RV10-Archive.digest.vol-ee
January 27, 2009 - February 07, 2009
      http://www.chiefaircraft.com/airsec/Aircraft/ELT/Ameriking.html
      Michael
      -----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Tuesday, January 27, 2009 10:32 AM
Subject: Re: Ameri-King AK-451 ELT
Tim this brochure gives the detail you want. It looks like some dealers have very good discounts on this unit, under $600 http://www.seaerospace.com/lc/cart.php?target=productDetails&model=AK-451&substring=ak-451 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 27, 2009
Subject: Re: [Fwd: Re: Recall: RV-List: Improvements to "Hinged" wingtip
installation] Mark has a lot of cool little ideas. I've stole, er, ah, leveraged a few of his ideas including my hat shelf and baggage compartment lockers. :) Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters Sent: Tuesday, January 27, 2009 12:58 PM Subject: RV10-List: [Fwd: Re: Recall: RV-List: Improvements to "Hinged" wingtip installation] Forwarded to both RV and RV-10 lists! I saw and RV recently that had screws holding ALL of the tips. It was really done nice, but the first thought that flitted through my brain ..... how much extra weight from screws and nutplates and how much extra time spent installing them? I'm leaning to the carbinge for the wing tips, but the rest will be attached with pulled rivets like the plans call for. Linn http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=23961 Hi Linn- Here's a direct link to the section of my Expercraft website detailing the wingtip installation. It is a single entry with subsequent entries accessed by clicking on the "Next Entry>>" link at the top of the page. Oddly, I am replying to your post to the RV-list but only your address appears in my "To" window (borrowed Mac!) so if you'd like to forward this to the RV-list feel free to do so! Any questionds, gimme a holler... Mark ________________________________________________________________________________
Date: Jan 27, 2009
Kelly wrote: > > > You are probably correct. From their brochure, if what you say is true, > I would call it deceptive advertising. I would interpret the w/GPS to > actually have a built-in GPS, as opposed to just an interface. BWTFDIK. > Sure would be nice if the literature were clearer on the available options. > > -- Steve wrote: > > > Is 36 years as an avionics technician enough experience? > > -- I agree and had the exact same thought as you Kelly. Even had an email T'd up to that effect when I slapped myself and remembered this old thing sitting in front of me with a bunch of numbered buttons on it. I punched a few of them and was talking (loosley defined as I wouldn't call what I was hearing english) to their tech guy. Either way he was very clear on the differences between the units and that only the expensive one could take GPS data. And Steve, I certainly wasn't disregarding what you were saying but I also wasn't sure if you were quoting direct experience or the brochure as it really could have been interpreted either way. As the old saying goes, trust but verify. Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227193#227193 ________________________________________________________________________________
Date: Jan 27, 2009
Subject: Re: GRT and G530W
I am away from my records until the end of the week. There used to be two wires going to G530. There are four wires now. They all relate to ARINC stuff. I am guessing 4from memory, 8-49 going to 3 &4 on the GRT. On Tue, Jan 27, 2009 at 12:54 PM, Bill Mauledriver Watson wrote: > > > Thanks Rob. I'm in the process of installing and just downloaded the latest > diagram WD-1007-01. Which wires are new? > > Bill Watson > > Rob Kermanj wrote: >> >> >> FYI: >> >> According to GRT, their latest update will now enable the unit to do the >> entire approach (procedure turns/holds, the whole nine yards!) without >> flipping any switches for the Trutrak auto pilot input. This requires two >> additional wires between G530w and GRT. If you are in the planning/building >> stage, this is a good time to think about it. They have an updated wiring >> diagram. >> >> Rob >> >> >> >> >> >> > > -- Rob Kermanj ________________________________________________________________________________
Date: Jan 27, 2009
Subject: Re: FW: E04
Ask me a specific question .... maybe I can help. I don't see anything out of the ordinary .... but then I know what I'm looking at! Linn David McNeill wrote: > FYI. I am still trying to make sense of the diagram. > > ------------------------------------------------------------------------ > *From:* Mike Akatiff [mailto:MikeA(at)ackavionics.com] > *Sent:* Tuesday, January 27, 2009 11:56 AM > *To:* 'David McNeill' > *Subject:* RE: E04 > > Here it is > > > > ------------------------------------------------------------------------ > > *From:* David McNeill [mailto:dlm46007(at)cox.net] > *Sent:* Tuesday, January 27, 2009 10:39 AM > *To:* mikea(at)ackavionics.com > *Subject:* E04 > > > > wiring pdf please > ________________________________________________________________________________
Date: Jan 27, 2009
Tim Olson wrote: > > That's very cool that they have an In and an Out. Right now > I have a GPS signal split that goes to my APRS, also, so in the > case of the ELT, I'll probably change the APRS so that the ELT > gets the GPS signal and then outputs it to the APRS. It should > be almost nothing to change my wiring to support that plan. > Thanks for the update David. > > Tim Olson - RV-10 N104CD - Flying Tim, I'd just hook all the items needing GPS input directly to the GPS. Going through the ELT may (or may not depending on just how it's wired) cause a problem if the ELT fails, and you'd never know it. Linn ________________________________________________________________________________
Subject: Ameri-King AK-451 ELT
Date: Jan 27, 2009
AWESOME Imagination!!! Where does he find the time?> Subject: RE: RV10-List : Ameri-King AK-451 ELT> Date: Tue=2C 27 Jan 2009 18:05:28 -0500> From: rob in1(at)mrmoisture.com> To: rv10-list(at)matronics.com> > --> RV10-List message po sted by: "Robin Marks" > > Tim=2C> You have another option in case you go down. Searchers can just> go online to see your late st web postings of your trip with updated> crash photos and PIREPs on equip ment performance for off field landings.> I further expect by the time the rescue team located the site you will> have the whole Swill Family Robinson tree house thing going on with> Andria preparing lunch for the kids while they ride the stationary bike> you built to power the Satellite TV on your =======> > > ________________________________________________________________________________
Date: Jan 28, 2009
Subject: Re: Fw: Alternator failure
Suggest sending readers digest version of your story to Avweb for consideration as FBO of the week, and/or copy AirNav. FBOs see those comments and appreciate them. On Mon, Jan 26, 2009 at 12:04 PM, Bob-tcw wrote: > > ----- Original Message ----- > From: Bob-tcw > To: rv-list(at)matronics.com > Sent: Monday, January 26, 2009 12:19 PM > Subject: Alternator failure > Fellow builders, > > I'd like to share a little adventure we had last week and how it may > impact my RV-10 project. > My Dad and I were cruising along at 8500' enroute from PA down to FL in our > Glastar when I noticed an annoying red light on the instrument panel. That > little red light of course was a low voltage warning light, and sure enough > we were on battery power at that point, the alternator was doing nothing > useful at all. We requested a landing at Charlottesville VA, KCHO and > within 15 minutes were on the ground. They let us bring our airplane inside > a heated hangar to sort out our electrical problems. We'll we got the true > southern hospitality treatment. A mechanic came over and offered us the > use of any of his tools that we needed (although he was way to busy to work > on our plane). We removed the cowling and then the alternator and ohmed out > the field winding of the alternator, it appeared to be an open > circuit. The alternator was a Ford Motorcraft as originally supplied with > our 1960's vintage Lycoming 0-320. (however it had been rebuilt in > 2001, and now had about 350 hours of run time) We asked the mechanic if he > had any recommendations on a place to check and possibly replace our 'Ford' > alternator. He said, "Sure, I'll call Advanced Autoparts, I think they have > an alternator "spinner"". Sure enough, they did. So the mechanic gave us > the keys to his truck and we visited the aviation department of Advanced > Autoparts. Well the alternator was really dead and they actually had the > exact replacement in stock! So $57 later we were back on our way to the > airport. Well we put it all back together and sure enough we were back in > business, the aircraft bus voltage was back up to 14 volts!. We thanked > everyone over and over, took on some fuel and just over 2.5 hours after > discovering the problem we were back in the air. We were incredibly > fortunate that day to meet such wonderful folks as we did at KCHO. But we > also really enjoyed the benefits of building and flying a homebuilt. > There is no way that we would have been able to continue our journey that > day if we were flying a certified aircraft, There were no mechanics that > could spend their time working on our airplane on that day, And almost > certainly they would have had to order a new alternator (that wouldn't have > been $57!). > > So the lessons learned that I'm going to apply to my RV-10: > 1) Low voltage idiot lights work, they are a must have in my book > 2) Although we were able to safely make it to an alternate airport on > battery power, a back-up alternator equipped engine really ups the > convenience factor. We were incredibly lucky to get our airplane fixed and > flying again the same day. If we had a back-up alternator and were flying > VFR as we were, we would have probably just continued on our way to > Florida. > 3) Bring a decent tool kit, We had the very basic tools in our airplane > tool kit, but I'm now going to add a small DMM (multi-meter) to the kit. > 4) A condensed set of basic wiring schematics for the airplane could > have been a necessity. If the alternator wasn't the problem, I really > would have had a difficult time trouble shooting much more as I was working > completely from memory on how I wired the plane (almost 10 years ago). > > > Bob Newman > TCW Technologies, LLC. > www.tcwtech.com > RV-10 40176 - finish kit > > ________________________________________________________________________________
Subject: Door strut
Date: Jan 28, 2009
I have been having troubles, over time, with the door struts supplied by Van's becoming loose and allowing the door to fall and possible hit me or a passenger in the head, if we're not careful. I've talked to several people about this and they're having the same problem. A friend of mine who's on the same field as me, Ron Grover who also has a 10, ordered some stronger struts and that seems to have solved his problem. I just ordered a pair for me this morning and thought I would pass along the source for these in case any of you are having the same problem. Both Ron and I have full interiors with the doors being finished with arm rests, so that makes them a little heavier than others I'm sure. I ordered the struts from JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com. The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was $78 each. They didn't have them in stock, they come from Germany, and they said it would take 4 to 6 weeks to get them in. On another note, I had to fly from North Texas up to northern Iowa this past weekend for a funeral, burr cold, and ran into a problem that I thought I would pass along. On my way up I kept noticing that my slip ball was constantly out to the left so I had to keep applying left rudder. I usually don't have an issue with rudder so I was attributing some of it to strong cross winds. Sounded good. Anyway in leaving Iowa on Saturday, trying to get out ahead of a snow storm coming in, I pulled the plane out of the heated hangar space I rented into a minus 30 degrees wind-chill weather. Man after being in Texas for awhile I think I've turned into a Texas weenie, man that was cold. One positive of the cold was thick air and the plane was really liking to climb. I noticed again that I needed left rudder to keep the ball centered. We ended up with head winds and had to fly the last 100 miles in the dark. About 60 out from my home base I started to hear and feeling a fairly noticeable fluttering noise/feel. As you can imagine my wife, who isn't real thrilled with flying in the dark to begin with, thought the engine was coming off, well maybe not quit but close. I was obviously concerned because any time something flutters I think of control surfaces, but everything felt fine there and the engine parameters were all fine. So I just continued on home without making any quick movements and landed. The next morning I headed out to try and determine what was causing that problem. To make the story shorter I completely checked all surfaces and engine area and then, after talking to an A&P friend of mine, lifted up the plane and checked the tightness of the front wheel. I found that the wheel was fairly loose and could be pushed from side to side without much effort. Apparently over time the tension had loosened. The nut for the fork was in place but apparently over time in had just gotten more play. I tightened up the nut, took it out for a test flight and the vibration was gone and the ball was centered without help from the rudder. I have to assume that when I took off, the wheel pant cantered to one side thus caused the need for additional rudder and for some reason when I started to feel the flutter it had gone way to one side with the wind hitting it sideways causing the fluttering noise. Just thought I would pass this along in case any of you experience this same thing. I actually checked this wheel in June during my conditional before flying to Alaska and it was ok then. Maybe all those landings up there in the north country loosened it up. Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: hello all
Date: Jan 28, 2009
Welcome Dave, Sound like you and I are at about the same spot. I just purchased a QB wing/Fuse and am going over the plans to find out what the next step is (which is harder than I thought) Looks like it will be floor panels and baggage door. Its amazing how much work is done with the QB option. Kinda seems like if I put the lid on I could be flying tomorrow :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227340#227340 ________________________________________________________________________________
Date: Jan 28, 2009
Subject: Re: Door strut
Wayne, What's with you and them nosewheels=C2- :) does anyone recommend increasi ng the side pull tension initial set to more than 25 pounds? I plan to chec k it on a regular basis until the washers finally seat to each other.=C2- At what=C2- point can you=C2-stop checking the tension=C2- frequently ? Rick S. ----- Original Message ----- From: "Wayne Edgerton" <wayne.e(at)grandecom.net> Sent: Wednesday, January 28, 2009 7:37:03 AM GMT -08:00 US/Canada Pacific Subject: RV10-List: Door strut I have been having troubles, over time, with the door struts supplied by Va n's becoming loose and allowing the door to fall and possible hit me or a p assenger=C2-in the head, if we're not careful. I've talked to several peo ple about this and they're having the same problem. A friend of mine who's on the same field as me, Ron Grover who also has a 1 0, ordered some stronger struts and that seems to have solved his problem. I just ordered a pair for me this morning and thought I would pass along th e source for these in case any of you are having the same problem. Both Ron =C2-and I have full interiors with the doors being finished with arm rest s, so that makes them a little heavier than others I'm sure. I ordered the struts from JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com . The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was $78 eac h. They didn=99t have them in stock, they come from Germany, and they said it would take 4 to 6 weeks to get them in. On another note, I had to fly from North Texas up to northern Iowa this pas t weekend for a funeral, burr cold, and ran into a problem that I thought I would pass along. On my way up I kept noticing that my slip ball was const antly out to the left so I had to keep applying left rudder. I usually don' t have an issue with rudder so I was attributing some of it to strong cross winds. Sounded good. Anyway in=C2-leaving Iowa on Saturday, trying to get out ahead of a snow storm coming in, I pulled the plane out of the heated hangar space I rented into=C2-a minus 30 degrees wind-chill=C2-weather. Man after being in T exas for awhile I think I've turned into a Texas weenie, man that was cold. =C2-One positive of the cold was thick air and=C2-the plane was really liking to climb. I noticed again that I needed left rudder to keep the ball centered.=C2-We ended up with=C2-head winds and=C2-had to fly the la st=C2-100 miles in the dark.=C2- About 60 out from my home base I started to hear and feeling a fairly notic eable fluttering noise/feel. As you can imagine my wife, who isn't real thr illed with flying in the dark to begin with, thought the engine was coming off, well maybe not quit but close. I was=C2-obviously concerned because any time something flutters I think of control surfaces, but everything fel t fine there and the=C2-engine parameters were all=C2-fine. So I just continued on home without making any quick movements and landed. The next morning I headed out to try and determine what=C2-was causing th at problem. To make the story shorter I completely checked all surfaces and engine area and then, after talking to an A&P friend of mine, lifted up th e plane and checked the tightness of the front wheel. I found that the whee l was=C2-fairly loose and could be pushed from side to side without much effort. Apparently over time the tension had loosened. The nut for the fork was in place but apparently over time in had just gotten more play. I tigh tened up the nut, took it out for a test flight and the vibration was gone and the ball was centered without help from the rudder. I have to assume that when I took off, the wheel pant cantered to one side thus caused the need for additional rudder and for some reason when I start ed to feel the flutter it had gone way to one side with the wind hitting it sideways causing the fluttering noise. Just thought I would pass this along in case any of you experience this sam e thing. I actually checked this wheel in June during my conditional before flying to=C2-Alaska and it was ok then. Maybe all those landings up ther e in the north country loosened it up.=C2- Wayne Edgerton N602WT == ________________________________________________________________________________
Date: Jan 28, 2009
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Gascolator.
Topic of discussion at lunch today. Why isn't there a gascolator in the fuel injected systems? What would be the potential problems if there was one? Dr Fred. ________________________________________________________________________________
Subject: Door strut
Date: Jan 28, 2009
From: "George, Neal E Capt USAF ACC 605 TES/DOA" <Neal.George(at)hurlburt.af.mil>
The day after you sell it...? neal << At what point can you stop checking the tension frequently? Rick S. >> ________________________________________________________________________________
Date: Jan 28, 2009
Wayne, Do you know how many lbs of force these new struts have vs. how many lbs the struts have that came from vans? I was working on my doors/canopy recently and decided to measure the strut force on my van's supplied parts. I measured 120 lbs force required to compress the strut and thought that was an amazing amount of force even given the tight geometry of door/strut mounting brackets. thoughts?? Thanks, Bob Newman ----- Original Message ----- From: Wayne Edgerton To: rv10-list(at)matronics.com Sent: Wednesday, January 28, 2009 10:37 AM Subject: RV10-List: Door strut I have been having troubles, over time, with the door struts supplied by Van's becoming loose and allowing the door to fall and possible hit me or a passenger in the head, if we're not careful. I've talked to several people about this and they're having the same problem. A friend of mine who's on the same field as me, Ron Grover who also has a 10, ordered some stronger struts and that seems to have solved his problem. I just ordered a pair for me this morning and thought I would pass along the source for these in case any of you are having the same problem. Both Ron and I have full interiors with the doors being finished with arm rests, so that makes them a little heavier than others I'm sure. I ordered the struts from JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com. The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was $78 each. They didn't have them in stock, they come from Germany, and they said it would take 4 to 6 weeks to get them in. On another note, I had to fly from North Texas up to northern Iowa this past weekend for a funeral, burr cold, and ran into a problem that I thought I would pass along. On my way up I kept noticing that my slip ball was constantly out to the left so I had to keep applying left rudder. I usually don't have an issue with rudder so I was attributing some of it to strong cross winds. Sounded good. Anyway in leaving Iowa on Saturday, trying to get out ahead of a snow storm coming in, I pulled the plane out of the heated hangar space I rented into a minus 30 degrees wind-chill weather. Man after being in Texas for awhile I think I've turned into a Texas weenie, man that was cold. One positive of the cold was thick air and the plane was really liking to climb. I noticed again that I needed left rudder to keep the ball centered. We ended up with head winds and had to fly the last 100 miles in the dark. About 60 out from my home base I started to hear and feeling a fairly noticeable fluttering noise/feel. As you can imagine my wife, who isn't real thrilled with flying in the dark to begin with, thought the engine was coming off, well maybe not quit but close. I was obviously concerned because any time something flutters I think of control surfaces, but everything felt fine there and the engine parameters were all fine. So I just continued on home without making any quick movements and landed. The next morning I headed out to try and determine what was causing that problem. To make the story shorter I completely checked all surfaces and engine area and then, after talking to an A&P friend of mine, lifted up the plane and checked the tightness of the front wheel. I found that the wheel was fairly loose and could be pushed from side to side without much effort. Apparently over time the tension had loosened. The nut for the fork was in place but apparently over time in had just gotten more play. I tightened up the nut, took it out for a test flight and the vibration was gone and the ball was centered without help from the rudder. I have to assume that when I took off, the wheel pant cantered to one side thus caused the need for additional rudder and for some reason when I started to feel the flutter it had gone way to one side with the wind hitting it sideways causing the fluttering noise. Just thought I would pass this along in case any of you experience this same thing. I actually checked this wheel in June during my conditional before flying to Alaska and it was ok then. Maybe all those landings up there in the north country loosened it up. Wayne Edgerton N602WT ________________________________________________________________________________
Date: Jan 28, 2009
Rick, to answer your question about > 25lbs, that's what I did the 2nd or 3rd time I did mine. With that castlenut, I could choose between maybe 18-20lbs, or maybe 30-35lbs, so with the past experience, I chose the higher. Now when I did the Matco axle, I just did a guesstimate by hand and I'd say I was now in the 20's somewhere. So I'd err on the high side within reason, if you have to choose. Tim Olson - RV-10 N104CD - Flying Rick Sked wrote: > Wayne, > > > > What's with you and them nosewheels :) does anyone recommend increasing > the side pull tension initial set to more than 25 pounds? I plan to > check it on a regular basis until the washers finally seat to each > other. At what point can you stop checking the tension frequently? > > > > Rick S. > ----- Original Message ----- > From: "Wayne Edgerton" <wayne.e(at)grandecom.net> > To: rv10-list(at)matronics.com > Sent: Wednesday, January 28, 2009 7:37:03 AM GMT -08:00 US/Canada Pacific > Subject: RV10-List: Door strut > > I have been having troubles, over time, with the door struts supplied by > Van's becoming loose and allowing the door to fall and possible hit me > or a passenger in the head, if we're not careful. I've talked to several > people about this and they're having the same problem. > > A friend of mine who's on the same field as me, Ron Grover who also has > a 10, ordered some stronger struts and that seems to have solved his > problem. I just ordered a pair for me this morning and thought I would > pass along the source for these in case any of you are having the same > problem. Both Ron and I have full interiors with the doors being > finished with arm rests, so that makes them a little heavier than others > I'm sure. > > I ordered the struts from JWF Technologies, 6820 Fairfield Business > Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com. > > The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was $78 > each. They didnt have them in stock, they come from Germany, and they > said it would take 4 to 6 weeks to get them in. > > On another note, I had to fly from North Texas up to northern Iowa this > past weekend for a funeral, burr cold, and ran into a problem that I > thought I would pass along. On my way up I kept noticing that my slip > ball was constantly out to the left so I had to keep applying left > rudder. I usually don't have an issue with rudder so I was attributing > some of it to strong cross winds. Sounded good. > > Anyway in leaving Iowa on Saturday, trying to get out ahead of a snow > storm coming in, I pulled the plane out of the heated hangar space I > rented into a minus 30 degrees wind-chill weather. Man after being in > Texas for awhile I think I've turned into a Texas weenie, man that was > cold. One positive of the cold was thick air and the plane was really > liking to climb. I noticed again that I needed left rudder to keep the > ball centered. We ended up with head winds and had to fly the last 100 > miles in the dark. > > About 60 out from my home base I started to hear and feeling a fairly > noticeable fluttering noise/feel. As you can imagine my wife, who isn't > real thrilled with flying in the dark to begin with, thought the engine > was coming off, well maybe not quit but close. I was obviously concerned > because any time something flutters I think of control surfaces, but > everything felt fine there and the engine parameters were all fine. > > So I just continued on home without making any quick movements and > landed. The next morning I headed out to try and determine what was > causing that problem. To make the story shorter I completely checked all > surfaces and engine area and then, after talking to an A&P friend of > mine, lifted up the plane and checked the tightness of the front wheel. > I found that the wheel was fairly loose and could be pushed from side to > side without much effort. Apparently over time the tension had loosened. > The nut for the fork was in place but apparently over time in had just > gotten more play. I tightened up the nut, took it out for a test flight > and the vibration was gone and the ball was centered without help from > the rudder. > > I have to assume that when I took off, the wheel pant cantered to one > side thus caused the need for additional rudder and for some reason when > I started to feel the flutter it had gone way to one side with the wind > hitting it sideways causing the fluttering noise. > > Just thought I would pass this along in case any of you experience this > same thing. I actually checked this wheel in June during my conditional > before flying to Alaska and it was ok then. Maybe all those landings up > there in the north country loosened it up. > > Wayne Edgerton N602WT > > > > > > * > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Jan 28, 2009
I'm swapping my nose wheel out with Grove unit so I thought I'd ask before lowering the nose down. Sent via BlackBerry by AT&T -----Original Message----- From: Tim Olson <Tim(at)MyRV10.com> Date: Wed, 28 Jan 2009 13:16:42 Subject: Re: RV10-List: Door strut Rick, to answer your question about > 25lbs, that's what I did the 2nd or 3rd time I did mine. With that castlenut, I could choose between maybe 18-20lbs, or maybe 30-35lbs, so with the past experience, I chose the higher. Now when I did the Matco axle, I just did a guesstimate by hand and I'd say I was now in the 20's somewhere. So I'd err on the high side within reason, if you have to choose. Tim Olson - RV-10 N104CD - Flying Rick Sked wrote: > Wayne, > > > > What's with you and them nosewheels :) does anyone recommend increasing > the side pull tension initial set to more than 25 pounds? I plan to > check it on a regular basis until the washers finally seat to each > other. At what point can you stop checking the tension frequently? > > > > Rick S. > ----- Original Message ----- > From: "Wayne Edgerton" <wayne.e(at)grandecom.net> > To: rv10-list(at)matronics.com > Sent: Wednesday, January 28, 2009 7:37:03 AM GMT -08:00 US/Canada Pacific > Subject: RV10-List: Door strut > > I have been having troubles, over time, with the door struts supplied by > Van's becoming loose and allowing the door to fall and possible hit me > or a passenger in the head, if we're not careful. I've talked to several > people about this and they're having the same problem. > > A friend of mine who's on the same field as me, Ron Grover who also has > a 10, ordered some stronger struts and that seems to have solved his > problem. I just ordered a pair for me this morning and thought I would > pass along the source for these in case any of you are having the same > problem. Both Ron and I have full interiors with the doors being > finished with arm rests, so that makes them a little heavier than others > I'm sure. > > I ordered the struts from JWF Technologies, 6820 Fairfield Business > Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com. > > The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was $78 > each. They didnt have them in stock, they come from Germany, and they > said it would take 4 to 6 weeks to get them in. > > On another note, I had to fly from North Texas up to northern Iowa this > past weekend for a funeral, burr cold, and ran into a problem that I > thought I would pass along. On my way up I kept noticing that my slip > ball was constantly out to the left so I had to keep applying left > rudder. I usually don't have an issue with rudder so I was attributing > some of it to strong cross winds. Sounded good. > > Anyway in leaving Iowa on Saturday, trying to get out ahead of a snow > storm coming in, I pulled the plane out of the heated hangar space I > rented into a minus 30 degrees wind-chill weather. Man after being in > Texas for awhile I think I've turned into a Texas weenie, man that was > cold. One positive of the cold was thick air and the plane was really > liking to climb. I noticed again that I needed left rudder to keep the > ball centered. We ended up with head winds and had to fly the last 100 > miles in the dark. > > About 60 out from my home base I started to hear and feeling a fairly > noticeable fluttering noise/feel. As you can imagine my wife, who isn't > real thrilled with flying in the dark to begin with, thought the engine > was coming off, well maybe not quit but close. I was obviously concerned > because any time something flutters I think of control surfaces, but > everything felt fine there and the engine parameters were all fine. > > So I just continued on home without making any quick movements and > landed. The next morning I headed out to try and determine what was > causing that problem. To make the story shorter I completely checked all > surfaces and engine area and then, after talking to an A&P friend of > mine, lifted up the plane and checked the tightness of the front wheel. > I found that the wheel was fairly loose and could be pushed from side to > side without much effort. Apparently over time the tension had loosened. > The nut for the fork was in place but apparently over time in had just > gotten more play. I tightened up the nut, took it out for a test flight > and the vibration was gone and the ball was centered without help from > the rudder. > > I have to assume that when I took off, the wheel pant cantered to one > side thus caused the need for additional rudder and for some reason when > I started to feel the flutter it had gone way to one side with the wind > hitting it sideways causing the fluttering noise. > > Just thought I would pass this along in case any of you experience this > same thing. I actually checked this wheel in June during my conditional > before flying to Alaska and it was ok then. Maybe all those landings up > there in the north country loosened it up. > > Wayne Edgerton N602WT > > > > > > * > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Jan 28, 2009
does anyone now whether the 'footprint' on the small unit in the panel would be changed for the new gps-elt. i assume you would have to run a wire to the new elt from your gps. (long way to the tail!!) larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227409#227409 ________________________________________________________________________________
Date: Jan 28, 2009
The panel switch is compatible so you don't even change that. Also, I have a GPS signal to my APRS right next to the battery so in my case it's one short wire run and I'm done. Should maybe be a 1-2 hr project. Tim On Jan 28, 2009, at 5:16 PM, "lbgjb10" wrote: > > does anyone now whether the 'footprint' on the small unit in the > panel would be changed for the new gps-elt. i assume you would have > to run a wire to the new elt from your gps. (long way to the > tail!!) larry > > -------- > Larry and Gayle N104LG > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=227409#227409 > > ________________________________________________________________________________
Subject: Mistake on the Aft Deck: Fixed
Date: Jan 29, 2009
Hi Everyone, I've had a couple of people ask how I repaired the boo-boo on the aft deck. Last night I finally got around to repairing it and thought I'd share with the group. Maybe you'll have an opportunity to do something similar during your build. :) It sounds like a lot of work and definitely is not the simplest fix, but I have absolutely no concerns about the long term integrity of the repair. I can't claim credit for solution. David McNeill put me in touch with an A&P IA who sketched out the design and sent it to me Thanks David! Phil This is the original damage... You can see the longeron below and it's fine, but the aft deck skin was pretty messed up. The damage extended beyond an AD5 rivet and it's possible that an AN3 bolt probably wouldn't have fully removed it. http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3528 .jpg I was only 7 rivets into installing the aft deck when my screw up happened, so I went ahead and removed the entire deck. It made working on the pieces make easier. Once it was off the airplane, I removed the damaged area with a uni-bit and deburred the hole. It required a 5/16" hole to remove the damaged area. Next up was to create a 5/16" plug for the hole. The plug was made from .040 scrap and matches the same .040 thickness of the deck. My buddy is an A&P and he stopped by take part in the process. He did a great job of building a round plug that fits the hole perfectly! The first photo shows the plug and the sitting beside the hole. The second photo shows the plug sitting inside the hole. http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3531 .jpg http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3532 .jpg Next up was to re-create the rivet hole. We did this with a 90 degree drill and came up through the bottom of the longeron. To keep the plug from spinning, we taped it down with duct tape and applied pressure with a wooden block from the top. It worked pretty well. We were able to get 80% of the way through the plug before the tape gave and the plug started to spin. However the hole was started deep enough that we could finish drilling it out on the workbench. Looks pretty good! http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3534 .jpg Finally, we created a doubler out of .040 scrap (same thickness/strength as the deck skin). The doubler has 5 rivets. Obviously it's centered on the plug and we picked up the adjacent longeron rivets. Then we attached the doubler to the deck skin inboard of the longerons. We thought about adding two additional rivets by splitting the distance between the plug and the adjacent longeron rivets, but after looking at it closer we opted out of that decision. There isn't much clearance for rivet pitch (spacing) by splitting those holes. Sure we could have done it and it would have been fine by the book, but we would have been sitting a minimums. When we weighed that reality with the reality weakening the longeron by drilling additional holes - we decided it was better to leave well enough alone. On the inboard deck rivets, we chose to split them between the plug and the adjacent longeron rivets. This was by design to share the shear load between the plug rivet and it's adjacent longeron rivets. Here is the finished product. http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3535 .jpg ________________________________________________________________________________
Subject: Defrost fan steel mesh filter screens
Date: Jan 29, 2009
I ran across these the other day. The mesh screen covers would be a bit more attractive than some other alternatives I've seen discussed in the past. http://www.directron.com/smf80.html Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227521#227521 ________________________________________________________________________________
Date: Jan 29, 2009
Subject: Re: Defrost fan steel mesh filter screens
Those are neat looking. My solution is to get window screen (used to be able to get aluminum, but now all I find is fiberglass) and spray a wet coat of paint on it to match and protect the screen from UV. Linn jayb wrote: > > I ran across these the other day. The mesh screen covers would be a bit more attractive than some other alternatives I've seen discussed in the past. > > http://www.directron.com/smf80.html > > Regards, > Jay > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=227521#227521 > > > ________________________________________________________________________________
Subject: MT propeller and cowling work
Date: Jan 29, 2009
I have been told to not use the propeller and the spinner to do my cowl fii tting as it will most likely damage the finish of the spinner. Can anyone direct me to a source for how to make a plywood template and dir ection on how it comes together. I was told that this document exists=2C bu t I don't know it's source. Thanks=2C JOhn G. 409 ________________________________________________________________________________
Date: Jan 29, 2009
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Regardless of which direction you go, it turns out that the location where the fans are (at least in my install) aren't really that visible in the first place. Now, if you had chrome grills or something like that where they stood out it would certainly make a difference. I've got the grill area painted flat black and the covering I used on the glare shield is also flat black, fake leather. Unless you're looking for the fans, you really don't notice that they're there. Here's what I'm using for the glareshield cover and edging: http://www.cleavelandtoolstore.com/prodinfo.asp?number=GSF15 I've also heard that Abby also now makes glare shield covers and will put custom cutouts in for defrost fans. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb Sent: Thursday, January 29, 2009 12:01 PM Subject: RV10-List: Defrost fan steel mesh filter screens I ran across these the other day. The mesh screen covers would be a bit more attractive than some other alternatives I've seen discussed in the past. http://www.directron.com/smf80.html Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227521#227521 ________________________________________________________________________________
Date: Jan 29, 2009
Lynn - Check your local Ace Hardware. The one here in Navarre, FL keeps a roll of brass screen on the shelf. Not cheap, but it doesn't take much and it won't rust... Neal ============= Those are neat looking. My solution is to get window screen (used to be able to get aluminum, but now all I find is fiberglass) and spray a wet coat of paint on it to match and protect the screen from UV. Linn ________________________________________________________________________________
Subject: heads up
Date: Jan 29, 2009
When carrying four adults, be aware that one front seater should remain seated while back seaters deplane. While I stood on the wing this morning, the right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear and struck the bottom rudder fairing. Fortunately the damage seems limited to the bottom rudder fairing which will be replaced. Unfortunately I have not added the additional firewall avionics battery which probably would have eliminated this incident.. ________________________________________________________________________________
Date: Jan 29, 2009
Subject: RE: 406 MHZ ELT
Date: Jan 29, 2009
One consideration prior to replacing your old ELT or installing a 406 MHz unit in your new aircraft: FAR 91.207 (d) (4) requires annual inspection for the presence of sufficient signal radiated from the ELT antenna. This is not a big deal for the old 121.5 ELT's and only requires an aviation receiver. It is a big deal for the 406 MHz units as the test devices are almost $3K. Not every shop has one and the DIYers in the experimental arena probably don't have one yet. Might be a good purchase for the local EAA chapter. Also, in most cases the unit will have to be removed from the aircraft for testing, and enclosed in a Faraday shield to prevent a false data burst. The aircraft antenna would then be tested separately. I have heard the FCC aggressively prosecutes violators, and after registration they will know who you are and where you live. The double and triple ELT units that transmit on 121.5 MHZ, 406 MHz and 243 MHZ (military) frequencies simultaneously will satisfy the ELT requirement as you can still DIY test the 121.5 MHz signal. The 406 MHz burst theoretically occurs 50 seconds after the unit is triggered, so hopefully you could get the unit deactivated before that occurs. How this will be addressed in the future is unknown, and is one of the reasons the 121.5 MHz units are still permitted. Until the dust settles on this issue, I am keeping my old ELT for the FAR requirement, and purchased the ACR ResqFix PLB with on-board GPS. Thanks Tim for recommending this unit, $520 at Puget Sound Inflatables. Steve Roberts (still lurking while waiting for a suitable build location) N2700W 1966 Mooney M20E 'Ms. Obsession' KMOR Morristown, TN ________________________________________________________________________________
Date: Jan 29, 2009
Subject: Re: MT propeller and cowling work
John, I found it on the Van's web site. (Hunt around a bit) Applicable to all models. Easy to make and quite useful. Regards, Dave Lammers forever finishing John Gonzalez wrote: > I have been told to not use the propeller and the spinner to do my > cowl fiitting as it will most likely damage the finish of the spinner. > > Can anyone direct me to a source for how to make a plywood template > and direction on how it comes together. I was told that this document > exists, but I don't know it's source. > > Thanks, > > JOhn G. 409 > > ________________________________________________________________________________
Subject: Re: 406 MHZ ELT
Date: Jan 29, 2009
Steve, I recently discovered an easy way to do the signal radiation test. Several weeks ago I installed my Artex ME406 elt. About 9 PM that night I answered a knock on the door and was greeted by a very pleasant man from the Civil Air Patrol, holding his direction finder. I had inadvertently triggered my elt during installation and he had picked up the signal 10 miles away, ground to ground. This method is probably not FAA approved, but it is effective. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227590#227590 ________________________________________________________________________________
Date: Jan 29, 2009
Jay I ordered these quite a while ago. I've installed them in the forward fuse but am not yet flying. All I can say as to their effectiveness is they fit nice and look good. -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb Sent: Thursday, January 29, 2009 10:01 AM Subject: RV10-List: Defrost fan steel mesh filter screens I ran across these the other day. The mesh screen covers would be a bit more attractive than some other alternatives I've seen discussed in the past. http://www.directron.com/smf80.html Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227521#227521 __________ Information from ESET NOD32 Antivirus, version of virus signature database 3811 (20090129) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3811 (20090129) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Subject: Re: 'do not tow'
Date: Jan 29, 2009
Here is a sad towing story. Mary and I were bringing our airplane home from the paint shop. The maiden voyage! We stopped in Wichita to visit family and show off the airplane. I arranged to have it put into the hangar overnight and told the line manager I wanted to be there when they moved it. He was a sharp guy and came over and let me show him what the towing issues are. He said he was going to the other end of the airport to get another airplane and would move it when he got back. Elderly in-laws showed up and I got involved with them. Long story short, one of the other line guy's decided to hook up and move the airplane by himself. The results are attached. To make matters worse, he acted like he had not noticed the damage when he unhooked the airplane and went on his merry way! He is no longer employed, and my wheel pant is on it's way back to the paint shop and will be repaired and repainted on the FBO's nickle. [Crying or Very sad] -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227598#227598 Attachments: http://forums.matronics.com//files/img_0916_777.jpg http://forums.matronics.com//files/img_0914_314.jpg ________________________________________________________________________________
From: "John Hilger" <ninepapa(at)bendbroadband.com>
Date: Jan 29, 2009
Bob And Abby's glare shield covers with fan cutouts include the screens! John H ----- Original Message ----- From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com> Sent: Thursday, January 29, 2009 11:24 AM Subject: RE: RV10-List: Defrost fan steel mesh filter screens > > > Regardless of which direction you go, it turns out that the location > where the fans are (at least in my install) aren't really that visible > in the first place. Now, if you had chrome grills or something like > that where they stood out it would certainly make a difference. I've > got the grill area painted flat black and the covering I used on the > glare shield is also flat black, fake leather. Unless you're looking > for the fans, you really don't notice that they're there. > > Here's what I'm using for the glareshield cover and edging: > http://www.cleavelandtoolstore.com/prodinfo.asp?number=GSF15 > I've also heard that Abby also now makes glare shield covers and will > put custom cutouts in for defrost fans. > > Bob > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb > Sent: Thursday, January 29, 2009 12:01 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Defrost fan steel mesh filter screens > > > I ran across these the other day. The mesh screen covers would be a bit > more attractive than some other alternatives I've seen discussed in the > past. > > http://www.directron.com/smf80.html > > Regards, > Jay > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=227521#227521 > > > ________________________________________________________________________________
Date: Jan 30, 2009
I did some "hunting around" and found it on the Van's construction FAQ page. About half way down, titled Simulating the Propeller for fitting the Cowl <http://www.vansaircraft.com/public/confaq.htm> Larry Rosen Dave Lammers wrote: > John, > I found it on the Van's web site. (Hunt around a bit) Applicable to > all models. > Easy to make and quite useful. > Regards, > Dave Lammers > forever finishing > > John Gonzalez wrote: >> I have been told to not use the propeller and the spinner to do my >> cowl fiitting as it will most likely damage the finish of the spinner. >> >> Can anyone direct me to a source for how to make a plywood template >> and direction on how it comes together. I was told that this document >> exists, but I don't know it's source. >> >> Thanks, >> >> JOhn G. 409 >> * >> >> >> * > * > > > * ________________________________________________________________________________
Date: Jan 30, 2009
Subject: Re: RE: 406 MHZ ELT
Steve, You might want to look up in ac43.13 chapter 12 about checking ELTs. using a VHF radio. Patrick Thyssen One day I to will fly. --- On Thu, 1/29/09, Steven Roberts wrote: From: Steven Roberts <swrpilot(at)bellsouth.net> Subject: RV10-List: RE: 406 MHZ ELT Date: Thursday, January 29, 2009, 3:22 PM One consideration prior to replacing your old ELT or installing a 406 MHz unit in your new aircraft: - FAR 91.207 (d) (4) requires annual inspection for the presence of sufficient signal radiated f rom the ELT antenna. -This is not a big deal for the old 121.5 ELT=A2s and only requires an aviation receiver.- It is a big deal for the 406 MHz units as the test devices are almost $3K. -Not every shop has one and the DIYers in the experimental arena probably don=A2t have one yet. -Might be a good purchase for the local EAA chapter.- Also, in most cases the unit will have to be removed from the aircraft for testing, and enclosed in a Faraday shield to prevent a false data burst.- The aircraft antenna would then be tested separately. -I have heard the FCC aggressively prosecutes violators, and after registration they will know who you are and where you live. - The double and triple ELT units that transmit on 121.5 MHZ, 406 MHz and 243 MHZ (military) frequencies simultaneously will satisfy the ELT requirement as you can stil l DIY test the 121.5 MHz signal. The 406 MHz burst theoretically occurs 50 second s after the unit is triggered, so hopefully you could get the unit deactivate d before that occurs. - How this will be addressed in the future is unknown, and is one of the reasons the 121.5 MHz units are still permitted.- Until the dust settles on this issue, I am keeping my old ELT for the FAR requirement, and purchased the ACR ResqFix P LB with on-board GPS.- Thanks Tim for recommending this unit, $520 at Puget Sound Inflatables. - Steve Roberts (still lurking while waiting for a suitable build location) - N2700W 1966 Mooney M20E =A1Ms. Obsession=A2 KMOR Morristown , TN ________________________________________________________________________________
Date: Jan 30, 2009
My wheel pant too, was broken in half by an energetic line boy. As one who has suffered the same "low IQ and high authority" in a line boy, I think that this is one of those areas where we 10 owners just cannot allow others to handle our aircraft. Even after complete instructions they do not understand that the 10 is not a 20,000 lb corporate aircraft. It is painful to come out and see your brand new aircraft looking like that. My FBO bent over backwards to make it right, but no matter what they do, it cannot be made right. My heart goes out to you David. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dmaib(at)mac.com Sent: Thursday, January 29, 2009 7:47 PM Subject: RV10-List: Re: 'do not tow' Here is a sad towing story. Mary and I were bringing our airplane home from the paint shop. The maiden voyage! We stopped in Wichita to visit family and show off the airplane. I arranged to have it put into the hangar overnight and told the line manager I wanted to be there when they moved it. He was a sharp guy and came over and let me show him what the towing issues are. He said he was going to the other end of the airport to get another airplane and would move it when he got back. Elderly in-laws showed up and I got involved with them. Long story short, one of the other line guy's decided to hook up and move the airplane by himself. The results are attached. To make matters worse, he acted like he had not noticed the damage when he unhooked the airplane and went on his merry way! He is no longer employed, and my wheel pant is on it's way back to the paint shop and will be repaired and repainted on the FBO's nickle. [Crying or Very sad] -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227598#227598 Attachments: http://forums.matronics.com//files/img_0916_777.jpg http://forums.matronics.com//files/img_0914_314.jpg ________________________________________________________________________________
Subject: FW: Mistake on the Aft Deck: Fixed
Date: Jan 30, 2009
I tried to send this yesterday with embedded photo's but apparently the e-mail was too large with the attachments. So I'm resending with links to the appropriate photos. Thanks! Phil ________________________________ From: Perry, Phil Sent: Thursday, January 29, 2009 10:23 AM Subject: Mistake on the Aft Deck: Fixed Hi Everyone, I've had a couple of people ask how I repaired the boo-boo on the aft deck. Last night I finally got around to repairing it and thought I'd share with the group. Maybe you'll have an opportunity to do something similar during your build. :) It sounds like a lot of work and definitely is not the simplest fix, but I have absolutely no concerns about the long term integrity of the repair. I can't claim credit for solution. David McNeill put me in touch with an A&P IA who sketched out the design and sent it to me Thanks David! Phil This is the original damage... You can see the longeron below and it's fine, but the aft deck skin was pretty messed up. The damage extended beyond an AD5 rivet and it's possible that an AN3 bolt probably wouldn't have fully removed it. http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3528 .jpg ============ I was only 7 rivets into installing the aft deck when my screw up happened, so I went ahead and removed the entire deck. It made working on the pieces make easier. Once it was off the airplane, I removed the damaged area with a uni-bit and deburred the hole. It required a 5/16" hole to remove the damaged area. Next up was to create a 5/16" plug for the hole. The plug was made from .040 scrap and matches the same .040 thickness of the deck. My buddy is an A&P and he stopped by take part in the process. He did a great job of building a round plug that fits the hole perfectly! The first photo shows the plug and the sitting beside the hole. The second photo shows the plug sitting inside the hole. http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3531 .jpg http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3532 .jpg ============ Next up was to re-create the rivet hole. We did this with a 90 degree drill and came up through the bottom of the longeron. To keep the plug from spinning, we taped it down with duct tape and applied pressure with a wooden block from the top. It worked pretty well. We were able to get 80% of the way through the plug before the tape gave and the plug started to spin. However the hole was started deep enough that we could finish drilling it out on the workbench. Looks pretty good! http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3534 .jpg ============ Finally, we created a doubler out of .040 scrap (same thickness/strength as the deck skin). The doubler has 5 rivets. Obviously it's centered on the plug and we picked up the adjacent longeron rivets. Then we attached the doubler to the deck skin inboard of the longerons. We thought about adding two additional rivets by splitting the distance between the plug and the adjacent longeron rivets, but after looking at it closer we opted out of that decision. There isn't much clearance for rivet pitch (spacing) by splitting those holes. Sure we could have done it and it would have been fine by the book, but we would have been sitting a minimums. When we weighed that reality with the reality weakening the longeron by drilling additional holes - we decided it was better to leave well enough alone. On the inboard deck rivets, we chose to split them between the plug and the adjacent longeron rivets. This was by design to share the shear load between the plug rivet and it's adjacent longeron rivets. Here is the finished product. http://i141.photobucket.com/albums/r51/philperry9/RV-10%20Build/DSC_3535 .jpg ________________________________________________________________________________
Date: Jan 30, 2009
Subject: Re: heads up
This is why we always have the tail tie-down ring installed. - Bill DeRouchey N939SB --- On Thu, 1/29/09, David McNeill wrote: From: David McNeill <dlm46007(at)cox.net> Subject: RV10-List: heads up Date: Thursday, January 29, 2009, 12:39 PM When carrying four adults, be aware that one front-seater should remain s eated while back seaters deplane. While I stood on the wing this morning, t he right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear a nd struck the bottom rudder fairing. Fortunately the damage seems limited t o the bottom rudder fairing which will be replaced. Unfortunately I have no t added the additional firewall avionics battery which probably would have eliminated this incident.. ________________________________________________________________________________
Date: Jan 30, 2009
I-not so brilliantly-tested mine to the COSPAS satellite and hence test ed the process from beginning to end. - My remote activation switch was located on a removable section of the Stein panel linking to a harness through a large AMP connector. Somehow when I r emoved the panel it set off my ME406. The buzzer that came with the unit ha s a high pitch that only a dog can detect. After an unknown amount of time I sensed something was amiss and started frantically removing the screws in the tail fairing. Note that my aircraft was inside a metal hanger with the big doors opened not more than one foot. - About halfway through the 30 (or so) screws securing the tail fairing my ce ll phone rang. It was a Sergeant from the Air Force in Florida. I told him the story and all was well. Then I asked what was the overall response time and the process he follows. From onset it was 13 minutes and he had alread y called my Dad and Sara. We said goodbye. I removed another 10 screws and the cell phone rang again. This time it was a lady from Search and Rescue i n Alaska. I went through the story again except she wanted the long alphanu meric string to verify it was really me. Fortunately, I had my aircraft dia ry nearby with the ME406 documented. She said goodbye and warned me that th e Coast Guard would call next. - I relocated the remote switch to a fixed point to the left of my lower leg. Actually, all the emergency switches are located in a row at the same loca tion to keep the panel uncluttered: ELT, alt air, oil winter flap, alt stat ic air. AND - I pasted and sealed an extra ELT Beacon sticker to the side o f my registration placard so I could say the long alphanumeric code without opening up the tail fairing. - Guys, these new 406Mhz units work exceptionally well and there is a good pr ocess behind the alert. The 121.5Mhz units were seldom more than a comfort while you died and never a bargain at $200 (or so). Note that the 121.5 pro cess had a mandatory 8 hour wait for additional verification to filter out false signals. So, if you calculate a blood drip rate at .... - One item of concern with carrying a PLB as your 406Mhz device. As I remembe r the COSPAS packet or Beacon ID indicates-if the alert source is a Perso nal LB, Aviation LB, or Marine LB. The rescue process could be very differe nt if a PLB alert is sent for an aircraft in distress. - I sent an email to the ME406 Product Manager in early 2006 telling him to p rovide a pin for serial GPS data that we could optionally provide else the AmeriKings and Acks would chew his tail. He never answered. Well, we will s ee how the ME406 competes in the future. - Bill DeRouchey N939SB - --- On Thu, 1/29/09, Jim Berry wrote: From: Jim Berry <jimberry(at)qwest.net> Subject: RV10-List: Re: 406 MHZ ELT Date: Thursday, January 29, 2009, 4:00 PM Steve, I recently discovered an easy way to do the signal radiation test. Several weeks ago I installed my Artex ME406 elt. About 9 PM that night I answered a knock on the door and was greeted by a very pleasant man from the Civil Air Patrol, holding his direction finder. I had inadvertently triggered my elt during installation and he had picked up the signal 10 miles away, ground t o ground. This method is probably not FAA approved, but it is effective. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227590#227590 ________________________________________________________________________________
Date: Jan 30, 2009
Patrick, The old method won't work on the 406 MHz ELT's. That was the point I was trying to make. For one thing, 406 MHz is outside the frequency range of VHF airband receivers. Secondly, the old ELTs are amplitude modulated, the new ELTs are frequency modulated. Lastly, the old ELTs are a continuous wave analog tone, while the new ELT's are a short burst of digital data, very close to the way cellphone and wifi transmitters work. The short pulse allows a high power (five watt) signal from a very small battery. You need a special receiver to receive the signal and a digital processor to decode the data. That's what you get for 3 AMU's. (AMU is the American Monetary Unit or $1,000 US dollars. Also equivalent to one AJU, the American Jewelry Unit) :-) Steve Roberts (still lurking while waiting for a suitable build location) N2700W 1966 Mooney M20E 'Ms. Obsession' KMOR Morristown, TN _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen Sent: Friday, January 30, 2009 9:44 AM Subject: Re: RV10-List: RE: 406 MHZ ELT Steve, You might want to look up in ac43.13 chapter 12 about checking ELTs. using a VHF radio. Patrick Thyssen One day I to will fly. ________________________________________________________________________________
Subject: Dules Fuel Pump
Date: Jan 30, 2009
Anyone have a line on a good used 12 V Dukes Fuel Pump for my IO-540? I've been watching eBay for a while but they only show a new one and one damaged. Best, Lee Otto, RV-10 (installing fuel lines in fuselage) ci Embroidery lotto(at)ciembroidery.com (559) 651-8022 ________________________________________________________________________________
Subject: heads up
Date: Jan 30, 2009
Scott Schmitt has the same thing happen to him. We need a kickstand. :) ________________________________ From: Bill DeRouchey [mailto:billderou(at)yahoo.com] Sent: Friday, January 30, 2009 10:32 AM Subject: Re: RV10-List: heads up This is why we always have the tail tie-down ring installed. Bill DeRouchey N939SB --- On Thu, 1/29/09, David McNeill wrote: From: David McNeill <dlm46007(at)cox.net> Subject: RV10-List: heads up To: rv10-list(at)matronics.com Date: Thursday, January 29, 2009, 12:39 PM When carrying four adults, be aware that one front seater should remain seated while back seaters deplane. While I stood on the wing this morning, the right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear and struck the bottom rudder fairing. Fortunately the damage seems limited to the bottom rudder fairing which will be replaced. Unfortunately I have not added the additional firewall avionics battery which probably would have eliminated this incident.. 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jan 30, 2009
This has happened to many of us early on and was posted multiple times but it is good to repeat from time to time as it is sometimes difficult to read all the posts. My standard for loading is one person in back, one in front, then the second in back and finally the pilot. The issue arises when you have two in back and two people step up at the same time. That is like having two guys in the baggage compartment and two in the back seats. I also de-plane the same way. Also keep your tie-down in at all times. I have had it tip one other time but it just hit the tie down ring like previously mentioned. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________ From: Bill DeRouchey <billderou(at)yahoo.com> Sent: Friday, January 30, 2009 9:32:03 AM Subject: Re: RV10-List: heads up This is why we always have the tail tie-down ring installed. Bill DeRouchey N939SB --- On Thu, 1/29/09, David McNeill wrote: From: David McNeill <dlm46007(at)cox.net> Subject: RV10-List: heads up Date: Thursday, January 29, 2009, 12:39 PM When carrying four adults, be aware that one front seater should remain seated while back seaters deplane. While I stood on the wing this morning, the right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear and struck the bottom rudder fairing. Fortunately the damage seems limited to the bottom rudder fairing which will be replaced. Unfortunately I have not added the additional firewall avionics battery which probably would have eliminated this incident.. ________________________________________________________________________________
Date: Jan 30, 2009
It's actually really old news, going back all the way to the beginning of customer built RV-10's flying. There are at least maybe 8 or 10 that I know of that cracked their rudder fairings by doing this. Just don't put two people on the steps at the same time, or don't load the plane and put two passengers in the rear seats and then go bounding on to the steps and you should be ok. But it does take some remembering to be careful. Tim Olson - RV-10 N104CD - Flying Perry, Phil wrote: > Scott Schmitt has the same thing happen to him. > > We need a kickstand. :) > > ------------------------------------------------------------------------ > *From:* Bill DeRouchey [mailto:billderou(at)yahoo.com] > *Sent:* Friday, January 30, 2009 10:32 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: heads up > > This is why we always have the tail tie-down ring installed. > > Bill DeRouchey > N939SB > > > --- On *Thu, 1/29/09, David McNeill //* wrote: > > From: David McNeill <dlm46007(at)cox.net> > Subject: RV10-List: heads up > To: rv10-list(at)matronics.com > Date: Thursday, January 29, 2009, 12:39 PM > > When carrying four adults, be aware that one front seater should > remain seated while back seaters deplane. While I stood on the wing > this morning, the right seat passenger decided to deplane and > stepped on the rear dismount while the rear passengers remain > seated. The aircraft tilted to the rear and struck the bottom rudder > fairing. Fortunately the damage seems limited to the bottom rudder > fairing which will be replaced. Unfortunately I have not added the > additional firewall avionics battery which probably would have > eliminated this incident.. > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 30, 2009
Subject: Van's Whelen/ELT bracket
Whoever may have used this, where does it go and do you have the instructio ns that you can share. I don't think they are up on Tim's site. Michael ________________________________________________________________________________
Date: Jan 30, 2009
Steve, -I was not talking about the 406elt. You made a statement about the 121.5 elt that was not exactly correct. And those who still have 121.5 need to k now the correct- way to check their elts. -Pat Thyssen I will fly one day. --- On Fri, 1/30/09, Steven Roberts wrote: From: Steven Roberts <swrpilot(at)bellsouth.net> Subject: RV10-List: RE: 406 MHZ ELT Date: Friday, January 30, 2009, 11:27 AM Patrick, - The old method won=A2t work on the 406 MHz ELT=A2s. -That was the point I was trying to make.- For one thing, 406 MHz is outside the frequency range of VHF airband receivers. -Secondl y, the old ELTs are amplitude modulated, the new ELTs are frequency modulated. -Lastly, the old ELTs are a continuous wave analog tone, while the new ELT=A2s are a short burst of digital data, very close to the way cellphone and wifi transmitters work. -The short pulse allows a high power (five watt) signa l from a very small battery.- You need a special receiver to receive the signal and a digital processor to decode the data. -That=A2s what you get for 3 AMU=A2s. - (AMU is the American Monetary Unit or $1,000 US dollars. -Also equivalent to one AJU, the American Jewelry Unit ) J Steve Roberts (still lurking while waiting for a suitable build location) N2700W 1966 Mooney M20E =A1Ms. Obsession=A2 KMOR Morristown , TN - - From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen Sent: Friday, January 30, 2009 9:44 AM Subject: Re: RV10-List: RE: 406 MHZ ELT - Steve, You might want to look up in ac43.13 chapter 12 about checking ELTs. using a VHF radio. Patrick Thyssen One day I to will fly. - - ________________________________________________________________________________
Date: Jan 31, 2009
If you leave the tail tiedown loop in does it stop the fairing from hitting? Sent via BlackBerry by AT&T -----Original Message----- From: Tim Olson <Tim(at)myrv10.com> Date: Fri, 30 Jan 2009 16:31:39 Subject: Re: RV10-List: heads up It's actually really old news, going back all the way to the beginning of customer built RV-10's flying. There are at least maybe 8 or 10 that I know of that cracked their rudder fairings by doing this. Just don't put two people on the steps at the same time, or don't load the plane and put two passengers in the rear seats and then go bounding on to the steps and you should be ok. But it does take some remembering to be careful. Tim Olson - RV-10 N104CD - Flying Perry, Phil wrote: > Scott Schmitt has the same thing happen to him. > > We need a kickstand. :) > > ------------------------------------------------------------------------ > *From:* Bill DeRouchey [mailto:billderou(at)yahoo.com] > *Sent:* Friday, January 30, 2009 10:32 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: heads up > > This is why we always have the tail tie-down ring installed. > > Bill DeRouchey > N939SB > > > --- On *Thu, 1/29/09, David McNeill //* wrote: > > From: David McNeill <dlm46007(at)cox.net> > Subject: RV10-List: heads up > To: rv10-list(at)matronics.com > Date: Thursday, January 29, 2009, 12:39 PM > > When carrying four adults, be aware that one front seater should > remain seated while back seaters deplane. While I stood on the wing > this morning, the right seat passenger decided to deplane and > stepped on the rear dismount while the rear passengers remain > seated. The aircraft tilted to the rear and struck the bottom rudder > fairing. Fortunately the damage seems limited to the bottom rudder > fairing which will be replaced. Unfortunately I have not added the > additional firewall avionics battery which probably would have > eliminated this incident.. > ________________________________________________________________________________
Subject: Re: Van's Whelen/ELT bracket
Date: Jan 30, 2009
Michael, Mine is mounted 8" behind the baggage bulkhead on the left. Rivets to the upper and middle J channel with 8 pull rivets. I don't have the instruction sheet anymore, but it is stone simple. It will not fit on the right, but it would be easy to make a mirror image if you wanted one for elt and one for strobe pack. Jim Berry 40482 Finishing the finishing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227783#227783 ________________________________________________________________________________
Date: Jan 30, 2009
Yes, the old method WILL work on all ELTs. Point is there is NO regulatory requirement to test the ELT on anything but 121.5. All units still broadcast 121.5, as it is a requirement of the TSO. In fact 91.207 does not specify a frequency, so you are free to test its broadcast as you see fit(within the 5 min after hour). KM A&P/IA Steven Roberts wrote: > > Patrick, > > The old method wont work on the 406 MHz ELTs. That was the point I > was trying to make. For one thing, 406 MHz is outside the frequency > range of VHF airband receivers. Secondly, the old ELTs are amplitude > modulated, the new ELTs are frequency modulated. Lastly, the old ELTs > are a continuous wave analog tone, while the new ELTs are a short > burst of digital data, very close to the way cellphone and wifi > transmitters work. The short pulse allows a high power (five watt) > signal from a very small battery. You need a special receiver to > receive the signal and a digital processor to decode the data. Thats > what you get for 3 AMUs. > > (AMU is the American Monetary Unit or $1,000 US dollars. Also > equivalent to one AJU, the American Jewelry Unit) J > > Steve Roberts > > (still lurking while waiting for a suitable build location) > > N2700W 1966 Mooney M20E Ms. Obsession KMOR Morristown, TN > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Patrick > Thyssen > *Sent:* Friday, January 30, 2009 9:44 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: RE: 406 MHZ ELT > > Steve, > > You might want to look up in ac43.13 chapter 12 about checking ELTs. using a VHF radio. > > Patrick Thyssen > > One day I to will fly. > > > > ** > * * > > * > > > * ________________________________________________________________________________
Date: Jan 30, 2009
Subject: Re: Dules Fuel Pump
You probably can get one overhauled for much less than a new one. Many Mooney models use them for the IO-360 and I think TIO-540 engines. You could try www.lasar.com as one Mooney service center. Lee Otto wrote: > Anyone have a line on a good used 12 V Dukes Fuel Pump for my IO-540? > I've been watching eBay for a while but they only show a new one and > one damaged. > > > Best, > > > > Lee Otto, RV-10 (installing fuel lines in fuselage) > > ci Embroidery > > lotto(at)ciembroidery.com > > (559) 651-8022 > > > * > > > * ________________________________________________________________________________
Date: Jan 30, 2009
Well, some transport aircraft have retractable tail skids, more to prevent a hit from over-rotation. Wouldn't be surprised if a DC8-62 needed something, given how long it is. Perry, Phil wrote: > Scott Schmitt has the same thing happen to him. > > We need a kickstand. :) > > ------------------------------------------------------------------------ > *From:* Bill DeRouchey [mailto:billderou(at)yahoo.com] > *Sent:* Friday, January 30, 2009 10:32 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: heads up > > This is why we always have the tail tie-down ring installed. > > Bill DeRouchey > N939SB > > > --- On *Thu, 1/29/09, David McNeill //* wrote: > > From: David McNeill <dlm46007(at)cox.net> > Subject: RV10-List: heads up > To: rv10-list(at)matronics.com > Date: Thursday, January 29, 2009, 12:39 PM > > When carrying four adults, be aware that one front seater should > remain seated while back seaters deplane. While I stood on the > wing this morning, the right seat passenger decided to deplane and > stepped on the rear dismount while the rear passengers remain > seated. The aircraft tilted to the rear and struck the bottom > rudder fairing. Fortunately the damage seems limited to the bottom > rudder fairing which will be replaced. Unfortunately I have not > added the additional firewall avionics battery which probably > would have eliminated this incident.. > > * > > > * > > * > > 3D============================================ > href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List > 3D============================================ > href='3D"http://forums.matronics.com"'>http://forums.matronics.com > 3D============================================ > href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution > 3D============================================ > > * > * > > > * ________________________________________________________________________________
Date: Jan 30, 2009
I have the instructions but no way to post them electronically. I can either type them out here (there's 5 steps) or if you post or PM me a fax number I can send them that way. It gets installed between the F-1047C-L and F-1047D-L J-stiffeners, and between the F-1006 and f-1007 Frames, but closer to the F-1006. You slide it fore and aft to get a good fit. The outside face of the bracket's top flange goes against the bottom side of the 1047C stiffener, while the inside face of the bracket's bottom flange goes against the bottom side of the 1047D stiffener. The instructions have a drawing that makes this arrangement perfectly clear. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227784#227784 ________________________________________________________________________________
Date: Jan 30, 2009
I don't have the instructions on me, but I placed mine on the left side of the fuselage, about a foot behind the baggage compartment bulk head. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Friday, January 30, 2009 3:43 PM Subject: RV10-List: Van's Whelen/ELT bracket Whoever may have used this, where does it go and do you have the instructions that you can share. I don't think they are up on Tim's site. Michael ________________________________________________________________________________
Subject: heads up
Date: Jan 30, 2009
we used to fly a 747 combi DHA-AMS-IAH. Always at the AMS refueling, the announcement was made to remain seated until the tail stand was installed _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Friday, January 30, 2009 12:26 PM Subject: RE: RV10-List: heads up Scott Schmitt has the same thing happen to him. We need a kickstand. :) _____ From: Bill DeRouchey [mailto:billderou(at)yahoo.com] Sent: Friday, January 30, 2009 10:32 AM Subject: Re: RV10-List: heads up This is why we always have the tail tie-down ring installed. Bill DeRouchey N939SB --- On Thu, 1/29/09, David McNeill wrote: From: David McNeill <dlm46007(at)cox.net> Subject: RV10-List: heads up Date: Thursday, January 29, 2009, 12:39 PM When carrying four adults, be aware that one front seater should remain seated while back seaters deplane. While I stood on the wing this morning, the right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear and struck the bottom rudder fairing. Fortunately the damage seems limited to the bottom rudder fairing which will be replaced. Unfortunately I have not added the additional firewall avionics battery which probably would have eliminated this incident.. 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics .com/Navigator?RV10-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== ________________________________________________________________________________
Subject: Mistake on the aft deck
Date: Jan 30, 2009
I've been trying to send this fix out for a week and it's been unsuccessful. Apparently there is a problem with the e-mail, so I just posted it on VAF. Here's the link. http://www.vansairforce.com/community/showthread.php?t=39140 Phil ________________________________ From: Perry, Phil Sent: Sunday, January 25, 2009 8:55 PM Subject: RV10-List: Mistake on the aft deck Hi Everyone, I'm going to be sending this to Vans too.. Tonight I was riveting the aft deck to the longerons of the tailcone. In the process, I screwed up a rivet and tried drilling it out. At that point, Murphy slapped me on the back for a second time and I managed to drill adjacent to the original hole. The good news is that I just barely touched the surface of the longeron, so it's just fine. The damage has been limited to the aft deck only. In the photo's below, you can see the longeron on the bottom and you can see that I've polished out the error to try and reduce the possibility of cracking later. I've got a couple of options. 1) I can drill for a 5/32 rivet, but that won't completely remove the mistake. 2) I thought about drilling and replacing with an AN3 bolt - That might remove it. 3) I thought about drilling the hole to be perfectly round (in the aft deck only) and then placing rivets on either side of the hole. In this case, the screw up would be similar to a lightening hole. 4) Just drop a rivet in and keep going. 5) Start over again with an entirely new aft deck. (Obviously last resort if I can't find a reasonable repair) In the process of the mistake, I've been trying to figure out what the real purpose of the aft deck is.... (???) I'm guessing it is designed to keep the longerons from pull apart or pressing together in the aft end of the aircraft. Anyone have any thoughts? Thanks, Phil http://s141.photobucket.com/albums/r51/philperry9/RV-10%20Build/?action= view¤t=DSC_3522-1.jpg http://s141.photobucket.com/albums/r51/philperry9/RV-10%20Build/?action= view¤t=DSC_3528.jpg http://s141.photobucket.com/albums/r51/philperry9/RV-10%20Build/?action= view¤t=DSC_3523.jpg ________________________________________________________________________________
Subject: Van's tach
Date: Jan 30, 2009
I have dual lightspeed ignition, and now understand that it will not communicate with the Van's tach. So I ordered the tranducer. But upon receipt I then realized that with the backup SD20 Alternator mounted on the rear of the engine, there's no room to get the transducer to fit. Has ANYONE found a solution to this? Is there another way to provide the Van's tach with the required input. Thanks guys, Don McDonald -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227818#227818 ________________________________________________________________________________
Date: Jan 30, 2009
After having read about this before, I will probably mount a small piece of spring steel in the shape of a "U" at the tie down point using the tie down ring to hold it in place. Haven't decided where to get the spring steel yet, but that's my thought. Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: Scott Schmidt To: rv10-list(at)matronics.com Sent: Friday, January 30, 2009 3:07 PM Subject: Re: RV10-List: heads up This has happened to many of us early on and was posted multiple times but it is good to repeat from time to time as it is sometimes difficult to read all the posts. My standard for loading is one person in back, one in front, then the second in back and finally the pilot. The issue arises when you have two in back and two people step up at the same time. That is like having two guys in the baggage compartment and two in the back seats. I also de-plane the same way. Also keep your tie-down in at all times. I have had it tip one other time but it just hit the tie down ring like previously mentioned. Scott Schmidt scottmschmidt(at)yahoo.com ------------------------------------------------------------------------- ----- From: Bill DeRouchey <billderou(at)yahoo.com> To: rv10-list(at)matronics.com Sent: Friday, January 30, 2009 9:32:03 AM Subject: Re: RV10-List: heads up This is why we always have the tail tie-down ring installed. Bill DeRouchey N939SB --- On Thu, 1/29/09, David McNeill wrote: From: David McNeill <dlm46007(at)cox.net> Subject: RV10-List: heads up To: rv10-list(at)matronics.com Date: Thursday, January 29, 2009, 12:39 PM When carrying four adults, be aware that one front seater should remain seated while back seaters deplane. While I stood on the wing this morning, the right seat passenger decided to deplane and stepped on the rear dismount while the rear passengers remain seated. The aircraft tilted to the rear and struck the bottom rudder fairing. Fortunately the damage seems limited to the bottom rudder fairing which will be replaced. Unfortunately I have not added the additional firewall avionics battery which probably would have eliminated this incident.. ________________________________________________________________________________
Date: Jan 30, 2009
Jim Berry wrote: > It will not fit on the right, but it would be easy to make a mirror image if you wanted one for elt and one for strobe pack Vans sells this same part in mirror image for the right. Search the onlike catalog for F-10112-R -------- Chase Snodgrass, CFI Presidio, Texas www.flybigbend.com 40820/40821 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227830#227830 ________________________________________________________________________________
Date: Jan 30, 2009
Ok,- heres a Hint.. VHF, AM radio. -- Read AC43.13.chapter 12- Ask your Faa inspector. I did not read or ask one day on a part135 inspecti on. Patrick Thyssen --- On Fri, 1/30/09, Kelly McMullen wrote: From: Kelly McMullen <kellym(at)aviating.com> Subject: Re: RV10-List: RE: 406 MHZ ELT Date: Friday, January 30, 2009, 6:48 PM Yes, the old method WILL work on all ELTs. Point is there is NO regulatory requirement to test the ELT on anything but 121.5. All units still broadcas t 121.5, as it is a requirement of the TSO. In fact 91.207 does not specify a frequency, so you are free to test its broadcast as you see fit(within the 5 min after hour). KM A&P/IA Steven Roberts wrote: > > Patrick, > > The old method won=A2t work on the 406 MHz ELT=A2s. That was the point I was trying to make. For one thing, 406 MHz is outside the frequency range o f VHF airband receivers. Secondly, the old ELTs are amplitude modulated, the new ELTs are frequency modulated. Lastly, the old ELTs are a continuous wave analog tone, while the new ELT=A2s are a short burst of digital data, very close to the way cellphone and wifi transmitters work. The short pulse allows a high power ( five watt) signal from a very small battery. You need a special receiver to rece ive the signal and a digital processor to decode the data. That=A2s what you ge t for 3 AMU=A2s. > > (AMU is the American Monetary Unit or $1,000 US dollars. Also equivalent to one AJU, the American Jewelry Unit) J > > Steve Roberts > > (still lurking while waiting for a suitable build location) > > N2700W 1966 Mooney M20E =A1Ms. Obsession=A2 KMOR Morristown, TN > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Patrick Thysse n > *Sent:* Friday, January 30, 2009 9:44 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: RE: 406 MHZ ELT > > Steve, > > You might want to look up in ac43.13 chapter 12 about checking ELTs. usin g a VHF radio. > > Patrick Thyssen > > One day I to will fly. > > > ** > * * > > * > > > * ________________________________________________________________________________
Subject: weight & balance program
Date: Jan 31, 2009
Is there a weight & balance program for the 10 that anyone has written? I know there is an older one here http://www.matronics.com/searching/getmsg_script.cgi?INDEX=135332088?KEYS=weight_&_balance_program?LISTNAME=RV?HITNUMBER=2?SERIAL=0501037899?SHOWBUTTONS=YES but it doesn't allow any parameters to change without a password. -------- Dave Ford RV6 flying RV10 building Lake City, MI based at CAD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227851#227851 ________________________________________________________________________________
Date: Jan 31, 2009
Subject: Re: Van's tach
You need the 12" extension. I believe you can get just the extension and add it to the transducer. Part number is IE VTACH EXT12 PJ Seipel RV-10 #40032 partner14 wrote: > > I have dual lightspeed ignition, and now understand that it will not communicate with the Van's tach. So I ordered the tranducer. But upon receipt I then realized that with the backup SD20 Alternator mounted on the rear of the engine, there's no room to get the transducer to fit. > Has ANYONE found a solution to this? Is there another way to provide the Van's tach with the required input. > Thanks guys, Don McDonald > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=227818#227818 > > > ________________________________________________________________________________
Date: Jan 31, 2009
You can see that setup on many a Cessna, combo tail skid and tiedown ring. Heck, even my Mooney has a tail skid. Helps when pilot gets confused and tries to land it like a taildragger. ;-) On Fri, Jan 30, 2009 at 9:45 PM, Dave Leikam wrote: > After having read about this before, I will probably mount a small piece of > spring steel in the shape of a "U" at the tie down point using the tie down > ring to hold it in place. Haven't decided where to get the spring steel > yet, but that's my thought. > > Dave Leikam > RV-10 #40496 > N89DA (Reserved) > Muskego, WI > > ----- Original Message ----- > From: Scott Schmidt > To: rv10-list(at)matronics.com > Sent: Friday, January 30, 2009 3:07 PM > Subject: Re: RV10-List: heads up > This has happened to many of us early on and was posted multiple times but > it is good to repeat from time to time as it is sometimes difficult to read > all the posts. > My standard for loading is one person in back, one in front, then the second > in back and finally the pilot. > The issue arises when you have two in back and two people step up at the > same time. That is like having two guys in the baggage compartment and two > in the back seats. > I also de-plane the same way. Also keep your tie-down in at all times. I > have had it tip one other time but it just hit the tie down ring like > previously mentioned. > > > Scott Schmidt > scottmschmidt(at)yahoo.com > > > ________________________________ > From: Bill DeRouchey <billderou(at)yahoo.com> > To: rv10-list(at)matronics.com > Sent: Friday, January 30, 2009 9:32:03 AM > Subject: Re: RV10-List: heads up > > This is why we always have the tail tie-down ring installed. > > Bill DeRouchey > N939SB > > --- On Thu, 1/29/09, David McNeill wrote: > > From: David McNeill <dlm46007(at)cox.net> > Subject: RV10-List: heads up > To: rv10-list(at)matronics.com > Date: Thursday, January 29, 2009, 12:39 PM > > When carrying four adults, be aware that one front seater should remain > seated while back seaters deplane. While I stood on the wing this morning, > the right seat passenger decided to deplane and stepped on the rear dismount > while the rear passengers remain seated. The aircraft tilted to the rear and > struck the bottom rudder fairing. Fortunately the damage seems limited to > the bottom rudder fairing which will be replaced. Unfortunately I have not > added the additional firewall avionics battery which probably would have > eliminated this incident.. > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ________________________________________________________________________________
Date: Jan 31, 2009
Precisely. Been doing it that way for years. That is what I meant by old method. In fact that method was first demonstrated to me by an avionics shop over 20 years ago. Keep in mind that the FAA works in strange ways, and hasn't updated 43.13-1B in 8 years. I won't hold my breath as to how long before they update an AC for 406 ELTs. Like the AIM, ACs are good guidance, but they aren't the reg, (except for GPSs). 2009/1/31 Patrick Thyssen : > Ok, heres a Hint.. > VHF, AM radio. Read AC43.13.chapter 12 > Ask your Faa inspector. I did not read or ask one day on a part135 > inspection. > Patrick Thyssen > > --- On Fri, 1/30/09, Kelly McMullen wrote: > > From: Kelly McMullen <kellym(at)aviating.com> > Subject: Re: RV10-List: RE: 406 MHZ ELT > To: rv10-list(at)matronics.com > Date: Friday, January 30, 2009, 6:48 PM > > > Yes, the old method WILL work on all ELTs. Point is there is NO regulatory > requirement to test the ELT on anything but 121.5. All units still broadcast > 121.5, as it is a requirement of the TSO. In fact 91.207 does not > specify a > frequency, so you are free to test its broadcast as you see fit(within the 5 > min > after hour). > KM > A&P/IA > Steven Roberts wrote: >> >> Patrick, >> >> The old method won't work on the 406 MHz ELT's. That was the point I > was trying to make. For one thing, 406 MHz is outside the frequency range of > VHF > airband receivers. Secondly, the old ELTs are amplitude modulated, the new > ELTs > are frequency modulated. Lastly, the old ELTs are a continuous wave analog > tone, > while the new ELT's are a short burst of digital data, very close to the way > cellphone and wifi transmitters work. The short pulse allows a high power > (five > watt) signal from a very small battery. You need a special receiver to > receive > the signal and a digital processor to decode the data. That's what you get > for > 3 AMU's. >> >> (AMU is the American Monetary Unit or $1,000 US dollars. Also equivalent > to one > AJU, the American Jewelry Unit) J >> >> Steve Roberts >> >> (still lurking while waiting for a suitable build location) >> >> N2700W 1966 Mooney M20E 'Ms. Obsession' KMOR Morristown, TN >> >> ------------------------------------------------------------------------ >> >> *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Patrick Thyssen >> *Sent:* Friday, January 30, 2009 9:44 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* Re: RV10-List: RE: 406 MHZ ELT >> >> Steve, >> >> You might want to look up in ac43.13 chapter 12 about checking ELTs. using > a VHF radio. >> >> Patrick Thyssen >> >> One day I to will fly. >> >> >> ** >> * * >> >> * >> >> >> > -= --> > > ________________________________________________________________________________
Date: Jan 31, 2009
I just faxed a copy to Jesse so he can post. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227873#227873 ________________________________________________________________________________
Date: Jan 31, 2009
Subject: test - please ignore
-- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction ________________________________________________________________________________
Date: Jan 31, 2009
Subject: Tru Trak (RV-10) roll servo stop plate
Tru Trak's RV-10 roll servo installation diagram is at <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. In the first photo, item "F" is the servo stop plate. That stop plate is held on by two little 6-32 screws, 1/4" long, which only engage about one thread (!) into the servo body (due to the short 1/4" length of the screws and the AN960-10 washer spacer called out in step F). I'm not very comfortable with this arrangement. Only a single thread engagement (1 turn of the screw) leaves me feeling there's risk of the screw stripping and/or backing out and leaving the stop plate not properly attached. I don't like the picture of the stop plate rattling around where it can jam the aircraft roll control. For those who have installed this system and gotten it flying, do you find that the stop plate is needed, or does the RV-10's aileron stop system keep the servo arm from running up to the stops provided by the servo's stop plate? Have others taken steps to better secure the stop plate? Thanks, Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction ________________________________________________________________________________
Subject: Re: Tru Trak (RV-10) roll servo stop plate
Date: Jan 31, 2009
Tim Thanks for mentioning this. I just checked mine and I got two turns on those screws. Another 1/8" or 1/4" would be better. As I understand it, the stop plate is there to prevent any part of the linkage from going "over center". This would cause the servo to lockup when it reverses, Not a Good Idea. Check with Tru Track they might have longer screws. John H ----- Original Message ----- From: "Tim Lewis" <timrvator(at)comcast.net> Sent: Saturday, January 31, 2009 12:39 PM Subject: RV10-List: Tru Trak (RV-10) roll servo stop plate > > Tru Trak's RV-10 roll servo installation diagram is at > <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. > > In the first photo, item "F" is the servo stop plate. That stop plate is > held on by two little 6-32 screws, 1/4" long, which only engage about one > thread (!) into the servo body (due to the short 1/4" length of the > screws and the AN960-10 washer spacer called out in step F). I'm not very > comfortable with this arrangement. Only a single thread engagement (1 > turn of the screw) leaves me feeling there's risk of the screw stripping > and/or backing out and leaving the stop plate not properly attached. I > don't like the picture of the stop plate rattling around where it can jam > the aircraft roll control. > > For those who have installed this system and gotten it flying, do you find > that the stop plate is needed, or does the RV-10's aileron stop system > keep the servo arm from running up to the stops provided by the servo's > stop plate? Have others taken steps to better secure the stop plate? > > Thanks, > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1000 hrs > RV-10 #40059 under construction > > > ________________________________________________________________________________
Date: Jan 31, 2009
Tim, I cannot answer your question, but I looked at my installation (not yet flying) and I do not have the roll stop installed. If you look at Tim Olson's installation and he also does not have the roll stop <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html>, but Deems does <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html> Also, I do not have the stop installed on the pitch servo, but Tim Olson does <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html>, but the Tru Trak RV-10 installation photos do not show it. Deems does not have the pitch control stops installed <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html> Now I am even more confused than usual. I guess a call to Tru Trak on Monday is called for. Larry Rosen #356 Tim Lewis wrote: > > Tru Trak's RV-10 roll servo installation diagram is at > <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. > > In the first photo, item "F" is the servo stop plate. That stop plate > is held on by two little 6-32 screws, 1/4" long, which only engage > about one thread (!) into the servo body (due to the short 1/4" > length of the screws and the AN960-10 washer spacer called out in step > F). I'm not very comfortable with this arrangement. Only a single > thread engagement (1 turn of the screw) leaves me feeling there's risk > of the screw stripping and/or backing out and leaving the stop plate > not properly attached. I don't like the picture of the stop plate > rattling around where it can jam the aircraft roll control. > > For those who have installed this system and gotten it flying, do you > find that the stop plate is needed, or does the RV-10's aileron stop > system keep the servo arm from running up to the stops provided by the > servo's stop plate? Have others taken steps to better secure the > stop plate? > > Thanks, > > Tim > ________________________________________________________________________________
Date: Jan 31, 2009
Subject: Re: Mistake on the aft deck
Date: Jan 31, 2009
Subject: Deburring
I have just started building the VS and I have a question about deburring technique. I have used the scotchbrite wheel t do most of the outside edges and this works well. I have used the deburring tool with the swivelling blade to do the lightening holes but how do I do the notches around the ribs? I used a needle file but very tedious - is there a better way or d these notches not need to be done? Thanks ________________________________________________________________________________
Date: Feb 01, 2009
Keep in mind that the photos on that first link are from 2004...2 years before I flew. Somewhere in early Feb 2006 you should see an update where I added the stops, as the new kit of parts came out. Either right before or right after first flight, I had to redo the aileron servo linkages with new parts because the added the stops. I think they had incidents of jammed aileron servos due to linkage travelling to far, so they made length changes and hard stops. I would absolutely add the stops. Although, I don't remember the screw length being an issue at that time. I'd call them and ask how long you can use and then report back here for your RV10 buds. Tim On Jan 31, 2009, at 9:18 PM, Larry Rosen wrote: > > Tim, > I cannot answer your question, but I looked at my installation (not > yet flying) and I do not have the roll stop installed. If you look > at Tim Olson's installation and he also does not have the roll stop <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html > >, > but Deems does <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html > > > > Also, I do not have the stop installed on the pitch servo, but Tim > Olson does <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html > >, but the Tru Trak RV-10 installation photos do not show it. Deems > does not have the pitch control stops installed <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html > > > > Now I am even more confused than usual. I guess a call to Tru Trak > on Monday is called for. > > Larry Rosen > #356 > > Tim Lewis wrote: >> >> Tru Trak's RV-10 roll servo installation diagram is at <http://www.trutrakap.com/documents/RV10RollInstallation.pdf >> >. >> >> In the first photo, item "F" is the servo stop plate. That stop >> plate is held on by two little 6-32 screws, 1/4" long, which only >> engage about one thread (!) into the servo body (due to the short >> 1/4" length of the screws and the AN960-10 washer spacer called out >> in step F). I'm not very comfortable with this arrangement. Only >> a single thread engagement (1 turn of the screw) leaves me feeling >> there's risk of the screw stripping and/or backing out and leaving >> the stop plate not properly attached. I don't like the picture of >> the stop plate rattling around where it can jam the aircraft roll >> control. >> >> For those who have installed this system and gotten it flying, do >> you find that the stop plate is needed, or does the RV-10's aileron >> stop system keep the servo arm from running up to the stops >> provided by the servo's stop plate? Have others taken steps to >> better secure the stop plate? >> >> Thanks, >> >> Tim >> > > ________________________________________________________________________________
Date: Feb 01, 2009
Subject: Re: Deburring
Doug, I find the cloth type sanding paper the best as it doesn't tear and c an easily be folded to get into the notches.=C2- I normally use around 24 0 grit and tear off a 1" wide x 3" piece and slide it through the notches a couple of time to debur.=0A=0APatrick Pulis=0AAdelaide, South Australia=0A =0A=0A=0A=0A________________________________=0AFrom: Doug Gee <Doug.Gee@fir estone-textiles.com>=0ATo: rv10-list(at)matronics.com=0ASent: Sunday, 1 Februa ry, 2009 3:09:16 PM=0ASubject: RV10-List: Deburring=0A=0A--> RV10-List mess age posted by: "Doug Gee" <Doug.Gee@firestone-textiles.com>=0A=0AI have jus t started building the VS and I have a question about deburring technique. =C2- I have used the scotchbrite wheel t do most of the outside edges and this works well.=C2- I have used the deburring tool with the swivelling blade to do the lightening holes but how do I do the notches around the rib s?=C2- I used a needle file but very tedious - is there a better way or d ==C2- =C2- =C2- =C2- =C2- =C2- - List Contribution Web Site - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2 =====================0A=0A=0A Make Yahoo!7 your homepage and win a trip to the Quiksilver Pro. Find out m ore ________________________________________________________________________________
Subject: Re: Nitrogen in Tires
Date: Feb 01, 2009
If water vapor is the problem, wouldn't it be easier to just get the water vapor out during compression of the air? It's a fairly straightforward process. Scuba divers use it all the time while filling up their tanks with air. ... my 2c Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227970#227970 ________________________________________________________________________________
Date: Feb 01, 2009
It looks like Tim Olson used the hardware from <http://www.trutrakap.com/documents/RV-710RightWing.pdf>. This setup doesn't use the "RV-10 Attach Plate" called out in step "c" of <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. Alex De Dominicis told me the RV-10 Attach Plate is essentially a torque enhancer for more autopilot authority in rough air. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction Larry Rosen wrote: > > Tim, > I cannot answer your question, but I looked at my installation (not > yet flying) and I do not have the roll stop installed. If you look at > Tim Olson's installation and he also does not have the roll stop > <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html>, > but Deems does > <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html> > > > Also, I do not have the stop installed on the pitch servo, but Tim > Olson does > <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html>, > but the Tru Trak RV-10 installation photos do not show it. Deems does > not have the pitch control stops installed > <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html> > > Now I am even more confused than usual. I guess a call to Tru Trak on > Monday is called for. > > Larry Rosen > #356 > > Tim Lewis wrote: >> >> Tru Trak's RV-10 roll servo installation diagram is at >> <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. >> >> In the first photo, item "F" is the servo stop plate. That stop >> plate is held on by two little 6-32 screws, 1/4" long, which only >> engage about one thread (!) into the servo body (due to the short >> 1/4" length of the screws and the AN960-10 washer spacer called out >> in step F). I'm not very comfortable with this arrangement. Only a >> single thread engagement (1 turn of the screw) leaves me feeling >> there's risk of the screw stripping and/or backing out and leaving >> the stop plate not properly attached. I don't like the picture of >> the stop plate rattling around where it can jam the aircraft roll >> control. >> >> For those who have installed this system and gotten it flying, do you >> find that the stop plate is needed, or does the RV-10's aileron stop >> system keep the servo arm from running up to the stops provided by >> the servo's stop plate? Have others taken steps to better secure >> the stop plate? >> >> Thanks, >> >> Tim >> > > ________________________________________________________________________________
Date: Feb 01, 2009
Here is a link to just before first flight time, when I changed the linkage and added the stops...they had just come out that week I think. http://www.myrv10.com/N104CD/finishing/20060208/index.html Tim Larry Rosen wrote: > > Tim, > I cannot answer your question, but I looked at my installation (not yet > flying) and I do not have the roll stop installed. If you look at Tim > Olson's installation and he also does not have the roll stop > <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html>, > but Deems does > <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html> > > > Also, I do not have the stop installed on the pitch servo, but Tim Olson > does > <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html>, > but the Tru Trak RV-10 installation photos do not show it. Deems does > not have the pitch control stops installed > <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html> > > Now I am even more confused than usual. I guess a call to Tru Trak on > Monday is called for. > > Larry Rosen > #356 > > Tim Lewis wrote: >> >> Tru Trak's RV-10 roll servo installation diagram is at >> <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. >> >> In the first photo, item "F" is the servo stop plate. That stop plate >> is held on by two little 6-32 screws, 1/4" long, which only engage >> about one thread (!) into the servo body (due to the short 1/4" >> length of the screws and the AN960-10 washer spacer called out in step >> F). I'm not very comfortable with this arrangement. Only a single >> thread engagement (1 turn of the screw) leaves me feeling there's risk >> of the screw stripping and/or backing out and leaving the stop plate >> not properly attached. I don't like the picture of the stop plate >> rattling around where it can jam the aircraft roll control. >> >> For those who have installed this system and gotten it flying, do you >> find that the stop plate is needed, or does the RV-10's aileron stop >> system keep the servo arm from running up to the stops provided by the >> servo's stop plate? Have others taken steps to better secure the >> stop plate? >> >> Thanks, >> >> Tim >> > > > > > ________________________________________________________________________________
Subject: Re: Ameri-King AK-451 ELT
Date: Feb 01, 2009
Best thing to do is stay away from the 451. I sent a new 450 back to them that would not work. It was 3 months old and I sent the BOS with it. They have failed to respond and still have my unit 1 year now. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=227984#227984 ________________________________________________________________________________
Date: Feb 01, 2009
I think it is very important to install the servo stop plates. The servo is capable of driving itself too far and get in a position that will lock the controls if the plates are not installed. I didn't think they were important when I watched the linkage and moved the controls to the stops, but when I moved the servo arm itself, I could get it into a locked position. Be careful! Kevin Belue RV6A RV10 flying Sent from my iPhone On Jan 31, 2009, at 9:18 PM, Larry Rosen wrote: > > Tim, > I cannot answer your question, but I looked at my installation (not > yet flying) and I do not have the roll stop installed. If you look > at Tim Olson's installation and he also does not have the roll stop <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html > >, > but Deems does <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html > > > > Also, I do not have the stop installed on the pitch servo, but Tim > Olson does <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html > >, but the Tru Trak RV-10 installation photos do not show it. Deems > does not have the pitch control stops installed <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html > > > > Now I am even more confused than usual. I guess a call to Tru Trak > on Monday is called for. > > Larry Rosen > #356 > > Tim Lewis wrote: >> >> Tru Trak's RV-10 roll servo installation diagram is at <http://www.trutrakap.com/documents/RV10RollInstallation.pdf >> >. >> >> In the first photo, item "F" is the servo stop plate. That stop >> plate is held on by two little 6-32 screws, 1/4" long, which only >> engage about one thread (!) into the servo body (due to the short >> 1/4" length of the screws and the AN960-10 washer spacer called out >> in step F). I'm not very comfortable with this arrangement. Only >> a single thread engagement (1 turn of the screw) leaves me feeling >> there's risk of the screw stripping and/or backing out and leaving >> the stop plate not properly attached. I don't like the picture of >> the stop plate rattling around where it can jam the aircraft roll >> control. >> >> For those who have installed this system and gotten it flying, do >> you find that the stop plate is needed, or does the RV-10's aileron >> stop system keep the servo arm from running up to the stops >> provided by the servo's stop plate? Have others taken steps to >> better secure the stop plate? >> >> Thanks, >> >> Tim >> > > ________________________________________________________________________________
Date: Feb 01, 2009
Subject: Re: Glad to be hangered!
Patrick Pulis wrote: > I feel so sorry for all you snow bound folks. Skiis... :-) -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ http://deej.net/sportsman/ http://deej.net/kr-2/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Subject: RE: 406 MHZ ELT
Date: Feb 01, 2009
I don't think we have any disagreement. You can still use the old testing methods to satisfy the annual testing requirement for ELTs. This is because the new ELTs still have a 121.5 MHz signal in addition to the 406 MHz signal. Testing the 406 MHz signal and data burst is not required by FAR at this time.at least so far. As Bill and others have indicated, you need to be careful when testing the ELT not to trigger the 406 MHz burst. You may be charged for SAR costs incurred, fined, or scare the crap out of your emergency contacts. To my knowledge there is no DIY method to fully test the 406 MHz signal. My wife and I have also been carrying our PLB whenever we travel.vacations, hiking, scuba, etc.. We let our registered contacts know where we will be. When we went to New Zealand we put our itinerary on our NOAA registration in the comments section. You never know. Steve Roberts N2700W 1966 M20E 'Ms. Obsession' KMOR Morristown, TN _____ Tim, Ok here's where I'm coming from. Steve made a blanket statement of using VHF and thats all you do With the old 121.5 elts and As I said, I was not talking about 406 elts, I was concerned about 121.5 elts which we mostly have in the general aviation. And do not want someone reading this and say all I have to do is use the VHF radio turn it to 121.5 and see if I get a signal.The Vhf radio only lets you test to see if it activates but is not good for the radiated signal. As per Far 91.207d4. You can test that as per AC43. And ac 43.13 is acceptable data. (Don't forget to read the notes).That is the only place I know you see testing for sufficient signal radiated from its antenna. Except for the manufacturer books which I know nothing of. So go ahead and shoot. Like I said ask your local FAA. otherwise don't ask and ask for forgiveness afterward, that's the pilots motto around my airport. Patrick Thyssen ________________________________________________________________________________
Subject: Re: Mistake on the Aft Deck: Fixed
Date: Feb 01, 2009
R28gZmlndXJlLiBJdCdzIDMgZGF5cyBhZnRlciBJIHNlbnQgdGhpcyBtZXNzYWdlLCB0aGV5J3Jl IG5vdyBiZWluZyBkaXN0cmlidXRlZCBpbiB0aGUgbWFpbGluZyBsaXN0LiBNeSBhcG9sb2dpZXMg Zm9yIHRoZSBtdWx0aXBsZSBjb3BpZXMgeW91IHdpbGwgc2VlLiANCg0KUGhpbA0KDQoNCg0KX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCg0KRnJvbTogUGVycnksIFBoaWwgDQpUbzog cnYxMC1saXN0QG1hdHJvbmljcy5jb20gDQpTZW50OiBUaHUgSmFuIDI5IDA4OjIzOjA2IDIwMDkN ClN1YmplY3Q6IFJWMTAtTGlzdDogTWlzdGFrZSBvbiB0aGUgQWZ0IERlY2s6IEZpeGVkIA0KDQoN CkhpIEV2ZXJ5b25lLA0KIA0KSSd2ZSBoYWQgYSBjb3VwbGUgb2YgcGVvcGxlIGFzayBob3cgSSBy ZXBhaXJlZCB0aGUgYm9vLWJvbyBvbiB0aGUgYWZ0IGRlY2suDQogDQpMYXN0IG5pZ2h0IEkgZmlu YWxseSBnb3QgYXJvdW5kIHRvIHJlcGFpcmluZyBpdCBhbmQgdGhvdWdodCBJJ2Qgc2hhcmUgd2l0 aCB0aGUgZ3JvdXAuICBNYXliZSB5b3UnbGwgaGF2ZSBhbiBvcHBvcnR1bml0eSB0byBkbyBzb21l dGhpbmcgc2ltaWxhciBkdXJpbmcgeW91ciBidWlsZC4gIDopDQogDQpJdCBzb3VuZHMgbGlrZSBh IGxvdCBvZiB3b3JrIGFuZCBkZWZpbml0ZWx5IGlzIG5vdCB0aGUgc2ltcGxlc3QgZml4LCBidXQg SSBoYXZlIGFic29sdXRlbHkgbm8gY29uY2VybnMgYWJvdXQgdGhlIGxvbmcgdGVybSBpbnRlZ3Jp dHkgb2YgdGhlIHJlcGFpci4NCiANCkkgY2FuJ3QgY2xhaW0gY3JlZGl0IGZvciBzb2x1dGlvbi4g IERhdmlkIE1jTmVpbGwgcHV0IG1lIGluIHRvdWNoIHdpdGggYW4gQSZQIElBIHdobyBza2V0Y2hl ZCBvdXQgdGhlIGRlc2lnbiBhbmQgc2VudCBpdCB0byBtZSAgVGhhbmtzIERhdmlkIQ0KIA0KUGhp bA0KIA0KIA0KIA0KIA0KIA0KVGhpcyBpcyB0aGUgb3JpZ2luYWwgZGFtYWdlLi4uICBZb3UgY2Fu IHNlZSB0aGUgbG9uZ2Vyb24gYmVsb3cgYW5kIGl0J3MgZmluZSwgYnV0IHRoZSBhZnQgZGVjayBz a2luIHdhcyBwcmV0dHkgbWVzc2VkIHVwLiAgVGhlIGRhbWFnZSBleHRlbmRlZCBiZXlvbmQgYW4g QUQ1IHJpdmV0IGFuZCBpdCdzIHBvc3NpYmxlIHRoYXQgYW4gQU4zIGJvbHQgcHJvYmFibHkgd291 bGRuJ3QgaGF2ZSBmdWxseSByZW1vdmVkIGl0Lg0KIA0KaHR0cDovL2kxNDEucGhvdG9idWNrZXQu Y29tL2FsYnVtcy9yNTEvcGhpbHBlcnJ5OS9SVi0xMCUyMEJ1aWxkL0RTQ18zNTI4LmpwZw0KIA0K IERTQ18zNTI4LmpwZyBwaWN0dXJlIGJ5IHBoaWxwZXJyeTk8aHR0cDovL2kxNDEucGhvdG9idWNr ZXQuY29tL2FsYnVtcy9yNTEvcGhpbHBlcnJ5OS9SVi0xMCUyMEJ1aWxkL0RTQ18zNTI4LmpwZz90 PTEyMzMyNDQ0MjQ+IA0KIA0KIA0KSSB3YXMgb25seSA3IHJpdmV0cyBpbnRvIGluc3RhbGxpbmcg dGhlIGFmdCBkZWNrIHdoZW4gbXkgc2NyZXcgdXAgaGFwcGVuZWQsIHNvIEkgd2VudCBhaGVhZCBh bmQgcmVtb3ZlZCB0aGUgZW50aXJlIGRlY2suICBJdCBtYWRlIHdvcmtpbmcgb24gdGhlIHBpZWNl cyBtYWtlIGVhc2llci4gIA0KIA0KT25jZSBpdCB3YXMgb2ZmIHRoZSBhaXJwbGFuZSwgSSByZW1v dmVkIHRoZSBkYW1hZ2VkIGFyZWEgd2l0aCBhIHVuaS1iaXQgYW5kIGRlYnVycmVkIHRoZSBob2xl LiAgSXQgcmVxdWlyZWQgYSA1LzE2IiBob2xlIHRvIHJlbW92ZSB0aGUgZGFtYWdlZCBhcmVhLiAg DQogDQpOZXh0IHVwIHdhcyB0byBjcmVhdGUgYSA1LzE2IiBwbHVnIGZvciB0aGUgaG9sZS4gIFRo ZSBwbHVnIHdhcyBtYWRlIGZyb20gLjA0MCBzY3JhcCBhbmQgbWF0Y2hlcyB0aGUgc2FtZSAuMDQw IHRoaWNrbmVzcyBvZiB0aGUgZGVjay4gIE15IGJ1ZGR5IGlzIGFuIEEmUCBhbmQgaGUgc3RvcHBl ZCBieSB0YWtlIHBhcnQgaW4gdGhlIHByb2Nlc3MuICBIZSBkaWQgYSBncmVhdCBqb2Igb2YgYnVp bGRpbmcgYSByb3VuZCBwbHVnIHRoYXQgZml0cyB0aGUgaG9sZSBwZXJmZWN0bHkhDQogDQpUaGUg Zmlyc3QgcGhvdG8gc2hvd3MgdGhlIHBsdWcgYW5kIHRoZSBzaXR0aW5nIGJlc2lkZSB0aGUgaG9s ZS4gIFRoZSBzZWNvbmQgcGhvdG8gc2hvd3MgdGhlIHBsdWcgc2l0dGluZyBpbnNpZGUgdGhlIGhv bGUuDQogDQpodHRwOi8vaTE0MS5waG90b2J1Y2tldC5jb20vYWxidW1zL3I1MS9waGlscGVycnk5 L1JWLTEwJTIwQnVpbGQvRFNDXzM1MzEuanBnDQogDQogRFNDXzM1MzEuanBnIHBpY3R1cmUgYnkg cGhpbHBlcnJ5OTxodHRwOi8vaTE0MS5waG90b2J1Y2tldC5jb20vYWxidW1zL3I1MS9waGlscGVy cnk5L1JWLTEwJTIwQnVpbGQvRFNDXzM1MzEuanBnP3Q9MTIzMzI0NDczNj4gDQogDQogDQogDQpo dHRwOi8vaTE0MS5waG90b2J1Y2tldC5jb20vYWxidW1zL3I1MS9waGlscGVycnk5L1JWLTEwJTIw QnVpbGQvRFNDXzM1MzIuanBnDQogDQogRFNDXzM1MzIuanBnIHBpY3R1cmUgYnkgcGhpbHBlcnJ5 OTxodHRwOi8vaTE0MS5waG90b2J1Y2tldC5jb20vYWxidW1zL3I1MS9waGlscGVycnk5L1JWLTEw JTIwQnVpbGQvRFNDXzM1MzIuanBnP3Q9MTIzMzI0NDgyMD4gDQogDQogDQpOZXh0IHVwIHdhcyB0 byByZS1jcmVhdGUgdGhlIHJpdmV0IGhvbGUuICBXZSBkaWQgdGhpcyB3aXRoIGEgOTAgZGVncmVl IGRyaWxsIGFuZCBjYW1lIHVwIHRocm91Z2ggdGhlIGJvdHRvbSBvZiB0aGUgbG9uZ2Vyb24uIFRv IGtlZXAgdGhlIHBsdWcgZnJvbSBzcGlubmluZywgd2UgdGFwZWQgaXQgZG93biB3aXRoIGR1Y3Qg dGFwZSBhbmQgYXBwbGllZCBwcmVzc3VyZSB3aXRoIGEgd29vZGVuIGJsb2NrIGZyb20gdGhlIHRv cC4gIEl0IHdvcmtlZCBwcmV0dHkgd2VsbC4gIFdlIHdlcmUgYWJsZSB0byBnZXQgODAlIG9mIHRo ZSB3YXkgdGhyb3VnaCB0aGUgcGx1ZyBiZWZvcmUgdGhlIHRhcGUgZ2F2ZSBhbmQgdGhlIHBsdWcg c3RhcnRlZCB0byBzcGluLiAgSG93ZXZlciB0aGUgaG9sZSB3YXMgc3RhcnRlZCBkZWVwIGVub3Vn aCB0aGF0IHdlIGNvdWxkIGZpbmlzaCBkcmlsbGluZyBpdCBvdXQgb24gdGhlIHdvcmtiZW5jaC4g IExvb2tzIHByZXR0eSBnb29kIQ0KIA0KaHR0cDovL2kxNDEucGhvdG9idWNrZXQuY29tL2FsYnVt cy9yNTEvcGhpbHBlcnJ5OS9SVi0xMCUyMEJ1aWxkL0RTQ18zNTM0LmpwZw0KIA0KIERTQ18zNTM0 LmpwZyBwaWN0dXJlIGJ5IHBoaWxwZXJyeTk8aHR0cDovL2kxNDEucGhvdG9idWNrZXQuY29tL2Fs YnVtcy9yNTEvcGhpbHBlcnJ5OS9SVi0xMCUyMEJ1aWxkL0RTQ18zNTM0LmpwZz90PTEyMzMyNDUw MDE+IA0KIA0KIA0KRmluYWxseSwgd2UgY3JlYXRlZCBhIGRvdWJsZXIgb3V0IG9mIC4wNDAgc2Ny YXAgKHNhbWUgdGhpY2tuZXNzL3N0cmVuZ3RoIGFzIHRoZSBkZWNrIHNraW4pLiAgVGhlIGRvdWJs ZXIgaGFzIDUgcml2ZXRzLiAgT2J2aW91c2x5IGl0J3MgY2VudGVyZWQgb24gdGhlIHBsdWcgYW5k IHdlIHBpY2tlZCB1cCB0aGUgYWRqYWNlbnQgbG9uZ2Vyb24gcml2ZXRzLiAgVGhlbiB3ZSBhdHRh Y2hlZCB0aGUgZG91YmxlciB0byB0aGUgZGVjayBza2luIGluYm9hcmQgb2YgdGhlIGxvbmdlcm9u cy4NCiANCiANCldlIHRob3VnaHQgYWJvdXQgYWRkaW5nIHR3byBhZGRpdGlvbmFsIHJpdmV0cyBi eSBzcGxpdHRpbmcgdGhlIGRpc3RhbmNlIGJldHdlZW4gdGhlIHBsdWcgYW5kIHRoZSBhZGphY2Vu dCBsb25nZXJvbiByaXZldHMsIGJ1dCBhZnRlciBsb29raW5nIGF0IGl0IGNsb3NlciB3ZSBvcHRl ZCBvdXQgb2YgdGhhdCBkZWNpc2lvbi4gIFRoZXJlIGlzbid0IG11Y2ggY2xlYXJhbmNlIGZvciBy aXZldCBwaXRjaCAoc3BhY2luZykgYnkgc3BsaXR0aW5nIHRob3NlIGhvbGVzLiAgU3VyZSB3ZSBj b3VsZCBoYXZlIGRvbmUgaXQgYW5kIGl0IHdvdWxkIGhhdmUgYmVlbiBmaW5lIGJ5IHRoZSBib29r LCBidXQgd2Ugd291bGQgaGF2ZSBiZWVuIHNpdHRpbmcgYSBtaW5pbXVtcy4gIFdoZW4gd2Ugd2Vp Z2hlZCB0aGF0IHJlYWxpdHkgd2l0aCB0aGUgcmVhbGl0eSB3ZWFrZW5pbmcgdGhlIGxvbmdlcm9u IGJ5IGRyaWxsaW5nIGFkZGl0aW9uYWwgaG9sZXMgLSB3ZSBkZWNpZGVkIGl0IHdhcyBiZXR0ZXIg dG8gbGVhdmUgd2VsbCBlbm91Z2ggYWxvbmUuDQogDQogDQpPbiB0aGUgaW5ib2FyZCBkZWNrIHJp dmV0cywgd2UgY2hvc2UgdG8gc3BsaXQgdGhlbSBiZXR3ZWVuIHRoZSBwbHVnIGFuZCB0aGUgYWRq YWNlbnQgbG9uZ2Vyb24gcml2ZXRzLiAgVGhpcyB3YXMgYnkgZGVzaWduIHRvIHNoYXJlIHRoZSBz aGVhciBsb2FkIGJldHdlZW4gdGhlIHBsdWcgcml2ZXQgYW5kIGl0J3MgYWRqYWNlbnQgbG9uZ2Vy b24gcml2ZXRzLg0KIA0KSGVyZSBpcyB0aGUgZmluaXNoZWQgcHJvZHVjdC4NCiANCmh0dHA6Ly9p MTQxLnBob3RvYnVja2V0LmNvbS9hbGJ1bXMvcjUxL3BoaWxwZXJyeTkvUlYtMTAlMjBCdWlsZC9E U0NfMzUzNS5qcGcNCiANCiBEU0NfMzUzNS5qcGcgcGljdHVyZSBieSBwaGlscGVycnk5PGh0dHA6 Ly9pMTQxLnBob3RvYnVja2V0LmNvbS9hbGJ1bXMvcjUxL3BoaWxwZXJyeTkvUlYtMTAlMjBCdWls ZC9EU0NfMzUzNS5qcGc/dD0xMjMzMjQ1NDA4PiANCg= ________________________________________________________________________________
Date: Feb 01, 2009
Thanks for all the replies. Good info. I sent an email to Tru Trak asking about longer screws. I'll let you know what I hear. The screw max length will be a consideration, due to the moving pieces inside the servo that are right behind the screw holes. You can actually see movement of an interior servo part through the screw hole. Thanks, Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction Tim Olson wrote: > > Keep in mind that the photos on that first link are from 2004...2 > years before I flew. Somewhere in early Feb 2006 you should see an > update where I added the stops, as the new kit of parts came out. > Either right before or right after first flight, I had to redo the > aileron servo linkages with new parts because the added the stops. I > think they had incidents of jammed aileron servos due to linkage > travelling to far, so they made length changes and hard stops. I > would absolutely add the stops. Although, I don't remember the screw > length being an issue at that time. I'd call them and ask how long > you can use and then report back here for your RV10 buds. > Tim > > > On Jan 31, 2009, at 9:18 PM, Larry Rosen wrote: > >> >> Tim, >> I cannot answer your question, but I looked at my installation (not >> yet flying) and I do not have the roll stop installed. If you look >> at Tim Olson's installation and he also does not have the roll stop >> <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html>, >> but Deems does >> <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html> >> >> >> Also, I do not have the stop installed on the pitch servo, but Tim >> Olson does >> <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html>, >> but the Tru Trak RV-10 installation photos do not show it. Deems >> does not have the pitch control stops installed >> <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html> >> >> Now I am even more confused than usual. I guess a call to Tru Trak >> on Monday is called for. >> >> Larry Rosen >> #356 >> >> Tim Lewis wrote: >>> >>> Tru Trak's RV-10 roll servo installation diagram is at >>> <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. >>> >>> In the first photo, item "F" is the servo stop plate. That stop >>> plate is held on by two little 6-32 screws, 1/4" long, which only >>> engage about one thread (!) into the servo body (due to the short >>> 1/4" length of the screws and the AN960-10 washer spacer called out >>> in step F). I'm not very comfortable with this arrangement. Only a >>> single thread engagement (1 turn of the screw) leaves me feeling >>> there's risk of the screw stripping and/or backing out and leaving >>> the stop plate not properly attached. I don't like the picture of >>> the stop plate rattling around where it can jam the aircraft roll >>> control. >>> >>> For those who have installed this system and gotten it flying, do >>> you find that the stop plate is needed, or does the RV-10's aileron >>> stop system keep the servo arm from running up to the stops provided >>> by the servo's stop plate? Have others taken steps to better >>> secure the stop plate? >>> >>> Thanks, >>> >>> Tim >>> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 01, 2009
And again, just so people don't get confused, no, when I built it BEFORE flying by a couple years, there hadn't been such a torque enhancing plate. But, the week or so before I flew, they sent me the parts and it all got changed out. So yes, today, and ever since first flight, I've had the torque enhancing plate. That's the problem with reading a book....if you don't read to the end, you don't know what totally happened. Shows the day I modified the aileron servo: http://www.myrv10.com/N104CD/finishing/20060208/index.html I've never had the opportunity to fly without it. Tim Tim Lewis wrote: > > It looks like Tim Olson used the hardware from > <http://www.trutrakap.com/documents/RV-710RightWing.pdf>. This setup > doesn't use the "RV-10 Attach Plate" called out in step "c" of > <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>. > Alex De Dominicis told me the RV-10 Attach Plate is essentially a torque > enhancer for more autopilot authority in rough air. > > Tim > ________________________________________________________________________________
Date: Feb 01, 2009
One thing to consider if they won't let you go with longer screws is using loctite on them once you fix it in a position you are happy with. It would be better than having it come apart. Tim Olson - RV-10 N104CD - Flying Tim Lewis wrote: > > Thanks for all the replies. Good info. > > I sent an email to Tru Trak asking about longer screws. I'll let you > know what I hear. The screw max length will be a consideration, due to > the moving pieces inside the servo that are right behind the screw > holes. You can actually see movement of an interior servo part through > the screw hole. > > Thanks, > > Tim > ________________________________________________________________________________
Subject: Re: weight & balance program
Date: Feb 01, 2009
Here's a good one: http://nwacaptain.com/10weightandbalance.html Regards, Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228095#228095 ________________________________________________________________________________
Date: Feb 02, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Regarding the swiveling blade tool - I have used such a tool labeled "Vargus" for a couple of years to deburr an entire QB kit. It has a thin pencil shaped body with a swiveling but fixed in place blade. It was part of an RV tool kit I bought from "Ishmail Tools". Anyway, I figured that the tool must be getting dull so a couple of months ago I bought one of the deburring tools from Cleveland or Avery. The type with multiple blades stored in the fat handle. I quickly discovered the newer tool was inferior to the original. The blades chattered and caught on the work and quickly dulled. Apparently something less than hard tool steel or whatever is required for a good deburring too. I'm back to the Vargus and consider myself lucky it didn't happen the other way around. I have no idea where to buy a Vargus but if someone does, I'd still like to refresh it. FWIW Bill "I'm gonna put it up on the wheels" Watson. Jesse Saint wrote: > > Usually you can get those with the swiveling blade tool from the right > angle. That tool also can have different shaped blades for different > types of deburring. > ________________________________________________________________________________
Date: Feb 02, 2009
Perhaps you mean Isham? Is this the tool you refer to? http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=53 On Mon, Feb 2, 2009 at 7:15 AM, Bill Mauledriver Watson wrote: > > > Regarding the swiveling blade tool - I have used such a tool labeled > "Vargus" for a couple of years to deburr an entire QB kit. It has a thin > pencil shaped body with a swiveling but fixed in place blade. It was part > of an RV tool kit I bought from "Ishmail Tools". > > I have no idea where to buy a Vargus but if someone does, I'd still like to > refresh it. > ________________________________________________________________________________
Date: Feb 02, 2009
Yes on both counts. I bought a tool kit from Isham Inc a couple of years ago and it turns out it was a very good kit for me. Of course I can't easily compare with others but it's worked out better than expected. Thanks for info. I never really made the connection with PlaneTools but I will adding it to my vendor list. Bill Kelly McMullen wrote: > > Perhaps you mean Isham? Is this the tool you refer to? > http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=53 > > On Mon, Feb 2, 2009 at 7:15 AM, Bill Mauledriver Watson > wrote: > >> >> >> Regarding the swiveling blade tool - I have used such a tool labeled >> "Vargus" for a couple of years to deburr an entire QB kit. It has a thin >> pencil shaped body with a swiveling but fixed in place blade. It was part >> of an RV tool kit I bought from "Ishmail Tools". >> >> > > >> I have no idea where to buy a Vargus but if someone does, I'd still like to >> refresh it. >> >> > > > ________________________________________________________________________________
Subject: Deburring
Date: Feb 02, 2009
I have a set of the swiveling tools mentioned. I picked up a set of 4 different ones (from Cleveland or Avery I think) at the beginning of the project which has worked very well. I also use the mini scotchbrite wheels for some of those hard to get places and so far it has all worked quite well: http://www.averytools.com/pc-351-43-scotch-brite-cutting---polishing--wheel- -kit.aspx Best Regards, Patrick #40715 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doug Gee Sent: Saturday, January 31, 2009 8:39 PM Subject: RV10-List: Deburring <Doug.Gee@firestone-textiles.com> I have just started building the VS and I have a question about deburring technique. I have used the scotchbrite wheel t do most of the outside edges and this works well. I have used the deburring tool with the swivelling blade to do the lightening holes but how do I do the notches around the ribs? I used a needle file but very tedious - is there a better way or d these notches not need to be done? Thanks ________________________________________________________________________________
Date: Feb 02, 2009
That is a good program, thanks. -------- Dave Ford RV6 flying RV10 building Lake City, MI based at CAD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228261#228261 ________________________________________________________________________________
Subject: Attach the Tail Feathers?
Date: Feb 03, 2009
This morning I woke up early and finished the tailcone (Section 10). Now I'm waiting for the QB fuse to arrive in April!!! Apparently the facility in the Philippines was relocated and that has greatly increased the lead times from 3 months to at least 5+ months. So I'm looking for something to do. I wasn't planning on completing section 11 until after the tailcone is attached. But given my scenario, I'm temped to go ahead and press on with Section 11 and just leave the Elevators and Rudder off the plane. (I'll need the depth in the garage later) Anyone have any thoughts on completing section 11? I'm guessing it'll be much easier to attach the tailcone to the QB fuse without the hassle of the tail feathers. Thanks, Phil ________________________________________________________________________________
Subject: Re: Attach the Tail Feathers?
Date: Feb 03, 2009
I would start the section and get everything done you can. There are some steps you would wait until final assembly for like installing the trim cables or fairings and this is obvious. Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: Perry, Phil To: rv10-list(at)matronics.com Sent: Tuesday, February 03, 2009 10:58 AM Subject: RV10-List: Attach the Tail Feathers? This morning I woke up early and finished the tailcone (Section 10). Now I'm waiting for the QB fuse to arrive in April!!! Apparently the facility in the Philippines was relocated and that has greatly increased the lead times from 3 months to at least 5+ months. So I'm looking for something to do. I wasn't planning on completing section 11 until after the tailcone is attached. But given my scenario, I'm temped to go ahead and press on with Section 11 and just leave the Elevators and Rudder off the plane. (I'll need the depth in the garage later) Anyone have any thoughts on completing section 11? I'm guessing it'll be much easier to attach the tailcone to the QB fuse without the hassle of the tail feathers. Thanks, Phil ________________________________________________________________________________
Date: Feb 03, 2009
Phil.Perry(at)netapp.com wrote: > > Anyone have any thoughts on completing section 11? I'm guessing it'll be much easier to attach the tailcone to the QB fuse without the hassle of the tail feathers. > Thanks, > Phil I would do Section 11 for sure and probably start on much of Section 12. You then take everything apart and hang them from the ceiling or on the walls until you start the final assembly. -------- Gary Blankenbiller RV10 - # 40674 Engine, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228325#228325 ________________________________________________________________________________
Date: Feb 03, 2009
I spoke with Zack from Tru Trak today. The control stop is not necessary on the RV 10 pitch servo because of the way the torque enhancer works. You will not be able to lock up the servo. However, it is part of there recommended install for the roll servo. They do want the screws to be as short as practical. If they are too long they will ride against a gear inside the servo. But, one thread is too short. The screw is a 6-32. I will need to look through my parts bins to see if I have the control stop for the roll servo. Otherwise TT will send one out to me. Thanks everyone for bringing up this topic. I will now know of a mistake that I can easily correct. Better now than when it is to late. Larry Tim Olson wrote: > > One thing to consider if they won't let you go with longer screws > is using loctite on them once you fix it in a position you are > happy with. It would be better than having it come apart. > > Tim Olson - RV-10 N104CD - Flying > > > Tim Lewis wrote: >> >> Thanks for all the replies. Good info. >> >> I sent an email to Tru Trak asking about longer screws. I'll let you >> know what I hear. The screw max length will be a consideration, due >> to the moving pieces inside the servo that are right behind the screw >> holes. You can actually see movement of an interior servo part >> through the screw hole. >> >> Thanks, >> >> Tim >> > > ________________________________________________________________________________
Date: Feb 03, 2009
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Don't forget to put some tie wire/coat hangar/string thru the hole where the trim cables run. It will save you 45 minutes (at least) when trying to install the tail feathers. (don't ask me how I know :) ) Dr Fred. Perry, Phil wrote: > This morning I woke up early and finished the tailcone (Section 10). > > Now I'm waiting for the QB fuse to arrive in April!!! Apparently the > facility in the Philippines was relocated and that has greatly > increased the lead times from 3 months to at least 5+ months. > > So I'm looking for something to do. I wasn't planning on completing > section 11 until after the tailcone is attached. But given my > scenario, I'm temped to go ahead and press on with Section 11 and just > leave the Elevators and Rudder off the plane. (I'll need the depth in > the garage later) > > Anyone have any thoughts on completing section 11? I'm guessing it'll > be much easier to attach the tailcone to the QB fuse without the > hassle of the tail feathers. > > Thanks, > Phil > > > > * > > > * ________________________________________________________________________________
Date: Feb 03, 2009
Subject: Motivation
Kit 40515 passed another major milestone Friday. Got her back from the paint shop. Flying Colors of Texas in Gainesville did the job. Took four weeks. She is back in the air and doing fine. Keep pounding those rivets. It's worth it. See you at Sun in Fun and Oshkosh. Dr Fred. ________________________________________________________________________________
Subject: Fuel Cap Leak
Date: Feb 03, 2009
In testing my first fuel tank, it appears that I have a leak. The only leak I can find in the fuel cap. Air bubbles were coming up from under the tab. I moved the tab to different positions to ensure that the leak moved with the tab and to rule out the leak was coming between the flange and skin. The leak did move. So I decided to increase the tension by =BC=94 turn. That helped eliminating the leak around the seal, but it does appear that I still have a leak coming from the center post. It also appears to be the same with both fuel caps. I=92ll give Van=92s a call in the morning, but I was curious as if anyone else has run into anything similar and have some advice to share. Thanks, Bob ________________________________________________________________________________
Date: Feb 03, 2009
Subject: Re: Fuel Cap Leak
I had to use packing tape over the whole gas cap to get a good enough seal to see if there were any leaks. I don't think the gas caps are designed to be totally leak proof. Dr Fred. Bob Leffler wrote: > > In testing my first fuel tank, it appears that I have a leak. The only > leak I can find in the fuel cap. Air bubbles were coming up from under > the tab. I moved the tab to different positions to ensure that the > leak moved with the tab and to rule out the leak was coming between > the flange and skin. The leak did move. So I decided to increase the > tension by turn. That helped eliminating the leak around the seal, > but it does appear that I still have a leak coming from the center > post. It also appears to be the same with both fuel caps. > > Ill give Vans a call in the morning, but I was curious as if anyone > else has run into anything similar and have some advice to share. > > Thanks, > > Bob > > * > > > * ________________________________________________________________________________
Date: Feb 03, 2009
Same for me. I got one to seal, never got the other one to seal. Have some leakage in flight when the line guy fills up the tank to high. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Tuesday, February 03, 2009 2:34 PM Subject: Re: RV10-List: Fuel Cap Leak I had to use packing tape over the whole gas cap to get a good enough seal to see if there were any leaks. I don't think the gas caps are designed to be totally leak proof. Dr Fred. Bob Leffler wrote: > > In testing my first fuel tank, it appears that I have a leak. The only > leak I can find in the fuel cap. Air bubbles were coming up from under > the tab. I moved the tab to different positions to ensure that the > leak moved with the tab and to rule out the leak was coming between > the flange and skin. The leak did move. So I decided to increase the > tension by turn. That helped eliminating the leak around the seal, > but it does appear that I still have a leak coming from the center > post. It also appears to be the same with both fuel caps. > > Ill give Vans a call in the morning, but I was curious as if anyone > else has run into anything similar and have some advice to share. > > Thanks, > > Bob > > * > > > * ________________________________________________________________________________
Subject: Re: Motivation
Date: Feb 03, 2009
Dr. Fred, That is one of, if not my favorite RV10 paint designs. The colors pop out and flow with the airplane. Looks fast and sleek. Awsome job. Fly up to Oregon this spring we'll have a Northwest RV10 builders party with you and your wife as honored guests. Paul Grimstad RV10 450 Portland, Or. ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Tuesday, February 03, 2009 12:11 PM Subject: RV10-List: Motivation > Kit 40515 passed another major milestone Friday. Got her back from the > paint shop. Flying Colors of Texas in Gainesville did the job. Took > four weeks. She is back in the air and doing fine. Keep pounding those > rivets. It's worth it. See you at Sun in Fun and Oshkosh. > > Dr Fred. > ________________________________________________________________________________
Date: Feb 03, 2009
Looks great! We're envious here.,,, Thanks Bill Fred Williams, M.D. wrote: > Kit 40515 passed another major milestone Friday. Got her back from > the paint shop. Flying Colors of Texas in Gainesville did the job. > Took four weeks. She is back in the air and doing fine. Keep > pounding those rivets. It's worth it. See you at Sun in Fun and > Oshkosh. > > Dr Fred. > ------------------------------------------------------------------------ ________________________________________________________________________________
Date: Feb 03, 2009
Beautiful. Hmm, small world, I have landed at Paris Tx and Gainesville a couple times. On Tue, Feb 3, 2009 at 1:11 PM, Fred Williams, M.D. wrote: > Kit 40515 passed another major milestone Friday. Got her back from the > paint shop. Flying Colors of Texas in Gainesville did the job. Took four > weeks. She is back in the air and doing fine. Keep pounding those rivets. > It's worth it. See you at Sun in Fun and Oshkosh. > > Dr Fred. > ________________________________________________________________________________
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Subject: Wingtips
Date: Feb 03, 2009
I read Tim's saga of the crooked wing tip on his site. Have others experie nced problems here? I have attached them only to find the right tip is pre tty straight but the left curves upward and is out at least 1.5 inches at t he end. I am looking for any creative solutions before I begin cutting and try to make them true. Mike Lefever Chandler Arizona ________________________________________________________________________________
Date: Feb 03, 2009
Very nice Doc.=0A=0APatrick Pulis=0AAdelaide, South Australia=0A=0A=0A=0A =0A________________________________=0AFrom: "Fred Williams, M.D." <drfred@s uddenlinkmail.com>=0ATo: RV 10 =0ASent: Wednesday, 4 February, 2009 6:41:47 AM=0ASubject: RV10-List: Motivation=0A=0AKit 4051 5 passed another major milestone Friday.=C2- Got her back from the paint shop.=C2- Flying Colors of Texas in Gainesville did the job. Took four we eks.=C2- She is back in the air and doing fine.=C2- Keep pounding those rivets.=C2- It's worth it.=C2- See you at Sun in Fun and Oshkosh.=0A =0ADr Fred.=0A=0A=0A Make Yahoo!7 your homepage and win a trip to the Quiksilver Pro. Find out more ________________________________________________________________________________
Subject: Re: Wingtips
Date: Feb 03, 2009
I was able to adjust mine slightly with a heat gun. Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: Roxanne and Mike Lefever To: rv10-list(at)matronics.com Sent: Tuesday, February 03, 2009 6:54 PM Subject: RV10-List: Wingtips I read Tim's saga of the crooked wing tip on his site. Have others experienced problems here? I have attached them only to find the right tip is pretty straight but the left curves upward and is out at least 1.5 inches at the end. I am looking for any creative solutions before I begin cutting and try to make them true. Mike Lefever Chandler Arizona ________________________________________________________________________________
Date: Feb 03, 2009
Lookin' great, Dr. Fred.- Thanks for the boost in motivation.- Although most of the boost needs to be in the form of flying lessons!!!--- Ho pefully, I'll join those of you flying,, soon.- Working on paperwork and finishing touches. Don McDonald --- On Tue, 2/3/09, Fred Williams, M.D. wrote: From: Fred Williams, M.D. <drfred(at)suddenlinkmail.com> Subject: RV10-List: Motivation Date: Tuesday, February 3, 2009, 12:11 PM Kit 40515 passed another major milestone Friday. Got her back from the pai nt shop. Flying Colors of Texas in Gainesville did the job. Took four weeks. She is back in the air and doing fine. Keep pounding those rivets. It's worth it. See you at Sun in Fun and Oshkosh. Dr Fred. =0A=0A=0A ________________________________________________________________________________
Date: Feb 04, 2009
Subject: Re: New TSA Security Requirements
=C2-Hello Patrick. My wife and I operate out of Eugene Airport. We got new airport badges yest erday, and they put a "ghost" image of our picture up above it, claiming th at it will make it more difficult to make up a fake id, as if that will hel p=C2-some perceived "enemy"=C2-enter the gate-since it is locked!! We =C2- were also told, be aware that tsa will "show a higher presence" here . I told her that they are not coming in our hangar, and that they have no rights with general aviation. She said: Just to let you know , they will be around more! What a veiled threat! If someone doesn't stop them and their egregious power grabbing we will quit flying. It isn't enough to try to foi st this set of ridiculous 12,500 lb set of outrageous rules on GA; now they are already targeting small aircraft. They better not approach me! Oh well .. Hope someone does something. I called AOPA and reported this. I can't be lieve this. I told the airport staff in the office that they are brownshirt s who really want general aviation planes grounded if they had their way. Brian and Ruth ----- Original Message ----- From: "Patrick ONeill" <poneill(at)irealms.com> Sent: Wednesday, February 4, 2009 6:32:13 AM GMT -08:00 US/Canada Pacific Subject: RV10-List: New TSA Security Requirements At the end of this month the new TSA security requirements for pilots opera ting out of Part 139 airports take effect. Unfortunately for me, my primary airport is one of those affected by the ne w rules (KSNA).=C2- I get to make the first of two trips this week to the airport=99s administrative office to apply for a TSA background chec k and access badge for continued ramp access. I know most of you operate out of smaller fields.=C2- But I figured I =99d see if any other list members have had the pleasure of this experie nce.=C2- Anyone else been through it yet? I=99m hoping it=99s pretty benign as far as red tape goes. Patrick #40715 =============== == ________________________________________________________________________________
Date: Feb 04, 2009
bruce breckenridge wrote: > It would be great if EVERYONE failed to comply. Might send a message, > but at the expense of many who might pay a high price for standing firm. I'm convinced you are correct, and that is probably the only way to convince the gov't to get rid of the menace that the TSA presents to the US and our way of life. -Dj ________________________________________________________________________________
Subject: Cowl hinge sealant?
Date: Feb 04, 2009
Before I rivet on my firewall side cowl hinges... I recall adding sealant to the lower firewall to fuse tabs. Section 41-8 says rivet it all together, but doesn't mention any sealant. Seems like a good idea, but why bother if it's not a problem? What have others done? I noticed that Vans firewall high-temp sealant is marked "We are temporarily unable to ship this product. Available only for Will Call purchase until further notice". hmmm. Proseal would provide a good CO block, but not do much for a real thermal event with visual indication. Thanks, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228457#228457 ________________________________________________________________________________
Subject: New TSA Security Requirements
Date: Feb 04, 2009
I learned to fly and was part of a flying club out of BED (Hanscom Airfield near Boston), and one of my destinations was Westchester County (White Plains, NY) HPN. Very high number of private jets, etc, plus a military presence in the former, and an even greater number of jets, etc into the latter. So, needless to say, the security apparatus ratcheted up significantly at both very soon after 911. Double gates and all at Hanscom, where the 182 was hangered. You had to drive your car into a holding area, wait for the gate behind you to close and then the one in front to open. Cameras were installed that could be focused down each hanger row. The local FBO/charter company had to put in baggage screening equipment and procedures. American Eagle used to fly commercial out of there and had to put in a full system along with security folks, who mainly just sat around. Those of us with planes on the field had to go for training in order to get our badges. The training was worthless, in my opinion. Just designed to try to get you to turn in anyone that you thought looked suspicious. So, what does one do with the training? All become paranoid about everyone on the airfield? Be the civilian watch dogs for the state? If someone wanted to "take over" me and my 182 to do bad things, wouldn't it be very simple to come to my house, "secure" me and my badge and car in order to get through that joke of a gate to my hanger, or anyone else's hanger? This, to us at the field, was a system so easily defeated that it was laughable, but in the meantime it meant the loss of an intangible about flying that was dear to all those who sacrificed a great deal to participate. I don't know what the answer is, but I personally jumped at the chance to obtain a hanger at a small, open, old time airport when I arrived in Oregon. My fear is that soon, for any field with a 3k foot runway, we'll see the requirement for a razor fence and double security gates. There are decent sized biz jets with a good deal of speed, range, load capacity and mass that can operate into and out of a 3k strip, fully loaded. Is this what they are concerned about? What's the difference between a towered airport with a 5k strip and one without a tower with a 3k strip? They both offer opportunity, and I would think the latter would offer more. TSA has visited our little piece of flying heaven, and they were told by its owner to basically to get the H off the field. At my airfield we watch out for each other, for each other's safety and possessions. We know who's who on the field and introduce ourselves to those we may not recognize, only because it is a very friendly and helpful community, not because we have been asked to be paranoid watchdogs. I remember being absolutely shocked when I first arrived because folks would leave their hanger wide open when they left for a flight. I must admit I haven't gotten that comfortable yet, but what a wonderful feeling to be able to trust and depend upon your neighbors and fellow flying enthusiasts. Where or when, in every part of our extremely complex society, do we cross the line that means a significant and enduring loss of freedom, our way of life that makes us so unique a society? And, yes, we can debate what "freedom" means, pragmatically. Certainly no one wants total anarchy. Flying, the way we define the activity, is so much a symbol of freedom. We need more folks watching the watch dogs. We need folks, like Bruce's wife, to get involved, or, by fiat, these freedoms we have will be curtailed. Kurt Vonnegut where are you? John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bruce breckenridge Sent: Wednesday, February 04, 2009 7:51 AM Subject: Re: RV10-List: New TSA Security Requirements My wife is the ASN (Airport Support Network) representative for our home base, 7s9. She has really taken this TSA thing to heart and attended in Burbank one of the only 5 or 6 hearings TSA put on to hear what GA pilots had to say. She and 74 others had 3 minutes each to say their concerns. Most conveyed facts, which is what they wanted to hear. By the 27th of this month, they plan to hand down the next doling of regulations. The "book" is 261 pages of rules and guidelines. Only 2 airports in Oregon will feel the change you mention, and both are part of the Portland system: Troutdale (KTTD) and Hillsboro (KHIO). Setting up increased securities in the airline industry was one thing. Really irritating at times, but probably inevitable and necessary. This long handed reach into the smaller towered airports is, I believe, a total waste of energy. The small commercial operation affected will have to provide and pay for the TSA approved employees to check out each aircraft and person boarding. I can see the closing of businesses due to the increased regulations and costs placed on them. It looks like they've been given too much freedom to act in the name of "security". We sure hope it stops soon, yet all indications are that the "red tape" is going to get really deep.... Bruce 40018 ________________________________________________________________________________
From: "Rick Barnes" <rickbarnes(at)highlanddental.com>
Date: Feb 04, 2009
On the Van's high-temp sealant: I talked with them several months ago and the issue has to do with hazardous materials. In order to handle and ship a hazardous material the people at Van's have to be certified to handle the material. Van's doesn't want to pay for all of the government certification hassle. Rick -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb Sent: Wednesday, February 04, 2009 9:55 AM Subject: RV10-List: Cowl hinge sealant? Before I rivet on my firewall side cowl hinges... I recall adding sealant to the lower firewall to fuse tabs. Section 41-8 says rivet it all together, but doesn't mention any sealant. Seems like a good idea, but why bother if it's not a problem? What have others done? I noticed that Vans firewall high-temp sealant is marked "We are temporarily unable to ship this product. Available only for Will Call purchase until further notice". hmmm. Proseal would provide a good CO block, but not do much for a real thermal event with visual indication. Thanks, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228457#228457 Checked by AVG - www.avg.com 08:24:00 ________________________________________________________________________________
Date: Feb 04, 2009
Hello John! =C2-Thank you for that! I love it! Get the H off our field! I would have loved to see that! Ha Ha HA... =C2-We will look for a field like that also, or igve up flying before we allow any intrusion into our freedom=C2- when it comes to flying. We wrot e Phil Boyer before who agreed with me about the tsa. Brian Preston ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Wednesday, February 4, 2009 9:22:54 AM GMT -08:00 US/Canada Pacific Subject: RE: RV10-List: New TSA Security Requirements I learned to fly and was part of a flying club out of BED (Hanscom Airfield near Boston), and one of my destinations was=C2- Westchester County ( Wh ite Plains, NY ) HPN .=C2- Very high number of private jets, etc, plus a military presence in the former, and an even greater number of jets, etc in to the latter.=C2- So, needless to say, the security apparatus ratcheted up significantly at both very soon after 911.=C2-=C2-Double gates and a ll at Hanscom, where the 182 was hangered.=C2- You had to drive your car into a holding area, wait for the gate behind you to close and then the one in front to open.=C2-=C2- Cameras were installed that could be focused down each hanger row.=C2- The local FBO/charter company had to put in ba ggage screening equipment and procedures.=C2- American Eagle used to fly commercial out of there and had to put in a full system along with security folks, who mainly just sat around.=C2- Those of us with planes on the fi eld had to go for training in order to get our badges.=C2- The training w as worthless, in my opinion.=C2- Just designed to try to get you to turn in anyone that you thought looked suspicious.=C2- So,=C2- what does one do with the training?=C2- All become paranoid about everyone on the airf ield?=C2-=C2- Be the civilian watch dogs for the state?=C2-=C2-If s omeone wanted to=C2-"take over" me and my 182 to do bad things, wouldn't it be very simple to come to my house, "secure" me and my=C2-badge and ca r in order to get through that joke of a gate to my hanger, or anyone else' s hanger?=C2- This, to us at the field, was a system so easily defeated t hat it was laughable, but in the=C2-meantime it meant the loss of=C2-an intangible about flying that was dear to all those who sacrificed a great deal to participate.=C2- =C2- I don't know what the answer is, but I personally jumped at the chance to o btain a hanger at a small, open, old time airport when I arrived in Oregon. =C2- My fear is that soon, for any field with a 3k foot runway, we'll see the requirement for a razor fence and double security gates.=C2- There a re decent sized biz jets with a good deal of speed, range, load capacity an d mass that can operate into and out of a 3k strip, fully loaded.=C2- Is this what they are concerned about?=C2- What's the difference between a t owered airport with a 5k strip and one without a tower with a 3k strip?=C2 - They both offer opportunity, and I would think the latter would offer m ore.=C2- TSA has visited our little piece of flying heaven, and they were told by its owner to=C2-basically to get the H off the field.=C2- At my airfield we watch out for each other, for each other's safety and pos sessions.=C2- We know who's who on the field and introduce ourselves to t hose we may not recognize, only because it is a very friendly and helpful c ommunity, not because we have been asked to be paranoid watchdogs.=C2- I remember being absolutely shocked when I first arrived because folks would leave their hanger wide open when they left for a flight.=C2- I must admi t I haven't gotten that comfortable yet, but what a wonderful feeling to be able to trust and depend upon your neighbors and fellow flying enthusiasts .=C2-=C2-=C2- Where or when, in every part of our extremely complex society, do we cross the line that means a significant and enduring=C2-loss of freedom, our wa y of life that makes us so unique a society?=C2- And, yes, we can debate what "freedom" means, pragmatically.=C2- Certainly no one wants total ana rchy.=C2- Flying, the way we define the activity, is so much a symbol of freedom.=C2- We need more folks watching the watch dogs.=C2- We need fo lks, like Bruce's wife,=C2-to get involved, or, by fiat, these freedoms w e have will be curtailed.=C2- Kurt Vonnegut where are you?=C2- John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of bruce breckenridge Sent: Wednesday, February 04, 2009 7:51 AM Subject: Re: RV10-List: New TSA Security Requirements My wife is the ASN (Airport Support Network) representative for our home ba se, 7s9.=C2- She has really taken this TSA thing to heart and attended in Burbank=C2-one of the only 5 or 6 hearings TSA put on to hear what GA pi lots had to say.=C2- She and 74 others had 3 minutes each to say their co ncerns.=C2- Most conveyed facts, which is what they wanted to hear.=C2- By the 27th of this month, they plan to hand down the next doling of regul ations.=C2- The "book" is 261 pages of rules and guidelines. Only 2 airports in Oregon will feel the change you mention, and both are pa rt of the Portland system: Troutdale (KTTD) and Hillsboro (KHIO). Setting up increased securities in the airline industry was one thing.=C2 - Really irritating at times, but probably inevitable and necessary.=C2 - This long handed reach into the smaller towered airports is, I believe, a total waste of energy.=C2- The small commercial operation affected wil l have to provide and pay for the TSA approved employees to check out each aircraft and person boarding.=C2- I can see the closing of businesses due to the increased regulations and costs placed on them.=C2- It looks like they've been given too much freedom to act in the name of "security". We sure hope it stops soon, yet all indications are that the "red tape" is going to get really deep.... Bruce 40018 == ________________________________________________________________________________
Date: Feb 04, 2009
Hey, Brian. How's the Cirrus running? Hope you can come up to Albany this Spring for the RV-10 gathering. Once an RV-10 builder, always an RV-10 builder! John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cloudvalley(at)comcast.net Sent: Wednesday, February 04, 2009 9:47 AM Subject: Re: RV10-List: New TSA Security Requirements Hello John! Thank you for that! I love it! Get the H off our field! I would have loved to see that! Ha Ha HA... We will look for a field like that also, or igve up flying before we allow any intrusion into our freedom when it comes to flying. We wrote Phil Boyer before who agreed with me about the tsa. Brian Preston ________________________________________________________________________________
Date: Feb 04, 2009
And what about the 45,000+ Americans who die on our nations highways annually? TSA money would be better spent giving those worthless TSA morons a radar gun and monitoring highway speeds. Chuck -------------------------------------------------- From: "Dj Merrill" <deej(at)deej.net> Sent: Wednesday, February 04, 2009 8:17 AM Subject: Re: RV10-List: New TSA Security Requirements > > bruce breckenridge wrote: >> It would be great if EVERYONE failed to comply. Might send a message, >> but at the expense of many who might pay a high price for standing firm. > > > I'm convinced you are correct, and that is probably the only way to > convince the gov't to get rid of the menace that the TSA presents to the > US and our way of life. > > -Dj > > > ________________________________________________________________________________
Subject: Re: Cowl hinge sealant?
Date: Feb 04, 2009
Jay, I debated about this also. Fortunately I got Van's high temp sealant before they stopped shipping it. Rather than seal the firewall flange, I sealed the aft side of the firewall to fuselage skins. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228490#228490 ________________________________________________________________________________
Subject: MT prop governor rotation - final position
Date: Feb 04, 2009
I need to position my MT prop governor to set the opening in the fwd baffle on the left front area of the engine. I know that you loosen the six screws that retain the governor arm. You only loosen the screws - DO NOT REMOVE. Then you can rotate the arm part of the prop governor. This related to me by Jurgen at MT. Question: What is the final position of the arm on the MT prop governor? It looks like the passive position of the arm should be in the 10:00 position as you look at it from the pilot side. Could anyone already flying please set me straight on this......... -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228509#228509 ________________________________________________________________________________
Date: Feb 04, 2009
Paul Bowmar at Plane Innovations LLC (formerly of EPM-AV) has an excellent and thoroughly tested products. He sells a 2000 degree silicone seal for his fire protection kits. He will sell you some at a reasonable price. This stuff should be a lot better than the red goop........I bought some myself. Bowmar also sells the stainless steel heater valves to replace the aluminum Van's valves on the firewall. I consider this a MANDATORY Option (along with the rivethead door pins and CNC trim blocks) when you are building this kit. It would be foolish to spend a lot of time on hi-temp sealant and ignore the biggest risk area on your firewall. As I recall the Plane Innovations SS valves are $200 and Vans will give you a $100 credit on the aluminum ones deleted from the kit. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228510#228510 ________________________________________________________________________________
Date: Feb 04, 2009
Verrrry nice :D :D :D :D -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228511#228511 ________________________________________________________________________________
Subject: Nose Wheel Spacer - Shimmy
Date: Feb 04, 2009
I know this have been mentioned on the list before, but I have some new experience that I thought I would share to the list. I have recently checked the need for an additional spacer under the WD-1015 Nose Gear Link Collar. I found that to put a little preload on the Nose Gear Elastomers, I had to add 2 spacers for a total of 3 after the elastomers had seated. This definitely seems to help the shimmy issue. Also, on the nose gear axle, with the newer Van's spacers and after turning about 1/16" off the end of the axle (making it shorter to preload the bearings with the spacers), there seems to be no movement of the spacer or bearing after substantial use. The key, I think, is to shorten the axle a little bit. I have seen that the Bellville Washers that control the tension on pivoting the fork does loosen over time, and not just once, which can really cause a shimmy if loose. The problem is getting the 26 lbs of force that Van's recommends with a 1/6th turn increment on that castle nut. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 ________________________________________________________________________________
Subject: firewall sealant and valve option
Date: Feb 04, 2009
I have been working with Paul to modify the heater valves as I believe the product is very solid and seeing the RV-7 vents that have small lips around them I asked if he would make one like those for the RV-10. I believe he is working on this and it will be a Must have as Mike has mentioned. I am rather certain that the hot tunnel will be diminished. I'll report back once I have the new valve and have completed the heat gun test. I trust based on the products so far that it will be a worthwhile investment. My reasoning is what good is a stainless steel firewall with a weak aluminum valve that gaps/leaks when there is the option to have stainless steel valve that has lips that blocks the gaps. Pascal -------------------------------------------------- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Wednesday, February 04, 2009 12:37 PM Subject: RV10-List: Re: Cowl hinge sealant? > > Paul Bowmar at Plane Innovations LLC (formerly of EPM-AV) has an excellent > and thoroughly tested products. > > He sells a 2000 degree silicone seal for his fire protection kits. He will > sell you some at a reasonable price. This stuff should be a lot better > than the red goop........I bought some myself. > > Bowmar also sells the stainless steel heater valves to replace the > aluminum Van's valves on the firewall. I consider this a MANDATORY Option > (along with the rivethead door pins and CNC trim blocks) when you are > building this kit. It would be foolish to spend a lot of time on hi-temp > sealant and ignore the biggest risk area on your firewall. As I recall the > Plane Innovations SS valves are $200 and Vans will give you a $100 credit > on the aluminum ones deleted from the kit. > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - wiring and FWF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=228510#228510 > > > ________________________________________________________________________________
Date: Feb 04, 2009
Subject: Re: Nose Wheel Spacer - Shimmy
I know that on Mooneys, no play at all is allowable for the nose gear shock disks..probably exact same parts from Lord. In fact, when new there is a LOT of force compressing those disks. Once they age to where there isn't pre-tension on the disks, they need to be replaced on Mooneys. On Wed, Feb 4, 2009 at 2:23 PM, Jesse Saint wrote: > I know this have been mentioned on the list before, but I have some new > experience that I thought I would share to the list. I have recently > checked the need for an additional spacer under the WD-1015 Nose Gear Link > Collar. I found that to put a little preload on the Nose Gear Elastomers, I > had to add 2 spacers for a total of 3 after the elastomers had seated. This > definitely seems to help the shimmy issue. Also, on the nose gear axle, > with the newer Van's spacers and after turning about 1/16" off the end of > the axle (making it shorter to preload the bearings with the spacers), there > seems to be no movement of the spacer or bearing after substantial use. The > key, I think, is to shorten the axle a little bit. I have seen that the > Bellville Washers that control the tension on pivoting the fork does loosen > over time, and not just once, which can really cause a shimmy if loose. The > problem is getting the 26 lbs of force that Van's recommends with a 1/6th > turn increment on that castle nut. > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > ________________________________________________________________________________
Date: Feb 04, 2009
At KBED, you just arranged to get in and out of the fence through an FBO. I'm guessing that would hold for HIO. Two flying RV-10's there. You could always hook up with them for the procedures. Any reason for HIO? Nicer places to land, cheaper fuel. John _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James McGrew Sent: Wednesday, February 04, 2009 4:18 PM Subject: Re: RV10-List: New TSA Security Requirements So what does this mean if you are a transient aircraft at KHIO? That's where I go when I'm in Portland. -Jim n312je ________________________________________________________________________________
Date: Feb 05, 2009
Hello John! =C2-We would love to fly up and join you this year! Thank you. We are sta rting the Farmers' market in April on Saturday, since our farm has not sold yet. Th e price is down now and ma y sell this spring- can't count on that though.=C2-We may not go to every market early on. When is the gathering ? We sold that Cirrus because our house didn't sell, and lots of things kept needing maintenance; thank God=C2-it was=C2-under warrantee! We finally flew it to Scottsdale and sold it there. Then we found a low time 79 Grumm an Tiger that is really nice. Since Ruth flew those for over 30 years we bo ught it in Alabama from a retired=C2- 747 pilot. Flew it home. Affordable and fun! We go to Independence a lot. Our mechanic lives there.=C2-When we do sell the farm we may still be in the market for an RV-10 project that is much closer to completion if the economy comes back. Talk to you soon. Please let us know when and where John. Thanks again. Brian and Ruth ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Wednesday, February 4, 2009 10:02:59 AM GMT -08:00 US/Canada Pacific Subject: RE: RV10-List: New TSA Security Requirements Hey, Brian.=C2- How's the Cirrus running?=C2- Hope you can come up to A lbany this Spring for the RV-10 gathering.=C2- Once an RV-10=C2-builder , always an RV-10 builder!=C2- John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of cloudvalley(at)comcast.net Sent: Wednesday, February 04, 2009 9:47 AM Subject: Re: RV10-List: New TSA Security Requirements Hello John! =C2-Thank you for that! I love it! Get the H off our field! I would have loved to see that! Ha Ha HA... =C2-We will look for a field like that also, or igve up flying before we allow any intrusion into our freedom=C2- when it comes to flying. We wrot e Phil Boyer before who agreed with me about the tsa. Brian Preston == ________________________________________________________________________________
Date: Feb 04, 2009
Jesse Saint wrote: SNIP > I have seen that the Bellville Washers that control the tension on > pivoting the fork does loosen over time, and not just once, which can > really cause a shimmy if loose. The problem is getting the 26 lbs of > force that Van's recommends with a 1/6th turn increment on that castle > nut. More is better .... at least on my Grumman which has the same setup. The specs for the Grumman are 25 Lbs, measured by pull at the axle, but experience is that near 30 is better. Different scenarios in stacking the washers also makes a difference. Stacking two washers belly up and two washers belly down should help with the loosening problem. since I haven't gotten that far, I have no idea how Van recommends stacking the washers. Linn > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > * > > > * ________________________________________________________________________________
Subject: THrottle Cable Length
Date: Feb 04, 2009
Was the chatter a while back about insufficient throttle cable length for the quadrant or the vernier style throttle? -Chris #40072 ________________________________________________________________________________
Subject: Installing Door Windows
Date: Feb 05, 2009
The instructions call for installing the windows in the doors while the doors are not on the plane. While it might be easier that way, I am wondering if there would be any advantage of bonding the windows while the doors are on the plane, locked closed. My thoughts are that it might be possible to induce a small amount of twisting/distortion when bonded off the plane, vs being bonded on the plane. Thoughts would be appreciated. -------- Gary Blankenbiller RV10 - # 40674 Engine, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228643#228643 ________________________________________________________________________________
Subject: Re: Installing Door Windows
Date: Feb 05, 2009
If you're using Weld-on, the stuff runs.. it is MUCH easier to do it on a table than the plane. I did it on a table and there was no issue. I would suggest putting the Weld-on while flat, let it sit (after all the tape is removed) than put it on the plane after 2 hours, and lock it down, not needed but that would be be better than the mess that would occur from the weld-on dripping down the door. -------------------------------------------------- From: "orchidman" <gary(at)wingscc.com> Sent: Thursday, February 05, 2009 7:08 AM Subject: RV10-List: Installing Door Windows > > The instructions call for installing the windows in the doors while the > doors are not on the plane. While it might be easier that way, I am > wondering if there would be any advantage of bonding the windows while the > doors are on the plane, locked closed. > My thoughts are that it might be possible to induce a small amount of > twisting/distortion when bonded off the plane, vs being bonded on the > plane. > Thoughts would be appreciated. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Engine, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=228643#228643 > > > ________________________________________________________________________________
Date: Feb 05, 2009
orchidman wrote: > > The instructions call for installing the windows in the doors while the doors are not on the plane. While it might be easier that way, I am wondering if there would be any advantage of bonding the windows while the doors are on the plane, locked closed. > My thoughts are that it might be possible to induce a small amount of twisting/distortion when bonded off the plane, vs being bonded on the plane. > Thoughts would be appreciated. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Engine, Fiberglass - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=228643#228643 > > > Much easier to do off the plane. Any small twist will be taken care of by the hours of filling and sanding at time of final prep for paint. Dr Fred. ________________________________________________________________________________
Date: Feb 05, 2009
Subject: Kits
I note that on Tim's site for what is in the various kits, there are listings for a firewall forward kit, separate from finishing kit. However, Vans only lists empennage, fuselage, wing and finishing kits. Has Vans changed how they package things? Or is that just a convenient division of parts in the finishing kit? Kelly 40866 ________________________________________________________________________________
Date: Feb 05, 2009
Something like this? Problem is that vendors want to sell it by the case (12). Jay http://www.fireretardantsinc.com/3m/images/3m_2000_silicone.pdf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228687#228687 ________________________________________________________________________________
Subject: Antenna Mounting - Sealant vs Gasket?
Date: Feb 05, 2009
A couple of my antennas came with gaskets while others didn't. I spoke with an avionics guy yesterday and he was of the opinion that one should ditch the gasket in favor of a silicone sealant. Any other opinions out there? If sealant, what sort would do the job? Would antennas need to come off before painting? Cheers, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228698#228698 ________________________________________________________________________________
Date: Feb 05, 2009
Subject: Re: Antenna Mounting - Sealant vs Gasket?
I'm not in favor of scrapping the gaskets. They really help in the problem of dissimilar metals corrosion, and cushion the installation. A fillet of clear silicone will help keep water out .... and if you're worried about paint not adhering, there's paintable caulk out there. As for sealant, I really like the hi-temp red silicone .... for almost anything. Linn jayb wrote: > > A couple of my antennas came with gaskets while others didn't. I spoke with an avionics guy yesterday and he was of the opinion that one should ditch the gasket in favor of a silicone sealant. > > Any other opinions out there? If sealant, what sort would do the job? Would antennas need to come off before painting? > > Cheers, > Jay > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=228698#228698 > > > ________________________________________________________________________________
Subject: Avionics Liquidation website
Date: Feb 05, 2009
Found this website and got a new COMANT 105 xponder antenna at a reasonable price. They have all sorts of misc avionics and he's willing to deal... http://www.jimkantor.com/ Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228705#228705 ________________________________________________________________________________
Subject: Kits
Date: Feb 05, 2009
The firewall kit is highly dependent on which engine you get. There are too many options, so quite a few folks roll their own. Vans does sell a firewall kit for the 540 models they sell. It's in their catalog. You can use those as a starting point if you get an engine from another source. There is no overlap with the finishing kit. You can see the details here: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198&bro wse=engines&product=FF_Kit The following is off the web store. The RV-10 Firewall Forward Kits below can be ordered with or without a three lever throttle/prop/mixture quadrant part number "CT10-3". If you opt for the NON three lever quadrant, your engine control cables will be supplied as vernier style. >From December 2007, FWF kits DO NOT contain the wiring harness. EXAMPLE KIT FOR AN RV-7A, O-360, WITH A CONSTANT-SPEED PROPELLER: 1 VA-138 FUEL SUPPLY HOSE 14.0" 1 VA-139 FUEL SUPPLY HOSE 16.5" 1 CT BLUE VPROP 48 7(ALL)/9(ALL) 1 CT BLK THROTTLE 44 6(ALL)/7(360)/9(320) 1 CT RED VMIXTURE 45 7(360)/9(320) 1 FAB-360/540 FLTRD A/BOX-360 FI320 1 BAF-360 COWL BAFFLE KIT 6/7/8 1 VA-149-360-PC KIT THROTTLE/MIXTURE BRACKET 1 VA-153-PC McCauley or MT governor cable bracket 1 PROP GOV MT P-860-4 (I)O-320/360 LYCOMING 1 AT0-028X3/16X6 ALUMINUM TUBE SOFT 1 AT6-058X5/16X15 7/8 ALUMINUM TUBE HARD 1 SS304-26GAX1/2X9 STAINLESS CLAMP MATERIAL 1 FF 3/4 FIREWALL PL SS FIREWALL PLUG 1 ES PC680 INSTALL KIT BATTERY MOUNT 7/9 1 AS3-063X1X12 ALUMINUM STRIP 1 EA LV-1 HEAT SHIELD EXHAUST HEAT SHIELD 2 CT A-740 BLACK PUSH PULL CABLE BLACK 1 DUCT CBT-5/8 COOLING BLAST TUBE 1 EA CV HOSE 9816 BREATHER HOSE 4 CYL 1 EA DYNA BOLT BOLT SET 4 CYL DYNAFOCAL 4 EA DYNA VI-STD VIB.ISO. ALL EXCEPT-10 1 EA EXH W/MUFF 320/360 EXHAUST SYSTEM 1 EA OIL COOLER II O-320/360 OIL COOLER 1 ES 24021 STARTER SOLENOID RELAY 1 ES 24115 MASTER SOLENOID RELAY 1 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT 1 FF-705 OIL BREATHER TUBE 1 FF-709 OIL COOLER DOUBLER 1 VA-161 GASCOLATOR DOUBLER 1 IE VMP INSTALL KIT MANIFOLD PRESSURE FITTINGS 1 GAS-5 GASCOLATOR 1 PT-035X1/4X12 FUEL OVERFLOW TUBE 1 VA-102 FUEL PRES. HOSE 15.5 1 VA-168 FIREWALL SENDER MOUNT 1 VA-133 OIL PRESS. HOSE 27.25 1 VA-134 OIL COOLER HOSE 19.0 1 VA-135 OIL COOLER HOSE 16.5 1 VENT DL-03 2" ALUMINUM DUCT FLANGE 1 VENT SCAT 2X6' RED SCAT TUBE 2"X 6' 1 VENT TG-10 CABIN HEAT SELECTOR 1 DOC FWF COMPLETE TEXT/DRAWINGS 1 CT BEARING HWR, CARB BOLT, NUT, WASHERS 1 CT BEARING HWR, PROP BOLT, NUT, WASHERS 1 BAG 604-1 FF MISC. HDWRE 1 BAG 607 FF MISC. HDWRE 1 BAG 608 FF MISC. HDWRE 1 BAG 611 FF MISC. HDWRE 1 BAG 613-1 FF MISC. HARDWARE 1 BAG 958 AN426AD3-4 1 BAG 991 AN426AD3-3.5 1 BAG 1907 AN426AD4-7 1 BAG 1916 AN426AD3-4.5 1 BAG 1934 AN426AD3-5 1 BAG 1935 AN426AD3-6 1 BAG 312 AN426AD4-6 1 BAG 1978 AN470AD4-5 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, February 05, 2009 10:57 AM Subject: RV10-List: Kits I note that on Tim's site for what is in the various kits, there are listings for a firewall forward kit, separate from finishing kit. However, Vans only lists empennage, fuselage, wing and finishing kits. Has Vans changed how they package things? Or is that just a convenient division of parts in the finishing kit? Kelly 40866 ________________________________________________________________________________
Date: Feb 05, 2009
Have you confirmed that the merchandise is as representeed i.e. new lightspeed headsets The 30-3G lists for $545. Anybody a clue as to value? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb Sent: Thursday, February 05, 2009 12:09 PM Subject: RV10-List: Avionics Liquidation website Found this website and got a new COMANT 105 xponder antenna at a reasonable price. They have all sorts of misc avionics and he's willing to deal... http://www.jimkantor.com/ Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228705#228705 ________________________________________________________________________________
Date: Feb 05, 2009
Subject: Re: Kits
Thanks for the replies. Appreciate all that. I think it is a bit disingenuous of Vans to not list it in the kit prices <http://www.vansaircraft.com/public/kitprice.htm>, and in the price estimator to show $3400-4800 when the current price is $6000. Oh well, won't be the first chunk overlooked in budget. I don't see a whole lot changing in that kit if you stick with a 540 series engine, regardless of source, which is perhaps 98% of all RV-10s? Obviously we can choose to roll own, with the time issues to research, price, order, etc. Kelly Bob Leffler wrote: > > The firewall kit is highly dependent on which engine you get. There are too > many options, so quite a few folks roll their own. Vans does sell a > firewall kit for the 540 models they sell. It's in their catalog. You > can use those as a starting point if you get an engine from another source. > > There is no overlap with the finishing kit. You can see the details here: > http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198&bro > wse=engines&product=FF_Kit The following is off the web store. > > T ________________________________________________________________________________
Subject: FW: pre-load axle spacers
Date: Feb 05, 2009
I received this email today and I am a little confused. I thought I had pur chased and received this product several weeks ago=2C but I can't seem to l ocate the box in the shop. I sometimes do not open the boxes until I need t he item so I may be completely confused the box as it may have been a box f or a different item. I may have purchased direct from the fabricator?....ca n anyone shed some light on this. At least to this point=2C I have not star ted working on the wrong tooth.Reviewing credit card statements.This is why I don't like it when the family throws their stuff down in the shop...I HA TE CLUTTER!!!!John Gonzalez 40409 with Old Timers at 42.Date: Thu=2C 5 Feb ol.comTo: indigoonlatigo(at)msn.com**an immediate response is needed** After much discussion between Cleaveland Tool and Effectus=2C a decision wa s made to produce a one-time-run of the adjustable pre-load axle spacers fo r the RV10 nose wheel. This action is in consideration of the orders made prior to Matco producing their own part. Prices will be: RV10 axle spacer $170.00 RV6=2C 7=2C 8=2C 9 $180.00 (includes replacement axel) We want to have an accurate number of axles=3B therefore we ask that you pl ease respond to this email by Jan 27th. A positive response will lock you in for the purchase of the axle. Cleaveland Aircraft Tool www.cleavelandtool.com 515-432-6794 ________________________________________________________________________________
Subject: Axle issue
Date: Feb 05, 2009
I think it figured it out. I never had the box nor the item...it was backor derred and they are asking if I still want it dispite a cheaper option. So rry for showing my confusion.Yes I still want it and this time I will put t he item in my hand and then store it. Should need it in a few days.John ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Feb 06, 2009
Subject: Kits
There are definitely cheaper and better options for some of the items for t he FWF kit. For instance I believe both Bonaco and Aircrafthose.com have k its to replace the Van's hoses for less money and with integral fire sleeve . I know I went through and deleted probably about half the items in the F WF. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Kelly McMullen Sent: Thursday, February 05, 2009 9:30 PM Subject: Re: RV10-List: Kits Thanks for the replies. Appreciate all that. I think it is a bit disingenuo us of Vans to not list it in the kit prices <http://www.vansaircraft.com/pu blic/kitprice.htm><http://www.vansaircraft.com/public/kitprice.htm>, and in the price estimator to show $3400-4800 when the current price is $6000. Oh well, won't be the first chunk overlooked in budget. I don't see a whole l ot changing in that kit if you stick with a 540 series engine, regardless o f source, which is perhaps 98% of all RV-10s? Obviously we can choose to ro ll own, with the time issues to research, price, order, etc. Kelly Bob Leffler wrote: rv(at)thelefflers.com> The firewall kit is highly dependent on which engine you get. There are to o many options, so quite a few folks roll their own. Vans does sell a firewall kit for the 540 models they sell. It's in their catalog. You can use those as a starting point if you get an engine from another source. There is no overlap with the finishing kit. You can see the details here: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198& bro wse=engines&product=FF_Kit The following is off the web store. T [cid:image001.jpg(at)01C98830.6880A980] ________________________________________________________________________________
Date: Feb 06, 2009
Subject: Flamemaster Shelf Life
I have some expired Flamemaster. Some expired in 2007 and some in 2008. It has spent most of it life since I have had it in the freezer. Is it still good? How would I know if it is not good. Larry Rosen #356 ________________________________________________________________________________
Subject: Re: Flamemaster Shelf Life
Date: Feb 06, 2009
Larry, Mine was crap after the expiration date...I cured so fast it never made it out of the tube, that was the firewall sealant...the proseal seemed Ok but I only used it on the cabin top and naca vents Rick S. ------Original Message------ From: Larry Rosen Sender: owner-rv10-list-server(at)matronics.com ReplyTo: Rv Sent: Feb 6, 2009 8:35 AM Subject: RV10-List: Flamemaster Shelf Life I have some expired Flamemaster. Some expired in 2007 and some in 2008. It has spent most of it life since I have had it in the freezer. Is it still good? How would I know if it is not good. Larry Rosen #356 Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Feb 06, 2009
Take a look at this company, as well. I have used their FP200 expanding foam with excellent results. This caulk looks like it might fit your needs. http://cableorganizer.com/3m-fire-protection/fire-rated-caulk-cp310.htm John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228937#228937 ________________________________________________________________________________
Date: Feb 06, 2009
The problem I found with intumescent fire block products is that they begin to intumess or expand at about 250 degrees. Close proximity to 400 degree cylinder heads could touch off the expansion leaving future voids. Plane Innovations sells a NON intumescent 2000 degree fireblock sealant. www.planeinnovations.com Paul ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Friday, February 06, 2009 1:09 PM Subject: RV10-List: Re: Cowl hinge sealant? > > Take a look at this company, as well. I have used their FP200 expanding > foam with excellent results. This caulk looks like it might fit your > needs. > > http://cableorganizer.com/3m-fire-protection/fire-rated-caulk-cp310.htm > > John > > -------- > #40572 QB Fuselage, wings finished. Finish Kit started. > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=228937#228937 > > > ________________________________________________________________________________
Date: Feb 06, 2009
There's no need to get Intumescent caulk online, it can be had at any local hardware store. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Friday, February 06, 2009 2:09 PM Subject: RV10-List: Re: Cowl hinge sealant? Take a look at this company, as well. I have used their FP200 expanding foam with excellent results. This caulk looks like it might fit your needs. http://cableorganizer.com/3m-fire-protection/fire-rated-caulk-cp310.htm John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228937#228937 ________________________________________________________________________________
Subject: Parking brake
Date: Feb 06, 2009
I would appreciate the brain trust opinion on parking brake installation. I have one in my Socata and find it very useful. Are there downsides other than cost and more seals to leak? Are the Van's valve and install kit the way most are doing it or are there alternatives? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=228974#228974 ________________________________________________________________________________
Date: Feb 06, 2009
RV Builder (Michael Sausen) wrote: > > There's no need to get Intumescent caulk online, it can be had at any local hardware store. > > Michael I had to look it up ..... great scrabble word!!! :-) : An *intumescent* is a substance which swells as a result of heat <http://en.wikipedia.org/wiki/Heat> exposure, thus increasing in volume <http://en.wikipedia.org/wiki/Volume>, and decreasing in density <http://en.wikipedia.org/wiki/Density>. Intumescents are typically used in passive fire protection <http://en.wikipedia.org/wiki/Passive_fire_protection> and, in America, require listing and approval use and compliance <http://en.wikipedia.org/wiki/Listing_and_approval_use_and_compliance> in their installed configurations in order to comply with the law <http://en.wikipedia.org/wiki/Law>. Linn ________________________________________________________________________________
Date: Feb 06, 2009
Subject: Aileron rigging - Reflex ?
I have the flaps and ailerons mounted to the wing and the wing is attached to the fuse. (I don't have the wing tips on yet). It's pretty straight forward to align the ailerons with the trailing edges of each flap. However, I recall somewhere seeing/hearing about a 'reflex' position where the ailerons were rigged 'up' 2-3 degrees on each side. IIRC correctly this increased performance. What's the experience/advice from those who are flying? Deems Davis # 406 'Its all done....and it's almost put together.....' http://deemsrv10.com/ ________________________________________________________________________________
Subject: Re: Parking brake
Date: Feb 06, 2009
Hi Myron, It's pretty easy to roll your own bracket for mounting. I made mine from 3/4" angle and Nick Gautier gave me a duplicate of his plate design that you see between the bracket and valve in the picture attached that will hold the adel clamp for the vernier cable and forms the stop for the arm on the valve. The valve, straight fittings and other odds and ends shouldn't reach $200.00... and you can get it all from Spruce. Jeff Carpenter 40304 N410CF Progress suddenly slowed by the economy (all kinds of time, but no money for the panel) you have the same number of connections to make On Feb 6, 2009, at 2:31 PM, woxofswa wrote: > > I would appreciate the brain trust opinion on parking brake > installation. > I have one in my Socata and find it very useful. Are there > downsides other than cost and more seals to leak? > > Are the Van's valve and install kit the way most are doing it or > are there alternatives? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=228974#228974 > >
Date: Feb 06, 2009
Subject: Re: Aileron rigging - Reflex ?
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233967990-424-648&browse=airframe&product=reflex talks about it, so I assume it exists. Wondering if this unit is preferable to the flap positioning system. On Fri, Feb 6, 2009 at 5:47 PM, Deems Davis wrote: > > I have the flaps and ailerons mounted to the wing and the wing is attached > to the fuse. (I don't have the wing tips on yet). It's pretty straight > forward to align the ailerons with the trailing edges of each flap. However, > I recall somewhere seeing/hearing about a 'reflex' position where the > ailerons were rigged 'up' 2-3 degrees on each side. IIRC correctly this > increased performance. What's the experience/advice from those who are > flying? > > Deems Davis # 406 > 'Its all done....and it's almost put together.....' > http://deemsrv10.com/ > > ________________________________________________________________________________
Subject: Up on its' gear
Date: Feb 06, 2009
Can someone give me a measurement of how high the fuse bottom is off the gr ound while the plane is on it's gear.I need to barrow a pallet jack to rais e my fuse holder off the ground and I want to barrow it and return it in th e same day.Thanks=2CJOhn G. ________________________________________________________________________________
Date: Feb 06, 2009
Mine is 27", measured at the landing gear. Steve Mills _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Friday, February 06, 2009 8:11 PM Subject: RV10-List: Up on its' gear Can someone give me a measurement of how high the fuse bottom is off the ground while the plane is on it's gear. I need to barrow a pallet jack to raise my fuse holder off the ground and I want to barrow it and return it in the same day. Thanks, JOhn G. ________________________________________________________________________________
Subject: Matco RV-10 Nosewheel Axle
Date: Feb 06, 2009
Rene' 801-721-6080 Got an e-mail from Matco today saying they charged my CC, so I gave them a call and yes they were preparing to ship a whole bunch of the axles. Since I am only about 20 miles from them I just asked them to hold mine and ran down and got it. Very nice company to work with. ________________________________________________________________________________
Date: Feb 06, 2009
Myron, I think the parking brake is a 'no-brainer'. I assume that Van's is selling the Matco unit. The installation is straight forward, as far as seals go, The unit is fairly simple and easily serviced. I doubt that you will have a leak in the airplanes useful life. Do it! (its only money!) Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ ________________________________________________________________________________
Date: Feb 06, 2009
I installed the Matco parking brake in my RV10 and it didn't leak until I started using my brakes for engine runup. Then it started leaking out of the valve (not the fittings), so I removed it. Kevin Belue Sent from my iPhone On Feb 6, 2009, at 8:55 PM, Deems Davis wrote: > > Myron, I think the parking brake is a 'no-brainer'. I assume that > Van's is selling the Matco unit. The installation is straight > forward, as far as seals go, The unit is fairly simple and easily > serviced. I doubt that you will have a leak in the airplanes useful > life. Do it! (its only money!) > > Deems Davis # 406 > 'Its all done....Its just not put together' > http://deemsrv10.com/ > > ________________________________________________________________________________
Date: Feb 06, 2009
Wow, That's news, I wonder if others have also had the same problem? Looking at the parts diagram it looks like you should be able to replace the 3 O-rings fairly easily.http://matco.veracart.com/pdf/mastercylinder23a.pdf I wonder if you could get the Vitron O-rings this size? Deems Kevin Belue wrote: > > I installed the Matco parking brake in my RV10 and it didn't leak > until I started using my brakes for engine runup. Then it started > leaking out of the valve (not the fittings), so I removed it. > ________________________________________________________________________________
Date: Feb 06, 2009
Deems; Put the flaps up in the reflex position and then line up the ailerons. You really have to have the wingtips on before you can set the ailerons. The cruise position is to have everything in the "reflex" position. Alex D. taught me to drop the flaps from the reflex to the neutral on downwind. It helps slow you down. Fred Cant wait to see you get done. Deems Davis wrote: > > I have the flaps and ailerons mounted to the wing and the wing is > attached to the fuse. (I don't have the wing tips on yet). It's > pretty straight forward to align the ailerons with the trailing edges > of each flap. However, I recall somewhere seeing/hearing about a > 'reflex' position where the ailerons were rigged 'up' 2-3 degrees on > each side. IIRC correctly this increased performance. What's the > experience/advice from those who are flying? > > Deems Davis # 406 > 'Its all done....and it's almost put together.....' > http://deemsrv10.com/ > > ________________________________________________________________________________
Date: Feb 06, 2009
Yes, I was thinking it would be easy to repair, but after the pain of getting to it and removing it, I decided to not go through that again and left it out. It is really in a difficult place to access once everything is finished. I mounted mine the same as most of you did- in place of the bracket that holds the brake lines to the firewall. I hope you guys have better luck than I did. Kevin Belue Sent from my iPhone On Feb 6, 2009, at 9:49 PM, Deems Davis wrote: > > Wow, That's news, I wonder if others have also had the same problem? > Looking at the parts diagram it looks like you should be able to > replace the 3 O-rings fairly easily.http://matco.veracart.com/pdf/ > mastercylinder23a.pdf > I wonder if you could get the Vitron O-rings this size? > > Deems > > > Kevin Belue wrote: >> >> I installed the Matco parking brake in my RV10 and it didn't leak >> until I started using my brakes for engine runup. Then it started >> leaking out of the valve (not the fittings), so I removed it. >> > > ________________________________________________________________________________
Date: Feb 06, 2009
I would let Matco know of this. I think they would make it right based on my experience with them thus far. Also if there is an issue, which I can't figure out why the valve would fail so soon then they need to be aware of it. Since yours is out already no harm calling Matco explaining the issue and seeing if they will RMA and fix for you and figure out why the valves are leaking. P -------------------------------------------------- From: "Deems Davis" <deemsdavis(at)cox.net> Sent: Friday, February 06, 2009 7:49 PM Subject: Re: RV10-List: Parking brake > > Wow, That's news, I wonder if others have also had the same problem? > Looking at the parts diagram it looks like you should be able to replace > the 3 O-rings fairly > easily.http://matco.veracart.com/pdf/mastercylinder23a.pdf > I wonder if you could get the Vitron O-rings this size? > > Deems > > > Kevin Belue wrote: >> >> I installed the Matco parking brake in my RV10 and it didn't leak until I >> started using my brakes for engine runup. Then it started leaking out of >> the valve (not the fittings), so I removed it. >> > > > ________________________________________________________________________________
Date: Feb 07, 2009
Did you have the PVPV-1 or PVPV-D? I just ordered a PV-2 yesterday from Van's, which I believe is the PVPV-D. Just curious..... Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kevin Belue Sent: Friday, February 06, 2009 11:43 PM Subject: Re: RV10-List: Parking brake Yes, I was thinking it would be easy to repair, but after the pain of getting to it and removing it, I decided to not go through that again and left it out. It is really in a difficult place to access once everything is finished. I mounted mine the same as most of you did- in place of the bracket that holds the brake lines to the firewall. I hope you guys have better luck than I did. Kevin Belue Sent from my iPhone On Feb 6, 2009, at 9:49 PM, Deems Davis wrote: > > Wow, That's news, I wonder if others have also had the same problem? > Looking at the parts diagram it looks like you should be able to > replace the 3 O-rings fairly easily.http://matco.veracart.com/pdf/ > mastercylinder23a.pdf > I wonder if you could get the Vitron O-rings this size? > > Deems > > > Kevin Belue wrote: >> >> I installed the Matco parking brake in my RV10 and it didn't leak >> until I started using my brakes for engine runup. Then it started >> leaking out of the valve (not the fittings), so I removed it. >> > > ________________________________________________________________________________
Date: Feb 07, 2009
Hi John, =C2-Did you get my last message about going to the spring gathering and s elling our Cirrus and getting a low-time Tiger? Brian ----- Original Message ----- From: "" <n212pJohn Jessenj(at)gmail.com> Sent: Wednesday, February 4, 2009 10:02:59 AM GMT -08:00 US/Canada Pacific Subject: RE: RV10-List: New TSA Security Requirements Hey, Brian.=C2- How's the Cirrus running?=C2- Hope you can come up to A lbany this Spring for the RV-10 gathering.=C2- Once an RV-10=C2-builder , always an RV-10 builder!=C2- John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of cloudvalley(at)comcast.net Sent: Wednesday, February 04, 2009 9:47 AM Subject: Re: RV10-List: New TSA Security Requirements Hello John! =C2-Thank you for that! I love it! Get the H off our field! I would have loved to see that! Ha Ha HA... =C2-We will look for a field like that also, or igve up flying before we allow any intrusion into our freedom=C2- when it comes to flying. We wrot e Phil Boyer before who agreed with me about the tsa. Brian Preston == ________________________________________________________________________________
Date: Feb 07, 2009
Another leak issue is when you set the break and it is cool, go away and the weather warms, it will blow out the seal in the wheel because there is no place for the expanded fluid to go. This happened with solid lines, so if you have flexible ones you might be OK. Someone with too much time on there hands could calculate the expansion volume and let us know. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Friday, February 06, 2009 10:50 PM Subject: Re: RV10-List: Parking brake Wow, That's news, I wonder if others have also had the same problem? Looking at the parts diagram it looks like you should be able to replace the 3 O-rings fairly easily.http://matco.veracart.com/pdf/mastercylinder23a.pdf I wonder if you could get the Vitron O-rings this size? Deems Kevin Belue wrote: > > I installed the Matco parking brake in my RV10 and it didn't leak > until I started using my brakes for engine runup. Then it started > leaking out of the valve (not the fittings), so I removed it. > ________________________________________________________________________________
Subject: Re: MT prop governor rotation - final position
Date: Feb 07, 2009
AirMike wrote: > I need to position my MT prop governor to set the opening in the fwd baffle on the left front area of the engine. I know that you loosen the six screws that retain the governor arm. You only loosen the screws - DO NOT REMOVE. Then you can rotate the arm part of the prop governor. This related to me by Jurgen at MT. > > Question: What is the final position of the arm on the MT prop governor? > > It looks like the passive position of the arm should be in the 10:00 position as you look at it from the pilot side. Could anyone already flying please set me straight on this......... Did you ever find out the starting 'clocking' position. I want to do this, this weekend also. -------- Gary Blankenbiller RV10 - # 40674 Engine, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=229049#229049 ________________________________________________________________________________
Date: Feb 07, 2009
I don't think any parking brake will stand up to that abuse. IMHO, a parking brake is to hold the aircraft just long enough for you to place chocks, or to hold it during runup so you don't inadvertently let it creep while running checklist. Holding pressure on the system for hours or days is just asking for a leak or failed O-ring. gary wrote: > > Another leak issue is when you set the break and it is cool, go away and the > weather warms, it will blow out the seal in the wheel because there is no > place for the expanded fluid to go. This happened with solid lines, so if > you have flexible ones you might be OK. Someone with too much time on there > hands could calculate the expansion volume and let us know. > > Gary Specketer > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Friday, February 06, 2009 10:50 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Parking brake > > > Wow, That's news, I wonder if others have also had the same problem? > Looking at the parts diagram it looks like you should be able to replace > the 3 O-rings fairly > easily.http://matco.veracart.com/pdf/mastercylinder23a.pdf > I wonder if you could get the Vitron O-rings this size? > > Deems > > > Kevin Belue wrote: > >> >> I installed the Matco parking brake in my RV10 and it didn't leak >> until I started using my brakes for engine runup. Then it started >> leaking out of the valve (not the fittings), so I removed it. >> >> > > > -- ________________________________________________________________________________
Date: Feb 07, 2009
The word "parking brake" is deceiving. It is not meant to be left on all the time when "parked". It is for temporary use. set to hold plane in place while a long term solution (chocks, etc) is completed. The parking brake is than released before leaving. Pascal -------------------------------------------------- From: "gary" <speckter(at)comcast.net> Sent: Saturday, February 07, 2009 5:42 AM Subject: RE: RV10-List: Parking brake > > Another leak issue is when you set the break and it is cool, go away and > the > weather warms, it will blow out the seal in the wheel because there is no > place for the expanded fluid to go. This happened with solid lines, so if > you have flexible ones you might be OK. Someone with too much time on > there > hands could calculate the expansion volume and let us know. > > Gary Specketer > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis > Sent: Friday, February 06, 2009 10:50 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Parking brake > > > Wow, That's news, I wonder if others have also had the same problem? > Looking at the parts diagram it looks like you should be able to replace > the 3 O-rings fairly > easily.http://matco.veracart.com/pdf/mastercylinder23a.pdf > I wonder if you could get the Vitron O-rings this size? > > Deems > > > Kevin Belue wrote: >> >> I installed the Matco parking brake in my RV10 and it didn't leak >> until I started using my brakes for engine runup. Then it started >> leaking out of the valve (not the fittings), so I removed it. >> > > > ________________________________________________________________________________
Subject: race
Date: Feb 07, 2009
this was posted on Vansairforce web site by Pierre Smith--neat!!!! Larry B. "I was reading my new EAA Chapter 172 newsletter this morning and the following story appeared: A friend of mine had flown his brand new RV-10 to Greenwood, S.C. for a breakfast meeting and so had another friend of ours, in his F-33 Bonanza. They agreed to do a formation takeoff with the RV ahead, then in level flight, start the race at 2500RPM. The Bonanza pilot hollered to slow down on take-off because the -10 was blistering him, so he rotated with only 18" MP showing. The Bo pilot flew directly behind the unpainted -10 in order to sync his prop with the ten, visually (how cool is that?). BTW, this guy flies airshows in his MX 20, then pulled up alongside the 10. "Let's go, full throttle", he said. The -10 couldn't believe that he was pulling the airplane of his dreams, the Bo' by a hefty margin, neither could the Bo's owner......end result.....even with the gear tucked, the -33 made 176 GPS knots and the RV did 184 GPS knots, on his Garmin 430!! full of fuel, one soul aboard both airplanes. The -10 has a three-bladed composite prop and a stock IO-540, and it's named "Bo Derek". They relayed the results back via radio to the EAA guys who were all made aware of the impending race beforehand...too cool. BTW...the -10 has a Sam James cowl and plenum. He's contemplating a new name now....Bo' smoker...Mercedes beater.. Yep, all you -10 builders will never regret your decision," Regards, __________________ Pierre Smith RV6A (Sojourner) 180 HP, Catto 3 Bl (410Hrs) Air Tractor AT 502B PT 6-15 EAA Flight Advisor/CFI/Tech Counselor....green Transition training Louisville, Ga -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=229066#229066 ________________________________________________________________________________
Date: Feb 07, 2009
I looked in my archives from OSH-08 and found some pictures that indicate that the arm should be in the 10:00-10:30 position. See my prior comments on rotation. You want the arm to be able to pull down without too much fore and aft movement on the bushing One thing that this taught me was that my 200+ pictures of RV10's that I took at OSH were a real help in finishing this project. If you are a newbee, I cannot tell you how valuable the pictures that you take at OSH (of RV10's) are in finishing this plane -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=229069#229069 Attachments: http://forums.matronics.com//files/p1020054_192.jpg ________________________________________________________________________________
Subject: Re: Up on its' gear
Date: Feb 07, 2009
Yes to all of the above, but you need to raise it up higher than that in order to capture the gear in the receiver. I would est that you need to jack it 33-36" up to get the gear legs in the hole. Remember also to grease the gear legs before hand. Good luck. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=229073#229073 ________________________________________________________________________________
Date: Feb 07, 2009
Deems and Tim are my baseline when it comes to thousands of pictures. John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of AirMike Sent: Sat 2/7/2009 9:52 AM Subject: RV10-List: Re: MT prop governor rotation - final position I looked in my archives from OSH-08 and found some pictures that indicate that the arm should be in the 10:00-10:30 position. See my prior comments on rotation. You want the arm to be able to pull down without too much fore and aft movement on the bushing One thing that this taught me was that my 200+ pictures of RV10's that I took at OSH were a real help in finishing this project. If you are a newbee, I cannot tell you how valuable the pictures that you take at OSH (of RV10's) are in finishing this plane -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=229069#229069 Attachments: http://forums.matronics.com//files/p1020054_192.jpg ________________________________________________________________________________
Subject: Change in Economy... Change in Plans... Interior
Date: Feb 07, 2009
With the downturn in the economy (my business, a commercial printing company, is down 40%) I'm having to rethink my RV-10 plans and would love to hear some thoughts about cost cutting options in the home stretch. I imagine I'm not the only one struggling with these issues and I think the conversation would benefit many. Because of where I am in the build, and the many topics this will span, I think it's best to break this in to three threads: Interior, Panel and Paint. Others may want to expand beyond these three, but these are the areas I have in front of me to consider. The option of taking on a partner is also something I'm considering, but I want to see things play out a while longer before I go that route. My plan has been to buy a Flightline Interior in leather at a cost of about $5000. I'm now considering adding the craft of upholstery to the list of things I've learned while building this plane. For those that have "rolled your own" interiors, was the raw material cost low enough to realize some savings? What are some good resources for headliner, carpet and leather? What tools are required? What are the best "How To" books to read? Up until now, I have had a nice mix of time and money. Now I've got a surplus of time... money, not so much. Jeff Carpenter 40304 N410CF (reserved) ________________________________________________________________________________
Subject: Change in Economy... Change in Plans... Panel
Date: Feb 07, 2009
This is the panel I want (well, what I really want is a Garmin G900X), but the current economic conditions are making it look like I'm going to have to work up to this panel instead of getting it all at once. I think I'm going to have to start out as a basic VFR machine. With that in mind, what is the essential subset here and in what order would you add the other items? AFS Advanced Deck with AOA and Battery Back Up ARINC 429 Datalink GNS 430W SL30 Trutrak Digiflight II VSGV GTX 330 Transponder PMA9000EX Audio Panel Compass and this: UMA 2 1/4" Airspeed Indicator UMA 2 1/4" Altimeter Trutrak 2 1/4" ADI with Battery Back Up or this: AFS 3400 and Battery Back Up Jeff Carpenter 40304 N410CF (reserved) ________________________________________________________________________________
Date: Feb 07, 2009
Jeff, when I built my Pietenpol Aircamper (which, btw is in this month's Sport Aviation on page 78) I got an entire hide of leather from B&B Aircraft Supply at OSH for $110 (this was in 2002). I made the seat cushions with Temperfoam and then took the foam and the leather to a local upholstery shop that specializes in boat upholstery. They charged me $400 to make two seat cushions, so between the foam, the leather and the upholstery shop, I put a total of about $600 into two seats (and had enough leather left over to make the cockpit coamings, and still more is left). I would think if you do it yourself like that, even paying professionals to sew it (leather requires pretty heavy duty sewing machines) you should be able to do all four seats for about $1,000. Jack Philllips RV-10 #40610 Pietenpol NX899JP -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter Sent: Saturday, February 07, 2009 4:42 PM Subject: RV10-List: Change in Economy... Change in Plans... Interior With the downturn in the economy (my business, a commercial printing company, is down 40%) I'm having to rethink my RV-10 plans and would love to hear some thoughts about cost cutting options in the home stretch. I imagine I'm not the only one struggling with these issues and I think the conversation would benefit many. Because of where I am in the build, and the many topics this will span, I think it's best to break this in to three threads: Interior, Panel and Paint. Others may want to expand beyond these three, but these are the areas I have in front of me to consider. The option of taking on a partner is also something I'm considering, but I want to see things play out a while longer before I go that route. My plan has been to buy a Flightline Interior in leather at a cost of about $5000. I'm now considering adding the craft of upholstery to the list of things I've learned while building this plane. For those that have "rolled your own" interiors, was the raw material cost low enough to realize some savings? What are some good resources for headliner, carpet and leather? What tools are required? What are the best "How To" books to read? Up until now, I have had a nice mix of time and money. Now I've got a surplus of time... money, not so much. Jeff Carpenter 40304 N410CF (reserved) ________________________________________________________________________________
Date: Feb 07, 2009
Subject: Re: Change in Economy... Change in Plans... Panel
If are really trying to save money now with the ability to add it later consider this: Paint the interior, you can then add it later. The head liner would be easier to install now, but many have done it later. Don't paint the exterior until later You will get the most bang for your buck on the panel, and it will still be much better than most of the spam cans out there. Single screen ASF 3500, leave room for the second screen SL 30 portable Garmin gps x96 which you may already have GTX 327 PMA 8000 compass use your portable com as the back up add the air speed and altimeter (they are not that expensive) install the ADI later If you plan for the future adding in the other components later will not be that hard. You could even cut the openings now and cover them with a plate. Jeff Carpenter wrote: > > This is the panel I want (well, what I really want is a Garmin G900X), > but the current economic conditions are making it look like I'm going > to have to work up to this panel instead of getting it all at once. I > think I'm going to have to start out as a basic VFR machine. With > that in mind, what is the essential subset here and in what order > would you add the other items? > > > AFS Advanced Deck with AOA and Battery Back Up > ARINC 429 Datalink > GNS 430W > SL30 > Trutrak Digiflight II VSGV > GTX 330 Transponder > PMA9000EX Audio Panel > Compass > > and this: > > UMA 2 1/4" Airspeed Indicator > UMA 2 1/4" Altimeter > Trutrak 2 1/4" ADI with Battery Back Up > > or this: > > AFS 3400 and Battery Back Up > > Jeff Carpenter > 40304 > N410CF (reserved) > > ________________________________________________________________________________
Date: Feb 07, 2009
AirMike wrote: > I looked in my archives from OSH-08 and found some pictures that indicate that the arm should be in the 10:00-10:30 position. A picture is worth a 1000 words. Thanks -------- Gary Blankenbiller RV10 - # 40674 Engine, Fiberglass - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=229118#229118 ________________________________________________________________________________
Date: Feb 07, 2009
Subject: Re: Change in Economy... Change in Plans... Interior
Jeff Carpenter wrote: > > With the downturn in the economy (my business, a commercial printing > company, is down 40%) I'm having to rethink my RV-10 plans and would > love to hear some thoughts about cost cutting options in the home > stretch. I imagine I'm not the only one struggling with these issues > and I think the conversation would benefit many. Because of where I > am in the build, and the many topics this will span, I think it's best > to break this in to three threads: Interior, Don't install an interior. You can always do that later. > Panel Don't know whether you're planning on full IFR, but you can install a VFR panel and then upgrade to IFR when you have the cash. > and Paint. If you have a hangar to store the completed plane in, then even paint can be delayed. If no hangar, I'd recommend painting it so it withstands the weather better. > Others may want to expand beyond these three, but these are the > areas I have in front of me to consider. The option of taking on a > partner is also something I'm considering, but I want to see things > play out a while longer before I go that route. > > My plan has been to buy a Flightline Interior in leather at a cost of > about $5000. $5000 will go a long way to populate your panel. And you'll be somewhat lighter for it! ;-) > I'm now considering adding the craft of upholstery to the list of > things I've learned while building this plane. For those that have > "rolled your own" interiors, was the raw material cost low enough to > realize some savings? By the time you invest in an industrial sewing machine and toss the 'learning experience' material, I'm not sure that you'd be very far ahead. You'll surely save on the frustration level by contracting that part out. Installing the 'bad' parts will aggravate you each time you lay eyes on it .... and that's true when only you notice!!! Good luck Linn > What are some good resources for headliner, carpet and leather? > What tools are required? What are the best "How To" books to read? > > Up until now, I have had a nice mix of time and money. Now I've got a > surplus of time... money, not so much. > > Jeff Carpenter > 40304 > N410CF (reserved) > > ________________________________________________________________________________
Date: Feb 07, 2009
Jeff; I feel your pain, my group at the Corp continues to diminish each month, they announced a 12K headcount reduction within the year and no one is safe, so I have slowed my project waaay down to assure I have funds for that thunderstorm should I get stuck in that layoff. I plan to spend the money on the engine- new one, maybe do what you did and get it on clearance at Sun n Fun, I plan to get the panel I planned on or maybe better as technology allows, , my seats are done locally using a good quality faux leather since my 2 daughters are very young and will test the seats for durability so anything less or more was not acceptable. Everything else is not critical to my mission and can be done to a minimum. I'll paint the interior with a decent paint and deal with better later, outside will probably get painted like Tim did since it will be far easier time and financially to do it in pieces than after completion in a pro shop. I'll take my time doing all this as it will cost money to park the plane in a hangar, pay California taxes and of course all those trips for the family as Tim has teased us all with these last three years once the plane is completed, THAT will far outdo any spending I am doing now. The good news for me is by my saving for the thunderstorm, if it dissipates before hitting me I'll have the funds to finish and afford flying the plane, so time is a good thing. Be patient and work on the plane, delay the major purchases as long as possible, and get the panel you want that too will cost more to replace and redo later than just doing it right the first time. Best of success with whatever you decide to do. Pascal -------------------------------------------------- From: "Jeff Carpenter" <jeff(at)westcottpress.com> Sent: Saturday, February 07, 2009 1:42 PM Subject: RV10-List: Change in Economy... Change in Plans... Interior > > With the downturn in the economy (my business, a commercial printing > company, is down 40%) I'm having to rethink my RV-10 plans and would love > to hear some thoughts about cost cutting options in the home stretch. I > imagine I'm not the only one struggling with these issues and I think the > conversation would benefit many. Because of where I am in the build, and > the many topics this will span, I think it's best to break this in to > three threads: Interior, Panel and Paint. Others may want to expand > beyond these three, but these are the areas I have in front of me to > consider. The option of taking on a partner is also something I'm > considering, but I want to see things play out a while longer before I go > that route. > > My plan has been to buy a Flightline Interior in leather at a cost of > about $5000. I'm now considering adding the craft of upholstery to the > list of things I've learned while building this plane. For those that > have "rolled your own" interiors, was the raw material cost low enough to > realize some savings? What are some good resources for headliner, carpet > and leather? What tools are required? What are the best "How To" books > to read? > > Up until now, I have had a nice mix of time and money. Now I've got a > surplus of time... money, not so much. > > Jeff Carpenter > 40304 > N410CF (reserved) > > > ________________________________________________________________________________
Subject: Getting ready for the Monster Plane rally
Date: Feb 07, 2009
People that visit the shop now say:1) Hey how big are those tire gonna be?2 ) Are ya goin to a monster truck rally?3) You musta spend time at a boat ya rd.4) How ya gonna get that thing outa here?This is 33" off the ground at t he belly...it is level fore and aft and side to side. Only took a few hours and all the wood around the property that I could find. Tried to move the engine crate from the storage container to the shop=2C but the fork lift go t stuck in the gravel=2C we had to pull it out with the F250. Just another day=2C not much accomplished.Just having a little funThe last shot is a pic ture of my teeth after propping the plane up today=2C I was cleanching! Jus t a little nervous!John G. /9j/4SIFRXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAQAAAA0gEyAAIAAAAUAAAA4gE8AAIAAAAQAAAA9gITAAMAAAABAAIAAIdpAAQA AAABAAABBgAAB6wgICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNS41ADIwMDk6MDI6MDcgMTk6NTk6MjMATWFjIE9TIFggMTAuNC45AAAhgpoABQAAAAEA AAKYgp0ABQAAAAEAAAKgiCIAAwAAAAEAAgAAiCcAAwAAAAEAMgAAkAAABwAAAAQwMjIwkAMAAgAA ABQAAAKokAQAAgAAABQAAAK8kQEABwAAAAQBAgMAkQIABQAAAAEAAALQkgQACgAAAAEAAALYkgUA BQAAAAEAAALgkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAEAAAkgoABQAAAAEAAALo knwABwAABDYAAALwkoYABwAAAH0AAAcmoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAogoAMABAAAAAEAAAbAowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAAAAEAAAAApAIAAwAA AAEAAAAApAMAAwAAAAEAAAAApAQABQAAAAEAAAekpAUAAwAAAAEAHAAApAYAAwAAAAEAAAAApAgA AwAAAAEAAAAApAkAAwAAAAEAAAAApAoAAwAAAAEAAAAApAwAAwAAAAEAAAAAAAAAAAAAAAoAAACJ AAAAHAAAAAoyMDA5OjAyOjA2IDIzOjExOjA5ADIwMDk6MDI6MDYgMjM6MTE6MDkAAAAABAAAAAEA AAAAAAAACgAAAB4AAAAKAAAAOgAAAApOaWtvbgACAAAASUkqAAgAAAAYAAEABwAEAAAAAAIAAAIA AwACAAAAAAAAAAMAAgAGAAAALgEAAAQAAgAHAAAANAEAAAUAAgANAAAAPAEAAAYAAgAHAAAASgEA AAcAAgAHAAAAUgEAAAgAAgAIAAAAWgEAAAoABQABAAAAYgEAAA8AAgAHAAAAagEAABAABwDuAQAA cgEAABEABAABAAAAwgMAAIAAAgAOAAAAYAMAAIIAAgANAAAAbgMAAIUABQABAAAAfAMAAIYABQAB AAAAhAMAAIgABwAEAAAAAAAAAI8AAgAQAAAAjAMAAJQACAABAAAAAAAAAJUAAgAFAAAAnAMAAJsA AQACAAAAAAAAAJwAAgAUAAAAogMAAJ0AAwABAAAAAAAAAJ4ABwAKAAAAtgMAAAAAAABDT0xPUgBG SU5FICAAAEFVVE8gICAgICAgIAAAQVVUTyAgAABBRi1DICAAACAgICAgICAAUCMAAOgDAABBVVRP ICAAAAUCAAAAAAAAAAD/AQAAGWESMQAAgdEAACDMAACLxgABF4wAAReMAACLmAABG0YAZACDADIA HQAAAAAAAAnRAAAEgQAAAAAiHwAAAAAAAAYAAAAAADAAPBEAAEgDFZIAcwSBAAADrgBXCE4AAAAA AAAAAAAAAAAiIiIiIiIiIiIiIiIiIiIiEREREQFrA6ED7QGGAgIBxAHdAgABAwBgAAEDUgAAAA8A HgAQAAUABQAAAAAAHgAQAAAAAAAAAAAAgwFHAdQCYAMKAgIBLwICAmEAAAwTDPUAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiIiQAAPgAAAHAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAIeAkcCKQHzARAD4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAIeAkcCKQHzAAAAAAAAAAAKYgvgC74J5wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAHd3d3cXIhQfFx8QHg4XZABNAQoBAAGCAAAAJABBBGDMHoIAZBks ZFcbJRskAdUBfwGPAqEAAABKAC0APwHEAd1mZmZmAAAACAAAAAkAAAAKQVVUTyAgICAgICAgIABP RkYgICAgICAgICAAAAAAAAAAAAAAZAAAAGQAAAAgICAgICAgICAgICAgICAAT0ZGIAAAICAgICAg ICAgICAgICAgICAgIAAAAAAAAAAAAAAAAAAHAAMBAwABAAAABgAAABoBBQABAAAAHAQAABsBBQAB AAAAJAQAACgBAwABAAAAAgAAAAECBAABAAAAEzYAAAICBAABAAAAaUsAABMCAwABAAAAAgAAAAAA AAAsAQAAAQAAACwBAAABAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAAAAAAAAAAGQABwEDAAMAAAABAAYAAAEaAAUA AAABAAAIBgEbAAUAAAABAAAIDgEoAAMAAAABAAIAAAIBAAQAAAABAAAIFgICAAQAAAABAAAZ5wIT AAMAAAABAAEAAAAAAAABLAAAAAEAAAEsAAAAAQAA/9j/4AAQSkZJRgABAQEASABIAAD//gAMQXBw bGVNYXJrCv/bAIQABwUFBgUFBwYGBggHBwgKEQsKCQkKFA8PDBEYFRkZFxUXFxodJSAaHCMcFxch LCEjJygqKioZHy4xLSkxJSkqKAEHCAgKCQoTCwsTKBsXGygoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUS ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3 AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgAagCg AwEiAAIRAQMRAf/aAAwDAQACEQMRAD8A0Z/ghod1GzaT4qiLgnak21t2O3UY7+vSsO++Ceu2k8UV re2Vw0yhowJCpOeg6EfrWI+ra7ao3n2kbsy7d8UvAx0PAP61ds/FM0V0JVW4tQqpt3Ek5AHII5HI zkVzOeGmbWrxKM3w+8U2DOW01mOeSjoc/rmq39ha1Ehkm0S8RE5Z/s7gAe56V1+neNxZuTBudXyA shO7d146V6r4T8RWUNi9xdt5EaswLsx4wTwc4ye3HJ44pPC0J6p/iP284uzR86oF27WjdeO1Tpbx yBfnJcf3l5r6j0a9t9e00G8S2l81ifKba+V916D/AAIPBOKddeDfDd3F5cmh2IXPWKERn81wazlg IdJMpYl9UfMaJKpILbvx5/WpXtJRGJvJPlFtu7GQD6Zr3HXvhp4T2I/lXGnKucmCQsH9jkkjpxjH Ws2fwt4Tg22h1HfCORCQwBYcA/LyTjPOf8axeXTtdSRX1qPY8cZSqgSxcHkYPXnvmopoIj0yPm3Y UlSP6V65N4A0W886VNYmMyFYY02ZI4+VNpOSRgjqOw+uPN8KtWkiE9mY7hDwNylD+A5rlnhakX7u voaxqxlucBDJdoxHm5XORuyc/jV/7S3loVDNwQ2PXPYelaF/4R1LSrgQ30EduUOXLXCLlOMkAkE4 9qpNpzw2UVy8R/eSMm4jAAwCD+PPOedp9DUyVWnuK0JbDorovkLkkdcdqlW929/1qgwG12OdpAHz KDnv1PSqboOqsEA5yGx/P/GnGvfcmVHsbkWqGZS2HTBK4cYPBxn6elSpf4yxaNgCPlkYgHnnp7f5 Fc1ukVASxwT1IpjXEi43NnHQE+/bPue1bqrFmLptHoOgRWt9cpG10DyMgBpG/IAk16tZ+FrKFFby 5ZTxxs2n/wAexXzjYeILvTLlJ7a5kt5ozw8bFSOx6V0afEfXZgQ+sXWSOCsxXB4/PvW0eX7RGqPf 10a1QDZaKfXe2P5A1BdJorAw3MmmbD8rxTlWz7YJH8q8v8F6deeL5ZpJb+R1jxvZt5IJ98YrvY/A 2nwx5uXLbRy3AH45NbLX4IC9WfKz6rLAgzauR6JcMB+WajbVyAWfT5QcdTcZ/mcU6z1FbdWefTIb 2LzOJAQwGeAMbT6/rXU2nibQ1s0im8LWtxIp++1u4yPxhPT/AAqJ+zitS4ub2ZlWuv6YNLktxpNw NQily9zHdLlF/uFAeDkHn68VZt/EIt0Zit3hePuiTn6enHXt+Nc6tjLa3+qXr2qWVjdTGSILKqiN SWIXaMEDB7gdO1XdOv8AT9RuFtrWfzJWBIjG/J+mRyevSpkoz2X3D55rc6aPxu9kQsi3EDjkq1oy sP8Ax3itO3+Ks8UASC5uVXkAoJlHX24qvp3w88Qa4oFvpskUbYHn3P7qMAnrk/eA7hQT7VYn0uw8 Iu+laba/8JH4ghBeUvF/otrwGb5T98qM/M2FwcleKunhXPVK33g61viOo0SLxL44sH1CC9cRqwCf axKiOM4LBiAGC4OcEkYPHIzaFt4X0VZZNc8RNeXY2/ubGMr5Tg5OGOd3THOPp6N0nVdVi8Eanquq 6kLm+3FZHjljmRFBGVVlypBBwccZHFeKDxCZdQjaC0jBklBWF8umSen7xmOPqa9T2EKUU27/AH+T /U5HWlNtJJf1/wAA9Rn+IWhW15Jb6To6rGAZC9zvlXAB+ZlMhBxk9u/vXR6/rl5pEKX9rHGmoyth HVFG1mBywGDk8n/vrv0PHR3mk6jpSyz6HaWt7PEV3WpIUhzklh06cYUAA+2AOx1UW2oS6HeBlaze 8hdpdwCCNudxPpwPzq5qElFru191tPxM4ykm032OGk8Y+J9WuG/tCdLpcjKmNUyO4ygDc+xBHrS6 zq0es2ggl0mzsp0H7u7tFYSA4wC28tv4yCD6+uCOo+J2jWmhajHJYmFFmUM8ZlAKn1xnIBI/nXM6 d4Z1bUpVdbKZlL7dxVU2+/7wqWX3XNcLhKXvPQ25raHH3kN/Y2kcojBCnDtC7spA6Mc8j3z+ZzVG PVdQZtyhXB4BwcD3PGa92HwzmeBGhniMh4dHkKrj14Q5PtXc+EdPutD09bG6ttOgjjGIzZAjPu3y KCffHbnOaxVClLWVjVVJrqfKker3X2mO1EKyTSAkYYqAACTnORjAp0txLDPNDJZ3L5P31jYryOgI 4/pX0T8TLG3vo4JYGZ7xPk8sRs29eehAxnNeU3Hh28UF7i2e0IBbFwjRkjgZ5HTkfnWdbCxiuaK0 Zca193qeeSXCJLIC7Ryddki4JJ9utR27TTtJm4dVViMqB6A+nufyrqtRPkW93BNtZgjrsD8MORkV hWNiqIOFT5dyBWGHXJGcZ45B6is1HlCUrlixnurVG8q8uVJyCyvt6H2ptteTXNxKLiaeYJxh5Cc/ O4/9lFXba3RoTgrw7Ajr3IqjpsYW7uQXAx1wv/Tab/CmpOzIZlnQ7S1t7i/tYred47sNbCCbzHCZ 6FQe2Op596igNx/a6ytfIY3cyeU12vyox4ypPUdcdfaqF1dzR3qyHU5FVpg/kiR8qpORxjbjHbNW Lr7JPdzNkxzDyhH8m7zMqAVz2OCO3O085q/ifvLdGmy07mzpNlYG2kj1Oe6ullCkxmfaqgfMQep6 jHBHAPPIx0ttf6dp9wbjTYI7V3yWaGMJIMnld3JxwOM4rk9HiEkzWynmQMnzY4PP8sD9a0fslxbx hJNodG2NGHGVz0/PmtkoIyldnuXhrxXYvpMDz6hGkshdnFxcgyE7jyxOM8CuR8RfDqy8R6rLqNvq aA3DNJIY58ZY9BjDDGO4x9DXKWWnXNxtA4PXg8YHFbEOn6hb27TLbsi44DdT68cZHTmu6lXS0SVj KVJy9TqdH8NpZ+DrvwsLqNjK7BG80MdpKkkkDg9e1clP8GiCNlxK5HPyTLx+ait7wW8011cSyDDA rgDoMbs/0ruDJXQ67trFP5f12MXRs92eb2/gnV7CJIkeedU6B5IycemcCuwjsJrnw9Hp2pSLHcMu AIn242tlBnuQAuexweoNWr2++ygO0MsgLBcRAEjJ6nkcVm65HFI9tqA5ltNxjJzgbhg/yxWFSs5K ySXXQ0hTs7vUuab4d03T2ikSISzpk/aJQHkyQAcEj5c46Lge3NXrnWbXTGHDSzZ+6nJH1PauftdT klG0yBR3wMU3yfPV5Ht41+ZgEDZLAEgHsBkAH8a5Z6u8maJW2NS68UaxcnbbvHBGP4Y2G9vqc5/L FUdT8T3+kRPcanpouNq8rMhBYngLuHPUiqh0qF2+WV0YZ4STA/I8VzPjJ2srCGCadri2llJaN3Ij VgpVWYJgnG/sfz6HFwSLTMK41OfxBqySZ8+4ncBLVF2j5iFVVX/vn5e/HU1NBE/k3EE0iJBKqiKC SUEq6yhtu3nyydr8Nt3Eg89a53VNXvGht7GOOO2h2otwtuNgugo+Qvg7WwCcNjJDEkkkk6Oj3N6J LWO8NyIDdRLapMxCYYy/MN3RS/JI9+pzWbVlcYnijQVv54itxJbSQKYZU2hl3BjyrKxVlwRggnoe 2CYp5t+sagEYlxPKMk8A+Yx/kwqWZNYSfdqc8co8jDmPb/rN/wAvQD+DAI9evNY1/p8dvrE6zRxX JvJJLgbo8lcsfl9/X86xU7zcb+hpKNoJ2Nu2LrGc8Dex/wDHjVLTXU3VwQMnLZPUH99Ljj8/zFS2 Gm3cu2O3tNq/MyjyCq4z6nAHXvVWzsJo55VMsTTvNJD9nVWMnDlw2MYKsJBjBJ+U5A4Jq2jM9w/4 RyKbzTcIrIThGQ/MRtwDz0OO3I/Krkfgu+lKXizJEp+Yssxjdgc9eCMbWI6evrivUNP+FevJYPbt d2IDoqnEj43DB5+T69O9c74x0Xxf4Sh/tG7bTW0a0+z29xBbvmWVNu1plDYIG5yuAQcgZBUbq3lQ qWui+eJz9n4IKSPc21+0DMT99A7A9+RtBGQDyOwNZ+vXE2j6hHaBEmZ/LYqAQ8rF2GVBDbsDYNuc 5bIGM47m9hvPD9nK11p86xwlVRYkDIvQBQ4+THvnHbrxXCX2uJqd0kl5btJArYVUbaiIxHzMQ25i AFOBjkEEEdeSDkpe9sauKcdDXsNTuo5msjA9vtDLtcbW6FsgFfQbsg9PaunXUZHiaNpGKkDIz1I6 E/r+dcPZeP8AU9Dub+eJhdI4WNBdIruYv7jMfmPyqBnnPGegxLqXiOXTryKU6c6Wsqfc83cy8jJH A6dMEZ9674OMbWZnFvqdFLqCWpKykkO4Y8Z7f/r/ADqXT7vTnj8yW+aFskKoB9aw2mgvpLcFWTzV PD/KysR8qn3JwM9s5rJkETzx5lMURlAZ2QjYucbsDn3xWnMm7pmclqd3C0M87OLuMqnKszMeOCDk 9yQfl7dsitOW+jdCGuhNHtGTvO0n8a83utXl0y6u4radTcyNINwjVvKB3A4JBGSCOnbOeejJL62j uN8ElwtpNK4tzOAJHRfXHG/BUkDpmpjKVTXYlpQO+OowIPug88YlCk/rUN1r8kaceXGMcZfOK4ua 8hWPO/c55xjNUnuZZiQDgGpk7dQWp1k/imVUIEo56la5281ZtQguF/d7htK+ZjH3h1zx271S8hpB lsn65xUdxF5cB2qRnhtg5A65rnbuy+hNaPb7WspFjkldNseduUOeCrHJxnqMdCelagi1CC3hiM1t LBIsIiW4uImjaCRZA4Xe21Wyz+hDDI5GRWstHltovtephLVIS0a/acqS+QMbcckKx+VsEgcU0a1f 6cNml2cl4rOZBNPhgGycsgx8pZSASc88jFK9g1L3iCaXyEuHV0M7K0ny7FLN8xwAMBT1A44xWFqm vXthfGKC6uIVuE2kQziLOS3U7T+Bzxk+taOrRTrFD5iGJWk3FpAQMAHJ9/w+grltRuYpdRSRLeW4 aEDaFyN55wcYJ4OfrweOh56Hx8yN6i9yzNHSL67h882Ni8lxI7RzTtMHkZuSeWU4PPJH8+amfxdq iaPfQ34mvFD/ACRXjjZE5I+YIEB3DBBGQPm6dc8os96kjKGMMzTGXymyrI2OCCfqfyp17ezTWsVs wVvNKytIwJkZj756V2cuuphfQ+obbXNNu9SeePVoY5wgC/6WRGQmTgqj4OS3Ug84wRinm6gaDNrP bLayFz5dttdWTJJVeMEcH5hwc9Bk5+XRaa80BgSxvTBj5x5bhfxP9K6Dw8dW0azlhjnNrbXJ3OFu ACAAwbgBtpPrkfdGRxXU60Fv+ZilUe57ZdeJDqN9Dd6dqEFhbWqsfs8gVjdHy+Aoymfm3MTnk47D NTC2i1aVG1eLRLi8vbKOWHMO4Rg7+MMC+4DaWG/GT8uOreK3uq6A1tYJP5nm2aMy/ZZcAsTxzgns D95Tn0oh8e3OlwyDRrQ2YuESN5iWZ5NowMuxZuACAAwAHauScua9lc3irbs9b1L4f+G7WNblLKO0 ER+aT7W2AOmTvyO+AT6/SuM16wglsEtn1S2vbyElQkNsY93vvDMjE/L3GO+K4hde1jWdThkuZpfL 8xWklUkn5TjBY5J4OPYHpVLVdXvLPUbhLO7kMJYExOAY34GCyHKt2wcdgRSUZPR6DulqdHqEniTU r0jUYYdPwuZJEgypGeoZeN3X+IdunWsi3lutLLWs2sxx2zHc0X+sBfjJwQMdPrxVSLxtrEbxmObJ UkuhRdrk+wAx34HsO1bFvrMOpRGXVtIt1c/M9xGRG7MCNvoR0A681fK47Im6fUvKLhJLbUEtNQid yVMvmLCWmbjC4Xf3bgKcj0ANZF1qLRFokj/1fHzMGDEE5JO1SepxnkA4rf1OGbU4GlfUpLfbtkLS ESRxhu3B2g59/wCYpk8KraubnTVhMbL863SPvU5zkcbeCB37Y71lzcpajfcy9La0v7V2ub63s51f O2aXZ8vYgEYPIP8AF/8AXLHUopIEkzBBuOMSTjcfwxWTq0UMCQuq+cPmIQchO3Ptxjn09queCLP+ 1dVd5NscMCc7f4Sen6Bqe8eYTXvWNyDyLhC0Mpkx3DBh+lU9UuksoCr3BikI+XylPmfhzx+NaPiq 1jV4UiVMEndtAGRkZPpnk1HNon9q65qKywCdI9n3XwASi47r2zWSkm9RyjylTSbM6iz3Dq13Myhs yOeR9Oc8+vt0rQnWeD97LE42A9QDt9wTzUKWUmiyR7PtFvFkj5wQV55GcYK9McnNaURudRjZGufM jOVLSbXXHfgdeKlx5m7hz8trGTNcw3cPkyNIwccoFIPHOCcYxx2rnNQ8/VXc2K4EHAMRwo74X17+ 5JzXVP4XupbqSVGR4iQAm8qFG0AnA465IH61sHSDFGkUcSpGo+4tKCUHcc5uSPL5RrEIbHnYXnPl fzOKe9i1zcxtuOFUc+pya9HfTdp2gAepximrYhWJCgZOTgYJP+f5Vt7TqkZ62s2efXvi/V71QJLp ig4GWLHB7fMT6dsViTajcTH987yEZ/1jk+9ODpCXAJYjswPTuMev4469aiWCSdiUTqTx2FdahCOy IcpMu2d3GzKrxrFnOXCljj259M1uatqdjcaZDb29uyPHMhMhydwAbrwOeayNQ0i90lY1lt5FllOA V5HT7oIyD1/SlEGo3I/0q48iEEN5ZP8A7KO498VMrb3GjWstH1TVFMGnyqkSDdIC+0ZPHbk9P09+ di38B29qS97cSSsOyjapHvjn8c1Q069zPHaWhXMzbpWkJxtUFuAOhwCOc9e3Wukt9QaOXdJm4Vcj 94xJHU8E9OtKkrx8yqkve02IYPC1k0Z8pPJJGAyJyP8AgR6n86yrrwg0AE816ZlDj5c42jPqfTOa 6dNWSYAO3lueqk55+tcP4luNTTUZI2ecxMxMJK8EYyQvrjNOSa2Ija+pJq+tz6XcW6aa8UbuPNlZ IkIc5wD06qQazbvWry5be7knfvcgAbmP8RwOfbOcdqfbeG9VmzceXhh0VmAZu3c1N/YF15nln7PH J/ce4jDD8M5rO0Yo0u5GcNVuGne5OS5J2lyTtznPsep7Vf03X5dEt2uRBHKbiUs+chscALuOeBt9 D1qxc+Fpold47i2eNASTk56ZxxkfrWdNpj3hXKuIYxhMY5/ziknCfoP3o6nWyXD3+l2168BgaUhh Hv3YBzjnHcYOKv6LOsxubiNmBJSMhuD8igZ/E5rBsJZPsiWxVtsSKo3HngVsWrIgVwOcAEetYcij KyG5OUbs0tQR761aPO+RDvQe/wCJ75I59auWF19ss4pSwZiPmJx19apo+cMRtB6E81PaRLCZVX5x KxkP1PWhrUm+ljVjbB3ZBz36VJzj7zZ7mqH2hICqsSN2cDBJqxBdRTZEbgleqngj8KzbGSMhYjCg g1BJbEg5TBHSrsb9qoXGtad5hha4CyBtpyhwDnB5xjrQgPD0gluG3xReQh9Tgfhnk/hWjCsVsoLM ZGxjHIUH+Z/So89D6nmoASWOTmu9tyMtjRu9XubonzJWZQcgZ4GfaqBlZzjJ5P50x/v47Vb0VEl1 KFJFDqd3DDI+6aTtFOQ1eTsLZ2NzdEeQCv8AF5jHaFwRzn2rrC+4AcjPQVRvnY3IUsSuV4zxVyPq aKFRzTY6sFGyJRESOTxT4Xmt2HlylQOoPI/Kktzkc8//AKqkH3l+tdBkXoNSXbsljx/tqc/z5/nV rzIsZR1fjPynmshwMCq4JE64PcVDQ7lu+tUu94K7SwxuAGar/wBngBU3ttHAAA/oK0oPmigLckxg kn1qK4JEpxxwOn/AqwsirjTZhbeQBWL7DtOTjOPSnabbxywrISATVq3JMaZPaq9qirbRkKB8g6D2 qJLVDT0sXfJeQFByp9sU+PTZoTvikYHsC1OtmbYeT+daQJ2jk9qhjMDxAJUjhuSpDRHJKjoOM+4x gH8KktkksEjuOWRwPMOSRg9/f19cVq6wAbKTIB4rG00k6FCSST8gz7bgMVhVdkmaR1djpo0JUHv7 1yuvxXNrfm46pLja4+XYcY6/5/pWtozsbKPLE/KOpo8QANprAjIJA59MirSIvY//2f/+AAxBcHBs ZU1hcmsK/9sAhAABAQEBAQEBAQEBAgIBAgIDAgICAgIDAwMCAwQEBAQEBAQEBAUGBQQFBgUEBAUH BQYGBgcHBwQFBwgHBwgGBwcHAQICAgICAgMCAgMHBQQFBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwf/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJ CgsBAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIh MUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpT VFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6EQACAQIEBAMEBwUEBAABAncA AQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6 Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeo qaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCAGQAlgD ASEAAhEBAxEB/9oADAMBAAIRAxEAPwD+ZZtO1KERxtbkgHbjnpzjp14pSl2n2czQvt28jGdp49hX w1SktpqzPpoycdidgoiMrRgx5Jzg54H5j69s+1JELQgvAD5StnA6Hn0P17f1rgqYdPZHdTxEla47 yGkY/OuejhlPzdAcAH8easfZbtWZortQxOeGOMHuTwACc/rXFPDtaWumdkK1OSV1Y0LbWNctY8xX B3AA43Nzx9M1vxeM9ReKQXSxvHg7gQ2T14A/w968+tg4yd7WOmPLNXizBuLLSdUulm+ymMoSxMeC P/r/AFr1LQtc0SOJLdmZFUgAkjn/AIEff29axxUatSmoR15QUeW9j0jT20S8VVh1GAjvufGT6jOM Vtnwqt4Ny+TIGHZl5H1B56Y614c51KTtNNMu6jsyEeAxaJMY7UoC2cggjJOO/TJx/nmsL/hH4LVj DHOI4yDlWbAB75Pp9f61axMptt63/pFxdy/Lpdz9kQpCHhCbWCnnbkdBxn8PTNSaBBaJktGwiKYA xgA+vp0z6datybg+VhbSx0UESL5uzzfLUfMW/h49Op6+neh3jYKWhYK/3CwGW5/P/wDX+FQ97oV9 TnrrW08PM+oTRFoNwiIjGNpY+5z2Hf09q6bRdUt9bsWudOlfhyCrx5GQfQf0/Wt50X7NYhbdSXJc zXUt6hFaXMRh1DTBlgckSEblOecNj0/zmuR07wJ4UtNSXV7JLmGd97szO0iktljxyB7emMVpRq1a MZQTTjIhwjJ3a1R63oes6hokKR2OtI8AyFSQZCt7A8j19Oa7KDxzqA2nUNHikJHDq2CwOR+Ga8+r h4yk2m4yHa1kzRbxJolyc3OiywnO4tDJ06AnB4zzjtViNtEvtosNXeCbqFuIsD8xj371j7OpDdcy 8tyru12W7zwv4jaSO6gFrcRAZjYTMpPGenoevWsm8E9uJo9Q0lIrnBA+YHcPY9/aqjODt7OTTXQI vUwl06x2QzT2BadQWOyMgdT/AJNFvb2l9OYhbSwyBSVEmVyOBkf5FU5Tabb0XQpJLY0INPkVGjgn c4OGDFWK/mKuHTLqMK9u53ryBtIycfzzWTcXdMG1sV5J571ZIr21guQvzbJUV2Tgge//ANaufufD Xg69+W50+S0kJBVoCxUH/dPPbp7CnTnUpXVP7mZ7rQqX/wALJ7yKSfRdcimUnIVhsYj0/l6dPy5G 40vx/wCGLB9NNvKdM3KfL2+Yik9SvXb046dBXbSr0ql435X5kNRas1/X9XPNPEkup6pFAqq8cqMr dGXODnnr04x6c9a9M8O+N9V0m0gVNUlgkCqGQMWUkDHfgj+ldl3TjH2b1TZlUoxnpJXR7FpXxb1W NRNfQwXNpk/6siN8Ajk4yv6d69I0z4oaHds0c0s1tKSMCRCyk49Uzj6nHau+hmLjaNY8qtgWnenq js7LxGLyMyWlwsyDGTBIGxnucHj8fWtAa5wI2zg5GCecf0/SvYhWjNc0XdHBKk07NGjFqW5gVzyT gY4/+t7/AEq1/aibiScEDkf/AFz+eP8AGtPaN7sydLTQtLqB27i3J568mrC3+48sME8AHPQ1op22 M+Wxdjv1BVepJAHJHt/jVxL0kAj7xB4ycc/T9aamxONieO+YhgHPqQD05/8Ar1oQ6ipwok6ejdPw /wAKojVl9NSCDeZAEBJx0/CtWHWwj/IeDntk4/z/ADFO0patbh7vQvRa8+QFxuHI28VYGuXcm5Wb 5QBzj3z3ppJayIve5OusSqMGTaB3HAHPt7dqh/tyBSytK2zOABVX/lFyvqM/4SGNQXGT9c9P8j9K hbxIPlxKAuSCeSc0NtuzErMiTXjMdqMGbPO05P6VbjfVbm4tbGG0ka5uGWOKPadzliAoAPqcACmo ykrvYTT3exxmn6zH4l1658VQTrLo8EQ0zR5EBCyWyOWluVzjIuJd0itgEwrbKfuV2cN1K52q3BBI x1/EfiaKytLl7afdv+IK1tTrNIhkncKq88A4ByPxr3Xwn4fu53iDREjOScZz2zXJUfu3NILoz6W8 NeBjceUnk/PgAHH+fevXtO+GEwVd2nkjqeD6j6VzOdtjdRsrnqWhfCQSKgFr+77jGK9Z0v4N27kA 2ec9crmnHmk/dRVl0PQbP4LqEUpa/IOwFdDB8FPk5tyffH51rGhLsHPFHTaf8FI0wDZ89fu13Gnf BlGAH2QAD/Zx+tdFPBzm9jN1Y9DqY/gshj2CFQP93muR8V/s9X00ekXdhH9otoLpZLuzCruuITww TccBhndyeduO9dDyyrKD9n8XQmNePNZ6Gfr/AOxj+zt8Z9BjPir4daTqdi++LNzZJ5kTKxR0OVDR urBlYcEEEHHNeXf8Olv2KP8Aoh+j/wDftv8AGvYwscbToRjCq0vl+qM5YqadpJNrukz8LfH/APwR o+Gt5rVyZvhndWtoD8z2+8bemcgfKADj2xXyp4i/4IK/26txN4F8Uagvluy4ltRIpUcAggjng/8A 1sZr9FxGQ4bFJycU11fa55eFzrF0rKtG58YfFb/gij+0n8NZL2SKK1msFUvAZ2eNrlBySoK4PYYJ 618ReLP2EP2jfBMzW178N7p337M24WTacZPCE5PPT3r5PH8IzhN/VpXv/X4bHvUM7wdS0ZS5X59z w7Xfgd8T/C5nGu+BNStQowxltJQEAwe68dM/jXm9zol3B80ljIg4BJQ/MD+H418xisnx2Ek1Uhse vTqwqRvCV/RlKSyhQYeYr6h02ng//q/X0qrFZyOhUhSQScDnI9+9eZOlyq042ZvGUk/c+ZbS3kTK +VlQMn5cEcjjj6DA5qzhGBjNu6qehXOC3HP9PbP1rkqYWEtY6G8cTOO+pfhubJQApdXGcHZnj6jq RgD8vatO2u5LZlkt9Q2kAHCsV5z74xyRXDVwM7Wauv67nTTxNOa95WO/0vxf4otrdUhv5ZAVwBu3 59jnJPcfT8q1l8V6vJI7X9vFKDzh4ioPT0/Dt3rx6uApxk3FcrN0oyu4M6TTvGMORv0fbuHJQht3 H04/M9O9bNr4h0R2XcnlofvAxldufTb9K5JYScb8ruHLozsrGbw/eqYzNHub/awGB9un5+tbK+GN JuUcwyKec53E8/T8qwXPTumVpfQy774b2WpiQNKdrj5l+8Dx3568k/1p2jeATopH2f5YVHEajjn6 9DWyxUnT9k9F2/AOXy1Ns+HrmeGdZ7X5zkKzNnjtz+HH0rl5dCkhcPHCyuyhcsrDkdDx6f40k9fd d0LR6Fj+xYfJQgbSSAQeQP8A9ZAxVKRFjMkS7FY5+6OOOhwTzW9OXPJKRNWLszqbDZJCUKD5eeuc 9v8AP1rXs7eNneIqqt1X0PcZFck5Wk9dC4RTSl5HRadrF5pryW9lcldrhTA+SvTjHfsfyNVvEsmp a40c88KxxqABsycHHJ46Z+nWs4wgqiqf0xcut7nKQQ3kDF4JSQP7vPr+Aq99u1CII0kQO5eQuDx3 ODTlGMnZFWVis3iey01I4b/fHPcyBAzKGLPjjGOn3R+Wa6u18U2D3KcRvbA4be+1sjGCOMdeOaiW Erul7dpqF7J9PQiUoOXJ13sVbjS9Ct9XbxDbvdwzucN5LiVWAzwVzkHPcev5btu1jq5Z7HExXGQU IOcg4PXHQHn196xnKrKKm0tFa6/Ujla1Rx3iHT/EUEhuNLs5rfaMboxkBuvv7fnUumeKNVjslOoE vcKORImeeh549BXQqVOrTUlrJdSZLyKVxqnhzUGEWr6Ord9wUHr0Pb9Kz7zwJ4SvV/0C7ktgeV8z 5vXBO7n9aulOtQa5/eRDvqtzy/xBpUXhe7t4G1ASRyHgwAjjHU4OOPYmrkV7fW0YngjlaHO0uUPy 46ZP4dcV6PLGrBTXUm6b5ToYNZuGiGpvI8MyYQOrFWGcdxz3/wDHfavXPBPifVLvXdJn8QarNPoh dUmMyqSqdCd2NxxweT0HvRTrTw81JPcxrYenVi9Neh9h3/g7SFsZb21vBHb/AD4Z/u4HP4DH16V4 y+o2Usk0NjqENxIr42iVQ+enCthmGT2BHPWvoJYiClFS0ueJGEpJrtuI15NFIY5Q6OOxBHI9QRn2 xWjHe8f6z0wWz68VpGpfYTguqL8d7Ic7OcnB6+3b+lW1v5XV8Egg8cc+4461vGV2c8o6aFyG9lcK N6mXG3B9e5q/Hd5XDTAcc4/z+NbKcb2TuzJxZbS9tkIViSFwQQMdPyzV/wDtm3iO1QCo43Z/pitH Jt67GduUkOugiNgQCB37d/X8KedTu2i+0fN5BJHmFTtJAHAOMcccfjVqLd21cTvfQhk1g4UhgRjj JxjH/wCr/wCvUP8AaDNgBdw+vb86d13J1/r5Ewmk2ZVjjjqeevbj9KYRFMh3zKCOexIpc1nsLXct Q6jrtjbpb6Nrs1tCCTtiVVJB5IJADfTk4zXRat4z8TJ4Rl+Ht3q5vL/WIfvzwKZdF0ws6XEyTH94 klzhraOMsRs+0S4RkjLunCPtFUtZrX+vJ7Bpa6LOl2ywQQ29tbhbeNQihQQFAGBgeldtpukzzFAY WHIx7deOKjVy1fqJ6K1j2nwf4PnuZoAUbJ4zgnOeetfoD8HvhHPeGBpLQuDjPy/5965q60ujenqf e3hj9nuU+RKiOAQCAFAx+le36N8AJlCtO7MpxwYxVUcHOq72NJVIx0PWdI+CVlZiNkiIx1B7/WvQ bP4Z6bCqgxgewr2qGVt9DmnXudVa+DtMtlwIs/Wrsml6JYIZbgwxRjktIyqPzNepDL6dON5tIwdS Tehztz41+HGmOYpvE1h5y9Y451kcf8BTJ/Ssxviv4MGRp0F9dN/0xsJVB/GQIP1rVLC0/hTkK1SW 5Xb4l6jc5Gk+B7tieAbmaOMH/vnea5m78e/EucXv2fQLSySF/LYzRzSclVbKk7ARhsZ9QR2rSUcX Km50aNkv66lKmt2zmvB/hD436jZ6rLr3id7KOfULqaKKBIoj5TysVbgFl3A7sZ711n/CtviD/wBD /ff+BR/wpQy2XL+9ra67Xdrsc5U+Z2Oru/H3wj1kzafP4w0mSTGZYhdxbsAbsMM56c810mjS+CW0 i1m0VrNdHKkxOgVUI6kgnGfXP419DKGOp0lFqSjf730/C55kZ4abfKyl4v8AAPhHx5pDWHiCwhur MRvGjOA2wEFSQf8APIr899R/Ym0weKLLWLySN4o9SDujjKvGHDfMAQSCOo716eU4+NK9PEJu3w+X f8TkxmHSnCpF9Ueg/FP9i74ZatY6v4iTQbSVnhM86LCPLfb8w2ocgD6V+Sfxr/YV/Z/vS0mpeDtM xOBIC1nG+3PPUAHOMc5pvE0sXSvOOuz/AK9AUsThalqU35WPmmb/AIJK/szfEPy7mz8Hm2t7WEza tNa3TxeTbrtBkiUsQWJf7oUnI4wN1fPGof8ABvzPrXxE8R+B/DXieRNShglms5IzDLDNtAb5mZkK qVOQw3EsVGOSRxvI8Bi4KWIVl7zbS2SV/wArdD2aGdYunJRnaSf3nwr4j/4I3/FrT57yPQ/FtjII mKEXCvHz0wMbupGPTPtzXzn4v/4Jl/tQ+GI2urbwtDfx+Ydq2d1ExOM9nKnHFfK4rhinduhP70ev QzzDzt7Rcr+8+ftd/ZN+P+grI1/8LNYEQIG5LN5FB6YyoI9vbGa8s1T4beM9KmSPVPD9zasvDJNb snI7kH/H9K8WpkWOopyjC68tT06eKw9Zc1OaZkJoeoRsitasirkjC4x+OOp57/hV+1h1W2EgWZ8j GCG/Af5+leZUwctVVp/ebc8lrF6G9Dc6ggO8K8ZGfniAwM47fWtC3nhdmMunKGDA7omKkccdc/56 Vw1MphJ+5dP7/wADVY2pD3dy5FKElVgHQKORxxg9sY/zmt2xvJopMW98Uycn5WUn0/pz7CuSpk1a zatL8zojmFKXxq35HT23ifXIGUC83oT3ZX/9C5611Vh4y1AYSWJGycFmGOeeRjg9/wBa8itlc4fF Fo6o1aVRe5K519l4xtXcGaFguMHZIGHf1GetdJa6pZ3Sr5cgADbSsictx7cY6V5tXCThrvYs2vsm mXMZyICcZ4UZQ/p9PwrnLvwvpksm6Dhj0IzwM++R0/Csacpw11By3uVovCJ8pZIZ/ukbTweMYPOf xxSy+HdRTdmNWPUEZGD25P0H0pTmpX6GilFR5S6ult9njkNuVkIGcDIODzgjrW1pvh/VtakTT9J0 25ub58lYYYncqqgknCjIAHc//rrD06mJqwo0tZN2RMqlOEXKTsl1Obv9D1PT7iWynsCl2rkNHIGS RTjoe+e3SseRb6NGRbYsVHC5U8dxnrn/AAxVV6cqdWVKrpJPUqLjOKlCV107HQeF9Oi1DWNLuLi0 U3cLvKI3QOYjsZNy7hhTtY8jkZo8UaDb2uq7obUb5I0eVgACz4xnj6AZ9h6V7SbXDctdPaWPIlf+ 3I2/k/zPP47HWra7meZwLc/cMWQVPvjqOK7PT/FevaZCsELJIB/CydM+49ee5r5urThUvZ6Hr2dv eN2Dx/M7It1pyOwOWZeDjgnGcZPPSr0/ibw1qUO2aDy5snAmiJJPpkccZPf156VkqFSnK8XdGTXY 871XRNOv3+3WlwIyjg/u2ypPI5BPTv2/WmxWN4UyjMUGBtz98Hvg/n+B710qq2kpdOpPLurmDqvh iPVI2F9as6nuBgqPqMeproPDcsegWgtmt2kt8lieOnOeg9f6V0Oo50/Yp7GPs7u52L2vhDVrTElt GjSEMW8vYeg7rx296e/9keFtAublS0llbrvYL8528ZA9T6DGTmsm61WMaU++n/Dmesbo9Vg8SX+s eGIrO1u3GlTRBkI+V9jDjHcjH16+9eTa14HuJopbi2iEqY5TILe/B4PH8vzpYqcrQrPbS/mFOnCn dxW7uyDRvEGsaOy2ksz+SjZ8m6XcuO/DAkfpXWf8JYl3cILfTowrksfLm2cHsM5B/MV6GGxlainF u66GFfCwnLmg7Pt/X6GpJ4hsIrkQRSSZChiZowu0nnGQSPTuRXRQyzzQxzqhaJhlWwCp/EfX1r1c NjI1W4w0PPq0J0rKa0HNOCWHm/09cU43LHLF+3YDtjNehGrrZo5JQ1ZMt18wIY9V+YHknv39v84q XzY8YEpBwOc5/T8v0roU9LJGTVjL1+78QarJp50/xVLp8cMnmBbS0sx5hKlcEvGT0ZuhzyT6Y+J/ 2eP2wfjR44+J9n4I8SalanQ5UuDIiWa7lMYZl3FtxYHHIbOf1rtp4aniMLVqu6cFdWb133+45akl GcUluffh1FDIZE2KGbcQibcHOQAOwGe1K2rHnBJPHRv8/wD1q5k+smXyt7jv7WO04bHHpn8f8+lW I9RfDDcSuMkH+VVzGbjf0NmDXdP0i2fW9QQXCh/KsrDzdrapdY3LArDJRMfPLL/yzjDEZcxq1vw/ OIXu9T1jUBca/fS/aby4ZdpdwqqqIOkcUcapDHGOEjjRQMLVOXLTs3v+S/zf5E2s7dj1HR9U0slD JOo6cZH4/pnmvdfB974aZ4RLqESc9TJjOP8A9dYSq2Wo1vqfcXwrl+ECzW769430q2i43faLyKMA f8CIx0r9Q/hR8Vf2UNAtIjD8U9IvbtAMxaYXvpM9Pu2yuf0p4ecatSzi2l5MOZpPlPqDTv2i/hZN Zibwp4d17U+gVINDmtmb6fbfIH610I+NGvXkAfQfhPfeZ2TUb23g/WDz6+rwqTShRpXf9dv8zNwk /idi1F4v+M+rohsfCulWDHG7zDc3oH0I8j+VWzo3xn1Zg9z4wFkvdLKztkU/9/llb9a9H2GLlpKS gvx+5Xf4k2px3JB8KNbvpBPrPjjVZn/iUancIh/4BEyp+lXbb4H+DY3E11arNcdC7oGY/wDAmya0 jhKMdZtyf3f5sXtbfCjs7LwB4XsVVI9OVlHQN0H5dK3YNC0e2x5OnRAj/Zz/ADroioU9KcUv677k OcmaaRRxjEcaqPYAU2aGKdDFNGrRkglWGQcHI/Wnd3vfUm7TuEs8MKl5plRB1LMAB+dVP7X0n/oJ 2/8A3+T/ABoUZPZCP4t9Z+IOt6tf23inw54znnuTbPNrdvPMsVz+9k2sVVmJf/WAluTk9MKTXqvw 1/4KIXvh7Vte8MapqV6NJvWtLW2jkfzXhaNkib5copJVi5CbCzJjK5zXs08bUlFUKitd/hfQ81UY Rl7i2/pH043/AAVN+K3hT4qj+wb6wu/g79re3SC9gPmTR26BZ9igg7so53ZUFiSdoPy+ufH/AP4K T2Fj8QdO1PwDr0snhK5060u1W4gMWHliSVdyknGQw4z7ZOK3wtXCTq0q/Jq21Jd9rP56p+mxjiFP 2VK7u20/+AfQfxE/4Kf+FX8EarpemeF7qPXbpWhttSguIhbLGWKGVFkHmMVZWRo2Qco4yNpA/Pi5 /aX03xhpU0s2ozHTVcWembvJ3ws+6W6V1BDuql3+YZwAAW5Ary6tP2DqQoyuunf5/f8Agd8HGck6 i10/r8T2z4YfGvwdo2p+CJfE8uzTrjUICl6hjkt22MQqyISGK+YGBIVl2sc44z95+LP2oPg/4B+O /wAR7u0lSa8sfB0mo2z2sfnJcymG1miKhMBA0eVLMVHbI3V0wxq+pxs3qqkXr1aX+RrKkvaWbWl2 vuPztb43+DfiRrE2o6PDBb2MrtIYSw+QJGrEvk8lpBIT3+bOTiu61fRtNNz4f02OZDd39uby3DKV 89WldCi5/iUptYdQdw7VxQxScffet/8AP/IiphZRty66amZpHgnSddkgMVvGZnUMi7tuQPmGenJ6 Y9xU2ueCfDbvbQ3mjW11CWCgS26OGJJGCGBzXVTqQmkkzBwnCStp6HPf8MQfs4+Nbn7PrnwQ8OvL dMXkdNOSBy2CT88W1hx6H+VRaf8A8EUP2QPiTLJb2vgqbR7kxNKTZazdKfQApKsq++MjNaxlQcv3 8FNLdNX2+5/idlHGY2ja1S/r/VznPFP/AAbbfAa/sr+Twr8W9a0++ZZWgiuIoLuNW2r5a7tsTYyC D7EY6V8N/EP/AIN1/iL4fE8vhX44aHdFVLvHqVlcWjGQKzCMGIzhySqqDxlm7VFTBcPZgrQw8qU0 t0+ZSfez29Ls7Hm06SXtY3v2PAtR/wCCBv7bFtF5uj+G9G1TBdH+x67bL5ZXqp+0GM5yO2euBmvn nxN/wST/AG4PCMs0Gqfs7+IZjH/Fp9l9tTJ6ANAXUk+2ayp8H4HEtQweZUue2qqP2f4ztFv0bOpY +lVtZ7nzf4v/AGTfi54I1F9O8X/DfWNNvEZ4/Lu9NnhIZWIYEMo6EEEeoxXEL8I/ENqxcafcRsME 5BG0+vNcmP4JznAw5q2FcqfSSXNFrumrpm8a2vuzJIvh5qMUpkuSQRjgpk4H4ZzkmtODw3qVkzrb x5QckMOv4/j2r4nG5DQleE6TizrhmNalZSldeZpeQwVRLYZPco2Qfw4NQXFgk8JUSzxSEbCyhlIz noRnFfMV+Ha0HzUGpLs9GenTzSlJctRWE0q3vNPtYLNNTeYou0STPuc4JxuJ5PHHPpXTx6heImJ4 t/ugz+XWvnMbl1ejN+1puPy0+R6FGrSnFck7ls3Q2oxtypxuwBwenY49M+1fVX7Htja6t8VzHPkm DTJ50GzLE5jU4BH91mJFLKE45jQfm/yZljtcHWvtZlz9sDw9YaH4+8L3LwrvudIjl38Bptks8O5g OAx8v5vfJ9K+QLiw02SSOSOYRykE5Yggk85xnJ9c5rLOnL+0q1+4stdsHSfl+p7N8J/hD4m8VWHi vx9o1pHceFPD7WdrrVyk0X+gyXq3TWgaPPmESfY7kBgCoMeCQWUN5F8RbnQbfxtJok90o1NoVZIm JDFecEHvwK9SUZLhmKitee/y1OOFSMs7fL0hb8n+py0nh9AWaKWVeg4fcF4988c+/esi1tNVaDVL wadK1tbXgtCwQ7pR5cTlwBztHmhc46q3GASPHwODqY+pOnSaTUW/uPUxOKhhoRnUWjaX3kCeHTZN czLDIWkPmYMgODjGRk8djj2/Gqtzbo64f5JVwCMEgcYwM9K53O70/D0N1GNrRK89rDlXhkKfxFgc Ffrz/Wp459Uik8syrJGAMCRSCRjsRgnvVSSqJX3IcTX0+6M0zW8kTxk/x7iwz/3ySPzq1ZanpXlh J4mE/GVkX7hOM9M+4P5VrUwdaGEhjItcrly/cc0asXXlh7apJks0kCKzQDdFvAXafbBPt/8AXNLL BCbeZFCeQ4AeNl3CQEd1PB4wMe3tWEJytqXKF5K6NCDxgbW1i+y+UIwgC71KjGf4Rxn8K3NO8cW0 2YL+22yjG7Yc8Hrw3Qfn0FYzoy3TfzElZpGwbvwzq0gErRlzwPOTkdehP4ng+tc7qngCOQNJpOob XOGA3Y6f7Q4/OtaFd0lyVFoKULO/U4cR6ro+qS6PdgSX6xCZUVQWKD+LI98fpXsFr4/0KH4f3NrY aVJZeI7W6shLMIUIuf3UsbLuHQHyldgepJ4OTXoYd8rlKns1/wAMY1Ye1UV0vqZUPxI0a/8AIh1P Q4THwss1uTDMDn72PuHj+HaM+orlr7x1pUFzDbebLFJOxSKORd6k9fvIOo9Sozkj2rvw+NnKXJVX zPPrYNq8oPQuf8JGBIY5H+fhhhjjB7kfhUiazC7BmlGduR7/AI+n1/8A1+vTqac19DzqkWrxZImp iRnKvlDzgda4W30zQ/Cvim88YabpVvBHd24t9QaGFVZSjO6ynaMnJchzyTiM9F47aOIdpU1K3Npv uc1SPVnpKa5C6rJ5md3IOeexHI/Pioz4gPIIUZPfjt/9fFHkyXfcrR+I5AWYO2/OMZ6k+nt0rQTW o7S0XWNaumttH3+XG0a75r1wM+VbR5HmvgjJLKiZBkdF5raCUmZyucu/iO/1DUP7auohDOI/Js7V HLpYwbt2zfhTLIThpZtq72AwqIkcaW18TaizHypm8zAHt+NXJxnJ22RPK1qXItX1ycLi9dWByTnH /wBft+ldPptjqt8yi41mXZnORIePbioaitbBZXZ95fsV/DDwd4k+NnhTwxrXiSK2utZkGl211eRN KkVxK6GIBFUnczgIpBHMmMgEmv6xfhH+xJ4S8CW8cniXXm1O5V90Qt7RbSNAOmRuck/iO9elktOO JxklVhdQSdr6O9/v1RnOShHbVn1vpfgTwloyIlhokK7RgEjcf1rp4rW2gAENuiD/AGVA/lX2rnK3 KtF2Wi/A5nKUt2TMyqCWYADqSelcrqvjzwPoZK614x0u0YdRc6hBGfyZhSs2JJvRHl2tftRfADQG ZdQ+KWmFh2t3e4/WJWFeUaz+35+zhpJxF4jurwdjbWhwf+/jJXPVxWGo/wAWql87/lctUps8j1v/ AIKc/CezZ10jwxeXI/haa5iiz07KH9fWvHdc/wCCp0+XXQ/BthGM8efLJKQPqpQfpXn1c6wtP+HF y/Bfqaqh1kzy/Vv+CknxZms31JLmytLWTIto4LKMtMR1I8zcQo7t68DvXzZ4p/ba/aA8SyzufHOp xoSfktLloEx6bYyorxXxDiq0qjopRgtFpd3W7u7+n3nW8PCnCCUbyevouh4refG/4h6reSf2/rN7 dxTfLI0tw7NgkcgsTyOo/DrTf+E7m/5/NR/8CP8A7GvExmOzh13UoVvi3vd67flY2pyoKCjW0a7W 2PyYT4ladpulve3cqz6zeEvugLDyEO0CPHRQMPzkk4TONozQ0jxf4V1e5uG1W0VruCEzx3LAiVJl yF244ZizEjJwNvfpX6d7fmScHZrqfP8A1ecE30/HQ9i0b7L4W0DXfG2reLFuNSiR7S2jjuD52oC4 nmaVmVshHUbHBxtO9TneHFeQ+IvHth8Qfid4Z0nTL+9i8Myyabo+Ll45JrZUWKFwNoQMF5CggYUK D0LH0aE6arR7K1/zf5nJUjKcqcWtE/6/M+rP23Na/wCEY8TWkfh7U7jUPB32VrbRrqVkQs6OpcyK gVfnDPIzLlneZ2dnLFj8qaH8WPFth4WurexuQ8E0y3ce5RuiEXmCRVPbd5meDzgZ6CuNVHUlKo3v /n/kaRiuRq1u/wCp9bfBX4h+DtQ8T+Ar640OLWdLgDve+ENT1640z7ZIsexTBdxI5yWDSeWVQvhI wWDtt5fSrbWta8TeP9EtjCus2YktZY4j+5kd5X/1e44UNGEI5J+fHrVVpxVOKhp8Tem93v8Adb+m bRk3ZdjI+H3ijxHZf2hcW9w4nkleArE2BEhbDYxxghm4Hvx6foR8OfjIvjeX4cx+LNQS1fStWTTl mMmxPst7IzGRiwA2iUNuJxt8xTyC2Ko4aFaEW91Z/wBfeN4mVJvr/Vv1PqjwRr1rqN4ZZr4W7xxz 3AJUl4kxFOqn1ZRNnnbw2fVR4BqPxH+I/gX4xeBvhv4h0i3vLLxDp58U2E8SuLrTdPklu/JWRFbE 2I7bczfwgnnAAoq4OdPlcL3ei7Xd3+hVHEKtJQlay6/J3/I/VbwlovijVtPstQa1WPUnRJh5KApg EFOnBBHPqM+5r6s8CeH/ABNYTXH2e2RYp8OPNBw2SCQMAgcDB+ufWtIUJ0k3UlYc6lKV1HY+hrbT RL5V3dwhtQj+ZMk7VYjGRj8fzPrXzJ4++JnhrUpfEuhTsU1G3uXijiiAMs0sbbVQLg7iZMDjBPY5 wDWFcp1/d1S29LnNViuWEV3PpjwxbNZaalrKxeQHcZTg+aG5Bz34wPXiuiIArjrPmqya2bOqKSil 2IJLe1u418+BJIzyA6hh+teTeJf2efgN4xaaTxR8GvDF9PJ9+W40OzeRv+B7N3610YTMcwy+bngs TOk+vLJq/rZ6ryehcW1Zpnzh4o/4Jm/sTeKzPJd/BCztriQljJYXl5BtPqEWXyx/3zivlrxl/wAE Qv2U9ejlPhvXPEOlXLfd3T29zEv/AAExox/77r3FxTXxC5M3wlLExel3BQnbynT5dfOSkaxrTjpc +WPGH/BA2LaZPBPxstppOyalpUluF/4FG8v/AKDXzR4z/wCCHH7R+kFv+EcudE1gBRhrXVDCfpi4 EfTp71zvCcHZjpzVcJJ90qsF/wBvRtP/AMkZssSn8SsflT+0v+yd+0X+z7r3/CI+K/hFfW9/sE0U wVJbe4RuhE6FomwcZw2Rg5r5fsfgZ8afFtysEVsLYuQFjtElll5HUhQB+vY18pmPDVajipUozVWk 9Yyim1KL2auk0vVJp7pNHXSxFOEefm+5n2L8GP2HfFFjqWm6l8RJNVutL85TPaySeSrpuG4Do+cE 9DX3drn7KN78OLW2+JX7P/gnxHdeIIWW2m057Oa5R7aUESNHhQzOML/G3BPHevNfB9p05YbDKKvr K9t+t3oKtnsvZzpOouVq2v8An3PHfEf7OHxY/aZkuPEnihofD3jDSidLfSNStZ7RnQsbgTbSNyZM 7/w9VOOteQeJ/wDgnb8dNOhAtLCw1Vc42Wt7GOMdT54jGPb9K+OzjhZ/Wqj53GpfqtPvR7GW5rho 4aFKp0W5xfhX4A/Fj4U6+ZfE3g6402yFjcqreViBgqF2UOmUyyB+Aexr5m+MXwya6+I8usx3RWQW 9uGAThcxq42nPHLfofeuPEYHEYPJvYcvPLmd7a6a66GlCdKvm7lTlePJp+AscctnFHBIxMiADg43 44J/z61HoVxDIfFofIC34jXb3zbwMTj/AIFx3/nXh8PQnDG11KLX7uW/yOnN/wDd4X/niLPZWkqo wlI29mJbn14x61iz6HJNJKY3hNqyjjJDE9z0x+HtXz/NZttd/Q9VNFJ/DWZWWazzGOQTtw3Tng8f jWdc6A6BGDuAOQCcfT0B+laRrJtaDk9RND0W8k1YSOwk2xOcDoMAnGM8nt/njntf07UrPVr0rAWj MjAhQWxk5Jx2HJ+le/JxlkdNv/n4/wAjy4f8jWpb+RfmR6Ta28uqadazTOkT3Ecb7JNjlSwBAJ6M ckA4PuOMV2WpRXPhu+uLKOUXFlGqPiZQTjGTjB3fyPqBXHHDU55bLEPSaklf5G860li40GtHFu/m nY0YbzwvexW8l/Y3NmxHEqfMgGevzdB+f1qeDwbpkuo3GpaRq9tcTzALtlJVlAz0Bzjhsdq85zqw i+de7tdGzVlysrz+E/EtreJjRy1iclnifPIUbcAcAcHr6ih7bULRiLa4kVxgEB9o4JHOPp9OKn93 KKt7yHpLUz4tR1G11ZNTvNNEl0qeSkxVcshOcEqc8nnmurl8Q6JqFlLb6jpiYcqWLAZG3OCD9T61 Tc4yjKm9EiHDTQ4+58PeGdQlmh07UGhlIB2lzhc56K2Oa5TU/hrqLy20yTR3QhYSRncFcEDgDIx2 Hf0roo4u0+WrG3mZSS6nH6tZ61BPDJfh44odwOQV3+mOnTnkVnf2tfpieG8YDglZFDZUe/X9f659 ilVcLOGqaOOrRhNe9uSR+LLuGUx3MeASSrIdw47eueta0Pim3vFCrIc5HYj26H9DXfDEKXK0zzql FwbuWYNSnhybaVGtR1gZiAp7hGHKdR/eUZ6CtYappb20s0kl9BcfLui+zxyh+mQriTBHXlgn4V6E KsaiXNozklCUdldfkVY/EMkTD7Dpe2XOVn1ArIUw2eLeNvL3YAHzSSLyQVOKrS6ndXt2L7Vr+S61 Dyli82YqDsUcKioAkSDnCIqqOyjNbe1jCPLTd31f+X9amLhJy5pfcSjUodxHm9O/5E/X/ParcWrW wKkzfNkEAkj/AOtnrRFrZITS2NqDxIkcmfMJBIBB69PXr6fnXQWXjGMBdrDrng5yM/X8q1V+W5nZ bxZ6J4Q+LOs+FtZ0fxFoeqS2us2VzFeWlzA2JLeeNw8bqw6FWUMD6iv2T8Cf8FqP2qrLSNF0zV9f 0e8a3t0gkup9Ki8+6I4MspBC7zjnaqg9lp06lbCVvb4ebUtn2avs1/TJaU7qa1PSZf8Agsp+0PfR MY/ENhBkH/VaZZ/puRj2/WvOdZ/4KkfHzXHmFz8T9QiGMYtphAD+EQWvUedY6SsrL0S/W4vZ010P F/EX7b/xJ8QOzap411C6kYnme7kYk4Pdmry6+/aQ8SX5cvqkjOx5BkJJHtXPPEYqrrVqN+rG2jmJ vjPrF42/7dIwbkjPTAz1P1/nXQaB4y1vW5ljS7ctu44JzXPNuKbmCV9T1yx0bxKPKkn3+QAMlR1y M/h2ru/D/hS6vr228y2aaNXV2SVsK+Dna2DnBAxxg9ea4pVFL3os6FDY+gm+FN/4hv21OS3hjEn+ riRtqxr2RF4AAHTArrYvgD4gNvut7QbcgjkZA59vpWFGUKVONJPRK3/B+ZvK9STnLqdRY/s+X8yr NLCglAyAR/StP/hn/Uf+eMP/AHyP/iat1E97mbhG92fwDad8YPjhoxjJ126ljXqlwiygjtnIzjgd 67jTf2q/iNpsiTXmjW1woYs+Y5I8noD7Yyfp717FHGVabTp1fxuj1qmEhLWcT2bw5+3/AK/4a1fR PEeleCoY/EGnXEd3A06xXFuJYjuTfDMpjmTPLRSKyMPlZWUsK6L4IftI+GLrx5P4y8da2LGaN3uY oZ4swzTSEkn7pGBlscgglWH3MV7OGzerGS9q099vM8mvlUJPng9Vt/XqfW3xJ/aI8OfEuHQtJ025 02DRbCIxwy2V3K4nJAHIkcgcd8DvXIWfjm0t7KDQ7PVhOr7h5SIXbZhQx3DoOhZscYHtXXQzKlXq OMX7zdrf10scFXATpW5kfSmhzfDqDXdJ1vT/ABbNFpUGgiW8SaErNFqIiaJ4YVQkSoHIdXzuKuoK qQxX6e+Dunw65o2ta3YaHf2OgaqLvUbTU5rpPJ0xbWWM7LmSR0EibWlD4DSb1tggPmGvfo1KU+aP Sz389fyX3nn1IThe6tbf8f0PLfFt7q2lTaxJNqFvZa1O6agtpGybnUkpIiKoGwh8PsIXAZevfntN +IvjDQpbq3imdp45JBNHCyP5cxKMUycggEjHvkDpV06sITUVLyOWUZO+n9dz6E0P9onxdoukT6pJ Okj2tuUUiUo7RbVKh2HBAAEeB7LwQMfQ+m/E3XPEuhfsyfEHXIGs/jF4esLbS5X1q2L2OtafDeTX kCtGhAdRDeNEyuVDqSMjIz6tOtCpXpResVKLfpqnbzsyKSVKUpz7r9dD9mdF/ar8OxeNm0O106HS tOgvo4rix+2LP9ln3RCMWsqKFuLW5JkaJ22PsaLMa+ZtT9M/A3jnSfEYRIJo/OaGK4RB1Mcg+RgO 4ODyPQ0Y/CTVBV3u9X+H/D+RlQrr2ri+56BrWqWmiaPqWsX0gSytYHnlY9FVFLE/kK/DzwX8StK+ KGoeMlbxLeaTqEdhdahaxacbg3t7KJoXjTZbI8jxbyhkKjcpZWU5TI5crUVCtUnrZLTvvoaYyb+s 0YR83/kfsB8C9d/4Sf4PfDXXJBMLqfRbQ3C3CSrIsyxKsit5pLnDqwDFm3ABtzA7j6Tf2ZvLaS3S 5kidukkRAdPcZBH5g1wYheyxdWLXwyenTR+R6NvdsWwgCqo4Axin81z7lATjtUMlzFCY1kOC7bV4 zk4J/kDQk3ohOVtyQOp3e3Xik86LareYNpGQc9aLMOaO9zhfG3w28DfEexk07xhoUF9aOuxklzgj 8OtfPQ/Yl+DdkrDw9ZPZIfuxokflr+CKrH/vqvZwWd4rB0fq0oxnTWyktV6Pf80ZTpKafLLcpD9l e60t5m0HUtLV8AJK2n7ZD9Sd+OmeprnNW/Zt+INykn2nXzcRAE7IrgoG9toCg/Su15llmId6kJQf yaX5afI5pYWS1Wv9f10PLZf2bL9bi5hfwzOzo2Hl8o7c44+bPP1FT237Oc5ZiNKKeh3MOenfFZV6 ODqx/eSjNff/AMMZxnWpu0bowfGv7Fnhz4j6Kmi+J4brykm85HgvHR422svGBgjDHggg8ZFYXhf9 g3wz4R8HWPgiJ31DSbdpmSTWbe2uHcSSPKQ+1EQgFyo+X7oGcnJPkYnL8unR9nThya3ut/zO2jjM TTlzt3/A8j8X/wDBOP4G+I5xY3ng7w4125ICWym0mZv+3chv1r85/j5/wSA+Jvh7xpDP8D/h2z+B LyKK41B4tYt5JIbnd5T7VuZvOYCKOI4AIznvXjR4cozqSlKcYpxau1ZvyTt+eh6bzipWpqlUlomn 328zxr4v/wDBLzxd8PrJbvR/F8k7yzbBZ32mtEehJbertvAIA4UdRXxlrf7Ivxm0BmEXh6K4gjxg 20xXH0Emzjr27/SvyfM+G40q0qeGna3R6n2eEzOliqUZTja/zR5XrXw6+JmhSyf2j4Q1GJ0yDJ9m d17ZO5QR+teby3d9aeYbi2kTBweCTnHIxx15/OvnK2W4rDtucNF16HoKUJ/DLQgt/EMlnqul3cCl 3811EckXysBFK53f984/EdKua3c2N9qV9fWS+VG7+YkLNynGME9+mf8ACu6pzxyOLa/5ev8A9JPO ims1kv8Ap2v/AEo5zwZLcah8QvCWizaPIDNqNoqzqwMbFpVAzxxjnPX8a9X+Pfg2fR/FxsgiQiW0 VwUdc5V2Qk7cEcocg4OB3BydcNZZJXk3f34sKn/Iyp3/AJJfmjjfhnbXt/4q8G2fjO3gk0mbWLaK VLd2R2txcxb1LFvlYrkZBHrxXUeMdMtrLxLrWnTWJ3W13NC5A2O2x2VTyARnaDjqOB2rDRZNW9m9 PaLX1i/1Ll/yMIK/2H/6UjI06+u7UObLU7iBg/Clvk257bhg9T+v4atxrGrRbbm+S2u7bIOJYgrb ScHBAwDg54z0rwlyt3Wj8jrdNOzRXEXhLxA9pc3Nhf2kkbb1ktmLROfcAEkcHoB7Hiti98G2N0Lq 1stYjNwHwYpFCSIemG4zxg9h0NUqs4WU46LqvPuiJKx5nqXgHVtPvblba1fysqweNw2c9enPqa5K 6m1bSZjHBOBIoUPDvKSDJwrbT2z79q7aLp158uj/AEIqSSirs56Px/bayNQtDMs62lw1pcq64EU6 bS6FsbSy7kyOT8y+tSi18NX0avNYmIlc74mwuTjO7sfxFdkY18JU5YvVdH5mD5ZJODOb1TwrazAX FhfxkZPyNxg++Pr6d6zD4f1mHLzWm+HBIZSCoGMZByT+ldSrwnZP3ZGKTV+qNSzMcgkmlyXjBBEu 7kdMgjkY46nHtxipLeXSJodk+oSWl4JFVVmXfEyscKdyHcOvTacdfSuulXlCyqao5qtBNtwG3un3 6xvMpE1uvWSBw4HA6jquP9oCsF5zh2EmAOAMcnPBHr2J79DXoUqsXZ05XR59SDV0QtehFVTkqcEl eoGM/jjOM0w3+FDDuBtORk9hjPXn2/OuqLurs5JR7kh1bliCcnsTwMcH/Pbiri6tI2AvUjjkY/p/ kVum7LUxat1Ne21qZGLeYAMkcN+Pb/CuptPEEkQwLghRgenH+f5VrGSsHqdNb+IrkFit4cDqGbAz jHX9Pb0ra07xTfWsrSW8kTPkAieGOULjoRuBweeo5rbli9tAktdDuLrx9qGtabpmnX1rYh7UyMlx b2kdvNIr4OyQxBRIFIJBZS48wgsVCqsNtfXEjnZ14yBkDn39aFZRSvexF2dvo1rd3csWyMscc5PT 1ya+x/g34B1jWb6zSHTpZpHcZwO3Trj9KwxErQfcuK95WP1++Fn7MOs39tBLLpzeS+MK2F2cD/P5 V9OWX7KGFjeHRgJFwchSx49gOef51wUaVar8C0O3mjHRs9q8JfsrTxCN7q0QJ12smcEc9D0r6Q03 4D6Ba2ywvEDxzxXsYXKK1V80kc1TFKOkTaj+CnhraBJbLkHOQAM/pVj/AIUx4X/59h+f/wBavS/s O6XMYPEtn+cPrf7EmxXOj+IrdhnCoz8nt26cZ/KvDNf/AGS/HWneaUs7aWE5J2tnJ/EccHjBxwK/ NKOYqy5nY+9lRaeh4le/BDxHazyG+8IqyAk5Chg3sDnH+fxrkLj4YWOLi3m8OywyluWRT8uOnt36 16dPHTetOpcxnRswHw60GONXayukYDB3BucHqMj69/z4xr+CU1H4eanql/4M8U3Omz31o+n3Ziba bm3cqzwy7QN8bFEJQnaSi5HAx10cyxMG5QfrY56lCNRctSKaPTIvif4wjKx3WqwXFqh3CIRPF6Z5 GRjpnjnNer2v7SfiWDR4fD1sbyLRvPW6NtFKfJaYADfs+6WwqjPsPavWw+e4iGkm3r/SPKrZbTqX 5VZ/8E7XVf2gbTx1rel+IdQgkg12G0s7Qv5Tkv8AZYkhWRmYtudliQtz8xLHA3YqMfF/RtAvbe7v /ECabdSeZgy3SL5nHzHEpION3JI6HGeRXtUM8o1Jcidn955VfL6sFzSjdLsbWifGGfxnq+n+C/Ce qyavNevGbu3svLeVIwcyOpIYAhN4BIIywJBAr9Otb+Mng/WL+SK70l7e3NgbTT5bKacPpE0peN4t ksjLLsTYHO9MK74U4WvqcJi17PnXV6fp+p5eIwz5Uo+b1/XyP0D/AGdfi74Q8ReGfB2q6xa2v/CT wLbHV40jACom5VB8wkjZiJQd3RAcgGv1P+C+qa1JrGharZ6gFjjWC7lhiASBoIEVSjyEZcCIYB3D 5tpwR8p+i+t80Gqkrxs1r2seVOg4VLtG1+27+0nJoXwW1fQ/D1zEfEWsTCw+zQXCNJFZLvNxcMcg BCAqDG4t5g4G1iPzy/Yi+Fv/AAtL4/aV8RPGbvaeF9A0pNU0WaC4i8m9F7aGNdx75hu2ZoznG3bK Bna3Fl1ehSdWcZp8qenny2V/m39xr7Oc6vt5rS2n5f5n9CGn6jpOhQaJo+l2MVtpiIIUhhjWOK3Q L8qoAAB0AAHHP0rY0O5g1C51PWIbgvBM6wRfM+0RxblztbgEuZPmA+ZdnXArhmm1Oo3dvd9bt3/Q 6qdRXSOkDKTjNOrmOhNPYKqz4MtqShYBjjA+6dp5J7DGR9SKa3FLYsEAg5FcrrGgpc2E8cU0iTLv aNldt2W3ZUH0+bA9MD0rWjU9nNPzM61PnjofPXjq08deCbyG80rWQdFRSw5K/dUhUK855bOR1I55 rxHU/j78ULKzukluYVAIRJ4lVnJQMZcFhwMMmMqO+ehr6GFHBYqlGty9NfXqeTKrWozcGzotN/at 1HTvh9ql5LYG88Q2MscUglkUNIZGUKqgAg8MRuLZyrKQMDPn/ij9vmKx0e2h0nThJrHnM5kKMsck KSMh25OQxGxhlSBkg5I582vg6cZyce/3I7KWJlKKucDB/wAFDZrSxtrwon2i48wyWzKJAjZI3BsA gA/w4GSuenB19H/b9sNe0i/Gv6bJamL50ngG3+FlUyndwu8x5AAPU5z8teJialaheUEnY74KjVVn v07HPw/tralf/YW03xLmOXa06C2hXGHbzFi3gudscZbkg4cHtXpXgb44+GfEmvSw+K9Xs57CZ2a3 udRu7kIioQ0pdBMIQqReZIPlG/yyoJJGfHp8Rzw1WKrw5fNq9vPU6p5UpJunK6XY9E8V+IvGGk/E tvh94S1rwzpwu9LFzp7WGmxJcSXDRPIi+ZM0iSbjGwAEYyHT5ga+QviV8Rfjbpd5ora744nm8Prd mwuLqJDHDqMpWRgkbRFIi42lsoCpSPgAktXXiMb/AGjKdGVWV+6ev9amVKi8O1NQv112F8IaB4l8 aQxy29gJ5XVnb5znAZlyc5PO0kd8dq+oNV/YxuL4yPo+sWUkbRrJGb22eFmyvOQoYoc8Ef8A6h4F LJI1pT/eS30e57EMyjBJTp29P8j54179iH4h3809tPommxKGOJovMnUqfr5YH58e1eQa7/wTc8O+ IblbPxXq1k87D/UILZnI5yBHiV8cnjPc17GG4TTlzVKvtPJbfPqvnYVXO6VPWjF37vf7kfN/xl/4 Jk/DTT/DOpWPgP4ZalN46XDWmp+XLbwW7MQHJ+0SxRtmMuoAjbG/gjqPliL/AIJi+Dm8J6dN418Z X+kePSki3K5tp7WPa7rHtVOfuCMt+9OW3H5c4GGc8P4eOF9k4Rcb35YvVab3Wl/mY4XPKixP1ier ty69r3PF9a/4J3+LvBt/B4k+Fvxr0a/1KwK3sCTu9pM0kJ3p5aIZhvyBjJAyAOK5H45fs+fHTxtr P/CTeHfCt9q1gtmi30hjjWaO9dnuLiIQAiRgGlOGRSpyQOQQPiK2S4d4GtQw0rOTTtLS1vwPap5l Qr42lUn7qUZL7zwHwJ4V8X/Db4ufCvUfiR4M1TSNFs/Eel3l5NdadPF5dtFdwySSYZedqqxzhscc HpXFftBN4t1P4razqV7AdMuJbj7ReaftB2GQLIEOQDkDAztH0Ga8V4Cvg8trU8TH7Ubeej1Xo7Ho 3hPG05U2n7j29Ucza21jcCRxMwkQbiSB6duOfwrFmvdKvbL7TaAuFkMTbRlgVPv1PtXzUU5J2O/Z 6hZancQW7LBcPHAwLfOCChHrn6Z9Ku6lJdXl3cSRgTxEZUZyBknvycf/AF6IxUW7vUTjc565l13R 2zaXU+SA+fOLZLH/AGjgDHAHtWHPAuq61a6/rGy+vLePYv2iOORUU5yMADaeck4/Gt4uMH7Sno9d VpuROMWrNFyG38KfZboWnhNbWOeYzy/2edgkdsAvtKgEnauT/wDrNE6d4euZZILPU0gcAnZcDZ78 sOD9a6Y1q0m3VfM+vf5nM4RguWK0OU1PwnqqRLc22ya3IZhJCRJkY7dz27eprMsr/V7O7nsLq0lA iVWEsgyrhsjAB9MfqPrXVenWVov7zNrc1kujPLM2pQxy2zAAAQ4dD3y2cnPpx0/LFvbXw5eS2ttF cSQzSP8AKWPyoynPViMnPQgnp7UoyqQdlrFE+pWbw54gtEmniWO6tW6EMTntjn8emehPrWTcX6WY MWqaUqLgnE0RGOx+ZMN2HsK6KVa758PLXsTUhGacZIoy3GgXk9mljdtFLMRGQ8oZN2N2cqAVGAeC pPv1qhfQi3aSELHKq8ZjfO7GMEdD+nb1r1cPinUVp6SPLrYZwu7aGFNcMp3RyYz94BjzjPBph1YD iQ5G3kdRgY/Xp9ePw9KLvuefKCLFtq4YHbkRnjqfbr69+P8AJ1rfXtqkxuMjkHHBA5OOc9Of88bJ tK19jKUNfM2IPEUaEDzBgAH7w6c/579a3YfFViEBlkH3u55I46VfPJ7Inbc6zT/HejIQxkLYLNna eBjn8u9d1o3xO8JWpCzJK4GM7Yif589c0P2khXS95H0V4C+Nvw6trm2W48Ga5e45K2kERzz/ALbK Ox71++v7DniLwd4wstH1Lwl+z5rl5eyvtSK/vIYipViDu8kTjsW6ngjOOQM1h8TWrQoxcfedrdfy GpWu4n70+DoPFg06JZ/htp+l/KMR/wBpeeV+uIUru4LPxQMZfTo19EgkJH478V95Qy2lQhGM5K67 K/56HNKSb1lcujTtZc5k10r7RW8YA/76BqRtGaX/AI+NWu2P+zN5f/oGK7lGnHZX9X+isRzR6IY/ hvS5eLlZZh6SzyN/M1F/wiPhz/oEx/r/AI1SlbRRX3IXOz/L2tf2rPA15IZZdR1K3JJwrW7FQPqC a6BP2nfAd4pH/CXSrk7T5ttLwO54U+nP9a/EK2U4tf8ALtP5n6dDHUJWuPl+MXga7jZY/GVgTuyd zkFux6gcfX1rnZtR8E6s/wDakHibTWLP92O8XY3HGcHjnnI/wrCOHrUbt0n9xt7TD1UmpIsSahp3 k4VLGdR0ZZx0I4+5nPuT/wDWrkr21WZY7x/Dp8pjgbHBUDn25qI8ylbm+9GM6EJXcGjJv9K09Pt1 xdaD5UcUAnzIEUyAZ4U5+YgZ47c+orh28Q+F4TiXQLjywM8xMoIxgj27/wCOK74U60k0pJ/15nE6 LUrI6XRtZ8G+ejSaVPGqg9CykjIzznPv+H59PqY+F/inTW0rX7Z3sJPvpMAR35GSSD0OevHWtlHE UpRqR3W1jKVLmvF21PTfhJpXwv8Ah9pp03wPqcNqzg+ZPOheZx2DO2MAHAAXGO3evpy58S654qex ZdY0O4lhCpCLqyldGVQFUN5Uyu+FUBctwAB0GK7/AO38fTmpN2S6LY86plNGbble/qfX/gH9oD4r +F1gubXQfBQv4wCs8WmzjoACVSSV1BwMZx244yD6F4h/ae/aQ8Y6ZPpt9rVvHYOnKWEcEXTsp8vg c9BgcfSuerxBjq7adeX32X4WuNZThFurrzX+R5nput+NrnUItcvhLc6hsMRa6ZJlkiYEFHQpyu1m XHUZOCDzX0h4Y/ai8a6VdaR4Sn+HbR+Fbeza1tYNPjv7eC3TZtAExllc4AJ/e+Zw5AIOwKYbPsZQ p+x5k1fmu9H13fU1rZXhatmtLK1lt9x9Z2f7XmpzeAZfB8PhfVLS9MSQf2haaiRI8aHhSzQhlG0B Mj5+c7w3Ne5+Ev8AgoJ480KwlS6tpZ7dTtVZxuEMeRjYsabiwGSSxbOeAMc/Q4TjHk9zEx0v/X3H j4jh+cm5UZK/3HsXhn/gqDos8VvcyaTqGo27Zjd2s1s3jxncRE4yv8ICszdzkYG72/QP+Ckfwm1k qhtruyWNczC9gcOTjO2MLlHYkEbmdF75zhT72G4lyzEycXPl+Z5lXKMfQV3Bv8T3nwf+158MPGcV udL12z+1yHCW8l0kchPXHzEDOOpztH97AzXbf8NH/CDTbaFNb+JegJqXlqZorfUoZEikI5UOGwee K9qNbCzpqpGonfbU4X7aEmpxd15E8P7R3wfubiK00/x5ptxISAWS6i2IO5ZyQijGOpySVABLAHjf Gv7V3wo8MWGoSSeJ4hPEhUSSoYl83bvChJMMxAwScYG5cnnjeMNIy7mUqzaskfMvxZ/akgvPDkbf ZfL+13ebaF3UzNbbCFVYc790jdGIUFX4ORivz28f/HWwgaWwW86QeTI+8+XM2/cWBz82ASqsVBC8 cZNd0cTChBwi9TilTlUlc8rv/wBouWOwu1+1CdZLciTe7qkc/lhYJIgqhfO3mR/n3DYzYw6qw+Ud Y+KeomeSO0u8NtCyOWBZujNyOMFxkdeAK5quN5pam8KLsecXHjTV5BI890d5+ZcO2SeSQD165PH6 V7h8IPFFrr+j+OYfEfiK3ttKtdHvCj3cxRLqZbS4uI7cNkN5kot5PL5XL7VySyq3JNwqtXsdELx1 Zw3ij46WWta/ffZfDVtpVo1vGttY6SJPs9rBFGrAqZneV3KqzSSySksx3YCkBLHw5+J2raxq+leH bPfLrN55ccUMUSPI0rk4SMSLkEbhjGMeYQcV4eOws8dVl7mrd0l6nfRxEqWqke3+O/2s/E3iPxx4 r1t/sW61kj8PaRdw2vmfbFt4oLaR2W4DqY2cRTKpiCspkChQigfRv7OXx88e/Frw7p/hDxxo8ep+ FNM+JCf2Zr9/do0lnZPAqSabGHf7ReSSGd5C8zFkLq7yuZE8vTB5Pi6OL9uqMmktW72V7Xt062X5 6GyrqpScZytvY+mvCnx88bfsx/E64+GXiEQzWF7bwaz4dmZI3TxNp3KNHCiFTb6gWDAQs+wvFLEF LvCT9+fFb9pa78E6LY6zo1jpt3q8k0uo6Ro8OrRS3PjPRBp012ktjCALgzPIgiWKOGZhIg3YhkMy xg4YvB1cVhZ3k1JOF09VJ7adno+1maVoUaipVYacy1+SX9f5Hrnw+8f+MPGmqX66z8MtQ03wtcRm 7sLq/wBsUiQG205kiubeQLJHO88+oJsUOqLY5dlM0an2EJbwJhY1VB2CgCvdXtEuWenkndfhoefN Ri3rdHyr+0z9l1bwZqOh6dfX2navMg8nVLAQM0Bzz8sqOrZGRyBzg54wfwK+Kv7PFjdXd3da58Xv Hl9ISTtbVra3j/75t7dOP/1UYqtCFBe0oxlJdXfb0TOaEIzqc0T5W1b4RaBZSynT77VUuSceeNTm jlP1kj2t3JxmuHlk0P4Pyz3l18VdT0a4m/0loo9fvBPd9F3i3R2knPHJEbnHHTivjcVjq+Ibw8aU XfaKjf8A4J6sKFOKUm3cy/E/7ZepXOi+IPCa6p4n1jRb2ymtGuG07TI7aaORGUkPc7blGAbjdCRk AkcV8p+P/jTD4y+GGn+A7L4awafqdpKm3xNayW15rE0cZY+XKHW3jkOMJ874wB3Ga5qmWV/YuGIi owb1T5npbZuzt8mb0sUqFWM6baaPkC51zXrEzySa1FayOzCOHxHZR6bI0fd2ubaWTTIuSFVHuhI5 KhUJJFVbn4h674dvrjSfEnhuS1v4gFmhkYxOoxnlHXPIweTzkV8dmHDcKDbpSavt1T9Hv+p9Hhs1 Ve2l/wAy1H8Z/DjXKW/2A+SVBkaeBcg5HGIyWxwOcnr2zXoNr428L6yrmOOwkJRcCK8SKTkcfKx3 n8j655r56vluMor2knf8UelDE0pNJO3qMuYreTy5CLy3fZlVkQlf++x97HPG044Nc1bWNjpyyRw3 XmKzPITI+SWYknqQcZOMY7cVjBtRtbfqv6/M2tqSRwykMVLAmPbkk5OSCOvH9ORVZoLaO/xdHy96 MrbhwBt4HTHpxXbTiormM5JWOAbSptPzcadqc4mlkZsCZ8L2OPQewx+deiaXe3BtrR7nWI2lKHzI LlFOGJ6ZyDjA65PXGa0xGsYzjDXy/M5nFpNtGrcDQLxUe4sQsrAAvZzg9evytjr6DP1rNv8Awbpd 8sV3FfxmeJiYVuEMbox+X5Wx8xxn25rnp1qkbc2vn1+a/wAgcVrdHlWpapFoWnXeo+eyWkV4LOSS OTAjkGScknodvBxySPWsn/hMbXVrcxR6lDcxhhmOUjeR/usOhIx/WvRhg6tSj9Zpx0Ts2t1/Vzll iKMaqozlZ6NGfd6f4R1JI5XtZLS/X/lpGMpnPPGTx+WK599G1WFftGk6nFeRKS5+YB14OOM5z17/ AM6dOs7qFdad1+pdVXjsY3jPxRBB4b0hYosa0PK+0BYiWOEcSBiMHIJQncMncmMjNeV2Hiua+nI8 iTbgg7WDhSOMY+979O35/RUZfuoyZ5M6Ommj1+460i42B0kVyBlzGwfHJ4YjOOoHOP61GlxIuD5u euR9OnPQf/WrshODd7nLOKvsWftRjPzMCc4Bx97Ht2/HFadvfw7VEq5Qj647c45Hp+NdG60RzTWh 0FrqkMWCo79BwCO3HFdlp/iJLbyvKiBwDjjnj1456/lUytfcyd76HcaR8TZLJo2hlCkIGOSABjOe R1/D0r+gP/gmV/wWN8B/sv8Aww1b4P8AxX8H3ep6VJq0uq2OqabfwebbCVIEeCSCUKCoMbyiRZCc vtKYG6tKFeGGxVKu9eV7X7pr8LkON0z9bH/4Lvfsiy24lstA8RmU9EnSxQf99JO/8q878Sf8F9vg dpKqbD4b3Lo2djXGrIh/FVhb+f8AjX2MM2yxxTlUk5Poo/q2vyJVHTmctDwrxb/wcHxWMssWgfDf RlG0FTc3kkmMhSMlZEHRlP0z6V826p/wcJ/FbW7+4tdNuPCuiQpDJL5s8RZSV+6qg+cSxJAAxgck nAJFPOMJFOVHCudv5pPX0UVH8xWord3/AK8j468ef8HAv7VV/NcwaX47hS2BKGS1trW3wc4ypWNW C45y2D7dK8s/4fx/tc/9FVuP/A1K0/teuvgowS/69qX4yu/xFzQX2V/XqflzF4f8BXWTN4csSzfw iMLzj1GO38vbFNPw/wDhpI0bHw7EpX5gUmlXaSe2D65/OvnpU6c1sddPGYimrqYj/Cn4VXITy7CW M+sVyc4PX7wPbH5d6qH4JfDSUB4b++WTnkzRsB9flGe3HFcs8NTeqR1xzKtFpKzRQm+A3g9/+Pfx PdRjj70Snv8A7w7Y/wAiqqfBW3tdhsPHkifNwAskeOAOzntg/meK5J4KE9LXR1QzOSfvx+5k7fDX xZtEFv428yNMeWJJ5doyOcKVOPTjtWnF8PfGuF83VLeXAxzKuTxjjcB/niuWpli+ykdMM1i1e7R+ kn/BPz/gnB8Rv20PGfiDwxpXiLStMbTtPOo3Et9KoBj3pHhEhDMxzImcLgZ5IyAf008Rf8G5Xxxt oriTQviH4WvJ9h2B57qPc3X+KHA5/Dmv1HLOFuDY5RhVnOIrwxNWHPenCMoRTbUU7zjJuyu2u/e5 U82w0bKc3d67aL9b/I/Ez9o39jf4sfszfFXxJ8JfH3hgf8JNp6wGVtPlS6iZJ0WSJt8JYDcrq21s MNwyOorw+Hwfqun3AnktbmByozvV1HGAT/L/ADxX5Nj8H7DF18PRl7SEZNKVrcyT0dnrr2Oqljqd RKStr5ne6W/iG2hT7Nr11G+RuPmy4A56c8Hr69K9M0XxV480wo8Piy4IA2Lvl3gAezA15M8PH7a/ A641qbXvI9D0/wCKHxJsQZBryMFG1A0MC5Xt0QZ/P8a9R0f49+PrZIzcJYyOMdYz8wxkg7XHoPXr XLUw1LXlbXz/AOHLSoy2PU9M/aR8UKUNzollJIMAFQ6bvY/McdfTFelWH7S0ctuhufB0PmHlit4T kfTyzz+Ncc8LLVqZqqdP7Mzqbb4++HZYgz+FZElwQAjREA4Jxzt4z1479Kp/Db46r/ampJ460qJL JzvtZLBGZoRyCrgtk4AyGH0xnmsI4ea5pOWvT/gmqotxdj0+9+K/wmlmkDa/NHK4yFe3u9rAE5OM FQefY49sVzl74s+GWtTNbweP/s80rb4y7vAVxt6BlUY4Ap0q2Lp1OWm3fyd/yMp0E481Wkn6pDda 8X674F0HWL7wT8ZZrPULmMCZrbVog0sR+YhkDAuvOQDkc5xXzxrPxr+KzR6HqEXxFjvbmCZIpXmE UwwcsX2OW2jdzwcZY17+Az7OIVY0XUlp3v2227nnV8oy2tCVX2STdtVp2K978b9UvJX/AOEouhcT pGyxG02ZXcoViVVx8xHUgZIPNcBqHxY8NWTJfTDULeRsH597RnIYcphiSOoyw5AznJB9ehxdj01D EUVJP5P8Tz8RwxSu3h6jS7P/ADMG9+LltqqxtB4zMYZdwF1bOS27gsWzu3dshc8AADApkHi6xmMU UnjfSJJWIJTzZojn6SooP5+noa9vDcRYbFNQUJKb0ta/5HkVskxlD7PN6H2X+zb4W+Dnxg8OeKdA 1a18Y3/xRMV02i2Xhjw/qF9E4hTcrM8ds0bhpCBtDrnj5hnI+ufhr/wTD/a08X+GNQ0638P2nhjS da2C7vNc1KW3nns43jljt5LOAyMitLHHOwli8wPDEPkCEP8AoGX5TUjFYnPH9WotJwWjq1Iu+sad 7pOzSlJxj0vc8+th3RspPXsfVHgj/gh/4bs5bG++JfxzmkRW3XFppGmiMOuCAqTzyMQMHvEeOOa+ svh//wAE9f2JvgReT62W1S/1k2tza/a9S1uRJI47iCS2m2m0EAUmGWRN33l3ZBBAI9Z5vgMJB0cm y+MW017Sr+8qesVpTjddHGbXSRy1J04pqTFk0v8AYH+GsFlp/h74ReB3ms1xavqcFpdyxgSNLkSX Jkk++xfO7q2c5rnrP9oL4beHoJ9D+Fuh+D9Is2lL/ZtD0+whUu2wltsS/eJji5xn92noMebjs8zX FprFYucot35btQ+UFaK8rJIzjNS+GyR5h4q+IOt6x5JF5tSEFIVjjUCEMxchQBhQWYtx1JJrzW/8 ffEdJoLu38c6tDNBB9mt3j1C4RoYs/6tGDAqhIB2jjjpXyeNr1JSvzO5207JWex598Q/2ofG3wk8 OXHi3xj8a/E0VijiKG3j1m+kmvJ2wEhijD5dmPAUA1+e/jP/AILXftFeGL1YtG8TQ6bp7bhHDrFx HqFxJxkb3f8Adow6MqmUZHDHPHZkeXYzMqlSvXxTpYenvJ9+i107foc+OxNGjFRhDmk9kuv3HkOs f8FoP2vvF0+kJFr/AIeu9PtrhLiaOGC2jbUQpUtDMPKJEbDKny3jbDHDA7SNLU/+CpnxD8Q6Tepr HwY02LXJFzDPbNNNBEx6F4Vl3uOvAlT68V7WZ5JjXRjLL7VYLeUZJt69V39NDlwmJw7m1Vqcsnay krW+Z8m6v+1F49+IfiPT7bxn8QpfD/hi4njjvV8NaR9me3i3gvJEJJ2uTKq5wn2yJWI5KZ+X91v2 L2/4IseHbHwnHrniGDXfifLGst/rHxBsrmG2ku5Ejhl3RSA6fHEzu7qJ3nMakl52Cb6+Xw2Mo5Ri 5KjRftJKzckuaL62T38mtUul9T1r1pQvpby7dGfst4LX9il/A82ufDW08HR+GDbm7Ft4dksUSFMg f6u0bahyRkdc/Svwa/bb/Zt+An7ZWo3Ph3TEg0jxVAZv7E120WOG/tG5ZV83hnjJyWhbIZT/AAsE deDE46nHF08ZRlzON3NN3unvGXyvclycouEnufyjfFtf2nf2QviDf+DfGdzF4l0eJi8C3DSSLqVt 0WS3nIDI3B+Riw+QjAIIrqvhn418E/FLQbif4YWcEsNko+1eCdTdENhglsWLEH7EdxYhYx9mkZnL orsJ4/SzvLMPShTxeE/3Wuk1/cfy7PRr1RhgcXOnUcW/fi7PzRoeKdL8LxaT/b2nRxDTTdG02yxy QTwThEdre4hZiYZ0Ljem5lKtFLG0kU0Ur+R395o9vEk7Wk6xtlSY5AwHrw3XjA4x1r4eeBlGbpxl rtr/AJr+rH0Mca9FNbmXaeM7KwfzLPxReW0mdy5RxnuMmMmuoh+JniALvi8QW12VwT54idhx0JkX zAcn1z1rzsTlibvWo2/vL/ga/edtHHRv+7nY2E+M2qWES/a9DiTC8GB5o1fk85Yuvp0AHB554SP4 8eGbkiHUIbuOcN8xREkVRnqWDKRyOm015zyqaTlhp38np+J6EcZf+KvmjYt/il4Ivp/ItvE9sFVC VNxugAyec+cqDPH5/r19rJHqNtHeW0wlsZBhJYzvUkEkngkcc8dO9YVI1qCjHEU2v677FxnTqX5W PFq4EjW14FYNkL93sepIzx7VZTWtV035ZZ8wqu45QMvc/wA/TNctSMKz00Zo72Z53471ez1LQza3 mhwvbT3G6RIbbeZgqSuCY+CdvDHgnAJ7c/P+oWlsJ083UJbOMzRBriFwjx4ZCNrEEDJGMc9fy+xy DmjganN72r39EfMZtpjKbT6L82fY934W8LXFlMy3UUY8pSWSRXLbc4ODkt0Bx3/E155f+DrO6tm1 rQ9agmgVfMMkbEHbjOBjPOPp7jtXx1DFNzftIu23zfQ+glHS/U8F8Ux6qXlZU8+LYCjOC2wDuW69 RntjI9M15ZFJPbC4vra+HnxNl4WyxJGCME9eDnHPv0r6XC+zdP3U2n+H9djkqx0TubX9oXjrBez6 VLDMF3pPFwAAMg8dO/P/ANah/Ed0nMd9FOjZ4mQ+YGJxnjBP69T7VvC8XeLuu6/JmU6cZxPPta+I fi7S/MdrKGSANnfCDlRjOMP0P0yCK4I/HPX7hAlppV6zqzb2ECFSvHAAXIIO7PJznoMc+7hMJGvD nhU063Z4+J/cy5Wrs1Lf4ifEG9iD2/h3UZNz54V0468nABzx09K1IdS+Ld/GssHhuQA8bp7mMDA6 k5fPY+nb2ro+qYaKvUrrTtuc/tpNrlhY6TQbH4gata380728F5CxX7wZWkODjI3DG1skjueM816J oOh/E2Mxk67BHbH+71zyTjKcfn2rnnDBptO7sPnqct7ndNp3j2JAzeKZDnJwuQOMehHPPH0rB1WD xf8A2ZfavNrryLBkmNi5c4A6E9OSK6cPPDRlG0N9NPMxnzPS5wtqfE+s2PiDUvt0mLOyhvZNoP3Z EMi5J6cAH/PPQfCvTrbxrZavc38ckkltKg3byoUH5lBxjJ6mu+tWVOlJw6NL7/8AhzBauKex9S6D 8M/DQsbUPpkDOwZsNHvPyf72e7cn/Zrb/wCFcaB/0Cbf/wAB468z6zVnq5m0aUXuj81oviprcPyv qt4oXDlgkowO+Qw4xxVtPj3fW4KDxMFfAYeYyg4zjksPqPxqnSxdtEzqTot6tFqP9ojUDIBF4gtm JIIUyQE5Hb5SO/PuTU037TWs6ZbiW4vrPyg4jDOwbLHoPlbv3xjFSqVdtJp/cyrUbXv+Jsp+0X4h IRY7SNjjoUkUgdsfNyefbOOtbFt8fPEaqrf2MZMErhWk4PuenQf0qXOcVrK33B7FS1uPb9pu406c 22qWnlXBAJU3YUnJ6gEZxnvWjp/7UmkPKC0paXOQsd6h2dunA5Pr69cVcXVtzKN16EuMb8vN/mfT /wAIP2+PGPwj1Ztd+GvxF1vw/rroYftejau9nM0RILL5sEivtPGVyQcDrX1RP/wV6/aU1rSm0a7/ AGmfHLaY6uskTeJtQZJQ4y4cCb94D3B3Dk8cnPRVznGSoRws5PkirLukm3ZO10rtu1y1Bvs/uv8A kfMNx+0noV6ZJbnxFt/j+aKQ5/75U89f1rTs/jhoF3sWPxXGc/xMXGfXBYD8q8+NWm1blsiHCbd+ U6xfiho6wq7+LLF0kYoFS8iJJ4zkKxK9R1xXW6b470PUtB1rXrvxlbQw2DQxRRgJNHeSzLKUiZs/ uhiJnB5+4RUVKtDVOOxqlVVmuZHS634y8Di203U/BmoM+jSK0Drfy2j3MNxGATuaLarKysrBtq5J YY+U1StvGUYiUFgFPdXIyTjPAP8AnNZKlhai99Rv/W3U1+s4qD0m/wCvU9F8V6xpvhmfQ9P09nbf o+n38ztLI+XuoI7rGWZsELMqnpyvSsS38fLFhfOfOC2OCD+YNc/9n4SprbfsdEczxcW0nc2IfiFG GDfb8MAP4j/Ltnnn29q0h8R7iVhFDrTLngfJyo/Fu9YVMnoLWLZ0QzmqvjpmhF8Rb9Yx/wATUtMB jLjIPYetQv411S4ZMXNsz4YAuSre2cJyMcdewrlllEej/A7I50o6ST/r1LEPi7WzsieyspkXnaZX AbHrt2nn1yOOM1t+HP8AhMPGWtaR4csNGtJby/vIoIFe+tbdGllkCKrvJIiRqWYZZmVVGSWCgmun B5TU+tUqcKiXM0rvpd27XNv7WpVI8knZPyP2h0//AIIqftM6p4fsdR1C78O6bq8sAM1lHqTNNCzD lGaNDEWHTKyEZ7kc18E/tO/8E3P2ovghd+FtK1zwvqeqNrdw9ppcWiXSalNdyphn22tu7TcBkyxT GWUZyQD+m5jwJw5isMqeR5hKri9Fy1KXJGT6uE+aSSWrvPk91a2ehlTznCOfLGpd+aa/E9o/Z5/4 Ib/tWfFeXTte+I17D4E8JybGMmsMsuom3kBY+XYxgsjggBo53tm5HoRX7g/AX/gi3+xz8JbPTZvG 9jqPjrxNCsLPca5cm3sxLGc7o7S1KAox6xTPOpHByK9LLMtyfhSHLl8Y4jGres1zU6b6qlGWk2np 7SScd+SL92Z5eZ8QKT9lhtG/tf5f5n6neE/Bngb4b6JHoHgPwhpmieHoyXWy0jT4LS3Vj1by4lVc nucZNeLfE/8AaX+FPw/jubbXPHWm218gOYWv4ll9Pu7w3X2rpw9LE5lipVa83OTd5Sk7t+bbvf5n w+ZZhKjFtXcmflX8df8Agov8FrUXluviS5vCAw2JFcSIQB6hSv61+I3xT/4Ksfsr6nc3C205dwxU n+xLsHO7HT7Pxz39+2ef0jLa2Q5fRUa8oSku0f1sfFV/7bxU3KnzJetv8j5k039uD4M/FbXx4d8H RmbUXUyeUNLuIx5YwNxZ4lCjPHzHqR61Z8RXseu+Lfhz4S06RbLWda16zsLS6i2xyWJVjNLcbzgo ESJ2JHdh9a9jMamWYzh3FY/DQTik1tbb5eZlgVmNDNqGHxM2nJp2bvp56vzP6IbVINM0rTrKC6eb ESqskjZaXAxkn3wTWRd6rH5swzhYEDPjqxwcYzx6/mDX86VKXM3Jo/TFLlSVz8Hf2o/jPrXxK+M/ iC9B2+D/AAgf7J0uB0wr6jtJu7kNkpJjesCsuNuy4GcORX5r+MLO48T6tfX12JFjfCxqp7DAGCfU biT6k/Wvq8ZQjgOGMFh0/frNzfy119Lr7jyaMpVszrS6U0l83/TPFNU0uVJ5ooWlACscN3IycHIA /LoPrXV+F73xBZRImm3NxDCjAEJMyAEY6qDj+Hj9eOK+do1MThZqVCo4PybR6M4U6q5KsU0++p6+ ieINau7OfXbyQxqoCs2MAHvhQB+hPGDXph8PmCzQ2k8juQTnHD49CK83H1JY2tKvifenLdm+Gaw8 PZ0laK2Q3Stf1bSLpES6nimXJDxlgy+4yR7ivcfBfx6+J3hW7S50vxVPOx3Dfchbj7wII/ehmHBO CpHtXj1aDheK2f3nW3TnZ2KPxZ8TW3xz8I3nh7x3o9u82Wl0+/t0bNhNwQw5LANt2uh4IAOAyqw/ ID4j/Az4ifCrWYvitocNzY3NpvNzrOlN9pgRRjZO8SfP5RbCzIQHVN0qxuYtsv2WSYzC43Ka2RYy VqivKlfr3jfo27273PHxdCthsZDF0lenLSXl2fptc+hPhr8RtC/aS8M6vBqGi2//AAt6xtfsutaI tysCeILeMtseCYgrDMheRoLnD+Q8kisslvPcQzfOvjnwrf8Ahs6JdW3iq5XT7iLdby3FmUe6SPdC fNTrFLHIskMsRZjHJDIm9ttfN1KOns6keaUHZ97W0f3fkexCf7vXdHkMltq3nPJD4jidCQfJaBgi LnjDE5I9+v51LdTeMEkCroTXEAj3b0kAztJUkDJwMggZHuaFTpOSV+X1IctLpnNLqmoQ3OJop7Mg H5VbaRweCVPJ7f8A1807/hIfE0NtMP7QeVEAdRcRJLuUfMFYsN2DjBAOfcUSwNCo/fh21Wn4l08R VpWcJfeblnpPiSWPTrnVbaAJcQRzwC2jdCVkRZF3MzMpIVlzgcfUnHeeH/hF4z8T2kOoeEJpZpZb lbCKC1kV7lrpigSIRod4LswWMsqiRkZUJZSo5q2Dpwuvij56nbRxk3pJWZzEfxC+Knha18yHxjIL VEJxeNE5KhQSFNwGwcbQFHJJ+XJzXQ6B+1j4hZ7aK/8ADNnqMCDbI1oJoppuOpfe6A554jx7enkV uHKGJblQ/dyvutn5W/ysdsM29n7kpc3+R6Fpfx/HiuRbS1+Gms/b42kcxW1q9ysavFIjNujQHIEm eVA4yfQ8hN478J6hqLWd9dpDco4EtvqERjZDkHDiRetdOAwFfLoVcNUmpSWvu7rTqtzz8fW+t1ae JhBqNkte6Z9EjU9Qm0aDXNMWK60R8CO6t5fMjJyFxuHv/D1z6VUsNai0tLhrWPyt7szRpLhZcjq2 ASCeRgA/4fBumnzRXfVW6o+t+KCa1Oa1Txfo2A17paiU5UTxkKePlOSMEnrxtOPyrz+3g0G8uJ2t zHseQN5bj5sdeCMYHJ4PbNd1GNelFtu6/E5qkbOxbbRtRX7QLS9kRWYGNlYOuDklSOg7/hXGa9ZX jSRRX2nQT7CWZof3ch4YYIyCQMg9eqj1rtw9eEpJp2l+G3VGUo9jxLxP5EdrObe/ngJyPLuVyqjk nB7du35YxXb/AAm0Vr74T2s/DymO4Yt8p582Ruf5flX0tGXLh17tveWq2ejPCxi/ext2Z71pXhww 21sVC8qGOeOemfy4/OujbQ0e0u4XPJiOORwSMjA+vrg9+MVk6i3OaySK+k6Tawp4jEUasfPkDjAP l/ulx0J7YOa7bTFtFsoAWV22heeFzjnHtgd/r71Mm22/MTvfU0b3VtNt7RkEgMwQgIcckH3/AAFc /r19pcPgjXoVnj81reQqu8cd/XnHr/Tiro86nDTqiN9bHn1p4m0yPw344jMMkLv4N8OogRGO4/2J bb2JA/iOW555P0rY+F0+jaDHqselWzmO40nw7PKB8wWSXSLOaY9hkyzSN2PPJr0a3P7GtHzj+UDJ Wbiez2niCZXsUt0ckJIxBKjgkccH1AHOO/Wtr/hJL7/nxf8ANf8AGvJlOcXpJL7zRykno0j45h0j T1hjukswZ0UKwxjgDAzgf1rNufDGlXW6ZLJFckjPl4PGSOnrjA7c4r6Pma1MnZ9Dy/XdCtpr7Ult kjH2aZUkUpwVYA8ZGQOv/wCvNcpB4U0zUdVmiu9JtpF+bzCbZMk4wD067iOc04OT1Ta+fzI3R0Sf C3wiws3Hg6xKOAzA26An5R1IXoSc/wCFS6p8OfC0drZ2sfh6OOwaVVeOLKry2DwuPXJ57txxTlOW 17lx7mddfC74dN80nh+NTjlvtMwUZHrv4HfPGK86Phz4F28d3LeCSGCGYxXN1B9seGGU/dVpQrJu wQcZ7VEK2Ib5Ya/Jf8Ap2tzM1IfDf7PE9m01n8QUjnGTzeIh49BIuc8D/Ir1rR/2fvBGt6Y2saH4 vv7nS9zLBcWuoQyxvjIPzLGVJBBBwR07HrFWrWhG9aj96f5lRlF6J6jNU/Z80DS4Le8u9b1NreKV HmWWVDiPcN2Nv/Ascdq9G+IXwi1bUri08PW/i6awfRNSvrCFrezVDJbyXMjjOD+9dHLrk4ypjAHD E5TqwdOnKdNNXenol5dmaq6k4xbOesfgR42hd7Y/EZigjKt5sBjww+XOftDlh3+RR3/DpNZ+F/j+ Hw5pXhvw38S2eKGd7u/upLQH7XO6qsaoGwRDGisE3fMWllY43BVwk8BU5V7Cyvd2/rvb7iozrwT/ AHlyXwP4K+LttB4p8G6740sjp+q2afY5rgCKOy1KBw1rNIQuCpVri2bLhEW7aVifKANXwp8JPjzc +MU0TxPqcNn4fsXa41yeO1eOawtYTmYKJgq+eRiOJHHzSNGpI3ZqXh8t5pztJJK6+Wlvy+81VfEa Xaa6mN4s8TftI654n1zXLLwmLeG4uT9mtYbuCNLW2XKxRAm4BxHGsaA7egzx351vGv7TlsBKdGJj ITprLZOSCCQrHjp1/HiiGW4BpJYhp27GbxNTaVJWMy4/aA/aC02KcXOkzFwOWS4EinOf4nBBx1/A 81t+Dv2jPj74n8Q6f4c+yQ2VxcswWe6t4WRNoLc7ATzjH4+lbSyylClOqq7aim9Oy1YU8T7SpCn7 NJvTqe/DxZ+0lpkjB7/w1cQ7yMy/aEOOuSEjOOvbn+dMPxZ/aJtQB/wjWgXDkbdkV5Ov45baOcd/ Xn28WFfL6l/384vzin+R6UsJiVtGL+dv0Hab+0T8eLC4WS/+FVrJHtYHZq8SKMqQf49xHfjuMdwK +wf2ZdG/ar/ai8Z2Pgn4Q/BO/wBW8RTOqvFp9zJOLONmWPzrhxEIreEM6hpZGRFBG5hya+oyLIZZ 1ilSwmJXLHWc3FqMIreUn0SX+SOepCtTTlOm0lu7rQ/rv/ZF/wCCbv7Rnw68OWVx+1j+11r+k6G7 I48B+CPEV6ysWWBhHdXTERgnbJBJFBCwIVGS5Fftb8Nvg98HfghpMtt8OPA9jpPmoBc3KoZLy8AL MPtF1KWnnI3NgySNjJxX3OJ9hhKEcFlifsXo6kladW3V9Y0/5Ydd5XdlHx62PjVc4U3ot7d/M+S/ jX+3b4K8AaDq/iaC+ik0aKQ2+n4fjUpgSN4OD+7JB2sAcqN/IIx+afiT/gtf4h8OG8t9B8N6NdXT MArXcM5WEDOSAkqk9urEdPevRxWU0sDQo0sRf2k1zO3T+ndfI+RoZjWxeMrVafwQfKvNrf8AQ/PD 9oL/AIKn/Fj4oIlpr/iWRrKMl47YFLeBTncuY4QqsR2Zgzcfer85vHH7YHirWzKbnXTuPTgnaB6H muadSNKmqdNWj0RvySqzdSo9WfMfib40ajqskryak7sQcbieew4HXmvh/wAZ+Io7PUdT/wBKUEMX wV6A4I7Zz9M89K4Jzk72/rfodUIWaS2Pa/2NJhr/AMQNY1qC5MiW9usTKMkYkbzBk4H/ADwH6n0r 9Y/2etKTxX+3H8H/AApd2sc0Ok+G9X1xw65SRJZILMnbjBGN4B9Wxjk1+k2+r+Gzl1qOT/8AJrfo fPJqrxdGP8kf/bW/zZ/Q9e2rSSRHPyAH04IA6V4z47vNK8MfDj4jeM7y123FjZ312Bv5ZoEdY+nT d5a/ga/FJuXI1Hc+4aTep/Nr8M5Lzxf4J8HXfkedL4huJNblRizEXGoSfbJCDnOT5p4OR1AA7WPi T8LdT0aaK6a2aJAoYsVHDDPHP8PXPTjkHmvqeL2sPVyzD7WpX+92/Q8nKvf+tTv9to8S1XwK08S3 V1DlnYhSRwzYGcEY4yO3Xgg46+heGvBtiYbN5bJQwAbAXG5uMZ49O4zXzFeTnho1Y9ND0Ye7UlD5 nuFv4Esr2OJbcL5ojC7XPDdvb/IrBn0K70CYRxKfsx4YKPu57D1/z6V5UZc+j3Nupl3unxaihS2T YgOUUxkkntk/px39q5m80OeCZQYp4pjgqwO5X/xH+NKVPT3vQpSsGl3MlvcPDcPKl2B8shXAcY6g 4+YcEYPOfwrudJ1hllBLqCP+WsfAbOeCMcf/AF65KtD+XodFOr0exwHif9m/wR4i8Q6H8QfBco8L /EOwVI7bUdLt0FrcRx7QIrm1G1JUCfu/laJwCvzEIgHCfHn4PvJ4cv8AW9VtILXRb0i51uS3jkuI dD1Hy1iGrxKF87yiqQwXqpGzPbxRTCGWWxiR+ihiXUqwhW+K3Lf+btfz6eaZfLFNzjsz8qtdsvEP gbxLqHhXXdPaDWbG4MUy+cssZdeux42ZJEPBR0ZlZTuUkHNXNO1HVrhso7HcScpn5ScncMfy/wAa 6PYpTs0c0uaOh3FnpesXiBZ4/MVmAxtDY9T0+nHtUmseEbhLGaWOwXcf3YypAAJP4Y55+tdVLDSf urqRz20PXLvVJTo2g6YiWJitLC10+NIbNoyq20IgRnbYPNZwC+75iTKxOCSK83vdVuPD8t22kpeR TXKbZBCT5bjekgJAwOHjRsA8FQcZUYzjlWLqc1qUmt3o/wADp9tornyB8VPE8usxtpFq5ys29/K3 bEIBJHzFjlmYlsNjOPoPsH/gnP4d0fWbL40jXNIiuZoZNHMMlxEG8kuL8EqTyvA5xzXLnNKrg8uv FNSU6fr8cTTBWqV5Jr7M/wD0ln3pp3hLwtb3lz4v0B2URSSQERsDG2x5oH2n+Ib4+GBIIAIJyK/I P9ofw18SNW+Mnit9I8JX99vW0aR7KwlmXcbaEvgoDj5iR1OMY7V4uD/2jiHG1Kvu+6l2/lf6noVV KGU4dR1f/DnD6T8LfjxFcrcad8NPEMEygN5kWnXkRQEgZ34AHO3nPXaPSvZdC+Ff7WEyq8OgXrW7 HfnUbuzJfJxjNxJu7HoR0NehisJllXWtOLfdb/ejHD4rGUpXjdL8PuPU9I+DP7SWtmOHWPCGmwRY A3nVIYsgLyT5csgyfpn0yeK8S8YeK7Twv4t1/wAJa3aPDqumXkljcmJ/Nj82FyjlXwpYZUkHaueu K8n+y6aUng6vMl0a118z0o5mnaNePzX+Rp6D8RkhkKWevAxAny1kZUDcEdJOnr+HHJrYvvFB1WVJ LiIPLlnEqF42AJ4XkFemB0HT2rzZ4H2dRz5eVnYq1KorwdznNYGn6lBNbm5O6WNyiOmSTjP+0vbp 1Oce1afwW+3D4caPYw3TR27/AGgOqBfnBmkz1BP5fyxXp4a7wrU1b3l+TPEx0l7eKXb8z2+ygvwi odWnIGF+VkKrjjHyqOmM5OT2PpVuC1ludTubSfUp/ISGIrsnKn5i4P8AIDp0q/d19zU5fXcueGtK tGvfEizBpEjvBlXlZg37uMnOSc9euc4xXokejaY0ak2kPm9QOMjA6ZPc4/X8plN8ztoKz6/1oQX2 lW8ax+VbjeeCTH90L2H5Z/E1H4oM0fgLXo1P74Wcwzt5BCnH07fmfwdK0qlO/f8AUjVnzR4fvTfe DPiNfKmRF4a0aH5RwTHo9spx1x0I6+p9K9G+C0q3mj65d+WPLGn6HArHDB2XR9PDfjkj8ewr0MQ2 qddpbOP5QMlq46dz2pPNWTT4+RiABhj/AGiTnitLC+o/OvLd+lvmW2uv5XPl671zWtJn06xvtMQX t0SkWJgFzsck9O4X0HSrEuhfEq4CtZ+CrmXJ3IYBkMCeOQB3yccf1r6OlSc/h6GPS9jIsPhH8btU 1PU72y+HWosZ4lA3GJBuXcX3CR19P0/Cuz0H9mz46trkurf8ISwtblBGI2vbINuJHIHm9OCO/wBO ldsMHKyu0LS2rPpr4ffsHftE/Ey8lttBs9KgvEUyG3ub9AwUADqgK89QM8YIOARXda1/wSr/AGwp Ipo7LRNCmdXSXA1u3iyA+eDKUBJHPfrjiufELC0JqnWm099E36G0KbmuZSPH/HX/AASo/bl13SCl j4C0pmSZpvLXxPpQeZQpBHM4GTwQCRnA79fiDxn/AMEmP29tNs/E2uH4NXH9lqUleC31nTJmuFC7 nbZFcnO0qOCM8jA4OJw1XA0pSm6yt5prqvLpuVOjL2NrrRn5aLEQyJ059uPx/Gv1D/ZD8SLa/C2+ srh1xBqdwoRg3IZIT16feY8Ad88da3zVt4NuPdHPh/4lr9D6V8UeINCufC+pwfaYjOIHBT5RsyMZ wcnPB+vpXo3xL1bSZfEXxBl8+FC2t3cgjW5X5MXMjbQD12gY6kYxjPf53mm6UVy7Sdv/ACX/ACOx Rd72KcGqaRJILhb+1ZXBJxKgyeOODjBI/wA9TLNLZt5ctvKmWKiT5wQQcAYPY/j2qW1bVDad7p6E NxDaXWpWYW5AV4X3KpB+b5QDnjPG7/PFdmNV16fR7Pw/qfiG7m0G3PmW1jLeSvbxYXgiNjtGF3AE DjJHc1DcZRSl02uSlZ26M57VLQypMsUIExIxg8dMdxxXn9np23S4DPguse0nAyuM9+oH0PWrhN7D fdM8i8S6PGbtYpASSGkJ28YBywOAepIXHpmuQ8CCNvit4ft1yUO87cj7whmPY+mP8816EpKWFqr+ 5L8iaKSxNNruvzPvu98JjVLoop2sMkMSMnOBznnHHFbvw2/Z0+JHxi8a6Z8P/hz4Q1DW/E95mO00 /SbN5ric8FmIQE7FUMzORtVQWZgFJHzGRZVi86xsMFhY6y1beijFauUm9FGKu23ZJas+vlJRi+Z6 H9C37Mv/AAQQ8E+ARp/xE/b4+IaW0KeXeReAPDl3G93MAYXKX9+mUjQ7Zomitskqyul2jArX6oaT +1x+zB+zd4ZsPhJ+zp4Q0Tw74QiKpHp3hyGNGu5lSKHzLi4+/d3DqkYaZi8rlfndjzX9CZXlWFwm XU8HhrrDNpdp4mr/ADNb+zi/gi9vilq7H5jxDxHVxWKllmWPVazl0gu7830XTc+jPgp8Rrz4neKr zV7sA6Roqo0q/KVe+kAZI85P+rXEjDg5eEgkEiuU/be/aLm8GfDdPDOiapJF4n8TXv8AYVpLCWDQ QbGkvpgw+4Vt1kRWyMSzQ45NdmNy5VuIsNlMI3SlCD/7eacvwdvkeDl9b6vk1TGybfMpz17dPvSv 8z+PP/gpD+2lqWhfEvwx8ONGy3h7SbINMkUihVuJCERRjhSiKevGJF9q+OLL4w6Z4jS2/szUi9yw HmozHzOgJ+XqeuPTP50uLcT7TP8AEqC92m1Bf9urX8bmXD1H2eU0Zy3neT+bb/Kxm6ve+INZkZbC 3kaNl+QLwV6jn8SRWv4X+B3xr8canBpnhn4c6rqd9LHJKkVjZT3MrRxjc7hYlZtqqMs2MAcnFeRg svr5hVjSp25n3aSXq20rW1b6HswlGO56rf8A7E/7ROipptz4w+FWsaNDqCiXTW1jT7i0W9TAwYTO qrIDkYwTnIryvx9+yx46s0mt/EXhOaC4UMocQEFc+54bnHBrvzHhzF4Dl9o1K60cWpRfR2lFtOzT Ts9Ho9SnVipcrex037Fvwj8ReFvFfxPgvbPFrttPszmNVLcXIIJwORu7/wB49e36cfsh+F5bH/go V4c1CbO1vh1d2y/LwR9tkdhnvyiHHH3Rweo+vzOnKl4cUo2+FfnJnzeFafF82+q/9sR++93bGOMu R7cV8YftdLqkn7PHxGGlwI0Nzay290xkC+WrsVJHTJLlB6cmvxDku9dtD7ub6H4bfsd2MMsP7Mdn bRyrDd6VodvIhmOZne0hBXIGcF+QCMj5e65r9mPi/wDs1t4t8Lasmn2SyXaBo4WWRVUsVJB3cqoz wc9wwJGa9fxGqypZhlsn1oL0+KR53D8eaji1/wBPJfkj8nvGXwyOl6i+kwaduuzMIoyAkfmsgWQy ImxG8towmzdzIzKAWJwMXT7TRLS4W3ugEtym5HVRgnADcHk7cEZ9V7c189hJSxFCVNfI760VTqKT Wxdu9Yg025jSEyMgYrvRmHHBwf09qfqHia3lQxPECNoYE84GO/v938xUPBVE72J9vFvQ8p1h71Dc NCzBcgqOhG7nPbHU+lYlvq2olTbX9wotPukln4H+zg59+w49q0lhVKN+oKs+ZJbHXReFNQ1C2iu7 fW4HtfLLrFIx3R8Hbk5J/D0FSW/hW4tnKJPEHIBXFxuB9yOoz+HDcCvNbipcslqdJuW1le2Uotbx Gjl2kRyK+7ePzIcc49a72zhAgK3YP2abCkgrJBKCACpwOOCcqfUAisatNNq25pCbWp4F8Vf2IfC/ xm1TwFH4e8V2PhWeGSHTbq+vrW5ntotPaVAGdIRJO0dtGZPLSNXxEkVvGI4oYo0/YH4Ef8Gxfgrx b4S0fxoP23NN1nQr9DLFcaF4NMtvNtYqwWVtRUhlZSrKyblYMrAFTX1fD+KyW7nm2HnVqRa92M1B Nd3Jxm/Kyj8yqri18P8Aw5+g/gT/AINxf2UPD1vaJ4r+JfibVLlCd8lpDZ2QfOeAHWcgdO5PHWvo LRv+CDX/AAT+0y/s7y/8MeINSgi62t7rCCGbgj5/Ihjfv2cdBX2seLMJhG/7LyTD01aydRTqzXZ3 cowbX/Xuz6q2hztXSPZrf/gjr/wTes4kX/hmPT5gh3KJtX1d8nrj5rrB+h4pvjb/AIJdf8E99D8L farf9kPwjdmw8qeKG9tZrhJjC0TgTCWRvOB8lQ4k3Bw0gYMJHDVT454mrzjQWKjCMnZ8lGhDfTeN NP07GdV8kHNbo/nS/aA+CHwI0jX9Q0qP9kn4Z2cUM7Rpc23gLRxNuVYBlS8LRg74XkxtwDeTKAEW FIvjDTvhL4Q8KWF9deEvBmhaQl7L5FwllpOnw7lWJ0QmNIsjCzylWGMOVdTuRWX5biWtisRUnDEz cl/e622dtr38jfCVI3Um9fL8Tx7xB4Y+yvJNCxCZBOONo5OenGT7f0rzLUbK8RyZJC2FCnJJ24BX r2GAAK/KsbTn7eUkz6OnyciUYnKayskV7Myw4j3YIBb5Cc+vP51bsLiQ7fM6quRjOSB1/wD1/wCN RT5tmZ1EuU6u3nit7O7vrh9tvHEZGfbn5Rgknn69Pb3r5R1T9jv4OeJtY1HxLrXiTxPda3f3El5c ut7aIGnkLsxx9mJILNu9Tg85OR6eGxUsPGTjFPm736fccFSmpvfY67Rv2Pv2erfbHN4e1C6jEuWF 5qshZkBJ2loRGD8pUE4HIzx0Hzn+2t8JfAHw0i+HehfB3w4NH12WK7vdXnm1W4kS8t3eOK2KpLK5 Xa8V3krgHcB/DXXh67xFVwrpOLTei+7fzIcnSTcNGfHWlaN4ihltv7Z1lZLdTvKw27EKVIJAbOT0 Pb0HtXtXhL7JoOnQaXYXcj6cjM67raTI8x2YgsFx1c9ugFZ1acFFwow92/f+u5nKrOpJSm7tHqdr r9rLHGkMd3LK6KxVIce2fmIwB2/+tWzpss8uqz3j6ZOlqYI4zvEYJ2liScMcj5u/f8645Q5U22tS 77JGt4cvVkk8SoYTsGoEtllwB5ac5BI6e3XHWvUtLt5rq2in+xnYVUqC5ORz1JAwMf0xWE+ZSauJ 3uXXsLu4ngUxRBdpPc4wVB6jnqPzrlPHun3zeBvFIDIEW2nwFQnOEJ69B0/z2dC3tYW7oVtD5Y+E 1nNqfwr+MWo+a6CLR7aIAIwDeXpUA5+gUduc16P+yzam/wDBPiXUDO+5biytyi8hvK02yHceh6Dn jvivUxT/AHWJ/wAa/wDbTCO8EvM+kIIBJqMMd1532ZgSXBwOc+n+etdJ/ZGgf8/c3/fxq8ad7rY3 TSVrH5x/Fm8v7fXvDM8d7IrpdAKqMAApRweO35d/Wv1d8EiOTRNHnuZMTSWtuWyoHJjHQdvbHrX3 eF5FSul1OK+mrPZ/DUib0heZSxJXscDBAzXXaZrOiRR2yXF9CGVyqq0igqQQB1PHLV0urCGjkTZv Y+wf2W/G3hXTviRb2N34isYluIJYPnvI1G/spJbqemM96/Sy8m0i5haeHWLRoMgEx3ULAk9Dwx6/ 0r5rOqtNYmLb05V+bPQw38NLzM99IiuLZZYZVb5icBx90AHOB2I5zn1qK38PW1xeQW9xGpiaZUk6 Mu0kAnjgjBzwSO/cV4dStT9nNcyvZm00uV2fQ/y+ruF4by5tpMh1lZSPQg47e/pX6Y/sRzJc+AvF NjnLx6mZW5yBviiUZ7D/AFXXivq8xaeXtvy/NHnYf+ImfSPiAT6f4kuYLdd4v9Lk3RquWYoyKSMA 8bXA6dj68ev6ULnUdL8O6xIX+032m2d++Wzl7iCOck8c5Ln17Zr5pWeHUvP/ADO67ujoILQRzBXC nuBgc9MnJ4/z3zWPo+n2F/qHiO1uNPjdUvQoLqhG3y4yeoyBuBPsSfxUHJO39boOrRrjwlojrKja bA0bA5LxofyzkZ/D/Cs240DTtPSaS00mFYWQhtqIgXjGeASMDA6dOCeK0cpW3Fvo3ua48MWLpKzW ab85yUO76E9SOn5dKzJfA+kRWYX7IrPg52s65PI42kY7+n5UQbSvf8gafL5Hz1rHgzT5NT1eMRTp FvQRgzTKwUcH5t2cFgxGT0Irkvhd4A1TVPi94O07w9pN3eatdaj9htba3Es0tzJMGiRFRcl3YuFV QCSTgV7WXYPE5nJ4TC0+apNNJJdWrf12M4WVam33X5n9gP7If/BED4meO0s/iN+1DrEngT4ciJZT pbGI63dx7Y3BZHBjsAd7AmfdKrxFWt8MGr7l+Of7a/7Gf/BL7wLcfDL9nXwfp1h4ovUj837KUl1b Vz5j7Jrq4l3SmNWkmKPMSFG9IIwF2j7bh7JsvyfA1IVpXpQs69Rb1JLWNGm+sbpbfE1zbKLOfiLO KtWUcuyzWpPRdvOT/ux/Fn8un7V//BT/APaA+P8ArF6H8VSaf4XmuSqafaSkIxyMPPKTuuG4B+di oIyqqaX9hLxjf/EX4v6j4o8SawJdD8NWh1KeS5l8yNZRlIcs/wB0Bg0mQAAYe9fU8JYqrn/FmFlX VqcLyjFbRhCLkl+Cu+p8nmuCpZRkeJVDWbi+aT+KU5+7dv1en3I/tL/ZX0a48F/ALwVLrERj1/Ur Q+INSWQszpcXpNwYmYgFhEriBcgYWFBgYr86P26PG7a38cNJ0jds07w54ZSROcBbrUJWkuFcdMiK zsSCRx5jetevw63juNli3r79Sf3KVvzRw51bCZBUw60tGMfyifzseMPiJ/wTp8a6v47X456N45X4 gtrLW51fw82mX1rfQRtJCSLa5ktnhcLHAVfzJlILZCkCvAZvhr+wfr2ta1deBvj1rHh7RYVd4I/E uiOLiYhFbaDp0t5GrO5ZFz8vybmK7hj57H5lhsRja8q1NXc5O63erto9PV3+R6WEpzo4WjSik0ox X3JF9/A/gPwbYale+Ef2uvB2s6lB5ZsLFJ9SjN5H8zPg3djDGhRVwUkeN8sNiOeK+p/2fP2pP2hv gfd23ij4V/GDws2px2++4OleLINOle3jKyOksV08XmIdqkxsGVthyPlrnhWwdpKEmltZq6ffuaOE 0+ZJp9D9e/h3/wAF8PiUtqvgD9o74I6D4qsJFVL9XltImuo5ANvmeXvt8cg/8e+DnA9a+xLD4mf8 E0/jxJDpviOw1f4b+PdmdQ8PpH9vtLWZuBA0MSTG2YYI8kR2jjB3IAVLdeX1sThZuhljVSE7t0Zt uLstZRd1ytae9ddE21o9alalUp82MXLb7S/Jo88/aC/ZD+F/wi+F/ij4j+B/GHhrU7N2sktodFHk zJvL7nuIZGknjyWHEksm05UKnQ/D37O1pp1v+1T8PfEBwssmm3enAgjgMJHC+wJIHftX1mOx1DMO Aq7w0WoKW0mm0003qrJq7dmkrrotj56lReH4ohzNNtfg1p+SP2hv7GOW3kGOfb6cV8t/GDw+vif4 K/EjQ57cgNHcEqereTOWGPxjB/Kvxh2UVfuj7afx38mfgl+yHpJstd/Z40zXrhbJtG8V6Tpt1M7Z WO3tNQjtjLwDlfLhZs+m3A71/bb4I+AWjav4Ys5b7JjuYF3oyhWQ9GBAA2sOQVGACMcdT3+IdCWL xGUShs6L19Gn+pxcPzVOONX/AE8f9fgfkn/wUS/YtsfBf9sePNDDSabdWd35vkW8YmQXLQwXG1Y8 A8SJtDbEB2jI+8PwH8XaNJpuparqOrqIJzIbqCOJg6bJPLdV8vcPIKxvE5Q4O8yFuWxXxuAlUoVZ UZPWLsexiIxmr20Z51Pq+ijy3nuThmyiswJUclRlfvc8ADOO/U1xmua3AL+b7Lh7kAsYyx3Y2KTg gAEcjAzng57Z9mVao3q9jz/ZxSsjktV8SaxYLb2j6ZLCLiBJoVlV9skci+arg8YQqeGJwcqRmpNO 03V9SDRpauZAFkdepA6HIAyOSpweecY5FEp8vLruVGDe56xoHh3XZL9IvPX7xVo1YksN3QZ7jIPT t0GK+yfCfwOvfFlqJJNAnmmkjJOItrg4ALYAAxknGDjrxXM8JiasvaU6TfnZnQnCOkpJEur/ALJ/ ja1mddNsb1gq/caPIQ4HQ9M8dOn07cfdfBj4s6FcFY/Cd49q+CCsBAkUckshznGD+WO1d8eH8yxE VKNBmcsVho6OqvvO30TwL4tsHRdV8JXcOQp+aJmT2bPJXjjqevPev0J/Zf8AjP8AFD9nfWY9R8H6 vJFpM7ltS0e93NY6jlVXdJFxskGExMm1xs25KFkblnl2OwFRSqUmmmaU69Kp8M015M/ol+Bn7RHg X456LbzaNcraeLEt1mv9GmlDTWp4VyjYXz4gxAEigcMm9UZtg98r04vmSZbEIyCKoapp8OqWFzYX H+qlQoce9XCThJTXR3JnFSi4vqfz+/t0/s/P4dvNYv3Rvskm6VZQP4Tkmvwe+IHmWunpJA8Bs21K 8aNYUt98fywAb3BM5U7QQknyLyyHc8wHqZ1GFeEasVpNX/A58HNwfK90zx/XVB3W08e1gvB5Ixk9 zjPA6V5ZqdvF50n7s+WSqgAck5zkZHWvzTG0HGtKMlrofS0qqdJW2f8AkzlNX02Ka6vjBseNpHVf LLbCB6b8Njr97Brm4tOuLVk3Kx3EA84A9f8APOa4atO07LTsaX5ki3qk1laaDqPmiSZLkxWLr5Xy 7rljAMkHoGZDjHPzdl5tQ2TRsoB+bpgfpVKPup9TnluzodM+0iaMgfdZcnA4HT+vp6V8X/tSalc6 /wDEJIri7E9taWEUMABULbozSSsgUDCYkkkO0cAsRXTQvGUn5fm0c1RJRPBNLskhUK8Sq/yl1AGe eTz6dfy+tddbWVmtlcmZB5OCc5A7dycdx1/yVKV9jJJaG3Y6cz2NtdIMZjU7Tg9unHX6jt9K6q20 +UQR5gG7GOMkn5geuehz1xXLJp2NE+4/SNL06O21Ca0kk89mne6EsQA80SOo2H+JfLEZycEMXGMD J9T02NbXRLEShY4xAjHDA4O3p0wMc+3FZSlebT7sbtzbf1YbDfwSzNO86gKCPvDAzjJ/Tn8K4v4j 69pv/CA+LrWK7SZTYTjEZ3DlD3X/AHhxkdR07VQV60Fbr+ommz5N+AGp2sXwJ+OfmzbLlrWVNmxi cf2bCFOccjrjnt19en/Y+vIW8F+KbS6usAalE2EhlbB+xWaj7oxzjGOv5ivWxV/ZYq2yqL8kc0N4 fM+zrwWV5/Zi2jXUhIyFitnGct1w2Mj8+meam/sif/n11H/wDNeI0tLpfP8A4Y2krvQ/NLx54CvZ 7iw1J/EFyzw8o0ix5GDxwqj6/TFeR+INb8e2v2OG68eaoLFG8oRR3c0IXggfcZeBj8MmvtVK2HbS 2/rqckEnUUWtGw8Oa4UvG+16jf3Vx97fPe3EwTnGQJHIB6HI54Havozwh4FtPHl/D4dtNXm+x6mr G8EUhCptR9m5CCCQecEe/HWvm8xxdam3Xk7qKv8AdqtvQ+kwdGjKm6aW561B+xb4GkYs6pCCSSUC CQnA54Ubcc/d5/mfSPCn7F3gLUr6cy6xqkNtDEGdLO/kiRgXC/MFIwvPGCK+djxVi6lT2dk1rvqd s8tw8Yc0E0/U5bxJ+yR4PGpXWnNqmupaxXEse1tXlw0W/wCQ4bdlSoB+XOQRjsa1tH/ZO+E9vcRQ 6hqepG9dvKjxfP5Ku3yAMseA4OcEY53Hsa45cTZjKDSjDe2kdbP8DT+zsL7KTu+Zrvpc/AyeIpcS wyKN6uQecjIPOCD+tfev7G9zriWnjeLSby2hXzLNn+0W7zbv+PgfLtkTH3eeucL0r9Rx9pYCd9rL 80fGUdKq+Z9pDTfEc+qxa6dYsTffZJLZR/ZcqxqGKscjzi3JQYIbiu31DVPE0Wm+HLjT9R0yHTbX w7pELLcI5KyRadbJL8wkA5kRzg9BxzjNfMP2fsuVtqzXbz8jt23ZN4V8Ra94ktludE8XeHppPLEk kUCNO6NwGXK3AwQ2ASR+A612fh3Sdb0u/wBWubm+tJZLhlkxDC6bcdcbmJyR7n64qeWCbWt9lf8A y3JTvsdXM2qhInYQn94qEgHndgdSc98446Hn1Zd6fq9yn2Xz4Qj5VWAY+meuPr19fSlrsy35amwI dXSN45BA5Kgk/N8xI547ccde455qva23ijxBM+ieH/DpudWkuPsltbRpLI13cSEeWiLGpZizMMKo LEkAA13YLAYrH14YXCwcpyeiSB3WjR+pv7Jv/BCP9rX9oLVNN8RfFHSl+Gvwv8tUe78QW0h1OZE8 5FEGlkpPuDJGG+0tagpIJI2f7p/qC/Zv/YO/Yc/4JteFrrxd8PvA0c3jpFcXHi/XjFfa5du/mDy4 ZSiR2oZJDGY7aOBGVQZNxBev0nA4ZZVR/szLpc+JrWhUmtdH/wAuoNfZf25L4vhXuX5vOxWIhShK Tlolqz8cP+ClX/BY+50yz13wF8H9YtpPFIR4xdIBPZ6LLhlGAeLudeSSR5aEAEMd6D+Lz4rfEL4s eOfFF94j8T3Goajrl5Obi5vJp3uJLqQ4y7McnJOMZxhcAAYxWGY1VUnHLcM70aWn+Of2pfovJHn4 GNnLGVlac9vKPRfq/M4+x0D4o+Or6w0nSfD+oXkq7YYYo7SSV+pJIZV9cnPXB4r+gz9hn9lHx/8A Cv4W6h4f+MPgi40fxD481Sw02K11CF4JLjSpiltE4H39pkurpR3JU4r9A8PcsrYGti83rRtFUaij 5yt0XlG7Z5nEk/aYGnQT1nVpL5c6f42P7LXvo/KmiC4WJo4doBH8Ktj6fMK/nl/am8SLqXxt/aQ1 m5ux5TaqlsgJIWNLXTrO1Iz/AL0DuemS/HNa8Arnz6pPtRqP/wBJPI4snbKrLrOKf3v/ACP4v5fE GirfSXV9oxkkkkYu39oN87AEt9zp3OPesw+NPDzRgLoEhbcPu3kpyecYPU9e/fvzX5dX9tKtOSmt W+h9lTdFQjHl6FSTxRo7lyuhTKCTwl2yd/c//W9q7H4cxTeNvEWn+GPCkd1HeyJLcSvdODbW8MEb XFxPK25mCRwxyysVUttUhQxO04xliYSTU1ZF/uGrWP0j/Z50R/FMj6b8KdadLS3lDah40urIRahO xC5/s8tEG0yE7QFfm6cIZN0ImlhX9bPhRD8OPhN4bj0bw/4KtbrU9nlz3l7K0u8lQrbEGAgPzHks xyAzMAAO/Ocxr5Vg/wCzab5cVWSdWXWFN6xprs2vel6266ctDDwxWIVWUf3VN+6v5pdZfLZed30R Y1/4lNZWU9lo3hzTNNtp5lW7msxcCW4RiAVcySsu3cUbAA5ReeMVF4K8b/8ACKfGL4GeJZZjHp8f iS3ttQlHKx288ckfOfWXyFBweW96+44XlPG+HOPjKXNKEprW3RRktvU+azR+x4rwr0Skl/7cj+hR 76RoJFj+9tyuPccV5tPZz61YeJdGvSqPcROig8grIpwcf7278jX5s7Om31R9dNNzjHo7n85E2i32 n+L/AI3eC78iGey8QXcMEaEK9tBIqSIR6ZMrEH/ZP904/vh+C/iPSfHnwu+Hnjzw9j/hHdb0Wz1e wOHG63uoUniYB1VhlHUncoOTX0XFND6zgMixC19ycW//AAD/ACZ5eT/u8Xj6X96L++5yv7R/wz1L 4mfDDxBoOjsP7V8szQZIG5kG5VGVbklV7fn0P8bP7UPw/wBW8KfEG58NWNvJpevwpbQ6vepam6tt OF06NbSR/ZUZvMzO4UwFiUhjCqzqyr+eVaEqGMbf2tfWx9C/epryPzevIb+6u7G6tIBO4tpFCvAz yOY8hyUII3eYhZd3OVY5ztrVi+Hmo3cFjPKwRmijKrKWxgDhSoxjBJ/4FzjAzXv4DLMbmNT2eHhf z6L1bPMxGJoYaDqVpW/NnaaT8L45oEs7vUlypMsrx24LKqqo37iMD7oO7AAAwc5zWefjL+y/8N5Y 7fW/HVrqmoTRyKILD7RqQndTjy3Fv5kcb7sAB9mcL+P3OE4fy3KaXPmU1Or0XReSW7f4HjTzDGYy fssDBqPfr9+y/M+hPh38ZPjJ4/lhh/Z6/Yt8c6ppsiRrLJq6xaNBvJ5kjlMc0cqklmwSpAJBOea/ S34PfAf/AIKL+KLmA6/8J/Bvh3RFKOtvqms3E90jdcpNZ70yB32Lg9DXn5jxFQw9P2dLljJeV+nR L9Trw+VS5+etVbfZb/Nn6jeDf2ZPirqegwweMrfQLLX40CR3Nrq2pXy5UcMyPHAX6kkMxGfXNcbc /wDBN/4o+IvP/wCEj/a51eKGR9wTSPDWi2phXOQqu0LsQOg3En1Jr5alxJjotuU+ZdLJRS+67fzP WeAwrWtO/q2bVn/wS3s40KN+1j8QDL8o3raeGARg56nTC3t1zjvS3X/BM3xjBOs+h/tba7Iq5xDr fhjRLlCOwJtIbVyBxzvzx15rtjxVXelSgmvV/rcz/s7DfZhb0bN3T/2K/wBozwnqNhrHg/4weD/t 1rtaGUeG9Ws5w6gAMZE1OUA8c7VUdgBX6a/CXVfid/YMenfF7+x38RwhUW/0eaYxX3HLPFJEnkNn srOpz/D0OWIzaljZRfJyv0X6f5GtHDuimlJv11PYKKRqfOP7Sngfwz8Qvh14i0DVniGovaSrbOxG UkKnb+Geor+Sr4sfs9eJND0nxRHdaPM0llr1zalvskOA5gtpABIp858o6MEYBF3BkJMkmPUpKdbC xpNap6X7NHNJxjNyj1Pz/wBV0fVNNuxctZ3M8LERx7ctkBd5A4J/2uO2a0tM+GHjrxKJ2s/B2pBo 7gCQNauFhAKkh2ZcJhSC24gDIJwK+bzLKsR7TmlG233Hfh8VGK5XsbkvwQ+IFtf69e+JfDN3Yxw3 0lvcLqK+VNHOxUFHSTDhyJIzgqCd6EdRXJXXwd8W3Nkbmz8N3UkLZk8xYSEZAQpYHABGSBnOMnGa 8KdCnOc4QkuaLd0dkayTV9Fbc88+IngvxF4G8FWV/qenpG1xrMMEisT5sUaFbkEgHC/Nb7R1JzIC B8oPkx8aWa36sYAQCFIDDnjHbr9a5a9F0nGP9bg5xmpPc6yLW2Z4XiQLGwjY87vlKhh09sZ/Lsa+ EPGiHxX8TtfsNPu50eZpr2C3MDEtEGjZgkkgAl2CeLKruKhzx8r4qPu0pS30uc8nzNX6njPxRurv 4f2F3dWs7S6nbwwyNDcQuq7JZHUPmNQrD93KMbtwPJGOvoHwivtL8e3cWieJNNuoPEEEHmzYnMcR YCPcpiY71ZWkwVOeMc9qmrH/AGeOIjvfby01/ETvGfK9T6Vt/BWh2CRRxeayrkKDcPjv1wwH446C qB0G3fxA9htk+wizEuxppdm4MATyQe/05z3rjlZRvoVpqR+EvDml3Gs+L4pNKE0cGouiMTyqlEcj 72c5y3Tqepr2XS/B+gIhEemqYDyEKEgHkfdboPz6VnJPmlfozR9H/WxjN4bsrbxFbW8dnGLJoZGV c5yeGJIzxnOADngEe1VfiisNv8M/HYFtEoOl3KqBGpyfLcZJ9uP89bo614eqE3fqfDP7LaCT9lf9 oaeUJt3X4y4yWP8AZ1rjB6ccnAHc10X7Hzs37P3j77ONssnitdz4O51W104oB9Dkgc9T9a9LE29j im1/y9/RHNDen8z9ANDkaxvSjybjHDsx1Rxng5GRkcD8/Wut/tg/8+yf99D/AArx+Xms35b2/wAz pTs/6/4B+KeoftBfB3VxFDc+KNPFvvHmSJeXuducvtU2AyeuMsufUGvW/BGk/CT4reGr268KeOvC 1ysF35UtvrF29vcJtUMuc2J2qxOVYylTtYbsqwX2lHOKn7ua5IpXbtb5fEy4xy6ivaN8z7fqcP4/ 8HeEvBGl32t6V428IJ4ggieZtLs7yS9maJAQ7KJLJoXIABChs9wRjcMXwN8FfHfi600Px98PPiZc 2dtdWy3EDJGsbRODscKYohkKyYBPIPuM1yYuqsvo82Op88X7rb0vdPpftc68P/tUm8NNxtr0/wCC d/efCn9qCKS5kPxumfIx/pS5cDkDlk+XqelbfhPwl+1/4d1Fbjwz8b7UalIpiUOsLO6OASpVozkH A4x3GK8L63w5G8/qbXmr2/M7vYY+S5Pb38rIvaj4C/bD1fUtSuL74mWsuoDDTbbWGL+EDhVRQMj0 GOueSa7Lwh8Ofjqt7aat4g8W2d7p0BMV3bLM8QIJyy7rcph8kAZcY6ZGAK87FY3h9U5fV6ElK2j1 fo9Tro4fG7VaicfuMJf2SfAFxO1y3wh8OqzO2RNqGvSs33juIi1ZRknqAe2cjoOx034IQ/Dvw9rk vgv4c6Lp2pM0Ukk2mjWG86KM5KEXmpXIzgtyFXG48tgCtv8AWzFTUcPWq3i7J6RStf8Aw3/ExeS4 dJyjC3zPFPjT8Ubn4X+Hri8SAfarixgn095OBcm4jDQMB3GDuIU/wNjPWvzD8SeINQ8UJaaj4p1e 6uLkBj5s/mShEDELHwy+UMluAMfMMAV93kkI1aKxltZWt5aa/wCR8tjYuFeVF/ZbRxtrqXiGwkgb QHeGBVVmNuSBKCQqk55zux1HUD0FfpT+y7+0l46/4TXTfhp8QvtGsTajqR0+O6haa9vRdyOkUKqy swli8wFNqgt+83qzY2t6eMwscTTfKvfV7f5XMqM3GSvsfuHpv7MXxl1610qS28Gyq97IHtopbiJJ ZwjKzAITvXAP8QUc819Y/Bn/AIJiftdfF7Vks9K+GwsbZFPmXd7dw+SmcDkwGVs85+7jrzxXi5fg vrlRwjLbd2e2zO+cowjdvU/Xb4Qf8EEvDWkzabqn7QHxHnnBcFtP0ox24K4O5N58xyP9tWjI4+Xv X7RfBj4Dfsz/ALLmjDRvgh8LtI0ed4xDc38NuJL++AOf9IvJd08wBzgO5C9AAMCvssBTnhKVTD4V WUtHLq12v28lv1uefXxGltkeiaz8QWWJ3V8YHQV/J3/wWM/4KC+I01nUfhf4U117SFru50eIxOyS RQ2rCO/mx1DPOHgVs4Mce5eTX0mV0VQp4rHPelSk1/ilaEfu5m/kfP5hUdWWHwy2qTSforyf4Kx/ NRpp1fx5qZJb/R5JSFJcnIJ9ffIP4+/P7O/si/8ABInW/it4Eg+N3xJ8U6P4Y+CUQ33XinW9Qgs9 OjXzTCWNzMwjIEo8o4ZirkKVBOKMjweAjGWLzCfLThq0tZSeyjFdZPp5Xb0TZ6NRzm+SH9ep9V63 +23/AMEvf+CclqLD9nfwhb/FT4zwL5T63fwmDQ9Pmx8zRq6Ce8KvkHiKNlYMrkitH4b/ALXPxB/b q8dfs5fGbx81vHr154s0u2WG0jWO3t7Wz1sukcaryAEVhySdxJJPU/b8PYj+08RmeKnHljQw1RU4 LaClZO/eUvtS+S0SPn88lyxwMIu969NP5Nv7tND+hee+iR5w21QZuSTwSFAz9cCv5hP2nPEhbWP2 jdTjYBl8T+JYCfvZ8i/u4B/6KHr0rDw8X/CvjJ/9Q8/zgedxh/yLKS/6eR/U/kTtfDtrbJdxzACd WLruZiW69jwDtY8f7Q+tDS6YsCR2samdRiQ7eY8Huc9h/Ovy+s7TaPr4ttXMCebdJu8o8t93aMAc E8V7B8H7+C0ufGcaRsbybw/dJEI1+Z1Vo5JxnGeIEn9c4wetZQfvxvtdfnqW1a9n0P2R/ZjufL0j xndxhRA+rzQgIAADGzAjjjIzyO2fwH1It8WB+cY44GMg9P8A61edxdVVbiLGTg+sfwhFFZTFrLaM Zb2f5sw9UkuLyyubdcmVg21dw5PVfoc/yrP8Z3X2rwDd6nbwyy3+nww65bQWx/eXE9lJHewxgf7U sCr6HJr9O8Mf9o4ZzrAvo72/xQa/9tPk+KP3Ob5diH6f+AyT/U/pU+G/jGDxz4E8FeMLSVXttV0u C/EkeNp82NX4x9T+VbM6CPVI5kQjzEKswOB8uCo/V6/OnHk5os+yetmfhr+1t4ci8B/tj6vfLEU0 /wAXeHYb5SEVY/Psn8iXJ4yz/a0JHcRD0r+rP/gmd8ULL4j/ALHnwjL6jpj6zodrL4ZvLSwmV2sB p8sltZpOoZjFK9lHZzFG2nEyuFCuor6XMpqfCmXYif2KvL98ZL9EeVhPczrE0/54J/c7fqe1/Hv9 rz9nn9my1U/Fz4lWOn6tLCs8Gkxb7rUbiNzKqSLZwB5vKZ4ZE85lWIMhBcYNfyS/tiftZ+Ffj34p 1pfBPgO40vwbcalPfP8A2lLEZr8yR7E8yCEFIjEAvlYmlMbF2Rl3sK4co4axHEGIp4yreGFp3d+s /KPkusvkrvbbMs3p4CDpQ96o+nbzf+R+bGsfHH4c6Fcf2VBrEN3qscjRix01VkKsz/MpEfyRNuJO 1yp/OvUfC/wh/aw+OBWH4d/DWLQdKl3oupeIPMiZQD8rpDsL55zzFLGf72DX1WYZ1l+T0vqGVQV4 7y3iv/kn+B42Ey6tjH9czCbSlsur9F0R9ueAP+CPHgzXpIfEP7UXxa1fxJAZFlk0e1uDp+nMcYK7 Yj5gIOcGFou5wK/Sr4Ifsufsr/B7yNN+Gfww0fT7hYUie9h05Ptd2EztM1y376ZhuPzu7Nz1r81x maY3HTqVbtx6u+/r5eS0PpYQo0IRo0/dXb/gn394d0nQrO2WOx06325ySIUHP4D6V6tpMzpsWMEL jgAYAr5+UpTb53c9GnGMY2ij0WynJCndziurt7sFcZ49qqlKzsFuhpReW2HCfNj1NWg0gP7tUwO5 P/1q6LkWHyXYhVpJZ0QKMkk4A+ted6l8bfhVo7yR6n8UvD1tLGcMtxrFpGVPodzj8vaolWjB6saU pbGHF+1v8CrCRYP+F4+EyN23ZJr9lwT0/jz+uKyPEPx9k1OzSfwF8UPDl7NjIjt9UsRv4wAMiT8y w5/KvXy/MaPMo4mLce+uny0uY16dWMfc0Z8EfFTxj+1nrc2p2XhzX76aa7jlgDaVdrNsEqxxkRPC uUk2xKFaPayl5SpUzSl/lXxv8G/+CkPxAkS0guPHayTXFxPIh1S8tLMLKu1o1QyRxRoQXQxqFQKQ oAAxX2uH/s/ERvRr00vNrt2ev4XPFlLEK6qRf3fqjwnxV+w5/wAFGdXk1S/8Q+NfECGQgub7x1CT c7pY7l1Ytclj+/ghlO7rLGknLKrDyCX9gv8AaD0Ga11Hxj4w05vsz4IufFSNLBD5rTSeWTKFHzPL JglRvdmySTnKvhsByu2Kj8k/8kEazcrOLufLXjT+1fhZ8RY/D2ozCbR5vEOmtHqN/rwu4Yo5ZrZZ YDKkk2yLaCI8Ow2rJmNCqGTp/F/xp+GmneIbjT08RaSNOib/AEeVL6MiaXb8wkXblASGxk/72OSP ybHxeFzeu6Luua6t1u7+Xc+mpWnho83Y8S+MXizRfip4eN3aRabewadqJvbl7ORZRaySiaFdwhZo 4ifNlCBgMr5gXha+P/H19onhSHR2tPDMUwuWlM8yRFzEF8sAbQjkFldiAFzle2Aa6K9d16il5Py2 Tfl3JgnGNjk7T4vX2j4tbnwCh01YZpGu/wDhHgiuMIsZ3vAZT+7f5gwA8xGYEZDV8Q+LH/sL4g+L NQn1S7Op3MFlDLJbNLCs8aWluvzrCqIMyKWKAEZIxjhVxw83apHuurv1XnYJK1rnR/Drwd4N+MHx g+Cnw78TaBeXOna14r0nRp2t5LiGUfa7y2gDF4XSTC7juZWDKuWB4rvJ/C/g34W+NZtd8L+GDHZX 1vcqEhKyTKiSRSr5k0zB3H73ADMf9UAPugC5VKsqNSg7WSXZPd6O3p/VgjFO8nuelW3iGe8txLDp E4BGcO8QyevOG6ZPv0NXLTUNTk1MXf8AZ0aDyAhxOMschu2QR29fpyK89u8bXKWjd2YPg3xTeaY/ j3Uf7NSSKPU5JHxc7Tjy0OMeXg565B/iPHGa9otvEWs3JSUaMgzh18u84AwCRjYOfpxUTdpT10u/ 63LertcZcz6rc6tBdtDBGwjMX+tZgf4uuBnjHGO/WvOPizd6q3wv8fEiIqmlXIyFLFsxuTjkdien pWtC/tad11X5hbokfCn7NWqanF+zF8e7e0EHkGXUvNMkbFjjTbfgNuwBgnHHBznqAO3/AGMrnU2+ FXiiximUWZ8Sl2ygZmdbSxZeTyFyBn378nHo4qF6OLX/AE9X6HJH/l38z7Mg1zWLm5mMN/iLPaJA I889weB6f/WrS+36x/0Hj/36X/4mvGldvRXOnfdn8x1p4PtZzNG0bCRQM5Y9O/QfT8KfP8PtQjiW e0t5GjcHCbuePT/PNfd/WLOzZyezdrot+EvAcuqu/nSEBZdoQKcsM4OfTFfr/wDsxeLfEXh7wj8K 9I066xpkk2s2UsGCUURPFJG2BzuBlY44yDznivluKpwrYVUprRNv58k7fie3k0XGcpLqv/bkc34v /bxGia9r2h3mkXA1Oyu5rGfFlaSjfE5jbDsQSCVOD6Y47VzMv7fulzxSLPpmpK7kO/kWlmmSOSrY bkZHTOMYPFfP0uEMXOlGcZxd11b2aud/9tYWMmpKX3I7v4YftI3XxSvr/SdAiurN1t5Z/MmghGw7 G+aNQWycheOAM556Hr/if8fNE+FusaGfEel6lPJqmnLqVobBEZIw5dArB5FxyitgZ+VxyCDXFWyK v9fhlilFVJJu93bZv9N7HXHH4dYb65ZuCsraX3t3R5/cftk+BtNit5H8Pa6zSQ71YxW5LAnDZH2j 5RuU45PHpXrnww+OCfFLWNI0XSdNu4rS7Mu97uRVdliieclVRm6qjKDu6kemKnF8KYvB4aeLrVou MU3ZXvpr2Io5zhcRVjRhGV3prbr8z4M/bw1K8svH3w50KzeM6PN4Pt4ZYZII5jEYtQuY3MbOrNE/ +iRruRg2wsmdrurfZH7JfwD8E/HPwF4G8J2nwev/ABHbapZXVnI/hXSnl8R6HqFv5BuLq2MMebwi NIJmtblZYWgvpkQ28zpdQ/eZPKtHJsDOjG6b97yTctX2Vz53GQjPMMRF99D15/8Aghv8frzx7qNp 4/8Ain4K8I/Dmye2W11qe8mm1PxLZynzBLBpdqskttcRKVElrqBsWWQEAso81v02/Zf/AGGP2J/2 HtetfHtv4q174jfFeC3mtYdR1SK10rS7YSYUSwWEPnTwyBdyCQ3zZVj+7XdXoYvNMNSoPDYOPtKk lZy2jG+9l9p20vol0v081Llba3Pv23/bRnsbqE6Romn2thGc7YbVfmA6DJ5A/wA9ea+ivD3/AAVA /aM1G20nwR4P1uC0smkS2tobHT7OAhjheGijVmYnJJJJJySa8zL6ONlNUKU2udpPvv0/4BtR5INz q+83rqfsz4A17xHpXhHSo/FOvXF94pmiWbULu4lZ3edgCwyTwq/dAHHGccmuofX5JZFcyEgds96/ TqdClQXJTWi0Xy0PHq1HVm5vqzOv9XP2eaZz8qjp/Sv89/8A4KY6rqOnePPhZ4wuLpru21TRDZxO 0uHl+zyvK0jk/wB83XOevNe9hMPPEcP5vKlG8o+xenbmlf8AQ8bEVeXNsBBdef7+XT9T80Yvi14l t7eG4F75DKWRfs8YfbtII4JVSMn+8e/evTpv2o/HPjDwrpnhXx7448Ran4V0RJbbQdKm1q4azsHu JPMlNtA6tHbBsM0m11LM6nDYOPk/rdWnCVKP9P8ATdn0lOlS5k6jv+C+f/APAfiT458M67rNpc+C U1TT7F1jVtP1WaC7kTaqozrcxww7w7IXAMSlRIULSbS7/wBP3/BIK6bUPDf7IMDSGYy+INQlOHH/ ACxu9Qmz07eUD6YH4V95wHNzwnEMnpbDS/NHzfETi6mWRitPrEPykf1kXkonRs9DMQO2eOa/lM/a Y1SRYf2o1gUb4/GfjmPjJzs1rVFHXjGAOntXZ4dv/hSxl/8AoHn/AOlRPI4wV8BR/wCvkfyZ/Lo+ o20LXcZd7i7lZ41A6c9cEdsEenXpWR5r27zkAKmSW3Hd06c9COK/KqivJs+zjZJLoclq+sJC0DRs XwSSAeG4zxxyeOPrW78PfH9voHi7RtZvNOaXSUmK30EbEGW2ceXMoPzYLRs2Djg4PUc4NNqSW5p/ eZ+h/wAE/ijqXwj1FdFnu5Lnw7cOLm7USbzPG+AmoxZbG2RFV2HBUsVYDA2/qXo1/ea1YQatoatP YSos0bRRbgUblWBweDkcn1rLiXCxlLDZtSXu1orm8pxVnf5W/EMvrP8AeYSo/eg9PNPY7jSNA8Wa tLHDaaFdzTsVAWG1ckbxuXhRnkHI9iCOKj06zvvD0+o+HtVs57TUbK4khkgmUpLARyAykAqQCMg/ SvuvCDEQeKzTAc1+enGVr/ytr/24+Y41h+4wmISvaTX3q/8A7afqn/wTR8UXWt/steH/AAzc3LtL 4P1i/wDB6+YBveLT5fLgduhHmQtFL9HGOK/QKZUdY55OSrgqM9Dyv6Zr5DMqbo47E0mvhnJfiz6n DSVShTqd0n96Pyo/4Kc6FbJp/wAFPibGJv8AiT6/9ivHiViGhvFNpGj4GNiyzpM3tDnHBI+c/Df7 Ynxb+Afw28XeCPhx8S28O+B767k1TUdQtHFvL80KQSMt06rJbDEcLeapikVol2uBuB++4Ty7A55w /WwOYq9KnUU9XZaWav5b38rnzGd4ivgMwp4nDP3pRcdrvXsfnPqn7S3ib4teNL/wp8CvB+reOviL fXAkubxnMNnHLNIytNd3tzjaPM2lppNsTCQsZx1r6c+Hv/BLv9oL40R2+o/tMfG6bTNHnjjnuPDX hYyW1vbIyKxguJGUmQpIuclbiM8mOfnNc/EfEdGnH+zsrjy01o2rK6Wll2j2tq/JHRluV+ztjMc7 1HqovWz7vu/yP11/Z+/Yi+AnwOsrGf4eeBtOk1UIV/tK4AnnweWDTOXkYE5GwsV9hX2jc6vH4Z0x I49KUqAFJRFjTjpxwSB0Ar8vr82IqKHNZ3/rQ+gTaTqyV1YytPt9d8VSreTvtsjjYp+UD6DPFd5p /hiCzuI7qa4KxA5bA6nPoP5UTqwpL2MF5fMmFKU/3lTvc+gvD2qWqxxxQyAhQAOMV6dYaiifxAD3 715E4tSakj04SVrHY2WoFgrb/lIrA8W/G/4bfDq3W48X+L7S0YhWWHeZJ3Utt3LFHudgCDkhSAAS eBUX5XcbV3ofP9/+3h4QupntfCGlzTgbgs90NgbBIBCrk4wM8kH1Fa9p8c/Gfi6xlil1uz062uAW ikhaSKYDHRWOMfXHHPNYVMTNabIuMIvVngnjD4E/FH4i3n23TNbl1NUXIkuNWM8kR+7w0zuT0zjg c/WvKNa/Yq+KdtuvJNCtYbBTlpWiluZZCT3AIUfrjnmtaMVVXuvV9rDbS3Z5nqv7PPxC0NILCDwu qB2IlvLuN4gg9diRsc5I6Rkc4Br8m/2q/wBqvwp8Mdbj+HnhrT7jWvibbqYb5oXFvDBuEUyq7LLM olRJXjZQEMTQeXLDFNFJv3eFs71JWS1b6JdvNiU5Xbsfnn4z/bS/aHvZNTum8TadoPhae4SV9D0j TopYogsVxEqrPeefc423UpZPPKM6wuQWgiMfnfw9+Nv7SXjdtcv7j45+NE0MMltbWy+KtTQF1VlM rEThy4R2jDE52u69OKw9t7KMqlC6Ssk+rfcItuVnuS65pnxEWNZofHGpTXSIY4hqN/LqESK2Q2I7 vzU6ncoIOxiSuCSapaZ+1b8QfhX4ms4vjD4M0rxB4BuZ1R77SdLsNK1G1iWIpGsa2qJbOAxR232+ +Xy2XzkZzIu+FzDEOdlN82ttXZ+TV/xJq0lKOp+ofhbTv2dPHWs/AD4xXN1He/CG/wBXhiv7ojzZ rVo7yyuIk8ja3kXUQhup1co2yS3jbDfKG/HH9mywn8S6T42n8a2kd5fRaqI7X7RawrDHbNHuUQwR qscShmf7iLjaF6RqBhiqqxMJ4iUWruFtdU/ejL8UFG8IRh9+n3H2D4Q8HaX4cs7keH9LjtYLuUNM kTOELKMqShcgYMkuPlHLv17fNP7cWpeIfh/4X+HfiLT7WzuIbuLW41RdSlinspI0tAJfItbhBuEj KwFzHIrBTtUqWzGDiqmJUW97327emv8AkOXuxlfc/H25/aL+K7eYZPGVz9lI2+SZ4SOmDwyg9/wz 24qjq37QHjnVoTJquoNNdDgXbSSmQZwuRtlxkKAgxjA+te19Qw8U5Qgk/wCvU441J3tc/V34beIL vwj/AMFJfh34W0zwgllpUfxp0+LRwiOLd7CLWo1CRFAR5ixqNqEjkjO1SDVPxbq9vrWo6atu3MOn SB9ytu3bIAMZHT5W7/0rwoxvRjVk+bmhBt+t/wBTslpOpFK1nb8TpdIkWS0ijPyMMED3Xvzzxj9D XWWdvDv3LGDIyjcwGCccAfhxnnufx5HytNMzZwPhWPdY/FEFjhNUuSoVc7QIIyRgDjOCD7fgK9fF 3HEkGXiQAZClwNvXBJPXg5//AF0pW55Nd2a3aRMuqojkSX0SOBnlwB7n3/wP0ri/idq1o3wu+JEU 1zAHbRbwqDIpZ28p8BQCMnn81FXQf7+n6r8xt73Pg79mwwx/sv8Ax6Ml0gxcao3ltIA3/IPtRnae eflHTnkdq779iaaIfDjxbAzg3K+JJSyFgGAFrZgMQe3Xtzg+nHpYp/uMU3t7X/I5I3/d6dz7Qs3t LeRppZgvzA4VWY45B4Ucduo7Vs/2rpP/AD9n/v1N/wDE148nDpG502R+Ln7Xfhyy8B/GD4h2Gk2U VlDLfi4t47dBDHFE4WQKqqAFHPAHA9uK+1v2APDfhbxb4P8AHX/CWaBY6nLDd2hga+s4LgxRtE/C GRTtBMWTg4/XP2mVwjVouU1rb8rLf7znlKUYpX6I8X/bd0DQPAHxk+HkfhvSLWw0y+sLxZIbSFIk kkR4yGIRRg4cjua9A/Z+tkl8P+BGSdRFa+MLm3dEUZ2y6cGU4znmQL054zzg18nxPG2DlLzf5yX6 ntZI1KTi9Xr+aPzn+Nel3lj8afivBNGpb+376Qnys53zu45IGQQ35YrEl8JyWOgW+t3zIWlYbNqj amSB6Zzz+HP1r6fCTj9Qw04/ajH/ANJR4dVP21Rdm/zPqP8AZOWGPx7qUMc588acMhlwAHubaP5S 2Ocyq2e6hh3r1P8AaV8HnWNB+Bmu6jqbx2l54YkkSdQrNC0AtwU24GRiYE4wSWI6AV81Us+LMOmt XF/+kTf6HtRv/YM32l/7cjxXwR8IZtQ8XeD9I0q3vdR1a5v0iitXtQ8t0u2UqqxRhmd2ddoAJPQA Zxj9av2bf+Cd3j7wv4k8A+J/ix8RNG8N6db2TR3GktcnU9WjM9hIheK3ts2oUSTcrLdQyLtIK5r0 sZUpYjDVKdfTni1FLVt+8nbyWl2/+AcmHjGhOliN0mn57Jn6IL+xX/wTi0LWtJ8b/FvRbvx94xsb NLa2h1S/ljsbSVbue8MkVramFHV3uWVormS6TaoHOWJ9Q8SftLtonh+T4a/s9+DNJ8JeAXuJbqLR vDWm22m2MEjD97N9mtEjiDsAMsqDOMnOKwwccbWwtLAx93Dw2j31bvLv5duiRjisTCpUnUSs5Hzn da38Qddu5GEs0m3JZyrHJI5Jz94np16HHpR/whPxEm8i71m2eG0k5866UxqT/vNhf1A6+lerHAQp Rc56HkzxVrRj1N7TPB0cfnjUvFOmwEEqJBco+ACM/wCqLn9K/RP9jfwH8NR8Y/DLf8JVbazeafBJ dJBa2swRJCrRq7G4jQ/IWVshTztwR1HvZdCisXQlTWzv+DZzxxNeU3Fx0s9enRLc/cga2kblvNGw DOSegratdRWRWbzPQ19K0rNozuRX+qbbZ1MpB67s8qexHuK/nj/aX/Zs8X/BweIoNd+Hja58DjO8 Wl32n6c+polkxQW8F3aIJZ4pI1by3m2NCVtzO0kYYxx/acD53hclzCpDHRTo1o8jvrZ3TV/LdHzf EOXV8dQhPCytUg+Za277Pv2PzE8Q/svfsr/FyyutR0PQtPELk2sd34dv9sNrMhCttS3cRGQdGDKw GMEV4NrP/BNTwEqzQeE/iFrtmzAhmupoJFyc4wEhQ+3UZBwe5P6bjPDvhPP0sXh5ey5t+Rq1/TY+ UocY51lblhcdSVVp2973ZL1svzT9Tx0/8EoLue/mmPx0iEW07AdCJI5PVvtABPToP8a/Z7/gnJ8O pPgP4z/Zr+Flx4iW61jTNXvJlvI7fy47qO4kvWYDlgSBceWxBJGVJwGFcUOAsPwjlOc4qhivaKrQ lGzST/m6PyOr/WuOe43L8J9WcHGtCV73T3XZd/M/qCn1Axxx7YmffKckDO33r+YT4waBH4g8W/tI +HbzrfePfGIdh8w2Ta7qUiH5QQPkdRjBxyCOMV8T4W06U89xNOr8MqE7/wDgUEetxpJxyym4rVVI /kz86LT9gT4ZW/Fy0104ZnDS3kgKA8HhIk7Hp06Vcm/YW+EUcY/4peCTLlwJNQv89gejdOD6f1r9 EXhzwhG7dNy9W/mfMvjXOptJKKv/AHf+CZkv7CPwSvmMl74JtySuDjU9TPHYHE6+mePeg/sIfA6z lAsvAtruJ5J1HV4iuAMcrcnOcdeMcdaiXAPCUHphfnd/5jjxhn0l71SP/gK/yOgg/ZC+E0Hh0eGW 8LQx6bFO09vELu/doWZWDeXMZxLGrb3LRKwRmO4qSFI7Hw9+zz4Q8MWTaVoEb2mnEEiKO5vnT5sZ 4ec8FuvPbOK558D8MqlLD/Vr0272bur+V9i/9ac3bVT2sVLuo2f4E978FNIuJmBaZo+uReXa47dB J7H65r07wj4fj8K2x062lZ7VVyXeSZzGpYs2XkZmP4sT+WKMq4RyLJMTPFZfTcJyi4/EmtWnt6ru Ti8+zLMaCoYuacU09tb6r8mfoR/wTH1uytviB+054XsNUSeO7k0XxJPGJYybS5khuNNljIVyV/d6 ZbOdyLzJ1OK/X4SrLBLGzHYwxweue/FfztxRCEc+x3s3pzs/VsolKWWYZzWvKt/I8H+NHwpsvjX8 NPiB8L9YlMUWrWDCC6wjGzmkR0zHuBAZCM5IOPM6HpX4v+Gv+CXcOoeK7rSv2ifihda5ZzamtxZa TE81rGyAXCAZ86SQRkTFtsbIcxJ+9IyD5+BzCeEoVacJPV3tfR+q67G+IpqdWD5E5dHbZ+u6P2T+ GfwE+G/wm8P6V4V+GvhWx0rRrU78WttHADIQod0SMBY3bau6UfO5UFmY8ns9a8OjUGh0v7U8OmMx LwwDb5jerkfeJx1Jrj9t+855K73+f/AKnQc4tSlvp8uv3/8AAPQPD2hWei2i2ljFtjAz1zn3JroR ZQygrcRA+7cg/nXmVKk5TlU6s64wjCCgloblmBbgLGPk4Hpx/nFX1MlyzJggcfN6/Sub7XP1LdrW sbEWv6f4ZgV7u5VQx+XPJJJ7Dqa5TxX+0R4d8H27z3E0SXSAkw3DATZyV/1LMpGGAyHZDggqGFRU WntG9/vCDu+RH5zfF39vj4t+IJ77SfCGoJo2kMzIjW2WuCp2/wDLbaMHIJVo0RgGILN1r5Yh8Zap rNzcXviO+uZJJZXklmmYtI7OCcndzknuSuTnFYShZXSN72Z6LonxYsdCZo9Hik80fK1xKqsyfN1R vX/a2qcZGMjJ7SH4w3Woz207a5K0yKypGzkDOSx4z1PP6Vg6UldtDT1O58PftF6ppN0Z7CYEREhd 0jHfgjkc9D97FfT/AMOf26/FGg6jBNe+IbnyyPmiE5KFQO0ZO3HbOOuDng5zUalNuUXqUrS0kj4e /wCCg3/BXu517Trr4QQaZPqfgjVtJlN9Jp99orwXhb7RHHBOklndPG8F3DbXKywzWswWORGXe8Mt v+Bt3PHfWd1fS6PLECN6Tr80ZU8/K2MFefbrjFdWIqVXTpwk13fr2+S0CLUbxij5c1Xw1reu3lzD AjtulwGccKmP1/8A117b4Hn0zwrZQaBaXZa4VvMcZ+VpP4jz3PTp0XvXPXkpQVOOy1YoXvzM9iuJ Eu7eKWOPJC9iBycHHTjt+VfMHxais9S0vU9OuGVpjIXClY38opG2fvRSMp/eEbkCtycMDXNRupqX n/X9XNJvSzR7P/wTD+J2iaX8SYvgB8TLwv4NutVi8Q6NaT3MqLa6xGoUSbGmVE8+BJIZcRSO4tLR AUWMmvOP2WrLU5NP1u2uGmmnSx0mSe4lUhnnlhd5Vbd8xdSSCT9485NddblWGqqS1U4teju/zZhG 7lGyPtKwmurGK3Z4GMrSbVXYWHGOecdzjHP6GvmX9r/QtY8Y6L8EvD91qi3Onz6te7tItm+zXEcl 3LY24UNMiorutsB5gLxDzI9zlllSJYVKPtKseib8lo97FrmnJRa/q5+J2tfsjftGwXNxa3HgSVUR /m36pZ4LEADBaXB6dc49+KzU/ZU+NtxcwQXPhBSEI3Br+1YE8cfLJnPbnj1xXbPiLJVGTjiU9Oif b0LjlOPk0/ZW+a/zP1X0DVbGH/goN8Jb46jJHHB8ZtKuJ3jKASeX4gtMxyb9xx8xBAI+52qb4kaP oj+L9M/cIzjTlZkPOxvMcZxjGcAY68dK87Byf1N3Vvcp/qTVjy1pX7sS30nRI7dbhdJt0ZBjiNcZ 6Z5HA79D+NUNCt4zrOrWtysexII5FUAMELM4J/MDJOThRnnmuVylZ8zEm+pF4ASyOo+OR5IJGrPg rEDt+SMcc4z1Pb+tepW9napJHkIp/iQx9sY4/H696iV/aS9SvUzJZ1XxFYxrHgLbSkLtG1iZE6j/ AHQep7fTFH4vaj9n+GHjJjaxm0FjMt0hIBeIxOGUHse46j2543w6/wBppq/Vff0E20tUfJ/whvvC 178CfjnL4I019P8AAlxLfRwpeTK80Uxs4keSUs5wnyofldznOFr0D9nHwppvgzwb438L2fjvT9Ym i162vIbjS3W4tLlp4YklhWVGIEkYhR2BG3a3LqxjWTvxDbw+IjJa+01fS6sn9/Q54O8oN+Z9XWKi OQs6gSFePTvn6dhyOMVobj/z0i/76WvIl0v+VzoUbrY+dfEXw5+Evxd+MHj6D4gaGbvXf7U/suOf fIiJJ/Z1vcWSSbTsUOrvGGxkmIZyWFaui/DTSPhJBbXnhHV9R0vw9d3cCaneaRamW306Brm6s4ZL hmhZo9skE+Sy7GAISTcQtfS4KnOMuR15K90krJa7dL9uv5npwpU3hYVY4eMklG7d9+vU+L/28rjU LzWPhBPqbZ1mwub/AE24aTb+8G2No3JXIO9U3ZHHOa6b9mvX0g0CS43K6WvinR5wGJwnnEw8emQp B9ARXi8QSlWyhVOt1f8A8DX+YsoSp42rTWiuzsfHP7HnxY+JPj7xB478L/DS9uvCV5KLiK/DxRQy gIFlIeUqpIkR1b3U+hFeNeKv2Y/GV/Fb2WhXnhyPTWfzfKn+IHhQI7YxlUe7B9Pbp6V15XjIPCYS nOd+WEU0k272VtIp2/4c8/G0YKvVS3cn+Z7B8Jv2bPiP8OviVpNnqHw5vVtLefZeX9igvbaNCkVz GstxatJEOFHG4lSVQ8gAe7ftG/CXxL4obw/pHhTwlc39jBYap9nWwikRLBp5NPRUxHxx5UxCkY4H B28aV8P7bNMFj6S0U9XtZckt79NfxNcPVUMBPD1J2vfS/Xmjb8LnrF94Ov8A4dfFe28eaFptla64 nhq0jivJ5QIra4czxXO1UR8TeWkaMQQwWZlYYkqnP8VfEFpP9q1bxYJsvukMcUmGbphWZtx784/n ivUpYfBc15tuV2kl2u3v8zzqtavK0dOVf1f9D1Hw38RtN1cPf/2KslpDIsUt3qt9MLcSKvIAiKbs kN8o3cfnXXar+0bH4e2ad4UishF5a+cDoVmBvYAtsklkmkZcYwTtJAAI713y9nTmqNJar7lptpuz gqSfs3V1s+y9e5r658d/Fb+GrCyPi+9Gm3ASeSwtp2jtwTyAUXanQdce3evOrrxw7zW7vPIzAA/K 4PzN+PXA/UVyV6jbd9C6VCnFLlXz9SpD4zyx+eYTHJHzLgfjnjjNfoj/AME4/Gaz/tEaDBJdDL6d eqxZzj/V5X2Iz+uOpr0cok3j6V33/JjdNKnK3Zn9Dqpp94jpcqrxtj5Scg45H8s10VrqMFnGkSSb FXAAAxgV9VzS2OH3Vqy1cXkNyjLLIcMCPz/z6U22vn020aK4xMgP7vIJIAHemp6NPqZyj73P0PmT 4mfsy/sr/GPU9Q8SeLfAdgfFk8bQ/wBtRM9lqNrGwQOsF5CyXFuGCAkRuoJLHqxz4xrv/BOD4HX+ kQ2ngjx34t8OX7lS1xbaumqblGVAxq8V1yf72cnryea9rLuJc3yul7HDVmodt1/wDhxOWZbmNpYm kpNff96sz531r/glP4zurkT+Hf2wPFqxJMEEd3ovheQbRjlvJsIy3TO3IOc881658Gf+CfGofD34 lfCv4ka18WrzV5vD15Jdm3utIs7KVmaKWI7nt5JUdWLRExgJgxq29tu1vWxfHeZ4zA1cFiLOM00/ 6t+pyYfhvK8NiqeKoUuWUHdWba+5tn6P6v4r0y0ujp4uV+2LMFMRIz8wXHB6jB/Ovy1/aC/4J+eP PG/xP8efEf4N/G/TvDo8QXP9o3um6xoAvrZbryxG8kRSaIpuVVLZyxcFi5BAX5vJM1xGSYyOYYbS XLKPydjvzDB0MwpTwmJV43T3s+6s+h41pX/BOv8AaqeN2f8AaB8BSTI4TnwZfMhAA5JTUhgnOeg/ Wse//wCCdX7Z5llEPxm+GP2ff8jN4Y1nLjj76/bSF9flJ9/f7FeJGMgrSjr6L/M8H/U7Kp6rnS8p L/IyJP8Agnf+2VBaiW6+MPw8kuWGWWz8M6qVTqMBpL9S3GMHAPGMfxHgW/YQ/bhudQ8u08d+ABbg hWF1pF9CznHUFbxuAcA8E1a8S8Vv7P10/wCCT/qZlyd41J382v8AIJf2Dv27olZE1H4cSnOBK15q MYboQdvlOQOSOpOR71kXX7EP7ftnkRr8LZ5ssRC2u6tE2BnbybNge2en3ulQ/Euet6X4f8EFwZhW v40vwZU0/wDY3/b0kuFhvPDnw0RsEsF8WamwcqccY0/IydvbjtmtaX9jL9tBY/s+o+DvAZhYgboP GV+2457qdODY5Bz1wDxxUS8R6TT/AHf4P/MpcH0U/wCPK3ov8z7w/Ye/ZK1b9nSHx/4q8WXdm/jr xRd/aNRSzdpI7WKOSZoIFlZU8xVM8z7/AC0LGY7gSK/QDaoGCeAeTj8a/IsdWWIxNSsvtO+p93Qh 7OnGHZGdFcwxXF5aErgKJAqx7divkHJ/iJZXJ+o9a4rwz4I8JeHtYvLzTdKP9oyMJPtVxI8zvnjH mSZbjHc57kmvOb0aNnujvpH2OyoMc4qhm4NwgSPch78AL+BqVKLXvdgZ2NrKkaDzThs9x0qWaRiN yDhec9frXNyW1kU30L8M6hQzHgc8njHv+VeJfEn9o3wN8PY5rc6jHc6sgX/RrV0lm+ZQwPlhgF+V 0f8AeNGGQlkLkbThbW6KTPiXxN+0t8SvE1xM2haI+nQNuTzQRJcSISRzPtXgrnKIFUjqCwzXjGp3 Ov6zqpeaC4ZFRUCzqyKJCqlhsBbdhsjfnJG0nGcDKcOZ3T1NY2irFtfCMGmTm81KBZb0nKhUOUJ6 bf7uc9gT6Marv4Lv9RQ3k6eVaKrOism3I65x27nJ/meZtyq4avdmFe6MylbeytGMgGGYADkHkDHX 8c8HNQQ6BqNpDLfSFRjJTHQfQnjOfrScdNeo2mcje6hqFsI3XOeUXCgBwOc+pxnPPPI9hXkfxW+K MngHwdrGrTS3YlETErZxAzRRbkTzd8m4QrveOEzFGVHnjG1iyxvEqafQa8j8etR+MfxAvb7xL4y1 3xFgX15Ldyxy20ZguZpXLyZg2+WFy2QoUKOAFUDA7XTPHOjSfZ7ub7VoWsOu8eWrXVhKGI4KcyRL jJI/eE4xwKxrwXM3T2benfu12a/ElNvWR6Na6zpevWstnZajps8xGxbnSrpI5pGJHK21wElkyT91 FBHbFeY3/hjxXo1wt9p+y7s4UMjiCaOSTbksXMSneoAXJyBtwQaxpqL5oT39Gnf8vmW5O+x1MPxK nl0cI9q3mqo+aMZYnIJx74FeN6vDqniDXoItGhnm1Se5QQQ24ZpZXkdUWNAvzEs2AAOSQAMmtsPh 5xqOmo3uir3V+h+0nwO/Zw/ZP+FWmfCLSfj58GPGPg34xaPHHc6j4j0TU7rT9UuZ5UkZkurDVoni 8tBNsjijis3MSqJTIWYt3/ij9nT9kn9nHQdR+Ifw3m17xjpOrrHBp2nt4os49QnuYTCcXdu2mWkd pEsMs7PLDPdfvEtowuJmlhJV51E8NiIwi7fFZv4W2k7PfzQo25tNzifDHxCbWZPtWj/sheG9O8M2 bb73XfFXjnU1stMURzzhrl7WQqSUtZikCq805iaOGOWRlRr/AIt/4KM/s7/tF+GPEdx+1b+zbBN4 98KwWd34P1Lwzfpp999rtXtVjRblom8+AKsKYnimCI0rrEzkZVGlWpKniqdVNSfI1y2TjLSX629N B+0s+7R+bkfxPl+J9tJ41bwNY6DHevG0WnWQvPLt1ESK2Bd3FxKGZwxYGVgGLBQqgKMBZ5IQ0jRB uoXI+4cnHP05/L61+aY6FKjjq9Gg/cUml5WZ9rhZTqYWnVnu0m+m5+dmoeObLwt+1b428Ta9PHDo +jfEhNSjuHRyba4XUGuNyhQWzttn44H3uTkA+13vjefXPEDato8MN2o0u3kWRneIGBmmaPDFDuyC 529uM4yK/SeSUcLTbdlKEPyV/wAWfE1H++q91J/mzt/Dt5rt/a214Ft/s7hWSMysGAKjH8J9ucd6 6fQfDfiK1v5tQvRaTXE0aIoE0sYiCllyRghzhh3wNpPJwa4WoO92/uDfRHOeBBrUDfEe9VLffDq8 zurl8DEcbbeByAMdcck9AK9KuI/E8iI0aWKSvtJLNI3B54AI5zwfx55rKaSqTbb3fQrXaRHB4e8R i+TV5LrTwwiMHl7ZCEJKtzg5PpwcdvevPPjtLrtr8I/Hskl7aeQNNnBEdvKrNuUqVB3keo6dTyDW +F5frVK3eP8AXUmWzR8p/Aiwv4/2TfitdxX1sLSaLVpWje2d5DiDaSGEgAztAztOMDrjFdR+xTY3 uo/DHxNe2txbpFH4oml8uSBnbIt7QDPzgbfmzjb/AAnnmu/E64XFX/5/Mwgvep+jPtQXeqC5LS3N qGYnav2VssQATx5nPXpntVv7dqP962/8F7//AByvHd07Xt81/kdCdj5F+DU3xz8HfEDxx8Ste8U6 JNq2stp13G2lz3kBhvLBlWJ2R7VwUeB5YnQA5D9Rwa+vfBnxz+KXg6ztLHwZ4P0KOf8Atm4125uL eXWzPqd5NHNGHuj5SJLt8xWC7RveGMyGTBByxefU5VZfVotQ03ir6Jf3l2XzPqMvoPD4dU6+rs09 Vazd+q8/wPmf9o34G/Fb9pv4jT+NLzUpdNt5b86lNaab4SumjnuyoV5MvKXUthQVLkHghR35Hwp8 E9Q+Bfh/xXb6neXrxahc6ddqL7TZrXyXtbqMsyZPzqBJngjG05HPPFXz6lWwKyyNJp3j7za3Uk9j PD5c6GM+s86t262tbc4z4zfttftIfAjxz4g8C+A/Hd7aeErxIb6ytLu3sboW8ckaRyIhnhkdUZ4m k8tXCb5JZFUPI7H4pv8A9pb4gavAiXFnoqNggG30HTLUqDzgeRCmBnnAx7V9lkuFp1MswldtqTpw vZtbXffu2/mz5nMJSeMrxf8AM/zPsv4YftH/ABlg8M+CprD4patbaZeQXsOtWqX0oiu5BI/lqyhh yUAyecrGgxwDXqd5+0T8QNUZLTUPiDcyNHEqHzJ3kZ13+YDvxncCMbgQdo252/KZxEnKu40oWUNE kuzf6WOzDQpRo807Nt328kUtZ+O3jHxathaeKfiPqOpi1bFpb3l7cyi33EbkjEhO1ThQUX5SQD9e h8Mi91PTtUikdZZ4GheMSeYxCyS/vD64Uf8AoXoK7KKkpLmVn06HJVhC03Te+/bc6fxT4q1TQ9Lj tBNvsILtZfsxaURi5Kq+7aG2sdr7STznPbpSl8WpdrpNzdqGjZFiMi5BjCKo2gc52hsLyCdoJ9vR 9mpKEk92/wAf8zg0tOL12/y/U9DttWmvdPRJBIUaBJdm8AKAofGWX34PtUqakvkxrDCxY44dxjpj 9OB61jWottdWy1KNnoTrqBbzVd2SVidgCZz3559RivpX9nT4n3/wy8b6f430iZPt2nRllYr8zBgE 6Hg53dOemcYFdGBjUw+IjVb2ZPu8skup+ga/8FNvjVYarN5NnpMtmMhIbq3ZuOcHMbIcjjvjIHHN Vx/wUo+OlzdPM81nGpG4RW9kAoIPRd+5iOeh5wDXtRx0+qOb6vC+7O40P/gqF8Q7G8s21jT4Joww DwS+WhZQOcFEBB9zxnFfQmgf8FQdOv57ePVPDsaWYc/adkcjSIMnG358HA5ORz2xXRDFRla6sS8N /LI7zTv27vAZIlhsRf3Uyh98ls0L2p6+W2VCucdGQlRnrnIr2/wb+1v4Cu42n1G+trOJmzHE+m3Y dc8n95AJF4BAGVHHfNd6mqiai7I5vq8qbui9q/7XHhmy1B00mSzktSNxeO4kU7xjli8S7gQTx1+V Rn5jjC1D9sHSYdFtLu4Fm2pSKzNFFdumxuDt4DbuuM5HQnFYTsleRUYTWzPnrVPjPfeKvit4c8TT TrZ6brNsmkQwJNI5a7ia8nTGTsjAghkLkjLl4xnCYr9AfAGvah4m0i4fVpBJdxXHl+YoA3pgEEgc Z65xWsValGS6f5l14w9nr8TsvwuegwyyWvmKE446cHms27vJReQMQTGOpz9fSsJJSk3c507RXkaU d7A6Z8sZApvmwuoyh8wHkZrhqc0bu50q0tjPcwIScEn2OTWFdW2nvdtLJD+8PGQoGfxrHnkmU0nZ szwlgj70hUMOAdgz/nmnOtrcsMZChsjB4JFZVHLdlxjHYtJJHGoVc+p5rz74rfErRvhX8P8AxR49 15wNL063M8uXC9MDr6ZPPtng1ztXdu50LRHzx8Ff2kZfi5dW2ozwixRrAJPpTsDLaXrpDOIpcgMs qxPkrgcNmvp6HWlmk6HjjpkducjtkisKlO0uVa2OirGMFDl6pM2o78zBRwMfTp/j1q6L+O0wz/M5 ICrnkn8fxrC3QxeiuPmmkuWSKWQrGCMhV+8fr2/CuT8XfFrwj8PrYpqt4898ygx2VtseeTJOMBio UHBG5iq5UjOaTTq2hT3C/LeUj4z8e/tL+LPFEj6VZJLpOmBsOtnOWkI3KVPnAKVO5f4cYBIJIOa+ YJ9F0S8vHG+Z5vlUBo+mOOPTt1Fd0MNCnHlsSpvozVsvs2kapp9sNVmt5WdHESEq2PdX6+pUjnJr 0EeM/EsTfa7XULaeRm+Z2ijfcR1znIOeucVy1cLSl72xoqjSZ0elfFDV7eNDd6Zpk7l1Qs9jCTkd cMAGUjA57E11tv8AFfw1fk22r+AoWtQfm+yzSxM0hHXLl+OnygAfKD1ya5J4WcHeMm/XX5f0x89z 0fRvFH7PNwI4tZ8O6vY27K8vnJNb3bEgYIAKQk8qQMkAZPrk+mWvw9/Z78eWaw6F8UYbMKSFTWNO a2VXOBl5IfNjXqMFnC/MPXnCpGULSlD7v8v+CawfNoWp/wDgnnrmueHte1zwpe2Gt26kiK50jULe 8DtkBhticngEnBwfUdBX8+//AAVN8GX/AMJvEHg74RajJ4gtNdiaeWSw1m1ks4EscxNFcQ5YxXCy zfaEZkMiRvZsocSGZEUVGSlPRqNy1pdn5P8AxA8H+ItNbTBL4evU0K3SFnuHspPs7+cqsv7wjB3K wI9jkZ4qz8XptS8CWOm2tnPHdR3en2d8b+1t7lYolubdLhYSLmOJ1ljDmNwUxvik2l02ueOEfbOn Fa2Tb1+f+QJWUmjwPwzB4y8Y+IND0Pwva3l94gv7hLXTrKxgee4u7iQ4SKKKIM8rsSAFVSSenpX7 A+AP2I/2xtOt7DWvjJ4r8MeAfBosg/mfEW/Nnd28iKgeH+yYoptXtZ+MCWS1gRtmPOGa6KuGpyUZ V9FrZrd7aJdfyJs76a3PYpPD37EPhm4vIh4d8XfGn4iWEA1a4tPDWkXOh6aLREf7QLm3s5LrULyA NvY3sd3asAgLBVBFcnJ+2f8AGDQ/D+swfsf/AA88M+DNBe3TS7xfh5pm3Xp0kkMcFre3TodV1Ely yRrcPOxKtgngkdbkhGE3aG13a/lzta+nQuOr5d2eM6ve/Fyz+CHi7xr8WNO1dPHN3qdtfW667BOk 1xYP5MsBQTBWMMiu7K4++HyCeMbXw6fxEfEuk658Q9QvLnTh4YuLfw9oemmKS/1C/vLu13TFmQpZ 2oigllaV0bcYrdFh8qZ7iDimoc9q0rL39uya29V+YWb1jufSms6T4l+JTWlz49gjtPC9vcXF3pHg rSQ66RoRnMKkYkLPcymG2tIpJpXmlkFunnSzsA4+NPid4d025+KnhzTb7T2k8O3niq3sr3yIojNs mmZFDYYSRxu4VJHUkKWXILmIHGriZ4mNWotFGL5V2stC4wXPBS1uyr4qtoLDVNYt7YotqJdtvbBF jjt1VFQIgVeFyM98Z4OAAOBvZ0vDBImBA78rgjpuAGG9MH8vevyynNzftG7vq33f9XPvnHlgo9kf jz8f9Zgj+Mfxu0Zhi7ufGEt0uRjCwyXwcdBgFpoz+Fe3/CP4jeDX8PanFqGsRWzQ2MNvEk7BGaRI yjAdyOB0z1HQ1+xSo1J5fhZU1e0Y/jGJ+eVJqOJqp/zP82e/aH8XPhVp2jabE3jizt5Y4kSRFbDf dw2Bjk55PGOvqK9A0/8AaA+E3kiMeNLNdjHaMPhsjOcBfXP5+9eZLC4tu/sZfcDnHSzKvw98ZaHq mhfFC9sb+GSxn1a9KyhxtffEgQ4OCcgrtwASWAxnivWYvEPhyRIEGt2ykIBsMyjgYXIB9+/1rGpC Uas049X+hpfmV47F648TaIlu0H2+He+0hmnULwDj7x6jP+RXz5+0T4jsf+FH+OzHcwM8tkQjJNGS 4covykHnIOeMjFa4Vf7VSsvtLp5ilqrs8G+DGo6PB+x74wtLnUEW7l0vWH2kgljvuQinA4JKjqc4 weQQK2/2K9Ss7X4Z+MoTfbbw+KLk7cjcF8iz564wSOuf4SO+R111L6ritP8Al838rsxjvT9GfZlt qGkvPmW+hLFyu55QOuBwep/PuBWzv0T/AKC1r/38/wDsq8vVdGaSTWx+af7QfxY8ffDDx7omhaPr jz6TqEC3W+4aZniO8xlUdGXoFzznG70r5bP7S/xjvLVpx4kmWRcoSJ5+WGRuO5z83b8K7MqyLLsX gKOJqw96STfrez6eR6GLzPE0cRUpU7JRfYzn/aV+Nk6+VL4+umQjb84jkJHplwTjk19o+D9bv9Y+ Auo61cXRk1SS1ukLPNuLBLQs5AH3QHiZ8AfKWAHSsc9ynA4DC0ZYWnZucbvf/hjrynHV8RVqKtK9 o3XQ4H9qfQLnxt8efAcFnbRsLjw1byvJuZTFm5vJS24NltqsO/XA9DXkmu/CjS9K1axjigu7/Tpo ZZ5hZvBcXcMcQJkKwTLllA/j3gEhxwVJr0cjxbWBwmGXSndt9LNrdej7nnZlRUK9etL+dpLuHgvX YbPw5dabpEc501dQbablI45VQKjYZVZgOWJwp6qOtdLYtJdEjADDJBY42f8A1s8/jXtU6Vqkptat 3OR1eWPLHt+hqaXcW8eoWU8hbCyg7sfeIIwQOODg/nn2r7i8BXUMGuCOdt8c8At5YxwQq7uSDjg9 Pc08W+WpTfk1+QYVc1Gon/WjNb4x25t7fT7VQRh/MBdwC/yCPjJ54wDjpivNPDsL3Nrfae+VBAnh kK4CumCQD6kEj8a6acv9mVTzv+Jy74nkfVW/D/M9X8PT3Unh2C8jZE2Qy2siE4Zn+Zip/wCANnr/ AA49M2bbUJ47MvIq7cgbgcd8fj/9cVpLlcn5MytazLK6vsuooTADwvckqSO36duteteHrqKxjvIy QXuEWNSYwuBkMOA3POBjIp3s1qONrvsbP/CQi3Y7lhkm2nhldscdgSo9e9YL+O59Tkt7C3hljuJM yKAoTjGPmUc59jnn61rG7XvMt8t9Nj0fSJJLwoHiBYdcrkAnOePwFd7asyXsAOwDISQq4JLdM4HQ YAHP90/SrVVXXctQdrnqukl4C00UyE7dw6Djnr+GOa9j0jxFdSxQxPCWYKDlX6D+QH869bCz00Mq sOrNWXUrprRm3DzGO4gjp2/Dg9f/AK1eQ+KddmllgtXeRb0v+7MZIfPOSu0HJ7dPwOeCvK8bM57P VWPo74c6B4k8TeHP2d/E2kabNNaKw1ee6VgY4Y1h1e1KSM2MymSeMgDPyBScH7364/Bm+mWHW0wv 2fdEyjkFW+boB149+w9a74/wFZ/1df16DrRtQcmuqt9zPdTMJHYl+AMdO9NlSNwCoPT+tcEpuDuj njBNFTyvKDGLgDj1IqRGdEOGPXI69a5ak4yuzSELNWKUkjb3DHjvjg1zF9e7JODkHocH/IrOOrtY prSzRjS6vFHIIXYCZ8bVbq3+7644/OtexcyMWdiQMHHpxSqK0XdBTd2lYczsssqZwCCcfpXwT+3w NV1b4UeHtGtbOa4spfFejm/jhR2LWq3CmXcFBxEFBMhPyhRk8Zrmp2dRanTqfJ37On9s6Xp/iHxD qGnhbfWNcbUNPMM8ZN1ZzWkEEE7MuQu5EDAHBxsztOcforZeI7W9Z1vdVlKswTaUXZyTnCxBQew5 JOO+ea3hGm5y9ojTFc6VJR35f1Z0UVx4W0qOS5m8ayW18Nw+yW2m2yzScZVtpUlAeoLAD0PFZsGv 6wm+5s/Ej+Z5gPl3iLLhc9QQyhflAyNuASamrRoSXu6HPGc9mOvviL4iuSdPS8iRiMs0MWSw+YYy SNoPBPBIO4c4zXA39jLqdzJ58UUp3tJI0kbSEKxJHUg+3BAHIHHFcdOCpX5dUat8yRzOteE7Cbyp YbOIv5ZDSyERBmG3HC5weWJwCOvTvyaeGfs8SxKFMjIGdIs7XkGM7iOgyTgEnvgnBrSVV7SDlXQ4 XVvh9dXmsjxDDpskl7JaureaI/3ZZNhAikGQw3k5IyhKkYI48uvvh/4hsFMllZXkrkFkNtuZpFx1 VUJJGOeAeCKzU09GUea6he/EbQp9QkF46w22EMd2MPIckhkD4LKO5H94Zx3x7b4meMLNp11DRInh Q/vXilwEzgZYo2MfN274FJ1Vy3aJcL69zuLP4vQQTKbq3uFYICC2CqoQSHwF+6Rgjscg81a0/wCN fh2yS7hvZ5RFJIqSg25+QdcZBOMFVPHqDWNSpGcLOOppFSXU9K+G/wC1bq/hD4l6Hd+EPGHkahZS u1mj3nkqwwxOPM2gsRx8uSx+VeTX4q/tl/HH4p/tf/tKaleaDoPifV9f1Hbp+meHbu0kubzSrq58 y7v9M0+2ijEhgiv7nUBboVeYQ7fMJk3MeOpRS53DTmX6/wBXZvCT5W2rnNeCP+CaP7S+o6vbePvi tqvhv4beFVgivLebxnq/k3twonUSxDTrNbi+trhURmWO7htVbgbxkkfet94C/YKTxjJa6vH4j+MH jhp5rueXVrj/AIRbRbq0itZJJZ75bed9Q/cKs9w1wmpxoVj3NHwRXK69FTU6C5mla9tPl/M/wKhG VtTxXSv+ChXxD/4R/wAW6F+yh4W8FfDX4NIw8OX2r+Hra30GHW5bCC5uIor7UJYYTqE7Qwu0H2y4 kvJ2ZgsbMJMfC/jP9sHxJE2t6Xp37Q3hrXxq9gj3E114EOr3wup02GztpNY0pXtnRnO+SKWNMIWj d5FjV69nUnVcp8zkt3e23T0XkJy5VpoeZa/468enw1oGneLPEOtW3gjwtZSQ6dpU2pz3S2vnQ+Xc TWMbP5dpczOBI0kQhKyPuVlwSvuHgL9sXx/pXgs/B7QE0+1+E2l36ajrGgXN7rUek+K7yKOFnS5s bC7tLZZJLby7WRgoldYAfPCvGF5a1FV6KdRtwi035u6s9ezd16aEXcZK259O+HvH/iD4qfsn6Ta6 v4nmvItDsdL0Gxu7q7mnhthb2ls0jQ73GyA3Mk9wFTYpaVmKZZsp+zmfFPgv4/P4D8biw/txdIaL 7Vp929yJ1uLax1SFZHLsiyxwyLDLGqqUkjkjY5jAHmzpc+Cm29Ycz+V7fhobxdpNRW57l8XP2+P2 e/2eviLq3wt+Inh3xTdeJrC2tZ5W0uxsZIWW5t4riLBmu4mZiksZICAZJ54NfKHxa+P3gvSLv4Zf HmC9vbXwNqWsrqf2c28clxcWkrC7jhlhVmjL7Qh+8wjkRXVtyK1a0suxkaXs5JfvYvl17xvroCqw U1f7L1OA8K/GXwn8Y7/xfqfg1dQNtayrPdm78mNYfNLCNQgck/cflAQAPmIyBU8niSJbm0kmK7JQ HSRQXTGSAQQCDk5GTx+Zx+d18ur4CvPC17c8bXttdq59zQxVLF0VWpX5X38v0Pxv/aI1S2j+Pvxc lhs4XkXxBfEThsb1+0SHOCM4I/xxX0b8P/g58OfEfw5+GfifUvC8YvtS0aW5unF3c/v5Y9U1K337 RJhf3UMKYVVH7vOCSSf1edath8uwcqcrc0Yr/wAkv19D4KcIyxNfm6Nv/wAmPQIP2d/hA6x/aPCK dCT/AKZcEnrjH7zGfwHWpdE/Z4+ElzqWoLJ4VV7aIFkD3c+do2HJw4yMuBgVxyzDGav2lvkv8hey gn8J3fwX8N+GPDel+I9K0uwMdidaukCjL9MKB8xJHyovX0HQk17R/ZdjAwWOEl85xs6npxgc9T+V cNecpV5yk9W2a2SXKloQ6fYwQa5LGqjPk52kcZLDHbvk/wCevnn7Uiw2/wADvGTwKnSIELxuLOoP QY7nH4+9aYTmeNo67tCd7NX6HiPwsihX9i7WZjZxGVtJ1gliils/aLohs564HtwKyv2R/wDR/hx4 nuHyZB4ouVdtmWwLe1Of1Y49QK7ajbwuJX/T5/mYwd5U2uz/ACPs23ht7iJpWiTPTbhcnt25I4HP I6etP+w23/Pgn/fLf4V5Em09/wCvvNm3pqfCv7TukwXeqeHPEFy8AQ28kEJlTduMe0nGQQp/eAkn Gcj0NfIEujWAEu7VLGGIncybUyQTzgYGT3/AntXu5C5f2VQ0fVfdJmmYqP12q33/AER554gg0+zZ Bp9ykjmUIxWJUxwe4+mO/Wv0Q+ELR6l8BU0y1/1yafPk4ziSc39sD2+ZVZeD1HIxWPE9/qFKT6Ti dOSW+sVIpbxf6HWePdQgstD8EeN7zcdT1DQbayikXGUhjIYoo43b3KHnOSo5+bjz3wf4G+KMXhjx n4l0T4a6/eeLppY7e3trLR7qeazMmRFK6orPHtXcys2NzlAc5FcGTRay6pJytzT5F/hUnf8AUrNK kfrbiuib+bscFF8NfGvgC61Ky+IPgzUtDkurh5dPGuadd2n2yMKcCNpYxvA2BSc7QSoJ5zXb+FPD F1eWkt+rRKqbUKyRM+dwJAwqHgbTnPHIHtX1CnGMPaJ3WlrHkzTclBdkX5/A9wLEXWnXDSyGUFma NVCrg8q7EgkdCDj/AB9j0aee3v8ARtSwOVKysnOxlwxHf+JT/wDXyamvWjVnT6WumaYWLhGovT+v xPpT4p+FoPGHww0zxdYHfe6aCJwD96FyuDn1B9uAh9a+UPD91JY6/ou5CsUk3ktv+ZT5mUyc8Hrn 68Z7114SSnhqlPqm1+pyVVyYyEvQ9L8HDxHNcWcMkjPBdq+0MgZv3e7HLYx944z3HSrs+pD7NNBL a7pFby2Gwpt556Y7AVfNCU2qb2/za2IcZxVpL+mr/qXrfUbe42xzwkbR8oU4APGe2c+2fevWdA1Q TS29pgHMRKZwpYomRjt0HTvUpPuON7o7bTfDd3qNxFcW8LoPviTKqMDrgsQMfjzmu4PhZLS0fVy1 k9x5mwW3nR+cxAz8uFwB35YdKwrY+jSag3fW2mu51wpNx5rXv5mv4f8Ast9foNYtSmneX5m1XwCc jupwe/NXtLM99pscx0mO11GIzo9urMwkJA8uQksSoDMoPPO3/a4057TbjLRf8FM03pqyOh8GXGuX 1+8d1HtsyssJG7lWwGB9wc9f1zxXdaT4i8SaTY3Nre6YiTqTsbJzjGQcj6+lexRqqDcVLe336nNO ndWaPO7v4teJjEYZLiGNgShhCkrzgg7j7Ej8M4Gas2via61lZr5mSSZdoKgZBUlfUf3scnHT8/Rr qHJdbo4lfmXmfqt+yPepP8G9Nt4rVoo4riSHHAU8g5XBOAMle3Kn2z96/DaaXT7O5nBzm42lQMHa QmGznBHUV0U37iV90j0cZByy2k4rZ/5nuEF7a3kaTQMccAn1NXmnIQZPy9v8/wCelcNXmTaZ5Mdl qUTeiM7WA2805rsPkjla5Zx1uzVJWuYV5q0EL7Xf5z7iuY1HUgJIY8HLvwRnv3/z60kuprBOXoWz bowjkIJOB03Hb71oWcrFnmjGYGdlHy4wVJVuvXDKefY1nNtrUbhaw2e4RZOo3E8f5+teMfFnRIdV 8N3e6MfaIV89SVJwUwx/HA6n1rmT5Wa0/jifD9/Z/YbC5vY2YbCHZG+VJAMYycbsDnlCOcjORxm2 vjTxReJ5EurPHbbGQxwsyDBOCDjluOec1tzPmaRvj6XLOCeun6s6DT52VT+9fJ7hivX/AD6V2VjP cuSq3DbDzhmbAOPTPt+tKWxxROr0GwCShlwkTFiyxngszEknHOSxJJPc96T4u/F7wp8Avhl4m+Kn jK2vX8M6WLZbldPiSS4Y3FxDaxbFkkjU/PMmcuuBuIzgCs46Ky1LSu0jyfQ/2m/DHiy0tLq40HXd DguBF5MmuaS0azNJ0G6F5UVRxlnKqM9eM16BZ6x/asFvqmnXiXFjLGHhmtphIko5wQykhuQeQeor lo4uliIc1MqVNwdpE0kerQxqUcqHOAHYDJOQPX1qhLp1+0oHmsrZ3nAOS3c5NVZtMfmdHpulvbCM +asca/KDgjsBgY6fkas3vhrwdqyxHWrCK6kC53TxLLhumcuv9c596jklvBWBtI8z134QeD7vzv7O tIoY54vLu1gtxELpQwYBvL2gncEPIIJUEjIzXlGq/AbQ490lmQ0wSaDb5shBjkDBuCxA5YkfLkEg qQQCJnTe1hqbOB134O+FtG8FeNfHcmmEavoGj3t7BG3lNaRrFDJKW2zxSGVgUU7WYHlsHgV5X4y/ a11/wT4c8WfD/wDZ5+Efh2xltr2y1G/S2uLq3u9cgjiy6XkWn/ZWup5oyv8ApAlikcrIUZZGjhm8 vHxlOMYSnaN2n+Frr5nTRcVK8lfyPwr8WfED4peP/F+vT+M/iFftcIifZbO4a4ZZyZk3oWjj2bgp c75GjAVGyclQfpO81i88F+JtD/tDWtTsLK7sLFtR/si8Md2sEqRXlrPsBxKscn2S9SBjH5pgjCyR FlmTKahCaglZW/y1+8Fzatnwp+0TYarH4qhuPEPmS+K1vp4NRuJGSWWeSNox+8nUt5xBDAEOwxjB IxXh3w00cXni3Td2Y284hDvK7X2ttORkg5wcg5GPau1Tf1e8nfQymr1LI+sby6/tWwh8QXxmtNEM KPLcSOj3FxINysBkbVLNHIcEErkEnoD43qWvWt3balZ381w+jSb4/s4uXYOjDJwuevXn5cc4rz6U FO3Oua3fa/8AkjXd6H6Qfs2eItT1/wDZG8YvqFy11Jaa5NY20eqvDc24gRLcwwn7WHiMRjdN6yAq TI5b7xNfo7Z+HfEGuH4G/F74u+KtB0648JQP4Pe50+RRp6STwXV1BbXmZ5DZ4FxPM160k0TSMY5v soWNpPDxvtMPTlVw6bt7VOC2cW73irfEuW6S3+G12mtaSTaUlr3PwF/4KraTf6J+2t8UoNTtHt7l LPRNy7V5P9kWGGyAdysAGByQQcjg10f7T9tBa/sVfs3XAB8yW30duMjGdM3E/wCe35V9bhqkK1LL KtOV4ygmn0a9mcc42qVU9Lf5nJ/sAzD+wvjjIVOAmkKWAHXzLj2wD8v6np0r7W1A2k0bp5MZjGWC 4UAkDI+nPNfmXEnNHP8AFSXeP/pET7TJUv7Ng35/mz8t/i3+zn8XvEPxa8c32keHRcwXWp3E1uBf Qq0sbSEo21mBGV24zzzXvkzeIfgx4R+DPw98aabHZa3H4XuZ5oXcSvA76xq8kY3RsFwVZDkZILYY YPH2CzLBY6hhMHh6l6kYptWeyhZ7+bsfOVcJXoyrV5x91t2enWSZ1EOq3+63HmRbW5C7W2suDwMN gYrodEnvkd5h5AMgO4JHIp7A4JY44RfxHHpSnGPL5HOryWxgfD/ULvTPD3iW+SOMhNTvHbchYqVl c8fMN2SeMnrnrXs9ncai8bB40GDsUEntySBWVVL2s79Ww9S7b/2kmoNdpHC7lApBZlEYzuBPHJ7f Uk9q8P8A2o9X1Rvgv4qtb+3ixJ9n2vHJgD96hOF5zyO2OvtWuCinjKTXddAlZQb8jy/4X6hcR/sf +I7RII2gTR9SQuj/ADoXMrkEZ67ZFbHow7Nmm/seNNJ4B8SJJIjWy+JLmVsllZ28i3UZOCOOvr15 6V11LLCYn/r6zBWUqfoz67hub+MMqRws+fvGQp3X/ZPfjp0zirX2zWf+eFv/AOBL/wDxqvOjGD3b +46LJ7M+WfFWmeHNf0/4Q6r4o1HTpdHsSL26t9Yukt01FZYrZnTzGIOSsbZ2nPz8DOBXJTfEb4Kf DS30f+0/AXg3xHqZuc3DafFp/wC6hG3CPFNaSI24F8MsoJB6cZrqymeIqYOFCk5Rs5q6vb4m9192 51Zk6cMTU50m3b8kfOuq237P3Lr4klkjSZpo7S10m4OwsfumRp4s4GF3Y+g7V7x8DtV0m68P39ro DBdMj1JHMM5RH8g3FqpRA8ju4D3Cg4LHBJPAYjbPo1qmVtVY2aa17/16iyVqGN02af6HEftFW0X/ AArP4CR3N1L5MKahAvkxqSxUwIA291Cj5Hx16HpzXzl4nlg1jxLd6rY6ZqWlxSRwhYJGjBYpEqM4 dmUNvZGfgYyxxkYroyF/8J8b2+Kp/wCnJGGap/XanpH/ANJR7P4U1DwhGnh3SPC2hajF4gu7eZdR mv8AWrHUUmeGFJWeKJLaBrVf9cdjvOSCiqcoWf1G8s7uxuxcSWPkXkTkndjAKuw3BgME7lK4I/h6 9a65VvZVoqpLe9un4P8ApmHsvbUueK2tf+vMsyprWpXKi9nml6BAznAyOFC5wBjoP6V6h4egudK0 e0S4VllMoIABHDFiRj2BJP8AvexqsTUpezpxpWWpeDjJSnKS0t19dj9C/wBna2/t7wVf2N/j7Ak0 lrIq47sZQuWBB+SRVyM8Y7815f41/Zg1yx1S5fSL2HYjLLaxyM2+Yg9E4AAxjGX6HrXJh8fCjjql Oe0v6/UMTh26cai3j+R6L4d8D6tH9un1/T7a2nMAzLYyYWWTKg4RlURock4XHpz1rg/iD8N76x1q 81K0lX+z59033gxLbGkHCgAFmGPTLdhUUMTTp4qTUrwkrXe+m39dSqtOVShF9TzbTvD2peY0LaTP JIHwxVGIyTgfd/DvXsXhbwvr8XiSw+1WMlrpDny8zFfMG9CnCthiSXxkL6+lez9cwUOSDqK72Set 9Pn2PNo4XH1KsmovkW7tpY99s/DsKRslnGqSxnG52Yrj0Hb6HFejeDvh3LdahHqGpaxfRoqZEEFz cQxTJkqRiMqM8nkckHHasZ0oTbcopvzO6NuVps9o8a/ATT59Li1XwwiRzvGGguCWkKvjgsS25h2O W/qK8T8P6NcXF/Ja6paiO8W4+xagsjALCeVaXOf7rlw2cZGRnFdMKbajfoKDfvRZ9AeHf2fPFete E9J1qLRDFp99EzQMt3HEQw+SRDkjlXVhx6VyHjPwX4w0O4aXUvCtytuUPmTJsdVI4G7aSVyQQAwH A4r0ox5pct7WNqmFq04ubjofK2u+Eb24utWuIh/o4ywjJwyqBwMc8BcAD6Vv+B9He2sbKSS5YTzI d8bdl6AgYHYA/wD1q7nUjKm0vK55soOL1P1b/ZNllg+G+oabLa7JLe/Z2bP31YYAwPTaD1Od/tX6 N/D+2lm8NQOg2JJLIzbl+/glePb5cdO1dC/gRb8jsry5cBTv3/zO80vThp8EdpFKDGv3VJ6AkkDJ z0GBWk53HI4IA6elc1Wd5NnlJK1k9isUIjKEjOcjBz9OtQPGVC7ZPwz1rmlIuNtDB1LTY3cyoDuO QB1x0P8ASuO1+S80i2m1K3sBdTxj5YSzr5vPI3KrEcc52noKnnva5vB2R8SfEf8AbG+NPhWTxFpu m/BzUo5oUljtphoM1xBvxiN/MW4jZ0PynICHB6gjif8AZf8A2h/i58QdW1Of4o6Dc6fDPBF9jt7m Py2jdVxMoBlk3IZC2xz5bFdu5MjNc1efLKKXz/4B2U4fuqjnZq2ne59zL4ghmVXVWDnIII6flWXq 80Gq2k1qBkMrIwBznI/+vUOJzpa3PhfxbbvDa6xZTjDwxSCT0LRgsD9OMY5PNeE2FwYZnVW5Gfl5 6ZOc1pb37nZmd/aU3e/u/qzs9P1BwQWYEdgM/h+PNepeH75GBVmDLkdMnjv/AE/yaJep5quz07Sp YhKCu3B6g859a8L/AGxfD6fEb9nrxj4D8xUXULnSYt7gNwmpWcvIbjGIzn2rGU3CMprpqWrNpH0L 8C/CWjad8P8ATNB1HUrGS2tbZU23E8OXVRkgBjlz14GSeAKv+IvBPw18y4vPDfg1Dq8u23mubOeT SzNF1KmaEiUgc4Vlxn618jlGFxk6fOm4R8/0XU6K8o8+mpFpOjPpdg0bQmK2SVBClxPJcsqlgCDJ K5kdiDgMW6kcYG2rV/BHJKjiRdjDG0Dofrn3FfTRi4xUW7vuYX6lu4isFjWObG0IwJ3g4GP/AK3Q d8UlpbLcRRSLbxeQ67lJYh2AJHGVxnjpkcH83Uqeypp82/YUfedmWLnwvfRYbFusJUZIlY9hxyK8 91XRrnTpMyRo8e/AWIvuOT0BA4//AF1zSxDtfqbKmnojyP47aS1r+z98br6GwiS9fwrrbRGY7/Jb 7DOueRjdyyjofnJyK/nP/aG8a6x8O/jT4e8UeG7xob6bRLO4kC/duF+ZSsgBGRhBwfbGDXLWarwa kt+b/wBtNF7qR7hpHgn4bftcWEeo6LqEPh74xM0S3aGaCO31JWJ81ZCw8uOeRdwjndliZ8CYoGaZ PiPx5rni3TfiH4x0zxL4bOk6za3ctpPobW8luuimFzEtksMh3QpAqrAsWBsWNVHAAHLT/f0ZOXxR sn3fZ/NFN2acdjyL4lahHr1j4XZVjF3bw+VJDFbRxRwLGscESKEOGPlQoS20El2JJJNed+FdLmj1 loVUYYSHY5CoW2Ngkk7RwTyTgAnPGa2hb2L67/8ADmcveaa30PTvHDWen+D7bSNNZmvYb6aOaIAn JVYgH+hYOAMccdc143FZ3V/+6tYJZ2feQAhYlsdSMg9WyfTB695pe7C77s2ho00fo58BEmT9i34+ W6gmb+1NQgRU9TY2oXaBzxuB+o96+w/+CbfiXVdYsvH/AMDdd8c2uqJfeHYdfgj0C4W4vJrO2kWa 4tLl57ZZoriKGNI3mSF22MEglBAMXDU/dqniYr36dVtaaWurp+V7PtoRFXTjLZoi+J/7Nfw//a9+ GVh4E8Q+J9Ul8c+E7e8vfA+vEx/atR8Oxma4l0m681UdzBEDd27gADZfRp5iz25X5++Kf7Ovhzxr 8Jvh/wDBTV/EV5b6V4b2QG80uG2u5pzZxfZFxumjikDBtxZZCCVBU45rzocQKlmmPwuHoqNHDTnK Cu/gndxj/hi3KMfKKR6MMtUqdFzm3OaSf3b+pxnwm/Zi0z4ReCfizP4O1zUrx7g2krWupW9vBdXF vbCRpZoY7eWVXSMSlpE8zeqjzNhjilkTF+2LHGJAjbiMOP5eh9/88/L5lW+v4meO0/ePpfokra+h 9Lg6Cw2GVBfZvv53Z9MabaWQ1OPUGhQ3uNhlI5ODjHPsP89B8Bf8FEtMje+8M+LdLcp4isdKtot2 W2yW5urkBSCCCQzHjOcO2cjbg4Vk1n1NT6xkvk7HnZpFfUJPzR5v8LPED614I8P3l0q/aGh8tkCk 4KllAOM8gAfXn1r2TRbiN3NnHKomOESMDG85AAB6HtwM9PrX21WPLzQ7N/gz5uLuroq6Db6ZY+Dt aTTtchvhIZ7uWaxR2giMx80xhnAZjEJRG7FFXzUlCeZGElk7W88aeFNN0xb9/EdiLY7FaRblHVGZ sZYgnYu48sTheSSOcROjVnJ+zje7di3JX1Pp3T/gp45+I1zf+JfhNoEGo+BRcPBbz22rWsiKUA3g F5t5w24Z6nmt+X4BWFl4S+IujftG+D3b4fPpjXN9HbXMbXFokKzSi4gkikZUmjK70BwG27JMxykH DBxxMFSqX/erlunprfVNfma1IxdWcYfDfT0Pyj+FuveG/h1400Tw5Z2LeKvC10p0NIINIuoI727Z 9tvFcQyXEP2wq80QYJNFgSMCWUIW+rbP4beDPh34j8bP8KNH16y+EOq67LqGhweIrO5ju7EyW9ob mxM8sUIvhazs1sL1Uj+0IiTtDbtI1vF7WKUeXFUn1cZJXu01e6+78rF16bVDCuaVuV20tf3pLXvt +HmdXOkMaRNHb7SY/mAYYZgxwVwMgYxxz0J6MAKm9/8AniPyP+FeRDRdDnd1omj4J+Nemw6p+zzo tysu7UrdrFUG1c4TfEVzwOFwCeSSq9c183T/AAu1fxYINQ8D6Pd6k66NZ3V/b2VrNctp6xW1vHLL Iyg7E8yRck4C+aq56Z9PIpy+qSjFf8vJr8b/AKGma3eLcvJfkecal4O8Q6VFNNrWm3NpLGm8pNCV 8xSyKoXn5jubDDjaFOT2H1F+zxpYks9ejukMNzp8t1LPtdgWAWFjG6g4dQ0O8ZGAyg9QCNs7qp5d V5Nf6t+v3hlOuNin5na/EvT9Z1r4PeEptKubVdU0vxVdWtuXeJQN8t2MZuCI1QKxLFyFAGT93I8h 8NWGqah8OfE3jDU9N0690OwvItPvrWLUhZ35ebcUmkij86KWNShDBljOQCAQrleLJ6tJYKUJ3TU5 dG/inpfpu9dbo0zKE/rjSV/dTa9Ejq/AnwmW703xP8TdA1bTo9Y0+2vNStbJFtBeo8UqQx232a2v NuHSZ3lH2fcqQsQDuXd7pKj6x4J8Y6nZJBDc6hoa/wBn7vLtktZhdTiMb2YRx7PtSkudiqoYkDBc 555Vf1jCWvpL8LryT1t/wToymH7rExklrG/4SPmPwt8YtV0O9i8P6zoFvdb51MN9JcGwlhXzCu5n B8tlw24gqH4U78dfsjw1q/w28WXKaZ4e+Kunvq4jUNa3sq2UrSOFxFBJIPKkO5jGAru7FCwBBBPp YulLDzVSmnOG7XWK6+q/Gxx0Ksa0XFvll+f/AAT7l+AOqaf8MLe/8J+MruWylkv5LnzdQDbVxCgI ablASUIGSpOVGM8n6v8AGHi/wR/Y1tHPrESXYDIJGlEWQAzAqcgggKx3ZHC54xXk1ozq4pYrDq8Z W26aW2Nqi5aPLN6n556z8UvHWg+K7uzt/FrajokM4VcxwN9oiVg23cqYzg7S4wcjPrXsvxT1iTU9 USDS7hG0/wCxRLFLH8yzJIm4OhB5BD5BzjAzXqYzD0aFTC1KcLKSbkvPT/M4cPVlOFSnfZ/5nI+A fEcsdteWd7cSFY5WDCIsCuSWOVGN3BGDgfia73RvE2jy63pxTTpnKXcLGSdTtIDKSeDuHsBg/Tiv JWDqvM3UpNRimn5vZn0NDF0lgo0ql5Ss1+Z9xW3hAajLcX0UrRs8jM4kTfjrjBJ+ozj0/H2bwro2 jWSWsOsXDxadJJHHeXMJjkEUTYdWEe3JZSH3c4PAIOMH6P2lqkU++p4vs7U2rHs/gm40RbS78O6z qxmiuY0+yXEFtiGOXYgAIkCOowQxwWXkFVG7dVvWfgR4Giv7zxNqOtz2V8Tuu1tYkhkuGCoqFWYs NylWG4ocq6qNpTe3dQqKe2p6FPCU5xhNKza1X5ntuh68viHwVBpmhIjtpscH2e3vplhnkC703IMH z2c7PkUbjuducc+Z+NtZvtE8SXdo9pbM4jQk29wrqGKo4AKggkb5AR2IAJByB6D5nudtnZprY+Mf Ffg218XX+panGfsmpoi7jEiGN8scFhuBydzHIyAIyOpFeUaNoVhpfiAw3l0DDbw+YtuyENLn5QBg ED+8QccAjPStIXtJWPAx9BQaqLZn6Y/AXxVpvhXTZdXlgin02TTvMuIJAyFJAphdi4yPmERwNvIZ uRxn0Sz/AG1fCNlILC58I3dtpkQCwzQlZkKZVQQCVwuDnnHAPeuh14KMYSdv6Z5FVVal4x2Ratv2 5vhqLmS1ljlIUjMipIFOVyfvKCMZOc46H61di/bf+GEiKV07UpUZuDGtuuR/uyyowxx1UVMqlCfw VPvRjGniYq8qa+TOl079rP4W6pcrG181tGcBpLqa2VY+4yVlYdCMd+RXeQ/Hn4XXSvJZ+NtPlQNs Plylju9Dxxwc/jmspcstU/6/ryLXNG11/XrsRX/x4+GdlbLdT+I2NsV3B4rG7n3DGQQIo2JyPTp1 6c15pe/tX/AszSW//CSak0kbiNjH4X1x0JKk5DraFWXA5ZSQp4OCQKy5ZP8ApGqk07EsXxd+GXig XMGja6xnaInM9ldw5z/12iA9OOw7VDpt7pSSQvDe6e90r/LIZYY3YDBOQcMT0ySM+tHIvtrU09ry wtbU7FvGWmwOlpNfWondto/fxd8/7X44+ta0erwJb+ZPcW4yc4jdSeffPtWLtb3QUpaHy/8AG+e1 tp9QubJlD3dtnCMF81iDvC5zkiNQxHpzXydZ21wHllEhaQsG355fjOTwPfpx6VN9TqxU/aQot78v 6s1oWlSfLNyRwo7nt/n616DoNzJFFI0M3z8Agc5puWhyJO56Bpuq3MW1Xb5iPp19MDjrXW6deLcK qzknB7nIHP8AntWd77ltdDtUu4bWIbWUZHKgYz/Sk/tqPY8iufl4JGMCi6CzRVn8ST3MMccUvCup cMTjGRnp39OvOOnWqmp63HFu8shQeuDgtwO+eOgrCT3sOy3OEvPEb+Y4jnJXptDYHYH8Onf1rvrT Ukh8P6UyvtbyEcfMck4z+GM/y9K5pyv7snoVFKK0Kh8cwvG2y5ixGpLAPkoQO/UYrwzxN+0HpOiT uiSefLyQYo9+GwOMkjHFcmIr0ormZ0U6UpaJHzV8Y/2gG8VfDTx94ZRI7Wxm0LUIRNOHO8NbyAgI pXBbkBiWxnJBxX4hftXm7/t/4cavsQrN4XtEbKhvmV5ScE/73T1x0rnpV41UktN/0NKlOVPRnlng fxVf+FbbU/iJp1y0OrJPbaZZAIWSTbtubooRgK6AwRsjBgRdkjBXj9Ak1bwP+3P4V02WV7XSv2i9 Kt0sbTVLy4ECeILWGMRwafeu5EauoSOO0vpCixqfs9w/kLDLZY88qVR1L+67xf6P5P8ArUmKi7Jo /Nj4g219pj6n4a1DTJbTVtN1S4gntLq2khuLV0WOExypIoZHQwFWUgEMCCByKx/DmmvbX41KaJnS MtIw2AnaFJIwev4+nNbcsqdJQlo0iZfFddzbht9CmTVpLyXzNYmktkSEMMxiWSYHJwOSFLepKjOB g1+sGk/s/wDwV8dfA2y174FWY1DU9N0mG78V6l/aVwuu+Eb2d1tJ7W5sYJkhtrI3bosF+luEuUuI YzNHLJdWa5wcvaRvrvp3NUn8SR5/4S+F/wDZn7P3xP8ABGoXNraPqd8YmurVAIoi1na26uyRgFSv lASMF3sQ0mJCwZ/Ev2S/hl4s/Yu+Ifw9+MXiXRri0v8AStSh1m4g1G/06a0udOn8hJTKsc7S3MBi mikG5Yg6sGVXGGGlKpg+SdDHOSpyc9Urvm5XyL/wK1/zMJU6z/3dJyXftfX8L28z9UP2gNN1L9nL 9oC21vwDPdR+HY7638YeHXeM2639rcyfbrVmRCQsZjlWPYWcYLEH5iK8K+IVpoulePvF9p4Yk/4p 1NX1SHTQAxJtluiIeWy3CBeTyc1+f45f8LeNqx0jUoX+6UX/AO3s+phFcuBff9EzxXxVqNra6Pa3 eoxxy2dvfwXUscvlbZFjkSRxiTCPlUOFPLHCgEkCvmGK4jaSQ+apc5ZT1znn88muCnf2L9dD1X8c kfROhai/n3VtkOiysOowuCBgdDxyO5znp0rwX9pL4d+LPjD428F/D/wBpkOoeKdcsYtPtbOW9ht0 3Ry3VwzM8zKp+WMgKMs5IVQzYU9HD8o0s4jVm7RUZXfoePmTvgZLzR+g11/wRROhWfgW6+Ffx5e+ u9JsS+s6NrdkbW11qRo7ppp4J7cl7Vd5tvKtJUkC5laS7Xbtb87Pif8ACS68DeJPH2gaZ4W1PVvG fhq5e38SWmg3kF7Z6G9o8xki1W8tjLFp6E29xGC0geSSBo0OQzp+g4SpTzCHtKdPlatzX1V7t3v5 7W76a7nzkoOl1ujkv2cPjn8GPDkHj+y+JuoMPDOiavY3Oj6Hb6nKoUSrd/aLi0ktnjmEzGO2aRzK 6AW8eJzmJK++/B//AAUR+AHxr+Lehw3/AIvn0nw3oDyy6YjPrTtfmaERM01hZIYpsMzKDI83lgb0 Vt7Idq+BrezrSpxvJK0V3ctG/K979bGM6rdROKVm/uX3a/gfphY/Fb4R+INN8MP4M1uG6F5bvdyW f9nahpl4FjEeQIdQtoXkQGVB5sSyRt0WTgVw1/qHiDxho3jLSdV0zTx8L9T019Nu4tVs9wvrcrse ONgVlhDIuGlXa7hz8wyxPJUprDXc3aUbWWl779NLdfkdNKXMko636nx34u/4JgfHT9pL4vab8Xfg n4v8LeH7y48QQ6xpg1LxVrbXyXsdxEbOC2jFveNAYljgt7eNbp9qW8YJDIS/yb+11+yP/wAFN/hP 4W1W++KWgSy/CWx1WHV5tQ0y9t9asbaaddkG4xuzwFoVWANNDFnDQqcApW2BxOCzLETpzlaq9Ipq yd7rR69+tvvPYqzpShg4R/5dxtK+3xt6eVmcZpTReC1tbb41fs36lqd/qML3FnF4lj1vwxcxrJKZ N0PlwXY8tWaNU3RHIZf3gO2M7f8Ab3wb/wCjQ4v/AA5mvf8AzP1g1PDe5Ub11VuRprpq5r8jzJql zNKUUr6XWtvuPiHUdIvrv4daXbWGoLbW9rNdSyXEs0MahFupIiG8whSMNwOegAGcZ6n4Nazb/DvV P+En8M/tAww+JLyP7G1pp39sFpFkK4RniWGKIrKsUqvvdFaJGIIGKnKq9aFKp7Gnd88rvtfzenU6 cwgvrUHN6tR0/A6vxR8LtI1631XxT4f0u6bXEtVSTw9ophgh1STOGeKMgLHMyMdyIyiQA7V8xtsn yH8LvFem6j4h+Jw0/RrzT4ryKGA297cGe4EzQXKyM7bAQS4LbSOOhLHOerHr22Br1Fa6jr56pmWF g6GY04dHe33PQ+gNJ0o+J/h14z0uKzV7uDU7meDIQ4lPltty3HzjK9uCfWvk+6svEfga8n8R+Bis tjf6fIHsZRLJDq9mRukjYZVnmhKqxAILBUkXBBB87KKsYxqwn8HNZ+kknf5PX5Guac8cRCa3sv1L WoaN4g8BeH/C3xC8AeMn1PwrfpE8d6qJFJDcIrI1tdQBnCSR5lVNxbKMVVmVkLfQ3hC4u9X07RNM tVkiivPDk4RoRt2SMlgQVYsxBy/UsckZwucDfPWqlKlUeklJq3blTdvzt5MrJbqVePkedaR4J0LW fFng7xE2nrP4dubBbm3huYrh4ZnZXjd3CxSNIYZI5lkK7trTW6ooAKj1if4T/ESy1ya5tdN8N2+l XMDRLNpc95dRW8TsMZSOBQfuKMBd3QnANd067fK6smtLWVrX15t3ptZHmKErWguv/DHu3g7S/jt4 O+GmkW2i+Btd1ea2g1ORoH8P3s9tdGNJTboqMm+BHaMKAjJuMigNyDXqnhaw8darpGmf8Jn8Nbjw PqF6whW11bVtIFndvLEUJFrdTxzo0kg8pUSFpAZVXzBhjXi4OvhYrFVvrcY1YzfLBu/PG/Tlu1Lz tZnuV6FSp7GEaLkpRV32fz/4c9BXRLPwKdU0/wAYfCuOV2jJmktYDN5asFkTZHIfNhXyZUZWDuWD K245BrJ1XxP4X1qx0u38PIVuLW0Fs1u+PNRUViiGM5fKgHJ5GQOfXuq4uWMjGrCo2lbR9NOnqed9 Xhh7xjGz7nAeAluG13VpZo1KsVVE2kAY/i685GMDnOT7V9M6fLbLbQD7MzSAgMVQDp9fT/8AVWWM n+/TpvZL8jry9N09V3PoPSvizqVtbqLuzLRSLlvLR29xj5mJxjHzE+5PWteP4n3/AIrvNL0DT7Sa 006Z/wDTLt2IlmRVZxEg3fIjFfmIyxwACo3Bu9VoVqkYp6XRVPDp1I821y9oHxK1rw54kn8J6rC9 1pMl2RYSFwslgJGUDa5UlolGMxNlQN23YXLH661nxdf6lpOgSXl6JXO9CeOAFRQDzzgDA/Adq9bL JJyfk/u/rc35eRyt/e/Io6Z4putOntpLW5ZJVzCyckNGeRuBPIJLcY7DrU/i7xBLq19a3xtY1nRA r+WgRXIJOSo47jkele9CScbdU2YzlJctm+h4xf3csWozICVR05GOpGa8tso4W8f6bb3pDLcQusau cDcoJ4P6f41UpWUn5M8vG3cddrn2V4D8a+GNAF3pk6yiM2AFsItm7zsSoCx9B5rEDGQSSSQ1fPcV 1Z6j9g0aZmikjiSAh1wBtYcduccdOo59a82pO8rtnHy3i2jyXWrd1uNSvow6Wkl60IYDIYZIIHOf yGK1YpZBa2KI/bfnaPmyT1I+mPxqaU1LqW4pRuM02wuZ7i5FqzMhPRQcHGPb1Fd/Y6bPabzcJtTZ vGWBOBnHI+tdsLRko9Wcs/4ba2On1PwX8RPEHw3v/F/wyuZG8R6W0l//AGY0kEUWsxRB/Ngd3RnV sYYFGJ2rIBHLK0IXzXQPifoetz/ZdOtpI5EUGN5eJN7EpLGyjco2bgm5WkDkuVJXazerh8BWzDC4 uvhqdlhYuU3r715JJdk7N/KJwVcXTw1ahRqy1rO0V2sm/wA0l6s9n8JzW0jmBViWJIwqhQitwWAI UKpHBX8MYArvtEnsNQXy2lCL90LH8uEByvykAgYOcY4PHNeKqmtmd/KeoQQT6bbx32jarcQ37ERF knkQqrkA8j/PPtUGo+JPFEw0+xfxXqTaUqJGkAu5fLjHmCXO3OM7wCSeuADkDAr2rWiBwTdmjnNV 8OQ6ncpPNK7OQGc54kbkEHLZ46nOBnaRkg1hxeGhDaxeXMfM2Zb5i21j1wTn8AegrBzu9y1FW0Et NDWS6PmShVHIwoJByOMe44/lXSJo8pO20nKoDzgcNnPHOcAfh90e+U32GtFqdFa6VcMLZUkkd8lG IK4YdSWAX24PA5OQeMdhb6dcQbfKdVlMbBWfkKexxkH8MjNJoRV1TUY1kcx3ageXgHGSrYOWznBH QAYHQ8nOBz8/iKKOKWGO6QEuACwzhARuHBHJAYA9BlTg4IOd30B2Zx2qeJ44zPt1GNIw6lW2luPl IyAeobJ3cbeCR8uTyNz8SJA0lkLxZNxB3swG0d/r0/X2qJaarcFrsZ0vjPTrUyzyzedGsijajgNt JXcRxxjLHBznA5GeF1D4xwItxZ306mCZFig+z5PkoSN5bj7wUvhRkEqoLKCSPDxtfkqRi3p1O3Dw 5031PDvEvjDT9MiuVtNZW4guEKqzb0MeRkBsj72c4AyMAEkZIHnVtd+H9VkgTWfF8Vjb4eSWR4Jp WXHRdiKcljwvQZ+8VGTXBOWiXNodsE0m1HXseU+KPEmiLb3FnpniJJJLr7RbpH5bCVI/LOGdTlRu BwQCSMNntn88/jLbWXiPw18C49IhmhjuTqEH2W6bZJYRxywkwFp5D/qwxUGR8nncckmujCpKXLB3 Wr/B/wCRz4maklK1n/wxxfxK0GXwjcaP4DvbCGDV7DRbK81NoAE8y81BP7RkEoRmUTQpdQ2bEY4s 1GAQa5Tw1qms+CjBqOiZttW80Tw3CniTJyVI69yCDkEHg9aVf7NKTtdp+vVmVOz1tofolps3w+/a YFq3jrQbF/jdY2MNnm9ubi3t9egiiVILW6mjliKSxIoht7tnwihLeffAkElp578QfB/wg0fTvGml WcEuh/EG1si9ppsUk+oW19JIViNuXSPzLOePFwzpcMzhowjKhb5ahUnUhG8vh0e23R3/AE8g5Y3s fJd34O0XQ7LwzdSLeReN7u+lkvra4hIiSw/cmyk3lj+8Lm9zGwVljML42yoT6n4E+K/i74O/EDWP Gvw18WvpfimJrmxkuEtraZzDKwE8TJOkiSQzKPKliZCk0TyQyK8UsiNVTmsvPXT1utu35iUktGff knxL8KfGz4UX2vppeneCby7ntNP8VXsE95caTZagywrc6pDb20D3VrbeVJHcy2kCXLrItwbZQjw2 kP2T+2x+1N/wR/8AHvwV+Fv7F/7NXw11jXPiJokDaRB8RktbTQP7ZhMI1HUbyaDyjLdNczxvIyTW tkIZ2Uxfuf3Evo5bWw6hWxmLivdUrp9dNUkuumj6fnrRU1Xh7Pv166nC/EuSx+M37KngfxzprBtd 8C6lP4M177LAystrcBrvTpLm5yQ7jdNCNqRgBUHXOPki9Nw1hpEyMyTbZ2cCTPJK5znhuSfzr8+r xi5+06OjJfdKK/JI92jtho78s5L8/wDM+evjVeSQeCAJblRELlCcKp37ug9BznpjpXz7oNx9sRGM rhiAoB4ycZzgjjk+g447CvOpJRwqktrv9D2G05NWPpfSNREOr3FuxHl+ZLg+p3dfTjP159ea8Z+K fx1s/hf8RvAuuWV3d2eoNoEd5baxp8W68gjmkvUIjWV0WPhV2sBvPmsGO3p6HCuWPNs5jhFa0oS6 2W2up87ncq0cvcqElGSlHdXW+qOnvf8AgpT8SfGun6X4M8Q/FqCfQ7O4hmt9Z1Twhe2d87mEKRPF pF9HBIsTM6geWd4COwLEhfg/xP8ADP4QT3us+OYv2ozeeK553uvscfhrVY/Nlkl/gaSDao2szbmY k4I5OCf2LCcN5rhcMsJhqPNTT/njpv3s2fMuvTm+aUrP03Od+Bfwz8PeOP2jfhh8Pdb1138J6zez RXN5FbQBgPJlndFS+t5IuMIAXjcKX3AZwa/U/wACfs8+IP2Vv2zta+L3gSbVbP4RaZYQ6RDqdvY2 Vi/ima6tImuEggsore2a3Q/LIUIAlCL+9YSbfnc1xVXB4ytklemoylSU07u6lzWto7aLXvoa0aSq L2ieiZ6n4u/a78DH4mz+KvCvw2S5+IllbyLJcxzSym1tFUBi6xh7e3k2r80kwcrgbMkqp868Z/t5 HRrrX5rZdX12C8jNxaxy2t1cR2ip5ks8IWyViyeWAAwlhC7GYs43NXmfUquJs5PVpeTstt+676nZ 7SMNtbfcfEPxL/4KcftD6fr8Gk6Vp+taM2nX32mHTtSV7E2bNy0MkOTcTpgLt8+diBiv2k/ZJ/4K t/Ez4paRplpZ+KbWz1KS2mn1LRZFW4vPIWRUXN0xyArjK4YvtYPhPMKkx+U08Ph41Ya2007vZ366 2FRxEpTszI/bX8Mf8Lt8YaF4ovvjx4el+EHgppLnVpdJjaayubuOdlnjkaWOFy6EGEOiMzNK8aE7 sN8ef2h+yP8A9FL0b/wV6n/8TXj4itjKnJSw1By9muVvbXdr5Xsa1MPOrLnjKxxf7Sfwr0L4Y+Kd Q8J/BrwbrniLwBqbNdW7ape6a99pcjyCeWyvDEixStDIxVLsRxx3CbJvLgkMltB8w6n8MPjnabZd K+BVvHFIF3sPFtnICGAI3Qpc/LweV2jpgj09/wCp4XBVqtNV1y8zdtX5beaSNXVqYlRqun71rdtv vPoLwB4a+I0Ek8/jJrK2jO1khidmYupOeEVgD0wdxGAO/FdL4s8BfDzXJE1W90+Ow8UKm2XVrK0i V70FgP8ATQAGudgLBHJDqG2ksqqo48ZXpyo1aVNtqS/4P+R1xjapCo1rH/hvyPK/hnofw+8JWGtD X/ilHMLnUBepbaLoWq3eR5OzaWmitxw5V/vAHYOmTtzk+HHwFl8Q6nrWt3HxEkj+2m9sItHtdLsB bOziT5Zrm5mIG4ZUCFSPl5+QGvMw08TRcuSirSWvO/JLZX8+x0YnD0sTJSlUat2Wu9/63O2+D/w4 +D+reP7bwA3wb8RnwH4tv4rW/GseI4Ba2srlczR29nZQmJiwGRHOgG47QFVEW5o/hPxf4X8QaTqX h79mvQNO0OCVbS7inutd1B7C13IJipur4xuQE4bymHyA4OKqo8RipU6GNxCUWr+7G23u7yu72tdq 29x4aFHDNuhF3dk7vpue73fwl+N2o+Ota0nwH4P8I6b4ds72+fwmLPwzosaWNs11AwuM/ZmWSSSC O3EgYANIEk27okK9ddfsw/teeILqPVfEvx3vrW7VQF/su7ks1TjoEs/IReR2A7fWuCdTCyhTnX5q krfak3r10238jWDcG404qK8kl0XzNXXP+CfviHXLuO6+IPxa1LVrgZIa+upp2Vdo43SvIT65Jx7d 65HVv+CenhjSIF1HR/EV3DrNuRPa3pMQaKYdwGQggnGcg4yT2FYwzJUrRpU1GN+iWq67W3KfM7Pq j5K/4KEaz8f/AAH4c/ZR8MeAPi54oTw2+l32hReG9K1a9RJdX0+XMl0baFwks0lpq9tbBgmfLiMY wny14RD8Vf2nvDNyulftIfsua5K/liRtVu/Dt14evoFlZdkrO0KW5jCK4RQsO4kZl619hg8PQxuW Uarkqc1zKMvSTSXmttPuPArV50MXVha8G9vXse6aJ8V/BL3dtY6J4+02PU2uJLaPTNS1fTLq7Y+Z 5Cos2n3EwkZtu5c+ahU7lYht1fRmj+PUWKA39hstnkMcJWdCkrtKUVRPnynwpQkl16njoK4auHqK TpVVyz6P7Mumn9eh30KkIRVSk+aD37r1Rcm+N3ivSNaj0+HwV9r0KS1BtAkrQzOc8Mx5UKylWVNu SpDZwcV3vgn40eFvEupaNe6fvTVfLF08IDSbAMB1UqOcgkZCnABJ6ED06OXezpwxMZ3eja/B6mUM Y3XUJLqe96fqCa/4li1TSmMthI8cyupQjau0M3HXkY/HtXvFhr++O3gckKpGFPYcDH6V25ZeE5tr eR3tpyTW0mzburrbJbTqxO5tpwePUE9/b8c10moX0VzY2lzDxLsKyD+8wPXjplSP1r6JfE2u/wCa Oad+WLS1R5/qUsfnW0p++WCc9s45rhryPTLLxRoOr3m+OWBmKsqg5DgqVOeg569RinWc40nKK1/p HDXjGUXfbQu6/wCK7e2ube8tJw0BUROExngk/mPl/I1d0/WtD8aTy2s2pxQ6nHGFjnlbZ5jdMOTw eMANx0PNeXJyfLO3qccVHWHXocbrNnrGn6edLki/0GO4aXzYm8yNxgfdZTjHOcep9q9a8HfC3V/E OnaPeXlrt08jzPnm2M6DnPRtucfeKnGQcHFFOdKm3JvcGpShax9t+Hvgp4A0PTLK0KK88jsY3llP mSHAY7QMZAHcCsjxB8EPDt4Zm0nXPLnaAqIp1+Q9M/PxgZK88n9a6YYm0+aWpz1KScLRPCfipqfj T4GfBLV10SxmfUbi6NqLy1YBLNZUZgwccxyNt8tW4Cs6tuBVVb5T8BfCGSDwx/wlMJgTW5Gjubso R5cPmOkVm+BGUYXAeGJpHZds8lpbokz3LeX9bHMI5RwnVxGFd542pKE3/LCCV1bvq/lI+fnhvr2d wp1lph4xlHzcr6/h96PofwroB1Oxtru9WSA7bWNo42aVLnERSWXc3O4yJuK8jMhC4Cc3bXS5rPUm srhykqMF5JYoSq4Vj3YA8+h4PIxXxfNZ33/U+qp4aUocyPofQrNjp5ie6Q4j5YHOSMED3zj865++ nYX8rRZEecct0+vOO3WodSzu2ZqHSxPJdTOqxLAApTnZxjdxyMce/PP61zsuqNbAz71ZVwG4xzgD FHNpsQkrtM5Y+Lfs00k8kQGcrtBwDz1x+X+TW7aeP9KRQZncMo3HnIz2ya1T92/ch9mW7j4yaVbo qQNkjk4XPtzxXD6j8aLq5UtCX8oH5cA4U88cH/OKEu5DZ5Xq/wAWNTLy4kcAscE5H+f1rlT8TNRm Rg8xwG46c9fX+ZqZWS03FZnA6z8Q9QuXkg/ezLtYlEPQ7Sck4PAxz7Z5HWuPt/EOozXCBpX2nGBy MZ6fhziuadRR0bNIrrY0pNenh08/aZWMofKsrANyemO/X9K5O88T352yedsZQFLFyWAwewwAPw/G vDzBxk02elhE+XU43VfFVoFeWW/LTEZ3Mc/Tr+NeReJ/iNPCksNjLmTJXcTkrnOMLnr1/rXnJ88l TjsjrnenF67nl2ieJZIvENvdyTxC4bzFzdLvX51K8rhsHk7eOG2kFcbh558aodQuPhn8J9V0y4uI 4IZtRgt5prhXulV3haMyyKq5m2oWZyoJbn3r0KPu1o3/AK0Z5tVXj/XkeNWV9r2sSa7rnijUbm+1 q7nW4ury8meaWd2JyzyMSzE92PPFer+HPDcXjPXYdBi17TdNvpLVpLRtTm2W7FMFlZijqWKlsAjD YxkEgHHEyXtVVtdK70+W3yHT0i4n0N4Q+Gj6Hp2j22jeLtBF5ZW0x1DVrppIRp8zSTSu8cxkXEKR RrK0k6FdzPGiklVf2vVte0/4keE9b8AS6hoEnxnGnBdM14S3qPArR+U0fltJCIpWCRxrJdQymMRR gAIEkjmnWhKt7SzST19H/l/VhyhKCSbPOf2WPDGheAPE3hfWv2kvAF54tsRd3tjr2iaxqlzE968N tPDA0kok81PJ8xfKkVhgAbG6GviHxsNMj8UeIZrUMLZ7+Xyi20FVLMTuPQHp9MGuqjNv28JNXure STa+7axFRWUbdT7J8EadKf2UvjL4f04/8TUXdzaOHJHlXD2dsRGS3RhvQMMDaxKEbkJr8xP2flur j9qz4VaW9yxsYDfRoFQKD/odwXY7QSSejbixAAXO1Rh0pJ5Zik10qf8ApOn6hTVqlJrT3l+Z/Rp+ ynrOkW198X/hHrFnay6V4sNzZRRXHnvG19aWen3tntSF42UtL58RcENjdg5wV8b8RaPdafewaNHD JJdWn29HUnc22GQCQ/KOcBSxwOFVm4AOPi4TlXo1IJ3klV+68P8AJnuQfJioRe3Pf701+h8i/Hll h8E3BdWIa4gI5xwMknv6fp9M/P3hq+EqI6xvtwMHzMlRgkjp6n/DBrmop/Un6v8AJHuR+Nn0TYXa zajeFUO0zSDqG+UnHUD0GcY5598/MP7R37SHxB+EXxI0PR/Cuq3Q0H+xY3utPW+dLaWRpJwZGhO6 Nmxs+YqT8i4PyiujhujTqZ3D2i91Rb00vZp2+fX1PGzK6wU1Hd6el+vy3PBJv2udW1kRQeIPhXo+ oRHLZu7C3lDYPfdCQenXtVdvj/p015YXmnfADwRH5bpM8cvg/SbgTOpzlzJBll6Aqcqccjmv2DM8 ywlbBTw+DpuhN296M2ra9LW9D5TB4KpTrqpWn7SNn7rWlz0fS/23fHHhO2n0vwv4C8L6PYzBGuxo XhLSNKN2ygY80WUEQfGWAz0B6DPHfn/go74s1DSJNG8V+GF1KcSQrbLcXbeRbRIJN6fZcGN95dcl s4CAAfMTXxFXK51ayxCxMnU/mbcn97PZUqSjy+ySXkcjqn7Yfg3xIdOfWfgn4YheGYSGTS/DGjac 9xjaCsz2dtG84wCP3xkHPIPetpXx3+Aer6rc/wDCTeGxpVlIJZmlt7bzbcScuqrCIWKAnCgLwuem OnVB5phqUlSkqklquZu78r81vwFyYScr3cV8vm9mV9H/AGkvhLokMWk22q+Iv+ERNw97PoV1cW1z pVzdMUxM1jLamAsBHGMlS3yDkYAHvHgn9o39lLVPFL+JvDX7Kuhaj4nV2upWmHiSWGEyvG4H2SDU 4rOFQyNGESFUKyOpX7hQxEs01lCMYRa1t+l72b7omMcNG0XUb+R8OftQ/tjePPjTIfCdqbHRfAdp OWg0Hw5C1rpcbKgi3IrO8sgOHf8Aeyy7TLIEKoVRfiv+1NQ/5+P/AB//AOvXsYPDLD0I01FX3d9W 29XdnBiJ81R8uy2P6f0kl1BRNPcGXjYjltxVQAqjnsqBVA7YA7Vde0bBAGFJPGcdB349z/nmvn5x cm23ds9qCXKrGVdWGSA5IcFvlIyScDB+n+H54+n6NZX3iHSLPUH26ZNeQx3DsdqrEzKsh9sKScj/ AArlnG8kvM1Su0mfceg/s1/CS1AX/hGo5AoHMgBzg9h+Ne7RfCjwNZ6dp1tYeF7ONxCrBmiGDgbT zjqT1rzcVVqNWTNYLq9TyL4g+Cre18N6zdaLZwwX9o0d1BcRwhDD5TKxZSccgK2Pcn1q9eaXY6r/ AG1Z2jqbLUbRzHKVx+7mjyGGO5WQE1zVHJxpy7N/kv8AI0jZRlG2pT+CmsWGqJNPYpcK9itrok8c rvseSC3ilaVA2Npb7RhjznYvJwK+lWYt5ysF4G7J9ecfpmuWtFupOKWl/wANzR30ffUr3WZPLjiw MxR5YjOMYXv0rl/EOlltFu2kfLgZwDlsgcjAGO/+elc3Ju29v0C70PhT41+FPB3jD4YeJvD/AI6j mXRo9Ugn+2icINNS6V0eQrN4i0C2O64WyiTz7qcb2RVt3ZxJH+MfjHRNJufA+qaj4uhuX8GxTyJY eLtZ0HRrR9ekRjkR6vpWk6lNcNvWSMyHUnjLKVWdtvP3mRynLLlGDV02tb9Un0te99ua3lqeBmcY xxLb6pfl/wAA4TSJtG8T6F4T8DS6museMLrVr1NO0r7dqHii1sw13dGSSWGwuzKQoQSlorKfzlkW ZQ3mPj1S1u9f+H/jvTvhlNp3iywVrOO9sxp/hdrFtUtGmECBbG9t7C8WDd5pJS5nj8yHGH3MV96G Elia0cPUkm5vROyXr3+eqPPWI+rwdWKaSWtr62PpL4TeJtY1G2l0nVNAhn06aJ7ixnWUmXVVhSDz 5IH/AOPaV1W5hVvJlEceUzKzDFex2PhLTA+neJvBrSxqkh+eOIEwLKGlVwrAGVWWVHCsSxjb5Q4Z QqxNP6hXqYOpNTS3te2qs7XV9HozfCVo4lQrpOMuztfffruum59W/DZ9Tg0+7k1FY/Odows8flkz 7Vw5Zo2II3ZwSqZwcqK9DW4aFjLu+fgH0/xHalQcfjg9H+h70HK0W91+Z11tqEF9aCFZQZFAZcNy WBz0HPOB+takGrS+V5YlBjPJBOMZ6c17tK7aa6mdVav1MfUrrJfYhHzZ56A9e3euM8VTieCQZHmE YDY/Ecfh+lbTs6Vjhqp8jTPnDXvFN7ApjRt+7Z+7OSzg53YOMDBAznnpjvjkrbx1dw3SSRvskMfz q3bGBwc57n8xXByxZ5z5k3FHQf8ACydWsYoN7BIy29SZyqseCQ3YkZwR9a+i/APx2uLbRm0y7kje 1mhKyQyRxzRlDuDKUbK4YE5XjI+tRKhGTYKq7anv5/a116SJIbfUIiWVRt2r16Y4GeT/ACHNVpP2 vNdaBrG4uYHts8q0SZ45+9jP159qfsFayRDqbtmxa/tC2HizQtR0TxDaxz6NcApcW7xQzIw7DDqQ ce/Q8jkVk3fxb0L+35dTu9R1C6M008lzvkkMkiTRNDLGZQVkhV42lXdDJFIhcyxyJKA44MVLFUoK jF3ppt2d9G7J6dLpJP0RtSjh5TdR6Sejfkr2+5tnpvhnxNpfgHXfDevahiCymtXexur21ti8omZ/ s1zOsVmnlF2tr23dWkKR3VrdwxJKLV5k6i1+LvgO+1jWtZ1vSrGQ/apHjmnVUiuI0O0SCO3I8reV MjCQO+95ORH5YHnLE1ab5Z30dv68zshfeMrXR2GmfELwJ4gt3vfDmmobfLq7wSNjovA3Kp4JHPOB +Nc82q6baQ3r+QMyMRExbJVfwP4dB+tdLrwlKzepzuFS1znpddY4ijO2ERtubqeBwM59fevP7rVI tUjMiXyMUOB5Ug2gqcEcZweCPrWk8Uk04ohUubcxktrV5PPu3kdCrAqsyqVOOCDtPfGfXHbrSX2m 6EdywC5Vio2f6bH6HOcR8jp6Yx3zT+uaKxHsdXdnAan4fV2BN+EjGcfvifU84Xn07dKoDw/bBmWX VFEZHQO3Pfr+VJ4xtWUdSVR8zQuNG0JYI2eYMQuBnPzd/wDCuLvtJ0GN5pmvgsYA+6Rx+Z/z/Pml jKlmupvGgjzzWPEfhPQxmCMyPnu4646fr09vwrg9S+I1vKjmGBYx32oPyz+dYRjOcrzZTcIx5Ynm 9/41nnkKxSHgZ6nnpXHXviW9mBMl4wT7xwRjGPw+tcWL1dk7nVSk+W1jgtZ8SCMb4nLyvgYDbi+c nAX05rxrUPEFw1y8cp2sOz5JA9MdjntU4OlJ3uRip2iooZoztfahCkl6URcbdwTbIfTBHGRxnsen ODXqN34Pn8ZfAbw7pjhINRj1jzpLmd1jjCGOVpCc8KVLKuR97buIGeOyo1Tcai6f5M50/aRsUtB8 H/DHQ9PGkXGuyahqjRCRktFzHuGfl3HG04YDv2ANcl8RtBXVdPj1LRdJmsdPgBSOR5vMYgc/eAA6 np7+ua5Kbn7VVJ6b6eotOWyOc0bR9V1/wYl7f69qD6PvudLe4ikkFvsUrJNbxSgGNZFW4VmH/TVC wwwNdHdTza5rN5qGnfEOyt/EskcF0ZtIhed7OZXQEyKRHhGKBf4kAmYcnO6uXlk4um7J/KzfUp7K XN0/r5n6qaFYeFNZvfAej/FzULu98ERyotnrEYubBbksqvJb3KWtwZ4oyUziK4EmxW2sy+ZEe3+O f7Mv7G3gGDw7qfxL8RTaD40udD87whb+HdYsXj1WKJ5BFdyWkWn3U91OzvIBdXV1bRSNaiN5CySA rDSqRlyU4JppvXTTrd+T/wCG1J31kfH3ws+Hnwx8OfAbxV4Y8D/GSTxTod5rWdR1e901bY6bO8dt E0UqxXVyZikaRzPICjN5rDyhtBf5s8Ff8E/te03xJa/Emw/ai+G7apZwXX2fSdL1zxBaapJJJG6B Y5J9NtoEPzHO64XAB5NdMK1KNOtTqQaU+bS10m909n17Cs7R5Xs7n6LfBr9nH446JoPw+8TxPbXO pWskMuoy2njHQ9Q1HzjcM52W8N7LczYiKJhVf7m0E1oa/wDDb4s3cfgvXLzwxqGn+Kr5bjVvKkH2 eWzm8zzGLlynlFX6bipLFMfMyZ+Gw2ExNOvirx91qbj/ANvTul62SPZVai54aTndpPm/F/qfDv7V sN1Y+F5rPVdENjrMN3DHdW0MI8ps5HnRhflRW+X5AdgMi+X8rBU+Q/DVpNq9nLaTFYrxZD5ZDY82 MZCkEA7SPUjgjPIODtyOlhpc+jUn/wAE9unK8rrVW/4Zn1HYRQ2uqX0UBLRCeRckZJG/Az368/h+ FfDP7XFuj/Ei3SWMMToEAXKgFcyyg4GTnr646etRkEnHN77Plf6HBjrfVnfufD1n4r0+C/1CCYxC 0W4aKAFCpK54LENgEk/TA+hr60+E3hz4YePYzp8Ou3EmvLp/n3FtbOV8thIY2wzRlTx5bdf+Wh5I BA+/x9CdKCqU9V1v0v8Ad1Pm6GLkpKNkfK0vj/UIJ5LaG0tzAH2qcyMSAfUsc+v/ANav0FHwB0C4 trW7Gv3Cu6gNmFXIYjOAQR6H8u2K48fS+qzgqevNffyt29TqhjG5OLhe3mc0vwLsbzW5NEh1uXzC iMjLbKxdidoXbuB5IIGM5/SvIfjD8L7v4batpnhm+WebUbtZm8t7byZITEob5lPPOfXv6c1OGlUn UUW+jlv0Suy514NNKHkeWah4Ut4NH1GSSGT7TFAxG5FQ5C91DP3wM7s8dq/Q3wX4L8M+FI/CWgaJ piwaW9xum8sMTOTE5LuxJLFmVeSScLjgYAMTiJ1EoRlpd/glb8zKtSUJRfLrb9T8bLlt006jpuOR 7Z4qvs/6Yr+lfSS3PLe5/UT4KvF1LSNKkisWVFtomfzJgzs23DSMQo5Zg7EBQo3YHSvo34RfDZ/i BqOu2d9fR2lta6fLdxyqhxFIpUJ5hJIKY3E4AOF6ivGwWGhi8WqTXuu57lScqdJz3aR0v7Q3w08O eBB4Ot9BgEV3P9pa5cs7mUKYvLyJGKjGZOgGQec4GPmG20aO/wBc0qzuYN1tLcxxPHkpuUuuRkYI 4OMgg+hziubGUIUcbKnDRKWhWFm6tKM5vV/5n6p6/wCF73w1dSXEe6TRZWzDKcMU9EkI4DY5zgBs ZAGCFtQXQlt7TLAhUlUrkg9fy53elfNYiL1OyFrnJeI7aDUNP1ezuEKwXMTwE5ywVsqcYx6nv2/L wDS/FUmmj4UWtx4c1W5i1QPpX2qwtklt9MNrFPskvX3gwI6WwRXCt+9lijIBkUmOXnjCN0rPr6S0 /ReZUZpXt5f5fqX/AIZ21xo3ifxrp0C266Y2oS3Mka4WSJ5EgELY2nzBJECrEuoT7NGFVvNdl+mt j7ZJB9wx5/E/1rmq6zk+tl+SNdYxjcjE0ckUEYwDsA+Y4GAxPUc8E/Sql5ODp8kEhXyRlQsZJ9jy T04J/H0ArncU200U33PgT9prwzdav8G/jl4d0/U7i1uLnwXqslvLYTPHOZrGM30SBkwcSPbpCy/x JI6nIOD/AD//AAc/4J9fFn43eH4vE+h+JNFstIZni8/V57qIeaFQhD5cMm4bWHKhgOhwQQPs+HcT TwuGrSrLRNPTfW6/Q8LNqU6laHJ/L+p9R/sA6D4S/Zk/aZ0yy+PmsW1h4R8YeHjZaR4ntmRrIxnU Ugn3yzbDbKsllcxO0salGiViohkE1fvR+0L4cj8V/su6/wDCz4V614V+LfxEme3v9F1mwj0xZ3Bv bGSSS6dpjaWNnHpg1m1uLudk84X9ksW3bcFvZqUZ4rG0a1K6i0nzfy8r1v5a6/ctTgVlhZRer1TX n0PjDwrb6NP8Fte0CbWhpmqeE7p9R0/TNQ1KygvNYhlvILaaye2tkIlkslv5JIWdmeW3ubp2eD7M sN1+037Lv/BKP4fah4f+H/7Q2ofFTWpPiFrel2OuTacml6T/AGHeWt1AJobW9sbq2nacpazRWZnj ktpAltE8flSKHH01bI6dLMnVnLmbhFvtLm5vvSt2WtjysDXrxwrjWScotx020W/k/wCrnl37Rf7H UHwS1q2vdM8Vafotheu0VtaatdzLp13KI3YxW96yubdsrGFS7CqAcNeSMAD8h6laXmj3lzpesQbL uMbWj8xGwMlcqyEo65VsMpZSVOCeteLLCrBzlSi7xu7eXl/XQ+oy/F/WYqM17y38/MwF8R6RpGt6 Ro02s2kGrX282dtJcxJPfeWoMhijJ3y7EILYU7QQTgEV6DFdvHGSFJION2RnOcZyMDvn+lehhpX0 Oyskr9yjd3KqGcoRgEgkcnHJ4+v9K47ULqSa2d0B4BUHA56c/kPSu1tONu5w1rdj5X8amUS38dsN +PmICHahBGMtkAckjp6DvXlOi3pigvHe0jF2QAzsT2J3Y7AkZ/D6c8Durxb/AKuedJqMry6MjvNb vL5LuNkZYN4AyT8pXgdeDj0P9K1PC2valpl0geRgVkDISMHr/wDXz2/KqitdTmcnZlC+8eXsF1IW kkEQYhtvO0jqOvue3fpWt4O8VHxX4o8P+GmvjDHeXsFmbgLvMQkdU37fl3Y3H5dwzjGeeKcuWLlf ZfkCUZNRW59Y+MtJ8B/BKy8L6Tr9l4i8S+INWS4le7sdas9EtrUROUTbFJZX7zMTy2ZIsDoTnjkv Ctj448WaD4k17wjpizWdjdW3mqb+3e7USyGGKNYGKSTlnmiTKRszMFCBQrg/LYTPo5hjHg61NR00 d+q6fcepUwMqNL2tOTfyPqv4Fw3/AI1m0/4JfEbRr2TR/Etnea54UudPtFS5W/Z/Ins1WOONpZLm O1t5raEOfNvtK02232tpqGoM3jHxM8TDR5NQ8G3EEdpqkSozMlz9oguYGTzIZbe62IlxBNE8c0Uq AiSKSN1yGBPfisEq0k4LW1/u0f6feY06qjdS/pnjmmfGTXvDE32azeRMNt4cjJ654OPb6g16Ro37 Rut38EcDXczOCMBgCM445OMf4Z9DSjhVVinbUUqsoO3Toa198YtRuIpFlvmU9NqkDn6cfSueTx68 qs39qMxCqGZgQWIVcrxuBA6A55Cg8ciumnhUtGtDKVTXQ5q7+J195u0XbMgYjIyMnpkep47etcxq nxO8QK5a3u/3JwSAWBA6fTrzWrw8eUhVGpXINO+K3iCV4opriRCXIVlfII4PP8vxrsh8SdThgcy6 hODxtIU7eo56dOfx65rlnhIbmirWepyV98WNYuUIgmnGAQQxOD+A/D9K4LUfHmrXLTfbLxlTO1X3 Nkn2PesHhqcG2tWae0lLyRx99rtubi2/tHUpVg85fMkU7miQEbioZlBOM4BZfTPU1nPrsYVDDOFQ n5sAcfiOg69/f0rKUZJvsC1+Zz934kjt3lZpww+6qnP/ANc+lcVqHi24mGRcbYwASRgAHv2J4654 6D8eapCLbk1qawl3R5xq3iVpGaKKVpIwMbVO0MTg8nv2/L8K5t21+fcLS2VUKgqdjEg/oOuR/nm6 MIRSuvkjGvJym2bXhXQ9bh1ezvr5g4WUEpOWWJ1yPlYqy4Ug8kMCM5BBwa9i128nvPgld4unWe38 SKshVh5exYXRMHnA27FPOQc+mKmrJTqQstE1+ooxfs7ng2ja1baNMt3GxackFiATu9CMc9M8+9ev t4R13xZDHqHhW+x9oZUuYyTwhwQSOhAJI9uvGayqy9nONSa0/qwRvKLij5O8ZfAi7bxa2mahcxnW kAe1tT85vH3MhQEABTkZGe2c17H8DPhpqngvwnqvx2/4RmGaPVY28N6bazQySRXDRyxtI0UFvJHI zL5bKZGYAfMApJ3L7DzSFTCSw8qes+XXrazfyW5z/Vn7WMubQ+87b4neOPBf7OusfELx3rVxqF/r WmJp3hzw40JitYog5k+1vBGVWRy6xsk7J5sccBaOU+ea9h/Zy/aE+H/xd8FaZ8G/2ltAOoeDrlbh reS3k+z6jocsqLHNd6ZO6uYJBuiLxsskZZI/MjlVQp8HWFOOJpKzUnZeWi16+9rf1OpW2K0v7IXi f9nj4JfEr4WeH/E8Hi9fEeqXGteF73RLWXz9Tt7mGG3gj+yKXeK6Mts6mBXl5KhHfcDXg/w+/wCC eviH4Pa3Y+NP2mPi7p3hXSb6CKePw9pdtPqGv6pD56blWIGKGzViksf2iSSR45EZHtuGx1SxNKVK pyLWblJeSevvdkv0IUZXil0Pu+Xxra+BdDk1n4L/AAv0rwno1szWLeMdbFveazNLGHt5HguHiNvC 5EbnfYxuZC7BgzK1ed/Df9oL4jaVp2qx+KNZ1XVL3VfES6vrU2oajuingiW4jtYooNgDNGLiaQSS AOxmKliAc+EsTQweEUpNyV7KT1lOy3XZJtf0zto4eriqnJBer6LofLX7VPijRNe0fwmNIS/TS7SO 209X1K7kmupBGk/zTTSSSSXL4CkySyO7Mm5mJ5r5S0232Si4gG0klmCnocjvnvg15OJrwr81WHwv /I+owlJ0qUac3qlb8D2c3YttV1dpJAqpcyg7j1w3U44x9a+Jv2oL9bj4nWLPCogOg2oDAc7jPMMc dOB/k5pZFC2aX/uP/wBtOHGyawvzPzt0MK+tXC3MAaOVX2qRncSw7Y9jX6pfD3wV4e+H/hmy1i0s xZ6u9jBDeG0UF5ZMKr5CqSVMpJJJ2qBuOFBr77NqkkqdFPST1+Vv1PlKCTk3Loflzqcoa6nZAcbi wOfU5/rX7NeGNTvptDsr+/1lHCwBj5kcZAG3OTsC+pPGOBWOaR5nS011/GxrT1k9TT+Dv7anwy8N xSnVfh3d2dzMojfVLOSG6nvMsCfMEnltDGMKQivLgqPvHLH0745/tP8AwW+IPwm8X+C/DfjEXXiC 7htprW2l0+7jLSLcws+GkiWMFYxMM7hkBgM5rypYHEUcT7R+9FPVrR289drdjrw9WMqkU97r5n5Z +I2/4lGt/uU3C2kUkjgfKRj06t+tfdqXmqHWdGvp9MT7HbymTMdzud8pIgXHlgdWzuOAOc9TRC0n BN9X/wC2nTjveqx9P1PxFc7rgv6sTyferPy/3R/31X1tS/MeGf1BfDiDytC03eh3m0tiS2B/D/hj P+cfRPgHWPEGkXl1B4duo4riYpI7yhvuocgHGc8sDjHYGvJwVSpRxEKlO3Mr27fM92rZ83MtNS38 Q77XNQi0aLxBqv2toYXSICONFhjyCR8o3vk5JZix6+teK3HirQ/A3n+OfEFtN/wjujSrqV5FboGm lgi2ysI1copdlBVQzKCSASAc1NdTr4yUqnxSkn21b/4JNBwpUklsj7q+MP7Y/wACPgfpc2n/ABo1 LxPd+LdY8P8A9reHtE8J6A0+lmQtHDLbahf3Qhe+uIJZFuJLe0k0+MQqcX7+fbtN+J3iP/gqd8Tr XxD8NNRttJ8NaR4d0WQQ674Zs4bq5s9bTcGX7ZfrcDVbkNGWjMT3jNA8bSwTRGURw/U4fB5Ng4PD OjGs5Jc0nu90+/L/AHbdtbvbwsVi8VWqqpCbgl0XVq6u328j9Av2Sf2yvD37TehTadfCK0+JGnW6 zXluhLrdQZ8s3CfKNvzEK64Ay6FeH2r7XpLi0l16wuZH+12+ryTAZOPLmRXQAAYA/dOT0+8PSvzX NsD9QxFbDr4U1KL/ALrat+bT80z6bB11XpwqLdqz9epeguoLH4lanFFH+5vtOhu5C2RmSJjDgE/7 LZ/I/X6Rt5RLo8Y5Mnl8nA/DmvJkk5u/Vf8AAOttuEbs5xSVFuw7DH3TxzgEk9iT+pqvNfWdks89 /diKyA3PIzBUTPyrkngZJA+uB3rDlVndlWk2kldnifjDVdM0XxhavJdWZvrO6trie3mlQSCGVyoU xk5KuQBjHODzxX5b/sky3GsSfEP9iO+063ubjwVrmsx/2w2r3UVtfJaahJHFFJFa2s887ef867Ni sEQEDblvdyarB0cTGMk+VRl0fwt2087nHmGHrQVGdWm4qV7Nq19npodR8Uf2b/h/8UfgbZ+LfEfi y8hsPCt/rE1vpvh7RAkMX2u98+5RZNTvorlyryoob7OpYZL7mLOfnrxr8TvHP/BPDQx4O+Bt59o+ H3j/AEmG9mHjJLLUbqwvI9hlkgjjjjhOD9hmQPFcCN4EbJYA19Jk2cVKeKeGVJck1Jbu6es09NNG v61PDxdC1OThNpu13/w5wfwt/aH+Lq+P5dW+Ifi+S8vPEepDUbbV73Sh5bCSTE0cP2yO3ht7Wcv5 cy28eJEPlAOjGN/7H9O/4LCfsOfDXwNpHh/4eaVb6DJHFBDb6DLoy2M0EW3lilsq2/7sttZIZ2Qu HCMVw5+llnEYUqlXGVG53Vt37qWyt0Tu/mzijhaUKNOjQgopb+vdni3xg/a68G/td/ZbLU/DUUlh b6XNPpVrptpeyw6heSKro7yuyOqrhVKqm07WIlwymvzk+In7O3xw8AnUPH8+o6fcaHp9t5wt/td0 Z7a3WH5YUbY48tQI1MLh12RjaUYCReaqvbReJjtu/wCu6RtSk8LUVtex5Npt98NPiD4g8HeKWijP jjQbi9m0mSSRop4VubaS0nTy87WWSJ0ZgN5Vo49r4Dh/oGC6+SYE8/eJ7YAGR3zn1zTwdSM4px2P fXLKDn3f3bDLi5DABidxyec9frXO3QP2GaZV+Zc5OeOe3HSvSk1y2TOequZOx823wNxrN7p4dD5l 9IjoxxhWSMggfg2R7ZGarXGgWsaalFPbLHJHGwYKuSCMgEHv6/hmvJr83PGKb7/ccKStJtGBqNpb WlpIqosKblMkm3C55HIznp7c/pXjszT/AGyWa3uEIUIQSDgk8kZ68dz09CRk0UWrynzXMqsVblSO H1Zrc6rPpl75tqGchlkcKyckDPABySeflHBPau18AeHJ7PVtK1S3Ilvo72K4tfJ2s8371RGqxg7m YsB8gyzDnGDmtK0n7KTjrcxpxXtFzH23+1ddagumfDDVbG3S5urWXVzJHJcRRSTRC4s0+TeR5rKZ 95RMsUV2UHGD8j2PxpvfDWueBrb4TXOop8TZPEFlpttYPptrNaau8swieOSRpd0IBYFSI3BJO/5C yP8AmWXylTzejVg9U9em63/E+mrR5sNO+339T7C+O/7XHjXSvA2j/A20n0yLxPpaSX1rfxaXdW2p W1ul5NbzWs9xGywTpsJlVLmPycGRVIdoUMvi/wAR6p+0T8CtD8bxeRP8YLJrfTPEFoGFpBf6/wDZ 7u9e3S0hlSJDq9rZ6lrNm6EO+oWHiOy8jypNIjX7epVlHHU6HP8AFCNSL7J/En87/JHh8sZU6lRR +00/0/Q+ENP8Q297pKrcxsksWFQxjJ6Ank9OQBjnt1rYtLoSRmJboLMDwOQCeuBwCcd8Z/nXsKn7 OpOD3RxuaajJdjqdPbVpcpJMkYbG4oOcAencAD1/CuyFxLIsQa6ckCMFmY5YKqrgZORjHHsKemwm 0XLW1sjcrI0RMmRn5hnHX6AcVdv7rTbKP5oAY2ORhRlcnnp/X6UmtVYW2xi6ld6YvzSWkQYrlScj B6cce1cxc+IrBMpcwlJchQ28jHpjH/1u1RJMpNtnLX/iW2UssF6hYtysg255zgnP07elcrq2uKkb xTAsdpIIH3weTgYxzjkVyWV7pGsdNtDkItSaXW9Mmhv5rZ4545FuIGxNb7SCJEKsnzLtyDuXkA5H UYd5qTA+RDGRGuFOOA2ewxXHOVnY1Sltcp/Z9S1BiYoyEz/EOfz/AA/pUyeGIpy/2u5GQ2ThSfrn n0rgq1bu1jaKuvU0o9E0i38ox2Q7Avjkt1xntnGePfpWnBEsW4wW68dghYk+hJ/x7msZVJSW5Xs1 uOmt72U5YrtUA4APQHOOD05/z1rYu4o1+CfxItrm5WSaC+tr1EEbAxiSZACxxyx3Pzz8u3nsHSk3 ONr6NE1I7nyFDrUmlxvEYfNHOxQudo3YIHQY5A+g9a9g+GvjHU4w17pkpSa1kGwKzAGNyCOCfmHA GfrW+JpKVJt9TGDSmrFbxzaa/wCKPFd1400+3kW6t0juosAkj964wep/gzn2PbNfdGlNZR69onws uvC0lto+jaHP4g1Sa2LJa6fPczgmEMOjyEy7OQcI5GdrY4sQvaxjGEtYxt+S/VpGkW4zvI8b+N+u Dx8NIjstNVYYHK2gjjCx2VqmxVVVGFReM4HbaOgAHjfhr4cfFb4heI45PhdoF/e6pAiJp8en2vnX QRZY41nH7sfZ4fOljElzKyRIspDuF3CtaTShaeyuvRCmrax3P3P+H2n+Ffgl4H8H3P7UHxH0jUPF FvtuJPC3hu4upLiOVUjYlpgqiEGRiUMUjv8AIWPlHbXyt4//AGufgb4v+JcHhL4ZfCfR7XUtKS9v NI/tJVvZLXYgSWS7nY7b+6CxxZeVHMbwGXEcru8mEr4bC4jESu4qLdutld69r7fiOzbS2b0PHND+ J3iH4rRf8Jv4i1/+1p7y5uWtZ38tlhjjlkiAiw7qBuV24wR5m0jIrfiZ0ur5CSybgTk5z3znuPr7 fQ/EY7EVMRiJKsrcuiXRJaWXofXYSnTpYaCgtWk2+9z58+O9ww8OaUQzKp1FI+nRTFcZx6AYA69/ evHfD91API3rvxyw3McAEfh/+o+tdNNXwcX6nTHds9IY3Fzq3iAxkZS7nkIySThmOR3xjgdOlfKn 7SWh6reeJH1iPTrhrC30mFHnjgfy0Ilk4Z9pVSNyk57MPWuvJuWOaL/Db8jysbb6s7HxL4L8C+Jv EetSaf4SQT2ETNFNqq2srRqvU7cruJA6DaDz2BzX6OWmgWHhnwRpNhr/AIhkjtYIY4bq+uD5YmVF wSoYsSzKjsEAJ+XAzwK+7zCpGVWlTiryWv8AwP8AM+VoppuT2PyY1wpZztHLOryHLbEydgz69M/Q noa7bwn431y0i1u51Hxbd7p9Mls7eCR5pUlaUqjCTkBQI2lYNhyGVBgA7l9OdOFSHvRv2IbfPdM6 HSvE2k2sNvBLfASfxMEf6ddvNanhTUJb3xnFJEInglidUXzVLJhSflUNnsexGCfauKvHlpVpSXRm +H/j0ku6/M9P8SxSw+HtYk2NkRNjbg4B2/ePYE9/cd6/VRPiP8HPiRZ32pab4h0jVb8xzKAjtb3z rEu9tkcnlXYjwM7goU4H93j56NOc3Sq0k2otp26X5T1cc7VoqXb9Wfzugl5yobJZh/PrWl9kk/56 H/vkV9dVlyyPAd+h/WB4A+D/AMXtY1g/Dvwz8O9Z1LxnZ2tuX0zS9PmvbkRLChV1itldnUqVcMoK srqwJBr9Cvgt/wAE6f2tvF+ieKNbv/glqFrbTaRcpYQaxc2ul3IvA6PC32e7liuI8Mn3zHtwxBOD g9eUZLiniadetDlgtdfTtu16I9LE4ujChJxmrtadz6wm/wCCQH7TXjTwv4ds49Q8JaLfW93qFxcR 6lqdwXuhcfZ9jFrS1mUkLEUOcYCoBkAY5XXv+CBfxv8AilpEPgT4l+P/AAfF8OtRubL+2LvQda1P 7fFZxXEMsr2on0swtMBHuRZDsYgBsKTjuxWRuWYSxiqLlUlJK3bZfgckcwo+wdKzbsfh5/wUs1b4 5+I/hN8Uf2bfjRpOkQfGj4Xta2N/Z6C08C/aLRkSTVEaUJJc2d9YmW7ty0aI0cykxxzwyJH+IfgL 9iT9pnxf8LPFvx1tfhTrFt8D9K0vUNTuvGOrafd22jTGxt3uWggujGVuLh9qxRxxhhvmj3tGmXXg Xtb4zGVI2pwkm3bRcyVl6t6JHK4RlrTWjV9fxPL/AIU/FXxJ8IPiR4J+KXhhlXVbKdLgxfMsVzHk rLBIFKkxum6NgGBKuecnNf1UaD4p0Tx1caV4x0ecDQvEHh6z1u1Vim92kKhEbaWAdIpjuXJ2lWU8 rXz3FNC9CliEtVeL/wDSl+Uj1cmq/FRfR3+//hjT1+X7DrHgbWpJiIEnfT9qHJd54iqA+oDKCR7f Wvorw7qMNxaxRTSA/Lj73rnBGe9fFS+JSfb9f+CfQP4DwTxx+0f8KfC5v7C18Sw3niFbtbSGyt2Z lechGUPKF8pE2yRuXyfldNodnRX/ADQ+L/xv8e+KrvxCuo6xa291bbNX0q11m+srO3jljknaAWLN Hdkzxutpny0V5CcRy7Myycam514RTajfom29tlpturtd0z7LJ8nnh8PWxeJprna91Nqy63bV7X26 vy1OB0G68CaZrx0fVde0/Vze/a57sG8ggi8MBYriQSWz3sEk88kex5BfXMKySRQ/NBsULH1Hhf8A aXW28SeGbXw1eTXCtcRy6XcX8hln1G0xmSSOd5orcW0E0TRyPmSJxb4cyGN4XdPLMbiMfCtTouEI ardO17elmveajF66barfHZrl8Mvq4fGV41JWtJKzSeu11pZ2jq07WbOp0/40+A9P+F/xU+HPiDX9 GtodX1TUW0wjxTo86wM4tZhHKGljmJIMaqLeO5wxfeI1KPJkftt6N4fuvh18GNE8UeHtaaS2tfsB v9O8WeGZoH+SLP8AyBL7VEn3i1Kxm5hRcRzhRkNt+uoQlSnTxEVZprSSa6W7ee+3mj8qrQu5Qb92 +61Vt1967s/OvXYbLRXhbRfhXr2ixlorey8T2qJYRLK5zIky/ZoLe5UxlofmeA5VZWKt5it7rqXx G8D+Lv7a0lLySy1szCTSZtXjtHsZ4/KL7G+zTyFWZ9uH8z5QT8kh+SvRq1JzjGUWpSWul+vTqr+r 6mFPD03NKTajf0/H/gG18KPj38Y9InvodP8AF+raVaae1tBbRabq1xtSDLK8SskuFiCxxKqqdu3P bivpz4yftF/tOQeHJIrP4qapJ4T1G1+zXVs4hnLxyLsYb2QuuQTkhsjJOQRwo4/FKUYRl7jTT0tq /wAe56NXAYelialFq6XK4ttN2aurtWX4H5seONR1+L+zNYvNTuG1ZbyNobl7h2njZA7KQ7HKlWwQ QeCPUV7l8M/+CgXxJ8GR2uleOtOh8RaNEvlee0ggvowAiruuFBSbaqsf3imSQn5peldmBxDpSa+y Vdxk47eR+k3wv/aZ+E/xZNnZaB4jFv4jkBA0vUVFvdMQW4VSSk5KI0h8p5Nq5LYwa9tmnE9ncxpK pc52HA447j2yK+jpVYVIXg7qxnrfVbpnwF8SPjrp3hvxL4t/4RPw1E95anULCddSu552uZrcz2xn hFuLcx4ALhGMqggZ3dK/RfR9cj8bfAKw8Vaj4b8I6H8cNK0ca3mCGWLSfF2lLPNZyG3nuXAF6sgj l8vdJNC8ttbSRRm6gYcEKvtfaScbOO3p1PDqua0UtGfKnxd1/wAM+KfDGneOPDsQt9UuLdRqumLG FEEqrESw2DaA28ZA/iyQSDx5N4c0K3/4RddbklLTzRsVCdcs21OucDkd/fPNcs06ftI93o/J7HRC XNGLfTQ8z+IOh6fJbQ3ICGYBkCI+ySNQcAHb7AH8cGu2/Z18G65ruq65F4ej3Xdhoer6zBKlw6SW c1vp1w9pPG0Z3CWO6FuyDkFlAYEZFZ06knTcJPb/AIc2jCCqKa+bPpj9sYLp+ieELixBSG11XUYV RRhsyCzfH1+SQ+/1FfIng74ST+GPEN58Z/iD4msoNPtII9S0bw3cBhcG4u4pWt7y4nhUGxRG8m8i VpUnYSW90sMsBQXHxuUUIzxs6s18Kb+dtD1sS5Kmox6tHnXxB+JUnxV+IOoeJ0vUlsBNPY6fMBFm WBJpQZG2xxPmV/OmxJGkmJhuXGK6r4M/Hi2+FnxTj1XxVeazH8LfEBfw34rfRGVdWsrAXkNzb6lp 5Zl26hpmoafp2sWh8yMSXOmwRSsYJZ1f63MF7PNMsctL4enf/wAni/yPFw8uejiWn/y8l/7az6E/ aE+HuvaB4h13xDpM1i0kGpQ2HiuLw5+80ddQubU31jqWnSKiB9G1qxZNX01/LiJhnkiWIpbCWT5/ tLGSbaqJe7BaJKjRWu9PNkaMBCSwG0KxJOe64BBYp9rw9klTPq2JpQq8kqaT1Td7uyv201/A8LM8 fHLoU5OF1NvqlbS+nzOz8PnU5vPWG9R7aKZoCZopoS7RkoSN68rkHDqSpB4zXo+h6zafa5rOWVzL FJszuZfmRiAVB98kE44OeM1pn3DWNyKNKpiJRlCd7OLfTXW6TMcuzbD5jKpCnFxlGzaduvo2dvZW VjPOiPFgMWPRRuHAzxyPbnIx+W+9npsSIbi2TyFRk3SHaNuWyTnqck89enpivneVdD1F5Hj3ju+8 OWUS/Y5EciLy1zIx8rBJ3Ag4Y4+XkEYJ4zyPFLnWkm8xY4irlVWJdxYKwwNxzyxOCSAQMsD0GK5q 0uRO7Naac3Y5DVLeOeWQKWjB24BmD5bHzZ2gYBOSBjIGPvdTn6nE0gtlhuHESx8YGNx4GDjp9QMn 05rinVdro35GndF6w0xIbiFlupMoEZWCFSTxuAIJIxliGz2HAzxoS6U7SvKiOzBsI7LjGO4Hoc55 7mvPq1e+/qawV3roaPlSb0BO08ElF256Y6VOlsygKqsW3fNj/P1rhlNN+Zu/hsR+Sx4S3APTJ+Yr +PP6etSxQXWBHIF2n7uCBx1xj8Mf41n5tgnZ6F4abOS+BgHkNjHSn2upwWfhH4p6fcRRvZI9kwtD EBH80kasS5IJI+UkkkDHBGMVdGSlPkT6r8yJbXaPnbXPCNpqcMWt+GJhPZscPap/rYGAZ2BXOSuA entxVPwQjWerNbZK29wrW5LcBnHI+o3D6cE9Oa7JVHKm11W/qjFw0uup9gfBb4TeI/Gnxb+GcsWk TyeHNM/03VbqPIigWNZJYo5WOVzJJtUISCyiUgYViPtfx5+zv8YPFWi3Nj4Q0GDR9I8UajHf+KPG Gv3UNjY2lkoZY4Ymk3T3aqkbQ4s4bjy3d3YR+ZurkhKHtvJJfNq7S++wm76osaX8Pf2Yfhtoml3X iOO8+IFxHAscweWbRfDcu/zY3DyJL9rvhHMCFktpoOIwJLY5YH56+N/7dWp6VoL+EvC5s9L8OQ8p oPhKwg0rT4ZGjKOWECR75HEa75gscrMN0iuWJrWjTu+WVr39Uv8Agj6XZ+Ztj8ffiD4r+Ieo2OpX UcOnT+F/FV5JZ/ZoSrtFomoyWzvJIrO8iyRiTdlRvQEKvBrxPQPF/iXwl8OPGPxQnQr4r1qKPw7o 9xbvs+yWzO8l1Iqjo0jRgK+QVMT8YK104yhS5I0E9akoRfmr3l98YsUZyk+a213/AJH6DfsnTtD8 D/hykiMjC3uHIYZPzXMzH2/i/T1zX0dHeb7vUAoBOFbHT+XbBr84xzTx+J/xy/8ASmfaYWL+qUf8 MfyR89/G+d5fCOnSvGFf+1ogpY52jybjHUeuTXivgmy17XNS0nRNB0y5vtZmIRLe2t3ldiOWbaoz gAFmPRVG4kAEjupJfVE3sr6lqSTlc+ivija/DP4D2Guap8U9aXU/HU8xkTwdpMys0Bceahv7hWCx AhkDRjcTvUhZY2bb+YXjj4y+Lfix4r0u01qeK20SSeOK20u0G20gz8oKxsx3sct8zlj8xAIXAH0e RZe+R46uvea91dlbf1elj53McTK6ow6/1/w5c8C/tKeK9H8Jw6NL4NtYrHToEgjvo5EgjdY0Cg7C vzuSpZtjDczHAG4CvCPiJ8WfEnjm/a5vNVklssNJAuWCQhgoIROicAA4646nrX1FHCU4VpTUub13 XzPDlOXIkzxiaI3t1EhJKswTJ7ZI/wAa9/8AiJ8I4vh/NpljY6o9zcTRNJJHcQ+Q0SDAUkbmySQ4 5242jrnjoq1lGrCj0ab+6xC6vsebjQrpSGa3QqvB2zY5/HH9K9I+GGiNF4gt9Ru2VEVZlETbiZBs YZXjaRwf4h+Nc2Mf+zVUn0f5HThWvrFO38y/M9n8ZPGPC2slWBXyAQAQQPmUZ+nNfFH2GSZyqysI wfmOMED8a48ldqNT1/RHfnH8aHp+o5bYR3dpFGnG8KOOT6cd66f7BP8A8+x/79Gu+vLVM8d+h/s/ 6Xd2vhqPT9HtoY4fB1rHhkhg2GDc0rKQeQqkbdxBUAngKCK9XttL0u5dWtnZGPLxHOGzyQR1HPPo c96/QKMpexUt+/8AX3Hn1IxdSTXUfcWi28wKWIZQQd0Z2uORzk9emPp3FXInghUJahmjIGY2+Yk9 yST9O+OOKJXkldhGyPkP4xfsJfsh/tA/GjwV8f8A42fAPRvFXxS8PabJpWkX2rxSzW0dmzvIYZrX eLO7UPJI6faYpjGXkKbdxzyHx5179m34z/Drxz+zX8YvhaPEfwT1C2t9KutJsQq2d9BCY5o0jaKa B4kikii8sxMCGiBXAAJ5cRUpxoLDVZe47tLzerfr+PTYtXlHk6bn+cD/AMFa/wBg7w9+xd+0XrWh fC3w9q9v+zzrOL/wLdaveWtzcyQJFbtf27mJmdTb3Vw8S+d87xiKTneQv68f8EZvAvwQ+Pn7FWuS +MfEHiWX4tfDjxbcaVLo3huHSh5Ph/VrdJbK7uJNXntLRj9qXVs7LsSqlvF+6wAW+ZxeGwuOyrFR xFTl5Emnv73MoWsvKTO7La1SjXbirv8A4KP018Yf8E6vHGuaFZRfDf4laXeXnnLeRnWbOfTmsdj7 h/x7NeFn+VlI4AYkZ4zXyh47/Zo/au8GaX4m1PVfhfr15JK11F4esfC++/OI45FieddPaWYtJ5hc iZEjTEaKjNCZZfzHE4arQi/aQ2vbTutPy2PrcJiacqkU7Xut2rb66/5n4IfGbSvFcut+LtUu72fS tf1S9NreWElrELmJvNPl2scUaQeQN8yQeSRti83+OQh28RsPAnhq60zVPFU/xT1jUtZ0+ZdOS4lV JoZGCh5dt3cNLIdrO6CWOONesiICAze1gPY0MPC+HTk7RvtppFefV+ttTnzXH4zE1p0cNipRp0/e ad5Xb9699L9Gu11Yyrb4aeF9TM11p8115v2qSG7Zr1y0o3gqkU2BLGmAEwSzfOSxchSO3/4Q74fa hpN3Dd+Ho7u5vzJczXl8z3VzIreWxH2ibdMMNzzIS3J7HO2JzLESiqMbR5NNFrvffez7HDTwdOSj OpNzhUtLe17rqla7Ta13vc5y5aXwva29tpEgjtYzIkEUAWJFjLR4RkUBWQsmT3yiN1O4cX4i8TeN L3xFrFnpVzdNbgW9tGiXMoCrNGfMSONZVA3k4YAEn5uQTzNLlqzVSprdPz7d7+ZdT93zUY7K34p/ 8D7jkrDwJoGs6tpmo+ItTke3dlE0FofMlEIym7av+pCoFfZuIxkBlGwFNRuoYII7S1lee5g2M0tu ziJX8zymzHwUDKSQDkksucdF7XN1JwhFWijn5OSMm3ds1vgvay678XrzSNOkQPqGnLZ2yynZ+8a8 iRBhsY+8AeOAc8V+4a/DLR9e0e7spV2R4BRd5kGMY5HzEnnOSeeSepNbVovRy6o0wSu5yW2h8T/H r4L2OkeE9RjFifMjnSQSlSdwLrHjJx139unJr8yfHHha7tbRI9MtCyiTlAeijnJJPqefrmufCzca lpvS+p1Vm7SlFXZ9H/sieHr+X4l2EqiWZ9O065vHcqcohHkhvYfvwM57iv1Mg8X6tpSqbe8ZrdSQ IpRlCP7ozyB9COn4V5+KzHEYHMI1KEtGtV0auzWEYzpWmv8AgGC11ovjLWLTT9cvLTSraRJUkuLp ZpLeQyIVKuIopGXcSMOVwucl1xmvavhpa/Fv4QjX9T8PeDND8b/Dg6dPY6zaaPqNpqi2q3EKqxja BpWgZtkIkhljxMkAidQRE8f1OBx9PHQjWgrNJ80b66/p12PExVNUrwkvdfXzufF3iTx7441E61b6 /wCHTb3l3PNNcxvvVw8g/eEqVC/OzM5wFGSdqqMLUnh3xEqeEo9KuoCsm1AOS24CbeuPTAxnPXGO 5qY80o69CVGMWvP7iDXNNW9XWUnkRjDE00ThgwlBVS2QOpPXHYkjHaqn7PXjnxX8OviZpeueGPDn 9pawhlt4dLtxOz6kWR0MESxhnMzBsw7UkKzCJwjlQpdGtyS21TX57Fcjck3s/wDI+u/j546n0nwx c694m8F2d7pGiXs11bpqGnBINW1BVgSGOCaxuvK2Fpo5GtJLOFHtIbwq3nIhH47/ABO+I/i7xlpv k3moXF1dJ5k897cSM0kpZgT8udiKAeEjVFXfJtAEhB8VTy/nX1FWjJ3b+e1vXbyO2Xt4xcaz1/D+ rfqaHgaxW1ubCICQDaVlBnDCSXMjbkXb8o2tGpU7iCpbOGCiz41tfsto0caDeb1pQjL8zvI5bGRk gEyD09T93NelnWmNymd9HQj+FSojhwbTw+Kj/ff/AKTE/RX9nj4m654z+DOo+H9XsW1Pxb8ONCuI H03zhBP4z+Hkt0b7UtMiZI2JvNGvZJNctZTHMUtJdVlmP2bR7a2Pyf8AtJ+K7z4NaV9tj1qXVPh1 re2fRLh7KEPqdq7SMgO4t5ZVoZYZY1kdY5YZY8vt5+jwmaZjkuYVK2W1eRVUlLaz0vqn6v7jzcTh cLjqFOOKhzOGq6Wfe6OU+G/x2uPFOhRaroUMMtiC8T/aoistuykEqyxOEGMqwHTa4PGa9r03Xbud o7+e2kinmDTLKVO25Xe670yBhQVMeMtzG3POK9TOeJ8dneFoYfHRj+7d00rN6W118jgwOVYbL61S rQv7+6bv5+p3z+MNS+xK8k5hmQEK6HDFsE5I/LvXnt/4xnuT/peqSXGAQytIV3dDz29MAHsMdq+X nXSukj2IQvqzk5dWtiwaGxd5M7lAbcBgcjnoc46Edx9KDyX0xO+KNG6kfdOBjIJHPcetcFWq27s6 acWlpohGiVuImLZGMdj39eO3HX2q/ZlFYIwO7JDE4PORwT+PT0NcVWbtexpZfCdQjpHF5SRHoR8o z1J9D7nj2HXrTy0jmRsF3J5zuPXOc46c9f8A69cL5pXZVtNC7BDK/lA22cgg8ZH4A9Djtk1opBMH ObYFD2wAD1HHPv8AWsZK99SrrZkz27oP30OEBAOWXg9MH2yB29fSoZJgFJFkQwB5POe38zms+STV 1LQaklsiIXDeVyW8sZKgEDIPTtx75I9KyIpH1Ow+JWiSeapk8KXF25BOx2tzJIo5PykZOCASdxGR ji8LDlnd91+aFUleOx8vfD3wf478ba9HoHw98P6lq/iqVGeDTNIsri9ubmNMvIy28Cs7BVBLMFba uSfWv1A8PfsUTaHpFprH7TXj/R/B93GWeKwsJ4dZ1ibZskUNBayfZljeMsoJuXljK4eA42nrxE7z 5Ka978vUxitD7e8B654f+HXw3vNa+BnhSDS/Awnk2+LPGd1/aN7fSII3ilhhijS2j2eYsazLHbHK uAXdWFfE3xd/az0ixvbyXVPEV14x8bSFj9o1KMSxRsGDBreyyY4OVRxLM5ZTkrMAdtZUacYpqPne Xful2X4sd3y6bHywfj349+IfhzxTqE2k58Y3WplFttSs7bUbhYYXjmjlhaVGVQ4bLlEVXGUdmUst cV4H+D/irWbq/wDFV34OXVrD5BcQ3tvcy2ts1yQsU000bRRqFd1YDf5eUVW3qXjrW8KTkpTS3S+W ugWnOPLGNyU/sgXXg3X7T4q6r8W9Bv7bUdI1TQJPDqR3dtqa3Wp6deaZBHH5kX2OTa9ykskpuEHE rBWOA/O3n7I/xV+Jmr+A7q3+H9vqXwm0qGRbmG08aaHY3BK741t4xLcvK0cfkxqXSJhIBIUZd6sO Gtm+Eq4qhWjLlUIytdXvKzS/rQ6Y4Gsr03HV226K+p9x+Efg/wCJ4NKsbbwf8E9U8P6NFGY4dGt/ t1+mn4LZX7TIGMuTufLMSQRjjFXZPCWv6DPqA13R7u0YnpdQvC3OAOHA75r4fEzdTEVZ73b173e/ zPraMYqjTinsloeZa/4H0zx2ukeH9X8SwaZo4uRcXU8to1w0sex0IiCxsBJh+HONmSwBKhT5Rr/7 QujfDLQ73wP+zt4ZGh6TJbpb3/ia6Jk1fUHAI3CT/ljyXI2AbS5aMQkla9fLoSxUIUqi/dxd7fzS 6J+St9/3nHjFKlzO258Q+JtI1XxjHK80rR2Uj+dc3k5LSXB6kgZyxLHJOe5yc9fCtS0O20f4reDb axYizjNvIokOS7GZlY9hnK9egx6CvssHibuWHWqUZN+ttl6I+fxVK/799Wrehh+J/h98XNRkEK+F p7yOMFIYtJeK9jjAHG0WzyDpjn0rldS+Efxa0qws31r4ZeI7KP7u+50e7iHAJ4Zoxxgfzr2qGLwU oqNOrHTpez/HU82rRrp3lB/ccHZWd5FqtlHdW0kbNcRg71KlRuHr+NfSPxf1C9tr2PW9Rnim0XBt rS4tnaRAod2WMn+/jJOPl7j0FztKvC2uj1+4z1UXdGH8NdL8N+I7zVLvxTHPdaR9lVEFveJBl2dt zfOj7SAoVeAcHOTnI6G30XwfoXxXj0nwZpdzBpP9mNLsvL5bmTdzks6Rxgg4BHynHTJ7c+IlU9ni Kbeii9LeRthFevSf95fmdt4wb/ilNZ2E58tQCPmGS6cD0yRnH0r5Vu5GaEbzhApdmXgtgZ5/KuTK U1Rnffm/RHoZtrXh/h/UwdGka+1uyDxEqZkUKM+v869s/sZP+fJ/yNdmKkoyivI8dq+x/rYad4sv 7OzZrJZZbwSSWsu4yBpFRQ52vgh1+bcyhxgMWAC8j48+PX/BWLw7+x/rp+GviXw/b6/4rOlxa3DZ XF7dacBbSXMtsY0nhtb1Zp2kjlkWN0t41jtZ2ecO9vFL9RiM3o4FQ9utJaLysm/+B01PZ4Z4crcT 5tDK6NTk5k25WvyxW7teN9+6frsekfCf/grZ8E/j1pN8vw30y6b4gQ+dDHo180TblUqBcbLYz3Yt w0sCGaS3gDvKI0DspFfPfxt/4Ka/tb+A9L0vTND/AGVrHUfEFzfRC1ntryTUItbWSOeVraz08SWu oPNDHbzyy+THdOsUDzNAqAlfUxeKw2Hw+GlTfPUrJTSTVoxle1/N/h8zgWTfVuIMdk+a11Sp4eTh zqLfPKO/Le2nRN6Np9Dr/gV8YP2t/iFB4s8aftF+LtK0LwPq9vbPpngvRUs5rnRRI211lmjiimlJ SWMfZ2uJnYiUtHGIwW7r7JrE9tbajeWkNnpzySxxXt7L5MbtEqySKsZ/euwDKBtHJZQOSAfGqznX qKVTyu+nyuRmdPK6WMlDKJTlQVknNLmk7Lmdlsr3su24z4zfA39m34ueCbZfi14E0zW9BtZjqema ZqdrbXst1LFCqRTSW9350NoHt5Z5xP5UpjF0+zzU8sL8fXPwI0n4ZeHrfSvhB8DzaaPrSC4nh+HP heDw7HrFrC80lrJcrHayPqV0guLqM7jIkJVVjnuI3fdNRUoQqYenHVtX+f8Aw1/U4oymlfmtH8L2 se8eHvFOp+DPBui6f4n8DeOrLWrRbe71HSr/AE+Ge3tkeeRWllt76Fo7V5I0i8tfsrpI/lB5kJVI +88YfFDVfEepxav498R6RY6Za7EuXutajgtYpFkFtbxz3rrHaBZJJYIALVUgkJ3JFucl/MzTljh1 T9mubba/Syt59Oh14aXNJty0RNq3h/4K/tD+CfDcnifRfC3jf4ezqmoWCXYs9c0u8V0wJYmkWWC6 iZWI3YZHU+hxXxR8Tv8AgkZ+wX8QNP8AFUVn8MF8Kajq90tzLeeE9TmshbMAgItbJ/M063DKu0qL MjuPWvj5wdO8IS5Wnt5ryPQV1fzPz08ef8EF/DOm3+uz/Ab9oK4t7GOCNtH0LxF4cS6LTgkO91ql m0cSqRztXTzlt2QQ+B8Q/Er/AII+/t1+BBBb6T8OPDviqOCxa4l1Twz4gQ29nIqkkpBqcljczucs BHHA4J4AyFNckpty56l1fd9+/n+Z3Ua0adJUpxTSvZ9tbpadPL8tT5J1n9g79sG5gguNY+BmoWIu 7Az28XiG607S5J4kHKhb6eJ4mOFXyzsk52AHOK+E/FemTab4tutP1GxWK7t7fNzHeW+wwXG6W3If cQ6OmzhSOGU5r0qK9mopbWdn93U5pScpym3dt66adfy/U5uXQNYnuJ7S5tY43gZo/wDS8NKrBl+W NScyP8wVVVT0JwdpYO0mxGp+NdD03TVbVtQl1OILp4kkupJ4w6bVeVVV8bPNRjtXAdzheGrphK7t FX8yJq2reh+ovwb+AWgW3jHTPGEnhfTtPvrdWufslvH5YibbsG2NZJGyHZSC7k8ZPpX6P+E/hrqu uwXllYlXvltUvVj8tnMyNKIsL5SnaQx5LkLgda1wNHEYuPLe7V3r2NKdSnhaTnLZs+bP2p/hpdaN 8P8AxLbT6cE1W1vbe0nAnVxHILqONxlQVfndggkHAwea/Gvxn4ZkiNyqROCMnGB1G4Y/D/PWuV+7 WdzqbvHmTPt3/gl54S1LWf2gPGmlaZIUvpfAt4Y9quG3R6po7BVIPU8jPYEkA4wf04+MP7IniV7W 28ReGW0yxugsr6ha3O+whZcIY2hUq8aH/WhgWiQBUwoy2PIzmcIOHNe9la3qxxi+ZqJ+efiz4c+N tDuRDqVtZmSRWZZLTWNOvIyDnGTbTSBeR0OGHcV5vqmiW3h63l1PxJ4ztbNYJlmjnjJ2owbIJlka MRnPGRk+grHDzqU+WpC6l03T/wAxTtqpbHzzqX7YPxU8D6lrmn+GviDJrOlziOKceI9M0zX3uxH0 Iub63lePccZ8mSMHAPbNeg+Gv22fCXiO4uYfiN+zh4fcywGCzPhfVbzRLmSXqXcTfbYnJxnEcSDk 9uK+ypY9qinXp8z8tGebLCQlL3J8v5fcfUWoab8DfE3gzSPGGiax4r0dIbJptbabT7K+tNJRSqqR Jb3K3UiRqQ8jC04RGJAALDyn4nfCHRfDHgDx/wCIdL+LmhatZxW8lpciK0vre9tTJwbiNL63hJMZ zJ8j/Pt8kEtKqNeEx2BxM4whK0m7cstJab+T36Mxr4bF0FKTXNFLeO33aNHv/wC0ha3ut+DtN1C0 1WyvNPTVRJb/AGaZZYvtE1iDI7NHLJDNCwhgMTodu1pSB8+5/gHUPh5qviHTZ7fTtKD38sTqC2xP MCkgFv4V+UqW52gk84xXymEwuJxeP+qYGm51Euay7JOUv6+S1PVr16NKh7WvJRjtr3eiI7/QdH+G /wAV7Pwx4s8VafPZWZB1K68M6tpfiGCyLKysiz2V21nKw27mVLnC7sMQwZa9Y134j/AoXdlHF8Nv FMV39rMV1eXGp6frFsieRGqGKz+wWhZ1k3HLTOo3DCN5fz/VcQUVNZNKU3Gp9Xtbp/Ek1fXz/U8X BSkli0tVz/ojT+Duh6rb+PdH+KHwD+I1q3jHSrsX9np91LYtJeJuED2kthMYZdWS4jkeCbTrazu1 nhnlheN43YPU+PXgfwVqPg34hfBTxnokugW/2g+Lfh7pF5Hfw6rot1dnF3p8YvVNy9r5FpFKt1cx tvitB80M88qrrUlXnOnKSStbbXbf8L/eQlBU3H/hz5j+FvwuvvAXgyysbG4klD3M1xO7oi+ZKyxq SoGcDaqADJx+leytJN4agtr8IftMseE+bK5BO5iAAR/CoU553EnkCtZ1lZ2JVOyTlsYM/iW51CcC b93uJVmCjg8DPr35HtViWZoYA90S8YAOR0Pp74wOvNefWra8q2OylSunN9DE/taCbO252KCTtRcD tjBIB5yMcfyq+lyRFlI9y5wWcH5gRxg854HYdDWMp8rshWcvJHR6NbXN/s3vsULu2Y+Xt7c9vy/P 1LSvDcCRb7llaRwNynoc49e/+FcNeUpPl2Q1okdPDoulwAMIEPH90ev6n8ayoNQso57pJQrYVQvy Zb6cdcH+VcyjKSdn6Bd21ZBJr1oIsxSqm1sDK5BIIHr0zj9KkXVlmVkikztQgnHI7n0z39P0o9nJ K9hczQG+i+VWclgMKuOef5//AF6ri6ilAjiDMwIZhyBjPJ6ev86XI3e+xXzK8kEpIRIWMnY4HX+R q14LTwlpXxF8ND4lSQ2/w+u0uLPWLq8kuooVs5hGssJktykiLIAVLqfMTflGXOQKLV/ZvW2nqJSu reZ9lap+2P8ACr4NQL4b8B3HhKb4ewSW81x4b+HktzZ2+ozINga+ungtri9cwoqSSq8cmXGLt2DC vl3xN+314g0KO/uPgx8PtL0bWAdtlqs0ateBNxJSa5mNxeTYzhWe7Y46nmtqcbpRqxaTevd26uzd +5o6e9tdD580v9sb42eKfGF1qnxY8XW9/wCG7nSrmOSL7VdmW0uXUhGgiLMZDtBHzEhQJCWTCbuJ n0Xxt8adUg1uysrs6TNLK8mo6zqM8mTsjjUxO4k4HlKgSHKAQlN8eRjTEzw+Hi6rlaC27t9l6/1s KjTqVp+xS1f3W8z7Z8BWNp4B0J9Bh8R3MlhcPHcXUUGYbe6kiaQxPJCrM1w8fmyCOS4eeSMOyI6q dtdxBrFjc+YYpoinB3bgWbPUgH2/lXxmKxVTFzdSasui7X/r5n0mHw0cPT5I/N9zgPEn26LWrzxB dzbpEtZdM0O2t32SRzXMRieZmIzvAZ8KpxsQ5BOMdfpGnWuk2VpZRXLCGGFIliGxVyBg8Yz1PPJH 41yzm2uVLp/l/wAEUYWqyZbgNzBdXdwt1ISZPMjO6NfIG1VIXaA2MgtlixyxwcYA6ODxt4ssMNov jDU7aVTgeVezx7QOMHYwIwMZx/Oolq7WOy10cn8TPi78UdU8Ea7aa346vpNONk3nQ3F3PMwcshGy ZnBCYEgYbQWDLkqAyt+PniDxHNrGqmMOOZNqf7ALZG0Ecfz4zxXvZNGPJUklscOLV3GPQ+nfDHwR 8efE+aTWbbVbfR/hbZRMb/Wr9VWGIBgpSJes0hJ2qqkAkMudxVW5T4q6j8KPA+m6lofw78L2dxDa oY/7e1WyhudRudhyXSR1/wBFXdyqxhG5LfKWK08PWnVxEKOHbjGNuZp/FK/w+iXxd3p3OecFLnqS 26fJHzBp3j7T4JIoL3VoIQoAbz5NnOemW4zivXrbx/4fkWGJNa09ZXQSAR3sGXBzjAznnmvRxWCr J3VOVvS6HQxdCcEudfgbcvxF8QWqiPSfEN5BGIwzNa3bqCBnJGxugxng9+Kry6pperCCTxBBHqEj hW26hDFeqQechZg/fJ5H6VyKFalFeyk4vyun+Bu4Yep8cE0Mjh8GlHjTwnoiureSqpoVhEein7yR KQck8E9MVxuraL4WsJ0l0fRLaDUssHnjaZm2FT8u13KAZweFzx17V00sVjJN06tRtNdXfT1eph9T wqanCNpJ3VvXTQ4XxhKqeEtR3YERjwWYY4DAn+R47V8c3euySi5XToGEZRhIXUMNhBBPP+eBX0eU QvSm79f8jyM2l++ivL9Sx4JYNrmjbxn/AEqIjd0PzDH+FfWfm/8ATtB/30ta4/k9ouY8uy6n+o7B 8UbK90u7tYL6w0rVJIm86SZPNhk+UBVC7W2tk7shsgqvINfE/jb9ib9j/wDa68WeIPG37ROv3k1z a6MYLaDStQvbC/s51DvItnPHcJFIHlZplgmhuV82SRUZI2WIfQVsHh8RJe3jzct5L1St/Xc78ozv McixDx2VVOSsotKVk7J6PR6femea+F/A/wAEPhz4SGn/AA0+Afh/w34uNpBYX2pab5hutQSEOAbu VyWuH3OW3HC5L/KQQF/QL4B+IfgtrNvd2Oh6ZcWvjSCHUni0e91AFkthb5aYSKkFvdsqy3UYDr5w 3FgpRAielgqVGc5xkrytovJLZdrK55+OxmLx1arjMTVc6s25Sk9XJvd9DwPxF+0HefDn4jal4Csf DP8AYWsrc3SSaLHOsnmSIrraZuVT7U7JK7SBvM2tvVVSEKXfzXSvj147n+JzyfEbwTFda3bG4kj0 3U/tkcesXMbNFFE8spdX3TDa4X5eDG7IQzLlNuc6L5fK3drb8kc1Ocb3Wuh8+eLPiR8U9R8U6xL4 6jm0/Wmm3SwSwtEFzjAjGNpjG0BdvBAGPlFfqdH4ivfB3wS+FWtah4ca/f8AsprOe8m1HbFp0ohe WGJYi5gR1jSN3nuFUwxgtJJHFDJsywVNzjUq9U1+T/4b5l1JJUklqfN/inx/8SfFmu+Arjx3Ff3H hmNQNLs5brRbuWNDErJLBLDGLi3kWUMfliiYMqKGzhm/mF/4KR/8FFtO+I3xi8S/s/fD+yso9N8M a9HFa6re6mBBfaza2t3pM16JpXTyyLq5umt2kmjiCNuuVaMMo4cZFSxNqi97ey7/ANalQu4JLruf oj+yn+0F+xz/AME+v2Z9H8AfEj9rq28TeMdWu38Rrb6NqN7dxRm8SC38uymvEhjggY232zZcmBg9 5LLtCTKTvj/gqj8NpfiJrk/iia48M/s5fYbuOy8QXUltfeItV1RLaN7b7NaWUksP2L7Rc2/mmNLp zbYl863eZYk8WjldbMMXiMTiFywabXRuVrRv2Tla9z0Z4mFKMYR16M8rg/4Kj/t2fFXU9P0j9m/4 Q+GfEuiXz3mn22r+H/DWpX8sHlmMJNLb3mtWUdowEqEi5DfMVJjRJog377eFPEviTX/B2g+JfHPh OfQtek0q1vdZ0lrhJ18P3UsKST2ss6ExSeTKZIfORnjfyy6sykGuPM8uoYVRp02+fmd09el1sv8A O5rhq8qibmrLT/gnA6h8ev2f7WTUFk+KehXl9aqWubPTNRjv7qIDOQ1vaF5M/KwwUz8pHasbWv2T P2VvEuu6l4g179l/4b33iC53Pc6pqngXw9eXV4XZmYtPPbvMx3FiSSuSxPNeXHD1aDjP4f61N5ON RWkeEXP/AATJ/Yx03wp4m8MaD8HNBs4NU1MapJcy6LZ3k8ThGBhSeRDMIDuB8lpCqlcrsLyGTwLx f+xV8JIPDmm+DfDnxA07RdB0ySRYLS10SKQWql3LRR20NzAkYMjtnDfeXn1r0KdWrjF7ONJ7JNxv bTuvM5qlOMHzOf3s+Of2t/2XPHP7PngHQfFvwBvNb8a6neTXBv5NE8GTSW2kW9ssDsL3ynuvLjl8 zh1kjGYmw5HX83Ph7/wV0+Ifw0vJPDHif4RaVqSwXiIy6bNdW7WqLIS8Qjm+0EyFshmLIeFHG0Y2 y/GywmNq0JK7jp52/wCHOyVKlWwMPaS1v0Pb/Ff7Tnw++PXg3xDBb22oWPiHU5lvFs7y0DykswuN 3+jPKqBSPmLMu3BJGBXw34/8GiaNrvyxs3YYbeG4IznrxXPPklX5oO67nRC8dOhxXwu+Lnhv9nrx VeeK9ettQeS5sWsIY9MI3FXdJHD7pI1ZPkTgkjhTjiuy1H9urXdSjvrT4cfCqGBo3Nx517M8qsmc sZLe3WPYSDyfOPH0pTSla2+212Q+VScpSsj5o8d/tS/EPXpbmPxJ8WNM0jTbnLx22ktEDbkfwCW0 WW6X/dkk784r5U8T/FHwnJez6rc3eo63qTk75bhiu/0Pmy75GHsUHT8R0YfLq83ztcqfXqcVbHUo LlpLma6vY4vUoPix4ul0iXQfBV/a6beRs2nubd4ortE4YxzS4STGMHacA8YHSvOra31u2eK+1G6t VEjN5btMpLNHwwLKcDByM9zwK9elRw9OHJT1fU8916lSfM2er6F8Q/FsifY9M8V301uItrw/apGQ oRgr5bk5GODxjnvX0h4U+Kev3PhPxLoHjC7uG01tPnsmlsrSB7yS3nib93hygeNZIoEaQk+RHJKy q5YI3FUoUo1o1VG01e3q1bXyPSoVHVTpzfu2u7u11HVpN9dLLR6vY/T+38X+OPjl8N9A1O38L303 jLV9Qt/EGoxxaZdJYLG8dyoWK+kjS3ldVkt42UTMV2FWwY2A8B1r9m/446nrcGq6pod1Y+F528uJ rZH1h7WYKY1eWDRlvZU+7kExnG9cjrj5nB5rXyTM6uJwla0+Vxvpqn3+z06vc7cRhaeOw/s6sNL3 9GvxPVvgB+wZ8GrXxfd6T45+PumXXiJ0d4/CmiX0EGo2kxxhp4rxTcDAdwYWtYyPkOeCte8/EP8A 4JvaUdG1C78P/Ei4hvrVZJmS5028kmvlXLmNyLuS3RyF2BorOM85YMWYtrjuI6mKxlCriMO1CFOM I3eumrfVat306dTmpZbKjRlGFTWTbfbtb5I+Avjx+zZ8Tfg0Re6joqtoxvEt0vJJ4J47x3Z1hEUk QXJaJGJR44yhjYFMGJ5eO0Twfa+LrnwvezfEOC71XTraRraCK8e5NmZBh9iecQMghCdoyPxr2MPj qVXDxq0rta/L772ZxyoVU3TlpY7DUNRk8F2yQ65f2UdvDG7rJJdSpJIoALsFCkyEBegBJHGMiuHv vjF4S15Lyza6eEiZvL83Lx7EztKsIdwUqzEnKZK5MZwpraOIo1FzcrQexq2S0afYuQeOfBdxqiwD VbdTFL9pERDFgpb5Vb90FxkdCuDk/Lg4r1D/AIVt47kjhe18P3MsMi7uI5dpU5A48s5yMc5A5HTB zjWr0Ypc1RK/cahOnvFm9bfBv4n3KNJH4PuPs+0oSIQCc5wfnZcew56da4+50fTPD+o3mmeKvEdh p+pRxrFcWkmq6Uk0e7DoWjkulK5UKRn1QjGRWceWafs5pv1v99hubevL+HkdJZXvg2DdNba3p9zc 7Avz67pgGEwAvyztyMeuOnoca0XiyzCBLZrB4yWIP9tWjEDpg/NlR6YGcDnjrLoXb9pUt8n+pnz1 HpGDLNvf+ItWWV9M02KaFXbLQOJNu7JA/dnqcke+KtW3gT4i6p88Ph+/MbLt3JYzkbSCf4VbPcen H40oxwkE4+0uwca+n7t29C+3wv8AFIRpNS0rUI4yh3qNNu8hBxk5j79QR+NSXHh620K3SPVLuaBG VTm4t5YevGcsg9h/+vFRUnRdkpr7xqFZ7Qb+TMyPVvBce4z+JYN/G4LcKeB3OSD36+35PGreA45F eLWonbkhVnj7/U4rPlT1UkVyVk9YP7jTfxj4Mt5CDLE3QMfPD5/755PXHf8AGvEvjbr2h+L/AAnc 2WjwBRbSx3UYRHUfJlWBLAZUJI+MHqAPqUuRVo+9qP2dRJuUdEfHVlqslnL5TQvJI7fLGg5AOBz2 J4zxnrzzmuwsbfU/EVxp+kxN5Elw6RlzDLM8ZdtoHlwI7scsMKqu3+z0z2zoNz5nr5f1/mQq9oOK R9u+Bv2fPAGhwwa7qts+o3EkccmLiKaK3AK8g20hZs8ndHPuKtxsQrge85hlXKw/IPlXnp16fTp/ jXwuYYvEYmvLndlF2UemnX1fc+lwWHp0aKkt3q2zIujEbwKIztGDgNwecHrk/wBKydQtZZbe7+yy BZDExR8Zw/J5xz1x7nJ6VxXkt32O7TczNLiu7jVbe1llZ1t7Rrqbc5ZVl8pwgKcgEDLAjHTtxW+b nUEt0/fbZPmACtnGDxjOPY/h3ppxd5GUG3Obsv60IGv9SaRw1zleMgoCce+OarJqGomQrGQEGfl4 4OfUc/z6e1KKT6mvY5Hxt/aWreF9as7eDzJpYTDFBC8kks7nhUVQDlicDHrxyeDl/Bf9jrwZ4G0+ x+K/7Ul7LHcbGutJ8D2EqfbLzBPlzXb7v3cQ2yOV4X5AGZiGgbsoYz6rhqlKk/3k3ZabLrL5dPPv qc2Ihzyiltuzmvi78WdS8Xk6foWmW+k+GLZfLstLsgVt7RPugqOA8m3O6QgckhQgUKPkLxnpwk8L a5cNGd4tmdyxwRt6k5HyjA//AFV6GAjGlOnGL6rX5/n+pz14qNJpdn+R8g+NLWC502CZLy0Fu8wj WaNgxV8E7WK9BgH2yPavJYdOurm9e2RRI0amQledyjGfu555/Sv0ahZUrv8AE+PlvuSqbO2nlMkU hOCAygnt3HT/APWK1NI1jVIGuG03xLfQhY8xqs8iFSS2QAG47Vc6UJr34JrzSHGpODvGTRraf498 ewRPdW3ia+kcyEu8rtKu7qM+ZkE9Pyr0T4Y+OfFPirxLqNrr2redaxWbyBVghjwdyDPyIMgZNedj MFhYYerVhTSklpbT8Fod2ExeIdanTc7pv1PWPGs0g8L6nIshSRUbaytzkdCDnsR1/Gvmi71zxDeW 7adca1NOkisjrKyvhG6jcwJ9e/escoivYNtbS/Q0zT/eF6G14L8Lmw1bTNVgldpYJVnRgRtDKcjj 64P4V9F/8Jh4m/5/W/Jf8a3xKjVndnm2v1P9HvTfGPwoutJedYbr+1S+2WTUI4jaJCMbnkyGaMls EMivxnKdmr6R8Xru+8L2+jaZ4It9f0HQzJGwszamVBLiEPDtt45yvlw7vM2syZjaTBVa+9VGjC0Y rR7/ANf1seY6j5nzv+u57poPwx+Buqa34WbWkOk6dqy27CHVryLT4VeaLzPs/wBqup0drleF2RxP uYMy71IFfP3xr/ZvvvAXxIng8NXs8V5bXFvc6RcG5iZp5ECbztGMjzd6qm7ft2k5+YjPF0vqVSli af2dXbbTz2vbtey3HSqSlPkk7p6Iq+OfhfYftE6do2seO7e6mhvkaC1n0mDyZdOuIGAng8ycyJIW iWF5CfNAEsaAKyjFrS/2YW+GvgrXfGfhzWZl1bRLyyXT9Tt5mRrcZkjjaEowA2XRscSLsZd6YAJ5 ipQUXUrRemrS+f3bFKUqSsv61MvW/F3h/wAcaRonxD8Q+CtM8U+P7GIy6rFPcTWi6nbM6NLLJbnZ byyI8jTyxxozNscrj91GO48f/toeH7rSdYsfhUt/aeCbCGGwjvrWB4tSH2aZZxNNfXC3USokCOQg hwoncCGQAtHEp0cLSquGl3zW8n/9tf8AA0Sc0qfZ/gflx8XP2hNS0/xprvhTStfsdb8V3U0sGoa9 ahL1Zgzus0kcsyoHubiNA3mKkZhSX51FwCbbgvhx/wAEff2OPiT43vv2lPGHiLVNZOuXA1W+8P8A nTRizvmbbdFLiK7QSwyTCd1iMX7tJFjydrM3yFWrPE1ZV1PkcdO++ul/Rdz06dKEYr3eb8D9BvBv 7Lv7KfwD8NzeLfhZ+yzY299p1qZLGXwr4aefW7kK6KYkkh+a5nbcpEcj7mQNgFYXYfCP7D3/AATl +Av7fvi34wfCpPEviH4d614Gvv7R0Wz1PTbW5+26Nqt5f3qwyaeywPZ3VrBPpVlua4ugYrWEcoIl j6Mldf6xi4YiTaUFJXv71pRv6aNhXpQqRio6Nb2/r8T7O+Ov/BO3wl/wTk+NP7Kem/BH4neJxoHj DUL6PxDerfyWN9dGxigkFjI1k0Nu+mzyPButPI8yQx7JZbhCiRer/EH9jzwv8fNb8NeLfGmgQXOr 2d6iLej5HKBmkSGaNt0cozgZ8sSY2jeA3CzJzxlGUo/Gm0mrq1rJL7vzub4KEdbq6XodJ/wxj8Mv CFwvi26+D/h2DWlvxcWVzqenQXF/bsuVMlo10JTCikf8syowQQMHNdFf6T8QpYTNoniuwhv2uVIm vNPkuYmiJG9AqSxOWKlgkm8qj4YpIoKN8jaeFrKNeF2rOzfc67qrBuD0PGPEuj+NYbmV/Fuh3sFp nyreawibV4UeWYrBCJVSK63hAGluntbeFBuHmEcnxvXYp9St5NS0jxRaaho8sxSKSO8SWFtrNG3l lWZZVRwRuRpAD1PJNfb4HF4XE0k8MrJbrZr5f8OeJXo1ac/3jv5mO/iiDwfJZ6lqni6HSRMXhtbm fUIrFHZwAVVnePO7GMA5Y4GM8V22ovH8W5k074qfBiz8bnQog1rZeJfBdrK3lMAT9iudZWCzckEk mOSQ8nByRXJm8MplFzxc7VLaOPxX/wAvU3wn1pNKnG8X32/r0PIvH3/BNH9h+2u7P4jjwfP4Lube S4mvdQ0nxFe2kMqT288MkTQ3zXNjFgSs8Yjto8Mi9K/ND9oz9mH4PeEbfWB8Lf2lINYdQ01vaSaR HPbafaojvJLdaxb3Bgk2LE7N5NsTx90AZr4aGOr+0VGK5nsu9r7s+hUVGnzVPhXf/M/n2/aSuviJ 4C1ex0fRtDja9VriO8kudMFysGzYMq1whjQEfMGHVcOPlYFvjqdvG3i+ZoNb8WtLgGMKbgyKmc5U BDsUc9AcfnX2WEcKdBVHH39bniYvmrYmSi/d6XPWfBH7L3jfxpMjaPok+pQE53xPsQYPIBwVJ/4E MYr9Yf2X/hT49+BltaXNz4F8HWOqwSl7HUtT8MR3+q2m7AYx3emus4BGQFlmOATwD148XjlVXsbt L5r8f8yqeHjBXnqd5+09Y+KfitLYv4M/awtfClqtgLW+8P2oayh1KdzL50kl1BMLoI6MF+zukwGx jzvIH5PzfsnasNbNnZeI9GudIi2ZvLZLwo+SdwRbmBWYrjJLKqHcMMaxw2JWHiqcYfNNasp0JSfM z2/wR+zD4E0hYJ9dv77U5Ypt/k7hawuozhWjTc5GRnIkGc8etfbHgfxx8MPhDfaHrvibwba3eiaT DN5Vg7xNevanzHeGykunDqxLM0YSSMCRlIZDhxhVrTqYmEqmya0XbqdEafJTlGPVbkU37UPgTwqu rWfhK3vr/SLq/v8AUbKOPCQ+XdXU9wIzJMfMwplMe5o8sE3EDIrxbxX+37r1o5sfD+oadpQZgFSC P+0rxG7hvlMR9MND9SK8/wCo+3quNKF1f7vXsdLr+yipVJWZ8v8Ax+/aX+IPxh0PQdJvbvWf7Os7 o3vm65eGGCN9vluYrZWMcAPmJ8425yAVOc10n7PXh/8Aa51LRGi+F3xT1Dw74VExmggtvFVylldy ZYM3lWbPGwJHO9QCDnJr1qOXUcNg1RrRUnrpbTV7X8jz6uYzlV5oaR/rod/8eviL+1E1vp3wa+P/ AI+tda0yyFnqtiltaWyBWEMkUb+attDLIwWWZGMu4k7mBYMrn5JntopnB37ZscsDjHtxjJ9v8amj TpYdezw6tHt6nbGr7aCm2WLa1MtzHbs3yuyROwI+UE4xx7cfl1rzkXAj1G0XBkQsuIgRljkcsT2w M8jnntnOq1bXkO2qd9ztfCD2TQ3rWuHvAxFxJuBcu4Vjux2BDDvnBNfup4S+CHxXfwf4G1vwh8Qr eTT73TrO78hbkLcIssSOc+epHTjO7gg/KeDXkY6tRpVYrEp2d7Wvpt+H3k1qdaok6FrrozpZdD/a N8P3vk6hoiS6FGuJnRN5kGedsivtA4HO0jg/SvxJ/a81fVdU/aL+Id1rGnPaahLDpavbyclUWxt1 QnIXkoobp/F36noy2FF1ZVaFTmja34o4XUq3VOtCzNT4RfDDwn42tb+LxPDdkRRpLbi3jaRd245Z 1UEt/DwBg4bOK9tuPgBpC2uzTfEMCJ1ihlsxCEHUc569c4UfrXXHENuSvezZtVp8kkutkXPB/wAI V8NawNS1q106/iEZSOOIiRd7YwzpIArADIAO7nB7Zr3Oz0nRIIxBLodoIySoQWsA+XgcbRxwfY9K yrKEm6jQ4OUVpJnRL4b8KXjPC2jWm6Q5ClFBznIwOv8A+uiL4WeCphiXQIjvJY4L9cYPOf8AOc9a 53GKTL56l01JnOy/D7wDC4Fr4WEnOGxc3EYYZzzh8Z6dv0xWY3w28FSOwOlBYzwUjuLj5c9txfd3 5PXmuFzneyZo6k5fFIqTfCPQL2RxY2t3HuJ2/wCmSEICCeN2Wxz3I6nnJqHxL4S+F3gXR/7Q8d+J DpliBkBr6bzJj6RoCzSsMn5UVjjnoK2p1q86ip00nJ+SOeUVJO8vzPlSH4rfCzVvEMmn+B/B7z2e 7E02pCOBLogJgiK0WKVB+7C4aYqc7zGshL16jYeIrzV7fUptP0qzsLMReUbewWUKSVOcySvJLhlG ChfaSoO3PNa4+pWoxcaktdPxOjCUKMnGpu0ei+BvAaeJzqs1hdXkOpQ+WJXs72W2YqwZRyjqc/I/ tyK9At/A/izQZFlt/EmtzADpdalcXAUccESO3Tg4I6Z7V5adOtBKrTTt1tr5a2Kq1KlKvNRk7X01 JXn8ZRytLJesYg2Bm0hHA9flJ659KpnxDrNn5yS6XG8agowRHzgkcZyAvp36jtWUsFQnpB2f3mlP MKqfva+pm+EvFVzYtefbtMnkvpzcTPJ5isYwYXxEAkalkRBsBbJwR1qZfiH4duJls5/tqTEqgZ7X KZPGBtJPPTp6etYTy2taUqVrXe7/AMzopY+nC3tFqXoPHfg1tTvtIn8X2sGq28piuI73zbJkdDtK sbgINwOQeeo6DFdLYXOl65LIND13Tby5ZtpWz1G3nJJAPPluccCuGpQr0X79Nrz/AOCj0I1qdlbq F7DreiS2N69k8d/a3EF7G/kyNEGikRvmYjBGQODjPUA9K878f+Pde8RTaxrerXUkl3dFVluS297k kDBIUAKAPlVBhUREAA2g1hSip1FK/l+tv68gnJOXu9jwrVEt9LsbnVtTvo4NOtYvNkmkmOwc92/v HhQBnLEADOBXzdffEfR/FejeJtOs5nSVYo47BfmVr19+XdwowFAAUKT0LEgkqE+ny7Dzrfv4R0g4 +m+v3LX7jzsXWhTjySesr/l+p4drvgvXdct28yGEqpDKYsl0Jzg7iAccnjH5VxVn4S1TQNSe7vrY u5G1QMKOSOTnoPf8q+3p1YShyRZ8s4u6Zta54f1Jpo/LhjkypkkKiJ2ckkKMSDJHDfNgcnGTWHf+ EtXuNLtbgacYrtZHEjeU0a+WFTHHqckcdfpWsZpcquK2hkzyXtrAun6fEsEiNukjKox5BOTvyCeM ZzXZ/A6Z5/EuuXUzbrj7JtkLepYHBxwBweMY6Vz4631Ks+tv1OjB6Ymn6ntfjGLzNAnhlUjf8nIP VgcDPT/9VecaF4DW5YObMNnGOex7Dk9jjH1rzsum6eGkvNnXmK5q8bdj3bQPBFnpzxthVcYK71JJ HBI7/Su4/si3/wCmX/fNEqspSuos4krLY/qL8Mf8FmrPRdY1B9G1W5sWlUpE+nabZ3QmDo8anbJc KOUkJRwDtLhgc4NGu/8ABUPwpe6paa1d6drWr+L7o3EFv5PhrTIbuYOr7mCQXKhpU3HZNIyrCSpL DKMv6EsYlyqNlJadT5KpiaaqWlFp7f19x9eeDP8Agp1YWE0Mtl4U18lAk0cV/pVlBcxXTbQ6sINZ dZGXAA83zweGPI5o6r/wVn/Z51a21C/vdZ1i6097Wa1udTstFOvWul3TfuIp/J0lpLd2t3lidoJS m8jaxXzQR3yxtGpFQlJXta/rpfVJLpuTDF0HP3L/ACR6L+z3+2H8JviH4g1/XPhL8a7DxPo7RQ3U httI1fRNQsJLWOIpcjT7uKNYli81UdYGuYkgul2+W7w7PuPxZ+0J4Ls/D9xceM/GELXOvWDj+0YD dTzHzIy7i4jMLJMIyySRysHQFISDIIiI+KpJQpSpSeqVr776Xv1TSS9V3R7EJe1SZ82+DvF3wo0D wtq2s6X46aHwdBqcNhf315aMGU3AldI0YFnZmit5mKpGjnyvlUgEr+QP7Yv7RPik+PbP4H+GvD8O kfB60tF1HSLqFAJ/ED3e1ri5lmdFnO4xxRiNvlSKGCMKCsm7w8wrOFNUnvJb/LmS/C/yO2nBuV/v PAfD8kdglrqt8kRijUubmc/uIGUBgWXjnjOd6kY781+nfws/be/Zd+BXws8H638XvFV+kSC9jW10 fQtQuZNSkSZrgRQXBX7I5aK6tzvMxCCdC2QcV4uCp+3mqV+vptdnoOThFyfY1td/b40Pxvp39t/D i8u9Z8ONaC70qOysbmFJLeRsIY3nRNhbG4ZT5h8xGBmsP/gnn+0Re+B/23da8V+O9JvtE1TX9A1C A29zbhbh7WCREjn8qEksrOkYKsu9toZsHax2wlWUcVXw9SLjU5Ki12dovZ7dPyHKKUY1OZb237o+ yv8Agov+1j4G+Ifw/wDA1nJ4o8zxP4Y1Fb3fqMlvFJfJIBZuqZKQySyGaP8AdqoJP3FC8HwrQf2s /jRfabpkHgjwb4i1SCOM28Nlbrp9olgJVYIt0GuIi0a+VtCkueAFUKCq+Viswq4LDKM07yk5Kyb0 sl0N8JRjVlOz0VvyPozwX8R/2jfF+pfavH/gfSNLtIokSzEmpvcRyRKpURhYAxhxnec9WLHgsSPd ybi50+2tbMJDPGULDT3mjVWwB0WQNtx1QtyAK8j28sTN1pQab+/9bHZKEaSUabGyHWLeKO2gW2WZ gTufdJuYH0BJ7EnknryM5r5H+K/xz/ZD8Napdav8UNW8J3viuQ/2fMqWEWtX8jplVtnjhilkB3Nh YnUDLe9YVcVSpSvGTi9t7fkOFGU9LXPii+/4KO/Bb4aQ6vofwL/Zkv7NGMn9pwfYdP0AR3K7lEi2 dokjXoyoyV2s2RgnqPlj4l/8FBf2kPHVtqyaZq0OgeGmhCFdB0kExljhfNubpnmtnB3L5gSNTtJw ucV4WIzJzqqMHo93u3/w/wDVj0KeGUYc0tX0Pzy8dfHWyvr5Yviv8bp7nVrrZbyx3utx3V0qjGGh vZA8ttwr5k+0wZPRgSBVnQNG8D+Nn0/Wtd8ZXzae9tbW1peQW8eo7kjI3Ks32iPylwAVeLcUPZsE t7WBqTpSVSdH2dOW0ravvd7r00OSeGliF7ONXma37eSS/U+97HR/gZ4t0j/hGr29tNT0aWMWslpd wxkXHGBuhfYr5zk7YjkknAr5U+LP/BNf9lPx9Jc6jpHhaXQNYkZX+36FdyWLIFH3UgIa1TIIyfIy TzX0dOUY3qYWpq9+qfqv6ZyVsPJtRrRtbr1Pm7Q/+CfPxF+FOuwaz4A+Nd3e+H1lxPY3IitbtIfm C4vkWZg27GT5CcE45xXttza65oumR6d4j8G+JUZS3+lR6p/apKKD87yWqrLjHJDxjrjtVOUKjarw s/Lb/Nf1qZqlKMbc/wB6PA/HVz8DvCci6nfatM+ouI5X09Uzcnd8wJjkAcLyTzg+/TPzH8QfjtpG lWc914c8N71jZtpmuvLQRkkK38LA+qncOuCcVm6VCE1ThNu7FzVbXmrJfifOuqftI3Ztgl1r0rXR LZg0vKLD6AygruHPZ278V5efil4v8QTXEPhfw4yNy5l2vcOcnl84CgDIByCMkZNb08uetSvLlj27 +pjUxllyUtW/uP09+Fv7A2ual4LsNU/aOh1zTtBhmWAabbyrFLpsUtrbOLi6ZY5Io7SF1lR2JBib c8mxEkev0Y+H3/BPr4LeC4EsLLwxYxX8kagzXjpczHaeDtclVILAFgo7CuKtjrc0KGkL9Or9TJUp VLSqO7/yPlj/AIKFfsfPceE/h7ovwt+Fer6/40utWlml1DQdPlmttOtIlzPHcxwgLGZZZopBJIoB FvJ8+A4qP4U/Ab4dfDT4J+Em+IXxAs/DfxeMdwL7Rba207Wzp7RyzRRqRYuG86SAIxM1yoHmeWdp QrVRxc5YeKjO8k3prt52/D8iXh3UcoRVkfnn8TtVufEHj3xBf29zdXWlRzPa2ctxGsTywRHZE3lK zrHuHzFFkcKWIDtjJ8/ks53YP5EiqwDFtp+X6Dn19fSnKV9Wz1aVN06UYPoiCaOeAAkDfkHpyOM9 P19u1cI2kpY6rerGo85ZGi3gYLbSR14PYfl2xSU+W5dnozV8PeB4dE1JtZS/kdZImTymBBQsc/e6 nAAHI5znivpDwf8A8FG/j/8ADIT+EvtWk6to1ii6dYwavpZUWVvCPLRUa0eAvhFUbpC5OMnNQ8NR zScvbK3KlZp6kVa7w9uXr3PqvwR/wV6tLA6ZaeKfhbd2ulww/wCkT6JqqXG5+BlLORI0VeOFMxIx 14wfze/a0+O2m/H/APaA8YfF7QLW4t9L1SDTEjhvY0SVPsthbWjBlRnUcwk5BIOe3QGX5NLAYmdf 2nNFprs90/0Ma+KjWhGKVmnf8+p9K/ss/tAfCP4c6Vdv8SdDe5jlt/ssklu0U5QEqzFYmIHOBncH IAXBGTnZ+Jn7a3gC316O3+FPgPV7nwyFVpZ9fu7aG4kODuVI7dHVVBxhyxLA8opFaYbA14V6jqSX I235+noTXq06nLUXxWSt0sjE8N/tQP4mmmvbz4S38GhMShvba4+1KG/u5aKJSc9g2fatr/hoDwe1 5JBqOj6tp9oP3kU9xZTRqwGMj90SfrjI96qdGmpyjSmm/X+tSYyvFOSaPRPDvxm8D6vC5sPGsKBc ErO4jHT/AKbANjnnB/lX0N4X1a31yyTULK5gurbOFlgYEZPHJXIPUdx/LPFWpTg9Voap89uU0ZfD OpESXDqxtVK7imSVGeuSOByO38qemn2GnqXvruKBD8376YIFznqzEdcE9hxx0rzJRk31E9Hqz4w8 Y/tSarfwyQ/DvSBZWDqGW8ukjluD8qnIj+aNDncCSZAfY5Ffnx8S9d1bWNTgvNb1S4vdSlcs011O 8juFwuCzE564x6dMV7OBhGlV5Fq9bsqvFRp2XU5LQL2fSddtby3by7cthiG/p/CQcHA5xX6R/C2W HUNI84y/u5wwZcniTIBxn3BGa5s+Vqcai+ZrgL3km9j6J+Bz2Vt8VvDml6iyrY6lMNJbchc75sCE KvTcZ/JXceis3av0nn+B8qq8ptCAp2rsA2nvzt6cc15GFnzKUL9icdFqtzd7HG3nwqvIZH8tGjT7 zFnLHHToVPH+Fefar8NZomkR/II3HLyqvb0OP8+1dXs0+rOTmb3ex5jqHge4tmleHS7URLG6qUyN 4ZdpyVJ9fw9K8A+IGj6j4V06z1u1WW2nS88tZbe7ljYEq5wrJtOSFbjpj6UOPLBpef5G2G96vTi9 mzx6w0nQfEVnZ6tqTyC+u4o7meQys7vJIAzMS5JJJYnJ5zzmuc1z4d6VHaPJazEPuyS6qxIOOmME /ifSvOhiMRGqubVXPeqRptO2lkYPhDwlrVp4r0kWeryppqXcRuIIZpFWYBwxVowSGyp6H1xXt3xS 8S+H/Bfh6XxDr7smnR5kVI13yzkEABRkAknpkgDPJ9FX5sVjqFGhG0nptbV9WYRkqNN1Ju63Pzc+ IXxi1P4lotrc2/2bRS3mQ2UEhbyhnjLEAO+OC20dWwBmvV/gf8ItO8TS2eoyC+WFVy0bjAf5hnkK NwI4ODX2M6UctwCoQd136t9z5ydedes5y6n2WPgv4NtbcE6e6ggFmjklLJ/497/r+XE6v+zv4e1m PypLvUDEw+VWlTdn+Eg7N45x3/hx3FcNLGzhaWg3SUloeYar+x54dk89rXxZLHMBhBLAJWPp88rn Az04z1NckP2YPGemRT6foXjKFbdWbP2pmK544wAAvUV3wzW+lWH3GToNbM4vUP2YfEMUUgi0xp5+ GmnF5AxkJ/3iMD0wP15rF8NeAJPh7qN62oW08M86qg80EAhSTjIHfNaV8XHE4adOL1f+ZphqcoYi Dt/VjpPFgfVNC+zaZG73Ms0YjHHBO8Yx07n8vrXTeD/AHizTLRJZbKcu3HCDC8D8e/1riw84RwvJ J63Z0Y67xCfkj1PTNJ1W3IW+tyBjLeaMHHue3r/kGtr7HB/dh/7+L/jUSqNP3WccpW3PgvSfG2p/ DjxXZWmoteRWLCRBbXqOslq4YnBB252uXGRjpnapO0fYnw4/aGawv9W1HU78yQXDeRK4IaYwJFOm yPyySCXcSb+eTyDxX2KqONmfM47B+2nzx6r9TH/aD/aq1ebwfNo2ktP9nkLbg0pAuDKZli8wK2Qq KpkaPO2RtgYFA6N+aeteMvFviC9uNQ1nW7u7v7lmkkeeaSR5GY8sxYkknv64qVOU5Nv0NcvwkKMH JrVnUfD74jeP/h14l0nxX4J8R6hpev2kgkhurK6lgljPA4ZGBGen0JFf1t/sc/8ABSeL4ufCXXvh x4qm2/FrR9KbU7XSLi5uFh1B5MWy3kKKGBaBpGuXhIQFoiCWjcCuylVUoOnPpqvPuv1+/uelZW5V v/ka3xv/AG6vhd8IPCOnXvxN0+yTWLSw26N4cs7qCRtRZ5PtEZFuTKQZbq3Z576VCsYhiiCkJFbj 4R+KnxU8ZftEeCP2c/Hni2zD/ETVrTxPe+Tby3NmsSvcW0empEjuJVh+zR2+yTzHbaI3EuXBrysw nzOnVi9FLT/wGS+djppbSXp+aNa88C6Z8L7P4feJPFOhww6Zqfi3w/ZTX2razPPFBGJvtExl+13E qCICHLZGNob1FfGX7bHxA8MXPxr8LLLqN/obaYiadLqekQIHs9Iadm8iLTJ2tY7wKXluBmcRXCTx IHRF3nOle2GqKWrdR2WlkuWOvdfIdaUpOUX0t+R4d4E/bN+PXwi0D+x/CnxVbV7W6y9gdTtPPuNC Cu8QDCeNlWUxQxsscc88CR3DDBkY+V738Jf25P214NW8UeP/AIdaZP4s+I8Dw2EGpyWM1+mhRXHn NI8FjEAiF2hQqChhXY2YizqV6amIp0n7evZWTTb0SurPXTuRFSfuxV2fdnhf9lz/AIK3ft4/2dJ+ 0F8WfFWmeALpLWWfSy0GhaZeWj5Jb7FZCKKSdMKT5lruO77+Rgf1OWPib4YfAjw/YaN8RfG2haRf wW5uWtJrqOK4nHBY29scTTDkY2oWOelfH5lmeGrKNKjG0It6972/yPcweGqwg4tXlLofPXxN/wCC lHwD8Fm7/wCET0jWfENwiRyJLFZmws8sSCJZLsC4ixjljbsvTnByPhz4jf8ABWf42eIUn0v4deFN O8MafIA0JmddTuYmG4B4mnEdlNuBO7dBvAYDAJwfma2azSlGhp0v/kelDCRbXtHd9v8AM+Dfid+1 D8SfiDZ3WpfGP4qXV1YPNma1u79oNOgmRgodbQCKODB2qdkbYYHOeTXxh4y/a48H+H7d9D8Pz6vq Zv2+ySWWifubeaYYKSTs5it5Qx58ySGQr13DGa5sNl+MzXERjDSLdry2/wCCbVMRRwtKUpdOi9T2 yz17cALdIJLF5ImktI3IYsp+YnJYqWXOTH5fJGCO/wAr/tR+P9VtvEFpP4K1S7sdNa3jAtJJEUW8 sJ+Zt9yXkmD7mXCv90LkHgD7HD8OYbCKnKPvzT1b/NHhVM0nVbctF5HIfBL/AIKI/ET4JaHZeFfG 3w90Pxl8OvLnie2l3RTz75GcLJM8U1sUDOxKfZzuycsK+nfDX7Qv/BMr423i3V3pWs/Cfx9dPDHJ eaLLNpcTytnKIbM3FgkKnG6SeG34545r26uX06sF7KydttNf0fz+85aeLmqnOnZnvt78EvGGn+F9 X+J3wf8A2jPC3jj4Zab9ovrx7q1X7SlrbxM8sNreaZLLbXMwVThHWLLYXIzTvBXxp0Sawjfwt8UE t7jLRtZXkjQsmF3MQJR5OBggMXycAgda86GT4lqpUwj5Zw3i3o/S/wA9H8mdks6pU5wo4yHuy+1/ X9eR6H4R/ai0DXr+fSV1bSdWvrUutzDpepxG6hKkqzNGrPjDDg4QHsehr2ex+IPw71mKX+0mkgEr DcLuLJQn/ajyP1wK5o4ual7HExcJeZ3zw9OrD2mHalFmRr/wF+FvxAgluo9D0LUoWjMRne3glkUH J+Wb5mQ/Nxt2ketfEnxH/wCCYnwl1u4uNR0qy1PSr9YmWNoNQe8ieTP3pUujJIwGD8qPGK6IyrUZ +2pvfruv69DgrUFUXJK6a9T5O8U/8E+/FvhvT9ROgXGka/q6vEYXnsxYSRwqkuYxEZJULF3B3tIM 7Bnb0r5m+EP7O/xt8GfHfQPCviTQr7R9H1nU7TR7jXHsPtltawTXluFkJhl8pyu1SYxMpYBlDKTu HUsbTcKqr9Vor6eif+ZxvCVI1IJLd7n9PXiz4+/CDwjrGp+G5/EP27xDbkJPpGmpHNcxgjkPuYIM d1LKQD09fgfx7+114l8CwXOlfDjwRDB4PUEQWupyy3VxYKTIXNsI2jCxLuj8u1YyiIK6Rkx+TBF5 VHCz5eappF/1fyN9pf13Pk7xP8fPih42tvK8U+LtVn064VZDaSs1tbyLgMjG3VURjhgQxTOOprh9 D12HxB4o0rw1b3kR1W5kLRxGQB5ERWkYhev3Ubnp0z2FW48qfJst7eR0ws7JKx6hL8NvtGoxWosS 2oXDxrEiw7mkdsoEAH3iThQAMk4HNVL74aiMT6feaWqSYKAOhUxnnjkZHUZP0rzXUlqtT1YuCSVj y2XwxZJHJHLaRqwyNrKBzyB34xjHvXlfxW+Fr6bqEuraLzFPbxXUkSgYXzY0kJXHbL9P170UsTKF aPO7p6Cq0ouN47nD2ySSWMRc8qnzZX7hHX8cnv714N8XD4zvLnTLadNGWwA2WMOkx2BuJVCoo+0m DdO0rDBInOdxcgDNe1ls4RxDUuu3b/I8XHQbhGSexyGhfDjxLfLE2pstnagcbgRKR6hcjv64r0i2 8CaNpKbSsl1e4GJZmJA7cJwMcd8/WvSrYrXkp/eclOi/il/XqDaKi8JGvl45w2c56dP0qbTNIspb mG1kgBmkkWKLJ5mckKqj3LMABwSSPWuapiJKL5dzenSvJX2P2v8ACvwM8BWvhXR9HMyXEdtCqKdQ 0W3u4jtQ/vI2z5ibs9FUnJ74BrstA+A3gXUNThn0nXrew8RQSJcQy2Wo6hbTRPFho5IxeRrGGUqp VgpxtGDxx8DHFYnnb5r3b+966dV8j6N0oqFnDRLp5eR5t8Vv2fLH4a+GrrxPZW9pfWpvorZLm8ax upYS4diR5SKoIwACUJIbr0r5Mu9HuXWLWbLVZLLXoMrb3cEpjlyT8qhkYHsRgHgduK7KeKrppzb3 28uxnGhScXyR/A7X9nD45fErVfiPpXg3XvGd5d+FL2+msbq3v3N2Zn8qTyyjyBpUHmmMgKwVsYPF fdHxI8J/D7w/4L8X+MNRWP8AtSxsbqWBle43yP8AZ3kBVRGVUIUAfcRklSOMke/Rd6vKt9D5/Hpq rGO3+Z+LWkaWJ9Ms92MbOuMjHXivCfiHp88GtW++N0thGrJJIpAcljnB6dqvBTvi5J+Z2V1+5WnY 5LZGASVYxkh0Lc5Iz1x1HX/9dfXv7Pvi6J2u9CuHPmMfMjGRkOo5/EoAcn/nmfWrzem6mElLsRhZ qNZLufVGoGe2nTULG4aKYfvopY2IZH65BUgqQcEEc5Ffeui/tdWj22im7DSatKqfakgaKNbRyAXB a4kiDqGyAVLHgZA5r5nBwqVJXprZa2OrHcsYwlLvY9g0b9oRdaj+0WF7DPFuPC3Fu+O3JjdgOR0y c+3bT1P4vWbxMk0UTED+FATjuDnn8voK74zkpcst/Q833Wnyo4K68baPqxJudMiAUBSyoVKjPPr7 dB29q8l+Lnhbw5478J6lokGpjS9QkMZtr1IRcG0dWDbhGWjDEqGTORgOTz0O8Kiclzart37oI80Z KcXqj4Dm+Bnxo0LVLWx8M/E7w9qVmmI7ZdUtZbdgqjaAVt43wcccsc46+vlfgPX/AI1eOrjVrDR/ h3pupSWcPnXL22r2dsm3K4y8k7qThlJUHcAwOMEVpPC4GpB1buna395a+mpvDHVIe7Jcyf3k194y 8deAwbnWPhDO08h3R3UOrxXFurhQPvWyMGxweHU844xmj4i+Mz8QH0GxW3WTUHtIxLBEWdY3dQ7L uwNxBbB9Oh5BFZ0cDGjjIYqNRSVn0tZW/M0rYmNXDyptWtbT5nu3wY/ZLguHtfEnibTojcN+9SGR M+Uf9rj5Sf5Y45r7at/C2m6DBFBHpkUdsoO3AwoOBn7o4/8Ar/SoxFWriajk72W3/DHFCMF6nE6u NKurjdaIqAEjIUA8Z5OR3xxz35rlG0CKTeXmZGU+YXDZC46HK8gYPt1PNZczS/qw9L3KSeEpNSnY Q3xkjfO3nKjsevPb07DpVw+Ff7NthCkyJ5RLmQxBmdiO5YZI/wBk5HbFUpt2XQl33RnyWcDPsRIX fgdycg4/ugA8HjHeqWo/D/w54pKWuteHLW5dTgSFnVlBwSFdNrr+BHT2oVSpSXNF2fyLg+Vp3ItK +A/wxsmt7i08JrBc27llJvL+Xa/AyRNKy55xkDt0rvY9B0rT90NmiLFxjK78deuD/WhVakneTuvk E7yd5O7CDRrO5/dzWiMoG1SygfMenbvzip/+EPsf+fBf++h/hWkZ2RCSsfz7WvjzxN9iittRu2ub CNw62l9+/tYG2LHu8iTMbHYoTlTwAK8+vfEmoaRqss2msscJVcxMi7XwAoYgABScA8Y7c1958Tsz yXGJtQ/EexuWU6rpALOgilw+UyD8kgyMoV3EYw4IJ4BAI6vT5tB1WS1h03RLmWeRtit5kUUO5jtG 5wORknnjPYVDhOGz0MKlOUXdPQ6qS18P+GEu7rxJaqk8DRoi2yF40LIp3KpOZCM/M5IPTgE4P0P+ zZ4T+EfijxbrniO/+L2gWeqRrIwOtSxWkd4sifOmLwqkqyq0tu0A8rhuZ4lO6tMPCdVvlTej2dm/ JefzIo88pqV/d7n17e/Dv9nzwpoS2fhDwl4Y1jSGn+0/aP8AhMPBSXttM4GVQebqOpGNNpxtvcnI IGcV6vY/Fj+zLnTPDOqeObm/8P2/kXsGnaFf6jf2+qq8bK1nd3GsqBBGheN1EdpdoTEVUx5Zq+ny /hbN80tWmlCipK7ttbpdvmbeu0Un1Ctj8Nhn7OzlJ9H1t/Xc/WH9nv4d+AvFPwk8K+MNC8B6Npmv 3vntLBpNnHawwhbmWOMBU6Hy448nqxGfaviz9ob/AIJU6T8V/Gg+I/jnxj/wj2ltOUurq71G1ggl DBtiJJcBQuGIJXnPzAY3Aj8ZzKvUyPiPGqj78YVKkFd/Z5nbrp6H1VGj9cwVHmerjF6d2jkdP/Y+ /wCCfHgue203XJJNavUuVV7Xw7BqV68kkJALRG+mijKuVO4CS6Q9VXHB+jfBH7R/ww+AtvMv7O/7 Pfh7Q55JpDe396jzvKwAQGW20lbX7Mw6kyxyoNqg8c142LznGYio3Oo3G+kU7R+ff5/I9HD4CjSS 92z77v8A4BxPjH9tj4/+K9F/4qf4s6vDYNYnyRpckGj20iOrpIrTWaeRer90rHcLGccfxc/E/iT4 /eBtHtzBf+KbeS7ZHgktbSye7RynyESRM7Rqx5y8c65JPXexPFGji8dP3Pe/Jf5f1udl6dNNLRf1 954T4m/a80OK4V9N8MTzLsRWfUdQ2yxsp58swqXVSOMO8nBK4IOD4D4j/a3+Il7/AGhHba8tsl1G 0MkWn2MMQZPk+620ujDYBvUhsE5JzX0eB4ftyyxD539yX+Z52Ix0VpHQ8P174gXGrW2mw2Vi0LIJ HuHZ9/nzO2NygKPLXy1iXZ83zK7AgMEXi9b8VeJNL0cy2usSQTzTeU3lkqxTBJweq9F5Ug44zg19 VhsPTpThprc8nEVp1Iz10P1y+C3wb8X/ABD/AGdPhD4+8N+L0TW5bOc3HnFit2I7ieMKzHLbhswT gEkYyQBn45/aj0X4heHtQ0Q+LpW83Eot02pJEm1U3eWRnkk5y2Txx0rBY2SxcsNUX2pWfzZVXDw9 hGot7I+Nr6w1DUiX1S/eQMfuEkheM8A8DHsP8a5C4jjtGaIf6wdDySfT8K9SFRy0SOBxt1Oo+H/i 3W/C3jDSrrQPFN1o0s+6xnvra8ktyttODFMrSRsp2MjEMM4IyDX2t4cv9Rvtb8MeHofEthqEmq/a ILGJYne5MEULu10Zl+Vo9yhE+ZizLLnaEy28Z1FNJbWf4GNahRrUnKfxJ6HzT8ZItN0b4g6hDaMk 2orN507JK+2KQ/MUZlwWkOVclW43Y65C9v4K/a/+N3ggR2zeN5tTsI2B+y6wgvBIoG1U8yT9+iAY wqSKBXLXw9PFUvZ1o6fivRnThq9XDNOlL5dH8j6x8A/8FGpIjCnjXwBLbyAHztQ0K8ZWA527LeUg jjgn7R7+1ffHw4/bl+HXib7Ctj8RbRmTDyWmuD7HIpPATzJQEdvaN3NfO18vxGDlz4eXPDt1X9eX 3H0NDG0sUlGsrSPqAfFLw9rMkFpqlu0VxKGcMAXjIGOhGQAM+g60y+0LR9TRjYarbXLOMBYp0Zy2 eFC/e6dQBmuaFZVH72jNKlDlV4ar8j568dfB3wPr95K/ifw0C7FS0k6KrhhxtEke2QY44J64wa8w v/g5qNnHF/wjfiy+W2HEdvcS/bYEiA+5HHIQyD3Uk/WuuNWcVywlzLqmckqV1rsfH/xQ+C/7Sb30 up+G3sNQ0vbIkVtpdxFbyCHLEeYLvYGbr8od8HO3rVf9mPwL4p+DXizX/GHxk8H3unWdxotq1pLH LZ3kUUF3K5aS4MUzSRSqbZEMARpU84+Yqbk3dk8dRr4T2LkouKslZJ623aWq9b28jmp0p08VGTi2 m9XutvwPv/wb8T/hrr3jbwXe6P41sWSPULdim4pcxpHLGxfyHAlYAAnhD0454r728F+BPAsngY2o 1231HTodfeJpbq3sjLJPNIlhaoEuFeBnmmKtDuZQ32hPkyxAnLqEZRq06qTvbR+m+vruaY7njKE4 30W67nwh+0V8N9C0L4q+JrDQLD7NpKSRiKNM7FYInmYPb595wOmcDHSvmXxXpospLEXEokMtlG6s MnbGpeAEg9P9We/T8K+XxUXCrOEdlJo9nDScqdNz7foeTap8O/tWkXd9pUYE0RYsu0ZHQ5x04z/K vne+1I2l+9hNEcQM8ag7iU5yQPTJ57CvRy2r7ZSi94nBjocklbZleXULVNk0jnf6E889ePX8+o61 wniLx3pumoDczrAzfdDBi2MHBCjkjtwO/WvVpwlVkoUzjk4wXNM8h1D4japfNJFotsxD9ZZlwTn0 UfzJP0r6L/Y2+HGsfE749+GtT1W3n1NtDDeIHg8/y9n2d0ELDjGBcPAxUdQDXbiaMMHga9X7fK9e 11Y5KdWWJxNKne0br8z+hPwx8PYNUgguP7GktBggrA5JRhlflI7cntzjtzXT2ngi4W7XNwlzEilT HPHhgPQMOVP+c18L9WlGCm9V36o+nddOTgeM/Hizv/8AhAvEVjDC/lAJIX8kuTskjb5pA3AChu3I /OvzN8SieWW5juI38sI/2MWwLTMWUmRx8jEbFyvyg8OcjpVxjH2ys9v6f6nRh03JNs6z4caHoD6x 8PtZ0ieFYLPU7KWS4j2sogjnUylimcnarnucn3Nfc3xkvvCep/CP4oz2ev2N1Mnh3VDHtmjlOWtZ 03AElhnJ7D731x6+XOpOrNSW0kvxPnM5jbFR5t3/AJn5Q+HYCdPsUVT5vkR9B1JX2+oPXvX6k/Da x1/wH8E/C8dppLXz6hb7pbfT9zvKJSZhvRST8qyKrYB4BXHUVlRjGpiuWW2rDMG4UIrz/Q4eX4af DzxNb4v/AIMaKIp3BvJhY2yXAYghv3qKsm4EAFdwOOe1eV/ET9mPwJ4V8Maj4s+F3hqSw8TacPtk Xl3t3JHdLF88ibJXb/lnvIVQpZtq9zn0JNy5qSb5Xo/66HnUKs4zi33OO0y5g1rw7bXlspaJlDL0 JQHqD9M4IB616h8LYLe/Gq6fP4ce9nS5ieKYBiYllVRg4IKjdGSACSctwcYrwcG3SxHJJ2s2v6+Z 7eYR9phW+qaZ2/iT4ZadcTNqVrLcecsZjaGG5QKV3L8wR+Wzjk7lGG5zwKp2vhPXAYVXVVs4gNgg jV4m64BXa2PrkHOO3f3nKM4+9HyPnvfg9GdRpmk+K9OtNVifxF9olFv+6UTRfu2Zk2F2ZMgDdkkk 8Bu448Q1nW/in9uWyvbSFFbIK7WkbGTwpXj9OfSso4XDzcmro1VWpHfU9F8G+FvHk3h/XPFdx4UW Kwj0+aXT7z7aZZL65RSYwIPLVwrMD84LLlQM5PH5KprGrP498a22h34ttJGqyp5jDEDxriKJAxGA QIjgEDjArehSjHB4pyvKOlrdbf8ABNac5OrTa91n1d4R0nVJdNWWfVNOmgIDOSrv5o5PLA7SAeOg 619D/DnUfg03ijQNLsfDdvL4nmmEDTrIVhG1C7bVOFJwG5AzkAZycV8PVxOLeJ5cHzKKfvJ7W7f1 qe/Uw9N0XOtbbT9D9BYLPSLaygOmwFIB8xdjgY44PPQdemea4bxAY7wvHas0loQQ0fP7/wCpA7Ec ZwK+ijU5oWseNyJM5D+zLRy6fYlidMM7SOFEY9cgkdCO4PuKguPD0I2otsjXOdpCueen3jt46flj ip22HZW03NG30NbGFXSAb2+YsD0J9B06Cue1TTWuZWZAyxodx9wM/wAun58009LLcHHqc7Ppzh87 Mu3AYxsf/HucjjPTjPetqy0y4s082OIsx43DIJ/+tz6VL1StuZ2Lks94FaVnYMwKuR8rFWHKk9SD jke3TPSC2+zSRGJ2x2BcDGMepPvj601FtNrYtf3mbVpo8MxYZG7bnABznv8Aj6Vb/wCEbj9Jv++x VwkoqzYnofy2RapGGMNwAgP3RLkDPqeueuawNdKTTLKrhsj5mBzuI78njj+VfoC0aPK9DCW3uJWX yoWYHphTXZeGn8V6JcJJpaSbN6yGJwTG7DoxHqOzcEc88mqqThblkwcOdNM9y0htZ8aPrOj61dy2 VtqsItppSu+NQksUyBlXDY3xryMYLbjkZB+mvD3/AATn+KWoaPa+JfDepwPo88C3cU9yFSB7dl3r IsiuwKshDAkDjmvFxud0MpnCU4NwfZ63SNcLgKlbmpweq8unqew+DP2PdR0preDxd8TdEtpHCbP7 MaTUGDNnAyNiDgf389q978MfD/4feCrgxXtnqWvalFwjXDxafaMW5UGJHaV/vA7opx1B4zgdlTxX xOHwTwWTYZxlL/l5PW3mord69XbujspcM06lRVMbV0X2V+r/AMj6RP7SXxP03SW8KeDrubw9p2RC ll4dszbtZN5xjUeYdl6hlZuHiMwZpARuzk+H/EL4laZpmqTeIfiJ47Uajelrl5tZ1VZ7ucgYZlb5 vOIxgxzWp6g5Jr8srfXMdXcpN1ak222tW23e99vx+aPp4eyoU0orkilp00XT/I+bPEX7Xnw00G1u bXw02o6nK2+VI4LOO1sjIwUBWWUttAxkeVEnI44PHz5r/wC2D441CSU6BptpptmzKY12m5kgIJOV knyRyQOMDp0r6HBcNzklPHSS291fq/8AL5tnnV8yjFtUFe/X/I8V8Q/Fvx54pZ313xDd3YdxIUnn d03DOCFYlVwHIGAMZPHJrjpNW1Gf5nu2bOPlyQOfYcV9JRwmHoRUKUbJHnTxFWo25SIYoZ7nhFJG eSewPf1Pbj2qeOwExyWyyk+3fPf2J/I1s5qOiM4xctXscrr9xqsOsNoulAK3lxsSNoY5RSSWPC4O emP50nhO1jHi3QbzxLqlq1nFfW7XEU1ysrTRrKu5QFDgkjPXiu6lTj7JSS1a39TjnJupyt6XP6I9 C0vTvAukrbeEvEkrWkatJGIIoYTPlTsy0CxwOFB4Uwv1BPQEfm7+1d4mjn1SLw7qPiTV77WrCQSS f2rp9rDxKiyHbLBIBIDvXA8lCoBHORXymFnKri+Tdq7vrf8Ar+rnsYylKjRVnaPY+EdT1NyRj/a2 478nrnAx6cfrXIXrLIjnHzjkDpjufpmvp6ceWzPGbuUIrm4it3tFVWRmDEMikKeRwT0OK6Dwt448 Q+AtU0/xL4c1N7TW7LzEtp49hMayo0Ui7XDKyssjggjB3sD1reLUW7dQeq1Me5ubzVLu61DUL6aa +uJHmmklkZnnlc7ndmJyzE5JJ60RCJBvVcYOCTgd6zk7vQqKSLSXJZgsKNg4Gckfr1/GvV/B3hnx DrapbaJpM9zO38UMZbHpuboPYnHSuavJQp3bOmjrK/Y+4fhFpPxD+FOiFb22zvu3uY7eCeYmLbsH 7wxMv91m25Keuea9v0v9obWbZrKLUNGnnuTOwY7EV3cnARGQIqAEgEkPwcknNZTy/A5jh1VXuzXV d/Nf0zm/tTG4PFypvWm3s+3kz2rwR8WPiP4sbRdK1z4X+ONDvJoJZLWDWNBmex1BhE8jxwTYMbHY rMC4iLHaBycV9DaJr+naZevoXiLwt/Z96CrfJ50ErKQPmZZs/wB7IACjBFfK4p1sFUVJT547prt/ XQ+oozoYyHNFWl5/5HpFt4f8F6jIsgvWEhOVF0pUdePmjLD8TjpXkfxy+CvjDxRp2mWngfRxe6OS TO6XVuyoecnO8Fxwo6EjP1rllWjKnLlV5XX3X/AvkcJrneiPy78bfsI/Hqe7v7uOKwe3Zm2W4unS ZV6nIZdueo+8e/Hr6J8Ff2cv2zvBqW99ofxluPDFjbI0dpaandPqUaAgENHbMssMQJJG7CyL2XNf R08xw8MPCM6d/J2373Wx5cqGIlWlKk/8mvnoez+MPEP7UumfaZvHXgfSfFzRDc+o6BfSw3NxIT80 kkc4MkzMTnakS815xeeJpfGGnWeqzaFqdjKEa3S31KKKJyUmcMdqyEjDkjDBSQBxzXi4+FFr29Kp e72e9/Xqj1sJUm5KlUhZpfI6bwN5Nwb6NVLRzKHAJwXBz27duPrX56/HPxN4a8L+OfEluL3Zdm5+ a2jQtKOB/CThc9ctjIOazyeFWri506S3Wv3rU58fKlD35vbbzPmXUviF4g1Xfb6RD9ltuhkzulYH jljwOnYZ561xw8Pvclrq8lkM7cs3OcnPOTX3eHoQw0bR1k92fNVq8q8ry0XYsJDLZTWyQXbPbmRV ZSuMgkDAPfrX7W/8Ey/Ac1p4Q8ZfES60yZrjV72PTbKbyUUx29su6RkdmDMkkk21gBjdajqeB52e VIxwEk9OZxX43/Q6Mthz4uPldn70+BdMsLPS4A6qGZRyCMsfz9PbtUfibQraDztQaMJuBXcFAPcn B79c14KpzhRUox/yPU571Wm9D4v+K1tqV5pGs2NhfkrcWtwvlm2VwRsfgnIxngAgE5PoDj8rJdDu 55NSvZLlmaWLybQ7sG2V1IfaSp2t0IPIyea8X2kfbTbXVdfQ9ym1CKbWvf5lP4J+B73wp4jf/hJb wrol1LbC4+xOPMRQxMhXepUMqkgfKwJIyMDn9Bv2xvgBpXgX4E+PPF2geO7iXS7O3t1+yX1nDLcT NPcwWyjzoHgjUAyg/wCob0GM5Hr4TFOeOk6a0k4+vboePncYYjEU6kXb+kfml4U0m5uptNsbSNmu 5GSGGNT8zsTtAwPU4H48Cv010rwz8evBP9m6Jr3hHV57CG3SMQwaI17BBGq7V3T2IkRO2Q0nQnBH Wpw1Siq1TndnbTp177HBmTny0lFaa3/A4OD4qalfape6UjQXSqfnW2uo4/sw3bG3rglSBlihOSCO c5FdjH8TNA0Py01m9vd08gaU7FZBg9Tgg+3KtjPvivUlBNL2Z5EZ21nofGFhBougePfFfhLQbln8 KyyG/wBKMkLjZBKBviAclgIpCyDJy2wt/FXf+Art9H8c6TID5Vvc5sJGC5cbziPBBA+/sJPPBb05 +fxClQx8m+6Z9RGSxGC06x/E+kvFejanp1lFJ4dCXl75ziSKYlfL2kZYcruBwAPpjHHPJWtr4nux b3EqSK5CbY/s6iFmLgNvd2RlG0MwZRJ0VSBkmvatFRTe7Pndea1jt7ddPh1GPS0llk1W8jUJCtoX kCA7tzbM7Eym3zZCq5OAc4A9z8NfDLw5BHFea1cxXd2G3CAQfu1JBHCvxIMYO5wOpG0kAnnqVZL3 I9d/6/rQ6IU+Zpk3iPwbr3iWJfPutljGN0SvImGDH7p3AlwQBnjPHFfPUP7Nmj6JfS3vhfwhZWzz k70tYSQXP8WG6npgYwMAAYOKr6y/ZOnqo9uhfsr7bkSfsleDNRQNrOjSK29pJRb3E1o0m4Z5a3KO zZOPmJ/LFdpoH7P/AMMPhvmfSPBdpZ3KgK14VMlwwPZpn3SyfixNccm6spKOl97W19X1/I2tPljG Um0ujex63beGYLy3MFldmO3UZIXkA8n+opo8FafHHMzX0hmIAGBjb1Oc9Tnr+FSoWBNvUrHwe/ly eXP5h4AIVQx59gPT26Utv4OFqDLPdOspU7Qecdccjnjj9PSiUdBavRmTPY3+6WCAq2fvfdwPTHse eazZ9Av0RS9ujcZyoUkDHf8AA9Pc1Vkn5he10U7bw6PMMj2wAXrljz34B6dKuvp0KttK/IwzkFR+ o7fX86fwuyFza6GTcaRZz+Yzw4YHaARySOp/DHT2qqugW5RBErGPOPu5X269B19Kd7LXcbWhpQ6Q 0SZtZQZNuOTjHX1PFL/Zurf89f8Ax5ah8r7hZs+MLb/gjNc6yIVj1PW0jJzm5urNRgYHy4gyOOO/ 6V1mnf8ABFjwZpOpmDxB48eWXyhcize5ieRYhgF9qrEdmeN2CAfWu6XEGZOm2qUI+er/AAHHA4dP WTf3Fi4/Yx/ZY+GJitrjWdPv9QUOrQpIbt43QEtvSLd5eMEneFGRXAX3gz9nbTZINU0j4XCVQGe2 ucSW9pOR8oUOreQG+bAWRlznPQV8zis1zWrVbhWaT+7+vx7HrUcDQSTlCx3C+O9X8OW6HRNL0zw7 cyRMEVo7cOpbhWIb5JRgFf3U24kA5wpzw3iPxr4p1GF7vxt4muJ4hGGW41K8dFjBLFvK+0NBLGuB wVkmDZwAeM8VKm5P325yfV3/AA6/g/Q7eRRXNBKK+R4zrHx2+F/hgTxtrS3N0DEXi0qAbpgqKBun jECEg7vvxzdAc8YHhfiH9rqSCCWz8G+E4Iod+RJelXWXBVgz20YWANkHnaSNxwc/NX0eCyGtXani XyR7faf52+d32sefXzCnSk1S95+Z4H4l+PHxY8UB4Ljxdd29h5jNFaWMpgithyFSMIQQgBICkkc+ teQ3E8j75ZpCZCSSx53+uf8APNfXYXCYfCQVOhC3fu/Vnj18RUrSc6jM61bVtQllex0yWeBMGRoo 2cRhuhbGduegz7V3+keAPFerR/bBaLDbqQSZX2tnIU/KPmzyO1dFSdOlZSer0+8nD0K2Km40o3sm /klqz3jwr+zZqmuWyym7lM5OcFFSNP1LN+Q615D8UvAV78PLzTLVtXF3ZXcJmSaJlKEq7IyBkOGK lRnvk4OMU7WScupnO8HZHO+GpZJ4rwBgVWMMgwMq2eT+X8q2LO3ILFUbcQQeevGMgDp2/KuGrJRn NX7HXSXNCLsfV3wp+Cnw38W+FL7XNbsdQl8UXNldwx6jY3WP7MuCskcEZgaeATFvkaUAuixSKQZH LQD3/Uvg18BfC8Gl/wDCKxavrlxe6Ukuurqtr/ZEWm6iL27YwWP9l3SG4tjZNZxSS3KCSSVJ3jS3 UqKK3EEcvouhhpJ1HyrZaKzv7z2d7bb90a0cgljqqrV9Kad+ut/w+87R/iVJocU+r31/YrpzOSq3 MkkRt2Lk7BPI7l1RSqrvVnbALSMcmvzs/al8d6F418e2GsaDeST/APEqjt7oOflinjklDKh+VWGz yyMdQfXmvHyhyqYv2vJZa37a9v8AI783oxhQUIyvZr1+Z8v3NwZFX94MLkAAhuPqcevTBq7aWyyR q8kK47lhnvx7D0r6ec/d0PnoQSlqZ2r2ZRt6HHqOPw/l+tctfRAWcxIO7bnGR2/lWlJ6ImorNl7S 4Lm9ihW2gd2CgcLnn39v8a9J0P4Y+INbmh3qYUfoSOW+mcDv70VJxg3chNs940T4IaHpBjm1sPcS jkA5I3ZBwR931/Kvd9L1W30m1it7W7S3tVBAWONTuxxz3HHHYVzTUa0ddRpyT0OtsPifpunFBPqE RkY4CysA0hJ4AUEk8nHp+FeFeG/GEnj3xR491yISXl958Gkw6TdXqBnmlhmiSeBMqCBLGZCCixwp HEJJJDKWKoUvYRq1tnZfd1Co/bOEGr/5n6U+FP2xLv4UfDG20n4u+N9KPiNNNtrSKJgt0bS4VAJW nitUV5mzjBWRV5z9fOtD+N3wb+Pmt6VrPxM8U3d5ptrEYrRNK+1wanbzM0/lMsVkI5PMDEEeUGyq ruU9+OpRwtbKp45TaqqolGPJZcnWTk3a3S1u3mejB1qWKjRVrOLbd9ebsl6eZ9L+HPgva67daDL+ z5+1q15rBWZ9O8K/EWGX7bdsABMzjbaajsXPBeCXb2JxXS6pf/tMfCy6E3xC+AF/f6fH8i6x4GvE 1MSMM7pPsx8u6gQDJyyk18/iMLSnJNPkl0a+B6+X5q69D04YqpTXJXV136/NHIXP7VngPxTLZ2dp 8QDaa3bTMjWWrCS0uAzEDYUuApfBPPUfhXrOm/F3Wmjiha8s761EKsYTFErBSB0Maqzgc/M2TwQB 6aKFWnBe2gm/07pluUG/cfu9LHzJ8Xvj7K2qTaNpOh+TciOPzzdzh7eJ/mY+UECEk71BdmwdmAg5 J8Njj+IOp6bdzav4a1fUdbmvmls1tdPkdZoDFCgUMAIYfmRjh2TIORmvLxDp8yV7ersvP7tfNnbT tCHO9WYr63f+HBqtzfamLK/iiaKW106NLq4g4JG6aUfZoZRtYmBkkYgEgjAr4z1XwD4e8Qa3rni/ X9Vuby4up9/mahOklweFUBiiIvAwBtRRgKAAK9vJf3VWpKEfiS11v/wE+29zxM39+mp32e3a6/M8 41/RvDlq9xFommTSiIgb40ZySeg4Gep49a5uz+GfjTWtN1DV7DRZfLtoLu8ltJEZJxb20LXM021x gosKSPkEn5G46V9Oq8IWVWa5n954KjOScuXQ8Tt/EF0bplsXlj3hogY3KsyOCrDI7MpZSvcMRzX9 QfwF0bSvhn8Ovhx4Fh1F5NRsdLge8hgfzVF1J+8uWUqDlGnklILH6AV4vE0pKOGpRW8m320/4c9n Joc0qs7bK39fcfZ0/wAQoNNs7GSIyBUA3yFWx/LNQ658Ql1TTi0F0kiPhSobIOex55rwqleUIct/ uPUp0LtM8X16W5N3atZ38kOCrruAcL7BXzx7AAe3FfmbeW02j3lzo94u24gd4pFLc7o2KHr1+Zev 0/Hx4NynOT7noWSirFq0ma4aONuWZvun5QWAJIOO2Bjof1r70/bS8T28/wCzT8SbHzA019NpdtFu AwCNStJflz1+WNvwzXq5Yv8AatdNjyMxTvSv/Wx8L/s4aI2v/GX4b6fC4/dalFqB3hTvW2/0lx6Z ZYWGPev3jsryeNsC9TyAfLK+UiBc5xkpyOMHP0FKmrznO3b9TlxfxpW6EmpWOn+KrO50nxNpNlqO iSptNvcWy3MTqM4BjmVlcfMccfxcdefOr/8AZ3+DGoLA3/CIJaeQn7ldGurjTYNo4GYrKSGMkAnJ YHPp1roTnTsqbt+X3bHHKnTqbo+HP2m/2WR4Z8L6t8WfBmv6xd6voEo1E2N7JbyKunnK3SxbIBLl VKys8ksgWOKTuQa+R75rbUobXULbaYLiBZkIUjIPpnp/F+lc2P8AelTr27x001Vn+p6mX2VL2S6f qer6RoH7RXiGy0nxL4K8Male+GLpTH5seqadDbpiQxu+yefzyVZGBCw/dJxng16LofhHx94n1C50 DxUmtabZwktcajDp89vHLH+7fy4ppbeNYx99WI3uMbhIoIr0niaVSnGVJ6tdU9+366HiqlKlWlGe ybR9IeEvDHhDwbY/2LoUaLFE4Ezz3DS3EsgADNNMzGR3+RVyzk8AcYrsLOJr11W3ndtpxjLNzwAe p47Z46Vhsry1N46NWNWPStQuAkX21BCpG7yy2B6jbz7fnXRabBFbyRAQo2CQZNzqOOrY/wA+1ZS6 20NoyXLc9FtJFVcR6dDPjJB2cN0ON2Qfx+lR6na2uqFXvPD4R0fapWBTjHGN2N2AfUnr1qVOMWi2 k1qyW10O2mVisKw5PIcD5yQCBgd/fjpWbPoEU7y+Xboz5BI8phjpxjtx6+9JO8bp6f10It2MibQ0 3Mj2RWPGB/dI5HXqf05/TOu/Dkb7HlfZg7QNp+UA/Xp7UnPRoW27Obl8POJJlhkcyDgBsY9xgj2P PvWHd+H5d6ySWmCCSGQEH/OR39KpVfIlW18yuplgVVERMf3SH64Pp9PWoLyCOTLCIbiMgEEYwafM irdDCbTHdtmGxwfv/e468cev5VE9vbQOPOLrKOhCn6dvb+dO93rsKV7ajlgiiKurl34KtgHGe4GO e/5VZ3yf8/Df9+Kektf0Jvbc4TXv+Cgnxk8R20knhHTtN0XRY5vMS5t4Uu5WgI4VriTz7UEEHllg 4xyD0+XvF3xj+I3jmC01nxn42vNSsvOe4WSeYG0EzEDa0bs1oM8AeXcQ5wCU7V4tStUquzf/AA/9 ej8me9CEKa0Wvf8ArY8D8T/G/wAB6NbR2es+N4EEEzbLaCd7mew3YLNEke8xhiMkLdgH5QRgHHz5 rv7Xnh6wvJ7nw9oV1fXRJzNeTfZi4OckyQk3DBuPkaZvrXo4XI8XiXea5Id2tfkv87LyMKmPpUbp Pmfl+rPDdW/aa+JF89y2i3EOmRzK6SfYIEjaZG+8HlbMj9sszMT3JrxjUPFOu6pJ5+palLLLxzJI zEEfU8f/AFq+sweWYbBq8I3l1b3/AK8keRXxdSu7t2XYyi7zHcHJboc5P+f/AK1a+leH9c1gSf2d p8kiKpdnx8qgDJyxwB0/zmu5uMVdnPdnpOhfCTW9SmZNTnNojIgjMkBPmOSpKAHGSq7mIBbGwg98 en/CP4f+ANRl106/phvbq2RJbeG5kZA5UktjY2MH5Qd/qRjrWU6l4z5HZpbiTTkk0eleMNbstM03 4geGtC0SCx8JpdWlnGsVituJLv8A4+ZWwoULwyIMAgiM4yGBrpvgP8PLn4pR6tZWuoNDBYTQS3Uc KRs00Ugb5d5Uum4RuAVOM5ypxXHCi6lVJvXRv8Gepl+M+qVJVVHo1b1TXW5+h9h8JtLCJbv4dWWB UUCKSMPEo3ZU+W25N4IBEgAYZ4bqK+Cv+CkWhf2XbfBe5ktGS4mOro8h6uqCwIBOTnBdj6816c7N x9f0Z5LsnY/PX4cxPc315ARysD9R67ecfnXe2FjCwUvnHmkZIxj6f5+nv5WMny15r0/U9bCR5qUX 6nsuhfGQ/Cjw0NKbTpLi8nmecR+YIkAZFTdvwzfKRnYFIPUEGvNfE/7SfjvWX8qG5hs7UIY9ljGV 3dyxZmZlPupX9a4cPldHETeJqu6bul/n3O7EZlOlBYekrNKzfU8V1nxfrmrXK3N9qU09yxUGSSQu 57ZLMSxx0yc9q5K5InAaQZbqSWLEn8fr1r6ClThTSUFY8OrUlUbctSBEWOMuFVXPQnnHrx0z1rq9 Csda8QXY0rw7o91e6gQSsFpA8z47naoJx79BzVz1WpnFqCPfdD/ZA+M/icpLqVpbabbPhiLu5V5g pxkiOLdggEZVih7V6npP7GGh6PIs3iDVZ76deGG0wxr77efoQWIxzU+0lFWhH5mMmpS3PULD4JaF pltELLS4441G0hVG4jtngY78+3XtWB4qh8PeCtLur67llRUVckKSwOQoGCemSOnuccV58o1pVLJ6 /mae6keE6l8WbkQmOIILcE7XfHJ68bTweueT1Nefaj4+GoqypO7MRghjsHPUEd+O/Wu2nSktXuZu StY4mXWkUGSeULESD8vH4YHP+TXtP7MMcF98fvBOujR7h4zNP590QwjZmhkUE5++SxGfc5OarFaY Std2XLL8mXh/94pPzX5n6s+KfhN8MPidcLp3jDwvE6xIYrea2le3liLYDcRkI4yQ3zowDc4GTn5u 8MeAvhx+yb4s8T/Ey9j1G90rT0aC1hijjE8LMxDSE70R8RLJt4AJkHI4NfLUa9ath3gIS+NW16N/ 8D/gHvSp0qNf61KN+XU988Bft5/sz/FS417wx4sY6ZpZiyG8S6dDJHfRFfnQBGlUOCSNhPI2lSTl V9gm/bZ+CHw1kWy8N+OfFUttG0CLZaesTWjQxBUSKKHUFkjtYiBg/Z1iPzZB4BGSyrMcHV9lBrl3 7xf39V95tLH4XEQcpf8ABRwHxH/bP+EHxiKw/FL4CWdxpG1liumltrq9jTJ4RXRGiB6EpcZ46Dt8 nfETw98Am8La141/Z7+JGp6R4ssVWS00L+0ZU3M7KHWOObLuwQuf3byD5Dngk17eDguSMN9rpr8V /V/U8nERlBuVJnyBH8SvHeq61DqPjOd9TW2IBkn3iQlcgbiDgnIGSRk5JPNfU+iftGQWfgbX9Fkv 7y1uDGJI1tXbbMzMA6ZXDHK9iAME88mscyyaU6kKmFe3R+upeEzeEYuniV8/+AfNVz8XvFdrpt1p Oj6tPZ2E8sszpAUEsglj8qXfKFyEeP8AdtGSykduefPLWw+IfjC5g0rQreIpISBuuUOST1LFt3cc 89uwFejTjh8BS9pWeqWrscdWpVx9RxgrRvt592fWPg+80v4faOPCni3SdR0eWMCW7B2TREY+eUbX dphgMd2BwMDpgPu/2hPhjoOn+Ir2LwlrD2sdhcR6Vqs9tE6SaxsY2aSRlhstmZS7sG8zC4CA5ZfC pYOeNxDrRqrkk736u/T7j0KtdUKUaaWqVttj4o/ZB+G0nxR/aH8BaBcQsdJtbptX1ArA0saQWoM2 JABwkkixwZPGZgPav6N/B9jeeHtQvLhbSBtPul3QTI43MoGE2D+JcZJJ6denR8UVE8ZSpX0Ub/e3 v9xrk0X9XqS7v8kb9zqt7fS3MB1TF3DHlI40BG7G4Z5PGQOTjjnHFY/i6CQN/aOkzeXqcbruWIZD 5AIyB1P9Cfx+ZnUlzt+W3c9qEVdLocfeeMdbW6tIdbtW8sBHDRFdxGCNxVsDnPfgYFfGPjrUItR+ IPim9t03CW8kukXZt2rIfMIwOAQTt9OBRQSvKaegVI8qV+hUt0YeSI1IeObeMqBuODj07n05xX1D +2fepdfs+fCmSzlZU1DxHpKzBnz5qvaXU3QHB+aNT07dfX1ss/ju/Zv8GzycwX8L1/yPM/2TdPe4 +JB1K1t98thp80kbIOkjskY5HfZLLj8RX6WzahrNquya3KzTFXmPmYZSMDjknGBjOAfxFa0Ip8z6 3/Q4MS17WyRs23iq/tjvVdsinAw7HbkA85OfTmo5fGupeeZfICRyAGRBITgkckg4B9eQenSt42iY J66aD9Q8QjVLSWzv4Y5tHmhMUlvIFMckbDDIyHKlSCVIOcg4r8jtV8MzfD7XvFHw2uBI0OmXZm02 V33tPp0/zxNv2qHdc7HKgAMSo6cc+JjGWHvb4Wn+n6ndgZWqOPc+xf2V/HUunaT4i8HSsjmOX+07 UNvYCJlSOVc52oFbyyAACxlY9a+trW/N7vxOQ7EPlRkYI455GKywr5qPo3/mZYpKOIm776/eWbiR EVotTsPMYclpISvYtn5uG6kcdPwqnbR+Gop4ttkIrgowREkZAwGMkKrAHGR2OMitrO1kYabnRW5E zAnUJZRt2qtykbqo9sYb82Oea24Yb0RNlbGe6B5/10C46dMuP0/HvWa3uhvWxIjXUMqkadPuKli6 SRlFIyMAFkYj/dXr9M1dbV2giuJXnmgGMFp0eBe44MoUMMjsxFS3HqrjWmpnW+s3t5LJ5eNrLuWZ WVg2AMcKPxHtW/HrN0iP9s8gkDc244bHGSMnpzWSlGWrdrFN9CJ9WWVl/gK5xhjtb0yMY7eo/wAI 4p45mJmAY9RxgE44HH+feqbTVk9hX1sU7yOIs4aLqDgr0yPf8+ff8aoSabZldqj96ccjJ9zxj2/n 0pLsgt+JnzaVGwyBuC8ggA49/wCWDWVe6VbSxuvl53A5OCAM/L1pPmT1Hs7FCbTrQKCkTtyBkHr6 cflXP3uj+eplAX72Du9ev0A/wq1JpD0lFo5yTTr6OZirjOMAleO/IAGON3XBpn2HVv8An9H6/wDx NOUp30RO2jP5yfF37WfxF1gxyaNaW+mjb8kqhrieJuCWWafcwJ9sDB4ArwfX/iL4+8VSO3iDxReX Ic/Osk7bOOnyjC+uOK+nwWUYPBe8o80+7/RbIyrY2tW62XY5Ebm+ZnLHg4Y5/Sp4SIoyzMuwZ+Yk AY/GvUdtkcyuVZtb0u33B7tS/BxF8/6/n3rKPimFifJt13ZzulJ/kDVwozau1YlzS23K0mv3nySm 5JbPAUgD9PSul0j4n67pMZjgmZlMckJDjd8jjDAZ6ZB/keorX2EJRs0Q5yvc9c0j9oW9e7i/tGBV tkSQRwWwWOOLcjr8qj03cDNSXfxY1LRolu/AGl+WpiMTSC5aeRQ0iOBgqBtzGBgKfvMCTmsJ4ZXt f3XuX7TrbU93/Z10rxv4r8Sy+NPFnhLRdVy6O9v4gdoW6kMYYQ+2RyoIzNC6AAHAODX6fWvxc8D+ FbWHR7/S103RYG8r7LiGGOEfxYhjCptyBkj2JyADXDUxNKjUVKjG7X3fL9TqhCc4Xk7Hungb45/C TU7Rp9O1C+tmiuTZebJpkk6SyBUY7JLfzMrh1wSB36Yr5N/4KhHwf4m+Cnw98V6Tq8c+q2XidLJY vOxIsN1a3Ukh8sgOMNaQgnGAWA7ir+tQqQUdFK6/NGU6E4vm3R+P3wlAbxS1u+dskLBjnoMZzx/u ivU9N0gTJO7ArlVZU4HzFz2+gH515OYz5cTP0j+p7mXQ5qC9X+hynxfiRY9GKrhjLcrnA6DywBjn /JrwotxxgDPsfau/L3fCQ+f5s4sdpiql/wCtEamjeH9d8TXY0vw3o13f35UsLeyt5JXwOp2oCeMj nGK+nPBn7GHxd8TXFp/bunxaTp8oVmZ3SeUKR1EcTEZ/2XZCO+K7tVojz5zjE+0PAn7BXw+0mWxb xKl7rV6cJKsrrHBG2fvhIiGA7bWkfr0IPH2zo3wN0TwfpcWm+GNMt7S3B8z7NaIgAO3aTtQAZ6ZJ zwOp4rb2T0lu/wCuhzynzas5++0bxDbSrAJFhC56qCG78kcH0P0PqKqReFPEVxIzzTJNG3yooG0E n0AGT3/LvQ4VH8OqE5R9C7Y/BvXtYWRo7JwAdsoWEEZPIwWGDn6VB4n/AGdtEmsTa+JNMS5sCcqH hDknpnPrlvb1rnqYdvW+q7DUr6X0Pgr4ofsmeHBciy8Ni4stSZhILfiU7WYKP3YbKjLD259eK8UX 9iTxzbvLdandgWm790kDoXf1HBO3twcHnpUqvUgmpRu/63L5Y2Vmdz4b/Zf0rTmVp/D5ebHEl2rs eB1+bCg5/uqO3XmvR/BHhjRNL8VbLTUja6xplwSUeLC4jw24scrsx67T1zXnYyrVcJ318ttzpo8q nGy1R9F6Vp+q2OrJ4mEWmXk++WR7wXMsJjQybhHGn70OFXCDdIg4GepNeM/tPeIrDxP4H8aWtlot 7FqF1pjHY9tIdjKc/NJEXiyQmcF+PrXi4aUvb07v7Sdn0XkexUqwnRmpaOz/ACPxElSe2lcMCsqn IB6jHtXrfg6/8Q+Il1G7uNd8oxEYb7LFKzs2c5yB6DnPevuK/L7Jzav+G587Tu5WTPeNT8aeElie CHwzexoVKoftcZ2Hsc+Xg/T868y1HxLYxTSSTaXPk9D9ojwR17RYB/CvKw9Cuviqp/L/AIJ3VqlJ rSL08/8AgGbD8SpbIRwJp8rQZY7ZrhHBzjIYLGpYcZxuB9CDzXoXh7x7psrXmi6l4deDVL61MSPD P5izFWEgKqVDR8IB1YnkZHSvR9nP2bvL8LHnVFByulZnksvjaQXM9le6CnmIzpKpmkwWDc8A/hjN ey+APjBb+C3abTfBloLzGVmZ592eTz82MZ2n8Pc1x47CfWKLpOpZPtY7MJVjRkmoG94v/aK8R+L7 JLHWNAsJYY87GbziyEjk5DA7SAMryDjmuA8X/GHxR4q8KQeDru2sItEhmjuY44YNpDojKvJJP8Tc 9en0rjw+V4ehyKMpWi7pX6nTVxcpqS5FqrG7+yW17oevfFPxxZarfWMkdgdMhlsLua2ZmmmWUgSR EEgGCMEZx+8BPavpaT9rT4+aD4lk0a48QWt94bktlMn2u0iDxfeDnzYhHKSeMlnboOOTnHHU6OLz GrCsr8sUl3vZP579TfCVJ4fC05U95Nt+l7fodTov/BSH4dLHcafrPw71PT7uBsW+oaXcwXguX6F3 jlELRq2M43yn5jxX2t8Jv2qfgv8AGO/srDwp43sz4wlh3jS7qOa1kmcDc0caSoqSn5WP7tnIX5jn BA8bH8O4rDxlWp+/G13bRrq7r9Ud+HzXDVmoT91+e3yZ6XrWoQ3GoQ3Vpo0jg5imiwNykDdgAnnH zHg4/UD5Y+LWgRaV44N/HbGFLyxiuBCxG6JMvH/eJBJRmIzznPtXjU6apx5lLfoeg5875H/wDhk2 Rt5keMkowycj7w/LHp/9avZv2uLpLD4Pfsy+H4p0Md/NDqSxAKfL+y2KpgnOQR9qI49DycV34Gpy YpRt8UZL/wAluefjafNGM07Wf6nU/sgWMFnoHjLxG8CSLdXENlGGHzRNAhdueOvnp+K19a3GqLI2 yC2Uy5HRyMLnk57HH09K76KtB/15HjV7Oq9DIur3Upcpb3PlPnKsAOTzjIGf5emaXTzqSI5vL0Sy ccFe3B7D196VRTck4tJEe647HURXcbxq7RIdq4Uv8wyD0yevrkcda+UP2nvC+7SdE+KWnwL9p0px Yal5Yx51hM4VQTuG4xzsCqgf8tXY/d4bipJ03s01/XzN8PJxqxdjy/4VeL/+EP8AGega59sWKyMy xXTEtsNs42ux29docyD3Re3NfqHBHZXyeamoPHMOFbd97GTjkkc9+/061wYVuLmrdmdWOS54y7r8 iPyp8XdtdIzQsTgGd8529VOcL34Bx1PrTxotvh/KlMQ3E7mbPPy/KobHGR2IxXZzuzS29P1OLlTd 2XRp13aKJlQOdpywyM46dXJIOfb/ABu299cQCPdZsZdw+baQCOnvxz+dZcyerdhaGpa3rXaozXEk ScZ2qoK/U5PP0Nbf24sTElwzIRncyYXP4ZwPf36Vm1bRPQpPXUtKLK8aI3enWl06sCkkkSMUfrwG Gc8dR6HmrTQW6meQNOjPwP8ASZSF+iZZFxjoBSfNbQvRamMLOSVsrcebc8EyXMMZ49MRomOB1yTk d8057C4tTuNpGYdvzMHkViemNpUjoOue/Wk7+hXuvUzftQhDT3NtMqhsDKB9x/2RGSfQ8/jUJ1Oz hKtNdxgtlVSf90T+DgZP09/Sje9kGqH/ANoyExZiBTGFZcNkDOeRWLeXpmLidGU5+UlMZH5DnjPN K/vWDl6NXIGiGSIHJXOSgIBz78+uPzFQrYzmFlkaZnLsRuVeh6jIxgdR0z7mq2s5Cv1Rh3zXUcb7 4BsTAXew6+n8qx/tt3/z6xf99CqUW9UYyUr6fkfyDojHG4HaBzuI5z6ZFKGtoy251Jzkc8D/AOvX 3tnLZHC2Z2oXd9K8cOkoDGckkFSfxJ4rmrrS79kMt7d7pAPlQszYz6k8CuimoxV3uRKTehgMrq+G PI9afkdf19PWuggUMEzhuR+lIs3QEnGfSiwy3gpliMZHcV23g/xnq3hyZvsOwxFgTG6hunQjuD7i sZxUotMcW07o+gfB/jvSpZRJrv2rzJZwZJY5jlVJByAcK/BJwdvWvdD8QvhHoVrNBpVlqGoq2Xij njjhSIHauxs5yuMjjAGeleHi6FRzSp2t+R6FGcVB8zLFr+03r+j2epSeDbK20qSR1nmVwJlYxqyq WWXcOA5IYYIyQONwPF/HD4u+J/iD4V0nS/Ek1jLve31JHsddsLtI28t15itnYxMRN9yTEi4IbkGs qeFk6kJNu8XfbT+tDSdWKg4pbo8m+EQP/Cc2qAnZJDIpI6D5c+mcEjrXv1n5cMF5Ij/MsmQrdein 8s/09K83NW/rdl/LH82ezlS/2Zvzf6Hovhj9n3Uv2idc/wCEO0HV4LG5tYW1N7qWIygQllR1UKQS xaWM4JA+Xk5xn608C/8ABNfwZ4caGXXEbWdQUAsb65kSIOOSUhjC8HjKyNIMZr1cqjN4SDe2vrvs eTm0nDGSS7L8j7A8M/AbTfDVmmk6fpNta6XG25bSwhSGIHAzhVCqpPBJxnrXXReEZbe4a0stHVYV OPMkPGehx3/Hk160YpbI8hu93c2pNEttI3SXW3zW6AYIJI7Acn15/wARWZeeILKIhEuCZeQIoAS8 g56k4Cjgc5A6c5NaOXJG708yUrnEXV/PcXsyq8CRkBgSrPI2VyRuwApGSDgMOOGwc1q6Nr+jadeS yalaxyvEyktNhAvqzfMAMe+RzXLSxanLlgrpbst0rJuTO9ufiLqmsxfZPCuhSSBk2hgTawKODyxB YjHQpG49xVeDw34k1KA2/iTxGDayby9tayND8vHykqS5HqQ4yQflwa7Oe7dtv62IsLF4b8H6e/2f T7S2toMkn93EgZicliMAlunJJPJ9TWq3hrSUSO5kj/eA5BAw3PcDse/A71k6UL6Fa2PIvGHhCPVh OtmgPG0u/UYP0/Hrxj3r5f8ADeh+H9B8SfEuK3uN2pJfQMx3bXSL7JBk4IyQ0jSYOOo6nHPiZtFr DOUO6/z/AEPQy5Kde0uzNeWz0nVGKXCRC5GGjkJCyKPqNvHXj8O9flR+1p4w8XWHxK1vwV/wkNx/ wi8MVu8FpGxjVg8KNlwuPMOXf5m3Hk9OleZkyU8Y6c1eybV++h6GZJ06KlHvZ/ifD18GkkkdR3Pv jjua7P4d3q2y6sv7zlozlQD2b/CvsKyvRkjwoXVRWO4ur5iG/cS8MO68e4/z2qrF5d080clu23oA xX8+T/n8a44ppXTR0PV2sc3qmmSQtIVgYqDyVZDn8ifWsvU9Yur0WLOrpewoESVCFJAxgnuCMYyC OldVOXMkYTjyvUybXKzB2hdiW65H8813VvuEIcocEfdDc9Op5+lRW9Sqd9VYzZp5N+BC2MdzwOvt z1qjLPIdyhRg5ON2f6f0pRS3uNtn2D8NtGXwr8PNFsG82O/1MyateRvjpM6+TjHODFHE2D/FnjrX FfFfUBo+iard7tt9cItpAQwG0tnIGPQBvyFeBSk62Yyl3k/uT/yR6tRezwsV2j+L/wCHPiWRXDHJ xz6g19pfsDeGbrW/2i/D2rwX8cY0Wyu9TljZXYzxmM221SBgNuuVPOBgHvgH6THTUMHWdr+6/wAr HiQ1klc/oCeazvIlLxeZCcYDjkcZHB5BHpXyn8aba6HjVNQv9UllgkhijtbeVYglvHghgjBFJDSb 3O8t95gDgBR8DjIwjS9oo67PyPo8tqylVdOT0s/Q82e2lWFGMnBUqeO7fzHP6V5V8dvHXi+/1X4S eHPE0Fs3hzSrW/n0e6j3efNHMIUeOb5iCIzAqphQdrkEtwFzyuKqV23uoyt91jbHNwjDTRtH3z+z HZmy+E+izz2qqbyeW8MikYkVjtDZHTKooHqAO+K+hraGCYyrEhIB2syEnbj3PQdf88V2xvGNm+v6 njy1qMSUwhSNyFMcLnJB7c859x61mtOPPeNSepBDZB6dRx79Kq2hMb9jTtS8sbMz7WzgncOenbt+ Yq9LbxaxYX+hanEtzpN1A1rdRFziaN1KMnykH5lZhkEEZ4qHZNS7F679T81z4f1PwlrviLwTqp3a tpU7QRySAf6RCw3QShedoaModuSRuHUmv0t+CviD/hJfh5ot8WE11br/AGddnzMv50OFy+4D5mQp J1x+84rhX7vFyitn/wAOjuxPv0ac+x66zYUR2sSiIgjB6nAODwePUAZ6cg0kTsu1diqgPTAO76/p 27V0uxxWXc3bW8smWMSoydNwUf06+tb2y0ljXy1feflBA+UH/Pp71F2mK2thken25JDyBFLYbjqf cYOcfh09akk062ZlgVg7dAx68k+nv7dqTVmLdEsdo0L+Stw3BGO36+nWrMc1zBHJG8hMTAYIwfp7 kVL3KsxHW0ZWkhco/wDsbwc+hx3/AAqy093a7WSZDCPlIZzkkjJx/j/OpfvXuVaw17sD5pLYlh8y 4CsGz7kew/OoLg6bOh82yRZSNqncFb6cj9P8KT0vYL3Mc6FpOZJ3sY1lbjzdu2Q9f4sZ/WqbaZIY zHbXsyZzkOwb8Ruzz+B60cyt7wK/RjLrTW3LuZREAMl4xITx1yuMfgp4/OobqM2YRoFeaIQb5Nvy sJNzDYodgGUKEIbIyWI2jGWb1V7i3OSvbm5iFjBc6bcMblWxhDL5YyAA/l7gmeTz/d96r/2f/wBQ 1/8Av0//AMTVWt9oOaK3P4w4oEDksoZiB9f/AK9dTp+m6e8TXJCPKuMRKNxPXkkfLjjpmv0ZqSZ5 CaaLF34Z1F2LWjJJEcFVX5D0xxkn+fesK5TVLNfKuYZAFHzCRMjk4zk9s+9PTqF+5z13E8oO6IAA 4Ytx/Pmsl7cR48wMvbOAQaqMraIfmV/KkOCpDYPb/Crtlp1xNLG7oUh3ZLFTgYPOPWrcklqFjrVS 2cSLd2KlVJCyLkK2OM5Azz71r6f4a0jVLmGG21qG2Ow5OdwzyQDu29TxnJ4rLde6P1PSLXwne6fo 4uLrZKIXK+daEyiRTgk4ABXBYDnr2yBx3OkeDV1NrS6QXwtmyHa4sRCIhxhiHkDHk9lPr2rx8RUl Scm1971+R20kpJK56p4f+AzeIJPK8qaWBxh1jbYhB4YNIQMAgnjg44p3xb+Cfw58CeDdc1Kz8bW8 Pi2KKKGLRLTbMshWZS3mtgvE4WQtliudgHOa4qWMrSqxjFLlbsbVKEeS63PAPhLdeV480KRxguxQ nAJBZG9evavfby2ZtTuiynbgykDsueQfyHFcmavkxql/d/VntZTrhpJfzP8AJH3l+wtq8elfEzV1 aWKO5uvD09vbyzAeXC4ktJNzKWTcAImyN6cA4PGD+m+qfFXwR4f1xdLm18/a0mC3SvAZI4QVY48y NSN2cE8kjkEZOa9nJoupgoeTl+f/AATys8tHFp33iv1Ol8OeN/CPjmHUh4e1qG6gt5RBcCJpFliY ruAKEK6bl5Bxzg46GuytNBuJLaJbKIhQmRJJuLkEZJJbnPPf8a9RxcfiPFuePeKLfSNIuLm61zXW uZ2bZHDCQQeO3BBwepzkD8K8UuvGUtw8sOh6FA21djSE+ZtYdQT0TuPmZeQa4KlGpOX72Xu9l1/4 BrCSitNzR0zwJ4k8WPBe3jzR2coRjL8sarhgzMSVOTgkAqJR9M4HreifCrwvok9tdXFybu7VxJ5j khc89OcKTnGVCZHUDnNRioLkgrL+vvE25O7O8OnWheVreKKHapDlAFyccY/z/Ksi5WO1a4le7VXc Yw8ijb1A45x2Hua6Yb67Es4WS3hleSTErtKpQnfnA+U8Dgdj/wDrrI1jxNa+HIGlmvoxZKuHkmfA GBwPz4wMn+VTJwpKU72XW/53KipVZKEVds+d/G37QOgadbvBp7tdMo+RWYrCAR1XI3uQcHAAHfPI r468f/FXVvFflTa5NHFBFk2mEET2qtgExeX+9GcY3bs9unFfL5jmjxMvYYVe7pr39Oy8+p9dl2TU 8NH2+N+K2i7f8H8jyPVfjfq2jQmzi8UM9ocPu1NY5DkDA2sgExOR1Z3z3xXx7+0B8QtN+KPi3TfE ek6S9tONOitb3fKXSWaNpBvjyMhShjyCOCCOep6srw0lXjiWraNNLZ37f1b0PPzadNx9lB3W67r1 PJfCvh5vEWtRaa48yMI8jIMqBgEdunJHevUZ/DOleFJpIUgEaTbVYknDkZ6Fvz/GvWr1n7T2Eequ eXRor2TrNbOxmNc6cXclhsDZBBH+R9aS3nsA0mACm75TuGTnqODmpcZ2GnBs01Nm2IfLJypxwcHj v+ArjtW0TbIzQwsUZsjaD2ooycZe8yqkOaN0hLbSxJhRE+8HBJXBGM8fT/D89b7OkaqGjbJGM7D6 cnGOaqc7u1yIw0uU3gi5ZLd9wIJxEeh6dBS6Tol1rGvWOlWsUoW4uI4g7REeWGOCxwOgGSfYU3NR g3J9CeSUmkkfYN5NFPqF21rGEtEKxpGq/dijAjRB7fKcewFfIPxu8Qyaj4gh0gN+5s1LSYUDMr8n p6KFA9MmvIyqmpYtS/lTf6HoY6f7ppdXY8FLF269Ometffv/AATnnt7H42eKbi4BIXwtc4AXdybu yHv2z/LPNe/mC/2OqvI8iD95H7b2eu6dJHIsRJAO47mJ6nPOckDnj06V418YWt9Wj027tUViqlCx zlMEHcPTq4+hr4zGwthp3W1vzPXy6f8AtcI+v5M8VQytbvEzKXAI+Xr+H/jv51zXjv4Yf8JgnhHx Uskkg062ktBBz5YXzWkycDruY8dMHGDXn5bWdOu33TX32O/NE5UY+q/Jnvnwg8a3PhfT7bRrjI01 eFU/dhz/AHR2HY47/jX1LZ69bXkcLM6TQgljHyFzgc8YOenp+lezyLoeOnrqyUSqdrI/IAGT6cEd M5PX86c8iNH5qSyDA7hQu445POD/APrpW0Euupatb+UbVWU4zt2soIbHuO3866UyWj7V2gMhLbVY gk5J7j1HTt1rCSSfmOz2PlD9pDw7Lpknhv4o2u/yYc6Tq4QPJshcsYpSQvAVyVLHJO6JRWt+zB43 nj8U6t4NM4FvewGa2BmADTxBdyKp4ZnjYtkc4g56CuLERSqwq9LL/L8juhLnwjj1R9wvqmoW6TBr d1LALlk2AjPOMjnp/nmqseo3KiM3UeA3IGzdjnIycf8A1q3TTj7pybaGhpskbEiO5Dvz977x4xz6 8Z/w5rrLe5ugkfyYcZb5e47k47/jWbf8wtWtTXFy6bhFKrRgn5pAM47ZXJAOOcDpnrVuCRxnzHjM mMbQAOnH8+e1RLl2Y9UW47lwQSyl2A+Qk4Przjpz6VZefCkswAAPPT88nis/IpPcajRkEMuVOctj jj/P8qRdhRY4iSmMjpjr+f60ataA1bQ07Cwkk3B1byxjlhgnIODk+2Oc/jWpHoVvtzLebWPI8xRj uexA4/PjNEVeWopMWXRYbYvIt3GIuADgDOemOueM1WFhaTOzNCsiZPIHLdO5x27VXLsCfcglg0+M j/QpQfuqH6Z/z/WsS9e2tgXlAIYA43YHt79ff+dUo30K21MK5uIJomj+zEP1U8c59P8APesny/8A plJ/30KaVla5F+VtJH8TJaSAZlbapGQDxux7Hr+tEdxHJ8saOpOVGzepfJ7g5B47ACv0k8bzPZfC dqF0uNJbndInCoyhDt7Z5OOmK3bzTFvbS5tiw2yxtHkjOMjrn2PNZz1voWrnzDdm6tp5LZ5PuOVI zwCPr71XLPIQWJb8c1okrXBMvwQ2rAiQ/X1/AitSKwmP/Hpqp8wdFfOPpnn+VS/NXGm7G9ZSamwa 3vdLaRehaIHP/jua6y5+HN9LZ22pLi3gBV5Js5kRCOm3jc3TAyOccjrWDbptNPQu6a1WpiaN4h8Y 6RdW9rokNxNqTEiG2SJnLkDJIVeTgcnHpXvnhD4t6x4Y0DUtW8caKJbhGEcUkrxhkmOCIzAo3KMB yC20thuTtbGWLoUsRC32+hpQqunK/Q4vxj+1L43123m07T5jb2DblwPkG1uMFY8bvbeXr59m8Qaz ql7bSahqM0oD5CFsKM9cKOB+FPDYGnh4t7y/L0Kq4idV22R6x4D1VbLxRoN2DxHcxk89Rnn6cV9l ytD9vvpmYYYL87A8AsxBIB54Iz+PpXzGeRaxFNrqmvxR9JkjTozXn+h7d8EbG9i8eaLNaafdXFkf MilNtaS3JhDI4UlY+fvep9CQw+U/Wfiabwt4Thn1fXPEFjp1orNBLLeyRmPzXVlKMsgBR8biCUGD ypyuROS5rPDTVBrmjJ6pbp91/Wv55Z3hYVpxaaUlH9Xuczpr6ZrNhpWr6RJ59hcwxXdrcRl03Kdr I+Rhh2POOTjvivV7r4wfFaG11Ff+Ela+Rtht7S6cWqQ8YYLLFC0gBBJyd2DgDaOB97Je7fl/ryPk IycW0zs/DOpeG/Flxfza3r0NpPG8eUupBHCGfO0h2O2UHYwKuZGHB4BXP0tovhXSNOsnisbGK+j2 qYvNiUJGNo3bE6KOTyOMelcFWLg+aSv5m0feV+hPearcK0UmAqquPkAOznjHH0FZT61q1yVhI8uH +98mRzxyTjr1/wDr1DT+yUnboUJL6cMzicsRwGiGO44JwQMDHI/rWfdGAQmWe+YsX4Qhvzz654x3 +lS03pfX1G2eQ/FnxFrOgfDzxt4i8PTw/wBr6fpV1fQecAUBijaQkjoThG4JHJ61+QNx+0/qviC4 jfxm06TlAVlhk8xM9QFVseWM/wB3OM9DxXk5nQrYuLo0p2t06P8AXoevlOLo4So6lanfz6x9P6uc nrvxg03yJri01FY0ZsEJvad8dAcglc9zwPevEdZ+KGpXLt/ZyhMniWX53xye/Az+NcmDyyUf4q/4 P+SPRxua86tSd+3l5+p5TqF/qF7PJNf3TyTljuJbJcnkmsOfcT8z4OOQeT/9f6178IqCSitD52pK UneTNTwjdNDrbyRSsriInKEqcZXjOf1+lezbnvwWmllaQ9Q8zN69MnP/AOqubF+7UU0uh1YX3qbj chksI0tQ3mMXLbWAJG7rg8f54qMRfOU67f4Q+D/9bk57dawdRyVzZU7SsSGMKCnlk4BIwTyf84qG ZIpJ1dwq4UdDnsP8/pUJvcvS3K12I2tiWZUT5s4DbuuMc/8A66rPaMHP7sEdGHXHOP6GqUu5MotO 1iqqlCqyxgjBGWzgdCK9A+HNjHHdav4jeLKWFsUibH/LeYGNQR/ENvm9O+PSoxEv3MrPy+8dCN6k b+v3anbyXsem6fPfzuAyxs/PU4xgHp144r42+Kd59t8bavdLBFGsyQOVt3DpzEnII/M+5NaZTD95 OdtNvLoYY6WiizzZILlm+WByevCnivsH9jm21C2+JWr3L29xHAdGlQOFZFJ8+3baT052nj29q9jF OLoyTfQ86Ds00fq7Y6zcDKrJuHRhnPPHP5CrGp3IvdPvLdT5k4UMADzjPOPwzkV8pmMLYWrZdD08 DK2Npev6HBWwRc4JJcbeCeDxjpn/ADzXr/gq2+2eF7mwCkxi5kjPGM5CseWPqxr5zBu1VaanrZl/ Bv5lCx8KfYr5irMY933QwIH4dB3PSvYNBiubI+QtwXtScDKhdw9zn/8AVivoqcnKN0eA7tvseg6f BLPb74iBDxk7hz3OO3/6qkeLYPs8DMw4ZtoJGSevXH4/5Cb0bZab6kym0tZI/Ms5ZIc8kMFUE8ng kt2P+Paumto4pk+0Fniyc4dxgDjv36VyyT5rrqaejsYXjKPQdX8H614a1wxnT72FreU5VmXIJWRQ cqHVgrqdv3lBr8+Pglc6tZ+M9GsIrWV9e0nVFgvltjhTDGypLIXbojRlgG754BJAMVaUvYOT6M3p TUYyi30P190p0kjPlPG9kV+Z2kBIJ56N79+OvoeYtQjbPlW4YTLwJVbhyR0wT9azTbfvGPa5TNhd tiKVj5hXKlASWPGfTHFbltcajZb2t5VliUcbs5HXgE/j/jUT9B20Ny01eNLdxcRiObJ4ZVIJ9/z7 jtV+O5cySSxxll4yysCB0x6Z/wA+9ZS8xtFu2N7uaOI+YF53AcY7ccEc/wCe9baXJ85lniAI9OMM c9R17j86jm3VwJHa3G2fzsY5GSOnUjgVZdYY4GltZkcMcbQXGD68j/OaLvZItaFiC+cRYjkAQdAz cgdvr14rQtLy52EFsnBAwP5+o/KnFtJXCTT1LT3E/BaPc2QrFDzznBye30/KtKKTO3zINykjJGAO vfBzV3vrLoS9h91GkmRGcbuQBwAOgwMnFcZqdhsLMd7RN0YdBxg8f/WrTTRIOl2jnpkitkkMJAuC MRbuQzYwMLjJ9eOgBNZXmeIf+mP/AH4krSNra/mRaL3/AFP4wPEfhzXfDMwsNY00CMDKNjhl7FX/ AM+9bvw68MJqMut+LLzTmn8GeH4Ev9VBDDzS0gjt7UsHQjzpmSMlG3rGJpQp8o1+g86cWzyEk/eR wNxquoNeT3pu5EuZXMjumUG5iSeFwF+gAA7VuxeMbrSNLYI8l1qDjcCWLLEPcjn8PelbSxWljgWa PVjNduVW8LZZcDac+g7VXltI1ZFkjMbkZBQ8Hkj+nSr1joBU/fgEmPcinqBgj34rr/CkUeoahFbi dATuba6v/CCf4R0yAe3SiT0bQz3zwz4Hu9NiEzwmYlVkd3YeVyDgkcg43dTgjcw65rnvib431Gym 03TtMJCxAs2AAHwdo3DnIyrcdD1PauNNVapptHU8cPjzxGt0bqC5jimGQpSFPkHtkGue1DVL/Vrk 3WpXLSzkdWPQe2OB9BXZGnGOxFzMfBAI/Krum2N9qN3b2mnWctxfSMAkMCM7yH0CqCSfoKqTUYty dkCWp9g/DX9mz4k+Ib3TNR1W1j0rS/MRy11lpmXOSVhX5genDlO3Svua28MfCnwyG/4SXUpdS1WP /WW69FZSwwyqVRTngo8jHA6Gvgc5xixlaNHBauN7y6a22/r0Po8uc8JRm6mnNb1NyL9o3VvClu+l /DvSLPSLbblZlSKWcD/ZJUIoPoI8jP3u9fFXxd1Dx78WfiPoemBb3WvFF7bLbwRKXnnkw8rlQOTw GZiegAJPAzWmU0I4etGTd2k7v5GGNrSqwfqfpL8LPBPi3wB4D8P+DPGeni28UaZHLa3Vv50cmzZN KFUPEzI3y7QCpI9z37q7X7IkE13ZFGdC6FgSZFyRlTjplSOp5Br72nUVWlCqno0n96PnJ3jOSfc5 q4s/7US7iltFFs2VeGYKyuDwwZWHII7H0+pr0Xwd8QvF/g0sLLWpW0yO0FlHp0p32sKIE2FE48sq FCAKwXbxiqkubRroKMrM958OftD6VeR6RpnjLRbgahKjG4ubF4FtIZNzlciVw4Qrsyw3ksT8gAzX oFtexeObZdQ8NwSSQFXOyDdKwVSM5UD5cbhngYBHXIrlq0+RNp/8D59fU1TRVWK2hjxcX2y3i4bJ xtz0+n5965wRWNlLcNb6jPdFz5gRpd6x5GOD6c9OcVy6vVy0Zep5R8YJIZ/hv8R9PD7nm8P6jCkY yRua1kA3YwepA/HJr+elZobqBQJt1ypI25BO3rj1xycf0rCafPfyX6m0W7NWOa1VUSVTGo544OcY /pmqAiJVmZtz9gB/n3rTokVFXiQyuqLsVcP6Z9PqKq22k6lrd0sGm2Uk0x6JGvPuSR0HXmrTUVzS ehLTeh3Wn/DzVvDU8Gp6tHGqOCm0Nu2k+pHfjoK7C0lTcdm1nxnGQc4Hpj+f65zXFiJqr70djswk bbu2p0LqGi2LDGCONpwAOPp/KqZteCwVRLgjlsgY5A/DH51wqdkelKnzapFOa2uMhQ4AGOAc+v8A 9cdK7T4efCf4hfFvXbnRPAOjfbNThh82ZTJHEqLuCqC8hVAxJ4XOSFJ6KSLlXpwg5yTsv1MJ0ppO zPVNX/Yv/af0ckXXwzmkj3bVe2v7GUYz1+SYkZ46+tcfP+zH+0TYBy/wo1gx4wTHbeYBz/sZ+n4V m8fhI+7Uk4vzTX6GMVKVpRZ5t4o+Hfj3wbcrp/izwrqOn3ZTzRHe2csLFNzKGAZRxuVhn8q7DQrE 6f4W0ex4E2oTPeSblIYRjCIGyOAQu4d/m96K1alVpJ0pXTd/wubU4yTd+xxvxH1VbW3j0mOTlyHZ Q2DtX5R+Zyf+A1e8L+C7TxBcSajJcZiNvHhQq/3ACvfpz745rpw8nQwyn3OHE+/NJs6C68P6Rpsi oLFJZAOroDnr2x9K73wJqFrpPm3pjWIOuxMEjCg54H1/pWqcpv3mcrtHZHt9t4xdYpJIpwVVggDH OT+ZJr0TSNfluIX89ABKNiuhHPOSOw7Y7VjjqXNhasO6f5G2EnbFUnfqvzKlqsm9GkbKABC6kjdw cnPQknP+Ne1+AhC2l31uWVZDPvPXH3UXqenT9PevjsH/ALwvn+R9DmV1h/mjs7WBEn8pJdsnULs/ hPvjJ+70ycZ963LWBvOVi+22A6D+Pv1zXvUk7Kx891O3h1+18uOJV24GCM7iRk+n41Odcs4yi7lG V+XnZjjA56+nHPT8KqSv7vQ0umiVZzcTOyBvLOCuFBz9cfnWmbLWdUKxxS4DDGD0HAx24/LtWEny Nsq9zS0z4WLeKsuoXcsg4YqMjcegzz61k3/g+00nUJLiHTkEsgTMiKATsCquT1OFAAznjA7VhKop 6SewRjpzHb6Jqk7xLaFeRlgQGDKMj0wR16eldrEv2hd0b5XI5JH15OPb/OKmatqkVFplkLdF0hMg JGdrBhzx2544ye3FS3MN1bwJcSzfuSQN2doBzz0+vc81i2k7WL21GpJlfLa5WRSM7Sc5Ax+nSujg nSOVRISgOG+Vtw/z7e9ZSvdXG1sjSFyzO0lq4jPXhs5GeTjGKuQzywgKzNkAc8foDx/+vrWcpRWl ibO3oXzcknEgOcEA7c57A5/OrUcsJO90ynqBx+Qx24x+PFPR6oq+upMPIfeEmVXI55zsJ/T3z/8A rp8d7PHG3mRruDHDKSee36YP4VSY21uia3Z22CNgUAGQWO4njnIxn6YrWjk2ALKCoJyGXBI/Ac1U b77iv16Fr7THGnmfaNq4zwOnv7imSylxHIGRumMk4+px9elWnqvMRyUoE11qN0Ewu4QqVI2Dbk8c ccsQeTyMcdKr5k/vf+Pj/Ctm3fWNyHdaI/i10H4n69pFmNB8VWEereHBn5Zhl4uOqt94Y/EfnXB6 X4y1/Q9dm1vwxqNzYXP7xV+xTOh8pwQ0ZwfmUqSrA5BBIOQa/QrJu667nkrc9W8SfEzRvGHh68m1 34faTB41DCUazo8P9ni4yRuWezhAtNoXhTBDbsGOXaTpXhRn86XNvbMrHqqkkH1o5VHRPQPQ3LTy ri3c3SHzVI2BVGWz1ye3Qdj3rVttEv7sCBQUYnAypLD2Hc9/xqJSjTV5MaTk7I6zS/h3dSqWY7SW BLt1GfRRz374r9H/ANmz9jv4W+P/AIbat4q1bxBqlt8QYNVks7O5hFu1rFGIYGDSwNHukB82QEea p+7hhgiuJ4hzcow/rVaHR7L3HK+qOt8b/sj/ABQ8P2jT6dYJrun43Q3WlAszA4ChrMr5yvjqIvtC j+90r8m/iBY6vZeJtRg1nT57aZZHiVZ0KkhCVbHAH3w2fQ5FLDzTk4tWfb+tzJu7t1OBntI5Q3GP Qiu+8J/A74k+L5If7O0JoNPfa32u9zBEFYZDDcN7rgdUVu1dVXF0cLT568rL8/JFU6U6slGmrs+l vCv7LvhLw+9tefEnX/tJJEn2WCQwQkA/MC3+tkGCD8gjNfRFn4o8F/DrTm0f4feEbKzlkjETXK24 BfaSfmPzSS4H8Uj7vyr5LH47E5lLkg3Gj27+vf8AL5nr0qFLDJSl70/yPP7z4ieINU8yK+1mX7OQ CY0OxG9AUUfPz0Lc+tc3N4jSBA5b97g4Zxwfrxx0wcHvSp4WMfcgtBTr3vdmBfeM7ZUZYfnkZwVJ QDBweB3wQf8AOK+jv2B/FPhPT/2u/A1z8QPDc+p6PeaXqtrG9or+dYSx20lwJUCAs5IhMBBIAS4J JwvPpUsNGnSqOb5fdlr20ZyOpz1Irpc/Rb4x+MNN1z4xfEi70vSZtM01buzRbGYnfbhtOs5PnOSW Ll/NxnOZSMA15hd3cLvBHM+wgFUYg/NyW4HYew+v1+jy/wD3Ghrf3Y6+iPNrq1Wa8zHaRQ8IdiGZ hHEAMksT8oA9TnpjvWoluqsTIuwKed3vgZwRyOT78/XHXddUZKzdipdTwBWhtEjPQMQuQ/ToDkdg eKvaR4q8V6VDOmgeLL7TpGcSiaymaJ0kxt3rjjIHGSCMdscU4trVAvde56HY/FbUZ76M63bxTafs LPcRlvP80cAlD8j7ucsW4z3rv9K8SaF4j0+2v9HlcGZ3hWK5ie3uGkDc4RwrOvHBAIOfy86tRcHe C0/Hb8jeMk0N8T+HJde8L6zo00Wx7u1ltmDsGU7oypDAdiCeMZ571/PR4++Ffjz4d6vJZ+MvDdxY XImdEldC0MxB58uVcpIvXkGuH2kY1LPqao89vLacS7pXDIAAO5z+PTp9Km03S9V1q5Fro9hJOQcE oPkU4/iY/KPxOfyrRuKXM9EjSL91HvXgz9nbV9YvIjq3mXU0uW+y2aOQTjoXxkj1wB35HWvu/wCH 37M9hpkVpFqkMdna/KWt4HLPJ/vPgjPX+99ea4Z1J4mXLDSIN8iv1PTfiL+z1beJvAd94V8I21pZ 6jJNFIk8zMigKQWLuqsxyBjGCfm6V812P7C3xAsgZz4q0djkAhHum47/AHoQDxg49j6U6lKpH3KU dO5dCvGnrKN9T0f4dfsP6re+L9BtvGviGJvCxmP2uOJZEkaMBuFk5C5Kj6A+9fY4/YM/ZygcGfR7 qX+EeZrV2oB6clXXn0ryMVHFU5pU5cqt0s/zR6tGsq6cmrWZbi/Yk/ZmBKHwVGW2jl9a1FsEH2nx k8/n1rotB/Z18A/DG6mn+FWkJpMtyVN8yX90zT7d3l4aWRwCpeT7uD83OQBjzMU8wdGXLUbe6Wi6 36JHVT5OdNrQ6ubRfHGxpZfE0jY6FtSUYHqMvgdP0HpXEX2teK9OfH9uMwYdVuwwPHrkjpn9a8qr icwUk66f3XOr2FFL93+R5hqXii41Xwp45u9G1C3OsXdlOn9oGQF4pkiaJGbaCU2EA4C+pxzz+YGs 3MU2p31zHxY248mEMB9yMAAen8OPSvUy2q6ymppc0dNP1OOvTVL3o/aLPjP4TfD/AFTV/DK2HiKP ULz+xo21BrO68xPtgkk8xQVJAUKVwfQVoaf8OrTTNMjstNaSK1BOVLFyzdfmYj/I/GvoadWr7GEZ q3l+R4tW/tJIpar4V1iSzMYdHQBcHOMZHpjjp39DXKWekazCyC6gcRrwQqcjjJ/lXZQlFpto55t3 2O80e6t4JYY5FUkMAFPPHI+7jGfr/jj6V8K+HrS6tleK8QXBVpAkjbMAY5Ud+Tz16/lGIi5Rcb7p odNqNSM+zX5j2s1gJjSRsBTtwTgjHB5+p6+xrqPD9w7W9zulcH5DkEfNgsOT65GK+MwNlio/P8j6 jMmnhpP0/M9Z0ia8mMbC4BIPLSKM7ee/HtWnqF1LOzW4uG8pSD8jFQPXODyfx5xX0Ub2ufON3epH poO9QxkMZICqcsAAMDDYGc7c8+vJrstJ0me4MiibqTzGu1G54B69Bjnjn05FJp8vmKO9jrbWf7EF iZXMj8KdoUKSf4iePxJrStdWu4ZFiQv5+4Yjf5GYdwMCs+XujU6rT/ENzbjypW/dEKSepGR9M9+m P8Kbqeo7ZBJuLsWIBxkYHt2xz2/rXPOPvWaKTvZXLukQrK5eYhWc87H98d+fb8BXWmx8vzG3s3G0 46c8n681nJ26lKN1chWbyXBLuQVxtLc+5Hb9cVeFxcGADnyGHzIwyWA/2SMGud2e3UqLPIR8XvDu pavqdlpGmfb0spdrSBlVCWyAYsZMgDArkADvzkGuo034rw30cco0WZXaTyliaKTEmTnKP0IwyknG Bz1IweDGYuGHqulbmatfW3m7enU7KeG54X5rXMeL49R6ZPNJrHgm/is0Aw0BRpSTj/lnJ5YxgEnD E9OCcge5+D/G/hjx7pS6z4Y1lLqzJMRaMMrxnurxuAynGDyOQwYZBBrSnUhVh7SD/wCAYVKbhZPU 657iNdjwShjjAx/Dn/PWolYTEyyLIGGCMHPfHI9O9O3QzetzQWQfaElKYIHIwBn/ADnt7e9X/NYy vtkwGAxjJAwfc/z7VSVhrvY1LMQNhSrHcDkjpnvjH8+9WdQlWGOW5ml2wRoXZsDaqjJLE49P5VcU 5+7cS7Hwfrv7ZHh46vcr4a8EXV9pkbMqX1xem181gxVWWNIpDtY4AL7SAwyowa5O4/bemgufsU/w 6VY+dy/21IrEjjr9lJwCDkDOeOeCD0ONOFWVKMm5L0/V/ibez93nueieHP20fhXqIgg1Sz1TTP8A Ry0kzWf2m2RwAfLQwlpXbnqIgvvXTf8ADXXwN/6G65/8J/VP/jFbJSW1n80v1MXFxemvyP5LviT4 r8NazDpLeFtBksLpwzXYkfOw8YVOM+pJPPTHv5VZ4luYUe58t2OPM5O30zX38Vyx01PGS0O806Oy u7j+yr+cB5CV+0KP3aH1bn2GRx9aRdIhsdTurM30Lukhj325bYSuM8tzkZ9SM1nJuPQaV3qd1pml WJk8xsNJnJyQOT+f9OtdxpsUUGI0jWIfc+UDrjGa86tKUn7x1QSXwnT2qnenBJOCoBHH4DPtX6Y/ sQ65FaeGvHsFzDmyW7t2ilIbBkKOJFXjaSAsRIzwGQ91B5oqzfp+qN217OSZ9q3/AMQdJ8KwTza3 qtpYWDRNKFuJB505BXIiiX95KQvUKpPtXw/+0Tq/wG+Kmn2lpceErqa5tppp5bgyw2dvezOyEuyL GZpAwQAkPDL6OAxFYYnFUqFraz6epFPCSxDTekV1/wAj418O6J8JPACrdaNoHnasuzybqVRI+8AH d5shPlk5PKKAfTHW1rPxW1NhJHphS0hPJNsjB8ZGAZCMgjH8O3jrXkuFfGVnWxMrrsejz0aFP2dF a93ueVnXJZZbuS5DNI4JG5jlm92PJ7f49KTU/FNu9ogkkbzQNu3O47uOmOevp/SvQWH96KXQ45Vd GjjZ9VeKTqItvPzffGc44HT6n198VhyanJcyPI+CBnJZsnHOPYdun1r0adNJ8zOWU9LCLIJSV9SS wOcDjv8ATkcg/pXuP7Pnxa0r9n745fDz4u+IdFn1DQtNg1aF7O18vzbr7Xp11ZKAXYBBunUlxnaN zAOVCnRqMr0p7STX3qwRlytSS2PuXwp8b4/2htQ8cfEeHw++jXFxqkWNNW+F20SRWdpEu6Tyo9+7 yifuLgDGTjNdLOF1OCaC4YgZyqg4cH6qemODz3PNerg6SoYWnh1K/KkkzkrS5q05Wtf/AIc6aKa1 0mxtltI0QAAMXYnCgY5PBOP6c+lZUuqtdB/NlXGM9d5z9QenTiunS+5l11Kh1G3tYQqZaQHr1+Y9 CemOn09a5q6vDJIzq5VH2hQc98e/v6HrkHvSvfRCSTEgaWaI+bdeVGXxlgccH29z26Ht2qrcNbSF I71RNDG4kTzYg6I6/dIDA4I9cVKk9VcqzVmeqeHPjT4h0Oe+l1xhf2twC+JGA8qXPDYVcHjC7Rjg deK9FX4rfD/xToW3xtp1nawyytDPbX8cc9u8YK4dtwKhWJHD8/KeK46+GjVi7LfppY0hK7948p8V fsQfAfxleQ6zaWV3p8bKJmtdNuQLaQnkMUbeFBB4VCqgdjXeeHf2R/h/4fsLYQWD7Y12iOSYAZGe AE+Uc5zgV5k6FSVozm+VdLa/N/0zZScdUenaZ4A0jw5Gqabp1vBbfcVYwFLj3PU8/wD1662LQVVV YwfMozkj0GeuR2/lW0YRpx5VoDvo2ydtPFvGwX7gJQZBy2O+B9D3qxa+S0OPLCnI4ORxzgnoM1ak 9Q03MHxHpK+ING1DQLi9uoYbiIxNNZzNDPEeCpjkXlCO2OvQ5Bwfmkfsn6ZHcG8b4q+M2uz915Nb +YA46YQHp1GcYNY1YTnrFpPzV/1VjSnXqU1y05W9DtLD9nrSYHit5PG/iSe4OPmmvI5OM5G0+Vg8 ZBHX3rZ1L4FeFLUpby61qtzcEbl+1R2hGMEZ4iBxxnJz2xzXDLByfNJ1X8jqeOrtWT/A4PxxY6L8 KtHjms9De/iluCYoDcGDc5XJZhGFR84AwR3znjjxw/FLWfLlh0fwhpkE7AEhrLzHycY5JOeW6Y98 dK+Ux+DgsTN1qkmu1/6ue5hMTKWGjKW/V/5nE3/jD4o2NlqT+JdalOjLbuY7f7GbeFtx4jT5QCBk nAJ/XNfOUWj614nMmm6EUS6ADvJICAuGHXAznPtk4PTFepgaNKFvZU7JvY48TWk6bm5XsnsfTPgL 4c6jZWEDavHC94NyiaOMkuoGcknk9cfQVr3+iMpmeOYKEIAQqoyOe+Bg9OOnWvYajpFI8a95Nvcz ns4zhGUt1wxYAE56/N1Hfgityz8P25j8qTyyhOVyQxUH1PoOmfxp6QV3di5W3YtQ/D3wxczb3iaK QgktGAFZ+x9+v6EV6dp/hsweSkM6mLaANxAK9s5HuAfypRqN6S3Bx1ueX6zJIms6laycIjqiqFwN oGB26YXpzn6Vo2Fy0dvsWMGVwM852gdDg9f88V8rhvcx8Y9mz6fFy58E9Oif5HZ6ZqN7FbLEse5M FiVYZQHsRzjBAx0611thazTRlipLEqAGUEEdyDnv1/rXuRklNX0PnGt7dTsdNs2Uxq4JkAGxMMOn oTxxjHH0r07RIp9kIEZ2dMFeMdOjfT8qJatrqOO1zrJ9L0yWCU/ZFDOuchRk5xxntnmvKNeuI9La RI2ePy13RiYEEDnOOcEY6jjpVU276id0rrcwbbxkLdDc3bMqKOCMgnjAxgnoO+O3PJxWvF8RNPmY XMtwknJGW3bsZ4yeT1J46ce1ZVYc8lYtSdrNHpHhbxro10iL56CIcfO2Vc+xx1Gf617lpv2Z4YXg utshAKqz5LjH6VyVqbVm9jWOsbl6W2unMIaOOTL/ADeZ6dc8cj/PNVZ1tIDtnt1QAg5UEBR0JGfz rlv71oml7u0T8z/BviFfhj40+Ifgy4aV7PT757e0vBHFI5t3bfbFzICrFoTyCCQVP94kd14ev/EH xEm1e8tf2hIPCiwKJbDTdQ8JWd60qlA4L3S38AGSTtRYCY8+W2SOYq5bh62NrV60ObmasuZxSvu3 o/6fkdftqsaEXStfa3X19Og2fxppc9pFY+I/EF9qd7Emy4ureO1tUuX4BdYhHIUDct5fmOATySea f8NPiVofw/8AGVi9ukkegagXgvZmAZJbcsTBIw3ARy277oXBB3xoZkUCVVB9SVCFqD0vqvLV/g7d vQxdSc01WXT8T9CIbiWWOOUzHyyARycjvjge/wClb1nfxgCBsscqpXbkZ47jvwfTijR6ow2NEyW7 NtwATnIJxx6c8n6Vdt2ZvmyDGOD0Htn0/Ci2uwX11Rqb2CkBdvzenUnoPyptwVmSWG5h3o6FXBzh 0xhlPfBB7evFUrKXmXdWufjjceErj4e/EXX/AIdeIrmc6VHM1vY6tNFM63Fs8SujMQp3yOvyNsDR 7wynGxiPnm70L4xeNvGHjSx8P6t4ag0bT754NMPiSTUIb7UbJCFilLRRSQN8jRZQNlCwBUV00aWG rV61XEN6Wty2vr5adLP8tjarVnSppU1e7v8A18z2Hw98LrBvDtpqXin4j2tn4jdcXNpp+iT3cG5Q Sxhk8yPcoUB8lUIGBg85l/4QDwb/ANFbm/8ACUl/+Sqp4aUpSaaSvprbToYKvNxXur8f8z8svEnw JtorY6hompW97pxJAKOGIH+7/npXy3qJ0eGabTtMkzP5hQyBA0TnOBg5zjOecEccZFfcQcpOz6Hj q66HNQSSABGbIJyyjgH8q6eyup5SrSOdirgDJPyjsOa2n0Gl2PRdE82QWyRozyswCIv3nY8BQO55 GMdTXZaRpnjHXLoQ6dpRt48gtJc8sBnnMaf1Ydq4ZqLlzSehspONklqz6g+G3w4+GEWj6vJ8ULTX dT8SFSLKO2vYrayBKjbvRFLsA2dwbcCOMDrXrvhr4kWXw4006d4egsdN07zFka0sVKm4GfmDyI6y JkcZjeFhkkGvHxePhf2GE1T36a+v6/cdtHCtfvK7+R5l4x+NP9s3Mj2GlxR/Mx37TLIN7E4Mj5ll +8QDO8zjhRIQAB4/c+KJ7s/v7tgxOTu5YYHXsBxg1x0cLL+JU1kzapWXwx2OfmvopLgXHnGONcFS zk/z4B+n6VjS61bynYEZ4chiAcYPT72Bnrj+nNehSpSbta1jknNfF3MJpLhlknaQ7Bhck4UAdRnv yf8AOarJdSQwbIZgeSd4xkcdQcZP15/DNdijG1rHO3fczyu92LMTOSCQcc//AF/Y9c570pISRoYw 3mg4I3Y3H/J5+vNbdbC3LMMzCMsqrx6MoCnODyeMfT35qnrcjT6fY7XZphcd9o6qfujr/CRkjHI6 VCXvpjT6H2X+xleNFb/EPT5IxuMlk6fORvA+0bsAc4HynI/vYr7ddiYyVdVAO4IPlyePXp7/AI16 1Fp042OWqnzsxb17m8LQq+yIrhhsXoe/pXMMC0k1uVfyhxuZflAOePl6HrxWjfYz2LCfZ0jwJArN 0QuBnkAnnllP0HfmnzumIwozvwcyDIY45A6Z7dPb3qLtrVDa6XGyajO7rHFb7LdRtAQE5xnqBj1P f057VIEkmVRExOSeFOB685PAyevPSmrJCbvqjNk0maVw32c+YPmB/P1/w9Kj/su7JE5UBA3zKOAT gnjt/wDqqJJyvdFJ6G1ofijWdG8Qp4g06eebU4kKsLi4uNrZTYfMRXAkIB435wcEcgGvevA3xx1H 7HdWfjuzjkujKoszZRMHmix8xdcnBBx0AGG6+uc6Sl1179vIuM909T1y4uvAd0/h/VEvp5Jb8+ZF ES7kBhg7lJO3DDAA7jpXsNlZw2Fu0kjb5DnbuU4Rfyxnt64HvXIqUoS953/r+umxo+7Kd6kEod7j LMcnKrkY9OPx+lcw1tbyyBTbsyjB+Zu3cDr6VNuVNvQL2IwIBcTRCJtu47iMjaDz3/zkfhVo6bbO 0bQzAuFbbvAwOABjGff06A1M27aMpJ7lZIJo54VJYy4+VupGMA4A644HSqdzCyxvm7VolOccjfxy Mc8g8Z71lNt20Gu55r4vurWYNZXelrMEKyxrNEjqp5GV3E4PPUf/AFq8uS5YxB1sT5GdoYRkAAnH UdvfPSuCpTozm5uK5tFexbm+W19D56/aDuNau7fStNsPD7mQyPkQxlhlcL8zdAe3PTPFeX+A9G8U eHPNuf7HIlnKsVmjY7SowMZwG9encCs3UjSqXW/Y6XKMqMaSfqejN4q8aZjgubdkUZIEcQUN3GDg f54xUdy/ifUY/wB/bS4Kqzljgk8YznB6dvY0Ko6nTQy92K1Ro2+kajOluXtuh+6xztODwBj3Bz/+ sd9p2k3Vw32ebI4ULggZycYBHOevr34oTukr6hzb2R6ToHhu6twrz2rmJm5/jCDtkd8/0PTv1mnf D7TNG+33omu2a4O7a7sY4yWLHC9F5PB5zwPSuujN06dWnyp86W61VnfTtf8AIwknJp32/rU+ePHl odJ8XSRTxsnmjeokBHJA7Dnvxn15q94WsHv9QZRzKVLD/ZwQK+UqJwzFx6OT/Fn09SXNlykv5V+h 65p/hi5kKS/YiFY8MinDDvj1HGMdPrmu5stAmfDpbjfg4XIx04x6cj3r2FHX3kfPpuTudPbWjwXh 2Mo28BX5cZORkHoenYcfprSare2n71FxETnKqM49MnIz2/GtGtLyKtoWbbW55Yogsm6UL1LYBOcc 7fp0qtqUIvEMN7ZDdyCwwWH6YHNZSfK7lcqtY8uuvh/eTLI1g8qxMCTkbgpPUY6kdfT1rj08F6ub 1pd6JhBuiGzY+CMkHhg3XvjpkHunNS3RHK4mxbabeWD+aynJZhjaDjnntgdfSvVvC+o3kM1vFezN teTKEzFArEkgEk/L/kYpTd42sEW09T6b0vxTo4gEr3EhkeMDYTkjjnknv3/+vWV4qvlm02eOwU73 BO888HuMnt6e9cXs/eOi6Wtz8gPipqereFfij5mq6dJbwSR7HkcDbMNzANvBw2Bg9Q3y4I6V0yTW 10VMbKLSWPOQm4KDk4yR3yRjitcT7mq0Ul+J2ulCNRRpS5o6O/ql+N7o7/w74EluWubk7DpkcQeR xOFcrwCysylTyWPKnA+b5uRXsuvfC7wzqmlvDaRyQayGFwkUUi4dHIHyZOGUD5d397Jxxk/JYjM6 9PERnSn8O6e3mdkaMeX30etfAvxheyaXN4O8Ruy67pYWMFkMZmgAARgrHIxkD0wyHkk19HWKqxJM o8tgMNntgDI/ljn+Ve7GUXG8dn/wDyZrlk4mt9mkMiOq/MANgbO0D/PI+orct7VyxKN8rA8k8den 9KvR7PQzuX18oOGYkyDO4Zyoxzx6H6c9qq6pcLb2dxclFAwxCn6evT3qopc13qaJ+R+R/wC0b4hm HiCC/v7J30p5BbXFwgAZIgxKnO0kFHbcCGGMttG45HG6De3l5o97pTR28t4kAdmcfv54MgCReB82 So+XGfl6EgNtOao4qE0/dml960/Kx0R/eUWusH+BpaX4D0DWtJluNO8WPb6rGFee2uYZGaIFkU4A yxAYlRt3du3AX/hWY/6HiP8A8ALz/wCNV57zWdOpOnXpe8n3W3Qv2M2k6UtP68j8ANM8c+JtMt5L STUpDayKUIV8HaeDj86wvNsbVN1nHI1wRgNIAoQ/3uvPqB/Ov1Jx1dtmfOWuyooyVGcjPYDA/wA8 16z4Q+HvizxE1u1lpDpZOAwuZx5ULLnBIZsbsc5C5PBrDEVqdGHPUlZGkISnK0UfR2mfCnQdGtUm 8T6gHkKtviViEycgYGAzDAIPGM/hntz4osrTZb6bbljtHzynOeMezMcjOTkkjvXzFfE1cW2ou1M9 SlTp0bN6yOa1TxHrF4ro96Vg2riJOEA9wPvcfL3rkGugVcTzusXDAjHA98cnk/XrVUqcYpKKJqVH JtyKt1Nb2zPPLGCzBlLZ5APBxke45479q524umlY+X5nlbiQAv3j04JHP074rtpRb96WxzTkkQxC EvL9pfB5LAFiFHtgY688D29DUck9nagpBGxfywuZGOMnqQO3HUZweo9t9XotjFu+rMae53bRNOSF O4A9+vX+R6kfypSz7/lihb5j3xlsc9up7cV0RitGidUWFEqAxs7ltvygYywOfwHXoT/OrkdusIEt yuR/dUcZPHXOSc9v0pNrZB6lyJIbu5gtJblIQELjcpCrgE84B5OMDIOSelQahaTzWa3lyFghMo2q NzHkheSOT9764NTdR3Hq9D6t/Zm8LeJdGt9T8d3dq0fha7b7BbTNjE8qbZG24HKhWXDDaCdwwSrb fsS31lZmUvGRGVX5jxyeoyOnHJHPb1r0MNUjUpRcHorr5p6mNZWnquxoRtbvvk2srMMhw+cDHcHt yah1E2KMg3EyZG0AcE4HU++M+nFb+bZlp2KK2cd0IyYkVgPlYHJ59cj8Pw+laS6PFGkU7TEyHHyh Rnp1z0Hp17dKT7C33NuPTo7dWZoNw/iBXjAPc/p0PemTpAWlWytXAY/L82cDGcZAAPp+Gaei1C6V 3cz2tpIcuq7rnjG3q3t9ff2704WFxK7yTyFkAGUAG5foMY4/z71fohJXJDpAi3yTlYt5DPuP8PGc 8Ajpt69zz0NVp7GZkaFFChRltvRAccn169enNTf7irJdDNutLku4kig3iJyB8pYEHIOO3XH/AOqv adD+M/j3T9U0n+175JtDj2Lc2/2NJHdAFX5G3IVc7QSzEjJJwehyknJ23+/TzKUrbnq+hfG/QvEV 8LI6Xc20iuW8yXb5Xl5IyzEjnI6DJ54zXrNv5V9E1/YvHPb7eJYpEkXrj5dp5Oc8VyVIpN2V0tDR dyRtO8xtoTEjDnOfm9sZ7Y/WqzwiKR42wJB/qwhwcjqcYHf2/lWErrfZD8zn9S1yw0qXy713iMmD GzkYychue2MY/GsafWbS9XYs0Lwnn5eo6dWzknnoR0NYS97VP+vzNI93Y5DW2jWTYURg5IkDbQMD 04GMDgevFcvdoG3LBAkagcMFKD5s4wPocDgY4rOSUXqK5y0MEMsUv2lN77TsRVJ2nkg5APQ4zjjB 7Ui2jq8SyxK8O7bnAx14xnpgc4A7dPSORbsewXWmac8iEQYI+fG35dwOMAkH64wevSsiTQlDzSSW 7YJ24AzjPTp0xilyxirw32BN3Ni38Oq0ZEkW2PbkKFHP0z74z0rZg0Q28TSWpIuFAICsMsevH8+9 KNK62Dmsd5p+oXUsaI1yuxQAFyC2CARwe/8AniuhhvZAgVpWJIO5QMl/b+f5GuiKbi1YnmR8qftA 2ip4h0DWEiyJbYp5gUKThtzZ25/2R9Me1Hw/k369p8bW+fPQoDuBzhd3YjH3T2r5jFx5c0jH+8j6 OLvlm32X+B9bWGmvNCyCLaVwCQ+CceoI5P8Ah9a6OPREhgiZn25654xjGf8APsa9qXus8NNLYSOx to+LmVnYfd2qSdvHpycE+lYkemWjxvGbqR2kZnJYkFF4OOFHA6jOSOeayal3GnfdlQ2cME7usPyk k4yCCR7/AHvXg5NP+w3W5FLEc8bcDd/nr+FYzlaNluaJNbbGzbxXUiG3lT5z3U4ZG7HPUH/PerH/ AAiy3OwzcOG4JYg9h+ffGfWuRv3vdZbaJ28JT7Jhc2ubkKMHoygHByM9c+uMfSufl0gxvMk2nSBT 91lZcA9Oevt7c963hJPXmM2ktTo9D8OXN9Ktx57xmNd7YKjcOB0Hp71u6jqk+hI+nMjmEOEWVgzl Od2cYz0+v40Plm97DTaV7nwv+0lbjxJoc5R1F1CPOVtvz5ByBgds4yfRT1zXgPwr1P8At3TrnTHn 239rmHy8MWK5G3t9R1/hPtTxMU8L7RrZmtGS59z7e8A+Gpp9M8pZQ0iuqyLGsXlyR7SCGDDORgtg 44z9R6drdmbWOBbCDbPEn2aJTGscex0fcARhc5XcODz8p3ZJP59XpTdaclH3W31118vL5HtwqpWV
January 27, 2009 - February 07, 2009
RV10-Archive.digest.vol-ee
