RV10-Archive.digest.vol-eb
January 09, 2009 - Present
Subject: Re: Old subject revisited
Date: Jan 09, 2009
Ron, 1. I haven't yet put nitrogen in my tires however yesterday when I went to the hangar to fly my tires were low again and after some cussing I made the decision that I'm putting nitrogen in the tires yet this week. I have a good friend who is an A&P and runs an FBO and he maintained my previous certified planes and I never had this low tire problem. He always filled my tires then with nitrogen. He told me it will probably stop 75% of the air loss I'm experiencing. I'm going to take off the wheel pants and fly over to a nearby airport and have a shop over there put in the good stuff. All repair shops should have nitrogen because they need it for the struts on some of the planes. 2. Yes I did installed static wicks. There was a write up, I believe from this forum, on where to install them. I have instructions on this at my hangar if you can't find it. Wayne Edgerton N602WT Subject: Old subject revisited From: "McGANN, Ron" <ron.mcgann(at)baesystems.com> Just had an enlightening discussion with a work colleague that prompts some questions: 1. Nitrogen in the tires How many use Nitrogen (as opposed to compressed air) in the tires. I have not flown yet, but I notice that my tires regularly deflate very slowly. I've now heard that this may be oxygen leakage through the rubber membrane Interesting thread on VAF on this. To what extent does Nitrogen only in the tires reduce deflation? Any list experiences? 2. Static wicks I always believed I did not need them. After all, I was not building a plastic plane. After adding paint, I have changed my mind!! I used two pack Acrylic Urethane on my paint job. Came out pretty good. When vacuuming the paint booth of paint dust, the static build up inside the hose and metal fittings is unbelievable. I often see sparks greater than 1/2" between any conductor on the vacuum cleaner and a ground. Greater than 10kV in this apparently! I expect the static buildup on the plastic paint I now have, especially in the hot, dry, dusty conditions here in South Oz is likely to be quite significant. Looks like a bit more work on bonding the control surfaces and adding some wicks. Will it ever end . . . . Cheers, Ron -187 fiddly bits and paperwork (and I really should just finish and FLY!!) ________________________________________________________________________________
Date: Jan 09, 2009
I have had static problems on previous planes and thus bonded and static wicked the 10. To date no issues, but I don't expect any either. Gary Specketer 40274 flying _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron Sent: Thursday, January 08, 2009 9:20 PM Subject: RV10-List: Old subject revisited Just had an enlightening discussion with a work colleague that prompts some questions: 1. Nitrogen in the tires How many use Nitrogen (as opposed to compressed air) in the tires. I have not flown yet, but I notice that my tires regularly deflate very slowly. I've now heard that this may be oxygen leakage through the rubber membrane Interesting thread on VAF on this. To what extent does Nitrogen only in the tires reduce deflation? Any list experiences? 2. Static wicks I always believed I did not need them. After all, I was not building a plastic plane. After adding paint, I have changed my mind!! I used two pack Acrylic Urethane on my paint job. Came out pretty good. When vacuuming the paint booth of paint dust, the static build up inside the hose and metal fittings is unbelievable. I often see sparks greater than 1/2" between any conductor on the vacuum cleaner and a ground. Greater than 10kV in this apparently! I expect the static buildup on the plastic paint I now have, especially in the hot, dry, dusty conditions here in South Oz is likely to be quite significant. Looks like a bit more work on bonding the control surfaces and adding some wicks. Will it ever end . . . . Cheers, Ron -187 fiddly bits and paperwork (and I really should just finish and FLY!!) "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Subject: Audio Jacks
Date: Jan 09, 2009
Hi Brian, First let me preface my comments by saying I'm not a fan of the KMA "Audio Panels". They do work ok, but the don't have an intercom and they aren't stereo. Is this for a new installation in your RV-10? If so, I'd strongly encourage you to just file the KMA and go buy a modern audio panel with a good intercom in it....it'll save you a lot of hassle down the road. That being said, plugging the stereo cable into a mono jack wouldn't normally be detrimental (dependin on whether they are physically mono or stereo jacks). If they are mono jacks, then you may have to leave the stereo plug out one "click". If they are mono jacks it shouldn't be a problem. Just depends on the installation and how it was put together... Sorry I don't have any more definitive answer, but it's not something that is black/white unless I know all of the facts. Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of cloudvalley(at)comcast.net Sent: Thursday, January 08, 2009 7:27 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Audio Jacks Hello Stein, My wife and I just bought a Garmin 696 for our plane. It has a stereo output jack for music, a 3.5 mm. We were wondering if you know if the KMA24 audio panel is a stereo unit. There are two 3.5 mm input jacks on the panel and don't know if it would be detrimental to the 696 unit if we plugged in the stereo cable to a mono jack, if in fact it is. Thanks. Brian Preston ________________________________________________________________________________
Date: Jan 09, 2009
Subject: Re: Audio Jacks
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 09, 2009
Ron, No direct personal experience but I hear that the air stop tubes from Mic helin or any other Butyl rubber tubes work pretty well to minimize leaking. I'll probably run Nitrogen in mine but I haven't decided on the delivery method yet. As I will also transfill my oxy tank I may just get a Nitrogen tank while I'm at it. You could also take one of those little portable ai r tanks and go to many tire shops and dealerships and see if they will fill that up for a couple bucks. Here in the US the big new fad is Nitrogen in auto tires so almost every dealership or tire place has on site Nitrogen s eparators to fill customer tires for a nice little fee. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of McGANN, Ron Sent: Thursday, January 08, 2009 8:20 PM Subject: RV10-List: Old subject revisited Just had an enlightening discussion with a work colleague that prompts some questions: 1. Nitrogen in the tires How many use Nitrogen (as opposed to compressed air) in the tires. I have not flown yet, but I notice that my tires regularly deflate very slowly. I 've now heard that this may be oxygen leakage through the rubber membrane Interesting thread on VAF on this. To what extent does Nitrogen only in th e tires reduce deflation? Any list experiences? 2. Static wicks I always believed I did not need them. After all, I was not building a pla stic plane. After adding paint, I have changed my mind!! I used two pack Acrylic Urethane on my paint job. Came out pretty good. When vacuuming th e paint booth of paint dust, the static build up inside the hose and metal fittings is unbelievable. I often see sparks greater than 1/2" between any conductor on the vacuum cleaner and a ground. Greater than 10kV in this a pparently! I expect the static buildup on the plastic paint I now have, es pecially in the hot, dry, dusty conditions here in South Oz is likely to be quite significant. Looks like a bit more work on bonding the control surf aces and adding some wicks. Will it ever end . . . . Cheers, Ron -187 fiddly bits and paperwork (and I really should just finish and FLY!!) "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Subject: RV-10 Winglet Photo
Date: Jan 09, 2009
It seems like I heard of an RV-10 with winglets awhile back. If I recall correctly, I think it was in Oregon. Does anyone have a photo of the plane? Stop the flames! :) I'm not wanting to build them for my plane. I'm just looking to pass along the photo. Thanks, Phil ________________________________________________________________________________
Date: Jan 09, 2009
Subject: Questions - Help!
As long as it's within engine design tolerances I wouldn't lose any sleep o ver it. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Don McDonald Sent: Friday, January 09, 2009 11:55 AM Subject: Re: RV10-List: Questions - Help! Rick, I have found that the BEST info available usually comes from our RV c rowd..... with, of course, the exception of a few,,,, no finger pointing in tended. One friend, an RV6 pilot, was really concerned about both pressure s. But according to Lycoming, they are normal. So I just wanted to get a few more opinions. Don ________________________________________________________________________________
Subject: Air Stop Tubes
Date: Jan 09, 2009
I put the Michelin Air Stop tubes in my Mooney eight months ago. They are filled with Georgia air (that's where they were installed). So far they have been perfect. The previous tubes needed topped-off about once a month, a real PITA. Steve Roberts N2700W 1966 M20E 'Ms. Obsession' KMOR Morristown, TN (still lurking, no suitable place to build my RV-10) ________________________________________________________________________________
Subject: Re: Erroneous Plans sequence on elevators
Date: Jan 09, 2009
Kelly, I'm confused here. The plans steps you listed don't jive with mine. Why are you dimpling the leading edge rivet holes? The rivets called out are AD-41s which don't need a dimple. Also the templates in the plans are full sized. That's why the steps say cut out and glue to the foam blocks-- you'll get 2 ribs from each block. Personally I made copies so my plans would always have the originals in case I needed to make new ones in the future. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223720#223720 ________________________________________________________________________________
Date: Jan 09, 2009
Hello Stein, (sending this again, as it appeared not to work right the firs t time) Thank you for the answer. We have been using it, and although It works ok, I didn't know if using a stereo cable could "hurt" the 696 when plugging =C2-it into a mono jack. I wish we had a different audio panel, but=C2- the story is that this in a 79 Grumman Tiger we just bought last May. Befor e =C2-that, we owned an RV10 tail kit and completed the empennage in a class here in Eugene, Oregon=C2-but realized how hard it would be on bo th of us to complete the project, given that I have carpel tunnel and our small farm =C2-here is not sellling. We may buy an RV-10 that someone has brought cl oser to completion in the future, should our farm sell, because it is such a great airplane! In the meantime we have this affordable Tiger to fly..maybe we shouldn't ha ve =C2-put in a 430WAAS, GI-106A and GMX200 that we just had done a few mont hs =C2-back, before we knew how bad the economy was getting.. Now this Tiger is becoming less affordable..at least it's a low-time Tiger. Thanks Stein. Who knows what the future will hold.. Brian Preston ----- Original Message ----- From: "Inc. SteinAir" <stein(at)steinair.com> Sent: Friday, January 9, 2009 7:24:25 AM GMT -08:00 US/Canada Pacific Subject: RE: RV10-List: Audio Jacks =EF=BB Hi Brian, First let me preface my comments by saying I'm not a fan of the KMA "Audio Panels".=C2- They do work ok, but the don't have an intercom and they are n't stereo.=C2- Is this for a new installation in your RV-10? If so, I'd strongly encourage you to just file the KMA and go buy a modern audio panel with a good intercom in it....it'll save you a lot of hassle down the road .=C2- That being said, plugging the stereo cable into a mono jack wouldn't normal ly be detrimental (dependin on whether they are physically mono or stereo j acks).=C2- If they are mono jacks, then you may have to leave the stereo plug out one "click".=C2- If they are mono jacks it shouldn't be a proble m.=C2- Just depends on the installation and how it was put together... Sorry I don't have any more definitive answer, but it's not something that is black/white unless I know all of the facts. Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of cloudvalley(at)comcast.net Sent: Thursday, January 08, 2009 7:27 PM Subject: Re: RV10-List: Audio Jacks Hello Stein, =C2-My wife and I just bought a Garmin 696 for our plane. It has a stereo output jack for music, a 3.5 mm. We were wondering if you know if the KMA2 4 audio panel is a stereo unit. There are two 3.5 mm input jacks on the pan el and don't know if it would be detrimental to the 696 unit if we plugged in=C2-the stereo cable to=C2-a mono jack, if in fact it is. Thanks. Brian Preston == ________________________________________________________________________________
Date: Jan 09, 2009
I think he's talking about slightly rolling the trailing edges of the control surface to close any gaps that might exist around the wedge-shaped insert. I don't think he's talking about the big broom-stick roll on the trailing edge. -----Original Message----- From: tsts4 [mailto:tsts4(at)verizon.net] Sent: Friday, January 09, 2009 12:53 PM Subject: RV10-List: Re: Erroneous Plans sequence on elevators Kelly, I'm confused here. The plans steps you listed don't jive with mine. Why are you dimpling the leading edge rivet holes? The rivets called out are AD-41s which don't need a dimple. Also the templates in the plans are full sized. That's why the steps say cut out and glue to the foam blocks-- you'll get 2 ribs from each block. Personally I made copies so my plans would always have the originals in case I needed to make new ones in the future. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223720#223720 ________________________________________________________________________________
Date: Jan 09, 2009
Ahhhh. My mistake--apologies. Not the leading edge but the trailing edge. I forgot that you put a bend on that edge as well. I seem to recall that I just went slow and it turned out fine (I have the vise grip style edge roller). -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223728#223728 ________________________________________________________________________________
Date: Jan 09, 2009
I bought the tubes with the 90 deg stems but I didn't like the way they fit the wheel. The stem on the tube came out of the center whereas the wheel has a hole offset to the side. Then stem was forced out of its natural path in order to fit the wheel. It appears the wheel needs to be altered to make the 90 deg stem fit. Maybe all 90 deg tubes are not the same. I don't think there is sufficient room for any screw-on extension to work. Albert Gardner Yuma, AZ -----Original Message----- Linn, We looked at the 90 degree valve extension but they would not work (too close to the center shaft and extra spinning weight). You are saying that there are tubes with built in 90 degree valves? http://shop.desser.com/IW_Products.m4p.pvx?;MULTI_ITEM_SUBMIT (did not look for exact size) Rats... I just found them. Sure wish I knew about them before the plane went to paint... I would have bored an access hole. Robin ________________________________________________________________________________
Date: Jan 09, 2009
As Tim and others point out, if the oxygen really diffused much faster than nitrogen, all you'd have to do is overfill the tires by 20%, and, after a while, they'd be at the correct pressure and 100% nitrogen. (Or let then deflate 20%, the refill with air. You'd then be at 96% nitrogen). I believe this owt started because the airlines use nitrogen in their tires. But that's to reduce the fire risk (not leakage problems) following a rejected takeoff when the tires can get really hot (and sometimes blow a "fuse plug"). The new leakstop tubes are a real improvement. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223759#223759 ________________________________________________________________________________
Date: Jan 09, 2009
John, Not sure I saw the answer to your specific question. The standard mike configuration uses the tip for PTT, and the mike is on the middle or "ring" connection (and both use "ground" for the return). So you cannot use a 2 connector jack, you need the 3 connector one. But for the rear seats you can leave the tip connection open, unless you want them to be able to transmit!. As others noted, this is an unusual jack, 0.230". To eliminate noise from ground loops, "float" the jacks. Buy pairs of insulating washers, one with a rib which goes into the hole (Stein sells them), and use them to electrically isolate the jack from the frame. Use one of the wires inside your cable to carry the ground back to the audio panel. Connect the shield to ground only at the audio panel, leave it float (cut if off) at the jack end. Do the same for the headphone jacks. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223761#223761 ________________________________________________________________________________
Subject: cowl hinge pins
Date: Jan 09, 2009
In previous emails it was discussed that the hinge pinsthe come with the SS hinges used for the cowls need to be replaced with a different pin. WHich pin needs to be used=2C it is not stated on the plans and is this smaller p in only used on the top hinges or the side hinges also??? There is not enou gh provided in the kit for both if it is the SSP-120 which is smaller than the one inside the hinges. There is one long length which is of much smalle r diameter but that seems too narrow.ThanksJOhn ________________________________________________________________________________
Date: Jan 09, 2009
Just from memory...small pins on top, it is a sizeable diameter difference. You will need that to be able to make the turn. Larger pins on the side and bottom. Do not use the AL pins..they will gall the hinge if you try to pull them in and out with the hinge under stress...ask me how I know. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Friday, January 09, 2009 3:36 PM Subject: RV10-List: cowl hinge pins In previous emails it was discussed that the hinge pinsthe come with the SS hinges used for the cowls need to be replaced with a different pin. WHich pin needs to be used, it is not stated on the plans and is this smaller pin only used on the top hinges or the side hinges also??? There is not enough provided in the kit for both if it is the SSP-120 which is smaller than the one inside the hinges. There is one long length which is of much smaller diameter but that seems too narrow. Thanks JOhn ________________________________________________________________________________
Date: Jan 09, 2009
Correct. Re the foam ribs, Copying the plans introduces a dimension change, because unless you change the enlargement, most copiers add 2% enlargement, and how does one know the originals from Van aren't a copy of a copy? On Fri, Jan 9, 2009 at 12:15 PM, Perry, Phil wrote: > > I think he's talking about slightly rolling the trailing edges of the > control surface to close any gaps that might exist around the > wedge-shaped insert. > > I don't think he's talking about the big broom-stick roll on the > trailing edge. > > -----Original Message----- > From: tsts4 [mailto:tsts4(at)verizon.net] > Sent: Friday, January 09, 2009 12:53 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Erroneous Plans sequence on elevators > > > Kelly, > I'm confused here. The plans steps you listed don't jive with mine. Why > are you dimpling the leading edge rivet holes? The rivets called out > are AD-41s which don't need a dimple. > > Also the templates in the plans are full sized. That's why the steps > say cut out and glue to the foam blocks-- you'll get 2 ribs from each > block. Personally I made copies so my plans would always have the > originals in case I needed to make new ones in the future. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=223720#223720 > > ________________________________________________________________________________
Date: Jan 09, 2009
My HP all-in-one made copies exactly the same size as the plans (I checked)-- I guess I got lucky. As to whether the plans are copies of copies, I don't know. There's an easy way to check. The forward end of the ribs fit in between the rear spar flanges. Just measure the distance between the flanges and compare to the width of the rib template. I bet it's pretty darn close. All I can say is I followed the plans and mine fit fine, and in 5 years since the -10 was released I don't recall anyone ever posting an issue with the templates here or over at VAF. Granted, there can always be a first time, but I wouldn't worry too much about it--build on! -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223799#223799 ________________________________________________________________________________
Subject: rivethead door block installation help
Date: Jan 09, 2009
My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. ________________________________________________________________________________
Subject: Re: rivethead door block installation help
Date: Jan 09, 2009
Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman ----- Original Message ----- From: Ben Westfall To: rv10-list(at)matronics.com Sent: Friday, January 09, 2009 9:45 PM Subject: RV10-List: rivethead door block installation help My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. =========== ________________________________________________________________________________
Date: Jan 09, 2009
So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? _____ Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. ________________________________________________________________________________
Date: Jan 09, 2009
Ben; with my ends basically are .050 passed the blocks/ close to flush with the seals where the round tip is protruding. I go through the fusellage about half-way of the magnetic pin in the closed position. I'll confirm this weekend. I'll need to measure the blocks but I estimate that there is a fair amount that gets removed to fit when I put the delrin (stock) blocks next to the aftermarket blocks. I have the Iflyrv10 version. Pascal From: Ben Westfall Sent: Friday, January 09, 2009 7:33 PM Subject: RE: RV10-List: rivethead door block installation help So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? ------------------------------------------------------------------------- ------- Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. =========== ________________________________________________________________________________
Date: Jan 09, 2009
Ben, I was able to rig the pins so they went through the blocks and the door frame. I let the pin protrude from the door about 3/16" when it's fully retracted. It still clears the door frame, and it gives the pin a little head start to fully engage the frame. I also put two additional notches in the plate that catches the rollpin/stop so the handle "locks" not just in the closed position but also in the fully open position. The stock notches are are roughly 9:00 and 3:00. The new notches are at about 12:00 and 6:00. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Friday, January 09, 2009 7:34 PM Subject: RE: RV10-List: rivethead door block installation help So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? _____ Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. browse Forums! ________________________________________________________________________________
Date: Jan 10, 2009
From: pascal Sent: Friday, January 09, 2009 7:59 PM Subject: Re: RV10-List: rivethead door block installation help Ben; with my ends basically are .050 passed the blocks/ close to flush with the seals where the round tip is protruding. I go through the fusellage about half-way of the magnetic pin in the closed position. I'll confirm this weekend. I'll need to measure the blocks but I estimate that there is a fair amount that gets removed to fit when I put the delrin (stock) blocks next to the aftermarket blocks. I have the Iflyrv10 version. Pascal From: Ben Westfall Sent: Friday, January 09, 2009 7:33 PM Subject: RE: RV10-List: rivethead door block installation help So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? ------------------------------------------------------------------------- ------- Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. http://www.matronics.com/Navigator?RV10-List Web Forums! href="http://forums.matronics.com">http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution =========== ________________________________________________________________________________
Date: Jan 10, 2009
Ben; The magnetic pin is more like 1/8 past the fusellage in the closed position. 1/16 past the door in the opened position it's easier to cut the rod than file down the blocks. I cut about 1 inch off my rods to fit the 48/64 pins as starting reference for you. Pascal From: pascal Sent: Friday, January 09, 2009 7:59 PM Subject: Re: RV10-List: rivethead door block installation help Ben; with my ends basically are .050 passed the blocks/ close to flush with the seals where the round tip is protruding. I go through the fusellage about half-way of the magnetic pin in the closed position. I'll confirm this weekend. I'll need to measure the blocks but I estimate that there is a fair amount that gets removed to fit when I put the delrin (stock) blocks next to the aftermarket blocks. I have the Iflyrv10 version. Pascal From: Ben Westfall Sent: Friday, January 09, 2009 7:33 PM Subject: RE: RV10-List: rivethead door block installation help So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? ------------------------------------------------------------------------- ------- Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. http://www.matronics.com/Navigator?RV10-List Web Forums! href="http://forums.matronics.com">http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution =========== ________________________________________________________________________________
Date: Jan 10, 2009
Thanks for all the responses guys. I actually spoke w/Van himself a while back about the rivethead door blocks/pins which is what prompted my question. He looked at them with an eye of skepticism because he hadn't "done the engineering" on them. He continued by saying that the door locking design was engineered to spread the load onto the door pins through the cabin top and frame. The analysis of the parts when engineering the door mechanisms showed sufficient strength for the forces that the door would be subject to. He hadn't looked at the rivethead setup closely so my understanding of what he was basically saying was I wouldn't install them if they departed from the original design without doing an engineering analysis of their strength. For legality reasons I'm sure he wouldn't say "yeah they are fine". I think he wanted to make sure that the strength of the door closing mechanism should come from the pins passing through the cabin top and frame. I wanted to make sure that after installing the blocks that the door pins would still pass all the way through so the load of the door pins was still on the cabin top and frame and not just applied to just the two AN3 bolts that will hold the door blocks on. I think that was Van's fear with the product. Who knows if the shear strength of the AN3 bolts is sufficient w/o proper research? Also is the threaded in tip just as strong as the rod end? It's always prudent to look at any modification with an eye towards "does this modify the engineering intent of the design?". I'm not qualified to answer that so I'm overly paranoid about modifications sometimes. -Ben _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Saturday, January 10, 2009 7:37 AM Subject: Re: RV10-List: rivethead door block installation help Ben; The magnetic pin is more like 1/8 past the fusellage in the closed position. 1/16 past the door in the opened position it's easier to cut the rod than file down the blocks. I cut about 1 inch off my rods to fit the 48/64 pins as starting reference for you. Pascal From: pascal <mailto:pascal(at)rv10builder.net> Sent: Friday, January 09, 2009 7:59 PM Subject: Re: RV10-List: rivethead door block installation help Ben; with my ends basically are .050 passed the blocks/ close to flush with the seals where the round tip is protruding. I go through the fusellage about half-way of the magnetic pin in the closed position. I'll confirm this weekend. I'll need to measure the blocks but I estimate that there is a fair amount that gets removed to fit when I put the delrin (stock) blocks next to the aftermarket blocks. I have the Iflyrv10 version. Pascal From: Ben Westfall <mailto:rv10(at)sinkrate.com> Sent: Friday, January 09, 2009 7:33 PM Subject: RE: RV10-List: rivethead door block installation help So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? _____ Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. http://www.matronics.com/Navigator?RV10-List Web Forums! href="http://forums.matronics.com">http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution =========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c __________ Information from ESET NOD32 Antivirus, version of virus signature database 3756 (20090110) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jan 10, 2009
Bob, Your suggestions are exactly what I've done. Wires are soldered and pulled to the "rats nest" under the rudder pedals. The actual panel avionics are still a dream until I do some big buying at Sun 'n fun. Can anybody suggest a way to test my new soldered jacks without any avionics? My Finish Kit is on it's way via ABF and my upholstery from Abby shipped Friday. Avionics and Engine choices to go. John -------- #40572 QB Fuselage, wings finished. Finish Kit is on it's way. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223863#223863 ________________________________________________________________________________
Date: Jan 10, 2009
I agree that having the frame as the core for the strength is key. The blocks will add an extra measure of strength which would avoid the threaded part from really being stressed/bent, per se. One thing I am rather certain about, the mag tips will help with the rear not closing correctly, an issue that resulted in many door issues using the stock setup. I am talking off of thought and not fact BTW, I still need to get the door fully installed and tested to assure all is as I'm thinking, but I expect it will be. Let me know if you need any other guidance and I'll focus my build around this section for you. Pascal From: Ben Westfall Sent: Saturday, January 10, 2009 8:10 AM Subject: RE: RV10-List: rivethead door block installation help Thanks for all the responses guys. I actually spoke w/Van himself a while back about the rivethead door blocks/pins which is what prompted my question. He looked at them with an eye of skepticism because he hadn't "done the engineering" on them. He continued by saying that the door locking design was engineered to spread the load onto the door pins through the cabin top and frame. The analysis of the parts when engineering the door mechanisms showed sufficient strength for the forces that the door would be subject to. He hadn't looked at the rivethead setup closely so my understanding of what he was basically saying was I wouldn't install them if they departed from the original design without doing an engineering analysis of their strength. For legality reasons I'm sure he wouldn't say "yeah they are fine". I think he wanted to make sure that the strength of the door closing mechanism should come from the pins passing through the cabin top and frame. I wanted to make sure that after installing the blocks that the door pins would still pass all the way through so the load of the door pins was still on the cabin top and frame and not just applied to just the two AN3 bolts that will hold the door blocks on. I think that was Van's fear with the product. Who knows if the shear strength of the AN3 bolts is sufficient w/o proper research? Also is the threaded in tip just as strong as the rod end? It's always prudent to look at any modification with an eye towards "does this modify the engineering intent of the design?". I'm not qualified to answer that so I'm overly paranoid about modifications sometimes. -Ben ------------------------------------------------------------------------- ------- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Saturday, January 10, 2009 7:37 AM Subject: Re: RV10-List: rivethead door block installation help Ben; The magnetic pin is more like 1/8 past the fusellage in the closed position. 1/16 past the door in the opened position it's easier to cut the rod than file down the blocks. I cut about 1 inch off my rods to fit the 48/64 pins as starting reference for you. Pascal From: pascal Sent: Friday, January 09, 2009 7:59 PM Subject: Re: RV10-List: rivethead door block installation help Ben; with my ends basically are .050 passed the blocks/ close to flush with the seals where the round tip is protruding. I go through the fusellage about half-way of the magnetic pin in the closed position. I'll confirm this weekend. I'll need to measure the blocks but I estimate that there is a fair amount that gets removed to fit when I put the delrin (stock) blocks next to the aftermarket blocks. I have the Iflyrv10 version. Pascal From: Ben Westfall Sent: Friday, January 09, 2009 7:33 PM Subject: RE: RV10-List: rivethead door block installation help So when you latch the door to the locked position do your door pins protrude through the aluminum of the fuselage or are they only in the receiver blocks? ------------------------------------------------------------------------- ------- Ben, I installed the rivethead pins and blocks. I trimed the tubes so the magnetic head protruded about .050 past the delrin block on the doors, then I machined the back off the receiver blocks until I had the proper clearance for closing the doors, If I remeber correctly, I machined about 0.100 off of each receiver blocks. -Bob Newman My question for those of you that have installed the rivethead-aero door blocks. How did you make them fit? I've trimmed the door pin tubing flush at the base of van's angle cut so the ends are square to accept the threaded magnetic tip. With the door handle completely retracted the tips still stick out past the delrin guide blocks on the doors. There is barely enough clearance between the retracted door pins and the fiberglass top w/o the rivethead blocks installed. I don't want to trim the door pins any shorter or they won't protrude through the holes in the fuselage door frame very much. I'd assume for strength reasons you really want the closing force on the door pin tubing not the threaded in tip. I can thin the rivethead blocks down 50% or so but I'd bet they would still be too wide to get past the pins. Curious what others have done? -Ben Westfall #40579 I have to say the doors are a boat load of work that never ends. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3755 (20090109) __________ The message was checked by ESET NOD32 Antivirus. http://www.matronics.com/Navigator?RV10-List Web Forums! href="http://forums.matronics.com">http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution =========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://foru ms.matronics.comhref="http://www.matronics.com/contribution">http://www .matronics.com/c http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution __________ Information from ESET NOD32 Antivirus, version of virus signature database 3756 (20090110) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jan 10, 2009
Hi John, Keep in mind that it might be wise to purchase at least the Garmin equipment before SnF, as their yearly price increases are almost always put into effect here before too long.... Cheers, Stein >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of johngoodman >Sent: Saturday, January 10, 2009 10:42 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: Re: Audio Jacks > > >Bob, >Your suggestions are exactly what I've done. Wires are soldered >and pulled to the "rats nest" under the rudder pedals. The actual >panel avionics are still a dream until I do some big buying at Sun >'n fun. Can anybody suggest a way to test my new soldered jacks >without any avionics? > >My Finish Kit is on it's way via ABF and my upholstery from Abby >shipped Friday. Avionics and Engine choices to go. > >John > >-------- >#40572 QB Fuselage, wings finished. Finish Kit is on it's way. >N711JG reserved > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=223863#223863 > > ________________________________________________________________________________
Date: Jan 10, 2009
How about a price decrease to match my mutual fund/ 401K/ GE stock/unleaded gas/ house/etc.?? Wouldn't they want to move some product? Show special? -Chris #40072 ----- Original Message ----- From: "SteinAir, Inc." <stein(at)steinair.com> Sent: Saturday, January 10, 2009 2:34 PM Subject: RE: RV10-List: Re: Audio Jacks > > Hi John, > > Keep in mind that it might be wise to purchase at least the Garmin > equipment > before SnF, as their yearly price increases are almost always put into > effect here before too long.... > > Cheers, > Stein > >>-----Original Message----- >>From: owner-rv10-list-server(at)matronics.com >>[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of johngoodman >>Sent: Saturday, January 10, 2009 10:42 AM >>To: rv10-list(at)matronics.com >>Subject: RV10-List: Re: Audio Jacks >> >> >> >>Bob, >>Your suggestions are exactly what I've done. Wires are soldered >>and pulled to the "rats nest" under the rudder pedals. The actual >>panel avionics are still a dream until I do some big buying at Sun >>'n fun. Can anybody suggest a way to test my new soldered jacks >>without any avionics? >> >>My Finish Kit is on it's way via ABF and my upholstery from Abby >>shipped Friday. Avionics and Engine choices to go. >> >>John >> >>-------- >>#40572 QB Fuselage, wings finished. Finish Kit is on it's way. >>N711JG reserved >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=223863#223863 >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 10, 2009
I don't know about Garmin stuff - I'm not sure I want to go down that road. Everything they have is too pricey and they really treated me like a leper at Oshkosh. The minute I mentioned that a GNS430W was good enough and does it integrate with other brands, he started looking over my shoulder.... It kind of reminds me of Microsoft. Bose is another that seems to think that they only excrete in clean, cellophane bags pre-tied with pretty pink ribbons. I'll look but I'll view any price increase as an opportunity to go elsewhere. John -------- #40572 QB Fuselage, wings finished. Finish Kit is on it's way. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223943#223943 ________________________________________________________________________________
Date: Jan 10, 2009
Problem is Garmin is sort of the only one that has a decent GPS/NAV/COM that intergrates with the AFS EFIS, if you know of better options, I sure am interested. -------------------------------------------------- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Saturday, January 10, 2009 4:41 PM Subject: RV10-List: Re: Audio Jacks > > I don't know about Garmin stuff - I'm not sure I want to go down that > road. Everything they have is too pricey and they really treated me like a > leper at Oshkosh. The minute I mentioned that a GNS430W was good enough > and does it integrate with other brands, he started looking over my > shoulder.... > It kind of reminds me of Microsoft. Bose is another that seems to think > that they only excrete in clean, cellophane bags pre-tied with pretty pink > ribbons. > > I'll look but I'll view any price increase as an opportunity to go > elsewhere. > > John > > -------- > #40572 QB Fuselage, wings finished. Finish Kit is on it's way. > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=223943#223943 > > > ________________________________________________________________________________
Subject: EFIS - Dual screen AFS advanced deck
Date: Jan 10, 2009
Hey folks, I was playing around with xpanel panel design tool and it looks like it will be tight to get a set of Advanced Deck screens side by side on the stock -10 panel without pushing the com/gps/avionics stack to the right of center. I've seen a couple post from Rob H that shows his panel and it looks like they will fit, just snugly. (I'm assuming Rob is flying with the larger Advanced Deck in his 10) So, just curious with those that are flying with dual/triple screen efis's... is it a big deal that the avionics stack is pushed off center? If you were doing it again, would you keep the dual screens side by side (and/or stacked) or would you split them up and move one screen to the right side and only fly with the one screen in front of you? I'm flying with a Dynon d10 in the 7A and of course without the moving map I want the 430 close. Won't I still need to have easy access to the 430 for IFR approaches/flight plans, etc. Hope to finish up the baffles/cowl tomorrow. Going to have to get off the fence and decide on avionics soon to keep this thing moving forward... -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223990#223990 ________________________________________________________________________________
Date: Jan 11, 2009
Air is funny stuff, but it acts predictably. It is a fair assumption that oxygen doesn't react with the tire appreciably over a 30 day period, therefore the rate of deflation is a function of the diffusion rate across the membrane. In these physical exchanges, molecular size matters. Nitrogen gas (N2) has a molecular weight of 28, while oxygen gas (O2)has a molecular weight of 32. This reflects a difference in size of the molecule and based on this you would predict that nitrogen will leak out faster. I really think that all this effort to put N2 in your tires is bad science and wasted effort, or perhaps a way to extract a few more $ from you from the A&P. As the previous post points out, N2 can be used but it is driven by other reasons, not leak rate. By the way, humid air is less dense than dry air for the same reason. Water molecules with a molecular weight of 18 displace N2/O2 molecules which have a proportional molecular weight of about 31 making the average fluid denity less. The same principle is behind reverse osmosis units. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224016#224016 ________________________________________________________________________________
Subject: Nitrogen in Tires
Date: Jan 11, 2009
Previous thread under "Old subject revisited" I filled my tires with nitrogen a while back and they don't leak down anymore... not much anyway, what a blessing. At the same time, I replaced my inner tubes with Michelin Airstop tubes, so I'm not sure how much to credit nitrogen for the improvement. Curt Bryan also put nitrogen in his tires with the same result...very little leak down. But he too botched the experiment by further tightening the valve cores just to make sure they didn't leak. Consumer Reports did a study on this by inflating 31 pairs of tires of various models to 30 psi. One of each pair had nitrogen, the other air. They were set outside for one year and then rechecked. They found that on average the air filled tires dropped 3.5 psi, while the nitrogen filled tires dropped 2.2 psi; a difference of 1.3 psi. Yes they were careful to measure pressure at the same temperature, etc., etc. I assume they were tubeless tires... not sure how that would make a difference but maybe it would. But even if you have a much greater pressure loss due to actual tire use, landing or braking technique, or whatever; there is only a 4.3 (four point three) percent difference in air vs nitrogen. Hardly even measurable it would seem. http://blogs.consumerreports.org/cars/2007/10/tires-nitrogen-.html Airliners and race cars use nitrogen too: Air is a mixture of gases, not a gas in itself like oxygen or nitrogen; there is no such thing as a molecule of air. Air is 78% Nitrogen, 21% Oxygen, and 1% other stuff such as argon, carbon dioxide, neon, helium, hydrogen, methane and krypton, not to mention a huge list of pollutants and water vapor. The presence of water vapor in the air naturally dilutes or displaces the other air components as its concentration increases. Water vapor expands and contracts with temperature changes at a much greater rate than air. NASCAR teams use nitrogen because it allows them to more accurately predict tire pressure fluctuation. Nitrogen fluctuates with temperature change, but it does so less than when water vapor is present. The FAA requires nitrogen in all commercial aircraft tires to eliminate the potential for water vapor from freezing at high altitudes. Also, nitrogen, unlike oxygen, is not corrosive (no oxidation) and will not support combustion. If you want to rummage around on the internet you can look into molecular weights, permeability coefficients, Fick's Law of Diffusion, Henry's Law of Solubilities, Graham's Law of Effusion, and other fascinating gobbledygook, to find out that O2 permeates faster through rubber than does N2. So if that is true, and you keep filling your tires with air, and the oxygen keeps leaking out faster than nitrogen, wouldn't you eventually end up with mostly nitrogen anyway? jb RV-4 Tacoma -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of nukeflyboy Sent: Sunday, January 11, 2009 5:01 AM Subject: RV10-List: Re: Old subject revisited Air is funny stuff, but it acts predictably. It is a fair assumption that oxygen doesn't react with the tire appreciably over a 30 day period, therefore the rate of deflation is a function of the diffusion rate across the membrane. In these physical exchanges, molecular size matters. Nitrogen gas (N2) has a molecular weight of 28, while oxygen gas (O2)has a molecular weight of 32. This reflects a difference in size of the molecule and based on this you would predict that nitrogen will leak out faster. I really think that all this effort to put N2 in your tires is bad science and wasted effort, or perhaps a way to extract a few more $ from you from the A&P. As the previous post points out, N2 can be used but it is driven by other reasons, not leak rate. By the way, humid air is less dense than dry air for the same reason. Water molecules with a molecular weight of 18 displace N2/O2 molecules which have a proportional molecular weight of about 31 making the average fluid denity less. The same principle is behind reverse osmosis units. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224016#224016 Checked by AVG - http://www.avg.com 6:01 PM ________________________________________________________________________________
Subject: Wheel pants install - timing and helpful hints
Date: Jan 11, 2009
I am proceeding on the messy (no - no - not fiberglass dust again) task of installing the wheel pants and gear fairings. I have departed from the plans at several points. Suggestions 1. Fit the wheel pants before you install the wings. They will be under the wings and access is whole lot easier earlier in the game. It is a very time consuming task with a lot of fitting, measuring and back and forth between the wheels and the bench. 2. I used the composite pieces left over from the windows as shim material to "right size" the distance between the support flanges and the fairings. 3. Measure the centerline carefully. It is not always where you think it is. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224038#224038 ________________________________________________________________________________
Subject: Re: EFIS - Dual screen AFS advanced deck
Date: Jan 11, 2009
I have dual AFS 3500 set up to change to 4500 with garmin 'stack' between. They are 'shifted 'left' so all is easy to reach. I was initially concerned that the panel lacked 'symmetry but since really appreciate how easy it is to reach 430/530 and the right AFS. The copilot still can use the right AFS and also reach the radios. The autopilot also is in each reach, and easy to see. cheers. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224051#224051 ________________________________________________________________________________
Date: Jan 11, 2009
Slightly off-topic, but here is my 3 screen GRT with Stein's "center canted left" panel blank. Fair symmetry here but still pilot optimized. Bill "wiring it up" Watson 40605 don't archive ________________________________________________________________________________
Date: Jan 11, 2009
Larry I'd love to see pictures if you have them. -Ben __________ Information from ESET NOD32 Antivirus, version of virus signature database 3757 (20090111) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Jan 11, 2009
Don't discount Garmin entirely because of a few bad apples. The entire company isn't that way. After dealing with them for years now, I can honestly say that they are making a much better effort to work with the homebuilders. A number of their people are RV builder who are really great guys. They have in the past year created a new department within Garmin to specialize and focus on LSA's and Homebuilders. While the OEM guys aren't used to dealing with homebuilders, and admittedly Customer interaction is not necessarily some of those guys strong points, there are a number of them who are super to deal with. They have started listening, and listening for real. Take for example the new 240 Audio panel. They actually designed that thing 100% around experimental and LSA aircraft. It's Garmin's FIRST non TSO'd product that is marketed exclusively to the non-certified world. On top of that, they made it affordable and put all the functions in (and left out others) that WE as homebuilders asked for...period! Anyway, please don't judge the entire company by their inability to communicate with you as a homebuilder. You have to understand they come from a very different world, and while they are trying, this experimental stuff is still somewhat new to them....but give them credit because they are trying. Aside from that, at the moment there just aren't any good alternatives. Me, I like the Garmin guys for many reasons. I think if you were to work through a credible dealer you'd find your experience to be quite different. Garmin does not sell direct to homebuilders, therefore they really count on their dealers to help them. In the end I'd just encourage you not to rush to judgement on the entire company and product line because I can tell you that is not representative of the whole company. Here's another example of things I see as a positive....they don't fly around in corporate jets - they have to fly themselves around in single engine piston planes just like you and me. They have made great leaps over the past year or two with homebuilders and I can promise you they'll continue...based one what it coming down the pipeline! Cheers, Stein >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of johngoodman >Sent: Saturday, January 10, 2009 6:42 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Re: Audio Jacks > > >I don't know about Garmin stuff - I'm not sure I want to go down >that road. Everything they have is too pricey and they really >treated me like a leper at Oshkosh. The minute I mentioned that a >GNS430W was good enough and does it integrate with other brands, >he started looking over my shoulder.... >It kind of reminds me of Microsoft. Bose is another that seems to >think that they only excrete in clean, cellophane bags pre-tied >with pretty pink ribbons. > >I'll look but I'll view any price increase as an opportunity to go >elsewhere. > >John > >-------- >#40572 QB Fuselage, wings finished. Finish Kit is on it's way. >N711JG reserved > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=223943#223943 > > ________________________________________________________________________________
Date: Jan 11, 2009
i'll see if i can get the picture attached. it's a crummy picture, but only one i have of the panel. haven't finished it yet--still trying to figure out what kind of labeling to do. i'll take some pictures next time at the hangar -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224124#224124 Attachments: http://forums.matronics.com//files/img_0262_127.jpg ________________________________________________________________________________
Date: Jan 11, 2009
I have developed a new panel for the RV-10 I am building and it will hold 2 AFS advanced decks side by side. Here is a picture of the prototype mock up in my Rv-10. In this picture the backups are above but I will put them on the left side running vertical. -------- Build QB RV-10 N829GW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224128#224128 Attachments: http://forums.matronics.com//files/rv10_afs11_v6c_142.jpg http://forums.matronics.com//files/img_1201_114.jpg ________________________________________________________________________________
Subject: Maximum Panel Hieght
Date: Jan 11, 2009
I'm hoping to extend my panel height to 13" but not sure that I will have a problem with my forward stick movement hitting the panel. I have a CH Products grip and I have cut the stick down as far a possible. I'm trying to avoid having to reinstall the horizontal and elevator to check the stick forward clearance. I know that others have done this with various custom panels and I'm trying to find out if the elevator stops will limit the forward movement or do I have to trim the panel back up the the original height? Jesse or Stein or others that have gone through this, can you give me any insight? Thanks, Nick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224142#224142 ________________________________________________________________________________
Subject: Re: Maximum Panel Hieght
Date: Jan 12, 2009
I have the CH sticks and needed to also reweld the bases of the sticks to make them clear the panel. Gary Specketer -------------- Original message -------------- From: "Nick Leonard" <nick(at)nleonard.com> > > I'm hoping to extend my panel height to 13" but not sure that I will have a > problem with my forward stick movement hitting the panel. I have a CH Products > grip and I have cut the stick down as far a possible. I'm trying to avoid > having to reinstall the horizontal and elevator to check the stick forward > clearance. I know that others have done this with various custom panels and I'm > trying to find out if the elevator stops will limit the forward movement or do I > have to trim the panel back up the the original height? > > Jesse or Stein or others that have gone through this, can you give me any > insight? > > Thanks, > > Nick > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224142#224142 > > > > > > > > > >
Gary Specketer
> --> RV10-List message posted by: "Nick Leonard"
> insight?
> Thanks =====
Date: Jan 11, 2009
I have a Stein panel and had to re-weld my stick. Here is a copy of an e-mail from Scott Schmidt, he led the way for me and gets the credit..... "I had the same issues. There is nothing you can do with the rigging to make it fit. I cut my stick toward the top, purchased some steel that was the same grade and wall thickness. I can't remember what it was, but I called Van's and they knew. I then extended the stick about 1" and also angled it back just a little until it didn't hit anything. I hired a professional tig welder to help me weld it up. It turned out great and I actually like it back where it is. Here is a picture of the finished product. http://www.scottandranae.smugmug.com/gallery/1630837#101769967 Good luck. Scott Schmidt Office 801-990-1252 Cell 801-718-1277 Fax 801-990-1256 scottmschmidt(at)yahoo.com" Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Sunday, January 11, 2009 7:49 PM Subject: RV10-List: Maximum Panel Hieght I'm hoping to extend my panel height to 13" but not sure that I will have a problem with my forward stick movement hitting the panel. I have a CH Products grip and I have cut the stick down as far a possible. I'm trying to avoid having to reinstall the horizontal and elevator to check the stick forward clearance. I know that others have done this with various custom panels and I'm trying to find out if the elevator stops will limit the forward movement or do I have to trim the panel back up the the original height? Jesse or Stein or others that have gone through this, can you give me any insight? Thanks, Nick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224142#224142 ________________________________________________________________________________
Subject: F-10110-R?
Date: Jan 11, 2009
Van's Wiring Harness comes with a fuselage part F-10110-L, which covers the wires in the left sidewall. I have quite a few wires running down the right sidewall, and wonder if there is an aftermarket F-10110-R that would allow for similar routing on the right side. I suppose I could make the part myself, but trying to avoid the hours. Anybody have any better ideas? -------- Chase Snodgrass, CFI Presidio, Texas www.flybigbend.com 40820/40821 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224150#224150 ________________________________________________________________________________
Subject: F-10110-R?
Date: Jan 12, 2009
Tried to order a RHS one from vans with no success. Made one using mirror image of the left - took about an hour and works fine. Cheers, Ron -187 fiddly bits and paperwork -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of westexflyboy Sent: Monday, 12 January 2009 2:07 PM Subject: RV10-List: F-10110-R? --> Van's Wiring Harness comes with a fuselage part F-10110-L, which covers the wires in the left sidewall. I have quite a few wires running down the right sidewall, and wonder if there is an aftermarket F-10110-R that would allow for similar routing on the right side. I suppose I could make the part myself, but trying to avoid the hours. Anybody have any better ideas? -------- Chase Snodgrass, CFI Presidio, Texas www.flybigbend.com 40820/40821 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224150#224150 "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Brake lines
I just installed the Bonaco Brake Lines on the pedals today.=C2- I'm very impressed with the quality of the product and customer service received fr om Brett.=C2- I think it was Deems (thanks) that pointed out these are av ailable in color as well.=C2- I chose Royal Blue to go with one of the co lors in the interior.=C2- I have no affiliation with Bonaco, just a happy and impressed customer.=C2- Photo is attached. Sean Blair #40225=C2-=C2- ________________________________________________________________________________
Date: Jan 11, 2009
The elevator stops won't limit the travel, you will need to modify the geometry of the control sticks to allow for full travel. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Nick Leonard wrote: > > I'm hoping to extend my panel height to 13" but not sure that I will have a problem with my forward stick movement hitting the panel. I have a CH Products grip and I have cut the stick down as far a possible. I'm trying to avoid having to reinstall the horizontal and elevator to check the stick forward clearance. I know that others have done this with various custom panels and I'm trying to find out if the elevator stops will limit the forward movement or do I have to trim the panel back up the the original height? > > Jesse or Stein or others that have gone through this, can you give me any insight? > > Thanks, > > Nick > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224142#224142 > > > ________________________________________________________________________________
Date: Jan 11, 2009
Subject: Re: F-10110-R?
I had wanted to do the same. Instead I ran my right side wires according to the Wiring Harness kit's procedure (at least that's what I recall). My thick wires (2 batt/2 alt) are both run on the left under F-10110-L along with a few other wire. I only have thin wires on the right side and they are run up under the triangular piece common to both sides. It's working well so far. BTW, I didn't buy the Van's kit but did use the manual to order the key parts. The Wiring Harness manual is very useful even if one is doing a very custom wiring job. Bill westexflyboy wrote: > > Van's Wiring Harness comes with a fuselage part F-10110-L, which covers the wires in the left sidewall. I have quite a few wires running down the right sidewall, and wonder if there is an aftermarket F-10110-R that would allow for similar routing on the right side. I suppose I could make the part myself, but trying to avoid the hours. Anybody have any better ideas? > > -------- > Chase Snodgrass, CFI > Presidio, Texas > www.flybigbend.com > 40820/40821 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224150#224150 > > > ________________________________________________________________________________
Date: Jan 11, 2009
Subject: Nose Wheel Axle
I installed the new nose wheel axle assembly from Matco this weekend. It is a very nice piece and at around $60.00 is great price. Here is some more info on it and pictures of my install. http://www.vansairforce.com/community/showthread.php?t=38336 Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Subject: Re: Wheel pants install - timing and helpful hints
Date: Jan 11, 2009
Check the centerline very carefully. I ran a steel ruler (24") from the center rivet out to an equidistant point on the wing flange and it was a hair off. Also in the rear part of the fuse the ribs are not proportionately spaced. Like I said check the centerline carefully. I also did the job alone. It is a lot better to use a thin string line running from front to back with2 people monitoring its position. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224165#224165 ________________________________________________________________________________
Date: Jan 11, 2009
View this previous thread. http://forums.matronics.com/viewtopic.php?t=42513&highlight=stick+weld Scott Schmidt scottmschmidt(at)yahoo.com ________________________________ From: Deems Davis <deemsdavis(at)cox.net> Sent: Sunday, January 11, 2009 8:26:07 PM Subject: Re: RV10-List: Maximum Panel Hieght The elevator stops won't limit the travel, you will need to modify the geometry of the control sticks to allow for full travel. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Nick Leonard wrote: > > I'm hoping to extend my panel height to 13" but not sure that I will have a problem with my forward stick movement hitting the panel. I have a CH Products grip and I have cut the stick down as far a possible. I'm trying to avoid having to reinstall the horizontal and elevator to check the stick forward clearance. I know that others have done this with various custom panels and I'm trying to find out if the elevator stops will limit the forward movement or do I have to trim the panel back up the the original height? > > Jesse or Stein or others that have gone through this, can you give me any insight? > > Thanks, > > Nick > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224142#224142 > > > ________________________________________________________________________________
Date: Jan 12, 2009
At 13" you shouldn't have any problem at all. Most of the panels we do are exactly that size (our modular panel is exactly 13"). That is only .75" more than the standard Van's panel. More of it depends on your stick grip than the panel, as those can add 6" to the stick. As Rene said, sometimes the easiest is just having a new stick welded or modify your current one. Been done lots of times! Cheers, Stein >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Nick Leonard >Sent: Sunday, January 11, 2009 8:49 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Maximum Panel Hieght > > >I'm hoping to extend my panel height to 13" but not sure that I >will have a problem with my forward stick movement hitting the >panel. I have a CH Products grip and I have cut the stick down >as far a possible. I'm trying to avoid having to reinstall the >horizontal and elevator to check the stick forward clearance. I >know that others have done this with various custom panels and I'm >trying to find out if the elevator stops will limit the forward >movement or do I have to trim the panel back up the the original height? > >Jesse or Stein or others that have gone through this, can you give >me any insight? > >Thanks, > >Nick > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=224142#224142 > > ________________________________________________________________________________
Subject: Re: Nose Wheel Axle
Date: Jan 12, 2009
Scott - could you please explain in detail what the defect is with the OEM Vans parts and why the Matco axle resolves the issue -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224223#224223 ________________________________________________________________________________
Date: Jan 12, 2009
Hey Mike, Here's the repost, Later, - Lew Hi Everyone, I want to share with you the permanent fix that I have come up with for the front axle spacer problems we have been having lately. We have seen everything from gouging of outer yokes to the bearing spinning on the axle due to the loss of bearing pre-load. I decided to take a real close look at the system to see what the root problem is and I found that the spacers provided with the kit, both the steel ones delivered with the kit initially and the aluminum ones sent out as a fix do not interface with the bearing properly. This is due to two issues. The first is that the mating surface on the bearing for the spacer is curved. I contacted Timken Bearing and they sent me the dimensioned cross section of that bearing which showed that the curved mating surface was a compound curve that melded two radii. This is not an easy surface to mate to. The second issue was that of the wall thickness of the aluminum spacers set out by Van's to replace the initial steel ones. The wall thickness of these aluminum spacers is .250in. The mating surface of the bearing is approx. .187in. This is the steel contact area inside of the rubber bearing seal. This meant that the spacer was pre-loading on the rubber bearing seal instead of the steel portion of the bearing. In many cases this has resulted in the loss of the pre-load as the rubber deteriorates. Consequently, there were bearings spinning, yokes being gouged and loose wheels which add to bearing wear and shimmy. I initially thought that I would take the same approach as Ross Farnham and machine profiles on the end of new steel spacers so that the interface between them and the bearing was close to identical. I called Ross and talked it over with him and he said that if he had more time to put into it he would have made one of the spacers adjustable. I asked him if I could run with that and he agreed it would be the best fix. So, what I have been able to design is a system where there is a perfect interface between the spacers and the bearings by utilizing the Timken specifications and the accuracy of CNC machining. I have also been able to design a robust and accurate adjustment mechanism into one of the spacers so that the pre-load can be adjusted without having to take the wheel apart. Integrated into the spacer design are notches that accept the heads of 10-24 socket-head cap screws installed on the inner face of the yoke. These restrict the spacers from being able to spin on the axle. As well, you will now be able to accurately torque the front wheel bolt because it no longer has any relationship to the pre-load of the bearings. The screw adjustment ring is locked in place by two 1/4-20 socket-head cap screws that have drilled heads so they can be safety wired. All of these new components including the hardware is made from stainless steel for durability and corrosion resistance. I just finished installing a set in my front wheel assembly and it goes together and adjusts very easily. I will be offering these for sale through Mike Lauritsen at Cleaveland Tools. The kits will include all hardware instructions and the drill guide used to locate the anti-rotation screws. You can go to my Blog site and read about these and see pictures of the RV-10 as well as the RV6/7/8/9 components. It is located at the following address: http://www.kitaircraftmods.com I feel as though I have now installed a permanent fix to this problem and I hope that if you are interested in the kit I have put together you will go and visit the Cleaveland Tools site. The first 10 production kits of each variant will be available sometime in mid January but please leave your name with them if you are interested so we can get a handle on how many are going to be required. Many thanks for reading this long post. Dave Hertner RV-10 Builder #10164 Effectus AeroProducts Inc. -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224230#224230 ________________________________________________________________________________
Date: Jan 12, 2009
I didn't wait for Van's to correctly solve the problem. I have gone with the Grove nose wheel. Was very easy to install and I think it removes the original problem. -------- Gary Blankenbiller RV10 - # 40674 Engine, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224245#224245 ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Transporting Fuselage
Does anyone have any suggestions for transporting the -10 fuselage to the airport? I'm approximately 15 miles from the field, all on relatively congested roads. Any suggestions or info on how others have done it are appreciated. Thanks, Tom Gesele #40473 ________________________________________________________________________________
Date: Jan 12, 2009
I am a little confused about the different products ou tthere which address this issue. Matco=2C $60.00 or the axle Cleaveland is selling=2C $170.00 w hich I thought was marketed by an independant...Aircraft Mods blog guy. The n I recall there also was another person who made the YouTube videos or are these the same person. Which one is distributed by CLeaveland???? JOhn G.> Subject: RV10-List: Re: Nose Wheel Axle> From: Mikeabel(at)Pacbell.ne t> Date: Mon=2C 12 Jan 2009 07:58:49 -0800> To: rv10-list(at)matronics.com> > - could you please explain in detail what the defect is with the OEM Vans p arts and why the Matco axle resolves the issue> > --------> OSH '08 or Bust (busted) be there in "=3B09> Q/B Kit - wiring and FWF> > > > > Read th is topic online here:> > http://forums.matronics.com/viewtopic.php?p=2242 ====================> > > ________________________________________________________________________________
Subject: Re: Transporting Fuselage
Date: Jan 12, 2009
Hey Tom, Others have used snowmobile trailers, construction trailers, etc. -- has to be 8' wide. We checked into renting a trailer and found that it was a lot cheaper to hire a tow truck (skid truck, roll back -- the kind that tilts) so we're planning on doing that. It costs about $75 here in SC and they pick it up (we'll secure it) and deliver it. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224258#224258 ________________________________________________________________________________
Subject: Tailcone Question
Date: Jan 12, 2009
For those of you who have completed the tailcone (and attached it), I have a question.... I am ready to begin riveting the tailcone, but I still have some confusion regarding the attachment - and how that relates to dimpling holes. The plans say to "dimple all of the #40 skin holes with the exception of holes that are part of the F-1006 frame". I did that. However some of these holes are shared between the tailcone stiffeners (1047's) and the F-1006 frame. I think I need to go ahead and dimple the holes that are common with the skin and 1047 stiffeners - even though they are also common with the frame. Otherwise I'll never get a dimple back behind the skin again and I will be forced to try and dimple two pieces of aluminum at one. Anyone else run into this issue? I bet I'm okay with dimpling those holes even though they're part of 1006 assembly. Phil ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 12, 2009
The one that Scott posted about is a new solution developed directly by M atco (manufacturer of our wheels) to address the short comings of how the w heels mount to our fork type RV's. The one that Dave Hertner is developing is very similar and will be sold by Cleaveland. Nothing against Daves fine work but given the one that Scott posted is ac tually developed by Matco and is 1/3rd the price I just ordered a Matco. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John Gonzalez Sent: Monday, January 12, 2009 10:54 AM Subject: RE: RV10-List: Re: Nose Wheel Axle I am a little confused about the different products ou tthere which address this issue. Matco, $60.00 or the axle Cleaveland is selling, $170.00 which I thought was marketed by an independant...Aircraft Mods blog guy. Then I recall there also was another person who made the YouTube videos or are the se the same person. Which one is distributed by CLeaveland???? JOhn G. > Subject: RV10-List: Re: Nose Wheel Axle > From: Mikeabel(at)Pacbell.net > Date: Mon, 12 Jan 2009 07:58:49 -0800 > To: rv10-list(at)matronics.com > > > Scott - could you please explain in detail what the defect is with the OE M Vans parts and why the Matco axle resolves the issue > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - wiring and FWF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224223#224223 > >== > > ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Re: Tailcone Question
Phil, I think the holes you are talking about are the three near where the longer on meets the tailcone? If so they get machine countersunk to accept a shim and dimpleted skin. IIRC. Rick Sked 40185 ----- Original Message ----- From: "Phil Perry" <Phil.Perry(at)netapp.com> Sent: Monday, January 12, 2009 9:08:50 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Tailcone Question For those of you who have completed the tailcone (and attached it), I have a question.... I am ready to begin riveting the tailcone, but I still have some confusion regarding the attachment - and how that relates to dimpling holes. The plans say to "dimple all of the #40 skin holes with the exception of ho les=C2-that are part of the=C2-F-1006 frame".=C2- I did that. However some of these holes are shared between the tailcone stiffeners (104 7's) and the F-1006 frame. I think I need to go ahead and dimple the holes that are common with the sk in and 1047 stiffeners - even though they are also common with the frame. =C2- Otherwise I'll never get a dimple back behind the skin again and I w ill be forced to try and dimple two pieces of aluminum at one. Anyone else run into this issue?=C2- I bet I'm okay with dimpling those holes even though they're part of 1006 a ssembly. ============ == ________________________________________________________________________________
Date: Jan 12, 2009
I had to hire the "larger" flatbed because the little one did not carry enough insurance to cover the aircraft. I had the avionics and engine installed which exceeded the 100k coveage on the little tow truck. It cost me $165 to get it to the airport for a 10 mile trip. I can't wait to haul it acrosed the county to Boulder City for the first flight. Rick Sked 40185 ----- Original Message ----- From: "Lew Gallagher" <lewgall(at)charter.net> Sent: Monday, January 12, 2009 9:05:29 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Re: Transporting Fuselage Hey Tom, Others have used snowmobile trailers, construction trailers, etc. -- has to be 8' wide. We checked into renting a trailer and found that it was a lot cheaper to hire a tow truck (skid truck, roll back -- the kind that tilts) so we're planning on doing that. It costs about $75 here in SC and they pick it up (we'll secure it) and deliver it. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224258#224258 ________________________________________________________________________________
Date: Jan 12, 2009
Hey Tim, Is this the Matco page? http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224271#224271 ________________________________________________________________________________
Date: Jan 12, 2009
yep http://www.vansairforce.com/community/showthread.php?t=38336 -------------------------------------------------- From: "Lew Gallagher" <lewgall(at)charter.net> Sent: Monday, January 12, 2009 9:32 AM Subject: RV10-List: Re: Nose Wheel Axle > > Hey Tim, > > Is this the Matco page? > > http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Painting when it's 60+ degrees! > Piddling with wiring and avionics. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224271#224271 > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2009
Ah yes, sorry I didn't include a link before. Also, Scott was asking on my behalf and here is an email that they sent via him, regarding what you need to order: ------------------------- "The WHLAXLE24 nose wheel axle is now linked on the home page of our website. the address is http://www.matcomfg.com We are offering them at a very good price! He will need two of the WHLA24SP spacers as well as the WHLAXLE24 (the spacers are the 0.325 thick discs that go on each side of the axle) for the RV-10 installation Thanks, George R. Happ MATCO mfg" -------------------------- Tim Olson - RV-10 N104CD - Flying Lew Gallagher wrote: > > Hey Tim, > > Is this the Matco page? > > http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Painting when it's 60+ degrees! > Piddling with wiring and avionics. > > ________________________________________________________________________________
Date: Jan 12, 2009
You can save a lot of time by using a laser level that is capable of shooting a floor and ceiling line at the same time. Makes it much easier to determine the fuselage centerline, then transfer it to the floor. Then establish parallel offsets from that line for each wheel pant. The laser level also makes it easy to establish level lines on each wheel pant. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224291#224291 ________________________________________________________________________________
Date: Jan 12, 2009
Thanks Rick.. I know the 3 holes you're thinking of, and unfortunately this isn't them. I'm talking specifically about the forward-most holes in the stiffeners. Those holes are shared with between: 1) The tailcone skin. 2) The stiffeners. 3) The F-1006 bulkhead (frame) 4) The aft end of the mid-fuse skin. Phil ________________________________ From: Rick Sked [mailto:ricksked(at)embarqmail.com] Sent: Monday, January 12, 2009 11:19 AM Subject: Re: RV10-List: Tailcone Question Phil, I think the holes you are talking about are the three near where the longeron meets the tailcone? If so they get machine countersunk to accept a shim and dimpleted skin. IIRC. Rick Sked 40185 ----- Original Message ----- From: "Phil Perry" <Phil.Perry(at)netapp.com> Sent: Monday, January 12, 2009 9:08:50 AM (GMT-0800) America/Los_Angeles Subject: RV10-List: Tailcone Question For those of you who have completed the tailcone (and attached it), I have a question.... I am ready to begin riveting the tailcone, but I still have some confusion regarding the attachment - and how that relates to dimpling holes. The plans say to "dimple all of the #40 skin holes with the exception of holes that are part of the F-1006 frame". I did that. However some of these holes are shared between the tailcone stiffeners (1047's) and the F-1006 frame. I think I need to go ahead and dimple the holes that are common with the skin and 1047 stiffeners - even though they are also common with the frame. Otherwise I'll never get a dimple back behind the skin again and I will be forced to try and dimple two pieces of aluminum at one. Anyone else run into this issue? I bet I'm okay with dimpling those holes even though they're part of 1006 assembly. Phil 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Subject: Re: Nitrogen in Tires
Date: Jan 12, 2009
Exactly. There are a host of reasons to use nitrogen per the previous note, none of them have to do with leak rate, and non are particularly pertinent to RV-10s. It's one of those things that you can do if you want (ie, does no harm) but is of dubious value and not worth the effort and expense. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224312#224312 ________________________________________________________________________________
Date: Jan 12, 2009
John, I make the IFLYRV10.COM parts and am also the one who tried to describe the problem in the youtube video . Cleaveland aircraft tool has most of my stuff available in their catalog, but I don't think mike listed my version of the axle yet (its on my website @99$). there are some great options for this fix, mine is based on a cessna axle style with end cups instead of sleeves. As tim mentioned, matco has really stepped up offering a nice setup at what seems to be nearly at cost to manufacture. steve dinieri From: John Gonzalez Sent: Monday, January 12, 2009 11:53 AM Subject: RE: RV10-List: Re: Nose Wheel Axle I am a little confused about the different products ou tthere which address this issue. Matco, $60.00 or the axle Cleaveland is selling, $170.00 which I thought was marketed by an independant...Aircraft Mods blog guy. Then I recall there also was another person who made the YouTube videos or are these the same person. Which one is distributed by CLeaveland???? JOhn G. > Subject: RV10-List: Re: Nose Wheel Axle > From: Mikeabel(at)Pacbell.net > Date: Mon, 12 Jan 2009 07:58:49 -0800 > To: rv10-list(at)matronics.com > > > Scott - could you please explain in detail what the defect is with the OEM Vans parts and why the Matco axle resolves the issue > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - wiring and FWF > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224223#224223 > >== > > > ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Adjustable Axle Spacers - Effectus AeroProducts
Hi Everyone, It seems as though I have been scooped in the marketplace!! With the introduction of the Matco adjustable axle my product offering has effectively been run outta town! There is little chance of me being able to compete with a product being offered by the company with whom the problem originated. This is just how things go sometimes. I would like to inform those who had contacted Cleaveland Tools to place a pre-order that I have canceled the product offering in fairness to Mike at Cleaveland Tools even though they had ordered product already. I would hate to have that product sit on their shelves with no interest in them. To those who had the confidence to pre-order my adjustable pre-load axle spacers, Thank You. It is always gratifying to have the confidence of your peers. I look forward to offering other accessories and parts to the kit builder and kit manufacturer alike. Regards, Dave -- Dave Hertner President Effectus AeroProducts Inc. Kit Aircraft Component Manufacturing Machining - Fabrication - Laser/Water-Jet Cutting Blog: http://www.kitaircraftmods.com Email: davehertner@effectus-aeroproducts.com Phone: (519) 933-2055 ________________________________________________________________________________
Date: Jan 12, 2009
> BTW, I didn't buy the Van's kit but did use the manual to order the key > parts. The Wiring Harness manual is very useful even if one is doing a > very custom wiring job. Where can I get a copy of the "Van's Wiring Manual" ? Thanks [/quote][/quote] -------- Wayne RV 7 "eh?" 120 hrs RV 10 fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224350#224350 ________________________________________________________________________________
Subject: gas strut installation gotcha
Date: Jan 12, 2009
I created another oops today when installing the wd-1023 gas strut attach brackets to the cabin top. The plans say the overall position is determined by the "best-fit". That is true but pay special attention to Figure 1 on Sec 45, Page 16. I've attached a picture of the plans for reference. Notice that the attach hole for the gas strut on the weldment piece is roughly in line with the edge of the cabin top. This ends up being an important height although not called out in the plans. If your attach hole is higher than the cabin top edge be sure to "locally relieve" like the plans say. If the wd-1023 is too high above the cabin top lip the gas strut will contact the door before it can close all the way. I installed mine too high thus I couldn't fit the C-1013 brackets to the door. I didn't want to go to the work of filling the holes in the top with epoxy and re-drill so I made a new attach hole lower on the wd-1023 bracket. I'll cut the old hole off and round the bracket so it looks like the stock ones. Just thought I'd send this out in hopes I keep somebody else from inventing new cuss words like I did today. Pictures attached. -Ben Westfall #40579 ________________________________________________________________________________
Subject: Fuse Stands
Date: Jan 12, 2009
Hi, I'm expecting my QB fuse in the coming weeks and I'd like to have a fuse stand waiting on it. After researching on Tim's site and he a photo of Rick Sked's fuse holder. Does anyone else have photos of similar fuse holders? Thanks, Phil ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Battery Chassis Grounding...
I'm mounting the battery in my RV-8 in the rear similar to the way the RV-10 is mounted. But what's the recommend procedure for attaching the Ground cable? I assume a AN5 bolt and aeronut, but what other hardware? Where's a good place to physically attach it? Anyone have some pictures of their installation? Thanks! Matt Dralle RV-8 #82880 N998RV ________________________________________________________________________________
Date: Jan 12, 2009
As I recall, the plans have you leave those holes alone until you mate up with the forward fuselage. I think the idea is that you want to match drill them, and then dimple them after you've mated things together. It still freaks me out that we can just butt join the fuse and tailcone. I get the engineering but it still seems weird. Perry, Phil wrote: > Thanks Rick.. > > I know the 3 holes you're thinking of, and unfortunately this isn't > them. I'm talking specifically about the forward-most holes in the > stiffeners. > > Those holes are shared with between: > 1) The tailcone skin. > 2) The stiffeners. > 3) The F-1006 bulkhead (frame) > 4) The aft end of the mid-fuse skin. > > Phil > > > > > ------------------------------------------------------------------------ > *From:* Rick Sked [mailto:ricksked(at)embarqmail.com] > *Sent:* Monday, January 12, 2009 11:19 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Tailcone Question > > Phil, > > I think the holes you are talking about are the three near where the > longeron meets the tailcone? If so they get machine countersunk to > accept a shim and dimpleted skin. IIRC. > > Rick Sked > > 40185 > ----- Original Message ----- > From: "Phil Perry" <Phil.Perry(at)netapp.com> > To: rv10-list(at)matronics.com > Sent: Monday, January 12, 2009 9:08:50 AM (GMT-0800) America/Los_Angeles > Subject: RV10-List: Tailcone Question > > For those of you who have completed the tailcone (and attached it), I > have a question.... > > I am ready to begin riveting the tailcone, but I still have some > confusion regarding the attachment - and how that relates to dimpling > holes. > > The plans say to "dimple all of the #40 skin holes with the exception > of holes that are part of the F-1006 frame". I did that. > > However some of these holes are shared between the tailcone stiffeners > (1047's) and the F-1006 frame. > > I think I need to go ahead and dimple the holes that are common with > the skin and 1047 stiffeners - even though they are also common with > the frame. Otherwise I'll never get a dimple back behind the skin > again and I will be forced to try and dimple two pieces of aluminum at > one. > > Anyone else run into this issue? > > I bet I'm okay with dimpling those holes even though they're part of > 1006 assembly. > > Phil > * > > > * > * > > 3D============================================ > href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List > 3D============================================ > href='3D"http://forums.matronics.com"'>http://forums.matronics.com > 3D============================================ > href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution > 3D============================================ > > * > * > > > * ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Re: Battery Chassis Grounding...
Matt, Bob has an excellent article on his site with a pic: http://www.aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html I'm attaching 2 pics of my interpretation. You'll notice I added the ground wire for the forest of tabs in one pic. Thank You. Bill Matt Dralle wrote: > > > I'm mounting the battery in my RV-8 in the rear similar to the way the RV-10 is mounted. But what's the recommend procedure for attaching the Ground cable? I assume a AN5 bolt and aeronut, but what other hardware? Where's a good place to physically attach it? Anyone have some pictures of their installation? > > Thanks! > > Matt Dralle > RV-8 #82880 N998RV > > > ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Re: Fuse Stands
I used two motorcycle stands from Harbor F (they were on sale). I used a couple of 2x4s to connect them, then I threw a 4x4 board on top. Crude but it is VERY easy to roll around. Perry, Phil wrote: > Hi, > > I'm expecting my QB fuse in the coming weeks and I'd like to have a > fuse stand waiting on it. > > After researching on Tim's site and he a photo of Rick Sked's fuse holder. > > Does anyone else have photos of similar fuse holders? > > Thanks, > Phil > > * > > > * ________________________________________________________________________________
Date: Jan 12, 2009
Phil - I used two engine stands from Harbor-Freight on my RV-7. Minor changes to the aft attachment would adapt it to the -10. Does anyone else have photos of similar fuse holders? Thanks, Phil ________________________________________________________________________________
Date: Jan 12, 2009
You'll get real anal later and look at how everyone of the 10s has a differ ent appearence when the doors are completely opened...some the left door is more open than the right and some the other way around. Kind bugs me.JOhnF rom: rv10(at)sinkrate.comTo: rv10-list(at)matronics.comSubject: RV10-List: gas st rut installation gotchaDate: Mon=2C 12 Jan 2009 16:36:09 -0800 I created another oops today when installing the wd-1023 gas strut attach brackets to the cabin top. The plans say the overall position is determined by the =93best-fit=94. That is true but pay special attention to Figure 1 on Sec 45=2C Page 16. I=92ve attached a picture of t he plans for reference. Notice that the attach hole for the gas strut on the weldment piece is roughly in line with the edge of the cabin top. This end s up being an important height although not called out in the plans. If your at tach hole is higher than the cabin top edge be sure to =93locally relieve=94 like the plans say. If the wd-1023 is too high above the cabin top lip the gas strut will contact the door before it can close all the way. I installed mine too high thus I couldn=92t fit the C-1013 brackets to the door. I didn=92t want to go to the work of filling the holes in the top with epoxy and re-drill so I made a new attach hole lo wer on the wd-1023 bracket. I=92ll cut the old hole off and round the bracket so it looks like the stock ones. Just thought I=92d send this out in hopes I keep somebody else from inventing new cuss words like I did today. Pictures attached. -Ben Westfall #40579 __________ Information from ESET NOD32 Antivirus=2C version of virus signa ture database 3760 (20090112) __________The message was checked by ESET NOD 32 Antivirus. ________________________________________________________________________________
Date: Jan 13, 2009
Subject: flexible fuel lines
Hey all, After trying to make the bends=C2-in the solid aluminum fuel lines, I hav e decided to go with the stainless/braided=C2-flexible lines.=C2- Can a nyone recommend how much length to allow=C2-for the section of line exiti ng the fuse for attachment to the tank?=C2- I assume=C2-most lines =C2 -are different on the overall dimension depending on the placement of the fuel valve. Thanks! Sean Blair=C2- #40225 ________________________________________________________________________________
Date: Jan 12, 2009
Here are some thoughts. http://nerv10.com/wcurtis/fusestand/index.html http://www.vansairforce.com/community/showthread.php?t=37550 William http://nerv10.com/wcurtis/ -------- Original Message -------- > Hi, > > I'm expecting my QB fuse in the coming weeks and I'd like to have a fuse > stand waiting on it. > > After researching on Tim's site and he a photo of Rick Sked's fuse > holder. > > Does anyone else have photos of similar fuse holders? > > Thanks, > Phil ________________________________________________________________________________
Date: Jan 12, 2009
Here's the best pic I have of my fuse stand. all 2X4s .... the uprights have a screw (protect the spar with plastic hose around the screw) through the wing attach holes, and the blocks on the step keep it from sliding off. One crosspiece across by the uprights. Then I added an 8' 2X4 under that because the CG went too far aft with the tail feathers on. Note the block on the floor next to the step ..... the 8' 2X4 sags too much and needs another caster. This keeps the fuse low so you can lean over to work on the innards and it rolls around when I need it to. Linn ________________________________________________________________________________
Date: Jan 12, 2009
Is your favorite airport manager already banning experimental aircraft? On Mon, Jan 12, 2009 at 10:22 AM, Rick Sked wrote: > > I had to hire the "larger" flatbed because the little one did not carry enough insurance to cover the aircraft. I had the avionics and engine installed which exceeded the 100k coveage on the little tow truck. It cost me $165 to get it to the airport for a 10 mile trip. I can't wait to haul it acrosed the county to Boulder City for the first flight. > > Rick Sked > 40185 ________________________________________________________________________________
Date: Jan 13, 2009
Well, Rick, Kelly has a point. If all the experimental-types on the field got together and refused to pay their rent on a given month, buy no fuel, hire not a single instructor-hour, not even a canned beverage out of the machine... say... Feb 09... you might get city council's attention... I see an excuse for a community gathering; homebuilders, local media, AOPA, EAA, AvWeb, AeroNews coverage... eggs and livermush, biscuits and gravy (you guys know what that is?)... families, well-wishers, bookies... Waffle House, (no)... on the ramp!... Around a pile of shredded cardboard and discarded McNellis trash to heat the grill... neal -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, January 12, 2009 11:14 PM Subject: Re: RV10-List: Re: Transporting Fuselage Is your favorite airport manager already banning experimental aircraft? ________________________________________________________________________________
Date: Jan 13, 2009
ICBJIHdhcyBvcmlnaW5hbGx5IGdvaW5nIHRvIHVzZSBmbGV4aWJsZSBsaW5lcyBhbHNvLCBwcmlt YXJpbHkgYmVjYXVzZSBvZiB0aGUgdGlnaHQgYmVuZHMgZ2V0dGluZyBpbnRvIHRoZSB0dW5uZWwg YW5kIHVwIHRvIHRoZSBBbmRhaXIgdmFsdmUgd2hpY2ggaW4gbXkgY2FzZSB3YXMgbW91bnRlZCBo YWxmIHdheSBkb3duIGluIHRoZSB0dW5uZWwgbWFraW5nIGl0IGV2ZW4gbW9yZSBvZiBhIGNoYWxs ZW5nZS4gIEkgdGhpbmsgSSBsZWZ0IGFib3V0IGEgZm9vdCBoYW5naW5nIG91dCBvZiB0aGUgZnVz ZWxhZ2Ugb24gZWFjaCBzaWRlIHdoaWNoIHNob3VsZCBiZSBtb3JlIHRoYW4gZW5vdWdoLiAgVWx0 aW1hdGVseSBJIGRpZG7igJl0IGxpa2UgdGhlIGZhY3QgdGhhdCBJIHdvdWxkIGhhdmUgdG8gcmVw bGFjZSB0aGVtIGV2ZXJ5IGZldyB5ZWFycyBhbmQgeWFua2VkIHRoZW0gb3V0LiAgSSBlbmRlZCB1 cCBnb2luZyB0byB0aGUgcGxhbnMgZGVzaWduIG9mIEFMIGhhcmQgbGluZXMuICBJIGRpZCBpbnN0 YWxsIGEgYnVsa2hlYWQgZml0dGluZyB3aGVyZSB0aGUgaGFyZCBsaW5lcyB3b3VsZCBleGl0IHRo ZSBmdXNlbGFnZSBzbyBJIGNhbiB1c2UgYSBzaG9ydCBwaWVjZSB0byBjb25uZWN0IHRvIHRoZSB0 YW5rLg0KDQogIElmIHlvdSByZWFsbHkgZG8gZGVjaWRlIHRvIGdvIHdpdGggZmxleGlibGUgbGlu ZXMsIHlvdSBtaWdodCB3YW50IHRvIGdpdmUgQnJldHQgYXQgQm9uYWNvIGEgY2FsbCBhcyBJIGJl bGlldmUgdGhleSBoYXZlIGJlZW4gd29ya2luZyBvbiBhIGZ1ZWwgbGluZSBraXQgaW4gYWRkaXRp b24gdG8gdGhlaXIgYnJha2UgbGluZSBraXQuDQoNCk1pY2hhZWwNCg0KRnJvbTogb3duZXItcnYx MC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZl ckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgZG9nc2JhcmtAY29tY2FzdC5uZXQNClNlbnQ6 IE1vbmRheSwgSmFudWFyeSAxMiwgMjAwOSAxMDoxNCBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25p Y3MuY29tDQpTdWJqZWN0OiBSVjEwLUxpc3Q6IGZsZXhpYmxlIGZ1ZWwgbGluZXMNCg0KDQpIZXkg YWxsLA0KDQoNCg0KQWZ0ZXIgdHJ5aW5nIHRvIG1ha2UgdGhlIGJlbmRzIGluIHRoZSBzb2xpZCBh bHVtaW51bSBmdWVsIGxpbmVzLCBJIGhhdmUgZGVjaWRlZCB0byBnbyB3aXRoIHRoZSBzdGFpbmxl c3MvYnJhaWRlZCBmbGV4aWJsZSBsaW5lcy4gIENhbiBhbnlvbmUgcmVjb21tZW5kIGhvdyBtdWNo IGxlbmd0aCB0byBhbGxvdyBmb3IgdGhlIHNlY3Rpb24gb2YgbGluZSBleGl0aW5nIHRoZSBmdXNl IGZvciBhdHRhY2htZW50IHRvIHRoZSB0YW5rPyAgSSBhc3N1bWUgbW9zdCBsaW5lcyBhcmUgZGlm ZmVyZW50IG9uIHRoZSBvdmVyYWxsIGRpbWVuc2lvbiBkZXBlbmRpbmcgb24gdGhlIHBsYWNlbWVu dCBvZiB0aGUgZnVlbCB2YWx2ZS4NCg0KDQoNClRoYW5rcyENCg0KDQoNClNlYW4gQmxhaXINCg0K IzQwMjI1DQoNCg0K ________________________________________________________________________________
Date: Jan 13, 2009
Subject: Re: Adjustable Axle Spacers - Effectus AeroProducts
In all fairness to Matco, it should be noted that Matco just made the wheels and Vans picked them for the RV-10. Van's designed the axle and spacers, and Van's chose to make them the way they did...choosing not to make them fit the bearing taper, choosing not to size the inside of the spacers for the rubber seal....all of that. So the design flaws aren't Matco's fault. They didn't even SEE an RV-10 application until they worked with Scott to try to find out what they could do to stop getting complaints about the design...so they worked with him to come up with a better design for ALL of the RV nosewheel kits. They HAD to come up with something, so that their own reputation doesn't suffer from the bad design of our original kits. This isn't a big slam on Van's, either. They try their best to make things cheap for the builder. The problem comes in that many people, especially people building the higher-priced RV-10 model, aren't happy with some of the cost compromises, and expect more. That's how things like the axle extensions, this nosewheel fix, and heck, all of those Rivetmaster and iflyrv10 parts came to be....they're all improvements on the original design that many builders think should have been done better initially. That trim nut that goes on the trim cable access plate is a HUGE one.....the original welded stuff is an accident waiting to happen. If I hadn't silver-soldered mine up tough, I'd never have felt good about it. Now you can buy a nice replacement that is much better than the original. The sad thing is, all of these improvements have never made it into the RV-10 "standard package"...which would have made it easier on the builder by maybe upping the kit price by a few dollars, but providing you with the best in parts right off the bat...saving you shipping, time, hassle, and worry. With products like the Axle extensions, there are going to be many people that don't hear about these parts, and they'll have things like smashed wheel fairings because of it. Anyway, Matco wasn't the problem with the original design, but they're part of the solution...and I think the pricing is indicative of them trying to ensure that their company name doesn't suffer because of an over-zealous cost-saving attitude of our kit supplier. In the end, it's just a good thing that there are becoming some good "standard fixes" for the handful of shortcomings that we've found. Tim Olson - RV-10 N104CD - Flying David Hertner wrote: > > Hi Everyone, > > It seems as though I have been scooped in the marketplace!! > > With the introduction of the Matco adjustable axle my product offering > has effectively been run outta town! There is little chance of me being > able to compete with a product being offered by the company with whom > the problem originated. This is just how things go sometimes. > > I would like to inform those who had contacted Cleaveland Tools to place > a pre-order that I have canceled the product offering in fairness to > Mike at Cleaveland Tools even though they had ordered product already. I > would hate to have that product sit on their shelves with no interest in > them. > > To those who had the confidence to pre-order my adjustable pre-load axle > spacers, Thank You. It is always gratifying to have the confidence of > your peers. > > I look forward to offering other accessories and parts to the kit > builder and kit manufacturer alike. > > Regards, > > Dave > > ________________________________________________________________________________
Date: Jan 13, 2009
You know I remember when all the aftermarket things started to come about and what a great thing the people who made them have contributed, the trim nuts Tim is talking about were a joke!! Mine broke off just trying to rivet them to the plates...Has that changed? If not builder beware because it is a BIG safety of flight issue. I think I've purchased almost all of the machined replacements from rivethead when they first came out, iflyrv10 has great stuff too although he wasn't around when I needed the parts. I mounted the door pin receivers this past weekend and I have to tell you the door just sucks in and locks...I was very impressed how they work. One thing I had to do is open the receivers just a little, I used a sanding drum on a dremel. The machine fit of the pins/rods was way too close to work with the movement of the door as the pins engaged. A quick pass inside with the sanding drum proved enough to allow them to slide in easily but still no movement once engaged. My pins protrude at least a half inch past the vertical aluminum posts both fore and aft, I know someone was asking if that was happening. One tip I can pass on to mark the holes for the receivers, chop off the end of two AN-3 bolts and sharpen one side to a point. Screw them in to receiver pointy side out. Put some masking tape where the holes will be, Slide a piece of the door pin tubing into the 7/16 hole drilled for the pins then slide the receiver on pressing the points into the masking tape. The points will leave a nice dent to drill your bolt holes. Thanks Chris H. for the idea!! Worked like a champ. Rick S. 40185 ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Tuesday, January 13, 2009 7:12:36 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Adjustable Axle Spacers - Effectus AeroProducts In all fairness to Matco, it should be noted that Matco just made the wheels and Vans picked them for the RV-10. Van's designed the axle and spacers, and Van's chose to make them the way they did...choosing not to make them fit the bearing taper, choosing not to size the inside of the spacers for the rubber seal....all of that. So the design flaws aren't Matco's fault. They didn't even SEE an RV-10 application until they worked with Scott to try to find out what they could do to stop getting complaints about the design...so they worked with him to come up with a better design for ALL of the RV nosewheel kits. They HAD to come up with something, so that their own reputation doesn't suffer from the bad design of our original kits. This isn't a big slam on Van's, either. They try their best to make things cheap for the builder. The problem comes in that many people, especially people building the higher-priced RV-10 model, aren't happy with some of the cost compromises, and expect more. That's how things like the axle extensions, this nosewheel fix, and heck, all of those Rivetmaster and iflyrv10 parts came to be....they're all improvements on the original design that many builders think should have been done better initially. That trim nut that goes on the trim cable access plate is a HUGE one.....the original welded stuff is an accident waiting to happen. If I hadn't silver-soldered mine up tough, I'd never have felt good about it. Now you can buy a nice replacement that is much better than the original. The sad thing is, all of these improvements have never made it into the RV-10 "standard package"...which would have made it easier on the builder by maybe upping the kit price by a few dollars, but providing you with the best in parts right off the bat...saving you shipping, time, hassle, and worry. With products like the Axle extensions, there are going to be many people that don't hear about these parts, and they'll have things like smashed wheel fairings because of it. Anyway, Matco wasn't the problem with the original design, but they're part of the solution...and I think the pricing is indicative of them trying to ensure that their company name doesn't suffer because of an over-zealous cost-saving attitude of our kit supplier. In the end, it's just a good thing that there are becoming some good "standard fixes" for the handful of shortcomings that we've found. Tim Olson - RV-10 N104CD - Flying David Hertner wrote: > > Hi Everyone, > > It seems as though I have been scooped in the marketplace!! > > With the introduction of the Matco adjustable axle my product offering > has effectively been run outta town! There is little chance of me being > able to compete with a product being offered by the company with whom > the problem originated. This is just how things go sometimes. > > I would like to inform those who had contacted Cleaveland Tools to place > a pre-order that I have canceled the product offering in fairness to > Mike at Cleaveland Tools even though they had ordered product already. I > would hate to have that product sit on their shelves with no interest in > them. > > To those who had the confidence to pre-order my adjustable pre-load axle > spacers, Thank You. It is always gratifying to have the confidence of > your peers. > > I look forward to offering other accessories and parts to the kit > builder and kit manufacturer alike. > > Regards, > > Dave > > ________________________________________________________________________________
Date: Jan 13, 2009
I copied Rick's design and am very pleased with it: http://nerv10.com/wcurtis/fusestand/fusestand32.html On Mon, Jan 12, 2009 at 8:27 PM, William Curtis wrote: > > Here are some thoughts. > > http://nerv10.com/wcurtis/fusestand/index.html > > http://www.vansairforce.com/community/showthread.php?t=37550 > > William > http://nerv10.com/wcurtis/ > > -------- Original Message -------- > > Hi, > > > > I'm expecting my QB fuse in the coming weeks and I'd like to have a fuse > > stand waiting on it. > > > > After researching on Tim's site and he a photo of Rick Sked's fuse > > holder. > > > > Does anyone else have photos of similar fuse holders? > > > > Thanks, > > Phil > > -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Subject: fuselage stand
Date: Jan 13, 2009
Here are a couple of fotos of the stand I built. I use my aerolift to turn the stand on it's side, which allows me to work on the fuselage without leaning over. This is a real back saver! 2 people can easily rotate the stand without a lifting device. It cost about 30 bucks in thin wall 1X2 steel and a set of cheap casters. Chris Hukill cabin top hell ________________________________________________________________________________
Date: Jan 13, 2009
It worked well for me and the added benefit after I was done with it, I screwed a 4 x 4 sheet of plywood I had laying around to it and now its a roll around storage table. Rick S. 40185 ----- Original Message ----- From: "Rob Kochman" <rv10rob(at)gmail.com> Sent: Tuesday, January 13, 2009 8:15:12 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Fuse Stands I copied Rick's design and am very pleased with it: http://nerv10.com/wcurtis/fusestand/fusestand32.html On Mon, Jan 12, 2009 at 8:27 PM, William Curtis < wcurtis(at)nerv10.com > wrote: Here are some thoughts. http://nerv10.com/wcurtis/fusestand/index.html http://www.vansairforce.com/community/showthread.php?t=37550 William http://nerv10.com/wcurtis/ -------- Original Message -------- > Hi, > > I'm expecting my QB fuse in the coming weeks and I'd like to have a fuse > stand waiting on it. > > After researching on Tim's site and he a photo of Rick Sked's fuse > holder. > > Does anyone else have photos of similar fuse holders? > > Thanks, > Phil -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: Jan 13, 2009
I sort of did too except I found that I had lots of wood from the crates the kits came in and used all that wood. Bought the caster/wheels from HF. Works well and is inexpensive From: Rob Kochman Sent: Tuesday, January 13, 2009 8:15 AM Subject: Re: RV10-List: Fuse Stands I copied Rick's design and am very pleased with it: http://nerv10.com/wcurtis/fusestand/fusestand32.html On Mon, Jan 12, 2009 at 8:27 PM, William Curtis wrote: Here are some thoughts. http://nerv10.com/wcurtis/fusestand/index.html http://www.vansairforce.com/community/showthread.php?t=37550 William http://nerv10.com/wcurtis/ -------- Original Message -------- > Hi, > > I'm expecting my QB fuse in the coming weeks and I'd like to have a fuse > stand waiting on it. > > After researching on Tim's site and he a photo of Rick Sked's fuse > holder. > > Does anyone else have photos of similar fuse holders? > > Thanks, > Phil -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Subject: MT prop assembly?
Date: Jan 13, 2009
I can't remember the conversation I had a few months ago with the person I am having assemble the prop=2C and I don't have the paper i wrote the info on=2C but what have others paid for on the assembly of the MT prop? I seem to remember it being less significant of a price than what i am hearing now =2C but I could be wrong. Non of what I am hearing has anything to do with crating=2C or licensing or import fees or any of that=2C just assembly. Thanks=2C John G ________________________________________________________________________________
Date: Jan 13, 2009
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Just a small addition - the iflyrv10 receivers are done a bit differently. Instead of a tapped hole that you but a bolt/screw in from the back, they are drilled through and have a recess on the exposed face. He supplies stainless #10 capscrews for installation and the heads sit inside the recess. Much easier to install. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked Sent: Tuesday, January 13, 2009 10:02 AM Subject: Re: RV10-List: Adjustable Axle Spacers - Effectus AeroProducts You know I remember when all the aftermarket things started to come about and what a great thing the people who made them have contributed, the trim nuts Tim is talking about were a joke!! Mine broke off just trying to rivet them to the plates...Has that changed? If not builder beware because it is a BIG safety of flight issue. I think I've purchased almost all of the machined replacements from rivethead when they first came out, iflyrv10 has great stuff too although he wasn't around when I needed the parts. I mounted the door pin receivers this past weekend and I have to tell you the door just sucks in and locks...I was very impressed how they work. One thing I had to do is open the receivers just a little, I used a sanding drum on a dremel. The machine fit of the pins/rods was way too close to work with the movement of the door as the pins engaged. A quick pass inside with the sanding drum proved enough to allow them to slide in easily but still no movement once engaged. M! y pins protrude at least a half inch past the vertical aluminum posts both fore and aft, I know someone was asking if that was happening. One tip I can pass on to mark the holes for the receivers, chop off the end of two AN-3 bolts and sharpen one side to a point. Screw them in to receiver pointy side out. Put some masking tape where the holes will be, Slide a piece of the door pin tubing into the 7/16 hole drilled for the pins then slide the receiver on pressing the points into the masking tape. The points will leave a nice dent to drill your bolt holes. Thanks Chris H. for the idea!! Worked like a champ. Rick S. 40185 ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Sent: Tuesday, January 13, 2009 7:12:36 AM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: Adjustable Axle Spacers - Effectus AeroProducts In all fairness to Matco, it should be noted that Matco just made the wheels and Vans picked them for the RV-10. Van's designed the axle and spacers, and Van's chose to make them the way they did...choosing not to make them fit the bearing taper, choosing not to size the inside of the spacers for the rubber seal....all of that. So the design flaws aren't Matco's fault. They didn't even SEE an RV-10 application until they worked with Scott to try to find out what they could do to stop getting complaints about the design...so they worked with him to come up with a better design for ALL of the RV nosewheel kits. They HAD to come up with something, so that their own reputation doesn't suffer from the bad design of our original kits. This isn't a big slam on Van's, either. They try their best to make things cheap for the builder. The problem comes in that many people, especially people building the higher-priced RV-10 model, aren't happy with some of the cost compromises, and expect more. That's how things like the axle extensions, this nosewheel fix, and heck, all of those Rivetmaster and iflyrv10 parts came to be....they're all improvements on the original design that many builders think should have been done better initially. That trim nut that goes on the trim cable access plate is a HUGE one.....the original welded stuff is an accident waiting to happen. If I hadn't silver-soldered mine up tough, I'd never have felt good about it. Now you can buy a nice replacement that is much better than the original. The sad thing is, all of these improvements have never made it into the RV-10 "standard package"...which would have made it easier on the builder by maybe upping the kit price by a few dollars, but providing you with the best in parts right off the bat...saving you shipping, time, hassle, and worry. With products like the Axle extensions, there are going to be many people that don't hear about these parts, and they'll have things like smashed wheel fairings because of it. Anyway, Matco wasn't the problem with the original design, but they're part of the solution...and I think the pricing is indicative of them trying to ensure that their company name doesn't suffer because of an over-zealous cost-saving attitude of our kit supplier. In the end, it's just a good thing that there are becoming some good "standard fixes" for the handful of shortcomings that we've found. Tim Olson - RV-10 N104CD - Flying David Hertner wrote: > > Hi Everyone, > > It seems as though I have been scooped in the marketplace!! > > With the introduction of the Matco adjustable axle my product offering > has effectively been run outta town! There is little chance of me being > able to compete with a product being offered by the company with whom > the problem originated. This is just how things go sometimes. > > I would like to inform those who had contacted Cleaveland Tools to place > a pre-order that I have canceled the product offering in fairness to > Mike at Cleaveland Tools even though they had ordered product already. I > would hate to have that product sit on their shelves with no interest in > them. > > To those who had the confidence to pre-order my adjustable pre-load axle > spacers, Thank You. It is always gratifying to have the confidence of > your peers. > > I look forward to offering other accessories and parts to the kit > builder and kit manufacturer alike. > > Regards, > > Dave > > ________________________________________________________________________________
Date: Jan 13, 2009
Subject: Neat to have but..
This may be a little off topic but does anyone find it a bit disturbing that these are so easily obtained? I wonder how well it would work in the cockpit? http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=55734 Rick S. 40185 ________________________________________________________________________________
Date: Jan 13, 2009
Phil, I took an old heavy-duty pallet I had laying around and put some casters on it, then covered the top with some old carpet padding. It worked well for a while but it tends to become a pain when you need access to the bottom. If I were doing it over, I'd use Bill Curtis' simple plan. John -------- #40572 QB Fuselage, wings finished. Finish Kit is on it's way. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224521#224521 ________________________________________________________________________________
Date: Jan 13, 2009
-------- Original Message -------- > This may be a little off topic but does anyone find it a bit disturbing that these are so easily obtained? I wonder how well it would work in the cockpit? http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=55734 Rick S. 40185 Why do you find it disturbing? That's almost like a lay-person saying "they find it disturbing that anyone can build their own plane and fly it over their heads." William http://nerv10.com/wcurtis/ ________________________________________________________________________________
Date: Jan 13, 2009
I don't know whether it has been mentioned but a wooden dolly on wheels from home deport aviation department under each wing attach point and one under the baggage area works fine . Total about $40. _____ ________________________________________________________________________________
Subject: Re: gas strut installation gotcha
Date: Jan 13, 2009
You also want to make sure the bracket does not interfere with the door hing nut and bolts. Larry Rosen -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224543#224543 ________________________________________________________________________________
Date: Jan 13, 2009
Subject: fuel lines
I just got a call from Brett at Bonaco.=C2- He said they use a type of ho se in the S/S braided fuel lines that is good for approximately twelve year s.=C2- Sorry, I didn't catch the type of material. Sean Blair #40225=C2- ________________________________________________________________________________
Subject: Re: MT prop assembly?
Date: Jan 13, 2009
John, I have the three blade prop. Assembled in Deland, FL last July. Assembly was $400. Crating was $300. Unless you're picking the prop up yourself, I highly recommend their crating. A very substantial box with the prop really well bolted down inside. Tom Hanaway Boynton Beach, FL #40639 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224568#224568 ________________________________________________________________________________
Date: Jan 13, 2009
I had mine shipped assembled from the factory. I do not remember the amount, but I know it was less than having it shipped to the nearest dealer, assembled, recrated, and then shipped to me. However, I lived in a city (Minneapolis) that had a major airport and customs office, so it could be shipped directly to me. I bought mine through Jim Ayers at LessDragProducts. David Maib 40559 On Jan 13, 2009, at 12:12 PM, John Gonzalez wrote: I can't remember the conversation I had a few months ago with the person I am having assemble the prop, and I don't have the paper i wrote the info on, but what have others paid for on the assembly of the MT prop? I seem to remember it being less significant of a price than what i am hearing now, but I could be wrong. Non of what I am hearing has anything to do with crating, or licensing or import fees or any of that, just assembly. Thanks, John G ________________________________________________________________________________
Date: Jan 13, 2009
Me too...from Jim Ayers. AND I had to hire a stinkin customs broker for $15 0 to get it out of customs.For that fee I signed a limited power of attorne y, she made a phone call and I drove back and picked it up.=C2-Our wonder ful public servants would not deal with me direct. Odd how the customs agen t had a card, (read stack of them)=C2-for a broker 2 miles away in his po cket. And you think only the crooked ones are in Illinois. Rick S. 40185 ----- Original Message ----- From: "David Maib" <dmaib(at)mac.com> Sent: Tuesday, January 13, 2009 1:39:48 PM (GMT-0800) America/Los_Angeles Subject: Re: RV10-List: MT prop assembly? I had mine shipped assembled from the factory. I do not remember the amount , but I know it was less than having it shipped to the nearest dealer, asse mbled, recrated, and then shipped to me. However, I lived in a city (Minnea polis) that had a major airport and customs office, so it could be shipped directly to me. I bought mine through Jim Ayers at LessDragProducts. David Maib 40559 On Jan 13, 2009, at 12:12 PM, John Gonzalez wrote: I can't remember the conversation I had a few months ago with the person I am having assemble the prop, and I don't have the paper i wrote the info on , but what have others paid for on the assembly of the MT prop? I seem to r emember it being less significant of a price than what i am hearing now, bu t I could be wrong. Non of what I am hearing has anything to do with cratin g, or licensing or import fees or any of that, just assembly. =C2- Thanks, =C2- John G http://www.matronics.com/Navigator?RV10-List href="http://forums.matronic s.com">http://forums.matronics.com href="http://www.matronics.com/contrib ution">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 13, 2009
Thanks guys. The price is as described=2C I=2Cm okay...My brain is just wor ling from the cash outflow and lackof inflow in the last few months. From: dmaib(at)mac.comSubject: Re: RV10-List: MT prop assembly?Date: Tue=2C 13 bled from the factory. I do not remember the amount=2C but I know it was le ss than having it shipped to the nearest dealer=2C assembled=2C recrated=2C and then shipped to me. However=2C I lived in a city (Minneapolis) that ha d a major airport and customs office=2C so it could be shipped directly to me. I bought mine through Jim Ayers at LessDragProducts. David Maib 40559 On Jan 13=2C 2009=2C at 12:12 PM=2C John Gonzalez wrote:I can't remember th e conversation I had a few months ago with the person I am having assemble the prop=2C and I don't have the paper i wrote the info on=2C but what have others paid for on the assembly of the MT prop? I seem to remember it bein g less significant of a price than what i am hearing now=2C but I could be wrong. Non of what I am hearing has anything to do with crating=2C or licen sing or import fees or any of that=2C just assembly. Thanks=2C John Ghttp:/ /www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution ________________________________________________________________________________
Date: Jan 13, 2009
Yeah, I had to hire a customs broker as well. Same deal, Customs agent just happened to have the name and number of the nearest broker handy. David Maib 40559 On Jan 13, 2009, at 4:51 PM, Rick Sked wrote: Me too...from Jim Ayers. AND I had to hire a stinkin customs broker for $150 to get it out of customs.For that fee I signed a limited power of attorney, she made a phone call and I drove back and picked it up. Our wonderful public servants would not deal with me direct. Odd how the customs agent had a card, (read stack of them) for a broker 2 miles away in his pocket. And you think only the crooked ones are in Illinois. Rick S. 40185 ----- Original Message ----- From: "David Maib" <dmaib(at)mac.com> Sent: Tuesday, January 13, 2009 1:39:48 PM (GMT-0800) America/ Los_Angeles Subject: Re: RV10-List: MT prop assembly? I had mine shipped assembled from the factory. I do not remember the amount, but I know it was less than having it shipped to the nearest dealer, assembled, recrated, and then shipped to me. However, I lived in a city (Minneapolis) that had a major airport and customs office, so it could be shipped directly to me. I bought mine through Jim Ayers at LessDragProducts. David Maib 40559 On Jan 13, 2009, at 12:12 PM, John Gonzalez wrote: I can't remember the conversation I had a few months ago with the person I am having assemble the prop, and I don't have the paper i wrote the info on, but what have others paid for on the assembly of the MT prop? I seem to remember it being less significant of a price than what i am hearing now, but I could be wrong. Non of what I am hearing has anything to do with crating, or licensing or import fees or any of that, just assembly. Thanks, John G http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/ contribution ________________________________________________________________________________
Date: Jan 13, 2009
You ought to go, Rick. And take that airport manager along... Neal Heh, heh, you one smart cookie Rick! :) We're going Saturday night, wanna go? I'll give you three guesses who at BPA wrote this and I'll bet it's not the good looking one or the distinguished gentleman who founded the company!! Coon huntin' ________________________________________________________________________________
Subject: Lower Cowling attachment
Date: Jan 13, 2009
Another builder and myself are approaching the point of installing the engine. We want to install the cowl flanges and hinges first. We are aware of the issue with the eyelets on the hinges breaking on the bottom of the cowl, so we have both decided to use a flange/screw and nut-plate arrangement. The question is this.... In a recent post someone mentioned that they used .063 aluminum plate to support the bottom of the cowling. That is awfully heavy metal, but maybe that is what is called for in this location. I also see that Deems has used some kind of aluminum flange with 3 nut-plates on each side. I also think that Tim Olsen did not use the hinge on the bottom of the cowl. But I cannot see the pic on his site. If anyone (or hopefully several) of you can give some insight here it would be graciously appreciated -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224639#224639 ________________________________________________________________________________
Subject: Re: Lower Cowling attachment
Date: Jan 13, 2009
The original hinge material was 0.063". Using a flange of the same thickness makes it easier to maintain cowl to fuselage alignment. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224645#224645 ________________________________________________________________________________
Date: Jan 13, 2009
Mike, I replaced my broken hinges with .063 sheet of the same dimensions as the two hinge halves pinned together, about 2" x 6". The sheet is riveted to the horizontal return at the bottom of the firewall, exactly like the hinge was. I have three nutplates in the sheet to support the aft end of the cowl. The hinge half on the cowl was removed, and now the cowl screws directly to the sheet. The hinges cracked out at about 50 hours. We've got 306 hours as of today and the new attach is working fine. Soon after the hinges went away, the vertical center support also cracked. That got duplicated in .063 (I think it was originally .032). So far so good with that one too. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Tuesday, January 13, 2009 6:09 PM Subject: RV10-List: Lower Cowling attachment Another builder and myself are approaching the point of installing the engine. We want to install the cowl flanges and hinges first. We are aware of the issue with the eyelets on the hinges breaking on the bottom of the cowl, so we have both decided to use a flange/screw and nut-plate arrangement. The question is this.... In a recent post someone mentioned that they used .063 aluminum plate to support the bottom of the cowling. That is awfully heavy metal, but maybe that is what is called for in this location. I also see that Deems has used some kind of aluminum flange with 3 nut-plates on each side. I also think that Tim Olsen did not use the hinge on the bottom of the cowl. But I cannot see the pic on his site. If anyone (or hopefully several) of you can give some insight here it would be graciously appreciated -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224639#224639 ________________________________________________________________________________
Date: Jan 13, 2009
Hi Mike=2C I did the same as been echoed by others. There are some pictures and info a t the bottom of my blog: http://www.aviationstop.com/ Vern Smith (#324 finishing) > Subject: RV10-List: Lower Cowling attachment > From: Mikeabel(at)Pacbell.net > Date: Tue=2C 13 Jan 2009 18:08:46 -0800 > To: rv10-list(at)matronics.com > > > Another builder and myself are approaching the point of installing the en gine. We want to install the cowl flanges and hinges first. We are aware of the issue with the eyelets on the hinges breaking on the bottom of the cow l=2C so we have both decided to use a flange/screw and nut-plate arrangemen t. > > The question is this.... In a recent post someone mentioned that they us ed .063 aluminum plate to support the bottom of the cowling. That is awfull y heavy metal=2C but maybe that is what is called for in this location. > > I also see that Deems has used some kind of aluminum flange with 3 nut-pl ates on each side. I also think that Tim Olsen did not use the hinge on the bottom of the cowl. But I cannot see the pic on his site. > > If anyone (or hopefully several) of you can give some insight here it wou ld be graciously appreciated > > -------- > OSH '08 or Bust (busted) be there in "=3B09 > Q/B Kit - wiring and FWF > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224639#224639 > > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Windows Live=99: Keep your life in sync. http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_0 12009 ________________________________________________________________________________
Date: Jan 13, 2009
Thank you so much Tim, Dave and Jim. I cannot tell you how grateful I am that you and other builders are out there to help us newbies through the building process. From your efforts and others on this site we will have better built and safer airplanes. :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224669#224669 ________________________________________________________________________________
Subject: Lynell added you as a friend on Reunion.com!
Date: Jan 14, 2009
Hi, I looked for you on Reunion.com, but you weren't there. Please connect with me so we can keep in touch. -Lynell Do You Know Lynell? YES - Connect with Lynell, and see who's searching for you http://smtp26.mail.reunion.com:80/track?type=click&mailingid=68800& messageid=6100&databaseid=1229335862&serial=1228209693&emailid=rv10-l ist@matronics.com&userid=221001&extra=&&&2002&&&http://www.reunion.com/sh owInviteRegistration.do?uid=318979543&invitee=rv10-list(at)matronics.com NO - I don't know Lynell http://smtp26.mail.reunion.com:80/track?type= click&mailingid=68800&messageid=6100&databaseid=1229335862&serial=122 8209693&emailid=rv10-list(at)matronics.com&userid=221001&extra=&&&2000&&&h ttp://www.reunion.com/showInviteRegistration.do?unsub=true&invitee=rv10-l ist(at)matronics.com&uid=318979543 ---------------------------- Reunion.com - Find Everyone from Your Past. You have received this e-mail because a Reunion.com Member sent an invi tation to this e-mail address. For assistance, please refer to our FAQ or Contact Us. http://smtp26.mail.reunion.com:80/track?type=click&mailingid=68800&m essageid=6100&databaseid=1229335862&serial=1228209693&emailid=rv10-li st@matronics.com&userid=221001&extra=&&&2001&&&http://help.reunion.com/se lfhelp?lid=2 Our Address: 2118 Wilshire Blvd., Box 1008, Santa Monica, CA 90403-5784 ________________________________________________________________________________
Date: Jan 14, 2009
From: "George, Neal E Capt USAF ACC 605 TES/DOA" <Neal.George(at)hurlburt.af.mil>
Randy gets to wield the stick... neal -----Original Message----- From: On Behalf Of BPA Don't feel too bad for them John. Those coons can get pretty mean when they get surrounded by a couple of blue ticks. I've seen more than one good coon dog get more than it bargained for. I could go off sounding like Jerry Clower with some stories but I'll save those for SNF or OSH :-) Allen ________________________________________________________________________________
Date: Jan 14, 2009
Matt, I pretty much stole Bill's setup (previous note) but used a ground bus instead for the ground connection. These are available from B&C and it has enough room for 2 large (5/16 I think) bolted connections plus about a dozen or so soldered fast-on tabs. This gives you the option of grounding some components in the aft end of the aircraft without grounding them locally on the fuselage or having to run ground wires forward. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224733#224733 ________________________________________________________________________________
Date: Jan 14, 2009
Matt, I pretty much stole Bill's setup (previous note) but used a ground bus instead for the ground connection. These are available from B&C and it has enough room for 2 large (5/16 I think) bolted connections plus about a dozen or so soldered fast-on tabs. This gives you the option of grounding some components in the aft end of the aircraft without grounding them locally on the fuselage or having to run ground wires forward. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224734#224734 ________________________________________________________________________________
Date: Jan 14, 2009
I just ordered mine from MATCO (sorry Dave). Must be popular because they are already backordered about 2 weeks. They are still offering the sale price. I bought the balance weights too and will balance the mains as well as the nose wheel. My thanks to y'all that have paved the way for the rest of us. On some aircraft it is a good idea to balance the wheel pants too in order to reduce shimmy. Does anyone think this is necessary? -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224739#224739 ________________________________________________________________________________
Date: Jan 14, 2009
I have a 2 week back order as well. I'll balance all the heels, statically as I have found that has worked fine with my bike tires, I know Scott mentioned that Dynamically they were out of balance even after doing his statically so I may pursue it a little further. I wont deal with the pants since I can't image they would cause a problem unless they are way off aerodynamically Pascal -------------------------------------------------- From: "nukeflyboy" <flymoore(at)charter.net> Sent: Wednesday, January 14, 2009 10:01 AM Subject: RV10-List: Re: Adjustable Axle Spacers - Effectus AeroProducts > > I just ordered mine from MATCO (sorry Dave). Must be popular because they > are already backordered about 2 weeks. They are still offering the sale > price. I bought the balance weights too and will balance the mains as > well as the nose wheel. My thanks to y'all that have paved the way for > the rest of us. > > On some aircraft it is a good idea to balance the wheel pants too in order > to reduce shimmy. Does anyone think this is necessary? > > -------- > Dave Moore > RV-6 flying > RV-10 QB - cabin top/fiberglass hell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=224739#224739 > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 14, 2009
I have a feeling they hadn't had a full production run yet as I ordered mine right after reading Scott's post and I was also backordered. As to the wheel pants, I've read in the past where people have balanced their pants fore and aft and saw a large reduction in shaking of the mains on other aircraft. It's fairly straightforward and doesn't add much weight so I'll probably be doing it. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Wednesday, January 14, 2009 12:28 PM Subject: Re: RV10-List: Re: Adjustable Axle Spacers - Effectus AeroProducts I have a 2 week back order as well. I'll balance all the heels, statically as I have found that has worked fine with my bike tires, I know Scott mentioned that Dynamically they were out of balance even after doing his statically so I may pursue it a little further. I wont deal with the pants since I can't image they would cause a problem unless they are way off aerodynamically Pascal ________________________________________________________________________________
Date: Jan 14, 2009
For those who asked: Yes, the more recent RV-10 kits do come with the upgraded nut for the trim cable. Basically, a larger welded area between the nut and the stainless plate. I thought Van's even issued a SB on this? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224771#224771 ________________________________________________________________________________
Date: Jan 14, 2009
I have the same balancer as you and Tim but, rather surprisingly, I could n't find really any point of imbalance on my nose wheel but I still have to mount the mains. I like the buffer trick and will spin mine up and see if I get a resonance out of it. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Scott Schmidt Sent: Wednesday, January 14, 2009 3:23 PM Subject: Re: RV10-List: Re: Adjustable Axle Spacers - Effectus AeroProducts I believe my issue with the static balance on the mains was that I put all the weight on once side of the wheel. You can imagine that weight wanting to be thrown off as an imbalance or vib ration starts. I also used the balancer that Tim shows in his write-up. http://www.myrv10. com/N104CD/maintenance/20080503/index.html At first they were very out of balance statically and took close to 2.5 - 3 .0 oz to bet them balance statically. Now when I spun them up I could not believe how bad they were. Part of my problem I feel are my Goodyear Flight Custom III tires. They seem to be heavier and have more tread and the place where you put the weights on these wheels are very close to the center (low moment). To answer how I balance them. I know where I had the weights before and ju st started taking weights off as I spun them up. My buffer was running at 3000 RPM (6" disc), so I had my wheels roughly at 54 mph. It was really cool that I could still pick up the harmonic I get a round 30 mph. Through trial and error I got them very close. I need to revisit this agai n and I will take some video to show you what mine do. By statically balancing my front wheel and placing weights on each side it worked out perfect. I feel I just need to go back and statically balance m y mains by evenly distributing the weight. I may pull the brake off and put the weight on the inside to get it even cl oser. I am going to see how my vibration is before balancing the wheel pants. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Date: Jan 14, 2009
They did. You're supposed to inspect and replace the part at your cost. http://www.vansaircraft.com/pdf/sb06-9-20.pdf All SB's can be found here: http://www.vansaircraft.com/public/notices.htm -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Wednesday, January 14, 2009 1:42 PM Subject: RV10-List: Re: Adjustable Axle Spacers - Effectus AeroProducts For those who asked: Yes, the more recent RV-10 kits do come with the upgraded nut for the trim cable. Basically, a larger welded area between the nut and the stainless plate. I thought Van's even issued a SB on this? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224771#224771 __________ Information from ESET NOD32 Antivirus, version of virus signature database 3766 (20090114) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3766 (20090114) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Subject: Appreciation
Date: Jan 14, 2009
All you folks enjoying your nice, fancy, modern slick RV-10s.. Some of you may have forgotten what it's like for the rest of us. Brenda Specketer was recently reminded what it's like among the commoners, the sub-100-kt peasants. .forced to suffer a trip around the patch in the CherokeeJet. Neal E. George Navarre, FL 32566 ________________________________________________________________________________
Date: Jan 15, 2009
Subject: Project for Sale
Hey everyone, I wanted to let all of you know I've arrived at a very difficult decision t o sell=C2-my RV-10 Project.=C2- I sure don't want to do this, but feel it's the best decision for me at this time.=C2-=C2- All is not in vain though.=C2- I've met some great people, made new frien ds, became a pilot, lost a little weight, and learned a few things.=C2- =C2-I hope to=C2-do it again someday. Anyway....thanks for everything to this point.=C2- I could use some help spreading the word about the sale of the project.=C2-=C2-A flyer is att ached=C2-and I have a fairly detailed spreadsheet itemizing the contents so far.=C2- Please.....only serious inquiries. I'll keep in touch. Thanks, Sean Blair #40225 Colorado Springs, CO 719-660-9943 http://websites.expercraft.com/seanb/ ________________________________________________________________________________
Date: Jan 15, 2009
Man that's heart breaking, Sean. Good luck with selling the project. I hope you can start another one at some point in the future. Phil ________________________________ From: dogsbark(at)comcast.net [mailto:dogsbark(at)comcast.net] Sent: Thursday, January 15, 2009 12:52 PM Subject: RV10-List: Project for Sale Hey everyone, I wanted to let all of you know I've arrived at a very difficult decision to sell my RV-10 Project. I sure don't want to do this, but feel it's the best decision for me at this time. All is not in vain though. I've met some great people, made new friends, became a pilot, lost a little weight, and learned a few things. I hope to do it again someday. Anyway....thanks for everything to this point. I could use some help spreading the word about the sale of the project. A flyer is attached and I have a fairly detailed spreadsheet itemizing the contents so far. Please.....only serious inquiries. I'll keep in touch. Thanks, Sean Blair #40225 Colorado Springs, CO 719-660-9943 http://websites.expercraft.com/seanb/ ________________________________________________________________________________
From: "Bill and Tami Britton" <william(at)gbta.net>
Subject: Is this corrosion??
Date: Jan 15, 2009
Finally got around to wings and found what looks like corrosion on some of the W-1025A flap hinge brackets. If it's corrosion do I need to worry about it and replace the parts or clean and prime them somehow??? I'll send pics to Vans also to see what they say. Thanks, bill ________________________________________________________________________________
Subject: Vans Manifold pressure fitting replacement
From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
Date: Jan 16, 2009
FYI. McMaster carr part number 5058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS, ADAPTER FOR 1/4" TUBE ID X 10-32 UNF MALE, BLUE This will replace the nylon fitting sent with vans FWF kit for connection to a AFS or other system. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225053#225053 ________________________________________________________________________________
Date: Jan 16, 2009
Subject: Re: Is this corrosion??
Bill, It looks like corrosion but not on a large scale, I suspect that there may have been some corrosive chemial stored nearby in the garage/workshop? It w ould take water quite awhile to develop the pitting I see. Pool chemicals, fertilizer, pesticides etc in a oxygen/moisture enviromet will create an ac idic atmoshphere that will accelerate the process. Just my $1.25 worth, her es some info from the U.S.=C2-Army's corrosion identification and abateme nt course. I did'nt include all the forms just the ones that would be appli cable to bare metals. Filli form is another fun topic. Rick Sked 40185 Uniform surface corrosion Uniform surface corrosion results from a direct chemical attack on a metal surface and involves only the metal surface. On a polished surface, this ty pe of corrosion is first seen as a general dulling or etching of the surfac e and if the attack is allowed to continue, the surface becomes rough and p ossibly frosted in appearance. This type of corrosion appears uniform becau se the anodes and cathodes are very small and constantly shift from one are a of the surface to another. An example is the etching of metals by acids. The discoloration or general dulling of metal created by exposure to elevat ed temperatures is not considered to be uniform surface corrosion. Pitting The most common corrosion of aluminum and magnesium alloys is pitting. It i s first noticeable as a white or gray powdery deposit, similar to dust, whi ch blotches the surface. When the deposit is cleaned away, tiny pits or hol es can be seen in the surface. Pitting corrosion may also occur in other me tal types or alloys. The combination of small active anodes to large passiv e cathodes causes severe pitting. Galvanic Galvanic corrosion occurs when different metals are in contact wit h each other and an electrolyte, such as salt water, is present. It is usua lly recognizable by the presence of a buildup of corrosion at the joint bet ween the metals. Two dissimilar metals joined together form a galvanic coup le if moisture and contamination are present Light corrosion Where the condition of the metal is characterized by discoloration and pitt ing to a depth of 0.001 INCH (1 mil). This type of damage can normally be r emoved by light hand sanding. Where the condition of the metal is character ized by discoloration and pitting to a depth of 0.001 INCH (1 mil). This ty pe of damage can normally be removed by light hand sanding. mil). This type of damage can normally be removed by light hand sanding. =C2-=C2- Moderate corrosion Where the condition of the metal is characterized by blisters, evidence of scaling, of the coating or paint system, intergranular corrosion, and pitti ng to a depth of 0.001 INCH (1 mil) to 0.010 INCH (10 mils). This type of d amage shall be removed by extensive hand sanding, light mechanical sanding, or by deoxidizing with a corrosion removing compound. system, intergranula r corrosion, and pitting to a depth of 0.001 INCH (1 mil) to 0.010 INCH (10 mils). This type of damage shall be removed by extensive hand sanding, lig ht mechanical sanding, or by deoxidizing with a corrosion removing compound . type of damage shall be removed by extensive hand sanding, light mechanic al sanding, or by deoxidizing with a corrosion removing compound. with a co rrosion removing compound. Severe corrosion Where the condition of the metal is characterized by blistering, evidence o f scaling, flaking of the coating or paint system, intergranular corrosion, and pitting to a depth greater than 0.010 INCH (10 mills). This type of da mage shall be removed by extensive mechanical sanding, grinding, or by deox idizing with a corrosion removing compound or paint system, intergranular c orrosion, and pitting to a depth greater than 0.010 INCH (10 mills). This t ype of damage shall be removed by extensive mechanical sanding, grinding, o r by deoxidizing with a corrosion removing compound of damage shall be remo ved by extensive mechanical sanding, grinding, or by deoxidizing with a cor rosion removing compound removing compound Enviromental factors Moisture Moisture is present in the air and often contains contaminants such as chlo rides, sulfates, and nitrates. Condensed moisture after it evaporates, will leave its contaminants on surfaces of the aircraft. Accumulations of moist ure may result from cycles of warming and cooling, and drawn along poor bon d lines by capillary action. moisture after it evaporates, will leave its c ontaminants on surfaces of the aircraft. Accumulations of moisture may resu lt from cycles of warming and cooling, and drawn along poor bond lines by c apillary action. result from cycles of warming and cooling, and drawn along poor bond lines by capillary action. Temperature/Climate Generally, corrosion will increase as temperatures rise, but a moderate inc rease may reduce corrosion by prevent- ing condensation. Temperatures above 104 =C2=B0 F (40 =C2=B0 C) will inhibit mold and bacteria growth. Temperat ures held at the lower end of the range will generally reduce the rate of c orrosion. Warm, moist air, normally found in tropical climates tends to acc elerate corrosion while cold, dry air normally found in artic climates tend s to reduce corrosion rates. Corrosion =C2-does =C2-not =C2-occur =C2 -in =C2-very =C2-dry =C2-conditions. =C2-Certain =C2-areas =C2 -within =C2-an =C2-aircraft, =C2-such =C2-as =C2-the =C2-cock pit =C2-and =C2-air conditioned equipment bays, may be subjected to cli matic dry air that has been cooled by air conditioners. This reduces its ab ility to hold moisture, and when ducted into interior area of the aircraft, can release sufficient moisture to accelerate corrosion. ing condensation. Temperatures above 104 =C2=B0 F (40 =C2=B0 C) will inhibit mold and bacter ia growth. Temperatures held at the lower end of the range will generally r educe the rate of corrosion. Warm, moist air, normally found in tropical cl imates tends to accelerate corrosion while cold, dry air normally found in artic climates tends to reduce corrosion rates. Corrosion =C2-does =C2- not =C2-occur =C2-in =C2-very =C2-dry =C2-conditions. =C2-Certa in =C2-areas =C2-within =C2-an =C2-aircraft, =C2-such =C2-as =C2-the =C2-cockpit =C2-and =C2-air conditioned equipment bays, may be subjected to climatic dry air that has been cooled by air conditioners. This reduces its ability to hold moisture, and when ducted into interior a rea of the aircraft, can release sufficient moisture to accelerate corrosio n. lower end of the range will generally reduce the rate of corrosion. Warm , moist air, normally found in tropical climates tends to accelerate corros ion while cold, dry air normally found in artic climates tends to reduce co rrosion rates. Corrosion =C2-does =C2-not =C2-occur =C2-in =C2-ve ry =C2-dry =C2-conditions. =C2-Certain =C2-areas =C2-within =C2 -an =C2-aircraft, =C2-such =C2-as =C2-the =C2-cockpit =C2-and =C2-air conditioned equipment bays, may be subjected to climatic dry air that has been cooled by air conditioners. This reduces its ability to hold moisture, and when ducted into interior area of the aircraft, can release sufficient moisture to accelerate corrosion. tends to accelerate corrosion while cold, dry air normally found in artic climates tends to reduce corros ion rates. Corrosion =C2-does =C2-not =C2-occur =C2-in =C2-very =C2-dry =C2-conditions. =C2-Certain =C2-areas =C2-within =C2-an =C2-aircraft, =C2-such =C2-as =C2-the =C2-cockpit =C2-and =C2 -air conditioned equipment bays, may be subjected to climatic dry air tha t has been cooled by air conditioners. This reduces its ability to hold moi sture, and when ducted into interior area of the aircraft, can release suff icient moisture to accelerate corrosion. Corrosion =C2-does =C2-not =C2 -occur =C2-in =C2-very =C2-dry =C2-conditions. =C2-Certain =C2 -areas =C2-within =C2-an =C2-aircraft, =C2-such =C2-as =C2-th e =C2-cockpit =C2-and =C2-air conditioned equipment bays, may be subj ected to climatic dry air that has been cooled by air conditioners. This re duces its ability to hold moisture, and when ducted into interior area of t he aircraft, can release sufficient moisture to accelerate corrosion. condi tioned equipment bays, may be subjected to climatic dry air that has been c ooled by air conditioners. This reduces its ability to hold moisture, and w hen ducted into interior area of the aircraft, can release sufficient moist ure to accelerate corrosion. reduces its ability to hold moisture, and when ducted into interior area of the aircraft, can release sufficient moisture to accelerate corrosion. to accelerate corrosion. Salt Salt Salt dissolved in water forms a strong electrolyte. Normal winds carry 10 t o 100 pounds of sea salt per cubic mile of air. Since dissolved salts are s trong electrolytes, salt water environments are highly corrosive to aircraf t. d.=C2-=C2-=C2- Ozone Ozone is an active form or oxygen which is fo rmed naturally during thunderstorms, by arcing in electrical devices, and b y photochemical reactions in smog. When ozone is absorbed by electrolyte so lutions in contact with metals, it increases the rate of corrosion. air. Si nce dissolved salts are strong electrolytes, salt water environments are hi ghly corrosive to aircraft. d.=C2-=C2-=C2- Ozone Ozone is an active f orm or oxygen which is formed naturally during thunderstorms, by arcing in electrical devices, and by photochemical reactions in smog. When ozone is a bsorbed by electrolyte solutions in contact with metals, it increases the r ate of corrosion. d.=C2-=C2-=C2- Ozone Ozone is an active form or oxy gen which is formed naturally during thunderstorms, by arcing in electrical devices, and by photochemical reactions in smog. When ozone is absorbed by electrolyte solutions in contact with metals, it increases the rate of cor rosion. Ozone is an active form or oxygen which is formed naturally during thunderstorms, by arcing in electrical devices, and by photochemical reacti ons in smog. When ozone is absorbed by electrolyte solutions in contact wit h metals, it increases the rate of corrosion. and by photochemical reaction s in smog. When ozone is absorbed by electrolyte solutions in contact with metals, it increases the rate of corrosion. increases the rate of corrosion . ----- Original Message ----- From: "Bill and Tami Britton" <william(at)gbta.net> Sent: Thursday, January 15, 2009 8:57:04 PM GMT -08:00 US/Canada Pacific Subject: RV10-List: Is this corrosion?? Finally got around to wings and found what looks like corrosion on some of the W-1025A flap hinge brackets.=C2- If it's corrosion do I need to worry about it and replace the parts or clean and prime them somehow???=C2- I' ll send pics to Vans also to see what they say. Thanks, bill ________________________________________________________________________________
Date: Jan 16, 2009
Bill, My suggestion is to take a scotchbrite pad to it until whatever that is is gone and the surface is smooth. Clean it up with some coleman fuel or acetone and shoot it with a bit of primer. Unless that runs deep in to the part, I don't think you've got a problem. Jeff Carpenter 40304 (spending a lot of time on the phone with Stein these days... structure is almost done, control systems are in... but big money between me and the finish line) On Jan 15, 2009, at 8:57 PM, Bill and Tami Britton wrote: > Finally got around to wings and found what looks like corrosion on > some of the W-1025A flap hinge brackets. If it's corrosion do I > need to worry about it and replace the parts or clean and prime > them somehow??? I'll send pics to Vans also to see what they say. > > Thanks, > bill ________________________________________________________________________________
Subject: Riveting
Date: Jan 16, 2009
Page 28-14 step 3. Rivet callouts are on page 28-12 Riveting the bottom flange of the Fwd Center Section Bulkhead to the F-1076 Center bottom skin and the F-1072. The outboard 7 rivets are to be double flush on my plans. How does one go about that. Do you counter sink the Bulkhead holes. I noticed that the older plans don't call for the double flush rivets. My plans don't call for any prep of the holes for double flush rivets. Just trying to prevent another screw up. Thanks in advance, Rob Hunter 40432 Fuselage ________________________________________________________________________________
Date: Jan 16, 2009
Thanks guys. Ken from Vans says to clean it up and prime it. It was mentioned that I must store chemicals in the garage to create a somewhat "acidic"environment but in reality I don't store any chemicals in there. The blue "wrap" from vans was peeled off where the "corrosion" took place. Thanks, Bill ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Friday, January 16, 2009 10:47 AM Subject: Re: RV10-List: Is this corrosion?? Bill, My suggestion is to take a scotchbrite pad to it until whatever that is is gone and the surface is smooth. Clean it up with some coleman fuel or acetone and shoot it with a bit of primer. Unless that runs deep in to the part, I don't think you've got a problem. Jeff Carpenter 40304 (spending a lot of time on the phone with Stein these days... structure is almost done, control systems are in... but big money between me and the finish line) On Jan 15, 2009, at 8:57 PM, Bill and Tami Britton wrote: Finally got around to wings and found what looks like corrosion on some of the W-1025A flap hinge brackets. If it's corrosion do I need to worry about it and replace the parts or clean and prime them somehow??? I'll send pics to Vans also to see what they say. Thanks, bill ------------------------------------------------------------------------- ----- Checked by AVG - http://www.avg.com 1/16/2009 6:52 AM ________________________________________________________________________________
Date: Jan 16, 2009
Subject: Re: Riveting
Rob, Yes, you machine countersink to do this.=C2- If I remember correctly, the landing gear bracket has a flange that resides in that area.=C2- It will need to sit flush and the shop heads will interfere. Sean Blair #40225 For Sale =C2-=C2- ----- Original Message ----- From: "Rob Hunter" <rwhunter(at)integra.net> Sent: Friday, January 16, 2009 10:03:14 AM GMT -07:00 US/Canada Mountain Subject: RV10-List: Riveting Page 28-14 step 3.=C2- Rivet callouts are on page 28-12 Riveting the bottom flange of the Fwd Center Section Bulkhead to the F-1076 Center bottom skin and the F-1072.=C2- The outboard 7 rivets are to be d ouble flush on my plans.=C2- How does one go about that.=C2- Do you cou nter sink the Bulkhead holes. I noticed that the older plans don't=C2-call for the double flush rivets. =C2- My plans don't call for any prep of the holes for double flush rivet s. Just trying to prevent another screw up. Thanks in advance, Rob Hunter 40432 ============= == ________________________________________________________________________________
Date: Jan 16, 2009
YUP!!! Sean has it right...I missed it at first, seems the misses are easy to remember. Rick S. 40185 ----- Original Message ----- From: dogsbark(at)comcast.net Sent: Friday, January 16, 2009 9:19:16 AM GMT -08:00 US/Canada Pacific Subject: Re: RV10-List: Riveting Rob, Yes, you machine countersink to do this.=C2- If I remember correctly, the landing gear bracket has a flange that resides in that area.=C2- It will need to sit flush and the shop heads will interfere. Sean Blair #40225 For Sale =C2-=C2- ----- Original Message ----- From: "Rob Hunter" <rwhunter(at)integra.net> Sent: Friday, January 16, 2009 10:03:14 AM GMT -07:00 US/Canada Mountain Subject: RV10-List: Riveting Page 28-14 step 3.=C2- Rivet callouts are on page 28-12 Riveting the bottom flange of the Fwd Center Section Bulkhead to the F-1076 Center bottom skin and the F-1072.=C2- The outboard 7 rivets are to be d ouble flush on my plans.=C2- How does one go about that.=C2- Do you cou nter sink the Bulkhead holes. I noticed that the older plans don't=C2-call for the double flush rivets. =C2- My plans don't call for any prep of the holes for double flush rivet s. Just trying to prevent another screw up. Thanks in advance, Rob Hunter 40432 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jan 16, 2009
Bill=2C If you have Alumiprep and alodine these are good to use. The etching and co nversion coat process will stop any corrosion that may be missed by the Sco tchbrite. Vern Smith (finishing #324) From: william(at)gbta.netTo: rv10-list(at)matronics.comSubject: Re: RV10-List: Is this corrosion??Date: Fri=2C 16 Jan 2009 11:04:39 -0600 Thanks guys. Ken from Vans says to clean it up and prime it. It was menti oned that I must store chemicals in the garage to create a somewhat "acidic "environment but in reality I don't store any chemicals in there. The blue "wrap" from vans was peeled off where the "corrosion" took place. Thanks=2C Bill ----- Original Message ----- From: Jeff Carpenter Sent: Friday=2C January 16=2C 2009 10:47 AM Subject: Re: RV10-List: Is this corrosion?? Bill=2C My suggestion is to take a scotchbrite pad to it until whatever that is is gone and the surface is smooth. Clean it up with some coleman fuel or acet one and shoot it with a bit of primer. Unless that runs deep in to the par t=2C I don't think you've got a problem. Jeff Carpenter 40304 (spending a lot of time on the phone with Stein these days... structure is almost done=2C control systems are in... but big money between me and the f inish line) On Jan 15=2C 2009=2C at 8:57 PM=2C Bill and Tami Britton wrote: Finally got around to wings and found what looks like corrosion on some of the W-1025A flap hinge brackets. If it's corrosion do I need to worry abou t it and replace the parts or clean and prime them somehow??? I'll send pi cs to Vans also to see what they say. Thanks=2C bill href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - 270.10.8/1897 - Release Date: 1/16/2009 6:52 AM _________________________________________________________________ Windows Live=99 Hotmail=AE: Chat. Store. Share. Do more with mail. http://windowslive.com/explore?ocid=TXT_TAGLM_WL_t1_hm_justgotbetter_expl ore_012009 ________________________________________________________________________________
Date: Jan 16, 2009
Be glad the plans show it now. My plans did not and I had to redo the rivets when fitting the landing gear brackets. Make sure the rivet is flush with the bulkhead, otherwise the bracket will not fit right. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225127#225127 ________________________________________________________________________________
Date: Jan 16, 2009
Thanks Guys! Rob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of egohr1 Sent: Friday, January 16, 2009 12:09 PM Subject: RV10-List: Re: Riveting --> Be glad the plans show it now. My plans did not and I had to redo the rivets when fitting the landing gear brackets. Make sure the rivet is flush with the bulkhead, otherwise the bracket will not fit right. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225127#225127 ________________________________________________________________________________
Subject: Re: Jacksonville, FL?
Date: Jan 16, 2009
Hey Linn, My screener deleted your response before it went to my email, but I got a glimpse, and I'll respond here because of that. Otherwise I'll keep the cancer stuff off the forum. lewgall(at)charter.net This treatment is proton beam therapy. Unlike traditional radiation which uses photons that does damage on the way in and on the way out; they strip the electrons off the hydrogen atom, then focus the remaining protons at the prostate. Protons have a low energy entrance, peaks energy release at a very specific distance, then dissipates - no exit damage. Unlike any other procedure (including the ultrasound or microwave experiments), they have achieved accuracy at 0.1 mm. !!! Way cool. No collateral damage, no side effects, painless, non-invasive - as good or better results cancer wise as every other procedure. I'm off on weekends and I had thought of trying to catch a shuttle launch if there is one during my time there. Bill, you are absolutely right -- building is a wonderful reality check for me in many ways. I tend to have a really vivid imagination that can lean toward the worst case scenario if I let it -- one of the BIG reasons I'm not flying! ... yet! Other really neat uses of this proton therapy are for brain tumors in children, optic nerve tumors, lung cancer, AND breast cancer. Back to building -- let me know if there are any builds going on in Jacksonville that could use some help. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225196#225196 ________________________________________________________________________________
Date: Jan 16, 2009
Have you cleaned with acetone? Frequently the blue vinyl leaves adhesive behind that looks like white residue. If not adhesive, probably fine scotchbrite will clean it right up. Bill and Tami Britton wrote: > Thanks guys. Ken from Vans says to clean it up and prime it. It was > mentioned that I must store chemicals in the garage to create a somewhat > "acidic"environment but in reality I don't store any chemicals in > there. The blue "wrap" from vans was peeled off where the "corrosion" > took place. > > Thanks, > Bill > > ----- Original Message ----- > *From:* Jeff Carpenter > *To:* rv10-list(at)matronics.com > *Sent:* Friday, January 16, 2009 10:47 AM > *Subject:* Re: RV10-List: Is this corrosion?? > > Bill, > > My suggestion is to take a scotchbrite pad to it until whatever that > is is gone and the surface is smooth. Clean it up with some coleman > fuel or acetone and shoot it with a bit of primer. Unless that runs > deep in to the part, I don't think you've got a problem. > > Jeff Carpenter > 40304 > (spending a lot of time on the phone with Stein these days... > structure is almost done, control systems are in... but big money > between me and the finish line) > > > On Jan 15, 2009, at 8:57 PM, Bill and Tami Britton wrote: > >> Finally got around to wings and found what looks like corrosion on >> some of the W-1025A flap hinge brackets. If it's corrosion do I >> need to worry about it and replace the parts or clean and prime >> them somehow??? I'll send pics to Vans also to see what they say. >> >> Thanks, >> bill > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > ------------------------------------------------------------------------ > - 270.10.8/1897 - Release Date: 1/16/2009 6:52 AM > > * > > > * ________________________________________________________________________________
Date: Jan 16, 2009
Haven't tried anything yet but will in the next day or two. Too busy working on spars and ribs!!! Bill ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> Sent: Friday, January 16, 2009 10:48 PM Subject: Re: Re: RV10-List: Is this corrosion?? > > Have you cleaned with acetone? Frequently the blue vinyl leaves adhesive > behind that looks like white residue. If not adhesive, probably fine > scotchbrite will clean it right up. > > Bill and Tami Britton wrote: >> Thanks guys. Ken from Vans says to clean it up and prime it. It was >> mentioned that I must store chemicals in the garage to create a somewhat >> "acidic"environment but in reality I don't store any chemicals in >> there. The blue "wrap" from vans was peeled off where the "corrosion" >> took place. >> >> Thanks, >> Bill >> >> ----- Original Message ----- >> *From:* Jeff Carpenter >> *To:* rv10-list(at)matronics.com >> *Sent:* Friday, January 16, 2009 10:47 AM >> *Subject:* Re: RV10-List: Is this corrosion?? >> >> Bill, >> >> My suggestion is to take a scotchbrite pad to it until whatever that >> is is gone and the surface is smooth. Clean it up with some coleman >> fuel or acetone and shoot it with a bit of primer. Unless that runs >> deep in to the part, I don't think you've got a problem. >> >> Jeff Carpenter >> 40304 >> (spending a lot of time on the phone with Stein these days... >> structure is almost done, control systems are in... but big money >> between me and the finish line) >> >> >> On Jan 15, 2009, at 8:57 PM, Bill and Tami Britton wrote: >> >>> Finally got around to wings and found what looks like corrosion on >>> some of the W-1025A flap hinge brackets. If it's corrosion do I >>> need to worry about it and replace the parts or clean and prime >>> them somehow??? I'll send pics to Vans also to see what they say. >>> >>> Thanks, >>> bill >> >> * >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> >> ------------------------------------------------------------------------ >> - 270.10.8/1897 - Release Date: 1/16/2009 6:52 AM >> >> * >> >> >> * > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 6:52 AM ________________________________________________________________________________
Subject: Aileron Rigging
Date: Jan 17, 2009
I have a feeling that this may have been covered before - forgive me if I a m going over old ground. I spent today doing the final rigging of the ailerons pending first flight. With the elevators in the neutral position, I managed to achieve a near p erfect alignment of flaps, ailerons and wingtip on both sides, with the sti cks both centered and bolt upright. I felt good. With the wing trailing edges in alignment, I moved the elevator up and down and found that both ailerons would move up more than 1/4" when the elevato r TE was dropped. Not much (if any) movement of the ailerons from neutral when the elevator TE is raised. I don't think I have a problem, the ailerons move up only with full forward stick (not a condition I expect much) and both are deflected the same amou nt. Is it possible to achieve flap, aileron, tip alignment through all elev ator positions? cheers, Ron -187 gettin' nervous! "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Jan 17, 2009
Subject: rudder trim
I've seen mention of rudder trim made from hinge material. I'm going that route and wonder how effective it is with just the hinge or if extra area was needed. So, for those that didn't cut the rudder and installed 'hinge trim', how well does it work, how big (I saw 1') did you make yours, and did you have to add a tab on the hinge. TIA Linn ________________________________________________________________________________
Subject: Re: Aileron Rigging
Date: Jan 17, 2009
Just like Tim said. You want them even with the flaps when the elevator is neutral. Because of the way the sticks are connected both to the elevator and ailerons, the angle changes on the aileron pushrods going from the sticks to the wingroot when the stick is moved fore and aft, pulling the ailerons up when at either side of neutral elevator. You did it just right. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jan 17, 2009, at 12:15 AM, McGANN, Ron wrote: > > I have a feeling that this may have been covered before - forgive me > if I am going over old ground. > > I spent today doing the final rigging of the ailerons pending first > flight. With the elevators in the neutral position, I managed to > achieve a near perfect alignment of flaps, ailerons and wingtip on > both sides, with the sticks both centered and bolt upright. I felt > good. > > With the wing trailing edges in alignment, I moved the elevator up > and down and found that both ailerons would move up more than 1/4" > when the elevator TE was dropped. Not much (if any) movement of the > ailerons from neutral when the elevator TE is raised. > > I don't think I have a problem, the ailerons move up only with full > forward stick (not a condition I expect much) and both are deflected > the same amount. Is it possible to achieve flap, aileron, tip > alignment through all elevator positions? > > cheers, > Ron > -187 > gettin' nervous! > > "Warning: > The information contained in this email and any attached files is > confidential to BAE Systems Australia. If you are not the intended > recipient, any use, disclosure or copying of this email or any > attachments is expressly prohibited. If you have received this email > in error, please notify us immediately. VIRUS: Every care has been > taken to ensure this email and its attachments are virus free, > however, any loss or damage incurred in using this email is not the > sender's responsibility. It is your responsibility to ensure virus > checks are completed before installing any data sent in this email to > your computer." > > ________________________________________________________________________________
Subject: Re: rudder trim
Date: Jan 17, 2009
The trims I've used are about 8 inches long by about 1.5 inches wide, from my memory. This is the aerotrim servo and tab (which is now in limbo because Norm passed away). This may allow more trim then I expect to use, but with a narrower tab you would have to turn it further to trim the plane. I don't know if that would create more drag or not. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jan 17, 2009, at 1:21 AM, linn Walters wrote: > > > > I've seen mention of rudder trim made from hinge material. I'm > going that route and wonder how effective it is with just the hinge > or if extra area was needed. > > So, for those that didn't cut the rudder and installed 'hinge trim', > how well does it work, how big (I saw 1') did you make yours, and > did you have to add a tab on the hinge. > TIA > Linn > > ________________________________________________________________________________
Date: Jan 17, 2009
>From someone who has been through prostate cancer and out the other side with a valid 3rd class physical, know that you will get through this and can get your medical back. Find yourself a great flight surgeon and let him help you. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Friday, January 16, 2009 7:53 PM Subject: RV10-List: Re: Jacksonville, FL? Hey Linn, My screener deleted your response before it went to my email, but I got a glimpse, and I'll respond here because of that. Otherwise I'll keep the cancer stuff off the forum. lewgall(at)charter.net This treatment is proton beam therapy. Unlike traditional radiation which uses photons that does damage on the way in and on the way out; they strip the electrons off the hydrogen atom, then focus the remaining protons at the prostate. Protons have a low energy entrance, peaks energy release at a very specific distance, then dissipates - no exit damage. Unlike any other procedure (including the ultrasound or microwave experiments), they have achieved accuracy at 0.1 mm. !!! Way cool. No collateral damage, no side effects, painless, non-invasive - as good or better results cancer wise as every other procedure. I'm off on weekends and I had thought of trying to catch a shuttle launch if there is one during my time there. Bill, you are absolutely right -- building is a wonderful reality check for me in many ways. I tend to have a really vivid imagination that can lean toward the worst case scenario if I let it -- one of the BIG reasons I'm not flying! ... yet! Other really neat uses of this proton therapy are for brain tumors in children, optic nerve tumors, lung cancer, AND breast cancer. Back to building -- let me know if there are any builds going on in Jacksonville that could use some help. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225196#225196 ________________________________________________________________________________
Subject: Wing Tip Construction Stall Warning System Steps
Date: Jan 17, 2009
Hello everyone, I'm new to the email list, but was wondering if someone might have some guidance. I'm working on the wingtips, and the directions recommend doing the steps on 19-2 before continuing onward. It doesn't state which steps to perform on 19-2, and as I look at chapter 19, it looks as though there are steps on 19-3 that could be done also. Can anyone tell me exactly which steps they performed in chapter 19 as part of the chapter 17 wingtip construction? Thanks. Andy Johnson Poquoson, VA ________________________________________________________________________________
Subject: Re: Front Wheel Axle Spacers - A Permanent Fix
Date: Jan 17, 2009
Date: Jan 17, 2009
Date: Jan 17, 2009
On my RV9A used a piece of Balsa obtained from the local hobby store. Cut and ripped it into the shape of a wedge. After several flights and shortening the length (I started with a piece 1.5" wide, 5" long, 3/8" thick on the fat edge) I ended up with a wedge that was 3" long and 1/4" thick on both rudder and aileron. Then I rattle canned it, and Scotch Double Sided taped it to the rudder and aileron. Light and effective, easy to modify if needed and it never came off after 300 hours even in coastal marine air and five hours flying in rain. Worked for me and will use Balsa on the RV10 about two months from completion. Chuck ---------------------------------------------- From: "Jesse Saint" <jesse(at)saintaviation.com> Sent: Saturday, January 17, 2009 6:00 AM Subject: Re: RV10-List: rudder trim > > The trims I've used are about 8 inches long by about 1.5 inches wide, > from my memory. This is the aerotrim servo and tab (which is now in > limbo because Norm passed away). This may allow more trim then I expect > to use, but with a narrower tab you would have to turn it further to trim > the plane. I don't know if that would create more drag or not. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > On Jan 17, 2009, at 1:21 AM, linn Walters wrote: > >> > >> >> I've seen mention of rudder trim made from hinge material. I'm going >> that route and wonder how effective it is with just the hinge or if >> extra area was needed. >> >> So, for those that didn't cut the rudder and installed 'hinge trim', how >> well does it work, how big (I saw 1') did you make yours, and did you >> have to add a tab on the hinge. >> TIA >> Linn >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 17, 2009
Hey Gary, Thanks for the response and the support. I'm not a pilot -- not sure I ever will be -- just love building. I've done a great deal of work on my friend's -10 and I'm hooked! So no issue of getting my medical back, or getting a flight surgeon. By the way, there is not an MD in my area (and they pride themselves on being state of the art!) who is familiar with proton beam therapy -- or else they are protecting their area of expertise or income. I had to find this on my own and aggressively pursue it. Altho it will be difficult to be away from home for two months, and no income for two months, and no -10 building for two months, the benefits of no side effects, no pain, no collateral damage, no incisions -- make it a no-brainer for me! Don, Thanks for the great attitude! The closest treatment center (and the first one, since early 90's) to you is Loma Linda hospital in LA -- I almost went there, may yet if I get great offers like yours! Later, - Lew ----- Original Message ----- From: "gary" <speckter(at)comcast.net> Sent: Saturday, January 17, 2009 9:10 AM Subject: RE: RV10-List: Re: Jacksonville, FL? > >>From someone who has been through prostate cancer and out the other side > with a valid 3rd class physical, know that you will get through this and > can > get your medical back. Find yourself a great flight surgeon and let him > help you. > > Gary Specketer > > > ________________________________________________________________________________
Subject: jammed main gear leg
Date: Jan 18, 2009
Has anyone had their gear leg get stuck in the attach bracket? We got the right leg in with a moderate amount of wiggle jiggle twist and turn effort, but now its wedged in tight. I think that some of the powder coat material chipped off and got between the leg and the bracket. We heated the bracket with a heat gun and we can turn (with a lot of effort) the leg about 10 degrees while pulling down on it. We've sprayed some silicone in the tube. This baby is really stuck. My next tactic might be a very large brass drift and a very heavy hammer to drive it out but the opportunity for doing serious damage scares the hell out of me. Any ideas?? Paul Hahn #40203 ________________________________________________________________________________
Subject: TSA
Date: Jan 18, 2009
Just saw an illustration of why we are , as country, screwed, Flew the 10 to KPRC (Prescott AZ) for breakfast. Upon leaving the restaurant, we saw 6 TSA/law enforcement types standing around. I believe they have a couple of commuter flights a day.You and I paid 6 government employees (probably overtime/premium pay). This is the Bin Laden secret plan; kill us with bureaucracy.. ________________________________________________________________________________
Subject: Width between the wheel pants
Date: Jan 18, 2009
Can anyone tell me what the distance is between the wheels while the plane' s weight is on the gear. A rough measure of the width from outside each whe el aswell as to the outside of the wheel pants would be helpful.Thank=2CJoh n G. ________________________________________________________________________________
Subject: Re: jammed main gear leg
Date: Jan 18, 2009
I don't know if its any help but those legs fit with a pretty close tolerance. If just a little residual po wder coat worked its way into the areas between the leg and bracket it made it even closer a fit. I don't think you would have any issues with the hammer and punch. If the leg rotates. I would do it but t hat's just me..I'm blessed with the midas touch!! A li ght tap will tell you how bad its stuck, if it moves down a little your probably OK... Rick S. Sent via BlackBerry by AT&T -----Original Message----- From: "eagerlee" <eagerlee(at)comcast.net> Date: Sun, 18 Jan 2009 10:51:17 Subject: RV10-List: jammed main gear leg This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Jan 18, 2009
Paul=2CDId you put any lubricant on the two parts before you slid it in. Va soline would be a good idea. This issue is very important to me because I n eed to get my grear legs off in order to get the plane out of the basement =2C so I am very worried about putting them on in the first place. This is my next step.You might need to try cold=2C nitrogen or dry ice=2C before ba nging on it.JOhn G.From: eagerlee(at)comcast.netTo: rv10-list(at)matronics.comSub ject: RV10-List: jammed main gear legDate: Sun=2C 18 Jan 2009 10:51:17 -070 0 Has anyone had their gear leg get stuck in the attach bracket? We got the right leg in with a moderate amount of wiggle jiggle twist and turn effort=2C but now its wedged in tight. I think that some of the powder coat material chipped off and got between the leg and the bracket. We heated the bracket with a heat gun and we can turn (with a lot of effort) the leg about 10 degrees while pulling down on it. We've sprayed some silicone in the tube. This baby is really stuck. My next tactic might be a very large brass drift and a very heavy hammer to drive it out but the opportunity for doing serious damage scares the hell out of me. Any ideas?? Paul Hahn #40203 ________________________________________________________________________________
Subject: Re: Width between the wheel pants
Date: Jan 18, 2009
John, I just measured it at 8' 6" from the pant spacer to pant spacer Rick S. Sent via BlackBerry by AT&T -----Original Message----- From: John Gonzalez <indigoonlatigo(at)msn.com> Date: Sun, 18 Jan 2009 10:26:53 Subject: RV10-List: Width between the wheel pants Can anyone tell me what the distance is between the whe els while the plane's weight is on the gear. A rough measure of the width from outside each wheel aswell as to the outside of the wheel pants would be helpful.Thank, John G. ________________________________________________________________________________
Subject: Garmin GPSMAP 496 For Sale
Date: Jan 18, 2009
Hi All, I've decided to upgrade to the 696 and so I'm putting my 496 up for sale. If anyone is looking for one, I figured I'd check with the list before putting it up on ebay. Unit is in excellent condition with all original accessories and box plus one extra battery. I'm located in SoCal and anyone local is welcome to come take a look first. If anyone is interested feel free to make me an offer off list: poneill(at)irealms.com. Patrick #40715 ________________________________________________________________________________
Subject: Door ajar indictors
Date: Jan 18, 2009
I opened my Van's door warning kit today and began reading the directions.W hat am I missing in the understanding of this system? Are we removing the 5 /16 threaded bolts which we spend time shaping the ends to a point and then tapping the inside of the aluminum rod to receive the theads of these bolt s=2C only to replace them with a one inch long rare earth magnet and five m inute epoxy?????There seems to be two issue that are confusing me. 1) I mad e sure that the bolt length that I made penetrated atleast 1/4 past the alu minum/fuse jamm when the door was closed and was also long enough the it wa s still inside the portion of the aluminum pin that was housed by the nylon block which is screwed to the door. I didn't want the pin bending in the g ap between the fuse jam and the nylon door block.Now=2C am I asked to disca rd this bolt pin and replace it with a one inch long cylindrical magnet?? A ren't we weakening the mechanism just for the safety of seeing a light go o ut??2) Why are we using this complicated method with magnets=2C fore and af t when we one switch could be thrown by the pin physically pushing the swit ch closed/open and thus turning the light out or on?I made the inner portio n of my cabin top flange fit so well that a business card cannot fit betwee n the door and itself=2C so if the foreward pin is closed the rear one is o bviously closed by just looking at he inner door fit.So with the relay or c ircuit that Stein has placed in my system=2C can I just place a simple swit ch with is pushed closed by the pin or should I just not hook power to the door system and since the light will always be out=2C assume it is fine to fly?What happened to the priciple of KISS? Not=2C PISSED.Two steps forward =2C 1 and 3/4 steps backJOhn G. ________________________________________________________________________________
Date: Jan 17, 2009
Subject: Re: Door ajar indictors
John, I just couldn't go with the rack and pinion door latch and it's resulting possible problems. The next time you get next to a Cirrus, look at it's door hardware. It looks like a trunk latch from a small car. My problem is I don't know which small car! I have a good friend with a Cirrus that's trying to find me some info. If anyone out there can shed some light on the Cirrus latch I'd be really grateful!! Linn .... Waiting for that small car to show up! John Gonzalez wrote: > I opened my Van's door warning kit today and began reading the > directions. > > What am I missing in the understanding of this system? Are we removing > the 5/16 threaded bolts which we spend time shaping the ends to a > point and then tapping the inside of the aluminum rod to receive the > theads of these bolts, only to replace them with a one inch long rare > earth magnet and five minute epoxy????? > > There seems to be two issue that are confusing me. > > 1) I made sure that the bolt length that I made penetrated atleast 1/4 > past the aluminum/fuse jamm when the door was closed and was also long > enough the it was still inside the portion of the aluminum pin that > was housed by the nylon block which is screwed to the door. I didn't > want the pin bending in the gap between the fuse jam and the nylon > door block. > > Now, am I asked to discard this bolt pin and replace it with a one > inch long cylindrical magnet?? Aren't we weakening the mechanism just > for the safety of seeing a light go out?? > > 2) Why are we using this complicated method with magnets, fore and aft > when we one switch could be thrown by the pin physically pushing the > switch closed/open and thus turning the light out or on? > > I made the inner portion of my cabin top flange fit so well that a > business card cannot fit between the door and itself, so if the > foreward pin is closed the rear one is obviously closed by just > looking at he inner door fit. > > So with the relay or circuit that Stein has placed in my system, can I > just place a simple switch with is pushed closed by the pin or should > I just not hook power to the door system and since the light will > always be out, assume it is fine to fly? > > What happened to the priciple of KISS? Not, PISSED. > > Two steps forward, 1 and 3/4 steps back > > JOhn G. > * > > > * ________________________________________________________________________________
Date: Jan 18, 2009
Subject: Re: TSA
David McNeill wrote: > Just saw an illustration of why we are , as country, screwed, Flew the > 10 to KPRC (Prescott AZ) for breakfast. Upon leaving the restaurant, we > saw 6 TSA/law enforcement types standing around. Just remember, TSA stands for Totally Screwing Aviation. I suppose it could be Totally Screwing Americans if they continue down the path they are on. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ http://deej.net/sportsman/ http://deej.net/kr-2/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jan 18, 2009
Our flight department has a one year old Cirrus Turbo G3. It is a nice enough aircraft but in my opinion the door latch mechanism is the weakest design point of the aircraft. Steve 50212 --- linn Walters wrote: > > > John, I just couldn't go with the rack and pinion > door latch and it's > resulting possible problems. The next time you get > next to a Cirrus, > look at it's door hardware. It looks like a trunk > latch from a small > car. My problem is I don't know which small car! I > have a good friend > with a Cirrus that's trying to find me some info. > If anyone out there > can shed some light on the Cirrus latch I'd be > really grateful!! > Linn .... Waiting for that small car to show up! > > John Gonzalez wrote: > > I opened my Van's door warning kit today and began > reading the > > directions. > > > > What am I missing in the understanding of this > system? Are we removing > > the 5/16 threaded bolts which we spend time > shaping the ends to a > > point and then tapping the inside of the aluminum > rod to receive the > > theads of these bolts, only to replace them with a > one inch long rare > > earth magnet and five minute epoxy????? > > > > There seems to be two issue that are confusing me. > > > > > 1) I made sure that the bolt length that I made > penetrated atleast 1/4 > > past the aluminum/fuse jamm when the door was > closed and was also long > > enough the it was still inside the portion of the > aluminum pin that > > was housed by the nylon block which is screwed to > the door. I didn't > > want the pin bending in the gap between the fuse > jam and the nylon > > door block. > > > > Now, am I asked to discard this bolt pin and > replace it with a one > > inch long cylindrical magnet?? Aren't we weakening > the mechanism just > > for the safety of seeing a light go out?? > > > > 2) Why are we using this complicated method with > magnets, fore and aft > > when we one switch could be thrown by the pin > physically pushing the > > switch closed/open and thus turning the light out > or on? > > > > I made the inner portion of my cabin top flange > fit so well that a > > business card cannot fit between the door and > itself, so if the > > foreward pin is closed the rear one is obviously > closed by just > > looking at he inner door fit. > > > > So with the relay or circuit that Stein has placed > in my system, can I > > just place a simple switch with is pushed closed > by the pin or should > > I just not hook power to the door system and since > the light will > > always be out, assume it is fine to fly? > > > > What happened to the priciple of KISS? Not, > PISSED. > > > > Two steps forward, 1 and 3/4 steps back > > > > JOhn G. > > * > > > > > > * > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?RV10-List > > Forums! > > Admin. > > > > > ________________________________________________________________________________
Date: Jan 19, 2009
No surprise...the forward hinged door presents its own issues...I just finished to final fit of my doors today and have total faith in the mechanism...I imagine Deems does too, it's all in how well you make everything fit..but I will say I have an easy 100+ hours in fitting and the. linkage/ locks Rick Sked 40185 Sent via BlackBerry by AT&T -----Original Message----- From: Darton Steve <sfdarton(at)yahoo.com> Date: Sun, 18 Jan 2009 19:53:25 Subject: Re: RV10-List: Door ajar indictors Our flight department has a one year old Cirrus Turbo G3. It is a nice enough aircraft but in my opinion the door latch mechanism is the weakest design point of the aircraft. Steve 50212 --- linn Walters wrote: > > > John, I just couldn't go with the rack and pinion > door latch and it's > resulting possible problems. The next time you get > next to a Cirrus, > look at it's door hardware. It looks like a trunk > latch from a small > car. My problem is I don't know which small car! I > have a good friend > with a Cirrus that's trying to find me some info. > If anyone out there > can shed some light on the Cirrus latch I'd be > really grateful!! > Linn .... Waiting for that small car to show up! > > John Gonzalez wrote: > > I opened my Van's door warning kit today and began > reading the > > directions. > > > > What am I missing in the understanding of this > system? Are we removing > > the 5/16 threaded bolts which we spend time > shaping the ends to a > > point and then tapping the inside of the aluminum > rod to receive the > > theads of these bolts, only to replace them with a > one inch long rare > > earth magnet and five minute epoxy????? > > > > There seems to be two issue that are confusing me. > > > > > 1) I made sure that the bolt length that I made > penetrated atleast 1/4 > > past the aluminum/fuse jamm when the door was > closed and was also long > > enough the it was still inside the portion of the > aluminum pin that > > was housed by the nylon block which is screwed to > the door. I didn't > > want the pin bending in the gap between the fuse > jam and the nylon > > door block. > > > > Now, am I asked to discard this bolt pin and > replace it with a one > > inch long cylindrical magnet?? Aren't we weakening > the mechanism just > > for the safety of seeing a light go out?? > > > > 2) Why are we using this complicated method with > magnets, fore and aft > > when we one switch could be thrown by the pin > physically pushing the > > switch closed/open and thus turning the light out > or on? > > > > I made the inner portion of my cabin top flange > fit so well that a > > business card cannot fit between the door and > itself, so if the > > foreward pin is closed the rear one is obviously > closed by just > > looking at he inner door fit. > > > > So with the relay or circuit that Stein has placed > in my system, can I > > just place a simple switch with is pushed closed > by the pin or should > > I just not hook power to the door system and since > the light will > > always be out, assume it is fine to fly? > > > > What happened to the priciple of KISS? Not, > PISSED. > > > > Two steps forward, 1 and 3/4 steps back > > > > JOhn G. > > * > > > > > > * > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?RV10-List > > Forums! > > Admin. > > > > > ________________________________________________________________________________
Date: Jan 18, 2009
I used the rivethead blocks and pins..but had built mine IAW the plans first. 1. IAW the plans, the bolt/pin is used to mark the frame, but is then discarded. The end result is the angled piece of rod that is used to "pull" the door closed as the pin goes through the frame. 2. The magnet is placed, along with the switch, in a position such that when the pin goes through the frame the switch is activated, but when the pin goes on the outside of the airplane it is not activated. The problem they are trying to address is when the door is closed the front pin engages but the back pin would pass outside the aircraft skin. If not carefully inspected the pilot would think the door is completely closed but upon takeoff, the air loads will open the door...and off it goes. 3. Why so complicated......fail safe? If you want the red like to always be on unless the door is open. There are other ways of wiring the switches. Some people are just using green lights showing the door is closed.... Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Sunday, January 18, 2009 7:51 PM Subject: RV10-List: Door ajar indictors I opened my Van's door warning kit today and began reading the directions. What am I missing in the understanding of this system? Are we removing the 5/16 threaded bolts which we spend time shaping the ends to a point and then tapping the inside of the aluminum rod to receive the theads of these bolts, only to replace them with a one inch long rare earth magnet and five minute epoxy????? There seems to be two issue that are confusing me. 1) I made sure that the bolt length that I made penetrated atleast 1/4 past the aluminum/fuse jamm when the door was closed and was also long enough the it was still inside the portion of the aluminum pin that was housed by the nylon block which is screwed to the door. I didn't want the pin bending in the gap between the fuse jam and the nylon door block. Now, am I asked to discard this bolt pin and replace it with a one inch long cylindrical magnet?? Aren't we weakening the mechanism just for the safety of seeing a light go out?? 2) Why are we using this complicated method with magnets, fore and aft when we one switch could be thrown by the pin physically pushing the switch closed/open and thus turning the light out or on? I made the inner portion of my cabin top flange fit so well that a business card cannot fit between the door and itself, so if the foreward pin is closed the rear one is obviously closed by just looking at he inner door fit. So with the relay or circuit that Stein has placed in my system, can I just place a simple switch with is pushed closed by the pin or should I just not hook power to the door system and since the light will always be out, assume it is fine to fly? What happened to the priciple of KISS? Not, PISSED. Two steps forward, 1 and 3/4 steps back JOhn G. ________________________________________________________________________________
Subject: AOA CPU
Date: Jan 18, 2009
For those who have installed an AFS AOA, where did you mount the CPU? Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Date: Jan 18, 2009
Darton Steve wrote: > > Our flight department has a one year old Cirrus Turbo > G3. It is a nice enough aircraft but in my opinion the > door latch mechanism is the weakest design point of > the aircraft. > > Steve 50212 Steve, would you elaborate? I had my first flight in my friends Cirrus today ..... well, yesterday ;-) ..... and found it to be rather solid ... and this newbie didn't have any problem closing and latching it on the first try. I did find it much easier to close the door and then move the seat forward. The only downside I saw was that when you open the door, you really had to push the button real hard. Linn ________________________________________________________________________________
Subject: Re: AOA CPU
Date: Jan 19, 2009
Hi Dave, I built a shelf and mounted it up under and to the rear of the instrument panel. Wayne Edgerton N602WT From: "Dave Leikam" <daveleikam(at)wi.rr.com> Subject: AOA CPU For those who have installed an AFS AOA, where did you mount the CPU? Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Subject: AOA CPU
Date: Jan 19, 2009
Subpanel, behind GRT displays.. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Sunday, January 18, 2009 10:29 PM Subject: RV10-List: AOA CPU For those who have installed an AFS AOA, where did you mount the CPU? Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Subject: TSA
Date: Jan 19, 2009
I was in the Moab=2C UT airport last September and saw that they had at lea st six (there may have been more I didn't see) TSA personnel wandering arou nd. I can't see why there were ANY TSA there. The airport only gets about t hree scheduled flights a day from Salt Lake City using Piper Navajos. The t own of Moab is only about 7000. This is not much of an airport. Just a smal l rural strip. Typical government reponse I guess. Dan Riggs > Date: Sun=2C ill > > David McNeill wrote:> > Just saw an illustration of why we are =2C as country=2C screwed=2C Flew the> > 10 to KPRC (Prescott AZ ) for breakfast. Upon leaving the restaurant=2C we> > saw 6 TSA/law enforce ment types standing around. > > Just remember=2C TSA stands for Totally Scr ewing Aviation. I suppose it> could be Totally Screwing Americans if they c ontinue down the path they> are on.> > -Dj> > -- > Dj Merrill - N1JOV> Spor tsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ> http://deej.net/sportsm an/ http://deej.net/kr-2/> > "Many things that are unexplainable happen dur ===========> > > _________________________________________________________________ Windows Live=99 Hotmail=AE: Chat. Store. Share. Do more with mail. http://windowslive.com/explore?ocid=TXT_TAGLM_WL_t1_hm_justgotbetter_expl ore_012009 ________________________________________________________________________________
Date: Jan 19, 2009
----- Original Message ----- From: "linn Walters" <pitts_pilot(at)bellsouth.net> Sent: Saturday, January 17, 2009 9:06 PM Subject: Re: RV10-List: Door ajar indictors > > John, I just couldn't go with the rack and pinion door latch and it's > resulting possible problems. The next time you get next to a Cirrus, > look at it's door hardware. It looks like a trunk latch from a small > car. My problem is I don't know which small car! I have a good friend > with a Cirrus that's trying to find me some info. If anyone out there > can shed some light on the Cirrus latch I'd be really grateful!! > Linn .... Waiting for that small car to show up! > > John Gonzalez wrote: >> I opened my Van's door warning kit today and began reading the >> directions. >> >> What am I missing in the understanding of this system? Are we removing >> the 5/16 threaded bolts which we spend time shaping the ends to a >> point and then tapping the inside of the aluminum rod to receive the >> theads of these bolts, only to replace them with a one inch long rare >> earth magnet and five minute epoxy????? >> >> There seems to be two issue that are confusing me. >> >> 1) I made sure that the bolt length that I made penetrated atleast 1/4 >> past the aluminum/fuse jamm when the door was closed and was also long >> enough the it was still inside the portion of the aluminum pin that >> was housed by the nylon block which is screwed to the door. I didn't >> want the pin bending in the gap between the fuse jam and the nylon >> door block. >> >> Now, am I asked to discard this bolt pin and replace it with a one >> inch long cylindrical magnet?? Aren't we weakening the mechanism just >> for the safety of seeing a light go out?? >> >> 2) Why are we using this complicated method with magnets, fore and aft >> when we one switch could be thrown by the pin physically pushing the >> switch closed/open and thus turning the light out or on? >> >> I made the inner portion of my cabin top flange fit so well that a >> business card cannot fit between the door and itself, so if the >> foreward pin is closed the rear one is obviously closed by just >> looking at he inner door fit. >> >> So with the relay or circuit that Stein has placed in my system, can I >> just place a simple switch with is pushed closed by the pin or should >> I just not hook power to the door system and since the light will >> always be out, assume it is fine to fly? >> >> What happened to the priciple of KISS? Not, PISSED. >> >> Two steps forward, 1 and 3/4 steps back >> >> JOhn G. >> * >> >> >> * > > > > > > ________________________________________________________________________________
Date: Jan 19, 2009
Linn, I have an RV10 with over 200 hours on it with both the lights and an open door warning on the Advanced 2500. The Advanced operates either normally open or normally closed. I used a single pole double throw momentary push button switch in the rear pin. Joe ----- Original Message ----- From: "linn Walters" <pitts_pilot(at)bellsouth.net> Sent: Saturday, January 17, 2009 9:06 PM Subject: Re: RV10-List: Door ajar indictors > > John, I just couldn't go with the rack and pinion door latch and it's > resulting possible problems. The next time you get next to a Cirrus, look > at it's door hardware. It looks like a trunk latch from a small car. My > problem is I don't know which small car! I have a good friend with a > Cirrus that's trying to find me some info. If anyone out there can shed > some light on the Cirrus latch I'd be really grateful!! > Linn .... Waiting for that small car to show up! > > John Gonzalez wrote: >> I opened my Van's door warning kit today and began reading the >> directions. >> >> What am I missing in the understanding of this system? Are we removing >> the 5/16 threaded bolts which we spend time shaping the ends to a point >> and then tapping the inside of the aluminum rod to receive the theads of >> these bolts, only to replace them with a one inch long rare earth magnet >> and five minute epoxy????? >> >> There seems to be two issue that are confusing me. >> 1) I made sure that the bolt length that I made penetrated atleast 1/4 >> past the aluminum/fuse jamm when the door was closed and was also long >> enough the it was still inside the portion of the aluminum pin that was >> housed by the nylon block which is screwed to the door. I didn't want the >> pin bending in the gap between the fuse jam and the nylon door block. >> >> Now, am I asked to discard this bolt pin and replace it with a one inch >> long cylindrical magnet?? Aren't we weakening the mechanism just for the >> safety of seeing a light go out?? >> >> 2) Why are we using this complicated method with magnets, fore and aft >> when we one switch could be thrown by the pin physically pushing the >> switch closed/open and thus turning the light out or on? >> >> I made the inner portion of my cabin top flange fit so well that a >> business card cannot fit between the door and itself, so if the foreward >> pin is closed the rear one is obviously closed by just looking at he >> inner door fit. >> >> So with the relay or circuit that Stein has placed in my system, can I >> just place a simple switch with is pushed closed by the pin or should I >> just not hook power to the door system and since the light will always be >> out, assume it is fine to fly? >> >> What happened to the priciple of KISS? Not, PISSED. >> >> Two steps forward, 1 and 3/4 steps back >> >> JOhn G. >> * >> >> >> * > > > ________________________________________________________________________________
Date: Jan 19, 2009
Subject: Re: Garmin GPSMAP 496 For Sale
Hello Patrick, =C2-My wife and I did the exact same thing. We sold our 496 and got the 6 96. It's really great! Brian ----- Original Message ----- From: "Patrick ONeill" <poneill(at)irealms.com> Sent: Sunday, January 18, 2009 2:47:46 PM GMT -08:00 US/Canada Pacific Subject: RV10-List: Garmin GPSMAP 496 For Sale Hi All, I=99ve decided to upgrade to the 696 and so I=99m putting my 49 6 up for sale.=C2- If anyone is looking for one, I figured I=99d ch eck with the list before putting it up on ebay. Unit is in excellent condition with all original accessories and box plus o ne extra battery.=C2- I=99m located in SoCal and anyone local is we lcome to come take a look first. If anyone is interested feel free to make me an offer off list: poneill@ire alms.com . Patrick #40715 == ________________________________________________________________________________
Date: Jan 19, 2009
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Windshield
Brief heads up for those who haven't put their windshields in yet or haven't gone to paint yet. My plane is in the paint shop now. I'm getting mine done at Flying Colors in Gainsville, Texas. Mine is the 3rd 10 that they have painted. All three of us have had cracking that had to be repaired in the bond between the epoxy fillet at the base of the windshield to the aluminum. I scuffed, cleaned with acetone, didn't touch the prepped surface, used West system epoxy and microballoons. I put the aluminum tabs as per the instructions. It still had some cracking. I have about 70 hrs. Frustrating. Ronnie ( the paint and bondo guy), cut out the cracks and redid the area with West systems and then screwed the repair to the aluminum. The heads were then filled. The joint looks great now. Will have to give a report later on how it holds up. I'll also ask him specifically what fasteners he used. I wanted to add this information. I remember the posts on the bond of the windshield to the cabin top. I used the 2 part weld on, spring clamps and did not get any of the crazing problems noted before. I have been really impressed with their work so far. Will post pics when she is done. The price is competitive, he will be done in about 3 weeks from start to finish. I didn't have to get in line for one year to get it painted. He has good facilities. So far, he's worth a look if you haven't gone to paint yet. website is flyingcolorsoftexas.com Dr Fred Waiting to get it out of the paint shop is almost as bad as waiting for the DAR to get here to sign her off....... Maybe done this weekend. ________________________________________________________________________________
Date: Jan 19, 2009
Subject: Re: TSA
HI, I thought they were just "considering" monitoring planes over 12,500 lbs , and the proposed rule wasn't made yet. But now this? Navajos' are certainly way under 12,500 lbs.=C2-tsa has no right to be there. I sure hope Obama et al changes this=C2-and curbs their runaway power grab. They are getti ng like brownshirts! Total waste of taxpayer dollars. One more reason we ar e going into the red deepr and deeper on the deficit. How much did it cost to just change their white uniforms to the new blue ones?? =C2-We are next=C2- if this keeps happening. Can you imagine them stopp ing us at our hangar searching our car and luggage as we try to go in our =C2- hangar and put our belongings in our own airplane, trying to tell us we can't bring 80 items on our OWN plane?? If they tried that on me, I wou ld end up being hauled off to jail before I would submit... Brian ----- Original Message ----- From: "Danny Riggs" <jdriggs49(at)msn.com> Sent: Monday, January 19, 2009 6:27:49 AM GMT -08:00 US/Canada Pacific Subject: RE: RV10-List: TSA I was in the Moab, UT airport last September and saw that they had at least six (there may have been more I didn't see) TSA personnel wandering around . I can't see why there were ANY TSA there. The airport only gets about thr ee scheduled flights a day from Salt Lake City using Piper Navajos. The tow n of Moab is only about 7000. This is not much of an airport. Just a small rural strip. Typical government reponse I guess. Dan Riggs=C2- > Date: Sun, 18 Jan 2009 22:26:26 -0500 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: TSA > From: deej(at)deej.net > > > David McNeill wrote: > > Just saw an illustration of why we are , as country, screwed, Flew the > > 10 to KPRC (Prescott AZ) for breakfast. Upon leaving the restaurant, we > > saw 6 TSA/law enforcement types standing around. > > Just remember, TSA stands for Totally Screwing Aviation. I suppose it > could be Totally Screwing Americans if they continue down the path they > are on. > > -Dj > > -- > Dj Merrill - N1JOV > Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ > http://deej.net/sportsman/ http://deej.net/kr-2/ > > "Many things that are unexplainable happen during the construction of an > air > > > Windows Live=84=A2 Hotmail=C2=AE: Chat. Store. Share. Do more with mail. =============== == ________________________________________________________________________________
Subject: Windshield
Date: Jan 19, 2009
Fred=2C Did you acid etch after you scuffed with sandpaper and cleaned with acetone ? JOhn> Date: Mon=2C 19 Jan 2009 09:45:29 -0600> From: drfred@suddenlinkmail. com> To: rv10-list(at)matronics.com> Subject: RV10-List: Windshield> > --> RV1 0-List message posted by: "Fred Williams=2C M.D." > > Brief heads up for those who haven't put their windshields in yet or > haven't gone to paint yet. My plane is in the paint shop now. I'm > getti ng mine done at Flying Colors in Gainsville=2C Texas. Mine is the > 3rd 10 that they have painted. All three of us have had cracking that > had to be repaired in the bond between the epoxy fillet at the base of > the windshie ld to the aluminum. I scuffed=2C cleaned with acetone=2C didn't > touch the prepped surface=2C used West system epoxy and microballoons. I > put the a luminum tabs as per the instructions. It still had some > cracking. I have about 70 hrs. Frustrating.> > Ronnie ( the paint and bondo guy)=2C cut out the cracks and redid the > area with West systems and then screwed the repa ir to the aluminum. The > heads were then filled. The joint looks great now . Will have to give a > report later on how it holds up. I'll also ask him specifically what > fasteners he used. > > I wanted to add this information . I remember the posts on the bond of > the windshield to the cabin top. I used the 2 part weld on=2C spring > clamps and did not get any of the crazi ng problems noted before. > > I have been really impressed with their work so far. Will post pics > when she is done. The price is competitive=2C he w ill be done in about 3 > weeks from start to finish. I didn't have to get i n line for one year > to get it painted. He has good facilities. So far=2C he's worth a look > if you haven't gone to paint yet. website is flyingcolo rsoftexas.com> > Dr Fred> > Waiting to get it out of the paint shop is almo st as bad as waiting for > the DAR to get here to sign her off.......> Mayb ====================> > > ________________________________________________________________________________
Date: Jan 19, 2009
Subject: Re: Windshield
John Gonzalez wrote: Yes. Been a year . Forgot I did that part. Fred. ________________________________________________________________________________
Subject: TSA
Date: Jan 19, 2009
The only thing I can think of is that the luggage would get checked at Moab (people also=2C perhaps) and then go directly to a connecting flight at SL C without going thru security again. But=2C they sure don't need six people standing around to take care of several (sometimes less) flights of Navajo s a day. The flights weren't even full when we were there. What's to keep t he plane from landing at some small airport on the way back to SLC and pick ing up "unapproved" items? Bet they hadn't thought of that! On a side note=2C I told the pilot that I'd bet the plane was older than he was. Yep=2C the plane was 30 years old and he couldn't have been older tha n 25. Dan Date: Mon=2C 19 Jan 2009 15:48:54 +0000From: cloudvalley(at)comcast.netTo: rv1 0-list(at)matronics.comSubject: Re: RV10-List: TSA HI=2C I thought they were just "considering" monitoring planes over 12=2C500 lbs =2C and the proposed rule wasn't made yet. But now this? Navajos' are certa inly way under 12=2C500 lbs. tsa has no right to be there. I sure hope Obam a et al changes this and curbs their runaway power grab. They are getting l ike brownshirts! Total waste of taxpayer dollars. One more reason we are go ing into the red deepr and deeper on the deficit. How much did it cost to j ust change their white uniforms to the new blue ones?? We are next if this keeps happening. Can you imagine them stopping us at our hangar searching our car and luggage as we try to go in our hangar and put our belongings in our own airplane=2C trying to tell us we can't bring 80 items on our OWN plane?? If they tried that on me=2C I would end up bei ng hauled off to jail before I would submit... Brian ----- Original Message -----From: "Danny Riggs" <jdriggs49(at)msn.com>To: rv10 -list(at)matronics.comSent: Monday=2C January 19=2C 2009 6:27:49 AM GMT -08:00 US/Canada PacificSubject: RE: RV10-List: TSA I was in the Moab=2C UT airport last September and saw that they had at lea st six (there may have been more I didn't see) TSA personnel wandering arou nd. I can't see why there were ANY TSA there. The airport only gets about t hree scheduled flights a day from Salt Lake City using Piper Navajos. The t own of Moab is only about 7000. This is not much of an airport. Just a smal l rural strip. Typical government reponse I guess. Dan Riggs > Date: Sun=2C ill > > David McNeill wrote:> > Just saw an illustration of why we are =2C as country=2C screwed=2C Flew the> > 10 to KPRC (Prescott AZ ) for breakfast. Upon leaving the restaurant=2C we> > saw 6 TSA/law enforce ment types standing around. > > Just remember=2C TSA stands for Totally Scr ewing Aviation. I suppose it> could be Totally Screwing Americans if they c ontinue down the path they> are on.> > -Dj> > -- > Dj Merrill - N1JOV> Spor tsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ> http://deej.net/sportsm an/ http://deej.net/kr-2/> > "Many things that are unexplainable happen dur ing the construction of an> air> > > Windows Live=99 Hotmail=AE: Chat. Store. Share. Do more with mail. Check it out. get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution _________________________________________________________________ Windows Live=99 Hotmail=AE: Chat. Store. Share. Do more with mail. http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_hm_justgotbetter_h owitworks_012009 ________________________________________________________________________________
Date: Jan 19, 2009
You might try Silkroil from Kano Laboratories. I have been amazed at what i t will loosen. www.Kanolabs.com. No affiliation. About $10 --- On Sun, 1/18/09, eagerlee wrote: From: eagerlee <eagerlee(at)comcast.net> Subject: RV10-List: jammed main gear leg Date: Sunday, January 18, 2009, 11:51 AM Has anyone had their gear leg get stuck in the attach bracket?- We got the right leg in with a moderate amount of wiggle jiggle twist and turn effort, but now its wedged in tight.- I think that some of the powder coat material-chipped off and got between the leg and the bracket.- We heated the bracket with a heat gun and we can turn (with a lot of effort)-the leg about 10 degrees-while pulling down on it.- We've sprayed some silicone in the tube. -This baby is really stuck.- My next tactic might be a very large brass drift and a very heavy hammer to drive it out but the opportunity for doing serious damage scares the hell out of me.- Any ideas??- - Paul Hahn #40203 ________________________________________________________________________________
Subject: Vans Manifold pressure fitting replacement
Date: Jan 19, 2009
What is wrong with the nylon one van's sends?? Doesn't work with AFS or is it just the material it is made of. John G> Subject: RV10-List: Vans Manifold pressure fitting replacement> Fro m: EGOHR86(at)alumni.carnegiemellon.edu> Date: Fri=2C 16 Jan 2009 04:15:22 -08 " > > FYI. > McMaster carr part number 5 058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS=2C ADAPTER FOR 1/4" TUBE ID X 10-32 UNF MALE=2C BLUE> > This will replace the nylon fitting sent with van s FWF kit for connection to a AFS or other system.> > --------> eric gohr> EGOHR86(at)alumni.carnegiemellon.edu> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.php?p=225053#225053> > > > > > > > ============> > > ________________________________________________________________________________
Subject: Re: Vans Manifold pressure fitting replacement
Date: Jan 19, 2009
SG9zZSBiYXJiIG9uIHRoZS4gQWZzIHNlbnNvciBpcyAxLzQgaW5jaCB2YW5zIGlzIDEvOA0KU2Vu dCB2aWEgQmxhY2tCZXJyeSBieSBBVCZUDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpG cm9tOiBKb2huIEdvbnphbGV6IDxpbmRpZ29vbmxhdGlnb0Btc24uY29tPg0KDQpEYXRlOiBNb24s IDE5IEphbiAyMDA5IDEwOjUxOjM3IA0KVG86IFJWIDEwIGdyb3VwPHJ2MTAtbGlzdEBtYXRyb25p Y3MuY29tPg0KU3ViamVjdDogUkU6IFJWMTAtTGlzdDogVmFucyBNYW5pZm9sZCBwcmVzc3VyZSBm aXR0aW5nIHJlcGxhY2VtZW50DQoNCg0KDQpXaGF0IGlzIHdyb25nIHdpdGggdGhlIG55bG9uIG9u ZSB2YW4ncyBzZW5kcz8/IERvZXNuJ3Qgd29yayB3aXRoIEFGUyBvciBpcyBpdCBqdXN0IHRoZSBt YXRlcmlhbCBpdCBpcyBtYWRlIG9mLg0KIA0KSm9obiBHPiBTdWJqZWN0OiBSVjEwLUxpc3Q6IFZh bnMgTWFuaWZvbGQgcHJlc3N1cmUgZml0dGluZyByZXBsYWNlbWVudD4gRnJvbTogRUdPSFI4NkBh bHVtbmkuY2FybmVnaWVtZWxsb24uZWR1PiBEYXRlOiBGcmksIDE2IEphbiAyMDA5IDA0OjE1OjIy IC0wODAwPiBUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20+ID4gLS0+IFJWMTAtTGlzdCBtZXNz YWdlIHBvc3RlZCBieTogImVnb2hyMSIgPEVHT0hSODZAYWx1bW5pLmNhcm5lZ2llbWVsbG9uLmVk dT4+ID4gRllJLiA+IE1jTWFzdGVyIGNhcnIgcGFydCBudW1iZXIgNTA1OEsyNDMgQUxVTUlOVU0g U0lOR0xFLUJBUkJFRCBUVUJFIEZJVFRJTkdTLCBBREFQVEVSIEZPUiAxLzQiIFRVQkUgSUQgWCAx MC0zMiBVTkYgTUFMRSwgQkxVRT4gPiBUaGlzIHdpbGwgcmVwbGFjZSB0aGUgbnlsb24gZml0dGlu ZyBzZW50IHdpdGggdmFucyBGV0Yga2l0IGZvciBjb25uZWN0aW9uIHRvIGEgQUZTIG9yIG90aGVy IHN5c3RlbS4+ID4gLS0tLS0tLS0+IGVyaWMgZ29ocj4gRUdPSFI4NkBhbHVtbmkuY2FybmVnaWVt ZWxsb24uZWR1PiA+ID4gPiA+IFJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZTo+ID4gaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0yMjUwNTMjMjI1MDUzPiA+ID4g PiA+ID4gPiA+ID09PT09PT09PT09PT4gPiA+IA0K ________________________________________________________________________________
Date: Jan 19, 2009
Thanks=2C I'll order this now and I should need it in a few days. Really ap preciate it!!! John itting replacementFrom: ricksked(at)embarqmail.comDate: Mon=2C 19 Jan 2009 19: Hose barb on the. Afs sensor is 1/4 inch vans is 1/8 Sent via BlackBerry by AT&T From: John Gonzalez Date: Mon=2C 19 Jan 2009 10:51:37 -0800To: RV 10 group< rv10-list(at)matronics.com>Subject: RE: RV10-List: Vans Manifold pressure fitt ing replacement What is wrong with the nylon one van's sends?? Doesn't work with AFS or is = it just the material it is made of. =3BJohn G>=3B Subject: RV10-Lis t: Vans Manifold pressure fitting rep= lacement>=3B From: EGOHR86@alumn i.carnegiemellon.edu>=3B Date: = Fri=2C 16 Jan 2009 04:15:22 -0800> =3B To: rv10-list(at)matronics.com= >=3B >=3B -->=3B RV10-List messa ge posted by: "egohr1" <=3BEGOH= R86(at)alumni.carnegiemellon.edu>=3B> =3B >=3B FYI. >=3B Mc= Master carr part number 5058K243 ALUMINUM SI NGLE-BARBED TUBE FITTINGS=2C AD= APTER FOR 1/4" TUBE ID X 10-32 UNF MAL E=2C BLUE>=3B >=3B This w= ill replace the nylon fitting sent with vans FWF kit for connection to a AF= S or other system.>=3B >=3B ---- ---->=3B eric gohr>= =3B EGOHR86(at)alumni.carnegiemellon.edu>=3B >= 3B >=3B &= gt=3B >=3B Read this topic online here:>=3B >=3B htt p://f= orums.matronics.com/viewtopic.php?p=3D225053#225053>=3B >=3B =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D =B7=9B~=89=ED=B2=2C=DE=D9=CA% =A2=BD4=D3M4}=A7=1Er=8B=AB=89=EA=E7{=07(=BA=B8=9E=AD8^E]t.+-=12f=A2=94Z+=BA e=2Cz=D8^1=ABk=A2x=9C=B0=B8=AC=B4W=9A=B6=EA=DE=B0=D6=AF=8A=06=AD=A2=BBhn=BA 0=B1=EBazf=A7=C8=B8=AC=B6=EBb'+bz=CB.r=16=AC.+-R=7F=D2=B9=BB=1C=AE*m=8A =89=C0=AD=C8b=BD=E4=9Ej=B7!=0E=8C''=86=9D=EC6=B2=06=BA0=B1=E0=A1j=D1@@=F8 h=B6=8B!j=B7=9A=9D=D9=AEr=19=AEr=19=A8=AD=E6=A1=AD=E7=E1=B6=DA=7F=FF 0=99 =ABk=A2x=9C=B1=CA&=FC=D6=AF=8A=06=AD=A2=B4U=D7B=B2=D8m=B6=9F=FF=C3 &j=DA =E8=9E'=2Cr=895=AB=81=ABh=AD=15u=D0=B8=AC=B7=F6=8C=014N4=92X@E9=15 I&z =DEj=D7(=9E=D7=A7=B5=A9l=A1=AB=DA=8AV=9B-=EBj=D8^Y=E6=C5=A2=BB =B1=A8ky=F8m=B6=9F=FF~=8A=EE=9A=C9=9A=B6=BA'=89=CB=1C=A2hm=B6=9F=FF~=8A =EE=9A=C9=9A=B6=BA'=89=CB=1C=A2o=DA.+- =89=ED=AE&=EE=B6*'Y=E6=D2=8A=D7=93 =85=A9=E4=CA=8B=9F=A2=BC=A8=BA=B8=1E=9D=EA=E8=BA=CB.=9A+=B4=C6=AD=B4:=DA 'W=8B=8A=CB@vh=A7j=1A=DE~=1Bm=A7=FF=F0=C3 =9A=B6=BA'=89=CB=1C=A2o=DC=A2{k =89=BB=AD=8A=89=E1=B6=DA=7F=FF 0=99=ABk=A2x=9C=B1=CA&=FD=CA'=B6=B8=9B=BA=D8 =A8=9F=F6o=F7=E8=9E=DF=E9=AD=EF=DB=A1=DC=86=D9=A5 ________________________________________________________________________________
Date: Jan 19, 2009
After the fiberglass cures, it's a good idea to use blind rivets before applying the filler. ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Monday, January 19, 2009 11:14 AM Subject: Re: RV10-List: Windshield > > > John Gonzalez wrote: > Yes. Been a year . Forgot I did that part. > Fred. > > > ________________________________________________________________________________
Date: Jan 19, 2009
Had a similar case on my bird at about the 50 hour point and getting ready for paint. Windscreen was starting to work loose from the metal and you could 'oil can' it quite a bit. On advice (and with significant help from) Joe Mckervy, we re did my bond to the metal by using layers of 1 inch wide fiberglass strips soaked in epoxy and laid up. We did this for several layers, then used super fill to smooth it all out. So far, it looks as good as the day we painted it. Joe is magic with fiberglass, so all the credit is his. On another subject, I took Tim's advice and added 2 computer cooling fans last weekend to serve as both avionics hot air exhaust and inner windscreen defrost (not hooked to heated scat tubing0. Test flight yesterday was 100% successful. If you're not yet at the windshield install phase, strongly suggest you make provisions for windscreen defrost capability of some sort Lots easier than trying to do it afterwards..... grumpy N184JM On Jan 19, 2009, at 9:45 AM, Fred Williams, M.D. wrote: > > > > Brief heads up for those who haven't put their windshields in yet or > haven't gone to paint yet. My plane is in the paint shop now. I'm > getting mine done at Flying Colors in Gainsville, Texas. Mine is > the 3rd 10 that they have painted. All three of us have had > cracking that had to be repaired in the bond between the epoxy > fillet at the base of the windshield to the aluminum. I scuffed, > cleaned with acetone, didn't touch the prepped surface, used West > system epoxy and microballoons. I put the aluminum tabs as per the > instructions. It still had some cracking. I have about 70 hrs. > Frustrating. > > Ronnie ( the paint and bondo guy), cut out the cracks and redid the > area with West systems and then screwed the repair to the aluminum. > The heads were then filled. The joint looks great now. Will have > to give a report later on how it holds up. I'll also ask him > specifically what fasteners he used. > I wanted to add this information. I remember the posts on the bond > of the windshield to the cabin top. I used the 2 part weld on, > spring clamps and did not get any of the crazing problems noted > before. > I have been really impressed with their work so far. Will post pics > when she is done. The price is competitive, he will be done in > about 3 weeks from start to finish. I didn't have to get in line > for one year to get it painted. He has good facilities. So far, > he's worth a look if you haven't gone to paint yet. website is > flyingcolorsoftexas.com > > Dr Fred > > Waiting to get it out of the paint shop is almost as bad as waiting > for the DAR to get here to sign her off....... > Maybe done this weekend. > > ________________________________________________________________________________
Subject: Re: Wing Tip Construction Stall Warning System Steps
Date: Jan 19, 2009
Hey Andy, I've been a bit preoccupied lately, and I haven't gone back to the wingtip section you refer to, so I'm not real sure what your question is. (Not much help so far!) But your post did remind me to mention that we got ahead of ourselves and fastened the wingtips BEFORE we had installed the flaps and ailerons. As has been mentioned in other posts, there is some play (rotation) in attaching the fiberglass wingtip to the wing, and this is critical in lining up the trailing edge of the wingtip to the trailing edge of the ailerons -- which are lined up with the trailing edge of the flaps, which are lined up by bumping them in the full up position (or -3 degree position ... at first glance you'd think they would be level with the upper wing surface, but they're not). I don't know if that's helpful, but I sure wish we had paid attention to that earlier in the build instead of later! It was just irresistible to pop those suckers on instead of being patient and waiting until the wings were installed and the flaps/ailerons functional. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting when it's 60+ degrees! Piddling with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225790#225790 ________________________________________________________________________________
Date: Jan 19, 2009
I'm only building my wings at the moment, and I don't even have the section of the plans that everyone has referred to with regard to the attaching the windshield, but whenever I've wanted to attach fiberglass or plexiglass to metal, I've used phenolics. A phenolic is a piece of composite material that can be bought in many sizes, easily bonds to fiberglass, and is strong enough to run a bolt through (with a washer) and attach to metal. I've made some really solid transitions in the past with phenolics. You just embed the phenolic into the plexiglass or foam, then bond it with fiberglass, flox, or both. Then, drill a hole through it for the appropriate fastener...good to go. Again, don't know what's being referred to exactly, but figured I'd throw it out in the chance it may help. Andy ----- Original Message ----- From: "Miller John" <gengrumpy(at)aol.com> Sent: Monday, January 19, 2009 8:48 PM Subject: Re: RV10-List: Windshield > > Had a similar case on my bird at about the 50 hour point and getting > ready for paint. > > Windscreen was starting to work loose from the metal and you could 'oil > can' it quite a bit. > > On advice (and with significant help from) Joe Mckervy, we re did my bond > to the metal by using layers of 1 inch wide fiberglass strips soaked in > epoxy and laid up. > > We did this for several layers, then used super fill to smooth it all > out. > > So far, it looks as good as the day we painted it. > > Joe is magic with fiberglass, so all the credit is his. > > On another subject, I took Tim's advice and added 2 computer cooling fans > last weekend to serve as both avionics hot air exhaust and inner > windscreen defrost (not hooked to heated scat tubing0. > > Test flight yesterday was 100% successful. > > If you're not yet at the windshield install phase, strongly suggest you > make provisions for windscreen defrost capability of some sort Lots > easier than trying to do it afterwards..... > > grumpy > N184JM > > On Jan 19, 2009, at 9:45 AM, Fred Williams, M.D. wrote: > >> > > >> >> Brief heads up for those who haven't put their windshields in yet or >> haven't gone to paint yet. My plane is in the paint shop now. I'm >> getting mine done at Flying Colors in Gainsville, Texas. Mine is the >> 3rd 10 that they have painted. All three of us have had cracking that >> had to be repaired in the bond between the epoxy fillet at the base of >> the windshield to the aluminum. I scuffed, cleaned with acetone, didn't >> touch the prepped surface, used West system epoxy and microballoons. I >> put the aluminum tabs as per the instructions. It still had some >> cracking. I have about 70 hrs. Frustrating. >> >> Ronnie ( the paint and bondo guy), cut out the cracks and redid the >> area with West systems and then screwed the repair to the aluminum. The >> heads were then filled. The joint looks great now. Will have to give a >> report later on how it holds up. I'll also ask him specifically what >> fasteners he used. >> I wanted to add this information. I remember the posts on the bond of >> the windshield to the cabin top. I used the 2 part weld on, spring >> clamps and did not get any of the crazing problems noted before. >> I have been really impressed with their work so far. Will post pics >> when she is done. The price is competitive, he will be done in about 3 >> weeks from start to finish. I didn't have to get in line for one year >> to get it painted. He has good facilities. So far, he's worth a look >> if you haven't gone to paint yet. website is flyingcolorsoftexas.com >> >> Dr Fred >> >> Waiting to get it out of the paint shop is almost as bad as waiting for >> the DAR to get here to sign her off....... >> Maybe done this weekend. >> >> >> > > > ________________________________________________________________________________
Date: Jan 19, 2009
The leg, she is stuck no more! Today we sprayed some Aero Kroil on the stubborn right gear leg bracket and packed the leg in ice. We let that set for about 10 minutes and just before adding some heat to the bracket we gave it a try and it rotated quite freely so we pulled as we twisted and it came out in about 1 minute. Last Friday we worked for about an hour to get it the first half way out. The differences were that on Friday we applied heat and cold (as appropriate) to expand the outer and shrink the inner parts, and we lubricated with silicone instead of penetrating oil. It was the oil that made all the difference, so much so that we didn't need the heat. Physics and chemistry won out over force once again. - OH that was one other difference: Today we had a huge double jack standing next to the fuse in plain sight, but we never had to swing it. Paul Hahn #40203 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225807#225807 ________________________________________________________________________________
Date: Jan 19, 2009
Our particular aircraft had problems with either the left or right lower door latch popping open in flight. The method of adjusting the mechanism was not very well thought out, it was difficult to adjust by adding or subtracting washers and or adjusting a rod end. Our Cirrus service center had no guidance or instructions as to how to make adjustments to the door hardware, the adjustments were done through hours of trial and error. The striker posts are mounted in a concentric hole in the door jam that allows for alignment adjustments. The posts are not very robust and will get bent up if any part or the latch system gets out of adjustment. If that happens you are back to square one with the door adjustment. To give you some perspective, our flight department has a 2004 CJ2 Citation, 2004 Grand Caravan and this 2007 SR22. I am one of two professional pilots that fly any of the three aircraft. I have flown Randy DeBauw and Scott Schmidt's RV10s, I will use the basic Vans design with aftermarket upgrades in my RV10. Steve 50212 --- linn Walters wrote: > > > Darton Steve wrote: > > > > > Our flight department has a one year old Cirrus > Turbo > > G3. It is a nice enough aircraft but in my opinion > the > > door latch mechanism is the weakest design point > of > > the aircraft. > > > > Steve 50212 > Steve, would you elaborate? I had my first flight > in my friends Cirrus > today ..... well, yesterday ;-) ..... and found it > to be rather solid > ... and this newbie didn't have any problem closing > and latching it on > the first try. I did find it much easier to close > the door and then > move the seat forward. The only downside I saw was > that when you open > the door, you really had to push the button real > hard. > Linn > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?RV10-List > > Forums! > > Admin. > > > > > ________________________________________________________________________________
Subject: Windshield
Date: Jan 19, 2009
My windscreen faring is about 1.25" taller in both dimensions than plans bu ild...by accident. Hopefully with the number of laminations and the greater coverage=2C mine will not separate. Notice there is a foam core buildup fo llowed by two more layers of 9.0oz satin weave...no wonder I have so many h ours into the project and I still don't have the engine mounted.The first p hoto shows the amount of fiberglass overlap on the windscreen. It may look like the visibility is hamperred=2C but really it isn't.JOhn> From: gengrum py(at)aol.com> To: rv10-list(at)matronics.com> Subject: Re: RV10-List: Windshield > Date: Mon=2C 19 Jan 2009 19:48:33 -0600> > --> RV10-List message posted b y: Miller John > > Had a similar case on my bird at abou t the 50 hour point and getting > ready for paint.> > Windscreen was start ing to work loose from the metal and you could > 'oil can' it quite a bit. > > On advice (and with significant help from) Joe Mckervy=2C we re did my > bond to the metal by using layers of 1 inch wide fiberglass strips > so aked in epoxy and laid up.> > We did this for several layers=2C then used s uper fill to smooth it all > out.> > So far=2C it looks as good as the day we painted it.> > Joe is magic with fiberglass=2C so all the credit is his .> > On another subject=2C I took Tim's advice and added 2 computer cooling > fans last weekend to serve as both avionics hot air exhaust and inner > windscreen defrost (not hooked to heated scat tubing0.> > Test flight yes terday was 100% successful.> > If you're not yet at the windshield install phase=2C strongly suggest > you make provisions for windscreen defrost cap ability of some sort > Lots easier than trying to do it afterwards.....> > grumpy> N184JM> > On Jan 19=2C 2009=2C at 9:45 AM=2C Fred Williams=2C M.D ed(at)suddenlinkmail.com >>>>>>> Brief heads up for those who haven't put thei r windshields in yet or >> haven't gone to paint yet. My plane is in the paint shop now. I'm >> getting mine done at Flying Colors in Gainsville =2C Texas. Mine is >> the 3rd 10 that they have painted. All three of u s have had >> cracking that had to be repaired in the bond between the epo xy >> fillet at the base of the windshield to the aluminum. I scuffed=2C >> cleaned with acetone=2C didn't touch the prepped surface=2C used West >> system epoxy and microballoons. I put the aluminum tabs as per the >> i nstructions. It still had some cracking. I have about 70 hrs. >> Frust rating.>>>> Ronnie ( the paint and bondo guy)=2C cut out the cracks and re did the >> area with West systems and then screwed the repair to the alumi num. >> The heads were then filled. The joint looks great now. Will hav e >> to give a report later on how it holds up. I'll also ask him >> spe cifically what fasteners he used.>> I wanted to add this information. I re member the posts on the bond >> of the windshield to the cabin top. I use d the 2 part weld on=2C >> spring clamps and did not get any of the crazin g problems noted >> before.>> I have been really impressed with their work so far. Will post pics >> when she is done. The price is competitive=2C he will be done in >> about 3 weeks from start to finish. I didn't have to get in line >> for one year to get it painted. He has good facilities. So far=2C >> he's worth a look if you haven't gone to paint yet. websi te is >> flyingcolorsoftexas.com>>>> Dr Fred>>>> Waiting to get it out of the paint shop is almost as bad as waiting >> for the DAR to get here to s ========================> _ ======> > > /9j/4SItRXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAQAAAA0gEyAAIAAAAUAAAA4gE8AAIAAAAQAAAA9gITAAMAAAABAAIAAIdpAAQA AAABAAABBgAAB6wgICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNS41ADIwMDk6MDE6MTkgMjA6MTI6MDMATWFjIE9TIFggMTAuNC45AAAhgpoABQAAAAEA AAKYgp0ABQAAAAEAAAKgiCIAAwAAAAEAAgAAiCcAAwAAAAEAMgAAkAAABwAAAAQwMjIwkAMAAgAA ABQAAAKokAQAAgAAABQAAAK8kQEABwAAAAQBAgMAkQIABQAAAAEAAALQkgQACgAAAAEAAALYkgUA BQAAAAEAAALgkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAEAAAkgoABQAAAAEAAALo knwABwAABDYAAALwkoYABwAAAH0AAAcmoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAogoAMABAAAAAEAAAbAowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAAAAEAAAAApAIAAwAA AAEAAAAApAMAAwAAAAEAAAAApAQABQAAAAEAAAekpAUAAwAAAAEAHAAApAYAAwAAAAEAAAAApAgA AwAAAAEAAAAApAkAAwAAAAEAAAAApAoAAwAAAAEAAAAApAwAAwAAAAEAAAAAAAAAAAAAAAoAAAC1 AAAAHAAAAAoyMDA4OjEwOjI0IDE4OjA4OjQ4ADIwMDg6MTA6MjQgMTg6MDg6NDgAAAAABAAAAAEA AAAAAAAACgAAAB4AAAAKAAAAOgAAAApOaWtvbgACAAAASUkqAAgAAAAYAAEABwAEAAAAAAIAAAIA AwACAAAAAAAAAAMAAgAGAAAALgEAAAQAAgAHAAAANAEAAAUAAgANAAAAPAEAAAYAAgAHAAAASgEA AAcAAgAHAAAAUgEAAAgAAgAIAAAAWgEAAAoABQABAAAAYgEAAA8AAgAHAAAAagEAABAABwDuAQAA cgEAABEABAABAAAAwgMAAIAAAgAOAAAAYAMAAIIAAgANAAAAbgMAAIUABQABAAAAfAMAAIYABQAB AAAAhAMAAIgABwAEAAAAAAAAAI8AAgAQAAAAjAMAAJQACAABAAAAAAAAAJUAAgAFAAAAnAMAAJsA AQACAAAAAAAAAJwAAgAUAAAAogMAAJ0AAwABAAAAAAAAAJ4ABwAKAAAAtgMAAAAAAABDT0xPUgBG SU5FICAAAEFVVE8gICAgICAgIAAAQVVUTyAgAABBRi1DICAAACAgICAgICAAUCMAAOgDAABBVVRP ICAAAAUCAAAAAAAAAAD/AQAAGWESMQAAaQkAACOyAABn0gAAz6QAAM+kAABoAQAA11IAZACDADIA HQAAAAAAAAAAAAAAAAAAAAAhGQAAAAAAAAAAAAAAAAAgMg4AAEgCFW4AAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAiIiIiIiIiIiIiIiIiIiIiEREREQFrA6ED7QGGAgIBxgHhAgABAzBgAAEDUgAAAA8A HgAQAAUABQAAAAAAHgAQAAAAAAAAAAAAgwFHAdQCYAMKAgIBLwICAmEAAAwTDPUAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiIiQAAPiAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAKvBEkEowPkARAD4gAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAKvBEkEowPkAAAAAAAAAAAIxg07DeQL7gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAHd3d3cYIxQfGCAQHg4XZABPAQgDAAOBAAAAHQRGA0CAHoEAZBAt ZAAXHBceAdUBfwGoAlAAAABVABEACAHGAeFmZmZmAAAACAAAAAkAAAAKQVVUTyAgICAgICAgIABP RkYgICAgICAgICAAAAAAAAAAAAAAZAAAAGQAAAAgICAgICAgICAgICAgICAAT0ZGIAAAICAgICAg ICAgICAgICAgICAgIAAAAAAAAAAAAAAAAAAHAAMBAwABAAAABgAAABoBBQABAAAAHAQAABsBBQAB AAAAJAQAACgBAwABAAAAAgAAAAECBAABAAAAEzYAAAICBAABAAAAgEgAABMCAwABAAAAAgAAAAAA AAAsAQAAAQAAACwBAAABAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAAAAAAAAAAGQABwEDAAMAAAABAAYAAAEaAAUA AAABAAAIBgEbAAUAAAABAAAIDgEoAAMAAAABAAIAAAIBAAQAAAABAAAIFgICAAQAAAABAAAaDwIT AAMAAAABAAEAAAAAAAABLAAAAAEAAAEsAAAAAQAA/9j/4AAQSkZJRgABAQEASABIAAD//gAMQXBw bGVNYXJrCv/bAIQABwUFBgUFBwYGBggHBwgKEQsKCQkKFA8PDBEYFRkZFxUXFxodJSAaHCMcFxch LCEjJygqKioZHy4xLSkxJSkqKAEHCAgKCQoTCwsTKBsXGygoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUS ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3 AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgAagCg AwEiAAIRAQMRAf/aAAwDAQACEQMRAD8A8lSAnB8zBHHI/wDrVM0TBQPNYH0C8fyojiI+Yh8emTU4 LuhUqwx9B+teG3qemkIsIxkzdfTP+FRXmkQ3aY3/ALwdGIP+HSpInkhjwC7Ed2AJ/lUn2iRgCUz9 QKScou8WDSaszlJbY20pjdSGX34qzp941lJzkxE/Mo7e4remKXAHnQq+BjkD/Cq7WVk5yYQuP7pI /ka74Yq261OSWGfRl6wv0uovKaZS+SXBOTjPGAfarNleNaTDyZQ6xMSNw3bOxBHRlPQjocn1rnjp FpLI/lSOjDsG4FJ/Zt9Ad8FwJML0fvTc6cno7C5Jx3VzttU0azNvFqdjbOLWclHjZyfs8w+9HnPI wQynqQRnkGsYW0WcfZ8H/eOa1vAt59u+1aPqEYjW6QQuzYwrDcYnB6k5DKAMD5x1qndWD2l1LbSg B42KkAVx1ocjumdNOXMtSg9oC42KFx261YW3iQgmDp3LmkeLOPmA59Kt6Ro82q6jDZxtkMcscfdX uTWSvJpXL0SNTRbOz07T5dbu7eKVQ5js7Z5MiWUYJZ16mNByRxk7RnmuV1DUVlkkkkdm3OXZ5Dy7 E5LMfU10/wARp5ri8i0vSm2WdigtkJOAu0AuSMABi3BIHPliuF/sdCxNzcPK3GQD+hrscacFa/8A mc15Sd7FO8v45mxGeB29fes8K8rEKpc+gGTW6tpaLlY7VeDk7uf51ZFxLGPLUlB2UNir9uoq0UQ6 TbvJmZYaPlfOuVKf3UI/Uj+lb0EiQSCSNpxggkB+Dg96prcyOeXJA/z3qTzZSMgH8F/+tXLUlObu zaMVFWQ10iPOZjk/Wonih6/valaSXu2B6FB/hUMkjyAo/IP+wP8ACpSZTOwsfCltfW0c6atBGDgP G7kPG3fIzyPQjOfrkDQj8C6aDibX2QjqFgJ7e7j2pqW2nTRGOeUhe43E8e9ONj4ctdoF3djpnY8n A+mR+dawrRt71O/3hKLb0nY1NL+HOgXz+W/ih4x/CxschsEg/wDLT0AP/AhWmvwk8Nh3QeLSQgBy unNjHt8/PUcCuWmuvBsblJdb1ONz0Xz3z+RJqOPUNDSGNbTxNfRzAdog/PsSM4reNWl/z7aM+Sp/ OjsB8I/DJWPPi0gyY2505x1GR/HWK/w80H7QsUWuzFSxXdJY7Rxj/b7nPJwOM5rEbUbyNfNtvEN1 JHGwzutsICSSAcDHODx7GlbxjrUMe2O9R16bfIxn8xirc6L+yTaqvtFnT/B2nXmq2emm5nQ3Mywh 2tuhLBehYVp2XgjRg0f2q/uLdJIRKJDY4U/KTwS4zyrL7kDHWuaPirUGmEsduwmXBV1PIx0OQQe1 NXxHqqMB5bIFYnaseApJ5AG7jmkpUY9Lh+9fU7a88N6DpGkTX+nahcTanbrG6MIAIg29c8nkgHHU DkD1rpNN8D6BrxuL7U7lvNL7Vit1UttAHzNnPByB+FeW/wDCR39xALa4D+SFxgjAXnP944556V0N l4m1LQbGCWzkJZooVkOTyduQeCPQ1ftKbd+XReQJVOWWup6F/wAKk8Mvlo2vtoB+Xykzn64rMm8L ad4X1ExafM8hmUFldNrLycDA9j/PpXNN8WfEqZKvG2cYDtJgflLRY+I7zUSdTvpN0xBZm3E8Lx1J J6AUe0pyTUYjpKpze8yK28OaLr2mpqGoajcx6lOss8yLaB04LkkHcOuO3Q+1c/qPhvRbOQxpeyFt xHz2mwDHckt/+qmReIdQiWO2tLUyxqCi4ZtxyCCAM8fePbn8apnV7sOsg03eVbeqSOpXOO4ABPTn kZ9amU6MlZrUzXtF1J7HwraateJaWt9mRwSFFqS2B04HqPyrW0j4XwatHfzPra2sdjgSs8ACqTnA JLgDkYJPAyM1T8J67daXqAupLVITDC6qQwTezJtH3RkHIBJBGeecnnUl8TzPepftJHHPDkLcRITM ysu1lbB+bjOPQEgEKABHLTtdBzzvZiRfDXwqreTfeNTZ3AJEkcmnkGNhjKsPMyCMjqMZyOoIGtb/ AAV0G8QyW/jgSRKGLSf2cdqhcbskvgY3L+Yrz3xJrlxqevX15b2DJbSTu8bGM7ipYkZG7jjAxnjH enWHiXUBanTjBdm2AYBLeMltzMjMeGGf9UnBLD5ScA8g91aWC8zv1+CegytiPx/bZ5+9ZgDj3MlS D4DadICF8e2ZwCTi2XgAEk/63pgE/hXn7ajJGMtZaogB6vZnH8629I0fWtZJjs47uMTALIJ4WhH3 gQCWwDyoPB7c0lq/hE5SW7KcsQVGIyCVxnGay1umjldJd4J7nk45xWjKmIzGInRAMAKQMfrXN6hf JZ3SrLlBJxuYk8fn0rssYk11Hbyy7l2+cRzjKsw9eMVl2enCSSVsQIsU2JDMSypnncRg5HA6Ak46 Gr8skXl7vNGHGSODkdqzYLgrE1v5jLDLkOobAPJ/pRZGkZabnQvbeH0eNbzzpbiIh5Ps1msEFxDt ydpKoyk5K5KN1BHoa99b6Ld3S3dnp1tZWynH2aHzCQvXJdyxzg4zgDjgc1RS/uYlggtrmT7Pty0L qHTJY84PB5wcnv8AQV3/AIV0PV/EERuLm/W30W1G+5kZISFVcYQbQwDHoBzjHToClFy0N5VE9Ulp 5f8AAOe0jw3FeT3C2cBYqrqNjudgZSMsSirjAYEEjPTvVmw0TSppRFqtxFZ3BXeZH27eDtwcAtuO M8jnOfc5mtSRzzZKi5SPu4A3geigYToBwBwBnPWmTah9tkjleONTswdgxkjuTyT2pOjCSbcvRJfr /wAA5nUd9F/XodWIPDNnIWNxZXc28uX8uf5ie5AUKfpjHAqCeHRbtLaOfUACq7IlLEGToBxsOT09 K5aVc7WOck/dHUe/p6VZTTXu1XfAZPJVc5GdvOCecehPt+Fc8cPGLfvP7zT2rtsjTm07wrGwE+oz RSMxRUAILHuCNvHUf/XxWnYS6X9nmsreSbyY4GzMyfKVbOSuOTgnuB+NYE+jkW7O0ccqRPgPgDgg euMfj+NU2lMcbY2lyhyMckCr9kr6t29f+AHtX0R0djpng5ZhMby1aZDuDSyyIQw5yCsfX6ms25sv Db3E4ht2O07gYZY2TBOPlwucDPQ8gDPQZrmHuwxwIQDn1Gf/AK9WPNjtLpLgxqdjbgrEgZ7dPelH DxvrJ6+f6WIdR22Reu9JtwDJbRZhDEb87lYgc7WHDfhUGm6E85mJtGkQkANsLDPOcHH0rQ069jF8 txJaJ5Ujq8sYOCW/vAjkcfX8a9Fv9LGn2EGqQSfa9MnbCTxjBU4LEP8A3SMc845GKmdPlbgpX89h xndp2+Rl+C/hFpOtX1qus3i2onjMkdvbIpdsF12lzkK3y7sYOR3BNeh3vwT0jT1ju9F1CS1ngTy5 JbqTduXPOWHCkKcDC15xHe3EepJfW3nIquFTaOcjj19Qa6hfFepSqYGinaAkiQvkDJGfmP8AnrW0 IWVrXJlM5FdQ1TTrqKS8lmk2n5TIxY7c579s4/Kusg8ZwM0CyxLgpguDhq4Xxj4ivoNTIitYzCEU hywZSMAY+U8YORz1pdInsdbaJptlgAo3GWZiGOcYUrG2PxFbQXvW6mcknqSyxB1OA/XqVI7/AE+l cr4k0pJ57eN3McskgRG64yCen/Aa6yTxjoUkzxtYSRQgYKoxeQN7HdtYA8g9/SsO3vNP1K/N0vhy fUr1NpRkllXYBkdEzxlh2pzjZ8qfzBPS5yNrLJAkyyptdSFBPsoX+gqpHcRRxLNOW8sSYYIMtg+m fpXXeJdIu4dP1OU6ZLZW8EwIWd1DD5uMA4LDDdhXIWei3Oq2v7qaGJFIz5pYZOM9gfWstY/Foab7 He6L4Qk1S/sBE7rZXQXynEQLOGUEKM4HJJ5xxznJGK7/AMfX8GkWkfhbSMQ2lkAJFjO0SyclmP4+ vp7muZ8O3T6DdaQ2Az2kCS8IpDMFG0444ztPJP8AhR17UP7QvZXd8PI+cHqf8810aQi0iJasxHQv t3A4PYY9aYlrEzrbrudDln2kDAx2Jz6fl0xT5gElyTnA4DE09FjlG8qS7HjqcjHJ/L+vpWSelwLV jYvI+UBJ2cDcpH19hjP44rvdA8IXV+HeJdu47Q2/lscHGcZyTkZHpnPNctotiJpFz5eFiLks33QM c5Gec9voPp758PVzZFmbfhQucddpwO2eBjrnrnqTjJu7sUjzzXvB76fplzAIvLXKbRuLHjGfr3Oe PfPWvMdY06Xzy0qyRFRvIfI4IHTjpnpX0j4xKyC6D8osY3BWwSOeM9v1/SvCdagRU8/zo1WNyOW5 b5SSeOAAMdx1474SeoNHCyWbGf8AdyBxkHA4yKWWMSSeW6EgHLFa0pEVJHGTAwPCkkYxkHg5yenQ 9qieAAkMAAG6DIznPt07fT1rRPQkbFL5a5yDt44r0z4Y+JkSZtM1HbJYXnyPHIoYc9CQeOOfbGc1 5qIAm9eAFxjgD6mtPSrn7HNuORnhsAnk9APespK+w0zo/GvhyfwlrbxRuEtZZd1vkAhV/u5Pfr35 HeshbtpAcHKMc5AHI9fWvUNSlh8d+D2h8pX1C1iV4XIJycYB4wePl/ycV5D5qQSNCXKuhKlTwQe4 I7c9u1b9FIWjHahapeQNwA/Pl5HU46Z98Y/nVe1T7LHHAkuMkAjZ3/Or0UsE7MGLAjncoGBjsKkF lZykuL/af+msRz+lClFagyCHwTdlAZ7LWIlOSZRY/KBnuMk+n5it2z0W4W0i8hL6ZAoADWpVzgdS pIOeOmPwq1N8R/DulQCy09WeR4jhYwwCZzzlsg9c9TWvo+v2euWw1G3tdRt7qNTH5xmSRAQMkgOp XHPccY475UpRaT0s/wCv60LUbXszmZ7DS7u3aC51JLScMFkjmALP7eUcMB9aveC/h/omsJCmlapc TxLOq3BliG5idoOF4KLw2Cc9ParOu/En7PaSWusanLlusdikcSyjjgsCzEduD0ODmqHgfX4tUv8A Ur6CC5htkjMUe+aWRXZsk/fY4bG0Ej+9+dwhQlJRS0E5TSbe5peL7E3fjC+e3jXyEYRoycDCjA+u cZ445rAn0mZXAMQJBz1H510U5nuLhpY/kJYnEnzf4U+S2kc/MVYA/wB3n+ddklg2/ekznTrJaJHC 3mg6nO5WO3LJ2O4dO+KfbeHtRXy0S3cLgbiJF4JLccn0/rXaC0kAwPunpVm3gJKoQ55/ifI5x7e1 PlwNrc0v6+RF8R2Rm+HvDOopJmWBI0fC5Mg+UFhk4Bz/AJHY17V4W+zaXaLDNdRKZSBGJHClsAnA GevBOM+przyKGSwm8t/miMe4MMHJxkDH1wOv4dq0tPeN4fmga3VWI22yBhjrntzmuaVPCp3U/wAD aLqW1ibniO48+WdflJmgZk2nOcHsfbcO3415LqWl3s820W0knmL0LGP5cA4J4weh+o6Zrurq9ee4 lkG75j36kA8cZ4/XFY0t7M7ECNTz3apjTwzetT8GNyqdInA3Ph+8hKJ9kDRkbkIK5AOODgk9SODz 17VnyeH9QYh/snyZJUK6jB4z9f0/lXqupad5OnWl5Dc72mJ8yNkC7MdcEMSefUCuflDMwLjdzxjr XSqWCXxVH93/AADByr9I/wBfecWND1NSGNq21hkL5iE/eIP8WR06e30q3FodyCGKIp9CR/8AXrp5 V+TCrIjDpl8gfgB/Wo4oJN2dxz+NS/qC+1Ia9v2RN4YurrSdQiZ5HW1ZirorZCBuGOD7elct48sY o/ENxe2rKIrv5+mAXwN2B9f510Nws0bcc1nazH9psS7L5hiG8LjOcA1nOWHcGqbfzNIKope8jipH mtsMQdrDsfTH+Iqax1IpcgszDHOSeabcFZMLtyCuAEOcDPf36VSun2oU5zjHNcsXeyZq0dZq/iPw 5p15cz28Ru7iZQsgc5DYOOgwTxngkY44rAGr694itJItLC20MK/LaQAKRg9doAAOM9BntXEwWV1I fMWJ3QH5mXnvWtY3C2TvtEYZsKY5o8hwTznP4VMYRjvqVzN7FnRtMimu5GvWSUBCQ7vkZyBnJ479 69Z8O28y6c7QwTTq0vzvDAzhDgYU4B5xj865zQLCTxxq1lpsVr5EIAWaRcfu4uMqOMAcY6enGM17 HFc2OnTW3h7SbO5kt7X5d9ujeWDn+8cbj1/WtadNybl06BKSSsc1Fp2ogec9hcrF1LmFgB+lCHY9 600sYWOSPYh3byHB4Ax0BRsk8cgda9Mn1RbBBbfZrhpdvzBow/H5mvOPF/iK1gmjK6VdYzhvIhA/ TNFSk1qhRktiD7SpztB/EYpRK0u0K2z35rMsfGulR8y6ZqKYPQwMT/hXUWPxG0d4gCupwMBj5bNj 9P4DWD5uxVkVDMFUI8oYj+InrWrpkwMJCX8EJ3fdkkC9utXLT4hWG4GPUL9c9m06T+kZrpLDx5pU kYZ7i6bHUjTrn+kdQ1fcex55K7oGYngDJIqoDOsMMt0AsskKStgAD5lDA8cDIINei6p8TfC0I2nW JImDDK/ZLhSPzUVzB8deAbOxitI9ZZool2pGsMwCj0HyUnCSeg7qxzst+NojLrt/3qpi4yxACf8A fQrfbxp4HkBZby5cegtpm/8AZKzrnxr4QjIMUd/L7fZXx+ZWj3idDOe5xwImyem0ZzTopy7bPKlD f9czRefEPw1txBa6rIc/w2/H64NRad4z0q6uE/4l99Gv/TRVGD/31SalbUehrXXhjVHvr2Wygnvb JCscNwImRJAFySN3fLFT7rjtWbeaFqttCXn091jK8kMp/QEmvS/C+u211Z+SGm8yVm+XzIRyWJ6b x61b1DR7/wAwRpZ3BjkJxuePlsem7jjNXT1ZMj5llu9PN48DRSWsplKurEERnv6Drx7c9KjvdPMk b4McikYDock/h+Fdv8UPBTQSNqsdrPFKG2TAqCM44zg8EgHBxg4I7HHlUlxdwptjlIA6A9v881vy uJPNcvm4igaV1jjeeRdrBeYl5HI45PH/AOuq1tZS6hfRxxxiSV+ijAAPX6D+QqBu3+e9dj8MY45f EcQkRXHA+YZ7gVFOPNJRHJ2Vz17wnpdr8PvB/wBrfym1zUEHlKSH8odd5B6cHjOf4fVqs6W8Xg3R 5dZvpN+oTRGWIOC32eLBO8jqTjoKxNd48e28P/LL7N9z+H+Dt+Nbd9/pWtSpcfvleTDLJ8wYZxg5 616Gkduhle6uZV7LLIxeeZcOSzSbg24+oPTH41y2ppDNJNs83ZAE3yFMoN+7aN3qdjcH0784s2tz Pd2lnLcTSTSSoGkeRyzOxAJJJ6nNZOtEr4g8oEiNtPBZB0JEnBI/E/mayqTckkXFW2IIdOjmZVV0 kYjP7yQRDA6ku2AMDJ59OorXis0t/kAZn7j0PvXPEf6JdN3WByD3B2mu01ZFi1vV4o1CRx3kqoij AUB2wAOwrnk+g0UIngZ2QcSo+1owGAVdoIbJGDk7uATjHOM4HSQXd3Z6f9otkVxvgiIkACqHkVWJ JIAwGY5JA9a4Wz41y9x3jhJ9/mkrubMlksVblW1CwDA9D/pMXWs5FIm1uxK6h++hfc2NxjGTn6Hr 9OK5mGKXfqcbRIscXyqQ3LfulcfUgsQcdMV0OuMwvMgkE45zWFd/8jFfDti3/wDSKCpWw1uZAgly TDLHBtRnYSK5LAKSAu0HBOB1wPccVj3LRuhY8d6vw83lsDyD5mf++XrOu+jj0FXHclmTJHLbXMkU 0W2SKV42UZX7rFc889s1uWZb90TEdpB/e8gDbjj3+8Oe3frXPAn5+erv/wChGtlCRo2mAEgfab04 H+5aU5xBM63T71lljVJFjJb77kKF9yTwAO56AV6N4e+IX2vRBDqgIk8kMHjxIV4Bx1GSD0bjpXku mqskV6JFDgabeuAwzhltpGU/UEAg9iAau2ztlfmPPvURbTGz0rT/ABLaeMzPol3tj1OOEAO4wlwr 5xG3udmc9jjHNeI+P/BM2jX0/wBnViq87WGGA9x6jp6emRius09FElxMFAlM+0vj5iAowM+gya6T 41Et4c0KZjmSeOFZXP3pAcZDHvnJ6+tdi9+Opjsz/9n//gAMQXBwbGVNYXJrCv/bAIQAAQEBAQEB AQEBAQICAQICAwICAgICAwMDAgMEBAQEBAQEBAQFBgUEBQYFBAQFBwUGBgYHBwcEBQcIBwcIBgcH BwECAgICAgIDAgIDBwUEBQcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcHBwcHBwcH/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLAQADAQEBAQEBAQEBAAAA AAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNC scEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY 2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMi MoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpj ZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbH yMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgBkAJYAwEhAAIRAQMRAf/aAAwDAQAC EQMRAD8A/lKt9Wt4UKwPL5bEgpwN3tkf/X7VTOoW79Yjz2A7Y4r80tJ77n2UVZ3ZvWOpWUSBnibk kYVR7Dt05J/SuosfEXhq2YI9jJIg7Mw/Dnv1HrzXJWpVZXcWkdEJJdDq4vGPhyLLvpDE7s5KjnJ/ /Xz7/nFqXxK0HTrPzm0TzNpA2qAO3Pr61xLBYic0udJtmzqqEb22OdHxo0OVYMeFGZm+UKZEyvr1 9f8A69dbaePdOul82Lw1lWHIMoXGcEjoOeo56fWtKuXVqOsqu4U6/tW3FaFo+NLDb5X/AAifzNu+ bzge/wBDj6+mPxnh8X2pk3f8IzGXzkMsvPUe3+c4rn+rVLfxjb3027BJ4xtS8jf8IypGejuRuB98 e+aqy+KY0iZBoUbN6hmz/wDWqnh5OzdQav8AEcf4t0bTfGNm8V1psUNzs3QzqX3A8fn0Oc+gr5J8 R+ENR8PXJgvrPMBGVk6h15HBP4/nX2PDuMai8DVldrWPp2/U+Zz3A8rWLprR/F/meb6hof2ja0Lk d+elZo0PUotpEoYE9j37fXpX1l7o+ZtYmSHWFZCyMwBwMqeM9eT7VagvL6N1LQEc5LAY/D/PrSsg 3OwtbRNWsZbiNAk8YJkiI5cdyPX8652W3msJDLFIwjBABXrGR0ORQn9kUl1Pr34R/FJ9WgtvDviC 7X7b8qW8zEATDH3G7E+hPv6V9I2rzI33gQeAc4+gIz0r6LKMRen9Xl9jb0/4GxxYmPv86Wj/ADOr l8U6jpfh6PyLghhM7xlvTJABJHpyKd4C+IHjfXL67hEsDWtvhZmZeSW3Yxg8Zwcdvyr4zNcGqGYz UXaE22v1/E+kwNWNfC+/vHQ9wspbr7U99NJv3YUowDANyOPfGe/6VgeKtU8K3EFxp2ptALsAkusQ LKT34HfHT2rD2WHo0WpdfvLvUc1yHytd3EP22YaLckwKTujkTYzAZ6A9D14+le9fCH433WgsPD3i XdceF5vlAkJZrUn0z7Z49K4VFapaf1oOtDnWi2PTviN4MEs+k+OvAmsyWniOzlW+03UrCQxywSKd wZWHKkEdO+SOhr9QvhB4h+G3/BVf4dXfwm+KlzbeG/26PDenkWOqLiOLxlBEPlZxxuPzYYDJQnI4 PJWjGdKNSauo6SX917/c9TfKq3JUdF+q9Vv96/I/FX4xfA34pfB3xxr/AMPvHfhW6stfsbl4pVkV mWQLyrKwyGU4yGHBFeV/8Iz4glJ8nSpFycBjE2R+GP19elfMYmjDC1pUpS9PTofUxnGUVKPUSXw7 4hMSxixuVjJxgwt0AxwPw9P4apnwr4hUE/2ZOEJPBjfDHP059OnaudVaUVdzX4BdLckTwlrssZV9 Nm4BBxEeRwMYPUfjRD4L1yKNNmm3DkITuaI5BBAxjH1FV7enraS+8m8b3ZfXwbrjK6ppU6kkY/dk FT+IpH8J62I0I0WUjcMkIcgkY7dsf/qoVam3pUX3ik1spdSmPCfiEII20GUBeOnTt6cdh36e1ZF7 CNOJg1CJYm++ysoBA7Z9/wDPFa+0hL3YzuyU1G7uWYvs4jCxkeaUVmyCWXnC44xz/StmLQdUuVVY dPlkc/MuEHPOM+oHX9OvUqVo2cnYUaiWzHL4S8Uu5L6O6yBj8u0+/f8AwqceEPFEfliTRZdp6LsO AP8AP86xlVo/DzopTtq9zr9P8KeJrewWUaVNkEPtRTkY9TxjP/1q5S/8KeKDOX/si4kzjcMZLDv6 k45/CtOalZNzSREZx5m7m/4R8N6hBNO9xpEqDcD80RAI4Ax3OMe/HtXs1rpr73Vbb73fHpxx36Yr ysTCVbERhSd22lp3HKcXfleh/QF+yj+yZ8Hv2Gvgte/t+ftqrHHdaVbxaj4c8L7Y5Z7a6lXdYjy3 OyXVZzgww422Kr58jeeoFp+EXxv+LnxY/bo+O2t/HD4tSeWLh/J0TRIWZrLw/p6MWhtLdW/hUNln IDSOWduuB97l9CODw9o/ZXKn5tXk/wAreTt0PnMyxEptU09H+S/z3OA8Z+ILHwvZDw/okg+07Ss0 kLADp0BHbPfv9OvgFywuJNz9CdxbPJ9cY5/z3rysbXcpOPb8zTL6HJT9s1q/yMz+zomjcZHlkZX8 zgjH86pPpkbbiSc4PBPQZz+HX9T178CrO56TgkrnlvjHVrfR1ls7actqLkbiCCYwRgAYPU59fevH EgnnduHeaVtnA6k5G3B6j35zX3eSYf2OE9tNWc9fl0/zPmc0rKpX9nHaP59TlPEGtxWouNP0yRfN 3Dzp0bcE6YQdifpkfzPBiMAGWRSTnKr3HHU+pNejzOV5y3f9I822tkBuEhkJCEv/AA/N/OsyWNLg l5XO0HIGMcen5Zpa6sZF9ktu3OOeGx/+qmLFCu1vJUN9ART1Y7diaC0nvHW2toGeZjtVIxksTgcA V9X/AA0+FEOirba1r0Kvq5O+KLORbYxyfVvfGB0HrXi51jXhcM6dN+/PT5dWenlWE+sV+ea92Ovz 6I92828hZjvYKDnCnnj69Meg/wDr1nx63rNjeLdWV46Xw43cHbwOB74P+HSvh1Tg9LaH1kkpRtff 8jt734wfFC7tTE/iqbYGxgGMdsDoAcnpn3PBrvtV+Jfjq6+C2iwzeIJS1xqF5Z3DSNl5I1jhZVYk ZwN7dueO4xVxhCLi4r+rM4pYeinFxVtf0Z8zyXGpu0CyajIIQMhVI3Me59uoH/16iluLoRsHv5AO m3eB747fTn3rXlp30gjobad7kSzTq8TzXDyMVIx3Bz1/l+ANMa6uQ20SNjuo45wfXr+vfntV+zj2 M22Z015LwHJA/E5GenTjp+g61Qknldm8uZtmeDgEj6cdOBWsYK+iJ6mdI907/NK5yMndxnn1/rTc Teg/7/N/jWjS6I55NJ+83/XyOuggsJmKnSyrckEydG9OnIH+cVeOhRvgwbwV+7nuDnj3/wDr1zOc 4fFK53wT6FtPDiOrkqDjHUYCkH079avx+G1dSEYEZ2gqvBwcckj25+tZSr20NlTstzctPCAkEarP 84+U5JKgdu/vn8q0p/hxbywmOe83R7eQFLEnJB/nn8K5pYzkkklsaezjbV3MQfD7QtMEl0EBkALA 46cf5FVfD8tvqepT2SRAKil+mePQdh0FauvUxEJ1JO6SCMYUnGEVoz0i38M2EoBe4UJg9enfH+Hb r+ch0CzXES3GQVO1ipHQ+o7YrgWIk7xtsdFm9EiwfDtpISPMZlAznGDj/OOM/wA60odEtCoiRdz7 hsUAHr74yeue/WpdaY3e1rkg0OEOqtaTBV4wUcdPc9fTv1/LJ1nwXomuWEljqdo3lbDuBTBjODjB 9fr+da0cVVw9WFWnJcyd/wCvyMqtKnXpyoz2asfEfxB+HWreDb0ExtNpUhJin5xj0J9e34V54nlk 7ipAHBxwD27DGea/UsJiYYzC08RDqvufU/PsVQlha86M1t+XRkhLbf3QXA4Knufrj0/lShwcK8Sh jnqfY8e3SurUwJYp0hLKqtj6duOOO/FRKI5Q0bn5CMAn8OPf6/X0oXcl6maYJ9KnjngY/ZgflYZD J6H619pfCf4n2fiexi0DV7hU14xbIJCcfagBx1/jGOvcflXVhazw+IjUW2z9H/kZTipRcGjs/ijJ qcejWMsJKaWsUYC9CCFJHPrk/l6169+zlf2V34XeV44TqjSkSNjBYJlVyep9fxrfNsLGvg/rFN3d Nu/o9/0Ky6v7LEOm3pPT5o6vWfG2q3Wrz6FZ20Xkq7D5T2U45PXv/KrWi6NdS3bHULeBYSc4BLO/ TnJ6HGfy718DGNTEVnOpN2T2PqfcpU79WaXjTw/4dm05RDpkUd9kKkiIA2OT2/D8/wAa8Xv9NurJ lM+nKs+04eMYWfnPDf3sdD7+9dOIou7lGT0RnSblGz3O98B/E2Xw/N/ZuoxF/DkzBJI2wTASeoA6 HrkZ6Cu/8Q2eu+C/Evhn4wfCnXpLHxbpdzHqOmX1rIVKup3AHB+ZW5VlzgqSOhqqEk1aeqejOGq5 YfERqw73R/Rp4G1P4a/8Fff2Vj4ttLe00r9q3wpbfZdTtuF86ZRxnA+eCbBZW52Fs4+8p/n+8a2e s+AfFuteBvFfhq4s/EOmXD2t3aTAJJG6ZB4OOOAQe/GDg18rnmBqSh7aL1g+WXp0Z9ZRnCaUo7SX Mvn0+TONfxDAdrjTpBz6gcenPXgVnXHiu2hV3+wtg5+8w49CPz7e3NfMKjOWjZtbVMz18cQFyk1n 8jEYIbJ7c9P88VJ/wmEMzKYYQcg9wMZP+PHWtfq04psHHVlr+35ZfuWAMbNk/Pn6H29etVZtdvI1 ErWKKSMgO2Cfw/OpjTV/iItHujAvde1GZHiR0iGMEpyT9M8gcHoPxryTXdAuL955o3BnJySSMkZz kntxn/PT0cLajJS38/IHFNadStbaDqMctwbiRWVwIgigZBx8xJ64GeOPyr2jwlqGn6Vp8VrKv784 JZlOXJAOM9MDJ5+nFa4upz0eWn/wdifZtu52J8R6QgAkvhuzyu08Z7kcenT/ACXp4g0iT5jqqlmJ B/dnjHoPT/CvHdOpe7i7F8sraxL8XifS0jKrebl/iO1hg5+n4e34VWbXNFMoc33LAnoSVDfxdPUf 5ya1UZy0sSo6kUepafISbe6LlASTtIC8E5zjjpzX9EH/AASr/YTtUSw/as+NFpDHBbK954Usr3KW 9kYNxl1a6LkLtgEb+Up+VZEaRsGFVb6DIcBOVSpmFRWjT0X+J3t80k38kcmJqKKVGL96X5Ldn5Mf 8FIf2wdX/b0/aETw54OvZR+zJ4Lup7PwvaEMi6vMTsm1WdT1ln24QMP3cOxMBmkz8n+LvEdj8PND h0HSmT+3pYgkhDf6pMEce5IOfy+n1GMqLD0fZveK185PV/jp6HzrTxeL5Ol7fJHzA15PdPLJcENI 7b2LDhm+h6fTHrxWddNAuHEiBByPmPqOefx/+sK+VcpSbct2fRJKKVlZIhmngXOJYwwJ53gBR7iu U8Y+JbXw7p88kBV7yRSsIHPoC5/z1wM1rgsM8Vi6VBfaevp1/AjFVY0cPOrfZaev9WPmeZri9mlm lkY3DMXZm5Izj9T7dsVz+v6utlFPpVpcEagylZnXkQqccdM5xnP1x61+lzXLCNKO36L+rHxblduT /pnnAUIsZlJxglM8FiT1P+eenaqk8nBJ+73zxj/PSk97BHcqnPcjgheBz+H5c0mzpydi+nfGe1S/ JDGqANqYPpj2z161c0rSdT13VLLStJtHn1GdxFFEgyXc/XgepPAAHtxMpRpxlUm7JK7KjFyaUVqz 9Hfhb8AdN+H+jtqmq3VtceMp4mHmblcWW5SMRA98kZfHOOOOtfQvBmvDW7e3vof9HhkZ2fzQ/m5w Vx27D9fWvzPEZqsdXxNeei+wmvsq6X33ufZYXCrDUadOO/X16v5bH0TDpNh9nVPs8LAheNobPH/1 sUyTQdJd3/0OLDd9ig49f1/Wvn/rFRLSTOvZEX9j6RCsqjT4jtzzsUd/p+vtXUy2+gy+BLPTPs0T XMOqSSJHtX7rRJnA68kAZ9hWtHE1Oa7l3/Jmc170e9/8zzmTw/oErlTpMG7upTqP/wBf8qyrrwvo LjjR4Mg/KQgX2GMdPyq4YvEbc/3mlo7WM9tC0mN9raTECGIG2MZHY/TsMf7WKcfD2kkgJYQhtm7O OcHHJ71q8VWWqkyWtbpFNvDWjKpkk0+AEkjBUcdeenHQfXn3qk3hjSmIjOlxBeQuV6HqfqRj9far jia9vjYmo21Kn/CN6QNzGzh8vd3A9e+eg4/X1FO/4R3Qf+fC0/z+NafWKj+KbMvZ3OZsYfDLxrL9 skGectx3/wD15Pf3rorfT/DwKMdUY5JwCMc/1/8Ard62qVK/8h1Rj1W/qa6af4cHzNqJZyc7uR/+ vrn8KnNn4dj2tFcyu3DKqgf16f8A1+9c7q1m7cqNUpdv68ywEkMe2zD/AC8845IyRz07+vbvVPVb +7022klmB24UAEn5s9sc/Tr2qVFTkk92XsrnFWXjXT77V107WbFltXxtw3sCRz1HPtXrGhaX4GsH aeCJlmLE7i2cAgcEg45HX/JrXFQr0FyU3eMkTCXtE21qmdMJfCiAt5hDEYBXOW7E49cjpik+3eEE bah/eAlgWzgD2z1/z9K81rFN2SNLzJl1HwirqoiZhjAypPv0z9OakXXfC1vIHgtpCxJ5Vc5x+n6/ nUuGLldMfvu66llvF+irlv7PkLHquee2M88dP89KpS+KdElUyf2I5JyoZv4vfI+vf+Qpxw9ZaqSQ cr0Vyvqt54d13TLrS9T8Kq1tKuxlbAz2yD7dc5r8/viT8NL/AMI3ct7bQu+gyPiGVhzHkj5Wx3/x r67hbGTw1eWCr1Lxn8Pk/wDgo8LPcE50ViYLWO/p/wAA8nAJLoAOAR3Of8P880mMqYwxO0HOcfX/ ABr9AtbU+QJgoKBs9DyCT24x+NIvD/KeRgAA985xSDUkiXem2RQUPBB7+nTn/P4VWha40i8hurSX aUbdG6nBRqtappkyunc+g7P4jah4m0q0tNXvvNW2w0kLhcHHAbPpx/WvUfBXxE07QI5QQ1uWlDL5 Iyp9+Ofmxz+FenhK3NhJ4Wp1un/XoYSpqNVVae+9j6o8FXvh3xPDHq9jKBLJ8zJwCH4yD6duO3Fd VZa1NFeXcMmg3SNbEK0kwwjgDgjHbGTniviOX6tXlRa+FvX0/wAz6XndWnGa6pGZ4h1ucxnVptJk ezgT5EX7rMehLY4XoTjJ7cdvP7L4iWt+HsfEmnIlq+FjuIFP7lu2QTz6Z+tE8UqVTlltL+kOMJOK 5XsV9f0A6W8c9rGJYSAyup+WeLpnjqQPxwPrXVfD3xiLCQ+G9YZn8O3JURTHOLV36EHspJ9qwjeF Vwf/AA4YiHtaPN1R9Gfs9fHHxh+xN+0L4e+M/guSR9AlkW28Q2CsAmpae7KZEI6bgMshPQ56Zr96 f+Civ7Nvg39rH4T+HP2rPgULe512fSY9TkntwudW0/YCS5XrLCODnkKpBPygHaph4YiSpS2qR5b+ fT9PuOzL8RH6mr6unL/yV/8ABufzaX3gjxDbztBdDEykrtZgMED398Z+lc/d+HLiJN7gMSGKl3/H B4+v05r85nJUasqT3Taa9ND3lKNk47HNah4d1NYYxZwBgX/vjBOBgjuD1/z1S00q8iCC6h8ogAr8 4IJHUgjr6dcVu6tNw0lr2KT8rI1ktpsEoclGyMt2xjoPx9qWTTrolQ7nJAyu7AHfuP8APHvWPPFW d7iduiM46RcMGWWPGRnBIz/nrSjRrscyRlVA4wygY5znnnPJH17Vqqy2uLeyHPpZyh5wMkYYfKPz we31xU8ehv8ANnO0gjBK88H36ds1m6ysmXF6IvDw9JJGGUHI4HQ44x2PGPxpLbRvs4+dQWGec/44 zkf5FR7dapMTlfc0vsduiCPyxvIIAAG7+efeofJtvtBQplk+YALuP1x1/lQpyeq3Idz9Rf8Agmn+ xpN+0b8U7HWfGOlzp8MdI2X+pvgDzoVYiOLJ+UPM4KRggnCTTbHSB1b9OP8Agtr+1nP8Gfg94f8A 2Qfhhdrb+OPGenxLr62C+WujeGYwYILCIIQIVn8ooUHSCAoV2zqa/S8Lgp4HC4PBVfit7Wa7OS5k n/24of8AgTPn8RWjU+sYuO0XyR+W/wCN18j+aq0aw+FnhB9ZuGVtQK7YFOMtIRy3PXBPqf0NfKup 61e6xe3epX91meVi5ZjkKCeBz9f0rycyrc75fmc+WUvjqv0X6nOT6nErDddoU/hDNyCeAR6dz3rL ubqF5HxMCAepzkY6+/f9K8yKknpE9iytqzD1TVINGjkmuXVIwd4GRuH4Z554/H8K8I1vxVbXt3Je 3U4ABGxScHA5CgDnA5+ue1fU8P4R81TEyXkvnueJm+Jioxw8X5v9DnLjxX5cGNOBF0+RGT2ByS5/ z3rknj+UPNgljuYMvMrZ65645/zmvopq0mzwb8ySsZc7jEjKflPAxxx1/wDrVTkifhcjGD1/LPH9 ayK20QoBEZVc7QeSx/yQf8aru2SwUljjoB04/wA96Bk9npurapdxWemafNLduQESNSxJ/wA/4193 /Cj4Uv4G0dLzUrFf+ElmQmeQEOYlJ4iBHAAwCeuTnkgCvneJMZGjhFh4y96b/wDJVv8Ae7I9rJcN 7bEe2krxj+fT/M9InubqEzbbeTy48ZO0ntnt29KbHeTpHHKbWVFzn5lIIwfrn8f/ANdfDezilfmW p9W12JBdTMWW33GM8cqeD+HrVj7bexFY2yFU9CTxjquD+IqXCOo7JEb6nO2YlUkFhkYLZ6enbn9a ge9us4aFzzwNx69P88dz1pxppPYzltsUpr24yUlJyeuWK45+ufTv3NZ15qTLGoiJyOCBJgZ4wfYj rWkad7MUrpHOrd3Uu+WSYoh53KxO7g/X/P6aEepkJuSRhjjBkPTv/n3H4bSgtlHQzTsuaQ1b+Ulj vkAz82ZGHTHPr054/pTJLm53H98Qw5/1p457+nX/ADiqUF2/AzbVmjDvdSlWMSLPlMfdZz17Hk4G PoayP7YuP+eq/wDf5K3VLTRGLlFac35HpAtA6iQwFcMB9wHBzg/yHNbcEB8lflBcHJO3hf7v68/5 zXHUk7bnpJKN2TxieEhljCndtG0KcZHI6e2Pp9K39PA/e7kRVIA+WMZHU8/h9Kwnto9TSz7m/NJc SI5t5AJugOzOAP065qm1pJMivq07SuDv68ZPb1HOTk1gpKN5Je8Va5k23hvw/FdS6jNp6vduxMe0 lvLU8/QHjtwMZoFmJp/NhURrgkK75DZ/ya1dWc5c03otAjCMVaK1N+1sEEMIlgWSQLywQ/eznvx/ +qrD2V0wzFaIrdiwzgfhWTl7zvKxV1ayJRpD3DLFlvK3EgKy4A4HJ6f5/Cta20uGBcPGFI+6S49O O2McD8xUVKia5Vt+IRtqTtaIpYugIxjhgc5/AZ7dvSlW1jjwWtiwyc5Gfl6nj/P4VjzvZMad2Om1 NTmIaQ5KgAKLZ3IxwOgwR7e9c5qfh1dcsbzTbnw1ftaTRmEwrGIgQenfIxg/5NbUHOhJVVUV07q7 7PsROMZQlTqbNWPh7x58GvGfhXUlih0V5LFl3x/PkgZOAeABwPr+deZ3Wja3asDPo9wMKd8ixlh7 jgfTn2r9bweNo4vD061OS1W1z87xOHnh606TWzsYpv7dCPPJjIXo4ZT+oH+RU0dxbyK22ZWz6Pyf rzXac5ZXyQh2ykHnGc89v54q4BA6gPtIIwQAQAP8cjrSu09AeqaMqW4n0RTLC/zLhUcA4YdwR6f4 VRj8dpHK6iSSKMnOAdy4PfH9K6qNRQbUldMxcZPZ6o9N8GfGvWPDV4JNK1JVdmXjdgNjplWH0r6w 8KftU3vyx+I43CHlbi1XGPQEKOmc+ves6uX4HGVXVU3Gb38/kbxx1fDRUZQujrtZ+Meka74f1Wxs vFURlmQywxSAjyuQWznGPlLcc9B1xXi+l67o8nMmvK8u7cysCAD6AEZ75yK8TNclxNCKqUYc6S3R 6mCzHDV21J2fZnuHgXx9pKTR+GdTuw2my820zMc28hOOvUKc4P19K3NUaz0a5e1mOIt5UZP+rY84 A7KeCOwNeI4VnSjUa1i7f5Ho+7eSi9H/AEz3HSdU0fx3oDafNKHvYYArA5zgDDdck8456c1+w3/B Gj9py80PXPFP7F/jrV2jiuvN1fwNPcNuWCcBmurNd3ZxmVVyf+WgGMCu67lRb7a/dv8Ag2c+Xvkx cqD2mmv1X9eZ53/wUK/Zul+CXidfGGiWE7+C9TaSVWQAmGRCBOj4wMqzKcAfddD64/Jq68TafNKg zIWLHPB654XjgLx0/GvmeKMudPG08woJezxEebTpLaa/8CX3WPey6o6lF0nvTbi+/l+BE2v6ZKqn edwcglkOAOcfgOPyrOOp6fK8Be9JcHLEqTk4PJwME9OpxXzUadSNrq538smtTWt77RRJHIbrbsU7 RIrffx94nHPHHfrVg6hoqovk6mis2CCwf5uPpyc9uOg96i1W9nEThJ+7YxpruxLNv1mEpuxhIZMH OMdvcZ69PepbfUdNw2dRDR7QAVickHp1/OtXCVlaDHyy3sQHW9JihiE10ZJVQBmMbKPr7ev4/nox eJNMi3LHCWX724LjOfX8Djp296ylQqvyRXK/Qhn8TwNKuGaOBR0yAWbtzn8cZFSTa5ZtC4tDscg/ NsHGe+fX/PWl7CWn4k8ruZ41rTvIeL7TJHMeGkABb0zk+vSvVvgr8Pbr4geJYLe1iln0pZFE4hhk aW4Yn5Io1QZd3bA2AEklRjLCvpuF8mnnWdYbL5R91y5pvtCOsm/JJM4MzxSwGCq4l7paecnpFfef 2MfADwh4J/Y2/Z/17xD8QruC18NeGtOl8S+Kp7NYmea5SFM2sLhytx5RVbO3CsI5XPmKqNdPn+QX 4hfE/wAY/tU/HX4j/tF/EaRU1zXdSkvzCrO0dhbIqxQW0TMAxjhgjigTOTsiXOTX22MxLxWIxWNf 23ZeSetv+3YqK9D5yvF4fB0MN1td+fS/33Z8o/E7xGvi3X7m3WRV0e3HkwqHCh8HqcevT9eMmvDN Y1TRNISeKa6t0RRnHmgtnp0GT/k18vGGIx2IdLDxbfkvzZ6VN0sHhoSqu2mp5nqPxJ0mFtlpbtcs R8oGeuMdfT/E815vr3xP1FYnia5gtIOm0NmQYHAwvzDpX1WDyKhheWpjZc0+ken3HjYrOKtZunhF ZdzxnVvGxn37HuJ5TnDEFV6noW5/TtXDzaxqk7t9mtduT97G5/zPTp6Cva9o7WglFHlcj3m7s6LT LXU1Hn6jNtDHkMeW/wB7vj/61a5vXu5TFGju20HbEpfGM8ADOP8A9fesW77FKNmaFn4Y8U6kQdP0 K5YMcZkXyxn/AIFg969M0L9nj4peIVj8vSzFHwQdrMQOnB4HXJ61x4nHYPBx58RVS+ZtTo1artSi 2esad+xt4qlCHU7mR5SQTEkkca/pnHHPX1r1fR/2Y9K0EW8N3amSPJ3YIJPfGTk8+uK+XxnFmGs4 4SzevdI9jD5LOTTxEuVdup3th8NdM0J4GtNJ2TKevmAhev4HoPY1tXa6miyxw6c+/wCbhQucfwkf rXy2JxlTH1FVrzV9j6DD0KGFh7KirJ/iZzyai/kRjTmVAgL7FwWbI4z+fA/P15jXr3xAJZF07w1c zbRjJQHceMnr/nmlRpU5TTdRLfU1nWcVotR2kJrszM9zpMsMgYDEkRbORz06YPPOeK6aaK4cxj+z XfkDCjrnjsCR9PpSqKEaloSv53FGpzJNuxFsum2pHpskYXHBV8Hp2wB3PsMfhUdxp+qOhKWrom3k mLlsZ5B3Y6etRdRlacr/ADKvG2+pnP4fvpk8sQTBWJwTDy31K8449e5ok0FDAok0iR5fL27jExOR jvj6fpV+1t7sWl8ybR3ORXTL+MQ2/wBgYIFwMK3T0245xwPetEaZLJG/n2JWQ/dAUkdOh44+nrmt JSu7qW4rJPXYb/ZM3lNiwLTocAiM46YyfT88/wBcq/06MY8qwYuWG4NGwG0H1A9K0hUlzW5vxJly OOu5xus3/hvS50ivV8uLOGaSF1DHBOAcYbqf0rI/4SL4ff8APWP/AL9f/Wr0YYfGVIKUFdHnVMRR pzcX+R17wa2Y123TbS2Thvuk84P8vwH4xG71yxmdC7vGw+V+euc5B/z+tc69jK8Wj03zxtZnTaZJ qzIyvdOGwOegBPXt1/lwfp11pPqEAbf+8kPUbSfbOOCO/SuOrGndxWh0wTW71Opt/FTW8Kq+kRud u3JVjnoOoz7U1/FMjRjytGtgdvBIzkfn/wDW/ryPDyvpUZdu0mc7qOrXs4ErAAg5Com1RntgYz/n p28V8R+PLnRJrCEi5Yz+YUEIZ9nlqDycnknAHbkmvRweGjWkofn5K/6GGIrewp89tn8z1bwnr+pS 22k6w0MwkYZaOTdyeDzk4GOn4mvbY/iLZqgS40F1lA3NtCYzn3HH3vevOxmFcqjjTkk03+ZrFqcU xh+I2m7nUaFIcjkYTDA55B/E/wBKkl+ItxIEjtdDXJH3n5A6dgP89K5Hg6l71KhrboVG8da4zkpa W4UDH+rwenT+dSJ438QHJRIBzgfuQd2TnpkE/wD66f1Snb4np6DUezN2w8b6jbqHvLNGjyQdpIbj qR6dRXRxfEbRSFaeORWHVSOv+cGsKmEna9N6fiJwd9DkfF/i/TdVhFrZWrtv+XzWQLt4Y9Tz2Hbv 9a8nk0i2uUjEsEQfPLNjn/PP5V6OBqYjBw0qNPyZMsPTqRcasEzFvPAWhakzrcaVFIzYUKY1bHPB /P8ACuUvPgJ4K1AOz6NGjd3T5CPpjFfRYbiXGUbKo+ZLueRiMgwlS8qTcfxRxWofsyaYyltM1C6g y5VR52V4ORyePw965O4/Zw8WWeHsdd3qDj96ink++ef517+G4nwNXSteLPFxGQYylf2a5l5HLXnw i+ItmHil02G5i242qcFgccDOR/npXlWtfDi/tmka/wDDF7bvlizQDzUHrgDntXuUMZh8Qk6NRM8i rhq9CVqsGn5nD3HhdIHWMX5icZIE8ToR+fv/AEqKPSNctcGyvMhRkGNz+mDzXVdW2Mr23NKLxB4m 011WRi6Zwd6g5/Ec9627fxud5F9pxCMScxtnaT0wG/xropYqrR+F3XZmM6FOeq0Z1+l+NLQFHtNU MU2c7ZSR1+vA6569q+mLL40WWt6NY6f4ktme8WMwPcwkMJFA+Rjj+IY61VbDYPMKc1FclV7dmy6O KxOEklP3ofoeqfDbx3aWeo2F9ZXYmMbCO6AYDep6HHTkfrj6j7BvdR1rwZ4g8F/F7wBetD4n0e7g 1bTZoiVYSIQwzjkg/dI9CQa+YlQqYaq8PWVns/RnsOtFyp4qk9n+K1P6odY1fwb+23+yf4e8a2UU H2LxHp6XQD8/2TrEKlJo3x0BbzInGD8rZAyAR/LB8YPhTe/DjxfqWj3tq0arIyCOVSGiYEhkbsCD kd+AM1zZnR+tcOVY3/eYaakv8M/cl90lF/8Abx9BRkqGauK+GvHT1Wq/Bv7jxiaBFk+df3QPByee f5/kKSO1s5IWCECQE7lJYFe4GD0Ga/POZ7o9tp9Oo0WjkKCvJHG0gk5HXp1Pr/KiOCCSUeW+xlPz IR0+uPz6/rmqUrJuOwpPoyCWELGW8pXbHGH7Z647/wD1vrWddzxDDNbyF84OHHy4yByMe5/CtYLn 2YrsyROZAyGMvJg7csoH49uvH+NSTaj5OwywfuyByGB5x27c5OfxqlTu0nIalfVojfU0DIHTBcgZ yQD78dvWpLx2i8orlmfAAX73147dfz9DRy2dn1HrLY0tG0PVte1nTtE0nJnuJFQEE7VXqzHuNoyT ge3PGf6O/wDgmb+z5a6Ven4iSaaX0fw7KtnpDyRuBe63IoYXGSMN9kjPn5Vt0c8tkwGEYV+p8GYf +zuGc24glpOrbDU+95/xGvSCZ8nn9V4rH4LLVsn7WXpHSP8A5MdL/wAFqvj7ceFPhz8M/wBj7wpe sNX8RvF4m8VMjN82nwu6WdswHDCS4jlmdWwVaztmGd1fzpfFzxvZ/Cf4YxWkAxrmoxm1t4geQoA3 v+APXjDMtefQovESp0E7czbfkv8A9lHHmtWMMS9LqCSt5r/Nn5f658TpleSJ9RCPjHlQEuR7H0PY bsda80vPFeoXxMtvYsBk/vLolsdgQoPH54r3aUMPg4eywkbd5dWePVqVsVL2mIenRGBctrd7G3mX cphP3tvyIfXgYB/Gn6f4Xub2RobW3eWTnP2aJpMY6nPQcZ7iob3bf9eoJJaRPQtI+C/i3VSrQ6N5 cJ6m4cZH/AUGB9M16XpnwAkRFfVNVZXJw0cCiMHn15P6/lXl4vN8JhFyynzS7I7sNl+JxL9yOnd7 HaWPwS0KHa0OmJIw6meR2JIHq2eec+n8q6OHwedJulhtdNtRITwiBflGByf7v4/WvnMRxBUrtwpv lR7dHJKdLWs+Z9un+Z6NZ3OvaWqvaNYIMHKRRLn1xkDvzxmtSH4j+LoWS3juIhIB02KOOmenX0+g r5qrRpYuTnVk2/Nnrwp06MFHlS+RXufiZ453MVuoiCfvR7Qc/h/PPrXPz+M/GN3KJZLtiGBZSCnA HJ6+tXTwOFpoicu6EHjPxbawiaZ9y4x0zgD6f5/Cpf8AhZOrNGsjrAQc5O7HPAGcc9PareCoy96A m2txy/ErUZNgSxWR+gwOh4zzz0/rVyHx/qjIfN0FiAeArlT6HqP5fzNTLAQX/LywnLtsaNv431A7 caFKxAw3zjOR9eCMd6u/8JXfiOOaXSGBkU4VZAensDkZx+lZ/U10qISdtB48bFCxbTpt23f1HX/9 eKV/Hlo6SRz2kywDBJ+Ug/lWf1Ob1UkF9yGH4i2kDDbaSqxHBIHA/Dnr61Xn+MGlfNbkyNdgcxgA HJ4/z34qlllWpLToKVSK1bGD4kq8isbGcKQcfIB2OTzye4oi+KGnZKyQyAYI+ZVz/n1+lS8uqfZd /mVzpq7LEnxQ0ZCcWkhIAJ+QD9B7Hn8Ko3XxTttjm20uZzyAGUYOenPPeiOXV7puSS9Qc42ueS+K dR1HxiCt7aYtwMrGIyAD755z1/zxXBf8IfH/ANA1fyP+Fe/hqrw1JUoT0Ry1KUKkuZnulpeWlwPK SN0XJwF3Ec9eR65xxWskKyZZGBXAUCXPzAd+3TivHqc0X7zPaVmtC/FDMglBdApUZ+U8An+mQeaf 9qa1585eP9kFjgHsSfyqPi01LdlqWF16yeFxcvGs5IXlsEj1xn+nAq/9oSeOOeGSNkYdWGdoGCAD 9QP51DhKOuthpxsuUry6kwGxrS3PA5YHjPQgn9cVkjUP3rSssQUYA2xFtx9PYcD9auMGtU/6Y0r3 fQ0Rdam0myNImRgT/wAe5yOe3OD9OegFNN/fZ/fToDt5/cZYDPOPXPPFLlh6/MLu/kK+oxw/6+63 n0EYAH5DP/6xzxUltrdqkkqyF/JAz8uTx1JIJ6/h3NW6bcHZEc9qsY30NVtfs4wskcL/AHSWOOCc kf0H+RWbH4qkjmKSkFMFlAHTBHPP1/8A11gqDle71NXUSWhDd+IZ2XfYs4uSoZiCccEdR39Knh8R OxBMR8wfxMDk++B0FafV4pJ31JVRPU1TrhZA5UFsd8MA3b8Oo79ao3Wq28jgyRBsAkAqMH6/4c1M KUotj50tmQDULRsLHpakjvvzj8B7/wAqIrxo9pFrgZB2eaQOeh9OPWlyPVtmilG1xXjubqNI42EL nBY+aT/k9+1bVgZNOgEEtyJjn5yzHqeeB+dRJx5OS2vcq/u7jL26Yjcqx5zk5bvz6d8YHtWLK090 5VraN2JyMnOOeTnpz3/GtKE6lJ80JtMyq0qVVfvIp6dTndS8NQX+Y7mwsjk/OGiVi2R3PGOtcXff BnwdegPPpkcM2D+8gJjyR1H6jj2r6PCZ/icMkp3mvPseDi8jw1b3qHuP8DitR+AkKqTpOuui5OEm USAjJ45/SvNdb+CXiiyPmR6Xb3alS2YHCMP+A5xnpX0+EzrB4q0eblk+jPnMXleLwt5ON490eQ6l 4Nn0+Qre289m44KXER2jrj5l4rIit9a0jdPYSExcnMb7kI9/y7ivYTWjTPO8pI7XQPHNxa3AkuEM VyOfPgyOfUqDz+HvX62/stfECH4leBNR8N6peR3GraawKtux5tu+SvAwQVIKnkfw8dKnH1IYjCt1 F+8jaz7ra34ioqVOpyRfuS6dmfuR/wAEmPi9/ZuufFb9lDXbwi1vYG8UeHo5JWIWVCsd3EnZcgxS Yz2c+tbv7fPwDTxZpd/420m3C30KKt6UXBaRSFSbHUkrhGx6biCckfOVJuCrJfDOLT9JKz+6Sv8A I+yhathcLiV8UP8A212f4H4PTaVPC88M88i3COVdBlcEcEYPPUHpRDpLoMRMoTOC20ncSAfX6fnm vzqU1GTg1Y972iaTS3EbSrrJ/wBJO8DOFB5x6Y+p5+lQnR3jTCSFF6sQPvse/ueAMmq9pFq1tCZT K0ugynczTvt6cfwn27/h3qtL4eViWaM8HJB6YwQeCfr37mrVZLRInnS6FE+GIjjdnHJB6DgZz3J4 HTvTZvCkDAfuzuAIzhceuM+uf8nFUq+pSmmylF4YYSNcQ3RBHy4EYJUc8nOe/Tjp+sz6Q7FwzHBb Hf7vYbt348YFU6nO1oVFn29+y18DfE3iPWNL07w3pyS+K9Ynjgg81QFsrfO4yysSBtAQyHcy52rk qqSSL/W18E/h/wCEfhd4Z8KeDtAkWHwvo9kzTXk6iJrkr+8uLyfqV8xy0h3MxVeCx2iv1PHYyOHy bLeH6KsqEfaVPOrUV7f9uxbXrofI4ShLE5tiMyltKXJH/DH/ADabP5OP2gvizfftN/tMfFT4333m HQr/AFJ49KjmTa1vp9ti3tUPbKwRRBuPmYM3Oa/DT9pnx7qPxT+KOtJYXzDwrph/s+0CMojKRnDt uB2uHfcQTwV2ema58Kr4iV9oJL9P0PKxc1Vqzn3bPFdG8KTXzpBommSXc543xINg/wCBvgH6AHk1 6XpPwh127kC6hcx2p7xxRmWQdMfOeF6jsOprfFYyhhIOdaWvYzw+Fr4qXJRjf8vmew6B8GvC9q4k u7CS7lQfeumyAxPYEbeo9q9e03QbHQ4U8jTbeNskJsCkJjGMYBxxg9zz19PicwzzEYm9OlLlj5f5 n1ODyahQalW96X4Ivz61YJuWRSHwB8u4Drj8jXJ3etW1vctLa2yDJ5Z3Jz649eBnFeLTpzk9Xuew 3TgrJfIZL4ynMTR28YjDKQJI19BnHtXN3msXD/ZGaXDId7ZfIc4yMjrke5710UsMqb11bMJ1OyEi 169UMs8+8s24Nn7vHQk5/IY/nSSaxHwUhkLE/M24DcQe+Acc5rVYflfuoz529ytHrJChCkixgdpM AZ57DI/+v7Uf2qxJ/wBFLIR837zA4JAzgc9Pp/KrVG2zM3PqQ3Gq3UynbGAo+UDOcDt09ORnpWW0 cbq0uz+MEHOO3PHcfr71UIOCvFg22dBpt+lusYcHg/KOMDjB7Yxx+vfNbo15GVY41OM9WGSenJNY zpuUrormSKlzrt8MfZbRWGPvEk4Jx0A7fl3q/cXl1/ZkPzO9zgl8MEUHdgbcYJ9x7URpU4pX3J5r NXOeuLq8V1+zqSxO5ieAcdBjg9+eR061K7ziMBk8yVm3MSQdo4HHIHb3q3GKs+otm0I091I80dsj hiM+YzZDE9sdT9fp9TTTTZhFLM0TNfkAjcVCjB5HB4xkfr9auMlDd7ktacz2RRltr15yzM3mHgE+ wxwOn5VJcWwWNfLjdpAu4c5+br+h/SqUlzJIe+rWhRRbpZiwJzgfI3cc9P8AD6/StIGx2hJJFWQk kdSTj046c9/WiSTd4ImOuj2KrDbteC7Kxn+JjkenTp29qN0v/QVT/v1/9ehtfyX+4SXZ2+87/QoY o3EgizGpw6BQeMAf/X/CujEEr3BWO1IYnKsxYAZ649ent9a8ycrS1PWiklZELR3UjSyeS4jyQhCk b+wOcfpVd7G7IzJCxkUllIBbAbngc/446VN49DWK01OV1fwddarcrcfMp2BH+TdkDPTPTnFeg6LY 3On2Yt7iKRI4hsUE/McbQCcfhW1evGdKNPqjOFLlm5dzcghNyzySwODjClyRuHbp05/WubudOnj+ 0RRQM6nc2MYA5z1+ma5otJ2bNOZJofBb6ksm5bN1kA27mc/KPT1HYdP6Ut1a6pIuNuEACgAjPX0/ L2/Ktl7O+rE53Why13persRK2duWYjeMj9eePw/Kq8WkXTSuocMABn5lz79e+D/+s5rrhOnGOmxj KLctOhdGlXsYHy5XgDLZyfTjnvUq6Tfyq2FTjP3iPXJPB96zcoMvm01LFpp97CJWZkAY5PzHHOOO g9amWxkdwy7QRngDgjp357/yqG1uStWi5HaTMfmkwAc5J9OPXrz/AJFQtZSqZCvIwe4O7pyf16// AF6a5VuguV1szAERickckjqOB/T9TUssQLIY5j5nYkHn6c+me1KSi9kHMxTNMq7ku1HzY7jnpj8y B71YMhaSBp5gCrgqMkZBznjHI+tRyK97Fe0ktjQl1K3jCI0y4AzgqM57H8j/ADrznVPiPaWepLp8 Vj5rMdpcEj8/84rShhHVk4xdiamIVNJyR2+l6ppWpCMxXQDEAtGQQfpgn8ccVvvZWcq7heAOMnGC DzjAzn6VhU56bcXHY15lJKSLC6QpO1E3sDtCKQQwz15Hp2/ClOkTFVj8t8dTwDxyO3P+NQqvX/gE u0k+qKlz4fguIjHfxo8XBbfEGAHTGMn+fevONf8AgX4L1hJJrSFrG9Of3tsdgz7joR7V7uAz3E4N qFR80PPoePjsooYi8qK5Z/gz5s8ZfBHxFoDzztAmoacD8tzaALMAB/EnRv58flq/s1+Mb74afF/w vqMUxOiXk402+X5gu2Y7AXTsVba3Pp719xCtSx2EdSg7pr53/wCHPkalGph63s6ys0ftr4Z8dap8 B/jb8LPjTpu9F0bVobi9CuR51izbLlDjrmF5MDB5A9K/pT+Kuk6R4n0+7W2aKfSNSgW6t5EOUdXX epHqOfyNeO/etfqrfdr+rPqcmlGWHdOW0Z/hJW/NH82v7TnwrX4fePb+6tUMelXjsyr2hcEFhn8i P/rV83RPbQ5Qgsdxyd7cj6f56/n8LmFF08VUjY9hJxXI91p/XyLP2i0YsAfmwPlCr0PXt/jUiXNo VAxKADyqkcZxjOOPbnvXGoT+ILyvuQedayAIID143NyDx/8AWpnlI0IV5SpOOcrz+OPc8f4YoUWm m9wXqUwpMi7QWZTgnanGeMdPb+dSG2kVCFRSAcnLDGO3zdif6UpNaWKb0Kk1sqK4XO/lgAz+w/z7 GtP4f+HNS8Y+KdK0a1hW4R5FDQorF7g5wsSAZLOzEIAASMnCnFduWqFTGUYzjpdN+i1f4EYhuNCp KO9tPXp+LP6Yv2UvhFF8JNCku73S7KTxZONt3cDy5kgYN8kMDDcrKpClpVdt4XarFNzSeoftrfFW f4M/sW/GPXIJ9mv+IbdPCentnJdr4mKZR6H7L9scY5zGPqPuYKdWbq1H71SSb+buzgVGOEw6ivsw b+9WX6H8tfi651Pwz8Ldfm8PR58QTW4tLBVcowmkIQOCoJBTc0n/AAA18ZeEP2a7eGCO88XL9qvg QwiJ2wRHIP3ec/U7j71jjc2pZXhpTetSb0Xp1PncFgZ42rr8EdW/66nt8XgvSdKt47a3t0gRRyIo xnHGPfqM+vNVHutO0rGbeLIyittBIyOCT6ds18NUxeIx03UqSbb/AK+4+wp0aWGgqdJWS/r7zirr UHS+uLrTrtofM5KKqMrYGDgY64IGfXFY11c3NyBvmjLHAz5S8k88+3P9O3PRCMVrJa9QlJt6GZLa zvC9xJMgjHOPKOcDr3ryy+8S31neTW0dh5kBPyMXYF+wOASRySfw/Cu/DU1VbjflOarNweivc2bF p9RhkMkYSfnhi/HcZOevP8u9ao0K4KRlZgAfug5OQeP73FEpxpytYLymrsQ6LJt8v7SocfLnnBOP Un6D/GmNoMsQEjzYhzhWYfT1OMe38qUaq2sRKLjdoxwsXnZEhzgc9h1JHBH/ANfFbEVpmJpWIZ+h x2wPofQVcny2vclb2MiS/ALrNZ4Vep7sR154/l/9et/afmFUhtCFz3bkjvjj/GtHTbTdxXfrc6Cz QTRK3klepwSOe/Ycnn2/DrVoK/lyFSm7BPzHbgDtwfb0/Pmud3u0aL0FhkVUOIo/lOWZXLAdumMj PT8K1JrmOa3ggFvJwD82FAB69MZ/yKnbZkt31ZRZkUGT7OxUDuy8/Un2NKk9sGKtE2CNp/I05KTX xDbXRExuoGKMsEhGcnBXJGM4/TtVz7ZEgVYoJCeMg7AFz3xj8fx9ankl3HpvYxruYnbLHb/MGH8Q zjHOMD0FJcNIUBFngn+6VOD17+4//XVpd2Tre1ijJLPHbF7aycybcgMVwnp35/DgZrz9dM8WNqUc kh22jEbiST+A6ZrpoulFS9q9ehlU57x5UdakF2pCzQgYGQcE7uh/LHNTfvf7kX/fBqGolNN7afI9 htdc0GCNI0mjCM+T7MSDx69un5dq24PFGgwqoMqHAwSqk/yGTnj0rxp0azvoevGV1oPfxV4a+eTz Vzw3KnOe+PT/AOsaiPjDw2khLXahMZBJbOcAnoOc/wBKhYWu7NCc+xBL400B/uzq7jHSNsjuecdO TTB4u0qVBGt8VYphv3ZJHp+POPz9q1jha19V+IlK5J/wl2lhhi55J5whG3r/APWqOPxHps8oVZ33 Z3YK4zzj8PWq9hNdPxHfsi4NStiqGaUmQc84B7nn0BJ9+lDatagZETZUAjjnOScH+X60Km+isTd2 MmfWgr7gr53Z+Ucdfc49cfXr2rCs/FX2u8uIE0u6hEbEeZJGqq/Q5U5ORz3HrXTDDylGUk0rLuZz laSSi9Wb39vBSo8vMecHnkZ6HFLLq0TDC9xg5IUE8D09Pyz7VCpS3LdyI3yyR5MQzjuRg9Acevf0 yP1he5b76Bhg43buv4de/p/KtFTZLlYiE007lvKc5IGM9z0xj9O/86p75QCWG1QD74Pv+vNUoWVr i5rbmebyV3j2yAwnBJyfy6n1/HHvmmyXJdN2x85zzn69B368ciqcGt0Cd3uQSyS/Z5FSOTLA9/mP 0z04z09BTIriYQW/kxu8Q+YZJJORkHHH0/DHXqKLs7g99Pu6E08V0UKqFCgAlsZ5P1z6+w5ri7rw db3N79se7cORkpuXrx/P068VpRrexbaVyKlP2iSb2NmxtFsdnlP84bGPYcc4Jyfy4rWOuXEbCLze BnqSW+h//XUzi6zu0XFqCSbLkPi5oWVZWIYH5lB6/T0+vb862rPxfKfk84gg898nkc+g5zXPPB3u 0aKpHY6W18Q+eu2UjtnIJIGe4x/k1rW+o2Eir57lskqdidDkdcDjiuSVGpB2jubLVkr6bYX8GYJn V2HzeW2OCRyPTjrjp2PFeWeOPg3pPiBv7S0BvsniBchJo1+W4PUb/wC906jnj1r18lzSrgsRGnV/ hvf/ADPMzXLo4vDynBfvI7f5f11P0q1LTrjXPhl4SvdYtl/tS50i3kugDnDyQqx9D1Y8n8q/bT9j rx3c/Eb9kP4eXOq3Lya/4dabw1esz5b/AEUgQk46ZgMB57tX1MrXTj0k18ndf5HjZPNxden1cb/O LPlv9tH4dN4v8J6nPpsAbUo1+02/ABZ1+bAJz1BI+hxX4c/aNQXCsqrjkjYTg9ADnqc9K+ZzfD3r RqRW+j+R9XK3NzbJpMsCS9PkzsR5YGMbF6nGRnH14/wqU3V8WcrCowcfcOQen+P5+9eXGhLszN8t 2myRptScSEBi3A6A7fTkU1pdQIA3KSxG44GPTIpfV2rOzBcmyM37He+bPMt3cI4IHyyHr3GPft/9 erX2jUGcMzM0qsScAZ/Hjrz/APr4odFtq8Nhxte4yRtSJVckAnhSpxjHHY/5Pev1k/Yc+E1tYaPp /i/UYZJfEWqKZYCdiR6fa7mQMNjkyPKoON4Takj/ACuHRk7sqw/+1c1ugpRjUnCn0b/LX/I/bXT/ ALHpltpOmWa8BFyrNn5gAGOR6tuOPf2r82P+Cunjx5P+Ge/gpazMNsd14n1CJWBWQs32S0JX1Vo7 7HtJ6c19bT0cW/N/gzz80naliZP+7H79f0Pxj+IOunSIdM021HSNp5FZQxGPlVh6fxj+teJ6t47v 4UlETKHK85QDHPf8RXxOa0PrGYScnorL+vmGVQjTwMG3q7v8TzS88bapKzMm1jjBynCn1HP1656V x97rOp3DuTI7MegUY69Onv2+taUsJCHQ6Jzu1yjILy9kmLS2rSRsNxDqT/n/ADz62476RDhLL5Mc vhsfl+f51pKmtbOy+RKbabe5HcapeS5gW3UKcKQA3oeuTkn/APXisGaxXE7fZHcAkkBQMe3XuKKa 9nflYSimtS+AYlRfs7Z558vqex/z/SkluJuCkjR5G0YXgEHJ4Prj/PaWnJp7oG0lbYeuqAANnOBk Z+8T3PDcUXF+kyhGl+UryVBHHTn9OP8ACpVNqSdiZarU4+XRY5rwXkd24THMZX5QMdD09c49hW8s bRwKkYRlAy28Zyew/T9PauqdXn5YuNmjCNNxu29WRvZ2ciwLJA/m8ZKNgLn2bPp2Pv3p0VjbKxYl wAehIGPl9x1/z0pc8trhy2Wr2NCK40uH/XRzMg4Pzr/IDHOPzrSs7rQ22BbOR2B5zKMk9xx7g/5F ZThWavFpfIcZK6TLk174ejk3XGntwOMyHHcdOv5/lWiniDTIYmj/ALMZYj90kr144z/npWUqNeor cxTajsRHxZp5I2adHlTzwOuOuMfpSN4j00q+7SQcH0yOfYD6f/XqVha1rKYuboOk1/Q8BW0V93U/ MAcj8feqX9saPKN39lOAP7jjgY6njmnGjiEruYN67FWXUtEcMyWsyqoLfeHBPbP5fl+FS29/okyj ZHOAechkz3I7VahXUdbfiKUrPRFKSTTpPuNMDu77Tj9enT9Kkmks5FzvlDEA8KMH8f8A9fStOWb3 RLbvexkzz2YdnS5ckL3AOfyPv1PcVS+3W3/Pd/8Ax3/4qtIxlbWL+8Wr2Z6onwxtiQRfykBSQGC5 /n1/+vUUnw8hWMIuoMGIJ6AEjjjqDW6oyZ1e2UtbaEM3w9t8bm1FwCCPlXtz79Dk1THw7gYMY7+U lWPJXnt1554H86pUkldIPaJ62FX4axgskt05JyMDZxzyev5fSph4Ci2CZruXAXhQBwP93r/n1p8k HfQPauNk0JD4IifKPeTDB24YgHrn04xnj0z361rWvguCKRpjcSNGVwPmGAP8554odGPXYFVfY7S1 8MWDhSbggdGWRlyCc9PywOO3bNa6eC7eZMqzFenygNke5A5H61zLCpTenoJ4iSu7Eh8DwqW+RmVW PODn/wCv1FRn4dadJvuPLfOASAcDPbj0+laxw6WqTsS8Q7Dh4HtEaBUh/eE8/e6f06fy+tX08BWq I3nWwGT2Trz16ew/I1rHC31jF3F7efRokTwJaKkim0fZjPOcZ9eMY/HirUPw+s9ypHat0yfnxn6c 9P8AD2pfVnz25Hcn28nqmXF8AWy7idP64z1J44HBP+c0x/AFkEBm0oYA27XPIyfTPSm8FXguZwf3 CdeXcqzeArCINt0cCIA7sK2CDjHAOfw5/pVN/BVkseFsE2Ddw2Tkc8Ag++f1rGpTqQ+KL+4qNV9G Z48M2AVom0xVVeM4Y5zwQO3r+dOHg7SpEy2nJ5QBBUIwx09OvA/+t2rCXPHZa7lc0u5MPAmiu6zy afGXX5lbYRgDAHGetWIvBGhNLmfTYzxwBFkY9OTjODWbqVFZJCU5LqX7bwJ4e2gHTYwi8nMEZxj6 5449OuK1YPAGgIhWPSYXO/CqYUO4Z4PT6d6n21WTXKTee9zU/wCEB0gRqRo9uZVGcGJSQO3BHXnF a1n8PdCCbm0a2BJBOIV4OAD0HPTp+lDnWu1rdaA5PqzqbP4e6I5Qx6ZB1zxBz6DPA55FdDD8PdLV mA0eIIAMHyh789PrW0MNj6kVKFOTV7bf15C9pJvd6nQ2fwz0yUqU00MRgY2ZGCeeAufX8q7ux+EU NxHFEmjMMntEeT7fL3r1sNw/neKSlQwc53stIt6vbYiU59xfEPhC88OW7w/Y50sZV5WQHajDgBc4 7Dp7CvrD/gnF4pfTdd+Ofwpu7lWtbyyt/Edkhc8yxnyLgqMnGQ1t0HOK97E5fj8thChmFCVOo0na Sae66P0PNwS5MzcP5lJffFn1B8RIYNX0S7twP3kbFe/fkfzr4Uk+FVrc6pdK+nB7qR/M+SMMZMnO TgZ6/wAq8+rgMVjqtOhg6TqVHKyjFNtvyS1PcxU28LRmjZi+B3mSLNB4cdt3Ab7O2fUjhfrWk/wV liUM+gyDHORbkcYx3HNetHgDjOdPnhlFZr/r3L/I8znqX1TM2f4R2kEb79EcFuW/cYz9eM9MCs2b 4YWRHy6XIHIwp8nJUdM9vQivNrcJcT4afLWy2qn5wl6dhuU92iMfCOHho9FcR5wcwE5PTk4+nOO1 Vbz4RSJCXbQ5gg6sbfjnPt71r/qZxS4Sm8sq8qV/glt32Epz6GKvwikvJYYodHuWdz8xSHn16kY9 +fTNfpT8FvCZ0a0sYTEsZijjUKgwqBV2hV9FUAKF7AAVlHJsfliU8dh5U+dXjzJq8e6vuerll3Uk 3rY+nNJu7aXxZZ2gAIDqigjso3N9K/DD9uvxavxB/bG+IjRvv03RYrTQbcHkRtbxKJ0GM9Lhpz9X +taLR2e/L+bR5+bT/wBlqPvU/JM8J1XwNNqEVvcTRzIAm1naAtg4yR6YyTz9K4XUvhwgRZpbUw8Y UG26j1AI/TGK8vG5HnFOdStPBzSXvN8r+FvR+j6GdBONKEV2Rxt34BtTKUWFRsOWYRYyf59K5278 GR27DyIQB6rFgnPfp6/oK8SdLEQVpU2u9zdSkjKfw2jZkE0o4+b91ggDJ5P09elY83heJRIBNIpP PMYwe38j+vBrn5pLSUCot32Mw6ATkrNKCANm2Mcfrg9ccHv2rHl0S4gQEakwwMDMfXPHIHTgHI96 cXF/YLbbMiaxv8t/p5O7+FlXIORz05//AFVlvZXWCpuHI53fuEx6HBK8HOefpzWsY0+sLfeTzST3 MmfTZ/mLSLu5wPJQ9SeoIyfp7d6ovYSHezeUMEFW8oZXpyOMf/r9q3iqa1t+ZEpVO5ly6I2NglUk Y3CNQM9ct7VA2mXEUczLMuSPusq8cZ44z/8AWz6VsvZy3iYc1VPdkT6XfyDbvUqvzfcQkN25A4H0 9ferlpot9MqiLBUcYKKSCQMjIrRQpW91bidSrfc1j4Pu7qFPOjTbja3ygY544xxx/npWSPAF5ZP5 0GVYcFQp+bv3GM8/rW0IKzi4uzIlOpo+bYjfw9qrTnzUVzlc5Q4OCcdO3FaP2fWIB5Q0yDAKjf5T MVHOD17/AOe1DpQT0uiJVKr2Zk/ZtUkYqlhblS+WVoWwwJ5Ax+FaUEOsBW/4k9oSCAcQHHUc9fy6 nrWcsNTlreV/UccRVirXEk/tFHjY6Ra7geSIn+bqPxz/AF6VSdtQZkYaFaY/65sCc9e/XGaj6mrX U5FLE1e34ED3N50bQ7QqT0VG4GPY8/XiqH268hKMui2wVRgAq2D+GemR+tNYWDTXO/wF9Zne9kTL q9xsYNoFszAj5trgHnnvx/8Aq/BW12T5mfw3b57EvJwOOeDk8ccetJYK+1V/gH1qa1sijdaqCrj+ wLdVPBO+TAx0HB+n5Vmf2gn/AEB7X/yYq/q1kr1X9yF9ak/so/bb9kf9h/VP2wvhz408T/DPxzpS +MNCAnvPDl2rx3ctsB+8lRsbCBhQuSA/zYOUIN3Qv2EPEieKbzwp461VNB1qCRrV476ynJS46KHE auwQEqzMoY7TlQ3GfpcoyihmE6cZ1bXs3t17eRWOxbwMuSUL7ao6/wAd/wDBPy08O+LvFWiaF8SY LzR7bU7u00yd7PZNf2qyEW87wq7GPzEMblcnaSRltpx6VpX/AASc8a6h8PdF+Iknih4tEu554Euh pzPb7o9qlCyuTG4LHh1UEAlC2G2+pT4Xw755VJtKP6v/AC/E83+3ouKkqOumhpab/wAEpNGmvY01 T42xw2bqCJV0lnI45XHnAZx9OR+Nd54f/wCCSPgG+g1eTVf2gvKjjgb7I0OhF/NlCKQr7phsBZgh 4O0Lu712UuGctuudu1n1XyRlPiBpO1H8T1X4Zf8ABF/4La9q9ovij9ptxoEkQWW4sdMjQwTkuuHE 0h2gYDFgDkZ54zXU/Fr/AII3fsyfCfwhZXXiX43+LrLVYr9hd64NEsr7SdRtdsjr9kS2l3xuUNvJ meVON2EwVYen/q7klOjyuk5SfVyt16ab276Wb7Gf+sVSV3Gj+OpT0z/glf8AsN6n8LPCnjS3+P3i uTxBf2dzq8sFpaWFxDZWkrzfYEnk2r5ciog88guvmF0UL5bkfYX7J/8AwQ6/Y5+K/h641nVvj/4i uZI76S0NlbvptvJKY4oJGYCSOQkATJkquBnnk16McnyTAzq4uWXKr7OyUHOVnrZSly2dtL2TW+4v 7erSreydNJd/Tc+3tJ/4N6/2HtJnuZNT8ZeNriGSc/ZYjqOmx+WvGEOLM+YwIPI28YG3gk7c/wDw b4/sKPPqMq6l42EUylYoV1ewxbMeC65tMnnnDE/Sl/a+XRpKjDIsMlrq1WcrvR6+1tprZW00vexs 80xEtkjmLr/g3c/YtTbLbeN/Gkbh1JMuoaeykcZBAtR+HSvVvD3/AAQ//wCCdQ0C2NppesahDeLF Naak/iBGaRDghojHGsUiyDHO1gQQVxwa0wudYXBRlPB5Lh+aTV3KM6m3RKU7JPW+7ts1YTzSu3Z8 t/Qdrv8AwQd/YC1a+hvINB8R2UaRhJIrfWz5cp5w5MkbEN9CB/s1saF/wQu/4J86TbzRv4J1q9ke TzFnuddm3INqjaBEEXbkFuQTlzzgKBnLPaTm6yyrDKbd2/Zytf8Aw8/Il5KJH9o4ly+Jelj1W0/4 I8/8E8bVdo+AcbjCgl9c1bnbn+7cDrnn6DpzWVqX/BGb/gnfqMksh+BrRMZGkAh1/VlCBo/L2j/S OQDmQZyd3UlAEG9Xi3M69N0a1HDuHb6tQX4xpqXTvYbzDEPZr7jF1/8A4JBf8E2V8PazdwfBWCDb YzW8V1D4k1QG3fYwDrvuWjLqcEB1ZcqMqRnPzF8TP+CXv/BLTw9p/h82XgWcapJq9igt4/EWqym+ tJdStInWYeb+4WVJGtYZN0efMVt+7LjCtnFfH2WNwtCV3b+BThv25Ix9b9LW2uiXmOLk7Qlr6HyR 8Vv+CYn/AAT60FtI0E6Ne2XjW207SNL1G3g8Q38pu7yWSb7TeKPPOJFeOO2mjVBDC85UDIU14Z4B /wCCY37NPxKm8Wab4T0S4fVdMjjkS3GqXu688tzBOkZMn31eKVpMbgDJCoADrnyK+HybFYqzw8Fd vVKy/P5DWOzDlc3JWXkif49/8E6P2Tvg1/wjtjPpEEmsPpUEl3aLr148sTuk0kssqLO+x1xEQgwN pQYPzZ+QNc/Z5/ZZsN8q6BCk21fLDatd+VEzbSqjdKWcgHDFj3PHyivBzFZV9YnDD0YtLTRdjsw1 XGzpqrUlZN9lt3PNofCH7JGkPNFeeFpr8sd8Tw3l0FhBYKBlpVDdTnOTlhgYFfoP+yB+yz+yX8YP Fdk5+Ev2+3sEGoanp1veXrvDp8LKZZSYnPB3Rgkd5EQYyMvAww8KtGWHwsXOLT1itou7bTv2Iq4j GxnKXtfdIvG3wL/Z0+Mf/BQf4i+F7H4aaD4f8ERanqdodJgtf7NtbFNI06YAi1t9ioXksjI0aqjO ZTuKszMPQPBXwc/Yk0z4bfFzW/FXwVs28WaPFpd/blfOMUdpc30FvL5+GITDy20YdQz5vowBsD59 qhLCQqxrzoRlUnzN80U797366P5nPHEY2UZSda1ku3U+yP2dvhX+w1qXxx8G6TpnwG8HS6Jqd9rK 6bDquhm8j1CxR5vs72skjSpK6t5QMc0aMEmUgqVCL9O6x4S/4Jx+H/FHhLUfEX7NfhGKC1km0iJE 8MWDpeXirC2XgIC3IWGcTZKyuFkjfoqk+zSzPGwpcuFnyQt8KSS5ne0rJWUldNS3TSs9FblnisVC cY+0d35nT+AvDP7H1hrXj7wx4r/ZL8EabDZ+KbrTV1BNB0yQSWtzKGtbxt8Sy28Un2pYY413bGjK oSqoa9t1EfsM6J4kh0qH4R+CZfEFtPHZlYPDWlBrJd0qKeYw2zMcgUoDk/KOQca0+IOI+Z4bC5pW jBdI1ZxSvZtWTS69P1Jniq9NJzqO+nVn5w/8FnNO+Cr/ALIGo3Pw48E+HbXX9P8AF2mpeXdlYWdp N5UkVypWJkRWnBYrlAf4GYjEbY/lb/Zi8RXPhz9rL4TyoAtvqpvtCuMA5KS2ss6Dnjma2hH48da+ U4kxmNxk6Kx1aVScYNXlJyla7aV229L7ep3ZRW9pjaNTmv76WuvkfqlrWiyjWdatIFYxhwpUDjIJ GOPpX75f8E2/2fvBXhj9n288ffED4SaTeeJ73WLm5stQuNEgutQOmiK2QIrMjSlFmjuGEadeSqlm yyyGeIw7q4vDVHTnZRUk+V+9urqzV43v5XPczes6eX04qVnzP7k2fozYeD/gvHLNYaZ4L8OrcKpd 4ItKtFYBmJOU2A8tk89896kmsfg+IpI7jQtC8iEgPusLcpCW4GTsKrnHtXtyx2cTlzTxVRy31nL/ ADPk/rN95v7yjdeDfgZqRa0vfA/hmcyD/VyaTZS+aFGc42HdjB/Ksw/CT9nW8gM0vwm8HPZ2qOpd 9C00pbAHLLzHhPUg4/w3hnHEFFJU8fWivKpNeXSXyBYl/wA7+9iXHgP9na0spLi8+HHhSDTVKs0l zoNlDF1wpzJEARknDDjng81PbfCz9nnxlo09pa/Dfwne6LJujeOPR7IpnoeAnynuDwehFDzriGDV T6/W0d/4s3r/AOBD+syb5XUf3v8AzPDP2ivhL8GIfgP8WLT4f/Dvwpba9BpyQFtN0mxjltN8kfGY kDIduSBkdq/nesNOOlO0cSc7iu4DAJH4cf8A168jP8fjsfg6EcfWnUqRlN3nJydpRhZXk2+n4n1f DlVyjVvJtXXW/wBxufD9HvvE8U5IwSTyemSByfX5q/n4+Hf2345/tBaZc6hE51Pxr4yjV1gVWk83 Ub5VxGDwTumwo6EkCvl6D5cRGW9nH829fuMM3l/stJPrKT/I/wBAHxr8O/2CbGw0rw14q+D3gVIZ HgjtLJPDunK8vO1QixoDIoKEMBlcRsDwprxr4heDf+CfGs6Vpj3HwO8B3cMOr6fbaVY2HhaxlutQ ZLm1WYpHbFTNAjXESuW/dbUmL74txr9M/wBYeJXC2IzGtKDWqlUk1JX2kpNppatJ3Sd2rO58z9cq 2tTqNfM+W9S0T/gnPpnxQsNB1v8AZw+Hs094Ihevp9vpFzY6OJ5JWjMz20jxJJHu/eZIUptK/uwg T5r+K3wE/YKXXLLw9afATRdOvbwvY3l3aSu/2a+aJ7dVjiLhVSO9MKnBU4kHBy+zjr5jGp7WnVUZ 7XvCN7vd35b37jjXx65f3r11PgHWPgX+yNqdncajF8MbKyt7R/8AT4JL+8Rnd5YVVbcNIZ5dri6T aIwyr5LSNy+3xG4+C37Lfna21h4CspLmLRI74WcviGWJ7W4uLm2jUMonBYRhpsRqxkKukjoEic18 Vi3l8Hd0I6vsv63PSpzx8n/Ef3I53wz8CP2XtU0P4gapq/hFUe10e41Kx8i9uV2TsBBDHueU4jEk 6zEiOV3aKKH92ksk8XjvhX4JfBm90ec614PWa4mv40hktzfyvFCI5nm3eSxRFwsZy4BJJCnhhXgw qYOvh6klRV4ya28l+rOqcsZCcYupur7epLqH7OfwZkilfSNDsZUhmSK4dtTn/wBHZk3MnlqS7upy Djhfl3H5k3e5fDP/AIJ/fCb4pz6PpOj/AAyvQYd0+q6lHqk8VraWpTzBcXU8o8iygVRt812Ch5F3 SEMqJ0YRYCpjYUORPn28ramVStjaVF1pTsl3scd43/Yb+AWhavLpenaZK4WJZVzfy/xRhwTluDnd wcH1A6DntM/Ya+AV8nnz2NwEdnSORdRk2lkVJSAcZOFkUnrw2ehzV4+lgsNXlSjBJrp/TIp4vGSi pPb0PrL4V/8ABI/9nXxvq994ZTStaub5BLiW0upv3YDqitEsioXddxbbIY1JTaT6/QnjX/ghx+xj 4Z17T7jTdT+IM/hfUNIubdoLiW0jvPD+rLGTHLdR+RmS1YiRlaP5B5JRpWdoxLzYfE0YurCdCDSV 03fRrWzs+q0XnYtYuttZHb3X/BBP/gn1o+g6fPqPx28RXGoXaLcx3Nrrumvb29lErTXMzlbUh2Pl m0RFckSOsnzAmIfXf7Ov/BAP/gnnd+BtL8b6lJ4g12y8RaL9q0lz4qtrq3jtrnEttfwT2dvFHNI0 LROoBlgUSlf9IwJn93JMfhPrNKtRw1KXJG75k5Jtvqm7aL/hiKmMrqKdl9x7Zaf8G/f/AATyjd5h pfiiWN0+RW1uDavfcNtuCT7kkdKhk/4N7/8AgnxLIrrY+LVQMSUXWrXa2exzangdq+0WeYKStHJ8 L/4BU/8Alpk8bVvflX4/5nIap/wbkfsDajdXFzFrPji3Vv8AVRRatp5WM4xzusiWH4joOe9Zdt/w befsEWkV6brxN45laThGk1TTFEI6dBZDJ9Oe/SvPdfAe19tLLqXe3v2/9K+7XTzD67P+UqP/AMG1 /wDwT/jitIrXXfH28zKZZf7X0stsAYkf8eQC5OBkBjnHHUjWuv8Ag3F/YQZIorDXfGUMQADb7+xk Z/qfso+vStqeNyzlanlNGSaX/PxPS70fP56/oP67L7UfxOQ1H/g2r/Y1vjmL4h+LIj5m7k2LfLxx /qh83Ubvfp1zyeq/8GyH7KN01udM+MHieDbneZbS0lLZ6YxtC+/B68YqKksiqX/4Soq/apL9Uyvr 3eH4/wDAPKNQ/wCDWn4PzwyG0/aV1BLsuCpk8MRsoXnIIF4CT93nI6HjkY4eb/g1W8IEkR/tUyFM nh/CJPy9hxfj1P5D3rxK2DwDd6WEa/7f9f7vYPrkXvF/gV4f+DU3wdgmb9q19x4AHg0kAf8Agx56 /wCcVE3/AAajeCzCf+MsJDP1H/FG7VGfpqFKODwKtzYV/wDga/8AkR/W6X8rKH/EKB4T/d/8ZZuH ON//ABReQnY7W/tAFu3UDqasf8Qnfgv/AKO7l/8ACI/++VCweBbdsNJL/Gv/AJEX1un2f9fM/mY8 DeK734U67F4v+HGu3ela9Dz5llcupYZztIzhhkZwcjgGv6IPgV/wUo/Z1/bW8M+GPgp+1V4VtfCH xd00QR6J43tIyItQaMDzTdONzqXClm5xu5ylfEcPZrVg1Sk/eWsf1XzPp8wwTxNFprXe/c808b6r 8P7LxxF4a8Q+IYbp7Zy0esQ3UNrFfQhiY5BIzfuA8QG4bmO7dH14qx4f/aJurLwtfeEfCmp6pD4c SYStpL3btCFwMSuq4Vn5ZQSCVCn8f02jVq1Ix5pLlnrby/r8T4GVOKbglt+jM8/Hi6do2nhimYYw jscR4Hyrn7xPTgHisJvjzefapIpL5bdt4AjYFo8nkANyQM4+vQY6j0I0nG75vkYWTdkrmjp37QEV rBL5M+ZV3TN5UhALnKhjgZHAOPrWpfftO6xqvhrUtCtvFs8eiX9t9h1HSnld0uMklljJXCpiOFiq t8z4zkACqeqtKWn9fqTa19DS+FXjzRNS0jTfAtlqCzJNBfJCssqhY2uIZI8yMfvELkZPTgjkceuf s1fEPxJNofxQ8PWviq4W102BLq+sYb6KJosSmJ2yWDS+WUR3Ee75N54289Mpy9nUalul90X/AFYz VpYiN/M+wbb9oPxVaweD7OXX7+C0jQyWuHlGLaLfEAgLbcKfM2kAc5ySQa990n9rrxTN4cuNebx/ q/8AwkWkJ9ijhvp7bbLbsrM4RoIk3yFmC7pwAEiiYO0maJVaVWDjKCb1/HR/fr8yrTi3r/meA+JP jx8R/G1pf3tn48X+3SET7CokgWQGSVpg32lmhmcI6sz4G4xLGiHndf0/9sH4m2M6OsF/qVpbGcCO KeKNp08qLYpM6TLGFm8xlCIGWMGNWQuJI4UuaLUla132Wi026X7a6WKiuVpJ7mXY/tY/tB/8I3de F4dV/tO3cxtBqWpoxGkM5KyQo2fJjZ/LZvtEgBiTfsMStLIep+Gf7cPxkbwFf6edCUX9hqw+1axH q9zA18txGfs0TKzMibTBLlgvKAAbW3yvuv4EozSSco30uul911lq+t/LQhp+1UtfhaOw0j9vL47z Ws/2nV5AlqJBb/6tnmeTCxtM32YEpHz8q5LHaCDkunb+EP20/jt4kTx74h1i/NlaaLoc93bWWi2P 2q/1EpJuf5ZQba3TaFZ7uUOwVHWKFnkGMquFw2to20fld2f3G1NyWsj5Z8F/tL/Gz/hmjxlF421U aj4utNWunkMbzEeXcbShZVKRlNwYsqJkAknlhu+AD+0T8VrLUtR1YaWzbxH5pjSUM6IkCKhBbC7D F5qyAb/MAbd93bw4mCskl0X323/4JvSk1JtdzwXxX8Z/iV4n8Rar4r8TW1013MjCWFJ/LhEm7czJ H5WzY4SE9M/u2HG4k89p/wAWvGdg2o6jf6hrUVjNPYtqxguponl0+OSKOZWaFg8mT5dy5fO9rbnG ePGUVCcXJaLX8TtVRSSi0dR+0ZqPjNvF1r4s8A2TN8LNQtkltbuOOIyZCJFLHOYkWGLM5LRxAZjg ntUYuT5kny1fzeOL/ThLcQu1jEFEztGSsbknYvPBO1SwAznD8cGuF4WnCpNtW5m3950SxVSUYXey S0PKfEFhrM32ASWht2iQxPITu3ZIJbAbg8AcAYC+5Nfpj/wS5uvi3qvx80fw/wCBNfvNPv76xWz1 S9tJpWmTSBdW0l1FbxK4DyuYowpKyFNzSKqmPzE9DKlTeNjGXw/pbX71pc4cZUl7J6uy19fI7bx5 aaz8Fv2+/jbd6vD4htnOp+J5AkhaW+uH1PTb37O1wZIlaSGZrqN5WWMM8MzlCCVYd340/Z1+NOs/ DPxD8SLeN7TQvEeu6TokOnJeXcMlisjWrpFfwNtUwzSXNuyuZJE3wQSHb5kLH0Y4eNVOqtORNLtd vZeVn5+Zy+2lGil3t69D5w+HHiu+8J+K/gtBpgvm0rSNdhnSMXDpIQ15A1xJA8flvA0u2RD5fzAB DndECfuH9s/49W2vfEJ/hn8I724svhhaSwzX/mWkO/UJ1mnd7hI4o1MKeR5AihTaESNBheFGMMRa g4tWvL8F0/r/ADFJ+9GT7XPKPB3j74jfErxB4J8PeIvHl6NOu5ptNurieaV1Nq9vEEmcO+yYQNHM 0MeQA0zjKebuPda1411g6p428PQ6hfx+GPDGrXrXFs1x5dy1m93p0McMkiA/P5tuhcKoQPK5AVTt HTTqwirwW7b/AAWn9eRxzlJyS7fqch8eYPFHxL+C/wATb6FJYvC9t4U03V0MUsrwQPBcS2rCZnLB Gmmsbl40U/euFKtsLCT8M9C1CbQfij8H/Edq2xbHxnokksm3OIWvoEm/ON5B+NeDn7viKUn1j+p6 2TPlqwafwzj+h/QbY+KtP8M+KdJ8QnTI7iGG4E8sEoBSbnPPFftZ4S/4KC+GPHfhm0t/CnhYWeuQ RMghIM0NlnaqusaFTNsUv8ny9cjOMHPJK7mo0Jd/+B/w3Y+n4mw8o0liIPSKehyDad8S/GnhHxRq eoX2pWs19qBtrC3uZjHchY7qYpv8pdsTPCM5jyD5pPzA5budN+G+s6sY7fUNWuBF9rlWKENLGvlx zSGPKbst8u3lsnAQ9AFr7T2kIa9V+lv67H5j7Wbe4+0+H3ii9sjZ2d4406OY208FuViUtDKpU7VG 3IaLdyCfm57iuh0nwf4xSOG6e4uo5Ul8xVIEhO9FEgLvkfMF54PYDaMYUq0He5SqVHuXdQ+Gmpa8 gTWrm8kuIxthluJJJgML1+bhSRgcAcKvcZrb8O+FvEXgiHVF0OF4zeZdpo5f3sCkA7EOMbGZSxBB JLdQMAZSqwcfZu1hqpUTvdny7+0z8apvhd4L1/wbbXMn23W4IpfmYA2qq27YBgd95OByWOOOK/JJ /E41B4IowARnkAc+5+tfK5zVbq3fY/SeFaTWDU292Zz6neeCvA/xI8XTD5NL0O91JGDZDeRbyzYz 1H3Bn0r8L/2YoPK+NHwguYrgwNB4gsLwzoWDwmGZJt6lfm3jZkbfmyBjnFeFSknVTWzlEjPYypUq VOW6Un+J+xXjj4i+N9Jt0061BjtcxfamvbRJ5b6KZZ2zdC5Ey3JX5tguY5Xj8wlSoZkT5o1/4meI NS0L4l3uvSwXupwaDptxbreolxEJor7T5JN0VykyyxySCSV4m2x/vJCoRQYm+7qYiUkl00PhaL0T iz6l8YeEvE3h/wCItj8RPjf8WtTk1m8NrpXhvQNQ1cvrOoXtxp1rOLq8MglXS7Vbi9d3LIXmn8yG OACSa4tfkzxf8Z/HPhHUPEZk12/h8Wakk+jalHHqUojkjkj8u5g8sON6KVjk8pnaItGBtZchlivq 9OjTlS1k1eXr+iWq11e+zR1KpKXLqfI2vfFjXV0a2tIAjsSxZo5Jy0kobbcB2MhOGkRDkAEAFsqT g+b2nja7iuL37Za2xkZebsISwwxIICkA7iwOW3EYOOcAfM4mlTqPVfcejSxFSOzPY9D8ca+3wm8Z eM7O0hhisYLeKe0k1ErLqMKzW0UkgtUUAQpJJAN5K5aWJIllEF08XFaR448d3fwx8VfEC01F9C0i 317SrBVgd4TfRXkGrJPskYEkRLHGjFOcXDZB4KcdHLqPLLW/NJuyVlt+i7GlTHVOZW3skYf7POke PPj78StK+GukXEdz4u1W1c21zc3P2a4lFnAbqaGF15mlmjsGgRW5G8Dje+f2L/ZMtPjTc+NvG2nf 2dpIsfAun6pZ6zq995UIstQsU+y6btuJ5fs0kkl5eCPy/KE+LATJNG7QkKjlbq18PWw9oypys+9p LRemlvwK+txnGrh68nql6f11LH7VXgXx7Pa6f8Q/DPhW0sbi0tLMeK9MtVuBaaM27yC6rJJM5Qlo 2d2wxlu0VIhGm5/zL0v4oW63dydHuUttWVAWtJp5kt752XblSS/ll9o3LtG4lc96xz3BVJyeJprV O012e9196b8mdWBxK5FRqPRrR/5n9SnwF+AHws/bW+GHgz48fsz/ABK8c/CP4i3djL/wkVppt5Jq Ol22pOVMyvaahI0ZXzYw6rB5Y8sxOUXehOH48/a80nSf2iPgd+zJ+0poN6o0/wAVW8fiXVPFdnYO IFig8yw/s+XTrG1UWE92yo7SIwkiVFc7JJK1w0YY3LJZtgcOo1KELVuV/Gorl51DbSStJre8WYz5 ozcHuj83f2pfhH4q/ZA/bc134NRajeWXwD8cuk+iWUU2oXkMtpO86iNIVmkkmuA0rwoSklx56rLC BIIgY/gv/wAFUdX8CTXP7K/xP8cWvhbwb4cliufhh48vtNl1P/hCrqxi2JY30Fhve8s7mFp7UyKZ XgW4JUOvlmHbOcJHK8ynWwitSrRhUtGyvCrFKol2ad7f3l6hKo5Wv/X9IbH/AMFtPjTcXGmm91XS ry+sbh/Pl07TYbex1otNPyYtiyvGQIWB/dNlm3mTCNX1V4A/4LhasIUFreQzztcQhdLv4RNiPy38 1UmV4yXeXywnzCONFfh9y181WqY7DYydajXcldq/lfRtbbWvb5A3SkuVo910T/guE19rtvYeJ/Bl nodgZ4kDyO9yHhPzSO0ihPugqodU2gb3wcotfY+qftM+MfjP8Ev+F4eDvGCWvw/0/T0vtS08aHcJ bXU0nMLPqV29kQkckWEhtRcvI09tK4ltp0WT1sFmGOxWKWHryXJJOzVl0/rYzlGnFJpa+Zhfsyft V+NfiJouq6/Zal4afX7fUmsE0XUPEs9te38EdvDcSrZaeIys8hEqBZ5JAgaN0yoMjjtfEf8AwU4+ CVpa2rHXZorzKJLZx+TFexTZfcklu3mHZ+7wJULBt64HzAkWIr4TAR9nJz5r30s4tNpPfZpb918x Qgpe8zFm/wCChn2rUmXw8um3NrIu+BJLkwTSLjcdiXLwq7fMoVQdzEgCPnNTyf8ABRBNKsrfV9Qi spLBmEUn+kxqbeQZykkYy8bcE/Oyg4+XIBrzo5xjub3Jv5mqo03sdZov/BTv4K3IdtTt7vyWkVIZ oYNkMowN22SdkVmBPKcEArnlgK7Cx/4KM/AvULi6sxPJbSpKYUuLmVHs5m2o3Fxa+ci8OhO7GAwJ 616dPiKpGFq1G8vIzdDtI6WH9vf4FSXiacda3XTSNEHiIkhLBiAA6564PJA6ehBrrZf2xvhBD4d1 XxD/AGi8q28Ek6QW4Ej3IQHGzHOGb5QcdevfG9LiGlKpGFWHLfqR7F9GYsP7c3wFs/A3/CWeJPFk Wn6oqQ+ZpNw0aXKyyxPMqDDsmAkchaQuFQIS5TIFecf8PNf2av8AoYbb/wAHej//ACVXpwzHDypx qOSV+9/0T07PqOOHqS1P87KLTfAt/Yy2sv2hZJBsDom0pnuMHP8A+qug0Dwr4E0jT1iW0uJrgE5n mIZ2PY4J4OADnjp3r8ap4mrTi4ppa38z9HlTqSVrE3ij4p+Jbaw8PWumai5g0ux+wW8Zs4SDEJJJ cyOBvmYvK58x2ZsFUB2Iir4XqP7WnxW8M6z9otra3jib5CGtnO/8Qw6jj06V9HhM1x1ebk67UvJ6 W9DyqmX0opqVNO7v331N+P8Aby1K2Q/a/AFjNORuLb3Xcx74ye9H/DfUc7Kbr4UwA+qXzg+h6j1x 69a9iOaZzH/mJ+9HJLK8E3rSJH/bl0WRMP8ADe8hDHMhh1AfOOgyuOSOPzNWrT9uf4daO1te3Xwr 14zIRIrR6tGAjgcMPlDAg4OQQc9weRvHOc5dkqkG/NMyllGCV5KLVvMg0/8A4KIfCay8SzTWXgDx Na3rRmaMRXtqsUJ24BAOe4zjPf2r3Pw5/wAFAbL4LeN/BHxA8M+F9RvfFM2mz6hqthqixrCsep2s kMMUqxsBKDaNb3sZUhR9ojU52stdkc4znDwcsRKDTSWl9ne5zLKcHUkpUbppvf8AyPTrX/go54Z8 YaVc3fjb4layvi3zmeyury2upZ7eF2GbdnhBQRjc8g2HGWIwNzNXW2/7YHhgSLa6D8RrC4jlw48z UWhG/hiNsxG3A4BJJ+U5JOa7qHEsKUVCtTcbdtVp6d2clbI63NeEk+57xpH7Rmu32n25hurW4Ys8 qTWVzayMQSCwZkclhgEjtXQ6f+1Xq3hvUYy8VxLpk3zvGLR2j+cZKZAAUjgYGACQB2r06PEWAr+4 qq16PT8zz6mV4ui78j+Wp6/4B/bzf4d/E+41/wAPRXdpc3RSe31GCJZX0kFXty3lzK0bOsM00QLr jDqwIZVI5b4dftLaZ8MPGmq+B/GF9qJ+FeqOsc13pzRCa2ihkjnhKttli3oGBkhZsZKZK7cntjmd KpvUT269U7rbuzneHrRlC8X1Xy1PfLf9qXwRouqGz8R38FpLGm52V/MCLuCo6PtEc6kZO4EBiDik 1r44fC/xVomvwarrmm2+sPb2kenTSkGS7LzhZPKlVWEMewyGQsQcBVAILEavHRbknLchwno7HVze Nr7w1o2hxf23bWf2yxjBsoJDJFq1tI6rtLRqVBMYeRPOeKJ48qzfOobXfwrpGkeID4Q8XyQW2veZ 5VwBcRlrW4VFaSHcpILI5RCM4+bgkrUzxEat5N9WVGHI3Jo29F8LfCHWbTUpp7maP7OTHiQAtJ67 QeDjkc4yVbtyea8S/Cn4eQ2GttHElzNNps8Bt1SOSKcvGybCrdB85x0+o4I5pqm0mnqacz6I8x/4 VVbeE/A0NxPr9/o1wTc6bDY30okt5GktZI1jDKuSWVdgG87SmMEKa+YPEmlWNreajpFjM89tHsmR V+8RuRWCr3CoWLE4CCN8cnFcWLpRbjymiqX5nY82uvCyXEWmTXV1C0s6si27DFzdktlZBEDlUY5R W6nys4y6g+ofB3xNo3wf8ZaDrlw96+vW0aXNtNpF3CjWDnY6SfaMsiuiFnwUfZIiK6Eh1GmEao1O Z9P6/AwrLnVkepftSfGPw94d+Nek+PdI1FtN8Na7NFqBvHlku74+VM9tIZXm2yT3XlRxPMZJS8sz u0xjkeSKK9q37RuuP4U0/wAP6BdXtroVm0Gv6Rf7DbXUgVri8splkVRO0InvXn8qSWVd6oB8kaAd PtXFOMdN/wDhjnUOaB4bB8XNN03xk3jTU4omviZ3ntorWF4oppFd0kSKVSIj5rq+UAZCqlCpVSOx n8fabdTXBn06cLfW0J0u5JESW4RYYz+7kQsUaFXjUBkZd6nccFTnz3SVtEDpNdelix4M8f3Phy1t dbksWe6t7vyo7hkbAkiiEZ8twQS2yc5TOF8yN+GSIr6Ynxd0LVb7xfeQtcS3uqtObqSYYa8WazHm yKPnKyrcDzRyVY5JJC4a1VcbLoZyoybvHb/gnoniD43+FdU+DvxB8AaHp94LW68L3QkTzo7b/jzg uZIrdEAIMKzXbXEpOHn8hYwY8O0n4NeML46ToWpa63MlihvYwhxjysSjt6pkV5ebVPaVaDkd+V0v ZNp9WmfuP42u/skphMmFXPtj/PvXo37KPj7R9K+KMFlrfiCTTrKS2uEN1CEMkUnkybGQSEJu3AFd zAZ6kV52WVOWpCXQ++zul7XL60Uvsn7I+Dv2xvhza+AdM1zxH4duW1CNVVbGSBmmuxHPcKpKwAqk zp5EpcAIAZD8qrmvpfwL+1D+z9qy3L3F1Pb3yoLmaa7iKoruykxowOGK7gMjPC5LE5J+ueImrpbH 5PGgou8o6HtOk/F/4BRWWnxaZ4u0ryGZiqGeNWVjliXX7wJJySRyeTyRUkXx5+BrRNLL4r0uFYxu bzLqJAigZzgkcfhWEsS73cjoSoLTkuUI/wBo/wCALJMJvGFrDatJ5Qco3lzNtVuGUFTgHk5wpVgS CpAydR/aV/Zp0cSJc+NbMuYg3lAOTIpAYYU+vA9jwcc1H1qy3K5aD1cWfgP/AMFAfjN4W8ffGqSf wRqay+GBp1qsJClBnb83XnPTIr4q0fVmku1UMOGII7/l2/z9K8XMqvtJ38j9H4fpezwNJWtdHdfE fVRb/Aj41xuv+t8IaxEcHGN9lOmc/wDAutfjX+y/qFp4f+NPw213U1/0Kwvor5sqrBTEC4YhmUEA 4J3MoIzuIHI8ui3zJLrL/I8/ia7rRj/c/wAz9R/EHxc8B+ILDTl1KycPDcxxTK+2R7tg92GlAiQb wn2iJVGXJYCV/lIR/Dj4l8B/2hoV1pmgwanq9vHp6rp+q/Z4tO1R4XY28F4kh2NZhAhmj/ehgzou 0ESD6j6xUik5bHwtOjJO1yp+0P8AEM+JviLrnjLUfEd7qetutlcx6jeWy2E2o3AsIc38tuWl8qWW aNJHQlwoYqCWCyD598eSweJLvQ76BVeWysbPTr17nUHma8ulWUCZRtVyyRKkErfMPMRWYkSgGa2J cm3bobwp2tc821nwkl6f7OsfMuNbit/tEygeVHEirldgGP3qAKkuB8zFlAz8zeV3Hh2Ga4kmmmiy rrGZTC4ZQgDHhAcgjKsAD1U4rnlK9lc3itLs9c+Pfg7w78KvhX4V0LRNV+1nxFDoWsMiTHYrrpjX d6JNvyyhbrVFtYwudiaUpkG+UlvOLnWZIvgz4b+FdvOWtb7VW8VauwSQDzJLVLaziRZgdhtlFxI8 kYi+0PdlZBOlray1tOajFSitLX+bViEru5X8G2/jD4RfEzwH8S7VXt/EdjqNvr1ok8h25BBKNGCG RGzNleCVlPY5P9Lv/BNY+IPi74h+I3xF+LFtqGp+P4bqfWNFvNakih07RrYraWr3tyksUsE81lbR oloJUKWdtBKIgDcrDLOBSjjoSe2l/wDPp37lVFs31/I+ovG3jj4S/Dafxb8b/CNjY39raaRavrkG riBtP10agkw1RUzIbWaK4/dxJLscTPcyuGZCJG/LL40f8E1vDPxi8Hx/tUfsB+IbDUfhVezR3Wpa DNfTG98H3EQkaWAkCR3hT5XMsrArsLH92d1PFYpLGfVaq/d11JXS2qQ2/wDA4dPI6sNTVWno+qt5 f8C58dfshft0/tEfsfeKdV8IfDLxXbafpN+yTX2lz6fbTQz3AQqsjJKUEZAVd7B4yAD1wyn+gzXP 2wP2Yv25vghpnhX9pjwdJH8U4RHPodz4b06/83U53ijJi0yZVNwk7TMsIt0kYPNFG29oxuHy31rE ZFjq1CF3TqKScX0cla/o/tLtd20O2klNqpa0k9fTqfLn/BSXX/jF+0r+wQnxb+Lng2w8Hr4Onitv Cl9e6hHcax4tvZYPLaUJa23lWlsz27TRyyfZxcpExEMO+Et/KF4vudeTTfMZZLi1lf7RDfImVK7A 2Sc8cM7YBOBtNelXqVsTlmCnXmpTgpQVk0uVO6382+3loYTcUly36mB4cudX1G9tbGwguLi6ZTsS FGZ9p+Y8D5iVABwAcA9K6afxRptraWracb2LX4r24mklmlRo1gbyhDEoChhIrLOzy5AYSxgIvllp PL5NeVL/AIBldanZaH8WfFt1cWNnJq089iH4th8iRksW3Rr9xDln6ActgcCv0+j8VeH/AAN+xtqf jKw+MPj6W/1/W4NIi8KQrd2/hqykga4uJjdTsUgv7ls20sUcKEQBpHkZnnVYt8vo0vrkFWj7qUnf s7PUOZtNXPpf9mz/AIKUab+zx+yRc+D/AAn4jsNQ+K+s65f69rGleJdMh1Gw0+VQkFtNayxSRy2l wy28LMJzcglUkTyd7Efm18RP2q/EvxK8Q614q8UarnXL+cXV9LAqBbq4bmSVgvG53LueOTIxJJLE t1Kn1WnQknpzaX0s22rdr/h6CjPljYxNK+N/iOwhhddR2TspjjBjD4TlSoBUqvGMMeQFBByRW7f/ ABt1ySzS3fUmiJXyytuXRY1446nHKh8dAx4AwCPNlCKat/W5op9UcpcfE3xG6Sy2niOdJJGKlg7b tnGM4/hz2HPJ65p1t8W/F1nM1qfGFxFGE2xlXVNhOCG6H+EnpglmBye8tUkr2uW56Jmonxm8ZwNO l34xupoWfc6tMWD5HJOCDzxkcdcV13gz4/aRpsfiGT4neNvEjeBvK/eaLosqNPrdzjbBbJJMTHYq Q0m69ZLjylLEW05zGdIKmpRaVtVrvbzGm1sek+Jv27vF0nhWH4C+G/CGg6F8LYboT3sWj6c63FtK 0cUU8ZubiZrm7MaW6DzLmYysUCs6RxQwweX/APC3/BX/AENmr/8AgDa//LCt6tS1SXJrr16eWnYI 1Z2snt5nhWl+DlBieLSpNpAAAKDBHQfj/j9a9Fs9FuAnl2nglZNvBea5Xrgf/X7f/W/M3KU2+aSR +lp32ZOPBmsXEbRJ4U07nvndjIx3PJFPg+Bc2rCM32g2GxgBgQp19+aj28oS0m9DVKm1rqbMv7J2 g6hJH53huyaMKBwkark4546e3sauR/sO/D28WSe48L6eGOM8gfyIreOZ14SdqrW4nCg4ptHnMv7I vwSm8SWvhWDSdNS963G67k+Uc4AJ43Zz+Qr0OT/gm38KdQsd0WkfI/zfLeuRgHj+vFdcc2xkUm5X 66r7iJUKO/Lb/Ixov+CVnwqvZi8dtDA/I3GYc9+u05rZ13/glZD4rvrrWbnxgHvZtoJ+0oiqqKI4 0REULGiIqokaKFREVFUBQB2xz6q0lVd0YfVcPB80Y6/5nIan/wAEip4VaaLxpGqg5O64Xjg8A7ee n0FfONj/AME+Jte17WtB8LeMHk1SzlaNknRh5pXAJjOPmAyBzjrXVSzaFRvTRK7MpUIPWMSDxL/w Tj+MOjCLyI45kXndvbPf/Zxjp+Z968N1r9ln48+G3nESzJtI5jZ1IPbnH69ec10rGUZPXVHM4Rdz g7rwJ8ftM3i48R6vEgOWxe3S8A8dD265Ppn0rKuk+Mt1GsF/491UxqrL5cl7cYwTkg88j7wI9q1W Mw0dYRsRKhCWlk/uLdv4w+N+iae1jb/EK5ey2kGO6P2gxHOQFMqsU5PQEDnpWpp/xP8AjVpt1a3N v4xtvMjdXiJs4gVIyc/d4IJJH4V0xzJp8yck/X/gnO8BSd1yL+vQ9ri/ap+MFzqlnfavJpf223m8 +F4HeMO+Ry0eNmPlIIIIPOc9+71P9sfxx4r1WTVvG2oXV5q7PJO0q3eMyOcyPv4fcxbJyTzgiuuH EFeO6uvS3qcFTJKbS5Haxu6f+2/4t0SE29p4m1SLI2sXZJS+ck5JOfXnjqPQV19t/wAFFfHJtLax u/EN5JaRKqQebbRbl28rkj73PrmuyHENr3pnFPJai+GWp6z4N/bOTxP4T03ToL6EXtu9z59vIhOx HZ2zs+5li+4upLbh1HStC4/aFGpX8Fxfix86FHhhGFwIyjrjggkje7Z9T07V7EM1w1SMZ33PKqYO tSnKDWxxmq/GTQ7u9+36nqVqkwRVIFxEiqiLsVQAeAAD/nOUb47+AbZ2ub7xXpsa7Nu43iYUD5ie ehPQkY6Vx1c3w+0Xc0hgMQ1dI5f4u/tgfDL4l+DNK8E+KvEA1m20oPJYyaXDG9yZJJWmdmn2AO5a SRTNcSuyLIoRHWIRjwnwl+0xqWlXNmmtPc6hpkIitk827HnxwIFVIzIVAbaoVQdoGMAAAV5uLzyp Tqx9nHTr/kejh8olOm3U0vsdjqH7S3hq9uDDBpd3DGBlS7xuQvZGI2hsdnwM4PAzXS6J+01opNzB qN7ePArk2/mQnZbIERSmT1GUJ4/vAelTDP8AlfvJ3FLJKrjo1c63Rf2tfhtcamulTavNPGsjymH7 oiZgmTt/hPyoxCjJ2j2z1Nv+0n4Jha6lgmdopc7Yngb90m3HBJ5PGOTjk4HQjeXENOHxRaMXk+Jv siyP2gPB2opLpySX5nmjeHCgKrFk29SCeT1+mOM8fMvxJgN94P8AGdooy7abdQEE8rmNlPpUPM44 6UZQ6Mn6pVwr99b7fI/br4j6ms7Szq2Q5JVs54JOK8A0bxYdJ8R6bdGTiO4jdsHBIDZOMeuK2wTa cbdD7fFrnw1u6/Q950n9vf4QWloLfWLLVIoWlJ3xiFTarkFSvGMAbkUHkBELbiCG6u3/AG8/2cYv CIsLbRNTfxFdgyXV5ckG204rKpjW2jUhn/dJ88jsTmViBuVSJq8SwnK0HbXV+XW3n/mfCf2TiY68 lzoLT/gpD+x7p97HJqHhDWPsIvbieQ23nyKbcxBYIAN4cRh9xZsNMVUYfcSVy9Y/4KL/ALIF1rCT vba3NFNfqZfsNmlvBb2obJ8mJlZ8hQoWN2YnLO0hYhhx1M7r3umn/Wvz/wCCbxyuo1Z02mYniX/g pN+xrZpHaaGt6usvqu8veySBI7VvLUwZCkMQA4EhQNvccbV2tzni79uz9lu2uWPhXxPK1q0rfZvt VqYMgIxXjc5GHHXOSG+6CvzUs0xU7KT+IzngXC7VJ2PM/EfxCh8Xa3DrmnuPst7Bb3EJ37hseJGB Ugcg54rrvD96lu8Ugbljn9Ogr1sS3ypPXRfkfY5ZHkoU15I6/wCJ+ptJ8GviejkYfQrtMk44KbT9 ep/zxX5VfBvxVZ+CfHumeJry0S4tbSCfzIJpDGrhkZMlu2M5/DHevLVRwas+v6Hj8RJvEx1+x+rP rG7/AGlfhxdsiXfhywgsknWZms7gB9qhiN7MHaUncTkEbfmwrFgU9Ku/iR+zD4vgsP7As/EU17BI mn/ZrDRdRuBqNxNLJ5EZVLdxLmVWCIo3OVCAhQ2OyWY1nUhGMOdPex83DDXjJrSx87/FPxpouveP ddv7LQYBYZ8qDznFq7kGXEgt3KuqbGTYjqGAjiMgDFs+DX8niae3mNk1ujs7Rx5aN/LUYGTk98tn AHAHJJ43njU5OMrq2hCw+m5K4+y65d6g880WmqlwbPDxXFxkgCHeNyKzbgm+UbSqu7qpZUUngrSr e88Rw23iaVrPw1OqwvdxwJcm2QsqNO6b49235pCisMhAhb5iwf1qmlfmJdORwH7YHxm+Fes/GrUf Anw08aWFz4D8OSTabb62s4uV1MIFj+1eaiANELeC2iSOIKhMTzKhmuZpJMXUPG+k+M7611C18f6Z cafBaWNjGlxewic2dvFHaQqqq5aMLbwwQpHkiPyk2gJtFa4nMaM6nsk9Lf5FxwdaK5nFrY7fxi/i vxf8QBPaWbtod5I8ccyXKMJUf5iCdwIVRsw2CipAgAKAKv7H/Cjx14V8efss/G/wBLqU1zZab4fi 1fVrIyqUnWbXNPtkhnUwGKJQ10AotzGVURylnbzI5dsHiYut7SDunf77Gc6LcoR81+JwXhD9prSL z4qW2r+I9A0oeAodWsrNNOnsLu4tzAt1LIJbp7h3FyjttjuLXbBEYB5MUcKPsPj3g/8A4KC6R8A/ 2iIvjh+zvZXPg6yudTtLfxj4Jtbwz6NfCG5lWf7FM27bbtGylFfeyl2ZSEIjTz8ZXq43DzjTsotp ecJxu4zi+6fxLqn5HQqao1alNvzXnfdHpP7ZFz+x9+1vrFj+1R8Ctdj8Maxqu2Lxf4Z12e3sJ7bV 9jStNaNGXEiyhZR5jKFMqhpCvn8eb/BCXwr4XEU+hauJ9QtbsXK6wNXs2uNI04RSW95EJJJ0t5PM lndCBGnmqII9+LrY3k5jmUsdKEXQcakYJSv/ADJcrafVStfv951xpJRVVzWvS/6H65ftb658MdH/ AOCaXxO1mz8dHxZ45stO0nR7q51fTIYotGt5rxJFEGAi24KwgGUmRh9olUyOpTyf5K/Gfx58F6PJ a6XBavezx2YXUoEjkdJrvzGaYkuC21FZIiWyxeFiMbhj08POnWyfDqjo7yv3TtHqclVTU7SPLovj 14YngvYZfBlr+9GPNWNgYAjK58sjC5wME8/KSQOQVx1+O3g+W5lOoWh8lsYSIkAqBkttwSp/hxu5 CK3QkDm+rV7tmTaS2Ox+G3ifRvHPiGPTtEthGsQM1y7sWCxrgE7Fy7HOAFVWJLKFBJAr2L9o/wDa O8UeKrD4Pfs66J4Pig0HwlbSwW8Vnp1vFeXmpX8waWW+miBaWdkW0i8tmxB5XlbEdZczh51aeMne Xwxa/wDAtPyL5P3XNbVux6nrvx5+GXjH4NeAPhBp3hXW7fX9JmjWC7ttdjawuo1WfLNppt90MryT IzOJgFKzSN5kl07J5a3h4QLmSAKf4tuSQSffknH9TWdXFezp06c37yWr2vq/yuOFJtPlWhJaSxW3 7y3iHl72UhCxAOSTjcTnv1yR9akn1uBVkEgYNkZ45Hbn+VcMq7ehUabT2KU2uwwptil2sV2j5TuK gg5z+HBHOAe1ZD6p5siF5XzjODxnHT06/gOPTFZ891qiuVtaoqHV5H/dRXLc4Vdvf8hx6dq2dD1e z8M6pZ6lc6X9u1ECU6dbtPLClvdsjJHct5JV3MHM0SBlQyxxmUSxh4X6KVXlqRk1fr9wnB7dDOW6 1bRLXU4zLE2QQFkwpgk7Nt4+ZBlRuBAz6kVzf/CTeIP+gs3/AH8g/wAK6qc4ycpT1bfmTy+Z97za jbSWN1a6BYRzauV2wpKjFA3HXK/U+lemfD4arBpMX/CTxQPq24lxBE2Av8IwOpx1PrnmvzZ8rjr8 XQ/R1s2j13T47KVpc6XIABxiBseh5x+Nd1oGkWl15bppFye+4xnGBk8AgY69K5uVtvsap26no8fh XT7hgz6HesxUDc8hGAOOB0H6Vx/iK+8CeEmshrumSRwmbyyN0jkkZzjbnPTrwKlwlzKKtqVCb+FM 5a18Ufs7LeNqKeDxLqEeHEh8xHVQc88jvXs+nfGD4WizSQ+FZjEFziSXJx9Cf0rr5MRLWXayNXGq 1rIv2/xt+FU8oT/hFGO3/axj364Pp361pf8AC8PhcoXZ4VPUkAMOP6/59qPZ1UttRezqbcxpQfG7 4WrGPN8LsGHT51wM/Xvz2rxfwL4r8O+HPGvi7xj4os4p7e/nb7Jb21uga2i3kx/MpBLKm1MnJOCT ya3pwkoyv2svvX6CdKSV7n0ovx++FVzHaL/YV3vkHy+ZEo24x6nHHrXC618YPhHcGX7V4V3oMkfL Hzz/APrrdRqraxy+wb1bPEfEvjH4H6oiQv4CBl+bPyrj9Bz16V4XrGl/ALWJ2t5vh3G0fTIjHUc+ n8q1SxHRh9W6XseM+KPhT8Eb0hLXwZFErnJ45xxxnj1z0rwfxR8CvBN6u3w14egjcMQNwKjGMnJw T79B1rqoqtKSU52JdFqOjuzkW+CPg+KIpfaQwnwCWiUHa3HAzjPp2rgdY+EHhuEyT2ejzeQhAJEK E89+v1/GtH7VStCV/mS6Ul1OC1z4c2WmzH/iSGOIW0lyGkSJFwg+6CW5Y54UDJwa8cujNDmdPBUx GAymSJBjPTJ/DPFdFKlWktZ2Xe5hy3lynLjxL4j0+RXs/DxiZRtbAAzk4wQDnt/j6Vgz+P8AW5ld JdEQOOqunAX65OcfWuhYdyS/ekukk23DUfbfE6dUYz+GoxDx/CcDk85PH/16ST4pWfmlZPC7MshO 4KBgnIyQMZPb8qTwVRv3apNoxs7GzY/FDRYAWTweUYjkqsQI4OeR1PsevNXo/i5piygf8Iy2MccJ hemCPXj/APXxWEsFiJb1b/eNKO2ps2nxf0SOaMt4emIVdvJi5yRjgntgVu/8Lh0BwofwzIOmMCPk HjJ59aweX4i+s/zBQW6Y63+MPh5JEdPD7qc7TtWNSPm74PPX+VbKfGrRi5RNBl4z3iA+pwRnH9fT rnLL8TLXm/MpU+xv2Pxn0Tz0ceHZlYfdJ2ZB6kZBPt+R+te26vfR6pbaiVUFbmM5Azkh8jIxz0P0 5znHNehl9KphlJTd7tHk5nBpwfr+h+tfjjUUHh/RpUk5ktYXBz1Hlqc/qPzr5vtr6O98Sacu8485 d3B4Geeg59fxr6nCJOKfdHt4mVsPF+S/I+EX+LmhQu00mhz7R1wUye4Awcf5HpwJ8W9BBjP9iXI3 jaAdnPfnnHf/ADiviHhK3M7NX+ZzKncvR/FPwmY7p59GkLqQgU7M4xnd9Ocdc5HTFQv8UfDCZMek zAf7PljjGfw7VTw1bRKS/EhwerseYax4ks9T1Ga7trXEB+b58ZBHGf19+lYet3LPa2cbwSJIk6t8 rdxwAf8A9VduFozjUi5vYzqR/d8qP1r0ICDS/BVznmTQdMkyBzta1iYc/Qjn/GvXNE1DeYOcHA5z yB6V9ni4uKj6L8jqy5/u4o674u3jR/Ar4iSBwobTREW9N8sS/wDsw5H/AOr8Y/EV8tl4M8WTYIc2 ToQTkgnC449z614VWTuku/6I87OlfHUv8K/NnxkviTU42dZJLgxHIxGV+UEf7wP6Hp712uk/Ff4i aJqNnr2k+KtWtdVtMG0mtr10a0QbsLFtYBFB3YAAAz0xk15cac4t8srfNnTUpUZ/HBO/l3OP1vxz 4m1i/n1bUNUv3unCLJcS3Ess0iKoRQWZucKoUA5wFUAYAqMfEXxI1u6W2p3SEDht5JXuPlB59eta ShW3c9e92ZvD4eT5VTW3ZFW7+LXiRUEUcl5IFADMZNq5Geeoyf8AH2rDl8b+IZpUGpardPauwLxF Wkj4A7M2D2IGKuNGbi5Tnf5maoUbe7BL5IiXxVYsZIjbkOwK+abOPaM4HIJx0HQVk6jd2pM07agw gPHy20YOT2xn3xxRClUjK7V7+ZTprlPYf2dbzxDqXjK10nwE9xcaut2J4w8SKhHyH5gxCbRsXr/e bn0/c34FfDnSvgh8MviZ/wALK8QWMeoeKtMttLtoHuPMhtFS/glectETJOc2U0A8kPGjMwlnU5if 38tpTlSqS2a21vrY+ex1SnSxCjvqm/RO5474k8I/s2QprzD4qz2uqX372+SK/iiEyFo3VDvhQfKU LYbcWJVi3y4byHUvDf7KdrG7aZ8ZYywdyovNV0V0CDjao3xE4xksW5xgKpG6ueMszpS1pRkv+3lf z2fl0MHPBzTd5Rf6FTRND+HGp3Daf4U+Jeh39yuZo9jWLO6HA+bydRk2rzywjyN556LXpnw/8baT 8KPGvhi/1Txjpd7oUU5lvtH07Ure4uHiddu9beW4VHbcjcYCkwjk/MAsTOri8NUpSw1p2aT6J9G3 ZNamcY0oTTjWuvR/cfpN/wAFK/2/f2OfHH/BMe/0DwD4q0//AIXzfaxpmmaboV1Pdm90KzgMV3ct CLsSTvDvSGN8zNBI8zyxbZFljj/j7/4X18Q4TI8fiixjiJJMX2FQn0AA6cnHbnpWtBUZZThaaptV E58yT0Wqtbft+h1u8rNtf8A3dL/ab+IFsS8l1pTlW3Zksw2WGRntnrn6mttP2ldZm2i98L+Frghk JM9lM0hKjAO7zA249ck5z14JFYSoTTbUpWDlpt2ktToIf2uPiBo9pPb+B9K8N6DqUjjN9pmnMZUA DAACaSSFThshvLLKcMhVhkc14Y+Pvjbw7qN9qGqa7b6tNcBvMa5H7wM33yrjoWyQ2Qc55684+xUL zabm3dt/lYbhGateyPoHwV+2B8OPD1uU1T4UfvnkLGSw1qCAEnO8eX9mIGTjBGBwRg9a9etP23f2 dZU33nw38QxED7qaraS9hyMqhPfg9ePeuaeDrzk5zd790y43jFQjY6KH9sX9lC98t77QvE9u4T5d 1tZygA+mJhzz+uc5rpIf2p/2N7pAj6rrlu+3O2TSlO4577HYn06en1rF4GpLS34lc0lZuK+86jSv jr+xjrUsSf8ACy3tVZQN95o90ioDwQdqE9cnPt6mtmX4k/sgNIkMXxk0592AubS5wTjLFjs2rycc t0APU4GTwVVa2f8AXoJ1Nf4f5Fee8+CniSzgk+HHjnRNQkjuDCyy3UVtI5HGI0l2yOWbADIpBBb5 gRUq+E/FsF+D4c26h4mlgzItpD8umIediYwMlSFDKxbblRtwd21OhyaVJO/n5f57Gcpc+kV6liw/ Z18X35ifWbCXMhzMqx7dwIJOdjoWYknCAoBv++ORW3/wyzF/0Ll3/wCAk3/yxrtoYfFVYc1Onp6H PNxi9ZL5srSfFfVreVYzL8i5B2oMsQR3H179efrUtt8cdb0tk8h/KmlYon7tTnPQ89M5/pXky4Xr LaP4n00c+wiV7v7jroPjf8SmjiltdRjVHAwWjQEg/h9O3vSWv7RnxmW7lsLfX1jljy4Y28QAAIGP u5Jwev8AKrXCEm0ml97E+IMLezb+4uzftFftBhvNj8XDaOBiGHGOo/g5z/U9a8w1f42/FnxuZbvU tX877NdSWpdreNcOpIbjbjHI6jOCPodYcHyU00lp5kLiLDLWPN9x57d+MviNDJLcRa5gKpz/AKNE W6cg/J+RrnW+MHxds4Zri01yVrSOQwSD7JbEoo+YfwZx27+xrqXDE18TS+bGuJqUl1+48n1/9p74 v+Fbm6urbS9Xu5HG/wA2yhsXYoozna2CBjkYB7+9eOa5/wAFGPHOkTxW/iOLxDp865Aa4062j6+x BDever/1Zqt3XK/mxf6zU9rS/Atad/wUd1u9KxD4hXse44YPb2q7uB6px+HHsa2X/bv8aXW9IviB qMkJBCsq2wIHpwprGfD04aSivxLXEVOWqb/AuQftx/EGKHZH8QNVAI4CvBkDjGPlyR6duPrViL9t 3xjf3Kx3nxI1WGMgKGYRkHPXO3tz6e9CyJSa5rfiL+3Yr3tTrof2l/EuoQxzxfG252sMY89F7k85 wSee+fanSftD6/NCy3PxnvB1G5btM54Pc5HXIPc/jXQuH6H8yX3mEuIFq/Zv7zsfhV45134sfE/4 d/DLQ/jc8XiDxPrun+HrGW51BlhS6vZ47eIyOGJVA0qliAxAH4HhI/jTYTRx3i/Hq5McqbtxvpOQ QcfecHnucfXkV0vh/DqlCpz6tyW3a3n5iWeN3/dv7ytN8W/D5jCz/HaYnALBrzPGRxjfyOtQj4p+ CwohPx3uVVyCR9vIyeTjJfoMCpWR4VLWX4C/tufWn+Jc1rxJ4Ht44LhvjLPKgJKs16kuCe/yStgH nvz0xXLT+Pfh1cl2f4rqwbCgOSw98ktx9KU8ooQfLGTsvIFm85a+z/EiTxT8KppF3/Eu3YdcFeST wM5PHamJq/wfQZl+IsCZXBKwgnnkgnPI9j2zWf8AZtKOim/uG81m1rTv8yzDcfBy5CJH8QbIZUg5 iRcj8T+nvxXpV/8ADj4caf4J8B+Oz8QbR9F1qfULSCRrddv2myMBnjX5+dqXVu5P/TZfTJpYChFN yqv7geaVNlS/H/gHVeMvg78HfC2n6JNB8TPNvLq3s5WjbTUVH86xtL1wjrIxzH9shjKlQSWz8uSt cifAvw2t/Jf/AITOMB4hJG0tmVEoP8SHoy9sjIypBwRisZYfCrm/eNIP7SrS/wCXP4lZPB3w3AA/ 4Tm3MeANv2UcN/X6ZPSrS+FvhusjMvji3JVjkLbBcc/Tg8Y/E1n7DBPR1ncP7SxF7Oj+f+RbXwz8 L8pjxhCXLZGYF+bj/wDV+vuamOg/DuMxA+KoBnj5rTkdxj8vpyPSpdDCWSdZr7xPMcV/z5LqWHgO IJGPE1uz7ScJanLEjk+/QfyrKTxNLHBC1vG3l7WiDyKfnRG2BsEfxBdwHoR3o+rUUr0JuWq3+ZzY jE1KzXtIcu9j9gdT1U6n8OfhvqaPuNz4e064LDAOXtYmY/nx0rwi3aOwvNX1yacpZafY3N7KwUnY sMTyMdoyeAhOPavcy5aJSXR/kfRY6o44SL/u/ofIn9s+AYsbtbhKB/8Anl1x7fl69vWnf8JR4FX5 l8QRGP7x3RDgZz/T+navBll+Gu7V2eP9frLV0miY+MvAqKpOs27NkDBTnIGRwKoN8QvA9vlZNdgy WI2K23k98EdcH9az/s6jLR1n9wnj6yT/AHX4mXc+OvA8cMLTa9Esbfd+bdyPTPTt784rmb/x/wCE 5FRIfFNtGVPys0ZJAyAe/PH6iqjl9FNXqMzeY1Zf8ufxP0r8F65ZeIvBnw91qxuVmtW0WzgSRWBD +TGsJPQcbozxXo2j3LLMBHzyBg9/evrcTFOjTt/KvyPWy2pzU430Om+OF9s/Z1+J8uBmO1sWwxGc HULJGwD1++PpX42ahr8RFvbX4UaVLP5M80i5S2UI8iu3pl41Ucj5mHrg/O14uUlC9tX+Rx55U5cZ CyvovzM5P+ECSXB8Saarfw/NHk46DG7Pf09q09H0LwHqeoWVlJ410uK3nnSFpi0REYZguWHmDOMk 4749s157wcFtWepyrMqmjdI7PX/hP4G0Tw/q2uxePNNmS3vbO2VRbRKr/aPt+WLrMwRkawZdnJO9 slTGVrhDpPgwxA22s6O8DNn5/JJzj3b69AB19TUrDxcdazRcswqNpqk36P8A4ALoPggMFk1nSCcF SpEWMg5AHzY/Lr1zSSeF/AM6iQahpEjOMZbyWP8A6F/jnjFCotWtiWSswkn/AAWn/XkZc3gbwVMV X7do/lv94eXbjJGeo3c8L+ntmsqf4c+FrjzkXUtFaH5gPkiA98kH0B+lawpqP/MQN49v4qTOx8B6 Hp/w/v7m/wDC13oqzSoEdZII2R+GUFlU4fAdiFfcmWztyAR6Vq/jvxjrs11qOp69aXXiKZi0l3Pc yzFjgbSElLru4bJbO4EZHGa76GLq0I8vtE15nm4iFDET9pJSUjloQiT3Go63oljq967/AHr2+ldP L5CoVkR0cJkqpZchcDOABTr+e2bS7a00/wCH2gwyxj93GZ8RIvzAbQkCYGdv0568V2LMpxi4uz/r scrwtPnvGbS9P+CM0jXda0ezvUsvBugW9/Ix8tre6lRduP4g0ReTB7FueSMVwPi9Pix4pEinWtPs odyqBp8ksT8ZwBII/MUct8ocDGeOcVy1sdKpDkul38zopUMPCTnNt9rnz7efs3i4uZJbgWhlkJd2 N3cEu3UnJGd3PXPPHNZcn7NNvu+a3tSOSpF7LnnA4/zxWLxdVJNT/BHY3QfRoib9mrTYQB5ERY8/ Ldy8H0+b645yM/nVGb9nmwiYOtgxVSCSt3jJ9gx98fhTWKxTfxKwNYXrcqN8IvCdpI6yx7ZBgfLc BsHnknce1XtD+A2meLJJW0Gx1C6giZopbi2BNvAy8kTTYMcJAz99lzxUrEYy/Nypr8B/7Kt5Ha+E P2MdV+Id/qOmeDNKuNSu7Ar9qFjrOnSRwZAIG/fsJIz0YmvWbX/glh8YtQl8u0+H+pbz90rq2l8+ pwZOT2xx296unj8RLmj7umjvfyIcMKnfmZ11j/wR5/aX1Ieba/CfV3UpkEaro6kYwcDMv/6+R71r L/wRT/aulI8r4P667YONup6TheeP+Wh4/XiuqNevfWcLebYOGEv8ZjeJ/wDgjl+054RtY7/xJ8Lt ZsNMZgi3F1qGmpG7dcBi4GcZPWuV8I/8EpfjL4tMZstEvobVkWVZZpIZCVLBclIVdxtLru4G3cC2 ARXXh44qtK0IxkurT0+8wrTwVD3nUPtf4Wf8EL9cu0ttT8a+Pb+xtEiaSYxxxwKjIWUx+a6u/IGV YwbWJXJVcsP1b+DH/BNnwT8KI9NHiPx14i1uO2aaOxjl8Sas4kdl/dTfZ0nhtWChCpjktiPmDHOF De9Qy7DycfbRUpfle3c8HEZhdOFFWXfr+R+ufwd+HXwi8P32mXV74Wt7hZ7uC5BBSFY/KQ+ZF5cC oro5YD94HIC9SxyPtDzPgL/0SfTPzP8AhX0Dwk6UYQoSUUl2X6nkKsp+9U1Z/BJp+m2d1ezS+ZtB +6WVRwM4HT6evBqnrPh2FNVtnmbeoGQgyctz27d+T0yPWvl7fC9j3UztrQ20UcCtdqIg3yhgM4HY n2x9K811HU5n1y8k03U4PkJBWUH94MgNjHTkfp+NaRd5q+4a7kVj4+vNR068mOiMzpMYM20oYNtL KxwQD1C/r7Gp/CfiSys/D1xZ39lKk63813KxUMGMzDGD7YIJ9q1SaevYnTY1pNd8K6iJlt9SiMpO wpnByfY885rjRHb3dtdlIVEUtwwPzZ3EIoHH5jg96hy1Bbux8v8AxK+DHjS/1y51zw78R762Q/NJ A8hWGJegVVTjGOvGT1Pv87+IYPjTpiz2mu6u91bplf8AT9JW4jYf75jYYPGOepOK5nGN2loz6LL8 ZhFBUa1CMtLO6Wvz0f4nkmoQWhWZdc+HnhqdiASwsntWU9yDC0fJ9/SsWHS/hdaySzaj8K0eAPt3 6frt9DtPcDez+p6g9B26vnxEdOZP1R7EcNw7XhzVqEqbva8JPz6O66G34U/4UJpmvDUb3w54nFsU ZGs/7Wt7qNt3GVDWyscEdd2eD9a6ibw58AbyeSTR/iJ4m05pQF/4mXh2zukUMTwNl1GeM8MBnAqZ 1KkkvaUdP7rsVHhvJ8S74TM3C/SpH9Y/5GxF+zz8D7rTZH0r9sC1Gq3Em5otS8LanbGFcHKhoDOv pyBntj17vwx+xR/wl1u66F+1T8OXnk4WG58QzWUv/AVuYIx0Bxkjv34oli8Joql4PzX6o2j4d55W TeX1KdfyjNX+52Z9nfsJ/wDBOP8AaU0j9rL4JfEizSz1TQfCGvxeMDd2PibRbuC4Ojq+qKoWG8aY hmtFj5jGN2SMZr5j8If8E+/2uPBfi+/tfGf7M3j24t49PZSX8JanNaRNuiwVmSJ4mIUEDDkcnng5 7KipVsFFYWcZP3no9dWls7djxsTwvxBluJ9lj8DUhazel1Z31urq2h8s+IfgV4o0zW7yx1e4v9N1 h5GeTTLiFoJ7UE5AaJyHXAI7Driq1v8ACh7eyuobvU5Hc5YTNE++IDAyCr4xgHjHQ5+inh6tNWnT at5Hz0oThNxkmmc5P8J5ooYWHiebdJEWVUjyBkbuSW4H8v1q/wCH/hTeRXbSy+IDMhj2qssJIXkH I+brx1rCfK4tcpMXJNNHQyfD+5WOcm8iDKWY5gOO4yMNz/nk1zll4faTWvDFzFcqbKa9iPlksfkL 5Ck554wDwK5moxjL0f5G6nzSjzLt+Z3Wt+FXvfEmppaN5dpFHEm1FPB2kg5BAzyPy/CvdvBGgnxH 8LYPhF4q+If9nR6d4lbxBpOrNYNMllHcwwW2pQGJckiRLS0lUgElrQLgbs1ywa9hCc430i/xTa+7 zNqknGvLl01Z6Bq1ncfG7xR4m1Sy8SPoOg33xG1S8CR28Ey6Lp9+6ERIpB/d28dscNtPyoBxwK57 XfCPi/xD4g1jW/8AhP2tLWWd5LbT4NOt3hs4mJaOCLflhGisFUsxOAM5IzWLo4Vr36bfzfZDVarp KMtfRGTP8L/GBm/d/E1kmb5iE02DIHX+vt+laXh/4ZeLbvWIbTU/iUfsKzwmby9Mt1cxMQGAYkhT gHDEHGckGoWGwXWk/wDwJlfWcTvzr7j6i/ak/Z0dv7A0j4IrqFvHBBLPqUmnq975u540gzKzNtO5 ZFZFblgVIXBz4VD8Cvix4d0u1l1PxLdyRxbDLLd6FIkh3ckbi4BwD1Iz04rNU8DKmo1Eua7fxJP7 uw/b4pzclt6aXOxtv2a/2jtRaxl0Xw3rt1pNzbNdLdW3hG+mh8oBCrh4zh1cPkMOCOckV6DZ/Bzx h8P/AIZ+I/G3xes9Q023j1GzsNNk1LSptMSYOZVmXbPklgWtXV8gAS4IyRjTDwwFOpFRmm5aL34v X03vcK9TEVKUuePw67H6afDO+g8R/AfwHNDIWaz057RhzlRDI8YT5v8AY2nt2rwjx1rs3h74W/Fn XLSQZl0xtP3ON6p/aEqaeTgMpwDcjoVI5PXArswcEqlWLVrc35s97FV+fLaU1r7q/I/L+48LeMl2 xp4itmZmO1PsMoAHTnM4Hfrx0qo3hXxw4n26xYooHyFrWdiccgn99jIzjp1JrjeCw73b/C/5HifW p9YpnM3vhr4ixO7Sazp4K72bfaznBUZzkT9cY54x/Libm38TRXjGbVrFlBG/bZXClsk85NwT+Pt+ ekcHQa0bf3f5GUsTU3svxIbfR/HV7FIYtWsDDJuOXspi0K/uwFB8wnBK9Rg8sM4JFS2XhDxncLKF 17StwJBD2VycjHXP2gf3e+OtbPDYey+K/lb/ACM1XqN3sv6+Z+0f7Jmo3+ofs5+Dbe7liebSr3UN Iaa3Uqjss5u9uCWPCXkfBJwAvJHNfVWhxAaxOjOWmlhV9nVVCnGR+Lde/wCFdmIS9hD0R9FlU700 zjf2ufFX/CO/Bj/hHhqCR3usahb25gXBeaCLNw5XP92SO3B7fMPavwq+J+g/EPxZdw6b4f1+Kw0W 2X7QQIRJJeS4K7yegChmUAY+8SeoC+XGFBWnUjfd/kjz84nOeYNU9LKP5XPKv+FO/FGA+ZN8Qowp ABxaliM+2CRgfjzXtvw/+HV5ol14Bv8AxJei7Gi3l/rOsvEsgfU0WKF4ISpXjG2QKvK8s7BQpYTU WFkv3NK2/wCT8+9jzlKq/ildHeeGfhB8Z/ih8I/APwq8N+K7d/HfiTxa8sV/dTJAnl2FvcybJGkI UZbUnO44G4gZ5zXzdrHwe+M3h3XdQ8MzfES0kvLW5ltZjCfNRmibbIUkjJjlUEEBlLKwOVJBBqMP DAeym50rvmf3NtLr5FTqVotKE7GJJ8Lfjfc3Mslt43ggiBG1WZ2z1G7mL1HQE+3aoJfhp8dLeKaQ +PoPJClyfKBBwM8DGSe3+eLdPKnZexf9fMSq4r+e5XPw/wDjhGmH8a2pLKjAeV3Pb7uMj8vrVJvB nx+ll8tdegkZQCCYsf3jjkDup4680/q+VbuD/r5h7fFLRse/hT9oOBgXvbKTLfMNqjPBzz7DisRd I+PIg3i/04KGZAPcdcc49OvtTWFymW7f3h9Yxa0djC1A/HK1EZlv7Xk8bAM+g5LY/Udq52a/+MTO Ym1FfNGGbDlQo9yGIB4P69OK6KeDy1fDcznicQ1rY+mPht8Pf+Em8GaXq/iPVL463LJKZGgumWIB XZQFxnqFOev3jz1rXu/hFZySYi8Ta3EpYnal4uBjoB8meCfT+H8/nq2YTo4mpRVOLjGTSuuiZ7dD BU6tGFSUmm0tn3Maf4UzR7kXx5ryydQReqceg+79ayX+G2qRN+4+JOvFBkDdc9+MY4FVTzOMviw0 GKeXL7NWRmy+CfFsRK2/xL1o4ByBcE88dcEccD0Nb2g+FfE8bsdT8Y6ndxI/3DOwXbjkEEtnsOfQ V0/XKLi+XDxT7nM8HUi/4rPa/C+lavqmoN4d8MeEtNfUFg86e/11JL75DJtGy3/492bK9fLDYIwT k15F48174ka/PPa+IdQ1DUI4y0aJc3TQW6BTt/dwQldo46biPeu7D0VOHtHG7VtbXSvtZd/NnBJT blFdD9VP+CWtmPBvh7x/qnjqODS7G5mW4tWkhW3S6iVAzPGuAZcBTlgG+6eeOP1v1D9qT4UfD69N vPZ6hdahCRBLDHaLatbynJCypeNDIvYlgjABlJwGUngoYGvWxeJcY2Tnu9rWX3lVJKNOK7I5ab/g pJr50+f/AIQXwjo1kQsirJqMtxqEjnadh8uP7KseWKfxybR5jEEqEfhbn9rb9obxxeMt18WdUisE lEkVppZi0yMopm3IZbJYrkqymDOZiwxIQRuXZ7lPLsNh0p1Vzy8/hXy6/M5JVpSulobHw1uLPWfF sh8dQJeas0klncXN7O9w7yECFpPMdm3ZILhgcbm3LjCkfrN4c13w3blLHRVtktxEJPKt41RFaQgk EADPJJGOhB9a9O75uTovu7HlV25Su2z3PxJ4WtNS8E3o0r/j4l2RSAY4OMkj37fjXkiXE9i9jdXE JeW3lSNmeIKhZiRgc5OM5/EYr0cJU0Tt6nHONzpNJuprfTtMeQsHhkLkKCeTnjn6Cuj/AOErn/un /vj/AOtX0Cq8yTX5nDNSvpofyjadpNvJPHeRwYdfl8th8pVT27Z/DNU9es7C6uJJ5t0DBNrsBwc+ 3r27fpXxLa5VofUIyUs4ZLeW2UL5A+US5+Yg8Z6YwK8T1bQJrPV9aUS72MKtlCSPmYj6HkH/ADmk +bni/Uo8o0a91zRb26tllYf6bMChOAMyPj1wMe/ft0r1PSvEmZLixnINvvAb5hjII5wR3wPfkD2r oi04pktFW30y01LU9fuPs6+WLoGJscrmNQR2xznpxz9abB4amguWurS6uIxuHMUpxxjPBGAT/hxz U8uivqGtrGNN/wAJTc2N1I2pxSqxljTfDhwAzqPmU4zgelcX4jvNTW0kiu9NVtsq8xyK2cE87GAJ Bz696jkulpqxo4PVdW055bS3ntCpS1dC0ibgj5XA4BGfl69sfWvmn4hR6RDpkNuILXMmo7iyoi7l 89ic45xtPHQc9KySftIxf9andRlP6pWlGT0cH+a/UmtE0W2t4o7W2tfIweBsBTrzj0yenHerGoeL b7+zbmC1uVeQRYhQHcykA4AHPfHAHb2rot3OVV60XdTf3mfrGpQzoyXljapwM5hjBz9cc9Ov09DX v/7On7N/i/4/ahd6V4Y8KW/lxOkkmo6hdxWFpaKRxvnldEJb+GNQ0jBXKKdrFcqtKM1LmaVtbvbz Po8gx+eVcdRw2XTlKpJ6Jatv+vkf0L/sOf8ABFf9sTwVD4r/AGiPhZb+F/Eer2/hrWtI8OWttqkF zY3t1qNrJpNyZF1CFba6WO3u70+UyyRNJEFcvhon+f8AQ/8AgnD/AMFjfA3jyHw14K8J/FHRUjsJ NQFxD4wj0yxtYIztKSak96lhBIMLiJplZlBIGM46cXldCdLC8tWMVGOrvy2cm5Xd12t3elt9D9Np 8c5vk2IxlPH1IVqsFCnUhL3tnP3UtbuLlZ2W7aex9vyfAL/gsl8GfhDe+JvFX/BSf4VaZ4MktWmv NG8aeK7DXpssD/o89xdaXe2jyE/IAly6s2ADX46W37dvjq+8H3/hfxX+wp+zlrxvFB1HVLv4XDS9 YuSzDOLvRJrDYSO6jqM5PArihmKw9WWGwWN9pFb3Xu3fTXf7k/I4MRn/AA3nt5Y3LlTk7ax92/ey 1jbv7tzjtc+NP7Kfifw/Y6Tf/wDBOGTQddkcLNrXg34k6rLJN/1zs9Wgv0BOeAX7DNcZ4m1P9hq8 bSLHQ/8AhaHhGYbVvG8S+HNI1qLHQtGbO4s3A9CYj3OD0rmrOvUk3Kn84u34bGUsk4Uxsf8AYsS6 U+00pR++Ov4GC/gn9nXXdZNh4H/aP8KXGnlf9dr+mavokozxtdJbaSIcnP8Arsd+lT6L8ANNvtZg bTrbw9rGj2simWbQNX0m8cxKQC0CJKXLAEso259cCuF83OkqjXdS0/G9vxPHxfDOKw0XUw9KNWK+ 1TtJfdv+B7H4z+APhbw/49uNN0Xw3IPDmoS28+jS3qRyMUuI0kSN54h5bPGXMTkdChPI5PNfGf4I 2tnPqGj+BLe2R9M1xtImaKKGJ3lbTreZRJsZ0z59tdoxWRhvm+UkAk6YK/7yFTflbt00a2/I+QxX vQi+VJt66L5nyx4JnGhySpLqKwi5Ertmba0is77gcEZHJ+gIHNfYvwp+D+mePIkv9f8AEP8AZehH Gy5Wy+1NIepKR+ZHnHAyXAznnjnzs0zKjleGliq6vqlZbt+RGDwlXGVVRpb737H1ba/s3fsxiJP7 Q+JPimaQLtc22mWCbhnPAaV8enf610C/s+/sVf2dcQP4q+IgupV+e4gtLBJB8pVRykigrnKkY5HO 7pXz0OOMCk08G2/8X/APYfD+IX21+JpfCDwf8Pvh58SP+Fh3nxs+JGuSLbNYx6ZfabZR2USNyPki gjICclQGA3En2r7Eb40eDJJXkex1GW5ZCEaSJA4BIyMseBkKcc5wK/MuJZLPcasbH9y+RRtGV1o2 7731vb8j6HAYX6lR9jZS1v8AfY9M079qrw5ZQxW03hi8EaLtZpgPnXHTGehIPFfIX7XGj/Ar9rjT PCmi/Ev/AITG00vSr03kSaLqMFtBdMSjYuY2tZvOQGNduWQLyeSQRwcNYSOQ5pQzVSdWdO/LGT92 7TV3r0v33OjHU5YzCzwtlFStd9dGnb8Cb4aW/wAAfh74buPB2lWfiy60qd9y+fqETLA20KxjZbPA 3DBbPGQMAc11tx4A/Zc8WaBfeFdU8J+MbjSbmSGW6Flr9qssiwyxzRj/AI8Gx+9iQnj9OD+k0+Ps VRq888PF82+/+Z5n9jueHWGU9F/w5rr8Bv8AgnrFbl7r4P8AxCJGCw/4SpA456Ef2YDz0x7Y96oD 4T/8E1m8qOT4L/EMkSAKreLYkJzj108EDrjnkivWpeJOHV1LLV9//wBscM+Ga6d/br7v+CS3HwR/ 4JkTeetx8GviLHuQo3/FY2gXBU5OTZADjJ9f0rRsv2N/+CZHiOwU6d8GfiVLDGiq7R+L7ZzGOQvI syex9AeeDzW//ETcFTsnlqd/W3/pRmuGa7X8eNvRmnB+wj/wTxS3iutL+BHxe+wpKLczQ67bFA7h iApNlhvuMCwyAeCRla87vP2T/wDgm24eLT/h38XI3UE749b0x9h4/vWJJzxx6/Q1T8SsDOLlLL4r 5/8A2xn/AKuVeayrRLPgb4K/szfCnR/EGg+ELX4hxaDf6p/aoi1O606cwSmGKErGsdtHtDLFGWGD lkBHeu7tm+A+iNHNMfFaYXYjSwWeW56HJU8c9P5141TxFqVvcp4WNl01v+Z7GHyieEppc6PF/jV4 A/Z6+Mt9oNxqnibxbaQ6fCYbeOGLT1TLMxlk/eMfmfEasVAG23hGM7i9Dwn+yx/wTgmtoL3xZ8Q/ ipDr2xop2tE0V7RuA3yL5O8AY7s3XH16cv40w0q1sxw3uW3TfU8zG5NXqzlVozTk31/ryO60X4Jf sC/DDxFp/wAQfCHxB8U6nqtoJRbaZ4n0azazuHkjaINIyI2Cm8uh2kh1THTNdxrXxF+GvjDSG8Le K/EkV34NSMQSaZdLLc21yA2cmOW1fBDk4jRtm0DPAVR8jxnmeOx+YxxHDleVKlyRXK5P41KTutuj XTp1PVybCYbDYd08zoqUrvVK+jS/VGPcp+ztYto03hrTPD9rBau0kDLobj7JI5BZ4WeAiOVtikkc nYueAMfNHxm+A3wo+LfjNvE+gePNA0CIWixSQW2j3BN5cl5JJLiVkjjBkYMgJ+dvl5boBjwtnGb4 Sr/wvYmVRa9dL2+7e7+8WaYDA1abWXUrN2PE739jqwhUnSvjVojTISqtKk8akEnrkH1P4ZPrXJ3n 7HPiS6sbq2tviX4RaeRHWN5NVeIAkHu0eBwc/h0r7pcS5ZJ6c1/Rf5nzjyrFK+hz7/sdeOd6q3jD wrcXjKW/c66GDDgkgGPcRkk556dT0FfUf2W/HGjxvPaJpN/ubrYapbsxJH3iGK7unQZPB6citXxB llRpKrb1VkZyy3FpXcPzPA/FnhXxL4bnlTWdDubS4WRgpniZFkI5+RiArAZXlSR2rxLTtPl+xSmZ WaLz5fKTbyCrD1zj+vHOc17VGtTqwVSDTT2a1TOKcJKXLNao5LxRaeUjuY2IU4VAuPMduFH/ANfs OfWvN5dLgsIJyUzNJh5mCD5mwATznjjABPACjJr0KcnbY5pK17H1N8JLGOf4faTIjEgmZly3IzM/ A545+vSussvDQvEun3N/rJByO4JA7DjGfz6nrXxeMny4uu3/ADP8z6jCu2Gp2XRGR/wjxTUI4rol o8BSUAAbGOOORz/KsjVPDl5L9ng0i3ke5knCRqseWOc5O0AnPA+mDVYe8p8qRtKVo3eh9n/s7f8A BMz9qz9pyeCL4S/CnUr+EJEbmad7e0ihV+DJ/pLRl0QqQxjD7dwzyy5/oX+Bv/Br5rDeHdNvfjl+ 0Pp+meIWnEtzpfh7R5NTiEPyfKLqeS12SYDA4hkVW5DOOK+xyXKqdT/aMxi+XpGLs2/N2dl8r+h4 2Jx9OLtBXf4H6+/B7/ghN/wTs+ETtcy/DbVPE2o4VVuPEetTMUVW3bfLsRbROpPUOjAjj1r5F/bp /wCCbPhDw9qn9ofsvfs3eHNLil00abJdaZoUbXBi8u0Td5r7j5v+jsTMMSMZ5mZi00rSfaVa7qYa eFpwjTptJcsFZO1t27yfXVvq7WueUqspzbk9z8I/2hfg/wDHDwdJe+HPHz6pZw3MsV0+nbpILUtE 13LEVt02woImvbto1VAI/tUwQKJGz8v/ABX+DWsfDTwb8J9a1GC3x4j0qfVljil3SwKL25tVSZQT sO22ScDjKTIcYIrxaUJU5qk9NG/uQVOlj5sWSRLpUiBVA3LLwNu4ZH49q908Eatc6fC0l+7R28Gx JZc5ZVPmOTtB5OAcDjoKpKU+hhLRHufwf8WwX8RWW8YTqWceY25my3Gfwx+tfevw/wDHf9npJc30 7LgRLnpjAxj6gCik+arOJx4iDsmj9EdK/aA8LaBo1tdSyCaO4s0eRH+b96OCAOnPXHbIrwjU/jo9 7rcthqtzC2hTanbTI8UIjW2CojNED1O1mOW7kE47DqpxlCLk9H07HHZuLPrrSpvDfiuGf+wtShKM jOqFh8pA3YJ+uB+NL/wiF1/z0g/77X/GvRpYuEYWqbnFODb90/k40bWTvuLU2jL5MuVVk2MEY4Dc /wC6cfj6cwaz4gguJfsiwMSQGOcAL6depz79q8R7R9T6FJ9RLOVnjliufLaIAkqRgjk9x9f19q8S 8aTaxb6jO/he1hlk2IHjuXJXbuOQCO+QPXP8oabmmFzw1T42E+o3+peGIwZrl59kNyMxhjuxgjoM 4znrmq0XiW3Qzu9lcW5iYowkTgMox1HHt3rSN1aN/wDhh3N/QPFMcpv5WuFjZ5VYJJkbgNgYADvw 3Xb0rtLHxBZam7E6qiqqb/v8ng8AflxVSsJ6alzQyr2Zkx8xkmKA/wDXRx+JxjPqc1yfi2FZNMun RlwWRgQfvAMuP6dKhq60eugXPKtUjLwbp9pPylzg8cdj7k+mK+V/iFZWQ1ERRTDK3YAjmxggoGYZ 6HqAOBzmp/5eQv5nZQf+zYuP92L+6cV+pZ+D/wAOl+KXxPn8P4kg03TtOfUb+eLYDGhlt7dQu/hs y3EK8AnDE4xzX1hrH7Oeh6ZqGiQ6F4av72Ke48m8mt7iCL7Kny4clk5ByTgV2+ztCLtq9fzRxO1r o9R+A/8AwT10H43eIvGGqeNP2jvBXw4+GOl3v2aS+8T6lDLqMhZEfNvp/mRGZRvCmSSaBGOQrMQ2 P0k1qP8A4Iifsu+EW0Xx18S/iN8TSbYXlppWga3Jp+n3zBWTzLeTSxAFVmUAI+oyLiOPJ+UGvAx+ PS5cPh8O6k7q7krRT3S7O3n9zPreGpYvDV/b4GaVWcJJPZxTWrWujtfVHzT8K/8AgsX8TvBfjLWb P9nDxx4m8A/DyELBo2gnW7/ULi5gh3i0SQXck8XyQ7YiC3lhY0LlyrSHqtf/AOCpv7XHjj41aJ4x +M/jttf+EEsRmk8O3E26W9uigaGKOBQIuZygwUCiMkskjAhufH16+MlhaOLfM0ltpeVrJNLon17H 23C3CcsyxmMzXMLSjCpGU+dtXjJyc5aat6bdWzxD4+61e6n8YPiRp7eLNV1XQtL8QapaaQ2tX0lz NDZrcSpDGxkwA3logYIiKWBIUA4ryDTri5SG0try2RPLM0m5OWUny0Vc9c/L9B82O9cXLGnKUVt0 +8+Ldk7rY9WfRra8k8PmWyt3WCwZ5ZHRFCMhmAOemSyjBPVgVz0FdNP8M/CfiLwVcaxJZXDS2viW w01pIHPlpDcQytLvZWQhhJGBGPLYEeaGYbFEvoYeThUnaWn4PVGTlKmlJPU8y039nT4eat8Svib4 cGqt9k0mzvZraYwq0N/PAyqhjZ42YrIJlGAEyYnUlT8685q37LHhWWydtPmtTcmza9gk8u4hacJt O1P3pXdglwCOQCACTXSqynBOcbp3/O36HdHMsVhakY0m42Ufva1/U+m/FvgPxPe/B3wpo+k/EbVL Xxf4JlIt7mxnmhXUtMuHEaicEgMySImAykKJ5s5zk2PB+g6xrnj210KwS88VeIbvz2luo7aS5lu5 5Ld4o7uWKMthg7CQschW3HtXI62Gw88TUnJQUU25N2ST167WPKxdeeKp0qCp3ak7NLXV3s7euh4t 8aPgbB4D+IE1n4w8GQNqdteiS9069QvuMrCUxMYyHCOT1RgcOMNnBr7E8GfA/wDbR+KGjaTqHwn/ AGapL3TwsIs5JNAtrK1FsfLwYJbvyo9gj5XY23AAAxxXiZhl2BzqlRxGJxTjRSvFqVk1KzT89NrG OFxtbL5zjCC5m7O/S3Q+t7X9kf8Aazs7qysPGHxJ+EvhLU3QyTWOu+KLRL2ONSu5vJtoJs7WcA/M OXUbhkV01/8Asm+MreOE6j+378PrOQKp2af8PdQ1lUPOCJIruANx32e/euDCcF5Zj7f2fhMTiF3h dR/8Ca/Q2q8RYmkr1Jxj/Xmypafs5aXbKsfiT9vzUrkli0p0P4VR2iygnGAby+kI7nPA5PWt22/Z 4/ZysWaW4/bC+JyzBQHOmeGvCkGeT3mikIP3u4/GvoqXhJiZ++sjnFP/AJ+V7flZnJLi+Sbj7aPy VzI1b4Ufs7JIWtP2s/jK4Gd+6z8CqxxjOD9i+Q888NnA6VQ/4Qj9mW08vb+078Z3YKQvnX3gFB1J OFXRmx3/AC5rSPhJiIuTqYGhDtevUbS+TF/rhKaShUu/KIyXwt+zSyeYfj58WZ3ZjzJ4g8GICScH AXQiOeegH6DGbr9holnpN34f+DX7QsuiT3aC5n1z4o6jpt3p6wW7BWt4TplhZMkkkk6Fg7TbhENo j2EtyZn4YwwOW4nMHSo8tGPNJUpzlNK6T5VKTV9eqOvBcR4jEYqlQm3aTsrxsm7X3+R4vYeHfHWl 6rb6x4x/bv8Agnqfh5ZHeaK1XW7Ka5jBQOqSTRSorZXIARuW252kg/SDJ+zZp17LdWv7QXxB1DTH Zlt9TsvF/hma2u1BAYxCXw9yFZShJXIZCucAGvmuG+E8vzvGVMJg6LtGDk3iLpKzSdnBxV3zdex6 eaZrisHShVbtd291XvdX/QrLefs+Bri30z4z/E+V/N37V8R+EHaRjkH7/h4nk/w5AyPWqfxB8M+O vH/gTwnN8Dv2qvA3g+a0u7jS7iy+JOoact9qMgwyXRZYY0eTY+CYbaJAY96pGVBb3M+8OoZDllLP K1OnKh7T2cvYynKXvRb6tpbdjhy/Pp43Eywc5NS5eZJxt1+9knwo+DPxk8Lf2tF8bf26vh7qnhWR HugvgPxj4ZsL+O6OSFA1PTLmNkYGT5QyNuSMqyruDWzF+z3ciIy/GX4nsQFYZ1rwhg45wM6COffG e/bFeZkXBWD4mdd5bSglTav7WU4S96+2tntbQ0xuc4nLpxU5aS/u32Pj74tftT+PvDnxB8WeF/Bv g3T9S8JWV9Pa2V8PEnhfc8UTuEbzXXecoqlmZMtgnYM4r2z4H694Q+J3hjVk+MOuanY6nDOI0stD l8PXSSKUXc00xikL/MuAnlwgAM26QyER+NkvBlLN84pZVly9pVne0bzjayb+Jq2lmd2NzfEYXDPE VXaMbXb21dtlqexXHhL4D7THb/EjxHGVXaFn0zRJNoXnbiMRe46j61g3PgX4Wli2nfGJrcvgGRvA 1nO2B0B2atFx16YPNfZ1PB7N03FYN+aVaP6xPGfGNOPxTj81IrTfDTwdetutv2kbCFPmAWX4VyMA TwOV8S84GDnj0qFPhVosMSra/tL6RcODwJfh7eWyD2JXV5jjryATwOM8159XwnzqnHXBVtO0oS/R Fx4uw8nyqUH87fmcpr/wf8U3yRHQfib8Ob+QMw26jc+JdMOC3GfK0+828ZzjOMjnisCD4D/Fu4jM aXfwnvbscpDZfETVI3diTyBqOk2aDnbwZMH1548iv4d47CrnrqvTX96jdffGX6HVT4mpVFaMU/SS Zi3HwN/adkW8jH7Ost9plvCXaXQ/EWkawZwfvbYrG7mlwOMZXnngYxXzt4h1PVPBE+fF3wr1jRLi ZsImp6fJZyO2duNs8SEnJ25I7Y9q8irwvOMnGhjYt9rNP7nZ/gdNPPqVvepP70XPCd5c/EK71ay8 IeDNWu720sJNSuba1uYhKtrEyRs6JnLgNKg2qC2XGFry+/8AHui2NzJpc+l6pa6gpbzFuZEUhsqA sgZQVIOBgjq1cFPIMQ61TDRxFOU4Wbj1Sezfr0O95xQ9jGtKlJRd1e3Vbnm3jWe38UpbyW8N3FDF vcxSSsdxO3GMZAxg9PxHp4ufAkKQPJd3twse8sFjlwVyQfx6n8q+8yjD1MFg6eHq2clfbzbZ8xj8 RTxOJnVp7O35I8l8TeFY0Y3keo3Zit5SiK0gK78EMc84OCU7HO8EcmvNNd8PMLe6mF5OGKEYMuV9 ucck9D9c/X36MlzLTU86a19T60+B2mBPhlocQJ3KJgDwSxM0hGeOOnt0/GvTrD7JaK4mJ8zzJcKU Py4b/ZHHSvh8fL/ba+n23+bPqMM39WpJLojLtdJk1/W7ez0a2lubs5IhghdnHGBkAfSv3D0X9ki9 /Zs+Hn7InxPh1GF/EeueF7bxjqFvf2dlIYLi8vbqSCOSzIkikjW2Fumy4MrloZmkWHeLWD6HhzCO tia86qty0215u8V+p5+aS5aEKd9b/gf0a/8ABOL9oLRfC/wl+JGgfE3xBZac2l3E+vQRSG3sLKxt Wji863tbdRHb2cSSDeIY1jTfPIwXlmP64+FpdYn8NaBceIbZYdfks4ZL6FG3LDcMgMqqe4DlgD6C vssrrKphnTk/fjKX3Xuvwa+48FrS5vUV6ZJ81ftEfsrfCr9pLQ4tM8c6JEdShOYL+OMCaMYwV3dS D/SvwR/4LUfspfC/4afD/wCBur/D7w7FZRwW8+iSRR7iGjRllWRuuCWllZjwCSTXVg6cateSqapU qiXqouSf3q3zN6b5nyvsz+YfVfCcVrJMyhzMWjdhswEyQSfp27/46OmNqdrpsL2t1Gt4RPdiaVwg V4guxlLcbwVcIRzuIC84ryqck527GM116Hm3hjXb7RdVEkdw6+UAAQDzg49OfpX2n4R+MDzWVnY3 aK+HRnlLH0zjOPc8e1ZRi/aOa3M6qdtT6cvPitZNpttYvAsaQRsQU5kkcjGBknPUj9a8NvfiXNb6 3qEMli8EP2uWYWp3n7OdxJXDHI25wcnPXJzXfaXstd7nLGK1sfTngz4uX2kJCYNU2RgruTdzzz69 Oua9O/4X9ff9BRPzX/CumPs2ve3OCUJ3fKz8aNB1C3ufEmtyWzKym0tznIbJ3T89c9BViWBZL24k aJSBj5doAx+vTn/6/NeXb4dEeqmct4wjsdI8PaxeoPLlgtpZvMBICMFJHt1x+tcba2un/ZrfUI4S rzxKXLE/MPz7f1q+XVv+upSb1Oc1qK23zyIo3EgFTxg5yB16f4CvEJbYTjUWf5c3szAFsnO8/TJO T+X41nKLugv0K0Vm/myO8ReNWO1s5yO+SOT6D0rNtY4JricizjyXk3MyH5sZXg/w8/5waEtUugad SLVWu4NPZfC/lRXwRsNNJIFxkHA2sMdOueM+xz5/rnjHxhYwra614WujBlXM9ldkq2McgSoR24y3 PA71lJST909XL4ZbW/d42Uot7SVnb1TM60+I2jahvSfUp7aOX/n9015FTPbfbu2OSecdBXN+L/Du n+NNC0yfQPEeiSa5BPcyXEKXSRyzZ8vycCXZluWznG1VyCxO2pjVgpJTXK/wPW/1crzpVnlteNdS irKLtP4ouzi9enQ9K/ZZ8EeKPAf/AAsHWPEWjXMGu395ommWa48yOe0eeSe6ZXTcpCmC3JOcYbk9 K+2/iHZ+Mv8AhFdaHgKWOPxO0aPCXCtwDlgobjcRlQTwCc+9evGpSlCnJvmirbdt3+Z83Ww2Iw1S VLEU5QltZq35n57fGj4uaSdV8Pr4n0p7DxpaIFuSZ7YvLIoBDGNXLpk9CwGQxxXtfwq+CfgP9pvw DH4b1DXLjRfHulweZptw8Sj7VFKN8oMbEGWNXKtnIYBuMAmvOqqnWU42sr6feevljeArxxdKfM0t rNXXX7tWd34W/wCCXPx28J+KNO197rS9e8LNazyBI7qSzlcyW8iwOrSRSLHiRonJ+bAU8HoWeAP2 NvE/wz0W9+Lnxx8a6XBp+lxzSafpkF3va7vxGTbLvlEabVYSSuibpXWApHhnDLw1aFCnKFSfxRvb zfT5XPsqXFrWFxOFwvNetHlslrfVd+l9up8kwfAL9oG/8Mf8J3Z+HtTuPCAR2fU1uldMBtnmuQ24 KCOXICgHOec10vhb4Y/EbUrS8ZLbU9T1aFCohtJZFtojv8thJcAgTEHJIhyrIwZZsgivVpYSjP4Y xbtfp+J+eVXicPKdOd1ytr5o+kNL/ZY/aJ8T6B4buZJW0+BIp4zELthtO87cKoIY7TjcxLHHzEmu M8Q/Dv4nfBcX/hDW9eup7LUWtNchlE06xRvYecrK67uV2zktngAEgZBx0VMNhqTcrJu2uhnTlVrV I0Yyd5NL53Nr9m/VvFej/FzxTqV1JcpfNousMsZLyRea9vLwU3DduMkgAbI3Bd3y5I7S8+GniHw/ D8OtNvNXurdfENrZT2JacFtKieWJomJztwRtDbedgYHIyDPsKNPCQcqd7X6erf5GmMq1K2YVnTm7 OTtr0u7fgfpT+yP+zJ8OrbTtS8afFz44S6mkthPoF7oz36W1ouwCG4BmlYTyEOC4aNYGjY85PJ+3 db/aE/ZP+Afgmew8FX+j6Voa7N80DwWVs8m4RgyzTYknm5XBxIWyMuK/mXPsXxNxtmtXC4LDypYK EuXlS96bTsr927/DsvXU+2wlDAZTh1Uq1FKtJXu9l/XfqfHHxt+K/hj4qeH/ABr4g8h2v9X0mSAa v4fskj1P54USKW3us+chQRxsFB2u0SloyTivgN/20ta0TwJonwnbxR8Qdd8OaPGbaGz8TeK72FYo wXPly29oyK/IJxIC2CO2AP6fyvgLD8DcO4T/AFqoPE4iai6cdXCmoxSUHLq1u1tfvufnmLzZ5zj6 sMrlGFOD96TV5Ntu7UdkvNnD6b+0Rr/h83V74D8G6Jol3LmOSXTrFVmKfKf3spyzgsVxubqnTJFU bj9oL4v6uZp7rxpdRoVxstlWMqRyfugYIOc/TFdFTivOPZrD4HloUloowSVv68jKWXYPmdSverJ9 ZP8ATZemxWufHfjK6/d6j421R96glm1OYDcAx4UkdV/AZHsB5vq3iTxFMJ5U8S3r/MjDzJ5SXU/L 97nI4bvxj6Z8rE5lmuMk3iMXOX/bzN6ccNSVqVGK+S/yOah8T3DCP7XrzbWkeICRWdiFUFeQeCWw uAMHJBbbk11On3zXFrJcx6hLJMdzKSvzOuOMjHQYPHQYJzwa4KjqNe9Uk/Vs2VXy29D3fw9qdzLp CDz2ZYi275jlgCw5HOM4xgtnnvg44741eP8AVF+Beq2dv4nTTte0/XYZ7UM8aefbTxyJKgDfeCui sQBxn2r2uF/q8sfVwmNf7qtTnCV3ptzL8UvM2zOU/qVOrR+KEotW33s/wZ8JWv7RfxKgjjsl+J8f kAYKtZ2DiQng/eiJ6Z5z0J+g/TzVPGnws8Zfst+B2tPHWn2vj6wtvtaWkU6LJcO0pFyNkYZgXLNL gBctjoDX1OCyThfBYDNIYeUVUqUWk+Z7q0rK77xX3HjVcxzKpiMLKUW4qab06NNfckzxPwL43vdG 1nw/rD3DTraXscrxHpL5ZVmwOuCAV3Dpn1rwr9tD4xeIPEHjjTNS8PWT6dpf2PElu0qTETByJGyU UqSEjUqc8x18jlmMwjyHF5DjaTmqk41E725XFW/FM9LEqvDH0sww00uWLi13vr+Fj5e8MfFnxFc6 9pGn63eSzae0hWULtAcHkYKhcDHv174r7/n1/wDtPUri80a7azsZGLRxGYHapPBJAOBk46Y6D+E1 4uLwuX4TD+zwVOUJt3bu9Vrp952UsZiq0nPESUlba3U4r4efBb44/FT/AISjXLv9oLSdDWHUGie0 1e2hg8xG2yhw00a7jubYcA7SuCcMK/RX9lH4UeL/AIaanq1541+Leh6tp00IjVra5jJYnaQ3QE4C 9Tk4NfsPAvBnD+Ep4LiOjiIqstUr2te8WtZb/I+RzfPsZWdfLZ05td7aPqmrGl+1ToIttBTxf4S1 6DYswS+EN2mVzwjAA9zwcf3h7mvzL1rxx4usLmzVfEF95E3D+XckFOgODu6jpgZr5rjulUwHEVZ4 HFP2dVc65ZOyct1p5pnflWJWKwFKVWkuaHuu67bdOqtqc7P8W/idp0Uy23iXU2uSzCFIrhpGf5hz hdw5GeDzgZ9q6nQPj98TWu/7KHibVE1ASMGLTMVJXO4BmbBXp+8JAwc9wT8tTzXPKN3Txk7erO+d DA1FeVCP3I6HVP2lfjDp4WaLxZfIoH8ahgGAwFJbgZ7HnOB61Lp37ZfxpsiVm1xJWDHiW3UEYODn genP19RXoUOMOIsNHldfnj/eimYTyrLav/Luz8m0P1z9qnV/G0tnP4n0RJdWgZBDf2V7cW11CqkE xxzRSKyK2MNtxuHr1rlfiHrnhL456NpOj+Mvi74/sIrCSW6020u9dl1XTdMuZMb2t7eciSMvhdzi Tc2xQcgAiq2b5Hm1WGIzXARhXSt7SCS+bXfuwp4TF4aKp4atzw/llv8AKXZW2Z7p8CvF/wC0l8FP A/j62+HPj/RfHvgrW0TS9SsLzT401OWJEOxA95FJC8eyaUSQGRdwljO5sYXpvhx+1f8As9RXOp/D j4vfDO2g15NSDWUNzus7/T5nkR9yFysMcSMqgCGUkghxHu3u3wHGXhvmmX4Z8VcO1m6VdqSaWziu VK38rSenU+kybP8AB1/+ErHxScE1yvzd76db9UfSvxo+EfhTwRo1prvh7W5ltp7YXK2N1EJpIlJH Blh3Ixy8a8BlySd+Oa+OtS1mwFvLb2UzvfuwiRVhZ9rscAEcEgbssARwOOlfO5FmOIzLCc2Kp8tS MnGVtrx3a8vJhmOFhha3LRnzQkrruk+5XvPg74+8U6Z9n0HwbdyeW6Lm8UW7KgPJzcFWbpyec471 3ujfsUeOfE7PFrPijTtOtpB85hWS6kiGTxsAjXuOBI3Hcda+mhOMLOR50k9kfUXw3/Zb8N+CtA0/ w3f+IbvUmhDbpliS3V2dmPKfPgZbj5s8c17jovwO+FmllpU8EWc5Jy7XMZuQxJHO2YsOueg7/THL HA4f2s8Q170m3/wDo+u4j2SpQdktPP7z2rStPg0+0trTS7ZIdPQbY4YEREUY42quFHft6+tfVP7S nxx0fxZo3wk8Ox2FpFoHg/wnovhJXyP9OubO3LXMqMxyX825GTnkAsSetenhKjpTqKC+KDj/AOTR f6HJJtvU8nl+K93NrfjfRL/yn0mTTruCVC7osZlt/LRt69WWVoim75XdUUghzn+yb4T/ABq8M/En wX4c8Rw3kaXF3ZxTSJkYDsgLAc9Mk1rgK31bE8j+GS/K3+ZnJ3R0Hij4qeE/DA2XeqRCcglVJzvP ZQB3Pvjv6YNnwX44tPE9o1yZ1BJyoyBxXszxUVUjFEB46+JGg+BtC1DWboS3UsMZdLSzjaWe4bsk aICzux4CgEkkAAmv5z/+CnXxp1b4lfEPQfDk9okWlWFq0f2ZZVljEm4l/nGVc/7Q4IHGa3+spRqR g9XFr8iovldz4Q1P4E+Dr7wHPr2s+H0h80BYpvLwXIHy5B5xk9B9K/NjWPh1e2+uXehXKvNZ7HW0 dHSOOD5yQ7rtO/A3fIpU7mU5KghvKw1WooTc3te3ohtqyPDPFfw41PQ73ymtzMnQSRAkMeeMDnJz +v41Y8I6RqN7rul6RDNtVpVd8t8yDIyOmOAAfr+Jrto2aUiajVmz3LwNq/m+ItWjNwYmtlzDdyO5 EcqDJYlQTxnPAJ4OASa8BbxffW+p3ksWqlHlLOylQyksx6E8jPPrnNejUajSlb+b8jCMbyl8j0nw /wDEycRWsGpSqwX92vzcgMeDnsRkHHsfeuz/AOE6sf8AoIv/AOBBq6VWPIuZXMKkFGVkfJlr8LdD 0CJxo093ZzfKGNtdyoHODxtUgdT+tYWp6Lq9iLCC28b60s0syrn7VkY2kkYIPp3OcV5jV2rPQ3i7 7okv/DnimXTrzT38eXc8NxGYpFvLaCXAbIOCFU9/XoK4l4/iKlxcWsWs2EtrbkRqJLKSPcoVTwVf 5ucjvyv5aNPuJNLc5+81XxnPGJ1ttOdy2zAeRQW574IAHH41wUcXiCweY3mmBp3mkkJhuPkyWJAH APtg8c49aGne5WrK6eIdQImMujXbMGZGEZQkHkHHPPT3rOtfEEqpJHc2l0i/aHO17eUk5YkEbRyO fXrmosr67Dt1Mi88QWxRp2vAE2FMFGUjpwAfrivRJPFWlPalI7+J3WPcSkikAAYORk4IyOvPHTii S0Er2ued+JU8N6nc6TbyWlu26KUsUjQHH7vgkYPfjPXBr5c8f+HNJ0m/uNTthILt5FhyHcoqkg7c MSv6d++KjkTNqeJrUWnTmzqfDOnSaD4T0/XrHxTqVpfzagsBNrdvEIbcgEFQhAZiQ/BGMY+lfSEP jbxZYWol8F/tFXNzpqffTVdLDtCCM/M5Qt39ccfSj6vFawbT8j36fE2MlTVDHQjXp9pq7XpLdfee U+K/EXjXXrq21vWIfBviS5scSW961oomiPIyJEw24YON2QCoIGQpHidz4j8TX3ia38WJZahZJCy+ c2j3EgeGBAQTE6LuiyWyWO7r7YONRTXu7vcvD4jAOqsVh4OKWji3eOuml9e+h+hPg39vG58N+M9K 1u6Ot2/hZWWdtJOrOftNuMERvu2gB8YJ7bjyazfgj8ZdF+J3inxTZ/tJ/FBNT8KwWkcdhZaskEFk MyrIXCxhYVIMS5YAO52DcQuByYKNSGIVTF6xV/vd0vW1zsoYGFZVaOFSdacbRu+WzWrfa9tnc+5b b4c/scaolrYw+LvBkNhESq2un+M9Ot4XmPSWQW9yBLMAzgSMSVWRlGAefZfCs/wS+G+lSWWh/EnT LnSraJoYNP8A+Er0+7igLEMxTfMSDkNk7ucnIzXufWMHRk5SsnbX/g2Od5JxLXoug6XtI3uleLs+ 61vc9U0f4w/DZ7NIoPFWkC4CNs26nZurHtu2y+/17dq5jXb74W+OLTSY/FL6NcTm8UbmubWSOGEO ZCDuY8SInlkAdZcUp43CSWlRdN/xMaPDnEGGrwqywM04vm+G+q1W3oeg+Fvhr8AbzW7NdF0bTJNQ uEa2hhtZ4jJLLIREscYQg/MOAnJJPHBCj57/AGq/GOo2XiC0+EvwQ+C58QfFPw+5sdU1q9lWHwz4 MhWCCdLaa4tpSbi8H2kGWyPktAFUDzXkkjg66HNmElhsPNXs23paK6yb7K/37XPCxuGxGXu+NpSp vtJNN+i6n5r+L/hr4Pg1PxH4s+O+vv4u+IOooiTXVuzWunaXswVigtR/x8IP+ekp7jEYbc1fOGr/ AAk8C6xO13o+nxCLLBZLYhSrdSMDv7V9jwnheHXTllmDornp/aa96X95dteh89m2IzC8cVKT5ZdO 3k/X/gH6i/sqaTrl34LtNIneaSG1UIjTJg7R0HT04/CvTfjF+zx4Z8caPJqmpCDS/EluuYdWLKij GWxMTjK8tznIySCOa/cM3ybC5xw48FmFl7t1J/ZaWj1/E+Dw+YVMFmbxFJ3u9Uuq7f1sfmdH4Tk0 a/udGl1hJDbnylnsrjz4Jtp3B1ZSFZCCSPXocEYHRaVoKs0KrIfOwduBwwBJJHPOSQO3Q8Gv5Krw VGtOkpJ8rautVppf0P1KM+eMZ20aua91bWq2k7xopc5AJXJkJHBB6jGW46cdOK8u1a9l1FL2C4jM VtIyYVDjcQCgZs54OHYnoC3GAecbWv8A0i1a+xDa6RAXt5UUMZRlSuSWXG3AAAKgZOevoOpNVk1e exDWtmmLNI2VmIA3jL7vm52jHGe2M471lKLe5V9dz1XwDqXl6DMzCT7CZ5I2CncTgAOMYGeGx1JJ U845rlPiXC/jXSJbTUGCwv8AvwmEBGwMwUnHLcZGMgngDLGnSi41OfodlWd6agux83p8HbWK4t0u NLCwurN5zAPGh+fG7Ax/Ay5TqQcZKc+06DoMej6XaNc6aywIsixqYz5bBclthJIYKORkscHrk89F Wo5XSZyQTg7npdho+iSskn2doxgpKE3YkzggZwcfNgkEj7vH8Wa/j34b6TcyQagukedYNZJEGuEU i3nGxpmRY2GPvu4VzghWPJBUYQTh7wTm5LlZ4tN4RttF1NbEaBati4RZpLVy+I1cszQsHcovLjGX O0lm3Ebl9k8L+TpmqJb6q+zSrVJls/IjjcxyBRLHGc+W8i+dDb7+CgUk7Wbapir+9d3rb1HTbjF3 e52k2hWeo295c2KfLOzLIoZQRtDSEZUfPgEl3wAd3KgblHT+E/7J0nTLW3tGVp3Zp2ZEVT5kjbtx C4ySCnOP5LU051qa5VN8vqb0mnPmsrnJeNtXgn1KRxsMDxtIsS+buHPB3ezY+XPQgnqoryLW4LG6 mt4I7NpHU4lk/hA5Z8ADJxlTkEABDkHnGvPOespXsc9TScvUyRBpj2otksWSFE3+asmCQSQSBkqe Qw4PqSfTmdd0VNPaQWClkBLybHJxsAd+wyMKW78A44xlR51oJWaubWiabLqMcQm/jzBKvlkxw5LF idgIXcME5wTtIxkCqniDwdFayywxIDMmG+6dpGdxyT0HGeBxzVX+zYlHk95oV1byTvaSsWQsMk7A RwD0znrgAD2rvPhp8MvEXxL8UWPhjTFSKSSP7Rc3UynbbW6MiySbByx+ZUCjGWZVLIMsvTgMtnme OoYCiveqSUfverfpuRXxawlCpiKj0im/+B8z9f8Aw98NYvD2jafoGl2X2bSLWEJCuMAA5JPHJLEl yTyWYk8mvzw+OvwQ8Ial8QdS1rW7IXV3OY2WJxhSAGBIH8XI6E/kK/qPOMpwdLIY4D2adKmopLyi rI/N8vx1aWNlU5/elf727mv4R8DadaX15Y+A/iNd6b4pNoEjsNSke+0yc/eEbRytvt85yGjYbA27 a2cV91/Cv9mjWxNoXjq5sbafXIIJ9QutHsJJLmO5vAzmKSzlKq0saQ7XYNiQOrDa0fzD+T+J8Flm ExOIqZfHltO04paLpz+i2fbc/T8HiK9anCNd7pWb6pdPU9wP2pJ2TaEmYcx45Q8foMcD0zXdeHLW FIEaecAs4PIOce/vnH514EYNWdjrlO2h08LW8YkcQhpZeVYNjPPBAHpnjtx6Vo6NPeTqySWgiQHK Eg5dQO46j2HHviumMLK9zPm1sdnZgTuVEoigT5zKFG1VHLN246n8K+FfiH41uYr+08zVHlup3N5I ZJCzHzGJQsT/ABHPOTn5RnnFddCneMuVf1qQ2tGy3D45kuNP8Ya5cWzSmRrSISqzL9nlJV9wxwSV hcY9C5H3a/bz9lb9rvVNL+Huk2kl2Q0MYQDcegAx71FSHvU5eb/JEM+lYP2gdW8V6tDJfSK2T+7J wWRj3XPTI43DsSOhNfTGh/tJS+GtLit7a9VXAGTuAzwe/wCFbvWSZKd9WeK/EX9oy+1q5jiutRuD atKgk8gr5mzdlthYEK5G7DFWAJBIIGD806xoNt458QWHiDUYQ7RsHJcnI7/lzjrWspOMXK+6sLc8 +/aZ8W2vh/wnY6VZAidf9Wq4wDggnkds549+nFfl9rHiDOmXNzZ3iKsjlJY92ZH2nIOAOmQfTtwc cdFCCVGK7r+vQG7WR5fJePfyzz/O9ssihyOhB6kcY9D7c8VNYaPbNq0EsNpHIfIMryoMEfKOSeo5 b8fwrpox3ktiZS3VzDk0y40e+1WQRObGSC6lQA7W3kbUyxB+UNhsY55GRnI+dfEFhdTatfv9nKKj bdqxkKOxPTAGR2P8XSuicm1Z9xwauyGKCaLyl38KwPQjkdPzzWj5137f99mo5mhyp3d7He6lboWS Rg7MGUgAnjB5Pp71574mYHV/DloQEcXAJPJKgIxJGeeMe9YNpOJkvI6S5sDtWISZyQd7AkjjHbvX B6tZ+SHmLcbiMdMc+n51d3bYGjwDVb66srOOW3nYyNuZc9McnHH+eK8tl8f6hb3CQXEqlMkKDkYI 6fj1+vP4Q6mhSitdC9oOu2+q2t3cIAsq3kqk8DawbkcjHQg/45robaeWc7pVwoGOFyA3J5JHt36/ Wn59B7aGjp0McthpouIFbam0kDjrj3J5J/SuK8S6NB9lSP7LGWe4iQ/u1OQXHXP559PanLfQmzMK PwlpUC3FwmnRxup2qyoFLKcHj24Hb+VfNnxDtrSOdoVUgG+2qoZgNpXdj8Ouahte7b+tQW9jv7yG Oy8CaPp8kUhlklhljwEwrRiQkMc5/wCW0Z/4F9DVnwTqsXhKbXtVuJtPWGK2iuVj1BrcJcMJol2I tz+6Z2VnxuIwu5lyyqDdaUoqfI9bfod+Vxw88ww6xelLnXN6X1Ol8Q6Tpmt6lc6rCdNNjeC3nktt FnL2Qm2qJwG2hGCy78CItC3343eNoyOz+Flja3njvxctwSIotMv7kptBBFrGZwmD1yIQoXHPAx2r C8lRfM9bP8EaY10/rdSnh/4alK337nkPi7wrpOleNPiLpF7bPcz6TPdWen28y+WZ5Em2KZcqHwsa P8gIO5lJbClT4rosvixdVtbqLSIktySCsZgRQuVyuM91JHORk5Oe+MJ05NxquysrfcVRxWIozpVq cr8rv+O39dz9Ev2Zv2QtT+P/AIyu7TUPilpXhHwbBaCZ9V1mWSaG3nbzDFatHbB5Wd1hncHaQsUL yEhVBZ+k/BS+t9e8U6FeeLNMOoadcz2JZXDxTNHIqiSMgfOh+Yo2OQR2Jrsbw8Y01e8nG7XbWy/z O7GYXMMLTjjISkqVRy5H3Ss9+rSkrmhb/A+WRUx4w0V5Ci8zghWygbJOw92yBj0/D0H4S/8ABPz4 m/HX4nHTvh/badf29pagXt75wGm6XvL+W9yzR4jJKuwCgsyxPtUhGK1RpYXFV40oQbbfa+n+d7W8 zkWZZnh05+3aS1fvP/M/Tf4O/ssx/A0XeuHw9c+C/AcWnmO98Ty+TZ+L/GAZJFe2tJ7WVzoVgSMy C0l82TZt+2XsMySW/wAx/Hv48adc2Fh8O/hh4as/D/w/05DZ6bpumWYggtwoDDaq5zkMSWbJ3OxY szEn6LM4YfKcJHA4b45K9SS79IJ/yw/8mnzPa1vDljcVnGKeKxdSUktIqTb0Xr33/pn5veLzPeLd PJdu9w6jIJBB25A4HHHr1/PFcZ4F8SD4ZeKbPXr+y+3aMCTcWUzbVlXcMsC3KsOxx7Ec4rx8jzKe VZtQzKCuoSV13XVfNDxlCOJw1TDS05la/bs/kfY4/a88Wa0kul+ANB0/QtHiBZXixc3BUn5WDyqq ZwDnEZPuK8p8W6/rviq8srvxL4jvdTu2IULdXDyIpJwAiE7Uz2VVXOcY619jxRx1j89qewpTdOhs orS/rY8LK8hoZevazXPU7vp6dvzMSGRYSsJYMiE7sSDDZIwAO/8AD6npXY/bNNggS6W1lX5CTlwM nOR820kEjOR32n5hk7Pz6Sd7panv9LHO3NxG8d1asViRxIkTKZF86RASTtkJOAMcdRuGTkGs2HTo buK/sbazEiyIiSSnL7VUpjacc5Kt2UL5mMuOEjVR3NIRcpcpU1G4XQtNiW0ihluPNkneeRV3xgEK irnqA24lfmwQOCGaufs0truSdYoY7h1MarbSROvkcqheWSP5ghMxDdNo77qje+pTVpNHskjy2ltp VrNa2sTmQR3CSR3IFqgh4nmRV3JgLI7JucsrIyq2zanL2OiX8uvXvh3WG+zanb3BN1HMjQmMRbyY 2Q7pFY4AAK53BhlhytwSaG2r6G7r9peQ/YtUnMEpuJNtxIsqg28e9gC0QJ2hi2Q74wF2KDjiIWeu 3SaTe63q915bQq9nAHl8y2jaZZQYmkXEKeYzvuQgF3IAG5qtR7mal3Ni2u9ae3ZJmFv+9klKs4j3 YjySqoGz8zDABJIyCVLbk9QmW/t7FZnkkFqVKusrHeGAIzgEEOAWAYsoy33h1GdktGLY8P1K7nvP 7NgCTxTTyfaJZjgi3jeKMBcD7qqkJJU9C2CQQUSjeBP9GjisUjKRRE744pJXmRSrYl2AhFKKSMEY IXBPIVrXuK+o+11KW+vrm20gs88qyr/qAgZmg2qyszEZDFvvKvy4U7S3Elh4jtbKd9NYysY2EPmv GUEhyFbknK7WYgKR0OcZyFiUNG2tTenPllZHn/iTX7KHWEWV/wBzJK8il1b5V2tHjYWMZJYHO4Hn byoyK5yz1PR/ESskE2xI1Zvsz3MZeFTuITdhVZvlIXcWJLKM9w43VrkVNZNnLtfrCjFVXyCd+AxJ weUwRzjavTjnk5I4yr/xMZo52kHm+YvlbmGH4IIUEk8g7VPsemADVWT1RK7mp4M1gyyQOWjVJ/MB 3EHBbaScctxtBLAZPzAMT930vXLl/LWVIGZzGWZiw4wCTz2AHGfzxzUyvzWTEu7OC+1WUi5nXO8B MhCDg4J59QR6E9Oc8Vp6Dr9/o2qx6to13NDeK/3rWdomUezJ3GSVyCAccFflO9LEVcFVp4rDz5Zw 1TW6MqlKnWhKnVV4vRo+idL/AGrviX4alsdOmu7XWoV4lW8jVJQMbmIkiwNqgNyQT8pB6jPaa/8A G74XfFHw9cazqui3VhrcUJktoQdy3TAAIElQZXcxxkpkDJweAf2DJ/EinVwM8Hnsfe5XaS6u19V3 bSXzPlK/DcqeKjWwD0vqn0TetvkfHeky6xY6sdXvLhmuJGLMycKzHODjGByc42joBgCv1I/ZN/al l8F6jaaPrsiXnhltpnspGcSDCgLJHkkqU3EhtmecZPIr8Cx9SdWrUxUZe8239+6fda6n3UYJRUFs v0P3Z8RfsuR/tBeAYvjR8MlF15zO1xJFEBdNMUjby5SuROo5Yvt8795gkqoFfAeu+CdY8JalDoev QNEQpkM5BMdwmSCyP/EAQQcZIIZSNwIFYWNPEYWOJoLrZrez7enb7ugOT2l/XmWbIowW6aNfMJCo hXt69+gx+ldVY207b4Y43JZhvbHCDjHPvzx2wKuUVHULrqdle6fc6f4T166to5DeC2eOFlByHZcZ GO4HI+vtX5ceNrS7vfFuoSWtt+5lumighRTwFICgccKTgDntnnrXXhUnRlfv/X6mU9XZHWaT4dZP C9rG+mtJdz36u0hLLiNFYFc9OsgJJzgAYI3YP1p8JdX/ALKN1bWltOkKINyFQSGPptAAGM9u59aK sJOCa/rX/IlH1/Y+MJ9MsIbqS2HnOGMRByxCgAgL2z179D6VzGpfF/VJpIoJbuOObcwKNOgyBgcD OTyefb60oxkkrA2tzsfB/jrT9Suit74gjt7zcT9nDh5XyQmwKvOWZtnTqdvUiuwPxg0OMy29hqMT S/8ALQqWKxAozJlx8qhgr4LEbtjAZIOLVCrN8qiyeZbnxZ+0t+0B4O8PQ20vjXxQlrcT2j31pG1j e3QS3VkiNxILeGTyYi8ioJXChicKSQcfi18Yf2ubuy8Yzaf8MtV0u/8ACiQxILmS0ukFxKQTIx83 y3G1mK42qMKOD1PVP9xTdOWkrLQq19ejPN7T9tnxta2jafLomkSQtIZAwFwGJPynA8zgYOOQe3cV 9IfBj9uPwTe6mNI+KvhiSytJ0EUN7pMplkEpdeWRyFKrH5rH5xkqo6MSuUMVOml7uxE4Np2Z+nHh Hxl+y54ohj0q7+MD6dPPA/2+4vtPzGioplijgaFpmkaQrFHlhAokcqzCNTK28vwY/Z5u9KsNcf8A aM8LFG02e9vIoNTjkeCZJDGIAgXc4i/d3DyHBnjeSO1SaWHD/QYWjDE2jJW9Dn9q4LZnReEvgJ+y 1rsNtF4h/aS8KI5lsIrmSCOV1tIpYxLeXQ3Sq0ojcG2hgwHkZhNMbVVMbezf8Mif8E8f+j3tL/8A CbT/AOWNetDJas4Jwg2vn/kcs8xqQdlBn4sDQfEX+m7PFZYxqqgmEYIIDdD256e35cre+EPFlzrF pqL69FPJES8cZg4PBXn14J5/+vXyPLJ2Z6K2vaxq30/i22trqVJrYvCjHbIh+cgZ4wcdsVyXiCTx TMlvHdRW+x1DkAMCgPPX15PT2qve2BWPnjxJZa5EE09ZIsoCBuHDAZPHX16Z7ivkTx54ruNNvktb +a3WURzXIjCMSY4QSx+UdcDgHrwKmUbS1K5ktTl/hz8Wo/td5Y2s0cwknMqxXMhgfJ+9gN1PbOcn NfUlh4r1q+tlb+wgbdGbcftSngZBH/juPxHrT5WlqgunqdTa+J9X0vT4LO48KSl41AUx3ETGTGTx gj1PYZ/GsHXPEuq3Blsm8G3sTFo5V3CNyNrhiCQSOmO/pmiUr6ISS2WxxeqeM9YtI0hPhyYSbix3 r0VCNx689QMD+8K+bPGGtSahqulLHaTi3+2b23p13oAQRz3B/ACs43clbox2R6FrF48N1aiacLGl rAREXXqxUhsEkcqoH/ARWHeHT9fsZLHUo45LbqUc/LIByASORyPpmru27oaR7ZoUFmun6XBNIqhm QRwqyjygO23224A+npgaXwzlVvHd/LHqSP8AaIrhHCkA5kVt28nIAOcE89QeambbUtOjNI6PU83+ JuoR6P44bxJcXil7gQXLNAzbnaVELYJGWGZNvOeM5z35zWPB+nwalPeWd5A1mJPOt3+4SOT90k4J GDippU5ulFxXRDuuazeh71Yj4qah4A07wD4audPfwq2rrqtzFfzmNYy6i3lmEtuySsDGqIVLgAB9 u0sxP1v4e+GepJ4limTw9Bq/xI1m2N/aRXNoE0m20zaoIjktzHbrdpG6SSuQ1tZW5JcCfIs/RoUI Kc683rZXv0SW7fkk/wAzsqZhjMZhsLlak3GDfIvOdr/N9D6q+C//AATr1L4+/tBXfg/R7x/Dvw00 i3s7jX9TWaW7BDK7umnxyKZcNIFghFyFmdY5pvKkMTwD+xH9nD9jH4Xfs8fCrRtOtNEtvDnwo0pJ bs2zKDNqdwyo0l1eSON007eWBt3MCNoYsscap7mQVcK8As2oxdqjfJzKzfRPvbf5+STMuK8lx/Dm PeSZi4qtFKVRRkpct27RbXW1pNdmu5/Pz/wUs/aF0b4g+M9Y0/wsj2/gy3SSGzV3bdIi7WYNtCsS RuBAB2lpF3HYN34FeJNVkvbl1+USDPID5AznPPBBye/bnHFeFm1R1K0r7s8zAw5aaZ55d5+YGAMB nJKA5I6gE5x15579q8w8W2t1NZX1xNukumVipZtrq7Z4zkFe3f068g8EVZW/r5Gstb6mZ4O8RTWd pDaKsSxEqsrMFJfGcks/GBk/KMDjkZwzeovqMtz9nEaeZI0gDEyhTHwSMgkD/Z4BOTk8ZI2UNXIi +ljYins4rUXTzyPAshgZlQhVLY/hHMgIHDYyS4UAnras9UeaK+kjVYt8qvCskpQRNGTj745I2/dB x8pypyVWLpldLDWkuJpI57xF+xqu47PNO5W5JGACzHoc9VHI+bFdZZ65YWWnmbyIYCqrsHyKka46 uzfKSepYnsWOSSRLXMrIuDcX6Hlev3F9rPijVNUg1BWuZbaUi5v5QVaZPmIUTEkOyCQhs8uAobNV vDPnOtpLcMxs5blZkELKsb3CBWAZ3XaNiMu/bs+6rkuNhqWtbWEndnt8XgvU7fUbpvJkmZRJdAWj TxSm3jSQSDbcRp5Kq6fOZgkiiOQFTgrXSeFIBJqE2jaTY2l7bRTRXSWkq3KJdWkivELWTy2G4x+c qNjYCqS7iuEAUUuWw3rYlvPDGo3Wo6fodxMUvHcT20Udg885t49sMccQV3flQzKuIgpjG594jjF3 TvD1lB9kN3dNNKtvJaW1xIoVnRZIolk8oxmVlUqR5bsnCxSBtqtsq/uuSHsbbaLpemWsi6NIHur5 GY2sizM1pasnmws0k0EY3SEbyyAN96Qx7mAH01rfw3ltvC8M0NpuBjRoSyNzGyqQ3I5UhgQevIPr WU5LQix8E6hp2o282srYWtvO0UaRyI8IMuJztUqrMHaRZFUK4ZWwrAgBagnjtYBZRXt6m4JtUMp8 luBvfHzAc7SFBC5bgcFhrJrk5idmYWsw3tva2M2mKpwhZJFJSQQOGDcKquMBtjsdx+fCyhcE84tu t41hpdlaQHUWeORpXlREDspcLvfEcIIXexckoVyWAytZ3TV7mifRHKeLYo544NWkuGWFpElaEyia UgMWKJhCylwcqHwrFhknGR45pTiNr2aSQOJIXwrEhosK2JCAxI2DB+gPUA0kusQm/tIhsrOW+jmu LeRkPnsW8worPGoO7bkjO0DB67trAdDXHMl5MZLeVEzESiuuSgchjuOMgj7w5IyRjB4FaK1idjqf Csdy89ndQSNDDEuHjSVd6feBcHGRlhngHA25NeveIZ70zaUtu2U3qmwAfIjAZIAzuJ4OM4HXsTS5 fe0Gu5gi8vTNABJEYV+WL5soFwQc7sc84BI6kHp1ludShtissaguh3RMFwGOeR8uCDnnA5z0z30l C6SexltK55+DFdTtLHeMt9K+C4jchNoGcADG0leHyc8jHp7PY2pgtLURykgHYxcnk8HcSMZIPOfx 5xmuWreNoo1i03ex3WlWMd4ixzR9ASx2j5jjjOR9TnAP5cdp4fsX0i6t762GCrh13ZZZCoO4OFIJ wD6598njy6q91wZ0xeh/QN/wTC/bc1j4IeONO0jxJGL/AMDamI47u1MQby1cBZCo3BY3ZY1JbIz5 WCOhr+i/40fsufBj9pn4cQ+PPhbp9lPBfH7YVhT9+0mFG/Iw0chwqknIZduc5Brjy2r9VxU6T+GW vr3X6/eVLVXR/N7+16vj79k4WUTfDu3eya5urafUJYJZY7c/uxA7JvJCbt8MoGCrmL5sEeZ8Pwa1 r/jaKC+1O3On6nfN9rxperX1lIyP8yTiIS7kRw2UkICvyQTjj6LF4WFKpT9+8Jrmj5rX8V1MFJ2v byZy/iTxx488AXXhxLP4h+IpI7y/Nulpfa5dXdvKArsS0MxZWbBJ5zg4PVc16zY6jr1/Z3VzG1iN TMgeWWa0G+ViXLE7TgkhyCe+0N97LHSnSpRlZRtft5Myblfc4DWdb+IGknTLOTVEeBWaRDEiAqxW JCXKgZyIlPzdwx/jbLNM8SfELxBLd239rvHasW86QkAc+YM56n/WP83UEpjlVNdCpLRKJL/mbOwu dV1VbW9uri9eW5ijAtmHy4bOWckdSWIPXIwB0AFQ3V9pt++q6hb39zFZJEsEVmyqNszRxIyoi5Ch fJREzn5YoywJFdcaaVoyXYxcrIf4XsvEWoavestxO8jMMJl2bDTvIF5DZGXdvqSck19meHvhd4l1 bwoNNTWL6DVppVlWaKRke0UZ2qpGNgAOOPQdSM16GEh712tP+ActWok/NHwn/wAFAv2BdS1L4V2n xR8LeLpJvEPh22Rb62eZnMtkgByoGRiEZfGANhkbJwBX4GXnhLXdKnjj1e0k2E4WbbmN+nRh068A 4PtxXBn1GnRdCtHeUWn6x/4Fjvwk3VpX7aE0GhrA/wA43gj5jgfMRxwccdKrW7RPq8cVyo2pEzrj cDncoHT2z68Z/D5vmck+V6nUlZo+xPhJ9t1nS0lKEqmEJbI3KMevXuc++e1foh+yr8QvhH4L8RT6 Z8ePhZL4i8KzhFiW2vpreeOTAPVWAIHOSQe+Aa+ky6rKMKdVPa33HmYlSkpRg7H7Y/C39qH9i/w9 F9n8GfsqaPJLuWNRq9wsz45yd0iO3Ufhj2r3P/hrz9n3/o0/wf8A99Rf/I9fYRzFUopKu/kkkebH DVJ3k5/195/OpPZrZz65EwIJmUEMTzhF5+n+HeqluIyUlLr5kaEZGc56EZ9q+GS01Pb36HNatAkN letMmV8o7WAwWLcZOMZz6/Wua1eKOUKxcEsOOBj8B2/rSXmNJ6njfiyyAuCpTbEy7d2eo9uODn1r 8x/iuJ7L4peFnYDZctqNmquMqPM3xoDxjklTkflWb5uZP1Br3bdD5elsJI9VKagHW5wSzOSG385O fr3z617T8I/HnjTRPFOh+GftYutDu7qOF45cs8KFhkq2c++DnOMd63tcErn1f4q+Menad4lk8HG0 kk1vYkaeWDhy4XYF2/MxIZRgc5JxUY+IXxF1WO2mttGjWabzIVliieTzjG/ls684AJViD0OeDiuP Ez5cNCdP4pSat5JLX5t/gdVCnTlNqrK0Ur6d27WOeNj42vL6C98Qzzw2K4fbhfnwR8nHIz369K8M 8TTMdRs0D7im9jgdT8y/zPrWWHU1F+0d2xVnSk17GNkjWST+0lYyqzBLWR3Pf5UO3nvgkfl6Vci+ IvjV3hgj1uXziVQAsAeOpyeR1NbvVkLRnc2Pj/xK17GPtBMMMTO6BQVJRMg/iQOB1z9a1fhJ498X XfjQQX0gkiEbyDMIXLYCjPHzD5jwfWsly3cfI0Slfa52vxq8dX1v4g0eSxkRvD8HmxBzbxiSeGO7 uEV8spx+7EWePfHaum8H/Evxrrvg/wASPp97p6X2li3uY47q1gEs8WWWRY8r87gMhIx91XPOMVdO py0OZt/0xcvPKxe8JfHr4gq8lvcfYTNHHviJ0+FeQwK5wh464HTJ59a/Q79j39m/4yfti+MorqXx PLo3wEiv7ObxvPFbzNa37W8qzxafHao8cVxdPIqSL+8VEVFmkUGHEnuZVgZZlUlRlJqCi3N/3dn8 22kvNip4iODr0sU4qXJKMrPZtNNL5n9wn7IP7Mfgz4V+AoNd1LTbbSPAVhcPdwLKoDXLMVXz7qST 55rlgscbSPtx5caRxxRRxQp8D/8ABRX9uiz18aj4P8L6vPH8P4rfEKWMSv8Aa8O8UnLEJIxBbagZ SSuPm3Ar7OJcISVGlG1OiuVJbJ22XotDgzLMMXm2Nq4/Gz561aXPJvr/AF0XRKx/Kv8AFvxvc6pq 9xcOo3sjIR5oPkqMAbtwJOCTjd90kKRgEN80tZxRiOR4MMpLkIcY59ecAkc5B6HHWvksQ5SqN3Om muWCZxd48iSmMSZJ5XahAPGOeRjrn8MVyOtCFbMxOu4IuScZyPzyec9OQTjvzzrd9xtbo8MuVuNP mF2sBDwK6o2AfKjLbRjn5TnaCSerEHG3J9e8I3aXwF1aLLvAy4fL7kI2scnGQfp7cmu+gm4z9Dmq e7a3Q6ZLOaGGTUJIbl7mWRVhlQp5bncUEaKQVH+pc9Bu3svBQNUV7qmn3smiadehHg2yHe0zKJfL jRcKshxwY3Ucgk42q4kRji48rNo9juo0SfQ3uzfII3mEEMZVhvYnkoCPujqWxnAOA+0in63pzR2m oXLyxTXasvlQmMuGkDphRGrEqx2tlWU/dx1ZVeG+XVbj957HC6Touo6jrxh1k2Yt31B3uLksvlqP uLtEbZVQM/6sEfw+gr3nwz4OP2W2u7TXDHeloZILdIlkiX92WVGlBDIsrrGAkqbJI8PIpyRXO2l5 lRj0Z6DpGjJc6VrtxpunzC6tobO9t3aObb9kSES3ASyIETW0zRrdMJfNixbAB32SM/s/h/SdM8Uz XOrSav5+pwxxaY9lAbuMadbxeRDtjMLABZI2eV8FPmLHycnLzzPdIa10NnWPhRdaHd3g0zT7u51F rW+uppFk2QXtx5E0oBt0VvkhdbkGLy4zL5ZR5I0covNafpN4/iHW7jTdTuG0O3gluc/Yd940Mp+d kt5ZcPwJdxeSUpARI6zeWqNCnfdFWTWpI3wzOsajDpkOpyXpui41GcXjLDI0pLPKvnlJZC4UDapV dy/Myuyx19vaX4anbwJapLcxTX8ShDLDCrRgiNQD0CoM/wAKqBg+hFZ1aiaSXcnc/Pf4n6d9gvfE lhcxXh8SS28V4tn+/jSGJYxmZ/MQ+YXAYI0Y2uNqBhw8fiV5phuITqFlZx3MzBYN7oAlvII1LBlI KFgz8YPzBN65BBG/N7quS07nCavpllpdvpN/DczvFLIgu7i43RbJixbETK5M6LG6PkBQWJTjbmvI 9RncX13CZJI4bdMl3wrCcOEIK4GDtwWwNq54YZ+Zp316BHXUv2gsry0tHi1GWDV4JIbVPKSeVrkZ aYBUbEYCNtBZtv8AAVDElV8TfwwJrq6NjqgL3O+QRW6bsRhgxeTewSNdhbDbiAYwMqCHChKzK0bO Tivdc0ezuLm0v7qKWGaFW+ymST98OYs/dHA3MOpBwQPn4523kae9ub64keFlTzJhHFuLEFcAkDaP 4j3xhuhPPVGKaujNuzsz1zw5cRztaOgU/aSHlcKQq4GNsWB8iDgDAHpgcA+hanCJdUvdkEZQQlZp ZbfeqxkbU3Btw3Ybb3OMNn5CwhRdwbSRxF5YSz25eBh5oyI977V7by5fHbIHIyQSOMBvLvFGqRwz Xtkz+ZaKCGkaMKjMzBF5JKLhcN82Ofpk9Mo+7a2qM1e7uzY+H+mW5vrqfT90lllYhICwLx/fLnqG LMSOCVAX8T9HWFtFDEYmGwxthV2hQeo6546Yxg574wM+ZWbc9P60NUrRu9zr9P8As0gWWCc5wFU5 YZIGSB9MDPIxxXd6dG1w0wZ5Mk8EsAHOSVz+OT+A45zXFUjq77m0fddz3P4b3smnanDdxrm3tYlk lECqWI3ZXILgt85Q5GThCexr+mn/AIJwftp6l8MtSt/D3iieYeEHUyXMEkqpDEHUuXMexRFt8t8M uRh0ztAOPGxSlSqRqx3TT/4HzNo2krdz9dP2uP2ZvAv7SvwxuPFng+VZ2uYEu7G5sQGZmiBaNo25 2tncu7oQ2PQj+Oj9q74GeOv2MdP8E6fH8NbZPB89/Paw67oumi7vmm81pRaMsskawwnbcgq1wPKG xYD5Mc8R9qUauYrC08NUacG5JdJRcbuL9Hr9+jdj6TKsZlkMjzTL8dRi6s4xlRm94zjKPNFNfzRW ifVW6s+FPHnxLvPEvjrwZdf8IrcQaVp00szQi6WYszEZUy7I1ICjAbYu45OADgfTXhv9oTS9NVYY vhs807Hc089wjD8FBxgY9O1etS/mfRfifIT1lynTah+0LPNqkF7pvg7SbaYIU8tgOu0gchCB6+vu M5rrNL+NMwsbaTWvh9o13IHbc5uRHvz8p4A5IOR07e9dSxfJJPlZjKgpLSYuvfEvwVrmmSWkfw0F re+QBHPZ6mvBAz8wkQ8Hjjg8EccU7wD8TvAHhK1FxN8ILnVNckl82WW+1e28tj1yIlj45bPLH16d N1jYStLk1XkZSw8uXl51+J6FB+1WmkyTXulfAa2FwzZyNRtV7YXHToP8BXnvir9sX4n67OqW/h6S x00nb5NtNAC/TguHBPXsB1FdEcy3tHUhYaL1lK6PI9V+P+pzPImtWN69i7BJFlvEZWB4wVDEHj0+ n1+IfFWseFfCcuo2mp2Bi0S8dpbSKTbKAv8AdJGV45HPb868fOZVsbhbRjrB836M9HC8tKTSa1Pl bXJvBeoSajN4ZkaC5ALRwbMwybs8KT/q/wCHHUYGNvOR4DBqom1y8sH06485QqtGqZK/Mc57ckdq 8mjTqSi1L4v61/zNZuzuj7I+H3j6fT3tLSLw3dT2kaCJYjsCsT0JIbJ78ZGTxX1/4em8QwWtvrV7 4Q2nmYs9zbJsPTne+Tgj17mvocDKceWMYc39WPNrKLlZytfubGh+Mr/w7qkfiC4sLhrkMSY1urUK zHI4Bck9c9Ow9a9I/wCGiNV/6Fq5/wC/1rXZXqVJ1HJxa+7/ADCMIJb/AJjtSvvGM+s7J9Hi8uR/ mAk+RcDacsFzjocY+nWsXU5/ElrfWMEeiWStMzICLl8ggFjwE6fKec9x+Hl3dtjdKPU5/VrvxFc2 FwsmhQAHcDsmdsdu6gYPX6D1rl5l8TPG8h0+3WUJwhlPXt90Hn261N5XZSS7nlHiZfEr2kV79mtx JJErqqeYdqsA3A7Y6HOa+Dvjx8NPF/ie3sdUs7KM3NjK8m9NykbmDjAz2IP/ANfGaiTs7voOyZ8U 6lewx6o6+Jo3gvZJtsrJkK5BKnr90nH07+1bXhy9l0bxDpF0HKPb3kVwhJz91lO1v19eM1uneKsJ KzseofEe/jufizp+pTRp5xtbVt0RI2HcQGznr0b6CvrzwncahoOirp1hdo1rB5cYldNwJ2AfKOQM Y5zXl1W/a049LM7KaSw9S2+n5mJrV5f3NlcmfUAJ0JjwqBs5OT0/If7v1r5M1ost5PK10X2EgkAD GWzn26D8q6IPU530On8Nz+Xb6s0j5aOMIu4ZDbjj6Dt+VVLOa30zUb+WO7xboGw6pvB9No7/AI4P aqns0io2umzo4NV1tAj6JEsgdN3myJsAIzhcDJJJ9doGep5A9v8AhL4j8U6j9t0TxB4V8t4oJrq2 1CJ42jdYo2kkWVA277qFt68jB4JwK8erRoynJudp9Nz1qNSpGEbU/d3+R0XjjVfD/iHwv4X1rfZm OGNI53GlkYlktkdwRncQHgmb0JDNxms7wx4m8G2N2ITq+npK6eXKg0ubLgnlSRx6e31rtjGqotLa 7ONSpQfM9z7Z/Z9/Z9tv2gviM/hnwldaSmjW1uuoalqL6VctHZ2pICIoBVZbiUny4bcugdiWkkih SaeL+0//AIJufsbafoXhDwbDcabHaeBtNtUuUiVFWK4keRpGcDnBYoWbueCXLM1feZD7bAZXXxFX edn8ley+crP0SPLx7pSqQhDpf73t9yv956D+3/8AtS2lppM/wt8Ka0uneF7eI4jhKf6eYo8lZGZS qR5ZF5IyzRfMNzY/kt+PvxHvLi7ujDLPLYma4tmu5mIklPm5kyrMTt3NcxqEZwCmzO1SE58V+5oK N7yesvV7/icVJqrU5+nT0Wh8Eza5e6jcfbbqFmLYkP7wkgsuRluDu7jJyRgnOTVC6lSKM+SGCOSG +X7+c8ckgg4r5uo9bo9RbHndzK2JpFcIX+ZS2flBJHDduOcVgm3mvWGAxh3FWjIwA2cKARknOQCA M9gdxzUU4tyVkRUslc5TxJ4HvdUks1lmjXT5Dvklj2gHaCpILdssF4OPmLgbSQ2n4Xkt7Owa1swf snlFlVgu7b5jpzIF/eNwwLFFQHGAeBXoUI+8kznm9Gzb1fWZJWt7SM7pHPnJO5Kuq4G1WycMVGD0 G5toJIUbuAvLe48U69aabGzLpdn5hvZQmN+w5WAFeT6hMgKAuQAoqp03SqNvoOL546HuVhPdzaSJ 7eQTeXbiJN8MUiMGQnIHzLlFdQh5IOGUr8gHF2K32raxp8t7bN9n2rblELNtcR/MwyVwTvDDlcHb jtXnTerudEUkj13wnZOkdwrSQ2iPCj/aZiqLbq7sSF3iQEkIy7mAC7geQWx7XpdvbWmpRiKwttQS URtqFhHAYbHev7+aGQMSREsrLG0e5C6q23aqs64u70RW+nQ7LRNG0Oy1QNo+ixXAuZbeOK3j80C3 +1RK0LSIw2yP5bukaFivlMu44XcPonwol5LZXljpt5c6WTpgkmggBWCOxtwuQZEPFvPcKFijCiMt 1893eR8ptrSQ0tTvL3S7vTvEk+t2NtDp8F1e2X9mxz28t0trZ3VusjSmWceXLK8bwoMPsczSKERZ I2rk4/A9ze+I7bwvonhqIXOjLfQXkaNBLLOyQXV9Fbi2kfZMPtF1HKZplZZTYyt5qxuUt4uktX/X /DsqzOm0Twm401IYbOG/1yznwLv7esl6pgVIbW4OGEkcSlVxbOsckKzwZRGhZR9Z/DPTft/gF4iu 4rG0JUwCF4grvtV4+sTAclD8yjarZINY4htQTbC2p+avxq8EXU3iTxZqWqTJHolv5ww219g81JpG dMM/lKdzsAh3ENgjy3J8H1SFNa8Maq/k4ht0uHsAN/2hoo1I8xIFU+bv2EebKAql5ApcRu0PVDWm iHfZHnmq2UPjK703SvsU1lAIPtFxcXUMrrGxZg/lAqQ4BKo2A3zKAGG6vnz+y2udZj05oLtlkuhe TTWam4eKBQP3ux2UMiw5l6qhBBZwvzJUUuVsixW1n7bYW+tandWX72NpFVWkQw7HZGOwRRhHLu7F SCdy7+WwWHnOrN9ouoo5RJHAyxWi/KEKgrkbm2AAnBBcHOGZgrd680V10OJ1QanJJJo8cBkld3U7 uN7SrsbAYfL8iopxjG08fMa4+NL6yDQyq+JIjGjMgi8/dk/vFIOdwUg4IyAhHLYrenZaikuqPSfB t1tOkyzWC+SJljYudmCo3kHkckkjHu3OOnf6tdE6hcQ2RiLSNGSVHGAOQeOeWIzx35IIrrpwUqnM c83ZJMoXl1OtlLO0Y27WbggYznKknOByep469c14z4j06eWM2SRJsvFAIjUqZZWTeI2+XD7Awb7j dCwYkhzM3qxpbNnpnhWznsrUefe779owTOvzGRiDkbjt4znHy4G7uFGfVbS4YO0soVkYKyruKgck bscdQp6Z6n148ipHVtM6LPc6KyvSJFXHLHaCrFfLB9epweBj39K6yxvFgkbzNvkBuxXgqOBnB5Pq e3XNZzjZPv0LTu9D03QPEz2UUZnDeVlyB5gTYWXG7J6ZYEnA3NjqCFx9efBP4k3kXjDTtR0y/uLd bCa2t8qzAL5ikyBk3LIAw8gSMpyDJFhcB2Tz8THmpvS7Lg7H9WP/AATV/a00S70yD4e69qYl0aOB Yon8/wA5S+AVO3kISrKSgY+XuCt04+9/jx8FfBGpWPiDSvFHg+21P4U+IofJ8RWDx4BOS0VzCwGY 5Y5JGfzFIbIB9CMcvrThFqPx05KS9N7foauzevU/iQ/bo/Yx8W/sffFv+zL5l1L4earHNfeGNeiQ vFqOnmT5Q52gLOgCrNGMhWIwSpBP5yan8ZdO0q9ktNN0x7mOF9hmQAJk8EZ/i7c9OuK+0nTpuSrU H+7qJSj6Pp6p3XqjjnpJ3PVNYvPFXgrwF8OPiJr/AIYih8P+J0unsYDMjXT20UxhW6ZRJuQPNBdR KGRQwhYgtnj03wH4n8KeNFtpLLTJ/tpuikcNvYSPKzPGMIi+YclQHC5OeTkngDkqxlFQlHXm87d/ 01BWd2bHiTWLjSD4htNR8Ki1urIXbXEEvnJLam3QySIUcqVZfJdcMMgsQeduMy08TWbIk40hkikR ZB+9YPtILL97jlXQ5xg7VIwCc6ODXT+kT8WpcXxLouwiWzmCD5iI7gAMCUzg4J9ef930Oc+0hsby 1XVPM2W6bid8x7ADIVVJO5iQMnrtyRhmNroriZl3N14MlvbU3mlXf2cyCSVBdruaEO7OI22bVJjM ahip2sC+MEIPKviLofgnxl4butIvdPvRdBYns5Q0bpDIiyb2xgk7nZFBBAC7+CWBW073RK5lJM+W dW8Dado9l9rsYRHcxArKCm1+nQkDnvk+1fPWjWcMmv3klwGUqGOCxKsScLg44zwT/PFfOUObnlGe +z+87qkY8qkj6/8AhXong1vCviO91vXJU8RLLGdNs0jcNMdybmYgY2BS/G4HIB+b7p9yg8VeGrwQ waxrFwkBhhhUtEqoxZQJS2HyFXkLjJbAJC9K+sy+UKMYtvV3/wCB+p51SjVq81l1/wAiE3XgW9mj mm16YjMoz9m+RUGBD1cD5jkN/cXDAyH5afv8Ef8AQSt/++k/xrufs6kpSb/r5Fx/cRUGfaFlCT5u 2VHPQsh+XP8Ant161yPiCy8vXfDBWIFzcyFsKOAbeYjr+A/GvFetkNOz1KlxaxzSPjOA270yQcjp 6VyF5H5LXUndVLdQAWGcZGPp61lPbRFqx5nd6bv0XShcKBELOHB2jBOwdPQ5/pXlniDTLW20+ea4 LLbqNzs2Og5Lflz/ADrKo2rsrufA3jX4L2fx0kXT/A91ZQ6h9rmZbuRm8kozs2QUViwIIOQD7cGv B/iJ8J9f+GF3pOja5qcVxeQw7JLuMFIyOAgAb5i2M5AGeCegNY0sVT9qsPrd39PQ0nQnCmqstjD8 YXa3mteG9TiIEkmkW5BBBIdOGyD/ALQORz0r7j8U+KPCsul+HbnwtOWtTbRC7fY6lrjb+84f1yCC OOQOxrGvpUp97v7rP9bG9PmdGdtv+CeP634pjkikAlXJ+UbeAeccHnv+lfN2q6pHHNdmOQkCU7iC cHr/AFNdVOKWtjmlc77w2lxqmmzi0Qt5pX5ARwoKjkE+oJxx3rSTw3qwdLExIL1/3uwzpkKO55zj OOn/AOtyaUrstXsj9I/gP8I/C2s/CjwTq+s2CtqZjuopZBt3ALeT4XIGQMgd+ozwRge7+J5fhb4A 8C+IrS91Gw0+8vtOurHT1l2CW4LxMjYXlsYdVLdBuxmuSvJJzvtqdUVJxtFtt+Z+dug/Dq98c+Hp NA0vUIX1KxgnuleOdgs0kMkkpbJUZIhkbgdAoPfmn8J/gT4t+JHjHQ/BXhW8sbvxXqlyttbW0d/H uyFeRyxPEcaRo8ryOQsaRPIxVVJHoYKk8bXjQpbya+5vf5WOaa9i256WP6/v2A/2W/CXhPTfB/w0 8CWEsmlxSxR6zq0kTG78Q6oxRmun4VY4QqOkFsM+TEvSad57i4/pl+MviHTP2aP2foPDGhWiR6rc Wj2cEUcm2WIupC7epkbe3Xkk5JH3mH3GJ5PZ0aMNIyl/5LBafmkeRUldSm/6b0X4H8kn7Xfxdj12 78Qwy348u/Vbe1nk89ZBAzYadtmWXzHEkm9ifkGFcRxAR/jz8R9XmbzLNZHkPlJEmUESiMqpIVs4 wVAGfmyJPQE187jqzlOVn5GuGjaKPB/tV3bJaW1yUgtoyJHjJYIgJG5jwWY5Ofl3ZJIBJDKvRBPL R5J51YsBncxP3gCeVBBzkjjv6c15NTfQ6ovXQy00bQ8utyzvKAu0l9pD7lCrgKSQPm5GclwPvK4C QaT5dxbJZ20jxPKVC7DtnZiGClF4RiGMYBOTtcBskGqp30JnqrXOyn0qyFvI9isrXhYyxoCpW3Kn OVyAR86sMbk4VBiQ7dvm2t22k6Lqarp11C0ksRllgwkm6IF2Q7i+yTKzRkEDcN0uEYoTWsZO5Dsl 5nJeIBMDEkn2W63eZHbvE+x7id4mWEZcowieQxSHeCVRwWAbMTd14K8OaT4H0+aWfOoTJayQWcgn KtqN28i+Y67IAw3t5g2B5gm6NxKwj2rWKlbRbCprsexarBYJNZ6LCPNVGTT1BuEllENuf3ZWRtse 5YkUKUCKyvna4XiPS/C1nqF5dxWVskMcM77rl84dkWT98m90LzO0nEQ27lT7rSuPL4JWvodOq0Ow s9H8AW11FpuneG4Dr16tha21w87yNazeSvn4j3Qm4dyr5HlyJG5YN821m9K027jlins/DN6lpY31 2libZrlo/te+6aJbqa1RnhlRI5JbQIWVUWAu6puRnyk3fceu7PQ/BGn+NJ9J0azvdKniubqK401f sNlcvdo0UVwXjiXAjSSIsI0dDuiW5vSrMqKp+wPhv4T8F+GU1bVLPTRevNLZ6nZW2oW91YrFE4M0 0rAlEjk86J4wIZiGPlv5h+TOE3paP3lxR9F2Hwh1KfUtK1jTUuIPE4v/AOzLqdre3EcEDTIlwY5U BeJjBPJE9zIryedf28py5In7Cz+Emu3skd5DpOpWE146nQTNqF7byaPPvEkssckEDtM/+kMHEU6D dFNb/ZknjFzFzcyT1Lsct4q+EniqbxBPofhY3MXgK0uNKv52024S4h00kxWt5AN1wi4S2ktocbTC rwogLQwRRJ7r4X8I6VbadfxWOnudPV3juN9sEaC4LuzKSpIVyoC7XBKtvUgshKk3eC1JsfmD+0rp usWfjC8Lwu2kJZymxRUjeKW8kkWORJGeJjCrQyXTB2Q7sYRCxZ0+adY8NW3w/wDF0z6T4Zs7DQWS 4WxfUGeWOV7dkSbatxI3nSt5W1vvxKzozIgAVOum0qUVfcyldXPF/GFhJfa/5YZQhja0t44A3Eis FkVEJ83aFd43+ULlFY4Yjf8ANHiXwtdaNNb2cEapqF9HH+9XzV8uORwrCXGNp2rEWT5zH5jhgGBx dnZye39eQmyvq9rJcWc+j3+mx3fiSa8EhmWxkMTOeV2sGQyg+YzO7gKqhBu+X915/f8AhTR7meS7 jsHl054muhNLKcyARO7ySTRKFQfLkExgZUudyI6tTbS16BGxxGreEohb38VossrwXc00jApHPEVB RrdgQrPho8MwVcbyfQDgp9H0ezluJmBkghfzpFN0Bs2CQgD5eQ5ZACCG/iPC5FxlJLQTNvwzd3dr bS6UInRZ2824VLoHzAGRkGFGCBgsOAOB93aRXUzw29xrEa2v763eJW/d5Af+9kk56qRwR2Oecj0s I2uaT6I5qrtZMo+INStka7RbRIlVRdeVJuIcEDcijPzZI2csRnI6Zxzui2dtq2o2oAlg0RlZmzKI muoyAybkQhiimNAMkK3lrhQctWFV+62uppFHolzZr9nEUEkgJiSPOzKIBtCkDBzk8ADtjGQavRHy 0ubfzATHycc5yFwF6DAADk54GBjnjzp26LsarXY6HTwWEsAbEaqGDHAIYYAGMHtxjOeM49N60uEV tjfL1zkMMDk5wOMDjOe/1xWVr6PYqOnyK9/rnleSIZwzSSeQoRtj7sZwHYNGnzBOWVuwx82K9U8N 6te6nqOnXVrrFsbKAFURbmKV7qF5kTa+CoRy3nMCw34RSDkA1zVoPl5UtzRO72P1b/ZT+J2neG9U 0CVmvTKltb4u2eXynaR/laWUtuEW1JQFkkJ/ecgjmX+zH9k742+D/wBoL4Xp4cm1yHUNYtrZElEZ ZjJGUG0tuUDcybWZcBQX4yMMfLofucbHm2lo7ee34murifHn/BQP9n7S/iZ8B/Ffwg8T6b5+jSTz X+mXJiUy6FdsjxieJsrtXEpDoDg9K/hpn+BOt/Cf4ua14I8daPGZrUz253ANBOGRvLeMt1VwQQev zYIB4H2dGUnl3s0/gba8lLdfKWvzMeVybiuhe1l9S8QJ8Koorn/iU6YQbiNcEDY5SPIPP3IsY5AC g9SSafh/4geJdAls4PDnie70/SrvxIk19HaTTQi6jVhAnmBGAdQGlUBgf9aV4yahyfPFW7Kz9Jf8 AlwlyS16M9H1j7X4o0vXYGvA+u6gn2NZbqUHMssihixbqWyRvzwSGycYropfiVqnjTwnoWl6nCJd E0u4u7XRLmW2jiuH03MaQxMy/MwRopmALMFaWQAnJxopOzk+jf42/wAjJpaWOC8q2vrwQIQIohuc Bzlv/r49a9M0S7m8L3lybGTZ9q0q4tGkEaN5Ecls6yLuZSY/MUSR5QqWEhQkrIytMW+da/1oDva5 4zqUJe9SztzvUksRuXKDJJ69R97mvRNI0jSoNO82/kjE7nZbxs23zW7knnC8gY44P1NOUnpYqC97 3tj51+P3gbxLpOjN4ii8meyaQNcRw7M7iANw7sMqBxnGCcYBr5F+G/hnUvFviEpZxAM8vLO42RKC F3M3O0D2z7ZJGeSrQjGtGrDaSv8A5lyk7WWp9c3XwS8U2UpOhaxB9lAUAl9pGFG4gAHHPbJ4PXjm AfDfxNHasdR8TQx3meF+UqqjHQkA9vT05r1UqCSdnfS/6ma9pzcsdSinw01ye5tVvtQWS180crIC OGByMD1II/pXXf8ACrF/5/ZP++66HiIxSjDY5cRRlOd6q1PtVNfS3gn+y+Hr8W4cZKRKoBOCeCw9 uPpWPe3HiG9utNntvC10skcrNmd4lymx1x3/AL2cjsD17edfblOiN76lrUdE8R2Wm6lrlxo8Ytrd Hnb/AEoZ4BPGBweMDPc1mSeC/Fd608MdvYwEcBjcO5+UegUY/PtQ4t3Q0/M4i++H/jCy063tLzU7 CKO3gEIxC8jHaMAgbgB0H454xivkD4j2fiSfw74sifWY9ghubdRFa4yELp/EW5IHX+dc9VPUq+jP k79kfWp2bRYpJOExH0+YFTszk/TvXXftpeGsS6PrbZWGOYA7ej7gQOnpXkJqGZU9d21+B6VROWD5 n5fmfCZtopZvD7PE+yE3du+0gny8xyI3TH8R49j619FaXDFFosMF+UuRAzNBKMEbBlVO3sSM9vT3 rqxLft4L1/Uxo3dCaOKudQhW7mjhhhDLG53tHwegyRjtjP8A+uvBPFmrKZWj2nzDI2CuQdoPBP4/ 54rsp6tHO9j174daklvFZwiM7jAuRz1J3dz6H+XvXSfGOZbLwBP4itX/ANJWeCNypZXljLj5N4wy qcZJGCaibSqK/V2+8q/7tux8cwfE7x1p8x/sbxXqNlp4lLw2kOo3PlwgksFALkkDJHOSe+a/oZ/Z 68FaN8WP2fvA/wAXfFXha3cXkLiSC10O+1adZEmktzIsFrDNIqyPAMtgKpkTcQM49Klh4VYSTV7b 6b/JCpzm5JRdm/O34n0Xpf7NN/478IeJ/wDhCtFm8LeKdPjk+xXU+nT6Z++feoUSxKfkcKVcDJ2H 7pxivYfgd8IdP+C0OieGLfy73xLK/wBp125OYHuPtJgd0ldo1lULFFEvkK8iDe7rJm4l264PDfV8 yhiIXS5HptbeNrfO/wAi8RNxozw8mm21qtfN6/mf1f8A/BMP4Q2dvpI+IurWUg07T7YLasxHlSyq FLOqj+IFnTLhSTvKBlw9eA/8FMPi5qHijVJdF0HU421QnfArP5S2agb490ipPJyIt7JFHuZYmChT J5o+lxT/AHrX8sEvnL3n+H9WPEq6SUO7v9x/M38RrHT7q81KGxV/3JV5FlB8qLyo18wEKpwEWO2i +YFCI2XgIm75l1PybxLi8ughJjZz5caskbjA+82duN7ZOfvN/EQTXy+Ifv3O2n8J4Z4p0f8AslZh Zb47uZTHLAu9QoAJdZOOjFsYOAuzBOQ26fQ7S3eN28lp9KhdWB8wxgbi3lo0gHU4LEhS20HCjgVw uze5qO1fUrOR4LeUoJvMKyMhjMeQNpO1cKqDhiwIUgDHBy0cEZiF/baRBiUSfZkmUj5SFIYb1BRG JYbSrcZcqDlcbQi7GcmdLZBr2wkv7JoxYqY3u3kicogEcsjZBGEZ9rgIxAOWwMBmTwzx0+of8JKk OnzSNK6XEsd0vYBWbyztQlF4jlLYHyoVDOyjBJ2vbqNWknzdCz4O0C+sbWX+0NKkv7ZY5B/xMHjE DvHt80yQ5DlViuJH3YICu3VcZ9Rs9VsrYTXMtta6jqFwrebcG4LxLICk0SIH+aRkCPJMuCIwzEyS GZKznNzst+hai4qyOiv7q/umtfDyaRaXNhaRCWe6tcuI5C8IDgMqiMhlBR2C/NsBb5YdvpF6bG8t 4LPStHWS2NrttrAwzGK7nNsImLrPLKVXzA8m3JBydqoojjjwbS0fUpHo13pWhJqPhC/0qyTVBHbE R3F5bui38Jn3nzLWEPIXQfam/wBcZWiMblB9yXtfCNtqXgg+GJdMvbhdflDmbUUE9s9jbWt9cTFc qhkWUyYILbgQYmZyrEW+M33LW6PqL4NeALAa34ftTqlvdXNvpmn/AGKKOwljGm28iyN9lMkiQJLd XMckwkJMyFpgFkVonav0a+FHwru9T1+71y80W2vLLQ5I7eKySaRPstxHcFbSxZ441jluFLzhbRVR iysDLG+6ZOWo7u/T+v6+ZrF6H6V+E/glqXinw9Bq/ijD2ot2tjBNqNxctEoaMykhmZNpk5Cp5hAa OFNg+Ud0P2dJLa9ae3uSsckSiM3lu0kkKlolSNNriREChG8sbGEsispZtytwpSb8jV2+88l+I37P WlWXhvXYb+yWKGNCZXuUX7J9j8vyLvbPKkJfFkSoYb/LJiQq+0xN4ponw71Xw7o2p2eqR26yRXM8 Mr2snmxzyb0cPFIWJ8zy5bdDleDGz5aOZMXd8sk/6/rQicWrH5mftReG7i61SK10jRru81M3Onyi G0JMs0Yn3SxwRK3+sVI5FUbcGSSEs8f8fwbIt3a+RZ3GtrFOhuImaKaUPcskyCRohE2JC03lASqS SEWRkEkRirqpyfLFGNrI+dr6+gvrLxPA1tdQrGLWxvUVELp5iLLKgb/VyAXaI7JzukMJLK4Lnx68 uNK0XTLeT7BKuuPKbaGSYQm38q3YMzlD+8jeR49pkVwSolxuxmuqMvdaf6ktWOL1OLUGuJ9N0nS5 7q2jCNc20U8lw7xxebDLHItsSA0gDsQgRvLUlWC7HrzvWZ4rG6kl021M0ZieOC6xLsdEyG8p2HzF RCwYknG11A4G53WqexnL3Tirj7dc2Vobi/ljdpTNaKijEuCQdrcM2142APOGDc8YrHttCSG1urbz I5gzeWrOWxHICQGUr8oX94cvxnpxjNawd9bEuTWljrNF8Fy2STNHGYvlVCSg+Qc8+i4GCD/dYD/Z FTXtNt9LvIBGjNHLC44TYYy2UJGQDjgHaMgh8ZBzXrxgqdG990ZSlzyVzxLxHbC58Uw2+mqtxalI 4oFkXMj4XbIxzhXAkRsA8Y2ZX5gK7jwvZz26Sn7dcC2SaSO0jZtqW7SbWIiXOxAzMjcYIyuQMYbg qSvdI1Se50txNFa288sd0pmQsyxsgABiVeCDltwErKGwATkdc1cg03UXYrf2hhidBIjIz/L+8YNh WAyAwlBIB6YViORxyTva+5S01ehuSfubi68jy2QLGoEsm1mk4B2jHQEdSCPmyMjGMXWdZghheNbh zHIM7IjhiM7SM9UOfUc84zxUQSepV7KyM3Q21HWJI9tncPYo+TDuGyX5RlPVS4JQvuBCsyknqPoL wiPsyyPJp8btEokWOKBWhJQco/PAGOV+ueOuNdKSav8A19xcO7PvH4Ra5qRu7JLW1zqEEswjd/MA Xz0j3yARxkttjxGFMfl4RBuwqKP3t/4J9/He+8L+PfDt0dellFxHCJ7p1wsrJI6yxsqoR86+WoG4 tviP3g4YeDi04vnjutfuZvD4T+if40eHLbxf4SGvC2BtZodzruJPK4x9COMHHvyeP5iP26P2etLv 9RtfEX9hPM+nqZLcJ5hM0O2QPGSnzboy29MBjuUJtw2R9nhXOrhasqa+KLt81/mc/MqdeEpbdT+a rxlquueCNQ1DwyfMfVBH9hkJ3BYHV2KsgYA7SJN46Z3E8biK87fZNceN7W2nZp9F0y0WExDJ8xbq IykgHkLI8xDHso5xxURabjLpp+Lil+FzZwSvHvf8memN41m8bWUkunaJDbXNwq2iK1yzNNdSYBcD ChVBK7VAJAZzk/Lt7XVLTT7G0stMsoiYIIxGjuMMVRdu5gOFdiS7Y43Ox71vKVrx6HNbSMvUh8Pa efs13PFO3mPIcqxPzYzkDr3/AJ1sz64kCTx3F46BljDqASCo3Hk45wSOOfXtUrYHtqc/pUs91cSa hHbuDKfLhUj5iu7g498+nI+ortbm0W8vNOtnG5IYyCAcHdgkYXp7Z6/nS1WvqGljkNKN9qNxqmkT aLbXdlOq2TxXpOxlmPAAPQsFK/KQQMkHtXmM/gzQ/h5HcafoFuzwK7nzHdTJIzSbsHGOmdoA7AdT knq9mpRjBvqTzWbYknia4WKOGy1J4FVVLAyOVO7BA+nPfHWuU1uC+1gTajHfJPhsHZkFtuBnGOvP XNbq0LKUQ5pc3NTaNX4deIrzR/EWm2F9uWwmmVHQnIXp82D0IwDx9MV9af2/4e/5/wD/AMh//WrO pTqKV4RumKvWVVxct0tT6P0SSSbUNXaUJJGJlRWI5HyK3Pvksc+9dg8aSq5MXzcIgGOB0JB9BjP6 VnH4U2Q9NjD1/TrrWfCviix0qxeW7/s65lZIwW8uNInkeRsD5UVUZ2Y4CqpJIAzXPyX0pmWSwYvC cSlt3D5A/Tp0pPf1Kit5I8P+NXxK0H4Z+F9V8Y+L7yRdKtVDSNFGWZifuqqrnJOcdgO5ABNfjv4k /bQ0TxPK2laL4Xlj8OT3U0V9e3TDzESbdgrGCwHLA5LHhTxyMc04+0bSe25Se55h+y5rceneJrnT JTlEvjgsCBhyCvTvwfbFfoF+1FolnqOieEb3VdNa58NmSNbsxthklLL5OcMPkZhtOMEll7Zr57Hu VLFRqR0ad/nY9mg1UwyhLZnzrL8O9BvIbOC60mFbGNWEMcKhdm4DjevXOADg9xk169oXwk8J6F8J PH3iVtJAv4LK9S2LkyeXGkAdSik4D+Y8uD7L0xk64aXtKE5VHeS1v6kYiKpSfLs1+R+Z+s63ILm4 NratsKndvcZHvwT/AJzXhRvrq81B0cDLylOoIALYxnvXrwSPPvdnuGiXey7tMuV+7k56fKBjOfy+ tbXxq1OOb4bNCrL893BgZznAYjI/l/k1LScoPzX5lX9yR8VrycE89eO9f1w/8E6tH+J/hT9iX4df EHWvAMVl8N9I0y8vp9Z1jWrPT7W4tvtlzL5g3uJNp8xUUY3O20IDuFfUZNhpV51ZKaioK7cm0rfK 5x1qqpU+Zpu+miPq62/ajufEaeMPEMHgVtP0JFhEMrzgQ3108MckYgjIMkh/exsxcRgjztpYxyKu b8GZjf8AjCbVJybjVSZbtol8xkmuiRhcDIHmfLGMlPnIy2MBs8LiKGLxfPQmppPlulpdN3t33R25 hl+Ly10qOMpuEpwU0nuoy+G66Oyvbs0+p/ZV8Oruz/Z6/Yu8OajHatDeXGlxkxyTGV4pmhO8l9ke 9mZWbdsQDfkD5QD/ADM/tP8AxHj8R+INX1u31KWZmaS8jhM6nyNuY0IEHEQbbC33iSrooYjYI+/G ytVxFRfztfKOi/I8beqlbZfnqfkt4uvftt1b3cNo4Sd2kt4FmZlYgF2k+XO0ccsMZwSAAWx4dqs7 SRQxrujiKKxhyAOUYSBm+YD5vlyCNoO3BO4181X1bO+NjzS9u59TNySB5i7h5zqQSV42HnG0gkKU QhQXBOVAJcJBaWKXMSKrQIJWyowG+QZkA3BzlSowQQGQYHK1xbrUt7XOEbU9YlnhudEaK7eKWODy 9pLbiHZMIFGAux2zuPK5xtUEWdN1Rbaa5twzCzu5GmWDzG2O4LIjFVGMAOx+7gq+FGAdnVDSKS2s Re71OtgmNxLfyxqFgl2QQSxK2yIopVVCqAGJVVZn+U5jL8EjOBqOmRT29vHFbynWnmWJYoi+6YSM jRAlvlw8jIq7WXOzlSXyZavdF2sk1sasekX2hot/fWhi1CQWgt2meIQzSztHtcgbk8nkSbuW2x7A E3ybcG30/V0v3dAZkijinMouHSWVHkLJIzMW+YyDcwBYAtMMAINmHMtbqyH5s7e0OoTXGnr+/h0T y0lW9k8p5ZRLCvlMkz/Mo2HMe1vukhB81ewWkotIrK7+zkIsKRxS+Y/lIZFYIQiR72faMJ9/jJw4 KgYyY0eh+ErmTTPD2j22m27tqN/f+RLNeSWM0MCMJYJmKyjkN+9KkSxhY40fc7MjxfRfw/0XV9au 9KttH8LrD4oujJLp1pbwJMk7yOfPnt4tjtLEYw9qkSLIhcsApC7BjUe6+8uK6n25+z54a1XwvpV5 rtlqVvDqEVnc+VdpHMrxWgkgjkktLyAMkM5a8WQt5ispiEQcretA/wCn/wAG9BtfE2p2up/bLyDw 5pkhjJht4ZYbqVpjJfw27Rp5cAlDWkEYmSTefsUW6OKSFIOOb5vdubwWuh+y/gLwhdNo/hie9tWj 16V41uza5eO3lCMh3/c2IpCqyrJuIVM8EhvWovAum2NvY6TBFbRxqGcedGxbG9pGePaUYOXcs3Xl s8E89NOguS4pSPBfjf4P0K+87WIBAkqTwLbSkHjzRDBCEkAXyN8mzJLZfZGqsC6lPgTUNDgXT9YN vC0umtdX8MLmOVEW1aSOW2MUbOxVfs8kW3gFWikVi2FLc9VcrmuwO1k2fnN+0V4bOi+Iotei1CDd sI8sC5KlCHt3J2rziGe52x4BLbSSAmR+cXi/wcya7Z6UdMke5u5xcQR3Nt9nnkhucqkeJjm1UyTo WG4qCA8bLk1NJtQRDTZ8h+I9DZgLnWtNiTSoGJWS1jEZZZQ6pPIMbW3CJIkDKuxFVl2/6yvn3doU VlNfXlu16yz3MSW4MHk+U77IZlkb5NjNGEdMxlisa7kDrXUk3qQ1daHPXIme2stPJ8rVI7xZbaCW G0W0jQ2zTskUOG4lXy3ZyEi2RJxMDlPJfEWnmXTbvWo/M+1WtsI3eO78x1gCRLGWSWRnVGAIzwv7 yNkG3CHWF3oZt6nHaNoMk9xeOAy6c7I5mZW2QxM4TLOp8wx/MAwUMck4+bioZVOm7WguLiITrGLj yCCLpzIDtbdjZGY14U7juXIO1vl7nT5IqpYzTvLQ7O3udbvbJFs902sz4WGBInWSTjOcEYUnKpgn O4DgHk8n4iuUlvLe0+f+0WiMDgbMk7PKAUl/lYYyc4UE564xoqvMkv6sTy2WpxE3h9rC4GmyWUE1 7BeC7acxySS+WC+4KM7drMUJ3YPyxgbeM39A1W50fQbE3lravCzRQ3hkR3mMaf6to8MNxVhkHejM eDkAMuE3dvX+tWXbSxnTR313qgnGlQ3ukQpHJe20zbQmQZREZI38xCxZ2IjKlgOOSoXPsLmC5ttC mWyTzp5ALeCDzJyhV0LAZAIJZnBQkn/V4IBycWtL3HdN+aO6tXMoDjbLGkRlLbmRSo+UfMcMSPuj qxyB14rLl02K4YEMEd4BCZF2krtGZACpx8xJHTAznBwMzHa7Hfoze023nt41mll3T8ck9CFGPukA EAYXqBjhe49B0K+ncnYrRpCh3suNsYPyg/KM4LBQxAJO49SxNYTNU0tFufSfgrxpfQLDFPG8VyV2 XBF7IZN2Ew/yj5cbeSeCT2Ucfq18AfG81jcWdxa69Oq20YU2uk3DiWFHYIjEkgYG11KOw4mGwOwR a8jFwUlovwNINdT+tv8AZQ+JGm/Ej4XHwzLPDPeRo7Q+VIssITORsbc24LuRcH7oIBPXHgH7RvwP n8VaBr1jHaQm5jZymSVVyPm5xnhunfrz7/R8NVFOlCnLpo/69Dlxfw3P46v20v2a/E2m/FHSPH2h eHLi4VJZU1GzsLV52zb75PMaOFCyDy42Us3AEY6DAH5q/BuweTxL4o0bUYWj+2adNbJ8p4aVS0Zx xgE7DwOQR61rjXDDzr0INc0OR2vqlzOza87O3ez7Hdh37WeHnLaTa+drP5/5nfeE9Jj0260fQf3Y ubeWPUprvcC6TGI3OxOnybFhzwSHD4bDKB1NxMLiW6uQyH5wqktnp+PHOelHNzRbtv8Arsc1SHs5 8j6JL7jodLdbWwaHzcSq5IOCCD24/EVWvDHdXrlmR98pZ0Gd7bUUA9OhzgDr14He0vdM7d9jobOG 7tSzyOwkUN8qcLDngjAxzg/hjNZGn61dy3uq3EsIdlikMRbhmXIGMj2yeaElJsNkc/Z6Vo15qckt 6ly1yJIvvbD5Kq0ibTjHVgvuNvcGq/iG1sLuO9jGr77/AGAP5iHapJ9CTwAAucev0HoxVrSlG/8A kYt76nmeveHru3ujHDGslvjIkiw+4gDpjnPPIwMc9a5+fT9QsrK2njBSMnLSI3KDHIZRjB69fbmt HaVle4r21Ol8I3tvcaxpwurAT3ybTlRlJGySMDIJ449ee3b3r7U//QoD/vzL/wDHKys7+8yJTSen 9fgft/qP7IfgbwDq0mm+IviVc2c95bLqkZvLYIkkLLEissmNhOPLyAeN6k8MpPMeLfgv8LPBscJu /iuzLKqOphtwwKuu9SMeqkHNfX1uFadGF/aOx5tPM3Ua91diZPid4L/4VZq/wv8AghZJZeCLjTLm D4m/EG5t55byK2ZkgaCMhVZBNIXigtYRvdwn7wbZLivzquLPxXZ2muamnhvX9A8F2sqNBdXmkT3I SN5P3KtKqrEcholLDgs+1QMivgOIlXw9eU6KtFRa9IrZ9rt3Z9PglSnTiqj+Jp/5L+u55t43+E+k ftF+DNe8FzeJr6zt5PKke8ubYSvs3cCOEbVyxGASOAema8f8Lf8ABEDwxpXhO6+Imv8Ax2jg8KX9 w2n2tiVt47mcrgyeYoZwu0bsmMvhl24B5EcJ0J5pKrQrz2jzXvrulb8TPNoxwadaEd2lZeaPf/hp /wAEgfgJ4Kgk8VH4la8Z/kIeSIsJ3QFjlfIiKHGT15zxgVn/ABu+Enwu17wAfCXhfV9ZlaVWSdrm GBHjnjKshQo8qxgMmRuySAMLkGvXzfKMrp0m1Uk5pp6Ls+5xYXHY26p8iUfN9/I/NzxtoF54U1Cz 0U3MolSFJ0hkYF0BLY3lQAH2qDtPK7gCAQQPa/Cs9tr/AMK/FGnzSbvMS4RkJ/hkiwOMdMg4618V TiqVWvR3Wv4HvVm6uFjVkvM/GLWJdlzcFvvdGPP9P5/j2ryzQx5+pSPjhZZGJI6Y5/r+te5BOzPL W6PRdQkMKSEZBAABPvz29sfnXn3i3WL670kWs1y0kInVgpYkIQCP61UFqrik9zzJfmOQflH/AOuv 6AvD/wC0Dq3h39g34B6NqtxfXvhjyRDNpYtXmtb0W0sot4p3ZwkMYnWOTcMyBoYygB+YejTqyhQq xTdpct/PcmFk02k7NM+0IvFmr+MvCngfXfEJRdcfS7G91B9sattFsBZK3lMRFst5RIbZstBLc3ER d9oJ9y/Zo1FtU+J2j2cqxPJHJFKlpMGVSvmKdkjDoC43sDt3eSy9NynfJcHDLa2FwdN+7F6+bvd/ e7nq8RZ1Uz/NsZmtXebsv8MUox/8lS0P6Y/2zP2jZLPwJ8P/AA4sckVrBo8UtxbyJJuWEwx7ZSCr lnmeTMRCtlQF/dvmRP56vjZ4tt7orlllkm2nyQp2uMFEc8EEgh8lgMqy/Ku4mvUzJxhzxWur/Fs+ Xotym5bHxD4kv4Li4v71pQF8s/Z0IJGS+QiKTz0DFucd9pKk+E6zqktzvW2RjC0mJXULkMcLwPvK MhR0xkpxnIPzVRnoR2OKur+N5lidbc3EfzySR/MSr9j/AHcY24yBlT74n1mSKC3eW92qUi83ne7G YYUbS2Ap3HJY7QuwkFujclrz10/4YrW2p55HZS6fZSR3CRoJVEd0J1MkiM4GZAgIw3yseATtyDjI rd0rR7JfP1C9vluYoHeDyI4WR2dEWRpAEB42tghup37j8v7zqV0mzNd0aunwy+WNMS8S1upbczwh NxVcjeFwDw2xlCqinmTDFSM1qw7JCYYrGS7BItVNwQxkkJUESIv312uCoP3iiqwYOwVK7vfY1e1j rPDd/o8+sXenyC9Og3bgG3FzHLN5ULqwTzXjKh3DBsKowY3A4w9YHie6ttAtLYrrBuoraDzXliij dGZ/KXa5d8u4hmVQm1dqyTZX5Qx556yvYErJeZc0e4i1O60q1tLBIdb8uS7u87jGdzB2/wBZt2hI 0mcHe4XhSyumW9903UrldTtbN2XdbxXNpP5VyhliiBlEscU6qA5EcvlgbeQHB3KGFYSfd/8ADFLt c6DSHuU1PwJPqSXUWgWmpwraWUsZWKZBIqzMdy4Z9kaKRsO4KAxymD9hfBP4feKB4kkvXsd/madN NAkkjB57VYFu1uJI4riB2iaOSKZXeRUWNkn3tFCzDCeupcfI/Q34Y6JNqOmeD0ttA1OTSp76drOK 1nwbyeC23Ys4xEHc28Mscrv/AAw3BwUAaST9af2ftHtJteBs9PMelWl48scq6lJdy25aJAFjeMIr 2628fktIyoZkh81grWttt5Hv/X9am8T9kvCkMEOm2/lQRQpIN5iiQ8NgAHdgEjaoxkDgDHAxVu7t LOa6jkeDzWcMCZFLR9R1JyF+6OB3x7V7SS9jFGL3PGviqC1tc2sRmmiVVnkEKOGzDiRF3DJYsyjG Fk4U7uAa/PO2u4HtbnTLaAHT4yYrB8DdLCdzM27aNrg+WrszHcdgwAMt5WI+OXzL+zc/Pz9o7SWj sdM1T7Xd2r27mRbq2t0klLsQiZ3xlmiOCr4kiwRvLhUZW/J7xRoZv9dtNBEpury4jkFnuvIxtSKJ SPtbyyK4KpGiNEsq7MFlEhIrGk/du9v+HBvdHzzf6VLomqWrP4ubTPEst+Q1+MGFZCk4EvnxGSdi ig7kWNiT5Zyw2A/K99p0WqDTNCtN7abLeQ207pCDOQszW8bspx1AUeWWChnJBy5NdbTVu/4mXU5H xOltZX+oTahY+bYGJXa/ubrULiW1VmSO3YSx7VRvMYSEuQT9nZAsTL9mbzXUtEW8ubSHR/Eoa4vZ o4reVvIhk+1rcGOP5pDEISdsEvmNJIhDgkKSQm3NZ2I13OKtYp4/Fl1by6okdpcnznu4AkkIKrsk ceWSrqr7lCD5HLFGG0src/rWm3elXd7o32qzEaSNAPMIkYCN/MQlo9wO8Mqry4OSAyrlm6pVJOKj 2/4JHmupqyaoka6SYbdmhm2xMyoGMAZl3FTtYIrEHOQCdhAPBrltI0TUb+bVNbnSWTSILidI5Z2U SzF3DDI6ox6c5GYzgEYYFN6JLf8A4cUr21ZrT6UlvFDfzBE1Bt6LGHDkEBdwOCTyCuD0IB5wKqDR YZ0ksJbMJJIsAjOwDdIrogAx8ijJcseQFQjG4YOc5a6lLVXIdR0/VINcgt9E1Sfzric77byZWkAb cp+ZowjNsBfkKPmAz1A4LWZXsfsHhe0vVXTUjjSV44CHhkIJIxKoIIbJbbtDfNgsfnpPT5C67HTa Tpk7It5LqETLImD5C7UjWMKFX+8c4b5iMlgwPPJ6qz0i6NsbtkjSISOFieRN6kAbh5Wdw++Odpzt bBO1sYN8uz3KT6mrBZwSx8krKxYJkEZU4BxkAr2PYA5GScV0llFHCt66pCInTy5EbDMhDZwhIHJI GWUg7d2TgncrdEi17up7N4WtRoN5d6fPHJHe2kkiblgYHg/vCdyhsfIQFIDDjoxxX2N8O9dm0260
January 09, 2009 - Present
RV10-Archive.digest.vol-eb
