RV10-Archive.digest.vol-ei
March 02, 2009 - March 10, 2009
On Mar 2, 2009, at 7:01 PM, Deems Davis wrote:
A bit of a milestone (for me) today. N519PJ drew her 1st breath!!
Deems Davis # 406
'Its put together, time to call the DAR'
http://deemsrv10.com/
Subject: | Re: Kick the Tires & Light the fire! |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Subject: | Kick the Tires & Light the fire! |
Congratulations, how many beers have you had since you fired her up? You
can see the first flight from here.
Gary Specketer
40274 Flying
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
Sent: Monday, March 02, 2009 7:01 PM
Subject: RV10-List: Kick the Tires & Light the fire!
Deems Davis # 406
Well congratulations, I know the feeling
Bert
rv6a
> Deems Davis # 406
Wahoo!! Huge Congrats!
> Deems Davis # 406
From: | Don McDonald <building_partner(at)yahoo.com> |
Way to go Deems.- I've run mine 4 times now, and I let it out of the hang
er last Sat. just so it could get to know what it's like outside.- Won't
be flying for a month or two, so you'll no doubt beat me to that.- But we
'll meet up in the sky soon.
Don McDonald
Date: Monday, March 2, 2009, 4:01 PM
Deems Davis # 406
le, List Admin.
=0A=0A=0A
Deems,
Congrats - that's a major milestone! Mine is nuclear powered though and doesn't
breathe. Much better for the environment - no greenhouse gasses.
Dave Moore
RV-6 flying
RV-10 QB - cabin top/fiberglass hell
http://forums.matronics.com/viewtopic.php?p=232861#232861
From: | Patrick Pulis <rv10free2fly(at)yahoo.com.au> |
Well done mate, I'm sure that you can smell and taste the first flight now.
=0A=0AWishing you clear and safe skies always.=0A=0APatrick Pulis=0A#40299
=0ADownunder=0A=0A=0A=0A=0A________________________________=0AFrom: Deems D
avis =0ATo: rv10-list(at)matronics.com=0ASent: Tuesday, 3
March, 2009 10:31:24 AM=0ASubject: RV10-List: Kick the Tires & Light the fi
=0A=0AA bit of a milestone (for me) today. N519PJ drew her 1st breath!!=0A
=0A=0A=0ADeems Davis # 406=0A'Its put together, time to call the DAR'=0Ahtt
======================0A=0A=0A
Stay connected to the people that matter most with a smarter inbox. Take
a look http://au.docs.yahoo.com/mail/smarterinbox
From: | "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> |
Paul;
As you know, I installed the overhead console from accuracy avionics. I
put two naca vents behind the aft bulkhead and used ducting to rout it
up into the console. I also made a fiberglass piece to fill in the gap
at the aft cover piece and up to the console. I get some airflow up to
the front with the overhead air outlet while on the ground and it is
quite ample when airborne. I rarely have it all the way open. I wonder
if one would have been enough. (Then one would have to go through the
mental gymnastics of which side to put it on given the rotational
component of the airflow secondary to a prop.)
I haven't ridden in the back seat yet, but over spring break I want to
get back there and look at sealing off the joint better. (wonder if I
could get any offers from someone to fly the plane for me ?? ) The rear
seat passengers (aka my wife) report a lot of air that comes out of the
corrugations around the back panel. I am assuming that it is secondary
to the pressure leaking around the joint and filling up the tail and
coming out the only place it can : under the corrugations.
I want to fly with the vents open and then plugged. I think that will
be a good test to see if air is coming in from some where else. (around
the tail then forward??).
Again, I started flying at the end of September, so I don't know how
well it will be in the summer here in Texas. I don't think it will be
as good as Alex D's air conditioning, but I didn't want the added
weight and complexity.
I'm glad I put the overhead in place, even with the leaking problem.
You feel cooler when you have air blowing in your face. The system
doesn't weigh much at all and gives ample area to run lighting wires
overhead. I think it is and was a little expensive, and if I did it
again, would really look at the overhead consoles out of the cars
mentioned in earlier posts.
I also want to bend up an aluminum bracket to hold the pilot/copilot
shoulder harnesses. There is no good place for them after you take them
off. They fall right into the back seat and confuse the hades out of
new passengers. They all want to hook them into their seat belts somehow.
I also need to add a couple more plate nuts to the overhead access
plate. It leaks around the edge from the pressure when all the vents
are closed.
I'll try to remember to write up a little report about what I've
found/fixed in a couple weeks.
I do plan to fly over to Sun 'n Fun Friday and Sat if anyone else on the
list wants to take a look.
And, I still have one set of axle extensions that my Dad machined to
specs on Tim Olsen's site. I'd sell em for $10 plus shipping if anyone
is in need of them. I had to fix a crack in one of the wheel pants
fairings after painting and checked both of them when I filled the tires
(with good ole Texas air). They are doing well.
Fred.
515FW
90 hrs
Subject: | Re: Countersinking Fiberglas |
Les;
I up loaded some panel pics. I hope it will help some. I did use the
accuracy avionics panel. If you will look closely at the rear panel
picture dated 5/13/08 you can see the aluminum rails that I used to
mount the stack. If you look under the stack you see a couple of boards
that the panel is resting on. These are two layers of MDF that I cut to
the exact size of the radio stack. I then inserted them through the
opening of my center cut out and used them as the parallel and
reference to get the two aluminum rails in place. I don't specifically
remember how I attached the rails, but I remember trimming them to just
fit flush and up behind the fiberglass of the panel and epoxying them in
place. If I remember correctly, I used the corner screw holes to help
hold the rails in place. I also put plate nuts on the rails to hold
the exterior screws.
http://picasaweb.google.com/drfredparis/PanelPics?feat=directlink
Then, Tony's directions on taping the frames together lets you drill
into the sides of the aluminum angles and drill and tap for the screws
that hold the radio frames to the panel. If you don't have a copy of
Tony's directions, let me know and I can dig mine up for you.
Regarding the weight on the screws issue. I really just wanted you to
be aware of what I have seen. There are a lot of screws across there to
hold the weight. Also, for me, I covered the panel and console with a
layer of carbon fiber. That should be worth about 4 layers of
fiberglass. I know I have put a lot of weight on the console when I
have been panel diving to fix small issues and hook things up.
Also, I don't think I would have put the center console in if I had a
choice again. It is very difficult to work around and limits access to
the tunnel for maintenance.
I looks good and is functional. It also takes up some lateral knee room
on long flights.
Fred
Congrats Deems
You must be a proud papa.
I can't wait to see it in person.
Fred.
Subject: | Countersinking Fiberglas |
Hi Fred
Thanks for the PIX. I think I have an idea as to how you made things work.
If you have a copy of Tony's instructions that would be great. Unfortunately
I wasn't able to get a copy or speak to Tony about how things should go
together...
Cheers
Les
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams,
M.D.
Sent: March-02-09 9:24 PM
Subject: Re: RV10-List: Countersinking Fiberglas
Les;
on long flights.
Fred
From: | "Bob and Karen Brown" <bkbrown(at)minetfiber.com> |
That's an unforgettable day, I know! Congratulations!
Bob Brown
Sent: Monday, March 02, 2009 4:01 PM
Deems Davis # 406
Les,
You may want to give Eric a call. Eric used to work at Accuracy and
Redmond Air has continued manufacturing of the fiberglass parts that
Accuracy used to sell.
Eric McDonald
Avionics Technician
Redmond Air LLC
Redmond, Oregon
eric(at)redmondair.com
Phone: 541-923-1355
Fax: 541-923-4181
Full Service FBO CRS#: Q9RR266Y
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Monday, March 02, 2009 11:50 PM
Subject: RE: RV10-List: Countersinking Fiberglas
Hi Fred
together...
Cheers
Les
M.D.
Les;
on long flights.
Fred
Subject: | Re: Overhead vents |
Hey Fred,
I'm in Jacksonville, FL for the prostate cancer treatments (a minor inconvenience
to fixing up stuff at the rental house and surf fishing), but I'd love to send
you the $ for the axle extensions if you still have them.
Let me know. Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Painting when it's 60+ degrees!
Piddling with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p=232915#232915
I have attached the mounting instructions for the panel and console. I hopw
they come through.
Steve
Sent: Monday, March 02, 2009 8:50 PM
Hi Fred
together...
Cheers
Les
M.D.
Les;
on long flights.
Fred
Subject: | Normal build fuselage question |
Ok, I have a dumb question to ask and it's three hours before I can call
Van's. I was hoping to get a response off the list a little quicker.
On page 25-5 of the fuselage plans, you mount two hat stiffners to the
F-1004B center section bulkhead. Per the plans, you remove the hatched area
to allow access to buck the rivets on the lower flange of the F-1004B center
section bulkhead. No problem so far.
However, the bottom #12 hole underneath the hat section on the right side is
riveted already and the left side isn't. These are one of the massive
rivets that were pre-riveted from the factory. I've spent the last hour
looking ahead in the plans to see what might go into this hole, but can't
find anything. I've looked at a dozen sites looking for build pictures, but
this area is obscured in all the photos by the hat stiffner.
So my questions are:
1. Is the center section bulkhead correct? Is only one side supposed
to be riveted already or both? Again, I'm referring to the large #12 hole
at the bottom and underneath the hat stiffner.
2. Step 3 refers to riveting something later, so what page in the
plans highlights that step? I can't find it.
3. What goes into the left hole? Am I missing one of the large
rivets?
Underneath my hat stiffeners I have Van's installed rivets on both
sides. I don't see anything in step 3 of page 25-5 that says you rivet
something later.
Rob Hunter
Fuselage
40432
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Tuesday, March 03, 2009 2:57 PM
Subject: RV10-List: Normal build fuselage question
area to allow access to buck the rivets on the lower flange of the
F-1004B center section bulkhead. No problem so far.
side is riveted already and the left side isn't. These are one of the
massive rivets that were pre-riveted from the factory. I've spent the
last hour looking ahead in the plans to see what might go into this
hole, but can't find anything. I've looked at a dozen sites looking for
build pictures, but this area is obscured in all the photos by the hat
stiffner.
supposed to be riveted already or both? Again, I'm referring to the
large #12 hole at the bottom and underneath the hat stiffner.
rivets?
Thanks to all the replied!
Just got off the phone with Van's. I am indeed missing one of the large
rivets on the center section bulkhead. They offered two fixes. The first
was to send me a rivet and attempt to set it with a really large hammer. I
opted for the second choice, which was an AN3 bolt of the appropriate
length.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Hunter
Sent: Tuesday, March 03, 2009 5:34 PM
Subject: RE: RV10-List: Normal build fuselage question
Underneath my hat stiffeners I have Van's installed rivets on both sides. I
don't see anything in step 3 of page 25-5 that says you rivet something
later.
Rob Hunter
Fuselage
40432
rivets?
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3890 (20090226) __________
The message was checked by ESET NOD32 Antivirus.
A recent email lamented that there were about three hours until he could
call Vans. It has been my experience that whenever I had a question , Vans
answered no matter what time of day.
From: | "John Testement" <jwt(at)roadmapscoaching.com> |
It's a great feeling to hear her purr! You should be real proud or your
creation.
We started ours up a week ago and looks like the DAR will inspect on
Saturday
John Testement
N311RV
40321
Deems Davis # 406
Checked by AVG - www.avg.com
17:46:00
Subject: | Carbon fiber panel |
Here are some pictures of my carbon fiber panel and lower centerconsole. All parts
weigh 2lbs. These will be available very soon if anyone is
interested. See more pictures at the link below
http://albums.phanfare.com/isolated/L5LenCCI/7068012/3161550
Geoff
Build QB RV-10 N829GW
http://forums.matronics.com/viewtopic.php?p=233076#233076
http://forums.matronics.com//files/img_1558_137.jpg
http://forums.matronics.com//files/img_1552_172.jpg
Geoff,
Sometimes it sucks to be an early adopter. You miss so many
"goodies" that come along. Clearly the design & execution are more than
just a goodie. Really superior work. I notice the rendering is
significantly different that the finished product in that the radio
stack is shifted right. Good call for side by side glass is ideal (for
me). The only downside is no throttle quadrant in this configuration.
Are you going to offer that as an option?
I see you installed AA's OH console. How about trying your hand
at one of those too? There are so many things not... ideal about that
unit.
Well done!
Robin
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of geoff Combs
Sent: Tuesday, March 03, 2009 9:33 PM
Subject: RV10-List: Carbon fiber panel
All parts weigh 2lbs. These will be available very soon if anyone is
Geoff
Geoff,
I watched the video of the CNC and block of aluminum. Is solid
metal required to form CF parts. Can carbon come off a wood form.
Robin
Subject: | Re: Carbon fiber panel |
Geoff,
Gorgeous work. How tall is the panel directly in front of the pilot or copilot.
I'm working on my panel right now and could easily make the switch. My layout
is two AFS Advanced 4500's directly in front of pilot so this layout makes
sense.
My biggest concern is whether the Infinity grips will still fit (I'm assuming some
cutback of stick).
Also, when do you anticipate available?
Availability through you or a vendor?
Tom H.
http://forums.matronics.com/viewtopic.php?p=233092#233092
Subject: | Re: calling Vans |
He was probably talking about tech help which has specific hours in the am and
the pm only, ask me how I know, I never have a tech question during tech hours.
http://forums.matronics.com/viewtopic.php?p=233093#233093
Makes sense about one naca vent. Has anyone that just used on vent flying
yet?
ricksked(at)embarqmail.com
Sent: Tuesday, March 03, 2009 9:03 PM
Subject: Re: RV10-List: Overhead vents
I spent the weekend at Redmond OR to get my 480 upgraded by Eric McDonald,
one of the original builders of the overhead when he was at Accuracy. He is
the avionics guru at Redmond Air and the real technical brains behind the
now defunct Accuracy. Seems he had several discussions with a few builders
and the conclusion was you only need one NACA vent. FWIW, Redmond Air is
selling them and Eric has improved many of the parts. He's a very bright guy
with a good company behind him. He took on the burden of helping Accuracy's
customers with tech support because he cares about his product he built.
They have experimental panels for all the RV's and the FBO was great to hang
out at...I gladly picked up the tab for dinner Friday for all he did for me.
If you're looking for avionics for your RV-10, you might want to give
Redmond Air a shot....very nice facility and a great staff...
Rick Sked
40185
Sent via BlackBerry by AT&T
database 3906 (20090303) __________
From: | "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com> |
One is more than enough - if you've got 2 you'll want to block off some flow.
----- Original Message -----
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com>
Sent: Wed Mar 04 04:39:41 2009
Subject: RE: RV10-List: Overhead vents
yet?
Rick Sked
40185
From: | "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> |
Bigger question, how much $$$.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tomhanaway
Sent: Wednesday, March 04, 2009 5:58 AM
Subject: RV10-List: Re: Carbon fiber panel
Geoff,
sense.
cutback of stick).
Tom H.
Someone always answers tech questions , even during the middle of the day.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of doctornigel
Sent: Wednesday, March 04, 2009 4:21 AM
Subject: RV10-List: Re: calling Vans
and the pm only, ask me how I know, I never have a tech question during tech
hours.
Geoff:
Wow. I wish I had my own backyard CNC and a block of aluminum the
size of the panel. Significant cost for the first one. I bet you will
be able to recoup your investment. Looks great.
Fred.
Tech support has specific hours on their web but the truth is that they pick
up anytime of the day from 7:30-4:30. Ask me how I know.
Pascal
Sent: Wednesday, March 04, 2009 3:21 AM
> tech hours.
I saw your email last night.... and agree with Robin.... it seems no matter
what we put together, there's always going to be some smart ass that puts
us all to shame.- All I managed to do last night was forward your email t
o my brother, his shop foreman, and the guy in his shop who handles all the
Solid Works projects.- They used Solid Works to design my panel includin
g splitting it into 3 pieces and designing bracketry to support all the avi
onics.- I can't wait to hear back from the shop.- Hopefully they won't
want me to tear out the panel and start over!
GREAT job Geoff.
Don McDonald
Date: Tuesday, March 3, 2009, 9:32 PM
Geoff
le, List Admin.
=0A=0A=0A
I would assume that if they specify a certain time this is what they would want.
Calling anytime of day although you get your answer is probably an inconvenience
for Van's. Owning my own business for over twenty years we have to do what
the customers ask although it is an inconvenience. I get calls at home all the
time, my wife has her business at home with posted hrs. The phone rings at
meal times everyday, we answer them but do you really think this is what we like.
No we do it because this is what we have to to keep the customers. How long
can we keep this up , don't know.
Financial planners say to start planning to sell your business ten years ahead
of doing so. I'll have to start planning today, it's time.
Not trying to offend anyone, just pointing something out that Van's can't really
push but I'm sure they would like to.
Ron
http://forums.matronics.com/viewtopic.php?p=233152#233152
I loved the website, the photo slide dissolves and the process video. I
was blown away at the thought of the cost to most of us builders to make
the mold out of aluminum. Wow, as I watched the coolant and shards hit
the camera lens. I forgot for a moment that I was not there - Live.
Then I scratched my head and wondered why with the most beautiful panel
ever developed you would resort to using stock rudder pedals and a ill
fitting fiberglass overhead plenum. If you decide to cast an aluminum
mold to retro the canopy, let me know, I will prepurchase one to help
with that ingot cost. By the way, though one NACA might work, there are
lots of times where two are more comfortable for both the fuel tunnel
cooling and the passengers under the glass "south of the Mason-Dixon".
It made for a wonderful evening and a lot of dreaming on several fronts.
Composites Unlimited told me that knowledge and skill of Solidworks 3D
could have a major impact on the quality of fabricated pieces. You have
driven that point home with a Grand Slam. I am not sure they will
abandon their mold technology for aluminum ingots though. They tend to
assign their 5 axis router to build up foam substrate instead. I would
wager that CJ is looking for another cool piece of machinery to play
with.
The ability to do quadrant installations as well as vernier cables
would open a much wider arena for sales. If your lower console can
adapt for a VP200 display, then I am sold! Both Rob Hickman and Stein
are probably redirecting their customers to your site as we read this.
Congrats Geoff (and belated happy 50th)
John - watching in awe as that bar moves UP so rapidly.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Wednesday, March 04, 2009 8:12 AM
Subject: Re: RV10-List: Carbon fiber panel
matter what we put together, there's always going to be some smart ass
that puts us all to shame. All I managed to do last night was forward
your email to my brother, his shop foreman, and the guy in his shop who
handles all the Solid Works projects. They used Solid Works to design
my panel including splitting it into 3 pieces and designing bracketry to
support all the avionics. I can't wait to hear back from the shop.
Hopefully they won't want me to tear out the panel and start over!
GREAT job Geoff.
Don McDonald
http://us.mc01g.mail.yahoo.com/mc/compose?to=g.combs58@yahoo.com> >
centerconsole. All parts weigh 2lbs. These will be available very soon
if anyone is
Geoff
<http://forums.matronics.com/files/img_1558_137.jpg>
<http://forums.matronics.com/files/img_1552_172.jpg>
http://www.matronics.com/contri==============
<http://www.matronics.com/Navigator?RV10-List>
John,
I have a full size drawing up on my wall of Geoff's panel, so that I can
play with equipment placement. I've haven't checked depth yet, but it does
appear that the VP-200 display shouldn't be an issue for the lower console.
I'm still debating on whether or not if I want to go with a quadrant or
not. That's what both my son and I are familiar with, but I think with
Geoff's panel, I'm considering going the traditional route. If I hadn't
been laid off this past month, I would have probably purchased a quadrant
and given it to Geoff for prototyping.
Having the opportunity to see Geoff's work in person, I can verify that he
does great work. His aluminum center console is a work of art too.
bob
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Wednesday, March 04, 2009 12:10 PM
Subject: RE: RV10-List: Carbon fiber panel
I loved the website, the photo slide dissolves and the process video. I was
blown away at the thought of the cost to most of us builders to make the
mold out of aluminum. Wow, as I watched the coolant and shards hit the
camera lens. I forgot for a moment that I was not there - Live. Then I
scratched my head and wondered why with the most beautiful panel ever
developed you would resort to using stock rudder pedals and a ill fitting
fiberglass overhead plenum. If you decide to cast an aluminum mold to retro
the canopy, let me know, I will prepurchase one to help with that ingot
cost. By the way, though one NACA might work, there are lots of times where
two are more comfortable for both the fuel tunnel cooling and the passengers
Composites Unlimited told me that knowledge and skill of Solidworks 3D could
have a major impact on the quality of fabricated pieces. You have driven
that point home with a Grand Slam. I am not sure they will abandon their
mold technology for aluminum ingots though. They tend to assign their 5
axis router to build up foam substrate instead. I would wager that CJ is
looking for another cool piece of machinery to play with.
The ability to do quadrant installations as well as vernier cables would
open a much wider arena for sales. If your lower console can adapt for a
VP200 display, then I am sold! Both Rob Hickman and Stein are probably
what we put together, there's always going to be some smart ass that puts us
all to shame. All I managed to do last night was forward your email to my
brother, his shop foreman, and the guy in his shop who handles all the Solid
Works projects. They used Solid Works to design my panel including
avionics. I can't wait to hear back from the shop. Hopefully they won't
GREAT job Geoff.
Don McDonald
<http://us.mc01g.mail.yahoo.com/mc/compose?to=g.combs58@yahoo.com> >
Geoff
http://www.matronics.com/contri===============
Les,
If you are still looking for information on installing the radios see the
attached file.
Steve
Hi Fred
together...
Cheers
Les
M.D.
Les;
on long flights.
Fred
I will try and answer most of the questions. Yes we will have a configuration for
the throttle quadrants. This was already in the works.
We used a aluminum mold because it was cheaper than making a master
part and then making a carbon fiber mold. These parts are all Carbon fiber prepreg
layups. Sometimes when carbon fiber or fiberglass molds are made there are
voids that are not visible on the surface. When go and layup in these molds and
vacuum bag and autoclave the parts it
opens these voids up and the parts have flaws as well as the molds break down much
quicker. As for wood molds they do work OK but do not last like aluminum.
As for the overhead console that everyone seems to be all fired up about. I chose
to do what I did because it was very close to what I wanted. Yes it had some
fit issues but it was OK. It was not AA overhead. It was much cheaper than
making one for myself. It was not my perfect solution but it was 85% what I wanted.
As for the little die grinder it is for the tool & die industry. Turns about
30,000 I think cuts thru
aluminum and fiberglass like butter.
Also if you use a throttle quadrant instead on the push pull you can just put a
plate over that area and cut out the 3 locations. You could then put switches
on the plate. Also if you do not want the center console or side panels we have
a cap the fits over the bottom middle area that finishes off the panel real
nice. As for cost somewhere between $0.00 and $1,200.00
http://forums.matronics.com/viewtopic.php?p=233191#233191
This matronics thing is too cool. I keep reading all of these write ups that are
so far in the future for me. Oh well, I am getting better at drilling out rivits
than bucking them. Not really. Just about finished the elevator halves,
had the kit for a month know. I ordered my SB wings. a few weeks ago. I am
really enjoying the building process and reading the emails on my Blackberry.
Also, I would like to know if there are any builders/fliers that will send out
the airport (western U.S.) they are located at and if they don't mind, let me
meet them and their airplane. With my job I travel a lot and would love to see
any other tens out there.
Here is a pic of my fathers old machine shop and a few parts he made me. He made
a squeezer yoke and my HS attach brackets in his mill. I made this back rivit
table from some scrap cold rolled 1/2 inch steel.
A&P, ATP
typed CE-525(s), CE-500
RV-10 emp started!!!!
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=233194#233194
http://forums.matronics.com//files/home_made_back_rivit_table_small_184.jpg
http://forums.matronics.com//files/dad_milling_parts_small_167.jpg
http://forums.matronics.com//files/rv_10_rudder_and_elevator_012_small_185.jpg
put me on the list for the $0.00 one. (haha)
Your work truly is amazing and inspiring.
Pascal
Sent: Wednesday, March 04, 2009 11:05 AM
> configuration for the throttle quadrants. This was already in the works.
> prepreg layups. Sometimes when carbon fiber or fiberglass molds are made
> there are voids that are not visible on the surface. When go and layup in
> these molds and vacuum bag and autoclave the parts it
> down much quicker. As for wood molds they do work OK but do not last like
> aluminum. As for the overhead console that everyone seems to be all fired
> up about. I chose to do what I did because it was very close to what I
> wanted. Yes it had some fit issues but it was OK. It was not AA overhead.
> It was much cheaper than making one for myself. It was not my perfect
> solution but it was 85% what I wanted. As for the little die grinder it is
> for the tool & die industry. Turns about 30,000 I think cuts thru
> put a plate over that area and cut out the 3 locations. You could then put
> switches on the plate. Also if you do not want the center console or side
> panels we have a cap the fits over the bottom middle area that finishes
> off the panel real nice. As for cost somewhere between $0.00 and $1,200.00
You might want to register with Tim. As a registered builder you will have access
to more info that I beileve will be VERY HELPFUL to you. Hint hint [Mr. Green]
Gary Blankenbiller
RV10 - # 40674
Engine, Fiberglass - SB
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p=233212#233212
Geoff - you are an inspiration.
The median price of $900.00 looks right ON... Not too Cold, Not too Hot.
Ready with a security deposit$$. You are one of the first to acknowledge
the poor mold voids that have lead to such Vans part manufacturing QC
issues and the dozens of hours of redux. With the aluminum female mold
you could run refrigerant veins to slow the layup time and speed the
ramp up time on the autoclave heat up. The process is still pure
Starwars.
The pencil die grinder is often sold for around a $100 from A/S or Tool
Yard, but Harbor Freight has them at times for $9.99 on special. They
either work or don't. Three years of heavy use and I have given two as
gifts to friends. Another buddy burned up my Dremel using electricity
for extended periods. Uses Home Depot 0.125" shaft Dremel products from
buffing wheels, cutoff, sanding or die grinding inserts. Is great for
punching quick holes through composite for nutplate attachments or
shaping an edge.
John N49CX
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Wednesday, March 04, 2009 11:24 AM
Subject: Re: RV10-List: Re: Carbon fiber panel
Pascal
works.
fiber
made
in
break
like
fired
overhead.
it is
just
put
side
finishes
$1,200.00
Subject: | Fuel injection servo attachment - concerned ? |
Trying to get my Precision Airmotive silver hawk EX F/I servo attached permanently
to the Mattituck engine and Filtered Air Box.
I called Mahlon at Mattituck who told me that the servo is bolted on to the engine
with the already attached studs. He said to use a std washer and then a star
washer over that before you bolt it on to 204 in/lbs. I assume that it will
not vibrate out - does anyone use locktite????
Next is the attachment to the FAB box which is accomplished with the supplied "non-standard"
1/4 x 20 bolts that are 1/2 inch long. Instead of the standard
#AN4 bolts that can be safety wired. These to be secured with 96 in/lbs into the
aluminum. Ingetion of these bolts into the maifold could be catastrophic.
Question: Does anyone know a source for 1/4 x 20 x 3/4" long (the 1/2" are too
short) bolts that are drilled with a hole for safety wires????
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p=233228#233228
Subject: | Re: Filtered Air Box Failure |
Wow - thanks for the heads up on that Dave. Might be a good idea to add a bit more
glass during the build while the unit is free of grease. good post.
http://forums.matronics.com/viewtopic.php?p=233229#233229
Subject: | Re: Filtered Air Box - FAB (Filtered air BITC..... |
Any suggestions on fitting the baffle seal between the FAB & the inlet?
http://forums.matronics.com/viewtopic.php?p=233230#233230
I thought this was going to be a chore, but it turned out not to be. I have a 1/2"
gap between the aft edge of the inlet and the forward edge of the FAB, so
I made the baffle strips 1" wide. Installed them so they were in plane with the
top, sides and bottom of the FAB. The material is flexible enough that it adjusts
to any minor misalignment. It may have been pure luck, but it worked out
well.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=233235#233235
Subject: | Re: Fuel injection servo attachment - concerned ? |
From: | "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu> |
Check with Vans. My FAB came with drilled bolts straight from Vans. The bolts
are specifically noted as needing to be safety wired.
eric gohr
http://forums.matronics.com/viewtopic.php?p=233251#233251
Subject: | TCW Technologies new product announcement |
Fellow RV builders,
Once again it is time for TCW Technologies to announce the availability
of a new product. We have designed a small control module called
SmartStart. It simplifies the installation and operation of push
button or control stick starting of the aircraft engine starter.
SmartStart provides an arming switch input and an interlock input and 1
minute timer during which a momentary switch may activate the engine
starter. The arming switch may be hidden to improve theft resistance
of the aircraft, the 1 minute timer helps prevent inadvertent starter
activation. The interlock switch may be coupled to a door or canopy
switch. SmartStart directly drives standard starter contactors and
is all electronic.
All the details are on our web site: www.tcwtech.com
Best regards,
Bob Newman
TCW Technologies, LLC.
I'm not sure if this will work for the FAB to Cowl, but here's how we
did on on the Will James cowl.
http://deemsrv10.com/album/Final%20Assembly/slides/DSC07042.html
It's a simple piece of neoprene, that is glued into a cylinder glue, and
then clamped to the cowl inlet. This is the process used for connecting
the cooling intakes for the James cowl as well.
Deems Davis # 406
DAR is showing up on Fri!!!!!
Jesse Saint wrote:
> I may get flamed for this, but I have seen this done and tried it
> myself and it works great and saves a bunch of work, as well as making
> the cowl easier to get on/off. Spruce sells rolls of rubber baffle
> seal that is thicker and stiffer than the Van's supplied material.
> This seal material can cover a 1"+ gap from the FAB to the cowl inlet
> and the cowl can remain as it comes from Van's. I will look for some
> pictures, but I don't think I have any close at hand.
My FWF kit that I picked up approx August '07 has these plain 1/2" long 1/4x20
bolts. They use this "tab/washer arrangement" to secure the bolts in place.
I consider this a poor solution and potentially dangerous giving you four more
pieces of steel in the FAB.
I may have located the drilled 1/4 x 20 bolts at Spencer Aircraft in Washington
State.
http://forums.matronics.com/viewtopic.php?p=233298#233298
No flames intended but a lot of information exists to supporting its reduct
ion. Look for Fred Moreno's five part series "Homebuilt Aircraft Drag Redu
ction = January 2009. Part One is a pdf file of 1.06 mb. Pages 13,14 &1
5 address the consequences of casual cooling air & leakage air flows, baffl
e material, plenums,etc. Ideal case = no leaks. Interesting counter poin
t.
Mike, contact me off list. Not interested in flaming, jousting or tying up
Matt's wonderful list or I would have attached it.
John Cox
Sent: Wed 3/4/2009 2:38 PM
Subject: RV10-List: Re: Filtered Air Box - FAB (Filtered air BITC.....
Fred's other four parts were
Two - Reduced cooling leakage/drag for already flying aircraft
Three - Reduced airframe drag for already flying aircraft
Four - Advanced methods for reducing cooling drag in aircraft still under c
onstruction.
Five - Advanced methods for reducing airframe drag in aircraft still under
construction.
See you at Osh '09
Subject: | RE: James Aircraft wheel pants |
I have Sam's main wheel pants, cowls, and plenum. His parts are nice
to work with, fit well and have minimal pin holes. The wheel pants
are not as oval around the tire as Vans, so I used the stock axle
extension cut down a little. I have 100 hrs on the set up now with no
problems, and will do some speed runs to see what I get at different
power settings. I have done a few trips and at 7000'-9000' @ 23/2300
I get 170 kt TAS @ 14.5 gal rich of peak. Blue Skys
Barry Marz
18735 Baseleg AVE.
FT. Myers, Fl 33917
239-567-2271
blalmarz(at)embarqmail.com
Remember that it's really not a big deal to drill a bolt, either the head or
the threaded end. There are jigs out there to help you do it (Avery or
Cleveland), or if you're a welder, you can make a jig. I have purchased
many bolts for things like FAB's from a nearby farm supply store, some of
them maintain excellent selections (lengths and diameters) of grade 5 and
grade 8 bolts and various lock washers. All the attachments to my FAB on my
plane are safetied...although there are also some shop side rivet heads that
could conceivable break off and get sucked in. The reality though is, that
isn't the cause of very many accidents that I'm aware of. Good luck in your
search. BTW, I hate tab washers...and have broken many tabs at installation
over the years...which doesn't inspire much confidence in them for me.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike
Sent: Wednesday, March 04, 2009 10:26 PM
Subject: RV10-List: Re: Fuel injection servo attachment - concerned ?
1/4x20 bolts. They use this "tab/washer arrangement" to secure the bolts in
place. I consider this a poor solution and potentially dangerous giving you
four more pieces of steel in the FAB.
Washington State.
From: | "Michael Wellenzohn" <rv-10(at)wellenzohn.net> |
Interesting explanations on locking methods:
http://www.roymech.co.uk/Useful_Tables/Screws/Locking.html
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?p=233357#233357
Without the cost of a special jig, just purchase several center drills.-
Used in the machinists arean a lot.- They come in several sizes.- I use
them for starting lot's of holes because they don't wander.... and I just
finished drilling a bolt that I needed that was just a little longer than t
he pre-drilled bolt I had... no problem.
Don McDonald
--- On Thu, 3/5/09, Bob and Karen Brown wrote:
From: Bob and Karen Brown <bkbrown(at)minetfiber.com>
Subject: RE: RV10-List: Re: Fuel injection servo attachment - concerned ?
Date: Thursday, March 5, 2009, 6:32 AM
com>
r
the threaded end.- There are jigs out there to help you do it (Avery or
Cleveland), or if you're a welder, you can make a jig.- I have purchased
grade 8 bolts and various lock washers.- All the attachments to my FAB on
my
t
could conceivable break off and get sucked in.- The reality though is, th
at
isn't the cause of very many accidents that I'm aware of.- Good luck in y
our
search.- BTW, I hate tab washers...and have broken many tabs at installat
ion
My FWF kit that I picked up approx---August '07 has these plain 1/2"
long
Washington State.
le, List Admin.
=0A=0A=0A
I spoke to Vans this morning.
Apparently I had the FAB installation kit with bag 939-1. This kit was delivered
in August of 2007.
Bag 939-1 has been superseded by bag 939-2 with 1/4x20 bolts that are DRILLED.
Vans does not show this item in their on-line catalog and I was unable to find
these drilled bolts anywhere else. I would urge anyone using the tabs to replace
them with the drilled and safety wired bolts. The tabs are only supposed to
be used once and could work harden and break off if used twice
http://forums.matronics.com/viewtopic.php?p=233365#233365
Subject: | Oil Recommendations |
We are trying to figure out what brand oil to run our engine on. Is one
brand better than the next for any particular reason, or is it a Coke,
Pepsi sort of thing? I would appreciate any reasons anyone has for
selecting one brand over the other, other than just brand recognition.
Also, does it matter for break in versus remaining engine life (oil type
aside).
Hopefully this doesn't turn into a primer war, but I can imagine it might.
I dug through the archives with no joy.
Just getting ready to dump in oil and fire it up!!
Thanks, Jason Kreidler
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
Subject: | Leaning For Taxi |
We started writing out checklists (POH) and have noticed that a few
samples have the operator lean the engine after start and before taxi.
What are the reasons for leaning during taxi? Upsides, downsides? Is
this just a fuel savings measure, does it prevent fouling?
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
By recommendation of my engine re-builder and A&P. I use Aeroshell. For
break in I used straight mineral oil, 100. After break in, I went to 10w50.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
jason.kreidler(at)regalbeloit.com
Sent: Thursday, March 05, 2009 1:12 PM
Subject: RV10-List: Oil Recommendations
brand better than the next for any particular reason, or is it a Coke, Pepsi
sort of thing? I would appreciate any reasons anyone has for selecting one
brand over the other, other than just brand recognition. Also, does it
matter for break in versus remaining engine life (oil type aside).
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
I operate out of Ogden UT ~4500 feet. Need to lean for takeoff and the
plugs will foul during the taxi if I don't. With the new engine (before
first flight) I could not get from the hanger to the runup area without a
little fouling. But, other than the first flight, it was manageable.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Sent: Thursday, March 05, 2009 1:16 PM
Subject: RV10-List: Leaning For Taxi
We started writing out checklists (POH) and have noticed that a few samples
have the operator lean the engine after start and before taxi. What are the
reasons for leaning during taxi? Upsides, downsides? Is this just a fuel
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
Subject: | Re: Leaning For Taxi |
You will foul your plugs real bad if you run anything over
what's necessary to run the engine while on the ground.
So, the fix is lean real aggressively. So far that you
can't even get 2000RPM out of it during taxi. If
you do this, you won't forget to richen it before
takeoff (also if you use your checklist), because
the engine will just bog if you add throttle.
So it's just for keeping your plugs clean (and it
saves fuel as a bonus) while running at lower power.
Plugs won't foul so easily once you add power.
> #40617 N44YH
> Sheboygan Falls, WI
> (4) Partner Build
> Jason Kreidler
> Kyle Hokel
> Tony Kolar
> Wayne Elsner
From: | "McGANN, Ron" <ron.mcgann(at)baesystems.com> |
This is an intriguing thread. I've never heard of leaning during taxi.
(A sheltered life I guess!) Looking forward to some more opinions on
this one - will be doing some taxi tests this weekend and bedding the
brakes.
Now VH-XRM on the Australian register. No longer a kit!!
Ron - can almost taste it!!
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson
Sent: Friday, 6 March 2009 7:21 AM
Subject: Re: RV10-List: Leaning For Taxi
You will foul your plugs real bad if you run anything over what's
So, the fix is lean real aggressively. So far that you can't even get
2000RPM out of it during taxi. If you do this, you won't forget to
richen it before takeoff (also if you use your checklist), because the
So it's just for keeping your plugs clean (and it saves fuel as a bonus)
> Is this just a fuel savings measure, does it prevent fouling?
> #40617 N44YH
> Sheboygan Falls, WI
> (4) Partner Build
> Jason Kreidler
> Kyle Hokel
> Tony Kolar
> Wayne Elsner
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
Jason;
Just pulled my plugs and cleaned them at 80 hrs because I didn't lean on
the ground. Another lesson learned. Started having asymmetrical mag
drops. As the other posts have said. Lean out aggressively once you
get the engine started.
Let us know when you fire it up!
Dr Fred.
> #40617 N44YH
> Sheboygan Falls, WI
> (4) Partner Build
> Jason Kreidler
> Kyle Hokel
> Tony Kolar
> Wayne Elsner
The safe way to do it with any aircraft engine is lean till the engine
almost quits while you are taxiing. That way any advance of the
throttle will make the engine stumble, so you don't forget as you take
the runway.
On Thu, Mar 5, 2009 at 2:47 PM, Fred Williams, M.D.
wrote:
> Jason;
> Just pulled my plugs and cleaned them at 80 hrs because I didn't lean on the
> ground. Another lesson learned. Started having asymmetrical mag drops. As
> the other posts have said. Lean out aggressively once you get the engine
> started.
> Dr Fred.
>> samples have the operator lean the engine after start and before taxi. What
>> are the reasons for leaning during taxi? Upsides, downsides? Is this just
>> #40617 N44YH
>> Sheboygan Falls, WI
>> (4) Partner Build
>> Jason Kreidler
>> Kyle Hokel
>> Tony Kolar
>> Wayne Elsner
That sounds familiar. :)
Also, another step that helps with the plugs that I've heard
over the years is that before you shut the engine down, you should
run it up to at least 1200RPM (or was it 1800?) for about 15-20
seconds while leaning it as far as possible...trying to get
the EGT's back up a bit and burn off any lead right before
you kill the engine. Then power down to idle, lean to cut-off,
and that helps keep things clean too.
> the runway.
> wrote:
>> Jason;
>> started.
>> Dr Fred.
>>> #40617 N44YH
>>> Sheboygan Falls, WI
>>> (4) Partner Build
>>> Jason Kreidler
>>> Kyle Hokel
>>> Tony Kolar
>>> Wayne Elsner
Did everyone forget about running their engine at 1100-1200 rpm on the grou
nd?
Tell them why Tim.
Patrick Thyssen
One day I- will fly.
--- On Thu, 3/5/09, McGANN, Ron wrote:
Subject: RE: RV10-List: Leaning For Taxi
Date: Thursday, March 5, 2009, 3:34 PM
brakes.
> #40617 N44YH
> Sheboygan Falls, WI
> (4) Partner Build
> Jason Kreidler
> Kyle Hokel
> Tony Kolar
> Wayne Elsner
"Warning:
your computer."
An exceptional reference with one small footnote. Nylocs have a max
temperature range and should be used judiciously around the FWF
application or near brake cylinders and M5606. Heat will cause a loss
of locking capability at your worst time. Other nuts meet that higher
temperature requirement.
To that I add, every builder is the manufacturer, they set their
standard on their experiment and they know best!
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael
Wellenzohn
Sent: Thursday, March 05, 2009 8:21 AM
Michael
#511
And if you still have a problem with fouling plugs put REM 39s in the
lower holes.
Linn
> Tim Olson - RV-10 N104CD - Flying
Steve / Dr Fred
Thanks for all the info on the AA panel & console. They are invaluable given
that I am a FG neophyte.
Cheers
Les Kearney
#40643
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steve
Sent: March-04-09 12:03 PM
Les,
attached file.
Steve
Hi Fred
together...
Cheers
Les
M.D.
Les;
on long flights.
Fred
Subject: | W&B envelope program/spreadsheet |
Does anyone know of or have access to a Weight and Balance CG program
that incorporates a graphic 'envelope' to depict the ranges? I saw one
that TDT posted, but it's password protected.
Deems Davis # 406
'Its all done....Its just not put together'
Subject: | Re: W&B envelope program/spreadsheet |
I can give you one designed for a Mooney, but you can change to
identify the 4 corners of the envelope and most anything else, as it
is just an Excel spreadsheet using its graphing and linked formula
stuff.
On Thu, Mar 5, 2009 at 6:26 PM, Deems Davis wrote:
> Does anyone know of or have access to a Weight and Balance CG program that
> incorporates a graphic 'envelope' to depict the ranges? I saw one that TDT
> Deems Davis # 406
Here is mine. I will give anyone who wants the code. I am not sure I
really finished it........
http://www.hillflyingclub.com/n423cf/n423cf.htm
Rene'
801-721-6080
Sent: Thursday, March 05, 2009 6:27 PM
Subject: RV10-List: W&B envelope program/spreadsheet
Deems Davis # 406
Doesn't Rob Hickman include something like that on his EFIS?
Sent: Thursday, March 05, 2009 5:27 PM
Deems Davis # 406
Don't think I have seen such an animal. Champion doesn't list such a
heat range. REM38E is the recommended, REM40E is okay. They don't
mention for the Comanche 260(same engine as RV-10) the REM37BY extended
nose plug, which I know is approved for the same cylinders in the O-360
and IO-360. Other than fine wire plugs, it would be the most resistant
to fouling.
linn wrote:
> And if you still have a problem with fouling plugs put *REM 39s* in
> the lower holes.
> Linn
I did switch to fine wires at something just under 200 hours.
They work well. The massive electrode ones ran well for me.
With aggressive leaning, I've never had to miss a takeoff for
fouled plugs. But, the fine wires stay cleaner. The others
were fine although they don't last as long.
> to fouling.
>> the lower holes.
>> Linn
Yes he does. You can see a screen shot of it also on his web site
Gary Blankenbiller
RV10 - # 40674
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p=233450#233450
From: | "johngoodman" <johngoodman(at)earthlink.net> |
Has anybody tried out these Adel Clamp Pliers from Wicks? If so, are they worth
the money?
http://www.wicksaircraft.com/catalog/product_detail.php/pid=17313~subid=12123/index.html
#40572 QB Fuselage, wings finished. Finish Kit started.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=233494#233494
Subject: | TDT rises from his slumber |
From: | "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero> |
I hung around Avidyne just long enough to get my "employee discount" on
a PFD and MFD. My airplane building is a little slow, but 2009 should
be the year!
I have only observed it tangentially, but it seems my former colleagues
have not moved to support experimentals as much as I would have hoped.
They have been going after some of the certified retrofit market
instead, but now Garmin is moving in that sector, too. Hard to compete
with someone who has the amounts of cash that Garmin generates.
With the overall economy the way it is, and the OEMs cutting way back, I
can imagine it would be getting stressful. Garmin has their
home/auto/marine groups to at least diversify. (But presumably those
sectors are contracting, too.)
Did I post a W&B spreadsheet? It shouldn't be password-protected.
Somebody point me to it and I'll check it out. Or was it someone else?
TDT
Tim Dawson-Townsend
Aurora Flight Sciences
tdt(at)aurora.aero
617-500-4812 (office)
617-905-4800 (mobile)
If any one needs good aircraft hardware go to JCAero.com. He has anything
and everything you need if it is not on his web site give him a call and we
will have it or he can order it. I get all my hardware from him and he is
way cheaper then the other places.
But I can drive right up to his shop and get anything I need on a moments
notice.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
Washington State.
It's not a graph per se, but the EFIS does do the calculations with
current fuel and zero fuel to let you know if the CG will move out of
range. They do show a CG line along with CG limit lines and change
the colors (green = OK, Red = You really should not do that!).
It's really nice to load up and just dial in the numbers to know you are
good to go. Although try asking a couple of ladies what their weight
is! Should you guess? How lucky do you feel today? Most of the
men don't mind
Food for thought!
Jim C
N312F /
40192 - Flying (Phase I - COMPLETE!) - Installing the AFS autopilot
servo's now
"orchidman"
Yes he does.
Gary Blankenbiller
RV10 - # 40674
Engine,
Fiberglass - SB
(N2GB registered)
Read
this topic online here:
- The RV10-List Email Forum -
Features Navigator to browse
Un/Subscription,
Chat, FAQ,
--> http://www.matronics.com/Navigator?RV10-List
- MATRONICS WEB FORUMS -
available via the Web Forums!
- List Contribution Web Site -
generous support!
Admin.
I do agree with leaning during taxi. But also spend the big bucks and get a
set of fine wire plugs they will last almost the full life of the engine and
are not as apt to fowl if you forget to lean. Once we did that in the
IO540K series engine we have had perfect run ups with and with out leaning.
When I do the engine on the 10 it will for sure have the fine wire p[lugs in
it. I also like the looks of the g3 mfd electronic ignition system that
will work on either bendix or slick mages.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Thursday, March 05, 2009 1:57 PM
the runway.
wrote:
> Jason;
the
As
> started.
> Dr Fred.
What
just
>> #40617 N44YH
>> Sheboygan Falls, WI
>> (4) Partner Build
>> Jason Kreidler
>> Kyle Hokel
>> Tony Kolar
>> Wayne Elsner
Wow I wish I had a set of those when I did the engine overhaul on the
Saratoga. I have a hard rule no tie wraps in the engine compartment just
clamps as needed and wires tied with the proper wire string as needed.
The engine looks perfect and everything is secure.
John G. Cumins
40864 horz stab priming
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman
Sent: Friday, March 06, 2009 11:40 AM
Subject: RV10-List: Adel Pliers
worth the money?
3/index.html
N711JG reserved
Subject: | Page 9-15 Step 7, Trim cable attachment question |
From: | John Trollinger <john(at)trollingers.com> |
So I bought the after market trim cable attachment brackets from
Cleavland tools and am ready to assemble. The vans instructions say
to use a LP4-3 to put the pieces together. The aftermarket bracket is
pretty thick and I was thinking about dimpling the WD-415 and then
countersinking the bracket to accept the dimple and then using an
AN-426 and back rivet it together.
Just wanted to get some group feedback on my plan and see what others
using these brackets have done.
thanks,
John Trollinger
Builder 40923
Subject: | New Hartzell Available |
Anyone notice this this week?
http://www.aopa.org/aircraft/articles/2009/090305hartzell.html?WT.mc_id0306epilot&WT.mc_sect=gan
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1236378475-338-27&browse=props&product=csprop-hartzell
At over 15k it must be heated and add 15kts. Sheesh
Rob, did you ever get time to make any runs with the prop?
Michael
No. However a simple piece of hacksaw blade and your pencil grinder can
make an Adel lock tool which is easy to install, easy to remove and just
plain slick. Discarded Medical Forceps work on the cheap.
If you are doing triple stacked or quad stacked Adels for a living then
maybe the tool will prove itself.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of johngoodman
Sent: Fri 3/6/2009 11:39 AM
they worth the money?
=12123/index.html
N711JG reserved
Subject: | Re: New Hartzell Available |
2.5 times the price of the two blade aluminum is nuts!
At AOPA last November I was given the scoop from a source within Hartzell
that the two blade is the best blade for the RV-10, he suggested I get the
blade balanced and I would have everything that the three blade would offer
except the looks and maybe a slight decrease in climb performance, but with
the RV-10 the climb would still outpace another three bladed plane anyway,
he saw I was married and knew I wasn't looking to impress any women along my
travels and hence told me to stick with the 2 blade.
Interesting thing is my wife wanted a 3 blade but changed her mind when I
mentioned the difference in price.
But that is nice looking blade!
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Sent: Friday, March 06, 2009 2:31 PM
Subject: RV10-List: New Hartzell Available
> Michael
First positive today was the news that Rob's prop is now VAN approved
for the rest of us. The second was the picture of Robin's panel and the
third is word from Phoenix (Deer Valley)- that we are ALL waiting for.
So I am listening with anticipation and have a foot that is hoping like
a rabbit that another Barrett / Forsling / James Fire Breather "Chunky
Monkey" is ready for launch into the heavens.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of RV Builder
(Michael Sausen)
Sent: Fri 3/6/2009 2:31 PM
http://www.aopa.org/aircraft/articles/2009/090305hartzell.html?WT.mc_id=
090306epilot&WT.mc_sect=gan
Michael
Subject: | Re: Page 9-15 Step 7, Trim cable attachment question |
Back in December, when I disassembled the airplane for the paint
shop, I decided to attach them with nutplates for the re-assembly. It
was a real bear to get the trim cable panels off with the brackets
riveted on. I believe others have done this, as well.
David Maib
40559
flying
thanks,
John Trollinger
Builder 40923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I dimpled the access panels and machine counter sunk the brackets to use
AN 426AD4-5? Don't remember the length...just used rivet gage for
whatever worked on that combination. Comes out nice to have flush rivets
to keep bottom of plate smooth. As mentioned, an alternative would be to
rivet nut plates to the brackets and use countersunk screws to hold them.
> thanks,
> John Trollinger
> Builder 40923
Subject: | Another Milestone |
Well today marked another pretty big milestone for me. Gary Towner (DAR)
drove down from Overgaard today, and performed an inspection of N519PJ.
Gary had all of the parperwork ready, except for the affidavit, that I
had to have notarized, and we began by completing the required forms.
Made appropriate entry in my (new) Airframe log book, and then we moved
to the inspection. Gary's primary focus and concern was the flight
controls. we began inside of the cockpit, and then proceeded outside to
all of the flight surfaces and connections. His next stop was the
firewall forward area. I pointed out to him one item I noticed
yesterday, where I hadn't sealed (RTV) a firewall passthrough. Gary
spent about 1 1/2 hours on the inspection, and didn't note any squawks.
We moved back to finalize the A/W certificate, and went through the Ops
Limitations. Gary gave me a REALLY big Phase 1 test area. Essentially
DVT to Kingman, to Laughlin (Colorado River) down the river to Parker
then SouthEast all the way to Casa Grande, then back west of PHX
(Goodyear, Glendale) and back to DVT. Gary helped walk me through the
repairmans cert application, and then handed me the A/W cert and the Ops
Lim and made the official entry in the Airframe logbook.
1st flight will occur as soon as the FAA sends my medical. My AME said
to expect May1 :'(
http://deemsrv10.com/album/Final%20Assembly/slides/DSC07403.html
Deems Davis # 406
'Its all done............ period!
Subject: | Re: Another Milestone |
Congratulations Deems! Great news! Now if OKC will just move along
smartly for you............................
David Maib
(DAR) drove down from Overgaard today, and performed an inspection of
N519PJ. Gary had all of the parperwork ready, except for the
affidavit, that I had to have notarized, and we began by completing
the required forms. Made appropriate entry in my (new) Airframe log
book, and then we moved to the inspection. Gary's primary focus and
concern was the flight controls. we began inside of the cockpit, and
then proceeded outside to all of the flight surfaces and connections.
His next stop was the firewall forward area. I pointed out to him one
item I noticed yesterday, where I hadn't sealed (RTV) a firewall
passthrough. Gary spent about 1 1/2 hours on the inspection, and
didn't note any squawks. We moved back to finalize the A/W
certificate, and went through the Ops Limitations. Gary gave me a
REALLY big Phase 1 test area. Essentially DVT to Kingman, to Laughlin
(Colorado River) down the river to Parker then SouthEast all the way
to Casa Grande, then back west of PHX (Goodyear, Glendale) and back
to DVT. Gary helped walk me through the repairmans cert application,
and then handed me the A/W cert and the Ops Lim and made the official
said to expect May1 :'(
Deems Davis # 406
John, I would love to know more about the hacksaw blade/pencil grinder adel clamp
tool. Sounds intriguing!
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=233544#233544
From: | "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> |
> David Maib
> RV-10 #40559
My guess is a slot cut in a short piece to lock the two halves together.
Inquiring minds want to know.
Dr Fred.
From: | "Byron Gillespie" <bgill1(at)charter.net> |
Congrats Deems...
Many of us have been following along with the build and very excited for
you - Keep it up!
Byron
N253RV assigned - Just need to get it all finished!
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis
Sent: Friday, March 06, 2009 8:30 PM
Subject: RV10-List: Another Milestone
to expect May1 :'(
Deems Davis # 406
Deems=2C congrats on your passing the DAR inspection. I went thru the same
exercise 3 weeks ago. Passed without any real squawks. I too have a medi
cal issue with OKC and am waiting on their approval. My AME was a jerk abo
ut my medical this time=2C so he shipped it to OKC without even telling me.
I have a BP problem according to him. This was in November and I've lost
nearly 25 lbs since and my blood pressure is down below FAA maximums. I'v
e jumped thru hoops with my internist since then and now am waiting for FAA
approval on my medical. Bud Warren has been my test pilot for N730WL. He
flew the first flight last week. And I can't wait to fly my LS1 powered R
V10. Hope to meet you soon at Oshkosh??
Regards=2C
Bill Gipson
N730WL
> Date: Fri=2C 6 Mar 2009 18:29:48 -0700
> From: deemsdavis(at)cox.net
> To: rv10-list(at)matronics.com
> drove down from Overgaard today=2C and performed an inspection of N519PJ.
> Gary had all of the parperwork ready=2C except for the affidavit=2C that
I
> had to have notarized=2C and we began by completing the required forms.
> Made appropriate entry in my (new) Airframe log book=2C and then we moved
> controls. we began inside of the cockpit=2C and then proceeded outside to
> yesterday=2C where I hadn't sealed (RTV) a firewall passthrough. Gary
> spent about 1 1/2 hours on the inspection=2C and didn't note any squawks.
> We moved back to finalize the A/W certificate=2C and went through the Ops
> DVT to Kingman=2C to Laughlin (Colorado River) down the river to Parker
> then SouthEast all the way to Casa Grande=2C then back west of PHX
> (Goodyear=2C Glendale) and back to DVT. Gary helped walk me through the
> repairmans cert application=2C and then handed me the A/W cert and the Op
s
> to expect May1 :'(
> Deems Davis # 406
Windows Live=99: Life without walls.
http://windowslive.com/explore?ocid=TXT_TAGLM_WL_allup_1a_explore_032009
Congratulations Deem! I guess you have time to do a few more modifications. 8>)
> drove down from Overgaard today, and performed an inspection of N519PJ. Gary
> repairmans cert application, and then handed me the A/W cert and the Ops Lim
> 1st flight will occur as soon as the FAA sends my medical. My AME said to
> expect May1 :'(
> Deems Davis # 406
From: | Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> |
Subject: | Re: Installing Hartzell prop on IO540 |
I ended up drilling a hole, taping it, and using a screw through a piece
of scrap to pull the plug out. I tried prying the cap out using tools
thru the hole. That didn't work.
There is a rear plug installed that seals this section of the crank. A
shaft with a cut-out in it is installed across the mouth of the hollow
crank which must be where the oil enters/exits the crank.
Thanks for the help all.
> Does the metal cup pressed into the end of the crank have to be removed
> before installation of the constant speed prop?
> I assume that cup is in place for fixed pitch props. But I can't find a
> specific reference to the need or procedure for removing it in the
> documentation. Even reading the procedure for changing between constant
> speed and fixed configurations doesn't directly address removal of the metal
> cup.
> Thanks in advance
> Bill
I use a small pair of hemostats to hold the andel clamp closed. You can
usually pick them up at a flea market of fly mart for a couple of bucks.
Larry Rosen
the money?
> John
> N711JG reserved
From: | "Bob and Karen Brown" <bkbrown(at)minetfiber.com> |
I know how that all feels...and it all feels good. Congratulations Deems.
Bob Brown
Sent: Friday, March 06, 2009 5:30 PM
to expect May1 :'(
Deems Davis # 406
Hemostats and a tapered punch are hard to beat.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen
Sent: Friday, March 06, 2009 8:00 PM
Subject: Re: RV10-List: Adel Pliers
Larry Rosen
worth the money?
3/index.html
> John
> N711JG reserved
AirMike,
There are many ways to lock a bolt in place and there is nothing wrong with the
tabs that were sent with the kit. They work fine and are a recognized way of
safetying a bolt to prevent backing out. So is staking but bent tabs are much
easier for homebuilders. Often times it is not practical to safety wire and
this is a good substitute. Of course you can only use it once.
You can replace it with a drilled head/safety wire combo if you like, but it is
not correct to say it is "dangerous".
Dave Moore
RV-6 flying
RV-10 QB - cabin top/fiberglass hell
http://forums.matronics.com/viewtopic.php?p=233566#233566
John,
I drilled my aftermarket trim cable attachments with a 6-32 tap drill
,counter sunk the bracket, dimpled the cover and attached them with
stainless steel 6-32 screws.
Much easier to adjust.
Joe
Sent: Friday, March 06, 2009 4:27 PM
Subject: RV10-List: Page 9-15 Step 7, Trim cable attachment question
> thanks,
> John Trollinger
> Builder 40923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This has come up before. Vic did a test next to the Van's plane
(attached) and I took away that the higher HP 3 blade still was slower
than the Van's 2 blade, Rob did a preliminary, if I recall, and it too
was slower than a 2 blade, Hartzell has told me outright that the 2
blade is faster than the composite three blade.
Three is more "sexy" but when it comes to performance at this point the
2 blade is the best value for the dollar.
Pascal
Sent: Saturday, March 07, 2009 9:32 AM
Subject: RE: RV10-List: New Hartzell Available
Jim, you could do a big favor to the experimental market by lobbying
Gert to allow custom blade paint on the MTs. Nothing against White
Blades, Black Blades, Grey blades but boy do the American
Propeller paint jobs get my juices flowing. Some RV-10s just look fast
standing on the ramp next to a G-IV.
I am sure Aerocomp blades would sell as many in stock "restricted" bland
paint colors but those finished blades are prettier in my eyes and
impact marketing= Sales. Enough so that money must be budgeted a
little tighter than I had planned originally.
And isn't it tragic that not one "Head to Head" has been done in all
this time. 190 finished, flying RV-10s, nearly 1,000 kits sold and Not
Hartzell, Nor MT nor Aerocomp will take the gauntlet. Rob, I understand
your timeline priorities on great new AFS products have distracted you,
but many are leaning into the prevailing winds to hear more on Field
Tests of the Hartzell ASC-II.
lessdragprod(at)aol.com
Sent: Saturday, March 07, 2009 9:08 AM
Subject: Re: RV10-List: New Hartzell Available
Just a point of clearification here. Michael's 3 blade MT propeller was
a new propeller available for comparison flight testing on a flying
RV-10 with a 2 blade hartzell. With no takers in over a year, I sold
the propeller to Michael.
I have new RV-10 3 blade MT propellers available for $9,890 delivered
assembled to your closest international airport. 13" or 14" spinner
included.
Standard colors are Red, White, Grey, Black and Yellow for the blades,
blade tips and spinner.
Grey with White tips is recommended for IFR aircraft.
Black with Yellow tips was the old CAA required blade colors.
As a special offer, White blades with Red, White and Blue tips is
available.
A Hi-Glo spinner (looks like polished aluminum) is available for an
extra $450.
Sorry if this offens the SPAM sensitive. Just real prices.
Please contact me off line, or directly at the phone numbers below, if
you desire additional information.
Jim Ayers
jim(at)lessdrag.com
Less Drag products, Inc - Located in California (805) 795-5377
Custom Aircraft Propeller - Located in Florida (321) 441-3544
From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
Sent: Sat, 7 Mar 2009 8:14 am
I have to disagree, my new 3 blade MT was under 9k with 14=9D
spinner, assembly, and shipping. You don=99t pay extra for a
14=9D spinner with MT. I did get a bit of a price break because
it was one that someone had ordered and then backed out on but this was
only a couple months ago.
Michael
=EF=BD=EF=BD~=EF=BD=EF=BD,=03g=EF=BD=EF=BD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From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
HARD HEADED? No way!
Dean ;)
PS: Why is $$ still an issue when building an RV?
Criminal Lawyers - Click here.
http://thirdpartyoffers.juno.com/TGL2131/fc/BLSrjnsMx6xCaygWtCqZeqmjGzEx
4BrbqCZ9EsN3WmNp0Xky6vospv1OnVO/
From: | "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> |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Subject: | rear window install |
I've been working on our canopy and overhead console and now have it
ready for final installation on the fuselage. Looking ahead, the plans
call for installing the rear windows after the canopy is permanently
installed. Has anyone done the rear window install with the canopy
off the fuselage?
The benefits seem to be :
1) a lot more clamping capability
2) the canopy can be turned so gravity is your friend with respect to
dealing with the Weld-on.
Thoughts and comments would be appreciated,
Bob Newman
40176
Subject: | Re: rear window install |
HEY BOB,
I'M FINISHING UP MY OVERHEAD AND DOING SMOOTH PRIMING, FILLING ALL THE PIN
HOLES, AS FOR INSTALLING REAR WINDOWS I'M WITH YOU ON INSTALLING ON BENCH,
GRAVITY DOES HELP WITH THE GOO. THATS THE WAY I WILL DO MY REAR WINDOWS, SOME
OTHERS HAVE DONE THIS AS WELL.
DAVE
#40466, CENTRAL NJ
In a message dated 3/7/2009 4:46:21 P.M. Central Standard Time,
rnewman(at)tcwtech.com writes:
I've been working on our canopy and overhead console and now have it ready
for final installation on the fuselage. Looking ahead, the plans call for
installing the rear windows after the canopy is permanently installed. Has
anyone done the rear window install with the canopy off the fuselage?
Bob Newman
40176
(http://www.matronics.com/Navigator?RV10-List)
(http://www.matronics.com/contribution)
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
%3D62%26bcd%3DfebemailfooterNO62)
I can't wait to have that same smile on my face. Great airplane Deems.
Geoff
Build QB RV-10 N829GW
http://forums.matronics.com/viewtopic.php?p=233631#233631
From: | "Evan & Tania" <etandrews(at)westnet.com.au> |
Fantastic photo and result Deems!
Evan & Tania Andrews
40379 Flying
[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Deems Davis
Sent: Saturday, 7 March 2009 11:30 AM
to expect May1 :'(
Deems Davis # 406
E-mail message checked by Spyware Doctor (6.0.0.386)
Database version: 5.11910
http://www.pctools.com/en/spyware-doctor-antivirus/
From: | "Bill Schlatterer" <billschlatterer(at)sbcglobal.net> |
How about these,... if you don't have several straight and curved hemostats,
you are missing a couple of great tools. About $4 at Dollar General. You
can also use them to hold small nuts and washers very effectively.
Bill S
7a finishing
Sent: Friday, March 06, 2009 1:40 PM
worth the money?
3/index.html
N711JG reserved
Subject: | Flightline AC system for sale |
I have a complete 14 volt Flightline system for an RV10 I will no longer be installing
in my project. System is complete with overhead console for lighting and
vents, compressor, condensor, evaporator, two groove starter ring gear with
alt/compressor belts, all mounting hardware, all ductwork and hoses, fittings,
crimping tool for hoses. $5200 plus freight.
Dave Ford
RV6 flying
RV10 constructing
rvdave(at)centurytel.net
http://forums.matronics.com/viewtopic.php?p=233650#233650
From: | Don McDonald <building_partner(at)yahoo.com> |
Although not flying yet.... here's what I can tell you all about the MT 3 b
lade..... For out first start we put a camcorder on a tripod and filmed the
entire sequence.=C2- One thing I noted... novice here... I was told to e
xpect quite a bit of rocking motion on start and shut down.... because the
camera was mounted on the tripod, it was really easy to study any movements
made by the plane or the engine during start, running and shut down.=C2-
To my surprise, there was almost NO movement at all during any of these 3
phases.=C2- I reviewed the recording multiple times, especially the shutd
own, and was amazed how smooth it was.=C2-=C2-=C2- Yesterday I watche
d an RV7 run up the engine in prep for his first flight the following day.
=C2- On shut down, I couldn't believe how violent the rocking motion was.
=C2- I know this is only a 4 cyl engine, but certainly there was a huge d
ifference.=C2- I simply purchased the 3 blade because I was pretty sure t
he overall vibration would
be=C2-curtailed quite a bit.... very smooth.
My 2 cents worth.
Don McDonald
=C2-
=C2-
Today I watched a first flight of an RV7
Date: Saturday, March 7, 2009, 9:57 AM
This has come up before. Vic did a test next to the Van's plane (attached)
and I took away that the higher HP 3 blade still was slower than the Van's
2 blade, Rob did a preliminary, if I recall, and it too was slower than a 2
blade, Hartzell has told me outright that the 2 blade is faster than the c
Three is more "sexy" but when it comes to performance at this point the 2 b
Pascal
Jim, you could do a big favor to the experimental market by lobbying Gert t
o allow custom blade paint on the MTs.=C2- Nothing against White Blades,
Black Blades, Grey blades but boy do the American Propeller paint
jobs get my juices flowing.=C2- Some RV-10s just look fast standing on th
=C2-
I am sure Aerocomp blades would sell as many in stock "restricted" bland pa
int colors but those finished blades are prettier in my eyes and impact mar
keting= Sales.=C2- Enough so that money must be budgeted a little tight
=C2-
And isn't it tragic that not one "Head to Head" has been done in all this t
ime.=C2- 190 finished, flying RV-10s, nearly 1,000 kits sold and Not Hart
zell, Nor MT nor Aerocomp will take the gauntlet.=C2- Rob, I understand y
our timeline priorities on great new AFS products have distracted you, but
many are leaning into the prevailing winds to hear more on Field Tests of t
he Hartzell ASC-II.
=C2-
=C2-
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m
atronics.com] On Behalf Of lessdragprod(at)aol.com
=C2-
Just a point of clearification here.=C2- Michael's 3 blade MT propeller w
as a new propeller available for comparison=C2-flight testing on=C2-a f
lying RV-10 with a 2 blade hartzell.=C2- With no takers in over a year, I
sold the propeller to Michael.
I have new RV-10 3 blade MT propellers available for $9,890 delivered assem
bled to your closest international airport.=C2- 13" or 14" spinner includ
ed.
Standard colors are Red, White, Grey, Black and Yellow for the blades, blad
e tips and spinner.
As a special offer, White blades with Red, White and Blue tips is available
A Hi-Glo spinner (looks like polished aluminum) is available for an extra $
450.
Sorry if this offens the SPAM sensitive.=C2- Just real prices.
Please contact me off line, or directly at the phone numbers below, if you
Jim Ayers
jim(at)lessdrag.com
=C2- I have to disagree, my new 3 blade MT was under 9k with 14=9D
spinner, assembly, and shipping.=C2- You don=99t pay extra for a 14
=9D spinner with MT.=C2- I did get a bit of a price break because i
t was one that someone had ordered and then backed out on but this was only
=C2-
Michael
=C2-=EF=BD=EF=BD~=EF=BD=EF=BD,g=EF=BD=EF=BD =0A=0A=0A
I am really surprised at the debate over whether a 2 or 3 blade is more efficient.
Unless there is some defect in the design a 2 blade will always win. In
fact if you could make a one blade prop it would beat the 2 blade, though keeping
vibration in check would be a problem. It's because each blade can't get
completely out of the way of the turbulence of the preceding blade. Composite
vs. Al blades seems to be neutral question. While many claim some magical efficiency
with composites I think experience has show that to be pure marketing.
Three blades win out on ground clearance and tend to run smoother. Then there
is the "look". I relate the debate to the tip up vs. slider canopy decision for
the RV-6/7. Go with whatever floats your boat.
Personally I'm sticking with the 2 blade. With the 3 blade composite at twice
the price and slower it is a no brainer for me.
Dave Moore
RV-6 flying
http://forums.matronics.com/viewtopic.php?p=233681#233681
One thing I forgot to mention.... I was playing John Kerry over this issue,
and what changed my mind was the comments from Greg Nelson.- He-retire
d a year ago from the Air Force, where he flew U2's, he now test flies them
for Lockeed down in Palmdale.- This being said to let everyone know that
he pretty much knows what he's talking about.- He flies a Rocket, with a
lmost exactly the same motor I have (both from Performance Engines).- He
changed from a Hartzell 2 blade to a 3 blade MT.- BTW he has competed in
several of the Reno races.- Although it's a different plane, it was the
-SAME plane with 2 of the props in question.- He observed a small decre
ase in top airspeed, something in the 2-4 knot range, with takeoff and clim
b very comparable.-
In my previous life I used to race.... stuff on the ground,,,, -and anyth
ing that could/would reduce vibration was a good thing.- If it's smoother
for the occupant, it's also smoother for the motor, the avionics, and the
entire rest of the airplane.
Ok, that's probably a total of-my 5 cents worth.
Don McDonald
#40636
Awaiting my ticket and the FAA ticket-
--- On Sun, 3/8/09, nukeflyboy wrote:
Subject: RV10-List: Re: New Hartzell Available
Date: Sunday, March 8, 2009, 5:38 AM
icient.- Unless there is some defect in the design a 2 blade will always
win.- In fact if you could make a one blade prop it would beat the 2 blad
e, though keeping vibration in check would be a problem.- It's because ea
ch blade can't get completely out of the way of the turbulence of the prece
ding blade.- Composite vs. Al blades seems to be neutral question.- Whi
le many claim some magical efficiency with composites I think experience ha
Three blades win out on ground clearance and tend to run smoother.- Then
there is the "look".- I relate the debate to the tip up vs. slider canopy
decision for the RV-6/7.- Go with whatever floats your boat.
Personally I'm sticking with the 2 blade.- With the 3 blade composite at
twice the price and slower it is a no brainer for me.
Dave Moore
RV-6 flying
le, List Admin.
=0A=0A=0A
I recently learned a little more about vibration.? There is a 1/2 P vibration which
is 1/2 of the engine RPM.? This is a vibration that can not be removed by
balancing.? Neither static nor dynamic balancing affect the 1/2 P vibration.?
It is a characteristic of the engine and propeller and probably other factors.
At 2400 RPM, the direct frequency (1 P) is 40 hz.? (2400RPM/60seconds per minute=40Hz)
The 1/2 P would be 20 Hz.
How would you determine the 1/2 P vibration in your aircraft?? The next time you're
flying along, rest your head against the airframe.
What is the significancy of the 1/2 P vibration?? It is the environment that your
instrument panel is expected to exist in.
In dynamic balancing the engine and propeller, the higher frequencies are balanced
out to less than 0.04 IPS.
The only numbers I have for 1/2 P are from cessna 182 STC flight test data.
With a Hartzell propeller, the 1/2 P vibration level was 1.2 IPS.
With a McCullogh propeller, the 1/2 P vibration level was 0.8 IPS.
With the STC?MT Propeller, the 1/2 P vibration level was 0.2 IPS.
It would be interesting if someone could ride in various RV-10's, and get a "feel"
:-) for this with both 2 blade and 3 blade propellers.? Preferably in two,
or more, with each propeller.
Jim Ayers
HR2 -?configured for 15,000' to 17,500' cruise altitude.? 4 blade MT Propeller.
Lycoming peak torque occurs at 2200 RPM.
Sent: Sun, 8 Mar 2009 10:01 am
Subject: Re: RV10-List: Re: New Hartzell Available
One thing I forgot to mention.... I was playing John Kerry over this issue, and
what changed my mind was the comments from Greg Nelson.? He?retired a year ago
from the Air Force, where he flew U2's, he now test flies them for Lockeed down
in Palmdale.? This being said to let everyone know that he pretty much knows
what he's talking about.? He flies a Rocket, with almost exactly the same motor
I have (both from Performance Engines).? He changed from a Hartzell 2 blade
to a 3 blade MT.? BTW he has competed in several of the Reno races.? Although
it's a different plane, it was the?SAME plane with 2 of the props in question.?
He observed a small decrease in top airspeed, something in the 2-4 knot range,
with takeoff and climb very comparable.?
In my previous life I used to race.... stuff on the ground,,,, ?and anything that
could/would reduce vibration was a good thing.? If it's smoother for the occupant,
it's also smoother for the motor, the avionics, and the entire rest of
the airplane.
Ok, that's probably a total of?my 5 cents worth.
Don McDonald
#40636
Awaiting my ticket and the FAA ticket?
I am really surprised at the debate over whether a 2 or 3 blade is more efficient.?
Unless there is some defect in the design a 2 blade will always win.? In
vibration in check would be a problem.? It's because each blade can't get
completely out of the way of the turbulence of the preceding blade.? Composite
vs. Al blades seems to be neutral question.? While many claim some magical efficiency
Three blades win out on ground clearance and tend to run smoother.? Then there
is the "look".? I relate the debate to the tip up vs. slider canopy decision for
the RV-6/7.? Go with whatever floats your boat.
Personally I'm sticking with the 2 blade.? With the 3 blade composite at twice
Dave Moore
RV-6 flying
--> httphttp://forums.matronics.com/" target=_blank>http://forums.matronics.com
I put my rear windows in with the top on the aircraft but only temporaril
y affixed. Once they had cured for a week or so I took the top back off to
do some of the fit and finish work. So far no problems noticed but I'll k
now in a couple weeks when I put the top back on for good.
Michael
atronics.com] On Behalf Of Bob-tcw
Sent: Saturday, March 07, 2009 4:42 PM
Subject: RV10-List: rear window install
Has anyone done the rear window install with the canopy off the fuselage?
2) the canopy can be turned so gravity is your friend with respect to deali
Bob Newman
40176
I will capture several pictures from work tonight and edit them down for
the bandwidth impaired. An Awl (from Harbor Freight), A discarded
locking medical forceps or two (they sell new ones at Harbor Freight), a
broken hacksaw blade 3" long(I have a few). The Pencil Die Grinder was
already talked about to fab the blade mod. The finished product will do
6-32, 8-32 or 10-32s in a second. For the more technical types that
would be MS21919 clamp installations.
Double or Quad stacked Adel's that are filled to capacity are lots of
fun (Like tying your shoes with gloves on). For the $86 bucks that will
buy a lot of Tall Neck Lone Stars, Coors, Sam Adams, Becks or Big Gulps.
We ran into a problem working inverted inside fuel cells and under floor
boards (blind) with just the forceps. An ole timer got out his "Poor
Boy" tool. Pictures will answer the 1,000 words that no one wants from
me.
That said, some of us are still suckers for more tools. Will answer
questions to the pictures "Offline".
John - #40600
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred
Williams, M.D.
Sent: Friday, March 06, 2009 6:15 PM
Subject: Re: RV10-List: Re: Adel Pliers
adel clamp tool. Sounds intriguing!
> David Maib
> RV-10 #40559
Dr Fred.
Subject: | Re: RV10-List Digest: 22 Msgs - 03/07/09 |
Re: Fitting rear windows with the cabin roof off the plane.
I would counsel against this.
The cabin roof is quite "floppy" off the plane. If you bond the windows in
this situation the cabin roof will invariably have a slightly different
configuration to its installed position. When you install it you will be
preloading the bonded plexiglass which is generally a bad idea.
The rear windows can be clamped in place with the cabin roof mounted by
running straps around the plane and using spacers (lengths of 2 X 4 or
similar) to apply pressure where needed.
Leo Davies
RV6A flying
RV10 gestating
Subject: | FS: RV-10 QB wing $12,500 |
I am in the process of building an RV 10 but came across a really good deal on
a Mooney. What I have for sale is a SB wing completed to the stage of a QB. Every
thing was primed with P60G2 just like a QB from vans. Also included is the
fuel senders and electric aileron trim option. This is not an old kit that has
been sitting in the garage. I started this project 10/08. The price new for
a QB wing from Van's with these options and crating is $15.5K. You can email me
at smokenjoe50(at)gmail.com for more info.
Asking $12,500.00
http://forums.matronics.com/viewtopic.php?p=233830#233830
Subject: | F 1013 Longerons |
Hi!
I am on page 29-13 step 6. All the drawings sure look like the F 1013
longerons sit on top of the F 1001J gusset at the fire wall, but when
you do this you lose the centerline of the longeron with the skin. Does
the longeron actually go under the top of the gusset?
Enjoying this section believe it or not until now. After sleeping on
this, I think that I may have drilled the longeron wrong because of a
misinterpretation of the drawing.
Rob Hunter
40432
Fuselage
Subject: | Re: F 1013 Longerons |
Rob
Longeron as per plans set on top of gusset than matched drilled with 30
drill. longeron my have to be bent in line a little more to aline with skin
holes.go back to page 29-3 and review. my skins line up perfict. good luck.
Dave
#40466 central NJ, Blm
In a message dated 3/9/2009 7:44:57 A.M. Central Daylight Time,
rwhunter(at)integra.net writes:
Hi!
longerons sit on top of the F 1001J gusset at the fire wall, but when you do this
you lose the centerline of the longeron with the skin. Does the longeron
Enjoying this section believe it or not until now. After sleeping on this,
Rob Hunter
40432
Fuselage
steps!
Hi Rob=2C
Here are some pictures of what I did. Also look ahead to page 14 for a clos
e-pu.
Vern Smith (#324 finishing)
Subject: RV10-List: F 1013 Longerons
Date: Mon=2C 9 Mar 2009 07:36:49 -0500
Hi!
I am on page 29-13 step 6. All the drawings sure look like the F 1013 long
erons sit on top of the F 1001J gusset at the fire wall=2C but when you do
this you lose the centerline of the longeron with the skin. Does the longe
=2C I think that I may have drilled the longeron wrong because of a misinte
Rob Hunter
40432
Fuselage>
Windows Live=99: Keep your life in sync. See how it works.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/9j/4AAQSkZJRgABAQEAYABgAAD/4QOaRXhpZgAASUkqAAgAAAAUAA4BAgAgAAAA/gAAAA8BAgAP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Subject: | Re: New Hartzell Available |
nukeflyboy wrote:
> I am really surprised at the debate over whether a 2 or 3 blade is more efficient.
Unless there is some defect in the design a 2 blade will always win.
There is an overview of this on the Hartzell FAQ page
<http://www.hartzellprop.com/engineering/sitelink_engine_faqs.htm>
More technical info here
<http://www.epi-eng.com/propeller_technology/selecting_a_propeller.htm>
> It's because each blade can't get completely out of the way of the turbulence
of the preceding blade.
I can see where that might be the case if the airplane were sitting
still. If it is moving through the air, however, isn't each blade of
the prop traversing an arc through the air in a shape similar to that of
a corkscrew? If this is the case, I'm not sure the blades would be
hitting turbulence from the other blades, but I'm not positive.
There is some idle chatter about this at
<http://www.rcgroups.com/forums/showthread.php?t=917956> with lots of
shared opinions... :-)
fyi
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ
http://deej.net/sportsman/ http://deej.net/kr-2/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
From: | "Paul Grimstad" <Bldgrv10450(at)comcast.net> |
Subject: | Re: F 1013 Longerons |
MessageRob
The longerons do sit on top of the gusset. I enjoyed this section a
great deal myself, even though I made my first two perfect longerons
exactly 1" short. Wait until you get to the point of attaching the skin
to the longerons over this gusset, it's a real challange.
Paul Grmstad,
RV10 450
Portland, Or.
----- Original Message -----
Sent: Monday, March 09, 2009 5:36 AM
Subject: RV10-List: F 1013 Longerons
Hi!
I am on page 29-13 step 6. All the drawings sure look like the F 1013
longerons sit on top of the F 1001J gusset at the fire wall, but when
you do this you lose the centerline of the longeron with the skin. Does
the longeron actually go under the top of the gusset?
Enjoying this section believe it or not until now. After sleeping on
this, I think that I may have drilled the longeron wrong because of a
misinterpretation of the drawing.
Rob Hunter
40432
Fuselage
Subject: | Top COMM antenna |
From: | "Michael Wellenzohn" <rv-10(at)wellenzohn.net> |
Hi guys,
I want to mount a com antenna on top.
The tape comm antenna I understand is not an option for the -10.
Now COMMANT has a veriation of models:
Which one can you suggest?
http://www.comant.com/showproduct.aspx?CN=44&SCN=59
Looking forward for your thoughts.
Cheers
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?p=234006#234006
Subject: | Re: Top COMM antenna |
Marcus
Do you have any pictures?
Best Michael
#511
http://forums.matronics.com/viewtopic.php?p=234124#234124
Michael,
I glassed a VHF comm antenna into the cowling. It is oriented vertically and
works great. More details and pictures from my previous post are located
here: http://forums.matronics.com/viewtopic.php?t=6664
-Jim
N312JE
> Hi guys,
> Cheers
> Michael
> #511
March 02, 2009 - March 10, 2009
RV10-Archive.digest.vol-ei
