, 2008 9:43 PM Subject: RV10-List: Re: GPS Antenna Mounting > > > mckervey(at)charter.net wrote: >> For mounting between the doors you can use aluminum tube standoffs. drill >> the top skin the diameter of the screw and the inner cabin top for a snug >> fit of the standoff. >> >> Hope this helps >> >> Joe >> --- > > I think my next step is to get the coax connector and go from there. > Guess I will be making a call to Stein Monday. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Instrument Panel, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 2986#202986 > > > ________________________________________________________________________________
Date: Sep 07, 2008
That is where I mounted mine. It has worked great. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Sunday, September 07, 2008 7:39 AM Subject: Re: RV10-List: Re: GPS Antenna Mounting Any problem mounting the GPS antennas on the top of the tailcone? Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: "orchidman" <gary(at)wingscc.com> Sent: Saturday, September 06, 2008 9:43 PM Subject: RV10-List: Re: GPS Antenna Mounting > > > mckervey(at)charter.net wrote: >> For mounting between the doors you can use aluminum tube standoffs. drill >> the top skin the diameter of the screw and the inner cabin top for a snug >> fit of the standoff. >> >> Hope this helps >> >> Joe >> --- > > I think my next step is to get the coax connector and go from there. > Guess I will be making a call to Stein Monday. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Instrument Panel, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 2986#202986 > > > ________________________________________________________________________________
Subject: Fuel Lables
Date: Sep 07, 2008
Final call for any one still wanting a fuel lable. I ordered a few extras to get the price break and so have 4 more sets if anyone still wants one and missed the cut off date. Gary Specketer 40274 Flying ________________________________________________________________________________
Subject: Elevator pushrod safety wire size
Date: Sep 07, 2008
What size safety wire did you guys use for the F-1089 elevator pushrod? I didn't see any size specified in the plans. I used .041 and it seems to be binding... Should I use a thinner wire or just make a bigger loop at the rod end bearing? Lenny, #40803 Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3074#203074 ________________________________________________________________________________
Date: Sep 07, 2008
daveleikam(at)wi.rr.com wrote: > Any problem mounting the GPS antennas on the top of the tailcone? > > Dave Leikam > RV-10 #40496 > N89DA (Reserved) > Muskego, WI > > --- That has been added to the list of possible locations. I dug out the installation manual and the one I have been using for the 430W is REV B. paragraph 3.10.1 It lists a max coax length of 35 feet and you have to calculate the minimum length. It comes out to about 15 feet. However, I have an updated version REV E and checking it, the text has changed. I have a GA35 antenna and the new text places this antenna in a new category only requiring a minimum length of 6.5 feet and the max still at 35 feet. All of this is based on a dB signal loss that is required for the receiver. If I mount it on the first AL skin on top, that would put me right in the middle of the dB loss range based on 2 connectors and the coax length and having a full view of the heavens. The only down side is that it would be within 19" of my magnatomitor. Guess I will need to call Rob tomorrow and see if they have any feeling about the amount of mag distoration the GPS antenna emits. All thoughts are appreciated. Nothing is locked in stone yet. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3083#203083 ________________________________________________________________________________
Date: Sep 07, 2008
What is the current price for the Vesta package and what do you get for that price? -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3084#203084 ________________________________________________________________________________
Date: Sep 07, 2008
Your magnetometer is not much over 18" from your auto pilot servo. I don't think the GPS antenna emits anything. I think it is just a receiver. 19" should be fine, but it wouldn't hurt to verify that with Rob. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Sep 7, 2008, at 4:18 PM, orchidman wrote: > > > daveleikam(at)wi.rr.com wrote: >> Any problem mounting the GPS antennas on the top of the tailcone? >> >> Dave Leikam >> RV-10 #40496 >> N89DA (Reserved) >> Muskego, WI >> >> --- > > That has been added to the list of possible locations. > I dug out the installation manual and the one I have been using for > the 430W is REV B. paragraph 3.10.1 > It lists a max coax length of 35 feet and you have to calculate the > minimum length. It comes out to about 15 feet. However, I have an > updated version REV E and checking it, the text has changed. I have > a GA35 antenna and the new text places this antenna in a new > category only requiring a minimum length of 6.5 feet and the max > still at 35 feet. > > All of this is based on a dB signal loss that is required for the > receiver. > > If I mount it on the first AL skin on top, that would put me right > in the middle of the dB loss range based on 2 connectors and the > coax length and having a full view of the heavens. The only down > side is that it would be within 19" of my magnatomitor. Guess I > will need to call Rob tomorrow and see if they have any feeling > about the amount of mag distoration the GPS antenna emits. > > All thoughts are appreciated. Nothing is locked in stone yet. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Instrument Panel, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3083#203083 > > ________________________________________________________________________________
Subject: Epoxy on Trailing edges
Date: Sep 07, 2008
Can anyone explain why the epoxy is needed on the trailing edges? =C2-I ha ve just finished the flaps and ailerons, and the clecoed trailing edges (wit h dry center wedge) follow a laser line of straightness. =C2-I'm afraid th at if I pry the skins apart enough (everything is such a nice tight fit now) to get the center wedge in with epoxy, that I'll bend the skins outward, an d I will ruin the nice straight edge that I now have. =C2-Therefore, I'd r ather not use the epoxy and just go ahead with the double-flush riveting... Has anyone done it this way? =C2-I went flying with a friend today in a 17 2, and there was certainly no epoxy used on the trailing edges of those wing s! Jim GIlmore, #40317 Wings, Empennage finished, ready to start fuse ________________________________________________________________________________
Date: Sep 07, 2008
jesse(at)saintaviation.co wrote: > Your magnetometer is not much over 18" from your auto pilot servo. I > don't think the GPS antenna emits anything. I think it is just a > receiver. 19" should be fine, but it wouldn't hurt to verify that > with Rob. > > Jesse Saint > The battery + lead (closest part of the battery) and the AP servo are right at 23". The one thing that might be a problem is the strobe power supply which is 28" away. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3103#203103 ________________________________________________________________________________
Subject: RV8-List: RV-8 Empennage Kit for sale on E-Bay
Date: Sep 07, 2008
I have just posted my RV-8 Empennage kit for sale on E-Bay. Kit number 81777. I am currently building a -10. Details for item number: 140265193528 Listing URL: http://cm.ebay.com/cm/ck/1065-29296-2357-0?uid=47907171&site=0&ver=LCA080805&item=140265193528&lk=URL ________________________________________________________________________________
Date: Sep 07, 2008
Gary, My battery and TruTrak servo are in the stock locations. I have my GPS antenna just aft of the cabin roof on the tail boom, a little to the right side. My AFS magnetometer is mounted high in the tailboom just forward of the first former aft of the battery. I mounted it on a little 7* tray to align it vertically with the panel. The thing I worried about most was a cabin speaker mounted high on the left side of the baggage compartment rear wall. I was prepared to move it if it affected the magnetometer, but everything (mentioned) works perfectly. I think you're on the right track. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman Sent: Sunday, September 07, 2008 4:03 PM Subject: RV10-List: Re: GPS Antenna Mounting jesse(at)saintaviation.co wrote: > Your magnetometer is not much over 18" from your auto pilot servo. I > don't think the GPS antenna emits anything. I think it is just a > receiver. 19" should be fine, but it wouldn't hurt to verify that > with Rob. > > Jesse Saint > The battery + lead (closest part of the battery) and the AP servo are right at 23". The one thing that might be a problem is the strobe power supply which is 28" away. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3103#203103 ________________________________________________________________________________
Subject: Re: Elevator pushrod safety wire size
Date: Sep 08, 2008
Thanks Tim! Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3145#203145 ________________________________________________________________________________
Subject: 51% Deadline Approaching
Date: Sep 08, 2008
The NW RV-10 Builders completed a remarkable dinner on Saturday night at the home of Randy & Cheryl DeBauw (First flying RV-10, N610RV). We were fortunate enough to have both Dick and Diane Van Grunsven (N410DV) in attendance. Dick shared with all of us his personal perspective and experience as Co-Chair on the ARC Committee. The deadline for written comments is now just three weeks away - September 30th. The FAA would truly like to hear from you. Painfully, very few builders have written comments on this important policy changes. One of our members who could not attend asked that I forward to all of you, the information from the EAA perspective (the body the FAA chose to run with on this) and the contact on how to make your comments known. It is not important your politics, or politically correct affiliation. It was too easy to forget that not every member of this list is an EAA member and may or may not have already heard about the process. Several foreign countries are watching the direction the U.S. FAA takes on kit built aircraft policy. Please find attached, two PDFs on the EAA recommended position (for reference only 12 pages) and both the email or the US Postal address (two pages) for your needed written comments. Thanks John Cox #600 <> <> ________________________________________________________________________________
Subject: Performance
Date: Sep 08, 2008
I made a flight from Yuma to Southern Idaho and return last week and recorded the following: OAT ALT RPM MAP GPH TAS 64f 7500' 2200 22.5 12.9 154k 50f 10500' 2150 20.7 11.2 155k 45f 11500' 2260 20.1 12.2 154k Engine is IO540 with 10:1, single Lightspeed, ACI 3 blade. WOT leaned to approx 100 ROP. Also, FYI, Fillmore, UT (KFOM) 100LL was $4.419. Albert Gardner Yuma, AZ ________________________________________________________________________________
Subject: Garmin GPS496 Antenna & XM antenna mounting
Date: Sep 08, 2008
I have my GPS 496 in an Air Gizmo holder in my panel After expending considerable anxiety trying to decide where to put the 2 antennas for my 496 (principal nav device) unit. I decided against putting them on a shelf in the engine compartment. I put them both on the glare-shield on the advice of Bob at Garmin. I hard wired and screwed the GPS antenna into the glare-shield. The XM is another case........ You have to procure two (2) metric M3x6 screws to fit the bottom of the XM antenna. You want to make the XM antenna removable form the aircraft so that (if you want) you can get satellite weather at home. I fabricated a bracket that fits on top of the glare-shield and is removable. The XM antenna is screwed to the bracket and the bracket unhooks from the glare-shield with one screw. You also need a 1/4" hole in the top of the glare-shield to push the wire and mini-USB cable through. My first though was to get another XM antenna. NO NO NO...... The XM WX subscription is dedicated to the antenna NOT the GPS 496 unit. Many thanks to Bob at Garmin Aviation division -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3321#203321 ________________________________________________________________________________
Subject: Re: Garmin GPS496 Antenna & XM antenna mounting
Date: Sep 08, 2008
I put velcro on my XM antenna to hold it on the glare shield so I can swap it between the RV-6A and RV-10. Kevin ----- Original Message ----- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Monday, September 08, 2008 10:22 PM Subject: RV10-List: Garmin GPS496 Antenna & XM antenna mounting > > I have my GPS 496 in an Air Gizmo holder in my panel > > After expending considerable anxiety trying to decide where to put the 2 > antennas for my 496 (principal nav device) unit. I decided against putting > them on a shelf in the engine compartment. I put them both on the > glare-shield on the advice of Bob at Garmin. I hard wired and screwed the > GPS antenna into the glare-shield. The XM is another case........ > > You have to procure two (2) metric M3x6 screws to fit the bottom of the XM > antenna. You want to make the XM antenna removable form the aircraft so > that (if you want) you can get satellite weather at home. I fabricated a > bracket that fits on top of the glare-shield and is removable. The XM > antenna is screwed to the bracket and the bracket unhooks from the > glare-shield with one screw. You also need a 1/4" hole in the top of the > glare-shield to push the wire and mini-USB cable through. My first though > was to get another XM antenna. NO NO NO...... The XM WX subscription is > dedicated to the antenna NOT the GPS 496 unit. > > Many thanks to Bob at Garmin Aviation division > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - exited cabin top/door purgatory > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3321#203321 > > > ________________________________________________________________________________
Date: Sep 08, 2008
Mike, You know that AirGizmos also sells an XM Antenna Dock that allows you to remove & use the ($500) XM antenna else ware. I purchased an Antenna Dock Premium at SNF 2 years ago. http://www.airgizmos.com/antennadock.asp Of course it's not as inexpensive as two M3x6 screws. Robin ________________________________________________________________________________
Subject: Re: 51% Deadline Approaching
Date: Sep 09, 2008
These are part of the comments that I sent to the FAA on the new proposals - what do you think? I like the education and recreation language of the current regulation. It seems that the words "significant personal involvement in the assembly and fabrication of the aircraft for education and recreation ", makes a lot of sense. A time log and or progress log (written or electronic) might have to become mandatory. Special accommodation may have to be made in the case of an Experimental aircraft that was started and then sold to another home builder. If I order an experimental aircraft from a professional builder - I should have ordered a Cessna or a Piper. If I show up at the professional builder's location for a few cameo assembly pictures, then try to pull the wool over the DAR's face, I should not expect an Experimental Certificate. Perhaps, for a fee, the FAA can certify professionally fabricated kit planes, but they would be something other than Experimental. Significant personal involvement should not be too difficult to ascertain with a simple checklist and careful questioning of the builder on the structure, and systems of the craft. An experimental owner builder MUST have an intimate familiarity with all of the structure, and systems of the craft. This gets back to the phrase education and recreation. An appeal process could also be implemented for those turned down for an Experimental Certificate. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3340#203340 ________________________________________________________________________________
Date: Sep 09, 2008
OK, where are the pictures and plans. I want details, details, details [Mr. Green] -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3358#203358 ________________________________________________________________________________
Date: Sep 09, 2008
From: "bruce breckenridge" <bbreckenridge(at)gmail.com>
Thanks John for the reminder. Mine's going out today.Bruce PS: Man, that pulled-pork was good. And the deserts! Way too many! On Mon, Sep 8, 2008 at 9:49 AM, John Cox wrote: > The NW RV-10 Builders completed a remarkable dinner on Saturday night at > the home of Randy & Cheryl DeBauw (First flying RV-10, N610RV). We were > fortunate enough to have both Dick and Diane Van Grunsven (N410DV) in > attendance. Dick shared with all of us his personal perspective and > experience as Co-Chair on the ARC Committee. The deadline for written > comments is now just three weeks away - September 30th. The FAA would > truly like to hear from you. Painfully, very few builders have written > comments on this important policy changes. > > One of our members who could not attend asked that I forward to all of you, > the information from the EAA perspective (the body the FAA chose to run > with on this) and the contact on how to make your comments known. It is > not important your politics, or politically correct affiliation. It was > too easy to forget that not every member of this list is an EAA member and > may or may not have already heard about the process. Several foreign > countries are watching the direction the U.S. FAA takes on kit built > aircraft policy. > > Please find attached, two PDFs on the EAA recommended position (for > reference only 12 pages) and both the email or the US Postal address (two > pages) for your needed written comments. > > Thanks > > John Cox > > #600 > > <> < on Convoluted Proposal for Enfo.pdf>> > ________________________________________________________________________________
Date: Sep 09, 2008
Ok, there's good news and bad news. The good news is that for all of you that requested the shoulder harness bracket only, they went out this morning.... even to some who I hadn't received ck's from yet. The bad news,,, which is actually good news, is that I pulled the headset bracket off my 10 and redesigned it so that it would fit almost all headsets, and also changed from aluminum to stainless. Also good news,,,, they ran them today on the cnc, are partially deburred, but now are awaiting the brake and about 6 hours in the tumbler. Best guess is that they will be ready the end of this week.... to probably ship next week. It's been great talking to everyone. Don McDonald #40636 Finishing the plane and the kitchen remodel ps. We ran another 45 of the shoulder harness brackets and the first run of the headset brackets was 32. [Laughing] -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3496#203496 Attachments: http://forums.matronics.com//files/img_2629c_114.jpg ________________________________________________________________________________
Subject: elt locations
Date: Sep 09, 2008
I'm considering mounting the ELT antenna inside the airplane on the longeron behind the passenger side rear window. For people that have done this where are you mounting the ELT itself? Pictures would be nice. THX -Ben ________________________________________________________________________________
Subject: power off glide and descent rate
Date: Sep 09, 2008
What sort of numbers are people seeing for best glide speed and rates of descent? I'm curious if there is an appreciable difference between the 2-blade descent rate and the 3-blade descent rate in a power off glide? Rob have you done any testing in this arena with the hartzell? If so do you know what your descent rate is? All this talk about cruise performance between the 2 and 3 bladed guys but so far we haven't discussed the "oh s**t" performance. -Ben Westfall ________________________________________________________________________________
Date: Sep 09, 2008
Subject: Re: elt locations
Mine is on the floor of the tailcone right of the bellcrank assembly in the tailcone...used some angle stock atached to the J-stringers=C2-and made a floor for the bracket to be attached too...pretty basic..There is an adva ntage to making it accessible in the event of an unlikely water landing as you suggest behind the passenger...you could actually remove it, install th e external antenna=C2-and=C2-plug your headset into it easily if needed . Rick S. 40185 ----- Original Message ----- From: "Ben Westfall" <rv10(at)sinkrate.com> Sent: Tuesday, September 9, 2008 8:21:29 PM (GMT-0800) America/Los_Angeles Subject: RV10-List: elt locations I=99m considering mounting the ELT antenna inside the airplane on the longeron behind the passenger side rear window. =C2-For people that have done this where are you mounting the ELT itself? =C2-Pictures would be n ice. THX -Ben ==== ======================= == ________________________________________________________________________________
Subject: Aluminum Windshield Fairing
Date: Sep 09, 2008
Has anyone tried fabricating an aluminum windshield front fairing instead of the fiberglass? I seem to remember seeing one, but cannot find anything in the archives. I have access to some pretty sophisticated metal forming equipment, so the thought crossed my mind.............. -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3503#203503 ________________________________________________________________________________
Date: Sep 09, 2008
Subject: Re: Aluminum Windshield Fairing
http://www.mlskunkworks.embarqspace.com/#/windscreenfairings/4528454960 dmaib(at)mac.com wrote: > > Has anyone tried fabricating an aluminum windshield front fairing instead of the fiberglass? I seem to remember seeing one, but cannot find anything in the archives. I have access to some pretty sophisticated metal forming equipment, so the thought crossed my mind.............. > > -------- > David Maib > RV-10 #40559 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3503#203503 > > > ________________________________________________________________________________
Date: Sep 09, 2008
I hope the pics are self explainatory.- Any questions, just email. Don McDonald #40636 --- On Tue, 9/9/08, Ben Westfall wrote: From: Ben Westfall <rv10(at)sinkrate.com> Subject: RV10-List: elt locations Date: Tuesday, September 9, 2008, 8:21 PM I=A2m considering mounting the ELT antenna inside the airplane on the longe ron behind the passenger side rear window. -For people that have done thi s where are you mounting the ELT itself? -Pictures would be nice. - THX - -Ben - =0A=0A=0A ________________________________________________________________________________
Subject: Tach Pulse Generator
Date: Sep 09, 2008
There was some mention of a tach pulse generator that fit on the vacuum pump pad. Does anyone remember the source of that device? Albert Gardner Yuma, AZ N991RV ________________________________________________________________________________
Subject: Re: power off glide and descent rate
Date: Sep 10, 2008
There are couple of Robs on the list ,I think. I have done the testing but won't have access to them until next week. I'll be happy to tell you mine if you tell me yours! On Sep 9, 2008, at 11:33 PM, Ben Westfall wrote: > What sort of numbers are people seeing for best glide speed and > rates of descent? I=92m curious if there is an appreciable difference > between the 2-blade descent rate and the 3-blade descent rate in a > power off glide? Rob have you done any testing in this arena with > the hartzell? If so do you know what your descent rate is? All > this talk about cruise performance between the 2 and 3 bladed guys > but so far we haven=92t discussed the =93oh s**t=94 performance. > > -Ben Westfall > > ________________________________________________________________________________
Date: Sep 10, 2008
I was told that antennas like these cannot "see" thru carbon fiber. Is any part of the cabin top made with carbon fiber? Also I think that Rob Hickman from Advanced Flight Systems also has his mounted in the baggage area. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3528#203528 ________________________________________________________________________________
Date: Sep 10, 2008
I mounted my ELT antenna just inside the baggage compartment immediately on the left almost against the fuselage. It's out of the way and in case I ever need it hopefully I will be able to get at it. I thought about putting it behind the bulkhead, which I think many have done, but as I said I wanted to be able to get at it. Also I have an overhead console and I have the ELT antenna mounted horizontally up in the console. I've also seen some mount the antenna horizontally in the tail section area and you can access it if the rear fairing is off. I've attached a couple of photos of where I mounted it. I've done quite a bit of traveling, using the baggage compartment, and it's nit proved to be any problem. Wayne Edgerton N602WT ________________________________________________________________________________
Date: Sep 10, 2008
Dick Nordquist from the Lino Air park made metal fairings for everything on his 6. He can tell you the good and the bad. Let me know if you want contact info. Gary Specketer 40274 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dmaib(at)mac.com Sent: Tuesday, September 09, 2008 11:58 PM Subject: RV10-List: Aluminum Windshield Fairing Has anyone tried fabricating an aluminum windshield front fairing instead of the fiberglass? I seem to remember seeing one, but cannot find anything in the archives. I have access to some pretty sophisticated metal forming equipment, so the thought crossed my mind.............. -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3503#203503 ________________________________________________________________________________
Date: Sep 10, 2008
I'd tell you mine but I need to get busy attaching the wings and motor! Any response from a "Rob" will do of course :-) but I was thinking Rob Hickman but obviously didn't make that clear. THX -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj Sent: Wednesday, September 10, 2008 2:48 AM Subject: Re: RV10-List: power off glide and descent rate There are couple of Robs on the list ,I think. I have done the testing but won't have access to them until next week. I'll be happy to tell you mine if you tell me yours! On Sep 9, 2008, at 11:33 PM, Ben Westfall wrote: What sort of numbers are people seeing for best glide speed and rates of descent? I'm curious if there is an appreciable difference between the 2-blade descent rate and the 3-blade descent rate in a power off glide? Rob have you done any testing in this arena with the hartzell? If so do you know what your descent rate is? All this talk about cruise performance between the 2 and 3 bladed guys but so far we haven't discussed the "oh s**t" performance. -Ben Westfall ________________________________________________________________________________
Date: Sep 10, 2008
I have not tried to measure it and I don't have enough experience flying another RV-10 with the two blade prop. Dan Benua and I flew both my RV-10 and his RV-10 on Sunday practicing IFR approaches and he felt that my RV-10 had more braking (prop drag) in the pattern. I am currently using the RV-10 for IFR training and flying over 5 hours a week with an instructor. I am finding that the 90 kts flap speed is pretty slow and the drag from the prop helps. In practicing engine out landings in the RV-10 I have not noticed a big difference between it and my RV-4. The fine pitch stop adjustment on the prop will also make a big difference in glide performance. When I switched from the 7660 Hartzell to the composite two blade Hartzell (same large blades as on my RV-10) in my RV-4 I lost a lot of the braking that I had been used to. I am not sure if it is because of the fine pitch stop or that the large blades have more thrust at idle rpm settings. Rob Hickman N402RH RV-10 85 Hours **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Date: Sep 10, 2008
Not sure why putting the gps antennas under the cowling isn't good idea. except for the XM, rest of gps antennas are under cowl and work great. 530. 496,AFS, etc. 496 is mounted on gizmo bracket with usual cables hard wired to back. ran the XM 'extension' that is available thru small hole thru glare-shield and brought it out by center pole at base of glare-shield. the end of the extension just sits there--hardly able to see it. plug the xm hockey puck into it and good to go. no mounting. it sits there during takeoff, etc. works great. unplug and your ready to use it in another setting. simple, no fuss. larry b. -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3714#203714 ________________________________________________________________________________
Subject: Annuciator Lights
Date: Sep 10, 2008
Les, I'm not sure if you got any responses so here's my .02. I have the same pitot and recommend you keep the lights as is. One is for power, one for low temp, and one for heat on. I don't think you would want just one light and it would take some creative electronic wizardry to employ a light with 3 colors available. I just drilled 3 holes in the panel next to the pitot heat switch and glued the lights in place, it works great. I haven't used any annunciator lights other that what came with the GRT EFIS so can't help you there. Marcus 40286 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Thursday, August 28, 2008 12:34 PM Subject: RV10-List: Annuciator Lights Hi As I layout my panel I am wondering about what is the best choice for annuciator lights. I see Stein has some nice LEDS (http://www.steinair.com/lights.htm) that will do the job. Has anyone found a similar light that will display red/yellow/green on the same light? My Gretz heated pitot has a small board with three LEDS that I would like to combine into a single light. Inquiring minds need to know Les Kearney #40643 - Some assembly required ________________________________________________________________________________
Subject: Re: Annuciator Lights
Date: Sep 10, 2008
Hi Marcus I might do as you suggest. Do you have a pix of your lights? I still have time to decide. Cheers Les Sent from my iPhone On 10-Sep-08, at 5:52 PM, Marcus Cooper wrote: > Les, > > I=99m not sure if you got any responses so here=99s my .02. I > have the same pitot and recommend you keep the lights as is. One is > for power, one for low temp, and one for heat on. I don=99t think yo > u would want just one light and it would take some creative electron > ic wizardry to employ a light with 3 colors available. I just drill > ed 3 holes in the panel next to the pitot heat switch and glued the > lights in place, it works great. > > > I haven=99t used any annunciator lights other that what came with the > GRT EFIS so can=99t help you there. > > > Marcus > > 40286 > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Les Kearney > Sent: Thursday, August 28, 2008 12:34 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Annuciator Lights > > > Hi > > > As I layout my panel I am wondering about what is the best choice > for annuciator lights. I see Stein has some nice LEDS (http://www.steinair.com/lights.htm > ) that will do the job. > > > Has anyone found a similar light that will display red/yellow/green > on the same light? My Gretz heated pitot has a small board with > three LEDS that I would like to combine into a single light. > > > Inquiring minds need to know > > > Les Kearney > > #40643 =93 Some assembly required > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Sep 10, 2008
Subject: Re: Garmin GPS496 Antenna & XM antenna mounting (orchidman)
Here is how I mounted my XM and GPS antenna for the 496: http://www.vansairforce.com/community/showthread.php?t=29027 > > Subject: RV10-List: Re: Garmin GPS496 Antenna & XM antenna mounting > From: "orchidman" <gary(at)wingscc.com> > > > OK, where are the pictures and plans. > I want details, details, details [Mr. Green] > > -------- > Gary Blankenbiller > RV10 - # 40674 > Instrument Panel, Fiberglass - SB > (N2GB registered) > ________________________________________________________________________________
Subject: baggage door seal on hinge
Date: Sep 10, 2008
I noticed that there is a gap on the hinge side of the baggage door that does not call for a seal in the plans (sect 34-6 fig 1) . Did anyone use anything on that side to fill the gaps? Thanks! Pascal ________________________________________________________________________________
Subject: Weld-on 10 & crazing
Date: Sep 10, 2008
Well folks I'm not a happy camper=2C Just finished installing my windshield with Weld-on 10=2C and there is craz ing where some clamps were on the sides=2C photo & details below. So here a re my questions: 1: How common is crazing at the glue joint? 1: If left as is will the crazing run across the window? 2: Is there anything (other than replacement) that will keep it from creepi ng? The crazing is small and can easily be hidden as long as it doesn't kee p creeping. The fine print: I have installed all the other windows with no problems usi ng foam blocks and straps to clamp it in place. The windshield was install ed at 80 degrees. Main pressure was from a strap & foam blocks with additio nal clamps on sides (the area of the crazing.) Only rubbing alcohol was use d for cleaning. Edges sanded completely smooth with no nick or scratches. T he gluing surfaces were roughed up with 240 grit sand paper. The crazing was noticed 1 1/2 hours after I started the gluing process. At which time I removed the side clamps. And called Scott at Van's=2C he has r equested pictures. Any help or suggestion would be appreciated=2C Vern Smith (#324 finishing sort of) _________________________________________________________________ See how Windows Mobile brings your life together=97at home=2C work=2C or on the go. /9j/4QbSRXhpZgAASUkqAAgAAAALAA4BAgAgAAAAngAAAA8BAgAPAAAAvgAAABABAgALAAAAzgAA ABoBBQABAAAA2gAAABsBBQABAAAA4gAAACgBAwABAAAAAgAAADEBAgATAAAA6gAAADIBAgAUAAAA /gAAABMCAwABAAAAAgAAABQCBQAGAAAAEgEAAGmHBAABAAAAQgEAAAAAAADHZJXGbJXGbwAAAABL T05JQ0EgTUlOT0xUQSBESUdJVEFMIENBTUVSQSAgAEtPTklDQSBNSU5PTFRBAABEaU1BR0UgWjEw AABIAAAAAQAAAEgAAAABAAAARGlNQUdFIFoxMCBWZXIxLjAwAAAyMDA4OjA5OjEwIDE2OjQ2OjEw AAAAAAABAAAA/wAAAAEAAACAAAAAAQAAAP8AAAABAAAAgAAAAAEAAAD/AAAAAQAAACMAmoIFAAEA AAA0AwAAnYIFAAEAAAA8AwAAIogDAAEAAAACAAAAJ4gDAAEAAADIAAAAAJAHAAQAAAAwMjIwA5AC ABQAAADsAgAABJACABQAAAAAAwAAAZEHAAQAAAABAgMAA5IKAAEAAAAUAwAABJIKAAEAAAAcAwAA BZIFAAEAAAAkAwAAB5IDAAEAAAAFAAAACJIDAAEAAAAAAAAACZIDAAEAAAAQAAAACpIFAAEAAAAs AwAAFJIDAAQAAAC6BgAAfJIHAPgCAABEAwAAhpIHAH0AAAA8BgAAAKAHAAQAAAAwMTAwAaADAAEA AAABAAAAAqAEAAEAAAAgAwAAA6AEAAEAAABYAgAAAKMHAAEAAAADAAAAAaMHAAEAAAABAAAAAaQD AAEAAAAAAAAAAqQDAAEAAAAAAAAAA6QDAAEAAAAAAAAABKQFAAEAAADCBgAABaQDAAEAAAAkAAAA BqQDAAEAAAAAAAAAB6QDAAEAAAABAAAACKQDAAEAAAAAAAAACaQDAAEAAAAAAAAACqQDAAEAAAAA AAAADKQDAAEAAAABAAAAAAAAADIwMDg6MDk6MTAgMTY6NDY6MTAAMjAwODowOToxMCAxNjo0Njox MAD3////CgAAAAAAAAAKAAAATwEAAGQAAAA8AAAACgAAAAoAAAAyAAAAIAAAAAoAAAALAAAABwAE AAAATUxZMIgABAABAAAAPTgAAIkABAABAAAAq3AAAAABBAABAAAAAAAAAAEBBAABAAAAAAAAAAIB BAABAAAAAgAAAAMBBAABAAAAAQAAAAQBCgABAAAADAUAAAUBBAABAAAAAAAAAAYBBAABAAAAAAAA AAAPBwBmAgAA+AQAAAAAAAAAAAAACgAAAADqAgQCGgAAAAD/AAABGWESMQAAglcAAARnAARNqgAI m1QAAqXyAAFS2AAC9mwBRQHhAMgAIAAAAAAAAI46AHEhTAAAAAAhGwAAAAAAAAAAAAAAQAAAPgYA AEgCGOgMfwBxAAAAkwBjAF0AqoJXAAAAAAAAEDUAZABnEFcABAAAAAAAAAAAEREREQHbA78D4gHl AgABZAGKAgQBAXBVAAIDUgAkAA0AJAANABoABgABABQAAAAIAAAAIAABAAAAxgFuAhYCvQNkDw8A 6gIEAhoAAAZPB1IAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiIgBABBa EABZAAAAAAAAAAAAAAAAAAAAAAAAQBDZEAEQ2QAMAhgBAAG1Ae4BmQGSAW0QWhIAAAABAAEAAQAB AAEAAQgBQAHiAc4BnwFFAQ4BAwEPAX0CmQG1Ae4BmQGSAW0AAAAAAAACpQN6AtcC1AJ2AAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHd3d3cdIR0hHSEPHg0WJgAs AEYAAAGdAAIAAAAyC7FLEY0AZBAjAGMfIR0gAZQBSQEMAfdkABwpABgA+wFkAYoQIygcAkYCEgBu BAkCBAABmZAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANUw JCACEAIAAAAABIAEOwAACVoAAAAADL///wAACS8AAhACFIAIJwAACOkAAhAAHL///wAACK4AAhAC JIABLgAACIUAAhAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAAIANYApABLAEAAAAAZAAAAP/bAIQAAgICAgICAgICAgIC AgICAgICAgICAgICAgIDAwMDAwMDAwMEBQQDBAUEAwMEBgQFBQUGBgYDBAYHBgYHBQYGBQECAgIC AgICAgICBQMDAwUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUF BQUF/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLAQADAQEBAQEBAQEBAAAAAAAAAQID BAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHw JDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6 g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk 5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKR obHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hp anN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgCWAMgAwEhAAIRAQMRAf/aAAwDAQACEQMRAD8A /fuiptqAtFUAUUAFFABRQAUUnsBFIPlPtzXy58cZV8u3QkACSI8Y4O8evSvnc7so4dd6kP8A0pHr ZMv9tVuif5HV/C1B9jt+P4Vye5xgV74vQfQV7tNWbPMn8XYWitiAooAKKACigAooAKKACigAooAK KACigBKKm+oC0VQFHUSVtJio5VeBXjnxJjil8MtujGWQ+3JB/wAa8zH3SqNfyndgv4kLae8j8/8A 4kWLyafZ3to67RHGsqMucBVWNjx7lefcV89XKuNygAHtxxn1z/nrXzdaEXXnLms5PXtv0PsE26XK 4pWSX4mBNazlmYEr0AUHp2J5/GohaTAjLcjp94Dv1H5VrCNNQaf2tH/XyRm6kknHl20/T7gWFkwp Zjg8bSRjHPfqOQaXbt45xkck9vw+tK0NY8tlbp+H5CTXuPsNGepHGOvRepIIx0poAGNowMn5lBGc cdBxWUVJSi1/T1vYmSduVLRf8D/L7yGQHBI+U5HXkHn6d85qIgcLxjAwOcDvx+dNNWkpLdpen9Mp WWvfT8/1EXqckcZ9iDn07dqjxz91gpGc42g9ue+OfWqfyS/HTZfeP3oxWlrav02f36feNAAPC49h wvPQA1KSVGcEZJ6Dlc/zPPFLlV0tGt99bXVvX/gGaUk79F/SG7ecA7eucdMDjFLgLj6d+QF9f8ii StKUUmr7fp82VzSvy2207f1oxYwA2AAAvPGc9u3atKAjHPqMA7Rk5/SqbdvcjZ7vyb3Mk3fl2s/z 0+6/5l8DHAOOgJJ6dD0H1oHYggADjHX8h249K0guVK0tPTy0/ruadU1orBnaOARjPXJwDx2+lKGx wPpnuf6j/wCtQnK6921+n9ev9aicnFWS0/J/5DSMZXoT0J4xge3A5NKCeeMDqTjGT149O/X61EIO MeZvoYtTtddf0EAH055zkD9Kf0PZeMEgYx+H+e1Gyi1GzXXy3sbJ+z5U1f0++4KRk9O59BnPt+dO U468Mc9uc9Tz/nrVvqr/AIdNRdVdW/X+vysAIB4x16HkfX9aDngjGR6DgdRS5VpJR9OnT+vvCTab XKOBHfueuGzn05/GnDjHUEkDp1A7DP41UX7KKUVytPT8f0uQ+iSt+fl99h3UELnpkZwSCPX9aiY+ nAPKjBBzyeaEuWS1/ruJ6XaVmVJPLBOflbJ45GODjoa5zVCiBQAMjkZ+Yc8fhzgfjXRBx5uSOjav f+tDNRfupxta3p/W/wAzItZCzkEDK/MGHTk8/gMH0rRfG3b0HUEYXH05rF/C1s+i/D/hzSLXKm9L XX+enroZ0hVgF6DJwuMAZyQfbkAfjWdcIfIlbjPlOTjdz8p4P5n9abja1nZpr+v0BN82j0/q36nx V4n5128XA/1oGR0BOMcY9wPU49qh0373BIDY6/KRkBjnPb29j71pjtJzjKNlZLva6V/vVvzPawTf uO1tlY7OCHMMYPysABtBxkAnGDu7/wAz71ZQSoQD8uCMrhskfNjj1GR/k14j+F8rs3pfrZ3+fXX0 PpoSkm3o0l0XXS9vy/4cuxASqzKWEmCpV8fMw5yDxx049/zgi+ScqzbFZisikAAEemB+PH59q1ox vSq01JbdNdbav77DpTimrOz3S7XTT/G2h3Wlx/ZpIisituxhgSBtLdAO3GPyr3bRIxLBEHJyqKVb kYHUduOOPxry68acMRRkly+XRLT9enU2rc31dOSs0/00OvjBiQcY9hjjAHIx16CrLSlgihwGAB28 jI7j9D+Nd0FJWm1dLT0v5dkrL8Dwqy918qtKPTv/AEvyRrQGTao2fd6A8Y9TnvzmtBUH3iOvVeeO h/HgdauKtUhBS16dF5P7zib+GMVbuxxKgZVUJHOQScj6VLFNGEPRVxx14P8AhSqLTzvb00/zT6Fx jbm1tdde3/D/AKAhAUhem7JIHv8Ap06c96nikEYGDgDGe2T68cUSaaUrX5tn2Sto/wAPvHZ3UUv+ G/r8AeRARtG09cAjuf8APpUiSFV3YAKkYxjge/6fpSfNyU4J6p2v3XmTZrbo9P67eZ+6VLX6BHrp sfl4UVV/wAKSh9AFopgFFABRR0Ahm4Q/Svkv42+Y13aImSomhLKMdNx4+nH6185nCvUwUe9WHz1P XyfTE1GukJfkei/DCPy7ODB4wuO3H0r3QdBXvQ+JnmVE4ycewtFamYUUAFFABRQAUUAFFABRQAUU AFFABRQAlFZLdjForVCKWoD/AEOYDg7Dj2NeH/FOV7bwoz9gB7Yy1eXmKXs59NF+Z3YG3tIp9/0P jLVrFLzw1dyN8yRrNg9cZ2kY9Pu/hXy1qU8Fq7FcMMnG3aSOpI9sf/Wr5rEvlqQjFWco6edn/nY+ xowvfr/V/wDgnNSavAoPyheOBuxgkcj/ADnrVGTWNmCoGVByemB/XnH5VnCNSeijyp7GclytpO+v 4Cw6gLjnG1uwA24HPY8DNE1/bWePPZVGAQS2Bt4yDnvjpWjk4KXuN26dXb+r/MFFKTipWXl3f6FQ a/o33TdQr0JBkUgE4Hb6/r61fhurC6jDW08b7gDhHBIOcDofYVlDERqT5VScWvWy/q4nBqEuV2Wv X+ttSKXAbC4IGMAEjPY/5HvVfIwcDb7g84ODznpW9O8VG3Tp1/pP82Zp8ul/TyGnd0Iwc5YYC/XP pTGPRcnGM/KwULwT2/KiSju42TfT0/DqWpS08v8AMB93jKkcen60hLdjx69GGMdj06VNrpOL5baL +uiX5WBL3fcbSdvLrchKvnKttyAQo24GOOf0/KrGWCgMO2OSOx/xHp61ai709bNafPa69HbTuTrZ 2W2/37oVCQcjC+uCOCOfxrUt1JHHO0DBDAEA84x09a2XLGDurO1v+D5X1Cy5bcr0X9P9fUvD5Bjg AD2GegGKBjg9CevJGDjP9ahuz5krr+v6+RCTiuVK1rfL+v6YgGMkDOOCSSP6U3OMYwOScE9854/z 3q1Jp81+Wz/B/wBIppa8qt/X/AEVgPrkHaeink+n9aduTACnGSRwQM9+lTd26WTa+/z6CUNLrTX8 xofnHQ5PfGTjHT64p27CjGRnnkkDP4fjT0svd9PuE9Nnq7v0HA8AfdAOccH6GjJBPBGPmPPX/wCt /wDXpRsr+en+f+fyFG9nprpb7mKG+U49OSP4T+eacDzu6YLewHT8xTfxb6La2n9dR2futvbRfjp+ Yqk9gMYO0dOp96k3DlOAw+XBPQY68dO1Ckru+lvz2f8AXmCTvJbLSxGA2R82AMen07Ux3IHTpjjc FI6noPTNaNQj7v8AXkvIiV09dEv6t+ZmXKB2OcrjOPm+h6VzWpFlA5DbQ3fnGP8APari0opKVmlp 5f1uTeV3povw1/4Bn2f+t4z8uc44xnHXPXvxyPxrUZsAA4AXjHK7QT9PcfhUycuZqDtby76hBJRW nnbdrr/kVyp7A47ZJCgE+o/wqjdK3kSADb8jYAI6YPH5UU3bpdJ69+v6G0YpfE9H0W+y/Q+HPFIV fEF6SQP9IB2hsZIA4wOeoB6+vtiKzDkgxjaVwxBO3B6gc/QfhWuZ8vtakOnKvK+i/LX70elhNFZS 1X9fI7qz8wxQHtsGGwABg+/HTB6c4q6QHJ2kq6nGT0HCn23dR0/Ovn9INci5rWXb3dbtefr3PpaT 92Eo6tR0e2/+ZZi4GFXBKndjJOQOoHXsfyHpV63s0ljLrhiXbgsCQemc9AeDgdq0pf7POyad/v1v p5Le730HUjJJu9mrO3XXz6a6nR6FEba4RZ2UoPus+f3YJwB15Pb869k0m5e2njUozJtXBBIUrxj0 Ht79K4sTFOtUp09G1eHRJrdfr6HVUlH2NJT91SVvR62/z+R6BHJlVdCGx2U8DA5/lmrVuiOVcoMb scDHP4V0UFKNOLlone/z/wCD+p8/V5ryj2f4X/yRrJPltinhTxkcrn9Pzq6jMhHRlIPTIweRz6df 1/Gt1Bpt7SVvyuc/Ivh72Xqtv1+4VpBtZym3yznC9GAGefbNOgZJUymNh+XaARt459qGpcsbd7XX R7r87F8mtuy19H/kyYqVheKNzkqwBLAMGPPYD0rNi+0worz4AVsFemV5wfrTioVIShF8rUlbtZp3 f3/kKEnGUk1fa3z0f5lgkmdWB2p1IHyjPH/1uDVoTFJAuBsbOM989hiod+TngrSUfxTLUXdJRs1d flY/eCiv0DbyPysWkptgLSU+1gFopgFFABRQBXn4jb6fSvkD4wXUg1qzjQ4IuYh6cc/4181m9vrG XxvZOrE9nJlariJbctOR658N1/0SA4wcKSBkZPXP617UOgr3qPU8qr8cn3ForczCigAooAKKACig AooAKKACigAooAKKAGnigVzv4rDFFLW0dkIo6gdtpKemB9K+d/jjdm1+H9/KvytDAZgw/hKOrfl/ jXlZk7Qq200X5noZel7an/i/Q+V/Bmo2eqeF9SE7Axz7129MFcZP0r5G1fTbSC8ukh3CJZ5Qg6qF 3EKfbivm513zxpKmr8v9W9WfYKEo80o7f1076HNPplsrH5R8wPG3G4fUHrzTBZQAFdq9T8uPUdvS ul1J76bdvx/IxcNVK/Knr+v+bGeTFHnYu3B6jIIU/wAuueKzNS09b6Foi2CVzn7p749+uOKTmlra 9rar5f16WM7bqLsn+H9O5wFx4UlDkxsVwTz36jpn371r6RY3NgUUszKMY64JyeePz/zx0zhCpFOC 5drdHtt/W4JOFrLt6f1ax1YldUG7PG08FSdvpUZu1B2+WQvTkEDBI44/KuPklqoPlt5bvTr00NLN aRWrtr+bHhwwBTjgjGNuO/6UE4HTbtJGBjJGDzz0HrUqLpu1rb6/NWXp5js0nFRtrv32f+Yq8AZ6 4xjnj/OB/nqhDDkbgQSScdQR3/PpVz5VdPp8rr+vyYr2vGOn9ahuIxjOSMdOAQfalwylTjHbJyCu cDjuep/zipXNzcqdr3S9dLf5/Ji8rW2/K3/BJYwM8LtKjONowQT/AId61IEIBI/DbwMk+v61o0ml B6/h5r8w/wAWj/zRcIGAOx46HB9sfSm5O4bTwOf5flQ1Zrql/ViL3Td7N9uwwuvGOMKd3ODkd/z7 1CzgLjngnIAORjGabk1y3W13fpa7/UdneN+l9du3boRGbjqAMZ9MHHH+frSecOecfe45XkehOOf8 /ROyuorZ/jpf+vn1NHTUbxS16v8Ar5gJdmCBg469x27fUVKs2CB8wx3HHH1xUe0grSUt9vT/AIcS jGPLG1r2/PUmjkXHoD93IIAx0HtU4IyMnGM8E+vA6mqVpXvdX/r9Pl1MnHW+yXyD8CORgYABBzjv TiRgZDqPQdB/n+tW1O6ilawNuLStbuNJIGVGCBkKTx6fiCaUvt/hAIOfvc/5/wAKJWitNHe39ff+ ROiT9dPUiN0q/KwYdexwGIGOn+eRULyDJOenYjBA+g9aIQnduWkb6d/JW6fpcHF/C11t/XrrYpyA tjGVxgKSDk9hggf5/WsDUk2qvJHfC8dOCQD9f5VreOitZrVr5/53MZNRdvT8d2/l+pTsx84IA3cA HGOnqe3X9a0GTg9t3sVz3PfNCTTmr2urem33Di1py6dHp6/pp6ldhwqgEEZG7g4A7eo/+tVS5U/Z pOSCsb/KD0496UG41FK3y9V1/P5mkW4t3sk/vPhHxdFI+u6kYyPME4Cg8ZyATx+GfwFM0wSIgYt9 0qHHA559OvT3P5115iqcmrvlei26WX6np5an7Xm2T6P8f8zvLX5LaCQKQMqACpwCc56Dt+I4P0N1 CBKsnA3EEkHGcHjAx1I4AP58ivmpydJOV1ta3o9/u0/4J9RCyiopctvuvbT5b/cXAxVwMt/dUAA8 c8HnHqSPx4qZC6qxhfyju68REnHB45ycfXGK1pQineqtHy3t0329ddupUo/yqz0flpuvy+7Q6rRw 22L7Tld5PKkHbkjAPp1YY9/rXu+jW8Pk24LK5C8FmAYD0z255xXDUnCjKglG6d2u68vxHXi3QhK2 mmnXb/gnWxYhdBsARsgpwPTnj8K1YQF+6MY4Axx39On1rpScNUvdev8AX32PHrQioNLt939Xfy1L UMGJC2cE4YrkA9MZ46dBVmVCu0o5JYAFQVXaRxkZHvXSk23zdYvy9P68jli+VU1bVffqLaxsSd+S vIHJ6H1/Dv71dihjhDqAAGwTgYGc9h6/4Cslz01UjGWi1t6aWNJJ86a0/r/hvTcckYRiq4xydzcA ZP8AgadLGJcoM4IPTkfTjp1p+097SOq120vvvt3EvdUXLzVyNoSkZji64GBjGB29+1PFs0sah1IZ CGU+hH9a1i1pO1nF/LVa/ePnSTSdndPz8z93qK+5Py4KKACiqv8AgIWko6oBaShvWwC0U+gFS6OI m7cH+VfG3xUxN4os1XO4XJwuDg4AGc9OCelfOZn/AL5lqWn71HsZS+VY2Xamz3n4ewFLO3O3b8o4 xjHSvW696krX6Hl1PidtAorYzCigAooAKKACigAooAKKACigAooAKKAGNSKf89K5paTAeKWtobeg FDUtv2Obcdq7Tk9MV8s/Hu7/AOKF1G3gZJUltzG2XQGLcR2PUV4ec1adOnNSqKDaSu/X+keplcG6 8LLZ9PQ/NDTfHep+G4bnSkiaS3kMiK6uQYy+ASOD2BHbqPwxZ7yO4ZpV4DtkggcE9f5+9fLwjOGI qVPsv4elrdPmz7SpOHJy047b+WhSZFBOCMKTgZxnv9f0qmZoQ2xnVSBwCQO/9K7VOHf19e33HA07 Nd/y1K0m35QDxkcLgZ9CfTnvUW8c8AYOfc59PSri7tu3Xe1v61/QFDlSTjqn6ab/AKkTDGBjsuCM 8Hv09QahbYP4cc4II+7kY49a0b5UrK1rWt2/4Ape61KPu8y0QzIABAxgYwCOAcDt/L3poYdgMg5G eOB/I8/pWaU7uaXu/d1t/XkEL8tm2v6/4A3ocDCEfMGwB/L600McZxgkggZIBzwR7f56U9Ze/wA2 lnoxq9tX8PTv6/eOLH+7x2Py4bv+dPUnGOgyRtB5Kg9WGPXis4tupFJ6N79rp/mPrePT/L+rknls QTjk9D0pwRs8Z6YOBgAegx781vpzcklZx/N6fhcU0rpJ2X5D0Qqe/BGOSQBzjPtWnD8uDgei9OBw TTcb30tZ+mu34P79yXDWSva1vl/WhKzbeMgdD8uCM/T+nFQtIeSuBjsOOv8AXn9ay1s/es/+CxKm r+702IGmHcYx1OfXHeqxlGTtBx7ehzk8VLaUXDst1v3f4m8Irkavbby/rp9xWMpHC5GGJHXp3/Wk 3c8EZGScgjI/ycVXtPdV+rdvz/z+RduVzlb3bfj/AMC9xQ/8Izn5erY5znk44qYP0/h6ZHGMH3ob jdRSuuiXT+v1J5OSNrXb1/4Hl0LcbkYGTnDHb0OfT0q/GzDAA7Yx0P8Ah+ZqpuKdk7X8vL+rmc0o 6LRroWQnHqPU/eA/yTTthUcDbjoAMY/X/Oa0i3aL7d/67ERslrpo/wCv6+RCwxk428Y4Iyfz5H1q AnkFfU/8B7jt05H6Ur8qfTsvPTYhQTTjHQQ4yMkDBGD0z68+tQE4PQAcdTjrnHSnBqy03/X8rfoD fLJtJ2W3r/mV3B/vqCqDpwAe556dDxXOX0kofZIqlMZBXIBJyPp0HaqgryUYuzh36rXf57GVlzJO KV/w33I7MISQMkbjkBSoBOfw9q1CVCsB0IwoK546dT0/+vSbvzOKtt1Gnqm7q5WCrnp8uML2OT9K oXxX7NPhm/1TjJHOAD7/AOc1UPjTim/w/wCHNJW5YtLV/wCWuh8JeJpNuu35XHzSkHruB65H/wCu q1gSjbnU7hgpsBA9T069a6Mf7tScr2aUfTVL/P7z0cLF3pqWtt7emn5anolrIv2GB8KCp57A8cAf n3x+tWV+aRI/lXsoG449OSB9fy7nj56XLyKLdnFz0fVX3/rv5H0tN+7B27/c1/wfxLUmN3yYzwCf m2kE8cDHJHT6/WrbxtsTduAxtRs/dIGBwMHsevHPUmqoO3sqdubm6W7JO39apGk7U4xdtG1r91vv 0R0OkzOjLG2CCwdSDnL87h+PzHgenvXuGhXUarbNnauPmJHKnB49Dz3rz8TDkrR6xXTzfb+up0Tp L2SSdmktPPX9bHeoY2QsuBx8uRkEcf4/jmti2UeWCB1H047cD867KU48sLQslp/X36ngVYqPNG1l 5bpjsyiUKwULjKt0z75HXj3q3Iu5UwxBGARyMH6jrW9lBRerSVvS/f0f4GDj7q5Y/wCaI4pChdMs ShyFAIyPfPb8KunM8ZCHHQ4BAI9KE/ZuMnHTT8e/zuW0+V33jb16/wDBuWYwiptfOQDzjBBx0/z6 1BE0iyEY2qDhcHtjnr/Om1FU+SOl9V5dLfqJpN6aX7bLT+n8y8kgUMBjPJIGABx+VZR1X/THtsFW GCACc4OBkD/D1pSUo0qsottRV7d7WvovLUUIQc1FO1r/ADaW33a/I/euivvj8vCigAooAKKACjFV bbpYQtJTegFO7wIj9DXx746iN34ytI9pws0pDDBAOVHP6187j482Y5XFaL2jf3RZ62W6Ucwe1qbP pTwZbeVYw8DhAQcYNd3Xv01ZPoeU9worQQUUAFFABRQAUUAFFABRQAUUAFFABRQA0jiowa5quk0A 8U6tKb0Gcv4vNyug3zWksUEyRMwaVWZcAc9CMGvy5+J/iLWL6+k02/1RGiiAJiido4C2c5IJz+fq K+P4ijQli8N7WpotVHZddX/W59Pw8vdruMbSWl/Xt8jwG8sImJYbGHJBHA54rmrqERq+35SoLBOg J6E8fjXMpwlZxndJLT8j3J3tflt/wdLnLJNeQz/JEwRGBGSVUKew/KnTx3Mz71bac9MEZ69Pz9K2 9jqm5JW17f0zCU1e/wDL/mW4kkVcO3Y57YPpx708lcggZCgY5PIOQRg8VbvFQpxWi1v23+/qn5Ey cPdtpf8Ay/4P3DWzkADpkHBHXPHI7f40wnoB0GQRkZVTx/njtUpOL5VJdr76f1pcUXHlSaslov6+ REcdeFXPA468jkDtzTCBxgjCnBBwTj0ptvWMY+6tvXyE/dbg3aP9f18yLcwAC9hjHOPXH5H9aORw CQOuBxgf480uVLl5dNb/AOfy0ZWqS020+XX120AydVAxxtwB6Dpj6g0huFg5Y/KOm3ngj/Gm+WPu 811bbrrt9wOLukn5dujvr/WpDJr8Eanj7vAA284z6fjSQeI7aUhQm056fJzjg9D15P6/hyzVW/Nz ctnd38+/ote4lGyet76feupqxX0co4O3qcZHP1A6da0Ipx6dOQen0HT1+ldMJRk4ScnZdtrv/h0/ kEuivy3/AK3BpcA7eqjIUEA9OmKqNM3HIGcEgYGMdsfgKJNWil7r19PLUqDcW+WOvT+u5A75bGfT PAB7AZzwKiLZyvy8fdzwBj6du/Ws3Hbl3XXzd/l5/cVTdny7W089/wDIaTgjAyvA+X5cZx6fT8qC 442gjjjOBjBHv04/zitFBv3XsrP7un/DGiuk9f8AP+r/ANbCq5BC/dPrjsBk4PQd+eKeDjPzYCkH GduOvpwKTXK1bRaP77/18iU53TatrZItwNyvzbRnjpxyOT6f4VvwNAqqZHVAMEtnqfr/AJ7UnU5L vqvT7v008wktUktV99rlo6lp0YUefEqjqdwX09D9frTW1TS248+PoBnePX9OtYPGR52nZWv87/qR 7O3O+W1tiGSeykQ+W8ZDD5QrAsTjv/Ks1nUHCkcfdweNp4OO/vXZTxFOUXdWtbT+vIzS9lry/wDD /wDDiKyYOPlB46gnI5x9eelBxjjH1BByBx1HFaRlqotfC99rpmTTWre7KsuPTjsAccg1z+p468jB wB1HPQgdQPb2zWlNONVNq0er7eX4owqL4pbN/nf9blXTzgnLDAz2HXGSfUD5s5q60nbIHJPUHA7c /wBfpWMVaUrK0dL/AIfoaLm5V7uy1+VtBnmHJC9VAxjGf8/596oXY320wHynY47AgbTk8fz963hL klBPS8l92q/r1Ku+ZW0tb+l/kfDviNgddv1ZQpSUBdoAIbGTgY9/bmqFqmVBXG/ggc7gQQcAjjvW +MlJVaqdmvdt92v3Hq4O3u3VtPyT1OzsnkS1jDH++cLkdCM9flPJPPtjtWnG7earMeFJG3ay5Gen TGPu818/Wio3erd38v8AgW19T6XDOKjFRjtp96vc0ZZiNpOAVB2gAAhcfLkAcn8+1TrcXAUrjMcZ OVyobgkZGBg8Yz9cdOiw0WlFRqW5W3fy6fjobNeyi481r623Xr97Or0pGaOOZU+ZWKupBQNkkhsY wO3/AOviva9DRRFEnlgRMnysRzkL3JPPrn2+prmrtRcJXs1fyu90vu3+ZdaUfZThLS9tV3tv96as dpApVkQYxkdxjbjPH0xwBW2GaJAYvoU+XoThuAewOf8A9da023WpwirJrr0euv8AXfzPEqytH+XX /It72WFW2dsnjkKTx39P5UBndMkcA/L/APq7dM1vGL5byfy/rYxjFQW/M1fyWj/IntxyOvAAHZse metW7eMLKChZTuzjAUD/ADx+VNKSp1LvSP5a/f8A8OZtuLfkr/K7/wCCaUiZH908/hzxyPY+naqD BwGx/CCQMAE+xHHrWjty04c2i0/r+vzFCT97oun9emhPE5KDKhVwCoKgYA/z/Kqr28Jm+0MqiRQc ZGDkcgfpWcJzpxlFWaV00uzSuvXf7wSXPGUHa2qZ+8tFfen5gFFJaaAFFP8AQAooAKKL9gCihvQD OvziJu2FNfLWo232rxkrf3WlPtnfjp+FeJXjfM8D5OX/AKSz08C7YXHW0vG34n0x4fhENkmB/CK3 69yGx5j3CirEFFABRQAUUAFFABRQAUUAFFABRQAUUAIarnKnAFc1ZbdAJB2qTHaimtLbXGeefEbS ZL3w3qLRale2LR2sxxbSRosnynhgyn9CK/D74iR6t/wkupILi5lCTtGrNM+8qAACcHrx2r5fOcJQ ni4Q9nefLe/l27H1OQ1ZQoVYxSST363tff8AA42wGsQzZBlK5HLTSsGHQj5iRXUFpGALry2QxwvH HPXmuJ0IUXFwdlpppvp+p7E56WfXRd/66/cVZI1U4+XPPtnPT6iqUkiRdto64O1Tz1xmt4XafV6W 6GXaPV/1f+ur8xhkBVQPlx0CqcYOcD9fWoTgZ2qD0BC5GOvbsf8AGlzyU0opK+/lr+r6ehL3ulay 6fK36DgVAO/5cbeOB15Hb1o8y1IH7xR053AEE9+fpRKcqXJdLTTT0v8Apb1sFp2iorR/f/X6jCYG X5WXK/dIbA4OB07dqqnA+XCjk9M4AznPHehSdpTTte9rLts/u19RNWlzNWvYb0H94Ag5AGcj26Zz 9OtIc7u+7B+6D7c46H6UtlFXa7fcLmfWO3+a/X8BvYdORkehz29xyfyqKSLzQVZQOeMdwc4xgcf/ AFqd3zxt02/J/wBeZTabS2/4Omn4mLNo8JDMMrkDoT6Z+mOc/jWWPD/lkMjMnB+6SFyeegPvXRyp px2j+PX/ADXqRyyWsVbXv95tWdrLbY3NuOec5IHr9O/61rpMy8YJGFxtx79vx/SsvZ8qtFJJdf68 7IqK5d9Ent33LIucjrxyvIxgcgdBmkLqxHUDHGOCPw/Ks4xsmmrNJ/rv+BcVy8tlyu2v5/loBbbn YDzgKMEDOex9OaQFcAAbSMAYOD9c+vX/ADxTkoe6o7PX8O4oz5ddlrb/AIIEDlsEHHyjGOOAeBx3 xRjqFBUdvlHHXv2Hemrx5Xtrb1XUtTS5W3a//DL59ReQAFAPTvjp9Onel5ByAOo44x78fj+tOENf ZpfF3012sQpJap9OvzQSEoDsK4xnjqPUVyGq3l8SyR+Yc5IUMwHuF/8ArVUaPtJuV7KOq076W/Mn mcXfZ29Ohx7RX7EM2/PDbiWXaP4uCeM4J/GpIUu4SrBZGGMbd2Dxjrk9fp1rb6vTcZJR97Xot3a3 4GftnZqLvbp3Z1emXd3DIu6PCNtU9Tgkjp36+td1BI7oOGA/AcdeBiuVUvZSavbf77Wt+KGm7Nz9 3tbYvrtwdq8c9iPz9u9OGBggHpjg4x6DI+tbxTj7uzX6om791/1fr+pUn7/w59unIzj/ACK5m/B7 5wMbQDjB9c/561vGEb2eqX3N9P6/yMKul0la3Tv5fkVrJlC9RkEheoIHse1WySB7HJxuwcDkdee9 ZJW0Wl+nRaX/AAZqkoR2s3+vQg3kOQowvI745A7/AP6utRTuPss3XHlyHJONpPr7UNODi0ru3y/r /gD5mm9LWV/mj4g8UsR4g1AfdLS7cZUdQM45z19frxVO0YA9thwM4wq88EkflW2Ycz53y25Uv0t+ qPSwlV/u5OKv/ntf5M7K1A8ghV5ycEEAgZVskdh09emMVaK7fLKKQo+VlJJ/H24yfzx7+BO0pOCe stPJOX+d7fez6bDq1uV7/qlrbvuvuReidCgcAffww2gbc4+9njrx/wDWyauDzIoJGSL5c8FcIwYn A6cdz0z1rTCpXjG3K07X7WTX6X9Wi6y91yWnf13X3o7Tw80hg2kkGRsAkbcE9fvc4x0/PvXuejIY oLdDtDKoVwRgkHPXH0xXHVcIVn3bb220sl5Pb8TWu7UUlGzevzWn5NnXJChVeGQA7l2sPT0HWt61 KIhjc4fqo2gHB7j9PzFdMJv3anLrCz1007Hgycrrm0V/xuSyYMZC5YqASoA4xkAHnHGarW10JUaI qPMXuFwpOTjP4c8VVWPuqcY2Sav5J9Px+SIhrGUeq18rf8FuxoW6x5yRnGOvGAOeR9cH8a17OF2O SDhemcZz/LFNtpWvaK/4e34oicr7e6knp8/+HFui6OcnCkYxnADf5IqpCrtksANvPHTmtai1TUbP Tb5X/QUI8tONo62/W49CoY7QcKDnOCFOP/rU6WNO57554+tQr80tNOv4P8i9lCKX/DP9dj926K++ Py4KKS3tsAUULy0AbnBxj6dqdUwe67AFFWAUlS9EBlah/qX7fIfYdK+ctOCXHjGeM9Uyyqf99hxX jVH/AMKmDXlP8j0sJ7uDxnkl+Z9K6dH5VrGuMcCr9e7HRI8wKKoAooAKKACigAooAKKACigAooAK KACigAqCTjFY1lp6AIh7f/WqYVlSeoHM+MPK/wCEf1FJh+7NtLkdM/KeK/Gz4gy6NB4j1MGWCNVu DgGRc4wDk557/pXzee1XSxdNpW0tfrt/lc+nyCnzUsRppdf1+nzPP5b/AEhQdjR5XJ+U5yPbH+ea zZbu1nB8k/KVI3BSpBx9P8/hXk06rn7O8NL69NtT3pUlaUe9v68rmJOkzSKUIHXAyQAvBP4/570g RihDrnAwAQAOMg/1rshCEVdbO1+69O3r/mYWXLJRW34f1YayKMhVIAHHXIO7PPH+eKi3pwuSTnBG Bw2PbA9hmj3kou6v1t69vKwKL5XKL0/r+vuK1zG7IwU7eCQV4wcY49ev61ylxp98DuSQBSWJJXGC Tgcd+O/6euiSlNe0Xuv79lZW+9+pHvRkorS1l+OunyLFql9FtVx8gO3PQdieK3E3YAbIPTcTjp1H P+etZuChzJT9P8v6/UHppGNra/1+hLleuz5gCoxgDGehxzmpI4920A4GSc8cHj8qFooqWt/xfYHy 3jpsrfnb7yX7Kv3hxgHjtnnGcH9c0ot1AGduVJ6YAwOAent+lLnSSjtJP+vX9BKMrxXLoreX9f5F eSPr8o6gLnHvzgdOv86rNndjHTHAGMjvwB+tOW0+V2b29QlGV5R2XTp/W5GCBj+EBuQOOOhx+X60 wnnKgrtII9h6/wA+vvVxuot3umlp+X463HGLS7tLX/g/MbuPJXHUAhQTj3qZZdpUHg4XBxkE/hx0 7VNt+XW9tOrtp/VxSau2pW/rsTBz93A4IIAPXp0ycdf51IMbsY7MOeuCeegz6UL4lpZR0dvL/gWI d01GOvLf8L3FYjHClSA+3bzwOOSP5UoB4BHQkjHGMHjp64pVItRWt+V7edwV4pLf/g/8OLkDpwFy Mgjrg9cfX2pVCqRgEDOBnkAjA/Pof/11qlGzk3oktPNlxvzcummtvK/+Yh29NoAzjv0xkZ/T86ge 2jkwdoXuARjrnOR2p03ZN7aX7aehno7tbr+vy/MgOnw45UbVxwRngZPGTg9u3NJ/ZcW4nHC4wAAO PTHfua09taMXF9ktdvL1FFKFlGO1187pluKwijUDZtAOQeNv0z/n/DQjjCkKoIAyMA8en5d/885S lOTTWn+a/UdpWd1p+F/6sWFJGB90jAPXjp+v1qbGMD3x1JC5x2z/AFpwcYy2u2+33f15kJKOnX9f 6/AqzjCscc5yAOD1x0zXLankKRnAHI9Pr3wf8B2raPWXT/gbmcl7stdynalRGT2bjBJHoT9PXNWC RuO0nGOp7dsD65H5H1qVU5efmW2n9er1Lt7q5lZPbsQ7uWKjA5IPGSf5f5FRXLbreUHkeUwC7fmH BB/OkrRcbPZq33v+vkCUur0V0/1/A+HvE5b+3r0Y4844Pr0I9/QfrUdku7AIwxGcbgoGT7dMdc/h jFduNsuZ3tbo+ui/L9Lnp4RJ2glb/M7LTztjAYgncccHgZHfp/d5Pv6Vfl6gIu0bTg7STznPPpyf fn3r562sox21s+q5df1aX4H1FKypq3uuN1+K0+7Unt9siyDG05yW5APC/nzu79unpr28UkkWY85i DB1YdG5yG6d+c4wPT0VKXJKPM1bm1b9Onzt93mVVTi4qK2/Gy7fedxoloHs0YPtdCCVB+YDvkfoR jHX1r1vSmlHkszYHC4bcrBvX8cD164rjrRpqUoxj7ycrtaOz2aNqulOPuvTX1TTv+h3FlMZgMbkI Yqdy+gPr9f51pTRMyl9wjaIggr12HGfb/wDXmuuhFXjdbXT13T/4L+R4lXT3UvNLr6F6yjPlEq4I YbuPmHI5+lQD9wwU7YxuIZh+nPY9KaknRm79bL8lp9xhH3JuNrafj/X5GrEHU8KApAOQSOfrn8Py res3VY2xxwAw7VO0NHZJL8eoVIrlkrbIoXrljmPDgHoPy4FJFIYwA2VLZzkEE/WtJybvJLWL1Xa1 vzsZ0uZRtez/AKQgPl7mJKhhyB93GPfgdKyb28kWZECyBcLgoMgeopK8puUZWi4/jpv8jSPLz049 tPXX8z99aK+/vbTax+WhRQgEpaW3kAlFJbgFLTXkAlFT0Aw9UYrDNjtGx/SvmnRJivjiRgflIwee gLN2/rXizaWb4LpZT/8ASWephV/sGMS6pfmfVttjyI8dNgxU9fQx2R5QUUwCigAooAKKACigAooA KKACigAooAKKACoJh8vT+lZVV7oES8AEdiB6VYU1zU3aYzG8QWyXWmzxOoOUOMjOK/HP44eC7G08 X3kh2WsjIrlYwsaEpmMNx3wq5rxs5lClUpykt9Pwv+R9Jw+5fvoR0/rY+e7jRHRiILhuDgAHPHGO vTv+VQ29jdW7ZMrsoODuY49OgPrivLgqNR3h7vNqvK3b8D6Kcpxi0lb+v60RojdzkD04OACMZwB+ PSmcrkDk5xgg9+p5/E8etUtLqMreb9TlTi7tK3T+vMidQVGBjHXBI57devB/SqT2w370ZwRjI7Y9 h/nvTveN5fFd2Xl309fuI+0op2v9z6D2DDAyeQQeABx9O3X/AD0rlXU8EbcH5cDHT8PpUpvXmbjb b5bfgmVPW7ta23a4oAwpbAPr0ycZP6k96YSuOPvLuGCMDjjtwT0PXv8AlT6taX6+RK5b+6rPRP8A 4HqIScnBA4JGCAw/u1j6hqclrF+7DArkkjnnHbH+Tmko89re60tPW/8AlsEZKKXf8lYy7XxLcFWj n3JwBuChQMnGR69/zrLk8S6jDcFfNl8vqdsanC5x1x3zntWTw6vyO61763/TVlOfLJKL1vb02/q/ qbtlrrXA5LYPUtheSM8Y6j9Oa1lk3YwecdAdueen86r2fL7trWuvTtb1KqSTqOzWn4en3inHUjGA Rx369/f69zSE4wFGcAYOdvH/ANb8Ka5I21aUdL+m/wB+xmnb3WrWXTuMx6EKSD0wR69u/wDh9KD3 4OVAPzHCj3/Q1ajzcnL7tnf8b/K+z8hRjaSTVrdNun6jg2NvIXBBAyTz7irCTKRgEgliARj6cdx6 0XilyLRtvrsmPRbx5X92n9fhqThxtAPIBI+Ungk9cfj+nTrSqdpGFPHQZwMHjt9T35oWis9m/mrX 0/EcXZqCVmL8o6DHPG3jJPXOOnP9aerkY64G5c559hmjSLu1309NhRer921/w/4ArcN1wQe4IPOO pA4OKcxA29uOQOh9ePofzq+VWleTVvyv0+bt6ERja9unf/gCoAijoM4OOAoA69PepVZR7EDp0BOe vXjFCjTXlvp03X3WKUYq7ctfLboreQ9TwOeeSB6nqOn1pwKgDk4I5A2j8OnFCadtLJP01aeq9NvQ Uv5Wmrt/rb9BynHAx1zjHA4wAMcj/wCvVjdgZ5BA2cAn/PWtXOKjJxVrfLSxE7rbVPrtbX/IrSsB kg8qBliwBx0rldUyCBgYz0zgk859CORWlLSTV9O3X0+X+ZzyS1Tdu3qitbfJHxgADCjoQPw/nmlk fOQM9gSDg54GPXsa5lycytL4W7fobawpqK7rX+vX72yJWGGzwD0GADg4GPU9evWqknMU4wVPlyHG ScnbjGO3HfjtVv4r8uqa/L9Ls0d7J22/yufGnitTDr95xt/eKVI4BGB0GOD7/wCTTtCRIuQQdoO0 Dns3TPPYZPHArvxajzKT2t+aSf5no4FWkmn2du2n+R1MLeUAFLMhPQjC7cgHJP09exwOmNlFUKpy FzwqlRtHQnB6r0J79MV8/Vi6b5lDW/39vxvfuj6SjFqD0utPL7ydY0+aMZRiPlGAMk5yQfXoav6f LPZ/vdoBAKlWBAIGGwRxx8vpjkVUIxlSVOdm7Ky7X1f3WW2uljacpXUXon07d/wudporzp/pWWaO Z2yqquVc7v4uuCNp9fxr2fRo5FjR87gwLhm6AjPAHpxivPrU4urKonb2jfyknb8rlV/3dJO9uX3X f70/uO0sy3mAlTGzEgg7TkjnPtx2NdAoVkOfmOACMHlTyCcV1whGKpq+2i/L/K/meHWa15Zf12+X 5Ijld7KPMKsYwRlRnjJHb06/lU8KxzASkEBhnbg5P0FaNKPLOK+O9/J3uZrl5E4vVM1oCWwuArK3 Xlcgd+nH51oLuU4EfBU89OMen4mlBSuraW79Vp1/ExT133V7fcUfK+zu7BsIxyF4ODz0/OoZMOOp 3A5GOFx6Yp1uVSc4q3No+mun+V/maJXhHuvv0WhZ8tfL5I5wCBwuDx9KzbgeW4lTkZ2MMfdweuOn aqpQjyqmtOa67a/p21CK5Kicdno/Jf1qfvfSV91+B+XBRSuAUUgCigAoFNaMAqKVtilgOg6VM3ZO 3QDntVlRrWcqRlY249OK+YNElP8AwmNx6oyj0xnOK8Cprm2EV7e7M9nCRccDi7q3w/mfXOnPus4G /wBgCr1fTx2R4rVn2CimAUUAFFABRQAUUAFFABRQAUUAFFABRQAVE44wP8Kyqr3QKRcoSvYAVZib j6dulcK0qIdrWKWrMi2j7ztUjGRxivzj/ab+HZnmt/E8KyyWrKIbgoWKpIzHn0HY5/2q4cypxqS+ G7jqj28mm6VTeylofFbafFak7SRg5xkg8Yx/hVaQhcgL7jIAAH9P/rV4MW0m46J222S8vK9z6apJ ptczTfXz/wCHKLLgAAduARjOcGq7bguVIXjkZAXjP15q01a19Nfnr/w5nqnyweuvz12Kzllz8uBj jIwRn6dTj1qu1yFyMfLwADwSSMjg804pKWm6vb5aaig+VK6tbRfLQasu85A2jnkKf9nPUdaGPoQe eOQMHqOBnv2q5c8opQsr/hra1uvmQ2ubms1fXyIznuVGMDJOCeSDjHA6j8/aoz1xgAE8ZyP933JH 8qj+Vq6uml99/wANUPRJdJN/lb+vUQ5zj7uOORg9Tz61DNbJKeRxkj5ueeMYFPVcve+n3f0/uFJR 5U77a28l/X4lI6XAOWVc5JAx7n29+n04qu+kQEk+WgXHy4B+UjjjPbGPzreNRRTm1bXTve97/n94 5JfEla1rf15fqhyWEMR+VBnBODu6HGN2P5/0q4BsGAq44AH93ucY6cc/jWblFvnk9W/ltbp6v+kT C/uPbrf06Bll7DBPTnAx7D6nmjJG7AQEZ6YC9uePp0qXC+j1W/y0/GxV7c19PP56/chjZ6D5Rn7o 9cj1H1x7igHaAc5OR6gdD0wOO5/Ciyjzea+66t/kJO7avewgzgcccHoCAoz068/4Uu7k7Rgd+MDn gAn8/wBKvkV0+jTWv4fcDTfo7P5NkyuwYHI4+8Rke/8APH51MsmeMY7AADByPx9KTjDWTvbp36FX ST+Xy2JSQADuGeT3Xseg/A8UK4wV3Kpx0IXBPH+FKL+HlVr7X7dG/ncl6J8vay/P8yUnHJI6AFQM Et9RT88cHqcEDtn27/8A66r4XrK9k9PX+vkCd3bZt/LzDnOFHGOo4x7+n5UoJJ44CgewwR056c59 OtTHlUZRjr/wd3936kaQmlCNtPv8x4OOP4shgMjaB/TqO1SYAUg7RxkrhSMHPr+HHvRJuKgo+61/ Tv8AhYatePLolff7hYyAfm3DkDHI4Ge4GMf/AKqmyASRlTuOMHkn6D6fzq4RtZPrb8/+G/ETlGyd trfoVZn2LuxnIBA2556dxj1PNcxqLhgCo2lc4BGeTnjp6fzzW8G/acyV1+K0MZWdlay0/Vv/ACK1 tGfKGQRhsDoue3pnB6496kI5x2A+boox3xke3X6Vk172sU3HS+2v9XNUleLSsl+ey/4H3FbAJIwc budqnIAPIyenYf8A6jUNySkcpBOPLf1I+5j/ABP+FJz99a7rm7W6fk3sdPs5RTlu7X8l/W33nxt4 wvFk1mcDHmCXaQNqrgKo2k9sn1NZsBZNmAV6fLwSDg9B/F1659a78S7ezjy2i19/9N/cb0JqMtrN Wv62v+djqICcbcg7cgEHgg9cAkEj6DAyPx2YmwB82GyRuwMnk5/Ut+Z9q8GqnCTpu7TendX/AOGa v3Z9NQ5pRjFrdJXvtZpv9bf5b323KoyM9HTkDaOcjIBJz/nGKsWsilGUnaS5QjAJ7fN7ccZx+J60 6LVK9SC5rP3XbXVtP7vyOiad+aOjXVeen/DHdeH5FW1eLeFTfuXI+7nHOT0PT8vxr27R3MENmGAa N1GGU55Zccfga8uTl7Zw2lzO3a9k/wDP7y8QnyvmW9k3t0OzWVYPLDDcGA2kgKARjj+n862bQNnK rhS2eoBx0/nXcrJ01eydtOi7r7z5+pHlk5cqST26ev5Fm4LKCu3uASRkAY7mmITFCrRlS4PIyPlz xj/9dauPLKCb0k7aeZMdNLaJr/gl2O4kETMqBXUZ4XnYOcVat78yoCwK5H3SACDwOe/4UpKrCFOS 1s9dfl+hnOEOa0Xa+v37/wBdyRpEI2cAdgcA9ew61RjRYWKlsqxzyeRknjp7+vFK94uMnd7rotOo 4Rkny3tf7vP9UVtRe8t4YpLZfMVZQrqNwbYTjr3xkHH+FWUKmMb0HzquVIxhvXB9803CUVSrRaV3 JNfc7/O/4GiUeWUU7SUvvTitfvuj96aSvvtOh+VBSZqG7AGaX/IoT09AIycdKB9Kzu76CH9P84pQ MVav6WGNxx/kVFJ06fh0FRLYRyetlI7O6KgL+6c8ZH8Jr5Q8OXmfGt4hOMPHjJwOleHJ/wDCzQVt qc/0Pewq/wCE7Fu38v5n2borZso/YCtevpqfwI8OWkmFFWSFFABRQAUUAFFABRQAUUAFFABRQAUU AFNIqJr3QMy6+Vsge3pTrZxnFebJ8tS2xpb92nbYp67j7GUPRsZrgdW8L6d4g8N6jpOqRJc2txC4 AccodpwR6YqZW9u3bZHXQk4UbrT3v8j8kvG3h2Tw5rd9pcmHS3nfypF6NFk7G9enB+lecS/KTxg5 7ZCgYwcH6f1r5tbVI03ZLb8T7FvmpwctHa9vyMyR2Jwuc4OM8Djrx6YP6isdjfLICoBXOOwGOB0H +f6S6Upez9635Xtb/Mh8yaST6+X3lzc2FDAo3vzwMkA/lgj3qu0alvlHHOSeDnjIGfofzrb4YvW9 738/8rhKK1sl7vd9f17+omACQqfKuf8AgOM/rVJ71InIPykZ4GAwJ7j179qiKnaUopXT/q3z/Ihx k0raJfhsPSeF1yCODk5Jzz6jHH+e/VPNiwVJXGfbJPv6jt64oWistuvZa/8ADfeUl03X+f8AwbFq NUYZLcYzknBAPJHHSpzboAuHGOQNvTpkDP0qJzjFq7+Dp37L5u5Ka1aW3+WpA8Yx8rD5eVAxwAB6 n9KpP8oAY9zzu/IAZ6VomrLX+v8Agf8ABC3KuxGdo6dBgckDaOmPr9PWozjsGHcD0PU9B7/rS5be T/K71Xpa7/4ItEmnvtbotdfxDAHQKCcnb657knnnrwfWmtkA5DZBCgj7oPbI6j9au848ytZK+nl5 D25o7+X9fd8xpBB2kDHOCB757UKQvBAwQdoGO3Qeo/GkrRXs7b6K/np+bX6FXXkv6/4b+mM3MG/3 eRjPOck8g9uT0pdzLnHbcPTkY/IDB5o5fecY/Z0+++v6mdnOfK9P0v0/FCJKv3ccjAJOcDoBU6vg 9McjaCSME9AD9MjBpNtN8y6afl/XkUklGz0f9a/mTq20c4ABxg5GBjrn8aFRfvf3QCCpJz0OBRF1 I35o2Xlpp/WoJWSajZf8MTDp0wOO+cYHY9TUvC4Kt83PXoOh4/z3pxjCDinHS936P/NdBr+ZKyTV vmPAOB9QQec+/X1pc4CnHUgMPckDHJx14/Gn1airXX3J9V52/Mlpppd/wFwBxhcjoOh9z09SKevG FHOMED5hz35+oonFRXLqm9fwv+o3Gy5e/VdP60HAsOMdATnjjORRuK59iBx1Dd/19q0jO7guWySs vnt+P5mTl7q02uv1/EpTXTxNt8lmXnLDG5QeB3ArI1DysBtu0Ec5x8p6/wCB/wDrVcU6T5m/det+ 1nt99kZNKUpJK2trfPdEVoQYgu0LtLHKnPPNPZeo+6M8k8cccDJ+hqYylZuNlB7dLfLy0O2FOy9n Fab/ANehUY4Y4HPoMf1qhdAtHNtXIEbsFAPORg8dulQpKMvaW5raelnp+n3lu3s5Sta19D4l8TSQ vr18U/1gkQsDwcYB78kc/wA6SyLNIh5UEAlQAxGD06c9M8969TGpNu+lktNV0W1tjPDOM2uXS7/L +rfI6m1kAlKOGAVTtJ5AboM4z2xzkZrfWRCASEAOGwFBz1PT06f56eDVfK3FSvdO1vndeXRn1uFl FqyVu/l0+V7osZLw7cgBQXGDk59MDp9B7806BVZTkgbSeTlfm7kgf4d++eYw6XJUjKLtffvft26p +ptK8Uknblf9f15no2jWyzW8MtuwUn5JoyuACMKVwPzyOtezaVvs47aCRWKsAVc4+U9ePSuCpTjK pL2a5ZQbut7tW/RWRvWfuSg9O3fy/rtod7GkbxpujDEYK9OOnOO1aFs7puVR+76nP3gcD06fp3rd e9Sim+V9F2t2+Vz56drycvh10+9f5fcWJd/lkcjJDIxABHcfXvVeQSJbhiTlgWYDIY4PauhrSMbX s7q39fP5kU01F3W5padI/lhZAMgcq3Uj8KkIEJLoh3Z5XkAA+/bvU09FNLRSurdnpt5ITXvNrXTR +f8AWpFdwvNBmCULIp3Dg7Qwz781BbtOu1ZkXPOHXvnBxz+PvzVyp+0hGUXy1Ic11fp5r8R03aTp T0e8Wa/mKY/mG3vyeeDnGDxVQbZBkAEpkYB4HPOR19ayi7RUuz2+W/3fmHL70rq39f8ABP3ror7/ AKH5cFNHFRLpYBR06flTfp2/DFSwIs89P/rVN+n6VMewhRRWuy2GJUEvQj/61Zy2Ecf4jGNNvDj7 sEh7f3TXxh4dnKeN9ROGG24RD0Ixgc+3cV4ihfOqf92lL8WkfQ4VL+zMXrbWP5n3R4ck3WEZ/wBk fyroq+kpfCj5+W76BRWggooAKKACigAooAKKACigAooAKKACigApDUy2YGbeqducdP8ACqVtJ834 4/GvKraVFobwV6Ul2I9dYfYjjgjBGO3Ncot4/wDZdywIGIpF9P4WGawnO1Zpfy/odOHj+422kfk/ 8XZ5f+Ew1YiNmXzVU4cMg4ByBXj1xkEkZA6fT/OK+ZpRim5R1v8A5n2ja5afLGziv+HM5xgg4JHH bBU9Twfx6etQkkJggZHRRz1JrpbvFc1tNvR9DFptWVo/1bUrvgYIU5Dc5GMdD6VXYtyB7EdOh4HI p+zsm+i8/P8AS2hDSSbtrfX5+RFlMrkgZLdRjucdM/5NRPBCxBdSSqkbhn39MZH0p2lGSSjbe35X v21C0Ul0SX3P/LoR+TEAQV+XuSvb+nvUElpFg43dCNvAHHpnj8eKqyTd0rP+vzX4iUbX5XZPb5FS 7LwQnyWO5VbIXIzgcH0z14/xrjXvtURjgzEYwMSOuB0xjsefSs1RhU51y2s7J9f6sxRlKHTS66eS /wAzW07VpwFjlWUD/bckA9wPTr29+a6SKVpFLDjcRyTkg9xgde1Q6ag7bJv/AIP3bfeXzR110v8A 0v66BwD9MknA655xj3/z6JjnIPY8E8BjgYwPfA/CtZJ2cL62flby+8bsvdWjT+Xf/geo0YAwuevI x908Dr29aYW28jg5JOCMYx6fj/8AXoptpxWz/DRf02Q1yvmtZ9f8182BJ5PQemOvIyAB/h3powOB gHIPGM5PB9+gzVNWkuZ7W/R/noSmm+Vxa0/T/MXj5hjHTI/T+tGFGMdgRwOFwcZ5/GpjdTckr637 b629Onk3c0so77aa+X/DigZx93IB74Hvn81/OlAC7SDgjG7vnoc4/wAKcnbmilZLT031v5MSScXr Z6fLf8vMeGwwUYIxyMc4yegHHf0qwsnXqPYcYHHP9KTirJpv3V389yU17ul7a9tNv1Jwyjk8AjIB yex5zn/OaUAYYewJyTjnJ7fzrR25r/F5Le72QKOqja/ktOj/AOHGlwBkKd2GO3APOeg/yOcUJL22 MPmAOQAR3HXjr396VrNTjG1vl8l6WBRer5f0/r/glhT14KjjBycY7/lU0cmChBJ5xgYHAA79u9Oz k3dbfKy8wS+KMnotfxv+LJXZCR5WVjIA2njDA9OOcdPyNN7EjhSwxjjbx/jShPmSl8LSXovP7zNR taLe3X5EE27G0DGOuQBx6E+vvXJanAxK9kG7gnBBHHGB0rZKKag1dS27fd8/xHyO6fJZpq3RDdPQ RRFVz0DFieck9O2evTHrVmSTb833TkY4CqD7YGfWs5aWVreXrp91zrg110sv+HKRbBYZGQcYx/D3 5P0qLhPN+bjY2F3YDDqQQeevHHpWSk1dRW19Ozvt52WpT5bWST0d/K3/AAEfFvju3tY/EV5NbjBn dnkUFQFOSvOOQMEd/wCmM+yO1ECqMHaq9mHUFQPwz/hXr4yTqKN1ayW2mySu/krmODpKjJqMtOnz 1/X8LHRREblZQQPvAZzjJx+HH8q3omARgCMqC6sOeSM4Jbp3xgY6evPhVqbXJ7R29Fpba3z6/cfU YaVr80HaT0Xyv+a/EntZ4yBy2VYB0bILAYBwR6Y+nAFacMRChgQQTndHwwGM8fljHufrVU48rcVo 1ezWyV+3p+VzttrTdr3unfp/V7HZeELi7hnLLvZfMIZMdOScHPTggZ9Vz7V9CadtuIItwcYwwAAA TPPBPTP9a8mp+7x8qsNYt29L26fdfyLxbjKnSnF+9G1/uuvuOziSPYuwnYFUADPXjPQ/55q9bxck qMLzgKeQfp2rrg01FW5b/mt/TW54NVOMnB7O9wnR9qLG5BQggdSD2yParb58hd4OeCMhQ24D17DH eteVc9OUVZxvf71+FjK79nGm1qn87dfy/EnhMe3emUK4yCAB2yc04v8AMWA28EAHGBnPUdP/ANdT G8o6JJrt1v1+8H7klHv+un4Dx9zghXXDNxg88ZwKaJIXUhSGZW6jGQR2IHb8utP3IL2j3i/lZ7f5 CSv8Lty6+m6FkXzAAh6AdGwPfNRwxvb7xtK7gXyCAB24H/1qbpwl8Gltlst9CuZJWve/fufvdSf5 9K+6ex+WiHik6cVF7CF4ApjHHtSeiAiB/wAKnB4pRAd/kdqK1TVuwyPJDYxx2qKbOOOPSsXpHtYF ujh/FLlNLvsHjyJB6djXyJ4YsZJvFOoTjvdlQCuMqOMY+vNeNTS/tly192k/TWSPoKFo5bV03lE+ 2vDKlbCMEY+UdsYrpa+kpfCeBLSTCitCQooAKKACigAooAKKACigAooAKKACigAopPZgUbkfIR+V YMRKyFfQkgdDXkYm6lHodWHXu1EGrkPZkH5eAa4/Vp7ay8N3k+9VZYJg+GA28EE+3XNclWpCn7WU tLR/Q6cPF+yjBK3vH5QeMGGpa7qd4LgvDPdytGXPITOFwR2wAK801CBYmIDDAPGDgdef5mvBw3s1 7OMd7arpe7Ps535GrWMUsAwGTntn1Pv+VRumQdqg8quOenOcj/PWtnG0fd2tZoxcFFNrVLVoqyqQ RkFTycKD82M8Y7f/AFqqOcbucDliOg3Dvkn86Phi3e8Xor/5fdr5GN1o46X/AMtRh2r2/vYJAyMY HTr0J/IetNIbGNu3P3Q24ZHqPTnP5Vck/eu3dNW9LdOmmzGotWvpb/hv1IyCBnnpn5eR/nmmBsHI BwCVKgcgevt3qOTRLa2nq/8AhxWd+V9P+HIZI1f5M43HgYUDGew/z0qubKBefLAO7kYByemfX2rS EpRgo7Nbrv8A1+ZU7WhGKuKLSDsuDwV+VeMAjPPA7/n9cKsfl5AYqOMjAC4xyvI69T+NTO07qUbK H9aEuKTSSv5ev9MCGGM9OT7Bs98deT+ppuNpXccAcFQBjPXFP3b8qfLfX5dV/XRMpJcsne0rfMQE ZJ5yMfLtwc5I6889f8kUjDaDgkEDPQAYH0P9KcElNJ7W2/DT77egO17WeyXo+v6jR68qeSckEckn p+GKdjgcgAc4wcj2Pp2FSnHl92NrfkxK3M1HdafJ7/h+I0YCrgjuSB3x2zSZHG0HBBGfp9Px7dqm UtVyq34NX1/DTboDjrZq3T73dfgHKknvzxuPH0/LP/6804dRg4yMj0yPqAR/9erklfa19LdLW/Du HK7txdl273FwASeQN2A2OhxwPzH6e9PQgAckAKOo75B/ngU3anHlXR9Fsney87ahLlg1/LFP73sW lkHToe+AMDP/AOv/AD3kyNw69BgEk4OensOf5UKHK4yXX815eW4Ncvs7dfPYcp2k9OD+I7/1/lTw cZ2gdwBkZ5PPHbr+FKc3J3crWvp52e3y/MTTjK0n9wN6KSOM4K8ADv8A7P5U+NSo2nqQRnGeMHIP tj8KTl2Vl/V/v2B3vvZNFoZ6L8owcfpjp+P5GlUEA4zj1xnB/pVRSTTWi0+++n+XqNJaqKtH8hki nkY+6ecnB29Sc1zeoAqGJ7DgHuuM/j1NaQ5Fu99n2vb9CW0tL69yraKfLLYc4OGG0jj6E+/TA6e9 LICBxzznkn349uxqIuKur2av+bSR0R0i2l01X6FBgVwyqTjIPOMD6DscVTuMrDIMnHlSEHDAZxnq Pu9axULS5l7t/v1vr99kTKKurO3Nd6ef69T4u8TZk1m/OT8tw2RgnOQGxk+gK0yxOE28Z4zgbSxI wccADqfr7cV7OKWsvds4pXS80v8AghhlJVbPT+v1R1EUYVFK/uwqnaVwMHrghu3U4FaEUDKpkyQW Cg4Zec4xxxg9cZ75rxpVI8qjJcrlJ6Pzb/SzR9PS5rQUdFHz18vw/MnjRMAI+0/K2QRnnqDxweB0 zn8AD0mlrHLvtyV3FSoLqcHjPIHI4HPas5uUKdSqp217bbK33P8AA61e8f5bNdvm/n/mdf4eQQGd DhZUkyOcbgCTx6cAH8fUV7fpc/7i1aNWIXBkPGUyBwP89K4K8IrENJ7u1/8AEvd289NPI0xMk6cb abX8k1+mh2kOU4DFVbHBHCkj6+4q7HK0TqoJ54x2PHGD+v8AWtIpcsfd1aXlZrd/PR/geJUjrD7v n3t+KLaBlmJ/h5JXk7uRnHqeavSkSR4TPAGB0Kgcc+ua6eflqKSdo6O/5/lZGE3zcko6OJDFKyus OP7uG2kA889OlXJA0anB3DbuDAZOfpn61Cgqc1yuyeq167f5/LUVRx0srfoytbu0xBUleMOrgg9e MA/h+tQ29i1tdySB22y8rF91VOSSQOtVyrkxFOrHa2no1ZocXKFSLUdGn809fzubAi2ZbO3BzwPr n/PFBclGUcbT6EEenp7mlFpqDtazX5f0/Izamoz00X9f12P3j6fT8sUlfdPsfmAY7UhFTYBCcdun 4VC59PrUS7ARoecAD/CrH6fpQtBtW2Hg+nH6UpPQVdxDeAeKrSngiolsxrdHCeLP+QXe9v3LdK8G 8Eadv1W8k2dbt2DAYzz/APq/KvIpJ/2pV0t+7/8Abj3YPly+St9pfkfVmkRGK2UYxx6YrXr6Kl8J 4cviYUVoSFFABRQAUUAFFABRQAUUAFFABRQAUUAFFAFacfL+dcxcjy5crwPyrysYrXOrC6Ta7mbr 0sg0qeSIgNHHu54HHrjpXwB8evinq1hoVxp+jaqLW7uj9jngghWTfESRIw352HCgb8d+nNfK5w3J U6N2lUstHZ79+h9Hk9KHvSaS5HfXbyPz8utd1mSVmea7YbjkbioHt8v41atdTuGAWYNtyD85JKn0 yf61nDDOkm2rWs7r5W3PZqLRc0umna//AA6NA3UUal2A4AznA57HHGKoP4ls4soFyRnptGCM857V U7xUOV+6tH8+3TQwk46K1ktH6kC63b3CnbtwSuAGU+2f5U4zhsFR0AHXGOM4P45qoJJN81uVei8v x/Fmcnt2a0/r8CvI8oxtCt1bIwcEkVWlubhGXEXAGF65/QfhW0YycUoS2d1fq7Lf+txy0Vpbf1+Y QvK/DR8fePA9dxHvnFShuvyYwc4wM5z3x+XU1DUrpNpbPt66Ec3S2r/4Zi7zxjAO49BtwMDt27/n UZkXOGBUDlejD8gOe1J86uoq7W/oWvhS2dm/S9l/kJvxjgYUHAHVTkn8enU1G06I33QMjkHJwSf8 ec/0pp6tq23+b37kpLRR2/Lr/wAOG5ezY4+Vc4HI54HOOKaMHvwThexHpj/Iqk5ct0rWv59rITbX JZW2Xy8iMsVJVgQQB1BA4yc8c+v+eji3JJbrwB2AA9QKpJ6qV0l1+79Lmiio8rvfz+RHnqOPRR65 56jpxzTvlHbHQYHGBz+Pp0oiuR22srev9WI5Ulbb8P60EwQzYxjcQeM9sDn8j+Jph446en3Rgep/ WjlUU3tfV/d0/L/hwi0oXeiWlv68h4AHBx0yrf8A6h/n8KU7T1XOACOQOxP9KV24ySdktF5O/X7v wY1pbmdk1t27/iCv0yGXBJx93A7Y9acD7BSM4weRnHXvnFNQ97kW7/Fef4Byrmai7WX4b/mTLjj+ HBHPAw3U5H4irCk9D6A7Rk8Zx6ZPP17fSpbVlJNpp7dLdfwVg5VLbp0/UlGABkYwO5GQAOf5CgsI wNqjr1xgEeg9KTtzRV7a9ul9de7/ACFaSd102X9d9RysnAGAOuBnpwSM8Vcg2OSq4G3jIbv2x9f8 +lUlaSk4p30/rp5/8ONQTsmn/wAH+tvI24bJAM5AAGAeM/QcceuferIsrfbuEiLjBx0xx7DFKpWs uXlSte3dddvvK9nJbPb+v+AUJfsS70Mke/JGNwH8xn6VyWqwoo3oVK4yCOx6bcgVVGpDmtJWul5W svzfUicWrSelrLby6f10M2zwsTKSpJzxgkAZzzx/nr2p0h6DgAHAILDjsfXOcdKqUlzTjblUX+H+ ev3ml/djyp+f63KMmD8ozkA4HIx+H8vxrNmTMM/XBglJONu07cdOfalFwlKCtrv8tv16FtxSi1/w 2n/D3PirxA4GragVxtW4IKgjOMEdF989D6/Sm2RAVDyjAjAU42jdySByByOvr3r1cZHVzW1ttto/ 53MsLN+0Tetuvp0sdjFHujCq/GM4B4Gc5OMfj0rThB8lVwc42gjLMFGQfTjkHkfh6eDPak0tebR7 LXS35/mfXYdpJTtdJL9N/PUlCBYSrqwIHLKMEYCjOR93v0+nvWhaCeSVWUlSNp3IQOgzjPYgHp/T ovclCba5WtEn5r7rXv8AmdUXyqWmltXbVJap/K2vod9oonhnjedWlJIXPUnP1GSOgr2fTZJj5DQR gYYh14B29cY/E15l2qqi5JKz6bbJfduFaSsnta239bHdwSZGcZdVXcoTHPPb/PatGGASAFsKM/L2 IbB/zxXTBSg4rn33+S/qx4dWCbk07Ws19/8AkTTs8KYXoAMHjGO/p/P8qfbiV3B3BYmAI28EHH4D 1raVJQvzO11p5O3X7rmatdv18vNaF7IUGMD1JI4JI68/561VBeFHLkjbjbkkcd+p9PyqVTvZSlZp qWnmtbf1tYzTXPJ3tvp/XcrJeQrcBGJDP80ZGSnoRkf5Na4JZPMYlSB8pwARwf8A69KaaqRffbzV 2n9xo0opa2tdL1Xfy/zJrKZZEc55B539cj/Zz/n3pf3cqOysULcYBA2t06CrSs6kWrKMkn5X7fcw lGSktldX9Vt/kj94+ntTWbGMV9w3Y/KxN4x6UbsVN/kAhPH0qA8Hj/8AVSfQa3EzjHFSbh0/+tR8 ga2HAkGpNwH4fhTTsIYZBnHT0qCVhjtx+lS3oNLVHA+LXA0y86j92RxxXB/D2zV5JZcDJncnH1Ne dh0/7Rr6bQj+Z7DfJgF5y/8AbT6Et08uNVxjjp0xU9e/BWijx3uFFWIKKACigAooAKKACigAooAK KACigAooAKKAIZh8h4rnbyLgleNvPPFedi4/EvI3w75Zo8l+Ivis+G9Bu53tLq4BidRHaxGRzwen YfiRX5TeKtbt/EOqXt9GJFWWaQrHNhXjyRkcZH4A+lfF4p1ZYxKUfcgtH1v6fr9x9hl1OCoN31m9 reen3nBzWlv8w2KP9nAGR0PX1rOkt4kyFUKCeFGOf6dMda3p1Pcs5Lb+n96O2WyUdLP+v8yhc2/m xsgGDtwMEDbn6/geK5mXw1G5O7d329eG47H88+3tXTDk5XFqy6f8MYSv/Lfmvr66/mSw6Mlsc/dK kHg4DduhPTj9fetNUEQABwMZ7n+tZyUI2jHW346JkKWiX8rsvv8AP8fMUMABxjbyMgHAIx2+tIzc A7VAJIIPAzjjIrPWHLF6a9Ol/wBL9O4ppKNrbP8AEbkgcDCnJGDlQeMEL2phBPDAAfN0IzjH/wBf pmiLjzJ9vn5L8R8qtzPZW9en/DjNvOQMnGe/r1x26gU3IVVGBkdctk4Pfjr19q25vLTb8WwTtzO2 l/y12+4GI43A4HK4xhRyOB+lQuqnGV4BOMjGPb86yioxty6WdvnYHaMdNEun5oTy0GNqgYzjGcg/ X/PSlwUxgjAPAHHJ6e/r0p8zSUb3SVu1tf8Ag39bDVoSio6DQw4B6gnPIHtkDPHemkjOMY2kDoB3 AqorkTV+ZP8A4On5/cNpRvdbf8P/AF6AMn+EE524HC4PTPvjFJgbsgABQCF6ZPU/54o5UpqUettO ml9PK/cJNN6R3sM5BBOASfm7YHpxx7UpPB9h2UYOcAjue5/Wio1GEUldq6eu3T8k/kSlrGV00un9 eWv3AxbPyqMbSOmOByP6U7IxgDLYx05Ax+uc+tOMGneOt9bejf8Aw4KL3jG+jd32/pfiKSegIDDj OM49MevOaDxzxkYPAPLfQdPwoTbu+a29l93X8htuy6WQ8OFI4/PJIzx17fSpFLYBz/EOQADgDPb8 Off2qIr3JW6aW++3+aElG3u6N69vv/Qc6O4Vlbb2JBA69c49c06KCRVIkJxk46k9iT2HfnmrfJZQ 5eWUe/f+thpqN0l3t8tvxRYSPYPunCkEdmI6n+np/OpQWQFkUgg8bRjPp0PvTvs0tXv5J2Jd7pX7 X+45q+1rWYjsiLKB/EDjj6fjWJ/bGueYwMkoVsD7xwBkZIAP4/4UVcGm3JpK+zX9df8AIuVWSXux 5f6ZXZNRuHEheQsACSzMBxyRk9fw656VcbU723RYZwWTAHP3scgfToOgq5UH7ko2jLR28n+tv6sT z8vu20ktuz6r+upat5xtyuVJzx0J4Jx6nn+fvUhlznlcZzzzgZP+J61k4SvzNJNu7Xbrp8yqajFp R6PX7v8ANFdZRuIYkHPH3lwufb6H9arXblLa5KlRmGVuSxAbHr/np3qoLlqRco320tb5ferlTSjF 2Vl1W3mfE+uRldW1DbjBuMd2B4GCMdu3p7jNJpwU+UGLAplT1Y/KSePQAZ/KvUxLclJuN0l+j/UM IoqpFSVk16Pe/wDwPmdrahwoXsEByc/c5A+vtnpzWlGGSFZFO4LjevLbGxxnn6H8ffnxHGPIot8s XJW8r9/w/q59PQfuwb0Wui7df8tOxajmBaMMhxkZO/HBOTgdDzj0/wAdfT7j7LK5ZN0GSuCoKkED PH8/pXPUoylRqQUr22tvv08rbW6HbGF5xjd8rT/4b7m/mel6eYpoI5ocrk7cheApJ9+ODjFew6PB CUt2ljy+wcsM7mAxk+/vXFGTlGLa1V426uz/AM/8grqKTsklfX1s9zo1jJYBSxCkFlAA6kj+Y/St RHZAvA3LggE4xx1wPyrpVNc0Ol7q35fK1rHi1rRgklbvb7i2xBK7yFxjuenTAA47VZjaEqABtdRn kkMR1B4+tW24KK5dL637df1Ofl25NEtfOy3/AFHlHkAUEhgSBk8/l+FStaJJiKQliw+6RwR1Iq4u Kb5dLP8AX/hh8nNs7K/9ehIdPggijKgYToFXnHse/SrCohXAJwwOFzjHXPT8aqcouMKihda+iu/6 /DuSr+9ZX/4a1/66meLd4A8sZUtxkdA2OhIHX/61MtLoMW2RkFgemQN1RVTUHVp6JNXT69jeDvo1 rFf1/XmfvicDjGB1FMP8q+2PykYD7cflSj2pAR/MD6DvxQR/npQlYpJDgKGA+mPSgXX0HKPT0oPH bH0oEMP/AOqoJTwfp9KmVrFwWqRwHi8j+yrrt8mPpmsD4ZoPKYgcGV/bvXn4V/8ACjiUv5I/merV 0wMP8T/I90AwBS19DHZHjhRTAKKACigAooAKKACigAooAKSk3ZAN3CnVnCerAWitQCigCKU4Q1z9 03ykjpzntxxXBinq/I2o/H6HzF8e9aFh4ZvYFbbJJDJGgBAO+QFBj/von8K/MW4gETvhQMsWOM5y OOoNfCVXfF4rotF939I+4wEOTB03be/9feZE3ygjPfgfX29KoOBjIYAj+E9R+X9a6KapqDSVraWt v0S+/T5mknZ8q0+Xy/NlGWURDODgYY+/r9KqLco+duQeQMgjbx0+lbv3VFJ25tPR7v8AMy5OVWTs 97fj/XoN3Hcwwwz2OBj8vwqBjjOBg4+YHp1A4/P+VJtpJbW+T7CXLJtWt38/mIS3UY6EEA459OmP xqLkNkkgLkjcMEHrx2xxj+dJxXO+be2ndIElq+3+f+RXYT5G3AXp34x+PoacGcfeHQYXaAe/oPrT hyRUopWa6+r0/NAr+l3/AJX/ABHbvuhcqccHk8YJGD0HODk//XppPTsc8Abc8d/w/rVqCupLp06a f8EWllZWd0/8r/iMJA24HPYk9e/+FJjHOQCeQQvU5yfw5pSUVGLXS6+W/wCC/wCCO1ou8v61/wCH GMwX5hn5f4QMEZx2P06+9MHA6N0OP4cY55wOO/B6U47O3Vdv66foP4bRb/zv/Wg0L0JBXHpxhe5P PXIz0/rTmJ5xkEgFcfeB/EUrPeNkuqflfT7hSV4ysrNbP8PwQg+UdOfrjBHOaD3wNvIHXvgEdeT3 5pxkleMVZP8ADzX5kpbWTXLe3r0/H8BcjJCgA8cdMNngU0kDHOOBkLwRnnBx06jr60rKU52VubTX rp9y0/IpuCv02/QQsvZcFTjC5456kfn+dJna30BOOf6fhxTcuig7v/Ja2/rqDXvXldW1t0t/SHDC 5GOVJyucHjtj65pQBg5B4xuHIIPX/CiMVyxSXp934dAXK/K19B52p055AIycZxxzj1/rTlIGAM44 6ZA+mD+FO3LJve3Ts9f8xWsuy7dtCVXO49FCjgY/2u4qdCBuOewwT+nfp1qY25nePS1/OzCV4fDr 0+fQlDNtbtnlSOSTjpjt1/WoXaVSoWPKd9vGAOeT1FNpxbcVZ/1/w3zLj7ru4WavoSLEsoy6AEYw Dtx2z/X86gayhXooG3JBIP14x9a1jNxfLy2svvtZfjoS0ld8uj6f100H/Z4484QcAAk8YyBkce9c /qMMeQSoBbuOCDnPX0FVCekm3drb9f67ESulFb/19/6lC3UCM/LgAgjA429eD/OnOMdMjK9eMAdT 9PrzWKcuWXNHXp5W1LjdWXL5+iv2KmCpPBG3DEcA+5Bzgdc1DcuXtrgAFCsMoAGD0XjGf8KpW5oL v92+vz1fyZUneEoKNrf8H/hz4z1fjV79SDxdOPlPCjgEfXJJ6/41FbKisVygySSSQNozkZ9uT716 mJvF1IxWqSt923z1+8KKV4O3Xf8Ar1X3HYWcwGCxLD+H5gMggdf8OP1rRbDMNokjWXB27gFbKjGC RnuOPqO2K8dQqQlPRKDT0tfbX792fTUnel7qtL9GrfK7fQsRblAUYUDC8kAHGT9efX1rXgzGDsKA SbQseRywJ3AnoeTnsOD6UWindbO6W2nW/wAtfXQ7ad+anK+sdkn5anqvhZCbUIGVlbGUJCmMn5tw x+X/AH1Xs9omIIG2nGzBwMFT6gH8a8VcqxE4wlezb2tq9f8ALYWIs5Q6X79XayZ0FpIcgMBngN/C 4wQRx2rSjMfmbZBhGORgsDn0PcH61003eTUd9fw109Oh49Sk7rldujf9dy41uGQEgFB0wMc8Ec0r QxiSIksGXkgAgsMdDjsOtbzacebl6teavp+f4anNzOMld2s1+PT8S1HhHIAIH0Py8darv9p8xfIy ynIY8DB9vahR05U1G/V+SuVTtDRx0RooZPL+YrnowDYz7Y9OtNjJ3sAQCeVyePwH1FZxUl7rem2n b+tRXlr5aJff+uqJ1cZw24dsHpg1m3TNaxu0EQxu+ZYxhwvsKcE5fu2+W/Xpvp/kNWSU1ppZ+S3f z/yP3uJpO34fSvtz8uG4/D8OKQnHfH0o2Cw3PHv2HSmg44/+tQUluh2do9P0pC3Hp+gpeWwW2FXj 7vHtSk/y/Wj9Atr2IwcGq0rYBFRLRehpBe8jzrxnKBpVz2GAPTHSsf4XSDyBgjBdsEdCM5/rXnYS S/tHEx2tGP5nqVlbAU1b7T/JHvI6UtfSLZHihRTAKKACigAooAKKACigAooAKjc4FZVHZWApNIQa txNlRXNTdpDtZImortWyEFFMCheuVjIXrjpXH3Ml15Em37y52oSFPPPWvGxrld8vmdeFUdb9z4Y/ aU1LX7GO286wgaxaSPdItyzP91+q7QFxjrk5yK+J57kXG5whjXrtIIwCBjBr42nRcalaVSabcnt0 6L8D7fD8n1anyNu1vuvbQxpXGCDkkHHpj0weOuetUHbAJ4A59B79M9OMV1QSi3Z7L+n8v+D2Kk+W 6S6P5NrQpSfNlCoxgsSOOeD061W+zxRHKDaME/dwpzyc456579q0i5O6el7P0vv89Dl5pyWi2vYY QucLjj5VyeMgnPOc9QPzqEgAP1wvzcDHYk/544+lNLnae6u32+fb/gDbTdu/3bsjJGNoXC4ySP8A PB6/lTFYbQScDPAIYfyrR8rbbjq9P6/MuMWrtO3NbT8xjEfKqjBGB97jOc/hQDjAOepIHXtn8OcC skk20t1t6b/nfci26dr9P1/MeJY0G5iAnOC2ADj/APX7U2SWD5hG6kjJyNoAwOPxFJLlkrrlsNJy 3W39f16kEhHHzHsV6gAEnjHT045zUZCjJG4EgEDjP0ApuDj70dn0+X5t2+4StGy9W/JCZwOc+hGA M8ZJx3+tIGUYIznI9QMenv8A/X/CrU3zOnGNk2la22n/AASVy35tu/zt+qGkjuSueOCR69Ofp0x1 pM4A+UgAYUjG4jIANRJuEqfu6df6/H/hmVNqyjy2Tt8tmxRkgcH3wTgdunQccfjSA8ZGByeAOMY5 yM0mm4pX5b2Sa6639FpoOMWktbdPw19NBpxjAyAOpwAAPRcd/wD9eKVh2GAOnH3h16Hjr6/5FtSg mormel/NW7fh9xNkvdS1VtfuVv68hu4JuyMfKSwXnB5GMfQg9O1KqjnkDqFxk9OmPw/kKG9E78u9 /L5+dim+bWzW69On6fd6jVj4O1idwU9P8nrj8qkA4IyBwWJ/DpxjH/1jVv4XCC5bp2fltf5fkKN9 uW1932JBnBztHc56njP4/wBf0p2P4eV7gYDc8Dnt3z36UlbkcdnJ27ef6foS7rTv/l/mOD7SB7kk JkkE9QAB64/WrAIyeOnAAB6+nTp/9ehJQ91R1v19P8v61HF66K/9W/r/AIJKpXI67gCcBscE4HH5 GphIBwM8dMgAA/3T2FTHlulfVdO/X+vNFNp3XTp+evyHFwARxxjnHyke3+f/AKwXAUYHP5/iec1r pzXi9F0+56/cV3kv6sVZX4HIPGSdw4Izj/64rntROQRnB6gDgr6857/1q4K8ZfZ5fzv/AJL8TOWk fPr+FylaYCFQRjIJOMNyB6Y9OvrmnPgAnPbBwCBt4OOBz0x6Vm4uLvGfT7l5fimjWMfhk5Wa/JFW THy44+b5j93AweePUiqN1iO3uODgQytjOTjGeCeMcmogpNt2tqkvRbffqS5uKnJKy2t+K/y/4c+O NclWPVL9wSGE7hiGIYHJ4P8APGfSqkD52eudykKQ3I4AA4Pfke9e3iPicno/+BoRTdmov+r6r9Pu O40prYqiXGyMDq5OwLxnBIIA5A/M121/PpCaYtuZg1xAuYWhUMXUcckf49fqK8ZVvZYqm5ax1srb qzTTfmnf7ke/CcnGnCmuW9m+lrf0mc7kkRNvaRAu0ckYAJ+UZI5Bz+db9tFHNb+jJynDKwOfmBA4 xyTgevHasZOmvZOlGy19Fv8A8E9Olo2r3S67W7ff17qx6n4YtPLWCbcMAbNx3LyTk/IMA9evT371 7PZSMQF+VsYBADHaOD9CPp0ryvc53JTstb6dUl18kVinzfY5eVd9na/3G7FEqShw+PMUBlUcj6en f9K0IdiyGItgDJAbJ57YwOPaulOME5U1qkvy10++55M3J2vpft/XQ2ogIkYKCoI+YYHXBHT86QxF QuxRhuh64J6Dg5xWqestLc2trff+X6nPO75XFNW7/mWFAcBeAVXkDgmqsISCWRVL/MeFJwuSO3PF Enek/d2Xz3/NLsJOUtPh0fz2LMhKjOAo6YAwBk//AKj0psiCPZ1KkHGPvDHT+f8AnNVTtJRSlbfT 0Q72t9m+j+aViQssq+WyEMuNhHHocH0qCF1clcYdMA7sfe6dD/nmsYpqO2kflvfX8F95caaTajK6 f9M/ebOP84pc+mOK+5PywKiPtx9OMUnYa3EBH+eKbx2padNChQfy/KjGPb0p/gMQHHSlPTil5BbY h3c45H9KgmHBx/hUPY2grSWh5j48YJo1x6jHt9a5j4TXa+WAMAb2A/OvLwj/AOFPGW/lh+Z6lVf8 J8bfzP8AJH0oh+UfQU6vp4/CjwQoqgCigAooAKKTdgEpaSkgCiqAKKT0AaTiq7nt2/KuWowKj49u KnifA29P0xWCfKy2tF5FtTwKfXZSkrW7EBUbOFHpVVJKKAyLyX5Tg8fl61zU0wwR0x1z0rxcVO3k d2Hj7vY+Wf2idMg1DQlZ2CmIq2Rgg4YDBH/Av5V+empwR2xZNvC7sYAGfwHtj8q+Z54+0q07fav+ Cf5n2OCclhKattt95yspGSMqADhcAnqOB0qlIeCv1GSMcnP/ANetYu3LyPTZ/P8Ar5Gk2/ejHS+n boUZHZVONuOmAeRkHjB6Hg1W3yFcj5MDrg8nuPrVrS/M7X087W/r5nOotSairW+7y/QYdwyrRjIA J5/M8dP6etQMw+bOM8DBJBUHJ/EcVTkk2727K3RDfLza6W/yVhmGxkfLhQQD0yTjqOPxpDngL8pw RkMc9s9Dz3/Oj3er2te3kgaSsrbkZPBJO3HTBwAOnB6Dt+RpgJyBncQc7ckAD6k89z271EVK7V7f hZav532Eulla35DJomkQqucBWyB6kcDHTuf/ANVUbXT3gI8xnfPQZxtzjIyOnWq5F1lay691dfiK yUnq0lt+RovE8YOOmF6AAgZzx79agdtgJOPyxgdue5pXj7ur+Xr/AEwtpNWvzLT79fy/q4uTjjOf QZPJJ9f880zbgrkcj35GT25znt/WqhfmlaNnFbrf7gS3TjbTTutdPuQLwe2ORtwSVBz36cD6UgY4 AC8Ak4HGO/b3FTeEfeb3to+ne/zbBcujvd6jdwGRnhQoJGQBz6fiPyFGQB2yvXJHA9P1rRxXL72k b/o7/wBfMFZJK9r3089tPloMO4A84MYIAHAA6cjqP/rfWlJwCo4Kjpkg5x79Og/z1S+Cyeq1S9Nr +v5kO/v3drtq3ldW9NevkBI4C52jJAIIOOcc54PTrS7yueij0+Y5+uMYNEFyqKT5t3uvK7/Nr1NV J+6tvP77/kNEgOOcbR94AgKeV7j0p24ZyrEHvggAA8cEj6YohtUa3ey8un+XQIfE4t2t+W6/F/mP AOSPulfXPIx396cORyMHBHfHPPX8T+VKG9nomtP+B+XoKK1e3T8H/wAH9CQYGcIFbvuIA568+nT8 qnTAXAKkZ24BwD/eOcY9fz7Um5NNO+97/k/P/IIu8U46foTq4DDHABGeNpGP6UpcDruAPTuevPUY wOe461fwNaXeqv0s7/16mjvFJbtdu3/DakrcjaNuOw6HI4/n7VGxKquDn6ZHHb6fpUxVm0tLv8tH +pErpyj01stiqXwTn5QVyc5CgnnIODXO6lKy4wTtwCPmweOh9O9dCjNc0trK/wDX3/oROLspJaqz +9L8CCBx5YP3AcHB+Xgbu/Y8jr6CkfJzhsYUDqxBI9O5rBucJKXN3893/wAHXzLi1a7Vla9iqW2t kEKBnvnOenB9z1/+tVK6fFtclDjbDLwTwDgnPH4GlRXK7qV7af5lNqyl0S/yev3fifFXiPK6nfsW EX+kSuEGBlSd3bp3/nTtPkDRxFWyBkDBxkZwT6YyR37ivdxEuvLZefpbX+t/Q5aMoxxFlO9+nz6n ZW6J5K78bsqrDJyR948DoM8Y9+tbZt4oYUddnEeSpI3Nn5s8Z/z9a8SpNUoQg9bO3ntuvy9T6vC0 k4VGpXcYry9bfgvmMQEpGwP7tCQducLjrj0Iwciug0sqQcTKuHQLl9o25UgYHQEkHFZ1W40/ch7u 8tNVqm9fm0l6HZQU3KNNpKy/T9PLyPYNCaeyiVSvmKSpVSqnKkfMM9PXp616tYysPJkQiIlcquQA 30H4/TjNeNyzu+Ve5JSeu6Wl/wBfwNKzVk299H8tH6aam3GZ/OBz8qOCVcHaQccr9M49s10sDp5g 39MfLhcHn1I6dhXVCLi4yWiS7+n/AA7PKrcqppRVuXr2LaSKsnlMSqk/L1xjPeru4g7Ny4UZGVB4 68f0raVrpPSyTXTTS/3s4kpWTi9Fur6aar/ISGUKxBAHXgcD6+1DgfMydf4flAAbsentTi7Jp6K1 xptW6Nf1/wAH5lVJo5o2BZkdCVZcY2kYzgnkjk8+9WYxuRWJ3heNpO0gjHP5UWUJShblnGWnezX6 rUpqSd1tp+PX+uwxBiUlT8vy/Ln5R3wTUzIgO8cEjJI6HHY/nS5ve957qz7Xt+F7Gibsusj93N2P bj8qXd/n0r7U/LbCAnnjioSTn0Hp0qXuuhSSuAAxRnGPywOwpbfIruuwoPp/hR04/wDrUbbCt+AZ APb3HSkJ444x+FHysFttCEkduD+VQSkgH+VS9mbQXvLyPJ/iK4TRLg88e+K88+El4MIFY/ePtg56 V4uGk1meM1suWJ681/wnQ0+1L8kfW9q+6FD/ALIqxX1lP4I9D556NhRViCigBpYDjp+lRtKq9KCb pERnxjtQJx6/0rKffsUvIeJf/wBVSK1YxlrYY+itlLTsAUnShvQCNj+FVnP+elck2CRDt9Kk2gAe v4YrPoym+iWxIr4qRZPw/pVxm4/Ii1hDOAOlU5JW+lKc2yox1XQzLg/Kcelc3exMysI2CHsccDNe bitYtI9GjZW02Pl79oKyuk8MTSreSbo4y3lqqLGzB0IDZBJH41+b0085aRJ1ZirMAxY8DnFfMRpv 6xXcdGrfP/htT6zBz/2eDtZLTl+Zluflb5cjDDGcHj9Om3r61WfGMbODkg5xg54+ldl3CSTkrLa2 39XKm2mk16fNlV2CL82zHUgkcdQDVE3cRYqAMqSThtuME8cfUf8AfNaNaJ7Xt8upktdGtd7+Yx2B yRgc5+nH/wBc9+1Q7j1HVdvUgYz1Hoc5oabUHBW5V1879iJL4Ula9v8AhvxGSFhkjkjucKMHHQDp 2/nUR83rwD6nu3AHH1/kKGnyyk31/Cy1/M0+zyx6L8X/AMP+AnRcMAfl4Cnt+uOOO9JgrgDvxg9u 3bvzRKTi1Zabq3X0ElvddFZen+YGVYSXPy4BGMYORk/hnAqNNd04sUeQKy4+UgAE9wckDnkUpp8t 7aLTy1t/SJS5V7y1drLt3v8AjcebiOXLRHav3genv/L+dChMfNhQMZPXHB9BnGD1x+VCsuW2jXb8 WVOLvyRdkv1V2M8sKQAQoIwAGOcY9OP1oIPyn7pXcd2SODyc/wA8+31pwk1yqStJW2+S/P8ABiu/ i5dV+vb5MbgLgADALYJOApzTWA7KM8AAHA9ehPH/ANeqcYyjLlWvf8/x19AWmySsvTtf+kMGM44w OBjH1yO3YUh2qR0BGD0A5Pt9e1KXu6LVXTt6pf8ADfcOPJpdaO+/TsN+UcDGMH1yRjOPXp/Kgllz joceny9QemD/APr/ACIK99OVr8F0X3XJcb22Uv0/rX1Y7ueOm3OCAc8dM9en40xBjjOOCQQCgBHt +Z/Ck+WEpQSSbVlbRav8Nf8AIGrJuFnb+vz/AAZIuCB8o+bIIzhcjJ4/Xn/IMnOB0UZHQg46fSh8 sbpaKS1fq3s/WyHFq8mo200/r7xxBBOM5znOc9enr+v50/06Acn73rj/ACa0jCklCVrpXT8vT5/n 5Fe4rtef3f0xAG+QZOADwO5xx+HXmpF3K33scAcgAHkgj9RUPXmk1t8K7Jf1qQpKL20/S+5OAeBx gj6YbHQj6VMGIIDHccDABAPUHAzjHp17mmofC78rX9f8OXC1k9rf8D/hhwB4zhSfbqeD/PnI/pSM 3yk4KgZ4ztJPU+w9eveiMY3SjfXS/VdhO1uq3KUm3lDweOchSB0HoOxxj1rmr/A4A6EHA5IIPp+u fb0rWLd5qatFGUpfzacv/D/je33BGf3Y+U+u0Eg8dMZ78YqNztBAwv3sHzACOD2454FZ3hpbS+/5 WS7aI1k9Lp9CoAFJBXHy/ewBjuMZ+nWqN7n7Nc85PkS7cc7TtPIHp1P6+tOCSkkoaX6dbv8A4cGn GM1a19NO9v8Ahz4215N2pXisF/10px1KkE88dPT/AAxVfTkWJFDOdqnjauME9e3HXv1+te3WfKpx tppv6HLTgvrMZtW6Ox2lsyCEnJU7WCn7rDv8oJ5zwce1XI2zhGJVQiqGYoMtyD/LGD2NePUgoxVR Ru036JdvvbaufT0pJJuKtZbdErr8vyLkC7WVOhIJ2bmbJzjGMYP5fw1raWiiSSFlwrfdYlk8t+3B HTtUc0pUqlvJvorK333s0dlKd6tOztq196/q57HoE0rQwo53+WSqsM9CvQdvQgmvVbRCYI2iHlsu Cqs2QAOCDgnH414kaii6UrWi2426xi/z/wCGOyqlam103t/Xc6+3l/cKXTovzKGJAPByK2raSGFV MyjaGG1uDjr610U4T5XFNKz0fd7fe1Y8ivFWmtFrt/X5Fx/Kb7pyPvIRgf8A6utTQpyGOSOmcA4I z0P9a1bT1atdL+vwONwUEly222/HQsqlv5h5xgfd4HoOPyp2Uz5cZUgtjk9+OcHFXOW8ZRsmkvJW 637sHGcXptpcja0jDGTIBZdrYOxQDyP5jpU5EflgLnCtxg9veiTj7S8vi3v6dA97lbvZK/yWpDJC Vw8eE2nLYUEEHrx69aa86BNu0kjOcEgAcf1rLl/hyjpdfjrb+vLzHFK1rW7en9bH7udh2HtSZ9OP avtb7n5qoig8UwjB9qXX0CKs9hoPp+nFGQOKX6F2sJ0/w9KUn04x+FPy2Cw3d2pT0zkfTtSHa1iI tjt+VVpz8v51MtIvQ1irNHkXxLYDQLk528cHkc46V4r8JbspIoJ/5aHOTwCT/wDrrwsPZZnjl5Q+ /U9rkf8AZ1Jr+aX5H2vo8we2TnsDWzX1tB+4rdD5qatKS7BRWxAVCz8ccfpQTJ2Krvj/AAqs8mPb H4VaSM9iq8wHf8KZ5xBx0/DArGqrK2xrAtRzA4/Dir8b8D6flXD9o1lGyTsWAadmtYyRAmaQnFDl oIiJ/wA9KgYge36VhJ9gQBlwRiq7OOf0qG9F0LjHXYYZORTlk/z0qU+xpyeQufTHX6VEx9Py6UNh FalCc/z47VkTDkngDrjpiuLEPTQ66atZWPFfi3pMOqeH7lGYAKjBgD0xzz+hr8zPEunrZXU8e0Aq zAEcDrjIx+FfPVHFV6sYytza29P6Z9Vl7/2aKfS5w8sByTjA6d+OfbgHNUZImAOQc8+wHpgHp0H5 11U4qycpdUl/wxq23zLs9P6+RRlQAlApHGcHI4+n5/5NZ5giWTeFwcnnB5HY8deK0W9Tqtm/8l6m Tt7199tP67sjOAeo2clTkZB+mPc4qInA7+voee2PwpWcVfbTZbdvkKz05lttb8SIAjd1APGAMg+n p6g/SlORlehPbpg4z1HHfsah3Vo9H/ldP59hQV0vdtHb/gERBXgDksp4JXrg5HqKapC4XBPuCDxx jmrV1FrprZ/16vbsOXuP3Xa39WGugddoGSwGeCPw/wA+v4VlHRrZ3D7BuzjIO4Ef4/8A6uaULw3d m1a36kpSjr57P0/XUtwWkcPypkYxgAEjHTr/APX5rVSEAD0A6hcAgg+v16Y796nZe4rON791t+bu i0uXSStdPTqty0loCpwDzjgZyCOp+tBsmy2AQcDoDwe/SlGai3dWtfbfX8kQoKMVyppflfoQG1IV Rjoc4OMbvx61E1swZh2Yk5ztwen+NV7Vx5FDS7387dfyKSdoxtbl/qxRlREIGAAd20DJwCDjp2+U /kahIIJ4Ck5Bbnvn/P8AnFTGKjyODfMk1bz835PZ+hCjaW2j2X9f1sNyynaCASARwAcf59fX8lwF JAPHqOSDxx0/CtbzpubUbcz62022+7cNIyk0trfLTVfmg7ggAYB5HGCcDk+vTj3pwxgDdjHZcA5x kcE/X0qXFNKS1v8A5u34fiP+8+vbyv8AnYFBG72wRzjAwT0HPb1pwBHCjgHIJOAfT0/z+dWoWTa0 8ui6/wDBBW3WzX+f+Q87cbSTgddpIxjnr/h/9YoG+UHPA5BHbn+7+dTyO0eWDV/wb/4CK+G1lZ/p /X4skGR32jJwRxjOCQT1GfT/ACH7cZxnt24XBIP157f5NKnyxSi/gTf43+65DjKUYuPTqvvf6EqE Z+6cDcMj5fmP8+oH509Svrg4OAByoP5cc0QUrR6btv8AM0918utrLW/3f8EdnoBjjOTnHt/Qj6ik Yn5gPU7QOoTk9vWmt373Lbqvx9PId0nbqvu6lOXgHAG4DjB6/wCHeua1EkN0x8wzgjCqM44PU9Ou K2UeXmUk3p8npp99/wAjCpZPVWvq18r6+WpJCcwK5XacAH5QAW5/GoZOhwTycAY5AI/PjINcrTXJ Z2SevRpX0X9dDRRtJW2e/wCHy3K+3O75eFUDHIIHbk/WqF6SthdnAC+RJl842KFPP5cVadL2kYJW tJJ66+b/ABX5lz+Ga5fJ2+ev43Z8e6+uzUbrbgp50hIzg4BJyPTp79KrWnKAEg/d4IIxng5GMene vYxMvcbV9H+JnCyrSSVrf5WOrg3iM4XA2jGOCRz054zycVajQhAQSGxlV2DJz7HqefyFedJR5Uua 0U9en4+tkz3KHP0+F/rb/gE9nK0cgIZ88hVO3O/jG3IyDjqAe/0rqrFpPMeV0MikZkXGDgAHJOeu B/npWLi9VT0u0k79b66ev9WO/Bw99xafKr3fld7f12PXvDlxBjdt2ruBQcHLEjg+gHqB9K9RgZPN iZcNGwJZUADBuMYHYde3cfj4sIqPtVOOkU2l05kl1fd/5nROPK4KPZ/fodRatG3+qI27SrKOqn0P 68+9bEcEdzE8LjgdOoIXPXA/D6VpSm6c4Ndbt+TT/wAjzKyupp7LXT52LVvCtumMllT5cE5wOxJ/ r7VopIiEDO1WXBA6A9f8a6JpRaSj1/LX5nOlZyTl6sUxo2H3lSnGF9OMHpWYkTG5M0MrKF3K8WRg kdT7dR0rSUoSozi420a06Pp6NP8AUIe6pK/w3uvL+tdOpcE5lBVflOMHcpBU8/n+lMha4ttqswbk AhQSMEgDI/CsLKUZU3pKOvpbt6/mJR/5d2stUaPn7gN3AyoIzkd/z69agaRF+9uADcNjKj09KUXK 0Xa6etvPT+vl5mnLo1FbLT+vQ/donHoPTmmA/wCe1faH5oo6bDwccdP0xSMffj27U+mwJWa0sM9D n2x0p/bikU0J+mPwphOP84o2BLsM3D2Hp64p24BQPr7Y5pbIbWxFkfT8qrXB+TA4I+gqJaI0itUe M/FNyvhy5HQ4PbJzg46V86fCi+2zKM8+ZzjtyT+VfP0XbNMw6WjDT5nvU4v+zqXL/Mz7r8NXQaGM ewrtBX1uFfupHy9aPLUa2ForrMRD0qm5wT6Cgzn0Kcr4PFZ8suP6c1vBaJbGTemhnSSH39PSni43 IFKgEdG6EDNYV47K2xvS6E8L7SO1a0UmAP8A9VeXJ2kdco+4XUkGKf5g+neq5jntbQTeP6Uhai/y ERFgB/QcVAz9O30rNuy7FxjrsV2lA6cfpVYy/gfasJStotDphC3Qj356H+lToeP88VMXqaONlYmB I/Dt0NJkH0HTjpitb6aGVrbFWUD6VgXttM+7ynSPg8kEkfhXDiYc0WlodNK0Wro8T8a2F4+l3ivq DsCl0yhI1jAUYUL3zznn2r84fF9vcWWoTrcl/ldiC38Qz69T1FfNOmqeITer8/mfV4SUfYPlhboe fT3lvCeSAOwJGcVlTavaEkJIvQZAIJ4yDwP88V0xveK5fNL9RySi5N9+nqZb3CMxxtOAu3Hv35qu xyDg7cDIzjA9h/n1rrukkmtfLTXf8iJW5nyxVkQ44G5jjGf4RgAkVF/F0KjIwcgAKCMnHf14qZ8s YtKGib/rvYl6e8n1f5/qIRjGc9Pu4x6nr25zUW47jxjsQccHAJ6fT+VK1lFXs+vrv/wPmKM7Rte2 qfpawmem8HaGIABAAOP6Go/lGeB/unsB2A/EmnJdYu3Lp83+XfzQWWltLJ2769/nr94EHsQOTgH5 cfh+BpPu9CAPQ55bHqOv1pWfOk9Ovl2/z+8qV/ddtNNO3d+v6WELgLxxg9zhQCD/AFxWRea41sNv fBGMnB57HvQ4JX5VbX8enqJySas9V3XV/wBM5yXxbqiEi1VsjJJkXdk98Z9j+lVj4o8QOfkYK2Tt XZ34APOe30pvDO8pSum1sv66r8SHNwfLfdfi/wCrFn/hIvEGMtEpA54A3DA569OMVoweJLtl/wBI UoeflCjYOeOe55FKeFcYRtO/KvntdX/MvmjNSW19fM04L0T9N2QOMdMnHf8AA889qs8ZLBjk8YGc Z+o/nVwskny2kkrd/W36BeHXR/1p+gvIPTnOOCR3xwDyO/5e9O+UcFtpUEgYK9QfmPX0/wDHvTNK LS/eSS02/wCG/rqyUuW+t307eX5iDGMDbjgg9fmxjgfrS4GMH8yCoOeR/n8fWnGVk5WutV9+/wBz 1LiopJX36r5/5fgOXj09cAjGM0vOMAHoOgDEexPryKUbyTt8Ld7bPsl9xF/e5Xorf5r7yTCjgDkd z9OP8mjgMByTgAnqADjjBq5SqL3YvRp/mr2/rYqSVo2b0793/kOA5xye3AIGBx/nj6U3EoPB6gjj I75x1z1pct3ON7W1X4afgNRcVybLy9dPlYkjLA7Gx1AzkDPGcYz7n8qmXsv3uNpU5HfjgfnVNKNt bRjb53f+YrWfLvp+X9fgSAFcemQR90k59cd/m/8Ar5prEgEbSNo5JyMnHY9en86hXfNayg7/AJK3 9eo3aMpLpp/mVZNu0lRwARtG4exA3Y55H61y98AHGG65+Y55wPYd/b1rW9R80Wtvutv07vYwlq/i sv6/Dy9CeB1EQ/hX05OOoyD09P8APNVZWwVwT1I7cZxn8eDWairPlvb9f1NJNR5bdV8ul/zICwTI x7KMsQD68cdzzWdqD+Xp14eMLBJuwGHy/e4/KnTjH2lOMVrda9v60LcpJJWt0+Wuv4Hxdql6z3t0 SG3faZSfMXbxuIxxyDjHX3rVs3UR8AA4DFSCGz2Ixk/hjvXtYunJRUl8KetvX/Pc58PNOtP+62vx dzoUYgKSBkdMNt+UDHTPTnGfYetWw7eWNoBfaTkYCliSQOD/ALWOv9a8twi3e3u7dvw876n0FFzs 4qOqs/RbXCyfaSNqnDBhy3HBwV4PpnA969K0a3/0ZrgIHLBW8vOOAc5z74I/D6Vz4m69nyO0dEtN ndNPy7noYKUXBtprla9NdDrfD6kACOTygz4VSflyCPl9AT17dK9et1eNIcFSQBu2htwB6479c/Wv HlGk6s1CVqknJ26Pb9TsrqMEoqV3HXy8/u3Os0rYMnnLZ37eATkY5POa6CwcCR0wQoORnkqO1OEe S8mrW17W/pWPNqpXkktltt1NEJhZBkMMHbkEZHuRzwMU22PYrtC8BeQD/n3rpmnyu+ya26N6/I87 RSkrp2108lp+X4k26K3YruK4wSORgdsdu9VgyqzsoADHDZBwB37c9T1q5JKM4pWv+Ftb3Ljy31SX +ZagNvcOMMoZcgMOB+OPx6091HzBCMqeVOA3fHAHrWcZq7jbVXX4jakmnay7fdcqxGVmYFR8j9cg AjqSD1FWT5RUgH6rzgMOh9auPK17q+F/d3f3svTlhraR+7TY/L8KZnHTpnjFfYn5ul8hw/z2pGPG Pbp0o+QW1Gg4459qdnH+cULbToNr5Bkj/OKYzUumgJbFc8HIPGOnTFO3cemBwPSpXYvsR7iOcVFK fl/Cpez8iktTxf4svs8NXR+7gN0652mvlD4Y3w85AThwxzg8E7jt479/zr5qnKX9q5iouz5IM+gw 6tl9PXTmf5H3R4Qvswwru6AdDXrNvJvQfT6V9TgqnuRPm8dDlqy6WLNFeqjhEPFZ07YzjjrTitUj KpojLkY4OKpSNzgDH+faulq1rdDFFUr+nTHFM+70wMdulclZ6PyOqitUiRJcdOParkdwAOuMdK8W rPlk7Hpxp+7Ytrc8DB6D+tPFyucZwfrgUlUWmpjKi+xILpexHtzTxcD1H8qpVF3sZOi10GGQdqhd zz2H5VMpaaFwhb5FZiefbp2pnPp+mKwbfodCVgUHI4qyo9sYqoJ7bWFLsTDj04z7UYHHb9K1RiV3 28gYBHasu+Kx28rt8oVSc+neuatZRl5XN6a1S9DwTxfqIXSb4ZMgEbqHUBVVjhz9DzX5n/FzUL9b pjGozkhTnkdDjjpxivlneWKj739a6n2GDjyUuXltf8D50uZdXuScgrkYPYg59+Mc+34dq9vpOoCT LSSckE5JAAP04/zivaVOC5tbK2mm3S/4kScueWun6bM6i0t5rZFVzuKrk525JOPx71Y+bkcAcZAB PBAxgA/5zUWlzK2q7fL+m/wMo30vtr/wBjHAB3YJA/vAL36d+nX3qNzztweB0znA749+f1qIqKlL S9+/TTt934jioprpvp/XyIjx935evOB3POMfjTPm4Py5PfGM9u317URWkuaVkt7fp5v8gsnJJaP8 H3/UTK8D7oAztye/8qYSRyDyMgEgHB9c+vWp5LJcqae33XX5ag7LVKzelhfMVAdwH93O5eDjOCO3 GPzpBdWvA80BhyF5BySBgY+vX2paqTa6dPLy+a+4Le7KN7WTImZScIeOSSucE8n+pOf/AK1UpbGO UcqMk5Ppj/IBpw5o3s7a7dF6PyHyxtyJ213+65Aukwxj7o7HAC8L17fSnjToUwyouD83bORnA/X9 K3ba5vfspJ+XkQ1FTjJpLZf18yT7JEM5UEJkFcfLz+HvUZtYef3ajGBke/T6jt+VZ25Z8rdktdNt FZfj37kyp2bUNL/1/mPjhVSAq7RgZx8vI4HHSpemR6ZyMqATnBx6UN2UbL3l523Tf+W+2xolHlV1 e7/z/wCAKTgBQcAfxcnk47DrSMT/AAnJHzc54yTjt7/07U01GSvpfVenp8n+AtYt20tqhcEdAcDn pgc9OR+PpSjgYGehPGDjB4/kP8moV4zpxa5eRa/Nfp/w4/dhePwtP5a3/IN4XgfLtII6EdcY54/T vT1wMjO3J4Kk9PTA68gdqfIlNK+y0v20v+VyGviSVkrfkPIwze/AHsPX6+tOUZIOcABcYGOQcZB/ pTVnFxkrRW3T1/A1jGStF+dvTUaRtOR0JLAk/Nj+lSjIzzgEZGDjb6Z9RnFHvONorlvZW7dW/vX6 i5oxk0vdumvJP+rjlDjkn1GMjqf/ANf9fSnBup3AD04H1/xrV8tlFaaa6dU7r8NfMOWzWuq0/Vf1 1H5+VRnkHnPGQR6du3+eKa7gZOQDjHPB681norxUbL+krf1oOot03a2v9f1sV5SRwDzhdwOehz+n bgVy2pSMHBUHGSQVOM8Yx16dOnrW8Uox3tK3Xt0/MxaSlF32d/Lf82PtpN0Qyvlkc8rjnOeo/n/+ qmuODgE+mTjpnpzx61gnK1tIJ/n5/K9/M11UItJXexSZmAAzjGc4IDFeOh71lazIV0q9YkBlhcbc /gDnj2OPf350pqPtaXI7XlHy67kwXNqtNOt99EvzZ8cXcKSTzuGOfOkCjJ45b8vXr3FWYAwQABjs +Y4O4E8Ejr9RXr1qnNzxSsov9Pz1OelDkqy5d3f71d/16nVW6kmPzUG0YAOQx2Y6r36E8nng/U3p VWP5I5ARswrgMCoOR8273Prn8uPOulLlitGlt3u/0foe/Rc7dn+ae33MbC/kyDIbLEhsN5fGCeoP oMde3r07nQ2lIARgATjaGZHHOctjGRnqPp2rnxl4Ut/dbX6L/L9DvwLs5q+n9M9Zs7CL7MhjYKQ6 71Qj/Wcc89vbjFelaaS6QxtyyrtJBK579PTp+VeNPlXJUjHWLd1bp1fzdnodc2p05Ratyv59f6+R 1ljF5akBMFO6sW3Zzzlv5VuWxU7mQqrK2Pu8c4z/AFrSLcpNP4dO276HBO9+2i++12jQWZ43K7QB jA4IUcfzP0oUtH+82r8x7HPP0B78/pW9moyhJ/8AD/1r8zhbSalZKT0KeoW/nFJIXKEgBwoAwOoP PTmrEcUqW67n3SKMF9u0scYz/n0rVzi/Ze7Zx0dur1/4H3F35Y7Wts/x/r5Gfb20ttK8qM7LI2fK wAQeuQOo6frWyJTHkvtBwQSPT8Ov1qKkf3s6sGlzdPkvzuXdtQ920kvv0/y0ISDG4dXymeY1+b5e MfzqOKe3nd40cgggMoIUg8j/AOt7ZrKU3G9aEdGrPay1tsNRvto46fL0P3jz9AKaT27flX2Z+cJW AMB24FMZ/T/Ck2NR12G7/wAB+H1pA/P9KlNrQdh+7gDt6VGzY/zihy7CsRFqRjxjtjoPWofkWla2 hFu5x/8AWqOZsL6UpfCyktUkeL/Ftf8AimLrtw357Gr4s+HcrLMmDyrnIPGRk8ivmKcks3zFW1UI fLU+iwq/4T6Omim/8j7h8E3h8uEE4IC59q91064Gxeew9BX0OAn7qT0a/wCHPBzKnabsrG2HHr/S nBhXtQnsjxxjtgY/lWZMCcge49K6IOzTIktCgy4qsyAVrKenYzjCz7WG7Pw9KrSLtB7Y/CuGtOyZ 2UY6qxQaUD2wOmfzqE3iJ3xj0xXzmJrKDkz2aNJtJJFdtTA4DYx74qFdXw2C3t2H8q4FjGmun9XO r6nKzdtiUasoYAMPp0Iq7FqQIAzitI4tXa2sYTw0opaGlFdgjr/SrqOG44/DjFd9OonY4p07N2JN n+NKE4HFa21Zne3yHBMdun4VKq4/wq4qxDY4DHGMYzS49untWiRn1IzCd2dv0PpUN1pwuoJImHyu hX0xUSpKUZJrcpVVBxfY+VPHcc3hwXumXjZt7gSvDI3G9myAAfXABPSvzv8AiLcRTalJbfu28t2O cFuckfnXyPI6WOlTttdelv8Ahj7fD1faYeE4r4lf/M8uNvGrDgDGTnAzyO4/T8BUDBVJ2qOF4BG3 OTuz+FetTn7t72X/AA9rGc017t7JvT+vmVyByOB6AAYGeOagbhRjgYOQOqjp+Pb86ltwkod308v1 Ibs7JWin/T+8gO/JwABjA4AycZHbr+R/pGdyA8bex7ZGMge3+RSb1cdk7v7nbT8PW5aSV5Rev/D7 EfOeMrgkDj9ORnpTPuFRjpuPHfp/h+gosnaKSUbp+mi/zehPNGFtLL9f+D+pGMdAMKrFssflGM9T SZJLZwC34FeuR1+tTzNJxs01bbtdL8dbGcm1fo/6/BW/QrzRFgVyw/IAA5/+v3rPGlqXBEjKcA4D EDPbjt+VVHlteOl/lo+nk3r94/evKT0X6f0y7BEIgB8w4x1A4z6n6HJqZc9A23HUHkD68D3qZRXu xcLJ+eqfXyFrCUdL308uuv4hnHIIz3x0x0H4/jQXIA2gA8nO4Hbxzgdf/wBdOKfJK8dEr/r+ZWnL o721/r8PkRknjgAr94DnGfT9eRSAhSw+6B0PTJBPb8TVJNvlvayt9yEtHdRve35v8+4ZIPHrndgg +hHHpnt1pmDz0UN0G0dsDk/r+FCcY25dHH9f6+4bSXLy7Jf8C39dg3Y4GOnGVxjAHIJ+n/6qRQu0 EMV2gAgHBx6Y+p/z0qYr3Xronf0X/BEmny289PPZjsA4bPQ8HPTr0wccYz09KTPP3cn06Dk8ken8 utObdm+W3Kt+jb1t59i7JNSvt39Eh6gYyBtUEZGQBjg9OCOmetOOO23BAwFI6n6d+9Zy1mtOiXzv tb0sNqNlJPX9RSHB2gjjGDgkmnYwcg8gEDjGTn26cj8a2jyyipcqSb+7y+/7rA7PTb/J/wBP7hdr DBKnK8jjIB54GO/HT6U8kcjADMCMcZwOvGDnpR7SXJ8HLfW/a66epFlyqySXT0fX1I9zg7CuUPGV wSO3P51YD9No7ALySeMD/P0qm1G2v97zIvbr/mlr1AnHzELnP0Pr070jHnCjHXH8JA7Y9On8hSUu VxlbSW3ptf5XKs/e5luun9ehTk3c5yO+BnIX8eMfd7duvpzN9ndhd2QPl3BsDPTOP88e9WnFNpaq 339DKcZNJJ8rk7Jaf0t/usLa7jGyyfIVJ2gAHjBO78R3Hr+T2O0sTkf3Rtxxx+IyP/1Gs1dppR03 /Fv8jaXxJ9EvuK7DOeMAdMkbQeB6Vja1hdJvyWAOwnGD0yATx9KuDpe0hDZprTvrZ/jrZA52jZLf b87eXU+PSR50wHysTIQDjP4DAGRwOentWnbbTtVsKTjBRMcAcdO2c/nXqVr3m9uv/D/1ujDD25rL ZN6/d/w34nQEGIRFByy5BKZxxxx7fKfc0oBG45JCgNgjA/2QAT8uCfxrk0pxUlo1b/hl8vyPZpXs 1GVra32vZLQswBLhkx8p3AdepBwOSeO35121jayJ5c8cm3zAnyoNoyCSeh5B6cngEVzYhpyhGSVr P8k/0++x6WBSjUnNR912bX3vT1e56xoc93cqsZiXdGNsgDANnsSO3HFelaerrLbtgEg7ThsEDPQg flXhar3HK7imvvTt+f3noVHCLajK7f5NWO2hQK28ZU8ZG4dMZHuRyTWjbY2sVUqORgDnGM/Tuenr W0YxapqK20/4LXR7HlVLRfLN6rb0NaF05wN6bcE7RkZ4/wAPxqPf5cgCgqhz8oHKjnP07V07qSSs 5O/3efqcHK01zO1nb8Xt/WxI20bAqBWB57ZHXj/GozleBlhwSOgx149Kb5bQUlZ6f183cv3uVw5b pf8AAGfao1PlsG3eoBOB2/z/APWq1hZIuB2x3HTnsc+v61m3adpLRf1+hryNRi1vrf8AFbGbbzxe e0AJEisVKnkEdjye9Oi0+3iu2uk3LMxG7BOD0ycDr65x3qp2VSrScElKPys3e/rcpOVPlkteZOz+ VtT95d35flTGOOnH6V9afnaWthARgjn29qrk846Cpdikn6CFscflUZY544x+HvSf3WHaxKJMf5/G mM3v0pP02FZDc8fT8KaXxx/XHehjI92Onv7GoZ2+XvUSfu2WhSWx5P8AE+PzvDdzHt3AhuvB+4w4 P0Jr4y8HWDQTA7eFkYdMDqf/ANX4V8pVkqebY2W16cT6nLqfNgYJdJP7z6y8IymJYuT2GO1e5aVd Hao+lengKzvZy6/1Y83MqFkna2h1UU3A5FWlk6V9HTlt0Pl5w5W+g4t+Ht6VXfuK7YS07EcuhVdf b+lViv4VUpWQlHW1iFyFHpj6Csi5m25GcfpXnYmooxbO6hT1StYwJ7jbkZx1rm77UxFkA9PfFfF5 nivZxbR9ZluE9pKMbHOXGtlB97HB/nn/ABrNOsyH50fOMggE5BHPP6mvmvr06kvcdml/Vj6mOWQh G7jcSHXiWwZMMODzXSWutLhcSfXnv/SujD4ySs5Svb8zhxeXQS9yFmjqbHVEYLhvT3/SustLoEDm vqMFiVJRs9H/AMOfI4zDulJ3jY3YnB/z0q0FHb8K96FuU8WfusXb7UoGOAP6VaXbQzbJFjOeAePw xVlIPUY/pWkIbaGUpdETiJRxj8PSoLtvIt5nVclI3cKODlRnH6VtKHLCUrbEJao+N/i7qltraXMD RlZrKR4Ht5FCuCMgyK2fTaf+BV+c/i+2hg1OXaWDct83J6kcnP1/Ovi4z9riajatJuS+Vv6/U++w lL2OFoxj0X5r/gnASfeJUd+Meg981VZOSNoJwMDBABBz198+vb8a7IxaaioWtp5diZ8qb6W/K5Xe N+duQF47juDwR7YxULr8p42kD5gM+/8AU/ypyXJzRerf6/0mTLS/u2Vv6t89dSq2EzkZHPHcZPOM f54NQMD2xjnHOAQTz7E+34etHaT05d1/XeyHC9tHa3/BIshVBBP4naMYB/yaa7qCBxkZwAQcg9Dn t+f/ANYcotpWstdPz+drIba+FRs118+v/B+8aMHJU9dp6YAU53H09Pam5XaRtOM8EcgkA8UKXvx6 JW232uvwVhuUfd02+XX/ACb+8bu2jg7T0x9cDH+fWkLqBweOoJ4545z/AJ70PkinzO1r3XXm/wA7 XfzIlKV4pbLft6W9X+IoPAO3BwCOTgMcd6aB3OckcDHY/wCetHuxtC9r309Fdff/AJFNRa5bWS/D 0/rcaflbDA9DxyDgY6gfjTGPJIC4J/i+XB9iOPT86UuW0PZ7JWt5df8AhyLxj70Vtsl2ta35fmAP Y5OG6ZxjPTvmk5HYcFgQT1PTuTVc0oR+G9r38la2++o0kox0s30Xft+f5IZjBGCwC9QQdp7Hk8+v HuaQHg9MglVYnIGPQfrjFKUXywvotE/S+n5WG7acr/paBjC554JwvI65GP8A61DjGeTgDIPHPbvx +VKLjZcttX/wf1VkQ4Jt30S+V+ugueijPBGCQSMZH9M/pRz83HA6BeOnr6d/8iq3W9rbL+utwtH3 VHd/pv8A15ioQNq8lQAe2PT/APXT+hAUMDg4Axxn3H09KUtOWVrLv16/pp6A4O+22q/Pb5koPV8Y 2navG1s+h9OgqxFLErfvDtKgduMngnPpwado2k9lLW3ntt+I4rleq1/4a5bN1pwj+aRAcgjGAR6n 3BGB/wDrqnLdQdEKkDJ6n8BgcDOO3qPwUXeVraK1vKwO8b6aJf1/mQg85xt6EjPTnkc/ge3TA61I OG7AZGB15B5I5xWiT1WyVtvudvwJbslG27S/r9PMXdjLYKhc5GepOeRj2qJ+M/Ujnrj+n4+tSr3u 3bl09V1/4ZBbVa2Suvy0+8o3U7xruVOQpI6YA7/5xXK3Fw9z/A6EE5Zjgjn0GO1aU6dk5p2t9/oZ z5bqN7dvkizYlxE2SxYHHTaCf8n/AD0p8hIb/byM4Pc+3p6Vnyx5vh5d9PT+tPU0XKoxu7X28iEF RjCiM9Djrg4PHHp/KsLxKSuiaj5Y+byjtHzEMSR15x079c4q8NCP1mmqjSs0+2t1/wAAJJ25Vq7X Vna+jX+SPjPLvdE84WQggfLgZwdoHUnI/wA9Ogt5YkMYVjsPJzn5M5wMZ5x/WvZxCjeV46Pt3V3+ P9bnPhLqc+ZW8vTf7t/M6yX5RFG3BwCQwycEZDAdfofTvVFpMMykfLjnsGIBzn16DHtz2FedDltC y6N379tPu/E9uDUVz3tHqvu6fO3qT2O1XWRAMbyuGyuATkkZ5xyCTnsO4rt4Y7m3jaRGHljBCEjA dsknnt04z39uMMU4q0eW6a07X6L89ux6eXp2bjtH+rfge0eF4/MtYLgT4eYbZBtCnp0wPT/GvQbW CVJIZLZ0bBxMvH3cfeAzXir2TfvLl0ktPLRf11O6o7ys42S+9pf8OdhHlAJSRjgEkbdhxj146ite xYlHO4SKDnAyG246c+1Cdoqzd1a9vK1/lf5nnV1HkldbaenYfGxy/llo29CTweBzn3P6H0rQg804 JjLcdDj06jvj2rrcY80tbSj/AJL8jiktN7cu3r5ErOnDOu0oduMZ5z7Y9vzqvdzINhVCV4BUDBPc YI4H1pcsr7crTa+7/g/mXCLTi09Hb8e5kX0gieByjBchWwMn6HHatyDb5S7GIOMhSeueegPH/wBe s6kmqlD3dJxfpo/wte5e1OVnZ3d/v/r7ynJHiUMsfzZALBfm9ssPwJ5qG5kkjmjZSQemc5ye4z+A q38bi1dNNp9tkkVCK93p5eXQ/ePf+GKYXI/wr6zY/PLagGH09s0Eg8d/r2o8gsQk4P6enSmlh1H+ GKh9QGl/09OKryzbCPT1AxjNRJ8ttLDSHrL8uccduaGf9fxxTvp2Q0rMXcuP88Cq0/oCOv5VMmrD St8jhPGlus2jTo5IUrIMjtlDzXy3pGlx28zLA2+NWIy3BzknPuK+MzKSpZrXS6wj8rXsfY5Jd4Oc bbS/I9s8PMIQgOAfY/lXrel3IAUZ6de1duBqpNeRhmlJWult+h2NtdLgDP8AStJJlwOePyr6ijU0 Wp8fXpNSdkTCVcdR9M1GZB2P69K7o1Focyg+xA8ij8O/pVSSdRnB+nSlUq2XYqFPUzZ7kAHnj8vr iuZv75V3c4PPAOK8LHYmyavZHq4SjecVbY5C91Lg4bgH/wCvXG32oBmI3Hpkc9f8K+AzTFNtQT6n 6HlGEUUpNWOaurv5cAnP55/GsCe6miVijFc53YYjdxz0/GvB9o1G0dH92i/4B9VCjFx5ZLRmXHqM keW3EchuRweTmtOz8RbZApcDax4Jx3NdlOraMIuVn19G1p9xlXwakpdLaHomj66pMeXwOAPqa9Q0 rU1kC4Ydu9fRZbiErU7/ANdD4bOMHZSlFbbnd2VwDjGPzzW/EwIwK+3ws04qx8JiY8r9CysbHt/+ qrC244yOn+e1d0Ia2SPPb7FhUAAGMYqQDFd1Okoq9rC2GkAc9P0rnfEGowWNhPLJIkYCMPnYKM8c c1z4ycKNGo72STZdKLlUpwSvdr8z4r+In9jaub64mlWC5feUaHeQxA2qcr93oK+DvFFk8F7ceZIb gIQBIcudnUZPrwfSvhIVouq5Ws+nm9z9Bp03ClTjzWskvuPNbi7jVyNp3KG4OAR0x17EfSsyTW7O 2BEowRleoycYHAzkdvyr0YPmUrLVNadjNwSaW1vx+ZWPiTTDldjI3OBhCCTj0PP/ANemvqVtcKvk MyAjBBxxxz06d6m01NXi1v8A1+hjKUedxSen9X9Cv5u7+IEjlQ3A4xk4H+eaYQFzgYz0BY4OSeTw OOTxW1RSd7O1v0/zf5lXT0k+Xr6f1/wBuwcjq20KR06E9+vr+Qqs1vCF2gFcLgAbiOoJ/pUxsppd Vr82t15Nkc3vOzem3rf/ACbFRBGCF3YB7sc8j36f0x2pTjA7c4I5JAPPQf54qJcuqtquv5/ht5jl s4P7+i1/PderuNPQMO5B2legx/n/ADmkJ+Y8hf6Z6Ajt3/OteVe/Lu9F59/XdFTvCS8/6/QQzxx8 Nx04OCTnH9Qe9Qm/hXcG4XoBwOCeucc1jVk7pqPLa6+7/PX5mUZSWq0to/0v+IqzxujMh/h6HIIO OmMfT060meirnpxg4xn6D6UaxUeWG17/AC7dtfmaXXvNbb+en4b/ADEIGcduOuOvfGenY0duAPvc 4PJOfTp6DrWyjokla+j87f1cE0pPW1v8/wBBCT8rKP4RyCw5PU4HQe/1pBkYBO3OCMAbQxI7nuTm lH3ZKP8AL38r6/L8dyPaO90rdl211G8jJ+6xxg5IGPX196cDtGW3diOCOOpHPT/69SoqanZWS0Vu nl9wU9brl/4fZ3GAFeMnjGAOB2xjAz6fqKcoYZXAweQDnHOdwPb0/wA4puLu4LRaXfX+v+CEeVNS Ub9O1rL9WKGZeeF29ueBjOOO3WpAT1BGQc4JwOcHn059MZFK0koNS0W/qv6/Mc7Xtf8Arr/mLkDc M7Rz04C56gDt9agnheRQofnbjcCw+vTH16960ileMnq1a3o9/S3kDty+67b2+9mONHcNvaRsdTtY jGfT8BWlDZiHb+8YcAn5uWwOe/J56fj9Sc5WShBJJq+22tv+CZwi9LOyT+++/wAu5oZYHHVMAjcS uD+X+c9KepOMnK88gYIHYDIHNLmW8XdaL0at+DNndXd9F9/3+b2HjCBiCcEjIJAI4B6AHt/OoG4b AOOOQBtyeuPy9aFb3WpJNu/l/VzKN7+69UVpcYPPBHY4weOxHp/OuZvPvrg85xhflAGcjg8DjPp+ lb2V5JO1ttf07vV+plPm91NeX/DeY+y5Vt2E+bPAI5HJOe/Qc/zqZwBjB45GOBgEgA+vf9K55KXO 0o73e9v6uuho7K0Yxs+npvb1sVHYBuuCpCjoMduMjBIxn8RWB4oYLoN+3zL8n3VxwByQCOhIB7n+ tbUUlXoqy95rTXfTT7t/PU1i4x5Yx3jZef8AwD4+AOXOMKX5BIBBzjjHJ5Ud+avxLJ8nJJVhwvyg 8jPGOOh45+texWupcu2/3anJTa7W/wAnqdtfwukdqVwCYkJJLAhgqjIPrz04zmsgArtyxJU4YZxt Hc88fh9a4afJGEL6cib+Wt/8j2ZRd97Ren5M1LKJdgV1K7m3RmKRVxID3GPxOOfr1rtdMkeJEius bWbBZuSMndweuM/p6VyYppxTjLllF8yt1Vnf8e1rHrZbCUZK8tLWeumu3p6nruijyfKitwzIG3kq RkDgZwOvHNeqWEW2aOUsYw6qJQWwpbnJA7Ac+nWvn5pxlOKW69LN9fLa56NWPux0+FtfffQ6u3hE kZVZuVblOO3Pr2x2rZsojHu2lSDwx4GD26c54xnit1ycnNGT06dL3T/E8itKyknG7/Hy+7T7icwr K7HGH7Z6dj9PfNWIpHj2wsdrKT1z19+O/WtuVa20a/FW/p/M43JXUb2X3a9F+OpHIyeY4YHDcMeN u3GckfWqMjqkiqsihCNrZPToRz2xjpW8X7tmrXV18l/wCov4FayTs/Xb5IcHi3GCTGcfu2OACxHo ef8A9dUkS6tJwY5cglmVDuxt74bpnOeKx+PmhK+qTT7X312+RtD3ZtpLla1T79fw1NWS58lA+Hw2 c46LxjpVUyrKrAkqMALnGT36Dp0/lQlKMIJve3lZ9RwSjGy6ab+j/U/dzeMe350wv+GPwxX1bbT7 H58l+AK3H+HGKCR2OP0o7Ba1iNif88fyqMsR9OcfWoYW8rDA56dD26jvTWAIwcYH4VDY9hmdgwCM D0oMg46Z/LFTe2gWs/QVTx7du3pUMrcY54ND22tYqO6ON8XE/wBjSgf7X/oLV81aZKIJD1I3sOeG Bz69K+FzmTjm9Z7fu4r8f8z7bh6F8HU6e9/X3no2l3sce3aQCOx/z0rvLDVEXA3hemORVYbE8ko6 f8A6cbh/aRl7uy2Opt9ZVf4h9VINbUOrZA+YAY7f596+hw+KWyex8liMI468ti6mpe/FSHUVX+ID jua9SGJSS1sebKjraxVl1JR/EuPY/wBKzpNUT5vnAxnvWFfF9E9DWlhpO2hh3esKoIDDHTjpXFX+ sEsw3euCDjPTjFfMZljeW0U7XPp8qy98ynJWSOXudTODz0BBxisGSdnO7OB6HgjPT6V8Zi6nNL3u n9I+8wVGMI7FWRtpwMewxz+X41h37lFIGBtzkHjB59KxSXK7LVHrRitE9DnLlmWEkADn169+MVzf 2oq4OSDzgjAx9a0d4SjdWdl/maQh8b/rr/mdbouuGIojHbyRncB3Ar2jQNaGEG4dsdsdK9TDVWvZ uLs18j5rNcJeM/7x7Ho1/wCYEww7d/8A69ei2A3KufTjHFfoWVT9ot9j8ozSl7Gc42tZm4oUELwD 2HSpgMV9RQhG2nQ8EWiuoCKSJHG1s49NzL/IiuR8VeHtI1jSLu1u7SGQNGxRmGXjk2kBlPUEVwYu nTdOpFrdP8jWjOVOpTlB2cWn+J8D+NLddKiubNGkh8uRwnmdSuSep+teD+To10ZUupY/OJbIcgHO cYGfavzty9nOcuXbRLoj9EheVOE9k9fI8f8AGWi6bayGa2RRkkMQQMZAA6f5/OvK7rTbeZiGCA45 bA4yCeg5/wAivUwtb91eK5U+vZevc5cRD3oxWj/zMptGtgSFBAHBKnkY4yPQf4U5dOWPIVj/ABYw QMDHBz37+vX2rsbvF8qtf79d3+JnyqLvF2k1Zf197LSIqADHy/XBB74IoLDlTwc5HzHDAZ4Gfx/W sU5pe7FKz1Xr/wADYFK0Y+7a/wCHRenQQkjg9MEr0Bz64pMYHUA4YHP3RgcAfkf8ahXi22uVJ/iv 8r/1YVrNdGunf+noxcdPlGc4BxgcjAGD169/T8m4IYbRgDqOMcdePxND1UVdJPt+vlewWlzKysl0 /X7yPb1yMDOTnqCc8cewxUY9eQAR6qAKuUFaSjo11/X8x25U1v8Anb/Pe3yK0sCSA8FQq4JBwfXI /AZ/Gmi1iCYA+Uc53AYxz/8AX/GslpfW71VuvmLljo7730XT1/rdipGkY2ooULwAfvccH39MZp2W HGdvHHy4A6Y/M/yNW3KKaSvvp+b+b/G5SjdJbvp6662+77hucDqAM9h2yDjA/n+lAPXBHJGeqj6Y PQ8frVpqHKkruPy9Xb7/ALxaWi1q1rfzf/D7CDjICgcDAHGW5xg/n1oU9cDhewwfx+v0rN3Scoxt 5/111v8AImOkpWjYCeRt4HTPGAcZxx9DQDx8uOwb/wDZ6fj6/jTjyxcVezu5fPb8WEfidtLu/wCO +gq/JwxK46qDg8+ucDuPzpB8pzyMA4wRxzwMk4HrV+1V1yu7em3y/wCD8xuHKl72v9a/L9RwIwOM DPIGDg46dPqKeCAcDYuf4QQPcY98e9KUYxsnotn6dPn1+Y4pJJvSzv8Ah/wfwY/I24ztxuC98ZOR n9Py9qFOCVIVV7euee3+elVBOL5VbTvv3t6GbW9o2/y1+4lR1jUgoX5HUlSDj/PFR8YbHA6sAMfK Bkf0/Kpb0TcfdbWi6a/8C33lr3E4tea/IfxyBwBgjDgkc5wD1I5788UFiMfwggDGRx35wP8AOfwq lTslry2adtv61Ycr01s+39etxd3+764GMY6ck/jULk4GBgZBA5Vh147VopQi+RwVtGu6/Tf8NTNR lGzdrr71/TRWcnaSAuSPvDgD16D3z+P1rmbziQ8AqRzxk4B9fwH6VUVBTVl8Lv5b9zGdRxcNNb9f w/LoSWbRkfKAoXL4+7jjBIHbg9R1z71K5G7Cgc5xkbduOQMfh3rmcvfk0uV62fpov67HRZS5W9Ld vTT5PUrP9BnDAABuOnBx+P51zvihWOgagE/hRmfnA+63A9Pr6ZFbYazrUot/y3tvZyW33foLSnGT +1fX0stT5EA2Hay4wWDbjzz0BA74J6dq07ZsNGFG0bsnsM99pH+fbmvZrttycdot/wDAsc1GSTXZ fl/w56dr9tFa2FhPHIgBgj8yNiM7wiDIGOnB6DtXOzfYpI45YX2zKTuhzgdcqc/U9z68+nBRuoYe VtGmn3Su918lf5ntOaTdOK8/RXt9/SxZtBiEBgpCPnKttJPYAj3HI/D3PaJGJ7KCYbAQwVzj5+MZ DAcn68da5sVyxcJt2SbS6XT/AK0v2PWwHL7OpdWvZv77fm0el+Hits9s0R+SRUV0ckbcDk+ucn15 7ivarF7fylCnD7eFGTxgcn868C7jUlGUW1r6XTtp8r+dr9z1cVpHZ9b/AC/roa+n7wdxYMCSBjgj PTp745zXQ2j4Zl5BJGOVOCO2a0Vtb7Nprt3S/I8TEKznaPK2W/ORWKnarE9Dg8ng8dqlcxvt2kbh yMkccnjH+egrrjyRknLV7fJ7fgcThpCdrNJtL8vvW/zICwdtqYVhuUqeCCOv86wYrRoL2cSyFo5P nSIgkA4PQ+ufyzVON6VWmtGrW+Vmn81vY1oq0lfaS+7/AIbc1iEDophLKMlT1x2HPapISuWDAAbj gHHyk8/hz/nis1K8Gre70fbVpryHLls9bX19NSdWXBj4C4AzwR7cVXMKxS72X5TxwM4GQDjHHXNV pLng7K+34fd/TBNwld6Lp69/uP3Pzj6UEj/PFfTt207HwdvkMJII9Pbik3Y/n6VN7AR78EjPrxg0 gPFTfoO1hMgZ/wD1VGz4yB27dP5VDfS1hpakBc5P9KjD846c9sDFJdNC1HQsBsD+XY1XmbAOB+GK L/IUFaRyfisj+xpOBjJGP+Ak18tLOqPlSM72JyPUn8a+Dz6Vs3ml/JH8T7nhpf7LW/xGvBqTRYGc Eeh6DrW1BrjIRhiB9SMduledGbT2t8/Lb7z3qlNbJWX9dDprHWicZbaOD1x/9bvXV2+tBUGZOOMY PT+lepQrOFrPY8TGYeLvHl1LX/CSKv8AH06c81Xk8TjkBx+eK65Zgkkl0POjlfvLoim3iXOV3Y6j g9M+mKg/tljwH4yR6Vy1MbO700/H/hjrpYCnByvH0M261XggNjrwTjAzXMTXxdiFz1P4c142LxC5 m3o9PzPoMDhuVaK1hGyyA5GfvbeADVcHGBjHPTgY6/5/GvErzano9z3sPFRVrWsQTEA5wBjrxng+ /wCVc/qU2Tnb9T7H1qKck5NdH0X9aanUkrxa6HKajdeVHs2HpkMCMj6iuTlf5jjBAGSM4Pvkjj3r ep70+ZLyXl5m9KKWt+txIbqRGDL8oU88YbGfavTPD+tlQg39+f510UG1dPbW3fpscuPoqcGktr/I +hfCmrhxGC3XGO1e96NMHSPnjH5f4V+hcO1U48lrNJf8A/HeJKDpVJO1r/5I6kKpwcDI5B9Kkr76 lFKKa6nxoUVoBWulzC6hWJ2nAQkNkcjBBH86+c/EfxC1a1k1DSTFDbXMciLE87FF2MwUBjGz7SAc nJP+HzueYiph40/ZK3PeN/k7HrZThIYqrOMvsJSS+aX6nxn8QrvW9Xtbi7Mc0V0pJ8xRuiZcY3Jy e46EelfIU9/fSX0sNxcTJLGx6ZXBBOBxjNfJU6VrSkr2V/W9v1PtopUoQjFWS2/rsUb64uJUKysz bAQCxJbjt6Vz0ny5PHbPIBxkg8k+3WvQw62urQXlpb+tfmc9ZSVlfpuQkqH44JLdAM56dsD/APX+ FMkAyGXhSBjg7gec+w7cVu+ZaJ6v8PT8fuOZxVo3bv09V2K+Dg8gEHPp7+nv/ns35cgd+nQ8ZwcH rgc0OSg1Dltonftay26hdWu1f9GN2YG5S2QoOMc9hj8qAwjJzwgwQeckg9KyqVLSSnDTTT77/h32 Y+Xld/5f+H/4JLHqGmrjzJo0ZR8xJClQcdP8ioxqVjnKzRsOSSjgYBHUAdOh61D3cFGySVr9O/4C TXJdvVFY3loxzFMuf4RnIGeRgf09fpTXkXJx0OSCN3BAHPHuTVxTjO8nqvlpp+vMvmQ5KHNb7Xlb +nsN4C8YO4DsVA7n0/zioiV+T5QCDnA6ZA5x/OqXKnJyS1enp/VrlXdox2T/AF2Qg78FsDlchf06 9KQngAAAAfLgjrknt6f0/OFZOTtrr9y/rp0C/I7x0spa/J9PV/gNOckKMDrjnIOe3H4fhQw6gHae egwRnvxwKvbmUVay/HZv77+QnaKaj8S27af8Ncbz8uMDIxgEnLev0xSY4AHGDwVyuMdiRnt6VaXK rSjvrZd9dv0+QlzRailtt/wPk9xTx0yBsJ4DDHHOP8+nWlwenBA7jjvjtyazc0pptaR/XfzHJcs0 lGzWnZ/8O3qAOGBGMBBwORn0JP50fdGf7oJGMgjnk4zzjP61VNRUfdVrXaffX/JCVrSvpf8ApfIc vGDgc/KD06ngcfSkHUe2cDdkeo5xx3/MVKUufl5bx2d++v6FLa23LdP/AD/EmH8QBU4xx757Y+hF OBwMAc9eCAF+npVK6Sdvh/8AbnypP9Oo0lbmitv+G/UTIU+nJIxxjnpnoKADwMnpuXPOODkHPOPc VaXLfn01urP+u/3oipdayXXbayf/AA2o4HdxgkDgEAY6YI4/D8qUEhuMAY754I/TnmqfLJaxsna+ /ovw/ETsryu7Wa/AQnoQD04BxkE9jjocYqMkfxBsEZGBlQBxn/64rNRnBOTa0T0+9fLcT05mun5/ 1qUZZCqsoCnd93GBj/62K5W4mYuR90DPyjAIxz3H6f5PTDm5JNRtbv5u79LbGLfSStGP4f8ADf8A BLVkxdSAqrtOCR/Fkgcn8c1ZfgqBj/eHHbPtk/THWuZJpuTvZfdr0+/X/hjeEo+81Gzey7kZIyCC cKAcjAzk/X6fnWB4ncQaHfnYSvlnOCAdpUg4Hr2x3rXCx9+Kta7Wuzvpp/XcOaPI1GFml+H9fkz5 GnO53ZQFLvlEU5IIJP161NYKXki2j5i4XGCFAz3x2/x9a9mqnHntp+i/q9jkprlkvK/5ntXjnw9P HpGg6hFA8kckEcblARsfaF69ugP6e1eXgyRzonlMu37ykkE9e3bHt9etYUlfB4Koo702vnztP53f 3WO5NqtWtd+9Zelui/rc6G2UMoJAXKjIO7GcE49sk/r1ruLZFt7aJ7YK0bZjuYWGGDDIVl9BkDuO vpxXlYm7dOM21Fu34WT9E7H1GBp8lNycfeVtO6bt+GjPTtGeK6W2JV4sMMAgAgoQBwP6V6tZ7dqM RjanBI2g4yPbGcDrXi8ydSL2sn377fPTV9z0K037seW1ttej13Ni1uGDnYNyjBUfd4HJH55P+Nbd ncxzO2wqJFOHTIXaRxyB+H5VrFKF5dNF6ef3rT5HkV48rXvaK9/S/wDT+RpCIOQxToRuIyOp6mpw I1JKoQQFJOcbcZ6gZ46/r6V0NP3ebdKzt5HnuUoq19NvkR71BDAiJiwGNyjPPX6c0eURKGwZBngk kY9ev+eacmk5Rj8X520X9dzSN4ckIq1v+HT/ACLM3lwRMwACquduAGHrwOvessSxSx+dCVwx7Pzu HUdOtClGMNY6N2fk2n+v3hTTd+vJ+T/4I9fN2sVYjj5cE4OCMD61ZgMnlqJFxtweDjAPXOeMdfyr OpZpSjCz27XVv1f5G8uXkaatL8rf53/E/cvd6f4UwnAx7V9S3bY/P7W8hhfHoPrTGcD6VLfS2w7b ERYZ9Panhv5dOlRsDVtBrED271Bu5x0/Kk+y0KStYYzhQO341AzBcFal+7a2hcV2VkSLJ27exxSS njg+ntj8qGuokkmcZ4vfbok3JUDPTrjaa+QxdfO3zAfOwGCAeScdPavgeILf2tVS3UI/efe8MR/2 SvZX94nW6dM+noc9Kd9ukU5X19cHnGOleK6zhG7X9f8ADn0vsotF6LW5osKQQMcYGf0FbNr4hfIX cRnnBxgfT8v1q6eKXM23a5zzwOnM1uySbXXViCxXHTBIPf8A+tVP+3ZTlQT7ENzUyxSvZLZ/1/ka U8HCydti/aX0sh/iA7A8c/Wt+K5lA27SoGAG9B/KtI1Va97X/wCHRM8NFS91WuRzF5ATg4Axz9T+ XWkghPRhjHGQMYP+f5151WpeT0tf/M6aCUadlui2UKjHYDrjpx1qFo8AfqOR29vrXFUcuZpaf1qd 9F+72sU7iP8Adkr8v8IyQoxwP61xd07h3GQNvIweOP59K0ppQdN2+L/Lc66Ti1NNHL6m4KY6EAcD jOCfy71y7MfMAXIIzjP+f8K6EnOq7qyve3X/AIb9Denbkat3/r5DSwWTLAqDkdhgD0rTsrs275Rj t6gdOf6V2QUYXstU7X/P/MymnKLW6S/q57f4M19d0SswGMA4ONvPtX1f4V1RJYYwGH3R+FfWZBWj GtFRfxJfqfmHFeFcYXts/wBEeowOGQEelTV+nUX+7ifmbVnbawUVqIQjg9v6V8h/FCxlXxdcQX8Z e2ubGykElupiMbCZyJee5+774HpXz3EMJPC0pRXwzX5M9rIZxhjXfS8Hb1ujzBfDurm1vbZ3jjia 3ch8CRCT0JQjjgjp718Q+LNCeDWL5HIklhnbfKieXvyQc46DOa+TSUJ3Utl8v+HPsYzu0lst/u/4 Y4C9hZRtYbWA55HX6GubmJBZSNpzjgHnvzj3/nXoYepypReifRdd0Y1Jpcytounro7fmVdzAhQCA OG25AHU4yfx74+mKi4HBG0846YAGOeOP/wBRrdRtztaJ7J9/+G6dDldk5a73t5aaJf1uN+THvjC5 AB+oA796iLYyeRwO/X3/ADx+VS7JuUnZL8P+AFnBq7vuvxt+pRnvY7fBYdACAARjk9qiF3Hdqqxh s/dyMj2x0znnPTiiUoczS11X67/qDlvHo9rfd/XnoZVxoiTE7ixZtx4ODg/h7n8qji0SOJdu5iwA wVOR6Uc7ipXiltden6f8MZqGrjtb+lb1JYdIWDozjGCoLE449e/P8/y00TYQD0XONuex5PTof8+x VcXfldlbS3ff/gfI0cdLPTqvmPBOAQCB3PGVPUk8ehNNc/ewcAdFGAc8ZyR04zWS5ve5Y7WX3/r/ AF0JtFRVk/d6fr8ho28kHAAU/MOhPAOOo4OCT6Z5pBsA3AdMbTnj64xx1/StG1e0l81r5N6fkPTl j2tp/XmGRnpn5T7AdDUe5eRsxkYGAAARkf56USdn7nRLyvfp/XkJvk0cdNX5+X+QpPUAkFRxjp1B OO57HtnFNycgDjaD83qe+R/9ahqXLFL5/hYtXV9Pe/yb0H/d+bo3bOVwSM/gKTLY+bgdwOMnjGMd On+NJtaW01vt66v8PkS7XTttr/X9dRwyR1wcfdGMH/P9Kbk9cMAVyuOoyO47DildU3JKN0tPw+5d fvE18Ljt1/P/ADJMgYIYrtwWHAx3HXp0pAzfNxkAdOh/L+vtVwXxaWbV/Tb7u33iSsopLXe3bp+R IAQVyPvD24IH09PQ9s+9TCI8FVPB6jn5c8DjjPT/ADmlzaJK67/hFf153K7J+6lYl8psjCkEZY5x nAOOOcDr/OoyAgIxk7TgZ9CQe3HAqeWakknaytbprrd+liZJ3be19PSzf9eZEXUHGDwQMkZ289c/ Uf0pQf7uVOMnGVHXP5nA796r7EopNy7bLTX16fMUVFqy07evX8NRchQOi+oOB1xjjn0/Oo2JUHj5 hnGeuCeRWlJ2fvLR+WiIcVFS06rTbtr+hnTuA2CeGHynOMHsPx5+hArnboAuc8Mp4AO0PzjJBHua pNbq6vffp5ffr6ESjFbaq/T5f153LNgOG3YUZb2w+CeOwHOMfWrjooGQv1HGQTzx6f5/HF2gmorR u/8AwxtGK5eeWjWvy7L0/wAyJlTC7V4GF+UjBGASe2eM9q5jxmxj0C7ZANyq7YzxtK4x27ZP4+lb 4eKdbDN+6k1f1d27/ekaSXLF80Vp27dvusfJs6s0zGONcbi+E2qMZPI/qPWtTw1DENYs0cDY04Do 3AwSVPHQDjtjoR2r2a9o06r62frp2PNp/wASEk+Wzd/v/r7z770Wy0660SKzu4I7m08obY5BnawA IK4x04rw/wCJ3hTQIoY7/TVS2uUba6IQFkbPU5IKnj9e1Z5VN/V1CUbwmm7v7N9fzS/E1nOUcS7J pO34PTTv29EePWfA2s24x7c4yXAJCnI7nrj6da66wutqqreWodhlSQrAE54OMN1Hp1+uPLxlNacj s4t/NbpfJ2+R9ll1R2jGcrRkt/ut91tfU9t0W0VbW3kV1AARtwXcXjA6gD2r0q02NCuFJGzCkoRj PQY/h+nFfP0puUoVILl5m7r73Zr5W9TtrdL+7y/l/X4sv2EDeXJuYFlY7VGF2DqPYDrz71q6VGpl lXYsTMDuO0B2OfateaTpVHHRJ7dv+AeZWTbnFJ31/r5m5ETbsyNkH+Fm6ke4+n8qd3ZwDgjgdP8A P1rojDllLl0i9V3d9vu/Q4G4Nc1rP8v6/Iz7uyeYKPMMRDqUkXlgepHA961YEMUQVzuKBRycHpz0 oqRv7NJcsoXs+jTsrP0te5bbjCPb/KwkhTzfLYDBBKjBPBzkfr1rOt9OigmkW3jOx23ueoz6D0HP T3pXtCdPo+V673X/AA71LpxjFJxdlL/P/gfqa/log2g4cDABCjB/znvVYCcPkAbADkYwPTnnOOfT /wCuOMVCUbtNWW/TS9vvZcFeTdrJf1+p+3ysfXAoZv8A9XSvpHpZHwXWwwuOOwHpUXmDp9KTetik hoOTx0/KlZwo/pUt220HbVdLEPmH/Ck3+3OeO2P85pX200RVrW6WInboMYGPyNQ5wMe4/wA/rU3e 5SWluhID0x0/Kll+712kUPZglqkcV40B/sGcr/D+HZq+JIZm8yRSeQ7jgnjk+vPpX59xBpnVSKdr 042+9H33CyX1Stra0jetyDgMSR0GSQecHv8A54q8sIz9046dee9eBVv9nXrb8T6n4dmWI7UZ5Ur2 Hc4+v1q6LVAOBjjGccLXK5Nc3Sz/AD/4BolokQS2pbP8WMAcYPp1ohs8OMf3uv8AOsudRbu7Pf8A E1ppKCXLa2/p0OusLVmUAqqnAAO2uggtgi7SSB+HHT8q7oVFZcz0e/l/X5M4aiSm/wACU24H3T6c DHX/AAqWOEAAbSCM5AHSuOco8y6W+7U1glyXWgySMLn8s471mSllzg8AnI5GO9c8m/aaO19bPtpc 7aKVu3/BMC9uTErDLYO7POMZ9M1yk8g+Z1OBg9sYzyP59K2oSvUV5WS2f39DqjHkg2tLnHajcBmI ONwwcE8f1HesjcMj7wbqOMfzrtou9VSttv30/r8DW3LGLtZW+Yszx7BuGO45AwW5zz9OR71UWQE/ ewOgz2Pb8/8ACuzkvfonqv8AgmEG7SVtDe0nWJLCVTzgHBIbGecdq+q/hz4yt50hXzhuXCspbDCv Tyur7CtBX2t9x81xJgPbYac+Wzt8tj6i0jVIZo0ww5HQGumVgQCOlfrOBrKdONmfiOIpulVnFq2o 6ivRMAryP4myQQw2Ty20U8DeYl02FMkSjbsOeoXcfzIrzM2ko4Gq2lp0OvAJ/W6CTtqfLXizxDJY LMdLSGS2Ek3klp9pVBuABA6gf0r4x8V6lO+pXNxdRMkk7E7QgC8AA89+/Oa+Au5TnbS/Raa3sfoF FcsNve/U8r1OaN2PzcZOAfUdP5Vy07jsMcjjnIyQP19ODXoYaLVuV6q1r+exhUSbTtfbS3n/AMOi iSVGO5wcfKMY4PQcHmmFgMfLg4yRjHXqc/j6V3xkmnFaOP8AWnq73+85klr06/frb9fIrkLkBeOh 5LY49j24/WmkdcfKc/KFLBsg8gdOvNCnGzglfVr5Na3X4IlcztHmsv08/X/glaW3hkIMi8qpOO49 SMe+fXpSpBDHjaANmSCuePft6/561Cg1JWtZrTt5fgNR193Tf8v6+ZJnb/Fwvy4+bHTORjgfzpgA x2yM7QMjn8P1rK/K3K++lvw/4IJxjJ91fb0t+F0RZA+Ujjt0GB6AHGM8Dr/OkY/KBg/e7ngMfk4P 4/57W0v5Xp2Vv6s/wsTF7a2V/u8hpJAAA47DOPyGeRSMRj5Ruxk4xt3flyOnX2oXLCTu9+i6f02k /mF5JuKjZ9l/Xo/UYMYzwp2HJAPJ7gHPtTFPHynaMAqTkcdRx3P41CXLfS17/wBeW1ydNH56ruv6 2DJz83TOMBfbv17fzpCeo4xjoCd3J7/jz+pqkmnt2+4b5k1y7La/4fiNLcbVwvykfeABxz36n/Cn D5epH988d8np0HT8f6jTdtbNb+t/68xybUtH5L89RB8p3buoAzyOf8g/yoHHLADndjsvHb/63FDk 0o2j7qdrddLK/wA+g0m5c2yf4La3l/mLuB74XkgnGcc8Efl69aXIGBgKQSdo2/5PY9/rSd4tQ0j1 t5bW+S1Bu2zt1+7/ADFBHGTznI9McHGD17dMfpThhQF3EYA4xtx0GB+tOMleclsr/c3t/XYJNpJK Oqe+3Z7jhJ0wcbRlgOOB1Ge/Trx+VSDVIbLfvCgdxjBA6/h3/WiEX8NrR6vro9F97+4Xub82ivf+ vVkZ8S6bhipJG0kZGcjnpUQ1CO5f9yGA5Y4A749T1/zild2bV1eS8rLd/mJyUrcvou9un9dicE7Q MYIxwMenbHbnH50d9o46Yx2BwT0rVSXxRjZvfo1v92n4goNKXLpbX5geBnPTIAwO2ScHg9sdcCom OcgKCedoUZAJ5x+Y/SqnU5INxd+mq0t/wbmblZO6v/w17WKUx4VdvKk46ngc9R/n+vO3OQ+4HBzz kjjJ7fl0+tEFolrFK7t26/ejKN72tv8A5f8AALVgDz8u3ax5I6dlOen5+nvV1s5HCghmPBPPQdu2 McfSsYPWSlePkvlb/P5nXG0VT921lb57/qRnAU4TjJwM8H69Mf8A16x9ct47nTZ4HwNyMoOQOMcc kf5/SujD80JwaV2ns/LqZ1GvZuNuVtW19TwL+w4bIS7vmdWkIYbQAOfX09O/t1rA8OwofFFsjbTG JQSVwpA7Yx74PXtXqVZR9jintHlaX3Nv8dDjVJUp0F0b/wAr/mfaN7fx+HtCjuGbEQtwytnKgKOh I6V8veIfFY1u4uo1nYwBi0YBBQOe3PXgHpSwso08FzxjaDX9L7jrpQj7duV1ZO3re+v3I5C3dzcx yxyS7gwBQrncM+nqAf5V2tnKkTRM2XhbAdcEMCeCRnjPuM9cVwY6m5RSh7smnrfRW+Hz16/5H0GU VP3nK1s3a/Zp39D23RrlHsoYoiVcFBEyvtZiAAMYwM816rpUz7USZWjJUMVb+LrkjGB+mOtfM09K UFdKSu396f4XZ7mISXMlu9vz/M6G2RNz7TgnjaRgZHOMfTmt22gVV3HGV6HOcEY/z0711xenIo2e ll8trnjVXK8+Vv0/EssY2yrYAwWDKcHP48dDTkPBB6DGzJxwevbFbyaXKk+W17X37fd0OLVK/V/h pZkMpXySy7lK42nAwB6j8uv+NQ2t45j+ZSHQ7G+Xhu2R69qznGUeSotWnyv9UbU1eD11S/q3YfJm Ubom2sucAg/IO4/I1YicwL5q4ZzycdeeDn/PrSk/aWjJ8trp2t8l8v1LtGC5EttvR7mbql1Ntjlt wc7sMi8Dvzn8aiju5fKJ+fcu8c8die3Tn6+gp1eRKk+flet+y1tf8vuN4UYqm0tGndemh+5HmkdM D2o8zPHT+lfRNr0sfAWt0sMLlQAD+XrTO/XB9KS9Bqy6Eu7A/D6CoC+SP84qXuulhxXXYAwHQD+X NNL++OaX4JlW8rEbkrx/9b+VMDcDsB+FQ91psNaWJVwAMY45GPSmTOduPb6fzpt6O+g4r3kcb4t5 0C5UnGHQZHGMg18KwyFbmYjgLLLjjB4Y+or4DiFP+15a2tTT/I+94XssLiLL7R09rOCF6A8ZHHUe tbsMq5GSpB5GD1r5+pom20pbabas+lal/W1jWi2ZG3HBPT65qzxn0wMcjI3Z74rklaEeZNW/r/hj WCs0h4RcKMYx2xjNWIYBkdByOnGPyrCVrKG3/BfQ2+FbbHUWcOFXsOuD2I9K3YYuF4wMYPH9a6E3 GEuXT+tf8jz6ktXK1tSQQIG4GMn6AZqXycdgPfGMf5/rXLo3Lpd/kNSdkilPHt+nUYIrAusLnrjP QY4PrWe0pO2q/D+md9F3itP+AcZqZYIQBx0AGMc8/hXO3MtmsBzKqSNt4w3Aw24HjHpj611UbXcW 9bLl/ryR2y5vZw5Ffv3PPbqUmZiPu7u+M4z+lLHIqhSRxgjkgnHU88Cu7B6csbXvf5dV+ZeIvGKj 1t92hWvGVflj+RcjAzgkHkknuOP0qgpbpk5U8Y447fXrXXWcYO3Ltb7u3r0Iw6urW6/gWSx7YA/i A4wM5FdL4d1ybSr2GWNmC7xuXO3Nc1Cr7OtCyvy/1t5foaV8Kq2GnFp7PX8j648FePY52gQzgZCg AsPvHNfR+k63FOifOuCB0NfpuRY68eVy22PxHiTLHhqzlGNv8/8Ahjp0nQjII/QVKGHb9K+xhWjZ Hx9raWtYRydjbR820lc8DOOK+BviR4g8SweMtfgupZYrUmIJBvaSBYvkIC8DgkK2cdc+lfP8Rybo 4aO0XJ/fZ/8ABPf4dpU54qtzLWMLr70eSfZLnX7naIpVjWdpCWbMRO8kADjHGR+NcL8TtJsUSKBb cLeKCDKpVQAMc8Zz+NfKxfJKOiTv9/qfXKCTdnffTyPmfUrM2zMpfsctgHA9P161ytwG4I+UZODx tJH+yPftx2r0MNHZJ2UbHNNctntbb0Xf1KpOM8kAj7vPGeMYHTOaZgjpjqdpywJ44B4rqtyp8sbX 89l0++/4nM3azUbWa/r56/eMK8DjIyCPbn/69MZSM8hecfLjvlfbvmtIONKKklq3t80vv8uopJ6O MeWK/r+vQgLbe/OOOvAz6/8A1/ejA5UDGCCDjOOhHXv1/KoVVU4OLWjf4300/rp3NOW3Ny/a/r7t Nxu4Jk/d5HBI9+MdOn9KaCdw4xgAdcD6fpWVSdvc22+SVrfpfz0MZKUU4x0Wn6t/kMyAGXO09Vxx gdDgfXPrUeQBgj+hwevb2NUp2cntfVPvdf196KtZXkr2dgPGQSq9Dl+gB64wceg/Gm8djjbjB4HH YfTk1LnJKo7W8/6/yJVk3bTz9f8AhgAVckZGMkKuBg9Dj/IphfB7Adj19M/Tjn/PLb91pxtzX/r+ ugWsmtEJuyMLjjOD2z3HH4VGQcEHKnJJ6DBxznPv+v5GarsouKtZq3oncUknyuNk1+QHP3TjHGAB jnrxzz+g6UrHkjn/AGcbTjJJ6H8+RVuUVNWW39f16Dair8q+f5P7rDeh6/KhJAyQT9fWnE43YYZG Aw64GMY9j0+uRSlKzjpfuu1uny0RWqslrt6bv+vuFLFRyOBt+XIDYz7j154o6c4Gepxy3PA/DGaf RpeaX3f8En4m5bbf1+Q4ldy465GADz2yf0Hr+tKAVHHyjngYwCCe+R1J/n60WesWrKK6dNf8301K vG1mr6W/UNxXsFDK3BwCO3GPbH5/Sq01ok+dx+XGCG2gewH4kH86IycLKKtG93+nz119TNQila3o vLV/16kA0uEABVXgDsOPUDse/wDKrUVqkC7VKjvg9cnkYz06dKpT1lpeydte/wDw1xW+VtV5dOnU snaOyqVGBgHIPTnp70oY/IATnuOMgE9fyp9I8q018un+ZKdo3j8K6f126ACc7s84yeg6/wBaaflI wwXqvX/PpQ4tRVPdd0FldPaz/NlGchVIJXGDnAAPpntjrXOTKoJHGVPcHg8jn/6/c1rzOMm4O73f 4kNe8327f16lmxBIJ+Uc4IwMdOfl9OefrV12VDjC5wf4QR2OPT14FZWn7WcN0mvnZafct/Q1jdRU b2t/nq3/AF2GEhSOdxXIAPcdenfr7frWVq5IsmIx9047AZz0B7ZrSlf21Jc79PPX/gXLqxtSdtNP x/pHkV/zDMW2qR85yAFT65OD24/2T1B44zwTCLnxVGuCV8xiGAyuzPcDqM4546V6lR+ywtdvVav5 tLT8zjaXtMOrbPTvr+h9e674el1nwfd6fZ/PcJE0kKrkPkAnAz17flXxzLpd7pUknmw7TvdZAwCM rDqCpGPbHHY55zV4f38r5Vo1Ozt2aUr27N3R0Ydv2snbZXt5aL8/zNfRbKUfZrx42SEyyp5rD5Ay kZBHJ56f8CHvjpgg83yJI2SF3+R1OBuOM9umT14/pXHVt7OpLmV0mo9PhdrfJHt5deFa8XaOl/8A t5f8Mz0jw0I4pobdmA2SHa7yfKThVPBPHXt6kV7lbrHGkDv8xVAqucEk9SPbOB+f418pGSdapyK1 07JdnfT79D6DFwa5ZQVtbr5nQ2oAycAfLwT17Z46jPWtO3O1mTBBwQD2AOeeOn5d666b0SXr6WX4 HjVLpz0t/X4FlEXpIyhs5BXk8nn/AA/CmzMkaqBIVYnCtg4PU9vp7VrLl9pft27df8/kclpt8yfx aLvft/XYhw7QnaNueM7Tz1B47HIqKOZ4yYWU7RHlcnILDr+PFZt/u+aDu07/ACvotPLqdEYK0obF yCZCmcMrHqdpj45/H86ngTepDsAoPy7eMjnqO57/AI1EdFK7u7pW626/gTK0Zuzso7fctihqHl28 bEkbQOMAn6dPrWbbQ/aHOxsBvmZsEAHrnH1/pWlZxpQhzPfbtf8Az1NqXM6c29Nfu7/f/mfuM0uP b9KcjBsDOP8AD6V9Euy6Hw1tLjyccD8qAcUr9tLCtbXYRj/n61XJwcf0xjiod+YqKaQ3d6eufSmh jnrjsBUtvmUVoXZa6Dyf6/h1pgOPbp/nii1hWW1yQHHQ/rUcrcEDj37Chuy9AVuZHHeLnC+H7ong K8bYHHc/418DWl7F9pu435IuJCuDjbyenbqP1r4PPpJZvNpf8ulf8Gfc8M3+qYm2lpfob1tcAEbG 5GfVSef/ANVdFbXPTPHAOenPNfM1L7aL9PNfn8z6uN0k7WWp0FvP90qwHp29a0FYMM5wTnIB9jzX NK15JLRbf1/Wti07Wdrf1/wSxE4BAI7Hpjj24/Cta0Ee7sMj5SMcev0qOX95B23/AA0/zuXNtL3d P0/4c6m2C4AwBxwfT/OK2YhtAOR06DvW0uVRalo0l8v6/Nnn1e1t/wANf+AToOn144wf0qVhxwPb 0xXI0kmmvR/1+Ala6RQmXg8YI7Zx6+lcrqJCA84OcY6YrF83T3T0sO9l52ODv5yuQfu4OBx7dPSu I1KSPy3DLgAllKkKQeg6dO1ddBXirx1Wnoel8Nrbp/I4qWXDN8xGGH19cY7UkpZYtyH5GXnsqnp0 7V6VBe6/Z6W77u39MVe/PBLS7+8a9wHjQEcrtyRwCOccn1qFcfwjnjH/ANcd6MRNNPpfQrDpRcm9 NfzLCjgA8Hg+/OelXLeNt6k9eQT0/Tt2ry3O1S0dF+Wi/U9TkXJZKy/4c6vRdUm067gMcpUKy8KT j1H0r6b8M+PPLSJXcfdGcODj5sevFfVZNj5Uoc3VO1vu/wAj4XiTLY4iKfLq/wA9dT3HSPFkNxGu HHTpk129trEbhcOuMZwTjFfo2Ax8KkI+9q/zPx/H5bUoVJLltYvnUE2tyMbT0PTiviT4lgXXiq9u HcuhjiTA25SNfY9fvZrnz2tF0sMm/t/ozp4fpyhia0mrWhp63R5Wt+tlIyQHYSSdvzDk9sD6/pXj Pj/WVa5YTK8bqpDbyAhBydw9Oa+bd+aDez/r8D6yPuyS2ufO2s6pG0pCjcAcDbnH+PpXOm9O0oIw yliMsgJQ8ZKnqp6CvWw8OWnyxVn3276HLWailZbdPOxS3li2AUK4JzxkA56n144/OmtcCP8AvAYy NwAHvnB9T6jp2zx0qMYODv1SdutrfejnstJRen9P8NiA3QDfLg9doyOfUZ7dfr+VMFwJQfl53A5+ Y44Hp16/zolF3qNaqL08+v4PfyIU/iS2/wCD/XzH7cnb/EAx4PXoTwOc9T19aBzggHoBgcgH0I/E 0kklTimlotPK1nbz0/AcPcdrtaXT6f11IzxklcLkZzgjAHp07n9aDnH3TycgE446Z46/SlKkrXvZ bX+9fdbX1BfFaWuj/T8/wsQs3zHk9e3qeB2//XTSxxygB6jbwPc/XHbpWTXKovdbW6db2/TzJskn dOyu9Ov/AAw0nJGV4YHAyR8x24OD/ngjmmn5eMMDxjJOBjt/+v6VScUuVq60t002d/zHaMbabPTv 1/4KGEqrY5weOcDbx6ikBHHTA6dAQRxkfSnqopNbL8L6/gTdRjft+LugB2gjAXa3XaRtOePx4pvI I4+ZgWIA+6CT0A+lSlFWjdq23+b8rJ2XoDcenT7r9Q5Xhs44weu3kEHr+HPrTT0J52hTj1OOR0/H H1qkoyjfRW6db62+8Oj/AE33s/lbQUtxubkc9Gx09R2pG6nAAAHIzgY5IOB6UuVrp1dunf8AXUFp tpb89B+FUZPGAQBxk+3BB4OKQcfeGAFwBuyQ2OOCfb1NXFrlVl3Xzd/+BcfMtbPt9/8AwNB347cA ZIIBU+nrxz2xT+V3ADB28ZwoHPTjp+Qpc20XFLla+7d/5BzWSsrbf1+gnrtxzjJPTtnAH+Hanbhn A6Hsc/L09OQeMfjSXM3polf/AIHz/wCB2Hf4uZ25dvnfb+uwm7jGB15wR8uT9ff+dGTwATwSSp4J Hfj8cfnV8rjGnO2r0enX+tCI7prW2/8Awf66i47Dbt4O4HH4Yx+OKUNjnpyegYD8j/IUtLSp7Wt+ D1++1vwFe3upW/yv+o3kAKedpILA7cDr06+lIT0Az0+vtkjj3OPpWrkqd+qStb1/NdPVDUkrK1lb 8u5SmPDAAD5cAdeAMHHv0/Suen27gEwMHrypzx+ParpaJL4bpP8Ar7zLSNTtzP8Aprpp0LdnwCQQ jdMDk4+v9KsHbuxtxwCpyfzx2HWsGlHm6W+X9a/gaKKtH7LS+9r+vu1I9o9lwejdhjGPbjJxx196 x9flK2PBAyHGADnuenbODzW2GUVXopS5fe+S32Jm2qclfpdeVtPn59zx3VI82UshwTtYtjPytgdC cevp35FZvwztWbXXmGSY2UKpz05PB/8AHewzXqYrlWDrK3l+KX3dvI5E2q1FuVkk3p5LQ+29CmxH Cyjy22/MrFsHoCc8f5/GvPfit4Q0PUbOXUUItdRVd4PmFIZGCnIK44J5Oe5x6VWWWp1VBx92ScZP 9UvJbFycozpyjolb17v71+PoeJ2y27+B5Yk2G6tLopMisQ0Y3ffXpjgD8/bNcaJ7gwJA6nEjgrly rA8HjB+nfnnPvhKjThSgpe84Va23qnp5ctmexhZycq3IrKyv9ytbttt1PQ/D08ltJbmaIq2VUuRg kg9SeOeSfxz1r6Q0SVLm2iBAK4UA5G4nGfvZx+VfI106OLUoyXI1dd7X00Ps8Uv9kpNS1Sj667/0 zrY9iqQCirt5GRwB1xjpn3qVZGVC6klVb1AwvXgn611qEGktm/l00/4PzPn59e/59jRMx8sM2Au3 5Sm30HpxVaUQzwnzWxtIY5Yjb0+YH0rRTXs4ra7t+n4/qc8FaS5Xon6a/pp+ZftGQxqAcqwwCWzn OOTUriBCCwVSDwSCA3f6Z/XmsqcVBVIwvpdb+u3pt30CpJqba0X9WX9eRVaVeRs3ZGABwAP5Y68e 1RKzI4ZZAFOQU+7ggZ/+vVP2cee2n9fr0+RtGPu+9pfoywbaOQMJHDBTlQOQDnrx1qpCu2RkT5Nu VKqMblHTnNZv95GMmvhatdaWfUalvB7LXTZn7ZN2/kDinRbQcd/yr6OOh8U17umhMWwR+FQmQKcc 46c1LdrCS26XGM4PTt2/z9ai3fX14qXe+9rFpWE3qP6deOtNLDOR2PSpctUr7/n/AFctJ+iFzjoO Oc+tJuPGOD+eBSaXoK26HByAAeOM46USt8nbPP8Aniq+y9LBy2kmjhfGrkeHbzb1BQYOR3r844Ls DU7oFgP9KnXj7oAc46+vrXwucv8A4WJxva9Nf+2n3PDfu4WvbrI7K1uBuxk4ABwMcDj8+a6WCTDA Lz0O3GMdPyNfN1U1J3ur/wBfij6unp8zetZWyPpkcjA5/wDr/pW5BOMYIxg9sjBP+fauOacWlGNr r+vzKcbNtf1sWkm5xyAD2Pqea29PcZHAIGB9OlRCHbTv8r2Br3HbS2x1VuzDG0Ee3cVs25IUZAA4 5xiiomny3sjkaXJv/wAOX0buM8D8ue1WCRjHPQjsKzco8rt12/r5mXbTYzroqF4HTjj8a47VnQR5 xtxkN6DPrWKlaLiltt8z0cNePLJdWeaanKATyOp4Bx+I7964bVXaMZQrgtgDBJzyfTn8K7KLtCUl 03/4Y9ay5o+7a+n9f1ucdJJ+9zgrubkenX2z0I/KnXExVAmGBC4IBO0jNehSSUJOPpby1FUjaUU9 bfmVFnXyxtyOcBT+PSnLPg7RkHdn+707enr+tTXcfZ3i7W/rb1ui8MvefM9U/wCvzN+1iLAMw+VQ GBPC9+c1oC4VWVIsnHUkjg98D+teVUioW0s/+D/w34M9GKT91aJCQN/pURzxnOOAF/H8K6mHVGtX j2FkZQgJ3AceuPrXXg6zpQnrs/nqcGOoObjC3T9T1Tw94weHYrufTdz3z3r1vSfGGRkyD5cd+hIr 6rL8bOHLZ2X5dD4HN8qjJyTjbT+vyOzXxSJbUmJmZihwq4BB9MmvkDx/r9zLrdzvUQMeEcMWB6ja R2yK9fFYv26w9tl/wx81g8D9Uq1nJW6L/hjx668R3llfebMsrDafkJATIbd+HVq8r8ba/JrLnFss DR8BxgysoyOqnBH+AqFFScI25V+f/AsdkndLlfU8YlDbmLDv0IweOvFREkfKAA3G0HkZ/H0+leth 4NX69H95yVYpp9FfboiFivO4kcnnB6/w8HGelQNGhGSDj0HAzgA44+npW1+SKuktbrTr18ktNTmc lGKtGzb2/L/g+YzyIzyFA/QZ6D9MmgLGnABB74AJIz7H/PtWsLXSho0t/lZ/l+oKzs+XTa/5f15X LMYi3bSwBALAnj3x6jrWjHbW7AfvY1K5O0nkds9cY5/WsWkkoKLun93/AA7Ka0UbbP52fQja3RDg SLnGchgoB/z9fWqUsSLuUOAucgBsEEn8vU1CmlzK1k++91du33roQlK6ey6ebvt8/wAilIYlJCsM rncOCd2OpGOvGKgJA742njjAyepOePT/AD1q2qfJZW/HS/4X+Q37srJ67r+vTT7hh+U8YK88jJHB xg44PX9Kax4IHPcZGCD6A9aUfcUmltt5O/8AwfwM4JbXs0/69BMgEcjpk8nJPA/yP8aM45AAHAx0 4PT6cA/rSbafIo7P/gIThsrf5jeFyCBjHTg9Qec5GR0/SjKjdtHA+Vum76HHQdOPp+Ld4uUlF+Xl bv8AJ29SrKMXypr8Bq45xjBwfQ84OPpSFhjkFQCQBnbj8R6dPzoUFe0V71lp0/rSwX960Va1+nXb /hxDxggcZ6EkjGB05/pQMZ4z8vzei5Pt+H61ajNxstNLLyHFWUu29u2v+QvyrkkFQRwPmA9O/X/6 9HRRhQu0HpwPYAdsc0owtK70Xfpp/wAMiIRV9V+nXVf5DhhcZz8ufQ4x1/Hp35pVQbshSOfQkj2A 7dB+dZvWNTTWK6ev/B6eZbS000XffqO+QZG0g5yeQh4+lLuPqAcZKnOP0GfQ1pF2lN2vdLyta39f eS0k7Xtt/X3sQ/wqc4zx35AK/wBf/wBVOAA+6c8cHg4Axz+dUmnUV9Ldu7d9v1QJ2vpZX+/1GjuV XaB0I6DBOR+lPwMgAH5RgnouevX8OKN1ydHv5apr+v8AMHytp8tktvLUekTMCTgDJO3d6j6d6WSI ou4j5VweOo6joO3I/HFDcVGTjpyq3l6k62aez+7zMq5IAOcdDgliOgyPT1zx71zkrEtj5Ry2eNuD 6fXPH9K1UuXk05vw07fLZd2ZvSUOX7NtH+ho2ZUR7QVyMA46BSckY6dBn8KnbjkkLkcY+9g89Bx1 xWFlJtLdtb7P+rfidKceVRSvf+tyE52BQNo24AyV57fdFcZ411FbCwRiNqyBsduQQdvbAOD37114 alzV0k1dL8tfnZIyre7Tlra3lp/X+R5Ld3on01pOQzAqQoUNtAIbJzgDofw7Guw+FNmimW42nJlZ eFwFJ7j0HTt612YiD+p1Ixlbnl817yX5L8UcMVJ1lKWl0/6Xydj6o0hlVEHC7TyoYYUDqM/gfSvG /jbqVzaRRQwsrW11GFlByQDjAPB578epFdOWxftJNPaLt01SUlp+fkjWLtWpLe9k+39dT5306S7h tprVWYRT5YFcqeQNwx0IOAMnnntWpGQwjDoE8kjK4bepBTLKD1GAenoa46s/d9ry2Sk3Zedlr9x7 eEjKLUXHT/J3/FXPQNNKTw2pSUuoIAZ1IZeMY474bP4c19CeFIBbWcKcsGUbZBkhhxyPyr5PFW+t Rgly8t/P1j8tGulz66rNRw1r+69n/X9bHZRIyn5dowRwcbipBweO/NaQiRU6lWYH5eSGPfjNdsYL 3Yydr6/rufP1moxk1uvu1YZQIgVOmFIXHGf7pPP4+1SvHE8W0LtDgkjqCp4x+GKaTU4q6jfq+jTe vyM0lyxaVr/o/wBCk1tdWcUI09vuScoxbbsbrn8R2rSErzKvmhVkXAZeozjHsamrGnGSqxk1du/r ffTzbCNnrqrfkv00Gqi5bG0gckD5ec+xqqLpA8ibVTy2+ZirZAwR9O/6UW92XSzWi7/1YuCez6pt F9buOZV2ZJwFUrjA/wB7HbA+lSiBEJcq3y/Mqnjj+Zz/AEqIuKioWu9vub0t00e43DkXvK3T06/0 z9nGfGOcY6emaVWAOe3txXvppNnx9rW0HtIO3T8RVdnIbjtkfSpe6S0HGNraWAuQM+nvx69qbu5G M9uvFTeykNLoPzx6elRt8vOcegpNbNK1ikIG56/060CTH51PNr2sh2WvQXzMkf55pzt8h9cZHYU9 lJJWEo22OA8dtjw7egEj/VsCOo5r8ymdk1W6X5l/0qUEcAgbj175r4jOIRnm89LNQiv/AEnQ+04d tHDVb6Wl+h3dhMVAEnI+XB5GBwePb/GuutpCyqVJGAMH2A/+vXhYiNr3drX08+/5H1dKWia6HRWc 3zqCQDjBwoA6+n41to4RwDwp7jAHTt+NcFtFJvdW9P6uaNNcqWll/X5lxJFLY3emMf3f8mt+xfB5 IHTI4AHQ/wCfxrOMVrZ2t8v66/cJ2UXfodVbTJgcHIyR24561swyYAAxjHtwKms+26OTk3b7l+Nz x06dOe9TmTaDggcf5+lcfPa1lawOKTSS2Mq8nOCMrgD6Vw2rXICkdsfQVDbhdvW2uh6WHgkkrHmG p3B3Mi8DpjgAHOT/ADNclezFIxlhjPQnAz04/Q13Yd80dXay/wCGPTaXu6fccxIp8zO4feyuCRk4 zioDKPOWNgcZIbcGG3jGcmvTp8seXXRO2nr/AMEmo1zPXSP/AA/4XKk7IknAIGTyCcfWo45cHI+n GBzz/wDX/OssQlzWWll+bb/Nl0X8Lg7d/wCvuNqC5kKBC7+WPuqQQOMAfXr9K0YZBlQMY4PHAx0P fGfx7V5lVO676X8mv+Ad8eWLlZW0/Q0YWAlBwFGT0xkc/l/+qr7tuYBR6ccVcEuR2d+rMaq96Mm9 EaVpeTRFfnOARhOnH1/E16XoV6QinzGG7AB3f7P6V7GDkk7RfKl0v/XU8TMKUeVu1j1DS7jaIZY5 SFICuh6Bjx25HUmvMfH/AIfguLp7nPl5AYHadrnuAcdeB1r6OhdKDWqi/wDg2PhcalGu7Kz2MG1+ Hen+L9EcQzrb6jbCULK5CAgdFbI554r5J8ZaBqHhnUbjTNTjjSVXcK0beZG67sBlbHfH616Nmuno l2drnFzSU3Dl/RHlV3jkqApz32gLk5znv3rJcc5HJOPYAZPftzmvTpaQ93rr/m/u/Kxy1Pi1/r+k QbsY52+i8emMj2zu4+lRtkHGOBjgEDv1J446n3xW17qVter9Ouhzq+jktE9v8hrEjH8I/h5I5644 6VESeeCuCMHoR1OMY/P8KqKsope71svO9197f3j+Hpoun3/5lG9SWRD5LmP+6wyCG6+nv69BXNy6 bqrHi9nXdxwxU4PJAA+70985pxVotrSztfr1t9+jfn6kSl7SMbK3p00XX0YQaRqH/LW9um5ALedI ufTnjnuccfga0Y9JKj57q4fb0LSPgcDHfk5BHTtWbUYcrtqrrTo3Zr9fkKz91Xel/v8A60L0dr5L FxI467s/Nnj3yP8ADPqMVLgqAPmycA7iCAfb2qb++76afdpb+v8Agja3al8P9fiGBjC444GcjHrz +P6UZ4HPOeAR25JxgfWldRbs9LJq3fVP7uw4pR1S102/F/12HmPqBwMZzlTxj0P1BpuwqOp4zuIA wCffv1qVZK1rtNX8lbv8hRg4aX2XX8SN+g4455AIwCeeMf5/CmkBWPAzg5HQc4HOfqKpRcG9fdd/ v/pr8hNOLtra/wDn/XyQhPXChSOoOBjJB4IGMcnj+dGBzyFBXjJPB7cHocD8abahZJ6qybt22fps Ky0lF91b77jcjgDjB6A8dQTkYHcUM20g8kZA5wMY449ufTtVX91JaOyS8uny8yrRV273Wn6Nr7mO LADAJH3hzgEHtgDt7Uo28Akqc4AySNp46DqSai0VJRvZP/Pp+KI1jFLe7/r9RcgdBkg59wOfw/P0 pwzjGG429cjnr2/3elJOKvJ6KS9P67lNxs1LSz/D/h/1FLAHGeo4z8uPT3qPIGDnoec4JAH6depp xdm492/n2/r1JtGySVvO3S/9feO+QBu3HAOcDsRj6kdqQDZ03cnJUkE9MbeOG75P5U3HkTSlv+Hf /L0YO+zel0/+AKCP7xULtOMHGCAfu5/z/N2Nq8MNuWbC4yOuQcjj/PFO/wAMZKy6v0u/0DaPn+n9 dexWmnmiBESnOMYJxzz7cck81VW9vzgSx/JleQT1zjIP1x7VpGlT5Zcu/n6WX36MhuSi4pX2svno EzlkwxCg5XAwcADH59fzP44EmAwUEY4OBzjPp6D29x6U6atbW1uvz2++5DST5rrsvw1/G5bsyQx2 7lxklcbTgHbx6jj2q6W5ZCjYBB4+UZwOTnt19eo96yiopcye1reS6Pyv18jaLfskkrSVvUhLc7Bg 89wTtIIxjHXAyK8n+KEoNpaxAlBsc7txAIIbI4PHX+Y6ZruwKcq9KUZWV2/VW/N3MqqkqEkrWVr+ r/XU8d028EtnLas5LxEqN+4HIIOMgA4wfrz+B97+Gts1tahl+Vn5Ybclucjk/wAs+1dOJ5VS9m1b mnotvNHFQqSdne/KrPy6fifRWkg7ASQOOinA54/x7+3NfMnxrnvYtUWxnCNbkF7eUOc88FduMDbk dz97pjk9eCTviLNXhBtdOyfyszqgkqitH7L02tfrb+up5Hp1w6xNETgqQVXLKQP9n8c8DPQ/jtSM 0JjZs4YDnkMoIAIyP88n6Vxzhy1HBNJO7++1/wAdvmevh7qOit7O3Xz1/KyR3mhzwPDaQh9qSy4E gUja2AQpOMDp09x3OD9LeHY3jsIIZCM9VY4BOc4OB6+g9DXx2K54V4O1vek35JOz/rqfVVJN4KnG KVrLbyW510LOoGULZxjbkfU8fy9qvrINw46HOCM4AH145z+Vd8ebltG1rPZHiTb5uXluvu13/As+ UDF5gYL34GOAcj+vSoXeNURVcA7s4BGMk8gY7e1NtyhDnVpK+n+f9eRkpO1pLRa+f9bllZIUjw25 SR2zlTz/APrrMn837Qs0OQONyk/eUewGPaiEocnLJ6SX4t/8BM0ptQfNa2mq+f8AwS5BG2WckoCC QRgkcdCOn4/Wq4e3NwVC5LKckKOTjoTn0/nWcE0qknLTTT0uv0Q1B8ygpapP8dh2nm3AljUvuVgC uSTH04x+NXIL1VEqNuwoORtY9emAPX+uPaq39q7Walpbpov8wkpyspae6vy+7/go/ZvOePTn0oLh Bjnv+GfpXs6pWXU+TUddOhGX759wMYx1pEcZH9cjAzUu6foVbTsSbv8A63am7sNn6dBjFK6urbAt FYf5gA9PzNQNJg8dAOMdKi+t1p2HFagr/Tv7VAWZW4/n+fFPRO/9dy2kr9Ljlk+YHPH4j/PWp2bj AP4Hj+VGttd/0JcbNaHA+Pmx4d1DGc7FIHTowr8u7i4kXV73DKvl3lwMZyRiRhzj14zXxWbNwzep JJ25I+vS59jw/wAqw1TmWnMeg6VdGa3jwFJQYxjoM5P866y2uAAFzjgAcEH3/UmvFxTfNKVtL/nf 8v8AI+poxim4xVmun9fI6O2nJIBKkk8HgYGB1I56V0UchkiUDgr178dD/OvLfNZ3Vm2tPLy+46bf C7Wtb/IkjLI2Cx4P0HsPatyxlZSACuMnt07+lYq+21t/zX3hJK21v6/r7jqrafCjcO/eugtpflHO B27cUVGtWrX6+i/4JzcqTvbR7GpHKAOPTvTJZwo259unArkcbOK7gormikjAvrzAbpkduT3rz7WL wKG54xx/kUua3w9Hb8P6R6OHTTj0SPNry5/eHLdCSO5K1zmpT9BxwOnTqfwrtoXp0OZrRu3qehJW lT7Pf+uhhD5nKoxU5yu04wPqP88VVYuJQGPzL1HC56j+ddsbwUHsm9vS33X0JqLldnpv+O2hRupC shCsTgknJHy565pkbncMHGD2Jx7/AE9aVRe0qNrS359Pl0FTfL7q/r+tDatJWGAV7cdc5B6ZxW5b A5HX5cYG05/DmuCst7LVnbB2u09/wNSI8c/wngDK/wCRxVrphl4PHQ5x0z0qYXjFxb10/psbtzaP RF2OSLBWQsCCGUgYwcEfkePyrrdEuW8sQgF8klQgywIGM/rXfg5qM5SUfkvL+rs8jFwfJK+ltvkz 0TS21dGDCGaKP93gujAE/KQCDz7fjU2v6yzaa63EIYpvUgplV4J3+3C9q+pwMpKElJW/L+rnw2bR g6sZQa21sczo3jfQNI0u5nZ4BOiyDZvVGHH+0f8AE18b/EPxXF4i1i5vUZ/J+ZIgW3EDO4lPTP1x xXpxlJ1FGKu4pP8Ar+uh4/LaU3ve2n4nj1zOjHoVOR0BxyO4x9KzGwzLk/w8Y4JGM5z26f5zXp04 r3Zttez7fj9y1OWqmtZWTvZ+S2f5keR83CjceDwAOnAP4jv/AC4ZnqCQMKSCPlXA6dfqfXpXRzKy 5I2bWi9f8zJSa5eVpKX5/wBIiyVHUAAttUkZBHcjrTM/7uTyFHGV69O3SqXvWae179NPQJ6Ne9ZP +tfUcD2BCgA44x6j0oOeSCoHJzjGPY+/+GaT2krabLXp/npb19QSskk9raeggDYIUKp3ZBwdpx1P T0x6ZqEEKG/hx8oznrnjP14qGmpRlo9v8v8AgfeTa0u1k7a/101Gj5TkHA+gx0IwCfp1qEnAK8Be QV/vDqMjGfypS3i+Xe+v6fL/ACKtOMeWPf8AC34/8ETnIB4A44ztAGB06e5+tH3T8oUAZwCpVXPB z65OMfnUuME24y1evbf8Lf5MzSdmrf8ADIhmvltV3MB17Lgcf/r/AP1VHHqXmKGQbjjDLyMcZx+o PX+dacl/Z80eVN2vf7v1G3q0tH/mAuywIClBlipwcn+n/wCupNxHHT5t3BB7AdRwf0qFBRUbvf7u /wB3b0Jumo20/r+kJgocjGMZJ5wF+gGWPbtQ2en8S8gbSpJ49ThuDnP/ANeqUnpFqzf3bfqvlsU9 Fpol/n/kA6clUAIPB5wMZzxilJwvVfqx5PGRn8+KFs42ty328v1tqVpBXcbNCcYBYAg5zj5ecnHX 6/rTgOBtGDtxgYUdP/1enINJcsnZK2rs/wAfz0+RDUvhW/fp8hVwRliO/QbeD6AHI475/wAQoPAy Ap9QSCOR1OcdB1pRgoyjzOyX3XtsNRfura+9/wDgC7iAwHXcwxkdvfPvzRuwR2X09OpPp+Y/nWl1 ePS2nkv6vf1sK7UZLl0W3zeoZ4AB6DcMA9R39vSmEccdhyR05PY55o015dEnfs99fzT87CXNJ3Vk l+Wr/wAhzEqwA+7jaeFOQTjBH0PNLxlcEKuctkYxxx16eo/zlU1yy20s7/1/WgXbdrWst+39agGJ yAdq7jn13Zwcf59aaSoBJ2jd8wCgLyenHGO/btWkE4e7vs/O6v8A18iYXXKmrN79dtNDNumG08jg cZGSB1bb7f8A1qwXwP4tvHA6HvwMc8f4VurqNrXUkl6O/wCVkvMhpc72V/we+3TQs238LK5DK3RR t659eMYFXSOuDt9c5Hf9O+OK5ZJcylGO+j6Wu3+mvoaQXK1BLV9fLp5EbkDBBwwb+HABGcfh1rhv HegNqlpb3Vtgvbo+5GGcgAk9Oc8n1rtwc3Rr0oTSS2v20ZNeD9lOntZ6X07/AJXPmKy3QapMik7G mO5RwdwPTAHv+lfV3geLZZwqW5K/d+7gHvxx3Peu/GyjCcI8t3f9N/vsjzMMuVVbO1/+DZ/ge4ab KYF+YjAGSwHBA9M+gr51+Nm24ntri3f5uQyBcqHXoc9uf5963y9RTqykn70JLbyTt950U01UpNSv JdfLXQ8WsGBC7CEmXB2FQQzDJOTj0H8z711UFs1yMMoiKj96rAruBYkkYPA6fp9K87EyjTT095be mqV/w/pn0OXQlU9yKspf+la/56HbaDp/2O6tkIaSLfvRhliq5znngfl35Hp9IeHLi2uIx5Tcx8Nk 52kdQfzr5avOU8S6ijbmtp5N637Xa/q59NUg6OFpU46qKfq0tP1+47IHADRfKMA8Egcc+vfNJBcQ 72VyAeGwQSFI7fX0rsg1Gnv8O/npp92//BPDlbWKdml/X9fI0FMbQgKwwMkAZUA/5NcFHrMieI4r NoZfspjZdyoVUOAVGD0A5/z1rSSl9XqyXxU4vTz3Xr1OS/vUIrRyf9XO4McbSKFwseRg5AZTwei5 NSpEUAwfuHA4II/H6VmlGUV7ujt8jpS0d5b3/O1/wESXzYnETAt85BxnBHYjr/8ArqlAY45irgiQ tnPAUfQduvQYqamtOqotrltzad9fka39nOUb2dl/wfwZqxiNSf3a9wxUYbJ/n0NQFEzIUzux9w4G Rz60RTduV9Fr26fpclbaO7S+dutl6n7OA9ew7f5/z1qJm6jp344r15fEfLqHVaDVbAxnsenam7lB OO3bnNT9rsDWlkiUN+Ao3jj+XTii6tbawJK3oM3/AIDp9OtRluvbn8Pyqdb3WlioxDftGPT+dVg/ zYyQPXtSduaxSjurW6iqdpA9xgen5Vb3DHT2I9PyqlbX1G46LSxwHxCcr4evtoJxESBj0Of51+b9 5Polzd34nQ2l5HdTDzFBBbDN254JFfH5nyvMcRzLWME4279mfV5GpRwslHT3tfQs6PfQ20nySFgD gjaqhk47En19+ld4gEuZYfmjK5wuSVycduwyPzrw8XG8ItO6V/8AgM+motwkp9l/wDZsJNrBJCMY zwQMH/PFdNbzYIVGIHp1BFeXJRi7xe/zseg1e3u6f1qaLXCuoBRVbgBlyGbAxzg4xxWnZP07YJwO e9YqTdSUrWv+iehnKHLDyR0dvPjAIxjofb/OK37ecfL6cDggYrCs427f1/TMktF0NZJwF+U4xn24 rPubnGcHkDBII56VyzurOL2NKcddrWOV1G9KgjPQdM4z7V55qt+pJVioxyCeeR06Uo7Tvprb59Pl oenRp2UeVbs42adN5Idck5xu6HrXPahKrNxjjPzA44zxgdfWu1cvIkpXiunTTodiherrokU4G5D8 BeuAeM1SuG3SnbxtHPPrk9K66M17JJq2uj9W/wDgL5GFa/MtdtDMkDDAIwcjnGPqB+dTxAgr8oy2 C3O0Z54x71ta7uo2Stf1/q33mSvfRbG7BFkr046enB4PbsK6O2i4GBtHX0/+sK4qt01yxs3r6p2X 9eh10dlpb/M144+Bjoc5BOB6VP5ByABgYOf4R+dc7uk9beX32NNE/QsCzbBZQd2QccfrXo3hbVNN 0yMfbLKW5dclUjlS2jc9OXKsV/75NdeBqxpVeapHTR277/5nmZjCrWoThSajL8tD0e38deaVgsdD 0e2tiVVzP5t9dBumdzsqD67K5jxcXu9Iu7aK0zeNHM0SqFVC5BxsOQMe34V9dhMVHExqKNNQjFWV t+93/XyPg8ZgZ4PknOq5ylvfRK3ZdEfNF94I1S407+0bdpGtpEbz4mPlvC4PIK9SDgHIz1rx3WdB az3kqwK7sgnoRwT/AJ//AFenBpShLmelvXyPPaUU5bd7HnN4gR2Hy5zgds4+U/1//XWQXXlWK7h0 OQNo5O3+devH3YKXRW8tHr+RyVVs2rrf0/4ZkbDaW2n5ehG9RjOf8OtRHaPXjgrgDjBxyOe4/Ktf d5ocitfX7/8AgWRzShG++qvov66DT8ucLxnOSDle3Uce9MX8WAAy2NuP8mq5lD3fLX5LT7yfevrH T+vy/QeCASpxn7vcDg4yB19P8KsQxh8LgIRnj7oxxxjj3/Ohzp3clK63t5X/AMhpOLva/e39bl0a e2BgrnH8JKgHnoO/b8M1nz2zRk8gYB5Bxz+Xb8aiUlOcfZrRLT0vt+AmuV3jaz/zV1+hnPgN04yR jkYPToeRnP4cVGVG/HOB0J4Ctjnrn26ZqIu91ay1Xz62+/8AQJp3vf7umv8Awwm3aNo65VsKARyR ng9KD8p4+XB6dO+cnP1pRaurQ0je/wAv6082TzNOy6fk9CJ4o3Vlkw2Rg8YPfkflTI4Yo14QKRyB yAM+p69fyzVXaV7+aXRPvbyvYSdpO+/9L7xdi7eFwxyMkgKPf2/OnEdgNoK/KQ2Dn6gjmnyp2Te6 Wi8tdP8AIceWO+q28ugnO/B4GOCN2Oo7D/69J1wABnPXJQcfTJxzmphyxcObW33fP8ipJOPxW029 GNIGMjIHUHPA/LoOAfr175dwAxBUDk8E9cnIx/ntUveppvt038/Qzvfltp5+X9MT5cjAPGByTjGM ZI4x+fenc9j8pLY6bcDGfp1xWvK4twikreXfd/Lf5lOTTso2tbT10/PUEG1hjoCVBGAT2yMfzxTx ke2Og3Eg+v6fj6YpKNop/ZX5dNO4lJxlFJWtunve3/DA2OqnPBXsc565A6frTScc/Mh4IGSBzzjn pVOOtmrb3XS9mxxUYqaS6a97v/gpsHdEVd2FAJw3IAHbk8ZJx6Uu9eFOPvYAAA28HI+nH6/mRum9 Lrv+QknZ2Wn9flcXI4wCQcqcleoJUkDHbA6elJ2AIOOM5IC7u39aaqLSKXr6f1oKSSV4rb7r/wBX HAnGcAd/Tj6dug/OonUYOSemCRnjAHJ/Wqgmr2V2r/L+tfvCNrt3tyt+vdr/ACM+52hcAnP/AHzg YHTsKwJCA+OTwTxtBOR0IxkDPHatI2dOUXok/T7mvkjGMuZNuO7flZ7f5ontlHzFTg55XoSDjGOx q/lhgA/xcDdjHGe+D7g1nJJOMY3XS+mmm7/rr5G8YWjTfM1e1vn/AEyMNsPPHOQdwIx0z0459PWr M8YewY8Nxyceo4Bxnj8utXRi1VpJqyTTf431+75WKcd4NXb3fTqnf5nzDq2hJbeIJzHHs3yBwFbg N9PxPrwRXvnhCMxQwj7pVVGGPGzPOM/59upr1MZKDlSVnd29L2u3955VGFpSlHS19OmrPW0mWCyl lKsQscjsCcEqB2OOOp7j+WfjXxhqtxeaxdETefCkjKsIwSAOMN79fTNdGHt9VxDTcb7a7Np/5M6K Cca6aXwx27vSyXpa5z1rIA6ERY+bcrAgFWHB49+D7enp2Mmqs4jV41ifKqJYo1UDII+YjjGFPPtz Xl1KbdSLb1Sa9b2uvlZH02XzUfayty3s1bo+n5q/yOz8NpcSTxK6MTgYJwQBnB6djivoXRbRII4Z MCOfZhyqsgIxjkE/NjtXzFecfrDjFXTST9H1+TsfRYuXLSpx2ajZ+V9/8/xOygJER5DBhkY5zjH0 2/1xTU8mSVPm2FhsJ5HJ4HHUHmu2nyxhJOOmvX+tf8jwuRRbtFaL08zTRY49qyME2rxsIOQenv2z /ngGm6c1yk4gjd2BIbngZJPTgfjVU5WSjGWku/V+f9eRyuCVns1+D6A0bxyeZGEVFbCjLbQfr+AP SnLPIsjRsn7uQZVlOApA6HPSqqNayirabdLxeq+79C0tUl0X57EsaLCGYAgNy+FwcjIyO3fH41H5 SyShm+YHB3cjGfwAPTpWUpRcpyj9pL8r2+6xreLX+Hd/kN23Ed2QEPk7cMWOMDgj/PpVgqrsTgLj n09un+etL4JNwjeLS+T16FcqSpuOlr/m9D9kS2MDp7D/AAqNmOMj/wCvzXr2+R8sl0vYZu4HG0em MUzd2HH5CpurvpcLb+RMHxkdD+AphbnHtn0xQ7WdgSV72sHIwewA74pCwB44744GKh32bsUr2t2I Xbgdh6Yx0+lRIw3c9ugx/hQvit2LtpZbolyPf6cVJvx7D27UeVxdktEcJ4+P/FP3wHaBzjueOlfl 7qs4TWdQSRcAXM218HKsG9enJ9vWvj8wbebVop2tTWvzR9Zkd/q1XyZcsX+YHPfAKkLxwec/Wu80 q5cII97AjhWBZQM49Pwryppe9H4U18k2v6XqfS0UklzdtO39dPU6m1mZJN7MWLH5s/MWJ6nPfmum t5DG6EHgEHvjArw5t0mkujev5L7j0Y3jGGmj2NRZQXXCrGe+GOCTzn2wOPwrZtWIIzuHfjp+IqF8 TcY9fuKlF8nLv+BsxyFcAdu+MetatvcnjnGO/OQfbn3rCabdrr+uhjCK5eW2xrLdhV64+hFZd3dg Zw2ByDjj/PauSfLzpJWtv5f0zSjG0nZHG6re4DAEjj3GOv5V5fqd6xY4HOcEA9T/AFpS+NJK1/63 9fzPVw8Um1svwOXa6KsWAKgkhiDwD0/DNRl/NDMrLvUjIPUg9MH6/wA/z7YWcf5Lfc0lrp30Oqa5 Fz7d11t/Wo2JuGBGCM9Oq+3H8s1CoG5xkHIxye2M8CuynLSmk903/lp5HDU1TW3VfkvxKLph9qgB RyOMbQOtXbRGxkZxwpXGAFPqCffv7U7u0lZpO/z01/ryMmkk5LS2n6M6iyhyBn5RnnK44/wrpbe3 OB6dgPbv+n8q5q84rVNpb+h0UrrS1rf0jYhtug5B6jK4yD14/AVopZgDp2H8/wBK4pT+1e/5/wBb G9/L1L8NqFTDIMbhgkEYJ56f/W7Vo29oAB8pOB09B3FXTqNJK+mnrZf1+Zy1VpJ7q9zobW3iUpJF lJQwJUKNnH45FdZeTboViKLhgEwy5AOQQa9nA4xYX2jTsvd9PM+dzHByxHsota3a+VtGcz5ZsNPv bW+hj8uWOUpInEfTIwW5PXGTXyj4zNtEblFKsQ0hH17AfpX2NOpGSp1KXwtLXrr/AME+NlB0J1Iy 05Xb5/8ADnztqTjzWUYwGYcZULzjj8+lYT8bmKtkeg75z+H/ANavcpS5YJ7pv7n/AJdjhqzfNJct l5ab7fqRHcCduckYG4dBtOc+n5HGaYd2MN8oOBnIBBxjtVtu9k7a6ei2sc+ySStp18wBUEcZH3Qo wDxjv+I/L2pp2hyoPBUY6jngYA7gfT860VNpJNa6fJ9vxD4VytaLr6rT8yNgw2gZ6HqVzkcHp6+l ZVxLfkZgBQqeCcgKTxg9PXpVRspXS00/O39eW5MXKN7PT/gme03iPot0xHGNoI2jg859PxqW2bWA Sbq6efqDG4HGc54A+vXPNDVNRbWiW1vxX3kRbcXfT/gf5s1lLYxkA8Y6ghiefpxn8qCMZXac5JXA wDn1/wA9axj8UWtLXv8An/XqV71npa6/zG84BJPRcLzgcZPp3xSdBklvQcZ6gdh+PPNS1tyr4dPn v93ci1nHWySt/XoMC7cHGMAnkDcFwM/MeQDgcUf3QM4C4OBgjH+f0rTZ2lHRaK2j9f07aj05bS32 9PP0WwhOMYwFyDj/AGiMYPfH+B9KT5d2D64XjAHvz07f56U/cbSVr3/IKdPpf5ef/Di/xAjqcDG3 hucADBHp/OlwRk4YjHUDnBHBBPXtUKUeWUeTlXmtv61frYcVF81tLfl/TI9xAGCc9CDxtPX8PxpO 5yeNuCBwvH3fcdcf5BKbjpTeqS6ebun/AF00Bxtft0/IUsRnaD1AP3cj09OKM4G0fKOSCQDxz/gO tOK0kvw+dn+rfyM2rNKWlmlpv1/LYUMMfpkEDoeRk9PwpwIUDK4H3SMdj7f561T5YRit7/l/VvxK bXuta3XztcUFVHTapCnbtHAwT+nH603cSSOF3BTwSDwOce/SiK91NOzXX9C7Lmt1XbTt/mNO07Ty ChUA9cgjBHJ59c/4UfKmAONmSpBxt9c4/Hn3puUoPTbp5dV5CtZSTdm1uvxHAYAB6knnPUHqMZ/w 6inHvnC5woIBLLngfT9KUfdfPGF/+H0JXNoorV6frcM8EA9Oc9iQM4IPtmoyQM4JPO71z9Mkccjn A4q+lor3W9eny9WvuC/KrNWTb9d/6+4zrhV5ySpwCNoAHJx268nr/jWE7nPDdGbBIYcf5P8AOqjO NnCMWv07Nf15mCdqnLHRfktf0YW8v7wjBGNpONw9VBA98df8K1srnj3IABCnPQ9abSjOpyO/Rvon 2/L8Tenb3W5NWW33/wDAGE4wMjqD0zyT2P48YH8qsTF0tcE7V9uMg+30qqcf3tNrRXenR7Xv2u/u 2Ccmou3Z6dd/+CzyvxLax/aYLheGLZDE46dCfx4xzniu48KMpiThieMDgf3QCTyOoP5V21YxcaL5 brb8e3yX3nDCKjztKyTt331/B/LQ9MedEsJScAeQ4K53A5XpnFfFWvMq65fvbokYE8pCopUBs/Nx xz7d67IJRwtWFrRurfitO3Xc6MOlCr72rVvx6eRWs7khmh25WXgHGQpzyR154Iz611Xk/wCjo+d5 U4dWGSvTlSeCPm/D+Xk4hypVabjHe/4q1/yPqcutNyly6RW3dLXb+tj1zwQCRF8ilox5TLgBwEAA zntnjBPT617dZExkJIRsbkKQCVz05/A9BXzKio16snK9m3fum9vu/M9rF8vLFRVr/wBL+vNHQQmN B5fOCOeWOOMkkDp0/WrItoXBGBz8ylQckj0IP+cV2w9naNno7vTout/nr954VSMo89viu9v66/8A ARJjKkENlQNp6E/XntgDnrVmJiqK3PybuF+8Mj0xxVKPKoxjZNaJ920lr95z1PdTkrrmX62/D8gh neRcPnh8MWAUEjv6evUDpUs/ywO23ODngYxjH5U3ze1UVKyTf6L7rNDo+6ozatb+kU3v/lX5WRGD beB1B6E9u1TC6TyOcgkHawXbz/U8is2pR5YwVldq3pdM2Ud1Td236dCa1uFeNlMm4AKQ2eoIGKcF XfmIHGMkn19D7f404PljONrWenzS0/Ac24Kad9fw6/p+J+xbsAc/oOPeoi3GQePQcV61lZXPmrW9 BAwx16np0/z1qLdz6cevGR0o0UtNEirWv08h+R93pz2pA4HToPTj0rN+67Lbr/XzYkttCQMMdcen oKgZiCe2OfwpS3WlioLWz0t/TIGfk/54NRiULxnHPGMe9Re2lt9LmiVtNl+JJHISRjH59OKuE4Q/ Sq6a6f12JkkrJaX/AAPP/HYP9gX/ADtPkPtJOO2BX5haph9c1MSuFY3Eu13IVQQfQnA78+hr5HHw vm1RWa/d3Xm/6Z9Pkrth6zS2a/QS3doJNoIAU5UDBXPXqPY11thdYMZSQ9RlWAHbPX8q8uta3u6b adOm35n02Hvyxdvl2R3drcRlY2XaCSSy5IKn/Drz710dvcrtRSN3Ixg+/r6dq8epFU05ct7beX9f 8E9Gir2je1vwNmCRTt4AXOeOMZ9K6O1KgL8xOOQOCB2/z9a5IO6lrZWWnX+rm1SLUeVaWNVOACpH H6Dn/OKnikKk8YJ9OB71jP49tO6+/T8DLl5U1tb8/wDhhlzdsg+VscY59x+lYM+oM2QDyOuMAfl+ Nc04Pm1lb+rG9COkWv6/pmDfT78qc429M4OOnT/9VcTewMznhsEkcZHuP59KFUV4u22treZ6FFqF klv0+ZlGBY0dXiJjOD3BH0x/nmsSRCpyMgemTtHoePz6VvGSjZK6f/DFp6y5VovuQkZYIeCRyFOC M56/yBpiBiW2lsDjHAJ/+v8A/WrqhJydK2iWny9DKSXNJ7L/AINx6RkHGPl6epGT/iK2LOB92cHq BkcYHUe3rWvtIwclrpp89r/MwTjzW5b2WvqdpZ2nAOCO+Ocfr06frXSWtrwoHTk98f5+lcVZK7Vr LX5aJm8XbS2puw2hyMoPTPcf0rUjtCP4Txzx36cVwtpaL7vJt7/ci21roakFsoyCNueRgcHjvU0N qQ4A4wG4HH6VUEmtNP6/r7zCbtePT+rnQ2dqiYfbggjI6cZP+FatwVyoEYJU+vOeM8dK9PCQjVpY hbWiml2etzxsZN06uHX95o5DxFLL9luYYEaUeTcIE2ll3lCoX/ZI4OePu18R+O/tEF3dRktEBISU Jzs45BPXv/kV9tltKVOlTg5fPst/+AfG4+cPrE5RXLbf1X9I8Wu25b0Ge+M9RnHUf59azWLYHr24 AA6fy4HH/wCr6WElyx0TS+XZ3/rseRVk4p22/wCCyHJzjOOmORkde3446VG2B09CCcdRgg+3atUt nytO+vSy8jB9J3vay/zHKMYx8o+QkYAIyOePw/WmFSCRx1UA7gNueuCOh/x/K435bx1V01rZ2X9f cRy3W9loLnquAqjIBJPQg8gnk9v/AK1ICq/KR0469eMHH502ldrk5U77f18iUrN3e17/ANeug1jz 8owAOByB1/SmHICr8h9flxz36dOcVnCm3Hljok7383r+CbHJO2kbJffuRn5fpgkYyPmxn3xUbFsq QTwMsQM59OfoP1qmpUovS/a2zbf5XHJyUbJWs729P87hycKoHC98Bfrx/PFMJIyB17jqQR/j+FR6 ytbZefX8LiXw9vK3V6gc88lSDjBwfXgAf54qPIXG7GR65znJP9fboaU+fm9xaaGdrybWis/mtLfj oKMfiFOOcAKPr9R+v4t+6WbKgdeuT05PGQf89a0XKmp7JX0/P5atehUYNqbvr/wRjbuQudwxhuin ngZ69xn/AOtUKyXGdv3eMKcEcZyeKcuVxvF2unp01bd7foVdv3Yvl7rt1/r5EysSMY+8MKQOuB6H 60oHUncqDpnBJ6Z4/wA9KhxVt1zW2tbbewmkkop8rSuvV2d7/oHYEHjnA6EfLzkfnTsEY689ccnj J61Lkk1K2j0/FL/Mahpd6W+/u7/1qAbC9ccfNtyOT3yfTrzSgc4DYIAJABJ657Djk0Jat81rK1un R/8ADEJ8sU7Nbq22m/8AwPkBJyMY644yfXqQOnIpu8dv4TnqcjrgDj2P5Gqi/hg43t06W2Xz1Xnf 0CN1G7dk9tPP/ITPTAAwT82PmPbnt/8Ar9Kkyf4QM9c55+uDx6/5NVycvJpyr56PyBJ3f2rK+1tL f5iEY4V+QOgGM47ZHbrx9aQcgYIUjkg8j6dAM5x/jRHlUlF7pK7+/wDTYSa1fXTb1/4ceBs3bRgD v78k/wAzzUL4wTkcqwUjcQR3xjj8j2FaxSjy30u7v+75W9PwCbTteFknfS9kjMu+hGdo5OMc7uMA 47dTx/8Aqx2xuPyP1J4+UAdCfyJ/yav3rKKmoxTett12Xpu/IiG97W2/TQmg2rnhezLzjBPGefpz V7hQM4xt6DAA9SP/ANfehKPMuV276Wu7f18zWlG0NJaapL5jONwC9mGRlQAeh9u3v0x6kNvZRHCV +6MsoAPXr93HJPHTFODcaum3623/AK7jlyxjKTV9N7+n/BON12ItaRyKASGztGV+Xj8O3rWr4WlQ cAgMAp24UYz6kfpzXfNr2FOa91e9fz1Wv3s86UuycUraLrdX/H82bHjDxBBpmmNb+aIpbmLbCysy lZNvABUgg8j+lfKc8rS3ly0zO0kkhMm7JAzkdR1OB7frXSnbDcu7k+a/krJfobYR8kpPXTT59Pw1 9TRgCRBHmT7jhwxcAMu7HyjHvznHHHHfsNPuYXnEeVSAplAScKcAnPvkkfnXk4tuFOVo3avyrz0/ JX/LqfV5VanVpRul39HfX79z1XwnCxnES7VYnzAyZjLdF5IORnH4fy9ttI3jVgxxhAGJGeTnsPb8 6+Zg4+1mrW6Pr1VvJPdHuY5xi2ui/wAnbT8DUtXDZUlSARkD5SFwOcVqeTxuikdZE52r0PUHjHof euunGKVlpbdeV9Dwqqk1f/h/60Emuo/JkCt5bKcMvQZ6DBOPX9c1fs3RrXevJCgMMA8HOPp3/Oqk 0nTinZqVr+asYSa9npHRP/g/15E+2NYGKhh8pYAtk571VaRiEUMdpUFQeeMdenua0irNyktE3693 /XkKmmpOnbf8Fv8A15lOVWwwY4A5VBknPT7o/pU0UfCJIAI2xtDjGMgAe2frWVV6x5bq12vXR/i2 zo9xXvpbb/gf1uTCKG1XftOT9456DOO49qdDexFTsIJUY5xn3zj8amScOV7R7+fb7ga5oSeun5q3 6Nn7FbuME9e/TH+c0hwvHp2r2W9XZ2vf5dD5uzVknr/X+Ygbg+vHSockH9OeARSaS5fMpJapOwpc jjAyB+FJv/p+FZapvp0KUXpZbimTAA4Hb6U0sMfy+tRJxt7q02/r+uw1ZNW0Kzt6Ed8Y4/lVQvyO nX34/wD10no0i1pq1sXYGAwScH/9X5Vc3fKQuP5cGr25YPbp5Ecuq8tjh/Gp/wCJDfqcAG3k69F4 zX5WeJW8rX9TjGGP2pirJwAck89z2/X6V8nmF3mzin9heVkv1PqciT9lWS0XN9xFZ36qFRwSOMYY YBx1wOldbYXC7lKvxuwckgg5x9Mf5+vnV1Hlu9Lfd3PpaMXBaq9v+D+R3ljdwxoobK4GVwc46DB7 Z6V1NhNFIyMrYBwduTwOueOh4rzKsYycU97K/wDXqdtOMkrrb+rHR2zqG2oT1yAeDwfb610NnI28 cYGcEdM+9edCPJVa6Pr003X5nTPWC6WX9fc9DoFYDHPIyRxjk96erDrjA65GQKwk4xfKtOxEYv2f nbQybwsFIycdOuDXLTswfGeh9SM/gPWsZR97Vaf1obUlZdrFOV/lCkjIP0GOf8azJFyw6YHcZ/px UVYcs7bWdl/XodNJ2t2+4rz26lDt+XjgdveubngAyCNuTkqfXHYf56mkm01dX/N/L7jeCa0T3/4J WEY8soR0HUYyB0xUaW7JtdCec9eoxxjpxXVGUlGMk1fT13MpPl5u3/BLCQDd0xyvcj/I5rpbGAFV wuDtxnjGR7/jmrlUk7aJv7tOj9TBJLWOh2VlbkKg5G3aFJxj16Dp0xXU2dtwo6dh1wPWuGrKUXa+ y/pfiaQdldLVfkbyW4DKcdvpx+HIrSit1wOPur9PyrmTS5nfcHK1nsXUh2kDbgY4Az6U6JMzAfwh RnHP8X/1jVU72aT0ZjKWy2/4c17cooIOfUDGB1NWbPUNNi1Axag2yHg71RnKHA52ryenavoMkpQq 1q0Je7FpX+9fh+lz5/OJzhShOkryjK6Xyf5jb6+0m0vb77DKksMsTsCUdAC6Y5DdOcn8a/PL4q6k za7fJGqkeaTkEAjjt6H+VfdUqcVyKGqinr6f1f7j4qU6jlUlVXK3a67Hhc8khBOAvOcAkgZIx+HF V2bGTgLjAAycg+4HTjv3r14xtFLm95a/JPVM46jTdm7PT7uv5sjDHcGHyjGScsDgHOAf6f8A1sJu Xd16ABQcbgB+HTJHJI61s3rZu17Wtvq/0/K5nrytX1kv6/QYTx1Hy8DkDB6/TuO/0zxTd4DDp+Ay OpHU8gD+hogk3Lleln+O9vv+6wSaj00d/k+gE8HDDB6Z3LyeMdf04oYnJ57EcZUZPX/PuazTnG7V 0n+D8hNx35bf8Pf/AIcapwcnHyggjJAAOOx/zxTDkA4PCjvw2Dg9vqR2rZJwla97/wDAf5P8B+4o qUbq+/ff8kN3HGMDgkqTg9O/+TTCTxtwq8fNkj06noPzzQ27yV7RSTXq3+Gv5BzJXvL+u/4DSCM5 PIIGMALzjP8AOo84U9cjgnrz16cHtRGyitOVK3pfpr8n95mk1FRituv5aiA4yQQN3oBnk9fw65+t I3JBUcLnGGGOMZx+H+fUTUUlGNrXv/X+GwK0Y2XT+remwhYD5dp3AAgEkHr6H/PNMGV5IA4AITjA 7jr6kUKSml3V7r81+P4CgkoqV0tdf69f0AggdducBFUgE5Pv1xx/ninqTjnjaR6g47fTr/nFRZRa UdLW9O/y/ruEVySSlo3f+vTYjLADHYHrjGeOMj8T27UvQnCsCMc5ADY9x9R+f5OMGrcz3fXomVor ap6tAGI5zwc7VwBjHbPX1/Kk+XO1evQg4J5AHAHfmlZpuOnoulr3/wA9PUmKafLbXb+vw1+ZLzjD HaMA7egPTgfXr+dIMjaAAAGxwR8vf/D86qMIxlKyd9Xbs7q1/kVdq+lrX/UTlQMkfdJ2g4IJ6DAz /PtRu4AOFJwOOAPcZ9cmrpptx6a/Ldf195PNy200XXpe7X4sarMDwdoGQoDbsc9x26f405TjsABn CjkL1/x/T0pybinzOyV/xvqvuTFF6c3/AAO/6gO+7AIBIJIAwMkHI4/x/GnoWXGcclhgYBx7ccGp ttZ266bPclNRVlq127j/ALTDGPmPHYsNrbTjGAee+MmoGmifBRhg5wD8rD1xyPYcA5q1BKSVmr9P u/EWl1Fu1l+a0Mi7fgjoRnCnCqSCe+M44/UVkMSg4YE5w3TAwQOn/wCrnNap8sNI/C3dbfd+V/Mn nvG+6V328ixZgZ68AYHRW68EFvmJ6c98k+lXeQGUYBGBjBBIJ7j8f0pTk6ck76326rvobKTWi+z+ ZANwyN3HQNnHzZwPz5z9fas7VLg/JGX9hwVAAyeMdunb1ooRTqpW95JbbdL/ADX83qjGvdU2lo4/ dfXT8jM1DB0e4GzDqFkwOThf97nGPp+deaaf4yhsb+NDKqlyqFW+VdwPXHY9Rj3FetGHtcO1sk3p +MX6O23XrqctX3WoqyTt/X6GL408RtqV4i5ZYkHKMSFVhtAwSenXv2xXKBiSkwJP3Qq7Wj2Lkcji tG3y0VZaJa/15HVSmlK3VWdrdun5/cdTplxBLYi2mVXkfcsb7dzc85P5dz29zWhDYyWjwyYMkO5W +6cBc9wCOcckex7149R+ybp927Pt0/HW3pc+owUVWp06sY25bKTXWz/4c998GxxG6RsD7qhwABkk Zycjjkdj3HvXstuVV+c8Dax6ZHYkfnzXy9H3ZVIrS+3qmexjZv3lbRJ6/wBfK5LFDHDcB8MoYgEg cY6D09ex7fnrr8mGiIbB53DA/IdOPrXow5fauWydvXZr8d/vPBqTaiklt/w3+Q2509ZMg7gCcjYR gH3A69fWo7KJ4HaGNSFGCSwxnvjHWqmk4J8tnHVW69/n+AozjZwtb9LbmhLKgGBtIUYYEgYB74qK HG1GZVAxuVgT6dDik+eMVp8T27JK7++/QWsZPS2mnp/WgTI6yICgK53K6ZA7Zzx/n6VLKElQBHKF ckLgjGDzwKhvWKbaUU/vdn+d18y02403slvfunpp/W5FOpSHduUlSoyAAe2SfXt0rOQGBSVQYkYE Yycdeo/z2pKneMebft6behrGNk9bX/4Y/ZINj+eOf8ijf09PXpivXS6W0PnVovQkDdv1HFNJAI6f j9fSk00klp+gLr0Ef2//AFfSoy3QYGRgdMVn7q0Xy/zGlZaLYYSPZQORj1prScccYBz1wai6Sd91 +On6FJ9lsUXl6gcAAj05/pUaMTjnv7DH+FLS/bQq3vaIvRPtG3pVqNsDA9/8/rVRaX2bWX9fgLSz 0tY43xqR/YV9/wBe8ntg4r8p/FblNf1LapyLlzgYBAJ/z+tfJ5hpnHw/8u1b0W59Jkr5aNS6+0v0 MyF0G1gQPmUDGOF6ZGOcf/XrdtLwIc4ClVz0Izjv/P1/TjlrwjzTUbprVdvM+nouzetr/wBf5/ed XZamQAGcFeo3deTx1/rXZWF8uFUDbgA4ByRyen+e1eHN8rny9P60fR7HqQj7qjH/ACX9bHXWF9l1 3E4+uAeldxp8obBXGDwTgetcXLNXcXotv1NXFq11ZWt/XqdIhPAycegxgAfSrOQqdD0Bz7fhXH/y 8fdLf+vMGrQ93ToYN9OAGA7HG0HHOK5iWU5PIyDxjGBU2fMvy21KUOWN7bfqZdxN1zwcbSe/Hqap LNjaO/XABwR6nH9aKsZe0Wjt+Pr8rfea0b7W0JLi4VYhtJzjgADIH0/WucmkQs2OOeAfTtj86Tpy 5o04u63NY2112/rQqlipAznpuyAe/foB2/KrMCllwF5ycA8AnPHT6f5zWsNJe6uVpa9r/wBfqZcy ty/1934mhFbjOVAB3Y5OAeMAgfh7dK6fToM7do5GABxUO8WrNL+lp/wwuVapadf69Ts7KHAVdoyM EemOh611FogUDjjp0PB/z7Vy1E7xvpbp20Wnz3HFct33/A2UQDb6YHGRgc9cVfQAcDA684HBrKKc Z8trW1X9fcYzm0uVaE2dvQjpx2GarpKiyHDYxgcdAOT1rSLs9VbR/nYycte36gLnBHYZPTsQawbm fzbyTaTmOQMVAIIXDdx2JH6V9BktN/7VJK14aW6Hi5pJKeGVtOdfI5zV9et9G+13Fz9x4QjJkBhh C2QT06D86+FPGOqDU9Zvp4Duha4l8vIBbaGOO+Aeetfb5XCbp0YJaJa9Hr/SPlsdyutUdtL/AInF yRMMgDbnHJGQBgZ/pwfeoXi25HAAY5wQQD1GMfkPrXre8pP3dVt56X19f8+p5E4yvta97CBFxjKr yAVGN39feoZESPt357HPsOMcmjmajKUY7v56O6t9/wBwlaC0dv6RVJOB6AkhQSDx9PSkOOBgkAlj wCR19Oe+M++Md60bblzSSjZ203v+hnNXk3e1u3nt/XzAhSMLnPLD+E5+p6UmSMgDjJHBC5OeoxTb kouK6Xt+K/r0M7WW91/w9vxv8hMhflxn0bO4he386TPAwNvHQHjHByfy9O1VCU9FJpW2X3L8dduu g3JQs2raLTv/AFf8xe+D06deF64OMe2P/wBdRfd4ILHAyNvU5P5+n4itItRfw7rZ+tn+LXoP4Fbl 3Xr/AFb/AIAzPHLYHYgHB/Lp1FREnaQCT0xyARz1/rQno+ZJK+mvn1/L5iTScoRenX9PxEyMdDnB wMYx3H48dunX6JjjG3by2eSOTkZ/x60rzi1G2ulv87+pMuZKMb6xt/ww0k5GMITkgAAEdMf/AK80 e54A7ZK7QcE5HbrSi7P3oJdn16L8PxvcqPL7q67fd0+XQUngfReDnBPJ+724ye9M3YIG3H3icK44 AA68j0P0qk3Htp0XXt/wfIpqMYxUnrrb9BOehIGOnAGRg9SevXikBHcrkDKgbeRg8Z5x16e1S1Hn be7d/wBfT/LYzioxauvO6/UcO/ByAV25BAOM/gevX2+lAHpk9wuCOR1HP1pKOkuV2avZ28l+mwRt Zxi9V+v9W+RJkZOFOMnDd/UD269KM44OFO3gDOT07Z7c5+tKKfMmpX5l+ZTs48u9/km+/wDXYTOF ypI4/hxyARgde47UuexB9ACFVvpg8d/xrVQUUpRbs/0v/wAH+mZNNQWziv8AP8LDdpHAwvQbgBuA AxyP0/GjgA8srY5B4HXp7dMkj1obg1yp7P8AHt6N66dyoJ6LmSiunzE6424B9hnjGDj2IqQHGd3G M9eRken4fyqou0k7XVk/VN9vmVyKPu2Wvb7yvLbxS7Q4HygBTyB2wB9MD8xUAhhgxs6NlySOi9CO eR6fnVRb/d8miVtLa2/q5lK0XFR3k10+X9f8Ao3gXH5jByMZ5GBnPY/565QHbbjAyMsSuCCP5ZGP f3rRSuvh1X4IzW/Lba7flcnhT7uRt6gD7ox3P8xj3q9uGCucHHU5x1OBzx+ves1ezmlft8r3/E2j o7pJJ/8AA/X+tCEHDLnAXjptzxkkHk+g/X61zeoXCm7KcfuyQRgEMScce+M+g574rojzSm+VKEkt /nq3+GpFZR5eXRXt9/5lvJMcaELsZcEZGGQ89Mcjg9fT614d448HGyZ9YsiWtjJvniG4GFmYNxjo O/tXo4O6ahJ251+K1S7XvovU4q0U9En7tt/S+h5+z5mVlmaZXRVyQdwwT1IPTqc+nati1IiCqwY7 sE4YBcYOBg/Ufl+RV5pRjZWbW3buv67nRhdKile/6p2Llk88M4YKCY5WkX/aU+m3gjBOemMV6fpT G8RHRA0W9S0b5BBJA6H39q8jMlyw9pfVWXmr7fr+J9TkPP7StTcb2vp1tZ/8P8j2/wANxRWhjAQh mQEBuNpI6nPXAP6CvSbcg53AKdgBxnOPUc+/6185hXzNNK10n8u39eR6+Kd4t/Da6X+RpWx3x7Tt ypC4yCqtj9KtJHJbSvIrNtdeY8HhgeTxjHX/ADiu72aSkr/F16qzT0+Vzxpx5XtpL/27X8C3ayu0 TGT92obCn065wM1GCyT5BXB6MM8/hitOWVpq9mv1tf8AzCMVzPl00/NGDqUWqiRJraVVWNirxyZC vG3PTsfz/Wty0M32dN+1WGchQTxjAwOMY9MVlVSXLOF21p5XXVff+AR/dxmp6t7dlp/w/wAmAmdm YMxIDHGT8wb0I+gFSQuzOcnoDjGRgDrnI6daKiaSTW+m2t9L3+ZafKrtaJfde3/DknnBnYYDDHJX BwTjjH41mXtzJC6R7PkYYyQRnoMj35FawvBuMNOX89P8/vKglzqzslp6P+n95+xpbgDG3t6YoBwR 074+h9K9Fu14x02PnrWSS0RIGx+Hbnj/ADxUNxMIl3HA4xjkY6VlKfLbmWi0+8FG8ko+iGJOHG4d MduPxp5nTGAADj6YNS3b3ErJfhp/wQUdulis0gxx9Oc5+tRtKuDyRwaz02taxa3SKLOAc9uox6UR y9hx6/Slf5fkN907FuObgY49jmrUUnOBx+fvWl0tGt3+v+RL6dDmPGWH0O/UZ/49pcD/AICa/KDx gNniLUwRtzcSYGdvH49uelfK4/3c2jpdOH66/wBeR9Fk0rUK6t5/kY0BIjXgFSflcbsA5GMkZHBB H/AhV6OYx5yoTAOchvvZwcZ5xkGufEWTipaOz276aWPpsPJNRjLe3T7zWs7pgRjsRjPpn8x/9cV2 Fhd7QuCVUcA5z83H+NePWSfNFRstX+B7dOTUO7j/AJI73S5WkClMEqQWVeuDjnFehaRdiMFdwAB4 Ujv6e35VyOny82n/AA1un5fIqesXG9kv+HOrtrrHXj8u/Q5+tXzOdvHTr3FefOC5pJK1/wBblRcX He2hz99NtZsZAPUEbfyNcncTbWbBAPPXoO4/GsoJc1rfNdLHQopQcv8AhzIu7tY/X6ZwWPpx+f5V mLfKGABABPTJPbgcfnV1IPmSjpbfz22/Iyg/Zxl5tr7tdPuK15qKIM7gp29BuPHPQVhtqA3A5UcZ wMD3xWnL7PmTT0aXnq/y1M/aNOTWmv8AVi1HdiUqrdcEqcDp9R/jW5asuFG4KcKeCT/+ulVpvWSd vy0X/AZpC/NZJf5HQWxTCnjAyQBxj27eua6Sy25G3g4B74yP8iuOSso8yvfVd/L8jRLSWm51NpIO AeMZx0GPoK6C2kGRz2OB0rCV3NS6p/Ihq11f/gf1+prRyYPXpjjp3FaCzLjsCMEY4IHai3R/5M5q jUXtt+RG9wvY44P86zWnwzHd09OOf6da1UEm0tLaIzTsnfSxnNqH71EBYHcOhIH86831TxFPYeJE 8slAy5cgHBBboQO2C1fV5BTV6ie1radenpu1c8DPGlCk4vldzzj4leL4pgIy0UeQ5wjYC8YA5/D8 q+VtQ1/SYJGO8EjJAUbwT6HH4n8K+xwNNRTcVyq1temun4nyeJqJK8nb/P8Az/Qyn161kJMLBQWJ ydw+T3zz2qL+1Im+6eRgkAnjjg+/Xt6V6Lpz5mtuVO/b5s4OeV029V9xk3Grywl0SJmBAXgALz1x z6c/iKamoSzEDDKCSuPu9OfX055qnBxpp8qvptbTfb/PzE5dIK2r09O3macIwnRz3x069Rg/iePe pVAUZyARxgcD/I/p9ankvzQ5LXfz7p/PUiLah72l189QO0EADaV3qAQw4zgn9Bz3GCM9aCAMsFLA DIHT6f5/rTbptpbtb2urf1uJ8utls2reS21GdjkAkjgE9/oORyPzNAKqT84Kj5e525/Dj8R+lNKP OrLa1u/9XBKEoJc1m/8AO/8Aww887TjPJA4yPXPPv/X61CeBwcAk4wST7due/HHWm03FpWTe1un9 a/McbxteNlrr/XoR7hj7vGSMkAEEccHtgg/pTD7EA4Y88EY44x7etGkYyVvedv8Ah/mr3+8lQV4u LaV9e+vX0/QAcE8BQADjpt/Xn+XX2pny8fKucYXkDgdcZPt+tU7rkW6f39/687FaWjfrb5L+tfMb u64PB6DnAX6D6fTn65QEZPG3aF4HPQHnH0yKm0r/AA7X/C/3dCfsvl6X/Ff8MPxwBwBnHcY9+eKj 3DIO1doH+z1xwcjtj3/pQldcqly6P+l+PzE7Nvzt/X6CFdpzyCCDjGc/X0xjtRjblQp3Y4GOOeuc d856fp1p3TSfa1/y08h6weju+vb+rNajgcEnjOM9Ocke3PvSgbcsSnyjdnphvTHbirstW5Wcb3tt s0hOPLPtrbT8CTj+EDOckfd9eeeB1/nTeV5KjHAwOSCec4I/M/jU+8mm42stEuq0+Xf0sUoWlGUt F09G/wDhhN2BwD0JUYOOnQ+vU/55AGIOOMKCdxGDgZI6dOnX39OldLJ2tt2V9X+v3Gcle8Iq69el 0/0HZx1wdqk/KCGHJJ9B3NNz64UAryF456e/8qJKKUlzW5bfPvZ9N9ENuKvJKy1X9fP8EKo5UDOO eSSB0PPPH55p/A7HGecZAH1x79vr26XGC+KKtdfPyX9eZMGlG6Wqvf0s2M3ZXgYyflx2479+fTFQ ucLySp6fQn6AfXt/i4NxkujWj26/1+Iu2mz+VncyLtlAG3K9duBjk8cgDHv/APrrM3LkZwgB2jja oHAJI+nQ/wCNavk5pXh06dbP/h39xEfdlLl16W6bLc0IQHjVsAMBjI9OOenTp+X5y4wpC46DbwcA 55+g6/n+NY+9zRcVZLR/16nT7q5lbb7r6bf13K6nktgYAP1OOSN2OMkjj9K8/lnZ9TkJB4C+gxxn n1GSOOPWuunyOVX+Vp29G7W+/qcmI9yMZvTfRdFbf9Pmb3nFY0VV6qrIuBkZ5x+ZxkZ61U8R3EVv ot4GUHdGQwI2cHgjBPofc12YVRU6MVdJO610S6r+v1MW23LmVrW16Ws/v/4Y+a7NYZDOjYj+Zmi+ UBEU5GPRhkj8vytxh2YdDtJJ2Mwx7+35enrW9bSVS2nK9PQuimoQ5PS3VWen4HUfZ3SKCVWykgBO VXdgYBXOOuRnHfrXT6DLNHOFCNs80YJHzDacjkZxxnjjkZNeLiOSeFk5aN/+2vb5rQ+uy5Oni6Ul dqS1tsrp/j/kfRHhi7gvEjt9qpJAASpycdAQp4J7V6LEq4+Q9PmAICjGB1PXv3r5uhb4Y6Shbp0d un3XXY9HGx9nzxV7X0792vu0LMLnd8x2j7yEbT8vb5fXJH5VsbVlh25UvglcgAHjH4flXbSunOO1 n8rP/Kx5Ek1C97Jfnp/w5AIWWGQbjuI5zxkY9T19aSCGeNSXbdGRnnsOR2+n+TWk0oRSju3+S2/Q IS0k9tlf9fzIWlEm2NnZQDjB6AA+nWtUBAqBGOVHJBCnp3yOemPxpN+9FWSUb6fn/wAD5Da91Nuy lqU7ki2XcuRuU4ULgE/l7U+2KMqsAy9d24ZYY6qVI9QDUzqL3NLJ8y0+X/DGiS5X2jp6r+mW4VMb OfkxgkAAqOAcZrIvFneYbYwyjqxHGD2JH4etXCy9o9rqyv6f1b0HBxhNJKz/AE1/yP2NcqMY4xnv j3qMMB246AAkV3puKZ85fRWdgDYGencdKinYOhTj+gNZVYqUZR+7yLVkk46NbFONfKUqM98c4pd/ PUjHOOR/Kh21vv8A1/wQbu3buQySFQcdOw6Y7CoWkOD7ckZIFZq7cla1v8imnutLfmQF+CM4PpnA +lPQ4AwRgDOP04pPS10Nqy7FiLKntjt24/wq7C/OB7Zxxirjyu/S/wAgklyu3QxPFK50i/wP+XeT jkHlea/J3x6RH4l1JQMKJjkckjIOT9K+YxzUc3o6X9zTy33+Z7uTy5adfTRdO2xx6TsBhmO0AAKG KqMjIOPT2rQW4aQBSTkcDO4YHXAzwfWoxEVy+9p18+mny1X3H0eHcdLaJbPZ+n3l+0nKkj7pJ6dc A9v8+tdNY3Ox1zjbwCpbA29OOPevFr8yqRauk9L9Gj3qEdFputu/9WO6067aKRWilIHGWHGc8dOP Tt616BYXJbafMYE9eQAOvB98Vy2ezdnG6X3r9djpskotaPZ/p+Z0sF4UZRk7c8HJ+nAz+PNdDb3v QFhjjBOOmMD69TXmTi/aLVxb0+fy9RuCUV0/q5WvSpBwfTAByBnt/KuSu125J7YJwMfX/PpXNBSU pe9onb8v8jXl9zmT0OS1GbZlc9ugzn0GP51zJvGjfCEkAfMuOTnPPt+XbFdys6jcXdp/L+uxje0Z xS01t+NjH1C/LZCl1J24B/hGOece57d6x1vX3n5uFIAHOB1Pb/P9dlS5m7zaWmv4pfJ7nIlyWbuv 8zZh1AhowuTkKAR19OK6q0vG2qSdoIHbBH6eh/KpxEHZ2W/6aen/AA5pS0Sje3+R0VteherfxDAH T9OK6O1vxkbWIGcYJ5AwMjP+eleZOFrb/wCV+npb8zuTSUUnY6C11Hplvzz15z0/lXQW2p4x82Bn jH+faudJrpo/w6EO3TQ2E1FMDa2Oeg4I6HOcVd/tEAfeA44xxj8K1UOWzt1/4df13OObaaRWfUgF b5v1wB7cdKx59U6lWwM57j2z7VvGk01ZX/r/ADZi2tb7dP69TJfVo/OiYuyyK4GcgJkd8flXL+L/ AAzrupQJ4k0qIMLRW+1wxglni2I4mGOoGHz+HPr9Hk0vZz0i7N626ar9Tw84UeSLkrcuq/r5nyt4 vS4vbhvtCs7FgCm51GRxyPyrz+bSoYQN0KKOdu5SSD+HT7w/zmvusNpG0V116eX4N/gfH4mOkv6+ 78im9pb9BGi8cADAGPT+f+c1XNrArgr0wARgrycgADHTHU4rpvOKev8AVu3Z6nAk7WW/4JaDvLjB IwOpyTkcA+/Tg/pTlSNG2hOuTnOT6E4AP0zWbaSVlZpX+V+vf/gk8sVJ67bf8Em4AUYAI+XbwDk9 ueP/ANVP+7tVfvdl+7k8YA6f4VSvZyvZP/h3+L/plONlFPdfd/w40nngY9CMk4443fjTSSo5wnOM AEEdOv5/r+JuEUrqEd9fnbr1tcSsrxSs336XGBgozwPfoD06Ej26+9JhMMPu9ypwD1wPrn1/wq/f tdu6W/3u36L5CjKySSaj+dv6v6hkjI3HA/hxtJ546cCo2foAecEAHHQjPTPX3x3pSir3irPrZ7O2 vy1X3juo2vsthn8I+crg8AZIzn+vX8cUhf7qlsBSflLYHPBPPC8Dn6e1EovmXRK/rrb8kvxQlfXs vl6/m0NYjkKF7cAD054xx/Om4zgL0OeRzgdD9O2TVrltFR0tovXzv56BdLRN6/hft5Bk7cdhk9eV XjsD6n9fam4/4Dt3ZI6ZGemRjPBHFJN2dlZu1r9fX7rgm1FqNru1n07bAxz6kAZOTjn24+h/zyFg MqBgdAQSeQSAPrkEHihODfLyJrZdm1/w4NxcmrbaK3Z/8HXyE3cqCOcAZVcgHGc/qOlGSA3O4dCS QcY9gPoe1KME4xS0ato9LLRtfr8yXbk5U7u7/wAkrfj8mPI4OdqhRjHA4/h5HHt+dCkfKRnJXIAO Cfx6YOf61Lj7zUHbbpfTTXzstB3jzeffy/pP7xS2GGGA24H3fm65Hf8AzkUEkDk9OP7xB5/+t+f1 q4xdOz2tdLvfyXovmPmcHFqP6+e3lZOw0EDLAHoPUdSPoccdfcetAJUcnheCAc4AwMY/+vQotWlF p2t6vp6af5h7i2dm9fl2/roxdyjALDqNoHXjgHrSbuSN3tx8vBz17d+1Nq6ptLlu9F53/wCBZDbV /hSs7+Sv/TXzJl2rg8Yz3LDjBGenPAI/4FSEjHB45OABkc54I59TinFzi30Sv5dSWrbfd/l+H/Dk RYgA4x36bdvGe3b/AD6VDLkKQGZVzntkEc8E8H8atqCtyq1/vWvfzRk7K6touvlv+Ov3GPdyLyAW AUcg5wx7jHp061knJZl4wRgjHyjnHX8hj29KuUnSVOSVrW+5Xv8A5kXVnyOz6ab38vM1ok2Ku1vv fKSCOOh/wx9KGcIGBKkKwyowRnjA49Mj/PNc8uS0lC7bsmtdmv62Nk3BJN2tf8f80RsU8ts5xtYb TyAMEEHB+lecqR/aMwjJCmQqMZBGfpyPp7e/HXQSUJuMOXT8+X9UZV3G8eX7N9/66/8ABNsy/vos ZYZUdCTkEA8AY79cfy48/wDiRrEkMaWcTjJxvXhdq8ZIJ65A7Y6n616WEjebbj8C/R9PX/M5ZS5I VGo6bfnt955HbSqrNxtPDYODk5+YA46ZbOK6vRIYJpDj5Tw+CPlBPXg9Og6+v0FGI9yMprra68uq /NHVgeVyhBaNPb1/4FvkdmvktCIDn/WK6lXVVTOTnnjuAOPWu+0OwhYxuikOyMHbdg/dyO3OOT+O fWvmcfUmocsXaLu15PR69rv8z77L4xdKc77W+9KX+Z6h4biSF1YRqrqOGDAEKcDBH4Yz+teiW43n LnA4UdRjPb8ev4V5uGqe/OXLZrZrRaK6/rsZ4ubtTu27a/k2/wCuhaWNt6qvDKdykZ24znknoOD0 rQDOgXETbhjldgGSDx1A9T+FddOK5mknaX3RX/B/U8qrKXupabv0/pfmTeYsisgJBUZ5U5C9PocZ zVcXnlL9nJG7BMeR94/TFaOzlFcr91/jpe/TvYiMGtNtkvNX/pE0NskqCUfKzHpwPpwcZ/H0qWKC S3f5gdrZZQoyBjsecjr3rP4oyaVteuztb9CpOyjFfj2e36j/ADo52MbA4C4xgDb2xx9KpXLTx7hA ihQrYABA6c49/wD61XF0ueCaso6283t+I+WMGo99f6/BhpkrSQqzhoXQbGVgVIHYZ/z0qeKYM7Ky jI6cfiBn8vzqOZ/vnFO8Xt5W0f47FW95xhvbTtb+rn68lgF5xx7gVEXwOox2x2r0uVJtR2Z8+lZc ttECtwenHuAahJ5OTjB+lZy+J8v/AALh6CZwD9D+VVJZAp4I+nAxj2paP59Clp6Fdpcd+o4A61EZ OD2HHqKlXbktrF2fTSwxiADzj6dcfhTUfgKCM+mce9EtObT+vIrRRTvoXIZADtx2xn2+lXoG2k49 cjitPdWvl/T/ACJl7ulih4hAOl3i45+zyeg/hNfkx8RUMfizU+CBvHThSCee3PJ9PSvlMy9zNaHR cjt01V2e5lFvZYjpov0OFVtoDYHyg5UE8Yz2yPrjg/lVhJSuCRtxuPAwNuR0P4HjjrU1nyxdor3W 39/S3qe9hWubXb+tbF63l+bO4cnjPRTzj8K6mzcZAOMHGe3GMjntn+leRUjNfE7W17PRLRfefRYZ tO7dtPw/qx1tjcYYbTwMKCCBjnjn8+/Su+sJ2VQrAL6npjvwfz/OuNu6m3o38uzVvl+R2aO0Xp1/ E6S2uBkZxlcjAIAJ54/+tW1BPgAZxjHpmuGoouSe3TT/AIPz87nWqfu+XQVp2+baePQHGDz2qtL+ 8U5yvUdQd3Hv9P1rms05R5Ur/wCa/wCB+InFxjGOxy1/Zx7X6BucgjgjHauMuIiGBCquAQMLj5jn /POK3pOKb5dEnp62/pHLO6jNrRJP7rPY57UIj5hzhSAdpUHGe3GaxBERIOWAHtjJ9Przn8K7ac48 yi1a7X37fcjlsk03rpb8TRhJDLj7ylTxgAYyScevbt1rdF3t2kLGhJJZhkBj6spJA6Hp61NRKabt ZLoRH3GrdLmjDqAUKCw4PXd1ye2PY5rXh1YIVXcOeh+XGK8+SlzScdlK3y/r+tToVZqzitL6eRpx a2E/i29B1wPy4x6Vs22uqBjeAF7D3x7+9ZulZpa79rd/y1Lc0l8vy/q5rQ68AygPxjpk8H1/WtNN dUj7/OOcEjuO3atVFcqstJdP6+Zyyenu6dgl1gbCRIoIB46HOO+T+NYs2pExuyMvGSVZgpIxk4z1 rohTlzWsr7pemv4WMG3G91t+W5iX19ItuLhZVMfy7huQMrNu4IznOVJ4r1fwX43k/sefTJ4ZNrQS CC4VQ8MqjZiJ8epZjznPTtXuZWlCq4yjpJNf5P0PGzKPtcM7aOL/AOHR8o/FfCaxIdPUwSGQh0i/ dpgZBHGPrjvXj13JPI6/aSAy5BBwWU4HUH6fnX2OHi1BJbrt282fG4hWSk5e6n93/DfoUXIX+XBx g4/Tt9cVXPBJVsNnHAIyAcH8f89q3kp2T2/pfrt5nLLlur3Wv9WGkBCSD2HPI9SQD6ZHp2pOflyf kUYGMAZyWIJHuT/nFVFu6vo+3axLhZ8sVfX8l+o4Afdzwozkjpjpj0+p4+lOJOR26jAJJDDg8H/P FQnVluvdvdNaNLf07hvfS/K/+CR5PG3jcCc5Yjnk9OucE8AdaQnbxkEqMY6EDjnkfStekVH3X37X en+Qnaytpf8A4fQaTn7rBec8DGAOfT6n16H3prYAbtzgAcYI7j059SKpKULO6W6d/N6/e9fmwfup pOzX63v+ghIwQeOMkk4AOM4J79+9Rr94rxjkjHQfe9On5Gqbs5N7e8l62Wv+XTQz5fdfvX/p6v8A ATOOy8Bs4+YDHr+H1qKVNyHOBub3LZJOckDIx/U1Ca92Ki9t+1k/8vmVdtRj2Tv/AF5eYqKAAobD ZBBLADp19+CfTp9cgP8Ae5Hdeg544z24rVS5KllGy6Pt2/G/3ie6lF2Vn6/1Ybnvz6AA4+XOfY5w P84p5Pyg4APUZGOg9vwx+dJz5ra35flbv9xacrztG6Xy66/oyPgccqRuHy889unTrj/OaPu8lsdN vQe2OOOowPWqsocsE9Hsuvb+vMhScbyXR7fmISwwqnAHQD7qjBPGPx/KgdTkjAwB1GMZ9cduT1qY p3Uk+XfdFtOUY8r5b9lrtv5XZICOeeeANwUZJyeB+NPDjoOMYBXOR6jAHP8A9aph7qgpqzXS/wB/ 5oiN9W1bRP8AP/gDNwB9CDyM5J+g59f1FITtJxke3PBHWhOUOWVt1b8V/wAFjSaa10i/xu/zX5IC T8xwMHhgBjAPU8D0oxxgEr+AAxnjIPTt+FaKSi37tra9ttfzuEEkmozs9Hr8/wAwJ2hTjGB8o7kk c4A6AH6dKaWBJOQp4IABXGOOmQB27E/zEKMrRd3orer3/H9CXF295Wd9Px0+/wDGw7eR3X7vJBwe eRx378fWlDY44X1wANuR15+nStKcVy2lrZ9NOt/vW4JpPXWy/S9r+rIHdcbcHB4G1cY9Dx9Rk1C5 xkjOQMY5B3HODjj1FaQvDnc7aaJen6J/5mM5q7jfRLbzX5dTFvHK7h8pBAIUZJyASSOc9z7celZ4 l2kLtDANghQMhj0GCcZ9u9acnu66x00fmk9bdx058kldqPLa33dvyZrodqoEXaoVTjk4J7jPI6dD 6jpTycIMgDHXdhdoPP4YrFq0k/htrbtuvutt5s0lPSWlrW9Eldf5kDZ8mYrt2rHJhV5DcEY4Bx1B /wAc15nHIDeTKAAVnfAG3lc5zg4GOQP8McduGcpRqPzTXmu3439EYzacoRXX/g/daxvI375AcnA4 H3WyM4GM84/DGK8W8eXMc+thAV+ROSpJCMMAgHuCR6CuzCy9+dm7Rh2te7t+GyOCq/hSlorL7m9P W2pyVqi7wjAZYkBUBbg4Oc/1/wD111NirJ/qyqFSUYDJwpzkjnBxyce/NTX1XKv68/kejglytyjq 1t62v+h3unx7bSOVSiyk7XUgFsADvyBnnvzk9a7jRy9mY92RHICNwII3nACkduvr6V8rjpOcZpwt zNpa9VqvvX46H3+XxXseV2s0n218/Poel6UXhuIWCj95kGVQB74OcdenAPQGvQdPdvnDNu6cnapB 756DPX06j6Vx01Hmd95Jdt/0/wCCYYjrdWv/AE/wNeB0XPygE4xjJOST3P16e1aMaBmXgFQCW6jB x+GO3FdKupaSVktLfejx5q3Xpp5aOwjQQweY5lZAeVGOAQOmD26VFGIuJYdrYOCMgkZ7/TNaptrk 2UtO26/VsdPS6va34dVp+PqWvMViojIU9RHwMgjkf7J5q4sqZ4HQYYnsOc9T7VnJ2tfRW27PUl6J 62109P8AK5kyxSCQlf8AVkHJwMhhx9fWpLdMIXk46Ag9OO/HalOMnNyhpdxt321/JM3Uvd1jZWsv 69bFgmNRv+XDZGF4x+vbmqabYQ0rIQdxZcNkAc8AH86tpq9Pq7LsrrVjprlhd6WVj9b3fHGMAc8c d6heXHYD9OK9C62TtufPrRbXsNSbBwfl9uT+NQG5YSFNvHOKSTUo6W0+V11KUd9LNa/cSeaR259s jFVZHXtwfofrWT1cbaWK93TpYqM+DgDac8e1M3nOBn27Y9aHde7zW/rYask+n9bDyw2/06e5qurk MOwyPalFK/byBL3b7WNFMcfwkc9fzrQicdMenPfn6VSjrppb7rdgata+hV1k/wDEvuxx/qXGDnjj 1r8ofiohj8V344wSMdAOSfxzyfy/P5jMlbNcKvJr8/kexlDUY4hbf1f/AIJ5o0hABO4dRwRy3qf8 96sQyr5e3byO5zlfp2//AFUq0G6cve5X99+r9Nep72HajKKvr+fl95atpDv5HA6ZGNp5A4H9K6ez m9OBjd0wBwPWvGqxaTnbVq6+7TT+tD6HCtcsbPT8tNf1+R1VhKBIvH8RIySDj1Pb+dd3a3TmIL8r YxjhQwwAOSMHHH5k1xTl7slybrTy6P8AU9OMUuXTRG9azDcvAHJY8Y5/D15ro7Vw3TIxknPGOn/6 q4Wo+9HZrb5v8NTvatG+ysWGbYcbuR6DHr6/jQGUjGO/GeCPwrCMVzNON73/AOAZNe7fvt5dzEvy Fyo7DIAyVyelcjcAbj8p6HHtk/5Naw+J2jaN7/16nFNWTa7HNXuA3T7pzwRlcYx/I/n71inG/HIG ehwcnPp6c11Q1ST0a009On33/E5NbLpb8OxFI4Vm2rxz7YPfGcd+aabrZwxGMDOR3644PtW+sYv3 bJvS3V2Wv37kP3bW30+/T+vvFN7sKFiVQ4wwyA3Gcc9Dx6evtSf2nsGAwIHyjqvGOnP06msvZPm0 Vkl8m7fqQqiVtGhf7d4TJwwPOCARxwCehxVyHX2TCo4ByeMgbvXj6mnUpOElZbXT/wA/zL9pZKK6 Jm3aa2XlVVc8nHHGCcEf5xWvHrphOHIGB8wHBGehHYdKj2bio+7ZPS/bs79DndT3uXbQsjVjJG0g 37OQDk4DdOSOg59utUTqZJAztDcY3c8dDzXVTpu6lFWdtfT/AINzHn974tv6fyHia0kgliuZPJk3 M9vcIA6sSmdkgB452447mvV/AGoPa6Hc48q6RZZgbdowSUjTIwxGcEgjg8Y+lepgYKDWtrpp+X/A PNx7fsptLdp/10POvHPhO6vQfENrbSXFtvnkmQjcgIJOPwAUfnXzhqW03DgRCIIS21SVUYbJPPPv yTmvocE03ODqONrJ66NO1ml/SPl8UoRUYpWUkvv0vYyWUjPJyxJPAHb5fw6fWoSVzjB/2QOgPsOP y+lehO/K1F9Hp8tPz/M4W42cVpdPT77fne5ERgEY7Dg44Gc5P8qQD5SFxnnvgDrg/wAqOWdotJKP 37/8ORyrtsrdd/66ir8qkYwDyezY+vvjgUnyg4GM9eMgY5Hf8auPxpLov6+9fqSklsrb/ld2HYXg naFIwwbCjHPQE+vFTBIeNsif7vBI4yOD/k8cUJ2bSWiV/wDL+t7ahZQfMtLK2vT+tyqzAHAPT5Rj 7oOc/Xv61CR0GNvOSeBge/bkgd+9Vblklayd2l97t6BbVxS03/VfgDKc5wQOemCeRjH05IwQe/rU WCpHIyDkAZORkjHp/wDqoUqkbNpWk7P5yvt3tYm1uaXLo1/XpsISuAOhyQPfG3J+v4Uw4GTjIA+U BiME/wBM/wAqq8oO/LdLy/rRLqN/3Y2f9X/rzHA7SO3AHB28ZHAwc/jx/ihDA9Np4brnPYgfz/Gs 1y68qte6t2vs/wCu5C/litEnb8/uGsTnA64yRtI79z6kcUm7GenBIHbaSMc88DP51qlZW5dl8t7P X8f+HL9zRJ/Dbvo+uv8AXcavyEZXjpwAOvU9c/5NBz0yw29iCvrnv60K0ZOKTfLazemySvf5gnFO Sta2nrdf8G9/IBgfeJUngkAev/1h1pVIADc84PPGDxxx+f1/Vte87Lay7aeon7z91WsrP+vSwuRx twoxjG3jG3g479fX1oyOh4DHJxtzyACccewxTcVr0a07Nf57L5BeOsdr7efp94YxnJxsBOMYypxz nPHajAyQSh/ujA4YDjHP1/WnOycoy92y0f429f8ALzC65W0uWz/HoL0GzAA5PBAwcnJOO3U07jPC 7RjC4wAMcjIzSau0tkv6/wA326kv4muuv/D/ACXQYTxxhQuF4HU89cjr+FJxs4I9gBjGDgfU5wev enbdJWcbL5bafh8g5W4vl3Wq9VqJ0AKths4DBQPw+X6n0puMmNsEDGRng9sf5H9aUY7Sty76fjf1 uJKCcZcu6XyfXTy3K53Lz3A4GD0/Dn0//VVdy/JIAIxhQM7e5+hrVq0U72v/AFv6fec7g4pNLTt6 aO5iXRGSVbODkcjGATkcd85yPrVVfl242hdgIK4ycHHH5Dn+WOHUjLkUVK3Mkkvx19NV9xEUnJ6X ulp5Xdl8rm2oAjTpkL8vykH8cY5p7cI3B/hI/usp57e30qo6y92V7X+a1dzpclzSVtr6fl999fUg k3JBOAMHym+9kbiRjJHbjP8AnNeW28jG6nbg4kk6rtyFyfTuePxFbYO7jW91pJ/ppH121Wm5zzbS p30SdreeuhqtMIxK7HAVH2ncFw2O+DkdfyHbmvnjVbl7vVrp3cbVcruGcYBJB/z6CvSw6UY1pJdE u3f/AIbz3OSs2uWKkvNba3ev3EliCZUGG28AMMkEjGSP69O1dfDCIpU2yxlnVTlPmC4AY/QdPz/L Gs+W2h6eX8rs9mn+a/4Y7jT4XMcUmVyuCY0IK7uNp5OCO/5detdbbs7+UuxSxwWRMD0PyjHuegxz 9K+Zxau7cqsr3Xa//DdD9BwkeSkpcnZ2+Sf5nqvh64EiQrIqbkXDKwwwfH8BI+nHeu9gJBK87cYQ 4x+B4rzsNFJumtHGyv573v22/pHLjLXbjFpf56X8r7F+BtpI8znjg4O3JIGAOT/+utuNgu3YwU4x ydgPuMd+D+lditFcko2cFv6HjzTtBRjZ629df+D+hFfgPbyJyvy4BXgr0IORWbp8YtlX5yynJJBz hueMD/61ObvSpcqs07/Nfl/wQpL93V927dte3f8ADQs3ABmR1LRlD95Rt3KcZBz/ADq4u1HVoxtL gbyc7c4yD6etS3dxtCy5bfd1/wAw91QXu6q/9fgmQzzSw5Xb+7K5BTGAeen+e1RmVpIgArLuVh3B UjBP9fy9KOblntZfk7Xt82XFPl1dvTuiGYSLHHGrAdAegznHAwffP41YYhYUSQEZyFY9m4x1/Kqm nKVGCV3q/vTfrutfU0n/AA5was0/l56fL8T9ag6468dvb/OarswOdvReeMdeOldzVr2Vv8z5y7il poxFIX2GOB0I5zQxXdnAHPX0+lPVNdNC5aP3fUYWwTzx2Pcf55qFsA/oOx/KsdY3V7jjpFIry8dQ B9P1qHOOOOmalNLW1rFWVtRrScEcZH4VCrMe3HbrjH4VS01tvt+f5FfZ5du39feW4n4xz+YA7VqW 5+b2xkDOD6dPxrS2q7Xegmvlv/mJqpBsbgDg+U2OmBx+lflZ8WY/L8V3mQcZI7AjBPb8c18vmT5M 1wr7p2+56nrZRzXrxXY8hduT0UqAFbpjHcjigOBjBC8EZOR7fj1z+fpUV6crRUXsnf0dr/qj3Kdl PTRL87f1cmhu9rKm5MKOu0ZB6ZJHbC9z/OuisbnGMnHQAcgcdOSPp/np5lePLaMla8e+i7v+uh7u FnyJWd/+Da/ysdhZTEBGDAYIGSwGPbHB7Z9s13umtFLH8syJKB91zjeevGO5/DpXDKnKSnGPxK7X T+t7/I9f2yhB2WhpJcCJwHL9DwwI6j0/D9a6Oz1JAQoIHHY4I7H+defyWkotXtudcWlBdlaxpS3c aqGRhyF+XIHbuOv41Ua/XkK2B2+Y5GP1rNxlDmtG1vx3svwu/UHJKC02uZWoX6lRtblcjbnnn0IH sK5qS8X5xyuCTtYgYHbGPqPyopw5qkrRtdaer7f1+Zw1mnTatZPZefb8Tlru8XJXLZ64AHGOeQT8 vIrFe8UE7SM5PqcHvjgetd0KbSjyx2v5dFf9fuscik4xulvf8Cs14m4YZvXt1JzyfXr+NV5blOcn B4x0AxnHT9f8itlFwi1a1unXbT0/yIlbXTRa/PUqtOpztI7kDIPOOB+tREN5ZUAg/LjJI556f5/S lH7MWrN9e/8Ak/8AIwqTSSW39f8ADmdMssZLZkXJ3Z5Axn/x01S+1SxuRukOMnIIAP4ce1dMFDXS 3+erf4towdaKlo9Vt5ev6fIu2+seUyurmNxjjkNnrgemM56/zrZh192mdjKHJVEKSkMCqkFQO+Bg frTcIvmjbVP8Hr6X1aD2kefulp+N738rnQ2GruAc7TGy7ipzt5I5BH4D8qf9vG4nO0ZC4H8h6d60 VKKcXBtX+V109P8AJiTipb6Pb7rf8OWN4ZEkiIXqBgsMfLzweMYyOvtivfPhelve6XfQNcxRXETS yyxOUVyDHkMpPAyyx5+hrfBrlqSs+j+66/rucOYR/wBmqOKul/TPSoCToOqxW7wCBllHlwyQThJu smdhOwFmPBx1HFfnv4numbWr+JYQpinkHXaCd2Oi8D869/CJSkmo62v2tofK4y8bK234afcc8zyF R8owQRyQdvYdqpy3ITg5AAYqwBH15x0zn8c16aVkpLR9ulv6bPPbsm3v0t0/r9AW6D8YI/xwBgnH T/AU5SNvIPrzwVBxge3OT360mpJSTmlbbyWmvl6IL+60nZrT1tuxwAyQBxnJHyjjdk8kY9fpTQQg +XjCrxuyPpjp3PT/AApKSenLyt7br+l/Wwqto2dttF3Ks6zdFcqTwAMDkE8g8k/zqkbO6LZ+0suO doAC9BknP0HtXVGUI/8ALu/L+mmv4icUryvZLf8AF/8AAJoYpoz8z7xuIGRjAAHXjGea0o5YE3iU pGqgkE556YHH0z+NZylzTjNabaed9kEYqPvX0fyS/p/oV5L22Z2WEq5XhiuAAc8nrn19O9RFhngM T6AgEDrj3qruMIyXvWeqt21u/O9l23Ju1Tuklra3cTcxxhWA28HjjHT3pDuIUAhRx3GQo9sHr17H p70SnonKO3b0tt2uPbmdrW/p/IRSMEAE9QcE/KM9yOh9u2BSBvmGfl28ALkAD0/PH5iojHlipLRu PXpHrp3t/kTFcsk72uvX0++zE+UHAAX2+UEcAdB29qR+OFJBU5PPRSeeOn4n1rVbx5tUu2l/l9wr Wi3HfX0v/ncVdmcLgDqeid8/lj2pvyk+hw3AJwSOR0PHbHHp2FZ817JR5eXZf157f8EJQtotOW93 37CArkFcZD/KeOADjpjn6fWnEsBwfl5Ck7D1AHTt6Zx+XZqc1yq1tkl15tf69GWm4p2TXe2v9f0h 29QV4PORjuPTGOh+lNOODgDnIB454zx68nFO8rOTXK1ZL5rz9CG04y6NW+QhfGR7YIGOB3P9akB4 JCqMcA9BnPPbHXv+NVFWSS8tOy0vbz/4calK3K1dPt2/rX5ocM56qFypye+TjnbwD6UnmbVHBUZ4 zgccDr26ZqXJxS5Vdvf56P0/4fsKKlTvyxum/nr/AMNYbuOCNoVenAwPbp0yDTC3XP3eoBwgUAYI z+NXGLhLmkuqv0stLfl94Xu9Y6duy9e//BAsnBIxjBwhHTafb2BqMtz93AAIGG2kH1B/z1rRxfuu LtfTTfT8uglH3krpX087K33Lz7EZIxnYcYBwGZSefXt0H/fX0qvI+ASc4JDDOQMg468DpQrpuTei 6durfy3MbcstE7W/TVmDdFd7fdG5MMcAsFwR6jgg9M//AFmRkK6qVOAGA4wFwOQcdenvTk+VptfC /vTvb7/LuzONqcpJLXm1t0v19OiNYAjbgAYGB7KeB34OMfkaVgcYbJHAVlx8oIyc9cnPt0x6UPlj GMY6XX3d1+Jqmtu366r8HuTW8RlEuPlO116AcfTqc4J/CvGmb7Jql3BtIAlcLkZ6HO4AZ9enH8q6 sJpGuo7RSv6prVfiY1rQdN8vXTsun5mDr+sxR2UyRSqshwBnBz1+7g968eQ7pMPmM7s/NjnjdjGf c9u9etCLhBqVrv8ALp+BwVJ80r7dPnd9PT9TrNKt/tLouCzqm5QAueAD3xxyM9a6mKydmjMKYHfa MFWP3hwMg9T7V51eVpatKL3T6dV+X4n0WX01yRahduzv6W0Oz02xkaW3UOFJYIy71BLAcknnkDGO R1969I0y3gt7jMrKibd4YlAwYgEgZ+6M9ffFfNYqUedwpq62fpvfz009Ez7egpwoxjCVk035/Cvy f6nZaRg3u+Mr5YC42upJIGOn0/ya9DRQqrj8AWGOvY9vxrjoxSqTl1ez7NX3+6/yRx4x6QlHTT7y QKqurNGytwFYHKsoxnI4HXHatoIpQ5PGOvbOfX8OldifvNx1VltdLQ8uUm4xT0Sfpo/6f3mXel5I JYoSNy5Mf3lDHGBz3GQfaksY50t4Q6ruU5dAFYdwMZ49DVVNI0+V+8nrbtb9NLjpvlhZLllp5Jml dqXhURjDqQQT9CPrnn+VZGk3V0ss8Nyn7qFsK5QhdmBjA9sn1o9nH2XOm48iv63a6fP7ghbVTVr6 /Ly/E0hK7SOIyJIyN4H93JzipWdCBEVIK/NtyF2kHnHvj3qatlOTslHy72s/xuNaqKtZx3t1/q1x RHC5DKnK5BBID7f8ildovlQ42sf4nDbcf/qAqKcXzRfNZ229dbX79rdi5fElF2Wui39fmfq3u+Xr z7E4Bphccc+p7ge9er3d9eh89d27foBlHH1xwD2+tPDfXr6dKT291/1uVtydL/iRTPt6Z9Vx61UM pJwc/wCe1YxjZ8z6XKVlsrb/APBEZht684Bqqz4Ptn0/Kk5RUvn+XQpaRs1awpHGRjnPtimD5SB7 +4FCb5rXt/w2oJaW7FlOMZ4/u9q1Ldh0GcjgY44PNXF8uqj/AFsJrYdqP/HnOAefLb2Pf8q/LH4w qf8AhLbgofnXftX5QxyzjPPTkf57fOZjy/2nhH0Sfy0PWyl/xpR0dvu/pnjDE8qcg7to4xgjPv7E /WqkjbQSMnlRjOGAJ7jPH0I/EU5T5YdLK/4t/nf5XPYh7j1taL/rQiic7/4QSCcnJyM9MH8evvW/ a3QXYhONvAJHHrx39/y9eeCtQvyyva609H+l7feezhJWt0S1+XSx1FndjKchRkdN3CjHTHfp+ldd YajsCoCGHGAOTj8a82cJQuk+ulvK/wDwx7EJJwim++nla50H9oE4bdznAJz0wfwNadrqKblIIU5X LDJBBrjdN8976PZ9tn/n9xvGfLBxvZL8tNC3calgAqxUr15IIPsc+tQR6qfmJODkjPb8hx071hKh +8stu/ZidX92lezMe+1IEE5xtxkjgAnjB+vP+Nc1Pq2Edtx2jJODgckZ9wevNa0Kb5uR6Oya+e6X bRM5q1RNWWhzNzrGcjcBguwbgYHTGQfQj3wO9V9N1CGSVklkWJTwHd9qIe+4noPeu6jScpvorO2m m366nBVny03yu7tb8f62JruC5t3LLDKIyCyscMm32dflbr29TWQbtmYquBzxtAyDkjIOPTt3/OhQ jFTi9Hrfo1t+V/uRjHELW+1k33NG3if178DG4Z64A4z0rbS0bYM524HQY59/0rkqVOR8sdLa69m9 Pw6d9zmrYlWjyaX7/f8A5FWe2ZEC+Xgbcq54PUkjP1JHf+dc5d2pVshShXeWwcZyDxx+f4VdJuOl 7K/z1eq8/wDhzg9ulJvz/r5GL5TMXALcAEEggY254xxz9Kswq6YXnKkrgjapOQPb3rslBqC96zVl bvpJ/wCSNYV4ct72Xb72ztbHzFto1KgZiOxvmPcZxn6Hg+tTpGSTs+Y5GVwRj1OB/kZ7VrzWak1Z 9lst1+unodEanvNLZ2/z/A6zRl+V7dlQpOu1TIRH5chIQcnnOWVuwwDmu00GzfTrq9hZ5rdsqts8 hMQkQ8FSykDJBXkHHNawi6Uotu2j+fT8epU53jUjvpt6PX8z3L4eQ48Ma60obE8l1L94v8pjzkHj qVzx06c9T8U+NLGGLWb2SJSA00h2gc/eP9SPSvbwk3+7jvdL9L/gfMY6DVWcUtO3yOHkXB4z64BJ wvTHHT1/CqbxJhuBwD97nODk9/Q+nY9K9KKVPllrrbbt/T67dTyZJJqz0jb0KxVR0UABcgkYDDpj JP409SVQ4B75IwSpP9f8/U3fL119Vr/w3yuQ+W107W1/r1HtwcZK8ZJ67vUY/WlyOBjbkY4IA56f rVQil7vK48q6/JhNK3vLbX+kITtGB0GTyM4yc/403J3AMQByR2QcHPXGO57HitYNyV72bWi6a9X6 /wDDiST08rW/r8/Nkf3WHO48/dJOT2Jx16enTFRyxK6lWUdvugdeSePp39qmL5ZRfLZpvTt3f+Xk TyP4ej0XdlOKxgikZownGWO3jbnOeAeOM4I4JFWeM8cBSMDAJI5/EdK6FraMEr6S/Ffju19w0oRs trPX5a/qGPrj5hkevQD27cUm7C7UIDYOWxg5xzUcsW3d9X8rva3zEne6elm+n9bi8DBOMZ+cgAfL gZGD35/zmowcqMABx/DklS3Geo5+pGefwqY81oy25em211/XyKUVHS+u3lb/AIYTOVOPlIHbA7ZH f0NHzZYYICnAwQAGPIz7H09DT66aNbW6bX/r/Mh3XKl7t7X9d3cYB2AGSR04Cn39KXBx2UDI2rnP TP8Anjn86UW1y861eq0tpv8Aju/wLs1FW1vrf/P/ACQ7uOoAPBGcADjnPtkdaYd2Bye5ChhyODjg eoPeqikrd79tLrS6/MUG+VqL0vr+vr3+Q49iMBgvAxtAxjnjrxxxTRkHJwEAySBnnrn260SbdSKi 03rpb7vu0+XqSoOL79Nd+9hQvXIO3BbB6DJ9B+PfvUw28kHaADxxgn046eneqdqcVZ36fPVf18iu ZaWja23z/r7h4OMnICjBAHysoPIzgdfr+NRjceFyM9WPIzxjp15zUw0euiS/r8dAU/ZytLr8/wAv MUKeB0Uj5tvBzkDt9c/rRyCM7sA4+p6Z+nfrWztFtJp2/r520/Mib1btpurdW/y6jNnXpnHA6YOf TP6UwqBgtwCWwfbnA/A/zFVFNx91PT9epPwrmeqZWyckAle4+bGOf16frVdzjLZIHXO0A7uSOhyB 9PWqUuW9pXctNe70/C/+ZlNyTs3e2nrd/wDBX5mDc/Ow6kJtA5AAzjpx7Z/DFRRBt6YIUjIUgL8w yMntz7DpTlKVNSjKN20tNtbuz/yITip3UW3JK+ttL6f5GyGCkdSDkZGGAA/2j17f5FSkhRwAo5yA B74xz161mkuRpOzSvp1uvyWhqoQu2tO69f8AgIu6cWLPglcDkMAF2854/A/rXjXj+EaZfT3aMU8w bwQABnAPr7/y9cV2Zf8AHOMlry/i7P8AO5ji9Kd7W5Xb/gfh97PnG6uprm5kaSQlTJ8oV/kzkbcE dOvrV5JdyqpRcxqBlVBZlBAGTnggDrXqzSTUr2t+v/BPKpaOV+v4bnXaE2LqNk+UqqiM5AcyZzwQ Rt5UHPNdXDdTxSYddp3k4yFDdjx06/nz7V5mIjDmmt2rfhfQ+qy6r7GKl36dlp/k/u8zsbSeMOks UmWXBCkEMjgnkcYPPpn04ruoGTUoVZT5TMpGSADv6e3PqOnJr5nEpxqQduVR0evf9N/6Z9tBp0ea Ltq18rfr+R13hq2ubIMssgkPUHaAATnA444x/nivQopSYxwUPG8gfIoHp+fSuWn786k4qy5v6v8A 1bU8/GXajG9tFbt/mu/qa8BBRBgsowVYZOAM8e/0rViAZDsYlOq888nP4H/Cu6LXIqaV3tb5o8up JK6tqv8AhitOBEhG1QRgBj8vfPOBx1xREy7csdm3GCp27hjOOOgolTlo4uyfy3/r7kKL9ySa1Wn6 /wDBHkqFYhyOOm0AAj2P0/rUMLpcBiFymNjYOGA4zkdD9acFeEox0Wi+fRFRvqltr8iOGzjsdphd vLcksrOSPcDngc1IB8ysuGQk/KOw79PqPSoUUlLf3unZ310+80S0XRJJL8v6+/qMkHkqSRtBHykH kE8Y6+9U2cbS2CwUk919APrjjpRKCsp7a/j5IqlFPaVmv6/Bfmz9Y1fHGfX6D0+lOLkEDoPfg8/S vTkre4/66nz3ktmLn0x9OKkRjgj1GR3x9cVk9Nney/H/AIYrS2ita/5jZM/z7cY/yaz/AJVPfrwO eOKzk3HlUF/V0UttNBryAYwOmT2H+etVnk25PY/UY7mpcVzWbtZ/nZ/doVZWs3a39XJ0lUIR3Xpw T7f/AKqarB/w6dMZ700rTfK7WQL3b67EwJBC9l9OfzrUtiNwPRumOg9KqK6376Ca7PREl+QLWUdt jdPpX5lfF+3B8VTFVxzJu6gbtzdhn2/L6187mqisxwTcrXuvTT/gnp5Ul+/ja119x5O1pHnIUZOc MFAIzjhfXrVK60w+WSoXbncSNvfHHXnoeffmk43qNNq1/wA9v8z2FGUJXkrbf5f8H5FSz0xWuUjl xHHkgZ24P3u/tk+5Nal3oT6fITGxlhb7r5BXLKGXHJ52kHgnBNY4tOMKfKtLpNryWnybtodVGfLU 9m9brR/oJDDNFjYBkHOX5x1xnH0xzW5aTzRyDhhjaVA9v/r156k21FpKLvd/f0+75vyPXhiE4WTt p/wxum6dgJI41jGQDsEhXcSccEn19RSw3b4Ab5RnJILAZwfy6jj2/LOdL3uVydo208jSFfSzlt+N v8tSW4v2jTbuJGFGVYZOR2B/A1UXU22sC+3GcEYBOM+nQ5B/OueNBqo3f4vPy7ejLc/dXS+mnQz5 NdNm8paKO5hlQRvFPvMbAncCNjKwIx1B7mucl1KOXzjGqRL5khVNxZUUgEKhJJIGVGT7VtGEeS1v eirPs+v3q7Xpc55VLRcua17adnrbzu9uxy91PklR8vUrxhWJHAx1H14/lUFvLdA/LlGycEZHPX/C umnGUU4J3unfXZNfhY5a0+WDfl/w9vzNOD7S7AZkJOQQzHaTk54HB6nr/Oty1t2DIpXnO7AUYzwf /rVzVeWMb6Pld73/AAt935HFPERS7W/p/i7HZadZMQpCgdDkZGOmRzXVQ2JMeDkDptwM8c4xj1z+ deNVqcrmoyVnt9/f7jgr4iKlbutuzIbjTSucA7hyOCNp9hXOXWltjIAU9AewGMHnnHAqcPVbc1tb b+u/XTucMql5NWtb+vzMWPS9suxh7cAjHJwRk571FJpywttA4GSCOSRkg5B6Hoelemq0VClrp5fK 33mtKvy2jy+XmatnJOkH2f5vJABBAA2n2z7gD8K0I4n3DG7ccZAJUgYycEf569zW9GbkuVq3b1/T f/I7aEnt5/dfp/XU67S7V7i4jhtiJ2lCqyYdGGMH5mI68EjqeK+nfBvwU8T+MGtJ9QuXW2wzxRW8 TSOEf7w81gADz1welddOlVrTVOCb1t5b6f0jqxOJpYSl7SouVxT++39PQ+hpvg9aeDvBep2F7qVn bBYpJLee4vkWRSwYmORYwWxk5xtYnGAK/KDx3dwxaxewICxhmkG4BlRsHbuGRnnnjGfbNfQrC1cL KlTm7O3Tp+v/AAT5aONhjJVKlOLtfTz/AF8zzZ70Fi20gbgOAQADj0/Hj/61VGuGUny1yASAcYYY yO+PQHHFd6uk4xejTXzuv+GOTXVxVv8AhlqRNdH7rQsFHJA4AHUH155/SlEj4ysRz1VenGcjGeP8 5rVwgo2vZ9+z2/DT5Csrctrb6dehKjO/GPu/KRuznP0/+tUxI4yQM44U4BH160oRSk+bbVfev0f5 Dk1ebas3orL5W/BEfJOcgZ6YcA9cYwfbnjP4daZwGPpls9SevPJ/Ht61aS0jy2stPS6/H9DJxXI4 20X4bafLX7hMkEg8EcYwcYyQenHcHimDHQHgHuMgg/TpR7PlTls10v8Ad8ru78/uKXu2aj/W6/ry GlxwMHGRnIPbGeDnjp/kUm75jgZAHGQQvTn9P5n8B0uWV1LTRPpZL8n5/wCY42tUbSTiI25QeSST yAMH0yCD+nHQU3AU/MQC3GOMbT6gcZPv6GrUZSS1vbp3fR/18yLuy20evn0/P9SVYQgyAFwQcjnO cc8+1RY2njClgcYY/KSM4J4z3HNJ2UdFa2/kv+BohNJNaarr5N/5fqIdvcEZwAMDb8x6f59KAFCt gqrLztbPzdBx+o6dqekVLorLbd3/AOH/AALSjdea26d/x2EXCg5U7h0x2z049elIMcsrD73IB+7x k8Dp60TlqmpWWl+jWif4fjYTmrWWiV9u39WE3cN1I2g53bV54I9+nf3pHxwQ+Cf4WY5BGD1H16df 6tSUFyQjeHV/Jf0/Ulvks1Gz0+//AIb8wBG7GR3CnAwB/hz/AIClUEduMld24/dycZI78YqIy5Y2 cU+XqtH1+ejEuZNqWn9b/eOUnCnAHOVKnAYHk49Mk/pUg+XnAJBBxxnPXG4de/tVxivi77fev8vW 9zVtKDutthoBbgBiODgYPAOecHpzUyrg4xgYI+Ygfkcenr1qknFTS69P689SYNwbtGzf/Df8EfjH bPqO3OBj+nFMYFerYAIO3HH+PXt70KFua65b6X67/h0ZWr3jypWVv66WBl2huMDIBJyRhh254PQe 2ahYDbkBTgdPUEnkdsdauLko+67J226N7ktrmjeN0tLLp/S1KjDCsQcHnHcAjtjsOvb3PtTuE+Vm znaBnByRk9z/AJ6GrXJJtWs97/c7fM5qltWorRaPr/X+SOem2bhsBZQckEkNyR7fU/X1p9qFaQMO D1AYnAJH3RgD/P1FTK8pppaJ/JNPb8fuSM6cYylbmsml9138t2a+W4GCuW7gAnockj0B/lSuRsAD bRnGeRkHoefYd6mmpxgr9f8Ahlb0Not7Wsno2/x/VFvTyI5WHyYLgZ3Agg9BkZ79Pwrx341ubWO3 Vfl85cJzhW7nbjnrj9a78DJfXX5J6d+qMsS2sNVku+3bon/XU+ZYi3mDkcuMg5GAOpz0rZjRjtYE g/Kobd1zn168MePSvUnZNfM8ei9JdDudBsGnW4RHVLmBPMQMdrOg5baT16DjI7101iifKuPND/Iw LFXjbIBIBwT3x9a8yvKX72SWqaX4JrT1umfV5bC7pK179P8Ageh1AVbUw7VLMpyFCeWMDH3sDI9O f1NeraRGJkjnESpuXO3hvm7dO/59fxr5nFbU22lKV0u/R3+WvnofZwXs4uHL7unlqdxp8PyLKgC8 HK4J5GD6dOfWtm3MmACjKM4xjgnOfpjnH/16zhdqceazvyt7a+X4fM467fNqtmrfh92pvQDYi4DA LzgKdpHHA/LNTwweVI0kYIDndjcThuD0Hb6f/r66UeX3G7+fW+0jzKulV2W17+r/AF1GQXhu5ZYQ ArQOUcHcF7EEexzmrFxHjCsdoLZDAZKEH37dRTslU5ab+G97rbrb1a0EnC0Xb4v+Dv8AcTKixwKr MGJB7ruIwPT/ADzWLLbzRP5tq4VW5ZMsAwJJ7dOSef0qYX/eRty3vp33t6b7+RpG15SWy3+e/wDk WYCzqVb5WV84bGAwJ/DHtViIyRttV+nRAPujqf54/CsX/Km0118+/lroWlyzcaeyW5V1G63J9nzt YleBxhuOCPzJ+hqGVXEEaqSHGwMNxB29+R16fmea1fLbD01K3L71+u1r+moQi4/Dor9dOtl9+5+r olweOgzjsD+Hel83IGMd/rn2rt5U27acu58/btpYcrAEc7cdu2easpIvTjjv0/z16UpJcjUVZien UjkfAPUAcfX8azyx3ADGPbjn8fas0nzN/Dt/wf6+ZpFLl2sx52hcntgY/wA9OKrMRzgcc4zxg5qX bXTX+maRvZra39fkIGXbkALx+X0pizBeB1z2AAFNJXT20uJrR3VuxOkh644zjPp3rVtX/D8uPy9a Iq1u3ZEt6PpYtXpHkS9ANhHsOK/OL4uxN/wk8hULyXJAxgAP3/DNfN5vZYzCNrdv8VdWPXyZXlWW 11+jueVJGGCgYGCQclfmGO461L9nBG7KjGcfKBx1wuaxqOUbpbRW/ft+vmfQ8mqfLdfr/wAP/Vho suGCog6k4GVUk9cjr1NTxRrbDG54m56J8rkjGM9s+voaz53yS1227dtV5rZryJkorZap/h5EYhAB 6gdieD17Y+v6mpFhA27Fxx908YPJNYPRpxjy9fLp/X3HQly2nFdP0NSDIRkOMYX7owPT6d/0p62q 5ZcdQQw6MpPfjr+FS+STcmu/y8gi/efSzb/D/Mp3FqV4wQAQRnlPl759apNasFJG3byBjvnvjoPX 8e1KMU4326ab31tb8/RFznZJJuzOW1GObkYB2527SxGMcBccevHb9ayGtJVBxkLjgHI6ZGefQ/1p 8i5m9m3+L/4fQwnVcUnKG7KP2OTd0yAMEjBPrnjp6VrWNgSMhCpxwCclT2Gfx9PWomvZ3b92zt8t v+HOWvUad4O2v3LrodLBppB8zy19MFcnsMe1bttpvKnaM5z0yB7Z/wDrd683EVIcrSjb+nd/ff5W PMq1JaRfp9/Y6+ws8FRtUcjtjIGOhH5V2ENmuAFAU4Aw2QMjH3f1rx6my0ty69tb218rbfecc5tt u2uy7/1YnewGwYxkrgDP4delc/dWCAn5VxnggBShB4PH06j0ooP3nqc925SUXoc1NZL5g7qpAJUk A8H24/ToKyZ7I+dggcj5cZIGMnscDp+vvXbTcrQ5VZXa30tpY6qElFxtK1l+r/4BqWtmvlhSh3cf dAKsQRjOfx59B71sRafCxQYK/L2UgBh3HI4zjj3r1KNuWVn/AMOt/wAev3HqUG1NP+tLfib+mW72 VzDdQHbLE4eKYqpG4EFSVOR2HBz+Nesw/EDx5LaxaaPE+qW1iFRPsVjOdOgZAOjC1CcE5znrznPf soYuthb+zsrrffX/AIfX0O+eEo4mMXWhzRWtn3W1z6ItNQdfAzxXrSBzZgOzO3B2kk7mzmvzH8fR Qf8ACQahJE2QbiYrkA8Z4/Hj0r6ClOrUmpKXvW3/AMvkj5mpBU6taNOFoq9klbstPlc86fH90DBB BIAxwe/eqrKBggL1z/CQAD79/wDH8vQhDljH7r+dt3955s9HZLluRodpBwpG05AGDj2I/Chgcjae 3ABxg5zz06881s5RvF/adv8APbtbQHHVXlZ/m1v6IRR34O0HaxI/I8Y9fypcd+MA4HQZOfUY/wAg URi7Rvv1+bt/wwnaMeW9m2vTQjBA2nBDDOOeCcYA5/8ArcflSEg4xwW2nGMg8EH6c5/Eg96vlklq rJX2du/6CV43u7J/fqv+D9yI8heMNlcDJPv+Hof++TQB/DnbjgYx+Gcfy+lJKKhGS3t11um9P8/+ HG3ZqMXb+v8AgWGAgbuhAJIDA4xgZ/L/ACKM428YyF42jBB5IGPpmm39mKT8u2ivf59OwRV6TXZP Tu/Pv5fIaTx34Kg49SD7dKRm6qDt2ljkgjHGQT6dcHjse9Umvdko2t59rdCIrVvltZfcv+CUS96h xGVZeQcsBjPJ6DgDB59vWrStJgD5VPUgISDg9fx6YPrxRJxtdK1976Wtdr9X8g96ylbRfd6/Ieee gA2464UZHGfYcn+nSk2fKOPmGX2thiMc4x6c9fYfiLmvC0r6a+Xo/wAPRlu17N6r5PuLgcjoFGem CrH05znn9TTeRxnpkY78/j7EZ4+tEYxh8cL2Sv1d7W/SxPs7e7HTW97fn5dRrNyqqCOoByAcnAxx 3OMUg9Rg8gkHGSDgjAHTv65/WiDpxTSVn26b7fqRdpKV7W6W7f5iZOeDsIXnPJyP0704A9MjIA+X oOmTyf8Ad9R/SpcvhcVpHS/lfX+vkNWd76b20+b/AK/zHLuXPzYI+bb8oCnA4Hbr/nFPJIyowM7t wIAA6nr06n+VaXXuRireXzHdWairq7T+e1vMmRTuwMcKeDgdDx+A4PfrUxAIGeg6KCV/Lmk1ZrlT 10+//Jv7g6Wi7bfkr/d+om0jGOdoPQj8gCKQkAngjlTgqDg+mB7Z/wA9KUdLJuVlo+/n8rfkXyvZ S2V/npYC20kAjoT3AHY4z06CmOVjG7HQE8gABQM/4+39D3nFp6KW9vPTT8LibUIztoo/03+Lb8io 7AgBRgndwCRjuMj6DOfY1n3A2q65YAggqDyAewx9QSf/ANVbwSS0XTVej0/RHNUT5lC+66dv6bOc kUozYyqp8uWBIzleBgDjpTrXYjhXJ5BLEhlXd74OO361FRWhOMFqm0+m12kv61M1FRajF7aelm7f hb7zYAIIwCo6rxuLHoenXHJ/D3pmflbceOVzwDtwSQOmPcHjirUlThGmrvX57/lqbWVnyvd/d529 dC1Zt5bBsELuHykknaQMnGAf8iqXxE8Gx+MPDo+ygJqFmpmts4IJx91jjPOPT+tOhWdHFwqy+Ftb aaNW/V/cOtBVMPKEV009d/68z4mvtPudMuprS6heCaFijq67S2O2PXjp71fsDk7SFbIKgMDnIzg4 Ax+Fe9NLl93bujwqPuzttc6ixeSCQTQuYXRtyyKTk9uVP5dfxrqNOaWS4TLMu6RWK4wG5B3ADoTz 6HmvLrX5KklHVL8rv8Lv5H1GXS5atPl91cy2899f63PRLaFbi6RdjAyABlyuzzQMg8cknaR24J4P b0rSInjh8qFk2qPu8goSvOT+J/HjpXy2Ilf2UNNNmunS3S19fx7H2yny00nHrLy7f8Nfod/piNHA oJA3A45IG7GAK2FJKFdu0bgB0GCfocd/50qMrqySV3f8df67nnYlp1ZKOl38rX/r5mhbAqpVt2B1 6kEfp6+1XsZxs+QbTkcjIB4zz19xmuintdKyXboeXNu7UU7r8LNa/MYkKhiVIVic9ADweBj+XWpZ cvtRjkFQcfxDjPOOK1a1bUbW1ffT/hhyfwOP/Df1cWK2XeiK2Bn5dxORnn/DtUtxahUCrweSSASr dec9jg9qhNXhJaPfz3vb/IFeNpJaW/r+u9zPAW3yWGdp528ZPB6CnWcGXNxE5EbZyhO4g9+p4+lZ SbjzxkrKX5af528zrpSXLOpJWjL5f8Ekmt4JA7OhRkyd2eQw9AKzlky6qpDrgjdwOOxPcnrRKEeV ycdaa0flZf1bvqSptJQavbW/a+nz2aP1PZ+Bt6dcHp7VXjnw3Qge/H0r0Kbip8rVrpngxgmpN7r/ AIcuLL26euRU8bHnA4xxjPHSm0leUdkvxBQUUtNgY9uMYxt6Y/wqBwo5xg46Af8A1qxb95269P18 gWrXLs/v/q5XZ/4eRg8dvWo1ZVHzfhxjFJX1jtb+rGj9x+g1Xxu645z7CmKBuJ+7g5xwKaUZOyVm lbfyGtm0vMvRFcYJ59OAf0+laNuQDlfwxkYqklzQt02/Iytuls/8vwLN0f3Eo/2SM8dcV+d/xhAi 8TsdxXc0wz0I+cdfTr+tfOZzpisHZdXZ/L/h7HtZJH97Vttb7jy23QSNt+7yTjpuOO2O/OMf41Zk VYDsOF2ttxuK/mD355/GuCWvxbPt5dD6bl3/AK0t/Wo+1mMcpVUEgPBU4Xg5GPUHk1JcyW7g48yO RWOY3zt3YxkenY4p1FpCMb3X6N2t6XRmqclXTW1tV6t/8D8CiZVXauQrHGMHHQ/pyTViLZ04HQhQ cdMc4/KuZzlHmuvd287X/wCG+46HHl5rP3V/mjVs0CuEj78HtjJ5P+fWtTyNnzbNvOeAAp9jmq5Y csEla/Xt6/fbbbUh8sWl0tb8EPWKGRcMD/3yo5xyRj69aadPiZG8s4C5UZ5wB7elSlCLau3yvT5f 8OZSaWnLZJ6fr96OYu9ITcQEBHbgqOgH51Sk0hERfl25+UHpjvwO3U8VdJL2fLf4V/wyX339Saqd o200/H/hjOXSdhzgbScY2dh6k/j2rXtdLAThSMEbSF5U/wAq5K8+Vd0tGvWxwVkrpPrf/gG5b2SB QNm3oeQQAScfT3z7VswwLGBkAgAjpnOeBx69eleRiW9lpa9u3kzyqzfuxWkVp9/Y1LVOQEwOc7Tw CR1HJreS48ldrfL90kYIKnHIx+Ncs4Xj/iVk/Pt+bMF7uvLbdCSXQA6dOw6f56VmSyCf5E5cglVU jc2BkgZ6nGawo022oxVmtgjT5WuhjGMMWSQFHUMGVgVKHGehGf0qokAExwVYqflABII+vB9T+Brv pRaUZT69PP8Ar8jaMdraWVv67G7BbjptAOEwAMcY5rTgs/u/INp6bexAHXn+lelSioxvFWta/R+X 4/hc9fCw1in0/wCGPSPDWl2VxaXX2pCxikQrsbDbdpztyPX19aZZ2ETXo8jesKMJBvChjjB5A+h/ SuuNOzotLV2v5Pqd8ajj7boor9PzudX43+IcemaCukiRN/kkBV2hhldozXwxrl291czy93ctzjvk nHP19K+nw8LSjyrltbbofL1Vbncb73Rycq89QrfeIAIIxgdAc5GQPxqs/AOOeM7lIHB4BHHPfoa9 SMml7qsk/wAPM85y1qStts+39bkIBz8qkEg88gMx79D3x+tBVsgMFj+8OrA4zxnA4zzx+tQ4JqMt rffa9/8AMzlBqKSa1u7/AH9Oy6DcYJzlQBn5SQBkEZwOo53fpTcnIzkAj/Zx29fw6Vt7O11GKdt3 ft/wxb0jG62tp5f0/vGBR8xx7dBwDzwOwzng+vpTWyOir/dwBgY7jn/gRqZNXXVaL0ajvb77+RDj GKfW19P6/q43oCuQCDxjovODyOnQU/G0A8YweMAqFxg8duv04Pc8rXSNmm9u1rK/pt0M4aay2X/B VvXsM65H3Sv3VOck89yMAZz064/CmZ2hQAACFVRkHHHHJ5z/APX+g0p25JK1pb+r/wArXTNIJJO+ i3/IXoAeBzx82NwHXp05P50wHjuQueMAcZ746HNaQs+bmVuXVdttQvH4o7/0/u0X9MQgc4Vj6Ece /SnZxt7Kp+bAxz/CB+f+e0qN2/dur7fh+o/hlLmfLbddOv57fMessOGAO0rkjA5AxnqevTjtTS8X KqD8uSQpxzjn04P4VEk1JOLso9em2mnyE3GDi7b3u/68n9w3jkKDxkZyegHGeox0P5Uwuc4B24B7 ZwMHJB445PQd6aveTStf7tv1epK5otNtq+y7d/xIyBzzycFcjJ6dR29/8aa3baqhcgdDz25wMc5P 5e9XaWs52i09fut99ire8raPb/MlUxY6/OF6EAc88g4HTjpQNvIzj1JO0duOOh680JN2aXKm3fT0 /W4ldvl21320t/w33jslMEdiCQCSF4zn/Z6fpUyJlsklck5AGOQMnpwO9EYSUlFWad/kv+H0/wCH JjaKly6bNr+vUubQOMDkFSVGGweuf059qQ/QgYXCkZ6+vTkDtWkFypRa2/V/52/E0uopJ6P8r6r+ uhEuAAD8x65GRx0/XH/6qN20DqDgnOBgDIx24HJxx6UtbwV7Wd10aWtvxsO8bqV3ZNXt0Xy+S+Yz Kg7QP4CAecc8Y9O1MbGCdygDBVVYr3Ukkegz06cde1aaRtf4VeyX9bmbspNcqtr8yqyAH5QvHBHI JBJ9vY9P/r1SuCdrMpOQW75GPb/63rVqPK3re7t95nNRi4cnu3a6+mn3nPuRlmPGFYjBIKfU4Axn nB9KYrMsgZUwo/hAJUr6cdTjj/PESUYzlGWiv/n+aM76ysuXtt+Xbf5GmWfAf5kDcjk5GMdfToT+ X4xNJn1IydzN2z2z6cnoP14OUdVdNbWf3tad+zNNEpcqtpbtbz/Is7gscSkbQMAdRgg8cYzng8mu x0S65EbkbdoznGBnjt9c8emK0XJH3V0V/wDDqy6fu2001+Wu54L8aPAWoNrFrqum2rSW17sVpIU3 rFLgj5gO56CuS0L4S6/dvHK1o6xybdxZQpDEjJ/L3716k8ZTpYeg1rKUdF5r/NnnRwsvrFSUlZJq 39fn8zu9c+FWqaJp0d7FCJIlRjPEoZnjGM7sD8fy964vTmktnP7lCq4ODz0ODjI4wc8fzzXG1UdC NWcWlLTfRaO+h9Jl/I6kXGOkXZr7mdfYrIXS6iJjxyBkYJyfxA6Zz713Re6s4oLyORl3yKGyhKFc gnIGAOD7V83UipYiEJ20TTfom/LZ6X/zPqIq0IyjdpPZ+e/5fgeqWMz/AGONicbl3AEA8Y54x/Ot eGYMm1lOd2fl4G4dD/8AW461FGfwScWr/f3Vl33+R5uIXJNq9mm3/l+haiuhvAVlWSMei524yPlP +ecVpQSbmbd8jbcgMAVyM/lyT0x0/PtTdPlt0Wi7K2hxSgotSS/p3aHzIwh3Rg71X5Rgrg5J4P48 VFbJINstwuSM7QTt254PPuCeAPSnOTSbTs27fLrf5XHbkV/u/D9C3CyrIXUhgCNqhunODz2zzWmz h1Dqchf9nOPXp+I/wqEuS1TlvokkltZP80yW7SjyLdfhr92/XuYtzFvkDo6jB+dcbcrk4U5Ht+tC uqsVQbCMkK2Ovr+X1qE/tSXwqzXzeq6f5JG0dKcIrpe3mn/SKl1cNDGGcB1kYI+1SDg5yeO3P8qp NGsKhYiylyrKWXBUHnoPbkf5zUXK1KM+rcv/AAHb8y6Xva7bR7ef37n6nyNgZGB9On8/eoBjIYDB HfpzXoWS6LTRW89Lngp2SUdE7k6tgDB5HQ8f5NXYH529/wA+tJJWlG2+36fmKW1lp+hJLgHjjsNu Pp/X9KpO+OoxjHT0P8qxs7vpf/hy433WmhVY45HQknp068Y/KoGY9s57L04+n+elKDlokrOO/T+v +HLS1V1sOjfGQ3Hft0OaepBbgfU8Y/z2p2i27aJdh8q5pK9l/X+dyzGDxgbQMnHpWrb5yADgj8K0 pauOmi/Izbtyu1ki3c5ELY6henP+RX51fHN2i8SB1XaQ9woOMYzsOeufy9Bn3+bzp2xWClF7OSX4 W/Q9bI5Wr1Ndl/X6HiEWqAEd16Y5UdxjGfoc/wCTOmpBs5yh6DAJUHjjB964WknJbJdLH0sHdvtb 0E/tYwurAlMElWIPTqDz061oHVBcENJNnChQSE+UZPQDp3+vWpk048t9E77ddU1+BsuWMlK+i0v3 1/4GnyKrX0akBZAFPcZwR0OT2PT86njvQrKN3TooXj+p6Z/Wsk5JSSh72lrrTXf7rv7h8yUWktv1 1t/Xc6Kyv1AywUhgCenXgdc+nWuiW7iIRwNvqOoHA7Z46fp705JW5VHltbXz1un934oUr6Jaafd5 F+FoOAuQMEnIxtbnpjt/+urSR7RwflweduBzj396yV4NNbSM29Y9GtPwuU5YQzDjHbpux0/qen0p r2m/Gf4ScDA6Y7flURk0nGKu3r6BOC5eVqzXbt1Iv7OXOAgz1OOCCen88/jV1LIRqBgA4J9Cuaxm 2uVRja/Xv1/A4ZwUeXTUkWBUQDG3I4A5wOuDxx3/ADqtPIIgAnAxgAdRkDqB+NebVi5RUlpf899z yq1NLkt5ff8A1poVIrtg+FbC7vlIJA545x9auS6g3y5IxwOeR9fT1FYOEowV9dPx2+/RnFGm+ZK1 r/n/AEvuZGb9tuAcY7ZOCvP5ev41VmvG5x8uBngjpx3/AA9qKUOSVou1tF5W3/z9TqVJe9py/p/X 9bkETu0ivuYkk7mkwdx579ycitCF1Z9zLsIODsP8hx9a6IwupR5rcr0fn1+8UUo2s7bdPL/Kx01r h1VccfKQSoJHJx0Gcc10VnACV+QKM8kED2rugoXWt7/pu/y+49TDv4LLf/hz0PR4FhsZimASVOOM 4AboazNNuFWa7X7pWA7T0wQwzjnH/wBb8K9CDSnSTWkXp+aOmrJKnirdl/mfP3i+6luNQuhKzsRL LwTxwcDAx7ZxXmdzavuOBz83BGAB/h1r6TDtWjNq/Ku9v6b2Pmaq9xcst76d+/z3MmW2dAdnXI4A 4Dduf8+9Z0ihAevyhhnnA/Hqe3516MdKcEpXi7Wfl5nHNci+G1lt/mVWIDEZOQoychShAOPp2596 YW34IDE4YcHbtXjvjrwecU3+7ptxjfT8OmnpqY8iVPmWjX3/ANXGAbSCCF+8NrZ7cAj2Ppgf0ppI HAY7emOMAe3pT95OaStfXtru9/66Byu8kpWXT9f68hhY8qDtXB4wAOSe350xjjHJJB4A44/QHnP5 fjVycfZxcdWmvK7d3/XyCU1Gy7W+/V/8AapGcArxyF4GADweOgz2PelEh2ALhVI+YDg8EE98HnH5 VEY2lHVdbedv6++5Pu3TWy/z/T9RNxHB49GJA5B68HI5x7VGAw2g5HAK4wB2/AH/AOv601Hki4pX 1f5bX9d/uG00pWtGMdfn2+4TIzg/xL1B3YXHoD64xil3YxgBQOOik56Y/wDr9/xpxUlJxceXm0a6 bfrb8fMiM+V6Ld2+/wD4boQmQIMk5Cg5P3eMHOOw9cUeYJV+ToMg5yGA69fY+vqMU4OK5tbWv638 /v33sU/tNq1v61RmG1n3N+9kGcEJxwfy6+3ariQtGMtno21c7cDOOcfX9frVKmoxir2jHX1en4W2 8g5VFSguq/G1/wDhiUJtP3iCRtPJ2g+w7dMfkaMjOASB1zxjGe3p+n60ndwUbJJbfp/XzKhFcqbf +Suvv7ibmHGDwcdwBx/D/wDXxSkDjACgnBxhgP4uhI7mmoKLXRJ6t66Wf/AIV7cusf8AhtBflHy5 AJBYZyCfpjnpkU4lAAw+UAYBZSrc9eT07fkOlTz3n7Nx0d32tr+u9gdrcieu9+nn933EifwkDkkb Sp4xnsD1GT19/wAr6qqLubglsdxwe+ce/t39s1FctRc0rWv8l6et2/UqCVvh2/pi7j93HQEZ6AD1 /T9RTA46rn+I98gduCMk89qvW0UrJb+i31/LyLlP4oSXbZad7f15BkdhgDsx4IznvwfTHP8APLGw FxuPXOMjaOhPTr9P/wBVKyjJN/a/y0+W/wB/kLlUVZaJ/wDD/wCYwMAByMdPug/Q45x2/wAnFVmY YzkqR0Ldcc44z6itW21FSdvwXZJebe5nPSKkna35dv8AMgZsE8jjOOM4Pvz05/nwKz7tlCMOe5X7 oI5zjgcd+KuHJytLR31vp6vte36ky5LNbNfLb/hjBLDcxOfmzhcHggZyexyec+3rQrDehDcjhgW2 ndjJ46Hk/rioqRXKtL8ur1sl933fcYxhypzvZrp8zTLFVQEdiOFYkY78e/t/FUL4wrZYAAYAyAMc jrWfNGystHt08nZee7Rq9uWL21XbV6/qXY0/dIozjcM9yOTx+vr6c962bAsjDnAAAwBwM98+nbNN Jr0k/mtFf0WjDm3Wq0/NHfWV4ZoktpgrxqOVdQcdB1xx1J9frW9bWsSkeWoUAAjaCo3f57fhWtGE Y8rtte1+jb7f1sN3d5Re2nyv/lsM8RXS6fod5dSIWWOB/MAUEbNp9e3XrXxs99G95cyRxBIZZHmV QAp+Y8ZXHp6fpXfNf8J8lNWbml9yv8r6/Ox2ZO5QxNTTRxV/K7s2lttf8kb+nb5kj8uPaC4VsHaV fA6YxuHPWvTLOOY2sUbRBgSN2zoOMHgn8zx/h8riFF11JQtq772T+XXY+zbXsYO1npdWta1jurSE NCixv5bBBkbenAPTPqf84rUgjQZ3HYy5IAGFPPoOnOKww8Zcqs7cu39el7eZ5WKUXNPpfT1/4b8y 6kSlt5RCwBAbbjcBnueQOOn61ajEoAKZZVPQDdgfj/Ie9dCailrayVvRaL07nHO/wLRLb8E0SiZ2 OzHz89cDoO4//X1qRpiseH+Ts2FAAbOOPfNbWbfLy7W/r56oaSSjHq9v0uSQwKFZgxBOeeBhe2PQ 57VKVBiKh1UkcgDHPrx646VNNuTVlpfp6K1/wFJ+9G3uvRWXT5/kZX7zcVY5IXrgjp296ZHIruwc CMqO271yM+/H61nVUoupKGq2tps3v/XmappSStbS68urHbw0wQ8qOADgA4/rUNxKnmxwcDb93I2h gOo/yf504KMeb3m+RXt+L+7qOMXeEbb66d272+65+oAcAYyB6d/wqSMhTg++B2r0WrOcV239bP8A I8K1rq1tyTGO4Hce35fhU8ABHuPQ4/z1oS5FJdV/SKbST+4WR8ZyecH8OD3qm8pztHHQ45x6mueS aS/r0sEVqrdP6RWL4z6H6heTioJCwOVOBntnOOvT86cX71n0/rU2as1fS44SAgc7WGcHGOKmQ4x7 D3AAqYtqb6f5f1cH22/yL0cgwB0x6H9a07ckEdAeoPfnPHtWukbW3/y12M5tpS0Lk7Exsp9M96/P /wCO9lHc62ym4jtJBJJ5bylljYkDIYqOOuc49R7V83nUf32DSWt7rX00PRyiaVWpLlsuVXX+R8sO HglaI43RnGVyAT/sk8nseneopJ3OGC4HzeYVyTnk8g9OmPxrik3aN21K19PP9bXPqk3eKT2V7/1+ BSkvCjDPynk/N94k9+vb/OKh/tOVMbGxtJxj7o69B0FY+0a52l8Lva1urs/m9+ysaKzjHnjayXl3 t/XmP/tSRjlm+YZGCoXp1xj0z+lXINRkwfmYKjA8kYTAyF6ex6n+dHM0+Vy3V9NddZP8X8kauKjF pvTX5PV/r+ht22sAAMECk/eKnBPPHGR+v/6+qs9TRlx5yZXaNvOc8ZP8vzrWNKTpPllyt/lZ6/fq zG3LF+9a17f8MbEes7dhEinB24DkdTjp+FdJb6p5sYYcNjA5xgcdvzrPkkt1a19l0s1/w3qQ3FJP +vV/hYniv42ccjA4wOR1xnjp+XrW8sieWjbl5KkEEZ56cD3rlV05KMdG7PTa/Y0lKKSsv6Y+Ijgk jqcYyR6AHIHT/PvccLt9vcDbnOOfbr+dctVOPNHm0X4Xf6mE4Ldb66fhczrjO30GAcDjj3x9ffpW RcIxUDo3GThh2GeMdea5pWjfy6fd/wAH7jzqlFWvaz/S5k7JI23LkL1I7HPv0+tMkPzg8KOOAMjO Cfx/AdqcV+7StdXflrf+vncj2OuiTEDsMA4wF9CAevQfX+ZpzEKM9PqNp9R1/Hr61zqLTvFW3+S/ 4P6mbi1H4dx0TFsKGKgHtkjt37H/ABrbtYDknG4HG5WYjbnpjp/T+lKnJcyb2T/r9DmnZS03Wx1u nxJsxgBgAOc9uTk45NdFaMF6Y642jA7jkAfjXbRdo9mrW118/Q9HDyaUUun+R6h4a0jUdWtns7e1 ZfPGYJ5Cqodw2nj7x7dB3rdvvg14u0mwutTa0a4g8tS8kKsiLGeuDIB2BHPJ7DOBXr04S/d1IRbU V73kl1M62No4d1Kc5JOporvv/TPirxVdwW2pXazgrMJ3EispTaS3cHGOprz681a2TcFZVBBHBAIJ /lx/KvoqMdFbRO1jxak0o2j0b0633f8AwDnZtdiB4dADkk7l47ds4xiqJv4bjOxlxlsAEMv5f0/r Xpxi4xj7iSX3d0vLW+vkcU5WW+ulu+mo3ceqnOMAbgRzgD69e1MLHII2jpkDkhhyO/PXpirfLycj ha23l1Xrb+kLVxi7aJO3p2t8vvYwnGD8xORzu+7jjH6ds/hUbMQCSD8o5X9eh74/z6TCzTvo09v+ D93zMnZNd1uum3+f3jQecDKkDI+6Rz2UenI6+p5pRgYO3DN/CcgDA9ye+cVbXJHXVJ306N6p2++5 MuqSva7uM6dSQuORnJGOwJ/OkwQoAYEjJyeGOQepP1H5Cqb0jbbR/e9f8ytIxg1FXetrff8AdsNC jPygkjnLOSB3/LPf3pxUZC9mYdVLDOT+I5/XFCfI+VKye/nbW43eMVqk76r8/wAbW+Yh4OcgAKAR zgEcfTqajO3PzDPXIzkAjnBH0yfwNQ4rmdSN+bfy11a+7sTG7UraW/4IiqBkBTwMA7enUnP0yf8A Ip4CjjBGW6DcAev5dQD/AL1Jr4dVFuy/zXzWifSwotST59LdO2vX0EXKrjIztAxyRkcHPbv6VEuM 4BK7ScEDkkgc57fl2q+SMW30SVlfp3/rc05bJRjpf7u/yGgjczMMYAIGTycgdun/AOqkzkkcbhnj J+9yM+5x2H9DT5X105Vt6639bakNtWcXbR37L/PT5CrkMAc4yDgg8dMZ7+n5UpA4wMAfwZ5Bx6/j 3onzKztZaN9dly/16FN7Rvbm/DT9RSUGAQxI79Bzn0+p/wA9VXhkHHBz3GF57nGOtaaOLXLonv1t qQoOUWkt+pOhI7jPUfKQ2Mgdzkdep96l37VXqRksMn5sexPc5xmsVeXvSSs9Nd7/AOTLTkmrS5Wt PyY0S4GV67v9oEcjOewzkUnnKvUAbWwM/NweexH8/qKtNtOKhaUWv6/7eEnyxtKN7NfPXX5DN4yc bc43Y6bSAeOnHSml15GdvoMkEjkdT9Dz/WrTmuVyVl+rT08tioy0tta9l+n3DN4BP97GeoGAc/l0 PT1qu0mAN2Fzn5AQp7gccHuTTvffpbTt1/Ru5Dd3tb18tvyIZHwOCeo+bpk5GOnXnjAFZl4/7ttu Plz8uSCBxjrx0P5GrTVnGTsr7W620083ozGpFck4bf8ADf5/iYe8/eUDcSzZYgYOexwB0P6/iVzy OdueeDywznGAOOffnihfburJ3XzXT9PkQl+7lTbumtH59vxNtRhEyWwpUbs5ZT+OTjjnNB+6ykgf KSFUkZb6nvwOp/nWEFNxi7Wa11810X9aHTGNuVbabb7eZrQQgRJwp+UZ+9kZ5y3ofp6/jWlbqUKr jIJG0Y6AbuRn/P4Vcb8sVHpvr2Wvyu9AafK29LadvuZ0lnwAc4Ab/gQH1/E//WxXa2BDIhBz64OA vocD8a6EvdjLlu76+W9vz/QiL30f+e9/uVi/qtvDPpd3FIu5HglUq3XBUj+n6c18T3cEdnqF5CEb EbOoDKU4zwSDzn16/lxXfU/5FsrKzjNb9FZ6peTt91j0MoaWKqp66L/0pf8ABWp0PhyVGXewZSrt lWUheTySAfl6cfh+PqOmzqqlH+YFvkK8oMAc8D1r42vCcatSzuotOy7X1/NH16jKVPV2SS/VP8zr rQDg5985KqSfbOAf8CK2Y9kibOQFAXAUkY7fqRRQThSS09X2tv5b29PU8nErlnu24/5F1FGzB+Ug DGSdvQcjHOeuavxI6W5cYzgk4wCvOOnX15+ldcKKinzv3vwslpp95xzur20b/Df8jKtrp5Llh5bL tLBsgqQ3BAw3XrWm/m/KdnyZBzwRtPBDZ9s805LlqOPRJJev/Bd/R6Dkmo0+WVlZeqtZjxIX+WMs qhQdp4K454PT359aa7uG4XaVwAc7R+Pc5zSUFGSjGNlFJaaO9u3y/ETts3Zu9359f1/ArMSk2AOG GcjGD83Trx1/xqxJFEV3FQHCkjjHXjp+v4isotKXKtLr5f0n+popNRivtO//AAV89yCCJNquDg7S cFgPXPGf/wBeBWRJNvvgrLkx87hxlfXn8alwnF1mnsmvXW1396+RvTcpT5W7KKvf5f8ADfkfp3vw Qc4HPTGT/nrVmOVT259B6f5xXr8qVkna1/6Z4LVm5JWtuiff0I6dl4A5qVJdpxnA64GOPTpWWsbW VtNe1xpbbK39fkRzOQfl4A5xwBVLzv8ADggdT0rDr/S9S1HVP+v6QeZ04x6dOtNeUAHnjPbtT5Um 1tzO39eVyn7rttYadvDK2OnTA7VNEw4zj6Zx/nrUp8qacbW0X9ef5Ml20a+yaEIA4+7+R9K0YQQw GeMnA6YrWnGz20/LyM53V/60NCUARnj+EgZ4APt6V8C/tAoU1Pdt6ynggEHK57jjtzmvns7gvaYN pfb/AMj08mX76StZNM+W7ia4cqkjblXplQcY47YPGMfjVMhf4SFZBypzgEZ4A65xXPJRapuOj38l tdeqPp4aOy1stn5a/h/wxjXcbrg4ztXC/KVT5uo6H0PH61RXp1A+bJy6gnpnAP0JH8qwcYyhUbjd K2u3e6/I6npGLT1Vvu1/4A1SwDLgYJOwkgYJ4Pb0Jwc8cZ9rHAhZ0Z9qbT25bGe3t7fSkuSmpPls rad7t/56fgWrWlpu/wA/+CWbW4DZHEcikgYONwyTnnjnPf16cVpJdyQxswY5C9Bj5sAcZHv9P0rR fBGVFc17Prpd6rytu/U552gnBO77+r2RXGqtFMmGZTu2lT/CBkn8cmu7sNdVLbLNzxtKkA4HTGfX PpUwh8Wrstb/AHE1U/dcVZaW+Wn4liHWyJAcnCnjJB+U8HJAxyK7KDXAYlIJxwGVtpK575A5/Cua MJK8Y6X/AMtyrtOMXt+v9XXzNm01YYGWAB42k8Y4yP8AIrdW8SRVK4AOD975effPpXJKK/ex2039 Q/w3Uv6/Um3KQPTHQ53Zz/nvTJbdSMKNvOVz0Pc/h16e9efaKi2na/8AlY55Q5ve76fMhWyx8u0Y znORtBPf6cCoH05WG3ZgZGMg4DYzilKXLTitu3z1T/ESpxhFWVklt8v+CQNpy7QDz2DdBjIPUfWq M9ltAGGbGAM57dDj8Cc1HPLWMntvp5L+vRM5asNH0t+pBEpjx8uQrfPjA4IA+gGDW/ZzRru25U4y Rg8HORxjnpWUVF1OXVLpr939eR504NSUYqyX9WNu0nVW4Y8kDOT0z7+wrUhusP1GB93GBjGDXZh1 GMbLX+rM66F435VbbTpp/wAH8z0fR/if4m8M2SwaLPZW23hLl7CzubqPnI2yTq+B152/jVux8f8A jfxk2oWOq+LNcumeESQRHUZ4YFySrBYYisYHzDgKK+rwmOqU/wBzSppKpFpystfJX2VuyMcTluHf tcRVg5OO19l6I+QvG3hCe1v7pn3MzO29pCSzNnOeev1rx+60aRG24YEdQT2JzkKff0r0sNW2g9lv 0W9l93T7jzZ042XLpt6GQdLmDdCvJxgY47DIHt+Zq5bWLQ5w5HJ9Ohzjt79/6V6MeVJp9dN9t9fz +88+peE3OK06d1/TuXtrIcZAKjGcrweBnH4HmgDH13deo4yOc/QfnV2jZNPR6eaf6aEJTSVna+lv zRGBgE854A6L29iM9MZpGyAOgAHA6gg+4GPxyTSspNXjy+j7Nf8AA0KSSjZbqz80MPygYwoPG0HG 0/z7YBz+pppxuOQv+0owMg/7Puc/lQpLllzbeXRu+n42FdrR9b/LzsM5XsOuAeABgDgcehHQ9RTs duOSAMgHaVx2HHQ9/wDGnF6R6PtpbfT9SYpKT0t0/r5jem7HcsMfdAXuOnHT/PWon1CK3fEqcD7r /MRgjvxx1PPNVy6+ejt2WisTLS0o97fK2g4ajFJtKqMnkA5xt459Mcj1oBWQfLlQOQo5O7jqB9en bn3qeaVNR6R/FW8u2ho46RXw2tp6+X3i5GAFPfPUg4xwcjtmmmTATGAPqAcckfXPr6U72dOPLa/5 pP8Ar5C+0r/C/lqNJAAI+UrjHPY4HX6n9ajJ3E4wAOPvDkAdc9+AB+FSlaPtbWUdGvXT9fuM1eLb jHd3/wCB563/ADEwMjoCg298Dp82CcjmnY5UjO4A42scDGSeg74Iycda2qOV4+f320vb0213GkuW Mt99NrL+kJg4PBA4A6A+p4J9wOv/ANdxIGVXrjJGMHdgcHjg45x7e+acrRtFr3XZfjt5GmujSslp p0uxoxz8u08hegCnrknHHfk+tSKo2kAbuUyBgY4zkZ44z/npUScoylBQslrp5pN/mTG8Fa3Ly9V6 /wBL5DgzcDPzA4B6HODjoOlNJHKgcr/EOp/X2/TvQnytJtK35W/4INSva9tfm/8AL/hhWC4256A4 xncOBxx3/H+dMORkBSD6jgcdhnufp7cVcpe6rt3a1/T7mJppRWrtv/X9bAxCKCBgbTtHTj8evr+d NHb+FRwAeMjH5D8j1qp8iaUVs03bbrf89inpe2l9r7evzGfLwBxwCduWXqT1x7fjmmcKeMDGFbkq fTGe3GfzqdneEXd6WXZPXT5fp1M+RpOcnZJbdF/wb2+RA+0KS3G7IwpwwJ/w+lY182FHO0KNoxuH Ge4/ix3HtWy5ozT5O+z+9/eZVtY8lv00v/kZEZADbtpDEkH0Pr1xj2/HFTAAhduSRwACuFJPuOf8 85qLRd042VS7etr3b+7/AIcFGMFFcl7rT7jaiIMSMSeF6qfkGDkDrwPm6dOT60v+zgZBYqoGSMev cnjPTvWMLcrlH7vPVK3426febyjKbh711b0s0rL8jeiCrEnRjtAJ+b5SOoweenY1fgYfLkfdPUEj t/njvXTGN1JSSUtlbbqk/V9V5Det4uVknb597G/bADbyF68Egg9cYXv9eOv5dfprYKjgbsc56f0P OO9dFGMuRyirf8DT/IySnBp30W9ul/8Ag/qTeJzN/Yt0tpKsFx5Mnkv03PtPBx6mvjlkvTdyy3jE TiR43UDHzHJBI4P9DXRWqWyyS5bqUtX5KLdvvPTyZSnipyUrJJP5Jq6/U63RLNAVniyEkykikgAH OOmfbpXeWoSOWID+FkVyCQCCF65AHGSCOenHBBr4yupqpWnTTVlbybta3otNup9lonGnFWir3/P/ AIB3kSxBQAMfKCCCMBh+vofz/HSjACLuAONuSOepz+Hb245rXD8yUJWvff0b3/L+tvFrS9+b5NU+ v6F6ZBsDRhgOCVG4dR+f+fSrlv5m0gdEx78EZxx/ng+9dHuWTS5enbb8F0OKXK4Ss9nbTz/4JAyh J3LIq4XO8HHPccf1rQglWTaoPTqGXBI45oa95uStaz9PNd7PV/MhOPKuVNJK3kr/ANX9CJ0Fu7Nj ptbpx7++Ooz6VBb3PnGYNE0aq3HygbsDqOemOB0rXRQnU57y6er/AMiqdpO8nZvbt/W5DJciMcIM JkHHZTyD7+v+eI3nRsOGIU42hSOB6YH+eaxjFU3yrV9P1/PT5mig7RUXs/TfW424DbQkO9GAyNxH bpjBqpEiLE0mRvH3w2RjB9fxqWo+zioJK719PP8ArY2p/A7Ky/y7/gfpZhwdq4x0GABk56/zq3CC M9V9uh7f416ityu+jep4skk9CXlT1OOAO+P88VNGeMEnIIHPHGRWV7JQSte4mlFNLp/TI5QwyMkc dBxiqgHzDPyjjHbPrWKTumltovla/wCA09raWHyAbfQZ9uKrId5IJH16c9P8ioin9p2t+Zai1721 tH8/InCMPTAHt1qaIqOD68dBzVp63atb899gurpL/It+Ywxt4Xpx2q/auSRx7ntVUmmrJWa/pk2s k+xtSnELe4yFxjbxmvhv9oCNvtg4zHvDE45HGO3TrXg55CzwkbXfN39P+GPQyeyxMk1fTb+u58mz w4LDBAyCBgABe2QetVpYuORkrz8q5wOcnr+B+tck7+7dqNnt531263/TsfSQbik1108106/cZl1b 4BwfQrkY4GDyOMd+c/8A18totpXI2hSdqlug55/Un8fxrFw99xU7tf8AA39GdELN725e3l3/AAKs iEc7CIsqysOTnvwfc+p6fnagUiJgVbYdx6ZyCMf596iDmnNtKWi9LeX9a7lKTimoq6Vvxev47fML WOMyt8pU8tggccY4/Pr05qaVPLRvnOFUna2FwMZwMcfh+ddKU6astknttorr/hvIylNQXu7LXyVt /lqZjiNnDKMNuUHIA+fIwOnXJHNXnndLY+UdpAbdl9p3gE/pwfypKk+WXK242fon/wAP+hLa5Fd2 tZfP+n/VjMsdalhmUMy5BVcnBLHnrngg+vsfXFd9baxGvlySF0R2XzRx074Hr1I59KSivZ89rK6S 6aO13+K/I0la6klb3vysblvq6LgQy+YuQWZQy4Ab7pBwMgDP0au00/Uw0a/PjbnrkH1HH4GvOrYa UVJqOu3lvp+VxvRKys/Xz1/4BvR6mo2qWGTyCc9sdAT/AJz+epFfK21QwAAB/wB0HI6dOx/EV51S yU4dnZaWsNW3ta3T/hjVt5VYYBAOSeRg9u3btRLMFJUttwRwMD6Hnnsf84rGouSEZNbp6fd/XzJn vdRvbp5WKcs+MhcEnjsNvvVC5ceXuUn5VBJUN/n/APXUWf7zlW3+f+Rw1UrJLv8AnZGH9oSOVOig vyM47YOc9OOKmF/Ep3INoH3ssCe3cde5xjvUrWK922unT8fl+JxVIP31bRbaeZo2t+jsRuChckfM R+gzjsa0o71d4BkwRwDyfXtivQw8V7koefTt3/r8zoo03C3TW3+RrR3jNEUjGd3RVA5B/H3461se ALq5/wCEss44YJpBKZYZ1jhkkVFI3ZbA+XkfeOOvvXpYe6r4aMo25bXX4G1R/uq8Zbcr++233nWf GDR4bdGnEIj3pvZiuMFlycZ/CvjTUHUTPg7gDkDCYyeOPbv2r3cMknJX/wAl1/Q+eqLR68vl2vfX 7jGkxt9NwyOCnPQY9OtUXUjoCBngZIG48Zz3PTn2r1KVN3Sir/l0/A8+pGUel72uvJ9iIg5Od477 cAcHk59+aYOnGVPUZXp2ySMDGB+grRKKTXz079bdupz2913krp6adWr6B65O0cHGQEUg+vYcH/Jp jAjoOMZxzkjt/wDrNOK5OW3u3XzXZev6FpSS97R+n3f8EQjgBQO+5QFGM49+P/r+wxHu54AUHsMA 9+2cj/P4KSacrSSfRPq1s7f1qg0i3KTsu3na4hB+VlAJ4JwCBgn17Z9eetNx3x0GQTyAV4GP8atQ 5Xzp311XR3vt27+okkndu6t6a+nz+9C7sdsbCTt6EAjHbpz/ADNMKR5G5OCcAsPunvz379u3pVRf LKMpK2tvXXz/AK2Be7PWNl3/AAt9/wCg3ykTgICTkqdoGAepJHtgU84wQBt/u8sCo9cevb/OaEnz Lomvz/z7dLX6BZWkk2mvv8iPMm3p0HTOMHjp1449eMU3KkcZ4JwTnBODyMUTlyxjFaX0/wA/1182 S1CO92vyY1yMYwQcgKuST70KApGByDg9CO+Onfv1/nVNRgoJQTTVl5evn1G7QvpeyX5AQvIGFOBh Rg4P4en09aZjq4B+UklRwSBnjGM4yPfNFrwp21astdN3v8vxKTfKo8t7L/g/8AcThF24UsSMHJw2 M49vT8RTgcHOVBznnDYwCCTx17YppN3jy3cfLZLr/X5ijpa0rbvXyugUAdVGCpx33HBHPYe/0pwb vj5s7QOCAc5zx/n881N+V8yVm9Wuy1S8tba+RXLo3e2m3dv/AINxQQuPvDJYjjGOOOPz7Uh4DKvT cCp+XK57c89+B+HsBQSjGUI316ryv92w4Q9yUVq+/XbcTaMbefoCDk44wMDrzz0qNjtOMHbluVwC PXqeuMcemfemviUr8v6aK/yte3qSoPlfL9/5/wBfITaU5OehUN0PQjt0znpTsquSnJyQMMV2+vX6 n8+O9UqVPltzaxt92uunrfsLRKKWm6t5LT5asaQBnPdcAkZ59Ofc1CWwVJBXnk9j9R/nGDWtKnaT cnZW7bW317/5kVFyyfL1tdfnp+L8iu2SM4O0Y+U9+nBPbgf0rGvzhOcNkqUUBBwMAnGMj8j2NXGW vLFWavddl1fnoYy5tWlZta21t2flbsZnZhjnJwN3Yjgg598/jTjjG3enGAwPXjjPoM9c49u/MKGq teV77addPvf33Jg37vKtr3Xotd/y+42rYlolHIKqwUN0JzwP05yOAKlAI2qVBUHA6ck9MYz6EjrX PHnSS5UrfLb/ACeqOqP8NJO6+7RN29Lde5tLlFToMDABGWxn09Per9uMsvbPcZwMZx9On611U7NQ ktbLbrr+ruElDmeuuq+f9fhc6G2PyqOVB9yrLkevJ/HHeut0+IhVxnZkDbnJBPOPYYrWN4x5Vor/ ANX8kZXltay6fje5x/xS1S80nTLeWBd1vIxiuCG2GLPQjn6D8a+c47v7U7PJOZGyCS24AgEDBABy RjjHp+FbYufJgqNLl0nd387tWX3pnqZFBRr16nMtfd+WmnluzubW32WqNExAKoT0AJHIPGBk4547 dK6fSmEyoVxuQjcrAlscj1zkcdfU8cV8fVqLlvJuKTs9P5nZP8LH1spys3G6cbvXbTyPQIELRhAS OPlUZwMjHBPTv6fzrVt90QU4IIARgTwME888dga2px9xRbtZP1td/wDtx41Ry5pdU/w/r/gmiZ/3 LYwCoLYOADyDgf4/rUlpdfLucFWGACTgc88euMj8q7E4QjHW6Tt+m34+pyuCin2VtPy/X7hNrvI7 dgCcHnAOOe3+f0RnZWj2FRtwAFwMKODznoa1kuaUoy2Sf+X4/gVdQUNLpfld3/yJy5kDBCwbbjnj Jzj8v5iqBZ4onbI+63yrwoPXPXisYwbVN/De3yX/AA343Go6JQVk7af18ipZOXR2l/1aswGADleu KkSFSzMDiMENtHy8/wCf61nUmrymlbWyXm/L7joi3C7jG+munZL9W/uLO9Xwq4IAxwMqAOOp+gqN 1gKEHjswzgkcc49R+HWlreFJySta621f/AsRFNRkt7/h1P0l3D16DHPUfWpEc5GPTGMev8+teilp rppt5Hia2VtCx5g4yOcjqACB6fpVhCNpx1/IfnUJLqrMattfayf9fcNk45wOMDPI/H9KqFwvQAY9 +Kxav8L0j/X+ZdrKLelv8mMMmRgY9emBgdaixtJ2/Lz9MVKVrK1mvxHH1t/X/AZMsu0bTx29Of8A GmE/NxwP8OKEteaO/wCH9bjtvy6WLkEh4B7ZzgdBW5aEKQBjHbnA55rZaX5ev4kvb3dNDVdhsIHT aRg5x+nSvi/48xf6SPlYDchBAznIwT09z/nr8/ni5VhXHV8+3nud2UtLEuySuvzaPk+4Uo3K/Jxh TuB55PP5cVUIXDKQo7cZC444/lXHOV4Ri5aprp01/wCGufSLa7drW/IzLiFWwFDc7lznG4nsAfx9 6zp7fYRjIIGNp+Vge/H+etccueL5kuVK+vl0XyS1fyNU4x0S36eRSaIlcZ2k4C7jgD+X179D61ZW EiDcAgwevIJ5GB/Lj2NdKTlSjafdadt195rzOyj06/LXb+tSoqKrBgRuJP7teMYBJHIBz05P9abf QyMvyq29QCGzjHJ6fkOMA1rHSlD2rslbbr8N/wA9vUwfLzOLb/r9GVdqiNSwA5B+6QwwAckdOxOa pXrMYWAk3DsoJzyRxz+P+etU7qEorWKb0XVO+3dKyI6xjHZPW/n/AFocqQfM+clCrDsdwwcdB6c/ XNbLal5FuI5AZGyQmCyY4HrwOc/55pzjBQjSt0vfpfv+f3HTKCXLFNaXen59+33Fmw1yVCvzFBkZ YnoMZJwBgDn1/HtXpek60htwxkwVx8qt054yBjOOayhBrmXM7q3nr1+/p+Jg3ZxfRN+vW+hqR65t kB3ldvT2weP8eK6G115WGEkGTknBPXoTj+ECvJqwn710tb+SvbQ6HJNRsuVL8/8AhzoLXxEEyhbo cFiR8pOBk5/p1xQ+uqcv5nTrwR0PufwrCtSScYv3U/L+un36E7K/Z/8AD2/Epvq4I3Bxj7pyx3Y9 QM4PXt7/AIRXOshIgDJgEH+I/MB71E6U03BQS8/663ucs0+aHm/lstPv6nOvq654ZQSTkbsEnP8A hn8qItVP7z5txI+XDBfmGenBJ4z09KcYR5lyxdo30t+Py2JVPdtctu/6/iaFpqqAFfNKsqkqMEZP PHy9M7QAc9/xrasr5Z5kTzdoJAV23MM+4HXjJrrow5eTljy/8H/PU1jFQSVtv6/U9y8O6Jp1nFa6 jrOpWdjbh0kVr24ggExXJykeS8o4AwFP0r3jwf8AGT4Q+Erm10u20PUfEeq3bpCn2GOzstLZ2+UG SeRvNI4/55lsY4r3svwtGrUi8VNU4Jq8n9p6e6vU8XHrFVY1Y4XST+5EHxxgj8SaLJqFnpkWixNA His7eSSfYpGRl5OXJ45wBzxX5rXdlLBdSq7PgykAE9SCeuf8+tdNKUI16kIJqDva/RefyuedGnU+ r2nJOcV97W/3lZ0OBnAOTuySpGMdgePw6/iAaLlcscj723Kg9xgZ9QOfzH4d9Fp8vS3Raf10OWsm rPy/r8iLIB+XqN3GMZHHPPXj6Hio88kBcY5C49PT/wCv6e9da5V7NK0W9V6enzdvQz93VSVr7eX/ AAP+AN9AAFI5VQeSBgfz/Dn825YdSyhiQpH59Ovp6f4ZN2ko25ddP0M202oKNrv8Bp2nHzHcC2Ae DjHXJ5PU0E54Pyg4OBn5m9D3HSrXwp9V+V9vVsppaXWttPxsrff+Qw5yBjcFxnPO3H4Yzlc/lTS2 AeUU54PQg5HTHvx+VCm1NLz0+a3/ADXqGmutr/etP81+AhIUsQevZRk5+vA6Y5FBYDagABIBzkKC D2P+TitpNe690/vv1/BkQ0vF6bfg/wDgjS2R8oUHCjO7nA5B9x7d+KYTgAYA9QC3QZ7fpWatF3Tu la3yu/66Xd9i+WSdktldf1/XcRiB09BuIyqhj2//AFUHt2GCxXBxnDDr9RkD2oVRrS3denlf8b+m ok1FtRi3Zfnv+Oo0scYzjcQCfbpjj0OTxjjnpSHIwMgcYwflOSeNvX1/zmlCd78r1tf8Xp+gO+ji rXX4b7D1eMkg/ewcA4XAHQ/596b0IweM9j8pzgZHX6/hWjf7rbRtfLr/AMH/AIcIppR5VZq3zEzt KklVOSASAOgHB7AdcmlGQMrwQSp/h/8Ar+tOFve99K+/3a6+bLirxcUt0v0f6/exwBIGOAMEfKw+ b055xjPYf4CqM7VPzbhgnC4zkAY6Zz/IUVNU0tLNab6N3X6sHJS+zta/32v6vt3DGOTsGACRkFRk ZHbn0/Gl4HBK9AACAPlHUjHvRG/vW0i7LTs3ZjbS5oxfKv02/T8hSCvADAZ6HGDg4yPbn/8AVUTd eV6EjPB24659M4/yeKFP4otPRO/a2mn4Cm4qTsrJL+rW72/MAQeD8px0z8wByAenbGKjBCAhTk7i uQenOT1P4d/54a5eX3Y8vTt2tf77drkylC0eW0WlbRf1uDtgFVA9yQQeeScDp0OePSoWKhQMgLkD /eXGAB06YB/IVUW4S1b5bL8dPvvb8ydFa27376sgc4AHQNgemeQM8fp9RWFqBAdV3Y+bGOm0eh55 4HSujlXLzRvC90/u373/AOCYym07Rdk2tNtuhnqgTJ5wo6kYYAgg8AcEcdB6VKSAu043KuAMcEHq cZ9zjr/jinyrnpu+q6Waslf7unp3I95WlFfE/TW17/jb5GxZsBDgsWOcgEKcE8fiMj36/QVNH97b njcoBxtOASM+vr065HXpWcLPSTtLXp59fy/E6YwVlfSL+9dP0/E1mckKy7sABQDxwAO/GO/5VdtC xGTx/sYIHb0wPy/rXRCm4why2Tv71r/d5vS+gprlajy2td282+39bHUWi7l6jJOS3CjqD0GM9DXW 2J2MoyTjJDDPGa3hq23Gy1Vu3X/LyM/dScuq7ev+RzHj+fTL3Rbi1um8wFWC43IySdAcgHGOua+Z tLtxZXCIOYhI+DsJ2qCQvTr27flVZneGXUF1u7Lsrf8ADHsZHF81aaXwaffa/wDXl5Ho0bpLapyI /mZVIBGFGOBjJHLfia19MEkE6MAHiyFbYGDqCvOTnrk+/bFfIVo8kGmtL3t+Ono3b/hj6m9ozU3v v038+/fzPS0aKKMNkKzAfIc78d+nXufx4qzDLkqysVC9RjIweOPXFdFKypc1vs/c/L56nh1W4cyT 6fPtb/gl1mDRrhvl3bhgAcdPyz+dX/JWaHyzlRs4ZMKVwMZ/T+VdDspQ0stfTv8A5rQ56i5Uknfm +7+lsh1tC0MLIzKwwUyQc4/GhYv9HcxjIUOQeQRg9PY5/nSp3Sak7K7127sakpJxtZJK3lprb5lK 2efYQMjjnf13e/A9SKxrmWSCQowcq8vzKACBk5zkHJ5ycgf0q1NarRWerXbX/M3hGPNvZP8AWxci hZFKRsuDl8fMdpIB5HBHfj60J5sCEn5hkksOMDB/A9f0rljOMv3ko2Tafo329bfkVJ+6ktG9/wAO n9aMp28xjaSWQnZlmUZIJ9vxz29KmSdGLyEkxnlWwMLg4IPt9Kp39pOTVrtJaXtbf5tFckoJN7W/ TT80fpgOg5HBP5VPE2COf6EDivTSd0krPrf8DwW9I267ffdEjnacj146dPwqWN8AbSR3wDzn6Goi rQaejQ0o2v636E0jYGT7nJH4f1qjIRjggdDxgdPasLcr5YuyXT1/4NzSLST8/wCmQh9uR0Oe3+eK TzTyOmPcDijrbbYIrb+UcrhgFyAeo/CnA42jkjnGeBQk4LTbvfYb0vpa39JluHqCTx+C/wCe1bVs 3Kg9AcjnGPy/z0raG+9rf0jOTs7RVtP6/rua7EbOP7nA5GCeK+WfjTa/aPlKdNm0jg9T+fWvEzhN rDqyT59/M68ufLVb2aWn9fefJuoadLGx2glV3e5UfT8+B/WsBrfHQfKMbgcDA57dvX8++K890n8N 9rW6Wv1/X5n0NGcWlpbRf5L9CpdQCLLBlfBYgAMCp4/+v9KoXYDqGCIjgAOykgtwAMjPIB74HUnn gVytezjKClezv6dGrdtHodKi1Fe9a1/+B9+pQNudwwn8JfIByR64+nv3FTNFtQfLhc/QEZ7H/OCa unKVJP3draWst7fga3StytK6t2/qxRMH7zKDaVOeMqD149uP5fSlUMDsVenJwRk8fl26V0U5JRXP 0at220v5f5+hi3GHxS1Xl8yvJbGZ9u0x8kYbrnknsO+f0/DPvtMaBG3NwBnIGSG9MDqeB+lONlSa WkU2l+q087/eCbhKMXHz/X9TlnjZ2SJQoZSoLqpVtvGATnsB/wDXzmrN3Y/uUVQu5cnBYAkAH36E k/lnNZycY0k5ac0r2v8ALftq7lSny8mvVv5X/wA3+JzhBjYYBX5iCAcNtGQfcdAQepz7c6I1SaBV 8tyo4wMlSOAMgEjAx6jn8a1pwfJzJWb0fq1v9xpy+7TbjaSbuvzs/ky7Drkke3fKfUbjnA65Gfp0 /StiDxAY9kgICk5X7wGOMjnAyO44/pXPPDtS5pKyvbtvtpt3ZEpyi1Llsm7f5t/ibn/CUQeQuJZl uF+XYsYaJzuJDZ3ZU7eOh5GeOtRnxQAgO7A+7wdoGc5B9Mgn8/Ss505QlKKSd0kvLZP/AIffUl1L VHGVkttPJ/qkMTxL5hPlMW4zw3Y8AjHqSOnNXF12S4gZlZSYzhlYgZyQT+PX/Oac6cVzR7a3t03t /wAP2t1FK3u3em6Xbf8AMxjrI3mMsA4PIyAvbr6f/X9Ku2+qttZtylcE/eHA55AxluOf19TWdOnB ScUrU3fXrq/8jZO6UuW1tf6v9/oatpdo4ZxKqSLkqHLZ3HIGF5IOSR759K1YdW/eDy5GXPBUEgjA 4OPb+op04O6imlyrS/k97/h8zNt3SXz8tf8AgL5nRWeoowEjM8jBcsAcsQMYwW574x6itzwy13Nr 2m3MFtdPHFe2zySxRPIsSbx8xK8KB3P1+ldMZtVaUq09OZLXa90/lpcxaT9pHaydul/6Z+i3iSNL rwaob5mW0IzyP0/Kvzg8UWoj1G55UDzW9eBux0H+ea9CFoV5a2uvkfNpO0l12X33/wCHOMkXHC/K MkKOuew4HPes+RRnPfoODntjIHA5PWvTjFc1m7f1f/Iwn1ila33dX+ehUcKDhcBtue3C8f5+tRfM ORknOdoHA5wcDuOhx/kbRioqKn0va/bp+ZxqMuZxdk3f7txpOPlBP3eQoPPc8djgHvTGOMMoxwo5 x0J/pxShOFttN7fdbX8/n0GnFSfLu0/0/pgzn5hhSfmOAMD9PXGKbnaCoY8nnGOMEdQe3P6mtfcs tUnt+TS9d9Qne66W0/Nr8w5j7HqAM8AZJx168g8d6acAnlUI5YEEAYbPrkdP1FK60dN6vSz6Pp+G 3b5AlspSs2tvT/hvuYzdhiV28YPJ4HBA4z36Y/wppPIyec4Pbb0weP8APt6kJcsHyK6T0v6Lf0uD vGCaf9K2/wB/9WGMduQM5IBHJAA5xj0zmlwMdOCM7eOd2B3+lTy+5d2u1F2+d7eWlrfMHJ6u1tNP TqMztJyCCBgKABjIHQ8gDIz+NLjAXpzubG4gjr07dj+XStLxgkm9GrPpq9PlfT5kNqK9126fl+Y3 K8ckA4zh8YPHGO3BB+lGFA+QKMDgbgMAduefalGCtFxiknq+j1t/X4lpLddlbyuvyADJOSSQc5yv YYGCAM/y4p2zp/CQDhWwSMk546j6H2qpQ5VUk3r2/BC5LqST5Wvw2v8AewCjCgjaNw4BIJIAIwQe nGaXGTgnrg4zkZPHQf4/hWceWEHGWivZW9PvXUdukHbW33LYM7QD06HBPT02jOM04ZxhSVJyoJz2 PIwQCO/NOneNpSTS0/BLr25vzCUuX3EtOnzd2OJHy/3umen14/Ae1NOQOSQBkNk4IHXj2/lmtYX9 6LdklZfOz/UajZTSdtH/AMH8vzGYOFHK/eAC/dwO5/PpnvR0ZVwfc9NpABOOx9aa0Xrfbo9Vb562 B2heMlrG349P67jTtHGcDPOCQQSfbnHH09KaWPIxk9AMMCOSDgcH09+OlNRbUY82rvvpour7a2E9 EowXK/1t/l+o1uemcMOhbj8P++vTt3qCT5V5yOF+6MH0HTn8qcEoWcVfRejs9/66pEXtyuL2Sb+9 /wCRBIWUAgKv58EZwfzFc/dN823G1toIJUsVXPUAc9AeMjOPy1hCNrXab7/g/Xoc85e6nfSLX5lR WH3vl4xgMykbc7icnn8T7+1TA8DBPG58ZJxnvx178fWlKyUor3VddNU9XdequU3fnjF8qVvXz9Nj Utysca4Jwcgs3U8DnJ69+asQbjKFXKglsZ9snH6Dn3rmkuVSalazWm2ytb10276m8b8qUmtH+f8A VzRbAfaNu3gfexggHPPTkjHStO0xuGflC8Y4HUdhge+a618Ks9Wvmr2/Fbd9RSS2XxLS/Ta+v3nU 2OAQPujjPGOD17V19mqkq2fl5BGecY6jPseRzWkIu8V0/L/gf5EqnGz5Xa/+ev5HhnxF0/UYruWa zvTJaOVZ7bIV4mJ5AUclTz+WO1efQrIsKOCN7DcybQcOuC3zAjIOT3GPx4Wb1JuOHTjyR028lr9+ 9j6Hh/l9jOUVpH7769PndHS6VcR4jSRcOgUlAQcnkt+pzn6mu80+dWuIvLDFG+5025Bz1xx9a+Wx SUVUlJPb3e++v4Nteh7tWnK14Rtf57/5bnauU8sF02kZO4decntwOnrTrZvnABDArlTglAe456f/ AFq7KUFyRalbf53a6brv8zyZwUZyV9lf77a+hphlVQp+XkADOPmzgDtzjv7iryN5SAjkkZGDwuRz /MfnWnLLmgua17/drbTppp5M45SlvFei8xILh1lO4gxDnB3Db+GMf/rzWnuihjUowVW/hBG0E9MD 0zVL+Imnpv8ANf8AAa+QqkZQcUtn/nt/XczXuEaNkjUxv83zAY6nP9P1rJFtcFszSK0ZICnjdkf/ AFuKmrKMI1YU7OcpS2t91vI6acY3957rT7r7f1qLKs0DI0LblxgqWAC4H69AfyFRp5wUlozhuNgP QdeB0/z+eaSVJK+2npbr6O41LmSjaz09ehBdQL5QSNwrHBVehGOpBPeqkTyWwWLy9yyECTAwB746 dv5VE3f2Kvvd3XktPysbrklGUWtdF6dD9PgGA+UcdcAY+hqzbhueAFweBx+HNerFrla2fT+vU+ee nysSONn3cYxnHtTUl7AYI544HtgVknJxlF6XYdHF6L+n/XoSynAAwPUDtg1Uw+eMdfT/AArHa7T2 bBK1rbAq44PHcDoAKeUAQ4wMdP0z9KTvZuTt0RaS1jfQgxxx8px7fp+VSISrAdMeg/z6iqV9b22/ W39fePl+K2jX9Mv27LkDgDAPXkE+lbEIxjbnHHy1o73jFra5nLe1uhqMWCAAds47CvCPiXafaMkD jAzjqOf0714mcRTp0Wla0vS2n53NsJ7s1y9j5y1PR17ZG3I4BPYd/wAuK4m90VBu+Qh+m4EKMkZG QBz1z1ryPbNRXvaJP/hvz+49SlU5JWX9ehzVxpMyqVCg44PQjPB9enXn3HpWK+nXSEjaVTkElgBn j05A49qz57TckrO22/W1/wCu56say5br+nt/XqU/s86EfKRzjnkgEg5/r2pPJKDMkZCsfmyCBgnl v09P51rT99KNrN39NbL/AIYtSiuTW9102Tvf9V+JVe38pwsbRlWZgFByAMjBIzlev+RVWQPvB2qv G5e2TwOffP8AnpnWPNCMFZJpr7lff0Fb2k1K9m3ovP8A4cqzysrJxvbIBKD7uf7o6j/PrT70NJbK 3zjau4/Njr0P4epx0p3iqM2nZqzVvVv8fyQ5aOEtrf8ADfnb7jkGtpY5PMTKnzMtyuRxn09RxzU8 7tKm11XzFAB5249M8Y6444xSbahGLa669dr69NN/NoqTatyq77r8TC+ybm7ArkBck4PHGevQYx9T 3qjeafNAzMqSKWwV2gBAwORx1HT07+9aqVSKUo6RfV6b26eetvU05vehzeflprrb0/MxpRJHuDZ2 7c5wAAR8wHX0xg8dB0qvvlixksFzgHc2AB9clu/NdfuSalypK97X7dvO/Tqcs27pRdrfl6GhFOwd Q2X5DKSw+ZuSAQD3OAPpn3qO5ugjFUbYVAyuTwcA9x8pwMnBzg/Sk6cJVHyR5bPVbefz1YKouXVc tv8AgJMm0+bzHDCR8dzwAF9Sfx6c1oNqDWjGOFgck7l+Q4Y84A4+v+FVOgrv3E0la34rReqKdWE7 WXu6fht+hUW5dRww+YbgeuQVGcg9xxz2IPrV2HUWjctyNoIYElUzg/McdK53R0auotdOy/rRehsp KzUHv36L/h1+h0en3jqA2GjcHaGjyepwBycY7ZOf1zX0v8MvgF4k+IzRX1lK0drLiVRZRm6mZGGR gnCR4yOpbpjHpzOhy070oOXLZa9G7dvnp6o4q2Jhh/eb919+llr/AF8z7D8Pfs//AAW+GZhvvij4 u8OafJF5bvZ6/rkFxcuEIJC6danJOQONhJ5HOTnurn4+/sj6Jd2GleG9N1HxTdSFbaCbSdAS00xC SFCH7a0DPnJ+6rdDzXvYHhp16DxmZ4hYenpyKTUbt7Wju+17HydfM8fiaqp5fTclHeVtEvUofE3x bpDaFJd6FpUul2E8DtFaSSLuTOcYVCQuePlya/NfWtUnutRnZkOGlkyPu7fm45xz3/P35wjToKpK nGpzKOifda699kdsOaNOHtLcyV3ba/XUyGyFB2spySe2D05/MdKpOo29QuPlCj5eTjGTniumm/hj fTa/9db/AKGTfd7f1p330KTRhQwPJUngtnC/Tkd6iK8jAAAGQfp12n6fzFdNO3I3zWto/O+9jFvl d4vX029fQQD5SDuAGB2698AdP/rikOQMrknjbwDxwAcZ9z3xwKq0IyWluZpa7dtfn8upCSUo6rXy 0/4AEn5j93qFBO4k8jHB+noPbtUZY8fLj+ELkBuepBz/ADxzzQlBSULrRJr8r9ulmKdtqe7/AC0/ yRGcjK/w/IOCWGSBnnoOP8+rCSvRiSSMYXGfcdfXr7fWiEUpWt8Oujs+l/1+4hw+GUXZrt/l82HH K9T8xPzcAjHPTr6cZpGfoqgHkHByDz1A9P8A6496uVNezaTsld/l0+QrNxtazWunyDK/wnHKqPXo ck59z/nimll+XKnHzHGOemQMcds9PWpUUlK7/lvpt6fr8gUHqlGyVvxf5CLjgYb0BIH5nucYFIdy j5SQN3DHOBk5GPwB5rRQjHSO61duvl8nZlNKyhGPf8X+gH5vlHYbu3P68Gl6BQq4DZHQKc855PP5 Z7cURTgpRWkrvXsun9bDjBe7K23T1HFeMdArYYkbAoIwOR170igDOAMZwCMDOSD+hoqKfM4vS6+7 Sy9e4QjNSl7tl1/r0HY+f02k5HQEHGfx5pMLhceo7BcgDjr7c/nU03STcWra2/BO/wBxolKEoxa6 dezsv09Rw+XgD3IJI4Hp+fT3pBuAGABjoRwCeOhPHb2696qPuQtf3b6fN/f6eRKVviW34br9RxJ2 /Lldxwc8MM9B/X19qQnjGPmb7ozt4JGcqenOalPnqQaXK9Fv83+G3oPTlTa0WmnW6/4I3I7fKWGA MDaOMHr+VMAwAMABvugDtjoPyzzWsWuZqLttZdutvx17BL33ypK72/L8PzAnnp0JI7/MCRx6enPX NRjZjCg8qB02jsSeMZPt7/Sh80Y8tkr/AJ3v+fQlcytpr5/p8xvTKj7v97gccnOBzVfHcAqqZJ6q PY5PHOD/APWq4e7yT7c1110WllsYyva8dL39W128tyjdS7duMqQw6YJHf6H6549K5u6nhN0I9wZh 8ucgMByDkHlR8316ilTUo80bNLV69tU/zM5KMfdt9/TdaDwf4AdoO07QwUnp8oA56cZ4/XNPT7yq qhY9uMYKjOOOozjt361d0pRsm+67Lp/wfUqCtNOC97rp6vX8jXQbUCle+FHTavp6e3WrUGfMTG4F cgYXA54wc9MY+tczWig921rbu3/XkrI2jB8y9pFpvb5/5WLQYl2OMliSMYA9TnsMdcdRzWvY9V42 9THwEO7APTBxn6V2JRinG7vFt22Xy+X3MnVRaSsut/P+kdbYgkKMDcuNxxge/t39q6uxIAy2McjH A7Z/r2rog3y1XB26X/D+vUyelkk0o7P1ev4nzb8TZ7uHXwqyv9klwECMUC5OCGxxxt444zx1OOVt 7hldY1HmI23cVJYge4OOvP5jp0ozeUmqFJRtyw5+ydkra97n0eRWVH2kIdbPuzsbOFbeRZBEBnlW 27W2kghcjgHPTvgjvXbaGqFx8m1CdwGTuycA9BwM59Op+tfJVl1Ur81uumis/wBT6OpflXKrK2vf o9PJs7ogeXtHTaV+7yo7Z/PrUlrCkKFQx2lSUPA2jGTu5ram9ly22fol+h4U23N627+mmn4oej/M d+45yqrtVdrA5B3Af7I9OtawkKop27G7KeOOe39K6IO8003Zfeujfb/gHJJ/DKGmu3a9/wCvxJIo xKQCNpwxUDA7+3Hf+fvVq4ACqqkLgAkk4XGeAOPX+VEEvab2cE9F0/r/ADKm425dmndfj0/EpZiK hWTax44GCGAzx9eM1m3cjxruQH5SoKhiO4Oefb86bppufK9Y3fyu9fzNYt3WllK1l2tr+pM0yhP3 a7hjc24fMevHP9eOBWd9rEsyGFgc5WRANwDA4IbHToOuOtQnD2d+XlaT07P/ACdvxv1CFvapW1jp 921vwv8AeI+TdBXJ28MMjaVwCOARxV1UibLAjAxt7nPbPFEZJVFpZW0XSz6r8fmbpddk3f5n6SKx wPQdPz7VbicKuBkHJ7/oPX8a7+WO99vy1/4B8/eOl1sxry87eg44PT0FMU7XPTkjA6c/h+FSlG67 P9S5Wad9P60Lb4KYHXqPQD+n/wBeqbMQeOOB7D8P51i0lJq9r/8AA/4fyBKPLH5/1+JHv53dBnHu M89/rUjvheAMdR39PypOyil0KUUuWxCjseSvAJ6d81YjwcfTk4x/nrRyXXbyX9dbjVrPS1y2nB4B A4weB/k81rWrMCMfUdQK0j8Pu6foTNLXS39f18jbb/VgDKjZjnjH4fWvIvGkPmPjH90jn/Oa8TOl ajFap83+epWESc7LTf8Ar9TyC+00bTlOpI6YI9eetcdfaSATtXjbjBBIHH5V8vV5figmrNabedzv WlpKNkn28v1OUu9MMYOUOOvHb6du/wDkVlx2oiYbolaPoysgbPByBnkcZ6CsI4hqXvO0bfO9lqmd PO7Wg7NbdrlW40q1LZtopNmPmWRVGxvVSD07dB3zWfPpZEeVRAMcpgcZ6kY6c/zq4Yr2canK7yWi 8/63HCqtlo1b+vwf3nLS6WA7Ex5UnkKNrdh0BHOSP0qGbSQYiYgB1wrpgqenrz16/wD667KFeUou z73T872087tdvvOmNW1ktGvz/RHNyWLxS5EYIBUsgwQV7jp8ufbNVrr5Y8RDYgBHzyZK49PQcdve u2M/d9rGSaWjVt7prReTv951Jxly6r+r2MNkOV4JIAC4AwDgAnd6f41IkAKneqhjkcKWAYE54PXH T8ahxnyyjZJJ2ttp/ndWXkaOTTeySW39bX1KBt2SUFUACfNggEE+/PToQeeppt9Ioj3eTyCMK+OP myR7jH9a3hU5qahzWlH8Fsn96/MmWip/Za69nY5l7f7RKGWNlQswXJJA7bmGeMcA9OlWRpO/buGe clF+QDA656fhjtSliXCMI/Fy3tfS1u/+RhXqxprktflT/wCD+Nn94k2ivuRggUjAUgYkJIwDk49B 6d65+/sZ4nO+Pp984A+Udtw69P8A9fBOlLEOpLklpJt28vJo8/ndnFayl/wLW7EEaxR+Xy6ShVRh tVomxneVcHI528EDv+MsyBZzzuyrY3Bj82d3ynJ3HB9M/lx6FTmTgo2vrr5Kz+T1t8jpi+WKureX ZJ/0/IqOMHav8Ofl6MATjO0fX9atlwiK6kKWCFlCuZBkfNkkAY5I/wAafsvaxjLk31fdp7/j+JtC UU5S+708/vOngni+zjyp13bVcJzgMACDgHoSevfFddpHxD8d2FmNDsfFXiGw0ZkIk0uw1a9srF1O 4jdFC6qwJY5BB5PfvVHE1sBUnNQi33cU9dLOz0bTsr+Rz1qVCtGpCr70fLRLf89nYtx3M7Sea4ee YjMgIaWd8HG7pucfMOOf1rrfCfg3xfe+I9G1OPw/qVtpX9o2rm7mtXtoXVSGGzeAzZOOcAHLYz35 8TjJ161KpiazbutG+r7eRlT9lTpTp0UoRSaSStbf/getj7u+JMZtvC1tG+UYWqhlPy4J9fzOK+Hb 9U89wNuQ+SBkHcACf16YqqXL7W8Vdxenp/w35HA3Hkal/V1u/mZchIHHQowwpHXHHH4d6zpGPoqn GfbnOOwHc+v54rupLaMnZfd30X5HLUVlaSt/VvwKeRk8cY4wWCgkBgcYHv8A41Hz1x0yACwUc56Y 5H4+lb0m005JtLRea6P5dTlbWsk3d38r9vyeo0gDJ5zhWx1OeSeDyP8APpUeccAhcDIzgdBn8PpW l5OC92z1VtrdPl/mxc1rJdP0GF+V+Vl3ZPC8A8gZ/T07fSm85wMDn7u4gYJznvnv+VUqUYqKdrNW XdPX/g39Qvy6WvFJbfn94jE4PcBjkdBgYP8AQDP5UzJC8DG0krtx7fkc8Yx37VNuaEeZNXdrbWa/ S2vz7iXIlLptb8vzuOyMMBwN2FBJJ24PYk56dumRjrTSRk5x1IGASATgY6enUn0qoxklyx05U7Wf Rfmrv7kNKKejsu3fzuJ9zK4J6YzxhiD378bfSg7PlGMeoGA3P8up/KpXM04t2T0/Pf8AH8O4pSS+ FWvb+vTRgHXH3gG2/dG0Y5IPQD16+2fU1H68nkDjGfm56n2//XT5fflyaJ/em1p925a5Xyyhol+r /ry3HBMfdOB8oGDlTk56H/P51LkKpByo4+bG3nJ3EA4xxx+Oc8UWdP3krtPVf16/eNr3Vra3y6f5 jSoIU5wOhYDBwODyO/Q5/wDrUmVUyADaOuQCQPcZ9yfTvmqV5u6k7x6aadE7/IFfmTV3fT5bDgNp Xp06h8qRwepPbsfXNLjsfvc5GGAA7Y/rj0qrbQUNI+8l2W2vy6eYSk1Ha1tvl0/r1E28kdiMMM4Y HqOMehNIcDbkkgAkYGBnjpg5J61UXG7gnqu6t53X4Glo27P7vX+uwcYChTyQeeRjA7e+TRg4BG1T 8vUDBOcAdPw/GoduZTiuWVunVa/jf9CXtpHRaad+4zABONw6YUdAe2Qc+uaTuqqBjjAUjoTkdOox x7flUxjzu8o/DdW9Xvp6IjkjtGNr776DSQACAByxIGV6DsCOeg//AF0xxj5VDLzkK3c/XPTv/Otn F2heOur8ktde7exUmoJqSvbstl/VvvEfAb73X7vrnpx6ZyRVJjgZGcDGflI+YE9CM8YP6fWmk4uT d/TyatZfn6MzknZJa/8ADfqULgjcBjOFG3AB5ABPsOc4rlZVU3zHPlsvQ8EdsY9D04+p7c6UmuWT SbtFtK/V9V5foc6cZWk1vrdvb5fi/mXQUAVlIGeM5JPHp6VdhXLZ5DKcEoDjB47EjtnB6E1jOXLC fI2pPbqrbtfeaReq5HZR1T+Vv8y8GCgLtI5IPbnnqc4OcDGPXv2mh2+ZkbQMEgMMcn1JBPHpz2Pp V04cqcrtyWny6fhZlxclB3leduvq2l621LsQCsNq8YYdByScZBPuGHXua17IL8q7Sp+Xbj15PUcf jnP6VtCznO0rtfr09P8Agg7pcuz/AOAl+eup2enjPOCNwAb9T06dQOnX8q6GMtFA7oMMqSYHb6YH QmuimpTtGTsr9NOv+X+Zi3pOEVtt20/q58oeKdSm1HXGEgBMErJJFI2eQTnhf/rflTrWIB4ZVR15 COMYKLx9335z9K585a+sTjzWUItW8rN3+WisfU5LTUKMXGN0rNeVzv4vKfy4NuxlIZZOi4wfvZI6 +w+tdNpaiPYFPDZKlXGDngngdepxxj15NfKppKlTk7W/W7X5v7z2XJcrVrJq2n5HWq8jYUEAEcA8 DIxnGB6Y71IiMqp8xLBt2zJHc5CgcY9v1rtirKCvvZPy01/HX8Tw6ujkrbL8dvkWomcIU2qydeBl gR7fpWmXV0H7rjYMHrwegGOnrWiSU1CDspR3trfqvu/ExTa+Jaq3zCKSPeBzxkqAANwP06fl3qWQ q+COmAMg960cbKp6P/gGb9yak4pb3+8xpZDb3sa+YSnynacjaxOMnqfX86e2JpWDblAIO4bscjPz foOPX1FKo5wUov3XKKt39f8AgeR0xlFWjJ2tt8ndEihkjcswYqSoIIJx9CRWKFFrLNOASsnIbHDH qOPXJHT/AOvURjy0p0o6K6t3dtVp6P5lwsuaUZX0u/K/+fW3Ye0y3ARt5jk5+TAGQcY5PTqKnVJL eIMGY9SDnccDnn06n86hu7ioxtbb8b/15jk3F2eie3k/L7z9MIfl+XnAPPPuanQgE4wOex4H+c16 bVpron/X9ep4UbXivL+vyGSgcEdvXjvUYc5B/nx3+lTTVpNctv0NNFu7W/4OheZ8R8HHHGMcVnyT EnrgAdOOmKyklzSb3Xb8RX5YxfQjEg6jtgLnH9PrU3Dx4zj36YHWiSSpycXrvbz/AKZXw62/pj42 CHHA9O2alLKMBSB6gngH09+tTFNOLWjfTy/4JO11tr/Wn4k8TsGGOPmA6EAH8a2LVxle3IA7HP1x WsEtPdB2d76HQ5HkjAxwee9eZ+J0Utlzg4yPb0rxs6hahJWtr9xeFT9pFNd/wv8A5HntxaKScDkZ 4A6enp/n9MS6sAVOFAI64Hb246/418fUaXupPz+/8uh6z0/u6nMXumrhspxgkZ2gAfh+Nchc2JiB KYUZOOMZx14riqPlckuq0Xn/AFYlqUdlZL/gP/My2g5JwucDg/Lgnjpj681BJBlcKoHB24HByT2p RXuuO1rJ/r9+noS24ttK93/X+RlyWeNw28H0AHB9vxqm9ovlNGE5YHgZBz17/TNXCo6fW19Bwt7t vX9LfqzmrjTXAYDdtbhht5/vc8+uK5m80tlBGGUDcc5A9OvTBNenQxMZJxt0/LX7ur8jspTVlp5f 8P2vv+BzQtWRhGcKM7VJwD0x+uPXt0q39jQJuw2MDLDIK5GAf9r1/Ku2LTipRfLdq/dO+9n952e0 95LRX10+dzNe12twzr8+SWHpkEfrmo7u3R9qkbu3DBTjHTr9D2/ljSlJKM0o7pK/l0f3/qRJu7Vr WVvuX9fIZaaUCyrGihc/KB1x1+vWuig0bBVlQhlPUAAgjJP06HvXl4nESSUXp+lnp9/c8/EVHe6l ol+hf/sUdWGORzxknGPw7n/IrmNY0cbmG3+HAOAAGz6455/zxWNHEOEede64O2nkrfPXc872vv3T d1oujtdnEnSminEc2BETjlVBbkYKnHHQDNY13A9pcqjxgKpBDK4IAxyCehHavpKOK5lCO0n92m33 36HfRm3GMG7zS+7z+7czbmHZIXRhjqAMbQu3HC9PTj3q1DELpoYsFdzkbgCR03DgdOcn/Oa7o80a dO1+aN7q++zaXl591Y2bjG3Notev9JXurHX2OgXDPHtkzEydFZBglt2ODnB64I/+t1+m+HVS5QzE lcjcRhsgnBPt6Y965XXcnGM1y6q9v1/SxyVMTrNwXKkvyvf7z6s8Ga98FPBumQXms2+qXmtwx7jY aLpSSTTMAeGvLkqI1OSMjOMng8Z9m8DftHXmva6nhnw38J9G0fQArhta1xbrXb0k/d2yMsVsrEZO wo2M/TPqUMvy2lzYnMsTzuSbhThbmcnquZ7RV7Ky1PBr1cZiJqlQfs4prmk9+uiXfzeiLvx0llks SP3aOydI0SNAQOcKuAozngV8J3inec8HeWzhTt9jxXFQ92cnBWSei/R/e/0PThoop9Ov9feZjqwx yB2wCFBBH0wP/r1lzsi5Un7ucD7vfOTjpwenSu6hy8zSXw669bXbt/W5M2knB62+5EQdA2TuU4Ix u4weM+nrzQZIueQpI3dUBBxgnnp2ro5JKMW3aMdbL5K33fO5zOSjb+ZW2/D7yqXT5jvz94D7oB+6 R93GO9Rjbyc4bHyEADC9Mrjkc5PPrVSirXtyrfr5f1+ZkoxTlpZa/mRNkEFQduSNg6gtnPbg9MH3 6Gl3Db146FT8oGfTHX+X4UuW23VJX136v1vbXzBWjP3Ojf6f8P6siwfmDH5h6Kw2nPG38DQTjnIA PToB15HXqfb1q421jZxs9+uul/u1+7sKEYqWr0u/y0/Mbu25/hAbgE5Dc9s9OtA45B4JzgZBz7/X r/nNEUoRcebpda2u+1/RfqSm0paOy08r/pp8tBolRSAS2WPBPOD0xn6Cnt82RjhTjkkKDjoAefXi hWvy7pf5X167q3qym48sk3rvtpp/wCGO1RWOGYEk8ZAxxwfb7wGfarQAUDJGAcAEkDH4dyfTvTjG y5pu3vJ912tb1C/NaUU9Pu89CMZG0c8Mdo+XjjOR9OKUgDPGCvBBH4n6dv8AJovHncZq2zW/T8O9 /MaSjy+9ql/lr+afmC/KTxt+XbjBOOuSB+OOlKo45OTxxjpkAHGfx/X6USSjJuldafi/60Kgm+RL RxT6/wBb2/q4u3gAdO4GAFBI4GB1pvAxhckcDt7DpyM1SvZpPXZdm9P+A/UFGSeutnt3ut/+AOI6 jHbrjAHuCOhzj8jSsDgHJJYdCSNvU5H4kD+VaWhDd6p2/L87fiNu93y2t/W39aeaGjKgdgRt/hXA 5HAx7GmfMCAMg/eyeCVyeOOc8dR+dZrWr70eXrZbK9tL9Nr/ANMmK2dra7L0TWvff5CNjj0J+bPG Bzznp6A/WmZ6D5RjkYyMH1PXsfSrhdSevKor9NvPVL0+Y5O8rbX36d/1AsOM/QnB+YHuB2z1qIHH 3ic4G1huBUZznnr1xWkpSb1Vvzs1/S7i0Uo3e3+X9fcNJ+Y9OnXABK8cYz696ryDG4bmU5AGTgnH 4e2c0m+WyvdRWq7rRW+T1v8AoTP3VJddNTNuCFIzjaQfvA9QCe3+feuZcbpZCvz/ADNhQTgLgnIH b73uPUjtvGKjSla3La3yXQ57KDUYR2T06W6/ivxLQB2gd+v+yCBzzjP19OlXbQkH5wAmFUcKc9cE DOCMnHrx9Kzc4qEnFJb28v6/Q0UmuTkevl27fLsXThSMB1KEkYwOPQ/n79auW0Yfe2dpVDgHgZ+b jB6ngfnz6VzSqTc4pO3Tyavo9PLT1ZpeMnFpbL5af1YsRIqk9iy5Axj5d3H5E9B/XFbtmCBn2yME kkg5HbA68dq7Pgl7sbXelvTr+PlYiy95rZa21vd67/PQ62wJyBnocnggAdewwD7f/Xq1qmqDTLVp HJOELHge3UdTnP5D3rvw0Yzai/sv/gfM56sZRvbutF3/AKZ8zazqFjfa5JeWKxqWO5hgIGkQHBOR jP1/xq3pcmZAssjxqzYU53bG4AOevPpXl55BRrzet1FJ99nt5aan2WRNxoU1Pz/TT720drbw5kVC /BQHeD91uvPTjv8AQcV2en2qpCgcqGGQu05wOOgxxzivmYLm5YJcrj3/ALy0Xytex31LpSVtP87m /wAKu1hheCSM/dPHPp61KSwQPExz/EN4GFwM8+v19a9CHMouN9LWu/NWf3bHk1YJqbirf5l+0Mqn a7cEFiwG07cZHt+NWXj2ggE5c9QCcZxj27Z61UU7ztDZ/O9+n4/Jo5+mib3/AOANhtmyT2HOOBs5 Oeg79f8APGoF2Y52tg5G3dg9Dzjkc1FO8rrV236X138r/kKbb5Y7f1p5a6GXqMMMhDD5HU5G0BD+ OM8f41hpcyi6MGxgmVO7YxB6cHtjp+ZretFOMZynb2aS+ZUG/S7/AA/4c0hcK0rQhWUqMcAlcZPG O3r+X4RG1GSNwVQclOSAOtZOEuWNtGunW9t/66GtOG0tUnsvz/IRLe3kkVchTGyk5xjJ7Y7/AP6v Wpp1KOoyPKAG3GQAQRkHg8ZOKXs5U3e+sY2Xq9f69AdTS1/M/SJfl6D7vY4H161JGwBx7g88CvR1 2bs3qv6+Z40eW130/wCGJWbjGB06DtVZyN2B9QOmAOOazu3K3y+Xp6D2WruvxHByVK5IPp046f1q DgOcceoPH6fn2ofuyfT/ACHHlsrK1nt0FxySMLjjsOOv1FKH5KhiG5yBxxWaUlKytZ/18ir8q0Vk r/8AD/IlVSSMfXjg+tXlQDHr+Ax2/wAaVo/Ds1+WiHZK3T+v+HJUA54wBz7kd+laVsuCD05HHTj8 aqGjl5du70JklZxtb+tDo1I8njpjHTHbFeceK28sZAHI47d68rO1P6tOUerXpZf1c0wSftYed/vO CMmR349cD/P/ANeq8i/T1x0PrjAr5ScWk3bb/g3PeSSWq0X+b/zRkXUGQRgYxg4AGM+46da5O/tO GG04wegAHOTjn6da82pBpt2ty6r8d/T/ACM5JXkkuXX+vkcjdwGPJUc5/Men8qrG6QweW8GHQKvm KxDED2BwOgojFRThe0nqn997/j9yOCTdOV+62+f9MqEIeVBxnHAwTngdPrUsdrnonHV0AwTnJqnT lB+SV/K9mr/d+RjzShZ3tr/VypPp0bKcArhfVep+n+elYt5o7CIjyyysCTjAwT/+r2rKhUdNuMb6 /d2X+R00qr5o2ejv6bf0jiLzSSpYKpXGcMpwePfr68c1kXVtsQqAcgcHHzAg89vTp/LivoMNVUoN NJpWt5Ppr5Hq0amrutF/X9epgOpjPfr046c8Z/Ec8dKpNFumQqSBnG3jI7cZ7+/+NbJyUUpJKavb zTV7drLoay91K+uj+XT8VodfpdiS6kgAllz06YwO3uT1/wDr93a6du8slFyuTuxyfUk/XP4mvncx nypy5d2nZemqPAxGl+WX9f1oXm0kbhiMcZ5ABPucDvXMatpA3H5AMEkYIH+fz715sK0lfldk3qum r1T+enyPP9papta/+f8AX4nC3elfOoMakAhgdoHXrt5xx37emK47UdF/0gIFK54wdpB9M+v/ANev pMvr25XZW19L33/Wx1Ua0Vre1lv/AF3f6nG6jYzWxVipUADC468ngKRzwB3xyan0+3aKWORVyNyk s20hi3UHOCRjPf8AWvo4V+bDy5Uk7b99fv2ev/AOudXmi1FaPT7l+R6xp1o7xiRUGFEYZVBGAoAA GO3fv3rprJFjcyNDldwUghQGyCRjPavOs3OMea1tfzbu/wAPkcrqe642v/wDu/CkvhFNS+0+JwUs 1Xgpbm7kUAgHYn3W5JOD0zivsP4OfEPw7q/iSPwp4T8CTanohYGTXPEIaH7OTt2C2itDtQZ3thpS fmxtAGD7eFwGGq+/isSoU43tFfG5pe6oron3+48jE1q0Hy4aPvNq76JNpP1si5+0X4N1PSIWuZXV IShkWNAVjGcHA7gdvxr8+bxCsjgA8nJI6Y6kc9etYUlNSqRa5WnbXyfX9D16bUqcZxlfRfft+G5k ybkLcDPfoDnBI/mPTv0rInBcsB8ozggdQOc5II/P/I7abcVrLRfLt+ZEo3imlbTX11/yMeS3umIA kwucEZOeTx17cevHFQCyuuhl4AOACw45/wAMYrrjUcGoRdubZ9rq7+5OxzVIyiua9m3p5K3/AA33 FmKEoArsG45Jx83U8nr1qYKMEAYAxxx6En/6341cnKU1K6tF289f8nclLe6a02vp/XRDSCM5wCN3 AwDnpyCMdP6cVET2HptK85ByQPb/APXRTirx5pWT8+j1fo+l+2gowjvJNO3pZ6/5f1YYeCuAFAbk 4IVeT9Tj7vGf5Unyr0yp5bkAktjnoffJ/pU3k/cT0jdt/Jta/l6eYP3FZaP/AD1/BjcFWIG3k/IS COvBGM85I68CpFUYAAyPmwMdFwD/AFNSpO8dlyyUvXZC6Xvbl7dXddPmJ5CYUkfMp5BUY4yBg8+/ PFShFGdoKqBkAkH5hgHB/wCBdf8AHnogmnKUY289v68iXZNNLb/K4c4br3AGAOOnAHTjHPpyaYcZ GSRgglRnBI9uh/8Ar0fE0776fr95rTtaOu19PXf9CI/XAGSeMbQM+/tTu/U8tkMBnjGQd30NS4px ipysktu63/4HcahFpRcrXv8A5/n+ImBnhzjbgdT0OSR/ge2MVOQoVGyUcDAIwq8jBJGMk5JwO9U4 vkbl7t1p6d79kvxuJaSUUrXtb06v+tBvBZRnad33iAAc4H8IGB9OmPyaQQMKVLZ5JIHPB6ccZ59O fwqrwXJp209dflfqWo8qhJP8ellYQg7iSBnAAAbgd+oHHIGfpnqeHDgD2DY7dR0J69xUShHm5ldt JX13ey/C39MmMZXba1e+um/3bfiISV6c9CMd8n0z+vtTSDnGNvHB4AGM5H4jFaa8qcVZNXt6aq7+ /wC4UkoPkj7qTvr9zGtkZOdoA4PHzH88Af4VHjBztDBcEgkLjjGABwMUtdIxS7+jbX9fiJppNpWt Z/1+IhJCgFRu4BHRR3B59uKixkDPzNn7ykKD+GOnPSralG9tHLZva2z/AOA/yY5JStJaNJ76X0/r 5oZ0zjHJAA6AY9T+fFQk7WCsQcMCcquOgI69Pp+veiPw+7G/Lp6br7kZSS+Fysutvu/Uybx2w7FQ qrnJOAo284x0HWueRlLvIrAZODgbcvgcEAZx798fhWsYv2c2pWUrNdlf9W07mM42nGUbqcldrotd fwLajA6rjn2A6NwOcEkZz9fSrlp98KV5I3YXcAF7HPUD/JrO941KVNLmWuvk7O3l/wAOEZ3qNxjb 8O//AAPxL7fuyGUdMkkHsRkhu38qu2nKSYBx/C2MkAZHTHXPOe+T+JKOzi4pRS0v+H4a9mdEIfEo pRSW3n0/z+ZbQ/P7naCp+6FA46d+nHtW1ZggnbjjHGBypGDx26D9a6ErNPfVq3nf/hyZK10tLPb+ vJfcdLY9R2AwOTwRxnj6A4Ncf8SJw2kS+XOYpoFD7VYBimORgdsnPWvSwcG62i5eTt36fdp8zJXj JKelmtvl08lZ/efN+nNLLcs5yCpLkMq7X5ySeoPv6Zr0OCKJI0kA4BXK4UMBxgAjp9a+dzSU5VUu bV6O2mt2/ue33H2WVWVCcn1e3W++nzOq0+4KgvFnYwACN1znHGOB+ldxp86ywRkb0dWOUbBIORgn rweM8968lwSkoqNkt3fW61TXm3+CZ1VrcsopbPTvubshDxKBkD0AQEE9PyFTwhkVEGW25KsTt4Bw enU4x1raN1GnZ3Wt29r/ANWPKmtbJaO39L5/kaW4xxBnYZzwP16E+h6/4Gr1q6vEG7DHy9GHODjP Tt+tawio8rUuVR/p+b2fyOdu2lr2v+f67E6xlZCyl8HGAc46gYwehq2XCIAfU+529fw9a0ik27e6 tf8AgX+4mVrPdKOn4X/4BSumhAWT5NhXIx/D2/DmqUQARiAobJGSF6kjsRx+dRW15FJ2Tsv00NKb ThNLS2pAUCFpOBvznHVc8dOtR+SXZpEk+bBJXIAwMdBzSVotpSve/wCH9Nf8A25uW8b/APD/AKf5 EFr99g/yMT1yM9+fTp7g1fuYMw/IcEDjkA46AY7dqSlP2zulaV7fdf8A4d+THOKioNRtdW/U/R+I DHQYz7jr70uMHKjgZ+uMc13SjyVHbpp+lvLY8SCjytWt/X/ADPA45wNpGcg9P6VEVw3Qd+OnH+cV HKubR7P+vxBe7FRv1/RDwoGCAPUDhcDgnpVZyAT69CeR1+nNZyag779vwuCaj8wjzjHIHftg1KF5 xgZ7cN/+qk7Rlta/62/zLS96Wm2n46lyDCZBHbH6VJv+YccfmMn/APUaE25R0tden9dwi90WAT0X jsMdR/nmrtsx3LwRyevAGefyrSD38vxav/wxDSs3s9DoVY+WMYHGMD17c1534vIEa/7rfj09PrXl 5x7tBra7/r+vM3wTUa8LLdnncbg4OCvHHsevT86kbuQO3H6cV8y+V83K9P60+Z9IlHW3X8P+HKM/ 3X4IxgDB59/pXM3oPPA4zn5sYrnVJXb2vp+v6/ciHRT2W39P8zkbtGBORzz0JXj6d+hrBljAQ8EH nAJxn/D/AOvSeHs+aKWifp2f+XmedXpSuuXZa+nr6lJJWyVUHaASOuSTx1HT9a3LaQbEBbDfL90c MOMc/j+lOdFwUkl/VtUl8zzZycZ+zkrJfmXPI3YYggdTyB+Ax+H+eo1ksiYIbnIwckDg+n0ryJP2 d7xtbt/XW5cJ6pbb7eX5HLX2j43HYcYyD1AHH45rlNQ0oCIjZnAbHByOhPQV6GDryUJJq3X09Pz9 Ud9OtJNJa6/mefXenmNmZV7sdu3HQkHkdcD/ANBqnBa/P5mwqoIABXAHAJBx2/HFeupR5VVUbydr vys9vv1PRc17KNly7K/zOy02NFKsnTjpgHqNx9c/4V3unupUDAHO4YOB2FfMZp8K5Y2b0flrb+vz PDxcbXUdE7r+vmdEIYmTKqp45wMY68iuf1O0BGAqg+igKfrz/nivHUlTa0tbl19N/wAfxueNKbg7 Wu9/RHF3Onjf0wvTjB9Mjr/nmuS1DTCHLLHgrjPHQDJ7fnivUwdZ8sErLlcnvvszopys3rtf0OL1 XTGkOGU56j5QMdc5PGDyMVlRaXLC4IjKplWChgw7dABkg5yB6MPavrsLVag6fNaLe9tm77dkUsTJ JxbtbT7/AOvvPWPDlpJMIrUgqWXOSABkLkdBx24754znnqEsRbbo2CHGD8oIGWUMvBUEcN1xjk+1 Y1KkYuEYtpq6v6aa/wBdSVJciUHZbu/9ef5AdOVpEBiyGkUDI+8Tu6dAf4T9a/Rv9muyOj28M6+G IYlKKGur6TcFTA5hijCqOO+eo6GvYyuWHqSj7aTfK1ZW1bulZdFvq/U4qntakuWkrRSbuunn+PU7 D9qmU6p4WheFsLGdzxqAMDaRkD+Q96/KC+gbz5ASBhyM56df/retduKSWMr6csW1t6HpZfH/AGSE LWtv95jS26gHrkehHTHP0+nvWdJbJklSB6LkAY6g/Wop1IaRULtf5u36HXNaKztay/r79fUqtCFI HC85A5OScen1zUTW4UkqR83QBh0IySemOvSuiE5R5fd0j5dL/wBetjjcVZRa22+7+kZ8qKnqOmB2 3dBweAeR+dZkskyZ8uMEAcA8fw4IB/8Are9bxlF/Zsmrro31fmYtW9y3p9/9epCtxJ3RhwGBIweQ MdOuc+3Q9KsBXdQANp+UcZGTxxx7/wBKu6fIoa6J22tdrR/dcV5XjzKzey/N/c726Asb7QvGACSS Tk9R249eOBUqxkKVxnALA9u/GRx1q1GFOMpRXxdP+3bfp99imnG2iSfXrtpp8/yJAqgHb1x16AJj JAI9vwpOABjA4PGWGQeM5H+TirUEpRVr/L5/hb5mTvzNJNXf4K33CA4P3B/HgYIUq3cd+3agAhQA EUbT8oGOvJAB+p/M0c8leN9NPxTaf6Mack4wnpf+vyEGQvptHHtweMY7evv+cR6r8oGQT3BAPPHq f89qduXl5ttfJrTf9S6b9nZbX0XzGs3AbC4A5IwCwOemB7fz9aaG2HAHGMjdknpk8Dpg5H4etJrX Sy5dl3f9dC4tRmvJa2/y/rUcpOOAVBOAMHAxng9R07f/AK6eDtxztJO0LyAvOBkeucUox51aO1r2 7JrX9R8vvrsvwHttwGIxt5bHTj3Jz/8Ar96TByqhShZQflOQDnGPXGMVV2k1Gylt897eq2Hbrf8A y/paDtnJKgAHJBJI6jp+QJHSmYKkADILcsWIwf8AP6YqafPJRlLRt2a/X+uwopwSSlv/AJANq5Hy Y6NjrkfNnHb/AOtSY6/KVAGMe3pj/wDV/g4Xi+XktZaL73/n95Mm9Itapb9N7fJ6DcHrtTBzg9Mk ZIz+o+rfmjq4BKjrzjJBU56k9zx+tJSandwSve3k9vkPRJ6et/8AL5/iQsF+Ztoxu4wQOnuB07Y/ GoywGAAUBJB4AAHYAduB/nttZOFox1T3fS/R+t7kyl7qvG6vb06/PqB6MSBjGBkZPXnkVTk4A2kD nqewxjGPX6D05p0pKDmp2UY9vO34djObcbKMd/LS+n5b/Ixrs/IwBwCpBXABORtOQeMd+388c9ah UDj721gpUEfL1+XA56e/fvxW126bilaLaaW2t79Ol2ZctpJt6q69NtDRIK/wrk8BTvBJ7DrkckY4 79avWqkvn5kYK+4AgHPHB9Ov6VFSVOCckrO35/5v8tx2VuWMdb6fNWuWyozkEBQ2GVipweOCOeOn oefz04E/c71XAyF44+o+XGOh+nTvxzx5EqaktWna39d7r7joaUee8dWr27bf5luM42t22gn5tpxy CeO3H0H8tu1OAuRg42liOgxz0xmuqn7sItLsmuq3/Hf5mUpST2snf7joLQLj9ckkbVGeM9uv414b 8Sry5i1OJkc/ZinlybGAT6HPIPYcHqe1ephVJSrvldox0+7f/hjNJOrRdrWf3dNfU89sEZd08AXb kMygbecjI6Dvj/A16BpiGddqxhVb5l2gj5sEgYboOP1r5nMXFRdRtx1X3q1v6/4c+3wEWqVtla6f Y6KJY/k2oDgglRjI5657nJJ9/Wu90yIKinYcZxgqVyOAD1x36f4V4/JPmpy53G2v6L0svvua4iVo 35d/LXp/wTaniIHyg4AOAqkDJHp25/pU0CvsUtglfu5GOuT1457HHrXdZ2jH1v8A8N0PJlNt3a5V uWJAkqpnKFD1P3hxzwe2f51oW7GIDjHGAVGBwOTk4xyB0x9K0pQvKC5rpPRbfL7jJvlbXe3S2/8A V2SpcNuO4Fc9GHbGCD7VPJKjKETCtjIAZfoc+g79B0qqUXDd3Ubr+vx+TJXRN7tv0sylMw4iUsBj GQT8uDgAeg/lVaRWjUgHbgZY9MEE4zjoO+aibu4U1q7pr1/q/wDw9y48qXwbO34asgkjlZVXb945 LKQoHfr9MjiqYjk87aj7dnp2PJ5JH1qIP3VZWa38ui/G6OhWXNaO7Xy/pk1tGrT4bIK42nPGRzz7 1enlGGjVQeSAwAO1sYBOPr/nPNUnauuZ35F+V7/jb5WKkvd9lGNtd+1z9GVlO7AH8uB+HSrKH6Dj PQ9K9Bxly+90/wCCzwkkpPXfby6iMTH3wMd+Bx29qhMmcemBznGBn1rOy91bf1f8/wAw66aEo+6P pn9f/wBVMY8fd5Bz1x+H0rJxSbjFdflv/kJJRSaXX83chD7WwAccdjn6/pQzEnK59f8Aa6/Wk5K1 +WzRaUeZt6XZYhccDGOcDPHHrV+NuNuOhyPrVtJSXTT8tSpWjotLFhB1HHtzz9cVah+UgY79c+9V DRpdvlsS9mkrb/kdIhAhHGMfhXAeLgPs4PTAcjkf4eteVnN/qztsnfb5mmE92tS6Wf5nlXm7SMMF GcY5HHc1YWcDIHBAyBg/n/OvmvdVorS+n9fmfS/Dp1YjbGGB1/EDnrisa4txknjgH5cY+vvUSjON uXTlfp6strol5/fv9+hh3NjknC8jg/KBj8h/nFYFzpZCk7TjpwMf/q6dK6qTjKHJZK2n4amNWmrP T+v+GMd7DY5OCAeuRtPr+PUVYtbbngMMchumOvv6UqtKMlKPN07bf8N+h42Jo2kna/XTv3NiOEge hUD5cYGe/WtJIuMH07Hbj/OfavnMVS5Z8t0kt/69NfmcnLFSXS3+Wv6lSayEinCnGDkE4I+v1zmu ev8ATFVT8nQNxnB79KxwtRwfKnZPv99jeMrSWmr1POdT0vbnCY4LcDn3x/nvXD3MT28hVRtBORkc gZ6jHPqPWvocPWXs1FO6j0/xbfNNo9KE1aKsT2twU+VQyEZBDgZPTkD6D36+tdlYXi7V+Y9+cAEc ZHv/APqrgxtFqU03fp/T9TkxTjZ3Wmz/AF9DqIb1diqTtI6c8c+o/wDrVPNOkqBcDkjA46ke3418 /iKLjCTitX8Plrpp91z56onCVS19Nred9jLe1Uv90DPQcYBOOw6d6ybrTcucJt3dsZB6/wCf1pYZ qLfub6X/AD9Lv9exjzOK0uk/6/H9Tn7vQstuCDcCOzfX19+T/kZzaBCw3qDGOCu4lgCSc/yHXP3a +owddU17NS1Ssvnb/hl6mbq8rcHG1vxOm0m3EVsNvyvET5Z27WGMHAY//r6Vu2tjd3siLBDNdyyf dht4XnmPRRhEBZuwxiu2u7RTSUUtfS+//B/yNoya5IyWrWn9eh7B4f8A2fviV4pkt30vRZbCLKOZ tQVrYjoRtiIznIHYev1/Qb4U+AvFGiaNBpXi2WCD7MuxGGIZmVeB8i84x9a9XJKvPV9lDDtxlqp2 0Uuqvtt+RM7Yfnk6iTaty9WvQ5f9o/w7b2nhKe4s9TgYquDBcSxwfKEY8eYck8Hjmvx81nU0iu5o zMmUaQfI4OCOmCK9SvBwxtSnNXtZprquuu1z08BW5sPB2UW76P1OWuNYj2sd2VyR8qnJPPXI/wA4 9652bWokZhvmwM8rGOvPI59PyrSnSXPaLt6efTy/Oy0Na0mlT5Yvz7dmU/7acY8uKRtx4AKnqemD yBgnjNNXUr5iMQMnBKli2MHHPTPQnjnrjPauhr2cObns108+uhyqTutLXfyRaSS7ZeRggcZ+Ugns PftkY+lXbeCR1bqzKAQi43nJAOD65YD1+akkvciopyS8+1n8v8gTcWmna/T8/u/QaMgrnCnvjgKe TyD/AJ5pyYUhVGMdF7Dj0Jx1PPP51UVBRUo/CraW/rbViUeZXabf4/8AA0HKRxgBBnH3Dn1AGR7G nZzn7v3fu4AOP6euf19dI2jyvov8v+AZwesbq9r28v6uNITB/wBrvvZQwyeD2PXr9ahVAD95lHH3 vmA9Dk9euadvZ2duVyauuv8AwO/3gmtVy76W/ru/1FyBgYVuFJPoSMHHAHb8AcfRDsByWBOc4OTg EDBzycYxj8fwai3tolfTp2X+a+8fLZOW3Z+vl934huVuR2zkg4G3Hpj6/l2qIleig55+UjHY+nHR vzpSVOMqXOm0tu6S72+/8Bpr3baK+nfTf/MY2OuFHqMsF9gAOB3/AK0ZAP3ApycKBgbfQHrnv+X1 rKW8rKze1vNtflua7ax0t16/0xF7YBwSBuLbcYwSM9sZGPpn6SqcKqqGzjAPAOCD04+v5U48tNws 7af+S/8ADMSdp2tZNrXayFAwSOrZyVICkfNxwOTjjH8/V/GT83RcYAx1UkcAZ9O+Kvlu1KMuVfnd X/W34GkZJW6cumvbb5hhR24xkA8Hn1A9yeKUD5SMHAzjjjJGBj9abiveUXdevff8dmQ03yq2m+n9 dxuwAqVG7rjbnAGD6dv8aeQv3c/N1O7AJIyPT0z3/Ok1G0k1y8qulfVatGjaU7tWt08nf7tmyzHD ERuY9V3YYj044Hb2rOnlQShU+YAEj+EfgfwHbvT5Z3i7LTd9ttPO/wDmQ3ZJr7/l+hXJIzj++Dg9 euTz3P0qM+5PynIHIVc8evuK0UZQU5c1uaV35aO/3f5eQ3K8fdWq/KzQx88c4CsOoG3OSepI9h/+ vFQyApjkDjHy8FSMHnj/APXWjipLkjZN28rrS2nna3zMZuXu6Wt02MK5XiR2OF7A5wRjJOCeOT+P OOayIQMcFQqn5SAVGOc7eOen8ucGopy0cXB2Wlutv89fwRzU2uZ6X127X7/mWgV4wv8ACyrjbwP7 vP8An3q/allOVHBPRugwDjJzgdAfxoqxdl2W/rZq3zett72Nop3c+69fNW/rqX93GOc5DcgA4PH/ AOs4/iH0rRhA8rO0hsDcuNx7bsY9Qv6/hUqNOKpSVnfpt5NfJq33M1VlzJK3KrLz/q1ixCqrjaDh cYznd14/z7flsRAgBNrFcrwQen3iemcgjpx1HvXTFLmaslHV+nVW/AlpfE5advPT9TSmvI7C13Od gycBvkCtx6++Pz96+WPFmotqOt3LRyM0KuwIBJA56YHXv+tevQl7PBVp9JJfjLp0vb8zlim6sUl7 v5dfyLumwNHGCQyhwDtGQoJPHXviu/0wFEWRQd+NrFB90HkHjgf/AKq+RxlpPlg9JSWn3p6el/zP ucC5KhZXtFbeb/yTZvWsY3q543ZZclfm5HH1wR0967qwDomCxZMHawKnr7enXn2rzoezdXX3Wra3 01unv2fy1+RvWneMYtWUdL9n5/oa0krBFDAgAZ4Gc5z1P5cDp+VTwuqxblJQ4+ZQ3XnPIP412csE 02nba/8Ae/rQ8e0ld7W6P5F8N+73bcHgZIyqjrnjqf8ACriFAmG4VxgY5yx7jtnjHHrVxtFq/VXX S2y+8h8qilK7/Adb58w7uYgw247D/J70s8HlStIhO3HKngdeMfpVf8vZRT1912+6+33MU4xc4t6a fi/6v6MqRSbiXdSSpwD6YPGQenGOKrqxkmfOVdcMExgMoHcdBjPX/Cpk0vbPqm1fotW3t0vZ/MdN NXTjay+V2WGlVIwpPzZOFXPTk8fn/nrUBhdW8wIRuGeF6j+979/pj3rNqPsnZWU2166/5u6NlzRb lun/AMC2n9akZgeOPMZIbIwMHsMdD9fyFRhCSqnduIG5RwcY7j8T3rOUvZzlKHn5K1r/ANepqnGL tt+Hp+bP0ciYg9xzwBx0Pt9auxyAgYOO2cEc/wCTXsSWmiPnY3i7PT+la3oOILLj3GT2JPTpVdkI Pp27jHtWN1zxint93f8AI0lqmr2/4YmBwuO3UA1DnbnI/wCAjIOPw+lDirtXtcrm91W6DG6grnnj uOuOv+e9TDAyTn8OBxWUrWatbdfgCaWtrdf8hy9Rg4AHt1/pV2M/Uc9en60JPZ/ZSHe1pb/5+heR h64K8g+3FXYjyDwCO3Ax3rSEHBLS9v6/zJs0k9ul/I242/dY6egOP8jrXDeLAPsh52jkHPPJ9K8/ NYS+q1ei/wCHNsCn9Zo6b/meOs4HGRlT1GAPwH070nm4xzg8EdcLXySVovTZ/d6H07V47WYq3IyB uII9x+lOMqE/zweg/lQ1eMYPT+tPwGlqlfb+v+B6iFFPJBxwQvv1H8v0qs9uMYZRj+Ecdux9KS05 bbJ/8MCje2mmvl/XQzbjT1ONoC9zgAcf5HWs1bbyzjaQehzjoO/FdXM1BtrVfivI4cRRsk7f8N2L SRrlcDkADsOvXP5D8q040UqB/dweMAgHnkV42Lhq2onm1aXK+Vadfu/4cf8AZuDs44zg9xnqPT/6 9Zl5bIV2lPw4H5/lXjX5dbWs/wDLocsfiV1ZHEajp4JI6EfpnpXmur6Z5bsVHOQW47859v8A61ex g66Vkvtfp/w34HZRqq7W1vu/rU5CdGtwSq8gg9D14/nT4b/aQGJUjB6HPB6Ee57V3VaPNG62T/4N 7en4lVWpp206fff9UdDbaoXIO7IGMduffH1PWthL4ZQZ+YHOcAMMcAA/Q8/nXiYjD+zT5k7Sf3+n a6t2PHr0XGfNtf7v6/yNe2uATgsRzyMYIOc9RjH/ANetkQI5B9MHjjAIAH0Ofy4rzadOUY2aaV72 tr0seZL7VtPy7q3yT/pjJrIYyBwPvDDADqSSf89KyZdNTYMcMueDuB4PABH4/lXr4OSjOSi9uu2z Wn6mcmtr2S7/ANXIvs3lwt1H3iSoGBg9sf1r3r4MfFnQPhrDcDXPCjeIpJn8238q9hsGhcDG12aJ yy/KDxjGSec5r6fLYYDEVoU8wm4UH8UrN8rWuiWrvblS7MqTqRhJ0NZrWN3p2f4ar5HsOoftneNb sjTvB3hHw94bEx8u3llEupXa56cvsjzz12H6V33w48U/FXxJqJ1Lxhr97NGY1KLvFpbmPLNgQQBY h97H3c4A5NfbVM7yinSjl+UYFqGyqztd2VrKK0S69XojDC5TiZVPrGJrc7W8VtH16vb06Gp8bp7L UfB99bXc26VInMbAg7m2nAJP61+ROsafAL2UD7iswyMFsHr/AJ9h+Pj15f7TKbno0rLs7ary2PpM HGMKSg9LX/Hb9fyOYnsYApHGMkjODjJzycdsH+tY0lhbAgbOh6fL05AwfYd+K0oxcJ2Ttq38k+ny /AuvyRum9lttoCWUUWcRqMcg4OORjsP6HqKnMajABPyjCMu0ErzwQfdvbnHtXVGO/NJJt2Wm3T8U v6ZyOXK1yrpt0T/rT7hjBQBxxxgHIUEgc47euPp6Um4xn5W8v7mSOMMCPmz9QPyFUo+zdoXulf0J i7O0lf5df+DuMLnndjGQMA7SMMRnn/PP5KrbQDgjOBjB5HA9PT6dTWkUtFHu3Zb3tqvz+ZSfKtXb yQzcMYAI91BPOT2I/WhmX5cYJ+bJ+XC5HTH4iiDipwjF3Vno++/6q78hqUU2lpzJ/iODnBxkDByS MFTjnAxkjHv1pu5T32nnBAYjkY456de/pVTnZyqNLa/6Jfdcwk05pdu2+m4u9QpBI4A+UcDPJ5/L nr2phUOpVTjj6jBwPu569+1NdU1a9/yvfy0/QHopLbsvv/QhRNjEb29Wxkrgcg8dP58UEn5fu7iv B5XkEj06cioVOKhFyu2tPNd7r8RSsrcqt018/wCrDCVUddoJUhjjgcemOvP0zR3IGQOATjnnJ57+ +P8AJyknGLitVHTT5t6feXazun07dddfx+4TdhRggYIDHJOWxjnnIPB9/WniTn5sHjqdw2Yzxge5 7Z/w0gpfE3aytb7r/O5qpa3vba3bQk39emDkZHAxwMhck9+/60CRueAGUgEgYxnqefx4wKcotbK6 1afRLpp6q3yE2tE2hDIq9SFA5YY59v5dz2pVuQMFRztPG7PH8geMf54tQdoOntLvo7f5v8NS04xv GMrdrfl944zvjaqngFu+M/j79cf/AKoGdyoKjjlexJ7n8D/QU4xSjZauX4aP+vUUrQ06vf8AG5DI t0U4duwHABwP5Dkccenaoo7PYd8kh3DB+bBxgDKg455759fpV3tel1X5Wvv93yE2o3vZJLb8/u7k 5BU45AHJBOSG6qcYIx75x/Oo933uoGCwIAUdT3/A9fX8leLduXkT6N6d/wAxRtryq233Pa3zGFQO FwACrMBx168dxz6c8VSmYIhYbicHjGAeBwAeCDkEf15qlrKPPG1u2ltd/wAPvJlZyvNpb/k7GPcv IImzkDjGQF689R35zj2/KlFGFiA384BIwcqOOoB9D6Z/nWlocrSjZu3ney2v5GMZv3FJq7a067li NZPmAyuAQd2D1GMkjp147/0u2uVbBHDD5VII2gnqP55rJwcFyxejs9ej195+j+ZtH3eRLpt00XX8 LF5xk/LnjAzyc8/T3A/AVpRNtjA2rgdCd+Sx746c9cY70moL2VKOjUr9+n+ejKtFS/dt+732v1/E swnkbVC4Khickn0yf8fxrXhGCCT2AXqOc9/7vf16e/HXCPJaF9/TbZJf8HotSJtRi4rR7/jp/mcz 8Qb1LfQiDJIrtnyz905x0B/HPTqOnAJ+dI5WNyZimFk+VlAIIIzhiOnbP4V3VI8uX0Y3tF83X+8v z6GFCajXi1qtPzd/S/bsdrab5Ilj7ZJViAgDEZ2nB7DPPH9K6i0umiCRbWxjjP8AfHT2x17d+1fM 14U/hgtYty7Lr+K/U+0w8nbmWuiv96v+H4HThGKRCKVkfIIB+YknnI4GeCP8K9AsyfKj3EYUBWPQ H8jxzj1rzJcsakeRX0u/XordP10Lrq9O8Vs/6/zLUycLtPGQTjsvr9MU+NxtC/Mu7KnYMHOccZHr /OuyLduVKyd38jzZRdrqOq/4b77GhG/3UQZcLwCeCeSPxrZRQYQSO+WUgnbz24+np2oipKVNXvr/ AMNf5sia5VdNtu/ysSKqhgfu5GAABjPr6+vPuaZKeBvkwFAyOOF4wMD+f4VvH2cXKcdZbLzvfb7v 6uQ+W/Nsls/v1KEibXUxn5GYk56geoBGAfYVGZj5oj2/IAMtkjB4z149f1rCad72to21pZNOzXno johqklp/Vv8AL5Mge4j+0BOMseoBwQBnPPbrz9fXndWWOOMjcNqDaoAI249u1Vyvmpq22q7f1oLm fLZq2/3r+mU3kjXO77ikdCeOAMYHtUBZUDOOAeVOAQfxPbH5VXKnLbRytb89PQfM+dK2vX8f6/4c /QyPPHbjoT0wfToKlVihAyAOenTtXdJtNez1i0eLZtO+jdvuLSSAIfTp6f56UwyYJwOMggZAGay5 LTVlvp8/+G/EcVaL6dP68h4HsR1PcYphwGGBx6Z6fjWfVRS2/P1HFdFr5CE8ZGAFHCgc8j/9VICM nPAGe/Iz7dqlx1lfdfh/w9ykmrcv9f1uKuF9hnjHHpV2JxxkjGcgdPb86qKXu67P8R2cdUtV+f8A w5bTAwuR1Dc5Xir0RCsP64HB/Srp2W+7/r8mSullsjoEZfK5HUA8dj/jXE+K222L/KMc9RkDg8cf yrz84s8LXTfa3TX/AIY0w38WkuqZ4LJdgM3IG7I7AdcHj86ptfcAAjH/ANf8+lfHq3KpJW0/4G35 H1L0Wit+oC9yduR6ZBA5/p1zUi3h4+fAHQYxzjJxj2qml7vK9rfK359ioKyS2/rV/eaMN56n+nbP Sr4kiIByOnOegPTgGnFLkkpaLt/XmPSz6rv16fgRybSpAA6duMHGO3Sst0AIIH3eOOOfw/CiLaSi 1r+lrDkouE111/r+uwzbtI9RyAB0HXNWEcrj29ccfkK58THRpO7bX/DI8uvS0btZvp5af19xcR0y c4B68ggn8KZcIrL05YdOnXH+Irwq0LXT2d/l5HlTVpWWie3rsvwOZvIODwBkkNgcc/WuL1SwR0bg exIJ7/56U6E+Vr3Wmtu1/wDhiY8sVa3p62PN9Q0w/PhT8xPQHHPtj6Vy76e3mdlIyV+UgA5J/wAM da93D1Fbl20el9Ffp9/5m06j5Wlo3b0/q/52IY4pIZUVWJywyeCobd1GfxPHXJ4Oa1EuXjH97uBg jbjgnjjv+tZVKdlLq1ql/wAH8Dkq33cvd/Xb+vmdBpl3+9Tlv+BEjucAg/zrv7ObOMMpXHAAxnOO 1cFajyRXKtVv8/8Ah/uPJqqST5dbdjoBGHQbcDAJIAXG0e/5/rWVNbbCDjgke3Tkgjp3A/Gs6NlU SjHb5f1ojBKPNaS23M2cFGYLnb1IwB8vfoOlZMzeWVZVP3s4VSGHGTwP8mvapyXNBbJfLTX8zejO 81GMOVa29Etf8/mRpqU9vewzw/LLFIrDAx0YHt/k1+lHwgbU/EPheG5uRsdYVVSARlQowc19Flyp unNRj7ya5X563O2lWnGo0tIyi0/zRl/GLw7cQ+FLu5e4VVVJCQ80aFjt6KpOWPXgZ61+W2tn/Spc /wB9lzgKeM9seg/T6V2JT9rVjUja1n23/Ox30ZxdK8Vb+tjk7ojAHG3qdx4BxnP5VksckhWHRhgg Acjtjp+VdlNKKd03K+n4b/1tcxq8ibTb1Wnn6+rEPytnPzDj5cDkA4798+v/ANaxFEm0EuEOPXHz A5H4/wD160londaJtfdf9TJRStGWy29PP52/EryBByXGcjk4BbAA/wAk9qqs3+0OgwAoAyDx29h/ StbtuSULWXutfPcyu7JrS39fh/kRZ+8TgZ59dpB6Y9OP16U3jv8ALjGWB+XPA4B6cY/Ooive5VK7 0fkrpr89W/8AMcbXk5aNf5vX7xTn+E9BjnIUY6rjAwePb6E9Gk4/d8dQQRj5sAcY9enT+lU0o8sI 6N/inb9PxYlZLsl+un4fmIGAG1PVsAYzxgemPy7YoUkg8EcZGCMAr6H8e1W0qcLtL0fp0+ZKlyLR Wa/C/wDWvzGltpXgKQACckYB7dP8KUkgNklepHysM4I6L296bfv+67LTf5X9Fbb013HspXevb1X4 eQ3kdSMYIGVyQ2Ovcdz/AJ4qI5G0gBPvYB5HPU8f096Skk5Sbta9vV6/g2rDcve5U7JaX/r5iDcu OQvUDYcLtBH+eeeTTTs+b7rYznG0kZ+Yd+DjB+ntRbm5asUo/wCXn+nyDZpLTlWv3bfoA4+bcP4i 2DhSMYH070jZyMEFVwADuHH3Rz0z7ccfnQpRjByUbXv0218iWtlF6K7XS1/Tz1+YBgDyUUjO3CHo D1BH0NLvAJVSA4PHzHue/vwK0ilBJ7ptei+XY0c1yttW36dV1/rzH5OSVGRjGGGBjnB/w/CkViFI A/vAcDK+xz75/wAaVoc6a0u7pLZJNf18hKTUot+7f7tv89SVX+VsZVVHAGR346+v/wBepcehXpuU gLk9hjB5J9vWmoe87SvGWit56/8ADepKlJP3rNWtp934/qSFT06/e6DHft+dO8raRtIztGflxjPT nHA//V1quZ39mlZXd3btr+TK5J2cUlbp6btfoV3h6ZG0EZye5PIJI57mmMuCVyqgH5SMKAep4wOP 8acoRtFpX/4D/PuWoaL3b/npr+GhBJHtyRlUwBjbgHIPPsearSJnIXqOm8Lxzz9D26nvQnTb5Zar r/wPX8zKUIW1fu2S3636feY96rJCR8uWYAqcDIHbj+f+FUbdfQKrllDgdA3sewx/IVo4yg00tVdW 9FovTv8AcTqql1FPo+/e3l5ssAHj5iQAME5B5xwB07gk8dD740raIKoOVGAAOiBR26j2HH4+tYyT UZU9uZNN/f22f+bRrTvqoPRf5W/ryuWQgB4I+Y4Oc8D6/mOlWemBkxlSG3AYbGMdB346470oN88r W91fjb9P0XmTKbjU9mla3+V7/fdFuHpyOMcdfoM+n0rWgK7lHaM56n5QPpXoQW2iV+nb/J7kztyW cdtHbtra3r/keTfFHUmzBpxACu0bI5C7QSSBnI4x6mvMLRVhPzMvDbGX5QDnqTj6HP19K68W0qOH hFbRd121MsGrV6mnLFv8l/weh2tiqFFHGducD5SqjHQ4z+vfnpXRrCTGpV/kkwMltxRTwCO+AfX8 6+Yry5JyUVe609G/81+Z9phofu9E3bT1Rb0c6hFeeVKyT23G07MOikgEAdAcY/LvXrVgB5YbaOhY jkAAck9Mdhxx1/CuKpKisR7isrbW2bV9H8vuFUTjSjza2v8Ajb8v0G3rOksbgZiJKsqDY46D6ccV qWqhIwSy7SwYE/eUE/5FdEleEOVa6a9e36tdzz3Nq1+n9X/TTsXowPMEowOgDDC4B4P+TWiAq8bt nzBiMHA6nscDOaSfJJ+z3W/lb/h9+9iXNWUVo/06ETifzSvmZXaGGDgj34HH8PXrioMPCNrHJ5Kb uCAeOD2711JyT92KdrO+3yBR92NldL8X0M0XMm902urpkq207SMkdT65/QUgnWN0JzlgFYYACntj B+v+euE0ueKSSk+z6a3X32+ZvTV0uVJeXn1/4BYSKMt8yruBwrD72OoyW+tXQ8e0KP4uAGwDgjHb p+dZxak5TjpbT0WmgLlcVG2q+7bdfciJgCpGQu45bHA6AcY+tVCDtMSyjYPlyTyowT078/TGDxVw unfm0i27vo72/r0BS5XJby01/Hofo3HyB/D1JHI/z/8AXobsOhPcdBx+Vd0lJSstLL+v68zxIr43 F2/S245D049sE4HTv27VOoG3jI9MDHX+VS9EtLW/r9RxfK7X0f4MkQnacHp+GB6VE3HGOnzDtwfT FZy5Y2S2/VjSSXb8ADcDgZY56Z788/jUQ3Kx29G6HA/n/SobXMnbfp18vxSLhF+lth43DPr1HQY6 f57danjPTbx9cgjPpRePN7unK/6+/wDUbla3fb0/QuJkEZz346YPrWpBgADgHP8AicVafL8MbXe/ 5kfDrt0Ny3yE9cAY+nHauQ8YrjTZTjaBjJ6Hk57dK4M5UfqdVt7JFYayrU03rf8A4c+Z5JTvcgqR ufjODxwM/n+Yqp5vPGBtGMDtx1H5V8kovljzLltb/L9Ln1uzlJafoL5g67iCp579R19qUTkHjJGQ B1zk4pNOLcHK2+m3Rf8ABBKKd9+W/wB//DMtRXeMYbg53diD68HitBL08fN0wp5AJ578+nsOhprS y0d7r0/rcVui0XT8Lkxv9oxn37Hr05xmmrcryAcYKkDBbn6U3bmXKraaP0t/XoVdWkr2vf7/APhm Ss+QBhR7jOfb26etPVmUcjPccgUVlFq+1vwuZVKfu8yWm3n2/DQsQsVHYDPAHJB79PrU7MVGP7w+ mPXGPpXkVqW9orX9Tyq9JK3T+v8AMzLlAwOOMnqRx06dP85rmr2EjJUcqOPT8MVyQi6TcY6W116X 0+W55l1Ce1vU468t13H5SCTwOg5Pp/npXNXWmZJKjkElSozycj0x1waqDlCSp3su/wB2/wA7sHJN +7ZJX/r7zGNgUcHyz97Azx6nvxj24qKa0fqvbt2HXv8A56HrXYqu8uZ2X4LQiq1aUYqy6+SL1jak EccgkqQB0znoOvGR+ddrYKyths7oyOgxwSMfr2p1uWcbRXXp0XRfd91jgrRlypJ2tr/X3nYWrrt5 DZOMEjBPqOlPmijkwpKxZP3z8qqfXjPfFcbhJTShq1sul9zkcYwV2u39fmWPDVtbPrH2K7jjuYWi fcUfIAIByCO4BP41Q8VaTpWm67DbWBkHmTFXhcAxxk7k4cHPtjHcHNfQUMOp0qVVNJ3acX69Dppx gqVR2vyySTXnb8BmmeCLjVtfs4YISFkkQEIS+Rxw3PAr9KPBdm3hHw/aWMlsVzAigIp5OB/XNe5l tlLl5tn2tayOj2XK5PbS36nm/wAWWe70O++0wPHE0T+UXBCng8ZP1r8uPESIl3PwgCyOo+YHqeCB kY/Cu2rLmqykpcySSXl0O6heFK+1r+mvkcDcFMkgqq5Y/eXhiQex5PJycc5P0rPLEEkLgD5ierkH vzwcdfXIrsoSi+SUut99NtzOrKyi3Kytb+vTb7iDceFCnscgDOM/l/Wq0sV7wIn2KM4wQGOCc8fT PauppwleycdbLuulvL/hzmb91pEYsn48yVs5GVUgE8/d9vT8PU4qcxDbwDhcYG3IDdemc+v5/klJ rnute3RaLV+fXTo7dSeXT11/4A4jbu6Dd2VScHscfj7/AODSgx0wFb1AwOASe/t+VPljGL5VZrp1 tfT8xxaUXK15P8NUv69SMIoyNpxjB4xx7fnj/wCtSEEHPyZU5wOm3t364BBI/wDrUnFWUlK1vlb1 +5ffcThrddH/AF97QhUZ3MoPt16564/QUBDgDO3byMgBcHH54/8AZjnrwot2ir7xtrt39dU38idf S+3l/wAPYTZyFG3v3xgcEZx0/wA8U4ptOTkbSRs9v90EYx6+31rV83JpZXvp9/336dipLklyp28+ mm3z/wAxhA7kcndkjHsTnk8dfwNRsoGSBj6ZOBkjv2yP0o5OVJqPa/32v99r+QuROyjp1/y/4PqJ tA+XA6ZVSSoJ4wM84NN4Uhtq5xlf7oHr+gpLmSV1aLVvR6W+6xpF2fZWd+/9OxHg7W6bSMsu0nue O/r0P+FBUcYwu7gfNjbnAbkHjr0/wxUzTgmoxTad/lo2rff8i3q1JaW/4d6L5jMjLKBggtlST7jP v9Bng+3DcbcAKuFGcnGOeSM56YzQpSUqltU1pptpovlv80ZNva11tb79P19RwHU5QjAGD2OQMYBH HuPWpEyNvKAEZ4yTk46BR25/M8dw1FcsYyaTv6ff+CXT7gk/4cd139f+HJwuM8D5sADG0kcDPXr+ X49anQ7cY56E9h3Jwe3IP51pyKL93bp+Dflppa3miWrXi9lpt+P5kyKCFUrtxuBHAKjt/Lrn+dTF VxgnB2oRknr6Afh9OapuUYfA4t3W+hVNcsbXcbJf19xGQBxxuB56jjI6+h49jUTqAoO3aTkkjAwc YwOM+n5e1VayUYK19LtefbyvYtXjfo18rdNvXoV2j+UEfLlcqCBwANozn09Ce2arOF74UEc+jc85 PBU/lnB+tJWaaUNI/lo7/r+BklFRvy76JPv6fP7zn9RC9AADkH0684A9OpxVS3J4z/e6EYzxgHHH tkf41rOShTVPZu9n32tb8DN3i5adfztpb5k2G3BSAp4zwACB36HsQeOvGO+dWFf3a+p2ttJ4yDkd hxz/AJ61z2XInF+8lddF5X+Z00uVKdo9LrpZ9Pu7EnCuPlGDxkH1xxj29/rVrDZVeOMZxjJGTknj OR0z/kkLxq90ur66a/qyHG37y9kuj+X42u/mXYP4cnaCTgfdwMA9D154/wA8WvNFunmMwXhmLElR z1HHsP1rtorWKtZq97eX+bM5vlTdrJfgrHzx481pdQ1PyAMi2wCSckMSePT9T+uKwbNGeP7oK8FS Nox0HI7dvSuzH3pqKT2UfLf/AIczwal7WF9k/wDgfjud1ZQqEhWdtvJYEjaeB7cgYxgcjn8+0toQ 8EOxhhMZAAJDE46D3Gf1r5Stze2gtk38l2fyfQ+2wrlCCXW6v92j731t8zqLCxigYMrKu5svkE5z jA6/LwK7mzXy02KBgjA4IAJzuJH4/wBPSuWNKXtL7Nfj0ul818tjPFSnFRajtdNf16/gxt4I0eNi QoOcjqpGfvYPTINXBCpgCbjhlwu3DdeldlvZcmmrjey62/z/AFOGUY8qV9US2sbQnazZ6feyM+vF aZ2bcDGMjAOTn2647UnJubajy2/XX7rmU4pSdlqrfL/geRW8+PJOTuBAIY4PT061NJt2gt2z/vD8 eOnP+eK1u+V9Xtp06r/g/MuM7Ja2S/z/AAd7lRY180sWGOgVz15J4z15qMwo7hGG1eqEKB/DkZ/u 8npXO78ycbJ8vu9Pue39JGvPFckorbXT5JfgWgvlD5cbAM7hjPYHP5ge9VJDI7B0jZdmflJwuDxn jkYyfzpRiqKhyvTXbfXclTS5bR27dN7/AOZKrjy1wuHUEAHg56d/6c9OnZichvlCOVydw7k849OQ aiV+RJO2tn5b/wBf8MU/ilyq10/v02P0YUbX6cZwT/nr1pJ0AwTkemMeh/zivTbcXGUfdvpr8l+R 40VG7SVr/wDDf8OQrkccY69+OvarHRflwB1BBxxSm2m7r+t/+AKdm0krN/Kw5CVBIGMfQDcDzTXf 7o7ZAAPY8Vm0m30W/wAun4l2Suu3b5DiCozxjAA9x3pYplTIK8cdBjHI/wAKnl9532+7X/LqFnZK L2aHq8e4qowDn6446VMqc/Kcd8ccn60oxUWvPp2LTV2rWLcY6ZGMfLg8AA+np9a0I15XGQO/9K25 VdWewm7W00R0NmpEeOcY+lc14ui3aXc4HCjI7YHTp+lefm8Y/U6/u20/UMPFe2p9NT5HnbbPKhJ4 kbhSAMZJ/wA59KgLjkZ4XBHGccdOgI7V8lePs6dn0WnZ3/4c+turtbc3l0SQ5XC852jBJzxyOPw/ +ue9DOAAFPHH/wBanOOqlUXW3p/WpVnfbbb8hpkYAc7cHk7cYA4I9ec1P5x25GQOMEE4zk/4nn3q Fyvm923Lb/hy2lqtun5jTK+M+/Oe/XH+farkDkAD5sryQT29P8+lXC3vK3LZfj2/L8TJO6tbT+vz NeNmAUDJHYDGe5zj8h+FaUUXQgdeu0/gOPwol7qUG9Xul/Wl+g0vO1tV5ev6FsRYUFRxnGOn1H9c +9SGMhcDjj0J/L8T+tck6S5W5K2+nn2+/fyOOvTUn2SKzwtg4GevOAMVk3NuGz8pAwOOBn1HB/Ku WVJK6ateyt81+B5GIp8jSSt3/M5e7tFDHAxj+EjA9uMVkvbAMV6gjPA5/LuO+KwqU3GN7pW6/r92 x5yUoTf9alB7JSfu4wQM4x+nbv7e9U59MCjhfTG3OPoB+NclKc4tweib+7/gb79w5m1aWiW3l/wR 1pYbWLKuD1BIx8wxn9ARW9a27F1yrbMgFSp6fX/9XSuqE4xUYxdpa69P600OaSvG8Va+7f4fetTf gte33R14yB79/T+tWLi1U42A5AwCQAcn6Hjp6elXZKanHSzu/kYSioy/rc6bwRo6T6gZXPlyRMQP mO1gykdfxrM8VWETeMbMTkrbPcxiVlIBSJnILH16579DXv0I2p4Xl0Unp+H9I2pRcMLVcW7pr8O3 3H3d4PuP2ffAGiWmoajrWntqf2dHkEEN1f3pkIzgEIdpJU8EqKs2n7QHgTXNWOkeHdJvpbPa+241 EQW5Zt3PlqpdgO/UcGvvMPkNLLsHSxWMxMY1MRqotpyd9dIrZep4/wBexFfFrD0aMowi7c1rRWvd 73OH+L/ju9XwxqNpFpGlSWksEojM8Mk08QKMAQ+4DPPUj0r8pdaneS4kE1su/c7LIA6uoDE4Cqcd CB0OMDFeXJ4X2s5UFKLive1VutrLz6n0+EpVadNxlO71a+eljjJUAb7o6udyt+g/z/hVTDDgrtPI J7Dg/wAWeOn612R5fZpRhbb8RVZ3t7u35dfv2GkKMEYA4JGNpY/0z/hUpC8M3ynnA6Y6/gM5z+NN x5oxlGOi+y/z/roczXbS/R7pETpwRyRkcZXkE88Hrnnn3phDY4ONuM/e54Yn0/PnvQ7SfJZx2f3a fdpczk30ulp6vb+mNI2kL90c8ZYk9TjPGPp2/kxVIIOBuGBtIwMH16/XPpWzTtGUU35+jf5aX8mX FO6cdH+C6tfkNIA+72AZVLYCgZx79P1NMC9MEMuTgbRxyc9ueRzTnblcLWsrvzSV/wBU/kOTTbjd K1nbyVrafO4cqowFXjoe44z05yQD9M9+6gN1wFzkYHGAOAMD6/jWc5X5Go2Xl5a/qvxXUULct0t/ v1/4awwLsAAwnzcE5AC8ntz0+n9aGJJG5i2PvE9ACeOT17d6cbzjJy0b0Vtk7u/4W1XRspxVtNNr df66feIehJGAq9AApOOSAo/z19ajIIG3BUkfhnJ5APbgce5rWLnG1rK2luu6/wCCZqNvLz7Mh5UB c8ZHGME9jjOe3OKaSRt+bgDsM84zxnoe/HrxUKdpe8rxd/k/l32LeiV+vb8/nsMAwSNu0fN14xkZ PX1pBtXAxyPlXkZwcE/Ljvlffv8AWOsmui/XQFzc23XRevX5DAeeMj7oUFGXIOSeRnH8XX+Z5Ujb tJxkEYOM8ZHT8j+ODz3tqStry21+ev8AwPu1BNr3I6W1HYOQApUDd8uQMA8DA+h/zzUygg7AeAoG DwvOTj25qlF3jJK3NZN9PdVk/mvyM5c1krpN32WnS/p39B6sFJyVUNyFzyDjJ9h1Hp0PcgVYTK8D AJ6kgAY5IHTr159+1a6qcI20Vmumr0v8k3dGkYxW2q737aXX3kyhs4BBXAwePz5Bx25qQZA2n7hU noULEZ4BHpzx7VE9lG973/NafPf5WHGDtf8A4a63/X8hj/eGD15zj1H0HTr07fnE2cAJjhRuJ6gA 4zkjvjH403zqMVHp+f8AVvTcHJSV1ole/fv9+pC46gZzjrwBwRn/ADx19aozYBB5AxwcerEfKOe+ Bz/WrSlrFaXta/le35fgZtO/xbbfnb+t9jDvgx2sc/KR1UncuF7Ecdhx+dVIsYJAIGB8qg9gQPqR jv6GnOMJpRUW7XfbR3s7/p1Ji5c6VLeP+b/MlCsG3ljngDaqhmAOcjsOP61qxjZEPoCNufvADjPG OmcVlJKkqW9krfla/wCXrc1irc6vv91tF+iRIoCuAVAOSNwwuM8Ag4+nX/61aGdoUAHB4D/3W9+B 3P1rSnFSk4ydna+1rN/8DT5mk0+ba7WunXT+l95Z+6flyqZ2kbiAueMEnqecfWuR8b6s2kacGXkz ZAUEAdMYxnnOc5Nd+DilUpwaV1d/c7r79TlxD5YS5Ul3+/Y+cZZpru5a6kYEktuIz8oJ5GeuMnPF dRpEbFVwwxg7lLA44GRnA4xkDnsKeMk5c7Xkn5Bl6caqd9b/AHanc22FEUfDBcoVY7ShPce3I/z1 7OwDK8KBSFwQucc5OccH2Iz718xivdcZN35b8q/L5as+2pq1O0d1ZJ/LR/1+p1kJKsFOBx8uBwc4 x1659PbHtXWW8gRFx8pKpnHJ+n64z7e3HJSlLnj7SNrb+Sf6f8AwxN1C6fKm1r66fn+ZG8Esuc58 vsRgHkk5yefTpWpAp8pVwV24AB645zjHbHNdd3KdP3bW2XXb+vK557fLKFm/+CWkhyuAcHgjHHse Dz61KIJA2PMIwOexHcdP89KrSPxq6v0XrYcmtZXe/wCulvwIJIT5mNvIXqvDHAB6fh+tWFTld3zD aNvG4qOO/wBf0quVwfJFaNLr6u/z3t8hxfLGK0W39eurGXADoqxqoA43Dv07AZyP0z70ioWQx/KS QCDtx29R06j8qycFFRvflg9V1fT/AIK/4cpLl02s9PT+r2IUjdEYd1PPzAAt6YP49Py9IzNIGTEY C9GK8BT+XTqPwopLWfMkopO3la9vzsy4tpxUV7q0/wA/lqWNylwxO0f3gR1IGcj8R19aaPnPspAB UYKA84IPfpxxWbjL3XeyfT9fxM7tTdl5/i/u6n6HF9rAlsDtgdu3NK0obHHTpngZr1JLmjHyf3f1 +TPJV4v2i6jCpDddvIwOgx/kVMhOPYceo7//AF6l2tbbf/Ip8t7x3/CwpJHuOT0x/wDq60xyeuAQ AAMYH17Vi47W0t92n9dQi0m+bTciEh+VV+7wOMfp6dKkUDjnj05Byf8AOaUlKV3f+ug4N+6krf5j gh3/AExjqf8AP/160FDBRkkYAHPH04/z1pxfuwi4/wBMtLlfYtREHHOCMYxwf88VoRgrjtgjHABr T4Wlayv16a3/AK9SL6tdUdFafcPb5eOOMVieJE36Vdg9omIGcjj2NcWaNfU8VC20fw/rQdFtVaXK tpW/E+N9QQre3C9xNIDwODk9qqggH9WA4wfb9a+ToxiqUbPVJel2r/15H17av7yJVK8EHjOBkcjB 9PzpxJHG1V5yB1/Efz/Cs7czUpf112+77ium+yvb5EZkHGNuMnOeMe3+fSrMbFVKAHryTgZ6EcVU E+ZtL3evy2+7UiV18L/r+vzFEYzz8vOQCQQTn860oYzwMcDjOCCR1AoUbK1k79eug4t2RrW8JwGI OODgYByew/QVtwx8LgEYx0HIGR3/AM9KiXuyTte3+VgtvbY0o4Bj7uMDAxUxtvQEduMD88VUoXtf S2j/AC/UmSupRS2/4b/glSeAgEAD15UdOnIHTv8AnWLdREbuBwepUY7jH8vyrN4ezSt6evQ8yvRv eK7X/r5nMXThexx0zjHGf881hTOm49e4GCo2nBH8yP1rkxVP3E0rK1tvwt5bep4dem4NX0aGK0W4 L93ac55PB/kefapWjTYP4e/B5Pfv2PSvCqc8W5dVb8G3/mjkhNJ8rd9fwY+CHnA9PTHfj+laUMC5 H8IK9Aeucdx7Yralbksp2d9fm9F5afkRO1kvh/4JsRRBVAAAPBI6gf5yetW5EURg8bgAMEfyxXdC 6916X3X+Rm+WD5Xa36/8Nc6DwnIYrqVU4ZSsqg5wQrAMM9+GNZniVo7nUsupByux41BdCGbOeeQc 5/KvdhOP1WjrZp39Nv8AJ/IuFvZO7aSb9TJ19HmhticqVRQNxzngZyPwq58PllXxDZrG4X5wOu0H IIIz9CeKp4qo8XSkpt8r0127Jen3CcWpJ2S2+9H054n0x7jRL+K6PmRm2ym/nBI9a/NbxXaJb6jd JuCiOaRRgd9xHP4fzr2qblGtGpa10m7eXl5ns09IpXtvbpurnm90wVs4AVT8rcFcHg9O2ef8ao+a g+6B1HOAvTHHHX/9VexC8IJctlHT012+W5y1Vy8ycr+Xl2+e9+gGVQQd3GeTgj0wcDnvTRcJ0Bxw cLtOVyecnp3zXTyyajKK5b6bbW/rTyMJOV4O1tX8/wCunkN3ryckf7QB+7jIxkc8f0+oaWGw7fl6 EEA4A9Mfn+f0qLWSau0+qtt6+v6roJygk73/AMu2o4nLZXYSvP8AdySOeAPcc0z5cE5BBUZGO4/X nHpWkW6aco+enlv9/QST9yytf/LW/mRY6AAoAwUk7evtjr+dJjj723acdgABnr0znH69+6pprm13 tp17W+7cqyTbjpr1+639eoH/AHvYHJVc+4Pbp1xjBoPygfMPu5IGF5GSM9+mO+KfKoK0NUt9P0+4 SaunHa+q+Te/3CHIHHbbwQAM8duO2elMIwARnA+XI6D0yRzn29z6Vraz9xe6una/9ad/mDdoOytf YbyQeWUAgEEdePw9jUZP8IPAHGMcdD2P1596xUZPkvHV3v691+VvmJW7LW23n/w4zOAEKsSCCc8A KB6c+v8APPrUbr1CluONzHpwcHB69Ov4c1MVBykn7sYffo9vSy+4IrWy91rXyEOMOWJ+XK8D+EZ6 gDrx+lNB5B3YAz8nQqD3yRnHTvR7y63stdPJ7fMucrNW3S/Aav4jJJOMgK+Og7cEr37U8bVw2SpX kEgbsEjGMD39+9XJNv3Y8qWl+ut0/Wwm9pJWbbXb+tyfeGjQbEAUHa653nk5UgnB59uwHGKciZwM bgpO3LKDgjpgfifw/Gr5lGcbfDHy0vslb+tyG2pe6uW35d/xJBkDGBjgjgZ4yenY8fpT8spJyBuA KjCgHGCfx69M1ctlJK7X2e3X+vIpL3W4yST+649TyeqkfeIPoPUf5yT0qVQFwecKMn5TnJIHU9ai K+JdHt/wPTcFza33jZvys7DQcYAUqM55YZ568enUZzTQ3JAzgDBAGAOx4X6Z5rVxX8KOjTV+l9r6 +ewcsYW97lt5df6/yICMtxjG1hwQPl6gHBz6f981QmU4CgkAFioQDb144PQ9/wAPbiVGV0npK9+y trb+l0InyqXM+nbstTEumydpycHChguCDyvQ8jjvUKL1yCNwPI4YP2OOncd/anyqPs91y3vb02+6 xMZLnTpu1ld6dNV/SJFYcLyDzgchcHkYAOfTpyf0GoSFA24ALLgfdJb+Y47+1ROnJXS1Sve3rp5b 3ehrCKjdLW2n56/Pd/IWADzAGyQrH5jyRgnqT3GPX0471sKvBBG0dT24464HXH44qablz8zTlJ6S s9vL1skyp+7ru9nbRar89dxSwUkIcdSFPygdew59Pzrwr4i6yks62CEfJltvT5xz3HHT8hXsYSEb 1ZS15Y3Xffb8Tixb1cVpZrX9PxuebWxyflUgEjKnHQcYB+ueD6d66zSFZpljUlWUMXAbaGXd1GO5 PbqPwrmru0Ze7ay/r9PusdGAsqtNbX2fmdnbxtJMI/MIyT0XgBh/s9T6fWvQNPV0MatyyBTuCYLL 2Oe55Pp1r53FO6jFwtpzW8rP9UfZ0Xy07yV9em23byOqiK7gVCjGBt28p0xj8c9x1roo87AR/Dgn A4HHHHTt+tcseXnXMtNLJa9GrfLf13OWvGXJGF7+n5f8N5j0ciRUzt3NkEY+U+nuP8BWmC6ABTxg jH3RyeDgfWu3mk5SSVtvW3r6vU45R+B7W+7vf8BwkZcruwuVIyANpx3HX0NWo24yWGOOeCBwOBk/ 5zUOpdPlV1p96tt/WxTSjFLmtZX8tAZH3jI2hSzKwyABg9fbBP8AOllZuTGpEmOMkEYH0xWq5eeL ba0V+ln6fj8zOzi1Zf5X6FfcdqnlSCcjaAB06A1H5hi4YkhiwX+9jgA/XvWMnzOXu8iu9t0t/wA3 p5Gz0aXXe3k/6+4gVyC2GODycHIyOnX6k5py3Sl1h/jxwT904wc/r/nNVblVRRVpLX5NO9vwQlFt uMZXe66dNfQUsflBwrNwqkYBHsPx/Dmo5cxlVRsNtBPy5O7/ADx/nnNJKS5vsr5FRXK4WW7tb5X3 +79T9Emfb656YGAR7+1Rh8Fe3GBgV6KX2oqy/r+keM7Xstlr5FgHp7Yx2wcUofbgZ79ugxStFNLY dpcto9P6/IejEkjB9iDnvxSysBxjsAMcfjisXF2STSt/w/46+ha25b/L+vmQhPr2+n6UobaQMj9a N7pP/gDhHu7FqNxxxzxxyMVpK4KAHjaOOMfyquVJJN21/wCD942lda2sORNvTIJ4zxwR/nrWhE4H HPsOnY/lj0rRap2Jnvva/Y6GzY7euBjgn26Vma7ltPuhnH7l+MYz1rkzJL6rWfLa0X+KFTsqkel3 +qPj7V1QX1yAMN5zZ24K9ep4+v8AWswLg4UEHkYAIyeQeTj3r4+koxow5JJpWsutuv8AkfX2so62 vb/g+hIEbsoUc5U4OfxP1pWQgDttye/bNTZKPLa936adfwKhaKYyO3aRtgJU4Oc9D7enetqbTWhh Vw6/dXKjcGJPUjsDyDVawpLlWj+4lyp8yj936/kNihIZTjAXOD7cenStWCI8defTA7+lQlvZdv6+ ev3eYWtL3VZL/M2reLgfhntWvDEAAAOO2R1P4VK1aXb9ei+4dtraX/r8i/Gi8YxgYK4yOParaqMK QMdcn7vHt+tJ81r2s+nlbyFf3dNbEUkSsDyM4zgZA6/oawbu32ocD2JAPBPTiqVtYtWff0f9MylD S+1vvOK1KHZuxnPJGQBn0zj3BrhbxzG5O4gDjIyMfh+JrSUIyTb3s/lv09TxMZR93lStb/hzLF/h lG7qSQMEcY9R9c1rwXilVG5gcZIJ5A/oMf1rwMZSs5aWu/w3X66ngySTflpp5djRtruPdjr9RjaM HOB2rZilQFcEYwD6emePz/KuWinG9+jV+/p/XcbacfS3+f8AXqblq6lkYgEAj5SQSeRx7cVo3ItR gWrMynlg642YOcfzr0aaXKp81raW2dm73XzRmopJpu//AAWrr8Ctb3E1lMJYMqy/KMehHIx/ntVt riOTdcyr+/PJXHy59/Su+nKMqcIytFRfzt5/11HTupNbRl+D1Nzwz4Q1HxxdNBblVW3Kho4l3Oin ocnhRjoT6dK9jsfBHw18Az2uoa34u02PVraUM2n207apevjHyGO3+SFu3OMda6sBlOY5jjk8HTtC nq29Fy3WreyXqFbE0MLBSmrt3SS3b6WSOg8feLvDieG7m60hWW3e3bYLiRRJIQpJOBwnsMnFflh4 rvJ77ULqZY1VJJXbaHY4yTg5HJ7V9ZGgsJJKU+eSVl2bWu/z+Z6GHdScFK3Lezt91v69ThmjxtR/ lbLcds5Ocnr1OcVX8uJSflAI+bCuMk9eSM+4rtpOUrNbdNPLf+vIUtJe8rvq+2n9IURqAfwO0njB JHXHv0xj8aGVQvC4UD0K8fgOnNVGcowi7OSTez27afh+RlL3fdtZLVW8+iEIUfwjDZGONoHb3HHO PWm4xyoCHA4J4AAxnHTPJ9PrTlK2sVZXW3eyX6shpe5Z2TX3NP8AUhcnB+ZUwSMJlQQeTz3+nuPS k6kZK5HPBPzE88H15/UetDkleNra6f153/MEnGzTatv02uKw2nAPQjGTlgCc9vbP/wBemjChvmy2 MjcTjHbkfyqlOTcpcvZLy0/peoNe9e9tVp20/RXAYyMj/Zzk8nHbH4dqNwwM4xuHJ4GfX196aSSe ui1+a6X67f5g/djLotvJaL8xAELIoZQdzDJyowO+R7/z9uFlilhOGXa2GwQemMEZ7nOP0zQ5+7GM XfmWnfz/AM++409lHS17X/r+kQlhkHgDouMn2B6fXt1NQk52/dxhsBlO70z7fQdvWqlOSk+aVrXd vlZD0Tjpa1rem5GDsU5x9/03FFJIGAB8xFNzt3HoOnpjHPX15Pp1rL3bum2nrdfN/wCXTpoDTWt9 7rst3+j+8RtynBYY2/Lt7kAZOPy9uaZwGBDjacqApXHTOT/+v/6wqfJbmjor2d9lfTX1f4eYKEk7 aq36r9EKuBk9CAMtsI+Ubs9BzTyWweq8ZUj5cEDt3PUdeDmtZTkovllZ9LfJ+n/DEawi7v5ee/4f oPAB7kYcjcQEwCcjH5irEecjd8oVT32jPTjkgdB+la80Ycyikm91bZPW1xtKEVZaJW+//PcPM2nH oQGUcY7HgjI69qcGXceD0wDznP0J6f41nNJtyvo7+XTX9FqTDlv8N0nt2Wl/v6W/UenG3HQEFSAB kkheueeSP0+lTfKCN3cA/N93qAPTHTp/9eqjzKMeZ7Wtpr+HyNbJxenLtfp3/N2Q3eAAOMcH17c/ XGPTv1GaQKSN6nIB5VQVAIz298kfhW0tG7Pb7/X+u5MneL1tfr8tF/wxXkwAeAc4xn5Sp7dOnT09 KpzA+WAGwVCnACj5T05HPf8ASpcnaOvKo28/L/gin7qWm9/w2MKfBYbiPmyOcnDdeR7+ue30qMfd 35bdhGAzt2tnnOPrjqeM4pVJySXKko7vTdXTdvlvfUwSnG1v+H0+7TUcMBiV+UseOCAo6ZyOn0/w rVQLsRt+0hTwuBxycH06YrJe4qK2Wq830/G17PudUEleN9bt29fMfb8TLgY5KljyBjqQCOOcc8df rW0fTp3B+bA6dgMcDdU0VOM3BJJJ6fOz/wA9zRRsvhstbeq6fN7mDrOoxWVvNmVY3VHIBbbgDkn2 5Ar5h1a/bUr+W5LrgSMisM5IGenHUjPX8a9yk3Gg21Zv/gaf1ueViVaUYqXdv5f8AID5aKSRgsQW JIye3KjP/wCv2rrtNIhQMFZzsA4U7lTjBGev69+vbz8Snyq2nNt5dfzO7B+5JT3SWn9dztNIaNrh PlOWUEkE7fvdefzI9vxPeQzPuEW5cqMBgQ6kYHf/AD0rwcUlzzk43cUtV2vZ/wDDeR9dRlHkpvbl evbp+eqOg0+UHaSONxXOMAHp0H1H+FdSGEUY2hhtGMEdOeuP89KwoqPMm20op2v/AF6bfMwryULc ita9vz/MichnAB25wyjBG48c5xjPA/Wr43DacHCkbdowTg8cfT0966eZQScXy3sv816f1Y5XBLVO 3K728/Q0PLiVNyYDNgMuCPlyQce/Ofx9qmhC7DICduRwckgg/wB0gcY7mqh7zirpL0tr+mxF2+Zt f5dfyHknoAMdicEA4IJx6daV1O3O0Y6jK4we64x/nFKMu78u22332DmirpdP02KBO6QKhwqkZUsw HPuOmSarOFwQzhSMhT/dfOcAE/hTTXO0tOa3332/r9SlF2j76X6f8Np8iePhSJGACjIAIHy9efrj 9etUwu6dtmMcjsGB+n1P6+9YRUacakZO9t353/4Z/gXBWm0lqk/yWvyNRolURtnDKBkjGOevJHTk flVYE7pC4Kg9DtHPqCe3XP4ChRUoKTWjVrfPX8AWicOW0Vd37f8ADH6DOw7Zzzjnr+NMDAADgYJJ 5wOw6fhXfyuKULWt/n/wTyGrX0srf1oTLjI5HbA6deeKmG3BKgZ4zzz/AJ60O9lpayf5gpNaWu39 3T8iwihRuGF9QcDikYegHsBwTzzWU1e0eWzV1+X/AA5cbX9F9wwHqPZTwBgH09hUDqQRzjHQevb6 1E46pJW19P6Q1pdfcu3csROFwABnjB5z07VqoCUXAIwOR+H/AOv8q1WkW7Ws/wDP9bfISTcklr/V yVCVwv0746/5NXYUPXpzyDx35q4dHFWv+QnFpv8ADyOjslAXaemOP89utZ+tf8edwo4/dPj0xg81 z5hGf1atfS0b+isKkrSXMtn+bPkrV4GGo3JGATJyBwOmfwNUVtznGCTwc9cDt/OviqKjGnT02++z urn1y1Ubrs/UtC2XjGQAM9AAMkU77Gc9OAOAMjOenX8KJRslGWj3+Wxa0ly26/8AAtb+thFtXByM DDdhs69B/P06irQt5MrvJCjjg4z26D6/oKrncafsrJL9d/1sDir3t8O3+X3v7i5HAADxweMA/X16 VowRbdo4GOmcDjvz+NZtuaTUbJ/hp/wSuVq6/DzNmCIDGV/M/wCf8iriAKMYGMfLkng//qocVdta bf1f+tybPXbTTsWFPHAAH8u3XpnGKlVsYHQ9+MZ/wpW0TWl7/n+Yo2VlHR2EJwODxnOOAaqTIOQM YPJwACDzx6VSaai1rb/gIGttLf8AA2OO1WEYJx0yAw4PTivM9Ui2kjG04OWAyPfpwOtbRfNdbev9 W8zgxMVZ+7Z2OJuJDGwXK55BGMNjPAAPX/61WI71ljUF+dvyjIyv1/OuLE0U4Nctnt6HzeIpODfI r73tp218t7mlb3vzNzjADYbrz1xn8T9a6G21BTheON3sCR7/AJV50MPq5SXTfZ/1+hwStFLlj0v5 /wBW3OksrtSY9vUFcEEDn1/SuhExlP8ACGHbAAIJ9vrUxSSW7a0Xe9gUmrK3L/X/AA4gByBggrj7 vr9KrXQkyAMr2B6Y69u3pW/PywlK1u1/O1xwTadtP6/4BnLdanasYdOmuI2mG1kt2kVpCwxt+Q/M eox+lWLLw3rlvfC51Gxu40jQyFZo2XJxlT075WvQw2c4qPs8uVfkpOS0Wl+12t+m+li4YaM5usqW qa1+Zx3jrxbeNJJpwuGjtYSY1iBKrgcEkDOO5NeFXl1GWI3gnleGAHB4GD7V9hFyqxpqySirad+9 /Wx68Kcadvx+X9fgYU23jIYMpByhPQg45x04/PI+tQgBiAvJ+YAAjAJ9MfU/j716lJ8rXs7b2fzO SrFKTcXs9dfOzG84yeMNgc/Ljjv6dPzNIzYPygkZ+6uCDzjIH1NJJLljLS22mi/r/Izej0vdrRW2 G7hg7cKCBj7oxntgf06U3PJGQOOfm5GOe/Tk/wAqqCvG0YpR3t57v8fyIhJJWe628/T5vYjJGcdR tIVT1BwByOmDwOB2PXFNdhngBRkMQdvGcYHqP8afLq5SSUldJfr62tcVldy2SuvT+rahkHJAHqMH C7TyCfxAo+XbkcEYLH0PHQZ6Y4pWuoaW5tui1d9fu+4HBL372/S63/G43PYZwBkgPtwc8g/n+OPy TLABduOQwDEKOOeuMYyMnP8A+scbcyTt/wAP+v6ilLmXJHRX/TV/11FxweNvAIbgA/SopGPBO5tv qQpxxx+JA70kkk401bl3fnZXf6epXs+VaLbRa6+v5kfVTgDg98cADtjnknPr+dRAbQQVG0f3SBj1 znOR16VV1eMrct+n3u333/Ad+ZKOzS06f1fYjY/3cgb9zAY5z/LjPHv7UHgEEfdGOMYB6jgdM49u nFRypP8AhLfZvfTV/cTJciceXRe9+X+TQB8DgMFyBhto9uoPOcdOKYGxg7BgAEjuOgPH4mqSc37z u2tPv1v5XHNy5VaLvbftp1Hq3y7VTceR1TB6dQMnv79uKASTgBl4IIGRjkjr3/8Are1UoRppWjbV 6dLaWf49RtNXjbTe/q/68ydM7Oh+UAYLZ67T9ex5PNSgJncVxzlsg7uT/hjNXGVOLXuON7Lfpbr8 2K6jddX+Hb9RCFAwEUFeMPyc5PPHOR19OaBkN8y7Ngyc+/Yj+tXUUb8sVa/Tbql6JDSk6kWlZWXz vbdf1qWIhzwBheAF2lScknkYx16VNwuSDhgBtzxj6gnOevT+tEX8Fo2SvfzX9altK0mou2mvaz6/ IhzgDAJ4A68dOnPTjH+ercsM4JU5I6gdOTjHqP502pXhZWa1+V1b530+Ym0lHp1Xq9lbpsRNhvmO 44+YN0XkYIxkfh6VBLt2kjscDHHb8/Xn/CqjZSUZQu3366K3l6eZmlFSSTtJ/hu/009Uc/Mn73Cj bt3Dj5tpPPGeDgAgdMbgPpGrNkjbjpwxI5OeR09e2RnHXNPnva+i6rTRO6/r1IjJKCfZW8uqsOQD gA5bdwAOBu4OQMDHHX2xWqqjygMfwYO5mJAORgMWyePU9PWuaLs9r8v4pJLT16b7m1N3ioWSte76 6WXyWmhZswhm3kngDo4J4yCcfj2Fash8uPkdBgsNg2LzjnqOvr/KtYqXO7K2t1bye9/W9+ho005x 6avTy1v/AF0PnDx54hlmvprJWwsbN91iuQMDt2Oe46V51GVVyS/Hbo3IPc9B35xXs1Eoxp0o9Ejx XJTqS6Nbeh0NoCUA2kL3+6G27cfl3zjPX8OlssQ4KsSuSApBwM8DPrwfXg15tbl1Tei2/T8dT1sK rTp2dk/+G2O30+FXKsrpkHIAO1cnJ7D0HpwetdZZCJ5FkZirqVUqOVY9c4zjkN/k9PCrey5qiTsk uVeb3T/P7j6+jyRjdR3W3bT8v1NzSXnjuXWRCkR2smQME5ORg88Y9Mciu4MrMg2BcBdu0kDPTbyB gVi3D20IxWi/Oy+9X/VHn2k4Qcns3e/TX+vuH2kayO6zELgMVORjp0x/DyMc9PpVyMMhZBnIAZRw QVOB2+ufy+laKMLzejUbNdun4/5mU0r73ur+V9v8xVZiGXaoKNgMcY24HcfUn86sxMUUjAA3bd3Q Ej6Zx+H5c1or8zjCOqauvz/N/gLW3JbX+mSyyEBXj52kfL1544OOlT/aAYsqMDBVgv8Ad5x1/pV2 ivZvl1s2/VbGbSjHm0SVvu6lZvLxvUBCOOep5GCMnrnr/Ss6f/WbD0YbjuOMHk8/T/CocVBX2er/ AK9N/UqMdFLt07X1/UcoKZORt2YX5wOmCfY9fahB5bZXGXBx8wyOe1ZSpqPd6NL1u/8AhzeVR8zl FWWtvmWLe5WXCZb5eR0A57HPb/69WVVH7YGMA5BGcDkZ5PA649qtwSTXNa2i/wAl+DM1ypWbaWn6 X+Wp95544HU/pSbT0VTkAg11uUk+Zaf10PKSevTvfyLUSnAz8oH0BHuf896uKigdCMY6jnPTt9aJ Jpqztd/prYb91a9S2kSgcn3461G6gfd+uP581lU0mrRdr/dqUrLS1l/wf6RXb5edvfPpx1/rUJbc CMHr6Y46d/pn86mW3Ktbfh/Wv3DtZxtrZD41A7HoCMcY7VrwDEPToOpHA/rT5Woyt/X9IPhtyuze n5/oWIijfN3XI9PyHatCNvl9Cvb2reK5eWNrJbfPYHomun3M3bE8H6H298ZFUdV+WCUY6xsCCO2D xWGMT+r1U9pRZnC6nr5fn/kfNeqWm6+mwuAW7d+34dqrix6cMMYxnC4B9v8A9dfEwcY04tK3Imvl 6fNn2EPh5r2sl+K/4Jox2Yx8ybR0GOvoO2RxUv2IdlXjJAxj/Pb8qFbrJpaLbbr+VvvZSvta1v6Z C9rGCMKQepAGMHjJ9qYLYJkFTtH3eOR1Hb6GsvKMbf8ADsbTUe1u39dxyxBD0yOG4HQe/b/9dWEU BgcHA9ucdD9OlOzjyxtZL8P63Hdq1zSiwFAxt565GO9Tjge3T1x+VVFcqv8Anto/+CwUUvdJRxt4 x2PU84zipFBznlfQEgfn+lKUdLWtchpW00b/AOCx+OfqOh4OfWkaP5cYOAMZxj9KOW0PdVuxT7J2 t+H9M5zULf5WwvuowSf8+1eaa1bDZJgEDkH5cEHpnH596qFotpq//DX/AK9DGtFSUn3/AAPKtSRY 5N3OflGcEZHHp19cVkm4ZRtwSOOgz+g6HmuyUFOmuv69vT/gHhYina6S0T9O3/DFu3uDnGQvygDP IPOO3v69q17W6PmAZIPPXcd2Mc5PGBxXj1qShbR2/q9zw5Q5EtL2/D+rnWWV7hgOchskcjjBPT86 7a1mfbHuBCEAg4wuODn+f51wR5Y83K73enq/P0RztyutLP8A4c14W3rnsDwRwMcjGadLESynHAHc Y4P41rNcsXF9Pu1sXB+9LlW26/Q9r8DeNfhX4Rs1u/EOjalqGpogLQ2lrbFDIuTuE0j5XkDnb/Oo fGn7Rdn4rs7/AE/QfCtjodrbKFguZSbu9nXBClyuxFHB4wf55+uy/JchoYV4zF4tVK9Wzp01dyVt fe/l87eREMVjPrdKhSp+zpRa5pPr6I/PnxPql/qN9czSCJd0jbvLiVVBOew6dznPrXHiMjlyzZPI 6/MO2BnuR+Qr1k6aTjSpct9Ne3TXo+rPdUJQglKWzv57lSQBSwGOOSFXBKgHv6ZAOKhJXJ+TnjBK 4Ixyfr1rspSkoOLXm+ljnqL35W+G9tPxGFSQvJ2gKPdMgAk8+nH4UmFxgKR8rY29AuTk/wAuxx+F bTdveWz128v0/wCCYaxte6S++2wzkZGPlPzoB29O4x9c8fhSBj8qjK7gMdvl659TnOSfeiNrNLWL S8vn92pEYSlvo466f11sRP8AL64BJ5xgtj1Hb7oz2/DhkqZYFjJ7KdoCkkjHHPTv9fbNT5aXLUtz PVLvvr+UvwKcH70NtL6edyNUCdMncoBwN2c5Hb1AGCPerUUYYSKp2uq/Icq2fXGeD29f50SlGcUl HVbdNt/w/INFe+60/pf10IMHhc8ZP3hjoTwT+fPNGDwdoG1gMkn1B7d/eohzae7y20+/b8dyEuW7 3Ssvk1f59vQj6AdWx8wGcKBzycdT2I6fzqJ+MbM/LkvwQW4BOeCR1JxVObXwUr/8P29L/caJx91N 6LsNYgYGcdRtxgY46Dt1FR9AMLwTnnnAJHtkHk/lSldcq5rpO9106p/5+rRFmmla8VrfzS/ryGjI HRiOPlBChXHtjjn/ACaadvIw2DjnG3HU45oblCTlba6W/nZpfL9Opc3LliuXfbzdv69bjSflIwyk AZ4AyMe3PbrxSAgEAs3Q5I+bII6HjPv1H6Uqb/ecsVZNPXa2ttPXRr5MSVlzSb9Pl/nYcCpO04JX 724Bic7ux79//wBdPXIwFXauPcgH2x+P+TWvLKE5v4lP8tPy1XYHJp/DeLt8kWlGBuVV6k4z347d Bnjp1NO2lcYwpPHPLAY6dOvI49zzRGK5Y6+9fa1tN+vzbHZXd10t5XauQkKpIGOeWHTIxg5xwe/X J4HtSoiYxjaPlAyFAAABGcdMHHYdaqSnyTfNsmr9GrKz9W+w3pdLRteitf8AB3uXYyRwARjBwOee nY4Hb8qkYcYxnaVyuADg478evv8A0pQX80lt91tPmDatvdvp5dP1+ZB8oBOQO5JynY88424x6Z4/ Iy2BlcEbssMDbggdO/P0rdWd32XzWm/y/McW0uy/K2v/AA5EwIBGSOm0Hdjv27d+wqCQnIB3dMgg kYBHr17mhJcq961np3111/NmM7qD1ba17Pv+v3GLcHazbSeH5xwemOec5Ix69KrhSASpOOpwRkfg cE9d2T+FJwfNBR0sk9dG1/m9DJWu4pWs/vXvbrvr6CRhuOMryoX/AGjuU5UjFauML3wFzuIxt5J5 HT26HrWF4QnBNWirrz6v8tfLQ1pXXM+XrbtZX/4BdsCS8hG4E8cDnOTnk8Ac1Lqk/wBl0+5lGVEc RKnO09x26fU/3a2w8bVrRd3p6bLb9Te9oymnpt8uv6nyBrM8l3qNxKADukkCYIx1BwSevueM4qGN MD94CpBUrkBdvOenbPPXNerXajUdumh4iT9pJpWWv3HR2KpwgPy8EMDjaMHHt16muv0+DMblgdqh dpyGABP3AR9P515WJdlJxVtLej/4Zs93BRXtI20ev5X/AK+463RVCuyAHygAfugkZ5Of7vOeD0xX VwRKreV24PcAe/0PXv0NeFXap1JJO2zt33+Su1+PmfV0uT2aUL6p26PTp897HX6avypG4IKbQTs2 kgKMEH/P5muiKhUKrkHA+Xp8p4xznHr+dY0FObUrJLV6+rb/AA/U4sS4p8kYta3fpfsT2JkYNuj8 sr1XGTjg59MYzwKtKuHXps5C5wPTpx81dUeVe1jHVK6t302/I5HFc0oxuktPT+tfxJwu3BQHP8QP A55znqKkkBEbHYCDwW3enJ4/lVRtZSfutO/39H+V/QXvRVovRf8ABQsWxMLyOO3UH2J6/QA9DTpB sB28Hf8ANuyBg+mO1XZxc522Ttt+XroJ87UlayfT8fzbuVlZQCcbclUxgnHIAIx9B+dMeIbw2MDG V3DuNueD25PT2rJ89/8ADe36/wBW6G0bx+Hpt8/6/FEzRrgfLxjJHTGDzgDqTyaPKAV8A5GcDODg Z7elQ1K65ZXXf8xK10rb3/T9fzIoQq8bAo6Eng+vf6/5NTIQp+VXHXr0HTocf/XquVazjdNNWT7a Jfm3cle8pRjo1ovu7fife/8Atd8cdOOfyqVD2PHueRiu6/K4r/gHmpq76X/L+vxuTjK8dsDjpjt0 HWpY5CD1C54A6/59anurbbW/r+rhy8jTTul/X6llJAM598knAFSB0ydoHTPfpik2m9rO235/r94k km1brf8AO/5leQ4AYAYH6fWq6sc4xjjOOn+f0rNKMW9Nt/uua3fMtNFsSLgEYzx6YB/StC3JPyjP y5OccD8K0VuWTvay/X/IGr36Wf5/0ydPlbgEHI6HHfrx0rTgz9Cfxx2ojqo3eivt+H6BJcr30X9f 8E3rHKtwcD+RqHVBiJ/o3HRaWKj+5l0aT+4yiuWXax4le2atdOwA+98xxxkgcY60wWI4wOehz1AP PNfCxXKlF9L6+r0/M+vppckXfZfiTi1wCecDk9OB/k9KebdR2HXOf889hUX5Zdl+lv6+41tFWtrq UJIQvXg57DB7f41UdMe3Hfk+4NNW1kl1FdJO/S1vTqQfd6Y65KgY4/PpTl64yQRjOR0B6j9aS+Lm 5bX/AK0GrbW7W+/QuITt7j888+1Wo+3HftnirsveUZfL8QjbWz1X/DFlABwcr6Y6qfepVTrkAenH 5Y96i7bduy9PMXKtUWAnuFAC+xP/ANanGMYPXHbH09/rTi1ze7pbT7hreyVv0/rYwtQiG1ugx+BO BkfQ15trMZG/jqWPOD+h/H/PS+R31W/9foRUWnLbbW/r0PJtYhXn1ByDtxznjPHPAFcVcxshxgqe AMLnA3Z9D1/ka3py5ZSg+j/zfppsebiIxnGcYrp/THwSEHk7Qox0znBGQPTr39aurMFlDAheRyMA 5x6D9fr2rCvCShKotnfT1vfT7n6ngYiO7Wiejj6f5r8Tfsboh1ySAONxYDqOue3avSNNvS0CozEr 8uMdPbntXkN8s2uVapO3Z/1+R5slyyUb6Lfy0/r7zqbKXhQVAGCMcAkj3H862pcRxpLGeCoDAAnG Tx9KFbllfWy2NoRj7yva2v8AX5+hw+sliHKAn/dXGGPQfjmuTshPEmoq6SIVOSOgxsb/ABHSunK5 /wC0RUne23qrP/P0QQjarSadveW/X5f1seSahkySEFshseozzk4+g7YrFmB+6CFBIxngFsjGOf8A OK+5jyxi25Xvay+6+nkezKDT5U+VdPvu7mYyjBGcHKhu23nqD6+9RAj5hnbuPGMfdPbP5c13LV6a JXt5rr+p58+WnJRafX8WNJIAwvChickZC9M4A4xz+vtUa4OcbgADjHynjP8A9bt3raK1k1olr8nf +rBKK0W1/wCv6+8ZjB+8oBGfmH3SQevTio5BkncuOy44yCCfp3HPPSj3lO0I2to12X9aImLiua17 fl5AN3UMOQGOMgZ6DGemPT6U09eB94HjdjbxnBXoDntmtHyU3rq3strW2/EUfdSS1s39y0S/ruID 0UdeT14wAvPbpnp70h3KTjHIAwDtwc54zWajycjvZ+Xb9d7+pDta66NeXXX8RhJH3eoz2wec5xnH Q59aAQpO0LnaRyCDxzkjsOP1rZLkTe29ltpa/wB+/wCQ0kn8Nknf17/cthU2hx5pYIxG4kYIBx8w BIB56c9sfSCTarFVZiAcL8uzrj8O5rHVKTk+W7S81bmf5XDlcJvW27t/Xa/59iFyMrhuMEEnIAA4 Gfx5zTAEAO7AGw4VgBkZC9OgJH4c8U0k4yik0paab3/y3+a8inyqyWiSf6L8/wDMdu5GCML9D36c ds4/I/WomyCGJK8Fu/Pqfrz27jPrRSblaNrJb99N1bp3HZKM47cu3r5eg0jgksdwAXdkqucnhSPf PA9fek7ncHHqQM7QOPrjPsKnl5L0Fro3ftfW+nRL7yXKME4rW+z/AB0+/wDAcvGCrAbTn5Qcdep9 /wD61TBWxk/wHAGMHB5+g789sj0qk3T5UtOXV38uwO0VyPfX+vUsJu5+4d2MEDGegzxg+g7U5lO3 aoJ68EYyO/P9f510NuEo/O1++n47mMm7JRdrX07rz+7+rlaQ4IwVIClh/F69MflyKFJC8BQMjG4Z Y5PPU4/X8qyl7zim7NXVttXtdfh+PQpOXvRWjVlbtv8ArrYvKH57Hp3AY4yfoTyKmA+UcHpzt5Ix 1zxx9fahXUfhSSa/z379zVxfNFtbLXzfe3nYi5Ur8w+vA5J6Edu/50nQgLgEHnbnJU+g9PXrj9K0 pyabjL3V26W7fe7f8MTGPKmn1bRGxyDggbdy87hnscA49Ppz71UOSW4Ubc7VLAbl2npnjP8A9atG uRyXLtvb03/zE5P4mrKK+fdeXQxpWIfB425OF65GTzgf171WH93bjBDDII2g7sZOO/Azn096mVta lrJrTumn/nchRspTUr32t0ta/wA3qWYgCwAAUB1IyWGPmAI46c5x+ver7bVXy/m2qOckE54HJH1A x79+KxcHzzik3ZXu+jtsvLY2pQai29NNvz/Et2C8swVlLHGOASenH19f0rE8XX6W2jzqzLl4n28g AjGMdOuM8CunBU26t1pK79Pw8tSa8nGHu+f5ny4203Dtk53FgBuCkZPUHsevT19KsR5BA+Xb2BH8 OMenpj8q75/HPW2/5nm04ra239f5m5ZgFhjYqjHclskA8EjHXPH0HNdlpxHyh/QAMMqoHQ4IH09P 5V59WN1KS0ev3+npex7mAi1NNPfp5f1c66yi8pmkV9uB8xHHXBwcc5yG4/n26zT29GwSq7ASckZ6 e3t0rwq9uSTktuy6aJ/hc+opQjCNopx5fyZ1tky7dzbQBhiueUPHp+POa3EI3FhjGMKSWxxwPlPH I5qYLlhzJaJaJbvRfde6ZxVrS5nfRX+7ZFqMgcD5W+VsDucnPA65PH4VZUcZA25AGDn1yf5D8jWq lBaRjZbfLT9TkilZ300+/rf11YsblcIxA+YEHLcYHTrjjGc1OzZjIU8NnnknI+o/z+Fawas7WdrP XTTp+jM09E0t3/T+5klqEKqH5wQFccYxyMHHP/6qmKH5z95Rlgue340R5VJy5NFt5Kyd/wCuqLk2 2mvdvs3/AF6orgHaPkOfu5xgBuT8w7Dj1/pRlSdoUllPuAPUdu2PyFS1Gzd9Gt+lr7/jf5lQvzWe j7dL9/xE/wBXtOT12jPykkY78c9PrUwPGMHePutjIwevt/8ArrOLsnyu3b7r6B7yfLLR9/X+vQrn hgOgzjpgjnqR2pNjrkADAyduAvOOBgdP/rGhPWUVFpp/doti4pq6gttPm/8AgI+8yX/D2+v6VOmV wQRg9eOn5fX+dd7cfiX9P+tTyJQ5bPv0LAPA6KMYGMjr/OlGMZyFC475qXdRlJRt0+/X+vmVHold Jf8ADgrlcjIOCRz1Hp06damiJBGDtHbjgcGla/K+XpsvMdnr5BISO/U/UEn0qMD5jxwOvbH+eaxi 9XdXS0/y/Gxb201TRY27T19uDwcjjt74q9b8MMenTt0rWD5ubmjp/l/SYNrld1ol/wAMWuCRtIHO SAeRV63YAYzg44wcf1q4qycb2T2fkKWltbLQ3rFvnGflO3Pt0pNR+4yjjggj259KnEJzptWt7r8j PmfO1tueX3EG2d/lAAY5z3AP+NMWJV6DrwMc8e1fBSWsteuj/wCAfW4d/uabXUQpxjgH8qruoXkA L1wOg6c/yqVFcs7L0/r7zZ+6vdVrGbPtwRnBBIxnK57dazJDgEZGPTpjI9Ogq3T9mo26L8dPyJ0S l5fqyvxzxwOo9e3TvTiFU/IcdBtHGD9f6+1Z1LxgmtHfVeWv9MFfZf8ADb6fiW4x8oJGDgYBGBir MKlTkYA/ukjIOeg/nV0+Ve+1bbysy1FWdl0/r73Y1UXgfh2xUoTBCn37D/CpXOna6/4Gv9fJA4q1 27E6qBjAOOMD6Hpj8Kdj5eMcenHv0pKLjO0XZPX7/wCreoknaKTtbf5mJqCcsMDI64GMEjNeca2m N5XsTkAgkd+nTuauHNdrp+P9XCpfWMTyDWFxuAB+9gEZIJJ6YHWuMuSxYZU8EH+HjgkYx26c+ueO 4uC1a5rJN3/V/ccvKopQW3f/ACK0KPiTp68HBIPoB+dQBtsgG7acnAO5RjoBgjn05p1Ztp9Gvl+G 3Rnh16XvOLWjX3f8N/kzotPVtwJOMHgZ5znjr2r0TSXZFXjj6DCkY644rwqzj7ZO+iur7d/6+88K rZVWktn+Wn+R21oxXGABuHYDjPGRjmtRnOxgu7AXOBknH07/AOT2qFOMVJvs7fKwqaas723/AMjl rrU1sjN5sKSqVIKPu2nBByAOQeB0rmdO1mfVL+9t5kiWJIiEMa7W3bgBnuflzjgd/pXs5OsO5R91 qdtPXbb5lwqVOaCiraq/d7aI8p1YCK7niTkpI65A3AY75HT/AOvXOTDBPPCjPIKjHXpgDnPI9hX2 FJpKDa+7fz/V+jPZmuaNvT+v69DOO3IwmPmOW4BHfr3z+H48VWPqpZuehO0n0B7L3NehTTcV01su mmz+7dnDPb4bX218r6/MaWyCGxjGCdoC8ev5dRTGHK4Hpxzgdzj24xW65YuMY68jend+v4NiSstZ enk+r/MaTt78jaeRjBzn8c4x27VHwMghVIwo28FRkHOe3Y1MFJOKS3bv00/4CtbyMo/u0nJb/n/W 4o6jCFO6gkE4J5Pp2/SpPLJzyRgMFypXB4PAJ/z1puS9/TbS3Xfdetx+0jd+5Zp6W23f5jWj4Kgl T0XrnIGByevfv/EahZs5IyNrgcYHcDgdRUQcvdVtN1311KcleN1a97fn/wAEj+bLbTjcrYwwyTjG B1GfXJpjZwR94AgHJ56dcDOD7DPWt5R0Tn307eX4MLz5rWur/wCV7DC3dOiqcEHaN3PIPbioS2Mc EYyeVAI7kcnPTt7e9RJcytFXlt5db38tyZSfO01dNejWr/rzQ3aOV5A4woIGARwSCfQY/p1pF6Ag nGSmSGG1Sc5wOQBnr0/CpnOTly8mi1T89Lfi3b0FJe5JuF2mt382tO/9dBAxKjltuM8gnk4I9ug/ Tv3RwMdlUYIZSoO04xhuRgZ+nSs4u8XJx5fT1tv/AIXftsVJJtavW9l5f0mMYlcBuB04O05xx14J z9OtIB/q/urjBHUYPOckZzjJI+tXLRNxas9FfTXz9df1BtJbJW0077fL1FYlTt6cnuc54ODgeuPX vU0ZOOgAwckDbt45we1ONFWcW7prfZ9beX/Dkqyk0o7X/Bv9NfmWkZucE7RjIIPy9/z5P+RQAwXg 7VUfeyB9AB+Q/HtxWsVKEVHSVmtflv8Acrg2lGTSvt87v/hyoTjORgDgAfwnPbPbv/j1pwLcbdgO MbTgDHIyOOD7Z96p05c11q7t9tL21/QdNSu9LW2+9fcXoSwUbcqRgYbj/HGcDmpVJVTn5eo4YqeT k849/frSjzaQulytb9f+HRae2nw6f18hmVHY/LgDC8nHXjv0P5ioicEjHAwxOecD04yfp9Kbi7uT Vk3+D8vXQTSnvpf+un3EUmQPdX6nOPXIyT+X8qrSk8425BAGCF254z06Y9Qeo9Kq6coyjKy0tbfp p/XmZtOMX53+/wDrTyMN2xKHwFG4AcAYGCTlR39z69ecUgYovXls4/hAI7Ad88dP0pzTTh7zVktE tn5L+t0SpuFly2eia7NtXt96uT243EcFMD5cELkjknj3I/Orpz26EP8AgwzgZGAOh7+lYv3JP3nd rV9LW0Wn9bG1uXmur6/g+l/T/IvWajyQwUAbSQuMHOeevU//AKu9eUfFSeZRbLG23dl5BjaSvTrn 1B+uDXblzan7SV7pSen4elupniJJ0Klo20+7Vf8ABPGUChvlABxnk7SQO3HPr/npdTBMedp+8qq2 QSoIxgj2JOP1rWa1+K3U4qf2nHp+e/4o37QIEwiKDlT8jcAjJ9e+0evU9ua6yxK4VCgDljsYNhcZ OBxznHT+fFcVRS9nPXl/r+vvPawejppbNfdq2v6/yOwtISUZCNoIJK4+8ByNvHy9Cfw/PpLGLOzy 32leOuOQCQRyAeeSfpXhTk/ZyUU1du/46fhb1Z9JSk/Zp3tFLX0V9DsdMX5QrAoASoDbhgnnt2OT 27/hW0I/KbYAAMhQSc85yfYfX2p0FLkcm7cunLtptb8n6nFUmm5Rt09PK39dSVU9+gGT1znHXHT8 fetCHlApG3bu28jGeRn9TWrSXL7tnp+n/DnLJOKutW393QY/yEnjgABicdyDn061KBuj+TAG5QTk 7Sue2On6VTguWKTSS1f+QlZt9Gu3rr+pZRXQqIwEK/w5OW456DFOYui5A5JIK5PAwTnH45oipRVO zstNu7Wqt/VhO7Vk7Lp6/wBa+gxZQF5yVwQQQOoxj/PvSB0kZtr9M46KffAHXrUtNxm9op9drNr8 /wAildJLm1t/Xnv+ZXdjuIbO1cAYJ4Hb/d71MkoCjA2kZ5OB064PTv8ApVOLi29lG6t89bfivI0T agnLe7/MjUjBI7EHk4AkwOoHfFPRyFONo2sQwJxt9f6H8cUlBynPldl9z2Wn4ffr1G7py1tf8+lv Q++wgUdvxAAHH/6vzqJs8ABcDOMdsj8q6WrabJvbp5HmJaWv/wAN/Vh6buBx9Bx+tThAOf7vBBwA DRJP3XGy/piTS5Uo99V5f0hrAZx0PUg4Bzj0HvTk+XHTqD15x/nNQpWUUo+9+CLi9I+7Z/1/wR7L wB2649ff2qQLwMHPpS12St38n/WpW1tP6/4cmA2L7Dj9f0qxC+CM+vAIxj8qcL35V7u//B1E3ZWa tbXz3LXOVIOO44AOOM1oQKE2jA7Hpjn/ADzWkUlF3311/AHJLmtpb+kbdoSGGMAZ5wOg/pT74Hax x649vw9KdVLktf8ArczirN62f9aHAXUf75s+rcYGQM1VxsGOh64wfbOTXwck4VJR0XK3p2+Z9Vh1 +4hfZJW+/X+u1irK2OO4GB0HU+mKoSuB0GMHJHofb8qy5bSXLpdfg/L70bN8uytfYzXOSf4c9OoG fcVQcYYgZPpjoT+FauD5bu2m3b+v8hczuumn4siAxnOO/t+H6UKnzdMAEEAfdHcZ/Ss2ml2T/Dp/ XzZcWoqVla2t/u/UvQqVAx8pOefx9DVyPhlySDjquAMn/PbNLld9+n5309bsp6Ru1p/X9fI04lwe hzjbgDtj/wDXVgAg8++MdvQChfEvd0X/AA//AAPwE7Kzt/wetyTpjB5B6Hjjv9aOBnngdDk8EZ6f hQ21HTTX8Ov37fMd42XKjKv14PygccYx+Neb6yv3sADgkHnn/P8AWrjslez/AECXaO54/rKkN12j P3Spz0zyc8f59q4W6JR1IVhjAwCF29+nA4yK1jHli1BbK1t/v/rzOZ8yktNv1/4A20kG5jjAKnKn 5QegByvHtj3qFlVZN3HLZBwec8cVxVnNci7K607KyR4WLlZyXRrp07/d+JuWTjK5wRznBHX1z17f 1rudLm2Ec4HGVw3THOK8mro3bS2qXr/w35M+fr3clpZvXT+vM7KK4XjaSOmAByGAx049zVz7Wdu4 HbtBO4YGO+B6H8K55zalBQjpdfl/nuYPV8qXT9DkNSLXUohDbBNKIt5Gdu5gAx/GvpHQf2ZbWy8F T+M38ZaRa3Mtst0V1TUbW2t0gX59oVWZ933sdznp6e3lOGzKvNVcswjruGslFO/Kt/m9l8ghWw1C SqYqo4QTSi/7zVo/ifCmvXEMF/dwQ7JdlxKqzIreVKFYgMpIBwe3APNctIxJ+ZQnK9wTz0xnrzmv tafNTcI35W0m07Jp21T7a3Po1O8W0rRsrPbf+kZ74zhTkZKsSV7fw8f55qucZYk49BxnODk5yecn HQdK9CCShZu2l/6Xn/W5wz5tU7LW/p3GOwBCt3LZxhQAe4zwB14pPMUDh1z9QTgkjtznmqjzJRdr Npfd1v5dfUi696/T/gflcj3gj5WwCQBjpg8dR+P/AOumMQMZB4JDDkDHYAYx0xzWqlyKM43absvv UfXz+SBO1m0n/m2MMro6lRv24PUA5OOeDg9fypst5OwwsRUKR8wxgHqM+2Mf4GklG7eiUUn93/Be vmhRTXPpa1n9/wDX3lctdnG5htznkE4PGBx0znOTxxSosig5JyR038ZxxjtTUtFC3Kkt/Vtv8/wD klytt+SS6b3/AA3H9uhDAkBRgg8euPXP+eaj+ZTtClUxn5ScKoyD07cj6UPmcoxu1FK6f4K6+5jv 7itpdP8AzGeYOgYZOPvAKOrdMc4GTz7D1pmVRugznaQuBjjOSB75pqU1zq17Oz7W/wCAl0Jbjf3u nZab/wCX5jHBJCgYDcqRkg57+2QT+fFKfdWznGemB3A7fh6/Ss0uSFou0VZ6+l7fL/MalbmVrRk7 /lt6vbzsR44ZhuBxgkbff5cKen+JFRj5R7K2QF/QE9R604xurKXw6WXfy/q2w1GKlFRjzJX0266f i/6sHc4XDBchTtwCRwBjp3+vNGOpVSoGc5LISMDGMcevftTiuZuMb3X46/19w1K6lHlt183/AFsO A+6+QSu0KeCFz16fUHj/AOvU4Q8HHCnHQAk5x1OSCMnn+VaXjoqa8rWs1uvy67XRGiXL30S677vt d/kWEUEEEHrwQu0tnr1HToOfT8KVl24GH74BKgM2ABkev4fyFbT151K14vp20vb53G4XVOyv59km UCSDyMfN93+E5wfQnt+tSJ1xhhjjGcLng4HGCOf0x2NZTsprlbS19Lb3+Vl89BqKhFavRq1vmvu0 LUbbMEDjjvg4zxk+nI9fSrQPzDcSMbscqNq4B7+3px+VKm5RcpS0tt3b01+7YuKs9V38vNfkQ7sH GWI6njnGT09euaiPzE7dw424XCgY69vcd+ea1qTlG7gr28t77fO/Yzk95rp27Lb/AIPkRNu3cr93 HoPmJOcex44qpK2Rx8rk4I4zzgA46/5FRCDVny2tb7/idl/WlyGn7islb8/P9DBdzvbAABbBxgkH 5s+3Ukc/Ue79x3EKAGUgqGI4XqOOh4I7Y9q0ule2rWmnS3dd3pqx07wjNuCetrefS34IuWqjDMF2 Ec8qOncngHA5JxVh8MSOvDHCgq275iMjPGSGzz9etYJXqOC93RLyei1/D1NEnyyjJ2vZWX9f0zTs yojVTtGSScYPBOR0HqT37V4r8T5Sbu2QBh8gJONq84IBHXjAPFd+BTjOVtkn6f1bT8DDE+7h4wXS 17bLyPKo3yNu0bhyQCeOc5Cj6/rWnBjCK0fGQMADcoJA4AOevGf6dNpWs0tGkctLRvQ3rSNFO3BB BXhxggk9RnnORx6++a620QiJkBXGONxUZJBPzDGenP48V59WVoS5lfsl+C+89vBQblzRVl/w52mk x/u/Nyd7fdAA+6AFPyj6Z59TXVWp8lo22kIwyw5JB4J6ZHYYPXqR3z4bV6l9mvwa7+tj3YuShGMU rpa39LNv8NDqrI5jBWM7BhgORgkfd/Pr36Vpqeh5DDHy8kL145HT/CnBJSta6v8Ai7W9bWW/c5Kl 1PkaV47fjr+Ayd2VGeLO9cBVCnHXPbr1/WrVrMWVGZWVcgMDkhcZOCSD/nj2rqlaELxST2t/XzTM FpN3fu9fLXb7i3MVkizHztJGMc9OgPTgZ9aWAYiRdpULgH7xJIzg5OT0Oc5qZpxtGKs7Xeu19dOi 7fMFK3NLk0/HqXN3lgjmRMcHOMDGOn4k49s1HKW2YY8YOAQOuR3H+elUnHk7ctrX7frbd+hmpOzi tGuv5/5FC3md2KSRlFU8HGFIzgHj6ZP1FXVXyxgAHdk4AxkYOB6Y4ApSSUpJO8V8ut7/AJGz932f ktfL7vkMlYAEqpx27Z6ZBHtx3/lUSjCJjaBknIycdeu3pWc4WlG+mqb+5fnvp3FCLTkpRsrfP+ur 9SUKmcAY5AIAH9entUcheIOg6cntjBBB4/GiL1lb1f366ej6FOy5U9bfh/X6n6AkEEdvQgY5AqA4 BwPTgjPrz9P/ANVdas19716f1c81Ky5Vrp/mTK3IA7YPHJzUgcY29eAcHtjPSqUVpbZW8u49opdn /mDAkn2GeCc5H86lAAXnsBxjP+etZ8qvftpbt/wBp6N2t/wwZ2qBjjgccYoD/N0JGeOueTk/4VFO 3M+ZdfzQkrX5dG1p9/6Fs9OhA54xz6ninRgdRn5eqngdKaWlm7Pp5F6JJOOr/DqaES46cdPfH/1q 1Yl+VSeB6Djkd/0ra9tum35fcTaUeZNJL9TUtXCMAfl6d+3WrN8CVYqf4QfQZoqwjyxbVv8Agmcb X7HAXbASEY5BO3aMd/8A9ZrPY7eM8Y7Z/lXw9dWrVNLK7+7ZH1GET9hDy/rQzpnwD+AA5A/zzWZI 2MY7Z65AA/z/ACrJpK7t93ro/wDM3vZ8zV0v6f6lSTrwSuOR796iOzoFK925wB6fhTtJJpaW/r+v mNp20V1qKIvmPPXqePbpUvkkE5Hv6+p49uKyk9FGL0Vvw/rUqOiWjsrLy9f+CXI4uRgY7ehHvn/P Spo4134yBjkAjGCMehpJ2cUlrr+f5dS3dXje1tf6/rqaEYHb8+5OOKm6Hp9ARgYp627bDT3drJDx gYxwFPPGSRn06d6Z06fKOR9Pf9fWlFtNtWen9fmCsr23f/Df8EzrzbtIA7EgdMcZNeea2nDY64Pq ABVxhZcsn/WoO6tbT/gHjeupgsqj6gHBP+Fea3kmJGAAwu0gNjgjGB8vfn171fKoxlyvlvom9r21 ++xzS0doq/8Awf16ehAj4IKkDBA98cdfTNWSVUpn81HOOpOMev8AM1wV1KUYRU9Yb9ktNfxf4s8L HOKlJL8PO3+f5mhazBOnGMAcgZHrg/4V1dhequCCAMgADA+bPf8AUfjXBJNO8YprX71f+vU8Jrlm opd/xX/AOsi1BcKDjKjOQuMZz6VZe9TZuR87lGexAwBkVz+zjKU2to6/p/wfvOdu3MnpZ2/z/ruc bqt/IMtF8pUncVbGeeuc8DvyO1aej3F03hu7eWeTZJ5x2F3ZCMhQSfcZ/wA9fsuFs4x2VRxFPBVn SdaLjJrdxb79E9LehOHoUa2JpKrC6T5knsmtn66nl92g83oQMkHknaf5Y5BrIuFKqVX5cAlScjb0 PAPTufyzXtKcLp2vJ7vz3v8Ak38z6SSjyqN7LfYyZlCAdQ3JC5PTJ5H1PeqRAZghAHGTjnBwScHP r6+lehTUYyTty3f9Ly2sjjrKMZNWtba35/ihnkxgAfdB4A5AA4446fT8KDBGF+7gqBu2dT1OSRg/ z711Sh8K5uVPT/Cn0X5/gY2vZvRNfdtp/wAMMwAowCq884AwM8nH8/f9QgZ2g8Hk4B78dun/ANel FR5mrWX3L+ttu5mktYJf8ONITK98AkAAsOScnn39c8dqQ7TuA5GOig4JxjJI59T+I/FqS5YRprRL Xqt1o/K7v+JcnpaL6L5dbfiNJ4OTgccEkgYJx04//WOBmmnA/wB5Ru4LDocY+uO/T+VVPli42ik0 7d9/+CGr2TXKunne9v62GcgsQ/16nJYf0FMbOCAAQN2TgDt2HQ84qW7NO9m79Ldf1WvyYrP4o621 7P5ev5MhBBIwxGck5BBA5z+vuev40oKhto3L8ygbTlmz9Tjtj3C5+kvmj7NKOkndpaLT8t2ODa5X Pbf0S1/FDGZsjoAArdxwckg9P84oC7e5XB9GBXOevcdKmWzVkmrq212rapel/vYpLlTXJyr9OlvP yIscD5T3JxliSQOAfTIHb1o3YLnCqVx0BBAxk4BzThFNNxXLsnr1T/q/e4R5YJtabeu9mv63uNdl HIGPvAZONwPPynv0+vGaQYwAHI+XjkjGc5AAH0HNTeUW3Bb6bbd7fNvXTa3Ql3cny6NL7n/WpIgO dykfMchSMjJx7/XpjPr62FGDgbtwDDhxkhhgg5IOOeRkZ/HnppRVOUYbqS+aVlr+fz1FdKLezei7 6f0yyC20g45BzkZIPJ/Go36ZwBjgBRg4HHQ1Voq0kt+nla9/usF9IW81+PT8vUqNhe/zYxhhyOOV 9F/nTRJzxnnsd+AMAcc4z8uefWoa62aUbvTe234fm0VGUUou+i1v3d0v1LKnqwYrgHoMYHfGcdf6 1aJGcL3wR1xkYxnP59O9RGmtY81/1s3+PcrlXLa93HX77/8AB9BhYjPDEjCgcg8gHgY+bp7U12Yj OSoJ2rkldqk46duuOD3rWLbaaXLbv5O7Yve5XK1u/TcqvnHsAAVbJByMYKjjrnp6VRkZQpDZBKFt wx9MDoehPT156UNNpKKvbp23+eqWj7ImUFzJqN1qreb/AK08zILBW3FcqcnhWbORuXJ79Afx600d OPl2nJIB68jHA9gMe1Nv3pRl7iv00+fz7E05QUXdWkm9vm72+SNOFdsezhcZLc4I55C4Pv8AjzQH IZTgBs4BUbQeRj2/D/GsltzX2f8AmdKV76Jf1/Xz0NWO4VwhVQp3YY4IPH8XvkcY9TXh/wAT51N/ Am4YVcd1YZ+U9Og6cdq9HCKXtJwatGKlbzt/wbnLi5ctF+qT6HmsLKPmUlQOM7VA6c4AHpk9PT6V qRt/dOPl6kHJ/X1+nU05xs1La39fic1O6SS0R0NgFMkTBdsgC4K5AxjBJDcdvTgH6V11szQsBgDH I3EqpHHQ5+nX0NefWirNze9/kl6HtYFSTi1ok9V28167ndacYliI5XjD9SDjnn+QrorRCyiIHK8F GBHI69T19P8A63NeMrJSlJXbd/wuvLt9x77lGPO7WtZr8v69DqrNVRAnI25BDd19ifUGr0a4IEgI BBIHJ7DJx2/I9a0oqLpqL0d9Ol0rv8t/+GOCopc9291/VhmI8nJYFc9AAAfrnFX7d12jauAeoAAA GDwCPof8Ktx96T21v8n0t67+pk9vdtvdvvv0LCgDKqPkx8owRg8f481OpwmAFyRtwuT8vQdPwP4V T92Xvx209Vr/AMP8xyWnMrrd/wBfN/IjZlz8pK44w2Rk8nt0ol8wqoj2/KcMBk4yQOOhz+Pb8qTj a9r2VvJeX5r7zKXSys7/AC8/z+8hQBWKsgOACcEg4PGMj8RUxccEAADGCCcqcEfp+FRFWmuVWTta ++u/qaNNySWnbvp+G48uqoAy9MEjHIHGcc9Oc1C4jjB27uxxz1yAe/J/LHtxSabalezu/wAGrW9d P6Y3dty2cn8u/wCSIVkRfmOB82MDI4xz+Gf/ANfTIf3iOMHd+R4xyOeP5/1mM+VpN2ktPKztv91g 2s7Wv/wD9AJbgByhG3PIPSoi3IIbjAA56+pzXW4qCS3i9n53OJPl9zmtb8dRU5HpyB2OB/ntUudo yMDtkEgY7/TvQ/dbS0j+PRom8tOiX/AFVvQ4xgqe/X+vNTqckcj+WKmTjZK1nrr+gOUdpLRXJTt2 gHbngDAAPHX86WPg5OB79h/9br+dTGPNLTpf7/8Ah9i+uivo/wCvuLRwQNgwAQSehz79u1SQ8MPX qTgjjj8DRGFn6/gxp7O1jThKD9PYVoxnGPTpxwPx9K0jeLbbtvb0J6PX+lsXIm+cFfz6+ncVozDM QBwDtI6/lxVVOb2at6/8AiyVrK3f1OEv4ykrEf8A1wD3rEcsM4+U5znHOCTkfqa+Jrq1er03uj6j BOLw1PpuZszZJA6AHjOOf8/zqi/pgDBIGCfw/lWUY6a7dvlt8n/wTf4U+35diDaMcdsDPQccdKVY uflHAGVGAMn6Ucrs21/Xp9w7e92S/paFqKDBYAEfyFW1g4HAxwPTaSOayairbbGkJaOKdrJk625G DjHUcE5H+NONv8wZTjGRxwce+PrWbbV+Xp8vkNJc1krKxbSIrzx9ASP/ANVDJgk89+g6d8fzpa3V 9F/X4D/u9LfeLtwcjPQHIHT/AD1pMAY4Ax7Y5/L3rWLjdq13bbZL+twja17W8jPu0G08kHH4enSv P9YU/Njng8jgc460JvRJ2f8An38iNVJaW/4LbPHddUBm46EDAOM9sV5VqKlGLZwrFc4wABjjnPJ5 6dK1fvRa3tv8/wCkZTaT0jtbyM0OxOE+Yg4XkkA/THHb8KkMzcDcOnyggkjr7jg46V5tRtTleySS 67/d2/roeBi1yyfKraW+d3r+BMt2qgchQpOWUnnOM9Onr/wGtazvssUWXDEbRztbJzge3X16k1kq d7Rpxs0799NW/wAPzPFkor4rq23+f4M6W11B9xV/lZSw2k4bA9h/jVv+0AImVSPmOAFYDqT6/hTn Rfvcrtp/n0/zIrR5Ek5WSu/O72sV7PR9Z1u4W203Try6m81I2itoXdlQnAyRwM49a9R1Xw/PoOmL pU9o9tOFxLHKu0xY5xjHc+/YV25TUpOv7PnScYv3VvbS36/eb5bQlzuu48sUt9teqPHdVjhhc8D5 ckg9AcdPbgZ/zzxt3PCW6+u3AIyDkEZ/z3r6qjGMpR00T72/4ba3rY9qUoJRut/v2/UwZJI9xJXj nGSM56cnv6/pUTMA2c9228MP58Dr6+texGEYxjJrmVltpq+r9d7efmeZUS1i3t8v62IiRt6cDcQM 568YwR7HtnOKH5VcZJ9M5yBnH4VpG3tfdfNaT8ten3K5lFpcto2S69uxFtXdnAO4YJIwVX2wfUDj 8aVY8Nwu0ccHkZPr27j8vfil7NvlTs9Vd9NNvO9hLeLSd15eSX6/eCoVPXAA52nJwOMbjxjI6+31 pjK2CPQgBhtBzz68d8fkaFFezSjTS7q+7e7flfT5FpXvK1rdP1/QaY2ByCTg4G48cjnHpjn/ACeY Wwueu5cEKoGcHPt7kcD19DkgryjqoW/y/pa9iF7truz626dNfx+Qh289eeT0DAdenXH+NRNk8YAw GDcKF7g5x14Pp+dKouZrms2nH5/07ILtJ/1vt936ERK8AnABCjadvzc+vA9fwpu0c7WKMcZ4wQBn Hv3OPrTcdYc3updE/wBe3n39RpqPW11t0/r+kCHHCgfw8c5ycdf1+lHygkdAF+bBBxzkHtwMAe+a xfMm18TT3t0V/wBbtr5CveW2zvd7X/q7Gk7PXG7OF4Cn+nTgE0wgHgEqCAOijcMjOf0P51fs+eCj Tl7sb+Wq/wCG/IlwVpxT328rbf15DQOVAypUYAQAcnJOB0Hfj2NORfmznC9VweGJGVOMfh+fakk5 KLvaNrb7J9Pvvd+oNtptLlv9ye9/S5MoAK9MjIwAR04GB06E/pU6Y/iI5OQcYA9RjuMEc8c+ldMI SdndxbSX3Xf5KxMnO0Y35dE33/q+5MBwACeCRgAKQD/LH9ahbaNp3crnbkA/MMA9MHqKuV56xja6 6ei/4b0B30jFWS/O71+RUbB6bjhgAjFsZAHO3t9e/wDKDhRw20jcQAQRn8BnI+vOfpjma19pK+ia teySsv1aEoq8ZS1bW21nd9CVFKZwxxnJyMgHODtBxz37cjPNX0JBAyTt5wCFPOMYyP09qpRdpXVk rO+zXy81/Vjb3oqceWz/ADe7+4BjA+b5wSQVGCARjuOwx/j2pjMcbcFdpO08sccfp+dXZP3WrPy9 Ve/9bXHGKSaWr1XzSsVHbnB42DKk9iAfbjjPzf4VQmbjtg9iPu56/Tk5wfX8teZK1rx66b2229DB 1HFJ9b/lf9P8zJKKhJwqgtlSAccgk/KMck9+e/1ChipAztII5PBC99xHp1JqZRU0oq7V9fKy1/H8 bDUE/dTslf8ABaf11NdQqxrkbc4/hcYzz2wfXr71HnBXOdwORt7DHJ9R0/XNYKLjRjZfFr22t93d G15RcIKFlpttfdffv+BZkuVgiaSQ7Qih2cKQmfUY47dvbjpXzh4t1BNS1RtmWjjwF5X5QDkgnjjj GOPpXq4aLSxEk7cto+j62+78Tgxs4rlpJWd2/ldrf8fmYCgqNuQqHcMqx+9n0x2BP6fStS2zgKOT twQoUe7Hg9gB+dTJOz0/r/gGVPddP6/A6myZEZMDgkbf4cHBGMngdT9TXS2i+ZMqfN8hUoMHjPHA 47Hn+XauCpzRjNp2dnb5aP7z3sH704xjpr+Fn/kdtah4Y0Ug5YEKVUgBeMLn16+vSup05WKI25lK +44JwV5xwfYeteDNNKnCKs0/RtLX9Nuz6H0ElSlTqJOzuv6X32R2MKbos564HI/i7/TvjHt+FnHA OW4PU5A4weR16c4xXRTg1JRTSdundrX8d/kebO8W9PX01tp8/vBkUZ2r0GBuwMnbj6+n5GrEREca kttY5wvXg9Scc479fWtlCTUbO8lbXe+jv+Wpi7qCdrWstui3/EsRlF7nPTBHBPf+fvU5cNFndgZU NjrnJ7Y4PBGaLPSV7OTfn3/C4nKSTtol939efccuBhs7uOinGckZ6gY69Peq7v5WGUjOctgKAOOx 78k/nQ04c8uVe722u9f68gSV5Jx0TvbbV26jleN8HHy57ZB7EcHr34qCT92CMMEXAA5znJAJHf8A Xv8AWonJxlGXL8Oq7aafiaJcsl72/wDl+bYRsxAGVAPC8FjjHQ+mcH6/jUnmZAjbK46c8c8Djtz6 1LiuZ30S/wCG+VrClzX2uvu7XICY9zBtuTwpx6HjoeT15pR8hxvIOQB9M4P+H40uXTlcrLT7v6uy k7JWV16/15/cffjSQyjawww6HAHJ6ZP5U1VIBz2zjHPP4/X9K7OR0ZOle8VrF/15nmRfNFRfuyi3 b0/pfmSqNuNvC46ehHXj/P8Ag5icKOQAOO/PTih2S1drb9bPX8i1fR3sr/5hzjAz+W3kDqKeAwH3 fYHH+f6VKnytpK6/EteZLtbqcYHp6/5xUsMkY+XgHt0A96cIvnk4vVK/3a7f1uRJ8itFfd09Sysx DbQODgnAxU3cbRjgZ9sZzkfSlrBxa6/LXf8ArzKWl7v5FpMDBycgg44AHT39604XYgLwMckDgGtE 01dqyX66/oKa02sakQUbT39PUVdkb91kEd+CMDp3q2k4tJWt+eorPSy8n8jjtSclgAMbewz16Y46 VgzDgjH64Iz6V8VjI2xFX3dbs9/L9cMopW1MqVOuB+QxiqLAjGAMndzgkjArCLWia/p30O5XWlvv 9B2w4PBxwckYBB9MVYiiIHuMYxgcdP8AOKTcdOnQP1/SxdhiI9Mfkef/ANXWtFYBgYAAx6ZPPX+d YTT5o2Wvl63Zcd1b/hibycAevqenr07VHtKOV6ZPpgDFJNpxTS179H38zSKa0ta36/1+ZJtKNwOg BBHHJ6/1/WgqVKgY/kKV2ryWtr3C1vd3DZt7D3FNbaM8D6Accn9OtCVraf1YbSWl7L+kUbqMbWPA 9j1FcBrPyq4wMjgcc4yRjOKun/NPpt/X36ialbbXU8X8QKPm4GBkAcEg5/8Arn8K8h1N8MwwNpbB yFwDnr1x2710U2owcVq236/1+Bz1LuLto0/u9O5kow3Kdvc44AwMk1LcBcI6rj36ZOBxt6CvOq02 l0ktbLZa3fy3svM8HFpw5op6L8DIklKFuQm4cZABLDJxyOe/5U+wdriWTbIIzGBIuWKknOCBk8// AKq68PTcXJLWUU7r5a7ddkecqcJXhdWT/q3pc6EalPgrK+1o2aMNgdcZODgZHXk1asbyXfG+WwCr Y2khx75Azxj/AD1JU4qXKo2Wn3Ozt+PTpscmJpuCV1qlp+n5I+3vhJ+0RovgODbceCrHWZ3gRHme dbWUMoULkBCGHTr/AE43Pi547uPizYWWrwaFpui28Ad4orFD5pDqBiaTjf8Ad9BX1v8AYnCmDyWj jsLinPMZVIv2drcqs9XLrG+lvM58vqZrXzKmp8sMKoNf3pNW6bLTXvp5nxX4js7iF5Ez65xjA/MV 5/JDKrHcM7QSOFKjkD8xgnt1rKjOmtIws5NP79/8z6Z/HaL1f9fmZsi8kEbTv24OB0Oe3HY+n+NY 7cna4XkHHQ8gnPJ6Djn3rvpuV0pK0Vr5aWf4/lc82rJ35bWT++2t/kMYHkj5TwR2znrj8P50zp2G 3OVYnGBx0Hvx+P69HKlJygtFr266evzMJWjHR2Wvz1/yZIGSMgsoAYqV5AbGB2PXt9KgkvVR9saA hjjaACQOw/z7U0nF88Vbf0/q5Sdozb0lffy3v5aDDeNlcRf3xjaMD8P1qMXMwJIj6EY4A4+mParU YWlG+rva3by+W3qZuWkVZq1rdrNf5r7mRefcMOVCEnplSFJGMD144+v1pcNkAtg7cHKgDscZOR61 MIwv7rcbdH031+8lpNOTVrOz+97jXGMcLkDIB4UHHYgcdSOg6ntSEYAGMnGTkjBBJx/Tnvz7UJbT ey09er0/Lt62Lso/C/dtt6W/V/1YjIGB8oXHTgk7iSMnHbn0PHWhiq54HAznO0E9/wCQx+OfaVTj 7RRlG7adu3V/otPMdox917Nv+vm7feIwXGQCAeQB/D2HBPqfcmmgY4+6OS2cj8uMHIOOvt2quW0W r6p630fnr5/qDirTV7tdPvv+G3kMwoHAAxu6kjDYOAe3f/PZm0fOAvQABsYOBg4H8+vapg6qSaXL F2u/Oys/xWoox5I2jq3p5efztcevJXKgkHkLj5eD/htz9O+aVAcjgbcEfLkEAcgn053dODke4q4q MEopWSXTRXd/87kupG9rWSW1vS/33JwnzEAbQONucD2PA49Ofzp4JAwQOAT8mMdvbg8dfc1tF8vL y+7yxVvXr/mS243t5q79NSb5wScY4weRnB6cdOvOfaomXkKQPlb5eRkYyeMjp07+3vVv3eaMdJJK 3T+tEvvZbSeqVr2emnp+GpUZfl545Xhcc46YJ/h5Gfqe+MwBuoyV+ZgByMDPQn06c/X3rKUfs9t1 td3V/mtLPzCPxvVLb5eX5MeGADYGGYnIAI7e38uOnbFWkyF475TJz8vrg5P48n+tEnG6XLe/6K3p az/M0ppWlpbr/n+H6DxtAGfl7EDoMHPBOM/p3qJmbjjC7iDhVAxyF7gjsBVPlu3Fctnr2+H/AD/E ekHLl3/Nd2QPjK+o4wABkA9QT25yRjvz1rKncAHBwRkjdxjA6nuD2x6kcGqi1zWitUk153f+RhNR UXyr3r6/N/jpv5XKBAGQVG3BZmUrjGP9np1PenwsC4BxgH5gBnHAB4+o/wA9aiMpyi3KXK4p7b/O 2+u//BGopcidS1v13NJgwUKf4ACvAGGAGevf3HeoyQGXaAMsdwK84xyD0wep59vWs7uMndpQjt+O 69NDeEZQ95u6Wvkraff+Gxk+JLg22iXbp8rKp2AFxgEcYz1wCD+dfNbFppJZDIFLMTkkDOD6Yz6+ letQaeHUlpd/om/8vkeTirSqwatovuLsURC4yMMuCcAHqB06+gJ71q2kXzdfmUAq2MDHcHH+eayb Vmvu+ZdKLe0tEdVZRrgM0a7Q2AFDAckEDHTjiums1IljcHBXbk7cNtPoc+wyPavLrqfLLTRJ+XXX /gn0GCspRko6aX8+36nb2jedgkg7TkgHoR6Efd6jggfd7810dmY0bYBg8EHBPJ6/UcHn615FflVR U5rllBN+m6+//NnsTjJOUdE9X59TrYAY1wDkEZCtwExzwTxxxVre3LZ2ke6jAxznGf0ropS5oNKN 2reT1WlvS2p584uPM797W8x4II4H8J3c5PfsBkdj1pDaCUbWzhPmHb5h6ccda1dbklGUN0/01/yI k9Uk9E9r9b/18yRdqYULsOQCVz64xz7H/wDXVjkoBj5sEZHy4OBk4/wpx1ppzjZq3rf08yGpKL2X /D9kT4AAGWVQMuDwf8++KpzRGTGx9g/hB4z6qfU84o+CLXLotX5/195T+JNaWev6/wDAJIlZYwPu nJx8vTsRx+f49qew3KwxuC7cegfqD05Gcevf0rNdrWTdtf8At38OoN+8mtNL2ttfVL+ugxV2jyyA BjIyCoBGffA7+1SKUQgfeIJwx5PIPf6/5zzSjF3k07cmuvn+Hf5mlnaUVpv/AMH+vkQ+UVcgAfe+ Ucjb1OfTr7VDdq4jZlO3aeDwAep7D2J/Dmkkvax5dU7X7fcLl0glolo/Tf8AQ+7Y93PrnqOMf1rS iJCjPB6c9MH/APXXfdOmtbW2/X07nmP7Kvrdf1/XQsoOg246EAnAAp/yjqANvcHkf4dqzlFK+v8A Xmi1onbR6IQyrgKB9Bg8cdRSh+flHOPQdc/pSUUveltb8NNR6q6elvz6gsoOfTOOmPw//XUgiTPA wVJ5Bwcdf8Km6VRyWjWny0/4A17qaS3387/0i0oxgjBG3jn8PwqdewXg4wQOx5xSUrOS6Xv9/wDV xJ2slsvvLMQ+Ycd+np35xWtCAo6bee4Axz7fjWyS5V0sJ66LRx1L8bngAdgc5wvPb1rTKnyM7ewJ xTdlCUld3a+QldSs/wCmcfqnBOF+g/PtXOyk9QOmCR04x27V8djE/rM4p7O/5Hv4BWowe1m7IoyA 9MjAyQSOmSOMVW8sZ9CBnjAHHv2Fc38zi7dVbp/X6nc09LaX/r5Eixj/AGQcjA5xVuOMA4A5AwOw B71hPdW0te/z/qxSS0srK+/Z/wBIsxLOjrhVK568jt6D6VrIoA9+M9vTPSlzJqM4t6b+t7lrR72X QlKqB0Hp6E/5Bqo4CsB6c/Qn09etYzTTstbW/NFKO93b+t/yHkjrx0yQT/n3qIkZwuM4BGDxj27U 7tRjpb+v8r6hazl0uJuUfL0wOAMj881G7j0/L/OKbdvX+rj0VtNX0Mu8nwpHsR6YP1Fec61dLh+Q McAjGAT39uT/AJzW8Et77dO+w3dN+X6JXPGtfuOWGRz0+bv1P0ryXV5D83O3BGWyO4I+7+IqlZq0 XbW1106v87nNK2nI7W+Vt7mEJDuIUcc4x3B4yB+J/Krsky+U3GCeDxjPU54P0/zmuXEe6vceit02 7/pueJjYRjdp79Pu/wCGMeYnaAFXkYIUg5PPIxj1P6U3SrctcsitjC7wAeSVHqeORz+FdGEqNSai mpb/AJb9tP8Ahjx4puUYrTmsvTudi8BlRlddpUnaMYYHHJOOvJPH+R0Gk2O5B+7x82PQYwD6fWni LWqyb22+en4bG04KXI3rv92x3uk6KzlI4omYt0RASxPHQD731r6y8I+D9Yj8Hyrf6TdW8TBjBJLB Im5evRsY69/as8FiKcHyVJ8rktOmqaZvQws6TjUjolf5dP0sfMfxA0n+z5pgV2EM+BgDJ/zn868I utuXGR/FwFwe4JB7kYH+cV9Dg0vZqV7pPpvt+PbtqdU7ppR0tf7+vlsc9MNu7jGd3GBz/wB9dOpq rtZeq4Yg7eMAcAY44OTXs0nFL3Xpe9vLTT7t/meXWvGaTfL0t5O2i7aDTkA7s/3R82PlwATgAc0b VPzbhgcH5urFuMe2Ca6k0rLa7v8AJ7WX5+RnaNmkrXX/AAb69Lu3oQnb1PA3DIHqT6j/ADxUe2NS 2FUdBz8u1hkn+Q/T60r6RUVZP8LWVvv/AFdyXyNKDVtPvXQG2hQdi7ckrjBBHI/kTSFWBCFQOWII OCFGRgfrz/jUODhaUm3G/Tpaz2/H8Bcl0+bRK23psAGMbVJ6DPsMYGMcYP6UwqRk+WFCllzxkg8A ew6g8+lapu+itfReel/+B8gu29Fe7t20X/Av66DcAdNoODjk5BwM9uuSfbp61AEyAAOOCCpJI5A+ XjOevbtz3w9YxjBKzfTstdb+itZFL4lyqyVtPVtfhow5Ck5xjPGWU5z6fw8c/oajbquzCqS/AwGJ OMnn8u3WpXuuUvhXTR309PVryTuR1itHe9l6P/h3YXBwSQfl/iOQoUdPTjjn6fSmZ5UZADEADjAX nPA5/L6U04Nqd9Gn6ddflbT18zS6i7rRtbfhf8RpA+Y5AGeOCDg8EYx3yf8AJpq8AhQfvEYwRnsO uSfwJ7c1Kv7sbe6nJa7d0l30t6WIl7tknrfTy/z0uS7MNuCndyCOenrj8e5H6U8JgjAIxkMCMjaD 2Na8ylGEo6J9La2vb9LmUoWdou6V9baLz+Q4fKVbIB39DgArngf569alGMDcG5AIyCOfXnp1HX2p +458v9JPR+Xp5amjsoO7vby69+3kSLxgbhlSoPykjPtzkE89c9elMYEFuR3yOjAg88kelU42crLd r9F+GoU2te+jt92nl/w5TY7WOcfKRjkZ9Bkeh6dv6muQchlU84GOMdOPpkDOPTFOpCMopxdnLr2u tvwT82TGXInGS956/wCXy1+9CIVUFVAXbtRUC4Gc4OSOnXGO2PepxnjDHPCjc2MqAcYHU8/zFZyv enOLVtenpdfcadKfL7u+n4f16kqkNkMOny46bvw6jtTH4ViMbRtGMELjH9P89zTfI07ac1rP1u7e S8/Iaiox5Vvo13Wr0/IhZAwOPlA4GFI7ZOCe3J6Vm3AwBwxA9AFJ5xgYwDzzz69emHSam1Hltv5e treX4oxlz80baNJfLzMzauBkE5IYnqTxjBz6YHT3qxCvznavKNwwwGGc9z09M8daHNR1b5OV2a3a vsvmaxpvmab5bKz8l1ZoM/BUhVOeD6Dp0HTqf/1VGANxDZHy5AGABnoQTz14qXD3opQ5YpaXej16 f1saqUo+6vge3R30dtf6ucL45vFt9LELN88gBUMNuASBhPz6Hnp614XGi4TGCGHZjwT6/n6fyr1Y qMcPRUFyr3nb5v8APp5WPIxF/buLjyySV+n4easzUjjOIxgAKcZLDqcDoeR1J/Dmty1j+4vBbOFI wQc5+XHbuc1jOO/S39fkdFJSSXLHV6HT2IIOBkK23OGAx09OnUflXVaeifJtI3IeuMdcdc9SD25/ nXm4mT5eWl/Xf83+J9Dg7XjdPTZefQ6mJ0i2twpYkEdCenYdumOfSutsVTZGWCsxIbkAY77gTkjr /T0rxqisqUnJJz0v1vre66rb7j0ptqF+XZ2fS127/Kx0iEbRjoQu3OByewJ/KpISwyrc4YtkDqTn kg9O9ddNWUla3La/3d/XXyt5nn1ZtTiraO9/LS6/En2bApxjgEYPTIJwATnqcfhV6IsFXsADtBON ueTjP0xnjrTcY87jHVaO9rWem35mc7fZV2/lv+RGUDjpluTnPJPAGM8dvTuafGCGBA5U/K3AAIJJ zjocjFVUUoyTT5Xf/P8AQlXXNyqz/pk7lWUYUK6rkjqCo7n+eOKgClWGWwATjPUH+a0QlGNPljql ffe60t+P5A7xbSjZJ3fzT0/T7h6OnHy5y2RgYHfkjGf6+lPBBUDBAX5htPrgYxzn8jUWSVmmrq68 rPReWv8AWpad9tGkl89rCKBkqDjBAIxjJ5PT3zyR+Oe0DtiTcMBSMbcH73bt7jvjrTkuiVr3v312 07DTd7pPr5bafnqPSX2ClQSM4BA44x+X51We4Vgylec55I6dQPQU4Qio8+7tp0Xlp2JbqRkktYv5 dXf/ADPuWGXBOOOuQcDqf8M/nWrHJ90rwf0HXt+FaOSV9LJb99v62OPkale2pZ804GM5PXHXH9Kh aQAg8j6A849qxVVc+istl+D/AM0aezat/XUA4GB6ZbHc8U5ZOmM4xwen+frQqijGUbf1+YrX0jsS Ky8Y45ORkZIzz/n6VcifHy5HIHtgcf1NCmlF2jZtfmOzS91k2/j6e3vx9OaljYDAA7ZB6DH+RSUr N3irBZ9Fa/8AVy5GfmGRgA+4Oa0FlAKrnHbAwD6Hj861TtFRS+F/8P8A15icUr6en3I0IpBkdj9e npx2raicfZyv+zgjvkc1U24xcYqy6f8ADEW1jpb/AIY5HVcANjjacYBxjmuWdxknoDwM8da+PxiU MTUjG9/6ufQZcn7BR2tfTsVnYZwPl2n6fy9xmmqMYGAqgEHsQMdeK4nK0eVPW2nzO5J6q39aDknV HVGUKCOGHTsAP1H51eR0UDjsPwPqPzrNy5OXl1vf1Vn/AFYunzJyVrl2N1HQjPbP/wBepmdcgjC4 zznr9fas5TsouMdnt2XX8SuW3M7WtpYRrhBgE4xx6devJqhNcrkHPHK88DHb9Krmc7S2v20t/WgN O77/AKMa14q4xjgEE9Mn04/EVWkvYweoz2yenY1LvKat1FfVtbL8yu1/GOhHHOM4I4NUptTRAcEA nGORwP8AJqrLktezWv4js9+v6GBe6oCGG4H154yR344rzzWNUAVtx45GBjkc4/z9PwqKaactNdPP XT7tiZScW7Nq3/DHk2t3qlSQ4BG4lfmLdBjGBj1FeYaldF+ScDjg4OMHAz75z+VbS+FwTt5rza/L r2sY1FHRLS+m39WM5ZjuXjGMfMCOfzA+uRVyWQhPkGQQDtJ3EHoPQ4FcE2488Oz6vW2n+f4HkYtW k/dtb/glR5nWMqeDzjJxgjHIH4r/AJFWtNHlzRt7hcAZUHBHJ9OP5+tdNGoqdaMYrey0v5aL5vfy t1PFmpc8W9Ev+Hf+f3nf29ohAcDcjADg5ZDgZBA59TXcaFYhdgK8DA6YHT0PX0/OoxFX35LVfpbf 8PyPXoUOf2eu9/6/M94+Gmo6f4b8Sabq2oWK3ttaSq81uyqN6ZGQNw4PHX2r7p1D9ojw1qlgNE0n wz5EVzCYWmuJIwqArjCqig/jmvpuGstyTEYTMcXj8XGnXjF04Rau5X25emr0b9DkzTA5nUq4aGDX 7qn70ne23ktz4p+NPheCewfUrZfLJ3OpTBHIz06/1r4fvYTGXXgEFsEDnIP588Vjgak6XtaMt4vS /a/3dzrmrqDtayd107fnqc7O20915C/Mcc46Dp64qozYzgEFWx6DGc/jn8envXvUnyXcbWs9vL+v yPPqxXtHJL09O/y/UazAghTgEA7Txg4PXuOp5H/16g8vnOSP4Rgj8Dj/AD9K1v70Z9lbTtsvPY53 fmdla2l+1gXjA3tweRnjpyM/hjvTC5XhQO5APJAH6Y5/WqdSSjHS3M76bdtvS7IScYRjbbRfLT/M Quo4A+bH3egzznj09/8ACkLjI6DpkhmOMq3HAwCAeeR171UHLlle+ju9NtV9y2+Q9oRtdc3T73de ggO3ptGc8lSSeCB/Tt/9YLAErwvBywHPYkrzx0PTqfbrUnHnUYu6trbf+k/1Gk1ou11+O/6DQ4Oc ZXbkrg4Oevfp9f1qPc2AQAuAT94ge+cZ74NRH920t1BaX/rf8myGuZxsmr+ei11/MjYgADcQBgnn AGMDrg+4phcA4wV25ywxxgnue3+PSnzxlFWly6t/dfT7tvTXoOWjtCOsbeq/4fW4F4yo2hsY3ABg FJBA6njPb8TTC2CBgqMsCoOQeuB146d/WpT0fK7evTt6dvQG5SlJRj9/T+rjQRyoyucBBnseACBz 17Yx835SApyVIzyTs244zjjHT6YpuST5pLbt3sl+YrfzLlvou/kxwKgHbycBSy4GFBPc/jz3FOUr wFX/AGN5IwvPf1Ax0x2qrtOHIrcqs77rV/18wlJuU1GN0tfw6Ejbcf3gNq8FSoGOwHtUgYKfmHAX CnA4J9ifbt6/lrGp8Scb36/Ntr5EcnwxUrx1bXb1/rYTcBjbgAYwSAT27fh+X4YUsP4VGOnYY44x 06GqjU5dna36vX8LW9QguXaNl/l+vVIhd+MDgkjcMHsBxuBwOvBqnIqnO0jecMoBwRk+gHfv9aTl fV3ilLorbu362+8m0kuzS08+lvv/AAuQErk9exIABCnoeAc/pThIATgcf3SQB1HUdR90cn396xuo ynHWMIvXfTXdfl6MuKlqlHltZ/O39L5k6ucMBgYJGQVGG9iByOTk+opVkXK/NgDCZK/jgAZz0/rW jnBXhGV0o/d6+R0uPuObdmv6+79CvIUO5lY7QUG1uTnBOM4578Dpj88u6lKgAAhi5C7tynHTAOOM kEcfh7KjUklTi1aV3d/LTz/4Y5bx91y01e3Z9P66+ZRVhu4xgY53EDdjsD7+npWhCPLLHA5YbVyC eCeO2Dz19MVHvRlebsne1/LZ9nqaKF48t7rV36/8OSOy8BODgL8r/cC5B4OR6jOM8/SmFh8o+YnC jlcFR2weOBz+v4JfHHnbvdtLtd/luvkVNU7pRT92/wCK0+Z5P8R7nlIB/DjAyMAgfgMdD26V5hAy /KpbaA390hsY/UYwK9xP9zStppp8/wDgHl1pxdeUlG1189Fb9DUgOx2zgp2BABGeOckj+L+nSt+z VcpkNgHOQSOueQDyPqB2rmqvlXN33+7+vmdOHspK/wDSO2sLfCrtJC4GMr8oPAHPr3/P3zvRQkn9 0ykbQSdvuOPYH5vzrw605R521aCT+9LT73+p9ZhKL5YpNK23la50EEXlxrG4JGAODwpGcAg9OvY4 5Heuu08HYoC7SoJGMjI5HfpzntxXl1J05SpzcnZ3l6f5Oy/I3qxahOK1V+3TT/hjoFXdjkYUoDzn H1x35PT2q7EoAb5sluo6kcKfoO35E+tejRq+7F2utNO+p5tTkhdJbaf1+T8h444ZsDGRkAA4PQ+n rViNlAPJUEYXGAuTx/X26/mJvntspPT163/G/kZ2jJLm0V0+y/pEzA8Y6qfukAcd8GlD4BbhT8rc AOAD82AevHI/yMpv97Dmlbr9+hNlFSXLs9PXoKHGN3zEjHB549ABz2xSySJxyQpJIAAAA9Og+nar V3Zq3Xy2/r8CoLl0vchJEcbck9COm3J+nI69zVZJenzlWGRtPBGQCKHOXJNvq910to9PK33lJXbi tFff8PwsPGA42nAYAsuOe/TsByKkXC7SBngt2XB4H1B5JqHVmueVtZW106Oy/X5Gl3ZqMW7CsAwO 0BTx0YnjP4fniqkhVRnlWDhSSuEwMnt25znjoPam272u1bf7+3fb5+hV3Zx5b22/r5n/2Q= ________________________________________________________________________________
Subject: Re: Garmin GPS496 Antenna & XM antenna mounting
Date: Sep 10, 2008
It ain't beautiful, but it works. The Xaon XRX sits in from of the XM Puck -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3757#203757 Attachments: http://forums.matronics.com//files/p9090713_865.jpg ________________________________________________________________________________
Subject: Re: Weld-on 10 & crazing
Date: Sep 10, 2008
I am not flying yet, but had the same thing happen to me with one of my side windows. It is really frustrating and it seems 10x as big a deal with the front windscreen. It has not spread on mine, but it is not really subject to vibration yet. I am leaving it, but on the main windscreen, I would have to think about it. Stop drilling is always an option and works well on plexi. I did it on an old Piper Archer that I had. My three big beefs with the basically superb RV10 design are: 1)the structural windows that cannot be removed and replaced easily 2) the riveted down floors in the back with no inspection holes (I made some) and 3) electric pitch trim w/o manual backup -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3758#203758 ________________________________________________________________________________
Subject: Weld-on 10 & crazing
Date: Sep 11, 2008
Same thing happened to me. I have seen no growth since I have been flying...~50 hrs. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith Sent: Wednesday, September 10, 2008 10:58 PM Subject: RV10-List: Weld-on 10 & crazing Well folks I'm not a happy camper, Just finished installing my windshield with Weld-on 10, and there is crazing where some clamps were on the sides, photo & details below. So here are my questions: 1: How common is crazing at the glue joint? 1: If left as is will the crazing run across the window? 2: Is there anything (other than replacement) that will keep it from creeping? The crazing is small and can easily be hidden as long as it doesn't keep creeping. The fine print: I have installed all the other windows with no problems using foam blocks and straps to clamp it in place. The windshield was installed at 80 degrees. Main pressure was from a strap & foam blocks with additional clamps on sides (the area of the crazing.) Only rubbing alcohol was used for cleaning. Edges sanded completely smooth with no nick or scratches. The gluing surfaces were roughed up with 240 grit sand paper. The crazing was noticed 1 1/2 hours after I started the gluing process. At which time I removed the side clamps. And called Scott at Van's, he has requested pictures. Any help or suggestion would be appreciated, Vern Smith (#324 finishing sort of) _____ See how Windows Mobile brings your life togetgo/msnnkwxp1020093182mrt/direct/01/' target='_new'>See Now ________________________________________________________________________________
Subject: Spinner blade clearance
Date: Sep 11, 2008
Well, I'm sitting here on vacation at the outer banks (surf fish on Ocracoke Is. every Sept. for the past 45 yrs. -- was here on 9/11/01 also) ... and I'm building the -10 in my mind. Go figgur! The Hartzell prop came in right before I left and we temporarily mounted it in order to fit the cowl and spinner. As I recall, the instructions say to make sure the cut outs in the spinner for the blades have enough clearance through the pitch cycle ...????? It may be obvious (since I searched the archives and found no one else seems to have this problem), but how do you rotate the blades through their pitch manually? Later, - Lew (keeping an eye out for hurricanes and eating lots of fresh Bluefish -- there IS a landing strip out here, send me an email and I'll meet you there!) -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Engine and FF here, now cowl and baffels,waiting on prop. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3793#203793 ________________________________________________________________________________
Date: Sep 11, 2008
I clamped padded boards to the blades and then used the boards as a lever. I think the boards were only two feet or so. Gives you enough of a lever to move them. Sorry no pictures. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Thursday, September 11, 2008 7:34 AM Subject: RV10-List: Spinner blade clearance Well, I'm sitting here on vacation at the outer banks (surf fish on Ocracoke Is. every Sept. for the past 45 yrs. -- was here on 9/11/01 also) ... and I'm building the -10 in my mind. Go figgur! The Hartzell prop came in right before I left and we temporarily mounted it in order to fit the cowl and spinner. As I recall, the instructions say to make sure the cut outs in the spinner for the blades have enough clearance through the pitch cycle ...????? It may be obvious (since I searched the archives and found no one else seems to have this problem), but how do you rotate the blades through their pitch manually? Later, - Lew (keeping an eye out for hurricanes and eating lots of fresh Bluefish -- there IS a landing strip out here, send me an email and I'll meet you there!) -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Engine and FF here, now cowl and baffels,waiting on prop. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3793#203793 ________________________________________________________________________________
Date: Sep 11, 2008
Subject: Re: Spinner blade clearance
Why would you need to rotate the blades? Seems you could just measure widest spot on the blades at the root and ensure your opening is circular with a diameter of that widest spot plus 2 times the clearance value you want. Or am I missing something? Rene Felker wrote: > > I clamped padded boards to the blades and then used the boards as a lever. > I think the boards were only two feet or so. Gives you enough of a lever to > move them. Sorry no pictures. > > Rene' Felker > RV-10 N423CF Flying > 801-721-6080 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher > Sent: Thursday, September 11, 2008 7:34 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Spinner blade clearance > > > Well, I'm sitting here on vacation at the outer banks (surf fish on Ocracoke > Is. every Sept. for the past 45 yrs. -- was here on 9/11/01 also) ... and > I'm building the -10 in my mind. Go figgur! > > The Hartzell prop came in right before I left and we temporarily mounted it > in order to fit the cowl and spinner. As I recall, the instructions say to > make sure the cut outs in the spinner for the blades have enough clearance > through the pitch cycle ...????? > > It may be obvious (since I searched the archives and found no one else seems > to have this problem), but how do you rotate the blades through their pitch > manually? > > > Later, - Lew > (keeping an eye out for hurricanes and eating lots of fresh Bluefish -- > there IS a landing strip out here, send me an email and I'll meet you > there!) > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Engine and FF here, now cowl and baffels,waiting on prop. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3793#203793 > > > ________________________________________________________________________________
Date: Sep 11, 2008
You can twist it by hand, but using a couple of 2x4's with a 1x? spacer (as Rene mentioned) with a rag or foam padding makes it a little easier if you are doing it by yourself. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Sep 11, 2008, at 9:34 AM, Lew Gallagher wrote: > > Well, I'm sitting here on vacation at the outer banks (surf fish on > Ocracoke Is. every Sept. for the past 45 yrs. -- was here on > 9/11/01 also) ... and I'm building the -10 in my mind. Go figgur! > > The Hartzell prop came in right before I left and we temporarily > mounted it in order to fit the cowl and spinner. As I recall, the > instructions say to make sure the cut outs in the spinner for the > blades have enough clearance through the pitch cycle ...????? > > It may be obvious (since I searched the archives and found no one > else seems to have this problem), but how do you rotate the blades > through their pitch manually? > > > Later, - Lew > (keeping an eye out for hurricanes and eating lots of fresh > Bluefish -- there IS a landing strip out here, send me an email and > I'll meet you there!) > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Engine and FF here, now cowl and baffels,waiting on prop. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3793#203793 > > ________________________________________________________________________________
Date: Sep 11, 2008
Been a while since I did it. But.....the blades only rotate part way (degrees of pitch) and you do not end up with a circular hole. You could just cut the hole to fit worst case blade movement, but then you would end up with a larger gap than needed........might slow you down by .000000001 MPH.....:) Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, September 11, 2008 8:30 AM Subject: Re: RV10-List: Spinner blade clearance Why would you need to rotate the blades? Seems you could just measure widest spot on the blades at the root and ensure your opening is circular with a diameter of that widest spot plus 2 times the clearance value you want. Or am I missing something? Rene Felker wrote: > > I clamped padded boards to the blades and then used the boards as a lever. > I think the boards were only two feet or so. Gives you enough of a lever to > move them. Sorry no pictures. > > Rene' Felker > RV-10 N423CF Flying > 801-721-6080 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher > Sent: Thursday, September 11, 2008 7:34 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Spinner blade clearance > > > Well, I'm sitting here on vacation at the outer banks (surf fish on Ocracoke > Is. every Sept. for the past 45 yrs. -- was here on 9/11/01 also) ... and > I'm building the -10 in my mind. Go figgur! > > The Hartzell prop came in right before I left and we temporarily mounted it > in order to fit the cowl and spinner. As I recall, the instructions say to > make sure the cut outs in the spinner for the blades have enough clearance > through the pitch cycle ...????? > > It may be obvious (since I searched the archives and found no one else seems > to have this problem), but how do you rotate the blades through their pitch > manually? > > > Later, - Lew > (keeping an eye out for hurricanes and eating lots of fresh Bluefish -- > there IS a landing strip out here, send me an email and I'll meet you > there!) > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Engine and FF here, now cowl and baffels,waiting on prop. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 3793#203793 > > > ________________________________________________________________________________
Date: Sep 11, 2008
Amen on the Gull Wing Door -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3824#203824 ________________________________________________________________________________
Date: Sep 11, 2008
You know, the common thread I see when people bring up crazing with window installation is the use of clamps. I did use some clamps, but not very tight clamps on mine....I think I may have only used those squeeze clamps that you open with your hands. Either way, I didn't use tons of pressure, just used them to hold position. I had no crazing. I'm starting to wonder if the people having crazing aren't maybe using a bit more pressure on their clamps, or perhaps not spreading the force out enough on the windows. I'd say, pad the clamps, and don't clamp any tighter than necessary to hold the window in position. Don't try to squeeze out excess glue, just position it. I don't know WHY clamping with pressure would add to the problem, but I do notice that in almost all cases, the person said it either crazed where the clamps were, or at least that they had used clamps. I'm betting this is the cause somehow. Tim Olson - RV-10 N104CD - Flying Vernon Smith wrote: > Well folks I'm not a happy camper, > > Just finished installing my windshield with Weld-on 10, and there is > crazing where some clamps were on the sides, photo & details below. So > here are my questions: > > 1: How common is crazing at the glue joint? > > 1: If left as is will the crazing run across the window? > > 2: Is there anything (other than replacement) that will keep it from > creeping? The crazing is small and can easily be hidden as long as it > doesn't keep creeping. > > The fine print: I have installed all the other windows with no problems > using foam blocks and straps to clamp it in place. The windshield was > installed at 80 degrees. Main pressure was from a strap & foam blocks > with additional clamps on sides (the area of the crazing.) Only rubbing > alcohol was used for cleaning. Edges sanded completely smooth with no > nick or scratches. The gluing surfaces were roughed up with 240 grit > sand paper. > > The crazing was noticed 1 1/2 hours after I started the gluing process. > At which time I removed the side clamps. And called Scott at Van's, he > has requested pictures. > > Any help or suggestion would be appreciated, > > Vern Smith (#324 finishing sort of) > > ------------------------------------------------------------------------ > See how Windows Mobile brings your life > togetgo/msnnkwxp1020093182mrt/direct/01/' target='_new'>See Now > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Sep 11, 2008
Don't know for sure, but just assuming that the clamping pressure increases the temperature of the Weldon during the curing process. It would not take much initial clamp pressure to do that once the Weldon starts to expand during the curing process. I would add that in my case I wiped off the excess Weldon except for the area under the clamp. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 11, 2008 11:17 AM Subject: Re: RV10-List: Weld-on 10 & crazing You know, the common thread I see when people bring up crazing with window installation is the use of clamps. I did use some clamps, but not very tight clamps on mine....I think I may have only used those squeeze clamps that you open with your hands. Either way, I didn't use tons of pressure, just used them to hold position. I had no crazing. I'm starting to wonder if the people having crazing aren't maybe using a bit more pressure on their clamps, or perhaps not spreading the force out enough on the windows. I'd say, pad the clamps, and don't clamp any tighter than necessary to hold the window in position. Don't try to squeeze out excess glue, just position it. I don't know WHY clamping with pressure would add to the problem, but I do notice that in almost all cases, the person said it either crazed where the clamps were, or at least that they had used clamps. I'm betting this is the cause somehow. Tim Olson - RV-10 N104CD - Flying Vernon Smith wrote: > Well folks I'm not a happy camper, > > Just finished installing my windshield with Weld-on 10, and there is > crazing where some clamps were on the sides, photo & details below. So > here are my questions: > > 1: How common is crazing at the glue joint? > > 1: If left as is will the crazing run across the window? > > 2: Is there anything (other than replacement) that will keep it from > creeping? The crazing is small and can easily be hidden as long as it > doesn't keep creeping. > > The fine print: I have installed all the other windows with no problems > using foam blocks and straps to clamp it in place. The windshield was > installed at 80 degrees. Main pressure was from a strap & foam blocks > with additional clamps on sides (the area of the crazing.) Only rubbing > alcohol was used for cleaning. Edges sanded completely smooth with no > nick or scratches. The gluing surfaces were roughed up with 240 grit > sand paper. > > The crazing was noticed 1 1/2 hours after I started the gluing process. > At which time I removed the side clamps. And called Scott at Van's, he > has requested pictures. > > Any help or suggestion would be appreciated, > > Vern Smith (#324 finishing sort of) > > ------------------------------------------------------------------------ > See how Windows Mobile brings your life > togetgo/msnnkwxp1020093182mrt/direct/01/' target='_new'>See Now > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Sep 11, 2008
Hi Tim=2C I used the same hand type clamps as shown on your web site during install o f your window. All clamps were padded with layers of masking tape. There i s no sign of deflection of the acrylic during or after clamping=2C but mayb e hand springe clamps are not the best choice. The thought that direct pres sure on the Weld-on cause it to set off is an interesting idea. I am in contact with IPS technical service (they manufacture Weld-on) and t hey have the pictures also. It was suggested to try using a diluted deterge nt (two drops on non ammonium based dish soap in gallon of water) to clean the mating surfaces instead of the rubbing alcohol. Also there may be a nee d to anneal the acrylic before installing to normalize the internal stresse s of the plastic. They also said Weld-On 10 was a good choice for gluing ac rylic to fiberglass. As for repair they are working on it & I will pass along anything I learn. Van's did get back with me and here is Scott's reply: Vern=2C Thanks for the photos. This looks very similar to what we saw on bo th of our RV-10's. Spoke with the rest of the tech crew here and all input that we've had is that the crazing does not 'move' significantly after the weld-on sets up and clamps are removed. scott at van's Thanks=2C Vern Smith (#324) > Date: Thu=2C 11 Sep 2008 12:16:38 -0500> From: Tim(at)MyRV10.com> To: rv10- list(at)matronics.com> Subject: Re: RV10-List: Weld-on 10 & crazing> > --> RV1 0-List message posted by: Tim Olson > > You know=2C the com mon thread I see when people bring up crazing> with window installation is the use of clamps. I did use some> clamps=2C but not very tight clamps on m ine....I think I may have> only used those squeeze clamps that you open wit h your hands.> Either way=2C I didn't use tons of pressure=2C just used the m to> hold position. I had no crazing.> > I'm starting to wonder if the peo ple having crazing aren't> maybe using a bit more pressure on their clamps =2C or perhaps> not spreading the force out enough on the windows.> > I'd s ay=2C pad the clamps=2C and don't clamp any tighter than> necessary to hold the window in position. Don't try to> squeeze out excess glue=2C just posi tion it. I don't> know WHY clamping with pressure would add to the problem =2C> but I do notice that in almost all cases=2C the person> said it either crazed where the clamps were=2C or at least> that they had used clamps. I' m betting this is the cause> somehow.> > Tim Olson - RV-10 N104CD - Flying> > > > Vernon Smith wrote:> > Well folks I'm not a happy camper=2C> > > > J ust finished installing my windshield with Weld-on 10=2C and there is > > c razing where some clamps were on the sides=2C photo & details below. So > > here are my questions:> > > > 1: How common is crazing at the glue joint?> > > > 1: If left as is will the crazing run across the window?> > > > 2: I s there anything (other than replacement) that will keep it from > > creepi ng? The crazing is small and can easily be hidden as long as it > > doesn't keep creeping.> > > > The fine print: I have installed all the other windo ws with no problems > > using foam blocks and straps to clamp it in place. The windshield was > > installed at 80 degrees. Main pressure was from a st rap & foam blocks > > with additional clamps on sides (the area of the craz ing.) Only rubbing > > alcohol was used for cleaning. Edges sanded complete ly smooth with no > > nick or scratches. The gluing surfaces were roughed u p with 240 grit > > sand paper.> > > > The crazing was noticed 1 1/2 hours after I started the gluing process. > > At which time I removed the side cl amps. And called Scott at Van's=2C he > > has requested pictures.> > > > An y help or suggestion would be appreciated=2C> > > > Vern Smith (#324 finish ing sort of)> > > > ------------------------------------------------------- -----------------> > See how Windows Mobile brings your life > > togetgo/ms nnkwxp1020093182mrt/direct/01/' target='_new'>See Now> > ---------------- ========================> > > _________________________________________________________________ Get more out of the Web. Learn 10 hidden secrets of Windows Live. http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!5 50F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008 ________________________________________________________________________________
Date: Sep 11, 2008
Ahhhhhh!!!! You used rubbing alcohol!!! That's a definite no-no! There aren't that many things you can clean it with. Kerosene is one. There IS one thing that I used that I can't endorse, but can report on. During painting we used PPG DCX330 degreaser extensively in prep of things, INCLUDING all the window edges, and we tested it on the windshield scraps to make sure it wouldn't craze. So maybe that is an option. But yeah, NO SOLVENTS on the windshield for cleaning....that's definitely not a good idea. mild soap and water, maybe...but I'd be careful of anything else. kerosene obviously wouldn't be good pre-cleaning for paint....but might not be so bad pre-installation. Also, I'd leave any plastic on windows as long as possible. Tim Vernon Smith wrote: > > Hi Tim, > > I used the same hand type clamps as shown on your web site during > install of your window. All clamps were padded with layers of masking > tape. There is no sign of deflection of the acrylic during or after > clamping, but maybe hand springe clamps are not the best choice. The > thought that direct pressure on the Weld-on cause it to set off is an > interesting idea. > > I am in contact with IPS technical service (they manufacture Weld-on) > and they have the pictures also. It was suggested to try using a diluted > detergent (two drops on non ammonium based dish soap in gallon of water) > to clean the mating surfaces instead of the rubbing alcohol. Also there > may be a need to anneal the acrylic before installing to normalize the > internal stresses of the plastic. They also said Weld-On 10 was a good > choice for gluing acrylic to fiberglass. > > As for repair they are working on it & I will pass along anything I learn. > > Van's did get back with me and here is Scott's reply: > > /Vern, Thanks for the photos. This looks very similar to what we saw on > both of our RV-10's. > Spoke with the rest of the tech crew here and all input that we've had > is that the crazing does > not 'move' significantly after the weld-on sets up and clamps are > removed. scott at van's/ > // > // > /Thanks,/ > // > /Vern Smith (#324)/ > > > > Date: Thu, 11 Sep 2008 12:16:38 -0500 > > From: Tim(at)MyRV10.com > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Weld-on 10 & crazing > > > > > > You know, the common thread I see when people bring up crazing > > with window installation is the use of clamps. I did use some > > clamps, but not very tight clamps on mine....I think I may have > > only used those squeeze clamps that you open with your hands. > > Either way, I didn't use tons of pressure, just used them to > > hold position. I had no crazing. > > > > I'm starting to wonder if the people having crazing aren't > > maybe using a bit more pressure on their clamps, or perhaps > > not spreading the force out enough on the windows. > > > > I'd say, pad the clamps, and don't clamp any tighter than > > necessary to hold the window in position. Don't try to > > squeeze out excess glue, just position it. I don't > > know WHY clamping with pressure would add to the problem, > > but I do notice that in almost all cases, the person > > said it either crazed where the clamps were, or at least > > that they had used clamps. I'm betting this is the cause > > somehow. > > > > Tim Olson - RV-10 N104CD - Flying > > > > > > > > Vernon Smith wrote: > > > Well folks I'm not a happy camper, > > > > > > Just finished installing my windshield with Weld-on 10, and there is > > > crazing where some clamps were on the sides, photo & details below. So > > > here are my questions: > > > > > > 1: How common is crazing at the glue joint? > > > > > > 1: If left as is will the crazing run across the window? > > > > > > 2: Is there anything (other than replacement) that will keep it from > > > creeping? The crazing is small and can easily be hidden as long as it > > > doesn't keep creeping. > > > > > > The fine print: I have installed all the other windows with no > problems > > > using foam blocks and straps to clamp it in place. The windshield was > > > installed at 80 degrees. Main pressure was from a strap & foam blocks > > > with additional clamps on sides (the area of the crazing.) Only > rubbing > > > alcohol was used for cleaning. Edges sanded completely smooth with no > > > nick or scratches. The gluing surfaces were roughed up with 240 grit > > > sand paper. > > > > > > The crazing was noticed 1 1/2 hours after I started the gluing > process. > > > At which time I removed the side clamps. And called Scott at Van's, he > > > has requested pictures. > > > > > > Any help or suggestion would be appreciated, > > > > > > Vern Smith (#324 finishing sort of) > > > > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Sep 11, 2008
Mineral spirits are recommended by one of the windscreen companies. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 11, 2008 3:29 PM Subject: Re: RV10-List: Weld-on 10 & crazing Ahhhhhh!!!! You used rubbing alcohol!!! That's a definite no-no! There aren't that many things you can clean it with. Kerosene is one. There IS one thing that I used that I can't endorse, but can report on. During painting we used PPG DCX330 degreaser extensively in prep of things, INCLUDING all the window edges, and we tested it on the windshield scraps to make sure it wouldn't craze. So maybe that is an option. But yeah, NO SOLVENTS on the windshield for cleaning....that's definitely not a good idea. mild soap and water, maybe...but I'd be careful of anything else. kerosene obviously wouldn't be good pre-cleaning for paint....but might not be so bad pre-installation. Also, I'd leave any plastic on windows as long as possible. Tim Vernon Smith wrote: > > Hi Tim, > > I used the same hand type clamps as shown on your web site during > install of your window. All clamps were padded with layers of masking > tape. There is no sign of deflection of the acrylic during or after > clamping, but maybe hand springe clamps are not the best choice. The > thought that direct pressure on the Weld-on cause it to set off is an > interesting idea. > > I am in contact with IPS technical service (they manufacture Weld-on) > and they have the pictures also. It was suggested to try using a diluted > detergent (two drops on non ammonium based dish soap in gallon of water) > to clean the mating surfaces instead of the rubbing alcohol. Also there > may be a need to anneal the acrylic before installing to normalize the > internal stresses of the plastic. They also said Weld-On 10 was a good > choice for gluing acrylic to fiberglass. > > As for repair they are working on it & I will pass along anything I learn. > > Van's did get back with me and here is Scott's reply: > > /Vern, Thanks for the photos. This looks very similar to what we saw on > both of our RV-10's. > Spoke with the rest of the tech crew here and all input that we've had > is that the crazing does > not 'move' significantly after the weld-on sets up and clamps are > removed. scott at van's/ > // > // > /Thanks,/ > // > /Vern Smith (#324)/ > > > > Date: Thu, 11 Sep 2008 12:16:38 -0500 > > From: Tim(at)MyRV10.com > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Weld-on 10 & crazing > > > > > > You know, the common thread I see when people bring up crazing > > with window installation is the use of clamps. I did use some > > clamps, but not very tight clamps on mine....I think I may have > > only used those squeeze clamps that you open with your hands. > > Either way, I didn't use tons of pressure, just used them to > > hold position. I had no crazing. > > > > I'm starting to wonder if the people having crazing aren't > > maybe using a bit more pressure on their clamps, or perhaps > > not spreading the force out enough on the windows. > > > > I'd say, pad the clamps, and don't clamp any tighter than > > necessary to hold the window in position. Don't try to > > squeeze out excess glue, just position it. I don't > > know WHY clamping with pressure would add to the problem, > > but I do notice that in almost all cases, the person > > said it either crazed where the clamps were, or at least > > that they had used clamps. I'm betting this is the cause > > somehow. > > > > Tim Olson - RV-10 N104CD - Flying > > > > > > > > Vernon Smith wrote: > > > Well folks I'm not a happy camper, > > > > > > Just finished installing my windshield with Weld-on 10, and there is > > > crazing where some clamps were on the sides, photo & details below. So > > > here are my questions: > > > > > > 1: How common is crazing at the glue joint? > > > > > > 1: If left as is will the crazing run across the window? > > > > > > 2: Is there anything (other than replacement) that will keep it from > > > creeping? The crazing is small and can easily be hidden as long as it > > > doesn't keep creeping. > > > > > > The fine print: I have installed all the other windows with no > problems > > > using foam blocks and straps to clamp it in place. The windshield was > > > installed at 80 degrees. Main pressure was from a strap & foam blocks > > > with additional clamps on sides (the area of the crazing.) Only > rubbing > > > alcohol was used for cleaning. Edges sanded completely smooth with no > > > nick or scratches. The gluing surfaces were roughed up with 240 grit > > > sand paper. > > > > > > The crazing was noticed 1 1/2 hours after I started the gluing > process. > > > At which time I removed the side clamps. And called Scott at Van's, he > > > has requested pictures. > > > > > > Any help or suggestion would be appreciated, > > > > > > Vern Smith (#324 finishing sort of) > > > > > > ________________________________________________________________________________
Date: Sep 11, 2008
I work with acrylics every day in my job as an engineer in the medical device industry. Acrylics in general can stand stress, or exposure to alcohol (or other solvents) but not at the same time. They, like many plastics, are subject to a phenomenom known as "stress cracking", which starts as crazing. It is caused by the material having stress (either molded in or induced by a load, such as a clamp) while being exposed to a chemical, and the result is a crack at a stress far lower than would normally cause a crack to start. The good news is that once the solvent and/or the stress is removed, the crazing stops and is not likely to spread, so if the crazing doesn't show, you probably won't have to replace the windshield. Jack Phillips #40610 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 11, 2008 4:29 PM Subject: Re: RV10-List: Weld-on 10 & crazing Ahhhhhh!!!! You used rubbing alcohol!!! That's a definite no-no! There aren't that many things you can clean it with. Kerosene is one. There IS one thing that I used that I can't endorse, but can report on. During painting we used PPG DCX330 degreaser extensively in prep of things, INCLUDING all the window edges, and we tested it on the windshield scraps to make sure it wouldn't craze. So maybe that is an option. But yeah, NO SOLVENTS on the windshield for cleaning....that's definitely not a good idea. mild soap and water, maybe...but I'd be careful of anything else. kerosene obviously wouldn't be good pre-cleaning for paint....but might not be so bad pre-installation. Also, I'd leave any plastic on windows as long as possible. Tim Vernon Smith wrote: > > Hi Tim, > > I used the same hand type clamps as shown on your web site during > install of your window. All clamps were padded with layers of masking > tape. There is no sign of deflection of the acrylic during or after > clamping, but maybe hand springe clamps are not the best choice. The > thought that direct pressure on the Weld-on cause it to set off is an > interesting idea. > > I am in contact with IPS technical service (they manufacture Weld-on) > and they have the pictures also. It was suggested to try using a diluted > detergent (two drops on non ammonium based dish soap in gallon of water) > to clean the mating surfaces instead of the rubbing alcohol. Also there > may be a need to anneal the acrylic before installing to normalize the > internal stresses of the plastic. They also said Weld-On 10 was a good > choice for gluing acrylic to fiberglass. > > As for repair they are working on it & I will pass along anything I learn. > > Van's did get back with me and here is Scott's reply: > > /Vern, Thanks for the photos. This looks very similar to what we saw on > both of our RV-10's. > Spoke with the rest of the tech crew here and all input that we've had > is that the crazing does > not 'move' significantly after the weld-on sets up and clamps are > removed. scott at van's/ > // > // > /Thanks,/ > // > /Vern Smith (#324)/ > > > > Date: Thu, 11 Sep 2008 12:16:38 -0500 > > From: Tim(at)MyRV10.com > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Weld-on 10 & crazing > > > > > > You know, the common thread I see when people bring up crazing > > with window installation is the use of clamps. I did use some > > clamps, but not very tight clamps on mine....I think I may have > > only used those squeeze clamps that you open with your hands. > > Either way, I didn't use tons of pressure, just used them to > > hold position. I had no crazing. > > > > I'm starting to wonder if the people having crazing aren't > > maybe using a bit more pressure on their clamps, or perhaps > > not spreading the force out enough on the windows. > > > > I'd say, pad the clamps, and don't clamp any tighter than > > necessary to hold the window in position. Don't try to > > squeeze out excess glue, just position it. I don't > > know WHY clamping with pressure would add to the problem, > > but I do notice that in almost all cases, the person > > said it either crazed where the clamps were, or at least > > that they had used clamps. I'm betting this is the cause > > somehow. > > > > Tim Olson - RV-10 N104CD - Flying > > > > > > > > Vernon Smith wrote: > > > Well folks I'm not a happy camper, > > > > > > Just finished installing my windshield with Weld-on 10, and there is > > > crazing where some clamps were on the sides, photo & details below. So > > > here are my questions: > > > > > > 1: How common is crazing at the glue joint? > > > > > > 1: If left as is will the crazing run across the window? > > > > > > 2: Is there anything (other than replacement) that will keep it from > > > creeping? The crazing is small and can easily be hidden as long as it > > > doesn't keep creeping. > > > > > > The fine print: I have installed all the other windows with no > problems > > > using foam blocks and straps to clamp it in place. The windshield was > > > installed at 80 degrees. Main pressure was from a strap & foam blocks > > > with additional clamps on sides (the area of the crazing.) Only > rubbing > > > alcohol was used for cleaning. Edges sanded completely smooth with no > > > nick or scratches. The gluing surfaces were roughed up with 240 grit > > > sand paper. > > > > > > The crazing was noticed 1 1/2 hours after I started the gluing > process. > > > At which time I removed the side clamps. And called Scott at Van's, he > > > has requested pictures. > > > > > > Any help or suggestion would be appreciated, > > > > > > Vern Smith (#324 finishing sort of) > > > > > > ________________________________________________________________________________
Subject: Fire rated foam insulation
Date: Sep 12, 2008
I came across a fire rated expanding foam insulation that sounds like it might work for those who wish they had insulated their floors. It's called Abesco FP200 and it sounds like it would work. The biggest gripe from folks who have used it is that it doesn't expand as much as they expect - a good thing for us. Here is a spec sheet: http://images.cableorganizer.com/abesco-FP200/Abesco%20FP200%20FR%20Expanding%20Foam%20(DS6).pdf John -------- #40572 QB Fuselage, wings finished N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3948#203948 ________________________________________________________________________________
Date: Sep 12, 2008
Vern, I had the same problem when I installed my windshield. Decided it was going to be far easier to replace the windshield right away and risk having problems after fairing and paint and glad I did. When I started knocking the bad windshield out it cracked quite readily from those crazed areas. Based on talks with a buddy of mine who's blown several of bubble canopies we suspect the "problem" windshields are being blown at a slightly lower temperature or are being allowed to cool faster after blowing. Perry Casson C-FMHP ________________________________________________________________________________
Date: Sep 12, 2008
I did get an answer from the tech group at IPS the makers of Weld-On10 abou t possible repairs. They don't recommend using Weld-On 3 ( a capillary acti on cement) for surface cracks/crazing as it can make the cracks worse. Only other idea they had was try removing the cracks mechanically with somethin g like Micro-Mesh or leave them alone. So there you have the options: 1. Leave them alone 2. Try buffing them out 3. Replace the window Again I would like to thank everyone for their thoughts and encouragement. vern > Date: Fri=2C 12 Sep 2008 08:57:15 -0600> From: pcasson(at)sasktel.net> Subje ct: RV10-List: Weld-on 10 & crazing> To: rv10-list(at)matronics.com> > --> RV1 0-List message posted by: Perry Casson > > Vern=2C > > I had the same problem when I installed my windshield. Decided it was goin g> to be far easier to replace the windshield right away and risk having> p roblems after fairing and paint and glad I did. When I started knocking> th e bad windshield out it cracked quite readily from those crazed areas.> Bas ed on talks with a buddy of mine who's blown several of bubble canopies> we suspect the "problem" windshields are being blown at a slightly lower> tem perature or are being allowed to cool faster after blowing.> > Perry Casson > C-FMHP > _________________________________________________________________ Get more out of the Web. Learn 10 hidden secrets of Windows Live. http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!5 50F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008 ________________________________________________________________________________
Date: Sep 12, 2008
I'd be exceptionally cautious about using this site as a guide for what to put on my windshield: > http://www.ridoutplastics.com/plexiglas-chemical-resistance.html For example, they rate ammonium hydroxide as "excellent". John > > > Not sure exactly what type of "plastic" our windows are made of, but > the list at the link below gives the effects of using various > solvents/substances on acrylic plexiglass and I figure ours is > pretty close. It's a pretty inclusive list, and I used it as a > guide for figuring out what substances to avoid (anything with an > "N" in both columns). Isopropyl alcohol is not so good. Ethyl > alcohol is better if you can find it without any additives. > http://www.ridoutplastics.com/plexiglas-chemical-resistance.html > ________________________________________________________________________________
Date: Sep 12, 2008
Sorry to hear of your crazing Vern. I appreciate this thread and the responses on what to do and not do to install the windows without crazing or other issues it will serve me well when I go to do them myself. Thanks all for the insight! Pascal From: Vernon Smith Sent: Friday, September 12, 2008 11:47 AM Subject: RE: RV10-List: Weld-on 10 & crazing I did get an answer from the tech group at IPS the makers of Weld-On10 about possible repairs. They don't recommend using Weld-On 3 ( a capillary action cement) for surface cracks/crazing as it can make the cracks worse. Only other idea they had was try removing the cracks mechanically with something like Micro-Mesh or leave them alone. So there you have the options: 1. Leave them alone 2. Try buffing them out 3. Replace the window Again I would like to thank everyone for their thoughts and encouragement. vern ------------------------------------------------------------------------- ------- > Date: Fri, 12 Sep 2008 08:57:15 -0600 > From: pcasson(at)sasktel.net > Subject: RV10-List: Weld-on 10 & crazing > To: rv10-list(at)matronics.com > > > Vern, > > I had the same problem when I installed my windshield. Decided it was going > to be far easier to replace the windshield right away and risk having > problems after fairing and paint and glad I did. When I started knocking > the bad windshield out it cracked quite readily from those crazed areas. > Based on talks with a buddy of mine who's blown several of bubble canopies > we suspect the "problem" windshields are being blown at a slightly lower > temperature or are being allowed to cool faster after blowing. > > Perry Casson > C-FMHP > ------------------------------------------------------------------------- ------- Get more out of the Web. Learn 10 hidden secrets of Windows Live. Learn Now ________________________________________________________________________________
Subject: Re: Aluminum Windshield Fairing
Date: Sep 10, 2008
I would like to talk to Dick. I was at his home/hangar for a Minnesota Wing meeting last winter when the FADEC guy was the speaker. I did not get a chance to look at Dick's airplane. BTW, thanks for the fuel labels. Your check is enroute. Regards, David Maib 40559 On Sep 10, 2008, at 6:57 AM, gary wrote: Dick Nordquist from the Lino Air park made metal fairings for everything on his 6. He can tell you the good and the bad. Let me know if you want contact info. Gary Specketer 40274 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dmaib(at)mac.com Sent: Tuesday, September 09, 2008 11:58 PM Subject: RV10-List: Aluminum Windshield Fairing Has anyone tried fabricating an aluminum windshield front fairing instead of the fiberglass? I seem to remember seeing one, but cannot find anything in the archives. I have access to some pretty sophisticated metal forming equipment, so the thought crossed my mind.............. -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p 3503#203503 ________________________________________________________________________________
Subject: GPS Antenna template
Date: Sep 13, 2008
I haven't purchased my IFR GPS yet but would like to fashion a doubler plate for the antenna. Does anyone have a detailed drawing of the antenna that comes with the GNS430W unit? I have the antenna that comes with the Apollo GX-65 GPS/COM. Are the mounting holes the same? If I use that to drill my holes will the WAAS antenna bolt up ok? Thanks, -Ben Westfall ________________________________________________________________________________
Subject: Re: GPS Antenna template
Date: Sep 13, 2008
rv10(at)sinkrate.com wrote: > I havent purchased my IFR GPS yet but would like to fashion a doubler plate for the antenna. Does anyone have a detailed drawing of the antenna that comes with the GNS430W unit? > > I have the antenna that comes with the Apollo GX-65 GPS/COM. Are the mounting holes the same? If I use that to drill my holes will the WAAS antenna bolt up ok? > > Thanks, > > -Ben Westfall > The GPS antenna I received with my 430W was a GA35. I have attached a copy of the installation sheet that came with the antenna. Hope this helps. -------- Gary Blankenbiller RV10 - # 40674 Instrument Panel, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 4159#204159 Attachments: http://forums.matronics.com//files/ga35a_669.jpg ________________________________________________________________________________
Subject: MT vs Whirlwind
Date: Sep 13, 2008
Well I am at the Reno Air aces. I was talking to American Propeller / Eagle Engines (They did the engine and prop for our Saratoga) They were recommending the Whirlwind over the MT for the RV-10 due to the fact the Whirlwind is all Carbon fiber composite prop not Wood/composite. Has any one in the RV-10 world use or have a Whirlwind prop. I would like to more info on this. Thanks John G. Cumins 40864 Emp. Kit Rudder ________________________________________________________________________________
Date: Sep 13, 2008
Whirlwind customer service should be thoroughly researched before spending the money. They would not repair a three blade Whirlwind system that needed some attention. It was sold to a hobbyist to be shortened and mounted on an airboat. Went with the MT 3 blade. Yes the MT has a wood (dampening) core. Don't ask me how I know. One of the big advantages of a composite vs. metal prop is the range of repairs that an owner/mechanic can do and the extended life of the product. American Propeller does some damned fine paint jobs on Aero props. I can give you a dozen painted three blade composites and not one will be a Whirlwind. YMMV John Cox 40600 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Saturday, September 13, 2008 4:52 PM Subject: RV10-List: MT vs Whirlwind Well I am at the Reno Air aces. I was talking to American Propeller / Eagle Engines (They did the engine and prop for our Saratoga) They were recommending the Whirlwind over the MT for the RV-10 due to the fact the Whirlwind is all Carbon fiber composite prop not Wood/composite. Has any one in the RV-10 world use or have a Whirlwind prop. I would like to more info on this. Thanks John G. Cumins 40864 Emp. Kit Rudder ________________________________________________________________________________
Date: Sep 13, 2008
Subject: Re: MT vs Whirlwind
Any word on Aerocomposite,(besides pricey) that a few RV10 owners selected? On Sat, Sep 13, 2008 at 5:50 PM, John Cox wrote: > Whirlwind customer service should be thoroughly researched before spending > the money. They would not repair a three blade Whirlwind system that needed > some attention. It was sold to a hobbyist to be shortened and mounted on an > airboat. Went with the MT 3 blade. Yes the MT has a wood (dampening) > core. Don't ask me how I know. > > > One of the big advantages of a composite vs. metal prop is the range of > repairs that an owner/mechanic can do and the extended life of the product. > American Propeller does some damned fine paint jobs on Aero props. I can > give you a dozen painted three blade composites and not one will be a > Whirlwind. > > > YMMV > > > John Cox > > 40600 > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins > Sent: Saturday, September 13, 2008 4:52 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: MT vs Whirlwind > > > Well I am at the Reno Air aces. I was talking to American Propeller / Eagle > Engines (They did the engine and prop for our Saratoga) They were > recommending the Whirlwind over the MT for the RV-10 due to the fact the > Whirlwind is all Carbon fiber composite prop not Wood/composite. > > > Has any one in the RV-10 world use or have a Whirlwind prop. > > > I would like to more info on this. > > > Thanks > > > John G. Cumins > > 40864 Emp. Kit Rudder > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Sep 13, 2008
There are a dozen testimonials lurking online. I count six with custom paint jobs flying right now. My collection of painted and flying RV-10s is getting downright exciting. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, September 13, 2008 7:38 PM Subject: Re: RV10-List: MT vs Whirlwind Any word on Aerocomposite,(besides pricey) that a few RV10 owners selected? ________________________________________________________________________________
Subject: Firewall penetrations - electrical
Date: Sep 14, 2008
I see where some of the already built 10's have a really cool "firesleeve" that wires go through on the firewall. It looks like a tube with a flange on the bottom. The flange attaches to the firewall. The tube allows an excellent air and fire seal. Where do I get these??? -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin top/door purgatory Read this topic online here: http://forums.matronics.com/viewtopic.php?p 4213#204213 ________________________________________________________________________________
Date: Sep 14, 2008
Subject: Re: Door Seals - Again
I found that when I installed the Vans seals per the illustration (Page 45-17, figure 2) the door fit was negatively impacted by the seal. Both doors now stuck up above the cabin lid. I ripped out the seals and replaced them with new Van's seals, but this time I placed the seal so that the lower edge of the seal flange fit snugly against the door wall (all the way down, in figure 2). During cure, the Van's seals were held in place with pieces of mixing stick (reduced in width). This worked much better. Photos attached. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction McGANN, Ron wrote: > > The Vans standard door seal is glued in place rather than rivetted. My > doors sat a little proud after installation of the seal. I'm with > Michael S. - I did not report the condition to Vans and just worked the > cabin top/door intersection to smooth the fit. Just another issue with > the (less than fun) construction of the doors. I have also noticed that > I have contacted Vans on build issues much less frequently during the > finishing activities, deferring to the collective experience of the > list. But I am surprised that Van does not recognise the weaknesses in > the door design compared to the rest of the kit. > > Cheers > Ron > 187 painting > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday, 3 September 2008 7:23 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Door Seals - Again > > > I saw quite a few different seals at OSH. From what I can gather, Vans > is not the preferred seal. Thoug with those owners that have installed > the Van's seal the seal seems to be working well and there is little > complaint on noise or air intrusion. One big complaint aside from the > lack of nice appearance is that you have to use pop rivets, and if you > need to change the seal (drill out the pop rivets), you will have the > rivet ends rattling around inside the door. > > I did see seals from AIRCRAFT DOOR SEAL LLC called the "Incredible > Aircraft door seal" see aircraftdoorseals.com > > He did give me a sample, but I did not get any feedback from those who > have installed it. any feedback on this product is appreciated. > > -------- > OSH '08 or Bust (busted) be there in "09 Q/B Kit - exited cabin > top/door purgatory > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 2189#202189 > > > "Warning: > The information contained in this email and any attached files is > confidential to BAE Systems Australia. If you are not the intended > recipient, any use, disclosure or copying of this email or any > attachments is expressly prohibited. If you have received this email > in error, please notify us immediately. VIRUS: Every care has been > taken to ensure this email and its attachments are virus free, > however, any loss or damage incurred in using this email is not the > sender's responsibility. It is your responsibility to ensure virus > checks are completed before installing any data sent in this email to > your computer." > > > > ------------------------------------------------------------------------ > > > Checked by AVG - http://www.avg.com > > ________________________________________________________________________________
Subject: Re: Firewall penetrations - electrical
Date: Sep 14, 2008
I got mine a year or so ago from: EPM.AV Corp www.epm-avcorp.com 195 N. 700W. Escalante, Utah 84726 (435)826-4601 The URL did not work for me today - you may want to try the phone ... John 40458 On Sep 14, 2008, at 4:39 AM, AirMike wrote: > > I see where some of the already built 10's have a really cool > "firesleeve" that wires go through on the firewall. It looks like a > tube with a flange on the bottom. The flange attaches to the > firewall. The tube allows an excellent air and fire seal. > > Where do I get these??? > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - exited cabin top/door purgatory > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 4213#204213 > > ________________________________________________________________________________
From: "James, Peter [SD]" <Peter.James(at)sprint.com>
Date: Sep 14, 2008
Hello fellow -10r's, I think there has been way too much made of gluing in windows, crazing, alt ernative glues, etc. I was scared to death to do mine after all the posts. It was a learning process, but didn't go nearly as bad as I expected .... . So here is what I did - take it or leave it: True: Weld-on is some of the gooiest stuff I have ever worked with...worse than pro-seal. The big problem is that it likes to 'string'...and it gets everywhere...just like pro-seal, it can jump 10 feet Put the window where you want it. Drill holes and cleco and fender washer the window in place. This does NOT put a lot of pressure on the window. It DOES allow the window to spring out to the exact shape of the canopy. T his is a GOOD thing. Draw a line with one of your kids Crayola washable markers (fine line) on t he inside. Take the window out. Use Black electrical tape to seal the window up to th e Crayola marker line. Get the seal nice and smooth and nice and tight to the line. Then come back over the electrical tape with BLUE tape. It doesn't have to get right to the edge of the electrical tape, but pretty close. I might e ven consider a second layer of blue tape. Do the same thing on the outside of the window...right out to the edge. IMPORTANT: Also blue tape a coupl e of layers on the outside of the fuselage around the window well. This wi ll be important to keep the Weld-on off the fuselage as you glue the window s in. YES - blue tape is expensive - but don't scrimp here. Get a 2 or 3" wide band of tape around the wells. Sand the inside flange with sandpaper - clean with ISOPROPYL alcohol from t he DRUG STORE - get the purest stuff they have. Remember not to leave it o pen as I it will absorb moisture from the air. I'm not sure that it matter s in this case, but I like the stuff to be as potent as possible for future uses. To glue in the window have 2 buddies over to help! One will be inside the plane, the other on the outside. Smear the mixed Weld-on 10 on the flange. Mine was somewhat runny.... It w ill try and run on you. MOVE FAST!!! Mine set in FAR less than the 20 min ute pot-life it is supposed to have. Gently set the window in place. DO NOT PRESS IT IN! If you do, the glue w ill squeeze out when you press in, the window will then 'spring' back to th e cleco and fender washers - leaving a big air pocket where the glue squeez ed out. Some of this is just plain going to happen. I will talk about tha t later. Have Buddy number 2 start clecoing and fender washering the windo w. Hit the four corners, and a few other places, then grab pliers, clecos, and washers and get them in. Don't delay. You want time to clean up and work with this stuff before it sets. The glue is going to be a mess! Have blue shop towels and a couple of plas tic resin spreaders handy. I took a couple spreaders to my band saw and cu t a couple of varying widths.. These are plastic and won't scratch the win dow. The also are stiff enough to scrape the excess glue off. Buddy numbe r 1 will be inside, scraping any excess off as it squeezes out. If you don 't have someone inside, this stuff will drip on you fuselage interior and w on't be easy to clean up or sand off later. If you did a good job of taping, you will be scraping the extra glue off th e BLUE TAPE - inside and out. Keep in mind, on the outside, you will have to scrape around the clecos and fender washers. Get the bulk off quickly. Next - again, moving very fast - pull the first layer of blue tape off. Th is will get the bulk of extra glue off and away from the plane. Have a big waste basket or paper bag nearby...because just like pro-seal - this stuff can jump 10 feet and get on anything and everything. On the outside of th e plane, you will have your extra buddy pull a cleco - you pull the tape pa st the hole, then have him put the cleco right back in. It should now be s etting on the second layer of tape, or the electrical tape. Go all the way around the windows, cleaning, peeling a layer of tape, clean ing, peeling a layer of tape. By the time you are done, the glue will be V ERY solid. It won't be impossible to get off, but it won't be easy. I the n used a metal square tip knife, to get the final remnants off the window o n the inside and outside of the fuselage. By using clecos and fender washers, the clamp force is regulated or elimina ted if the window has sprung up to 'meet' the fender washer. I did not get ANY crazing at all...not even one place. My result was not perfect. I le arned the lesson of pushing the window in too far, having it spring back, a nd leave a big air pocket the hard way on the first window. I later came b ack with a tiny drill....used a light and drilled two holes, then used a sy ringe with no needle to fill the sir pockets with weld-on. (I have extra w eld-on since I had some that had expired and I ordered fresh for the main p rocess.) The cleco holes are now filled with epoxy and the high strength West System s Adhesive filler. You will never know that there was a hole there. My results are not perfect, but they are not bad. The real key is to move fast. We did this on a warm summer evening...and the Weld-on went to set i n a real hurry. These are my experiences - you can use them - laugh at them - or ignore the m. I just know that it worked pretty well for my building team. I'd be ha ppy to answer any questions as this one of the most intimidating steps in t he whole kit. Pete #40100 - plan to have it Osh next year. ________________________________________________________________________________
Date: Sep 14, 2008
Congrats on your success. Looking forward to seeing it at OSH '09. John Cox From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James, Peter [SD] Sent: Sunday, September 14, 2008 8:59 AM Subject: Re: RV10-List: Weld-on 10 & crazing Hello fellow -10r's, I think there has been way too much made of gluing in windows, crazing, alternative glues, etc. I was scared to death to do mine after all the posts. It was a learning process, but didn't go nearly as bad as I expected ..... So here is what I did - take it or leave it: True: Weld-on is some of the gooiest stuff I have ever worked with...worse than pro-seal. The big problem is that it likes to 'string'...and it gets everywhere...just like pro-seal, it can jump 10 feet Put the window where you want it. Drill holes and cleco and fender washer the window in place. This does NOT put a lot of pressure on the window. It DOES allow the window to spring out to the exact shape of the canopy. This is a GOOD thing. Draw a line with one of your kids Crayola washable markers (fine line) on the inside. Take the window out. Use Black electrical tape to seal the window up to the Crayola marker line. Get the seal nice and smooth and nice and tight to the line. Then come back over the electrical tape with BLUE tape. It doesn't have to get right to the edge of the electrical tape, but pretty close. I might even consider a second layer of blue tape. Do the same thing on the outside of the window...right out to the edge. IMPORTANT: Also blue tape a couple of layers on the outside of the fuselage around the window well. This will be important to keep the Weld-on off the fuselage as you glue the windows in. YES - blue tape is expensive - but don't scrimp here. Get a 2 or 3" wide band of tape around the wells. Sand the inside flange with sandpaper - clean with ISOPROPYL alcohol from the DRUG STORE - get the purest stuff they have. Remember not to leave it open as I it will absorb moisture from the air. I'm not sure that it matters in this case, but I like the stuff to be as potent as possible for future uses. To glue in the window have 2 buddies over to help! One will be inside the plane, the other on the outside. Smear the mixed Weld-on 10 on the flange. Mine was somewhat runny.... It will try and run on you. MOVE FAST!!! Mine set in FAR less than the 20 minute pot-life it is supposed to have. Gently set the window in place. DO NOT PRESS IT IN! If you do, the glue will squeeze out when you press in, the window will then 'spring' back to the cleco and fender washers - leaving a big air pocket where the glue squeezed out. Some of this is just plain going to happen. I will talk about that later. Have Buddy number 2 start clecoing and fender washering the window. Hit the four corners, and a few other places, then grab pliers, clecos, and washers and get them in. Don't delay. You want time to clean up and work with this stuff before it sets. The glue is going to be a mess! Have blue shop towels and a couple of plastic resin spreaders handy. I took a couple spreaders to my band saw and cut a couple of varying widths.. These are plastic and won't scratch the window. The also are stiff enough to scrape the excess glue off. Buddy number 1 will be inside, scraping any excess off as it squeezes out. If you don't have someone inside, this stuff will drip on you fuselage interior and won't be easy to clean up or sand off later. If you did a good job of taping, you will be scraping the extra glue off the BLUE TAPE - inside and out. Keep in mind, on the outside, you will have to scrape around the clecos and fender washers. Get the bulk off quickly. Next - again, moving very fast - pull the first layer of blue tape off. This will get the bulk of extra glue off and away from the plane. Have a big waste basket or paper bag nearby...because just like pro-seal - this stuff can jump 10 feet and get on anything and everything. On the outside of the plane, you will have your extra buddy pull a cleco - you pull the tape past the hole, then have him put the cleco right back in. It should now be setting on the second layer of tape, or the electrical tape. Go all the way around the windows, cleaning, peeling a layer of tape, cleaning, peeling a layer of tape. By the time you are done, the glue will be VERY solid. It won't be impossible to get off, but it won't be easy. I then used a metal square tip knife, to get the final remnants off the window on the inside and outside of the fuselage. By using clecos and fender washers, the clamp force is regulated or eliminated if the window has sprung up to 'meet' the fender washer. I did not get ANY crazing at all...not even one place. My result was not perfect. I learned the lesson of pushing the window in too far, having it spring back, and leave a big air pocket the hard way on the first window. I later came back with a tiny drill....used a light and drilled two holes, then used a syringe with no needle to fill the sir pockets with weld-on. (I have extra weld-on since I had some that had expired and I ordered fresh for the main process.) The cleco holes are now filled with epoxy and the high strength West Systems Adhesive filler. You will never know that there was a hole there. My results are not perfect, but they are not bad. The real key is to move fast. We did this on a warm summer evening...and the Weld-on went to set in a real hurry. These are my experiences - you can use them - laugh at them - or ignore them. I just know that it worked pretty well for my building team. I'd be happy to answer any questions as this one of the most intimidating steps in the whole kit. Pete #40100 - plan to have it Osh next year. ________________________________________________________________________________
Date: Sep 14, 2008
A search on AOL.com resulted in a notice that the President of EPM-AV corp was out and the business was closed. However, Aircraft Spruce sell three sizes of the firewall penetration sleeves. SafeAir1 also sells a kit. In a message dated 9/14/2008 7:59:18 A.M. US Mountain Standard Time, johnag5b(at)cableone.net writes: EPM.AV Corp **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Date: Sep 14, 2008
Subject: Re: Weld-on 10 & crazing
HEY PETE, SOUNDS LIKE YOU HAD VERY GOOD EXIPERENCE, MAY BE YOU CAN LET US KNOW WHAT CLEANER OR PREPING YOU USED BEFORE INSTALLING YOUR WINDOWS? I'M REAL C LOSE TO INSTALLING MY WINDOWS. THANKS DAVE LUDD NJ #40466 In a message dated 9/14/2008 11:04:45 A.M. Central Daylight Time, Peter.James(at)sprint.com writes: Hello fellow -10r=99s, I think there has been way too much made of gluing in windows, crazing, alternative glues, etc. I was scared to death to do mine after all the pos ts. It was a learning process, but didn=99t go nearly as bad as I expecte d .. So here is what I did =93 take it or leave it: True: Weld-on is some of the gooiest stuff I have ever worked with worse than pro-seal. The big problem is that it likes to =98string =99and it gets everywherejust like pro-seal, it can jump 10 feet Put the window where you want it. Drill holes and cleco and fender washer the window in place. This does NOT put a lot of pressure on the window. I t DOES allow the window to spring out to the exact shape of the canopy. This is a GOOD thing. Draw a line with one of your kids Crayola washable markers (fine line) on the inside. Take the window out. Use Black electrical tape to seal the window up to th e Crayola marker line. Get the seal nice and smooth and nice and tight to th e line. Then come back over the electrical tape with BLUE tape. It doesn=99t have to get right to the edge of the electrical tape, but pretty close. I might ev en consider a second layer of blue tape. Do the same thing on the outside of the windowright out to the edge. IMPORTANT: Also blue tape a cou ple of layers on the outside of the fuselage around the window well. This will be important to keep the Weld-on off the fuselage as you glue the windows in. YES =93 blue tape is expensive =93 but don=99t scrimp here. Get a 2 or 3=9D wide band of tape around the wells. Sand the inside flange with sandpaper =93 clean with ISOPROPYL alcoho l from the DRUG STORE =93 get the purest stuff they have. Remember not to l eave it open as I it will absorb moisture from the air. I=99m not sure that it ma tters in this case, but I like the stuff to be as potent as possible for future use s. To glue in the window have 2 buddies over to help! One will be inside the plane, the other on the outside. Smear the mixed Weld-on 10 on the flange. Mine was somewhat runny . It will try and run on you. MOVE FAST!!! Mine set in FAR less than the 20 minute pot-life it is supposed to have. Gently set the window in place. DO NOT PRESS IT IN! If you do, the glue will squeeze out when you press in, the window will then =98spring =99 back to the cleco and fender washers =93 leaving a big air pocket where the glue squeezed out. Some of this is just plain going to happen. I will talk about that later. Have Buddy number 2 start clecoing and fender washering the window. Hit the four corners, and a few other places, then grab pliers, clecos, and washers and get them in. Don=99t delay. You want time to clean up a nd work with this stuff before it sets. The glue is going to be a mess! Have blue shop towels and a couple of plastic resin spreaders handy. I took a couple spreaders to my band saw an d cut a couple of varying widths.. These are plastic and won=99t scratch the window. The also are stiff enough to scrape the excess glue off. Buddy number 1 will be inside, scraping any excess off as it squeezes out. If you don =99t have someone inside, this stuff will drip on you fuselage interior and won =99t be easy to clean up or sand off later. If you did a good job of taping, you will be scraping the extra glue off th e BLUE TAPE =93 inside and out. Keep in mind, on the outside, you will have to scrape around the clecos and fender washers. Get the bulk off quickly. Next =93 again, moving very fast =93 pull the first layer of bl ue tape off. This will get the bulk of extra glue off and away from the plane. Have a b ig waste basket or paper bag nearbybecause just like pro-seal =93 this stuff can jump 10 feet and get on anything and everything. On the outside of the plane, you will have your extra buddy pull a cleco =93 you pull the t ape past the hole, then have him put the cleco right back in. It should now be setting on the second layer of tape, or the electrical tape. Go all the way around the windows, cleaning, peeling a layer of tape, cleaning, peeling a layer of tape. By the time you are done, the glue will be VERY solid. It won=99t be impossible to get off, but it won=99t be easy. I then used a metal square tip knife, to get the final remnants off the window on the inside and outside of the fuselage. By using clecos and fender washers, the clamp force is regulated or eliminated if the window has sprung up to =98meet=99 the fender washer. I did not get ANY crazing at allnot even one place. My result was not perfect. I learned the lesson of pushing the window in too far, having it spring back, and lea ve a big air pocket the hard way on the first window. I later came back with a tiny drill.used a light and drilled two holes, then used a syringe with no needle to fill the sir pockets with weld-on. (I have extra weld-on since I had some that had expired and I ordered fresh for the main process.) The cleco holes are now filled with epoxy and the high strength West System s Adhesive filler. You will never know that there was a hole there. My results are not perfect, but they are not bad. The real key is to move fast. We did this on a warm summer eveningand the Weld-on went to set in a real hurry. These are my experiences =93 you can use them =93 laugh at them =93 or ignore them. I just know that it worked pretty well for my building team. I =99d be happy to answer any questions as this one of the most intimidating steps in the whole kit. Pete #40100 =93 plan to have it Osh next year. (http://www.matronics.com/Navigator?RV10-List) (http://www.matronics.com/contribution) **************Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. (http://www.stylelist.com/trends?ncid=aolsty00050000000014) ________________________________________________________________________________
Subject: Weld-on 10 & crazing
Date: Sep 14, 2008
IMHO you do not want to clean your windows prior to install. Leave the protective film on all but the working edge and prep only the working edge. If you clean the whole window you risk contaminating the edge with things that reduce the adhesion. I would think this is true no matter if you use weld-on, epoxy sikaflex or what ever. Most cleaners leave behind some residue, and I never wanted to chance that it would effect the bond. Gary Specketer 40274 Flying _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLIUDVINAITIS(at)aol.com Sent: Sunday, September 14, 2008 1:24 PM Subject: Re: RV10-List: Weld-on 10 & crazing HEY PETE, SOUNDS LIKE YOU HAD VERY GOOD EXIPERENCE, MAY BE YOU CAN LET US KNOW WHAT CLEANER OR PREPING YOU USED BEFORE INSTALLING YOUR WINDOWS? I'M REAL CLOSE TO INSTALLING MY WINDOWS. THANKS DAVE LUDD NJ #40466 In a message dated 9/14/2008 11:04:45 A.M. Central Daylight Time, Peter.James(at)sprint.com writes: Hello fellow -10r's, I think there has been way too much made of gluing in windows, crazing, alternative glues, etc. I was scared to death to do mine after all the posts. It was a learning process, but didn't go nearly as bad as I expected ... So here is what I did - take it or leave it: True: Weld-on is some of the gooiest stuff I have ever worked with.worse than pro-seal. The big problem is that it likes to 'string'.and it gets everywhere.just like pro-seal, it can jump 10 feet Put the window where you want it. Drill holes and cleco and fender washer the window in place. This does NOT put a lot of pressure on the window. It DOES allow the window to spring out to the exact shape of the canopy. This is a GOOD thing. Draw a line with one of your kids Crayola washable markers (fine line) on the inside. Take the window out. Use Black electrical tape to seal the window up to the Crayola marker line. Get the seal nice and smooth and nice and tight to the line. Then come back over the electrical tape with BLUE tape. It doesn't have to get right to the edge of the electrical tape, but pretty close. I might even consider a second layer of blue tape. Do the same thing on the outside of the window.right out to the edge. IMPORTANT: Also blue tape a couple of layers on the outside of the fuselage around the window well. This will be important to keep the Weld-on off the fuselage as you glue the windows in. YES - blue tape is expensive - but don't scrimp here. Get a 2 or 3" wide band of tape around the wells. Sand the inside flange with sandpaper - clean with ISOPROPYL alcohol from the DRUG STORE - get the purest stuff they have. Remember not to leave it open as I it will absorb moisture from the air. I'm not sure that it matters in this case, but I like the stuff to be as potent as possible for future uses. To glue in the window have 2 buddies over to help! One will be inside the plane, the other on the outside. Smear the mixed Weld-on 10 on the flange. Mine was somewhat runny.. It will try and run on you. MOVE FAST!!! Mine set in FAR less than the 20 minute pot-life it is supposed to have. Gently set the window in place. DO NOT PRESS IT IN! If you do, the glue will squeeze out when you press in, the window will then 'spring' back to the cleco and fender washers - leaving a big air pocket where the glue squeezed out. Some of this is just plain going to happen. I will talk about that later. Have Buddy number 2 start clecoing and fender washering the window. Hit the four corners, and a few other places, then grab pliers, clecos, and washers and get them in. Don't delay. You want time to clean up and work with this stuff before it sets. The glue is going to be a mess! Have blue shop towels and a couple of plastic resin spreaders handy. I took a couple spreaders to my band saw and cut a couple of varying widths.. These are plastic and won't scratch the window. The also are stiff enough to scrape the excess glue off. Buddy number 1 will be inside, scraping any excess off as it squeezes out. If you don't have someone inside, this stuff will drip on you fuselage interior and won't be easy to clean up or sand off later. If you did a good job of taping, you will be scraping the extra glue off the BLUE TAPE - inside and out. Keep in mind, on the outside, you will have to scrape around the clecos and fender washers. Get the bulk off quickly. Next - again, moving very fast - pull the first layer of blue tape off. This will get the bulk of extra glue off and away from the plane. Have a big waste basket or paper bag nearby.because just like pro-seal - this stuff can jump 10 feet and get on anything and everything. On the outside of the plane, you will have your extra buddy pull a cleco - you pull the tape past the hole, then have him put the cleco right back in. It should now be setting on the second layer of tape, or the electrical tape. Go all the way around the windows, cleaning, peeling a layer of tape, cleaning, peeling a layer of tape. By the time you are done, the glue will be VERY solid. It won't be impossible to get off, but it won't be easy. I then used a metal square tip knife, to get the final remnants off the window on the inside and outside of the fuselage. By using clecos and fender washers, the clamp force is regulated or eliminated if the window has sprung up to 'meet' the fender washer. I did not get ANY crazing at all.not even one place. My result was not perfect. I learned the lesson of pushing the window in too far, having it spring back, and leave a big air pocket the hard way on the first window. I later came back with a tiny drill..used a light and drilled two holes, then used a syringe with no needle to fill the sir pockets with weld-on. (I have extra weld-on since I had some that had expired and I ordered fresh for the main process.) The cleco holes are now filled with epoxy and the high strength West Systems Adhesive filler. You will never know that there was a hole there. My results are not perfect, but they are not bad. The real key is to move fast. We did this on a warm summer evening.and the Weld-on went to set in a real hurry. These are my experiences - you can use them - laugh at them - or ignore them. I just know that it worked pretty well for my building team. I'd be happy to answer any questions as this one of the most intimidating steps in the whole kit. Pete #40100 - plan to have it Osh next year. ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Nav igator?RV10-List .matronics.com/">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution _____ Psssst...Have you heard the news? There's a new <http://www.stylelist.com/trends?ncid=aolsty00050000000014> fashion blog, plus the latest fall trends and hair styles at StyleList.com. ________________________________________________________________________________
Subject: Seat Belt support Bracket
Date: Sep 14, 2008
I'm unfortunately slow to the fight, but I was wondering how folks are mounting these? My machine is painted so I don't really want to mount it from the outside skin. Seems like there's not too much load on the bracket (assuming nobody tugs on the straps, which is probably not a valid assumption) so perhaps just use sheet metal screws on the inside? Thanks, Marcus -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, August 28, 2008 2:06 AM Subject: RE: RV10-List: Seat Belt support Bracket I would like one of the brackets, please. Albert Gardner Yuma, AZ -----Original Message----- Ok, it's been redesigned, punched out, tumbled, and ready to install. I will finish installing mine on Friday. They look great. Not trying to make money here, just taking advantage of my brothers equipment and I had promised 3 to RV10 guys in this area. We ran off 20, and 8 are already spoken for. $12 should cover the bracket and shipping. Any questions on how I installed mine, just give me a call. Don McDonald 11460 Elks Circle Rancho Cordova, Ca 95742 916-801-8402 #40636 Almost ready to pour fuel to it! -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p 1090#201090 Attachments: http://forums.matronics.com//files/img_2625c_159.jpg ________________________________________________________________________________
Date: Sep 14, 2008
Could a product like this http://www.intropc.com/item-25742-3m-auto-glass-urethane-windshield-adhes ive-medium-viscosity-3m8693.html be used to install the windows? Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: gary To: rv10-list(at)matronics.com Sent: Sunday, September 14, 2008 1:21 PM Subject: RE: RV10-List: Weld-on 10 & crazing IMHO you do not want to clean your windows prior to install. Leave the protective film on all but the working edge and prep only the working edge. If you clean the whole window you risk contaminating the edge with things that reduce the adhesion. I would think this is true no matter if you use weld-on, epoxy sikaflex or what ever. Most cleaners leave behind some residue, and I never wanted to chance that it would effect the bond. Gary Specketer 40274 Flying ------------------------------------------------------------------------- ----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLIUDVINAITIS(at)aol.com Sent: Sunday, September 14, 2008 1:24 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Weld-on 10 & crazing HEY PETE, SOUNDS LIKE YOU HAD VERY GOOD EXIPERENCE, MAY BE YOU CAN LET US KNOW WHAT CLEANER OR PREPING YOU USED BEFORE INSTALLING YOUR WINDOWS? I'M REAL CLOSE TO INSTALLING MY WINDOWS. THANKS DAVE LUDD NJ #40466 In a message dated 9/14/2008 11:04:45 A.M. Central Daylight Time, Peter.James(at)sprint.com writes: Hello fellow -10r's, I think there has been way too much made of gluing in windows, crazing, alternative glues, etc. I was scared to death to do mine after all the posts. It was a learning process, but didn't go nearly as bad as I expected ... So here is what I did - take it or leave it: True: Weld-on is some of the gooiest stuff I have ever worked with.worse than pro-seal. The big problem is that it likes to 'string'.and it gets everywhere.just like pro-seal, it can jump 10 feet Put the window where you want it. Drill holes and cleco and fender washer the window in place. This does NOT put a lot of pressure on the window. It DOES allow the window to spring out to the exact shape of the canopy. This is a GOOD thing. Draw a line with one of your kids Crayola washable markers (fine line) on the inside. Take the window out. Use Black electrical tape to seal the window up to the Crayola marker line. Get the seal nice and smooth and nice and tight to the line. Then come back over the electrical tape with BLUE tape. It doesn't have to get right to the edge of the electrical tape, but pretty close. I might even consider a second layer of blue tape. Do the same thing on the outside of the window.right out to the edge. IMPORTANT: Also blue tape a couple of layers on the outside of the fuselage around the window well. This will be important to keep the Weld-on off the fuselage as you glue the windows in. YES - blue tape is expensive - but don't scrimp here. Get a 2 or 3" wide band of tape around the wells. Sand the inside flange with sandpaper - clean with ISOPROPYL alcohol from the DRUG STORE - get the purest stuff they have. Remember not to leave it open as I it will absorb moisture from the air. I'm not sure that it matters in this case, but I like the stuff to be as potent as possible for future uses. To glue in the window have 2 buddies over to help! One will be inside the plane, the other on the outside. Smear the mixed Weld-on 10 on the flange. Mine was somewhat runny.. It will try and run on you. MOVE FAST!!! Mine set in FAR less than the 20 minute pot-life it is supposed to have. Gently set the window in place. DO NOT PRESS IT IN! If you do, the glue will squeeze out when you press in, the window will then 'spring' back to the cleco and fender washers - leaving a big air pocket where the glue squeezed out. Some of this is just plain going to happen. I will talk about that later. Have Buddy number 2 start clecoing and fender washering the window. Hit the four corners, and a few other places, then grab pliers, clecos, and washers and get them in. Don't delay. You want time to clean up and work with this stuff before it sets. The glue is going to be a mess! Have blue shop towels and a couple of plastic resin spreaders handy. I took a couple spreaders to my band saw and cut a couple of varying widths.. These are plastic and won't scratch the window. The also are stiff enough to scrape the excess glue off. Buddy number 1 will be inside, scraping any excess off as it squeezes out. If you don't have someone inside, this stuff will drip on you fuselage interior and won't be easy to clean up or sand off later. If you did a good job of taping, you will be scraping the extra glue off the BLUE TAPE - inside and out. Keep in mind, on the outside, you will have to scrape around the clecos and fender washers. Get the bulk off quickly. Next - again, moving very fast - pull the first layer of blue tape off. This will get the bulk of extra glue off and away from the plane. Have a big waste basket or paper bag nearby.because just like pro-seal - this stuff can jump 10 feet and get on anything and everything. On the outside of the plane, you will have your extra buddy pull a cleco - you pull the tape past the hole, then have him put the cleco right back in. It should now be setting on the second layer of tape, or the electrical tape. Go all the way around the windows, cleaning, peeling a layer of tape, cleaning, peeling a layer of tape. By the time you are done, the glue will be VERY solid. It won't be impossible to get off, but it won't be easy. I then used a metal square tip knife, to get the final remnants off the window on the inside and outside of the fuselage. By using clecos and fender washers, the clamp force is regulated or eliminated if the window has sprung up to 'meet' the fender washer. I did not get ANY crazing at all.not even one place. My result was not perfect. I learned the lesson of pushing the window in too far, having it spring back, and leave a big air pocket the hard way on the first window. I later came back with a tiny drill..used a light and drilled two holes, then used a syringe with no needle to fill the sir pockets with weld-on. (I have extra weld-on since I had some that had expired and I ordered fresh for the main process.) The cleco holes are now filled with epoxy and the high strength West Systems Adhesive filler. You will never know that there was a hole there. My results are not perfect, but they are not bad. The real key is to move fast. We did this on a warm summer evening.and the Weld-on went to set in a real hurry. These are my experiences - you can use them - laugh at them - or ignore them. I just know that it worked pretty well for my building team. I'd be happy to answer any questions as this one of the most intimidating steps in the whole kit. Pete #40100 - plan to have it Osh next year. ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m/Navigator?RV10-List.matronics.com/">http://forums.matronics.com://www.m atronics.com/contribution">http://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com. http://www.matronics.com/contribution ________________________________________________________________________________
Subject:
